RV-Archive.digest.vol-lo
September 21, 2001 - September 28, 2001
       thought I would fly-in a borrowed plane. Any chance I could get ride in
       a -6 from someone.  I have never ridden in an RV and would love the
       chance to obtain an RV grin.
       Gary Coonan
       Rockvale, TN
       RV-7 >>
      Yep,  I'll be there and will be glad to give a ride or two.  Just look for
      the white/yellow/checkerboard Rv-6 and ask the owner...
      Kyle Boatright
      0-320/Aymar Demuth RV-6 Slider
      Kennesaw, GA
      http://www.angelfire.com/my/rv6
Date: Sep 21, 2001
Subject: Re: proseal on canopies
In a message dated 9/21/01 1:31:35 PM Eastern Daylight Time, rv8a(at)lycos.com writes: << I would love to use Proseal to seal up the edges left between the canopy and the fairing but I don't have the slightest idea how to get a bead of it small enough to insert between these two. I need a bead about 1/8 to 1/16 inch in diameter. How did others do this and are there cake decorating tools involved :-) - Jim Andrews RV-8A ( flying again, thank God! ) >> I masked the plexi off about 1/32 (Ok, I'm not that good with tape, but I tried) from the various skirts, etc. that I wanted to seal. Then, I used a popsicle stick to squeegie a small bead of proseal into the gaps. To remove excess proseal, I used MEK on the skirts, and other non-plexi surfaces. Finally, I removed the masking tape before the proseal hardened, leaving a clean line. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Subject: Aileron Gap Seal Installation
Date: Sep 21, 2001
Mike I made a small bar 1/2" thick 1"wide by 2"long just for #3 rivets in hard to get at places. It Doesn't take much to set a 3. Your fingers may go numb after a few but we all know these are all built with blood sweat and tears.... Steve Rv-6a Can anyone out there tell me if they used the AN3-3 rivets to install the aileron gap seal to the top wing skin on a -6? If so, How did you install those rivets? The plans call out for 3-3 rivets but I can't for the live of me see how to install those rivets without removing the top skin. Since my top skin is already installed and riveted on, that option is out of the question. Mike Nellis - http://bmnellis.com Plainfield, IL RV6 N699BM (res) Building Flaps Stinson 108-2 N9666K ________________________________________________________________________________
Date: Sep 21, 2001
Subject: Re: Flight Traning Restored
THEY JUST DON'T GET IT DO THEY!!! Here at the Venice FL airport where two of the pilots were trained, that did the deed which threatens my freedom to fly etc, the govt jumps right back into business as usual. The student population is 60 percent other then North America. Oh well they're our wonderful leaders that are yet to be responsible for anything. Joe RV6A Heard it's suppose to get dark tonight. --- Paul Besing wrote: > > > One step closer, folks. See Below. > > Paul Besing > RV-6A N197AB Arizona > http://www.lacodeworks.com/besing > Flying > Kitlog Pro Builder's Log Software > http://www.kitlog.com > > FAA approves resumption of most flight training > activities > 9/21/2001 7:00:23 PM - The FAA has just released a > notam permitting the > resumption of most flight training activities. The > notam, which is effective > at 0000Z (8 p.m. ET) tonight, allows VFR flight > training in non-turbojet > aircraft and gliders (weighing less than 12,500 > pounds) outside of enhanced > Class B airspace. > > Within enhanced Class B airspace, with the exception > of the Boston enhanced > Class B and the Washington and New York exclusion > areas (see TFR), VFR > flight training in single- and multi-engine > piston-powered aircraft under > 6,000 pounds is permitted. (Almost all single-engine > and light twin piston > powered aircraft are less than 6,000). > > VFR flight training is still prohibited in the > Boston enhanced Class B and > in the Washington and New York exclusionary areas. > (See AOPA's > plain-language guidance on notams.) > > "We're absolutely delighted that the majority of the > nation's flight > training operations can get back in the air this > weekend," said AOPA > President Phil Boyer. "This is fantastic news for a > segment of our industry > that was suffering greatly. > > "AOPA is also pleased to have played a role in > crafting the solution to > restoring flight training in the Class B areas. AOPA > earlier this week gave > FAA a compilation of the number and weights of GA > aircraft inside Class B > airspace. The association suggested that a temporary > 6,000-pound weight > limit could be imposed to answer security concerns > near major metropolitan > areas." > > Conspicuously missing from this good news is > permission for basic, > non-training VFR flight in enhanced Class B airspace > > Boyer stated, "This is bizarre, and we expected VFR > operations would be > approved concurrent with flight training." In > raising this issue with the > FAA, it seems there is the perception of a greater > element of control with f > light training than non-training operations. The > agency has assured AOPA > they have a clear set of proposals to restore most > VFR operations in > enhanced Class B airspace, but they now must be > approved at a higher level > before they can proceed. > > In addition, Boyer pressed for the relocation of > aircraft from the > exclusionary Washington and New York areas. He was > told that work on this is > progressing, with relief expected very shortly. > > Boyer assured members that, "FAA isn't taking the > weekend off on these > remaining issues, and neither is AOPA staff. We'll > be working to assist FAA > in any manner to rapidly close the loopholes that > are so critical to > expanding Class B VFR operations and the movement of > aircraft in the two > most affected urban areas." > > > > http://www.matronics.com/unsubscribe > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Date: Sep 21, 2001
Subject: Navaid
I know I'm wearing this down a bit but I have to ask again. Has anyone out there installed the navaid in the RV6 or A under passenger side, attached to the the passenger stick with positive results (with no elevator disturbance) and flew the ACFT. Has anyone out there attached it to the manual trim control and if so what problems associated with the inability to manually trim??? Any pioneer response would be deeply appreciated. Joe RV6A Just love the right to pursue happiness. ________________________________________________________________________________
Subject: Fw: Another telephone fraud
Date: Sep 21, 2001
Not RV related but important nonetheless. Vince Welch ----- Original Message ----- From: "Merle Miller" <mmiller(at)mccarl.com> ; ; ; Sent: Thursday, September 20, 2001 10:05 AM Subject: FW: Another telephone fraud -----Original Message----- From: Becky Embaugh Sent: Thursday, September 20, 2001 8:50 AM Subject: FW: Another telephone fraud > THIS IS VERY IMPORTANT INFORMATION PROVIDED BY AT&T > > > > DON'T EVER DIAL AREA CODE 809. > > This one is being distributed all over the US. This is pretty > > scary - especially given the way they try to get you to > > call. Be sure you read this & pass it on to all your friends and family > > so they don't get scammed! > > > > MAJOR SCAM: > > Don't respond to Emails, phone calls, or web pages which > > tell you to call an "809" Phone Number. This is a very important issue > of > Scam > > busters because it alerts you to a scam that is spreading *extremely* > quickly > > can easily cost you $24,100 or more, and is difficult to avoid unless > you > > are aware of it. > > > > We'd like to thank Verizon for bringing this scam to our > > attention. This scam has also been identified by the National Fraud > > Information Center and is costing victims a lot of money. There are lots > > of > > different permutations of this scam. > > > > HERE'S HOW IT WORKS: > > You will receive a message on your answering machine or > > your pager, which asks you to call a number beginning with area code > 809. > > The reason you're asked to call varies. It can be to receive information > > > about a family member who has been ill, to tell you someone has been > arrested, > > died, to let you know you have won a wonderful prize, etc. In each case, > > > you are told to call the 809 number right away. Since there are so many > new > > area codes these days, people unknowingly return these calls. If you > call > from > > the US, you will apparently be charged $2,425 per-minute. Or, you'll get > > a > > long recorded message. The point is, they will try to keep you on the > > phone as long as possible to increase the charges. Unfortunately, when > you > > get your phone bill, you'll often be charged more than $24,100.00. > > > > WHY IT WORKS: > > The 809 area code is located in the British Virgin Islands (The > Bahamas). > > The 809 area code can be used as a "pay-per-call" number, > > similar to 900 numbers in the US. Since 809 is not in the US, it is not > > covered by US regulations of 900 numbers, which require that you be > > notified and warned of charges and rates involved when you call a > > "pay-per-call" > > number. There is also no requirement that the company provide a time > period > > during which you may terminate the call without being charged. Further, > > whereas many US homes that have 900 number blocking to avoid these kinds > > of > > charges, do not work in preventing calls to the 809 area code. We > recommend > > that > > no matter how you get the message, if you are asked to call a number > with > an > > 809 area code, that you don't recognize just disregard the message. Be > > wary of email or calls asking you to call an 809 area code number. It's > > important to prevent becoming a victim of this scam, since trying to > fight the > > charges afterwards can become a real nightmare. That's because you did > > actually make the call. > > > > If you complain, both your local phone company and your > > long distance carrier will not want to get involved and will most likely > > tell > > you that they are simply providing the billing for the foreign company. > > You'll end up dealing with a foreign company that argues they have done > > nothing > > wrong. > > > > Please forward this entire message to your friends, family > > and colleagues to help them become aware of this scam. > > > > Sandi Van Handel > > AT&T Field Service Manager > > (920) 687-904 > > Additional information can be obtained from the following > > AT&T Web Site > > http://www.att.com/fraud/home.html#thre/ > <http://www.att.com/fraud/home.html> > > > > AT&T Fraud Education: At Home ! > > > Sincerely yours, > > Marti Wash > HDR Engineering, Inc. > I was taught that the way of progress is neither swift nor easy. -- Marie > Curie > > ________________________________________________________________________________
Date: Sep 21, 2001
From: Charlie and Tupper England <cengland(at)netdoor.com>
joe wiza wrote: > > > THEY JUST DON'T GET IT DO THEY!!! Here at the Venice > FL airport where two of the pilots were trained, that > did the deed which threatens my freedom to fly etc, > the govt jumps right back into business as usual. The > student population is 60 percent other then North > America. Oh well they're our wonderful leaders that > are yet to be responsible for anything. > Joe > RV6A Heard it's suppose to get dark tonight. > > --- Paul Besing wrote: > > I'd be willing to bet that 60% of the student pilot population nationwide is other than North American. I for one am glad to see our freedom returning quickly. Disruption of our way of life was the purpose of the attacks. Bigotry against anyone who isn't just like you is playing right into their hands. Terrorists took the lives of thousands of people. The National Security Council took your freedom to fly. We would do well to remember that times of crisis do not necessarily perfect our leaders' judgement. I was pleasantly surprised at our president's call to focus our anger where it belongs: on a relatively small group of criminally insane individuals. I hope you will re-evaluate your feelings about the situation. Charlie ________________________________________________________________________________
Subject: Re: Navaid
Date: Sep 21, 2001
> > I know I'm wearing this down a bit but I have to ask > again. > Has anyone out there installed the navaid in the > RV6 or A under passenger side, attached to the the > passenger stick with positive results (with no > elevator disturbance) and flew the ACFT. > Yes, for many hours. It works just fine. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Subject: wire routing
Date: Sep 21, 2001
For the RV6--where exactly are you routing the wiring from the panel to get between the wing spars for flaps, lights, wing wiring, elect. trim, etc.? Vans wiring kit shows down f602 along horizontal support, down and across front of wing spar. Any other alternatives? Under battery box? Along floor after descending f602? Dave Ford RV6 wiring ________________________________________________________________________________
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
Subject: Re: Aileron Gap Seal Installation
Date: Sep 21, 2001
Mike - You might be able to use the long back rivet set and peel the lower part of the gap seal aft about 1/2" so that you can get to that row of rivets. Back rivet the row and it will turn out well. The only other option is to use blind CS rivets. You can hide them later with a little Bondo. Good luck on your project. Doug Murray RV-6 Just about ready to fly. ----- Original Message ----- From: Mike Nellis <mnellis(at)peoplepc.com> Sent: Friday, September 21, 2001 9:13 AM Subject: RV-List: Aileron Gap Seal Installation > > Can anyone out there tell me if they used the AN3-3 rivets to install > the aileron gap seal to the top wing skin on a -6? If so, How did you > install those rivets? The plans call out for 3-3 rivets but I can't for > the live of me see how to install those rivets without removing the top > skin. Since my top skin is already installed and riveted on, that > option is out of the question. > > Mike Nellis - http://bmnellis.com > Plainfield, IL > RV6 N699BM (res) Building Flaps > Stinson 108-2 N9666K > > ________________________________________________________________________________
Subject: Re: wire routing
Date: Sep 21, 2001
Dave - I brought the wiring back from under the instrument panel edges and drilled a hole at the top of the vertical channel over the spar. The wires run down inside the channel until they get to the spar. I then routed them under the floor pans to a conduit that runs laterally across the aircraft through the seat ribs. My wiring from the contol sticks comes into this lateral conduit- I just melted a hole in the side of the conduit where wires need to enter or exit. A gob of silicone secures the wires from chaffing on the side of the exit hole. Hope this helps, Doug Murray RV-6 almost ready to fly. ----- Original Message ----- From: dave ford <dford(at)michweb.net> Sent: Friday, September 21, 2001 11:36 PM Subject: RV-List: wire routing > > For the RV6--where exactly are you routing the wiring from the panel to > get between the wing spars for flaps, lights, wing wiring, elect. trim, > etc.? Vans wiring kit shows down f602 along horizontal support, down > and across front of wing spar. Any other alternatives? Under battery > box? Along floor after descending f602? > > Dave Ford > RV6 wiring > > ________________________________________________________________________________
Date: Sep 21, 2001
So let's if I understand your point here. A group of minority extremists don't like freedom and democracy so they attack it. They succeed in their intial attack and all of a sudden Pres. Lincoln was wrong, it seems that not all men are created equal after all becuase this group of extremists say so, and just to press the point home we're going to help them in their attack on freedom by ristricting the rights of ALL foriegn nationals. Let's see. I first came to this country 16 years ago on temporary duty as a NATO forces member, based at Lowry AFB where I met my future wife. I emigrated and settled here at the soonest possible moment. Subsequently I've worked in the defense industry and personally developed new electronics technology that is no doubt on it's way to the gulf area right now and will help the US in this fight. Living here, I've volunteered my time in Search and Rescue both local and FEMA. Trained and spent time as a volunteer emergency medical worker, helped the Red Cross and can attribute a number of cases where I've saved the lives of American Citizens. The list goes on and no I'm not looking for recognition or a medal. I am however, after 9 days of this, thouroughly appauled at the complete lack of respect that perfectly honest, law abiding and loyal foreign nationals seem to be experiencing these days. Appauled at the fact that all foreign nationals, no matter the race, are all of a sudden suspected terrorists. Needless to say I'm extrememly offended. Clearly your outburst seems to indicate that you feel that after so many years of dedicated loyal service to this count I have no rights. That, now that the long awaited opportunity for me to learn to fly has presented itself, I should be prevented from doing so becuase of some screwed up moron and his team of bandits. And yet by the same token I suspect that you don't feel that you should loose your right to fly even though a minority of US citizens blew up a federal building in Oklahoma city, or young US citizens blow up schools. I suggest to you that we're not all terrorists and in general the majority of the people on this planet are peacefull and caring people who stand loyal to the USA. Don't let the terrorist win by taking away these majorities freedoms. Oh, if you're wondering, I'm from that country that Pres. Buch called "no truer friend" in his speech last evening. As such I have suffered personal losses to terrorist attacks over the years, from several factions and I take terrorism very seriously. Do you still think I deserve to loose my rights while I'm here defending yours? Oh, and btw, something for you to ponder while you sit at home seething over us "other than north americans"; have you considered the fact that this country is what it is because of such "others". Go back far enough, we're all foreign. Deeply insulted. Ted joe wiza wrote: > > THEY JUST DON'T GET IT DO THEY!!! Here at the Venice > FL airport where two of the pilots were trained, that > did the deed which threatens my freedom to fly etc, > the govt jumps right back into business as usual. The > student population is 60 percent other then North > America. Oh well they're our wonderful leaders that > are yet to be responsible for anything. > Joe > RV6A Heard it's suppose to get dark tonight. > > --- Paul Besing wrote: > > > > > > One step closer, folks. See Below. > > > > Paul Besing > > RV-6A N197AB Arizona > > http://www.lacodeworks.com/besing > > Flying > > Kitlog Pro Builder's Log Software > > http://www.kitlog.com > > > > FAA approves resumption of most flight training > > activities > > 9/21/2001 7:00:23 PM - The FAA has just released a > > notam permitting the > > resumption of most flight training activities. The > > notam, which is effective > > at 0000Z (8 p.m. ET) tonight, allows VFR flight > > training in non-turbojet > > aircraft and gliders (weighing less than 12,500 > > pounds) outside of enhanced > > Class B airspace. > > > > Within enhanced Class B airspace, with the exception > > of the Boston enhanced > > Class B and the Washington and New York exclusion > > areas (see TFR), VFR > > flight training in single- and multi-engine > > piston-powered aircraft under > > 6,000 pounds is permitted. (Almost all single-engine > > and light twin piston > > powered aircraft are less than 6,000). > > > > VFR flight training is still prohibited in the > > Boston enhanced Class B and > > in the Washington and New York exclusionary areas. > > (See AOPA's > > plain-language guidance on notams.) > > > > "We're absolutely delighted that the majority of the > > nation's flight > > training operations can get back in the air this > > weekend," said AOPA > > President Phil Boyer. "This is fantastic news for a > > segment of our industry > > that was suffering greatly. > > > > "AOPA is also pleased to have played a role in > > crafting the solution to > > restoring flight training in the Class B areas. AOPA > > earlier this week gave > > FAA a compilation of the number and weights of GA > > aircraft inside Class B > > airspace. The association suggested that a temporary > > 6,000-pound weight > > limit could be imposed to answer security concerns > > near major metropolitan > > areas." > > > > Conspicuously missing from this good news is > > permission for basic, > > non-training VFR flight in enhanced Class B airspace > > > > Boyer stated, "This is bizarre, and we expected VFR > > operations would be > > approved concurrent with flight training." In > > raising this issue with the > > FAA, it seems there is the perception of a greater > > element of control with f > > light training than non-training operations. The > > agency has assured AOPA > > they have a clear set of proposals to restore most > > VFR operations in > > enhanced Class B airspace, but they now must be > > approved at a higher level > > before they can proceed. > > > > In addition, Boyer pressed for the relocation of > > aircraft from the > > exclusionary Washington and New York areas. He was > > told that work on this is > > progressing, with relief expected very shortly. > > > > Boyer assured members that, "FAA isn't taking the > > weekend off on these > > remaining issues, and neither is AOPA staff. We'll > > be working to assist FAA > > in any manner to rapidly close the loopholes that > > are so critical to > > expanding Class B VFR operations and the movement of > > aircraft in the two > > most affected urban areas." > > > > > > > > http://www.matronics.com/unsubscribe > > > > > > > > through > > > > http://www.matronics.com/archives > > http://www.matronics.com/emaillists > > > > Matronics! > > > > > > > > > > > > -- ideard 'Ted' Cross (N0IAK & G0HHY) n0iak(at)qsl.net n0iak(at)amsat.org n0iak(at)mttop.org ICQ: 16040894 N293TC (reserved) RV9A - Wings ________________________________________________________________________________
Subject: Re: Navaid
Date: Sep 21, 2001
> I know I'm wearing this down a bit but I have to ask > again. > Has anyone out there installed the navaid in the > RV6 or A under passenger side, attached to the the > passenger stick with positive results (with no > elevator disturbance) and flew the ACFT. Yes. You have to be fairly precise to make sure you get full travel on the servo with no fore/aft motion, but it works great. Mine's been flying for about 200 hours. > Has anyone out there attached it to the manual trim > control and if so what problems associated with the > inability to manually trim??? Any pioneer response > would be deeply appreciated. I don't think that would work very well. The manual aileron trim is not a direct coupling and with the quick seek time of the Navaid I would imagine the thing would "hunt" like crazy. Ed Bundy - RV6A N427EM 400+ hours 160hp 0320 w/Sensenich 70x78 Eagle, ID ebundy(at)velocitus.net ________________________________________________________________________________
Date: Sep 21, 2001
Dave, I ran mine beside the battery box, in a conduit beside the floor stiffener up under the fuel valve and over the center of the spar. That way I was able to avoid going through the spar web and it allowed me to complete the electrical before the wings were installed. Also, should the wings ever have to be removed the wiring won't be in the way. Dave - -6 still grounded in LA dave ford wrote: > > For the RV6--where exactly are you routing the wiring from the panel to > get between the wing spars for flaps, lights, wing wiring, elect. trim, > etc.? Vans wiring kit shows down f602 along horizontal support, down > and across front of wing spar. Any other alternatives? Under battery > box? Along floor after descending f602? > > Dave Ford > RV6 wiring > > ________________________________________________________________________________
Subject: Re: Paint is = done
Date: Sep 21, 2001
----- Original Message ----- From: Don Jordan <dons6a(at)juno.com> Sent: Friday, September 21, 2001 2:53 PM Subject: RV-List: Paint is = done > > I finished the paint last night. Don; Don't feel like you're alone. I'm doing all my own painting, and have taken three weeks to paint my empennage, flaps and ailerons working 6 -8 hours a day seven days a week. Just primed the right wing today, will shoot the color tomorrow. Takes me 3 - 4 days to prep a wing, but that includes fitting the wing tips and putting in all the nutplates in the wing roots. Probably won't finish the left wing and fuselage for another two weeks. A lot more work than I ever anticipated. Mike Robbins RV8Q 80591 N88MJ paint ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: Navaid
In a message dated 9/21/01 6:09:31 PM Pacific Daylight Time, jwiza1(at)yahoo.com writes: << Has anyone out there installed the Navaid in the RV6 or A under passenger side, attached to the passenger stick with positive results (with no elevator disturbance) and flew the ACFT. >> Yes, and it works perfect. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
, , "Carlson, Bob" , , , , , , , , "Wienceks Mark, Sue" <2wienceks(at)home.com>
Subject: Fw: Flight Announcement
Date: Sep 21, 2001
Son-in law Sean Clark was the First Officer on this 777 flight!!!! Dennis Flamini Tailwind N564DF ----- Original Message ----- From: "William Costello" <wmcenterprises(at)earthlink.net> Sent: Friday, September 21, 2001 7:46 AM Subject: RV-List: Fw: Flight Announcement > > > ----- Original Message ----- > From: "Bryant_Steve" <Bryant_Steve(at)xmail.asd.k12.ak.us> > To: "'swpc'" > Sent: Thursday, September 20, 2001 12:30 PM > Subject: SWPC: Flight Announcement > > > > As we try to resume a normal life style, this story > > may help and reassure. > > ----- > > Aboard Flight 564 > > by Peter Hannaford > > > > As it was at most U.S. airports, last Saturday was > > the first near-normal day at Denver International since the terrorist > > attacks. > > > > On United's Flight 564 > > > > the door had just been locked and the plane was > > about to pull out of the gate when the captain came on the public address > > system. > > > > "I want to thank you brave folks for coming out > > today. We don't have any new instructions from the federal government, so > > from now on we're on our own." > > > > The passengers listened in total silence. > > > > He explained that airport security measures had > > pretty much solved the problem of firearms being carried > > aboard, but not weapons of the type the terrorists apparently used, > plastic > > knives or those fashioned from wood or ceramics. > > > > "Sometimes a potential hijacker will announce that > > he has a bomb. There are no bombs on this aircraft and if someone were to > > get up and make that claim, don't believe him. > > > > "If someone were to stand up,brandish something such > > as a plastic knife and say 'This is a hijacking' or words to that effect > > here is what you should do: > > Every one of you should stand up and immediately > > throw things at that person? pillows, books, magazines, eyeglasses, shoes > > ?anything that will throw him off balance and distract his attention. If > he > > has a confederate or two, do the same with them. > > Most important: get a blanket over him, then wrestle > > him to floor and keep him there. We'll land the plane at > > the nearest airport and the authorities will take it from there." > > > > "Remember, there will be one of him and maybe a few > > confederates, but there are 200 of you. You can overwhelm them. > > > > "The Declaration of Independence says 'We, the > > people' and that's just what it is when we're up in the air: we, the > people, > > vs. would-be terrorists. I don't think we are going to have any such > problem > > today or tomorrow or for a while, but some time down the road, it is going > > to happen again and I want you to know what to do. > > > > "Now, since we're a family for the next few hours, > > I'll ask you to turn to the person next to you, introduce yourself, tell > > them a little about yourself and ask them to do the same." > > > > The end of this remarkable speech brought sustained > > clapping from the passengers. He had put the matter in perspective. If > > only the passengers on those ill-fated flights last Tuesday had been given > > the same talk, I thought, they might be alive today. One group on United > > Flight 93, which crashed in a Pennsylvania field, apparently rushed the > > hijackers in an attempt to wrest control from them. While they perished, > > they succeeded in preventing the terrorist from attacking his intended > goal, > > possibly the White House or the Capitol. > > > > Procedures for dealing with hijackers were conceived > > in a time when the hijackers were usually seeking the release of jailed > > comrades or a large amount of money. Mass murder was not their goal. > > That short talk last Saturday by the pilot of Flight 564 should set a new > > standard of realism. > > > > Every passenger should learn the simple ? but potentially life-saving ? > > procedure he outlined. He showed his passengers that > > a hijacking does not have to result in hopelessness and terror, but > > victory over the perpetrators. > > > > The Airline Pilots Association, the pilots' union, > > last week dropped its opposition to stronger cockpit doors and is now > > calling for retrofits. > > (It's opposition was based on pilot concerns about getting > > out easily in emergency situations.) The scandal of easily penetrated > > airport security will result incongressional calls for a federal takeover > of > > the security system. > > > > Previous efforts to reform security procedures and > > raise standards have been talked to death. This time, however, no lobbying > > efforts must be allowed to prevent airport security from getting the > reforms > > that are needed: federal operation, rigorous training, decent pay and no > > foreign nationals eligible for employment. > > > > Peter Hannaford is a public affairs consultant Terrorist Attacks on U.S. - > > How can you help? > > ________________________________________________________________________________
Date: Sep 21, 2001
RV-List
Subject: Rudder Problem?
I've found a problem with my rudder, please let me know if it is ok or if I have messed it up! http://www.geocities.com/hester-hoptown/RVSite/RudderProb.html -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ Finishing RV7A empannage :-) ________________________________________________________________________________
Date: Sep 21, 2001
I made a square hole in the center of the 604, that corresponds to the location where the two wing spars meet. This square hole is split right down the middle of the two webs of the wing spars. This way the wings come in around the wires that were already there when installed. In the event the wings are removed (god forbid) then the wings will pull out without distubing the wires. It would look something like this: Left wing spar right wing spar _____________ _______________ - - - - - - | | <---notch cut in both wing spars to match hole in F604 ---- - - - _____________ _______________ Hope this drawing comes out like it does on my system! Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ---- Original Message ----- From: "dave ford" <dford(at)michweb.net> Sent: Friday, September 21, 2001 10:36 PM Subject: RV-List: wire routing For the RV6--where exactly are you routing the wiring from the panel to get between the wing spars for flaps, lights, wing wiring, elect. trim, etc.? Vans wiring kit shows down f602 along horizontal support, down and across front of wing spar. Any other alternatives? Under battery box? Along floor after descending f602? Dave Ford RV6 wiring ________________________________________________________________________________
Subject: Flight Training Restored
Date: Sep 22, 2001
Don't keep me in suspense Ted, what is your nationality if not American??(After 16 years) Oh, and btw, something for you to ponder while you sit at home seething over us "other than north americans"; have you considered the fact that this country is what it is because of such "others". Go back far enough, we're all foreign. Deeply insulted. Ted ________________________________________________________________________________
Date: Sep 21, 2001
Keep people with straightedges away from your plane and you'll have no problems... I wouldn't worry about it. If you tried to bend it back to straight, and succeeded in doing so without putting some giant kink in it, you would probably create a lot of oilcanning - that is, assuming you've already drilled the skin to the skeleton. Anyways, looks OK to me - mine are tiny bit curved as well. I think it came from having too flimsy a bending brake and not flipping the skin over several times while making the TE bend. Matthew 8A 48PP reserved -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bobby Hester Sent: Friday, September 21, 2001 9:32 PM Subject: RV-List: Rudder Problem? I've found a problem with my rudder, please let me know if it is ok or if I have messed it up! http://www.geocities.com/hester-hoptown/RVSite/RudderProb.html -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ Finishing RV7A empannage :-) ________________________________________________________________________________
Date: Sep 16, 2001
We are strong because we are capable of understanding how other nationalities think. And that's because we have those "others" living here in the great US of A to contribute and help us understanding them. The challenge is to weed out ones who don't contribute. I know sometimes it's hard for a very few to understand America when you're a North American because it is difficult to "see the forest through the trees". Trust me, many Americans have a deep appreciation for this country because they are not North Americans. They have a point of reference. They will defend this land until the end. We lead other because we are not like the others. We have them right here, with a slightly different point of view. It's way too easy to be ignorant. Go with the majority and make America that much stronger. I am sensitive and empathetic to the many victims in the recent attacks. But I think it is still a tiny mosquito sting in the ass. I know it is hard to sit still and be patient. But I have complete confidence in our leaders. We'll smush that mosquito sooner or later. Anh N985VU Maryland > >THEY JUST DON'T GET IT DO THEY!!! Here at the Venice >FL airport where two of the pilots were trained, that >did the deed which threatens my freedom to fly etc, >the govt jumps right back into business as usual. The >student population is 60 percent other then North >America. Oh well they're our wonderful leaders that >are yet to be responsible for anything. > Joe >RV6A Heard it's suppose to get dark tonight. > >--- Paul Besing wrote: >> >> >> One step closer, folks. See Below. >> >> Paul Besing >> RV-6A N197AB Arizona >> http://www.lacodeworks.com/besing >> Flying >> Kitlog Pro Builder's Log Software >> http://www.kitlog.com >> >> FAA approves resumption of most flight training >> activities >> 9/21/2001 7:00:23 PM - The FAA has just released a >> notam permitting the >> resumption of most flight training activities. The >> notam, which is effective >> at 0000Z (8 p.m. ET) tonight, allows VFR flight >> training in non-turbojet >> aircraft and gliders (weighing less than 12,500 >> pounds) outside of enhanced >> Class B airspace. >> >> Within enhanced Class B airspace, with the exception >> of the Boston enhanced >> Class B and the Washington and New York exclusion >> areas (see TFR), VFR >> flight training in single- and multi-engine >> piston-powered aircraft under >> 6,000 pounds is permitted. (Almost all single-engine >> and light twin piston >> powered aircraft are less than 6,000). >> >> VFR flight training is still prohibited in the >> Boston enhanced Class B and >> in the Washington and New York exclusionary areas. >> (See AOPA's >> plain-language guidance on notams.) >> >> "We're absolutely delighted that the majority of the >> nation's flight >> training operations can get back in the air this >> weekend," said AOPA >> President Phil Boyer. "This is fantastic news for a >> segment of our industry >> that was suffering greatly. >> >> "AOPA is also pleased to have played a role in >> crafting the solution to >> restoring flight training in the Class B areas. AOPA >> earlier this week gave >> FAA a compilation of the number and weights of GA >> aircraft inside Class B >> airspace. The association suggested that a temporary >> 6,000-pound weight >> limit could be imposed to answer security concerns >> near major metropolitan >> areas." >> >> Conspicuously missing from this good news is >> permission for basic, >> non-training VFR flight in enhanced Class B airspace >> >> Boyer stated, "This is bizarre, and we expected VFR >> operations would be >> approved concurrent with flight training." In >> raising this issue with the >> FAA, it seems there is the perception of a greater >> element of control with f >> light training than non-training operations. The >> agency has assured AOPA >> they have a clear set of proposals to restore most >> VFR operations in >> enhanced Class B airspace, but they now must be >> approved at a higher level >> before they can proceed. >> >> In addition, Boyer pressed for the relocation of >> aircraft from the >> exclusionary Washington and New York areas. He was >> told that work on this is >> progressing, with relief expected very shortly. >> >> Boyer assured members that, "FAA isn't taking the >> weekend off on these >> remaining issues, and neither is AOPA staff. We'll >> be working to assist FAA >> in any manner to rapidly close the loopholes that >> are so critical to >> expanding Class B VFR operations and the movement of >> aircraft in the two >> most affected urban areas." >> >> >> >> http://www.matronics.com/unsubscribe >> >> >> >> through >> >> http://www.matronics.com/archives >> http://www.matronics.com/emaillists >> >> Matronics! >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: Navaid
Yes, and it works great. Also if you bend the tangs on the servo down 90 degrees, it will fit between the seat ribs without any cutting at all. I mentioned this mod to Navaid last spring and they told me there was no reason not to bend the tangs. Garry "Casper" aileron trim done, goin flyin tomorrow. joe wiza wrote: > > I know I'm wearing this down a bit but I have to ask > again. > Has anyone out there installed the navaid in the > RV6 or A under passenger side, attached to the the > passenger stick with positive results (with no > elevator disturbance) and flew the ACFT. > > Has anyone out there attached it to the manual trim > control and if so what problems associated with the > inability to manually trim??? Any pioneer response > would be deeply appreciated. > Joe > RV6A Just love the right to pursue happiness. > > ________________________________________________________________________________
Date: Sep 22, 2001
Subject: tires
As I redo my wheel pant installation, I plan to replace/upgrade my tires as well... I seem to have much more rapid wear of the Aero-Trainers on the left side than the right. After archive research, I believe I will upgrade to Air Hawks... my question is whether I can re-use the original inner tubes (catalog says all McCreary tires use the same type of tube) or is this begging for trouble? I was amazed that the tubes (which lose air like screen doors) are nearly as pricey as the tires. Another question: can anyone put me onto a source for tires that will result in a low price, and save me lots of calling around? I was just about ready to order from Aircraft Spruce when a voice inside said to ask around first! Thanks Bill Boyd RV-6A 200 hrs-- new nose gear leg "match-drilled" at local machine shop yesterday - WHEW, it fits! ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: Oil Temperatures (Again!)
Larry, I don't have any pictures of mine, but I designed it from some photos I found on an RV builder's web site. Don't remember whose site (I think it was someone's from Florida) but I bet if you asked the list, someone would know. Basically, it's a butterfly type door that opens and closes access to a 3" scat tube which leads from the rear cooling baffle to the cooler. It was fairly easy to build and well worth it, especially for up here where winter temperatures are so cold. Andy ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: tires
In a message dated 9/22/01 6:09:29 AM Pacific Daylight Time, SportAV8R(at)aol.com writes: << After archive research, I believe I will upgrade to Air Hawks... my question is whether I can reuse the original inner tubes (catalog says all McCreary tires use the same type of tube) or is this begging for trouble? I was amazed that the tubes (which lose air like screen doors) are nearly as pricey as the tires. Another question: can anyone put me onto a source for tires that will result in a low price, and save me lots of calling around? I was just about ready to order from Aircraft Spruce when a voice inside said to ask around first! >> Bill- I would recommend Desser or Chief (which will have them drop shipped from Desser). The Condor tires have given me good service and I have used the standard McCreary tubes. They are natural rubber for flexibility at low temperatures so they are not as tight a rubber as a synthetic, hence the more rapid loss of air. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Sep 22, 2001
Plans, prints and pictures can be seen here. http://bmnellis.com/BuilderIdeas/paul_golias_ideas.htm Mike Nellis - http://bmnellis.com Plainfield, IL RV6 N699BM (res) Building Flaps Stinson 108-2 N9666K ----- Original Message ----- From: "eCharts" <winterland(at)rkymtnhi.com> Sent: Saturday, September 22, 2001 9:27 AM Subject: Re: RV-List: Oil Temperatures (Again!) > > Larry, > > I don't have any pictures of mine, but I designed it from some photos I found > on an RV builder's web site. Don't remember whose site (I think it was > someone's from Florida) but I bet if you asked the list, someone would know. > > Basically, it's a butterfly type door that opens and closes access to a 3" > scat tube which leads from the rear cooling baffle to the cooler. It was > fairly easy to build and well worth it, especially for up here where winter > temperatures are so cold. > > Andy > > ________________________________________________________________________________
Subject: Proseal on anything
Date: Sep 22, 2001
I used the Proseal type sealant as sold at A/C Spruce. I have been told by many people that it is essentially the same B2 type sealant as the proseal you buy in the two-part can. The only drawback that I can see is it takes a fairly expensive dispenser to be able to use it. My Son found a used Senco with both containers on E-bay for fifty bucks. With this type of applicator you are able to make as small or as large a bead as you like. I think an ordinary caulking gun might be modified to work, you would need to adjust the diameter of the plunger to fit the tube. Went flying today!! God bless America Gene RV9 90296 Rolled over the "canoe" ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: Rudder Problem?
> >I've found a problem with my rudder, please let me know if it is ok or >if I have messed it up! > >http://www.geocities.com/hester-hoptown/RVSite/RudderProb.html > >-- >Surfing the Web from Hopkinsville, KY >Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ >Finishing RV7A empannage :-) > Bobby, This small "problem" should not affect the strength of the rudder, or the flight characteristics. It might have a minuscule effect on performance, but it would be so small that it would not be possible to measure it. It won't even be a cosmetic defect, unless some idiot is running around fly-ins with a ruler. If I catch a guy with a ruler near my RV-8 I'll break it into little pieces. And if I catch anyone down on their hands and knees studying the extra rivets on the bottom of my fuselage I'll step on their fingers. So, I recommend that you press on without attempting to do anything. It is almost certain that any attempt at a "fix" will end up causing you grief. Once you have the plane flying, if you are feeling "builder's withdrawal", and this rudder "problem" is still keeping you up at night, then you can build a new rudder. Take care, -- Kevin Horton RV-8 (installing engine) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: tires
Desser can not only supply tires at good prices but they also stock the Michelin AirStop tubes. They are a little more expensive (?!) but do not leak down nearly as quickly as conventional tubes. Here is Desser: http://www.desser.com/ Sam Buchanan (RV-6, just back from RV Fly-in at Lebanon, TN, great weather, great VFR flight!) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ======================== SportAV8R(at)aol.com wrote: > > > As I redo my wheel pant installation, I plan to replace/upgrade my tires as > well... I seem to have much more rapid wear of the Aero-Trainers on the left > side than the right. After archive research, I believe I will upgrade to Air > Hawks... my question is whether I can re-use the original inner tubes > (catalog says all McCreary tires use the same type of tube) or is this > begging for trouble? I was amazed that the tubes (which lose air like screen > doors) are nearly as pricey as the tires. > > Another question: can anyone put me onto a source for tires that will result > in a low price, and save me lots of calling around? I was just about ready > to order from Aircraft Spruce when a voice inside said to ask around first! > > Thanks > > Bill Boyd > RV-6A 200 hrs-- new nose gear leg "match-drilled" at local machine shop > yesterday - WHEW, it fits! ________________________________________________________________________________
From: "Glenn & Judi" <dirtyrottenscoundrels(at)home.com>
Subject: Rain in the airbox?
Date: Sep 22, 2001
Is rain getting into the airbox while the aircraft is tied down outside a problem? Does it help leave the carb heat lever pulled as part of the "securing the aircraft" checklist? Or is a cowl inlet plug a better idea? Thanks, Glenn Gordon N442E (reserved) At Paint! ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: tires
I changed to Condor retreads. $29.50 each (+$5 core charge because one of my old tires were worn all the way through. The original tires wore out after a lot of taxiing and about 25 hours of flying. The condor tires are not noticeably worn after 125 hours (but I've learned to keep off the brakes unless really needed). Florida Aircraft Tire Service, Inc. Lakeland, FL 863-647-1481 / 1800252 FATS Finn SportAV8R(at)aol.com wrote: > > As I redo my wheel pant installation, I plan to replace/upgrade my tires as > well... I seem to have much more rapid wear of the Aero-Trainers on the left > side than the right. After archive research, I believe I will upgrade to Air > Hawks... my question is whether I can re-use the original inner tubes > (catalog says all McCreary tires use the same type of tube) or is this > begging for trouble? I was amazed that the tubes (which lose air like screen > doors) are nearly as pricey as the tires. > > Another question: can anyone put me onto a source for tires that will result > in a low price, and save me lots of calling around? I was just about ready > to order from Aircraft Spruce when a voice inside said to ask around first! > > Thanks > > Bill Boyd > RV-6A 200 hrs-- new nose gear leg "match-drilled" at local machine shop > yesterday - WHEW, it fits! > > NetZero Platinum Only $9.95 per month! Sign up in September to win one of 30 Hawaiian Vacations for 2! http://my.netzero.net/s/signup?r=platinum&refcd=PT97 ________________________________________________________________________________
Date: Sep 22, 2001
You should have a small hole drilled at the bottom of the airbox to drain excess fuel (from overpriming, stuck float, etc). I would think that should drain off what little water would find its way to the airbox? Rob Acker (RV-6Q). Is rain getting into the airbox while the aircraft is tied down outside a problem? Does it help leave the carb heat lever pulled as part of the "securing the aircraft" checklist? Or is a cowl inlet plug a better idea? ________________________________________________________________________________
Subject: Re: Rain in the airbox?
Date: Sep 22, 2001
A drain hole in the lowest point of the air box when parked is a very good idea. Had a plane a Oshkosh that took a big gulp of water on start because he forgot the drain hole. Didn't start very well until drained. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org http://www.eaa.org for latest flying rules ----- Original Message ----- From: "Glenn & Judi" <dirtyrottenscoundrels(at)home.com> Sent: Saturday, September 22, 2001 1:26 PM Subject: RV-List: Rain in the airbox? Is rain getting into the airbox while the aircraft is tied down outside a problem? Does it help leave the carb heat lever pulled as part of the "securing the aircraft" checklist? Or is a cowl inlet plug a better idea? Thanks, Glenn Gordon N442E (reserved) At Paint! ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: SoCAL flight Orders
Komadant Birdstrike, SIR: Request Permission to volunteer in the So. Cal Wing, SIR!! Will Report as ordered, SIR!! Capt'n Crunch PS I really enjoyed your "Special Orders" DRP ________________________________________________________________________________
From: "Jim Norman, MD" <jnorman(at)intermapsystems.com>
Date: Sep 22, 2001
I've talked to the Vans people about this, and they recommend, (and I have done so) to make the hole in the spar into a slot. They told me that they do this on all of their planes, and that it has no bearing on the integrity of the spar. Specifically, there is a small hole which is about 1.5 inches from the end of the spar which is intended for wires passing through. Just extend this hole into a slot. That way you can put the wings on and off without worrying about the wires which need to pass through this area. Jim Tampa 6A Sanding, sanding, sanding. ________________________________________________________________________________
Date: Sep 22, 2001
--- Glenn & Judi wrote: > Is rain getting into the airbox while the aircraft is tied down > outside a > problem? Does it help leave the carb heat lever pulled as part of > the > "securing the aircraft" checklist? Or is a cowl inlet plug a better > idea? You really should spend a little effort to make cowl and carb inlet plugs. You can use Styrofoam (carve to fit loose) and cover them with vinyl, attach a red fabric flag ("remove before flight" reminder). I see a few of these at fly ins but not nearly as many as I would think. Of course I don't see many pitot tube covers, either... Add to your concern of blowing rain in the airbox (which should drain out the fuel drain hole anyway) the possibility mudobbers in your carb venturi and of birds nesting in your nice, warm cylinders. Some busy birds can build a nest very quickly and the probability of that nest igniting about the time you are lifting off is very real! Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: A certian letter
In a message dated 9/21/01 7:30:34 PM Eastern Daylight Time, lm4(at)juno.com writes: Larry: I tried to send you the message you requested (in another e-mail) Dave Pohl > lm4(at)juno.com > ________________________________________________________________________________
Subject: Re: [Fwd: [Fwd: ]]
Date: Sep 23, 2001
> > > Their names were: Mark Bingham, Jeremy Glick, and Thomas E. Burnett. I belive it was Winston Churchill ( correct me if I'm wrong) who said : " never was so much owed by so many to so few" ________________________________________________________________________________
Date: Sep 22, 2001
Thanks for the insight I spent 25 yrs as an ATC (center) I watched pigs fly and Goverment leaders do wonders. Joe RV6A Spinen & grinen Believe I'll brew me some moon. --- wvu(at)mail.ameritel.net wrote: > > We are strong because we are capable of > understanding how other > nationalities think. And that's because we have > those "others" living here > in the great US of A to contribute and help us > understanding them. The > challenge is to weed out ones who don't contribute. > I know sometimes it's > hard for a very few to understand America when > you're a North American > because it is difficult to "see the forest through > the trees". Trust me, > many Americans have a deep appreciation for this > country because they are > not North Americans. They have a point of > reference. They will defend > this land until the end. We lead other because we > are not like the others. > We have them right here, with a slightly different > point of view. It's way > too easy to be ignorant. Go with the majority and > make America that much > stronger. > I am sensitive and empathetic to the many victims in > the recent attacks. But > I think it is still a tiny mosquito sting in the > ass. I know it is hard to > sit still and be patient. But I have complete > confidence in our leaders. > We'll smush that mosquito sooner or later. > Anh > N985VU > Maryland > > > > > >THEY JUST DON'T GET IT DO THEY!!! Here at the > Venice > >FL airport where two of the pilots were trained, > that > >did the deed which threatens my freedom to fly etc, > >the govt jumps right back into business as usual. > The > >student population is 60 percent other then North > >America. Oh well they're our wonderful leaders that > >are yet to be responsible for anything. > > Joe > >RV6A Heard it's suppose to get dark tonight. > > > >--- Paul Besing wrote: > >> > >> > >> One step closer, folks. See Below. > >> > >> Paul Besing > >> RV-6A N197AB Arizona > >> http://www.lacodeworks.com/besing > >> Flying > >> Kitlog Pro Builder's Log Software > >> http://www.kitlog.com > >> > >> FAA approves resumption of most flight training > >> activities > >> 9/21/2001 7:00:23 PM - The FAA has just released > a > >> notam permitting the > >> resumption of most flight training activities. > The > >> notam, which is effective > >> at 0000Z (8 p.m. ET) tonight, allows VFR flight > >> training in non-turbojet > >> aircraft and gliders (weighing less than 12,500 > >> pounds) outside of enhanced > >> Class B airspace. > >> > >> Within enhanced Class B airspace, with the > exception > >> of the Boston enhanced > >> Class B and the Washington and New York exclusion > >> areas (see TFR), VFR > >> flight training in single- and multi-engine > >> piston-powered aircraft under > >> 6,000 pounds is permitted. (Almost all > single-engine > >> and light twin piston > >> powered aircraft are less than 6,000). > >> > >> VFR flight training is still prohibited in the > >> Boston enhanced Class B and > >> in the Washington and New York exclusionary > areas. > >> (See AOPA's > >> plain-language guidance on notams.) > >> > >> "We're absolutely delighted that the majority of > the > >> nation's flight > >> training operations can get back in the air this > >> weekend," said AOPA > >> President Phil Boyer. "This is fantastic news for > a > >> segment of our industry > >> that was suffering greatly. > >> > >> "AOPA is also pleased to have played a role in > >> crafting the solution to > >> restoring flight training in the Class B areas. > AOPA > >> earlier this week gave > >> FAA a compilation of the number and weights of GA > >> aircraft inside Class B > >> airspace. The association suggested that a > temporary > >> 6,000-pound weight > >> limit could be imposed to answer security > concerns > >> near major metropolitan > >> areas." > >> > >> Conspicuously missing from this good news is > >> permission for basic, > >> non-training VFR flight in enhanced Class B > airspace > >> > >> Boyer stated, "This is bizarre, and we expected > VFR > >> operations would be > >> approved concurrent with flight training." In > >> raising this issue with the > >> FAA, it seems there is the perception of a > greater > >> element of control with f > >> light training than non-training operations. The > >> agency has assured AOPA > >> they have a clear set of proposals to restore > most > >> VFR operations in > >> enhanced Class B airspace, but they now must be > >> approved at a higher level > >> before they can proceed. > >> > >> In addition, Boyer pressed for the relocation of > >> aircraft from the > >> exclusionary Washington and New York areas. He > was > >> told that work on this is > >> progressing, with relief expected very shortly. > >> > >> Boyer assured members that, "FAA isn't taking the > >> weekend off on these > >> remaining issues, and neither is AOPA staff. > We'll > >> be working to assist FAA > >> in any manner to rapidly close the loopholes that > >> are so critical to > >> expanding Class B VFR operations and the movement > of > >> aircraft in the two > >> most affected urban areas." > >> > >> > >> > >> http://www.matronics.com/unsubscribe > >> > >> > >> > >> through > >> > >> http://www.matronics.com/archives > >> http://www.matronics.com/emaillists > >> > >> Matronics! > >> > >> > >> > >> > >> > > > > > > > > http://www.matronics.com/unsubscribe > > > > through > > === message truncated == ________________________________________________________________________________
From: "Ollie Washburn" <skybolt-aviator(at)msn.com>
Subject: Re: tires
Date: Sep 22, 2001
For tires check Desser. They have free shipping and have ad in trade-a-plane.Also i talke to Michelin at Osh and they have a new tube thats not supposed to leak air.They didn't mention price but probably $$$.Ollie&Lorene Washburn RV6-A,N795LW,Now @ 97FL (Loves Landing) ________________________________________________________________________________
Subject: tires
Date: Sep 22, 2001
I bought my tires for my 172 from Desser. They are Condor and are wearing much better the Macreary ones that were on it. (though I no longer have my 172) Greg Tanner Driving---not flying :-( -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ollie Washburn Sent: Saturday, September 22, 2001 6:12 PM Subject: Re: RV-List: tires For tires check Desser. They have free shipping and have ad in trade-a-plane.Also i talke to Michelin at Osh and they have a new tube thats not supposed to leak air.They didn't mention price but probably $$$.Ollie&Lorene Washburn RV6-A,N795LW,Now @ 97FL (Loves Landing) ________________________________________________________________________________
"Rv-List(at)Matronics.Com"
Subject: Flange Bushings...
Date: Sep 22, 2001
I have an O320 with 3/8 thread crank flange bushings, but I need 7/16 thread bushings for my prop... I believe this is not uncommon and was wondering if anyone could tell me where I can get the right bushings... Thanks... -Bill VonDane Colorado Springs, CO RV-8A - N8VD - http://vondane.com/rv8a/ ________________________________________________________________________________
Subject: RV Fall Classic at Lebanon Tn.
Date: Sep 22, 2001
Saw your plane, but not you. Plane looked great. I had to leave for a bit but when I returned 1:30-ish everyone was gone. I am still looking for a ride, maybe next time. Thanks for the offer. Gary Coonan Rockvale, TN RV-7 989WT (Wings) Yep, I'll be there and will be glad to give a ride or two. Just look for the white/yellow/checkerboard Rv-6 and ask the owner... Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Sep 22, 2001
Subject: aileron trim
Bob, I'm having a little trouble picturing what it is that you did here. Did you mount the trim setup where Van's calls for it and with the springs and safety wire, just not protruding up through the seat skin? Which mac servo did you use? Thanks, Ed Holyoke 6 QB -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Japundza Sent: Thursday, September 20, 2001 11:22 AM Subject: RV-List: aileron trim I have the aileron manual bias system in my -6 that is mated to a MAC trim servo...works flawlessly. I have never come close to running out of trim authority, even solo when running the right tank dry to fix the fuel level sender. The trim servo is mounted on web of a belly rib, the shaft is connected to the arm of the manual trim lever rotated 90 deg., shortened, and mounted about 2" below the seat pans. Bob Japundza RV-6 N244BJ O-360C/S flying 210 hours working on weapons guidance system ________________________________________________________________________________
Date: Sep 23, 2001
Subject: Re: tires
Try Wilkerson Tires , Crowe, VA for recaps at $32.00. I've been using them for seven years now on RV-3 and Glasair SH2. They have more tread than tires costing $100 and I haven't had any problems with flaws/out of balance,etc. I tried it and liked it, You may not. Its your dollar. will mincey, flying again and appreciating it more!! ________________________________________________________________________________
Date: Sep 22, 2001
Subject: Re: tires
on 9/22/01 19:45, Greg Tanner at gtanner(at)bendcable.com wrote: > > I bought my tires for my 172 from Desser. They are Condor and are wearing > much better the Macreary ones that were on it. (though I no longer have my > 172) > > Greg Tanner > Driving---not flying :-( > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ollie Washburn > Sent: Saturday, September 22, 2001 6:12 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: tires > > > > For tires check Desser. They have free shipping and have ad in > trade-a-plane.Also i talke to Michelin at Osh and they have a new tube thats > not supposed to leak air.They didn't mention price but probably > $$$.Ollie&Lorene Washburn > RV6-A,N795LW,Now @ 97FL (Loves Landing) I bought some of these magical new Michelin tubes from Desser on 08/30/01. They were $44.95 each. Only been on for about a week so no report on the relative leak rate. The tires into which they are installed are retreads which look like condor treads and cost about $32 as I recall. I expect around 500 landings beign the optimist. Got avg 425 for condors and 250 to 300 on the aero trainers. Denis (Denis L. Walsh deniswalsh(at)earthlink.net) ________________________________________________________________________________
Subject: No Fly Zone
Date: Sep 22, 2001
Both the events of 09/11/01 and DIA's Class B airspace hang over 48V like a fog. The edge of Class B lies less than 3 miles to the west. The airport is as quiet as it has ever been, one or two IFR flights a day coming or going, if anything at all. I was out of the country for a while, flew once when I came back and then we were shut down. I have flown once in 6 weeks. I can't even go flying to shake this oppressive gloom. Great time to stick the other landing light in the wing tip. Soon as I get the tip off and torn apart, they'll lift the restrictions. Hey, that's an idea.................... Michael RV-4 N232 Suzie Q grounded................................trying to understand ________________________________________________________________________________
Date: Sep 22, 2001
I have an O320 with 3/8 thread crank flange bushings, but I need 7/16 thread bushings for my prop... I believe this is not uncommon and was wondering if anyone could tell me where I can get the right bushings... Thanks... Hi Bill Just did this, removed bushings and sent them to Bart Lalond, Aero Sport Power 1-800-667-0522 (Kamloops B.C.) he drilled and rethreaded the bushings to 7/16 size. I presume this is a standard procedure that any machine shop could do. Suggest you give Bart a call for advice. George McNutt 6A Langley B.C. ________________________________________________________________________________
Subject: Bubbles on fuel tank rivets
Date: Sep 23, 2001
Recently, I had bubbles starting to form on the tops of my RV's tanks. Not sure of the cause, Pat Patterson and I speculated that the cause may be gassing of the Proseal since the bubbles were only appearing on the tops of the tanks. In fact, most were on the left tank which is in the sun the longest each day. My RV is tied down and not hangared. Of course, it could have been fuel leaks. To see what the problem was, I used a razor blade to shave one of the bubbles from the tank. When I flipped over the paint bubble, it was clean. There was no fuel residue to be found. A sigh of relief. Although I had the stuff to drill out the rivets (about 17 of them) and reseal them, I was really dreading that. I quickly shaved all of the others and found that none had fuel under them. The fix was simple. I put a small drop of CA (crazy) glue on each place I shaved the bubble from. I wicked off any excess and let it dry for a day. I touched up each rivet with paint and let that cure. After a month, there is no sign of bubbles returning. Pat and I have no idea what caused the Proseal to gas. I've never heard of it before; but, it must have been the Proseal. With that, be careful about drilling out those rivets you think may be leaking. It may actually be what I discovered. A touch of glue and paint is a lot easier than drilling and filling. Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Subject: Re: RV Fall Classic at Lebanon Tn.
Date: Sep 23, 2001
> Saw your plane, but not you. Plane looked great. I had to > leave for a bit but when I returned 1:30-ish everyone was > gone I'm sorry I missed you, Gary. I think I was still there when you came back. If I had talked with you and found out that you had missed your ride, I'm sure I could have given you one in my -6A. What with the number of us out there flying them, these days, you should be able to get a ride easy enough. I hear there is a fly-in at Lexington next saturday. If so, I'm sure you can find a couple of them there. Jim Sears in KY RV-6A N198JS (The one with the two blue strips down the side) ________________________________________________________________________________
From: "Clifford Begnaud" <shoeless(at)barefootpilot.com>
Subject: Re: No Fly Zone
Date: Sep 23, 2001
> Both the events of 09/11/01 and DIA's Class B airspace hang over 48V like a > fog. The edge of Class B lies less than 3 miles to the west. The airport is > as quiet as it has ever been, one or two IFR flights a day coming or going, > if anything at all. I was out of the country for a while, flew once when I > came back and then we were shut down. I have flown once in 6 weeks. I can't > even go flying to shake this oppressive gloom. Great time to stick the other > landing light in the wing tip. Soon as I get the tip off and torn apart, > they'll lift the restrictions. Hey, that's an idea.................... > > Michael > RV-4 N232 Suzie Q > grounded................................trying to understand Michael, I hope putting your plane down works ;-). I too am tired of not being able to fly. We bought a lot at 48v (215 piper) and put our building plans on hold. What do you think the chances would be of getting 48v "scooped" out of the Class B once this all blows over? Cliff ________________________________________________________________________________
Date: Sep 23, 2001
OK: I am reading the NOTAM, and this is what I see: MANUFACTURER PRODUCTION FLIGHT TEST OPERATIONS ARE AUTHORIZED FOR AIRCRAFT WITH A MAXIMUM CERTIFICATED GROSS TAKEOFF WEIGHT OF 95,000 POUNDS OR LESS WITHIN ENHANCED CLASS B AIRSPACE AREAS, EXCEPT THE BOSTON ENHANCED CLASS B AIRSPACE AREA AND EXCEPT FOR OPERTATIONS WITHIN THE TEMPORARY FLIGHT PURSUANT TO FDC NOTICE 1/9953. I am a manufacturer of (an) aircraft, right? And there are some aspects of my flight testing I have not completed; further "G" testing, for example. And fuel consumption, weight-related rate of climb. The list goes on. Would I be legal? Michael Trying to figure out a way out.................. ________________________________________________________________________________
Date: Sep 23, 2001
> > OK, so what do I have to offer you? You know the drain holes you drill in > the bottom of the carb. air box to prevent backfire Fire! and engine flooding > out. I now have an aluminum tube epoxied(sp) in the bottom low point of the > air box with a drain hose aft clearing the exhaust pipes. It is a similar > system to that used on the mechanical fuel pump. In fact these two vent tubes > could be teed together and just one hose used for both safety bypass lines. The above quote is taken from "There I was at 10,000 feet" For the "rest of the story" check the archives. Ask yourself where the fuel goes in your installation, once it leaves those holes in the air box. Venting fuel into the air box by pumping the throttle , negative forces or a leaking carburetor float valve and then letting it drain into the cowl to be swirled around the exhaust pipes doesn't make sense to me. Play it safe with a little extra effort. Water will leave by the same tube. Gary ________________________________________________________________________________
Date: Sep 23, 2001
Subject: Re: tires
I installed the Michelin Airstop tubes about four months ago. While there is still leakdown, I have found that it is much less than the regular tubes. The old tubes needed airing up every month, but the Michelin tubes can go 2-3 months between servicing. By the way, I searched for non-aircraft synthetic tubes that would fit the 5.00x5 tires, but was unsuccessful; the thought was that the synthetic tubes would not have leak down tendencies. Sam Buchanan ==================== Denis Walsh wrote: > > I bought some of these magical new Michelin tubes from Desser on 08/30/01. > They were $44.95 each. Only been on for about a week so no report on the > relative leak rate. ________________________________________________________________________________
Date: Sep 23, 2001
That one is going to be an issue for interpretation - however, from what I can determine from the FARs, a production flight test is covered under FAR 21. FAR 21 refers to aircraft with a type certificate.... Any DARs or Feds want to try to interpret this one? Tom ----- Original Message ----- From: "KostaLewis" <mikel(at)dimensional.com> Sent: Sunday, September 23, 2001 11:53 AM Subject: Re: RV-List: No Fly Zone > > OK: I am reading the NOTAM, and this is what I see: > > MANUFACTURER PRODUCTION FLIGHT TEST OPERATIONS ARE AUTHORIZED FOR AIRCRAFT > WITH A MAXIMUM CERTIFICATED GROSS TAKEOFF WEIGHT OF 95,000 POUNDS OR LESS > WITHIN ENHANCED CLASS B AIRSPACE AREAS, EXCEPT THE BOSTON ENHANCED CLASS B > AIRSPACE AREA AND EXCEPT FOR OPERTATIONS WITHIN THE TEMPORARY FLIGHT > PURSUANT TO FDC NOTICE 1/9953. > > I am a manufacturer of (an) aircraft, right? And there are some aspects of > my flight testing I have not completed; further "G" > testing, for example. And fuel consumption, weight-related rate of climb. > The list goes on. Would I be legal? > > Michael > Trying to figure out a way out.................. > > ________________________________________________________________________________
Date: Sep 24, 2001
Subject: Re: Flying again
Now let's change things so that we in the B airspace can fly. I'm about 30 miles too close to DFW and office towers. Cannot understand how I am more of a hazard than my friend based 50 miles away! Will Cretsinger, Arlington, Texas Brian Denk wrote: > > > Went flying today. After over a week of turmoil, shock and emotional chaos, > we VFR airplane drivers are free to go. Well, most of us but not all. > > I took a short flight in the practice area just to shake off the cobwebs. > Have a BFR due in October and want to make sure I can still turn 'round a > point. Oh hell yeah I can...on a wingtip if needbe. Neat airplanes these > RV's. No terrorist alive could ever dream of such splendor..freedom..and > satisfaction in doing such things. No matter how many buildings fall, or > how many of our beloved American brethren pass on, we have already won this > war. We can FLY. > > Although my short trip into the sunny afternoon sky was greatly satisfying, > it was also bittersweet. I felt a subtle sadness unlike that which I have > felt in the past week. Looking skyward from my lofty perch, I could not > help but get misty eyed. To the fallen firemen, police, rescue workers, > office workers, and flight crews....this one is for YOU. > > Proud to be a free flying AMERICAN, > > Brian Denk > RV8 N94BD > > ________________________________________________________________________________
Subject: Re: Flange Bushings...
Date: Sep 23, 2001
Wentworth Aircraft wentacpart(at)aol.com swapped the bushings for me when I bought a core engine from them. Dick Sipp N250DS > > I have an O320 with 3/8 thread crank flange bushings, but I need 7/16 thread > bushings for my prop... I believe this is not uncommon and was wondering if > anyone could tell me where I can get the right bushings... ________________________________________________________________________________
Subject: AN3 bolt hole size
Date: Sep 23, 2001
This is my first posting. Hope I'm doing it right. What I need to know is what size hole to drill for an AN3 bolt. I'm ready to place my horizontal Stab. in my jig but don't see anywhere the correct hole size for the hinges or brackets on the jig. It seems to be a number 12 drill bit or 3/16th (same as the bolt) but I want to get it right. Thanks in advance Steve Struyk RV8 ________________________________________________________________________________
Date: Sep 23, 2001
Subject: Re: AN3 bolt hole size
on 9/23/01 5:23 PM, Steve Struyk at RV8Striker(at)hotmail.com wrote: > This is my first posting. Hope I'm doing it right. Yep > > What I need to know is what size hole to drill for an AN3 bolt. #12 drill bit I'm > ready to place my horizontal Stab. in my jig but don't see anywhere the > correct hole size for the hinges or brackets on the jig. It seems to be > a number 12 drill bit or 3/16th (same as the bolt) but I want to get it > right. Always check if you're not sure, but this will become simple very quickly. There are many good references available, including the Orndorf videos which will pretty much hold you by the hand and lead you along, especially on the empennage. > > Thanks in advance No problem. Welcome aboard > Steve Struyk > RV8 James Freeman RV8Q fuse/finishing ________________________________________________________________________________
Date: Sep 23, 2001
Steve, That's right, the hole will be 3/16" although you may want to drill it slightly undersize, say a number 14, and then use a reamer for the final hole. This will give you a rounder hole with fewer irregularities. You will find that the plans always call out for the fastener and leave you to figure out what size to drill the hole. Keep on building! Jerry Carter RV-8A 40 hrs, grounded inside "enhanced" class B ----- Original Message ----- From: "Steve Struyk" <RV8Striker(at)hotmail.com> Sent: Sunday, September 23, 2001 3:23 PM Subject: RV-List: AN3 bolt hole size > > This is my first posting. Hope I'm doing it right. > > What I need to know is what size hole to drill for an AN3 bolt. I'm > ready to place my horizontal Stab. in my jig but don't see anywhere the > correct hole size for the hinges or brackets on the jig. It seems to be > a number 12 drill bit or 3/16th (same as the bolt) but I want to get it > right. > > Thanks in advance > Steve Struyk > RV8 > > ________________________________________________________________________________
Date: Sep 23, 2001
Subject: Re: pin or bolts?
dear listers, i'm assembling my center console throttle quadrant, and am using the cables from Vans with the screw on clevis. they came with a pin and cotter key, but i seem to have miss placed them. can i use a small bolt or screw with a nyloc nut? is these pins extra hardened? scott tampa back to work on the rv. ________________________________________________________________________________
Subject: Fw: Coastal Georgia Fall Fly-In
Date: Sep 23, 2001
The Coastal Georgia Fall Fly-In previously scheduled for 9/20/01 has been re-scheduled to 10/20/01. It will be held at Eagle Neck Air Park, 1GA0, located on Georgia's coast half way between Savannah and St. Simons Island. One complete and 4 RV projects are based here. For complete details contact Dick Sipp at rsipp(at)earthlink.net Dick Sipp ________________________________________________________________________________
Subject: !!!New RV message board!!!
Date: Sep 24, 2001
To the best of my knowledge the RV community has not untill now had a "real" messageboard. So I started one! you can access it here http://www.flugfelagid.com/ffmessageb/ubbcgi/ultimatebb.cgi or go through our web www.flugfelagid.com (on the menu click messageboard and it opens in a separate window) I hope in time it will be frequented and thus become highly useful and entertaining for everyone. To post you will need to register. Thor Hardarson Iceland Building a RV-9 empennage ________________________________________________________________________________
Subject: !!new RV messageboard!!
Date: Sep 24, 2001
Date: Sep 23, 2001
Subject: pin or bolts?
Hey Scott, Tell us more about the center console quadrant. I'm thinking that's what I want to do, but I'm not sure where it needs to mount or how I'll run the cables. How are you doing it? Ed Holyoke 6QB -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of ABAYMAN(at)aol.com Sent: Sunday, September 23, 2001 4:20 PM Subject: Re: RV-List: pin or bolts? dear listers, i'm assembling my center console throttle quadrant, and am using the cables from Vans with the screw on clevis. they came with a pin and cotter key, but i seem to have miss placed them. can i use a small bolt or screw with a nyloc nut? is these pins extra hardened? scott tampa back to work on the rv. ________________________________________________________________________________
Date: Sep 24, 2001
Mike, Congratulations - It sure is a great feeling when the painting is done. Look forward to hearing about your first flight. BTW the way it took us about 1 1/2 months part time to do our painting. Good Building, Chuck & Dave Rowbotham RV-8A (17 hours - flying) Niantic, CT (Westerly airport) ________________________________________________________________________________
Subject: Crossing Rockies Advise
Date: Sep 24, 2001
A navigation question for all of you experienced flyers. What is the best route (without oxygen) to get across the Rocky Mountains if you departing from Oklahoma or Kansas with Boise, Idaho as your destination. I am still waiting for my FAA inspection but I'm already planning cross country trips ;>) Eric Newton - Long Beach, MS RV-6A N57ME (waiting for FAA inspection) www.ericsrv6a.com ________________________________________________________________________________
Date: Sep 24, 2001
Subject: Re: RV6-List Digest: 2 Msgs - 09/21/01
From Norm Donaldson RV6 working on canopy frame, I too had installed my top skins before I installed the Aileron gap seals. What I did was clamp and tape the seal into position and carefully layout and drill the holes as shown on the plans. Consider the fact that if the rivets are too close to the radius you will not be able to buck them. What you will have to do is cleco the seal in position putting a cleco in every hole. Gently pull down the other side of the seal. Remove one cleco and install a rivet. This is definitely a two man job! You will need an offset bucking bar with a narrow anvil to get up in the tight area. I always use 25 to 28 PSI on my 3x rivet gun to minimize possibility of damaging sheet metal. This is awkward riveting at its best. Remember only remove one cleco at a time at the bending load on the seal will tend to separate the seal from the top skin. ________________________________________________________________________________
Date: Sep 24, 2001
Thread-Topic: RV-List Digest: 21 Msgs - 09/23/01 Thread-Index: AcFEzdtoXG7cUKgqT2CA7W5Wi8i1oAAOSjMQ
Hi Jim, I have had the paint over two rivets on my tanks bubble. Don't know why, but it didn't appear to be a leak. I poked them with a needle and rubbed the blister out with my finger. The paint must have re-adhered, 'cause I can't tell where they were. Bob Japundza RV-6 N244BJ O-360C/S flying 220 hours ________________________________________________________________________________
Subject: Re: Waiting for Inspection
Date: Sep 24, 2001
Eric, By all means call the FSDO and ask them if they have it. And then ask them if they have any guess on how long it will be. They won't get upset over a couple of questions like that. Mike Robertson RV-8A >From: "Eric Newton" <enewton57(at)cableone.net> >Reply-To: rv-list(at)matronics.com >To: "RV-List" >Subject: RV-List: Waiting for Inspection >Date: Fri, 21 Sep 2001 09:41:45 -0500 > > >Since its fairly slow on the list (you are all probably flying), I >thought I would solicit everyone's opinion. I sent the local FSDO my >paperwork and application for airworthiness certificate about three >weeks ago and haven't heard a word from them. Local builders tell me >they usually get a call within a week from our local FSDO. I know with >all of the events that have happened since 9/11 they are probably very >busy right now. So here are my thoughts: > >1. Leave them alone, they will eventually call. >2. Call just be sure they actually received the application and it >didn't get lost in the mail. >3. Call and ask how long the delay will be. >4. Call a DAR and schedule an inspection. > >With option number 1, I worry that maybe in all of the confusion it got >lost. Here I am waiting and they never got it to begin with. >With numbers 2 & 3, I'm afraid they will get angry and make my life >miserable if and when they get around to inspecting. >With number 4, Murphy's law says the minute I write the check to the >DAR, the Feds will call and schedule an appointment. > >So what is the consensus? Any opinions? > >Thanks, > >Eric Newton - Long Beach, MS (no class B airspace here) >RV-6A (waiting for the FAA inspection) >www.ericsrv6a.com > > ________________________________________________________________________________
Date: Sep 24, 2001
I imagine the reason for a pin and cotter key is for rotation and movement. If you use a bolt, I would use a castle nut and cotter key just like you would on other installations where you don't want the nut tight, but need the cotter key to keep it from coming off. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Ed Holyoke" <bicyclop(at)pacbell.net> Sent: Sunday, September 23, 2001 10:25 PM Subject: RE: RV-List: pin or bolts? Hey Scott, Tell us more about the center console quadrant. I'm thinking that's what I want to do, but I'm not sure where it needs to mount or how I'll run the cables. How are you doing it? Ed Holyoke 6QB -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of ABAYMAN(at)aol.com Sent: Sunday, September 23, 2001 4:20 PM Subject: Re: RV-List: pin or bolts? dear listers, i'm assembling my center console throttle quadrant, and am using the cables from Vans with the screw on clevis. they came with a pin and cotter key, but i seem to have miss placed them. can i use a small bolt or screw with a nyloc nut? is these pins extra hardened? scott tampa back to work on the rv. ________________________________________________________________________________
Date: Sep 24, 2001
Subject: Re: Airline Bailout, Not RV related
Eric, I am all for buying American products. I drive two American cars. I fly an Aribus for a major airline and I thought I would just let you know that 65 to 70% of the Airbus consists of American made components. The engines are General Electric. The onboard computers (more than 70 of them) are Honeywell. The list of American components on the airbus is a long and distinguished one. You can ask Boeing how much of a 757 is built overseas and I think you will be surprised. I am not trying to make a case against Boeing. I just thought you would be interested to know. Paul, RV9 90355 PS The Airbus 320 is a truly wonderful airplane to fly. ________________________________________________________________________________
Subject: Re: Crossing Rockies Advise
Date: Sep 24, 2001
Eric, I'm sure some others will chime in here, but I feel compelled to add my 2 cents worth in light of a recent accident that took the life of an acquaintance of mine and a member of the "Kitfox List". It's just not as simple as finding a good route across the mountains. There are more hazards than you can possibly imagine. PLEASE, PLEASE, PLEASE don't venture off into the Rocky Mountains without getting adequate training, here in the region. Do not depend on training received in the lowlands to prepare you for what you will encounter here. Every year pilots from across the country venture off into the Rockies, and invariably, every year several of them pay for the mistake with their life. My suggestion would be to cross through southern Wyoming, Cheyenne, Laramie, Rawlins. Generally following I-80. Before getting to Salt Lake City, divert north into southern Idaho, avoiding the mountains that run north to south from just east of salt lake city to north of Logan, UT. From here it is a straight forward trip to Boise. Keep in mind that much of the terrain along this route is very rugged, often with few options for making emergency landings. There are mountains along this route, but you can fly around them. HOWEVER, they can still cause all kinds of meteorological problems. Keep in mind that even though most of the airports at which you would stop for fuel are not necessarily in the mountains, they are still "high elevation" airports and will present challenges. You can expect winds of 25++ knots at most airports along this route, as the rule, not the exception. So be competent at cross wind landings. Keep in mind that your ground speed at landing will be higher than you are accustomed to, so watch your AIRSPEED carefully. Be careful out there! Regards, Cliff > A navigation question for all of you experienced flyers. What is the > best route (without oxygen) to get across the Rocky Mountains if you > departing from Oklahoma or Kansas with Boise, Idaho as your destination. > I am still waiting for my FAA inspection but I'm already planning cross > country trips ;>) > > Eric Newton - Long Beach, MS > RV-6A N57ME (waiting for FAA inspection) > www.ericsrv6a.com > ________________________________________________________________________________
Date: Sep 24, 2001
Eric, From OK or KS, one way is to make your way to Cheyenne; then you could fly at or below 12500 VFR (12000 IFR) along the following route: V138 MBW V6 FBR V142 MLD V4 BOI. You need to avoid Denver because there is no low altitude route going west from Denver. From Cheyenne Airport to Boise Air Terminal along this route is 557 n.m., so you might want to stop in Fort Bridger or someplace. If you want to fly off airways, I can't help you. Best wishes, Jack Abell Eric Newton wrote: > > A navigation question for all of you experienced flyers. What is the > best route (without oxygen) to get across the Rocky Mountains if you > departing from Oklahoma or Kansas with Boise, Idaho as your destination. > I am still waiting for my FAA inspection but I'm already planning cross > country trips ;>) > > Eric Newton - Long Beach, MS > RV-6A N57ME (waiting for FAA inspection) > www.ericsrv6a.com > > ________________________________________________________________________________
Date: Sep 24, 2001
Nice Try! Keep thinking! I tried suggesting a one time departure for those stuck under a class 'B' veil to our FSS and asked them to pass it up the line but have heard nothing back yet. >From: "KostaLewis" <mikel(at)dimensional.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: No Fly Zone >Date: Sun, 23 Sep 2001 10:53:52 -0600 > > >OK: I am reading the NOTAM, and this is what I see: > >MANUFACTURER PRODUCTION FLIGHT TEST OPERATIONS ARE AUTHORIZED FOR AIRCRAFT >WITH A MAXIMUM CERTIFICATED GROSS TAKEOFF WEIGHT OF 95,000 POUNDS OR LESS >WITHIN ENHANCED CLASS B AIRSPACE AREAS, EXCEPT THE BOSTON ENHANCED CLASS B >AIRSPACE AREA AND EXCEPT FOR OPERTATIONS WITHIN THE TEMPORARY FLIGHT >PURSUANT TO FDC NOTICE 1/9953. > >I am a manufacturer of (an) aircraft, right? And there are some aspects of >my flight testing I have not completed; further "G" >testing, for example. And fuel consumption, weight-related rate of climb. >The list goes on. Would I be legal? > >Michael >Trying to figure out a way out.................. > > ________________________________________________________________________________
Date: Sep 24, 2001
A Manufacturer's PRODUCTION test flight means only for a manufacturer that has applied for a type certificate and are test flying a prodo-type. Thats the short version explanation. Mike Robertson RV-8A >From: "Thomas Mosher" <tmosher(at)gbronline.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: No Fly Zone >Date: Sun, 23 Sep 2001 16:09:52 -0500 > > >That one is going to be an issue for interpretation - however, from what I >can determine from the FARs, a production flight test is covered under FAR >21. FAR 21 refers to aircraft with a type certificate.... > >Any DARs or Feds want to try to interpret this one? > >Tom >----- Original Message ----- >From: "KostaLewis" <mikel(at)dimensional.com> >To: >Sent: Sunday, September 23, 2001 11:53 AM >Subject: Re: RV-List: No Fly Zone > > > > > > OK: I am reading the NOTAM, and this is what I see: > > > > MANUFACTURER PRODUCTION FLIGHT TEST OPERATIONS ARE AUTHORIZED FOR >AIRCRAFT > > WITH A MAXIMUM CERTIFICATED GROSS TAKEOFF WEIGHT OF 95,000 POUNDS OR >LESS > > WITHIN ENHANCED CLASS B AIRSPACE AREAS, EXCEPT THE BOSTON ENHANCED CLASS >B > > AIRSPACE AREA AND EXCEPT FOR OPERTATIONS WITHIN THE TEMPORARY FLIGHT > > PURSUANT TO FDC NOTICE 1/9953. > > > > I am a manufacturer of (an) aircraft, right? And there are some aspects >of > > my flight testing I have not completed; further "G" > > testing, for example. And fuel consumption, weight-related rate of >climb. > > The list goes on. Would I be legal? > > > > Michael > > Trying to figure out a way out.................. > > > > > > ________________________________________________________________________________
Date: Sep 24, 2001
Scott, You could use a bolt and self locking nut here but a couple of precautions. Make sure that there is smooth shank most of the way through the clevis as the bolt must always be somewhat loose and over time the threads will act like a mini file. Make sure the bolt is able to rotate in the clevis hole but is not sloppy. Being too sloppy leaves open the chance that if something came loose it could catch the bolt. Also you may want to add the bolts to your yearly condition inspection as they are not designed for shear load and may wear faster than a clevis pin. For this application they probably never will but one never knows. What I would suggest is go ahead and use bolts until you get a chance to replace them with clevis pins. Mike Robertson RV-8A >From: ABAYMAN(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: pin or bolts? >Date: Sun, 23 Sep 2001 19:19:50 EDT > > >dear listers, >i'm assembling my center console throttle quadrant, and am using the cables >from Vans with the screw on clevis. they came with a pin and cotter key, >but >i seem to have miss placed them. can i use a small bolt or screw with a >nyloc >nut? is these pins extra hardened? >scott >tampa >back to work on the rv. > > ________________________________________________________________________________
Date: Sep 24, 2001
ok i'm convienced, i'll find the pins and use them. thanks guys scott tampa ________________________________________________________________________________
Subject: Get out of Class B
Date: Sep 24, 2001
Listers: It seems many listers are interested in repositioning their airplanes out of enhanced Class B airspace. I have not seen mentioned the simple method of hiring an instructor. Why not? FDC 1/0345 FDC PART 1 OF 2 ..SPECIAL NOTICE.. ATTENTION ALL OPERATORS EFFECTIVE SEPTEMBER 22, 2001 0000 UTC UNTIL FURTHER NOTICE. PURSUANT TO TITLE 14 CFR 91.139 EMERGENCY AIR TRAFFIC RULES: 1. IN ALL AIRSPACE OUTSIDE ENHANCED CLASS B AIRSPACE, VFR FLIGHT TRAINING OPERATIONS ARE AUTHORIZED FOR SINGLE AND MULTI-ENGINE NON-TURBOJET POWERED AND NON-POWERED (E.G., GLIDERS) AIRCRAFT WITH A MAXIMUM CERTIFICATED GROSS TAKEOFF WEIGHT OF 12,500 POUNDS OR LESS. 2. FOR THOSE AIRPORTS WITHIN ENHANCED CLASS B AIRSPACE AREAS, EXCEPT THE BOSTON ENHANCED CLASS B AIRSPACE AREA AND EXCEPT FOR OPERATIONS WITHIN THE TEMPORARY FLIGHT RESTRICTIONS AREAS FOR THE NEW YORK AND WASHINGTON OPERATIONS ARE AUTHORIZED FOR SINGLE AND MULTI-ENGINE PROPELLER AND ROTOR DRIVEN PISTON POWERED AIRCRAFT WITH A MAXIMUM CERTIFICATED GROSS TAKE-OFF WEIGHT OF 6,000 POUNDS OR LESS.]] Larry Pardue Carlsbad, NM RV-6 N441LP Flying (And feeling a bit guilty about being able to go to ABI when so many could not) http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
\"Rocket List\"" , "Allen L. Mecum"
Subject: Re: Good thinking!
Date: Sep 24, 2001
When the cord holding the HRII canopy broke and the brand new canopy tore loose and bounced across the floor it was crying time OR it was time to say "well we know for sure that Van's design for emergancy canopy removal works". The "pop" rivents did pop the second time and release the canopy as planned. Did we say this right away, No. It took about five minutes to check out the canopy, get over the shock and then we did continue on and the quote above is what was said. KABONG ----- Original Message ----- From: SEERONFLY(at)aol.com Subject: Good thinking! READ THIS. LET IT REALLY SINK IN. THEN CHOOSE HOW YOU START YOUR DAY TOMORROW. Michael is the kind of guy you love to hate. He is always in a good mood and always has something positive to say. When someone would ask him how he was doing, he would reply, "If I were any better, I would be twins!" He was a natural motivator. If an employee was having a bad day, Michael was there telling the employee how to look on the positive side of the situation. Seeing this style really made me curious, so one day I went up to Michael and asked him, "I don't get it! You can't be a positive person all of the time. How do you do it?" Michael replied, "Each morning I wake up and say to myself, you have two choices today. You can choose to be in a good mood or ...you can choose to be in a bad mood. I choose to be in a good mood. Each time something bad happens, I can choose to be a victim or...I can choose to learn from it. I choose to learn from it. Every time someone comes to me complaining, I can choose to accept their complaining... or I can point out the positive side of life. I choose the positive side of life. "Yeah, right, it's not that easy," I protested. Yes, it is," Michael said. "Life is all about choices. When you cut away all the junk, every situation is a choice. You choose how you react to situations. You choose how people affect your mood. You choose to be in a good mood or bad mood. The bottom line: It's your choice how you live your life." I reflected on what Michael said. Soon hereafter, I left the Tower Industry to start my own business. We lost touch, but I often thought about him when I made a choice about life instead of reacting to it. Several years later, I heard that Michael was involved in a serious accident, falling some 60 feet from a communications tower. After 18 hours of surgery and weeks of intensive care, Michael was released from the hospital with rods placed in his back. I saw Michael about six months after the accident. When I asked him how he was, he replied. "If I were any better, I'd be twins. Wanna see my scars?" I declined to see his wounds, but I did ask him what had gone through his mind as the accident took place. "The first thing that went through my mind was the well-being of my soon to be born daughter, " Michael replied. "Then, as I lay on the ground, I remembered that I had two choices: I could choose to live or ...I could choose to die. I chose to live." "Weren't you scared? Did you lose consciousness?" I asked. Michael continued, "...the paramedics were great. They kept telling me I was going to be fine. But when they wheeled me into the ER and I saw the expressions on the faces of the doctors and nurses, I got really scared. In their eyes, I read "he's a dead man. I knew I needed to take action." "What did you do?" I asked. "Well, there was a big burly nurse shouting questions at me," said Michael. "She asked if I was allergic to anything. "Yes, I replied." The doctors and nurses stopped working as they waited for my reply. I took a deep breath and yelled, "Gravity." Over their laughter, I told them, "I am choosing to live. Operate on me as if I am alive, not dead." Michael lived, thanks to the skill of his doctors, but also because of his amazing attitude. I learned from him that every day we have the choice to live fully. Attitude, after all, is everything. "Therefore do not worry about tomorrow, for tomorrow will worry about itself. Each day has enough trouble of its own." Matthew 6:34 After all today is the tomorrow you worried about yesterday. You have two choices now: 1. Delete this. 2. Forward it to the people you care about. You know the choice I made ________________________________________________________________________________
Date: Sep 24, 2001
From: "Builder's Bookstore" <winterland(at)rkymtnhi.com>
> PLEASE, PLEASE, PLEASE don't > venture off into the Rocky Mountains without getting adequate training, Yes. All true, but perhaps a bit too dramatic. I do want to add a couple caveats. 1] The RV is fully capable of handling any altitude or density altitude you will encounter in the Rockies with plenty of remaining performance and plenty of margin for error. Of course, your climb rates will be lower and of course you'll use more runway. But area airports have that extra runway to accomodate you. 2] The mountains do not "make their own weather" but they do accentuate it, particularly in the case of winds. My rules of thumb (and I'm a big chicken compared to others I fly with) if the winds at your cruising altitude are calm to under 10 kts then they are no factor. I'll just fly right over the tops, or anywhere I want, including around the big 14ers. 10-20 kts and I'll limit my ridge crossings to the lower passes and/or pick up another 1-2000' of altitude. If flying cross wind on the downwind side of a high ridge I'll also start paying attention to upslope and downslope wind conditions by staying on the upslope side. If its much above 20kts I won't fly the high ridges or passes and will avoid areas of downslope winds. Fortunately these days are not that common and when they do happen it's mostly because a front is passing through or has just recently past. Just pay attention to winds aloft figures, the location of passing fronts and be conservative in making a go no-go decision. 3] Landable terrain is more common than you think. There are very few areas from where you couldn't easily glide to a landable location in an emergency from an altitude of 3000' or so above the valley floors so long as you have a reasonable awareness of where you are and the terrain around you. Unfortunatley I believe the mountains east and northeast of Boise are such difficult areas making an approach from the south perhaps more prudent. Other than that, flying along the Colorado / Wyoming border does offer the lowest passes, and although not the most interesting terrain will likely offer the best chances of benign weather. Andy Winter Park, CO ________________________________________________________________________________
Date: Sep 24, 2001
Subject: Re: Get out of Class B
What I was told about planes getting out of the class B air space arround Dallas and Ft Worth was to go out as a flight of 2 or 3 with only one filing a IFR flight plan to a airport out of the class B. The flight could land at an airport outside class B and close flight flan. Was informed that was how to get airshow preformers out of DFW class B to make it to ABI Southwest Regional fly-in. That was what I was told. Sounds good to me. Terry E. Cole ________________________________________________________________________________
From: "Doug Weiler" <doug.weiler(at)pressenter.com>
Date: Sep 24, 2001
Speaking of mountain fly, we are planning a flight from Minneapolis to Jackson Hole in a week. Can any of you mountain guys suggest a nice VFR route into there from the East for my RV-4? Doug Weiler Mn Wing ________________________________________________________________________________
Date: Sep 24, 2001
Fort Bridger had no fuel when I flew over on my way back from OSH. Rock Springs is a good place to land, but can be very windy at times. Evanston and Kemmerer have fuel but are both a lot higher...so watch density altitude. We like to cross into the Salt Lake valley two canyons south of Logan. There is a pretty good clearance and you don't have to be too high. You DO need to be aware of the winds though. Logan is a nice airport to land at and is outside SLC class B. From Logan it is a short hop up to KBOI. Another way, the scenic route, is longer but does avoid the highest CO mtns, would be to fly west through Farmington, NM and Page, AZ, then north through Utah...pick your valley and stay in it northward. Either way, plan your trip over highways and airports, and be aware of which airports have fuel, because a lot of the small ones don't. ________________________________________________________________________________
Date: Sep 24, 2001
It was..."never in the field of human conflict was so much owed, by so many, to so few...." > > > > > > Their names were: Mark Bingham, Jeremy Glick, and Thomas E. Burnett. > >I belive it was Winston Churchill ( correct me if I'm wrong) who said : > >" never was so much owed by so many to so few" > > Richard E. Bibb Sr. Vice President Worldwide Sales and Customer Support Redback Networks 10780 Parkridge Boulevard, Suite 155 Reston, Virginia 20191 Direct: 703-860-7012 Main: 703-860-7000 rbibb(at)redback.com Mobile: 703-627-0348 ________________________________________________________________________________
Subject: Fuel presure fluctuating
Date: Sep 24, 2001
Fellas, I flew my RV-6A first flt on 27 July and only have 4.5 hrs to go to get the 40 I need, but I one "challenge" I can not seem to solve. The fuel presure fluctuates from 3.8 to 6. lbs while running on the engine driven pump. When I start the engine with elect pump running the pres. is 6+ lbs. Turn off elect. and it is still 5+ lbs. Take-off and it "may " stay at 5+ lbs. until maybe 15 mins or so into flight then it drops to 3.8 lbs. It will probably stay there until I decend (say 5500 down to 2500) and it will raise up to 5.+ lbs again. I have fire sleeve on all fuel lines, and tried putting cool air on the gasolator and even sender unit which did not help. My engine is a 0-360, oil cooler is on left rear baffle, and the fuel presure gage is a Mitchel w/Mitchel electric sender. Oh yes, I do not have fire sleeve on the 1/8" I.D. hose running from the carb to the sender. Has anyone had similar problems???? What next?? HELP????? Larry, N939LT at 3SY INDY. ________________________________________________________________________________
Date: Sep 24, 2001
Subject: Re: Airline Bailout/Rebate, Not RV related
Brian, Here here... well said !!! ________________________________________________________________________________
Date: Sep 24, 2001
I'm not very familiar with the area you're proposing to fly in, having only flown low level there once. But I have some general advice about mountain flying (former mountain SAR pilot). Don't be too set on flying airways. It's amazing how many mountain crash sites are right on an airway. Terrain, wind, and weather should dictate your route, with airways being very much secondary. If you stick to big valleys (i.e. wider than, say, 5 nm across the valley floor) you will not find it hugely different from any other VFR flying. Nevertheless, at least two things are still a greater risk than in open-country flying: weather changes and winds. The nightmare scenario is that you turn backack from deteriorating weather only to find that the weather behind has deteriorated, too. To prevent getting trapped that way, get a good met briefing from a local briefer, and be sure you understand what the trends are. Then plan and fly your route airport-by-airport, remaining confident at all times that you can either reach the next airport or turn back to the last one. If you get a nagging feeling about the weather at all, do something about it right now. Be sure you understand what factors make the weather unstable and likely to change (way too big a topic to go into here). The big risk with winds in the mountains (beyond what any pilot should already know) is downdrafts. It's possible to have a thousand-foot-per-minute downdraft from a 10 kt wind, although that would be fairly unusual. But if you take 100 times the wind speed (at altitude), in knots, you will get an estimate of the worst-case downdraft you can expect, in feet per minute. If that exceeds your climb rate (at that density altitude and loading condition), avoid narrow valleys, especially where the wind is across the valley, and be cautious even in the wide valleys . (The convention is to fly valleys on the right for traffic separation. But where winds are a factor fly on the downwind side of the valley, because that's where the air is rising.) Think about density altitue all the time. Here are two good rules of thumb: 1. To estimate density altitude, add 1,000 feet to indicated altitude for each 8 degrees C above standard temperature (14 degrees F). 2. Increase sea-level take-off distance by 10% for each 1,000 feet of density altitude. Enjoy yourself! Tedd ________________________________________________________________________________
Date: Sep 24, 2001
And if you stop in Farmington (FMN) give me a call. Free food and shelter. Larry Hawkins, RV-4 Farmington, NM, N-345SL, (reserved) finishing. -----Original Message----- From: Robert Brown [mailto:bkbrown(at)fiberpipe.net] Sent: Monday, September 24, 2001 11:53 AM Subject: Re: RV-List: Crossing Rockies Advise Fort Bridger had no fuel when I flew over on my way back from OSH. Rock Springs is a good place to land, but can be very windy at times. Evanston and Kemmerer have fuel but are both a lot higher...so watch density altitude. We like to cross into the Salt Lake valley two canyons south of Logan. There is a pretty good clearance and you don't have to be too high. You DO need to be aware of the winds though. Logan is a nice airport to land at and is outside SLC class B. From Logan it is a short hop up to KBOI. Another way, the scenic route, is longer but does avoid the highest CO mtns, would be to fly west through Farmington, NM and Page, AZ, then north through Utah...pick your valley and stay in it northward. Either way, plan your trip over highways and airports, and be aware of which airports have fuel, because a lot of the small ones don't. ________________________________________________________________________________
Date: Sep 24, 2001
Subject: Re: Fuel presure fluctuating
Larry, most people using electronic fuel gauges have had this same issue, including myself, what it appears to be is a sender issue. The senders are not as good as they could be, my VDO sender is good to about 1.5 Lb. then it reads anywhere between 2 and 0 Lb.. Tim Lewis did a lot of testing and has posted it to the archives, plus he answered a post to me which I will attach. I wish the lowest mine ever showed was 3.8 Lb.. I see 0 Lb. way to many times . Garry "Casper" relishing every moment I fly LARRY RUSH wrote: > > Fellas, > I flew my RV-6A first flt on 27 July and only have 4.5 hrs to go to get t> he 40 I need, but I one "challenge" I can not seem to solve. The fuel pr> esure fluctuates from 3.8 to 6. lbs while running on the engine driven pu> mp. When I start the engine with elect pump running the pres. is 6+ lbs. > Turn off elect. and it is still 5+ lbs. Take-off and it "may " stay at 5+> lbs. until maybe 15 mins or so into flight then it drops to 3.8 lbs. It > will probably stay there until I decend (say 5500 down to 2500) and it wi> ll raise up to 5.+ lbs again. I have fire sleeve on all fuel lines, and t> ried putting cool air on the gasolator and even sender unit which did not> help. My engine is a 0-360, oil cooler is on left rear baffle, and the f> uel presure gage is a Mitchel w/Mitchel electric sender. Oh yes, I do not> have fire sleeve on the 1/8" I.D. hose running from the carb to the send> er. > > Has anyone had similar problems???? What next?? HELP????? > > Larry, N939LT at 3SY INDY. > > ________________________________________________________________________________
Date: Sep 24, 2001
Subject: Re: Low Fuel Pressure - Lycoming's response]
From: "Tim Lewis" <timrv6a(at)earthlink.net> Date: Sat, 25 Aug 2001 20:26:25 -0400 Subject: (Fwd) Re: RV-List: Low Fuel Pressure - Lycoming's response Here's my Dec 1999 email to the RV list ------- Forwarded message follows ------- From: Self <Single-user mode> Subject: Re: RV-List: Low Fuel Pressure - Lycoming's response Send reply to: timrv6a(at)earthlink.net This morning I installed a "T" fitting after the Facet pump, and hooked my auxiliary fuel tank (which includes and on/off valve) to the "T". This allowed me to draw fuel from my normal system, or to circumvent all the plumbing in my fuel system prior to the firewall. When I turn "on" the auxiliary fuel tank valve, fuel can flow from the aux tank into the fuel system in parallel with the output of the Facet pump. From there, the fuel flows thru the gascolator and to the engine driven pump. Tests at various altitude revealed no significant change in fuel pressure whether I was pulling fuel from the main tanks or from the aux tank. Therefore, neither the Facet pump nor the plumbing in the plane (inline fuel filters, stock Van's fuel selector) is having any significant effect on fuel pressure. I called Lycoming Tech support and spoke to Mike Caldera, who has helped me throughout the engine installation process. Mike's reaction to my flight test data (1 psi at altitude) was "go fly it, I don't have a problem with it." Mike says decreasing fuel pressure with altitude, and especially with cold temperatures, is normal. He said it's a normal side effect of using diaphram fuel pumps. He also noted that a reduction of fuel pressure during high flow (high power) isn't unusual. Mike noted that many Alaskan operators us the AN style pump rather than the diaphram pump because of the effect of cold on the diaphram pump. A different accessory housing is required to use the AN pump. Mike was skeptical of Scott's observation that "All of the carb. equipped airplanes at Van's that I fly run pressures between 4 - 6 PSI at all times." He suggested a closer examination at altitude and when cold. Scott, can you take some measurements from the factory bird(s) at 10,000' or so when you get an opportunity? My remaining challenge is to see if I can find a fuel pressure sender that is accurate. The VDO 0-30 PSI sender I have is unsatisfactory for low pressure measurement (0 - 1.5 psi all produce a "0" signal). Thanks to all who have contributed to this thread. I'd love to see more fuel pressure data from flying RV's. Please mention what type of gauge you use. Thanks, Tim Lewis ------- End of forwarded message ------- ****** Tim Lewis -- Fairfax, VA RV-6A N47TD - First Flight 18 Dec 99 http://www.geocities.com/timrv6a ****** ________________________________________________________________________________
Date: Sep 24, 2001
Subject: [Fwd: RV6 Fuel Pressure]
From: "Tim Lewis" <timrv6a(at)earthlink.net> Date: Sat, 25 Aug 2001 20:24:19 -0400 Subject: Re: RV6 Fuel Pressure Gary Van Remogel , Cy Garry, I did a lot of research, and found out that the VDO fuel pressure transducer has very poor resolution below 2 PSI. I confirmed this with Grand Rapids technology (manufacturer of the EIS), and thru carefully calibrated (water column) tests of two brand new VDO transducers. I then connected a mechanical fuel pressure gauge (temporarily) to the plane and test flew, collecting lots of data. Bottom line is the VDO transducer is not reliable at low fuel pressure. Fuel pressure does go down with increasing altitude, and with low temperature. I don't have my data here at hand, but I believe I saw pressures down below 1 psi during steep climbs at altitude (cold out, too). I called Lycoming Tech support, and they told me this is normal with the diaphram type mechanical fuel pump that comes stock with the O-360-A1A. Regarding low fuel pressure at high altitude, Lycoming tech support said that if the engine runs, don't worry about it. They mentioned that for sustained cold weather operation there is a different fuel pump that can be purchased. I believe they said it is a piston-type pump, and it is frequently used in Alaska. I hope this helps. Tim Lewis On 24 Aug 2001, at 7:25, Garry LeGare wrote: From: Garry LeGare <"versadek"@earthlink.net> Copies to: Paul Bessing , "Owens, Laird" , Gary Van Remogel , Cy Subject: RV6 Fuel Pressure > Hi Tim, > I seem to remember you had a problem with fuel pressure dropping as > altitude increased. What did you do to resolve it? I would really > appreciate a response, as the List and Archives are down. > > Thanks for your help. > Garry LeGare, > Caspers Dad > 25.8 Hrs > ****** Tim Lewis -- Fairfax, VA RV-6A N47TD - First Flight 18 Dec 99 http://www.geocities.com/timrv6a ****** ________________________________________________________________________________
Date: Sep 24, 2001
Larry I have the 0360 carb. I have experienced the same problem especially when climbing to a higher altitude. I have 140hrs and still no change. Joe RV6A --- LARRY RUSH wrote: > > > Fellas, > I flew my RV-6A first flt on 27 July and only have > 4.5 hrs to go to get t> he 40 I need, but I one "challenge" I can not seem > to solve. The fuel pr> esure fluctuates from 3.8 to 6. lbs while running on > the engine driven pu> mp. When I start the engine with elect pump running > the pres. is 6+ lbs. > Turn off elect. and it is still 5+ lbs. Take-off and > it "may " stay at 5+> lbs. until maybe 15 mins or so into flight then it > drops to 3.8 lbs. It > will probably stay there until I decend (say 5500 > down to 2500) and it wi> ll raise up to 5.+ lbs again. I have fire sleeve on > all fuel lines, and t> ried putting cool air on the gasolator and even > sender unit which did not> help. My engine is a 0-360, oil cooler is on left > rear baffle, and the f> uel presure gage is a Mitchel w/Mitchel electric > sender. Oh yes, I do not> have fire sleeve on the 1/8" I.D. hose running from > the carb to the send> er. > > Has anyone had similar problems???? What next?? > HELP????? > > Larry, N939LT at 3SY INDY. > > > > http://www.matronics.com/unsubscribe > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Date: Sep 24, 2001
Andy, Ok, it was a bit dramatic, but the point remains that you can't teach someone to fly in the mountains over the internet. On the Kitfox list, several members gave many pointers to one of our members planning a trip west, but continued to point out that there are many ways to get into trouble and that every possibility couldn't be covered. During the trip he went flying with an experienced mountain pilot (each in their own plane) and despite the direct and timely warnings from the other pilot he managed to get himself killed. I hope this explains why I was a bit dramatic and why I don't think it's a good idea to give mountain flying advice over the internet. It's all too easy for the person on the receiving end to underestimate the hazards that exist. Regards, Cliff > > > PLEASE, PLEASE, PLEASE don't > > venture off into the Rocky Mountains without getting adequate training, > > Yes. All true, but perhaps a bit too dramatic. I do want to add a couple > caveats. > ________________________________________________________________________________ Message-ID: <20010924200422.77454.qmail(at)web13408.mail.yahoo.com>
Date: Sep 24, 2001
So what exactly happened to the Kitfox guy? --So we can learn from his particular mistake? -Larry(at)BowenAero.com --- Clifford Begnaud wrote: > > > Andy, > Ok, it was a bit dramatic, but the point remains that you can't teach > someone to fly in the mountains over the internet. > On the Kitfox list, several members gave many pointers to one of our members > planning a trip west, but continued to point out that there are many ways to > get into trouble and that every possibility couldn't be covered. During the > trip he went flying with an experienced mountain pilot (each in their own > plane) and despite the direct and timely warnings from the other pilot he > managed to get himself killed. I hope this explains why I was a bit dramatic > and why I don't think it's a good idea to give mountain flying advice over > the internet. It's all too easy for the person on the receiving end to > underestimate the hazards that exist. > Regards, > Cliff ________________________________________________________________________________ Message-ID: <3BAF9765.8299AA96(at)rkymtnhi.com>
Date: Sep 24, 2001
From: A&P-IA Bookstore <winterland(at)rkymtnhi.com>
Cliff Agreed 100%!!! Also that I may have been a little too trite with my "just do it" kind of comments. But two facts are worth repeating. 1] In GOOD weather, mountain flying bears few additional dangers than low land flying. In bad weather, it can surprise and kill you. To me, this is basically a matter of being considerably more selective when choosing fly or no-fly days. Cross country pilots need be very aware and comfortable with the fact that your chances of getting stuck at some remote airport while waiting for the weather to clear in Colorado is far greater than it is in Kansas. 2] The RV is a far more capable aircraft than a Kitfox, at least in the realm of penetrating bad weather. Now don't get me wrong. I've got well over 1000 hours in many types of ultralights and "fat" ultralights. They are FUN and capable aircraft. I just wouldn't want to get caught in one in a 25 kt wind on the back side of Hoosier Pass. Now, just for a little bit of totally self serving spam; there is a really good book on Mountain Flying on the Builder's Bookstore by a long term mountain flying instructor named Sparky Imeson. (in the Sport Flying section). It's worth getting. Its also worth spending a few hours with a mountain flying instructor if you can make the opportunity. As Cliff said, you can't learn mountain flying, or any other kind of flying, on the internet. Andy Builder's Bookstore http://buildersbooks.com . ________________________________________________________________________________
Message-ID: <142.2138e7a.28e10856(at)aol.com>
Date: Sep 24, 2001
In a message dated 9/24/01 3:02:56 PM Eastern Daylight Time, K9HXT(at)msn.com writes: << Fellas, I flew my RV-6A first flt on 27 July and only have 4.5 hrs to go to get t he 40 I need, but I one "challenge" I can not seem to solve. The fuel pr esure fluctuates from 3.8 to 6. lbs while running on the engine driven pu mp. >> I think many people see this, particularly in an extended climb. I believe it is because the pressure sender uses a static pressure source that is slow to compensate for altitude (maybe its equivalent to the human "eustation" tube is too small). Assuming this is the case, you'd see artificially low indications in a climb, and artificially high indications during a decent. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, A http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Sep 24, 2001
Message-Id: <200109242337.f8ONb5509684(at)matronics.com> K6XKT01.E84 for Message-ID: <3BAFC367.7080806(at)netscape.com>
Date: Sep 24, 2001
From: mitchf(at)netscape.com (Mitchell Faatz) Subject: Re: RV-List: !!!New RV message board!!! Thor - I appreciate your effort, but I hope people DON'T use it instead of these email lists. All the messages here are archived and can be searched very quickly with Matt's search engine. I'd hate to lose good information. Maybe we can use your messageboard for the RV/political discussions! :) P.S. I *really* wanted to name my son Thor, but my wife wouldn't let me. owner-rv-list-server(at)matronics.com wrote: > >To the best of my knowledge the RV community has not untill now had a >"real" messageboard. > >So I started one! > >you can access it here >http://www.flugfelagid.com/ffmessageb/ubbcgi/ultimatebb.cgi > >or go through our web www.flugfelagid.com (on the menu click >messageboard and it opens in a separate window) > >I hope in time it will be frequented and thus become highly useful and >entertaining for everyone. > >To post you will need to register. > >Thor Hardarson >Iceland > >Building a RV-9 empennage > > ________________________________________________________________________________ Message-ID: <000c01c14552$68ed46e0$0200a8c0@jayeandscott>
From: "Jaye and Scott Jackson" <jayeandscott(at)home.com>
Date: Sep 24, 2001
Don't know if this applies to avgas the way it applies to jetfuel but there is a problem-especially in the DC-8- wherein a fast climb to a cold altitude with a load of warm fuel led to fuel flow fluctuations and the occasional flameout. Also, the maximum suction-feeding altitude tables for some airliners(when the tank pumps fail and the engine has to draw the fuel out using the vacuum created at the lowpressure, engine-driven pump inlet augmented by gravity) have two columns. The column used to determine the maximum altitude is dependent upon tank temperature and time at altitude before pump failure. This would decide whether or not the fuel has had time to de-aerate. If it hasn't, the altitude can be quite low-down to 15,000' for the A340. With the RV's outstanding climb rate, it is conceivable that- if avgas also has this characteristic-the fuel could be fizzing away like a soft drink at high altitudes and this may be detectable in the resulatant fuel flow fluctuations. Scott in Vancouver ----- Original Message ----- From: <KBoatri144(at)aol.com> Sent: Monday, September 24, 2001 3:06 PM Subject: Re: RV-List: Fuel presure fluctuating > > In a message dated 9/24/01 3:02:56 PM Eastern Daylight Time, K9HXT(at)msn.com > writes: > > << Fellas, > I flew my RV-6A first flt on 27 July and only have 4.5 hrs to go to get t> he 40 I need, but I one "challenge" I can not seem to solve. The fuel pr> esure fluctuates from 3.8 to 6. lbs while running on the engine driven pu> mp. >> > > I think many people see this, particularly in an extended climb. I believe it > is because the pressure sender uses a static pressure source that is slow to > compensate for altitude (maybe its equivalent to the human "eustation" tube > is too small). Assuming this is the case, you'd see artificially low > indications in a climb, and artificially high indications during a decent. > > Kyle Boatright > 0-320/Aymar Demuth RV-6 Slider > Kennesaw, > A > http://www.angelfire.com/my/rv6 > > ________________________________________________________________________________
Message-Id: <200109242348.f8ONmkN15383(at)matronics.com>
Date: Sep 24, 2001
arry Le are <"versadek"@earthlink.net>
Message-Id: Kyle, Tim Lewis spent many hours researching this issue with his supplier, rand Rapids Technology. I did the same with RMI my supplier and we both found the vent is not the problem, at least on our systems. The VDO sender has a large relief area, its so large in fact, it is equipped with a filter. I have also had this happen on the ground when I shut off the electric fuel pump after start up. I believe Tim's findings are the most logical as it is not unusual for Lycoming's fuel pressure to fall below 2 Lb. and I'll bet your fuel pressure is falling below the 3.8 that you are seeing, but your sender isn't deciphering it correctly. Lycoming states .5 to 8 Psi is except able fuel pressure. When mine drops to "0", I turn on the pump for a while, the pressure comes up and I stop worrying about it. If your RV's engine hasn't hiccuped, then just enjoy flying and don't worry about it. By the way has the grin mellowed yet? With over 40 Hr. on "Casper" Dianne and I are like a couple of kids, planning our next trip. arry KBoatri144(at)aol.com wrote: > I think many people see this, particularly in an extended climb. I believe it > is because the pressure sender uses a static pressure source that is slow to > compensate for altitude (maybe its equivalent to the human "eustation" tube > is too small). Assuming this is the case, you'd see artificially low > indications in a climb, and artificially high indications during a decent. > > Kyle Boatright > 0-320/Aymar Demuth RV-6 Slider > Kennesaw, > A > http://www.angelfire.com/my/rv6 > > ________________________________________________________________________________ Message-ID: <008b01c1455b$f88068b0$6401a8c0@micron>
Date: Sep 24, 2001
Here's the ntsb prelim report: http://www.ntsb.gov/ntsb/brief.asp?ev_id 010901X01850&key=1 Also, see this accident report. http://www.ntsb.gov/ntsb/brief.asp?ev_id 010807X01625&key=1 > > So what exactly happened to the Kitfox guy? --So we can learn from his > particular mistake? > > ________________________________________________________________________________
Date: Sep 24, 2001
Message-Id: <200109250135.f8P1ZVg13223(at)matronics.com> E2JIXPbve0ytzJdcg=="> by m4.jersey.juno.com (queuemail) id
Date: Sep 24, 2001
Subject: RV-List: EL Cockpit Lighting Message-ID: <20010924.203755.-263081.1.czechsix(at)juno.com> From: czechsix(at)juno.com uys, I posted this to the Aeroelectric list but thought I'd copy it to the RV list also. If anyone has used EL lighting in their airplane I'd be interested in your comments.... ---------------------------- Bob (or anyone else who wants to jump in), I am considering using electroluminescent lighting in my RV-8A cockpit. Specifically, there's a brand-name called "Flatlite" that can be obtained in almost any shape or size, and all the colors of the rainbow. The distributor I've been talking to is at http://beingseentechnologies.goemerchant2.com. My intent is to get a 2" x 24" strip (blue, green, or white.....haven't decided which color yet) and stick it to the underside of my glareshield. It won't be directly visible when seated in the cockpit, but it will cast a soft glow down on the panel. This seems to be an ideal way to light the panel with a minimum of glare on the panel or canopy. The product is dimmable by varying the input voltage from 12 VDC down to 7 VDC (after which it shuts off). Now for my question: the Flatlite kit uses an inverter which takes in the aformentioned DC and converts it to 280 VAC at 850 Hz. Do you think that this could cause noise or interference problems with the audio, or any other system? The tech rep I talked to did not think it would be an issue if grounded correctly at the firewall, based on experience with cars and boats. Any other input on this subject.....anyone who's tried it....any problems or gotchas.....speak up before I send my $65. Thanks, --Mark Navratil Cedar Rapids, IA RV-8A fuselage... ________________________________________________________________________________ 22229
Date: Sep 24, 2001
Message-Id: <200109250200.f8P20J 22229(at)matronics.com> K700LBC46S6U(at)mta2.snfc21.pbi.net> for rv-list(at)matronics.com;
Date: Sep 24, 2001
From: Matthew elber Subject: RV-List: Anyone with an 8A IO-360 exhaust? Message-id: I'm having a little trouble getting my Vetterman (Van's) exhaust on my engine. The engine is an IO-360-A1B6, and the plane is an 8A. I think I might have the 8 exhaust- the clearances around the nose gear seem very small. If anyone out there has this setup it would be swell if I could email you some pictures and have you tell me if I've got the right one. (The box said 8, not 8A, so I'm suspicious) Matthew 8A N48PP reserved feeling like a king with that engine on there ________________________________________________________________________________
Date: Sep 24, 2001
Message-ID: <20010924.210809.-133843.0.rvsixer(at)juno.com>
> > Eric, > I am all for buying American products. I drive two > American cars. > I fly an Aribus for a major airline and I thought I would just let > you know > that 65 to 70% of the Airbus consists of American made components. > The > engines are eneral Electric. The onboard computers (more than 70 > of them) > are Honeywell. The list of American components on the airbus is a > long and > distinguished one. Well, I fix Airbuses for a major airline and if you go down the "basement" where all those computers reside, you won't see very many familiar names. Same thing in the wheelwells. All those pumps, valves, actuators, etc, that make that Airbus such a delight to fly are virtually all made in England, ermany, or France. Still a good airplane (our dispatch rate proves it) but let's not portray it as mostly U.S. made... Mike Hilger RV-6 N207AM, 130 hours ________________________________________________________________________________
Date: Sep 24, 2001
Message-ID: <00cb01c14568$2d839d00$27c159d8@comfort-home>
ordon or Marge Comfort"
Date: Mon, 24 Sep 2001 20:56:13 -0400 -From: Eric Newton <enewton57(at)cableone.net> Subject: RV-List: Crossing Rockies Advise >A navigation question for all of you experienced flyers. What is the >best route (without oxygen) to get across the Rocky Mountains if you >departing from Oklahoma or Kansas with Boise, Idaho as your destination. Eric: Suggest you look at going to Cheyenne,Wy, then west toward Rawlins, staying a bit north to skirt the highest points and from there look at going toward Bear Lake. West of Bear Lake there is a series of ridges to cross, the highest of which are around 9000', I believe. If it is windy the ride would be kind of rough. Once you reach the Snake River Plain, the route to Boise is comfortable. An alternative might be Rawlins, Rock Springs, Ogden UT and then northwest to the Snake River Plain. Or you could go Cheyenne, Riverton WY, DuBois, Jackson Lake to JAC Wy. The Tetons are very pretty. From Jackson, fly a bit south and either go west through the Teton Pass or over the ridge just north of the pass and that puts you into the Snake River Plain, past Idaho Falls and then you can skirt the high ground and just follow the north edge of the Plain as it curves around toward Boise. The routes I've described are not difficult if the weather is good. If the weather is bad, stay put. Some clouds have rocks in them. ordon Comfort N363 C ________________________________________________________________________________
Date: Sep 24, 2001
Message-ID: <00ca01c14568$2c1b8180$27c159d8@comfort-home>
Date: Mon, 24 Sep 2001 20:28:51 -0400 From: Doug Weiler <doug.weiler(at)pressenter.com> Subject: Re: RV-List: Crossing Rockies Advise >Speaking of mountain fly, we are planning a flight from Minneapolis to >Jackson Hole in a week. Can any of you mountain guys suggest a nice VFR >route into there from the East for my RV-4? >Doug Weiler Doug: A good first stop en route to Jackson Hole is Rapid City, SD. From there I usually fly to Jackson direct but that does take you over some rugged, albeit not terribly high terrain. If you prefer to stay over lower country, you can head from Rap City toward Riverton WY and thence up the valley past DuBois and out over Jackson Lake at the dam. From there the airport is a bit south and if you are landing to the south the only terrain feature of note is Black Tail Butte just off the airport to the northeast. ordon Comfort N363 C ________________________________________________________________________________ Message-ID: <006701c1456c$895f6740$7d537418@EricMichelle>
Subject: Proud Papa
Date: Sep 24, 2001
Listers, While waiting patiently for the FAA to contact me to schedule the final inspection, I took some pictures of my nearly complete RV-6A (N57ME) and posted one to the front page of my website. Anyone interested can go there. I have chosen to hold off on installing the wheel pants and gear leg fairings and painting until my first few fights and any "tweaking". Just had to share . . .to everyone on the list who put up with and patiently answered my seemingly endless beginner's questions - a big THANKS to you all ! ! ! I'll let you know how the inspection goes. Then its off to Florida for a little transition training with John Henley before my first flight. Blue Skies, Eric Newton - Long Beach, MS RV-6A N57ME (waiting for FAA inspection) www.ericsrv6a.com ________________________________________________________________________________
Date: Sep 24, 2001
Message-ID: <001f01c1456d$658ee560$dda12b04@vz.dsl.genuity.net>
ene"
Subject: Insulation
Date: Mon, 24 Sep 2001 19:54:28 -0700 What are your thoughts on insulating the belly and firewall of the rv's. I will defiantly insulate the firewall but I am unsure on the benefits of doing the area under the seats and the baggage area. Any comments? ene 90296 ________________________________________________________________________________
Message-ID: <35.1b550569.28e14cf5(at)aol.com>
Date: Sep 24, 2001
In a message dated 9/24/01 7:25:53 AM Pacific Daylight Time, enewton57(at)cableone.net writes: << A navigation question for all of you experienced flyers. What is the best route (without oxygen) to get across the Rocky Mountains if you departing from Oklahoma or Kansas with Boise, Idaho as your destination. I am still waiting for my FAA inspection but I'm already planning cross country trips ;>) >> I'd head for Cheyenne, up over Bear Lake, then into the Snake River Plain for the downhill run. Lots of relatively flat country along the way, but likely cross and head winds from the west on the Wyoming leg. - V (RV-6A N1 V) vanremog(at)aol.com ________________________________________________________________________________ Message-ID: <002201c14572$3e5f3620$71cdbb3f@smokin>
Subject: Approach Plate Holder
Date: Sep 24, 2001
When I was at Van's Homecoming, I saw a plane with an approach plate holder attached to the left side of the fuselage. Any idea who it is and if there are pictues available? Because the canopy was closed, i couldn't see how it was attached. Ross Mickey ________________________________________________________________________________
Date: Sep 24, 2001
Message-Id: <200109250521.f8P5LkU12704(at)matronics.com> K7005F7DK0KW(at)mta7.pltn13.pbi.net> for rv-list(at)matronics.com;
Date: Sep 24, 2001
From: Ken Cantrell <kcflyrv(at)pacbell.net> Subject: RV-List: Canopy cracks Message-id: <00ef01c14582$166d2040$0400a8c0@pacbell.net> Hello fellow listers, I'm well along the home stretch of finishing my RV6 QB. I just finished bonding my wind screen to the foward top skin and roll bar. I'm happy with the results. What I just discovered has made me soooo depressed. I took my canopy down from the loft in my shop and noticed that one of the rivets along the front bow did not hold. It appeared that the rivet was not long enough to go through the needed spacers and the canopy frame. I should have simply ordered some longer rivets but for whatever reason I decided to tap the hole and install a flathead #6 screw. So far so good. I thought it would be a good idea to put some lock-tight to keep it tight. WRON ! A few days later I was sickened to see a star of cracks surrounding the screw. I was careful not to over tighten the screw so I knew this was not the cause. When I called Van's this morning to ask for a miracle, I was told that the lock-tight can cause a reaction to the plexiglass and this was likely what happened. I was told that sometimes the cracks don't grow too far but I somehow don't think I'll be that lucky. I'm really not looking forward to another canopy job but if I must, it will be done. I know there is some one out there who has been down this road before. I would really appreciate any advice or suggestions. At this point the cracks go out from the edge of the hole about 3/8 to 1/2 inch. Is it time to order a new one? Ken Cantrell N34KC reserved ________________________________________________________________________________
Date: Sep 24, 2001
Message-Id: <200109250600.f8P60oq17902(at)matronics.com> X6918.femail44.sdc1.sfba.home.com@c59282a> Message-ID: <01c301c14585$5da8e040$44310018@c59282a>
Subject: Re: RV-List: Approach Plate Holder Date: Mon, 24 Sep 2001 22:46:04 -0700 > When I was at Van's Homecoming, I saw a plane with an approach plate holder > attached to the left side of the fuselage. Any idea who it is and if there > are pictues available? Because the canopy was closed, i couldn't see how it > was attached. > > Ross Mickey That might have been me (red/white RV-6) , or possibly my buddy Dan Benua (Blue/Beige RV-6A). He's not on the list. I stole the idea from him although I attached mine a little differently than he did. Easier to explain with pictures -- If you're not in a hurry I'll try to get some pictures of both installations next chance I get. Randall Henderson, RV-6 N6R (~280 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Date: Sep 24, 2001
Message-ID: <01d001c14586$8735d1b0$44310018@c59282a>
Rr07073(at)matronics.com>
Subject: Re:
et out of Class B Date: Mon, 24 Sep 2001 22:54:23 -0700 > What I was told about planes getting out of the class B air space arround > Dallas and Ft Worth was to go out as a flight of 2 or 3 with only one filing > a IFR flight plan to a airport out of the class B. [snip] I've heard a lot of "I was told this" and "I was told that" about getting out of class B, from tower controllers to FSDOs, often conflicting with each other. However, the FARs, as I read them, say you need to be an IFR rated pilot, with an IFR equipped bird, to fly IFR. Perhaps there's some loophole or regulatory change that I don't know about, but if I were in the unfortunate position, particularly in these sensitive times, I'd want to be REALLY careful to either a) do it by the book, or b) get a written clarification from the FAA. In the end, the only *opinion* that's going to matter is the administrative law judge's.... Randall Henderson, RV-6 N6R (~280 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Date: Sep 24, 2001
Message-Id: <200109250626.f8P6QVM24799(at)matronics.com> X ([64.171.12.97]) by mta5.snfc21.pbi.net (iPlanet Messaging Server 5.1 (built May 7 2001)) with SMTP id <0 K7005YU K2 7(at)mta5.snfc21.pbi.net> for rv-list(at)matronics.com;
Date: Sep 24, 2001
From: "F. Parker Thomas" <me(at)parkerthomas.com> Subject: RV-List: prop questions Message-id: Hi to all listers - A few questions for you: * Has anyone installed a constant speed prop that was ground down from 72 to 70 inches? The prop had minor damage and has been overhauled by a supposedly reputable prop shop and stamped experimental. I find myself a little hesitant. I examined the airplane on which it was damaged - damage to the plane was indeed minor. * Does anyone have a wiring diagram for a Terra (now Trimble) TRT 250D transponder? * Are there any manuals for Lycoming engines written by third parties such as the Chilton series of books for cars? Looking for hookup information for an IO-360 A1B6. is the Lycoming manual the best? * Does anyone have a recommendation of an inexpensive CAD program to layout a panel? I've not heard good things about panel planner, want something a little more detailed than Bill VonDane's site (looks great though) and find myself incredulous that the best way is a big sheet of paper. Are there panel engravers that can do the cutting from a computer file? Thanks for all of your help. Parker Thomas F. Parker Thomas PO Box 190894 San Francisco, CA 94119 parker(at)iname.com ________________________________________________________________________________
Date: Sep 25, 2001
Subject: RE: prop questions
Greetings to all listers - I noticed van's guide mentioned bending the edge of overlapping pieces of metal on the fuselage and wings. Has anyone done this where the wing skins meet at the main spar? I'm worried about the skins flexing up on the outside of the rivet lines. Thanks, Parker F. Parker Thomas PO Box 190894 San Francisco, CA 94119 parker(at)iname.com ________________________________________________________________________________
Subject:
From: "Conney Karlsson" <conney.karlsson@iss-sverige.se>
Date: Sep 25, 2001
25-09-2001 11:02:20 Jag r borta frn kontoret frn 2001-09-24 till 2001-09-28. ________________________________________________________________________________
Date: Sep 25, 2001
Subject: Re: Insulation, was: nothing
--- wrote: > Gene" > What are your thoughts on insulating the belly and firewall of the > rv's. > I will defiantly insulate the firewall but I am unsure on the > benefits > of doing the area under the seats and the baggage area. > Any comments? > > > Gene 90296 Gene, Opinions vary (No!) but FWIW you will find that enough insulation to help will add a lot of weight to your aircraft. 1) Insulate the firewall for sure against heat and a start against noise. 2) Attach (glue) 2"x6" pieces of the firewall insulation to the large open unsupported skin areas inside your fuselage to dampen oil drumming. 3) Lay down some insulation in the floor and cover with a light carpet or thin sheet aluminum against heat and noise from the exhaust. 4) Buy ANR headsets to do the rest! Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Subject: Re: Proud Papa
Date: Sep 25, 2001
Good idea for the Flight training. Now find an EAA flight Advisor and set up a flight test team and test procedures. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org http://www.eaa.org for latest flying rules ----- Original Message ----- From: "Eric Newton" <enewton57(at)cableone.net> Subject: RV-List: Proud Papa Listers, While waiting patiently for the FAA to contact me to schedule the final inspection, I took some pictures of my nearly complete RV-6A (N57ME) and posted one to the front page of my website. Anyone interested can go there. I have chosen to hold off on installing the wheel pants and gear leg fairings and painting until my first few fights and any "tweaking". Just had to share . . .to everyone on the list who put up with and patiently answered my seemingly endless beginner's questions - a big THANKS to you all ! ! ! I'll let you know how the inspection goes. Then its off to Florida for a little transition training with John Henley before my first flight. Blue Skies, Eric Newton - Long Beach, MS RV-6A N57ME (waiting for FAA inspection) www.ericsrv6a.com ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Subject: EL Cockpit Lighting
Date: Sep 25, 2001
Mark, I tried this type of product in my IFR RV-6A, after seeing it at Sun 'N Fun a couple of years ago. I found that, even with additional power supply filtering, the AC noise effected my radios. I didn't investigate any further, but felt that the IFR operation warranted the more common lighting solutions...... Fred Stucklen N925RV (1840 hrs/8 Yrs) E. Windsor, CT 06088 WK Email: stuckle(at)ifc.utc.com Hm/Travel Email: wstucklen1(at)juno.com Subject: AeroElectric-List: EL Cockpit Lighting Message-ID: <20010924.203755.-263081.0.czechsix(at)juno.com> From: czechsix(at)juno.com --> AeroElectric-List message posted by: czechsix(at)juno.com Bob (or anyone else who wants to jump in), I am considering using electroluminescent lighting in my RV-8A cockpit. Specifically, there's a brand-name called "Flatlite" that can be obtained in almost any shape or size, and all the colors of the rainbow. The distributor I've been talking to is at http://beingseentechnologies.goemerchant2.com. My intent is to get a 2" x 24" strip (blue, green, or white.....haven't decided which color yet) and stick it to the underside of my glareshield. It won't be directly visible when seated in the cockpit, but it will cast a soft glow down on the panel. This seems to be an ideal way to light the panel with a minimum of glare on the panel or canopy. The product is dimmable by varying the input voltage from 12 VDC down to 7 VDC (after which it shuts off). Now for my question: the Flatlite kit uses an inverter which takes in the aformentioned DC and converts it to 280 VAC at 850 Hz. Do you think that this could cause noise or interference problems with the audio, or any other system? The tech rep I talked to did not think it would be an issue if grounded correctly at the firewall, based on experience with cars and boats. Any other input on this subject.....anyone who's tried it....any problems or gotchas.....speak up before I send my $65. Thanks, --Mark Navratil Cedar Rapids, IA RV-8A fuselage... ________________________________________________________________________________
Subject: Re: RE: overlapping pieces
Date: Sep 25, 2001
I used a neat tool called an edge former tool. I got it from Cleveland tools. Check out Sam Buchanan's review of it by going to this page: http://home.hiwaay.net/~sbuc/journal/formtool.html Happy Building, Eric Newton - Long Beach, MS RV-6A - N57ME (waiting for FAA inspection) www.ericsrv6a.com <> ________________________________________________________________________________
Date: Sep 25, 2001
Subject: RV-8 project with engine
This isn't a great time to be a contract employee at Boeing, so I'm now *really* looking to sell the RV-8 project and the IO-360. The sheet metal work was beautifully done by Martin Sutter, and the wiring, plumbing, engine installation, and canopy are yet to be done. The engine is a first runout from a Mooney. I figure it's worth over 30, but I'll take less. Ed Wischmeyer 425 898-9856 edwisch(at)alum.mit.edu ________________________________________________________________________________
Subject: Re: EL Cockpit Lighting
Date: Sep 25, 2001
FWIW, you might look at the Fiberlite system . . . www.fiberlite.com or Aircraft Spruce. I haven't powered mine up yet, but installation has been quite easy and one bulb lights the entire panel. Rick Jory RV8A ----- Original Message ----- From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com> Subject: RV-List: EL Cockpit Lighting > > Mark, > > I tried this type of product in my IFR RV-6A, after seeing it at Sun 'N > Fun a couple of years ago. I found that, even with additional power supply > filtering, the AC noise effected my radios. I didn't investigate any > further, but felt that the IFR operation warranted the more common lighting > solutions...... > > Fred Stucklen > N925RV (1840 hrs/8 Yrs) > E. Windsor, CT 06088 > WK Email: stuckle(at)ifc.utc.com > Hm/Travel Email: wstucklen1(at)juno.com > > Subject: AeroElectric-List: EL Cockpit Lighting > Message-ID: <20010924.203755.-263081.0.czechsix(at)juno.com> > From: czechsix(at)juno.com > > --> AeroElectric-List message posted by: czechsix(at)juno.com > > Bob (or anyone else who wants to jump in), > > I am considering using electroluminescent lighting in my RV-8A > cockpit. > Specifically, there's a brand-name called "Flatlite" that can be > obtained > in almost any shape or size, and all the colors of the rainbow. The > distributor I've been talking to is at > http://beingseentechnologies.goemerchant2.com. My intent is to get > a 2" > x 24" strip (blue, green, or white.....haven't decided which color > yet) > and stick it to the underside of my glareshield. It won't be > directly > visible when seated in the cockpit, but it will cast a soft glow > down on > the panel. This seems to be an ideal way to light the panel with a > minimum of glare on the panel or canopy. The product is dimmable by > varying the input voltage from 12 VDC down to 7 VDC (after which it > shuts > off). > > Now for my question: the Flatlite kit uses an inverter which takes > in > the aformentioned DC and converts it to 280 VAC at 850 Hz. Do you > think > that this could cause noise or interference problems with the audio, > or > any other system? The tech rep I talked to did not think it would > be an > issue if grounded correctly at the firewall, based on experience > with > cars and boats. > > Any other input on this subject.....anyone who's tried it....any > problems > or gotchas.....speak up before I send my $65. > > Thanks, > > --Mark Navratil > Cedar Rapids, IA > RV-8A fuselage... > > ________________________________________________________________________________
Date: Sep 25, 2001
Subject: Moving project
It looks like I'm going to need to move my project from MA to TX at the end of next month. I'd like to get some input on how best to do this. I'm figuring on something like a 24' Ryder truck, but would like to hear from anyone who has actually done a project move like this. Assuming that I can't screw braces into the truck's floor, how should I secure my RV in place for the move? Any ideas? -- Regards, Ken Balch Ashland, MA RV-8 #81125 (N118KB) installing engine stuff groups.yahoo.com/group/BostonRVBuilders/files/ ________________________________________________________________________________
Subject: Re: Moving project
Date: Sep 25, 2001
Ratchet straps on the engine mount, gear legs and tail wheel tube, all pulling in opposite directions, meaning for every ratchet strap you install, install another one pulling opposite. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Ken Balch" <kbalch1(at)mediaone.net> Subject: RV-List: Moving project It looks like I'm going to need to move my project from MA to TX at the end of next month. I'd like to get some input on how best to do this. I'm figuring on something like a 24' Ryder truck, but would like to hear from anyone who has actually done a project move like this. Assuming that I can't screw braces into the truck's floor, how should I secure my RV in place for the move? Any ideas? -- Regards, Ken Balch Ashland, MA RV-8 #81125 (N118KB) installing engine stuff groups.yahoo.com/group/BostonRVBuilders/files/ ________________________________________________________________________________
From: "EXT-Richard, Emmanuelle J" <emmanuelle.j.richard(at)boeing.com>
Date: Sep 25, 2001
My RV4 was moved (FL to WA) using the same truck you are mentioning without any damage whatsoever. The wings were on a craddle. Wheels where secured by 2x4 nailed to the floor of the truck and straps tied to the engine mounts and tailwheel. Screw braces in the floor truck if you wish. From experience, I won't use Ryder again. If you do, make sure you inspect the truck they give you!!! Don't accept one due for it's 100 000 mile service, that has bald tires and is going to do 35mph foot-to-the-floor in the hills at 7 miles to the gallon. I wasn't the one who had to drive and it was all the more embarassing to have my friends go through this. Emmanuelle J. Richard > ---------- > From: Ken Balch[SMTP:kbalch1(at)mediaone.net] > Reply To: rv-list(at)matronics.com > Sent: Tuesday, September 25, 2001 6:19 AM > To: rv-list(at)matronics.com > Subject: RV-List: Moving project > > > It looks like I'm going to need to move my project from MA to TX at the > end of next month. I'd like to get some input on how best to do this. > > I'm figuring on something like a 24' Ryder truck, but would like to hear > from anyone who has actually done a project move like this. Assuming > that I can't screw braces into the truck's floor, how should I secure my > RV in place for the move? > > Any ideas? > > -- > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 (N118KB) > installing engine stuff > groups.yahoo.com/group/BostonRVBuilders/files/ > > > > > > > ________________________________________________________________________________
Date: Sep 25, 2001
on 9/25/01 04:41, Mike Thompson at grobdriver(at)yahoo.com wrote: > > --- wrote: >> Gene" > >> What are your thoughts on insulating the belly and firewall of the >> rv's. >> I will defiantly insulate the firewall but I am unsure on the >> benefits >> of doing the area under the seats and the baggage area. >> Any comments? >> >> >> Gene 90296 > > > Gene, > > Opinions vary (No!) but FWIW you will find that enough insulation to > help will add a lot of weight to your aircraft. > > 1) Insulate the firewall for sure against heat and a start against > noise. > 2) Attach (glue) 2"x6" pieces of the firewall insulation to the large > open unsupported skin areas inside your fuselage to dampen oil > drumming. > 3) Lay down some insulation in the floor and cover with a light carpet > or thin sheet aluminum against heat and noise from the exhaust. > 4) Buy ANR headsets to do the rest! > > Mike Thompson > Austin, TX > -6 N140RV (Reserved) > Firewall Forward > This sounds like (pun) an excellent approach, one I've followed to the letter and am happy. I got this same advice from George Orndorff a few years ago. George is selling some lightweight insulating material and carpet now which have templates for installing and instructions. I recently got some and am very happy with the product and service. D Walsh 900 hours in 4.4 years, zero in the last two weeks. ________________________________________________________________________________
Date: Sep 25, 2001
11:12:00 AM Ken, one thing I learned from moving my wings from CA to FL. Don't put padding under your leading edges. Keep them flat on a very smooth surface. All the bounces will work the metal around the leading edge ribs and make little bumps where the ribs are. You can imagine how thrilled I was to learn this. Eric Henson Ken Balch (at)matronics.com on 09/25/2001 09:19:13 AM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RV-List: Moving project It looks like I'm going to need to move my project from MA to TX at the end of next month. I'd like to get some input on how best to do this. I'm figuring on something like a 24' Ryder truck, but would like to hear from anyone who has actually done a project move like this. Assuming that I can't screw braces into the truck's floor, how should I secure my RV in place for the move? Any ideas? -- Regards, Ken Balch Ashland, MA RV-8 #81125 (N118KB) installing engine stuff groups.yahoo.com/group/BostonRVBuilders/files/ ________________________________________________________________________________
From: Eric Newton <ENewton(at)beaurivageresort.com>
Subject: Proud Papa
Date: Sep 25, 2001
Already done - Thanks Cy -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Cy Galley Subject: Re: RV-List: Proud Papa Good idea for the Flight training. Now find an EAA flight Advisor and set up a flight test team and test procedures. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org http://www.eaa.org for latest flying rules ----- Original Message ----- From: "Eric Newton" <enewton57(at)cableone.net> Subject: RV-List: Proud Papa Listers, While waiting patiently for the FAA to contact me to schedule the final inspection, I took some pictures of my nearly complete RV-6A (N57ME) and posted one to the front page of my website. Anyone interested can go there. I have chosen to hold off on installing the wheel pants and gear leg fairings and painting until my first few fights and any "tweaking". Just had to share . . .to everyone on the list who put up with and patiently answered my seemingly endless beginner's questions - a big THANKS to you all ! ! ! I'll let you know how the inspection goes. Then its off to Florida for a little transition training with John Henley before my first flight. Blue Skies, Eric Newton - Long Beach, MS RV-6A N57ME (waiting for FAA inspection) www.ericsrv6a.com ________________________________________________________________________________
Date: Sep 25, 2001
When we "box them up" at Oshkosh, we nail and screw into most any wood we find in the U-Haul. One neat thing for wings is to make a sling out of those cheap plastic traps and hang from the truck sides nose down. I think you will find nail and screw holes in the floor. If not wedge a 2 by across the bed and fasten into that. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Call me 309-788-3238 if you have a question. We've shipped clear to England without a problem, to California by U-Haul. ----- Original Message ----- From: "Ken Balch" <kbalch1(at)mediaone.net> Subject: RV-List: Moving project It looks like I'm going to need to move my project from MA to TX at the end of next month. I'd like to get some input on how best to do this. I'm figuring on something like a 24' Ryder truck, but would like to hear from anyone who has actually done a project move like this. Assuming that I can't screw braces into the truck's floor, how should I secure my RV in place for the move? Any ideas? -- Regards, Ken Balch Ashland, MA RV-8 #81125 (N118KB) installing engine stuff groups.yahoo.com/group/BostonRVBuilders/files/ ________________________________________________________________________________
Date: Sep 25, 2001
Subject: Re: Edge Forming(was prop questions)
Hi Parker- Some listers have reported good results not doing this, but I wimped out and bought a Vosburgh edge former from Cleaveland (www.cleavelandtool.com) and am satisfied with the results. When used properly, it will put a very slight bend on the outside 3/16 (approx.) of the skin. I do recommend that you experiment with the gap between the rollers on scrap of the same thickness and coating (vinyl still on or not) to get the setting correct. If you get the rollers too close you will get a very pronounced crease where the angle on the rollers starts. Get just enough of a bend so it is detectable with a straightedge laid perpendicular to the edge, perhaps 1/32" gap showing. You can do this with the vinyl still on or off, but I seem to get a nicer bend with the vinyl on although it is more difficult to examine the results until the metal is bare. Just be darn sure you bend the edges before you dimple! (consider yourself warned- but even if you forget, you can still bend between the dimples, not quite as pretty but it still does the job...B.T.D.T.!!) From the PossumWorks in TN Mark Phillips "F. Parker Thomas" wrote: > > Greetings to all listers - > > I noticed van's guide mentioned bending the edge of overlapping pieces of > metal on the fuselage and wings. Has anyone done this where the wing skins > meet at the main spar? I'm worried about the skins flexing up on the > outside of the rivet lines. > > ________________________________________________________________________________
Date: Sep 25, 2001
Great! Let me know the details when the day comes. I like to publish good stories about safe test flying. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org http://www.eaa.org for latest flying rules ----- Original Message ----- From: "Eric Newton" <ENewton(at)beaurivageresort.com> Subject: RE: RV-List: Proud Papa Already done - Thanks Cy -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Cy Galley Subject: Re: RV-List: Proud Papa Good idea for the Flight training. Now find an EAA flight Advisor and set up a flight test team and test procedures. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org http://www.eaa.org for latest flying rules ----- Original Message ----- From: "Eric Newton" <enewton57(at)cableone.net> Subject: RV-List: Proud Papa Listers, While waiting patiently for the FAA to contact me to schedule the final inspection, I took some pictures of my nearly complete RV-6A (N57ME) and posted one to the front page of my website. Anyone interested can go there. I have chosen to hold off on installing the wheel pants and gear leg fairings and painting until my first few fights and any "tweaking". Just had to share . . .to everyone on the list who put up with and patiently answered my seemingly endless beginner's questions - a big THANKS to you all ! ! ! I'll let you know how the inspection goes. Then its off to Florida for a little transition training with John Henley before my first flight. Blue Skies, Eric Newton - Long Beach, MS RV-6A N57ME (waiting for FAA inspection) www.ericsrv6a.com ________________________________________________________________________________
Subject: Re: Approach Plate Holder
Date: Sep 25, 2001
It may have been mine - it's pretty simple, but I use it all the time. I didn't want to tear up a kneeboard, so I bought a suitable approach plate clip that just happened to be a attached to a $1.00 Walmart clipboard. It was held on with two rivets which were drilled out. It was then a simple matter of using the two existing holes to drill through the formed channel (the one that rests on the main longerons) at a suitable location and securing it with a couple of pop rivets. I can get a picture of it if you want, but there really isn't much else to it. Ed Bundy - RV6A N427EM 400+ hours 160hp 0320 w/Sensenich 70x78 Eagle, ID ebundy(at)velocitus.net > When I was at Van's Homecoming, I saw a plane with an approach plate holder > attached to the left side of the fuselage. Any idea who it is and if there > are pictues available? Because the canopy was closed, i couldn't see how it > was attached. ________________________________________________________________________________
Date: Sep 25, 2001
I moved my project from NJ to MA and used a 24' U-Haul truck. My engine was mounted, but I unmounted the horiz and vert stabs. I used a piece of scrap TemperFoam in front of the engine's prop flange and secured the engine mount to the front of the truck with nylon webbing straps that had a ratchet adjustment to take up the slack (useful after driving 15 - 20 miles and 100 miles).. I secured the tail wheel to the side of the truck with another elastic strap. I used the Tony Bingelis wing cradle (scrap carpet) to cradle both wings vertically and secured the cradle to the side of the track with more of the adjustable nylon straps. I wrapped the tail feathers in blankets and foam (obtained scrap foam from a furniture upholsterer - they had tons of scrap for free). As indicated above, after a few miles, stop and retighten the straps - you sure don't want anything loose around there. I checked them about every 75 - 100 miles (about the maximum distance I could handle with the truck ride :-). After the first couple of adjustments, there wasn't any further need, but I still checked. The biggest problem was getting access to, e.g., toll booth lanes. No one wants to let in a 24' truck. Fortunately, my adult daughter was riding shotgun and, on one occasion, she jumped out, stopped traffic, and I got in. She has more guts than I do. :-) The project survived in excellent shape - not a mark on it at all. I strongly recommend a few helpers to get the project into the truck. Since my -4 was on the gear, I used a couple of 2x10 planks as ramps for the main wheel with a helper holding the tailwheel. I used a "Come-Along" (sp?) - a ratcheting cable device. It was most helpful both getting the project into the truck as well as getting it off the truck. Once before, I moved the project to an airport hangar and did not use the ComeAlong and my helper couldn't prevent the fuse from rolling down the ramp. I blocked it with my body and got a gash on my leg from the wheelpant mounting bracket. Used a ComeAlong ever since and zero problems. You have a lot of control with that baby. Good luck. The truck ride is exactly that: a *truck*. Michael Pilla ----- Original Message ----- From: Ken Balch <kbalch1(at)mediaone.net> Subject: RV-List: Moving project > > It looks like I'm going to need to move my project from MA to TX at the > end of next month. I'd like to get some input on how best to do this. > > I'm figuring on something like a 24' Ryder truck, but would like to hear > from anyone who has actually done a project move like this. Assuming > that I can't screw braces into the truck's floor, how should I secure my > RV in place for the move? > > Any ideas? > > -- > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 (N118KB) > installing engine stuff > groups.yahoo.com/group/BostonRVBuilders/files/ > > ________________________________________________________________________________
Subject: First Flight of 24294
Date: Sep 25, 2001
09/25/2001 02:26:58 PM RV-6 Serial number 24294 is an 0-320 powered machine with a Sensinich fixed pitch prop. It finally took to the air this weekend after a six year struggle (most of it very rewarding). I can't tell you how much information I have gotten from this list along the way...Thanks!!. The plane is AWESOME. Keep up the building if you are not done yet.. it's worth it, big time!! If you are already done and flying, you already know what I mean......don Don Nowakowski , Equipment Engineering Tech Telephone (802)288-3359, "The Laws of Aerodynamics are unforgiving and the ground is hard." Michael Collins (1987) ________________________________________________________________________________
Date: Sep 25, 2001
Subject: 6A nose gear fairing installation
Having just completed the successful match-drilling and installation of a new, improved nose gear leg, I now face the job of mounting van's new pre-molded leg fairing. All I have to go on is the new drawing (not the new pages in the builder's manual). Two questions arise right off, as I consider what I am about to do. First, the plans mention two plys of fiberglass cloth wetted with epoxy to secure the fairing to the leg. I cannot tell from the drawing; is this done just in one area ahead of the down-bend of the leg (where the arrow points on the plans) or along the entire inside of the fairing? Second, won't that make the hinge in the trailing edge a moot point, as it would tend to epoxy yhe fairing permanently in place? Just how necessary or desirable is it to have the fairing removeable? I am accustomed to the older, molded in place, spiral-wrapped fairing/stiffener combo, there the bond was quite permanent. Never saw the need to remove it once in service. Lastly, the plans are vague about the mold-in-place leg/cowl intersection fairing. I've done one of those before! This one is supposed to be bonded to the fairing and float free of the cowl while filling the hole in the bottom of the cowl, correct? Does it need to be flimsy enough to allow the leg fairing to be spread open to get it on and off the gear leg? What keeps the whole thing from rotating besides the clamp and epoxy at the bottom end of the fairing - anything? Thanks for clarification. Archives not very helpful on this as far as I could tell. -Bill B RV-6A 200 hours ________________________________________________________________________________
Date: Sep 25, 2001
Subject: Memoral patch for leather jacket (not specifically RV related)
Wow. This is awesome. I suggest we make stickers up right away too. My RV canopy would welcome wearing it. Rob Acker (RV-6) -----Original Message----- FROM: Reeves, Doug DATE: Tue 9/25/01 12:35 SUBJECT: RV-List: Memoral patch for leather jacket (not specifically RV related) =09 I have an acquaintence through work who created an unbelievable image that I would like to have made into a patch so that I can sew it on my leather jacket. It is a 'Remember 9.11.01' type image and it can be seen online at http://www.paranteau.com. ________________________________________________________________________________
Date: Sep 25, 2001
Ken, I moved my RV-6 project from NC to FL last year, wings and tail kit and all my shop stuff. First I built two real good stands for the wings which will later serve as jigs for paint. Trailing edge down and suspended from the main spar and the stub that sticks out on the tip rib that you later have to cut off. I drilled holes through this flange and lag bolted directly into the stand to keep the wing from sliding off. I used a 26' Budget, the biggest one they have. Still barely got everything in. The walls have tie-down rings so you'll need a lot of rope, I screwed some 4 X 8 sheets of plywood between and around the wings for extra protection. I positioned the wings against the forward and right-side walls for bracing and tied everything down. It helps to have someone follow in a car. I got a set of walkie talkies from Radio Shack so we were able to communicate and clear for traffic. No emergency stops allowed. Got here without a scratch. Went back and got the RV-4 and flew it down, a lot less stressful. Pat Hatch RV-4, N17PH @ VRB, 700 hours TT O-320, Hartzell C/S RV-6, Finish Kit O-360, Hartzell C/S ----- Original Message ----- From: "Ken Balch" <kbalch1(at)mediaone.net> Subject: RV-List: Moving project > > It looks like I'm going to need to move my project from MA to TX at the > end of next month. I'd like to get some input on how best to do this. > > I'm figuring on something like a 24' Ryder truck, but would like to hear > from anyone who has actually done a project move like this. Assuming > that I can't screw braces into the truck's floor, how should I secure my > RV in place for the move? > > Any ideas? > > -- > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 (N118KB) > installing engine stuff > groups.yahoo.com/group/BostonRVBuilders/files/ > > ________________________________________________________________________________
Date: Sep 25, 2001
Subject: gas tank covers
Dear listers lost the e-mail address for the guy who engraves fuel caps. please help. do you know if he has them pre made and all i have to do is send mine in? scott tampa ________________________________________________________________________________
Date: Sep 25, 2001
A picture of my TX to DC (DCA - The new Southern No Fly Zone) move is at my web site, www.geocities.com/timrv6a. I mounted my fuselage to a wooden cradle, and screwed the cradle to the floor of the truck (they can't say "no" if you don't ask). Tim ******************************** The DCA Infinite TCA... "America's Southern No Fly Zone" ******************************** Tim Lewis -- Fairfax, VA RV-6A N47TD - First Flight 18 Dec 99 http://www.geocities.com/timrv6a ****** ________________________________________________________________________________
Date: Sep 25, 2001
Thanks, Ed. The one I saw was a metal clipboard about the size of an approach plate that was riveted to a approximately 12 inch long by 2 inch wide piece of what looked like heavy aluminum sheet metal that was slightly twisted so the clip board was at a 45 degree angle at the far left of the instrument panel. I couldn't see how the end of the sheet metal "post" was attached to the fuse. If I can't find out whose it is, I may just rivet a small "pocket" to the side of the fuse that I could insert the end of the sheet metal "post." Ross ----- Original Message ----- From: "Ed Bundy" <ebundy(at)velocitus.net> Subject: Re: RV-List: Approach Plate Holder > > It may have been mine - it's pretty simple, but I use it all the time. I > didn't want to tear up a kneeboard, so I bought a suitable approach plate > clip that just happened to be a attached to a $1.00 Walmart clipboard. It > was held on with two rivets which were drilled out. It was then a simple > matter of using the two existing holes to drill through the formed channel > (the one that rests on the main longerons) at a suitable location and > securing it with a couple of pop rivets. > > I can get a picture of it if you want, but there really isn't much else to > it. > > Ed Bundy - RV6A N427EM 400+ hours > 160hp 0320 w/Sensenich 70x78 > Eagle, ID > ebundy(at)velocitus.net > > > When I was at Van's Homecoming, I saw a plane with an approach plate > holder > > attached to the left side of the fuselage. Any idea who it is and if there > > are pictues available? Because the canopy was closed, i couldn't see how > it > > was attached. > ________________________________________________________________________________
Subject: source of dessicant
Date: Sep 25, 2001
All, I am building here in Houston on the Gulf Coast and my tools are rusting, or more accurately, dissolving. I came up with the idea of placing all the steel tools in an air tight container with some dessicant, but I can't find a source for the dessicant. Any ideas where to get the stuff? Thanks, Kelly --8QB fuselage ________________________________________________________________________________
Date: Sep 25, 2001
Subject: Re: source of dessicant
silica gel can be bought in granular or solid form at any refrigeration supply house. scott tampa ________________________________________________________________________________
Date: Sep 25, 2001
Scott, Thanks for the tip - I'll try to get some tomorrow. Kelly ----- Original Message ----- From: <ABAYMAN(at)aol.com> Subject: Re: RV-List: source of dessicant > > silica gel can be bought in granular or solid form at any refrigeration > supply house. > scott > tampa > > > > > > > > ________________________________________________________________________________
Subject: heat ducting
Date: Sep 25, 2001
I was wondering if the Vans adjustable air vent could be used for heated cockpit air coming from the inlet air box. I wasn't sure what the actual temperatures are that would reach the ducting and air control. Dave Ford RV6 ________________________________________________________________________________
Subject: RE:Gascolators
Date: Sep 26, 2001
From: "Martin Hone" <martin.hone(at)tradergroup.com.au>
Question from a newbie with RV6. I intend to place my Facet pump and gascolator outboard of the fuselage, in the wing root, as some others have done. However, I am thinking of placing the gascolator before the pump i.e. upstream, so that it's at the very lowest point, and to provide an element of filtering before the fuel gets to the pump. Any thoughts either way welcome. Cheers Martin in Oz ________________________________________________________________________________
Date: Sep 25, 2001
A solution also used is to put a 100Watt or 75Watt light bulb in with the tools you are protecting. The advantage of the light bulb is the fact that the bulb will not become saturated with moisture. Good Luck Rollie & Rod RV6A glassing the canopy. ________________________________________________________________________________
Date: Sep 25, 2001
You can find large tubs of it at craft shops, it is used to dry flowers. The desiccant has blue indicator crystals in it which go away indicating that the desiccant needs to be dried in the oven before it will be able to absorb more water. You'll probably get tired of having to keep drying out the desiccant every day or so. I laugh every time I see a tub of that stuff in a trailer or the bilge of somebody's boat. I've got a good friend who got really rich developing and selling those things. They work just as advertised, but only for about 24 hours or so before needing to be dried out. Usually the ones you see people using have not been dried out in years and are doing nothing. If you try it, use half of the desiccant at a time. That way you can be drying the other half in the oven, instructions on how to do this are on the tub of desiccant. (Your wife is going to love this :-) Rollie's suggestion of the light bulb might be a good way to go. We use a lightbulb burning inside of a dead refrigerator to store arc welding rods. They are notorious for soaking up moisture and being ruined by it, but keep indefinitely in the frig. Good luck Dave, RV6, wings ________________________________________________________________________________
Date: Sep 25, 2001
Subject: flaps
I just reamed the holes for the rear spar tonight & going to start the flap mounting. Looks like I have to cut a taper in the top skin to match the fuselage & there is no room for error. any help on procedures would be appreciated. Do I get it all mounted & swinging & then start hacking on the hole in the bottom skin so the link can hang out. Does the link just go out the bottom or do I cut some of the side skin. Don Jordan - 6A - N6DJ Arlington, Tx ******************************* ________________________________________________________________________________
Subject: Re: gas tank covers
Date: Sep 25, 2001
Scott, I had mine done by Steve Davis. He has a website at: http://members.aol.com/panelcut I sent mine to him and he had them back to me in about 3 weeks. Really nice work. You can see a picture of mine at: http://enewton.addr.com/wings/final.html Happy building, Eric Newton - Long Beach, MS RV-6A N57ME (waiting for FAA Inspection) www.ericsrv6a.com ----- Original Message ----- From: <ABAYMAN(at)aol.com> Subject: RV-List: gas tank covers > > Dear listers > lost the e-mail address for the guy who engraves fuel caps. please help. do > you know if he has them pre made and all i have to do is send mine in? > scott > tampa ________________________________________________________________________________
Subject: Re: RE:Gascolators
Date: Sep 25, 2001
That is how I did it. From the fuel selector to the gasolator to the facet pump to the fuel flow meter to the firewall. The gasolator is in the wing root at the lowest point in the system but I couldn't get the facet pump to fit there and still be at a 45 degree angle and be above the gasolator. Ross RV-6A...one of the last of a very good breed..... ----- Original Message ----- From: "Martin Hone" <martin.hone(at)tradergroup.com.au> > Question from a newbie with RV6. > I intend to place my Facet pump and gascolator outboard of the fuselage, > in the wing root, as some others have done. However, I am thinking of > placing the gascolator before the pump i.e. upstream, so that it's at > the very lowest point, and to provide an element of filtering before the > fuel gets to the pump. Any thoughts either way welcome. > Cheers > Martin in Oz ________________________________________________________________________________
Date: Sep 26, 2001
Bill, I just used the clamp at the bottom and then used some latex expanding foam to fill in the top few inches of the fairing. Leaves plenty of room to flex, wont rotate and is easy to remove. (Using the hinge). Be sure to leave at least 3/8" between wheel pant and leg fairing, because the pant will be flexed up enough to hit the leg fairing on landing. I didn't notice it until my first grass strip excursion. Steve DiNieri Rv-6a N221RV First, the plans mention two plys of fiberglass cloth wetted with epoxy to secure the fairing to the leg. I cannot tell from the drawing; is this done just in one area ahead of the down-bend of the leg (where the arrow points on the plans) or along the entire inside of the fairing? Second, won't that make the hinge in the trailing edge a moot point, as it would tend to epoxy yhe fairing permanently in place? Just how necessary or desirable is it to have the fairing removeable? I am accustomed to the older, molded in place, spiral-wrapped fairing/stiffener combo, there the bond was quite permanent. Never saw the need to remove it once in service. Lastly, the plans are vague about the mold-in-place leg/cowl intersection fairing. I've done one of those before! This one is supposed to be bonded to the fairing and float free of the cowl while filling the hole in the bottom of the cowl, correct? Does it need to be flimsy enough to allow the leg fairing to be spread open to get it on and off the gear leg? What keeps the whole thing from rotating besides the clamp and epoxy at the bottom end of the fairing - anything? -Bill B RV-6A 200 hours ________________________________________________________________________________
Subject: source of desiccant
Date: Sep 26, 2001
Check with your local safe and lock company, they have bags about 12-16 oz full of silica gel for keeping safes moisture free. They can be recharged in the oven. Ask me how I know, I'm the one with the stinky money ;} Steve DiNieri Rv-6a N221RV All, I am building here in Houston on the Gulf Coast and my tools are rusting, or more accurately, dissolving. I came up with the idea of placing all the steel tools in an air tight container with some dessicant, but I can't find a source for the dessicant. Any ideas where to get the stuff? Thanks, Kelly --8QB fuselage ________________________________________________________________________________
Date: Sep 25, 2001
Sounds like mine. I started with a basic kneeboard from sporty's, and cut it down a bit so it was just the size of the approach plates. Tapered the top too so it didn't stick up as much. The mounting "post", I riveted to the back is more like 7" long by 1.5" wide, .063 AL. Took some trial and error to bend it for the desired angle but I got it eventually. To attach to the plane, I made a U shaped piece out of .032 that fit over the wing bulkhead -- drilled out a couple of pop rivets each side and put it on there with enough of a gap for the tongue of the "post" to slip into. Works great. I'll try to get pictures. Randall Henderson, RV-6 N6R (~280 hrs) Portland, OR www.vanshomewing.org ----- Original Message ----- From: "Ross Mickey" <rmickey(at)ix.netcom.com> Subject: Re: RV-List: Approach Plate Holder > > Thanks, Ed. The one I saw was a metal clipboard about the size of an > approach plate that was riveted to a approximately 12 inch long by 2 inch > wide piece of what looked like heavy aluminum sheet metal that was slightly > twisted so the clip board was at a 45 degree angle at the far left of the > instrument panel. I couldn't see how the end of the sheet metal "post" was > attached to the fuse. If I can't find out whose it is, I may just rivet a > small "pocket" to the side of the fuse that I could insert the end of the > sheet metal "post." > > Ross > > > ----- Original Message ----- > From: "Ed Bundy" <ebundy(at)velocitus.net> > To: > Subject: Re: RV-List: Approach Plate Holder > > > > > > It may have been mine - it's pretty simple, but I use it all the time. I > > didn't want to tear up a kneeboard, so I bought a suitable approach plate > > clip that just happened to be a attached to a $1.00 Walmart clipboard. It > > was held on with two rivets which were drilled out. It was then a simple > > matter of using the two existing holes to drill through the formed channel > > (the one that rests on the main longerons) at a suitable location and > > securing it with a couple of pop rivets. > > > > I can get a picture of it if you want, but there really isn't much else to > > it. > > > > Ed Bundy - RV6A N427EM 400+ hours > > 160hp 0320 w/Sensenich 70x78 > > Eagle, ID > > ebundy(at)velocitus.net > > > > > When I was at Van's Homecoming, I saw a plane with an approach plate > > holder > > > attached to the left side of the fuselage. Any idea who it is and if > there > > > are pictues available? Because the canopy was closed, i couldn't see > how > > it > > > was attached. > > > > ________________________________________________________________________________
Date: Sep 26, 2001
Rick: I tried the fiberlite.com web site, and got...ladders. Tried www.fiberlight.com and got "Your request is missing the following information: No Search Domain Name." ? Semper Fi John RV-6 (left wing in jig, temporarily orphaned because of work...) > > From: "rickjory" <rickjory(at)msn.com> > Subject: Re: RV-List: EL Cockpit Lighting > > > FWIW, you might look at the Fiberlite system . . . www.fiberlite.com or > Aircraft Spruce. I haven't powered mine up yet, but installation has been > quite easy and one bulb lights the entire panel. > Rick Jory RV8A > > ----- Original Message ----- > From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com> > Subject: RV-List: EL Cockpit Lighting > > > > > > Mark, > > > > I tried this type of product in my IFR RV-6A, after seeing it at Sun 'N > > Fun a couple of years ago. I found that, even with additional power supply > > filtering, the AC noise effected my radios. I didn't investigate any > > further, but felt that the IFR operation warranted the more common > lighting > > solutions...... > > > > Fred Stucklen > > N925RV (1840 hrs/8 Yrs) > > E. Windsor, CT 06088 > > WK Email: stuckle(at)ifc.utc.com > > Hm/Travel Email: wstucklen1(at)juno.com > > > > Subject: AeroElectric-List: EL Cockpit Lighting > > Message-ID: <20010924.203755.-263081.0.czechsix(at)juno.com> > > From: czechsix(at)juno.com > > > > --> AeroElectric-List message posted by: czechsix(at)juno.com > > > > Bob (or anyone else who wants to jump in), > > > > I am considering using electroluminescent lighting in my RV-8A > > cockpit. > > Specifically, there's a brand-name called "Flatlite" that can be > > obtained > > in almost any shape or size, and all the colors of the rainbow. > The > > distributor I've been talking to is at > > http://beingseentechnologies.goemerchant2.com. My intent is to > get > > a 2" > > x 24" strip (blue, green, or white.....haven't decided which color > > yet) > > and stick it to the underside of my glareshield. It won't be > > directly > > visible when seated in the cockpit, but it will cast a soft glow > > down on > > the panel. This seems to be an ideal way to light the panel with > a > > minimum of glare on the panel or canopy. The product is dimmable > by > > varying the input voltage from 12 VDC down to 7 VDC (after which > it > > shuts > > off). > > > > Now for my question: the Flatlite kit uses an inverter which > takes > > in > > the aformentioned DC and converts it to 280 VAC at 850 Hz. Do you > > think > > that this could cause noise or interference problems with the > audio, > > or > > any other system? The tech rep I talked to did not think it would > > be an > > issue if grounded correctly at the firewall, based on experience > > with > > cars and boats. > > > > Any other input on this subject.....anyone who's tried it....any > > problems > > or gotchas.....speak up before I send my $65. > > > > Thanks, > > > > --Mark Navratil > > Cedar Rapids, IA > > RV-8A fuselage... > > > > > ________________________________________________________________________________
Subject: proseal on canopies
Date: Sep 26, 2001
I put masking tape on the aluminum fairing and on the canopy plexi, leaving a 1/8 to 1/16 strip un-taped right at the place I wanted to seal. Then I squeezed a small bead of Proseal into this gap. I used a sandwich baggie with the corner cut off as a squeezer. The Proseal sagged into the space between the Plexi and the aluminum. After 24 hours, I removed the masking tape (use the highest quality blue 3M tape so that it doesn't become a permanent part of your plane). This left a tiny, smooth bead of Proseal right where I wanted it. Surprisingly, about 12 inches or so did not stick the Plexi in one location. I will have to do it a second time. Proseal stuck to everything else. Steve Soule Huntington, Vermont -----Original Message----- I would love to use Proseal to seal up the edges left between the canopy and the fairing but I don't have the slightest idea how to get a bead of it small enough to insert between these two. I need a bead about 1/8 to 1/16 inch in diameter. How did others do this and are there cake decorating tools involved :-) ________________________________________________________________________________
Subject: RV-6 Fuselage jig - metal
Date: Sep 26, 2001
Listers, Anybody in the New England area interested in borrowing a metal jig (rectangular aluminum tubing) should contact me. Currently, it's assembled, but, since it's only pop riveted together, it can be easily disassembled so that it can be transported. Working on #2 RV6-A Fuselage Fred Stucklen N925RV (1840 hrs/8 Yrs) E. Windsor, CT 06088 WK Email: stuckle(at)ifc.utc.com Wk (860)-727-2393 Hm (860)-623-1094 ________________________________________________________________________________
Date: Sep 26, 2001
http://www.fiberlites.com This is a good URL. Tom N787RV (reserved) ----- Original Message ----- From: "John Lawson" <jwlawson(at)hargray.com> Subject: RV-List: EL Cockpit Lighting > > Rick: I tried the fiberlite.com web site, and got...ladders. Tried www.fiberlight.com and got "Your request is missing the following information: No Search Domain Name." ? > > Semper Fi > John > RV-6 (left wing in jig, temporarily orphaned because of work...) > > > > > > From: "rickjory" <rickjory(at)msn.com> > > Subject: Re: RV-List: EL Cockpit Lighting > > > > > > FWIW, you might look at the Fiberlite system . . . www.fiberlite.com or > > Aircraft Spruce. I haven't powered mine up yet, but installation has been > > quite easy and one bulb lights the entire panel. > > Rick Jory RV8A > > > > ----- Original Message ----- > > From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com> > > Subject: RV-List: EL Cockpit Lighting > > > > > > > > > > Mark, > > > > > > I tried this type of product in my IFR RV-6A, after seeing it at Sun 'N > > > Fun a couple of years ago. I found that, even with additional power supply > > > filtering, the AC noise effected my radios. I didn't investigate any > > > further, but felt that the IFR operation warranted the more common > > lighting > > > solutions...... > > > > > > Fred Stucklen > > > N925RV (1840 hrs/8 Yrs) > > > E. Windsor, CT 06088 > > > WK Email: stuckle(at)ifc.utc.com > > > Hm/Travel Email: wstucklen1(at)juno.com > > > > > > Subject: AeroElectric-List: EL Cockpit Lighting > > > Message-ID: <20010924.203755.-263081.0.czechsix(at)juno.com> > > > From: czechsix(at)juno.com > > > > > > --> AeroElectric-List message posted by: czechsix(at)juno.com > > > > > > Bob (or anyone else who wants to jump in), > > > > > > I am considering using electroluminescent lighting in my RV-8A > > > cockpit. > > > Specifically, there's a brand-name called "Flatlite" that can be > > > obtained > > > in almost any shape or size, and all the colors of the rainbow. > > The > > > distributor I've been talking to is at > > > http://beingseentechnologies.goemerchant2.com. My intent is to > > get > > > a 2" > > > x 24" strip (blue, green, or white.....haven't decided which color > > > yet) > > > and stick it to the underside of my glareshield. It won't be > > > directly > > > visible when seated in the cockpit, but it will cast a soft glow > > > down on > > > the panel. This seems to be an ideal way to light the panel with > > a > > > minimum of glare on the panel or canopy. The product is dimmable > > by > > > varying the input voltage from 12 VDC down to 7 VDC (after which > > it > > > shuts > > > off). > > > > > > Now for my question: the Flatlite kit uses an inverter which > > takes > > > in > > > the aformentioned DC and converts it to 280 VAC at 850 Hz. Do you > > > think > > > that this could cause noise or interference problems with the > > audio, > > > or > > > any other system? The tech rep I talked to did not think it would > > > be an > > > issue if grounded correctly at the firewall, based on experience > > > with > > > cars and boats. > > > > > > Any other input on this subject.....anyone who's tried it....any > > > problems > > > or gotchas.....speak up before I send my $65. > > > > > > Thanks, > > > > > > --Mark Navratil > > > Cedar Rapids, IA > > > RV-8A fuselage... > > > > > > > > > > ________________________________________________________________________________
Subject: Re: flaps
Date: Sep 26, 2001
Hi Don, Here's how I did it. If you have already mounted the aileron, take it off. Now place the flap in place, in its up position but not in the hinge yet. Just place it so the top skin is just touching (or close to touching the fuselage side) and the flap is outboard of its final location on the wing. Temporarily slide in a hinge pin in a few of the hinge eyelet's just to hold the flap in place so you can mark it. Now draw the outline of the fuselage side onto the top of the flap skin using a compass or edge marker block like Avery's sells. You now have a perfect representation of your fuselage side. Take off the flap and trim it to the line. I trimmed mine and then filed it and fitted until I had a 1/8 gap even along the seam of the flap fuselage intersection. To make the hole for the flap pushrod, I made a couple of measurements to give me a starting point. With the flap actuator in the fuselage in its most down position, reach inside the fuselage and measure from the nearest rivet to the center of hole in the actuator arm. While your inside, also measure the distance from the fuselage side skin to the center of the actuator arm. Go on the outside of the fuselage and using the measurements you just got (the distance from that same rivet and in from the fuselage side) and make a mark on the bottom of the fuselage. You now know where the actuator rod will come out of the fuselage when the flap is down. Using a unibit, drill a hole there a little larger the rod. Now you just have to keep cutting and filing and test fitting the hole until the rod will clear through the entire flap travel. You will end up having to make the hole travel up the fuselage side about 3/4" or so to allow the flap actuator rod end bearing to clear with the flap in it's most up position. Hope this makes sense. I have some pictures on my web site in the "Finish" section under "mounting flaps and ailerons" if want to take a look. www.ericsrv6a.com Happy building, Eric Newton - Long Beach, MS RV-6A N57ME (waiting for FAA inspection) www.ericsrv6a.com ----- Original Message ----- From: Don R Jordan <dons6a(at)juno.com> Subject: RV-List: flaps > > I just reamed the holes for the rear spar tonight & going to start the > flap mounting. > > Looks like I have to cut a taper in the top skin to match the fuselage & > there is no room for error. > > any help on procedures would be appreciated. Do I get it all mounted & > swinging & then start hacking on the hole in the bottom skin so the link > can hang out. Does the link just go out the bottom or do I cut some of > the side skin. > > > Don Jordan - 6A - N6DJ > Arlington, Tx > ******************************* ________________________________________________________________________________
Date: Sep 26, 2001
It's actually http://www.fiberlites.com I have seen both systems, and once you see the quality of the electroluminescent stuff, you will see that they do not compare. The EL stuff does not have a bulb that gets warm, or burns out. They have about a 10,000 hour life. The color is more evenly distributed than the fiberlites, as well. Just my $.02. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "John Lawson" <jwlawson(at)hargray.com> Subject: RV-List: EL Cockpit Lighting Rick: I tried the fiberlite.com web site, and got...ladders. Tried www.fiberlight.com and got "Your request is missing the following information: No Search Domain Name." ? Semper Fi John RV-6 (left wing in jig, temporarily orphaned because of work...) > > From: "rickjory" <rickjory(at)msn.com> > Subject: Re: RV-List: EL Cockpit Lighting > > > FWIW, you might look at the Fiberlite system . . . www.fiberlite.com or > Aircraft Spruce. I haven't powered mine up yet, but installation has been > quite easy and one bulb lights the entire panel. > Rick Jory RV8A > > ----- Original Message ----- > From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com> > Subject: RV-List: EL Cockpit Lighting > > > > > > Mark, > > > > I tried this type of product in my IFR RV-6A, after seeing it at Sun 'N > > Fun a couple of years ago. I found that, even with additional power supply > > filtering, the AC noise effected my radios. I didn't investigate any > > further, but felt that the IFR operation warranted the more common > lighting > > solutions...... > > > > Fred Stucklen > > N925RV (1840 hrs/8 Yrs) > > E. Windsor, CT 06088 > > WK Email: stuckle(at)ifc.utc.com > > Hm/Travel Email: wstucklen1(at)juno.com > > > > Subject: AeroElectric-List: EL Cockpit Lighting > > Message-ID: <20010924.203755.-263081.0.czechsix(at)juno.com> > > From: czechsix(at)juno.com > > > > --> AeroElectric-List message posted by: czechsix(at)juno.com > > > > Bob (or anyone else who wants to jump in), > > > > I am considering using electroluminescent lighting in my RV-8A > > cockpit. > > Specifically, there's a brand-name called "Flatlite" that can be > > obtained > > in almost any shape or size, and all the colors of the rainbow. > The > > distributor I've been talking to is at > > http://beingseentechnologies.goemerchant2.com. My intent is to > get > > a 2" > > x 24" strip (blue, green, or white.....haven't decided which color > > yet) > > and stick it to the underside of my glareshield. It won't be > > directly > > visible when seated in the cockpit, but it will cast a soft glow > > down on > > the panel. This seems to be an ideal way to light the panel with > a > > minimum of glare on the panel or canopy. The product is dimmable > by > > varying the input voltage from 12 VDC down to 7 VDC (after which > it > > shuts > > off). > > > > Now for my question: the Flatlite kit uses an inverter which > takes > > in > > the aformentioned DC and converts it to 280 VAC at 850 Hz. Do you > > think > > that this could cause noise or interference problems with the > audio, > > or > > any other system? The tech rep I talked to did not think it would > > be an > > issue if grounded correctly at the firewall, based on experience > > with > > cars and boats. > > > > Any other input on this subject.....anyone who's tried it....any > > problems > > or gotchas.....speak up before I send my $65. > > > > Thanks, > > > > --Mark Navratil > > Cedar Rapids, IA > > RV-8A fuselage... > > > > > ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Photo taken from top of WTC just before. Not RV related.
This picture was taken by a tourist atop the World Trade Center. His camera was found in the rubble, he has not yet been found. ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Re: Photo taken from top of WTC just before. Not RV related.
Come on guys! This picture has been proven to be a fake and has no place here! Let's be a little more sensitive. Mark ________________________________________________________________________________
Date: Sep 26, 2001
From: Brian Armstrong <armstrbc(at)ucsub.colorado.edu>
That picture (although not attached and no link visible) is a hoax. Brian Armstrong Boulder, CO -- On Wed, 26 Sep 2001 cecilth(at)juno.com wrote: > > > This picture was taken by a tourist atop the World Trade Center. His > camera > was found in the rubble, > he has not yet been found. > > ________________________________________________________________________________
Date: Sep 26, 2001
Paul, I'm currently looking for a lighting solution (seven 3 1/8" and one 2 1/4"). Do you know a discounted source for the UMA EL products? Pricing for the fiberlites solution is $222, the EL stuff would be $386 (one could buy a bunch of 2000 hour light bulbs for the price difference ). Rob Acker (RV-6) > > It's actually http://www.fiberlites.com I have seen both systems, and > once you see the quality of the electroluminescent stuff, you will see > that they do not compare. The EL stuff does not have a bulb that gets > warm, or burns out. They have about a 10,000 hour life. The color is > more evenly distributed than the fiberlites, as well. ________________________________________________________________________________
Date: Sep 26, 2001
I bought a couple of led Honda motorcycle brake lights about 4"long 1/2 wide by 1/2" deep, installed under the glare shield about 2 foot apart Does a fine job. Joe RV6A --- John Lawson wrote: > > > Rick: I tried the fiberlite.com web site, and > got...ladders. Tried www.fiberlight.com and got > "Your request is missing the following information: > No Search Domain Name." ? > > Semper Fi > John > RV-6 (left wing in jig, temporarily orphaned because > of work...) > > > > > > From: "rickjory" <rickjory(at)msn.com> > > Subject: Re: RV-List: EL Cockpit Lighting > > > > > > > FWIW, you might look at the Fiberlite system . . . > www.fiberlite.com or > > Aircraft Spruce. I haven't powered mine up yet, > but installation has been > > quite easy and one bulb lights the entire panel. > > Rick Jory RV8A > > > > ----- Original Message ----- > > From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com> > > Subject: RV-List: EL Cockpit Lighting > > > Frederic IFC" > > > > > > > > Mark, > > > > > > I tried this type of product in my IFR RV-6A, > after seeing it at Sun 'N > > > Fun a couple of years ago. I found that, even > with additional power supply > > > filtering, the AC noise effected my radios. I > didn't investigate any > > > further, but felt that the IFR operation > warranted the more common > > lighting > > > solutions...... > > > > > > Fred Stucklen > > > N925RV (1840 hrs/8 Yrs) > > > E. Windsor, CT 06088 > > > WK Email: stuckle(at)ifc.utc.com > > > Hm/Travel Email: wstucklen1(at)juno.com > > > > > > Subject: AeroElectric-List: EL Cockpit > Lighting > > > Message-ID: > <20010924.203755.-263081.0.czechsix(at)juno.com> > > > From: czechsix(at)juno.com > > > > > > --> AeroElectric-List message posted by: > czechsix(at)juno.com > > > > > > Bob (or anyone else who wants to jump > in), > > > > > > I am considering using > electroluminescent lighting in my RV-8A > > > cockpit. > > > Specifically, there's a brand-name > called "Flatlite" that can be > > > obtained > > > in almost any shape or size, and all the > colors of the rainbow. > > The > > > distributor I've been talking to is at > > > > http://beingseentechnologies.goemerchant2.com. My > intent is to > > get > > > a 2" > > > x 24" strip (blue, green, or > white.....haven't decided which color > > > yet) > > > and stick it to the underside of my > glareshield. It won't be > > > directly > > > visible when seated in the cockpit, but > it will cast a soft glow > > > down on > > > the panel. This seems to be an ideal > way to light the panel with > > a > > > minimum of glare on the panel or canopy. > The product is dimmable > > by > > > varying the input voltage from 12 VDC > down to 7 VDC (after which > > it > > > shuts > > > off). > > > > > > Now for my question: the Flatlite kit > uses an inverter which > > takes > > > in > > > the aformentioned DC and converts it to > 280 VAC at 850 Hz. Do you > > > think > > > that this could cause noise or > interference problems with the > > audio, > > > or > > > any other system? The tech rep I talked > to did not think it would > > > be an > > > issue if grounded correctly at the > firewall, based on experience > > > with > > > cars and boats. > > > > > > Any other input on this > subject.....anyone who's tried it....any > > > problems > > > or gotchas.....speak up before I send my > $65. > > > > > > Thanks, > > > > > > --Mark Navratil > > > Cedar Rapids, IA > > > RV-8A fuselage... > > > > > > > > > > > > http://www.matronics.com/unsubscribe > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Date: Sep 26, 2001
Subject: prop questions, panel, wiring diagram
Hi to all listers - A few questions for you: * Has anyone installed a constant speed prop that was ground down from 72 to 70 inches? The prop had minor damage and has been overhauled by a supposedly reputable prop shop and stamped experimental. I find myself a little hesitant. I examined the airplane on which it was damaged - damage to the plane was indeed minor. * Does anyone have a wiring diagram for a Terra (now Trimble) TRT 250D transponder? * Are there any manuals for Lycoming engines written by third parties such as the Chilton series of books for cars? Looking for hookup information for an IO-360 A1B6. is the Lycoming manual the best? Thanks for all of your help. Parker Thomas Rv-8 wings - just closed the first tank (fingers are seriously crossed) ________________________________________________________________________________
Date: Sep 26, 2001
> It looks like I'm going to need to move my project from MA to TX at the > end of next month. I'd like to get some input on how best to do this. > > I'm figuring on something like a 24' Ryder truck, but would like to hear > from anyone who has actually done a project move like this. Assuming > that I can't screw braces into the truck's floor, how should I secure my > RV in place for the move? You seem to be going a distance that is far enough to warrent the fuel cost savings of a diesel motor. Gas will cost double. Almost all cube vans and 5 ton vans have thick wood floors that you can screw into. Most have thin plywood sheeting on the walls that can also be screwed into but don't plan on each screw being able to hold too much. If you can arrange to move in the third week of the month you will be able to find a better truck. End of the month every rental truck out there is doing house moves while most are sitting around a week earlier. Stay away from the "lowest bid" as they run their trucks till they are worn out. Look for an outfit that flips their trucks when they are one year old. Ask if they have air ride suspensions. (quite rare) Book something that has under 20,000 miles on it. Don't go over 5 tons as it will have a very rough ride. Ideally, you would use a one ton with a big box. The suspension will be softer. For security when on the road: locate the fuel pump fuse and pull it when parking overnight. It is real hard to steal a truck that you can't get fired up. I am about to move myself, we have bought a new house over by Austin (it's his fault I became a builder anyway). I am planning a brand new one ton cube van for my airplane and a 5 ton for the contents of my house. My wings are hanging vertically in jigs that have frame all around them. They are very easy to attach to the walls of the van. My fuselage is not on the gear yet, it will sit on it's cradle at the front and wad of moving blankets at the rear. The steps are on so it will not sit on it's belly. I will use many str aps to hold it in the middle of the box. Each strap will be only just snug, no big pressures. I'm really not looking forward to the whole affair but wifey gets her dream house so I can get on with blowing huge cash on a new motor, CS prop and a bunch of panel peices. Regards, Norman Hunger RV6A Delta BC ________________________________________________________________________________
Subject: Re: EL Cockpit Lighting
Date: Sep 26, 2001
No, because UMA makes the light wedges. It all comes down to which light you prefer. I liked the EL lights, so I bought them. I figured, hey this is a $60,000 airplane. What's a hundred bucks or so to put in the EL lighting, and get what I really wanted. I only had 3 1/8" instruments, so the cost was obviously much less. Paul Besing RV-6A N197AB Arizona http://www.lacodeworks.com/besing Flying Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: <racker(at)rmci.net> Subject: Re: RV-List: EL Cockpit Lighting Paul, I'm currently looking for a lighting solution (seven 3 1/8" and one 2 1/4"). Do you know a discounted source for the UMA EL products? Pricing for the fiberlites solution is $222, the EL stuff would be $386 (one could buy a bunch of 2000 hour light bulbs for the price difference ). Rob Acker (RV-6) > > It's actually http://www.fiberlites.com I have seen both systems, and > once you see the quality of the electroluminescent stuff, you will see > that they do not compare. The EL stuff does not have a bulb that gets > warm, or burns out. They have about a 10,000 hour life. The color is > more evenly distributed than the fiberlites, as well. ________________________________________________________________________________
Date: Sep 26, 2001
Subject: navaide
I hate to beat this thing to death but... In placing the servo motor I would like to know if I'm on the right track. Should I pin the aileron and elevator to a neutral position then position the servo such that the servo rod will be parallel with the aileron torque tube both fore and aft and up and down (lateral and vertical) in order to keep from having elevator intervention. (Under passenger seat instulation) Thanks ahead. Joe RV6A ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Re: prop questions, panel, wiring diagram
on 9/26/01 10:25, F. Parker Thomas at me(at)parkerthomas.com wrote: > > Hi to all listers - > > A few questions for you: > * Has anyone installed a constant speed prop that was ground down from 72 to > 70 inches? The prop had minor damage and has been overhauled by a > supposedly reputable prop shop and stamped experimental. I find myself a > little hesitant. I examined the airplane on which it was damaged - damage > to the plane was indeed minor. > * Does anyone have a wiring diagram for a Terra (now Trimble) TRT 250D > transponder? > * Are there any manuals for Lycoming engines written by third parties such > as the Chilton series of books for cars? Looking for hookup information for > an IO-360 A1B6. is the Lycoming manual the best? > > > Thanks for all of your help. > > Parker Thomas > Rv-8 wings - just closed the first tank (fingers are seriously crossed) > I don't see anyone else answering this so let me offer an opinion. It is my opinion that the "cut down " limit on the constant speed used on RVs is 72 inches. When you buy one new from Vans, it is labeled as a 76 cut down already to 72, hence no further shortening is allowed. This is definitely something I would not be interested in experimenting with. I would keep on hesitating. Denis ________________________________________________________________________________
Date: Sep 27, 2001
Subject: Gascolators and Fuel Pumps in Wing Root
Hi Martin, A number of builders have reported that they were unable to get both the gascolator and fuel pump that Vans sell in the wing root. In fact I'm not aware of anyone who has been able to do this. It has to do with the way the fuel pump fittings are located, and that the pump is supposed to be at a 45 deg angle, etc etc. I believe I have found the solution to this problem. I am using a Facet #40007E fuel pump, which is similar to the "beer can" type used on all Piper Warriors and Archers. In case you are not familiar with it, this pump is a cylindrical-shaped unit that mounts vertically, but the inlet and outlet are both on the same side of the cylinder, not opposite sides like the pump Van uses. My plan is to mount the pump just forward of the spar in my left wingroot. The fuel line coming out of the selector valve will go out to the wingroot, turn 90 deg aft and go directly into the bottom inlet of the fuel pump. The outlet then comes out the top of the fuel pump, facing straight forward....it will go to the gascolator in the forward part of the wingroot (remember to put some sort of bend in the line between the pump and gascolator to relieve any tension...in my case, the gascolator entry is below the pump outlet, so this is taken care of automatically by a gentle "S" curve). Sorry if this is hard to visualize. I haven't actually done the installation yet (so no pictures) but I've figured out the details of the mounting and fittings I need, and can't see any reason why it won't work. Also FWIW, the Facet 40007E pump is virtually identical to Van's Facet pump functionally....that is the operating pressure and flow rate are the same. Also, the 40007E has one significant difference from the pumps used on the Piper series....that is that the fittings for the inlet and outlet are for 1/4" pipe thread (which is compatible with the 3/8" AN -6 fuel system used in the RV) whereas the Piper series use the Facet 478360 which has 1/8" pipe threads compatible with it's smaller fuel lines (either 1/4" AN -4 or 5/16" AN -5, not sure which it is but it's smaller than the RV). So DON'T get a "Piper" fuel pump. Other than the inlet/outlet thread size, they are functionally and physically identical. Hope this helps, --Mark Navratil Cedar Rapids, IA RV-8A fuselage....hoping I'm not one of the layoffs my company announced yesterday....anyone want an RV-8A completed to QB stage?? Really cheap???? Subject: RV-List: RE:Gascolators From: "Martin Hone" <martin.hone(at)tradergroup.com.au> Question from a newbie with RV6. I intend to place my Facet pump and gascolator outboard of the fuselage, in the wing root, as some others have done. However, I am thinking of placing the gascolator before the pump i.e. upstream, so that it's at the very lowest point, and to provide an element of filtering before the fuel gets to the pump. Any thoughts either way welcome. Cheers Martin in Oz -- ________________________________________________________________________________
Subject: Re: navaide
Date: Sep 26, 2001
> > >I hate to beat this thing to death but... In placing >the servo motor I would like to know if I'm on the >right track. Should I pin the aileron and elevator to >a neutral position then position the servo such that >the servo rod will be parallel with the aileron torque >tube both fore and aft and up and down (lateral and >vertical) in order to keep from having elevator >intervention. (Under passenger seat instulation) >Thanks ahead. > When I installed my Navaid Devices servo under the passenger seat, I found the limiting factor was getting full control movements without any of the pushrods hitting each other. That was just barely possible and there was probably just one way to do things and make it work. I used the instructions provided by Navaid, as much as possible. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Sep 26, 2001
Martin: My set up is Andair gascolator on the outboard side of the left wing root just ahead of the spar and as low and far aft as I could get it. The Facet is after the gascolator on the inside of the wing root area a little ahead but pretty close to the plans location because I did not like the very tight bends it would have taken to plumb it on the outside at the manufacturer's recommended 45 degree angle. I am a long way from flying but I did build a dimensionally similar mockup of the system including an Andair fuel valve and all the fuel lines and ran a series of flow tests. Without getting into details of the tests I satisfied myself that the pump would draw fuel through a dry system with no increase in time to reach full flow with the initial fuel level as far below the pump inlet as I tested which was 12 inches. This is just my personal experience and I recommend that you do some similar testing of your planned system if you are deviating from the plan's. Harry Crosby Pleasanton, California RV-6, finish kit stuff (forever) ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Re: Gascolators and Fuel Pumps in Wing Root
Listers go to the link below for a picture of how the gascolator and fuel pump is installed in the wing root. don hughs, a friend and great builder of 1 mighty fine looking rv6 has an e-mail address on the page if you need to ask him some questions about it. http://bmnellis.com/BuilderIdeas/DonHughes.htm good luck scott tampa doing mine like his ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Re: panel wiring Gulf Coast Avionics
Dear Listers, just wanted to give you guys a heads up. i brought my panel into Gulf Coast Avionics, so they could hook up the 4 wires from the intercom to the audio panel. although i had all the rest of the wiring done myself, they didn't want to do just that connection, unless i let them rewire all my harness relating to the avionics stack. to the tune of $1400.00 . i though i was going to pay a couple hundred dollars as many listers advised. i promptly told them not to touch it, i would be back today to pick it up. i was mislead by the service manager there when he said they would do anything i wanted them to do. i could understand if my workmanship was off, but i spent alot of time doing the harness right, and it is a work of art. to just rip it out and throw it away, was beyond my comprehension. thought i would let you know. scott tampa looking for another avioncs shop ________________________________________________________________________________
Subject: 'Remember' memorial patches for your jackets (and decals).
Date: Sep 26, 2001
From: "Reeves, Doug" <Douglas.Reeves(at)archongroup.com>
Hi gang, With the generous help of Austin, TX RV-6 builder Mike Thompson the ball is now rolling for the creation and distribution of David Paranteau's 'Remember' patch. I've set up a page on my site where you can sign a guest book if you intend to purchase one/both/several. We're trying to gauge how many to have made in the initial run (we get a substantial price break if we order 500 as opposed to 200). Again, ALL proceeds go to the American Red Cross. We're thinking the cost of the patch will be between $10 and $15 (depending on how many we order). That should give us a $7-$10 donation on each patch (still gathering info on sticker prices - will get back on that). The page also includes a larger version of the patch for you to inspect. It's at: http://www.metronet.com/~dreeves/david_paranteaus_remember_patch.htm Best as always, Doug Reeves http://www.vansaircraft.net ________________________________________________________________________________
From: "Jim and Carol Hughes" <jcdevitt(at)home.com>
Subject: RV4
Date: Sep 26, 2001
I am looking for a flying RV4 to replace my RV6 that was damaged during a forced landing in a field do to a power failure. I have since sold the RV6 to a guy who is going to rebuild it. If anyone knows of a flying RV4 that is fairly priced, please let me know. Thanks for your help. jcdevitt(at)home.com or call (563) 263-0684 Thanks JIM HUGHES ________________________________________________________________________________
Date: Sep 26, 2001
--- ABAYMAN(at)aol.com wrote: > > Dear Listers, > just wanted to give you guys a heads up. i brought my panel into Gulf > Coast > Avionics, so they could hook up the 4 wires from the intercom to the > audio > panel. although i had all the rest of the wiring done myself, Hi Scott, Your post just begs the question be asked... so I'll ask it: You've wired the whole panel and now you want to pay someone to do the last four wires? :) Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Date: Sep 26, 2001
Mike, yes thats correct. the reason being, my radio stack is all Terra, and the schematics that came with the units match terminology and is pin to pin. the 4 wires i couldn't fiqure out was the Flight Com Intercom hooking to a Terra Audio Panel. the terminology is differant, and i don't know what pin goes to what pin on the other componet. i also wanted them to smoke test the radios for me, and a do any ajustments necessary. i would have paid 2-3 hundred for piece of mind, but 14 is outta hand. scott tampa anyone know how to wire these items together? ________________________________________________________________________________
Date: Sep 26, 2001
I'm reading some methods of installing gascolators and pumps that simply scare me. I know you guys think you have safe systems, and may have; but, I sure do see places for problems. Have you ever thought of just following Van's plans and going with something that already works? Sorry; but, Pat Patterson and I have already seen one glorified system that didn't work and spent a lot of time rebuilding the results of that system. Yeah, it worked for a while; but, it had many places to invite trouble. It eventually did have trouble and suffered for it. It took us quite a while to rebuild that airplane. When finished, it had a much simpler fuel system that both of us trust. My own RV doesn't even have a gascolator because my Cheetah didn't have one. I had one in my C172 and hated it. It leaked. My IA friends don't recommend them, either. The Cheetah didn't and didn't have the problems you fellas worry so much about, such as dirt and water in the fuel. I flew that airplane for well over nine years without fuel system problems, other than some vapor locking caused by auto gas. I expected that and just lived with it. BTW, when was the last time you replaced a fuel filter in a car? If you're the average driver, maybe never? That means gas is pretty clean. Anyway, here's how I did mine. I have fuel flowing from both tanks directly into the fuel selector. The fuel line goes from there up the center along the floor and to the right side of the battery box. It runs along the firewall to the right side where it comes out into the engine compartment. All bends to that point are nice and graceful. Nothing tight. Just inside the engine area is the fuel pump. It's one of the round ones that has no anti-syphon. You don't want anti-syphon because the pump will shut off the fuel flow when it's turned off. Not good. From there, the fuel goes through a T fitting so that I can feed the primer valve from the T. On to the machanical fuel pump from there. In my system, there is a drain on each tank, which is the low point for each tank. I rarely find more than a few drops of water. If there are, I suspect bad O rings and fix them. The round Facet pump has a screen for catching small stuff, as well as the screens on the tank pickups. There is also a finger screen at the carb. I rarely find anything in either. I have found a drop, or two, of water in the small catch basin in the fuel pump; but, that was rare. I've had the carb open on the Cheetah and found nothing but gas. So far, I've had no problems with the fuel system of the RV. I do still get the vapor locks; but, I'm still using auto gas. Oh, yeah. The vapor locks are only on the ground at fast turn arounds. Pat Patterson may be using a gascolator in his RV; but, I'm not sure. I haven't seen one; but, I could have overlooked it. I know he doesn't try to put things in small places like you guys are doing. He does use a check valve at the pump in case the small filter on the little square Facet fills up. Wise move, there. Even though he and I don't agree on some things, we do agree on the KISS method. He uses Van's method that works. I use the Grumman method that works. Both are simple. Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Color Sky MapIIIC Users?
List, I need a little one-on-one with someone who has installed and flown a color Sky MapIIIC in conjunction with a Navaid wing leveler. A recent (but working) installation would be best so that wiring details are fresh in the mind... Thanks. Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Tarra Radio needed
List, I am looking for a used Terra 720 Comm radio to replace the one in my plane that is dying. The company is no longer in business and I would like not have to install a new radio in this plane. Anybody have one sitting on the shelf they would like to sell?? Tom ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Re: Color Sky MapIIIC Users?
Mike, I have that combination on my flying 6A. Here are the wiring connections on the Navaid side, assuming you have the built in Porcine Smart Coupler: 1 Ground 2 Servo Control (green) 3 Jumper to pin 11 (GPS +right) 4 Servo Ground (black) 5 Servo +12V (red) 6 Jumper to pin 12 (GPS +right) 7 -- n/c (Comm PTT switch) 8 GPS data in 9 +12V 10 -- n/c (Gyro test point) 11 Jumper to pin 3 (GPS Coupler +right) 12 Jumper to pin 6 (GPS Coupler +left) Note that I only have the Navaid connected to the Skymap. There's further switching involved if you want to connect to a Nav CDI. From memory, I'm pretty sure that I only used three connections on the Skymap DB9. Ground, power & RS232 out (going to pin 8 on the Navaid). Hope this helps. Regards, Chris Good, http://www.rv.supermatrix.com West Bend, WI RV-6A N86CG, 285 hrs --- Mike Thompson wrote: > > List, > > I need a little one-on-one with someone who has installed and flown a > color Sky MapIIIC in conjunction with a Navaid wing leveler. > > A recent (but working) installation would be best so that wiring > details are fresh in the mind... > > Thanks. > > Mike Thompson > Austin, TX > -6 N140RV (Reserved) > Firewall Forward ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Re: Tarra Radio needed
tom after the expereince i just had with Gulf Coast Avionics, i hate to throw business their way, but they have about 4 of them on the shelf ready to go with or without the racks, i think he quoted me 850 for the com. if you do call down there, they were having problems with their phone earlier. ask to speak to Todd. he is a real nice guy and sold me almost all of my avionics.tell him scott reviere from tampa sent ya, and for him to give you a break on the price :-) =C2=A9 2000 Gulf Coast Avionics Corp. All rights reserved. Phone: 863-709-9714 =E2=80=94 Fax: 863-709-1414 =E2=80=94 Toll Free: 800-474-9714 Email: info@gulf-coast-avionics.com">info@gulf-coast-avionics.com 3650 Drane Field Road, Lakeland Linder Regional Airport Lakeland, Florida 33811 USA 863-709-9714 good luck scott tampa ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Garman 295 Color GPS Hard To See
I had a chance to use my Garman 295 for the first time flying to Lebanon, TN this past weekend with my friend. It worked great!!! Except for the fact I could not see the screen with my sunglasses on. The only way I could really see the screen in the bright daylight and cockpit was to put the GPS down in the shadows, not up where I really would like to have had it. I played with the bright and dim feature but to no avail. I even changed the batteries to see if that would make a difference. Anybody else had any experience with the 295 color map? Dan DeNeal Trying to finish this 6A ________________________________________________________________________________
Date: Sep 26, 2001
Martin You can find better photos of Don Hughes setup of both the gascolator and Facet fuel pump in the wing root at the link below. We also have photos of Rob Ackers version of this setup as well. http://groups.yahoo.com/group/SEFlaRVbuilders/files/Fuel%20System%20Photos%20%26%20Drawings/ Charlie Kuss RV-8A fuselage on hiatus till the heat dies down next month Boca Raton, Fl. > > Question from a newbie with RV6. > I intend to place my Facet pump and gascolator outboard of the fuselage, > in the wing root, as some others have done. However, I am thinking of > placing the gascolator before the pump i.e. upstream, so that it's at > the very lowest point, and to provide an element of filtering before the > fuel gets to the pump. Any thoughts either way welcome. > Cheers > Martin in Oz ________________________________________________________________________________
Subject: Landing Gear
Date: Sep 26, 2001
I have a question for you RV-8A builders. I was testing the fit of my main gear legs into the weldments last night. It seems that they will need the persuasion of a large heavy object to go where they belong. Is this what the rest of you found? I am not ready to install them yet but I was just testing before I bolted my weldments in. Just trying to see how much trouble I'm going to have when I turn the ole girl upside down again and try to put her legs on her. Vince Welch RV-8A Fuselage Roaming Shores, Ohio ________________________________________________________________________________
Subject: Re: Garman 295 Color GPS Hard To See
Date: Sep 26, 2001
Dan, Are your sunglasses Polarized? If they are then that is the problem. You can't see LED type screens through polarized sunglass lenses. Mike Robertson RV-8A >From: Dan DeNeal <rv6apilot(at)yahoo.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Garman 295 Color GPS Hard To See >Date: Wed, 26 Sep 2001 15:11:18 -0700 (PDT) > > >I had a chance to use my Garman 295 for the first time >flying to Lebanon, TN this past weekend with my >friend. > >It worked great!!! Except for the fact I could not see >the screen with my sunglasses on. The only way I could >really see the screen in the bright daylight and >cockpit was to put the GPS down in the shadows, not up >where I really would like to have had it. I played >with the bright and dim feature but to no avail. I >even changed the batteries to see if that would make a >difference. > >Anybody else had any experience with the 295 color >map? > >Dan DeNeal >Trying to finish this 6A > > ________________________________________________________________________________
Subject: Re: Landing Gear
Date: Sep 26, 2001
Vince, You will need to take emery cloth and sand down the landing gear legs and the inside of the weldments to get a good fit. Mike Robertson RV-8A >From: "Vince" <vwelch(at)knownet.net> >Reply-To: rv-list(at)matronics.com >To: "RV8list" , "RV List" >Subject: RV-List: Landing Gear >Date: Wed, 26 Sep 2001 19:02:46 -0400 > > >I have a question for you RV-8A builders. I was testing the fit of >my main gear legs into the weldments last night. It seems that they >will need the persuasion of a large heavy object to go where they >belong. Is this what the rest of you found? > >I am not ready to install them yet but I was just testing before I >bolted my weldments in. Just trying to see how much trouble I'm >going to have when I turn the ole girl upside down again and try to >put her legs on her. > > >Vince Welch >RV-8A Fuselage >Roaming Shores, Ohio > > ________________________________________________________________________________
Date: Sep 26, 2001
> >Hi to all listers - > >A few questions for you: >* Has anyone installed a constant speed prop that was ground down from 72 to >70 inches? The prop had minor damage and has been overhauled by a >supposedly reputable prop shop and stamped experimental. I find myself a >little hesitant. I examined the airplane on which it was damaged - damage >to the plane was indeed minor. >* Does anyone have a wiring diagram for a Terra (now Trimble) TRT 250D >transponder? >* Are there any manuals for Lycoming engines written by third parties such >as the Chilton series of books for cars? Looking for hookup information for >an IO-360 A1B6. is the Lycoming manual the best? > > >Thanks for all of your help. > >Parker Thomas >Rv-8 wings - just closed the first tank (fingers are seriously crossed) The prop diameter is a critical parametre that helps determine whether a particular prop model/engine model combination will have undamped vibrations or not. These vibrations, if they occur, will be at too high a frequency to be noticeable to the pilot, but they could lead to blade failure very quickly. Once the blade comes off, the severe out of balance often causes the engine mount to fail. Bad news. The allowable range of diameters for any given prop model/engine model combination can be found on the FAA Type Certificate Data Sheet (TCDS) for the propeller. If you are talking about one of the Hartzell models that Van sells, I have a copy of the TCDS that I could e-mail to you. Some of the relevant prop/engine combinations can go down to 70 inch diameter, but most are limited to 72 inches (I'm pretty sure the limit is 72 inches for the IO-360-A1B6 engine/Van's Hartzell). Take care, -- Kevin Horton RV-8 (installing engine) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Re: Compaq iPaq's!
Hi all, A short time ago someone was asking about the Compaq Ipaq hand held PC. I have a brand new (2 months old ) iPAQ 3635 for sale. I was planing to use it in my "6" but decided to stay with my tried and true GPS. If your interested, please e-mail off list Thanks Rich ________________________________________________________________________________
"Rv-List(at)Matronics.Com"
Subject: New RV-10 Page on the Van's Aircraft web site...
Date: Sep 26, 2001
I just saw this tonight... http://www.vansaircraft.com/ -Bill ________________________________________________________________________________
Date: Sep 26, 2001
Vince... Although the tolerance is very close, after putting some general purpose grease on the legs, they slid in fairly easily... When I moved to the airport I had to remove them, and the grease allowed them to slide right out... I have posted new pix of the -8A out in the hanger & yesterday's mounting of the engine! -Bill VonDane Colorado Springs, CO RV-8A - N8VD - Finish http://vondane.com/rv8a/ -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Vince Subject: RV-List: Landing Gear I have a question for you RV-8A builders. I was testing the fit of my main gear legs into the weldments last night. It seems that they will need the persuasion of a large heavy object to go where they belong. Is this what the rest of you found? I am not ready to install them yet but I was just testing before I bolted my weldments in. Just trying to see how much trouble I'm going to have when I turn the ole girl upside down again and try to put her legs on her. Vince Welch RV-8A Fuselage Roaming Shores, Ohio ________________________________________________________________________________
Subject: Moving project
Date: Sep 26, 2001
I did this about 3 months ago. It takes a 26 ft truck. The limitation is length of the flat area. Measure the fuselage, it must fit into the flat area in the center of the bed. I rented a U-haul Truck. It was much less expensive than Ryder and they have blankets and other packing materials at nominal cost. There were tie points at three levels at the side of the van. None were in the floor. Insist on a new vehicle. Mine was a GM and ran beautifully. Also the U-Hauls have a lower floor height than the Ryder and a lower center of gravity. They also come with a long ramp which made the loading easy enough. I had the use of a friend for the day. He, my wife and I loaded the project on the truck. Only needed the wife to help load the fuselage. I had stands which I used for building which cradled the fuselage. I tied these together with some 1X10's and screws to form a shipping cradle. We sat the fuselage on foam cushions on the floor of the garage. Carried the cradle into the truck, then carried the fuselage into the truck and placed it in cradle. I tied the fuselage into the cradle and then tied the cradle to the truck. The other parts were not that difficult. Just use a lot of packing material. The common straps with the tightners you can get at the hardware store worked well tying the wings to the truck. The tail parts, flaps etc fitted well on the raised platform. The engine went in on its shop stand. I had no damage. Cushion well as these trucks, lightly loaded, ride rough. And take it easy. Sixty will get you there. Good luck! Tom Norman -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ken Balch Subject: RV-List: Moving project It looks like I'm going to need to move my project from MA to TX at the end of next month. I'd like to get some input on how best to do this. I'm figuring on something like a 24' Ryder truck, but would like to hear from anyone who has actually done a project move like this. Assuming that I can't screw braces into the truck's floor, how should I secure my RV in place for the move? Any ideas? -- Regards, Ken Balch Ashland, MA RV-8 #81125 (N118KB) installing engine stuff groups.yahoo.com/group/BostonRVBuilders/files/ ________________________________________________________________________________
Date: Sep 26, 2001
Thanks Mike. ----- Original Message ----- From: "Mike Robertson" <mrobert569(at)hotmail.com> Subject: Re: RV-List: Landing Gear > > Vince, > > You will need to take emery cloth and sand down the landing gear legs and > the inside of the weldments to get a good fit. > > Mike Robertson > RV-8A > > > >From: "Vince" <vwelch(at)knownet.net> > >Reply-To: rv-list(at)matronics.com > >To: "RV8list" , "RV List" > >Subject: RV-List: Landing Gear > >Date: Wed, 26 Sep 2001 19:02:46 -0400 > > > > > >I have a question for you RV-8A builders. I was testing the fit of > >my main gear legs into the weldments last night. It seems that they > >will need the persuasion of a large heavy object to go where they > >belong. Is this what the rest of you found? > > > >I am not ready to install them yet but I was just testing before I > >bolted my weldments in. Just trying to see how much trouble I'm > >going to have when I turn the ole girl upside down again and try to > >put her legs on her. > > > > > >Vince Welch > >RV-8A Fuselage > >Roaming Shores, Ohio > > > > > > ________________________________________________________________________________
Date: Sep 26, 2001
> I hate to beat this thing to death but... In placing > the servo motor I would like to know if I'm on the > right track. Should I pin the aileron and elevator to > a neutral position then position the servo such that > the servo rod will be parallel with the aileron torque > tube both fore and aft and up and down (lateral and > vertical) in order to keep from having elevator > intervention. (Under passenger seat instulation) To minimize the chance of coupling to the elevator, I put the servo as far forward as possible, just barely avoiding having the base of the stick and/or aileron push rods interfere with the servo arm. That minimizes the angle between the servo and the control stick, minimizing any tendancy to couple in pitch. My servo sits in a small metal tray that is attached to some 3/4 x 3/4 angle riveted to the sides of the seat ribs. The angle pieces touch the floor, and form a small "shelf" for the tray. I attached the servo to the tray, and slid the tray forward and backward until I found the best location, then attached the tray to the angles. I've been very happy with the results. No discernable pitch coupling. Tim Lewis ******************************** The DCA Infinite TCA... "America's Southern No Fly Zone" ******************************** Tim Lewis -- Fairfax, VA RV-6A N47TD - First Flight 18 Dec 99 http://www.geocities.com/timrv6a ****** ________________________________________________________________________________
Subject: Re: New RV-10 Page on the Van's Aircraft web site...
Date: Sep 26, 2001
Trust Van's to come up with a worthwhile design. I can understand having doors instead of a sliding or tip-up canopy - probably easier to run the shoulder harness mounts to the overhead structure. Tom N787RV (reserved) ----- Original Message ----- From: "Bill VonDane" <n8vd(at)earthlink.net> Subject: RV-List: New RV-10 Page on the Van's Aircraft web site... > > I just saw this tonight... > > http://www.vansaircraft.com/ > > -Bill > > ________________________________________________________________________________
Date: Sep 26, 2001
Subject: Re: Airline bailout - not RV related
In a message dated 9/26/01 7:15:54 AM Pacific Daylight Time, billshook(at)earthlink.net writes: << Makes me believe that one day I'll be able to buy an American car that closely resembles the imports in quality, engineering and value WITHOUT the government needed to artificially inflate the imports prices by taxing them to death. >> Frankly, I've bought several new American cars since the '80s and the biggest problem I see with them (and most of the imports) isn't assembly or design related, it's the bean counters that force the absolute crappiest stuff to be bought at rock bottom dollar to the minimum requirements of the Engineering Drawings and Engineering/Quality requirements traded off to "value engineering" the life out of everything. It's an extension on the old something for nothing principle. Sell them beautiful junk. Astronauts have repeatedly made similar observations regarding their confidence (or lack thereof) in a spacecraft built entirely by the lowest bidder. For just a little more money quality parts can be had. My airplane, on the other hand, was constructed of the highest quality parts/systems and crafted with loving hands. It exceeds in every way the requirements of the designer. With good maintenance and care it should last a lifetime. That's quality and value. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Subject: Re: flap actuator rods 6
Date: Sep 26, 2001
Hi Don, I just went through this. My kit is a year 2000 and what came was one piece of aluminum tube labeled as part number F-459. It must be cut in two and then drilled and tapped for the 1/4-28 threads. Its junk in my opinion and I called Van's and ordered the flap rods for the RV-9. These are the hexagon ones that are pre-drilled and tapped for the rod ends. They must be cut to length but there is plenty of threaded area. I put a picture on my website of the two rods side by side. Check it out on this page: http://enewton.addr.com/finish/controls.html Scroll down to the third picture. The flap rods are a little pricy (around $14 a piece I think) but worth it in my opinion. Happy building, Eric Newton - Long Beach, MS RV-6A N57ME (FAA inspection tentatively scheduled for October 5th) www.ericsrv6a.com ----- Original Message ----- From: Don Jordan <dons6a(at)juno.com> Subject: RV-List: flap actuator rods 6 > > I have lost my flap actuator rods that goes with the weird rod ends. > Deb managed to loose my interior for 6 months. > > The B/P shows an F-659. Are they actually parts or do I build them from > round or hex tubes? > > Seams like I had 2 pcs at one time that were hex shaped & already > threaded. > > > Don Jordan - N6DJ - 6A > Arlington, Tx > ****************************** ________________________________________________________________________________
Subject: FAA Inspection Scheduled
Date: Sep 26, 2001
To all who answered my question regarding advise on calling the FAA about my paperwork, thanks for your responses. I took everyone's advise and called to see if it had arrived and within a couple of hours an inspector called me back and scheduled an inspection "tentatively" for October 5th If not then it will be October 19th as he goes on vacation after the 5th. That's fine with me I can wait either way as I have lots of prep work for painting to do. He sounds like a nice guy. I'll keep you all posted as to how it goes. Blue Skies and happy building, Eric Newton - Long Beach, MS RV-6A N57ME (FAA inspection scheduled for the 5th of Oct or the 19th maybe?) www.ericsrv6a.com ________________________________________________________________________________
Subject: source of dessicant
Date: Sep 27, 2001
All, Thanks to all who provided suggestions for finding dessicant. I made many calls but didn't come up with anything. However, I did stumble across a website advertising a cat litter made only of silica gel. I went to Wal-mart and they have a very good selection, so I picked some up. Now all I have to worry about is something crapping in my toolbox. ;-) Kelly -8QB fuselage ________________________________________________________________________________
Subject: Static Pressure Head
Date: Sep 27, 2001
In Van's static pressure kit, he provides a rivet to be installed, drilled out, and plastic tubing attached for installation of the aircraft static pressure system. The S-Tec A/P pitch transducer kit provides an alternate head, and recommends that the Van's head be drilled out and replaced with the S-Tec fitting. I read in a message some months ago, but can't find in the archives that someone with an S-Tec autopilot indicated they had servo control problems until they separated the aircraft static pressure system from the S-Tec system. I assume they put in two sets of static heads. Can anyone who has the S-Tec system comment please. Duane Bentley West Chester, OH RV-6 (Finishing kit) ________________________________________________________________________________
Date: Sep 27, 2001
Dan, Try using the external power plug. It significantly increases brightness. Chuck & Dave Rowbotham RV-8A (18 hours) Niantic, CT (Westerly airport) ________________________________________________________________________________
Subject: Metal Working Site
Date: Sep 27, 2001
08:35:06 AM Heres a fun site for metal working toys. Wish I could do half of what they are talking about. Eric http://www.tinmantech.com/index.html ________________________________________________________________________________
Date: Sep 27, 2001
From: "William G. MacIntyre" <macintyr(at)vims.edu>
Subject: False spar for RV-8 QB
Vans suggests that the RV8 fuselage be supported (after removal from the fuselage jig) from a false spar (rather than resting on a saw horse) . I presume this support from a false spar should also apply to the Quick Build fuselage as delivered. The RV8 manual provides a thickness dimension for a false spar, but I have not found other dimensions in the manual. Questions: 1. Is support from a false spar necessary during work on the RV8 fuselage (till the landing gear is installed), or is support by saw horse adequate? 2. Is a dimensioned plan for construction of the false spar available? I would appreciate any suggestions on how best to support the fuselage, and thank you in advance for your comments. Bill MacIntyre ________________________________________________________________________________
Subject: Clamp Down on General Aviation
Date: Sep 27, 2001
Here's a link to an article written about general aviation, published in the Washington Post. I can't remember if this link was posted on the RV list or not (I read several BB's and lists). I found it on the AOPA's site. http://www.washingtonpost.com/wp-dyn/articles/A19877-2001Sep24.html Here's the moron's email address that wrote it... jakinney(at)earthlink.net please let him know what you think of his most uninformed and inflamatory article. Mr. Kinney's best quote... "small, private aircraft that clog our skies" enjoy! Bryan Jones ________________________________________________________________________________
Subject: Re: False spar for RV-8 QB
Date: Sep 27, 2001
I left the fuselage on the Styrofoam that came as part of the shipping crate (this might have been in the wings crate) and worked on it with the fuse on the ground and not propped up on saw horses. This made it easy to get in and out of, and to crawl into the tail section without worrying about tipping the fuselage one way or the other. Just my two cents. Rick Jory ----- Original Message ----- From: William G. MacIntyre <macintyr(at)vims.edu> Subject: RV-List: False spar for RV-8 QB > > Vans suggests that the RV8 fuselage be supported (after removal from the > fuselage jig) from a false spar (rather than resting on a saw horse) . I > presume this support from a false spar should also apply to the Quick Build > fuselage as delivered. The RV8 manual provides a thickness dimension for > a false spar, but I have not found other dimensions in the manual. Questions: > 1. Is support from a false spar necessary during work on the RV8 fuselage > (till the landing gear is installed), or is support by saw horse adequate? > > 2. Is a dimensioned plan for construction of the false spar available? > > I would appreciate any suggestions on how best to support the fuselage, and > thank you in advance for your comments. > > Bill MacIntyre > > ________________________________________________________________________________
Date: Sep 18, 2001
Subject: Re: 'Remember' memorial patches for your jackets (and decals).
Dave I will take 2. Just let us know where and when to send money. Earl RV4 "Reeves, Doug" wrote: > > Hi gang, > > With the generous help of Austin, TX RV-6 builder Mike Thompson the ball > is now rolling for the creation and distribution of David Paranteau's > 'Remember' patch. I've set up a page on my site where you can sign a > guest book if you intend to purchase one/both/several. We're trying to > gauge how many to have made in the initial run (we get a substantial > price break if we order 500 as opposed to 200). Again, ALL proceeds go > to the American Red Cross. > > We're thinking the cost of the patch will be between $10 and $15 > (depending on how many we order). That should give us a $7-$10 donation > on each patch (still gathering info on sticker prices - will get back on > that). The page also includes a larger version of the patch for you to > inspect. It's at: > http://www.metronet.com/~dreeves/david_paranteaus_remember_patch.htm > > Best as always, > > Doug Reeves > http://www.vansaircraft.net > > ________________________________________________________________________________
Date: Sep 18, 2001
Subject: CAP handheld radio
I have a ladyfriend machanic at US Air in Charlotte who just got her pink slip from U.S. Air. She is trying to raise some money to move. She has a Motorola FM handheld radio on Civil Air Patrol Freqs. If anyone is interested she want's $275.00. Let me know if interested and I put you in touch with her. ________________________________________________________________________________
Date: Sep 27, 2001
Bill - you need the false spar to safely support the fuse. If you use saw horses, you might dent the underside of the fuselage. Also, without bolted on legs (attached to the false spar) it might fall off the saw horses. I don't recall any drawings for this item - you have to use your imagination! Just mic your spar tongue(?) and make your false spar to this thickness (~+ 0.020", -0.000"). have adequate length to project out either side of the fuselage to allow legs or other to be bolted on. Use a hard wood that is fairly rigid (so it won't squeeze or distort in the spar center section). Bryan Jones -8 Pearland, Texas ________________________________________________________________________________
Subject: Scuffing
Date: Sep 27, 2001
I'm using Avery's swivel flush rivet set on my empennage skins, but somehow the skin is getting "scuffed" a bit around the rivet. It's purely cosmetic, but it's annoying and I'm wondering if there's a way to avoid it. I remember hearing about people shaving off a little rubber from the swivel set...was the purpose to avoid the scuffing? Or does it have to do with my wife's nails getting in the way and not letting her hold the set firmly in place (she's shooting, I'm bucking)? Or is it something completely different? Any advice is much appreciated. )_( Dan RV-7 N747DC dan(at)rvproject.com http://www.rvproject.com ________________________________________________________________________________
Date: Sep 27, 2001
I have been using mine for almost a year and have had no problems. I wear ________________________________________________________________________________
Date: Sep 27, 2001
Sorry, didn't finish. I wear polaried shades and have had no trouble. Len Leggette RV-8A N901LL (res) Greensboro, N.C. Plumbing & Wiring ________________________________________________________________________________
Date: Sep 27, 2001
Subject: Re: Clamp Down on General Aviation
Make sure you go to AOPA's website and read Phil Boyer's excellent response. http://www.aopa.org/whatsnew/newsitems/2001/010926letter.html -- On Thu, 27 Sep 2001, Bryan Jones wrote: > > Here's a link to an article written about general aviation, published in the > Washington Post. I can't remember if this link was posted on the RV list or > not (I read several BB's and lists). I found it on the AOPA's site. > > http://www.washingtonpost.com/wp-dyn/articles/A19877-2001Sep24.html > > Here's the moron's email address that wrote it... > > jakinney(at)earthlink.net > > please let him know what you think of his most uninformed and inflamatory > article. > > Mr. Kinney's best quote... "small, private aircraft that clog our skies" > > enjoy! > > Bryan Jones > > ________________________________________________________________________________
Subject: Re: Scuffing
Date: Sep 27, 2001
Use some clear packaging tape on the flush rivet set. It will last for 10 rivets or so before it needs replacement. This eliminated all "scuffing" problems on my project. I also use this tape on my round rivet set. I never had a smiley again! Other types of tape work on these sets as well, like cloth tape (not duct tape). Carl Froehlich RV-8A (moving project to the hanger next month) Vienna, VA ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: Scuffing > > I'm using Avery's swivel flush rivet set on my empennage skins, but somehow > the skin is getting "scuffed" a bit around the rivet. It's purely cosmetic, > but it's annoying and I'm wondering if there's a way to avoid it. > > I remember hearing about people shaving off a little rubber from the swivel > set...was the purpose to avoid the scuffing? Or does it have to do with my > wife's nails getting in the way and not letting her hold the set firmly in > place (she's shooting, I'm bucking)? Or is it something completely > different? > > Any advice is much appreciated. > > )_( Dan > RV-7 N747DC > dan(at)rvproject.com > http://www.rvproject.com > > ________________________________________________________________________________
Date: Sep 27, 2001
Ditto on the packaging tape, but it also helps if you leave most of the plastic on your skins. I use a hot soldering iron to melt a line down both sides of a row of holes, then peel off the strip of plastic. This exposes the rivet holes so you won't trap plastic under them, but protects the rest of the skin until you are ready to paint. This helps prevent shop rash during storage, too. Jim Bower St. Louis, MO RV-6A N143DJ Wings (Fuselage parts inventoried and waiting) >From: "Dan Checkoway" <dan(at)rvproject.com> >Reply-To: rv-list(at)matronics.com >To: , , > >Subject: RV-List: Scuffing >Date: Thu, 27 Sep 2001 07:22:48 -0700 > > >I'm using Avery's swivel flush rivet set on my empennage skins, but somehow >the skin is getting "scuffed" a bit around the rivet. It's purely >cosmetic, >but it's annoying and I'm wondering if there's a way to avoid it. > >I remember hearing about people shaving off a little rubber from the swivel >set...was the purpose to avoid the scuffing? Or does it have to do with my >wife's nails getting in the way and not letting her hold the set firmly in >place (she's shooting, I'm bucking)? Or is it something completely >different? > >Any advice is much appreciated. > >)_( Dan >RV-7 N747DC >dan(at)rvproject.com >http://www.rvproject.com > > ________________________________________________________________________________
Date: Sep 27, 2001
Date: Sep 27, 2001
I used two saw horses, each with a different leg length, to support our QB fuselage. I just made sure the cross piece was a 2X6 with the larger flat side against the fuselage skin to spread the load as much as possible. It worked great. And it made leveling the fuselage easy also as I just used a long thread eye bolt in the tail tie-down point. Once the fuelage was level I tightened a jam nut I had pre-installed on the eye bolt. This arrangement worked well for the installation of the empenage and wings. Mike Robertson RV-8A >From: "William G. MacIntyre" <macintyr(at)vims.edu> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: False spar for RV-8 QB >Date: Thu, 27 Sep 2001 09:32:33 -0400 > > >Vans suggests that the RV8 fuselage be supported (after removal from the >fuselage jig) from a false spar (rather than resting on a saw horse) . I >presume this support from a false spar should also apply to the Quick Build >fuselage as delivered. The RV8 manual provides a thickness dimension for >a false spar, but I have not found other dimensions in the manual. >Questions: >1. Is support from a false spar necessary during work on the RV8 fuselage >(till the landing gear is installed), or is support by saw horse adequate? > >2. Is a dimensioned plan for construction of the false spar available? > >I would appreciate any suggestions on how best to support the fuselage, and >thank you in advance for your comments. > >Bill MacIntyre > > ________________________________________________________________________________
Date: Sep 27, 2001
When I uncrated my QB-8 it had a "false spar" already bolted on and attached to the crate. After careful removal of the false spar from the crate, I used it to support the fuselage on my roll around fuselage stand. I can get pictures of it if you want. -- Michael Stephan QB-8 ---------- >From: "William G. MacIntyre" <macintyr(at)vims.edu> >To: rv-list(at)matronics.com >Subject: RV-List: False spar for RV-8 QB >Date: Thu, Sep 27, 2001, 8:32 AM > > > Vans suggests that the RV8 fuselage be supported (after removal from the > fuselage jig) from a false spar (rather than resting on a saw horse) . I > presume this support from a false spar should also apply to the Quick Build > fuselage as delivered. The RV8 manual provides a thickness dimension for > a false spar, but I have not found other dimensions in the manual. ________________________________________________________________________________
Date: Sep 27, 2001
Len, What plane are you using it in since you say your plumbing & Wiring. I have a feeling this great view from an all clear canopy doesn't give the shade like a Cessna etc. Dan DeNeal RV6a (trying to finish) --- Lenleg(at)aol.com wrote: > > Sorry, didn't finish. I wear polaried shades and > have had no trouble. > > Len Leggette RV-8A > N901LL (res) > Greensboro, N.C. > Plumbing & Wiring > > > > http://www.matronics.com/unsubscribe > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > http://phone.yahoo.com ________________________________________________________________________________
Date: Sep 27, 2001
Dan, Two quick things. One, which you have already heard I'm sure, is to not worry about it as that will alll be hidden once you paint it. That being said, you may want to try putting a piece of duct tape on the flush tip. It helps to reduce the scuffing and helps keep the tip from moving around much. Good luck. Mike Robertson RV-8A >From: "Dan Checkoway" <dan(at)rvproject.com> >Reply-To: rv-list(at)matronics.com >To: , , > >Subject: RV-List: Scuffing >Date: Thu, 27 Sep 2001 07:22:48 -0700 > > >I'm using Avery's swivel flush rivet set on my empennage skins, but somehow >the skin is getting "scuffed" a bit around the rivet. It's purely >cosmetic, >but it's annoying and I'm wondering if there's a way to avoid it. > >I remember hearing about people shaving off a little rubber from the swivel >set...was the purpose to avoid the scuffing? Or does it have to do with my >wife's nails getting in the way and not letting her hold the set firmly in >place (she's shooting, I'm bucking)? Or is it something completely >different? > >Any advice is much appreciated. > >)_( Dan >RV-7 N747DC >dan(at)rvproject.com >http://www.rvproject.com > > ________________________________________________________________________________
Date: Sep 27, 2001
Are you using tape over your rivets? When I started doing this, all the scuffing disappeared on my skins :-) Good luck, John Rott (j_rott(at)hotmail.com) RV7A Rudder >From: "Dan Checkoway" <dan(at)rvproject.com> >Reply-To: rv-list(at)matronics.com >To: , , > >Subject: RV-List: Scuffing >Date: Thu, 27 Sep 2001 07:22:48 -0700 > > >I'm using Avery's swivel flush rivet set on my empennage skins, but somehow >the skin is getting "scuffed" a bit around the rivet. It's purely >cosmetic, >but it's annoying and I'm wondering if there's a way to avoid it. > >I remember hearing about people shaving off a little rubber from the swivel >set...was the purpose to avoid the scuffing? Or does it have to do with my >wife's nails getting in the way and not letting her hold the set firmly in >place (she's shooting, I'm bucking)? Or is it something completely >different? > >Any advice is much appreciated. > >)_( Dan >RV-7 N747DC >dan(at)rvproject.com >http://www.rvproject.com > > ________________________________________________________________________________
Date: Sep 27, 2001
You are probably right. I am using it right now in an Archer. Danny King is using one I think in his 8 on a mount off the roll over bar. Danny are you having any trouble? Len Leggette RV-8A N901LL (res) Greensboro, N.C. Plumbing & Wiring ________________________________________________________________________________
From: "Ellis H Mcgaughy" <Ellis.H.Mcgaughy-1(at)usa.dupont.com>
Date: Sep 27, 2001
How long can one leave the plastic covering material on (during storage) and not have difficulty removing it? Van's instructions indicate it's OK to leave the plastic film on, as long as it is not left on "too long." What is "too long?" Just finished my RV7 HS Deciding whether to peel the plastic off or not before storing. Ellis McGaughy ________________________________________________________________________________
From: david.keck(at)amd.com.amdint2.amd.com.with.ESMTP.id.NAA18825.for (8.9.3/8.9.3/AMD)
Date: Sep 27, 2001
Here is an auto-reply I got from Kinney's email account when I sent my response to his article: ================================================================== Dear Friend: The purpose of this communication is to respond to the many messages that I have received concerning the article I wrote on general aviation security. I regret this impersonal way of responding, but I simply do not have the time to respond to every email in a detailed way. Our world has changed since the Boeing airliners crashed in the World Trade Center and Pentagon. We are fighting a clever and nearly invisible enemy and this task will take our creative energy and hard-thinking if we are to achieve success. There are a number of things that I would like to say. I apologize for the language "clog our skies." This was unfair and I am sorry. I note that this characterization came from a USAF pilot but I am responsible. There are many threats to our national security. Our world was changed on September 11. General aviation is just one potential area of concern. But there are many valid scenarios that suggest that GA aircraft could be used to inflict serious harm on the American public. As some of you know, a 16-year old boy flying with an instructor buzzed the Fayette, Georgia, fair, nearly hitting a Ferris wheel and frightening fair goers. There are numerous scenarios that could be proffered of small aircraft harming hundreds of innocent people. From a security professionals perspective, general aviation airfield security in many locations is often very weak. There are 19,119 airports in America with 219,464 planes. I suspect that larger GA facilities have some security but many, probably a majority, have no security at all. Any one can drive through open gates (if they exist at all) right up to a plane. While many pilots lock and secure their planes, many do not. There is technology available that could be developed to make it virtually impossible for an unauthorized user to operate a plane. I think that this technology is worth exploring. The long-term response to our enemy will come through (1) better intelligence and (2) pre-emptive strikes that will destroy those who oppose us. In other words, we need to identify our enemy and destroy him before he has the chance to harm us. I advocate a no-prisoners policy, which is a departure from our historic practice. Americans who aid our enemy should likewise be incarcerated as a threat to our security. The general aviation is a valuable industry and it should be restored to flying at the earliest possible time. I would like to see this industry grow and prosper and would oppose any measures that would harm it. I find it interesting that only a handful of correspondents have asked me to identify ways that security professionals could help make this industry more secure. Frankly, I do not have the time to provide the type of study that can and should be done beyond what I have done here. I would like to tell you about me personally. I have benefited from the enormous contributions that general aviation provides. I think, for example, of the mercy flights that corporations make for sick children. I once had a child who was sick in a hospital for nearly two months 2,010 miles from home. He could not be stabilized and eventually died after 47 days in a hospital. I grew up in the heart of the general aviation industry in Wichita, Kansas. I had five brothers and at one time or another they worked for Beech, Cessna, Lear Jet, and Boeing. One brother, now deceased, was an aeronautical engineer and another brother is a GA pilot. It saddens me to realize how many people have personalized what I have written as a personal attack from me upon them. It is equally distressing to realize that many individuals believe that I am writing about them and their personal aircraft. Many GA pilots see flying as a cherished right, not a privilege. I think that the events of September 11 may change that once and for all. Finally, I am a former Marine who has fought and nearly died for this country. A number of people have made especially offensive comments to me that make me wonder what motivates some of you. We need to place our nations interests first, not those of our personal agenda. In closing, we will require Gods grace and wisdom to handle this crisis. Our President has said we are at war. Lets think about our nation, and pray for Gods help. Sincerely, JOSEPH A. KINNEY ________________________________________________________________________________
Date: Sep 27, 2001
Please read the reply JOSEPH A. KINNEY sent to me. ****************************************************************************** ************************************************************ I am curious, Tim. =C2=A0Were commercial airliners a problem before 9/11? =C2=A0 Here is a general reply that I have been sending: Dear Friend: The purpose of this communication is to respond to the many messages that I have received concerning the article I wrote on general aviation security. =C2=A0I regret this impersonal way of responding, but I simply do not have the time to respond to every email in a detailed way. Our world has changed since the Boeing airliners crashed in the World Trade Center and Pentagon. =C2=A0We are fighting a clever and nearly invisible enemy and this task will take our creative energy and hard-thinking if we are to achieve success. =C2=A0 There are a number of things that I would like to say. =CB=86=C2=A0I apologize for the language "clog our skies." =C2=A0This was unfair and I am sorry. =C2=A0I note that this characterization came from a USAF pilot but I am responsible. =CB=86=C2=A0There are many threats to our national security. =C2=A0Our world was changed on September 11. General aviation is just one potential area of concern. =C2=A0But there are many valid scenarios that suggest that GA aircraft could be used to inflict serious harm on the American public. =C2=A0As some of you know, a 16-year old boy flying with an instructor buzzed the Fayette, Georgia, fair, nearly hitting a Ferris wheel and frightening fair goers. =C2=A0There are numerous scenarios that could be proffered of small aircraft harming hundreds of innocent people. =C2=A0 =CB=86=C2=A0From a security professional=C2=B9s perspective, general aviation airfield security in many locations is often very weak. =C2=A0There are 19,119 airports in America with 219,464 planes. =C2=A0I suspect that larger GA facilities have some security but many, probably a majority, have no security at all. =C2=A0Any one can drive through open gates (if they exist at all) right up to a plane. =C2=A0While many pilots lock and secure their planes, many do not. =CB=86=C2=A0There is technology available that could be developed to make it virtually impossible for an unauthorized user to operate a plane. =C2=A0I think that this technology is worth exploring. =C2=A0 =CB=86=C2=A0The long-term response to our enemy will come through (1) better intelligence and (2) pre-emptive strikes that will destroy those who oppose us. =C2=A0In other words, we need to identify our enemy and destroy him before he has the chance to harm us. =C2=A0I advocate a no-prisoners policy, which is a departure from our historic practice. =C2=A0Americans who aid our enemy should likewise be incarcerated as a threat to our security. =CB=86=C2=A0The general aviation is a valuable industry and it should be restored to flying at the earliest possible time. =C2=A0I would like to see this industry grow and prosper and would oppose any measures that would harm it. =C2=A0 I find it interesting that only a handful of correspondents have asked me to identify ways that security professionals could help make this industry more secure. =C2=A0Frankly, I do not have the time to provide the type of study that can and should be done beyond what I have done here. I would like to tell you about me personally. =C2=A0I have benefited from the enormous contributions that general aviation provides. =C2=A0I think, for example, of the mercy flights that corporations make for sick children. =C2=A0I once had a child who was sick in a hospital for nearly two months 2,010 miles from home. =C2=A0He could not be stabilized and eventually died after 47 days in a hospital. =C2=A0 I grew up in the heart of the general aviation industry in Wichita, Kansas. =C2=A0I had five brothers and at one time or another they worked for Beech, Cessna, Lear Jet, and Boeing. =C2=A0One brother, now deceased, was an aeronautical engineer and another brother is a GA pilot. It saddens me to realize how many people have personalized what I have written as a personal attack from me upon them. =C2=A0It is equally distressing to realize that many individuals believe that I am writing about them and their personal aircraft. =C2=A0Many GA pilots see flying as a cherished right, not a privilege. =C2=A0I think that the events of September 11 may change that once and for all. Finally, I am a former Marine who has fought and nearly died for this country. =C2=A0A number of people have made especially offensive comments to me that make me wonder what motivates some of you. =C2=A0We need to place our nation=C2=B9s interests first, not those of our personal agenda. =C2=A0 In closing, we will require God=C2=B9s grace and wisdom to handle this crisis. =C2=A0Our President has said we are at war. =C2=A0Let=C2=B9s think about our nation, and pray for God=C2=B9s help. Sincerely, JOSEPH A. KINNEY ________________________________________________________________________________
Subject: Re: Before you calm back down (Not RV Related)
Date: Sep 27, 2001
Archie Bunker had it figured out years ago: Give every passenger a gun as they board .... maybe he was ahead of his time. Also, a great quote from the Denver Post this morning...a commentator related knowing a woman in Lebanon who said she always carried a bomb in her luggage, because she thought it highly improbable there would ever the TWO bombs on an airplane !!! John at Salida, CO ________________________________________________________________________________
Date: Sep 27, 2001
I would like to see pictures if you could Michael. I remember removing the false spars from my QB, then promptly tossing them out - I guess I should have thought about it a little first. Right now my Fuse is on sturdy homemade saw horses with a wide top (about 12") with Styrofoam between from the QB crating. I strapped the tail down to one saw horse to keep it secure. I also put wheels on the saw horses so I could roll the fuse around. The biggest problem I have is the fuse is a little too high to easily work on the internals without standing on a small stool. Todd Wenzel twenzel(at)hsdinc.com Delafield, Wisconsin RV-8AQB, Fuse (on my tippy-toes) -----Original Message----- From: Michael Stephan [mailto:mstephan(at)shr.net] Subject: Re: RV-List: False spar for RV-8 QB When I uncrated my QB-8 it had a "false spar" already bolted on and attached to the crate. After careful removal of the false spar from the crate, I used it to support the fuselage on my roll around fuselage stand. I can get pictures of it if you want. -- Michael Stephan QB-8 ---------- >From: "William G. MacIntyre" <macintyr(at)vims.edu> >To: rv-list(at)matronics.com >Subject: RV-List: False spar for RV-8 QB >Date: Thu, Sep 27, 2001, 8:32 AM > > > Vans suggests that the RV8 fuselage be supported (after removal from the > fuselage jig) from a false spar (rather than resting on a saw horse) . I > presume this support from a false spar should also apply to the Quick Build > fuselage as delivered. The RV8 manual provides a thickness dimension for > a false spar, but I have not found other dimensions in the manual. ________________________________________________________________________________
Subject: Scuffing
Date: Sep 27, 2001
Ellis, On my wing kit the plastic had been on for two years (purchased 2nd hand) and was hard to remove. Leaving it on (in my opinion) also allowed moisture to trap underneath the plastic. All my skins are free of plastic now. Jack RV8 DSM -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ellis H Mcgaughy Subject: Re: RV-List: Scuffing How long can one leave the plastic covering material on (during storage) and not have difficulty removing it? Van's instructions indicate it's OK to leave the plastic film on, as long as it is not left on "too long." What is "too long?" Just finished my RV7 HS Deciding whether to peel the plastic off or not before storing. Ellis McGaughy ________________________________________________________________________________
Date: Sep 27, 2001
Ellis, I have left the plastic film on skins as long as a year before removing them without any difficulty. I now use the rationale that I'll leave the films on skins while I'm doing most of the cutting and fitting. It is difficult to do good deburring of holes or edges with the films on. While doing empennage and wings, I removed strips of the film over holes so that I could deburr holes and dimple. Richard Dudley -6A fuselage Ellis H Mcgaughy wrote: > > > How long can one leave the plastic covering material on (during storage) > and not have difficulty removing it? Van's instructions indicate it's OK > to leave the plastic film on, as long as it is not left on "too long." > What is "too long?" > > Just finished my RV7 HS > Deciding whether to peel the plastic off or not before storing. > > Ellis McGaughy > > ________________________________________________________________________________
Subject: Before you calm back down (Not RV Related)
Date: Sep 27, 2001
I wonder: How fast can you intentionally depressurize a plane? Isn't that a normal procedure for fighting an in-flight fire? That would seem to be a pretty potent weapon the pilots could wield, which might hurt fewer passengers than slamming them against the ceiling. At altitude, it would seem that depressurization would slow down hijackers who were trying to batter down the pilot's door, with pax and crew at their stations equipped with oxygen, it would preferentially disable the hijackers who were running around, probably using more oxygen than normal. > Guns would only help if you had enough notice of a problem > developing. If a > problem was developing the flight crew would notify ATC and > start toward an > immediate landing with the police waiting. The new and > improved cockpit > door should provide the protection for the cockpit. If the new and > improved cockpit door was being breached, then possibly use > erratic flying > to knock down the would be hijacker, thus allowing the PAX to > pummel the guy > / guys. If surprise access to the cockpit was achieved, then > it would be to > late for the crew to draw down on the intruder. > > ________________________________________________________________________________
Date: Sep 27, 2001
Todd, I threw together a webpage with my fuselage cart and pictures of the false spars. If you remember from the crate the false spars are just multiple plywood layers about a 1.25" thick. They are fastened to the spar carry though with two bolts on each side. Use also used the bolts that came in the crate. They had a plastic protective sleeve. I guess to protect the holes drilled in the spar. I did not tighten the nuts. The nuts just keep them captured so they don't slip out. The only difficulty in making a new pair is getting the holes drilled accurately enough without damaging the holes in the spar attach point. But they do not have to be perfect. They just have to support the fuselage. So elongated or oversize holes may not hurt. I would just mark the blank, take it out and drill it on a drill press. http://www.shrc.com/rv8/fuselagecart.html hope it helps. -- Michael Stephan ---------- >From: "Todd Wenzel" <TWenzel(at)hsdinc.com> >To: >Subject: RE: RV-List: False spar for RV-8 QB >Date: Thu, Sep 27, 2001, 2:29 PM > > I would like to see pictures if you could Michael. I remember removing > the false spars from my QB, then promptly tossing them out - I guess I > should have thought about it a little first. Right now my Fuse is on > sturdy homemade saw horses with a wide top (about 12") with Styrofoam > between from the QB crating. I strapped the tail down to one saw horse > to keep it secure. I also put wheels on the saw horses so I could roll > the fuse around. The biggest problem I have is the fuse is a little too > high to easily work on the internals without standing on a small stool. > > Todd Wenzel > twenzel(at)hsdinc.com > Delafield, Wisconsin > RV-8AQB, Fuse (on my tippy-toes) ________________________________________________________________________________
Date: Sep 27, 2001
> How long can one leave the plastic covering material on (during storage) > and not have difficulty removing it? Van's instructions indicate it's OK > to leave the plastic film on, as long as it is not left on "too long." > What is "too long?" Just peel it off immediately, unless you are going to not paint your plane. Scratches that look terrible on the aluminum don't show up under paint. Scotch brite the scratches until no high spots remain, paint and fly. Alex Peterson Maple Grove, MN 6A N66AP flying, oh scratch that, flyable. ________________________________________________________________________________
Date: Sep 27, 2001
Hello, Mine has been on more than four years and it still peels off the same now as it did on day one. Jim in Kelowna ----- Original Message ----- From: "Ellis H Mcgaughy" <Ellis.H.Mcgaughy-1(at)usa.dupont.com> Subject: Re: RV-List: Scuffing > > How long can one leave the plastic covering material on (during storage) > and not have difficulty removing it? Van's instructions indicate it's OK > to leave the plastic film on, as long as it is not left on "too long." > What is "too long?" > > Just finished my RV7 HS > Deciding whether to peel the plastic off or not before storing. > > Ellis McGaughy > ________________________________________________________________________________
Date: Sep 27, 2001
Very fast. That idea is batted around. Problem is, if you are only at 280 or so it might take a while to incapacitate them. At higher altitudes, that might be a very good idea indeed. Keith Hughes RV-6 finish UAL737 ----- Original Message ----- From: Don Hyde <DonH(at)axonn.com> Subject: RE: RV-List: Before you calm back down (Not RV Related) > > I wonder: > > How fast can you intentionally depressurize a plane? Isn't that a normal > procedure for fighting an in-flight fire? That would seem to be a pretty > potent weapon the pilots could wield, which might hurt fewer passengers than > slamming them against the ceiling. > ________________________________________________________________________________
Date: Sep 27, 2001
Dan, we put masking tape over the steel part of the driver and that helped. One thing to watch is the fact that the masking tape will wear in the center where the rivet hits. Also (Two things to watch) the tape will attract tash and will cause blemishes arround the rivet, however changing the tape often will solve both problems. FWIW after we almost finished riveting we noted that the metal will have to be scuffed for priming so we may have been too careful anyway. Good luyck Rod & Rollie 6A Canopy fairing ________________________________________________________________________________
Date: Sep 27, 2001
Hello, I tried many different kinds of tape applied to the rivet set surface and found that as the tape aged during riveting it began to break down and the tape bits and pieces either got stuck under the rivet head and or around the rivet edges. This made for extra work and I quit using this approach. I found that getting the broken down tape off the set was also a hassle. I now use a scotch tape that is about one half as sticky as the regular type. ( back riveting tape works good) I use it for three reasons: First; To hold the rivets in place on the piece I am about to rivet. Second; To stop the marring and discoloration that can occur during the riveting process. Third; This tape leaves no residue behind. used only once this way, it does not break down. I Put the rivets in place, put the tape over them, rivet them, then remove the tape. The tape comes off quick and easy and it is dirt cheap, I'm sorry but I cannot remember the name of this tape. It was more than four years ago that I bought it from an office supply store. I'll bet you'll like it If you try it. Jim in Kelowna ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: Scuffing > > I'm using Avery's swivel flush rivet set on my empennage skins, but somehow > the skin is getting "scuffed" a bit around the rivet. It's purely cosmetic, > but it's annoying and I'm wondering if there's a way to avoid it. > > I remember hearing about people shaving off a little rubber from the swivel > set...was the purpose to avoid the scuffing? Or does it have to do with my > wife's nails getting in the way and not letting her hold the set firmly in > place (she's shooting, I'm bucking)? Or is it something completely > different? > > Any advice is much appreciated. > > )_( Dan > RV-7 N747DC > dan(at)rvproject.com > http://www.rvproject.com > > ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Date: Sep 27, 2001
This is what I have been thinking too: " Guns would only help if you had enough notice of a problem developing. If a problem was developing the flight crew would notify ATC and start toward an immediate landing with the police waiting. The new and improved cockpit door should provide the protection for the cockpit. If the new and improved cockpit door was being breached, then possibly use erratic flying to knock down the would be hijacker, thus allowing the PAX to pummel the guy / guys. If surprise access to the cockpit was achieved, then it would be to late for the crew to draw down on the intruder. " If the cockpit door was reinforced, couldn't the pilots don their O2, and begin depressurizing the passenger compartment? Wait until everyone goes nighty-night and then cuff and stuff the snoozing terrorists? No guns necessary. Sure some poor old guy might have a heart attack but that's why they carry paddles on board now right? ;-) ________________________________________________________________________________
Date: Sep 27, 2001
Bingo! -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Don Hyde [mailto:DonH(at)axonn.com] Subject: RE: RV-List: Before you calm back down (Not RV Related) I wonder: How fast can you intentionally depressurize a plane? Isn't that a normal procedure for fighting an in-flight fire? That would seem to be a pretty potent weapon the pilots could wield, which might hurt fewer passengers than slamming them against the ceiling. At altitude, it would seem that depressurization would slow down hijackers who were trying to batter down the pilot's door, with pax and crew at their stations equipped with oxygen, it would preferentially disable the hijackers who were running around, probably using more oxygen than normal. > Guns would only help if you had enough notice of a problem > developing. If a > problem was developing the flight crew would notify ATC and > start toward an > immediate landing with the police waiting. The new and > improved cockpit > door should provide the protection for the cockpit. If the new and > improved cockpit door was being breached, then possibly use > erratic flying > to knock down the would be hijacker, thus allowing the PAX to > pummel the guy > / guys. If surprise access to the cockpit was achieved, then > it would be to > late for the crew to draw down on the intruder. > > ________________________________________________________________________________
Date: Sep 27, 2001
The tape is probably "Scotch Removable Magic Tape", product no. 811. Bob Trumpfheller > I now use a scotch tape that is about one half as sticky as the regular > type. ( back riveting tape works good) I use it for three reasons: > > First; To hold the rivets in place on the piece I am about to rivet. > > Second; To stop the marring and discoloration that can occur during the > riveting process. > > Third; This tape leaves no residue behind. used only once this way, it does > not break down. > > I Put the rivets in place, put the tape over them, rivet them, then remove > the tape. > The tape comes off quick and easy and it is dirt cheap, > > I'm sorry but I cannot remember the name of this tape. It was more than four > years ago that I bought it from an office supply store. > > I'll bet you'll like it If you try it. > > Jim in Kelowna > ________________________________________________________________________________
Date: Sep 27, 2001
I hope you will find my rebuff of Kinney's article amusing: http://www.vansairforce.org/misc/security_panic.html Tedd McHenry Surrey, BC ________________________________________________________________________________
Date: Sep 27, 2001
Hi Bob, Thats the stuff! Thanks Jim ----- Original Message ----- From: <Trumpfheller(at)aol.com> Subject: Re: RV-List: Scuffing > > The tape is probably "Scotch Removable Magic Tape", product no. 811. > > Bob Trumpfheller > > > > I now use a scotch tape that is about one half as sticky as the regular > > type. ( back riveting tape works good) I use it for three reasons: > > > > First; To hold the rivets in place on the piece I am about to rivet. > > > > Second; To stop the marring and discoloration that can occur during the > > riveting process. > > > > Third; This tape leaves no residue behind. used only once this way, it does > > not break down. > > > > I Put the rivets in place, put the tape over them, rivet them, then remove > > the tape. > > The tape comes off quick and easy and it is dirt cheap, > > > > I'm sorry but I cannot remember the name of this tape. It was more than > four > > years ago that I bought it from an office supply store. > > > > I'll bet you'll like it If you try it. > > > > Jim in Kelowna > > > > ________________________________________________________________________________
Subject: Re: C-660 Side Skirt...
Date: Sep 27, 2001
> Quick question on the side skirts (C-660) for a slider....drawing SC-1 > Detail "A" (both drawings) shows the side skirts just level with the side > skin, but on Drawing SC-2 (Section F-F) is shows about a 3/4 in overlap, > which makes more sense as it lines up with the aft deck. Any ideas here? Im > leaning toward the 3/4 in overlap as it is more logical??? Kurt, Due to the curve of the fuselage, its doesn't generally work to overlap all the way forward. As the canopy slides back the overlapped portion will bind since the widest point is about halfway up the canopy. For this reason most people either overlap just the rear 1/2 - 2/3, or don't overlap at all. I did the combo -- overlapped the rear portion, and trimmed it so it makes a jog up to just above the canopy deck about 2/3 of the way forward. I couldn't find a very good picture of it but there's one that sort of shows it on my web site -- have a look at http://www.edt.com/homewing/rhproject/n6r_grin2.jpg. (BTW there IS a way to overlap completely -- Art Chard does it on the planes he builds. It involves taking the curve out of the longerons in the canopy area, which flattens the sides of the fuselage. I think it messes up the look of the fuselage, and in any case you'd want to be really sure about what you're doing before trying that, since every change has unintended consequences.) Randall Henderson, RV-6 N6R (~280 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Date: Sep 28, 2001
Subject: Hanoi Jane
Guys, While we're on this thread of folks not understanding things...A buddy just sent this to me. I'd like to add this under the "Let's Remember" File. I know I'll never forget or forgive what she did!!!! Sorry not true RV stuff but, important none the less...! Jim Duckett, Nam Vet and RV-7A Builder From - Thu Sep 27 22:29:14 2001 (envelope-from pbparker@in-tch.com) Date: Thu, 27 Sep 2001 19:21:27 -0600 From: Pat and Becky Parker <pbparker@in-tch.com> Brent and Tonya Weninger , Clifford Garness <cliffman@in-tch.com>, Cliff Garness <cliff@sletten-inc.com>, Cody Parker , Cory Koterba , Dave Parker , Dean Taylor , Hall Hugg , Heather Topp , Jim Duckett , Jim Mills , Karen & Dan Griffin , Karla Mills , Kelly Weinberger , Rick Nowaski , Robert Morgan , Scott &Irene Pocklington , Scott Weinberger , Steve Shovlin , Tracey Wagner , Walt , Wayne Thomas Subject: Hanoi Jane > > >> KEEP THIS MOVING ACROSS AMERICA HONORING A TRAITOR > >> > >>This is for all the kids born in the 70's that do not > >>remember this, and didn't have to bear the burden, that > >>our fathers, mothers, and older brothers and sisters had to bear. > >> > >>Jane Fonda is being honored as one of the "100 Women of > >>the Century." Unfortunately, many have forgotten and > >>still countless others have never known how Ms. Fonda > >>betrayed not only the idea of our country but specific > >>men who served and sacrificed during Vietnam. > >>The first part of this is from an F-4E pilot. The pilot's > >>name is Jerry Driscoll, a River Rat. In 1978, the former > >>Commandant of the USAF Survival School was a POW in Ho Lo > >>Prison-the "Hanoi Hilton." Dragged from a stinking > >>cesspit of a cell, cleaned, fed, and dressed in clean > >>PJs, he was ordered to describe for a visiting American > >>"Peace Activist" the "lenient and humane treatment" he'd > >>received. He spat at Ms. Fonda, was clubbed, and dragged > >>away. > >>During the subsequent beating, he fell forward upon the > >>camp Commandant's feet, which sent that officer berserk. > >>In '78, the AF Col. still suffered from double vision > >>(which permanently ended his flying days) from the > >>Vietnamese Col.'s frenzied application of a wooden baton. > >>From 1963-65, Col. Larry Carrigan was in the 47FW/DO > >>(F-4Es). He spent 6 -years in the "Hilton"- the first > >>three of which he was "missing in action". His wife lived > >>on faith that he was still alive. His group, too, got the > >>cleaned/fed/clothed routine in preparation for a "peace > >>delegation" visit. > >>They, however, had time and devised a plan to get word to > >>the world that they still survived. Each man secreted a > >>tiny piece of paper, with his SSN on it, in the palm of > >>his hand. When paraded before Ms. Fonda and a cameraman, > >>she walked the line, shaking each man's hand and asking > >>little encouraging snippets like: "Aren't you sorry you > >>bombed babies?" and "Are you grateful for the humane > > >>treatment from your benevolent captors?" Believing this > >>HAD to be an act, they each palmed her their sliver of > >>paper. > >> She took them all without missing a beat. At the end of > >>the line and once the camera stopped rolling, to the > >>shocked disbelief of the POWs, she turned to the officer > >>in charge and handed him the little pile of papers. Three > >>men died from the subsequent beatings. Col. Carrigan was > >>almost number four but he survived, which is the only > >>reason we know about, her actions that day. > >>I was a civilian economic development advisor in Vietnam, > >>and was captured by the North Vietnamese communists in > >>South Vietnam in 1968, and held for over 5 years. I spent > >>27 months in solitary confinement, one year in a cage in > >>Cambodia, and one year in a "black box" in Hanoi. My > >>North Vietnamese captors deliberately poisoned and > >>murdered a female missionary, a nurse in a leprosarium in > >>Ban me Thuot, South Vietnam, whom I buried in the jungle > >>near the Cambodian border. > >>At one time, I was weighing approximately 90 lbs. (My > >>normal weight is 170 lbs.) We were Jane Fonda's "war > >>criminals." > >>When Jane Fonda was in Hanoi, I was asked by the camp > >>communist political officer if I would be willing > >>to meet with Jane Fonda. I said yes, for I would like to > >>tell her about the real treatment we POWs received > >>different from the treatment purported by the North > >>Vietnamese, and parroted by Jane Fonda, as "humane and > >>lenient." Because of this, I spent three days on a rocky > >>floor on my knees with outstretched arms with a large > >>amount of steel placed on my hands, and beaten with a > >>bamboo cane till my arms dipped. > >>I had the opportunity to meet with Jane Fonda for a > >>couple of hours after I was released. I asked her if she > >>would be willing to debate me on TV. She did not answer > >>me. > >>This does not exemplify someone who should be honored as > >>part of "100 Years of Great Women." Lest we forget..."100 > >>years of great women" should never include a traitor > >>whose hands are covered with the blood of so many > >>patriots. There are few things I have strong visceral > >>reactions to, but Hanoi Jane's participation in blatant > >>treason, is one of them. > >>Please take the time to forward to as many people as you > >>possibly can. It will eventually end up on her computer > >>and she needs to know that we will never forget. > >> > >> > > > ________________________________________________________________________________
Date: Sep 28, 2001
September 21, 2001 - September 28, 2001
RV-Archive.digest.vol-lo
