RV-Archive.digest.vol-kw
June 05, 2001 - June 08, 2001
      Now that you bring it up,  "Hey new builders!  Catto IS THE place to buy
      your prop!  Catto is your one stop shop for propeller carving and spinner
      fitting.  Look no farther for the absolute best in customer service and
      support!"
      PS.  I've really got nothing against Warnke.  I know they make a fine
      product.  But if they don't return my calls, they don't get my business.  I
      don't care if they're busy or not.
      PPS.  Craig Catto had a Warnke prop in his shop that had been sent to him
      for rework.  Again, not an editorial, just an interesting fact.
      Flames welcome.
      Scott (misleading the newbies) VanArtsdalen, MCSE, CCNA
      Network Administrator
      Union Safe Deposit Bank
      209-946-5116
                      -----Original Message-----
                      From:        RVPilot4(at)webtv.net [mailto:RVPilot4(at)webtv.net]
                      Sent:        Tuesday, June 05, 2001 11:08 AM
                      To:        rv-list(at)matronics.com
                      Subject:        Re: RV-List: Last visit to Catto Props
                      I have had more experience in wood props than the average
      pilot and
                      Catto is not the last word in wood props.When Bernie  Warnke
      was alive
                      according to tests in aviation journals,he was the one to
      beat.You will
                      be hard pressed to beat Performance Propellors by Clark
      Lydick.To tell
                      all these new builders that Catto is "THE" place to buy a
      prop is
                      misleading.
                      Bob Murphy  Poplar Grove ILL. (C77)
Subject: Re: Purge Valve for Air Flow Performance FI System
Date: Jun 05, 2001
06/05/2001 05:12:24 PM Would this system be similar to the anti-vapor lock return that some builders used in order to more confidently use auto gas? There were some good messages on this about 1997 and I think an RVator article detailed it. Anyone have a feel for this installation? I'm interested in putting this on my Bendix FI if possible. BTW, I have been told several times that the best way to defeat a heat soaked FI engine is to put in a high torque starter and really turn that prop. Had an A&P demonstrate a skytech lightweight. His comment was "man you can taxi on this starter" He said it really helped with the hot-starts. Eric "Jim Norman, MD" (at)matronics.com on 06/05/2001 02:27:02 PM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RV-List: Purge Valve for Air Flow Performance FI System For those of you out there with an Air Flow Performance fuel injection system, how are you hooking up your purge valve system? More specifically, are you tapping into your tank vent line for the purge return (which is what I intend to do), and secondly, what type of control did you mount in the cocpit to turn on/off the purge system? thanks, Jim Tampa 6A ________________________________________________________________________________
Date: Jun 05, 2001
Subject: Re: RVs and diamond studs - advice to the new builders.
Well, speaking from experience. The RV was an integral part of a divorce for me. It can be a real problem if you don't watch out. Luckily for me, we worked things out, got back together, and now she helps with the airplane, and since she sees the light at the end of the runway, she's much more supportive. Key point, get them involved however you can. (just don't let them see the invoices or credit card statements! A friend of mine has a separate stash of money in an account that he uses only for airplane purposes) Also, try to have a schedule. Family time, and airplane time. Stick to it, and if you both agree to it, you shouldn't have a problem. Works for me now. Food for thought for you married guys just getting started...you have a long way to go, so don't rock the marital boat! Paul Besing RV-6A 197AB Arizona http://www.lacodeworks.com/besing First flight coming soon with the family support --- DWENSING(at)aol.com wrote: > > In a message dated 6/5/01 3:10:08 PM Eastern > Daylight Time, > jjewell(at)okanagan.net writes: > > << I suggest that you go on with the idea of keeping > the current wife >> > > I agree! She is actually very supportive of the RV > project. > However....., Rule #1. To maintain that support, do > not let project/airplane > appear to be the most important thing in ones life. > Even if it is a very > close second. We do become obsessed. > Besides, after the kit is built the strain on the > checking account really > sets in. i.e.engine, prop, prop governor, > instruments, wiring, painting etc. > I need her on my side! > Dale Ensing > 6A still finishing and building hangar to put it. > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Date: Jun 05, 2001
Subject: Re: MD-42BS Rivet Substitution
John I have a few extra. Tell me how many you need and give me your address and I will send them to you free of charge. Earl, RV4 finishing kit John Wiegenstein wrote: > > In assembling the F-690 pushrod ends I find myself short of the > specified MD-42 BS pop rivets. Hate to order just those from Van's or > Spruce ($1 for parts, $20 for shipping . . ), and haven't been able to > find a useful cross-reference chart to show what alternatives are > acceptable. Has anyone come up with same, or any other source that > would tell me what these rivets are made of/designed for, and which > other pop rivets would be acceptable in this application? Thanks in > advance! > > John and Laurie Wiegenstein > Hansville, WA > RV-6 23961 - almost ready to order finish kit . . .AND FINISHED WITH > PRIMING (woo hoo!!) > ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: Last visit to Catto Props
Date: Jun 05, 2001
I know he has also had some family matters to take care of lately. He has been pretty good getting back to me. Give him another try, especially in the evenings (Pacific time). That is his home number. I don't think he has a phone out in his shop. If you still can't get hold of him, give me a call. I'll see if I can get through to him and tell him he's making a liar out of me! -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Greg Tanner [mailto:gtanner(at)bendcable.com] Sent: Tuesday, June 05, 2001 2:15 PM To: rv-list(at)matronics.com Subject: RE: RV-List: Last visit to Catto Props Scott, I have my prop ordered with Craig. I do have trouble getting my calls returned however. I've been waiting 5 days since I last left him a message. Kevin says he's real busy so takes awhile to get to his messages. I'm trying to be patient as I'm not even close to ready for my prop but I would still like to hear from him. Greg Tanner RV-9A WINGS O-320 D1A/CATTO N80BR RESERVED -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Van Artsdalen, Scott Sent: Tuesday, June 05, 2001 2:07 PM To: rv-list(at)matronics.com Subject: RE: RV-List: Last visit to Catto Props Who said he was the last word in wood props? Not I! I did urge people to do business with him and I still do. Warnke wouldn't return my phone calls. Craig did and was very patient in helping me decide what prop I should order. Now that you bring it up, "Hey new builders! Catto IS THE place to buy your prop! Catto is your one stop shop for propeller carving and spinner fitting. Look no farther for the absolute best in customer service and support!" PS. I've really got nothing against Warnke. I know they make a fine product. But if they don't return my calls, they don't get my business. I don't care if they're busy or not. PPS. Craig Catto had a Warnke prop in his shop that had been sent to him for rework. Again, not an editorial, just an interesting fact. Flames welcome. -- Scott (misleading the newbies) VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: RVPilot4(at)webtv.net [mailto:RVPilot4(at)webtv.net] Sent: Tuesday, June 05, 2001 11:08 AM To: rv-list(at)matronics.com Subject: Re: RV-List: Last visit to Catto Props RVPilot4(at)webtv.net (BOBE.) I have had more experience in wood props than the average pilot and Catto is not the last word in wood props.When Bernie Warnke was alive according to tests in aviation journals,he was the one to beat.You will be hard pressed to beat Performance Propellors by Clark Lydick.To tell all these new builders that Catto is "THE" place to buy a prop is misleading. Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Subject: Re: Searching for...
Date: Jun 05, 2001
Ralph, This aircraft is registered to James McNeill of Greers Ferry, AR. Sorry I can't give you more because of privacy act. Mike Robertson RV-8A >From: "Ralph E. Capen" <recapen(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Searching for... >Date: Tue, 5 Jun 2001 10:10:23 -0500 > > >Hey folks, > >I'm looking for info on the owner of a Red, White and Blue RV6 that was >parked at the Cougar Landing Fly-in this past weekend with N213JM on the >tail. > >This aircraft had roll bar handles and something that looks like a >compartment or access panel forward of the canopy on the passenger side. > >I've already tried the N-Number searches but all of the sites come back >as 404's. > >Any info would be appreciated. > >Ralph Capen > > ________________________________________________________________________________
Date: Jun 05, 2001
> > For those of you out there with an Air Flow Performance fuel injection > system, how are you hooking up your purge valve system? More specifically, > are you tapping into your tank vent line for the purge return (which is what > I intend to do), and secondly, what type of control did you mount in the > cocpit to turn on/off the purge system? I guess tapping the tank vent line is ok, but that will require that you select that tank when purging, or you will dump fuel on the ground. One spark during startup could make for a bad day with a puddle of gas below. The other solution, to run the purge line into a tee in the fuel line between the tank and selector, might be a little better in that if you don't select the correct tank, you won't dump fuel overboard (unless the tank is absolutely crammed full). You also won't, however, cool the system as well if the wrong tank is selected, as it will only be a closed loop of fuel running around. The surface area on all this tubing may be adequate to cool anyway, in this case. BTW, besides cooling, the other half of the benefit of the purge valve is to remove residual pressure (stored in the engine pump diaphram) from the system, so it won't bleed through the injectors (even at idle cut off, some fuel goes through the system). To actuate this valve, I used a small push-pull knob with a center "press to move" lock button. You don't want this thing moving unintentially... I got it from Aircraft Spruce. Alex Peterson Maple Grove, MN 6A ------ http://USFamily.Net/info - Unlimited Internet - From $8.99/mo! ------ ________________________________________________________________________________
Subject: Re: Last visit to Catto Props
Date: Jun 05, 2001
Bernie Warnke has been dead for a number of years. His daugther now runs the business. ----- Original Message ----- From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> Sent: Tuesday, June 05, 2001 4:06 PM Subject: RE: RV-List: Last visit to Catto Props Who said he was the last word in wood props? Not I! I did urge people to do business with him and I still do. Warnke wouldn't return my phone calls. Craig did and was very patient in helping me decide what prop I should order. Now that you bring it up, "Hey new builders! Catto IS THE place to buy your prop! Catto is your one stop shop for propeller carving and spinner fitting. Look no farther for the absolute best in customer service and support!" PS. I've really got nothing against Warnke. I know they make a fine product. But if they don't return my calls, they don't get my business. I don't care if they're busy or not. PPS. Craig Catto had a Warnke prop in his shop that had been sent to him for rework. Again, not an editorial, just an interesting fact. Flames welcome. -- Scott (misleading the newbies) VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: RVPilot4(at)webtv.net [mailto:RVPilot4(at)webtv.net] Sent: Tuesday, June 05, 2001 11:08 AM To: rv-list(at)matronics.com Subject: Re: RV-List: Last visit to Catto Props I have had more experience in wood props than the average pilot and Catto is not the last word in wood props.When Bernie Warnke was alive according to tests in aviation journals,he was the one to beat.You will be hard pressed to beat Performance Propellors by Clark Lydick.To tell all these new builders that Catto is "THE" place to buy a prop is misleading. Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Date: Jun 05, 2001
Subject: Re: winglets
> >Builders, any RV winglet activity out there? More specifically, has anyone >either pondered or engaged in modification experiments, molding winglets >onto Van's tips? Nothing in archive. > >Jack Blomgren Minnesota Wing >8 wings, tanks I'm not aware of any RV winglet experiments. The theory says that properly designed winglets might help reduce the induced drag very slightly. But, at normal RV cruise speeds and altitudes, the profile drag is much, much greater than the induced drag, as Van has given us a clean design, that achieves a high cruise speed. So, the additional profile drag from the winglets will almost certainly be greater than any reduction in induced drag. However, there might be a benefit if you cruised at very low speed (e.g. trying to go for absolute max range), or at high altitude, where the indicated airspeeds would be lower, and the angle of attack higher. You might also achieve a slight improvement in glide performance, and angle of climb at low speed. So, if you are primarily interested in having something unique, go for it. If you really want to improve performance, I suggest you first build the aircraft without winglets. You can add winglets after you have carefully established the performance of the basic aircraft. Measure the performance enough times so that you can get repeatable results. That way you can at least determine what effect the winglets had. Good luck, -- Kevin Horton RV-8 (mounting wings) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Jun 05, 2001
In a message dated 6/5/01 2:28:03 PM Eastern Daylight Time, jnorman(at)InterMapSystems.com writes: > For those of you out there with an Air Flow Performance fuel injection > system, how are you hooking up your purge valve system? More specifically, > are you tapping into your tank vent line for the purge return (which is what > I intend to do), and secondly, what type of control did you mount in the > cocpit to turn on/off the purge system? > I'm using the AFP purge valve with the bendix system. It is tapped into the right tank main feed line just before the selector valve. An ACS A-700 locking type cable actuates it. The cable is attached to the same plate as the fuel selector valve and is placarded "Select left tank for purge operation". It works fine. The selector plate is slightly larger than original. Brian Eckstein 6A 8.6 hrs. ________________________________________________________________________________
From: "Craig Chipley" <craigchipley(at)hotmail.com>
Date: Jun 05, 2001
From my College aerodynamics we learned 1. winglets needed to be shaped like airfoils..ie camber on the fuselage side..and 2. it usually takes higher airspeeds to achieve any benefit. I did see some on a glasair in sport aviation. The benefit was from the lift vector being directed to the direction of flight, but ONLY at higher velocities. good luck..thats why there called experimental. >From: Kevin Horton <khorton(at)cyberus.ca> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: winglets >Date: Tue, 5 Jun 2001 21:19:08 -0400 > > > > > >Builders, any RV winglet activity out there? More specifically, has >anyone > >either pondered or engaged in modification experiments, molding winglets > >onto Van's tips? Nothing in archive. > > > >Jack Blomgren Minnesota Wing > >8 wings, tanks > >I'm not aware of any RV winglet experiments. > >The theory says that properly designed winglets might help reduce the >induced drag very slightly. But, at normal RV cruise speeds and >altitudes, the profile drag is much, much greater than the induced >drag, as Van has given us a clean design, that achieves a high cruise >speed. So, the additional profile drag from the winglets will almost >certainly be greater than any reduction in induced drag. However, >there might be a benefit if you cruised at very low speed (e.g. >trying to go for absolute max range), or at high altitude, where the >indicated airspeeds would be lower, and the angle of attack higher. >You might also achieve a slight improvement in glide performance, and >angle of climb at low speed. > >So, if you are primarily interested in having something unique, go >for it. If you really want to improve performance, I suggest you >first build the aircraft without winglets. You can add winglets >after you have carefully established the performance of the basic >aircraft. Measure the performance enough times so that you can get >repeatable results. That way you can at least determine what effect >the winglets had. > >Good luck, >-- >Kevin Horton RV-8 (mounting wings) >Ottawa, Canada >http://eccentrix.com/misc/rv8/rv8.html > > ________________________________________________________________________________
Date: Jun 05, 2001
Subject: winglets
> One more thing... the Tampa group of builders helped me mount my > engine this > weekend (37 minutes). We documented every step with a digital camera > and > wrote a nice, detailed, "how-to" article which will be online > tomorrow am at > Doug Reeves' site. 37 Minutes!!??!! I am green (with envy). Wish you had done that three weeks ago, then I would have had the benefit of your article on Memorial day! Oh well, got it done (1st bolt,5 minutes... 2nd bolt, 10 minutes... 3rd bolt, 30 minutes... 4th bolt, 1 1/4 hours!) Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward - having fun now! ________________________________________________________________________________
Date: Jun 05, 2001
>So, if you are primarily interested in having something unique, go >for it. If you really want to improve performance, I suggest you >first build the aircraft without winglets. You can add winglets >after you have carefully established the performance of the basic >aircraft. Measure the performance enough times so that you can get >repeatable results. That way you can at least determine what effect >the winglets had. From what I understand, it is difficult to design winglets that have a positive effect, but easy to do the opposite! Here are a couple articles that cover winglet applications on sailplanes. Not quite the same envelope as an RV, but better than nothing! These are not very in-depth for those wanting to design their own, but I believe better information might be found in Technical Soaring back issues, or more thorough web searches. http://www.engr.psu.edu/news/Publications/EPSsum00/winglet.html http://www.soaridaho.com/Schreder/Construction/Masak_Winglets.htm Good luck! Jim DG-303 Acro RV-8 Emp ________________________________________________________________________________
Subject: Shims between flap skin and FL-406's?
Date: Jun 06, 2001
George Orndorff mentioned in his PP wing kit video that we should use shims if the FL-406 flap ribs don't lay flat against the bottom flap skin after drilled and cleco'ed to the flap spar.Has anyone done this? I noticed that without slightltly pressing the ribs down there will be a gap of about 1/4". Without shims I have no doubt that everything will 'squeeze' together, but will it follow the airfoil? Are RV-8 Wings ________________________________________________________________________________
Date: Jun 05, 2001
Subject: Making it easy to jump start your RV
Listers: I am trying to figure out the best way to design an easy way to gain access to the electrical system (without getting to the battery) for emergency jump starts. My friend Jeff Sharman (Nut Tree Airport) has a product called Plug & Jump that is hard wired into his fuselage. I don't have a picture of that installation yet. Does anyone else have ideas of providing this utility? I am thinking of having on os these systems wired into my Citabria. With the battery all the way in the back of the aircraft, the starter sometimes doesnt turn over reall willingly. As the battery is way back in the rear fuselage, it is not accessable without tearing some of the interior out to get to it. Dave Aronson RV4 N504RV Cowl almost done, then it is serious electrical wiring time. ________________________________________________________________________________
Date: Jun 06, 2001
Craig, Hmm. That certainly contradicts everything I've ever read on them, and the flight test results I've seen. Do you remember which issue the article was in? I would like to contact the builder to learn more. I'm going to be on the road until Friday night, so I'll be off line til then. Kevin > >>From my College aerodynamics we learned 1. winglets needed to be shaped like >airfoils..ie camber on the fuselage side..and 2. it usually takes higher >airspeeds to achieve any benefit. I did see some on a glasair in sport >aviation. The benefit was from the lift vector being directed to the >direction of flight, but ONLY at higher velocities. good luck..thats why >there called experimental. > > >>From: Kevin Horton <khorton(at)cyberus.ca> >>Reply-To: rv-list(at)matronics.com >>To: rv-list(at)matronics.com >>Subject: Re: RV-List: winglets >>Date: Tue, 5 Jun 2001 21:19:08 -0400 >> >> >> > >> >Builders, any RV winglet activity out there? More specifically, has >>anyone >> >either pondered or engaged in modification experiments, molding winglets >> >onto Van's tips? Nothing in archive. >> > >> >Jack Blomgren Minnesota Wing >> >8 wings, tanks >> >>I'm not aware of any RV winglet experiments. >> >>The theory says that properly designed winglets might help reduce the >>induced drag very slightly. But, at normal RV cruise speeds and >>altitudes, the profile drag is much, much greater than the induced >>drag, as Van has given us a clean design, that achieves a high cruise >>speed. So, the additional profile drag from the winglets will almost >>certainly be greater than any reduction in induced drag. However, >>there might be a benefit if you cruised at very low speed (e.g. >>trying to go for absolute max range), or at high altitude, where the >>indicated airspeeds would be lower, and the angle of attack higher. >>You might also achieve a slight improvement in glide performance, and >>angle of climb at low speed. >> >>So, if you are primarily interested in having something unique, go >>for it. If you really want to improve performance, I suggest you >>first build the aircraft without winglets. You can add winglets >>after you have carefully established the performance of the basic >>aircraft. Measure the performance enough times so that you can get >>repeatable results. That way you can at least determine what effect >>the winglets had. >> >>Good luck, >>-- >>Kevin Horton RV-8 (mounting wings) >>Ottawa, Canada >>http://eccentrix.com/misc/rv8/rv8.html >> >> > > -- Kevin Horton RV-8 (mounting wings) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Subject: Re: Making it easy to jump start your RV
Date: Jun 06, 2001
> > Listers: > I am trying to figure out the best way to design an easy way to gain > access to the electrical system (without getting to the battery) for > emergency jump starts. I don't have a way to jump start; figure the ole armstrong method is good for emergencies, but I do have a way to charge the battery. I ran a fused wire directly from the battery to a cigarette lighter outlet on the panel. With a little adapter I can use this to hook up a battery charger without removing the battery cover. Works fine. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Subject: New Online Article: "An Illustrated Guide To Engine Hanging"
Date: Jun 06, 2001
Thread-Topic: New Online Article: "An Illustrated Guide To Engine Hanging" Thread-Index: AcDuhcdW9wtgUqQRQ9qtqhtGqjxJOA=
From: "Reeves, Doug" <Douglas.Reeves(at)archongroup.com>
Jim Norman submitted a wonderfully written illustrated article to me for the VAFWWW web site on how to hang your engine. From Jim, "Here is what we believe to be the best engine hanging article in existence... not that hard a claim since we can't find even a poor one! We think this method is fool-proof, and it works on all RV types. It is self explanatory. I am the principle author, but the expertise comes from 5 people, all of whom are listed as authors and should be given credit (as written in the text of the article)." Read it at http://www.vansaircraft.net . It's the top story today. Best regards as always, Doug Reeves Van's Air Force - World Wide Wing RV-6 standard kit (fuselage) ________________________________________________________________________________
Date: Jun 06, 2001
In a message dated 6/6/01 2:01:52 AM Central Daylight Time, aronsond(at)pacbell.net writes: << I am trying to figure out the best way to design an easy way to gain access to the electrical system (without getting to the battery) for emergency jump starts. >> Take a look at Michael Stewart's idea. I'm thinking of copying it for mine. His page is located here (go to "systems" and scroll down to "ramp jump"): http://www.mstewart.net/michael/rv/rvhome.htm Eric Newton - Long Beach, Mississippi RV-6A N57ME (Reserved) (Engine Cowling) http://www.ericsrv6a.com ________________________________________________________________________________
Subject: RV-4 vs. RV-8 cockpit dimensions
Date: Jun 06, 2001
In the course of deciding whether to switch from my half built RV4 to a half built RV8 QB, I couldn't find any interior cockpit dimensions for the 8. So I paid a visit to Dick Martins in April and took some measurements of his 8 - in case anyone is interested: 4 8 Width - Shoulder room Inside the rails - front 22 24.5 - rear 22 24.5 Width - total Between side walls at frt seat 26.5 31.5 Length Top of inst panel to top of frt seat back 57 58 Top of frt seat back to top of rear seat back 26 25 Bob Reiff RV4 #2546 still building Reiff Preheat Systems 262-968-2342 www.ReiffPreheat.com ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: Wives & RV costs
My wife was most important in building our RV. Everything went on the credit cards and she paid them faithfully at the end of each month. I would order, she would pay. I don't know how she did it but we never went in debt to build the RV. She also shot all the rivets in the wings and fuselage and jumps at the chance to go flying. We just finished a trip to the Bahamas and her favorite part was the flying. Gary Zilik ________________________________________________________________________________
Date: Jun 06, 2001
Larry, I installed a Piper style plug on the floor just aft of my battery, which is connected directly to the battery with a short cable about 8". I carry just a male piper style plug in the aircraft with a positive and negative lug attached to it. Jumper cables or a battery attach easilly to it, for jump starting or just charging the battery. The Female plug on the belly works great it is flush mounted with its own spring loaded door. Regards, Bill Mahoney Sherman, CT RV-6 N747W ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: Fuselage Jig
Straight lumber is a tough thing to find in these days of surface drying at mills to cut costs, however, you can find dimensional engineered lumber from various sources. Engineered lumber is very strong and very straight, it's made from chipped wood by-products. If your looking for presision lumber this is the way to go. Bill > > > > I am looking for a cutting plan that used 2 > sheets of 4x8 plywood for the > > jig and in so doing would eliminate the warping of > framing lumber. The > idea > > is to glue and screw the ripped plywood into > nominal 2x6,s and 2x4,s . > > Finishing wing. rwood(at)90641.com > > > > > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Date: Jun 06, 2001
Mine is very supportive too. Guys come over to help on the plane, and see her mowing the lawn while I'm in the barn playing with plane parts. My guests just shake their heads and wonder how I do it! :) Larry & Pam RV-8 canoe http://BowenAero.com --- Gary Zilik wrote: > > > My wife was most important in building our RV. Everything went on the > credit cards and she paid them faithfully at the end of each month. I > would order, she would pay. I don't know how she did it but we never > went in debt to build the RV. She also shot all the rivets in the wings > and fuselage and jumps at the chance to go flying. We just finished a > trip to the Bahamas and her favorite part was the flying. > > Gary Zilik > > > > > > > > ________________________________________________________________________________
Date: Jun 06, 2001
I know that. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Cy Galley [mailto:cgalley(at)qcbc.org] Sent: Tuesday, June 05, 2001 5:52 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Last visit to Catto Props Bernie Warnke has been dead for a number of years. His daugther now runs the business. ----- Original Message ----- From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> To: Sent: Tuesday, June 05, 2001 4:06 PM Subject: RE: RV-List: Last visit to Catto Props Who said he was the last word in wood props? Not I! I did urge people to do business with him and I still do. Warnke wouldn't return my phone calls. Craig did and was very patient in helping me decide what prop I should order. Now that you bring it up, "Hey new builders! Catto IS THE place to buy your prop! Catto is your one stop shop for propeller carving and spinner fitting. Look no farther for the absolute best in customer service and support!" PS. I've really got nothing against Warnke. I know they make a fine product. But if they don't return my calls, they don't get my business. I don't care if they're busy or not. PPS. Craig Catto had a Warnke prop in his shop that had been sent to him for rework. Again, not an editorial, just an interesting fact. Flames welcome. -- Scott (misleading the newbies) VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: RVPilot4(at)webtv.net [mailto:RVPilot4(at)webtv.net] Sent: Tuesday, June 05, 2001 11:08 AM To: rv-list(at)matronics.com Subject: Re: RV-List: Last visit to Catto Props RVPilot4(at)webtv.net (BOBE.) I have had more experience in wood props than the average pilot and Catto is not the last word in wood props.When Bernie Warnke was alive according to tests in aviation journals,he was the one to beat.You will be hard pressed to beat Performance Propellors by Clark Lydick.To tell all these new builders that Catto is "THE" place to buy a prop is misleading. Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Subject: Last visit to Catto Props (warning, raving lunatic a
head)
Date: Jun 06, 2001
You know, I'm probably going to start a flame war over this (won't be the first time) but I just have to get this off my chest. And please, Cy, know that this is not directed at you personally. Are you guys aware of how many emails I received blasting me for attacking Warnke props? Please read down through all the attached emails and tell me where I attacked Warnke props? You'd think I was desecrating the pantheon of RV gods. But I do not worship the RV gods. I do not worship Van's. I do not worship Warnke. Yes, Bernie Warnke makes a fine prop. Yes he has passed away. Yes his daughter now makes the props. I do not feel obligated to buy a Warnke prop just because everyone else did. You'd think I'm slapping the man in the face because I didn't buy a Warnke prop. Well I bought a Catto prop. I feel it is a good product (good enough for the sponsor of this list). I feel it was at a good price. I feel Craig was a heck of a nice guy to deal with. You guys want to buy a Warnke prop go right ahead, it will provide you years of great service. But PUH-LEASE! Don't go attacking me for taking a different direction! Sorry to expose the whole list to this rant but it would be too time consuming to respond to each of the emails I received privately. -- Scott (heretic in the temple) VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Cy Galley [mailto:cgalley(at)qcbc.org] Sent: Tuesday, June 05, 2001 5:52 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Last visit to Catto Props Bernie Warnke has been dead for a number of years. His daugther now runs the business. ----- Original Message ----- From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> To: Sent: Tuesday, June 05, 2001 4:06 PM Subject: RE: RV-List: Last visit to Catto Props Who said he was the last word in wood props? Not I! I did urge people to do business with him and I still do. Warnke wouldn't return my phone calls. Craig did and was very patient in helping me decide what prop I should order. Now that you bring it up, "Hey new builders! Catto IS THE place to buy your prop! Catto is your one stop shop for propeller carving and spinner fitting. Look no farther for the absolute best in customer service and support!" PS. I've really got nothing against Warnke. I know they make a fine product. But if they don't return my calls, they don't get my business. I don't care if they're busy or not. PPS. Craig Catto had a Warnke prop in his shop that had been sent to him for rework. Again, not an editorial, just an interesting fact. Flames welcome. -- Scott (misleading the newbies) VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: RVPilot4(at)webtv.net [mailto:RVPilot4(at)webtv.net] Sent: Tuesday, June 05, 2001 11:08 AM To: rv-list(at)matronics.com Subject: Re: RV-List: Last visit to Catto Props RVPilot4(at)webtv.net (BOBE.) I have had more experience in wood props than the average pilot and Catto is not the last word in wood props.When Bernie Warnke was alive according to tests in aviation journals,he was the one to beat.You will be hard pressed to beat Performance Propellors by Clark Lydick.To tell all these new builders that Catto is "THE" place to buy a prop is misleading. Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Date: Jun 06, 2001
Checkout http://www.aeroelectric.com/articles/grndpwr.pdf Rob Acker (RV-6, interior paint & wiring) Listers: I am trying to figure out the best way to design an easy way to gain access to the electrical system (without getting to the battery) for emergency jump starts. My friend Jeff Sharman (Nut Tree Airport) has a product called Plug & Jump that is hard wired into his fuselage. I don't have a picture of that installation yet. Does anyone else have ideas of providing this utility? I am thinking of having on os these systems wired into my Citabria. With the battery all the way in the back of the aircraft, the starter sometimes doesnt turn over reall willingly. As the battery is way back in the rear fuselage, it is not accessable without tearing some of the interior out to get to it. Dave Aronson RV4 N504RV Cowl almost done, then it is serious electrical wiring time. ________________________________________________________________________________
Date: Jun 06, 2001
David, I did exactly the same thing as Larry. I mounted mine out of site and just behind the instrument panel. I also use the outlet to trickle charge the battery if I haven't flown in a while (haven't needed to do that in a while). Another benefit is that I can use a 12v adapter to run a portable CD or MD player while flying and not burn up AA batteries. Laird RV-6, 250 hrs SoCal I don't have a way to jump start; figure the ole armstrong method is good for emergencies, but I do have a way to charge the battery. I ran a fused wire directly from the battery to a cigarette lighter outlet on the panel. With a little adapter I can use this to hook up a battery charger without removing the battery cover. Works fine. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm > > Listers: > I am trying to figure out the best way to design an easy way to gain > access to the electrical system (without getting to the battery) for > emergency jump starts. ________________________________________________________________________________
Subject: Re: "An Illustrated Guide To Engine Hanging"
Date: Jun 06, 2001
An excellent article and a great resource for all builders... thanks guys. I would like to correct the first sentence in section 3 however... I installed mine *by myself* in 45 minutes without much problem. It's not that I'm macho or especially talented, just used the proper hoist and the techniques detailed in the article. It was Christmas eve day and I wasn't about to roust any of my friends out of their nests. The point is, if you have the right engine hoist it can be done solo. Second, don't forget those cotter pins! Now here's something you might want to add to the article that I don't know the answer to. First you torque the mounting bolts, then you insert the cotter pins. If the slots in the bolt don't line up with the holes exactly (they won't), then do you tighten more, or loosen slightly? Perhaps those knowledgeable in this area could provide an answer for us, and maybe this would make a good addendum to the article. Third, after installing your engine you may want to check to see if the thrustline is level. I checked into this a bit and have posted some info on my site... http://www.rv-8.com/Engine.htm BTW, at 33 hours my engine has not sagged at all using the standard mounts... still waiting. Maybe I need to go out and pull some Gs. Randy Lervold RV-8, N558RL, 33 hrs, taking right wing off to repair tank leak www.rv-8.com Home Wing VAF > Jim Norman submitted a wonderfully written illustrated article to me for > the VAFWWW web site on how to hang your engine. > > >From Jim, "Here is what we believe to be the best engine hanging article > in existence... not that hard a claim since we can't find even a poor > one! We think this method is fool-proof, and it works on all RV types. > It is self explanatory. I am the principle author, but the expertise > comes from 5 people, all of whom are listed as authors and should be > given credit (as written in the text of the article)." > > Read it at http://www.vansaircraft.net . > It's the top story today. > > Best regards as always, > > Doug Reeves > Van's Air Force - World Wide Wing > RV-6 standard kit (fuselage) ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Engine Sag
With about 1 hour total time on my engine only by running on the ground, it seems my engine sag is very apparent. It appears to have dropped 1/4". I haven't even flown yet. Any builders notice this just from ground running? Should I shim now, or fly then shim? Paul Besing RV-6A 197AB Arizona http://www.lacodeworks.com/besing Taxi Testing ________________________________________________________________________________
Date: Jun 06, 2001
There is a photo of my external power plug that I made on Randy Lervold's web site http://www.rv-8.com/MikeRobbins.htm. Very light and cheap. My battery is on the firewall so it's easy to connect, but you could run longer wires from an aft mounted battery. Let me know if you want further details; I can email more photos. Mike Robbins RV8Q 80591 wiring (almost finished after 6 months!!) Seattle area ----- Original Message ----- From: David Aronson <aronsond(at)pacbell.net> > Listers: > I am trying to figure out the best way to design an easy way to gain > access to the electrical system (without getting to the battery) for > emergency jump starts. > Dave Aronson ________________________________________________________________________________
Date: Jun 06, 2001
Randy and Others, For those cotter pins, if you look at the torque tables there is always a range, ie. 50-70 inch-pounds. That is there for cotter pins. You torque to the lower limit then tighten up to the upper limit to make the cotter pin line up. If it won't wihin the range limits then you add a thin washer and try again. Mike Robertson RV-8A And now officially an EAA "Tech Adviser" >From: "Randy Lervold" <randy@rv-8.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Re: "An Illustrated Guide To Engine Hanging" >Date: Wed, 6 Jun 2001 08:20:38 -0700 > > >An excellent article and a great resource for all builders... thanks guys. >I >would like to correct the first sentence in section 3 however... I >installed >mine *by myself* in 45 minutes without much problem. It's not that I'm >macho >or especially talented, just used the proper hoist and the techniques >detailed in the article. It was Christmas eve day and I wasn't about to >roust any of my friends out of their nests. The point is, if you have the >right engine hoist it can be done solo. > >Second, don't forget those cotter pins! Now here's something you might want >to add to the article that I don't know the answer to. First you torque the >mounting bolts, then you insert the cotter pins. If the slots in the bolt >don't line up with the holes exactly (they won't), then do you tighten >more, >or loosen slightly? Perhaps those knowledgeable in this area could provide >an answer for us, and maybe this would make a good addendum to the article. > >Third, after installing your engine you may want to check to see if the >thrustline is level. I checked into this a bit and have posted some info on >my site... >http://www.rv-8.com/Engine.htm > >BTW, at 33 hours my engine has not sagged at all using the standard >mounts... still waiting. Maybe I need to go out and pull some Gs. > >Randy Lervold >RV-8, N558RL, 33 hrs, taking right wing off to repair tank leak >www.rv-8.com >Home Wing VAF > > > > Jim Norman submitted a wonderfully written illustrated article to me for > > the VAFWWW web site on how to hang your engine. > > > > >From Jim, "Here is what we believe to be the best engine hanging >article > > in existence... not that hard a claim since we can't find even a poor > > one! We think this method is fool-proof, and it works on all RV types. > > It is self explanatory. I am the principle author, but the expertise > > comes from 5 people, all of whom are listed as authors and should be > > given credit (as written in the text of the article)." > > > > Read it at http://www.vansaircraft.net . > > It's the top story today. > > > > Best regards as always, > > > > Doug Reeves > > Van's Air Force - World Wide Wing > > RV-6 standard kit (fuselage) > > ________________________________________________________________________________
Date: Jun 06, 2001
Subject: RV-6A project for sale
I have an RV-6A project that I am forced to abandon due to health reasons. Empenage-95% complete, wings-50% complete, Phlogiston spar, many extras, and complete tool set. If interested, please contact me off list for details. Thanks, Fred -- Fred & Carolynn Hiatt Tel: (952) 898-4328 hiattcf(at)earthlink.net Fax: (952) 898-5895 http://home.earthlink.net~hiattcf/ ________________________________________________________________________________
Date: Jun 06, 2001
Thread-Topic: RV-List: Re: "An Illustrated Guide To Engine Hanging" Thread-Index: AcDun3LcAyZOdEDgTxGVX7+q5kC9HwAADu5A
Its common practice to uses metal locknuts instead of castellated nuts/cotter pins for the engine mount bolts. Installing cotter pins can be a real pain on the lower engine mounts. Bob Japundza RV-6 N244BJ O-360C/S flying >Second, don't forget those cotter pins! Now here's something you might want >to add to the article that I don't know the answer to. First you torque the >mounting bolts, then you insert the cotter pins. If the slots in the bolt >don't line up with the holes exactly (they won't), then do you tighten more, >or loosen slightly? Perhaps those knowledgeable in this area could provide >an answer for us, and maybe this would make a good addendum to the article. ________________________________________________________________________________
Date: Jun 06, 2001
Randy Lervold wrote: > Second, don't forget those cotter pins! Now here's something you might want > to add to the article that I don't know the answer to. First you torque the > mounting bolts, then you insert the cotter pins. If the slots in the bolt > don't line up with the holes exactly (they won't), then do you tighten more, > or loosen slightly? Perhaps those knowledgeable in this area could provide > an answer for us, and maybe this would make a good addendum to the article. FWIW, what I've been doing with all my castle nuts is torquing to the low end of the range and then tightening very slightly to let the cotter pins fit. For self-locking nuts, I just torque to the high end of the range. -- Regards, Ken Balch Ashland, MA RV-8 #81125 (N118KB) just about ready to pull the wings & hang the engine groups.yahoo.com/group/BostonRVBuilders/files/ ________________________________________________________________________________
Date: Jun 06, 2001
--- Mike Robertson wrote: > > > Randy and Others, > > For those cotter pins, if you look at the torque > tables there is always a > range, ie. 50-70 inch-pounds. That is there for > cotter pins. You torque to > the lower limit then tighten up to the upper limit > to make the cotter pin > line up. If it won't wihin the range limits then > you add a thin washer and > try again. > > Mike Robertson > RV-8A > And now officially an EAA "Tech Adviser" > > > >From: "Randy Lervold" <randy@rv-8.com> > >Reply-To: rv-list(at)matronics.com > >To: > >Subject: RV-List: Re: "An Illustrated Guide To > Engine Hanging" > >Date: Wed, 6 Jun 2001 08:20:38 -0700 > > > <randy@rv-8.com> > > > >An excellent article and a great resource for all > builders... thanks guys. > >I > >would like to correct the first sentence in section > 3 however... I > >installed > >mine *by myself* in 45 minutes without much > problem. It's not that I'm > >macho > >or especially talented, just used the proper hoist > and the techniques > >detailed in the article. It was Christmas eve day > and I wasn't about to > >roust any of my friends out of their nests. The > point is, if you have the > >right engine hoist it can be done solo. > > > >Second, don't forget those cotter pins! Now here's > something you might want > >to add to the article that I don't know the answer > to. First you torque the > >mounting bolts, then you insert the cotter pins. If > the slots in the bolt > >don't line up with the holes exactly (they won't), > then do you tighten > >more, > >or loosen slightly? Perhaps those knowledgeable in > this area could provide > >an answer for us, and maybe this would make a good > addendum to the article. > > > >Third, after installing your engine you may want to > check to see if the > >thrustline is level. I checked into this a bit and > have posted some info on > >my site... > >http://www.rv-8.com/Engine.htm > > > >BTW, at 33 hours my engine has not sagged at all > using the standard > >mounts... still waiting. Maybe I need to go out and > pull some Gs. > > > >Randy Lervold > >RV-8, N558RL, 33 hrs, taking right wing off to > repair tank leak > >www.rv-8.com > >Home Wing VAF > > > > > > > Jim Norman submitted a wonderfully written > illustrated article to me for > > > the VAFWWW web site on how to hang your engine. > > > > > > >From Jim, "Here is what we believe to be the > best engine hanging > >article > > > in existence... not that hard a claim since we > can't find even a poor > > > one! We think this method is fool-proof, and it > works on all RV types. > > > It is self explanatory. I am the principle > author, but the expertise > > > comes from 5 people, all of whom are listed as > authors and should be > > > given credit (as written in the text of the > article)." > > > > > > Read it at http://www.vansaircraft.net > <http://www.vansaircraft.net> . > > > It's the top story today. > > > > > > Best regards as always, > > > > > > Doug Reeves > > > Van's Air Force - World Wide Wing > > > RV-6 standard kit (fuselage) > > > >Also, according to a friend that recently hang his engine, rv6a; he said was easier to attach the engine mount to the engine, than viceversa. When is my turn, that is what I would do.. Bert > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Subject: Re: Engine Sag
Date: Jun 06, 2001
> With about 1 hour total time on my engine only by > running on the ground, it seems my engine sag is very > apparent. It appears to have dropped 1/4". I haven't > even flown yet. Any builders notice this just from > ground running? Should I shim now, or fly then shim? > > Paul Besing > RV-6A 197AB Arizona > http://www.lacodeworks.com/besing > Taxi Testing With 33 hours I have no perceptible sag, but have only pulled 3 Gs so far. I mounted my cowling so as to allow for 3/16" sag based on others experiences, so I hope it DOES sag a bit because my prop/spinner sits a bit high right now. Randy Lervold www.rv-8.com ________________________________________________________________________________
Date: Jun 06, 2001
In a message dated 6/6/01 12:01:43 AM Pacific Daylight Time, aronsond(at)pacbell.net writes: > Listers: > I am trying to figure out the best way to design an easy way to gain > access to the electrical system (without getting to the battery) for > emergency jump starts. My friend Jeff Sharman (Nut Tree Airport) has a > product called Plug & Jump that is hard wired into his fuselage. I > don't have a picture of that installation yet. Does anyone else have > ideas of providing this utility? I am thinking of having on os these > systems wired into my Citabria. With the battery all the way in the > back of the aircraft, the starter sometimes doesnt turn over reall > willingly. As the battery is way back in the rear fuselage, it is not > accessable without tearing some of the interior out to get to it. > Dave Aronson > RV4 N504RV > Cowl almost done, then it is serious electrical wiring time. > > > Try This, go to a welding supply store and purchase the male and female plugs & sockets for a small arc welder, the female sockets are a bulkhead type and fit flush to what ever you mount them to. Then when you need a jump you insert the plugs, connect them to some jumper cables and go. When you get your engine started pull the plugs and go. Hope this helps, Tim Barnes N39TB ________________________________________________________________________________
Subject: Castellated nuts vs. metal locknuts
Date: Jun 06, 2001
> Its common practice to uses metal locknuts instead of castellated > nuts/cotter pins for the engine mount bolts. Installing cotter pins can > be a real pain on the lower engine mounts. > > Bob Japundza Bob, This is the first I have heard of this. I have yet to get a cotter pin in the lower left engine mount (#4 in the recent article). It would sure make my life easier to switch to a metal locknut. Is this substitution "sanctioned" by any reference document or is it "common practice" among field technicians? Ross RV-6A ________________________________________________________________________________
From: "Snyder, Paul J (Grandview)" <Paul_Snyder(at)lord.com>
Subject: Engine Sag
Date: Jun 06, 2001
Are your mounts oriented properly? For the O-320 and O-360 Lycoming engines the shimmed mount (with the rib in the center) is in the aft position on the top mounts and in the forward position on the bottom mounts. Paul Snyder Lord Corporation -----Original Message----- From: Randy Lervold [mailto:randy@rv-8.com] Sent: Wednesday, June 06, 2001 12:25 PM Subject: Re: RV-List: Engine Sag > With about 1 hour total time on my engine only by > running on the ground, it seems my engine sag is very > apparent. It appears to have dropped 1/4". I haven't > even flown yet. Any builders notice this just from > ground running? Should I shim now, or fly then shim? > > Paul Besing > RV-6A 197AB Arizona > http://www.lacodeworks.com/besing > Taxi Testing With 33 hours I have no perceptible sag, but have only pulled 3 Gs so far. I mounted my cowling so as to allow for 3/16" sag based on others experiences, so I hope it DOES sag a bit because my prop/spinner sits a bit high right now. Randy Lervold www.rv-8.com ________________________________________________________________________________
Date: Jun 06, 2001
Thread-Topic: RV-List: Castellated nuts vs. metal locknuts Thread-Index: AcDurBgdlso6PAluTfy1yfnMOl6zKwAAAuDQ
Hi Ross, Not too long ago at the local FBO I was looking at a factory new 172 that had locknuts instead of castle nuts...but I've seen MORE installations with locknuts than castle nuts on certified aircraft. As a matter of fact, I cannot recall seeing castle nuts on anything but RV's. Bob Japundza RV-6 N244BJ O-360C/S flying working on F1 tail kit -----Original Message----- From: Ross Mickey [mailto:rmickey(at)ix.netcom.com] Sent: Wednesday, June 06, 2001 11:40 AM Subject: RV-List: Castellated nuts vs. metal locknuts > Its common practice to uses metal locknuts instead of castellated > nuts/cotter pins for the engine mount bolts. Installing cotter pins can > be a real pain on the lower engine mounts. > > Bob Japundza >Bob, >This is the first I have heard of this. I have yet to get a cotter pin in >the lower left engine mount (#4 in the recent article). It would sure make >my life easier to switch to a metal locknut. Is this substitution >"sanctioned" by any reference document or is it "common practice" among >field technicians? >Ross >RV-6A ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Engine Sag
I'm assuming they are, because I built my cowl around the engine after it was hung. When I put my cowl on after running the engine, I noticed the sag. Paul Besing RV-6A 197AB Arizona http://www.lacodeworks.com/besing Taxi Testing --- "Snyder, Paul J (Grandview)" wrote: > (Grandview)" > > Are your mounts oriented properly? For the O-320 > and O-360 Lycoming engines > the shimmed mount (with the rib in the center) is in > the aft position on the > top mounts and in the forward position on the bottom > mounts. > > Paul Snyder > Lord Corporation > > -----Original Message----- > From: Randy Lervold [mailto:randy@rv-8.com] > Sent: Wednesday, June 06, 2001 12:25 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Engine Sag > > > <randy@rv-8.com> > > > With about 1 hour total time on my engine only by > > running on the ground, it seems my engine sag is > very > > apparent. It appears to have dropped 1/4". I > haven't > > even flown yet. Any builders notice this just > from > > ground running? Should I shim now, or fly then > shim? > > > > Paul Besing > > RV-6A 197AB Arizona > > http://www.lacodeworks.com/besing > > Taxi Testing > > > With 33 hours I have no perceptible sag, but have > only pulled 3 Gs so far. I > mounted my cowling so as to allow for 3/16" sag > based on others experiences, > so I hope it DOES sag a bit because my prop/spinner > sits a bit high right > now. > > Randy Lervold > www.rv-8.com > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Subject: Re: Castellated nuts vs. metal locknuts
Date: Jun 06, 2001
> Hi Ross, > > Not too long ago at the local FBO I was looking at a factory new 172 > that had locknuts instead of castle nuts...but I've seen MORE > installations with locknuts than castle nuts on certified aircraft. As > a matter of fact, I cannot recall seeing castle nuts on anything but > RV's. > > Bob Japundza Great News!!!!! I will get me some of these critters. I have been avoiding addressing this issue on my "to do" list since the last time I spent an hour trying to get the cotter pin in. Ross ________________________________________________________________________________
Date: Jun 06, 2001
I followed the Van's diagram exactly... triple-checked. Also, they are not Lord mounts, but rather the Barry's that Van's sells. Randy Lervold ----- Original Message ----- From: "Snyder, Paul J (Grandview)" <Paul_Snyder(at)lord.com> Sent: Wednesday, June 06, 2001 10:23 AM Subject: RE: RV-List: Engine Sag > > Are your mounts oriented properly? For the O-320 and O-360 Lycoming engines > the shimmed mount (with the rib in the center) is in the aft position on the > top mounts and in the forward position on the bottom mounts. > > Paul Snyder > Lord Corporation > > -----Original Message----- > From: Randy Lervold [mailto:randy@rv-8.com] > Sent: Wednesday, June 06, 2001 12:25 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Engine Sag > > > > With about 1 hour total time on my engine only by > > running on the ground, it seems my engine sag is very > > apparent. It appears to have dropped 1/4". I haven't > > even flown yet. Any builders notice this just from > > ground running? Should I shim now, or fly then shim? > > > > Paul Besing > > RV-6A 197AB Arizona > > http://www.lacodeworks.com/besing > > Taxi Testing > > > With 33 hours I have no perceptible sag, but have only pulled 3 Gs so far. I > mounted my cowling so as to allow for 3/16" sag based on others experiences, > so I hope it DOES sag a bit because my prop/spinner sits a bit high right > now. > > Randy Lervold > www.rv-8.com ________________________________________________________________________________
Date: Jun 06, 2001
My battery is also all the way back in the fuselage. I made up some 12" #4 wires and passed them thru the lightening holes to the empennage side of the bulkhead (empennage deck area), attached with insulated connectors. Since the empennage fairing is held on with only four screws it's easy to get to and using #4 wires allows me to either trickle charge or jump start. Much, much better than removing the baggage bulkhead and crawling back to the tail, esp. on a hot, summer, Florida day. Boyd Braem David Aronson wrote: > > > Listers: > I am trying to figure out the best way to design an easy way to gain > access to the electrical system (without getting to the battery) for > emergency jump starts. My friend Jeff Sharman (Nut Tree Airport) has a > product called Plug & Jump that is hard wired into his fuselage. I > don't have a picture of that installation yet. Does anyone else have > ideas of providing this utility? I am thinking of having on os these > systems wired into my Citabria. With the battery all the way in the > back of the aircraft, the starter sometimes doesnt turn over reall > willingly. As the battery is way back in the rear fuselage, it is not > accessable without tearing some of the interior out to get to it. > Dave Aronson > RV4 N504RV > Cowl almost done, then it is serious electrical wiring time. ________________________________________________________________________________
Date: Jun 06, 2001
Paul, I have the Barry Mounts as well and they have sagged about 1/4". The engine has been on the airframe about 1 1/2 years. I put a standard large area washer (about 1/16" thick) between the engine and the Barry mount rubber on both the lower ones, which brought it back in line with the cowl. I used bullets and it was not to difficult. Good Luck. Garry RV6 Feds here on 21st. I can't believe I'm almost done. Paul Besing wrote: > > I'm assuming they are, because I built my cowl around > the engine after it was hung. When I put my cowl on > after running the engine, I noticed the sag. > > Paul Besing > RV-6A 197AB Arizona > http://www.lacodeworks.com/besing > Taxi Testing > > --- "Snyder, Paul J (Grandview)" > wrote: > > (Grandview)" > > > > Are your mounts oriented properly? For the O-320 > > and O-360 Lycoming engines > > the shimmed mount (with the rib in the center) is in > > the aft position on the > > top mounts and in the forward position on the bottom > > mounts. > > > > Paul Snyder > > Lord Corporation > > > > -----Original Message----- > > From: Randy Lervold [mailto:randy@rv-8.com] > > Sent: Wednesday, June 06, 2001 12:25 PM > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: Engine Sag > > > > > > <randy@rv-8.com> > > > > > With about 1 hour total time on my engine only by > > > running on the ground, it seems my engine sag is > > very > > > apparent. It appears to have dropped 1/4". I > > haven't > > > even flown yet. Any builders notice this just > > from > > > ground running? Should I shim now, or fly then > > shim? > > > > > > Paul Besing > > > RV-6A 197AB Arizona > > > http://www.lacodeworks.com/besing > > > Taxi Testing > > > > > > With 33 hours I have no perceptible sag, but have > > only pulled 3 Gs so far. I > > mounted my cowling so as to allow for 3/16" sag > > based on others experiences, > > so I hope it DOES sag a bit because my prop/spinner > > sits a bit high right > > now. > > > > Randy Lervold > > www.rv-8.com > > > > > > > > through > > > > http://www.matronics.com/archives > > http://www.matronics.com/emaillists > > > > Matronics! > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 06, 2001
There are available through race car catalogs "remote" battery terminals that you could mount in a more convenient location. I bought a pair but never installed them. Be sure and use big enough wire, especially for charging. You might want to put on a in line fuse to break instead of something getting fried with a short. Mark Goldberg RV-8 N982RV 135 hrs >From: David Aronson <aronsond(at)pacbell.net> >Reply-To: rv-list(at)matronics.com >To: "rv-list(at)matronics.com" >Subject: RV-List: Making it easy to jump start your RV >Date: Tue, 05 Jun 2001 23:59:48 -0700 > > >Listers: >I am trying to figure out the best way to design an easy way to gain >access to the electrical system (without getting to the battery) for >emergency jump starts. My friend Jeff Sharman (Nut Tree Airport) has a >product called Plug & Jump that is hard wired into his fuselage. I >don't have a picture of that installation yet. Does anyone else have >ideas of providing this utility? I am thinking of having on os these >systems wired into my Citabria. With the battery all the way in the >back of the aircraft, the starter sometimes doesnt turn over reall >willingly. As the battery is way back in the rear fuselage, it is not >accessable without tearing some of the interior out to get to it. >Dave Aronson >RV4 N504RV >Cowl almost done, then it is serious electrical wiring time. > > ________________________________________________________________________________
Date: Jun 06, 2001
If you do use the metal lock nut procedure, use the reference paint so you can tell if they have moved. Anti-Sabotage paint is another name. Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Mesage ----- From: "Bob Japundza" <Bob.Japundza(at)realmed.com> Sent: Wednesday, June 06, 2001 10:48 AM Subject: RE: RV-List: Re: "An Illustrated Guide To Engine Hanging" Its common practice to uses metal locknuts instead of castellated nuts/cotter pins for the engine mount bolts. Installing cotter pins can be a real pain on the lower engine mounts. Bob Japundza RV-6 N244BJ O-360C/S flying >Second, don't forget those cotter pins! Now here's something you might want >to add to the article that I don't know the answer to. First you torque the >mounting bolts, then you insert the cotter pins. If the slots in the bolt >don't line up with the holes exactly (they won't), then do you tighten more, >or loosen slightly? Perhaps those knowledgeable in this area could provide >an answer for us, and maybe this would make a good addendum to the article. ________________________________________________________________________________
Subject: How much to paint?
Date: Jun 06, 2001
Hi all, What is a reasonable cost for a modest paint job on an RV6a? By modest I mean, one stripe running nose to tail and N numbers on a one color background. I suppose a two stage urethane is standard? Hal Kempthorne 2578 Elliot Court Santa Clara, CA 95051-1849 408.244.4984 CELL 408.230.0891 RV6a N7HK Flying 1965 Debonair for sale! see www.aerobotix.org ________________________________________________________________________________
Date: Jun 06, 2001
> If you do use the metal lock nut procedure, use the reference paint so you > can tell if they have moved. Anti-Sabotage paint is another name. > > Cy Galley Thanks, Cy. I have been using this throughout construction as it is a good reminder that the bolt has been torqued to spec. Ross ________________________________________________________________________________
Date: Jun 06, 2001
Good point! ----- Original Message ----- From: "Ross Mickey" <rmickey(at)ix.netcom.com> Sent: Wednesday, June 06, 2001 2:53 PM Subject: Re: RV-List: Re: "An Illustrated Guide To Engine Hanging" > If you do use the metal lock nut procedure, use the reference paint so you > can tell if they have moved. Anti-Sabotage paint is another name. > > Cy Galley Thanks, Cy. I have been using this throughout construction as it is a good reminder that the bolt has been torqued to spec. Ross ________________________________________________________________________________
Subject: First flight N513J
Date: Jun 06, 2001
Hi All, Just a quick note to let everyone know RV-4 Serial #1616 N513J has flown this morning by myself. flies GREAT!!! right wing just a touch heavy. Other wise what a DAY!!! Jim Baker Klamath Falls, Oregon ________________________________________________________________________________
Date: Jun 06, 2001
You might want to ensure you can document a change such as this and show a precedent somewhere. When it comes time for inspection a DAR or FAA inspector may not accept "I saw it like that on a couple of Cessna's". Mike Nellis - http://bmnellis.com Plainfield, IL RV N699BM (res) Building Flaps Stinson 108-2 N9666K > Great News!!!!! I will get me some of these critters. I have been avoiding > addressing this issue on my "to do" list since the last time I spent an hour > trying to get the cotter pin in. > > Ross > > ________________________________________________________________________________
Date: Jun 06, 2001
Torque Seal is another name. >From: "Cy Galley" <cgalley(at)qcbc.org> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: Re: "An Illustrated Guide To Engine Hanging" >Date: Wed, 6 Jun 2001 14:38:25 -0500 > > >If you do use the metal lock nut procedure, use the reference paint so you >can tell if they have moved. Anti-Sabotage paint is another name. > >Cy Galley >Editor, EAA Safety Programs >cgalley(at)qcbc.org or experimenter(at)eaa.org > >----- Original Mesage ----- >From: "Bob Japundza" <Bob.Japundza(at)realmed.com> >To: >Sent: Wednesday, June 06, 2001 10:48 AM >Subject: RE: RV-List: Re: "An Illustrated Guide To Engine Hanging" > > >Its common practice to uses metal locknuts instead of castellated >nuts/cotter pins for the engine mount bolts. Installing cotter pins can >be a real pain on the lower engine mounts. > >Bob Japundza >RV-6 N244BJ O-360C/S flying > > >Second, don't forget those cotter pins! Now here's something you might >want > >to add to the article that I don't know the answer to. First you torque >the > >mounting bolts, then you insert the cotter pins. If the slots in the >bolt > >don't line up with the holes exactly (they won't), then do you tighten >more, > >or loosen slightly? Perhaps those knowledgeable in this area could >provide > >an answer for us, and maybe this would make a good addendum to the >article. > > ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: First flight N513J
great job jim !!! keep us posted on flight testing and future trips. scott tampa ________________________________________________________________________________
Date: Jun 06, 2001
Let me jump in here. Two quick points. One...being experimental, you don't have to go by anything if you don't want in these areas. Two....Metal type lock-nuts are proven to have an equivalent level of safety so are therefore acceptable. Don't mean to sound mean, just trying to be direct to the point. Mike Robertson RV-8A >From: "Mike Nellis" <mnellis(at)peoplepc.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: Castellated nuts vs. metal locknuts >Date: Wed, 6 Jun 2001 15:47:46 -0500 > > >You might want to ensure you can document a change such as this and show a >precedent somewhere. When it comes time for inspection a DAR or FAA >inspector may not accept "I saw it like that on a couple of Cessna's". > >Mike Nellis - http://bmnellis.com >Plainfield, IL >RV N699BM (res) Building Flaps >Stinson 108-2 N9666K > > > Great News!!!!! I will get me some of these critters. I have been >avoiding > > addressing this issue on my "to do" list since the last time I spent an >hour > > trying to get the cotter pin in. > > > > Ross > > > > > > ________________________________________________________________________________
Date: Jun 06, 2001
JIm, Awesome - good job!!!! Eric Newton - Long Beach, MS RV-6A (cowling) ________________________________________________________________________________
Date: Jun 06, 2001
You love a lot of things, if you live around them, but there isn't any woman, and there isn't any horse, not any before nor any after, that is as lovely as a great airplane. And men, who love them, are faithful to them, even though they leave them for others. Man has one virginity to lose in fighters, and if it is a lovely airplane he loses it to, there is where his heart will forever be. Ernest Hemingway While Ernest Hemingway was talking about fighters and for me it was the F-4 and my soon to be flying super RV-4, i.e., the Harmon Rocket II. It doesn't take much to change the word fighter in the above poem to RV to make relevent to the members of the list. (I got this from my web site and for some reason can't unformat the automatic centering.) http://web.csusb.edu/public/grad/tgummo/home.html I did the web site several years ago and it is not been updated lately. It doesn't have any building tips but a couple of pictures of F-4s and patches, etc. Tom Gummo Apple Valley, CA ________________________________________________________________________________
Date: Jun 06, 2001
Subject: turbulence
I am interested to know people's opinions on how RV's "ride" in turbulence. I am dreaming of building a 7, and i would like to be comfortable during light IFR, especially if things were to get a LITTLE bumpy. Thanks ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: RV4-List: First flight N513J
In a message dated 6/6/01 1:19:48 PM Pacific Daylight Time, bakerje(at)kfalls.net writes: > Just a quick note to let everyone know RV-4 Serial #1616 N513J has > flown this morning by myself. flies GREAT!!! > > right wing just a touch heavy. Other wise what a DAY!!! > > Jim Baker > Klamath Falls, Oregon > > > Congrads, what an achievment Tim Barnes Meangreen N39TB (Flying) ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: turbulence
In a message dated 6/6/01 2:41:18 PM Pacific Daylight Time, vans_rv(at)yahoo.com writes: > > I am interested to know people's opinions on how RV's > "ride" in turbulence. I am dreaming of building a 7, > and i would like to be comfortable during light IFR, > especially if things were to get a LITTLE bumpy. > > Thanks > > > My opinion to the RV 4 ride in turbulence is up & down with a side to side shaking type motion. I don't fly IFR ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Jig for drilling RV-7 & 9 "AEX" trailing edges
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGAAhwDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDiFHyjHoKXFNX7o+gpwrK3ZABXmkxS7sUD JNACAGnYoGKXFRfUAA9qcMUlKBTVmAUbeaB1p1GiATHNLRilosAUUUU7MZGw5oUU48mlApWE A9KcBSYpcUgFFKKAKUDFGnUYmKTFOoxVeghFFOoxThS5u4CAUveilFPfYAFOpO9AYdM0K4Bi lA9aXpSijYBMY7GnADrigHmlwKVgExTgKUUtLVgJilApKcKrWwBgUEU7BoK0gIjSVIVxSY74 60gE56ZpRRingGncBAM0uMc0tKBTeoCD8qXvyc0Gk4zQA8HilFR08GhOwD8j60oI7cUwH2p2 KYDtwFG5T3pjZxUathumKYFgYxRTAfalMnbFJoB2aTkn2pAQacKQCbQD1oxz1paTFPdAGMdq XHtSU5QPWncAHWndTgCk2+9Az60rAH4UwoeoxT8E+lID7U1puA3eR1pRJilY1Hj3xS0AkMgz RuBqPHNBVs8UK4HOqBgfQUpFCj5R9KXFCYCAUvSlxRihtAJSigCl49KF3AAKXFFHWhhYXijN IDSkUaIAAooFLTWoADS9qMUVDAbxmlpB1pwFJxkwDFOxRil6UR03AMUYpaDVtJgIBSikyKKm wIXvThTKUGluMdk0A03JFKCD0ppaiHCkKAsG7ilpQc01uAvPalBxSZozRJIB9ApAcGnUkkAv NHWlHSimAopwpvWlHvRcB1KPc03NGRmk3YBSaYAc9acaBjNHNcA207FJil4zS1AAKcKQDNOG KHFgIeOaYSM56/SpD+BphUD2+lPYBRTsUgAApaLXAWjtRSjB607CD6iomyD1FTbR6monUE0a IYqSetPOT0XNQgHtUqMV607gKM9xing5pu0nmnKMUgFpCTnpRRz2xQ/IBQfpQpw2MU3kGlDH NCuBKcdqbSZzSZwaoB4Az0pcjHTFMD0ZPvU3YCn3pu3igmkDGqT0AMe9LmmtIq9SfwFRfaPS M4ouBhL0H0p1NX7o+gp1TqwCigUmaewDqO9MIJ6GnD1NLcB1LSfjSjmi9wExS0UVPUBcUtJm lp3AKDR3pfpSsAwZp1IOKXPFUA6ikGadSCwZ9qO1FKBQmAmKTBp+KAOaYIYKdSgUuKVrDGMu 4EUIgjGBTvpRRdiFoAoH0p4pXvsCGjNKM0uKXimmwEB5p4Pam4o6GmA/ODRnn1pPrS0DHg80 tNQepFPpJ2AQ0AUuOaDxRe4hucGlBpvOaADRYB2c96BnPPNIBilp3sA4HBp2aZilzkdKFK4D gBmkYUg46UpzSuwEGTTxUW7FOVsmndgSinY7jFMKsuNwIyMjPel5pIBw9TTW5peaMHFXpYBg UA04rnpSYyeppwFIABKnFO3etNKg9aNo45BoAf1pcU3GO9OB5pANAOaXGKXJo5q1sA0Zpcj3 o+tHOeoxU7gApT+NJml/CnYBB6UpFJnFLmhIBpGKTP8Asj8qkGT6UuAKaA5pfuj6Ud6B90fS jv0qAHCkIopc0a2AaOelKKB9KXFGoC5xSqeKbjmlHFFnuAtLSUd6LAL3paSlwc9KbAKKWjBJ 6VNgGfWnLRtOehpdpHaiwXF6Gl70gB9KUA+hpMApaAjdcHFLg9xS0HcKUfSlCsRkKxHrikwR 2ouAtHHpSDJ7UvNMAxQBQKX8KBAFpcUDOaOaaQIXFKBmgCnCgYAUY5owaXB9DRa4gApcUoFB Bz0I/Ci4CijFIFOeh/Kn4PYH8qEkwEDc80hYE07bntRtx2/SnogI+acp/Ol247UBT2H6UwDA puKftOOaTHNKwCYx60uT6UoVvWj8afLoADPpR+BoIOehFIR3LGl0AYRzQM5707bnuaReDw1N AS7nbG4k4GBntRk03J6kk0u7ik4sBwY9iaC7+ufakznoTRnHUmlYA3MT90rx3GKcCaJbqWcR iWQMI1CLx2FN3r/eBoGLuOaUPxTS6/3hTdwB6ginuIlDE9acH+lRB+OoNOD88kUWAeHGeacG HrzTA4z0WlJBGdqn6UahcUmkzzTScdBTN3PSjUCXOTSg9qi3d6cD6mqVwJOtLkeopox70oAH QCgB4NGfemEelNyRSWgHOKTtH0FGTnrQPuj6ClrJzd7DDmjGDS0uPenHmAQZ9aCSPrS4oxVp sQAmjJFLikptuwxSTjigE+tKKKjpcQBjnrS7mPekpRSWrHoG4jvRvJ70mKQiquhDt5HelDk9 6jzihetMdiXcfWlDn1NMzS5pPUB+9sYyaNxPemUuahrsIeHcDG8gemaN59aZR0ppASBjTgc1 EDTgaBkmaUMaj79aWqdxD91OB5pgFLnFC8x2Hbj2oDN61GTTwaaSEPDnvR5uOM/rTcimkcji pbY0SiQ+ppWmYDOScdqgzzSgnNTYCcSuR94gUvmuBwx/OoRnFBz601dATedLj/WEewNHnyc5 dj+NRCjFJsCYXEoP+sNKbiZusrY9qr5OcU/tVpuwWJhcSL0c59xmnC6nz8zqf+A1WwaQkjnN PmYFr7VLn7y/980v2mc8fuSPdKpRuWY8gjPGKmGalyYiw11cvjLRnAxylN8+fP8Ayy/74qIG lFS2wJRPP/dhP/AaX7XcDgQWx+q1GDzS59KaYD/tM56xQD2C0v2iU/8ALKAH6UzPvRux2puV hjhcXA6RwfkaTzLhuqQfrSbu5wKN4zQg1F33Q6RQEYp3mzEY+z2+c+vamiQA0M+4dKAHEuRz bxH8aFJH/Lug+lIrc08EU0IUbR/ywH50m+MHm3P4GnBqNwNF7ggBhPWBv0oxAf8AljIPpS8Y pOSeOKaXmMUfZf4kl/KnE2uOFm/75poBznNO+bsaLCE22hPIlH/AaULa54Zh9VpQT/eJpQue 3FCSQCEWq9ZsfWlzaY/4+FFGwddv50uxO6r+VVcBAbZgdtzEfxp6xQMMieH8WpAFU/LGhHcb aCkZOfLX8qLgcmp4H0FISaQH5R9BRuqGkA4ZHelyexNMDZpRkUJX2Cw8GlzTM80u6kApYimh jSEkmgZpBckBpc5ptOBosAcigtS9aaeKtLTQLihqKjJOacCcVNmgFIFKCD0ptCrt6UbIB9Jz mkO7PHSlwalSGLzmjnNGDShT3p3bAOh5NL1oK5pNpAqmIO/WnAkDimgHPNLg1KsMepJp4pi0 89KeghST2NJyacKXvQ7juNxThmggHvS44601cApeaAMUtF7CG7aUCnAYzj070EVLdxoBS0g5 pRSt2HuBpBS0c1QgxzSijGaAPWmk2AopjEA5NPIpMUpIQKc9ABTvxFJRUbsYtJk0UhIz71Xo AuTTx9aYKXAos0BIKOlMzS0X7gKQWGKFG0UBqXqaq4DTQCaXHNKBU6iEDHPNP3GmAemRTgKY x2TSbyKAWGccA9aVvL2Dbv3989KWgCrJT99QAVIDVa9AHiUE4z2qTzB6VAAM5pep4zS1AmEg J6Cnb6rZxSg89aevURYDGjNRAmjdzSYyXPPWjfimU0jmmrCOXA+UfQUtL/CPoKQhj2puwDQT npQZQpwxAp+MGtzTLOGW1V5IA+c8/if8KTfKrsaRz5mT+8KQ3ESg5kAx1zXax2Npji1wcddo qX7JABj7OjH1MYrP28LaGign1OG+0xbtu8ZzjrThPEMfvF59TXcfZICMG1g/79Co/wCzbU5z ZwsD/sU1WgkPkRx3nR93X86BNHn74P412H9l2pGBYwEf7tJ/ZloF2fY4QPTFT9Yi3awcnmcl 5yZ++vp1pDLHjl1/OurGl24P/HpBj2FL/Zlv/Daw/itNVooPZo5ETR/31/Ol8+IdZEx/vV1h 02AjD2Vuw9hSDSrEn/kGqfYAYqXXiHIcn58X/PRfzFKJ4iP9Yv511p0ewJ/5BK/gooGkad0/ swKfdBUqvG4KCOU81f76/nSedGeki8e9dYdIse1moP0praRa7cLaoB34p+3htYXs0cyJUBxv GfrS+fFux5iZ9M10g0qIHP2aAD6Up062A/49Iv8Avmm6sQUEc55qf31/OojdQjP71ePeulXS 7M8/ZVH0FTLp9qo4soSPdKarQ6B7M5RbqEn/AFq/nThcRN0kXn3rqvsNp1+wwD/tnUTWdmP+ XNB/ux0OrHsHs0c8HXHDCnCRR1YfnW1/Z1uzcQDB7bKsLo1qwwYAPcLS9pEPZGAJUPIYH8aT zUz94fnXQf2PaIf9SuPdaQ6ZZHI+zoPoOaPaJbD9mYIceop3mD1FbX9jWX/PNvbFOGi2g/gN V7RE+zZiCQD0pfNX1H51vLoVoeWj49AalXQNPI4tyP8AgVZuqkHs2c75i+oo8xf7wroj4e0w 9YSP+BUHwzpOeEYk+j5p+3iHsznN4P8AEPzoEi/3h+ddCvhvSVOAlxnOcE0//hGdLA/49p/w ej20Q5GjnDIPUUu8eoroD4d0X+OG+H+6ab/wi2hPwG1BST/eNCrLqLlZhb6A4rcfwnp8QDLJ euoPd6iHh2xIwPti49WpqrEORmTvFJu5rQk0G0j/ANVcXJ9QxzUZ0qIH/XjPpv5q1JMORlPf g0bx61bGkx9PNc/jS/2Mh6yv+dK8e4cjKe+mfKHz/WtD+xEII8+RfqadH4dGNv2mc+/FLmS6 j5WUg4NLuFaI8Mp0/tCT8cf4Uv8AwicrY2X4A/2qOdPqLlZmh/el3Cr58JXoztuwfpSDwrd5 +a5cfRafNHqx8jKQYZo3DNaC+FLknH9ogHPGUpT4P1AkY1i2H+9GatOHcPZsz91AbFXP+EP1 0E7LqymHYqxFJ/wiuuY/11lHg/xOeal8re4lTZVDD1pQwqd/DHiBMsVtJl/6ZuabH4e16WMO sMKeodiCKd0uoODQwNx97j0pMjnpT30HX4+ttC3+65/wqP8AsfXRktZqPbPWjmixcrHZyaCe etN/srXOq2Jc+i037FrffSbge22hNLqKxJuoXANINM15l3DRrk8elQvFq8OTLoWoAA8kR5/k aOZBYs0oqssl5uC/2XfZJx/qTU+LlcF7C7AP/TE8UJodiSlAqLzSDhopU/3kIqQH0pisOHXm ikBNL+FCsBzK9B9BS96apyo+goJqtADPNdDpWUgRiwCtnIJx3Nc4TzXUWSMLSNfOt8FeFZcn qazktCoK5f6rkMMex4p6bhyG/DdVAW18MhHtFiA4XkZpn2NZ5AJZXgdSDujcqDzXHKNtjaxq AyE9R9M0SbgnOfzqsAV/jyB3Ddae0ksY3eRJKO4BH6VmnrYNBpmZDyDz04qRbiXPSq4mieMS RJNkjPlkjNPjl3cbHU+jLWlu4kW1kyMtgU8SjsoxUIx3jJpGlijxuUxj1Jpct9irFnzEH/LD d9KQzoTg2sv4CqouIsA+cnIyDu4NTCVT0c49VNJxfUdrEhZf7kg9s03fGRxvH1pNy/32x70B vfP1FTsxACP7+Pc0/huFY/Wmq8ZOCaCVz8r4+tUrhYVc5Izz/tUuADyA3sKME/xIacCF4K/i BVNhYiY88Aj2pyuTkEmpcof+WbH3qMyQA4O4H6VGt9BjOS3OOvrVhXwBjGPTFNQxZAIZgfan fu85VHP0FXqwRJ5nHQH8KVZCvO4j2FRnyyMMsn5UhSLOA5X61LuBN9o6gKv4jrTDJuP3EH4U mxugdDSMh/vL+dKz7jATFflPln9KUScZDp+YpjJkcMuffmmrF1IVefQU1NrcCUzwrljOu4fw 8VIuxwGMJY+1QfZLY/NJEu499vNJ+4iBdBI2OcUr3E0WfLjfgRSqf9rpTPsrZyqLx3V8VHvD qM+aoI7tSMFPBlmUD0NQ3rYWxOAwOPJJP/XUUvmMGCrbyAn/AGwaiE6LIsayR+Y3IDjk1PG8 TN+9ktQf1FVpuNJsaJm8wIY7pT6hARUmZQDmaT/gUdMY3Rb93Nale2SaQ/2jn5lhwe6uRWlt AsKyXw/ihZM8AIQaQPbs4iLOspH/ADzOKkiS6jyPM3Z6kzfypw+0KfvXD/8AAganm7jKskMs bYF1akdww5pqxRMC5WBsdcLVmSKXG794D/tIDUYvXt2/eRuxH923qo1FsLQb5Sk8RxjHbbgU m0nGDY+4cVb/ALWyuWLIP9qCn/aGkTzVSB06ZMNVe4WRSYvGf+PG1lGOseTUscYlb91ZKW7q Diri3qRr8saD6JtFOFzBKPnWPnuj4NRIEiBbeQffsQPcGopkkgbzTG8keD+7UfMDV2NoVbER cHPV2yKk86/yMfYnX3zmoBFCOaIru8tx9T0p7JJNgrCxH+yc1aMkKnE0FqAeTgZFSmSDH7hz Hk/8sxTsgsZjFl+Q21wv+7kUsU86fIlvMfeVc4rSZwuC+osp7b1FPWbKgRXcEzf7TYzQl1HY y3kmxmRVPsFK0kVy5cK1n8n9/dxWv5jg/vLeNj/smh5yoKiwkdO4QChyuLQp/bLaMhfLmb/r lzSSXUbLlY5kHrJGasrIHz/oTxj/AG48fyp5eW2IcW4ZTwcMTx9KFKyFuU1niCjLxN9GxTxd WvTKg9stUvm6XPIVNnCXxkgrhqU2uktkPZRoKG20Ow9J0UZWeEe1SrdyKctNARjjD81nrBY2 MjyWUVxNublF+cD6CraSxvgeWysegeCkuYFYsLf84Ep/4DUn24J1kP41WuCqqQthOTgfNHFk GktQHXJjlQ9ldcUJtj0L4uWI3Agg+gHNN88nqoP1FQNDIGOYZPqpqM2LPz5zx/71PUViDVHj NnL/AKKPmXrsH515+WyxzXfXFqzKV+1QsSMABjXAvw5B7cVvQm72ZnNOwd6MkUmfej8a67GB zKZ2j6Cg0qjhfoKUiiUrARkgAknA+ldRZT2z2yETwBsfxDnvWJpSB9Vtg3K+YOv0NdsqQ4H7 q2HvtFROasaQRiyX2pRzgRxabcWuOSWKuKs/2pAwKvbx49AwNaDC3U48uNuOqiom8oMW+zxZ 9SgrmmoyNntYzXvLC5LQm3kiYfxowFRWotLfMa3+obTniQhwPzq9LJDKdqpHuH90CnW9tbIQ ZniUHsxANKNOK1M7FJXtbZi0OpDk5xKmfyxTY9WgE2Bf2jEHHysQR+Fby2lsv3YYyMdlHNSi 2tf+eEX/AHwKr2kNmaLQy21WBOXljI9c0JqdhcjDyW7D3cEVpm3hBJ8iP/vkVG1pDIcG1gP/ AGzFSnDdCvqUzLpm3CNA46bVI4p8P2Vh8nlqPTIFTf2Pbs2RaxA9eFFMOkwZ5ijJ+lO0XuUD Cx/jUjHvmnJLayR/ubmNPTzDikXTIF/5YrQbG3P/AC7IfqmaiyWwhS6Y5nsyQOoanG5sUGZL y3Ue7DFMGnW5Hy28I+qVGdHtWIxa2xx2K07FFyMwtysls69QQwp4zu5Me32YVUGlxg/LbwL7 KcU3+yYCTuQA/wC/UuF1oJsuOEbjK/g4pfqyY/Cqg0m3A+4mB/tUf2XD6pj/AHjU8kl1FqXA cniRMfTFKQpH+vKD/ZfFU/7JzyGXH+8ad/ZvA2oDn1anaQ0XFKhNvnF+OpfmlGCMFAy/3twN UDpag5aJs+zHFNNihOCsgHorEVNmFi41jAzbg0657LJTooY1+UJI3+/zWebC3B+YXK+4c0C2 hThGuD/vOaaTDU1TAp6R4o+xD+Ikf7rVlfZge82PQOaBaRd5LhPfeaOWTDU1fsKL92WRc9zz SrZt2mT6kVlpbw7uLmb8ZDUgtVJz582PaU0Wkg1Lj2V2MlGtHX/aJFKkEu5Q0duCSBxJVYW6 HhZ7jgf36cbCOU8zTj6NTs+orlk2sD3SzywIZowUBVql+wWkvzSWRJ9SM1T/ALNjx/x+T/8A fQoGn5/5id4Mf3Xo5Ljuy2NPsM/6iZT7ZFKNOs1bPmXQ9mckVUNpNtITVbwHHGSDQlrJ/wAt dTvGPbkVXJpuFmWW0qxc7kkdWz/z0Ipw05cYW6f8Hqt9gDZ3Xtx+JFA0mIfN9tuD6gMBU8rs BM+lsRxdXRyP4WqCX+2oDiCNJAOAXUk4pRp0R6X10nvup66apPGq3oPs9CTH8hoknbB1AfNn GI4W4pxjjBDpc3EansVYCnHT7tc7NcvMdskf4VFFZarDnGt3Un/Xbaf5AVpYSRPsdVLrqCuo Gdm7k/nVd5lZ8SQTYP8AF5XH5imNHqDsVbUIWfuGhBJ/Ki91C70uJPtuqKFfhVij5x9PxqvZ 3Raj2JkurFPk86AknGM4NXI7W4Yb7aEMCPvK2axorKS5ZbuC7SeJjnBjyp/+vUrabeuhEeot akj/AJZEjFRKjbqJ3W5ekuJLN8XSXIB7eTkfnT0ubSQ5LbT/ALJwT+FVrWx1yBRjWTcjbjbO u4H3+tI9lrTt8x09gepEJDfzo5NLNoSZobo87vOz/syJkU3fb7s7Y1b+8gANYs2i6tuJ+2Kn phDTrWx1uBdr6rp7k9POtz/jVKm+4zcMpK4TLD1dsUuJMfKJM/8ATKSs1bbxBnct/ozpjosb D+tTrZasRk3Fkr9ygOKl09RF0CQ48ya5XB4DN1ppEUTbjeXKZ6/NkVCNO1Nv9Zd25X/dNTDT r9Rxd2uPRoyaPZAkgBhc7heMzfhk0O1sr7jPOreh6GmSaZqki/u72yjbsRCahOk6/wBP7Xsz 7mA/41Xs/Mdl3NCG4RDlWVT/AHs80k0gKFmE0o9YjzVKPR9WLfvdTsG/7YkVL/ZmuxY8i/04 j0YMKTpvuDSIY5Li1G63ur6KOXtK2dp/HpVhb3UImHnNdzRkdUQMaiaw8Uh9y3GjyKRyr7qj /wCKuikw0GkhMjlN+cUKmBrQTLICTJepn+8mDTxhOVvLp8/wuuazTd6qp+eCNvdciqc+oeIZ PltbSGMf3nY1LTFubEruVzHHGenDDGea87kYmZywwc8j04Fd5azX/k4vIbdn/vKTXEXtrLaX LxyFT0II78D/ABq6ekiJLQgzzS7qjPWlzXUrnOYKrhB9BQRTBLgDIPQU/OeRRbURY052hv4n QgNuxyMiuphdpE3FMevFc7o7OmoKyIG4wcjOOldRHG+MqyIf9oHmoqmsDO1h5rXTXmhUNuXq M5WqL6Fq01sjpq8sdqiEyCQ5Y985rR1GbzNSsLGaQHflgF6YGetQeJJ7tYIre3tp5onIaQwD 0I4/nWS0N0mjP0GzlF61zGJmhQ7DIDkk8dulVtR0TWL6+dtkEkbEbfMYggcf4GtnT/FGlrJB ppsb+xnkbbHHLGAGPTOfrXQgjOPLXHqetU5WeqCTZQ02BrDT4LeS5MzRoAWc85wKuea+eYsL 6inssR4aHI9qieOE/wAM6+wNYyavci9x+5SR+849zXN614j1LTrwW0Fm8UBGTcuu5eg9OnU9 fStz7LHv3LI/Xo/NMjvbPmJL3TpexRpAf0ohZvYIt3MOy0AanH9rbxVfTSlQ3+iS4Vc9Mipr nXPFNgztJpWntaKdqlsh2565qpLD/Y2qrNpTxCOU/PbwsMHk1c12UXDWto8rLIZFLKT90ZFb u+1jXUda+M3cxpd+Hb6JnbHmRoTHj1zRdeLZxOn2GxWS2z+8ZyQR9P1pda1JLK0jsobtSRwV PGAB/wDWrJk0q4tbNbx72PymGfJjByeePxpqjHcuKi9zuYpkuLZbhGdYygY57cVztz4mvjJL Jpdik9lCVEk0zY6+mKyZrmWHRLe3NzKpaPJ+bBI6YI/DpVWKRmmFjO89tE7KWVvkB6c+9Zxp 66j9nG5vHx1GzBLfQtQnlxzth4z3x7VE3jLVZmEdn4cEkuCSpPI+tbclzFpWmlYnjjEabVcj Jb059ayvDjbUmm8wBznJPXAznmn7OIuVEset3ttbSXHiCzSyjAyvlEkn14qGPxnZSSYttI1a 5jzjzI4eDVC9lutev5Fh1GyjEQIRbuTCkZP6mtO31XV9HtJZ7y+0WS1UeXtsn5ViOCTTjCDB QXUtat4kisRFFY2r3N23LwE8oMe3er+k6pb6zaGWKN4ZEbbJFIcMp5/TiuOttRv9OlN9Faoy SEgXc67hzySDXReHrVRavd/aYZHl6mI8DrwfeiUF0KcIJG8sJ/hBJ92zUcz+TG0kxRI05Zs9 BWZqOlpqC7G1S9tfe2faazNcuYrC2GnrLcSs2GeSTnjjj9awdOV9DCKuzoYL6zntjdx3Eclu mcuDxkdRVLR9Zl1ZrlpbAQQI22JwOW65yPwrmhq+ky6KNO06OUOX3Ss0e0M2O3r0Faa+JINI t4bazsJZwATMcZJb2/OtFTtujb2emh0wUjoDn0pxiOPmH5isoeILKfS2vYiUYYBhkGHz6Y/G qHh61vRdXN/PcTMkoGI3YleAeR6dqnlfQz5H1OmWAv8AdROO2KU2bA5MYH0Ncnqeo3l/qYtr LUlsYUYqZHOASM5ya0NB0e6s5Deya/JqcUqkKFm3Jn1FPlbVx+z0vc2vsykdSOOm6niziPUy A+qmjzEBG6Fxn3p/mwEEsjqMdazszK4i2yKfvP8AiKlWxkLZBJHuuK5W/wDFupG+lsNB0S5m kjkKefOhCEDjcpHUVm358TR+T9v1qT7RMCVgtcjac4Gc1pGEmaQipHcS2lwpPlGEMB0c81AY 79Rua3Vx6x9BVPQG1vStNuJ9fnt54YkDxkEmXtkNniseDxH4gvdct2SQCJpFDW0aHaF7k++M 01HoWqbvodIryEgPBMD6BKkY+VgvbTDPQ7Kq6/4ofS52s7OMS3BBy+OI+v8AhWZ4c1G/tre/ utQupLu3jXK+cc/McgKPxFJU2xqk2dArlukMir6leKb5q7iNpHuVxmuaRvGPiGdrvTrm1sLZ eUSTcA/oPpyK63i10/ztTaLzUQtIYj8pPPTP4UnSsS4WEXbj5sfgad+6bgqBjuK4m01rT4Nc k1LVb94IZSVEIOVIyccdM4PJruRHbNGGj83awyGHpTcJRQpQtqyE7VcMEhJ9SOa5HWNH1u5u 7vUrt7Y2sQAQxMflXA7euQa7MQjBInCenmCqWp2kkmlXSpc2jfuydpbGfp71Mea4QZx+jQ63 Y+Xfabi8sJZtk9ujZYdMkDseldyRDjJZ1YdjXO+FUuIrKUCERxmTcGVsGQkLk/59K2TMFPMM rn1PNXUk+o6jZK8kbDaX59jg0qxODxcTD8agiuYJGO6BUI7uMVcM4K4YKPTBrO6MxvlzY/4/ SB/tGnJGX+/OslNEkWcKy596b57BsoYvxFMZZVYgOAPypVAyQGAqt9oZeWKD/dprX0XTcAfU Ci4rGgkmDjzcfSpRIQclt/sazRcIwG24Ck9AQKcJGb/luh+lLmCxoedk9FB9CKeJjkhovxXp VKNuSXkB9MGlMzKeDxTbFYv+cCQDGcH/AGalCoOSn6VQju8njP41IJ9zDcxH41Dl0AvL5Y6R jPqBTg7DpwPQrVUOq8lmFSLMueHH41Sl2CzJyVP3gp+q00xow+4g+lJ5qg8sh+lJ5qk5wtVz vqF2QtYQM+TLKvsK43xhZxwX0RhcsGXJ3e20V3XmIVIJxn+6ea4zxjEFW1ddxHQszZJ5WiMv eE9Tk+aOacRRiuzfY5mc6RlB9BQh96CfkH0FMQHNVZrURraQW811UAk++PSt6NXjwJJ2U9hu BrA0oAFiy7gW7HGOlbSpacF7SVj67q5aznfQuJb3RjkiIsBgM4GR+NSpK2M+ZF/wF6zHOnSN taCdfTecCpU02wkOVhfPqGrK02a8zLzi2kKtJFE7qcqzDLD6Gmm4ROjEfU1B/ZsCLhfN5P8A e6UxtPhxlg/4sanXYLlj7WDzgEY/hNJ9qR85MimqosIh/qy4z6NStYZXHmuP+BVaVkKxYN1s bcJG65rFuNB8P3LmSS3Ebk5LRgLz+FaH9nMPu3L/AJ5pRYvj/Xc/7S1cVbW5STKdlpGk6e4e 1XLjoznJq28NvLdC5lQNMAAH74py2D5z9ojH1Wnf2e5PE8WffNW3fqDbIZ7OzurpLiaLc6jG MDDfUfjTz5ZG3BVB0UDipRpk/VrmJR7NR/ZsueLhT9WqfmL3irNp9lcurzr5pUYAYcVLew2u oweTdIrDjDYywx/+qpf7NnA5uF+hFIdLuScJNb598ii/mP3ipZ2EFtYGzaae4jLFt0x3Nz2q 3bQx2sXlW5Cpz94ev/6zTv7K1HIw9uf+BU8abqajjyD/AMCNF2+pWpnT+H9FuyTNZwBzySgx k1Jb6PpFpG8EenQtG5G8MuQcdKviy1AZJSH8DR5Fyp+aMA/WkpPYkQzW5hNqBGIP+eRHy/lV PSdGi0y5mnsr1/JmH/Hv/Cp56Dt1q/5d0Ogt/wDgVOW1u5BwbZW/38UnJxGmyYO2SWYn8KxR Yarda+094kItEIKkAncMDj2561qfYNSVsq9qwx08ypAl/FyzQH1Ac0ozdxp2Kk+ji61mGcmI WS/fhRcMTz0/Sq3/AAiWorOzWepJBA2ctIMuAa2hJdFf3YhDe7GlWWYR5mjlZu4h5FX7VotT Zi3Xg+TyI00/VIRIBmQ3HO9sYzx0pkdr43tdtut1pjWw+XI3Z298D8TW7HJvG7ZIv+y680/M rEKuQT0J9aPaN7oftJHLz+GNZYsI/sNwjMcl2I654Ix710NlGbGwitxZCFlB3Jbj92OSeKfd NPaxMWVd5ICj1NEiyxxxyPIh39QucZ9Kjnb0FKo2IsweQonmGTqVPGKaJYvtAjZ2EmMlVfOO O9WrVhbyGe4tV8nbjex75qnPHbfbd8bDEjZyQME+5o0MbFqO6ki5SR1bPyjGc/WsfRo7u/1y a+vYZI/KLbA4wGOOMe3FaUlusLK0kkQjPdW5NR4upbZ5IJ42GD5abyT+NNNopSaKmv3Gp6hq S6TawMsRALvtO1uTzn8qSOLxD4XvnFjp1tqkMqhWcZBHH/16v2dzKYwkhnaQL82096tx3arw Dcoad2WqslsYcWjX+sTXV5eI9vM5JRMY3HPT2Ayfyp9pp1//AGFe28lpcQzbldFYffxk8Vvi WdiD5kh78mpDdlAN8x/FqXO1oilWkc1b+M2SystN0fT5ZdQXatxDLGQAMfeB/CtHxjePDaQW qCVvOkBOEyOCOK0lubcNuWFBIf41AB/OnPNC5BlRiVORkbsUOXUXtLvY5TQbrwzA8j63LbJO rfu0ulAA6cgHv1rtrW8trqFZbK4hmgYZVo8EY/Csq5sNA1CbzL3T4JZOeZYx3+tWrY6fZxLb 2rxW8KjCogAAq5PmRUqnMtjT3cfMiv7baq6kZxp0/wBlsYZpShAQjB6dRSC4hI/4+Y2/GnLc Ipz5sfttbk1hZozTMXwj/aB0yWO9s3hiEpaJXTDDpng9uK2Xg3cAqPYrTmvh0Yt+NNN1k42u c9CKpyCUmxi28Q+80R9iKmSCIcskLD2qLzQeWQfUmpUeLqHX6bqSbYJ9xjWtqWJKqp/3gKct tbMABJj6EGnlrX/loVH4ioybcH9xMy+mFBo1ESCC1XjzgT6YFO8tOiiIr2yoJpFkCqN8oZvX y6eHR+rwL/vLihsYqoAP9VB9WWnFAeiWQ9jxSBUXky234tinBomP/Lq3uGFKyEHlJjDQwZ9V NMNkhB2ybT7mp0EfZE/A04hCMsFAHq1K4GXJpk5b5Zgfo1SW+nSxkbp3J+uavAwMfl2cej1I uOwix/vUlJIXMyH7Gxxi4cezYpxs5xwJo3H1qb92xw4wfUNS7IU/5bAZ9aq6ew1JkAt5lHyw K30ah3lVcGGXJ6YXIqwFjz8lzGp9zT8so+a7iP0otcDL82+EyjKeV/FleRWN4tlE1lAMICsn Vepzjr+VdRM0okTDwtCfvEferD8URW39kF4mJcSJ1HvTSsxt3Rw3FHWgdRS13rY5GtTmI/mV T7CngYNQwb9oyOwqcmk3YRf077Uiu1oqFt3O8ZHQVpxSaq6lZordfRlQ0zQkjNoxwA5kPP4L /wDXrYMR/wCexPtmsJztpY1jcpCXUhCFElrkDjzIi1SLqF2vDxwEDqI1wasGBiOGH50C3wTv Rs+qtUqV0aaiLf7iAYWBJx904FOPmSOG85VPZc8GnCOQD5WkA9+aBGxPKhvrUJIlERuLpeFg t2/OpY5ZZF+eJEPoKd5dwv8Aq4xj03UgNxn5oMe+alsY4vg/6tPrSCVv9g0m9s/6th9BSmbH WFvwWnoO7H+ZkEGNDx6VH5iZx5OfoKVbiIj7r59CtBuUPHyr+lMVg3Jj/Vj/AIFTRJyP3KFf UGlNxGCNzAj61Ik0ROcREfWp0Y0g87b0Vh7Zp4lB5Kk/WlDQMfuLnHUEUryRx87GP05qegbD TcbeBESP9ninCbv5bAfWhdsnKRvSlMHBjkBoSQXE+2unSKQj2FOW/wB4zsYezLRtI7H8aBGx Odin61WnQFccLtXIBiQ545Wno0LLkwRgHsRg03ZjBChTS/NnPyH/AHhSeo0IZ7VDgW4B9qBd xk4EG76UMAw5SM/SmYVc4iQH2paMdib7UiDItiPrU8M5lQOq7c544FVVbnlVqwrLt/1ScetI Vh/nFjhlfp9aa72xU74ZGX1FR+eRy0SbfbNRNcWhJ/cMT3AFGoNsUzadIRG4m45C55qRBZuv ytIkY6h/51Qe5s1kDRwShjxyvNTyz2ogZt0yOoyExnNUrE8xIHikBBwwzgA9+aEnsZS8Cy2z MuC0WQSvvjtTILhZNrRHaQFLBhyDxXK22oWulXQuIoI5JmzHPLcdZFZs5b3XgD2FWo9irnXY iDDAtnA6At/ShEC3STQi3Qp1RDgHPrUdvfadexO0S2kzRnDmHBCnjjP41VuJbbz1bywoI5Bb AqFcXMjRugk0yyhCmBn5G6nnmkUxyuCyM5HTdwKjRtMMGDuUY7SdKtWVzbCIiCTzEzj5nzih J3BMfDjBaMqTk5UninjY33zbADsRT1aFflKhSxz25pskUbR7kaLAB/hzTtc0QjOifxwgfShZ l/hkjzSJKiqAWiHH92pwNx3B0H/AKtJAN8wuPnMbH0Ao3wD70cef92pVdgflmhB91pczMfmk iI9lqQGAW7DhVU+wFKBag9Tn1K08xqesqD/gFMa1RuROR9KnULD1S2c4EyMfQpUjRogGZI1H +7TIUuIl2+dbSKOnPzfjTvKkZfnWNz/vcU2KyGkpn5Zo29itOVmzhYLd/TIqEpMGwYYvba1I 0jxEb7WQA/xLUt6aAyzucfft4V+q04NKPuR2n/fOKgzADlpJiPpSA2rH93K+e+acWxal1GkA /eJDnttFBaNuHhH41TDwg/6+Tp609ZLRgA1wTnoGo1EWD9mxzaKw9wDQv2E8fYUH/AKaAOiO h9s0oST0H50tkBJ5dp0+xj2INJ5Nswx9jJ/3jxQA/wDs08biOSoNLcGiIpaxD/kFoc/3KEFu x+SyMR/2qcRIORPGPqKTM/QyQn6U7JByskEUP/POM+xNSLCh4Fsh+hqsTltpRCcdQ1II2DZC N/33R6CaZdNvCfv2i5+tNFvCv3bZT+NQgTHk/L9ab5MhO4TL9KauCFNiv2nzk81OMbAflrN8 RwMNGmYk4DKccdjV+WG5YHy7gDI+tYOo2N1BZXLvIZVxk9apJ3H0ORBPWjPtSjPfiiuuLdjn ZzajCj6Cg0g+6PoKQnp9R/OqJNKy1MWMIQ288nP8ERP8q0bfXI5ufJnjPo6EGrFhiGBSN491 GanbbJkjJz13Lg1jNxvqaRM2XxNGkkkX2O6yo4cREqT9adZa9G7sJzJAOPvoQDV5HaJuFjP1 XmllmDfehiP/AAGoTh0LXqOOq2Xe9iB+uKF1TTsfPdx57bXHNV1dVz+7i+hTNLmNlw1tbkY7 RgUOMWUWFvbaQkLK6Y9T1qVZo/8An7ix/tms4lQMeWAPpTCEJ4i5+lZuFgTNnzoD8rXUDE9N rU3Ee7i6jXAzy9ZHynhbfGO5QUmxG+8seT0ylNLULo2S2QNtzbsPZqVYz3a3NYJRIcsIIWwP 4F5ojubZ22rCwJ6gHGKJKfSwbHRGMr1jiqMiEfeSMH2rFd4oiAWmAP8AdJOKkVYJl+WVyfVs 8VHvdQUma4SDrvhB9jTgikcSfk2K5e9uktlKRSpJJjgA/MKyBcahG5lVp5ApG5WPAz61apya uaKDauegrAV+ZJph/unNPCyBd32qYD/armLaWCWJZIpLiOTqUMnGfcVM8xY/elH0JqeWZm9D oTPO7fLcR9OFK9acJJlP7w5Hfatcyzvt+8VOOGLHIrLN5qdjcnN+bhf7u/oKfLJ6FR947oz/ AN1lX/fBoM8y8p5Jb3PFcbBqtzI7tIjOByAr81Cb7V0KyToqQtnCljuFLkew2jvPMYruKjPo tN8xSDvEifhXFtqLCdUQSgELljJ0J61Hd3FzJMIYL6UknGA+c1UaUhWbO2DI2dsgz7kA0LOU Iyd2ehBBrhUaKCbOoG5Z1ON0UhFaOkW8WoTlyt7BHGCVkSfjPPFEqUo7g4yS2OmmunjXKyoS P4SRVc3jOv34t3qOKwda0my0+ETQvdvJJn5pZye3pVy28O27wK1yLxXPzFYpDtpxStdi962x e3tnLZYj+43FSi4bHIb8aqSeHrG5UA32qQBCMKjbc0kPhG3mJVda1SIbSdzOP5kUaPZkWfY0 PtShDuDkcZwO2a8x8RPc6XrFxaTqzxfI0ciKSrgqpwD3wTiup1Jp9NuTHHcXSWeMC5nI25yR 19Pemm8vIZBaTNHdEN8rqAwGT/Kt6VlruaKnKSIfh7by2sF/dzoYbWbasSsMFiCuTiurnvSM bLeOZe4KjNU7jTGt7WOW5ncXEnMUO7hhjnA7nistZ7ltOW5tpFWYuU8t+CMHHTrRUipPQI0p G8LiCVG3adPEcDkRcGrS6jFBHGptQiL8q4jx+dYk2oazaiKOS6R5mALoB93NUrrV7l5WN27N Ghx8i89ucVEabfUr2M2do9ylxLFIFVGToFHX/OalSXDEhoxntkcVx8V2bixW9tbq8nDHiNY+ adb6ksyOJ5jbSIhZQy/ePp9al05XsHs5XsdmfnbLNGTUgwR99QPZq4k606Wiy+YzOTjZt5Hv Viy1mS5imdpDH5Qyf3fUc/4VPs5LYpUpLc6zauTkn65p6xxEZ85/z4rlLXW5J7aS6a78qJH2 lWj5P0pkXikXKMYb/ZtzgSw7c4peykP2bOu2op/1kzfQjFOCBujSfiK4/wD4SaSJQzXcLAjo sfI/WrcPiC4nheWO+hVUxkNHz/OnyNbidKR06hO+0n/dxTvLyM5xXIL4qkaUqbqJEHVmiP8A jVIeKtdYme1sUltwMmVgcflT5H1DkkjuxE4wVZPxqUJJ3TcPZq5W11fUb2BJo7myUsOUeMgg /nV5bnXGX5bjT1HrhhUuJLXmbmwMxwJQR27UeS//ADyP1xXN3Ws6np8Yae7spWJwETdk1BY+ J9SvZxDCIIpWBKiRjg47VPINU5PY6wJk42H8hTXij7oM/wC0K5i68Y3On3H2a6+ziQD5mXkA 1Yu/Et7aQxSyGzkjlI2FMnrxT1sCpy6m6oRP9X5IPfnFSht39w/R65SbxZqkF2sB0+0kDdCB z37Utr4z+0QySypbWoRtpEiYOef8KXJJ7IfI2dWFI6Rv/wABal8ssc+TJ+dczbeK/tkvlWeq aY8mMhN+D/Or39o60h2zPZqx6Lk5qVGXUTpSW5qmyMn3o8rnoWIp/wBkA/hVfq1YbaxfiTyp bqwik/uuxBolvtfhj80xae8QGd+4gVVmuhLi0bRtyo+REY/71OCy4w0J/wCAmsGHVNalVZBb af8AN9394efpU63mtSrkJaxsOo3nis76iNby17rKfbNRDYrYjgnz79KyTq+rq20pasQccOak TUtfbGILVVPdiarXsI2VDEcQSE+xrP1qGT+zbh/3qAAEqTxVfzvEEi5LWSj1DGqE82syRzR3 MkLIQQAjE9qcVdg1oc4eTxTTT2BDkHqDim12xWhzy3OWjbKLk87RS5LOo9WUfqKjaNWAOcHA pYCWuEQ9S64/OrckSjs4VdY1AYjHapOTxn9ahjaRYwu9jjpxmiUXChT5hTPTcvWuSWr0N1aw /YQNvP500xkdiahWa7IwrRHjqyGkLXwP3LYj6Gs+UqxLhs/dJ98Uws6nBX8aA9x0aOLOf4WN OUnHMa5x0NNORIzdno4/OgF89f1p21ecwoOOMU5I0PO3H0NU56BYVC/94kVKrP8A9M/xWlQJ ngk/Qg08xjO7Mn0FRzFIaW9AmfpSGONhh4YST7VIBkcLLx/s04QIRubzFJ9VpxbY9xiW0Cj/ AFSj/dNJJaROuNkoH+wcVKIYTwCSfcYqJ4B2nK+2TRdi5TKfQdOiledFmEh6lmqjZIHup4ml IQgAnNbF5bXrW0vkSxM+0lQSefaqGmWF2sLvcWyIxbox571op2WrLj7pJbaTDab2S6kcuxb5 m6VOYMdJKk+yynpGv500QOp+aPHvUKbkyXqV7i0lnhZPtO1SOvpWPcW8UFwLdJC8hIycda6T YccBfoTSbRnLQQ5HQgc1rF8o4ycTIFnPZwmW0QSTHtJ0qGOyvbuTzLvdGADgKePyrbaMk5U/ lUTrMuCY3YexpOprsLnd7mBOIxcGLzBv7BTWlp2msjNI7qxI/dj0PPWriLFu3fZlDf3itWow zkFdmPaq9o7aFc+hz32HUJb17cW0ks29uQPl+ua2pbHXbGCJdEWyYEEyrMDnd7Y+prUVlX+K QGpkjcnIlA/mah1pPRh7SRyM48S3NwBfWRknVcIkUZ2d/X610GiX+vXhm/tazNoiEBGUYLde 35VqxytENzKxx/ET1qb7RJIOGB+vNQ6ulrD9pJ6CDDcecwx6imNGA2ftbDud3Sn+dJ0fyyPp ikLxSEoWQgggjPUVnqwuzndb117iea10tILxRGVmO3dGBkg9Oh4rH0eBri+Sy+0BIgQWEY+c DJ/IcV1T6NYLpd1p1qEsYbg5d4GCt1HT8qfp1jpunB4rKSFp8ASMHDO2PX866Kc4xRcaiSsY 07zah4jiskkuY7eyl+QupJj5PIJqCwjQajcXd3JNDbWys7SSpjLdRyetdZ54DZBi3dy3+NDS s67G+xuvdWxzQ6iQlUscvpsj6xqhuxcQyRockq3Xk4/nVW9v5ItXlNhas1wrrmJlyGOB0HpX WrDHD/qbK1iyBnywBmnhDnctvAH/AL+35vzqVNdCva9hsE8pSMfZ5IZCASsaYAPeuSW2utW1 CVLeIvKCWbcOFrs1guWbJxn2apEtGh6RrGT1KcZ+tHNZ3JU5J3OOuNL11eDpYCRrtXyWJz7n NEdt4ktIJRFYAxzY3oQS2Bnp+ddoyTqOZpFHYZphnkU5E0jH261Xt7h7WZxwstdFjn7H/o24 sbcqfMJx2qe50y6ltLSVdJnEpXbIm0ZHPU11Yu2JBZpgfUtUnnSuPlWYg9waTqsPbyOafR5b eW2ltLNJcIu9JQeT3zTY/Ds9w8zzokLnlFVyBmuljBLZLup/2mqfYX48z8iDS5xe1kzjotH1 SW7jjure3FvC2d6nJYf41sJqmgTW1ysMu0xBkaNsKd3IxitpYlXBy3H+wKzLzwjoeoXS3c6X Cyg5Pl/KCeOo79KnmT3ZXO38RneHYIJ7aYvEZBvwOenSugFvbxruyUAH8R4Ap9vaWlrEsUSI I1AA+XB/GrKJFnKqp9utKVuhDs3ocV4g1fw21wLeXU5POiYgpbgN83IwfeoPDhtL/WQbcyeX Gj5Mi4KnacA+ldzHYWMc3mrp1kHJyW8jnPrmpiUjz5NrbqW+9hMZrRSSRtGfKrHJ6Pbafd6j qNlfmE3LnaA/3sbu1ZkFosOtx6ZOzIsMobY3HHDEge9dmunaempvqT2aLdyKFLke+ePTk0mq 6ZDqlrKI44Eu9v7uY9R+NNSQlVs9jlmnuLjXJ7rTYop/s7EkOchVGQCfzrP+Z7d3aNGidst/ vetdlpejSWmjNZzLbrPIP3s8WRk8f4VRg8JwCxS3u7nzJg+4yRHaGGc4pqVjRVkiKXwz4efQ 4ppY7a1vBCGE0RCtuwP1rFuJLu4ggleTcsbYSUE7iQe5rptQ8HaVq0yTXUN3uRAm2KYqpA6c etW7jQ7SbThYR200KLjYwPQ+tRz9yFXV9TlYIV8RasBfOwbb80iD07Z/GoGQLpMen/bLovHI WzvOCM5wfWux0fSm0aN1aJ53dss4HbjH8qyrfwzcQ6sZp5V+yFW2q33gSMVftIspVoPcytJt Hu9RsrY3EgSEZwD2HH9a7V7QoRlJRn+4uaydG0P+zL+a4e+ikVlKqO45zXQxMB80M4Y+gkrO pZ7EVZJ/CUjCqyYNvHjPVkwamS1jyHjYcD7pbg1PIskp+bIP+9UJiELAF5AfTbkVjvuZDJI5 cnZgf7IPFVLi5NuSslqxb+8uCDVyWRIhlpFPsDz+VVZjDIudoGeMv2oSaFY5K6b/AEqU7duX PHoMmoR0qxfxeVeSoHV8MfmXkHk1VwRXbSehzTWpy/8ACPoKls1zexH0YdqgH3R9BVqwB+2J g4I5q3ElHUKF567qcW+UAyMQAcBucVGHyMEn86jLojfOzYrl66GpLtYnIcj2pVck7d5z9aar IygrnBHrTW5OdzflTSYyZjjqWP05oUg9TJ+K1Ep7hjj6VYU7hw2aNhChM/xH8RTvKJ6FAfeh fqc+1OyR1Vj+FZrzLRGI44STsUepUVIFjJyNx+vFIee1QO6g4ZiB7US8h3LqsAOFIH1qTMhG UYfiaoK0BGd7f8CNKZ4xz5mB/vUkpWEi3tlY9VB9QaQJcIeVVx7mqhkizxIR9GpVKgblnmYe gOanUotO7Acxr0qIoWOfKB+hqPzQeCz4/wBoUb4/4WajlkG45goODGwP0NCoOnP0zQks4+64 IPYg04PJ1dAPoKvlaCwhjUEj7PI3vQscIHKup9KRZHc7R5pP1wKseYI0BmjfPtzUudtxN2IP Ly2NjL7sOKPIY9XDAjHBq39qBwi7z9V4pCgOC2ePSqTutAsVVskH3iT7E9amEG3iNFUDsKk8 xMEFW9iBS7WYnBP1phoIkLEfMYx9TUkcTFsbFx6g9aQjA+ZST24oUhuDvH04NJhoPKKh5ikP 1ORRkJyhVM+tOQleFJ6fxc0mNzZ2oX6jIqBIQ4c580sfpSYAHO2nt5o5xED9OKaYw3zMI8/7 Jq1IoAoJyYkYfT3rmLWyt7HxTI0KFC56g8n5QcGr2uXusWDxSWFuZIApMvGQOT6e1Z0+sRXV /HqMMZQBRxjnOAKEm3oaU43OlYtu4Uf8CFZt/wCHrbVXVmnnt5VBw0L7fzpdCvb3UVuJbuZf LD/uyExkcf4mn61Z6ldQxppdxFG2f3hdiMj2x+NVyOInGzMpU1Tw64iN4l3E65BkYsw+v5Uk FpqmpxSeVfeXGXBbLHOfb0qrd6Zc6XaxvfSq88ny5jcuM8+tbMt9Z+G9Ot2ltbqZp+oiAba3 +17VrFRtqjTRLQoTade6G4kXV7mQSkgeZJnH0qzpuvXNrayQXNy8zYPlSScnPvSWMdz4ivo5 7qCS2so34Eq43D2/OqU1uf7WNgkZDM3yAd145/Wi6e6KjJbMuRa1rttaJcfZxfwknfJzlR9P xq9f+IJf9EfTHgj3uomWccqM4PT9KqX+rPoyjSrG0eJTEPNeRMhs8fL+VZ1nfW9lcJd3en3U sUZz8kBPzdqFCLeiKSizsNS1RrDTvtIjglZjhVYdTjNXLF3urSKfCoJF3bVbp/nFcXqniH+2 gsNrpV5DEGJ/eR7S5wRxWvoevavdXsVlceHTZ2gUjzyDxjOM/Ws+RsxlGJ06xdmhR8+prL1v Vv7E8uNNM8yWQZU9Fxx/jVy71Cz061kur2Ty4YxlmGc/h71w8l5Jrt/JLplrqt3E5GwzIdqD A6E9uO1QoNsVOKb1NlvGeoGNRp+iTXM4b96sa7lVccc561Y0/wAafa7mOC90O9tXcH55F2gY Gemc1reHdJfR7PBYi5mYNJhuO3A+mKy9PmOveMLmR1BFmpABHT5cYqnCF7Iu8LkNz4p1mWSW TS9JiNlDw807dOenFWbjxZJb21pIthueQjzgjAYGcHb781Xn8D6o+oSeVqiRaW5LGAMQSc55 7VWvNBsE8QxaZElykEijdmXLDgcqe3Wi6WiLj7NnVapqcum6L/aERf5+I8kHBxn5qh8PXuoa lpKXOqTRJcFiAETAwCeefoK5LVtBbRLn7JbaleXMU/8AyxuZt237wHH4V21pHJDZwQ4jXYmD 8uD3qoqy1FJRS0Lw84/8t42X/drA1bxPf2l7/Z+i2UF9dLjfvHC5A7itqMYdf3/cZH41yug3 Qi8UaqixO0jAfMB9zjvUq1yIWvqa2ieJLrVBNb6hbx2mow8mJRw3rjPPr+VUtN8Vfabk2usx f2fcFiEJXap9OT+FGhtLc+KtQuWikjwxG+VMbvnqrrYbxBrMlpK9rAtqhBeUY38Kfx9qqyb0 NUotmyut6edb/spJbt5WGVmjIMZ59akg1iwuNQnsVurtZYRli4+U4GeD3rmvDmn2sxurh7to 44U2q8Z5zkdDWeLeEWk1y+oSK6sFQ7uZOO5/ChUnexXsoNnW6ZrkmparNaAssEZwJgPfHNRt rt2PEKaasKTWzqd0m0l14H6c03w5bvpmnPe3KqVkbeFx0HBFVdAvrKCe81O/uI7ff8oEhxgY OT/Km1FaEOCvojq0XbwnlFf9pKdsUfdjhB/3MVDa3sV/CtxZTx3ELfddHBFWN8/d4VUdS3pW LdjCWjsNCRlgCFU5x3xWNqPjLT9LuBAkZu5MHPlHIGPU1sQ6lazz+XBqFnLIrcoGBII//VXL 3fg2/m1Zpra4shYyNudSDv6DgY47GmrN6lwil8Q+x8dxajdJDPoE9or8JNcIFH51tXdm8qsT Eg4OBmsnWyLvVLLSk2OYApYKOwBH9BW8xZh+8gkJ9RxmicY7phUUbaHD6knl30ieWFwe3TvV Mk561teI1VNRHlowBQcMf96sbj0rpo35TinuckPuj6Cp7eYQSbyuarrkqv0FXbCITXSqWwPW tWQjUhvhKoxxn609pHfgKT7kVfgtQoAVVb3zVnyFOAwI9gawlyrY0RixmZT0PT1qwLiZeQmf atH7PCOMMfxFH2WM/d3Ae9ZuSRSRTS7l6tAAB69KmS96YSL8DVlbFT1Yke4FI2nRnhW2n1Aq HO+w7ETXq4w0Q+oNILqMH7zL/wACqQadsOfPz7EClNsQPlltyfRlzRGPcdiJr2LIG8fiaBNC /JC0421z/ctceoQ0fZ29LYfgab8h8pETbkkq4Ptik3WpP70AfVKka0lCnZDCf904pj2svP8A os3/AAFxRz2FYP8AQs5WPd/wGnCW0TkIE+gquLWfPEV0PckGpFs5RjFxg+kq5pRknuCY/wC2 WpwAzAn1FOW7tuczx+1ILSY9WRx6LHiopbMIfnsmk+i81TVi9icXcBPE+PdTUhuYRx9oLH3F VWs4woAjli+iCnQ2s23qw93So1FdFoXKBPkkDe2KVbkqM/u/xNQ/YDMcSMcAY+Tg1EdJRT8k kwPqWpON+omXftqjgsoHtTftMP8Afaqa6RnJ+2T8dRxTxpvT97cMBSjHzAti5tx/EaeLi3bh bh1PtVUacCOPMb8eacdKXHVyfc9K0a00EiwbiFOtyxz+tAubcni4cGqv9npHgmOdvpzUkcSM flhmB9xyKlK+4+a3QteehHyzE0b1/j8zHYg4qm9hG53+ZPz6CmrpiHO6W4I9CaLPoF77F8yW 6jPmTAe7A0LJZN/y2XPviqC6QhbdHPICP7xzTV0Jn5WdVJ7mlyNC16mus0ABX7WgUjoehrnL 3RXXVAbMpNaSspOT9zpn+tXzo88IUeakgIzuI4H19KRbclhHHdw7yQMBsitKcuTqUptbGpbR xW8CwRyQJGvRQalDbSABAR67hWC2kM7sGZpGz/C1Srp7Q/MYJsfTg1M3OT3E5N7m0TG33oon B7Eg00+WetspGc4YA1jRQwRTSSTQXJXy9qKAcA5zn8qev2c8mSYD0ORUqE0K7NsSYULhAo6A kDFMaWNXVvLttwGA2BuH41jSQ20gyFuZMd+SBUaQqg2xxkj/AGgciny1Crs2XkjBy0MDHHVs E07z3Kt5cEZj7g4wax/LX+PcPwNSi3WT5vtbKD25qrTtuCTZellREDSbUCnPCjg1eW8Zwi7n II9OtY4hiQDzLr5Pc05RARvS6JXoSrUkpJDaZuvFHPDsmjEid1dAwqxHKkKbFKxL/dRcVzar E5wt659g5qZLd+cTTEeu7NQ3NCs0b++33A7sn1NPSK3DM0SQIzcsy4Bb6+tc61uxGGnfHuTT RA/RbgH/AIEaEm1cLM6cQjqWT8XrDu9F1ObxTbX8SwvaKPmbzPmGFAx+lU/sdwT8rsx92NSf ZbzbgiUj/Zc1OvQLtbGtfaFaXd/FfT28jXMP3HDfX/E1OI5mJI8w/WsVLe5Vcfv/AMXNOWK8 A6z/APfRpqUg5mzeSJ16RqT/ALXFPSGJXZ0tYVlf7zqACfqawDHOD8wmY+5Jpm25PWNj9M0e 8Gp020nho1654xWFrHg3StcuFnuo545VBBMEmzd06+vSoFM69IiPfJp/mTryVk/WlFyQ1zFx dKs7XSH0u2j8mFl2mTHz9uc+vAqsnh/S20+O0lhSZUcOHc4JNQmS6c480/Rgab5F25ywEi+g zWilMfM0V9S8J3+pX5li1v7LaEBVgWTgAVJB8PNODh9QnmuyB90yfIfqO9TRxScj7M0ZB/j4 FIYJw+cFv92U0lUkHtZbG5b6faWEAgs7KKCJRwsZwP8APFJcwRXNtLblfLMilQwfkEiskW1w 44Mg9jJTZLedRzA8hz08ypk5bsjm6sxtO8BXdlrcV5LLEsMUrPujf52Bzx9Oa7lo2ELm3f8A eBTtVn/iwcfrWF5UhTm1us+gk/8Ar1TlhXd89pqQ4/gc/wCNDlOSsh+0bRJoen39re3N/rEM XnTfccSfMOc/1Nbp1CCPkk/8CbNc2iyxk+Xpl/Ln/nvzirG/bIFk02ZvUCM0cs9mLnvuVvEl wLieJlCjg/dPBHNYefatDV+bkOkZjiI+VT261mkV20E1HUym7nLAfKPoK09FKpdu7IH+XAB6 d6zRnA+gq/p4wznPoKu10Qjohc5Ofs8Sj/ZJqRZg3VQD7Gs1ZMYy36VKGOMiudxsaJGg0ykj 92MgdaUTc8KfpWeGdm6t+fFK0fmddy+6tis5FGmvmN6/gKRiOrPJgDtWYtoSci6uVHbElWhE SAGlkbH940twTLH2u2Hylnz7im+dHz5flHPp1qMKUGDyPrTQkZOVVQ34UvaJaDJGWaT7kzpj sGwKUeepCu8ZX1J5pqx8/Mx9gDUillb7qED1Oand3BDkjVgD57dOgApxjt1OWNwT7Gm7if7o /CpFBx2xRqUKjKWPlyyJj/notOURE/NK7N644qFog3fd9XphgjA+YqPo/IpxYrF4sqLuJOMd QaXzEUn99tP+0apwx20ZOyZyxH8cmakKTkna1uw7Zpp63bGh7FWGPPBPqx4qTyhsByrA9NrV WxMBjZD+FMZDkGXKf7rHmk530QWJ2jVwFcyR4/unrUTZUFYHl4PV1yDTfkzzJLihn5+S7RV9 DSSaFYBJJGPmBfP9xcYqWC4XcMO6ZHIaoC7H7qmX/dOKQxo5Ba0KuOh34NO7C5pxyQghi21g OTjillmTadsgZvWs8K6KS8dwQRgKPmoEihseVcoP9pKpPqIu+b84EdzgZ/jIp4eU/NmMMOAV brVMtbsu5wuM/wASYpCIZjnOQP7jYFGr6FWZcSSaPhUBpxmuBk7AfaqybQqhRctgdFOcVKkm eiT5/wBsVLYIk+0/MFktZRn+JU4FVr4JdWqW4mmtGaUASqvXpwSemelWFleNwQMnP3eSDQ0h ZSHJUE5IY8U4sDlPF1w2g6IPst61yly3ltIJM7GwePboa4qG+u7W8imguGEnmxny3Y7X+YYD e3P5V6y0FhcW09nd2kMttOMOFADfUeh96xrPwZ4X0y7W8iS+u5EYMkUjKyofoP611QcLe8jK SfRG41yi/v5pLVGdQ5VCeTgEha57S/Eus3F5aPM1iLG98wRRK5Mq7R1Pbrj866nz0aRZBbA8 5PmIMr9Ko2+naZbSmS006COUZ2u0fKAkkgfnWLlC7LV7Gj57nhp4z7HFJK7gDLoSehCZquTu OSIc9vlIqQNKn+pMQz1+Ums7tPQ0Q/zJcAiZFGey4qNpJi/zYfP91Kflzy7gH0AqPF8DmGdM 9ty1TkOxNHIAcMrE+6dKlZ0jDAohb3qFHv2/1rRb8elPK3JUmTZnPBC1MpX6koja4I4a2iYf 7ODTo5M8i2VR2+WqxjdZdy8HOThetPYygZDzKfTAwKS23DXuWhcS5/48IfqABSqCW3PAyH/Z aqST3SHJPnD06VL55mG1oLhR6rxU8r7ifqWw0faXn35phktzn/SITjr8uMVX+0RxERiKc88n GalVYZASCQO6sgwataIaZNGyZ/d3UBPYKRU2+cDPmofYVQVIIjuFnGD6oBUwubQnLQyg+o61 EnYdycm+bvHj2BoBnX70Mre61X8y0D7jdzx59Wp6yQO3yX0z+2aEyScmQj7s6/QZoRnB5e5P sVqIHByt1Pj0zTjJIBlLiTI7NVcyHZk4aQ/dd1P+0lOxN2mjz7ioFu5mGGwccHNJ57A8Rx/i anm1sFychsZeZQ3qFzQI58fLcQn6qaqks2Tt49iaTzUjGdzj2NWm0BcaGZhhplP8qVILkfdN sR7jmqI+b5t8o9s1JtO3IZsezUuZiLhicL8yQ59icUeRIASQo/3aoCRlPEjH2LVKk8rH/XBc 9iRSkr7i0J41nBIMyH6DmnHy2GHMxb1VsVXYsOTIG/3ajDu4GWIHpTV+gNFwIiDP2m4C+hbN RCGKRiVuLsE91PFKqqi7jz9TUEsksh2KrIPUNimpSW4tDJ8QWbQRwuZXfcx+8c9jWDW7rCt5 CDe77GOSx9jWGRXVSba1M5WOWx8o+gq3ZMqltzAdOv41VH3R9BTgcNnr7VrfQyRtpLHkYmQA +9Sh415Mikf7wrEDQMOWjQ5xhuKBHFj5pIifZq5pRlLY2TNs3US91/Gp45o2GRMv4Guc8hR8 y3CAemeKNuM4kye+GrN0n1Hc6kSQngSL+NO3RjA81B7muOMDk/LPIOe71KttK6gfamA9d9ON KT6oOY64SQgcvGT9aT9z13Rn2rlEsXQHF1M3H9+mPHMpPl3MmfdqORrQEzrfNXOFKUeY4PAz kdhmuRCXR63bf99U8f2jGAFnkYDvmn7KXRhznWA5XuCfU04Ljo4JPuTXKL/a553gL6MCTT/N 1UDCy7T/ALKmo9nJPcOY6tVI+9t/KjbgffhH1FcqLzV1OFlJ+uaX+09XHB2n6oaPZyuNVInU ERtwRET7YpojhHSHcf8AYrmf7W1MDmKPPr5dN/tjUweEH/AVIpuhIfMmdSWjZfuSqR9aYrR7 gCz598mueXV9VGCFQ/Umnf23qw6RQn8TTVGS6C5kdIJHUYSWM+z8UjGRuWSy+pNc6Nd1U8G0 tcY6nOacNavmBDW0PbopqXSl2K5kdAJWjHzJBj1Q0CWEneURj67qwDq9yww9tGR3FA1HCgJb KoHbFR7Ko9yeZG/9tC5wpHuslSLfL/z3kX6vmueXUX720ZHoalGpOf8Al1h+hFCptBdbm99u ftOrexUGpI9SJ+UwAnpnywKwUvnPW3j+oqUXk3px6A1qnK1rD5rI2WumPCpj6cUqTAnnzd3o DWI1xcsPkUZ981aW9dVBSN9w7t0zWbgw5jYJJOC0iD1DYpcx4GJpD9SDWUuoTZy0W4/WnNqE vBWCMexrK8l0Gmaf3eRhvqKYZiCx8iIH6dapDVyFG6Iq3sOKT+1wf+WefqtaXk9x3L6yzSr8 piU+melDfahwJ4wfeqH9qDGPs6g+oFA1R8Y8oGkk+w00aCG67yQn6ins0qjlwPdayzqLHIMZ HHY0v9oIowY5D7k1Wtthc6LzyZHLkn61EqKxyWbP1qAahEV5tx9TTft/Py26mkn2DmReWBQM iZxx/EaAOcfvmA7qaqf2kirlrVz7KaUazGRj7Lcr7gVC5m9RcyLaodxzJIR9alRAv8Rb/eNZ 41KPP3Z/oaT+0F65cH6VST7BdGmqRZ+ZW/ClZoUH3nH41njUx0EjD8KUagGBwAT6mq5H1C6L aT24JCyMST6ZpR5bnPmOfYCqS3pB+aOP/gPWphqMA+7HNn6DFS7rQdyynkA8rKMeucUrC3fr IQfYVVbU5HOP3gHptpy6kAMNbu3uFxVWFdEptrd/4ifrSCyjz+7lK47iq8l5FJ0jmX6ikW9d eFiz7tTV7bBdGtFA6oCXVsdz3oO1G3bPm/Ssv+0JenlLj/epy6pIuQIVP15qWtQuaZmiYc8f 8Bpgks+4zWc2qu3HkL+FINSB4Nv+GKEl0FdGwrRkZQMB6A0vykY2kn3rI/tGXotqcUf2hMT/ AKhl9xTSY00aRgBbLEj8aVYiWwFYgDtWd/aU+MeXu+vFH9ozLyFZfo1G24ro1GtU6eUT9RTv s0YHNvn8Kyl1GRupkP40/wDtC4U/KPzNJvyC6NPYo+WOPb9RS7GHbp6VktqV0RzEv13VCNSu h1j/APH6PQd0bDzShgFiLDvmmO87jiFB9TWWb66Zf6Zphurkjkrn3NNRe7JbuO1JZvIYFUAz 25rF4NXbm6ldQj7Sc/w1TxXVSvYzkzllHyj6ClpF+6PoKMVvdGY10VxggH6iofIjH8C/lVjH rRikr9BkAhTP3V/Kl8sDoBUpXPegLQ0CZHsPHWmiLHc/gTU5FJilbyAi8s9fMk+m408Z6ZP5 1JigDmk4pAmRlT2Zh9DQPMBz5sg/4FUu3NLtouuorkfmTk/8fEmPTNLvn/57y/nTgtLtqlBd AG+dMD/rX/OgTz5H75gPaldfbP0poGO1NJWGSefOBjzW/GnC7uMY3j8qaq5FLsGelG5Skx32 mY9WX8qBcTA/Ky/itNCUu2qtpoJSY/7Xc/8ATI/VacL2cdoh9FqLbxUEsmzsTWd1syuYvC8m /uQn6rSi+uOvlW//AHzVWFt/bocVMFFUo3Fzsn/tG5B4ht/rtpx1C4PWKDPqFqDbS7anl1D2 jJvt02eY4sewpTqF1j91FAD6kGocUY4p8qH7Rkq6lfgfMlvnH8ORzU41O6zny4vpzVPB70/F Q4Ji52Wxql0esEQ+hpRqlwv/ACxj/OqopKn2Ueoc7LP9rXOf+PaE08arMR/x6wiqdL3olSXQ fMy7/ach/wCXaL8DTTqMmf8Aj3T8DVYCjHNCpITlIs/2i4P/AB7r+dL/AGow/wCXRD9TVbFK BQ6KsLmZY/taQf8ALmn4U5dUc/8ALop/Gq2BQV6YbFZfV4vqPmZb/tSTP/Hov50v9qSbv+PZ cepaqfbijGO9UqSQ+YvLqo3fNan8DTv7WQHi0b9Kz+p60ZIPWn7Bb3FzM1BqyAc2fH4Uf2vD nH2Jv0rOBo3YPJo9mhXZp/2pGeRamlXVY+9qcfSs0OMUBqfsYsrmZpDWI8Z+xnp0PWl/tjnI tXHtmszzKcHqfq0e5PMzT/tle9mxPrmgayCMGyYj3rNDc0CTPaqVBLqPmZo/2orH/j2x+FKN RQdbbj2rLZm/hxilVyOM0Ogugcxof2tHvI+xSAeuRipf7Wjx/wAehFZnmCgMcdqFQiPmZonV k7Wz/hS/2mG6ROv1rP3Um+hUUnoTdml/aOMnysk+opft7HrEgrL3E9Kd5lP2KZSkzQN8R0iW lF+RybcE/Ws8SZpQ2KXsUJyZorqZJx9lQfWlOo+lvHn3rOySaXccUnSSBSZoDUcc+TGD9Kgk 1CWbICog9hVTdSc5q1TDmZJuJPXmlyaaAfQUu2tErEtnKgYUfQU+kX7o+goHWqYhaMcUUnNS x3DvRmlopXsF0HWkAoApwwaqLuGgClxRS0pXBCA0uR3pAKQipTXUGOBGOKcDzUeMjHSnjirT 7CQ7GaTZ6UozSg02luMauemKdQTQBUvYApaWgDmloAg54qGeM/e4xVgUjIXBFNO+wFa2J+YY xg1bUfnUUMPlknOSeanA4pgFLSdRS0lJgLSjFNBp1U3oAYpQR60ClwDzUxsMKMUAe3FHSnZA GOe1KBzQKUdaNOpIc5pcHrRRTQ7ijml6d6QHFGalsBOTSg8UcUm4YpCBjgUueKYWzRk/SnoO 48HHJpe9MAyKcARVJaaiFNA9xQB60pHHFKyAQE9MU/BpEBJp/AFCswGbctilJxxS8daGXPNP lGApetIBjoKcBUgNP1oHHalK5pcAU9RCd6UKRznijBzTwKSTAbwaMU4rShcU7LuAzBzThj3p 4FFK3caQ0fSnAUY9qD1wKLALzSY9TQufpTsHHOKEmIaB+NOAoHFLirtoA7FJwOKUCikrgcsv 3B9BQaF+6v0FLmh7AIKWgUtK7sFhKSlPNHeluAA0o+lNHWnCiyHcdiikBzS0nYLC4puKcKMU rJ6gJjmnDikzThjFV8gFxRik69KWpfkCCgUE8UtC8wF/GikpearToAtLSCl5pIBaUDmm55p4 NUkAEUDmloxSsAmMUtFH4UAKDzThTKXNCXYLD+1JTc80vUUILC04GmL0p1NIB2aaTSnrTHIB AJAJ6A96dmthDgaN1IB7U8YpMBvXpQEJ71IMHpTgKaSGRbB3oK57VN+Aoxmi6QaDEUj3p2w5 608HFOwaBDAnNG0A0/afWjbSAbj0p2KULS4pWsA3bmmgc4zUm05pcc002A1QKXHNOA9qXHtT 3QDMelG00BSTweKXaV6c0tQAA96UD608Dml20lcBuKCMU7jOMgUpGKaQDMetGBT8GgL6mnZB caeaQLj8akK4pV96SYEeKcFp2OaQk9MGq3ANtLigdafjBpANA5pcUvfilIzQmByKj5R9BS4p VHyj6ClxUJsBpHPWgDnrTsZoxVXAbjNFOxR3qrILjcc0Yp23kUYGRSdgClpDS80o2sAoFHXv RzRTUQExzTgOaSlFDGLijFGaKmwxcU7FNBozRqhDqKSlxTu0tBC5pcZpAOaWpSbGhcUYNGaM 1dmwYo4paTvRzSELmlpBRSW+o9BaTPzYpfxoxVBoITQCaKUUWuFx1KDigcigVLVguPFBwcZU E9j6UgpaanYLi4pQAeKSnAYptrcQKoQYUYFOFJS9KV9QCgUmeetLg09wHjNLz60gU0oXmjYB cUvFGP5UbRRoAo+tJgk9aUDaeBSgMDwBipAFGRzTghzwM0qginY5oQDQhz2pdvY4pcHPel61 SsBGFxTgue9KV4z1HtSgH0NGgAFBpwHHSlApQKdwGBV9KMU8pzmjFK4DNopwFLx60H2pxYCB TSEZ+tOwcUhBNJ7gIBQTxxS49sUoHtVXAjGc1IFzRznpTwq9c1IDdvpS7ak2j3o2elFgOOX7 q/QUvemj7o+gp2aHYBRRzSClz2pPYYUY5o7UtTqISlHNFHNVe+47C0mOaWgc0rWATHNFGMml Ap7iDFKBSUoNDdtgTDFFLRQtRhS0lLyaXUBRS0UopuLYCU7FJS0ldbiAUYNHegEZxT5rFABT gKbjnrTu9G+xIY5pcUDrS8UaAJjFL1opcVUWA0iilwaM0wFFLikGadU3Q7CilFNHWnA4NDsI cBTwtIpzTh1qbjALSgetGPc0YJ700IUKPSnBaaqHOcn8aeeO9GoAAfelHWlBPtQwJ6CmwE70 oHFJzinIG7jihIAApyrzTgMdqXjsKXKwDbTgtAFKBT2ATAFMOTUmKAnNTqBCEY9TUg3L2pWU twtL5W4YLtn2p2AAxpysOmDn6UqrtHPI9TUgXvTAZimt9KmxTWAPWi99AIlTPXrT1T3NKCKU Ke1IA2UmMHmn496QjFUMj4Jp2BSCnDkUIQzGacoPpTsUCkAoRevNBHtSZIp24GhJgcaBwPoK CKUfdH0FHejRgJilAopRT9ACijvzS4pW0KQlKOtGKB+tS9BMKBgUpoxzS3BB3paO9GOaXK1u OwmKUCgdaWqi09BbBRRRiq62EJinCjFHei3caFFKKQUvOelAgFOptLmlzXAKKUc0UrPqOwDN LzTelOBoswFFL0po606hCAdaWmil6U+XqAuKBSZoB5ot3AeKOlNyc07OaHoAd+KXJoPFCkGh AKCy88YqYEMOKjxk44pw46UuXqMkxSgc00GnAU7CHY9KUUAU8CqVgEA5p4FJ9KeCe+KTVwDb 7UAYpelL16U7WATApeKOKM+1K6YC7s9qUc9qRacKWoAcZpwzRn8KUYA4poBoBBz2p4wehzQC D2pwQelPRAN9utPApAMGnCkAYFIR7U7B7Uop3AjxzTgDTtvPajZz36VIDTwORTDU2MU0jNXo BEPpTs8YKipAvtSEY7UrBch2ue+BSiM+tSml6dKVgGhMUFKkHvQcZpWA/9k/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGCAh0DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDzhYsE0pjBp28ZNKD61g2xkDR46Ug44PpV jionAGTTVh3GyOAhqhtyxPvVuICeby/cVpyeFr14fOtvnX+6OtWkDdzNtYt56Vf8rahwO1JZ WksORNGyuM5yKuSR4iY+1ZVG72GtjnJmYSse2ackvPPHNJcD96R71DyPzrSK0JLYmycVcgtJ LhQyY2+tZqcjpzUkcsqcRyFRjpT1WwjaTTYxzI4+gNTLHbRfdXNY4u5xnLD8qZLqMyDKqG56 ZrO82NGrcwxXI+7j3Bqo2nKQRuBGOMiqS6xIAM2wPsHq3BeSTqSYNnplqXJJdR6MY+lhs/KO uetN/syYNlC3J5+apZp7xc+XAD77qrC+uVYrKmzB55zQm+gWSLUGmahLII4pguQT8xqCf7Rb SNDcS7iBzwOKuW9yswGDz3FTNbxSghkB96pVLL3g0ZBabWGQQau44qtHYiKXdC20kjI9aulC vB4rOVRSBWIYZHUMm47c9Ks2ts15cCFDhj3PaoQgzx1+ldFpumaf9mEj6mYZWX5lCE1FKKbK s1qZt74Qnjhe5a8DqMfJtxj6Vj/YApwTmu+utXMelvZnWY7pBgLG0QU/n+NcfIdzkjvXRL3T swr5nqiiLJexpRYIO+KuClFZc76M9HkSKn2BCc1ZSDyotq+uakFTKPl5NDm7amNaCUSiVJhB yetWoPuj6VXB/wBHU9iatwLgD6VMTyZbk61qeHhu1+1B7MT+hrLA5rR0O5js9btpZThCxXPp kGtUjNno81st9bPbM+xHUgkVx2teFbjSR9pin8+2bg5GCp/ziu7jt2O1kk2H+IDkGqPiSVId EljkwXfAUH1yP/r1k5JMLnnCgBulTSgPAyk8VG2DISOM9qeSTEwxWl7ocdznpdME1wkUMnly OcBiMgVBe2GoaTMYr+IKP4HB4cc4I/KtWL/j+jJ7Gura/t5rI217Gk0RGMHt0/wqovSzN6i9 086iIdwPUj+ddHbR7UHFUdV0mygVp9Pm2gY/dMP61lRX14mArHOcBeOazqQcvhOfY0deHHl8 52HH44r1zXidS+GuiXZIzJZROT/vRL/jXiksl1cYMsLlumQK9s0VH1P4LaMsce+VbaGMDvlG CEf+On8q2oRlazIm9Tx2GMMgZsjIHAps0sCgxhl388Z56VraV4SudVuHFxd/ZYUwQi8lh6Zr Q1zwzp+l6bb/AGeFfMExy/f7tElFS1ZcFc9E+G0jt4J09JWLOnmKT/20krsQ3FcR8N5P+KZC MeUnkA/76c12gPFXe+wSjZilx6imlvcfnUEtskrZLlT7VF/Zy/8AP0RSbZJaz9KQn/Iqr/Zi 54u3/KsfWrmXSJ7JY5DcJM7CQdCoCkhh+IFTqBvE+9MeTapOayraZL1WMVxsYdVxUtw/k2z5 ck+tKV0JO5mSPnoaqTj5CT2pzygE5NV5pwUIB7VzPc0idHozAIuK6WM5WuX0hwYVx1wD9a6W Fsx5rqp7Es5rxoN9rAvuTj1rN8Gy7A8eeh6flWn4t+byV/2G5H1rC8Pv5GolQMZGap7jR6Gr ZUGqupHKW3/XdamibMYqrqjYWz97hR+hqkSN1Q/6BMf9k1X8O39reWOLaYSeUxjfHZhgEVJq jYspf90/yrjvB9wth441fThwtzGlzGMdyxz+eM/nSuB3+qXBtNHvLgMFaOF2Un1Ckj9a8E1T UNYmeVR4hvkZmOcMOOTXtXire3he7EYz8vI9sHNeE3MamaRjjO89/etFqhNXK4ublVVZ7p5i q43NxnpyaaJ8uTn0qtdDHAFQQBhuzkVNkidjEdmU5DYOaSO5kJIKg/jTHbrUSH94v1qGkzQv pIT1pZcsh+lKqZUGhl+Uioemw1qN0pN16MEZBBwe9el2ClIVxwa8y0+VLe+zIfl3f4V6XY31 k9shEw6U23YQl3bx3P3xz6isq902P7O4B7VsllY5Q5FVb1WaBsKSMVg7tjTOBvLB4nJwCKot Hg+4rqJ0BJ3CqU1pG/8ACM04zknZiMIcUBqnng8s4HAxVY9cVurMB24k4HrTgmSFfueKiCnN PAJPTODTAtW+nSOwZhhfTFXxD5QxjApNNvG2eXIQSM/lmtIqki8dfSs53aGiirEVaEKyRZZA ahlt3QkgZH8qh+cHqwFYbAMa1h81ZFXa4BwQfWrCk9M1GM96dz1xWbmwLNv80yAgn5xVq/XZ OwHTJqgqk4yOOO9TBSTgZOfWhO2gHQ6do8UYhuxMS+NwVhkZz/8AWq/ceI30RxLcR/aIzztS MZAp1oMWsYx0XH86w9ffMwX0X/Gq0NqersP1vxJpWvTm4s1w33Tuj2nPHbFY+4E8Gq2KcKrm 7HrUaSgtC7biBplWeQpGerAZxWqukWkiblmbp97HWsFT8wOK6ax2tbAsO1cuIlLdMVdNK6KD 6YVb5ZNw+mKcunyEbQ4B+la6oCcgcU9lAXgDNc0cROOrdzic21ZnLrot6CqtKmxT0xWrBo8x THmgcdxWkqdMipj7ntitPrktrGPs0zJl0i+hG7yxIvqpFJaaaNQSWJn8thxtI69q24Lh4XwC SPX0qOZpZrlZUYAg844JrWOLfVCdNdAspPFelQrFbXUc8IBwsoGUHPAPeob2PW7k/aNQkDAD GFxgfh+NaiSuq9efSpIbprd3aTaY2XBQ8g81X1qPVE+yOZUDJB6jrT34jNb13Bod2xe0UQHH MZyQD7Gqx062KgJIOeoYVf1uD2BQscpF81+ig+vFbv2djGNycEVsR/Dm8u7+DUrS8gigxkw7 c56Drn2ro28I3nk7FWNjjHWumm1JXKnLSx5dqduqxfKOpGaw4o3OpW8SAgsx59ODXouteB/E OwtaWiTEEHHmAVTsPCOtxSCS60pkcdPmBrRxMkihb6bcGMFpPyr0jwQ5/wCFezW+Tm1upU4/ 3w/8mrATSL1RhrV1/DNdB4JR4NK120njeMpceYMjqGReR+K1VPQzmcxBaFDIVXAbJAHpWTrL yGyw5JCyZwfpiu4gsgvlkLhWrm/FdosNhM5IABByfrWc1d6F0nqbHw5l/wCJPMgPS4P67q7s HivNvhrcq9rexqchZQcj6N/9evRA/FWtDSsEhNMCqeooc5HQ01T9aTkjAeVXp0/Gub1eSMeJ LUMQEjh3EHox+biujyMHPpXBeK5CupyuDjaFH05P+NTfUaszprbU7LUFElvbiGTo4/Cm3zO0 RVBkk1yfhu5LahIpbgoT+Vauu6vLpUcMsMQlZmI2k4xgZqqruTFag9tKAd3WqktpNgkZx6Vi SePNROf+JdEvv5gP9KqyeNNVkB+WJBWHI2dKg7GtJ4wvNNVreCzjDx4Uu7Z9Of1r1LTJTcaX azk5MsKSH6lQf614WNa0JpQ2r3EklzNIiGGFTnJ4HI/Cvc9NiS3023iiyIkiRUBOcLtGP0ro hFpakTstDC8S5E6HttOfzrDsx5V2jgn0roNcTzJzkdVIrn428qXZtHHSpm9SEd1ayB4wag1U 5NgB3uh/6Caj02XdEAfSpL8B7nTF6j7Vz/3ya0T0EUPEmpW2l6RLLdSBdwIRe7HB4rxyTxy0 viCLW7DTWE9iPL8l3x54G4EZ7D5s/ga0PFV1MNRv7nUr1pfmZIlPAQbR8ormrHTWkthdmZQZ RlYsY9+fzqVe92I6eb43yavFJpcnhuS280FWk8/ds4/3R61yUl2XkdgeCxIx7kmn3WjwwxyX S3GXJBMZXp+P4Vl5y+0dz1qoyuwLImmecLCoZ9pOD6DrRHLIZHEgUOMZAqkX8uTnup5p1qRl +p6d6t3YtDELHJpoPzA0h6n60meako14DuhBNOcfLkelV7Rsx4+tTqSRtNZSTuNMpSM8U4ZV 5DA59eld/oN9ZXunIzQoZR94/gK4/wCyrN8rDNbWkWLQkLGcAnOPWjnvGwjqFKghUAAPQCrE kObViRyR0pLS0UKGb8qtyFBEwJwMVmo31Y2zjLuPbI1UXGeK1b5kMzBTms91BrKV0xKxmz24 I6k8VU+yhs461rvHwapMpV+O9XGd9hlF7N0yc55qNRtbkY5rVCE0yS1BxletWpvqBn7vKdZF 7DnmtOG4+RWBzkCqMlpIo4wRii3crlD1A6ZquZPRCNxLhWGGqX7KJl3AVjLLzWxYX8Q2I4If 0Pem7IZXNuVPIqe0tvNuEj/vHGatzFWG7aKqmZo23I+1h0IrGVrXQbks1t5MrJ6HGadFAWkX 60LdtNJukO5mPJrSjC70AIPI6Vgm5PYaVjWgBEYHtXN64+bpgD0H+NdRGPk9OK5HV23Xklbb G1BXkZvenCkHWnDNRc9uK0Hr1FdNpbBrZR/siuZXrXQaW2IuhrGttdGWI2NbKngHmgr3qIEk 5qUDPGa856s8+yGnsRThgjqM0gBPGaCpj5NCTYtBApLc9PanhEVgQOfWmhzjIFJvIbJGKrmS DctIz7cryPWkflckfhmkjcFcDgU9E807ScA9qFqIqZyx+TAq7bElCnU9qSS2ERwDn3rNvdYl 0kjyIFmcjIBbGDz/AIVtT3sgvY7a1stR1Kzt0DNYwIcsFbLPz+lbJ0+8SILb3bKwHU85+tVt EupruyQzxPGw4BPcc81rqMDqa9GnFpanPOZAV1JEUpcHcByMDk0i3GsorEsrEdBxzVr8aUH3 raxHMUv7R1dTzaqfxFN/tm88zbJZbWPcHrWhuNRszE9KVh8w63uWnTdJAE9qJ7HT7yJorqzj ljYYZT3pVDHtTwD6GnFogp2Gg6LpbyPp9ituZDl9pOCf8mtACP0pmCOvFNzVOaAJRj7o4pme O9Y/izX5PDejx36W32lfPWN4wcHac5I9xjp3qXQ9ds/EOk2+pWMm+CYceoIxkH3BOKm7YGmT hTXnfimYtqF0D2OP1NehP90/SvMfEMm/ULzH/PVuPbcaUdwRF4XmJ1hh2EZzW5r6QXNxZWs0 zRmZiqlRnPB/wrnPDO5NZXI+9kDFbGvOw17Rgv8AfYkevytWlTYUXqKPANgw3tfzHrxt61RG meG7W7e1vwcA4Ds5AP8AnFdczrDbs8jbUAPP515v4gtrTW7h0uCPKLHH61nBu5q5ux3Oi6Ro o8y40LToLzY4Dt5mdrY9/YV0f9oeIIxtGkrtHA+cHivINDtB4bWVNMvpY4pGDFFyMnHWtxfE 2rjj+0Zv0rrVjBt9TuLibVblt02myIf9kg1Re3nL7jaTZ+lcwPFOsDpqEn6Uh8Wa0OmoH8UF JpPoJNnZQajqNoMR6bJIB0zT5Nc1Oea1kl0d0+zymQY53cY9OOtcUPF2skHdfsP+AinDxbre eNRz/wBs1/wqbLYfMyDxD4BXxNfveXV3eQFn3KiR8JwB/TrVFvhrIsaKmu3ibECZaEdB61qn xbr27jUgB6eSv+FI3inV3V1kvg4cFSNgFFn0FzM5HXPB+oaPbfaf7Wa6hLAMpUDFcu8jKw55 Bro5NDka4kcX0wRwB5bSFlGBjoazrjwtqhc+Q0RT+8x5NUlYtO5lFzLyD7VatAdhz1wKsR+H dQhX960YPtU8VhNDlWGeB0qvUTucqep+tJ3pzdTx3pO4qCy5YnnaauOjBuBx65rPs8iZT9a2 13MuQvaspNgiCJWV857iu68P+TNahjGNwPXPsK41l2jpitTR9Yl08FViLjPY0r6DsdyQqDPa sq4ulncxx5U+9Z0viyXGDZnnrzVQ+Ijj5LMLn1NR7RdRWZdvESKPlQSe9Yc7BGqSbVZZSS0Q /OqE8/mcEAfSp5l1GotkzSApkd6hdN6HAyfaoQ527egFSQ3Nzav5lu6q3+0uRSemqBxY2J+S rDBFWjtKdRVW7up7xjJLtEnHzIMZqCNvMbDDa+eOetGrHYu7QeKo3a+W4PGMUMsgblm/Oobg MUPJziklqNJBNE0fzgg56c0sd1yA/NMnjPllwccjB/GqxrZRuS1Y2BdyeXgSZX0qWOQyL61h rIRxWjYS5BHXim6asFzUWKdV3rHkVe0ozPfRh02gHPX2qnHNtOCxHNbGlKWuA2eO1czi1saq VlY3h/qyfY1xeotuupD712bfLAx9FP8AKuIujmdj6807m2HV5EAFOApuOacBik7HrpjhXRaa cWwwOo7/AIVzw610GnDFomSSMVjWvy2RhiHoaAbA6YNPDBuOhqIAe/408Ke4zXCl3OC46NQh 69KlY5HrUQI6A0Z29TRfXQQ8rxTEALYzUm5TyGB9qZFtaU9qnkYD0wXEeDz3q+kflEcdKqDC ngg1OsyunJ+YDBFUou2om2Pu5iE3AZwcGuau7aTUNSQAAEvj9G/xrpYpYnfZJyjcGnpZxRah AYsFC4wCPrWlGFpXEzttNia3sooyxJVcc/jVzNQRfcGDkVKDXqRehzS3H/jRx603NHWnckcG 9K5nxt4qvPC2lxz2Vot1NISArNtC4HWukxiuB+KhA0yzHQ5Y/Xg1Or3GcPP8Y/HEjkwWdlCv YMobH6imL8WviARnFh/37H+NcqWG9vmB59amjPXkV0citsTyo7Cz+M3i+A/6bpNrd+vlsE/x r0rwP41/4TPTZ7l7A2csD7HjLbufl5zgf3v0rwZXAflhXq3wgbNrrHp5yfySk6atsFktjpvH Gk6hrum2VnYAKftAeWRjwij27nk0/wAL+H7fwxolvplu24RDLPj7zEDcfxIzWrd30MF9DZOd ss0TSqP7wUgH/wBCFHPB5rNPlQyWQnyyc9j/ACry3U2W41SeNmKh7hl3DqAWavUGyUYY7H+V eS6k5j1idSQSJmOf+BNRGSb0GineW91oXiy4gi1E3NrC67GaMKSCqE5/EmtrVrmK+s11DTrg mayQFjIuCGOBx+Zrn9VnMmrzyE5JIP6CquoarDOAgRkcAB+MAmt7XWpDWp02p69bXFnGsUsm /b84bpmuYkud8uc81SknjAGyQEH371CkuZBz+tOMQZsh5cdM/SmGaVT/AKt/wFRpNxWrB4p1 C2iWJWgKqMDcgJwKt3RLZm/aZP7r/kaQ3bn7yP8AlWz/AMJdfkfMtv8AXYKD4tuiDuityB6I KFcRjfawDghvypTcHPANa58VTcj7JbH8B/hSDxKTndYWxp3uMyftq45P6Un25OoatceJ1A+b R7Vv+BUHxNbH7/h+1kH+y+P6Ue71GjLiuRLKFB5qb7RtJGfarj6/p8sTpH4fjtpD0lEuSPwx WN5gkmAPAZufalJRtoC0LTXSlsE80faiwA44HpUgsrIgZuNvqetQSwwQylIpd64HNSlbcdzk W0LWGyBZ9+u4U4eHNcY4+yAf8CFeiDeTwx/On4kxyx/Oo9r5Gh59b+GddSUMbZcD/aFa8Wi6 zGQVt0Ix3fFdThj0PP1pQjdzUuae6BJHOHRNUkPzQIP+BUg8PaxGwKRQlc85eum2N60uw+tS pRWyC5zv9g6qw+7EP+BUf8I1qhHHlZ/3q6QKfUU8LSbT6AcsfC+rnoYs/wC9TD4S1oH78P1z /wDXrrgp7mnKPejTsNM5AeD9ZPWaL8AP8ad/whWst/y+QjjptH+NdgqH+9T1Ug/epc/kJnHj wLqp5bUYR7bP/r0n/Cv79x82rxKw7iL/AOvXaDnvQVPZqOZdhaHIx+AdQAw+uROPQwD/ABpk nw7vZG51tNvoIR/jXY4x/Ec0HjvU31CxyT/D2aSMp/bQAJ4/dDiq3/Cq5SedeyO/7r/69dwv Ip30qlKwrHDL8KTj59eYn2hx/WrEHww8rlddk6f88xXaA470v86fOyrHHv8ADCCTJk1y5Pts Fb2m+GotNgSFb2SUIMAsOcVqjinUnJPcCGTTIJYWjM7ruGMgVhyeArGaQu2p3Az2C10fvThS 07FJtbHM/wDCutNJOdVuvpinr8PdM4zqNwcH0rpQKdRp2K9pPuc2vw+0xTn+0Lk565rSt/DN pbRLGLqVgBjmtQD0pV6Y5qXZrVEucnuUP7DswfvzH8af/Y1rjlpB+NXwPSlH61nyw6IFNlBN BsOpklpR4fsM582Yj0JrRApTj0quSHYOZmb/AMI9Y5OHlH40L4bsBJuEkp9s1pgD0pw256UK EewczKH9g2PXdLn/AHqki0LT0OW81v8AgVXAAKcFFHLF9A5mUjoNiH3RF1HcE1Zh0+1hlSRA 5ZDnlutSj8acPamoRXQXMy8uo7RgW3/j1L/abZ4th/33VHPuc+lKD65qrkl7+03zxaj/AL7p f7Tbvaf+P1RH0pwPNNAi8NS9bbH/AAKsfxFoun+LLVLbUPMjjQEDy25561bFAApN66AcP/wp nwpuP+k3v/fVL/wpjwrji7vc/wC/XcZ5pcj61aqPZgjh1+DPhYD5rm+Y+oeuo8LeHNO8GW9x BpgmmjnYMwlboRjp+VaIIA9KWq9owaRU1/RrTxLJaTzy3NncWoZY3gbkBiCf5CoIdBuoUCx+ IrwgcfMgPH51pjHoKXPpWcmpboGrlH+yr7aR/wAJFcj/ALYrWNN8PLG5leWXWr7zGJJYKOpJ P9TXUYBpcr0zRHljsieRHGz/AAu0ue6e5Otaj5rkbjxg4x26dqqT/BzQ7l2d9a1IEtuwCMD6 cV3uRmjNWqjHynnv/Ck/D/fWtSz25H+FRj4JaWrZTxHqQHbgV6PkUZFUqrDlPOj8G7IdPE+p Ae6imH4P2SnI8V34PvFmvSaPr2pOpJi5Tzb/AIVBaqpI8WXuB/0wzTT8I4AMjxZeD621elnm mSEsOlHtH3DlR5ufhAGGF8W3APvag/1pD8HblcbPGDge9ln/ANmr0oMMd6cD6k4o55ByI8w/ 4VBeA4/4TH/yQ/8AsqafhHqhI2+LlI9TZY/9mr1LOP4jRnPejna3Ych5ePhHqg6eMI/xsR/8 VSN8ItYI58XQn/tzA/8AZq9RIHrTcD1pqb7hyo8s/wCFR64udviiE/8AbqP8ajX4UeIkJ2+J Ief+ncf416wBjo1ADkn5yKam2CijzHZntShcdqeC3PSnA9twz9alq5RGOvFO5px3DrigZNZt MAGfSnAeopADTgp96aAFGexp232oAbHenAE9AaNQDYf7ppQp7DNABHqKcM+9J6jFAPpThmkU E07ae9K1gFAJ7UuD6UbTngkUu1h1NMAAPQ80u0nrgUm0+9KEb1oAUJTgppNjUbT15qBjgGpf mHam4pQpz1/WqQrjwW704bjTNpzgml20WGh4zTsMR1qIKPWnBff9aHYCQA+tOG7twKiAp4GP /wBdDYXJMHPWnjPqKgApwGO1CtYLkwz3pwzUQxThjucVNkBMPrTueuapm8tFmELXKCUjIXvU 4KnkHNPQRMM9zTsHs1Q5HbilyO5oAnAb+8KUKSfvVCG96duHrQhkwUjuKcAfX9ahDinBgehF F7isS7SaXYf71RZA6UoZfei4Eu04+8KXaf71Rgj1oyM09LhZkoR/7wo2N61HketLu96LoES7 f9qgKf71R7h2pd30ostwsSBT604I394VEGo3c9qeyCxKEf8AvCl2OP4gajDe9Ab3ovcCXa3c ijY3eo93vRmlogJOexo5/vVHvpd9JXAkAJ9KAG/yaiLd6XfVeoEoVulLtYcHj6VFuoDelFwJ Cj/36NjdyDTB05ZRnpk0pO3gj9ad9NAHIDkjHIp2D2qHcA3ufSl3n1pNsCXB7g0mD2FMDn1J o30X7gh+1vSja2elMzx1NJuPrVXVgH7W/u/rSio9xoDe9ClqFjzkPnrxVC+s3MiSxOWUnkDr mrowCeKkDY6ZH40XuBFC0gjAY1IHbtxS8GgAelILhuf1pwkfP3qBilAGaQC75P71AeT++aXA pQB6U2xAJH5yc04SP2fFJgU4YoWgw3N/f/SlDP2Y0AgdqcCKm4AGf1pQzUZpc49KPUQoLetL lvU0gYdwKXOfSlZMYuW6bjS7n/vGlDClzzTsrAJknqaXB7GlB9KUUJgJz6mlH40tKCaltXAT n1pRTs0oYe1NghBkd8/WnZJpARmnZo0sMMUoHPU0A+9Lvx3yaSQxwyO9OB5+bpUe7HJIpR8x 4GfpV2sJMxrjQZpbvzo8GPduDFuR0rciVwgDHsKVRg1IGzSSQ7ibT6mnBfr+dGTS5yaYgC08 DjvSDPrThmlYLAAaXaKAacDnqaQIOnrTwM00HnrTgcUWsMULSgYo465pc571VhJsPxNKKTOO 9LmpAMA0uMdKM0Z96NWFwA+ppQKQEUoI7Gnqwuhw4pabmgGmA/Aoxmm7s9qUH3qWKwuMdqT8 KXPvQM9aL2GJjHQGl4PrS/jRmgBOPSjv+NLnNHFNpBc4Lx3o+tahfQyWUby2zRbERH2kPlfT 6Hmun8PwajbeHrK31Ni16kKrIT1GFX/69a4lYdGprsANxz/jV3srWFoIAQPelAJ70o3HkjGa Oc8CosMUD3NGPc0uT6UU0tA0EwR3o59aMe1GPrTWghMkdxQCexopQcU0O55vuINLuPpUfOTT s81LVhDw57Uu80ztSZNJXESiRqXzG7YqHOKUNSGTiRs07eRUAb3pwciqAm3mnB/eog+e9PBH 0pPyC48Nml3Gmc59aM/UUtWOzJN5pwY1FSg0vUTJd5pd3vUWTRnHai4E28+tAc+tQ5pwOKFq MmVjTwzeoFQA89aeKdgRKH5608OfWoRSjOaSVhWJd59KcGJ/hqIcU4E+hqrXGrkoI9KcHHpU OacD70tg1JN2e9BbsDzTASe9LnHfNNAh2092zUq8dKgGT609SRSbuFifNAJqMMaUNRqBJk8+ tODE96izTgc96V2gJQx704NjvUQLd6XJoTuPUmD570oOe9Qbj60ocGqQE4YgdacGPpUAanBj SbET7sUA1Fupdx70XBkgNLn2qPPPWncetTYLjwTS5plLg0K6AfkY60Z96YM9xilGfWqTYh4a lz70zPqaUDNF2A4E+tLmkAJpQp9KQxcijNJg59KUA565NVa4Ds0bjSYPpRj2p7DsLnikLZOK OTxQBil0FYUADpQBzk80mRmlx70BoPoBptOANMNEG4+9G40UYz3pNsTYEtTSTS9D1zSEEdxR dgg3HHNAyaCDigZ9BVoZwG2Cdj0hc9COhonsLq2AZ48xno6kEGoZI3Tk8r6io453jOxZGCk/ d6ipvfYSQ7FGKf1pdoou+oMjxRgCnkUAe1WkFxADinD6UYpwB9Kl2QCCng0gIFOzSauFxwJp wJNMzSilYeg7ApwA7GmZxSgkUtQHY59aX8M00NxzRupCJABRj3NMDAU8MaqwXFxxThmmg07N DiA4ZpwbFNBpRj0pp6APDU4Gox+NOFQrj1JKUN9fypg5NOyR3p6hYeCKdtHrTAT6U8NxnbTS BDgB2pdtNDexpwPtSQx23jrShc038KXj3puzEh22nbaQH0NOGT0NFrAtQGaUZ5FAyPWlzS2H YXAPWl2j1oDH0pQ1PQAC+9AQ9jTs+1OBFC02FsNwRRzT8jtSincGxgzSgjPf8qeAKX6Ur3EI D9cU4sB3NcX4x8dXXhu/SzsrOOdgoeRpH28HBAH510mjapHrWkWuoRoU8+JXZTn5SVUkfmfx ocW1dD2NEc9zS8+tNGBThUrQGOzS5HfNNpelMEOwOxpdvpTOfQ0uT707gSAUdOtMyaXc2KXQ B/WgZpgye1KCfcUJMB/40df4qbnH/wBel3E+lUgHZ/GgU3ccU4Nx3oFYXj1pQR600N9aUEEc Zp2TEOzzRkZ60386RicUrWAfmkpi8j0pc465NFkApFIM+9JkZ4BpQx7GmtwPMEuCoO01l6lq clqVkjTzHB+6TgGpVu4GJ2vj2NZd/vlk/doXx6UKKvuPU3tM1ZdQT54TC/Pyls9K0cVz+iRk soZcEZOK6QJxVNBuMAowRUnlE0vlH1pN22ERgHNABHepCiopZ3CgdzWbe6pFFbyPbkOyjvSu UkXxTgcUqxHywzqFOMnn2rm9Tvrh5ykb7YAxH+91os+gWN+ecQ27ygBtvYGnoS0UbkYLKDj0 yK5m2la5aG2ilDSySAbXOB1rp9QP9n2ZknG0hQFGep4pOVtx8pXudRgtOHYl+ygZNV21hY4X laHp0Getc7LeK8zP8pY9880sV3FNcQRXcqwW7SANIeQvB6+1JO4JHWWk0s1skkqbXYElR25p 093b2q7p5hGKXU54dKg+aaKWQ8IEbP41yU7C7l819sjY9cYptpA0dTb6ja3LYjlyPUipIrpZ pHWNSVU43eprloBLPm1tQFnkIC57c8murtrIWVqqStt8sfMW9eM1L0Fyk2TmlzWFeeIHRith AsoH/LQtxRY6tqMz5uBCYwPmxwRTvoCibwYU9X5rOtNXi1GaRLe2dY42wZSeDWkqH+9STYNW FDZ60oIpBHk9RTxEcVdhXFB9sU4NQIyKcI2HNTYLiBuaeGFAjY9+KcIqdmguG6lDe2KXyj60 CI560h3Fz3zTt3rSeSc9ad5ODnNCAAc8CnZIpPL96cIiO9AAGx2p4akERzTxE9AwDfSlBPrm kEbjnj8acEPegVxc0ZHelCkCnAHtSsF7jRjsacCM85p20ilC1YhB9aXPPGKUIfwoCEnpRYLm XrXhnQ/EflHVrRpZIuEZJChxxwcdegrRtba2sreO3t08uKNQiJ6AAAD8gKl2Uojbtii8tgFw DRgdsUmxgeTShWz2qbAmLtx0xRtzRhh2H50oDY7VWgXF2n1owaMHuKUFuwzSskFxuDRTstn7 tLu9qdguNFL+dLu9qMn+7Qh6CUZp+44xikLc8Lmk1Z3EAJ9KMilLY/hNIJAc/JSWohRjPWnB s0zd6r+VIZWB/wBV+tUk0BLuo3GofOY/8shj1NL5jk/c/WjUCYk0w+9My4zhc0Bn7oR+NVe4 D6Bz3xTfm70Dd6ZpJO4Hj7wRPn5cH1pbJfInJDZA7/jUjxFc5Bqk9zJFcBEAwx5JosM1tNiI JkI5yee3WtPzGAx196zLCTy1wZNoPUE1bnuooYWfzFOBnihu24ImkuCik55qRJGe3SUOW3Cu aa+NyTuO2t7S3R9IQvNCdhIJ384AXtSs7XGlcx9YvJpW8pfljA5OeayWuoFhKTbtmPmZR0Hr Tb+8eSc7SMHrVF2Y9TSUWUkdZqPiTTpLEiz1FLiRsABRgj6iuTaeWRiWbOT3NQiONGLhFDHq QOtOyB0FPlHYcyF1K7tue46ipRLdOqi4vZZ1RQqh+wHH41DualBO3B9KTimBKME9B9acVDqV YAqeCDUIOKkUUNIa0G29la2rFoYwh6cE1ZXbuzgZqJVFO8kt0ODUNLqF0T7Fd0ddySIyurqe VIOQf0rRlvtWv42hvr/7RDnKqUCn8T3rPjjeMc81MjnpnFZv0Bq4n2Vt2ASuOhHarMNoboJY STMgnIQyg45/yKEJxgMKc6rLG0b4KkYNDmlsho6sWH9iw+VcYt0TjLHrWTdeJvs7kQWbTqD9 7djNc9JHGHWJ9QuJHH3Y5HL/AM6t2nhrxFqjkafYyWqfw3EzDa3T+HrVxlzEuxvaZrp1Jght jE5zxnOK0JL63iufs7XKedtzsBzxUdh4C1eCzMUuoRmSQEO0KBTg54B7cHFaGmeCrfRkKwWQ J/id5NzH8zVcyW7FytkKzMxxGrMfYVdj0/VJV3Lbcf74zWxBlDsVNp74FWlyhJeU596zdS2w 1Duc26XducTW8q/hmmC5BbGcEdjxXWibaOXOD6c1DLHFcjDwI7DqcdaI1O4OHY5zzeOh/Ork NhfTruVFVT0JNaSaVao+4RgN/vdKtC1GOGYfRqt1F0BRsZY0a96+bHR/Y933uYxV+bzlAFsh m9fnAxUJlux1gUH/AGnFSqjZXs77FcaVcdBcIfwpw0q6P/LaOnJeXDuylAgU4JHzVYwSwR/v HkHtVcxPLYpnTL8fcCyD2NQvDdQn95byKfbmt2Leq43DjuDUqyOTkS78dqn2gON9jmPtAU4b dn0NPM+1C5yFHJwc10ztC3yzKhz0BXJrF1fTxJbv9lPlSdgBkHnpTTixKPciQB4Y5lu08uQZ XA7e9KEBBIu1H1WuastRl02dlaIvA7YdOhU9Nw+nPFdEZ5lVGWYFJOU2ruyOtF9bFKMS2lhd SLmOdWH0oayuY8eZMie+Kis9VJQHMjA/xBCP0q8L4SJksSCcYKnNPmaBxRWMGOftan6LQLa4 K7ov3o9F4p8xlUB4bR5R3+fGKRbrUgp2W4jb3bNNNi5YldpWjOJI3U+hFOV3b7qMatDVL5eJ 7WPH94VNHeGX5gUkXoR0ou0hciKYWY/wEfU0pEgH3S30NaSvC/BjKnsDzS+ZgYWPn2FL2nQO UyjLtOG3D2IpRKp6Gr5ZmPzRnHqRimNArDPkk+4qfaE2Kof60uT/AHiKcbdGHyl0+opv2aX+ Ehh60+e4WF3HpmjdUbBk+8G/KhCGONw/E1aYrEu4mjLUot5HAK4P4in/AGWb+6PzFNyHYj59 KXcfSn/ZJ/7uPxFBtJR1XP4ipUhWYzcfekL881J9klP8P60fY5v7v60/mFhgYelOE3oAKd9i mxyn60v2KYfw/rQpeYWGeZnqf0pd5A+8ad9jn/ufrS/Y5v7h/OjnCxFvOSc0eYal+xzj+D9a QWc/9z9aamhWIvMY0olI7kfhUn2Ob+5+tL9jm9KFNXA8Tiu5FJX5gM/WmmGaW48wKCmeTmpL a9gujzbMh+oNbFum1fljRgfUitHHl3RpoypYNDdymzuF+R0b65xxWdqGlWGkK0qSOQBzli2K 6JY2Em428R/4EBSXCK6ki2Rfq2amVmFkjg5NQjlJVAdvuCM1UaC3kl80od4PUZruTH1Hlxgd 8Ypv2U9UUEe4FCSGvU417qNAM7sgH+E1F9qUnADdPQ12mWjPKRkehUUhlPQJGPoBT5ktBWXc 4/zYyTkt78GkNzGH2/NkHH3TXXlpMZAQfgKUXMwGBsP1UUpTXQfzOSWbd/C4/wCAmnh1JwyP 07Ia6v7VcY4aMf8AABSi8u+0kf8A3wKjnCzOYGD92OQ/8BNSL7o4/A10wuLth80kWPZQKU38 sa/NNGv+8oocha9zmhjurfXBp6AFeHYfhXSwXWq3m5bCye4YAnd5YVTz6mtzT/DfiS8RZdQW 1sIigO0KHbP1+lP3bBY4ITImQ8v5g01LuaR/Jsbd7qQttCxrxnGeT0Feu2/hawTHnLJeEd9u 0VrW1lHaZW3s47fcMc8k1m5xQK55LYeFfEmppmdItKHrLiQsPoDxW/ZfD2CDbJearcX7gDMY HlqT36dq9EFirctH5jH8BSm3iTkokeOuDmk6itoi9DB03RrKxYi009Lck53dea20V1GWut/+ yFwKd5Ubcqz/AF20iwcHY20Z6kZrByb3DluLhmGTx+NRbWJOY2B/vFqnClOWIk/ShWXJDYX6 GovfYLWIyGA27Mn1WomRTwIdxz1Jq59i80HM67fTNSCOKIYaaIfjWiv1H6FBLJ35ZhjsPSpj auibmU4A9adNKQALfULWI99w3VWm027vQPNvw6Y4EYxmmkyuV9SlLrimUw29tI5HBMnyD86Z JqMhQ+WUDjqgkyBWgughlKnJz3LE03/hG4EOfk3A54WtLIacTGlmjuIR9otgLjnKxTY47c0+ KwtJ0V2R0cdmkJq+NFlimLxvFzxjb2qVoTGuCoYnsKdl0CTS2GrdywgQxMgiUYGBSI8txOqN ypPO3imskgGNi89AKs2UToSZQNx6KO1S0rGTZehgVUAK4HoaryWyTSE7mjI+7tNWEjkYnHHH QGmqpDnGfTpULQdyhe6HPNJ5trqs0UuOSUDj681AsXiG0jCzXMF8gx8zJscn+VbsZBI52n2p 43biXI+U54NUrdQPNtT3yN5ktuYJGOGQ85NJpGoS6XG0KTslltztA3GNsjke3tXaapZR3cTG VNynp2NcVdafNp0xTYRA4yrZzVtaCOhWTVPIw2prLn+IKoP0ptudThm3rdLtP8LANWTo+oxW c8cF5jyZX2hj0Uk8ZrsXtV2hlIK9iooi11KKqXWpHrcIfbaMVIt1qH8U0YP+7U8P7voePcVK Zcn1/wCA1RN0Njup26yo3qMVL5rN1AH0FIkiA5wM/SpRcqOqfpQK5Ey70ZSzYIwcVEvlwxqi syhRgdTVoXduWxgg/SnGW2bggj8Kmy6AZso1IO8lrqMZQgARTRj5T6g05PtJt1WW8X7RxukR OD68fnV/MJ6HP4UzYmcrgH1pcqBB5yBScO4HtSefEy/6oAH3p5HGCR9ai8iPJJXefXOKVrbD uL9pIGxZAo/u7c/rWZe6XZ6ipS6txIhPup/MVrqkQQhiMk08eUFAPOelHMkI88vPhdoc7MbW fUbLJz+6mJx+dZknwlA/1PiDVCPeQCvV1jXkDOKeLdT0HFaKqmS4njp+GEkZ513VfwlpR8NO x1nVTk8t9oHFevtbqc/JmoXs43zvtgPcGqVSL6C5TyofDJcEf29q5HoZwBSp8MF/i8Q6uo9p hXpTaW2chyPQGofssiH95A4HqKftI9hWPPh8NSpwviXWAP8ArrS/8K2bP/Iy6wffzq75Xtlc o3mL6Eqan+zwP92UketP3XrYlo88Hw0A+94l1gf9tqX/AIVqcf8AI0awR6ebXogsIiP9cwpf sEI/5bOfwpe6Fjzp/hw3/LPxJrJ+s4pi/Dq55A1/Ws9j9pFekf2dbn+ORjS/2UhPBcfjU3jt ZBY86j+HM3/LXxHrIz6Tinj4cHcceJ9Zx/11r0H+y1H8ctA0tuSGkx7mrio9kFkeJ/2faHIE Dgezmgafpu/EiTZ9pWrRVTjpVaT7/SrcmyriL4e0icBmhmI7fv2/xqUeHdKUHZHMOMf69/8A GprY/hVoZ7YNJtoLmS2jWqE7VfH/AF0b/GpItC0+SMO/n7s9pWA7e9aJDdMChcquMUriRhTa bDC/7vzMDuXJ/rUX2ZPRj/wI1s3EcjHKgVWaJthyvOOlUndajuU/skY/hb/vo1EbdVJxuH/A jW48avFwgBqkYyG5Wp0uBniFfUk/U0/7IjHBlKepYmrgjwRgVM0DTkeao/HvQ3YaLlh8ONN1 Eh7jXZGz96NGwK6ew+GXhSylWVbfzZR0MkjMPyziuR+yxocquG9QSCKt29/qtoR5Oo7Ium1o wf1rllWd9DXkVj1G3gNtAkMWfJQYUKAABTtkOSzP83oTmuBt/Fl3bIovCZSB8zoMD8q3LbxZ p8qqXcBSuSwBxWDqNvUFE6QSyqh2iPjouetRG8uYzkWu3PXnOaitrlJ4Ent1VonGQ24cio7q 9uIWLJMxUnAiWPcT75oVS+hXLYs/bS65lPljuCadA4PzoiDI4bNVYpLiaPzJYCvB5cf0qOSC SU8s78cIo21egjQbcx+dix7AGq9xdm3ikkeCYRxjcxA4xVKRdRt1HlWT7s8DzB/OmtqVysoS a+jQggGJU3nP1qWMRPFfhoRCSXUMg/whWqb+3/BpgMzXcKJjdk56VxmoSw3t9MIoNmOCQOpw OaoQ6VEjmWZULD7uec0uawrJnaya94Lnk2JqSl1/gy2fyp39h6Dq7wS29xK4nOFKk4ri5bPT rkKtxaKdrB1YcEMOhyK3NE1P+yTsTLZPyqOn+eKJVLaopRRuWnh/TokLI6Nbrn52Xk+9WbeS 2u7o21tqSIydFPce1c7qmpXExYt+5ZlKgK2eox0rlLjTbWRVid2jkQZR1J3L1Gc01Wk1qVdn rc1vHEGS5uXQdwp7VjtqHhyznfzNS2uOzMT+P864jVPiFHZRvZKXvJ9mMdySO5/EVxUkWo+I 5SJAoBkYhR0AOe/rg1UHOe6siLo98OpWUFrFOk6eTKfkYHJamSazYwwSXE0yJGi7nkbsK8Us vCGo2cOIdWaKORSskW0NgE/w88H3rStvCdn9nMVzf3c29cSAyHDDOfWqnFx6i+R30PjPwpJe Dfrls2SAiA96301ayupg9lcwyKq4BzgGvGp/A2jSFhCDF6Ekn+ZqDTfDFxo90TFeM1rkkqBx nsapqLV4sm3ke8W+x1Id1Qg/KqNkmoBLGt26R7zID68YrzT7RczxjbfNkdNnBpvnalA2+K9d ZCOCwzzWSk0PluerptVfmBB9DSuqtgoBt71wFp411qwXy3s47zpk7wv8xW5a/EfRkhH9oW89 vJ/EApYfoKt1UtwszpJIV253YQjrWJe2EF3HKGXcwUgZ4qzB438LXjRxrqKJJICUVwRkDr1q 07WeoqTZ3schIyFB61Smmhanm93aNkxzEEp0PrWz4W177DH9k1Cdfsy/6pm6jpwfyqHX7S5K sixCPbwHXkHpXNqgB8mY9+c1Vla4XPUB4g0RzzfRIalTVdGlPyX8bH2Neai1tSc+ShOOMinC xtVIZI1RvUVg6ko7FckWeltqWjKcNex5pRqmjE8X8X515m1sg3AgMM5z61E0FsGUmFRjrSVa XUfJE9RfUdIcHbqUQI561Ui8Q6NKzxx6vA2z73tXnDWloWDCNcUyexs5MeZbq3HHFNVmx8sT 1AajpuNy6pCPpT11LT2BzqEJHrXkg02z3cQ4x7moJrGD7YEMfygAj8ap1mtkLlR7D/aWlDrq EWT05prappg6XsR/GvKhY2wwDApx0zTJNOs3GGt1I+tCrSfQORHqjalpzdL2L/vqolv7GNsr exZ9Ca81Gm2YUAQDA9zTJtJsnckwjGc9TRzsXIj1Aa9p25VlvFUeoNaEbQ3CCSC4LoeQVNeN nR7MgfIQB0GTXo3gaawj8N21s7iOSJfLOT3GB/SpunrYTjY6EoGGBMwNG3yukhP1qGeW0Q7v tC49c02Ke3uFYQTK5U8gGqTRNiYzuvHJNAupsYMf61TlvLWBS00whx/erDn8aaXBKY/OZm+h 5q00Gp0hvHJIdR+VUporWVifLOfYkVzM/wAQLZCVjtGYj1qjN48vS2INMDKf4iwGKfN0Ebc2 gSzuXhvJ1GMYEhqsvhcs2JdQ1FfpPXPyeL9Zlb91GsXtkGq0ms6xMfnnC+47UhuB13/CK2in 5ta1JT/12o/4Ra1P/MY1Rv8AtrXC3D3s/wDrLyTqOld54akeTRbdnkZm2jk/QVUEn0MnCwn/ AAitqB/yF9U/7/U5fC1oM51XUz/21rX59aAMfxEVvGMewjzHziucGqcsmX5qd85OKqurbqmI yxbyDtVkSVRhU7uhFWwpq3ogJN9KJeoFRbWpQCKhX6DJN9MLZ/8A10YNIFNKzDUkDDZ0+tRO AWPbnpTwCaaVJNFgsR8AZxmi4DPGpRSzKchQeTx0qQKcU5ULEYBOPQ0naw0SbTLHiVCoOO9C qn3UJcdD2xU3lx8bl6cjPakG3dkc1xSWpuiK0t4rFDFbhjGSSVZieT/9c04oMkD5cjr6U/kH IwKCGLDcc8fpSTvuMrNbKk+9HmBbAwrnGfpWja6trOmjbY3+1S2WWRA36moXUFT5S5ZeSAab HtliDo4APr2NL3Y/Cg3NmPxXq0hBuFik2/xKcGpk8aGXzBgwKnyvN94g/TFc8iyAnKHaRw3r To4FRC5UEk5zSd5dR6HRHVLS6gBXV53BPzFlxn2qlc3salkslCg9ZG5qizGaL5thAPTFIoDR lThQPWqi+XcnlXQk87Py7ssaY0hhBd0LKByBTHureAKGySf7ozTGLTr5kb7V/lSk7sZNlJcs PlHeooZbWZ8QTiWQNtZFPQimC1+7IJcOHBbPR19PapVtYI3LxwrG55yKIu4CeepUSLHz33Hk GsjW9WtoxsVwZVXLDH3Rz/ga2ZnSGCSUjJVSc/ga46VJda1DyiMiQksBxhcnirpx5mTJ2LGk 6TPc3ry3X7uIHBwv3v8AOK6gQRRKEhUKvtT1dohsX7g6UZVyCG74I9KupUfwoEuo3awAGMD1 oSMBic7T6npS4Yc5P0FICSxDA4IrDXqXcedoPJyacoVgVKjB4OOtRDzF+aMjI7U5i7nLcH2r TWwWOOlnudH1TdG7NhgGQ/xLlfy4JrsVdLiJJI/uugYfQjI/nWFrWh3WpXKzW8ioCoD5wfT+ grWsoUs7GC2EhPlRqmSfQAf0rWy5CLO5Z2JngY+lRSRqT2OKl+8hx2xmkC553AVz6MuxQnto ZRtkt1ce4qKLSkidZLVnt3XGGjY9vatIOhdlzkjg5pZEuUj8yONSvYA81SfRom2o+S+1SW2W 3lug8a9Dt5qssEe/zZHAf+dTL5ksbCVwjnuBnFMe2jk4LkEdGA6UOcvsj5UOIXYWDjA7molu oSxjSXc4HT0p62qpHsErMWBBJ70LZwxqu2IKV4DCk33GQNexeZsL7WBwQRUw+YdOKdLFDcri aJWI7jinlY3jMRBCsNpGeopJpagVxJBLEJI2LKM5OPTr/KlimgnXKSZwO4pY7aKCLyox+7BJ x9TmmSW1tuBWPaxHUHvRF6hYkYhTgoW+lZl7qVtbX0anKycKVbsOec1qFsuGxVSQQyXjqyKT gcEfWm3qItNNCm3zGGSM8Uu6BmZAgLbd3PYU4RxAAFAcDApDgc7Buxjd7UXuMiBSQsIMsF/z impdI0iIAd7dOKsK/O5gPyqUScYCLjOelXrsxXK/nYI3L82M4qu8ccjkqGVz3UkDPrV5nV8Z QFh0PpTGiikYl1wSMHFRbXcLEc0slxld21D1A6Goba2ksbgXNrK6S4xncSMfSrIgAJCNxUQt rvzWd3xFySmO31ot1AS6lubxdt3OZFHQEVUEcYPyryKuSqy7dqkhlJ3dqqrKhXOc1UZPoKwg TmrHG0fKDzUKTI7gD1qdgccGru+4rEWFZvu4pWQY44oyR1GKaWHrUuWtrgRMpA5Ndt4WONEt xkfd/wAK4p+cfWuw8NtjSYQBkbf8K6qV0ZzR0OR34oBTuwquW9BQCT1OK3VzM80I61WlwDyc e9WD3qN13VCYEcT4bhqtBm7moFTFSjNN6gSde9GcUz5vWlGaV7ASAjvSgj0qPJpalu+w9SQE DtQSPYUzmlUE8kUJdwHjB6UxnMLqwcrlsHinDjrUNynmIMOFIYHJFKSBXLUkyjzAFw6YOCeo NIJszRosuNx6Bc59vaiOGLd5xfc6A4z39qsBoihA/dtzhgO9cE73OiK0Ksk0uf3cRO3lweuK TypJcSAmFNobdnJP+zirq3EgUHcSQDzjk03GyMMMBWGRj0qVOxdyFLW2CqxRhKvRtx5/Cpyo ZQWYcHjimg5JDEAeuKheRYzliAM8ZqVe+gicN8g5/ChGySoBqol5AziFJQZucIB1pwjlkt1+ 1fuJMc7Tkg1pydRD5nWBhvVhuOBx1pG/0m3MZb92TypHNPijkg3ZnaRWxjeOlKYfMbCv5ZPQ 4osA2CPykKI2MZPNSIhfnHzVFbXtncAeTMsjL1YVYMwWVlVgeMg1DjLuJXFVMZDGglv4cHnG TTEYux5yahvdQttOG+eYIDyBjJNFmMra9diC0+zshcSggOD06dvxqn4Zt/kuLg8sSFXH4E/z rL1LWU1SdXiVvLVcBvXpUEF/qn2FVtFCWqgZlH3iTjt+VdsKcuTQycrs7WWTauXOAOpqBbq0 kGBMCe2PWuW/srxBccXB3QZBKqcbvrT4dG1WMg29sFjHVdwOaUaLtq1ctSOsDmBDKF3KASfp SpP9thyv7tvQiuI+1eINJeMNOFx1RgDv5Fddpl7/AGlYRXJQI7KNwHY4Gf51lKjJasE7lxIZ VkxuVoyOe2DUiwPC28jfGx556cUwhSPnOfTFPD5TCsQKybaLuNMEYk3lyx6gelMW2hDuwPDN uKn19al81SPmG047c0mA+QpzmkmK5GkaIG4bLABjnrj/APXTViVFZHzIrHjPG3pUhV047U0/ Tmr5l1HckATaAVGcdacoJBXBPc4qIM45Cg0bm3559KlvsIlCKf4ttG0DpTUb5xn171ISu7dk U077CTGFuMY59aVT8pyf/r0ZyetIcHq2Kpq49WNyOtHPUc0B4wSGYA04OmeDkVElygMcHPI6 ioiS/INPmnTA4PHeohLGB8xxkd6SjfUB/JPAqrJ/x/P8uBgH+dWwhzwR+dQHcLjBZVLdB6ir 5rAWFP4UNnHWkUYbnGPrTHlRWYF8Y6ilJgSFsikCkngkVGWO4spAQ84p/mqOCeamMn1GSxx7 Rktk07cM4YZqNeQdvWlGecnNVdPcWo4FQeBinF24+aozx1pcg8Gi2oXHJ5m1guCp6iqpjgVz 5kXNWlAwMEcUyRC24+tVqtgK7QxFvkGKrPHcoMhww3HIx2qx8yseaUNmqu1uIr73YgBOcHJz VfzSJDuGOM1eJXOe9MKI2WI5oW90IqNMOpz1rtPDMnmaJbMo4KDn8BXHmCFmy2fpXaaIsUOm wpAMRhRtH4Cuuk29zKVzUJ9aVSO4phY45oVsZrdMg83J5pM5ozjpTWkJ4Yj8qjoAoPNOGO9M Bz3pc+9JD0HilpmTSg+tOyAkVtpyOvvRnPWmZpaNhDqUYpuRRnmlYY7pUF6qvbOplMYI5kAz t96mzTJlBhcdfl6UNWQEsAjYYLeZg9T396slgMHGB3OaowCWSM+YrRg9GI6ipAbd8onAHDZr glFuRvF6Fzcp+6c8VVF0IZfspVskZUDninCFSAbeTy2B+8BnI9KmA2ZA7+tRKK7lAqu8uMHD EBWPc+lKYjCztcgXEW/Ih/ujHrTSjuDhtpHQ96VSSBuyT3NQvd1uFmGyAqskMKx7genUUmSr FXY7celSHaBwcgUPKduMjGOKpTb3YxiqBuJbOentSsd0e3360gywORz7UAhWAYjn2ppa3QjD 0TQP7Iup5RIGDrtAPpmtpumcgFRyB6UvlR3OF8wRsDnHXIqUxwsAXj+dRgHNW5qXxBZHO6tq F2832SzzECR5kgGcDjoPWq0HhW9a5V72UvEzZMjHnb9K6iOC3XDqAWz3FSujSDd1+pq/awit ES43OP1W006ym+z6f5hXHzbgRzx/ia6bTDE2nQMFVUkhTIAyM7RWHrsbGaOcHgrjA9sVe8P3 JlsRF0eMDHcdBWntW4XItZm2JmibAO5T2NKJlPAUpn3qJmyu+QEEdcc1U1C8FnaedGgdycKD xzXNfm6l6GJ4kcPfIqcqFGfr8v8A9etzSYfsWnwwyoA7IpyPXArntOWbU71JpVC4+Zuc+nH6 V1RIddjREBQMEdxXRzckOViV2SbADkEUKQMjNNkt/OhaKM9SCfm6YqH7JMbZ4mZVcHG4elc0 l2NEiwsyJhGYZPQYppkjz8rEmo0iQ7Q3DD+I09YIUEpBJaY5f6+1TKK6gC3A3sm4ZXGR+FSe bx90VXltYnJdF2SkAFh3xRhApHRu5ojbsCQ9rgpnCbgFJOOtRx3aynHzA4DDI7HpTVTJySc/ WpShaPGduOhxVtCsC7pQ4kUIQcDnrSRx7Tzn65qbIydwBz3p2FY84FTFpMCv5bh9yXA256be tI8TPIr+dwo5UDg1YKA8qQacmV3Hb1GKpyS1YXKptoZWViCOevpThbxryJTuFTJtBxTNmXJz Up3DcjMHy4aQHPoKiuLITx+XI4KnpjgiroXApD8v8Oap2RRAsCht4b5uBj1FQXGmefdRzpPs MZ4XHb0/WrmcnHSkbaJivviklFiK8mnMZlm88cdcd6SSyEnMsxxjBAHWrhI6UhIZsE0SSYFN LBAmxJSY85xViKyt7dmKOcO+4g84NTggDFRNIM9KasApiUAruJU1Xe3kjy0bkqOgNTbxnHep ASG+Vu1DV9RJldJ9qASrgk1JvXsRTZUWUYkBI9qYlrBH2OD60osHYlVzk+ntThKBnJqAQJDn EvyH17Uwx5YbJR9SKL2CxNKQRkDFVN+1sU6WV0+ULkdzmosBl3kfjVXT1Yeg8yL3prOAoAqE EbuTQ+CetaJJ7EO4jtXc6ECdLhx02DH5CuFcDaea73RI5BpsP70jCDAI7YGK6aVjORfwfShQ Tng07bJz83NNCzA/erdIg8yzyaYy7v4gPrTcnNBznpU2GKhI4PWpM1GKUGkrXESUoNR596XJ p6sCQfWjNRgnFLk0rAiQdKMn0pgNHNGrGSZpCcqRjtTATS84qbIERWt0xDxGYkhiNpp8mXOT 2rFvz5d42M7WIPX6VpWMy3EQ5Bwdp+v+TXPUjbVGkGWoLu8h+S2CMMEsCO1WkuFZNxwGbnHp URs0G1nc4IONtKtvCeAwY1huallJATg5p4zuwDVbzYop1hmJUsNysOhx/kVamhJCeXKNjH74 rPkVxjGZUfy1YCQjcB7U4yDy1ZkLcckDpTjbxFUwPnXOG7+9LHvVSM4KjgDuKashXGTxyPCJ LRw53AlTxx3p6qjqA2fl55pFOx8gEYPaht7581SoJODUqTAR/JGSrbvU0hYfwvTgg24AxS4Q LhmxjvR6i1GHeOFjJHrT1JXnvUT3cSEjzOfQCmiYuXUIf9lj0NJpdAsxLu0huIGimUbT0Poa 5wW9/pVwLi1j3pt2lSfvV0IaUOYJUKZGUfOak8mVFO+cyDHKlcCtqbsrCauULfxBAEYzr5bg fMDzWfI93rdyBBEPsiyEiUjG4YPGPxFbq6dZK+7yFye9WoyQpjVwq59KFKEHdB7xHBYWdhDm 3hIP8Qz+NSLMXQkHYB2NNjjBUu8pB/u0wqhPGTms5ycnca0JxIqoW3Yz6UyOZXkIBzUYTywd o60mwsRyBk849KqKXVjuOeaME7gSR2FNV9zArkfWnlAkhAXtwT3pvllwecetLS+gCSORI6k8 r1xTBKCp9qCu3O0E461VlnCEEDHPamlfVoLluNwwBB68ip8llOCKpRSI8e4nkDmnW88VyZPI 6ocN7GhJLRAWwQOWNKXUDGCc1SkvY45I48bmdgvHanNcKs/l8k+w4pp6BcmJG/qQfrTw0g4V jio2aFXXef3mOBTHvYYWVDyWO0YHepaiwsWd7kcID75pC4B+Y4pol+UnoM96VdsnI6etF1sh pE4IC/eFNySvTtQY1ZQCOlKNqjAPSjkje7YEJR1YE9Kj3bpMjPXB4q4CvcCkLRcYOD3paIRE kb5z/DipD06VIEBXrTcKpIY4PpTjINSF3AFVZFMrDBIx6VamcKOg5psW0k5qr9REceRwamz1 qNmVJDzTxIGHFF2wDkDjpRu5HtSGk6UuVAJcEMgB61VSAMep4q4VO3nmmhAB0puwxYVKjGQR 71E77s/WpMVC0T9QKSV9wuQtEhPoaia2BbOcmrCxvu5FWI4x3HNbRcUSykLOQ4ORsFd/pQxY RL1GwY/IVx0hCIxwMDqK7TTcCyjxnG0VvRabInsWiKaDSluaRTyeK6lYyPJs9aUNUHmjJ5o8 9AeTWV2wLANLuqDzd3fgdqXzAehpqyGS7vWnA1Dv96UPTugJs0u70qIN70of1NGgEhajdUO/ rzTd3vUt9gLG73o3e9Vt4pPMocrLYCtfQJNIyydMg1Lp8ESAlHyM/NmoLp49u985HIrNt9Ti iuCzOUBOAGHBNZNuS0RUXY7aKWzt4w0k5ZACWQA8dzU8F/o1zbl9OtGG7BDuxHv0NchHrNoG 8szoo75qePUNPALLexgEYPNc7ptmidzqZmRrdmwOMgd+cf8A1q56HVp7OTZGuELEHJzjmlh1 y0COn2mMjGAd3Sst5LSV/ku1Ybic56ZqYwd7Mp3Oh/t4R46Mh6n0pE8URb0je1cocDzfauY3 RLKFWQc571ZWSNZRvmTbtxWjw6aIuzrhq9qE82OQcnHPanC/Sd+ZN4P5VxAlthIWO0DcMN61 o2k9tHiXzgDkjHvWbwq3KTOle7ii6ng8ACpAVdN8i7HAyADnNc8Lu2LblKlgOuaf/byo+7ej SAbcE0nSa0ih3N1kWbogUHg4FOEaIMdMVgxa6XRt5Cvxjnik/tuRpFG9dpOOtS4VF0GmbzOG QDg7elIJSUKt0IxmsSS9bAKzpg9eelRf2pMn/LRCPrVqnJxFdm8zEjIPSm7wzcEA1hyak0sh PmhVJAxUS3dvHOEiuhMT94Zxg1nCjNvULs3zcIr7dwz3p6Sb0JV1K4zkelYy3luG+eNWU8H5 qkh1K1tRtiRBGBwua29hZCuawkljkAMO5TyJCePpStbyvKZI50CscFMdB65rJbXotpUMuD71 DHq8YyBIuPrSdB2Hzm+bMrsmW5UjB69etKpWMHoWPU+9YrawhQL5q/L2BqJddiK/JInTrml7 JoXMdFlG5CgN396z72MRYKoCCT17Vm/20AMmUY+tI+uRyKEeZcDpzVRpSW4uZsvWVv5KtMqD 95kHJyMZq2siR5KoFb0Heuel1FQ6sk4wwORmp7W8SHJeXeW56+tacjYc7R0qyQMNwhQZ5qVp lKhdihs9a50X6BT86/nSW2pRtIwecAds1nLDzaug52bktvEXErL8+CM+1MMEar8qjp19Kqfb bYJn7Sppw1G1Cc3SisuWcVqUnctnY6EOhOcEe1OCKuGR8Y7VSTVbMfK1yuM+tD6rYDgXKA/W s02nqhouOhkGEl2H6VE2mySBj9uwCc421VGq2ZH/AB8pmnrq9kBzcpVaPoMmksJ3lDrcgR9C oFPXTSrqxuFba3J7kVCNY07/AJ+UP40065pgbBuU/Ok5f3RrUumFwxVXwpHUiojZoj5aUu3r VVvEOljj7ZHj603+29MfOLyPA7A0c0n0E7E1xE8nypIF7g4qQWTK0csU+dp+ZT34qgdd0tG+ e7THTrS/8JFoy9bxM/WtI/4RXNGayimKsshWTBzn17U1YnVSrx8joQetZy+I9HbOLtOBnrTv +Eo0dQALpenIzSvNdALoIVyHbGelRTXqRSqrP944GB3qsfE+isTm4QYPHtUbeK9GAxvjbnk0 KcuzC6NN5do+Y98UqygjpWKfFWj78rLjjBGCQajbxTpXIWQhSODg8fpRZvoxXN5WAOeKWSVQ K5pfENs+fLmBFQP4jhwQSwIPTaeacaU29hOSOn83PTrTVmLEnNc0PEcIAG1x77TTh4kjKfLD IeM5C9RV+za0SFzI6GSYGJgR6A13WnHFnHkknaP5CvOdL2axIInmMQyCQevWvQ7dDDAqL0Ax 19hXVQpyitSJNFssKRTyeahMmOtMEnXFdUTM8P8A7XvCTny/yoGsXKjmNG5NUM5Y/WlByear lQ7l/wDtm5/54x55zg//AFqadZuAOYE6euP6VQ+72pS27rRyoLl4axcZP7hcfX/61SDWpB1g 7+tZmcUdKXKhXNUa6e9ufwNPXW1IYyQFeOMNnNYwPHWlBOD9KTgmFzY/tqEDmM+lINXjZsBG rIJo3YoVNIdzY/tVFJUo2fWk/tSLHJNY5OaOAKORPcLmpJqFpOMMSMVH5untyzEjPTFZ3HpS gjmhU0tguXBFo7jmTb+Bo+w6MefOX9aqcEYwOlM2gdFH5Ucr7gm0XjYaMOsyY/H/ABpTp+kE 8XCde2aoFVweBzSALjGAPoKajYOZmj/ZulcYuFA/GlXSNMI4uFII75rM2jP3R0pBDHt+4ORQ kFzYXRbB8gXCAA9MmnHw/YE/65Of9o1iGFCPu80LEgBGzv60WY7o1z4fsQwBuV59zTv+Ectu 00f/AH1WQI4wPu8UhgiAyF/U0crC5snw3b85mT/vuj/hG4P+eqD/AIHWL5MfofzNKIlyeWx6 bqLMLmwPDUGOGU+++nf8I3CFzuU+++sby1HQsD2IY5FIIwBjLcDH3qnkYrm2vh2E9MH/AIHT h4cgGf3YP/A//r1iYYciRx/wI0o3kYM0h5/vU+RoLmyPDtrn7o/77P8AjSHw9aL/AAj/AL7P +NYwTIAMjn/gVOXKfdd+g/io5GFzW/sGzHRV/wC+j/jTh4ftD2Gf94/41kmWXP8ArXxkUhkk Y8yPj0zRysbkbI8NW5xtjGf98/408eGkA/1I4HXdWEd5IYSyA46hqaXm5/0ibp/fNDi2K7Og PhtGBHlqP+BdajPhqMHhFH/Av/r1h/vcHNxKf+Bml3S4/wBfL/31S5WK7Nn/AIR2EdYx/wB9 f/Xpw8N27/dUDjpvrD3S4H76TIzzupSZNvE8gP8AvUOLGbZ8MwDqB/32aB4atm+8o/77NYeZ O88p/wCBUu6TP+ukznOd1FpCNv8A4Rez/vDP++aT/hGLL1Gf98/41jbnOQZXJPfdSEHbkO4J Uc7jS5JFXNv/AIRexPUj/vs0v/CLWRPBU/8AAzWKryqCPNY57E0h3n/lq4+jUckgTNz/AIRa zHXH/fZpR4ZsB12j/gZ/xrCBcf8ALaX/AL6owepkkP1amosfMbw8N6ae6j/gR/xpf+Ea0091 I/3j/jWAQT/G2P8AeNOGcj53HPZqXJIOY3R4d0xeoT/vo/40v9haWB0j4GOprAxj+J8D/apc Z7t+dL2cu4czN7+xtLB5EePxpRo+l+kf5VgmMYIJb86GQMAWJODkc0/Zy7hzs3xpWl/3I/yp f7K0pcny0/KsBVxzk/nQBlcEtjHTNHs2+oKR0H9n6VwNidfSl+xaYpyFT8BWAEXI69fWnED3 6+tJU2uocxv+RpwAGEH4UGPT1X7yge4rngvIY9QD3pWjD5yMgjoabhfqCZvhdOz1XPrilL2S /wAQFYIAAx0o2Z5o5H3Fc3lnsv8AnoDTxPZ9mFc4sa+lP2DH/wBel7J3vcLo6RNRs7Zt5fbg gn866e1+IGiwxCOSU7h9f8K81IyMYz9aa0MZPManPrVOPQLI9QPxE0LON/6n/Cmp8Q9CkyVc /kf8K8yWFF6IuPpUsUcZzlF7dqFG3ULIok8mgGkPU/WjNakjs5FNzigGgrkZHSgBC1O3A036 0UgAU/8AhzUZPTFKM0AO70Cm5zSZOaAHZGcUnNJzmgelABmjnIoPtSY9aAHKehp+0fmKiFSd UHsKAF200L/OhX7Ggt6UAJSA9qP4qKAFzik7UdSaTOKAF5px5U02gf0pgKOtJSnr+NJSAWk7 dKAaKAFo7Ud6T+VAC96O9J2pQaACkope9ACqc8Gm/wCFKOKD/SgA9aBSdzS5oAMUZoHIpDnB +lAAOppec0nel6mgAHWnMOB7DFNUUp6UwEBp1NHWl5z+NABSgZoHrQtAB0pwprdaB1H1oAc1 A9aD1oX5jikA7tQBxSNxT+AKYCdKcBxTAcmn5wOKEwFHWg9vrSDmnNx+dJgJjgYpRwMn0pO4 9MU89Me1CYARRj+dL2NNB5puzAcBxTe5p27jikqRC5xRySPrSE8n60YIb8aY1cd6VJEOT+FR Dr+FPiY7m/CgZQPU0mBQ3U49aQ0xAOmKcDxim03/AApAPYckelJS4ypI60nU0AIAMU4DFNoz QAoPNBGDSGl6j6GmAnGaOKOtJjGTSAUYOaO9J3o6UwCnx9wehFMpVOKABhgmkqRxn5qi/iFI B1B6GikoAXiikz1+tKKAEFKM4/CigHH5UwFOaQdaM80YwaQAKKKKYBiij1ozyPrQAduKXtSU CgA60ccUHg0DigBaP4T9KaKcB1+lIBO+KKPWl7UAL2po549qXORSCmAEc0uKOcml60gFHSk6 5pKUDtQAdKXtSGimAL6UvTJxSAYpV689MUXEIetOzSdzQKQxy8jnrzSqMGkHp7UZ4/ClYBW6 /jSnB4pPvCndBVJAIBg0uflpBzzS98UWAVe5peppOQSKEJyRSEKeCPoadn+VIBk5peM0DHZ4 NIBzQf50meaAFPWnA9qYMnBpcc/hQ2A7jPFITRzmm/40IBykg59jSx5LMfYU0GpIjy34UAUD 940mcmlP3jR0/OgBKQ8A8dqXNGep9qYCg4zTT1/GjOe9H+NABSDpn2pcdKMcUAB9aUHmk7mk 75PrSAXGDR60dfrSUwF9aOlJRQAdetL2pO1KKAHA/Kc0zow/GlIpBSAAaO9KKTvQAY5P1paK DigA7UnQfhQOAKOtMBT70Zo70UAIOlLQOtB70AFGOaCKKAAetGOtJ04paAEPPSnD3pKM84oA U0nUUDk0AY/KgANH8R+tKDmjvQAdunNGaAecUEEUAHf8aO9JSgc9KAAc0oOKOnFKRlQe+KAE PNJQTilByKAEU5GfrTu1CjgUpoATrS4oBpP4vxo3Ad0FAGe/akHpSjjn2pXAVTinODgfWkXG c04t8uO+TTAYp4/Cl7ZpMZNO7YouA7rzQO/1pVHBzTV6n60kA4HFBpB1FLT32ELgkUo4NA6U oH86WwxDnFGOD9KOtL2xQ9R7BkjNHBPvn+lBNCgUJCEHSpIhkn6Cm9sU6Lgn8KLgZ/c0hz07 ZozyfrRn+dAABRnP5UA0dsUAID1pc+3ekzyaU/1pgIOlL2pPeg9PwpAFIeTg+tLS9KAAcHNH WkoB4/CmAmf50tA6mj/GgAAxQM5pKUHj8KABv60opN3JFGfagA6UD+lFHfpSAWkFFH+NABS0 nTiigBTR2HPeko7n60wFGaOh/CjAoxSADRR3NFMANFJk9KXFABScZ/GlxS0AIODR0o+lKDkD 6UAIB1zS0daTv+NIBaOc+1J2pe1O4BSA0daXvQAnX609T1X2po60Z6kdaQDiOKTvUgw+emaZ jn8aAG5wead0pCMml/woAPelUZOaQ5NKOOKABuDTwMofpTRyKAcA0AKTgY96B1/GkPIpe4+t AAvvThSKc4Ipe+aAHZwKRQaQ9KeDgUANXrzTiDtOKQdc9qf1/KncBBnBpeo/GlpOlG4AM4ow cUvalHSp1AQcUtBNJ3PuaoBcGnxjlvwpgOaki6t+FJsDM7mk70p7/Wg0wAdaKQUdjQAUZoHe g+1AB2oH9KO1AyPyoAWk5/Wg9aAf50gCgECikI6/SmA7r0pB6e9LwOaTHIPvSATpR9aXtRjj 1pgHeikHU0tAAKcRjNNBPWlOTSAM9aQUUtMBKO1HajHFAC0DrQOpopAHtRS0hpgJjmlx0opA Du/GgBc0HpR2FHagAzzQOtBFFIA70DgUtJTAB16Uo/rSDvS0AJ1APtSjsPaj+VITgGkAvQ0d 6CTR6UALSZwPoKWlA4oAaOpHel60d6KYAKXqD9KSlxgfhSAKXn9TSUZ9qYhR9aMZz9KBSgc0 hi45pT1x6GmjqTSnqPc0AKvykClPNNwSQfanZoAKXNJ60DrRqId1OKfimLnNO9ad7AKAc0EY oXuaCaEMUHtRSClwBzmkwA4pOpp2e2PSgcGmmAgNSxHlvwqMetPj+834U9BGcep+tJ2ooqRg OlJRRQADpSiiimAUf4UUUAIaO/40UUAIPvD6H+dKOn4UUUgDtSj7v40UUANP9KXvRRTAKD1F FFACHrSr0FFFAAen40D7tFFIAHSl7UUUAHek70UUwF70GiikAdqTuPrRRTAUUHoaKKQCn/Ck 9KKKYC9qTt+FFFIAXvR/jRRQAvakoooAG60ooopgKvQfjSj7hoopABptFFMBf8Kcfu0UUgY1 u31pwoopiFSl7UUUMYL3paKKaARaU9aKKkBf4jQtFFAmPXqKX+L8KKKGNDhTD0/E0UUkUxV+ 7T6KKCRO9KfvUUVSBiDpUkPU/QUUUMD/2Q= /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGDAhsDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDcdxisTU0EiHFaMz9s1nXAEi7QfxFZSWhJ y86ckVnzR7WJrdvYFizhsmsuQAg1ioyTKKyAMMYqKSAN2qYMFfBqQLnmqk2tWBly2jckDtTU JXIJrX2LiqN1GFYkeopxq6BYjEmO9Wre4IcZJxVVrdmG5c1CGMR55FWpJ9RHWwOkkYDc8daZ NCo5GMVhW94yfcf8D0q4dQyMGpdx3LSlUYNjoavxXEcrLjr3yKzEYSRbhVjTwWulH41lKOug HVW6bYR247Vz+tMDIQPWukjGIfwrlNXfdMQalI6KKbkZP8VOFNH404UbM9qGiNDTCRP+FdQk hCYBIrmNMXM1dIg4rgxjSOXEblhWDDrSUiH0pSea5IpHKHSnDBFOC5SmBTWjasFx2cCpIyCe arkfWnoSOc/hU3TFcs8dqieNm7Gnxgt1FXljUxc1as9xXM1RsYZ7VrWgEnyhRIxrJviIoSww f50zwi1y148iEyDHIY/yranC+xLlY7yw01RGpnGT2HYVqi0t2GCtRWgl2Av3HQ9qtgV6NOKO ec2xn2SIDAyKj+xDtIw/GrP40VvyohNlT7FKD8tw34mk8u9QgCbI+tXRn1pjdeSKlpJDUmED TgfO2anDE9ahV0HVlH404Oh/jX86cakV1E2S59h+VNZI34ZVI9CKQMD0YGjOKtTTFcqtpNgs vnRwJHJ6quKnQYGARWb4juJLbRpJYnKSA8N6ciuM8H+PJ9T1eTSb+M+csfmJMo+VxwMfXmpc h3PRycCmA00OGTIHWkBpcwhl4220kbpgdq8o1ifN8o45/wARXqOpuFsJPcY/WvJNSJN6GPQU Rd2F9D0HQm/4lluMf8s15/AU3W3QWgRiV3sFyPeoNClU6dCAQf3Y/kKh8QsTHCFyf3q5/Ooq J3CLKT+GIHjM7z8deT/n1qG20nR5VVROC54wWHWrd/qCQ2flhlywx1+lcJNpazXSXK3To6HI 2uQM5/8ArVVON9ypTdj0S38JWCOJGtXl44yua6WC/eziWJbaQIowAB0rgLXxVqdqgT7SHAGM GrQ8aajnkxH6it0rGPPJnZXGpGdeYnU+4rLlG85HWsP/AITS8P3oom/CgeNpd2HtIvripcFL cXNI6a01BbTG9WI9hVq61uC5sZoYt3mOhVdwwASDXJjxkx62kJ+opf8AhMV6tYRH6CqUEhub Oa1LwvrVzqZuEMZUMSoyehzVOTRNchUsYA2PTNdn/wAJhC4ObFR7isjWfEdxKitp6BCB8yt3 NN2GpLqeealLOszLOpDDg/rWd54AIrb1ZL6+Z55IfnPXFYDWVzu/1b4z6VSSW42xBISwHPWu g0rjFY62koILRnitzSV2v8wp6dCdzoIx+7U9iKy9QJjv0ccA4FaisNnXNZmq4xG47MKlDTL8 T5UVIWwKpQSZQVPvOOadwHluOtRMSSaDJUbPzQNEsuvW0nHmfWqr6zbKp2HmqP8AYs7dIz+V J/Yd1/zxP5Vy6mthk2orMxJ69cVRkuATxWgfD923/LI/lSf8I9ejgQk/hSsPQyZCScipbe5V flcZrR/4R69/55nP0pjeHL4niJs/SqsmtRFSeddpMQI46EVSldiPmx+Fba6BqA4eHPvTJfDV +/3YyMH0pKCQGPFKwXj1qC4ZmOcDoa3o/DGoDrE3tgGibwtqDxkLCScH1qlGN7hY5few5B7V KLkk1qP4O1c/dhI49+tH/CGazuOLfC5yOua0vHuSNtLhtuM8Vv6Ph5wfY1mQeFdZj625J9wa 6DRtHv7d83EJU89AaynHzKRtscQH6VxupvmdvY13MtpM1swSPnFcrd+H9ReVituxyc5wayR0 UZJO7MIU5eRWmPDupn/l2f8AI0f8I3qYP/Hs+KlxZ6ccRTS3E0sfOa6Bc4qjp2iXsLkvbuOP StpdNvMf6lvbiuavSczlrVVJ6FdcgVICcc1YGn3PeE0n2G4H/LJvyrl9jJbIw50RBqf2p32O 57Qt+VL9iuxx5L/lSVGoLmRAw+apNpYdQKVrK73Bvs8uOvSpUgnOMQP9cVfsZj5kTQj5BnrU ofqvNQrb3KniF/yp5gujyIn/ACpezkJyRSvbSSTtkE5re8JaelvEW2gHP+NQRJK0Wx4Sc+o6 Vt6LD5UXI7n+ddFO60sRJpo3k4Wng1ErcY5p4NdsWkjnY/NGfekoq7isGc15z8RtS1C0cJaX kluoXJ2HHOB/jXo1eWfEsv8AaCUUsFTGAMk8ChXbsFjy2TVvEzSHdr10BuPRzU8Wr+JlQY16 4HHUtWeWuC5xA/3j1U1OssgjGY2H1U10exXYXKjZtfGnjKxUlNRjuAB0lzk/rXuHhHWrrWND gurtQJnHzY6dWHH5V87CdgrHY2APSvfPh+P+KZtSR2wDntuaplDlWwJI0fFgM2mxwBwgkcjJ 6cYrF8O+HLGxuDcGWOSY9NpHFW/H1w0WmwqvUsSfpgV4PFqmr6ZrUWow3Vz5ayhnhLkqy5GR jPpmskpMq59OjaqAL0pA1YmhazDqOm28yyqd0Sk89yoP9a1hKh7j86z1WgblXW5NumN0wT/U V5lq1qG077VHPtlPBVvoa9C8RSr/AGWcHHzf4V5nqF1+4CE55706b1EamgaqsCmKeRlIACsO lal9rNqs7xz44GV55BrhBqUVuGVw3I4NU5NSW4Zy0uT79a6WrkpG5qGpK5O1sjJxzWfDMxHB /Wsd7tf7361ZtLlSoIYfnVxhoS9DV3ynt+VKJJR2NNtNUW1YtsjcEchxWmPElsRhrKH8BVKN tWCM/wA2UHvTTM/pmtL/AISCxP3rJTQNY0tj81pj6UtB6GcJ3xSi5bp1rQ/tLSX/AOWDAe2K PtWiN95JB+VJvyFZFD7Qe2RSG84xzWkJNBbq0o/KnrFoLgYvHT64qU0xXRnpOdmexpzTRsOU T8qjv/s0Rxby70xwc9arRQyTrlTxRJFpkzCBuGAA+lU1bypCU49KsNZTopbjHc1THzNgsFzx n0ojuDRfhvNwweuKS+YNb5JHBzV2HRg6KUvrc5H96oNW0t7KzMjXEThmC/K3OauyYlcr2r/u 1zVktTLTSLsxKwkj2nnk1aGkXjcK8J+rU0kFrlbeKYWGauto98vGI8+gaom0m+DEGHP0NLTu OzN0M3tTgzYpgpwJwetcUkzUUO46UokkHek7UAUlcQvmPnrT/OkPU1GVpwHFTqgJBM/c04SN 61DzS59qd2BN5jEdacJD16fSogcjpTgeOhFLUZMJGHpinCV/U1ADSg0JoCcSv6/rTvMc9TUO T6fjTg3FO4EgY9c81IJH9ahB/GnA0mwJhI56g0KxB/i/E1GDTgfelqxok3Me9PDH1NRginAj 0oC4/JP/ANenAtjk5pg59acOnWlYQ8E4p25qYCKcGoAkWVxxml3n0A/Co8mnZqlqK48Oad5j Ec4/Co80oNFuwEm8k9P0pQxH3SV+lRg08GkMkE0g/jb86eJ5eokb86hDZpwPNOwiYTyno5pw uJQeZDUIIpQRU7AWBPIf4yKa4hnH7+GOX3dQaiBp24e1WpMQz+z9OJydPtz/ANsxQdN0tuum 23/fsVKOtOz9KpVJLqUmyt/Y+jt1022/79irlusdnGI7WJIkHRVGBTQc0uaftJMQtykF+oW8 gjlA6Ais4+GtBY86bF/3yK0cj0oBpczAow6BpVsALe3MKjshwKsjT7cDCtMP+BmpqUUc9wKk uk2txGY5mldT2L1nSeDNFlXEizMM5+90rdBHrSg0lLsKxzMngLw/KpVo7jafcVUb4a+Hexu/ zFdjxR06U1J9WFjhZfhdoLN8txeJk92FCfCrSkUKmoXYA6Zx/hXbsfmz3p4zjiq9o11Fyo4R /hVZN01Of8cf4VC3wrTnZqzdc8j/AOtXoQFLxVxrMOVHm5+FtwT8mqL9SKj/AOFV34Hy6rCf 94GvTOPWjGBwar27Q+VHl7/CzV9uE1K04HHJqB/hlrq/dvLVv+BGvVse9LyO9H1h9g5Y9jyE /DzxGuRm1bH+2f8ACoT4D8SLwUtz9HP+FeyZbvzQcnqBQqr6oXKjxh/BfidB/wAeqsMdVY/4 VGnh3xVBkJp8hAPQGvagSO1G72puqPlR4lNpnipUI/sq5YZwQoqidK18od+j3a8Zx5Rr3vOe 5/OmkAjkt+dR7V9hW7Hgv9n6wgw2nXkXy9fLP5fWqU0OrSTbGtr0Ipz80bYr6EMSHu5+tIYE J6A/UCmqr6k8rPAhPqkPBW5AH+w1N/tC9DfemU4znBr3/wAiH+KKM/VBTDZWLdbSA+/litVU p9UNQPAjql6OtzJ+JIpjazegkC9mA9N1e9PpWmt96wtj/wBshUJ0TRyedOtf+/QpOrT6IfKj kBmlGfSoxJ7GnCT2NcuvUoeOuKUE+lNEmetKHx2pMBefSlBNIH9qUSY7ZougFGaXJpok9sUu 8+maNAHDOOBSguOgH503efSl3n0FGwx2SfSlBPpTd59KAxPOKWgWJMtTgzDsKjD4p4cUnoND wxp241GXNAY0cyDQnDHsB+NOUkVCHPpTg/HSkvICdWOOgpQ2ao3c0iREovNRWd3M+fM/SkwR rBqcrcVXV+4p2/2pPyEywGz2pwbttFVg59KcHNVZgiyGHpTgw9BVbd7U5XJ9qEwsWNw9BTgc 9qr7zTgx96d+wWJ8gdQacGGOhqAP704PS1AmDLTsj+7UAc98U7dg0vURMCPSnAj0NQB/anB8 0IdicFcelKCv1qAGnA09BEwK075AP/rVAGNOBzQBNx2NGBjqaizShvamMmGPWjj1qHeRRuJp CJ/pR+NQhqXcaaAnA96X8RVffjvSiShSsBYxx1pAP9qoQ+B1x9ajF7beb5X2iLzP7m8Zpp3A tFeM0q9KiEgPORQHGKE+4WJwCe1GKi30oc1NwJMUYNR7qXcT0qkwH4YdhRTNx9RRvNVdAPzQ TTN3qKTf7UX7APz7GjNM30bxRdgOzjtRmm76TfxQmA7NJnHam7+OlG8VTaAdwe1J9DSb19KT cvpS5gHY9aYR70u5fpTcIe5poDghzSgCoQ/oacGqHcZJxThiot3tQHqXdgTcdqUYqEOM96UP TutgRNgUvAqESU9XobAkwKXFM3UoahsRJil28UzdShhQmMcFFOAzTAwxSg+9J2YMftNOwKbn HejOaLRW4Jj+nalzUeaFyTz0quVAS4BGCM06OJF6KBSKABxTs0mkhpkuBigAHrTA1OBHpU7A PApQBTQ1ODetK7YhwGO9OApgNODUa3GhcHvTwPemA04E0NCHgDuRTxUYPHNODULcY4Uv0pu4 +lKG/Cm2uorDxSjH1pganB6E0A4dKcKZmlDUnYB4pwpgalDD1p7gPyR2p2ajzS5prQLj+PSj HrxTc+9G71NDYDgOKXBpM0A+9ILChcUUZopcoDSpII65rzyTwlqjeJIrtTMgjmWRpN5AYDbx +OK9FLY7AUodmGCTirg+UCGBHEYDHnHWpduPX60u45wKXnHNDtLUNhFGe9P2t/ezTR9KcAO9 TpsGoYIpeaX8abyTVWADmgEjvQBRgHmloFw3k8Z/KkBNHHek796q4xdze1LuNMJxRuFLm0EO 3H2pN1NLCkJpqSAdvo3+1MJHtRxRowHFxRvHvUfGetJjFK7GkiTdx7Um4Z6mmc+tJgetUpMH Y4QcUtIKWk7koMntS5xSYNAFJWGKDTgTTdtLtosA7NPU1Hj2pRn2oYiQGnD6UwU4Gp3G2OB4 6U4Gmhs9KcCDTAXNOBPpTRgU7HNK1gHZpwPFMwacFFG+41YdnAzxSq1M2k0oXnrTuhEytTsg 1CAacAaNwsSg0uRUYyO1O5x0pbDJA1KGqMcjp1pQPSizAk347flTgw9Kjx+FGG9RUhYm3ZpQ 1QgNSgkVQiwD/nNKG96gBpwPPFCQE+aXNQhjTwx9KTAkBNKKYDTgRRawD804H3pgGehpwA9a VgHAmlB/GmgGnDPpVaoBcmnAmm4FOAovcYZNLQBRtGaGIUE0u6kxSgdqEFwDUu44o2mk25po Bc560ue1JgijbQncBwFO9qZTgDQA4H3pRTQMfWlxRZgLk0maMe9GfamCAE0pNN57il+gzT2A QmjNIR7UmPapuMUt6AU3NBFJg+lP1FewZxSZpT9DSfhSQMTNBag9OlNHTmq6DVg3UZ9qDSdq SAPqKTdQab+FUgOI4zigHioGuY485YCmi8iPAIqRFoGnZ47VErhl3DoaC6gcsM+9PQEShqUG oQwIzuGPY04MD0ov2BkwPvS1EDTg1MRLS8mowaXNTZgPxThTAeKdQgHgn1pwbsaYDTgaLASA +9OH1qOlAHUdfemkMmFOFRilBPr+FDYEo64xSjFMBp2al6jH04Yx70wE4zTg1KwhwApdtNBH pTuop3YCgCnAUgx3BpcD1xS3HcULTlUelNGfXNOGaNUK4uwUvl+5oB+tOGfSmgG7OetKFpwN LS1AQD1wKcCvZgfpVLVVuG06T7KD5vbHXHHSuI8JHXU1qUXMkj2zxghZARsbjp7VaTaEeig+ 1PBpiZ2jIp4+lTZrcaHClBNNBpRS9AY8MPSl4NMxmlApgiQEYpR0qIce9KDSsxkoxS8VHk+t Lk+1AiQUYpmaUHihXAeKXHFNDH1pdxqtRDgcUv403J9KA1F0A/pRketIDntS5oAX8jR+FMJ+ YcE0vahDuOx7UhHpRmjNFrhcTBpMe1O3UZ9qfKF0M2mgge9LnnmjNFgG4+tMdgg680rltvFc H/wsqxHiGLSWsbgiWQRJccbWY7cd+nzChR7CO2yTzUmKhglE6bgCBjjNTgYzxmqEhpFJt9DT 898Um7ikvMoYRjrTCeegp5I9MCkwKaC54xLehpCWPer+m/6S/wAoyO9csHJ7mnLNcRsHguZI nHdTSvoVsdzd3K2sW0nHFc/LdSSylhKyrnOM1lveXc//AB8XBkx0pFkcfxZ+tZ2kncSidFZy SuQiEkZ5rcRfKjy3H41yWm6vLp0m7yvOUnkdx9Kt3utS3ijy0MQ7hutNzWw2jWm1q2ibbkkj 0FWLe/hnXduwPfiuQV3Lcr+VattFLckBR8gxmqJSZ0asr/cYEZ4xUoU1VhWO1iHYDvSf2taB tvnJn60k9bBYu4NKFNRpcK67l5HrUizDPNUIcAc9KcFNIJQe1OEo7UgHBTThn3oWUZ7U/wAw emaQDQDTgG9KcHFODDuKS3AaM+hp3PvTg47Cnhx6Zo9BjFBPUGnj2pQy+lODL6UxjRThzTgy +lOBT0o3AaDjqacD+NLujPalG3HFFiQFOGc8GgFaduX2qUwEwacobpmgEU8bT3FNsBORRk0o 2+1KSKABWKnI9e9KCDzsQe4FKNpp2E9aLtAJu9acGHYGk2oKXC9mxTs3uA4c9aXAB/wpoXjr mnDFLUBduaXae1NAHTNOAPY04xAQqRSgHPSlAPvRk02gDB/u0YPcU7J9qMtjtStcBMUDPvTg eOlH4UcoxOfenDOO9Az6Uu4g9KGJAPpSg0m6jcewpJDHhuwNLmohI39ylDn+7+FXYVyTJ9KP wqMMx6KRRlh/Cc0opgSdaXH+c1HuPpil+YjpVNWGrCkelJzRkjsaTk9AcVPMAbj0pM+1Kc/3 TTT7g0XuAZ5B9Oa5seCtFXXU1ZBL565IjOCgJxyBj2roj9KBwOlNOwCKoRQo4x6ClP1oJ9jT cj0pOQWA/Wmk4FKelRkg0wsGTSbj600nimmhAeAg+9OySOKBGemO/pThGfQ/lVcrLQnzUoMg PQYpcdcZp4yOopyTfQpD429uhq5G/HSqme5BqRJkUAHK/UVhKL6CLqkelXLXULqxJ8iOGRW6 pJ/SsxZfSp1nUfe496hxkguWLq/vbkksojB/hByKpRw7pBvjwfUVcRwRncCKCykfKaFJroGh egubhI1htgMYxk1r2yShMytkn17VhQX8MMZXcqyKOd3GfpTpPE+3KRoSw/vDArVN2FK50qin hc+9crB4jvJZQnloMnAK81ce68Qqu+KzjkT1UmhXW5HKdCFI7GpFHtXKJrPiFWw+mL07Empf 7a1v+LTD+dDuCR1AX0FPA45rlf7f1tSB/ZDEdz6UHxLrK/8AMFlPHYd/TrU6hojrAKcBXJ/8 JTqwznRJzxngD/GlHizUl66JcD22jP8AOiz7Bc60U4e9ckvjG/J50O7Ht5Y/xpy+MrrBzod6 PrH/APXoSlfYLo60fSncelcf/wAJ3KASdDv/AKCH/wCvTx45YnDaLf8A/fn/AOvSfN2FzI62 l/GuSHjyPcFOk6hk/wDTA4p48ewf9Ay//wDAc0XfYLrudWDTua5MePbUk506+GPW3anDx9YB STZ3ox/0wNJKXYLo6sdaXHPAY/hXO2fjOzv72Kzt7a5M0pwoMRAHBPJ7dK7KyLQAiSNST1/O m20tilZ7DYFt2ULKMtjnnmpzpkTjMcjL/vVcSKKZNwhQZ7gc0oiCchto6c1nzF8qM2TTrhBk EMPaq7K8ed+V/CtnZLnO8Fap3sbyxH92WyMZxT9oLlMS08QRwao1he26lWbbFMDx34Pvwa6k xQDra9+eK8y1a0eO4fCtjsfQ8811XhfxI11GLG7VReLzuz98ZJ4/MU+Z7jsdJ5UB6QY+opvl W+eY8VNHKzHleKc5R0KtGDR8Q0Qm3tSPuY/GoTZQH7jkfjmmt9lUkDax/uhqrtOIWbyoCG9d wppMfLdE7afKOVdWH1qJ4Z4xlkOPUCpLe9LLiciJyeMHIxVsXcSj5nUg+9JyaF7NnKTa/JbX UiNCskanAxwfSrcHiXS5n2PHLC3ffjH51rz2emakG3xR7/7y4DVgaj4Us4sMZ5REzAMNvIpN 83UVkjdt5LK6G6F/MH+y4NW1s7V/+WhU+5rze408adM32G5kFuGwjxv8w9jTIfEWr2RRFmhv I+/m8Pj6ir5pLQfKmemtp0YXKs7D/ZNQvaBR1cfWuRt/H9qJFiksr62fGPMZdyE49Qen1ro7 HW4b0bf7U0524ygl+b8qSd2LkRZ+xSOMoyMPQnmj7JcLx5JPuKleaIJnzY/rGwNJEjTANBqi 4PYtzVXuHINFtcY+4APpSG3kHOATVlbe8A5vEf6mpVjukHVWPoKLvqLlRnlJQOUP4VGWZeqt +VaytcFcPAynNNw442A/WjnaJsjL80egz9aUOenFaBWJm2MkW/Gcd8UxrONhlY/++TS5xWKJ ekD+9W2sPQuPqKjNlKBwyn2q+YLEBkpplqQwSrnMbH6Uwow6oR9aVwXmM3CkEntTtoNJsJ6A Ur9AAyLnpTfNX0o8s5+7zR5Z9KegxDIp6CmNJ9KcYj6VE0R9M/hTb7BYaZB6U3zB/kU1kI7V CU5/ioTA8yEFn3g/I08RWIH+pb8DWd++z9/FKDP/AHgfwrTXuPmNIQ6cRzDID7YpRDpuMNFK B+FZ26f1FAeb+8PxqbS7i5jTW10wnhZf0p/2TTCMFZT+ArMBuT0KfrTw12BwYyfxpKMu5VzT j0/SmPIlA9wKsrpWkN/y2cfWsYS3mOsX61Ir3hzkRfgTTs+4I200TSMbhdOPxFDadosf37l/ wArGEt8v8MX60LPesf8AVRZ+ppcrDQ0m0/QWOfPmb6LSHT9EkGC8uM9SlV4ru/X5Rawn8ash tSdcmzj/AANLVBoWrXRNHVg6XT9eAwrQezgXG3UZYx6A8VjK2oKc/YlOPRqmW51ED/kGhvxz S5mK6NdYotuBeB/c9alEAYEG5GKxBc6gDxphH41ILy/H/MNf86LyfQakjXFngjFyD+FSC1c/ 8toz+FYw1C/HTTZT9D/9elGrX4H/ACCZ8euB/jSU5LoJyRtCyfGBJH+VAs5PWP8AKsb+2r4H B0m6P/AeP51Iut3A66VeZ/3f/r01Ul2DnRsCyc9oz9KkFmQOUX8qxR4gmHXS70H12f8A16cv iGXGTYXv4x0/aN7IOdM2Da5GCi/lR9mXPMaflWT/AMJIwHOnXn/fqnr4mx1027/78mkpzJ5k aRtUx/q0/wC+aYLKNyR5eP8AgIFUv+EqjHXT7wH/AK4mgeKIOrWV4P8AtiapykxcyNBdNjP/ ACzB/AU7+zEOf3afioqiviu1A4gul4zzEaH8Z6TFJHHffaI45P4vLI7gf1pc0rCWpq6bp1vL KZljG2Niu4Jjkdwe/Wt2GCN/lXdtA5LVW0zWNFv41Wy1i0ZBx5auM/lWs6kWzFFxkFUyepOQ KwlUcmbKNlqUvP2MVjUsAewpftUhGPspYfSr9vZfZ4EQyRkgc4HepdoU/wCsUH3NdMaCa1M3 NplCJzOwUxMh/wBodKle3l27S2F9AKsOWJ/5Zk/zp0TMBtC5PsRVqhTQlUZzOqeHk1FdguPs 7f3gKxT8Pr6KRLm21xBcQndExTuOx9jjmu8kkZCTMkSjscjNIr7+UK49hV8kUHMzJ8PajNqd rLHdQpFf2b+TcwofusOM+u08kGttVJHMR/KuZ8R6PexXtt4h0gMLiE7L6GM83MHPGO7AnI+l W7fWvDtxbpcR69LEjA/LLJtP4g1hKnZ3RSd9Ce90uBpPOhsLj7S38ScL+NU5LDU3JVrZYyDl WVS2frUpu9HuQWi8WhQT/wA/KjH61nTGFpwbbxsgP91rlW4+may5rdTaCkiy2m3rSbpccdMJ 3psVrqOwtLCrKAcsAePwq3aNeKFdtSgvbcrkMGrQ+13v2X7QUijgI+XzjtyT61KlfcptmXHl lGI5FP8AtIRVpbl4DlzvU/wsM1bSS7vR/os1sEUYdSN21u/4VJ5bqFWUwOf4jkACmpwIfKUG m02c4ntol54JUc1QvvCeiakNwDwP/C8eBWy0djI4jhaKQk4IRgcGoWAhkMcMq5VsMh6j29ql VIX3FZs4i+8C65ahn024tL2MDPly5VvpkVzVzaGOfZqejvbOpDb3i2k46ENXsUbhuNwjkA6M 2DSzhZIwlzDHcI3A3DdRKtB6MnU8ttrx7ZVNlOxI42u24GtaHxHsizf6ckh7tbHafyNdDfeC tGumDKJLCUncDEdmT9K57UfBmt28eYDHfQg5yDh6cWn8LKv3NXT9d0W7UeVcSQt0KzyYYGt2 ODzk8yKZ5U9Ypc15g9osQZLy2ltJehMyEDr69KpynUbdTLo+oXFrIrBmEUnDAHnjpzQ2wsns eyRK4wA7jHZmqYF+hwfxry2y+IHiOztPNv7S3vbdSVBZSkjEdfbNb2lfErQNSljiuor/AEqa TOz7VFhDg/3unpTjPTYhqx24iRm3eWm/GM96VoWP8P5Gqlo8OoLusNTt5xj/AJZuGP6VaEF6 nG9m+grVWFYhMDifzSJOBjAb5T+FSeay/wDLHNPC3ncHP0pD9rz91D9VNHKtxDEuWyf3W2mv Jv8AvD8hUhafHzRJ+VMLAdVX8DSdMEVntklOcMOenSq0umFvuSOh9jWkCh/iH50u5l6YIqVd Duc3c6RroBNhfwH/AGblTj8xVGey8dwxkwrpExHbLf8A1q7PzeMGMZ9qUTQkfMpX36VpGVt0 NM8zm1D4iWzEPoNlKM9UyP8A2aqx8R+N1bD+FoifaTFesq0TD5Zl/E0jxo45ETfWiUo9Qcme QTeKfGiAk+Di2P7k2azZPH3imOQo3gq73DrtVyPzC17RJZQv0ZUP+w1Rf2ap6zv+dKPKide5 4UYcDpSrCD3qwYj2NOjiPetG00Ig8gYpPJB45q75XFNMZzQgK6QYNTeRxU0Ssp7GpmG4c4ob ApiLjpVmGJCcMD17UbD2qRVNSMVrUY4/Woxatu7/AIVaQkdafvIqOZ7MBiW/AycGrEe5Bgk/ nTQ2acGFNS0Am3HHU0oY+pFRqwp4YY5oESK/qTmpA59TUAZe54p6svYindodiYPjuacJCP4j +dQhhntTw645xRqwJlkb+8aeJD/ezUCshHBFPDL6iiwXJllb+9ThKR/EahUr7U8PHjrS0AlE px1Jp4lHc1X3L6inBxntRcRYEuOePypRKp6hT+FQ5HqKXI9RT3GWBIv91P8AvkVzviHZNqcA bywUi+QYHOSM1tjBHaue16ORtTt3haPcseCH6EEjP41MnoVHczJbO38wboYo3OcOow/4EVG2 t614fcXdjq08tyPurfOXg29wR1B9D9auTBMgTAOUO4FPX2NZV9ClxGySrujxyprj1TNmro3b T436raShNY8ORyqBzLZgnPuAc8fWumsPjJ4XvmKSbrSUcFbtVjwfqa8uMYCYCjaKgltbedNs 0KSD0ZQa6Y1kupjKmn1Pck8XQXADw2ttOh5DRTI2R/3zUkXiUzH5dLZPcsv9BXgSWUcQ/wBF kmtCCebeQp/KtG11bXbI5i1aWQDoswyP0q/ay7kqjbqe5x6pLKx/4lan33Kf/ZaVtWkVf+Qd EG/u7wP/AGWvJbT4la1ZKi6jYRz8Yzasck49DW9p/wAUNAv5PLuYZ7OXA+a4Tav55p+11FyM 71fEFtApku4haoOrllIH8q43WdX8La1DBFp2kzPOHZ0uI4AkeOpzg4Oc8ZFaZXw/4rt08yeB 2iOYmSQYz7jvWRdmGxdIYEdGAOQBxjPWpq12lZBGnqYZ8PxPcNK0UIiI4yBnr6U+40jR7yFo ZrVQGYMssPysuPQjpV9nk/1gCyD+6O9QxyR3SK4jaA4+aN+GH4V5vtLy1Z1JWRqeH9Qi0P8A ctG0sDZCxgZJz/8Aqqxreq311E8TsY0kBCxOw+UYxkAdCOtc7BdWFxdPFaXTT3MbFJIkbJUj +uc0/wC0oxWZbdmJyGzy6H3ptST0DlK8EVzZ6hDdWuq3EE8eA+JTiQc53L0PX9KXxP8AEvS5 LaW0sw91dE7kNscoevU56cisLXtWie6lhsstOUVTkYwwJ4/HFM8M+GUMT3GpIsCM4KW+zGCO OeO+K6IU1JXmJ22RhonivV7wXenzzWgEm5fs8rKqNnPbvzXRpH4/muVE2rwWkgJElymWac5+ 83GD6cYroo4RGVjhjCAH7qjAP1pGV5E5JVemOhFN1VHSKQow7nO6l4W1zUWN1f8AimWSYRiN TGCgwD3APPWsr+z/AB74cmS4sdXnu40IxGJ2ZWGe6k4H867tY8RqGckDIz3pw2B1xzzR7f8A uobhFjtN8Q66bFEuHW4uAMs0p+6cDIx6A5qSHxv4ls5EfyrOaA/ejIZSpB7VyHieS907Vo7y 0mKK2WCH7rHByD+BH5V0FheQ6tpFteRxsnmKSyEfdOWGP0rPlk/eQvI6hPiJot7aiHXtIube RkyVaHep7nBHWll8P+FNWiFzo+sw2srAbVjlXH4qea5sW0ZIO85x37VSudJtXLMbdAe5Xgn8 qFVkg5LGxqnhnxJYxAxw2epWo52xEhwPoeD+FclDPcWN0Yr2wuIHCkqLmMjnt+FXkintXU2e r6la4GPLinO0855BzWrb6vqxQQ6mkGpWgzzIuJfwPQ1pGrf4ieVmRbTvZyfbrWQWM5BHmW5w cHrmtax1zxQIpfJ1t2j3Dy2lj3Hocgn61RvLO3upmeytZLNG/gZs4qxa2s9tCElYM4OSV/Ht S5k1dMaTNQeI/F4TKapbSYPzZi6CrB8Y+J1Cr5tupI+8Yyc/rWSpcOcjYPWkacsME5x0yazd aXRmiZrjxt4rCDD6fJnqGRhSN418Uq237LphJ6Ha/H61icOCMkHrnNK5mj25dTk4zmj2kujF ZGgvjTxdC0m+30ecbvlO1sqPTrUkfxB8QjAOlaecdSC2D9KzHiYt0Kk9wetMjhbZtV1A28hj z06UueT3YWTNiH4l6zMxA0W0wMjdvODzUrfELVcZk0K3b/dlrmLC3VI5I33h1Jyuc45NXDbS FcADr3NNNrVyZPLE1Y/iFeSh2k8KyKF7iRef1pX+I0tuEI8OXnIz8jKce3WsZUlhUlwpXPDK eKcP3qI4OeOtDd3cXs0ajfFmKEB7jwvqBAHJVAT/ADrv9L1K11XTIL6KCWOOZdwVxgjnHNeV tEZBt3JgjBDVvaZ46udH0y3059FNwbdNnmryH961jKHcTgcWRmgKc96lIzQK607GIDdigZzU gAxmkIzSTYCLmpBnHSmr1p4oeoABT1X3pM56CnDNO2mg7jhn1p1NFOBAFJLuFxwOKeKYCKdm ndBceDSj6UwHJFODe1IB4Ip2R6CoxTgRQA8dOlOGO4pgNOB9jRewEgxjoKcNvYUwEHtSjAo3 AeD7ClGPSmfhTh7UWEO+U9RTgVpn1owD3NJrsBICtLhT3b86ZijGO9CuA/2DN+dZ94g8/eWB 2qAQTk4+lXc1i6lcLFq+0sFxCGz3HT/GplsVEZI6hMBeB29Kzp/unnj0qQTSTklUYsrspDfx Y6EfWonDgZKoGPOGbmuSzubq5RdTyeRxTF2AZeRRmpHinDEmUBT1U84+lNSFEbJQFvXFapJa hZEQKvIojO9WJG5RkDHrQ6OfuEVaOAeFVfpTABuGB2qXMVyv5QLDJJ4pWRGOx0DAnowyKnIx 7UHABIKu2MhFIJNO9+oFe30iEziSIPbkHOYGKfyrqLK8CxKVMl8wBA+bJx9TWTaqzMBIjJkZ wDyK0rOCOJ8qhIYYLLwTUVItoEXCxu1yUa2K9Axwf0pq2UbKsvnzmVXVlkJ5K91YdxU8cBY4 6HtUohWMkE5Oc5BrnjBIsj+yRJJvSKNH67o1wfzqDU71dO06W5VUWVQdhY43Ng4q0UdnGyUb c4IPWub8V3kolSwMcLwlDJux+8ByMe3QmtIXcrA9EZ2iafLrGsG5mBMNsd7MvG5m3YHv1rtZ LiR2YyheTzkVl6FbrZaHbs7LFLKglfe23OQpHWlv9a0/TZI1u7pdzsAFTk81vUbfuozjvc0V G4na/TuTikcucj5nz3qsl5Z3DL5cqru6FiAD9Kmkubm1nSI2ztCwJMyjKj05rmlFrdml0PKl sEZzjGD60B59hjZVCjuBTJLZ5VleG7w7DKZHCn0PtU32WScLNFcQpInJB5Vh1PHrRHbUqxj+ IdLuNV02OO0ZftUUhZTMcKQRjFP8P6fJo+jJbXUy+fuLy4f5VYluB7citWSGOZld96t3QcAm ozbW7XRkJcEqA6H7rY6ZrSNaSXKiGtSTDeWzdhyTimiMliwOD3yaYkawiQgyMHXa3zcYznpT UgQRmJmd8sGDFsFcdvpUczuMePLf0J3Fc9OR1pjTzW8scRs5N7ruAI4C5xuzU+xC2cAMCW/G nYLRqzLLgZAJOe9TK72AidJi6ujwiPZ8y5O7dn09KrLZ3qzAi6iMQ+YnnzC2enpirvlITkNk /rScL/Dx6Gne247lKbT/ALRK8k11IhI+QIeFPrTprC3uYsO8kc68CZen4iraNl+Bwc4yOlRk DPP6U077BsNhgMVrHEJQ7qgUuw+8fWqsVi8do1vNcNIxP+t9varmAOQCVHp2pr5V2AOCeoNK 7uIqxQTW8io1yJYATwR8wz71KYoHExIA4O1sdBtPX3peTJkgD8aSRh5E5ORiJyT9FNXfmQXM /SNNayMjR31xKJU+YTfNj6H8avLbMiuhuGYsQQx7Y61FpxC22I3ONnGauHhT3NJtvcEhgUGZ X8xtqnPlEfJn1pPsKeYHF3KoDhti9D7U5cBD1GetIrY+6gb+dTezAV7YBt0Ui+WPvK33vwqr LBMJGCNlexzirkaMQWKlRjpQVXP38VainqJmVtpdpx0pO9KCfWvRexzCilyOmaTr1oHNCsAo Gaeu0feBNNAFOpWAdhSeAaXApopwxQgHAc804Y9c0gFOAA9abEGKcKTgngH8aUDmkgFB45pw NNwPandOKW4xwpc4pnFOHTg0/QGxwp6n1NRZpw5HSjbVgS7qUNUYxThikmmFyTdSg1HS/N0w ar1Al3etKGFRZI7c0oJ9KjURLkdqM1HRmnZsB+a5/V7iGLWo0eIGV4cq5GeAQMVu5rB1osup ofl8sxAcrnnI/Kk1oUkBmd1AwAR1YDrVaQHdkhc4696UTfwqu5upHtUTXDDKhAdynJ7iuOd1 ubq9hj8nbg89/Som4bDHkGmySeYrKoZZV4I9DTUWdkAmZS4wSVGBmkncQ8lWKguq845NVvtL 5x9km/3uMVP5SuBuG4g55HQ+tTxhgDuG4YwM9qpJfaBEESSMxZpMqVACnt/nNWIrWEOHWJFc HggU9IsxjkAgd+9ToD7fhS5oXBeZPDGXK8AjIyPWqdh4jgm1iTSoLWRNgJV+OcYOP/HquR88 dO3BxTBZWVnPJfG3VXKbWl4GM46n8BTv0kN+RqtcDcvDqCMZprXENpE01zMtvEOS8rYB/Oop C0JiT7PPIrrkSqNwU9Rn8KwrzRb/AF3VI3mkItY5FKwzD5McZyO/f86wVNOWrsgWgur+N7Cz V2sE+0kMBvz8m76/SsCW/vtUZLqcRtPLwqR5PoAP5V2GmeG9I0XUUuI43uCH3bJVBjUk84Fc 9f3MzeIFlmS3jeKZCFtl2qRlD+fJ/Ou+kqSempEr2EHhbWL+OMX17MyzRAEyOcQYwQAPXtV2 PwDdwI7pqCyvIwJlkXewx6GutjIdQg5VkV8t1yQD/WmJLLGzFXZcGs54hp2SCMUcbc+Ar5II iutjaj7lULjb24PbrUPhK+1C21KKxa6nuLWdWOJSW8tuMH2HNdjqN6sNhLI6NlhtBPfkdK53 wfp0m6W+kcs0cflRkc5bHOf++adOr7RPnQSstjqhtX7x+Y9Ae9OjYBiixhASPu8UwTJNgTDD kc7RRFPHNl4gZEQ4JA6H0rmk0nojSN7EqyME2lQyqx5I+bmmhQy+WCw+XBaTqai+3RhS8WXG 7B2npzSG8RpZolXLwYMmf4c9DU3GSGGROAAVx160zDgj5f0qGO/Xz5ISHV0xwRgHPp61O1yx AGR/WhT6WAdmQAEj5SccdaaC4QkgkDnrULXUxXEW2ZWbBA5xj3/SmrJcPCWjjaOUDLRyDOBn nOKTbYF5GRo8HaDnucGkLLwoIqrJGkrhlOBgZyOppXjjYcSTRt6rjFXyuwMnIBbazBP9onFM 3wqyhnA3dCTgGoJIjLGsRuJzjvgZNBt7e4ZTKjErx68UWaGWdyYJVsjGcCobm4i67X4OMkUz 7PAoJSabzFJAJ6AZ7ilMPKo8wLZ3IQvGB60crYrXERon4Vvm+tEgl8iTZHvJQjGPbpUP2JTe RXEkgLxEkeXlQ2QRhh361N9mBgeFZ8BlYB8nIzmp5XELWG26bYBtRQcAYTnHtUrsYwPmAJ/v VTt9IlisZLQXowTuV8kN19aebGdoFiadMqwYucs2fQUcrewEpZhjaCQT26U9XUKMtgnoDVSG xaIusN6HVzk7s5X6VZh01I2ZzePMJcNtlP8Aq+MYFHs31CxLvbYQCTScnqD+VDwsYign2E9G XtVf/iYrwqKwHQk4Jqo6bBYp5pRTOaUE16exyEgx/FnHtSnZn5AQPeo8ml3GkwH8etHU03J7 ilDexoAXP1qRTTN2B3p276UKLAeG5p2feos96cD7UcrGP3ml3n600HijNCTESbjilBHcUzin dqTVgHgj0p2eKioFJXGSA0oNNANO28VWoWHqw75zTwwqArt7GnoQfWlYCYEU4EY71GFp4HFD AdkUoI9aTBo5XsTTu0IXK470uRxxSA+uaOMUDugz1rmvEBjGrWTOJGVomBRGxn5hgmujPcjn 2rmfFA/e2z/MrbCR+DCpbvoAyR49irHuX2brVYTMMA4C/Soba9M+1Gx6gkc1YMBcZAJ+lc1S y3Nosdvicfu5Ff1ApOp4pn2aePGyELkA0qxyZCuwVieAO9QkmUShcHr+VPAPTIx1FAjZVywx j2pMvNbs1qAJF6eYCAeeRVPRajuidUDISGDEelPCLEpeRwiKMsxOABUcCNg5BXd1A6irCq2x 4ZgJom4AYc7T2NYytfUQ8YEPmRAvg+n3h61PEJo5m81I5YGwSjZ4P0pkcYt0EcIJRPlVT2HY U9ZZnVizH2HcUJp7FJlmOQorKjsFPQZ4FPEkmxQSpA6c81Ciuyq+eSBkY5qQxRPy2dwORk8V EnqFh7COSMggluxzxXG+I7OSK4gvFgYwzLgug+63HX06V1skqwoHO0LuxgnrUV2Ymtwr7zby 8bY13EGqp1VGRLV0VNDvF1LTEV5SZ4FVCM/MSABWs5KBZZDEkOQGDHBzz61yl14cR2+2aK0k NwRkJITGf+BY5xUjaRrmowC31W8it7XcNwhJJYfU961nDnd0xRujP1b7VrGtzNai7kiilePb B8wiALYyv5fpXYWFmbOxjggYwhR94jh+TnPvzSabbWmgJ5NiGXJyX/ifI6n1NOcSCdZcyFRn 9233aU3yxshpdWWQWI2SAEE/ejHOKgFjbLK/lPKfMXaw34z7gDv70iTyicjyh5YGd3vmo/Nd Zw4ePYDyFHIrGN2yiZIFtwY1VTCCflA5P1pVeILsSNVLDaSV5YehPeot8zzExgop7uMVGGKN mUtIPenYETXHlTgJOVIjII9RjpUcp3xgMo25ytRMS3mbU2qfuDHv0qMtKcJgb84IJpBcsxpg nZ8u4knHGSepqUhVkaQs3mFcE56/WqyPjkxyZHYDrUpMJwVWQ5H3SaFdbhdEyyErtYfiBQ0t uSQSwPTkVG0zDooHGBUUjsFLFQ59FFC12GWojtkDRSLuHIpRkNllJJ7jpVURh1+7g+3FS4kK YEpAHbrRaV9SRSFMjHpxTyoAB7etV/NIYfLu6AmpXlXcFIIPHbiru+hWwMdjspUAetMZwYmO fansjSD7wx7VXdHRNvllwfSkkyXcmRhs60p+7tHBJ5OKhSFmXkbcetWSTyo2keooXN0BCKEU YwPrimO6njbSOSqY255qmyNO4OWXFFpN6hcuBgWxk59qeck5B4/Gq8e4ZHWpNx9DTFczAR6U Aio/qaVeTgAk+1en0OYkzSZ7cUxpAgO51QDklzjFLkYyCrD1BzQk7XAk3e9ODDuc1EKXOPWm BKSD0BFLgAdaiDoCN+7bnnb1xU9wtrHMRZySyQ8YaUYbpzSuAn40opgOe9KCKLgSilxmos/l T1bFF7jsP6U4Z6U0EUoIotcB+KcB70zIpykYpIB457GnAAdjTAwp64Peh6gLtyOacq4oBGPa nblHO4ChAOApcHHWkDJ604D6U7CDn+9SZb+8BT8DvScf5FA9Bv7w91I+tGHx0Ape/T9KQyAd TRZAGGHRRXM+JS0l7FExxiM4/MV0TTICeXJ9q5nxXJHB9numcAE+XjHOc0nEaOfgtLpJ8gRl Q5IOee/aunsxMy5VQcAlgBXJtqkTKv2W5QXAOV3H5WPpW7FdkhG3FTj5gGwD9KxqqS3RcdDc XT5XRXiubSID7yzv834CobiyW5hkg80LkFd8Y+Ye4NZZtWlnFzEP3gXAJOeK0YriZZSJVIQ+ grlu0yuYqvfw6e5triTfFgZ3H5h7irkd5YmJZN+2Mg4JI4waytVglmunkjQFSAFJHPf/ABrK 2XESbHQovOFxx7kVvGCmtwc7HX+fp0bjzbyCNyPlDOASDVj7HGGLsxA6bg1cSNPWUoslmXwO GZM8e1WFlvYpZIkupdoIypOff+tQ6C7i9ojsQke4LGdrddzHrTwvByBwM5AxXO2El28i73Lx AnBc9Dj+VWHeZmjMlyPKXBAjHJOQeT6Viqbva44yRtAO4V4ZUaIjLOOdp9DVWWG5VyFuRK4d SCowm3vUT6jZxRsXLRRso+RR39amXV7dEWQgshG04HIB/wD1Uck1si+ZE0Folu4LL5iK5cJI cjn2pLa2jsJWSOSTyScqN2SKrjVoJvkhWRmHtUDayg+WSKTC9TtrONOo3sLmRrt5Yl3qXYFc Et1qPzCRjdypyM1nrqtsyuQzAqu4KeCfpVc6ncSgPbWjbBzIzDlRVeyncOZGyJyZFYIN6HIY jgUSTO7jc4AYE8Cspr2aeBNs0US9yeoqW3nuFn3zXVs1oy5jVOWB9a1jSl1DmNBCjEruxgcl ulQXNzaWcqxTSQhH5EjH5Qewz6k9qSaSymTbcyxuFbdG44Kn/CmpqUJiaJ44mQEYGwEHHep5 GmHMiVrhHu40JcM3DBuwxwcVNCPMiLMq7OdrjofemPrEX2WNdiFw5+coNwGPX0qE3sezLPxj ovapcG9EPmQ6a2mVXzuWQgbe4I9qyrg3EG6UZkCDlFPzE+laf9pw45LYHrVK7ktnufM+Z14P Hcj1q4wa3J50x2dRuLKGaz8qOUgErOSGX1BAq+9rcNGjWnlmYZD+c2MZ9MVjyavBnKQS7t+3 aozitATGKZXaQMpBXbnvTcJdhc+pImman9hKGaBrncSXd+FXPGKWYzWluhWITO0ioXXooPc+ 1RnU0U7MNvPTHerSXahCuxhnvS5ZRWqKU0ynPJqK5+zpGGB5Zz1HfFTsJ44mcJ5jA9FHT61K JVcc7sjoRTU3+UAJnyOMDofrU3vuULGzSHD7Q4AOw8GnS3UEWfNkTKjOCe1K7AKnmRruwMNj rTSIJCPNggkI6b0zUJvoBHHf20p/dyKxxk7CCAKBrNqF3JLHKCjMAvzFh7etT+VZ4+WxgXIw 2xMZpsVrYwKqx6fEiA5UKuMfQ0211DQWG4jmRGKsAwyA3BFMlvLSGQgsC2QCqckfWpXhheMJ 5ZjAORtOKaUgiOUgjDnGWxyalSs9BEc837sFTgH3plvNGztENsjhSSAeRimTwQ3RKyI2O4U4 xUxgtXljmWBo5YwVDR8bh7+tU3cCsLqISsiOpdfvDNTNc4JBU5+lSXCW9y5cxNFIcYZFAH40 8xyHrPFnHcVcfMVjACnHU0KSDwT9apDUrfOPtEXX+9T1vYGP/HzCP+B16drbnPZlplV1KuA4 PBBGc0qqEAVAAOwAqsLqHOFuYWPpvFPE4P3ZYlP++KWoPQshWzhuD6U4IRjLHnPBqqJn3bjL GxJ67xUhmkPQr/30KTYmSkY608DI6mq++Rucg+4anIx53Kx+h70N2Anx9aM+tQ5l/uNSjzP7 jUbhcs7cL94UD1BIquC2fuNn6U/dIB9x/wAqbQE469acDg9arBmz9xs/SnByP4GB9xRZgWQT QTz/ABGoRKeykUvmuf4WFSkBYFLnHIyfpUAc8ZDn8Ker+uaYywnJJDAjH3alVsA4UfjUCew5 qYHHTNGgx+4LycH8KXc2enHtUe4d+tLuIGaaETCTA+6aAxNQ7+OtAfknNGoWJ92PekDjHP61 BvH940ocetF+oWJWbjoMfSuX8TxrcvFG2Cqjdj3roXORweawdWzvGQOlO7eoHJyaVAxz5S59 cVD/AGFmPb9puAvPy+ZxW0TlvxqdBnrTlPuHKYK6HMQduoXa47ecacNDvTuK6lffL1xKeK3i MnpT03DO1sZ6+9Yucew+RWOcbSbxWGdTvfxlNKdLuSPm1K8bjvLmtx03Mab5IPrVQn5C5DHG makwA/te72gcYemf2RdDcP7Susk5J39TW4Iz0yacsR71o5JdBqJif2XqewKmr3IUHON1PTTd XUcazMMjByK3FjP1p4j5rN1I9EUkc4dL1YZJ1SRsj+IZpy2GtKD5eqMEPX5RXSCNcdKeIxjp T9rZaBqc19l19H3Q6oQfUxgGneT4kY/vdUz77Aa6PywOmRSeWMc0lUXYLyObNrrRBH9oDcV6 mPofakeDxFKCP7TMSg5HlgjP19q6Xylx05pNmKaqLsGpzyr4jRdq3Vu4HQshzQF8RdGu4FXH 8MZNdDt4pUUcAjIFHtEtLA20c1s8Q97iA/VDSqviRTlZbY89NprpmVT2FKEI6Hinzx7AmzmS 3ifPM1sR9DikEniRBgyWrDvlTzXTlARUfkjvU88ewXkc28/iInDPZrx2Vqas3iNM4ltTn1DV 03krgjA+uKiZACQAKalF9CbyOeW48QRsSBaEk8/K1SJqHiWMfLDZt3yVbittYMHJPU1OIjjg 01OLC7OcN/4kZ1fybQOpyMKetWxrni8Lg2tifco3+NbHkgnOak2kDJonOLWqBNmH/b/i4DAg sfwQ/wCNJHr3i5Dxb2fpgqef1rd5HtS/lWT9n1RfNIwz4g8XEZa3suOilW4/Wk/4SLxZx/xL 7PjuEP8AjW6QSKMH1qUqf8pXNIxF8TeLV+UafZ/ip/8Aiqc/ifxbjB0+149j/jW127flSYHt RyQ6oXPIxv8AhJvFxyPsFn+Kn/Gj/hJ/FI4fSbVj2IB/xrawO9JgDpUctPpEOaXcxD4p8Tht y6Vbg59/8ad/wlfinb/yCoB78/41r9G606qUadtYi5pdzJXxZ4nUZ/smBvxNMbxV4pLE/wBk 2345/wAa2eAewpCRmjlh/KHMzghGo6DHPamGFHxuGeMU/P8AOgmvRMhn2aDBHljp1pptYvQ/ 99GpS2B+FITRyiGC3RR8pdef4WNG1hjFzOMdxIafnP50z0x6UcqYCkSf8/Vz/wB/TSjzgCRe 3YPtKaO2fagnr9aOVAAa6B/5CN5j/rqaBPfp01K6/wC/hNIT396QH5RmiyCxIbvUdvGo3Ix/ t08Xupxk7dUuevds1CT8pobpx1o5UMtpq+qhMG/k3bs59R6YpF1nW15/tAn2YVUH9aSlZBdm gPEOuqOLxOndKX/hJNf24+1Q/wDfJrP7UmeT9aLIfMai+KfECDi4tz9VP+NOPi7xBwC9oT67 T/jWTmjIx+dHLEOZmuvjDxGOjWf/AHyf8acfGviTHWz/AO+T/jWNnk/SjIH50uWPYOZm0PG3 iTutkf8AgJ/xpw8c+Ih/y72J+qn/ABrE/wAaM8UckQuzfHj/AF5VYPY2TNj5SFOB9eal/wCF gansyNOtTICAynOK5vPr6Uh9qXIhXZ04+I+pKBnRLQ89mNL/AMLI1A9dBtvwc1y4PT60oJwP pzS9mhanUD4j3RGH0KLpwVc1BP4yW7bL6W69Oh6VzuMDHtS57UvZIDbGuW7FSLRxzyMj/GpG 12CMcW7k+grBDYNKxwePeiVFMLs2R4jiOS1nOOM8Af405fEtmc74Llf+AisPJpVPzDPqKX1e JXMzfTW7SRPMRZNoOMMMN+VNPiGzH/LOcf8AAawnI8w445NKv3Se+KfskHMzfTxHaNwFcfVK VvEVlG7I4kyDg4XvXOc/pSk8k0vYruHMdJ/wkunrg/vTn/Y6U4eKNL/vS/XZXMg9xQTuHOPy pfV4AmdR/wAJNpQHzSuPfbUg8SaR/wA/LD/gNclhR2FBVTkFRz7Uvq6ZSkdaPEelMQFnJPuK T/hItM37fOIP04/OuUAUfwj8qXgt0HT0prDxByR1661p8n3J93GTgjIp41Wzbo5A/CuOQhGL IoUngkCnbiTncc/Wj6sn1JudiNSsu820eppBq+mZ/wCP2P8A76FcduJ4LsRnoTxTPKi2geWv HtTeHS6j5jthqumN/wAxCAfVxSnU9Nz/AMhG3I/3xXDeTDj/AFSf9804QQ/88k6+lJ0E1uHM dudU07PF/A30cU4ajYlN63SFfUGuHEMXTyl69hUsTNEGEeAjKQVxxzS+roOY7E6jYlC32yLA GetN+2WZP/H5AP8AgdcZ5Ue4/IOnPHWlMMOf9Un5U1RsHMdn9tsl63kP4NmnLf2LAFb2LB7l hXGqqIhUIoGT2qPyIyMGNfpij2CBSO6+1WpH/H3Af+Bij7VbHpdw/wDfVcMLaHp5Y6UptoSe IlqXh/MLncie3Y4FzETnnDUvmwf8/EX4tXDLbxqdwGDnqDzThDH1IJP1oeHvqHMdyJbf/n5i H1akaW3B5uof++hXDiBMdD93uaVYIwD8ufc0KgLmZ2wmtjx9qjz9aTzLfH/HxH/31XFiFMjj oaUQxhfu1XsL7sfMdp51uP8Al4T86PNgPInjP41xvlrjpx9aQxKWJwR9DR9X7BznZGSEn/j4 j6+tAliB/wBcnPvXHCNQQcnj1NIYlC8SSH23dKTw77j5jtAYifmuI8f71DSQA4M6fnXELChQ qSx4xyxpTCAf9dIPbdTVHuTzMrZz+dLgg8+lLikxmugkTOQaCcA/WlICjj0pAOaaQB0/Okpc ZOB2NKOlJgJnikNKPu8+lHFIY080dqUUYpiGnpTieKSlwBSGJ2pM4/WnYzTQM0wAniloI4zS UgFpAaUf1o/wpgJ2oGOaXtQaAEHSl7UYxjHrQBxzQISloPSjOc+1CABzRRR0HtQMTtS0UetJ AFGfzoFIT7UxD93H4U3OT+NHv7UZx+dIAzz+NO3fLim9fzpRQAhPWlxgnFIOB07U/rTGMH9a WigD5eaBCc496WgdcUH0pAAoGaOhpR0oAAeM0Z/nSL3+lL1oQCjmjqPzpV6UntTsMBzTxwM0 i9/pRjOaBDl5PtSZ59qFOG7daOrUAKMmgcmjO0fhTulACDk+2SKUULijHANADgOPwoNKvI54 OKafvUAPXn86KPuilB+XNCAKd/jUZNODZH409gHEYoHSmk80m44Ge4pAOo700c049KYC0gPG KAajZtppAKo7+wprD5jSr1z60rdaLAVz1/GjOBQBg5NI3NFgAHNHc0Y4/CjvQApOMfWmjp+F LnJH1pOmB7UIA/h/Cggn86MgqR04oBzmmAenucUlH+NFK/QAH9KQ8Z+tL260jevvSABnP4mk AwM0q47etH49qAA0E8Up6UnU0AJ0o/8Ar0pHSm5I4pgKehNLSdeKXkdfWgY7HFMpc8fjQP0p IBOtO7UhFHaqEHfn1oHTmkJOR9aOtIBT0NHWjtg+lGaLjAcfnmk7c0o7/Wk6flSAKX/Gg9KK Yg5oA/rRmgH5eKYC9z6YpR/Wm9qBRoMXHP40nTj2o6ZoxmpAUHP1xTgBTRwKUHFCQB1NHak9 6OMUxCqcDpQOppATg/QU4jAzRoApOenrQBlaQdqXO1QKABR1z6UoPUe9N55pV7mkwFXqT70o +9SdaX2oGDc1IR8tRkcU8k8+5pgIv9adkFaaB83407bQIFPOPalP3qQ8HPtTiO9D1BCbs8Uu eMUDgYFCgUr2AUigcAj3pMgt15xTd3Jpt3AkBxTev1pRytJn5fzoAeMfpmm55xQBTfc+tADs YppG4g+1KeVH1NI3C0DFz6U0k5oXpQ33jTuxEJHFAFBOaQUkAA+vpSZ649aXtQOpNAAMikwc ZNLn+dJ1xQAcFfwpB3pe/wCFA70XAQH+dAXd70mOR9aVcjBBwfagBP0pcZzTy/mAg4Jx170z pSAQDFGMikH09aWgYHvRQP6UvamISkA5HsKWjI4xQMCefwoJpKDQAtSJEXQsOlRYzT1dkUgE gegoSENORRnk0daSgYoHNB4pAefxpSO1MQdaSg8D6CjGD+NKwwGP1pT0oApOgosIM/lilpM8 H6Uvc/WgYY5/GkFKKTPIFCYgHH5UtIehPtSnj86GMMc/jR3Ax2JoBPX3paAEPQ0daMZyKWhA KOR+NIBzR1/Olo1QgxlT64pc5BB7GnbsLTOpNIAp3UU0U/2oAafukd8Uq8A+9IeDSgbvzqmA 4DApCOaCeQKeBmpQCDn8qcT1pn8VP6j3qgADHNLyaTqtCnIx7VKAUcnOKdnPFIeF4oUYBJ9a AFI5H1pP4adxSdaYCBMflSBeTUh6UnrRcAxxijHApRQeBx1oY2HQUhOePejPGTQOpos+okLt G3n1NMI6Clyc0E5NGg7MOMU1uvSlbhPwpCzA9aEIgx796O2aAf50gzQAhOTj2pw4FJ2oNAC9 TTT7UZ/nQBkUXGKPu+9J3pMcfhQTyaNAF68e9NzyKVc5oGMZoQCqcNmiQbXZfQ4pYwWbAxz6 nFNb7xz1zSEIM8fWjHH4Umefxpc0xgPX2ozyaQ5xRQIUUhODj2zQOtKaBhnjFHOTn1o6Ucc5 oAUdPxpOtHf8aKLgHY4oPr70vSkwM/jQAAUucD8KO9IOTSADyT9BQD1o/wAKO5+tO4C5pKcB k8nvQQMcH1o33Abil60mev0o7mkAtJwaPxoUf1pgGKU0e2aTn9aAF6UdqT8e9KucUgDvR0zn 1opcZFOwhRyKF6ikH9aBzRcY40nrSEkCl7/jQIB/WlzhT9KBzSDnHvSAOoNP+6OKTHFKT/Oq toAKRz9TSqaao/nS5+XikgHovJJ6YoJ+b8aVOEH0pG5P40JgKOh+ppVGEzjsaUfd/E0nQYpt 3AM04/1oxxSE549DUgPHFJ1NKBSYxzVbDsApyqeaOgoVjz9akQu3FNOc0uSc00njHHStUk0A 4A7Rnrim9GNOBBWjpmoegJjWHINJigtlqeDkUrXHcjf7lMJ57VKwBOKgfIc8U7IBnekz/I0D OaKQhBnv6UtHUYooAMUg6+1H+NHbFACHmlxzSdBzS5FIYZ5pnNOB/nSD1p2AP50H096B159K UnnigQgHr60YpcjFIOefajQYc4oooA60AJzkDPegcgfTml7g+lJ6UhC/X0pPWlNHTOKYCZI/ OlGaM0ZI/KgYp5FIfT3o7Y9qMUgDr+dIBjA9qdScfpQITt+FKoJPHrR2NKDimAHOaaDxzTm5 5zSY460gE7Y7Yp3NIelFNDAUqnA/CjrSdKPQAPr7UY5/GgHFFAhQKTpil9PrR2oACTSikpaB h1PPY0LxigHmlPFMQGlXk00c/lSqcE/WktAFOR+dIBjH40vXqKVenPpQ2AZo7/jQT+VAoGLz +tJjjFKBThytAh3RfwoUc5PrSL15p/HagAY4HHrTN3SlznikAyDQBKThfamD7x+tOz8o+lIW +b8aTHYeD/Ok6rn2pMZIp2MD8KteYrh1FIDjNHfikI5pNhYepFMIy2faheCPc0MvOe4HFHOA HOadk4pMGlApbgM/jH1pQfSjHzUu3HQ0wAdM96hdTvPFSjpUTt8560hkQpKOcUAfjSEOVtue B0pD+FJnIxRTAMAfnSAUuRSZ9KLgIeTj2p4AwaZjmlJwKQBxn8aSgA9z3pKaGOBHNJQMGjPN AAPrSds0D+tGQeKQBn+VHQUp4FJmgBabTupx70hpgHJzj04pe5FNHf6Up/rQAvBpDkDOOgNL SDnmkAvajNGe3ekOTj60xC/jRQP60CgAzx+FGP50mflpaAHpt/iJHNNAwq8545pM84oPNAwN FA/TFFIBce9IDntRSgdqYCYwPwoHeij/ABoEHP60o6CijPakAhzjNO7U0g4P0pTT0GKBQCTj NAII/GgdqBC45pDgH8aXPUUh659xQmgHAU7oKbjjNGc09AAZIp3SkXOfwpSO9FxgOv40q5x+ BoXkH60LwCKQhwG4U4H58e4oHApM5enZ2GIw+YfWnL0pSPm/GkQVKQhR19sUpADfjQQBSHuf em0A/FGaRTxzRimuwCjjNDGg0tJ9gEbjHHehcml60DgUX6BcD8oNM9frTiciiqsFxpz+RpQf WjHIpKmwxDw34VC+7ecCp2wVz3xUZ602IgOD+dIOlL/iab3/AANIBTwKCcUE54HXFFAw70nQ Uf40E0MQuaQ9aO1HU0hi5poOeaUUelNAJ6ntRzkj3o29fpig4BpAHPHHHNHen5UqMZzk5ppp 2QCHkcUdaOxPoKOKBDuAeDScdKQ9aBjOT1pNgHAoxRjj8KKaGAH86O1A/rRn1oEB6celH+NL 2pB1NFgFpOvalHvSAf1oGKAMfhRmkx60uOKAE7/jR1xS0UWEHtRnGeKKMfzpDDuKMelLjOPr QQM0AA6UdqTtR3pgKKDkUn+NLmgA7fWjHWjtS/40rCDFA4p23jOe9NBNMAp2P503/CnUKwCg 4oByab/jSjigB3alxkGm5pwNNK4AnDY96Xo1NxyD7088jIo2ACf1FC8Gk608AZNIYuaaOD+F KB82KXFCEL1waUjIpBzS4zRsAAYoByKUikUZFUrCF47UYxmkxx+FO9aLDEHWjtinUlTYQh+7 jvig8UpBB/CkYU7XKa0G4zSqOKPT60DkUNWJGkfNj2qNvvGpsDJPrUbplyaLIaKpPH40tFFL oMTsT7Up/rRRSQBj+dM/wNFFMB38NHaiigA7UncUUUCFP3T9KSiipAQdvrS9h9KKKAHniOmA 8miimMU03oeKKKAHdqaf60UUwFXp+NB+6fxoopCF7Uh70UU1uA4Uh60UUMEFHeiikgFIxQvS iimAnrS0UUDDvQKKKBA3Sg0UU2MT0o/h/CiipQC0L1NFFMQ6jFFFIBD90/SjsaKKYDv4PxoH K0UUkCDsacOpooqugB3NOXk0UUhifx49v60/vRRSQhfQ0o6UUVSAUdDSjpRRQwQrf1P8qEoo oGONJ2NFFCAOqj60D7v4UUUCW4pPNHY0UU+g2MH3jTjRRSEMz81DdTRRQM//2Q= /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGDAhsDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDg42XFPZQy8Gs5ZCo4OKmjuCB1zxU8orkr Q85qHawPIxg8VcSZG60/yhIMgCpcAuU1kZRilLFvapntMcgVH5TA9KzcbBdlzTcmY+2K6dRi Ic9q53TIiJM47iuibiChtDRzeovlzj0qlEfmAz7Vavz+8IqonWp0PSoR906W1G6IE1ZWME9A arWJDRir+B2rza8LSuZVI6kZT2FAUZ6U/GKOahSluiB2R24qaO4dVwTVelUZ65FVd7k7j1JM ucDFWVC4yUU/hVZQAeKlBIWmqrW4WLEMyQnJRcHrUstxayY8tmQ+lUW6VBwW6VSqTYWLzgSL jdkVcsvD8N8nzzBPes6A4wK04w3kj5vm9K2pzlfVicUWX8BpInyXoyfUVnzfDa6Y5jvUz6Y/ +vVwyTKyhGYtkZ5rUtrC6lId53HtmuxS0J5eXW5yrfDbWBys0bfl/jVdvAGvxk4RCO2CP8a9 DSzu0OVuGx71I0d8PuzGrUivrEl1PMJPBuvx/wDLqW+hFVX8N65GPmsHz7EV61v1NRxJu/Cm fa9VTqin8qFIpYqXc8dOlaukq7tPkA7k11+maXMbZN8LBsc12q6jek4khX8cVdimZlBMag+w o57qxlUqyluedalpkyROVj/SuYW182baUPX0r3D9233o1P1qL7FYFt/2SPce9CehzqTPNLSx ZEAVP0rq/BmbTVL2KQbfMhUge43GukFtadoAPoarxW8MeqqUUKWQ8+oANGj2KvcydSs1kvZW C/x5H5CqN5Yb7fhcmuluox5rgAdj/Ksu5+5jNJuyGjgNOQw69EP89q9Us3zEuPQfyry9/wB3 rsZzgg/1FekWD5gTn+EVPM7G0n7poluKhc04txURPBo6GBw2szlL1gDjk/0rptIlL6fCT/cH 8hXFa/Kftxwea6zRSf7Og/3FH6CtL+6S9zVdqo3s5hgZwORVh2rO1Fl+zENux7Vha5aOYufF 11C2PI4+v/1qoSeLb6TpGAPwq7He6Cr7Lhl833710EPhqzuoxJFbRspGQd9dEaae5SqJdDjB rEM7brwFmz91a9W8MRwppMJgVlRhna3uBWBH4Ujt33xWaBs92zWlCur2ihYY0CjgDIq/ZNbE SqX2NbVgzRYrk512SE881qzSavMP3sAP0Iqi9leSdYv1qXSmxKRp6RLnC1yHjWcQX0paQ5Zv lz257VvQw6nbMGijwR71n6r4cfWnMt7bsX9VOKSpSW4+a553HBAI1xNnI5qve29tHHujOSRz XWT+BdOtU3yO8IxjJY/41yut6PBp0mba5MqEVpZA9DM3AmoWk7e9QNIyuR6YoHzc5q0iUael k7kJ9K3ZYRJatxzisLTQQ6j610qKPs+0jPHWholWuVdOkzCPbrWfrkYLqw71YsiY5ZIz2bj8 hTtVQPbK3XBoY1uciR2p6mkZSCPpQvX8KSbLLtq2JAfpXQpdTfZSkRKkg8j6VzMJwR9a6jRt R+zr5BiV1nIQk/wk8A/hTYmj3Lwcwbwlpxzn/Rlzn8a8/wDE3mS6lOcd+Pbk12zajaeDfD1t a3Eoknjj2KvdyM8151qfiaa8uJPJiRATnp9ahyQolWOwmcZYbR71OmnDaMzx/wDfVZck0s5/ eSEjPShI0K8r+tZdS0cNhsAdxmgPt4NWHQLKPSpDbLIvAquYEV1kxV22uMEZNUXtZUzt5HvT Mun3hii9wZ1UbRvGMjP41HLbqeVxisK3u2jxsfA9Kufb2xzj86EgubFgmHrWn4h9KytJfeST 61qXR2w1lNJFR1OWvDmY1WXJPFT3HMpqEZzUJo9agvdOg084i61oKaoWQHlirykcc159aa5t Tnq7knUUAEikzkcGlTis3qtDIT7tO3+1ObBppHFKKfUV7iBueanVxt5qBQDUiDLYpWd9QJkT zDg0rwbelSIhQ9adM3ycda0SsBmXN21mAyruPpWzo2pGeEC5RVyBhvSuevUaeQDH5113hizC WSiVVbPtXVTjG2pnM0LaO1Eu9Zld+uK2IeVBFRpaWqkMsChvUVYUAdK6UkYtskBIFKDxzTAc UuT9Ksm48fWl5x1qPdWZrmozWGntLAMv0Hp2/wAal3A1Nr5qRUbrg14TqPxC8WrORBLCseMg 7QSapp468ZyHm9iXjOdgp8k+iFqfQwVsdKQ5HavAofiD4yhfm4gkAI4K9R9a7Xwb4/1TWrx7 XULRYyoyHVshuD7e1HLOwcx6Pn2rkfHV1PbQRSW0rRSDGCv1FdWsm5Qa4jx9IdkaLzgDOfwp K9x6HL6J8RdSs9QW21oCWGWQIs6jGMkAZH516At3HeWwkj+6wzXmnh/SbO+1FZL64jRY3DKr dzwc16JF9kgiCRXCMB0wauSQ0clffu9YjI/vf1HNehaW2bdOf4R/SvP9WwNRRgQRkc/iK7fS JM2kRI/hHQ+wqHdI3+ybRPFQuT2pQ/HWoZGGDnNJPuY2POte5vWb0zXT6Fdq1hEm7lVAx+Ar mvEVqjWbXEcpWXBJHbOKoaTfi0Y+ezFAOo7da3grqxEtD0h2BGTWTqt3HFDgk5qjdaxHHCjB yVI/KuX1LVVmkbaxIzWcaeo76Fa6sLG6fdKAzYxmrlvdSWiBIZ5AoGBhqx1lLNkGpVWaQ7UB Y+grqSsiGzcGtXgH/H1IPxpRrd6P+Xt6xTb3g/5ZMeaPJu+nksKNQsbX9u6gP+Xt8elKNevi OblvzrC8q6HWJqNlwc5hYU7sVjd/ty8P/L04/Gga3ff8/cmPTNYW2cdI3/KjM3TY2fpQKzNW 71Ce9gMU8zOh7GsU6XA2RuIB9STTi8g6o35U9WbaWKkUgTfUzpPDO9iy3AAPtTV0ExjHmbuc 8VqC4KjGab9pPUHHuKnUvQpwWxtZVz2rYjmVk6jOKzJJC7ZPPFIj4bjd+AqkJolPyXre5qa5 HmWzDFUZpsXCsQQM+lWPtSNHjkZ9qbQHMTjDVGKtXajzDgVVPFTsXYmjPP41s2b4MZ9JFP61 ip1rRtXwVyeNw6UJsHses+N7Upfxyu+/crbfYFmriGwHIxXoXjZd1vZScZaPp/wJ689k/wBY axs7scdhQamT7gqAcVMh+QVmtGM46ZwcEURTsFxjt0rcbwtdOfvDNInhG6A27+OnWtrIDHaf jpzUEjhwOB1rof8AhD7gnIlINPHg6ZhhpuvNRy2e4zjs4OSQOKeJjt65yK6o+BWY/wDHxSp4 Aw277UBV80RFjRFzHnv3rQv+IDg1YsdHW0XaZA1WZ9MS5TaW21m0m9Bx0OEmIMmM0zqD9K6w +ELduTPj6Uq+D7QH/XnPrS5YnfTxUYRtYpWQ/djmryitCHRIIlxvz71YGlWwA+Zs1yVMO5O9 zCdZSdzKANOGccc1rLptuOrZFOGm2Z/vfgayeGZHtDIDAHk0pORWx/ZlmRyCPqaVdMsxxg/n VqgxKoYkeD0NTD93zWuum2Sn/Vt+dSpZWY/5Zn86Hh77j9oZKzKw69KcsqFsPyPatcWtn/zy pwtLLqIBn60LDpC5zIe0ibDReneul0lPLt1A44qssNuOPKH1qwk/lJiLA9Aa2jT5SXK5rq3F PBrKF5P2I/KlF7P/AHhWuxmawJpw+n5Vk/brns+OPSlF7cf38fhRqLXoahz71heKm26Q2Ome R68irX2247SYP0oa4aZNswWRfQimvMaPn3UdQjiu/LZWzt59vaq8epQBcksPqpr6CNpYk7jY wk/SnC1sh0soR/wGtVUshNPofP39ox7hhX6/3TXa/Dy5WfWWIDAAYIIIzwa9O+z2f/PnD/3z SrFAjBooI429VFHOhWZtwAlBjP5VS1q2hl06VpI8kLwe/UVXE1yPuTkD2FH2i6PDTbh6EVnY s8C8RRW5lMZil37gcIp647VlWl3cWM37tbo5z8p3dK+j3SNuXghJ9dgphhjx/qIf++BWnPZE 6ngDa5ekq3lz5A3AMh55+leweCdcTVNHibBV1UBgQQQcAf0roEiiwMww/wDfAqRURTlI0Q/7 IxUuafQauXVJK8VHKCyHPFQ75u0pH0FBaU9ZSahXDU8816dlhdShx6AdOK5s6oLUktBKwI7I Tj9K9l2L/Eit9VFOCxY/1Ef/AHyKuNS2wmmzxB/EKTNs8ufGeMxt/hVOXVlY/LFORnr5Zr3p o4G620R/4CKT7Nan71vHj/dFWpeRNmeE22oIWA2y9OpQ/wCFaEeqNA2+LeG/3DXsv2S06eQm P9wU37HbDpCn4oKp1UCgzykeLrtc/O3XvH/9alHi+5OMuf8Av2f8K9V+yWp6wxj/AIAKPsVs BxDEfqgqPavsHKzyj/hMZwFJY8/9Mj/hS/8ACZSsQC49c7OOv0r1Y2Vv/wA8Yv8AvgU02FsQ cRQj/gAp8yFyHlv/AAl0o67T/wAB/wDrUq+MnYfKiHnH3P8A61enHTLbvHEf+AUn9nW4/wCW URH+5TVSwcjPMl8b5/5ZREjOfl/+tUF34nhvI9zxxxjH8Ner/wBnWhHzW8J/4BTf7K05uTaQ 5/3arnTDkPHYNTsnf95KAPern2zSQAWlXNeqNpGnMebSHj/Zpv8AYmlnrZQn/gNDmhqB4/Lf 2Yf5JlwemKt2vimG1hKEQuF7nqK9TOgaT2sYenZaQaHpIyPsMJ+q0c8SuU8h/wCEptJNRN00 cbY42dK1V8Yaay/NbRjPHWvRz4f0X/oGW+fpTT4d0QjnTYR+FUqkBch4rq2pWs87OjKqsuRz Wb9tt/8AnqpH1r3OXwh4dl5bSrdvqKi/4Qnw4Tn+yLU+22j2lM0seKpfW/TzB1q5FeRInmCR SF5/AV663gvw1njRrbPqM1G3gXw0VP8AxKoRn3NJTgS1dG54taO50PTrhMANHwfUZavN5Siz EbhXpLRQzafBYXEIe2gTZGoOMDnv+NUT4d0NnLPYZJ/2zWd1cErI4QMMdRUqOm0c/rXanw1o f8NkV9/MNA8OaKB/x7Mf+BmoaV9BmFuYjrSgnFMBpwzUXfUB4Zv71KM96YM+lO5wMUaAOA4p wz600Zpwp+gDhS4pASKXNTqAuAeDzTwPekGexxS84460gHAcdaUD3NIFNO5FNgL+tKKaBTgO KaQC08Ypu09aUD3pcoxwpwpgB9ad36012AcPoTThimUoAqQJARilGKZxTgB6mrvYB445pwPv TAB6mlwp70uYRJTgfeogB604AUnICQGlBqMhSPWnDgdaQDt3bFOHNRgj6UvHc1QEgNOBqPI9 TSjFAEgbmlzTAVpQwoAfuFIelJlTS/Lik0AKT608GmDAp2R600tAH5xRk+tNBHqaUmqS7gLn 3oDcUgK0fJSsA4E0uaaCtGRQ7isOoNNyPejIpRGOyKTNJxRkVQC0fjSZFGRSvqAuaPxpNy+9 JuGe9DAdmkoyKTj1oTAU/Wm496U4HemsAad0AoB9aKaCMd6U49aaYheaPxpMr1zmkOPWkO4t GKTgDrSceppWsMXFN/ClwOxNBXH8VV01ENP0pOvYn8aDxxuzSHH96kgAn8KUEY6A0n40DGPv CmrgcaN3enDNND+1KWqNRjsn1py5xwaj5zTgTT5bCJBmlzx1qMMRSkFxwcUkBKGz3zTh9arK hU96mGcUtUMkBNKD61Fk0o+tCuIsZxQG96hGR3pQDSQycN70u6oR0pw6cU2IlVqdkdTUIFOC 0ugyYMMUoI9KiC04DAoQiTd704EY61HQPpQBLu96UMajwKXAxTuBKG96UNUWPanA9KQEmcjr Tt59ajFOoAkD8UbiOhpuaXAoGLuNLu96bgUtO9wHB/el30wD/OKUBu1JJdRDw1O3D1qPb9aA pp3GDXATvTo7hXHBNUr3SbW/CmVpUkBB3KxAqS2sEtF2RyMy+pod+g1axc8zinB8DPaowvy4 o24oSZJKH96duqMDFOAyKFqA7fS7xTcUfnRZoB4ak3UzrS9O2R9aOgDt9BIPem/jRz7UJAP3 Yo38Uyl59qAHbuOKM470zNJTQx+73o3e9MpMEEHPIpNgSbhjrSbvQ1Hg0n40JgSlvejPqTUW TRzmm2BIDjvS7qiwaKLgSFwOtG8VCQD1H60bsdqaYWJd/FG4VEGpc0rt6AYvivW59E0d7i1A abIUBug4bk/lVDwl4ou9dt52ukCNFIyfLyDiukuba1vrV7a8hEsL/eU/j/iar2WlafpsIhsY RDGvRQacbW1E0XFJxknNLupOAMUZA70IAJpynjrTM0qsMdKpDOSApabmlzWbAcKUYpuaXNOz AeCKUUwZNPB4pWAcMCnUzdSgk96paAPH0pRTOaUGluBIKUVGDTwaGgH0YzTQc0uc1N9AJB9a cpzUW404H2p20AlHaj8aZuo3e9LQCXtS5GKhBHWnA0JASg8UoIx71Fml96eoEobNKGHSos0o b2ouBKGp2TUQYZ604Gi7AkyfWnBuKhzTg1ICUHNLmos8UoY00BMCfWlyaiBoBNTddQJufWkz x1pm44FG7ParQiQHJpS2BxTFNKPegY9enJxS80wH0NODcdKGhDwD606mA0uT61KAdnijPGc0 wEnvS4xTYx4NGabn3pKEwHZoyKbzSc0AO/DFGfc02ii1gF3fWjOaTBpKWq3AXPvRmmnpR2oW oDifem7qTtSc+lCQx270ozTce9JjFUIdmjNMxSc96GA8nNIT70zke9Jn2pagPz7UZpmT2oyc cHmq0YDmagMfSmZO70pc00rIB+QevFAYAcCo9x7UbjjpUgPLUq521CWpykY5Jz9apAcsKXJx SCnVNgAGnUgGKXBppAKGNODU0KaXFFkA/dShqZg04CpfkLUcDS5poU/U+tOAPfpR6jDJ7UoN FKM0rAAOO9LuNAXNLto06ALuPrShqTbQFb14pWuA/fShqZtOKUD2p2AlDZpRntUQp45p3AkC k9KUAj600dMZpQfQ0bgOwaADQCfWnDNDAUcjpTgKQGnA+tFgAAinAUgx2pw9jSsAu3ilA496 BS09QALml2n1oAFOUUtQECml24pcUo6VQCAH3pQppcUuT70tRCAZ9qcAKXPFAx6c0AOA9BRi gH2p2arUBuAO35UAcUuRSg5o9QEANJ+NPpMUAM2+9GOPfFPo47UmmMbjikxT8CjHvTQhmDik 6CnMQqk88VC0qudodVPoW5pcoDi3tQoB5FNxtGM09T7E0cowpCDTyD6CkxQCGYpOKk7U3A79 KdwGkY6nP0pvPrxT8AUnFFguM/CkPtT6Tii2g7ob9aPwpeMUUkIQj0FJg/SjIHXgVGl1aySN HHOrSL1UHkVdwHH8aOo64pSRTc5pbBcQg44NRhTjpTy1KOlNO4HM04HFMBFLwaTSYiQfWnDj vUY4pQaVkMkBz3xTh9ajBPengilIB/HanD8KjzSjjpUoRJSimA04NVXuMcMelKPpSBqUGmtt QFB9qcCB1pv40AiptcB4Ipw+lMBBFOpKNgHDFKAMcim8U4UNCFAB7UN8q5AyaM0oPTIGKNgO Sbxs0etx2DW3yPwH9+O3411kUnmxq/qM1nSeHdJlvFu/IZZl6EH6f4VqIiIAB6Yq2l0AUYxx ThQFBGeMU4KPQUgExS8ilC+9KFNACDOOtKCaXaaMVLQADTsmmfWnduKq/QB4P1pQe2aYBn2p cUIB+TkYJxTs981GKX6CjRASAk98U4E1FyOxpwz70W7APySOmcU4E1GAcdc04HtRqBID7Uoy aaDzS7ietO/YAAbPXNO/Cmg0tFgDkcClye9JnnrQTjHWi4B+NLn3ptFDYC5pc0zmkOaSYCuf lI74NeW+L/C+uXut+fbxSFMr5Uqvjyhznv8ASvUf1pAXzwxAqk7MCtaW5jUkkkknr9TVvPqK QDijmpbvsMM8UmfajvTSeKLsAJpuaQk+lNyT1p+oDtw7UZpm4+tJuoAeTSFuOlM3Ck3e9IB+ 7FNLcUwsT3pNxx161SQ0hZkaWJkBwSMCuet/D88WpRXTjYIy/IPJ3DFdBuA9KQv6GmmFhRkC jNM30m/PaldiH++aUMMdTUW6nK3y9BQpMZzoHSnbSe1NEg7CniUdxRfsSAU+lOCmlDgjpSh6 T0AQKacAfSjfx2zTg59qFruAAN6U4IaBJ9KXzR6il6DF2Gl2nHShXY9FJ+gqREuH4WJs+4qd EA3a3pShW9OKtR6dqDj5YsfjSSWd/CPngJHqKq47FcKfSnAEUm9wcFGHtirEVvdzAeXEQD60 R9REYBpdvtmrqaTeOPmdVqQaPMMZuFH/AAGhtBqZ4X2pwQelaH9lOOtwMf7tA0wdBdDP+7Sc 0gKGz8KcqVoDSHYY+05+i046HMBlbofiKSaDUzdh9KXY1W30u/T7qrJjuDUL297GpMlu6gfj V3CwwI3oKcFPrQgcnkEVOseSMgmiyBJkIDelOGfSrkdiZCPvAeoNSvpsKDLTN+VL3R2Zn5Pp S81Z+zRZwJWP4VItiG5UN+dJuwcrKYz6U7OKtzWBij3Akn0qqIpmPyRkj1qk0xWYc8cUCnra XTf8swPxqQWU/wDFSckgsRUZPtUxtJAPv/hioXSSP7w7danmTEO7UgbnpTMml3U00BJuNJuf HygUzdThIRVeYAWl/u0qmQ+lKJCe5pQ/vS5h2ALIBz+dGJD0NBb2zQGoTEOANKFpuT1zijNG 4DsfhRj/AGqbkkUnOMHmh6ASbfekx74pnPakO7ucUr+Q7C4PqaNvGCxOab83pSc000BJt9Wx SFfRjTPm/Ck5obQD8YHWmkcdcUnIHU0xix70tBikCmkVG2fU1GxPXJpoRNxjFIQOmRUBY460 mTVa9AJ+Kb+VQ5NGWou7AS4GaDg9ahyT3pckULzGSAADtik+XrUfNGGoAk+Wm03DUmD2NJCH Yp69KiOR3py5xRYo5vKjq2KcHUnAbP4V0MGkRRt88Ix6k5rRh060x0UH0Ws+aInFnJRxzyHE ULsfpVyLSb+X/l32e5NdUsUMWArkVMC54DZNS6gJHMp4evD1kUe1P/4R+5XrKtdA0bg5bao9 SahllsoRme7Rf93mnzyK5DIGhyoMsQfpU0VhGhAMQY1YbUbJQTbzNKfpiqh1m8L7fsSbP7wf mlzTY1G5ox2yqBtTb9KsCLAGTWIL+9lOEWQfgAKUjUJDmabjHTipUW3qNxsbg2gcuAKhfUrG AhZLvBPoCayo1aPIedpQf4cdKsRo7j91br9TVOPYnToWW1K2l4tiszf7ppN1243KBGPSkjsZ 3bkiMeq9atRWEELbnuGdvepvbcLlL/St37yfAPYCrCRSkAhmYdzjFXQY1IKQiT3PFOJkcghj H7CnfTQL32K/lIgHmSMv1pPPs0baZATjrirgjR/v4b60j2qAZMaKPUdqlAVkv7Z3KeYi++au CIgbhhh65rntR0jRZ2IexWZzyWDFcH8KrRacIl8uFHMf90yE1aV+oKx0EuqW0DbRIu/0BrPu 9TnmU7L2OFeu081VXREZhvhCA992anXRLZeiox9cVfIim0RJEZ/mWaMn1JxV+CExqB5ie/Oa jXTAOgQfWp49PUddpPqBQ7A5IUxSMNsc238Ki+wXBGWvSfbAq2tqVGB0FByg4JJ+lQmiLlM2 MneXeO46U5YRAoyz7SexJqcmTknIpnmP05+uKV7hdiKqq6kSNz0Bq0JfKIVlPTrise6vXgur RcgiS4RG45Ck4JHvW0jHJUuWxxyKqMLicrDPtKycJKAaiMwLhPtCknsKvxhdrMFiJXk7uPyq zGsMoAW0WRj2XrWiop7k8yMoQuwG1j+NBgI6uPxq9NZRnlC4I6qarNbgjYQcfrSdJrZBzJlK e0iC7hKN3oBVJtqfebj1rTbS4WOQXU+meKrvYIhKOBtbsT1qeSSGmmVlCsBtdCPrTtqgcyJj /eFctqHw60hpPNtpbq3znckUzYP6+1UR8O9NPW7uz7ec3+NVowsdyET/AJ6oP+BCnBVA/wBa h/4EK4b/AIVxpJPzz3ZH/XZv8aP+Fb6R2muiPQzN/jT5fMd0dyAg/wCWsf8A31RmIf8ALeP/ AL6rhT8NNIP3Um/7/t/jTf8AhWmkgfNFIfTM7f41fKg0O9zGf+W8Z+jUZi7yp/31XFQ/DnRk I+WcD/ZuHH9asN4B0dsBmuRjp+/f/GjlQOx1m+Afenj/AO+qPNth/wAvEf8A31XH/wDCtfDj cukzH3mf/Gj/AIVn4aA4gkz7zP8A41Nl3J0Ow861/wCfmL/vqjzrb/n4j/76rkP+FZeGj/y7 P+Ez/wCNKPhl4YH/AC6P/wB/n/xp2iB1pntQP+PqP/vqmG6swebyL865Y/DTwwD/AMebH/tq /wDjSj4beFh96wY/9tn/AMaXLHuPQ6c3dkP+XyH/AL6FN+22HT7bFn/ermx8NvCw6aecHuZX /wAacfhz4WOM6b09JWH9afJHuGh0JvtPH/L7EP8AgVNN9p+P+P2H/vqsIfDvwwAMacDgY/1j f40n/CuvCx+9p/5SN/jT5I9w0Nt73Tx1vIf++qrPqWmr/wAv8H/fdZ3/AArrwtjA03/yK3+N QyfDTwm//LpJH7iZ/wDGi0e47o0zqemHH+nwf99U06lpw/5focf71c1dfCHR5zm11GeD/ZK7 h+tYV38INTgBazvLa69A42f1NNQXRiuj0I6npmP+P+H86Qanph/5f4f++q8juPBPiCw3edoW 8DnfHICCPzzWTJHBbcXemzQtnHzqwFV7N9xXPcxqWmY/4/ocfWl/tLTP+f8Ah/76rw2P+ypA AFUHHfNWVs7B+ViU+4JpOk7DTPaP7T0vvqMH50f2npYP/IRg/OvGl06zJI+zj65NPXTbP/ng o/E1PsxXR7F/amlZ51GD6ZpRqelk4XUISfQGvIBplkekQ/DJrW03RbfdujhVWx1INUqfdg2j 0z7fp/a8jpy31lji6iNcamjtjhY+tWY9CudgxEuKFCwuY7J/E2hxuYy0zOP4fLb/AAoXWrSU bk0eZ0YfK3mAZqnqHii6jxGlvFI+DyVAx+lWdG8VW+owPHf6StndL/Erblb3yK4eeK1OjlS3 L8V8zcPpksI9d4anyz6fIm24EjDPTBFYPiLxbJosam3uYoQ/3TtDZ46VyNv8Yr61vHXUNOS6 tugZGCsDzz0+nFVBueyJdj0aK104giGynZT13OcfrViK2tlGI7MRn3rzpPiXNcTbLfTrq+jP 3ZYl2g/mPwqjqXjDx280klhby29ngbUlRGZfx601zXsFz1KYW8Y2uiEn+ECq62KynMVmFHXc xryzTvitr2n3Ih1O3iYFhudY9rqM8nB6/pXc2vjVri3WaYZkb5o/lPzKQCO3vSnJw3F8zfFh uCg3MeT/AAoakGipg71LAjqxrnF8cLAERPDxBOf3quNoP06/SrFt4lg1KUpd6kYum2LaUx+N SpcwWZ0S2cEBxt2ejYzml3qv3Y3I7tTrKG2ugHtLmOcjjCPmrsOm3cRIjXYpJJyc1WncVip5 ZI3Bzj0oEBUF3YBeuTVw2c6nczc+ppPIj5aUecfTpSaSGQKNpwqhqcWwMtCfwpk+oQQ4UyrG CeFrg9Q1HXLi+nlh1eS3jMreXGIlKhM8fpS530EvI7stIy/uVC/Xmq7xzT/6x3b6DFcOLzxC oRk1t2A6/ul5qd9Y1hlUG+kRiPvqo5qXN9h8rOu/s+Qc4fn1FKLKYdN34CuL/tPW2U/8TmYE HjKKc/pSnU9dVAV1eYH/AHFo9qw5WdsmnXB+YlyPSmvGyDAEjH0Arz67k1q6ZJZNfvY2X7uw KB+IxzTVv/E0Syf8VHK8pH7p/JQbeOhGOaaqSDkZ6GkMr84mHttp/lSg8eb+IrzqXV/EMFu0 z67cEqMthEwfwxxSpqmvSYEuszqvqgX8+lJzd9g5Wej4kx8wkVcdcUfvB6kV5sb7XSin/hIb oYHI2Jz+lRRz+IGlJfxJcFMfd8pP54oU32QuU9NzJjO05qJ5XwSQfwFed+ZrXlyH+37rcSMH YnA9OlQB9fJyfENywGePLT/CnGT6D5WdLr91i33INskbCRWxjBHINbeh+L9K1WIWWs2fl6ki 5JDECQdiMEfzrgYpNU3xx32oyTQSnY29F78VrQ6VYXcQhu5VEEagBifmJFawnLoTKL6noa6j oNoskSyXdv5mN3yFhx9c0kWo6Kp+XVxg9BLCf8BXNtd24jxLeIqKOCTVG68TeH9Nwtxfwhm6 ZQn+lbqT6mbgds0dtOd9vq9soP8AsYz+tSLZSSqDHcW8p9VfrXn1vr1jdQC4to7ieM8qUgYZ /AikbWJSN0OjMSR96SQL+lN14rRjUUeiHT9QUcRbvo4NNe0u2ULJauQPQA15o3iXVY/9XLBa nt+/3Y/SqD+J/EImZj4yEKk8Itp5mPbOamVTsgcWj06e0NuMyWkgTu2DxWRew2eDNHE5dcdM 1xUfjDxIjAP4jnukxyi2SJu/E5qRvGmpSzbF0nyhgYlEoJY+4rncru5Ub9TqLS9t5m8u5tpY GyAG6gmtIWcLdGyPrXnlz4l8RyDbFcQxJ3XYCfzrR0HTotcsZJ9Tmn+0JKyny5SoI47CtIOQ 2js/sNuP4iPxpfslsvWT9a57/hFNI7tdn63D/wCNKPCei9xdH/t4f/GtUSb/ANms+0o/OgQ6 eMbju/4FWD/wiGhf887n/wACH/xo/wCEQ0EgAwTn/tu/+NFkxnRBdMA+7g/79GzTez4/4FXO jwhoI/5dpvxnf/GhvB/h5vvWb/8Af5v8aHGNtw0Oi8vT2/5elH1NBisQOLlD/wACrnR4P8Oq OLBv+/rf40f8If4c4/0BuP8Apq3+NCSQtDeJtV6TRH/gVJ9ptF+80X/fVYI8KeHVAC6cB9Xb /GlHhjQP+gcn/fRqrR7j0N37Zpo6ugP+9Sfb9LHBaM/8DrEHhbw9nP8AZcWT7mlHhnQBgjTI 8jpyaOWPcNDYN9pX96Mf8Do/tDS8cmP/AL7rKHhzQl5GmxdO+aP+Ec0PHGlwgfjSaXcLI0jq WijktHx6vTDrWhrwZIv++6zxoGjLz/ZkVSLo2iKuDo9ueaegi3/b2goOJY/++6T/AISLRAf9 bFn2eq66Xoy/8we2+mKP7L0cj/kEW4/4DSaiMtjxToKDD3EY+r01/FHhKTAmu7Yn0bmqw0rQ WGG0q2Pp8tKuk6KoPladbLu+98nWi0e4rIoXtn8MtUy1wtiGYcurlW/MVz178P8AwDcp5lhr /wBkHUFZd38zXXjw/orjP9mWmPdBTxoukrwNOteP9ir5tNwPN3+HtjuP2PxjbSoDkK6gH891 Kng5IioOoxT4PVXGD+tekf2NpYIKada5/wB2pPsFihBGmxAjpgU1KwkkeVf8JDbaBcNBGYxI O7Jn+lXIfH083CPbNjtsGf5V6WY7ZgVbT4SPQrWbe+GvDWolvtmiRbiu0yR5VsfUUc0XuJxu ctb+ML2XgW9v167Rz+ldRaLeXdpHOLmABxnBUDH61jzfDzRVYPp97dWJBz3cfrQvhG7QbV11 WAJwTFj+tNOIrWInjfy2JAjbBI53dqwNY1q6trRooZY4ZWHMgGcDI5x68GtC+eaztJZLeYQs RgK43AEg1gafYJrM8yXjHYuCZMcE5PGPwrzKULu72OmUuhDp+iT6k4u5rl5skZldcYAPQD8K 6ix060slHlW0Qb+JsZzV8gxxhcqU9AKjAUn5s49quVVrSIopjItsBAgRUA7IMYqZ3eQfeJwM 46Gm8YBz09qV2OMFeByPxrFtvVsuyEnhF2oS4WORByAyf1rH1HUptDu0SO3823Y5257YOce/ StkPGyBhKS393FZXiMBtKF0EYNA+4n0XgZ/WiM23aQnsaNq1vfWCXdswaKQZ3f0pstr58LRu qsh7EVgeDJy0V1GgBtwQ6sOm4jkV0+VPHIOO1VUjyvQUWUDp0MMhkg3W8pIO6Fiv8qck2tW6 Otpr95CWJI3YcKfXBHtVxncR8MMDrxUflxygfeHqRUW7jbRJB4q8YW23fqVreqMAhrfYT+Na 8Pjp57fZdW0llOF/1ijcGbjgcdOtYO2K3AMjgKeMsetTeZCSIyxDkZwOaUm7CSJLjU7jU9y3 AVwDlGK4JqBA6Rjdn370m6TzpkiR9yNtUsuNxxUcU98spSS1dQuAZSwIk+g6j8aak2gsixG7 ZOAQMdac0jFTySB2qnLDe3M7FJjFCFJUHH3vT6Ups/tUCiWdoJ1GSEPysfSk3oNIlOGLZB+b rQkcgU7D8oJ+8aba280Mci3Jjdw42HdwVxUbQ3I1ETMw+yFdu1RyDg/nzSimUTxLJLESVyCP 8imeQMhjkY7k8LVeS0mdzcQXSRMBwpUkVOqF4WS5CHI6jOCOOorTSwWQl1Zy3FjPHEyO7IQq k4yfrSWiwtEwRPmVirj+6w6iq+oWMU+jyrlY3ZPmwCcsRjI9KTStOewWSKO/mkhYfclQEqfX d/j6U+ayJehf+zt5YwwC9vakEDLvkSdGVFy+B90VClmsaPH9qd/MTaGx/qzjqKdJbJLDHFLL IzRgASIdpJA74/lUKWgxYpd8zRhhub7mOpp58sAFnxzjn1p0sEVwiecT+7bjBxkUkNpZ20bR wo5UuXw8hbBP1pILkUscEyGJnOeG+mDUEWkaa0+68iNwoGdocj5uxq0LZIyyNcvKjjIXbtMZ x696i+yXIiby5oS2MElMEitU2uoPUV2ySLK1S2VT97G/f9c1fsNfvLC2lhmiguncjynaIL5f r9apPIsMbs0e1FI+Ynrx1xUdrcyXe4fZXhKnKluQ69iP8KG5PqJxJ7zUdSvHDfajCgBykXAb 2rPWELK0hZizdcsTViRlaQxlt0gUkqPSmBAOp2+2KWnUVkiFYIi5LRg856VZMMQC4GCT6dKR drNtDZNPc8AbeBTb7D0IRFHu4YZFOKOqZEgPpSggdMZoYtjAIx3od2IhxJg5QH3zXQeEEb7L eblIPncc+wrAcEpj19K3fCjOltdhIs/vvm59hW1K5MjpQvbcRS7cetRCWQ/eXH404O2Ogx9a 6TMk20oAApm446frShmNIBwPY0uAe1RtIY1LEcAc4GTSCR2AKgYIzzQBKBigYJpmZPajLH0p 7gKwAqPPPQYp5ztFRkgHkc0rNCuSj60ZXvTQ4IzijeB/AaNgQ47TTTj3pd/rSZBHGaTsxiUm BS8e9IQKEAmOOtJ0peexpv44qtAFJzR096QB+8mfwp2fUUaWAaf09KOfwp2+guPTFCsA0njo aapb+8aJJQBz0FJHPATguyfhRZASFpDzvx+FKHbHzOfypN5/h5H0o3N3xQgHCQj+LP4U4Ocd B+VRFif/AK1Kp4p8ojzHxC7NdxRMG4Tv3/zmtTSbVINNQHh5FBfA4PQ1zifvtQQPL8u8cu2c DI/+vW3c+I9Kt3WN5m3BVHyqSOmOoHtXFZqGhq2rmoCQxCnP40B2GFaPODx61zj+JXecGztg 8OQCxbB/DNWE8T2i+Wbggo5I3DjBHY1k4Ta2LUkb4jEibhIMEdKrvd28SSNK42RcOT/D25qp ZXVnqjfadO1ASKuQ0LIVK/XNaaOO6JuI2njqKhproCsRSFIjuYYQkDPZadJiLblPNVvTkfjU 0JK5WS3AX0JyDSxfxrC2FB+6RikmhuxQSNLGGHyLNYYmz5iR87Ce49ak33AGRAspCg5DbQRn 371YLlW4Y7h14pjvkkuAB603NhsMklMN1s2MUdgEYD19fSnMJpH2yIqCN8qVbIcYoyVLAMQD QjDbncMZIzQpX3C6JISyONwSQdcEcYqNLWKBXEMQUE5O09ec/wBaUvhOTu/rTyVJDKm04Gea NtRgSzqAScD1oU4+UyED1p5LFcsQ2aacYHPNNWZIilS4UjcAMZFNIwSCNvHQ9qU/LjaQT3FJ 8zNyv4VN7gIBgcHA+uaGJ2DDc+tO2Y5xxTljUg5A57UNxQFcuAOcgbc8U1Mc5HFKob5SDkgE HHSggp16UKVxkN5j+zp/mKqo5x1xUtuWEYAbJ9SajuQj2c0T/KHQrn8KdEUKbkOTgdRT5u4E /wDCM0xVQHLZU04bsZOMegqMthJGA2SYGAe9Sxi4AYEHPPeneY7cBM5PJBpqPuxUvzIMDoTn rQovuLUVQFGT+opSuUYrIACBximtKQACRzSHDLjFVZiJY2KldxVto4GM0kuybCNGxUNvXYxG GpgHz5UYFB3H7rYA60XeyHZEMqQXEDyNCYrp4jD56nkDsQP1qrDprlUC37MqKoKsvzEjqc+9 aiNtjC7QVweCKqSRjczBcY6YNNO24miCKzeGQBSGAPY84qEagPKVpIHAMrx/MMEEf0q0knPI Ix606RvNTa7Bw3YinuLUrvMgVfnBLdABmofOVpCvNWhHsmV0wMA5Xsc1XeyDSEwyMnUtu+bk 1S7AKzgjBbFb3hXaYLra+795k8e1c49vKWxFtZcrksccd63/AApYyWsV67MD5024KD04remi ZbHR5z0OKT5weo/KjmkwT3roMx++T0B/GlEj90/WmDP96jLcYP14odmBKJceop3mqe3PfNQ5 bH3qM+uKSdgJg4NKXwODUO4UocGmmFiXdgc1Exj/ALu4/XpS5XHvTSR7GqEODKDwnSnB89sC mggdv1pcg9ql6gh28Dt+dIWFIBkjnApGUHjd+VLcYuR1pNw9DTSqjvSEjHJzTQDt/tik346U 3t1o/HNIBd4HajJI4GKbkjpRzjIfn0p2dgFyR3o3NTdzn0NLvdRwFoXmA18kHFQxQANuI6VM ZHHVc/jSq5P19KaCw8H3P404KSOOTUYc9SaPMyOKLASEMOuMU5du37wqHzMDkD60ocEdKEgP HLWze/nSDcSrKScjHHHb8a24vCNgPkkG62ZFwgJBDdznNZ2lSuusW8ksgkdmw7AYByVrsFfg rvxkAhfWuapOUYqxcV3Mz/hD9IdVC25ZB2EhH9ar3HhHQ40zFaEMDyTIxx+vNbAHXOQfrVfU Lo29odzKGbgLnk9KyVWb2ZTSRyegW5TXbV0I3BSGA/iX5c13BDxjBQHcBkVzvhiwTLSsm/Cb Ez26d/wroFMyFlKlyp7/AMqurO6swigJdcMMbenvT2CySKZDx6ntVeW8WO7MEkflg/6uUt8s nbA980ouS0zRKuSnUjkCuaxZYIdVChjgUnyFSNm0kdRVVpbny1AQySggMF7KTyfwp06Xnly/ Z1EkiqrJvO0P0yB6Um+iDcsCJT0cc96Z5YQkOcc1BFOZpZIwmXQgFSMdRnrRK0iqyxwF5B0V W6+1DTEkTlI+gbKkZ4pAYiAokCsBwDwTVPyFlJInaHcmBsPRuxx/SpQqzL++fLxsNu4frUtu 4Ev2yRPkMat6Amle52kZDAeuOB+NSMrv87kMfXFIpdOFfgnoKpILkIvongEyNJznAMZHSm+f PcWhkjiMjt/D90r+dTb3PPmEfSnSRjzFZZS+RyRRZJXGrlZZ7xmRXzJI2cYXarEevpTZbpUR PtStCzfeUAsB+Iq3KZBGpDtgH1pY5JQeHIBHNQoJ62AoORA7mRpETbwFQtmmQT3B+0KTG8CI CkgzkNn7pFaMbOvyoxyegoyxAYSAtnniqirDK8k4NtI3yBo8BlZDncQStUtP1C7nsGFxDIl0 h6GPgjPatUyMpdg3TqT3pyTSk7snAHXNU03oTqZlvfNPbS+aPLIBUGIFiGxxTQ+rERssEixI ArCRQfNwPvD+7mtTzHkmyXATB5C4OcUwK0jF95AHHWlygU86hc+YLCz3sASqS/ISfc1NHFIE EhVlfYC8fbOOmfrVohgRlmOO+aYHcNxIcdxTbaVh3I3M5T9xGpYDkHtUX28Db5q7BjB3dM/W rAzwCMknpSOkMkfkzRExgfdA45pXYXHsA3IOPxpAAOr4qo9tL5yy2fliQDb87dF78VIkd+6t koZR0TGN30q1e1wLCyhgBuzt4FPwsiOMc8d+apQyXEqlGtGW4Cltnc/Q1FJdeWcTI5wMlVBy v+NS9dgaLEyhSSGJPfIqFZOcEj8ac9zEoRHlMTuNyLjJIqu258EOCDnBIq436k3J+TnB/Kmn KREnA9yarksNoJBJ79KJCwjHB/OrtfYBSwA465rd8MNiC53dfMzn8K547tucc1u+FiRBeNjk y/h0rWmn1IZ0YejziB0x+FMDd8UobP0rYgcZie1J5pHbIoPtSbsUWAcJfQUvnEdaiwCc8n8a djI7U1oC8x/m5PXNKZR0z+lREe9JtBHJpLzAk8zjFG/2qMA+uRRgjnJrTQY8OQetPV+lQZzT gTipsxEwJNGeOajXHc04nNCAXK/Sgnj2ph6dKaw460IB+/HQ80FyR1qIN8wOTmj5yeW/SiwD iQe+Kb8oPJP1pGO3q6/lTAx7Nn6UwJM46MTQTx3H41FvI7UobNICTf8A5zShvUZqHcp7c0AE +1FwJwxzkCnbj1GKgCtxnp7U8BscHpTCw4saQE4pp3Ad8570qrJt7U0JHluq20tperIYyYm+ ZGXpkEfrxXQabdLqNghDBp0UBlB5DACpb37OYRFdSBYHHGRmsGbw/bhmutGd5G/hQMynrzk5 rhjUjUjys2tZnUSEwL5jSKq5A2txmuSv7WbVNble1tzcyK/Kq/3V+b7uauCw1u6jEV1OLaDc N23Dbl7jnofetex0+y0eMJaZ55L85JPrWUY+z1bG9R9nYCGzSJkdI9pDENhlPPWrOCv3ZS4w ByP1qGUCV/NBcnvQ80uVKRjGMEA1EnzO41oStHbYOLeMOXDk9cMO496HQNhzgMecrxn61FK7 sAPMCH025pu55I9igl1OCR0oSb2Hcn3SKAcdBgEHpUfmjZy2Gbop71G0TYVjIS2MEdBTS7tE 0aqMnByOq03ZAiRpN4wpIOeuKaQu8D9aicSnG35SOtNUszA7unbHWkkwLcZXbyRxSmUFGAAK kdPWoUMu0ERDIGSAaeJMseFDYBFNxXULEyh85xgnpQ8sqcYBx2NQvI68vJ8p6Cm8dMnPuaIw YNEomBALRYz6GnCWOQna23HqMVCiuAN4wTzin4A68g+9S4ruO5IzZGwMCR170qE9CKiKKBmO MDPUiiISBuX49DT9GLUlyA2DgComAQnb0PPFKPMLkMgI9jTgFGNykE9ielNx0Ajy5hYe3Wmo 5Cnav1GamayeThD5efQg5pqwhG2nkjqKPmII2MidxuBBpwJGFB/OlPCj939TS7CV54FL3WAx 2Kg5xj61U+0Hzdvln61NKu0/6xRk8YpUhITJGfegBIiByCSalDEKRknPrUMK/KNx5qRl2qTy RTaVrjQhVGGG60pUGaPJ6eh9qRv6ijC9+tOL7gNuml8qMCRj7g8ioVubwthHwBjkqMmp5FLq O2BTI0ZV+9nimrb2E0J5KXBLSsyseN45xSNFFGu1WM7KT+8Py/kKmBZTnANV3bLsduMmhWBF UwSiIlJCFC5XjcxNRStOWH7nlFBZnOAauEgsDyDUixvIeCfxqouwjOkuY4Yt8xVVYjaVJPXp XS+GEzaTMASrPuz+FUo08odVz3GBWpoPJuiWyN4wB2rWEtdCZLQ1wuO1GBjpz6VIp44FOU+o xXUtTMi2c96PI9M1NjikBosBCLZuu8GnCBh71KCCOhoz25oAiMRHam+U9WNwHWgSgjg+1MCI RnHQ03yyPXFThj60hJ55pagQlDRtxUoxRtFNARbaOgqQqaTFAhnA6U3jPIzUwHamEYpLQZGQ p4xSbQO2PqaflvQUhLEjK4p3AjMK9SfzpBEo6GpTnoTj603GOtGgDfKAFHlKaXPfJAoB4zRZ AK8SL918j1Ipqqc9aGxj3+lOhBKkk55ppCY5Y6f5fenqoHWnhR03GnYVyHy8Uqq2OpqU0o2Y 6mgEziraBrQ+V5zNH1Af5iPxqZlUSBt4bPU4xVNryD5csAfWnLcI42pICcV5XK+x06FjeTkA Zx0ppnRgqMg3elUJtSt4wWBLkHBC06K/EsRMUJc9QAeaahJsVzQeaRkG7YmByKjDqnDMTnpV LfqCIrrZLICRuBcfKKvI2UV2jQoeGXOCR/SlOmx3Q+SPyY3kfAEeNwPWoIrq2nhO1w0T/K+x vun0PoajRILAKIiZIweC7liOfU81YS7hjuRIiwrubMhC8N9aUIsLoihlDwI2FEjcbd2f1qw8 EkilFAL4yFJxn6Gonu4ixEaRoo6KowPwqPz41bJbjA+UdjVOIcyQ2e2dVVlyMfeU9qy5ftNu pmt4xckudqbwp69Oa2ReQZAZ8Z7ms9/IW4MjKXw2QAcZzSjo7MXMieaG5nEbW9xHG3BORyOe VPY5FW3hmmQC1kiglXG4uNwI4z/WsqXVLVVVvKdS5ACDnvirnmmPbKzfKByPwq+ST2Qc6Jrf SpLeK4jF1GZJmLK7KWCZGMYp0Nm9rH5X2r7RIMgMRjPpUb3yxNgrznHynpUsV2Dglc5qXBro HMmVkjvmt0aQqspUF8/wn096Le2niE3nTtLzvXaoAA9Pwq15oL8ZAIxTXZDJwSMDk4qGoroV dWFeC6S6MZUBB0O77wOKdDLEY96yEckFGUg9cZpyK6yr5Jdm3DGT1pZJXEjbxh885HeosNFO 41WG33IyyCVYzIE2E7h04pkerQyysiFgFiWRgYyMZ+orQS5dMYkAb3Gaka6kdQCQTjn5RTas tSXcx4tdt5o2kRJDHHIEkYKfkz0JHUVNaXskpmUxoZkb5IkOdynocn25rTWeUt5ihQcckACl +0XDMpO3APZRQtgVylJqEKwiRFebKkhYxycU2K4nkBeWLbGBnd6D3q2shjzsCj/ZxioXlZiX AywxkUXURu5QkvoDeRxFiTIQqBV6segqe3ug11JaSgwygblR+rVYjMjEsoU4P5VMZJ5cGRVY jo2Ofzp8ySJRmPJcQ3BjuLdo1xlTu9e9WikiqrDBUj171Y8yXYQ6qykbSGGetRm0jSNkiUwu RweSAfXFJTi+pViIEsCcDr2OaUMhbHPHXHanNbsk5aORFyfnCr196qTaVeT3Mc51dECElYRD 1Pufoaq6GW2KsMZ/OlA3jCtnFRyQ3U0oiMbxRY3LOjA5b0x70rQToxilKmQgYVRjIqFKzEvM co+cqSOO1KY0C4PPOc1TF5Gq7ZAYX7BuppHvUKdelXzMehP5cYOchcDoKd5kRAxk+tU4bjzF LpyOnPFPVwW7D2zVNNi5S2XV22ggH0rQ8O433uOnmDmsMzIGyxx7jvWx4Ud5Y71zG6p5oVGI 4bjqK0op3IlsdEo56mnHHbNA547etHAFd9tDEAeMc0uKTPvQWoGLijBpMgrkgmk37f4CRUvQ B2D25o69QBTQ+f4cfjTs002AvFA4pOe1Jk5przEPNJwfekx70oX3NFhhg9qTFO6Cm5BoEIen SmE0pb3phYU7DDNMOB0NG8dqYSBSVgJMjGMfjSb+MVHkUZ4pASbv/wBVN3AdFxTMgCjdTuAu QTzwPapkAyMEkVBuAqRCOpxQmxFlalLY6c1AnPSpsHFVqAbie2KAHx90mkOAOTSCQgd6QXPF H16WQHGhsNwwf33UflUf9rzcY0eQY6fva2ygI+6KTyQewrNcqNHJmVHrt9AwaPSiG7EyAikX W7/ezS6PvZiTlJcVq+Xxjt6Uqx7fujFCaBSl1MlNbu42ZotFZS33szYzQdcv+o0zbx/z2Fa5 UEfMB9aBbqw6Ci8RczMVtavwedM5/wCuopy6/fp00zn/AK6VseUF6AfiKBb8570rx6IfMzHO uajJjOmKp9fNoGt6j0/s1T/21rYNuPSmiADoKLxe6FdmOdX1E9NPUfWQUi6xqqEE2aHn++K2 jB7UwwqDyKFy9guzITVr+I7v7PQ57eZTxrmo8n+zAfYy9K1FXHRRT/KBAyBVc0UO5kvreoyg g6Yoz1/eCpoPEmsQqqDS0ZQMAbxWi0YPapEUgdqTnEFJmYfE+tM4ZdLjUY6FxSHxNr7D/jwi /wC+hWtjnoKNo9qi0HuiuZmR/wAJJ4ixj7FDjtkjik/4SHxL/wA+0H4//rraAHTtSbQKlxpf yhzSMX+3/Emc/ZbfP0/+vTx4h8Tr923th9QD/WtcDHQ04AAetDdPblBNmM2v+KCObe2xnsP/ AK9M/tvxWBhRAB/ujitzigcdqlez/lC5iDWPFvUtByMYKCnf2x4tYctb8DqUFbOc8jikNDUP 5QdzFOo+LG/5eIUPqEH+FH27xYwCm6jC5zjYOf0rZDbTS5OMZpyjTtrFCMdbrxbgAXsYHsi/ 4UfaPFrkFtRQHH9xf8K2OgxRuyM1KVN/ZX3BYyhL4rIIGpqPXES/4Uwr4jP39WOe37pa2M5N MLNkADNUlB/ZQmjH8nXz11Q/hGKBaa4Of7UbPqIxWyeOlHUUWh2QrGKttrCuWbVDuJzuaIGm HT79nLtqL7j1IQDP4VuBRRtGOBTvFdAsYB0m7kwW1CcgDAGcU7+x7mQ831wTjs1bgXHangVX Ouw7GHHojg83VwfUF+teieFruR9LFrISfIYquR24rm0A3dK6DQ3A3gHvVRd9iXGx0YJNPAb0 /Wq6uAOWxUqucVohEuPWk2kU1ZG/Kl35GKSiICM9KTaRSbx7U0tSAfgilzUQcf3ufSnK3rTC 6JAPSk56EUhcKOeBUZlB6NQxk4JXqKdnNQIxPOeKlzxTuAufxpD9abv56/hTGYgU0IGqNmHr iml89jUTSf7LUDY4n0pm7sc1EZx2BP4UhdiM7Gx9KAJ8+/FIW96gDMeNrflQTJx+7Yj6Ur2F ckZ/em+Znuart52eIXNAS4xkQSUlZhcsqTnrU8b46iqaW963SBsVbgs79iP9Hx/wIVSsIuxN uGMnHpipScClisrkD5kA/wCBCntZzY6oP+BCmh7lZmxQpyvDD8qe1pN/fiH1cUi2Uu3/AF0X /fQoGkeW+fAf+WyUfarYcGdRxXIiCLA+Xt609QEO5AFI6GslRt1KudWLm2bO2dT9KPPtsgee u49BXLSsJpDIyIHJySo600onGV70RpNdRHVia2IB89MH3pftVqOPtMefSuPEMQ6IKeQrLtKL 0x0p+y6gdeJoD/y3j/Ol82L/AJ7R/nXGGGLn5Byab9niz9wfmaXsUUmjtvNjP/LVPzoDxHpK n51xPkxD+HoOuTQIkByMj8aHS8wudqXj7Sp+dM+UnPmR/wDfVcd5UZJJT9TTfIiznb+tP2TQ rnZ/Jx+8TH1p2+EcGZM/WuKMEZ52np60nkR4+729aHSvuwudx5kI6yr+dAkixkSrXECCLP3e nuaPKj3g7eppexQ7o7bzIv8Anqn50eZGesi/nXEtBGf4efqaPJjxnb26ZNT7DzJudv5kX/PV PzpRJH3mT864fyIsn5e4xyakeGPy0UOW5+76VXsOzK5jtC8X/PdPzoLxheZl9sVwwt4mH3cf iactomCFkKAjnPIo9j5hzI7XfH/z3WlDJ/z2X864owRByFclR3BNAhT++4/4FQ6PmK52wkhP HnrmgFP+eyH8a4kwRnAyTgetKLOIg4ODj1NNUB8x2Z8rOTOn50mYsg+enHvXJNbRMMZKrnPU nmmC1tsgGQn35pukK6OxLQn/AJbrS5hA/wBcn51xbQwhflB47gmo2hjbqvah0kCZ2+6IciVP zpPMhBz56fnXEi3iB+7+tL5MR/g/Wp9igudsXg2/6+P1HzUnmwDrcR/nXE/Z4uPk5+tHkRf3 BmmqSC6O2M9soz9pj/OmG7tP+fqL8640QRf88xR5MQ/gWj2KHc7M3VoAP9Kj/Omi/sBwbpOK 44QRddgzTgiYICjpihUkhXOxGp6UhzJeL+FaWn+LPDlnkS3ZIzyNp/wrz1Qq/wAK/lQyo+Ny LgH0p+z8xHqi/ELwav3rqX/v0x/pUn/Cx/BgHE9wf+2T/wCFeTeXFj/Vr+Qo8uPsi/lR7Nvq Kx6x/wALL8HDkNcZ9fLbn9Ka3xQ8JDGIrhz9GGP0ryrYg/gXqO1OVVH8C/lR7J92Kx6c/wAU vCwOVsrmQ/iKhHxV8OgcaRdfi1ebjGAAoA+lLgZzgZx6UvYv+ZhY9EPxY0JSduh3BP8Av9aQ fF7Sl+7oFwf+BivPVAHYDntS5OetV7N9wsd+3xesj/qvD0rH3kqI/FwAZ/4Rsf8Af3/61cNy cZpRTVN9x6nat8Xbjb8nh5QfeX/61N/4W7qOP+QCnt+8/wDrVxhPNDDgH3pqDGmdj/wtrViD jQouR3k/+tTD8U9bI40eJT2/eD/CuSB4oPTHtTSHzM6g/E7xAc/8S6Af8CH+FRH4jeJGORb2 6+3Fc6aMYx9aLIXMb58f+JCeIrYD0wKjbx74nOcfZ1/4CKxAOOaUDj3otcOY1v8AhNvFDZzP CMeiCmf8Jd4lkfm9VR3wg5rLPAzSA5/OjlQXNJ/FXiXI8rVNq/8AXMVE/ifxSR/yF2xjsi/4 VS7Cjt0p+zQi02u+JSf+Qy/X+4P8KiOr6+/3tZm/IVCf60mKjlXYLIGutWf7+sXXTnDkf1qM i5ZSZNQunb3lNScikycc+1Plj2CyIDBK3D3k7Z9XNKtkNv8Ar5Dyf4jU3P61Iikp+dHKgIga D0OKaOBjmlHT61QB/jQTSc0ZzQgDOBRn19KTB+nFBx09qAFNJ6UZpKLDFxmkY8UA0mcGkIXJ FG6kpAc/nTGOzxScYpDnH4GjqKSAUYBPNGeRS9qQUwA896DnafpSeh9qXnHHXFIBMnJ+tLnk fU0lL/jTAAeB9KKByAfaikA87expvekx/OgenvTEL2peClN7UKePwFAx+4gYz3ozlgc8c000 dKBB2/CgUmeKByOvGKBi0D7wo4FHWkAfWjvSH7uO+KOelAC0elH+NL1FMBP4ce1HrSY7U7oK YgzSE9KU0elCQCqPlpOgI9KcPuUgHFGwC8A5pBjtSj39aTOCPQmjWwB2oyf0pewzQeKQD1HF N70ueB+FIKL9wHYwue9Cfcz7UmcnB9KAcDA9qakuwDyMUhOAKTdSZJx7GndAPT7goxnr6Uig haceRU3AUkGkzSDikA/nTVuoWHA0Fhk00ZzQeCaVxjye1IKTtx60Bip6U2xCtxzTe1GdwIpe lIYEfzpM5NKelIBQIQ5ppHHtT/am8hSMdqLjFHP51LH9wfjUQ4z9alj+4PxpiKw9falPTFHS jgCpuAh/rSgcUh4GfejPFMYgORScdaBkgH2pccUAB96TqfxpeppM/wA6OgCZ4zjPFIRwT7U4 DH0pCeOeBii4AcfrR0x70oHWjrTATtmkHI/CgA4o/DtS0AP8aUCk/DvS5pAJxml7GikGefpT SAKUc8+9HrQOlAAOOPY0h6UvakNAC46fWl7ik5ozyKAF7Ugxj8BR7e1HPp2pAB/rS5/Wk7fj RQAdVoHSjOBR/DTAU0dxxQKKAE7/AIUpwV68459qOgzSHocelCAXkE5oHUUN1/Gj0o0AKQkk H6cUZx+VB+6fpTAXP86X0pP8aB0pCF7UZxRmigYLyT9aU/1opBnIoEOB4z7UYzRilGRQAh9q Uc0oXvQoHB9+lIBKMfLkelHTjNLxigAA45pVGBxSgZH40E4FMBAScCgnAI9qF+7+FB5H4UAK B1NKDSdBSjqPrTWwC8AfhSdWJ7cUjHAyakWIlSwYD2osAzGKO1BPGPekBwvvmhpJANBOac2c UgU7fwpc0kA4nPQUn09aaTilU9/ekwFAxyemKYx5/CnZ4FIcYp6ABOVp0f3B+NM5qSL/AFY+ p/nQMgPUUE8UdqQc0rCF7HikBFFApsYg7Y6UHhfwpQeKQ5oAKKKKQhPpR9aAOcn0oz/+qmMU Ugoo6UgEzjH0pxHy0lBPagAxSA8/jR/iKO+aYB2pR0pop3agBDz+BpRik9frijoKBCj1o60n agnjPtSGLR0xSsrLgsOD0OaTPNMBAO9HvQCeKTkDHsKLAOz/ADpab7+9KOf1p2EGBijqKT0+ hpegpMYZweKP8aMc5oxz+NABn60Dgmij3psAxR2pTknigA1IDR049KXG5CPUU4L8v4UoFNCG 0oX+dKMZpemCPWmAmOaMflSqRSEcD0xRYAP9acoyc03cSPxoViPzo0AceOlBPy5pC2aAcCkA 8HjFJ0HFICeaQHNFwFHI96X+Gm8jmnAcU9AHZwKZ1NBOWpw4x9aLAL2HFNIAOaUkjFIen4UA OB4pMcgn1NHenIu+RU9TSuAhPFHIHNIRhsD0peMY9qLAL2pMdzSDqfrQeBQkA6kb7tJnK8UA 8c0AGDjpRnkU7PvTBnr70hgPX2zSE4BPtTqbtzmqSQheuaki/wBWPqf51F3qaL/Vjj1/nSuM rnoMdKBwKQHJFDd/pQmIDzQBgY9zQccjtmkPQfWkAYzzR2o9+OlI3Cn6UAKaM9KCf50g7fWn cYZpOP0pcjApD90/TrT0EHc0Y6fjQOp+tKoyygetIBB0GKRuAT7U4DaMUhOaGAYo60tIP60h iduKXOAfpQe1HamID1P1o9KPWjoKAADpS44pufl69qcDxihDA84+tHfmgj2NJ6fWmAfT0oA/ kKB2HtSjp+FIQAUCkz/OlB/nQAnGPwoyMc9MUvYfSkHAx14o0GLzk0UZpRgnFCVwEFIDkn0w KUj09KQDr9KbVgHE0mTx9aO5pfT60gAHgHNA9T1xSE/L+FKaLCDvR/jR/jQAc/jQMBwB64p3 b3po5/Klz/KqTEKoxRjmgnA/Gl6AVNgAjvSEfyp2cxgY5x19aQjt7UXAAOM0qjHX1pBTh0po BCP5GnZAFNzkZo7fhSAXvmnACmrzS80wDrilwKTqKUA4yelK4DolVxLuOCpGPfimoAXUMcAH kigHrg49aMH9aAEbAfj0pQOPwpoU4p+MLigBvc+xpQOlKAKQGnZAGQMD2oxkUp9e9J1oAQZo H9TSgUn8QFGoBjmk+npSngUnbp2oAQjmpY2+QfjUZqWJQYx9T/OloBWGQKTPGaXPFJ0FOzGL /jSEdKCevbmkJyRj1oAB6n0oY84o6D8DSHk/hSABjpS+lGMUDk/jQgEOP0o9vYUAcD6Udvwo AD/WlXgg+9N7/iKUA/rSAV/vD3FIeKceY19RnmmHofpTEKf6ilAzSHA/Ogf1pAHpSE5BHtS5 6fSjjFMBO/40vYfWjrR+HejQBO4xSnpx1oHIpaAEDMCQOnAo7/jR6/XFHGaBhyCPpS9e1IOg oByPfFABjGaX3ox60f40XEJnGB7GjHFLgE49qGH9KAAmlHXNNHU/hThwRn1oAD160g4zSnrS ZwKBhjn8aOv4Gjn9aOeKAHDpTT04paTIxQIXrS9KQHFGcmgBR9c0YyPwpMU5TgUMBDz7c0vU DPrSZyTxjml54oQAvQUp7UnQfhR1HNACgZNOPoKRO9J3FMAGadzj8KaOTTtw6d6ADoKXsKSn dhSAQHC/hSk/L+GKQetB5XFPQAUZB+tOoHA4pBzzSQADS0g4/KjtkUbAKTgUnP60uM0DNPfY BM9KQ807FITgUtgAnApO4NKcjH1oPancBDSA8c9MCl6imMMqQPSjcB+M5p0T4jx7n+dNzj86 uw2uYlOB+dKwGZ2/Cgk449KOmD7UUXsMDwPypAABS0n+NAAORRjmk7D6Uv8AhQAuP50nQ0uc Cm9TSABQQSp9xQABSsw2nPQCgBBj8zRSdz7GjPI+tPQQ7+Ae9NHApx4UCmAfMR7CgY84IpMc 5pDx+dKOcUAKAMUhxtP0ox70n+FAC9vxoHSk6/gaXsPrQADIWkPT8KB938KX9KaABR6fWjHv 3oHakAo6Ck6Z+lLxn8KQcj8KLAH+NL6UYpMYxQADG0fSg5NL2o7ZoAM/zozyPrRijHNABzjr 2oHFGPWihoA/xoHb60Y5P1pQKYhSuAD6jNNxx+FBwOPY0HpTAOtL3GKTp+dKP61OwBzQDx+V KBkZpp4z64FGoDh/WloXk/jRjn8aAADIGfSgdfwpR92kP3fwpgLSckilGKUelADkXB59KRjz +FC+ppemTilqAuOfxoPNBORx603JppAKBRg9/QUZIGe+KOuPXFFgF9cdyOtPAAFIRjpSDrSu AvbNIMYpee3pSZJOPanvuAp46UA0AetIRgcUJsYp6UhHHNHOKRzlaL3EB5/OjtmgHnFL0pIB oHy/hSDpk0o6UgoAGHNTxM/lj5j3qA1NEf3Y/Gh2GUgTj8KVuhoooYBSiiiiIDW4PHoaVu30 ooprcQUhJ/WiigYmf8/jQeg/CiipAUUADNFFMBR90U3tRRQIU/1oWiimgDvSE/KaKKTAU8fn QKKKBh3H0oPGfoKKKQCnpR6UUUxB3FIen4UUU2AvelFFFShidhSZ4/AUUVTAdRRRSEHrSDk0 UUwAd/rSiiigBuePwpR1/CiihABPP40vcUUUmMVRzSEc5ooprYQoPzUp7UUUhgPuindqKKaA QdaXvRRSEL2pPX6UUVSAcOn40UUUIBw6fhQfvL/uiiikMU0i9PxooqeohR0pP4c+1FFUAHpS 54oopgJ2pGGFGKKKh7gHajtRRVxAROv4f1pB940UU2AH7wp8X+rH4/zooqAR/9k/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGFAh0DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwCvLPkgBhtx1zVO4vY41IDj865sTzbRmVz8 o71G0jE8sT+NYKTCzNK5kjkUnjOazQ+04qIsCfeoyM4PejVhylsycUgljZSrHB9TUCnPBpWX jpmhpgMLhHIUgjPalMqsOUquw+b8aevSi3UauQyqFyRwMUxZ2QnB4qzKgZD7iqLKQTitIO42 WvtW786v6ZcsJVAOQSc5rD5BrU0jJuU6455rRxIPQbNy0QJGDisrWmySDWrZgiFc+lYusn94 RXLLc1pK8jCJyxpR1owc0oFQlfc9qna1jb0ojy81qqw9KytLGIQD6VqD2rhrWvY4q/xEwIIp U4PU1Gv0p469a5tmYJkpwRTSOKaG5604sMcVakFxqgE1InzPtqOPDMcnFTqQvSmr3EWkTYc0 6Z/3ZIqJZQRyfwpUlXfhuhrRNdQMW8gkuZx2HT+deheHoDbWMSg/w/1Nc61vC0imPjnmus08 FYVHtXRSd9DKZpg0/OahUnvUgNdiSMB9FNBo60JCFzk15R471nWLa7mjsL57cEjkHpwuf616 uDjmvHPHvGpTf8B/ktEdxo4ltb8VM3PiC5/76qRda8UKAV1+5z/vVTGd3fg1L2rpsBsWfjbx lZgH+0IZ1XnEu7n8q930i9kvLGKaUYZ1z/OvnMfcI9q+hPDpzpdvk5IT+pqKlhFXxpIV0NlO eW/xrxK41AwXzkhueuBmvavHDD+zIxnq2f0NeNXNujTkhee9TTVx3GR+JLnTiLqwCMwXO1+A a9c8JeJU13TY7gAK/R1H8JyQR+leRC0iP3k/QVoaPqVzoE0ktjgiQ5aNulXKnFrQGz3Qtx1N Ruf3bfQ/yrzWH4oXMeEudMcnON0YyP51P/wtCFwVOn3AyP7n/wBesOSS6C5hdUuDH9qGT1P8 zXMQyojjzMAVPe61HftIUR1D9mHvWa7BgQa1p8y3Bu5o3Gqs0SwK4IU8c+1ZU105Jy5P41Eb cFsq2OaingMabt+eDxnpW3mTcngmy2a0YbiNXBkTcvcCsGCQg49qtiU0xHUJf6Lj5rVwfpTv tuik/wDHvJj6CuV85uxNL5retOwzqDc6Gf8AllIPwFIZdFYcCT8hXMea3rR5p9eaE2K502dF J5aUD6Cl8vQiP9fIPyrmPOIoExI60XY/kdOLXQX/AOX9lqveRWFvEfslx5ue9c/5nPQU4SnB zT5mxKRdQGVyqnmpvsM/UYzWUty8bZU4NSf2lcdpP1qOXW4bksgZHKt1rQsrK0mh3tfBGPVG PIrCN20jnd19acJcg54p6hbsa2q2VvAsSpdrJvbGQ3SrkOijYP8AiYRHj+90rlWbzZgf4Qel TrIyjh3H0ahX7jbZ0o0pc4OoR/8AfVQ6jpCRWLyfbYpCP4Q1YJlc9ZX/ADqMscH52OfU0agj MuF2yfjUDDgcVPOPmz71AegqbXLWpvLp106DEZBwO1K+kXmOUJ+ld8Cm0HYvT0oJ3DggH6Vg 5LoUefjSbhj0bNO/si4HbH4V2rQHdk4pfs4b0pqSHc4n+x7kg8fjTxo92qFgcn0xXZra4PPS nmBWQqR170OYjzie3eKQiRcEGodyggGu2vfCq3kxkM7LznrVb/hB4z1u+R3zSVmUpWOT8xB1 PFASFm5I7V1yeBbVQM3JOBgZNSDwLZZ5uW59DVKy6lcxyjaZDLEDHJ0OcZ/z61Y0u1Mdwowf xrpx4Hsh0u5lPqrYq1beF7e2IYTyOR/eOTVOStuQS24ZYQPasW+UT3RRuOgrq47aNU284xVc 6NaPL5mW3dfm5rnsrlRlZmFH4YEqhhLjPTJqE+HJxJtDDHrmuvS1hTGGf86mEUGMHfVejNfb z7nK29m9qu1u1S7wD3roGsrZj/EfrSf2baE/dNc9Sjza3F7ZvcxhICOtMZ8HrXQLp9oP4KkF jZ948/Ss/qy6C9oc4rZ5JpQSTxXRnT7I9IyPyqQWdmBjygaX1YXtDmV+Vsk4pxkweDmulFnZ D/l3Bpfsln18haTw4e0OchkJcCrg2A571tC1tAciBPyqQR22P9QtNUA9oZtou+VQPWurtRiN R7VlJ5SnKxKpHtVhb6ReBj8q1hTcSG7mupxUgPescX8vqPyp/wBvlP8AEBW62Isa+efejJrJ F9P/AHx+VL9uuM/eFK4WNVmwMjPFeQ+L7ee+1Gby4JW3MAMD2A/pXpX26f8AvD8qZ5iMxZoI 8nqdtVF6gkeIp4W1R2B8iXGf7tW08GawcEW8v4J717Ms+3pGg/CpFvpVGBt+uK09q9hqx4s3 g7WURmNvLkKf4Dg8V7L4cZjpkG5WUhSCCMEcmp/7Rn/2PypPt0/8IRfoKTndA7GB8RLgW9nb 7uhJz7cNXiEniW281sByMnnFfRU7x3q7by3hmHo65qidF0Vjk6Raf9+xShPlJszwP/hI7Tbk l8+mKF8R2rH+PP0r3r+w9Fxj+yLPHp5Qo/sTRskjRrEe/kiqVXyCzPDE160YfeIPoaQa9bdc N9a90Oi6R20iyH/bIU06LpGQDpNn/wB+xT9r5CaZ4YdftgM5YcZHFA8QWmTktxivdRoOiE/N o9mf+2Ypf+Ed0DOf7HtP+/YoVVPoHKzws6/ZjB3Hr2FRT69aSoFDYPNe7nw1oBPOj2Z/7Zio W8I+HHJLaPan2MYp+1S6BynhMOo2/JMq4x61ZGo22cecn/fQr21fCHhgdNCtB9Ix/hSnwh4Y P/MFts+ojFP2vkLlZ4r9ttz/AMtUxnGcjrS/bYP+ei49civZz4N8NHgaTABnpsH+FRnwP4a7 aZB+Kim6guWR459tt+0in6EU77XD08xc/UV68fAnhon5tKg/75H+FMPgDww//MMiz9B/hTjN Bys8k+0xZ/1i/nR58f8Az0X869Z/4V74ZwQdPXB7Aio2+HPhduDYMPcMKrni92NRZ5T9oj/v j86d56YPzLx15r1D/hWvhkZxZScjH36ib4Z+HGzm2uB9Jarmp9wcLnlzXCdd4/OmrMHICnJP avT2+Fvhl2P7i6XJznzaWP4WeHYg2w3ilhjIlqean3BQPNS8cK7pXUHHIzzUTTrMGAbYvHOc GvSW+Enh1iT9pv8AkYOZc0z/AIVLofRbu/x6GSleHcrk8zz5dqdSPzpwcf3hXfj4S6PnIvb4 HOeZM04/CzSgmwXt2OPvbuf5U7w7kumzzwyL6ik39a9B/wCFUaURhdRvFGMY3dP0qN/hRafw 6rcY7An/AOtQnDuPkPN7jGeo61WfjFekT/CJHPyavIPr/wDqqo/wik/h1th9B/8AWqbR7lJW NYE4H0pwY+tAHA+lOC4rlshgCaUE560Yox9KSuA7J9aUH3po60oJzVNAPyfWlB96ZSj61DGS AmnCox9aUHFCAkpwz1pgPvSg8/exQkBJSj60wHPenDHrVAPAp4zUYx6ilHXmlcCQe4pwx9KY PqKcCPWgQ4U4Y9KaPqafj3ouMUH2pRTe9OGKdwFBpwNIMZpePWlcQ4HntS556U0AUoAz1pWA cOtPBGaYMetOGM5zQMcPXNOBH1pg2+9OG2qvoIdxTgR600Ffel+WoAeD70oNNGwUvy9iaauw H5ye1GaaNvqc0cetVYB4INOziowRS5oAfnntS5pmQKUEetCt0Afn6UufpTMrS/L2zQ7IB2R6 009eKUBM0HB6UWAVSafkimL70vGetIB+aM+1NyPWjI7mgB2fajPNJkHvRx13cVSYDqSk4z14 o3DPBzQwFoz9KQsO9INueKFfuAufQ0ZPtRx60cetNALk0mfekyPpSZ96NwFzRmkz70mR607W AXPNIaX8aPxpJ2YDeaOaaSwbrxTuSOop3ATp60d6Dmjp3FJIA79aaeadTWYnrVXYHEhTgc9q UKetMBbA57Uu5vWsxjsGlwfU0zLUvOeTTugHbSeM4pduO9M/GlGc09xD9oz1ox70zBPWlwam 9gH4HrTguKjAOacC1Ty31QySlGKjxmlApq4EgxmniogKd+NCQCvMkQyePenRzJINysCKa0UE 0RSVDn1BqK3sUthiN22+hp8qAt5FLuHrTMUu2haASCQCnb+ajApQppaASh6XeKjC4p2KAJBI CaUSCoxzTwPXFIB4kBpRID6Gm4HTFLt9MCk0BIHFAcUzFKKcUBJvApQ4zmmAUYpiJQ2e9Lu5 qMU4GpsMkBpc0wD6U4fjREB27nvS7hnnNNH1pwpgG6lD0mOetLgGgQbsmlDUlLihOwAH/Cl3 4pCKTbnI9ad77gVbjU/stysMtrcgHpIEyv51cWYMBVI2t75rf6XvgzlQ/LL7fSrSR49/enoB KH5pwcetR44pQBnkVNhkgalDCmgfSl21SELvGaNwPekx7UnHehAP3jOBRupmKMUO4x+4etAY UzB9aO/NK9wHbxnijd6Uyg5oAfuIpN1M596Qg0wJM+9IWNM5puD3NVe4Eu4+oxSbjmoue1GT UpgSFiemKNx9qZzSc9f60LcLEu7Pejf6VEW4xTRgdzV6ATbqC1Q7qNwNIDkA3A+lODe1QBjg fSl3+tRqImyKUEVBuPrSgk96aQE+falqLcaUMfWhsCUUVGGPrSg0vMZIKUVGGpwNFwHg04EV HuwaXJoXmBIDzQG5pg5704dapCJAM96eCBUYIpc+9EnYESZ4pc1GDjqaXI9am9xkoPNOBGah /KnA+9JgTcUZFRBs96cG5NO9gJQRTg1Q7qcG5qWwJt3pShsVFmlBpoCXdShhUOTSgnuPyp3A m3UobvUIPvS55pATZpQ1RA0oNGoE24etKG96izSg89KEBKDTgxqIHJ696Xmk1YCXd+dKGzUW T6UvNUhEuce1LnnrUXPelBpDJRQTUWSKcCTTsA9T9c0ZJPtSZNKDipAcKXA9abuNA96paiJF xS5pg59fxo/Gn1AdmjIpuB70YFO4Ds0mRnrSYPY0fjU3GLn3ozTaSi3YB2aTJpuKXFAgz+dJ knvSYoPFNtMaDJ7mgn3pAc0nWktBhu560bqMU05zVJgO3UFvfNMPHc03n0osIkJpucd8U05p M0LQY/JpCaZk+tITTuByAzgfSjNKvQfSlxSaJAGlDe1GBmlApJgKDTsUzFOGadgHAUoBpm40 4NRZsB+DQM5pA1OzUtAHJpygjvQPpSj6YotpoMOTSjI70oA704AU0AgJpwPvRgUoFD8wDNLS 4FOCVNuwCClGfWnBaNtFmAg4pacB70uymkAzd70oPPWn7RmlEY9KXLqA3J7U4MRS+Xijy6Er CF3HNODU3YaUKc1SuA8HNOAGaZlVOGcA+hNPzQA4AetKFpv1p2BSvcBwHNO5po47mnBjQgHU 4Ypu72pQeabQDsZpdtIGFODfSlsAAetO2j1NIGzTgfencBAtLtpcjFL3oQCBcUoBzS0oPNAC Y9RinAUD60tMBcUlGaCaLBcMZoxigGnUBcbikxT6Tj0osAzijFScU2lawxmPekxUmPUU1iEG aNAGnpzTCaoy63piXi2cuoW8VywysTOAzdeg/CrqsrcK27HcU0oiuOA44pKeMjqOKDjrTsh3 I8DpSfnUnHWmnHakAw47E03tUhpvFMLjaaR6VIcUnFDsBH35NBI96dwPQUhxSsBxueB9KXee lRLKjKCGB47U8HPSjcCTdnvShqjHWloSESZpc8dKjyfSlBIp2AkFLkelMBpQ1JDHjHpTh9aj zTgxpiJBkd6cCajBPenZ9qmwyTNOB5qMGlBOaYEuacDUYPrSgmk2BKDz0pQfWowSfWnA4oa0 Ak4p3WogacDUpgP28cGl57MKaDTs5OcCmkwHc9zmnAmmjFOAPtT2AXP1pwpuCacAaLiF/Ol/ PpSc0AnPSnsBw/jDStcnvN9k1xggFGiYgA5Yf4fnXX6d9o+zIbj/AFhHPargkdejHFLk0J3V rCFAOaXFIG9qeDU7MYg/GlwM9TTgfanDFPQBgA70o9aeBRgUWAbmlHWlC+lO2H1FJgIDng0o OKAhzyaUIfUUIBQeKAaNp9aUL71QC5+tLmjZ6GgKfUVNmAobNPGfWmYx3pwB9aaAdznrSFc9 6Tp6UufcUtRWFHFB570mR7UZqldjF57Gko3CjNTswCjNJnmjBznJp3AM89aRuQRkcgigjnnp SYA6cUaAeeat8O7u+8TC+FxEbQyeYTkiQcsdoPpyK76JPLB9TyaeFBOaXj1qm9LBYXJ//XTc nNH40h+tAxCe9MLZ6ilJ96jZjSAdv56Um+mbv85pC30qgJN1NL1HupN1ICXd9M00sc9Kj3jN NL5/ip3Cx5/pyvMqEZwVB4rSnmjtk5IJ+tcfa6he2iKLeVQNo4YZp811c3jEzMM8cLxWTbfQ fKbf9sOZNqRA89xV2PUYyAHQg+1czDvU8sTz3robCyLxCUENxniqTSDlNBGVwGGQPepMCs24 v1txgYYjsKrW+sebNsaJ198U732EbnHrTgFPpVUzRgD94CT2zTlO7kUrisWgFFOAX1FVwT70 4ZouBZAWl2qOlVwakU56072QyYbacAtQjIPangn1qbiJgENKAtQj8jTvxovcZMNtOAXvUIpw +tK9hEo2Zpw8vvzUQIpe9VdDJcJ2p3yVDSjjvQBNlB6U4Fc9eKgJHU0bx/eptiLIK+tOBXFV wQRSip5gLAKevNKGXPNV9wHcZpFcH1ovcC2CtKAneqof0DflTgx9G/KqTAs/JSjZVbeepDfl SiQZ+9SuFiz8nuKXC9qrhxnrTt/NFwJxilGPWoNx9/wp3mH0b8qNEBMMU4GoA7Dkow+opQ59 Cfwp8ysFifIHelDL1zzUIY/882/KlDZ/hOfcUuYdibP0oGM1HuoyO5oESHn1oqPd70oYmi4E gXJ5NL5Sn+LH41HnNKOvWncB3lDP3zTxGo7k0wE96WpTAdtXuaML6mm0v401IBw2/wCRRxTe fWii9wHZX3pMrSYPbNJgmhAKSue9NJBNBX3pCozyT+FKTGLlfWj5KYFAPWgrz1oi9BDiV9KQ lenSm7femlD60rtDBmXtUZcA0MtQsPendvUB5dM00sntUJHvTPxq02GhY3L6ikLJ2NV+fpRz nqaLjJ9w9qQlM1Dz70Y96BHjqFgi4GTgVZhbJ9MetRLFII1AjfO0dVqRUmXrE35VNmzXoXEN O2SE5juJoj/0zfFV1EneKT8qlBkUj925/wCAmpUZXFYU2u45Mjs394tyamgVojgZY9s0iO54 8mX/AL5NSFJh8wgkyORgU1zEk8c0cUmZlkYg9lJq02uWcOA6TD0+Q1n/AGrUnGwwHb2ITmqr w37n5oZGB77TSincGjUfxXp0PLpMOO6GmDxtpIPKz/jGal0y3KrvuLVmGPulc1oM+nO+z+zJ lPqYuK15YiszNHjbSwf9XOfpGaVPG+luflhuT9IzWmsFkGBFq/8A37p5S07WbfhHS5YjUGzP /wCEx08cGC6B94jQfGmnL/y73R/7ZGtFBaY+ayf/AL908LadPscn/fujlQ+RmUPG+n54s7s+ /lGgeOrDPFjeE/8AXE1r/wCiDg2cnXjEdOH2Zulm/wCKYo5EHIzIHjqw6/Yb3Pp5Jpw8dWWC f7Ovf+/JrbW3tj0gIP8AuipBb24/5YD8hT5ULkZgf8J5Zf8AQNvT7eQc0n/CfWeP+QXf/wDf g10Qgg/59x+VPjtY5OIrXd6kJmpshWZzf/CeWuMjS74/SA5rV0bXJ9ckKwaVdwIDjfcR7Qfp /nvWxHpaZybXP/AK2LcGNQvlBR6AYqZSiloCQy106JSDcKHPoOlXW02wk6RMp9VqREUfMQRU hkXHFcznItIzpdHhHzQzY9nFZV3bahbOvl2y3CFgCY2yQCeuK35LhUbbnLHoopyWyE7m3A+1 OM2KxDZWkUQDSRZfvmtEFNvEEX/fNVxZws2fNuQQe78VXmuYoXKfMxHcNmtHd7Aol4uoP+pi /wC+RRvTvHF/3yKzP7SRf+Wbn8DViGeV8FljVTyM8mlZpaj5bFxZYz8oSP8A75FOa1tJPvQx 59QMVCgy+Qo/CrABIHB/KpTtqKxWbR7J8nDocdVqpcaK0aM0E6nHQOK11DDrz9KbM25CMVft GxWOYsLueOeaGSEbweABmtJbm8z8qRY9THWTeSi31gMwYK/B29e9Ww1ztBilYDtuNVFX3Lgj btGmkGZlhz2+WpZ1eNSyRQN9RWZaXJChZcCTuRV0XGOpGPehqwSVmRme76EWa/7pqRbdp4sX BgBx1TisyW8soZyq25L5604ancRsDDGm3uJKaVx6NFv+yUDcyEj604aZGp9frT0vLi4jB2p0 6AVOk5x+8UoR696luRm0V/sYBGIlxTZLIEZ2BfcVbeToVOfaqzSMzAlWyOlT5hYydQS/s4Gm tLT7Xt6xqcMfpXHP8RpoZWjl8KavvU4OLc16SGZfmAbNQyrDcgmRFLf3tvNWprqFjzv/AIWW 4+94V1n/AMBzTh8TG7eFdZP/AG712kts0RJ2Iy+uKh3xnqE/ACtFKL2RJyH/AAs1s/8AIq6z /wCA9Kfibjr4U1n/AMB6639zn7qZ/Cl/djnbHn6ULl7Bc5IfEs9R4U1rH/Xt/wDXo/4WZn/m VNa/8Bv/AK9dh5g6ER/lSiWIfwRn6AU049gOP/4WY2cDwprWf+vb/wCvS/8ACzCOvhXW/wDw G/8Ar12BliPOxPyFIHiPZPyp3j2C5yP/AAsr/qVdb/8AAb/69IfiUCP+RV1r/wABv/r12O8f 3V/KgsG6BPypXh2C5xw+JI/6FXW//Ab/AOvSf8LJU/8AMq63/wCA3/167EMO2z8qCVPZB9BR ePRBc44fEkf9Crrn/gN/9ekPxJT/AKFbXP8AwG/+vXZBvTbj6UZVjj5D+FHNHsI4v/hZMR6+ F9b/APAb/wCvUb/Ee3xz4Z1ofW2/+vXb/KP4E/KkOzqUj/IU7x7D5jzmb4raVBIY5tJ1GNx/ C6KD+pqMfFjRGP8Ax4Xw/wCAr/jXoVxZaddqVurC1mB674wc1gX/AMPvCuocixa1cdGtztx+ ApLlbDmuzBHxS0bp9gv+n/PMf40o+KGiE82d8P8AtmP8ar33wjlRd2la0eOiXHf8QK5298Ie K9LRmkskuUQZLW5LHHt0q+WPQbk1sdaPifoOf+Pe9/GKnH4meHj1hvP+/NebyXctqwF3Z3Nv k/8ALWMr/OhtQtiqnzeD6U+QVzuEvn2j91D0/u09b6UHmCAD121krJc7Rjb0p/m3Z4IU/TNY uDZXP5G2mokHJhj/AO+atR6jF1Nqh+iVzYkvDwAn5mpo/wC0zyqx/maXK0HP5HQNqwX/AFdp GT7rULa3fjPl6fbfVhWMX1MfeSPp6mhX1In5PL/EmmoyFz36Gymqa055tbJRnsDVuHUb7A86 GEH/AGVrBSTWgeBb47ZJqdW104IFr+ZpKLDnsbov7huVhTPutOF9cn70KgewrBH/AAkJHH2T dj1bFP8A+Kiz1s/zai0mHO2bou5s/cH4CpRdStjg/lXPhfEWfvWg5/2ulLs8SEj95ZY991Fp C9ozo/PlAzj9KXz39/yrmvK8TH/lrYj/AL6pyxeJsnNxY+2Q3+NHvLoNTZ0iyN/dNKJcdVyP eud8vxPx/pNh/wB8t/jQIvE2cfabL6bW/wAaFKXYTqM6QOP7gp2SfuoD9Ky9L0XX7iXfqN/B HAONkSEMenc101vp7W/+qUyepPek6lhq7IbSzErgzkhewFbkMKRoBEuB9KII4gB5qqW9O1WM J2HHoKxnUbKVxh3EYUAY603IIOQM/SlaNWOSW/lQQGOOPas1Iqw0x7ztzvPYKailikjwMgH0 qRywOxcITxlKfDbP1aQv9aNWGwyBVQ52AuerYqwZVTmSQLUN3dwaZAZrpXWJeCyjNZsWqXd4 xe1+ztbepGW79a0S0Got7GpPehUzBLA2DyHPaseTW7DeVNtCZh1Ma0wyX6Tk+TbLH/eeMkGi 2uJZZCJre2XjrGnWqWg+Vos2c0moElbeOOED72fmJ+lXfL+zoQArg/36pspUDGF/3eKF3NMo 3huehPFKUnIlyRftY5ZPnPC54APSpJxJGfl3MfrU8W0fMQv0WmplXJVzyc4bmkk9iXJGVfaj q1qFeHT5JY8fwEZz9Krp4qL5hu9Nu7WTHJeI7fzro5DkfPgDHGeKqzi3nUx/aYgx4wWBrZU9 NhKSRxuqXwldJoSrupyCOa1fI067VN+qSxOwHyjHX2qK/wDCWq3EmbJrAIRj5iQf0pi6HPBt gvfs63EY5ZTlfqKcacgjPUsv/ZVqyJ9tvJG/vR4IH1rYgjhC7jcs+QPv4rnjpbl9uYNvqG5q 3FYsnSUAf79NrzNW7o2jb2pO4lf0p32OBhnIP5VkpaAsd1zJg9t3SrkMGwApO+B05zU6mRZF mqE4uZgPTjildYVRi7SSgdhyaVScYdwfekdggB2Mfp1qeaQiMSLbn5mPlHkccj2rMufFkFpd /ZG069Z2UmMiPIk+laizpIc4Kj+6/FPjuSG2kRso6EjkVDuWiCG9eUpi3cbwDgLwoPrVsxFh 8yhfpTWD/fEqqvXioXcq2S5YHtmlcTJ3iA+88ezuO5qnPa2md0aqvrTw7ZVlVW284YcGiRA/ zY257AU03cViqsVq3bn2qQWcDchTTZLVy2RhvTNZOpaNqFyxls9XuLN+AUVsr+ANbxl3FY2f slv0IagWdoOWi3VyiaBrkpx/wlU2QeQVH+FOHhvXx18Vyf8AfI/wq15E6I61YrHobYUG3sic hHX6CuS/4RvXj08VS5/3RS/8I1r2TnxVL/3zRqxXR1gs7ZzxIVP+1QbFMfK6kVyLeGddPTxX N/3yKT/hHNcU/wDI1T+/A/wqUmB1fkFeQiH6Cjagzug/SuTHhzXScnxXcHjHAH+FP/4R3XcY /wCEquPyH+FVy6AmjqfLtupiJ9iKDHaf88WHuK5Q+G9bJP8AxVVz/wB8j/Cm/wDCM65gY8VX OR6gf4VKTHodX5VoB9yQ/UUhisSeUf8AKuTXw3rYyD4ouDx1wP8AClPh7Wgf+RouD04IH+FV cDqhDY9NrfiKUQ2eeCRXJHw9rJP/ACM8w+ij/CkHhXV3/wCZtuM+4H+FIVzrttmD2P405Psm f9YQPeuSHhTWScf8JdIBj+6v+FI3hPXB08YSfTyx/hRqx3Otm07Sr1Ck8FvMp7SKDmsa4+G/ hS5fedNhjPpEAB+lYx8H+IGyR4wf/vhf8KRfCeuoMP4vuScnoB0oTkt2K5x8UOQPoKnMOBwK kQAY+gqYelDKKaxnPSrMW4e1P2DNPUAU7JiFKButCxKDxTxTgM1IChaeOOlJ0pQKdxjxnPU0 /p0JqMdeacKVxEgz604UwD3pRzSuMeDz1pS6jqfpSQ289zL5dtE0jdCQMhfrXQ6f4bWArJey RtN/zzRuOvFJtLVgkZFrZ3d64WCI47u3AFb1locNsR5srSS+xzWzFZs6AZKKOioKsxWnlkbR tHuOTWMqvRFpIox2Uan53kPoM81ZEAGcEAf7RxVhiE4TaG9WqJiByzB3P5Vi2xoiMSHo4IoE ewhlYcdhUmRn5ggb26VF5qM2FIYjqU5H51JSJF80ncQCuOwqGSZpCyKi5PGcdKYbxGl8pp40 QdTu5+lXFksQvzTxn2BGa0jETY2GBUXgj1OaY+qWFuTHJew+aM/u1YbvpioZ9b0i2Yh2uOP7 sRNQwX2g6vLtjtEkkxuPnwbWH501a4JPcq3Wo3t5IUitLQR9vtR5I9cCqNxbSO2PPhh9RChA rp102BgPKtoox2IXmpJFt7cAPLboemXIBq7orma2RxkkEMMiCS/ZSTyJJiufpmtO3gVU3I+7 jgk5Fa0trZ3LljDbzMP49oJqCSEJ8kcW0DqBT5tNROba1Km1Mf6wse9PhAklVU5J6Z/Wmi3W WUxhXXaAT71paJYXElzNcqIxAoCR55J9T+da00mYskS1mbuMVajspAQev41eEWOvWmlWXo2P oa61TijK41rORwD5cXA/5aHJqpJYTmT5Gii9xAD+tXdjlTj/AL6POKhO1JAsl6oY9ELAZ/Ch pAPWAxr88qEjv0rF120SW8t3KK8ckTK3PdSP6Gt0QqT/AA/jUF9br9m3dSjZHHrwabirAtGc yLC1jUKluygehq/b20CJlrfeD6050bsRSfvVHyN+dcctza7JRBbE4+y4qaKC3jHyxhTVMNKD ncTUoMxIIkB9RipbkO5d2RkDBX8qGiG3jrVISXO/YGj9SDxUvm3EYBIXb3INR7wCsnqFP1FQ siq4YqMj0qwGc/wA03epPIA+op8zYWGJLGnzbWk9VPOPpTgvO6NBg/3hQXA9B9KYCqbsO4Vs dO3vSYImAiUEblJzyo6ge1L+7x0NMEccybg6u6jnYeTSIzRxK0cRfPRX61nrcejJfKjZerZp piGPmAP0poup0Jzbpx1xSveMrDMXJ54HFUpWGQywWs2dysG/vKMGqEkc0GSqPJGO4HNa3miR QWTvggdvenGJJBzk/Q1UajJZjJMki5Rg30NLk55FWLrR0nUeRN5Dj+6cZ+oqrsngcpOOR/GO hrSM7kuI7Jphz3Bp5BADAgj1prZx1rWJJCrfNgmpBnPeqoVhL941aVj3/Sq2C4uDnrSFT607 P1pPz/Gi4rsad1N5HUA0/AFJkdhS0Ghnyk88UYH1pc8dBSZoATaD2FGB6kfjTuOpApOPWhpD uNBZSTkEUea39xTS4zSbaXKmI84VeB9BUgpqDAH0pwqBhjnrThmk704UK/QBwJpwpop1O76g OBNODN3xTAaUVKYDwxp2T2pgpQTRp0GTRR3E7BIIy7k4wK3bDwrcXAD3jso/uRnH55rlJRdC 5SS2u5rcpzmJsZ+taEHiPXrTaouftSDqsoIJ/EVjObjsi4q531lpcWmoVh8xQw5RDuJPHU1f AjjGXCqew71xNp42uFA+1WC2y7AzSRPuAPTB75rYtfE2mXWMTxZJxl3GaxdS+5VjaO8k7bgg 9gvaoJLe/c7vMHHfdinQy+aiyW0TzRMfvoRj8Kz7+8ktZk8t72eR2wLaCMNs/wB70FJSK5S2 PPJ2mJmUfecN0/Gk+3Qq+xFY+pB4H1NCxTyQx+fEQGGTHC2QPZz/AEpDYXEqt5UkFtBjgFck n6elVpYl6bEryWDR5upWQIck5wv596ktbaC7jSSB0S2wduGA3Vz8whs7jErjULgvnaVzDF+H aua1K0tWnKpLMkrAs6RzMEH0HbrSWjuNO+56mNLs3HyxQZx97jmqc+jWzNgGFWPAbdg/hXlM OnXpY+ffX0cKAhY/tDAFe2OacmjoJ1uI9T1NSuP3DXDMhOevPOeK0dRWDlTO4fwtsuWmh1d2 ZZAPLkkyoYfw4/pWhDps0SLuGnid885IZv8AIrKttbi+wGM2zy3Bbe8iLyrYAyT61zmqXF3e y7jfTRqBhWV8HPY59RWXt30RSujvU067VtsrvDkZLrM2Bz0GajGg2yXHnl7aWX+/O5f9K41P G39h6VHBreo/amU4UscysvA/Hoa8/wBT17V/El86aSLq2TcNjGRlcqQOOvtV0pznpYHI98/d 2wCBRAjHO4jBY+w9KRnDQkrKGXaRnIBY14vBH49+yQwTarEyIAI55XZpIhjoMj+dWbrw9qup QRHUfEtxI0Qbb5QEfJ+n0FVKMk9WQ35HrEKtp+nz3ck8TSRqZGLNkLV/S9Z0KSzgjtNfsJBt wP3y5J+ma8Bbw14j06RbrTNcaZV+fyZZm+b2K9DXQWVlatEwn0zT0vHx5vlAoQ3tj6/rWkXy apkuNz3ORf3ZkF9b7B33Cqv2uyDYbWbFT7yr/jXhw0e5tJhLZ6tqVuuf9WZt6fkwNXzPqca7 VltLh/8AppFwfqRW/wBai9CXSPYDqOlgFX1m3I7hWyDUTX+gKwc3ULt2KxbjXmFtrd9Zopn0 6zlRRj9w+G/I1pxeN9OVdlzY3FuM43CIHB+oo9p5kcjO9OvaOG2/apQf9qJgP5Ul/wCJfD+m 25N9qkUSthQNxLAt0OMeuOTXKxa9oUkiRPqEULTcKszhHPuoNct4g0rSbKFnt71dQmnkVRLI 4dsbhxn6fypSqtbC5WeoKVYhN0B+UEOGGG47U8wJ/wA9YvwYGvJY9OgEMSrLcDYgGFnYZwPr UsOnrbytJb3d0rPjO6ZiBj09K5J1mnqbRhoer/Z4+P3kX4sKeLcE/fiH0YV5KYPm3SSzMcnO JW5/WoltYwGUXF1ntmdv8aSxCL9mj1e4gAlU/abVWIwN78mk+y3DfK1zb7cfMAea8hm0i0uI sztPM6AYczMXT3U54qH+y49x2XuooMgkm6fn269Kft12DkiexpaSBiDcqcdH3CpTbE8mSNz/ ALwrxae3lF5BEL27WMjeAkzYzkjFS/2ehIzcXwOMZ+1OP60Rq36ByRPXmjYHhVx/vCongm6r LB9C1eRDTFaQbr/UQMdBeOP61KdKQrJ/pl+Nxzxdvx+tU6iQezR6gI7m1lEyND1yyqfvCtJG iuoRPHIHXuB95T6H0NeLf2J1P9p6mDnPN2/+NdX8PbiDRbnVLW4vZCZjFIrTyFs4VgcE/UUu eMieSx3rPtwxJyKQzqQSAuQOcelMn1PTXUsLyDjqS4xUUM9veRStY3UDyoP+WcgPY8GpEDuJ D8jFTmo/LlDbhM/vVa/1vTLJB9svYrS6PAt2IDP/ALo79/yrAk8e6OsRkijvbkA4/dx9aFYX U6QTurP5iH5Rnce9Qyzi4Hlb1Xd2PX8K5J/iMZEzaaBdse3ngLn9apXHjvWZ/lh0e2hPHzSO dw9emavlS2HZnUJp19Zzt9kuopFc5MUxOR9Ku4nWPM0e1v8AZ7/SuBbxF4kuZh50lmsZ6lM7 x+NZ91da5KPMbWbldo+6p+Uf1qoTadiXE9Kw55xj2I5pwD+oqGzm8yxtXLEloEJJOSTtHWpy w7Gum5FmKPM/vAfhS5P97P4Ubh60K2T1FACFiOpppfFO+Tqc00lM8mnZAIHXuSD9KMr6n8qb kE96MqDg5ppAOyvYkmkyM0mc/d/SjI7k5pMBc570H/eNJkeoo3+1O4zztcYH0pwIpgztH0pw rJLuA7NKDTM0oNVsA9T606owTTgTQtQH5FOB9BUdODUtBj80uaZu+lGeakCMmRbpGVJHU8EL 0Huam8sFt24qf7tLHHvbdjIHXBqbCf3OT3FcteKe5rArNbRtcpdebKjqpXywfkfnOSPX3qRr aBXLrCqbj82FGCamIO0DA/KmMwUfPIFH+0cViuxbuQYuYHQW2o3sCZ/1cMuEB+latr4j8Q6e AlrcWs68ljcxksfbINUXngKqgkiWRjhC3AJ9M04APEuVkic54I5yDj8qTiG5sDxneRobq9tb dQBljbSHn8DTpddsdTm/4mD3wZRgRQZCL9SPpWGbeQoUmeNlJwQnp71MZPs7HadqHGdg609t mFrGhJd2dvbeTpyMwZiWbdyvqT6mqMUqqowzMT/E/JNCn97nqD1x1qNbxHUrbRiQgnIY7e9W p3WoiSSR4lLtCZlAztTlvwpkjwrG0zPsjUckdqjkBnXL7omwf9W2D+dOitollWRSytt2tzw3 uR61KK0FhuYDEZLdpJYGbaXzjGfUVBe30NpZSNNA+zBCeUu7Jxx/SrqxoGyqhST0AxmuZ8R3 0pvI7SI7VUgEKMZY7P6GkruVgcrIzodPufEWoRzqFjtVGGkUZKHnKj0+9XYRWdpaII7aIKAO Sy/Nn61DpWn/ANl6ZDBGVyFBkwepIGc+p4q00u7llPbmtZ1GvdiQtRdjYx2Pp3oRUVcljznG TSqA/EZB57mkICYWTaG6jmsV7xQ8ABN3lkqOpxkVzvi23ZZIL6Kdo23KuY2wMjbg/kMVvBSn PnMEYcZPBqrqdhbXunvZ3RaOOQqwZPvAg5BFVCTiwE0PUf7X0eKV9nnK3ly4PG8KpP8AOroW MY+XH41n6baWmi2wsIvNOT5mXHzSMcAn3PAq8sqPG5XOEGenXk5/lRUs3dCS7jXQEkqATUBj YvgxBf8AaqwJY2QOod8nYCgyuR1zTkLugWVWQkfMU7H2ojIdkVZNJhuUxcwpcqpyBMgfafbi qo0LSYJlmktxGYm3Ls4CnscVpGB4rkkXEjxq3yA9x/tU7bESR5WWbls8g1Tm+grIaGidWKvw oz2zVaK+iuGEUPmE9VJHD4649atLa2yD5LdFGcttFPKLsXbsAX7uByOe1S33BFCK/SW7Ft5c sM7ZKxyDBIFSS3FvbzwJcNl5srGq85NW2eRmDOqswOd7D5vzppCsMsi5HQkcipaS1iNspm5t 7acwSq4yoO8fdHPQn1FTFlMatGFkVjgZPBNOLAIy8HjuBTRwnGFAYHaBx1ovJiMvU9SNhfWy iwuHlx8zQxl1RMnO4Dv0rUe4iE6x+XJJuAw+3j8fSoZZpP7QC/Pt8oHOcfxHpVssGyvOMc57 073Ww0V5Jo0t5X+xSSeTn5I0y7fT1oPnRFXWB5RKpPlxj5lYdBg+tTZfcoV+nbvSiV0P3tvO c96beg7kKyTm1WdrV4wfvRuvzqfTAqKfZKYzLCpBHyORgfnVwTvvBEhL5zkdacA3pv77TU3u 9BFB1W+jRFlElvGgQ7CMNjsaS3sI9PDyWDC1Z12uYTtJHv8AnV4qjyNmLy8cAKuB9ahTTYbe WSaJzJM4APmPwR7j27VV+4rFOa2WWRJZ91xKnCySncR9CaQIMYAx7VYu4Z1V7iBo50bb5cSn BHPOars91tJFs6YOMuv+c1UW1sImgBXdwCMelDdQNi4pI5EEaiVgpI7nFJjqwbcPUcik3K+o WB1j2nCgEmq0sYERVXfkHHNTs6swGASKim+4eDwDVwbvqSdzp5xp1oNp4gQf+OirOQPaobIb dPtlJIIiQf8AjoqxxnORmu1NGbEz7UvPZsUhAP8AFTQuP481aJJOT3NJwD/jTCcdGoye5o1G PZB1JFNwP/1U3eB6ClDYoFqBBI4HT0pCDnpTi5xgUm8gc0CsJgHtR+VIH9qUEU7jPPVPA+lL TQeB9Kdms35DFFAPPSkDUcg9KdtAHUuaYTS5zSAdk0v40zPNOouAoJ70uaQUfjigAScR3SAt tBHrViJ5puVjJYZVgeOexFUpJvKnhPktIGbGQudvufStJHeQIpwoUHDD+L61y1+5pAQRylTG rRJJj5lY8/Wmm0YAxXMpmQYI4yCPQ1Pl3+YknAxnFNSQB3R2UEjKYbn3rlSe5sOjxFGY0jjK ZyykD9PekLJtAVSMDvTcgODxuP8AKosyXG5baRIZFPzG5GFI9qdnsInLLt6qpxxmopLuGJtk rSI+QAfLyOTgc1EtvMSUv2iuO6+UCAB261ZLnnaCUPbrik6aS3KTuRBbhMGfyXGT/q89KfDE uA0a5ToTUi8kbjtGeKwl1bVv+EmaxMKmwaMuriM4J2g9enXIohGXQlux0KRoCQ7qO9OUoR8v I7Gq5diwc7WDDbkDpWXqPiODS2MUUDXl0V3bIuQo4zn86fvN2C5uxqhy24gdSc/dri7OdZ9Y huLy6QJHucyTsBwACB+g/KoFk8R+KGkktT9mgibc6hzHxkd/Xmnabo1vqV/5V0SyQDcY+zdR z+VdVKlJayZm3c2bnxfokBk/0h2YLvAVeGz6etVIvGKBmS7t44DwVDMM4x354NasXhnRbYYk s1mUZKvIoLAdh9BVg+HNCyzf2fayk88oCaVqV9WNXM638SaRqCrDb6gLa5bkeZwv0z61tKoy v2mNHdc4YHP+c1w/ibSdPt7zybe0ji3ryqqB8x3AY/IV29pE0dlb5cPKqYYnueeoqZUor3os ak72JI4IFRoTCxhIPGeMVKqghgArbT8obqBUIV8g5Ax2p5QF8ktyBg4rndy7iFiHDFVbaeCw 5B9qaHGCVODycdqkwVIJYsAf4qb+7Y9PyFJR7gMRgrYXaqnnC8ZPrTzIpHLZx6GkdIgAd2T6 VG0lvsxuAPTnjNUvIRMHXAKs5PcMacQ2FJC88jBqqZI1KoTtLHCnGQacJ5kcIVXA747fWi7T sMlIyTz1FJyoKjketRNNMjcwSMp6FcU1p5hPsSNvJIyZG7HoBVpN9AtcmCEc804Rg5znBBzz iqh+2oztkNHnICHp9KdJ9qT5JIjI3PMHzYXPXNTJMLDiDwCA3GPpTT8vDA/TvUJjkRnIjmwQ Npj5A9zRam+WAGcRO24/cQj5cnHXv0p8r5dRWEl2yXquJdpEYTae3JP9asqT0Az/ACqpdnUF vrd7e2D24J84hMMRzjH6U8yXy3rIbZRb7WKttOeO2emaS5rArk5YbiVHIXnPehD5hqmU1PrC ihMlgJ2+YgnoRUrRahNva3it4trISkxwSufmxjvjpTs2g1LYO0/cGfpQHBcFcAjuKjWF4ucs yljnd2pjSXMT/NFHIjg7BEMsMdzUr0FqT7mJ/wBY3XpQxOcBVJBwc9qihuIpo1JdQxO3HTJ9 KkPy5JLD6Ch3uNeY4xx+XgLhsZyOOaredKije749OtWEm3dCTjjkYolRHQAsAcdFpLcViq8c EwBkjjYherdQDVc2aIqrGZNm4EqTxUr4RuenTJoLjqCBW6XYTK7WkpuGdCpDMT9KrTRXrq8c MTlip2t2J7Cr5JVOG5Jqs0rxqArlenIPvVRvcR3dpE8VjbxuxLiJA3PfaM1Ngj+KmQEm3i5/ gX+Qp24dQ2a7VqjFibsnqc00tg9acT3JppK9DVWFcDIO5FN8wHODRtGaRlPtSAN/OCaUPzTN v0owfanYCTfS7qipQfTiluMl3Ypdw71FmkJ96dwOBU/KOewpwaogeBz2FGakCbdSb6izzTs8 0tgH76Xfk0ylGBQmA8N70oc0wGlBFOyAeGNKGx2qPNGTWckguEzldj7ygU84OM8dDVyCZnVQ sibSD8zcjPpVCV8JkAHHPIzU4uPtFujfuWHI+Tg/jWNVaFxepaBnySskYBHTHGfWkkt/tir9 ojZCpHMbYPr1HbiqIlkiYFcnHY9Kux3xk5mhFs46orcH0rn5Glc2TJ9rBQIo1LKcgt39ifSn sftAAkEa9wAOBUSTqXxuznoRUygkYwMEc8Vi2+waDjgSfNzwOaYdqn5QVHoKYrKsjRqVJXh1 J5WpFMbSmMkxt2LL8rfQ01PQd9BgY9zge9OKuwKQMDLt4U9D9aIxcLLNHcpFsDlY2j5DL2J9 6UxwIEG7LqDgk804sVw8pyA3neWyrhkIyCR3FVLXRLO3uzeOiyztzz0zjHI+mKt+aGwQ2QR3 pf3gPyx8Dq2apScdhWuJcozxuhjCpINuFGAM4rlNDn+x6vHG+BvV427jOOM/ia7D5nGwtzkE ZPcelc7q3h97q4+0aaCJyCXjPC7gBgjH0rWnPWzFJG+TuUx8gjkNng1Hczx2lnJdyFjHGcHy +SSegxWFZeJ5LYRw63ai3lCL82cAjgHOfxpLq8v/ABFM0GmWbR2Sshe4mQoOMZA9c880nRd9 x6WIbFv7d1xLiSJ0iik3HzBjpnGPX71dQNksgZJGUkHcHXBJFRWum2WlwD7MkrFsb0Z84OBy vp0qc3KmJGkYDPG3uvOOampK6tEUVqRzfahcK6q72+0K3bByfmB9MdqYVuDLKkz7I2xsx16e tSz3Iji+Xc428bRmiS4REQsMhiBwM4qI2aLuNW3YzB5JR5aps2jnd6H69qZJasH823mbzCAG Rj8n1H4UNIC2ArIQT16YoeXMpQSKSBn5OmKaAWRiEwGJcevIqPyVk/1yCUD+Fh2PWmG4Bj6N x145qVJRkkkdhS5tbASpCE3rsURZBQA8rUgVW4DH8TURBzkyLt9jSmSMH5Q+PenYRIYiAQOf xpFRQrhoyR79jVZ3CsMllz05qRXkHSQkeh5p3HexMEXYQCB7imQq6qpzg4IOD1pCZc7gse0n nmkjlTdjDA1LTYrscBtVwMgDJOO/NG5AMjj3JpRJljsKk9xUUsbtyACODijoFx5chwu408sT hc8A561ULs8vEbjHBJFTxxlTuJGPQmmloAoRZGLE/KOmDT22qMjHHT1FIeuQAPYVWlcgnqM0 tuoMlLLgjLAZ9akVztyCATkY9qpRxvHyXLZOeatAkfw9qNBDLmKOYbWzHj7rRgZU+o96jjtW UOPt0vmNjy3Y5A+oqbLDoM/WjJ3A9hS5+g1cjEVwqCOe7g83OQQT8w9vemRiaIM0nklVHBD5 Y027VGmBIdWAwCBxnmiKGNCGXrVpXQXIDJ9pJAV0YD7ucn8qiLAMQJOhwQT0rTlk2qgVY+nL AYaqcscbZZ13Z4yKam1oiWQyK3yqGPqMGopl+UDjkjP5ipJLVSwCyyEjgAnA/SpFs5ldJHlh 8gEfLyX6itoT1JZ38Uf7iLjGEX+Qp/l/7IqSNsRIVII2jk/Sl3n2rsi7oyIjACccCm+QMfe/ OpGPeoWmA9Kq6YhrQkD7wNR7Gz2p3nAmjzPenYQgU+lIUp3m5pvmN+FAxNopuPpSk/7VRk+9 FguOzijf9KYWH96k3ikM89V8qOe1Hmc1ApBUfQUvepTETiT3pfMz3qAZpw4HSi1xpkokwaXz KhyfSlGRRYCbzDS+YahyaNxosBL5hoEjZqLPrRu9KlxC5L5hPWsiO6W1vBubGM8E4yPX8M1o l6qOsJcPJAshXOMjnFKUW0NM3oI4riPJlAJXKgdxTzDaJII2kbzD0VjnNU7G6s1gTy0DRuoC 4ONox09qvJ4juILjyDYWn2bA2y7N0gOP5VxTUos1THuRatCvkPJE8gQmNeY+Ccn24/WrHlpd JHJbzOYzncB98H0IogvVuCQjEnPTHbPPFcpJfXFtciRLhhgtkDgEZ71mry0KvZanYvbqdrrG FkChd2Ov19etDq4j2MCRxw3Y965L+3bwktDIFyP+W3Qc9amt/EuqwbnuhFeRFxgoMMo9B601 TmuhPOjqVjk8snbtQep/lUSRqTuXjr1FY3/CQtIxJt32bvlB6irr6mwA2xMz9iF4/Gk4yXQp NF7ckShW78DHWq8l8UYqYJ1wwU70x19vTmnwzlo13yRszJn5zgRtjtUnmxOwaWVWJ/iLZ5/y KyfNfUd0Qhbm4VY8xxyZ+UnO3PakjgkusNO8sUwGHEUm1WPqKle6jXlHj45wDUBvrZm/16g+ 5pRcr6CckTm3hYFp40lYcFpBlsf5NSh1TKgmOMgcLwKqvdQIm+SZNvTINVV1S3acxBJCFxyw 4P0NbLmloK6ZpJ5SIxYs754x0xTAqljlVA/2qqG7mEjeTbFwn3VyPnP+FWIWEsKs8aqw+8jt ytaKk0h8xIyBEMjErEo5I6Cmv5ccX8IYEElhyQfT86jcxQ/u5rhrqF+okI6ehA4p8J06NWja NWjPI3SEkH2Pp7VnazGmiQAO2CWJIyD1qF4XDEKgB2kgEYLfSnrcwgnyiqZ96BfIVCNNkLnA pat6MXMjOmnljAcQkgJlsA5FOF3I9klxa2xud5+6q+/vT71oZirpNwVwxQ4qB9Us4SxSSVSC FwR1P+TWl7aMLovt5scSPHbSzM5ClUX7hxnLe1MSPUnskdrP/Si3zxg4VBk5z+GDTobuRHDF yFb0bFO/tJQ2zed7frTSfYFOI2SU27Ro8DSPJnGBkA+57VH9rumlWOO0PlFtrSPxt44x+NXB dIYtuGz19s0jyLIh+Yg5HSs3JJ6juiIyOrIrRF95xkDip4sffG3A6kHgfWhWkIUo5YA9O1Dl FcnylTPVQMColK+wJjHubSPlpIgWOM7gOaRb+2C+YZowhbAJPBPtTljtGOXs7d2PJytD2dhM gifT4DEpzGgXhD7elC21YDDqdu7xwod5Zyu5BnBHYntU7SW6xl5HVFHVmOAKXyrcZxYwhiwY kL1OMZPqaQwxGUyNAhLAAqwyOPanp3CxDFe202VhYsMZDgfKw9Qe4qCS5jEr+ZIoCY3bjjGe lWmZQCqwIqAY2quAKZBCkMzXCWUTyMu0llyCP8mhLzFqRzXMf2dLkfcHIK85pYZi67kAZPUV YhjFsrpBahUc5KkZA+npSJaoJWlj82HIIKjlDn2qk4pbjsQkgggHH1pSOcFhTmtbhHDpsckY ZS3GOx+tRNYasbxZQbJbUY3ICfMaosmxIkZCWABz65pDxjggds00xXUjlo4CiKSuyQYY+47Y pssrxMglDFCDhwMqMe9Wpcu4D3gaTBHyjHX3qL7O4YHfkClN6hyqyAkDPBqJLkyBsE7cYNNS v8IWLSKE4+Xk96ZK2AvpuXnHuKgRlGWycDpUEtyA9tEA0jyTIFiRSzfeGc+3vThzSeonoeir yqnp8o4x7UhJBqV1wB9OlR/hxXoQWhzshZvfFQM1WXUHrVSUqOmRWlhDcnNIS3r+FM3c9Sfr RvGelUkMkBo3fWozMi9QfwFL5qkZz+dADmbjrUTN6UFx61EZAScA/jTAN5Y9KeDj1qPAJ5zT wvHU/jSEcAo4H0FGKVW4H0FG7NZ7FhThkU3PNLupCH0mfrTdxzSZOeGxQkA7HUgn8aTn1pQ+ Pel389KLMBuKaQO9P4xik4FPm0AiY4rKvYpZj8krJx/DWo5yaiZAe1K9thpGSsuqwoEjW3IA wCQcn61Ouqa6g2/Z7JvqDWkkKgDBJ471MqgKRtU57kciolyN+8rjsZH9seIAwZbO1BB/hBGf 1pv9o6xI26Sysu/GDW0IxUTJz0pRVNbILWMdZtT3lvsVm5xjbk4pXudXZPL+y2ca5Bwuc/TN a2056AUojJ4K1bafQVrmVHc61GwZba0f0U5qX+1PEQwPs1tj05rSEeDkcVIFbHTNR7vVAkYc l7rr5/0a3UH+HJzSpe67HGyLbWpQ9iWrdEY6mlEQo9xdB2Zhx3+uwyB47G1Y56Ek0Ne6y4B/ s+wUcnaAc1u+WF6GmmPJ60R5L7CsYYudaU4FpaAYz1bFPbUPEJAUxWO1eQuGz+dbRi46U3Zz V3p9hpGN/aOvKykWlmCOhBbj9aVr/wARNyYLTP8AwKtoDa4IAOOxpVXnNS+TsIwPtevnnyrQ +3zVIL7xCvCw2Q/4C1bjKD2HHoKTy6FydgsYX23xDnOyzH4NQb3XjwVsh+DVu+UnUgmmiJRz ihKn2DlZhfadfXkfZOnYNTRc64JC+y0LHnlTW6YQO1MEPOcD2p/u+wWMpdQ8RKf9RaNznkMa Pt3iEyq4isww5HDYraEfpS+XyDRePYOUzxq/inYQYtPPvsak/tfxWRgLZAeoRq1MYFB6VjKN K/wjSM1NU8VjobLH+61H9q+KieTZH6q1aQoJoVKl/KUo+Zm/2n4oz96xB9lanf2n4s/562eP TaavjGaXNJ06S+yTy+ZmG/8AFjNuFxar/ug0n2rxaWDfbYTjPGDg/pWrkGilyU+kR28zLa88 WEAfa7YcdQDUfneLGJxqUaj0A4/lWqQM5FANNRpr7IW8zK3+LCedVXPuP/rU7/iqWAB1naP9 lR/hWrnvSA4pWj0SCz7mZs8TgH/idkZHUIKYbbxCzZbW5CfXArW3HPtTRktyeKXXRIdn3Mk2 euMfm125P0NJ9g1UIA+tXLKDnbnj8q2OhpcA1enYWvcxH0y7kKltRuBtGBtIX+Qpo0a4b/mJ 3vtiXFbuBSY5rSLS6DuzEGiTMTnVL78Jq3vC7XehalHIkzXKOdref8xXPcHtSouatWoAnjzz 8wpqeuxLu9z0JZdy5zzRvPoPxqjFN8g5J4FWBLkckVoiLD5C2OoqnJvPerBf3FV5JdpqkBCQ 3c80A+uKUvk5x+lJvyO1UhCgkfSkIz2pN1G8+vFADXwoPy5+lQnBzgEfjUjvkHnioAUB6tRc asSIrDnefpVgZx1qBWAHDE/WnGTIAwfwNArHAAOFHKdB/EKXDdePf5q5NU+Vfnk+6P4zS7T3 kl/77NLlL0Os5HcfmKUZPoPqa5Irk/6yXr/fNIA24ZmmP/bQ0WYaHX4k9B+FG1j2H51yGJAD i5nHH/PQ053lfk3E34ORRyPoC5Trgj+g5PrS+W2OcD8a47588XM55/56GjEnX7TP/wB/DQ49 x6HYBG9M0xkk7qa5L97n/j6uBx/z0NODSZI+0z49fMNLkQaHT7HPQGkEb9lJrmpJJTjE8o55 wxpA0oUD7VcDAxxIaTp9mGh1iIwHQ1IN2fumuPWa55P2y4wB0L9ac1zckkrcyrk9FY4qfYt9 QujsME9jSeWTz1rjhNdg4N7cdc/fpWuLkkbbudeCOG61PsZdx3R2Pln0oCH+6fyrjDcXn/P9 P0/vU43N6DxfT/i2aXsn1YcyOy2n+6fypQjf3T+VcZ9qv88ahOOfWlF/qI4/tCf86HRbC6Oz 2n+6aQhh2NcZ9rvSm1r+c8dc0q3l6h4vZSPc5pexYKSOz2t1IOKac+9cp/aV0p4mZhnuaX+1 bwAYlb8+KpUmHMdVzjpRg+hrkTqWpZyLxhx0xR/amqg8Xzdv4RSVKQcx1wBz0p2CTwDXHf2p qrE5vmHPYUo1PVM4+2sevJHSl7KTFc7HY+PuH8qNr/3T+Vcb/aWqZ/5CEvT0FL/aWq/9BBz+ AoVKfUEzscN/dP5UmJByEb8q49dT1Pd81/Jj2AobUtRDZW+lWqdJsrmR1jCTONjflRsfHEbZ +lckdV1YDP29/wAqX+1dW/6CD/lR7Ji5kdftkxwjflRtlA/1bVyA1bV883rDBx0607+2NVOP 9MI+lL2Ug5jrdkp/5Zn8qDHJ/cP5VyP9ratgH7e/T0FJ/aurEnN++PYUKlLqLmOwEchx8p/K l8t+gU1xw1HVAT/xMJOT6CkGp6oet/Jn6Cl7Fsd0diYn7g0eU3901x7alqgAP25+noKT+0dU Jyb58/Sj2Mg5jsBE/wDdP5U8Rv8A3T+VcaL7UmZQb+QEn8Kc95qStxfuD/s0eyYcx2Ahf0Ip hicE/KT9K5D7XqmcjUZCfc057rVFy3288kfKD0pqkwujrvKY/wAJo8qQdVrkRfan3vWPPpR9 s1DeMXzr16VXsmLmR1xik/u0eTJ/drlFudRJO/UZiv1FIZ77ORqMg5HBoVJ2ByOr8mXj5aTy pB1XFcsZrwdL+fr/AHqT7ReZz9uuD/wKmqLFzHVmOTsKBDKT0/KuU867IH+mTjj+9TjLcAZF 5cA8chutCpdwcjrkgmzgL+dXLS1nNym4KFB5JNcKZbkrhb24znrvpp89gA17dcekpFWqQXPa IIMgD7VbDju4qc26KMtfWmP+uorwo2zMcm9uz6ZmNNbT42+/NcN9ZDTsOyPc28gdb61x/wBd RURjtnP/ACFbMewkFeHnSrctnMn030g0i1B435/3qaiJqJ7f5Nqv/MWtM+8ophFiPva3Yj/t qK8T/sq0zyrH6tTv7Ks8n92fzp8rQrRPZ2l0tB8+vWC+5mFRPfaGmC3iTTxn/psteODTLQE/ uv1pDptqBxEKOV7isj16TUPDzDJ8S2AI6lZVpn9qeGuh8T2f/fxa8k+wWvlj9wucUJZWuc+Q n5VNn3Cx61/afhNTlvE8R/3XFKNd8HD/AJmI/wDfQryT7JbBziFOT6VHLbQDGIE/KhQl3FYk U/Kv+6KXPOfpTV+4v+6KUDmqKFBozTe9BJyKdwHZP6UmaTt+FGDRcYcZ/GnelM/xpRnApCFz /KkzR0H4YpD1JouA7OaCabRnmjcBQcZ9xR1pPajpQA5myfxpv0pBx+dCj5eaBgT/ACoJo7fh RQA7NN/iFFFIQvaik7fhQRyfwp6DHd6QUgpaBAT8tHek6Uvc8Uhi0L978DRQud1Ag7n6UnTO KG70ueTTATHP40d6X1ooGIec/SijPGcdqDwfyoAXofxpB7UDrR3pgLnI/CkzR0H0FB4JpAKM iijP86UcnNAhKXrSdR+FKKADvSqOgFJnBFOA4zSATkilAj+YkNvJ7Uh4NKBzTAM4P40ehHvR 1/A0mTgDFLYZIPWlznmm9ABTiOKYhQeR9afUIOTT+aLgO3Y/LrSknHHSmfwH6UDgYp2FZEiM M4Pc0pYYpgGDmkpjHqcn8KdnBNR5x+VKxOKVgHE859KVD8wz05qNQc5z3ozQmAK2W5p4IqLB pfWndi0HZyTQpzTQTn8aRuKGwFfgH6UxMjNOzxSEc9anYY0jEn0NNkUMRTxjJHvUZ4UAtjrR dgIv3F/3RQc0ik7QP9kUcmhgLg5P1paMYppPNJAGf5UAHml4H5UE4FMBM5NA6Ad8UdKASe1M BCcDrQeeDQeR05xRSAM0A5NA6j60d+aLAB/pSHqfwpepP0o9aQCf40ucigUlAwPTn0oI5oP6 YoNNAHQ0ozkUn+NANAg6An2pepNJ1/KjGKBhjn8aXNFFFwDv+FFJ1H4UdzRcBQeaASDSDr+N HXpQIUE/pQeaQ8A/Slz1p6AKKb6UooxSsAZ7e1J3oxxyKd3oQw7/AI0D3pOc/jS96NBCdfyo 7mg8cU4LkUANHJpc44oHWgcmgYnOfwp3akpxoATHNLuxwPekBwTSqOfahIQHofpQO/NB5Y/S lUE0AKvWkbjpRnBpTgID3pgHuacxwOfamn7o46innmgBAoxn1NOU9sU3bkg09eRQmxCHuPal OOtHY5pDz0pX1GKCSOaROtOUnj60uAOlUhCd/wAKdkU39KdgbenNKwxCeR9aAOcUelIeop2A XHFITngUueOaRvvGnoAYx+dNzkDIzTgetNTB+nNT6AGOhPYYpCM07PJHtTKAFGc5NQzDcRip 8YxTHxxQ0BEg+Rf90U7NNX/Vr/uil6CjYA7/AI0Y3MBSHOfxpRwc96GAFdpwKM880ZzzR3Jo AQ84570Zpo+9+NOPagA/wpCKDjFLSGJSHqKUd6O9CEJnA47CjrmlxzSetAwxg/jR2oOc/Q0m CR1oQC9fypc8UlIelAC0Dk0UgyPSgBeAPwo70mOPwp1AAP60g6fhSg44pM80AHIHvQM55o7/ AIUp5FAB3pFP9aM80elIAJ/lQeKUcZz6UUAGaBxxRRQAdelBOKTgflSmgBR34pKAR+tAHFAg pc9RSY5/CimMUUmaDxj60o5oAByPwpc4FITzj2pSAaBCY5zTlPH50CjsKqyAQDLH6U4ZXJ7c Ui5yfpR6ipYDuOtDcikXlcdOaOPl/GhAOHKgH0pxzu9qQDP5Uobkg9KYApzmlQ88nNJ0II6g 0LngelFgHk80c0MOp9BQDmnsAijk/WlGc0Dg0ik96TbAceePalAIzzRkDJPpSE80bCFHU/Wm jLH86UnnFAODS3GhhJ3YPHFOx3obk8elGeSM07gHamqu1fwNLnBxSdM/SkgE5z+FIRgZNOPG PpSNjGDQAdqifPFSDIH40hHAzQBEpyq/7ooOSfbikThF9lFOHvTsAnQ/jSg5FITk/jRSsADg UnXP4UvQfhSGi4C96QnJo70DrQxgeR7UnXil749qB1NJAGOc+9IOnvS7qQ0wEyQMe1L1oFGO SKADv+NJ2pw570hpAJ39sf1pTwaQ+w7UpIpgA60Ug6/jQBSAXOMn2oPOaQ8KcdcUZ5P4U0Av +NA5Kn60Y5/GlHAoEIQfwpTR1pOpOaGMB1/GgdRSik43ChAKf6UdKTq34f40vemIO/40g7Ut HTHFAwI4/CkPOfwpaOpNABjn8aWk70ZpeoDsAoT6Cm05erZ6FcUhGP0oAD2oHAGKKcpHegQw 9c+1L0HHWg8mgdaLAKM0gPOPrTgMHjuaTgmgBV4fPtStznHqKb/CR7U8CgBBxSr8wpOlKlAD lFBGDxSfdbjpTiaYCE4I9SaUArilPBGRSK2Tk07CHZPP0pq/fNP4J/CkHJPFJDBPvn60oHHH vSg4NIB3pWYAelAJNB5z9KXFFrBuL3zSZyaDycD1pAMECnuK1g7/AIUdXoY8Zx2oXOWyeDji izQxo5Y/WkxzT+n50mM80XEB6fhURJZjjtipCcrx6U1RRYaF6U084p54qM9BSSAiBOxf90Up oB+Rf90UE0IBB1P1o70vFIcHHFAC8DmkJ9BR3xSnigBKO1J3H1o9qBh260oPXimn29KXvRsA c5pB1Ap/HrTaAD1+lJ3NHQ49qGHHvRcBc0n/ANejv+NIOcZ9DQAvegk5P4UtIx496QC/40Dr Sf40d+tAC/X0pOATS0h70ALnH50gPNA7/Wl6UABPp6UGj/Cg0wDqaAelFLQgGjOfwpecml7c 9MUnQmmAv+NLnik6EfWgngYoAT6UueaM45o4B6UrgHf8aOho7/jQKAFHJpP4vypV/pSdzQIV h6UA9vrR3oI4zRYYuMUh4pM0tADlz+tJ04FAz+tHFIQvb8KVcjmmj5h+FOGeabAUc8+9Ig5A pegoB70bBcXnFB6/lSn7vHJxR601fcQ4470gFJnkZ9acORRcYi5x+FOzgU0jqfalBxxTuwFO M0oODikIJI+tA/pQri1HAADg9qMH1pvXrTx6npS1AQDmg/exQp5P1oI70DAjK4FITgUA8/hQ xHekAZzx70nSlB6Y9aaegphYTH8qXAx70vb8KaSaVwGk8j60yQHjFSDnP1pjjIFVoBCo+Vf9 0U/6Uin5F/3RQMZJqBhxn8aAeRzQaQHI6VQBn88UpOaQDv7UdcikAA8/Q0g7etL/AI0UAJ2/ CkPU/hTu1JjrQADigUZ5/Gg9eKQC0h5/Oig8ZoAM80g69PWl9PrSDoKAF/wozzik/wAKD1qr AL0NLSZ/nRnpSsADnr6UHqRR0/KigBfT60nPFLRmhAHQ/hR3oFGOaAEHX8ad0pKOuPxpAL2/ Cg0e1IT29xTQhT2+tA6UUZ4oAOtHej39qODQkAUmaUUY96AFHf6UGk6Cl9aEADr+NAPHNBHI x60elCYCYyce1LikNO7kU2AgPNKPvUuMmmkc8e9SA4cNx6Up4zSA8fhS4yaYCnj86Fx3pF5b HvTu/FOwB2JHpSgikzzj2pcAik2AEZYfWnDj6U0cH8acMDjvRcAJwPwo4xQRkUoxjFOwCFjn 8acOlBHNLjikwQmaX+H8qaMZp2OTTVgsNHU/WlGcUAc0vSnuAhJx+FA5J4pTyKTpmgAIGR7G m9OO2DS9SaXBqeuoIbnj8KRsD9KCO9Dc09AEHBpCeB+NGfmHpSNyBQ/ICFeVX/dFL2ooqUMM UDjB+tFFHUBvRfoKXNFFMQhPKj1NHYGiikMP4T9KQ80UUwFHLAfWjvRRSAQdaXHWiigBT/I0 gPFFFAgXp+FJ1P5UUUwHUDgUUU+gxB2+lOI5IooqQE6n8aB60UU0Ap9KO9FFAg96Mc49qKKY w7/hR3oopLcA6UHiiikxCHn8qO5oopgO64pO9FFIA6Z+lFFFMYHgj60UUUAKDzijHWiigBc8 /jQeg/GiikhC4oXqfaiiqAUfepw4GfrRRQA0nn8KfmiikAA09etFFDABzn6UmP1oooQDqWii mAnYmloopxAO9LiiiqAbjk/7opetFFK4CEc/jS9qKKQhuOT9KZ/GRRRR0GGOfxpk/G2iikgP /9k/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGBAhwDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDucDNOGKYDntSd+9fK2aMxLpM27/7p/lXM nOa6aXmBweflP8q5xh8xqlruUhoBpy9aQUoxmlZ9AMHXRuuk+UkhD0/CshrdTncGyfetjWpA LtdzgfJ/hWQ11Apw0q7j717WDuoAc5ewtDcurEH0qrxWnqen32o3G60KKnHJqqnhPUWPz3YX 867dDRMqfSgitZPDNztAe9TIzyBjNPHhcAfPeO30I/wqedLqVe5ijAPNPyoPJArfj0K1iHLO /wBamXSbFTzET9aXtUFzmQ6xyB9wBHcVeEH2gGUbiSOtbyWVon3bdPyqV0QRMAigAdhSdXsJ 2sYQyIicDNVtxBIq/wCQGYjJVSetVbyDyJAM8GtacrmbT6CwSiMgZ/CtGxuN0hGc8daxQ+Dz Vq3uHhbdFtz6GtdEibF653NfKxHAI6/hVholeQ4XIHQVTF+rt++TB9VFWBMFUujB/YGsmWmi aCwkvY1s14aTCnB5AyM/pXoNnb2+l2EVvGAsUUahm6dABzXE+HNSifUisu2ERxk7mar/AIk1 uCSxa1trpGd+GCtnj/IrOSvoK4zVfHbxTPFplqpRSAbiU4Q/Q96oW3j3VUcG7t4JoyeTASSB j0Ncpc24uZmeWbEYxtiX7oA9vWo0t4oW3Rs2c561vGlTSsZ2k+p65aa7Z6hZicTRqmDkSEDb Xn/inUtSvNTkhg1gvY4HyRdDye/5ViShpl8tncRd0DYBp0aLHGEQbVHYVn7JJ3RS7MT7PFwZ AZGzwX5qXGOaQCjNa6DsEoLR8dRXR6VYeGbvRbe4udEHmOuDggMSAuT+tc9nKkV1HgbU7W0S 8tbyONlGHVmQHA+UY/Q1wY/mVNuLBFuLwl4PulhaPTLjfI+04c7V5q43gnwvb8rp27/fwRW4 NU017aSZCojiwCFUcZ9BTEube6gMsTZXcQAetfLRq4upLli3Yo5LWrC1tLCGCzt47eMvkKow K50qICdxAA5zXV+IfmEI7Ak/yrk7hFnukibpkV9DhaU+S0pXY+axrW008Y+V2Aq4l/MMJJID uOAD16VZe3Xa4VQBk4A7ViQYuNajXqIiTt98MP8AP0qqkZxejNIzT3Ojs2VIlUuNxzgE81cR 1D7Cw34ztz2rH0xBNqhY8iKJiD/3z/n8au6eFe9v5jztQKD6fNXVScmtTGo9S8pDZw6nHXB6 U4dCQwIHXHaseCXyYNTkJ5DAD/vmp7SCRdG2gnzZjvJPocGtDPmZoebF2kQ/jQ8EdwAxZtvb HSudayls0VpiSCcZz1NdLCuy0gT/AKZrn8hTs9w5pXsRLYQHu5pJLWC3HmHdkdM1Z3iJC7cg VkTzSzyFs4XPAqZSstS0VruVpHyegGBXNa1GNyyj0wa37klBz1rG1BDLaSY6gZH5ipjJlGGD T1NR55pVNbrXckmDZp46VCDT1NNrsLQmoFMzSg0g0H0oNNpVOaB3LNsN0mB1rcQHAye1Ydpz LjPWttTgVx4h2NKY9QDWdq3Ea5rRTt61n6t9xT9a5YL3kzboZB5NWbQfvlPpmq2atWo/eZ9q 9VO6ORrUvQY3dKmI5qG355+tTHrQAUUlLzQO4oNNZsGlprcmi4keuDp0pufrTyMcCk496+Yk rMVhr8xt9K51/vtwOpro2XKnjsa5yQYlYe5ouNCUmaKb3oVkyjB1y3We8RmGcJ/hWQ1vBGct EufUiujv7NZ7gO0jrhcYX8Krf2bakfNuY+5r1sNUSgNIyoHVSQpAHtVnfx1p82jHBa2fB9Ca z5IbqA4lQ/Ucit3Lm2KSLm4etGV9aqKzN3qVFOe9R11HYm+XFIVFAjJqRYzjkmhtD1I9vtQw JUip9gpREvrU3sSUvkT7wAH0rM1fY4jZB3IJ/Cte5sp3JMJRs9jWPf2l4tuxa1Zdp69q1hNC ZlHFIGx3qsJGPU0nmGuuPchF0TEdTSibHQ4+lUC7GgFgOpNN2GW5SJEIJIz3BqCKKOLO0c9z nk0wsx70qkgUtBWLAYetBbnFV9xoDGq5bhYm3ce9Lu5qDcaTLc/SgViyG5pd9VwxpQSam4yy jZOB1rQ8OXK2niaAzKrQuNjK3Q9x/KsdSQwINPtv32qWkbKXLzKAF6nhulROKkrMR66bq6tF P/EjtCpwNwIxTjPGLTz7pbe0dicICAMU/wDsKB0cTzThSxbAk6daqXuiadc7WuEeYRDagds4 /CvOtGF7ItMwddkVo0dGDKc4I6HpXMW+ZdRjA6bxk/nXQa/thtkVOFAbA9OlY2nLuubXj7xL Efga3wrvqRN6HTSv5MEshHTJrA0kMb2eY8kZP5tx/OtPUC0nlWyH5nYM2OoUEZ/nVGwwrXRx x5m38iK0qrS46e5f0F98t8wP3AFz/wABBq/pZJhuJCB88zDjtg1k6LOF026b/noS+fwNa+nD /iXw4wAcuefXFOj8I6u5lSRtNfm3DtteRQVH4V0YG3CjHGBWZp8YfVLmTGfL6exIrRZwvJ6Z rVsyitblK5/0rU4IMkpH8zD6YP8AKtYCsnSB5wlu26ucL9P8j9K1VOTS16Djvcgvm22+O5Iq iqcZxVrUG+4me+aiIwnAqH5miMm9PzYrPdQ0bA1bvWzJxVQ9KcbIDmZl2XEiEfdP9Af60gNX NRhxPuBAz2PeqYRvY89ua2TTQDwaepqLaR1U0oPOOlUkKxODTxUINSKaVkKw8GnjpUdOWnoG hbsv9eOa2jwKxbM4lrXDZxXFiUmzamTL2+lZ+qn92p7Z/pV9eh+lZ+rcRoAfw9a5Yv3kjToZ XQmrdvnJ+lUzV226PXppaHOy5bghfzqXvUcH3AfapKYhaM0Ck6mi6EKKa3WnU1utA0euDBNG aBHjvTtqj1NfL3ZLEJ+Uk1zc/E7/AO8f5mujLDBAUmsC8UrdSZXHNLUEyselApW5puPWi5ZB P9/gVFnPbFTybQ1RmRcYKGvQw/wlxI8c8GlK7gQwBHuKNoJyMinqMcGulNjsUn0+EncqYPtU RtCnbNauAO1GVHbNIDJ2e1Gw+grSdEfPyhfpUDW3cPRzJDKRjPrTOR61ZYFScg0wjcMbcU3L QWhECQTz+tNmzLCyMSQwxgn3FSGJv4cVGQ68kZAoiKxwBRkAU9QMGmkVb1KOeG9cC1ndTyGR CR2qlmf/AJ8rr/v0a7KctCWOFO7VFm4z/wAeF3/36NPzcf8AQPvP+/RrTmQrjsUtR5ujjGn3 n/fk0uLz/oHXf/fo0XQXHmkA5pMXnbTrz/v0aAt7/wBA28/79mjmC47FHSgR33bTLw/9szQI dR76Vd/98UOaBB0oo+z6ln/kF3X/AHxSm31Mf8wq7/74qeZdwDOKu6JEZtbtxhiVO75DgjjG api01U9NIuT/AMBrV0jSNTMzSy2jwfLhcnB60nJW3A7oyuzOuLkFhgZlqwkCwW4YmXzD2eTd xWHa2U9u5dyHPozE1qNeNKoVk244yOlefWjdMOU5/wASsRDF6tkfyqppgX+0rdFIISEcj1xi ruu2sl6YECOUGSSnbpVLT7F9OnMy5c7cANV4K8IWkTOL6F03sEOoTyzEBhHsj/IVQspAbF5A OTM5OfqMfzp80PmOWaMgk00Wspt2iiYAk5y3bpW9WSkrIIJpk1uhtdMWI4JZCOPUk10EZFvp 6ZH3YV/kKwhBJsjXcDt+8T3rQu5jPaiGIEEgKT6AY/wqKLsrMqpqP0R9z3JJyTtJP4VNqs5j tGAPzOcDH51W03Za3Nxk/IQACe/FErLcapBvYJBGdxZjgHg8V07mKUka9pELe1jhAxtzn6kk 1MrAE1AlzARn7RF/33Tlmtyc/aYf++qaZpFWRXvXDToo7UOf3Z+lQTusl4SpDAEYINSSH5DW TZZiXHzSGoSMCp5Op6VWc0ldgjN1aItb+Yo5UisUSFTXSXCebC6eorl2BSR1bqrEfkTW0bAW VmPc1MHVuqj61SU1IGrRJiLYWMjkkfjUgjXtIKqg8U7cOD3FFmhJFnYw9D9KBkdRj61EkxFO +0t0GPxFCdhNXLtp/rq1o84FY1o++Qgda2I+tceIV2bU9CwD1rO1UZiX61oL901n6s223Ga4 07TVjSxl+gq5bcCQ+/8AhVBHBbr3q/bf6pie7V60b2Od7l2LhcVJUcPSpOtBICnUnrQKAYtN brS0hFAK566DnPajrTUYMuQeKf1r5mdrjkJWFqf/AB9nr0rcJA71iarxc/8AAQf50kiSjmlp gPP+NOzScUWtRj2hlO5ZCDjp2qBopYuuCPXFX4wxGakyDw1dlJ2WhpFaGR5nrgfSlV93StB7 JJCSq4Jqq9qyHBH4iulSK0IwXJ6U7mmkOvQgihXJzkUc1hC4zRtzS0meaLoYpUEYI/SoWt89 DxUof1p2cjik2ibFNoyp6UmD6VbIPfFMKJ6YppsdisQP7in6igf7q/lUhXFNFNSfcQgLei/9 8inZYdFX8qBTsU+ZgNDSEdFH0FG5vb8qXgUuKOaVx2Gl26nFIXcnIxTyAe2aTAzxmr5xDfMc fxUoeQ/xUBeelKcL2pcwwEj+tLub1NNyR2pwPrUc4rINzj+I0fMepJ/GjI7c0m6nzDsBU9qb 5ZBycmpAfek3nsaHcBoPHAIpjRI5+ZAal3vnpSbmPXFEX3EVHsEYkoSPaqctjdICVVW+lanr nOfalpp8uw7HKz3lxbSBXjZfqDUkeurtw0Q+q10jqrgho0Yf7QzVCfQ7G5B+UxMe6cVpGcOq J5SimpQP1Yj60s9xHIm0FXBplx4cnjyba4SQej9az3tru2/11s689UGRWkeXoxNEjRxk/dqN 4kAPHaozeBCAT82M4Y81PGwn245DCt7aE2Ny1G2NOMcVbkceUcVAF2jAGRmnSA7MAGsXa4zP l61XYEnAq4Y8n5iAKQxr2P5U4gUipFYOr25jl84D5WPzH3rqhbFumfyqC80kXUJjk37T6Crc uUDigQO9PEgHVh+db6eFLZeCJ3HuavweDoWXdGlv9HfJoVSPcDkRcRg4Lr+dOFzF/wA9F/Ou vPhy2iOGit0x3KcVKmjQJ/DDjPVFFU5q1wscckysQFDNn0U1MAxydjAY6kV2B0pQMoM/hVWX TpFyApz6EVl9YhsFmYumkm4buMVuxc1VW2eGQsYtme46GrCnFc9aSk9DWKLKfdrO1g/6Ov1r QTOzNZOuSBLVSSAM81zxb5iruxkr8smfU1rwcW49zWIsgaQYOea24+IE+terFe7qczvctRfd qWooR8lSCqQrjqKSjv0pXGhRTWODThTW60ID1xcAcCl5pfwpK+XchN3Y0/SsbVgDKhHHy4/W tojIrJ1NYd6tKcDHTOKzc+XUFqZQGTwacEf0pDdW8XEaEn2Gaie5nfO1RGvqetQq05O0Ymqi SJOQ+PSraskncZrMQAE8gtVhGI9BXfBStqWkaAUjuaQkEYbmoI52HU7hU6srjg1ukgsV5bZG 5XiqjK0Z+YcVffj2qq7Z4IyKtNBYrblPSlyR2zTZYVbJX5T6iq5eaLqwYVSfcLFgt7Ub6ri6 jYYPWk8wdQaT3CzJ8896C1VvMOetIZG7U7tCLG4U07Tzmq+WJ5NOGBU36j0JCQvIoDhj3H1p gJoxzzVXBImzjng0bh3qDaezGlAbuaSSAk3Y6Gm7uetMPX79HTvmmmgsPGaDuzTN1HmY96q6 AflulGKZvBFKGJ7UXQhxUH+Ij6UAH+9n603k9KUfXmjQY8Y9c0u4dAvNM6HilC57mjm0sIXJ zSZzQFNKFPXOKSuAY+tJingH1zS7T6UWC5GAQadjFO8vuc0BWB4GfrQBEQfSjdt+8pb8M1OE J6ijb7Gm9QM6fSrC95mgAPqFAqonhuCCRWguJNo52Ma3Ai980pVRwKcZyXULGRPFMnIDH/dp ibzxJvGe/pWwBg9qGjV+SB9KrnuKxRS2GMxvHL/sseakMxi+WW2EfuVqQ2qMcjKn1HFRPFdR k/vPMT0JzRzMaSHrcIR8u38AKjebcTyKhZQeDCyH1HFM+xMx+V3x9aOa+47D2ZWBBY1TlRF5 WRgfY1fj0pn/AIifq1TjRVI+bZ+LUIXKY41K6hG0PHKv92XmmHWJkJYpbJn+5zW+uj2y/eWN vapU0+2jbIghz7rmr50hqJyUlxe3pOy4mUHj92mKZHBqkB/4/ZmQD/loMn867fyQRhVUD0Vc VBPYM6kbD+NTzx7DZy7zyOAjxtwQd7GlWp720ktZcSMDnkAdqgTqKlxT1QK5YX7gqhqs1tBb 77mPemcYxmr44GKyfEC7rNR/tVmnZ2HZ2Mr7XaTuRBZNER/ERitdeIoxWHAmHz7itxh8q+wr 0YXsc8rlqH/Vin0yIful+lS4q7koSloooHqgppHNOppPNO4Hr1NJx2pucdDTGb3NfIOTZI/c D0rF1tVLRFgD1xmtTcBWNrj/ACRH3Iq4q7KRnBgOBgfQUpI7kmqpc0m416UIpI2RZ4HYUbgO 9Vt5FHmVSQy4svvUi3A7ms/zfTik8zJ60OLY0af2sdDyKbvSQ/L+R4qgJKXzR61KdtGMtScA 5qpIaX7QAME7qiaQN0NVoIikjRu3NRYdOQCRUrGkDH1poARw3Wn7WP3elRMAxzQPMX7p4p8o 7EuCPrTeWOMUizZ+8KkBDD5TmpaQrCKrDripVHqKjzjqcU0yhfWktALIAp20elVYpmc4CEe9 WgabfkA0xI/XNM+zKuSCx9iam5o2n04p6MCmRtPpSgc1b2qeqA00wAjinsIgCg9qXFO2MnUU Z9KExXBFJ4p+0U3NPAXqcmqTQxNpzxinAeg5ox6UHNJysAoU5pdgNMTOeafn0NF0wFACjil5 +lJgHrn8aTcnQjFO1gHdKQlvbFG0dRxRnn5jxSQC8mk+7yxAp/0o2bhyvFGzAavI65zS7Rnk c08JgZpdrDrim9REW0Z4FKCR6VIqZPOak8lQMjJpOLArHbjnJNKq56A1KYwO+KiMWc7XY/Q0 WYxrKC3IBpiIscgYIDznFSiNvegIfSmo6AmXIrqyJw9qEPqBVlRaOMoqGsvyxg54pNo/hOPc Utg1NRo0HSMCmkD0FUEknQ58wke9Si8bOHQH3WgVy0CBUcrcHmkWdG/ipjnihtIDnNZbddfQ D+lZ6DkGrmpNuuH9jj+VVU+7nNVzWRRLWXrZxbL9a0xx71l66f8ARV7c1MLc2o76GTD80gX1 YD+VbD8YrJsV3XKj/aB/lW06rjJIFektjnbJ4/uCn1Ri1O0IwjtIR/zzUt/KnpfSSbhFYXTE DqybQfzqrEouYxSZqLbqDc+XBF/vtkipRZBlzNenJ7RCmlfYY1mAGSQBUDXcCnBlT/voVaSw tyciC4nYdC2SKkGmXDgMtkoH0pWtuB6aWpN1NLc0mQa+SaaVyRc1ka9/x7xtgcH+lahNY/iD /jyTHPz/ANKqDfMikYhlGaTzRVfr1pOletGF43N0TmbtnmkEhqDjPvQM+tICZnPambjTeaMk HmqSGO3nvS7xjrUXVuBS4NTyoEP3jsaTdTOfSl4xzVaALuYVIrZFRBvRTRyBnpUNATGgE1D5 hHUE1KpzVK/QLj8A9qURA9DimqMt6U8ZB9aTTYEgibHOCKVIIs8Mw9iOKdFIc4q0G3DBA/Kl ytAQ+UF7flTwqnrn8KesPdSR9aDGFPII9xTu9gGCNB0JP1p6rinBARkYP86AwBwaegAqZ7U8 IO4xQOeRxShivrT0ACoxjHFQtbRscjINT7w1BU44pcoik9syHn9KjIIIGfwNX/L96UwRMPmT J7HNLYCkAT0pwXGRkGpmtRjKvj2pnlleop2AbtzShAB2zTRgHrxS9+tSvICUDjAxTWVSelIO vSlKCmmAmEB70oUUBPelCEjvimAcg9OKkUFug4poA/v4HcUoZQeH59jVJgJI7Rj5Yyx9KVbh s8xD3p29hQGVjztFPRhsOS4EmR5BXHtTuo44oLAj726mgnqBSfkFhcHBzzSHgYxgelJl+4pu x/f8azuxDtzDuKB8x5FIIueaf5fII7Vad9xjGjx2JqPAXquKsBTnGTTJFVD87AfWnsBBIA/U 4phyvA5FTlJW6Kmz1zzSeVtHH6UlcCvhSelPUEZ2sfxNOMbE8Eim+VJngj8aNAsZ13pbzB2j kUOx/iPFZ/2C7hzvQMAeq10O1h2Bp2PUfnTQHNFsHDAj68Vn6tGZYVA9a7NreGYfvI049qzb vw7HcqTDdmIjop6VUWrhc4+yhdJs7enata10y+1dykCJFEh/eySnH4AdzU7aPqNi28COUqeC lX7XxDNa/u7vT1CZ5Krzn3ruUlbQxkmVBafYiIIhCoQdIxUysypufdt9K0XXSdYAaGdrec5x 0HNNOg6tFwRFcwdirc01LuTYhj1PToThtMa46ZYnIrbt/EmiIAp01YT6+WDWTcabAIwVhu0k yMr5WQKpyWrIQsVjeyHqdsJNDT6DsjsVvLW9QmAxhCOiAA1Rm0izmk3+ZcLx0V+Ky9O0XUp5 UkS1mtQOcyfLXUiwYKA8ybsc4os+oExPNITTMjtSFhXy1nbUELk5rL11j9g5/vVoZrM1r5rB gemRTp/EM50kDvSjB703IJ6UEmvUjOy1NUKT+dGeKM8UnOeDTTvsMcD7UYpvJNKvNNysgFBA pcimFfem7Rnqc0lK+4ySj8aYBTufUU+ZCFJH40YOKQEk08KTSvcBFpdmOnWnhR2oAxS5rbDE BK/e6VJG4foc0AeoBBpyx/3QB7ChTbdgJVHtVmPIqGM44IFWUGaq/cZIjA/eyDU2MDpkVGqj PWplGBx0pXQhqwrIfl+U+ooaJlPzKrj1HWpAobjH5VKsbL0o0EVVjDHj8j1o2EfwkVd2huqj PrR5TA8HcPQ0tOgyls55FKEI6VcKg5GAp9DTGi2mmhEAXqDSiI4+XmpOB1pcc9ePap6giIRn PIIoKg/wk/hUwbI9aQn3p6MZVa2jY/dxUMkLxHhMrV4nFNzwepPoaa7IRnBxnA69/anh89cV baONwcqA3qOKhNi3VSDScXYLkOT0wKA2OOaRkMZwetND5P3DQr21Ak+UjleTTWAXkCnh2A6A UYVj1zQgGI24U4quOVJPbFPxhe1SRqCM459zTuBCqY5HHsakXd0wc/pT9hJ6CpQQBjgU0hak aq2RyB7U/bkU0uCcZFJvwKLDHhAo5oBx0FJvBHOaYZCBncAPU1NwJgT1x+lRMA5IYA/UUi3C HowJ9jQ06fxE5+lCkA/btHUY9KY00asFbqfSkSRX4U5+lOKQn76hj6VSbGBRWGQRim+UOxzT lWBemQfSnKinOS1NeYFdlwfWmlKtFaZtycU2kIrMgzxkGk2Ed6nZcHnNMZT/AAis2gI8MO9N eGOTiQLg+1OyMkZ5pNo9aalLoFjPn0iyc5hYo46EcUWseqWTAQX4ZfSZiVq+cDnYM+wphfgg p+YrSNWSE0jqrOcSRL88DvjkpzzU5kmz98ge1cUpZTmNmTH904qaLWNStjxKkqd1YHNbxrrq RydjrSzn7zsfqaYcetYkPiq2ztu4JYz/AHgvFaCatpkq7lvYQPQsMitlNMmzQE4ptNJpM471 8zqIU5rN1jnT2HuKvE4FUNVP+gv+FOMfeuNGATmm04ge9N/CvSitDRByTilCnNKDxRnmqduh SDbS4o5pMH1oSY7gBnpSlcc0DIpQMmlqxWEAJpSlOC+pxSMyKRuYBfVjRZgOWOnbSATg59Kb 9qswPkuct6Cnp8/IJNFwFC8U4L70oBXpTggOOv4UmxjQnPSnj5e1OCketPA9SKpLqIEwf4fz qVYyDkMfpSBc9DUgyMAEVAyaNuPnXb71Oq5GVaqyj1GakTKH5fypjLaAk8jFTouOlV4pQ3Dr t9zVxMdjkUXQrChVPWgwkcqakADdRTgoHandpCKTFckSA/jTShx+75HoavsquPnGaia34Jjp XAo5XOCcN6Gk2n0xVnZgEMoJ+lMMT9UIx6GmgsRNkjrj6VGQx6Gp/Y5Q+/SjZgZH59qW4yts PvQAQasgDuPxFBC9qaWoEOSRjHFOErIMAA1JgAcUzYO9DbBEZPmtlwB+FRvZK2WQ1Y2gUDNA FIwSDhhx7UxU2knAH41pbiRgjNRPAknYA1V0BUyF5AzSiT/Zp7WzJk7cj2NRHHOf0pPyAcWY c8UnJ71F5kYJX5gfelVRnhs0r9wJVBA5xTgB2Jz70zp/9ejkngmhvsIczMP4d30prbmXG3j0 pQuD9404Ek4NOKutQuQrCitwgz7VZWCIrmTP0pVjyeQabInBUk4xQuwCeVBH9x9g9jR+6P8A GG/Go/JXHytn2qCW1m/5ZRL9SaWqBFwHb91QR704S56AVFDGyRgNksOtSqUH3kz+FNX6gxQ5 9qbtSUkF8H2PSnkofug0w7M5zTuIcsRjAAYsPU011BUnnim+aegzQJMdWA+tO6GRFV74HvTG QjoeKkfa/wDGg55zUJmiiJHmKfqalvoAAbaZu56CoZL+2Q4OWJGfl5qD7f5ikxxkDtu4ouIu nJz0FQuQn3igH1FZ5nlfrJj2FMESu2WZmY84zTS7AW3uLZThmz7CqEhsmckWp577RUyxqrfd AHrSvChb5XGK0i0B1pfk03caYW56Ubq8XUx1HE1m6vKq2hjz87EYFWrm5jtYjJIcDsPU1zss rXUzSsTk9s8CumjBt3KSGjrmg/Wl24o/Ku3Y1SQgPrTvwpOo6UoyPTFF77AH86WjK56UZA6C nfQBFHNLznim5zT1PA9ajVbDH9ByAaUxxSD51Vh70YJ60CH+6QKGwCO1twQUt48jocVOBjjA H0psaMB71MF9MUCE209UHQdaQLg8VIoDcKCT9KLdQDygOpP4UbQKlAYDlfzpCh7ind9QEUAZ 5p4UngHFIqHPC1IFwai6GKoxwOacN27GOKVQTyykfSpBkdjSeoXHqy4wwB+tSJviOU3Pk9M8 VCoJ7fnUyNgYxmlZoaLkUocjJ2n0qztHU1mqfXAqxHcMpxnIobfULFvHrQFIPykimLKj/dYb vSnhsGhNiY2RQ3DD8agaJwfkORVliGX735UwqSKLgVCQ3ysPrkU37ORyh49CavCNCMOv4imG 2IOYySPStFIVioYxx82w/pS7AOoI96kOGJVl/Ok2ug+Rgw9DQCY3apGcZHrShAewIpNyHg5Q +h6U0o45YY56r0xT3AcYo3HGB7VEbZhyh/OnEZ6cj1FAPBAJP40roYwLz81LsBpCccUbiOgo QDtuOO1MMEbA/Jz0zS5LHj9KcCwOME/SjfcdipJajsAarMuw/MjflWwoxyEOac0qfdkhH1xR oxGIHTpz+NL34FaUlvDLyq4qpLaPCCw5UUMRGGoOT0OKZ5hQ84H1p6y/7uKLgLHuAwZGp5Jx 1NMyWPGKQggHLmi9wJNuBnFIG9ah3HOWJxUT3UIBzKq496GwLe854bFMZyOnJrIXWrOWESxz BlYZBzVG68RxxqRbypv9BzQm27Azo/Ml5+XPpUUk21TuZFPpmuMn167nyEZ1z1PQVWe/u5OD OQPUdatUpvYlSR2Mt+kPDOOmcg1nz+ILRAdsik+mcmuVO9z88sjezNSiNR0UflWsaD6hzI15 tf8AMBRIpCfXoKpvqNw5+UKB75JqtgUVtGjBEuRYh1C6gbIZWz1yK0LfWYWYJNlGI5Y9Kx6Q 4PBGaqVGLFdnTefAR+6mV/pUiB8gs6onr1Ncwm6PmMhc+lWEv9oC3AZ4geQnU1Dodi1I0572 BDhriMfU4qD+05cAwWc00eOHRMg1d0y78NSsvk2yi4xwLgDd+tdGsV8yg28MaxkcBRgURpLq S5Fgn2pjSLGhd2AUetKzqil2OAOpNYF9em8lwAyxITgf3vrXhxp82wJXGXd095NvJIQfdXFQ jPbijn2pa7oQUVY0SsOHTk0U09OKAG71aTYCkHsacpx1pMUBc9qNgFLUin5qXbigU3dgkSYF Kqc8c0IrGpVUjioYwC8U8cfw5p4TPepFjIpKwDA2Oi5p4wT93BpwQntTiHXqtO4AiHOCwHvU NxLcrOsdsu8Z5ZRxVuNQev61PhhjaVCnqBTvcRlxT3IP+kWczn/Z6VbgS4MhYjCY6E1cBboO frTuSOFzQ12BJkLDA5I/ClRTnhc1KFwegp4BOePxosmCGAMOGBz6CkCsXwTge1SKQD0ZhSnD HIGKmyC7E2sOFOfrSAMDzihkA5J/WkKrjO4D8eaW2g0SKwJ5FSLIg+6cnvxUKIo53H8acZDg LsH1pASMWdgUO36VZjmZeGOaqqwAznmpEfGSaVhl1GR84I+lPUYJ+YfSqSsjD7xH0qVZypHy Fh0yKVwLe0Gm4K9BSqwIyD+BoJJ7CmmhEZKudrLg1G8DLyh49KnAz1GKYcqeBindCK78jDoP ypm1xyp49DVvIdSGFQPAQcxn8DVXuGxXZVP32MTe3Q0ggkye4PRlpzFgdsifmKilgllhZLa4 aJiOucVOqQ9xZZrW0Tdc3cCj3fBrNl8Q6eBi3iluDn7yD5ayNQ0mSzPmTWMl1yPmQbvxpLby 5dojQISfuHgjpWUqso9DrpUqct2XZdcudgdI4bZCMjzeuKztR8XzxQstpPbvKv3tpyP88Gop 7NrqVme4SQ4A2PztGBxj/PWqx01ogSLS1k9sYNa0oymrtiqOENEiKPxbqDHMpnAJ6ircfiub Hy3C5/2wc1X8qcffsAo9jQLezkH7yJ1bPdRXVFRWljlcm+pfXxVdpyZLY1HN4/e2B8yCKbHZ Bms+TRYpwfJRH46d6y5rH7M21oSuPaqcYS0J1N+P4i2LuBcaPdKp6ssef61q2Wq6Hq5H2O+8 mRuRHKQp/KuMRM9sfWmS2drI26QYcdGXhh9DQ8NC2jJ1O5v5LywBP2d5Ix/GnIrnZfF8TOyL cLuHG1Qcg0mmeJNU02SOJF+02QyHWbLN17VsXFtpviW3LwW8MF1gHKoFYd+azVLlfvFJnNya 5ePI0iszA/dDNjFUmvb+c5llVVz91B1pbi2ns7h7e4Xa645xw3A6fnTMc1006VO10iG2R7EK gFcgdu1PTCjCqB9BS7acBxWqgkFxMk0ozShaXp3p6iuN5p2aSg07IBwNBPNNAJoCNnnGKHoI UmkoeSOIZkkVR6scVB/aMRYrBFLcsBnEKFv5UadQLKqTThH3LAU+10vxDqrrHa2iWoY4D3JI /QV0dp8LRIN2s67NKSc7LY7Vx6HIosnsBx095p8J3STRb19CNwpYNd1sRD+zodRltjyrFGP5 H0r1XTfCHhvSVQW2lQTSJyJZ1Dt+ZrZBRRtWCFQOgCcU1bqI4a/vxeMY4mIhHUepqmMiowcd KepJ5J/KvIpwUVY2SsOHNKBzmhSBSk+1VyJsYowD70oOT3pvJ6Cn5xVqy0AXHNOxxTQpzT1j J9aQC7CelOSLnqDUiRseOtTrbkdsUm7AMEfHWpFiPXFTxwkdcGpBET6fQVN7jIliyO1SxxDu ee1SKpXtTtrFgSvTnpRYQwRHpUix7RzzTg5A+7n6DmnEMVx0yKNhkR4/hp6Z6lCBnrUvl5Tj r60wc/Ictz61KYhBJhjhD9alQkjJz9KQLIp4XI+lDMc9Pwqo2WwDyy9FAHu1IVJwScj2pVYn hkG33pZfM2fuiqn1J6U2wSEOBwFY/SmAOT90Aenesp9QuDLsVwB0ye9W4JpShLOuew7Vm5DS LMjjkKMexqMNGoyRz6mo5JYT3LSf7PQVAwYjJOfahu6AtG5HsR7Uearc9DVZEUGnME/hUlqz sMseevRnC1LHKHOAcgVRSAyMGMWSOmanUpG5GME+tVsIt+YoPANSi4Kj0rPZnYfKSB7UwMR3 JP1qW10GkaaznJOcVPFdk58xlxng5rHyx/i/WnouDkjOaVxm8rqwyp3fSgkeh/OsuGZoz8vF WDqEaj978vvVqQrFvI980wkimRyrICySK4/2TnFBbNaJokViD94ZqMxjquKcQuMLmojujJJN Va4EiuwBVgCPTFV5tEsbtvMVDHNkHcOKmEg/iFMkLYLxscDqKia0HGTRyTeDn0l5XsZpjI/J aRy+4471mytr9mT5lrDMoHWMEGuyl1wxpt2I3HGeaxNU1K7mhJiQRk8ZPSqhUdrNFM599cue UnsZIz0wRVNnM7FlZ1yc43VLPFLM26aUsc9AeKYE2DAFbxMmRpd3EDgpIxx2zWtbazBcJ5Oo xLsx9/uKx9lJhSNpAIxWvKmtSTZvNIMUfn27Ca3buvJX61mCJY5BuXIJqfTtUm02TaSZbZjh 0PP5fnWpd6fDdQi7sGMkbcso52/5zSu47juUUVAOMU8FkcSRMY3HQrVVJxEcOPzoa6TPBFXe 4i9qd9b3+nFLmA/a0/1bheD9TXOEEHmr7XQPA/lVeRUfJGc01oBCDS7qPKIGScCkMkSDJYGt 9LCsOBJHXijaTUTXa/wiojcOfYVDuFmWvlA5IphmjTqefrVPex/iNJ1quUWpZa5z90VG0zt0 bA9qjxQeFJ9KtLuM6HRPD1hdWiXt7C88rk4DnKgZI6fhXSQW9vaIEtraKEDpsUCqukqY9Lt1 /wBnn8zVpsn+L8q4K0m5aFxRf09t14uSWI5rfz65rn9FX/SpDgngc10KKXIUAn6VrRempMgz TSTmoYL20vN/2W5jm2NtYowOD6cVLgmugk88A68GpFXPpUojLcKrE+wqWOzmZsCM/iK86zNS uFpSMdAK0k0iVuSwHtmp00q2jBLlmb0zUuVhmOq56n8qnjgeQ4VCfqK2I7G3HKq35VOYUTGA c+wqeZPcZkx2UpABTBq1DYfNg5FXgDjA/OgREnJfP1NPmEQG1Ef8S5pyKD05qbaD/AT9BTyN o4jAFZ69QuVwGDjIGKk7fLjP0o3J/FRkDpRqPYdsK885PU0bcckkUgbI7mk2NktUiH424wwy acJCBg7SajAHoc0oKg/dOatD1DLyZHQdgtSLGVHC4puWfgHaPakbeo/1jEUhoCzjht2KhdpC 2UU/U09mAXqSxqIs/UcD3pN2F1J4pZdvzR7venSSSbM4X6AZqqkkrNw2R7VOJCPWnzXGU5YY XP3F3UDAGAOMVaZVPOOfWq5Tb0PFRLzECtGRwOac0qqORTQ6EFePw61G4fqi7j6GhLsFxxdW GBxmnRs/RQD9aiVu7oARUnm7lOBgAdRSuhpljzGTOG59qiZxJ98gc9T1rPl1C3i3HztxHYVR fV4Dy7BBnu3WptIVzaVto++WHvTvMwOCB9TXK3HiWI8whmlP8IHyrVSbXby6IyAuBj0q1Sk9 kF0dpLeW8MZM7rxyAp5P0qm+uxhcpCR6bjXHmeSRtztlvXNAk5ySSfc1vHCye4ubsdK2tzyM cYUf7JqpLdTy7s3EuCMEZrLWanC55xVxwyTJ5i1YS3OkzSTWc8hZyCySuWU102n+Lradli1B TbSnje3Ck/WuSE+aHWOYYkVXA5AYZrR0lskK7PTFcSKHjdXQ91o3DOGGfrXm1pqGo6VIHsrg tHzmGQ5H4eldNpnjHT7+QQXX+iXPQiQ7VY+x71nKnKI0zoyM9BUUoKxuRkcUo3kB42V0PQg8 VHcOfJbPXFYsDmyrnv29KhuVdYSWJP1q2XVR1yfaq104MR5rWCsi7Mxmyc0zbUu4Fj1x9KC0 CsoknijDHGXbFbJisZjMMkUijc3SlllgLsYWEqjo6chvpVY3UgYgDC4roijNkz5VsdKl0/VZ 9JufOgkOM/NGeQazjIzk5NKkTv7miUU9GCsdsq6d4iiLxslrebeEbAB+lYeoaRdae5MkOR6j oay4Z5rZ1ZlJxzkdq6ex8S74xDcBJUx0k5IrCScNtgTRzhkC9YyDTWuR0VST6AZrprqPSpju hDIx6jAxS2dlbxfvAFLHoSvQYFRKvGK5mdFKn7R2Oeit7ub/AJY4X/bqX+wYpTumdlPonFdM 0YbsKb9mUnpXK8x10PQjgoo5tvDdkTlJJkPsaj/4ReU/6m5I/wB/nNdWLdF7c+tLlEHBH4VK zCd9DT6pDqji5vD2q2wLlUljAJwuc+tUNw3MhBVx1Ujkf5xXoRuNowDn61k6hpttfksQIpCM bl4zzXTSx/M7TRjUwtNr3TlecVC8yb1j3ZZjgKvJPB7V0EfhyLfme5lcZzhTiteysLWyGLWy jz/fZct+ddU8TBLc4vqk76F61RltoxjHHf6mpGDY5P5VIjsVO9dppjNngAmuKU1J3QpU3DRl vS7yyspW+23aQB/ul2wKhudV1DxRcPp3h7da6erYuNUcFdw7iI9/r0/SuX8Tok8UUUqhlDhs EZ7itHwjr2qC7j0xxC1oc7CoIK4Hf9a68Pdq7MJo63R9A07w/Zi2sEfHVnc5Zz6n3rQyaQHj OKXk963IRSMKL9yNF9gKQIAOWH0AqUkA8tQCh+7k15imzVFZoXb7pIoEJUdMmrjPnk4A9BSn aVBA5pBcqAseg5qVYWxhnDd/pUhQ/e4+gFJls5GFNKyGRbccAUmzb2PNOeQA/NwaN+4Y28eu am9mGggeZQQCAtVWkm3ncSF7A1aJGOQaY8YkXgUuZsCCOVt3CA49RUu4uSTgcU0JjhWINIUB BDupHsaExjgOMqaA7j2+tRF+dqnilU4HOaQDzLn7w/KgOfw+tN3ZHGD9aiJIPancCwrjOEQU 8gEZD/N6GqouMcYGfakMhB4BoTAsMobgEg9zTHQZ+bLcdM1EZiBgimPcpH80kioMdz2oYIm+ VMgDaKiM21uMsKoPr1hhtzZI6e9UZvEtupHkKpI7nmizGbrTM3AicfyqF7nYvzsMegNc1c+J 764b5fu/lWZLqF3KTucKPY1XsZS2JbOxF1bq+WkA+lV7rxBZ25xE5ZvrXHu0kgw0shHpupoU AdK3hhns2Tc3LjxO5kEkUZdlHCkfKfrVCfXdQuxyEhB6hSaqCmnNWsLBMakPaSWQ/PIfw4qP y0zlgGI9eaM4o3Z4rf2dloiWOAHanZxTVwKUtntTVydRd1G6m9etLgVSuhj1YL3qRZADxVcD rk5+lHOPlFF0BaVjmpAxHUiqgdsYJFPUc9zTSAshwe9Q3FvBdRlZo1ce46Uq9OSBSmWFQdxJ PtUtMCWy1rWdDbNvJ9stcjMEpO4D/ZP+NdJa+OtKvrRvtYNnN0Mcw2H+dcg9+iAhFUc96o3F xHcH97FG3PdQazdGMgUjqLjxTpUAKxFp2A4EQ3ZrIu/FN1NE32awWMEcNN/gDWQsiqdsYC+w GKSVsLl3X6A1SoR6l3vsE11e3BPm3RQf3YuKQeWU2yqZSOjSHcR+dVmkyTjtSKxJ/GtVBdiG zVtcvGEjCqnIwB/KrgtllK2wYxzuu5EdcFh6iqVqzxyLsGT1xmuz/wCEsH/CNvYSaPD9pRR5 VyqDORjAJ6jofzqJy5SUzhoJFluZoFDCSI4YMMfjV8RuIuNwYntXWa54ig8UafBdnTbaweHO 5YwATz3PpxWVpM1vBEt1cKHMjNtjbpjtUwqqfQooWehXU7Ah5MdOeazZne21GW0dGZozgsoz 3P8AhXXHWJ5If3EBWNULFguBjFcxay79XlnYgmUFSSPc1pe4IITLNKipPgblyCcZGRkfl/Ou mjkCgYcfgc1yAsdQmuJIra2lG0gb2G0dq0Lfw3qBOZtRkjGc4Vua5cRSU1a5vRrcjvY6NZx3 NTRT4brWXDowhXm7nfHdmzReSLp9s07MzBcDFeZPC2O+GNvujeJ3/wD1qryRY6day7LUpLzI twTjqT0H+cVbP249BH+ZrD6vNPRG31qHVk6W5f7zce1XLbSGuS3kx7ioyST0FUY11BBuYRFf QE5q1ba/a2e9bmGXcRjg4FaOEnpYcK9KT0ZIbZI2KlRkcUpCRrl2VB78Uttf3N05/s2yEzt9 0yqdi/jRcWltY5udaulaUt8kEY3MTknCr3/+tThQqTdrWCpiacEVTqNpnG5iD3xxUpcFcp0N LDpV9rZSSaIadpwAZEA/fv8A73ZRx0/lVu9iSKURxg4VVH5D/wCtXdHDezjqedVxKqdDjPET N5sYPqCMfhVnweC2tIfRT/KqPiAP/ab7+AMAD8FrR8Fj/idfRCf0rtw60OObPRB05o3Yozgc 0wtzWyIBApJwoOPWlPQ4VR+FQJdIemD+NS+ar9f0rybWNeZMRAD6H6U4uSCBxSAEH5eBTTtj G4sSTQxocu/HXNRCIrIX3k57GnpICDz+dO3bjwo+oouAwru6qCfSjCLjK4NPLMOFAz71GzAc sATU2EmOYr0IyPaoGdVHQ49qc0gYdvwqrJJtbBOF9TQmihWG8HqBULBV6VDLeW6HBnGfTNUp tUiUkDdyPvdql67AaCN8/Bx71OCMdN2a5mbXFUcOPwqlJ4ifgAzNzxtHFUqcmK517MkYJkdY x7nFUm1jTvmEc4mZTg7CDzXIT6nc3GQxyCMZY81VRVjBEYCZ5O3jmtoYdyWoNnXXGuJGDt2K PVjzWZN4kumyq7SOgIHSsPYpOTyfc5pwwOnFVHDoXMXv7YvSg3Nlu5zVR7iefmaQnI5GeKjo wa1VKK6C5mKQG6jNNAA6DH0p1GK15I20C7GnnvRjNKeKO2ark0FdijgUnWk5PSgAjrTQm2J0 pQTQdopAwFVZBcRgcUgXHenEk03NPdAAHvT92BQFJHGKCnrxSWgCFwPajcSehpT5Sj5m/Woz coDheaYEgDZpQpzkniqzXp7CoWuncEFuPShWGy+ZI0ySw4qFr0fw1QLFqQGnYRaa8Yj0qAzM SfmJpmOKTFFguKzE0Kc0mOaUAZpgL5ZPSoZImGTkmrCEqwIq5FAlyp2kB+4NS3YDIGR75NT2 0RkmUjoDk1NdWT25LEcZ59qu6RbkxNIw6nj6cUc2l0BJFEysDjpV4KxXrn2qRYhjpUojx0rn nLuUokE1qLnR7m2/1eWViwH8Pf8ATNOt9WsIWSOOFZ5FG0FhkLxirNuoaRoyARIpQg+4rmni NrdyL3WRu3bJog76A0XtS129u1a1iAghxtfAwSuOg/Os6B/KYHptGa05bBrvTRfQfNtyGUDJ HX/CsckYPbit1GyJPREffGGHQ+lGzPbNVdFn+06crYyVJU4/GtIJg8HFcVW6kXFEGzPUVVvL a2mgMUy5B96uzSeUhOR+FYt5NI+cHnsKx5tdy0S2kSW3yQqqox5x3rVReKyNKQyzc5ODyK6A IFHStGna7EMttjXIWbIiCkkr149q07250/S9MkvHs1kRF3YZMk1mWwZ9TEanBMLYPocjmt4x QrbBboxlFUbjLjH1Oa1pRVrsiRWa5eZLQwA2omPRRjA96xNGEieK9WjuZUuTbFfLZxkrkt3P tXSvNBCY1wG3/cKjIqvJJbm4kRoI4mDZ3qMmQkd66Fyom7H/AGmaRsmSPbnpHkn8az73P2lv w5q7H94YDhfTG0flVK7b/SG+orKq1YIvU4XXTv1KU5zgrxn/AGVrV8FJ/wATKRvRf8KyNRIm 1K49iOP+AitzwSp+1XRx93jH5U6LVipo7fNJS5pCfatiEUksWgY/OrD0qcYQZK80+SURrkkD 61Vk1GBOJJo19s815Tq3dmaJIsebwACcelO3buOtZE+uWMYxHvc1SPiRwCQkaL23HmotqNHR EEDpge9NMyp1kUfjXH3HiOU7sO7+w6Vly6xcOSQpz7mr5JPZBc7ibU7SJgfPDN3wc1nT+JLZ clUJVRkljiuNkuZpRgtsz/dFQkZ+8S31q44aT3C6OjufFCyMTC5RP7oHNZ8/iCaUbVVse9Zg AHQCj6VqsNFCuTvf3cneMDvxk1A0kjZ3SufbPFJmgCtlGEVohXY0YJzgZpdwXqwHOBmlKZqS Joo1IkgWQk8Fu1WhXIj7H9aVSaNpz0Ao6dqa1AWmg+lP7UgUdvxpKAho6048UdKAaewxM0Ak df0pDk5wRTQdp5JNDv0C5JuGKDJkADHApnL9qd5ZIwDSXMA0v7gUm78af5ar95qDLEvvWiEM IZvujmlER/iNRNd+nFQvdMQRuqrCLuETqaa1xDH3yaz/ADWI5JP1puT9OaSQy496T91cVC1z I3VvyqDBpQuBRyiFaRmpvJNO280uKaDUYFpQtO6UDkZpjExRjNLjmgsi9WAoAbnFNyakSOaf AigkOehKkCrkOjXDnM0qIuOi9alzS3BJmcTjrxSI5dtsaPIf9hc10MGiWaHLlpD/ALRzWvb2 sMQAijVR7AVnKtFFcpyttpepXOCkAjBzzIDn2rVg8LvuDz3cwbjIiO0GukRcLUgB7VhPEPZF KKMW6sMZYqWXPQ9Kjhj2jAUAeldCUDLhuRWfcWhjy0Slx1IHaoVRvcLFTbSgUxJlfjkH0Iwa eSAM0ndvQEAJRww6gg1ka6nl6rI3RZMOvpzmtNmyetV9UzcQxZAOwEdO1aQeo7Io6JrA0y+E cuTazfK47A/5NWdf0U2bm8twHt5VVht56/8A66yjaRSgqZCvtW5o94ILb+zruQSwMAFkY8g+ 9diaZi1qZ+ha0NLnaCYH7PM4O4fwt059BzXbRSJcIJIpA6eqnNcXrGitYTOQheJyDkciqVpe X+nuGtJsID/qyTtxWFWlzaoqMj0KSMMlUjpyuxwxBNV9K12O9Cpcny5jxzwK21RScg5HqK4p Q5dzRMS0toraPaiAserGpyKeqcUMvHWluMzbWdh4iYKpIjtWbI9dy8fWtPXLK81fRZbS3Ubp V2nzDgDPc1VsCkevO5YKqW55JwOq1f1nWRo2nyXQhNxIFysa9WHHT8666duUzkS22nfZrSzh MrE264JJzk05mg82QJC5cHBbHf61FBqTXIs5Nhi+0JvaNx8y89MUgjuIjKWT5Xcnnk4zWtu5 A+MEuFUjryQdx/OuZ1jXIra6ljjDNICV4HAOa6SMqGUnKkZIH3R09K85u5ZJtSud4AHmtjjt uaplCMi4lfez3Mkj9XIJ/ICuu8Hx7ZLpvUgj9K5FxtYH3rrvCc213jwDu5z+AqoJRQpHWgUh BzR3orRWJOFl1iZgf3jSHPc8VSlvJZWyyiqolUsQMGlycVwKjFMq47zmJyOKYzBuSATRRs3d 60jGIEbHrioiTmpzFnjNN8rFa+giEZ70pBNSYA60hI9Ku4yMg5pKeVpNveiS0EAWijIo3VKd gAA96XGabu57UhaqYDiR60m70pu09gPxpRFITnGBUpWC4M3FNyM8k5qTyF/iahmhjx/FVoCM ZJwAaesTt3FRtfIrYVP0qB71mzg4p6AXPKjX7z5PpmmtNCnbJrOMzEk5NMLMxzT5UBee7BOF GKha6bB6dKgwaQLRygSNKx71GSSacBRtA7/nVcohgBPU0oX+VP2gUgOVxii6QxNvpS4waACK UA0XENxxSikLIhwzDOM4HWnxxXE7bbe1lf3K4H50PQY3FBKgZYgY9TWpD4c1CY/vZo4V9Bya 0rXwrYRtunMkzZz8xyKzdSCGkcskyyHbEryf7i5q7b6ZqVyoMdrsBHWWuxhtbS0ULDDGgHYK KmBDDg1jLEJbFcpzUHhdZObqdye6xnArRj0ewtB+7tgTnOSOa18c1HLgDnGfSsXiJMaiZpRQ cKoA9qQRj0qRlIPNNJPQc1KcpbjEEYHarUCkduKiRcnmrkYFJ2AlQZwMVNlU68mmhsLgChcD k8mlK1g1Hhd3J49qcDt6U3JNLuwOBSihkF1p1vejLr5bjoycGse506/tM7NtzEB/CfmrfGT1 OKcDj7vWq53HcLHH/awhImiliI/56LgfnUizwv8AKJUOeOtdY0KTLiaJHHuBWbc+GNNueUVo X/vJxV8yYtTnpNPOd8TfhVaRTgpIhAIrTn0DU9PbdbSieEA/Kck/nUENwlzugnjMco6huDW0 ZuxFi7pmqwTxDTtSddpIEUh/kahvNFgtJ289ZDExJDIeBVO60G5VPOgkWaPcCFIztI//AFVe 07V2kgNlqkbCRSViYnOQP68E1oqkXsxulK1yBvD8kiJcadcC4TG7CnLL/nFa+jX06BreYsfL wCHHPaqAsrjS7lLqxnkQHOI0OFPI6ith3e9RJ3iWKRkG4L3JA5rnq1I8tzooYeblqjZikWRc hgPbNVbrVLK2+V7hC3oDzWbNGbq3e3M0sLMMB4zgjg1gf2Y+nvtnZpWDErI3ORk965YTjPRM 6q2D5VdHUaRK+oahdSQIpxGoHmdK6b7OhKs6KzgYywzj6VzXhMKv2iV2ABIUep610zvwSOle hTi4o8yd7j3iT75QbgDgkfjWZbbjC0hkbBduC3PWplmlFxcysG8qNRgNwDxk0xWSZRIAA3GQ oyB7VoQKGAjkkZBhI3Y478etef34Q37yRn5XOR+tdxqM32fSbxix4hYLk5OSCK8+DEuOeKTi UkLOmU47EV0nhONiRIe2RWDIB5bGun8Jpi3Zu55+nSpTd9Qex1AGKaSc9KX3pCavQk8vMQVi cClzmlPOaBWa8wEzTgR2INNxQMDpS0uFx27FNLAmmljUZPPWnbsFx7YzTMik2s3QUqwynqRT GJk03NSiLb94gUrNBH95lJ9AatICucngA0qxORSG+jjHyYZuwqCS/mY8EAY7VSQFswKnLkZp C8CDJI+lZrTOxOWJ57moy7HvTSEaZ1FEB2R5PbIqtJfzP/Fge1VASTQQaOXuCuSPcOepNMLk n/69GKXHpTUQG8nvScYp2DnFAANFgEApwwKUjA6UYo2ABQMZoppmjU43At6Dk0hknrSYJ7VJ DbXlz/qbST6uMCtGDw7eS/66ZU9kHP60nNIErmSSFGWYCmCTP+qjeU4z+7XdXWW/hiyjIMoM rD+8c1qQ2ltbKBFCq46fLWTrRQ+VnGw6TqdzgrAsQ9ZOtaUfhYnBublm/wBlOBXThSeaAmT0 rCWJl0RSgZtto1nBjEKk+pHNaCQqgwiBR7CphHUojAGSRisnXdveZViuIx1xzThEO5wKkYoq k7gMVXkuAiZUFifSs41Iy2AjnRR0GaihJVsHGKqzXMzn5ePals2kkkKuBz2qkuYZqrz0B+tM ljUYLcn3q3HEVQKAahmiwfm/KmkkJmXKCzcDimKoWrE3BqDOelVzK2gD061ZQ+vNVkBJqypC 1Fm0BZUcUcLUauccUuffNSkuox+c09B6DNMXPcVLu4qk10AcAO9OzxUJkA6U9CzdBUybQXHj PXpRmgpgEsQo9ScVmXus6fY5E11Hu/uowJpKaeiEam9lPHNZ2oaXa3qM0xW3cD5ZRhSK5678 Y3Lx4062Cgj/AFkykfkKwp5by/YteXksmR90NheuelawpzfkF0dfYXHkBo/OWYA4LLyD1/z+ FSXlhHIBcRDO07sAcj/Oa5a0mazf5MBM/drpLHUQVBBBB4P5VjUhOm+ZHbhqsWuVl1BuiB9K sR8CkBSRP3YAzSrkDnrXDOq2erTS6CvEGGQeaifY67JV3D19Km344OKY5R+1Ywk07mzs1Ys6 LBaW5MTSSHc+9R7/AOc10IRSd2SR6VzECbHDBiPpWvBelxsGd2OM16+GxbfuyPMxWETXNFFq /OLGUk4zhRn34qBVAiX5FTHUHv8AhSGS5is4tyK0skoUiTkKDnmnusgbEzjdntwK9Ja7HiyT TszM1zC6HdPnrhcfga4SM5YV2PiqbyfD5HQySkD8ARXG2/JFSxxTLrDML8dq6rwsMWRbHf8A oK5tE3IwrrvDyqukRYHXOT69KUWDNXNH50CkzWqIPMjwTRmpNi4JLAAetRm4gQ/eB9aysUAy 3SnLDI/A4qvLqkO8CJDjHXtVeTUpzwpUfSrURGn9lRAS8oGOoJqJpbSMcnLe2KxjLPI5BdmZ j0qyLCJFVprhnkPLIp4Wq5bATy36j7inFVnvnJyBt96jnhWPmIkrjoetV+o5p2QErXMrHl81 GWJoxRt5ppAhvf8AOlwadto45oGNxQFp2RikH9aL9hC4xQR3owe9LkAHJA478UBYQ8UL1oDq 5wgLn0UZqxDp+oXJxFblRn7z8UXS3HYrgdTTSyJ95gPqa3LfwvcS/wDHzchQeoTitS28Nabb gZj8xh3fms3Viuo+VnHo0kpIghklbP8ACvFaEGhapckExpCmerZziuySKCAYjiVfwp4YNnJw PesXiI9ClA52DwnCCHurhnxzgHitS30uwtv9VbIT6kc1f2KTnrUgT0FYyrya0KUUQBP9lQPQ DFOVAKm2c1Gy81Dk2tQF20mw+lOjOeDUoAPWs2mMjUE9qkVD6U7HoKcB69KdmgGfdBLYqtJe wpbGd22pjdzxVzK4OFz9a5jX45ZLI/KWjDnKiueque0WF7GjY6xp+oTtCmWcc7WGK0Xi3cKq gVynhqzmbUWuHiZI4gQC643Ejt9K7IBeeKuNCFL4WSncyprQFguCM9xVm0sY4SW+bJGDmrJU FumaeOK1UiiYsNvAwKoznPQ1ZZvbNVZsAcUubUDOmHOOtQgGrM2MdKrbSa06aCY9evNWl4Wq irzVlRkdelQkxEiHvijOO1L0Xiqs19a24JlmUY96WiKRbVj+NSqNwySAPrXOXHie0j4t1klb /ZXOKy7jV9QvTgP5EWTnafmI7VcISlshN2OwuL+ytULTXCKB6kCsS48ZKCUsLd5AP42GBXOG EPt81mlI6eYc4p4GAB2ArRYXrJk8w+81HVNRZjPdNHH/AHISR+tQRW8S8hAWzyx61LjrT0HF dEacYrRCbbI2XC01BUrj5DTUq7sNBadDO9u4Zc4zyPWkbpTR94D3qZQTWoJ2dzo7O+UgMH59 M9K3LXF7A+0/vFGdo6muFfcoyjFT6ip9O1e7s5A/m7lC4J74/wAivNrYLmu4noUMXbRnWqhJ 5zUyx4pILiO7i8yLqOoz9f8ACpQSTjGK8uacXZo9WnNTV0IBt9avWNo97KUikVHA3ZY4/Kqo FOjk8qVJB/A2eKIzUXdGtrqxsNhmWCaRfMi+8zHHpSOoBIU5Hr/9esi9uzdTPMRtZjnirGn3 EkqMsrF8cjjpXsYXGKXus8vFYPTmRieN3Kafp8B/vFvzNcxaj5hW943Y/bbGMk4EWQPqQaw7 f7wrv82eVZrc04l3Aj14rrtFUppUC+i/0Fcpb4ya67TCDYx47DFKNmS0XelBIzSUmatIk8ek mkfIZyRmoiaCOT9aXtWlgGgmkwc08UYp2ES2gxPu7gU6dhv+9jn6VCCVORUr3QOD5QYjuRQ1 1KEdCkAXcSSDz6VCBgcmnl2kO5j+FMwc0riFJGKMn0pG2gckClTfIwWOGRzn+EUXC4nNJjAJ PStCHR76ccIIx/tda0IPDALBriZ34wVBwPyqHOK3ZSRzxdOm4EnsKlht7qc4htZDnuwwK7CD R7O3Pywpn12ir0cSKMBRj6Vi8QlsOxyFv4fvZSDNIEHdV61p23hi3iXMrPIf9s5roAAOlKBW UsVJ6DUSlFpttEMRxKv0FW1QRjA4+gp+KaQfWsXUk9ikiMsTJgCn+WzdSRQABKv0qwDxwKm7 HYgMeFOBk1W+wtczRu8ki7GztBwDWhhm6LinIhXsKlJp3ARYggwBT9oFLtYnluPSjYOpNWmI Zx6ZprRsw+UAVN9BUbMc8nP0pWYyDyyvVgTT1IHalIJ6LQqkHk0AO3UuTS9BxTGJ74okwHlh jHOSKpgptfcAQGPBqbP1NZ00ojtrhicbcnn61y1k2hGhEN4yvQdB6VLsIOc1Dpx3WqH17/nV s/hXlznOM7CGDd3IFKPrmhckfNj8KcDivapO8U2VdBjPtUEoUe9WAc5Oap3csSIS8iKPc1W4 irN0zVbd7VXn1W2jG2ImQ+3NZst/PMTg7B6CtYQk9gbsbIdEO53UD61Wu9cgt0IiRpH9uayG 3P8Afct7E1HMAIyAMVqsM27tk8yEudZ1C7wocQoRzt61UZA53SEu2MZbml704jito0YIOYaA BnAA+lSJyp+tM7VJH92r2JbuG2jHalNKBzmjm0EI42ilWiSkB5A9aL6DYsn3Dio06VLJxGah X7tKLuFxWPOKdEu6RRTKlhGXp9BDrjhCKZbrmi5bFOtPmYVKlYC7ZajLp1/G6nK7hkH6/wD1 67Bb2K8xLGApbtXBXHM2Pcda0IZpolAjY5OMA+tcGJw3tNUd2HxPs9zsCHAztODTCwUfMaxG /wCEqsJMSaZJcKehiJP86u27avdMI20iRJCM4k4A+tee8DVXQ7ljqfcsM28nHQdzWjYoQjvw V6DJ6/hTYdIeOcR38iBtofajfKOmAav7AilUTAHAI/xruw2Dcfekc+IxykrROP8AGpLa5brj AEHT/vmsW35bPvWv4wIbxNt/uRY/9BrJtx0r0WtDzb31NaAcGui0eUmIp6GufhrW0uTZPt9a hXuO10b4PFISQelJuGOlMLHPStkzM8hJANAOaMdSeKZ5kYP31PPAHNbXAeOlAB71JDbXVxxF byfVlIFaFv4fvZiPOdEHotS5rqOxlsVUckD60wup4QGQ5xhBmupg8LWanM26U8ZyeK1IbG1t +I4I198Cs5VooLM4yDT7+4A8u3KA8ZcEVoweGZ3A+0TFeOdtdRlV6Y/CgEnoDWEq76F8pl2/ h+zhOSu8/wC1zWhHbQRDCRqPwqby3I9KUQZ6k1jKq2h8o0FQOoFIXTp39qmFuuM4oEeOg/So TYyvv/2TTtzD+GpSApxgE+lCQs3Lce1FwQxCSelSqp9KkWICpAoFKwyMReoFOEIHapAR25pM 1LkkIiKDzAcVKMDoKY4OVPvUoBNC1VwEJJ7UnNOx70mRTYCDmlxxQDUc9xDbxNLLIFRRk0Rs A9sY5zmoi3NZ0GrreSOsULhVPVhyauJbXc/PESZ/i6mm9R6EmQOppN+T8ik1LHZxoctukPqT UuABwABUgQCOQ/e4HtTvLA96kpGpiIHQHoea5zWInns5ghxtJZsHGRXSOCQcVzd7KGhkjHLy OVA9qzmluhW0NXRHdtNQnAJzj6ZNaXaqlggWDA4+lPvJDDaSyA/Mq5H1yB/WvHrtSqWQloTP IsYy5Cj3OKzrvXrG0DAyiRgM7U5P5Vyck13chWuLl245CnApiRIhJVQCepr3cPQlyq7DmNW8 8R3c422sSxof4n4P5VmSNLOxeeZ3JOcZ4/KlxRjvXaqEY6k8wiqqgBQAKWl6UoFaJLoIBUc3 3KkqOb/V/jQJIrYO6nN0pozuGaeelS7IoaR8tKg+X8aG+7Tl+6PrVX0FYXFKOtGKQdaTaQIS TrSL94UOMnihM7qSWlwJJzmPGKgHC1NN92oVHFSgsIeKmtz1PvUJxViEALVt6AQXJ+bA9Kn0 75pMf7GarXB5/Crukrl5T6Rf1FTZ2C5HMP3/AONaFqge5twf+ei8VnSkecPrWjYAvq1ig7zD P5Gs4p3NOh6xHJIiAAkegqFPO+3Ss2zBUY5+f8faszUdUmsraHyVWSSVtpYnkc4496t2afv5 ZTuyyry3JPH/ANetrNGVyC52nVCJASgRTgc88VIMc8nr9cU6SJjdySq6OcBSo6gY701R++jH q4GPqaauBwnihy/iW6PZRj9FqhbDgd6s603ma3eMP7+B+S1Ba/dXHTAqJR8y1sakWQelXrY7 ZFb0NU0HNW4fvVktx3OiRtyAjoaRm5qvaPmADuOKlYnNbohnEweE4g2bid3OemeK1INJsLX7 kKZ9Soq4Y2b7zHHtT1iWsJVZmlkQgovCL+QqMs5k4U8jvVvatMYAOKwcpPcLIYIpGGCwA9qe IR0PNSj6UZP92k3ZDGiNR/DTwvtTgM9qkVPrQpXQDAuacE9qeQF6mmksx4BA9TS5bIBGKqOS Khw7Hg4FWVhUHceT70pA9MmhMCskIU5PJqXjFOOR6UmCegxT6AN5+gpQAfegLzk5pQecAVNr AKAe9LtFL25NGCaNGAx+g4707PHJpJFO3k0qgEUJXCwn60xmI7ZqXn2poUZoaXUCsy3D8KVR fU9ao3mlSXcflNOwB6mtjgDn9Kb1NPRDIrKyt7JAkS5Pdm6mrhYnqTUSrk9Kc5RBl3Rfqaly TCwHJHWjbn3NZt34h0uyyJLhWkxnapBNYdz4xml3LY2xXj78owKpRlL4RHXMm0EuQo9Sazbv XdLs+JLlXfONqkGuMuLvUb1j9ovZAmclIyQDUSQxR/dUZznOK0hhpv4iXI27nxRLcAraW7Rq Rw0gxVSwMk95vkOQi5xjuT1qnkBSTwO9bnhjTpb3ztQkRhZxodmf+Wp45HtzWssPGMXYnmNy xGIaZq526Vcnn7vX/gS0vmvbQM0cLysTwqis3Uv7UurOQusMMA5K8l26cV846TdYq6OcA/Kj FFKOlfUUY2gkQ2FApcUtbWEJilxRS0gExzUc33fxqWorj7oHvS0Giv8AxCh+BQRyKc3Ayamw xp6U8dBTH4oB6UgJD1oAzx3poOacn3qAAjBpsfLfjSyjBpYsFqFJWE7hKPlpi42VJN92ol/1 YHtUh0GN1qxH9yq5+9irKY2CjoCKdwfmrU0Zcx3DeiD+YrLnPNauij/Q7gn6fyql8IynJzcH PTIrV0NfM16zHPDMf/HTWS3Mze1bnhYZ8QwH+6jN+mKIlvY7i7CO9nCYR5f8TN1HzdBV21be 0gHRG2g4rLujBNr1lDMJ5JVQsEQZQDIOW961baBoN+99xdi3Hua0MiF1hNxKyz7ZAcMAMZOB SwbvtURHXfyOnSoTF5Ukzy4ZpH3Ag/dGOlOhfEyHJ4JpdAPOL479RumJ6yH+S0tuMBRUUp3u z5+8c/yqeH+GspIu9kaSHpVuI4NUlPSrCNgjmsth3Rq2c5MhXtVtjzWVaviYc1os3IrWLJZX UbugOKeI+epqYIKXaK5eY0I/LUdjTXi6EgDFWMAVDOheIjOPegQEAjCilWL3GaFIVPU075jw eBSauMXaAff2oAZh6CnAAfdyPrQSR7mhJAIFUdsn3o289h9acAT2pdo70n5iuMAHTk/WnBT+ FKOmAM07bx1pXQxm0U08VHLdRIdu8Z9M0xJWk4jQn/aI4pWb6gS7fTNIBgHJpVjkIyxA+lPA A6kU1bZgVXuArgKQT7dqsqcjNHlxkZ2Ae460oAHTP41KaWwXGv8AdPNNQfKPpSsODSIQkQLs FAHUnFHMgH5pOtZN/wCJdJsA3m3Cuw/hQgn8q5+78dSy/JYWRXn70oxx+FNRlLZAdm7bRk8V m33iDTNOVvOuFLqPuIQT+VcFc6nqt/8A8fF60akfchOBVNbeNW3EbmPVm5NbRwsmveYnJHSX nja6uAVsLbYp43S8fyrFlvL+7fNzeSdc7UYgVEeuaM81vDDQiQ2yxFHEvIQZxjJ61ODxVNWq VJOcV0RilsIsg0tMVs0+qsKxc0yxTUdRignO22+9Ke+PT8a9JFtGNNaGAbY0TAUcegrkNCij jsQSMyOxJPccmuus2ZbJj1+XjNZ1HoCKUcJ5XJxTZbIyK8aoSzqQBj6VIsvlgljyas2LSz3S mMHPTnvnFfJ1HfEaFo8wjH7tfoKcM4q5qtobHVLi2OAUboO2QD/WqmK+np35USFLSUordAFL RS4oEJiobkfKPrVioJ/4azdkMgpT0oNI33ai7GMekzyKV6QVonoIen3RTk+9TRwtOTrk1LGg kPOD1ohHNEnLUsPWkrAE5+UCox0xUkvamAcU9QGY54qdfuVCfvVPjEeaTEUJ/vfStzSVxpUj eoz/ACrCnPzVq2dyI9ISFT87INx9OBQ9EUiDbmRj6mt3wqmdZd8cLEf1IrEJ+bFdP4IQS6ld ZGVEag49c04Mcr2Oskvr+PWIbS3trVrdk3TTycOMY4Hqef0rQZlDbA67vTPNZPmgarPJyxWI nkYUHjvUdsVnu47gNlxEdxzw2fT2q73MyzsaNH2zJKrNksvNMDlIpW67UJpsSRJGFD/OByF6 Ci6YLp925P3YuPrkUSdgR5yOY0PXIq1FwRVSNSEjHXgVcj6j6VlItJMvDpTxnNNAp3as2OxY t2KuDUV/rawXHljJwvapUVRFkuAx7Zrn7sKLhsjJ96cVcDu92SRg1IEJ9qaquT8o496bI6RD M0oHsKxbSKsSgKvbJpkwLIRnaPbrWRNrMv2kQW8LEH+LHSr8QllXLEjNHKA+LG3ufepRuPCj FLbxgIQxwAfxqYFf4alrsBGIiRyadhV6Dd9KcAOpJNLg/Sh6Ahm3PfFIQPUU6mlMjkUkxED3 SR8BHc/7I4qpdNf3cDpEFiZhgHuPer2Np4pR1pNJjKWlaLb6fAFmeS4mzkvI2cmtRioGFAUe 1Q7yDgCkdlQFpGCr6k4pN23DcC3PNKuCe1Yd/wCLdHsQVNyJXH8MWGP6Vz1x49u5mKWFkqKR w8vX9KIxlLZB6nfMNoJchQOpPFY+oeKNI03IluVdwcbEIY/lXnd7qWrag5+1X8gXOdkRKiqi QRxnIUZz1PJreGEbd5Cdjp73x7c3Axp9mIwR9+YY/kaxLnUNS1B911eyAY+5ExUVW6UA4roh h4R6CcmOSGNM4XJ9T1p+6ow/Y0pPFbJJbEEgNL1FQZOOKkB4piH0UgPNLmkMXvSg03JoHSgR MkmOpqwjhmUDrmqYPpT1k2MDnBBzmgDt9MUlI4wOTXYRQkWBBHOztXMaFEZfLbHbPNddjdCV yemOKlq6Ay1CkkHnmrum7RfwhTyWqKKwcMeTjNWBCYJI5dpDKeDjpmvKll16vPcq9jz7xJGY /Et8MlsyA7j3+Veayq6Txla+TqcM2eJI+frxXNivUgrKxIYpaKXFWAUCj2oAoQC1BOOVqwKr 3B5WlJaAiu3WlbpQ3UUNWJQ1qTFDc0veriDHAfLSr1HpTc/LThQ9hISU4alhBzTJ8iQjtT4e wpX00Bj5Bmox0qwRmq54zUKT2AYetWD/AKvAHNQxR+cxXdgA81pwxQxgbRk+9U49WMyltSW3 uMVKMKuFxxWjKE2nIAFZ74ZyFHy0xx03Ezmuv8Ax/NfSdwyjP/fNcmFAFdp4DQtZ3cnXM5GM +gWmkEnc0bCSK71G8XEoB+UrIcA8dhWlFapaW7Lbxgvt+XPeqtrb28F/LNJcQvcsvManhB9f Wrd0He2kEalmI4AOD1oehBCS+weZEisepSs7WZPL0W7OeuF/UVoNlPlZ8nuB2rI8QMy6JJnA VpenrSeo0ccB8yjtVhPvAVD/AMtBU69RUO6LSLy9KkxkYqNelSVmm+oxUTAzisa8tBLcsxLf ga3YypBBzmsq8mRLlgeKqFriuztm+7WTd/6wUUVzy3RaIoP9a1bMH3aKK1lsIP42qSP7poor KO4h46Up6UUU5bD6EZ601utFFYiQ002iipQMX+E/57VzHiv/AI8ZP92iiqG9jzSx/wCPofX+ lazffb60UV6sRLYST71MPWiitEJidqQ0UUiRp+8ad2oooEIvUVJ2ooo6CHigfeoopDHCkoop AOXvTv8AlrH/AL4ooq47CPSPD/8AqU/3a6pP9XRRQIlHUVNd/cH4UUVnITOJ8c/6u0/H+lce KKKIlIKUUUVQxaKKKSEFV7j76UUU5DIW+8KGoorDqLqRv95frTu9FFadCg7D6U8UUVL2GR3H +tP1FPh60UVMdgZZqu/eiio6iEs/9bJ9R/Kr8P8ArhRRWkxoLz7n4VTTrRRQUK3Wu48B/wDI HuP+vh//AGWiirWxDGW//IUu/wDeT+tdL/yyP0oopMEUB90/Ws/xJ/yA1/660UUmCOR/5aVM v3hRRUSKLydBT6KKhjHr1rHv/wDj7aiipjuI/9k/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGFAhwDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwC6tuSGdHIOenarcLYTmqW4+acNxViNsA81 41rI7kSkFmyCPpT8/KRmq/mIG+cZ9CKN4JPce9RuUiYEEdakD8etVlJpyODntzVKRN2TKwD0 4MSagX72alB5600wJSTj/Co/M2yZIOfUUE4OcmnxlW3AjOalsaAylzznHrTQwBJJwfWleLy+ Rn86hkOCcjPFJMZNHIRMFJOSR1q7KMxNlu1VRchkUNGucjBA5qV2JTAPNRJtMLD45D/ZsXbg fh81Q6i23bz+NJA2dMi7kjJP/Aqj1FgAjcYqGrsEiedgbKZSc5wf0rOkLJCcAklcAfhVmZzH FyeHTjA/CqQckfMST/St6Okglseo+G8Dwxp47CEDmtfqKxfDDE+FtPY8kxdfXmtrNezHY4Jb ibRzUUj7D0zUucGmkK/JFUIBzg0hGCWo6YA7UoII5oAEfd2NPpuQO1AagBRSUm6lzxmgBRVa ZsMeSKnBqORN5yaAI/LJmVwcApgj1pZzIiZiQMx7E4qTB44p1AFOJp5Ij58YRw3RTkEVMBxT mB7CosSA/dH50ASMOKpzTpASJIy5xuwvXFXADjnrQ0MbHLKCelNOwipPEQd25jHj7o/pUMUt rvECWsqlurnitFl+XA4+lRbG3dAR70+YLCNBiPbGzJ9Dmn8hVHcEc/jT9uKMdD7j+dTcZ5R4 kYf8JXq6+k4/9ASstFyAcn5Sav8AiQ58Z6yBziZc+/7tP8/hVCKTEbA5J3f5NefiXqdNLYsx OQMYOQe9M1UltOnBOMocfpSQElm57im6oR/Z8/B+5/UVxvubDomPkAZxULAjkDjmnRNmEZz0 phyIxk55Io5h9Ascx2qhhwFwM0jMVQIeBjvSQTqLWBTz8vPtSysWnUYyNoGaTaZJOg+Qc8Vn 3SlHbH3Sav5AGCagkQHrzQtBFfJKhvQU8OCuc0q9CvpVbJjZlOetWpILCt88hNDRYGQOacBh RTgfWle4iFWI4NC5Eh96JGHX0qPf8wNUrrYZMh5PqDSx/KWBzyc0xT87Z74qRSCaPeFcdkbm DHqOapT8XpHpGMfTmrZ/1zHHRM1Tm/5CJI6eUvX6mmrrcAP+sT6irPeqrnEq8jqKs556U33E Ryf6wf7pqIcMSPSpZPvVCSAaE9BMRj8gGO4oTvQfWgfKhJ6U7hYj3fu6sx58tfpVMA7FFXkG EHPahOwNGp5pL81ej+Zaz8AN15q9bthazumjSwyVDn5aRdy1LIWz8vWoyGPU1Nl3C5MjUrHn NRA7cnuaXcSM0roqxMjZHGKeJDznrVeJhvwc49qkNDCw8uccUoLbCR96oixAIC/jSoxqbgTm Z3ADEcVGe+704pm/d0Uj8Ka5wx+lGoEsYkypKnbkc/jVyTcDuB7dKqrOcquSOauZzyw6nmpd 1uO5DAQNLhGD9P8AgVQeIH8uwLgdCOKfat/oUY9Mj9aZrmG0+TcMqEyR69KXUCST/jybByM5 FV1wUUkc45p8Df6BgtnI71Du/u9a6YaSRMr2PS/Cn/IqWK/3UZfyYitzPBrA8Hvv8J2jf9dP /QzW+K9eOxwy3IW3mTgfLTpSVX5VJ+lSUjAMDVCK8UrFj5ilR2zVkYNVTbjfuy2f96rK4VQC aAEY47UKc9qQuM4oLhaAHEcUmQgyTxTSS3HamSqrxFGPy9+aAJBIp5BFOBBqmI0VCFXr6nNP ikcR4KYI4AFAFikzUK+Zvy2AD71NQAxmxz2ppPzdKV/u0wuM8c0AK7leT0qGW8WIkFWY4BAH epX5XpmhFDDlaABH8xNwB57UEkH2qK6t2mi2RymI/wB5etLHG0aBSScADPrQBNml64+o/nSK KcBgj6j+dAHj/iAj/hOdcPYzoPyiSqWNrMAcgmp/Eb/8VtrnT/j5Xp/1zjqE4CivOxVrnRSW g+IbS3PBNM1Jh/Z0+c42c/pT4sspz9ai1LnTpx/sH+lcPMjdDouI1z6VCHyh9Q3FOibdDn2x UTcKcetLmsxoitU/coMEYFXI0BO/uPWkgYGzhzjO3/GiLIQ/XvTbuSNnkKngCofO9adc5+X6 4qAwmqVrAx8jFSGHemTZcBwOaVcspRh0pAdp2ZqXJLYWohYgCmGQjpzTyCx4Io8vByapNWAZ kPGc8HBqAYZSKsNw2McYqsvyuRirjJLYLEwPJP8As05TkikUCgfKw+tHNcksNgTL/tIQapzj N0pB/wCWQH6mrr4bYR16VRmbF4B6Rj+ZpxGMfiWPP94VZ71UkP7yM/7Yqy7bRnNNsQ1+tV2J z0qVmymaj65ojcBR05qNvTJx6VIfumoWOCKtyQkyRv4KkbJx9KhY/MgNWCOn0qea4M0jnzSc VdgyEJzVIZZyBVuIlVwaz5dDUe8uGwc/hUfmcGo5nO8YxTN3rWaVwRYDnrmn78jnNV0PNSMa Nh2HRE7tw+lWMnGfSqsZwDirEZ3DHem2CFclk4OKEJHUUHPOcfhSIy8E5680mwJWZh1xUDsQ 3fFSby7E7eO1RTEjGKl3HcfHh3HzZwavNNgY4rJhLLIMLkEjP51puF2H1+lS2MbbSD7KuOnP H4mn3uGRVPKsuCDUNq2bXPHfj8TU8/Ij46KKh3vcCBlxbcdjinw6PqV9bCeyjhljDEEbvmzS Oc27c9qrwXd7aD/Q7yS3VmLMqdGOMZrqpPVCle2h6P4RjktvDUFtcRmKZGk3I3UfOT/WugHS uc8IvPf+H0uLtxJceZIpYegYgfpXQsTjivZh8JwS3HZxUbBt4IPGRRyRk01plTqRVkkF/efY zakjKyzrExz03A4P5irDfOcg1ma2mp3VlEukPbpJ5qszTcjaDzgeuK0UchFypzjn60xDtrAe 9V1E7ufMjjxnqGqZrjaOUb8qZFLuZjsZRnjPekMcC6feXiqzW1rJqCS7QZDGf4s8ZHarpYEc 1nEpDqaNtPzoQp7diRTQjRVQo6UU1XBFBb0pDCQ7ADjP0pytuGaYG3UqoF6E/nQA2ePzU27m HupwarxwC2DBRI+45OWzV3tUUrMqkqpY+lNPoIijaTJ3RsB2zU/QVnrcXKy5khVYz9Qala7L SmJEO7GcscL+dNoLlnrzTDG7HqMUwxbhmQk/Q8VHLLJFEfJXdgfxHA/OlYLlxFIFOPQD3H86 q2V4LpG+Uo6nDK3Uf/WNWGPT6j+dIDxXxEc+Ntd/6+xz6/u46iJOUIHA/wAKk8S8eONdxnm5 X/0WlMz8q88ZArzcZudVHYkhYknPpTNQ/wCQdPjP3P8ACiBuTg027Y/YZj2CHr+FcKN0MgP7 gYHao5OnPFPg/wBVTJOFyRxUvzGiK0LfZo1HYYq+OI+PSo7RUNnDkYbbzTZHKugBxk81Tats Tcbcfw+uQaGZUPt70sq5K57c1XmYyOQKcSbXFeQA57U3O8bl5qIh14ONp60IwhOOcY4p2Qyy g4yRUcz4GF61G07NwoPPemoGGWc8/WlfuAqkn73WmsOcinZyM03ORRzLoIcp4yexpxPP41Gp wTTyenPBNOwiXcc9Mc8VSm41Bv8Armp/U1efjkjqpqncgfbv+2S/zNXFjIZm27T/ALQokk3b aS56L/vA0iA56VTlZ2JJl5jxUYYhuB1FPRudtLs5J9KpAMbhT71C/LipnGSBjGKhY/OPrQ0h Dmb94BU57c9qrk4cVM3UfSgGbUR2sTxip1bJJFUQrliBVmHK8E1ldGmo2Y/NnFND5p8py3Iq EZ3VN4vYaZOnAp5xiokPqKfnii5Wg+PO04qRGpkZ44oXipvd2EiY5AJx+NOR+mfmpgODjPHv TmcMOoAHXbS2GPcjjAx+NQTDpyelKhHUNke1NmGRRoBGhOQB6jv71puw2nOetZQB3DHXIrTT 5ioJ7jPHvSbXYCO3b/RyMev8zVhz8qfQVl6bfedLPbMhHlc7z3zkkfyqxd3zwX1raqilZVyS RyOD/gKibd7NCTRNJ/qGz0xVVHUAZFWHYmNuTVQlDwxPtWtJWaBvQ9L8CnPhOJv70sp/8iGu k7VzngQ/8UfagdnlH0/eNXREEivdh8Jwy3IZVdhhaha3ZuSFz71ZUHPWmvndnNXckI49kIj9 BTguU2mlB2jmjeMUAVZk8tspb7ieN27p+FSwElPnUKfTNSMwAyRVBri4J+SAjJ9O1VuI0Cyg DOATTGjRhhgCKimtI7kwvICWiYOvJGDj/wCvTjMFbb1qQHKqAkAAfhTHijOSVzjsDURh86Rn 3MM9s1KsKod25uPVqYEcJ54gZPq2asDrUbzKhAxknpQyGRTkkD/ZOKW4xs07xyKAoYE4ODyP wpsjXEgPlxKOertUCRx2oIhLMWOcFt3604TOR84VT6Ic1VhD8xI2JFO7tuOaV3DcCMD3b/Ck SIsOigeoOSfxp4jRPurz6mi6QFeO3bezAOVPXzG4/AVZEKH7y7vr0pQo707PoKTbYWIo7VI5 5JlGGfAOPQdKlyd68Z+YU1pNpAIJz6VIMEr9RSGeJeJWLeN9eJOf9KAH/fuP/P4VEDwM+tHi Fs+NNdP/AE+EH/vlKavKqfQ5rzMY/eOqjsSwHDGkv/msJx/sY/UURZBJx6Ut8cafOcc7On4i uJPob3I7fHk5JGcetMk5Q8Viacz/ANpoDIxBDjGegxW3JgxnmqlT5NWRGTZDazSJAhb+7xSy SMxBNTW4WeygYc4XBqK4QqxABx2pJqQyyx3KDVdQFLMe5p6MfKBqNzzQ7piRE/J+bgGkChfv HOOlI2CDnpTVVV4JJFChrcZKJFGeKiZi3tTsL24pjE5wBSklfQAU44pe5FN+o5p4ORTewhM4 PNOPOPrTT1zSjrzUxuBYLZUewqlK267GR0jUZ/E1YyQ5POMVTfP22T2QH9TWySWrEyO7PyqR /eFTouBUUoDMg/2xU+cU5NCG7QpBFIzHdjsaV+RTQflz3xQrtaCuNL5c81FjL1Jt2qSe9MUf NmtYx0AGzuFWOCBVYnL1PuPFS7AaXmlmJWp4XzyagQ7GNTRnJJrHdbF2HynJFM6UsnHNRlz6 Vhs9BpEgDfhTsjHWofO3fLmn54p2bGTRsfalz8xqJAQO9PRsNnrRyyT0BMsKVcEHINKUAxhs Z71FnkHNKF/vH5T3pOXRgCAqxBUYPpRIfmBB4xil5Jzu47imPyOtNDI2JVlIOfmX8ORWuhJI ORjcP51jlWOOe4/nWmDlM8CnpELGNpiSx6pel4nSM9GboeKvX0E8mqafMkZMSJ87ehw2P5ip IyW37j65q22fJT0Cjv14olUXUSRFKPkYe1UGXPI/Ors2dh9cVBGvyAHq36VVNqUrg9j0rwLx 4OtTjB3Tf+jWrpAeK5nwEc+CLA+vmdf+ujV0h6Gvdh8Jwy3KVm8/2IeeP3+5gc+m44/TFOkM gjJKA46jNSBViLbc5PvUU8rCM/uZGyO2KtEEkW54wT35FEm5IiQAcDuaS3YmIZRlwO9Nnn2x tiJpOOi80wFjlYxB2XOewqWNgy5K7T71FaktEN0bJwOGp7swYbQNueeaTAkDA5A7VWcyK4Yi NY88ktzSF3WXasJCEZL+9IyQSD94oc+jHNNASCQv9xDj1JpmJF3NMBt7YNN+Yfc4A/vGniIu csuf97miyATzY2XhMj1PQVnXk09tKJS4aHgFMEA5PatM26nrnP1pDAu3DEsO2TmmpJbBqQbJ kfDIhQ9ApxVhVXGPLCj0pHBPSlUMPvUN3Cw4KqDgAfSmnJ7YpxpuTmpGIF55OalFR5pwNAD8 DNLxlR/tCminD76/UUAeDay4fxbrbjgG7bj0+VR/SnxsdoAFUrtt+tak/wDeun6/XH9KtRMP LBNeZjNzppbFmI029ObGYZI+Tr6cjmmqRyKbeN/oNwR2jzXCom6KFlo0dpdLc/apJSFYbW6H Perz8oeanUFYlHHAqvJgoatyctGFiOydoIUXHyY6VPO4lgJHWmQputY8dAtJGCxZMVDaW5Iy J8rj0NKepOaagKiT/ZYD9Kc2MelNaoCBuGAOMEUbfTBFLIM1EocdGp2aQx5VW4P6UmNowvSg of7xBpuCOrZqdeohTu70oPHNJuyKQHNNbAOzk0o5bmmjrTz0yMUWAcwKsD7YqrMxa9yevlL/ ADarbn5QfSqUnF8/tGv8zVp3Yhj/AHk9mFTM+PSoJm27eDycUcseBW25JMvPXmmA4bbSBirY PSncbs45xUKOu4DZTkAD1pQMUwHLkmmG4kJKlcVevQVrjd3zfjU+7gVW6c08NkCmkuo7WNc4 3nmpoTg1WJYscqBU8RPtWDTSNCSVxj5jUDSJg4YfnVhHlV/liSQf7QzVkSJ0+zRBv9pMCoj5 gZ0RUn39amyB1NWzNIqEJbwdRnC9qmSTcnAiVj/eWnowuZ4kHOGp8bDf1P5VorcFRtkt4jj+ JEp3myH7nlqD6rim9AvYoMW5wjEj2pwmEybDFKGHbbV9TcLz5qH24p3mytwVkU/3l6VFrhcz gZVXHkSn/gJpGSVgNtvMfohrTWS5U/65yPQ07zJ5OCJh7xtilyBzMyfKusEC0nxkc7Diry52 bcc+lSy+e4wZ7wD0LcGq5LxsnBxnkkUOJSY2EZ3A+tWWOIo/90VWjYb2z61ZcZiXHXFYT3sN EM33cdKaLecgfL9DmpHG7jcPzqQISOZE/wC+gK6qEfeQpPQ9A8EAp4NsgV2n95x/20auh6is Lwhx4SsuQflfkHIPzmt4dK92OxwS3K8q4YEDP4VIcFCSO1OYjvTdwbiqJGAZUYHBFPESKhwo GQc4+lOHAprPjigBm0tCAOOAOKijXYOOfcnNWFxioNjbmHCrngChAVRdPsInCgg4PlZb9arm 4iE2FCqW4LAZJ+pq39lk34DlYjksq96IrYKWPlgEcBiOa0vGxOpNbsjx7guD3zU/AqKPjIzz T84rMYcmmMPWkMg3YJGfrTiOKBiZPYUhzjIGTUbF+yOaYhlGd6ye2MU7CJHLqu7YT7ClByM4 I+tIu7HO78aXpQBE9zDG+15FVvQ0n263BwZVzUNw9sZPLmlZH7FcZpsUlosW3zJZAv8AG4xk 5q1BMLl1LmJhkMCKWK7ge4EayAuPmIHYDrmqojyN0fSmzSW9lZ3l2IwjpCzuwxzgd6TikB4f a2xumaZ7iNNzk/NyetaCWIXBN3Hj6Vh2NxHHbRZeMHYv3m9q0kv7XGHvrZCfVq8jFO8jpptJ Fx40jHEyvn0FQXHNlNjsh/TFRNqFh1OqWhUZyAwqGXUtOe1lSO/gaQoQFDjmuC7vsbKSNCJs wgnuKhkPykUiyIkAMkiooHUnAFQG7s+f9Ng6/wDPQVTsx8yLFq8SQIJJVDY5HpUwWMSb45Vx jGapLPZMf+Pu3/77FTpcWCj/AI/bYf8AbQU9NrE6EhgG6Q+YuGIPFMaE/wDPQH8KR76w4231 vuPUbximve2KkBb63bJ5/eDilzpdATQwxbj9/A+lHlEdGX8qc+oWYAK3trIO+JBmmnUNLI/4 /ogcd3FCmn0FddxjQsTzKo/Cm+QwP+sB+gp323Tv4dQtz9XFJ9qs+q3sH/fwVVogmhPLGfvi gRNjg5+lIbqybrdWx+rim/a7VT8t5D+EgpKotguhxXB5bH1FAxjIINBvIMZ+1wsPdxTPtNqx /wCPq3U/7wostw5iXduBFU3I+1uf9hf5mpTeWkZGbyADH98VTku7X7W+LmIjYOd3B5pwV2Lm ROUDFDkAKQakAVc4z1quLy0PAuYiw6jcKU3VsP8Al5j/AO+q057OwXRI+HPXGKDjZgnkjrio /tVsf+XiPP1pPtNuTj7RH+dF0ugXJCq7cbjTDGhOdxppuLfOPPj/AO+qabmD/ntH/wB9Vopa aCHPGhHDEfWovLI/jFOFxARnzo/zppnt8/66P86SfMDZrjStbB+SSwH13U9dO8QITtbTmB65 3VjmLxWScRXGfqKQWvjJ+THcqc9pBitvqVWW6M+aPc2v7M8Rt1nsUP8AshsU7+yvERHN7afU o3+NYn9meNn6GZTz1mX/AApV0Tx854nfHoblR/Sj+z6j2SHzRtuzdXTNfXhtQgHuIyf61N/Y esPy2pRj6R1zbaH46T/W3eMnj/SRj+VIfDnj1umpR4yf+XwDj8qX9nT6gpR7nSLoepv/AMxU D22Yp/8Awjep4z/bDn6L0rlT4X8dHltWth9bw/8AxNNPhfxtnnXrVfYXx/wqf7Oqdx+0ideP DOoBTnWLg+yqM/ypo8P3oI/4nt+nsyr/AIVyP/CL+Mc5PiK1B99Qb/Cnjw94tUYfxFZsM55v mP8AShYKa6lKtA69fD923J8Q3mPZlH9KU+Hrj/oY9RHGP9Yn59K5BfD3iAYL61Ze4+3NT/7A 1o5zq9gPreNxTWFknuHt4nWDw3KQf+Km1E/WRP8A4mkXwk78y67fPjn/AFqj+lcsdA1U8nWL FT/s3bVDcaBcBd1zrTFc8fZbpifxFKWHn/MNV4s9EtNMWxt/K803JGTvlcFj1rOuI1bfC7ja 2QQHwR+NecT6Y0MyCPUtRZe4M55PFaSxfIAZJWGO8hNRHB8+tynUW506eHtLJ5lu8/8AX0f8 akPh7SwOZZj/AL1yT/WuSbaOC834OaRQgOQ834sa6Vh5R2ZPtke6+Er/AEfSPCVhYf2jaIYk bKSXS7ly5POTnvWx/wAJPog4Or6euPW6T/GvmltKsZZGYxvljk/vGGT+BpRoWnDrb5+rsf61 2Rdlqc01d6M+lD4o0IjnWdNH1uU/xpg8T+H15/tvTP8AwJX/ABr5wGi6cP8Al1T8SaeNI04f 8ucX/fNPnI5X3Pov/hL/AA8Ouuab/wCBK01vF3hwDJ1zTf8AwJWvnf8AsnTv+fKD/vij+ydO /wCfKD/v2KTkPlfc+hT418ND/mO6b/4ECmf8Jx4Yzk69p2f+u4r59/srTv8Anwt/+/YoGlad n/kH2v8A36WlzMOV9z34+PfCqHJ1+w/CUUxviN4PT72v2f4PXgw0vTf+gfa/9+V/wp40zTx0 sbUf9sV/wovLuLlfc9tb4leB1k8z+24N3QkHrUbfFfwQpx/bEZ+gNeNLZWY4FpAADxiMVILa 3/594sf7goU5DUe56w3xa8Bh9xv1Zx0Ozmmt8YvBYztvJX+iE15asUQ6RoPotP4HYflVc0g5 T0v/AIXF4UJ+UXj4ODiE/wCNMPxk8MgkLaam+DjK25/xrzgNjgcCnA/WlzzCyPQT8ZvD/wDD pert/wBu3/16Y/xn0cf6vQ9Yb/t2P+NcGCaXcfU0e0ZSSOruvi5pNxIJD4d13d0+S2H9TUQ+ Lmmx8L4d19h12G3GP51zBY+tNJPqaPaS7hyo6o/GaCMfuPC2sk+jR4H86oXvxV1LUbK4s4PD EkAuYzG0s8uNgPfFYeSO5phyaTnIaSGwW9soAkVMAY5FXFt9K/jS3/FBVTFJtHoK4alKc3e5 pGbL/wBn0XvFaH6xik2aOpGyG0BHQhBVDYv90flSbV/uj8qxWDf8wc7NOWawnjaOUxyxt1Ru QaqG10MnP2G1PuVFV9o9B+VJtHoPypLBSi7qQc7ZYa20TH/IPtceyCo/s2hZ/wCQdbZ/65io cYpMVr7CX8wc5N5GicgWFqPYxikEGjD/AJh9qB/uCoSKSmsPJr4g5ybyNF7afaj/AIAKUw6L 3srb/vgVWx7U0qPQflVLDyX2g5yybbRscWlr/wB8Coza6UT/AMelt+CCodo/uj8qMe1Cw0v5 he0fYm+yaOf+XS3z7qKBY6Rzm2twP90VDtHoKTaMYxxSWFl/MHOyx9g0btFbD/gIppsdJLfc tv8AvkVBsX+6Pypdi/3RR9Wa+0LnZI2n6SP+WNqx91FPSLT4VCxxQBR0AAqsY1zyopCo9B+V P2Ev5g9oy1utM/6uIfQCkP2X/nnH/wB81V2j0FLimsLpqw52WP8AR/7kf5CkJtuhjj/IVBt+ lIV9hR9W8x87LO21PWNPwApuyzz9yIflVYr7U0oPQUlhvMTqMtlbUfww/lUZW2z/AKuH8qrY HpTWUZ5FNYfuxe0Zc3XHT7Vcf9/DTCtxn/j7uf8Av6at+U2TxSeS3pXd6GehT8mRutzdf9/m pjWzMObm5/7/ALf41f8AJek8l6FcNiktqVBHn3BHvKx/rTDYITkvN/39b/GtEW7+2Kd5QXrz TswMz+yoX42u3uzk/wBaenh2xY5lVtvorGtLOB7UvaqUbCuVF8O6Pg5jl5x/Ge1WbLw9YR3k UqEFVbJjc5BqVc1NCMSq3PBpsDNvLKFbg4iVRzwBimi3iA+4tbGuWv2bU3iyT8qnn3Uf41ne W1ZW7DIVgjXogp5iXHyAK3rT9vvUkcZJ6VNu41psVVtpcDzJAxHfFS7CBj0q6sBxUc6iGJpG 6KM0krbDvcxNRubu32raxB3JG4EZwKguL2/SOPyrcNKw+YE9KtMGzI5dkZuSR7dKoyX1356C 2t2kLNt37eD/APWpppuwWNaAyOilxhscirKo2Ohp1vGxQFwA3cCrscftVMRSEZx0pfLatIQZ FL9noQ9TK2NRsb0rT+ze1N+z+1CTDQztppAhJrR+z+1H2f2p2FcohDThG1XhB7U4Qe1K1hp2 KOw0ojarwh9qcIfakFyiIzS+UavCEDqQB9aAsfaRP++hQosEyiImp4jPvV0Kmf8AWR/99CpF iB6EH6GhoLlERN3FHlkDvWgIhijyfapsFjNMZ9KQxkVomKozHjtTGmUChHaoyCKv+UXbAU49 cVIlgvUhifem0FzK2v128etPWMkVotbhDtI4NRbAr7TxzUWXQWqKvlGjyiO1aAjGOop3lKe4 qbajuZnkn3pPKPvWp5I9qTyR6VTQXMsxGm+UfStUwe1NMH+y35UcqsFzKMTelN8pq1DbsP8A lm5/4CaPs0n/ADxk/BDQohcyjEfSk8pvStYWcpHEEn/fJo+xy9PJkH1WqURGR5R9KPJPpWt9 hk6+Wab9ll5xC5PoFzRawamX5JpPKPoa1fss3e1n/wC+DSmxl7wuPqKeg7MyPKajymrW+xSD /lm35Un2R+8bflTshamV5R9KQwn0rVNqwP3G/Kj7K39wj8KXKCuZPktnpR5R9K1fsx9Kb9mo shmZ5JNNMR9K1hbH0prW3tTJMnyz6U3yj6VrfZ/am/Z+elFrhcyjEfSo2Q56GtcwUxrbJ6Uc twujSNsMnilFrnoKucEnkVFcErExRsEVViV5lWSKOIZdwPaqclygOEXPuRVdpGdtz5Y+pphb NXGPcCbzC3WjNQj6inbuKaAkBHpS5qINmlzxTAmU1csrKa9fMcsaiMgsH6ke1Z6tWpojYvSp 4DLjj86zmrLQcdzU1iwGr35uYbgRAKqsjeoAH9KqpoUfljzJzkDnB4NakI+Yj1ontv4gzD2F cDrTRpymXJo9mYwFZg4/iFVXtVgfapLD3rVIIO3Bz71SuiqXCIzAOw+UZ69aIzk3qxtDFTPF UrmCa5lCIhES8lyODVTXNYvLDyU09rdiwbzBICcdMYxWFL4k1qWNkHkqpU52g8CulqT+Ezuk bY046jcPEjlbSIjfJj/WtgEgew5Bq99kitXJEipFGhLMewqPw1e3FxpkguCjeU2AUGAF5wD7 1ia/eXeqX62Gnwsy5IZudvU9SO3Aq4xfUVzXjvre4037bp8kdywODDnDj6j8KpL4jmjX/SbP yT6BM0208O/2JpFxdSMZb2TkiI8YyTjFXtIutPmt4IL1GUMm6SaYcqSBxz3pTtFXNKcUyIeK 4RwsDkj/AKZ0h8XOeIrPDZIBdeP51WvYNES+nC6mGQYwIyM529DWefswB8jzCMnlmzWcaik7 JHVGhFrc6nSNch1FjFezWlpPn5d0gVWH410C6VvGVv8ATyD6TivObOG3lkzNAkgGcbkDdvQ1 O2mWJDSi0jRB3wFArXVbFQwkZPc79tLgTl9QtR9J1qpKNOt879TteP8ApqDXI6f4ctNVYJCt sC7ABiw6n3rX1X4dNoVib2dYcg4CJgk+/Sk6lnZiq4aEOpMuuaQ16tmk7NM2SuFyp/Gr+Efl WDfSuPsI1OpRlQAApPT2FdJECpyMj6Vo1ZHC99C6EFIVABJIFVrzUo9OgWWSMuCwUY9apNrb TjiCNF7bn60rNiuLe6mttNsXT4btSuf3rkY5AroW0vw5J4Pl12KxgN/DGHls3kAx06fnwa5O aa0uQDNOkcgBG1WHIqyvi+0s9NXTbjw3ZammNrSvMFLjjAYEHPQU1dBdF21m0y7iMiaFbR4H Zs44qFJkZo2S1ihBdlwjE9KSz16PUpdkGkwacoTJjjYMBj6Y/lWi1oZNKa74V4rnBVRgbSvX 9azqPWwXHLMQMMoP0p3mx9+KqNcRxAb2AJ4A7n6Vr6P4R1PxAfMlkNlYYBLhf3rfT0+tOMWw uZ0lxCjBd67j0UHk1atNH1C/AkERghzjdIpG76V29v4e8O+HkO2yM0wGRLKodvzNQrqrKWdy ixbiNh4H4U3yrdhcwU8O3iDbCUOPXvStoGoj7yqtas/i+3jXy7OzuWfvhBgVmv4gad/niuUY 93BqXJJDVync6LdohLqOBnishgtsxMqocdn6V1dpHu3zC5wWGDvaqt5Ywyo24RyDuKzVRPSw 7mPb3kUnCwWp+lWQ7EZEMGP92qU9hatK0cdpsmjXcjIcbj6U+GzmQbpH28dA9VyILFoySf8A POIfRaYZZB/c/wC+aYCFOA7lvQVHd3E1rbSSrCHdRkIerUvZpiJfMkH8Q/KmmaXtJj8K5tfF Gryn914ZmkHqGHH609tc1yKJZrvQobaFjtw02XJ7YHT9arkGb5mn7zN+FNMsx/5byf8AfVQW t0t3bJOF27hyvpUnXmhILgXlJ/10v/fVUNZeVdGuz58y4j+8rHK8jmr2QKjmYCCTocjGCM55 FITlY84kkn86Nkv7tiZEAAlP95RXplpcrC+w3HOxc4bBBwK5i8UCSMhEB8xMYUcfMtb01pap AZY7iKZnky6ORkHAoqvliZUqspSsaxuSOty+Pd6oTZeZpft6lMY8sv3rPKyt1lix71XksYJG y7Qk8HIrhjOXMdbNjnux/Ok2k/xN+dIkgKg5HTqKdvFd8XdGTbE2kdz+dIQccsaUtjvUcsoE bH0GeKq2grsdtJ70mwGo9Ki1PWrOa703T5J4bckSqB8+R2A7kinSXMMMiRTyCGR22KknBLen 1osHMSKmaa6CpFYKMgqfoaYzKxqhEe2k8un7gDS7hS1AgMYppi56mpywpp69qAsdYdEX/nit VLzR8WsrCNQQp6V0THrzUE4BhdfUY/UVoyTyUnGRmmk0SjbIyjoCRTc09QQucGnKs0jqlvC8 0rnaiKOWPpUddD4LtvP8QLIRlIE8z6HOB/OlOXLFyGYe25hJju7aS2nH3opPvL/nNG7NbnjF Quvb927zIgc59AgrAzWVGsqiuBPGAT1q3ZyeRqEBxkb8foaz42G7AYfnVqaaJdjI3zKcmtZW y7DPsKz77TzqckatIYYU5kmX7wHovpn196nSVLiFZos7WGQDwR9axfEk0MNtayXl1dQWfnYk a2OG+6cZI7ZqYxbdguYfiDVLW5vI4LaApFAGTMYyGzg9fXr+VZMskflMIIrjdjGCK6DR7zRt W8PzafPdaZpIglG2QMBLKPnO/P6fjT7nQ/DukWs7yeIJrm88v9xGH53EjGVxyMVrDExpS9nK 5k3dmLHfSadpksYlcR3DqZUjUlhjpz2Bya6Lw3dTQWX2+HTzcWz/AOsCJuljTA+ZV7/QGsrT I/Etwn/Ek8OXjzPIpM88HyADtzwRXo2k6F4sRlP2DTNMIbczPIzZ+mBXoJXV0SZ2uW9rFZW8 8V8l3BcsRlTt2/U9qqS+HtH1GXz5PmaOBWR0nADEcbDiukn+HNje2V5b6rrbv9qkErfZQF2M P7vBGDnnjmqA+E2nrYNY2nifUYbYtu2sFJz9QAce1So2LUkjJfw74at2iRoZPOmUn5ZAcEDo a5nVbKCw1GWK32eXkNhGyATXZL8HJodxsvF0pcj/AJbRBx+p4qi3wU8SCSSVfEdn87FifJIz k5zR7zZpGskcnZqeXwBhsAn6V1fgywstV8W21lqEENzayRuzwSnIbGCDj2qFPhd4otvk/wCE h0dlzkiTI/pT38MeOPDIbU9Nk0i8kj6G2DNIM9QAR0/Gs5Ox0QxCehqXHhmC1nfWNUj06HR4 YknkttIDRuYW4WTb3OVGce+M1n6j4f1K/had9fkltkKtiRizxI/KA+uAQPrWfJdeJP7Aew1O 7T7EihSDGRORuJCE/wB0E9PSn3+papNpFrZ2t1FYoiqXZTvZgFA259Pr6Uk77ikpszEBsr1x GRKU+UMeh6Vo2epn7URqEgihK5DBeh9/aseB2RgJHDPgHJPJ96uXWoyXW1blY2jijIUKvOMd PetZSurHm1VJSOpu7SzeT7K86XDCHzl2gEcjI61zFhptjqEsyXUDyKjttCHGOT/hVm90LVrO 9WC6mtWaaESQtDIcGPb0J9QeKd4caRbu5QxkEN825SM8tyPUVphl7+oTvyEg8KeHmPz28yN/ vVDfaJpVrayNFDJuCEoSc9q6iQF1ALxRZ43zDAH1NYurRn7DchLmGb90cPDyo4PevVqKKR5k ZSctzE0IBLh7hNhG0qCDkH8K7+5sNvh03rPIEaJZMD7pPy/41yel30F+p/0aGwCyeWd6YGRy T9DXS6tfW7+E5rOK5lmdUGwIwI4xwAOo4/lXzuMl7+h69KPumh4UtrD+y/7ZkhWTl9vnLnkM y8D/AIDWwniTUmBEMaJH1CjjFYWmO9zoVi8FpP8AZFjO1SmDnexyR+Jq6k5Kf6uZVHBBFSlU auzXk0Lr6pez/OYopH6fMcjFZ+oXlzKgCQWwdTldwPFZj+IrKzzHcC9DDq0ceR+dVn8XaIRz Pf49o8VKitxqm3siyZtW/he0T/diYmgXGoY+eT8VgNUF8U6I3CXOoA++KefEuikYe5v1+rVu lFrUr6tUfQtFrhs7pLnP+zFikWKUnLNft7HAFV11/SZXWOBr+dmIACNmri+RM2FS6JzyWc4F NQitgdCS3Qw2gkJkaG5DY28yY4qjqAg0+zlnkkMKqMbnbIFaUyx24ZpkYKoznzM5rP1K8svs sSyWMN8HUSLFIcjPuO/0q00TKEkOs9UtxahLcKzf89X+8a0Gspkh3Xe1zJhhz0B5xXMf8JQk upx2Mmjwm8c7kjsIyzIO2QOmcivRbPwvDJpSnWGnimmVXIRyGtyQOM9j607GZxJiXQrr7T9q YJNw0bN8q++KoeJpZLqawt1b5WBnUgfeBGMiuo8UeFNc0eOLU9Njh1+G24+zun7wqe5AHzYx WTb6tHfaIq674R1fT0tP3iPa25xGuBnk4IA54xWc+f7KBXuVPDLu8lzYgAsp8wZ/UfnXQG0m zyq1hyW2kR3cOs6bqd8FmjKLviIicHjOce1aVvrFuFVLi6kNwf4Y13L/AJ61n9YjHSW4Pctr bSDgon41FqEG3TLliqghM8D3FVrjXb23QtbWttdDBIR5TG35EVnv4k1K/hmsrvw+9kskRbzi 4ZcAjgEd89q0hVhLYTi7GHdkrNASwAE0eT7bhW5JBZyXW6OFWBAJO3HOKwrv/Wx45PmJx/wI V1ySNJbr5iqGwOF47VFZ2Rz0L87KcoiZAh2xgf3RUKC2AwzoPritFWjX+FfyqGeS0FtMXktl AU5LYBFcLm7ncaENrbmBSJbfGP7wzThaKRlVUj1HNcpZG13h/Ll9/wB2cVqSeKJtOAgtNIe6 j5PmH5OeuOa7KdZWsyHE1DZH/nkPyqvc2TC1lYR7QFPOOlUG8Vahcwcx2GkSHPzXT7sfgD/W qQvdUu9zt4p067gUfPFaL6+pycVu5kWIdP1LUfClzqdtpGs+Q93ChkWaNWwxBClDjhsFhj/C qctlJ4huIbua6fdDIf8AWchmHUk/jXUaRdxHwD4pf/Ry6tEP3pXco2EZweR7H6+lWtWtLXT7 OG3tRa7Tbxyk283mKXZRuOfqM/Qioe12Fkc9oNvDFNeSTSZkkk7n5QAMYHpWtPcafaxmS4mi ijHV2YACuPOsjSnZZbV50bJIXqp47VDaeLZrC5M9rYQXonXa0N4MCPnqPerjdrQGdOut6dcS rHp9td6kxPP2KEyBfckcCnvqdnDOsV7bXWn7h8j30flI59Ax4J9qyrz4javb2VxosWj2NqJQ EF1YykbAe64FO0fx9DFosPh3WtAn19lndo57hhIW3YI5buORWsY33Erm8iwTLuieKVfVGDfy p4tQf4P0rmrvxb4ZsFnjs/B15YXwb7yABQR9Dgiuo07UItRsIbqFlKSIrYBHGQDj6jNOUY9y tEdmUZhkKSPpVZ2Occg5H868b1fx54tlvDehbnSo48f6P5LlG6Z3Ej29u9Wrf4y34REm0m0l cYy/mlQfzqG2SkTXqFL2Yf7Z/pUA5pWvV1JjdqioJPm2hsgfjSWNlqmvagNO0O0+0TH/AFkz Z8qL/eYfUdPWm5JK7EQzXKQFUAaSaRgqQx8u5JAwBXpfgTwvq2l2UtzqUKpc3hVkiQ/6tPkI DH19fetvwn8PdL8Kk3Mzf2hqrZ3XMwDbOTwnHyjmurO455wDXk4zMItckAuclqvwz0bXvKfV bm6WWMMB5EoUc49vaswfBLwiBhb3UwB2+0j/AOJrvjHTfL9hXm08VVguWLGmcKPgr4UA+TUN TX6XI/wpG+CXhdv+YpqvP/TyP8K7oRDngUvlD0roWLrJbhc5iD4aaLbtEYtV1HMY2j9+Ofrx zVx/A+ml1c6nd5XnBkXafqMVt+Sv90U4RAdFH5Vm8RUk7thc5Cy8JaLrkIv5L6eGWQsHigkC oCCV4GOOlXo/h3oCzSvLPcTxyrtaCaQNH+WK6AQRJwkKIPRVxTxEp/gH5VUK1RO4rswY/h74 TgQpDpVmmQRu8hSR9DSaR4F0vRsmC4eZtxbdcRo7DJzgHGceg7V0IiH90U4Rj+6K641pS3Q7 jEjlRAizIEHZUAprWokPzurfUVKUX+6KTav90VX1jl0SERCxjH3fLH0QU8WgHQp/3wKcFXPT mnjHpWkK6b1QXIJLJ3XCXJiP95EGf1qjN4e+0Z87VL5gewYAVrYFLtFdF0wObk8E2Tcpd3KN /eAU/wA6ifwN5gI/4SDVIwf+eT7P5GupwKMVL5QTsef3Xwg0m83mfWtakLEElrjPI+tVT8D/ AA8yBDqmr4UALmYcY6dvYV6TtHvTdi9s/nWfNbb8yud9zzVfgX4fG0HV9WO1dozMOB+AoHwM 0NSf+J5rGD1HnDn9K9JCKO5/Ogqp6k/nUuq0S3c42L4W6ZHOkrarqEu1WULK4ZcEY6Ghfhbp 4SFTreqEQrsT94AcYxzgc9e9diY19/zo2L7/AJ1n7eUdUF76HISfC7TZkKS6xqTqeoaXNVW+ EGjm3eBNX1NFYEHbKB/Su5ESnu350ohXOcn862jjMRJWuSoRXQ4Wx+EmnafefaYtd1N5MnHm uHHIx0IxRD8ItLt9Ra/j1nURcsxYtuGORjpjHau7MS+4/Gm+Ug7t+dYSnUTu2Wm1sc4ngdYj uGu6hn2IFGoaH/Zul3F2+q3MwiTOyULg8iuh8sdmb8TUckEcqlZBvU9VPIrKeJnYbm+pwVn4 Um1e0DPPNbLk7SEG7v6irDfDWBx82tXQ/wCAp/hXZGIEAbmA9Aaabde7ufxrCWKqW0Gqklsz z+f4PabPL5reINTQ+iMqj8gKhPwZ0zt4k1b/AL+L/hXoTW6/33z/AL1RtbjGPMf86SxVW25a r1F1OEt/hHZ2dylxD4j1TzE6ZZcfjxTm+GcyxSRL4t1QRyHLDzBn88cV2htyBjzXP/Aqb5JH R2/E0vrdXuHtpvdnD/8ACqcRlP8AhKtSKn+84b+Yqs3wejPI8V6oGHQ+ZnFd8YjuyZHP/Aqa 0Q3E7pM+xoWLrdyXNy3ZDoWmWvhrT4rays4JJwoE17IMyzsP4nbqTzTL2z1K+1QXhvykOBm1 H3SR3NT+XyT5kn0zTRDgY82U5Ock0/rtbZsn0NJdYu4lCi1Vu3XrUMuo3M+Q8Cqp4K5zVLZg EeZJ+dGw4xvf86Pr1ZbMC3FqNzGhimtIZ4/4RgDFUrm3s76KVbjTIkldiRNCArKO3NKQf77f nUZjO7d5sn0zR9erPdgc9/wiN61xJ5+pRTWuSYtybZB7E9D+VJN4SuGhaGHUBHG4wynJyOP8 K6Aq2c+a/wCdMKvyPOc/Wo+t1HuxWfc4+5+Hd080c0GqRRNHIrhSCQcEHB/KtF/DmqtICt7Z KmACPLJNbmyTp50lJh8Y856bxVRrUlU0ndM53/hGdcWRiNSsmQ9A0RyPxzUV14Q1G+065s57 vT1E8ewyJGdw5Bz+ldMS/TzGpMtjr26mksRU6FW8zGPh+8Ee37XEWC4BwcVWtPDGo29u8ct/ HOzOzb2HQHtXQHdnIc03Muf9YcelP6xVH8znrXwmU0TUrDUYbS9u7lgbe7KZMI24IOeRzzx6 1avPDULfLpVlY6crQRxyeXGF3MBgtx1ya1v3gOfNb6UAuP8AloT9av63W2TFY5+18LTW/hvU 9HuIrC7lvZI3F0+QUCjADDHzY7dOtO193maIz2VlBIUVNtqNqjbwCBW2fM7SfpUM1uJpI5Jc M0f3eOnOaccXW+0xHi2pzxG9IMyAqpzlxkdKoSyIV2lwNy5GW7GvW7vwH4Yvp2uLmxl81uWM chUH8BVZ/h14RcKGtLoYGB+/NejTxtNR1ZR5jbJ5jhI9vJ7mrnlNHJtZsMDjKtW/rvhGDQJE udLkihsHYK73Lk7DxwT780W+i6TewK0viHRInPXNwAwP4muuGIjJXiL1OemDbSGJJPUk5qNL nULZBHbSRxxgcDBrsLPwDpl9I4tfFdrcOqM7rbXKsVUDkkc8e9cxey+HbK6kt0k1G6EZKmZO QxBxx+Vac8ZFJRZ38PihpLZpltre6QA53DP4fpVbSbvTfFazSXHhLT42jcozPGoc4x3x71hW a2trEYFu0J9d3+c1f0PWNN0O5ntry9SISkurkjB6daSsiU7nSw/DTQtQjE8st1osCP8AMiXA QP16DoBx16813WmXng/wzp0en2Gq6RaRRqFP+kRqzEADLHPJOM/WvF/E8uj6my3GZb+M/d8i 5Yjj0AOPWuTLeHozh9FvFPvKwx+tceIpSq6c1kPlvsfTZ8WeGB18R6T/AOBkf/xVN/4TDwsO viTS/wDwLj/xr5m8/wAMA86bdD/tsf8AGl83wsf+XO4H1nP+NcLyyL+0yeWXdH0z/wAJf4WP /MyaX/4Fx/40o8W+F/8AoZNK/wDAuP8A+Kr5j8zwyT8trL+M5/xp6r4dY827KMdRcH/GhZYv 52Kz7o+nF8UeGnGV8QaYR7XSH+tTLruiMu5dZsCMZz56dPzr5th1PTba2WGy0+xZR3urUTFu vVuvf+VWri11S8sFa8stIt7STJxAvlsQP5df0rN5fV5vdeg0mfQX/CV+GM4HiLSs9MfbI/8A GnP4p8Np9/xDpi/W6jH9a+YobbQ1VTLBOJAfUkZFRzJE0vmCG2dQOAsOzv3FbrLnf4mT7x9N yeNPCkON/iPTeem24Rv5Gnx+MPC8q7o/EelkZxzdRj+tfMRSCRCi2tuucchORUSWGkFz9rkn i5/5ZVosua+2Ncx9Ur4k8Pufl17TCfa6T/GrEer6TJ9zVrFvpOp/rXyqum+FWODf6iD/ALo/ wpy6R4WfhNSvgfVgoH8qpYRr7X4FJd2fVy3dk/3b+1P0lFOEtux4u4D9JBXyedL0eBibfUbq TI6rIB/KoY9Ps2lzLqFzCmeGMgpPCP8AmKSj1PrlVQ/8t4j/AMCp4jz0kT/voV8npp+kjka7 d/hKBTZXsbclE1LV3bGQ6T8fyqo0GtLlJQ7n1gXiVtjXMIb0LipPLbPBU/8AAhXyFLbpcfOt 9fs5IJaSXJOMY/kPyrRhlvQox43u4SONpun49vvVt7Ka6itTPqzym9vzFJ5ben618trdaqvT 4gXo+l1J/wDFVIL3XF5HxDvVHvcyf/FUvZy7h+78z6h8p/TNIYnP8Jr588NWnjDUtQikXxdq dzYqSZHWdwGx2DEkZ4I/CrHi3UtXsb2CxsvFeo2tySS5e93rtwcDjGDxR7KTW6LVG65lex71 5Mn9yjyX/uGvmcan4r7ePLon0EzH+tKNW8Wjj/hOLz8XP+NR7CXl+Ji7I+lTFJ/cNKIn/umv m9dZ8Z4xH42lJPGHcj/Gk/4SPxvbKVm8VStgnBQ7sj68Vm8PU6WFdH0kI2H8DflRtcfwN+Vf NNr4r8fzJuXxQi57SSgH/wBBq1/wkXxB/wChrt/+/q//ABNN06600/r5CckfRe1/7h/KmkP/ AM82/Kvnhdf+ILOobxbbqpIBPmrgc/7tdDZ/EVdK0pba78Ty39/k75ExjJIxj2H+cdsKiqx3 19Co2Z7Lsc/8sz+VN8uT+4a+cP7c+IN186+KSFPI/fhf5CoXl+IE3XxXP0/hvmH8qFg5y1ug 92+p9K+TJ3UD8aTyH77R+Ir5maLx1uDTeKL5owcsE1F8474561Rl1OeeQrHr2v8AmbipMt0e ce9X/Z8mty0oH1I0YX70ka/VqgeSBM77y2X6yAV8utpWt3wDf2nPKCP+Wt0TUH/CHai55KE+ 8w/wpLL2t5BaHc+oXu9PX72pWY+swqBtQ0sddWsB/wBt1r5y0j4f3V3qkUV4rC15MrwSAsox 7irOveCLKymihsWleR85Ekq/zAq/7NX8xUaV1dHv51PSf+gzp/8A4EL/AI006ppB4Gtadn/r 4X/GvmseDrvv5K/WWl/4Q+5A+9bsfaU1Ly9L7X4GbVmfSJ1HSiP+Qzp//gQv+NMOoaWems6d /wCBC/4183t4UuYwGeBdoIztkzkZ5/TNPn03Rph5VorCcnAUucn9aX9mr+b8AsfRv27TO+sa f/4ELSG90s/8xjT/APwIWvmv/hFr0422Mr+6tR/wi9+Of7MuAPrQssivtfgFmfSguNPb7uqW LfSdaXfasflv7Q/SYV82/wBn6SkZglhuVuF4Y88H+XpUY8NXEnzRQSlTyrBxyKHlit8X4DXm fTIgV/uTQsP9mQGj7FIeRtP/AAKvm6LQtWgULFPPCB0AuMY/KpxYeI04XVbpfYXbVH9mvpIr 3T6Iazm/uHHsaZ9klH/LJvyr598nxWnKazqP/Abt/wDGmiXxvEcx6prP1Fw5/wDZqTy6XSQJ wPoI28g/5ZP+VMaNh/yzb8VrwZNd+IEOAuo6scdMgt/jVq18Y/EKN8G5vJM9pYOP5Vm8uqrZ ol+R7WVwOQR+FRkD1IrylPH/AI9hODaRS47vbnn9RUn/AAszxup+bRbFvrbN/wDFUo4HEPsL Xseo496TZ7ivNl+KfiVRi48M2z/7isv9TU0XxWvy3+keE3Ax/wAs9x/pUvBYhdClFs9CKmm4 NcWvxTtMfvfDepL67Upx+Kuij/WaJrCfSNf/AIqk8JW/lH7NnYlKaVBrkU+K/hZziS11WH/e jU/yarCfEvwe/wDy9Xaf70B/pU/Vqq+yyXob11ZW1/ZTWd3EJIJVIZCB1wcH6jOa8m1TwRZ2 WpvaMLkKGysijKlcnHP0FelReMPC1wvyazCvp5h2/wA6Lu70TWbfy7bW9PkuFGUUTjkemKvD 1qlOWzQk0Z2laL4Pl0OTSpLSK1keNhFfRvtlyc8M3XBzyD2rDuPh/wCJ0mItf7Gnt+sbh2Hy 9s8daqXOmXMcRWERT8cDzcCsJrHxHGdsZEa9lW5bH8692FRzVxo6eXR7FkKNaqu4Y8xByPet 3R9NjtdOSJ2t7socB5IgWxgdfU+9TzQZzgfkKba74X6ZH0rZMzRSuhGusQbIIUyjhlVAB0Ha i6hhCM8sKEKM/dFTaiM6lYuFOTvHA+lS3FuJUKSDKkYIrnrNmkUjJtltrpN4tUA/2kFPEFjJ cGBrBSwG7cYfl/Opzb/uwlrLsCkZxg8elS70RlRmXexwATgnAzWWrehXKuxWbTrI/wDLjbHH T92KhfSrAklrG2z/ANcxUupXLQWxCfJK3CHHFV72e4jNs64CHBfjORj/ABq1CYvd7GJq+mxx zEx25WHapPlL16VQS3kSxluDBfXBnlbyo2BJjXscdu9dtp81nLqV4mpX32e1jRHiVVyWO0k/ qAPxqnq2pN/aKPp+5YPO8smSPaWQbucfl+dQq/LLksbRp03G9ziDHcAE/YLpR/1zpqLKx5gl UAZJZcAV2d7d3aSwcqI3JDd+1Ymu3ahls1bDyLl9nJAz+ldcZN9DB2MZv9Yzg7UzgZNNDeZk rHI/OCUQnmteO0QQtMYg6rgKjjr71ps7WKWpt4YwsrgOAvTjr+YFNysScqo3H/Uy5HrGads4 5jbHutdQ95HcxkxwjPIztxzVRlYt8wX8BU88uw7GA0ISPzFQAZx0waGkAUJJjrnnmtG8TdMi ccc/5/OtrTNPtreDzWj3zOOd4zgYHFJysrhZnJBYm6KDkY+7Tl25CDgY9K6q7iR2+SAKPZaz 3VY4nYqMKpPIqYVFIOVmMqsrn0FRsIFY58vLE9QK1tPsxO+x8kAAsQfX/wDVW8lhZFNjWsR9 CVqpyURJM4sLBkcR/pTjHA2ciM11r6ZaLkm3ix/u1Vlt7QNsWBA2PSp9rFlKLMWO+v44lt49 WvYLJc4gtpCgGSSenX7xPPrU12LWaP7Qlu4Ejk+bNyzHvkn61pQ2LyF0tVRZGG0EjjmtC30p bbTILS8RZXV3c5HHzHt+ooc6a3Noqq46bHILHBkBdmfY0pihyQdufrXWPpenIjO9pGoXnKrU Q03TJIVmSBCrLkEqAcU1Wj0MnBnMokaSCRQm9TkGpJLyd8Byu32rVks7UE+XAlZ13GiSgKMB FLYH41XtIvQnlZWeOGT5iF6d6atvAFwEU8etdNb6JaSQIZYg8hHJzjFMl0iziH+o/I03Vjsw UDnDbQk/d7+taFniICGPS7aUEbjKyjcoqw9lbFhiLGSB+v8A9etOLRCIZMM+2RAuc9F46Gol UpxWppCk57HMzW4dyWXGeykgVH9lUZwGzj+8a6VdC01seZ54OOz0snh6wjTcv2j8WpxrUugn Sa0Zy/k7TndIP+BmnuD5gPcnNak1jao+0kgE8ZbmqNxGqXAjXIGdtac0XsRZohaMtzudeP4W IppgmKFhLcBehYSHit8eHoHXLyXCH2aoJtKtbRNv2ic7+AHapc6a0K5WZEZkRjm9vkRuHEUx 5H9auXItZbSNrQ3gG85aWQ5yBziprfTpJWmWBz5pQhd3TmtA+HnaGKGaeaNEAxtPU96XPA1h Gq1oc0I5uhnn/wC/hpfLl/5+J/8Av4a6L/hF4u15cfmP8KY3huNAT9rm6ev/ANampwZk0+pg IZkb/j5nPbBkODTUBEmQSDnOQa05NLVDxI5wepNVbWAXF/HblivmSMpK9R1P9Kaa6E2ZADdj pfXYHoJiKXzb0cf2je/jMa3D4YXH/H7N+Y/wqrLoqxnH2iU/U1LlArUy2aRpWZnLMx5Ynk9P 8Kk/0zA8qW5WMcHa3ApbmIQPtyTjHU/St230K4ltgE1Bo4HAYqAOTgVTlFRuS7mCGuAeZ5D9 TmlEkwz+8Y1t/wDCKsD/AMf7E/59qcPBszcjU8e2KzVWA0mYW+5BytxIv0NOFxqC42ahcqPZ q2z4PuBwNUX8RTT4Su+P+JjHjPJ2U+eDDlZki+1UdNTuQPrS/wBoav31O4rXHhO8zn+0I+// ACzo/wCESvQuBqMIx3ZKXNBC1Mb7dqf8WoTt9TR9svjjN3L17Gtj/hE7skD+1IAf9yl/4RDU M8albEf7lHPBBeRjfa7ztO5+ppRd35BKyuQByc9K2P8AhENSJ/5CFt+CGj/hEtWGQuo24GME bSM0ueA7sx/tt8Pu3Lg0g1G/U/8AHyxPutbH/CI6oOPttr+Kmk/4RLVf+f2z+mDVc0WJq5k/ 2jfkf61T9Upv228PVoz/ANsxWt/wiWqg4+12Y/A0v/CJax1+02P680vce4uTyMN5JHOXit2P q0IqFoEPJtoc+qriuh/4RHW/+e9lj8aa3hbV1/5eLItnkZPSlekCh5GSt3dogVXAUDAAFRyX dyWB3np6VsnwzrA6PZ/Xmon8Mavn79p096anAqzPU1TmnqgU/dFSbCGpSeK1IRg+IXaCKCeM DcjH+n+Fc/L4wuowofTVfIzlGrovEg3aaT6MK4e5xgVLhGasxp2NM+JY48qbE2wY7iyDg/rU MniTw5O6G/N7IYmyht12srdM5rPXEsZ46ECoWgXzh8vesuRQehSk2jYfxJolzF5VteXhmbO1 Zo8L+dVDqsQh3LevNKn3oW6Ljng1lXMQGPlGD6ikto1bcCBnaMVau9hWOjk8QWMerfafs8za eyYbcvzIQBz9OoqW/wBY0i8jim0663sHBaNgM4rnku5ArQlEAPAfuKS3jEYZAEBBIBUY4qXd sbtY39S1a2mVfIkUlD8y4AI6cms6WOxuw88WoW7yEZaJSCaotaSSkhWRWIPJpsNtHCdgRAQM ZAp2a0uSbSshtRIskIxxtJ5P4U0XsTxKQ8ZdOq5yQf6VVuAphZgvO7is2NALp22gMepx1+tU ncDpUEMxVZL2ztw3AZnxj6026OlW8kcctvLcvjDS2042fWsG4ghmP7yJGO3HK1EsSRRFUUKu Og4FCkNFmRIrnUBJ5zIoddq9sDHWulBgPC3MWB/t1xsIHm9BVj7PD/zzX8qU1zKw76nWfu8f 6+I/RxWdqFiJoJBG6HcMEK3OKw1toVbiMD6VYW3XGVyPoahQsVc09Ds0tYJA7kMzZzIee/8A jWz5KMvEsf8A30K5F4+eWb/vo03ylHRnH/AzSknIE0jqJVwuzep467qpPalW38H3zWMpCdJH /wC+6QzYyPMcn03UlTaHdHUaQ8MFy7XCMylflK9j61fuAbqcuibUX5V3Hngtz+tcOZXP3XlX 6MRUbGc9Lmcf9tTWUsO5u9zaOI5Y8p2bSLHMIZPvEcD1FNlt1ZdqAiuKAnC4N7cZHQ78kfjU hN0yBTf3WPZ8H86tUWjFyR0Etq0WcqfwFYOoGcXDrDB5of5GGOQMHJFIPtQx/plw3P8AE+aU iQncJpFJPUN1rWMWmQ3podmLJ44w2GI9RVeSIONpBzj0rlQ9+Bkapd5/3+KkE97jm/nJ9SRW bhKTvcpNJGvNaOHwAexHHuD/AErVhuL2S2WCZYwiqFBVcEgAAfyFcr9qvAOLp8+po+2X/a+l H4Csp4fn+LUpVHHY6o27rghM/SopRKRj5x+Fc0L7UgcjUZfyFI2oaqQQt5k443Cn7OS0SBzu al3HGNpZTuLAD5c81mnSLufUI3NrJ5fmhjJnjvSNealhiJlzxjjinjVNbUYW5i2+hU1SlOPQ ltM6OeS6R4jFbLLGzfOWONorF1jf9qt9sTsuSWKjpxVRtY1lThriEjnjaf8AGq763qobG+3x j+6alKcnew20ka2nanBpd751xbySI2Fwg5Bzj+tdBNdxXLiSNSq/7R57/wCNcGdWvzywtmII IJSrEGu6tnragf7hqalKbd0jSGJcY8qO2XDJwOKrXSHYQoNc0PEGuL0ktf8Avg0h13WH/wBY 9sfoppKNVdDLnuW7hCCxCn8KzNGgnbxDAfIuFSOV2YyRkDo3Ofqam/tO8J3Hyd30qX/hINaC 7Q1rjpyprZe0S2C6Z0ki5Xpisq4iIJI/Ws/+3dXIAY2zf8BNMOq3z/6xbc8dADWfLUvewcw2 60W/vZd0MKNGcAtuIIHGa6u1i8m3jjP8Chc+uAB/SubTxFrMKlIUsgn+2hNL/wAJJrWeYrL/ AL5NXJ1GrWFc6osoPIAHfinwywzKTBIsmODg9K5MeJdX729iR3yDTU8RanDuEVpZJnn5QQM1 l7Oqh852QiJBJWmhMkAEDJxmuS/4SjXMn5LPH407/hKtZON1tZH6ZFNwqdh86OisJ5bqDzJI Hi+YgB1weCRnFWZIiykbjXKf8JZrGP8Aj0tPzNKPGOtjOLGxIx3zS5anYakbkOyw1T7Kqyye cpkLsc4IAGB+daqhmOfLx9a5VNavpYX1OSC3+1REKkYzswf68VH/AMJtr4PFhp4+uafLNq1h 8ysdgysg3bAafGhdclCD6GuL/wCE18Q97TTvoAaP+E68SKMCy0364P8AjUqnU7C5jtHVQwVs A9gad5AxjaPyriT468SHJNppvP8Asn/Gk/4TrxLjAttO+u0/41Tp1exPOdpIoiQsUJwM8Lk0 kR85AwicA9Ny4ri/+E58Tf8APDTs/wC43+NL/wAJ54oHWLTSPTYf8alU6vYOc6y6tmmeNRPJ DtYMQv8AEPQ+1Nh0uOO4aYSTMTwVZsj8qzfD954j8QxS3dxb2sCA+XDIVZFJweeeoyOv+Rk6 x4k8YaBqBsruGwB/gkSNikg9VJPI4qFRquWwc52DxqvbH1qnIyq+K4o+M/ET/eFl+KH/ABqC Xxdr5blbPp2Q/wCNbKlWvqh86PZ3PNQsakcnHBqBzXoGJm60nm6ZMuccVwt1DiMjPSu11qYx 2eB1ZgK5e5g3ROR6VOwWuULUAwk980rx5cNRY8rIvow/UGp2ZFHLAZ6ZrGrvcuOhmXSHag9M /wA6gtxtfPtitC6AMSFcHOTn8qpqMNzRTuNjJVBPTPIzinqSrqcd8VMiB59pBGfX6VFIpVWU /eRs/hiqUrPUW5cjBDKT0warn/Xkd6njfdGrVWY4uCapu+wWJWZipXtmqu7dducYz2q0oJU1 VcbLzbjkjpRFMQ9z84+lMblTUl1G8bRF0ZMqeo681H1Q0WC5BB/ratFsGqUZxIasYJNNq4Ie JMtwCatxeZj7uPrVRQVPpUyxNJ1lYD2NCAdMrkcsv4GqxUgEsWI9BVz7GAcmR2+pp3kqvQUA U1QFchSP97rTgjd8flUxXBpCaEwsR+VnqTSiMCnZozSuMTaB0oxRmjNK1+orCUd6KQmk0MKM 8UlGaqwBRRTScUkg9QzSpy4puafB/rlFO1guXFj+UkipCgxUm3CGmnpXJU3KRn3g+YVnSn5v wrRvDyPSsxz83PpXTTXuiaG5ycelTQ9ahqWL71aWJuWM80vem0VLQ0x1L3poozQA7NGab2oz xTsgHd6O9JnmlzzSHYUGjPNNzRmqEOpAaM0ZxUgB54pkjNHEzKpZgOFHc9h+dO96s6dEZ9Ws YgM7p1yPUDJNHKg2Na88PzadZTwC5aaaJVmmUnhevHT3rB9a9Lt7FLn+2rmQeZJOzL7KPL4H 515o3Ekg9HYfqaSQJhSZ96KSnogD1pOKWm0CFprAFSCOMYpRUVzv8iQIDvIwuPU8D9SKaV2D eh6n4EmvNT8HTPemNoUuSlthcZQBhk+vOan8SaFFr/h2aPP+mWhMsDDqFyMr9ME10OlafBpX hKwsIyN0cWGXuDluv51F4dKrq+J/mjV8knuM03FJiieAAlkU4wSMkUxzhq3PFFgNO8SX1qiB ESQgL6DCf41iMATzTs2Nnu7nr0qFzWdb+KdDusrJeiwmHWG+HkuPwatIKsq7opY5AehRgaG7 ko5/xA+IYh/tZ/lWLndGQehFafiEObiGLByeAPxFZzxNEShByODUvQZlWYxLcDpyv8jV621C 0tVkS50qDUNxwiSnGD9e1U4FxeTj2H8qguNUs7Kdop0JkJyCuCQPpSb1Gmahg8HamfJ1BNR0 e7wBC1u2Ycc8Z5A/SkXwt4URhu8azRn+6zr/AIVlpq1jK+1ZCG6gOmKR7i0+80KuD/EEBolJ vS4m2zT1TSNDs/Lu7LxSt3MzqpjldVQKMZPHtVfVdIisBDdp4h07Uvty7xb2rgtBkE84J9Mc 96hmt4vtFuG0yO6+cP5RwAy8Z5+lO1aWHU5/7Qt9EtNGhhxCltE4Lnj7xwBwc0KHW4KL7leD 7uKhf/j5x64p0GSqH+8D+lMbi5U+1N6IexL5wV3Xaev9BVeST/S0kzyOBmn4yzE1Wfm4HehA 2yeaeeYqZmLYBx7U1D1HtUs3NvGw7g4qBeOadhoiT/XgepxVzGKpof3/AONXaliG96sQGq/e p4OtJJoZcpCOKUHiiqEQOtREYqwwzUTLSswIs0lOIxTaizuAUlGaSqvYBaSjNFWgQZpM0Zpp PFDXYegpNML80EmqzZDHJNTYVyUuBUtq4Nwn1qn1qxZDN3GBQ0mgN9uhApjDipWXg0wiuSUb s1RlXnSsxuXP0q7q0yQIpdgoZsDNZ6urruU5GK6aK0IkL0qWA9ajqSLvxWtiSxRTQecUZ7Cp BDqQnGPrSZpM5osMfmjNNzxSZpbAPBpc0zNGaEwH5ozTc0Z4zVJCuOzxRnJpm7ORRnnii2u4 D62vB8IuPFtrnpDG8vT2x/WsP+ddh8PLYPfajd5PyokIOOnOT/MflQl3BnQ2bSi+v4UB8sy9 B6mPH9a80mGy5uF9J5B/4+1enQcahe7SQpnHGf8AYFebahH5WqXielxL/wChtUXsxorZ5opK KpAFIfalpO9Gwgq5otm2o+IrC1Xn955jD/ZUH+uKpCux+GtiZ9avL44xBGsa/U8n+Yqoks9T nKtGTxyegHNYlpeGz1xdkbNu4wRkZrYdgFPIB9KwXI/tdGSYRy7+Nx+tS3qNHDfFCzeDxc1w /W4jEh4xziMf0rh2PI+ler/FqCJ7LSrssHuCro2D6MP8K8lfqPpVQV0Ue6XVjY36Bb6xtLkD kedEGrJk8H+H97SQw3VmT1+xztGPyBxWPdeM9QbK21rDGP7zc1lT6nq17zJfOi/3YxilzNbE bFjUNLtrLWbaC21m+RJNxLzziQqQB0zUE8V2Jm8jU1mHI3yx53e/GKzY7KS6ukjTdIwUli3J NaawtbARspUjtUyTe4blWITJqLiZkdmUZZRjtXVWXhTQ/EWhKdSgkWYOStzb4EmMDjJHTnpX NNzeIcdR/hXf+HgE8PQg8dT09hU7IpHAax4WsvDmJbC7upQxKlZyDgfgBWFMd0DAcfLx+Vdr 4yYtaRr3L9a4lkPlkH0p81xWN6bElpA/fH9arywefbmQg5jdk3D2otnd7Fd2NqdPWpbW68pb lGiZlaZmBAyASBSe5VinZLuhjJHAdv60y5G2ZcdqfavsUqepct+ppLs5YGhPURCDwarA/v19 c1NniqxOJlPvVWAuNxaxknrmoc8VZfm1A9BxVXtSuLUhT/j5H1FaGKowgfaB9avE4oYDcVJD 96oieakhPzUajTbLwpRTB0oJqrgKRUZqTNRmgCNhURqVuajPpTEMzzSdaUikqbDEopKM07AG aDSCjNKzC41uaryD581YNQyLk00BGDViwx9ui571XKE9yKs6amL+Jic/Wh2sB0rDINRcVOw+ U0tjbLeavZWUjssdxLsZlPIGCc/pXJLfQ0WxX09oYjcyz2FreL9wJcpkL/tD0PvVJ9J0bUZ2 NzM+lqo4aEcH2Na954d1zTHngksvMh3FoZYDu3r23Z71kyuLISLdYjlQZaNjhvyrqjdRIauJ /wAI54RB/eeJ733IXI/lSjw14ZmKjTPGoEpOAtyhAP8AKs060MnZZ8epPNSQanHI48yBVx0Y gHBpNVO5nyeZpeGfBN94xnmS11O3t4bbKuytmSRsZBA/u8jmpfE/gHUPBcUN1cail5a3BMYy pV1YDPQ9qwNLYwa7aSwahcaY0jiFrm2lMZVWIHJ/ujvW544JttWttMOr3OrPaRbmu5Lkyq+/ djHbI/lVa2LUFbc5/d1o3VWLncaPMNOwFoMKN1VvMNHmGgCzmjNV/MNL5nNCAsA0hbAqDzaB KOlAFgGgGofNoEo60gJ+1emfDm0CeGzdE5a5lZ8kdvlx+leVyTbYnIPOOPr2/XFe2+HLY6fo VhagqPLt4859Sqk1f2RFF4vL1O8ZuG81SPf5V/rXnviGMxeIr9Tx+/Y/mzV6PdqGvJXV8ncD 7DpXC+NojF4jeXbhJ1Dr/wCPVktykc/mjPNHFFUxBSUZ60maAAnAr1b4b2C23hSO6JxLdu0r H2O0j9MV5NJkpsHVyFB9yQP617zpNtJYaHZWsSIFigRQW6/dWrjsS9y6YlOTtI9zXLawAt1u UNvU5BxXWly8eSxLYxtHQ1y+sNJHcAwkb/Q96iSRSMfxjp8+p+FI7qIowtCZHU/eK4J/oK8h u5ZElUKpYbeoNfTFhFBqXh+aNrVSJbaVGXr8xVq+ebvSr+a8n+z6fLJGkrpndt6MaaugPS4P D9rG2ZCWPtUl7aWlrYyskK9Op607+39Byf8Aic2n/fwVn6vrGmXFk0dpqNvPI38EbgkioVSL 2I5kVPDtnsWW8805kO0J6AZFVddnMN6DgkFc5/E1o6XqGlRadHGdTtBIC2VMgz1NZHiVkkaG WGVJlAOTGc461XMri5lYqwXAmuEwCMetekaSAmh2wJ/gB/MCvLdOObwA556V6pYjy9Kt0PUR r/IUpqxcGmcd4qRvMQs+Vc5C+mMVy5XO4e1dF4kdmuFBckZOAR04Fc+cLISfTNQtikSWLkxO nYEf1qWB2VpMMcF84/If0qGyQq90MfddRj/gJNNgJNwy7uA7fzNZ83vFNEiACo7tsjI6Yp8v yoQKrysTGM9hWkbSJasMycVVJ/er/vVZzxVX/lsnu2K1SJNPrb1WPSrCt+5xUBz3qRldDi4H +8KvE1nt8s2fcVeJzTsAhPNSQn5qhNSRHmgC8ppTTFNDPtUk9qTSYCs4QEk8VXiufPd1C4Cj rVKe5afgjC06xOJ2Hqv9aNUCLE9x5cpXAPSmrdI3UEVVnbM7n3/pSDmjVlbF3cp7001WHBpy kgdTRqImpAaj8wilDZouIdnikPSjPFMdtozQmx6Ck0zqTURY5JyaehyD9adxDqns/wDj8ix6 /wBKgqxZ/wDH1H9amWxSOlPIatLwtafavEcLk4Fspl+p5UfzrMPCsfaul8DxELqF2cY3LGCf bBP865o2uUbGqTMqlQxGAehrxnxBKLvXLqVwG+YgE+xavV9auRHBPIeiox/8dNeP3TbrhnP8 XJ+pJP8AWt6ctSbsh/GnKaaelKnWtrkiupdCMA57NyOuefyrV12eC6h027ggSHzbSMSKgwN6 rzwKyifrTljGO/TpmokrjTIR940pqby1z0o8oGquIgJozxU/kg96TyP9o0ARbqM5p4tyMndR 5Le1AEYORS5604RMBR5behoATqKKTawJODS8kd6AJLZPPv7SAdZZ40/NxXu8DDJjHARQoHsA B/SvEvD8Yl8UaUrdBcBz+HNexWUgM0wLcnpTb0J6kF23+kyLgZZlA9+a5X4iRbLrTZM5LRkH Hbhq6WVS+oqC3PmAn0FY/wARY8WFlLxlZSD7fL/9esykef55pc0IC7YX9TUhgwMs6/QHNWNE ROaOvSnlRk4zxTTuGeO9LcRc0O2F34i063YAq0wYg/7JBr3aHITDE/KB+QrxrwTEZfFaSf8A PKByD6ElRXrsc7p/rhtjI++Kt6KxPUuOHRSDgr2xXIa/n7SSARu4wOCetdHeXLRwFYW3Ment XCeKtXudKtY2KedNKxClug7/AONZNvoWkdhpPi7w9o8SQahdxWSpHlQ7jc3XtXk1746TTtUv 4rC3ju7V7qaWOVjg4Zyf65/GubjtYZb2GS/Z5FaRfOkLEnbkZ5PoP0rsNQ0bXreaMaBo1vea a8YeGWOINkHpk564x+dZTk4vVid+hSOnWJz/AKJB/wB8CojZ21u3mRQRo4/iCjIoF7cEn/QZ ePcf40x7h5ImLwtGc4w3Wqi9bHnxi76srwaVaSIGe3Ukip1sY7XJti8Y/uhiVP4VbtyjQqVO RSy8LRJsJt3KduxW9RmADbhyOnJAr1WMbLKP/dH8hXlsPN9Bj/ntH/6EK9N85NhiVwXQDcue RT6HTh3dHE68xe6Tccn5sZ/CsWZf3bnn7pArX1nJu1yckA8/iKyW5BHXjoaVup0rQkhdNpbd tLkEn6UsSJD5k2dwLdx3JzxSNJFKxAI3rjco7VCzNvEs2PLjbKoP4j0rF3bKuR3bspVQGIAJ J981CqmWNiMk7cgUnmvnJcn61Lauzs+QPlTORXVGNkZt3ZECMZqA4EqHtuqVNrNtxkio2H7w ez007CLyj5N1RnmrC/6r8KrH7xqW9QRVmz5vHTirYcY5IzULqGlPTtQylcHaevGBVLyGS5BN PQhSeaqq5J4STP8AumngHALAjIzgjBp2Af8AbZPMbCgAH86uLL51vvHQistzjpUlrMYwyE8E 56/59KXKhXGYwMe1Ptm2zZ9qYfemgkHIpjQ9juYn1oB602jNHQCQZzTxTENPBpMaA+lKBQKW kOwnao5CTxT3OBmo92QD7UxDDn0p8fQ/WkLY7UgfHY0bgS1NZ/8AH5H9aqb2A6VPZSE3sQI7 /wBKTWgHVHHNdh4Ti8nw4k/a4Jkx9dv+fwrjZFLAoOrcfnxXfRYtNHtLVlCNHAi4Xpwornil e49jmfFNwY9MnGcF/kH45rzW45f8K7PxrcEW8CJz85c/h/8ArrimYsea1pq+oNjKVetBpUFa ki1IBxUfepgMigBBS9KXGCaXFK4xMUUuOaXFLcBvSl96XHNFO6Q0JjNFLS9aNwG9KNo9KWlF BNzT8L23n+K7BVUZQPIT6YAr0OwcG7nBH8Ix+dcx8ObRJtcubp8jybcor9gW6/yrobUmLWJw WGwk9vQmhsC3bhX1IA5IHzN6dqy/G9t5+hyyHko4YfTpWhavjUJZGUsOAMd6NYT7VpN0jIVU p0P1FSwR5KR65zQFKgnJ6U9BlFJGCRTlTc231q+gMhErAnNPMueq96sG22D5k/SopbdDGzBm UgZ4qOazM3Ox3Pw8sY49Nl1N2CzXEmE9fLGQP5Z/Gu+jPmxspIYkY/Gud8KJDa+G9NTjekIz leoy1dDHIkhLLhTgZANaN3HF3FtVKRtHKQSvAY8kj3rgviEhmtYXCYIlb8OK9C8zEUibQfRu 9cR4yTzdIbPVZAfpUO6NEzzzT9Gm1RrkmUxWttEXmZeWIwTx+ANXbLW4tLthbaf4o1qG3HIR OVHbjj2o0abV9Ov1vrG286EqY5o5F+WVM4I+vXBrZuPC+hay4vYZrnSvMXL2pwNrHk4xnjmu SrU1s9gV3sQlVBNZl7PFJcRxLDIWDcuSMEe1Wriccqp+pFUYQGu1PYEmupI4UrGnbqqrgIMV XvBscjsRxU4NQXpzGp/Ch2JauVrL59StwP8Anqn/AKEK9NmARGI2hu7DrXmmijzNftExn94D +RFeiymRmmUwuoU4BYcH6UmrLQ6aC0OM1Uf6XgHPHX8qy3Qbs+1ampZF4wIwcdB+FZ0nGaz1 OgrpsWRypQs3JOeTgVSnnaRsZOAcVKJbb7SC9uFdWA3L/n3pt1FiUuMYZicfWtIwV7sTZX3/ AFq1ZYxcEnC+VyfxFVto71ZhIWwuyB1UJ+oNaN2JRGgAuBjpmmn/AFhP+2T+tER/er9aV+JD 9ai2oF4nFu3+7VYYKhvarSjNu3HUVUQEDHoKbGnYilQSNg5A9q1tNUJZhSN+GIyRnvWW/Dit SydRCFzyDTQMtSOscZYKBgdhWPcOXZnPetC4PygetZk7ckU0S2VXPWkjUtIoHc0NknCjJJwB V22t/KBLZ3E5+lDskUlcgeGRecZHtTAD3Uj61pEU0xg1CmVymeKO9XDAp7VGbfninzEkCmng nP4UphcHOMj2puCP4TTBDwxFODetRZpygkjjvzQO4TZKjb+NSRW6siqZkDEDrSbaQqOlAix9 hf8A57Qn8aqlQGI9Djik8sZwBUyQ4JLc80ILjQmevSprZAt5HRinxL++Q9wamRSOmsonn1Oz hRdzNMvHsCCa7vUnCx7R24rlvC8AuPEEcmSPIjZwR3J4xW1fXcN0ZDBMkqxyGNihyAwOCD71 jYLnA+KpN90O4VDz+RrlfWug1thI8jdQc1z+OeK2p3ExSKVO9Ic4py9D9atCEH3s1OCAOagB +arI5FDBCcGlo2jngflS4HpUjQgpcc5pDSY9zQMd2pM800huxH40394D0BH1psRIMn6UUwOw PKmmedzyrAfSlZhoTDinCoRMppwmQclhgdaeoj0b4bQqdLuLjbjzZyBx1A3D+lW5B5Os3BYg Lubg/U1P4GiKeGrDhV3IW9uWao9egaHXJo2K5bDHYeOcmiSBE1u4WPOOCfXFNurqKO2YZ3Bu CGP0pkhIRQAOfSub8Qm7SdSrhUB4C9/Y0rAcWXkR9nGF4IpfNkADRkB15AI4/GpZkw5J6k5q pKWVWIHRTWsdhHcWcdreQKWAVjyVfp+BpLrQ4NpKAoexU/L0o0lQ9sm4HGMZxWlJCij5cgH0 NQ3qFl1Ol0iMR2FqMAlUx9eTWoUVblWVFQPxx0zWfpK+bYQtH8wA5xz3rRu5bGzt2a51C3gf AKhnGT+FAW7Es0ZhDcDkdq47xFbS3WkXCBSpc4BPArSufGkEqeTp1k80qcGSYbUP0Pes0Xmq arIIb57aJGPyCPIAPvms5SVhpGFdaTLr+k2wtLs2moWURWW3RyFlGScr69B9M1hvo86Ntkub 0OOCN5FdDLHNb3AyrwTL1DDDCpW1O4bHmxQyOBguy8mvPbqt+6tB3aOLEzx7oJVAwevrVqyG Ziw7CoL5PNmPoDT7Eld/HAP9BXqpK1zjS01NImq943+j5pDdKXEcYaWZgcRoMsfwrTHg3xDq NurrNZ2gYA+XKTuHsalRYlFtnLf6Wkqy2srQyqQQ69RyK6FfEfidIFRbq1lGBlpYzk8exqR/ h/4oUFY73SmGeDvYEfpUb2FzpyLa3hiNxGNrGIkqfpmpqQTWp001bRkLSzzt5tyyvK3LFRgV DIMk59Ks47VBIK5o2TsjUxJR/pDn3/wqaRjJDG/p8p/IUl7ZajBuuZNPm+zO3yyqMg8DsPpT LdtyshzknIHvx/hXbZcuhFyPeAff3qyZANLQ/wDPVi3TtgYqmUZ5Aqjk1PekhIoY0ZvLjVQA OSal6jRCZAp3E4AqZiSM4NXLPShAhuLxlLg5VOy//XqCdhJK7r0Ziad1sCRPJcnyQqZAHWoV PFI3MVNRuKlFXEm+8tXbMB4Wz2fr+AqjMrOAV6g54q3pUokWUdCrYIP0FUlckmlLDOTnFZ0u SSTWjJyTVOROtOxLepTyVbcpweoNXrB5Z5GWQ8DnNVtnNaWlRbvMb3xSGmTG2cHggioWIRtr EA1peWQKy9QjfzBhHI9QOlZ8q7GkNWOC56EUm2qO+QNx0HrUolmGMEH2NHJob+wb2LO2jYD2 oikZxlk20/FTysylHl0ZGlmkzEY2jqSKqTOYJSigFQeCa2okEcTE9TWPdjfMcdc1UdDNkDXg QjdGSPapFmEigiKVcjuKltrFV/eSHc3p2FWyox0qnYEyrGTyCKkpxAFRF8vsXlicfSpT1CwM 4Tr17D1qxbWsrus0h8tByF7n606GJLceZIQzepHA+lTGUuu8H5QM/WqsI7jwdbsou7s428Rg 984NSao8VvHM0UUcYJLtsGMsepPv71No6jSvCcV1cMRFK4wwGeWLAVk+Ipf9CkAP3zt69RWE mk7FHFagcwc85H9Kx+9bGojFt6cVjjg1tTBgelPjBZTgHg96nsYfNucY+6MmtGaIJEx2iqk7 EpXMUKQ+Ksr0qM/ep65pXuPYdmgUZpM0WGLSUdqWgQhpM8UpFBFMBvam4GeacabigQYFMliZ 4pAiEkq2MeuDTxyw+orUihVBjHXrTTsB6v4etDY+HNPkkliWNIRyTheprK1bULa/1qS6iISL YqjjHIzk/rWFd3eqayltH5qrpsK4SGMEDIJ6+verUQBU28yeW2PkbHBqZSbYkF1e7MqsnzYz gVz0d1c3l0Y3QCMEkk9adG9w+pyQ3Ee0jGD2IwK1rq2ms7X7RBCsj/xJjkjrxWkY6XZNzk7m BxKxZcdaoybQHA5IUmtrVSwnjbaBuTJHoc1muEkDZUKxGKTZSNzT5pbZU2SoQQMLIeDWyb1m UeZbSDPdORWJalAib4lkUDo1Wj9lPMVxcW5PYtlc1DaA0Rq1zbwC2tbz7LGRzg4NUTbRSyed IfPk/vudxqlexrKyA4kwPvevvVYQSL/q5WXPoazSuFzo4mWJMngCmahFNdW6B5Gjif5lKNgn jPWsWHTNSuX/AHV1u2/MdxPAFdNZ3awQLbX0RkhzyU5Kn1H5VlVmoocWRi+SW3EeqFpNinbc /wAYHXk+3H5VVNp5wWS1uoJoWGVcOKk1C0eO0leAieMoxHljJ6dxXFnTZCcxzPAp/gVyoH4C uWmlLWLsaepfuvs0CPJdJIyAjAQ45+tSaBpt7re77NEYrXfzPICMj/Z9eMV0mneBpNSkW71o MkKsGS0U43f7/wDhXZx2iQQpFFGscSAKqIMAADHA/CvZjCy1OSK01MbR9D0/RYsW8Yec8tO4 BYnnv+NaTSFjknNSGBh0AqJonGcAU1ctJITfxXHa8wbU5D68murZXHXFclr4K3xz3Xj86zqL QpGOXzPjPHSmSjnFMJ+cE9qklkjGPm6+lcdtTRG3a3xOlLAmXkwRl+VXrwK5l/C3iASNLDFa yKXJULIc4rf0+MvD+NWZ5FsM4djIT09K7KdktSHucasN5BdC1axZbwjoeVX3J7VtQ2kOmQeZ cN5lwQCfc+3oM1YF55IMpUebJ1Pf8azZXeVzJK25j+QrKpO/woaRDdTyXBJYAL2UVTNTzMFU ntVZCXUn3xRTGJHLuBXBwPWhDUKMAakXj8q1shXJQxByDzSPcXEQDQCNDn5yB96m55Ge9GNr HOealWEXYHd4Qz43Y5x0pspAU5BP0FLEf3YpT0NUhWKpGOSDitnQ4/8ARJGI5MrD8OP/AK9Z ZTdkDvXQ6TF5dgoz1Zj+tGg0icx0xocg5qztpClSO5ny2EMud8Y69QKqHSFRiYmxns1bW32o 2Z7U7lxqSj1MmK0aOMBwN3fFSRWW9vQVoeWCelTIgUdKEEpuTuzOuIDFCzFsjFc874m3ehro 9UbZbketcnM3J+ppXMzUjcFeOlOcgLknA9TWZZSsEKHc3X5jWvBprud906smBtjXp+PrUOLb GV44ZbrOwmNAfvEdfpVk2scUHloOQc57mrrYC4AAA7Cq0sgQc8U1ogK8Eu9fIkxuAqYyRQoI VAORis6V1eQup59aImzIMknJpa9y7I1odR1vTXf7DfEwuc/Z5/mjB9QO3/16JtU1bUnjW+MA RH3ARAgk4xzU7xg8n1qjDJJJfNGyYWN8ZxXNKKb1EkQ6mMQfXNY2DmtzU8eUcn6Vhk9a3pKy CRqaQhE0kn8O3bV27IFm/fnP61Bp4K2Bcd3/AKkU+95t3XtiictQWxilwxyKkDgD8KgxSGtk roksbh1o3/zqAGguFGSafL2DmLIYUvOM0GzvIYTcS2jiIDO4c4FIrEoC0ci5HG5cZqvZaXuL mF60u3jrx71NbQNdz+TFkHjLHotbdpoFjB80geZ++85FTZLqO5zROD/eH+zzTf3pJ220zD1C Gu5WGCMYSCJR7LSHjoAB6AUuZCuziYnkjnUyWtxtyMny+lbojD9DWtuPTj8qUKv91fyqWwVx PD11LZagtrNHutbnKh/+eb9j9DXWXFlEY2hkQD37j6VyvlqRjp7iuvt5WvtFWRzumRdjkHng DFMDkZriD7ebK9PlyKR5VwvAYdgT61q4FrGomDsCPlfqCKy7uxW5Vt8ecf3uuaj0vU7rSXNt cBrm1Y4+fkoPb2ou7DsVfEcC7YZk6HK8fhWNa/ZY2Y3iFoyuAfSuq1zZJZRzRcxFs8dq5KZh tJA7d6SYGqzW0CARsfL7ZpoMk/8Ax7gZ9ZDgU6Av5KN5YYAdMZqyjWcmBIXhfPYcUrdyWypL b3GUExG4D+DpUqMFXDNCo9ScVYvFAMZjbI28EVWLF8oIXdsdUGaG7K5caV1c0bZry1lWSKKH 0YM55Unn9K07qBJ18+1zt/jjb7yn29uaogJrNo8kaS2upQcG3f5RMuchl9TgAfU0sYmt8Bt8 cqnkE8g158pSnLR2LUeXcieZ7WN5EfYFBJ7D8ay7vxHYQzBZbVJHKg7kTg1p3gju4Hjum2oR yy/19a5e50uOSXLyljjAK8DHb9K2hTcvjRLPcv7W0mRjiVx9VoN3pTf8vqr/AL1Y32dweYx/ 3zilW0LsAI1LHoK9ZqTMXY2N+nsOL6L/AL6qJ1sznF7D/wB9CqbaHdBd32XI9qpy6VMM5tG/ 75pcrQF2SKDnbewEe7CuL8SgfbIyJYn6j92c4+tbE9iV62xA+lc3qMSxSYVQMnoKznsNPUxX BGQOvSlkgDKo74BzT5BiYe9TSDH/AHziuFtmu5csb1bayZACZc8HsBVOSZncux3MTnJ9aiTP PJoPHJNWpNhYack5Oc+tVp5liQsx6Ut1crAuTyTnAHU1mSpcTnf8vI+UE1UbiEln8xuPu0+E /J+NRi0lbqUH1NWYrdkX7wJ9q12EU2GWyO9TfwD6VItsNnznB9qXyGwABnAo1Aibpn3FOUEi leKQDlSOafGykdsimk0BLArYyxAFT7IsZaRBx3NVN5zjHJqRIBIpaQZBFTqCRLKo2/JIP+AH mug09dtjCOvyg5/CuWcBGIjiC8j5vWuis9RsTGka3KK4GNrsAaLpDNHrRSIQwyrBh7HNKKEI WjFJmnCgAAFLSZpaAMbXJNqBa5eY5JPvW74gkzMR7gfyrnycnHfNC0A0NOj/ANGUkdST+tal vOI12SMqgDgmqtumyFF9BUslss8ZVh9KlsaEnu92QvC+vrVCSZn4Yk06ZXjcq4xjpjvVf52P yxSH6KaNGGwq8VPAN0qeuRUKQyNz5br/ALwxWhaxeWNxxv6c0PYepruPlP1qMIMluhxjNSMf vd+aTrXK0rlIytTXMQ+tYvrXQ3yBomHsa588E10U1oQzcsP+Qao/2j/6EaLwfuG/CiwI/s4c /wAR/maW6P7hjUuXvWZS2MQpTG4qctx0qBmyTxXQrWIG5HetrwxoLa1eecSiwQPgB+jt0/TN Y0cbT3EUCZ3SOFBHbPU/lXf6aFtLSOKFFjVDwF9e5qtkId9mklneOQEImVORwxrF1qEpneB8 g4+ldIt46Fs4OTnmsvW3imsJG6Mo6HuKzvcLGRpRENxJlDhgCWx7GugTlcjke1c5ojR+dNHK WOSDx1Awa6GGxd/ntLgOPQHn8qTuND2phOc1Y8i46SRr9ehpkkHGNj/UGlYCuODT1pjKU6Kx +tRmdweI2/KnogsWR+lblm/2cNj7sqAH/GuYNxORwoH1rq0RVsfNfAVIwTn6Ci6AoyIpdjxg 1XktBL0H41JGxlHynGDzxV5VS3t3nnI8tOue9A2c7qsDWNqsbHIkywTPSuXuG+R/oa19Ruxd SmUv24XdnFY0rB1YeoxzVRWoXN238worRenara3YxtubWNvcDBqlp0K3cK+TOUmXgAnitMC9 t+JLeObnGduaJLUz1IrtVeSMKdq7cj2q3ptukizWbyvC06gxXB4CMCOCfTAP508W/myRTSLG ApGU/EVJeWUkMpcPugkGU5zjrx+HFc1eenKaQbMsDV7C48qSUPIhGHdDz05BrQadrhQbgBpO pYd6SfVIooAt+4K5Gx8ZYf8A1uRTH24yrKV7EVyQhFv30U22VbrAjILCsmaQbxtPAFadyAyE djWRNHtfAHGPWu+CaW5LOuT40OP9doBI9k/+vSXHxhtLiIxjRbiIn+JUGR+tcITyab+Fb87O 76tE6pPiRAp5XUU/z9atJ8TLQ9by9T/fTNcQRz0pCq7TkD8qhuT6kOgjvh8RLSQY/tBf+2iV Q1HXLTV9ixXFq7qd2IsBq5jTvDeqeIJmSx09hbhsPdPHhOD/AAnHJ4NdLJ4YGgWIS3sLmaQn 53WPc7//AFvas5tpaswdKKZmSrmZDipZR+7JqC4lnR136bqC/W3apLi7gitWeTegAyd6EYrB SbJdkQxnrVe8vEt165Y8Baoz6zbRxnyZVZycD296zmuIXYu1wrMSTlmFbQjcV0Sl3ll3Octz +Fa0cWI1yP4R/Ksu0aKWYZkTaOT8wrXEyFcKwP0NbWsiblV2/fN2A4FSKRUEreW+SevoKYDI ZxEW284wKLNgXDzTsBR1qqrMMnDEICeTmpVk8xQR37UaodweSwJxNczJIvVV6VC66dHl7eaQ yFuVPSlnSPzMkAscAmoiyZwoGe/FNbENMQTsThYpSPUJT1vZI4yjW7DA5JFPiaY4/ebR0yOK e4BGXmLcdCaT9Bog+0hieCPY1EyxzOPMUEZ/GnvEzPlV49aDFtHzAj3xS8guh32iWCMC1uZY yBgfNkVPD4k1SAYkihnUD3BNVfKyPl5phRh1FHKuo0zfh8WWbYE8E8J9SuVrVt9Ts7kfuriJ j6BhmuIweaQIodX2gMrZBHFKz6Bc9CDAgEU7I65rgIr6/tTmC8lP+zI24VoQ+Kr5AVubSKQf 3o8ijUeg3Wpt91L/AL3H5Cs+1iMt1H6bsn8qbJK00ryN1Y5xnpV3S0yXkPY7R+lV0EaiKAKl BAGaavpTLmQQ20jd8cfWsHoykQ27+bcFicgvxkZq9IOOAB9KzrM7bZXHaRR+taclOSAqv1po 4BPcU9+ppgPtUarYdzSbpn1pD0pBkoPpSHgj3rO2o7la8O1M+tYIUb2zW3q+UiT/AHgKxc8m tqTJZsWwC2QAAAB/rTbviBqW15sx/vf1ouv9W1Jr3gWxlIoZainQRqTgk/3VGSfpVuBDsUY5 NbdtGlmqeQqGcqC0jrnB9q1ckhJXIfCGnTC9kvb2ykjjVdsQljwST1OPwroktHUsFwFLEr9C aqf2nfAkLNHL0+WQcj1qX+2ljA8y1Zm/2OlQ6xSptlv7JlQGYH3rM1Pw6+oqF+3tCo7J3+tX 7XVYrqTY8LQsem49astNGG27gfpSVVA4WOVi8H3trdpPFqKuEPQjBOa1Y0u4HBntkb/bhOGq WW6mmkKQtsjBGW7movPkhLbnZgemT0oda+5MYGhb367Ri5mTttuUyPzqY3JbJ+0ae3typrPg uBKfnIHuRUxWF/vIje+BRHV3G4iTSM3T7J+D1TaZtxx9m/76qV4ITn92n5VUkgiB4RfyrUnY U3RHSWJf9wZq7rWqubax09F2tcfNKw7IBkD8SKzQqrjAAHbiqt3O8msJJn5vLVUHoBkf1pK5 UVdnX26qFUKOtUvEVyuY7NTuVfmcds/5FRNqKWOny3bLI5VTsVBkluccVzv2sXMjSFiHdiSH Yg569Pxquti5RQl0sYjbYqjjsKywc8Zq7OMIcnORTdKhWa5kV0LfKCM/WnojFlRWniffBK0b juDxWnD4wvbFB9thWRc43oMGrVxoYYboCV9ial0LTs6lJBNGHlZMQJIAUZ89PyzVSqpRu0Tz M0YNVttQ8P8A9rQJK6RMRcJGMtHy2CQO2FzUVt4o07yTE9wjQMOjEfKfX9KzLHX30i6YyabB EXUi5gh4DgjHzKe43frUN/oGnX4fVNBUT20gLyWqt88ZPOFHbqOPavLklOXvbGsW7Gxe29td w/aEZZoAOWj5wPQ/lVH+2tOhXy1l4X5cemOMVgWxutLnaSxS5hb+KGX7reuRS3DNdzNM9vHG 7MSQo4yea6qVOSdk7oJSSNObxBAwIhjZyemRWRPfTySbtoHtTo4yTgYz6CpfsbnqprsSiiOY CeT9aSiisWeopMSlCgkg8jHSiihEuTseg2OqXsWnwxQzmONV4VeB1NSnxbqdkyoHSTccZcc0 UVyTinLU5JbllPGt+3+st7V8eqU4+KPPz5ulWL+uY+tFFJRS2IaTCR9Nv4ys+h6cc9/JFZ0f hzw/5hLaNbNk9wP8KKK3g7AopdC2ngXwvecNpITP/POQrVeT4W+HZJzHH9siGMjbN0/MUUVp KcrbmllYR/g9o55j1PU0xyP3inH/AI7WdefCy2hcyLrV+X67mwTmiislUlfcyqGDdeDri0kJ XWZGH+1CD0/Gse7truyDAXivjv5IH9aKK3TbONydzFl1G5RsMyufUrTDq1x/dj/75oooRrHY VNQmkIDH244rTtgsy/MG6d2oorVIbLxG1RikViTz60UUNAkBiRuxX6cVDLmInGCMdxRRS6Ah jKDg4phUYJoopLY0GBQRmk24oopIBCMY962rWMRwgDvyTRRSkIsW5JBzzVfVSREB2IoorG2o yGzJ8hxnjcvHpzW6ygqPpRRTkikVJBios80UULYDTQZiH0qMH9+g9WFFFYSSuUtiprv+oz/t CsT+EH2oorWkkkSzXs+bBT7/APsxpt3/AKo0UVRXQk09FKjIzjpWkijknmiilISBwu3IXBHO agRWLYLkqTnBooqHFNmibL5UJasABkDIOOe9IrfID3xRRQoohsBMY4G+UHJ6+naofOaQ4IFF FQ0rlrYlQAc4z9abfXzWVm8qorYHQ8UUVpDYlkVxetBEr7A24A4J6VSbV3kVv3KDFFFbxREj Ws7RLrSoLtzhpV3FQOBWbdxKLlWXgqCBRRT6jgSXlw4mSIHCgcfmKhmUOu5wpPY45FFFBNQy 55GXK5J+tWPD8xm1drU/KPL3hh1FFFFibHYWl6WcwyRIwHG7GDU91YiLE8UjJIh3KQPukDgi iisKquhpFfUbC11KCO/kgRJ3LI5VRhsY/wABWNDpcVjc/abSR4JAOfLOA3fkd6KKypRWxbJb q0jvmEkv3+MleM/5xUCaTb99x+tFFdEFbYnfcsw6bArYCge4FWHsYFIG0nj1oorRtk2P/9k/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAF9Ah4DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDz7uaWk7miuVNooWkoFLTa6lBRmkoqRXFo opKvQBaSloqV3C9hKM0UmeKbaewbhmiiikkO1g70ZOKTPNFNMQZoPX8aTNFGoxaSkozTs2CY tFJmkzQkVcdmgU3NGaqwh470nekzzR3pPfQWg6ikzRmhpMegtA70CjvSTS0C4UUUUN33JDtR RQKnSxQdqKKKFcVgo60UlNCuLRSUU7ArBRR3o70KyHoFJS0lGorBRS0lAB0oooqrMYlFFFRq GgUnalpKYc1wpKWjrQkTYQZ70mDzS0UDuJ0opaSnbS4OwlFFFNBcDSYpSKToadhoO1IRkU6m 4oQC0hooqhXTAVBdDMP/AAIfyNT1Bdj9z/wIfyNJXFY0emaWk6k0tY2dymrBRmjvRTaaICig Cik0NIKKMcUUJ2Q7oM8UUlGaa1BMM0daKShQGHrQaCaTNJoQZpM0duaQ07XFZi0gOeaTvSd6 rVF9Bc0mTQTxTc8UkxWHZpM03dTRTtcEPDUuabt4zQM5/CjQdx4PNOB96YOtKOabsA8HNLTA aUUkK44GgUlLS0GhaO1FB70rdxPzCgYoopNoVwooopoYUlLRnmixIDpQeRijtR2qrWQ7ITHN FFFTdgFFFFNAFJR3opXaAB0oxRRVKQ3sJR3paSi9xJdxOtFLRS0YeglHSikxjvTtYV0HbrRR R2ph6hSClpMikIOlJmgUY/lRqtxhSd6XnmimlcaYlIOaWiqsICKKPWkxSsOwVBd/6j/gQ/ka nqC6H7n/AIEP61QtTR7mgCjuaKxvfcYYpaSjtU9QTFoo6UVdtAuFJ/Kj+VJUp9AtcWko9aT1 qkgWgucU3PHHWik6UrFWFo6UlITTtYWgGkJpM0hNJoPQUmkJ5ppPNFNNgrik0mcikFLg44FO 47XEHU04UoHWk/xo1Y7JDlOaCPSmrxT+tDXYQ3BBNKDzSNmkGaETcfSg9u9NBpwouyroXinC m0tSh6C0tJQKHpuJtBS0lLSJvcKSlxxRTVgCgUUuKbXVCQnSiiikm+o9xO9FLRTbASiiikCQ dqKKKSATrQOBR0o6iquAUnNBopoLhRR1pCOMUW7AHrRSnvSUBoJR0NHX2pD0J74oQrrqHPNA paSnfsG4UntRRTuUrdQo6UGkou1sTbUKQUtJRuU7IOcmiigU0mK4VBdcw/8AAh/I1NUF3/qf +BD+tCWonc0upNFJnk0tZbjbAClpKM8UKwboUUUlGaaYlYKKSkzTY9gzSUZpM0vQLC0maTvS Zp7AmLmkJpM03NG4NCk8U3rSE0DjrTSsCYoHNOxzTgM0EUm1cdxAvFAHpSgYpwx0oaCw3FJi nkU0ilqA3FKDRijpTvYbFIyOKYQcinjmmkEE0Jk6ADinA0wYzThTbAdS5pBS0rdgFpRTRS0O N9yh1FJSio20ExRSetApaBaBRRRTs2K9go6UUGmkluO4lHeijvUtX2FZ9AxSUtJRbQaCiikp pBZsKMUUCmkPYTFFLiko66CQUtJnFFWvMd0J3opTSU7oLoOhoNJS9RUNdhaCHmijFJ/jTTCw tNxR3oxQJXDHWkpaT8KFcOoAcYpDS80GnYaE+tFLSUWAM5qC6/1P/Ah/I1OOlQXX+p/4EP5G mtAuaGeTQD1pvc0oNZA0L60UmaXNNJoQUUmaDRyjWgZpKKSjUYE0maM800nmnewthTTc0mTS ZyKFqK9wJpOSaVVyTUoTFPYYwJmniPI6U8CnqMUirEYQ0bcVNSFaXqJkWKXbTxRii415jMUh WpCKTGfzqRXIsUEVIRTSKpNMSbYwcZNIxp2DSY5FA7DB0pQe1HTrQKdidRwpaQUvei4IUU6m ind6Hceod6Wk5zS96m7AKMUA0tUhiUtGKWhu4aCfWjtS0n0qRXCkA9qWkoQBSdqWkq9xdQpK XJpOtJuxVxaSgZxyaKS12BMKTFLR1x9aLaghKTtilpPeq3AWk460v1pKa0DQKDR2pKbJ06B3 oopM1Nx3Epc0lFK4NCEcGjHpSmkqlIEA6DNFFAptjCkxR3paCRtQ3X+p/wCBD+RqfFV7v/U/ 8CH8jQhl/uaWmknnFA5/Oo16A7i54paTvRSdwTDnPtSUE0UId0NoJ4paaTVdRAT1phNOPQni mhdxqrCEHJ/OpUhJ/KrVrYs5DEYHpWlHYKvalZgtDMSDA5FP8njpWuLLI4FJ9jKn/Gny9x3M jyiO1LtOOla/2QEdOaYbTB6UuVg2Ze2jbWr9kz2pps+en6UuRhcy9vNBWtL7Jjt+lH2YelNR 7iM3bRsrR+ze1Ibf2pOIXM0rTGXGa1Ps4xTGtxjpS5RqRmEU3FXntqhaA+lNIV2ViuaZ0qco RxUTqQCaEn1ATJzThTMdaeKVgQop1IKUUndbj9RaXFFLipSQXEpaMUoFNsQmKKdiihOwWG0U 7FJVMBuKSnGkAoSGmNxQPpS0lCuG4UnSiiq33BJifnRRiip5baiuFHrRnrSUPUQUZoz+dBoV rlIDzRR3pKelxXCigZ70hNDYkLSd6DSUFB9aTOR+FLSUWF6C+tJR60DvTuDuFJ/hSg0lFhJX DHNGeaX1pO9DQwqC6/1P/Ah/WpxUN1xD/wACH9aI3DUtkdaUUnGTzS1CbFcKDQPXrSZpt3Gg z1opCQOpqSONpSAgzmmkF9Rn1IoVNzBR1xWnb6PPIBlRj3FalvorR8lf0rRQQMyLfTt3JGa0 IdMj4+QflWwljjtVhI44j81OwkzPiswgHy09ocdq0tyEYUZ/CoygNAmyki4p5i3irixRke9A jGeKVx3KAgZTyOKeIQe2a2rV4VXa8Kt7mny2sbHcm1faqFcwhbHPCk1KLJhyVOa0zc+SMGKN seoqtLqQPTaPYUAVvschHEZP4Uz7DKf+WQx78Uj6hjox/Covtcjnq2Peo5khimywcFlFMNko 43rSmY9zUT3HvQ52FcU2YA4YGoHgx2oMzucZIqaMHHzc1mqqGUniHtUDRYPStCaIE5Aqs0RF Up9gRSeEGq7xDFaBjNQSIRnjNF+4XsZTrtNIKtOYmJByCPWomjx0pXHzMaOKdTQKeBU2e4gx ThQBSgVDuOwAUUuKMU0nuIUUmKWkqtXuCE70Glopp2K9RppOacelNo0YtBtFOxTcUkrAtRtF Ox1puKpBsJ0pBnFOxxSHpVWASiijvSYm+wUZopM0r3FcKKM0g6UrjvcKO1HWjFUvMEJ1oxS0 lKy6DCijvRiiwCd6KMcml6mi4XEAxRjvSgcUlMAo75paQDmjYEABqC7GYf8AgQ/kasVBdD9z /wACH8jTQ2ztj4I0Ung3Y/7amnJ4J0Rfvi7b/tsa3zx2pN2TyOK832su5nZGEfBHhwj5IrxW 7kTmoj4G0T/ntejjGPMrowFJyaUhfQGl7Sb6hyo52PwRo8bh1lu2I5w0mRWlFo9nbY2KW/3s VoFR2o2qP4RR7WfULIhUKnCRrmn7yR/q1qQBSKTYDn5v1pqtLuFhnBHAAqB7USNkuw+hq0VH HQ0mAOCDT9rLuFiuLYIPvnFO8lP7zVLjutNAJPvSdaYxogiPVn/OnCOMdC2KRg7N2ApGBQqA d2Tz7Ue0mFhwReztSFWxxK/40ihlbJAA9KXds55NP2sktxETQM45kaojZburZ96ssxB4BINA JB6U1XmMqHT8/dkUfUU3+zXwf9IH5VcyT1pcjHSh15NgZz6VIwz9qUc46VEdGl/5+UP4VrZI HGKNreo/Cj2snuPQyl0iUH/j5j/KphYSoOZVI9hV3vSCQ4OFPtxS9pILlM2DnnzU/EU1tMkP SWM1oHfjsKTByQc5HtVKs0IyTpM7f8tIh9QajfRLo5xPB+tbXzeuaXJx8wp+3kxnLy+G9Scn Zc2f/As1CfC2sHpd2H5muswTnjjsacenQD6Ck8RJISZxreFtcA4m08n/AHmpB4Y17vJp3/fb V2WOMnpSHGOMGhYqVhtnH/8ACNa8D96xx67mqRPC+uSgFbjS48kjEsjAjH+NdcBnvSMqk/Mo JPrRHEyW4HKP4U1+HZvvNHk38fupWO368VEdD1hSVMVuxHcMcH9K68JHHwAoJ9KXAAyR+FUs RJ9BHHf2PqgHzQoPcEn+lN/srVDnbacA8kmuzycn09qQDIOD0NH1mS3FZnFHTdUB5smP40n2 DUv+gfKfpXa/gcjvQWOOpo+svsCRxBstR/58Jf0phttQU/8AINuD9BXc7yOAD9aUO2MAnr1z R9Za6D1OC8m/HXS7vP8Auf8A16QxXoBJ0y8HH/POu+DyLk5Y0u+RjnzGz9ah4psLnn5jvQD/ AMS28/790wrd9Rp14R3/AHR4r0Lcc58x/wA6XcxH3zVfWn2C7POS1x/0Dr3/AL8mk3zd7G8H /bE16MZJAev5CjcxByefcVSxQJnm/nSDObO7AHcwmm/aD1Nvc4/65GvSwRjHyn8BSYTuiE/7 op/WF2A81+0oBzHKPrGab9siHUSA+hQ16ZhSeY4sf7gpjJGW/wBTEf8AgAprEJD0PNftkBP3 m/FTR9tthx5or0vy4WHMEI/4AKZ5Nt/z6W5H/XMUniU+gHm5vbYHHnLS/bLY9J0/OvR/s9rj P2O25/6ZimGzsWJDWFsfrGKft4Dujzv7Xb/894/zpwurb/nvH/31XoB0zS8ndp9p+EYqNtI0 c9dOtST/ANMxT+sRQrnBm4g6+dH/AN9CgTw9POT/AL6Fdx/Ymk4GNMt89/kFIdD0j/oG2+f9 wU/rMWgucV5kX/PRP++qTfGTxIuc+tdi+j6MrFW0+EH/AHBSDw9pZGVsk+oApe3QrnI7kGBu XPpmgFT0YfnXWHw7pPGbXnsc0h8M6Pj5rZ+mOtP28bCuzlOPUUuOnNdQfDOkEH91MPo+KZ/w i2lk8rcD0/eUvrEQu+xzQHHNQ3K/uf8AgQ/ka6r/AIRTS8fK11n/AK6VBceD9PaEfv7peR/H z3qo14t2C7O14zyKTIHagnmgqSetefy6XGIevSkzz0p/GcUmDmhOwhuTSgk9uPejDZp2R04o vfcY0YA4FDLkUZAOeKcvzDgGlcBoxjnrScZzk8VJtJ9KjdfaqVuoCGQZ4oDnuKVSAOgzQD7U XtsABiR6+1NABznINOPtxSctx3p3AQfdxkn60EFV4YA+4oX7vINB3dsYqVLsCEGaByeSDikJ w3qPal24GQKfNcLiEA9+tAGOCc0ozjIUUuAT1pXswGbSrE5zntS7cnJBH1pSuOh4pmO+403d gKQO3FGTjAFBBYYFADYxxSu0Ah5Ujp70qAngn86UA+lIASSM0czANu0cHNAAPU4o2kDAzSbC FwaLsEOHpyaPl96aAfelIPvVIACLtyGJHvQMdAopAvfdmjJGT2+lJtAKMehBpBgnBGMetKDx nJ+lKcsM7alu4Ddq7s4BxSDlqACMkUAHHTmmgDjpmg9KaVbrlaXB9M0DEBNB3E9h9RS85pdv 1oTAZg5J4pTgdxinMB25FJjPUDFK4hCxwPT2pM807aSeMCgDAot2GMI9KDkDk0459qAfXGaa 8xCAnGaCxx0p4/Ok780rJMBqt/s8UuOc44pT1pM00AED0pMHHGKUH1o7U0wEwSKFUAc0vHbm l/KodxoaUGO9HGMUtGQO2aenUVxNopAAPel59KQ8jrT5tLAH6UcY96MYFJjHYGpVkAbFPofr QABR9aSnzMBWG7GAMik2n1pfxozV810CDAHWjbn0oJJGeKbye1K4C4qObHl856ipKimP7vn1 FOF+ZAapPtSZpvmAnBozzwKgBwGaOfwpuTQGJzjFOyYWFJx1NJnn/CjOeoFIR6UJCANt5qBT f6nObexjCqPvSsDsX6mifkCMZBY4HNbMEn2KxWCKUIMDcWGMn3rWjT5nqMqp4Ov3UsfEUCOB 0Rcr+NVri31DRpkg1FRKkhxHcRco3+Bro202W3yzXtqzEAlYH5x6mkmkhuLCSxmDyiThVUbm DdmHpXe6UWrWAwA3GQOtIGzkEVBAWMQLAj2P1qYD2rzqkeWVgDJ5GKTJX1oO7+6cU0L6kn61 K03AVTknOaUcc0mKM457UmgQ44NHtSZB+lKSMcVOwBkgY/lSZA4wSaQEE80HHvT6gBz0oOKN 3bFNyOxp8wCnOeMAGkAPakzn1zSnOetO/RAOxjpRg5zmmdeuaNnfcRg5qXfqFiTv3pOD/FTM 8dTj2pCT6GnHUB568GkLZ4pMke1RvcFF2ou5jwAPWmlqA+SWKBN0jAe2etVxqlnjO2TB77eK 04NLtbMCa6X7TdsMlG5VParwvXWNmlt7dYQuAgjGCc10xoJ6sNDHintp1/dyjPpmn/N26Uuo W1vLuuLeOOOTjiMYBqGOVinI5rOrR5dUBJjJ7/SkxkelALdcGkAODWCegCZ7Dmlz7EUYYc5w aXkjk1CeoCYzQaMcUYzWidhh2pATnigqT3pT9aT1EJik5xThkcCkOTSd+gXDIHWkyM0Dj3oJ 7kZoXmAEf5FAGev60dqTrVK1gFGKU9qb0PFHPep9AAg+oIoz8pyOKAfp+NA9zTUmwFx6CkwO nT6UE1HLOIkzwaHq7ASbUXktz70KUbo4zVdbaW4w88whU9FHWo5bSFGOyWRiOhzW8cPOSuhl 3HJ5zSYGc1UjeSJiJG3KTwRVksOxzWU4yhpIQpBoxikDUFh61ndgAwaTaM80uRijdV83YBMf Wk49KM80bjS0AUAde9LSZoyaGAdqimA2fiKfwBio5T8nXuP61dP4kBo7VyeKbt+tSUn4GoXm AwL6k/nRt54J/OlAGeQaXAJouAnTvRkmlKj8KQY/h6UWYiGYZnhYjOD1HatyCYbN08KBAOJD yPxrK2BgQas297NaffjikXb0lXIP+cV04eVtxo0U0+GeVrr7PZxOAB9oj4dvY+1OR2tZ/M81 cg5yvUfjVSS/mKF/3SA9kPyj8KzZpbnU2Nsh2wg/v5lGAB6Ke5rslVikBFCWkiWRywMrO2D6 bjUmCBjNPdQDhB8o4A9BTMPnnAFeZOXNK4CDIzgk/WjkdTSlRnOc0hJNJAHO3ihcgHC0D0pA SOlFgFw3rijGRRh2HAzSDAz1pNAKB+dJ170nJ9hQRt680+awC4pMd6XHGRQMnqKl6u4XGZHr QDjkg08YHFN5zxmmtQGk+1Jz/eOKkxmkIPbpTabAYf8AepQ2TjNOKewzSKOaE7AISSemaW1+ W8iY4wpzzSsPlIyeTTACjhz2pqWuoI0pJYi3ySqG9GPU01xdSwTXklskdjE4gjleTBnf+Lan 90Z6+xqudk0e5QhO3p61KiFSrMOQuBkZA4549a9KDTiBGHU792Bk8BRwBVeLDSS442uV/QH+ tWL2W3tleYq0cSDkkjn/AOvUdtE4sknkTa85MpQjlcgYB98YrOvKPLYBuDjBP60CjBPJ6UY5 4x+NedpbQAPSgEetLj6UgXvgfhU3GGcGhicUu2l2n1qlewho5GcUlSbcUnA60ON9gG/pSc07 GelA69KFoAzk0AHpmn4INJkdxTb00QDcUU4cdaOKW4XG4NJk9MU/8KTIHAFP0AYQMYNHanbv akz/ALJpXATPHSq2S84HGFOask+lVWO1zgd61h8SAsiN5JRFnLsccGqgltpLl44pRJJESrBT kAjrmmSRiSQB2lUHqUOP1q5CqfYY7SBI440B2kKA2Ccnce//ANevVjqgIJbtXJ/dlMHFTRks nSql1kzBAQcED5elaXlCOFBwTtGceuBXLikrARUntt/GngYNIevHSvPtcBMigYx6U7jPFJzn pRstwG4yetKTjilxRwaq+l2A3k+lHSnYox7Um7gNyPSop/ucKeo/rUx+lMlOYuPUVpRtfcDR I5pKOcnNArK76CE5PPA9qXPajmjPXNC13GGB60Y54o4IxSdOOaExXFBqeOfaACFYdwwzUAIF BwelUhlhmsic/Z0J9DTZLl5FCDCRqeEUYFQHbmgepPFDuwA8HrRTeQelLx6VNugAw+lH1pve gg5qnoguGPSkx7YpcY60mQe1TdMBenejaD3xSDHcUd6d0AhJz60oBI5GKXGKOSKE0wEwMcGk B96cq4FG3HOM1VrBYTHvR1GBnNKOR0oFSAmDQMdyaUDDdKCoJyBmgLAB37UnA7UD8qMetCQB nnNKCC3SkHc9KB60OIEUtnIxBtmUeqNx+VPjTUc7UtJm4wCXG2pFJU5Gad5znjcw+hrSFVx0 AZHpkonjutWeJ2iIZLWA7o89QWJ6kY+lSXM3nSM57nNMaQk8HNNO4dqipUcxCZBGKMUmCe9K PTNRqkMMUClxjvS0t9gEyfQUcml20mMUJyADkcUmPU07pTc+1NPuAmKBkUvPpS/Wqd7aCE98 UgIOcc4oJbtR+X4Uk5DF69qTBpcmjOOpqXcEN5o5p2Pek/GmnbcBoUjOaXnFLk+tB6VV7gMw c4yTTJIg+OnXmpeelJg5oQFKSSaD5XjLLjO8DIqAX8bKVRST04Na6ylflxkHselSLPGpx9nh B9QgzXRHEuOgFDT9NnlkF1cxNFCjZAbgufp6cVcl+ZzjoOlLJcSMcFmI9zUTZz1rGrVlNgJS ClBIPagksegFLYBMY9aMU4dKTnvSTiAhNBoP0o96TATrS4GOP50dKMd6aAO1Ryj5PxH9ak+l MmGY/wAR/Wqp2UwL5Gab060tAGfSpvYQlBXrQQfWk7+tN2a0GAGKXNFHFKzQCZoJ4pTmgDjm jmASkHelwB70fhS5nsIQGjqaXHNGadxiHHrikOcdaNvOTRnHFLmAQGlAwabtOc5pee1Cj1AX r0xSc9qQ5FKM45oerAOvfmlA560gApRwetCdgF9aO1HejpQ5AJkjPFGO9FLxmjUQmKQcGlJH YU7gjtSTaYxnOc0YJ6UpPOMUEE1Un2ATaR2oHHanAYNHtUq7AQA7etA5HU0cCjHHU0wG7Rzj NH1Jp1AX3NS0Ibz6UDA5xzTj7U3aRSTewxe9BGelABzS49DTTsA0cetG71Bpee9ByOlVzaaC Cg4oPTGaQA5qLPqCDI6c0Y+tL0pM5q9thgKKUcU09aAuLxSEA+9GFPXNGAOnSi9twDpR29aP wpOnahyXQAJAHJ5oAzQMHqKcMDoKnmvuAnOaTPtSjA6min5IBuD1oHXpS98U0Lgnkmmo2AD6 k4pQc9qTGeKXvjOasLB1o7UYI60hzUasBeBnrTQB7mnCkxz1oQCD0o6dKDwaCT1piCgUDmjF EWl0GGOetRzZ2fiP60/GKbLzH07j+tXD40IvAHJyKO9GTnp+dHX/AOtWIwAFBAz2oBwMU0da aQC4B6UYoJpAx9KbTAXj8aQGloznrikovqAcdec0celLQKpgMPJ5p2Bjg80daQrU3FcQfWkO S3alHtQBzzVOwxBuz1FBznrzS4BoHrUpsBAOeuTRjml69qM0XSQABigdeKT5jSAkdeaSaYhx PqKQcmjO48GkOaYxTjvRjJ4Io69cUoA607gB9KABjijrQGApXYCDGaWjAznAoB56U3sAYzR0 FHOaUj6VNrbANHHXmjrSn6Ck9gKE7bgGcA0nJpQPXFGQOlNvsAmfSlyfWgAHsaQAe/5UNJgO +tIM9ccUGgcVKVgDPqKAM0DJ7UHJp7bABpBxS4pMUr3EHWkOR0pcUhBI9KqMe4wLHsAaOPSk C4oPtRsAuPWkA560AZ70AdaSdwA+xoA9aTb7GjFVG1gFpOpxQBjsKWkrXAMe1IfqKM0YHWh9 xh0GaTn0pTzR1ouIQZzRhc0cg0DrzTsgAj3o7dKKMUbAGOKQ0HIpCSaXLJgGeaKTk9qXmnyt BYTPvS5zSYz2o59KaYBxmo5yQnbqP61KOtRzD5PxH9aum/e1A0M0nAoxzS7VPrmsroBOtJS4 7UbRTTb3EJRn2ox6YoAqmkwDg9qT8KUAdjS1D9RiDBzQaO/Wg0XVtA0AnikycUvHek4qUAgo J5oGM8Uu0E9s1ST3YJCfiKMn0o6HtSgEknNPmATpRQQTRlql67AA4pcU0fQ0uT2zTUWAEAc0 D3o780DB6UW7AA6etKKAKOlL1AKTPalAJ6UHik9WFhMHuaPwzRjJo9qvoADn2pMH1p3AGc00 HqSKLtLQBcEDpQM+lJnmjOetRvuApOaTGKX8KTr61S8gFzigMTSYGKKLLqAE57UAijmjHbFF kwDoMg0gPHr+FHTrS5GO9FmtgAE96Q0n0pe1TqAYoIpOaCc1SvbUA5zRig5A9aMn0oiAmDR0 70cn2oyT1AoQCZoJpeOmKCKaaTAOSKQZBpc4BpAaUlrcBeT6UhpTmkxk5Bp7oNRCKUce9ApD zSSvuITLE9DSilC0YptW2GNIOetH40oH1pCpHUUgFI560DJNIB7c0EVSkwAk5xig9KWkHenc BOKMkfSlzk0e1QrAA5NRTn5PxFSYqOb7nTuP61pST5gNDPPApM+tBOOoo+XtWOwC5J6Cm/N3 IpcZ7mk257ZqrtK4BjnrSmjGKTJ71N0wDC9AKX8aSkoTsFheAelH1FAzjmjAp3QBgZ6Uh9qX FNOR3ppgGMdKAD1NHfil/A5ouwDvSYpaTqOtNWYC9KB1ooNDsgFwaQA80ue1JQpWAWgD0pKK Tb6AFHFJ+lKKFdgGabxmlyKMgc015gg/Kgc0gOeaM8Hii/YAyM0Z9qAM80hAougFzmjHNHQU Yz3pXBBmkNKTxSJkjkUJoBaAaXpSE0nIYcUnSlzR2prbUQnWgUmT7/hR07k/WlpfQBciikxn pSHAPWqAWgYpM+9LjFLYA3UlFGaTT6AAyeKACO4o5oHPU1SuAE84oHvRkHpQWpW6gB9KUAdc 00c0UXYCjGc0h9hRikGeaaVgFFJk5pOc4penWna+oAaAck0cUbeKhgB470nJoP4miqgu4B0N FHJpc+1DSAQc560mRnpRk0vAHSi/cAxzxSUUA0LcAx9aZKT5fHqP60/Gc81HLnZ+I/rV0786 A0MGkxz2oIxnrQFPask+gCjI7D60meaTHvR2qnewC0mfajAoGP71QrAAz3AzS8d6TOR60cno RRdX0AKTnPWl5zSbj2FABmjvSd+aCTnGDTtfcLCmgc9TSHPbmj60KwCgY/iNJ360fSkwfSqu A6jHFJk+lLmjYBM+1Ln2o3Eds0A57VNwD8KOaQ9e9AI9KafcQUhPtSkqegoB9qbt0GJwaTjN Kc9QaM1NwFFHApPwpNobuaaAWik/OjvSugFJ98Gjmj3xSdaaAPrQSfWlx7UmMUOIhAOetKV9 6KKGrjDFH1xR0oI4qE7uwCFueKPrRwaOAOtXayAORRgAZJ/CkyBSYPtSuApo5oxnrR07VSt1 GJzmg07p2pM880a9BB+FAJz7UhbPSjJxRFABbtSYyOaDgDJ60ZyKHpqwDjtSjAPTmmilxSTu Au4HPFJn2oxik7nsO1O6bsAuaBn0zSUhJz0NDVhDup6UdqTJ96AD71N2hgD6Ud+aM4FJVK/U Bc8+tB4NJnijNJq4Ck0nU0oPFIAO9NX6gGfxpD9DR0PFGfWnoAdaZLkR/iP61JnPQVHKfk/E VcPiQF/PNJzSk5NArFSsAmeKB+NH5UEk+1Em2AcCjnNJgmjBNLlAVhnvxSdB1pMDvS9elNRs AnXPUYoo5PWlAwaEAhx2IzQKMAHgClx64pNdwuJ0ozk80ucHtRnjpS0WwCfSkBJpRRwKu91q AUcA0Ac0HPt+FLQQp6UlJg0pznpQ/IYvX2pOp4o2/Wl20k+4DenFLRR1qnNdAE6dTS4BH9aM c0VLXVgLgAU3NLj0pCMU1sAvApMUEZ6UdKSYABRxnijOelIM+lN3ADwc5o69aOPWkxnpReyA XpSbval2+1JjmndNAAoox2Bo6Uo2AB9MUmBijBoA+tU2AYpKXGO9J361Ki2IOexpaQ57Uc0K PcYdM80meOlLk0nXrxTTATqPT6UuSfU0ZKngZoL44qm7IBAOx60uccY4oBGc96Mc1PN5BYXB 7UZpqtuJA7U7aO5oceoMQ80YwKWk79KLJbAIDxQTxzS8E8c0hA9Kpa7gL9aQkjpQwyM80KCR zSaEAGBSZIFLjPQ0ntQncAHIzil3Y7Uc9qTJPWm79Bh1oxilyAPWm1KT6gJjvSgcUpOe1HI7 UWQDeuCKbLjZx6j+tP8AwqOViE6dx2rSn8SuBfxgnHWjmjJ5xmjn1rG9xB17Gko3HpzQB64p O6HYCKOe1B+tGfpTUu4CHNLk46UBvag59ap2AOtHajtSCi4C/L15zSZOaBwOKOcdKNGAdeaB g9aPwozxgYppW1AOO1BGOcGgL6ml3H60mwEHJoPB4FH5UA4paoBaOtITmk+lJK4CnOaCBSZP U0ck02n2AUdKTJ9KMYzzSZ4qVoApPtmjBpAQOaM5qmuoC9OlJ35oFBzRYAPXik6nmlzzSHk0 +XTUBQAKByaTAoo5biQvGetGKQdeKUn3pKwwyfekP05pcjGKTr1qmkPQTFLilOOlJjFJaCE5 peT60Z4pBx3olcAxQB14peB3FJxSiAYo7UmOaDwORmlqmAgPegYNKDnoKKrRgJ37Uu2kAJ5z xSmnbQA49KTcFGaXvSNSSuFyC0LmHc6kMSTz9eKnB60nPGaM+1VLyACKXgUhJPv9KAePWpaA XPHFGCaQZ9KGORimgsL7UmeaB0owaUhIQ57UoBIpvI96XkngkUJ2GGCDRnFHzetJ0709wFHN B4pM96Mn0pa7MAPWjNITmihpbgB59qjm4j69x/WpBmmSgeXyO4/rWlJ+8gL5OCaQUE+1H41l oIQnn2pDjpml2jHr9aQLz92k7MYuKAKXkemKNue9Oza0Abgil+tHTrR1pKL6gGSelAyOo/Kk 6dCRQOR1NPl7ALSc9jR0FJzg01cB2fWjAHSm9+TQSc8UlcB3HqcUuQKZyOtHHrQ1bYB3amk8 0uRnFN+UHgUX01BDgPcUhJz2pSO+KBzQvMA6igDHrSdDSHNNS6CF4o4pAaUkGlKN9hiA5PSl JoPHSg89qewBgUe1GM0YquVWuwEx9aXHFJzQQeuahiDB9aD9KO1AyaL2GHbtmlwO4pKOfcCh agLwB0opPzowRT0QCE80ucigd6Tjpmm2AfSjHHNGD2FJt9z+dK7EL8tFGRTN3OKb0GOLDFAY 4x2pDjHSgc8UmgDPPApaQA80Yb2xSQBnFGcdeKCB6ig54zzVXsgDIPSmtnNP/Ck4pJLcBpzx S9unPrSA880pBPSndBoIB70oPpmgZB9KOp6mk2AhzS5wBxQfxo7UasAwaMnvSZ45NJ+NJ6gK eTQeDSAD1oIpxiAHmgYB5oA+gpCeaXUA+X3zRTh0pCT2Gaau2AlHFLkd6Tj1qpJJAAqOYfJ+ I/rUlRzf6v8AEf1p0n7yAv5FJn1pSOeRScdqz5bgIeT1wKXI6ZNJilyaWoBig9ec0DAFJmmr AgzQPY0UdO1NvXQBO9KSc8CjHrSZ9DSdxCnNGT2pDmjnOMGly9hgQxPFGCOtISfSgDJ5q0rC D6nP1peMUnAPcj2pTg9OBSdgHAAcmkxzkU0j60ozUgHPfNGKDnoKAe1Dk0AUuOKQDNHIpp33 GHXgUEcYpOtG3Hcmq0AUYGcijOKMDPNHB6VLYADSc9cUvajnBxihSTACSab35pRSkZouAmTj IpOSOaU9MCkxkYzT5uyAAvHWjk+9HHejOOBQ3oAmDRtPXJp3fmjPpSTd9QGnPagZpSVA5ozn vVTl0sAZxQACfvUmQDRxmkkxBjmkz6Dj3pQOetJkZpodhMjPFKT9aMgHIFJkHsaq4hxPFJj3 pGxnmgkCpdugwCnvQWxxmgHjgUnWi3cBc5pOR0NL3pCaHoAtGfSgEiiqVmgEJPpSAn0NGTk0 ZJHNCQBnPFBNHUYoxUtAH4UdaO9GTmgBAB1IpeOlLj1pMiqTTWoXFI44NJnBpMAnIzQMA4zz SWgASc+1L07kUEfnQRxSstwDIpARnpQPpQRzxTSQCc9qjm+517ipR71HP9z8R/Wqpu8kBezR 34NBHPWjvzWa2AQ9aXtmgkdhSGoV0wCjOOooHHejjvVJ33ATPHSjPFLn2o7Yo0QthPrS/Lij PtSflT1AMUZxR+tGT6CjXoAA54xSZ9jQfagY7mml1GC+9LmkopWfQBc4oznmkPHTmgUrMBSf agMOaNwFGM+1JxdroAAwetGcGig+1CT6gIaAcil7e9Jg+lK0k7IBaOvSjpSA5zTtYAHWjPYU YNAzTQBgetAoxSCquFgA75NGeaASaCwHsaSswDjPSjODxQCDnmkFNoB2DikANJnA5oBGKSAQ 9eaXA78UnJ9KAfxqrsBe3FAApRjrSDrQmAFfxpMUoPNH5UrWAaBzSkelJnBpcnsaltgIMelL nnpmjkc4pMnNWveAXpSBsnFL1NISPalqAd+9AIzzSA8nmjGT3ptPYB24Y5FJnPSk2ccNRzjk VNrAB4pCB70DPpmlyRzgVSYCAL6c0vPbGKTk8kCiiwC59qTvS496TvS1AQrz1NL90dCaQjHO TQDihLQABz2xQPpS8mm8g0nGwheM8UcZ70YOaO565pqQ0KCAelJz2xRjjNGD2ouAhzio5v8A V9+o/rUuainOI+R3H9aukvfAvkc9aTB+tKRnvRgisXdIBAR6EUZye9LyetJQl3AMA0Zz0FA9 6PpTbAOcUox1IopO+am6YAc0n4UppM+xqlHQBMYpQD3o96OaSVgAdTikAHXijJHFKDnIxTaV gEwKDSgY9KTIFO7S0ABmlz3NGeKQd6m+uoAAM5xRj5uKUcUZpylZAJjBpSDSEE98UD3JNKN2 gDmlwfWl7UmPSk9AE2+tHAOFFLjHOaBnOcUbgJQBQMdxSnjoMVVwG/hSgDtRkgc80ZxQ7sLC BQepNLtFH0pB9TTiu4BijH40pJoU03cBMetG3POOPajrS4pJsBuwE9aUgDIxQR2oyPxqttwG j6mlHvRxS1LkrgIMeuKMUH6Gk60xA3HbNJnil96Mg0N9GAEc0mMml75pM7uMUlfoMB6UbTmg D8qWm/dEIT7UE/WncYpPyovfcY3B7E07k8nFIBzQT6Umn0CwfjQBml7YIpoPsRStdgLg+ooy KOKSnysANHAooJ44FNOwCdO9Ge/FH4UdTwBiquAnOSaXoeaTn2ozxzU7gGfc0Z4oH0owKSts AAUHIOO1Jk5NANOyTAWmSMQn3R1HWnAY5qOYny+g6irpr3kBfNA+tGeaM+1YyYg6jigDigUH ihXGJnNJil2jOaQik9NxC8+tHI68/Sk7UZppJbALRyKQE0n41TuA4UnXtR0oJ4o6ABBHSik/ GgcmgYHA5paCoFAGalxYAKQcGlAyaQUop7sAyCaUUgHGaaTtpyAdwT3pcimqd3Jpcc0JgKel APFFN5pgKSPejPpmijGe9OOowyPekHvmlHBoxu5p30JAZzS0i5J5pD3qFJXGhR69KQgg9aBn 1pMc5yacrgLz6UD6UoHFA64pxloA1TgZOfyoHzDqaU9cZoYcYHFDAPbrSZ5oA7ZNBGBTeu4h OM8CjnPTijtSjmp0uAmSPSlHsR+NIeKTr2qraaALjn1PrQQMYpBweOKU9KfTUYAiikyc0Doa nmsAAc5pCTmlHSlB6imtdxADTCqswPcU/GaTgdqGMOtHQ80YxyKTHGaSloA7qetJ35puBmlp pN6oBOaM9h0oo6UXezAcVwKbkdutFL27UXtsA3PoCaQZH8JH1pwOOlL1BzTTbWoCZO3pSDcR SikbPrSbSWoCc55oxnvQOTgmlPHFS32ATke9BzRSHrVxdtwDOajmOY+B3FSk8YqGXiP8RWkN ZCP/2Q= /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGBAh0DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDSY8Gqjk7xVpulUndQ4BzTuSWowCvSop4p MZRQ3tmpYcEcVLQMyxHM33rYrz1zT/8AT42AjhVl9c1o5NGaBFOOS+JG+IY+tXFzj5utG4+9 LmkAUdaOtLii4AOlQTjjrip6guPu5p3GQw/eHNXBVOHJbkCri0NiCgfrSk8dKaevXNINBksU c33157EVBi4tvusZY+4PUVO8kaHDcZqOS8gi+89AXASw3K7SMN6GkMc0JzG5Zf7pphe1u/un 5h/EOKdung5YeZH6jqKA0HLdg/KwKt3BqQFXHzKD9aYHhulPRiPXgim+TLEMxvuQfwntQFyr fabBOhxvjP8AsmqsNr5KkPK+wd8Zq808O7a7GOTH3T3qJrm3gDNJNs/DNFxsWJRgbI/NGeo4 Iq6GATLDaMd6wpr+adttnCxJ/wCWg4/Sli0m8u1Bv7qQ46BeBRcSLdxrdrE5jhDTS/3UFVyN Wv1Jc/ZYfQcmpGU6aoWJFZe5HWrEd07R7vMDL6HgilqBXttI07LB3M0pOW3E5Bpf9K09ttuA 1uOqen0qOQwu+9E/eA/eU1XNy5kAuAyDHWmGpdluoLlMMMk9UPaoVmlhIWFTs9+1MktYcCZJ sMcckVP5rqmzzVYHjpSsBa8h7qAee3yn+7VRVFtIEhtw+P4s4p0dzJA+JeEz1FOnkSZN8TsA OpAzTGXon3L8wwe4qXPpWbZTJkoHdsDqw71odRmgBwpM54pR0o4o0EH1oozSjvQMbSZPpmnH PPNNOAOTihAHPpiioXuUXhQWb2FJsnl6ttX0ouBK0qJ95vwqL7Q0nEaH/eNKLSFWDbSW9Sam oAgEDyHM0m4f3elSxxpEMIoAp9JQAEk9aaSPelNNJzTATNNp2OOlIRntSAbS4oPHXiomuEXI GWb0FAImA4pHdVGWIA96gBnkzx5a/XJpRbRg5bLH1JotYBpnLf6pS1Ajlf774HoKmAx0xS0A MWKNPurj3qSkxRQAUtJQc7Tg4OOKYIXoOelVxeROzLGC7A447VC0WoliDOhX/dq3GrKuDjPs KQiPbK/Vtq+gpPK8o5QkjuKnpKAGK4YVHNyF+p/pRKmPmRlX1BqOSVQq5kTqe9BRrMOKpSD5 6vMMjrVKWOXzBiMlfUHpQiSzAMJU2eOahhDBeRipc07D9ApQKSgE+lKwrC4opaKLAFANFA4o BC1XuDkcVPmopYmf7rAUAQQH94KuA8VXjgdDkkGp+1AwJNA+tGaM0CEkTehA61ntZXpzsMbD /aFaQoJ4oAoW9ncRn96Fx7VcEYH3WK/jVE3U63vll/k9KuvIqIWdgB7mnoBBLbMx3A5YdxUQ upLc7biMt/tAVH/aLTSmO1lXIOCCOKlNzqMY/eWUcq+quAam4aDnJu4ioiXaR1NZq6ZDbzFh EC3ueKuPfAAhrae3PqBuFQR3kcjEGdWPoy7TVbBsXopikeNo+gqRJGk7AD0zVZY2VS6MF746 iqBn86bZNJ5J5+70NIdy7cpGHyRz9aia0WdMthh6A4pBahk4O78aWJ2gyoJ9wRQFisixwS/u VeMA85GQaleWSRd0YRseoqWWTLZSYR885XipIo/NjyZVI/2RigTKa7WO52VSeq4qWFj5hjRM oehI6VPFawnIZN31qaNBCSqgAUWHZED2q71LEtjtT2sA4xFO0IPUKM5pZ54onDSuFHvUMuoo Rsg3MxHBAyKALUFoIB94sfU1OKo2E13Ip+0ptPartIQuKCKQkAcnAqFrlCSsfzEUxk1NeZEH zN+FQlZ5PvnavoKfHbxx89T6k0XAaZpZhiNcD1NILXfzKSx+tWOAOMUUANVFRcL0pwoooAKT NKabwO1AC0UlITjrwKACkyKia5QcLl29BTSs8o5byx7UXFqSvIka5ZsVC07vxHHkH+ImnpBG pzjcfU1JjHagCv5DP/rmLe3anpGE4UYqSgfSgApCM07pSGgY2jFH4Gl6UbhYO1IKDSZFN2EL nml60lL25pDExRzRRmgBaaadzTWo0C5HLBHMuJBkVnXGiac2CYDkk9GPtWn0pkx4XJ9f6UAa AcMcA08fWq6QFGzkmpxwKAtYKBS4oxii4BQM/hQaMZoEB4pHkCjkGlpHTeuMkU7jIxcJ1wTS faUB5Vh+FNFrg8SGpBACMM+aGhDDdxDgkj8Kk8xduc8VGbROjNx6GpBBGq7c8fWpGKJEI4P6 0iyK/wB05pBaQAfcpUgjjOUUj8aYElFFLgUAIKD0oNGKBHN6teyW14PLQNI3Kj35qdbK71WM NdsIhxlVrYktreYhnhBYd6fgKMBQBQBQi0u3s4yYMhvXrmnJLIP9apIHcdqvdRTVAz0osMjS RJDlck1DdwJKh3gEfSp5bZHO5SUf1FVJlmhBLKzr/eFAiC2t0QMEZyM9DSEAScbfxFS22+YH a20c9RSJastxiWYSe2KAJrfqfkA+lTSQLKvTDdiKkVAF4GKC6AH5gcdaa0GZE+n3zP8AK8fl g9xzirsMYigxjBqrJrUDs8VupaVDyKggnvbj5pEMQP8ACRmhu4GkjqvJIzTZjLIp8sYPqakg iCrkgZqbgUrCsZv2QXa+XdAyDPfir8ECQIEQYA6UjXIHCDe2aj2Tyj5n8segFAyZ7iNOGf8A CozLK/8Aq48D1pUgRe2W9TUoO3g8fShBchFuXO6RyT6VMI1A4Ap1H0NFwG4xS4pTxSdaEAlF BpO1ACnpSD3pM8ZNRvcKOE+Y+1AEp+tRvKiD5mFRYnfkttHoKctuindty3qaAE86R+I48D+8 aTyGY5lkLH06VOPpSGgBqqqYCqBS5PBpRyaOfSmAnWgdKO1IfrSCxHMSEJGfwqqXnJ+QtjHp V2jNAFRXljB80knsaY00mflkbH0q/nAxSE/SgCgszk8yEHPTFWWZvLyG59cVJgdcVC10I22l CfwpJICE3Mg4DnP+7TBeylgu3bk4zip21GIIWMTAD2pianbOwUAgk9CDQIVpZ0GQ+72ApY7i R2AYhfY96sjaQOAAaNqkD5RTGRyS+UB71AbyQKTtGPSrfHcCk2R5zsGaAI7efzo9+3FSE+1L gAcCm5oAKimJwvHc1Lj1qOYcL9TQM0PNi/vjNHnxr1cCm/Y4G5Kc/Wj7FAeqcfWmxEizRNwJ FNPxUcdrDGfkXFS444pAGBioXuYYzh5Ap96mwRUcltDLxJGrUAMFzCRkSKR60w39qDgyjPoK kSzt0+5EBQbK2bkwLn1osAn2mArnzOKqu1pK2VuSre1SzQvEP3Fure2ajWOfGRaIrfWgLCN9 mceW1wxYDsKjAtbZstduB7jNSFb3r9kT8xUkaXDKd8KA/TNFhWCLUrST5Y5Sxz6GlOpW4bYS wb6URJceYQ8CBc8ECrQjB/gFIZXfUrWMfM5/AUkeowTNhAx98GrXlR5yY1zRtQdEAp2EAORm kJ96WjbxQAzzEyfmHHWmG7t1OGmUGobiFy2UiBz1NRNYKy5NujH0pgi6ssb/AHHB+lHOeaox wTRt8tqEHsavonGTnNIY6imySCIZaopL63jGWY49hQBNgf3QPpTSi5ztGarpqVnIcK7Z+hqx uWRcqRigQvbHSqjWbPP5hxt9M1bUcUpGR0oGV0tLWJt8cCq/dhU25u5p2KQigBMcUUopaEBB LbRyc42tn7wqNXlhbbINy/3qt9qq3UUjj5WO3uKAJeHX29jS5xxg5rL8y6gBNu3mAD7hFTw6 mJflliMT+o5oAvDI64oyaaoDcnk+tPxSuMTOaDUUkyJwPmb2pgM0vU7V9KYiV3VPvECofOd/ 9WmR/eNPW3RTk8n3qXFAFLE/mkXCZQ9GU1aVYwPkUYp+MjFR7CvKfkaAHEgck4pu9R1YY9c1 FPuKYePP0qmLfz1/eRjA6DdigDSDKejA/jSGsgrJE2FsGx6h6mhurpXCtZFEPcsKLDNGikU5 HNL2oATNFHSgmgRFIGZflbBqB1vdv7p0B96tYoFDGVkS8B+cqeOoqJ49VLZSWNVz0x2q/SUI RSH9oCP5mQvnk9sU7F6I8jY0n6Va70uKAKivqBB82OI+mKav21smSKMDtgCrmKTHpQGhQaXV UzstI3AP9/FSRzX7Q5e2VJP7obIq4MjvS8+tGoymk12VJkhAPbnrTGur8nC2fHqWFXucUAkU IRFE0rpmWMIfTOaeBTz603qelACVDP247n+lT81BMMhfqf6UXA16WowTShvU0XuA+koDA07F ACUAUUUCuFLSlTTc/jQIUfjR17mgA470uDijYYlGTjrilwaUqcUANyT3pMZ704A0YxRoMTFI acQfSkx7GgQg96WgKfQ0pRvSgYzJxRk+pp2xs9KNjelFhDc59aKdsPpSbT6GgLkMyuU+TGfe q620wyXZST2xV/a3ak2Me1Gg7Gcbe/DEo0W302gVPDC+3EoGfY1Z2nuKXafSgBgAUYFLinbC e1BXHUUANpMU7aaMe2KQxmKTNP2n/JoKt/k0IVhoNJin7T7fnQFycAc0AVprUOS6HbJj8DWb dBYT8/yMT1rb2/nSFV6Mqn60DM+2uC8YCqzY79Km8uR/vudvoKshPTH0pCCOgFMnUiWNEGFF OxinbSevFG04osNCYxSZpdpxxS7SRnH60ANopSCKTFICKWFZV2sSAe4qqmmxxuHEshI9av4J 7UbT6UAUpNOjlYsZpAT2BqxHH5S7QSR71IVPpSbW+tMA7U007DelJtb0pANpCKdtb+7SFWxy KLgNNJTtrehpArehpgBzR2pdp9KUK3YUrgJQaXaw6ijB9DRcBtIacQfek2k9qYCdqUUoHsaM Gi4CUhp2DjpSYPpSuC0EpBxS0Y9qYridail6Djuf6VNtPpUUwOB9T/SkMn8y97mD/voVG1xd L95oQPUGuZ/4TbSRyNKlP4mmnxzpg/5g8v50c8RpHU+ZOwyJ4QPem+dOOl7APwrlz450/Gf7 Gf8AOmHxzYdtFf8AOi6Cx1q3M3Q30H/fNOFxIRzqMOfZK4//AITm2zxoj/nSjx3Go40Uj/gQ pcyQuU6xriUdNRi/75pwuWZcnU41P/XOuS/4WAwXKaIDx3YUv/Cw5/4dBX8WH+FCkmFjrfOP /QWGP+udHnD/AKC4/wC/dcl/wsW6/wCgFF+Dj/Cj/hY17jP9hRY93H+FNyiKx1bXCAf8hc5/ 650jT4UkaoSe37uuT/4WLfsP+QHF/wB9j/Cg/EXUB/zBYv8Avsf4UrxHY6ZL3ccPqTjnr5dS i5hxzqsh+kVcofiJqfbRoR/20H+FH/Cw9U/h0eH/AL7H+FK6FY6o3EH/AEE5sf8AXP8A+tSf abYj/kJTn6Rf/Wrlf+Fhav20qD/vsf4UH4h6z0/suEf8CH+FFx2Z1PnW5/5iFyf+2ZpDOgbC 3dyy/wDXP/61ct/wsLWu2nQf99j/AAoHxD13tYQj/gQ/wougszrBJAeTc3X/AHwaXfb/APPz d/8AfBrkT8QdePSyhH4j/Cj/AIWBr/UWUIH+8P8ACndBY67dbH/ltdn/AICaM2xH+tu/++TX IH4g+IO1rB+Y/wAKB4/8Qn/l1gH4j/ClsFmdaywY+WS7/I0i/Z+jPeZ+hrkh4+8QnrBABgdx /hR/wnviIdIIOvt/hRcSuddi19bz8jSf6L/0+D3wa5H/AIT3xHn/AFMA574/wpP+E88RMOYY QffHH6UrlWZ2GLb0vP1pNtt2W7z75rkB478RH/llB/n8KD468Rf884KrUOVnW7Yw2fLuiPqa X/Rf+eN3+tcifHfiIEDyoef8+lH/AAnPiX0t/wAqm9wszrv9FP8Ayyuz+JpcWx/5d7v8zXIf 8Jt4iI6QflSHxv4jH3RB+VHMthHX7LbPFvdf99Go5Y4ivyW94D/vGuS/4TbxKScNbjn+7R/w mvibP+sgA/3c1akOx1qJCV+e1u8/7xp3lW3e1u/++jXHHxp4n7Pb/wDfNH/CaeJhjL2555+X rU84WZ2Bitx/y63f/fRpBHbdfst2P+BGuR/4TbxLwd1v16baP+E28Sn+K3/75oU77BZnXGK3 7W12f+BGmCFCxza3W3/eNcn/AMJp4l5+e39jtpP+E18T5I8y3x/u01JhZnYeXbA4+zXZ/wCB GkEVso4t7sfRjXIDxr4m6F4Ov92j/hM/Euf9ZB/3zRzDszr9lsc5trz8zSGO3x/x63mPTca5 AeNPEoBy8BwOyUv/AAmXiXP+ttx/wGlzMOVnVSRwkDZb3gOf7xpVW3IG+3uxjjqa5X/hMfEm P9ZBnP8AdpD4y8SjrLB/3zRzCsdYFtR/ywvPzNBS16+Vefma5L/hMfEuOZYP++KT/hMfEnP7 63/74pczCzOv223/ADxvPzNNKW3/ADxvM/U1yX/CZeJc/wCutwP92k/4TLxJjmSDv0Wi7BJn VqsQB8yG8/AmlYWw6i9H51yf/CY+JO00H4pR/wAJj4k6+dAORxs60XY7M6oraZz/AKcPzpP9 Fzky3w9tprlf+Ew8SnJ8+3x/uUo8ZeIsAiS3Oe+yjUOVnVbrY9Jr7/vg03Mfm8SXezP908Vy /wDwmXiTH+utv++KP+Ex8SdTNB1xgR0JBys6zdbZx517/wB8GjfAOlxe/wDfs1yg8YeI+P31 v1/uUg8ZeJAcGW3xjrsoJszrPMhH/L3ef9+zSGWL/n9ux/2y/wDrVyn/AAmPiIA5mtzgDnZ3 o/4THxH/AH7fP+5Qh8p1TXIUrsvrnGeSYv8A61O+1R99SuB9Yv8A61cl/wAJj4kH/LS2/BKP +Ex8R8c23uSlF0KzOtNzHj/kKzj6w/8A1qQ3EfbV5B/2w/8ArVyZ8ZeJMfetfpso/wCEw8Rf 3rXP/XOi4lFnV/akHH9st/34prXZGAmsbvcwVy48Y+Ihxm0P/bOk/wCEx8Q45Fof+ACqvoHK 2dYtzkcayuf+uNMmuiAudXTqefJ+lcqfGGvEY8u2/wC+RVe68Ya+AuEtep6xj2o5kPlZBRXQ DwIOR/wkpAz977PwfwzSDwKON/iJseot6ydSK3YXZgYPQ0uK6E+ArcZ/4qpz8uf+Pb9OtIfA ttnK+KJevQ2/SnzwfUdznsUdK6MeBLM8N4skHv8AZqD4Ds+APFMmRnk29PnhYOY5zFBBxXRj wHa4/wCRqcn2tv8A69KfAdmMgeLH/wDAb/69R7WKFznNnjH1oHTmukHgO16/8JYxHOR9m5pP +Ff2IAJ8VyZ/64f/AF6FVh1FzI53HFJz3ro/+ECsR08VS+3+j0f8IFZc/wDFUy/Mef3FJ1Yd w5jnB/WlArov+EDtiOfFUn/gPj+tH/CA2u3LeK374Itjj+dHto9w5jnfajH4V0g+H9qBkeLC T3/0f/69NPgG1/6G0+4+zH/Gn7aCHzHO0V0Y8B2g/wCZqfk5P7jrSHwHbdB4sbHvbZ/rS9rB 9Q5jnse1Ic9q6L/hA7ft4sOPT7N/9ek/4QKL/oa8/wDbt/8AXo9pBC5jn+1FdCfAaA5/4Snc M9Bbc/zpo8CRgDHinb7G2/8Ar0e2gHMYFGK3/wDhA1PK+KgOO9tn+tL/AMIE+M/8JQp/7dv/ AK9JVorqPmOf/GlxW/8A8IG46eKV/wDAX/69J/wgj5/5GhP/AAG/+vT9tAOYwO5pa3v+EEm/ h8Txn/t2/wDr0f8ACB3BBz4lj/8AAf8A+vR7ZdwuzCHFJjjFb3/CB3I6eJoOfW3/APr0g8BX YAA8SQEDp+4/+vQqse4JmFilxW5/wgt50/4SG3/GD/69O/4QK8yR/wAJLbA/9cP/AK9HtIvq O5g4pMZ5rd/4QTUAT/xUVoef+eP/ANekPgXUsf8AIwWmP+uQ/wAapVIrqFzDxRitweA9Uxka 9aH/ALZj/Gl/4QTVyONZsj9U/wDr0Kce47mDjIpFTFbx8B6ynB1exJ/3f/r00+B9axj+07P6 4/8Ar0c67iMXFBArb/4QXXcf8f1l9f8AJoPgfxAfuXdgT7nH9aXOu4JmJScd62z4H8RgjM9h 9d9IfA/iYdJLAj/rpT549ymzHAGOKMVrjwT4nIwfsAz0xLzSHwR4qU/csT/21o9pHuHMZGKX Fap8F+K8ZFvZYz184U3/AIQ3xWD/AMelqw9phRzx7iuZmBRtFah8I+LAP+Qbbn/t4FNPhTxW pOdLhxn/AJ7rR7SL6iuZu0YoCAdqvjw34nJIGkKcE8+eoFIfD3iYf8wb8p1pc8e5V0UQo9KN i+lXRoHic9NDdvpMtJ/YfiUZzocn/f1aFNdxXKmwenek2D0q0dH8RD/mBy/9/Fpn9l68AA2j Sg9x5i1fNHuCkQeWvpS7F9KmOm66P+YNNj/fWj+z9c7aJcHnn5hUcyvuLmRX8pSckUeWPSpz ZauvLaRcD8RTfs2pk4Gk3J9eBVcye7BNdyLyl7gUeUoyQOvWlcXa5DaddAjtszTGknU4Nhd9 f+eRoc0h8yF8tfSgxKeSKja4dcZs7rr/AM8jSfa1/ihuAfQxNQ5LoLmJPJUHgUvlCoftsX9y UfWM/wCFN/tG2BIJbI6/If8AChtMakifyl6D1o8oVX/tK15yxHOPumlGp2f/AD1x9VNIfMT+ WMEVVvIgwT6n+lP/ALRtP+ew/I1BdahaYTEwPJ7H2qkxXPTBkUfMR1oz6g0uQK8xyRCG4PrT st60ZzTc84zStcYpz64peT15pOKOPSjyYAPpS84603P0pabAUjI7UgUe35UoFGQKhuwCbeKX avpzS7uKT8KaloK4YB7UYHpmlBpRU3vsA3aPSlx7Cl696THrQkxITHrilwMcj9KXPtRSejKs NGPxp1HP1ozVt3Cw04BzxShhS0cUX7AAx2owOpFHFARQSQOT1qbN7gL8voKTjHQUY9KXGaEg E4xyKOPSlA96Dn1p+QCYGaTaM9KWjFDTQXDHtTdpP8ApeaKSVgE2nptFGO+KXNGcVSn3C436 YFHXrindaBRzCuIBgUCnZoyO9O6GJj2pNrZ5xj0pT7UgHUjNJsQmzjnmjYBTs980uOOlEbDG bARgmlC49fzpQPY078KUrAN59T+dGTjgn86digj2qL2Abk4xlh+NKCR/E350uKMelVq9hbi7 34yzcdOaXzJf+ehpnPpQBxTV+o7DvNcdHfP+9R50uf8AWv8AnTOnGKM09VqFiUXMw/5av+dJ 9pm/vvn61HmgZ9KSbYiX7ZP/AM9Hz9acLy5UcTSfnUPPpRmk2x2ROL25H/LZvzpft11/z2b8 6r8YoA44pqXcCf7Zcc/vP0p639yvST9BVXFLRzMCz/aN4OkwPsUFJ/aVyerJn/cFVsCjimpN C0LH9oXHpG31QUn2+4IO6OHP+4Krmij2khlj7a/eCE/8AFMN0CebS3P/AAAVDijtVc81qBMZ 4iDmytj/AMAqvObQhc6dbNyeq/SnVDPnC89z/StaVSTe4EuT60BqMZNGQOO9YAJmjI70pIHN HHampSASkzS/hRTvbcVwpcZpByKeFwc7hUttagmJtFLS8dKTHFTe6AQZpeaTFLiqTsAUnOR0 oxRjHWhNMYEt6UZNH4mjFJNXBC54oBY9RikHXkUvUUSeugBnAoye1LigsRSXmAhPrSZycU7J NHPrmquIMe9HTvS0c54GaWoBkEUDjvmgjPajAFNPQYdqQAelGKXAHWkgEz70hxjrRj3o6UXu AZ4xRSEEnrRjNOyQC57daBTaXBHUU0AuaUU3n0pRn0qRaBjmlxx1NAHtRzTSQ9BMelHI70op cU3YBKM0cjtS9KWl9AQA4FGT6UZ9DS80SACaTPH+NHNFTYA3DFBP4UlGOuTSemwWDPpQcGjA oxTuuoBSEmlIpDTYAKXiko+lCiAtHbpTfrS+4ND0AWjFFJRzALSUYJpckDFFxWCk4pfqaTH4 UXGHXtR+FA6UUk3ewIM0mc0pFGD3FOwCZGeahnHC/U/0qbGRzUM/Rfqf6VpStzCJqOaUfQ0V klZ3GJz7UmDTqTOO1VdiYlMklSFC7nAFSGs++BdgOoxVJ30YFWXUL67ZorNNi44Y9DUkVvdR n/SblVPtzmljnSBVRU+VB93+9SGZpXLMOTyc12ww8GrtD0LkMmDtc596tA8cEH8KzBLswSM4 9K0UbKBjWFWiou6Adk+1Lk+lKAvrk0vPpxWErJAhp9xRxijGPzo5rNAISBSjBFHNKKtKwCYF KBnpRtGaOPSjQBe1Gc0Y4oHepEGBSgUlJ82cZ4pqSegx2KSlzjoaTPFFrALjFJ74oAbrmjPN Du9ADk98UYo60EkdqOW3UBO/NID60pNRzSLHGzZHAJo5mBFc3kVspL1mPrsuf3Y49MUhjN3K d3zJjcRjtU48qHKxRgD3HNdFOhzrUYlvrPmNtkXbk9a045FkUFWyDWblG+8gP0qW2dY2CAYB 6CrqYflWgjQ5FLSDketLtFcqikAvJNGD9aOQOBRzStZgLRSZNGPenqwDvR9SKAOtLj1pNLoA dqTJ7UuTijmpSATNJzS8E+9Jmn6AGaAetHajHrTSuAZPakyQaXAIpKHZMBT1pM0Uv1oaW6EI KKPpRmgYU13WJSWNO7ZrKvZGlcjJCDqapJN6AE+rIjEA96ZFqe81FHPBEmyOBGGercmiTyn+ YIqH0FdkcKmrjNaGcSrmpsjHFZFm7Z9OOtaq5I5rlnHldiWx4zijtRhqTnvWTfYYtH40fhRn 2oWohfrScUfgaKrQYnuKinHC8dz/AEqXFQzdF69T/SrpN8wE4owfWlFHFTYVxKKXBxRUp9wT Gmql0uAWq7jFI0ayjawFXF6jMBv9YaUEjvSalaXNgzTNbtLb4z5iclfwrOXxBpG3aZ3M27G0 Rt+WMV6cJpxFoXnkZVORnrgetb8SbIlB9KytMsZ72ZLy5tzDbqSYo3+83HDH069K2iorlxNR PRANyeeKdyRyMUmO1KR15Ncd31GIaTp1pccUU9wDFKKQ8U4dKLAAGD7Uue1NyR1BpcnPHSlY BaTvRS5pXSADwOaOKMetGT2oATPtSH3paOtFwAE0ZINHTpSHjrTtcAIOeRxR2o+tH4UWSBBm q92AYH78HNWOB1ppAdSBS16AZIZomYIxUlcNj0phdWJxgfjT9QAizKwO1B85x0HrVYxB4/Mi O5ezA16OHkuURNnHYY9c1LakvKyn+EZrNuLoWMXmXUgVSdqgDJY9gAOtbOlWk6W3m3KbZX5I znaMnArSrK0QLqjAGRTsZ7UYpcGvMe4xOB2NKPpRj3oIz1zTADSClC+lGKV7AGfaj8aMUUuY A4xRSetGOKV3uAYHTFJgelLij6U0AmOKOnel5pATTATPrQCewp2cmjrSWoCfhRRxigYHrTsu oBn2oz60o+lLgUtAI2PynnFYk5IdxyMmtwqM1kaxE0AFwEJi4Dt/d961pu0gM9vvZ7UjSfLx TzHIy52AoDwwOaqvNHCpaRgq+pr1YtNAamnMZFOQf8K2ACoxVDRYWkt/PKFA4BG4YNabA5rz 8QlfQS1GjnqaWlxScVxsYZxzmjOaMZFJj3qkktQFz70me2KWk69qdwDNRTnAXjuf6VLUM54X 6n+lXSa5hIsZooxRis1ILBmjPB60uOKMZ9qAAH0yaASDnFFLj3pDJo5mQ8gYp5nj3bvIj3/3 tozVajrVKQtCWSVpPvHNRHFHPrSVHUYDFLwabSjNNgGBS+2KTOOo/Kl5NEbvcVgAOOlL26Uo GB1o5703MBOTR06ij8KXNRqMTnHSjn0peaT65p7AL9aaQO4pSR70ZpXFcTHcUuDignignAqh hzikxSk0ZouFxv40oHvRmkouAHrSjHY0A560U+oEoZHXZKoZTwQayJ/BmiXMzTK81uzHLLE5 AP61p5NKD7UKUovRitcp2PhnQ9Jn+0W9s0lxz+8lct/Or8kjOxJ6mmZzSda0c3LdjSsGMUfj QfrRnjFZNtbCfkJyDR3zS+tIMVPNcYZ70cUE4o6iqAKSlxRRewBzR0pKCKLgLyaMHsKSjBpo ApeKTt0o/ClsAvNFISaBmm2AtLSYNJg0LXcB3HrzSYFJjHekw2eDgUNdgQ4fSnrtYFJACh4K nuKj59aUMalTfUDHu/BkE8jS6fqE1nvYs0Y+Zck+hp+neCbS0mS61C9e8mXlQwwF/CtYOfQ0 oc9DmtlWkkKxK7Ki7IxgDgVAfelLHHSm1k5N6jCkxS0hzjrip1YAaSge5oPWnYAFHekPNH40 mgA1FOOF+p/pUuB6VDPwF+p/pW1F+8BYBGKD9aMY6UtZ27CEH1peaOaXmheY0JS0mfajmpdg DFHSkzS01ohBz2NKKQmjNMBenQUc9/0pAaPxpWGOUn3pab9TQKaYDjijGKTp3pe1FgEyaOTR mlzQ7bgJ1oxxRntkUHPrSuITHelxxxRnFISe1GrGkHbmj64pM+oozxTaAXvwMUfjR0ozSTYA c0mKOKXtwKGkwEo5pce1JQtADt1pR0pOewo4oVmAtFJRn61VrLQBc0uabRznkUrMBTRSDrRn HalowFoJzTSfzpRS9AClB7EiikoS7iCl5FJjNHIod2MP1o5oH0oovYEJSjkUg9aOD1qtxDqO lJR0NFrDFyD3ooJzQD7UmIKXNJmk/CnZ9Bod2pKKKmLuA6kzTeaXOaba2GH4UlBpKSj1QtQz QMdzRz60mfpV3YC0hFGfegmq0QCdqOPSjNGahpAGainIwvHc/wBKlycdKhnJwv1P9K0or3gL HJoBoFHbis4yTEFLSdqOfWm0MX8OaOaSj8altILijpQaTOOlHNC1AAaM5ooBPTtVpWAXFGKM +1H1qHzXAMYoxRnFFLrcA5z7UuRR2pOPWm7MBcc+tHbpRQKTVwACl/Gm5z3pe1EQCjnOAcUU lNOwC8Y5o60maPxxQ02K4d6KQcHrS0eQXYUuaSipaQCnnpSAc0ufakyOuKeiQw/GijPNHBpA HNHPajGKOaerAMUuPekzijrRqAYxQaXpRkelC1AQD0FFB5NJj1q9EAuaBmijr3pNx6BoHNB6 Uq8EmjntRcBO1GDRyaTBoQCmjFGDRQ2wA0Z96KOMdKFruIKM89KOvagcdqLLYYueKM0ZzSdR SAPxozScUvQdKdtAAUnXvQfpSZ7VNmAuaWm0ufWrAOtJRxRUWQBRgn6UUc+pp8wBj0oNHA70 nemmAfhioZ+QvHc/0qaopwCF4PU/0rWlrICcUUHmgdKzVrAJS8+1GaKmyYgFL9TSDmgHtii1 kAUYzRQDU+gBjFLij6UciquwGke9KKKKEvIAOfWjNGKUU/UYZyKBS8mkOfWpbtsAYFGKTHoa APoTVagLS4pME0fjSW24C9KaMilxz1pOacdgFooozQ1cANGPakzQD7UrNiuKMUUlFNDFA9KT 9KXHvSdelJ26gLSY75opfxFEUwsFGRSZozTvfcAwaXmjNGc9qQBzQPpRmkzRswF60UcetGRQ 0Ao96KQ9eDRn3FHKAYOOtISM0uc9BRkijUAz70fjSYPelpgBNG7HGKTn2oycUPyAOvaijNAN TzW0ABntzS/hSZop27AGM0vbGaSiq06gLgUvSm9qBUtXAXPHWkH1ozRQm7WAOlFITSc09LAK faijnFGadrIApKWkqdQFo7daSloegCVDP0X6n+lTYqGfov1P9K1o25gJ+KPpR0orJ6i1DNHW jt0oGDU7AL260n4mgcUA0+moaBml/CkozRcAzjvS80nbqKMinZ2GgpcUgOe1BJojcNBaOaTJ NGSKbvcVmOx60c0maM+9S1qMXJ9KQH2xRjNIBzTQC5FLn0pPxpMmlZAOyKBSZNITxTAdSZpo OaUE07MQtHHpRmjdxjFCGGKSjNGaG3sAtJnPFGaCaVgFB9qTp2oBo3GhxGL9RRn2puT2pec5 pRVxC4zQQKOcUnPrTsAtFHNJj3oXmKwvbgZo6ijkCgAjvQ13GgxRnB6UZpCSe/4UldAOzScd 6TP0pQfeq3EncOKPpSZ96X8aVgsJkdzzS5zSE8dqAaLyGhc4ozx0pKTNKz7BcXvSn6U3OO+T QDTuAtAxRmk5xTSuAuaUdKbR+dDYC5xSZoowDST7gGaM0hGKODVegCg0ZpOaSmIcDR36U3nn ml+vNJoYUdqTPajPpUtWQBnNRT5wv1P9KlzUM/RcHuf6VpR+LURZ7UnNGaM1mm3sAoIo4NJz QCaNHuFxePWikyT6UZI71SGLRSYJ70YpAFLSUUmAuaKSimtgD8aCTRz3Apfwp8ysAlGR60uT 3xRmla+wBnFAOe9GaKnYQZHekBo5NLn2qkwQAj0ozSGjA9KUrPcYuaMiiihWQBSZHSl7Unaj QAGT3owO/Jo7cCjmq0aAOKM0c0nOanXoAufQUu6kooukAAnuaM0Gk/GnfTQAB+tOpKTmlYB2 aTNGMUDNNMBc0ZpPxo+vNJtgGc96UkjoKSimrMA/ClpM0fjS1WwBiijtRz681NxB1opPcnml q4vuMWkpOnel7UmwA9KXPvTfxpeKLc2wWDv1oyfTNFJ1oQC5ozTRS4qgDrRSUfSlfoIN2KXN IenvRnihaDuLxRTcilHPanpuFwz6Uc0nGeBRxU3QXDd7UueORikz7YoPI609ACoZzwv1P9Kl HFRzYwv1P9K1pRXNuBPRmm5x1ozWIh2aAab+NFDfYY78aKSk5PtQ2wuOB96M570lAOO1NAhQ ffNH4UCkJ4ouugC5wKCRSA0vFFnYAGKUnIpPpzRStbcBaM0lGR2p6AO/Cm5oBo5A4xU6AKCM dDigGkzRk9jRbqAuT6UfhTcnuc0Z9uKOYB2aM4603pyeKXPHWlcBaSkyKM+tCdwFzmlptGar mVgF/wCBfhS54puaSkpXFcdRTfpSlh3NDXcNRaKTPHrSUlcdx2TRu96TNBNUrgKDS5pgJz1o yaduwDs460uR60wH2pQfUUW7gOozSA9sCil10AU4pKOaKTSEKKQg+tHeg+tC0GGfeikoyabd wFozSZoyBTXmAUUUCkk1qAuaQUtJmjXqAc0HmjNFNNBoGT0oooxRZAFGCaTtRRa4C9KTn1pc UlCTEHakJpaTHrRqMUZ9aKMCj8al3TAKinyQvPc/0qWoZzwv1P8AStKPxAT59KP50lHFS0kA Z9qCaKCaSfYAz60ZGOtJS/hVW1uAZ460UZ9qBRYApcZHFJQOmM1m0wFxQPSgZxxRzTi+4goo wT0o7ZqhhRzRSiplfoGgnIpOSaXvR+FNR7gJg0vagZNFNW6gIDzS9qMCjApSs9gAAUEUcUn4 0JaALR0pM0c49KXmCCjAoo6dqrSS2DQO9IOOtGQaUZFN2sAZ9KKKMVOqAKXtSYApMe9S3cQZ pc0YoGKpNWGG8E9aKX6Ugz3NSpWFYXPFJnNLmjntTuMQZpeaQZHUUAn396XK9wFFKelIDxRm nYBM9qOlHfrSgCnq9BXEoyB3pTik3Ci3cYGjPtS5FJQ3bQFoFFHIFG496aBsKM0daKTdwuLi ikGaX6UkKwfXFH0oGR6UcAVo0NBSfSj3pKnVAOBptLnikou2Ac9qOfpSUfhTYC5NFJzijp1o tcA6VFPyF57n+lS8Y4qGccLz3P8ASrp/EInPXpRnjmlAorEYmaM0uPajA9KNgDNJ396dikxQ ndgJS5pAtKRV37AJwaUUZ9aXNTqwDmkwfWlo6UuWwMTp1PWlo5ozSa7CQc89aO/SjPrRnJpo YZFGfejIo602mCDJoyOc0vbrikIqQAH0ozSYpafKAZ9qKSlxnpRYWoUfhmk5o5xQMPpR25NK M96B9KqOgCc0ppDmine+4IBnPTiil7daTk0nZ9AE5paPxoxSQB26UoNJS079AEPJo5PQ0UCp aYtQoo70v4ChMYnPrRyKX60mfamgDk0c96XtQBQ2gsJkilGcc0lFSpAHAo60fhmjjtkVS7iD NGRSZNKM4p6dQAHijNGaSk7LoMXJxRSCjdzg09UAooo/GkoTAWikzzxSHmi4C9e9Hb2pv40v QU29BC/SikB9zRUJ6jQtJznrRkUA1TbAPxoyPWjvRRe6EGR61DP0X6n+lS8VFO3C89z/AErS h8QFnPoKQUc0DmsFLsMKXg0mKXt0p3b0EriYopeDSZpK6GL0pDmg0pPFOTEJQOlKOlGaSDUD RnAopO/SnqMUGjvRj8qXGPejSwhuOaUcUYHejjNJIYUUcUDiqvZaAJmgUvFB5FCSluAnPY0c mgdKWm9FYBOccmjtS9qKmze4BzRScZozii3YSDrS9KTNGST0ppjDijNFGDTAMg96O9GOKKnm kIOlGaWmkA8U0r7juBNFKF4ooWmwAM9xilzxSAUYptuwCc0uflo60YFJAAOaTilwBzik4PNJ vsAUZzRRx34pWAKM8UUtUlYBB6g0tFB5FACcnpQM0opOlD10EGcUHmgGjNOy6jDFBGe9Lmm5 GeaGkwF6DrR2oo5qVdsQmfaij3pCRir1GLz2o+opB9aU9KFuAfhQKQH1o79KbYC0lBNGaXK3 1FuHSjiikxSHYXmobjgL9T/SpqguOi/U/wBK1pP3gLVAFApQK57oBDxS5oo5x0pagJn2pCfa lo+vNaadQAHj0o60celFJpAKM+tJR070A8cmla+wh3akpOnNLRqMOnSkNLRRZsAxR2pM4oBp O+whcetJk0tHaiPmO4UUmTRWgBnml696KOaloBOTS0ZxQaeoBRSZzR0FJCFxRSZPpS5p6Mdg o60ZpAT61NtBWDNHNFHajWwwOeMUc46UA0daSXcAGaXHNJRmr0WwC8UnPrRRxUxSuIM0ufQU 3NBOKbQ0KTSZ45pee9GeKIjAUZzSZoyKGIXPqKbn2pRR+NNLuACjmjHNHFLQTQCiggUYGKLp AgpcYo46Unt2pt32GLSUEUVMU+4Bmkz70ppAKYrgQKKKTn1oSGFH1NBoBNGgC8dqM0hzminZ gLSc0ZpM5p2srgL1opKOe9Gm4C1DP0X6n+lTZqKbkL9T/SqpW5gJ6Wk/Cis/QVhc4FGeOaSj mptcYZFLRnjikBptX2FqLRxnrSUveqUdBh9KO3NFH1FLVAHalzSdqPypWv1AXvQetJR2xSd0 AZo/DNLSU9wFxSUcelJmi6AXNFJ1HWjFKUguLwKM0hHNGBQp3VrAKM9KOcYpMZpcVSskAUnb rS5oxxzQgExx60oI5o4opWVwD8qDRRnHansAlHWlzQaTd+gCYNHalpKNeoB+NH4UtFPmEJQS fSloIprXcYho5paMUr2GJ+NH1paTv1qlZaiFHtSUfjRj1NDaAMUYo+hoxUoQUde1FHGKbSWw B9KMnHJyaQc96XFKKXUaDJo+tIenAJpeKGkGgUUmTR0GaXoAHn/9dGcUflRjinzaWAOvejrS fWiqAKWk5NFCt0APwxR9KM+9Ax6UAH40Z9DRRildgJxSik/Sj8c0lEQp6VBPjC/U/wBKmqC4 zhcDuf6VtSiuYCznPFLSZ980ZrK6Qxc0UnPY0VKFcUZxRk4pKWrsrDAcUZoo/GpYB+JpetIT gUdaLIBR70dKM8UcdjS66CDtSY5zS0nPanpsxoWjOD0pOaB9aHZALSYNHNJ2oSAdiiko5pKK uAZFLikyOaOtVbsAtANJnFLkUrWAKKTNKDU6iEx2pcUho47k1V2MWkxSc9jRzSuIWgfjR+NJ V2bDcXpRSZNHUcnNDVkNC9RxRzQKKQxe1IKPrSUAOzRmkpPpRy3EOzSYpKXPtS5WnoGoUEcU mfalzRyvdiE5z1pQTSZNFPmXQBaMikz60UWTABj1oo59KOtDQwo5pOcUZP0qdb6gLRSUZ9qq 9gClpp6daKPUQpNJk0DpR9DQtUMUUYo7dc0lCiAZpelJRz60lowCijNB+taX7AGPeiijtxU6 dRWFqC46L9T/AEqYVBcdF+p/pWlL4hlntRRRXM9wDtQOlFFLqQAo/ioorZbFDjSd6KKzYxr/ AHh9aX+OiihAOPSkoopvcBRSHoaKKGAf4Uo6GiioW4hp/rQKKK1ew0L3NFFFPoAUp7UUVHUA 7Uh6UUVSAQUtFFJgIOtOPeiin0AKQ9BRRWUxB60d6KK0jsOIUlFFNALR3oooiNAelJ2oopsB ew+lJ2NFFEdyQ7ULRRTe5SA0UUU+gg7UooorBiEpU6GiiqgNCH+tFFFUwY0f6z8KU9aKKGAp pKKKGAGiiinHYQgpV60UUIEI33qO1FFVEYo6Uvaiipe4DaBRRTAKQ0UVm9wEHWorjov1P9KK K1o/EB//2Q= /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGFAh0DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwCurYFHmH1qLPamMcCuC5uTs5280Idq8HFV 87hjNSF9o65qWmC2HtIT/FSCZl6c1AZTmk83FbRZIXUskiBcGuU1mQtrQZgQV28fgK6WSfdx XLanL5utu2P7oP8A3ytXB2kKWxZiurmEF0gLlmJAXr/nir9tr1/CCU0W+LkfN+74P61BFIVE bJnchyDW1Br8iIFljdyOhWt3bsSmjObxBdnO7Q70N6+Xx/Om/wBvSNnfoVyx/wBz/wCvWs2u NICDG2PcVXF6vmb8ybs54pcqC6KSeJLhC5Xw9dEN1VoeDT/+EqnAy/hmUHuPJrUGs/JtZpQe xA6U3+0icMZpT6fJUtFJxM3/AISgSRnd4fuVA5IENTr4yhkT9/p1zGM85tzn9K049chUR+ZH ISpy2I/vCrw8T6QBj7JNuHYwjFLl7g2jnz4v0xFJS2nJzjb5DVE3iuzcAGxkCH/pic/jXRnx Hp8iMBYhHzwTCCCKrNq9sekEOPeIU+VdhcxnWvirSxgP5itj+M9Bn3pZvEGlz3XmLqSJkjKp KAD7da17e/0SRT9sgiU/3hGOlVrm40BbqaO30mF494CT+WOU9T9DSFcfbeJbSJZI5LlY4JDk hCMgjpT9N8S6baalb3VzcIPJ3lGVhkEjg/yqL/iUDP8Ao8BBOThRUtrbaLdX8Fv/AGdayxtw ytGCfoKaFc0rXxkYYru51C9EEMobY0cgySTxxXneuSQR2EFraytJGJvMEjNuLcev416B/wAI 7pE8l4P7GgJi+4pjzt+leba+8P8AaEcVtEIbZNu1F6DpmrVga0GtEY7OFCADtLE+uRXc+HY/ KuLhCOiIP51xjlJbiCNNxVmVOfTB/wAK7rROb69P0FOTJSLGos6ou1yuWAIHcZq9txnAAGew wKo6lg+UP9sfzrQPGfrUIZHtpVGDS0o4oYDhS5pB05o60AKvXrUgqMCpAMdDmhJgSAjtS560 wGnfhRsArLkdaaABR0HFANGrEPX2p4PFMHTrThjHrSsMXd2pD9KXPtQDTAQCnge1IDmnqeel CXUCWAfvU/3hWBZcqT6sT+proYMmVM8cj+dc9pwzaxEdxn9TSeoG1ZA5/Cp5OlRWXT8KkmOO 9K1kBBz2NOHANN69zT+Mc8Cp5gIkAVAvPHFTuyRwbgrEEheByCe9MBiJ/wBaAe27jNTMjSwt GJIwMqQc+hya1WwEYUoQrE8cE1aHKgK5oEUrn92FK9yDzTiuxVPlnJ7DtTENk4ABY0pIW2dl O5v7tOCCRiHGcd8U3CMCpjYKTjkdaYChiduetTM0mEyQOfrxUfkuzcFQPrzT9pTapO4KMZp3 AmJxRkHrxUeSzADqTisV/GOjwTyQTJdhkbaWEWVzWMnroM6BTn2qVOPWsGPxfoDcC6ZP99cU r+NfD8LbXupG4zuRCR+dK/cDoRUin61hW/i/w3cpuTV7dPUSNtI+oq6viDQe+tWIB9Z1H9aT qRQjSFPFc3b+PfCtzqF3ZLrEEcltIIy0kgVZD/sHPIrpVjZgGX5geQRzT5kwHIfmH1FYGmTy LNqOGXH2tsbj2Cr/APXroY43Ei/I33h2965fTzhLjLxrm4c/OMk84/pRYDzrvTXNIp4zTSea 44trc6WKpp0jYFMQ80TN9ad02IjLUx24oLU1s4rTmSEREncfSuauzu1d+43L/IV0ZPWubl51 iQ/7Q/8AQVq6UrvUmWxqxcVaTpVWKrSdK6tOhkPFOFIKcOlIBR0pRSc44pw6UAhwpfwpop1N WAWlGKTNFAC4B6gH8KVcDjHFIKWkAuAOwpVZ42EkUhjdfusvUU0Up6U7gSx+K9b0pmEaQXcM oxIZSRIOnIP9K4yWQXF+zYwPlGD2wK3b04RvYZrnoOZGfueaIpNgamkwq+qRhSQsbbgpPGAD 0/Ou20EZmvSePmX+VcjoERe8klxwqYz7k11/h/peHt5o/wDQaU7XBGhc2a3GN7spU5GKmzxy adj5TTOnpUpDHDnpTgKaDxThjtRYBfrRSijFFgAdeKcDTc89DTqNQHAU6mjFLTACaAKKUUAP GR0pwzTRTqQBz0xS4o4oBpagOUVItMBp69KNREkZweawNNH+hQDPSMD9K3ScRscHoeaw9N/4 8oB32L/IUWGbVn900+YjNJaD5SfalmPPNDQEWfalLAY9yBR26GopvvQjnmQf1qAJZFVpEzjc pyMjgcU0CTyZXKAc46cn6U94d8+/eBjnGetMiIeGXCsoDEFm4P1HtWlgElikl8uJZJIu+6Pg fjVwTP5JXD7xxvPeocMZUAGFAJKj+KmCQPDIVuGjYOeeqr7UbAPWS8jYA7snkCrUF6/zfaTs UHAJ71FGZfMAMzMm0c980sjuIQIo0lOcbW6AU0BZWXM2N8Yjx3HJpDLcvGgjNuGL/PnJG3vj 36UifMx3iJcqAT/SmfZY9sYj4XrhDj86BFvCqEfIySOa81uW33cx9W/wr00oNkY4wMZrzF2X zyvAJ5x7YFTsxob5a91H5U5UVeAigewpwU46U5RVlXIzbQyZ3wow75UUxtMsJAA9lbuAcgNG DVsAUoCg8VNtbj0Ks2m2NzGqTWFrIqfdDRKdv0qzDNqNuNttq17EnZBJwPzp+Djim5HOTRYV kXbfW9fgdSNWmkAPIkAOa6fQ1D6cryvGXdmYlh33HNcYvJGP0rr9EWZNItgTFnYSdwyR87UM h7nnAJHFNJpwHfNMIy2a4krnSSJ1pk3WnJ1FJLyai2uoMrmhjx+FD01q0t2JIyOtcwxzqsn+ 9x+QrqDwDjriuYVf+JlIfRv6CtqK1JktDYiqyvSq0XtVpK6WZD6cKaKcKAHUopB0pwo9QuKK d2ptKPxouAtLzRQM0ALRSCl7UgFppPFOpjnCmmBl6lLtt5T/ALJxWHDhUP4CtPWH/wBGYZ6k fzrJjbgL6mqjYVjq/DsW2zlk/vSH9AtdL4eGYLjH/PYj9KxNFUDSYjgjf8xB9wK3PDx/0OU5 PzSsf1P+FZtK4zXP3TUPepGPymo+9IY8U4GmCpBRdiF5oBopRn0pjCnDNAFHfFCYDhml59aa OBTvpQAlOH40nSnCgBw6U4UgxThn1pXAMUqigAfWlA9qrQBR1qRc0wCnikgEmO22lY9AhP6V kacuLWEeiL/IVqXhxp9yf+mTfyrPsx+6XjtSYI17QfJTZfvH9Kktv9WaZLjdSYDBntUUwzPa /wDXUf1qamMpNxAQSMMW/Ko1ACFM2dueMYPem/vfKO113bupGQBnp9acBmUgswGOeOev8qbG imJd0q/eB+Q8VotQJAX+0L2hx8x/iB/w6UkTyNCMNGZN3pxjNPVQhY+cSG5welKjkwocKM/w 45FMB6GQTADG0KDvPrnsKckzLb7yADkfJjnrTVDrISNhIA+lOQMqoDlsnqetICRWZndiEIxg 5/pShRtiGOF6YPX60BcswCEkdqjYqJUTzPLPOQTyfpTWgGhI22IZwOOgrzRdojBOM7Rz+Feh XJItJCOyE15wG/dj6D+VQ73GizA4aMZ96kwKqWrjyhyOpqyHz3FVuA7AxTkwR0poIp2/Hamg HgZqTbEqEsmTjiog4xSO42Hmi6BDPuZbp+FdppDSHSrYs0e4x5OR/tGuIdyI2PTAP8q9Dseb OH54x8g4x7mok9RNHkueKbnFKAMZpOpriTsdA6M/MBRKeaFHNNkPJpOzYMiY5pjDIpx601q0 0toQM6DrXORr/p0uf739BXSdjWB/y+v/AL3+FbUJaim9DRiwKsqarRVZWup6mKHinimCn0hi 04U2nCkhJDhSikop2GOopKWgAHNLSYpaQC1HIflNSVFKcKaYGBrB/wBHI75H86zMFAGweo/n irurNunWMf3c1FjzvJiAwTIgz/wNaqKA7yKLyrG1Tp+5jJ/75FXfDp/4l7ZP/LV//QjUV0oT ao6Kir+Sgf0qbw9xpan1dj/48az6jNRj8lRgj1qWQ/L0qEdcUriJAaeKYPanimAuaUH3pOgp fegBwPvSg/WkHPPFLmgYoOKcDmmilzSAd0PtSjrTQaXNFgHg8dKcpBpgzThxSsA7jtTgaQUo /CmkA8HFOGaaDxTh+VFrAQ3zY0y7/wCuTVTtBlBVnUiF0u5P+xj82FQW3CChagalvxHTZGAb kCpIATFUci5bmkwGqwI4pACZ48gYwaVQAMU4DJyO1SrAQNcMk8n7s7VQHdjrz0qGOYG2twYD HvdUVEXO30J9BTEWL7ZKRdykv/yzPRee1Wf7PmIjWOfEakFvmyWH1rRWQDVvMTz4AZUxuO3I B9qkW+g8pGMiAMcDPBJ6Y+tRmKaGd3aSEKRwoPOaYXIWNfs+9lbJZk6c8Y96T1AtLcRedKpw GVQxycBaljJ8uMj5gRy2c5HqKqead1ysu3ZJgRIVwSO+71qxHGAYsochcbl6D2FCQEolwkm3 fuGdv196e0dvJPHJJ/rUB2k/XtVRWupILjzLcqN3yKD8x561MLdftscrEsRHgbv4eaYFq8/4 8Z/+uZ/pXmoP7of7o/lXpF+wXTrkk4/dn+YrzUYWDgcBR/Kos7jCNcoinoetTCKPGMEfQ1DE cbBVgZqgEEIA4aQf8CoWJu08v504UopgGJAP9c340qs3RmzS00HmgYk7AW8h9FPP4GvUNKUP ZxgyRZVB29zXl0ytJBLGg3MyEAe+K9Cku5dNVN7RbXyFyvof/r1E90JnlmDSA9qXNNNcPU31 Hp96mP1NOjHNRyH5qErsVtBjU0kUpNNc8dK2ST2JsNPKmsNuL+RfQj+Qrbb7hx1IrDUlrtye ua0op3FO1i/HVlelVoxVla6WZDxTxTAaeKAHCnA00UoouA6ndqbS0asQopaSilYYtGaSii4C 5qvcMdtT/jVS6bCH6U0gObv5M3znsFH9al04B9QgHUean/oQptnIG1uFnAKmTBB9MGrtlFjX mHA2TKf/AEE0+a2g0ux3F5nexOARU3h8Y0aAnvu/9CNV7xuGNWtBXbo1sD/dP8zWVwNJx8lR CpX+50P1qIU9wHCngU0fSnDNMBwp3bpmmUo+tCAdxTu1IKPwpXAcKUYpATSjPtTAUGnA4pop w6UCQ7NKKQUo96W4xwpRikFKKOoDweKdnim5pRSv3AraocaXPzknaBx/trUVsd0YI6U/Vv8A kGyc9XQf+Piktv8AVrxj6fU00BqQDERqOQ/NUkRxFUUpHpQ0A3cAcZxWTd+LdB068NpeapFH KBlk9Pqe3WrN05VepHNeU6haRyX924SIkN828ctwKhJt2G0en2GqeGNWuvJ0/UY5rlgW2JJ8 xA5NbMf7pdqJvX/fzXl3g/TYbfxVBJ5cK5hcbo8enNenxKkabY1A/rWjVuokRT25lkMgSQE9 v8KWC4mtU2Pbyuo7heamMrQ/PPLDHGThQTzTxe2gXd9pix/vVKbYuZFS5uPtQUCOSIL1LrVq 1uljXZLcR47YUj86mW6tHGftER/4GKkH2dxlZUb/AIEDT1FzIqXbSzlTazKQM5+bFWbWJ4Iv 3t0kmTkluo9qkEURHy4I9gKX7OpXPGPcUaod0U9Wcf2Tdupyoj/9mWvOXP7g+u3+leg61Io0 K9CEHCAcdvmWvPZciBu3GKlXbKVxyJ86tnoOlTg89KhQ9PpUoqwHilHFNDZ4oBqRj80gNJSA 89Kd7CRIsqRNvkJ2AZJFaXxC1KU31pDBKAI1fcTxkk5rHkG4BOPmYDkcdaf4uuRca9csWWQL MyhsYzgCs5PVB1MzBoPFBYDuKMg9CK5ZWNxyHGfpULn5zUi9T9KjfGajroK7GMcU1jwKRutI TkVvFiCseSPy9TmQjpg/mBWu2AuT0qvqMGLqO47SoOR7Y/wrWmtSZ7DI6nXioI6nFdBiSCnC mCnCkhkgpwpgpwNMLjhTqaKWlcBaM0UUAFFJS8U7AIelZ2oy7IGI9DWg3SsXVZBtKexJpoDG t223kLHrvH9a6COIr4guyP8AnsmPbha5oNtdG9Dn+ddkI86zcv8A7Sf4f0qJ73Ljsbl4T5RJ /u9vpWhowxpNqP8AY/qazbls2m7P8Faulrt0u2z/AM8x/WkkSXJOEqEcVLJ92ohTQiRacKYD mnimA7A7UopuacKVxi0optOFIBwp1NFL1psBaUe9JinClcBwpwpBzS4oQCjNO6U0UuKVrMBw +tLn0OKbmlzTsBU1U4sQO7SoP1zS25+QCm6qR9jgB73C/wAjSwDCr9KEBqRf6rNQyOcmpYiR BVZiSTls0mCKN+cRE15beea+oT+XC0hDc7Bk9BXql3FI6HYhY+grhbnwnrZvJZrGd4hIclGX IBwB/SiDsytLEfgrzR4p2yRGNhbMSG68k/8A169SRjjJxXH+FfCt/pd7JqWqXizzvH5aoq4C jOa67O2Mn0FOdpCsiK+AkghGM8k1weq3s0PiuO3QsbYALKgXjJA5Nd/KvmW0QyR8vbrWNqnh u21iExtcXMLE5LxEBm+prWErK1jKaVyoLazVdzTW6jHUuBUHnaarfJqEWc4O2TjPpWLe/Dm6 tizx3XnQYwfMkJYCqUfhm4sY5Yo2t/IkILqOGJHetXWjHcFQvqjsVilYAxTTYPTY5xV2xS+j ni3XFz5e4ZV2OCM81w1tqGq6QY4dO1KBmZtkcFxlsn0GOfeu+0dtQuWDatb+VdxyFWCNlWwe q+31pOtf4VoRy8r1NHxI6roM5UAZ2A47/Mteey/6n24ru/FLf8SB8DGXQc/UVwcx/d49SK5W 3c6I7EidfwqXNQqealBppoB2fpSg03NANGox2eKQUhNIp4NKy6iHrKYpEkGMqwPNUbyF9Rna TPzbizfU/wD6qnlGUNaOjWqzRTSMf48D8BUNK47GO0sH/Pv+tRPKn8MIU0h5yaYc46VyKTNh yz/Njyxn1pkjlTwuabyGqOZ0DHLj86pLq0Jkn2hv+ecdNa5kxwkX5VXM0Q/5aL+dNa4i/vj8 6pWESTSs8TZAHHaiLUbe80n7Oyjz4W4PfvVWW8hEbAMScelZkUzQyh1XqRnFdEFczkzXTFTA 1W87jeAW9gKetwe8Uv5VtcgsinjiqouP+mcn5U4XC90k/wC+aE+4FoGlBquLhP7r/itKLmPu W/75puwFoUoNVxdRf3j+VKLmLruP5UrAWaBUAuof+ei04XMGP9an50AS0lM86I8+an/fVHnQ 95k/76oAVyAM1zl9iSKa4LY4KIM9a2ry4RYtqsp3HGQc4rmLrcpVTzx1qooRVkz5TY6hSRXd p811LIOdzoP1NcPsyMHpiu2tpDNcBUBCu2QfoampYuJpXPOklgR91lOK3LDixhHooFYE6mDS 7iIkMGBbnscf/WrobMYtIR/sj+tQmImkztxUNSy8AVEufUUAPU1ItRjNPHNAD6BzSDrS0ALT qQfSnYpgKKdTBTh9KQC96cKaMZpwoaAeKUE02lpoBwx60o4pB+NKDSb7jFz60CigU9xFLV2H kWq563AOP+Amnw8AVDqpybMesrH8lqaL7oosBqR48getQSLg5qeIHyF6dKglYA0nsCItxzxU qyt0LGoSwNHHXNZXGWAc8mnOB5TfSoo2zxmpWG6Nh6ihCAIdqgtgY64qCeyu5uI71UU91Xmr KyMBhu1SpJnritt0KxmLoIA3S3dxctjgSP8ALn6Cq2l292bmWXVLO1gMbbbdITkMuB8xz37V 0O9SO1NKRnqoNOKSHd9Dn59At7M3N5olhZ/2hPIrk3H3Rg84x04JrbiRi6sT+86nHTNSeRH1 CDNKqqpyFwa15kTZmV4tOdFAbvIv9K4Sb7q/7wrtfFzf8S2FeuZP5AVxMvO3H94Vh1LWxKvW pBUSHk/WpAaEkgHZozim+vNGaYDs5oXgU3NKp45pDGTNhDzW3pcflWKbj97LfrXPXJ3Agdxi tTV7oWAgjDY+8PqARWDl7xS2OWP2wnlkGfrTDFcMPmnYH/ZpraimMqrn8KhOqHHy2789zShS e9huS7lhbds/PNI31al8mMduvrzVGTUbhjhY0UfrUTXU7fxAfSm4VLk+0NBo415CKfwqFzH6 KKzy8jfelc/jTDnj5m4BHWqjTk92DmWJ3UIQpGfaoY13E0zFWLQZZq2hCxDdySCVoW2sflq+ jAjINVZIsrxUKytbkA5K+vpV2sK5qg+9O5qrFMGAIORU4cGldMLj85FOBpgNKDQIfmnAio80 oNGo0Shh6D8qX5D1RT+FRA0F9vWmIl2xHrEn/fNNka3iUs0MX4rVWW7VOF5PtWfLO8r7cM7E 4wozihRALy5WSTKRKoJwAorNuY3jCM5+Zs8ZrbgsxCN78ydfpWVqhzMgHQA5qkgIICrOQ5+X aSea7DSVJRGIII7GuI2llYAE8dK9At9q3sijoduMVFRaFRLGokixm/3D/Kt+2/1KfSsHUubK QDjiuggGEA7AcVCWgDpelRr1p8vOPpUYBzxTESDPvTxnHSq5cpKgycNxU46UDHCnimCnDmlq xDhSimg+1P5xTGKKUD60gpQfShWAUU7JFMpwosA8YIpwpoNLnilcB2aUU0GlzQAuM96OgpKC TigDN1Nv39iP9qQ/+O//AF6sp0FVNRyby0z23/qBVyMZxSGzSQjyV57Vn3MuHPNX1/1Cg+lZ dyoaQ8cUX0EIhJ5LZNWrdopIA0kTAnPKn61WRFxx1psC36i1miZBAE+dCCSc81CVxmjm1j5x P9OtSh4mX905DejVnu96jIyJC4B/eGQHge1WodxyzYBPtVpCJ8tjtSgP1Ean8aYpyalU8Yoc rAN3yD/li351EdWs4ZmhldhInDKOSP8AOasg1xt5bS32vXkdsUDGXlmOB91etJSbYzsIdRs7 htsMpLeh61MzgDoTXK+HLaW11q7SfBmSNVyDkDk9PrXUg81Tduokc/4tcmytQO8jHH4CuPk+ 8vXGa6rxi3Fmvu5/QVyb/wCsUZqYldCROp+tS5qrAzNvyCAGI5+tT5q7gPzSde9MJozR6BYe OB1zSg8VFk0ucL1pbIEEKma8RAO+T+FR+KGMt5Go52Aj88H+tWdLG7UGYfwp/M1nam7S3DPk HLE/oK5W7zLsrGAo+WmGpsAL1qJsA8kCu9GIw0w1JweRzTCKi77A/IZRjilpO1NAJ2qzZ/eN Vas2f3n/AAqlqI0AMio5IQw6U9TTx0pNAZzQSQnMRx/s9qkjuyDhwQaulQw6VC9uHzkUWSDU clxnnPFSCYVQNmVzsZl+hpvk3K9JM/UUDNLzh60faQB0rM2Xf95P1p6w3LdZMfQUkFy4103Z QKryXK5O6Uk/3RQlizf6yR2+pq1DaRxgYUEjuadgKccU9x0XYh9etaFvbJADtHJ6mpVGOgAp 3egCOX7lYl9FI5yi5NbrDIqExjPSgDnrOLc1wSD+7TJBrt7Ubb85PULz+FYdyFW0lIUD5ecD rzW5DxqMfuCKmdwRb1If6IR2JA/WuiUVz99zCoxwWA/UV0aikm7DIpQQw5zkUwDmpp1wQeDk VFigCG6O1Ff+44arS8jioJxmE061fdCOc44pXAnpR9KM0oqgFWnj60xTg9KdmkwHClxSA8e1 LQAfhTu1Np1IBwPvS596QdKXP1o0AdS00UtMBe3akzRmmnBoAzr/AJ1K2HOBGx/Wrie1U7o5 1OIekX/sxq5H25NSM0AcRKPaqFwAWxzV4/cHHaqkgJah7AV/uqRjipEhvg8ctvchYxHtMa85 96QoGGCM1H9gtyOsyf7khFRGwE7DVEmjeIQtHgiQSjk+mKuAyMuXA3n0FZg01M5W8vF+kuat 28DQAg3M0oP/AD0OcVV0FiyuakBx3qMHFOBGeKl6gTKcMD7iuKa/l0/Vr5okRi8xBDc44Xke /FdiHxWBceDdOu7uW5/tDUImlbcUSQYBwBwPwFNabgP0C5kvtSvbuVVQlEVVXpwT+vNdEDya yNG0KHQ1nEV7cXPmtnM5BK+wxWqCKc2kKxzHjHmWzHorH/P5VyzcSr7V0vjH95cW6Z6RZ4PI yT/hXMYPmgZqYSHqPiPyn6n+dSD3qGPegIKMeTyPrUm4n+FvyrWwCk0nOKa8gjTc+QvrUBvr M8G5QH0JobsFyxmlJ+WoY5Y5B+6kVx6g09jhOahspWLunfJbzzDg+v0x/jWTcdF+p/pWorGL RI/9tQfzway5xuC89z/SuVJuRb2MuKLR5HyYLjdnqAatw2+kIN6abK7DOC65rRg0u6gAaU2R A67ZhVqZ1FsxWLop+Za7lzdzHY5K4kEtwzLEIh0CL0HNQkGpHO6RjgjnvTT0qhXIqTHFOPNJ SsDG4qzadW/Cq+KnteC34U02gLq9akX6VEKkj6/gabYIfSiow2TT1YDr0zScrK4hxAxSbBV6 3s7K6Uf8TBY36bSwHNWToenRxvJJraq6qSIw45OCRXJPGUoysyuXzMgIPSlAHpR0JA5Gf60c +ldMXzR5kIcKUU0GlBpq4DqXNNzilzTBDqjY5p2ajY0JCILn/j2kHqP6itpMjUrc+uaxLnmF vqP5it1gFnsW/wCmhBP1xUyKRcu+PLB/vr/OujPyqx+tc9ecSQg/89VH8633J8tvxqVsBUsH MyTuzNxIQFI6AdKnI5qHS/8Aj0cgHBlcg/jVlgCaYEbjMTVWsX23Dwk8su8D6df6VbYfKayn kFve29yc4QlWI9DjNTKwG0KBQDuUMOhAIoApxegDhTqaKePqKbYAP0pR7A0cYox70gFFKKaO KdQA4dKM4pKBTAeDxThTM8U4UWuAhpD0pWphNIZn3B3amefuxr+pNXIsFl61Tk51WQ/9M0/9 mq9F94fWlcRoOflH0qsw5NTueOtQnk0S2Ghm36UbT3p4FKFP901mA1VqQZoHHalzxxQrDFHT mnKKaDTgeOaaQh9LjvTaUUMBwo/KkzRj3qXqByHiiUHVtuR8sSf+zVz8qMzAqf1rttV8LWus 3AuJr2aFwAMRYGcev51S/wCEDtR93U7k+m41cLLcDkws3979aXEw9a6Z/A1xn91q6gZ/jXNM /wCEJ1NfuanasfdTV8yA5+PzAfmA246U8qh+9Eh99orafwZrgHyXVix+pFRHwl4hUcrZN9JD /hSW4GCQ0MjeUoAJzwKkG5wARyeK2P8AhFfEBYBYbXJOB85/wrNSN1vEjkC+Yp3EL04qKmxU SzfnZBFGOgUcfhis5lJQYx1PX8Ks30vmTfQACq0jbUUD1P8ASuem3ct7EQsbIclOf9+tGygi mJj82UoB9zfxUTmBB80XH+7mmxXtiso2yojeg4NN1uXqDRlaxbXKajKy2bLaIoxKo+Xqf/rV mtXVeJNWiTSFtY4ncTceYvReh5rlAdy5rqoyclcylZMQ9KbTsUhq7vqQxpqa26t+FRGpICAW 7VUbMLFxSamiDbuV4quhwR9asrcBOo4HpTaQ0OdD121Cw3/Kani1GzebyJhMuR99FyF571Hc wra38luJRKoAZJAeGHHf1rN6Ow7Ff7Halw0kJbByNrYP51I1tYSSb1tCD1+d9xz65pfs+7LC RgewpI8If3rfpRZdhXKupzywmNYZDHnrjnioI7ufb80zH6025k+26lPBE6Hyjtweo6g5qRNO uh3hx7k1REqkVuaVu/mQq2c5HWpQagiHkxLGzLkDHBp3mr0DDNNaDUk9UTZoBqMMx6RyH/gN LucDJjcD1K0hj801ulANNY00BFMfkx7j+dbV0xQ27ek6fqaw5jhQfcfzrd1FT9mU4PEqHP8A wKodxo0rvma2AHWdf5NW6+XjYqCSc9Kwp+Z7M+soz/3ya31OR/Wkl3GU9NLx2zQyRvG6u2Q3 Q89qtUwn94/IPPPvThVaALjPFZNwo5z0B5+la4NZtyOJB7H+RqJJAXrGaK6sIpraVJosFAyH IyvB/KpwK5TwFcOqa1pDxmMW07XEG4YDKz4OB6cfrXVjNKL6AKPSnDr60g+tKPY1YC4oGaBn 1paEgDNFFL3pWGHalFIelKAaewhwxil4pvApdwoAGPaoxkU4kkU2kwM7OdVuPYJz+BrRh+8P rWef+Qnc8DIIGfw/+vV6D76/WkgNBz0xUO3J61K5x1HFRZHpxQwGTEpHkEg5HI+tDaj5bBHk GfdaSf7q47sBWLN4m0S38Rro73MovSfLKbAULHBHPrzWdmB0DSM4ycfgKaCx7ZpUIK8Hil5q 7IEwGe4p4bHamZ96cOaTQx4al3YpmcUoPFFh6D93tShqjzTwaGhDvxpRTc0uanUB2D7UtNBF LmgQuaQmgmmE+9NMYk07QW8kwYgopIOa8708b5mcnkJ+pA/wrsNfmMOkS4PL4UfmK5GzIhsZ 5R1IOPyIrGbLiU523TMfc1Hc/KqDPr/Slzl/xqO7Ynb9T/SlBalPY0kMg5ZE6+tM8pS24JES P7wpF028x/yEID+IqRdJvm/5fIefeojz31QbmVrEM1zGqYAVST+75xxWK0fkYQliT7V0mrWs +npADeK0jDJMR/Ss2PVwsvl3NuCv/PVMZ/Gu2lUaVrGc1dlNbJJITO9/FFGDgkjpUclrMIlm tg15bsCRLEM/pW5Fbx3GHtLkMA24x4HJ9xUs+p6Xb3CQ3rXVo7thSsW2PJ9+lNO5nys5qKN7 gHblMdS46VsafokIdpZ5zMhx8mMYNa1x4etrtlkM07EHI2MMH6gdaeuneUpBvCiDvIMZq0+w 7GTNo6q2bOYBM5KPk4+lUDZ6k6B0SHDcZLH6VsXFysTmKG7hcgckNVS3vJFCxFAV9TUucrgi tFpN7HM0k8tuEC4Ow5xznNRywvEu43kUpLcADoK6Wz0v+2rWe28yWBpV2hoY9xPI4B7HrWHr Gkw6NqdxZW91NdRQy7FmmTYzdDyO2M/pSd5CWjEhNxbRJLM0IJ5CqDnFXo76CQF5yfMfoAvB NUrlGSSJScqIlPTpVW3b94yPJtABYZ9fSplzWKZoaoukGKzezeA6iQftqR43Bsd/x9ahTOBx 36VUltjFdfaCLYGcZPlnLevzVaTO3oetVB2RwV9ZGlHBabNzwJn165NXbe0jmtzJDEqsAeCu BmsOTxdax2sa2+nGLUM7SlxGQuAB82aoLrGqS3cF1NdLiM5MMHyo/wBRVavY6YJKJ0ccuoRp Et1HCrlcuUHAPpVnKssiFlk+U+46Gn2rx3kCzOhyeMHp2/xqf7LEyMEATg9OKDW5ywPJHoSK Q80jDZNKndZGB/OpGTEQanYRVl/h5/iFdFqWV0uc+hU/+PVzkp+ZB6sB/Oun1Fd2m3Q6kqSB 9MmlJjRYzvn073cH/wAdNdEvTPeuZsz5w0dhzuwf/HK6YHiptcZACC8hPXd6U8GmJyz/AO8a kApoBQKz7pcSt+laKjJA6k1lXV3bNqUlskoeWNAZFU/dz0qZOyFqZFpdf2f4niun4jceTJ/u nJz+ddjKnlzMh6g1xmpwiVDg8lTyO1dZZXYvtNt7nPzsu2T/AHgSP5VzRmuYZL+FKDSD6U7k HpXVcBR9aUe9ANGaYhRS5pAaKBhx3FL+FJSUwH9B3ppPHFBqOWURxOc9FP8AI0mBFcX1naME uLqON8Z2Zy35VIkiSpvjdXTswryuS9vZbi6lRmad5n8zAycB2wPw9K6XwXdXk9zqEVxu2xlB yCBu2n1qfe6AdErE6hdMMH96QfyFaFuPnHHNYenymTXNaUj5EuMIcdfX+lblvxIOfwp7AXXY EHAIqHPvUjnAqHORU3YIr3cxjUEA9eSBmucnsdHXVrLU5I83puo1Lun8POT+GK6k9KoXhMmq abb5BALzsMdAuAP1alFgzThkSSFWRsqRxT80wHj0+gpRuPQE/QU2A7NG6k8qT+4R9eKjaWBD h7u3U+hkFLUZNn1NKGAqv9qshz/aFqPrKKb9vsB11G0/GUUbCLYbJpQaoNqmlqMtq1mv1lFM /tzRAM/21ZY9fNFJyQGmDQWqlHqenyHEV5HJ/unNKuoQSMRG24j1qOePcaLYZux4qQNxWaL+ bzCq24IB/Opo9Qhc7XzG47MKhVoXHYuE00n1pm8EZByPWmSSiONn7AZrRSVrgYXi24KwW8IP BLM35DFYLfutLRehYc/rUmsTG6vSXPOdo+lQ6g2xY4/QVhJ3NEUk+8aiuTnb9T/SpEOEY1Xn cBV+p/pVQWoPYtARK2BG4P0q1HAzruHmYqhO2p28gFzo2pRZPXyCR+JFT2mtKiYaN0B7SArj 86G0O6Rh+JbswXEdqN6nZ5hJ9yRisUT+blfMBOeMHBrubpP7RdZFRM4x93PFVH8Ps8bh4Yhu 6MI8MPoa3pOKRlJ3OTCPGwkjnljYHhlfGK0rbxBfKiwXUcGo22fm3gF157dv/wBVamj+GrO5 1uKw1EyzxOrNg8dB610Mvw68MCQeXBdqSf4ZjxW/uPqJNHOnSLe6QSWWpX+mysuQnnHywfp/ QVnaxp/iVVVb5pdQs1Od0I4P+8BXdv4Os41zFJeAKAAHbPArJXQdS0S58yPVLyW3c5MUp3Dr 056fhUW7DbTOC8+2VigRY5VbBjYbSD9K29Jn+0AblZSMgHPB5rrZvD9hrVsJZrWOVmzllXDj 8azrbwYdMmJt7idYyT8lwucfSqurCSZqaPex2ClnstQvWYjbDZrkPyOp7VjeJpDNqNzcfvH8 yTePMOXPThvfjFdhoTz6TZ3cCXQHngDCLg8EHg9jxiub1nQtUvGMlv8AZ8tIG+djnqP8KSlf QGzHuZXJR2jZTtUFcZxxWdO7JOVClhgnj6VuXun+JopA1hBbmDAHzHLbgOeapJpHiJvmk08f aDn/AFZ60+V7pCtczrRRwduCfzrUUkYI654qm8M1pdyQXURimQ/MpPTr/hVlXU7QSDyP5iq6 HDWT5izJfa89us9xokZsy/lLdGP5ScdM+uKzJA00Ux8tBJtIUJwBXcahKF+GdkhYhzqL4Geu EXNcHcHbZTAsyZwNy9RUKTZ1U4rlNqx1+K0soLf7JcSTJGofA+XOB3Namnayb6cwy2hhfqpJ GDXnwaQjDXExHoW4qTzZgmVuJEPqpp8stzVWN2WQvr91aiMk/aHO4dMZJq3IdykHjiuVM8gc yLM4lznzM85qx/beoR4XbBIv+0OaJJifkW1kJuY43+8HGf1rs7n5oZIsZLxNn24NcGmq39y2 IbW2Eo5DY6VdiuPEEx/fXaQg8HahJxUSvbYSTOs0AebYaQ5OFjiJkbOAuEHX0rpJ7uytE3XW oWkK44LygZrzOSDUV06Syh1ab7O6FDEFADD0zWV/YdyzKZIkmYLtHmOWwPxqVdmkYp7nqEWu 6GWKjWbIsWPAlHrV+K4tblS1tdwzgdfLfdivJk0bUM5jtLFeO6//AFq6Dw2z+Ghe3dxAJXlV QI4BhRgH1ok5RKdNdDrNb1lNHsxsw93MdsSHt6sfauJsHe2lZi7PK64kkY8sfU0Xd3cahfTX l3w8jHag6IvOAPzqNWwwrNzuZ2Ogjcz2yA4+Ud60/Dsxia4smYbWw8fsRnP86x9OI+yzPyfL AYqOp7UunaiJmttQigkiXzAGjmGGxnBrlbtO47I6PXL2507Qry7sovMuok3RrgnnIGf1P5Vi eC/E11q8ktlqs8TXO3zYZFGFZe4JPccfnW++s6euoLp86Tr5ziMMY8oQT/e6V5VqGlHTr65s IZ5GS1Yp58T4wMAgE/jj8K7qbhImx7IVK9cH3HNANcZ4Avpjb3WmXbTs8WJoGnOWaNsDg+mR x9a7P6VokNprcMmiijrRqIM0u6m0YyOtLUBHc4qlcfvF281bKE96jMHPXNMDl5vCwm1JruG7 lt2f7wjxhupJPHXnrXSWNnHZQFI8EsdzsRyx9TVhQIxwBmkD5P40NgihZqBJcMFGXnkJI7/M a1bb/WD8ayrDOyQ9zLIR/wB9mtS2I8wE+9LoMsvzUOalcjBPaq5YZ4pMBzVQUh/EDsR/qrXZ n/eYN/SrTuB1rGS923V/MrceYIwfYIP8alWHYuaxr9tott5kitLM/EcSdWNchP4t166J/wBJ gtEPIWJSWH4k1l65qDT38s8hLEDaijnAGen1rOSz1C6G/wCzuq5yuWxVKPPuUoSlsjQu7u+v JxLPrV6QBgpHLsB/KoGWAj5o/Oz3cljQukX5AwsCe7MSanh0i6i+aW+jAHUKvFJ8sOpXsanV FF7O3aYTJYxl1GB2H5dKQ2yZZjb28ZYjORuzWksTzyeXbzswx98j+Vatv4f0xMy3Eks755DP x+VZzxNKG4/YtbswrDTdNvHdo7dY5UGAzrlT68VasdEsobgStDEzOwKoE4+v6CtORImnEVrE EDHaAvt3rZsbJLVCSN0jdWYdPYVzyxDl8OxpyqMbsfZ2hgRAjoiY5Xb1rTWDcv7qRVbOScVU aN2jIjwG7ZpkMN8kn7xl29Tg1hzW1ZyTndm1FGApWS4IbplBzSTR24VVaKVk/vkjNQRZxgdR UUk1zb3KOZkaBjh1cdPpUVKcpR5oBCrZ6luNYgGNrcSAqPuuc1WnvJ5YHhCIG6ZPHFVrvWPK mAshBNGBz2INU7nWZJ1YPbIreveuejOsnZmrkmZrAvfLuAJDn+tV9QfNxwegxVi0UG43HOAS f1rNkfzJSfU16C13GgIfyfvAk89KqXvyLEg4xn+laEi7Sq98Vl6jNskHG7kj9BW8HqN7HVW/ xW0UwJ9qvtSE+BvURBlzjn9aJPiV4Rlz58d1Ln+/arXmRWIcbkz+tIgi8xS8EjL7IaUsvp3u 7/eYqV+h6APGPgOZyxOpwf7sYA/SrUWv+CGj/cales/ZZXx/OuGEYRd0OneZxld0OVP1pFtn yp/sgglgCREMDJpvBw6SZXM+x6FY6t4NivUvf7XMVyo24aQMMH/9dYt3451i9kDWEFrbwfwS SglmHrjtWr4U1Lw7aT29hcaRbxXL4JkkgBDNxnk1yF3cSJNcCMIFLngjIHsK0p0UtE7im31L 0ureIpsmbWXCn+CMYAqJZtTl5m1a7lXspYAfyrGW8kGMqPoM09dQYN0fHoDXTGg0r2JNJ4Lm SQ41C9hTJOIpduKj2aip2/21qDJ6PLk1AuqEHBWQj6c1ONUsiv8AqL7zME5KjbVeyn2HclaD VYoFli1i9AbpuII/lTrS58WCN5ItSt3RGAxPwST9BVSTWysYjZnWNRwrcYqv/b2VMEcqkOQS p5yR05qHQk90S33Zrnxl4jsLgwXlna3CxvyYgwJ+hro7PxCtxpUurJBPEII5GMbD5iVB/wAK 4VryQ8nA5xzzXTaFqU9poDSLB5sg8xhHID8/L4GPfp+NX7HkjcIyXQ52TxNa6vfS3t5lbiY7 nCj5ep7fjV5dVslQERdCMMqVYl1Tw1q8f/E98L3enykZae3gwAfqOaJvAUVxD5vh7XVkU8iK 5fr+IFZ88VoyJ0FLVlr/AISmy1XwuujfYzFdWN00izsceYjADgevr+HrWVbxpcloXwQynIPp /k1ZtdOvPD+n3Nlq+lzTm4kDJcWqCREPHU9R09Kgt7Xy5hMqndg8njg0nd7M0hBxKE3h2/8A Nb7LJC0P8IcnP40w6PfQxs10sZUf3GPFdMhDLnBqK5QSwuglVSRj5qlVLblaXOabTAzDDsv0 NTjw++Mm6bFSPI8BCyKGOcEocir8V1D9nDPKicZwx5oc3a41G+xTstLFlMZBM7krtOenXNaB Y1Ab60Gf9Jj/ADqRHWRQyMGU9CKyc2yrWHbqA+KaaQmpd9xK4/eeuT+dI1w+wgMcHtmmE8c0 3AFO99BkbO2eQDQJOR8vNDCm7TnpRZIWpvaE7NPIg/ijyPwNX7rBTDc56ZrJ0aQxXyE8ZGK3 5ocZB/WuHEaO5LRNbst5YQO2Nyfu2z1yuK4qfSRa3UsA3HaQcsSS3AIJPf8A+tXX6fxNLbgZ 8zlfqKz9ctpIXhuQGKnMTn0zyD+hrTDz1sCKukX72WpRS3BzEI/JPH3U7Y+mBXenGev415u6 hlKnkEYNdf4d1E3lk8En+ugPU/xKckH+leiopaoG77myDgdaT3ozxRmnoSHPoaKTpRmmA6jP Hamg+9GaQDD1zxTGYDmnNTCMqfoaTApaarrEd5U5ZmBHoWNa1v8Ae7Vlafg2ysDyRmtKFtvI 60lqMlnl8uNie1Zpvx7/AJVJqWr2unRK91uKs20BRmsq48SWu3NvaySn/dAFRKcVuy4xcti6 98Dg8jnvXMx3J/s9GYYaUFyPqTUtxq80wbMCJnsO1Zpy2Bk4AwBnoKxdZI6YYeT3IFt4w/mM oZz3P+fepd7eppr9QKZJIEIABZicYFYzm5nZCEYrQe0xUcmqcjvcY8yQxxf3B1b60MCSXDfM M4Y9BVWa7C4WJHlkPBYjiqjTuEmaNrOsD4QhQFwB0rQaVpVwGA9axrPS2Yfa52YyFfkB7f5z Vrc1ujIT8zcnHp6UqlFPc5b88jQiuoIyFDskufvHoK6PTpogbeCS4SWWdSyZ5BArjNPnWa6a LaGkBPBHXrXT2897DH9kitoPl+UMF5T8aTtBXMq6T0OiWIA8AZpHUhutNsROLYSXXlgngBDU l2yorMnAHvzUutSejOF03fQVMKvOCc9azr643sIfs4wOSxqlPq6jKxsVccHdVGbUJC+d6Hjn NTOtGMbUy6dN31Lcy2xgJSMRzg4Yg4DD6etVHUJamYyIxdtuAeRVaS+89CqqoYc7icVQSTzJ nOTkHB56VFPnlrI6XBPY0428q1klzj0/Ssq2y7ID6Vfv28nSkUk5dsfyNVLIclmyAFP510pM SRLMw8w5rmNX1F4JI1SMuTknaM46Vu3EhCOwPParVp4c8M6rbrNeTXUdz/y0CSAAnpnH0ArS m9RS2MH7ZYxYNvpyo57lQcULqmpTOI4ltgD03L0q2fB4H3Ly4z/tNkfyqvL4d1iJh9m8h1Xu SQT9a6/dmZtBPd6vbN/roSmOCAR+lA1K/mU7mgz22uRxUg0vXLiDZJDAuVxlmNJYeC5WmM2q 3Yjt1IOyNsbvbntQoR6iV7jNOl1DVL4W9vZlsP8ANPk7F98+uaAkT+elw+3bG/Q4O4A11Qu4 LK2WGyaOG3j43Lgen+FYWya3t5Fi09bvcHO5iMc57/jih8q1KkrrQw7fT7m6gWZZ7WKM5H70 nPHX8KeNPixubXdNX/dbNaugmZY5CuyGZRIcS/dTDjr+A/lWhDY6a/iaweGyt/IFtJOyLGPn AdQCf1rCeLnF2TMvZNrRnOCz0+MjztcZ9xO0W8JYn6VYjsNOZ1VbfxLds3QRW+Af0zXbaVp9 vG0yNAiNDfzzQrtA+VsYA9gD0pNOvLy4j0dpXmcyaLdTOI/lZ23AAj/axwPfFRHMp3stTWlT cdzlRpDwjzbbwhdzKWCl76T7pzjkc9zVzUre+0y1vrK8g0EJ9nMqnTQTgg+p6EVtx+bDoqMt 9cW16sJwb1+QvmKcuO7AZzWL4jnspJb2SCWwN3JaMlybNgY5JM/KV/Cs3jJVJ2aHXjF9DCsA pvk80MUy2QBz7V1dlcOLVSu6NecA+mT1rldN51JBtzncf0rs7G3zaJPIMIM5Gepy1e41+6Ry qynYfHczJEZbhxt/hUjOazbmcBzID5ZY4Gzj8Kl1G7RcSS5AGAAO1V4YRNIGkClQcqO4rk5b 6s6Qt3v97P8AbLoIx/1TkECrsMTlS8uDn2qaKHJz2FV9UvRZpGv8cjAKMdBnkn2pNIauypeX tza3JjtNNFwm0ZY4Azzmsu81jU8ENZ2UA9xuqzNK0Xm+WPPQsTvVidvNZS6jam8EcySMuw5X b82/jAx6c1i1FvUUkiv9omuXeRY2mbOG8peAaQ2l1MATa7c/89OK2Vlv/s4NpawW+eSGQ/rW XLpmrTtumuQCfRjQpJaDhNxRD9hMakyy28Q7gmte2i8i3WPg4HUVmDQHcFbiYnIxxW0Bgc8U SmraBzNjaKdim85rPmGNPII5pu3HcmnnPYZpvJHNK6e4DTinIgzmgLk1KuMUm10FYmtG2Tq3 93muuu0IYkf3v8a40NsDN6A/yNdxKu6IMMYPIrixDaRLMh2MMscy5DIc8Vf1K1+22E8QlG2V CQB2ODj9aqzLkEYq5pTNcWHlvtMkRIP0JOKzpS1ugRyMYaSEFuHUlXA7MDgj8xVmwupNPv4r lRlQwEi/3lyM/l1p2rQCw8QyR7Ssd4pnQ9t+TuH8jUBDKT3r1oSuriaPQEkWWNZEbKsoYEeh GaU/WsDw1e+ZE1i5w0YzHnuvp+Fb1aqwgNFJRmncBaXPFIDQTxzSAY2TTHO2KRiein+Rpxaq 13Jss5j6I38jSGiGyO22T6CrBmwCN2KqwnbCo9qqXU5DgAnoc0N6aAilr0ivCEJBKnINYIuJ Ixgfd9Ku6mfmByelY8k7RtkDPrXLUTbOmizRifzUyvX3poZgeRzVaKZTiWEjaT865qwzqUMm fl9RXLJO+p3xloRSyEvsjG5yPTgfWmsI4C2fnkb7xHenSyrDEcZyR+JqFRnk/lWsY6aDbsRS BpSNxIUE4UdDT7BI5L2KIoQgBYjpwMUsib1wKdpzlZXDgAhTitk0kc9RuxrTzR7cKNoAxWUz eZukIIL4OD2wKknkDHbkkY71DkM2B+tZRi2whFxjcmX/AEULOgJkVs4H+fet7w/rCakku7EU ijLK3BrnBMyTKZPug9KR7tUlDIEGOhzzRUpuSscVROUjtn1MwgqrKRWfcaq5z82B9a5l9UlI 4BY1CXvbhuGRFz7k1wrAtu7Lp0pXL9xeoZnlZ+STnJ+tUpb57ohIFZgO46fnSxadGvzzyPIc 5+Y5qwm1RtjGBXVGnCB0xoa3ZCkUioPOkJPotXoFwygDGWFRBMGrdmpa5Qds5q07mk4KMdB2 tHa1tGvQAk/Wo4uLcnPXiotRYvqbjshAHt1qVvlt0Hrk/rVt6HFZFScjbt9ayLmWS3fMRILk 5/DFak7ASAdgKzNRiIZGXOGJ/kK0pXZMjv8Abml2gU+mO4Rcnge9Y3a0ArXs7W1u0o6LyT6V iSa2ZcCSWBwOzdqsavf+bZzQqOCuDXOlRknFbwv0NqUObc1W1GGUBXhtmGemOKtWU32qFt4I BYDah6da50AFgMDrXQ6VFKkU2yFnbGcAexq6ik4WLq0lFaGTqt6ludRjikj3O8sUsbjnYTnI 9DxVlpPEqWIghi08skQQNDnzwhPX/PoKxdXwbu+Yujs4dyV7E7jiurdp4Z5L+1gWW6EUcLKW xuQsenqeK5mlGF2jlS5tyh9p8XSbJysIFuWPyA5bA2kH1qjMupQeTFJqdwrQRlIzC+3YrEEq D19K3o7zVpNX0+aG0hEi3c4R2k/dHjlZMfxDv71mJpN3NZ/bJ2MSfN5qqNzJgnOfTpn6VNOU U9UkaLQynt/OJe5nuLlj1M0hakEUMYYRxop77QK3G8OWiLes13eSyW0cTlM7VbzPugY5pmr2 Oj2VtLHCRFdCaFbceYC0isvzkjvg966ViKV7JDdmtTO0vJv0Ppu/lXWR3EYgjjaYKFzx7kk/ 1rBg0e/0qeK6u5LaS3k3BfJYl14yMj6Gm3k8/wBozE21NvAYe5r0nUUqd0ccYt1bWNSeyluL oOLyAQbcGNupP1q1FbsjD9/Dj2Nc4Lm8A+/GfqppRe6iDwYMdvlNcaqNvY9NYR2OyTarLuKl QecGuat5xqOoSyF1cbtqoOwyP/11Jp95O7Bbx4o0P93IrO0qxis9ShlEryPkLnsBkD+QFKSb MpxVJnVsI0j2JEqDuAOKqmCDfvFvFv8A723n86sMc98VWnmESFj8xyAFA5NcjTvZMxdnqVNQ v0tsRoDJMxwEUdPc+grEdr0Lv2s0rcnDcCrN/c29hHKkgNxdTu3A52ZJIA+lZtppBEK3WpTz RQ7crCrne+PX8q6KdNLVmbdy0moyR26xTBhcBBuZh1OKrvfzh18tjgMM5781NcEXIKRRqgxi ME9D71VtoWMvK8KR1/z7VpyRQG8nzIpPUigioo2bHbFSiueUUi0IR6U0+9OYEg8kUmMD1oTi txoTIFLnioyDng1GVYg/vGH0qHBXumLUsg7gR6jFdvYMsumxOOpXn8yP6V5/Ejq3zSM31ruP DrbtKZf7rnB+uTXPXg+XQlizphjUenzGDUkXICSnaSex7VbuUrLuFIwy8FSCPwOa4YT6CWhZ 8X20lxpBmijDT2p85CvJOOCo+oJrAVhNEsqfMjDIYdCO1dzbNHc2kM21WWRFLA8+mRXAQ2za Ze3Wk7zi2YGPnOUZQR+WSK9PD1NLFPUninktJ47iIEtGd2P7w5yK7mGaO4gWaI5jcZU+1cKQ c9K2/Dt5sLWLsArZeME/mP1rvRB0NLTM+9GRmlsIdmkLHFNJ+lNZsU7gI7e9UL5j9huBn/lm 38qtOxxxiqV6w+ySg91x+dK4DgSIxzjjtVC4/wBZn2q3u+Qc1Smb95jvikMyNT5YfSslonmb auPxrYvxnnFZW7YxI4J61E1fY0pysyJLR4ZR8wBJyQO/1qaWTacBcrGDwB1br/WmpfRtOImU 7geTikO5VXey5JOcHr6Vzyvf3kdsJroD/MylsbsZOO3FTLgLgCqk8nlZwu5sUqz+cpUEhvSt OTS6CcmTsOuDTMlckHBxiokdwDvXHPBz1pN+4g9+1Jxb3EnfVjbiaRIiIQDK33c9M1Uu52V/ LRj8vG6rMhaMk8Fv5VTdNxz3zWlOKCc01ZEZkmbhpWIq9p1puQytkknjPPc1SMTZ4HNdFawb LVAPQ/zNaVGoIzowcpakQgGOlSqoHapQvBpjnaMVwym3sego2IyrO49KeBtoQnI4606VSKjy GC8t7Vd08jzGfsoqlFypPtVuI+Tps8o/ukfpTSOeu9CgHM11K56tI3/oRq1cHlV9Biq1ouZO B1NSTNl2PbnmtmtDgKFwcu1ULsHanLdT3+lXHOWqC6Hyp9T/AErSma8l43O7uLuOBckj6Vi3 N4854JC+lap0e9miWX7K0iY+8vOKpS6ZKCQbaf8A75ocO5hdGNcAtEyjqR3rOYkEg1vtYnlW Lp7OMVSk0IM7MLphk5xnp+lXB8prTq8plg/MPrXQaYrNudrhxgEABsAgjnNUBoM2ci6Dc9OK aS0eFUsO3XGadS81oaSq8xBrdta28EpjhjBZSSyd85zXUyaTrMkbPZTWRfMLBJwygEZ+ZT39 xXL6i5l05rYxrhskMPvfSr58SuNRivpLxQYk8sW5Q+V9ceuO9ZRp3Vp6mEkuhcj03xDei9tb KWzhZN00jKWPmTtywT3479quromsanbQ3U99BFBe22+4FnGUeEnHyPnPBBPPtVB/FLJBBLb3 D2yCYzZtk/1jYwQxOeKz7jxQ81xPIs1+ouIvKljjwiMvbI7EetJ0430iSoyfU6O30C0g1TZq t1fzmbUvsCGSXylkhVNyuQMAgHNUdRttNu/CaSWNmltqH2lQIol3mYeYfm3dVGACc1hT69qF yibYPtckKgoJS0rxjpn69s01YNZvUMyzx20K7cop27h16D6VpCTtZRLtLY3FtGtdhvrmFrhu YY7eTcirhevv1zVC75uW7/5NXrWSCTylW1SNtoJXH3DgA/nVPVY7yG8ZlsLiaPAw8a5HU11U 9IO4RfLURXApQPaoPtE4xnTr7/vwaVbiXIH2C9HI6wH1rB8p66rQtuX/ALJJNaDyoDM+eEHr kVb07SL6KTzr0xJx8kUfOPck9+K19JtZIbFGdCrkdPQVLOWVHdgxCKWPHYAn+lc8qqWiPPrt TZm311FYwMzyRB8fIjH7xqhJeaY4WQzSRXoUBw7fK3+6O3Suf1DUYNUvpLiS3K7QY1z1Chm/ Xmqfl2UjH5pNwrelTsrs4pPobwa1FwkiBC+45JwQKdPax3MhlhLSShecvn8qxFEMYwoyPemm ZBwA4P8AssRWtuxJcSwMshZ5ZA3dQ3ArShtwgxiqekkNvPOMADn3rWArGcmnY0iNCYoxin0l c85XGM60hpzbsfKM00Z7iqtoA0gU3jHSnmmnpScX0GhB1610+gXcFvY3TXNxHBGrqd0jBRyC K5XJz0IroPDSwy3ckM8UcqsmQrqGAI+v1rKorx1JkjeaSO5hEkLiSNujL0NZ8y5BFakktus6 2geNJSpZIRwSo7genvVG4TBrzWmnoQWvD02YpLN2wY/mQf7PA/pWR4xtVtbyx1ZeBkW0+B2Y jafw21LaXAstTimY4QnY/wDunP8A9auo13SYdQ0m9smTHmIdh7hgGKn88V203ytM0WxwLLkZ BpEZ4Zo5o8b0IKn8ag0+Qta+VMQJ4XaKVfRlO0/yqwTzwRXqRbaM2dhbXK3dpFOnR0BIPY4G f1qTPrXO6FeCOdrVzgP8yE9j3H6V0BOKYClqiZ6GaomamIGaqN+x+yuR6r/6EKss1Ub9s2xG erp/6FSQDi3y+3aqjnMufarDNxxVV/vmiwIp38RliADsmGBOO/tWPMMMe1bc54IrHnGHP1pS RSM3Y4nOxhuY5GauwW/y/wCkThsckAYFQXEEhVZYgWdW6e2P/wBdVxbXM53XE/lL3G7FRyNr c6YK2rNh7aJhkDJx3NRNZW/DgMGB7HFOtZEa3RY5PMVVC7s+gA/wp2SC6nsePyrndSadjsja SuVp4MIXBLY5xVZUUrHunjWQg7drcn61pD0981nf2eY5R5exYxz0+bjpzTUmRUg3sAhlE21v n4yfpU7wIB0H5VJkjt2xmmPIe9U5voEaaRFHbBp1x0z0rcK7VIqhYqHkLY4BxV9zXPXm3oze lBFd32Eioxlm5qwyhxgikCBazUrGzRGOHUe9Szj93UJ/1w+tTy8xfhSeuotiCJsRN7VZum8n SVjxzI6j8OaqoN0brjk4H61NqrfNDF/d5reFjjxDGWgIBb0FRTf6p8dxj86mjG23J9TVa5J2 KM981cmcaK/U1BdfdT6n+lT96r3X3U+p/pWsGzo+wdTH4w1u3gW0tNPtBEjg73kIZxjoaW68 YeJLtDDBotmkzYK+VISScjgVhyWWqbTLFCbiPdgJAdzn8PWrel+HrzU54sXk9lhuX34ZWzx+ tdaijz+Y6rxDPeNpFmZLEpdyQqZF8vHlsQMgnvgk1yzOYIgbmQBhwxAOM1uN4JhmuWtL/wAZ 6m06YLRG4yy56ZB6VLHpS+D9Ra1Nwl9E8W4PqIDmM8cjH9azkk0K/Y5Zb2KYN5Uu7a208Hg0 zyb6e3iaC0a4JBDlMDbg+9dHrumXfiC4ilHiDSrONEwEjj56k81PpPhDwgh23/ii8lmzkhbr y0HPYAVFNw2kCqO+py40m6ktUglhe3llJw0o6fUim22lFHK3lhC6rgswbO//ADiu61jTUvvO k0KQXMED+XJBLJlpAB9+P1FZIhu4W2vp9xx6Lmrsl8LNlK+5j/ZdMmcJFaR2xU9EI5zSrp6L cusqWxi24Xyuv/Avetf7NE6FG02cEnJYR81HJYpawIIbeSMEnJkXG41N/MpyVtjEYfZL8NC3 lkAc9Nw54J9KddSRJK80u1N5GUg+7npxTblWe6II5HGKWeIyM6gcoQD9cU009TK7RVkuRJ/q Y3jX/bPNanhW7v21U20t08lsYXYRtztYEcj8zWd5DDg9a1/DMRTVi5HAgkH57f8ACiWsQW51 O4r6E+4oDHqT+lVrvVNOsXVL26SBmGV3nGap3XiLSUtZfIvI5pSpCLGQcnB/rXnzn0ZpdGDr Gv6lLf3EFpOkVrHIUVgvznBI+nasf7TfN/rNQuH4wQW4IxQc8sxySxJPqc5phwK6qdKKV7EN iMse05jX34qqbdZmc71jwenrxViRsRn6VatbJDCGlQEsc8V06WJsZRgI4LA0xIhvAIyPQ1vC xgz9ypVs4V/gGfpWbqxQ1ErWf7uEBUCjHariuT2NOWFQMYp+0AcVlKUWWlYTNLxiijGaxfKM Q0lKaaaFILAcU0getKaQiqTkguMIz0Navh9yms23PBJU/jisojvVnT5fJvoHzjbIp/8AHhRN 6WE3c72SCFphOYIzOqlFlKjcFPUA+lU7qPIzitHqikjGQD+lV5lBBryKj5ZaszOfuo98LqO4 I5rrdKuTqOjJNvbzFyjhj3Bbn8q52VMEirXh+UR3c1szFUcb1HuOv860hURSOf1+0Om+LZG2 7YNRBmHoJBuLfnxURC9iK6LxrZNdaH58KtJPZP58e3rjgEfiCa5y2kS4tY5kOVdQQfWvVw9T mVhSEO6Mh0xuU5B9DXUwXK3ECyLjnqPeuZxkcVd0ucwyNCcFWOR9a6+hNzbLe9Rs1JmmMeKm wCO1UL05jQesqD9atO1ULlvnhB6GVR/OlYCfoKrORvNT1VY/MxqkBVuXxWLfXHlbT3LD+dad 2+ASe1c9eNvk3YoaTLijWiYMiFW645rGW3e6l23MrErwefpVzTpCYjGeqnA+nFOa3UXHnAkH BGO3+eKxtySO2HvRLVlFDbxiKIEdyPf/ACKllUqwcfQ/Q1AsyRDPU+wyaeJZZhtCbFyCS1c8 nJu50Qtaw51xhqRnQjvn0xUvAGM0g6VN29yisykn0FIVA6c/Wp3FMxkgD1qk1YTRasl2RE+p /wAKlZgaFG2PFMNc8/eZtBWQ4Up6HNNFK33anRFlcgebnPerL8xe2KoXM6W6ea/TPT1rBa9v r+RI5Z2RGH3EOK3p0ZVFoc1WsobnQ2rSvqHlqE8ocse+ef8A61SX7ibUnHZSF/QGnaNAIgWH 8IHWq0RMtw7gfebP6CtfZ8rscE6nOy22BEi1TmP736L/AFq5IMtisu7n8kFwM5bpSSuyVoSh eKq3a8J9T/SpLe6jmRSDgkA4PUUl2nCfU/0rVcyZ0uacNDvo/BvijTtTtzo/l/ZlwZZJnw4b nO3tio9b0WDwxeRPZah5lw7l5beebc2eucdq0PFPjiSwkOmaNOst9/y0myWSHnv/ALXHSuCg j2O8rvJNcOcyTStudz7muhVb6JHn2Rq3Ny95dS3JTy5pQBI6n5mx6n8aYsZZi00rzMeplcsf 1qJDxUi9aaG3Ysxxp02KB6AVN9nRhkxoR7rUMZPAqysjcLgkAUEjo12MDGWjYDAKHFaEN/dR f8tC4P8AeNU1IPXinAnfwMj1qWkxqTRpC7uJ8iNlV/QmszVLDXryMCKW3DryqyE7TVlVkxlV yPX0q3FeGNNs6swH8Q6/jWMqVtUUpXOTHhXxBfeely1ral1AE6SFiDmrFj4J1K0jkjn1mKVX YNnYdwwMda62GWO4iWWEhkYAhh3FOPPSs/ataD5Uzm4/BVkzBrjULuUg/dDbR+nWoby90HwU 8Uf2a7lkuEYghtxAB9z711ITJ981xviHTIdW16ZbpS9ta2wKNHJzuIBYUoVJSdnsUvdKOr6n p3iMw3ccbwWyRbWN0oUkknp+B61kSaVLEBLap5qN02DBFdkbbQILGB5Faa5hUBUONi+4HrVQ zQSufJbA7c11RjFGbdzkGZ1IEitG2eA/FGfQ5NdTLFHKCskaSL7jNZlxoVrLhoZprcj+FD8v 5VokibsyecYPerWnBvtEg3EjGcE06PSTAWE1y0oP3ccYFXLazhgZ5I25fGcn0rOb6DROFNPC mmB+cLnFLvK8npXO4S6F3SH4pDQjBhTsVDuVe4zFGBSmihXAY+4D5V3UigkfMuKfmkqtEFxC KbinEmkzQwIpG2fwM30pyHDqdvRgf1FOzTQfmFTcR6NbyGWxt5B/FEpJ/wCAimyDg1W0OXzN Ctc9VTZ+QAqw7LsLMyqoGSzHAFeTWjeZDM24XBJqis/2S/guB/C6gj2JANadwmR2ORkEHINZ N0n7tu2OcntVw7WBHbhGYr5sQ8psbvdcg/8A168ugtH0nUbrSHyBAQ0WTnMZAI/IkivRPDup 2+p+HbW4DCZlHlO6nILKFH9a5nxxaPa3On60qgIpNvcMP7rEYJ+mK78PJRdinqjMwRSZKsCp wQc/rUpwVBBzn0qMivRRmbsEomt1fPXg/Whm4rMsJvKkMZ6MfyNaDn0oAidqpTtmSHj/AJaA /wA6tSGqch/fR/WpAsE8VVY9asZ4qjNII4nc9Bk00PcyNYn2xFV+8ax3lLfLgnJ4FXrwNdnI zg81JbWSx8kde/ekqiS1NoUmyraQzKxkwBuG3BPv1NWmiZh+8fHstWgoUcUwrmsJ1VJ6HdCn yobboqZ2qOe9T8ioVypq2FBFc831NIoj5NKp5pSMUxh6VNjSwrkUkC7pM9aiYEmrVsm0HinZ pBYnbgYqMmntUWeawtqXsPWory4jtbdpJWCgdu5NUb3V0tw0UAEk2PwX6/rWFcySTyGWZ2dj jAJ4H0ropUJTZhVxEYIku7truYtyFVjtHtkjP5U7T4994rf3VJ/lVQVp6Snys/rxXoqKhHQ8 qdR1JXZ0MDeTYSP7f1FV7FcEEdFAxmpLrMemBB1bH8waLddkRPTtXPzX1GloOZ8MzehrAvHC +TGQeE5P41tTEiHjqzYFc/eEvcE+gxTpxTloU/hGzNatCPJ3iTbzkYqncX13AiCOUEEn73OO lTgfLz6VSvh9z6n+ldPKYXOuijEe85JZ2LMx6kkkn+dTpTUXI6VKqkVCilsO5NFzVhRntUEY weKsrk07ATRjHvU657YFQx46E1ajUb/m+6QckVVmIEXccj5iOoFW4FVuoK/Woo5Whl/c4Hrk VdjzK/mOyhjjnFSBetohgLFhlP3s1DcRAMcdKkjmWI/KRkdxUEsu5+v41XQQWboo+zjCqo+U AcVayBn/AArFnn8mQuM/Lz9a1pCGTcrAKema4qq1uawE+0IkgbcAQc81xkMltJqup2kLMEeT KNn5t2xcge2au6pLuk2BySfQ1hnT54rpLqMOrpnHoenX8qUE07lOxFPdhJXt/KZp0YqYwMtk Z7fhVb7S0bN5sM9vjkl0IH59K2LyVJZ/7WjgxeFds2R1Izkj/PNRrrpYFZ4t656Oua3baRHK UrXWAjMg+ZTnDjkY9QauwX1mVzLcLGF6l260bdGvGDFDAxbJMZC/pXPW8Dbf3uOPXkkVcZXW gmrGvqF7ADttJBJkZL9utZpklYk+Yy/Sp/sSrGWLlcDgd/yqrIQpIFOK7si5etdROfKlVck4 V6mkk3d6ww5Dg+hrQWUtGD60NW2Gi5bSn7QFPQitCsqwBkuN2OFGc9q1celc9SNzSOghFFFF Y6rQsSmmnUlMLjSKaafTTV3XUVhhpMc07FIelLRgdX4auofsgtXnjSV5W8uIn5n4BOB9B+la l/p9vqenz2N2HMMwAfYcHg54/ECsLwt9lWZmuI4PNGTFNKBmM4wcE9CRx+NdX5Tg/MNp9687 ELlle5m0zMMEdvbQ28QIhhjSJATztUBRn8AKxJVnUzicRFC/7sJ/dx/F79a6C7mihKqyyOzd Ai5rJvbeZmBSe2jT+LecnH0ohJsNR3g64SC7uLCBVjhkYuYgOFbA5A7ZC/pW/rNiup6NeWTJ /rYmCk84ba2D+dcdpiRaX4jhu7WUzm6uR5xU5AG1+n8q9LlUsx2qDyecVvezTLizyLS5Wa08 iTPm27NDID2Kkr/SrTZzz0qfxLZnS/GLyBQsGpp5g28ASAsSPrgioWBHBHNelSleJnJMbypy DjnitKOXzYg2c+tZnPpU1tIUbYQcHmtLiLMh4qrIczx/jVlj8tVWP+kr/un+dTYCfPy1iahJ IzrCowjBtxrYY/KayLg5cCploi4K7K8UIRAvWpwppEWpegrjnNs9SnDQZt4pgGalI4pi8HFZ q5vYiZMGpojxQy5GaYh2nFaSjoSTNTCOtPPSo2PFZJtF9BhHNW4xhaqoCWq6qnbnoB1J7VUn ZEpjTzxWHquokN9lgOCVO517Z4x+tS6nrKxube0fc4bDSryF+n5VhIuABycDqeta0KDb5mc2 IxCirIcFwD6nrSSDipQMimOM8V6KjbY8uTu7siVSRW3pUWy2jHqSf1NZqQlx8uM+9b1jHh4l 7KOlTPRBEmv/AL0Ueei5P+fwp5O2ADuTmq9yS95JznAA/LNWJRtYLXHK9jZFW4fBiHYMWP5V g7t4DHuM1sXr7S/tgfjmsZRgAe1bUEKb0FA4NUL4fc+p/pWgOAaoX3RPqf6V1dDE7iMYFOLj IGKV2wu0AfWkRSR2rIqxMn0qxH1qJFx1q1GgFNATIoPYVZiXb/DmmRpU+QgwDTETCIuobbge 1IdkRJGST2JquZ3GQWJqF5wTjNAFtrnjHSojOM9aovNyaj809P50AXLiQOuM9RzV+wuYW0/E 0iDaxX5jz1JFYDScGu2+GyWt5baxHc2sMzQzRFS6A4VlbPX3H61EoKQ07HLXn2aC5WXfGQD3 I5q6ssF1ECgjb/cxXpdzomiXcRWXR7R1Ix/qhXD+JNEtdEt1fR7WKBedygHge2KX1dW3K50c hfEWl5IHQeWy56dBzWU95pkzlEYbvU4xVmO8/tK8gtbqTzFjJ35HzYwePpW5d6fpd1H/AMeU aKMABEFTGm+ouZdDl7exS9uJE89IPKG7Dcb19R61JcCG3hCxbS4yGbHP4VUuc2szBGybe4dA zd06YPtzVQMTxyT71pYm9xzznJySfqapyyZY1ZaCR1JwM1D/AGfcMeSAM9qEwIBkng1oW6hw obpTodP243cmr0dsB2pTmkVGLJoDHHGqRrhQKshgRVdY8DGKkC+lcs32LJeOxoxxTQDS1OyK RHIZg2I41YY6k0qhyPmUKfQU+jmiy3YCbTTdtO59ab3pXQhpHHHWq/mPu2+U/wCVWSfzq5p9 q87mZseUpx9TQ5eQ9BLaK1W38nVba4mtZmwywD51yOD+GBW8dYW/nNxD5skm3aGduMD29arw HbdAYGCOCavQ2kUeSkarnOcCuSrJSMrsqTXQNzHZ3d6Y551LRxKcFgM5P6GklsImjZDuYH+8 c1oi2glkSV7dGliyEkZQSvHOD26mnyRDbXJzJbMLs5prb7BBmHgRsZFA4xgdq9RKyyKJFIMb jIx+Nee3sW+GVW6FSOPoa7vR7kS6HZSEjcYsNn/eYV0QnzLUpHNeONLmvvDss0UDNd2R+0RM vU4IBH5E1ycE4vYEuF5WQbgcevNeutOiMNxJXPKkZBGRxXj6Wp0TVL3RWyI4XDxZ7oyqRg/i RXdh5rZhLUm2mkxg5qXIppx0ruMyQNuXNQni6H+4f505Djiot3+kZ/2cUroCSRhisuUZ2Njm tGQjaaz2bKA+tJptFwdmKg44pzHmkQHZRXmzTTPYpO8RD0qPo2akY1G2c0RbRo2yUHimOvcD NKnK+9O7c0SbEtRgPFNY09sY4qMcGqikyZOxNGFRdzHFZGs3k8qeQjmOEnkL1bjv+Zq+2W5/ SsfUjl8e4/lW0IJyOCrWfQz1UKPlGB7U+PrT1T2qRISTx1rvVkcTbe4mcDikxk1MbaVE3Oox 6g0RoHBAPINVoIktsb1XuT0rf09cOz/3QTWLbxATKw6itiNjHYTSDrtbH1wawq7FQVyCIB52 YdzkfmankOZCcdKis1O4tjhRmlkYiNz7Yrns+pqkZOoS/IfWSVj/AJ/SqS8irV2glmjTOMZO SahWF2OEG7jNdVLRETIzwpzWbeswCfU/0rUZcBlPBxVG9i4T6n+laNmaO1zk1PEM1ApBNaNn DvYcVCRbHxR7uoNW44hnPIqwkQCjApxKqMA8/SmSNAxzmmSNiguQDnFV5JPekAM5AqB3wc0h kqvI49aNQHvJ71XLnPFMeQVCZO+aaQE5k4r0H4UKCuvuQPv245/3XrzYsWr0L4ViSPUdYXrG 8MbEH1G4D+dCYI9DlYAEDFUZArAqyqwIxyM1ckIOeBVcgdgKtCOH13wdFqF0LyBEgmgJdHHy 9sdvY15uPElzHb/vLC5QnjGzP5V7veuU0+6bjiJjXnrwQrEAYVyAByAaipNJDijgPKm1LdMi MhkkLNvXHX2q3BpBjA3OW9a6eSFWOdir/uioDEOgQD6Vye3tsXyGStoqjpTvIGOlaXkAU0xC o57u4+Wxn+T7UCMVdMNMMf0pSlcpFbZijbU5SmbTTvdAR4NGDTytNpNNdQExQc+tHeg1Kkuo xppuKcaacsyxpy7nCj1Nae7YTH2tpJf3P2aIHkZZh/COma6p4I7eIRRAbF6YHXrzS6Vpy6dZ AsAZpVDSH3wOPw5qWcDbXDWrJvlRDM0fLdwn/bx+hrZE9qlz9nkmRJdu4KxxkZxxWNMQpDf3 Tmt3yLeWVJ3gjaRfuuRkjmue6igHFO64xTJB8vNT4B56VFL06g1g9XcDn755Yy5YKsK5Luxw AorsfD5jk8O2MkMiyxmLKsDnI3NXJ3/l+XJ5oDRkEMrcgj0Ndd4btUs/DdjAQqbYuB0GCzkf zrspNOI1uXm+ZcFa4Px5YG1nsdcQNtRxb3HHGxiMH8MV6FsHrmqGsaamq6Le6fJkJPGwz6EK 20/ma0hLkkimm0ecrtYAgUjYzVbTzIkMlvcHFxbyvBIMY+ZGK/0q2R3r14NNXRi9CM8c1Fz5 7HBxgYNSnBGKQ9MU2tAIpT8hrPn4QYq9MflrPnPSkthokhb5ACegFO61BC5HHY1OM4rgrK0j 0sNNtWEbrQRlaQ85xSgnGDWeljrbEQbc0uc5GOKlWMsKhmvLe2UgN5ko42rzj60LXYylUURW 4GTio9wJ6iqLzSzsXcY5+6D0oGQPvH862hTaRyVKvNoi8enUVj3uDOQat4JHVvzqvLASSQSf rW9PRnPIjhh3oXwcAkU6AHzPbNSWoYuY2Yj2NXY4Y433HBFdLZzsHXMOcAjFUYIwNzep61oz GErtXKqRzVYmNBhc4+tKI7iWwO5j74rSuP3dgid2P+f51TtxnGP4mq1fufMiTsFJP51lUlqa QQQnZbOemcVBcMfKVR3YZ/WrGMQIPXmqk5y4HYCsktdSyhPCJXyRnDZFWbRPkJ5BwaAIw2c8 1OsyKuMDdXVHYylK5nXkQaQ4GDjqKoXcRKJk9z/Sth0RnL/xEVSvUUhPqf6UyEdOkY3AGNgf XtWpbyiP5SMfWnW8Z2/dyKlmtVZfMHDL29aNiibzSI8gZ4qJpVP1quJfkxkj2pjS8UkBLJLn vVWSSmSTY71Ukmz3pgSSTe9VWlJPJqN5O1RFqBEpemEk/SkUlmwvJ9KuxWhk2+YNpPG3uaNQ K0Zy2OmBkn0r1nwPpFxpmjz30x2TXpVliI+by1zjj361i+F/AjPcpe6qIUsQAy2xf55SP73b b7V219pFjd3UlxHLc28zEkG3uANvAGFHQDirjFdSkmxpmnzgIOem6mNPKRjHPoM0v9moDg3V +w2bArSrxz976061sJIGhb7VLJ5WeJXX58/3vpRYOWXYj1VBDo10/mNny+n1I4/WuImB5zXc eIS66JNxHyVB2MCeo7VxL4zz37VyYh2LjFrcpstMK5q2U60wr7Vxp3LKuwGmFeetWwtNZO1U mBUZMnjH41GYx3xVzyh1pDHx0p3FYpGP0xTGiq75VHk+vWqvoBnNHioyn0rRaAnkgVC0JzwK m1wsUCMdRTfx/CrbRDPJGajaIegpNRYyuxABOa3NA07YPt06gsciJSOQMnJ/Ss6ztVuL2ON+ g+Yj6V0cmoWkM8VrJMsc0gPlR+oz2/Osa0uVWiRIuMwI61WmPymnk8VDKflNcajd3YjOusmN h9a2YruGLT7eWXiNsKW9Mk8msWdutaGjyRy6ckchViCy7G+p7Vo43WgGmksUy7oHEidmx1qr fRTyRg283lyKe/QjvVolUToqqB24Aqne7PLSRp1C7Q+VbPBGeaw5HJ6CMPVZ3hijiMTztNII vk5wTnk+3Felm3iihihZATGNoPpgmuF0O0i1XXEfeZIoT5p2H5TwQP516A++RixXknP512RT jAqKbZCVUcg81Gwy2VfmlkEg5VTn6U0NMDzGPwFC5mjU898V2J07xeLgbTDqqmQ46CVd5b88 iqZbgiuu8aWMmp+G5fJgJurRxcREjnIwCB9QTXGWdyt7aRXAPyyKGrvw0m1ZmMkGDmlxU1G2 uszKN0MJkVmTHpWvcxGSIgHBHNYkx5FD0Gh0Rwwq4BlazdxHQ4NWEvnCbSgz/erkqJt6HTSq chOgCZ3HApxmizhAXb6cVR8xnlXOTlv8a0xGMdAKxcUndmjrSexTnEtwu0yMieiHFQrp0Qyf myTknPWtIpSFaOez0M9XuVBZxgd/zpwtI/erIFKBmk6km9wsiAWkf+1TvskXoalpaPayWzC5 XNlBnO00jWcGOjD8as0xqaq1BWRTe2iGcbvzqs1tGTyD+dXX71AetaRqzuGhNZoFeNR0FLOf NvT6DiprJRv3HotVIGeW6RxjyyCxz17YxVu73I2JZ5Qk4jHZRVXb5ssgbO3OP0p90zGR2VR1 6k02D7mT1NO2lwHLZwDohz9ad9li28Aj8alBoJqFUn0K5UVzbLjGW/Oql5aRgJgt1Pf6VoFq pXjcJ9T/AErSM5PdiaVj0KOERpyKglmVSQKbb6iblHhnt5LW9hOy4t5Bgow4OPVc5we9VriU K27YGPvXXKLjuc6lcinYcngVRkuMAgGieYkE9PaqTPk0rDQ95ie9QliaUKzdBVy2sWnYLCjT Of4U5o1GUArO2FBZvarcVgXONzM39xeTXUWHhWZ1DXjrboRnan366Gz02z09CLeJA5OTIwyx /GsalWMRxi2cvpnha4lUO4W3j7l/vke1dHFoGkwqpMDTOpyHkPIPtV59zDOQc9aYo2jmuWVd vY1UUilcaPYSEllnz6+e3+NVjo9kGJEl0BnOBOwx+tab85qDn+6MVKqz7l3KJ0m05H2i8wT/ AM/Lf40w6HZtz9p1AfS5atEqB2xSfNjAbirVWdtw5pGfHpsNpIZI7i6Y9MSzFgPwNO2MSTu4 qw+frTMDGTgfUVjJyluK5DtPYik2HFTbRnjmkKk9cCj3UBX8r1agoMdanK/iPakaLPYmlcVi vsJ7U0oepz9KtbGHtQEJOWBP0p3BFTyyTwKPKPWrZUUeXilfuMq+WT97H5U1oge1Wwgpwj9R QpIOUyZtMgmbcxcH/ZOKYumLCpCFse5zWx5G45xSCLB5/WtFOwrHOpLcadeJO1rK8QJDbEyc c/8A1q2gmn3csN20cbyx8xyMOV+mauLGMdc1KIY2HKBvXis52kS0U5L2zjHz3cK+xas6fxBo 0eQ2owZHZXBNa82mWNwCJIE/75FUJPC+mNkrAi/VRWKoRvqxWZgT+JdJLEJcM5z2FaPhXWbO 4vp7V0OCN8ZYfMvqR6jnmpX8J2jsdiwj/gODVQ+A5BcpcW19Jayx/deJ+n6dOK39jDl+ISTO pilTUEuBFFKscUrQkyjbux/EP9k54PesBXhd5rW0t59/meUysM7jgdPb5q6KH7cYI4rmWG4k RFXzNu0sR3OO9TW2n3H2yK4aRFKMCFRcZrCELPUVmafhfQIfDmkLbxonmyHe5HOMgfKPYUt1 4dkuN23X72AP/CH6fSr8RPGWqUvDuAmcVo7PcuxFZ2U1pax25vXuSgx5shyzfWrBidF5fn0q FriJf9UWPuKb5zPw4Y/UVDlHZIaHEbpF34IyM55yMivH4rX+xtavtGZGCwMHhJH3oyAePXBJ FeuMwH8VcR44s/Mn0/V7WWMz24aGUZzlG6Z/75rajUUWDWhisV/CmnHYms2TXI4pGilaESL9 5SOlLHq8cy5jSJ/da9KLuYtF4nFYupx+XKh7MMirxvjg5Rc1VvLpJ7cxsFBBypHY02xpGbmg Gm0ZrFrUtMng5nj+v+NbAHFZNmM3KfX+la/asazXUtDaQinZFHFc9hoZRkgcCnik4qZJIZEW kHRR+JoBbuAKkpDTSQCc0xjTjTGNO+ugiCQ9ah71JIajXOa3gDSLkR8uzdz1JP8ASobLCRO2 MAKQKkuTss0TuWpkeVtB/tVoyCC4bMJ4GSOKEGBTJjyq/jSgmp6CtYmyB3ppakBx3pDWVrMt NiFqpXhPyfU/0q4RVO7HCfU/0rWCE9j1Xx2geG21pQqXCS+QwVQA6nJ59ea5KeQ4oortvc50 rFB2LUxokjj8w5Y5AwelFFIZ13hvwta6hb/aLmVyAchEG0dBXURQW9oBHbW8cQXjKjk0UVz1 GzSIvc89u9AXJ60UVyNJstMQkljjjFNYnPWiiqUVYRE3Wo2YkccYoopcqKT0Dk9eaM5O3AAx zRRQ4om5EQM9KTqDRRVKKKTY0Jz1o4xyKKKhxVwQnXjgfSn7RgA80UVdkFx2wBsU1z5bDHei iplFAMD7v4Rk96kVA2SaKKFFDARgZpMZNFFKUUK7F2jOOlPWFduTz9aKKairCbGmNQeBgelG 3jgkUUUcqFceEGM96XaCQvbvRRQ4ool8hMd6f5KxqWyWPvRRVcqAnhRTj5R0q9EoUdM0UVPK gJc0hODyAfqKKKUooVxV6YAAHsKd5eD95j9TRRUqCKEaASAjcRWPqGi2zafcg5H7p249QrEf yoooUVcL6HimouLe+lm2K5B+YEfewzDmrFmys8rqioGYHaowBn/9VFFepT+Awe5YYmqspy1F FSwI6KKKXQpFuw/4+1+h/lWqetFFc9SKuVFiHrRRRWHKrlXCjFFFOUVYLsaetITiiinCKC40 mo2NFFCiriuVpPWmJ2+o/nRRW8EiWyXUGO+Je2D/ACp0pIjjXsBRRRZXC5TYk3DD0A/rUgoo q7KwJiijNFFTZBcaTVO7PCfU/wBKKKtJA3of/9k/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAGEAiEDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDISRXUAZDADIIwRVq36N0xitfxNJ5ksZZE 8wZDOq4LVjW+fmGe1eZWgo7HVCVyFP8Aj6fjjH9aDQoxcyevSnAZrJXKIWHNRkZBqwy803Zi rjfqQ0iui80/A8xR9acEIakYYlUjqAf5VorpCIXFQsKtFSTTHTNJXlqJogEeRUUkQFXljyAK jmhwVz3zW0UI5TUQE1CUY6D/ABrUtEWSMb15A5rP1YAa1cL1VTj9TV1HXKukxOQN0ZH3TXQl oZvcurbxKflB/OpguBT4oVkXMbhvxpfsrj+JfpurN2RWpGFIzySDTgMYw+V9ajdG3YRxnoQK BGVBVpFZWIzgYoUkBMAwJBI6+tPqE7VwZZAEzw4HSm+YgkRfPAVgT5mOOKbY9CycZpcn6VWM 8B+5dbuM/dIqKJwdzhyVzg54pbgXcHrvo3MPujLe9VdyuxCzEspwUAoWeKOVYmEhc9gCaNWJ IvhZGmEKgSTFchI+av8Ainw/caf4KsdbdlXfO9vJCybXUliAc55Hy/qKr2Oo6hb3EEFlosVv AhUm4mlAz7+v8q2/iBrum3ngK10iF5JNQguvOkypwpGS5z0wd+BWkY9yWeRA5X3bgfUiu0t1 xDGPRa4yEZkiU/3wK7hAABiqmiSRQKcBSLwKenNZtjNPw/4dm8R6hNbW9wtvLHAZVdk3BjuA 2/rWXAxlhRyCCRyD2rT0jWdR0G8N3pwjMjAK6yLkMuQce3TrVJV6kJsyS20Hpk5rNN3GmIKc ByaXaR6UoGabAQClApQOacFOelPmBITFLinAGjvS1AAKUcUoBp23NStwEApyil204DHQU7DE ApwWlCmnhTSAaBUgWhVPpUgTmkrgMA5p4WlC8808CquxCAU9VpQDTwtHQBAtSBefSlC08LUK 4WQ0LTwtOC04LVprqMRVp4X3pwWngUm10Cw0Jk9Keq46U4CngUkA0L7U4LTwtOC07CGhfanB DTwnrTgKaAYF5pwWpAtOA5oHcjC1Rv4RcXumWec+ddISP9lWDH+VaoX8Kp2oFz42tUyCLS2k kb0BIGM1E3ZDjuaGtGK41feyZkgXapz0znNULVEhZrvb+9dlj3Z/h3gdKbLcmW5upTxulfH0 BOKhuZBHaWcQcF3uI8D+LAcE158G3VR1uK5Ttvw/Wik4or2zi0PJ/EKea/mdGUHIHesa3P3v 51u+JUxLGRxu/WsKAcuPp/WuPEJJm1MiHNzN7GpVA7UxP+Pmf64/WpY/vVgrGg1hzSBc1Kwy cUiDEmKtJEXGtHg1DIgEi/jV51HFVpsGWP8AGqs7CbIhHmmvFirgTFDoCpHA6VcVdEspLAW6 +tRXMJUxgnIYkVreWBVS/UB7TH8TNmq0QHF6hHnxBNC3dyOfqatvNHdorLamOWL928mf9bzw cdsdKivQF8ZSZ5Rbk5z3GW4+lXrRcOerR+cG56LyeK3jblM3uSWemxQKzNG5MjbmAbANXhZ2 23Jjwcf3q1EhiLkhQOeBTtkOfuKTUtXKuYxt4kYlAST1waR4rdpCTpue2d/WtoRwAH5cHFJk A/LGhHvU8tgMhYgE+S1CAnlc0oiEa/6pQo5PfFa+VHG5R7U0leo2n6CizHoZylAMso2kcNin xODKYxIsnGdoXpVgxrjcW3DuMdKFkEQJQrj0A5oSFch2yM5KDA75WnxteIQfOQf9sufzqzDe RzA7JQ+Dgg8c1MBv4GB64NPYDoNDmZ7C0t7rRkv7F32yuzBQmR1bPauc8dFBpS28E8ZtYVlE UUYyIx8ufm/irovDkMt7eR6Ul3Pa+fGx3xgMOB0INYHjxNStrOTT9UeN3tYGEbRRBBggenXt +tbRZLueY23+uhP/AE0Fdtk4zXF2w5Q++a7RTmMH1FE9iR9sjXDSA8BQOB3qykSjgE8Umkcy 3A9AtXJ0CDcB7VlYCv5fbeR+FKIv9tqQyf7Lf980nmEH7j/980XGh/l+rn8qcEB6SH8qiMvq j/8AfJoEwA5R/wDvg0W0AlEeP+WhP4U8R/8ATQ/lUHnr/df/AL5NH2gH+CT/AL5NKw7k+zH8 Z/KlCH/nofyqv9pXOCkn/fBo+1oP4Jf++DSTGWth/vn8qXaf7/6VVF9FjOJf+/Z/wpf7Qg/u y/8Afs/4UJBqWwGPRz06kUoVu8n6VT/tO2A6S/8Aftv8KcNSth/z0/79t/hTtcVi6ASfv/pT gD/fH5VQGrWgPLSf9+m/wpRrFiOC8n/fpv8ACiMWguaIB/vj8qkXIP3gfwrL/tvTwcNJIOM/ 6pv8KtW1/bXQJt3L4IB4Ix+dHKwNGJDI2AwPtipGiK0lh80wqeUZpOwXIAKeF55oAp4HTmkt QFVRmn7TnipUjXGciiV4reJpX+6B25p8r6BcaAKkVc1Da30Vwzq8e11BO0c8Z61J9stQTuDj 8DRyNgSKpzzTwoz93FN+2WagFmIzwODVqEwzIGjbKnvijlsDI1X1p+3FTm32jK8+uaZjtU2a AQLTwo9MUoFOAo3AQLTwo70oApyrRy2C43ZUgUUoGaeAPagBAmTWZokg/tbxDqTAbYUEanHp G2f6Vr7giM5wQozXLW07W/ga6umJ33twoA7nc7D+VZVpWjY0gtRUl32gJ+8wBP49arXcav4n 04lcNGuN2euWT/D+dP3YSFR3YCliQXXim2hQ4KqvI+it/IVxUfjR0yfuno2fpRRub1/SivYu zhPL/E67Vhb/AGv6VgRgZJ9q6XxSv+hxsP4XH9a5eM9awxCNqRHH/wAfM/8Avf4VOgwc1BH/ AMfdyD/fqyK5VF7mrBuaRBl80rc8U6PjcSOlaxTIHsCcVUfm4T8auuchRVaRcSoe9XdolErJ wRS7N3y/SnuSR2pE657047g2SBCecVn3y/6TZr6sx/lWluAArNvWLX1lx0Z8fkKtknF6oc+J Lo56TsP/AB410Fg0qaTLjiOaeNWG372CfyrnNRbd4iuR2M7D/wAeatnTwfN8sysY9ysqkdDW y1iR1OpwEkAUcZxxThGBycCkiXHUjipXCsPX1rNooYApHNAx90D8cUu4KuO30qUSOU2ljtHQ UbhqVhGu7ouanEaocMF6ZGOaVQmCe4oCgnpn8KGCRE8akghRg+lV5dOhkYsm6Fz3B4/KryZ8 4qY8DaCG7HnpTmX5uox7Chp7jMaW3mzGs9tHclDkTI2xl9wKWHVY7KMLcl2QdZPL5UfQVr+W hbJH681E9sNvBGPTFNeYWNHQtSQajp2oWdxHcWb/ACShGG5gT09QelZHjm7iu01R7eaWSAR4 RZvvRnABXnntVq28MWmtjyYbRV1AxHyJ4XMbo+eCTxkex4rmNWu7ptD1BL0g3ChVL/8APTJC lvzq4ktnJW+RFwM12cQ/0dP92uRhQ/ZjgcKSSRXYRf6hP90U5ohFrRgPMuB7CtCdflGPUVS0 UZe6P0/pWhP938RUbDIVB9afk+tIBTsUmCG5NOGfWlC0uMClYYgLU5d3rShRTgB6UAAdumTT 1ZgfvGgLzTqGrgL5j4+9Qruf4qaAc1JGKaGKHf1p4d89f0oC07bSuwAO+eT09hThI/Yj8hTc c0oouxD0kcEdPyqhfEvqjMccxp2x2NX1GSKoXv8AyFG4/wCWafyNAtS9px/fVPMOelQaeP3w qxNzR6gRD60rHAGB3FIOKbMcKp/2xUJFImQAsM80u8rNjb8oHApqMVkUg8d6dkbvStloSWIW zu8tFQ46ipA0jwgyqM9xUcTDBUdcU9W/cZ+lUOxLEF6hPz5pWklVhtIx3GKZGwCEk4NMfMjR sc5x2NFgLglkV0V3+8Cad3qGMlSo65HU9alzzWcw2Hg89KcOtMFOGO1ZsZIPwp4FMH0p4pXF Zj1PpUgpi5p4oQWM/wAQXX2Lw5qM6/eEDBcep6Via2v2fSNFsB8pDbyP905/9mq94uYSadb2 R/5eZwh+gyT/ACrM8QzCbxFFCOkEPP8AwIq38q567NqW4If9KgGeFOfpV7woiXPim7uSm5FR ivPQ7Qv9DWT5hWWSXtGN361qeBF8qGeVywLER5x1+9msaCfObVPhO+/A0UzP1or1ziOA8TLn SycZwwNcdEQGc+4Fdt4jUnR5yOw3VxMRwSa58RqjSkRwf8fNwc/8tDVsdqpWxHn3J5GJcY/A VcBBYYNckdDdjJDtc/SpHJA474olAZlbPRcU5RuAzW0bGbHKcqDUE5P2iHPTk1OpIO2q1wcX UII6g8022gLJ6U1SakONp5piYDnvVQSJYrPhR71nXLn7ba8cZY/pWxtU7AcY71lXqgalZqD1 Dj9BVX1A4m6+fXJT3M7Ef99GtezZW1QheCoGR71jzIsuvGFjhXudpPsWNaumQ7dRaNWyN38q 2WxF9TrI5Hx0p5dz/D+NLCoI5XrUxQAcY4qWMiWR+gOPwp+58EH88UuCw604OyNj9KS1GNw7 ONpOfTFOBYd/0oL5OMc59elKg3Pt3AcdSaQh2WH8WB9Kcy/MCspkyBkbcY9qQusQQhsDHU8Z pxmU/MWBHqKBihcH0pGB/vHH0pPNjYZxlQecNSK4b7nIqlYLm14RMB8W2UVwzZELtEi5w0mR jOPbdXm/imFxZ3TzgRT29yqlVPYkZGe9dzZahBHc2Xl70ubaQ3Hm4Py4XGPfOa47x29zjZe4 824kScfLj5TtPNUiXc5WB3wkAYBJXCsMetdmibUCjsK5GztXN3ah2yDKOO+Oa7BSSKqoQi1o n3rr6r/Sr8/KD6iqOi8NdD3H8hVu4bDIqjcdwyB2HrUNjEFOFHSlFJMBw6UYpQKWmAAU9etN FOGRSsMdRxQOfyoxz0pILiHrUqY7VGOtSLQmBKPWnYFMWnZ96AEPXilFJ3604A+tAMcnJqhd 86m3/XNP5GtFRWdd/wDITY46xoP0NCYal2w/1vNTy1BYf63AqzJzQBCKZN0TP99aeOtKwyB3 pDFT72GGafkK+PWmw53jjPrzS/MZGBxkHFaIVyeJsgkYxipGP7vOe/ao49wXGO3BFPYHZhRn 2od0AqYIORmpEO3aOOKhxIYmXyznHHNIoCBV7gdM09wL27LjJBOO1O71ApXeNvGBzTywJwTU SdlqJbkoOKcrVGoRv+WsZ/4EKkG1eS6ADvuFYcxTZKDUgNV1uLUkAXcOfTeKnUxnpPF/30KO Ym48GpFJNZ97rGl6ZLbR31/FE1w+yPuCQCeT26HrV63aO6hWa1ljliYcMhyKdylYwtYK3Hiz S7br5MZnb6ncornZ5jceINQuCBgyKo5/uooraEofxfqVyxG22jWIe2Gz/WuX0+bdG8rZLPlj kdya5qjvobwVixcyFbK6IJGSEH8/6V2XhS3EOkwkpkuxbO7p8zCuFvZgbVEzlnlJ4/3TXoel 25jsrRN6Dao4z/tE4/WlSfK0Oo9DpMGilz7CivV0OW5xutR+Zot6MdIWNefR8E816VfIHsLl SRzC1eZxHIJNYV3oaUyO3P7+6/67n+Qq1GfmzVK2wZLo/wDTc/yFWlYAGuLmNyR3BpY5MCqf mE5pwkxVxlcgt+aN3WoZzunRs9AagMmTnNG7cwPoKTbEXvN4qPzvwNVzJjpUZfjrWkZWQmaB myF5qhdt/p1qw6AOSfwpC/vULFWuI8t8oDZNNTdxHJyHbrfmZztn3E/8CY1q2xyzOjbWLZ46 nmsiTm+cf7Tf+hGr4trV9v2gSEZAOxiOPwrou7GWtzrImURqwYbj1BbpS7gT/rEGfVqxRoXh 5xudpCT/ANNW/wAajbQPDqtlbd39zM3+NK5VzZaRxkm5i/OohOdxLX0Cr6nvWO2jaQCfLtAO McyE1MulaLn95p6Fu7byKizuO5tRyxMfnvImHbHapfMjHKyoR65rF/srw6zgvCi7eV5NKNM8 PlgGjDKM4G44pWkx3NQ6hbROMalD5qkEqy5AFSx39pLuZbmIk9dnSs5LHwko/eafGx92NWIt O8Fu3/HtHB6nmqUHbcLliK7g80NOyKAeit1FSvqFmVwJVUHOOelZttY+C2lbfYGB1J2uWbBp z2/h0MTFahjjAOTTsxXOgt/EFrbyxRRRrLEsQLzHgE981w3iu/utW1WHz7wXIyqxAKAI1yuF 966i20TSpmtQlgPLli3FdxwT6VxWoJBBrHlQoEjiwu0djxVxtcG3Yt2Cg61jshOK6ED5RXO6 WQ17I7fTP4iuiX7gq5WZmW9G/wBZc/UfyFWGH/ExAGcbD/Sq+jt81x/vD+Qqy4kF4r7Ds2lc +9QxomI9KAKXmgClcBRQTS4pMc0JagAp69aQcU4cnmncLDgaB1oFFDsGoU5abT1FSrDsSL0p e9IKOKqwJsXNKOtIKcKmwXJFJyOaz7vnVX/65p/I1oCqFz/yFJOekafyNFguy5Zf6yp5eMc1 FZcyCpZc56UdAIx9M0oznAGfakFKrfvev8JNSlqMRZFLMDCBg4zu61KHjBIMWd33sNVUN5oY Mn8fTOKmwuWzgDB5zVisT2txDLvWNHQjjDUv2mCN8FjxUMZG2MKpwRxk80uYygDwNksOc8// AKqq4FuJ4J5D5bvuP5VMGQTBduWwTkDpVJgkSu7IVAxkr2qWEBwu0vhkJBP86VwJzJGxQ4Yl uAQMVDqK7dOus85jbj8DSCKdSqm4Yk/xbak1VN2nztgECNuPwNKWqBHm32GAknYRk54Y08WU IP8AHjoRvOCPzqVSCcDtxT8GlGI2VBpViOltGD6gVJ/ZtqRt8s49AxH9asgVIBmnYCnHo+nI CFsofm65XOfzqxa2509dunyvaJ12Qtgd+341OB7Ur/KhNOysCRoWjm18L6ndMxMkqkbzyWJK 81kWl5CtlM7EqsTLGSV7n/IrQ1H9x4WtrbOHlK/yB/pVfO+L2Jz0rhmlc3jsRh4bjU7K1jbL JIBKB1Gc16Zts/tCb95YONpCHGc1wHh62jm8Vx5TJTLsRwcjNekRzJG6KZWyTjB+tVCKdjOc Wa2fb9aKTB9aK9CzMrM5y4jDwupGSyED2NeXr8ruuOjEYr1Uj51A9RXlcgC3VwPSRh+prKv8 JdPcqWxINyT0M7fyFTg5FQWx3LP0/wBe39KkX7tebo9TcZyDQeaVqaDwatPQkaWwaehPrUR5 apEpWQwZqjL0jHk1GTzWqvYVxzOah39c44zTmODnvUYGSeeef60Inqc6f+P0n3P8zWnH2rLJ H2v8f61qRHNdkLuOpi1qWFRf7o/KnhR2Apop4p2FYBj0FO4JpKcO9UmAAAdAKcKSlGKEA4Ad cUuAeoFApaLMAIB4Iz9aMDpS0YosBEbm7tHE1pcvDKowD1AGfSueLNLeTSSNudiCT+AreuTi JvYVzyHG49yRQoq4G5oltFcFllUlC+1uccYH+NbwARQi52jgfSqGiaYZtLE4k2uZSRx/DgZq /gDp0qWtRotaKfmuf94fyFaj/d68Vl6N9+59mH8hWm+dp6VLHcjDZp4qNetPBoeoIeOaO9Jk mlHXrSAO9OFN5z0pwppaCHik59KBijNK40xRzTgaaBTx9KY0OFLSClxzmnqhBTxSU5eamwDx kms+4/5Ccn+4n8jWguRis6bnVZQeoRP5U0gRoWY+epZM55plkC0mB+tSSqS2T0pMdyMDvTV/ 4+fbYf6U8daaB++JH92kmA2Q+bGyyDo+Bjjj1pwfBcY6Lk8cYwelMAOPlwOak2Pzl1/LpVbh cRCshhbYc4yOcY4xzUivtQnY33vXmk/iGQDkZp2M+nX1o2AmR/mcbfudc9DSo24jCHAHTPSo wW3ElAR0xmpQu5gAg6djQhCrgqhDHA5PP3qdqp/4llwc9Iz/ACqvIUSWJGOGfkD+8Kdqn/IL ufTyyD+RolsCOG4HOKnDZA4qq5wmakWUKBn+VEb2KZY/CniqwuEB7n8KcLqP+9j8KBFoUyYb 1VB1ZgP1qIXUQOPMz+FS2zrPfwqvIGWP4CiT0KRP4gcGaygX+Bd355H9KiH3VH0qPVHMutMD 0SML+rU5jzgdh/SvPm2zeNjZ8GwifVr+4z/qztXn1auyTaJkxJg5HG3PeuZ8DQsmlT3PygzT tyRnIG3H866qN5DIoV4uo42+9EZ2kkZSmlobWaKM/wCcUV6t0Y8xzxOXXH94fzry6741C8A6 ec1enKAjL83pXm2sR+Vrt8v/AE0B/NQazq/CVDczLP7lwP8Ap4YfyqbpxUNrxHOP+m7HP4Cp N3IrzZI6SJ25xQT8tDjnNN561S0RI0nmpV6VD3qVDwalpDsQsTuNMJ5p7D94aYRzW0NiWgc5 qEg7T9DUjnpTCRtOOuDVK6Ec4cG/GK1Yqy8f6Z/n1rUirsi3Ywe5ZWpKYtPp6CFpaQUoosAo xSikFOpoBRThTRThRYBaCaBRSDUo6gwS0mb0Q1hJ0A9x/OtnU+bOf/cNYsfDAnOMj+dOKBno WgKj6DbYGTg/yFMb7x+tO8LkHRLbPPzH+S0xs7m+tQ7plX0LGjcNce7DP5CtOQ5WsvRutx/v j+QrTkHyjtSYIjHHSpB9ajHWnihMQ8UvFNBpQT6UrgP60UgozQA8AUuKaDnrWfrmrHRtNM8c XmzuwjhQ8Ase+fbINSxljUdV03R4fN1C7WIdlHJP4CsA+P7eZmGnaZLOBn95I+xT+dYdr4fb U7p7/Vbky3Mjbm44HfAHpzXQxeFdMkjwyk8ds1Vl1NI02xkXjW63bpdPtwuPupLk/wAq1rDx Tpt/OttJm1uXHyo/RvYHpXP3fgVInMtjIUyBlT/9esa7sbnTQUvYw1uWUbsdDnr+fenZWB02 j1MrtbB7Uorn/DGpvcW7WdwS0sWCjnq6cDNdABU8pnYeOorPlOdUl45Cpn/vmtAVnSc6pMfV U/8AQRQlqM0rT/WdKklPNR2g3PxUko5odhNIYpz2NAzuJA7UClIO09sdcVPN0ArPMPLJMJYe ZwOhz/hSyTJH5uQflGTx/KoLVbc7o/NkO58kv/KrYsiod/tLEEcZH3RWiAal0qFA643LkHGa d9sVowyISN2OB1qKM5Cxwt5rAY54zU32e82hin3WDHDdR6Um0A/zVzK29flbb6YPpU6khiQv RSTzxUNvuuPM2sFOeAe3tT5IGilaWS4AjYYVccA4x+NFgHLcxDyVkVWd1yp9f8Kfqo/4ld16 eWaithG+xVdHeNcE9M1Jq7bdJuh28s0PYOpwL58unx1Gxyg/OiNiWIx+NOI2WBmnUwdetO6+ lPQELn2FWtN/4+XfA+VCB+RqpnirumkJa3MxP94foayqyshxepnmUzX0shzksf5mpJmwkrY5 A6VBb8sWPc5pbnJhKj70kiKPxOK4G7s3R3/hULb+G7OMs4JQMfl6ZArZjlXzkxcMDuHGwc81 QtFKWkKCF8LGo4cegqaM/vo82Mx+Yc7xxz1raMPeTMZQvqjpsf5xRTv+Bj86K9HUzszmygHJ HIrz/wAURGPxJdk/xqjf+Oiu/QTLCBOwZwOSO9cV4xQLrSyd3hXt1wBU1FeI4vU5W2kGJo8H ImY/yFPGd3NRQ4a6lI9SPxzU7DDL6V5kkkzoTbGP1qNm4wKe9MpqzWwxvNSRng0ynL0NGyAY euajJ5p5PNRk81cXoSI3Wk6A49DTj1phzg/Sm/IRjT2/kXKDqSuf1q3F2qK8k8y4jyuGVNp9 +Tz+tSpXbTb5dTCW5aWnZpi1IOarQQopR1pBS0D3HUUgpaBDqcMU0UopgOFBoFITxSYzK1Zv 3BX1qhGN5SMDnIq3qpLNGg5LHAGar2oMV8qzAqUI3D04BoiB2/hoAaNAufusR/6DSHBZvrS+ GmD6WjJyhclc+nBpuc5IPBqHuBNo/W4/3/6CtKTpWdox/wCPj/rp/QVpP92h6AiIdakWoxUg PTipAcKcKZzSg4p6IY8UvFNHNKD+NFwFXrXNeKJ999a2xPEa+YR6kla6ZTyK5PxNj+3Idpz+ 4G4ehytG40TWZ+6K6CzjPXjAHeuXhuhAgIRmPsavxa+gjCuuwr265rNuzOmMlY3ppH4Oeg7V l66ftWmmNwCNy9veq6+IY5G52gAdT0q1LexXaGMhduOWWkmwckyh4di8vVIsHChCDXXLXEWN 0LHUjeNu+zxs0eCPv84zXbDmtb3Whg1qPBGetZ75OqzcHGE/9BFaAODWc5B1Scg9Ng/QULuy GzUs+H60+Tio7T72Kkl70NgiEyKvVgB71y9/8QbHTb+a1GmXd15e0F0ICnKg/wBa3bv/AFTf SvN73Z/aFznO4Sqcg8Y2rUxSb1Gd7oPiXT/EUU8sNhJbNAwUrIMknj/Gt4GSReHwpHQiuL8D PGZNRMQIXcnX1wv/ANauy2h1w3IPvVyST0JVhv2EfeWXaccECniC7K7ftO5cd1qnc30lk8nl xoI4xk5PYVRtPFUt5EJraNXjPGc4pqm3sDkjajs5IGDKsZYd8GpmjlnXbMqlfbNZI8Q3inAs 0b/gdO/4SO6B+ayU+2+h0pk+1ijYijW3jCRQoAOear6vk6NdlgM+WelUY/Es2SHseMZ4kFXt XBGi3bFs7o/yqJQklqCqJvQ4Fj+7B+lSLUTfcHpmnoeacdjRkwpc4plLmmCHE8Zqycw6Hz95 8/qTVNydnHU8CreonZYQR96xqtWKjuUrb/VjI7CrEEYudSsoCBgyhjn25qCJtsJNXdH8v+3Y 2kfbsjbbkZ5OK43F3ubN2R3cRCrgJbkj/ppipIpHFxF+4tyCw587GORVaOQFesRH/XPk1LEy m4iDQQt8ww23pyKiFRqokYKq7WOvx7n/AL5opcn+9+lFexdmfMc8TxjGeK43xvGVurGXHDxu v5YrseD+Vcx42jzp1jL1KSsp+hAomtClucFZQhFnk5LNO/8ASp2bNMtuYHP/AE1b+lKQa8ua d7nSthjUw09+lR80K4BT1+7TKevCkVWtgIScGmmlJ+amMewqk9CWK1NIyCM4yKcexphPBPpW kdibmXeRmG+VC27Kg59eTU0ZzTtQAc2so5BTH8zSJXXC7Ri9yytPzUamn55qrCHilFNFOBqN xjhSiminCqQhaUUUtDYAKRjkdKWmv0NAGHfyf6fAM/dwx/OrF0m3V5mxwVQ/+Ogf0rLv5MXU jjsh/rWxe8zb/WNefwFRNWZUWdH4VbOkwg9QefyFOC7V2+mRUfhc40qE+o/wqzOoErfU03uK 47SB/rz/ALf9BWnJ9z8RWbo6/LP/ANdM/oK0n+5UyYIiGc08GoweakBosMcKcOtIKKW4Du/W lzTB1p1J+Q0PU4PWuV8QWyrrsUo/5bw4Jx3G0V1IrnvFasgs7pVyqMY2I/hJIwT7cU9kONjL +yKG3SKzENkYOMe1W9MgWWWdCnPlNt+uDUUd3LIuGPNQ2uovZXDYhd93GaUTblRO+ltIqn7D 5qgf3vun6Vft7WO3zuQRueq1Xjl1B2F20JtlcbWh3Z9w1WVBd97HJ96lt7WGkhs1uHlAwGVz jb6H2rqkGxAuc4FZFhEJp95UERt198Vrg1UdCJtDxWexzqlwexK8D/dFXh1rP/5iM/1X/wBB FXe5ialp8zU+VucVHaZ38ccU+Uc9aljsUrrmJq8w1Oezj1S5F3LJEdy7cKcH5RXqjojDD5wf SohpmnuctbAn1JpRdmM5XwB5cn9oyQ72g80BHYEbsBPWu5BI2/UCmRxxxoI4o1RR0ApzZG3A 6NVOSZNipqVu1ytxEuR5ilQ3pmuLe11/w8JE0/TvtEDYJd3Gc9M4rvnSRgSsW4jtnFV92qeY UigSJf8Anoz5/StVNxRNjzx9Y8SyzoxXZAH+dFQBtvfk1etNY1C2kzPbfaoT2LBWWumv1nhm hWaKa6knfYJI1AWMnu3tUlz4Xsr14WMkiBM+YinibjofSmpzY3CFirp+rWmqloobWW2lEe8i QH5geOD0NdFq5/4kV1j/AJ581S0yGQWEcT2YsjGNiR7w2FB45FXdaLDRbkMMZXnFKcY21Iik nocC/wBwcmnp1qNz8oFPQ1C2NSWlzTAaXPNJiHD55okHdwKl1WQtPGp6BST+lMs133sf+yc/ pUV62+7PtxXNUbb0NIij/VAVd0KWGLVZZZ5/JATarY9f8iqJOAB7VJY6NNrG9hYtPCrYJDDj j0rLllJ6FS2O5h1LTyONSUk9u9WLZkluoisiv84wd3uK4yfRLzT0VdO8Ohxnkgrn9ajs11Zt RtBc6BexATRkkSLhfnHoaUcLU5076HFzSvse15oqbj1FFelysu7OZFYHi6Iy+HJHxzHKh/M1 qSagkCBniIHQEnvVbUs3/hrUA0RQlNyqTkgCqlsWeZWvNux/6atTiR61DaPi146FyakW6lAx tTj2ry6t1Kx0x1QxjzTCwHr+VSm5lPGVH/AajM8wP3xj6VEJD1G5z2pwyAcio2eRjy5/KmoW LYLE1fMOwp5prRt14/OmPycc00j1rRK6JY8oeNxHX1pGIVTzzg1EQvtTcgHkgcH+VVG97Mkd bQ/bNDfYR5luQcHuB/8ArqCPtVCGdoJ2cOQpGGHY1d3qvzdAa64IwluWFqQGoFlXPWniZP71 O1hEw604GoBPH/e/SnGaMHBYZoAmpwqETx/3hSieP+8KLAT0tRCeL++KXzo/74pASYqC5k8u JmPYVIJEP8QqjfyhwI1Pqae4GBeZHmbuvln+RrcuBvtY3/6Z4/z+VYcoMgf/AGlxn8634B5m noCCcDGB9aUkOJveHGCWVmhIAZQPxIq/eptnxnAYZrmrG8uUWOL7OI1hI2Puz09q6F7ma6RD MVOAcFRjr/8AqqXe4D9Ix+//AN/+grRc4Ss7SRxN/v8A9BWi/wB2hgiIdaeOaYOtPGaVguPG aWmDnvThxTsA6nU0U7FTpcdxRSsiyQvE4BR1KkHvSCnAHtVPULnGPC9tczW0gO+NiOvUZ4P5 VWi+3tJgSwQrg4LLkg9q6HxFZpiK9SRFlBCOh6sOcH8KxYvIkOJ0OeelZ6I2iS28GqRsXuNX ju4/7giC4/GtLKjp09aqI1sq7YY2XjvUsTgnHpQ02Wa+kPsDo3BZ8j34rVx781zonRSkQDPL I21FQZYn2ru/D3hOS4sJJNcVllf/AFManDRjnkkHk1UE7kTSSMcVnE51O5PGNw/9BFdLe+Gd Ss3P2YreQAZyCAw+tckLpBqt1FKHjlDAFXUj+EdKtqxijbsuX6VNLVeybL5GMeoNOuXKjjpU tgMOOtAz2qr5jMasQeW6ncGGDjOaz3ZROj9uKkY8DHY1CBCmD5j/AIiptwKgo+fqKEtQHK65 5FTo6+lV+pHANKBIOkan/gVbXSJLR2MMEVH5EfZcfjVWe6+yQtNMgWNepzUY120GN8bDPfdS UwaL4jUfw/rVXWm/4klyP9kVaEm5QwXgjIz71Q1gt/Y10WXHyj+dKUxKKOIY4A+tOQ0x+Qv1 pUIJ60JuxdkS5pc03NITRuS1qXNN5uJH/u4FUiwaXOKtWeEtZZD3cjH5VRQ5kFc9R9jWJM7Y LE9Atdt4NR4dAVzndM7PnpxlgK4G6crbysD/AAGvStGQQaPaR4xtiA/U1FJsJt2NUSuP4z+d TQ3EnmoN5OSP51UDCpYPmnjAHO4fzroiZ30Ol2j0P50UZorouQcfCI9+2aFZIyPwFXFihPnx RrhZI2BUdPumqEly5gbJQNj7jMBmkt9W06zk3Xuo28K4Ofmzjg1MpxW4anldsVitSkjhdsrr k+xxUJvbZDzMtS6paWP9uahLblJoXuXdJB91ge4qrmCPgBFrhqyTlodFN6ajjqFsfuuW+imm m9GOIXb8MU03cAPDr+Aoe4G3cORQo6aIpzSEN1Mfu235tQktwT91U4PfNV31HaxUQsx9c0hu 3YZEYH41Spt7oh1ET4lLfNN+QpDCf7zEfWqRuZifvAfQVE0krZzI1axpOwudF5kQcEn86ryC MAkDJwcc5qsck8knmm49qpUtSHPogC5IFW4ZfLO2ToSAOKrxD94KuNEGFbRslYgsLjtyDUgw az1doWCkEqT+VWklUgEHimBOAPSl4pganbqVgHCnZpmaN3NGwEoI9qUMPaoDKFHNQy3OAdpx 7mhXAszXKxjoCayXaS6JIxgg5YVLGHuTuOVjDYLt3pJNQsrcCCNzJJ0CRKWJP4UbCMthgso9 CK6LSCJLfngLxmsy08O+JtVw9ro8kcb/APLSZgoHuQcGuu0bwPqNpGG1HUo0bqYokBxyf4u/ as51IJasaepWSCCacIZRGT3rUS3hjUI92uMYHHJpX8PabDPJIIGmldsszsefoO1c1b6CWdZ4 NRlZUyGhk9M8AH2rFVubRFq1zq7KBLcybJPMV23L681cf7lZFq0kMI3Ahh61pCUSRBgRz1xW il3KlGwinmng81GKkFVcgdThTRThiqEO6mlGAKaOtSCIsm88KTge9TYZA8zchFB981Rup2CH LHPtWp5QK9KryWYOTikM5q7tbiaMyRZeQHOD39qpRzx5Cudj91YYNdaLRkOU4P0zmphbRz4E 9nHL7k9aAvY419VtY5vs6u0k+M+Wilj+ldFovhnXtacNHaNY2pIJuLjA49QvWut0iz+zEG1t ra2/2tu4/rXQoCwBlkeQ+/H6VpEr2jG6BoeneH4yLZTcXT4825fq5AHQdh9K2WnOOvNU42wM CpOtWjNtsazvuyHK/SpGjt7yPZdW8cy/7Q5qIgmm7mVsdKYihd+FrOPNxpieTIoOYckq/wCf Q1y90CRg9ehrvo5ST1rl/EtgIJ1uETEc2c46BuP51Eo3Q0zn0UD606OK6kIe3dVCtllIzuFN C4ycYyKZvt3I33hhZWJ24PNcysmXuXGW78xSNgGTuDDOeKmRWVTuHNUfMh8xGTUwuCcgfxcV eilSRDtlD46nNWrEkqGpAahXipAeeTSdxlHXmxosp/2l/nWRcaSILD7X5hZgw3KegyeDWpr8 mzRZTtLYZThRk1yP9oxs8UTPMQ0i4Uxtj730pwuDR6HGf3Uff5B/KqWttjRrn/gP86uRn92n +6P5VR13/kDTf7y5H40mwRxDkDb9RQgIYnOaa5yBwetKp5NaLYZLmkJpM01jgceopN6CLm4R 6eBnknP6VUi+9nrxVm7+SFEHSqqZxkVzSuzSJHdfNAyj+LivUYHBiXHTAry+Q8qD6Zr0uFgs ajPQCnTegplwGla8WxVLh8Y81I1z6swH9aiVgSAO5rk/FOsxnWdK0qE5ZLqGSYg9xJHhfyNa J6kWPYfLHqKKft+lFdBJ8rm3eRB5lxMx2jkuf8aifT4HYlxuJ9ee1aAjO0fQUeVWXKmNybKY iCKFGQo7A0mwemaueVSeTQoILlZFx0FTPkR808oF5NIxUrgGtNESyiyktmngcVMbW5Y5SDd/ wICnpp+pOcLaKPdpBT5kFimRzTSKs3FrJasqyshcjJVTkL+NQEc007gRkYNJTiOaTFAhYv8A Wj6VoLVCIfvBV9fpSsygKBqga3IIKHBq0MDk1BPqFnbg+dOqkdup/IUySPzZUPzoWAHUU43i L1JA+lSWa3+ruF0jSLq8JGQ+3y1/76P1roLT4ceKb4eZfSW2kxEdGxK4/I1nOrGO7A5s38Kj JkwPWqc2vWcZI8wufRVzXpdl8KNCgO/VL251NyckAmNR9MGuu0rRNG0cY03Sba3P97G4n6k1 zTx1OO2oXfQ8SsrHxHrK50vRJ2QnAeXCj6/Niuisvhbrl03marqkNn8wOxE8w/hXrs0ksqbW Y49BxVLPOMVySzCUn7qsDRydt8OtBgKm+NxqLqesjlV/75BxXR2dnZadEI7Kzht1HA2ryKnZ uRTSaxnWqS3ZSSI5i8g+ZiapuAOtXm5qrMvJ4qIyV9QMu5QhgR65rjNcWXTLuO7jH+iysRNj +BuAD9O1d1OmVNYt3Cs8TxOMqwINdMJ6gYgv1liQDPTk+tTw3TxOXQ7lONyevvWZf2ctrBHN n5Axif3PODUcD7AQDj2rsi5NXRqndHWxOJIw6n5TUornrG9+zS4bPlOfm9j610CFWUMpypGQ a1jK+5LjYkBpfeminZqyCSNDLIqDgE4J9KuTKu9UQ/LGpUe5NQWR6OR97OPfFSRyiRSeOpH5 cUgFVMjpniplg3r060+BNxpdRv7DQLM3mpT+WnAVACWcnsAOaEUhFtC2ABzVy301jjMZx9K4 e78c67eyPHo9lDZRBsLJL+8Zx647fnWc+p+OyfM/t+4HPRbRMAVSbZSg2etxQeVxtxVlOO1e U2HjvxRpoBvPJ1iFRh0CCGTHHIPQ/SvStF1mw8Q6d9u0+QsoO2SNgQ0bZOQQfoapMUoNGkpx 0BqXnFRDipUGT6VZAKfmprr8wp7rsG7ihuBk00rCGINpz2pl/EuoabNbqhLKC6E+oGeKSQ5O KWGXEoHbvikxo4XaQoyT0pRxwQD+FX9VtfsuqTxAfJu3L9CSaqbR0IrlmtS1sMCIesaf981K iIpyiKue4GKABTsYFTFCHgkUqknqKaCO9P8ApV30GPVyp4/lUnmsRyE/75FQj8KdUXEO3c8m s3X3I0h/Qug/WtDPtVDWbK5v9PaG2VWlLAgMcD60wRxUpwAQOhqLzlJ5j5rXXwtr38aW4+jU jeG9dThbSJ8ejgVpdWC6MsTj/nn+tOibzZFULjkf5/Sr40DX++mr/wB/RURt57G6CXcXlSqA xTOeD9PrSk9ASGX4BuN248DbjtUA+6Knvo54rgi4hMRPIBPaoOOBXPJuxtFjAd1zjsFA/nXp kTfKBivOLCyvL6ZmtbcyorBWbONvr/OvR0z0HPtWsPhInqxuoanFo2mzajOdqRY2j+82RgV4 7pl1Le+JLO8uGZp5bqJnz670H/sore+IWs/bdSi0qAnyLY7nIONz/OP0wK5zR/l13Twf+fqL /wBGLWkIX1ZDdkfV+B7UUv4UVqRc+aRH8q/QUvl1YVRtH0oI9qzsMrGOmmMVYNVLp2UhU6kU wILpWOABnIqukblCuxjz2q5BGzRgzxsHx1zVlURRkK34ZpOokUoXM6GwlZ8+XcKue2a1YdPh 25llfcP4cmrVkUlJBZ8ggAEmpbOOOGL/AE0BJmZiCzZ4z/8AXFJVIvQbjY5i+CJeOkf3QP8A GqxGDWtrP2T7QotiGO3Lt756VlYrS6sZMYetQS3UFtjzpAuc+9WDwDXcfDnT9Fv5ZRqGkQ3d 3GS8c787Apft+A5qZzUI3Y9TgLKS61G4EWl6fcXrnj5EIUH3PauusPh7401B/wB/Bb6VDnl5 XWRh+ANeyCSRFVIBHEgP3UUAYppUscszMfevNnmPSKFZnn9n8JNNXB1zWLjUWzzHGpjT9DXT ad4V8N6MVbT9EgSRRgSuS7EfU5raAxxtpD6GuSWKqS3Ycq6h5kpUKGCjHRQBTNmTzyfenilJ FY+0b3KIinHrSAVIcUwdfSpTQgJ4xVaVSGyOM1aqGRQwwRSvZjRX6jmoyOe9TFeajfGMdK15 gGdutRuAynvUpHFMPWgDPcckZrJuU2txW3OuCCPXms67jyucVtBruBi3Vqt9aXFo3/LVML6h uxrloWbLI64kQ7WX0NdcWKMGHUcisPX7L7JeLfqQIrkhWx2fAxn6130H0GmV1XPStCx1CSz+ WQb4cdB2qlCMirAQFea3atqbLU6KKeGeISRuGUj8qkdQ0W6Ns8jkVgaHN9j12ON3C29z+6ky MgHOQf0x+NdFcWgsdcaLlYS4PPcYznFXF3RnKNiw5ELqv9yMD/Gq9s2540XkkEn65pL2UNPO VOQT8pHpVHfdNaXD2Sh544mcKe+BmpbJRqv4jsoLS5azIu7yGT7OtuOC8x6Lk/zrkl0LWNQW 48R69Es7CRIVi8zGJc7Qg9BkDNdFpElrPq8GptFCltDah5EPLmYYb8BzVXw695qOv2Fpd4W1 trufUXOeJGHzA/QZppFIxptO8SSPOm+1s44JlgliTnynbG1Sx65yOfekfw34ntmuH+2RxG0k 8mdt+SJCMhVH8XFdTLA2teHZo1lBn1Oe51U46sicxj8wKsafqDWc+nalqgYTwadLeJCRzLcS HaoHuOB+Nap6DXMc7b6Xq1zpcD6y1ur3i503UIjn7QwA/dsg7kZP1pfD6654d8YQzXukyWUN 03kXAMqt5o6I5x6E/rXUWKQafqGi2mpXEca6TZi7nDc/6VOxUKB3IyelSazHca14zNoLFLvT 7WNLO4nkl2m2eQBywHcgAfnSC72OkutX0qy1VNMuNQijvZBlYj+nPQZx3NXBKucBxk9K84gs 7f7d4j8BarCkV9qE5nsNQl585RjaM9iAp7130ljZyxC3kvYtqgAZPSqRm0OuNWezZRPCHgPD MD933pJL+EOsS8swBX0xVGSyu0ie3mkFzCVzFcLjk/3SPpVO2mYRhXXaVOOTnincDa3ZYnHS hD+83dKqpLuT6n86sRk8800wTKfiODcILpQM4KMfwOKwY3iZctuB9K6y7gF1pU8XO4Dep9xX CTSQrArzyrGMgDc239azlEaZosUx8pNND0yHb5fynK9jUgx6VlLyGgBzTwaZThSTCxIMUuaj BpQee9NWAfmnZ9M0zIpQe1O1guPBNOyajzRuGagdyZXOQCf1rj7gm/8AEN0CekiR5/AGutDg At2UZrk9F/fagZiMhnMh/Bf/AK1Q30Gir4jlM2tyj+FSF/LIrMY8/TNSXcpmvpnJP+tf+Zqt O22GQ5/hP8qz1uWjrvCEfl6MJB/y2cv+eKva/q8eiaHcXbtiTGyMDux/yKTQLYxaRZwqvIiT 9QK898Y60dY1nyI2/wBFtNoXHRmwpJ/pW6d9CL6mNapPfahzzLNIzuze5JJP5/yq/bwpF4k0 +KKYTFbmIswHT94lVbW6+wsHBAL/AC7/AEHeui8PWOkyatYSeapt1nRlCt1bcMZP1rrSSVjJ n0hz7UVFmT2opAfPC9B9KDUiRjaPmzwORUoiXqSPxqEBV2k1Su0O4H0q42p2UcjpuZmU4O1c 1TlvY7niOGRiKdgGQXbh9rkbQuelaB3kDYwz2yKyLaOd7r5LdpAqnK9xyK0s3YztsZPrkVy1 Y66GsLj4pbpLhSyRbVPXPNUvEN081imXA+fHA+lW1N6zADT3OTjqKz7yAtMI7qEEKchG6DIq aEbTuwk3Yxo5WWIBnLYHFWVOVBNW109djFFRVx0Jpqw2r/61X3KRgqeK9Kbg1oYpMqkjP3h6 Dmtjw1qLaJrNhfgFo1m+zypnHySnaT+Gc1GlvbTStHbJFIqnDcEGpItNjjW5iR3IdM+W3Yg5 BH+e1cs1eLuM9zONx28qeQfUdjSevNYHg3VDq3hq2aZg1zbosMw9wqc/rW/XzlSLjNobE/Ck 4paSpuhDFPzlc9s085ph4Oc0uQe1UgA80mKU00/lS2AKa/TpS/rQadhlQ8HnJppwee1SSrzm oTzWsUgG57VG4Pbinscc0jDIoYXIJgCtUJF3JzitAjg1Sk4bBHBojYDFnTEh9Kr3Fut9Zvay dxkE9j2q9eKByKoo4EoPfpXZRlqCZzVvI8TvDKNskTlGH0q+kgqxrmkyXDC/sv8Aj4QfvU/5 6jnv2PNYlrerMmRkEcFSMEH0r0OW6uXFl65K7A+7aVYMD+Ndb9pa4MDyEOyjGcdRjFcTcEzQ Og6la6SxmElrHIjB+ORnvSSsVIkuHC+YB0yQADVyCyW4+yGzufs9rtZbpMZaXPYHt6VkXMmJ Gye5rU8MJJeRyJCylkY5XPOMnn9KZnYyfGdtfaIxu9JdbbRrpBHcqse/Y2eM55wcCqg1i8ub Xy5L/wCyzRrshvoog2UOcqy/pmvRYSQJbO6h3RSphkblWFctqHwzgkkebQdTk04Mcm3dPMjz 7ZPFWlcqMkjl0/t5NrW3ieABQVVxCoIU9vpVmDUtTt7iG5vvEL381upEKLAqiPP+1j6VcPgH xTv2Je2Lf9NCmM/hmrtn8MJ5JQ+t6008WMGC3j8sHPUEg5NUkx86MA+J9dvPESyaWILvVywd B5IYLyeWPTvXbf8ACGLdaJdvq05k1i7HmukcrJC0wHyEgHtgVuaVpGnaFaC20u0SBMckcs31 JqZovmzjnNNk83Y5uTUZPFN74fsLjTZ7O60iVZb2acDauEYBEP8AECe4rYvbHw/MD9oWGNj3 OamlhaUYYk1AtkUbItd49SaZLdzHfSo7XL6Lq7xHtGMsh/A0R3bvqjTXFu8V3Ig8wq2UbHGR 6VruZSdkVlg98cVmXTZkRm+8Dg0WvuFzoLdidoJwqgc1fiII9qyrNlKglsn0FakTAj6UaC3N CyI80Ang8HPvXkXizSbLUGksryVkNlKCoweSSMj6Yr1i3JaQBRk1yXjiA29zI4xtvHhVeO+V BH6UPuCuUrD7OlpHFbMPLRQoGOmABVnPNRKAOB+gqRUcjgfjWT1Zdhc80AiopZYbcEzzxxgD nc1Z0niXQomKtqkeR1AU1CEbAOaN2O1YP/CYeHQhf+0dyg7chD1/Kmr400J3VI55XZhkbYm6 flVbDSbOhDc+1OzWPBrcd1GXgt3AHTcetSrevIhGdrZxx2rGdVIfLY1OQM4/GmZJP/1qz1Sc jKSOSOuelOF7PEP3tszD+8DWKxcb2HyvoWr2byNOuZP7sZrn9GbybS5k5zHAefc5qbWNUW4s Xthbyxl8Dc3TrVbzo4NGuV3r5jsoA74rTmT1Q0mjDLZkc+pNQygyGOMdXdR+opQ42ucHhivI qbThH/atnJOpMcZaSRc9QBx+tJJ3KudR4r8Qf8I94bWGEhby4jCRkD7oABz+leVrGQMA56ZP r2/pWtrM02raq95M4Eajy4l6lUBb/GqY2JkEE9umK6KUNbsykysYmJ7kA1a0hbZdd007B5v2 qLoP+mi0xp+yR7R7mpNJJOuaeTj/AI+oe3/TRa6LkXR9Z5/2aKXNFAXPnWweGLT0MsiRrGgy WPQAVjeIXGoRxR2cxmjJ+cRtgfjVa8itpNpntvNZV43EgD+lVxczqnlptRR0wO1ZRbewyAab crgBiihshVagWV9uUxyFGUnB3UrTzA5EzA59KFvJeBIwY+vetHfqVdI19JfUnV1vXIKAKjpj LfWtHdIhx50n4ms3S5ru4kW1tYy8hXOWOB+daU1lqSDMtux6fdIOK5KsrM0jJliMXRG5ZX+t c1rl07XiRlmGFJ3dznFasmoX9oAkSjnk7x0qjNc/aAskzoZBkYC4pUU73CcjJgufJmDzTFog MMpPGK2pdK84+dY323dgiN/mB9ge1QBIJE+bbnH3cUi2ywKwhcxbjnI6V1yTZipEseqXeho0 dzaJGWkJEhOev0HtVi01A3Wp291IyE8rx0wwx0qr506LtN6zA8FSoxiqslukW2cXMckgbhAm Mcg1DpuUQujv/B96dO1sQPIVt5/3bH1YEbf0FemA8V4xd3X2e3W4jSSRiqOmwZOWHX6V6zpV 8uoadDcBwWYYb2IJH9K8TE03ce6Lxpp96d+FIRXFaxIxh3pFJPbFOIpvINXzDsLSYooJxQhD cjNIaXJpDzSaGRuMiqx4NWyKruCpqo3AhIyOvFMGORTmaoN2JDWq8wB+CeOKqTDPNWZG9Kqy Oei4z3oWoGfcrlTWWy7XzjvWzIpKn6Vj3bBGIHXNdEN9BouIxUhhwRzWXqegQai4mhf7PdDq 6jh/Yj8Kf9vkXjI/Kj+0pcjDLn/drvjUsirHLTm+05yl3ZSjHG+MbwffiptHu9We926fZubW Rh5pmGwKfUZ5PU10M2u3NvCzlkbavTHWkPizTiMS+apwMgRnjP4VrGUZPYNbCTaZeyT/AH12 k8vnn8qltrG4sZ0ktpCZkJIfGN1WbW6ivbdbiAsYn+7uBB6e9XdM1EBzaXUR8rJMcy8lT3BF VJKxB08V2t/aRTfxFBnI74qVSR2qlaYVAq4xVwNz0oTSCw8ZJpw9CaQEEcDmjp6VoAvXtSba UEUjOAKaAUIfSlaQRjk/gKiMpFRNcbDkAfXHSmK4lwZ7hSD+6h9M9a5nxI4gtImiPKzJ+PIz /Oty7eRiHluMRegFc94klWe0toYRuVp0GT6ZGaLlG9phZ41IwF65roLZA8eFAZgO9eff8JHD pZMDW0lzPGOFBwPb+VZ954s8VarF5UF4mlWzcNHEiyOR6biOKzc7Aotnba38QfD3heRbe9uG e8Iz5MKlsD1JHA6VmeJNbl1s2SNBHHCl1G6FTksAQa4S1sEs4yFTLE7ndjkux6knqTW9dXe9 7bHHLOR+FZuehfJYs6trCaVb71UPMThIz3riLnW7u5Ym6vpMsMFU+VR9Kua2Xu7kbZMBeM9c fSs6PSrJVGTI+O7GiLhu2XGlOWxT3WfmmZkZ324zIxbgfWrAkdxmPocAALmrX2fTrZCxi4A5 LGr1jNCiCWGIIxHQ8VMsRBbK5X1eS3KMNncxOslymxC2FU4+c+ldBaaeVYTTKFbHK020zLeC SRTI2eueF4rbS3HBDdaxnVnNaESlyKyKqX8MUm0AZ6dK0YpyfmUBfwqMxKuBsH41IiKOTXOo O9mczlcGuUmuFgbfvb7vBxQdRhtZmimu8MONrLwKo3VzHK4WOQ5U4OB0rOlQLs8uYzBxwzis Z0Ic25tBy5SzqdzHO0aQTeYh+Y8dOtZ98Y/IUeWBJnlvUUojMdwEIwwUE1mzzyS3LhugOBj8 K3hRtsyk29x20hFOetZ+qTeTDkEjPy/nWk/G1az3eOW5ETx7sgkE9B0rZJ81h7IwhcTnAjcd AQMZqTzbpzhhk8cYxXRGzfblI0HHqKqzWk/UlV9ya7YtbGGtzK/eHO5cHPTNWNHDPr2mggj/ AEqL/wBGLUxgKrn7xz6Vb0hXGsWDBcf6TF2/6aLWiQH1J+VFJj2NFAj5k1bm0ZduGVc1j4BU tngV099FDdxvE0ioGjwHxnBrlryy/s9AZ7lZ4ywyR8v4VEGk9C9yJ5F3BVR5HJwEjUsx/AVB 50LybdxDg8qykEVuaBrOmafqIltJltbkrgO/QHj1qLXvEUBvl+zTxzSbSZZFTOTxV86vZisJ p2sXOnWcyWhCysoZGddyseOCP609fFvidCdrWf8A37rJjuLy8IMNrJKSOoXANWk0nXLj/l1W EHHzO44rOUKb1Y7ySsW7jVL/AFtVbUIkSSIHayDAYc+n1NZaWl3KA0duzhhkNuAzWzb6Re2E UhufLuN/3VB27f8AGi3t47nTFtni3zMj+WAcEEd8+3FZ88aXwiabMv8As+9CjcEjGP4pelH2 RmYhtQAxjIjUvjP0rqbfTLC2t2fyYkZbddmTnEoXmp2v40Ds88SCOSFm2kDC7cn685qP7Qkt LXCNN3u2c3a6LHMiStcXckBn8ln8vYA/oQefxrPtYRcXEUe7bnPzE9K6e713TJ2RBeNMy3Ky Q7UI2Acc9j1Nc9py/wDEwhTjkt/ImuvDV5VHqiq0UldHXWIC6ZaKr7gkIhz67QK6jwbevHeX NjJjyziSLHU53bv1xXMaeB9nZVHCtnp7KKuRXD2V7BdRdYpBuH95ScEflXl46LjPQzpt2PVB z0pDmoreVZolkU/K4DD6Hn+tTV5DTTLY38KY2cHB5pxph6VSVyQGcUdfTNNBpfwoYCGgc980 lNLY7CnfSwWFY1BJkjg1KaiY+1CT6AVnGKqy5znvViXqeKjCc9K1TdtR2In3EgDrUDIEzmrX KsQR+NUrlz0FJPUditcScECueuJQ9y8fO4YyK0NTumtY1CJ5k0hwiD+f04qlbWnlJySzHlmP c10Uld3KSIfL471GUPYZq40RJGDj8KrXjm3i3ZrrUtbFGZdzDftx0FV4wZ5kRR8zsB+tROSx Jz161qaDbmS4knYfLGAF/wB4g/8A1q6oRS1M5M6CJFhiVF4CjFFlcIJX6H5j/OlB5/Gs23Yx 3Lp1wx/z+tD1A7C2n4HIxirizZPWsGylzbI3YjNWUucNjdTil1EbazipBNx1FZSzHsaespz1 qkCNLzPegNmqIn/2qeJ896sC5xTJGGMBRmq/2jB6/hTZXUYbqD70wIZld0aNlUnGVG7qaxpm I4kjAUHjPY1ozxpxMjAY54NZt3apfXKXUd0cJgmDHGeOaAMTWUCXCSD+Jf1GarwMMcmtLVkE lsjd1fv71mxqqDjn61zyZrAmcjbnI6VRuLiXf8p2sF2568GrMnK9MZFUrlt0pyOcVg5NLQ6I 2bsyuSScHk+tRPJtGAeaHkJlIjGTnn2qGQhcAHcx61KXNudWiWg1pFALyYwqkkntU8c5WIu3 O4AjjtVeC3WeQtOxKooO3t1qSRzIzOedxGB6VfLG1iGzW01o4o/MeF5Y5PlIDYzntXTafLNc LloPLjXgZbNcppuoLbXkNnIv7t3O1+wOP/rVvPqAiHyMDXJWnKn8JwVWmzXuCEj3D0z0rKn1 UISI2BYEcHtWdcao7DBbAx61i3N8iyNIzYPGazpzqyFGmmjbl1A7iSBycnHeqdxdB13opCj3 rDe4lvGHlKdoPLHj/wDXUsUTDAkcuwzz0rVYbW8mdEYNo2bFy0EkrEn5M5JrPtnM0hcgjOOt Wy/laTMw/iXAqraDFbqNiHGxLNJhz7VRjWCZ/KdzHKwO2QdjViZxtZves5kDAtTgiHoVrxZb J8XYkQ4GHDEq1ON7cqMrIrDOPmHatWz1EKhguo1ntiuCj96y75LZLqcWiFIdwKrnpwP65roh Ud7NGLuMN/cNgNJg57KOam0eSY61pwMrbftUXH/bRaojk/jV3Rj/AMTzTv8Ar6h/9GLXShH1 tiilxRSEfO91EbOxknntisUce5gOwAqKTSdEmis5b8bPtrBIBsPzHPTNaGv332fwdd6fJqEd w/2baGK8njArGv3eSHR4pZmYwsdgA2+W2Qfx4rihPoa2RvxfD/RWk8r7ApYNglnx/WqE8Nlp MjW6RW1ukZOOnr1zT57Rb1CLme4mUnJ/eFP/AEGmw6bp8GPLs48jjLZY/maKsm9BqCWqM9/E FkWMSzs7AdIoyf5CoJ9XeIBhHKiHABkTr+FdAZBAufkRQOwrn9evI7uKNEYko2ScVEEr6m0d dx9je/bbsbj0YKTjHcVi2yLfXriYPtRJNoVyp/T2q9ohIuGxt+8D834UaZZsNaeJG3M0TnJP H+eauUddBVI2ITpGgqyl5ZG3Nhjvb5c/jzVH7F5pJtbJnUfdzxx65NdH9j1RZ3jjsYvtAiMy DzMgYP079KtXGlau8W5JIY4UX92irlvmHzL+FKHPfVGd49jnYdL1GRv+PZEwwGC/PTNVNPO7 ULdcNlt2CRx09a65LK0y0U2oSlvmBcLgBlwB05//AFVl2UV2ulWsN2UihQkopwWbDHH0ropV XCWrQqiTjuammTp9rNr/ABtGXHPoV/xrQZR6elc1BItprtjKuAo+Q89jj/CupZNq9MEVjmMU 2pGVNWR1Hg28abTZLVz81o4RQf7mFx/PH4V02TXm2jX39l67bTNnyZmEEvsDyD+BAr0cHHBN eJUjrdFMDTPwpxppqehIxlG4HGcUvUUGmK4JIzyKmw7i004PBFKTTapMANRtTiffiq7vuOF6 VW40kNYhjgYpjNtXr0p5IVecVRmlzwOlVcBjynzCe1Z97ciJCxGewHqanlkWNGkkfaijLH0q jaW0l7Kt7NEyqAfJXPQep/KqhBsqKIre0JY3E/Mzgdf4R1wKsiNauNEwH3aiCEMSTn2rqjoa WINqfxDA9a5PVrkXF0Ui/wBWnA9+BXQatdrb2xxy56CuSAx6/jWtNOTJZHt9s10mlIsenx7R 1JJPqcmsFFLZwOgzW5pcvmWYGMFCQfzNd6atYzsXs1mNmPUpQeAcMPcYFaOTn1qhfbVuoXyM 7SCPypWA1LZ9ttGnooqaJiZM54qlDIDEre1WYXGaqzEaKOTUm+q0bD1qQsMVSAkaTHFSxyEq PWqRapompoLk1wxRsgHDc1LZzowaGXGDnrRt863KAZK9KogM2dmNy9qaYFwoIJCMZQjrVW6V Y0aSI49gKs2txHdIY5H2yKOh61S1FzAjIc596ARz19clwUI6nJqiGqS8fMuT3qAEGsZM1gPy cgkmqlyQXPPtVgtWZcsRMcH6+1YSbvodENxjsF+SMYBOW96aFGMEc0IMuzepJodgoz3o6G7k NHAZCTyOaCwzyQOahd22HHDEcH0qncyOMqCeMDNXGNyJySiaDXYSPaSBz1PcU1b2V1AjJI7Z rMijaWdFPPz9620hVAqgY4onCMdzClD2jKv+kz8M5UegqZLSGMbny7epqwFwc00jc2Kxc10O yNJIQNu4AwtShQORSYCjpTkBOPrUNltWRNft5elInduajt8rGx9qXVmBFtGP4Y84/OgHbbkD uRTg3bU4Z7lec4Ue7VTglQgrL0OanujwOelVo1yua2poSjzETja2Acio8AuzEdamlQ8kelQr 1INdENTKpHlIGADHHrVrRzjXdO/6+4f/AEYtUpMq3Hc1a0VS2u6aT/z9w/8Aoxa0MT69yKKS igD5eu9Naz0WdyYlJiJWNWLMeOKkvZoReWI81SqlSWHQcCn65YQK0cxLNOIti7EJxgnrWYkN 0F+W1YjtyOawjTu7oq9jp01XTUXDXagg4IwadJe2kts01rfwsoYITj7rHoK5hYrifcbWVJJE fa0PG4GrthaXgt31JL+3Fqi4ZmQOMnjoOcg0nSHzlzUNNvbWSMXs6hpf9WPXr/gaz7jT5XjI WRBjua0V0i9jeG8kv1vIpuAiQnK45/CneIdAvbEW/mNFaRyhcSFt3JxwRn3oVOwKdjCSB7dW LSLgnIPTHFMNzLDNHJGN/nRPGMcZU4Brq9P8OWH9ofYb3xDbXdxsBVPJCgOeiZz+tZhshDLL Dcx8qxG3bwmD2Ipvl7le0b3KEV7rAsIwLWSOKONVjIkHIXoM9ahkbVZZCyyKJHweT3xittbd GIeO4ZQFwFKkg1R1CNkXk85GDSXJcp7FFbO8uGUXN8yBjl1RACp+oqxDcQ2cMcLvvVGOGPLE Ek8/nTJo3kVRlhjkioRDkcAVcYq9zNzdrFjUBPKIri1t3mTyyQV/A12f34g4U4IB5rBtPEOk aRYQWlxI0c6xKWAQkcgd/wAK0bc2WsQpeRNI8ZyF+YqOCe31BrmxklJbDgrRC4QPG6kdQR+l egeHtQ/tPR4ZnYNKm6OT13BmH8hXBFopN4iYNsYowHYjtWt4TvhZ6y1lISIrtSV9BIoOPzzi vKnFSWgmzvPyxTDTqaTXP5MhjGpoOD0FOJpjcVaGL1zTCcUm87ckYqBmLnC8ChxAc0hYkBeB TCQi9Me1POFFVJZutNPohkc8uapuxyTngc092yazLh5L66NhbnCKVM8g7L12j3I/KrinIpIa hOqXgK8WkDfN/wBNHGf0FbBaUjrinQxRW0KRwoqIgAUelO38cgE+orZKxpoQCUu+wsS3XBGK SVSqkswAwT+lSvIuDlPxrn/EGoCK2MUXDSEAj0FaLXYdzB1O7+13jlT8ikhc/jVKnAevWmSt sQt6V6NKDSMWySwUXF+0f8Ij6Z75q3ps3k3U0B4G79cVX0FW+1xTnkOmenuKjmLW+uXQPBEi sAfcCtGB0gNYGo5j1UEsTvXOPTpW2rZA/nWNqkDfbFmYHYVxu7A8cUREaNtcoYQO4qxFLlsi sWG4QIFXgAVajugG61Yjfil496mD5rLhuAR1q2koI+9SUQLY56VPEy7tvQ+9UfN2jIok8QQW oCXNlJLHx++QEkfgKYI2YiY3DLxVe/tCXW6hOG74qK0v9Ovf+PWf5s9GyP51oxyrB8s65jPB IOcUJoLMwbkRT4edSJVH31NU7iTcoXzmkUf3u1dNPo32uPzdOKOG756fnWJe6Zaafb3E2t6i v2gqFto0/vHoDimGxzl4w8wVCpwKS4bLrzxSKSOnNYy3NYCs3FZbqfOl4PUEflWhKdqn6VXd sgMOorGSR1QV2UUkdXIZSBk81EZCzgDJ4OPetBjuIz0qjcDyZlfaCCDye1VGSNGhhljYcH5w vP600wk5OKmSNJokMijO0bsd6lYqFwKvmSM1Tb3ZHp0Gbgkrwp/z/OtJlAYU2yj2ox9T/QVK wz1rmq1LyOmjT5UQyMAOKYg5yacYm3d6VhtAFJWsa6j5RhAaWIZeMeppX/1dLajdNHx0Vj+t Qtyanwle+ffqO3+5Gv8AWpZOIwKrMfNv5n9ePyJqzKRvPtW3MrHmt3ZQuj82PfFNThRSSnfI f98mnDgCri9DakhrDIqo67WPHertV5RnNaQlZlzhzIqSBfM56ZqfSGB1zTcf8/cP/o1agkT1 65p+jH/ifab/ANfcP/oxa6E7nnzhys+v6KKKDM8F0azs9f0+a31KEzpwTtcp29vrWvN4U8PX CQJPphdYDmMeewx9cHms+KztouYomQkfwsRUv2aFuqufq5riVZpWNnG5rR6TokF9HfRaVCt1 GNqSeZyBToINOs5ZZLXT7aF5STIQ33j6msf7Hbf88ifqxpVtLUf8sB+JNJ1mxciLus6o9poW oG1eOGUW7mNkAyG9RXkDteSySSXF3LcO/UyHI/Adq9Iu9GtL2J4pQwV1KnaexrHfwT4ejJV7 qYEDJXec/wA60o1F9pg4M4drPzQIEjBaRsDA5ya9Ei8Q3wihhNkhEaqhYnk9s/rWNcaNodih ls9V/s4pyZZlLmTr8ig9+9WtAe71GJTJuaFM7ZCuO56D8K6oui4u5lJST0OlfBZVa7jidxlU KjJHrWVc+GRd3Jll1OXacZQRjHSprzQY9Q1iz1K4uCWtI9iRgcEAkj+daEtwqA7ua89uz9xm 8U7anJXujaPp3nWdtezm4dg0ucnbwRkH8Kh26bbokab2wPvEmrOvXAuGYpgMAAD+J/xrm45b qRgGjCj1NdNOcpLUlo1pbaK5jPKuMY5rZ8Np9mhntdpADB1HoDuz+tcv+9R8rNtGOwrV0C4d NacSTFzPFtzjoVz/AI1NZXiyVY6mVAAcADPPHeqModXR4yVdGDKR6g5/pWnIvrVKZef1rxFe 9gPQ9MvBqGl215x++jVjg9DgZFWGNcp4KvgPtemM33CJ4gfQ7VIH4jP411TnPepkrPUTGk0w t6ilzn6VED5h9VH86TSENOZGP90enrRwgwOlLIowDkgj0qrLLyaTfQpBLL1qm5LGns2T1qlf XiWUG8gu7HaiL1Zj0FNJoaRHezyDFraANdTDC/7A/vH/AArTsdOSwg8mJwxJyzkcsfU1U0rT Wtla4ufnvJhmRs8KOu0ewrQyAfl5P1roirI1ihGjPPc1Aqu2QY/L9DnNWCD6c/WoZN5B+UkD uDVXHYqz5gRndlKqMnPHFcLdXDXV08p4BPA9OBW34ivSB9jXO48sc9Ov+Fc/XTQp3dyJOwlZ 2oTfvooVAPUsfyxWgXVPmboOTWFas11qUW7+Nyce1ehFXM7nWaRD5SImMbP64qtrqlNYWQ/x oufqMVoQnF5MOR93+WP6VU8QfNFBKOXDBc+3FJgi9bSeZbo3cis3xJc+VpflBsNK4GPYdTVn TZN1uB/dOKyfFZGbIYG75yDjkfdogmDZgQ39zbr8pDoF+6ev51pw6tCx+Y7G7g9qyNvGKVVy rcccc1s4NkHSR63ap1uE/Opx4ksY+WuAR/s81yOxcn5V6+lOQeW6uqgEegpezkO51b+MbTaV heRzjp5Z5/Sq/wDwmWrRK0dtZxiPsXYZrDCu4Z2646/jVhR25P4Vapcy1G32HXeo6rqeRczr EM9IVwSPrUVi15BcrC2p3SwFTg7s4P4/jVhFJPQ057cMD0qlRjEnnaKvnaxFcu1vrFyoII4P UZ9On41c0rzxPJFOrTOSJGuJWyc9gPyoiQRnB6VcgfE4H4ZocFYFOT3JbgBpApoHAxSP81yf QUrYFcjvexvArXbt5DrGfnKnaT2NJGrbAHxuxziortsEDPGOaWOVI1GTWNRHVSF65HocUYBH I5pwJZy2ML70m0E81lsdDIWAXgUzyyx445FWWQDoO1ESbnqlLQVi2gCRAUmaVjxiox1rneru dEdESAmoZfvDjvUoqvcyCNWY9BzTSu7A3pcsPzHgc0mny7jM7LhYkbBPfAJ/pXOzahdzvtEm xN+AqjtWzbp9n0SUgnlWXP1zW6o2V2cVWv8AZRFYnzCJD/F83581ZlP3zUVguIVP+yKfM2I2 PfIApW6HKtWUyNz9cc807bxVJrzyrlgVJXcRkdv84q7HIkqqVb8K1SaR0U5xWjE+tNbkVLtq JxihNHRfsU5Vx+dLpKY17TeP+XuH/wBGLUknNO0of8TzTv8Ar6h/9GLW8GcdeN9T61oooqzk seKqpAH0p4rMtNTNyPkVmwMkYq/G4ccOQfQivMlF3NkSU4VGd/8ACST6kcVIobjccnvxS2KV iC8+1C1k+xRCSfHyKzYGfrVW00gec9zexATMQVRTkR+2e9agFOSOWZxHCm5z0z0pxb6CZXjs 7aW8iCWgmnLYTIyR61Yj8I+ILC+mebVre8tHyyRrGEKHsMjrj+ldBZwR6ZG23D3Dfef+77Co 5JHdsnNddOkramctdjBm0rVM4SOL676ydT0vU4Ld5ZVURryxRs1009wsQPGWx61lXFy84IY5 Hpmn7GCFdnFiKC/h3wTGI5xyM5NYcjyQy7JGz94fiK3tXUm8b+ykjBDHzW/hJ9v0rEbTb2Vl afapGS2Oc1StENWQPNnv27VLZXL2upWcxBwsyg/RiAf51ai08oByT+FStp6vwxPUH8iD/SiU 01YSgd05BBI6Z4qnKAe4+maLS+juBDEEkLtGGJ2/KuAOCfWnvYwfaxd+V/pCo0YfJ+6eoxXi 1I2lqNla0vH0vU4b5WCiM4ckdE7/AMq9KbAH3sjAwfXivL722eUsGb90Y2Ro8feznnP04rrf D19JfaQqTsGMDmNfUAFsfyFTNJx0DRm0GMzZ4Cchh3NSFgB6VCHxUMkme9cybFYWabsKqs2a CxJ601mCqSTwPWtU+5SGTTxW8LzTOFjQZYn0qvpOnT3c41W7j2ll228RP+rTpn6nANV7ZTrd 350i/wDEvgk/d/8ATVx3+gzXRKM9zj2reMbas0ihPJkz9zj61HJ5kS5EDSey1IxcH5FwPXNJ vkIzk5q7XKQg810z5JX2JqlqE7WdnJNJFhQCAc9TjirpllJGG+ma4nxFqL3V0LXeTHFnIHTP y1UNXawN6GRLK9xM00hyznJ/E5/rTCMU4DApjNgEnoBk16dNcqtY527mbqs+1UgQ8s2W9hg1 FosPmarA/VBuB9+KzppzcXskpGNzkAH+7k4rf0BVUxM5IY57Z9a3S0JZs3GFuZiCQFAPH41Q vZWubYkA7UcCr80RuJL5Y32NtTa+M45NVRZEWsjGVmP93GBWTiNMZpL4JU1n+KWzcWY7hXP6 rU+nybLkZ/vYqt4mGbq0P/TNx+q007MbtYwjx+VThR5frzULcZ+lTwv+7INdMZEDSmKVRgip GpFIzzn8q1EPE6gNE44YcH0OaeH29Y2PoRzUWY2HXjHpUkahP9W5X6GlbzBNE6ODzscfWpA4 PAVqjSSXPMrEe4pSzE5Lk0BdDi21hu6Yz1qwk6eYgCYyQMmqhZQRxUvzOuFHJx+FJgi9BGJb 5gz7V3cnGas3gsbODzbm6MUZYKH2Z5NU0ikQq6SEMDk+9VLye6vnRZIhHtyCAcg+9cklrobR bRBdMsrExSCSMrw47ipIAAOBzUYhEaBAOAMU+M7WxWM9TtprS7JgTS96ftFNYVzN9zq3EZhi pbcdT9KrFcnmrsQCpgUnsNAx5pveh/pVW5vI7RcsSWPRR3qEm9im0kWywWMsSAoGTmsC/vvO Zo4zlQRz69DUV1dz3h3O21NuAg7cn/Gq74ArrpULas4a+JXwxHwDfcRjHV+1dDeEppsKdAzc /nn+tYdgmbpT6Gtu+bL20PoC38q1qdjii7u5JANlsfcYqG6/1Yye+an6RKPWqd8+1CO+APzr G2pojFL7pG45LHJ/Gpg8IhGAwlGfpVdOWP1qQDPWupLQxb1JIr6aMDd84A79atpeRS/7J44N Zh++fpSFQTn3FJwTNIVpRNNsE9e9SaV/yHNO/wCvqH/0YtZSuycAnGav6NcZ1zTgwP8Ax9Q/ +jFojGxbrcy1PrmijB9KKo5z5vgv/snzxW7SkqMYYCrSeJJCwE1kVG4AYcc5IH9a5y2LbYxv YfKKvOCrKOWJZcBRknkVzyjG1zVHbr90fLj2pc+9LGGEaFht4HX6VFJPjgda45WuXYnUb3C7 wue7cCpLxtUsxHFoa2rZYNcTyyjLD0UVkzqlwu2VFdfQ1Qaw05M5tFx6BiKqnoyZLTQ6K2k1 eS5DX80FvAh5VHDl/wAe1RXmoXBdo4VAXs++uXngtXOBDgA8fMeKg+zwqMBW/wC+zXR7UlJm 8WuXPzt178Vl6jfMXNrbSZbH7yT+77VSNvF1G8H/AHzTlRUHyjHek56DsIi7F2jgUhp5phNS pdyrCU09acTSAEmldDNjTbq5jtCY4lmiWQK6hwpVT1PvT7nXLSIeWAfOIO0Dk1kjTre4eNpd 4dGyGViOvr61btbCK0j2qQ2M/MRzXJVhGT1MpN3IJbu7uM4tCMDhmbGa0/Btw8N7qEM4IaYI 6jtlQ44/TNV4bcwQ7PNeTqdznnrU2nyeTq1ux+6SVP0PFTeKVkhHYmUnrUe/J6Uwt87DPQ4o X865HoxocT7ZrKnaTVr9tOtzmGPBuZFPbg7R7motd1Sa3eKwsTuvrhcqAMhF5+Y/kfrWlpJu LO1W2h0nEWcmQycsTnJPfvW9OF9bGiNGGOOKNYo4tiIMAfTipMHsKlVQRyACewpHhYjEbhW/ 2hkVb7FoQHC8nBpmfVs/hUiWsm0iaRG9x2pjQQopOegznNNMVzN1nUFsLBpTgMTtTnknrXAK WIyx3HufWtLXb77fqT7X3QwsVj/Ngaz8j3rrw9L7TM5saSaztXmKWhiRsNIRkjsAa0Sw6HjF czd3LS6jOXHCkKo9AAK7YmdiHGZA2O/NdF4aBMbFifvNtB7DJrAQ8thcnPX0rf0CTbE2f7x/ ma0loiTbtjm61BMgnyQV/AmqUN9MZ3triIKoTJcHPOOKtWID6jcuc7JIDGcfnWPFI0TbSNwP BJPNZPUaGK2y5yP72aj8Rnc9ifVH5/EVJLxIGHQmqmrSeZHaA9UDjP1xSjo9i90ZZ5BHtTRw cjipeD1HaonWuuytczJA+7v3qRWf1z7VXU/Px61YjzgVSYrD8sf4e3apV59qYOlO+lXoTsTK KdTFJp2c0mwS7jWq5ZglulUZMkHA7Vo2xK3YhIwTjH1rOo9C4LU0RCGB25FQNHtB4H1rUA2j Eh+f6VRvW6bVZcZzXJudSVzHPMhzUbDDj0p+cyZ9akZdwrnlZM7aa0HxtlaGqOM7TinsazaN kIoy2KsgYHFQRr1JHGOtNubhtjJC209N2Klxb2IdRR3Ir/UI7MqAd0pOQntzz+lc/vd5A0jF nbqaknQpKdzlyWJJP1NMXlhXbRpqKOCvXctEPA4/CmOM8VJjj8KYwya6DlLukpumz/t4/QVo 3Hz6gvoq/wCFQ6HF0GOS5P8AKpgN147dt1YVLXLgTsR8q+grK1CQnzPd1A/IVqv94+wrGvTv QNjuDWMFeRp0KUf3j9alqOPgn61IOTXYYMjYdfWk7c09qYrZJBoAMZ/OrWjADXtN/wCvuH/0 YtRRgbuema1tGhRta08hf+XmI/8AkRaYH1dmim5opAfOVv4GuYWRm1tmVQMKIR/OuntbSx0w EwwGSYjDSueaebjanG0ZHYiq7MT/ABV50q0paM6FFEk1y8rZbNVXfHJpHYD7zE/Sq0twcbcV la5WgTXG3pzVN5i3WlbBYmoWOTWqiuhA0tmmZpxFNIosFhM0neg5FNzzQ52AUmm0ueaTNCaY MSrFvESDIeg6VFFGZZQg61qFFRdqjis5tIUmRQY83HrVoSwi4FsWxMV3BcHkVTDbZkbphs1p AfIpIBOOtc0k9zPcjZcA1RleSO4hZV+USLuOeQNwrQbAzWf5kc83lowYhwCPQ5qYXuB2GQKr 3d4LWHciGSZztijH8THgfzqGe7jt0MkjcDkj0qXR9Kaac6tdy+XMwKwQkf6pCMH8TgH9Kbpp u5pFF7RtJksIWnnIe8n+aVsdO+0H0Ga1AzAVCFZiP9IYL3461ZBjwQrA/Wna2zNLWIix68Co hcwDI+1Lu/u5qyQv90EVVkt7Y/N5S7h7UcrYDsqejc+uaxtYkmWGWNbrO5GLKR0XbVqaTykZ j91R2rnrmzuNV+226TmDfD5k05XPlxheg9ziqp05X1E2cRe308PleQwUMCWBGfU1cgE39lpc 3T/v3yVT0GSOfwqE6e1xewqf+PaN9sj+wyOnvU9/IWYlV2xgYVuwr1YQtHQxb1K11cSxwM0e Ccd/rWTdDddPNnAkK5GOnAB/lVyWTzLfAYH5fmqKe3Ty1aQnBI46d/WtoK24m7kUlte2kkBv LSW2iuAXglPIkUdxWvokLCOSbzQUYlVT0IJ5roJ7e88Z+HfB2h2k6JNFb4UnHy4BDcnvjFZI tNOtdTvbLSmk+ywSeUryNkswHzH8yafMnoKxq6WjGGSQAnnOayLtBbxPIwJAIH1Jrd0Bf+JU Dk4KdfWsTX5FijQu21N35mp5QKbSbsE1W1Eho7dl5HzA5/CiJdRkQrDp7MjH5XZwP0plzZ39 tbq14qqu7C4OetSk0x3simwGOlNJwcU4dPwprd+a6baEXGDhs+9SqelRZpUbIB6UJ2Yi2vI/ CpgOOlQRHPftVmPmtk7iHDikzhqXHNNYHqKVhClgMHGatedu1EOqcqvPPT/OKzy+Kmsj+9kc nrioqLQuGhsjUbpjtHAXpmmy3k7RkSMMmq6yjcxDcZqGWTeODxXFPlR1002RHqDVhemajA3R j6U9D8tczaO+CshGT5gaQn1qTOahZvmxU7inJJA7lx5eflx0pp6HFOApSOtaI4ZycjFuxmY+ xqFV79+atTruuGx69KFTayjHUHNdUNjnluQ+1AQnoK0zCrWxyBnb1xVWBD5j4PGRV3RJqaUv lKW/u81HZbnK56nOamhzDZyt6nH4YFNtPkjJ74Nc1Rq5pEJX2xSP7VlXhz8g6itCfHk7fWsx wWkb60qO5UnoQIpHPvTgQTxU8aMzKrYxnip7iBVjyoxxXVdGBmHJJ+lN2nJqTaQ4bsR/WpXj J4A44pjIosk475rX0WTZrOnoev2mLJ/7aLVBE8sl2GOflFXdHGda04n/AJ+ov/Ri0gPrD8KK KKAPmmKJREuCw+UH73tTgHBP7x8fWqA01NigM4AUDhjTvsJH3ZpPzrinFNmydjQDydpGxnvS FnHVjVA2UueLmQc/WkFteL0vWx6FBR7FDUu5f8yQ/wDLQ0m6TJ+c1R8m/B4vPzjFO26gP+Xh D9UqXTY+YuF5O7H8qTc3r+lVv9O7mJh6YxTd18OiRn8aXI+wucs7mJ5YflRk5/8ArVWMl/0N qrDHUP8A/WprTX3awHb/AJaCj2cr6onmSLBZu2KjaRwRgZ/GofPuv47Fhz2cGm+dPuybST8x VKHkPmubunIywiRhh3AJB7VZcmqMDRX9tD5heJo9p25IIIHt1FW3kiUfNKB9a5auj1JZXfqa vqJpbZTFJ5TDBD4z+lZVxqFjEfmuR+AJq9od7Z34eNHdmi54yMA57fhUtNxEkWzu25J3HHJx 1qg7BJd+AMHNXLhfNt5HjeSMRk5YDBGPY9awLy/hZzGku5hjcScVEKbb0CxtafeWN1erNqFy ixwt8kbA8uO/4ZrpE1zS3A26hFz0rz9JrcDHmL+NTK9mcAPF9K0nRb2ZcXY9Bj1eyI4ukIqU ajbnGJI/zrz4Lakf8s6b5NswOQg+hrF0ZR6lcx6L9thPHnKPxprTxn/lsp9MNXA+TEwxvz7b qja2iwCOMdMMeKuNOT6j5jq9TnO7y+SuMuB39BVi+L6dpB0xf+Pi5/fXZHr/AAp+RrH0IJ5S SytvEP3WY9W4/wD11pzBrgu5O5jkk1004tKzJbOSlgWBSxyXkPI9uT/OqE8BmUqGAXnII61d uiHu5McgMQDn3IrPu34CgqMnnccDHeu+F1EykUljjkulXyAQIwofOARU14UCEtGPkK8A5Gad brmBpTbKsZPyDdwFwOntU39nTahaXC2+fMQBlUfxEHp+Qp7kXKVtqs+l2tyDIqm4zGnPKqcZ x6dKdpeILMhSTgHnPWtTwVajUrfWLqaziuLKK3I8yUYKSDb93v0NY1g3/Ev3MckoTTsrhzM7 Xw+caPAx53IGx+Vc5AmPEN8r5dchlDHIXIHT8q6XQ33aJbFgAREoIH0FYEyGPxJcYI+dQfpj t/n1p3KuaBYk9aoawu+wbvtYGrmar3w32M4/6Zt/I1CeojlcYH4Uh5FPQh4UPqopvSujoSRt mmqcMB9ae1Rk4YfjSYy3Ee1W0HcVnxvzV6JsLVQuDJC2KN2RxTWGaYrYbmtCBpHOaXzdi8A5 qU89ugqCX5gMjFJq+402W4gNgPrTpDhaijPyqPenyDIrgrRV9Duw8tLslgIKAe1TbMDJwFHU k1XjJVRtHNNlhaYje7HnpXO4GzrWCa8TlIeuepqETOfQ1MtqvvTxaJkdfzqlyIwlKUiETP2x SmZyDgA1YFqncmlFsuec4o54k2Zk4b7SCRks1XBb5dSzD3q19jiPqO/Wk+yRgdW/OtoV4mUo NjXRBGUV+o646VWCKhwpzUz2yDIyT9aiWBVbIp88ZdRKDLkx22Kr/eb+lMiGIenXNF2SRbp2 yT+hpZW8uKIDuDWUjRaFe4Iyq+i5qssPJO4c+tSyfvJmz93YB+ppVs426lvzqovkVyZO+gqR qCMkcelOnAkAVTgDrTxaoO5pDbIOjEVoqsO5Hs2U3hATGOgoRcHmrTW4PViagI2kg9BR7RPZ jUGVpMs5z0zV7RxjWdP/AOvqL/0YtU2HzHFXNIH/ABOtP/6+ov8A0YtWnoJqx9XUUUUyT5xC fKPpRszUo+6PpTEkBkZdpAHeuNtG4mym7SanyDzkGlAFHMgsQbKNtT8UmBSbQEO2jZU2KOKi 3YZFt96ULjpUn0pKp37iGY5z6UcinUYzVX7gRMoI5FQtEuc7R+VWitMMZPajlW4FIxDPShIW WZJYnaOVM7WU9M1aMR9KesLelD2sCdmLJeahOMT3W7jqEANUJltbcB7h1QFgMsO9aHlN7Upt VlGJEVh1wRmoXu7A3crLZwP1AIPt1qRdMtSMeSvvxVxIsY46VOqe1aKVhWRlto1h1e3BGMZq CDT9Ivrcy2yeZFkqSMjkdRXQAEDgVBJ5caECNVPsMVPPYLHNxaBYNGP3TA/3hIeafHo1rFKr KJcg/wDPRv8AGtSEful4I+tO2g0+cFFGzpxA02BMBQegA6nAq3q86afpG1QPPuWAAB5VOhP6 1RtJQtrZhkaR+oA6VUvlaW/kXqqNtJJzgYBojqxvQyGUqehqleWoeNOMNuySemPpWxP9mijE jTIF3FffI6is2a5VnSSIK8RBxnoa6r2RkyF1G1Ai5wuBg8YxW1of+sPybTnBBNYyMrSFmXjj GOMc1uaCpM0hJz85/may5rFJaHTyw29l4c1AW8Swp5DsQvTPHNeZWkKppaMTnKZxXpmpP5Hh 3UJJYxJGISTGDjevoT71w5Gn3Fiu6E2JK44bcFPShza1tch3NvRA0ekQ7zn92v8AIVi+KY5r G4i1CzZfNkURlGHpjnFdJptsRbIhIdI4wS/Tgd65XXr6W6dLgHDKxUDHQelaRlzIdjHOu6vn iGPGe60HWdTlR1eBPLZSCcdiKPt90TzKCM/3RUy3Er2khZgTnHTtijlXYfKUEwiBR0xQwySa XblfwppJFdCehnYYfQ+tR9wKkPPfvUZHNUMfGcVfiNUF9ParsBpR3BlkrkZqAgg5qwDnikdO K1uQrkaNk02XkfjTRwfwpw+YMB14osDZIhIWlMm7FNY4WmKfmFcdVGkGzSRRsXjsKeEGaRPu r9KkFedN6nQmN2ijbT8UmDUXTGJigUhVscNg0gV88uT+FO+g0h9I1Jz60MeKI+YyCSmRjdIB 7inP0/CltxmUVrDyIY26+e4C+gxx+NFwr4ADYAGKT/WX7egfH4Ckmf7xPof5VpsSVo8jqc1Z U1Wj4Az6VZU05N2BIkzSE0zd0xSFqxsUkDNVeRutSMary9K0gh2VtCIn5uvermkHOt6f6fao v/Ri1R5LH61c0j/kN6d/19Rf+jFrrijnlc+sKKKKYj51ToPpTgATRRXAjZikc00tiiihbjQZ 9hTWY0UU2BGZG6Zp2NwGSaKKQwCAc8/nSKSScmiiqEKenWkUknBoooEPyQaevzjBooqZDFc4 GKen3aKKaAcBk1IqiiiqYIftHFUW1CaPWYrJQnlOhYkjnjHf8aKKkTNQMSKqToJJV3Z4NFFL qUQMMdKTFFFWSdDooH2KIYHIFZbjbfXmP+e2P/HVoopLclmbHpttfXri4QurTFiM4wfbFZk9 skCSRKW2JNtQH+EEZxRRXXHYzISSsluB3AJ966TQeNxH94/zoorB/EavY1r92l0TVYGb5PLI GOo6Vx9wgjstq/wqRk9aKKJCNa1kc21tEGISTAYA9RgGsnxEAqOFUDbLgEfhRRV0twOeHX8a tR/8ekn1FFFbMRWU8H6Uxuh+ooorSJkyPufrQKKKtAhVHP4VZtz89FFJAXejUpJxRRVIRC4G CaZF95qKKp7EofJwPxqJeWFFFckzeBsJ90VIKKK8+ZohaKKKyLE/ipKKKZXQSmNRRQSQP3p9 v99/YUUVpAlkNrzOT33N/Wo5Cdn1oordDIV/pUyk0UU5CRIO31pp60UVmUxrVWl6GiiqgQty Edfxq5o5/wCJ3p3/AF9Rf+jFoorrRnLc+sMmiiimQf/Z ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: First flight N513J
Date: Jun 06, 2001
YEE-HAW!! Another RV-4 takes to the skies! C'mon Jim, write us a story about it! Don't leave out any details! -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Jim Baker [mailto:bakerje(at)kfalls.net] Sent: Wednesday, June 06, 2001 1:18 PM To: Rv4-List(at)Matronics.Com Subject: RV-List: First flight N513J Hi All, Just a quick note to let everyone know RV-4 Serial #1616 N513J has flown this morning by myself. flies GREAT!!! right wing just a touch heavy. Other wise what a DAY!!! Jim Baker Klamath Falls, Oregon ________________________________________________________________________________
Subject: Re: turbulence
Date: Jun 06, 2001
> >I am interested to know people's opinions on how RV's >"ride" in turbulence. I am dreaming of building a 7, >and i would like to be comfortable during light IFR, >especially if things were to get a LITTLE bumpy. > >Thanks > They ride hard. No doubt about it. The short, and VERY rigid wings don't flex so every bump is felt. When I hit rough air, the only way I've found to lessen the impact is to slow down. Interesting email address you have. Thought you were from Van's. Brian Denk RV8 N94BD 209 hrs. ________________________________________________________________________________
Date: Jun 06, 2001
Subject: my apologies regarding "turbulence"
I would like to clear up any confusion before it begins. I just posted a email to the list entitled "turbulence" from a yahoo account i set up to use strictly for the matronics list. Unfortuneately, I made a mistake in the registration, and my name on outgoing mail reads "Vans Aircraft". I have no connection to Van's, my name is Ian Jessen, as it should now correctly read on my emails. Again, I apologize for any confusion. Ian ________________________________________________________________________________
Date: Jun 06, 2001
When Larry Pardue and I were coming back from the cougar landing fly-in, we hit a little turb. I think the worst "bump was about +2G and -1.5G, it was not unbearable or uncomfortable. I was doing my best to emulate his nav-aid autopilot but kept wanting to climb, it was easy to recover from the bumps and as far as comfort, was no worse than any other aircraft I've flown. (Thanks again Larry, the grin is just starting to wear off!!!) Bill Ervin Artesia NM RV-6 Fus --- vans aircraft wrote: > > > I am interested to know people's opinions on how > RV's > "ride" in turbulence. I am dreaming of building a > 7, > and i would like to be comfortable during light IFR, > especially if things were to get a LITTLE bumpy. > > Thanks > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Subject: "Experimental" placement
Date: Jun 06, 2001
Hi, I have an RV-6 tipup project. I wanted to know if it is acceptable to put the "Experimental" label on the forward side of the rollbar. It would only be visible when the canopy is open. My alternate location is the rear wall of the baggage compartment. -Glenn Gordon N442E (reserved) ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: Engine Sag
Garry LeGare wrote: I've had a number of people inquire about the bullets and how to raise the engine, so I'm sending my response to Paul Besing to the list. > Bullets are bolts with the ends ground down to a gentle taper, then > polished. The washers are just hardware store large area washers they > were almost an exact match for the ones that came with the rubbers. > I installed them by taking the weight off the lower mounts by loosening > the bolts, then lifted the airplane by the engine lift strap until I > could just move the existing washer slightly. Then I took out the bolts, > one side at a time, and slid the bullet in place, lifted the engine a > little more, ( on my straight 6 the wheels were getting real light) > forced the edge of the new washer in until it hit the bullet. Then I > slid the bullet carefully out just enough to let the washer be forced in > place. Once the washer was roughly in place, I used a small hammer and > knocked the bullet all the way in. I then lowered the engine until it > was resting firmly on the mount rubber to seat the washer properly. Then > the bullet was removed and the bolt put in place, with the nut just snug > against the engine. Do the same for the other side tighten the nuts and > your done. > I was really dreading doing this but the biggest problem was all the > stuff in the way . Once I got a clear path to the mount it only took > about 30 minutes to do both sides. > Hope this helps. > Garry RV6 N297DG Feds are here on 21st. Can't believe I'm almost there. > > ________________________________________________________________________________
Subject: Re: "Experimental" placement
Date: Jun 06, 2001
Check out FAR 45.23(b). It states that the "operator shall also display in that aircraft near each entrance to the cabin or cockpit, in letters not less than 2 inches nor more than 6 inches in height, the words....."experimental"....., etc. In other words, as long as the passenger can see the placard upon entry to your aircraft it meets the provisions of the regs. Mike Robertson Das Fed RV-8A >From: "Glenn & Judi" <foxinsocks(at)mediaone.net> >Reply-To: rv-list(at)matronics.com >To: "rv-list" >Subject: RV-List: "Experimental" placement >Date: Wed, 6 Jun 2001 18:18:15 -0500 > > >Hi, >I have an RV-6 tipup project. I wanted to know if it is acceptable to >put the "Experimental" label on the forward side of the rollbar. It >would only be visible when the canopy is open. My alternate location is >the rear wall of the baggage compartment. > >-Glenn Gordon >N442E (reserved) > > ________________________________________________________________________________
Date: Jun 06, 2001
That's where mine is, and I don't anticipate any problem with the Feds. Rules read something like " must be visible upon entry". Hey Mike jump in here, your the man. Garry RV6 Almost Glenn & Judi wrote: > > Hi, > I have an RV-6 tipup project. I wanted to know if it is acceptable to > put the "Experimental" label on the forward side of the rollbar. It > would only be visible when the canopy is open. My alternate location is > the rear wall of the baggage compartment. > > -Glenn Gordon > N442E (reserved) > ________________________________________________________________________________
Subject: Re: "An Illustrated Guide To Engine Hanging"
Date: Jun 06, 2001
06/06/2001 04:49:33 PM, Serialize complete at 06/06/2001 04:49:33 PM I just happened to be thumbing through AC43.13 last night and ran across this. It says you should tighten up to the max torque spec at the most to line up the slot for the cotter pin. The correct thing to do would be to set the torque wrench to the min spec, torque the bolt, then set the wrench to the max spec and turn the bolt a little bit at a time and hope it lines up before the wrench clicks (if you are using a click type). Scott "Randy Lervold" <randy@rv-8.com> Sent by: owner-rv-list-server(at)matronics.com 06/06/2001 08:20 AM Please respond to rv-list To: cc: Subject: RV-List: Re: "An Illustrated Guide To Engine Hanging" An excellent article and a great resource for all builders... thanks guys. I would like to correct the first sentence in section 3 however... I installed mine *by myself* in 45 minutes without much problem. It's not that I'm macho or especially talented, just used the proper hoist and the techniques detailed in the article. It was Christmas eve day and I wasn't about to roust any of my friends out of their nests. The point is, if you have the right engine hoist it can be done solo. Second, don't forget those cotter pins! Now here's something you might want to add to the article that I don't know the answer to. First you torque the mounting bolts, then you insert the cotter pins. If the slots in the bolt don't line up with the holes exactly (they won't), then do you tighten more, or loosen slightly? Perhaps those knowledgeable in this area could provide an answer for us, and maybe this would make a good addendum to the article. Third, after installing your engine you may want to check to see if the thrustline is level. I checked into this a bit and have posted some info on my site... http://www.rv-8.com/Engine.htm BTW, at 33 hours my engine has not sagged at all using the standard mounts... still waiting. Maybe I need to go out and pull some Gs. Randy Lervold RV-8, N558RL, 33 hrs, taking right wing off to repair tank leak www.rv-8.com Home Wing VAF > Jim Norman submitted a wonderfully written illustrated article to me for > the VAFWWW web site on how to hang your engine. > > >From Jim, "Here is what we believe to be the best engine hanging article > in existence... not that hard a claim since we can't find even a poor > one! We think this method is fool-proof, and it works on all RV types. > It is self explanatory. I am the principle author, but the expertise > comes from 5 people, all of whom are listed as authors and should be > given credit (as written in the text of the article)." > > Read it at http://www.vansaircraft.net . > It's the top story today. > > Best regards as always, > > Doug Reeves > Van's Air Force - World Wide Wing > RV-6 standard kit (fuselage) ________________________________________________________________________________
Date: Jun 06, 2001
> > I am interested to know people's opinions on how RV's > "ride" in turbulence. I am dreaming of building a 7, > and i would like to be comfortable during light IFR, > especially if things were to get a LITTLE bumpy. > I noticed Bill Ervin responded to this from having ridden in my airplane. The thing is it never got very bumpy that particular day. My own opinion is the RV is the roughest riding airplane I have experienced. I believe it is the combination of high speed and low wing loading that does it in. Trouble is those are the two attributes we also love about RV's. No way around it. Like Brian, I have found the only remedy is to slow down and on summer afternoons I sometimes slow down to 110 knots indicated. I don't think I'm really a wimp about turbulence, my primary concern is getting knocked out on the canopy. I have never worried about the airplane structurally. I don't think of this as so much an IFR problem as a summer in the Southwestern US problem. The airplane is not difficult to control in these conditions, it is just real uncomfortable. I know from glider experience that 1,200 fpm thermals are not uncommon here. Those thermals can have very sharp edges. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: Wives & RV costs
You are a very lucky man. Hang onto you wife at all costs Jim Streit 90073 wings Gary Zilik wrote: > > My wife was most important in building our RV. Everything went on the > credit cards and she paid them faithfully at the end of each month. I > would order, she would pay. I don't know how she did it but we never > went in debt to build the RV. She also shot all the rivets in the wings > and fuselage and jumps at the chance to go flying. We just finished a > trip to the Bahamas and her favorite part was the flying. > > Gary Zilik > ________________________________________________________________________________
Date: Jun 06, 2001
From: "James R. Paynter" <jpaynter(at)cyberg8t.com>
Subject: So California
Ernst, This may a little late, but hopefully not! EAA Chapter 448 at Cable airport in Upland, CA has about 12 RVs under construction and another 6 or so flying. This weekend (June 9 & 10) is Young Eagles day at 8:00 am. Some of the flying RV guys usually give some of the rides. Cable airport is located about 40 miles east of downtown Los Angeles and 3 miles north of the I-10 freeway. EAA Chapter is located on the north side of the field. Feel free to stop in. Jim Paynter/Debbie Rothe RV-9A Empennage ________________________________________________________________________________
Date: Jun 06, 2001
Subject: RV-List: "Experimental" placement > > Hi, > I have an RV-6 tipup project. I wanted to know if it is acceptable to > put the "Experimental" label on the forward side of the rollbar. It > would only be visible when the canopy is open. My alternate location is > the rear wall of the baggage compartment. > > -Glenn Gordon > N442E (reserved) > Glen, FWIW, I placed my "Experimental" placard on the underside of the part of the tilt up forward of the instrument panel. Its very visible while the canopy is open so a passenger can not miss it and hidden when the canopy is closed. Ed Anderson RV-6A N494BW ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Panel Pilot?
Listers, I've been trying to contact Steve Davis of Panel Pilot for several weeks now with no success. Does anyone know what is up? Thanks Brian Eckstein 6A Flying ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: Panel Pilot?
Just received a note from him tonight !! Len Leggette RV-8A N901LL (res) Plumbing & Wiring ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: Antena wing tip or not
In a message dated 06/06/2001 9:43:49 AM Pacific Daylight Time, bertrv6(at)yahoo.com writes: > Hi: > > Would like to hear from the list,about the Nav > antena on the wing tip. (better to have one on each > tip or is not necessary? Comments? > > Name of company where to buy them,and address > e-mail or phone. Besides ACS.... > > Thanks, > > Bert > rv6a > Look in the yeller pages for Sportcraft Antennas, or Bob Archer. With a single NAV radio, just a single NAV antenna is needed. With Dual NAV radio's, you can use a splitter from one NAV antenna, or use dual NAV antenna's (one antenna to each radio.) Jim Ayers Less Drag Products, Inc. LessDragProd(at)aol.com ________________________________________________________________________________
Date: Jun 06, 2001
----- Original Message ----- From: Randy Lervold Sent: 6/6/01 12:24:37 PM Subject: Re: RV-List: Engine Sag -- RV-List message posted by: "Randy Lervold" randy@rv-8.com With about 1 hour total time on my engine only by running on the ground, it seems my engine sag is very apparent. It appears to have dropped 1/4". I haven't even flown yet. Any builders notice this just from ground running? Should I shim now, or fly then shim? Paul Besing RV-6A 197AB Arizona http://www.lacodeworks.com/besing Taxi Testing My engine was mounted with an extra bottom washer to allow for possible sag. Engine was mounted and torqued for at least a year before flight. After 200 hours operation, including fairly regular G loading to 4 or so, the engine never moved. Finally removed washers for better engine cowl alignment. (Washer removal equaled about .250 at spinner base plate) In your case Paul, I wonder if the engine mount rubber biscuits are in the right place, properly aligned, and torqued. This seems to be one of those areas that varies a good bit from builder to builder. Dick Sipp RV-4/ O-320/ CS prop 215 hours ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Paint Booth Ventilation
I'm building a small, collapsable paint booth in my garage, strictly for priming (no finish painting). The booth will be fairly small (8' by 8' by 7' tall), and I'll be bringing in air through a positive pressure mask (home made). For this purpose, will I need a ventilation fan, too, or can I count on the exhaust air from the mask driving out fumes? (The mask pumps quite a lot of excess air.) I plan to have an exhaust vent running out the top of the booth to the outside. Tedd McHenry Surrey, BC ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Fus Jig & Inst.
RV6 fuselage jig needs to be rescued before it becomes firewood, well built, straight with 5 aircraft to its credit. Free Also have several extra gages I would like to pass on Directional Gyro, Piper, Model 99003-7, Core, $100.00 OBO Airspeed Indicator, Cessna (0-180 mph), Core (Loose Needle) $20.00 Airspeed Indicator, American Aviation, Model 7SCF005-1, (40-200 kts) dual scale, New, $175 Cessna Suction Gage, Cessna, 2.25 inch, 0-10 in/hg, used-working, $25.00 Suction Gage, 2.25 inch, 2-8 in/hg, New, $50.00 Artifical Horizon, Cessna, Aeritalia, core $100 OBO Artifical Horizon, Beech craft Model 300-3BCF Tso-C4c, Yellow Tagged, $300.00 Directional Gyro w/Auto Pilot input, Aviation Inst. Corp, Model 200-9M TSO C5c Type 1, working when removed, $200.00 OBO Course Selection Indicator( CDI ), King Inst. Model KI-211c, Yellow Tagged, $400.00 OBO Mark Delano Littleton, CO 6A interior paint ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: Paint Booth Ventilation
In a message dated 6/6/01 11:32:32 PM Eastern Daylight Time, tedd(at)vansairforce.org writes: > I'm building a small, collapsable paint booth in my garage, strictly for > priming (no finish painting). The booth will be fairly small (8' by 8' by > 7' tall), and I'll be bringing in air through a positive pressure mask (home > made). For this purpose, will I need a ventilation fan, too, or can I count > on the exhaust air from the mask driving out fumes? (The mask pumps quite a > lot of excess air.) I plan to have an exhaust vent running out the top of > the booth to the outside. > > Tedd McHenry > Surrey, BC > It depends. If the booth is for priming a few small parts at a time, you could get away without a forced exhaust. If you're priming more than a few small parts, you'll be surprised at how quick spray mist will interfere with visibility. I'd probably go with at least one box fan in your case. You can catch most of the overspray if you put a cheap HVAC type filter in front of the fan. When I painted my airplane in the garage, I had 3 box fans exhausting air, and had plenty of incoming air. After one pass around a wing or the fuselage, the garage definitely got "foggy". After a couple of minutes, the fog would clear, which provided a much beter view of the runs, curtains, drips, and critters in the paint... Kyle Boatright - Kennesaw, GA RV-6 Slider, O-320/Aymar-Demuth ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Re: Making it easy to jump start your RV
To all listers: Thanks for all the great ideas. I went out to the airport and saw exactly what I need to do. Go to: http://solanopilots.com/quickjumpsolution.htm for some photos and dialogue of what I found. An easy set up, no fabrication necessary. Just an adapter for a stock Piper jump system. The product is called PLUG & JUMP. I have a link to the website for the product. The distributor is an RV4 builder, Jeff Sharman. He is excited about the use of his product in experimental A/C. Jeff even mentioned a discount for those of us who mention the list or Van's. Again, Thanks for all the input. I saw some really nice work and the support you all lend when all of us brain dead need some ideas is appreciated. Dave Aronson RV4 N504RV Finishing cowling (whew) "Michael J. Robbins" wrote: > > > There is a photo of my external power plug that I made on Randy > Lervold's web site > http://www.rv-8.com/MikeRobbins.htm. Very light and cheap. My battery > is on the firewall so it's easy to connect, but you could run longer > wires from an aft mounted battery. Let me know if you want further > details; I can email more photos. > > Mike Robbins > RV8Q 80591 wiring (almost finished after 6 months!!) > Seattle area > > ----- Original Message ----- > From: David Aronson <aronsond(at)pacbell.net> > > Listers: > > I am trying to figure out the best way to design an easy way to gain > > access to the electrical system (without getting to the battery) for > > emergency jump starts. > > > Dave Aronson > ________________________________________________________________________________
From: "Nancy Jean Burkholder" <nancyb(at)mninter.net>
Subject: help with rudder pedal rework
Date: Jun 07, 2001
I would like to hear from folks who have modified the rudder pedals per Van's Aircraft direction to add the gusset plates. How hard is it to remove the pedals in an RV-6 with overhead pedals? Any tips or suggestions for how to do the job? Thanks, nancy b. "Good people are always so sure they're right." Barbara Graham's last words Executed June 5, 1955 at San Quentin ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Re: RV4-List Digest: 2 Msgs - 06/06/01
RV-4 N5361U is for sale. Priced for a quick sale at 33K obo. http://www.vintageaviation.com pilot(at)coolbiz.com ________________________________________________________________________________
Subject: Steering links and mail fraud
Date: Jun 07, 2001
Listers, Before I get accused of participating in mail fraud, I need to explain something. I sent out a whole whack of steering links via efficient Canada Post. I test weighed a package at our local outlet and then sent the balance out with that postage. Guess what? After 12 days I get a notice that there was insufficient postage and they were not delivered. Garry LeGare's made it to the destination after aprox 14 days of travel. It's not called snail mail for nothing. I am in the process of re-shipping via FedEx. All listers who have sent me money will be receiving their package shortly. Please be patient. I don't want my first attempt at selling stuff to fellow RV'ers to leave a sour taste. Terry Jantzi Kitchener ON -- <http://www.iwantarocket.com> <http://www.netrover.com/~tjantzi/terry/> Home Page <http://www.ontariorvators.org> VAFOW ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Re: help with rudder pedal rework
In a message dated 6/7/01 6:23:00 AM Eastern Daylight Time, nancyb(at)mninter.net writes: > I would like to hear from folks who have modified the rudder pedals per > Van's Aircraft direction to add the gusset plates. How hard is it to > remove the pedals in an RV-6 with overhead pedals? Any tips or > suggestions for how to do the job? > > Thanks, > > nancy b. It is a real pain. If you have the NACA vents in the recommended location, there is no way to get the intact pedal assembly (both pedal weldments and the UHMW blocks) out in one big assembly. Instead, you have to dissasemble (and later reassemble) the entire assembly while working in the footwell. It'll take about 30-45 minutes to remove the assembly, probably twice that to reinstall it. Here's how: 1) Get prepared... A helper to hand you tools and collect parts as you disassemble things. Get plenty of light. Get all of the tools you need. Remove whatever it takes to get down in the floorboards (seat cushions, sticks, center panel support, etc.) Consider removing the canopy to give yourself more room to thrash around without damaging anything. 2) Disconnect all the rudder cables, brake cylinders, etc. from the pedal weldments. You don't need to pull the brake cylinders out of the airplane, or disconnect them from the hoses, just shove them out of the way. You may want to remove the brake pedals, because once the brake cylinders are disconnected, the brake pedals flop around a bit. 3) Unbolt all three of the UHMW bearings the pedals ride in. Remove the center bearing. 4A) If you don't have the NACA vents mounted right above the rudder pedals, you should be able to work the pedals assembly around and get one of the end UHMW blocks off, which will allow you to pull the weldments out one at a time. If the NACA vents are in the way, skip this and go to 4B. 4B) If you're working around the NACA vents, you will need to take advantage of the fact that the fuselage widens significantly as you move aft from the rudder pedals. Slide the entire pedal assembly as far aft as it will go. What you want to do is move the assembly so far aft that the aftmost weldment is touching the next bulkhead (the little vertical ones in the footwell (F-602??). At this point, you can flex the fuselage side out, and get one side of the aftmost pedal weldment to come out of its UHMW block. Once you get this done, the weldment can be jockeyed around enough to remove it from the footwell. Next, slide the other weldment (with UHMW blocks still attached) as far aft as possible. Rotate the UHMW blocks 180 degrees so you can slide the second weldment right up to the F-602. Again, flex the fuse side, pop the weldment out of one of the UHMW blocks, and everything will come out. 5) Reverse this procedure to reinstall. 6) Buy your helper a frosty beverage. Have two yourself. Kyle Boatright - Kennesaw, GA RV-6 Slider, O-320/Aymar-Demuth ________________________________________________________________________________
Date: Jun 07, 2001
I'd like to add one word of caution to this thread. I've discovered in my 11 years of building two airplanes that it is easy to get caught in the trap of over-engineering problems. I know that on my airplane, I've done it in a couple of areas and after flying for a year, I wish I'd just kept it simple. In reality, if you keep up on the maintenance of your battery it won't fail you without some advance warning. When I looked at the complexity, additional wiring, weight, the increased risk of causing a short circuit, and the rare number of times that I would ever use it, I chose not to do it. I'm not slamming anyone who has done this, and I know that it can be done without too much difficulty. If you want to do it, by all means go for it, fly, and be happy. Sometimes it just helps to step back for a second and ask your self the question "Do I really, really need to do this?". Randy Pflanzer N417G RV-6 (150 hours) >> Listers: >> I am trying to figure out the best way to design an easy way >> to gain access to the electrical system (without getting to >> the battery) for emergency jump starts. ________________________________________________________________________________
Subject: RV-4 vs. RV-8 cockpit dimensions
Date: Jun 07, 2001
Oops, the columns looked good when I sent it, but they were goofed up when received from Rv List (at least on my screen). The first column is RV4 and the 2nd is RV8. I tried fixing it up below so it's readable. There were several inquiries asking what I decided, so I'll respond to the list to save time. I have decided to stick with the 4. I actually had a deal set up with Van's last month to buy the RV8QB they were going to display at Osh this summer, to save $1500 shipping ( I live an hour's drive from Osh). Shortly after it was arranged they canceled it saying they can't get a kit. I have a feeling we'll see a RV-7A QB on display up there, which makes more sense for them than an 8. That, combined with the cockpit measurements, and no one interested in my 4, I decided to keep the 4 and finish it. One of the main reasons I wanted the 8 was the perception of a bigger back seat. Turns out there's not much difference except width, and width is not a problem. I'm 6' 175 lbs and the 4 fits me fine. Plus I like the looks of it better than the 8. I am thinking about putting in a baggage compartment between the inst panel and firewall like the 8 has, then I can balance it better to carry more rear baggage and more rear seat weight if I want to give a bubba a ride. One big advantage of the 8 that I like is the CAD design. The drawings are much better than the 4 and the parts should fit together much better. Bob > In the course of deciding whether to switch from my half built RV4 to a > half built RV8 QB, I couldn't find any interior cockpit dimensions for > the 8. So I paid a visit to Dick Martins in April and took some > measurements of his 8 - in case anyone is interested: > > > 4 8 > Width - Shoulder room > Inside the rails - front 22 24.5 > - rear 22 24.5 > > Width - total > Between side walls at frt seat 26.5 31.5 > > Length > Top of inst panel to top of frt seat back 57 58 > Top of frt seat back to top of rear seat back 26 25 > > > Bob Reiff > RV4 #2646 still building > Reiff Preheat Systems > 262-968-2342 > www.ReiffPreheat.com > > ________________________________________________________________________________
Subject: Re: RV-4 vs. RV-8 cockpit dimensions
Date: Jun 07, 2001
> One big advantage of the 8 that I like is the CAD design. The drawings are > much better than the 4 and the parts should fit together much better. Better than the 4? Come on...surely you jest. Bill -4 wings ________________________________________________________________________________
Subject: Re: First flight N513J
Date: Jun 07, 2001
Jim, CONGRATULATIONS & WELL DONE !!! Chuck & Dave Rowbotham RV-8A ( finishing Elec this weekend) Niantic, CT (Westerly airport) >From: "Jim Baker" <bakerje(at)kfalls.net> >Reply-To: rv-list(at)matronics.com >To: "Rv4-List(at)Matronics.Com" >Subject: RV-List: First flight N513J >Date: Wed, 6 Jun 2001 13:18:25 -0700 > > >Hi All, > >Just a quick note to let everyone know RV-4 Serial #1616 N513J has >flown this morning by myself. flies GREAT!!! > >right wing just a touch heavy. Other wise what a DAY!!! > >Jim Baker >Klamath Falls, Oregon > > ________________________________________________________________________________
Date: Jun 07, 2001
Subject: insulation
Thanks everyone who responded to my previous question, and hopefully my email is now sending out the correct name. I have another question. I have noticed, while glancing through builders pages, that almost no one has installed any sort of insulation. What do people think of the noise level in an RV (with a passive headset, of course) and what experiences do people have in cold weather flying? Is sidewall fabric and a couple of heater muffs acceptable? Thanks, Ian Jessen ________________________________________________________________________________
Date: Jun 07, 2001
This might be interesting: http://www.hroads.net/~john/rvmain.htm#toolsprimebooth john.bright(at)bigfoot.com > > I'm building a small, collapsable paint booth in my garage, strictly for > priming (no finish painting). The booth will be fairly small (8' by 8' by > 7' tall), and I'll be bringing in air through a positive pressure mask (home > made). For this purpose, will I need a ventilation fan, too, or can I count > on the exhaust air from the mask driving out fumes? (The mask pumps quite a > lot of excess air.) I plan to have an exhaust vent running out the top of > the booth to the outside. > > Tedd McHenry > Surrey, BC ________________________________________________________________________________
Date: Jun 07, 2001
Randy: Thanks for the input. I, like others, think that everyone should have an opinion. Being as human as the next, I want to have the convenience of an easy remedy for simple human error like not turning the master switch off. Simple as that! Again, thanks for all of the lister's input on this thread. For those that would like to see what I think will work for my aircraft, go to http://solanopilots.com/quickjumpsolution.htm. I have put some pictures of Jeff Sharman's RV4 and his approach to the convenience of having an easy jump capability. Dave Aronson RV4 N504RV Cowling finally done! N rpflanze(at)iquest.net wrote: > > > I'd like to add one word of caution to this thread. I've discovered in my 11 > years of building two airplanes that it is easy to get caught in the trap of > over-engineering problems. I know that on my airplane, I've done it in a couple > of areas and after flying for a year, I wish I'd just kept it simple. > > In reality, if you keep up on the maintenance of your battery it won't fail > you without some advance warning. When I looked at the complexity, additional > wiring, weight, the increased risk of causing a short circuit, and the rare > number of times that I would ever use it, I chose not to do it. > > I'm not slamming anyone who has done this, and I know that it can be done without > too much difficulty. If you want to do it, by all means go for it, fly, and > be happy. Sometimes it just helps to step back for a second and ask your self > the question "Do I really, really need to do this?". > > Randy Pflanzer N417G > RV-6 (150 hours) > > >> Listers: > >> I am trying to figure out the best way to design an easy way >> to gain access > to the electrical system (without getting to >> the battery) for emergency jump > starts. > ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Simple vs complex
Ocassionally a real nugget of truth makes its way onto the list. Randy's post is certainly one of those messages that needs to be carefully considered by all current builders, and I encourage all new builders to clip his post and pin it to the wall of the shop! Often I am amazed at the complexity that is being engineered into some RVs. I fully realize and appreciate the "experimental" nature of our aircraft and the latitude that is afforded us to incorporate any bells and whistles we wish in our projects. However, it seems there is a prevailing mind set among many builders that complexity is good. To these builders, the inclusion of as many guages, instruments, switches, avionics, custom circuits, relays, servos, trick trap doors, extra electrical outlets, eye-searing lights, plush upholstery, etc, etc, etc, means that they have attained the pinnacle of custom aircraft building. The reality of these pursuits, as Randy pointed out, is that after a couple of years of flying, a couple of labor-intensive annuals, and many, many hours tinkering with the superfluous gadgets, many builders will be casting longing eyes at the planes that were built with a simpler philosophy and seem to spend more time in the air. Van hisself has always considered his planes to be at their best when they are built light and simple. The new RV-7 demo plane is by far the most complex factory plane in existance, and I suspect it was built more as a marketing tool than a true expression of Van's "simpler is better" philosophy. In spite of the RV-7's nice panel, it is far simpler than some of the planes now being built. I realize the impact of seeing folks drooling over a "loaded" plane at a flyin is a real factor in many builders' desire to "out-engineer" everyone else. I just wish all builders could fly back-to-back two identical RVs, one being 100 pounds lighter than the other. The climb performance and control feel difference is remarkable. But the biggest difference between complex and simple is the amount of tinker-time required to keep the plane in the air. Tinker-time is good if you love tinkering; it is not so good if you rather spend most of your time flying. It is ironic that many of us run from certificated aircraft because we tired of trying to keep everything working at the same time. We then load up our RVs with the same systems............ Sam Buchanan (RV-6, 174 hrs) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ==================== rpflanze(at)iquest.net wrote: > > > I'd like to add one word of caution to this thread. I've discovered in my 11 > years of building two airplanes that it is easy to get caught in the trap of > over-engineering problems. I know that on my airplane, I've done it in a couple > of areas and after flying for a year, I wish I'd just kept it simple. > > In reality, if you keep up on the maintenance of your battery it won't fail > you without some advance warning. When I looked at the complexity, additional > wiring, weight, the increased risk of causing a short circuit, and the rare > number of times that I would ever use it, I chose not to do it. > > I'm not slamming anyone who has done this, and I know that it can be done without > too much difficulty. If you want to do it, by all means go for it, fly, and > be happy. Sometimes it just helps to step back for a second and ask your self > the question "Do I really, really need to do this?". > > Randy Pflanzer N417G > RV-6 (150 hours) ________________________________________________________________________________
Date: Jun 07, 2001
Bob: Great info! But with all that room in the 8, I think that it would become cluttered with beer cans and potatoe chip bags! The 4 doesn't allow such buildup of waste materials during a long flight! Dave Aronson RV4 N504RV Cowl finally done Bob Reiff wrote: > > > Oops, the columns looked good when I sent it, but they were goofed up when > received from Rv List (at least on my screen). The first column is RV4 and > the 2nd is RV8. I tried fixing it up below so it's readable. > > There were several inquiries asking what I decided, so I'll respond to the > list to save time. > > I have decided to stick with the 4. I actually had a deal set up with > Van's last month to buy the RV8QB they were going to display at Osh this > summer, to save $1500 shipping ( I live an hour's drive from Osh). Shortly > after it was arranged they canceled it saying they can't get a kit. I have > a feeling we'll see a RV-7A QB on display up there, which makes more sense > for them than an 8. > > That, combined with the cockpit measurements, and no one interested in my 4, > I decided to keep the 4 and finish it. One of the main reasons I wanted the > 8 was the perception of a bigger back seat. Turns out there's not much > difference except width, and width is not a problem. I'm 6' 175 lbs and the > 4 fits me fine. Plus I like the looks of it better than the 8. I am thinking > about putting in a baggage compartment between the inst panel and firewall > like the 8 has, then I can balance it better to carry more rear baggage and > more rear seat weight if I want to give a bubba a ride. > > One big advantage of the 8 that I like is the CAD design. The drawings are > much better than the 4 and the parts should fit together much better. > > Bob > > > In the course of deciding whether to switch from my half built RV4 to a > > half built RV8 QB, I couldn't find any interior cockpit dimensions for > > the 8. So I paid a visit to Dick Martins in April and took some > > measurements of his 8 - in case anyone is interested: > > > > > > 4 8 > > Width - Shoulder room > > Inside the rails - front 22 24.5 > > - rear 22 24.5 > > > > Width - total > > Between side walls at frt seat 26.5 31.5 > > > > Length > > Top of inst panel to top of frt seat back 57 58 > > Top of frt seat back to top of rear seat back 26 25 > > > > > > Bob Reiff > > RV4 #2646 still building > > Reiff Preheat Systems > > 262-968-2342 > > www.ReiffPreheat.com > > > > > ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Re: Simple vs complex
Sam: Complex or simple, I don't think can be considered right or wrong. It is the beauty of what we are all doing! The freedom to express our concepts in the building of these aircraft. Your input is always welcome! Thanks Dave Aronson RV4 N504RV Cowling finally done! Sam Buchanan wrote: > > > Ocassionally a real nugget of truth makes its way onto the list. Randy's > post is certainly one of those messages that needs to be carefully > considered by all current builders, and I encourage all new builders to > clip his post and pin it to the wall of the shop! > > Often I am amazed at the complexity that is being engineered into some > RVs. I fully realize and appreciate the "experimental" nature of our > aircraft and the latitude that is afforded us to incorporate any bells > and whistles we wish in our projects. > > However, it seems there is a prevailing mind set among many builders > that complexity is good. To these builders, the inclusion of as many > guages, instruments, switches, avionics, custom circuits, relays, > servos, trick trap doors, extra electrical outlets, eye-searing lights, > plush upholstery, etc, etc, etc, means that they have attained the > pinnacle of custom aircraft building. The reality of these pursuits, as > Randy pointed out, is that after a couple of years of flying, a couple > of labor-intensive annuals, and many, many hours tinkering with the > superfluous gadgets, many builders will be casting longing eyes at the > planes that were built with a simpler philosophy and seem to spend more > time in the air. > > Van hisself has always considered his planes to be at their best when > they are built light and simple. The new RV-7 demo plane is by far the > most complex factory plane in existance, and I suspect it was built more > as a marketing tool than a true expression of Van's "simpler is better" > philosophy. In spite of the RV-7's nice panel, it is far simpler than > some of the planes now being built. > > I realize the impact of seeing folks drooling over a "loaded" plane at a > flyin is a real factor in many builders' desire to "out-engineer" > everyone else. I just wish all builders could fly back-to-back two > identical RVs, one being 100 pounds lighter than the other. The climb > performance and control feel difference is remarkable. > > But the biggest difference between complex and simple is the amount of > tinker-time required to keep the plane in the air. Tinker-time is good > if you love tinkering; it is not so good if you rather spend most of > your time flying. > > It is ironic that many of us run from certificated aircraft because we > tired of trying to keep everything working at the same time. We then > load up our RVs with the same systems............ > > Sam Buchanan (RV-6, 174 hrs) > "The RV Journal" http://home.hiwaay.net/~sbuc/journal > > ==================== > > rpflanze(at)iquest.net wrote: > > > > > > I'd like to add one word of caution to this thread. I've discovered in my 11 > > years of building two airplanes that it is easy to get caught in the trap of > > over-engineering problems. I know that on my airplane, I've done it in a couple > > of areas and after flying for a year, I wish I'd just kept it simple. > > > > In reality, if you keep up on the maintenance of your battery it won't fail > > you without some advance warning. When I looked at the complexity, additional > > wiring, weight, the increased risk of causing a short circuit, and the rare > > number of times that I would ever use it, I chose not to do it. > > > > I'm not slamming anyone who has done this, and I know that it can be done without > > too much difficulty. If you want to do it, by all means go for it, fly, and > > be happy. Sometimes it just helps to step back for a second and ask your self > > the question "Do I really, really need to do this?". > > > > Randy Pflanzer N417G > > RV-6 (150 hours) > ________________________________________________________________________________
Date: Jun 07, 2001
An additional tip: Once you've done the job of removing the pedals, you can saw the outer UHWM blocks in two just like the center support. Then you place a spacer washer in between the upper and lower halves just like the installation of the center support block. This makes the job much easier to reinstall, and do future maintainence. By the way, I have most of the stuff already installed in the cockpit, and I did not have that much trouble. I just took it slow. I did not even scratch the paint. Regards, David ________________________________________________________________________________
Date: Jun 07, 2001
My personal experience from the back-seats in both the 4 and 8 is that you 'sit' in the 8 and you 'wear' the 4. I'm only 5'11" so I fit easily in both (front and back) and enjoy both equally. When I fly (or come along) I don't need to walk around alot anyway, so the room in both is ample - except maybe the flap lever in the -4 can be annoying if the passenger don't remember to pull the foot away from the left footwell on approaches. Are RV-8 Wings > > From: David Aronson <aronsond(at)pacbell.net> > Date: 2001/06/07 Thu AM 10:33:20 EDT > To: rv-list(at)matronics.com > Subject: Re: RV-List: RV-4 vs. RV-8 cockpit dimensions > > > Bob: > Great info! But with all that room in the 8, I think that it would > become cluttered with beer cans and potatoe chip bags! The 4 doesn't > allow such buildup of waste materials during a long flight! > Dave Aronson > RV4 N504RV > Cowl finally done > > Bob Reiff wrote: > > > > > > Oops, the columns looked good when I sent it, but they were goofed up when > > received from Rv List (at least on my screen). The first column is RV4 and > > the 2nd is RV8. I tried fixing it up below so it's readable. > > > > There were several inquiries asking what I decided, so I'll respond to the > > list to save time. > > > > I have decided to stick with the 4. I actually had a deal set up with > > Van's last month to buy the RV8QB they were going to display at Osh this > > summer, to save $1500 shipping ( I live an hour's drive from Osh). Shortly > > after it was arranged they canceled it saying they can't get a kit. I have > > a feeling we'll see a RV-7A QB on display up there, which makes more sense > > for them than an 8. > > > > That, combined with the cockpit measurements, and no one interested in my 4, > > I decided to keep the 4 and finish it. One of the main reasons I wanted the > > 8 was the perception of a bigger back seat. Turns out there's not much > > difference except width, and width is not a problem. I'm 6' 175 lbs and the > > 4 fits me fine. Plus I like the looks of it better than the 8. I am thinking > > about putting in a baggage compartment between the inst panel and firewall > > like the 8 has, then I can balance it better to carry more rear baggage and > > more rear seat weight if I want to give a bubba a ride. > > > > One big advantage of the 8 that I like is the CAD design. The drawings are > > much better than the 4 and the parts should fit together much better. > > > > Bob > > > > > In the course of deciding whether to switch from my half built RV4 to a > > > half built RV8 QB, I couldn't find any interior cockpit dimensions for > > > the 8. So I paid a visit to Dick Martins in April and took some > > > measurements of his 8 - in case anyone is interested: > > > > > > > > > 4 8 > > > Width - Shoulder room > > > Inside the rails - front 22 24.5 > > > - rear 22 24.5 > > > > > > Width - total > > > Between side walls at frt seat 26.5 31.5 > > > > > > Length > > > Top of inst panel to top of frt seat back 57 58 > > > Top of frt seat back to top of rear seat back 26 25 > > > > > > > > > Bob Reiff > > > RV4 #2646 still building > > > Reiff Preheat Systems > > > 262-968-2342 > > > www.ReiffPreheat.com > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 07, 2001
SAM, YOUR FACTS ARE VERY TRUE ABOUT SIMPLICITY. BUT, IN THE REAL WORLD, YOU CAN BUY A STRIPPED DOWN CAR OR YOU CAN BUY ONE LOADED. WHICH ONE IS MORE FUN TO DRIVE AND OWN IS UP TO YOU. I PREFER A LOADED CORVETTE OVER A STRIPPED DOWN VW. THE SAME IS TRUE WITH AIRPLANES. THERE ARE MANY THINGS THAT CAN SAVE YOU MONEY IN THE LONG RUN (ENGINE, COMPUTER, CONSTANT SPEED PROP ETC...) EACH TO OUR OWN. REGARDS, TOM Thomas M. Whelan Whelan Farms Airport Post Office Box 426 249 Hard Hill Road North Bethlehem, CT 06751 PH 203-266-5300 FAX 203-266-5140 e-mail wfact01(at)aol.com EAA Chapter 1097, President RV-8 IO-540 LYC ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Re: Castellated nuts vs. metal locknuts
The metal lock nut to secure the engine mounts was the factory installation on the O- 320 powered Piper Warrior I use to own. In general, the application for castellated nuts is on any part that turns, or may otherwise rotate the bolt. A rod end being a great example. - Bob Bob newmanb(at)rocketmail.com newmanb(at)rocketmail.com ________________________________________________________________________________
Subject: Re: insulation
Date: Jun 07, 2001
06/07/2001 11:02:03 AM Ian, Most long time RV owners will give you one big piece of advice, keep it light. A full insulated interior is going to add up in wieght and you will pay in performance. See the string of messages on Vansairforce.net under "If I had it to do again". Noise cancelling headsets are getting cheaper. Also, our canopys tend to leak big time. Forget insullation against the cold, put on a coat or mover to Florida like everyone else and their dog. Eric Ian Jessen (at)matronics.com on 06/07/2001 09:58:16 AM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RV-List: insulation Thanks everyone who responded to my previous question, and hopefully my email is now sending out the correct name. I have another question. I have noticed, while glancing through builders pages, that almost no one has installed any sort of insulation. What do people think of the noise level in an RV (with a passive headset, of course) and what experiences do people have in cold weather flying? Is sidewall fabric and a couple of heater muffs acceptable? Thanks, Ian Jessen ________________________________________________________________________________
Date: Jun 07, 2001
In a message dated 6/7/01 8:01:18 AM Pacific Daylight Time, abarstad(at)sympatico.ca writes: > > My personal experience from the back-seats in both the 4 and 8 is that you > 'sit' in the 8 and you 'wear' the 4. I'm only 5'11" so I fit easily in both > (front and back) and enjoy both equally. When I fly (or come along) I don't > need to walk around alot anyway, so the room in both is ample - except > maybe the flap lever in the -4 can be annoying if the passenger don't > remember to pull the foot away from the left footwell on approaches. > > Are > RV-8 Wings > > Here is a concept, fastback the 4 using a Rocket canopy and drop the flooring. Now you have ample room (enough for a 6'1 and 200lb person) and the plane is good looking too.] Tim Barnes N39TB Flying ________________________________________________________________________________
Date: Jun 07, 2001
IN MY OPINION, Having the inside upholstered gives the airplane class and comfort. The loss in speed or performance is minuscule compared to the gain. If your cruising at 160Kts at 65% how much faster do you think you can go without any of these amenities. 5Kts? Big deal. TO EACH HIS OWN. Don Champagne N767DC O-360 C/S Upholstered ________________________________________________________________________________
Subject: Re: How much to paint?
Date: Jun 07, 2001
Hi Hal, I'm not sure if you're talking about doing it yourself or hiring a professional, but I just finished painting mine myself and it cost me right at $1000 for all the materials excluding the gun and respirator that I was able to borrow. (thanks Rob!) This included etching primer, epoxy primer and single stage (two part) acrylic urethane. The whole system was PPG Concept. White base with burgundy and charcoal stripes. It would be $60-$75 less without the 2nd stripe. As for a professional, it can start as low as a couple thousand if you do all of the prep work yourself. It can clear well over $5000 to have a good painter do a meticulous job. The real killer is the prep work. I spent a month of virtually full time work prepping/painting the airplane. Ed Bundy - RV6A N427EM 400+ hours 160hp 0320 w/Sensenich 70x78 Eagle, ID ebundy(at)micron.net > What is a reasonable cost for a modest paint job on an RV6a? By modest I > mean, one stripe running nose to tail and N numbers on a one color > background. I suppose a two stage urethane is standard? > > Hal Kempthorne ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Re: Steering links and mail fraud
Terry, I think it is weird that after waiting patiently for over two weeks, I finally email you asking where it is and within two hours the post office delivers it. From now on I'm going to be very careful what I say about the POST OFFICE in my e-mail. Guys, It was worth the wait, it looks like it's well built and the single sided horn comes with it. Can hardly wait to try it out. Thanks Terry, Garry RV6, Feds here on 21st. Terry Jantzi wrote: > > Listers, > > Before I get accused of participating in mail fraud, I need to explain > something. I sent out a whole whack of steering links via efficient Canada > Post. I test weighed a package at our local outlet and then sent the balance > out with that postage. Guess what? After 12 days I get a notice that there > was insufficient postage and they were not delivered. Garry LeGare's made it > to the destination after aprox 14 days of travel. It's not called snail mail > for nothing. I am in the process of re-shipping via FedEx. All listers who > have sent me money will be receiving their package shortly. Please be > patient. I don't want my first attempt at selling stuff to fellow RV'ers to > leave a sour taste. > > Terry Jantzi > Kitchener ON > -- > <http://www.iwantarocket.com> > <http://www.netrover.com/~tjantzi/terry/> Home Page > <http://www.ontariorvators.org> VAFOW > ________________________________________________________________________________
From: "Doug Weiler" <doug.weiler(at)pressenter.com>
Subject: Re: Ignition wiring
Date: Jun 07, 2001
> The Slick lead plug nuts for my slick mag harness are stamped with a number > like T-3 or B-2. Have you checked those? > > Cy Galley - Bellanca Champion Club Hey, you're right!! Just needed to know where to look and put my glasses on!! Doug ________________________________________________________________________________
Date: Jun 07, 2001
> Here is a concept, fastback the 4 using a Rocket canopy and drop the > flooring. Now you have ample room (enough for a 6'1 and 200lb person) and > the plane is good looking too.] OK, but without that I0-540 up front..what good would that extra room do you? In a word....CG Bill -4 wings ________________________________________________________________________________
Date: Jun 07, 2001
Subject: 24 hour report
I have now flown the RV for 24 of the 40 required hours. I told my daughter that this morning and she said, youve flown it for a whole day, Daddy. I never thought about it that way. Things Ive learned about the airplane. 1. Now that I can go 160 kts I want to go 170 kts. Funny, I never thought much about speed when I could only go 115kts. 2. The airplane continues to fly well, though it needs a pinch of rudder trim. I will put a small trim tab on this weekend. 3. The archives are a godsend during the flight test phase. 4. The airplane definitely fishtails in turbulence. Not a great ride. I wish I had that bigger vertical stabilizer. 5. The S-TEC System 50 autopilot is really cool. The altitude hold is solid as a rock. 6. Electric trim controlled with the MAC stick grips is working very well. Trim is effortless. However, I am running out of nose-up trim authority at slow speeds. 7. Id rather fly than fix things. 8. 1,000 square miles of Mojave Desert is not a big enough test area. 9. This is the noisiest cockpit I have ever been in, most of it wind noise. 10. The take-off performance with a fixed pitch is quite disappointing after youve flown the constant speed. Its only about 180% the climb performance of those Cessnas I used to fly. Nuts! -- John Allen RV-6A Flying. . . . . .like a bat out of hell! Sign Up Now! http://www.onebox.com ________________________________________________________________________________
Date: Jun 07, 2001
Sent him an email last Sunday afternoon and had a response with a couple of hours. I then called him on the phone that evening and we spoke at length about my proposed panel. Nice Guy. Name - Steve Davis Email - PANELCUT(at)aol.com Phone - Home (901) 726-6184, Work (901) 526-0491 Charlie Brame N11CB (Reserved) RV-6AQB - Canopy San Antonio > From: BSEckstein(at)cs.com > Subject: RV-List: Panel Pilot? > > > Listers, > > I've been trying to contact Steve Davis of Panel Pilot for several weeks now > with no success. Does anyone know what is up? > > Thanks > Brian Eckstein > 6A Flying ________________________________________________________________________________
Date: Jun 07, 2001
I have found the RV6A to be very stable and comfortable in IFR conditions and turbulence. Best wishes, John RV6A o-360, Sterba, 100 hrs ________________________________________________________________________________
Subject: Re: canopy breaker
Date: Jun 07, 2001
Another canopy breaker can be found via Watkins Aviation (www.watkinsaviation.com), page 34 of their catalog. It is item 9063, "SP16-SPAX Rescue Tool". Description is as follows: "Designed to be stored inside the cockpit, this new generation rescue device has multiple roles including breaking through plexiglass canopies. Modeled after a WWII crash ax, it features a pointed blade for penetration and a sharpened edge for chopping. It comes with a sheath, and is a bit pricey ($75), but, compared to my Lycoming from Van's, it isn't too expensive. Rick Jory, Highlands Ranch, CO RV8A ----- Original Message ----- From: Frazier, Vincent A <VFrazier(at)usi.edu> Digest (E-mail) Sent: Friday, June 01, 2001 2:15 PM Subject: RV-List: canopy breaker > > Occasionally there is talk on the list about canopy breaking tools. Here's > one that I hadn't seen before: > http://www2.grizzlyindustrial.com > > Search for item H2416, Walther jungle tool. It's only 9 oz and does > everything except convert into a portable hangar. Anybody tried this thing? > It looks pretty neat. $39.95 > > Vince Frazier > Harmon Rocket II ... the fine line between "hobby" and "mental illness." > http://www.usi.edu/science/chemistry/vfrazier/page1.html <---- note: new > URL as of 5/30/01 > > ________________________________________________________________________________
From: "Kevin Schlosser" <kevinschlosser(at)msn.com>
Date: Jun 07, 2001
What about noise induced from stobes or navaid servos with this setup? Any experiences? Kevin Schlosser -< PropellerHead >- [SNIP] In a message dated 06/06/2001 9:43:49 AM Pacific Daylight Time, bertrv6(at)yahoo.com writes: > Hi: > > Would like to hear from the list,about the Nav > antena on the wing tip. (better to have one on each > tip or is not necessary? Comments? > > Name of company where to buy them,and address > e-mail or phone. Besides ACS.... > > Thanks, > > Bert > rv6a > Look in the yeller pages for Sportcraft Antennas, or Bob Archer. With a single NAV radio, just a single NAV antenna is needed. With Dual NAV radio's, you can use a splitter from one NAV antenna, or use dual NAV antenna's (one antenna to each radio.) Jim Ayers Less Drag Products, Inc. LessDragProd(at)aol.com [SNIP] ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Re: 24 hour report
Thanks John. Great update. Garry RV6 Feds on 21st. John Allen wrote: > > I have now flown the RV for 24 of the 40 required hours. I told my daughter > that this morning and she said, youve flown it for a whole day, Daddy. > I never thought about it that way. > > Things Ive learned about the airplane. > > 1. Now that I can go 160 kts I want to go 170 kts. Funny, I never thought > much about speed when I could only go 115kts. > 2. The airplane continues to fly well, though it needs a pinch of rudder > trim. I will put a small trim tab on this weekend. > 3. The archives are a godsend during the flight test phase. > 4. The airplane definitely fishtails in turbulence. Not a great ride. > I wish I had that bigger vertical stabilizer. > 5. The S-TEC System 50 autopilot is really cool. The altitude hold is > solid as a rock. > 6. Electric trim controlled with the MAC stick grips is working very > well. Trim is effortless. However, I am running out of nose-up trim authority > at slow speeds. > 7. Id rather fly than fix things. > 8. 1,000 square miles of Mojave Desert is not a big enough test area. > 9. This is the noisiest cockpit I have ever been in, most of it wind > noise. > 10. The take-off performance with a fixed pitch is quite disappointing > after youve flown the constant speed. Its only about 180% the climb > performance of those Cessnas I used to fly. Nuts! > > -- > John Allen > RV-6A Flying. . . > > . . .like a bat out of hell! > > Sign Up Now! http://www.onebox.com > ________________________________________________________________________________
Subject: insulation
Date: Jun 07, 2001
I found the message below to be very informative so I took the liberty of removing the D.N.F flag and reposted it. I may like to search for it at a later time. Are RV-8 Wings www.ontariorvators.org VAF-OW Good questions. I found the low frequency exhaust drumming to be uncomfortably loud, particularly on long flights. So I installed acoustic deadening pads, from an automotive audio, shop on the firewall and fwd side skins. It reduced the high freq noise somewhat but was not worth the 5 pounds additional weight. I tried turned down tips on the exhaust tail pipes and found them to be totally ineffective. The ONLY way to go is with noise cancelling headsets. For cold wx I use strips of foam to seal the small air leak at the front of the canopy. Still my sides got cold from radiating heat to the cockpit skins. I insulated the skins with Ensolite, a very light weight, closed cell foam product by Uniroyal Plastics. Its 3/8 thick, semi-rigid, smooth skin, light gray providing a tidy finished look. Vans 9 cabin heat muff and heat selector box give adequate heat but my selector box leaks hot air. Every hot day reminds me to fix it. Don Diehl RV-4, N28EW, 150 happy hours Bremerton WA ________________________________________________________________________________
Date: Jun 07, 2001
My firewall is insulated with 5/8" black stuff from Aircraft Spruce with aluminum foil glued to the back. This is a technique that George Orndorff (sp?) uses in one of his RV-6 or 6A tapes. In addition, I have a thin layer (3/16" or so) of padding under the carpet in the footwells. All told, I guess it added 5-10 pounds. My airplane is very quiet inside. Certainly as quiet as the certified ships I've flown (which had mufflers, the RV doesn't), maybe quieter. I took a ride in a buddy's uninsulated RV-4, and found that it was by far the loudest aircraft I've ever flown in. The noise was primarily exhaust related. I'm guessing the -6 would be similar without the insulation. Even with active headsets, the noise difference between the insulated and uninsulated aircraft was noticable to me. As plenty of folks have stated, lighter is better. I just figure that what enjoyment I lose because of the extra weight will be offset by the reduced in-flight fatigue. Kyle Boatright - Kennesaw, GA RV-6 Slider, O-320/Aymar-Demuth ________________________________________________________________________________
Date: Jun 07, 2001
From: Charlie and Tupper England <cengland(at)netdoor.com>
"mustangaero(at)yahoogroups.com" , plugs up rotary list , Rotary list , RV list , thorplist , aeroelectric list
Subject: Get a (cheap) charge out of this
I think I may have a tip to offer the more uhh, frugal among us. While searching the shelves for plexi working tools at our local Harbor Freight outlet, I took a long hard look at their version of the little rechargable 'jump start' packages everyone seems to own these days. The box says 17 amp. Sounds familiar. It says 400 amp starting power. Sounds optimistic, but... Weight is listed as 19 lbs for the package. Hmmmm.... So, I brought one home & took the back off. Guess what's inside. There are couple of #4 cables (1 red & 1 black) just about the right length to reach a master contactor. And a rather cheap looking (and costs less) 0-15 V voltmeter. And an AC trickle-charger. And several cigar lighter connectors which I bet could be used for something, *and*, even a little floodlight which might work as an emergency panel light. All these goodies for less than $40. Oh, by the way, there's also that funny little black box that weighs around 14 lbs. It looks suspiciously like some rather expensive jetski batteries I've been reading about lately, just without anyone's name on the black case. I hope someone finds this useful. Charlie RV-4 sold RV2+2 bought, working on a new windshield ________________________________________________________________________________
"Rv-List(at)Matronics.Com"
Subject: P B & J?
Date: Jun 07, 2001
For those of you that are using the Potter and Brumfield breaker switches... Is the bat part of the switch really sloppy? I just got one from Aircraft Spruce, and I would classify it as junk... Is the how these things are? or did I just get a lemon? Thanks... Bill VonDane Colorado Springs, CO RV-8A - N8VD http://vondane.com/rv8a/ ________________________________________________________________________________
Date: Jun 08, 2001
I think you'll need an exhaust fan to rid excess overspray and fumes. You will want to have a filtered air inlet and on the otherside of the booth an exhaust fan that is also filtered to rid the booth of fumes and overspray. Old furnace fans make a good exhaust fan. John L. Danielson ________________________________________________________________________________
Subject: RV-4 Cockpit Ventilation
Date: Jun 08, 2001
Hello Everyone I'm presently replacing the canopy on my -4 and while at it I thought I could improved the cockpit ventilation a little bit because it gets pretty hot on hot summer days. So for you guys flying RV-4s,what are the best locations to install the vents and what are the best models available and where can I get them. Thanks in advance Bruno Dionne Flying RV-4 C-GDBH fo320(at)sympatico.ca P.S# Anyone with pictures on a web site,please let me know off list and I'll go have a look. ________________________________________________________________________________
Date: Jun 08, 2001
Hi Kyle, Thanks for sharing your experience. I've just bought a completed RV-6 and want to do this work before flying. I heard a few stories of what can happen when the pedals break, and don't want to scratch my plane's paint that way. I'm going to the hangar this weekend to do the dirty deed. I appreciate getting an idea of what's in store for me when I contort myself into position under the panel. nancy b. "Good people are always so sure they're right." Barbara Graham's last words Executed June 5, 1955 at San Quentin -----Original Message----- From: KBoatri144(at)aol.com <KBoatri144(at)aol.com> Date: Thursday, June 07, 2001 8:29 AM Subject: Re: RV-List: help with rudder pedal rework In a message dated 6/7/01 6:23:00 AM Eastern Daylight Time, nancyb(at)mninter.net writes: > I would like to hear from folks who have modified the rudder pedals per > Van's Aircraft direction to add the gusset plates. How hard is it to > remove the pedals in an RV-6 with overhead pedals? Any tips or > suggestions for how to do the job? > > Thanks, > > nancy b. It is a real pain. If you have the NACA vents in the recommended location, there is no way to get the intact pedal assembly (both pedal weldments and the UHMW blocks) out in one big assembly. Instead, you have to dissasemble (and later reassemble) the entire assembly while working in the footwell. It'll take about 30-45 minutes to remove the assembly, probably twice that to reinstall it. Here's how: 1) Get prepared... A helper to hand you tools and collect parts as you disassemble things. Get plenty of light. Get all of the tools you need. Remove whatever it takes to get down in the floorboards (seat cushions, sticks, center panel support, etc.) Consider removing the canopy to give yourself more room to thrash around without damaging anything. 2) Disconnect all the rudder cables, brake cylinders, etc. from the pedal weldments. You don't need to pull the brake cylinders out of the airplane, or disconnect them from the hoses, just shove them out of the way. You may want to remove the brake pedals, because once the brake cylinders are disconnected, the brake pedals flop around a bit. 3) Unbolt all three of the UHMW bearings the pedals ride in. Remove the center bearing. 4A) If you don't have the NACA vents mounted right above the rudder pedals, you should be able to work the pedals assembly around and get one of the end UHMW blocks off, which will allow you to pull the weldments out one at a time. If the NACA vents are in the way, skip this and go to 4B. 4B) If you're working around the NACA vents, you will need to take advantage of the fact that the fuselage widens significantly as you move aft from the rudder pedals. Slide the entire pedal assembly as far aft as it will go. What you want to do is move the assembly so far aft that the aftmost weldment is touching the next bulkhead (the little vertical ones in the footwell (F-602??). At this point, you can flex the fuselage side out, and get one side of the aftmost pedal weldment to come out of its UHMW block. Once you get this done, the weldment can be jockeyed around enough to remove it from the footwell. Next, slide the other weldment (with UHMW blocks still attached) as far aft as possible. Rotate the UHMW blocks 180 degrees so you can slide the second weldment right up to the F-602. Again, flex the fuse side, pop the weldment out of one of the UHMW blocks, and everything will come out. 5) Reverse this procedure to reinstall. 6) Buy your helper a frosty beverage. Have two yourself. Kyle Boatright - Kennesaw, GA RV-6 Slider, O-320/Aymar-Demuth ________________________________________________________________________________
Date: Jun 08, 2001
Hi David, Thanks for sharing your experience. I've just bought a completed RV-6 and want to do this work before flying. I heard a few stories of what can happen when the pedals break, and don't want to scratch my plane's paint that way. I'm going to the hangar this weekend to do the dirty deed. I'll take your suggestion and saw the blocks half in two. nancy b. "Good people are always so sure they're right." Barbara Graham's last words Executed June 5, 1955 at San Quentin -----Original Message----- From: David Schilling <davideng(at)opusnet.com> Date: Thursday, June 07, 2001 10:44 AM Subject: Re: RV-List: help with rudder pedal rework An additional tip: Once you've done the job of removing the pedals, you can saw the outer UHWM blocks in two just like the center support. Then you place a spacer washer in between the upper and lower halves just like the installation of the center support block. This makes the job much easier to reinstall, and do future maintainence. By the way, I have most of the stuff already installed in the cockpit, and I did not have that much trouble. I just took it slow. I did not even scratch the paint. Regards, David ________________________________________________________________________________
Subject: Spray Lat
Date: Jun 08, 2001
06/08/2001 08:11:18 AM For the Archives: Aircraft Spruce sells a great protective coating for your canopy called Spray Lat. One quart will cover an RV-6 canopy with two heavy coats inside and out (two coats each). It can be sprayed from a normal HVLP spray gun after reducing it with water in a 1 to 1 ratio. After drying it will give a transparent film similar to the plastic coating that comes on the canopy, however since it is applied in a liquid form chips and dirt will not be able to get under the edge. When you are done it peels off like plastic. The coating is very durable once dry and since it is transparent it is very easy to see where the canopy contacts the frame so you can see where to drill. Cost is about $15. Eric Henson ________________________________________________________________________________
Date: Jun 08, 2001
I WRITE WITH CAPS SO I CAN SEE -TOM-THIS IS YELLING Thomas M. Whelan Whelan Farms Airport Post Office Box 426 249 Hard Hill Road North Bethlehem, CT 06751 PH 203-266-5300 FAX 203-266-5140 e-mail wfact01(at)aol.com EAA Chapter 1097, President RV-8 IO-540 LYC ________________________________________________________________________________
Date: Jun 08, 2001
Subject: Re: P B & J?
The toggles on these switches/breakers have some "play" in them. This is normal. Bill VonDane wrote: > > > For those of you that are using the Potter and Brumfield breaker switches... > Is the bat part of the switch really sloppy? I just got one from Aircraft > Spruce, and I would classify it as junk... > > Is the how these things are? or did I just get a lemon? > > Thanks... > > Bill VonDane > Colorado Springs, CO > RV-8A - N8VD > http://vondane.com/rv8a/ > ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Date: Jun 08, 2001
Sam, Nicely put. The KISS principle really enables me to fly a lot more in N925RV...... I'm building a second RV-6A and had hoped to put in a glass cockpit, but am slowly coming to the realization that the cost and complexity are just much more than I can afford or need. The RV-7 panel, with a bit more for IFR, will more than fill the IFR requirements, at a fraction of the cost Fred Stucklen N925RV (1785 hrs/7.75 Yrs) E. Windsor, CT 06088 WK Email: stuckle(at)ifc.utc.com Hm/Travel Email: wstucklen1(at)juno.com Fuselage about to come out of the Jig on 2'd RV-6A ___ From: Sam Buchanan <sbuc(at)hiwaay.net> Subject: RV-List: Simple vs complex Ocassionally a real nugget of truth makes its way onto the list. Randy's post is certainly one of those messages that needs to be carefully considered by all current builders, and I encourage all new builders to clip his post and pin it to the wall of the shop! Often I am amazed at the complexity that is being engineered into some RVs. I fully realize and appreciate the "experimental" nature of our aircraft and the latitude that is afforded us to incorporate any bells and whistles we wish in our projects.......... ________________________________________________________________________________
Subject: Navaid Install on 8A
Date: Jun 08, 2001
Any suggestions on installation of the Navaid servo on an 8A? Pictures also help. rickjory(at)msn.com Rick Jory, Highlands Ranch, CO RV8A ________________________________________________________________________________
Date: Jun 08, 2001
Subject: FW: [rv8list] Navaid Installation
Hey Rick... I have thought about this a lot and wish I could afford one so I could try it out... If anyone wants to buy me one so I can come up with a quick and easy install kit, let me know... 8-) I friend of mine did a great job of mounting one in his -8, and I think it could be adapted to the -8A as well... His is mounted on the floor forward of the spar on the right side and connects directly to the WD-807 control column where the rod end bearing is bolted on... You can't mount it there in the -8A due to the landing gear weldments, but I believe you could mount it on the left side of the fuse just aft of the F-805B and connect to the control column in the same way at the rear. You would have to make a mount for the serve that would span the floor connecting to the F-814 & F-815 to add strength (you don't want the thing going through the floor in a high G maneuver), and you would have to cut out
June 05, 2001 - June 08, 2001
RV-Archive.digest.vol-kw
