RV-Archive.digest.vol-ll
September 07, 2001 - September 12, 2001
Date: Sep 07, 2001
Subject: Re: RV-6 throttle quadrant
Sell the 6, buy an 8, problem solved!!!!! ________________________________________________________________________________
Date: Sep 07, 2001
Subject: Re: parking brake valve where?
--- bert murillo wrote: > > Hi: > > I got the parking brake valve from spruce, no > instructions. Hi Bert, I have sent you some scanned pictures of my installation. Check that out and let me know if you need more explanation... Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Subject: Re: wheel weight
Date: Sep 07, 2001
I wouldn't - better safe than sorry - although I don't have a set of wheels in front of me, I'm only showing a Cleveland 5.00 x 5 wheel and brake assembly at less than 6 lbs according to a couple of the catalogs I've looked at. Mind you, that's a magnesium wheel - how much more could the aluminum ones weigh? Tom N787RV (reserved) ----- Original Message ----- From: "barry pote" <barrypote(at)home.com> Sent: Friday, September 07, 2001 6:58 PM Subject: RV-List: wheel weight > > Logged in the inventory on the finish kit (rv9a) today. I can't believe > they (Cleveland) make their aluminum wheels a 1/2" thick. Very very > heavy. > > I realize that they take a pounding every time you land, but so do 4 > wheeler dirt bikes. > > Seems like chucking them in a lathe , would shed 5 or ten pounds. > > Are there light weight versions available? Anyone thought about cutting > these down a little? > > Barry Pote Fuselage RV9a > > > Barry > > ________________________________________________________________________________
Subject: hole in wheel pant for air?
Date: Sep 07, 2001
How far from the axle bolt should it be to the center of a hole for a rubber plug for tire inflation without wheelpant removal??? Tailwinds, Doug Rozendaal dougr(at)petroblend.com ________________________________________________________________________________
Date: Sep 07, 2001
Please share this information with the rest of. Thanks Rollie & Rod RV6A Installing Canopy ________________________________________________________________________________
Date: Sep 07, 2001
Subject: Re: hole in wheel pant for air?
In a message dated 9/7/01 10:10:52 PM Eastern Daylight Time, dougr(at)petroblend.com writes: << How far from the axle bolt should it be to the center of a hole for a rubber plug for tire inflation without wheelpant removal??? Tailwinds, Doug Rozendaal dougr(at)petroblend.com >> 2" works well on mine, but If I was going to do it over again, I'd drill the hole 3/16" closer to the axle bolt. FYI, I have a 7/8" hole in the wheel pant. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Sep 07, 2001
"How far from the axle bolt should it be to the center of a hole for a rubber plug for tire inflation without wheel paint removal?" To locate a hole for a plug for tire inflation: 1. Measure the distance from the valve to the center of the axel. 2. Decide where you want the hole. 3. Drill a small hole the distance found in step 1, from the center of the axel on your paint. 4. Place a screw driver or something you can use to locate the valve, into the hole and determined if it is centered over the valve. 5. Enlarge the hole with a unibit until you have the it centered and sized for your plug and air chuck Good Luck! Don Eaves RV6 Flying 66.6 Hrs. ________________________________________________________________________________
Subject: Opinions Requested
Date: Sep 07, 2001
I'm curious as to why the RV-9 builders decided on that model (when compared to the RV-6). I'm torn again between the RV-7 and the RV-9A. Thanks Tom N787RV (reserved) ________________________________________________________________________________
Date: Sep 08, 2001
Subject: Re: BIG BOXES!!
My experience is that most drivers will not help. They do not want to get blamed for any damage. John Singer Denver, CO RV6A QB Just finished installing Empenage - waiting for Finish Kit to arrive. N444JS http://www.jgsinger.com/rv In a message dated 9/7/01 4:27:41 PM, Bobpaulo(at)aol.com writes: I got my college son and 4 of his buds along with myself and driver. I can be done this way, or should I say the old fashion way. Bob in Ark >> ________________________________________________________________________________
Subject: Re: speaking of Hobbs?
Date: Sep 08, 2001
Your gonna love this one Bill. http://www.aeroelectric.com/Catalog/switch/switch.html#switch Just the answer your looking for, eh? Mike > > Speaking of... What are people using for a buzzer? I was thinking of a > nice "ding, ding, ding" like what's in my Nissan... > > -Bill VonDane > Colorado Springs, CO > RV-8A - N8VD - Finish > http://vondane.com/rv8a/ > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of racker(at)rmci.net > Sent: Friday, September 07, 2001 10:08 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: speaking of Hobbs? > > > Won't the Hobbs then be measuring "Avionics ON" time then, not the usual > intent of engine run time? Also, it becomes yet another victim of a > designed-in single point failure (having all the avionics on one switch). > > Having the Hobbs on a two-pole pressure switch gives you engine run time, as > well as a low oil pressure/hey dummy you left the master on light/buzzer. > > Rob Acker (RV-6Q). > > > -----Original Message----- > > >You can also hook the Hobbs up to the Avionics Master, save the money on > the > >oil pressure switch. > > ________________________________________________________________________________
Subject: Re: color of rollover bar
Date: Sep 08, 2001
Michael, Great information. It looks like black is a good color to go with. Been to Sedona already, and you're right, its worth the trip. Kelly ----- Original Message ----- From: "KostaLewis" <mikel(at)dimensional.com> Sent: Friday, September 07, 2001 4:07 PM Subject: Re: RV-List: color of rollover bar > > > I recently saw an RV4 with a chrome plated roll bar that looked super. I > plan to do that to my 4. > > It will really look cool. And your back seat passengers will hate it. It's > not only that the bar itself will be reflecting right in their face, like a > big neon light, but the shine on the canopy from the bar can be very > annoying. It actually blocks the view out the canopy. I have a knee board I > fly with and just the reflection off the white of the check list onto the > canopy is annoying, not to mention the three small binder rings of CHROME > that were very shiny, indeed (and have since been painted black). And the > canopy mirrors that right back at you. I have a black sheet I put over the > knee board when going cross country to cut down on glare. > > > > I am looking for input on the color of the canopy rollover bar. I have > seen primarily white/gray and black. Black would >> seem to have the > advantage of minimizing glare, whereas white/gray would seem less obtrusive > in your field of view. > > Mine is black and reflects very little. Go sit in a -4 or -8 with the canopy > down, in the sun, especially with the sun coming from behind. See what you > think. Then think of sitting back there for three hours on your way to > Sedona, Arizona. Which is one of the places you should go when your airplane > is finished, by the way. > > IMHO. > > Michael > RV-4 N232 Suzie Q > 540+ hours and very little glare. > > ________________________________________________________________________________
Subject: Re: Voltage Regulator-question
Date: Sep 08, 2001
> Have question for all you electronic engineers,, > or not: I got my engine now, a rebuilt one LYc. 0320 > 150 h.p. > A wise choice for a RV-6A. I have one in mine and have been very happy with the performance. I can also use auto gas. The other day, I was climbing out of a friend's strip and decided to pull back on the stick a bit more just to see what it would do. At 105 knots, it was climbing at 1500' a minute. This was on a hot day. It will usually indicate about 140knots on a hot day and at about 2500'msl. That's a lot better than the Cheetah I used to own. You're going to like that little engine on that little airplane. :-) I wish I could help you with your question; but, I went with an external voltage regulator with an external OV protection to keep all of that seperate. My voltage regulator is adjustable and was bought from Van's. I did have to do a little adjusting when I first fired up the engine. Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Subject: logbook on PC
Date: Sep 08, 2001
Hey guys, I have relative looking for a flight logbook that is pc based so they can keep duplicate records. Anyone know of such a thing? Thanks Doug Bell 8 qb....golf season is getting close to being over here...:) ________________________________________________________________________________
Subject: BIG BOXES!!
Date: Sep 08, 2001
I hired a tilt bed tow truck ($125) to pick up the crates at the freight terminal. I borrowed four engine dollies from the local junkyard. These had swivel casters on the bottom and were flat squares made of angle iron. I could have made them from wood but the casters are expensive. When the tow truck arrived we (the driver and I) slowly tilted the bed of the truck and slid the crates onto the dollies and pushed them into the garage. It was easier than I expected and once the truck was here it only took 20 minutes to get both crates safely into the stored. Allen Checca 6A QB One wing done -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Tim Bryan Sent: Thursday, September 06, 2001 8:06 PM Subject: Re: RV-List: BIG BOXES!! Hi John, I can't imagine that three or four guys can't handle those boxes. I can pick up either end of my airplane alone. The box itself can't be more than the airplane. I wouldn't think. RV-6 (N616TB Reserved) Finish kit and waiting for my engine Tim Bryan tim(at)bryantechnology.com ----- Original Message ----- From: <JTAnon(at)aol.com> Sent: Thursday, September 06, 2001 4:51 PM Subject: RV-List: BIG BOXES!! > > Got the news today that my RV7A QB will ship out from Oregon in a few days. > > I'll search the archives tonight, but does anybody have any clever little > tricks for getting these REALLY BIG boxes off the truck and into my > driveway???? > > John McDonnell > > ________________________________________________________________________________
From: "Clifford Begnaud" <shoeless(at)barefootpilot.com>
Subject: Re: Opinions Requested
Date: Sep 08, 2001
Tom, It comes down to the mission. If you want to do aerobatics, well, you know which one to get. Most people that buy the 9 probably want a good cross country machine. I have flown the 9 and several 6's. It was turbulent on every flight and the difference in stability was noticeable. The 6 is more easily upset from it's path and seems to wag it's tail. The 9 is just a more stable platform. The price you pay for this is in the control sensitivity, particularly in the roll axis. The roll axis of the 9 requires more effort and the roll rate is not as fast. However, it is still a very sporty airplane and lots of fun to fly. If you would like, why not ask the employees at Van's which plane they prefer to fly when they go cross country to fly-ins etc. Ask Tom Green which one he likes to fly, ask Van which one he commutes in. Yes, I think the answer to all these will be the 9. One other reason that people buy the 9 is for it's slow speed handling and short field capability. It's true that all RV's can take off and land short, but the 9 just blows em away. It is really quite amazing how well it handles at low speeds. I currently own a kitfox and when my 9 is flying, I'll still be able to go flying with the other kitfoxes around here. None of the 6 pilots around here can fly with us. The 9 also stalls MUCH MUCH SLOWER than the other RV's. This is a great safety feature. Particularly if you ever have to do an off airport emergency landing. At the time that I bought the 9, the 7 was not available. The clincher for me at that time was the higher gross weight rating of the 9 over the 6. Now the 7 is higher. (you can carry more stuff) If I had to choose over again, it would be a much more difficult choice because I really would like to able to do aerobatics. Regards, Cliff www.barefootpilot.com > > I'm curious as to why the RV-9 builders decided on that model (when compared > to the RV-6). I'm torn again between the RV-7 and the RV-9A. > > Thanks > > Tom > N787RV (reserved) > ________________________________________________________________________________
Date: Sep 08, 2001
Subject: Re: why fool with a Hobbs meter
I put one in. It only weighs a few ounces, takes up negligable panel space, Keeps great track of operating time, and serves as my oil change reminder. And results in one less thing for me to compute (grin). Of course, it is the one instrument that I always prayed would fail when I was renting. From: "Randy Compton" <rdcompton(at)earthlink.net> Subject: Re: RV-List: speaking of Hobbs? Imho, why even fool with a Hobbs meter at all? I look at the panel-mounted clock in my RV-3 at the time I crank the engine. Likewise, I note the time at shutdown and figure my time. I got used to doing it this way when I went into the Navy (the U.S. government didn't bother to put Hobbs meters in its jets.) Granted, it takes a bit of getting used-to, but like other cockpit duties it will soon become part of your habit pattern. Also, it's one less gage to install and a little bit of weight saved. Randy Compton RV-3A N148CW Gulf Breeze, FL ________________________________________________________________________________
Subject: Re: Canopy side skirts
Date: Sep 08, 2001
> Van's later RV-6 slider canopy finish kits now include the "inside canopy > brace strip" that Mike describes below. My finish kit (packed late May 2001) > included these parts as item number # C-759 "Inside Canopy Skirt" - and > coincidentally I drilled these to the inside of my canopy frame this > afternoon. Hi Jim, Do you think if a person ordered these "Inside Canopy Skirts" they would work on the pre May 2001 frames? RV-6 Slider (N616TB Reserved) Finishing kit and waiting for engine Tim Bryan tim(at)bryantechnology.com ________________________________________________________________________________
Subject: Re: logbook on PC
Date: Sep 08, 2001
There are several out there, but the one I use is called DSSLog v1.37 and can be found at http://www.deloach.com/dsslog.htm It's only $19.99 and I've been using it for a couple of years now. It uses the MS Acess database engine so I figured I could always export the data if he ever went out of business. Randy Lervold RV-8, 120.4 hrs., Home Wing group photo with Ed Hicks at the coast today www.rv-8.com Home Wing VAF ----- Original Message ----- From: "Doug Bell" <dbell(at)manisteenational.com> Sent: Saturday, September 08, 2001 5:41 AM Subject: RV-List: logbook on PC > > Hey guys, > I have relative looking for a flight logbook that is pc based so they can > keep duplicate records. Anyone know of such a thing? > Thanks > Doug Bell > 8 qb....golf season is getting close to being over here...:) > > ________________________________________________________________________________
Date: Sep 08, 2001
Tom, I chose the 9A over the 6 as I was more interested in the cross-country and short field performance than I was the aerobatic capability. Had the 7 been available when I was ready to buy, I would have most likely chosen it. Greg -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Thomas Mosher Sent: Friday, September 07, 2001 9:01 PM Subject: RV-List: Opinions Requested I'm curious as to why the RV-9 builders decided on that model (when compared to the RV-6). I'm torn again between the RV-7 and the RV-9A. Thanks Tom N787RV (reserved) ________________________________________________________________________________
Subject: handheld computer question
Date: Sep 08, 2001
I am beginning to consider the purchase of a handheld computer, I'd be interested in recommendations as to brand and model. My situation: It will be a year or more before I'm ready for avaition applications; my workbook publishing involves Apple/Mac computers almost exclusively; primary immediate use will be as auxillary to a new iBook. I don't really want to buy one now and then have to buy a second one in a year or two when we get our 7. I don't mind not having cutting edge tech---I'd rather let some one else find all the bugs, particularly when flying----so which way would you go? iPac, palm pilot, handspring, whatever. Wayne Stiles ________________________________________________________________________________
Date: Sep 08, 2001
--- Rquinn1(at)aol.com wrote: > > Please share this information with the rest of. > Thanks > Rollie & Rod > RV6A > Installing Canopy Hey guys. I have put up some parking brake valve photos at: http://groups.yahoo.com/group/RV-6and6A/files/%20Tips%2C%20Tricks%20%26%20Suggestions/ Let me know if you have questions. Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Date: Sep 08, 2001
Thread-Topic: RV-List: handheld computer question Thread-Index: AcE4eAReJTyY/aPvEdWAOgAIxwleHwAAXrRg
From: "Reeves, Doug" <Douglas.Reeves(at)archongroup.com>
Wayne, I own an iPaq and absolutely love it. I wrote an article a few months ago that is online. It can be read at: http://www.metronet.com/~dreeves/articles/ipaq/ipaq.htm At least it will give my point of view. Regards, Doug R. -----Original Message----- From: d. wayne stiles [mailto:dwstiles(at)hotmail.com] Sent: Saturday, September 08, 2001 9:31 AM Subject: RV-List: handheld computer question I am beginning to consider the purchase of a handheld computer, I'd be interested in recommendations as to brand and model. My situation: It will be a year or more before I'm ready for avaition applications; my workbook publishing involves Apple/Mac computers almost exclusively; primary immediate use will be as auxillary to a new iBook. I don't really want to buy one now and then have to buy a second one in a year or two when we get our 7. I don't mind not having cutting edge tech---I'd rather let some one else find all the bugs, particularly when flying----so which way would you go? iPac, palm pilot, handspring, whatever. Wayne Stiles ________________________________________________________________________________
Date: Sep 08, 2001
)_( Dan ----- Original Message ----- From: "Doug Bell" <dbell(at)manisteenational.com> Sent: Saturday, September 08, 2001 5:41 AM Subject: RV-List: logbook on PC > > Hey guys, > I have relative looking for a flight logbook that is pc based so they can > keep duplicate records. Anyone know of such a thing? > Thanks > Doug Bell > 8 qb....golf season is getting close to being over here...:) > > > > > ________________________________________________________________________________
From: "Murphy, Richard James (Rick)" <rjmurphy1(at)lucent.com>
Subject: more stupid new builder questions...
Date: Sep 08, 2001
RV-4 HS. How do I tell which way the ribs on my HS face (eg inboard or outboard) from my drawings? What should I get for a polishing/buffing wheel to remove those nasty little scratches before priming? What is a recommended combination of cleaner, etcher,primer for the structural HS components? Which was does the "tab" on the HS410 face (I guess it would be up or down) when mounting, and how would I tell this from the drawings? Has there been a change to the HS410? I scanned the archive and there was some discussion to a change in 99. Or is it just when matching to the fuse? For anyone else that has an older RV4 kit the HS/VS bearing brackets 411/12/13 are available from Vans pre-build, out of steel instead of the angle alum that came with older kits. Should be quicker than cutting, building for only a couple of bucks. thanks for the support, Rick Murphy RV4 HS ________________________________________________________________________________
Date: Sep 08, 2001
Subject: White interior a bad idea?
A recent post on the RV-list caught my attention... I recently bought paint I was planning on using on the interior of my plane. It is almost exactly the same color as Vans powdercoat. I figured if Vans was using it it should be a good choice - but then KostaLewis' post made it sound like it was a bad idea - that it would create a horrible glare on the inside of the canopy. I hadn't thought of that - I thought white would be a good idea because it might stay cooler than a darker color. Has anyone flown in an RV with a white (actually, very light grey) interior? Is the glare bad? No big deal if I made a bad choice - I just have to get new paint and take of the windscreen so I can repaint the roll bar. Matthew 8A finishing kit N48PP reserved ________________________________________________________________________________
Date: Sep 08, 2001
I've flown in two RV-6's with very light grey interiors (rollbar, panel, everything...). Absolutely no problem with glare, so I painted mine the same color (I did use some flattening agent on the panel). Rob Acker (RV-6). > > Has anyone flown in an RV with a > white (actually, very light grey) interior? Is the glare bad? > > No big deal if I made a bad choice - I just have to get new paint and take > of the windscreen so I can repaint the roll bar. ________________________________________________________________________________
Date: Sep 08, 2001
Hi Tom; As has been said, if the "7" had been available, I might have chosen it, simply due to the image that the "9" seems to have garnered as the "little brother" to the "6" & "7". As it turns out, nothing could be further from the truth. I definitely made the right choice for myself. I intend on flying often into bush strips in the mountains, for which I would have been better off with a Murphy Rebel, but I also want to go fast in style (economically), on very long cross country trips (I've built aux. tanks), so the "9" is a great compromise. If aerobatics is a concern, ask yourself how often will you really be doing them and how serious of aerobatics do you want to do. I've occasionally done mild aerobatics (no neg. G's) in a C-150 & C-172, and I will probably do the same in the "9". If I decide I want to do some real aerobatics I will build a Pitts. If you are even considering the "9", then it is probably the right plane for you as it will do something's as well as the "7" and something's allot better. S. Todd Bartrim 13B RV-9 C-FSTB (reserved) Fuselage > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Thomas Mosher > Sent: September 7, 2001 9:01 PM > To: rv-list(at)matronics.com > Subject: RV-List: Opinions Requested > > > I'm curious as to why the RV-9 builders decided on that model > (when compared > to the RV-6). I'm torn again between the RV-7 and the RV-9A. > > Thanks > > Tom > N787RV (reserved) > > ________________________________________________________________________________
Date: Sep 08, 2001
Subject: Re: Tampa Flyin Results
Dear Listers, there were supposed to be 5 aircraft here to give rides to the public. 2 couldn't make it for mechanical reasons. an Europa and a Zenith from Tampa Bay Exec. the other 2 were from Peter O Knight and again they were an Europa and A Zenith and the 3rd was a RV6A from clearwater whom i invided with very little notice. before 10 o'clock, the Europa wouldn't start, and the Zenith broke a breakline. leaving Jim Durling in the beautiful RV6A to give the rides. Many people stepped out wearing the famous RV Grin. I didn't get a chance to ride, so other people could experience flight in a homebuilt aircraft. My brother Bruce said his flight was exilerating and the G's on the takeoff climb will be forever engraved on his face. Personal thanks goes to Jim for going out of his way to graciously give up his Saturday and save the day by being the only plane left flying. If it weren't for weather creeping up at his hometown airport, he would have continued giving rides. fellow, we are building the best aircraft kit on the market, i can't wait to be flying and giving rides myself. keep squishing those rivits, and get that thang flyin. scott tampa rv6a finishing ________________________________________________________________________________
Date: Sep 08, 2001
Subject: Re: White interior a bad idea?
In a message dated 9/8/01 11:54:35 AM Eastern Daylight Time, mgelber(at)pacbell.net writes: << Has anyone flown in an RV with a white (actually, very light grey) interior? Is the glare bad? >> My interior paint is off-white, except for the glareshield and panel which are black. In bright sunlight I get reflections that show in the canopy from various painted surfaces, especially the canopy decks. Not a major probem, but if I was going to do it again, I'd at least use a flattening additive on the paint on the canopy frame and canopy decks. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Sep 08, 2001
What engine are 9a builders choosing? Clifford Begnaud wrote: > > Tom, > It comes down to the mission. > If you want to do aerobatics, well, you know which one to get. > > Most people that buy the 9 probably want a good cross country machine. I > have flown the 9 and several 6's. It was turbulent on every flight and the > difference in stability was noticeable. The 6 is more easily upset from it's > path and seems to wag it's tail. The 9 is just a more stable platform. The > price you pay for this is in the control sensitivity, particularly in the > roll axis. The roll axis of the 9 requires more effort and the roll rate is > not as fast. However, it is still a very sporty airplane and lots of fun to > fly. > If you would like, why not ask the employees at Van's which plane they > prefer to fly when they go cross country to fly-ins etc. Ask Tom Green which > one he likes to fly, ask Van which one he commutes in. Yes, I think the > answer to all these will be the 9. > One other reason that people buy the 9 is for it's slow speed handling and > short field capability. It's true that all RV's can take off and land short, > but the 9 just blows em away. It is really quite amazing how well it handles > at low speeds. I currently own a kitfox and when my 9 is flying, I'll still > be able to go flying with the other kitfoxes around here. None of the 6 > pilots around here can fly with us. The 9 also stalls MUCH MUCH SLOWER than > the other RV's. This is a great safety feature. Particularly if you ever > have to do an off airport emergency landing. > > At the time that I bought the 9, the 7 was not available. The clincher for > me at that time was the higher gross weight rating of the 9 over the 6. Now > the 7 is higher. (you can carry more stuff) > If I had to choose over again, it would be a much more difficult choice > because I really would like to able to do aerobatics. > Regards, > Cliff > www.barefootpilot.com > > > > > I'm curious as to why the RV-9 builders decided on that model (when > compared > > to the RV-6). I'm torn again between the RV-7 and the RV-9A. > > > > Thanks > > > > Tom > > N787RV (reserved) > > > ________________________________________________________________________________
Date: Sep 08, 2001
>Has anyone flown in an RV with a white (actually, very light grey) interior? Is the glare bad? Matthew: Suzie Q has medium gray metal flake inside. I don't seem to get much reflection from the interior itself, which may have to do with not much of it in the area that reflects up into the canopy, and that it is not a really light gray, and is slightly flat. The main problems, I think, are bright shinny surfaces, especially chrome, and stuff that sticks up into the vision area, such as the roll-over structure on the -4. The -6/7/9 may not have as much of a problem as the canopy is a different shape and you don't have a back seat passenger. Don't know; never been in one. One of the first large canopy equiped tandem homebuilts was the EZ series. The interior paint recommended was that (awful) flat, multicolored paint, the name of which I can't remember. Part of that recommendation was to avoid canopy reflections. And a lot of them are finished with that (awful) paint. Reflections on the canopy are not a serious problem, but tend to be quite annoying, especially if you have to look at them a lot. Which means if you fly a lot. There was a part of my GPS that was black but shinny black and reflected exactly where I looked out most of the time. It has since been made less shinny and it was a great improvement. A small shiny area reflects on a lot of the canopy because of the curvature, basically a concave mirror. And anything that distracts from the fantastic vision you get through these canopies should be avoided. Oh: I think a glossy white interior in a -4/8 is not a good idea. IMHO. Michael RV-4 N232 Suzie Q ________________________________________________________________________________
Date: Sep 08, 2001
Subject: Re: more stupid new builder questions...
> I just started building an older RV-4 kit after finishing my RV-6A. Some of my drawings date from 12-8-80 and others are updated to 1-1-92. I ordered an update plan set from Van's a month ago but have not received them yet. > Q. How do I tell which way the ribs on my HS face (eg inboard or > outboard) from my drawings? > A. The ribs webs are shown as dashed lines near the edge of the rib on a top view. This is shown on drawing 3a near the top of the drawing on the left side of the HS. It is not shown on the right side which is skinned. > > Q. What should I get for a polishing/buffing wheel to remove those > nasty little scratches before priming? > A. Each person probably does this differently. I don't buff out minor scratches that are not through the alcad. I use emery cloth or the small 3M wheel in a die grinder for larger ones. > > Q. What is a recommended combination of cleaner, etcher,primer for the > structural HS components? > A. It depends on your comfort level. Clean with a solvent before scuffing with a 3M pad so you don't rub in some contamination. Etch with aluminum prep. Alodine. Paint with epoxy primer. I think this is the best - also adds a lot of time and some weight. This is probably an overkill if you don't live in a coastal area. > > Q. Which was does the "tab" on the HS410 face (I guess it would be up > or down) when mounting, and how would I tell this from the drawings? > A. The tab goes up. It connects to the spar on the VS. It will be easier to connect if you put the bend in the approximate angle before riveting to the HS spar. > > Q. Has there been a change to the HS410? I scanned the archive and > there was some discussion to a change in 99. Or is it just when matching to > the fuse? > A. HS410 has changed on later plans. The change is not for structural reasons, it is to make it easier to mate with the VS. I left mine as originally designed. Ken RV-6A N94KB http://www.mninter.net/~kbeene/ ________________________________________________________________________________
Date: Sep 08, 2001
Weird...my link got stripped out...try this: http://www.logshare.com www.logshare.com In case the links above get stripped out by the list server, go to: www . logshare . com Logshare is free and has lots of cool features like currency email reminders, etc. )_( Dan ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Sent: Saturday, September 08, 2001 8:21 AM Subject: Re: RV-List: logbook on PC > > > )_( Dan > > ----- Original Message ----- > From: "Doug Bell" <dbell(at)manisteenational.com> > To: > Sent: Saturday, September 08, 2001 5:41 AM > Subject: RV-List: logbook on PC > > > > > > Hey guys, > > I have relative looking for a flight logbook that is pc based so they can > > keep duplicate records. Anyone know of such a thing? > > Thanks > > Doug Bell > > 8 qb....golf season is getting close to being over here...:) > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 26, 2001
Matt, My -6 instrument panel couldn't be lighter. It is offwhite and grossy. The rest of the interior (seat cushions, side panels, baggage compartment) are also light but slightly darker. No problems. Of course your -8 would have more curvature to the canopy. Not sure what effect that would have. Anh N985VU -6 Marylan > >A recent post on the RV-list caught my attention... I recently bought paint >I was planning on using on the interior of my plane. It is almost exactly >the same color as Vans powdercoat. I figured if Vans was using it it should >be a good choice - but then KostaLewis' post made it sound like it was a bad >idea - that it would create a horrible glare on the inside of the canopy. I >hadn't thought of that - I thought white would be a good idea because it >might stay cooler than a darker color. Has anyone flown in an RV with a >white (actually, very light grey) interior? Is the glare bad? > >No big deal if I made a bad choice - I just have to get new paint and take >of the windscreen so I can repaint the roll bar. > >Matthew >8A finishing kit >N48PP reserved > > ________________________________________________________________________________
Date: Sep 08, 2001
snip Ask Tom Green which one he likes to fly, ask Van which one he commutes in. Yes, I think the answer to all these will be the 9. snip Cliff, I saw Van commuting in the blue RV-8/Franklin when we were at Homecoming......Sure didn't look like an RV-9a to me. Laird ________________________________________________________________________________
Date: Sep 08, 2001
Thanks guys - the one thing I have decided on is a 150/160 HP O-320 for an engine (I should have bought that O-320 with 475 TTSN I saw in the paper two months ago for $7,000). So, I figure, it's better to go with the RV-9A with the O-320 than an RV-7A with the same engine. Tom N787RV (reserved) ----- Original Message ----- From: "Owens, Laird" <Owens(at)aerovironment.com> Sent: Saturday, September 08, 2001 1:36 PM Subject: RE: RV-List: Opinions Requested > > > > snip > > Ask Tom Green which > one he likes to fly, ask Van which one he commutes in. Yes, I think the > answer to all these will be the 9. > > snip > > Cliff, > > I saw Van commuting in the blue RV-8/Franklin when we were at Homecoming......Sure didn't look like an RV-9a to me. > > Laird > > ________________________________________________________________________________
From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com>
Date: Sep 08, 2001
-----Original Message----- From: Matthew Gelber <mgelber(at)pacbell.net> Subject: RV-List: White interior a bad idea? > >A recent post on the RV-list caught my attention... I recently bought paint >I was planning on using on the interior of my plane. It is almost exactly >the same color as Vans powdercoat. Matthew: Chrome would be not so good because of the direct reflection to the eye. The problem with paint colors is not so much the direct reflections as it is the reflections in the canopy. I have a medium gray on my -4 and it still makes viewing difficult sometimes and photography even worse. My next project will have a darker gray interior in an effort to reduce the contrast between the interior and the outside light, especially in direct sunlight. The powdercoated light gray parts I have for the -8 will be changed. Gordon Comfort N363GC ________________________________________________________________________________
Date: Sep 08, 2001
Thanks for the quick responses on the pc logbook. I have a happy relative Doug Bell 8qb Manistee MI ----- Original Message ----- From: Dan Checkoway <dan(at)rvproject.com> Sent: Saturday, September 08, 2001 2:17 PM Subject: Re: RV-List: logbook on PC > > Weird...my link got stripped out...try this: > > http://www.logshare.com > www.logshare.com > > In case the links above get stripped out by the list server, go to: www . > logshare . com > > Logshare is free and has lots of cool features like currency email > reminders, etc. > > )_( Dan > > > ----- Original Message ----- > From: "Dan Checkoway" <dan(at)rvproject.com> > To: > Sent: Saturday, September 08, 2001 8:21 AM > Subject: Re: RV-List: logbook on PC > > > > > > > > )_( Dan > > > > ----- Original Message ----- > > From: "Doug Bell" <dbell(at)manisteenational.com> > > To: > > Sent: Saturday, September 08, 2001 5:41 AM > > Subject: RV-List: logbook on PC > > > > > > > > > > Hey guys, > > > I have relative looking for a flight logbook that is pc based so they > can > > > keep duplicate records. Anyone know of such a thing? > > > Thanks > > > Doug Bell > > > 8 qb....golf season is getting close to being over here...:) > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 08, 2001
From: Charlie and Tupper England <cengland(at)netdoor.com>
Matthew Gelber wrote: > > > A recent post on the RV-list caught my attention... I recently bought paint > I was planning on using on the interior of my plane. It is almost exactly > the same color as Vans powdercoat. I figured if Vans was using it it should > be a good choice - but then KostaLewis' post made it sound like it was a bad > idea - that it would create a horrible glare on the inside of the canopy. I > hadn't thought of that - I thought white would be a good idea because it > might stay cooler than a darker color. Has anyone flown in an RV with a > white (actually, very light grey) interior? Is the glare bad? > > No big deal if I made a bad choice - I just have to get new paint and take > of the windscreen so I can repaint the roll bar. > > Matthew > 8A finishing kit > N48PP reserved > N4375J had an all-white interior including the instrument panel when I bought it. It was never an issue until someone on this list was cruel enough to point out the problems. :-) Charlie ________________________________________________________________________________
Date: Sep 08, 2001
"Owens, Laird" wrote: > > > > snip > > Ask Tom Green which > one he likes to fly, ask Van which one he commutes in. Yes, I think the > answer to all these will be the 9. > > snip > > Cliff, > > I saw Van commuting in the blue RV-8/Franklin when we were at Homecoming......Sure didn't look like an RV-9a to me. > > Laird > Living close to Van I see him fly whatever is left over after the employees take their picks. :-) ________________________________________________________________________________
Subject: parking brake valve where?
Date: Sep 08, 2001
Bert, I have also posted a few pictures of my Matco parking brake valve installation. It is in an RV-9 but I imagine the RV-6 would be similar. Here is the link: http://www.execpc.com/~cjh/brake_valve.html Chris Heitman Dousman WI RV-9A N94ME (reserved) wiring and building hangar -----Original Message----- The main question, where in heavens you bolt this little devil. ________________________________________________________________________________
Date: Sep 08, 2001
chris where did you get the parking brake? who sells them, that i cool set up! scott tampa ________________________________________________________________________________
Date: Sep 08, 2001
> >Matthew Gelber wrote: >> A recent post on the RV-list caught my attention... I recently bought paint >-----snip------ >> white (actually, very light grey) interior? Is the glare bad? >> >> No big deal if I made a bad choice - I just have to get new paint and take >> of the windscreen so I can repaint the roll bar. >> >> Matthew >> 8A finishing kit >> N48PP reserved >> >N4375J had an all-white interior including the instrument >panel when I bought it. It was never an issue until someone >on this list was cruel enough to point out the problems. :-) > >Charlie Matthew and list, My Carrera Ultralight had an all white glossy panel when I bought it. It has a long sloping windshield, with lots of panel below the plexiglas. There is a small black turnandbank indicator in the middle of the white panel, and in certain lighting conditions (most of them, actually), I noticed there was a little peephole that had alot less glare where the reflection of the turn and bank indicator was...Now my panel is all flat black, and MUCH better with MUCH less glare...wouldn't have it any other way, unless my plane was a hangar queen, which it's not... Randy Simpson Carrera UL flyer titanium Ti-down maker http://www.airtimemfg.com p.s. Still have the RV Grin from Mike Segar's demo flight he gave me for a titanium Ti-down kit...*smile* WOO HOO! that was AWESOME...thanks Mike! pp.s. My best flying bud just bought an RV-6a. When he gets the bogus alternator problem fixed, that RV grin will permanently be pasted on my face... ________________________________________________________________________________
Date: Sep 08, 2001
Subject: Some Interesting Data (Long)
"socal-rvlist" Hi all, Since I converted over to a Hartzell prop on my O-360/RV-6, I've wanted to do some good data collection. I finally got a chance to go out last evening and collect a little. (Like my boss sez...."Data is easy, GOOD data is hard"). Thought some of you might be interested. Two areas of interest to me are top speed (I want to start doing a little drag reduction work soon and need a baseline speed) and range/endurance. I'm planning on flying to the Las Cruces RV get together this weekend and it's a 600 mile flight from LA. I wanted to see if I could make it without stopping. I've always been conservative when flight planning, guessing 3.5 hrs (10 GPH with reserve) and about a 600 mile range, but I've wanted to nail down the real numbers for my airplane. So I went out and burned some gas trying to figure it out. I came back with some interesting numbers. The test was flown at 8000 feet density altitude (altimeter set to 29.92 and corrected for OAT, which was 22 C, which meant I'd fly at 5875 feet) and at different airspeeds to collect the fuel flow information. I then put that into a graph to determine best range and endurance. Engine RPM was 2400 and the engine leaned to peak on the hottest cylinder (I know....that may not be the leanest cylinder). Know errors that I can't account for right now are static and instrumentation errors, so the numbers may be a little off here or there. After selecting a power setting and airspeed, I flew the airspeed and looked for elevation changes, and then adjust the power accordingly. I'd then lean to peak, then let everything stabilize and again make any small adjustments to the power setting. After getting to that stage, I'd note fuel flow, IAS, MP, and then do a 3 way GPS run to get TAS. I ran all these data points on one flight, so the upper speeds may be off a little due to a lower aircraft weight due to the gas being used during the flight. (I started at the lower airspeeds first). I flew points between 90 mph IAS and full throttle at 10 mph intervals. It turned out to be a good evening with almost no turbulence and under 3 mph of wind at the test altitude. I was pleased with the data I got, as it all fit pretty well and came up with some believable curves (i.e. no data points way off the fit curve). After doing some number crunching and graphing, it looks like the max endurance of the airplane comes at 100 mph IAS/112 mph TAS with a fuel flow of 5.0 GPH. Assuming a 6 gal reserve, that leaves 32 gallons usable. That gives a 6.4 hr endurance (my butt can't sit in the seat that long) and a 716 mile range, which is 22.4 MPG. I should note that the engine wasn't very happy at this power setting, as it would skip every once in a while (probably a lean miss). Also the fuel flow meter was a little flaky near these power settings, fluctuating between 4 to 6. I just took the average of what I saw. It wasn't until I was flowing around 6 GPH that the flow meter settled down. The best range comes at 125 mph IAS/ 148 mph TAS with a fuel flow of 5.5 GPH. Using the same reserve, I get 5.8 hrs and a 858 mile range, which is 26.8 MPG. (I still can't sit in the seat that long). So pushing it up a little to 8 GPH yields a 4 hour endurance (not including reserve) at 160 mph IAS/ 185 TAS for a 740 mile range and 23.1 MPG. Full throttle comes out at 9.6 GPH and 174 mph IAS/200 TAS with a 3.3 hr endurance and a 660 mile range and a 20.6 MPG The last test was full throttle/2700 rpm and it was 11.7 GPH and 207 TAS. This was only one data point on this day, I need to do this several more times to average the speeds to try to get a more accurate number, but it's a start. This is a about an 11 mph speed gain over the Sensenich 72FM fixed pitch prop I had on before (which was an 83" pitch). The main difference is that I can use full throttle with the Hartzell. At 8000 DA and the Sensenich, I still had another 3" of MP left to go, but would be at the 2700 rpm limit. Again, this was data taken on this one day, for my airplane, and is probably subject to several different errors (my flying included), but it should be close. It does provide an interesting comparison of FF vs TAS. I'd like to repeat this test at a higher altitude and see some of the effects as well, but that'll have to wait until another day. Laird RV-6 340 hrs SoCal ________________________________________________________________________________
Date: Sep 08, 2001
Flying Magazine (specifically Thomas Block) alluded to airliner cockpit colors in a recent article on Aeroflot. If memory serves (as it often doesn't), Boeing uses a gray color and Ilyushin uses something that seemed like a sky blue. Check the article before quoting me. Rick McCraw ________________________________________________________________________________
Date: Sep 08, 2001
From: Gary & Carolyn Zilik <zilik(at)bewellnet.com>
Subject: Re: Bart Lalonde Engines
Norman wrote: > > Are Bart's engines considered better than a new OEM from Van? Some people, including myself, would say yes. > > > How many ponies does one of his O-360's end up with if converted to > Airflow Performance fuel injection and dual Lasar electronic ignitions? 180 HP. Fuel injection and electronic ignition do not make more horsepower. > > > If money was no object, what would you put in a RV6A? > (Don't read me wrong, I'm a working class guy, I just want to know what > is the best out there and SMA hasn't answered any of my emails in > months) Bart's O-360 with Superior Millenium cylinders flow matched, 10:1 pistons, Carburator. Standard Mags. > > ________________________________________________________________________________
Date: Sep 08, 2001
Wayne, I've been using computers (a *lot*, mostly professionally) since around 1971. I haven't used any handhelds but a Palm, but I have to say the Palm OS is the most bullet-proof operating system I've seen, small computer or large. For me, reliability beats pizzazz any day. (That said, I don't know how Windows CE is.) Rick McCraw ________________________________________________________________________________
Date: Sep 08, 2001
Scott, I bought it from Aircraft Spruce for $98.80 on 2/27/01. They also carry the Cleveland valve but it was quite a bit more expensive. The Matco seems well made. Speaking of Aircraft Spruce, I just happened to notice that they charged me 6% sales tax at Oshkosh instead of 5% like all the other vendors were charging. So let's see, if they did $500,000 in sales during the show that's an extra $5,000. Probably paid for the booth rental. Chris Heitman Dousman WI RV-9A N94ME (reserved) http://www.execpc.com/~cjh/brake_valve.html -----Original Message----- where did you get the parking brake? who sells them, that i cool set up! scott tampa ________________________________________________________________________________
Date: Sep 08, 2001
Subject: Re: Some Interesting Data (Long)
Laird, Was this data with a Constant Speed Hartzell? Or a Fixed pitch. And what does your plane weigh? Don ________________________________________________________________________________
Date: Sep 08, 2001
Subject: F1 rocket fit for sale still for sale MUST SELL
F1 rocket kit for sale Kit is partionally finished, excellent workmanship as the work was done by team rocket. Kit includes complete RV8 tail. Just has to be mounted and finished. Kit also includes the following Ameri king ELT Vetterman Stainless exhust heat shielding areoflash strobes I have pictures that can be emailed to anyone. I have about 35000 into the kit. I need to make up for a short fall in income since i am owed 30,000 by a company that went bankrupt. Please email me or call for details on the kit. Chris wilcox (920) 858-7561 ________________________________________________________________________________
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
Subject: Re: Weight & Balance NOW WHAT???
Date: Sep 08, 2001
Listers: I just did my weight computations for my RV-6 and found that the left main gear is 17# heavier than the right main. I switched the aircraft scales from side to side and reweighed the aircraft - same thing. I have one landing light on the port wing, and all electric gyros on the left side of the panel. Would these items acount for the extra weight on the port side? Am I just being picky? The last RV-6 built in this area came out within two pounds side to side so I am a bit dismayed to see these numbers on my aircraft. The aircraft came out at 1072# no fuel, all painted and upholstered. How does this compare to the rest of your aircraft? Your input is appreciated. Douglas G. Murray Southern Alberta RV-6 really getting close to final inspection time ________________________________________________________________________________
Date: Sep 08, 2001
Ken, Thanks for the info. I have another stupid question... I'm ready to cut the lightening holes in my HS ribs. How much is acceptable to cut out? My fly cutter makes its smallest cut at 1 3/4''. It looks to me like the interior of the flange in the rib is 1 1/2'', how much am I allowed to cut out of the ribs before I've cut too much. Rick > ---------- > From: kenneth beene[SMTP:kbeene(at)citilink.com] > Reply To: rv-list(at)matronics.com > Sent: Saturday, September 08, 2001 1:54 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: more stupid new builder questions... > > > > > > > I just started building an older RV-4 kit after finishing my RV-6A. Some > of my drawings > date from 12-8-80 and others are updated to 1-1-92. I ordered an update > plan set from > Van's a month ago but have not received them yet. > > > Q. How do I tell which way the ribs on my HS face (eg inboard or > > outboard) from my drawings? > > > > A. The ribs webs are shown as dashed lines near the edge of the rib on a > top view. > This is shown on drawing 3a near the top of the drawing on the left side > of the HS. It > is not shown on the right side which is skinned. > > > > > Q. What should I get for a polishing/buffing wheel to remove > those > > nasty little scratches before priming? > > > > A. Each person probably does this differently. I don't buff out minor > scratches that > are not through the alcad. I use emery cloth or the small 3M wheel in a > die grinder for > larger ones. > > > > > Q. What is a recommended combination of cleaner, etcher,primer > for the > > structural HS components? > > > > A. It depends on your comfort level. Clean with a solvent before > scuffing with a 3M > pad so you don't rub in some contamination. Etch with aluminum prep. > Alodine. Paint > with epoxy primer. I think this is the best - also adds a lot of time and > some weight. > This is probably an overkill if you don't live in a coastal area. > > > > > Q. Which was does the "tab" on the HS410 face (I guess it would > be up > > or down) when mounting, and how would I tell this from the drawings? > > > > A. The tab goes up. It connects to the spar on the VS. It will be > easier to connect > if you put the bend in the approximate angle before riveting to the HS > spar. > > > > > Q. Has there been a change to the HS410? I scanned the archive > and > > there was some discussion to a change in 99. Or is it just when matching > to > > the fuse? > > > > A. HS410 has changed on later plans. The change is not for structural > reasons, it is > to make it easier to mate with the VS. I left mine as originally > designed. > > Ken > RV-6A N94KB > http://www.mninter.net/~kbeene/ > > > > > > ________________________________________________________________________________
Date: Sep 08, 2001
Matthew>> My panel and interior are White. For a look go to Steve Davis Web Site @ http://members.aol.com/panelcut/RVpanels.htm No Problem with glare after 67 Hours Don Eaves RV6 "Has anyone flown in an RV with a white (actually, very light grey) interior? Is the glare bad?" ________________________________________________________________________________
Date: Sep 08, 2001
I think that multi-flecked flat black paint is used on pickup-truck beds and in auto trunks. Found it made the panel very busy indeed.. Scott in Vancouver ----- Original Message ----- From: KostaLewis <mikel(at)dimensional.com> Sent: Saturday, September 08, 2001 10:23 AM Subject: Re: RV-List: White interior a bad idea? > > >Has anyone flown in an RV with a white (actually, very light grey) > interior? Is the glare bad? > > Matthew: Suzie Q has medium gray metal flake inside. I don't seem to get > much reflection from the interior itself, which may have to do with not much > of it in the area that reflects up into the canopy, and that it is not a > really light gray, and is slightly flat. The main problems, I think, are > bright shinny surfaces, especially chrome, and stuff that sticks up into the > vision area, such as the roll-over structure on the -4. The -6/7/9 may not > have as much of a problem as the canopy is a different shape and you don't > have a back seat passenger. Don't know; never been in one. > > One of the first large canopy equiped tandem homebuilts was the EZ series. > The interior paint recommended was that (awful) flat, multicolored paint, > the name of which I can't remember. Part of that recommendation was to > avoid canopy reflections. And a lot of them are finished with that (awful) > paint. > > Reflections on the canopy are not a serious problem, but tend to be quite > annoying, especially if you have to look at them a lot. Which means if you > fly a lot. There was a part of my GPS that was black but shinny black and > reflected exactly where I looked out most of the time. It has since been > made less shinny and it was a great improvement. A small shiny area reflects > on a lot of the canopy because of the curvature, basically a concave mirror. > And anything that distracts from the fantastic vision you get through these > canopies should be avoided. > > Oh: I think a glossy white interior in a -4/8 is not a good idea. IMHO. > > Michael > RV-4 N232 Suzie Q > > ________________________________________________________________________________
Date: Sep 08, 2001
--- "Douglas G. Murray" wrote: > > > Listers: > > I just did my weight computations for my RV-6 and found that the left > main > gear is 17# heavier than the right main. I switched the aircraft > scales from > side to side and reweighed the aircraft - same thing. I have one > landing > light on the port wing, and all electric gyros on the left side of > the > panel. Would these items acount for the extra weight on the port > side? Am I > just being picky? The last RV-6 built in this area came out within > two > pounds side to side so I am a bit dismayed to see these numbers on my > aircraft. The aircraft came out at 1072# no fuel, all painted and > upholstered. How does this compare to the rest of your aircraft? > > Your input is appreciated. > > Douglas G. Murray > Southern Alberta > > RV-6 really getting close to final inspection time Doug: How did you get it so close? My RV-6 has the following data points. Right 505 @ 60 Left 524 @ 59.8125 Tail 65 @ 239.75 Total 1094 This is 8 pounds heaver than it was without paint. Includes Sliding canopy, basic IFR (Vacuum gyro + electric TC), RMD landing lights, carpeting, seats, arm rests, 5 quarts oil, and 1 gallon of unusable fuel (1/2 gallon each side). Been flying that way since 19 September 1997. Will hit 1,000 hours before the end of the year. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 942+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com ________________________________________________________________________________
Subject: Hartzell CS prop
Date: Sep 08, 2001
Does anybody know if I am correct in thinking that the prop blade numbers (i.e. F7663) mean that the pitch in full coarse is 76" and in full fine is 63"? Greg Tanner RV-9A Tanks SER #90186 N80BR RESERVED O-320 D1A ________________________________________________________________________________
Date: Sep 08, 2001
> How does this compare to the rest of your aircraft? > My RV-6A is 1056 lb.. Painted, O-320 with wood prop and IFR panel. The right gear is 5.9 lb. heavier than the left. It is important to roll the plane on to the scales. Ken ________________________________________________________________________________
Date: Sep 08, 2001
> > > I'm ready to cut the lightening holes in my HS ribs. How much is acceptable > to cut out? > > My fly cutter makes its smallest cut at 1 3/4''. It looks to me like the > interior of the flange in the rib is 1 1/2'', how much am I allowed to cut > out of the ribs before I've cut too much. I cut mine to 1.4". Cut to the inside of the embossed area. If your fly cutter is too large, use your Unibit and cut to 1" or just leave these 6 holes uncut. Ken N94KB http://www.mninter.net/~kbeene/ ________________________________________________________________________________
Date: Sep 08, 2001
I would venture to say that maybe some of your equipment is more to one side than the other BUT in all probability if you establish a fuselage center line on the floor and measure how far out from this center line the main wheel distances, you might fine that one wheel is further from the center line than the other. Same goes for the nose or tail wheel, it might be off from the center of the fuselage thus loading one side more than the other. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Gary A. Sobek" <rv6flier(at)yahoo.com> Sent: Saturday, September 08, 2001 9:40 PM Subject: Re: RV-List: Re: Weight & Balance NOW WHAT??? --- "Douglas G. Murray" wrote: > > > Listers: > > I just did my weight computations for my RV-6 and found that the left > main > gear is 17# heavier than the right main. I switched the aircraft > scales from > side to side and reweighed the aircraft - same thing. I have one > landing > light on the port wing, and all electric gyros on the left side of > the > panel. Would these items acount for the extra weight on the port > side? Am I > just being picky? The last RV-6 built in this area came out within > two > pounds side to side so I am a bit dismayed to see these numbers on my > aircraft. The aircraft came out at 1072# no fuel, all painted and > upholstered. How does this compare to the rest of your aircraft? > > Your input is appreciated. > > Douglas G. Murray > Southern Alberta > > RV-6 really getting close to final inspection time Doug: How did you get it so close? My RV-6 has the following data points. Right 505 @ 60 Left 524 @ 59.8125 Tail 65 @ 239.75 Total 1094 This is 8 pounds heaver than it was without paint. Includes Sliding canopy, basic IFR (Vacuum gyro + electric TC), RMD landing lights, carpeting, seats, arm rests, 5 quarts oil, and 1 gallon of unusable fuel (1/2 gallon each side). Been flying that way since 19 September 1997. Will hit 1,000 hours before the end of the year. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 942+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com ________________________________________________________________________________
Date: Sep 08, 2001
Mine was 8 pounds difference on both sides. I wouldn't sweat the difference. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Douglas G. Murray" <dgmurray(at)telusplanet.net> Sent: Saturday, September 08, 2001 7:15 PM Subject: RV-List: Re: Weight & Balance NOW WHAT??? > > Listers: > > I just did my weight computations for my RV-6 and found that the left main > gear is 17# heavier than the right main. I switched the aircraft scales from > side to side and reweighed the aircraft - same thing. I have one landing > light on the port wing, and all electric gyros on the left side of the > panel. Would these items acount for the extra weight on the port side? Am I > just being picky? The last RV-6 built in this area came out within two > pounds side to side so I am a bit dismayed to see these numbers on my > aircraft. The aircraft came out at 1072# no fuel, all painted and > upholstered. How does this compare to the rest of your aircraft? > > Your input is appreciated. > > Douglas G. Murray > Southern Alberta > > RV-6 really getting close to final inspection time > > ________________________________________________________________________________
Date: Sep 08, 2001
Subject: Re: Hartzell CS prop
> >Does anybody know if I am correct in thinking that the prop blade numbers >(i.e. F7663) mean that the pitch in full coarse is 76" and in full fine is >63"? > >Greg Tanner >RV-9A Tanks >SER #90186 N80BR RESERVED >O-320 D1A Greg, I don't think their numbers work like that. They have too many other blade numbers that wouldn't fit that mold (e.g F7693, F7214, etc). In any case, the prop hub has fine and coarse pitch stops that are set specifically for each application. This gives the required pitch change range for that aircraft type, while minimizing the effects of failures that take you to one of the pitch stops. So, the pitch range of a prop with F7663 blades will depend on how the hub is set up. Hartzell has some interesting info on their web site. Go to: http://www.hartzellprop.com/resource_library/sitelinks_appguide.htm Type Van into the Aircraft Manufacturer field, leave the rest blank and submit the form. Take care, Kevin Horton RV-8 (engine installation) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://eccentrix.com/misc/rv8/ ________________________________________________________________________________
Date: Sep 08, 2001
> >Listers: > >I just did my weight computations for my RV-6 and found that the left main >gear is 17# heavier than the right main. I switched the aircraft scales from >side to side and reweighed the aircraft - same thing. I have one landing >light on the port wing, and all electric gyros on the left side of the >panel. Would these items acount for the extra weight on the port side? Am I >just being picky? The last RV-6 built in this area came out within two >pounds side to side so I am a bit dismayed to see these numbers on my >aircraft. The aircraft came out at 1072# no fuel, all painted and >upholstered. How does this compare to the rest of your aircraft? > >Your input is appreciated. > >Douglas G. Murray >Southern Alberta Oh oh. You'd better let me fly it for a year or two to make sure there are no issues caused by that asymmetry. I'll do an extensive test program and report back to you. :-) I think you are worrying too much. Go flying. Kevin Horton RV-8 (engine installation) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://eccentrix.com/misc/rv8/ ________________________________________________________________________________
Date: Sep 08, 2001
Thanks Kevin, Next question. What does "LOW/LOWPP" and "FEATHER/HIGH" mean on their chart. Greg -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kevin Horton Sent: Saturday, September 08, 2001 8:45 PM Subject: Re: RV-List: Hartzell CS prop > >Does anybody know if I am correct in thinking that the prop blade numbers >(i.e. F7663) mean that the pitch in full coarse is 76" and in full fine is >63"? > >Greg Tanner >RV-9A Tanks >SER #90186 N80BR RESERVED >O-320 D1A Greg, I don't think their numbers work like that. They have too many other blade numbers that wouldn't fit that mold (e.g F7693, F7214, etc). In any case, the prop hub has fine and coarse pitch stops that are set specifically for each application. This gives the required pitch change range for that aircraft type, while minimizing the effects of failures that take you to one of the pitch stops. So, the pitch range of a prop with F7663 blades will depend on how the hub is set up. Hartzell has some interesting info on their web site. Go to: http://www.hartzellprop.com/resource_library/sitelinks_appguide.htm Type Van into the Aircraft Manufacturer field, leave the rest blank and submit the form. Take care, Kevin Horton RV-8 (engine installation) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://eccentrix.com/misc/rv8/ ________________________________________________________________________________
Date: Sep 08, 2001
If you want to find out the certification specs on an HC-C2YL-1BF/F7663A-4 (the one Van shows in the accessories catalog) take a look at Type Certificate Data Sheet P-920 (unfortunately the damn FAA site that the TCDS are on is down (again)). Tom ----- Original Message ----- From: "Kevin Horton" <khorton(at)cyberus.ca> Sent: Saturday, September 08, 2001 10:44 PM Subject: Re: RV-List: Hartzell CS prop > > > > >Does anybody know if I am correct in thinking that the prop blade numbers > >(i.e. F7663) mean that the pitch in full coarse is 76" and in full fine is > >63"? > > > >Greg Tanner > >RV-9A Tanks > >SER #90186 N80BR RESERVED > >O-320 D1A > > > Greg, > > I don't think their numbers work like that. They have too many other blade > numbers that wouldn't fit that mold (e.g F7693, F7214, etc). > > In any case, the prop hub has fine and coarse pitch stops that are set > specifically for each application. This gives the required pitch change > range for that aircraft type, while minimizing the effects of failures that > take you to one of the pitch stops. So, the pitch range of a prop with > F7663 blades will depend on how the hub is set up. > > Hartzell has some interesting info on their web site. Go to: > > http://www.hartzellprop.com/resource_library/sitelinks_appguide.htm > > Type Van into the Aircraft Manufacturer field, leave the rest blank and > submit the form. > > Take care, > > > Kevin Horton RV-8 (engine installation) > khorton(at)cyberus.ca (613) 821-7862 (home) > Ottawa, Canada (613) 952-4319 (work) > http://eccentrix.com/misc/rv8/ > > ________________________________________________________________________________
Date: Sep 08, 2001
Hi Douglas, Just did mine also. Mine came out with 9 lbs difference between the mains. Empty weight without paint was 1,070 lbs. Its heavy with leather seats, insulation and carpeting and padding plus it has a backup battery. It has basic IFR vacuum gyros and elect T&B. It also has a navaid and the servo is mounted in the left wingtip. Its heavy but its mine ;>) Eric Newton - Long Beach, MS RV-6A - N57ME (final details before inspection) www.ericsrv6a.com -----Original Message----- From: "owner-rv-list-server(at)matronics.com" <owner-rv-list-server(at)matronics.com> on behalf of "Douglas G. Murray" Subject: RV-List: Re: Weight & Balance NOW WHAT??? Listers: I just did my weight computations for my RV-6 and found that the left main gear is 17# heavier than the right main. I switched the aircraft scales from side to side and reweighed the aircraft - same thing. I have one landing light on the port wing, and all electric gyros on the left side of the panel. Would these items acount for the extra weight on the port side? Am I just being picky? The last RV-6 built in this area came out within two pounds side to side so I am a bit dismayed to see these numbers on my aircraft. The aircraft came out at 1072# no fuel, all painted and upholstered. How does this compare to the rest of your aircraft? Your input is appreciated. Douglas G. Murray Southern Alberta RV-6 really getting close to final inspection time ________________________________________________________________________________
Date: Sep 09, 2001
Greg No, according to my owner's manual the blade numbers decode as follows: The prefix can be up to 3 letters. "F" is large pitch change knob Y shank The first 2 or 3 digits indicate initial design diameter in inches The last 2 digits indicate basic model or template. The suffix letters are various modifications. The dash number is the diameter reduction from the basic design. A letter following the dash number indicates a tip configuration mod. So the O-320 F7663-4 blades are 72 inch diameter (76" initial minus 4") with no mods to the basic design. My O-360 F7666A4 blades were 72" dia. with a blade cuff modification. The hub identification is much more complex but I don't see anything that addresses pitch in inches, only as configuration types. The actual pitch limits are set by the high and low pitch stops and can be adjusted. Regards, Greg Young RV-6 N6GY Houston (DWH) replacement pending searching for Navion > > Does anybody know if I am correct in thinking that the prop > blade numbers > (i.e. F7663) mean that the pitch in full coarse is 76" and in > full fine is > 63"? > > Greg Tanner > RV-9A Tanks > SER #90186 N80BR RESERVED > O-320 D1A ________________________________________________________________________________
Date: Sep 09, 2001
It is probably the landing light primarily. If I hang a 3 pound item on the wing tip and the tires are 6 feet apart, the left tire will weigh about 15 pound more. Not a big deal, go fly and enjoy it. Try weighing it with you solo if you want to really see a big difference! Bernie Kerr, 6A, SE Fla From: "Douglas G. Murray" <dgmurray(at)telusplanet.net> Sent: Saturday, September 08, 2001 10:15 PM Subject: RV-List: Re: Weight & Balance NOW WHAT??? > > Listers: > > I just did my weight computations for my RV-6 and found that the left main > gear is 17# heavier than the right main. I switched the aircraft scales from > side to side and reweighed the aircraft - same thing. I have one landing > light on the port wing, and all electric gyros on the left side of the > panel. Would these items acount for the extra weight on the port side? Am I > just being picky? The last RV-6 built in this area came out within two > pounds side to side so I am a bit dismayed to see these numbers on my > aircraft. The aircraft came out at 1072# no fuel, all painted and > upholstered. How does this compare to the rest of your aircraft? > > Your input is appreciated. > > Douglas G. Murray > Southern Alberta > > RV-6 really getting close to final inspection time > > ________________________________________________________________________________
Date: Sep 09, 2001
Those are the settings of the low and high pitch stops in the hub, in degrees. Kevin > >Thanks Kevin, >Next question. What does "LOW/LOWPP" and "FEATHER/HIGH" mean on their chart. > >Greg > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kevin Horton >Sent: Saturday, September 08, 2001 8:45 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Hartzell CS prop > > > > > >Does anybody know if I am correct in thinking that the prop blade numbers > >(i.e. F7663) mean that the pitch in full coarse is 76" and in full fine is > >63"? > > > >Greg Tanner > >RV-9A Tanks > >SER #90186 N80BR RESERVED > >O-320 D1A > > >Greg, > >I don't think their numbers work like that. They have too many other blade >numbers that wouldn't fit that mold (e.g F7693, F7214, etc). > >In any case, the prop hub has fine and coarse pitch stops that are set >specifically for each application. This gives the required pitch change >range for that aircraft type, while minimizing the effects of failures that >take you to one of the pitch stops. So, the pitch range of a prop with >F7663 blades will depend on how the hub is set up. > >Hartzell has some interesting info on their web site. Go to: > >http://www.hartzellprop.com/resource_library/sitelinks_appguide.htm > >Type Van into the Aircraft Manufacturer field, leave the rest blank and >submit the form. > >Take care, > > >Kevin Horton RV-8 (engine installation) >khorton(at)cyberus.ca (613) 821-7862 (home) >Ottawa, Canada (613) 952-4319 (work) >http://eccentrix.com/misc/rv8/ > > ________________________________________________________________________________
Date: Aug 31, 2001
what section of the country are you located in rick? "Murphy, Richard James (Rick)" wrote: > > RV-4 HS. > > How do I tell which way the ribs on my HS face (eg inboard or > outboard) from my drawings? > > What should I get for a polishing/buffing wheel to remove those > nasty little scratches before priming? > > What is a recommended combination of cleaner, etcher,primer for the > structural HS components? > > Which was does the "tab" on the HS410 face (I guess it would be up > or down) when mounting, and how would I tell this from the drawings? > > Has there been a change to the HS410? I scanned the archive and > there was some discussion to a change in 99. Or is it just when matching to > the fuse? > > For anyone else that has an older RV4 kit the HS/VS bearing brackets > 411/12/13 are available from Vans pre-build, out of steel instead of the > angle alum that came with older kits. Should be quicker than cutting, > building for only a couple of bucks. > > thanks for the support, > > Rick Murphy > RV4 HS > ________________________________________________________________________________
Date: Sep 09, 2001
Mine has a difference of 8lbs from right to left wheel. Is your landing light at or near the wingtip? I would think that with that kind of arm you might get a couple of pounds difference on that side. I have a full-up weight of 1018# with paint, interior, FP metal prop, and partial IFR panel. I was militant about weight during the construction. Ed Bundy - RV6A N427EM 400+ hours 160hp 0320 w/Sensenich 70x78 Eagle, ID ebundy(at)velocitus.net > I just did my weight computations for my RV-6 and found that the left main > gear is 17# heavier than the right main. I switched the aircraft scales from > side to side and reweighed the aircraft - same thing. I have one landing > light on the port wing, and all electric gyros on the left side of the > panel. Would these items acount for the extra weight on the port side? Am I ________________________________________________________________________________
Date: Sep 09, 2001
Subject: Prop Spinner Front Bulkhead
Would like to get the list.wisdom on mounting my spinner on a Sensenich fixed-pitch metal prop. I have the cutouts perfect but it did not intially contact the front bulkhead (the correct bulkhead for the prop). In Tony's "Bingelis on Engines" he recommends pushing the front bulkhead out using washers between prop and bulkhead. I have found two washers gets everything fitting nicely. OTOH, my Technical Counselor is nervous about spacing out the front bulkhead - cites reduced thread count holding on the prop. Those two washers =~ 7/16" thickness. Need help reconciling the two viewpoints. Have seen web sites where folks have built up the front bulkhead with everything from fiberglass to bondo. Tony mentions those as options along with the spacing method... I have to wonder why those folks didn't space out their bulkhead. Anyone spaced theirs with good results (which would be, prop hasn't since flown off the aircraft)? :) Thanks. Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Date: Sep 09, 2001
Hunterdon Cty NJ > ---------- > From: efortner[SMTP:efortner(at)vnet.net] > Reply To: rv-list(at)matronics.com > Sent: Friday, August 31, 2001 2:50 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: more stupid new builder questions... > > > what section of the country are you located in rick? > > "Murphy, Richard James (Rick)" wrote: > > > > > > RV-4 HS. > > > > How do I tell which way the ribs on my HS face (eg inboard or > > outboard) from my drawings? > > > > What should I get for a polishing/buffing wheel to remove those > > nasty little scratches before priming? > > > > What is a recommended combination of cleaner, etcher,primer for > the > > structural HS components? > > > > Which was does the "tab" on the HS410 face (I guess it would be > up > > or down) when mounting, and how would I tell this from the drawings? > > > > Has there been a change to the HS410? I scanned the archive and > > there was some discussion to a change in 99. Or is it just when matching > to > > the fuse? > > > > For anyone else that has an older RV4 kit the HS/VS bearing > brackets > > 411/12/13 are available from Vans pre-build, out of steel instead of the > > angle alum that came with older kits. Should be quicker than cutting, > > building for only a couple of bucks. > > > > thanks for the support, > > > > Rick Murphy > > RV4 HS > > > > > > > > ________________________________________________________________________________
Date: Sep 09, 2001
Subject: Re: parking brake valve where?
Hi Chris Did you ever look into banjo couplings for the brakevalve..?? Gert C J Heitman wrote: > > > Scott, > > I bought it from Aircraft Spruce for $98.80 on 2/27/01. They also carry the > Cleveland valve but it was quite a bit more expensive. The Matco seems well > made. > > Speaking of Aircraft Spruce, I just happened to notice that they charged me > 6% sales tax at Oshkosh instead of 5% like all the other vendors were > charging. So let's see, if they did $500,000 in sales during the show that's > an extra $5,000. Probably paid for the booth rental. > > Chris Heitman > Dousman WI > RV-9A N94ME (reserved) > http://www.execpc.com/~cjh/brake_valve.html > > -----Original Message----- > where did you get the parking brake? who sells them, that i cool set up! > scott > tampa > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Sep 09, 2001
Gert: I looked but couldn't find banjo bolts with 1/8 NPT pipe threads. Chris Heitman RV-9A N94ME (reserved) http://www.execpc.com/~cjh/rv9a.html -----Original Message----- Did you ever look into banjo couplings for the brakevalve..?? ________________________________________________________________________________
Date: Sep 09, 2001
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
The first few products on the following page are banjo bolts which MAY be suitable. They are G-1/8 thread which is the metric equivalent to 1/8 NPT and is generally interchangeable. (i.e. they thread into one another) This does not address the actual banjo fitting however, only the bolt. For whatever it may be worth here is the link. http://catalog.festo.com/enu/asp/default4.asp Festo is German company recognized around the world as a manufacturer of top quality components with distributors is most major countries. They have 13 major distribution centres in the US and 4 in Canada which can be found at; http://www.festo.com/fww/eng/worldwide.htm Bob McC C J Heitman wrote: > > Gert: > > I looked but couldn't find banjo bolts with 1/8 NPT pipe threads. > > Chris Heitman > RV-9A N94ME (reserved) > http://www.execpc.com/~cjh/rv9a.html > ________________________________________________________________________________
Date: Sep 09, 2001
Subject: RV-List:Canopy Side Skirts
Tim, I ain't Jim, but I didn't see his response, so though I would chime in with my $.02 worth. I ordered the C-759 Skirt Braces from Van's and have them installed on my 6A Slider (1999 version.) They fit fine. They come as pre-bent solid strips about 20 inches long. I cut out a series of one inch lightening holes in each. I also curved the top of the brace to conform to the curve of the inside of the canopy side rail. By the way, I also ordered the RV-7 pre-formed dog house cap which fits over the slide track where the aft skirts meet. Part # is C-792. Looks a lot better than my home made version did. I had all sorts of problems with my first set of slider side skirts. Basically they bowed out badly. I ordered another set from Van's and started over. To keep the skirts from bowing, I started the skirt mounting holes in the middle and worked toward the ends, using a hole finder. I had a helper hold the skirt tight against the side of the fuselage as I drilled each hole. This caused each end of the side skirt to be a bit higher than the middle when compared to the canopy rail. I had plenty of metal left to trim the skirts straight on top and bottom after all the holes were drilled. Before mounting the braces, I trimmed the bottom of each skirt to clear the top of the fuselage canopy rail ever so slightly. I clamped the brace on and drilled and clecoed it to the inside of the canopy rail. Then I had my assistant press in on the bottom of the skirt as he drilled the holes through the skirt and the brace from the outside. To allow for spring back, we arbitrarily held the skirt about 1/4 inch inside the fuselage side while drilling the brace on. I was inside the cockpit with a wood block holding the bottom of the brace tight against the skirt as he drilled the holes. The result was perfect. As far as I am concerned, getting the side skirts to fit properly was the hardest part of the whole canopy evolution. I hope the description above is not too hard to follow. Charlie Brame RV-6AQB - N11CB (Reserved) San Antonio > From: "Tim Bryan" > Subject: Re: RV-List: Canopy side skirts > > > > Van's later RV-6 slider canopy finish kits now include the "inside canopy > > brace strip" that Mike describes below. My finish kit (packed late May > 2001) > > included these parts as item number # C-759 "Inside Canopy Skirt" - and > > coincidentally I drilled these to the inside of my canopy frame this > > afternoon. > > Hi Jim, > > Do you think if a person ordered these "Inside Canopy Skirts" they would > work on the pre May 2001 frames? > > RV-6 Slider (N616TB Reserved) Finishing kit and waiting for engine > Tim Bryan > tim(at)bryantechnology.com > ________________________________________________________________________________
Date: Sep 09, 2001
Since 1/8 NPT threads are tapered it would be difficult to get the threads to tighten just as the crush washers on the banjo fitting get tight enough. In other words, the length of the banjo bolt would be fairly critical. That's probably why no one makes 1/8 NPT banjo bolts. Perhaps the German version is a straight thread. Now if Matco could be convinced to produce a version of the valve with 3/8-24 straight threads (or M10 metric threads) on the inlet ports, banjo fittings would be easy to find. Chris Heitman Dousman WI RV-9A N94ME (reserved) http://www.execpc.com/~cjh/brake_valve.html -----Original Message----- The first few products on the following page are banjo bolts which MAY be suitable. They are G-1/8 thread which is the metric equivalent to 1/8 NPT and is generally interchangeable. (i.e. they thread into one another) This does not address the actual banjo fitting however, only the bolt. For whatever it may be worth here is the link. http://catalog.festo.com/enu/asp/default4.asp Festo is German company recognized around the world as a manufacturer of top quality components with distributors is most major countries. They have 13 major distribution centres in the US and 4 in Canada which can be found at; http://www.festo.com/fww/eng/worldwide.htm Bob McC ________________________________________________________________________________
Date: Sep 09, 2001
Hi Don, My RV weighs 1065 empty, and the test weight was around 1500 lbs at the start. All the data collected was with the Hartzell prop. One thing I forgot to note was that on the top speed run, I richened up the engine to 50 rich of peak. Laird Laird, Was this data with a Constant Speed Hartzell? Or a Fixed pitch. And what does your plane weigh? Don ________________________________________________________________________________
Subject: Re: Prop Spinner Front Bulkhead
Date: Sep 09, 2001
Mike; I spaced out my spinner front bulkhead with a heavy slurry of fiberglass resin thickened with flox. I painted the bulkhead with mold release first and it popped right off after setting up. I did have to purchase the different front bulkhead from Van so the Sensenich F/P prop would come close. Douglas G. Murray Southern Alberta RV-6 almost done!! > > Would like to get the list.wisdom on mounting my spinner on a Sensenich > fixed-pitch metal prop. > > I have the cutouts perfect but it did not intially contact the front > bulkhead (the correct bulkhead for the prop). > > In Tony's "Bingelis on Engines" he recommends pushing the front > bulkhead out using washers between prop and bulkhead. I have found two > washers gets everything fitting nicely. > > OTOH, my Technical Counselor is nervous about spacing out the front > bulkhead - cites reduced thread count holding on the prop. Those two > washers =~ 7/16" thickness. > > Need help reconciling the two viewpoints. Have seen web sites where > folks have built up the front bulkhead with everything from fiberglass > to bondo. Tony mentions those as options along with the spacing > method... I have to wonder why those folks didn't space out their > bulkhead. > > Anyone spaced theirs with good results (which would be, prop hasn't > since flown off the aircraft)? > :) > > Thanks. > > Mike Thompson > Austin, TX > -6 N140RV (Reserved) > Firewall Forward ________________________________________________________________________________
Date: Sep 09, 2001
Subject: Re: RV6-List Digest: 0 Msgs - 09/08/01
unsuscribe ________________________________________________________________________________
Subject: Re: Canopy side skirts
Date: Sep 09, 2001
The Van canopy side skirt brace for later slider canopies should be adaptable for use on earlier model canopy frames. The main difference would be that the upper edge would be attached to the inside of a round piece of tubing vice a square piece - a bit trickier but it should be doable. If you decide to go ahead with the Van's part, it is a C-791 "canopy skirt brace" that you need. (I got the part number wrong on my first post). It is pretty simple part. Imagine a .025 piece of aluminum sheet about 2 1/2" by 24 inches with two lengthwise bends to create 5/8" wide flanges bent 30-40 deg in opposite directions to form sort of an "S" shape. The builder gets to cut a dozen or so lightening holes in the center part and then slit them out to the edge of the bottom flange. This allows the piece to flex to conform to the inside of the canopy rail. Plan on 1/8" pop rivets to attach the top flange to the inside of the canopy frame and AN426-3-3.5 rivets to join the canopy side skirt to the brace. Some scrap .025 and trial and error might do as well as ordering the Vans part. Van's scheme is to drill the side skirts first and then backdrill from the outside the canopy to pick up the brace's bottom flange. Watch the rivet spacing so as to miss the slots that are cut in the brace. (Guess how I know...) Jim Oke RV-6A C-???? ----- Original Message ----- From: "Tim Bryan" <timbryan(at)oregontrail.net> Sent: Saturday, September 08, 2001 8:15 AM Subject: Re: RV-List: Canopy side skirts > > > Van's later RV-6 slider canopy finish kits now include the "inside canopy > > brace strip" that Mike describes below. My finish kit (packed late May > 2001) > > included these parts as item number # C-759 "Inside Canopy Skirt" - and > > coincidentally I drilled these to the inside of my canopy frame this > > afternoon. > > Hi Jim, > > Do you think if a person ordered these "Inside Canopy Skirts" they would > work on the pre May 2001 frames? > > RV-6 Slider (N616TB Reserved) Finishing kit and waiting for engine > Tim Bryan > tim(at)bryantechnology.com > > ________________________________________________________________________________
From: "Scott Johnson" <scottjohnson345(at)home.com>
Subject: Need Advice On RV8A Wheels From Vans
Date: Sep 09, 2001
I know, theres no excuse for asking this since I already built an RV6A ... My cleveland rims, tires, and tubes came from Vans RV8A kit for my RV8A. Heres the question: The tub stem cam with a washer and nut on it. The cleveland rim has a hole larger than the washer and nut. So whats the point of the washer and nut ? Is there suppose to be a washer bigger than the rim hole to anchor the stem from the tube to the rim ? I don't remember doing this on the RV6A, its been to many years. Thanks in advance for your ideas ... ________________________________________________________________________________
Subject: Re: White interior a bad idea?
Date: Sep 09, 2001
Matthew I have a RV4 that is painted a light cream colour (Cdn Goverment filing cabinate beige actually, you take free paint where ever you can get it) The roll bar is black. The instrument panel is the same colour as the interior and I have not noticed any bad reflections as yet. I find the light colour makes it much easier to work inside the cockpit. Things are much easier to see than in a friends that the interior is painted very dark colours. Joe Hine RV4 C-FYTQ > > A recent post on the RV-list caught my attention... I recently bought paint > I was planning on using on the interior of my plane. It is almost exactly > the same color as Vans powdercoat. I figured if Vans was using it it should > be a good choice - but then KostaLewis' post made it sound like it was a bad > idea - that it would create a horrible glare on the inside of the canopy. I > hadn't thought of that - I thought white would be a good idea because it > might stay cooler than a darker color. Has anyone flown in an RV with a > white (actually, very light grey) interior? Is the glare bad? > > No big deal if I made a bad choice - I just have to get new paint and take > of the windscreen so I can repaint the roll bar. > > Matthew > 8A finishing kit > N48PP reserved > > ________________________________________________________________________________
Date: Sep 09, 2001
Is this what you wanted or do you need the notes as well? Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org P-920 - HARTZELL - Model - HC-C2Y HC-C2Y Revision 21 April 25, 1996 TYPE CERTIFICATE DATA SHEET NO. P-920 Propellers of models described herein conforming with this data sheet (which is part of Type Certificate No. P-920) and other approved data on file with the Federal Aviation Administration, meet the minimum standards for use in certificated aircraft in accordance with pertinent aircraft data sheets and applicable portions of the Federal Aviation Regulations provided they are installed, operated and maintained as prescribed by the approved manufacturer's manuals and other approved instructions. Hartzell Propeller Inc. Piqua, Ohio 45356 I Model HC-C2Y Type Constant speed, hydraulic (See NOTES 3 and 4) Engine shaft SAE #2 flange, special flange 4" B.C. Hub material Aluminum alloy Blade material Aluminum alloy Number of blades Two Hub models HC-C2YF-1, -2, -4; HC-C2YK-1, -2, -4; HC-C2YL-1, -2, -4; HC-C2YR-1, -2, -4 (See NOTES 1 and 4) Blades Maximum * Hub and Blades (See NOTES Continuous Takeoff Diameter Approx. Weight 2 & 6) HP RPM HP RPM Limits (See NOTES 3 and 7) Non-Counterweighted Blades Hub Models: All -1 7068-0 to 300 2700 300 2700 70" to 60" 55.5 lb 7068-10 (-0 to -10) 7280+1/2 to 250 2700 250 2700 72-1/2" - 65" 51 lb. 7280-7 (+1/2 to -7) 7663-0 to 210 2800 210 2800 76" - 68" 46 lb. 7663-8 (-0 to -8) 7666-0 180 2900 180 2900 to or or 76" - 68" 51 lb. 7666-8 250 2700 250 2700 (-0 to -8) 7681-0 to 250 2700 250 2700 76" - 68" 51 lb. 7681-8 (-0 to -8) 7692-0 180 2900 180 2900 76" - 68" 46 lb. to or or (-0 to -8) 7692-8 250 2700 250 2700 Blades Maximum * Hub and Blades (See NOTES Continuous Takeoff Diameter Approx. Weight 2 & 6) HP RPM HP RPM Limits (See NOTES 3 and 7) 8052-0 to 310 2600 310 2600 80" - 72" 50.5 lb. 8052-8 (-0 to -8) 8459-0 to 260 2800 260 2800 84" - 66" 48 lb. 8459-18 (-0 to -18) 8465-0 to 315 2575 315 2575 84" - 70" 50 lb. 8465-14 (-0 to -14) 8467-0 to 285 2700 285 2700 84" - 72" 52 lb. 8467-12 (-0 to -12) 8468-0 to 285 2700 285 2700 84" - 72" 50 lb. 8468-12 (-0 to -12) 8470-0 to 260 2700 250 2700 84" - 76" 49 lb. 8470-8 (-0 to -8) 8475+2 to 310 2700 310 2700 86" - 80" 52 lb. 8475-4 (+2 to -4) 8475-4 to 350 2700 350 2700 80" - 78" 51 lb. 8475-6 (-4 to -6) 8475-6 310 2700 310 2700 78" - 70" 50 lb. to or (-6 to -14) 8475-14 300 2850 8477-0 310 2575 310 2575 84" - 80" 54 lb. to or or (-6 to -4)8477-4 260 2700 260 2700 8477-4 to 350 2700 350 2700 80" - 78" 53 lb. 8477-6 (-4 to -6) 8477-6 310 2700 310 2700 78" - 70" 52 lb. to or (-6 to -14) 8477-14 300 2850 9587-0 to 320 2200 320 2200 95" - 93" 50 lb. 9587-2 (-0 to -2) 9587-2 320 2200 320 2200 93" - 75" 50 lb. to or or (-2 to -20) 9587-20 300 2400 300 2400 Blades Maximum * Hub and Blades (See NOTES Continuous Takeoff Diameter Approx. Weight 2 & 6) HP RPM HP RPM Limits (See NOTES 3 and 7) Counterweighted Blades Hub Models: All -2, and -4 C7663-0 to 210 2800 210 2800 76" - 68" 50 lb. C7663-8 (-0 to -8) C7666-0 180 2850 180 2850 76" - 68" 55 lb. to or or (-0 to -8) C7666-8 250 2700 250 2700 C7681-0 76" - 68" 55 lb. to 250 2700 250 2700 (-0 to -8) C7681-8 C7692-0 180 2900 180 2900 76" - 68" 50 lb. to or or (-0 to -8) C7692-8 250 2700 250 2700 C8052-0 to 310 2600 310 2600 80" - 72" 54.4 lb. C8052-8 (-0 to -8) C8459-0 to 260 2800 260 2800 84" - 72" 52 lb. C3459-12 (-0 to -12) C8465-0 to 315 2575 315 2575 84" - 70" 54 lb. C8465-14 (-0 to -14) C8465-6 to 260 2700 260 2700 78" - 70" 53 lb. C8465-14 (-6 to -14) C8467-0 to 285 2700 285 2700 84" - 72" 56 lb. C8467-12 (-0 to -12) C8468-0 to 260 2700 260 2700 84" - 72" 54 lb. C8468-12 (-0 to -12) C8470-0 to 260 2700 260 2700 84" - 76" 53 lb. C8470-8 (-0 to -8) C8475+2 to 310 2700 310 2700 86" - 80" 56 lb. C8475-4 (+2 to -4) Blades Maximum * Hub and Blades (See NOTES Continuous Takeoff Diameter Approx. Weight 2 & 6) HP RPM HP RPM Limits (See NOTES 3 and 7) C8475-4 to 350 2700 350 2700 80" - 78" 55 lb. C8475-6 (-4 to -6) C8475-6 310 2700 310 2700 78" - 70" 54 lb. to or (-6 to -14) C8475-14 300 2850 C8477-0 310 2575 310 2575 84" - 80" 58 lb. to or or (-0 to -4) C8477-4 260 2700 260 2700 C8477-4 to 350 2700 350 2700 80" - 78" 57 lb. C8477-6 (-4 to -6) C8477-6 310 2700 310 2700 78" - 70" 56 lb. to or (-6 to -14) C8477-14 300 2850 C9587-0 to 320 2200 320 2200 95" - 93" 54 lb. C9587-2 (-0 to -2) C9587-2 320 2200 320 2200 93" - 75" 54 lb. to or or (-2 to -20) C9587-20 300 2400 300 2400 * Weights apply to -1 constant speed hub with "F" flange. Add 1.2 lb. for "L", "K", and "R": flange, 3.0 lb. for feathering -2 hubs, and 5.5 lb. for feathering -2R hubs. Add 4 lb. for -4 model. ----- Original Message ----- From: "Thomas Mosher" <tmosher(at)gbronline.com> Sent: Saturday, September 08, 2001 11:20 PM Subject: Re: RV-List: Hartzell CS prop If you want to find out the certification specs on an HC-C2YL-1BF/F7663A-4 (the one Van shows in the accessories catalog) take a look at Type Certificate Data Sheet P-920 (unfortunately the damn FAA site that the TCDS are on is down (again)). Tom ----- Original Message ----- From: "Kevin Horton" <khorton(at)cyberus.ca> Sent: Saturday, September 08, 2001 10:44 PM Subject: Re: RV-List: Hartzell CS prop > > > > >Does anybody know if I am correct in thinking that the prop blade numbers > >(i.e. F7663) mean that the pitch in full coarse is 76" and in full fine is > >63"? > > > >Greg Tanner > >RV-9A Tanks > >SER #90186 N80BR RESERVED > >O-320 D1A > > > Greg, > > I don't think their numbers work like that. They have too many other blade > numbers that wouldn't fit that mold (e.g F7693, F7214, etc). > > In any case, the prop hub has fine and coarse pitch stops that are set > specifically for each application. This gives the required pitch change > range for that aircraft type, while minimizing the effects of failures that > take you to one of the pitch stops. So, the pitch range of a prop with > F7663 blades will depend on how the hub is set up. > > Hartzell has some interesting info on their web site. Go to: > > http://www.hartzellprop.com/resource_library/sitelinks_appguide.htm > > Type Van into the Aircraft Manufacturer field, leave the rest blank and > submit the form. > > Take care, > > > Kevin Horton RV-8 (engine installation) > khorton(at)cyberus.ca (613) 821-7862 (home) > Ottawa, Canada (613) 952-4319 (work) > http://eccentrix.com/misc/rv8/ > > ________________________________________________________________________________
Date: Sep 09, 2001
Use longer bolts! ----- Original Message ----- From: "Mike Thompson" <grobdriver(at)yahoo.com> Sent: Sunday, September 09, 2001 9:20 AM Subject: RV-List: Prop Spinner Front Bulkhead Would like to get the list.wisdom on mounting my spinner on a Sensenich fixed-pitch metal prop. I have the cutouts perfect but it did not intially contact the front bulkhead (the correct bulkhead for the prop). In Tony's "Bingelis on Engines" he recommends pushing the front bulkhead out using washers between prop and bulkhead. I have found two washers gets everything fitting nicely. OTOH, my Technical Counselor is nervous about spacing out the front bulkhead - cites reduced thread count holding on the prop. Those two washers =~ 7/16" thickness. Need help reconciling the two viewpoints. Have seen web sites where folks have built up the front bulkhead with everything from fiberglass to bondo. Tony mentions those as options along with the spacing method... I have to wonder why those folks didn't space out their bulkhead. Anyone spaced theirs with good results (which would be, prop hasn't since flown off the aircraft)? :) Thanks. Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Date: Sep 09, 2001
> Thanks, i got the pictures, great help, one question > I have breaks on both sides, it will not make any > difference no?, just one line goes to one wheel > the other to the opposite side.. I took a look at drawing 49, upper right hand corner... I don't believe having another pair of brakes will affect the installation. The idea is to capture the high pressure line between the brake pedal and the wheels. With right-side brakes you simply have a high-pressure connection between them; the right-side pumps through the left side, thence to the wheels. If you will insert the valve between the left-side brake pedals (lower connections) and the wheels you will be OK. > > Is any possibility, that the valve will interfere > with the breaks, if is not connected, or close? Of course it will interfere with brake operation if it is closed - it will not allow the brake fluid under pressure to get to the slave cylinders at the wheels. If the lever on the valve is not connected to a cable or lever or rod or some other kind of actuator, you will have to ensure the valve lever is "pinned" or otherwise secured in the open position. Otherwise it might vibrate closed and you could be pushing on the brake pedals for all you're worth but no pressure would get to the slave cylinders. That, I suspect, would be bad. > Is a simple pull push, cable enough, or will be > better to have a friction type.. > thanks for the help I am using a ratcheting cable available from Van's or any other aircraft supplier (ACS, Wicks). A friction-lock cable like a throttle cable would certainly work... would be a little overkill I think. I have been in production aircraft where the parking brake was a simple non-ratcheting type and they seemed to work OK too. I chose a middle ground. Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ==== Michael E. Thompson (Grobdriver(at)yahoo.com) Austin, TX, USA RV-6 in progress, N140RV (Reserved) EX-AX1 Sub Hunter, P-3 (B/B-TACMOD/C) Orion Aircrew, PP-G,ASEL, Motorglider Driver and Unlimited Air Race Nut! ________________________________________________________________________________
Date: Sep 09, 2001
Subject: Re: Oil Cooler, Tilted?
> He is doing a beautifull job, one of those with > attention to detail, which makes me feel depress > I wish I could do things that perfect... Hi Again, Bert. Don't let things like this depress you. We all have different skill levels, different finance levels (like, if you don't like the job you did on a part, you can buy more materials and do it again). Don't be depressed, learn from it. I visit projects armed with a camera and focus on areas that are ahead of me. There are lots of good web sites you can get ideas from, too! With that information and patience you can do very good work too, I am sure. My personal credo on this project is: "Strive for perfection... and take what you get" > Any how, in our conversation, he mentioned that if > one install the oil cooler tilted, that it will help > or something to do with the vapor escaping, > separating? The idea here is to smooth airflow as much as you can. A large percentage of our aerodynamic drag is "cooling drag" - the air going into the baffles, down around the cylinders and out the cowl is constantly changing direction. That slows it down and increases drag. Anything you can do to smooth the airflow inside the cowl is as valuable as things we do on the outside of the cowl. That's why the -8 has a hump at the cowl exit (which some of us builders of other models shamelessly copy). By tilting the oil cooler down, you are directing the air exiting the cooling fins toward the cowl exit, where it has to eventually go, but you have helped it along by directing it that way. That bit of air does not have to change direction to get out. It is perhaps a small thing - but many small things add up! Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Date: Sep 09, 2001
--- Cy Galley wrote: > > Use longer bolts! Good idea! Thought of it - according to Van's catalog these puppies are AN8-82's. Can't find something that size (and bigger) in ACS or Wicks - guess I could go straight to Sensenich, see if they have something like an 8-83/84... Was hoping to learn the 7/16" wasn't that big a deal. But thanks for the thought! Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Date: Sep 09, 2001
Great information. So now---any clue what the difference would be between a F7663-4 and an F8468-12? By definition, they would be the same length but the F7663 is listed as 210 HP and the F8468 is listed as 285 HP. The only remaining difference is the 63 vs. the 68. Which mean the following: "the last 2 numbers indicate basic model or template (there are some exceptions to this definition)" Quoted from Hartzell's web site. What's curious here is that the F7663-4 blades are what is used on the O-320 CS prop assy so I'm assuming that the stated HP "MAX CONTINUOUS" and "TAKEOFF" must be for the prop if it was not a -4 (meaning not shortened to 72") which would make sense then that the F8468 prop rated at 285 HP must be at the non-shortened length of 84". This is all leading to the question then, will the performance of an F7663-4 be the same as an F8468-12? Both being 72" in diameter but with a different "basic model or template" number? Am I getting too technical? Inquiring minds want to know? Greg ________________________________________________________________________________
Date: Sep 09, 2001
Wag Aero handles prop bolts. Or make an adapter plate to offset the spacers to the bulkhead. Use the plate to bolt on the prop. Use the offset holes to bolt on the spacers to the bulkhead. The adapter plate could be just another front bulkhead. The other thing is to open up the front of the prop cutouts so to slide the spinner back so the bulk head fits correctly. ----- Original Message ----- From: "Mike Thompson" <grobdriver(at)yahoo.com> Sent: Sunday, September 09, 2001 5:56 PM Subject: Re: RV-List: Prop Spinner Front Bulkhead --- Cy Galley wrote: > > Use longer bolts! Good idea! Thought of it - according to Van's catalog these puppies are AN8-82's. Can't find something that size (and bigger) in ACS or Wicks - guess I could go straight to Sensenich, see if they have something like an 8-83/84... Was hoping to learn the 7/16" wasn't that big a deal. But thanks for the thought! Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
" \"Randy Griffin\"" , "Jeff Jasinsky"
Subject: SW/Niagara shootout
Date: Sep 09, 2001
Listers, (long post, DELETE if not interested in this topic) There was a thread last week on oil coolers that I am following up on. The essence of the thread was that the Stewart Warner coolers were supposedly the most effective out there for a given size. There is also confusion as to whether a SW and a Niagara and Harrison are the same thing or not. There were several good posts on the history of the companies that are in the archives so I won't repeat it all here, but suffice it to say they are not the same company any more and their products are now different. Since flying my RV-8 this past May my oil temps were a bit higher than I'd like on days where the ambient temp is 80 or above. When it is above 90 they were definitely too high (like 218 at low altitude low power cruise). On one 90+ degree day in Central Oregon departing from a 5,000 elevation airport with the engine already hot, and while following another plane's climb profile, I saw 245... yikes! Since then I've learned to manage oil temps and have never seen over 230 regardless of the ambient temp. Still, I did not feel like I had adequate headroom. Several listers had spoken with Pacific Oil Coolers lately and been advised that Stewart Warners were the most efficient so I called them also to see if a swap with my Niagara would lower my temps. They told me "absolutely" and that I "could possibly see a 20% reduction". Of course they wouldn't guarrantee anything. Frankly I simply didn't believe the 20%, but I'd be happy with 10-15 degrees (5-8%). When doing my final FWF installation I had originally bought a Posi Tech. Solely on the experience of several RV-Listers I sold it and bought a Niagara from Van's. At that time I thought the Niagara was the identical product to a SW... ignorance is bliss. Again, the Niagara has worked well for 120 hours for all but very high ambient conditions, which is only a problem here in the Great Northwet for 2-3 months a year. If you lived in Arizona or Florida it wouldn't have been unacceptable. Curiosity got the better of me so I ordered one and swapped the SW for the Niagara while doing an oil change on Friday evening. The flanges and bolt hole dimensions are identical, but the core is recessed about 1/4" deeper than Niagara. This required a very minor modification on my mount... no problem. I ground ran it as usual when doing an oil change to look for leaks, none noted, and buttoned it up to be flown the next morning. I have now flown 7.5 hours over the last two days in ambient conditions of around 80 degrees on the ground. The comparisons I made are not good scientific method, rather my own feel for what temps would have been before versus what I was seeing now. After flying the plane 120 hours in the last four months though I feel like I have a good handle on what was normal for a given flight condition. Sorry, proper data would have been tough to get (identical ambient conditions combined with identical climb/power profiles) and way too much work. So here's what I found: when doing an extended climb before at 120-130 mph on days like this I would see peaks of around 220-225. This weekend I saw peaks of 205-215. Cruise at 7,500-8,500 feet, with the power settings I typically run, before would typically be 189-202, this weekend they were 182-185. During long high-speed descents temp would never drop below 180 with either cooler so the vernatherm must be working. When assessing this information it should be noted that my plane is non-standard and may make the oil cooler's job a bit tougher. I have a Sam James closed cooling plenum. This forces you to mount the oil cooler lower behind cylinder #4 than with Van's standard baffles, hence half the cooler inlet is cylinder fins. This probably impedes airflow and also may pre-warm the air, not good for cooling. Hmm, what conclusions can we draw from this? My own sense is that the SW does indeed cool *just a bit* more effectively than the Niagara. In fact my own belief is that I'm seeing an 8-10 degree reduction. The Niagara is $241 from Van's, the SW was $397 outright from Pacific Oil Coolers. Was the swap worth it? In the long run, probably. Was it dramatic? No. Will I keep the SW installed? Yes, that 8-10 degrees is important on those hot days. So there you have it, as close a comparison as I can give you. I have posted most of the above text and photos of the two coolers on my web site at... http://www.rv-8.com/FirewallForward.htm#Oil%20cooler Hope this helps someone. Oh, almost forgot: FOR SALE, Niagara 2002A oil cooler, 120 hrs, $175 delivered in cont. US. Contact Randy at 800-886-6659 or randy@rv-8.com. Randy Lervold RV-8, 127 hrs. www.rv-8.com Home Wing VAF ________________________________________________________________________________
Date: Sep 09, 2001
Subject: Message for Fred Kunkel
Fred, are you up on freq? Please drop me a line or two when you get a chance. Thanks! S/F John ________________________________________________________________________________
Date: Sep 09, 2001
From: Gary & Carolyn Zilik <zilik(at)bewellnet.com>
The way Bert stated the oil cooler was mounted led me to believe that the cooler is mounted flat on the back of the baffles but not plumb side to side, or crooked. I think this guy mounted his crooked so that the top of the cooler was not level and tilted upwards towards the outlet fitting. This would in effect make sure all air was purged from the filter. Does it make a difference, who knows. Just my two cents worth. Gary > > > By tilting the oil cooler down, you are directing the air exiting the > cooling fins toward the cowl exit, where it has to eventually go, but > you have helped it along by directing it that way. That bit of air > does not have to change direction to get out. > It is perhaps a small thing - but many small things add up! > ________________________________________________________________________________
Subject: Re: hole in wheel pant for air?
Date: Sep 09, 2001
Doug, I put a 1/2" hole 1 11/16" from the hub centerline aft of the axle hole. In order to air the tires use 2 auto extenders screwed together. It helps to mark the tire with a dot of yellow paint. ray rv6a ----- Original Message ----- From: "Doug's Mail" <dougr(at)petroblend.com> Sent: Friday, September 07, 2001 9:58 PM Subject: RV-List: hole in wheel pant for air? > > How far from the axle bolt should it be to the center of a hole for a rubber > plug for tire inflation without wheelpant removal??? > > Tailwinds, > Doug Rozendaal > dougr(at)petroblend.com > > ________________________________________________________________________________
"Rv-List(at)Matronics.Com"
Subject: RMD Landing Lights...
Date: Sep 09, 2001
Anybody have a some good close up pix of the RMD landing lights? How they are installed and how you adjust them would be great... Thanks in advance... -Bill VonDane Colorado Springs, CO RV-8A - N8VD - Finish http://vondane.com/rv8a/ ________________________________________________________________________________
Subject: Oil Cooler Alternative
Date: Sep 09, 2001
All this talk about oil coolers brought me to post about my alternative oil cooler. I have a Setrab oil cooler. It is a swedish auto racing oil cooler that has been successfully used in numerous Harmon Rockets. It has a very low profile, and is VERY efficient. In 100 + degree temperatures, I have seen 180-190 temps. I suspect I will have to close some of it off in the summer. Picutres of this cooler are on my website under the engine pages. Have a look. They also only cost around $70. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ________________________________________________________________________________
Subject: Re: Weight & Balance NOW WHAT???
Date: Sep 09, 2001
Kevin - Thanks for the encouraging words. It's too bad your not closer, - I would have no problem with you flying my craft. The only concern I have now is on the W&B computations. With full fuel, two 170# pilots and a empty weight of 1072# - I can only carry 10 # luggage and stay within the gross of 1650#. Now for the real world weights - I can have only 34Gallons of fuel with two 185# people and no baggage. Is this near the same figures everone else is coming up with? Thanks for the input. Doug Murray PS. thanks to all the other builders who took time out to advise me on this asymetrical weight question. ----- Original Message ----- From: Kevin Horton <khorton(at)cyberus.ca> Sent: Saturday, September 08, 2001 9:48 PM Subject: Re: RV-List: Re: Weight & Balance NOW WHAT??? > > > Oh oh. You'd better let me fly it for a year or two to make sure there are > no issues caused by that asymmetry. I'll do an extensive test program and > report back to you. :-) > > I think you are worrying too much. Go flying. > > > Kevin Horton RV-8 (engine installation) > khorton(at)cyberus.ca (613) 821-7862 (home) > Ottawa, Canada (613) 952-4319 (work) > http://eccentrix.com/misc/rv8/ > > > > > >Listers: > > > >I just did my weight computations for my RV-6 and found that the left main > >gear is 17# heavier than the right main. I switched the aircraft scales from > >side to side and reweighed the aircraft - same thing. I have one landing > >light on the port wing, and all electric gyros on the left side of the > >panel. Would these items acount for the extra weight on the port side? Am I > >just being picky? The last RV-6 built in this area came out within two > >pounds side to side so I am a bit dismayed to see these numbers on my > >aircraft. The aircraft came out at 1072# no fuel, all painted and > >upholstered. How does this compare to the rest of your aircraft? > > > >Your input is appreciated. > > > >Douglas G. Murray > >Southern Alberta ________________________________________________________________________________
Subject: N66AP First Flight
Date: Sep 09, 2001
My 6A is officially an airplane as of today! The first flight was completed by Tom Irlbeck, an accomplished pilot and RV8 builder/owner. A total of 4.2 flight hours were logged today. My face hurts from the smiling. Stick with it, it is worth it. Performance data to follow, but the equipment list is: Aerosport O360 with Airflow Perf. fuel injection, C/S prop, Lasar ignition, RMI engine monitor, Garmin 340 audio panel, Garmin 327 trans., Garmin 430, King Ky97 com, Century 2000 fully coupled two axis autopilot w/HSI, inverted fuel/oil, leather, stereo, Hooker harnesses. Painted outside and primed inside, 1174 calibrated three scale empty weight (BTW, re recent weight thread, both main gear weighed the same, 417lbs.). However, I only weigh 155 : ). Anyway, really an unbelievable feeling. Many thanks to all you wonderful contributors to this list, it really makes a difference. Alex Peterson Maple Grove, MN 6A N66AP, 4.2 hours! ------ http://USFamily.Net/info - Unlimited Internet - From $8.99/mo! ------ ________________________________________________________________________________
Subject: Re: RMD Landing Lights...
Date: Sep 09, 2001
Hmmm...I have one pic I think on my website under the wings section. I can take a closer pic if you like. The adjustment is done with 3 screws that you can get to when you take the lens off. The screws have springs on them that makes the lens "float" on it's mounts. You screw them in our out in different combinations to aim them. Pretty much like you would on a car. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Bill VonDane" <n8vd(at)earthlink.net> Sent: Sunday, September 09, 2001 7:19 PM Subject: RV-List: RMD Landing Lights... > > Anybody have a some good close up pix of the RMD landing lights? How they > are installed and how you adjust them would be great... > > Thanks in advance... > > -Bill VonDane > Colorado Springs, CO > RV-8A - N8VD - Finish > http://vondane.com/rv8a/ > > ________________________________________________________________________________
Date: Sep 09, 2001
Subject: Re: Setrab Oil Cooler
I don't have any personal experience, but the Setrab coolers have a bit of a spotted reputation. There is quite a bit in the archives on the subject. James Freeman not flaming--just trying to be helpful :) ________________________________________________________________________________
Date: Sep 09, 2001
One of the nifty things about experimental aircraft is that YOU the builder can set any GW you want as your upper limit. Just be sure you stay within the CG envelope. Bruce -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Douglas G. Murray Sent: Sunday, September 09, 2001 10:38 PM Subject: Re: RV-List: Re: Weight & Balance NOW WHAT??? Kevin - Thanks for the encouraging words. It's too bad your not closer, - I would have no problem with you flying my craft. The only concern I have now is on the W&B computations. With full fuel, two 170# pilots and a empty weight of 1072# - I can only carry 10 # luggage and stay within the gross of 1650#. Now for the real world weights - I can have only 34Gallons of fuel with two 185# people and no baggage. Is this near the same figures everone else is coming up with? Thanks for the input. Doug Murray PS. thanks to all the other builders who took time out to advise me on this asymetrical weight question. ________________________________________________________________________________
Date: Sep 09, 2001
Change your Gross weight to 1750. You are the builder, and can do so. It is safe, as well, as long as you are not past your cg envelope when fuel burns off. The 1650 number is a guide, but Van's has told me "off the record" that they have seen gross weights of 1800 pounds and still safe..just watch the cg shift with the fuel burn. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Douglas G. Murray" <dgmurray(at)telusplanet.net> Sent: Sunday, September 09, 2001 7:37 PM Subject: Re: RV-List: Re: Weight & Balance NOW WHAT??? > > Kevin - Thanks for the encouraging words. It's too bad your not closer, - I > would have no problem with you flying my craft. > > The only concern I have now is on the W&B computations. With full fuel, two > 170# pilots and a empty weight of 1072# - I can only carry 10 # luggage and > stay within the gross of 1650#. Now for the real world weights - I can have > only 34Gallons of fuel with two 185# people and no baggage. Is this near the > same figures everone else is coming up with? > > Thanks for the input. > > Doug Murray > > PS. thanks to all the other builders who took time out to advise me on this > asymetrical weight question. > > > ----- Original Message ----- > From: Kevin Horton <khorton(at)cyberus.ca> > To: > Sent: Saturday, September 08, 2001 9:48 PM > Subject: Re: RV-List: Re: Weight & Balance NOW WHAT??? > > > > > > > > Oh oh. You'd better let me fly it for a year or two to make sure there > are > > no issues caused by that asymmetry. I'll do an extensive test program and > > report back to you. :-) > > > > I think you are worrying too much. Go flying. > > > > > > Kevin Horton RV-8 (engine installation) > > khorton(at)cyberus.ca (613) 821-7862 (home) > > Ottawa, Canada (613) 952-4319 (work) > > http://eccentrix.com/misc/rv8/ > > > > > > > > > > > > >Listers: > > > > > >I just did my weight computations for my RV-6 and found that the left > main > > >gear is 17# heavier than the right main. I switched the aircraft scales > from > > >side to side and reweighed the aircraft - same thing. I have one landing > > >light on the port wing, and all electric gyros on the left side of the > > >panel. Would these items acount for the extra weight on the port side? > Am I > > >just being picky? The last RV-6 built in this area came out within two > > >pounds side to side so I am a bit dismayed to see these numbers on my > > >aircraft. The aircraft came out at 1072# no fuel, all painted and > > >upholstered. How does this compare to the rest of your aircraft? > > > > > >Your input is appreciated. > > > > > >Douglas G. Murray > > >Southern Alberta > > ________________________________________________________________________________
Date: Sep 09, 2001
on 9/9/01 21:56, Paul Besing at azpilot(at)extremezone.com wrote: > > Change your Gross weight to 1750. You are the builder, and can do so. It > is safe, as well, as long as you are not past your cg envelope when fuel > burns off. The 1650 number is a guide, but Van's has told me "off the > record" that they have seen gross weights of 1800 pounds and still > safe..just watch the cg shift with the fuel burn. > > Paul Besing > RV-6A N197AB Arizona > http://www.lacodeworks.com/besing > Flying > Kitlog Pro Builder's Log Software > http://www.kitlog.com > ----- Original Message ----- > From: "Douglas G. Murray" <dgmurray(at)telusplanet.net> > To: > Sent: Sunday, September 09, 2001 7:37 PM > Subject: Re: RV-List: Re: Weight & Balance NOW WHAT??? > > > >> >> Kevin - Thanks for the encouraging words. It's too bad your not closer, - > I >> would have no problem with you flying my craft. >> >> The only concern I have now is on the W&B computations. With full fuel, > two >> 170# pilots and a empty weight of 1072# - I can only carry 10 # luggage > and >> stay within the gross of 1650#. Now for the real world weights - I can > have >> only 34Gallons of fuel with two 185# people and no baggage. Is this near > the >> same figures everone else is coming up with? >> >> Thanks for the input. >> >> Doug Murray >> >> PS. thanks to all the other builders who took time out to advise me on > this >> asymetrical weight question. >> >> >> ----- Original Message ----- >> From: Kevin Horton <khorton(at)cyberus.ca> >> To: >> Sent: Saturday, September 08, 2001 9:48 PM >> Subject: Re: RV-List: Re: Weight & Balance NOW WHAT??? >> >> >>> >>> >>> Oh oh. You'd better let me fly it for a year or two to make sure there >> are >>> no issues caused by that asymmetry. I'll do an extensive test program > and >>> report back to you. :-) >>> >>> I think you are worrying too much. Go flying. >>> >>> >>> Kevin Horton RV-8 (engine installation) >>> khorton(at)cyberus.ca (613) 821-7862 (home) >>> Ottawa, Canada (613) 952-4319 (work) >>> http://eccentrix.com/misc/rv8/ >> >> >>> >>> >> >>>> >>>> Listers: >>>> >>>> I just did my weight computations for my RV-6 and found that the left >> main >>>> gear is 17# heavier than the right main. I switched the aircraft scales >> from >>>> side to side and reweighed the aircraft - same thing. I have one > landing >>>> light on the port wing, and all electric gyros on the left side of the >>>> panel. Would these items acount for the extra weight on the port side? >> Am I >>>> just being picky? The last RV-6 built in this area came out within two >>>> pounds side to side so I am a bit dismayed to see these numbers on my >>>> aircraft. The aircraft came out at 1072# no fuel, all painted and >>>> upholstered. How does this compare to the rest of your aircraft? >>>> >>>> Your input is appreciated. >>>> >>>> Douglas G. Murray >>>> Southern Alberta >> e Allow me to add 2 worth. I was present a number of years ago when Van answered the question of gross weight maximums. He did indeed say you could increase it HOWEVER he also added with emphasis " Don't even think about doing aerobatics above the published maximum!" Because of this and to keep it simple, I consider the plane a Utility category at all times unless I happen to be below max aerobatic weight. Personally I have certified my RV-6A for 1840 lbs gross, and have flown it at over 1800 several times with no problems; however I do not exceed +4.4 G when above aerobatic weight. In my case that is any time I am heavier than solo with no cargo and 9 gallons of gasoline. I do not do negative G maneuvers at any time. Denis (Denis L. Walsh deniswalsh(at)earthlink.net) ________________________________________________________________________________
Date: Sep 09, 2001
Well, maybe so, but the rocket guys love them, and I haven't seen a lick of a problem in over 20 hours. I keep an eye on it every day, and I guess time will tell, but for now, it's working perfectly. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "james freeman" <flyeyes(at)bellsouth.net> Sent: Sunday, September 09, 2001 8:45 PM Subject: Re: RV-List: Setrab Oil Cooler > > I don't have any personal experience, but the Setrab coolers have a bit of a > spotted reputation. > > There is quite a bit in the archives on the subject. > > James Freeman > not flaming--just trying to be helpful :) > > ________________________________________________________________________________
Date: Sep 09, 2001
Subject: Re: Some Interesting Data (Long)
Great data Laird , keep going. I know we all want to see how efficient we can make these "6s". Tell "Pop" Dianne and I say thanks for the pictures. Garry, RV6,"Casper" 40.6 hr "Owens, Laird" wrote: > > Hi all, > > Since I converted over to a Hartzell prop on my O-360/RV-6, I've wanted to do some good data collection. I finally got a chance to go out last evening and collect a little. (Like my boss sez...."Data is easy, GOOD data is hard"). Thought some of you might be interested. > Snip ________________________________________________________________________________
Subject: More Trim tab pics
Date: Sep 10, 2001
I've started working on the trim tab portion of my modified electric aileron trim system. I tried a new idea to accurately size a small rib that my friend Paul recommended to me. Take a look, it works great!! I wish I would have known about this idea when I was building my elevator trim tab. http://bmnellis.com Mike Nellis - http://bmnellis.com Plainfield, IL RV6 N699BM (res) Building Flaps Stinson 108-2 N9666K ________________________________________________________________________________
Date: Sep 10, 2001
08:38:20 AM Bill, one thing thats not real clear, well I missed it anyway, is to lay up a spacer layer of matt and cloth between the light assembly and the wingtip after you have made your cutout. You will want to add about 1/8th in order for the lense to clear. Eric "Bill VonDane" (at)matronics.com on 09/09/2001 10:19:27 PM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RV-List: RMD Landing Lights... Anybody have a some good close up pix of the RMD landing lights? How they are installed and how you adjust them would be great... Thanks in advance... -Bill VonDane Colorado Springs, CO RV-8A - N8VD - Finish http://vondane.com/rv8a/ ________________________________________________________________________________
Subject: Re: N66AP First Flight
Date: Sep 10, 2001
Alex, CONGRATULATIONS & WELL DONE !! Chuck & Dave Rowbotham RV-8A (Flying - 13 hrs) Niantic, CT (Westerly airport) ________________________________________________________________________________
Date: Sep 10, 2001
Thanks for the input. In Canada I can only ask for the gross weight that the designer approves by letter. My next move will be to see if Van will approve 1750 by letter. Thanks again, Doug Murray Southern Alberta RV-6 ************************************** Change your Gross weight to 1750. You are the builder, and can do so. It is safe, as well, as long as you are not past your cg envelope when fuel burns off. The 1650 number is a guide, but Van's has told me "off the record" that they have seen gross weights of 1800 pounds and still safe..just watch the cg shift with the fuel burn. ************************************ Allow me to add 2 worth. I was present a number of years ago when Van answered the question of gross weight maximums. He did indeed say you could increase it HOWEVER he also added with emphasis " Don't even think about doing aerobatics above the published maximum!" Because of this and to keep it simple, I consider the plane a Utility category at all times unless I happen to be below max aerobatic weight. Personally I have certified my RV-6A for 1840 lbs gross, and have flown it at over 1800 several times with no problems; however I do not exceed +4.4 G when above aerobatic weight. In my case that is any time I am heavier than solo with no cargo and 9 gallons of gasoline. I do not do negative G maneuvers at any time. ********************************************************> > One of the nifty things about experimental aircraft is that YOU the builder > can set any GW you want as your upper limit. Just be sure you stay within > the CG envelope. ********************************************************* > The only concern I have now is on the W&B computations. With full fuel, two > 170# pilots and a empty weight of 1072# - I can only carry 10 # luggage and > stay within the gross of 1650#. Now for the real world weights - I can have > only 34Gallons of fuel with two 185# people and no baggage. Is this near the > same figures everone else is coming up with? > > Thanks for the input. > > Doug Murray > > PS. thanks to all the other builders who took time out to advise me on this > asymetrical weight question. ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Re: Oil Cooler Alternative
I feel very strongly that the setrab cooler should not be used in aircraft. The question is not if it will fail, but when. Compared to a S/W or Niagra cooler it looks pretty flimsy, I know I have one (sitting on a shelf). A friend lost his life due to an in flight fire. The NTSB has not published any findings that I know of but has stated that the fire seemed to be from the lower center of the firewall. Could have been fuel or maybe even oil. I think the oil cooler failed. He had mounted his Setrab oil cooler in the lower center portion of the firewall. The pressure hoses feeding the cooler could have failed also. BTW the engine failed catastrophically due to oil starvation. Food for thought Gary (no setrab here) Zilik Paul Besing wrote: > > All this talk about oil coolers brought me to post about my alternative oil > cooler. I have a Setrab oil cooler. It is a swedish auto racing oil cooler > that has been successfully used in numerous Harmon Rockets. It has a very > low profile, and is VERY efficient. In 100 + degree temperatures, I have > seen 180-190 temps. I suspect I will have to close some of it off in the > summer. Picutres of this cooler are on my website under the engine pages. > Have a look. They also only cost around $70. > > Paul Besing > RV-6A N197AB Arizona > http://www.lacodeworks.com/besing > Flying > Kitlog Pro Builder's Log Software > http://www.kitlog.com > ________________________________________________________________________________
Date: Sep 10, 2001
One thing I found when I started flying was that some things broke early on and other things broke much later. I had most of my bugs pop up in the 80-100 hour range. Keep a close eye on that cooler, oil loss is no fun. Gary Zilik Paul Besing wrote: > > Well, maybe so, but the rocket guys love them, and I haven't seen a lick of > a problem in over 20 hours. I keep an eye on it every day, and I guess time > will tell, but for now, it's working perfectly. > > Paul Besing > RV-6A N197AB Arizona > http://www.lacodeworks.com/besing > Flying > Kitlog Pro Builder's Log Software > http://www.kitlog.com > ----- Original Message ----- > From: "james freeman" <flyeyes(at)bellsouth.net> > To: > Sent: Sunday, September 09, 2001 8:45 PM > Subject: Re: RV-List: Setrab Oil Cooler > ________________________________________________________________________________
From: "Todd Wiechman" <toddwiechman(at)hotmail.com>
Subject: Lycoming O-320-E2D For Sale
Date: Sep 10, 2001
Lycoming O-320-E2D for sale. First run engine with 1945 TT. New Slick mags 45 SNEW. Carburetor included. Compressions when removed were 75/76/76/72. First $6900.00. Moving soon so please call! Please contact offline at 316-721-5670 or 316-210-5670(cell) and ask for Todd. Wichita Kansas USA ________________________________________________________________________________
Subject: handheld computer question
Date: Sep 10, 2001
If you're using it with a Mac, that pretty much rules out the PocketPC / Win CE machines as they don't include Mac software. You can check out any of the Palm devices; the Sony Clie' is the neatest one I've seen yet. It runs all Palm software, has a higher resolution display (320x320) than most Palms or PocketPCs, etc. If you don't care about color, then the HandEra 330 is easily the most powerful Palm around. It also has a high-res display (320x240), sound, both CompactFlash and Secure Digital media slots, etc. All these Palm devices either include Mac connectivity software in the box or have it available for download. I also have a couple of PocketPC devices, including an IPaq, and I find that PocketPC is overrated (personal opinion only!). It's got a much faster processor, but it is slow to open applications other than the 'built-in' ones compared to any of my Palm devices (HandEra is the fastest, followed by the Clie, then the Handspring Visor Deluxe, and finally the Palm IIIc) as timed by a benchmark tool I wrote to measure such things. Also, in the month or so I've had it, IPaq in particular has crashed more than my Palm IIIc has crashed in the last 18 months - literally. BTW - I'm not a toy geek or anything like that (at least not one that is ready to admit it); I write software for a living and for these devices (it's what's paying for my RV6A!). Cheers, Brad -----Original Message----- From: d. wayne stiles [mailto:dwstiles(at)hotmail.com] Sent: Saturday, September 08, 2001 9:31 AM Subject: RV-List: handheld computer question I am beginning to consider the purchase of a handheld computer, I'd be interested in recommendations as to brand and model. My situation: It will be a year or more before I'm ready for avaition applications; my workbook publishing involves Apple/Mac computers almost exclusively; primary immediate use will be as auxillary to a new iBook. I don't really want to buy one now and then have to buy a second one in a year or two when we get our 7. I don't mind not having cutting edge tech---I'd rather let some one else find all the bugs, particularly when flying----so which way would you go? iPac, palm pilot, handspring, whatever. Wayne Stiles ________________________________________________________________________________
From: "Ollie Washburn" <skybolt-aviator(at)msn.com>
Date: Sep 10, 2001
Or Cleveland Tools has a very nice chrome extender Ollie&Lorene Washburn RV6-A,N795LW,@FD77. ________________________________________________________________________________
Subject: Looking for Mel Jordan
Date: Sep 10, 2001
Folks, I'm looking to contact Mel Jordan to ask him some more questions about his flap mod as outlined on Mike Nellis' website. All of my E-Mails to him (tmjordan(at)flash.net) bounce as Addressee unknown. Anyone know of his whereabouts? Thanks, Ralph Capen RV6AQB N822AR (reserved) ________________________________________________________________________________
Subject: Some Interesting Data (Long)
Date: Sep 10, 2001
Thread-Topic: RV-List Digest: 60 Msgs - 09/08/01 Thread-Index: AcE5BfwGSBLPYYzBSxao0feNhIBQawA/3fdw
TGFpcmQsDQogDQpIYXZlIHlvdSBkb25lIHRoZSAzLXdheSBHUFMgcnVucz8gIEkgZGlkIHNvbWUg dGVzdGluZyB0aGUgb3RoZXIgZGF5IGFuZA0KY2FtZSB1cCB3aXRoIDE2NiBrbm90cyBjcnVpc2Ug YXQgODAwMCBmZWV0IGJ5IHRoZSBHUFMgKDI0MDAgUlBNLCAyMi41IiwNCmxlYW5lZCB0byBwZWFr LCA5LjItOS41R1BIKSwgb24gYSB3YXJtICg4NSspIGRlZ3JlZSBkYXkuICBDcmFua2luZyB0aGUN CnJldnMgdXAgdG8gZ2V0IDc1JSBvbmx5IGdpdmVzIG1lIGEga25vdCBvciB0d28uICBJIGhhdmUg ZG9uZSB0aGVzZSBydW5zDQpzZXZlcmFsIHRpbWVzIG92ZXIgdGhlIGNvdXJzZSBvZiB0aGUgcGFz dCB5ZWFyIGFuZCB0eXBpY2FsbHkgYW0gd2l0aGluDQoyLTMga25vdHMgYmV0d2VlbiB0ZXN0cy4g IFNvLCBteSByZWFsLXdvcmxkIGNydWlzZSBpcyAxNjUga25vdHMuDQogDQpXaXRoIHRoYXQgYmVp bmcgc2FpZC4uLg0KIA0KVGhpcyBpcyBzbGlnaHRseSBiZWxvdyBWYW4ncyBwdWJsaXNoZWQgZmln dXJlcywgYW5kIEkgZG9uJ3QgaGF2ZSBhDQpwb29ybHkgcmlnZ2VkIG9yIGJ1aWx0IGFpcnBsYW5l LiAgSU1PIEkgdGhpbmsgVmFuJ3MgcHVibGlzaGVkIG51bWJlcnMNCmFyZSBzbGlnaHRseSBoaWdo LiAgTW9zdCBvZiBteSBsb2NhbCBSViBidWRkaWVzIGFncmVlLiAgRm9yIGV4YW1wbGUsIHRoZQ0K UlYtOCBoYXMgYSBmYXN0ZXIgcHVibGlzaGVkIGNydWlzZSBzcGVlZCB0aGFuIGRvZXMgdGhlIC00 LiAgSSBkb24ndA0KdW5kZXJzdGFuZCBob3cgdGhlIC04IGNhbiBiZSBmYXN0ZXIgd2l0aCBpdHMg Z3JlYXRlciBmcm9udGFsIGFyZWEgYW5kDQpoaWdoZXIgd2VpZ2h0IHRoYW4gYSAtNCB3aXRoIHRo ZSBzYW1lIGhvcnNlcG93ZXIuICBJIGZseSByZWd1bGFybHkgd2l0aA0KYSAxODAgQy9TIC04IHRo YXQgaXMgYSB2ZXJ5IHdlbGwgYnVpbHQgUUIgYWlyZnJhbWUgYW5kIGhpcyBjcnVpc2Ugc3BlZWQN CmlzIG9ubHkgc2xpZ2h0bHkgZmFzdGVyIHRoYW4gbWluZS4uLiBpdCB0YWtlcyBhbiBleHRyYSAx LzIiIG9mIG1hbmlmb2xkDQpwcmVzc3VyZSBmb3IgbWUgdG8ga2VlcCB1cCB3aXRoIGhpbSB3aXRo IHRoZSBzYW1lIHBvd2VyIHNldHRpbmdzLiBUaGUNCm9kZCB0aGluZyBpcyB3aGVuIHdlIGJvdGgg aGF2ZSBhIHBhc3NlbmdlciB0aGVuIGl0IHRha2VzIGEgbG90IG1vcmUNCigxLTEuNSIpIG9mIHRo cm90dGxlIGZvciBtZSB0byBrZWVwIHVwIHdpdGggaGltOyB3ZSdyZSBnb2luZyB0byBleHBsb3Jl DQp0aGF0IGZ1cnRoZXIuICBBIGZyaWVuZCdzIFJWLTQgd2lsbCBmbGF0LW91dCBzdG9tcCBib3Ro IG9mIHVzIHdpdGggdGhlDQpzYW1lIGhhcmR3YXJlIHVwIGZyb250LiAgTWF5YmUgSSBuZWVkIHRv IHR1cm4gdGhhdCBsaXR0bGUgc2V0IHNjcmV3IG9uDQp0aGUgZ292ZXJub3Igb3V0IGEgZmV3IHR1 cm5zIDspICBGV0lXDQogDQpCb2IgSmFwdW5kemENClJWLTYgTjI0NEJKIE8tMzYwQy9TIGZseWlu ZyAyMDkgaG91cnMNCg0KVGltZTogMDM6NTI6MzUgUE0gUFNUIFVTIA0KRnJvbTogIk93ZW5zLCBM YWlyZCIgPE93ZW5zQGFlcm92aXJvbm1lbnQuY29tPiANClN1YmplY3Q6IFJWLUxpc3Q6IFNvbWUg SW50ZXJlc3RpbmcgRGF0YSAoTG9uZykgDQogICAic29jYWwtcnZsaXN0IiA8U29DQUwtUlZsaXN0 QHlhaG9vZ3JvdXBzLmNvbT4gDQoNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIk93 ZW5zLCBMYWlyZCINCjxPd2Vuc0BhZXJvdmlyb25tZW50LmNvbT4gDQoNCglIaSBhbGwsIA0KDQoJ U2luY2UgSSBjb252ZXJ0ZWQgb3ZlciB0byBhIEhhcnR6ZWxsIHByb3Agb24gbXkgTy0zNjAvUlYt NiwgSSd2ZQ0Kd2FudGVkIHRvIGRvIHNvbWUgZ29vZCBkYXRhIGNvbGxlY3Rpb24uICBJIGZpbmFs bHkgZ290IGEgY2hhbmNlIHRvIGdvDQpvdXQgbGFzdCBldmVuaW5nIGFuZCBjb2xsZWN0IGEgbGl0 dGxlLiAoTGlrZSBteSBib3NzIHNlei4uLi4iRGF0YSBpcw0KZWFzeSwgR09PRCBkYXRhIGlzIGhh cmQiKS4gIFRob3VnaHQgc29tZSBvZiB5b3UgbWlnaHQgYmUgaW50ZXJlc3RlZC4NCg0KCVR3byBh cmVhcyBvZiBpbnRlcmVzdCB0byBtZSBhcmUgdG9wIHNwZWVkIChJIHdhbnQgdG8gc3RhcnQgZG9p bmcNCmEgbGl0dGxlIGRyYWcgcmVkdWN0aW9uIHdvcmsgc29vbiBhbmQgbmVlZCBhIGJhc2VsaW5l IHNwZWVkKSBhbmQNCnJhbmdlL2VuZHVyYW5jZS4gSSdtIHBsYW5uaW5nIG9uIGZseWluZyB0byB0 aGUgTGFzIENydWNlcyBSViBnZXQNCnRvZ2V0aGVyIHRoaXMgd2Vla2VuZCBhbmQgaXQncyBhIDYw MCBtaWxlIGZsaWdodCBmcm9tIExBLiAgSSB3YW50ZWQgdG8NCnNlZSBpZiBJIGNvdWxkIG1ha2Ug aXQgd2l0aG91dCBzdG9wcGluZy4NCg0KCUkndmUgYWx3YXlzIGJlZW4gY29uc2VydmF0aXZlIHdo ZW4gZmxpZ2h0IHBsYW5uaW5nLCBndWVzc2luZyAzLjUNCmhycyAoMTAgR1BIIHdpdGggcmVzZXJ2 ZSkgYW5kIGFib3V0IGEgNjAwIG1pbGUgcmFuZ2UsIGJ1dCBJJ3ZlIHdhbnRlZCB0bw0KbmFpbCBk b3duIHRoZSByZWFsIG51bWJlcnMgZm9yIG15IGFpcnBsYW5lLiAgU28gSSB3ZW50IG91dCBhbmQg YnVybmVkDQpzb21lIGdhcyB0cnlpbmcgdG8gZmlndXJlIGl0IG91dC4gIEkgY2FtZSBiYWNrIHdp dGggc29tZSBpbnRlcmVzdGluZw0KbnVtYmVycy4NCg0KCVRoZSB0ZXN0IHdhcyBmbG93biBhdCA4 MDAwIGZlZXQgZGVuc2l0eSBhbHRpdHVkZSAoYWx0aW1ldGVyIHNldA0KdG8gMjkuOTIgYW5kIGNv cnJlY3RlZCBmb3IgT0FULCB3aGljaCB3YXMgMjIgQywgd2hpY2ggbWVhbnQgSSdkIGZseSBhdA0K NTg3NSBmZWV0KSBhbmQgYXQgZGlmZmVyZW50IGFpcnNwZWVkcyB0byBjb2xsZWN0IHRoZSBmdWVs IGZsb3cNCmluZm9ybWF0aW9uLiAgSSB0aGVuIHB1dCB0aGF0IGludG8gYSBncmFwaCB0byBkZXRl cm1pbmUgYmVzdCByYW5nZSBhbmQNCmVuZHVyYW5jZS4gIEVuZ2luZSBSUE0gd2FzIDI0MDAgYW5k IHRoZSBlbmdpbmUgbGVhbmVkIHRvIHBlYWsgb24gdGhlDQpob3R0ZXN0IGN5bGluZGVyIChJIGtu b3cuLi4udGhhdCBtYXkgbm90IGJlIHRoZSBsZWFuZXN0IGN5bGluZGVyKS4NCg0KCUtub3cgZXJy b3JzIHRoYXQgSSBjYW4ndCBhY2NvdW50IGZvciByaWdodCBub3cgYXJlIHN0YXRpYyBhbmQNCmlu c3RydW1lbnRhdGlvbiBlcnJvcnMsIHNvIHRoZSBudW1iZXJzIG1heSBiZSBhIGxpdHRsZSBvZmYg aGVyZSBvcg0KdGhlcmUuIEFmdGVyIHNlbGVjdGluZyBhIHBvd2VyIHNldHRpbmcgYW5kIGFpcnNw ZWVkLCBJIGZsZXcgdGhlIGFpcnNwZWVkDQphbmQgbG9va2VkIGZvciBlbGV2YXRpb24gY2hhbmdl cywgYW5kIHRoZW4gYWRqdXN0IHRoZSBwb3dlciBhY2NvcmRpbmdseS4NCkknZCB0aGVuIGxlYW4g dG8gcGVhaywgdGhlbiBsZXQgZXZlcnl0aGluZyBzdGFiaWxpemUgYW5kIGFnYWluIG1ha2UgYW55 DQpzbWFsbCBhZGp1c3RtZW50cyB0byB0aGUgcG93ZXIgc2V0dGluZy4gIEFmdGVyIGdldHRpbmcg dG8gdGhhdCBzdGFnZSwNCkknZCBub3RlIGZ1ZWwgZmxvdywgSUFTLCBNUCwgYW5kIHRoZW4gZG8g YSAzIHdheSBHUFMgcnVuIHRvIGdldCBUQVMuICBJDQpyYW4gYWxsIHRoZXNlIGRhdGEgcG9pbnRz IG9uIG9uZSBmbGlnaHQsIHNvIHRoZSB1cHBlciBzcGVlZHMgbWF5IGJlIG9mZg0KYSBsaXR0bGUg ZHVlIHRvIGEgbG93ZXIgYWlyY3JhZnQgd2VpZ2h0IGR1ZSB0byB0aGUgZ2FzIGJlaW5nIHVzZWQg ZHVyaW5nDQp0aGUgZmxpZ2h0LiAoSSBzdGFydGVkIGF0IHRoZSBsb3dlciBhaXJzcGVlZHMgZmly c3QpLiAgSSBmbGV3IHBvaW50cw0KYmV0d2VlbiA5MCBtcGggSUFTIGFuZCBmdWxsIHRocm90dGxl IGF0IDEwIG1waCBpbnRlcnZhbHMuICBJdCB0dXJuZWQgb3V0DQp0byBiZSBhIGdvb2QgZXZlbmlu ZyB3aXRoIGFsbW9zdCBubyB0dXJidWxlbmNlIGFuZCB1bmRlciAzIG1waCBvZiB3aW5kDQphdCB0 aGUgdGVzdCBhbHRpdHVkZS4gIEkgd2FzIHBsZWFzZWQgd2l0aCB0aGUgZGF0YSBJIGdvdCwgYXMg aXQgYWxsIGZpdA0KcHJldHR5IHdlbGwgIGFuZCBjYW1lIHVwIHdpdGggc29tZSBiZWxpZXZhYmxl IGN1cnZlcyAoaS5lLiBubyBkYXRhIHBvIQ0KDQoJaW50cyB3YXkgb2ZmIHRoZSBmaXQgY3VydmUp LiANCg0KCUFmdGVyIGRvaW5nIHNvbWUgbnVtYmVyIGNydW5jaGluZyBhbmQgZ3JhcGhpbmcsIGl0 IGxvb2tzIGxpa2UNCnRoZSBtYXggZW5kdXJhbmNlIG9mIHRoZSBhaXJwbGFuZSBjb21lcyBhdCAx MDAgbXBoIElBUy8xMTIgbXBoIFRBUyB3aXRoDQphIGZ1ZWwgZmxvdyBvZiA1LjAgR1BILiAgQXNz dW1pbmcgYSA2IGdhbCByZXNlcnZlLCB0aGF0IGxlYXZlcyAzMg0KZ2FsbG9ucyB1c2FibGUuICBU aGF0IGdpdmVzIGEgNi40IGhyIGVuZHVyYW5jZSAobXkgYnV0dCBjYW4ndCBzaXQgaW4gdGhlDQpz ZWF0IHRoYXQgbG9uZykgYW5kIGEgNzE2IG1pbGUgcmFuZ2UsIHdoaWNoIGlzIDIyLjQgTVBHLiAg SSBzaG91bGQgbm90ZQ0KdGhhdCB0aGUgZW5naW5lIHdhc24ndCB2ZXJ5IGhhcHB5IGF0IHRoaXMg cG93ZXIgc2V0dGluZywgYXMgaXQgd291bGQNCnNraXAgZXZlcnkgb25jZSBpbiBhIHdoaWxlIChw cm9iYWJseSBhIGxlYW4gbWlzcykuICBBbHNvIHRoZSBmdWVsIGZsb3cNCm1ldGVyIHdhcyBhIGxp dHRsZSBmbGFreSBuZWFyIHRoZXNlIHBvd2VyIHNldHRpbmdzLCBmbHVjdHVhdGluZyBiZXR3ZWVu DQo0IHRvIDYuICBJIGp1c3QgdG9vayB0aGUgYXZlcmFnZSBvZiB3aGF0IEkgc2F3LiAgSXQgd2Fz bid0IHVudGlsIEkgd2FzDQpmbG93aW5nIGFyb3VuZCA2IEdQSCB0aGF0IHRoZSBmbG93IG1ldGVy IHNldHRsZWQgZG93bi4NCg0KCVRoZSBiZXN0IHJhbmdlIGNvbWVzIGF0IDEyNSBtcGggSUFTLyAx NDggbXBoIFRBUyB3aXRoIGEgZnVlbA0KZmxvdyBvZiA1LjUgR1BILiBVc2luZyB0aGUgc2FtZSBy ZXNlcnZlLCBJIGdldCA1LjggaHJzIGFuZCBhIDg1OCBtaWxlDQpyYW5nZSwgd2hpY2ggaXMgMjYu OCBNUEcuIChJIHN0aWxsIGNhbid0IHNpdCBpbiB0aGUgc2VhdCB0aGF0IGxvbmcpLg0KDQoJU28g cHVzaGluZyBpdCB1cCBhIGxpdHRsZSB0byA4IEdQSCB5aWVsZHMgYSA0IGhvdXIgZW5kdXJhbmNl DQoobm90IGluY2x1ZGluZyByZXNlcnZlKSBhdCAxNjAgbXBoIElBUy8gMTg1IFRBUyBmb3IgYSA3 NDAgbWlsZSByYW5nZSBhbmQNCjIzLjEgTVBHLg0KDQoJRnVsbCB0aHJvdHRsZSBjb21lcyBvdXQg YXQgOS42IEdQSCBhbmQgMTc0IG1waCBJQVMvMjAwIFRBUyB3aXRoDQphIDMuMyBociBlbmR1cmFu Y2UgYW5kIGEgNjYwIG1pbGUgcmFuZ2UgYW5kIGEgMjAuNiBNUEcgDQoNCglUaGUgbGFzdCB0ZXN0 IHdhcyBmdWxsIHRocm90dGxlLzI3MDAgcnBtIGFuZCBpdCB3YXMgMTEuNyBHUEggYW5kDQoyMDcg VEFTLiAgVGhpcyB3YXMgb25seSBvbmUgZGF0YSBwb2ludCBvbiB0aGlzIGRheSwgSSBuZWVkIHRv IGRvIHRoaXMNCnNldmVyYWwgbW9yZSB0aW1lcyB0byBhdmVyYWdlIHRoZSBzcGVlZHMgdG8gdHJ5 IHRvIGdldCBhIG1vcmUgYWNjdXJhdGUNCm51bWJlciwgYnV0IGl0J3MgYSBzdGFydC4NCg0KCVRo aXMgaXMgYSBhYm91dCBhbiAxMSBtcGggc3BlZWQgZ2FpbiBvdmVyIHRoZSBTZW5zZW5pY2ggNzJG TQ0KZml4ZWQgcGl0Y2ggcHJvcCBJIGhhZCBvbiBiZWZvcmUgKHdoaWNoIHdhcyBhbiA4MyIgcGl0 Y2gpLiAgVGhlIG1haW4NCmRpZmZlcmVuY2UgaXMgdGhhdCBJIGNhbiB1c2UgZnVsbCB0aHJvdHRs ZSB3aXRoIHRoZSBIYXJ0emVsbC4gIEF0IDgwMDANCkRBIGFuZCB0aGUgU2Vuc2VuaWNoLCBJIHN0 aWxsIGhhZCBhbm90aGVyIDMiIG9mIE1QIGxlZnQgdG8gZ28sIGJ1dCB3b3VsZA0KYmUgYXQgdGhl IDI3MDAgcnBtIGxpbWl0Lg0KDQoJQWdhaW4sIHRoaXMgd2FzIGRhdGEgdGFrZW4gb24gdGhpcyBv bmUgZGF5LCBmb3IgbXkgYWlycGxhbmUsIGFuZA0KaXMgcHJvYmFibHkgc3ViamVjdCB0byBzZXZl cmFsIGRpZmZlcmVudCBlcnJvcnMgKG15IGZseWluZyBpbmNsdWRlZCksDQpidXQgaXQgc2hvdWxk IGJlIGNsb3NlLiBJdCBkb2VzIHByb3ZpZGUgYW4gaW50ZXJlc3RpbmcgY29tcGFyaXNvbiBvZiBG Rg0KdnMgVEFTLiAgSSdkIGxpa2UgdG8gcmVwZWF0IHRoaXMgdGVzdCBhdCBhIGhpZ2hlciBhbHRp dHVkZSBhbmQgc2VlIHNvbWUNCm9mIHRoZSBlZmZlY3RzIGFzIHdlbGwsIGJ1dCB0aGF0J2xsIGhh dmUgdG8gd2FpdCB1bnRpbCBhbm90aGVyIGRheS4gIA0KDQoJTGFpcmQgDQoJUlYtNiAzNDAgaHJz IA0KCVNvQ2FsIA0KDQo ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Fwd: bolt length and front bulkhead (was Prop Spinner Front Bulkhead)
Wanted to share with the list a response I got from Ed Zercher at Sensenich regarding my prop Spinner mounting question. I completely forgot my contact with someone at the source. Thanks again, Ed, for your note! This information might ne helpful to someone else. BTW I do have the correct bulkhead. I guess I'll just get out my files and sandpaper... - Mike > From: "Ed Zercher" <ez(at)sensenich.com> > To: > Subject: bolt length and front bulkhead > Date: Mon, 10 Sep 2001 08:51:11 -0400 > > Mike, > > I saw your posting on the RV list and thought I would help you "off > line". > First off, for general information, we recommend that the bolt be > engaged a > minimum of the bolt diameter. This is a 1 to 1 ratio when using > hardened > bolts and hardened bushings. So, if your bolt is 7/16 inch diameter, > then > you must engage an minimum of 7/16 of threads in the bushing. There > are many > people who will tell you that you must have 2 threads coming through > the > bushing or you must be even with the bushing. While most > installations do > this, it is not necessary with hardened bolts and bushings. > > Now on to the real problem. If you have a need to shim the front > bulkhead > into place, I would assume that you have the front bulkhead used for > wooden > props. Vans' has a front bulkhead that is to be used with our metal > prop. It > should fit up nicely against the hub face. I believe that the part > number is > S-605 SEN. This would be a much better way to go. I'm afraid that by > moving > the front bulkhead out with washers will probably cause cracking down > the > road in the front bulkhead because it is not flush with the hub. > > If you have any questions please let me know. > > Ed > ________________________________________________________________________________
Subject: Woodward Prop Governor Overhauler
Date: Sep 10, 2001
All, Any recommendations for a good & reasonable Woodward prop governor overhaul shop, perferably East of the Miss? Thanks, Chuck & Dave Rowbotham RV-8A (Flying) Niantic, CT (Westerly airport) ________________________________________________________________________________
Subject: Pictures of Jan Eggenfellner Subaru Engine package (Texas visit)
Date: Sep 10, 2001
Thread-Topic: Pictures of Jan Eggenfellner Subaru Engine package (Texas visit) Thread-Index: AcE6DXsjiKgRV3vmRweABO/jLmYjkg=
From: "Reeves, Doug" <Douglas.Reeves(at)archongroup.com>
Jan visited Texas yesterday and I took the digital camera down and shot about 20 pics. He's traveling the USA to raise awareness of his Subaru firewall forward package for RV's. The GlaStar they were in has been running for four years (he told me). If you feel like giving the pictures a look you can see them at http://members6.clubphoto.com/doug412210/503703 . Most of the images are 640pixels wide but a few are 2048wide. You can see where he'll be next on his web site at www.subaruaircraft.com . Hope to meet a few of the listers this weekend at Las Cruces! Regards, Doug Reeves VAF-World Wide Wing http://www.vansaircraft.net ________________________________________________________________________________
Date: Sep 10, 2001
I'll second Gary's opinion. The oil cooler is the last place to skimp. A little data to back that up???? I broke the Setrab I had installed in my RV-6 at 3 hrs. Dumped 5 of the 6 qts of oil in the airplane before I got it back to the airport. (If you want all the gory details, see the archives). I was lucky I got back to the airport and didn't have an oil fire. The oil was everywhere under the cowl. Why it didn't catch fire, I'll never know. I seem to live an adventously charmed life (with oil cooler failures and bird strikes). Why did the oil cooler fail. Could have been my installation, but after disecting the cooler, it sure didn't look robust enough for me. I now have a Niagra installed in the same manner as I mounted the Setrab, and it's lasted over 300 hours. Paul, please keep an eye on you cooler, and best of luck from one who survived an oil cooler failure. I hope it doesn't happen to you. Just another opinion. Regards, Laird RV-6 SoCal From: rv-list(at)matronics.com on Mon, Sep 10, 2001 6:58 AM Subject: Re: RV-List: Oil Cooler Alternative I feel very strongly that the setrab cooler should not be used in aircraft. The question is not if it will fail, but when. Compared to a S/W or Niagra cooler it looks pretty flimsy, I know I have one (sitting on a shelf). A friend lost his life due to an in flight fire. The NTSB has not published any findings that I know of but has stated that the fire seemed to be from the lower center of the firewall. Could have been fuel or maybe even oil. I think the oil cooler failed. He had mounted his Setrab oil cooler in the lower center portion of the firewall. The pressure hoses feeding the cooler could have failed also. BTW the engine failed catastrophically due to oil starvation. Food for thought Gary (no setrab here) Zilik Paul Besing wrote: > > All this talk about oil coolers brought me to post about my alternative oil > cooler. I have a Setrab oil cooler. It is a swedish auto racing oil cooler > that has been successfully used in numerous Harmon Rockets. It has a very > low profile, and is VERY efficient. In 100 + degree temperatures, I have > seen 180-190 temps. I suspect I will have to close some of it off in the > summer. Picutres of this cooler are on my website under the engine pages. > Have a look. They also only cost around $70. > > Paul Besing > RV-6A N197AB Arizona > http://www.lacodeworks.com/besing > Flying > Kitlog Pro Builder's Log Software > http://www.kitlog.com > ________________________________________________________________________________
Date: Sep 10, 2001
This is allowed in the U.S. but Doug is in Canada. Do they have the same flexibility or do they have to use the designer's numbers? I think Oz is restricted, not sure about Canada or other countries. Greg Young > > Change your Gross weight to 1750. You are the builder, and > can do so. It > is safe, as well, as long as you are not past your cg > envelope when fuel > burns off. The 1650 number is a guide, but Van's has told > me "off the > record" that they have seen gross weights of 1800 pounds and still > safe..just watch the cg shift with the fuel burn. > > > > > > Kevin - Thanks for the encouraging words. It's too bad your > not closer, - > I > > would have no problem with you flying my craft. > > > > The only concern I have now is on the W&B computations. > With full fuel, > two > > 170# pilots and a empty weight of 1072# - I can only carry > 10 # luggage > and > > stay within the gross of 1650#. Now for the real world > weights - I can > have > > only 34Gallons of fuel with two 185# people and no baggage. > Is this near > the > > same figures everone else is coming up with? > > > > Thanks for the input. > > > > Doug Murray > > > > PS. thanks to all the other builders who took time out to > advise me on > this > > asymetrical weight question. ________________________________________________________________________________
Date: Sep 10, 2001
I have a Setrab cooler for sale---$25. hilljw(at)aol.com Jimmy rv8a ________________________________________________________________________________
Date: Sep 10, 2001
Alex, Congradulations on your first flight. Thanks for sharing. Eric Newton - Long Beach, MS RV-6A - N57ME (fiinal stuff before inspection) www.ericsrv6a.com -----Original Message----- From: "owner-rv-list-server(at)matronics.com" <owner-rv-list-server(at)matronics.com> on behalf of "Alex Peterson" Subject: RV-List: N66AP First Flight My 6A is officially an airplane as of today! The first flight was completed by Tom Irlbeck, an accomplished pilot and RV8 builder/owner. A total of 4.2 flight hours were logged today. My face hurts from the smiling. Stick with it, it is worth it. Performance data to follow, but the equipment list is: Aerosport O360 with Airflow Perf. fuel injection, C/S prop, Lasar ignition, RMI engine monitor, Garmin 340 audio panel, Garmin 327 trans., Garmin 430, King Ky97 com, Century 2000 fully coupled two axis autopilot w/HSI, inverted fuel/oil, leather, stereo, Hooker harnesses. Painted outside and primed inside, 1174 calibrated three scale empty weight (BTW, re recent weight thread, both main gear weighed the same, 417lbs.). However, I only weigh 155 : ). Anyway, really an unbelievable feeling. Many thanks to all you wonderful contributors to this list, it really makes a difference. Alex Peterson Maple Grove, MN 6A N66AP, 4.2 hours! ________________________________________________________________________________
Subject: Re: handheld computer question
Date: Sep 10, 2001
Brad, Since you seem to be the resident software expert, what is your take on Doug's observations (below) of using the iPaq to run both the Anywhere map and a MP3 player? The thread started with my question as to the best hard drive based MP3 player as this is what I had decided to using my plane for tunes. Then I thought about getting a two-for-one by using the iPaq. With your observations about the iPaq crashing and Doug's comment on not being able to run both software applications at the same time, I am back to considering a dedicated MP3 player. comments? Ross Mickey RV-6 +++++++++++++++++++++From Doug Reeves Hey Ross (and listers), I tried to run AWM and play mp3 files at the same time this weekend. No joy. I think the reason it didn't work is twofold: 1. My iPaq is a 32MB model (the ones shipping now have 64MB of RAM) 2. My 900KB road database was installed on AWM. You could have probably uninstalled the road database and had it work, but I didn't want to do that, as I use the road db when I'm driving on a trip and want the GPS in the car. Hope this helped, D ----- Original Message ----- From: "Benson, Bradley" <bbenson(at)trane.com> Sent: Monday, September 10, 2001 7:18 AM Subject: RE: RV-List: handheld computer question > Also, in the > month or so I've had it, IPaq in particular has crashed more than my Palm > IIIc has crashed in the last 18 months - literally. ________________________________________________________________________________
Date: Sep 10, 2001
It might not have been the oil coolers fault. Too small oil lines boost the pressure and if the oil cooler is in that line, it blows. We had 3 oil failures in a Long Ez that way PLUS the oil filter blew. Went to a larger oil line and the high pressure, high oil temps went away. I personally would check the pressure into and out of the oil cooler as the gage reads pressures a long ways away from the oil pump outlet. Your stronger oil cooler may be just masking the real problem. If you have any further questions, contact Ron White. longez38ar(at)juno.com He and his friend with the blown oil coolers did a lot of instrumentation before they found the real reasons for blown oil coolers and high oil temps in their O-320 Lycomings. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Owens, Laird" <Owens(at)aerovironment.com> Sent: Monday, September 10, 2001 10:36 AM Subject: RE: RV-List: Oil Cooler Alternative I'll second Gary's opinion. The oil cooler is the last place to skimp. A little data to back that up???? I broke the Setrab I had installed in my RV-6 at 3 hrs. Dumped 5 of the 6 qts of oil in the airplane before I got it back to the airport. (If you want all the gory details, see the archives). I was lucky I got back to the airport and didn't have an oil fire. The oil was everywhere under the cowl. Why it didn't catch fire, I'll never know. I seem to live an adventously charmed life (with oil cooler failures and bird strikes). Why did the oil cooler fail. Could have been my installation, but after disecting the cooler, it sure didn't look robust enough for me. I now have a Niagra installed in the same manner as I mounted the Setrab, and it's lasted over 300 hours. Paul, please keep an eye on you cooler, and best of luck from one who survived an oil cooler failure. I hope it doesn't happen to you. Just another opinion. Regards, Laird RV-6 SoCal From: rv-list(at)matronics.com on Mon, Sep 10, 2001 6:58 AM Subject: Re: RV-List: Oil Cooler Alternative I feel very strongly that the setrab cooler should not be used in aircraft. The question is not if it will fail, but when. Compared to a S/W or Niagra cooler it looks pretty flimsy, I know I have one (sitting on a shelf). A friend lost his life due to an in flight fire. The NTSB has not published any findings that I know of but has stated that the fire seemed to be from the lower center of the firewall. Could have been fuel or maybe even oil. I think the oil cooler failed. He had mounted his Setrab oil cooler in the lower center portion of the firewall. The pressure hoses feeding the cooler could have failed also. BTW the engine failed catastrophically due to oil starvation. Food for thought Gary (no setrab here) Zilik Paul Besing wrote: > > All this talk about oil coolers brought me to post about my alternative oil > cooler. I have a Setrab oil cooler. It is a swedish auto racing oil cooler > that has been successfully used in numerous Harmon Rockets. It has a very > low profile, and is VERY efficient. In 100 + degree temperatures, I have > seen 180-190 temps. I suspect I will have to close some of it off in the > summer. Picutres of this cooler are on my website under the engine pages. > Have a look. They also only cost around $70. > > Paul Besing > RV-6A N197AB Arizona > http://www.lacodeworks.com/besing > Flying > Kitlog Pro Builder's Log Software > http://www.kitlog.com > ________________________________________________________________________________
Date: Sep 10, 2001
Ross, That's the way I would go, mainly for the reason that I wouldn't want a non-neccesary item (the MP3 player) potentially disrupting something more important (the GPS). I am not confident enough in any of my handheld devices (Palm or Pocket PC) to use them for navigation at this point. It's definately not a knock on either Palm or Pocket PC; it's just that I trust the software QA process of a larger company (Garmin, for example) over a smaller company. My plan is to stick an in-dash CD/MP3 player into my panel and run it through a stereo intercom. By the time I get to that point, they should be practically giving them away :-). I had a Sony in-dash CD in my Archer, and that is probably the single biggest thing I miss on X/C trips. I'd swear I could pick up an extra ten knots just by picking the right CD :-) Cheers, Brad RV6AQB... -----Original Message----- From: Ross Mickey [mailto:rmickey(at)ix.netcom.com] Sent: Monday, September 10, 2001 12:01 PM Subject: Re: RV-List: handheld computer question Brad, Since you seem to be the resident software expert, what is your take on Doug's observations (below) of using the iPaq to run both the Anywhere map and a MP3 player? The thread started with my question as to the best hard drive based MP3 player as this is what I had decided to using my plane for tunes. Then I thought about getting a two-for-one by using the iPaq. With your observations about the iPaq crashing and Doug's comment on not being able to run both software applications at the same time, I am back to considering a dedicated MP3 player. comments? Ross Mickey RV-6 +++++++++++++++++++++From Doug Reeves Hey Ross (and listers), I tried to run AWM and play mp3 files at the same time this weekend. No joy. I think the reason it didn't work is twofold: 1. My iPaq is a 32MB model (the ones shipping now have 64MB of RAM) 2. My 900KB road database was installed on AWM. You could have probably uninstalled the road database and had it work, but I didn't want to do that, as I use the road db when I'm driving on a trip and want the GPS in the car. Hope this helped, D ----- Original Message ----- From: "Benson, Bradley" <bbenson(at)trane.com> Sent: Monday, September 10, 2001 7:18 AM Subject: RE: RV-List: handheld computer question > Also, in the > month or so I've had it, IPaq in particular has crashed more than my Palm > IIIc has crashed in the last 18 months - literally. ________________________________________________________________________________
Date: Sep 10, 2001
Thanks, Brad. Why the CD player? The thing I don't like about them is that they are heavy (we don't need the built in amp to run speakers), big, and they can skip or pop open. The MP3 players seem lighter and more trustworthy. The downside is that you have to burn your CD's into them. Ross > My plan is to stick an in-dash CD/MP3 player into my panel and run it > through a stereo intercom. By the time I get to that point, they should be > practically giving them away :-). I had a Sony in-dash CD in my Archer, > and that is probably the single biggest thing I miss on X/C trips. I'd > swear I could pick up an extra ten knots just by picking the right CD :-) > > Cheers, > Brad > RV6AQB... ________________________________________________________________________________
Subject: HS front spar riveting
Date: Sep 10, 2001
I've got a couple questions about finishing up the front HS spar (RV-7). 1) The front HS spar is primed and clecoed together, ready for riveting. But I'm curious about the riveting technique...what do most builders do? Do you just lay the spar on its side (on the flanges) and go to town? Do you clamp it down somehow while riveting or let it sit free on a bench? What's the best technique for driving those rivets holding the angles to the spars? 2) Also, the instructions and plans are somewhat confusing...I believe I'm NOT supposed to rivet every hole...it appears that the holes where the spar gets drilled to the fuselage attachment would preclude the need for riveting...or do they get drilled out later? 3) The RV-7 empennage kit came with a stack of scrap Alclad sheets. Should I be vigilant about preserving these sheets for fabricating small flanges and stuff down the line, or should I feel free to screw around with these scrap sheets? It's been a few weeks since the SportAir workshop, and I'd like to practice riveting with the gun again before I start doing the front spar. I would love to take some of this scrap and mess around with it for practice. Or should I save it? Thanks, )_( Dan dan(at)rvproject.com http://www.rvproject.com ________________________________________________________________________________
Date: Sep 10, 2001
I have a lot of CDs already, and plus you can fit *lots* of MP3s onto a CD. I never had any problem with it skipping or popping the disc out (even in L3 precip with continuous moderate turbulence), and as a bonus you get an AM/FM stereo. The radio sure beats an ADF for catching the news, etc. If I didn't have any CDs already, I'd seriously consider an MP3-only unit. Cheers, Brad -----Original Message----- From: Ross Mickey [mailto:rmickey(at)ix.netcom.com] Sent: Monday, September 10, 2001 12:51 PM Subject: Re: RV-List: handheld computer question Thanks, Brad. Why the CD player? The thing I don't like about them is that they are heavy (we don't need the built in amp to run speakers), big, and they can skip or pop open. The MP3 players seem lighter and more trustworthy. The downside is that you have to burn your CD's into them. Ross > My plan is to stick an in-dash CD/MP3 player into my panel and run it > through a stereo intercom. By the time I get to that point, they should be > practically giving them away :-). I had a Sony in-dash CD in my Archer, > and that is probably the single biggest thing I miss on X/C trips. I'd > swear I could pick up an extra ten knots just by picking the right CD :-) > > Cheers, > Brad > RV6AQB... ________________________________________________________________________________
Subject: Fw: OPT-1 Question/Problem (?)
Date: Sep 10, 2001
----- Original Message ----- From: "John" <fasching(at)amigo.net> Sent: Monday, September 10, 2001 1:10 PM Subject: OPT-1 Question/Problem (?) RV-Listers: I sent the message below to Electronics International. I would also appreciate any comments from other RV'ers that might help me resolve my confusion. Thanks in advance. > I installed an EI OPT-1 Oil Temp/Oil Pressure gauge in my RV6A experimental > airplane. It seemed to work just fine. BUT... > > My old oil temp gauge always showed an operating oil temperature of around > 200 degrees, more or less, depending on what I was doing. > > The OPT-1 showed oil temperatures MUCH higher, around 225-degrees. > After reworking the oil cooler's duct system (A Niagara 20002A unit) and > adding a "Cool Collar" to the oil filter (a finned heat discharge metal > sleeve), and adding heat shields to deflect hot air from the exhaust away > from the oil sump, and adding a cowl flap below the oil cooler to increase > exit air volume (or reduce exit air pressure) I still find I am too high (if > I am to believe the OPT-1) > > Today I put the oil temperature sensor into boiling water and left it 'cook' > for about 5 minutes. The local altimeter was 30.37 inches of Hg, and the > temperature was 72-F. While the sensor was in the boiling water the OPT-1 > gave a reading of 189-degrees. (This appears to be reading too low if the > charts on altitude vs boiling points I have are correct.) > > Strangely, this seems backwards ... I would expect it to read HIGHER than > 189-F when in the water, and if my old gauge was ANYWHERE near right and the > OPT-1 was in error. > > I would appreciate your comments before I tear more of the airplane apart > trying to resolve the problem. > > John fasching(at)amigo.net > > ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Re: Fwd: bolt length and front bulkhead (was Prop Spinner Front
Bulk... ________________________________________________________________________________
Date: Sep 10, 2001
> > >Ross, > >That's the way I would go, mainly for the reason that I wouldn't want a >non-neccesary item (the MP3 player) potentially disrupting something more >important (the GPS). I am not confident enough in any of my handheld >devices (Palm or Pocket PC) to use them for navigation at this point. It's >definately not a knock on either Palm or Pocket PC; it's just that I trust >the software QA process of a larger company (Garmin, for example) over a >smaller company. > Some comments on the iPaq and Anywhere Moving Map for navigation. I first saw the AWM system at the Cougar Landing fly-in this year. My first reaction was to walk away fast from anything with that many parts and cords but later became somewhat seduced with all the neato features. I ended up buying a system and have nothing but regrets for doing so. I have the 3650 iPaq. First I purchased a Pharos GPS to go with it. The Pharos never did work well with the AWM software and the iPaq. I don't know where the problem was, after all you are dealing with three different companies here (four if you include Microsoft). The system would often lose navigational lock even though communication was still good between the GPS and the iPaq. Step two was to buy another GPS, the more expensive one recommended by AWM, a Garmin 35. This setup works much better. The Garmin does not lose navigation lock and acquires the satellites quickly. But still there were problems, such as the iPaq unexpectedly turning off, or only allowing me to navigate to an airport in South America until it is rebooted. I later found out the turning off problem will not occur, if you follow a certain shut down sequence every time. It is not enough to turn the unit off. More problems: Screen visibility is often terrible. This depends on sun angle and whether I am wearing sunglasses or not, but more often than not, when mounted in my panel, it is next to impossible to read anything on the screen except for the very large and high contrast items, and even then I may need to shade with my hand to read what I want. The software is amateurish. You read things like it shows airspace boundaries and distances to airports continuously, but they do not say the software is not smart enough to adjust such that you can actually see those things. For instance the mileage figures are generally displayed on top of or under something else such that it is illegible. My biggest hope was that this setup would help in complex airspace areas like Southern California. It is completely hopeless in such an area to see much of anything as things are just piled on top of each other. Very inexpensive Garmin street GPS's are smart enough to adjust the display to avoid this problem. The software in not dependable. As just one example, I was flying to the El Paso area this weekend and wanted to know how far to the El Paso airport so I could report my distance to ATC (a very basic function). First I tried to read the display directly. No chance. Then I used the nearest function but ELP would not show up. Many other airports, further away showed up, but not that one. Typical. Then I started thinking about how I would report my position to ATC in an emergency. My old panel mount just requires a knob turn to the lat/long position, but I couldn't think of any way to do it with the AWM. The input procedure is hopeless. It takes a much more coordinated person than me to input something like an identifier with the tiny onscreen typewriter keyboard in anything but perfectly smooth air. AWM has tried to improve this recently, but I find I can't use the new system, because I can't read the screen well enough. I am using this system now because my old panel mount UPS 360 GPS is in the shop. The UPS GPS is a very basic unit but I have new found respect for it. It is reliable (until it broke) and it is always easy to read and I can input data. It provides almost everything I need a GPS for, simply and reliably and it runs my autopilot. I still am not happy with the way it displays SUA but that is about my only complaint. I know there are people that like this system but I would urge anyone who is considering purchasing it to try it in an airplane. I am going to keep the iPaq for other purposes but anyone who wants a discount price on a Pharos GPS or Garmin 35 GPS (both with integrated antenna) or the AWM software, just let me know. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Subject: Re: Fw: OPT-1 Question/Problem (?)
Date: Sep 10, 2001
John, I also have the OPT-1 and have been meaning to do the boiling water test but haven't gotten around to it. A reading of 189 in water that you know is 212 is most disturbing for a gauge that is supposed to be top of the line. Please keep us posted as to how E.I. responds and what ends up happening. Now you have me worried that mine is not accurate. BTW, I've always found that the phone works better for tech support issues with them than e-mail. Dave Campbell is their tech support guy and he's generally very helpful. Randy Lervold RV-8, 127 hrs. > ----- Original Message ----- > From: "John" <fasching(at)amigo.net> > To: <Sales@Buy-EI.com> > Sent: Monday, September 10, 2001 1:10 PM > Subject: OPT-1 Question/Problem (?) > > RV-Listers: I sent the message below to Electronics International. I would > also appreciate any comments from other RV'ers that might help me resolve my > confusion. Thanks in advance. > > > I installed an EI OPT-1 Oil Temp/Oil Pressure gauge in my RV6A > experimental > > airplane. It seemed to work just fine. BUT... > > > > My old oil temp gauge always showed an operating oil temperature of around > > 200 degrees, more or less, depending on what I was doing. > > > > The OPT-1 showed oil temperatures MUCH higher, around 225-degrees. > > After reworking the oil cooler's duct system (A Niagara 20002A unit) and > > adding a "Cool Collar" to the oil filter (a finned heat discharge metal > > sleeve), and adding heat shields to deflect hot air from the exhaust away > > from the oil sump, and adding a cowl flap below the oil cooler to increase > > exit air volume (or reduce exit air pressure) I still find I am too high > (if > > I am to believe the OPT-1) > > > > Today I put the oil temperature sensor into boiling water and left it > 'cook' > > for about 5 minutes. The local altimeter was 30.37 inches of Hg, and the > > temperature was 72-F. While the sensor was in the boiling water the > OPT-1 > > gave a reading of 189-degrees. (This appears to be reading too low if the > > charts on altitude vs boiling points I have are correct.) > > > > Strangely, this seems backwards ... I would expect it to read HIGHER than > > 189-F when in the water, and if my old gauge was ANYWHERE near right and > the > > OPT-1 was in error. > > > > I would appreciate your comments before I tear more of the airplane apart > > trying to resolve the problem. > > > > John fasching(at)amigo.net ________________________________________________________________________________
Subject: Empennage Jig Question
Date: Sep 10, 2001
I'm getting some conflicting opinions, so I thought I would ask what other folks are doing about using a jig for the RV-7 empennage. (I'll likely get some more conflicting opinions, I know, but I hope more input will help _me_ come to _my_ decision on the issue.) I have heard people say (and some of Van's literature) that with the pre-punched parts on the RV-7 you don't really need to build the big H-frame jig. I have gotten the impression that some feel it is fine to just build on a bench top. Did you build the jig? Did you skip it? Enquiring minds wanna know. Can anyone give me the pros/cons of using/not-using the jig? How about building a jig that is _not_ attached to the ceiling, but is on casters (as I have seen at least one person doing on their web site) so that it can be rolled out of the way? I don't _mind_ building it (and attaching it to the ceiling) if that is the right thing to do. However, if I can delay consuming that space in the garage (or make the pain less by having it be movable) it would be great to be able to do so! Thanks, in advance, for any info you can give me. :) -- Dwight Empennage kit arriving on Wednesday .... ________________________________________________________________________________
Date: Sep 10, 2001
Hi Dwight, I did my 8 (pre-punched skins) in a jig. Before starting I thought the jig was a real hassle. It's not. It is a great way to hold the HS and VS not to mention the wings, while drilling and riveting. Whatever method you use you will want it secure. Good luck, Jack DSM RV8 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dwight Frye Sent: Monday, September 10, 2001 3:31 PM Subject: RV-List: Empennage Jig Question I'm getting some conflicting opinions, so I thought I would ask what other folks are doing about using a jig for the RV-7 empennage. (I'll likely get some more conflicting opinions, I know, but I hope more input will help _me_ come to _my_ decision on the issue.) I have heard people say (and some of Van's literature) that with the pre-punched parts on the RV-7 you don't really need to build the big H-frame jig. I have gotten the impression that some feel it is fine to just build on a bench top. Did you build the jig? Did you skip it? Enquiring minds wanna know. Can anyone give me the pros/cons of using/not-using the jig? How about building a jig that is _not_ attached to the ceiling, but is on casters (as I have seen at least one person doing on their web site) so that it can be rolled out of the way? I don't _mind_ building it (and attaching it to the ceiling) if that is the right thing to do. However, if I can delay consuming that space in the garage (or make the pain less by having it be movable) it would be great to be able to do so! Thanks, in advance, for any info you can give me. :) -- Dwight Empennage kit arriving on Wednesday .... ________________________________________________________________________________
Date: Sep 10, 2001
Dwight, Since it's possibly my website and castered wing jig that you may be referring to, let me add a few comments. I think the critical difference you may be overlooking is the match punched empennage of the RV-9A vs. the pre-punched RV-7. Someone correct me if I'm wrong, but I believe the RV-7 tail is still the original -6 kit with prepunched skins, but not match punched ribs. I'm not sure what other parts on the -7 empennage are pre-punched, but I believe they recommend using the jig to make sure you get things square. The RV-9 empennage is 100% match punched - all ribs, skins and spars. Thus you can build it on the bench in a couple V-blocks with out a rigid jig because there is no chance of misalignment. I built my -9 empennage on the bench prior to construction of my rolling wing jig. The rolling jig should work great for the -7 wings (and new match punched -8) as well since they are completely match punched. With the match punched wing kits you only need to secure the main spar at the ends and let the rear spar hang below. I did this with my wings and dropped a plumb bob from either end to check for twist and found them to be within 1/32" at each end - both wings. I believe you could build a very rigid castered jig for building the pre-punched HS and VS and match punched wings. Good luck, Todd Houg RV-9A - N194TH reserved St. Francis, MN -----Original Message----- From: Dwight Frye [mailto:dwight(at)openweave.org] Sent: Monday, September 10, 2001 3:31 PM Subject: RV-List: Empennage Jig Question I'm getting some conflicting opinions, so I thought I would ask what other folks are doing about using a jig for the RV-7 empennage. (I'll likely get some more conflicting opinions, I know, but I hope more input will help _me_ come to _my_ decision on the issue.) I have heard people say (and some of Van's literature) that with the pre-punched parts on the RV-7 you don't really need to build the big H-frame jig. I have gotten the impression that some feel it is fine to just build on a bench top. Did you build the jig? Did you skip it? Enquiring minds wanna know. Can anyone give me the pros/cons of using/not-using the jig? How about building a jig that is _not_ attached to the ceiling, but is on casters (as I have seen at least one person doing on their web site) so that it can be rolled out of the way? I don't _mind_ building it (and attaching it to the ceiling) if that is the right thing to do. However, if I can delay consuming that space in the garage (or make the pain less by having it be movable) it would be great to be able to do so! Thanks, in advance, for any info you can give me. :) -- Dwight Empennage kit arriving on Wednesday .... ________________________________________________________________________________
Subject: Re: Handheld GPS
Date: Sep 10, 2001
imho the best gps for the $ is Lowrance 300.Been using one since they first came out.I now also have a Anywhere map using a ipaq pda. Ollie&Lorene Washburn RV6-A,N795LW,@FD77. ________________________________________________________________________________
Date: Sep 10, 2001
In a message dated 9/10/01 4:05:36 PM Eastern Daylight Time, 6430(at)axion.net writes: << I would like to ask your opinion on which make/model you would get as best bang for the buck. >> I went through this same process a couple of months ago. I was looking for a unit to replace my old Trimble Flightmate Pro, which had an LCD that was going downhill fast. I wanted to spend ($500 or less) and narrowed it down pretty quickly to the Lowrance Airmap 100 and the Garmin GPS III Pilot. The Lowrance was availible for $375 or so without accessories, and the Garmin was about $100 more without accessories. Eventually, online reviews at Avweb, Chief Avionics, and other sites showed a consensus that the Lowrance was a better value, because it is supposedly easier to use, and costs less, while having better features and similar GPS performance. The Lowrance left a few $ left in the budget, so I went ahead and got the entire Lowrance kit, with yoke mount (yoke mount? who needs that?), cigarette lighter adapter, carrying case, and an external antenna (the only important item). I had some concern before I used the unit that I would need the external antenna, because I strap the GPS to my leg, kind of like a kneeboard. As it turns out, I get good reception without the external antenna, so it and the remainder of the accessory package stay at home now. My recommendation: Buy the Lowrance without any accessories. If it turns out that you (or any other lister) needs any of the accessories, I'm taking offers. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Subject: Handheld GPS
Date: Sep 10, 2001
I have used my Airmap 300 for 2+ years now. Works great except in a high wing it has a tendency to loose signal at times. (I never use the external antenna which would help) Greg -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ollie Washburn Sent: Monday, September 10, 2001 2:58 PM Subject: Re: RV-List: Handheld GPS imho the best gps for the $ is Lowrance 300.Been using one since they first came out.I now also have a Anywhere map using a ipaq pda. Ollie&Lorene Washburn RV6-A,N795LW,@FD77. ________________________________________________________________________________
Subject: Re: HS front spar riveting
Date: Sep 10, 2001
Dan, (1) Squeeze all the rivets you can with a hand sqeezer! Just set a 2x4 under each end and start in middle and work to the ends. If you must set some rivets with the gun, it helps to have the spar held firm while riveting. (2) Wait on drilling the holes that will attach the HS to the fuse. Those are drilled in assembly. (3) I used very little of the scrap in the bundles. Guess you could practice with it. The key to good riveting is AIR PRESSURE. You will need a air setting for the 3/32" and more air for the 1/8". Find a setting that gives you a good shop head with a burst that lasts about 1 to 1 1/2 seconds on 3/32". Add more air and a burst of about 2 seconds on 1/8". Masking tape on the flush sets and duct tape on the universal head sets helps keep the manufactured heads looking nice. And ofcourse, good alignment of the gun and bucking bar on the rivet helps a lot! Good luck, Jerry Calvert Edmond Ok -6 ----- Original Message ----- From: Dan Checkoway <dan(at)rvproject.com> Sent: Monday, September 10, 2001 1:16 PM Subject: RV-List: HS front spar riveting > > I've got a couple questions about finishing up the front HS spar (RV-7). > > 1) The front HS spar is primed and clecoed together, ready for riveting. > But I'm curious about the riveting technique...what do most builders do? Do > you just lay the spar on its side (on the flanges) and go to town? Do you > clamp it down somehow while riveting or let it sit free on a bench? What's > the best technique for driving those rivets holding the angles to the spars? > > 2) Also, the instructions and plans are somewhat confusing...I believe I'm > NOT supposed to rivet every hole...it appears that the holes where the spar > gets drilled to the fuselage attachment would preclude the need for > riveting...or do they get drilled out later? > > 3) The RV-7 empennage kit came with a stack of scrap Alclad sheets. Should > I be vigilant about preserving these sheets for fabricating small flanges > and stuff down the line, or should I feel free to screw around with these > scrap sheets? It's been a few weeks since the SportAir workshop, and I'd > like to practice riveting with the gun again before I start doing the front > spar. I would love to take some of this scrap and mess around with it for > practice. Or should I save it? > > Thanks, > )_( Dan > dan(at)rvproject.com > http://www.rvproject.com > > ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Re: Woodward Prop Governor Overhauler
In a message dated 9/10/01 11:25:18 AM Eastern Daylight Time, crowbotham(at)hotmail.com writes: > All, > > Any recommendations for a good & reasonable Woodward prop governor overhaul > shop, perferably East of the Miss? > > Thanks, > > Chuck & Dave Rowbotham > RV-8A (Flying) > I got mine overhauled at Tiffin Aire in Tiffin, Ohio. I checked a number of Eastern shops and they gave me the best price. Best is relative, it cost less than a new gov. Their number is (800) 553-7767. Rick McBride ________________________________________________________________________________
Date: Sep 10, 2001
Comment inserted in Jerry's message. > >Dan, > >(2) Wait on drilling the holes that will attach the HS to the fuse. Those >are drilled in assembly. If you need to use the gun, it is worth using the C-Frame tool if you have one. My Avery C-Frame tool came with an attachment that fits into a rivet gun. This holds the gun perfectly still. You just have to hold the spar with one hand, and squeeze the trigger with the other. Works beautifully, much better than using a bucking bar, as everything is held in nice alignment. >----- Original Message ----- >From: Dan Checkoway <dan(at)rvproject.com> >To: ; ; > >Sent: Monday, September 10, 2001 1:16 PM >Subject: RV-List: HS front spar riveting > > > > > > I've got a couple questions about finishing up the front HS spar (RV-7). > > > > 1) The front HS spar is primed and clecoed together, ready for riveting. > > But I'm curious about the riveting technique...what do most builders do? >Do > > you just lay the spar on its side (on the flanges) and go to town? Do you > > clamp it down somehow while riveting or let it sit free on a bench? >What's > > the best technique for driving those rivets holding the angles to the >spars? > > > > 2) Also, the instructions and plans are somewhat confusing...I believe I'm > > NOT supposed to rivet every hole...it appears that the holes where the >spar > > gets drilled to the fuselage attachment would preclude the need for > > riveting...or do they get drilled out later? > > > > 3) The RV-7 empennage kit came with a stack of scrap Alclad sheets. >Should > > I be vigilant about preserving these sheets for fabricating small flanges > > and stuff down the line, or should I feel free to screw around with these > > scrap sheets? It's been a few weeks since the SportAir workshop, and I'd > > like to practice riveting with the gun again before I start doing the >front > > spar. I would love to take some of this scrap and mess around with it for > > practice. Or should I save it? > > > > Thanks, > > )_( Dan > > dan(at)rvproject.com > > http://www.rvproject.com > > > > ________________________________________________________________________________
Date: Sep 10, 2001
Austin, Take a good look at the Garmin GPS Pilot III. I have been flying with mine for three years now and like it a lot. It sits on the center of the glare shield in my RV-6 where it is out of the way and easy to see. The screen is a little small, but it is easy enough to zoom in and out depending on what you want to see. I love the ground mapping features and the database. I thought mine was a steal at $599. Today, I think you can get it anytime for $475, $425 if you can catch it on sale. The only extra I bought was the aux power cord to save on batteries in the long run. Good luck in your search Bob Hall, RV6 Colorado Springs ________________________________________________________________________________
From: "Albert Gardner" <albert.gardner(at)worldnet.att.net>
Subject: Re: parking brake valve where?
Date: Sep 10, 2001
----- Original Message ----- From: "C J Heitman" <cjh(at)execpc.com> Subject: RE: RV-List: parking brake valve where? > http://www.execpc.com/~cjh/brake_valve.html Chris-great pictures of your parking brake setup. A question though, why do we need the large brake hoses that go from the left side master cylinders to the firewall parking brake valve? Vans uses large hoses here but with bulkhead connectors instead of the parking brake assy. But between the left side and right side master cylinders in a dual brake setup they use 44NSR nylon tube with brass fittings. So why don't we use 44NSR instead of the larger brake lines? Albert Gardner Yuma, AZ RV-9A: N872RV (Reserved) Working on fuse ________________________________________________________________________________
Subject: Re: Empennage Jig Question
Date: Sep 10, 2001
Greetings from El Paso. I am presently building a 9a and my partner in crime is building the new 7A. I had the large jig in our shop for mine and we built the empenage on the jig as well. It makes life a great deal simpler to be able to open the skin and rivet units together. We were able to align everything in jig and it really made sence to us to use the jig. It makes life simpler Marcel finishing up wings almost ready for fuselage ----- Original Message ----- From: "Dwight Frye" <dwight(at)openweave.org> Sent: Monday, September 10, 2001 2:30 PM Subject: RV-List: Empennage Jig Question > > I'm getting some conflicting opinions, so I thought I would ask > what other folks are doing about using a jig for the RV-7 empennage. > (I'll likely get some more conflicting opinions, I know, but I > hope more input will help _me_ come to _my_ decision on the issue.) > > I have heard people say (and some of Van's literature) that with > the pre-punched parts on the RV-7 you don't really need to build the > big H-frame jig. I have gotten the impression that some feel it is > fine to just build on a bench top. > > Did you build the jig? Did you skip it? Enquiring minds wanna know. > Can anyone give me the pros/cons of using/not-using the jig? How > about building a jig that is _not_ attached to the ceiling, but > is on casters (as I have seen at least one person doing on their > web site) so that it can be rolled out of the way? > > I don't _mind_ building it (and attaching it to the ceiling) if > that is the right thing to do. However, if I can delay consuming > that space in the garage (or make the pain less by having it be > movable) it would be great to be able to do so! > > Thanks, in advance, for any info you can give me. :) > > -- Dwight > Empennage kit arriving on Wednesday .... > > ________________________________________________________________________________
Subject: re OPT-1 Question/Problem (?)
Date: Sep 10, 2001
FYI, Listers, Electronics International replied to my e-mail query very promptly, and after an e-mail exchange we discussed the problem (?) on the phone and they wanted the instrument back for check-out/recalibration or whatever. Can't complain about their response. It was what you would want. More when things settle out. John at Salida, CO ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Tires
Anyone have any thoughts on replacement tires? I am considering the McCreary Superhawk, the Goodyear Flight Custom II and the Michelin AIR. ________________________________________________________________________________
Date: Sep 10, 2001
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Re: Weight & Balance NOW WHAT???
In Canada we MUST use the weight published by the designer. Bob McC Greg Young wrote: > > This is allowed in the U.S. but Doug is in Canada. ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Re: Tires
--- b green wrote: > > Anyone have any thoughts on replacement tires? I am considering the > McCreary Superhawk, the Goodyear Flight Custom II and the Michelin > AIR. I am getting almost 400 hours on the Goodyears. They are rotated when 1/2 worn out. I paid about $72 each but they have been cheaper per landing than the Condors. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 942+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com ________________________________________________________________________________
Subject: New Slick Ignition Harness for Sale
Date: Sep 10, 2001
I have a new Unison (Slick) Ignition Harness for sale, part # M4006. It will fit all Lycoming 4 cylinders with Slick 4300 Series Mags and 5/8-24 spark plug threads. This harness is longer than most. It can be shortened or used as is by bundling the wires at the mags(this is how my old one was installed). From what I understand...the older engines sometimes ran the wires up along the intake tubes. By the way...I won this on a poker run in New England. I want $85.00 for it and I will pay the shipping. Contact me off list please. Jim Cimino RV-8 sn 80039 N7TL Reserved http://www.geocities.com/jcimino.geo/ (570)842-4057 ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Re: engines available?
Scott I have a nice assortment of rubber bands I'd be happy to sell him!! :-) Here is the beginning of your photos. I did a full and close up of each. The resolution leaves something to be desired in the closeups. How about sending me an email with an explaination of how you built your oil filler door. I'll post that and the photos on our web site. Charlie ABAYMAN(at)aol.com wrote: > > Dear Listers, > I have a friend looking for an engine for his rv6a, anyone with knowlege of > an engine please contact me off list, he said he will entertain anything that > will fit.i already forwarded the one Todd in Kansas had listed, but seem to > remember Eustice advertising a couple weeks ago. > scott ________________________________________________________________________________
Date: Sep 10, 2001
I purchased an overhauled Woodward from Pro-Prop Governor and Accessories Hallstead, Pa. 877 888 9072 Give Mike a call - great guy and an EAA'er Marty RV-6A >Any recommendations for a good & reasonable Woodward prop governor overhaul >shop, perferably East of the Miss? > >Thanks, > >Chuck & Dave Rowbotham >RV-8A (Flying) >Niantic, CT (Westerly airport) > > ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Re: streamlined oil cooler door
Listers some of you were waiting on my pictures of my oil door, go to the link below and see them. at the bottom of this is the steps i took to achieve the results. http://members5.clubphoto.com/scott351659/504362/owner-b6b0.phtml enjoy scott tampa Stream lined oil cooler door by Scott Reviere 1. cut away the recess in the coweling as you would normally do. 2. find the best contour of the oil door and place it under the hole you now have in the coweling 3. trace the area of the oil door and leave it slightly longer. 4. cut the traced area out of the door, and measure carefully and cut at an angle ( slant ) through the center, so you have 2 pieces that bevel where they mate in the middle. 5. use the hinges that came with the kit and remove 2 eyes in the center of 2 pieces for each door. ( you have 2 doors now that you cut the main oil door in half) 6. insert a mouse trap spring in the missing eyelets and insert the pin. do this on both hinges so you have a mouse trap spring on each door. rivit the hinges to the cowel. 7. to keep the door from popping up through the cowel, rivit strips of the oil door you removed earlier when you trimed the door to fit. you have to make a spacer under each of the strips, so the doors will end up flush with the outside of the coweling. 8. put a very thin coat of epoxy mixed with microballoons and sand as necessary to acheive a perfect contour, gap around the doors, and center seam. 9. make sure you don't get epoxy in the springs or hinges. 10. sand the strips inside to make a nice looking surrounding of the door. 11. with the center seam at a slanted cut, the top door closes first, and the bottom door closes last every time so the seam will hardly be noticable. note. when this is done, you can adjust the tension of the mouse springs as necessary by bending the ends and curling them down toward the cowel. you can make the doors as tight or as loose as you want. by luck, mine turned out like this. you press the doors inward a little and they snap back. you press them in all the way and they lock open ( the spring binds ) you press them again and the snap back. it didn't take long to do this, and is lighter, more streamlined, and is easier to open and close, no moving parts or hardware latches. also being able to have it stay open after flights to relieve built up heat in the engine compartment is a extra benifit. well that's my contribution to the list for the week. hope you enjoy it scott reviere tampa, fla rv6a N747ES reserved O360 c/s ________________________________________________________________________________
Subject: parking brake valve where?
Date: Sep 10, 2001
Albert, I don't have right side brakes so this doesn't really apply to my setup but I suspect that Van's wants a hose with a higher pressure rating on the pilot's side. If a right seat pilot stomps on the brakes and bursts the plastic line between the copilot and pilot master cylinders, the left seat pilot will still be able to apply brakes. The lightweight Teflon racing hoses that I used are rated for a minimum burst pressure of 12,000 psi!!! (3,000 psi operating pressure.) I don't know what the 44NSR is rated for but I suspect it is a factor of 10 less. Chris Heitman Dousman WI RV-9A N94ME (reserved) http://www.execpc.com/~cjh/brake_valve.html ----Original Message----- Chris-great pictures of your parking brake setup. A question though, why do we need the large brake hoses that go from the left side master cylinders to the firewall parking brake valve? Vans uses large hoses here but with bulkhead connectors instead of the parking brake assy. But between the left side and right side master cylinders in a dual brake setup they use 44NSR nylon tube with brass fittings. So why don't we use 44NSR instead of the larger brake lines? Albert Gardner ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Ride to RV Forumn
I have time scheduled with Mike Segar on Sunday mid morning and I'm looking for a ride from CT or Mass to Oswego. I can't leave early enough in my Kitfox to get there in time. Anyone going up for the day Sunday that wants a cost sharing passenger contact me by e-mail or phone. I can meet someone within 100 miles of Central Connecticut. Larry Gagnon 860-667-9999 days RV6 Finishing Kit N6LG (reserved) ________________________________________________________________________________
Subject: how to "recharge" dehydrator plugs
Date: Sep 10, 2001
One of the MS27215-2 dehydrator plugs in my Aero Sport Power engine is no longer a deep blue color. Is there a procedure for "recharging" it? Chris Heitman RV-9A ________________________________________________________________________________
Date: Sep 10, 2001
Well I spent a weekend building the jig and used it to build my empennage, however, my bench top would have done just fine. The -7 does not require the alignment that not having the pre-punched holes would require. It is hard to screw up with the holes punched for you. You will need something to hold the wing frames while you are working on them, but almost anything will do. Opinions vary of course, so to each his own. Just like some folks take the time to create bueatiful websites about their project while others don't. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Marcel Bourgon Sent: Monday, September 10, 2001 6:53 PM Subject: Re: RV-List: Empennage Jig Question Greetings from El Paso. I am presently building a 9a and my partner in crime is building the new 7A. I had the large jig in our shop for mine and we built the empenage on the jig as well. It makes life a great deal simpler to be able to open the skin and rivet units together. We were able to align everything in jig and it really made sence to us to use the jig. It makes life simpler Marcel finishing up wings almost ready for fuselage ----- Original Message ----- From: "Dwight Frye" <dwight(at)openweave.org> Sent: Monday, September 10, 2001 2:30 PM Subject: RV-List: Empennage Jig Question > > I'm getting some conflicting opinions, so I thought I would ask > what other folks are doing about using a jig for the RV-7 empennage. > (I'll likely get some more conflicting opinions, I know, but I > hope more input will help _me_ come to _my_ decision on the issue.) > > I have heard people say (and some of Van's literature) that with > the pre-punched parts on the RV-7 you don't really need to build the > big H-frame jig. I have gotten the impression that some feel it is > fine to just build on a bench top. > > Did you build the jig? Did you skip it? Enquiring minds wanna know. > Can anyone give me the pros/cons of using/not-using the jig? How > about building a jig that is _not_ attached to the ceiling, but > is on casters (as I have seen at least one person doing on their > web site) so that it can be rolled out of the way? > > I don't _mind_ building it (and attaching it to the ceiling) if > that is the right thing to do. However, if I can delay consuming > that space in the garage (or make the pain less by having it be > movable) it would be great to be able to do so! > > Thanks, in advance, for any info you can give me. :) > > -- Dwight > Empennage kit arriving on Wednesday .... > > ________________________________________________________________________________
Date: Sep 11, 2001
Date: Sep 11, 2001
I'm getting into this late but for what it's worth I had a problem fitting the pilot side hoses into Van's parking brake valve because the inlet hole spacing on the valve would not permit the use of 90 degree AN fittings. I called Van's and they suggested that I use the 44NSR hose with brass fittings as are used on the passenger side brakes. They told me that the 44 NSR brake lines were standard on the -4s for years with no problems. Just my $0.02! Harry Crosby Pleasanton, California RV-6, finish kit stuff ________________________________________________________________________________
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
Subject: Re: how to "recharge" dehydrator plugs
Date: Sep 10, 2001
Chris - I read somewhere that you can place the plugs in an oven for a bit to dry them out by heating them. When the color returns indicating they are dry, then they can be returned to service. Doug Murray Southern Alberta > > One of the MS27215-2 dehydrator plugs in my Aero Sport Power engine is no > longer a deep blue color. Is there a procedure for "recharging" it? > > Chris Heitman > RV-9A ________________________________________________________________________________
Subject: Slop in control stick
Date: Sep 10, 2001
Has anyone noticed their control stick getting more slop in it (for elevator control) after flying? I haven't pulled the seat pans yet, so I haven't seen if there is a problem. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ________________________________________________________________________________
Date: Sep 11, 2001
Yep, bake them in the oven. BUT, first unscrew the top and pour the crystals into a baking sheet. DO NOT HEAT THE ENTIRE UNIT. Bruce Glasair III -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Douglas G. Murray Sent: Tuesday, September 11, 2001 12:54 AM Subject: Re: RV-List: how to "recharge" dehydrator plugs Chris - I read somewhere that you can place the plugs in an oven for a bit to dry them out by heating them. When the color returns indicating they are dry, then they can be returned to service. Doug Murray Southern Alberta > > One of the MS27215-2 dehydrator plugs in my Aero Sport Power engine is no > longer a deep blue color. Is there a procedure for "recharging" it? > > Chris Heitman > RV-9A ________________________________________________________________________________
Date: Sep 10, 2001
Subject: Re: Slop in control stick
Paul, the slop you refer to showed up on Casper after about 15 Hrs. It concerned me, so I pulled all covers etc off to inspect every piece of the elevator system. What I found is each of the four ball joints has loosened a little, which cumulatively adds up to that slightly noticeable slop you refer to. Casper now has over 40 Hrs and the slop has not changed. Also, if you check, you will feel it also has almost the same thing going on with the aileron system. I checked a friends RV6 and it has exactly the same amount of slop as mine. He has around 500 hrs on it, and until I mentioned it he hadn't even noticed it. Garry "Caspers Dad" Paul Besing wrote: > > Has anyone noticed their control stick getting more slop in it (for elevator > control) after flying? I haven't pulled the seat pans yet, so I haven't > seen if there is a problem. > > Paul Besing > RV-6A N197AB Arizona > http://www.lacodeworks.com/besing > Flying > Kitlog Pro Builder's Log Software > http://www.kitlog.com > ________________________________________________________________________________
Subject: Re: Tires
Date: Sep 11, 2001
> > Anyone have any thoughts on replacement tires? I am considering the > > McCreary Superhawk, the Goodyear Flight Custom II and the >> Michelin AIR. > > I am getting almost 400 hours on the Goodyears. They are rotated when > 1/2 worn out. > > I paid about $72 each but they have been cheaper per landing than the > Condors. I bought a set of Air Hawks for mine since it looked like comparable size Goodyears and Michelins would not fit under my wheel pants without rubbing something. I have the older single piece main paints. After about 60 tach hours and lots of landings, they seem to be wearing much better than the original tires. I don't think that my landings are any better, either. If you have the older pants, you might want to try those. The price I paid for two of those was about the same, or less, than the one Goodyear; but, price doesn't mean much unless one can get the landings or can get them to fit inside the pant. BTW, my flights are normally less than an hour per flight. In the 400 hours, were those short flights or long cross countries? Are you flying off grass or hard surface? Those two things could make tires last much longer than average. I fly off hard surface, land too fast, and will be happy with 100 hours on a tire. Two hundred hours would be wonderful and is about the norm for a set of Goodyears for me. That's all I had on my Cheetah, when I owned it. At the current wear rate, I may just make that with my cheap tires. If you have the big pants, it's a moot point because you can use the bigger and better tires. I can't. Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Date: Sep 11, 2001
> I'm getting into this late but for what it's worth I had a problem > fitting > the pilot side hoses into Van's parking brake valve because the inlet > hole > spacing on the valve would not permit the use of 90 degree AN > fittings. I beat this problem by placing a small nipple in the valve: http://groups.yahoo.com/group/RV-6and6A/files/%20Tips%2C%20Tricks%20%26%20Suggestions/RV-6%20Parking%20Brake/Parking%20Brake2.JPG This pushed the elbow out to where I could rotate it to tighten. Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Date: Sep 11, 2001
Subject: Tailwheel endorsement
Message text written by Tom Ervin > Since I had a Bi-Annual coming due I decided to try and get my Tail Dragger endorsement to gain even more confidence for 1st flight. Boy did I pick the right aircraft! < I keep hearing about this Tail Dragger endorsement. Could someone please point to the FAR that requires this endorsement. I have never owned a tail dragger but have flown several over the years. Have I been doing something illegal? Leads me to ask, in olden days when every airplane was a tail dragger did pilots need a nosewheel endorsement before taking off in those new fangled contraptions with the tailwheel on the wrong end? Ron Schreck RV-8 QB ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: Re: Tire Wear
Date: Sep 11, 2001
I have 235 hard-surface, hot landings in 101 hours. I use up almost 1500 feet of runway before turning off, no breaking required. I land in much shorter distances with moderate braking effort. Most of my the landings are solo. I have heavy wear on the outside edge of the tire, and virtually no wear anywhere else. I'll soon flip the tires over to wear out the other edge. My landing gear geometry is per Van's specs and I carefully set camber and toe-in before driling the mounts. I am dissapointed in the rapid edge wear. Dennis Persyk N600DP 101 hours O360A1A Hartzell C38/68IS ----- Original Message ----- From: "Jim Sears" <sears(at)searnet.com> Sent: Tuesday, September 11, 2001 4:46 AM Subject: Re: RV-List: Tires > > > > Anyone have any thoughts on replacement tires? I am considering the > > > McCreary Superhawk, the Goodyear Flight Custom II and the > >> Michelin AIR. > > > > I am getting almost 400 hours on the Goodyears. They are rotated when > > 1/2 worn out. > > > > I paid about $72 each but they have been cheaper per landing than the > > Condors. > > I bought a set of Air Hawks for mine since it looked like comparable size > Goodyears and Michelins would not fit under my wheel pants without rubbing > something. I have the older single piece main paints. After about 60 tach > hours and lots of landings, they seem to be wearing much better than the > original tires. I don't think that my landings are any better, either. > If you have the older pants, you might want to try those. The price I paid > for two of those was about the same, or less, than the one Goodyear; but, > price doesn't mean much unless one can get the landings or can get them to > fit inside the pant. > > BTW, my flights are normally less than an hour per flight. In the 400 > hours, were those short flights or long cross countries? Are you flying > off grass or hard surface? Those two things could make tires last much > longer than average. I fly off hard surface, land too fast, and will be > happy with 100 hours on a tire. Two hundred hours would be wonderful and is > about the norm for a set of Goodyears for me. That's all I had on my > Cheetah, when I owned it. At the current wear rate, I may just make that > with my cheap tires. If you have the big pants, it's a moot point because > you can use the bigger and better tires. I can't. > > Jim Sears in KY > RV-6A N198JS > > ________________________________________________________________________________
Subject: GBA
Date: Sep 11, 2001
11:34:10 AM God Bless America ________________________________________________________________________________
Date: Sep 11, 2001
In a message dated 09/11/2001 11:15:57 AM Eastern Daylight Time, dpersyk(at)worldnet.att.net writes: > I have heavy wear on the outside edge of the tire, and virtually no > wear anywhere else. I'll soon flip the tires over to wear out the other > edge. > > My landing gear geometry is per Van's specs and I carefully set camber and > toe-in before driling the mounts. I am dissapointed in the rapid edge wear. > Me, too, but I'm only wearing out the left tire on the 6A. Wonder what gives? Maybe I land in a crab with the nose yawed right and don't perceive it. I plan to replace tires when I redo the wheel pants to upgrade to pressure-recoverey type. Looks like I won't be making any landings for now, since they require takeoffs, and they are now banned. The things fallen men are capable of... -Bill B ________________________________________________________________________________
Subject: Re: Tailwheel endorsement
Date: Sep 11, 2001
If you can show that you flew a tail dragger before a certain date which I think is in 1993 then you are grandfathered. Nothing wrong with getting the endorsement however. Recent experience is better than have last flown a taildragger that many years ago. I would highly recommend that you get some transition training in what ever model of RV you intend to fly. Mike Seagar used to be the only one but there are over 10 people now doing RV transitions, I believe. Call EAA at 1-888-322-4636, extension 6864 for complete information. It is to your benefit to contact an EAA Flight Advisor. He can help you. There is also a "First Flight Workshop" scheduled October 13th at Columbus Ohio. Again call EAA at the above number. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ------ Original Message ----- From: "Ron Schreck" <RonSchreck(at)compuserve.com> Sent: Tuesday, September 11, 2001 8:24 AM Subject: RV-List: Tailwheel endorsement Message text written by Tom Ervin > Since I had a Bi-Annual coming due I decided to try and get my Tail Dragger endorsement to gain even more confidence for 1st flight. Boy did I pick the right aircraft! < I keep hearing about this Tail Dragger endorsement. Could someone please point to the FAR that requires this endorsement. I have never owned a tail dragger but have flown several over the years. Have I been doing something illegal? Leads me to ask, in olden days when every airplane was a tail dragger did pilots need a nosewheel endorsement before taking off in those new fangled contraptions with the tailwheel on the wrong end? Ron Schreck RV-8 QB ________________________________________________________________________________
Date: Sep 11, 2001
From: Brian Armstrong <armstrbc(at)ucsub.colorado.edu>
The reg is FAR 61.31 subpart (i). The grandfather date is tax day 1991. Brian Armstrong RV-less Enthusiast -- On Tue, 11 Sep 2001, Ron Schreck wrote: > > Message text written by Tom Ervin > > Since I had a Bi-Annual coming due I decided to try and get my > Tail Dragger endorsement to gain even more confidence for 1st flight. > Boy did I pick the right aircraft! < > > I keep hearing about this Tail Dragger endorsement. Could someone please > point to the FAR that requires this endorsement. I have never owned a tail > dragger but have flown several over the years. Have I been doing something > illegal? Leads me to ask, in olden days when every airplane was a tail > dragger did pilots need a nosewheel endorsement before taking off in those > new fangled contraptions with the tailwheel on the wrong end? > > Ron Schreck > RV-8 QB > > ________________________________________________________________________________
From: "Murphy, Richard James (Rick)" <rjmurphy1(at)lucent.com>
Subject: GBA
Date: Sep 11, 2001
Eric, On this day in particular, we should ask God to bless all Americans, and pity the fxckers that have brought these cowardly acts to our cities. Rick Murphy > ---------- > From: Eric.J.Henson(at)chase.com[SMTP:Eric.J.Henson(at)chase.com] > Reply To: rv-list(at)matronics.com > Sent: Tuesday, September 11, 2001 11:35 AM > To: rv-list(at)matronics.com > Subject: RV-List: GBA > > > > God Bless America > > > > > > ________________________________________________________________________________
Subject: Re: GBA
Date: Sep 11, 2001
To all the American listers, I've been watching the horrific pictures on CNN, live, and wish to express my condolances to those who have lost their loved ones in this cowardly attacks on a democratic nation. I wish all of you strenght to cope with this unrivalled tragedy. Marcel de Ruiter Northern Ireland ________________________________________________________________________________
Subject: FW: 2 cents worth hand held GPS
Date: Sep 11, 2001
The Anywhere ipac combo makes handheld GPS obsolete. $1200 for package and it exceeds any GPS as a nav device plus road maps, personal computing etc. Windows CE software. I am not arguing just an opinion. ( www.anywheremap.com) ________________________________________________________________________________
Subject: Re: FW: 2 cents worth hand held GPS
Date: Sep 11, 2001
obsolete? not likely. Not until they have an internal gps receiver. not exactly convenient to have such an external antenna/receivers. >From: jrdial <jrdial@hal-pc.org> >Reply-To: rv-list(at)matronics.com >To: "'RV - List'" >Subject: RV-List: FW: 2 cents worth hand held GPS >Date: Tue, 11 Sep 2001 13:17:21 -0500 > > >The Anywhere ipac combo makes handheld GPS obsolete. $1200 for package and >it exceeds any GPS as a nav device plus road maps, personal computing etc. >Windows CE software. I am not arguing just an opinion. ( >www.anywheremap.com) > > ________________________________________________________________________________
Subject: GBA
Date: Sep 11, 2001
God Bless everyone who believes in freedom and the sanctity of life. I'm finding the nearest Red Cross donation center. Suggest we all do the same. John -----Original Message----- From: Eric.J.Henson(at)chase.com Sent: 9/11/01 11:35 AM Subject: RV-List: GBA God Bless America ________________________________________________________________________________
Date: Sep 11, 2001
Chris, When I was in the Navy, we had large cylinders of the silica gel crystals in the fire control radar waveguides to keep them from arcing. When they turned pink we just placed them in a small oven and heated them on low until they changed back to blue. Cheap & simple. Here, I would just sit them outside in the sun! Bill Christie, Phoenix, RV8A ----- Original Message ----- From: "C J Heitman" <cjh(at)execpc.com> Sent: Monday, September 10, 2001 8:53 PM Subject: RV-List: how to "recharge" dehydrator plugs > > One of the MS27215-2 dehydrator plugs in my Aero Sport Power engine is no > longer a deep blue color. Is there a procedure for "recharging" it? > > Chris Heitman > RV-9A > > ________________________________________________________________________________
Subject: GBA
Date: Sep 11, 2001
Thank You. ----- Original Message ----- From: RV4 <VansRV4GRVMJ(at)btinternet.com> Sent: Tuesday, September 11, 2001 12:58 PM Subject: Re: RV-List: GBA > > To all the American listers, > > > I've been watching the horrific pictures on CNN, live, and wish to express > my condolances to those who have lost their loved ones in this cowardly > attacks on a democratic nation. > > I wish all of you strenght to cope with this unrivalled tragedy. > > > Marcel de Ruiter > Northern Ireland > > ________________________________________________________________________________
Date: Sep 11, 2001
Subject: Rivet Spec. Question - slants and smilies
I need a little beginner advice about rivets: 1)How much slant in the shop head is acceptable before it must be drilled out? 2)Do smilies on the head of AN470 rivets cause anything other than cosmetic damage? John Rott (drjohn108(at)yahoo.com) RV7A HS ________________________________________________________________________________
Date: Sep 11, 2001
Subject: Re: Rivet Spec. Question - slants and smilies
I need a little beginner advice about rivets: 1)How much slant in the shop head is acceptable before it must be drilled out? 2)Do smilies on the head of AN470 rivets cause anything other than cosmetic damage? John Rott (drjohn108(at)yahoo.com) RV7A HS John, Have a look at MIL-R-47196A "Rivets, Buck Type, Preparation for and Installation of". It is available at: http://www.flash.net/~gila/ Kevin Horton RV-8 (engine installation) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://eccentrix.com/misc/rv8/ ________________________________________________________________________________
Subject: Terrorist Attacks
Date: Sep 11, 2001
To all my American friends and all Americans alike: When I turned our TV on this morning my wife and I stared in disbelief, we were unable to talk and sat in a state of shock. I had planned to fly my RV today, a beautiful CAVU day but after watching CNN for half an hour it was impossible to keep back the tears and had to shut it off. All thoughts of flying to-day are gone, I am going down to the shop this afternoon and try to do something on the 6A and try to get my thoughts organized. From this Canadian and I am sure all Canadians our thoughts are with you today. Eustace Bowhay - Blind Bay, B.C. ________________________________________________________________________________
From: "Doug Weiler" <doug.weiler(at)pressenter.com>
Subject: Re: Terrorist Attacks
Date: Sep 11, 2001
> > To all my American friends and all Americans alike: > > When I turned our TV on this morning my wife and I stared in disbelief, > we were unable to talk and sat in a state of shock. > > I had planned to fly my RV today, a beautiful CAVU day but after > watching CNN for half an hour it was impossible to keep back the tears > and had to shut it off. All thoughts of flying to-day are gone, I am > going down to the shop this afternoon and try to do something on the 6A > and try to get my thoughts organized. > > >From this Canadian and I am sure all Canadians our thoughts are with you > today. > Eustace: On behalf of our local RV pilots, builders, and Americans I truly thank you for your comments to the List. I too am in a state of shock. Me and a good friend were en route on a breakfast flight in my RV-4 this morning. When we landed we found out about this horrible act and stared at the TV screens in the airport restaurant in disbelief. It was a beautiful clean and calm day here in western Wisconsin. Our delightful morning flight was destroyed. Our appetites had disappeared. We decided just to fly home and think. The FAA had officially shut down all flights but we sneaked home anyway, put the RV away and tried to comprehend the events this morning. Thanks Eustace. You can't imagine how much we appreciate such thought. Doug Weiler pres, MN Wing Hudson, WI ________________________________________________________________________________
Date: Sep 11, 2001
Eustace, From a fellow RVator, Your American cousins appreciate your support and kind words. We appreciate our northern neighbors coming to our aid and landing all of our inbound traffic today at your airports. I'm certain that you join with us in denouncing terrorism in all its forms and wishing a certain, prolonged and painful fate to all those that would attempt to destroy democracy. Rick > ---------- > From: Eustace Bowhay[SMTP:ebowhay(at)jetstream.net] > Reply To: rv-list(at)matronics.com > Sent: Tuesday, September 11, 2001 4:07 PM > To: rv list > Subject: RV-List: Terrorist Attacks > > > To all my American friends and all Americans alike: > > When I turned our TV on this morning my wife and I stared in disbelief, > we were unable to talk and sat in a state of shock. > > I had planned to fly my RV today, a beautiful CAVU day but after > watching CNN for half an hour it was impossible to keep back the tears > and had to shut it off. All thoughts of flying to-day are gone, I am > going down to the shop this afternoon and try to do something on the 6A > and try to get my thoughts organized. > > From this Canadian and I am sure all Canadians our thoughts are with you > today. > > Eustace Bowhay - Blind Bay, B.C. > > > > > > ________________________________________________________________________________
Date: Sep 11, 2001
Subject: When is the Lebannon TN Flyin?
Anybody know when the Lebannon Tn fly in is? I thing is should be coming up very soon. Dan ________________________________________________________________________________
Subject: Re: When is the Lebannon TN Flyin?
Date: Sep 11, 2001
One week from this Sat. Sept 22. Marty in Brentwood TN. ----- Original Message ----- From: "Dan DeNeal" <rv6apilot(at)yahoo.com> Sent: Tuesday, September 11, 2001 4:05 PM Subject: RV-List: When is the Lebannon TN Flyin? > > > Anybody know when the Lebannon Tn fly in is? I thing > is should be coming up very soon. > > Dan > > > > > > ________________________________________________________________________________
Date: Sep 11, 2001
Eustace, I for one American want to thank you from the bottom of my heart for your warm support. I recently retired as pilot for Delta Airlines and remember well all the training we had for such an occurrence on board. Evidently these cowards were well informed and well prepared to fly these airplanes after removing or killing the pilots and taking command. I know in my heart that not one of the American pilots would have ever deliberately flown a plane in the those towers or the pentagon even with a gun at their head. I too am very sad today at the fact that this has happened and "But for the grace of God go I." Now it payback time, and I only hope we have the courage to do it right. I know that even though I'm 65 I would gladly fly an F-4 as I did in guard into wherever to settle the score. Thank You. Don Champagne ________________________________________________________________________________
Date: Sep 11, 2001
Subject: RE: Empenage Jig Question
Dwight- Just another opinion... I am working on an -8, finishing up the tail in a small shop and found that building in the jig gave me more control of all the pieces. The skins in the -8 are pre-drilled and the spars and ribs were not. I didn't build the jig at the outset, but found that the concepts behind Sam Buchanon's jig helpful - - http://home.hiwaay.net/~sbuc/journal/rv6.html. (You have the ability to level the rear spar with adjustments and the ability to change the height of the threads.) Since its the first main sub- I figured it couldn't going wrong by following the book... Ultimately I ended up building the jig. Not as pretty as Sam's -but its getting the job done. If you want some pix- I can send them. -Dag ==== ***************** Dag Adamson 617 513 1182 Natick, MA ***************** ________________________________________________________________________________
Date: Sep 11, 2001
Subject: From Canada...
Folks, Like any civilized human being, I too was shocked and amazed at the events in New York, Somerset and Washington DC today. What began with thoughts of "who was the moron who flew his small twin under VMC into such a huge building" soon progressed to "oh my God" and other thoughts than cannot be repeated on a G-rated list. My sympathies go out to my personal American friends and to all the people of your nation. Find the b******s who did this and give them what they deserve. My government will get together with your government to offer whatever help our country can give. If there is anything us ordinary Canadians can do, please do not hesitate to ask. Brian Schalme Winnipeg, Canada RV-8 Dreaming & Goal-Setting. ________________________________________________________________________________
Date: Sep 11, 2001
All, Even if it's pre-punched I would still use a jig. The rivets are not tight in the holes until they are set and it's still possible to get a fair amount of twist. The wing and tail jig is so simple to build why not use one? It's the only way to ensure that you won't have twist. Also, it's not necessary or, IMO, even desirable to use a steel jig. Build it out of wood per the plans and it's cheap and easy insurance. Dave -6 flying So Cal Gary Coonan wrote: > > Well I spent a weekend building the jig and used it to build my > empennage, however, my bench top would have done just fine. The -7 does > not require the alignment that not having the pre-punched holes would > require. It is hard to screw up with the holes punched for you. You > will need something to hold the wing frames while you are working on > them, but almost anything will do. Opinions vary of course, so to each > his own. Just like some folks take the time to create bueatiful > websites about their project while others don't. > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Marcel Bourgon > Sent: Monday, September 10, 2001 6:53 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Empennage Jig Question > > > Greetings from El Paso. > I am presently building a 9a and my partner in crime is building the new > 7A. > I had the large jig in our shop for mine and we built the empenage on > the > jig as well. It makes life a great deal simpler to be able to open the > skin > and rivet units together. We were able to align everything in jig and > it > really made sence to us to use the jig. It makes life simpler > Marcel finishing up wings almost ready for fuselage > ----- Original Message ----- > From: "Dwight Frye" <dwight(at)openweave.org> > To: > Sent: Monday, September 10, 2001 2:30 PM > Subject: RV-List: Empennage Jig Question > > > > > I'm getting some conflicting opinions, so I thought I would ask > > what other folks are doing about using a jig for the RV-7 empennage. > > (I'll likely get some more conflicting opinions, I know, but I > > hope more input will help _me_ come to _my_ decision on the issue.) > > > > I have heard people say (and some of Van's literature) that with > > the pre-punched parts on the RV-7 you don't really need to build the > > big H-frame jig. I have gotten the impression that some feel it is > > fine to just build on a bench top. > > > > Did you build the jig? Did you skip it? Enquiring minds wanna know. > > Can anyone give me the pros/cons of using/not-using the jig? How > > about building a jig that is _not_ attached to the ceiling, but > > is on casters (as I have seen at least one person doing on their > > web site) so that it can be rolled out of the way? > > > > I don't _mind_ building it (and attaching it to the ceiling) if > > that is the right thing to do. However, if I can delay consuming > > that space in the garage (or make the pain less by having it be > > movable) it would be great to be able to do so! > > > > Thanks, in advance, for any info you can give me. :) > > > > -- Dwight > > Empennage kit arriving on Wednesday .... > > > > > ________________________________________________________________________________
Date: Sep 12, 2001
Subject: Shock.
I simply have no words, but our thoughts are with you. Les Rowles. Traralgon Australia. ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Date: Sep 11, 2001
I agree Don, I believe the only airline pilot who remained in control of his aircraft may very well have been the one that crashed in Pennsylvania. Better to put it into the ground than let some terrorist cause even more death and misery. At least, that's what I would like to think. It is a pity that the only time one may be allowed to use God's name is in times of disaster but... May God help us. God cannot help those who did this. I hope our president has the will to do what must be done. -----Original Message----- From: AV8TURDON(at)aol.com [mailto:AV8TURDON(at)aol.com] Sent: Tuesday, September 11, 2001 2:09 PM Subject: Re: RV-List: Terrorist Attacks Eustace, I for one American want to thank you from the bottom of my heart for your warm support. I recently retired as pilot for Delta Airlines and remember well all the training we had for such an occurrence on board. Evidently these cowards were well informed and well prepared to fly these airplanes after removing or killing the pilots and taking command. I know in my heart that not one of the American pilots would have ever deliberately flown a plane in the those towers or the pentagon even with a gun at their head. I too am very sad today at the fact that this has happened and "But for the grace of God go I." Now it payback time, and I only hope we have the courage to do it right. I know that even though I'm 65 I would gladly fly an F-4 as I did in guard into wherever to settle the score. Thank You. Don Champagne ________________________________________________________________________________
Subject: Tragedy in the US
Date: Sep 12, 2001
Hi All, I could not believe my eyes last night when my wife and I watched the tragedy unfold in New York and Washington at about midnight our time. I'm sure all Aussie sympathy's goes out our American friends today. Our Australian Prime Minister is presently in Washington and he had the following to say during a press conference *** "The only other thing I can say .. is to say to our American friends who we love and admire so much, we really feel for you," he said. "It is a terrible day. "Words aren't very adequate but they are a sign that we feel for our American friends. "We will stand by them, we will help them, we will support actions they take to properly retaliate in relation to these acts of bastardry against their citizens and what they stand for." *** The whole sad event came home to me this morning when I drove past the American Embassy here in Canberra, Australia and saw the closed roads and increased federal police presence. Be assured that Australia is looking after Americans living here in Australia and we will do our best to protect them from any follow up of terrorism here. John Morrissey Canberra Australia ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Date: Sep 11, 2001
Listers: >> Yep, bake them in the oven. BUT, first unscrew the top and pour the crystals into a baking sheet. DO NOT HEAT THE ENTIRE UNIT. << I cannot agree. I leave the dehydrator plugs in the engine until they become more pink than blue. Then I place them on a cookie tray at a middle level in the oven. I cook them at 250 F degrees. They suggest up to 16 hours - but I do it for about 3 hours. I definitely leave the oven light on, the stove hood light on and whatever else helps to remember that something is in the oven. Back into the engine. I think a longer cook may just means you get an extra day in the engine. Not worth your spouses grumbling!! By the way, I am into long storage. This is my (boring) procedure. I install dehydrators in the top holes and real plugs in the bottom holes. When the dehydrators turn pick, I remove all 8 plugs. I install in the bottom hole of each cylinder a flexible syphon hose leading to a pot (peanut butter jar attached below). I use the syphon hose in a winemakers bung to plug the bottom 4 holes. First I use a bent coat hanger to locate a piston at its lowest position. I then spray oil "with inhibitor" generously into the cylinders top hole. I spray inside all around the top of the cylinder with a flexible spray can. Then I rotate the crankshaft a few times, before moving to the next cylinder. When I have completed all four cylinders, I put fresh dehydrators in the top holes and regular plugs in the bottom - all inluding their gaskets. I hand tighten only. I store the 4 hoses with bungs and the 2 pots in a large coffee can under the engine stand until next time. Back to building for a couple of weeks. I keep a record attached to the engine. Seems grungy - but I plan to build one plane and install one engine for the rest of my life. Happy building. Ernest Kells RV-9A - Fuselage, O-235 Planning Wood Prop Sault Ste. Marie, Ontario ________________________________________________________________________________
Subject: Attacks
Date: Sep 12, 2001
While on night shift last night as a fire-fighter a general announcement went across all fire stations in Melbourne. We turned on the TV and of course we saw the horror. We understand that hundreds of fireman doing there job and countless others have died. You could not hear a pin drop as my fellow workers and I watched helplessly. It is impossible to put into words how we feel but our hearts go out to you all. What else can I say? Chris and Susie Melbourne Australia ________________________________________________________________________________
Date: Sep 11, 2001
Subject: terroist attacks
I live in Montclair, Nj. We are a 'bedroom' community for New York City. As I was getting ready to leave for our store, my son said that a plane had hit the World Trade Center. I said that's impossible! I had just finish a 6 mile bike ride, and there was not a cloud in the sky. I said someone in a small plane must have committed suicide. By the time I got to work, someone said a second plane had hit the other tower. I decided to drive up Eagle Rock Ave to the park at the top of the hill. It provides a fantastic view of NYC skyline. The police had it blocked off. So I meandered up the hill. Cars were parked on both sides of the road. People were standing and looking towards the city. Some had binoculars and others cell phones. Cell phones to their ears and tears in their eyes. It really hit me at that point. There was no place to stop so I drove over to Highland Ave and found a spot to stop. You've all seen the pictures by now. 2 huge buildings on fire. I went back to work, only to hear that one of them had come down. And then the 2nd. Our minister called and said that a person in our congregation, a chef, worked 4 floors below where the 1st plane hit, was presumed dead. He turned up alive and well several hours later. Another friend of ours was in a building across the street. After the 1st hit. They evacuated their building. As they did so, the 2nd plane hit. She saw bodies in the street and people jumping from great heights. 2 of our friends were spared. But then there are many..many..many friends and relatives of people that were not so lucky. God bless America, and my he give our leaders the wisdom to make the right choices. Barry Pote ________________________________________________________________________________
Subject: Some Interesting Data (Long)
Date: Sep 11, 2001
Thread-Topic: RV-List Digest: 60 Msgs - 09/08/01 Thread-Index: AcE5BfwGSBLPYYzBSxao0feNhIBQawA/3fdw
PHJhbnQ+DQpTb3JyeSwgZ3V5cywgYnV0IHdoZW4gYWNjZXNzaW5nIG15IHdvcmsgZW1haWwgZnJv bSBob21lIG9jY2FzaW9uYWxseSB0aGUNClNTTCBtZXNzYWdlIHNvbWVob3cgZG9lc24ndCBnZXQg ZGVjb2RlZCBhdCBvdXIgbWFpbCBzZXJ2ZXIuLi5zbyB3aXRoIGENCmhlYXZ5IGhlYXJ0IEknbSBy ZXNlbmRpbmcgdGhpcyBtZXNzYWdlLCBnaXZlbiB0aGUgaG9ycmlibGUgYWN0cyB0aGF0DQp3ZXJl IGNvbW1pdHRlZCB0b2RheS4gIEkndmUgYmVlbiBvZmYgd29yayB0aGlzIHdlZWsgYXMgbXkgZmF0 aGVyLWluLWxhdw0KcGFzc2VkIGF3YXkgb24gRnJpZGF5LCBhbmQgYmVpbmcgYSBwZXJmZWN0IGZs eWluZyBkYXkgSSBkZWNpZGVkIHRoYXQNCmJlZm9yZSB0aGUgZnVuZXJhbCBJJ2QgZmx5IHRvIHJl bGF4IG15IG5lcnZlcyBhbmQgZXNjYXBlIHRoZSB3b3JsZCBmb3IgYQ0Kd2hpbGUgYW5kIGRvIHNv bWUgcm9sbHMgYW5kIHNjcmV3IGFyb3VuZC4gIEkgZ290IHRvIHRoZSBhaXJwb3J0IGFyb3VuZA0K OTowMGFtLCBuZXZlciB0dXJuZWQgb24gdGhlIHR2IGF0IGhvbWUgYW5kIHdhcyBsaXN0ZW5pbmcg dG8gYSBjZCBvbiB0aGUNCndheSB0byB0aGUgYWlycG9ydCwgc28gSSBoYWQgbm8gaWRlYS4gIEkg a2VlcCBteSBwbGFuZSBvbiBhIGdyYXNzIHN0cmlwDQphbmQgdGhlcmUncyBhIHNtYWxsIGZsaWdo dCBzY2hvb2wgdGhlcmUsIGFuZCB3aGVuIEkgZ290IHRvIHRoZSBhaXJwb3J0DQp0aGUgZ3V5cyB0 aGVyZSB3ZXJlIGh1ZGRsZWQgYXJvdW5kIHRoZSB0diwgYW5kIEkgY291bGRuJ3QgYmVsaWV2ZSB3 aGF0IEkNCndhcyB3YXRjaGluZy4gIFNob3J0bHkgYWZ0ZXIgR3Jpc3NvbSBBRkIgcGVyc29ubmVs IGNhbGxlZCBhbmQgc2FpZCBubw0KZmxpZ2h0cyB3ZXJlIHRvIGJlIGNvbmR1Y3RlZC4gIEkgbGVm dCBhbmQgd2VudCB0byBkZWFsIHRoZSBkaWZmaWN1bHQNCmZhbWlseSBhZmZhaXJzIG9mIHRoZSBk YXkuICBJIHdpc2ggSSBjb3VsZCBmb3JnZXQgZXZlcnRoaW5nIHRoYXQNCmhhcHBlbmVkIHRvZGF5 LiAgSSBwbGF5ZWQgd2l0aCBteSAzIHllYXIgb2xkIHNvbiBmb3Igc2V2ZXJhbCBob3VycywgYnV0 DQpldmVyeSB0aW1lIEkgbG9va2VkIGluIGhpcyBleWVzIEkgZmVsdCBhIGZlZWxpbmcgb2Ygc2Fk bmVzcyBhYm91dCBob3cNCmYqKiplZC11cCB3b3JsZCBoZSdzIGdyb3dpbmcgdXAgaW4gaXMuICBJ dCdzIHNpY2tlbnMgbWUgaG93IG1hbnkgcGVvcGxlDQp0aGVyZSBhcmUgaW4gdGhlIHdvcmxkIHRo YXQgd2lsbCBraWxsIGluIHRoZSBuYW1lIG9mIHRoZWlyIHJlbGlnaW9uLiAgSXQNCnNpY2tlbnMg bWUgdGhhdCB0aGUgVVMgYWxsaWVzIGl0c2VsZiB3aXRoIGNvdW50cmllcyB0aGF0IG9wcHJlc3Ms IHdoaWNoDQppbiB0dXJuIGRpcmVjdHMgaGF0cmVkIGJhY2sgYXQgdXMuICBJbiBzb21lIHN0cmFu Z2Ugd2F5IEkgd2lzaCB3ZSdkDQpjYXJwZXQtYm9tYiB0aGUgZW50aXJlIG1pZGVhc3QgYW5kIHR1 cm4gaXQgaW50byBhIGdpYW50IHNwaWdvdCBvZiBhdmdhcw0KKGp1c3Qga2lkZGluZy4pIGJ1dCB0 aGUgcmVhbGl0eSBpcyB0aGF0IHRoZSBzaXR1YXRpb24gdGhlcmUgd2lsbCBuZXZlcg0KY2hhbmdl Li4uc28gbGV0cyBqdXN0IGJ1eSBiYXJyZWxzIG9mIGNydWRlIG9pbCBmcm9tIHRoZW0gdG8gdHVy biBpdCBpbnRvDQoxMDBMTCBhbmQgbGV0IHRoZWlyIGRpZmZlcmVuY2VzIGJlIHRoZWlyIGRpZmZl cmVuY2VzLCBub3Qgb3Vycy4gIGp1c3QgbXkNCm9waW5pb24sIHNvcnJ5IGlmIHRoaXMgaXNuJ3Qg dGhlIHJpZ2h0IHZlbnVlIHRvIGNvbnZleSBpdC4NCmRvIG5vdCBhcmNoaXZlDQo8L3JhbnQ+DQog DQpMYWlyZCwNCiANCkhhdmUgeW91IGRvbmUgdGhlIDMtd2F5IEdQUyBydW5zPyAgSSBkaWQgc29t ZSB0ZXN0aW5nIHRoZSBvdGhlciBkYXkgYW5kDQpjYW1lIHVwIHdpdGggMTY2IGtub3RzIGNydWlz ZSBhdCA4MDAwIGZlZXQgYnkgdGhlIEdQUyAoMjQwMCBSUE0sIDIyLjUiLA0KbGVhbmVkIHRvIHBl YWssIDkuMi05LjVHUEgpLCBvbiBhIHdhcm0gKDg1KykgZGVncmVlIGRheS4gIENyYW5raW5nIHRo ZQ0KcmV2cyB1cCB0byBnZXQgNzUlIG9ubHkgZ2l2ZXMgbWUgYSBrbm90IG9yIHR3by4gIEkgaGF2 ZSBkb25lIHRoZXNlIHJ1bnMNCnNldmVyYWwgdGltZXMgb3ZlciB0aGUgY291cnNlIG9mIHRoZSBw YXN0IHllYXIgYW5kIHR5cGljYWxseSBhbSB3aXRoaW4NCjItMyBrbm90cyBiZXR3ZWVuIHRlc3Rz LiAgU28sIG15IHJlYWwtd29ybGQgY3J1aXNlIGlzIDE2NSBrbm90cy4NCiANCldpdGggdGhhdCBi ZWluZyBzYWlkLi4uDQogDQpUaGlzIGlzIHNsaWdodGx5IGJlbG93IFZhbidzIHB1Ymxpc2hlZCBm aWd1cmVzLCBhbmQgSSBkb24ndCBoYXZlIGENCnBvb3JseSByaWdnZWQgb3IgYnVpbHQgYWlycGxh bmUuICBJTU8gSSB0aGluayBWYW4ncyBwdWJsaXNoZWQgbnVtYmVycw0KYXJlIHNsaWdodGx5IGhp Z2guICBNb3N0IG9mIG15IGxvY2FsIFJWIGJ1ZGRpZXMgYWdyZWUuICBGb3IgZXhhbXBsZSwgdGhl DQpSVi04IGhhcyBhIGZhc3RlciBwdWJsaXNoZWQgY3J1aXNlIHNwZWVkIHRoYW4gZG9lcyB0aGUg LTQuICBJIGRvbid0DQp1bmRlcnN0YW5kIGhvdyB0aGUgLTggY2FuIGJlIGZhc3RlciB3aXRoIGl0 cyBncmVhdGVyIGZyb250YWwgYXJlYSBhbmQNCmhpZ2hlciB3ZWlnaHQgdGhhbiBhIC00IHdpdGgg dGhlIHNhbWUgaG9yc2Vwb3dlci4gIEkgZmx5IHJlZ3VsYXJseSB3aXRoDQphIDE4MCBDL1MgLTgg dGhhdCBpcyBhIHZlcnkgd2VsbCBidWlsdCBRQiBhaXJmcmFtZSBhbmQgaGlzIGNydWlzZSBzcGVl ZA0KaXMgb25seSBzbGlnaHRseSBmYXN0ZXIgdGhhbiBtaW5lLi4uIGl0IHRha2VzIGFuIGV4dHJh IDEvMiIgb2YgbWFuaWZvbGQNCnByZXNzdXJlIGZvciBtZSB0byBrZWVwIHVwIHdpdGggaGltIHdp dGggdGhlIHNhbWUgcG93ZXIgc2V0dGluZ3MuIFRoZQ0Kb2RkIHRoaW5nIGlzIHdoZW4gd2UgYm90 aCBoYXZlIGEgcGFzc2VuZ2VyIHRoZW4gaXQgdGFrZXMgYSBsb3QgbW9yZQ0KKDEtMS41Iikgb2Yg dGhyb3R0bGUgZm9yIG1lIHRvIGtlZXAgdXAgd2l0aCBoaW07IHdlJ3JlIGdvaW5nIHRvIGV4cGxv cmUNCnRoYXQgZnVydGhlci4gIEEgZnJpZW5kJ3MgUlYtNCB3aWxsIGZsYXQtb3V0IHN0b21wIGJv dGggb2YgdXMgd2l0aCB0aGUNCnNhbWUgaGFyZHdhcmUgdXAgZnJvbnQuICBNYXliZSBJIG5lZWQg dG8gdHVybiB0aGF0IGxpdHRsZSBzZXQgc2NyZXcgb24NCnRoZSBnb3Zlcm5vciBvdXQgYSBmZXcg dHVybnMgOykgIEZXSVcNCiANCkJvYiBKYXB1bmR6YQ0KUlYtNiBOMjQ0QkogTy0zNjBDL1MgZmx5 aW5nIDIwOSBob3Vycw0KDQpUaW1lOiAwMzo1MjozNSBQTSBQU1QgVVMgDQpGcm9tOiAiT3dlbnMs IExhaXJkIiA8T3dlbnNAYWVyb3Zpcm9ubWVudC5jb20+IA0KU3ViamVjdDogUlYtTGlzdDogU29t ZSBJbnRlcmVzdGluZyBEYXRhIChMb25nKSANCiAgICJzb2NhbC1ydmxpc3QiIDxTb0NBTC1SVmxp c3RAeWFob29ncm91cHMuY29tPiANCg0KLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJP d2VucywgTGFpcmQiIDxPd2Vuc0BhZXJvdmlyb25tZW50LmNvbT4gDQoNCkhpIGFsbCwgDQoNClNp bmNlIEkgY29udmVydGVkIG92ZXIgdG8gYSBIYXJ0emVsbCBwcm9wIG9uIG15IE8tMzYwL1JWLTYs IEkndmUgd2FudGVkDQp0byBkbyBzb21lIGdvb2QgZGF0YSBjb2xsZWN0aW9uLiAgSSBmaW5hbGx5 IGdvdCBhIGNoYW5jZSB0byBnbyBvdXQgbGFzdA0KZXZlbmluZyBhbmQgY29sbGVjdCBhIGxpdHRs ZS4gKExpa2UgbXkgYm9zcyBzZXouLi4uIkRhdGEgaXMgZWFzeSwgR09PRA0KZGF0YSBpcyBoYXJk IikuICBUaG91Z2h0IHNvbWUgb2YgeW91IG1pZ2h0IGJlIGludGVyZXN0ZWQuDQoNClR3byBhcmVh cyBvZiBpbnRlcmVzdCB0byBtZSBhcmUgdG9wIHNwZWVkIChJIHdhbnQgdG8gc3RhcnQgZG9pbmcg YQ0KbGl0dGxlIGRyYWcgcmVkdWN0aW9uIHdvcmsgc29vbiBhbmQgbmVlZCBhIGJhc2VsaW5lIHNw ZWVkKSBhbmQNCnJhbmdlL2VuZHVyYW5jZS4gSSdtIHBsYW5uaW5nIG9uIGZseWluZyB0byB0aGUg TGFzIENydWNlcyBSViBnZXQNCnRvZ2V0aGVyIHRoaXMgd2Vla2VuZCBhbmQgaXQncyBhIDYwMCBt aWxlIGZsaWdodCBmcm9tIExBLiAgSSB3YW50ZWQgdG8NCnNlZSBpZiBJIGNvdWxkIG1ha2UgaXQg d2l0aG91dCBzdG9wcGluZy4NCg0KSSd2ZSBhbHdheXMgYmVlbiBjb25zZXJ2YXRpdmUgd2hlbiBm bGlnaHQgcGxhbm5pbmcsIGd1ZXNzaW5nIDMuNSBocnMgKDEwDQpHUEggd2l0aCByZXNlcnZlKSBh bmQgYWJvdXQgYSA2MDAgbWlsZSByYW5nZSwgYnV0IEkndmUgd2FudGVkIHRvIG5haWwNCmRvd24g dGhlIHJlYWwgbnVtYmVycyBmb3IgbXkgYWlycGxhbmUuICBTbyBJIHdlbnQgb3V0IGFuZCBidXJu ZWQgc29tZQ0KZ2FzIHRyeWluZyB0byBmaWd1cmUgaXQgb3V0LiAgSSBjYW1lIGJhY2sgd2l0aCBz b21lIGludGVyZXN0aW5nIG51bWJlcnMuDQoNClRoZSB0ZXN0IHdhcyBmbG93biBhdCA4MDAwIGZl ZXQgZGVuc2l0eSBhbHRpdHVkZSAoYWx0aW1ldGVyIHNldCB0byAyOS45Mg0KYW5kIGNvcnJlY3Rl ZCBmb3IgT0FULCB3aGljaCB3YXMgMjIgQywgd2hpY2ggbWVhbnQgSSdkIGZseSBhdCA1ODc1IGZl ZXQpDQphbmQgYXQgZGlmZmVyZW50IGFpcnNwZWVkcyB0byBjb2xsZWN0IHRoZSBmdWVsIGZsb3cg aW5mb3JtYXRpb24uICBJIHRoZW4NCnB1dCB0aGF0IGludG8gYSBncmFwaCB0byBkZXRlcm1pbmUg YmVzdCByYW5nZSBhbmQgZW5kdXJhbmNlLiAgRW5naW5lIFJQTQ0Kd2FzIDI0MDAgYW5kIHRoZSBl bmdpbmUgbGVhbmVkIHRvIHBlYWsgb24gdGhlIGhvdHRlc3QgY3lsaW5kZXIgKEkNCmtub3cuLi4u dGhhdCBtYXkgbm90IGJlIHRoZSBsZWFuZXN0IGN5bGluZGVyKS4NCg0KS25vdyBlcnJvcnMgdGhh dCBJIGNhbid0IGFjY291bnQgZm9yIHJpZ2h0IG5vdyBhcmUgc3RhdGljIGFuZA0KaW5zdHJ1bWVu dGF0aW9uIGVycm9ycywgc28gdGhlIG51bWJlcnMgbWF5IGJlIGEgbGl0dGxlIG9mZiBoZXJlIG9y DQp0aGVyZS4gQWZ0ZXIgc2VsZWN0aW5nIGEgcG93ZXIgc2V0dGluZyBhbmQgYWlyc3BlZWQsIEkg ZmxldyB0aGUgYWlyc3BlZWQNCmFuZCBsb29rZWQgZm9yIGVsZXZhdGlvbiBjaGFuZ2VzLCBhbmQg dGhlbiBhZGp1c3QgdGhlIHBvd2VyIGFjY29yZGluZ2x5Lg0KSSdkIHRoZW4gbGVhbiB0byBwZWFr LCB0aGVuIGxldCBldmVyeXRoaW5nIHN0YWJpbGl6ZSBhbmQgYWdhaW4gbWFrZSBhbnkNCnNtYWxs IGFkanVzdG1lbnRzIHRvIHRoZSBwb3dlciBzZXR0aW5nLiAgQWZ0ZXIgZ2V0dGluZyB0byB0aGF0 IHN0YWdlLA0KSSdkIG5vdGUgZnVlbCBmbG93LCBJQVMsIE1QLCBhbmQgdGhlbiBkbyBhIDMgd2F5 IEdQUyBydW4gdG8gZ2V0IFRBUy4gIEkNCnJhbiBhbGwgdGhlc2UgZGF0YSBwb2ludHMgb24gb25l IGZsaWdodCwgc28gdGhlIHVwcGVyIHNwZWVkcyBtYXkgYmUgb2ZmDQphIGxpdHRsZSBkdWUgdG8g YSBsb3dlciBhaXJjcmFmdCB3ZWlnaHQgZHVlIHRvIHRoZSBnYXMgYmVpbmcgdXNlZCBkdXJpbmcN CnRoZSBmbGlnaHQuIChJIHN0YXJ0ZWQgYXQgdGhlIGxvd2VyIGFpcnNwZWVkcyBmaXJzdCkuICBJ IGZsZXcgcG9pbnRzDQpiZXR3ZWVuIDkwIG1waCBJQVMgYW5kIGZ1bGwgdGhyb3R0bGUgYXQgMTAg bXBoIGludGVydmFscy4gIEl0IHR1cm5lZCBvdXQNCnRvIGJlIGEgZ29vZCBldmVuaW5nIHdpdGgg YWxtb3N0IG5vIHR1cmJ1bGVuY2UgYW5kIHVuZGVyIDMgbXBoIG9mIHdpbmQNCmF0IHRoZSB0ZXN0 IGFsdGl0dWRlLiAgSSB3YXMgcGxlYXNlZCB3aXRoIHRoZSBkYXRhIEkgZ290LCBhcyBpdCBhbGwg Zml0DQpwcmV0dHkgd2VsbCAgYW5kIGNhbWUgdXAgd2l0aCBzb21lIGJlbGlldmFibGUgY3VydmVz IChpLmUuIG5vIGRhdGEgcG8hDQoNCmludHMgd2F5IG9mZiB0aGUgZml0IGN1cnZlKS4gDQoNCkFm dGVyIGRvaW5nIHNvbWUgbnVtYmVyIGNydW5jaGluZyBhbmQgZ3JhcGhpbmcsIGl0IGxvb2tzIGxp a2UgdGhlIG1heA0KZW5kdXJhbmNlIG9mIHRoZSBhaXJwbGFuZSBjb21lcyBhdCAxMDAgbXBoIElB Uy8xMTIgbXBoIFRBUyB3aXRoIGEgZnVlbA0KZmxvdyBvZiA1LjAgR1BILiAgQXNzdW1pbmcgYSA2 IGdhbCByZXNlcnZlLCB0aGF0IGxlYXZlcyAzMiBnYWxsb25zDQp1c2FibGUuICBUaGF0IGdpdmVz IGEgNi40IGhyIGVuZHVyYW5jZSAobXkgYnV0dCBjYW4ndCBzaXQgaW4gdGhlIHNlYXQNCnRoYXQg bG9uZykgYW5kIGEgNzE2IG1pbGUgcmFuZ2UsIHdoaWNoIGlzIDIyLjQgTVBHLiAgSSBzaG91bGQg bm90ZSB0aGF0DQp0aGUgZW5naW5lIHdhc24ndCB2ZXJ5IGhhcHB5IGF0IHRoaXMgcG93ZXIgc2V0 dGluZywgYXMgaXQgd291bGQgc2tpcA0KZXZlcnkgb25jZSBpbiBhIHdoaWxlIChwcm9iYWJseSBh IGxlYW4gbWlzcykuICBBbHNvIHRoZSBmdWVsIGZsb3cgbWV0ZXINCndhcyBhIGxpdHRsZSBmbGFr eSBuZWFyIHRoZXNlIHBvd2VyIHNldHRpbmdzLCBmbHVjdHVhdGluZyBiZXR3ZWVuIDQgdG8NCjYu ICBJIGp1c3QgdG9vayB0aGUgYXZlcmFnZSBvZiB3aGF0IEkgc2F3LiAgSXQgd2Fzbid0IHVudGls IEkgd2FzDQpmbG93aW5nIGFyb3VuZCA2IEdQSCB0aGF0IHRoZSBmbG93IG1ldGVyIHNldHRsZWQg ZG93bi4NCg0KVGhlIGJlc3QgcmFuZ2UgY29tZXMgYXQgMTI1IG1waCBJQVMvIDE0OCBtcGggVEFT IHdpdGggYSBmdWVsIGZsb3cgb2YgNS41DQpHUEguIFVzaW5nIHRoZSBzYW1lIHJlc2VydmUsIEkg Z2V0IDUuOCBocnMgYW5kIGEgODU4IG1pbGUgcmFuZ2UsIHdoaWNoDQppcyAyNi44IE1QRy4gKEkg c3RpbGwgY2FuJ3Qgc2l0IGluIHRoZSBzZWF0IHRoYXQgbG9uZykuDQoNClNvIHB1c2hpbmcgaXQg dXAgYSBsaXR0bGUgdG8gOCBHUEggeWllbGRzIGEgNCBob3VyIGVuZHVyYW5jZSAobm90DQppbmNs dWRpbmcgcmVzZXJ2ZSkgYXQgMTYwIG1waCBJQVMvIDE4NSBUQVMgZm9yIGEgNzQwIG1pbGUgcmFu Z2UgYW5kIDIzLjENCk1QRy4NCg0KRnVsbCB0aHJvdHRsZSBjb21lcyBvdXQgYXQgOS42IEdQSCBh bmQgMTc0IG1waCBJQVMvMjAwIFRBUyB3aXRoIGEgMy4zIGhyDQplbmR1cmFuY2UgYW5kIGEgNjYw IG1pbGUgcmFuZ2UgYW5kIGEgMjAuNiBNUEcgDQoNClRoZSBsYXN0IHRlc3Qgd2FzIGZ1bGwgdGhy b3R0bGUvMjcwMCBycG0gYW5kIGl0IHdhcyAxMS43IEdQSCBhbmQgMjA3DQpUQVMuICBUaGlzIHdh cyBvbmx5IG9uZSBkYXRhIHBvaW50IG9uIHRoaXMgZGF5LCBJIG5lZWQgdG8gZG8gdGhpcw0Kc2V2 ZXJhbCBtb3JlIHRpbWVzIHRvIGF2ZXJhZ2UgdGhlIHNwZWVkcyB0byB0cnkgdG8gZ2V0IGEgbW9y ZSBhY2N1cmF0ZQ0KbnVtYmVyLCBidXQgaXQncyBhIHN0YXJ0Lg0KDQpUaGlzIGlzIGEgYWJvdXQg YW4gMTEgbXBoIHNwZWVkIGdhaW4gb3ZlciB0aGUgU2Vuc2VuaWNoIDcyRk0gZml4ZWQgcGl0Y2gN CnByb3AgSSBoYWQgb24gYmVmb3JlICh3aGljaCB3YXMgYW4gODMiIHBpdGNoKS4gIFRoZSBtYWlu IGRpZmZlcmVuY2UgaXMNCnRoYXQgSSBjYW4gdXNlIGZ1bGwgdGhyb3R0bGUgd2l0aCB0aGUgSGFy dHplbGwuICBBdCA4MDAwIERBIGFuZCB0aGUNClNlbnNlbmljaCwgSSBzdGlsbCBoYWQgYW5vdGhl ciAzIiBvZiBNUCBsZWZ0IHRvIGdvLCBidXQgd291bGQgYmUgYXQgdGhlDQoyNzAwIHJwbSBsaW1p dC4NCg0KQWdhaW4sIHRoaXMgd2FzIGRhdGEgdGFrZW4gb24gdGhpcyBvbmUgZGF5LCBmb3IgbXkg YWlycGxhbmUsIGFuZCBpcw0KcHJvYmFibHkgc3ViamVjdCB0byBzZXZlcmFsIGRpZmZlcmVudCBl cnJvcnMgKG15IGZseWluZyBpbmNsdWRlZCksIGJ1dA0KaXQgc2hvdWxkIGJlIGNsb3NlLiBJdCBk b2VzIHByb3ZpZGUgYW4gaW50ZXJlc3RpbmcgY29tcGFyaXNvbiBvZiBGRiB2cw0KVEFTLiAgSSdk IGxpa2UgdG8gcmVwZWF0IHRoaXMgdGVzdCBhdCBhIGhpZ2hlciBhbHRpdHVkZSBhbmQgc2VlIHNv bWUgb2YNCnRoZSBlZmZlY3RzIGFzIHdlbGwsIGJ1dCB0aGF0J2xsIGhhdmUgdG8gd2FpdCB1bnRp bCBhbm90aGVyIGRheS4gIA0KDQpMYWlyZCANClJWLTYgMzQwIGhycyANClNvQ2FsIA0KDQo ________________________________________________________________________________
Date: Sep 11, 2001
Subject: Thoughts and prayers
I heard the first, garbled news of the crashes at the WTC this morning, but didn't really start to understand the magnitude or horror of the event until I phoned back to Ottawa and spoke to my wife, who is American. She had just watched the first tower collapse on CNN, and was almost inconsolable. The second tower collapsed as we talked. I cannot comprehend how anyone could perpetrate such a monstrous act. The thoughts and prayers of people around the world are directed to our American friends in this time of trial. I wish you every success in identifying and punishing those responsible. I hope they die a slow and painful death. Kevin Horton trying to do some flight testing in Wichita ________________________________________________________________________________
Date: Sep 11, 2001
In a message dated 9/10/2001 10:32:07 PM Pacific Daylight Time, azpilot(at)extremezone.com writes: > > Has anyone noticed their control stick getting more slop in it (for elevator > control) after flying? I haven't pulled the seat pans yet, so I haven't > seen if there is a problem. > > Check it out NOW, One of the So Cal group I was flying formation with complained of elevator slop. We took the rear baggage baffle out to find a bolt had nearly dropped out of the reversing bellcrank. Fred LaForge RV-4 0-360 CS EAA Tech counselor ________________________________________________________________________________
Date: Sep 11, 2001
From: PETER LAURENCE <plaurence(at)worldnet.att.net>
Subject: GBA
> > >Eric, > >On this day in particular, we should ask God to bless all Americans, and >pity the fxckers that have brought these cowardly acts to our cities. > >Rick Murphy > > >Rick, It seems that G_d blessed the terrorists on this day Peter Laurence > > > > ________________________________________________________________________________
From: "Mister Murphy" <mister_murphy(at)hotmail.com>
Subject: Re: GBA
Date: Sep 12, 2001
Eric, I'll second that...God Bless America. From North Carolina I would like to send my thoughts and prayers to the people and families involved. Erik Harrell RV-6A (wings) Mt Airy NC At a loss for words...... > > >God Bless America > > ________________________________________________________________________________
Date: Sep 11, 2001
Dan Sept 22nd 23rd=rain day John Dan DeNeal wrote: > > >Anybody know when the Lebannon Tn fly in is? I thing >is should be coming up very soon. > >Dan > > ________________________________________________________________________________
Subject: GBA
Date: Sep 11, 2001
This morning I awoke and went first to this list as has become my habit for four years plus. The very first message that came to the screen was; "God Bless America" My thoughts where not thoughts born of patience or understanding as I hit the delete button. As it happens I finished editing the email and went next to the television. The next thing I saw was an obviously Moslem individual being interviewed. The translator was barely able to speak English and I found it very hard to make sense of what the interview was about. I changed channels and saw what at first I believed to be a promotion for another in a long line of thriller movies. The reality of what I was actually seeing clawed and scraped away at my inability to perceive. The crescendo of horror continued on. the painful tearing and scraping went on and continues still. Please whom ever sent that blessing that began this day for me please accept my apology for being so jaded as to turn away from your statement born of pain that I to now share. If I am changed this much by such a reality as this day has brought, I can not imagine how to find any better words than yours to express this anguish that has befallen all of us. God bless us all. ________________________________________________________________________________
Subject: Day of Infamy II
Date: Sep 11, 2001
Thank you, our friends in other nations, for your expressions of shock, outrage and sympathy. This day of national tragedy and personal sadness brings to mind another one - that occurred over six decades ago. Woe be to those who think our give and take of a free democratic society means weakness. Yes, we bicker among ourselves with differing viewpoints about many things, but there are those things that unite us as a nation. United and with a common resolve this act will result in inevitable retribution and justice for those responsible just as surely as that act of infamy six decades ago. Ed Anderson Matthews, NC RV-6A N494BW eanderson(at)carolina.rr.com ________________________________________________________________________________
Date: Sep 12, 2001
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
RV list
Subject: Thoughts and Condolences
To our southern neighbours; The thoughts, prayers and condolences of all Canadians are with you on this black memorable day. Bob McC Toronto Canada ________________________________________________________________________________
Subject: Re: Thoughts and prayers
Date: Sep 11, 2001
I wish you every success in > identifying and punishing those responsible. I hope they die a slow and > painful death. > > Kevin Horton My thoughts exactly, Kevin. As much as I support everything the US stands for, the Army Soldier in me can't but help to skip all of the juris prudis crap and lets take these sons of bitches down. I don't think we would be too haste if we declared war on all terrorists, and any nation guilty of harboring. If it is this Bin Laden guy, and Afghanistan is responsible for harboring him, I say level them. And if Uncle Sam wants to call me up from the National Guard and help out, I say give me any weapon of destruction and I'm there. Whew. I'm glad Day of Infamy II is almost over. Hope there is a way, that someday, we will heal from this horrific day. SPC Paul Besing C BTRY 2/180th Field Artillery 13E Cannon Fire Direction Control Specialist U.S. Army National Guard ________________________________________________________________________________
Subject: Re: Thoughts and Condolences
Date: Sep 11, 2001
I wish to add the thoughts and prayers of my family for those south of our border. I learned about this tragic day while over the North Pacific in the dark eastbound for Vancouver and we shared in the ship-to-ship discussion on VHF with several United, Northwest and American Crews as each of us received more information via satellite link. My fellow pilots could only shake their heads and wonder why. Never in human history have innocent people been forced to ride in a bomb and I can't begin to imagine how they felt. Again- my sympathies to your countrymen. Scott in Vancouver ----- Original Message ----- From: Robert McCallum <robert.mccallum2(at)sympatico.ca> Sent: Tuesday, September 11, 2001 9:43 PM Subject: RV-List: Thoughts and Condolences > > To our southern neighbours; > > The thoughts, prayers and condolences of all Canadians are with you on > this black memorable day. > > Bob McC > Toronto Canada > > ________________________________________________________________________________
Subject: Re: AeroElectric-List: Thoughts and Condolences
Date: Sep 11, 2001
Thanks to all supporters in other countries around the world. I think it could be so easy for people from other nations to turn their head and not get involved. The compassion that has been shown from listers in many countries really shows that no matter where one is from, there is always a common bond when it comes to humanity. (at least from rational, caring, and supportive individuals from these nations) Paul Besing ----- Original Message ----- From: "Robert McCallum" <robert.mccallum2(at)sympatico.ca> Sent: Tuesday, September 11, 2001 9:43 PM Subject: AeroElectric-List: Thoughts and Condolences > --> AeroElectric-List message posted by: Robert McCallum > > To our southern neighbours; > > The thoughts, prayers and condolences of all Canadians are with you on > this black memorable day. > > Bob McC > Toronto Canada > > ________________________________________________________________________________
Date: Sep 12, 2001
Subject: Navaid
Finally recieved my navaid today. Looking forward to getting started. Any suggestions by anyone who has been there would be appreciated. I plan on using the garmin 195 GPS in conjunction with the navaid. RV6A 0360 cp 140 hrs Can't get rid of the grin NRA LIFE MEMBER ________________________________________________________________________________
Subject: Coastal Georgia Fall Fly-In
Date: Sep 12, 2001
With respect to events of Sep 11 the Coastal Georgia Fall Fly-In scheduled for September 15 at Eagle Neck 1GA0 has been postponed indefinitely. Dick Sipp ________________________________________________________________________________
Subject: GBA
Date: Sep 12, 2001
So, it's okay to talk about God during disasters but not normally?? I can remember within the last year a lister being blasted for posting off-topic material that included relieous beliefs. Now we all have religeon all of a sudden? Is this horrible, horrible event what it takes? Yes, GOD BLESS AMERICA. God bless all who use this... and may GOD help ANYONE who ever flames me for mentioning God on this list again!! And Tom Gummo, I'm with you! I think the US needs to take swift, decisive, and OVERWHELMING action. I sincerely hope that our President has the balls to do what is necessary. -- Scott (a slightly angry Christian) VanArtsdalen RV-4 builder -----Original Message----- From: Jim Jewell [mailto:jjewell(at)telus.net] Sent: Tuesday, September 11, 2001 8:17 PM Subject: RV-List: GBA This morning I awoke and went first to this list as has become my habit for four years plus. The very first message that came to the screen was; "God Bless America" My thoughts where not thoughts born of patience or understanding as I hit the delete button. As it happens I finished editing the email and went next to the television. The next thing I saw was an obviously Moslem individual being interviewed. The translator was barely able to speak English and I found it very hard to make sense of what the interview was about. I changed channels and saw what at first I believed to be a promotion for another in a long line of thriller movies. The reality of what I was actually seeing clawed and scraped away at my inability to perceive. The crescendo of horror continued on. the painful tearing and scraping went on and continues still. Please whom ever sent that blessing that began this day for me please accept my apology for being so jaded as to turn away from your statement born of pain that I to now share. If I am changed this much by such a reality as this day has brought, I can not imagine how to find any better words than yours to express this anguish that has befallen all of us. God bless us all. ________________________________________________________________________________
Subject: The Attack
Date: Sep 12, 2001
Send your men, send your weapons, and help us drive Bin Laden and his friends into the sea.... As a Northern neighbour, myself and all those around me wish to express our deepest condolences for the cowardly attack on your nation. I know Canada will do anything possible to assist in whatever form your country requires. ________________________________________________________________________________
Subject: GBA
Date: Sep 12, 2001
Scott, I think what we are experiencing is people reaching back to grab hold of those basic beliefs and strengths that many of us fail to acknowledge in our daily lives. When faced with the incomprehendable, we can only look toward (a merciful) God for solace and a (vengful) God for justice. Rick Murphy RV4-emp > ---------- > From: Van Artsdalen, Scott[SMTP:svanarts(at)unionsafe.com] > Reply To: rv-list(at)matronics.com > Sent: Wednesday, September 12, 2001 10:17 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: GBA > > > > So, it's okay to talk about God during disasters but not normally?? I can > remember within the last year a lister being blasted for posting off-topic > material that included relieous beliefs. Now we all have religeon all of > a > sudden? Is this horrible, horrible event what it takes? > > Yes, GOD BLESS AMERICA. > > God bless all who use this... and may GOD help ANYONE who ever flames me > for > mentioning God on this list again!! > > And Tom Gummo, I'm with you! I think the US needs to take swift, > decisive, > and OVERWHELMING action. I sincerely hope that our President has the > balls > to do what is necessary. > > -- > Scott (a slightly angry Christian) VanArtsdalen > RV-4 builder > > -----Original Message----- > From: Jim Jewell [mailto:jjewell(at)telus.net] > Sent: Tuesday, September 11, 2001 8:17 PM > To: rv-list(at)matronics.com > Subject: RV-List: GBA > > > > This morning I awoke and went first to this list as has become my habit > for four years plus. > The very first message that came to the screen was; > "God Bless America" > My thoughts where not thoughts born of patience or understanding as I > hit the delete button. > As it happens I finished editing the email and went next to the > television. > The next thing I saw was an obviously Moslem individual being > interviewed. The translator was barely able to speak English and I found > it very hard to make sense of what the interview was about. > I changed channels and saw what at first I believed to be a promotion > for another in a long line of thriller movies. > > The reality of what I was actually seeing clawed and scraped away at my > inability to perceive. > The crescendo of horror continued on. the painful tearing and scraping > went on and continues still. > > > Please whom ever sent that blessing that began this day for me please > accept my apology for being so jaded as to turn away from your statement > born of pain that I to now share. > If I am changed this much by such a reality as this day has brought, I > can not imagine how to find any better words than yours to express this > anguish that has befallen all of us. > > God bless us all. > > > > > > ________________________________________________________________________________
Subject: Center arm rest
Date: Sep 12, 2001
The other day I saw a web site with a center arm rest/glove box made for RV6 but I can't remember where. Does anybody know what the site is and does anyone have any comments on this item. Thanks John Furey ________________________________________________________________________________
Subject: GBA
Date: Sep 12, 2001
I agree with you Rick, but I hope you understand my frustration as one who has been flamed for trying to do just what you say below on a daily basis, not just during times of duress. I tend to think of people who only look to God during times of need as the friend who only comes to see me when he needs to borrow money. I'm far more inclined to give money to my friends who have consistently been by my side. That being said, we are all very fortunate that God has limitless mercy. -----Original Message----- From: Murphy, Richard James (Rick) [mailto:rjmurphy1(at)lucent.com] Sent: Wednesday, September 12, 2001 7:57 AM Subject: RE: RV-List: GBA Scott, I think what we are experiencing is people reaching back to grab hold of those basic beliefs and strengths that many of us fail to acknowledge in our daily lives. When faced with the incomprehendable, we can only look toward (a merciful) God for solace and a (vengful) God for justice. Rick Murphy RV4-emp > ---------- > From: Van Artsdalen, Scott[SMTP:svanarts(at)unionsafe.com] > Reply To: rv-list(at)matronics.com > Sent: Wednesday, September 12, 2001 10:17 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: GBA > > > > So, it's okay to talk about God during disasters but not normally?? I can > remember within the last year a lister being blasted for posting off-topic > material that included relieous beliefs. Now we all have religeon all of > a > sudden? Is this horrible, horrible event what it takes? > > Yes, GOD BLESS AMERICA. > > God bless all who use this... and may GOD help ANYONE who ever flames me > for > mentioning God on this list again!! > > And Tom Gummo, I'm with you! I think the US needs to take swift, > decisive, > and OVERWHELMING action. I sincerely hope that our President has the > balls > to do what is necessary. > > -- > Scott (a slightly angry Christian) VanArtsdalen > RV-4 builder > > -----Original Message----- > From: Jim Jewell [mailto:jjewell(at)telus.net] > Sent: Tuesday, September 11, 2001 8:17 PM > To: rv-list(at)matronics.com > Subject: RV-List: GBA > > > > This morning I awoke and went first to this list as has become my habit > for four years plus. > The very first message that came to the screen was; > "God Bless America" > My thoughts where not thoughts born of patience or understanding as I > hit the delete button. > As it happens I finished editing the email and went next to the > television. > The next thing I saw was an obviously Moslem individual being > interviewed. The translator was barely able to speak English and I found > it very hard to make sense of what the interview was about. > I changed channels and saw what at first I believed to be a promotion > for another in a long line of thriller movies. > > The reality of what I was actually seeing clawed and scraped away at my > inability to perceive. > The crescendo of horror continued on. the painful tearing and scraping > went on and continues still. > > > Please whom ever sent that blessing that began this day for me please > accept my apology for being so jaded as to turn away from your statement > born of pain that I to now share. > If I am changed this much by such a reality as this day has brought, I > can not imagine how to find any better words than yours to express this > anguish that has befallen all of us. > > God bless us all. > > > > > > ________________________________________________________________________________
Date: Sep 12, 2001
Thread-Topic: RV-List: Center arm rest Thread-Index: AcE7oTw4Tzrl36eOEdWAOwAIxwleHwAACDlQ
From: "Reeves, Doug" <Douglas.Reeves(at)archongroup.com>
John, that web address is http://www.metronet.com/~dreeves/turtlewooddesign/roger.htm God Bless America, Doug Reeves -----Original Message----- From: John Furey [mailto:john(at)fureychrysler.com] Sent: Wednesday, September 12, 2001 10:25 AM Subject: RV-List: Center arm rest The other day I saw a web site with a center arm rest/glove box made for RV6 but I can't remember where. Does anybody know what the site is and does anyone have any comments on this item. Thanks John Furey ________________________________________________________________________________
Subject: Manual to Elec Flaps
Date: Sep 12, 2001
Can any one who has converted from manual to electric flaps in an flying RV6/A comment on the experience? Number of hours for conversion, things to watch out for, etc. Ed Cole RV6A N2169D Flying RV6A N648RV Finishing Maxim Home Page: http://www.maxim-ic.com Products Page: http://www.maxim-ic.com/MaximProducts/products.htm New Products: http://dbserv.maxim-ic.com/new_products.cfm Datasheets: http://dbserv.maxim-ic.com/l_datasheet3.cfm The information contained in this message is confidential and may be legally privileged. The message is intended solely for the addressee(s). If you are not the intended recipient, you are hereby notified that any use, dissemination, or reproduction is strictly prohibited and may be unlawful. If you are not the intended recipient, please contact the sender by return e-mail and destroy all copies of the original message. ________________________________________________________________________________
Date: Sep 12, 2001
U29ycnkgZ3V5cyBmb3IgdGhlIHVuLWRlY3J5cHRlZCBlbWFpbHMsIGJ1dCBmb3Igc29tZSByZWFz b24gd2hlbg0KYWNjZXNzaW5nIG15IHdvcmsgZW1haWwgZnJvbSBob21lIHRoZSBtZXNzYWdlcyBv dmVyIFNTTCBkb24ndCBnZXQNCmRlY3J5cHRlZCBhdCB0aGUgc2VydmVyLiAgU28gaGVyZSdzIG15 IG9yaWdpbmFsIHJlcGx5Li4uDQogDQogDQpMYWlyZCwNCiANCkhhdmUgeW91IGRvbmUgdGhlIDMt d2F5IEdQUyBydW5zPyAgSSBkaWQgc29tZSB0ZXN0aW5nIHRoZSBvdGhlciBkYXkgYW5kDQpjYW1l IHVwIHdpdGggMTY2IGtub3RzIGNydWlzZSBhdCA4MDAwIGZlZXQgYnkgdGhlIEdQUyAoMjQwMCBS UE0sIDIyLjUiLA0KbGVhbmVkIHRvIHBlYWssIDkuMi05LjVHUEgpLCBvbiBhIHdhcm0gKDg1Kykg ZGVncmVlIGRheS4gIENyYW5raW5nIHRoZQ0KcmV2cyB1cCB0byBnZXQgNzUlIG9ubHkgZ2l2ZXMg bWUgYSBrbm90IG9yIHR3by4gIEkgaGF2ZSBkb25lIHRoZXNlIHJ1bnMNCnNldmVyYWwgdGltZXMg b3ZlciB0aGUgY291cnNlIG9mIHRoZSBwYXN0IHllYXIgYW5kIHR5cGljYWxseSBhbSB3aXRoaW4N CjItMyBrbm90cyBiZXR3ZWVuIHRlc3RzLiAgU28sIG15IHJlYWwtd29ybGQgY3J1aXNlIGlzIDE2 NSBrbm90cy4NCiANCldpdGggdGhhdCBiZWluZyBzYWlkLi4uDQogDQpUaGlzIGlzIHNsaWdodGx5 IGJlbG93IFZhbidzIHB1Ymxpc2hlZCBmaWd1cmVzLCBhbmQgSSBkb24ndCBoYXZlIGENCnBvb3Js eSByaWdnZWQgb3IgYnVpbHQgYWlycGxhbmUuICBJTU8gSSB0aGluayBWYW4ncyBwdWJsaXNoZWQg bnVtYmVycw0KYXJlIHNsaWdodGx5IGhpZ2guICBNb3N0IG9mIG15IGxvY2FsIFJWIGJ1ZGRpZXMg YWdyZWUuICBGb3IgZXhhbXBsZSwgdGhlDQpSVi04IGhhcyBhIGZhc3RlciBwdWJsaXNoZWQgY3J1 aXNlIHNwZWVkIHRoYW4gZG9lcyB0aGUgLTQuICBJIGRvbid0DQp1bmRlcnN0YW5kIGhvdyB0aGUg LTggY2FuIGJlIGZhc3RlciB3aXRoIGl0cyBncmVhdGVyIGZyb250YWwgYXJlYSBhbmQNCmhpZ2hl ciB3ZWlnaHQgdGhhbiBhIC00IHdpdGggdGhlIHNhbWUgaG9yc2Vwb3dlci4gIEkgZmx5IHJlZ3Vs YXJseSB3aXRoDQphIDE4MCBDL1MgLTggdGhhdCBpcyBhIHZlcnkgd2VsbCBidWlsdCBRQiBhaXJm cmFtZSBhbmQgaGlzIGNydWlzZSBzcGVlZA0KaXMgb25seSBzbGlnaHRseSBmYXN0ZXIgdGhhbiBt aW5lLi4uIGl0IHRha2VzIGFuIGV4dHJhIDEvMiIgb2YgbWFuaWZvbGQNCnByZXNzdXJlIGZvciBt ZSB0byBrZWVwIHVwIHdpdGggaGltIHdpdGggdGhlIHNhbWUgcG93ZXIgc2V0dGluZ3MuIFRoZQ0K b2RkIHRoaW5nIGlzIHdoZW4gd2UgYm90aCBoYXZlIGEgcGFzc2VuZ2VyIHRoZW4gaXQgdGFrZXMg YSBsb3QgbW9yZQ0KKDEtMS41Iikgb2YgdGhyb3R0bGUgZm9yIG1lIHRvIGtlZXAgdXAgd2l0aCBo aW07IHdlJ3JlIGdvaW5nIHRvIGV4cGxvcmUNCnRoYXQgZnVydGhlci4gIEEgZnJpZW5kJ3MgUlYt NCB3aWxsIGZsYXQtb3V0IHN0b21wIGJvdGggb2YgdXMgd2l0aCB0aGUNCnNhbWUgaGFyZHdhcmUg dXAgZnJvbnQuICBNYXliZSBJIG5lZWQgdG8gdHVybiB0aGF0IGxpdHRsZSBzZXQgc2NyZXcgb24N CnRoZSBnb3Zlcm5vciBvdXQgYSBmZXcgdHVybnMgOykgIEZXSVcNCiANCkJvYiBKYXB1bmR6YQ0K UlYtNiBOMjQ0QkogTy0zNjBDL1MgZmx5aW5nIDIwOSBob3Vycw0KDQpUaW1lOiAwMzo1MjozNSBQ TSBQU1QgVVMgDQpGcm9tOiAiT3dlbnMsIExhaXJkIiA8T3dlbnNAYWVyb3Zpcm9ubWVudC5jb20+ IA0KU3ViamVjdDogUlYtTGlzdDogU29tZSBJbnRlcmVzdGluZyBEYXRhIChMb25nKSANCiAgICJz b2NhbC1ydmxpc3QiIDxTb0NBTC1SVmxpc3RAeWFob29ncm91cHMuY29tPiANCg0KLS0+IFJWLUxp c3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJPd2VucywgTGFpcmQiIDxPd2Vuc0BhZXJvdmlyb25tZW50 LmNvbT4gDQoNCkhpIGFsbCwgDQoNClNpbmNlIEkgY29udmVydGVkIG92ZXIgdG8gYSBIYXJ0emVs bCBwcm9wIG9uIG15IE8tMzYwL1JWLTYsIEkndmUgd2FudGVkDQp0byBkbyBzb21lIGdvb2QgZGF0 YSBjb2xsZWN0aW9uLiAgSSBmaW5hbGx5IGdvdCBhIGNoYW5jZSB0byBnbyBvdXQgbGFzdA0KZXZl bmluZyBhbmQgY29sbGVjdCBhIGxpdHRsZS4gKExpa2UgbXkgYm9zcyBzZXouLi4uIkRhdGEgaXMg ZWFzeSwgR09PRA0KZGF0YSBpcyBoYXJkIikuICBUaG91Z2h0IHNvbWUgb2YgeW91IG1pZ2h0IGJl IGludGVyZXN0ZWQuDQoNClR3byBhcmVhcyBvZiBpbnRlcmVzdCB0byBtZSBhcmUgdG9wIHNwZWVk IChJIHdhbnQgdG8gc3RhcnQgZG9pbmcgYQ0KbGl0dGxlIGRyYWcgcmVkdWN0aW9uIHdvcmsgc29v biBhbmQgbmVlZCBhIGJhc2VsaW5lIHNwZWVkKSBhbmQNCnJhbmdlL2VuZHVyYW5jZS4gSSdtIHBs YW5uaW5nIG9uIGZseWluZyB0byB0aGUgTGFzIENydWNlcyBSViBnZXQNCnRvZ2V0aGVyIHRoaXMg d2Vla2VuZCBhbmQgaXQncyBhIDYwMCBtaWxlIGZsaWdodCBmcm9tIExBLiAgSSB3YW50ZWQgdG8N CnNlZSBpZiBJIGNvdWxkIG1ha2UgaXQgd2l0aG91dCBzdG9wcGluZy4NCg0KSSd2ZSBhbHdheXMg YmVlbiBjb25zZXJ2YXRpdmUgd2hlbiBmbGlnaHQgcGxhbm5pbmcsIGd1ZXNzaW5nIDMuNSBocnMg KDEwDQpHUEggd2l0aCByZXNlcnZlKSBhbmQgYWJvdXQgYSA2MDAgbWlsZSByYW5nZSwgYnV0IEkn dmUgd2FudGVkIHRvIG5haWwNCmRvd24gdGhlIHJlYWwgbnVtYmVycyBmb3IgbXkgYWlycGxhbmUu ICBTbyBJIHdlbnQgb3V0IGFuZCBidXJuZWQgc29tZQ0KZ2FzIHRyeWluZyB0byBmaWd1cmUgaXQg b3V0LiAgSSBjYW1lIGJhY2sgd2l0aCBzb21lIGludGVyZXN0aW5nIG51bWJlcnMuDQoNClRoZSB0 ZXN0IHdhcyBmbG93biBhdCA4MDAwIGZlZXQgZGVuc2l0eSBhbHRpdHVkZSAoYWx0aW1ldGVyIHNl dCB0byAyOS45Mg0KYW5kIGNvcnJlY3RlZCBmb3IgT0FULCB3aGljaCB3YXMgMjIgQywgd2hpY2gg bWVhbnQgSSdkIGZseSBhdCA1ODc1IGZlZXQpDQphbmQgYXQgZGlmZmVyZW50IGFpcnNwZWVkcyB0 byBjb2xsZWN0IHRoZSBmdWVsIGZsb3cgaW5mb3JtYXRpb24uICBJIHRoZW4NCnB1dCB0aGF0IGlu dG8gYSBncmFwaCB0byBkZXRlcm1pbmUgYmVzdCByYW5nZSBhbmQgZW5kdXJhbmNlLiAgRW5naW5l IFJQTQ0Kd2FzIDI0MDAgYW5kIHRoZSBlbmdpbmUgbGVhbmVkIHRvIHBlYWsgb24gdGhlIGhvdHRl c3QgY3lsaW5kZXIgKEkNCmtub3cuLi4udGhhdCBtYXkgbm90IGJlIHRoZSBsZWFuZXN0IGN5bGlu ZGVyKS4NCg0KS25vdyBlcnJvcnMgdGhhdCBJIGNhbid0IGFjY291bnQgZm9yIHJpZ2h0IG5vdyBh cmUgc3RhdGljIGFuZA0KaW5zdHJ1bWVudGF0aW9uIGVycm9ycywgc28gdGhlIG51bWJlcnMgbWF5 IGJlIGEgbGl0dGxlIG9mZiBoZXJlIG9yDQp0aGVyZS4gQWZ0ZXIgc2VsZWN0aW5nIGEgcG93ZXIg c2V0dGluZyBhbmQgYWlyc3BlZWQsIEkgZmxldyB0aGUgYWlyc3BlZWQNCmFuZCBsb29rZWQgZm9y IGVsZXZhdGlvbiBjaGFuZ2VzLCBhbmQgdGhlbiBhZGp1c3QgdGhlIHBvd2VyIGFjY29yZGluZ2x5 Lg0KSSdkIHRoZW4gbGVhbiB0byBwZWFrLCB0aGVuIGxldCBldmVyeXRoaW5nIHN0YWJpbGl6ZSBh bmQgYWdhaW4gbWFrZSBhbnkNCnNtYWxsIGFkanVzdG1lbnRzIHRvIHRoZSBwb3dlciBzZXR0aW5n LiAgQWZ0ZXIgZ2V0dGluZyB0byB0aGF0IHN0YWdlLA0KSSdkIG5vdGUgZnVlbCBmbG93LCBJQVMs IE1QLCBhbmQgdGhlbiBkbyBhIDMgd2F5IEdQUyBydW4gdG8gZ2V0IFRBUy4gIEkNCnJhbiBhbGwg dGhlc2UgZGF0YSBwb2ludHMgb24gb25lIGZsaWdodCwgc28gdGhlIHVwcGVyIHNwZWVkcyBtYXkg YmUgb2ZmDQphIGxpdHRsZSBkdWUgdG8gYSBsb3dlciBhaXJjcmFmdCB3ZWlnaHQgZHVlIHRvIHRo ZSBnYXMgYmVpbmcgdXNlZCBkdXJpbmcNCnRoZSBmbGlnaHQuIChJIHN0YXJ0ZWQgYXQgdGhlIGxv d2VyIGFpcnNwZWVkcyBmaXJzdCkuICBJIGZsZXcgcG9pbnRzDQpiZXR3ZWVuIDkwIG1waCBJQVMg YW5kIGZ1bGwgdGhyb3R0bGUgYXQgMTAgbXBoIGludGVydmFscy4gIEl0IHR1cm5lZCBvdXQNCnRv IGJlIGEgZ29vZCBldmVuaW5nIHdpdGggYWxtb3N0IG5vIHR1cmJ1bGVuY2UgYW5kIHVuZGVyIDMg bXBoIG9mIHdpbmQNCmF0IHRoZSB0ZXN0IGFsdGl0dWRlLiAgSSB3YXMgcGxlYXNlZCB3aXRoIHRo ZSBkYXRhIEkgZ290LCBhcyBpdCBhbGwgZml0DQpwcmV0dHkgd2VsbCAgYW5kIGNhbWUgdXAgd2l0 aCBzb21lIGJlbGlldmFibGUgY3VydmVzIChpLmUuIG5vIGRhdGEgcG8hDQoNCmludHMgd2F5IG9m ZiB0aGUgZml0IGN1cnZlKS4gDQoNCkFmdGVyIGRvaW5nIHNvbWUgbnVtYmVyIGNydW5jaGluZyBh bmQgZ3JhcGhpbmcsIGl0IGxvb2tzIGxpa2UgdGhlIG1heA0KZW5kdXJhbmNlIG9mIHRoZSBhaXJw bGFuZSBjb21lcyBhdCAxMDAgbXBoIElBUy8xMTIgbXBoIFRBUyB3aXRoIGEgZnVlbA0KZmxvdyBv ZiA1LjAgR1BILiAgQXNzdW1pbmcgYSA2IGdhbCByZXNlcnZlLCB0aGF0IGxlYXZlcyAzMiBnYWxs b25zDQp1c2FibGUuICBUaGF0IGdpdmVzIGEgNi40IGhyIGVuZHVyYW5jZSAobXkgYnV0dCBjYW4n dCBzaXQgaW4gdGhlIHNlYXQNCnRoYXQgbG9uZykgYW5kIGEgNzE2IG1pbGUgcmFuZ2UsIHdoaWNo IGlzIDIyLjQgTVBHLiAgSSBzaG91bGQgbm90ZSB0aGF0DQp0aGUgZW5naW5lIHdhc24ndCB2ZXJ5 IGhhcHB5IGF0IHRoaXMgcG93ZXIgc2V0dGluZywgYXMgaXQgd291bGQgc2tpcA0KZXZlcnkgb25j ZSBpbiBhIHdoaWxlIChwcm9iYWJseSBhIGxlYW4gbWlzcykuICBBbHNvIHRoZSBmdWVsIGZsb3cg bWV0ZXINCndhcyBhIGxpdHRsZSBmbGFreSBuZWFyIHRoZXNlIHBvd2VyIHNldHRpbmdzLCBmbHVj dHVhdGluZyBiZXR3ZWVuIDQgdG8NCjYuICBJIGp1c3QgdG9vayB0aGUgYXZlcmFnZSBvZiB3aGF0 IEkgc2F3LiAgSXQgd2Fzbid0IHVudGlsIEkgd2FzDQpmbG93aW5nIGFyb3VuZCA2IEdQSCB0aGF0 IHRoZSBmbG93IG1ldGVyIHNldHRsZWQgZG93bi4NCg0KVGhlIGJlc3QgcmFuZ2UgY29tZXMgYXQg MTI1IG1waCBJQVMvIDE0OCBtcGggVEFTIHdpdGggYSBmdWVsIGZsb3cgb2YgNS41DQpHUEguIFVz aW5nIHRoZSBzYW1lIHJlc2VydmUsIEkgZ2V0IDUuOCBocnMgYW5kIGEgODU4IG1pbGUgcmFuZ2Us IHdoaWNoDQppcyAyNi44IE1QRy4gKEkgc3RpbGwgY2FuJ3Qgc2l0IGluIHRoZSBzZWF0IHRoYXQg bG9uZykuDQoNClNvIHB1c2hpbmcgaXQgdXAgYSBsaXR0bGUgdG8gOCBHUEggeWllbGRzIGEgNCBo b3VyIGVuZHVyYW5jZSAobm90DQppbmNsdWRpbmcgcmVzZXJ2ZSkgYXQgMTYwIG1waCBJQVMvIDE4 NSBUQVMgZm9yIGEgNzQwIG1pbGUgcmFuZ2UgYW5kIDIzLjENCk1QRy4NCg0KRnVsbCB0aHJvdHRs ZSBjb21lcyBvdXQgYXQgOS42IEdQSCBhbmQgMTc0IG1waCBJQVMvMjAwIFRBUyB3aXRoIGEgMy4z IGhyDQplbmR1cmFuY2UgYW5kIGEgNjYwIG1pbGUgcmFuZ2UgYW5kIGEgMjAuNiBNUEcgDQoNClRo ZSBsYXN0IHRlc3Qgd2FzIGZ1bGwgdGhyb3R0bGUvMjcwMCBycG0gYW5kIGl0IHdhcyAxMS43IEdQ SCBhbmQgMjA3DQpUQVMuICBUaGlzIHdhcyBvbmx5IG9uZSBkYXRhIHBvaW50IG9uIHRoaXMgZGF5 LCBJIG5lZWQgdG8gZG8gdGhpcw0Kc2V2ZXJhbCBtb3JlIHRpbWVzIHRvIGF2ZXJhZ2UgdGhlIHNw ZWVkcyB0byB0cnkgdG8gZ2V0IGEgbW9yZSBhY2N1cmF0ZQ0KbnVtYmVyLCBidXQgaXQncyBhIHN0 YXJ0Lg0KDQpUaGlzIGlzIGEgYWJvdXQgYW4gMTEgbXBoIHNwZWVkIGdhaW4gb3ZlciB0aGUgU2Vu c2VuaWNoIDcyRk0gZml4ZWQgcGl0Y2gNCnByb3AgSSBoYWQgb24gYmVmb3JlICh3aGljaCB3YXMg YW4gODMiIHBpdGNoKS4gIFRoZSBtYWluIGRpZmZlcmVuY2UgaXMNCnRoYXQgSSBjYW4gdXNlIGZ1 bGwgdGhyb3R0bGUgd2l0aCB0aGUgSGFydHplbGwuICBBdCA4MDAwIERBIGFuZCB0aGUNClNlbnNl bmljaCwgSSBzdGlsbCBoYWQgYW5vdGhlciAzIiBvZiBNUCBsZWZ0IHRvIGdvLCBidXQgd291bGQg YmUgYXQgdGhlDQoyNzAwIHJwbSBsaW1pdC4NCg0KQWdhaW4sIHRoaXMgd2FzIGRhdGEgdGFrZW4g b24gdGhpcyBvbmUgZGF5LCBmb3IgbXkgYWlycGxhbmUsIGFuZCBpcw0KcHJvYmFibHkgc3ViamVj dCB0byBzZXZlcmFsIGRpZmZlcmVudCBlcnJvcnMgKG15IGZseWluZyBpbmNsdWRlZCksIGJ1dA0K aXQgc2hvdWxkIGJlIGNsb3NlLiBJdCBkb2VzIHByb3ZpZGUgYW4gaW50ZXJlc3RpbmcgY29tcGFy aXNvbiBvZiBGRiB2cw0KVEFTLiAgSSdkIGxpa2UgdG8gcmVwZWF0IHRoaXMgdGVzdCBhdCBhIGhp Z2hlciBhbHRpdHVkZSBhbmQgc2VlIHNvbWUgb2YNCnRoZSBlZmZlY3RzIGFzIHdlbGwsIGJ1dCB0 aGF0J2xsIGhhdmUgdG8gd2FpdCB1bnRpbCBhbm90aGVyIGRheS4gIA0KDQpMYWlyZCANClJWLTYg MzQwIGhycyANClNvQ2FsIA0KDQo ________________________________________________________________________________
Subject: Re: GBA
Date: Sep 12, 2001
>Get out of our country. Warn all those in your religion: They will be persecuted in this country if not killed outright. You will never convince this country that Islam as a whole did not promote the terrible acts of 9-11-01. (John Helms, RV list 9/12/01) > God bless all who use this... and may GOD help ANYONE who ever flames me for > mentioning God on this list again!! > Scott (a slightly angry Christian) VanArtsdalen > RV-4 builder > So the religious wars have started, right here on the RV list. Bigotry and justice seldom go hand in hand. We are all upset by this, but spewing hatred at those who don't share your particular religious beliefs can't help. How about taking your God to a different forum. And Scott, consider yourself flamed. Terry Watson ________________________________________________________________________________
Date: Sep 12, 2001
Look on Dougs site - Worldwide wing http://www.metronet.com/~dreeves/vaf.htm They advertise there. Eric Newton - Long Beach, MS RV-6A - N57ME (final stuff) www.ericsrv6a.com -----Original Message----- From: "owner-rv-list-server(at)matronics.com" <owner-rv-list-server(at)matronics.com> on behalf of "John Furey" Subject: RV-List: Center arm rest The other day I saw a web site with a center arm rest/glove box made for RV6 but I can't remember where. Does anybody know what the site is and does anyone have any comments on this item. Thanks John Furey ________________________________________________________________________________
Subject: MN Wing RV Picnic
Date: Sep 12, 2001
Fellow Listers: The MN Wing will be hosting our 11th annual RV Pig Roast and Picnic this Saturday, Sept 15. Location is Sky Harbor Airpark in Webster, MN (N 44 31.7, W 93 19.5). All RVs are cordially invited to join us for an afternoon of good eating and RV talk. Webster is 3000' grass. Unicom at 122.9. Eating start at 1 pm. Questions? Give me a call at 715-386-1239 or cell at 651-398-1184. Doug Weiler MN Wing ________________________________________________________________________________
Subject: FW: 2 cents worth hand held GPS
Date: Sep 12, 2001
Not obsolete until it has an operating system that doesn't crash on every trip! I'm sorry, but having used various versions of Windoze (the reboot friendly operating system) daily for years, I'm not about to trust anything in my plane to any version of it. > -----Original Message----- > From: lucky macy [mailto:luckymacy(at)hotmail.com] > Sent: Tuesday, September 11, 2001 1:35 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: FW: 2 cents worth hand held GPS > > > > obsolete? not likely. Not until they have an internal gps > receiver. not > exactly convenient to have such an external antenna/receivers. > > > >From: jrdial <jrdial@hal-pc.org> > >Reply-To: rv-list(at)matronics.com > >To: "'RV - List'" > >Subject: RV-List: FW: 2 cents worth hand held GPS > >Date: Tue, 11 Sep 2001 13:17:21 -0500 > > > > > > > >The Anywhere ipac combo makes handheld GPS obsolete. $1200 > for package and > >it exceeds any GPS as a nav device plus road maps, personal > computing etc. > >Windows CE software. I am not arguing just an opinion. ( > >www.anywheremap.com) > > > > > > > > > > ________________________________________________________________________________
From: "Albert Gardner" <albert.gardner(at)worldnet.att.net>
Subject: RV-9A Cabin Heat
Date: Sep 12, 2001
Van's leave the issue of cabin heat pretty much alone. So-while I can see that the plumbing from the muff to the firewall probably should wait till I install the O-320-A1A and exhaust system-it would seem to be a good idea to put some sort of opening and a controllable door on the firewall before I finally rivet it in the fuse. I'm a small RV island in a sea of ultra lites so I don't have any examples. Can anyone offer some advice? Albert Gardner God Bless America ________________________________________________________________________________
Date: Sep 12, 2001
Albert, Dwg 19 shows the suggested location for a 2" hole for the cabin heat valve. I purchased the heat valve kit from Van's (the wedge-shaped one). The heat valve can be seen from inside the cabin in the third picture on this page: http://www.execpc.com/~cjh/brake_valve.html Chris Heitman Dousman WI RV-9A N94ME (reserved) wiring and building hangar http://www.execpc.com/~cjh/rv9a.html -----Original Message----- Van's leave the issue of cabin heat pretty much alone. ________________________________________________________________________________
Date: Sep 12, 2001
Subject: Vengeance properly directed
Interesting story, but I don't like the implications. Surely we don't want to fall to the same level as the terrorists, and start killing innocent people (what had that mullah done?). Or, are you saying that just because someone has the same religion as the terrorists does that mean that they are guilty too? While strong action is necessary, it must be seen to be clearly targeted at the guilty parties (once they are identified), and not just a blind attack on Muslims. There are a lot of Muslims in the world, most of them are probably very decent, caring people (I have several Muslim coworkers, and they are as disgusted and angry as the rest of us). The problem is the few hard-core fundamentalist Muslims who have no tolerance for any other religions. Take care, Kevin Horton > > >Andy, > >When we were loosing people left and right in Lebanon, the Soviets had one >diplomat grabbed by the PLO. > >They reacted a little differently than we do. > >They snatched a local mullah. THe cut out his tounge. Cut off his head, >hands, feet, arms legs and perhaps some other parts. Then they sent him >back. They told the locals that if their man wasn't returned within 24 hrs >they would grab every mullah they could find, their wives, children, inlaws, >goats, dogs and camels and chickens and do the same thing. > >They got their guy back. > >There is a lesson there. > >Rick Murphy ________________________________________________________________________________
Subject:
Date: Sep 12, 2001
Thread-Index: AcE7sX0JeA788kBMRnyVoRUVR0rnjQ=
Sorry guys for the un-decrypted emails, but for some reason when accessing my work email from home the messages over SSL don't get decrypted at the server. So here's my original reply... Laird, Have you done the 3-way GPS runs? I did some testing the other day and came up with 166 knots cruise at 8000 feet by the GPS (2400 RPM, 22.5", leaned to peak, 9.2-9.5GPH), on a warm (85+) degree day. Cranking the revs up to get 75% only gives me a knot or two. I have done these runs several times over the course of the past year and typically am within 2-3 knots between tests. So, my real-world cruise is 165 knots. With that being said... This is slightly below Van's published figures, and I don't have a poorly rigged or built airplane. IMO I think Van's published numbers are slightly high. Most of my local RV buddies agree. For example, the RV-8 has a faster published cruise speed than does the -4. I don't understand how the -8 can be faster with its greater frontal area and higher weight than a -4 with the same horsepower. I fly regularly with a 180 C/S -8 that is a very well built QB airframe and his cruise speed is only slightly faster than mine... it takes an extra 1/2" of manifold pressure for me to keep up with him with the same power settings. The odd thing is when we both have a passenger then it takes a lot more (1-1.5") of throttle for me to keep up with him; we're going to explore that further. A friend's RV-4 will flat-out stomp both of us with the same hardware up front. Maybe I need to turn that little set screw on the governor out a few turns ;) FWIW Bob Japundza RV-6 N244BJ O-360C/S flying 209 hours From: "Owens, Laird" <Owens(at)aerovironment.com> Subject: RV-List: Some Interesting Data (Long) "socal-rvlist" Hi all, Since I converted over to a Hartzell prop on my O-360/RV-6, I've wanted to do some good data collection. I finally got a chance to go out last evening and collect a little. (Like my boss sez...."Data is easy, GOOD data is hard"). Thought some of you might be interested. Two areas of interest to me are top speed (I want to start doing a little drag reduction work soon and need a baseline speed) and range/endurance. I'm planning on flying to the Las Cruces RV get together this weekend and it's a 600 mile flight from LA. I wanted to see if I could make it without stopping. I've always been conservative when flight planning, guessing 3.5 hrs (10 GPH with reserve) and about a 600 mile range, but I've wanted to nail down the real numbers for my airplane. So I went out and burned some gas trying to figure it out. I came back with some interesting numbers. The test was flown at 8000 feet density altitude (altimeter set to 29.92 and corrected for OAT, which was 22 C, which meant I'd fly at 5875 feet) and at different airspeeds to collect the fuel flow information. I then put that into a graph to determine best range and endurance. Engine RPM was 2400 and the engine leaned to peak on the hottest cylinder (I know....that may not be the leanest cylinder). Know errors that I can't account for right now are static and instrumentation errors, so the numbers may be a little off here or there. After selecting a power setting and airspeed, I flew the airspeed and looked for elevation changes, and then adjust the power accordingly. I'd then lean to peak, then let everything stabilize and again make any small adjustments to the power setting. After getting to that stage, I'd note fuel flow, IAS, MP, and then do a 3 way GPS run to get TAS. I ran all these data points on one flight, so the upper speeds may be off a little due to a lower aircraft weight due to the gas being used during the flight. (I started at the lower airspeeds first). I flew points between 90 mph IAS and full throttle at 10 mph intervals. It turned out to be a good evening with almost no turbulence and under 3 mph of wind at the test altitude. I was pleased with the data I got, as it all fit pretty well and came up with some believable curves (i.e. no data po! ints way off the fit curve). After doing some number crunching and graphing, it looks like the max endurance of the airplane comes at 100 mph IAS/112 mph TAS with a fuel flow of 5.0 GPH. Assuming a 6 gal reserve, that leaves 32 gallons usable. That gives a 6.4 hr endurance (my butt can't sit in the seat that long) and a 716 mile range, which is 22.4 MPG. I should note that the engine wasn't very happy at this power setting, as it would skip every once in a while (probably a lean miss). Also the fuel flow meter was a little flaky near these power settings, fluctuating between 4 to 6. I just took the average of what I saw. It wasn't until I was flowing around 6 GPH that the flow meter settled down. The best range comes at 125 mph IAS/ 148 mph TAS with a fuel flow of 5.5 GPH. Using the same reserve, I get 5.8 hrs and a 858 mile range, which is 26.8 MPG. (I still can't sit in the seat that long). So pushing it up a little to 8 GPH yields a 4 hour endurance (not including reserve) at 160 mph IAS/ 185 TAS for a 740 mile range and 23.1 MPG. Full throttle comes out at 9.6 GPH and 174 mph IAS/200 TAS with a 3.3 hr endurance and a 660 mile range and a 20.6 MPG The last test was full throttle/2700 rpm and it was 11.7 GPH and 207 TAS. This was only one data point on this day, I need to do this several more times to average the speeds to try to get a more accurate number, but it's a start. This is a about an 11 mph speed gain over the Sensenich 72FM fixed pitch prop I had on before (which was an 83" pitch). The main difference is that I can use full throttle with the Hartzell. At 8000 DA and the Sensenich, I still had another 3" of MP left to go, but would be at the 2700 rpm limit. Again, this was data taken on this one day, for my airplane, and is probably subject to several different errors (my flying included), but it should be close. It does provide an interesting comparison of FF vs TAS. I'd like to repeat this test at a higher altitude and see some of the effects as well, but that'll have to wait until another day. Laird RV-6 340 hrs SoCal Thanks! Bob Japundza RealMed Corporation www.realmed.com ________________________________________________________________________________
Date: Sep 12, 2001
Subject: Re: Vengeance properly directed
Arguing, debating and finger pointing will resolve nothing- If we want to do something, we must do this: Go back to your work, be productive and act as one People united against these actions. Our votes choose our leaders, and our taxes give them the means to do our will. Let them do their job. If they don't, we will hold them accountable. This is our best response, it is what Americans do best, and we can ALL take part. Let's stay focused Mark Phillips ________________________________________________________________________________
Date: Sep 12, 2001
Subject: Re: RV-9A Cabin Heat
--- Albert Gardner wrote: > > > Van's leave the issue of cabin heat pretty much alone. So-while I > can see > that the plumbing from the muff to the firewall probably should wait > till I > install the O-320-A1A and exhaust system-it would seem to be a good > idea to > put some sort of opening and a controllable door on the firewall You want to carefully consider the placement of the cabin heat vent. If you don't put on some means (on the cabin side) of diffusing the warm air, or re-directing it, you will get a hot foot. With something like that attached, you will need to be careful how low you place the vent lest there be interference with the rudder pedals. The controllable door to which you refer is built into the vent box from Van's. So cabin heat can be as simple as a 2-inch hole in the firewall onto which you attach the vent box. Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ==== Michael E. Thompson (Grobdriver(at)yahoo.com) Austin, TX, USA RV-6 in progress, N140RV (Reserved) EX-AX1 Sub Hunter, P-3 (B/B-TACMOD/C) Orion Aircrew, PP-G,ASEL, Motorglider Driver and Unlimited Air Race Nut! ________________________________________________________________________________
Date: Sep 12, 2001
> > Albert, > > Dwg 19 shows the suggested location for a 2" hole for the cabin heat valve. > I purchased the heat valve kit from Van's (the wedge-shaped one). The heat > valve can be seen from inside the cabin in the third picture on this page: > http://www.execpc.com/~cjh/brake_valve.html > > Chris Heitman Thats what I did too, Albert. I pointed the incoming air end toward the passenger side and put the heat muff on that side, it works well. Kevin Shannon ________________________________________________________________________________
Date: Sep 12, 2001
> 99.99% of Islamic people are completely innocent of this or any attrocity. It > is not their war and it is not to them to whom we should direct our might. We > should not retaliate against their cities and populations. Those who fail to report those who perpetrate are just as guilty. I agree with your president who said words to that same effect in last nights address to the nation. I stayed up to watch it, at 2.30 a.m. LT This is in part caused by the "civil rights mafia's" and other such organisations. For example : Anywhere in Europe you will only have "the Right" to go to the gate if you have passed security in posession of a valid boarding pass. You will pass at least one checkpoint before you reach the gate, some airports it can be more. If you fly into London from Belfast you can even be picked out by special branch after you arrive at heathrow....... Even the CNN newsreporters believe they have the "Right and Duty" to blast America's intelligence gathering methods over the airwaves, so that the whole planet knows what the americans are up to................ I was on the 110 th floor in december last year and it was one of those nights with a 50 mile vis. I will never forget the experience. Ever since I was a child I wanted to go to NY, it was a dream come true for me last year. I'm very shocked and angry about these attacks and I believe that ones and for all this should be stamped out. Stuff human rights,etc, thousands had theirs violated yesterday. Let us not forget the PanAm 103, the prime suspect was chauffeured around in a BMW 7 series in holland for his trial, while an ordinary robber gets the sh*t beaten out of him in the back of prisonvan............. WAKE UP WHILE YOU STILL CAN.............. Marcel de Ruiter Northern Ireland ________________________________________________________________________________
Date: Sep 12, 2001
"RV list"
From: Graham Singleton <grasingleton(at)avnet.co.uk>
>--> AeroElectric-List message posted by: "Paul Besing" > > >Thanks to all supporters in other countries around the world. I think it >could be so easy for people from other nations to turn their head and not >get involved. The compassion that has been shown from listers in many >countries really shows that no matter where one is from, there is always a >common bond when it comes to humanity. (at least from rational, caring, and >supportive individuals from these nations) > >Paul Besing I second that. The free world all know that the black 11th will affect the whole world. An unconsidered violent response is probably what the evil ones who perpetrated this atrocity wanted to achieve. It is to be hoped that the big guys in the military are careful and accurate when they do respond. If they punish the wrong people the results will be bad for us all. I do hope that Bob hasn't been driven away by the ill considered political remarks carelessly thrown around. That too would help the evil ones to achieve their goal which it appears is to create chaos in the free world. Graham (UK ) ________________________________________________________________________________
Date: Sep 12, 2001
Subject: Re: Some Interesting Data (Long)
Just Curious, what does this message say? AOL can't read it. In a message dated 9/12/2001 9:05:26 AM Pacific Daylight Time, Bob.Japundza(at)realmed.com writes: > > U29ycnkgZ3V5cyBmb3IgdGhlIHVuLWRlY3J5cHRlZCBlbWFpbHMsIGJ1dCBmb3Igc29tZSByZWFz > b24gd2hlbg0KYWNjZXNzaW5nIG15IHdvcmsgZW1haWwgZnJvbSBob21lIHRoZSBtZXNzYWdlcyBv > dmVyIFNTTCBkb24ndCBnZXQNCmRlY3J5cHRlZCBhdCB0aGUgc2VydmVyLiAgU28gaGVyZSdzIG15 > IG9yaWdpbmFsIHJlcGx5Li4uDQogDQogDQpMYWlyZCwNCiANCkhhdmUgeW91IGRvbmUgdGhlIDMt > d2F5IEdQUyBydW5zPyAgSSBkaWQgc29tZSB0ZXN0aW5nIHRoZSBvdGhlciBkYXkgYW5kDQpjYW1l > IHVwIHdpdGggMTY2IGtub3RzIGNydWlzZSBhdCA4MDAwIGZlZXQgYnkgdGhlIEdQUyAoMjQwMCBS > ________________________________________________________________________________
Subject: Your religious freedom
Date: Sep 12, 2001
> I am sorry for being so intolerant and preachy on this subject. Christians > aren't perfect. Christians aren't perfect? No kidding? Reference the great crusades. The point being that more people have been killed in the name of God than all other reasons put together. This whole terrorist issue is an issue of God, and not the issue we've been told it is. Muslims don't want to kill all of us because we're not Muslim. That is ridiculous. They are pissed at us because WE keep attacking THEM. We have been doing so for 50 years. The Jewish homeland was invented and unfairly planted in the middle of the Arab nations without their permission. Then, over the last 50 years the nation of Israel has aggressively expanded their lands by killing the present occupants and taking it. No other way to explain a country getting bigger when it's neighbors are not selling them the land. It's aggression..and just because most of us over here don't hear about it, doesn't mean it's not happening. Standing behind that little nation like a big brother teaching his little brother to be a bully is the USA...and THAT is why the Arabs have not blasted Israel straight off the planet for their aggression. That being said, our current terrorism is simply their only way of lashing out at a clearly dominant country that they have no means of fighting otherwise. We look down on terrorism the way the British looked down on us when we refused to fight in staggered lines firing in succession. We fought that way, because it was our only way to make a fight out of it. They are doing the same, and no I do not condone it. I'm just a United States Marine that understands when your enemy is stronger, you use Guerilla tactics, sabotage, snipers, whatever it takes. Want a reason why this has happened to us? Ask Israel, it's their fight and they are the aggressor ...and take a look at their ever expanding borders while you're at it. Oh, and I couldn't care less if you pray in public....just pull your car over first so you're not in my way while you do it. Then you can get out and roll around on the ground waiting for the Easter bunny for all I care. Bill ________________________________________________________________________________
Subject: GBA, long not rv related
Date: Sep 12, 2001
01:33:02 PM I know how you all feel. We grew up on scenes of guys rolling up their sleeves and gritting their teeth on the way to join the Marines on Dec, 8th 1941. My chance came when 246 brave Marines, Soldiers and Sailors died in a cowardly attack in Beirut. I wanted to avenge the death of a kid from my town, couldn't wait to spill Islamic blood. This was almost a decade after watching brave Marine security personnel and civilians being forced to submit to the Iranian terrorist. I guess you could say some of us have watched this needless bloodshed most of our lives. I sat there in horror, again, yesterday wondering what could be done. Unlike Pearl Harbor, there is no return address on this. It is not the work of a country but the work of a few religious zealots that did this. To single out and attack based on the belief or intent that caused yesterdays tragedy would be against everything America stands for. No I'm not a pacifist, I would love to greasepaint my face one more time and hump the "busy" in a platoon of firebreathing killers on the way to settle the score. Not gonna happen. To kill a few only strengthens the resolve of the many and increases their numbers. They are a society that places martyrdom at the highest point of human existence. We are a society that loves life, and has much more to loose. We also are wide open and availing to our world wide neighbors. To fan the flames of hate only brings it back on us. Maybe the US will get lucky and some brave kid will pull a dream mission and go zap Bin Ladin, maybe not. So what can each of us do? I must have pondered this the whole day. It finally came to me. After years of education and Christian upbringing, I find that I still derive a lot of my wisdom from Gunnery Sgt. Lott, USMC. Gunny Lott was one of those lifer Marines that for what ever reason dedicated his life to keeping other peoples smart ass kids alive in combat. He looked ancient, totally bald, weather beaten face, walked with a stoup from many back injuries and too many hard miles, he was 32 years old. He kept his boots shined on our asses, and our ears ringing with a tapestry of profanity that even Shakespeare would envy. He taught us a lot about life. To this day, I've never seen him be wrong, and he never lied to us. So in my heart I asked Gunny Lott what can I do? I know what he would have said. "Ya know what you can do boy? Ya get on your gear, put on your pack and keep marching. That's what you can do" So what does that mean to those of you that did not get to "sit" at the feet of the master? It means you can refuse to let cowards change you. It means you keep on being Americans. You maintain your belief that the person you meet on the street is basically a good person even though he looks different than you. You uphold the "American Way" which is the very source of their hatred. We continue on enforcing peace among oppressed people at the cost of our own blood. We continue to develop new ideas and medicines that will eventually benefit the very people that seek to destroy us. We continue to bank roll the development of less fortunate nations with the unspoken realization that we will never see one dollar returned. We continue to be America! And when it happens again, and it will, we bury our dead, honor their memories, put on our packs and march. Semper Fi Eric Henson (my apologies to listers outside America that could do without my patriotic fervor) "Van Artsdalen, Scott" (at)matronics.com on 09/12/2001 10:17:41 AM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RE: RV-List: GBA So, it's okay to talk about God during disasters but not normally?? I can remember within the last year a lister being blasted for posting off-topic material that included relieous beliefs. Now we all have religeon all of a sudden? Is this horrible, horrible event what it takes? Yes, GOD BLESS AMERICA. God bless all who use this... and may GOD help ANYONE who ever flames me for mentioning God on this list again!! And Tom Gummo, I'm with you! I think the US needs to take swift, decisive, and OVERWHELMING action. I sincerely hope that our President has the balls to do what is necessary. -- Scott (a slightly angry Christian) VanArtsdalen RV-4 builder -----Original Message----- From: Jim Jewell [mailto:jjewell(at)telus.net] Sent: Tuesday, September 11, 2001 8:17 PM Subject: RV-List: GBA This morning I awoke and went first to this list as has become my habit for four years plus. The very first message that came to the screen was; "God Bless America" My thoughts where not thoughts born of patience or understanding as I hit the delete button. As it happens I finished editing the email and went next to the television. The next thing I saw was an obviously Moslem individual being interviewed. The translator was barely able to speak English and I found it very hard to make sense of what the interview was about. I changed channels and saw what at first I believed to be a promotion for another in a long line of thriller movies. The reality of what I was actually seeing clawed and scraped away at my inability to perceive. The crescendo of horror continued on. the painful tearing and scraping went on and continues still. Please whom ever sent that blessing that began this day for me please accept my apology for being so jaded as to turn away from your statement born of pain that I to now share. If I am changed this much by such a reality as this day has brought, I can not imagine how to find any better words than yours to express this anguish that has befallen all of us. God bless us all. ________________________________________________________________________________
Date: Sep 12, 2001
Subject: [Fwd: [Fwd: interesting quote from nostradamus (1654)]]
Arthur Glaser wrote: > > > EarlStark(at)aol.com wrote: > >> Subject: Here is an interesting quote from nostradamus (1654) >> >> "In the year of the new century and nine months, From the sky will >> come a >> great King of Terror... The sky will burn at forty-five degrees. >> Fire >> approaches the great new city... In the city of york there will be a >> great >> collapse, >> 2 twin brothers torn apart by chaos while the fortress falls the >> great leader >> will succumb the third big war will begin when the big city is >> burning" - >> NOSTRADAMUS 1654 >> >> He said this will be bigger than the previous two. >> 2001 is the first year of the new century and this is the 9th month. >> New York >> is located at the 41st degree Latitude. > ________________________________________________________________________________
Date: Sep 12, 2001
Subject: Oregon Air Fair 2001 still on.
The Oregon Air Fair at the Albany Oregon Airport and Linn Co.. Expo center is still a go this week end. Sept. 15 and 16. Van's will be there. Fly or drive in. If you can give some of you're time, volunteer to help, just sign in at the volunteer room. Jerry Wilken jwewilken(at)aol.com GOD Bless the USA!!!!!!! ________________________________________________________________________________
From: "Michael Sices" <michaelsices(at)hotmail.com>
Subject: Re: Your religious freedom
Date: Sep 12, 2001
Too hard to let this one go... >We look down on terrorism the way the British looked down on us when >we >refused to fight in staggered lines firing in succession. We >fought that >way, because it was our only way to make a fight out of >it. The revolutionaries in this county never used terrorism to gain independence. You comparison of terrorism to any other modern war practice, like gurilla tactics, shows a clear lack of moralilty. You and arab radicals' willingness to kill innocent women and children to achieve an end is what is purely evil about terrorism. I don't care if its the only means to an end or not. >The Jewish homeland was invented and unfairly planted in the middle of >the >Arab nations without their permission. Check your history books, this was land controlled and goverened by Great Britain prior to WWII... NOT by any arab nation. >Then, over the last 50 years the nation of Israel has aggressively > >expanded their lands by killing the presentoccupants and taking it. That was during the war in 1950 in which arab countries attacked Isreal and got their rear-ends kicked by Isreal defendeding itself. >Standing behind that little nation like a big brother teaching his >little >brother to be a bully is the USA Maybe you would prefer to live under Taliban rule - it sounds like you would fit right in... Mike Sices RV8 QB >From: "Bill Shook" <billshook(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Your religious freedom >Date: Wed, 12 Sep 2001 17:08:30 -0400 > > > > I am sorry for being so intolerant and preachy on this subject. >Christians > > aren't perfect. > > >Christians aren't perfect? No kidding? Reference the great crusades. The >point being that more people have been killed in the name of God than all >other reasons put together. This whole terrorist issue is an issue of God, >and not the issue we've been told it is. Muslims don't want to kill all of >us because we're not Muslim. That is ridiculous. They are pissed at us >because WE keep attacking THEM. We have been doing so for 50 years. The >Jewish homeland was invented and unfairly planted in the middle of the Arab >nations without their permission. Then, over the last 50 years the nation >of Israel has aggressively expanded their lands by killing the present >occupants and taking it. No other way to explain a country getting bigger >when it's neighbors are not selling them the land. It's aggression..and >just because most of us over here don't hear about it, doesn't mean it's >not >happening. Standing behind that little nation like a big brother teaching >his little brother to be a bully is the USA...and THAT is why the Arabs >have >not blasted Israel straight off the planet for their aggression. That >being >said, our current terrorism is simply their only way of lashing out at a >clearly dominant country that they have no means of fighting otherwise. We >look down on terrorism the way the British looked down on us when we >refused >to fight in staggered lines firing in succession. We fought that way, >because it was our only way to make a fight out of it. They are doing the >same, and no I do not condone it. I'm just a United States Marine that >understands when your enemy is stronger, you use Guerilla tactics, >sabotage, >snipers, whatever it takes. Want a reason why this has happened to us? >Ask >Israel, it's their fight and they are the aggressor ...and take a look at >their ever expanding borders while you're at it. > >Oh, and I couldn't care less if you pray in public....just pull your car >over first so you're not in my way while you do it. Then you can get out >and roll around on the ground waiting for the Easter bunny for all I care. > >Bill > > ________________________________________________________________________________
Date: Sep 12, 2001
--- Bill Shook wrote: > > > > I am sorry for being so intolerant and preachy on > this subject. > Christians > > aren't perfect. > > PS Please be carefull when you pull over I may be peddling out to the airport. Joe > > > > Oh, and I couldn't care less if you pray in > public....just pull your car > over first so you're not in my way while you do it. > Then you can get out > and roll around on the ground waiting for the Easter > bunny for all I care. > > Bill > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Date: Sep 12, 2001
>That was during the war in 1950s in which arab countries attacked >Isreal >andgot their rear-ends kicked by Isreal defendeding itself. Actually during both the 1956 and 1967 (6 day) wars - in both cases arab agressors were defeated with the result of Isreal controling gaza and other territories previously controled by Egypt (which later signed a peace treaty with Isreal). I know this is not nearly the place for this discussion ... just coult not resist the last post in light of current events. >From: "Michael Sices" <michaelsices(at)hotmail.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Your religious freedom >Date: Wed, 12 Sep 2001 16:40:59 -0500 > > >Too hard to let this one go... > > > >We look down on terrorism the way the British looked down on us when >we > >refused to fight in staggered lines firing in succession. We >fought >that > >way, because it was our only way to make a fight out of >it. > >The revolutionaries in this county never used terrorism to gain >independence. You comparison of terrorism to any other modern war >practice, >like gurilla tactics, shows a clear lack of moralilty. You and arab >radicals' willingness to kill innocent women and children to achieve an end >is what is purely evil about terrorism. I don't care if its the only means >to an end or not. > > >The Jewish homeland was invented and unfairly planted in the middle of > >the > >Arab nations without their permission. > >Check your history books, this was land controlled and goverened by Great >Britain prior to WWII... NOT by any arab nation. > > >Then, over the last 50 years the nation of Israel has aggressively > > >expanded their lands by killing the presentoccupants and taking it. > >That was during the war in 1950 in which arab countries attacked Isreal and >got their rear-ends kicked by Isreal defendeding itself. > > >Standing behind that little nation like a big brother teaching his > >little > >brother to be a bully is the USA > >Maybe you would prefer to live under Taliban rule - it sounds like you >would >fit right in... > >Mike Sices >RV8 QB > > > >From: "Bill Shook" <billshook(at)earthlink.net> > >Reply-To: rv-list(at)matronics.com > >To: > >Subject: RV-List: Your religious freedom > >Date: Wed, 12 Sep 2001 17:08:30 -0400 > > > > > > > I am sorry for being so intolerant and preachy on this subject. > >Christians > > > aren't perfect. > > > > > >Christians aren't perfect? No kidding? Reference the great crusades. >The > >point being that more people have been killed in the name of God than all > >other reasons put together. This whole terrorist issue is an issue of >God, > >and not the issue we've been told it is. Muslims don't want to kill all >of > >us because we're not Muslim. That is ridiculous. They are pissed at us > >because WE keep attacking THEM. We have been doing so for 50 years. The > >Jewish homeland was invented and unfairly planted in the middle of the >Arab > >nations without their permission. Then, over the last 50 years the >nation > >of Israel has aggressively expanded their lands by killing the present > >occupants and taking it. No other way to explain a country getting >bigger > >when it's neighbors are not selling them the land. It's aggression..and > >just because most of us over here don't hear about it, doesn't mean it's > >not > >happening. Standing behind that little nation like a big brother >teaching > >his little brother to be a bully is the USA...and THAT is why the Arabs > >have > >not blasted Israel straight off the planet for their aggression. That > >being > >said, our current terrorism is simply their only way of lashing out at a > >clearly dominant country that they have no means of fighting otherwise. >We > >look down on terrorism the way the British looked down on us when we > >refused > >to fight in staggered lines firing in succession. We fought that way, > >because it was our only way to make a fight out of it. They are doing >the > >same, and no I do not condone it. I'm just a United States Marine that > >understands when your enemy is stronger, you use Guerilla tactics, > >sabotage, > >snipers, whatever it takes. Want a reason why this has happened to us? > >Ask
September 07, 2001 - September 12, 2001
RV-Archive.digest.vol-ll
