RV-Archive.digest.vol-lx
November 20, 2001 - November 29, 2001
> climbs at reduced throttle, and more importantly, without the benefit of the
> carbs full throttle enrichenment. In other words, I was climbing somewhat
> lean, at a sea level airport. Unfortunately, I didn't notice it until I was
> already committed to installing the Ellison TBI, so I never got a chance to
> test the theory with the carb. I did e-mail Lycoming, and they agreed that
> it would have caused my problem, and the Ellison has had no such temp
> problems.
> Russell Duffy
Subject: | Re: Aeroelectric R-10 missing pages |
Hi Andy,
Received my Aero-Conn on Friday sans Chapter 5. Please send to :
Bill Griffin
1107 Nicodemus Road
Reisterstown, MD 21136
Thanks.
Subject: | Re: Oil Pressure Switch |
In a message dated 11/19/2001 8:08:52 PM Pacific Standard Time,
jnorman(at)intermapsystems.com writes:
> Can one of you please give me some insight on the wiring of Van's oil
> pressure switch (the one that is to run the Hobbs, not the oil pressure).
> It has three terminals... what is the proper hook-up for these three
> terminals?
> Thanks,
> Jim
> Tampa
> 6A FWF and cowling done (except for 3 wires)
Hi Jim,
One terminal is power the other two are normally open and normally closed.
The normally open starts the Hobbs when it gets oil pressure and closes. I
use the normally closed terminal to illuminate a master on/low oil pressure
light on the instrument panel. Watch the Hobbs wire hook up. It is polarity
sensitive.
Cash Copeland
RV6
FREE Adult Magazine in your e-mail.
Thats Right. By signing up you will receive our biweekly adult xxx magazine directly
to your e-mail complete with high-quality, highly tasteful adult content.
And its all FREE!!!!
To sign up simply reply to this email with the word "subscribe" in the subject
line.
To accept you must be 18 years or older!!! No Exceptions!
Note: This is a one time mailing. If you do not opt-in you will not be bothered
again.
Subject: | Baffled by Cooling |
A lot of good ideas on improving cooling have been mentioned lately.
Here is another one to add to your list.
The under cylinder baffle wrap-around spacing is important to cooling also.
Kent Paser, in his Book "Speed With Economy" determined through testing
that the under cylinder head gap should be 2.25 inches. The under barrel
gap should be 7/8-1.0" This was an O-320. I measured up a new Lancair 360
the other day and they used 2.0" under the head and 1.5" under the
barrel(mid 300's F, NW summers).
You can get close by using the Lycoming provided center baffle and noting
the edge to center of the barrel distance. Compare your wrap distance to
the center from the other side. I think you will find that the 'Baffle Kit"
gives a wide variety of gaps that don't make much sense given the typical
temps that people find (unless something changed). There is also two hard to
see gaps(holes) near the rear cylinder flange of #4 that are difficult to
plug. I got one of them with a tapered finger spacer about 2.0" long (1/4"
to 0.0 taper). The other is plugged rather crudely with an aluminum wedge
of bent sheet metal. As you all know, the name of the game is to prevent
any high pressure air from getting to the bottom cowl area that isn't doing
cooling work.
One poster mentioned that he used EI Probes on an RMI engine monitor. While
this can be done you must replace the 'J' thermocouple amp for a 'K' amp as
the EI uses "K" for both EGT/CHT(unless designs have changed).
Calibrate!!!!
Good Luck with the building after flight phase.
Lefty and Pancho
Subject: | Looking for drawing to show holes in fuel tank rib end flanges |
OK, I give up. Help!
I've looked at drawings till I'm blue in the face. Am looking in the RV-6 drawings
for the detail that shows how many holes get drilled in the end
flanges that attach the fuel tank ribs to the baffles. Can't find it. heeeellllllllllllpppppppppppppp
Semper Fi
RV-6 (off on the wrong foot already, on the fuel tank for the left wing)
Subject: | Van's Mapbox Kit |
Guys, is there anybody who has purchased Van's panel-mounted mapbox kit
who can tell me what thickness aluminum is used for the box? I have some
.032 and .025 scrap that I could make my own out of, but this seems like
overkill.....016 or .020 at most would suffice for this purpose. I
figured if I could save some weight (yes, I count ounces) and time by
ordering Van's kit that I'd go that route, but I called Vans yesterday
and the guy on the phone said he didn't know and really couldn't tell me
(!?) what thickness aluminum is used in their mapbox kit...
--Mark Navratil
Cedar Rapids, Iowa
RV-8A fuselage, finish kit on order....
Subject: | Re: Looking for drawing to show holes in fuel tank rib end flanges |
Drawing 18a ...lower left corner. These are the infamous "why are these
dimpled" rivets.
Jerry Calvert
Edmond Ok -6
----- Original Message -----
Subject: RV-List: Looking for drawing to show holes in fuel tank rib end
flanges
drawings for the detail that shows how many holes get drilled in the end
> Semper Fi
> John
From: | "Jim Norman, MD" <jnorman(at)intermapsystems.com> |
Subject: | Oil Pressure Switch |
Great... thanks...
But, which one is which?
jim
polarity
sensitive.
Cash Copeland
RV6
From: | Jerry Springer <jsflyrv(at)earthlink.net> |
Subject: | Re: Van's Mapbox Kit |
To me that is a pretty simple answer, you said you are counting ounces
so why not make it out of .016 and not worry about what Van makes his
out of? BTW I used .016 for mine and it is plenty sturdy.
Jerry S
> Thanks,
> --Mark Navratil
> Cedar Rapids, Iowa
Subject: | Re: You might be an RV builder if... |
You might be an RV builder if.....
You had Carpal Tunnel surgery on your cleco hand after finishing the
wings (yes, I did).
Your definition of "expensive" has changed (upward) dramatically.
"Only
$120.00? Hell, get two!"
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Firewall Forward
Michael E. Thompson (Grobdriver(at)yahoo.com)
Austin, TX, USA
RV-6 in progress, N140RV (Reserved)
EX-AX1 Sub Hunter, P-3 (B/B-TACMOD/C) Orion Aircrew,
PP-G,ASEL, Motorglider Driver and Unlimited Air Race Nut!
http://geocities.yahoo.com/ps/info1
Subject: | Baffle/cowling painting? |
I've been thinking that it might be a good idea to paint the baffles &
cowling interior with a high-temp, gloss white paint. This ought to
make it easy to clean and also prevent oil from soaking into the
fiberglass. Can anyone suggest a good paint for this purpose,
preferably in a rattle can?
Ken Balch
Ashland, MA
RV-8 #81125 (N118KB)
installing engine stuff
groups.yahoo.com/group/BostonRVBuilders/files/
Subject: | Re: Traffic avoidance system |
You might look at the Monroy device as advertised in a number of
publications (I think the web is www.monroyaero.com . I don't own one but
have two flights in planes equipped with them. The units are relatively
small (3/4" high, 3 1/4" wide) and can be panel mounted or placed on the
glareshield . . . Of course, they work on the principle of picking up a
transponder signal . . . so there is no directional capability and if your
potential midair isn't squawking you'll have to trust your eyes. The
warning signal is both audible (female voice that can be muted) and a series
of lights. It's a bit more expensive than the unit you've mentioned.
Rick Jory
Subject: RV-List: Traffic avoidance system
> Hello everyone
> Anyone on the list heard about,bought or tried the traffic
> avoidance system offered by www.sureaviation.com and if so what do you
thick
> about it.For the price ($595.00US.)It seems to be a very good and
affordable
> system.Any comments is welcome good or bad.
> Thank you
> Bruno Dionne
> RV-4 C-GDBH
> fo320(at)sympatico.ca
jim
my oil switch from vans has a label on it. its is marked nc ( normally closed
) no ( normally open ) and com ( common )
stop by the shop and i'll show you how i hooked mine up.
scott
tampa
You might be an RV builder if the words "Pro Seal" causes shakes and
shudders or results in temporary amnesia.
You might be an RV builder if the words "Pre-prepunch, Prepunch and matched
holes" brings tears to your eyes.
Ed Anderson
RV-6A N494BW
Matthews, NC
Subject: | Re: Baffled on the cooling |
In a message dated 11/19/01 9:06:10 PM Pacific Standard Time, Emrath(at)home.com
writes:
> For what its worth, our local EAA Chapter put on an engine installation
> seminar this weekend. The gentleman was discussing his O-360 fixed pitched
> installation on a Cozy IV (as in 4 place). He advises there is
> "temperature
> tape" available that you can put on an item, go fly, and then observe the
> color change. I've not heard of this, nor know where to get some, nor how
> accurate it is. Maybe others do.
These are available from McMaster-Carr and several part numbers cover a broad
range of temperatures. They are also available at welding supply outlets.
-GV (RV-6A N1GV)
vanremog(at)aol.com
Subject: | Re: Baffle/cowling painting? |
11/20/2001 09:59:20 AM
Hi Ken,
I anodized my baffles, but painted the cowl interior with white epoxy
paint. I used a two-part boat paint by Petit. I was worried about the
temperature resistance, but it hasn't even turned brown in the areas where
the exhaust pipes pass within a 1/2" or so (after 42 hours). You do have
to mix it up, but it can be easily rolled or brushed with disposable tools.
Good luck,
Dean
| | Ken Balch |
| | Sent by: |
| | owner-rv-list-server@mat|
| | ronics.com |
| | 11/20/01 08:27 AM |
| | Please respond to |
| | rv-list |
| To: "rv-list(at)matronics.com"
| cc:
| bcc:
| Subject: RV-List: Baffle/cowling painting?
Ken Balch
Ashland, MA
**** This is intended for the addressee only and may contain
confidential business information. It may not be copied
without our permission. If you are not the intended recipient,
please contact the sender as soon as possible and
delete the material from any computer.****
Subject: | Shielded wire... |
"Rv8list@Egroups"
What's the best price on 3 strand shielded wire you all have found?
-Bill VonDane
Colorado Springs, CO
RV-8A - N8VD
http://vondane.com/rv8a/
mailto:bill(at)vondane.com
In a message dated 11/20/2001 5:36:12 AM Pacific Standard Time,
kbalch1(at)mediaone.net writes:
Applying paint to the inside of your cowl is a good idea I just used the same
Dupont Corlar primer that I primed my plane with for that. Painting your
baffling just adds weight and after a few hours of run time it is not all
that good looking
...you have just re-drilled the same hole (or within .001") in your left
thumb for the fourth, fifth, or sixth time within a year and you still have
the urge to de-burr it, dimple or counter sink it and then squeeze a flush
head rivet (dipped in primer "of course") in the hole... before you decide
to go get another F%*&~`ing bandage.
...you still remember fondly your first ride in an RV but can't remember
exactly how much you've spent so far building your baby.
...you argue the difference between primers like "it really matters",
because you know you'll be dead and gone long before your baby ever sees her
first bit of corrosion (that's just for us guys & gals in the desert areas).
...you've accidentally gotten addicted to Matt's list because you're already
addicted to the endorphins caused by your RV.
...you are suppose to be working (because after all, you are at work, you
are on your company computer "right now") and you are on "The List".
yep, this will likely go on & on.
Chuck
DEFINITELY FILL and PAINT the inside of the cowl. You don't want oil soaking
into it through the pinholes.
I used a few coats of sanding primer to fill, then shot it with high-temp
paint ("Hot Stuff" rattle-can paint, from an auto parts store). Probably not
the best paint to use but its holding up well.
BE SURE to also put some heat shielding on your cowl! I got some heat damage
before I did this and I know some others have as well. Seems to be more of
an issue with the newer epoxy cowls than the polyester. Van's now stocks
heat shielding material. See
http://www.edt.com/homewing/rhproject/maintenance.html for more.
Randall Henderson, RV-6 N6R (~300 hrs)
Portland, OR
www.vanshomewing.org
If on your anniversary, before going out to eat, you stop by another
builder that is further along then you are to check things out.
You call home several times a day and ask your wife if anything is on the
loading dock (front porch) from UPS,
Your yard is the not as well kept as it should be, well lets say it is:
just plane neglected.
You come dragging home at 3 in the morning and when asked "where have you
been" you can say with a clear conscience. Been at the hanger, working on
the plane. Time just got away from me.
Ken, I used aluminum foil 12" wide and glued it on with epoxy mixed with a
little micro balloons. You don't want to add a bunch of weight so just swipe
the epoxy over the surface with a small squeegee, then lay a piece of foil in
place and starting from the center, smooth out any bubbles using a dry 2"
paint brush. It's lighter than painting, reflects the heat and is non
absorbent.
If you wish you could spray on a light coat of epoxy primer or top coat and
lay the foil into that, instead of the laminating epoxy.
To get the paint to work properly you will have to fill all the pin holes,
which takes multiple coats, a lot of time, adds weight and is difficult to get
every pin hole. Over time the paint will discolor and the pin holes will start
to show up as the absorb oil and gas. BELIEVE ME I KNOW.
Garry "Casper"
> Regards,
> Ken Balch
> Ashland, MA
Subject: | RV6A tail strobe |
I am ready to install the Whelan tail strobe on my RV6A. I have the
rudder with the cutout on the bottom for the light, however I do not see
an easy way of installing the light. Will someone out there who has
done the tail strobe give me some ideas as how it was done?
Doyal Plute
Just an FYI for everyone.
During my monthly shopping spree at Wentworth Aircraft in Minneapolis, I was
wondering around the junkyard "out back" and saw what appeared to be a
complete set of RV6 wings. Upon closer inspection I found there were !!
Complete with lights, strobes, etc.. and in decent shape. Further searching
brought me to a fuselage (no gear) and tail section.
Turns out this plane is Marcus Cooper's RV6 that the engine blew two years
ago. The plane is in fairly good shape, with the exception of Firewall
Forward.
FYI for everyone working on their canopies, the slider on Marc's -6 was
riveted per plans and even after the lading that sheared the gear, the
canopy doesn't have a crack anywhere. It still opens/closes and slides OK.
Anyway, I just had to pillage some "stuff" from it (Lights, strobes,
switches, breakers, etc..) and just thought I'd let everyone else know the
plane is there and parts are for sale.
If you have any questions or would like a more detailed description of the
plane, contact me off list.
Stein Bruch
MSP, RV6, Finishing
Engine hung, Slider done, Wiring :)
I forgot to mention that you will want to put some kind of heat barrier
(fiberfrax-AS&S) on the cowl prior to the foil in the area where the exhaust
pipes are close. This is especially important on the new S glass cowl as they
are closer to the pipes than the old style polyester cowl. If you have an old
style Vetterman exhaust (made for polyester cowl) and a "S" cowl, things get
really close. Last year Vetterman changed the exhaust to give more clearance
after Vans made the change to the "S" cowl.
Garry "Casper"
> Regards,
> Ken Balch
> Ashland, MA
Subject: | Re: RV6A tail strobe |
In a message dated 11/20/01 12:41:04 PM Eastern Standard Time,
dplute(at)onemain.com writes:
<< I am ready to install the Whelan tail strobe on my RV6A. I have the
Doyal Plute >>
I don't think there is an easy way. I made an aluminum plate that matched
the profile of the "mounting" side of the strobe. Then, I drilled and tapped
it for the screws to mount the strobe. Finally, I glassed it into the rudder
fairing. Easy to explain, but lots of work to complete, especially with all
the fiberglass work required to make the whole thing look good.
Kyle Boatright
0-320/Aymar Demuth RV-6 Slider
Kennesaw, GA
http://www.angelfire.com/my/rv6
...some of the worst insults in your vocabulary are "tuperware,"
"plastic," "porta-poties, "airplane-in-a-tube,"
...you've ever seen a Glasiair builder using channel locks for a rivet
squeezer, and laughed at him before offering the proper tools.
...the best advice you ever heard is "friends don't let friends fly
plastic airplanes."
Jeff Point
-6 fuse
Milwaukee, WI
01:51:41 PM
One way is to get a short piece of aluminum tubing that fits inside the
alum collar of the light. Drill holes in the tube along the sides and glass
into the fairing. Now that will make a recepticle for the light. Use set
screws to lock it in.
Eric Henson
KBoatri144(at)aol.com@matronics.com on 11/20/2001 12:53:36 PM
Sent by: owner-rv-list-server(at)matronics.com
cc:
Subject: Re: RV-List: RV6A tail strobe
Doyal Plute >>
tapped
rudder
all
Kyle Boatright
Kennesaw, GA
02:02:45 PM
Hey Gang,
Just put in the electric flaps. Is the motor supposed to stop itself both
top and bottom? When it hits the bottom, it will stop "motoring" but at the
top it keeps on doing its thing. Do I need to adjust something. How many
parts do I need to reorder?
Thanks and happy Thanksgiving
Eric
Subject: | Re: Someone's already done this soooooooo...Empennage(HS) |
Ralph: The second part of that sentence is the key, "leaving just a flat
tongue". The aft surface of the front spar has to be flat to mate with the
F681.
Harry Crosby
Pleasanton, California
RV-6, finish kit stuff
I used the light bezel as a template to cut the big hole for the light and
drill the little holes for the screws. Then, I took a pair of #4 locknuts,
and assembled the screws that were included with the light to the nuts (as
if the light were in place). Next, I mixed up a handy-dandy batch of JB
Weld and made a fillet of it all over the nuts (it helps to smear some
Vaseline on the ends of the screws. After the JB Weld sets up, the nuts are
bonded into the rudder bottom. Quick and easy.
Jim Bower
St. Louis, MO
RV-6A N143DJ
Wings (Fuselage parts inventoried and waiting)
>From: doyal plute <dplute(at)onemain.com>
>To: "rv6-list(at)matronics.com"
>Subject: RV-List: RV6A tail strobe
>Date: Tue, 20 Nov 2001 11:37:57 -0600
>Thanks:
>Doyal Plute
02:17:16 PM
When getting dressed to go out you ask you wife, "honey what color of
primer stain goes with these pants"? And you have many colors to choose
from.
Living room furniture is avante guard modern aluminum
Shirts are more valued for their clean rag status than as articles of
clothing
The compressor kicks on at 4:00 AM and it does not phase you, nor does the
kick from the wife.
You really don't understand why your building buddy keeps bringing up the
matching holes in the palms of his hands. "Ok, Ok, Jim, now just hold this
here for a sec would ya?"
Work starts an hour after you get to work (except Mondays, more like
Tenish)
The damn dog insist on scratching out the aluminum chips from his coat
right in front of the wife. "If ya can't take the chips, stay out of the
garrage Fido".
Nothing puts a gleam in your eye like a fresh sharpie.
You thumb through Flying magazine in the doctors office without the
slightest intention of reading any of that dribble. "Look honey, the new
172's are on sale for under $300,000" Boy thats $2500.00 a knott vs. $350 a
knott for a new RV. Oh, like you are not always trying to find ways to
justify your habit to yourself. P-lease!
You'd rather read the latest installment of the primer war rather than the
newspaper. (Epoxy Rules).
YOUR GREATEST FEAR IN LIFE WOULD BE THE SHAME OF KNOWING THE LIST OF
CONTRIBUTORS CAME OUT WITHOUT YOUR NAME ON IT. For Shame!
....and I could go on and on but enough about me.
Eric Henson
I just checked mine and it is 0.020. Yeah, I know, that's an odd size.
Harry Crosby
Subject: | Re: 'lectric Flaps |
eric,
the motor is designed to stop pushing or pulling at the end of its travel
limits. it does continue to freewheel at the end of each cycle.
scott
tampa
Subject: | Heat Shielding for Cowl (Was: Baffle/cowling painting) |
Regarding the heat shielding material that Van's now sells...
I have just seen this today, and sadly I must say, it is not as high a
quality as what is available from other sources. I bought mine from Design
Engineering through the Martel Brothers Web site:
http://www.martelbros.com/
Go down the left side nav bar and click on Design Engineering. All this
company makes is heat shielding, and it comes several ways. It is a
fiberglass cloth with an aluminum impregnation. You can get it with an
adhesive backing or without. I just got some and it is great stuff, and,
looks to be significantly better material than what Van's sells for this
application (having compared them myself). Here is a quote from their
product insert: "Designed with many uses in mind, Heat Screen is capable of
withstanding direct heat up to 1000 degrees F. on one side, while protecting
against radiant heat up to 2000 degrees F. on the "aluminized" side."
I bought the sticky stuff, and it is on this page under their marketing name
of "Reflect-A-Cool".
Jim
Tampa
FWF
Subject: | Fuel Flow Monitors |
Listers,
I have had a DPS Fuel Watch System that I had acquired from a salvaged
aircraft
a few years ago and was looking for a manual on the unit so I could install
it in my RV6A.
I have finally found the company that bought out the rights from DPS to
manufacture the unit.
These units were very popular with the Velocity builders and were available
through the Velocity
catalog. The owner tells me that a lot of the Grumman owners have them
installed.
The unit is a fuel flow monitor , tracks fuel quantity. fuel remaining, etc.
Price on the units is $525 including the Flowscan transducer.
He guarantees the electronics for 3 years and the transducer for 2 years.
If you compare what is out there in the market now, this is a pretty good
price
for the unit.
The owner of the company tells me these units are on Warbirds, the Bede
Micro Jet,
and other engines with up to 300hp.
The website for the company is http:\\freeweb.pdq.nwt/dma
contact:
DMA Instruments
14902 Forest Lodge Drive
Houston, TX 77070
The owners is Gene Plazak
Ed Cole
RV6A N2169D Flying
RV6A N648RV Finishing
Maxim Home Page:
http://www.maxim-ic.com
Products Page:
http://www.maxim-ic.com/MaximProducts/products.htm
New Products:
http://dbserv.maxim-ic.com/new_products.cfm
Datasheets:
http://dbserv.maxim-ic.com/l_datasheet3.cfm
The information contained in this message is confidential
and may be legally privileged. The message is intended
solely for the addressee(s). If you are not the intended
recipient, you are hereby notified that any use, dissemination,
or reproduction is strictly prohibited and may be unlawful.
If you are not the intended recipient, please contact the sender
by return e-mail and destroy all copies of the original message.
Subject: | Re: Fuel Flow Monitors |
Correct web address:
http://freeweb.pdq.net/dma/
Rob Acker (RV-6)
Listers,
There is a new AD on the HC-C2YK-1BF props we use on our 360 powered
RV's. Seems the hubs have been cracking and shedding props on a few
aircraft.
You might want to check this out
http://av-info.faa.gov/ad/PublishedADs/012308.html
for the latest on our props. Hartzellpropeller.com has the SB which
lays out the inspection process. A friend of mine gave me the heads up
on this and then later found out his prop is affected. Van's has been
notified so I should think they will post something on their web site.
I'll be checking mine this evening during the oil change
Gary Zilik
You go into shed (shop) after dinner for and hour or two, and have to sneek
in like a mongrel dog to face she who must be obeyed at one, two, or three
in the morning.
Les Rowles.
Traralgon Australia.
My quick take on the AD this morning was that it involves only 'A' flange
props. In other words, HC-C2YA props (for which the fix is a 'B' flange), not
our trusty HC-C2YK props ('K' flange).
If this is not correct, please advise.
Ken Balch
Gary Zilik wrote:
> Listers,
> aircraft.
> Gary Zilik
Subject: | new e-mail address |
My new e-mail address is cgalley(at)qcbc.org as the other ISP decided to drop
service. If your address book has the old "accessus" URL that I used for
over 7 years, please update your records.
Cy Galley - Bellanca Champion Club
Newsletter Editor & EAA TC
www.bellanca-championclub.com
Cy Galley - www.qcbc.org Webmaster
Cy Galley
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Cy Galley - Treasurer, Mississippi Valley Region of the AACA
www.aaca.org/mvr - Webmaster
Cy Galley - webmaster EAA Chapter 75
http://members.tripod.com/~EAA_Chapter_75
Subject: | Re: Shielded wire... |
All my wire ( 1, 2 & 3 wire shielded) was free!!! It pays to have a friend
(RV4 builder Jody Edwards) who works for Raytheon!
Charlie Kuss
> -Bill VonDane
> RV-8A - N8VD
I Epoxied 2 trimed nutplates & remove the light to service. Just not much
room in there.
Don Jordan - N6DJ - 6A
Arlington, Tx
writes:
> see
> has
> Thanks:
> Doyal Plute
Hey Jody---send me a private email--I'll send you my address!!!
Greg
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Charlie Kuss
Subject: Re: RV-List: Shielded wire...
Charlie Kuss
> -Bill VonDane
> RV-8A - N8VD
Subject: | Re: Builders logs. |
Subject: Builders logs.
I have a friend considering the purchase of an almost complete RV. The
seller has bought the airframe in its present condition and has never worked
on it. There are no builders logs.
My understanding of the regs is that it is necessary to have these to
demonstrate that the 51% rule has been complied with. Obviously having the
Repairmans Cerificate is desirable so if you a buy a partly completed kit
without logs is there a way of still qualifying for this?
Your input needed.
Thanks.
Rob
RV9A N919RV resvd.
Subject: | For Sale RV-8 Project |
For Sale!!!!
RV-8 Project,Illinois, Empennage 100% complete including
fiberglass,flaps and ailerons 100% complete. Left wing in fixture with
skins drilled, right wing ready for fixture. Exceptional workmanship.
Call (217) 496-2652 Lee Beare or
Mark Phillips (mphill(at)gcctv.com)
Subject: | Question for Mike Nellis and others re: pitot tube hardware |
I'm posting this to the List because I thought it would be a good thing to have
in the archives (couldn't find the answer there).
This concerns the fittings and tubing that connect the poly-flow tubing to the
pitot tube...questions go in the direction from the pitot tube...I'm
having a few problems figuring out how to ensure everything stays connected.
- Do you use anything like Loctite or pipe tape under the threads of the AN-818
nuts?
- There's a section of aluminum tube between the AN-818 nuts on the pitot tube
and the nylon nuts/fittings. How do you secure the aluminum tube to
the nuts so the tube doesn't fall out?
- Do you use anything like Loctite or pipe tape under the threads between the MS20822
elbow and the nylon female connector?
- Finally, do you need anything else (glue, etc) to keep the poly-flow tubing in
place inside the nylon female connector, or is the nylon insert
sufficient?
Guess that's enough crayon-level questions for tonite...I'm going to go out to
the garage and ponder the spacing of the tank ribs on the
baffle...brain-straining stuff...
RV-6 (mundane stuff on the left wing)
You might be an RV builder if...your significant other says you spend too much
time perusing the Wicks catalog for YOU, and not enough time perusing
the Victoria's Secret catalog for HER.
Subject: | Re: Baffled by Cooling |
I would think management of the "cylinder exit gap" described by Gary below
would be an important variable in controlling cylinder cooling, yet no one
seems to mess with. This is on my to-do list but admittedly quite a ways
down. When I pointed out the varied gaps to Van's staffers they kind of
turned red and said that the baffle kit "wasn't engineered in-house". Hmm,
makes me suspect room for improvement.
Randy Lervold
www.rv-8.com
also.
Kit"
soaking
not
damage
> Portland, OR
Ditto Randall's remarks. Since I painted my airplane though I just used the
same techniques/materials (PPG Concept) to finish the inside. Can't speak to
the rattle can stuff, but if Randall had good luck with it I'd use it. Gary
Graham, Randall, and I all encouraged Van's to stock the new adhesive backed
foil they now carry... it's good stuff and works VERY well. I highly
recommend it. Also, a finished surface on the side of the cowl not only
prevents all that oil & stuff from soaking in, but helps you spot leaks and
allows easy cleanup.
Regarding baffling: I'd anodize it or leave it. I think paint would scratch
way too much and in general be a hassle. Personally, mine is raw. Also,
consider that you will likely be replacing bits of baffling as it wears.
Lastly, here's a tip from Gary Graham's very smart dog Pugsley: smear a thin
coating of high-temp RTV
on the inside of your baffling anywhere it contacts the cylinder fins...
helps prevent the fins from wearing through. Don't know for sure if it works
yet but it sure made sense to me so I did it when re-installing my baffling
after a cylinder swap.
Randy Lervold, RV-8 N558RL, 140 hrs
www.rv-8.com
Home Wing VAF
From: | "Heinrich Gerhardt" <hgerhardt(at)earthlink.net> |
Subject: | RE: RV6-List: RV6A tail strobe |
I threaded the ends of two 1/4" dia, 1" long aluminum rods for 4-40 screws.
Then I roughed up the outsides of them, screwed them to the mounting holes
of the lamp and after taping the outside of the lamp to keep the resin from
sticking to it, potted the whole works into the fairing with cabosil-filled
polyester resin.
[mailto:owner-rv6-list-server(at)matronics.com]On Behalf Of doyal plute
Subject: RV6-List: RV6A tail strobe
--> RV6-List message posted by: doyal plute
Doyal Plute
Subject: | Re: Heat Shielding for Cowl (Was: Baffle/cowling painting) |
> Design Engineering through the Martel Brothers Web site:
[snip]
I'm sure there is better stuff than what Van's sells, but I think it does
the job quite adequately and is probably the lightest weight solution. Also
it's very easy to install. I'm sure you can go as far as you want here, just
not sure its necessary. Of course, time will tell....
Portland, OR
http://www.vanshomewing.org
Subject: | Michael Brown... |
Hi Listers,
In support of the 2001 Email List Fund Raiser, Michael Brown of Brown
Aviation Tool Supply Co. ( http://www.browntool.com ) has generously
offered to provide Gift Certificates to all Listers making Contributions of
$30 or more this year!
Making your Contribution to support these Email Lists and to qualify for
the Brown Tool Gift Certificate is fast and easy by using the SSL Secure
Credit Card Contribution Web Site at:
Or by sending a personal check Contribution to:
Matronics Email Lists
c/o Matt Dralle
PO Box 347
Livermore CA 94551-0347
According to Michael, "The Gift Certificates have absolutely no strings
attached and are as good as cash for anything from the Brown Tool Web Site
or Catalog."
The amount of your Gift Certificate is based on the size of your List
Contribution and is according to the following:
$100 or greater Contribution receives a $25 Gift Certificate!
or
$30-$99 Contribution receives a $10 Gift Certificate!
==================== How To Receive Your Certificate ===================
To receive your Brown Tool Gift Certificate, send an email message to:
browntooloffer(at)matronics.com
and include the following information:
1) Subject Line: Tool Offer
2) Which Gift Certificate you qualify for ($10 or $25)
3) [Your Name]
4) [Your Mailing Address]
5) [Your City, State Zip]
** Please only use the email address shown above (
browntooloffer(at)matronics.com ) to request your Gift Certificate!
*** Anyone making a List Contribution of $30 or more in 2001 qualifies for
the Gift Certificate!
You should receive your Gift Certificate from Brown Tool in about 2-4 weeks.
I want to thank Michael Brown of Brown Aviation Tool Supply Co. for this
wonderful offer in support of the Email Lists! If you haven't yet had a
look at the Brown Tool Web Site ( http://www.browntool.com ), then you own
it to yourself to take a peek! He has some great deals and good quality tools.
And finally, I would like to thank everyone that has already made a
Contribution in this year's Fund Raiser! Its YOUR support that keeps these
Lists running and NOT ADVERTISING and FLASHING BANNER ADS...
Thank you!!
Email List Administrator
Subject: | You might be an RV builder if... |
Naaawwwwwwwwwwwwwww....you're kidding...hmmmmmmm...then again, maybe not...
> squeezer, and laughed at him before offering the proper tool.
...you finally buy that digital camera for taking family photos that your significant
other has been bugging you about, knowing secretly that you
actually bought it to use on your project and at fly-ins.
RV-6 (left wing...gonna walk thru the garage on my way out to the car, to look
at Dwg #18a and see howinthehell I missed the detail on the holes for the
tank rib flanges...dimple 'em, too?)
Subject: | The end of the rainbow....... |
Yesterday I had a tough choice. Either drive 16 hrs.
round trip or fly my RV-6 to get my daughter home from
college for Thanksgiving. Guess which one I chose.
Instead of driving 700 miles (at right angles) I flew
550 miles round trip in the RV. Smooth as glass at
altitude and talking to center the whole way. It was a
beautiful flight. KEEP BUILDING--IT WILL BE WORTH IT SOMEDAY!!!!!!!!!!!!
From: | "Steve Hurlbut" <hurlbut_steve(at)hotmail.com> |
Subject: | Fuel Injection vs Carb |
Why does fuel injection not require an air scoop?
Is it that the prseeure of the fuel injection provides
sifficient air for combustion. Does fuel injection require
as much air as a carburator.
Steve
Kingston, Ont
Concerning the new AD on Hartzell props, the AD applies to the hub.
Additional information and clarification can be found at the Hartzell
website. Go to
http://www.hartzellprop.com/product_support/sitelinks_servdocs.htm and
select HC-SB-61-227 Rev.2. which is the service bulletin referenced in the
AD. Page 4 of the 26 page service bulletin has a diagram which shows the
various hub designs and serial number location.
Howard Williamson
"Aaron Hughston"
Posting for a friend
For Sale
1) completed RV-8 Tail Kit #1000 Asking $1400
2) RMI u-Encoder and u-Monitor. Both are assembled and tested. Comes
with EGT & CHT probes and the gimbaled Compass attachment. Asking
$2591 for both.
Location is So. Cal.
Contact Aaron Hughston @ vne200(at)hotmail.com
Ed Perry
eperry(at)san.rr.com
Subject: | Vertical stabilizer strobe |
Can someone shed some light on how they mounted their vertical stab
strobe? I have the whelen A625 model and the bezel looks to wide to
install directly. Did you have to make a custom faring or special
mounting bracket?
Gary Gunn
RV-6
Subject: | Looking for an engine |
Before starting what will probably be a long and opinionated thread, I
checked the archives. The last post was back in 1999, so I decided to fan
the flames again.
I am beginning a search for a mid-time O-320 for my RV-6A. (My budget says
"no new engines", thus the pre-owned one.) I have reasoned that many
completions have been achieved since the last time an engine search was
archived, so I guess a lot of folks out there have acquired a used engine
that performs to their satisfaction.
What I would like to know is if anybody (particularly those in the Midwest)
can recommend a source of supply that they are happy with. Conversely,
please let me know of any outfits to stay away from.
Jim Bower
St. Louis, MO
RV-6A N143DJ
Subject: | New props need home |
Listers:
I have just listed two NEW props on e-bay. The first is a Felix wood
prop. It is a 72", 83 pitch with all hubs, crushplate and bolts. Go to
the following page for the item....
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1667013154
The second NEW prop is a Sensenich, metal, 72", 83 pitch with
spacer/hub, bolts and logbook. Go to.....
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1666617314
I ran these by the list about 6 months ago and just got a bunch of
comments. Now I am pressed to sell as my wife is ready to kick me and
all these aircraft part out of the house!!! You have all been there!
Thanks for looking
Dave Aronson
RV-4 N504RV
Electrical system to finish then I fly!!!!!!
> [snip]
Also
just
> Portland, OR
Ditto Randall's comments. I can put my hand on the outside of my lower cowl
where the shielding is immediately after a flight and it is barely warm.
Randy Lervold, RV-8 N558RL, 140 hrs.
www.rv-8.com
I am interested also in this type of discussion, since I am at a point
where I need to order the finish kit from Van's for my -8A but need to
know the engine before ordering. I'm not opposed to a new engine, but
I'm thinking about is a O-360 to which I can add electronic ignition and
fuel injection. I guess I would prefer a run-out or close to run-out
O-360 that can be rebuilt or simply purchase a QUALITY rebuilt. Any and
all suggestions are appreciated.
Todd Wenzel
Delafield, WI
RV-8AQB - Fuse
mailto:TWenzel@Heartland-Software.com
Subject: RV-List: Looking for an engine
fan
the flames again.
says
engine
Midwest)
Jim Bower
St. Louis, MO
RV-6A N143DJ
From: | "Larry M Rhea" <rv6larry(at)dslextreme.com> |
I hope Jody still has a job after this reply.
> Bill
> Charlie Kuss
> > -Bill VonDane
> > RV-8A - N8VD
Today my wife Carolyn soloed in our RV-6A. I cant even begin to
express in words how proud I am of her and her accomplishment. I have
to say her solo was bigger and better than when I did the first flight
over 17 months ago.
Her flight training started about 1.5 years ago in a lowly 172. When
she was ready to solo in the 172 her instructor didn't show up. Stuck
in Kansas getting an airplane she said. So another date was picked and
again the instructor did not show up. A call to her house found she
was still in bed and that she had forgotten. At this point Carolyn was
getting a complex, maybe the instructor was trying to tell that she
was not good enough to solo. She was really in the dumps. We fired
her instructor and started a search for another one.
In looking for another instructor we decided that if she were going to
learn to fly so that she could fly the RV she should learn in the RV.
We found a willing instructor (the best I have seen, and as good as
Mike Segar) and set every thing up to start flight training in the RV.
The next day we lost #4 cyl and the engine had to be torn down since
there was metal everywhere.
Well long story short, her flight training began again this summer and
she soloed on this fine day. She made it look easy. Did I mention how
proud I am of my wife. It brought tears to my eyes and the biggest RV
grin ever.
Gary Zilik
Keep building guys, get you wife interested, better yet let her learn
to fly in the Family RV.
Does she have a sister? :-)
Brad
RV6AQB...
Subject: RV-List: RV Solo
over 17 months ago.
grin ever.
Gary Zilik
03:19:09 PM
The wire came from the dumpster after a King Air was gutted. We are the
vandals, not Jody. Jody is merely guilty of knowing us, which is probably
punishment enough.
Eric (swimmin in sketti) Henson
"Larry M Rhea" (at)matronics.com on 11/21/2001
06:23:32 AM
cc:
> Bill
friend
> Charlie Kuss
> > -Bill VonDane
> > RV-8A - N8VD
Todd & Jim,
I know this will start another one of those heated debates, but I visit
Wentworth Aircraft on a regular basis to scrounge up cheap parts. They have
literally Hundreds upon Hundreds of engines in their wharehouse. There are
several rows, stacked floor to ceiling with engines. Everything from C85's
to IO-720's, TCM, Franklin's, and MANY Lyc's. If you look at their website
they list some of the lower time ones for sale. I even saw a Big Block
Chevy from the burnt S-51 mustang they had there.
I've found Wentworth to be wonderful to deal with, as long as you don't try
to barter too much. Many of their engines are from planes that are hail
damaged, flipped on the ground during a storm, hangar collapse, fires, etc..
Some of them are from crashes, but they will let you look at the logs and
the photos from the rest of the plane. They usually dial the crank
themselves and won't knowingly sell you a bum engine. Steve is well aware
of the bogus parts laws, and for this reason they do not sell or re-use many
parts of the plane (Prop Bolts, etc..) They have the tail numbers from each
engine, so you can look up the NTSB damage report yourself and double check
their info. %99.9 they are accurate. I have spent too many dollars their
buying all kinds of goodies! It's like going to Home Depot for Airplanes!
Take a look at their website, and give them a call. It can't hurt!
http://www.wentworthaircraft.com
Best Regards,
Stein Bruch.
RV6 Finishing, MSP.
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Todd Wenzel
Subject: RE: RV-List: Looking for an engine
<TWenzel@Heartland-Software.com>
Todd Wenzel
Delafield, WI
RV-8AQB - Fuse
fan
the flames again.
says
engine
Midwest)
Jim Bower
St. Louis, MO
RV-6A N143DJ
Better yet.... Carolyn, if you ever get tired of Gary ...... ;-)
Scott VanArtsdalen, MCSE, CCNA
Network Administrator
Union Safe Deposit Bank
209-946-5116
From: Benson, Bradley [mailto:bbenson(at)trane.com]
Subject: RE: RV-List: RV Solo
Brad
RV6AQB...
over 17 months ago.
grin ever.
Gary Zilik
Subject: | : Looking for an engine |
Unless you can or have a friend that is an engine man, I would get a new
one from Vans. Next I would go with the Aero Sport people. If you find a
7K run out you can end up with a 12K motor that may or may not be as good
of an OH than Barts.
Arlington, Tx
writes:
> I
> to fan
> the flames again.
> budget says
> many
> was
> engine
> Midwest)
> Conversely,
> Jim Bower
> St. Louis, MO
> RV-6A N143DJ
Don't do it Carolyn!!! Scott's got a 4... and I KNOW HE don't ride in the
back.
Chuck
From: Van Artsdalen, Scott <svanarts(at)unionsafe.com>
> 209-946-5116
> To: 'rv-list(at)matronics.com'
> Brad
> RV6AQB...
> From: Gary Zilik [mailto:zilik(at)bewellnet.com]
> over 17 months ago.
> grin ever.
> Gary Zilik
From: | "Owens, Laird" <Owens(at)aerovironment.com> |
Carolyn, welcome to the fraternity of RV pilots. What a great day for you.
My sincerest congratulations to you, Carolyn for your diligance, and Gary for letting
your wife take off in the RV with out you. (Now that's confidence)!
Next time we fly to the Bahamas, I'll get to see Carolyn in the left seat, and
your RV will be much better looking from that side from now on ;-)
See you guys soon, and congratulations again.
Laird
(Now it must be Vicki's turn, huh Jimmy ;-)
From: rv-list(at)matronics.com on Wed, Nov 21, 2001 12:04 PM
over 17 months ago.
grin ever.
Gary Zilik
>over 17 months ago.
Yep, can't wait for Diana to get there. After spending a hundred hours in
the back of the -4 she watched Van demonstrate the -9A. She says I want
one of those.
..Okay.. I said.
She "graduated" from Henry Gorgas' sheet metal class last week and had some
fine looking parts to show for it. The -9A tail is in the garage. She has
ground school and 16 frustrating hours in a 150 under her belt and says she
will finish when we get the -9A built.
(answer: because I get to keep the -4)
Mike McGee, RV-4 N996RV, O320-E2G, Aurora, OR
13B in gestation mode
Pugsley is alive and well and wishes ya-all a "Happy Thanksgiving"; and so
do I.
Gary
_______
(_o_) ruff!!!!!!
oo-oo
Subject: | Re: Looking for an engine |
Jim: A good source for engines is Bobby Osborn in Mineral Wells TX , PH 940
682 4220 He has used engines and will work with you to get the engine you
want. I bought a 0 320 D2J out of a C172 and he gave me another ass case that
uses the fuel pump and asked me to send the old one back after I got it
apart. Good Man and fair. Might give him a call. Terry E. Cole
In a message dated 11/21/01 6:06:16 PM Eastern Standard Time, TColeE(at)aol.com
writes:
<< Jim: A good source for engines is Bobby Osborn in Mineral Wells TX , PH
940
that
apart. Good Man and fair. Might give him a call. Terry E. Cole >>
I second this recommendation. I got an engine from Bobby and was very
pleased with what I recieved.
Kyle Boatright
Kennesaw, GA
Subject: | Re: Fuel Injection vs Carb |
>Steve
>Kingston, Ont
Fuel injection doesn't require an air scoop if you are using Van's
intake snorkel with an IO-360A series on an RV-7/7A or -8/8A. That
is because Van come up with a nice installation that has a large
rectangular air filter on the bottom floor of the LH cooling air
inlet. There is a long curving duct that routes this air to the fuel
injector air inlet. The air is subjected to the same ram air
pressure increase you would get from a "normal" air scoop. The
induction path is a bit longer, so there is probably a bit greater
pressure loss, but the drag is lower, so the speed vs power works out
the same or better.
The fuel injector on the IO-360A series is on the front of the oil
sump, not hanging off the bottom of the oil sump like most Lyc
carbureted engines. If your engine has a carburetor or fuel injector
hanging below the oil sump you'll need an air scoop because there
won't be enough clearance between the air inlet and the cowling to do
anything else.
Kevin Horton RV-8 (installing engine & electrics)
Ottawa, Canada
http://eccentrix.com/misc/rv8/rv8.html
Subject: | How I lost 1.5 Quarts of Oil in 15 Minutes |
After landing following a short flight on Sunday, I saw a few drops of oil on
the ground under the aircraft. Once I rolled it into my hangar, took a look
at the belly, and it was COVERED in oil... I pulled the dipstick (which was
just sitting there loose, not screwed in??), and checked the oil level - down
from 6 quarts to 4.5 quarts.. I thought this wasn't good, even though there
had been no signs of a problem from the engine instruments.
Next, a buddy and I pulled the cowl, took a look, and it was obvious that all
of the oil had come out of the breather tube. I thougth this was BAD. I was
thinking big $.
Several days and quite a bit of troubleshooting later (I called
textron/lycoming, did a compression check, etc), my favorite AI and I had
found nothing major wrong. The folks at Lycoming did ask how my breather was
installed, and pointed out that my breather hose exit was beviled the wrong
way - it draws a vacuum in the airstream, and should be installed to AVOID
drawing a vacuum.
When I went over this with my AI, we discussed the breather tube, and I
brought up the fact that the oil filler cap was completly loose. He said..
That's it - You had a breather tube drawing a vacuum through the engine, and
with the oil cap off, there was a path for the vacuum to pull air throught
the engine, and this vacuum had sucked 1.5 quarts out in 15 minutes...
I added a quart of oil, put the filler cap on correctly, went flying, and
vola-no oil on the belly.
Lesson learned. Glad it was on a short flight, not on a cross-country.
Kyle Boatright
Kennesaw, GA
PLEASE REMOVE COMANCHE180(at)AOL.COM
From: | Jaye and Scott Jackson <jayeandscott(at)shaw.ca> |
I was thinking of painting the top cowl flat black as I was hoping to have a
military paint scheme. I pretty well thought it was a bad idea in that the
combination of heat-soaking after shutdown and the high surface temperatures
possible with this paint color in the sun might raise the "S" cowl's
temperature high enough for it to reach a plastic state and it might sag.
Does the performance of this heat shield mean this paint idea might still be
possible to do?
Scott in Vancouver
Subject: Re: RV-List: Heat Shielding for Cowl (Was: Baffle/cowling painting)
> > [snip]
does
> Also
> just
> > Portland, OR
cowl
> www.rv-8.com
Subject: | Looking for RV-4 insurance checkout |
I am about to join the ranks of RV-4 owners and am looking for a RV type
specific insurance checkout. Can anyone please direct me to a CFI with
an airplane who can help? I live in Raleigh NC but can travel for the
checkout. I am aware of the Vans-recommended training in Oregon but he
has a 6-week wait list and I it is best not to be too hopeful of OR
weather in Dec.
Any leads are welcome, including if you simply know of someone who
was20
recently checked out.
Paul
Subject: | Sratus pump fittings |
Hi Folks,
I have not been able to locate fittings to connect my Stratus vacuum pump to
the vacuum lines. By chance I do have some Nylo-Seal fittings that will
thread into the inlet/outlet of the pump but am not sure whether the nylon
fittings are suitable for vacuum pumps. Any info is greatly appreciated.
Happy Thanksgiving fellow builders.
Bill Griffin RV6
Balto. MD
Rob,
Getting the aricraft certificated will probably not be a problem as it is
well known that all RVs meet the 51% rule. Where you most likely to have a
problem is the Repairman's Certificate. Has the 'N' number been issued to
this aircraft yet. If not then all you need to do is register your name
under that kit number with Van's and that will take care of the
certification problem for the plane. When you are ready to get the aircraft
registered, you will get a Bill of Sale from Van's and submit that to the
FAA along with the registration application. For the repairman's
certificate get as many pictures of the aircraft during the rest of the
building process with you in the pictures. And start a builder's log from
this point on. That should work but no guarantees.
If you have any other questins give me a shout.
Mike Robertson
Das Fed
RV-8A
>From: "Rob W M Shipley" <glassman(at)tns.net>
>To:
>Subject: RV-List: Re: Builders logs.
>Date: Tue, 20 Nov 2001 16:46:16 -0800
>worked
>Your input needed.
>Thanks.
>Rob
>RV9A N919RV resvd.
Subject: | Re: Looking for RV-4 insurance checkout |
I would call the EAA as they probably have a list of CFIs that will do
transition flights and check outs.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
http://www.eaa.org for latest flying rules
Always looking for articles for the Experimenter
Subject: RV-List: Looking for RV-4 insurance checkout
weather in Dec.
was20
Paul
Larry
No A&Ps were harmed during the making of any of these emails or the acts
described therein. Actually, the field replacement harnesses that Raytheon
supplies are longer than usually needed. (They make them for the longest
"stretch" model) The A&Ps would save this extra wire for those times when "I
need a little more". When the collection grew to 3 very large boxes (in excess
of 100 pounds) the foreman told them to give it the "heave ho".
Jody called me and asked if I wanted it. ....... Of course I said yes. No RV
builder in SE Florida will need any 20, 22 or 26 gauge shielded or unshielded
Tefzel wire for several years. I gave away all the excess to the locals.
Charlie Kuss
> From: "Charlie Kuss" <chaskuss(at)bellsouth.net>
> To:
> > Bill
> > Charlie Kuss
> > > -Bill VonDane
> > > RV-8A - N8VD
Thanks to this list, and the GREAT people on this list, I too will have some
free wire!
Thanks Frank!
-Bill
Larry
excess
RV
unshielded
Charlie Kuss
Subject: | Traffic proximity alert system |
Hello listers
Sorry I posted the wrong web address for the TPAS system,please
try
www.surecheckaviation.com and let me know and the list what you thick.
Cheers
Bruno
RV-4 C-GDBH
I have a used 2-1/4"suction gage that I'm having trouble hooking a hose
to. The threaded ports on the back appear to be between 1/4"and 1/8" NPT
fitting sizes.The tag on the back reads:
GAGE, SUCTION
MS28061-T 4
AERO PRECISION IND. INC
FMC 15017
Does the suction gage require some kind of special fitting, or do I have
one that's European/metric or something?
Chris Brooks
I've finally got actual progress to report on my RV-3 project. I bought the
tail kit from Van's about 2-1/2 years ago. Today, with the help of my
brother, I finished riveting the Horizontal Stabilizer. It came out looking
great with no significant problems. At this rate, I'll be ordering the wing
kit within a year or two!
Rod Woodard
Northern Colorado
RV-3 #11339 Empennage
Subject: | Re: Pros and cons of IO320 to O320 |
Listers,
I am looking into the purchase of a Lycomming 320, for an RV9. It appears Vans
recommends a O320. What are the pros and cons of the IO320 compared to the O320.
Richard Luster
rlluster(at)msn.com
Marysville, WA
RV9, fuse 80% complete
From: | "Paul Besing" <azpilot(at)extremezone.com> |
Pros: More horsepower, inverted flight, altitude capability (all I can
think of)
Cost, maintenance, overhaul, hot starts, complexity.
Since you are building a -9 I guess performance is not that high on your
priority scale. (although the -9 without fuel injection still beats the
pants of most spam cans) I would keep it simple and go with the carburated
engine. If you were building a Rocket or an -8, I'd say go for the
injected.
Paul Besing
RV-6A N197AB Arizona
Flying
Kitlog Pro Builder's Log Software
http://www.kitlog.com
Subject: RV-List: Re: Pros and cons of IO320 to O320
> Listers,
> I am looking into the purchase of a Lycomming 320, for an RV9. It appears> Vans
recommends a O320. What are the pros and cons of the IO320 compared> to the
O320.
> Thanks
> Richard Luster
> rlluster(at)msn.com
> Marysville, WA
From: | "Garth Shearing" <garth(at)Islandnet.com> |
A flat black surface can reach close to 250 degrees Fahrenheit on a hot
summer day while sitting on the ground in still air. No problem while
flying. Many epoxies soften at much lower temperatures, so even without the
engine heat, the cowling could be in trouble if painted black. Softening
can occur in the 160 degree range, a little higher if the finished part has
been post-cured. The epoxy manufacturers have different standards for
determining temperatures at which the cured epoxy softens, distorts, or
whatever. You would probably have to talk to Van's to get the cowling
manufacturer's info. Let us know what the results are if you contact them.
Maybe somebody else on the list will already have this info.
Garth Shearing
VariEze and 80% RV6A
Victoria BC Canada
From: Jaye and Scott Jackson <jayeandscott(at)shaw.ca>
a
Subject: | Golf Bags and Skis |
I was looking at a mod to carry golf bags in a 6/7/9 by Dave Ford at
http://members7.clubphoto.com/dave493645/553869/guest.phtml
when I thought, gee, I could have done this as well as the ski
compartment I have in my 6A. See mine at
http://www.metronet.com/~dreeves/BuilderMods/NormanHunger/luggagecompartment_skirack.htm
I figure that mine will carry one big golf bag or two mid sized bags.
Dave's looks bigger. Mine goes back to the tail for really big ski's
which is why it's floor is at the level of the longerons. The longer
skis need to be up there to get loaded with my tip up canopy.
Both sites hosted on Doug's most excellent site, thanks again Doug.
Anyhow, nice work Dave.
Norman Hunger
RV6A Delta BC
Why do you say "more horsepower"? I believe Lycoming claims 160 hp
for both the O-320 and IO-320 (assuming the high compression
versions). Sure, the IO-360A and C series make 20 hp more than the
O-360, but those engines have a lot of differences, not just the fuel
injection. The IO-360B series is pretty much identical to the O-360
(except for the fuel injection), and it is a 180 hp engine (according
to Lycoming).
You may be able to get a bit lower fuel flow with an injected engine,
as there could be more even fuel distribution between the various
cylinders.
Kevin Horton
>think of)
>injected.
>Paul Besing
>Flying
>From: "Richard Luster" <rlluster(at)msn.com>
>To: "rv-list"
>> Listers,
>> I am looking into the purchase of a Lycomming 320, for an RV9. It appears>>
Vans recommends a O320. What are the pros and cons of the IO320 compared>>
to the O320.
>> Thanks
>> Richard Luster
>> rlluster(at)msn.com
>> Marysville, WA
Doug Reeves' Van's Air Force site has a listing.
http://www.metronet.com/~dreeves/transition_training.htm
Subject: | RV 7 Elevator spars. |
Anyone have prepunched elevators spars that appear to be to long? I find
that upon trial assembly the spar tip with tip ribs attached temporarily
leaves only 3/8" rather than 1/2" of skin protruding. Also moves the rivet
line in toward the web of the tip rib. Might be possible to rivet however I
would think 1/2" of exposed skin would be much better for the fiberglass
fairing. Any comments would be appreciated.
Dale Walker
RV7 Empennage.
My fault...I was thinking of the O-360 series.
Paul Besing
Flying
Subject: Re: RV-List: Re: Pros and cons of IO320 to O320
> to Lycoming).
> cylinders.
> Kevin Horton
> >think of)
carburated
> >injected.
> >Paul Besing
> >Flying
> >To: "rv-list"
> >> Listers,
appears> >> Vans recommends a O320. What are the pros and cons of the IO320
compared> >> to the O320.
> >> Thanks
> >> Richard Luster
> >> rlluster(at)msn.com
> >> Marysville, WA
From: | Miller Robert <rmiller3(at)earthlink.net> |
Subject: | RV-9a vs. RV7a Was: "Pros and cons of IO320 to O320" |
Paul:
Could I ask you to elaborate? "Since you are building a -9 I guess performance
priority scale."?
I was trying to wait for an RV10, but am becoming more and more likely to begin
a two seater now. So, 7a vs 9a??? Performance is certainly high on my
scale... but all airplanes are compromises, so performance to accomplish what
mission is the question.
Here is how I presently see it... RV9a gives up aerobatics, which I don't
really have interest in, in return for what is probably a more stable
cross-country platform, which I do have interest in. RV9a with better low
speed performance, docile, lower stall speed, and 160kt. cruise with better
overall economy (which could add up) . RV7a has 180kt. cruise, but by criteria
mentioned above is possibly less stable VFR/IFR cross country machine. 20 kt.
faster cruise would be nice, but 160 kt. still much faster than anything on the
consumer market until you are spending 200k or so. Also 200 HP needed to get
the 180kt cruise in 7a, 160HP needed to get 160 kt cruise in 9a.
Well, I'll stop rambling on and listen now. I will appreciate any and all
thoughts on 7a vs 9a, (but I guess it's only me who can finally decide to get
started, rather than continuing to wait for the RV10).
> injected.
> Paul Besing
> Flying
> To: "rv-list"
> > Listers,
> Vans recommends a O320. What are the pros and cons of the IO320 compared> >
to the O320.
> > Thanks
> > Richard Luster
> > rlluster(at)msn.com
> > Marysville, WA
Subject: | Re: RV-9a vs. RV7a Was: "Pros and cons of IO320 to O320" |
In a message dated 11/22/01 10:05:04 AM Eastern Standard Time,
rmiller3(at)earthlink.net writes:
<< Here is how I presently see it... RV9a gives up aerobatics, which I don't
criteria
kt.
the
the 180kt cruise in 7a, 160HP needed to get 160 kt cruise in 9a. >>
I'll jump in here... On 160 hp, the X/C performance between the RV-9 and RV-7
will be identical for all intents and purposes. If you've gotta go 180 knots
(and have the bank account to support this speed addiction), or the mission
includes aerobatics, the RV-7 is the choice. If your mission is 150-160 knot
cross country flying, the RV-9 is probably a better fit for you.
Kyle Boatright
Kennesaw, GA
Hi Paul,
I can highly recommend John Henley in Baker, FL (a mile or two from the CEW
VOR)for a checkout. He's a retired AF Colonel, with a bazillion hours, and
is a hell of a nice guy. He's one of those people who's literally more
comfortable in a plane that in a car. Anyway, he has a very nice RV-6, and
is building an RV-7. I got my RV checkout with him, as did another local
RV-8 pilot. I guarantee a pleasant experience if you deal with John.
John's email is- rv6plt(at)netzero.net
Phone- (850) 609-3175
Good luck,
Russell Duffy
Navarre, FL
RV-8, 80587, N174KT (Flying 85 hours)- FOR SALE
RV-3, Rotary engine project, retrofit 3B wings on order
weather in Dec.
was20
Paul
Don't have to worry about carburator icing in fuel injected.
I just recently purchased a project, and talked to Tom Green at Van's last
week about the Bill of Sale issue. As I understand it, you have to be able
to supply a paper trail to Van's that shows the project being sold from the
current registered builder, to you.
In my case, the original builder was the only previous owner, so I have to
give Van's a bill of sale showing that I purchased the project from him.
When Van's gets that, they will register me as the current builder, and will
issue me an official Kit Bill of Sale when needed.
In your friends case, he should find out from Van's who the current
registered builder is, and make sure he gets enough bill's of sale to link
the plane to him. I have heard of cases where this paper trail couldn't be
established, and the completed plane couldn't be registered without some
creative paperwork. If in doubt, call Van's before purchase to make sure.
Russell Duffy
Navarre, FL
RV-3, Rotary engine project, retrofit 3B wings on the way
From: | "Gordon or Marge Comfort" <gcomfo(at)tc3net.com> |
O320.
>Richard Luster
Richard: There are several variations of the injected 0320 including a
couple that are rated at 150hp. Those engines, and others rated at 160hp
have injection units mounted on the bottom of the sump where a carburetor
would be placed. There were a number of sump and induction tube variations.
The IO320 series also included engines with the Bendix unit mounted on the
rear of the sump facing aft, some at an angle and some straight aft. The
injection system appears to not include the high pressure lines and nozzles,
but acts more like a carburetor with the possible exception of the aft
mounted units, which may (I don't know) deliver fuel to the intake ports.
Some use type 2 dynafocal mounts a la Twin Comanche.
You can check with Van about the availability of type 2 mounts. Other
considerations include location of the injector on the sump, provision for
constant speed prop, clearance with engine/nosewheel mount, choice of
accessories, i.e. Bendix vs. Slick mags etc. The only injected 150 that I
have experience with was on a Citabria and functionally it differed mainly
in starting procedure and the ability to operate inverted. Since the -9 is
not intended to fly inverted the injector probably doesn't offer much
advantage. The injected engines tend to be slightly heavier. You could
talk to a good overhaul shop about the comparative costs to maintain the
injector vs the carburetor.
Gordon Comfort
N363GC
Subject: | Re: Cellular Phones |
Norman wrote:
> > Not a concern for Canadians... Cell phone usage in general aviation
> aircraft is
> > legal up here, as long as the pilot doesn't object.
> First time I've heard this, any links to some data to back this up or has
> any other Canadian heard this?
AIP Canada Com 5-14 says in the event of a communications failure to use a
cell phone. It doesn't say anything about not using one under any other
circumstances.
John Solecki
Toronto RV-7 Emp.
Subject: | Re: Garmin Jeppesen Update |
Listers...
This post originally discussed updating of Garmin database updates and
suggested American Avionics out of Seattle. I have a GNC 250 XL and they
don't offer this service for this model. As Paul Besing stated before,
Jeppesen will do the job for $175 but is there a domestic source at a more
reasonable price?
Any suggestions -- much appreciated...
Ken Cantrell
6 slider, N34KC reserved
Subject: Re: RV-List: Garmin Jeppesen Update
> Paul, my buddy Paul reminded me of the location where we got out Garman
> databases updated. It was American Avionics out of Seattle. I didn't see
> any prices on their website but here is the link.
> http://www.americanavionics.com/
> Mike
> From: "Paul Besing" <azpilot(at)extremezone.com>
> To:
> Subject: RV-List: Garmin Jeppesen Update
> > Has anyone found a less expensive way to update their Garmin panel mount
> > GPS? Jeppesen wants $175 for a one time update. I found a place in
> Germany
> > that will do it for $88 if I send them my card, but I am concerned about
> > sending my card and money overseas. Any ideas?
> > Paul Besing
> > Flying
In a message dated 11/22/2001 10:14:40 AM Pacific Standard Time,
kcflyrv(at)pacbell.net writes:
> Listers...
> reasonable price?
> Ken Cantrell
If you have not updated your database since you purchased the unit you can go
through the avionics shop that you bought it from, they can send your old
card back to Garmin & they will replace with a new updated one 1 time. It
worked for me.
Tm Barnes
Meangreen RV-4
Subject: | Van's Voltage regulators-adjustable? |
I have about 20 hrs on my -8 and have had some problems with stabilizing
charging voltage with Van's fixed regulator. It charges some times at
over 15 V and other times not at all. I ordered a new regulator and
decided to try the adjustable one. The regulator showed up without and
wiring diagram...so I called Van's. They told me to cut off the yellow
wire, red to the switch, green to the field, and black to ground. I did
this and this morning ran it for the first time. It is charging at 20V.
I see there is a adjustment on the back but am not sure how to adjust
it. Any body give me some advice?
Jim Cimino
RV-8 sn 80039 N7TL 20 Hrs.
http://www.geocities.com/jcimino.geo/
(570)842-4057
Subject: | Re: feathering microballoons |
dear Listers,
anyone with fiberglass expereince know how to feather microballoons to the
point of not seeing the edges with a real glossy paint over it.? i have tryed
everything that i know , and when it is sanded and primed you can rub your
hand over it and you can't feel the edge, but when glossy paint goes on, it
is noticable. i was planning on filling the rivit heads with micro, but if i
can't get a better result i just might pass. i have seen rvs at flyins that
you can't see any rivits, and would like that appearence rather than the
dimply skins. how do those glass pilots acheive such a smooth finish?
hep me heeepp me
scott
tampa
oh yeah Happy Thanksgiving everybody
Subject: | Re: Van's Voltage regulators-adjustable? |
>Jim Cimino
>(570)842-4057
Jim,
I don't know of a quick and elegant way to do it. What I did was to have a
buddy adjust it while the engine was running at idle. I mounted the
regulator immediately above the firewall mounted battery and drilled a small
access hole where the adjustment pot is located. Installed in this way, the
pot can be adjusted through the baggage hold door. I hooked up a Fluke
voltmeter onto the power bus so I could call out the voltage from the
cockpit as he made the adjustments. I left it at 14.2 volts which has
worked fine for two years now. The use of the Fluke meter also allowed me
to calibrate my analog voltmeter (Isspro) in the panel which does not have
very precise indications.
Brian Denk
RV8 N94BD
268 hrs.
Gravy. Not just for breakfast anymore.
Scott,
You need to put a primer/ surfacer over the micro, before the top coat, then sand
it with 280 or 320. I recommend using Poly Fiber UV Smooth Prime. You can roll
it
on with a roller and its water borne so its easy to clean up and it is non toxic.
It sticks to Aluminum and composite very well and once dry almost any top coat
can be used over it. UV Smooth prime is available from AS&S. Or Poly Fiber direct
at (800)362-3490. It's white that's how "Casper" got its name. Hope this helps,
have a good Turkey Day.
Garry "Casper"
ABAYMAN(at)aol.com wrote:
> dear Listers,
> hep me heeepp me
> scott
> tampa
Also a friend of mine Ray did this to his wings. It was a lot of work. If you
would like to contact him , contact me off list for his email address. Garry
"Casper"
> dear Listers,
> hep me heeepp me
> scott
> tampa
Use a small standard screw driver and turn counterclockwise to lower the
voltage. Make small adjustments as it doesn't take much. Most of these are
tested at the factory and should be a lot closer than 20 volts. You may have a
bad field connection that is causing the regulator to put out more voltage.
Garry "Casper"
> Jim Cimino
> (570)842-4057
From: | John Carillon <Carillon(at)centurytel.net> |
I too am primarily interested in using the RV for cross country travel. Given the
same no wind flying conditions, using Van's published specs, the 160 HP 9A will
take 17 mins. longer to make a 600 SM trip than the 200 HP 7A. The 9A has 49 lbs.
more useful load and the 7A will burn more fuel on the trip. Full tanks on the
7A
add another 36 lbs to be subtracted from the payload. It was a hard choice for
me.
The performance capabilities of the 7A are impressive, but I think that the 9A
will be a better cross country machine.
John - Awaiting January delivery,.
> criteria
> kt.
> the
> Kyle Boatright
> Kennesaw, GA
They get that smooth finish by building in fiberglass, not riveted
aluminum.
Sorry, Scott, couldn't resist.
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Firewall Forward
http://geocities.yahoo.com/ps/info1
From: | Jerry Springer <jsflyrv(at)earthlink.net> |
Depends on how you calculate more fuel burn. When flying my 180hp RV-6
alongside a buddy's 150hp RV-4 we burn the same amount of fuel.
the
lbs.
7A
me.
>>criteria
>>kt.
>>the
>>Kyle Boatright
>>Kennesaw, GA
I just tried this with Aerotronics. Martin called Garmin to see, and they
said no way. If it was a month old, it might be possible. But 3 years
forget about it. Who did you get your Garmin through, Tim? Martin told me
that it's not him, and it's not Garmin, it's Jeppesen. The bastards have a
monopoly on the databases and they are a close guarded commodity. That's
why they can get $175 for one freakin' update that will expire in 28 days.
Paul Besing
Flying
----- Original Message -----
> > Listers...
more
> > reasonable price?
> > Ken Cantrell
go
> worked for me.
> Tm Barnes
> Meangreen RV-4
I would like to know if one put auto body filler over the small dents
where the rivets are if that would cause corrosion of the rivet or the
aluminum? I know one person that did this on the top side of his wing so
it would be very pretty to look at and so far the plane is still
flying.....
Robin
If anyone needs a pilot operating handbook for an RV I have
completed a very detailed one and will send a disk to anyone who needs one.
It is for an RV6a with a wood prop but could probably be easily adapted to
any RV with some cutting and pasting. It has a lot of safety information.
Aircraft Systems
Normal Checklist
Emergency Checklist
Specifications and Limitations
Flight Maneuvers (Mostly aerobatics)
Weight and Balence
Maintenance (Including maintenance schedule)
VFR flight rules that are hard to remember
Anyone interested can send me an address off list and I'll send it when I
can. Use at own risk.
Dave Beizer
RV6A 110 hrs
pltdbeezer(at)aol.com
Or...........go to an auto parts store, hand them about ten dollars and
ask for a 1975 Ford regulator.
The Ford regulator works like a charm and is replaceable nearly anywhere
in the country. I first read of this tip in the "AeroElectric
Connection".
Sam Buchanan (RV-6, well regulated with mid-70's Ford technology)
"The RV Journal" http://www.home.hiwaay.net/~sbuc/journal
> Jim Cimino
> (570)842-4057
Subject: | Steve Davis Instrument Panels |
I can second that about Steve's work. Most of you have seen my website
before, but for the newer folks, you can see my Steve Davis panel at:
http://www.lacodeworks.com/besing/panel/panel.htm
Be sure and view the page 2 of the panel section as well.
Also, here is another picture from the first flight day:
http://www.lacodeworks.com/besing/flight.htm
Paul Besing
Flying
Subject: | Re: POH available |
Dave, if you like you can send me a copy of it and I'll post it on the web
for people to download and you won't have to send out floppies all day!
Paul Besing
Flying
Subject: RV-List: POH available
one.
> Aircraft Systems
> Normal Checklist
> Emergency Checklist
> Weight and Balence
> Dave Beizer
> RV6A 110 hrs
thanks paul. The problem is its over 100 pages total. Doesn't seem like
that would be practical for a web site.
Dave Beizer
From: | "Jim Norman" <jnorman(at)intermapsystems.com> |
Subject: | feathering microballoons |
The answer to this question is this:
You must NOT sand with your hand. You must use a sanding block. Scott, you
showed me this the other day when I was at your shop, and we got side
tracked onto a different topic and I didn't get a chance to discuss it
then.... but... having grown up in the auto industry and working in body
shops since I was old enough to walk, the trick to sanding microballoons (or
bondo or any other filler) is the sanding block. Sanding blocks come in many
different styles, but go to any high quality body shop and watch them "block
out" the panels prior to painting. Sanding blocks must be stiff enough to
sand the surface evenly. THIS is the trick to avoid the "build-up"
appearance where the filler was after the paint goes on. Its not the
"feather" edge which is the problem, its the built-up appearance which looks
to be higher than the surrounding surface (because it IS). Your hand cannot
fix this...no matter how hard you try. Only a block can avoid the look of a
"patch of filler" under the paint.
Avoid any temptation to use your hands on a piece of sandpaper until the
very final go. Until then, use a flat piece of metal wrapped in sandpaper.
I use a piece of 1/8 x 1.5 6061 AL scrap that came with the kit, cut to 10"
long. Wrap it in 40 or 80 grit the first time, then re-apply the filler and
sand again with 120 or 180 grit. If any low areas exist, do this step again.
Then prime and block out again with 220. As you can see, we haven't used our
hands on a piece of sandpaper yet. You should be way past the point where
you can't feel the stuff... but people won't be feeling your airplane, they
will see it in reflected light. At this stage there is a trick that many
good body guys use: wet the panel and look at it in the light at an angle.
If you cant see your filler in the reflected light, and you can't feel it,
then its time to prime again and NOW you can use your hand. The reason that
you can use your hand now is because this time you are not "shaping" the
panel, you are filling sanding scratches and preparing for the color coat.
For all curved surfaces, all good body men have a collection of heater hoses
(or similar) they use as sanding blocks. I bought several pieces of heater
hose at the auto store just for this. I have a 3/4" diameter piece about 8"
long that I use for the wheel pant fairings and other surfaces where there
is a tight radius, a 1" diameter piece and a 1.5" diameter piece. Again,
they are stiff enough to do the job of taking down the high spots only,
while allowing flexibility to go around compound curves. I also have a 8"
piece of broom stick I use when I want a round shape while sanding a
straight line (my wheel pant fairings, for example), and have resorted to
using a piece of left over Aeroquip oil line when I couldn't find my
favorite piece of heater hose.
In summary: Never use a piece of sandpaper with your hand to sand filler of
any sort... once painted, you will ALWAYS see the filler. No matter how good
your paint is, hand sanding will ruin all your hard work. (My 6A has been
funded by the sale of several classic cars [a 68 E-Type Roadster, and a 70
LT-1 Corvette Roadster), both of which had many hundreds of hours of
blocking into them).
Jim
Tampa
(Maybe this is why I enjoy working with fiberglass... I grew up around this
stuff).
Hey Paul,
I live in Fayetteville and although I'm not an instructor your welcome to
some back seat time.
Carey Mills
RV4 200hrs
Subject: | Re: Steve Davis Instrument Panels |
Jim,
I've also had some great luck with Steve. My panel is finally done, and
when I get a chance I'll email some pics for the list to see Steve's work.
Can't say enough good things about how the panel looks. Saves a great deal
of time, and the quality it top notch.
Kurt, OKC, OK
6A Finishing
> Dave Beizer
You could divide it up into 4 seperate downloads of 25 pages each.
Surfing the Web from Hopkinsville, KY
Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/
Finishing RV7A empannage :-)
Try Manasota Avionics
Located in Sarasota Florida. 1-358-1404 ask for Jeff
I recently updated the database on my Garmin 90 GPS unit. All I have to do
is buy a special Garmin patch cord to connect the GPS to the computer, log
onto the Garmin web site, give them a credit card number for $30 and then
download the new data. It worked great and was so EASY even I could do it!
Kim Nicholas
(all updated database but nowhere to fly....)
RV9
Here are the POH files. Let me know if you are unable to download it.
Dave
From: | "Ollie Washburn" <skybolt-aviator(at)msn.com> |
Well,you could get a controlvision anywhere map.Monthly updates from
computor for 100 $/yr. And i can see it.
Ollie&Lorene Washburn
RV6-A,N795LW,@ 97FL
Loves Airpark
do
log
> download the new data. >
Dito. Just did mine too. This is a new service available from them.
All the information is on their website, but it is real well hidden. Keep
looking till you find it. Ordered the serial cable to fit my GPS from their
website, it showed up in a couple of days. Took just a few minutes after
that to go to the correct web page to erase the old data and load the new.
Seems to have more accurate land data and more named features for VFR
navigation too.
Dave Burton
RV6 (wings) Seattle area
Subject: | Re: POH Download |
I have web space for misc RV List files on www.am2.com. If anyone from the
list wants a related file posted, email it and I'll post it with a link.
Mitch Robbins
robm(at)am2.com
I think I'll take Paul up on his offer.
Dave Beizer
Subject: | Re: Carpal Tunnel |
--- Norman wrote:
> The damage is terrible, permanent and often the surgery makes
> it worse.
> My solution was to use brain power to discipline myself to do all
> cleco tasks with my left hand (I am right handed).
That works for a while.
Everybody's milage will vary, but I can't think of two
cheaper-in-the-long-run tools than a pneumatic cleco tool and a
pneumatic squeezer.
Don't go to the shop without them.
Mike Thompson
Austin, TX
Firewall Forward
I just had the carpal tunnel operation 6 weeks ago. Don't know if the clecos
had
anything to do with it or not. They did a nerve conduction study on both hands
and said I had moderate damage on both. I have no systems on the left hand
but the fingers were beginning to go numb at times on the right hand. They
said
if I did nothing and it became severe the mussel for the thumb would atrophy
and the thumb would become unusable and could not be fixed once the
damage was done. The operation was not bad and the hand no longer gets numb.
Was done in the outpatient clinic. Wore a splint for about three weeks. Very
little pain. I will probably have the other hand done with the first symptoms.
Earl RV4
Mike Thompson wrote:
> > it worse.
> pneumatic squeezer.
> Mike Thompson
> Austin, TX
> Firewall Forward
That's a handheld. Totally different ball game there. The panel mount
units are only updatable with a special card. The Garmin 430's are
updatedable with a cord, but it is a file that you still have to purchase
for big bucks, and only works on one GPS.
Paul Besing
Flying
> do
> log
then
their
> navigation too.
> Dave Burton
Chris Good has an excellent RV-6A POH available on his web site:
http://www.rv.supermatrix.com/
You can download a MS Word file from his site. Choose "Documents" from the
menu.
Chris Heitman
Dousman WI
Paul Besing
i'm about to put lighting in but not sure which is the best way and what
brand. it seems the least expensive way is nav lights on the wing and tail
with 1 strobe in the belly. can anyone suggest options.
thank you
dan carley
rv-4 2295s
Subject: | Re: RV4-List: wing lighting |
Dan,
l recently put lights on my RV-4. The wing tips have the nav plus
the whelen strobes. I also have the belly strobe that is wired independently
from the wing tip strobes. I use the belly for cruise and then swich on the
wing tip strobes for landing. You can never have enough recognition lites at
a busy airport, IMOO.
George Spring RV-4
Chester, Conn. 4375J
Subject: | Re: Sratus pump fittings |
to
> the vacuum lines.
Bill, the fittings are in Aircraft Spruce, called Airborne fittings.
Biggest rip off in the whole plane (go look at the catalog). I got my
fittings at an aircraft salvage yard for 5 bucks each. Cleaned them up and
put them in. Only salvage stuff in my whole plane. Don't use any sort of
thread sealer on these fittings. Also, be aware that the 90 degree one
which will go into the front port may not go when the engine is in - mine
did barely. These fittings are unique (besides in their price) in that they
have wide open through holes.
Alex Peterson
Maple Grove, MN
6A N66AP flying 52 hours
Subject: | Re: wing lighting |
Oh no! Another Aeroflash thread! The Aeroflash units give you all in one
for about $425 including power supply.
Paul Besing
Flying
Subject: RV-List: wing lighting
> thank you
> dan carley
> rv-4 2295s
> have a military paint scheme.
[snip]
> still be possible to do?
The S cowls seem pretty resistant to deformation from heat. I think the main
issue is burning or charring when the heat gets too high. The polyesters are
just the opposite -- they don't burn as easily but become plastic when
heated up.
So I don't think it'd be necessary to put heat shielding on the top cowl
even if you painted it black. It gets hot up there but never enough to char
or blister, and I doubt that heating from the outside would make enough of a
difference there to warrant heat shielding.
If it were me I'd just fill the top cowl and paint the inside with
heat-resistant paint and leave it at that.
I do open my oil door while the plane's cooling down -- don't know if this
really is necessary or helps all that much but it doesn't hurt.
Randall Henderson, RV-6 N6R (~300 hrs)
Portland, OR
From: | Charles Brame <charleyb(at)earthlink.net> |
Subject: | Hartwell latches |
Does anyone know of a good source for reasonably priced Hartwell
Latches? Wag Aero price of $22+ is a little steep. I need about six of
them.
Charlie Brame
RV-6A QB N11CB (Res.)
San Antonio
Subject: | New Email List Photo Share Available! |
From: | Email List Photo Shares <pictures(at)matronics.com> |
A new Email List Photo Share is available:
Subject: First F-1 Rocket to Fly...
http://www.matronics.com/photoshare/jcash@centurytel.net/index.html
EMAIL LIST PHOTO SHARE
Share your files and photos with other List members simply by
emailing the files to:
Please view the typical Share above and include the Description Text
Fields as shown along with your submission of files and photos.
Charlie,
I have a bunch of surplus Hartwell latches available. $5 each + $4 shipping.
There stainless (Hartwell p/n H-5000-2) and polish up very nicely (you get to
polish).
Contact me off line for additional info.
Laird RV-6 400hrs
SoCal
owens(at)aerovironment.com
From: rv-list(at)matronics.com on Sat, Nov 24, 2001 10:32 AM
Subject: RV-List: Hartwell latches
them.
Charlie Brame
San Antonio
Subject: | Re: Hartwell latches |
B&B aircraft. They are in the yeller pages.
Paul Besing
Flying
> them.
> Charlie Brame
> San Antonio
Larry.Pink(at)matronics.com
Fuel = $45.00
Lunch = $13.00 for two
Gambling = $0.75 three rounds in the slot machine
Clean-up = $.03 6 squirts of mirror gloss #17
The Decadence of leaving work in San Diego CA with a buddy and flying in
your RV-6 to Bullhead City AZ, crossing the river on a free boat ride to
Laughlin NV for a 45 minute lunch, easily returning with plenty of time to
spare for the second part of the shift
= Priceless
W
The 0-320 has been made in ranges from 140-177hp. One interesting, or should
I say disgusting thought, about the high compression versions of these
engines is the rumour that there are only two manufacturers of TEL left on
planet earth, one in England and one in Russia.
W
Subject: | Re: Lycoming 0-320 |
Would you mind telling which model was 140 hp and which was 177hp?
Jerry S
> W
Can be found at:
http://www.kitlog.com/downloads/RVPOH.zip
This is a .doc format, but my MS Office is giving me a hard time, so I have
not had a chance to test it out. I'm forwarding it on from Dave.
Paul Besing
Flying
Subject: | Claudio Tonnini Sun 100 race |
BlankClaudio, if you are still monitoring the list are you racing this
year at Sun-n Fun?
Dennis Flamini, RV-10, race #53 , N564DF, Chicago
bruce.gray(at)snet.net said:
> Not a radio problem. Back many, many years ago, when I was a young
> brash pup. My grisly tough flight instructor taught me to turn the
airplane
> in a 360 on the ground and look for other traffic before taking the
active.
> It's a practice I still follow today, some 40 years latter, at
uncontrolled
> airports.
You are absolutely correct. My instructor taught me the same thing and I
practice it to this day. I didn't mean to imply that we should depend
exclusively on the radio to tell whether someone's on final! We should of
course use all the tools we have, including eyeballs, to make sure we don't
try to occupy the same space with another aircraft.
Randall Henderson, RV-6 N6R (300 hrs)
Portland, OR
If you want to save a few bucks by making your own Garmin update cable, I
suggest checking out http://www.pfranc.com.
Portland, OR
Subject: | Re: Claudio Tonnini Sun 100 race |
Claudio doesn't usually monitor the list. I know he sold his RV-3
project and has started an RV-7. No idea what he has improved on his
RV-4, Purple Passion, but when he is interested in racing, everything is
open for modification.
Michael Pilla
Subject: RV-List: Claudio Tonnini Sun 100 race
> year at Sun-n Fun?
Is there a place to buy engine parts such as gasket sets that will sell
to individuals?
Subject: | Re: Engine Parts |
I use Superior as much as I can. Here's there web address
www.superiorairparts.com
Actually, I'm suprised you're having problems. I've bought from Aviall,
Lycoming distributor, many times. They're more expensive and have a bad
attitude a lot of the time, but they'll sell to me no problem.
If you're looking for used components, try EnParts in Lancaster, TX.
They've helped me a lot as well. My governor drive components were going to
be over $1000 from Lycoming. I bought some good used components from
EnParts for about $250 or so. 320+ hrs and all is working very well.
Bryan Jones -8
Pearland, Texas
From: | "Mark D. Dickens" <mddickens(at)mindspring.com> |
I know I'm a little late to this discussion, but I learned a lesson a couple
of years ago I'd like to share. I was flying out of Destin, FL (DTS) on my
way home to Memphis. It was in the afternoon in the summer down there. I
was flying a A36 Bonanza and was on an instrument flight plan. Since Destin
is just on the other side of the bay from Eglin AFB, it's a very good idea
to get your clearance on the ground. Because of the number of aircraft
leaving, the frequency was crowded and it took awhile to get the clearance,
but I finally did. I tuned to the Unicom frequency, looked carefully off
the approach end of the runway and seeing nothing out there, I proceeded to
announce my departure and pull onto the runway. About 10 seconds later, as
I was beginning my takeoff roll, a Lear Jet calls a go around and blasts
overhead. Talk about embarrassed...at least the Lear driver had the class
not to say anything. Here's what I learned: 1. When you have restricted
visibility as we very often do in Florida in the summer, you may not see
another aircraft, especially one with such a small cross-section as a Lear.
2. I had a second NavCom in the plane and didn't use it. Tune it to the
Unicom frequency and listen to it in the background while you're talking to
Clearance Delivery or whoever. Had I done #2, I'm sure I would have been
aware of the Lear in the pattern. It might even be a good idea to ask over
the radio if anyone is on final (although this isn't standard practice).
My two cents,
Mark
Subject: Re: RV-List: Be Safe!!
> airplane
> active.
> uncontrolled
> > airports.
don't
> Portland, OR
Call Ted at ElReno aviation. He is great and will spend time with you explaining
what you really need. An honest guy that won't sell you un-necessary parts.
His number is the yeller pages
Eric Newton - Long Beach, MS
RV-6A - N57ME (flying)
www.ericsrv6a.com
-----Original Message-----
From: "owner-rv-list-server(at)matronics.com" <owner-rv-list-server(at)matronics.com>
on behalf of "b green"
Subject: RV-List: Engine Parts
to individuals?
> sell to individuals?
Sacramento Sky Ranch - http://www.sacskyranch.com/
Many more at the Yeller Pages:
http://www.sound.net/~hartmann/yelrpage.htm
Tim Lewis -- Fairfax, VA
RV-6A N47TD - First Flight 18 Dec 99
http://www.geocities.com/timrv6a
Subject: | Heat Shielding for Cowl (Was: Baffle/cowling painting) |
With regards to this post----painting the cowl black and taking a chance of
warping-----, I do think that you stand a chance of having your cowl warp...
at least over time and in a hot climate.
I researched this a bit a few months ago when I was making (re-making?) my
fiberglass plenum. I spent considerable time with the guys at West Epoxy
systems. They were very helpful and sent me lots of information to
supplement their phone conversations. There are MANY fiberglass resins in
use today, and they all have different characteristics. Bottom line, the
stuff that I bought to make a plenum out of is not the same stuff that I use
for wheel pants, etc. It's considerably more expensive, but does not become
plastic until a considerably higher temperature.
Leaving the cowl door open is a great cooling trick... but, where I live
(Florida), I would not paint my cowl black unless I did some form of
experiment to prove that it will not sag with time. Black surfaces can get
WAY PAST the plastic temperatures listed for almost all of the West System
(and others) epoxy and polyester resins.
I also am not sure that heat shielding on the inside will help... most of
the heat will come from the sun, not the motor... Bottom line... I'd
experiment or get some "real information" prior to risking my pretty
plane.... how about a nice gray color?
jim
Tampa
Subject: | For Sale: RV6 / 6A WING KIT |
I got impatient and sprung for the quickbuild kit. I now have an extra wing
kit.
Purchased from Van's on 3/12/98. This RV 6/6A Wing Kit is prepunched and
the spar is matched drilled to the fuselage carry-through, serial #3387.
Partially completed, both spars built up and primed with epoxy paint. Ribs
drilled and clecoed to the spars. Just about ready for jigging. Fuel tanks
started. Complete inventoried kit with all parts included. I will ship at
no charge (free) to your shop for a total price of $3400 or best offer. This
is a great deal!!
Greg Grigson
Honolulu
808-396-7771
ghgrigson123(at)cs.com
Subject: | Re: Heat Shielding for Cowl (Was: Baffle/cowling painting) |
Good post Jim. Let me add there is another problem with heat and epoxy or
polyester parts, the softening of the epoxy or polyester resin, this allows what
is called creep. Creep shows itself as the cloth weave starting to show through
in your once smooth paint job. Look at Rvs with dark stripes that extend from
the wing to the tip. If the aircraft has been in the hot sun a few times, you
will be able to see the weave of the glass starting to show on the part of the
stripe that is on the tip, the part over the aluminum of the wing will be fine.
The only way to beat this is to use a flat black temporary paint and let the
unfinished part sit out in the sun and post cure, until it gets close to the
manufactures recommended max temp. After that go thru the entire finishing
process and your part will not creep, unless it gets hotter than the post cure
temp.
Garry "Casper"
> jim
> Tampa
Subject: | Re: Smooth Finnish |
In a message dated 11/22/2001 6:07:27 PM Pacific Standard Time,
RMCKEE(at)MN.RR.COM writes:
> flying.....
> Robin
Taking a Hi-Fill primer and using a squeegee just over the rivet pattern
works very well, it dose not hide the rivet but bridges the gap between the
rivet and skin making the paint job flow better, besides your working on a
metal airplane, be proud of those rivets. Thus the old saying "If you want a
smooth airplane build a fiberglass one"
Tim Barnes
Meangreen RV-4
N39TB
Subject: A Rocket
http://www.matronics.com/photoshare/rtmarshall@thegrid.net/index.html
In a message dated 11/22/2001 6:08:28 PM Pacific Standard Time,
azpilot(at)extremezone.com writes:
> Paul Besing
I bought my Garmin from Hi Dessert Avionics in Lancaster CA, Jeff did great
job in getting mine replaced, I might add that it was a little over a year
when I replaced my data card. Give Garmin a call direct, see what they say.
Tim Barnes
Meangreen RV-4
N39TB
In a message dated 11/25/2001 5:37:27 AM Pacific Standard Time,
rvinfo(at)juno.com writes:
> to individuals?
Call Lycon in Visaila CA (509) 651-1070
Greetings all,
As I've recently posted, I purchased an old RV-3 kit (SN-751). The project
didn't include some of the fairings that are common to other RV kits that
I've seen. Since I hate fiberglass, I thought I'd ask if these are
available now from Van's, or if perhaps there's an aftermarket source. The
parts I need are the following:
Horz stab tips
Vert stab tip
elevator tips
tip for the top of the rudder
tip for the bottom of the rudder with no light
Empennage fairing (where the vert and horz stab join the fuselage)
gear leg fairings
Improved (lower drag) wheel pants (I have the original wheel pants)
(nice low drag aftermarket) wing root fairings
anything for the sliding canopy (assume this to be hopeless)
Russell Duffy
Navarre, FL
RV-8, 80587, N174KT (Flying 82 hours)
Subject: | RV-3 roll-over protection? |
Greetings again,
I noticed that the RV-3 sliding canopy doesn't really provide much roll-over
protection. It certainly isn't anywhere close to what the RV-8 has. Has
anyone installed any sort of additional roll-over protection? Got any
pictures or suggestions (aside from building up my neck muscles )?
Russell Duffy
Navarre, FL
RV-8, 80587, N174KT (Flying 85 hours) FOR SALE
RV-3, Rotary engine project, old wings in the trash, new 3B wings on order
Subject: | ACS Switch Question - HELP! |
Hi guys,
Today I wired up my ACS key switch. When I took my handy mulit-meter out to
check everything over I had the following results which puzzle me and I
can't figure it out.
When the switch is off, both mags show grounded (Normal).
With the swith either L or R, both mags still show grounded. (NOT Right??)
With the swith on BOTH, L&R mags indicate NOT grounded. (Normal).
Switch in START Position, both mags show grounded again & the solenoid
engages. (NOT normal).
The switch is wired per all the diagrams I have, and looks to be correct. I
tried with and without the jumper installed for the R mag, no difference.
I'm using a small lawn tractor battery for testing, and so far everything
else is going fine.
My question is, no matter whether I select R or L, why would both mags still
show grounded on my multi-meter and work fine in BOTH. Do I have a bad
switch, or does something change with a bigger battery and the engine
running? I don't think so, but Hey, I learn something new everyday.
Any explanation or hints would be greatly appreciated.
BTW, before you say "you should have used toggles", I WANTED TO - but my
building partner is so used to Pipers and Cesspots he insisted on the key
switch :(
Thanks in advance and happy building,
Stein Bruch
RV6 wiring, MSP
Subject: | 6A tire pressures |
Just curious. What are you guys using for tire pressures in your RV-6A's
without wooden gear leg stiffeners?
Steve Soule
RV-6A flying (20 +- hours)
Huntington, Vermont
From: | "Martin Hone" <martin.hone(at)tradergroup.com.au> |
--- StripMime Report -- processed MIME parts ---
text/html
--- StripMime Errors ---
A message with no text/plain section was received.
The entire body of the message was removed. Please
resend the email using plaintext formatting
Subject: | Re: For Sale: RV6 / 6A WING KIT |
I assume everyone knows about the quickbuild fuselage from VANS. This was in
the last RvAtor, but several builders I'm sure have already done this. You
build the wings, but send the center section to Vans to be used in your QB
fuselage. Extra charge of course, but not what the whole QB will run and
since you already built the empannage and have the wing, why not finish them
while you wait for that QB Fuselage.
Marty in Brentwood, TN
Subject: RV-List: For Sale: RV6 / 6A WING KIT
wing
> kit.
and
Ribs
tanks
at
This
> is a great deal!!
> Greg Grigson
> Honolulu
> 808-396-7771
Subject: | Re: RV3-List: RV-3 roll-over protection? |
Russell, didn't you notice mine at Tracy's?
Look at Tracy's web site under the Rotary race.
Finn
Russell Duffy wrote:
> --> RV3-List message posted by: "Russell Duffy"
> Greetings again,
> Thanks,
> Russell Duffy
> Navarre, FL
Sign Up for NetZero Platinum Today
Only $9.95 per month!
http://my.netzero.net/s/signup?r=platinum&refcd=PT97
Tried that too...they just said to call the vendor that I bought it from!
Oh well, time to bend over and take a $175 shot in the ass I guess.
Paul Besing
Flying
they
me
have a
That's
days.
> > Paul Besing
great
say.
> Tim Barnes
> Meangreen RV-4
> N39TB
Subject: | Re: 6A tire pressures |
Steve, I put 50psi in each main, and enough to just have the whole tread
width on the nose wheel make contact. This was in late August, and I don't
know what they are now, but they look to be the same. I might have had one
incident of mild main gear shimmy, maybe two oscillations per second, so
rather slow. Might have been the runway, but in any case, no other shimmy
problems. I have no stiffeners, and the nose wheel breakaway is about
20#'s.
Alex Peterson
Maple Grove, MN
Just to give you some on different temps, A soft yellow finish on equal
surface is 12 degrees F hotter than white (00).
This will probably make you realise why glass builders tend to fly in White
planes.
Marcel de Ruiter
RV4/G-RVMJ
Aircraft painter
Hi Finn,
It's funny, a picture of your engine is my current wallpaper, but I never
took any photos of the whole plane. I looked at the photo on Tracy's page,
and as I suspected, you have the tipover canopy. My project came with a
sliding canopy that's mostly finished. As I recall, the rear support tube
of the canopy frame runs from left to right, and comes to the very front of
the turtledeck when the canopy is closed. That will make it impossible to
install any sort of vertical structure behind the pilots head. It might be
possible to modify this canopy frame bar to work around the rollbar, and
that will certainly be one of the leading options. The other option would
be to change over to the tipover canopy. Yep, looks like building 51% of
this "nearly complete" RV-3 won't be a problem :-)
Rusty
Finn
> Greetings again,
roll-over
In a message dated 11/25/01 7:29:27 PM Eastern Standard Time,
VansRV4GRVMJ(at)btinternet.com writes:
<< Just to give you some on different temps, A soft yellow finish on equal
planes.
Marcel de Ruiter
RV4/G-RVMJ
Aircraft painter >>
Marcel,
What were the conditions - ambient temperature, sun angle, wind, etc. when
this observation was taken?
What is the worst case scenario? - High altitude field, clear day, sun
directly overhead and perpindicular to the surface being measured, with zero
wind?
Kyle Boatright
0-320/Aymar Demuth RV-6 Slider
Kennesaw, GA
http://www.angelfire.com/my/rv6
Subject: | Re: rv-6 parts for sale |
Ive got a vert stab completed, and two 016 elevator skins if anyone is in
need. switched to a -7. please respond off list. 845-677-3193
What are the George Video Tapes everone refers to?
Bud Balone
Subject: | Re: ACS Switch Question - HELP! |
Stein,
If you're using a multimeter they will ALWAYS show grounded in any position of
the switch. You will have to disconnect the P-leads from the mags to check the
switch this way. Or use a mag timer which you'll need to time the mags anyway.
What bothers me is that you said that they show NOT grounded in the both
position.
Dave
Stein Bruch wrote:
> Hi guys,
> else is going fine.
> switch :(
> Stein Bruch
> RV6 wiring, MSP
From: | "Eric Newton" <enewton57(at)cableone.net> |
I run 30 PSI on all three. No shimmy so far.
RV-6A N57ME (Flying - getting ready to paint)
www.ericsrv6a.com
Subject: RV-List: 6A tire pressures
> Steve Soule
> Huntington, Vermont
Using 30 PSI all around. No stiffeners. Some shimmy on the nose wheel when
rough surface and certain speeds are involved...no big deal, easily stopped
with speed change.
John at Salida, CO
You are picking up ground from the mags. Even a "hot" mag will read ground
with some resistance, just not a dead short to ground. You can pick up
ground through the points if they are in the right spot.
Paul Besing
Flying
Subject: Re: RV-List: ACS Switch Question - HELP!
> Stein,
position of
the
anyway.
> position.
> Dave
> Stein Bruch wrote:
> > Hi guys,
out to
Right??)
correct. I
difference.
everything
> > else is going fine.
still
key
> > switch :(
> > Stein Bruch
> > RV6 wiring, MSP
i have my engine disassembled & will take the crank & rods to be
inspected tomorrow.
I have torn down for an inspection only. The engine has set for 9 years.
The lower end looks real good along with the cam & lifters, but the
cylinder had rust from the rings. I have steel cylinders.
My A&P wants new rod bolts & nuts. Any good reason for this??
Also he wants new rings, looks like the old one would do fine.
any comments?
I have had 2 new RV's fly away this month. Sure getting tired of working
and NOT flying with them.
Got to meet Paul & Victoria Rosales from Ca. this morning. They sure got
a fine machine.
Don Jordan, Arlington, Tx N6DJ
Paul,
I have spent a lot of time with a fiberglass plenum. I bought it from Sam
James, and you already know my stories there.
Bottom line... If I was to do it over again, I'd make one out of aluminum
rather than glass (mine actually started as carbon fiber, but has been
modified with glass). The glass plenum can be made to fit really nice...
around every little curve... but it takes considerable time and effort.
Again, to do it over again, I would start with Van's baffles and then
construct a plenum out of AL. I've seen several pictures of these from
fellow builders, and that is what I would copy.
Jim
Tampa
Subject: | Pulsating Instrument lights? |
I have a slight pulsation in my instrument lights (all of them) when the
engine is running and the alternator is on. If I turn off the
alternator...it stops. I have changed the voltage regulator for another
problem, but it did not help. The alternator is one of Van's (35 amp).
Everything else seems good and there is no fluctuation in either the
volt or amp gauge. Anybody have any ideas?
Jim Cimino
RV-8 sn 80039 N7TL 25 Hrs.
(570)842-4057
Don
Your mechanic's recommendations tell me that he is very through and
conscientious. It is a wise idea to replace the rod nuts and bolts ANY time an
engine is torn down. This is fairly standard practice even in the auto and
motorcycle repair trades. Your connecting rod bolts are some of the most
highly stressed parts of your engine. Your mechanic wants to install new parts
to insure that you don't have a catastrophic failure down the road.
Since your cylinders are rusty, your mechanic will have to hone the cylinders
to remove the rust. While installing the old rings might work, it might not. I
certainly would feel uncomfortable reusing old rings in any engine I assembled
and had to guarantee my work. If you insist he reuse the old rings, don't be
surprised if your mechanic tells you that if you have cylinder sealing or oil
usage problems, that you are on your own. I certainly would.
Charlie Kuss
RV-8A fuselage
Boca Raton, Fl.
> inspected tomorrow.
> any comments?
> a fine machine.
From: | "Greg & Cindy Tanner" <gtanner(at)bendcable.com> |
If you hone the cylinders, throw away the rings. They won't re-seat.
Greg
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Charlie Kuss
Subject: Re: RV-List: Engine OH
Don
an
parts
cylinders
I
assembled
oil
Charlie Kuss
RV-8A fuselage
Boca Raton, Fl.
> inspected tomorrow.
> any comments?
> a fine machine.
Subject: | RE: ACS Switch - Problem Solved! |
Pual & Dave,
Thanks for your input. I guess I was having a brain fart today. To many
wires! After disconnecting the mags and looking closer at my mulit-meter, I
can see the switch is working right.
Happy Building,
Stein.
RV6, MSP
In a message dated 11/25/01 10:11:20 PM Eastern Standard Time,
dons6a(at)juno.com writes:
<< i have my engine disassembled & will take the crank & rods to be
inspected tomorrow.
any comments? >>
Don,
The rod bolts are one time use only. They get slightly stretched when
torqued, and should not be re-used. Even if you assembled your engine, never
ran it, and needed to pull a rod for some reason, you would need to replace
the rod bolts when you reinstalled the rod.
On the rings, if you hone (or wor$e, bore) your cylinders, there is a
significant chance that old rings wouldn't seat. Since rings are cheap, and
the effort to pull a cylinder (or cylinders) is at least moderate, it is good
economy just to replace the rings.
Kyle Boatright
Kennesaw, GA
> inspected tomorrow.
> years.
> any comments?
> working
> got
> a fine machine.
Don:
Lycoming engines can use a STRECH bolt that you tighten till it gets so
long. It is not reusable. The bolts are the most stressed parts in
the engine and should be changed out any time the engine is taken
apart.
If there is rust in the cylinders, the rings will need replaced. I
would not take the chance trying to get used rings to seat after
removing the rust from the cylinders. They may seal but you may need
to pull the jugs, hone, and then install the new rings. Why not just
start with new rings where you have a good chance that everything will
seat right the first time.
Gary A. Sobek
990.5+ Flying Hours So. CA, USA
http://SoCAL_WVAF.tripod.com
I don't see the problem. My seatback bulkhead has the indents for the sliding
canopy, just in case I wanted to change it. I welded up a simple "A" rollover
bar, as per the plans. The top of the weld was done with the two pieces
installed - bolted to the longerons, as they stick up through holes in the
turtle top skin.
Finn
> Hi Finn,
> Rusty
> Finn
> > Greetings again,
> roll-over
Subject: | Backup Artificial Horizon |
Here's a link to a self-contained, battery operated, solid state "artificial
horizon". Interesting for a guy like me who has a VFR aircraft, but would
like some sort of attitude reference without the weight or maintenance issues
that go with a vacuum system and conventional gyros.
I'm not gonna buy one anytime soon, but I'm interested if anyone has seen one
of 'em up close and personal...
http://www.pcflightsystems.com/images/MicroHorizon.pdf
Kyle Boatright
Kennesaw, GA
Subject: | What Can You Say...? |
Dear Listers,
I've been getting a ton great comments on what the Lists mean to its
members and I've included a few of them below. I'm sure _most_ of you can
echo one or more of these sentiments to the tune of a nice List
Contribution... :-)
Just one more week until I post the 2001 List of Contributors! Won't you
support the continued operation of these Lists by making a Contribution
today and assure your place on the upcoming Contributor List? I'm sure
your friends will be checking for your name on the LOC... ;-)
SSL Secure Web Visa and MasterCard Contributions:
http://www.matronics.com/contributions
Personal Check via the US Mail:
Matronics Email Lists
c/o Matt Dralle
PO Box 347
Livermore, CA 94551-0347
I want to thank everyone that has already made a Contribution this
year! YOU make these Lists possible!
Email List Administrator
Can't live without my List everyday!
- John B.
Information you can't get anywhere else.
- George D.
...one of the finest List sites on the Internet.
- Dennis S.
This List has saved my bacon more than once!
- Larry H.
Really invaluable service for a novice builder.
- John B.
...got some useful help from the List.
- Rocky S.
A valuable resource.
- Dennis N.
This List is a Super resource...
- Dwight F.
...couldn't have gotten this far without the
resources on the List.
- Jerry C.
Great service to us builders...
- Ronald M.
...someday we'll all meet in RV Heaven. Hey,
how come there isn't an "RV-Heaven" List?
- Louis W.
The info I've gleaned from the List has saved
me several thousand dollars...
- Kevin H.
...the only International, Interesting, Up-to-date,
List with the best search engine ever!
- Hans L.
...check it ever day so I don't miss anything.
- Jim B.
Great List!
- Douglas G.
This List has saved me a few times already...
- Thomas R.
...part of my morning wake up reading.
- Dwight F.
...helped my make my plane better, safer, better
looking, and built it quicker.
- Kevin H.
Have bought many items from the info the List gives.
- Jim B.
You meet the nicest people here.
- George D.
Informative, Amusing, Entertaining...
- John B.
Subject: Re: RV-List: Heat Shielding for Cowl (Was: Baffle/cowling painting)
In Burt Rutan's "Finishing the Composite Aircraft, Section V of the VariEze
Manufacturing Manual", he sets forth the reasoning behind his recommending a
basically white exterior on structural members of a composite aircraft using
room temperature-cured epoxy since those epoxies soften starting at around
160 degrees F. He reproduced a graph from a September 1975 article in
Soaring Magazine which shows the temperature of surfaces painted various
colors versus ambient air temperature. I'll post a few numbers off that
graph.
Ambient Air Temperature of 110 degrees F. Amb. Air Temperature of 70
degrees F.
White 163 F
118 F
Yellow and pink 169
124
Lt. Blue and Alum. 176
130
Purple and Blue 184
135
Light Green 192
143
Orange & Tan 198
149
Red and Green 218
166
Brown 231
178
Black 238
184
However, I don't know what the characteristics of the epoxy used in the RV
cowlings are. It's unlikely, but they could be using a high temperature
variety. Does anybody else know?
A problem I have with this data: There are lots of aircraft using glass
cowlings which must be experiencing temperatures well above 160 F a few
minutes after shut down on a hot day, particularly near an exhaust pipe, and
they seem to be hanging in there. Cowlings aren't structural, but......
Garth Shearing
Victoria BC Canada
From: | "Bob Hodgson" <bob(at)hodgson252.freeserve.co.uk> |
Subject: | Re: RV3 Roll-over protection |
Russ,
The original drawings (1971-3) had only the sliding canopy and no roll-over
structure. The later (1984) dwgs added the tip-over canopy as an option, and
a built-up roll-over structure, which can be used with it (dwg 37). In the
builder's notes, there is a sketch (SK-54A) of a welded steel tube A-frame
(not a tripod but better than nothing . . ) for use with the sliding canopy,
which I think Finn is referring to. It requires the frame cross-member to be
positioned 1" aft, and restricts the opening by 1".
If you don't have the sketch and notes I could email them over.
Good luck
Bob (UK)
3 fuselage being built on to new 3B wings
(- new builder wants my old wings !!??)
Original message:
roll-over
> Thanks,
> Russell Duffy
> Navarre, FL
> Hi Finn,
page,
of
be
Has anyone taken part in the beta testing of the Dynon system or heard
anything lately about their product coming out?
Dave Ford
RV6
Numbers are interesting and, obviously, support painting cowl light or white
color. I'm a bit surprised at how low the actual number is for potential
damage (160 degrees F). So paint it white.
But, it's easy to imagine temps inside the cowl exceeding these numbers... hot
day, hot engine, long taxi on the ground, etc.... perhaps especially at areas
of cowl in proximity to exhaust system.
Careful, well designed, heat protection of interior surface seems essential.
Robert
> From: <KBoatri144(at)aol.com>
> To:
> graph.
> degrees F.
> White 163 F
> 118 F
> Yellow and pink 169
> 124
> 130
> Purple and Blue 184
> 135
> Light Green 192
> 143
> Orange & Tan 198
> 149
> Red and Green 218
> 166
> Brown 231
> 178
> Black 238
> 184
> Garth Shearing
> Victoria BC Canada
Way to go Carolyn!!!
Nice grin Gary!
John "JT" Helms
Subject: RV-List: RV Solo
Today my wife Carolyn soloed in our RV-6A. I cant even begin to
express in words how proud I am of her and her accomplishment. I have
to say her solo was bigger and better than when I did the first flight
over 17 months ago.
Her flight training started about 1.5 years ago in a lowly 172. When
she was ready to solo in the 172 her instructor didn't show up. Stuck
in Kansas getting an airplane she said. So another date was picked and
again the instructor did not show up. A call to her house found she
was still in bed and that she had forgotten. At this point Carolyn was
getting a complex, maybe the instructor was trying to tell that she
was not good enough to solo. She was really in the dumps. We fired
her instructor and started a search for another one.
In looking for another instructor we decided that if she were going to
learn to fly so that she could fly the RV she should learn in the RV.
We found a willing instructor (the best I have seen, and as good as
Mike Segar) and set every thing up to start flight training in the RV.
The next day we lost #4 cyl and the engine had to be torn down since
there was metal everywhere.
Well long story short, her flight training began again this summer and
she soloed on this fine day. She made it look easy. Did I mention how
proud I am of my wife. It brought tears to my eyes and the biggest RV
grin ever.
Gary Zilik
Keep building guys, get you wife interested, better yet let her learn
to fly in the Family RV.
Subject: | Re: Looking for RV-4 insurance checkout |
Any of the CFI's with RV's and 25+ hours in RV's who are on Doug's site is
fine with the VanGuard Program.
John "JT" Helms
Branch Manager
Subject: Re: RV-List: Looking for RV-4 insurance checkout
While making final, (or something like final), decisions as to abandoning thought
to
build RV10, ... and choosing RV9a over 7a for OUR proposed mission, I am now thinking
to use the time to prepare my workshop. (May actually be useful, in addition to
providing the psychological feeling of getting started.) I will obtain and set
up
tools, build worktables, run electrical and air.
Most important, the building season here in the Northeast and other cold areas,
would
be too short without installing a heater of some kind. I will build in an attached
garage with my children's bedrooms above on adjoining wall... and I must admit
space
heating solutions I have looked at make me a little bit nervous. The garage is
uninsulated and has rafters and open loft space above (good for storage). Do I
need
to insulate? Close in walls, or space above? Are electrical heaters safer? Outside
vented LP? If LP, tanks outside and run a line in?
What are others doing?
Thanks (as always).
Robert
From: | "Meier, George" <George.Meier(at)goodrich.com> |
I had an unfinished hanger last year. We started with a 110 thousand BTU
kerosene heater (the type that looks like a bullet and sounds like a jet
engine). That provided ample heat with no ceiling or insulation. It got the
room (2000 sq. ft.) up to a good working temperature in 10 minutes. We then
put a ceiling up, and shot some cellulose above the ceiling (6"). In the
spring we insulated the walls and put drywall up. What a difference. After
that a simple 30 K BTU heater (kerosene) worked great.
This summer I plumbed in a Natural Gas Radiant heater (110 K BTU) on a
thermostat. It's now our second living room. The only thing we are lacking
is a TV. I'd recommend a radiant heater to anyone. It's approved to run
un-vented, but we vented ours since there is an aircraft in the hanger.
George Meier
RV6A - wings
Michigan - snow belt
I bought a second hand Empire propane heating unit. I also insulated the
shop. I think that you will find yourself doing better work and working for
longer periods of time in a warm space. Leave a high ceiling. You will be
surprised at how many times you will be thankful for a lot of overhead
space.
Steve Soule
Huntington, Vermont
-----Original Message-----I will build in an attached
admit space
is
Do I need
Outside
Thanks (as always).
Robert
Subject: | Re: Shop Heaters |
18, 2001) at 11/26/2001 11:20:09 AM,
Serialize complete at 11/26/2001 11:20:09 AM
Robert,
I don't have an attached garage, but I was very concerned about
safety concerns with exhaust fumes from the furnace and explosive fumes
from solvents being used in the building and painting process. Living in
Michigan, I decided to insulate and drywall my garage and I installed a
wall unit furnace by Williams International with an enclosed flame. There
is no contact between the inside air and the flame in the furnace. The
furnace draws air from the outside and exhausts to the outside. I would
not recommend electric due the utility costs.
I'm not sure, but I thought I heard that attached garages must be
drywalled, but that probably varies by your local building codes.
Hope this helps,
Allan James RV-7A Emp.
Huntington Woods, MI
Miller Robert
Sent by: owner-rv-list-server(at)matronics.com
11/26/2001 09:23 AM
Please respond to rv-list
To: rv-list(at)matronics.com
cc:
Fax to:
Subject: RV-List: Shop Heaters
thought to
now thinking
addition to
and set up
areas, would
attached
admit space
garage is
Do I need
safer? Outside
Thanks (as always).
Robert
I am building in a garage 14' x 22' with an insulated overhead door. It is
too small but I had it, and it is paid for!! The walls and roof have 4"
fiberglass bats for insulation covered with 1/2" sheet rock. The walls are
painted off white and high intensity (two tube) fluorescent fixtures are
mounted on the walls just below the eves so the light strikes the work area
from each side avoiding shadows from overhead lighting. Work lights are not
necessary except when working inside a structure. When outside temps are
above 45 degrees the heat from the lamps maintain comfortable working temps.
There is a single flush mounted in-wall electric heater with fan to keep it
comfortable when outside temps go lower.
The roof insulation and sheet rock is attached directly to the rafters
leaving the space below for storage. The building is too short to
comfortably work on the engine installation so for the winter months there
is a temporary shelter attached to the door end. The shelter is made from
steel tubing and a poly tarp in the shape of a Quonset hut. When working on
the airplane the garage door is opened, the aft end of the airplane is
pushed into the shelter and a tarp is dropped down to close the opening.
I chose electric heat due to ease and cost of installation - electricity
is already there, no fuel tanks or venting required.
Gaylen Lerohl
RV8, rotary (Mazda 13B NA) engine installation
> Thanks (as always).
> Robert
Subject: | Temporary Sign-off |
I have to go on the road for the next four weeks and will not be able to get
good access to the list during that time, so I am temporarily signing off
from the list. If anybody has any questions you can Email me directly at
mrobert569(at)hotmail.com.
To Don J. I will contact you next week in Arlington.
Mike Robertson
Das Fed
RV-8A
My garage is well insulated and attached to my house. The insulation
between the house and the garage is poor so that the garage stays about 40
degrees when it is zero outside. I have weather-stripped the double wide
overhead door and have 2 inches of foam insulation nailed to the door with a
beveled joint at the hinges. The other place which would help a lot, I don't
have insulated is the perimeter of the slab.
As for a heater, several people have had good results if when pouring the
slab, they include a plastic hot water coil. One can then use a small hot
water heater and circulator pump with an antifreeze solution to make it very
nice. Buck Hilbert even has a hangar with this heating system. He monitors
the return line to keep it above 35 and then turns it on full when he wants
to work.
thought to
thinking
addition to
set up
areas, would
attached
admit space
is
Do I need
Outside
Thanks (as always).
Robert
Thanks Bob, I think the confusion is beginning to clear. My drawings are
dated 1973, and there isn't anything in the drawings or manual that shows
any rollover structure. If you can e-mail me the sketch you're referring
to, that would be great. I will also give Van's a call and see if they'll
send me the drawings for the tipover canopy. I'm not sure the current
canopy will be in good shape underneath the spray-on protective coating that
it has, and there's still some work to do on the slider if I use it. I
think I might actually prefer the tip-over canopy anyway, so I might end up
changing it out. I just found out that there's a -3 in the area with the
tip-over, so I'll be taking a look at it for comparison. I guess I'll decide
what to do when I get all the options in front of me, but I do plan to have
some rollover protection.
Thanks again,
Russell Duffy
Navarre, FL
RV-8, 80587, N174KT (Flying 85 hours)FOR SALE
Russ,
Good luck
Bob (UK)
Original message:
roll-over
> Thanks,
> Russell Duffy
> Navarre, FL
> Hi Finn,
page,
of
be
Subject: | -3B wing retrofit |
Bob (UK)
Hey Bob,
I wanted to ask about your 3B wing experience. Had you built the fuselage
before ordering the new wings? In other words, did you have to replace an
already existing center section? That's what I'll be doing when the new
wings get here, but it doesn't look too bad. Fortunately, top front skin
isn't on yet, and it looks like there's good access to everything that needs
to be removed. The biggest worry at the moment is the spacing between the
front and rear spar carry-though (hope it's right), and the fact that the
original builder has already drilled the rear spar attachment hole. One of
the (many) problems with his original wings was lack of sufficient edge
distance on the attachment hole in rear spar itself. Even if the hole in
the rear spar carry-through ends up being in a good location, the rear
spar/doubler of the 3B wing will go (I assume) in front and rear of the rear
spar angle. This will completely cover the existing hole, and make it
difficult to match to the spar. I'm hoping they increased the size of this
bolt, to give me some wiggle room, but more likely, I'll end up replacing
the rear spar carry-though as well. Oh joy :-)
Rusty
Subject: Re: RV-List: Lycoming 0-320
Jerry S
Jerry,
I'd have to look them up to get the exact model numbers, but the 140hp was
issued in the orignal version of the Cherokee 140 cruiser (1966/67 roughly),
and I think the 177hp was injected and in one of the Beech models like the
muskateer. Beech then went to a 180hp 0-360 in it.
Subject: | Re: Dynon EFIS D10 |
Dave,
I signed up to be a beta tester, but they have not chosen the testers yet is
the last word I had about two weeks ago. I assume they do not have the
product ready is why they have not chosen the testers yet.
Bernie Kerr, 6A, SE Fla
Subject: RV-List: Dynon EFIS D10
> Dave Ford
> RV6
From: | "Doug Bell" <_dbell(at)manisteenational.com> |
Subject: | Re: RV Yeller Pages... |
multipart/related
multipart/alternative
text/html
audio/x-wav
Dannis good to here from you yes i race next sun 100 you can call me at mi
shop 18005823125 Claudio .
Bluebook says 140 hp lycoming from Cherokee 140 were O-320-E2A and E2D's
later...
Couldn't find a 177 hp on beech Muskateer... those have 165 hp IO-346-A or
O320-D2B (1963 model) and 180hp O-360-A2G (68 and newer mod's)
John "JT" Helms
Branch Manager
NationAir P + B Branch
Subject: RV-List: lycoming
Jerry S
Jerry,
Stein: unless you have a magneto buzz-box tester, you need to have the
switch disconnected from the mag p-leads to check function with an ohmmeter.
The reason is the p-lead will always read a short to ground via the coil
winding. The buzz-box uses pulsed dc and therefore is able to sence an
impedance change when the coil is grounded and/or the points open. Bottom
line: you need to measure impedance in this application, rather than dc
resistance.
Now, if you are measuring switch contact resistance with the switch not yet
installed, that is a different matter and you do indeed have problems.
I did not use toggles, but if I had it to do over, I certainly would!
Bill Boyd
6A
Mike i am back on the list and i am worcking on R V 8 call me at shop 1 800
5823125 or call home 732 5916942 thanks for help me Claudio
In a earlier post I mentioned "Post Curing" as a way to increase Room
Temperature Cure epoxy/ glass structures, resistance to the effects of heat.
This was the norm for any loaded (stressed) structures, such as the canard on
Quickie, Q2 and Dragonfly, since it was also the landing gear. The older RTC
epoxies such as the RAE system which Burt used, had a very low (165F approx.)
creep (softening) point. By post curing you could raise the creep point by
approx. 25F.
The newer epoxy systems in general have a higher creep point. The epoxy used on
Van's "S" cowl is probably a heat cure system. These have a much higher creep
temperature. Van probably used this type, not so much for it's heat stability
(although that may have been a factor), but for the ability to make more parts
in a day. With RTC epoxies, you need approx. 12 hrs for cure before the part can
be pulled from the mold. So you get only one part per day per mold. With a heat
cure system you could get 3 or more parts per day per mold. We all know how
frugal Van is, my assumption is he is using a heat cure system and that is why
the cowls are not effected by the heat.
Garry "Casper"
> To:
> graph.
> degrees F.
> White 163 F
> 118 F
> Yellow and pink 169
> 124
> 130
> Purple and Blue 184
> 135
> Light Green 192
> 143
> Orange & Tan 198
> 149
> Red and Green 218
> 166
> Brown 231
> 178
> Black 238
> 184
> Garth Shearing
> VariEze and 80% RV6A
> Victoria BC Canada
I've got an -E2A in my -8. It's no different than a standard 150-hp -320,
except that it's derated by nameplate showing 140-hp at ~2450 rpm. I've
added high comp pistons to it since installed in the plane for near 160-hp
and is working well after ~260 hrs.
Bryan Jones -8
Pearland, Texas
Subject: | SCAT tube route???? |
Hello all,
Plan to run the 2" vent SCAT tubing through the wing rib lightening holes
from the under wing NACA vent to the fuselage. Was wondering how everyone
has done this. Thought I would use a 2" hose clamp with an "L" shaped
bracket riveted to the clamp and the wing rib to hold the tube in the middle
of the lightening hole. That's about clear as mud. Does this sound ok?
Jack
RV8, wings
Subject: | Re: SCAT tube route???? |
>Hello all,
>middle
>Thanks,
>Jack
>RV8, wings
Jack,
Just run it through the rib lightening holes and through an appropriately
sized hole in the fuselage side AND the inboard, right side floor rib to
access the eyeball vent. Hose clamps work fine for attachment at either
end. No need to bracket/clamp/support the tube along it's run.
Brian Denk
RV8 N94BD
269 hrs.
Subject: | [Fwd: Returned mail: see transcript for details] |
Robert and list. I tried to reply offline but was unsuccessful.
Do not archieve.
Date: Mon, 26 Nov 2001 11:11:37 -0600 (CST)
Subject: Returned mail: see transcript for details
Auto-Submitted: auto-generated (failure)
This is a MIME-encapsulated message
--fAQHBbl28622.1006794697/granger.centurytel.net
from ppp199.hk.centurytel.net [207.230.218.230]
----- The following addresses had permanent fatal errors -----
(reason: 550 miller3(at)earthlink.net...User unknown)
----- Transcript of session follows -----
... while talking to mx01.earthlink.net.:
>>> RCPT To:
<<< 550 miller3(at)earthlink.net...User unknown
550 5.1.1 ... User unknown
Reporting-MTA: dns; granger.centurytel.net
Received-From-MTA: DNS; ppp199.hk.centurytel.net
Arrival-Date: Mon, 26 Nov 2001 11:11:35 -0600 (CST)
Final-Recipient: RFC822; miller3(at)earthlink.net
Action: failed
Remote-MTA: DNS; mx01.earthlink.net
Diagnostic-Code: SMTP; 550 miller3(at)earthlink.net...User unknown
Last-Attempt-Date: Mon, 26 Nov 2001 11:11:37 -0600 (CST)
Date: Mon, 26 Nov 2001 11:10:43 -0500
Subject: Re: Shop Heaters
Good morning Robert.
I am expecting delivery of my 9A kit in January. I live in northern
Wisconsin and it started snowing this morning. It does get cold here. I
am finishing up a Zenith 601HDS...I know ...I know... but it seemed like
a good idea at the time.
Before I started the Zenith, I built an insulated shop in one end of my
outside pole building and heated it with a salvaged LP heater vented to
the outside.It is fed by the same outside tank that supplies propane to
my house. This worked fine for completing the empenage, outboard wings,
and beginning the fusilage. The Zenith fusilage is attached to a center
wing section in which the landing gear is mounted. To complete the
fusilage with tail section mounted I had to move the project into the
uninsulated part of the pole building for the summer/fall.
Recently I rolled the completed fusilage into one half of my attached
two car garage to hang the engine, run wiring and tubes, and complete
the firewall forward before bolting on the outboard wings. My garage is
insulated and I still have storage above ( fiberglass insulation under
plywood I screwed to the rafters ). It is not heated however; and I am
planning to blow warm air into the garage from the room next to it.
Long story short...I believe that insulating your garage would pay even
if you were not building an RV. You could then install a vent through
the wall and blow warm air into the garage/shop from the house when
needed. No additional heater required and the noise of the air
compressor and rivit gun would not disturb the family.
Good luck. I think you made a great choice.
John Carillon
--fAQHBbl28622.1006794697/granger.centurytel.net--
There has been some discussion lately about the effectiveness (or
lack thereof) of certain carb heat systems. Well I now know mine works. I
have a Vetterman crossover exhaust system with two Robbins muffs each
sending warm air to it's own RV-4 style (TG-10) heat box. For carb heat I
used Van's EA carb heat muff strapped to the crossover pipe plumbed
through a DL-07 adapter to the carb air box. During my runups the RPM
drop is almost imperceptible but I think it is effective enough.
Today I went flying and it was very humid (it was foggy/drizzly
earlier) and the OAT at 3,500 msl was about 45F. I was just loafing along
at about 2350 RPM (Sensenich FP) and I noticed my EGT's on #3 and #4 were
dropping. #1 and #2 were okay. The RPM was falling off slightly but the
engine was still smooth. I pulled the carb heat on and the EGT's all
dropped then evened out. The engine roughened for a second then smoothed
out. Carb heat off, EGT's back to where they should be. Classic carb ice
encounter. Anecdote yes, evidence no but I am satisfied with my set-up.
Mike Hilger
RV-6 N207AM, O-360-A1A, 160 hrs
Inver Grove Hgts, Minnesota
Subject: | Vans Eye-Ball cockpit Lite |
Does anyone happen to have a extra Vans eyeball
cockpit lite they would like to sell ???
John McMahon (Wiring) 863JJ reserved
Do not reserve
Subject: | Ebay O-320 listing |
Folks,
I saw an auction for an O-320A2B with 208 hr. SMOH on Ebay. Item number is
1669420995. Might be worth a look for those in need of a Lycosaur.
Brian Denk
RV8 N94BD
269 hrs.
From: | Jaye and Scott Jackson <jayeandscott(at)shaw.ca> |
This is where the IceMan system would shine. If you're going to the trouble
of installing a carb air temp gauge; for almost the same money an iceman
system using a probe containing a photoelectic sensor across the carb
throat from a LED light source( that all screws into the same hole as the
temp probe) can be installed. The probe is physically shaped to ice up
before the carb will and the difference in light being received at the eye
will light a warning light and (optionally) a audible warning in the
headset.
I've had people look at the little "stove" that Van makes to mount on the
crossover pipe just above the carb heat flapper and wonder how it could
possibly put out as much heat as the much-larger cabin heat muffs. The
answer is in its air supply. It uses air that has already passed across the
cylinder cooling fins while the muffs use virtually ambient air from the
over-engine pressure box. A builder who just stopped by to make sure I'm not
slacking off has the same system but with a temp gauge and says he's getting
a 75F rise.
Scott in Vancouver
RV-6 systems install
----- Original Message -----
Subject: RV-List: Carb Heat
> Mike Hilger
From: | "Gabriel A Ferrer" <ferrergm(at)bellsouth.net> |
Subject: | Pulsating Instrument Lights? |
Van warns that you may get flickering lights and voltmeter readings when
using switching regulators.The warning was on the "spec" that I got when
I purchased my alternator..
I observed this phenomena on Bernie Kerr's RV6A on a night flight to
Memphis, TN.
I've heard of other RV flyers experiencing flickering also.
I plan to use a linear voltage regulator, that I'm purchasing from B&C,
for my RV6.
Gabe A Ferrer (Building RV6)
Cell: 561 758 8894
Voice or Fax: 561 622 0960
Email: ferrergm(at)bellsouth.net
Subject: | Re: RV-List Digest: 50 Msgs - 11/21/01 |
multipart/related
text/html
audio/x-wav
Subject: | Re: RV-List Digest: 71 Msgs - 07/26/01 |
multipart/related
text/html
audio/x-wav
Subject: | Don't Miss The Video... |
Hey Listers!
Just a reminder that in support of the 2001 Email List Fund Raiser, Andy
Gold of The Builder's Bookstore ( http://www.buildersbooks.com/ ) is
donating a FREE COPY of the new edition of Van's "The RV Story" video (VHS)
to any List Member making a Contribution of $50 or more!
To take advantage of this wonderful Offer, please include the following
information along with your Contribution, either in the Message Box if you
Contribute on-line, or on a slip of paper if your Contribution is by check
via the USMail:
Van's RV Story Video Offer
$50 or Greater Contributor
[your name]
[your shipping address]
[your City, State and Zip Code]
If you've already made a Contribution of $50 or more during the 2001 Fund
Raiser and would still like to receive the video, please drop me an email (
dralle(at)matronics.com ) and include the information shown above with the
following Subject Line:
Subject: Video Offer
Please note that this new edition of "The RV Story" will first be available
in about 8 weeks.
I want to thank Andy Gold and the Builder's Book Store for this *very
generous* Contribution! If you haven't taken a moment to check out The
Builder's Book Store web site yet, you owe it to yourself to have a look (
http://www.buildersbooks.com/ ). Andy has a fabulous selection of
interesting, informative, and exceptionally useful books and videos on his
site. Please have a look!
I would like to thank everyone that has so generously made a Contribution
so far in this year's List Fund Raiser! Just a few more days until I send
out the List of Contributors for 2001. Make your Contribution today to
make sure your name is on the LOC!!
Thank you!
Subject: Tom Martin HRII #28
http://www.matronics.com/photoshare/fairlea@execulink.com/index.html
Subject: Paint Scheme
http://www.matronics.com/photoshare/enewton57@cableone.net/index.html
From: | "Milton Bland" <miltonbland(at)hotmail.com> |
Subject: | RV6A kit for sale |
Complete RV6A Quickbuild kit for sale. Purchased in Feb.2000. Inventory
completed but I have not had time to begin construction. Options include
firewall recess, tip-up canopy, aileron trim, landing light, static air,
fresh air, dynafocal 1, finishing kit, dual steps, rudder light. Located
near Lawrence, KS. I may be able to deliver depending on destination.
Asking $21,000 or best offer. Milton Bland
miltonbland(at)hotmail.com.
I have kind of settled on a paint scheme for our RV-6A. I liked the
striping design of the RV-7 prototype so I copied that and added a
couple of variations. The whole thing was put into a computer rendering
by Glenn Gordon at email dirtyrottenscoundrels(at)home.com
Glenn was very patient and did a great job. If you need a rendering,
get with him and he will design it however you want, at a reasonable
price. You can see the paint scheme here:
Blue Skies,
RV-6A N57ME (Flying - down for 10 hour inspection and paint prep)
www.ericsrv6a.com
Subject: | TFR Shuttle Launch |
Hope Paul and Victoria Rosales saw this.
Eric
The FAA has issued a new temporary flight restriction (TFR) for central
Florida based on reasons of national security. The NOTAM is effective
from 1:45 a.m. to 8:45 p.m. November 29 and prohibits all Part 91
general aviation operations within 30 nautical miles of the shuttle
launch pad (30 nm on the MLB VOR 004 degree radial) up to 18,000 feet.
In addition, all Part 91 operations will be required to obtain a
discrete transponder code and clearance from the appropriate ATC
facility prior to entering the airspace within a 30- to 40-nm radius of
the launch area. Pilots must also maintain continuous radio
communications in this airspace. Because shuttle launches are frequently
delayed, it is critical that pilots check the latest information from
FSS during preflight or with ATC if in-flight before entering the
airspace. The NOTAM could be extended.
"While nobody likes airspace restrictions, we are appreciative that the
FAA responded to our request and released this NOTAM early enough to
give pilots the opportunity to relocate aircraft or make alternate plans
for flights through the eastern half of Florida," said AOPA President
Phil Boyer.
RV-6A N57ME (Flying)
www.ericsrv6a.com
Subject: | Fw: TFR Shuttle Launch |
www.ericsrv6a.com
Subject: TFR Shuttle Launch
Eric
Phil Boyer.
www.ericsrv6a.com
A few years ago I was on a team to evaluate the Slingsby T3 Firefly aircraft
at the Colorado Springs Air Force Academy for my company. The wing internal
temperature probe which is used to determine the wing structural limit, had
to be relocated away from the dark blue Air Force insignia. Apparently the
wing was out of limits while sitting in the sun. Dark surfaces do get hot and
painting an RV engine cowling would not be a good idea considering how hot it
gets from the inside already. A dull paint would serve the purpose to reduce
glare if that was the original intention.
Greg Schmidt
RV-6S N250GS
Finishing the wiring
Phoenix DVT
That looks like a neat paint scheme, Eric! I like the pattern on the -7
prototype too, and I may even stick with Vans' colours... That is, if I don't
go with a Snowbirds-inspired scheme like i've planned so far
(http://www.b4.ca/rv7/images/robs/rv-7_3view_mod.gif).
Has anyone else noticed the large number of people who paint their RV's wings
with a pattern that distinctively breaks up the rectangular planform? From
the photos and physical examples i've seen, my guess is that more than 50% of
the RV's flying have some kind of pattern on the wing that tries to make it
look less than rectangular.
If I were Van, i'd be taking this as an indication that it's time for a
tapered wing kit for the RV's... Anyone else agree with me?
-RB4
rv7 "at" b4.ca
Howdy 'list-
Has anyone tried/considered/decided against using hinges to attach the
wingtips similar to attaching the cowling? Seems it would be about the
same amount of time involved to install, not much weight difference, and
mighty easy to remove and replace. Perhaps a short pin on the tip into
a hole in the LE rib to locate the very front, with the "pull" end of
the hinge pins being bent 90 degrees and secured into holes in the rear
tip rib, accessible by deflecting the aileron... Any thoughts?
From the PossumWorks in TN
Mark Phillips
From: | "Crosley, Rich" <RCROSLEY(at)HRTEXTRON.TEXTRON.COM> |
Subject: | RV-8 Control Stick |
It appears that the forward control stick needs to be cut down to clear the
panel. Is that how it is working out for the rest of you RV-8 guys?
Rich Crosley
Fuselage RV-8
N948RC reserved
Rich Crosley
Fuselage RV-8
N948RC reserved
Yep, cut it off.
Russell Duffy
Navarre, FL
01:26:45 PM
Yikes, every rib is different? Its a lot easier to put on a tricky paint
job and swept wing tips. Boy the new tips really make a difference when
viewed from the ground. This is usually my perspective, sigh, maybe some
day all these parts will flap in unison to create lift.
I think the -6/-7 is the hardest plane to design a scheme for. Ever notice
that some paint jobs are very slimming and some just make the plane look
like a pregnant guppy. Little tricks on the -6 with the paint job can make
it look two feet longer. Just because the scheme looked good on a Lear or a
Bonanza you saw does not mean it will look good on your fat little stubby
winged homebuilt. Of course I meant that in the lovin way.
Eric
Rob Prior (at)matronics.com on 11/27/2001 11:50:09 AM
cc:
Subject: Re: RV-List: Paint Sceme
don't
wings
of
-RB4
rv7 "at" b4.ca
Subject: | Re: Wingtip Attach |
Excellent-sounding idea, Mark. I don't see any real drawbacks. No question
it would be easier to remove and install wingtips in the field this way. I
have had to remove them more times since completing my RV than I would have
thought, and with work planned for wingtip antennae later this season, the
need is ongoing...
Bill B
6A 200 hrs
That's what I did... I cut it so I could have my thumb up in the PTT
and still get it under the panel...
http://vondane.com/rv8a/engine/control1.jpg
-Bill
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Crosley, Rich
Subject: RV-List: RV-8 Control Stick
the panel. Is that how it is working out for the rest of you RV-8 guys?
Rich Crosley
Fuselage RV-8
N948RC reserved
Subject: | Re: RV-8 Control Stick |
Why not bend it like Lyle??
Subject: RE: RV-List: RV-8 Control Stick
Rich Crosley
Fuselage RV-8
N948RC reserved
Yep, cut it off.
Russell Duffy
Navarre, FL
Cutting it off worked just fine for me providing a very comfortable range of
motion. Like Bill said, make sure you cut it off short enough to allow your
thumb to clear the btm of the panel. bending would be unnecessary work and
put the stick too close to me, based in my experience.
Bryan Jones -8
Pearland, Texas
>From: "Cy Galley" <cgalley(at)qcbc.org>
>To:
>Subject: Re: RV-List: RV-8 Control Stick
>Date: Tue, 27 Nov 2001 13:36:43 -0600
Check out the stick in the Pioneer 300S...
http://www.airplane4sale.com/N26AA%20Control%20panel.gif
-Bill
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Cy Galley
Rich Crosley
Fuselage RV-8
N948RC reserved
Yep, cut it off.
Russell Duffy
Navarre, FL
Subject: | Re: Paul & Vicky/Clearwater |
Dear Listers
just to give those following Paul And Vicky's progress, they are saftly in
Clearwater Florida. Jim Norman and i flew in Jims very nice Archer to see the
airplane this morning. I can see why it won an outstanding workmanship award.
what a very nice airplane. Paul arrived to give is friends a ride and
generously offered myself and jim a ride. I felt we were interupting his
vacation, and jim wanted his wife to get a ride. maybe tomorrow morning would
be better, the invitation was extended till tomorrow.
anyone locally wants to see one nice rv, its at clearwater airpark.
scott
tampa
Subject: | Heat Shielding for Cowl |
Here are some more reasons that Van's now sells the sticky-back shielding
material.
The changes in cowl design/materials improved things like strength to
weight, warping prior to installation, shrinking, increased thermal
stability, etc. However, the kit airplane gods always seem to throw in a
little bad with a lot of good. I will therefore dwell on the few issues
that the builder should consider with this new cowl. Because the subject is
"heat shielding" I'll sneak by things like the importance of filling pin
holes on the inside and the criticality of hinge alignment that were not as
important on the less stable polyester non composite cowls.
The new cowls are mostly a composite structure with an air/honeycomb core
with some foam used to transition the composite to non composite areas. The
outer and inner layers in the composite area are very thin (about 0.010) and
do not support clecos or rivets without bonded reinforcement or solid fill.
Because the core is mostly air it is an insulator to heat transfer. This
fact is what led to the heat shield requirement.
On several RVs that I have been involved with, the first indication that
there was a problem with overall heat dissipation in the cowl was a
"toasting" of the inner layer of frp adjacent to the exhaust pipes. This
started to show in the first few hours of flight. If allowed to develop it
had serious consequences (see URL). In time the product that Van's now
sells was discovered at Boeing. After many hours of flight testing, this
shielding has been proven quite effective. While it is not the only game is
town, it offers advantages like; light weight, easy application, oil proof,
adhesive that gets stronger with heat and it can be patched with itself.
It is nothing more than a very heavy weight aluminum foil with an excellent
self stick adhesive. It has a peel off backing material. It can be
effectively applied to compound curves and can be used as a heat reflector
elsewhere by molding it around things or layering it to a foam sound
deadening product.
How does it work? First it reflects IR radiation then what heat it does
absorb it spreads over a large area (conduction) which in turn is dissipated
by air flow (convection) through the cowl. Aluminum is highly heat
conductive while stainless steel is not.
As for the upper cowl, it gets very hot after landing(heat soaks),
especially over the cylinders. My current thinking is that, for the same
reasons, this heat shield material would be effective there also. Some
builders have installed a small pressure closed, drop down door, just ahead
of the rear baffle that falls open when the plane stops. This creates a
chimney effect to cool the upper cowl.
http://www.edt.com/homewing/rhproject/toasted_cowl.html
Thanks Randal,
P.S. Randals pictures show a great job of, and a carefully done repair.
If you use this product/method, you could extend the foil higher up the
sides for even more thermal mass.
Good Luck,
Gary & ?(test)
_______
(_o_) ruff!!!!!!
oo-oo
oops sorry Laird,
he hit a seagull that bruised his right wingtip, so he is in a club with you.
real nice people. sorry i didn't catch her name right, i'm hard of hearing.
scott
tampa
Yes ... you need to cut the stick down.
Rick Jory RV8A
From: Crosley, Rich <RCROSLEY(at)HRTEXTRON.TEXTRON.COM>
the
> Rich Crosley
> Fuselage RV-8
> N948RC reserved
Subject: | jim, anyone you know? |
B. Reg. No.: 15VP M/M: RV4 Desc: PITTS RV-4Activity: Pleasure
Phase: Landing GA-A/C: General AviationDescr: AIRCRAFT ENGINE QUIT WHILE
PRACTICE LANDING, TRIED TO GLIDE BACK TO FIELD, WAS TOO LOW AND HIT TREES,
BURGAW, NC
From: | "Tony Castellano" <tcastell(at)bestweb.net> |
I was planning on attaching my wingtips with hinges so I could remove and
replace them
easily in order to get in and out of my little hangar. I checked with Van's,
and they could
not see any disadvantage to doing it. I even bought the hinges but decided
against it since
I wouldn't be able to get my RV6 in the hangar anyway. My tips are screwed
on.
Subject: RV-List: Wingtip Attach
> Howdy 'list-
> Mark Phillips
I started thinking about this while I was doing the dishes this evening... You
know, a little housework in exchange for some shop time... 8-) I was agreeing
that it'd be a lot easier to build a straight wing and paint it angular than
to build an angular wing. But now i'm not so sure. Consider this:
What're the first parts you build on your aircraft? The Empennage. None of
which is rectangular or regular. About the only thing going for it is that
each part is symmetrical about at least one plane. So you already have
experience building non-rectangular things, where every rib is different. Not
only that, but Van starts you that way, so it can't be the most difficult,
right? Worst case, you need to build a slightly longer jig. Best case, you
build the wings the same way you do now. They're self-jigging anyway.
How are all these kits made nowdays? Pre-cut, pre-punched, and matched hole.
I don't know what method they use to cut the shapes out of the sheet material
at the factory, but they end up with nicely matched parts for the empennage
kits, at least. If it's some kind of NC cutter, the difference in the sheet
metal would be a new .DXF file to send to the cutter. Ditto for the ribs. So
all that would be necessary is a new set of forms for pressing the ribs into
shape. You still need to flute, but you had to do that anyway.
Unless i'm missing something incredibly fundamental about the method, there's
no real reason why it couldn't be done... And it has been, once at least:
http://www.ontariorvators.org/members_pages/fried.htm
-RB4
just woundering why?
Subject: | Re: Heat Shielding for Cowl |
Or you could just steal your wife's roll of Reynolds Wrap and stick it on with
epoxy as I suggested in a previous post.
Garry "Casper" 60 hrs and no cowl problems.
> material.
> Snip
Subject: | Brown Tool Gift Certificate Reminder... |
Hi Listers,
Just a reminder that in support of the 2001 Email List Fund Raiser, Michael
Brown of Brown Aviation Tool Supply Co. ( http://www.browntool.com ) has
generously offered to provide Gift Certificates to all Listers making
Contributions of $30 or more this year!
Making your Contribution to support these Email Lists and to qualify for
the Brown Tool Gift Certificate is fast and easy by using the SSL Secure
Credit Card Contribution Web Site at:
Or by sending a personal check Contribution to:
c/o Matt Dralle
PO Box 347
Livermore CA 94551-0347
According to Michael, "The Gift Certificates have absolutely no strings
attached and are as good as cash for anything from the Brown Tool Web Site
or Catalog."
The amount of your Gift Certificate is based on the size of your List
Contribution and is according to the following:
$100 or greater Contribution receives a $25 Gift Certificate!
or
$30-$99 Contribution receives a $10 Gift Certificate!
==================== How To Receive Your Certificate ===================
To receive your Brown Tool Gift Certificate, send an email message to:
browntooloffer(at)matronics.com
and include the following information:
1) Subject Line: Tool Offer
2) Which Gift Certificate you qualify for ($10 or $25)
3) [Your Name]
4) [Your Mailing Address]
5) [Your City, State Zip]
** Please only use the email address shown above (
browntooloffer(at)matronics.com ) to request your Gift Certificate!
*** Anyone making a List Contribution of $30 or more in 2001 qualifies for
the Gift Certificate! But, you have to follow the instructions above to
receive it!
You should receive your Gift Certificate from Brown Tool in about 2-4 weeks.
I want to thank Michael Brown of Brown Aviation Tool Supply Co. for this
wonderful offer in support of the Email Lists! If you haven't yet had a
look at the Brown Tool Web Site ( http://www.browntool.com ), then you own
it to yourself to take a peek! He has some great deals and good quality tools.
I would like to thank everyone that has already made a Contribution in this
year's Fund Raiser!
Thank you!!
09:03:05 AM
Morning Metal Junkies.
Sounds like there are two potential probelms with the current RV cowl. Heat
resistance and wall thickness. Here in S. Florida there is a big boy candy
store called Joe's Auto Marine. Its a composite supplier and the people
behind the counter are composite engineers and boy do they know their
stuff. You can call them with a problem and they will give you a
recommendation for the fix. This thread looked like a good enough reason
for me to bug them, so seeing how I always learn a new trick any time I
speak to them I didn't hesitate to call.
The owner (that would be Joe) answered the phone and I told him the
problem. He said he just had that exact problem on his plane, the pipes
burned through the cowl. "Here's the fix says Joe". Its a high temp resin
capable of withstanding a constant heat of 350 degrees and a short term
heat of 400 degrees. It is also fuel resistant as Joe had just rebuilt his
wing tanks in his fast glass bird with the stuff. By comparison, he says
the heat tolerance for West Systems is 130 degrees and Aeropoxy is 160
degrees.
He also said there were three bummers about the stuff:
Its expensive (I'm sure you are as shocked as I am). An 8lb kit is $100.00.
Its hard to mix and you must use a scale as it mixes in an exact 100/12
ratio, sorry no pumps.
Once cured, you can't do anything with it. Forget sanding. He said it will
chew the teeth off a cheap home depot hole saw in just one hole. It cures
like granite.
Joe recommended using it with one of the neato hybred cloths he sells. He
sells a 4oz Carbon - S glass hybred that is extremely tough and not too
expensive. If I remember correctly its about 1/4 the price of carbon cloth.
Joe said the resin wets out real nice and is easy to work with and when
used with this glass makes an extremely thin layer but it is tough enough
to change the overall stiffness characteristics of your entire cowl. This
means lay it up and let it dry with the cowl bolted on or you may never get
it back into shape.
One last thing, Joe's Auto Marine does not sell the stuff. Gotta love a guy
that will pass up a sale to do ya right. He's a plane builder after all.
The stuff is available at
United Resin, Inc
Royal Oak, Mi
(248) 549-8200
Ask for John Los
Part numbers are:
Resin Lcast 760 036-676-20-52
Hardener AS-100 010-939-2501
Joe's Auto Marine
(954) 527-9200
Website is WWW.Jarmco.com
They have a nice catalogue with all kinds of toys for boys that like to
make noise.
Eric Henson
Gary Graham (at)matronics.com on 11/27/2001 04:21:29 PM
cc:
Subject: RV-List: Heat Shielding for Cowl
material.
is
and
is
deadening product.
dissipated
Thanks Randal,
Good Luck,
Gary & ?(test)
_______
(_o_) ruff!!!!!!
oo-oo
Thanks Charlie,Gary & Kyle:
He has built 2 other engines for me. I just wondered why. If they were
torqued OK & I have 1200 SMOH. We would expect them to go to 2000, if the
engine had not set for 9 years I caused it to be inspected.
I do a lot of praying when the shaft goes over there. That can be big
Also, I have read the SB & the 96 AD on the oil gears. I have a hardened
shaft & drive gear. the driven is aluminum & the cover is one piece. BUT,
I can not find a "N" or "C" on drive gear.
Don Jordan N6DJ, Arlington,Tx
dons6a(at)juno.com
writes:
> Don
> ANY time an
> auto and
> most
> new parts
> cylinders
> might not. I
> assembled
> don't be
> sealing or oil
> Charlie Kuss
> RV-8A fuselage
> Boca Raton, Fl.
> > inspected tomorrow.
> years.
> the
> > any comments?
> working
> sure got
> > a fine machine.
> [########---------------------14.5%----------------------------]
> messages.
Subject: | crotch strap kit |
From: | "Robert Dickson" <bubba(at)coastalnet.com> |
does anyone know if the crotch strap mounting kit that Van lists for the -7
& -9 will work on a -6A? If yes, is the kit for one seat or two?
tia
Robert Dickson
RV-6A fwf
Subject: | Re: Paul & Victoria Update |
Dear Listers,
With all the bad luck i have had in the last 2 weeks, being burglered 2 times
with airplane damage and all my tools stolen again, today put a smile back on
my face that will last a while.
Paul & Victoria graciously came by my home airport ( peter o knight in Tampa
) and gave me a ride, or should i say let me fly his airplane. i can't begin
to tell you what a nice couple these people are, taking time out of their
vacation to give a lowly rv builder and his brother a ride. after a few seat
cousion adjustments, i managed to get my 280 lb. can in place, and the seat
belt actually fit around my waste. that diet is starting to pay off, but i
still have a long way to go. he let me fly it for 1/2 hour practicing fast,
slow, turns, approaches etc... I must admitt, i can't wait until i can handle
the rv as smooth as he can. the controls are soooo sensitive it will take me
awhile to get used to it. ( did you ever experience the twin control stick
sydrome, you guys know what i'm talking about.) Paul said it takes about 4
hours to get used to it. everything happens very quickly and you MUST be
ahead of that RV.
My brother Bruce has a grin permentaly attached to his face, and he can't
wait till i've got mine flying so he can learn to fly in it. The evasive
manuver Paul had to take to dodge a buzzard, surprised the heck out of him.
After a photo session, Paul & Victoria mounted up and took off. We were just
about to walk to our vehicles when all of a sudden he made a low, high speed
pass down the runway, and pulled up hard. what a show. They are heading to
Bernies at Treasure coast, so maybe Bernie can pick up the updates from here.
Paul & Victoria, if you get this e-mail. I can't thank you guys enough. i
will be building now faster than the speed of sound.
Thanks Again.
scott reviere
Tampa
RV Grin'n for awhile
Robert,
The kit is for both sides. I bought one for my 6, and although I haven't
installed it yet, it seems like it should work. On my QB, the space
between the seat ribs isn't the same on both sides. It's too tight to
fit the brackets on one side. I'll probably have to cut the brackets and
rivet on another flange to get the spacing right. It's definitely
lighter than the angle bracket arrangement I was going to do and also
has provision to screw the seat pan to the brackets where the hole is
cut for the strap, adding strength to the pan.
Ed Holyoke
6QB
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robert Dickson
Subject: RV-List: crotch strap kit
-7
tia
Robert Dickson
RV-6A fwf
I'm asking this for a friend who is building a -7 QB. Does anyone know of a
reason that the under the right seat floor location for a Navaid servo won't
work in the RV -7. Seems someone told him that he would have to mount his in
the wing.
Harry Crosby
Pleasanton, California
RV-6, finish kit stuff
Help, I'm freezing my you know what off.
Casper and I were up playing last night and it was cold. At 6000 ft it
was 28F and there was no sun, Yes, I know for you non Californians
that's a nice day, but to us spoiled Californians it's cold. I'm getting
a lot of air coming in from the tail cone, since I have a cover over the
baggage compartment the air blasts between the seats and the armrests
and you can really feel it. I've thought of gluing little triangles of
compressible foam in all the folds in the baggage bulkhead, or putting a
reverse NACA duct on the belly.
Here is what I have so far as a base line;
Aileron boots as per Sam B., All holes in the area covered by the wing
to fuselage fairing are tight, Heat is supplied by two Robbins muffs (
one on each lower pipe, no scrubbies) in series with a 1 1/4 restrictor
(to slow the air down), which dumps on each side by the rudder pedals. I
have a indoor/outdoor house thermometer with the outdoor remote sender
positioned to read the heater outlet temp. In cruise it gets up to over
145 F which is as high as the sensor goes. The firewall, floor and sides
back to the seat back bulkhead are insulated using the old thick Vans
firewall insulation. Anyway you guys flying in the real world, I sure
could use some ideas.
Garry " Casper"
Subject: | Re: crotch strap kit |
Robert,
I spoke with Gus at Van's tech support and he thought that the 7/9 Crotch Strap
kit could be adapted to the RV6. There is a difference in the floor rib
spacing and floor rib height in the RV6 compared to the RV7/9. The 7/9 ribs
are lower which is how they get more cockpit headroom and I think that Gus said
the 7/9 floor ribs were spaced 1/8 inch wider than the 6. Gus thought it could
be made to work by adding a doubler on each side. I ordered the 7/9 Crotch
Strap kit but after some experimenting with the fit, decided that it would not
work very well in my RV6QB and returned it to Vans. The crotch strap kit for
the 5th point harness attach point was very well designed. The full size blue
print for installation of the crotch strap kit was a real eye opener. The RV7
kits appear to be much better with regard to how much more prefabrication
(rivet hole locations, cutouts etc.) is already done for you.
@#&_&&(
floors.
I am going to copy what Randall Henderson implemented in his RV6. Randall has
some photographs on his web site and there is another similar design on the
"Bunny's Guide" to building a RV6 which looks reasonable to me. Paul Bessings
web site shows a slightly different variation for a 5th point harness attach
you might take a look at.
Dave
> tia
> Robert Dickson
> RV-6A fwf
Subject: | Bluemountain Avionics |
Has anyone had any actual experience with the Bluemountain Avionics
system. I'm interested in their soon to be released small unit.
John Furey
RV6A O-360 Sterba 155 hrs
Subject: | Percent of power |
What were the numbers for RPM & MP to get 55% 65% 75% of power. Was it
42 45 48 or 44 46 48?
Subject: | The tools I have and those I wish I had... |
11/28/2001 04:32:12 PM
Over the years (almost 10) I spent building my -4, I accumulated quite a
workshop. I thought I'd pass on to other builders my thoughts on my
favorite tools. These of course are in addition to all "obvious" ones
required for metal aircraft (e.g., compressor, rivet gun, etc.)
Drill press - Mine is a bench top with a good speed range. I used it
almost daily.
Bench grinder - Get a good one an put a deburring wheel on one or both
sides. This one is almost too obvious to include in this list.
Dremel tool - I wore one out and had to replace it over the course of the
project. I sincerely believe it would have been impossible (at least for
me) to build an airplane without this handy tool.
Belt sander - I love my Delta 1" belt sander. It cost very little and gets
used all the time. At the beginning of the project, I bought a large
(floor model) combination belt/disc sander. I never used it - total waste
of money.
Shear (18") - I found a used bench top shear for $100. People have offered
me twice that to take it from me and I politely said no. It's been
extremely useful, and I would recommend buying one to any builder - though
they are hard to find. Perhaps the only sheet metal tool harder to find,
but equally valuable, is an 18" brake. Luckily, I work at a facility with
a sheet metal shop and have access to a small Di-Acro brake. If you can
ever find one at a decent price - buy it.
Bandsaw - To my disappointment, I was too cheap to buy one. I used the one
at my work. Unfortunately, I wasted a lot of time either using a hacksaw
in my basement, or travelling back and forth to work. Part of my
reluctance in buying a bandsaw (besides the price) was that I could not
find a bench-top unit with a good speed range. Before I build another
plane I will definitely find and buy one.
Mill/lathe - I had access to a mill and lathe at my work and used both
frequently. Before I start another aircraft, I will buy a small mill -
probably a Taig - as well as a lathe.
Spindle Sander - I bought this one late in my project, but use it
extensively to round/shape aluminum, fiberglass, etc. It definitely falls
into the "luxury" category, but is very handy.
Good luck, builders. It's definitely worth the work.
Dean Pichon
RV-4
Arlington, MA
**** This is intended for the addressee only and may contain
confidential business information. It may not be copied
without our permission. If you are not the intended recipient,
please contact the sender as soon as possible and
delete the material from any computer.****
Subject: | Re: Keeping Warm |
You may try lowering the pressure in the cockpit to reduce the air coming
from the tail cone. A simple way is to take one of the elevator push tube
inspection covers and mount a standard Home Depot round louver vent. They
come in different sizes. All it takes is a hole in the inspection cover and
some JB weld or RTV. Point the louvers aft of course. The idea is this will
create a slight suction on the tail cone. It's easier to stay warm by
keeping the cold are out vice trying to pump more hot air in. This trick
worked well in a flying RV-8.
Carl Froehlich
RV-8A (still working fiberglass)
Vienna, VA
Subject: RV-List: Keeping Warm
> Garry " Casper"
Subject: | Re: Bluemountain Avionics |
Sounds like you are referring to the EFIS/Lite model. If so, it will ship on
or before 2/1/02 and is $2,880. I am looking at it also. The info on their
web site is incomplete. In fact it does have an OAT function which enables
it to display real time TAS. The magnometer, which will let it display
heading, will not be available for several months after the unit first
ships. It mounts in a standard 3.125" hole and the bezel will be 4.0" x
4.5".
Randy Lervold
RV-8, N558RL, 140 hrs.
www.rv-8.com
Home Wing VAF
Subject: RV-List: Bluemountain Avionics
> John Furey
Folks,
I just had the pleasure this evening of unpacking the empennage kit for
my new RV-7A. All I can say is wow, have Van's kits come a long way
since I built my RV-6. The amount of labor saving work already done on
the empennage is amazing. Sure beats the old way of hacking each part
out of a sheet of aluminum. Anyone building from the new, pre-punched,
plastic covered, powder coated, trimmed, drilled, snap it together and
fly it kits probably can't appeciate just how much easier these are than
the old kits. I won't say "Back in the old days of RV building before
CNC milling and drilling machines and such, we had to mine our own
aluminum oxide....." but the old kits were a bunch more work.
I think Van's is to be commended for continually updating the kits,
plans, drawings, etc. Sure, there are still some nagging problems like
when the instructions and the plans don't jibe, but all in all, his kits
are good.....real good.
I'm going back out in the shop to pound a few rivets in my new toy
tonight. This is so much fun.
Randy Pflanzer
N2517C - Long-EZ - Sold
N417G - RV-6 - Sold
N524RP - RV-7A - Just Started
Subject: | Re: Percent of power |
42 45 48
Dave
> Garry " Casper"
Garry, I'm not an expert yet, but wait until after this Minnesota winter and
I will be. The coldest I've seen so far is 22F, and my plane heated very
well. I have two Robbins muffs on my 6A, not in series. Air supply is
pulled from behind #3 cylinder, and is supplied to the aft ends of the muff
(this is counterflow - optimum for heat transfer), then to the heater
thingys on the firewall. I believe it is important to have a high volume of
warm air coming into the cabin, to stop all the cold air from flowing in. I
have aileron boots, insulation but no other air leak blocks. I will
certainly add some additional things, particularly covering the 604
bulkheads with some sort of cloth, since it touches my left leg, and is
cold. A little cold air comes up through the stick boots, but not much I
can do there. Although air generally leaks out of the slider canopy sides,
there still seems to be a little swirl of cold air there, so some sort of
seal is in order there, also. With the heaters on full bore, I can't feel
any air coming through the triangles in the aft bulkhead. I built the
engine baffle heater supplies with little throttles that are ground
adjustable, and they are almost entirely closed, experimentation is in order
with this.
Good luck, let us know what you find.
Alex Peterson
Maple Grove, MN
6A N66AP flying 52 hours
Hi list,
I am building an 8, working on the wings, and beginning to check out
engines. I have contacted Bart and Sue at Aero Sport Power. They seem
like great people who are very patient and willing to answer any and all
my questions. I have decided to go with their new I0-360 B1B with
airflow performance FI with lightspeed EI. Their price is excellent for
a new engine from the checking around I've done. The weight of the
engine is 299 lbs.
The question is can anyone shed some light on the pros and cons of
considering the 9.2:1 compression pistons vs the regular pistons? I
also have thought about them holding back the alternator and going with
a B&C alternator, any comments? Their chrome kit is reasonable in cost
compared to the lycoming kit, pros and cons please? I have read nothing
but good reports from people on this list who have dealt with Sue and
Bart and am excited about this, that much closer to being done.
Also just want to say how impressed I am with the eight kit, the wing is
absolutely fantastic. Everything just FITS so nicely. I have ordered
the QB fuse and am anxiously awaiting its arrival (est March or April,
ordered several months ago). Already planning on a 7 after I get this
one done! This is a BLAST!
Thanks for any and all comments
Jim Tambs
RV8 wings
Michigan
In a message dated 11/28/01 8:20:03 PM Eastern Standard Time,
jntambs(at)voyager.net writes:
<< Hi list,
engine is 299 lbs.
Jim Tambs
RV8 wings
Michigan >>
Powersport has a good reputation, so my first impression is to go with what
they recommend for your mission. I have standard 8.5:1 pistons on my 0-320,
so I can't comment on the 9:2 pistons. I do worry (even at 8.5:1 what is
gonna happen when/if 100 LL goes away). I can give a good recommendation on
the B&C alternator. All my buddies who bought automotive alternators tell me
that they wish they had purchased the B&C unit, and will do just that if
their automotive unit fails.
Kyle Boatright
0-320/Aymar Demuth RV-6 Slider
Kennesaw, GA
http://www.angelfire.com/my/rv6
Pros:
Obviously - more power.
Cons:
Decreased TBO for one.
Also I passed on high compression pistons when Bart built my O-360
because of the eventual avgas situation.
I don't fancy putting a can of octane booster into the tanks on every
fill-up because the fuel replacement has an octane rating in the double
digits.
So, my standard-compression O-360 can run mosgas if necessary.
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Firewall Forward
http://geocities.yahoo.com/ps/info1
--- jim wrote:
> Hi list,
> seem
> all
> for
> engine is 299 lbs.
> with
> cost
> nothing
> is
> April,
> this
> Jim Tambs
> RV8 wings
> Michigan
Jim:
I would go with 10:1 pistons. There are several I(O)-360 (parallel
valve, 180 HP) RV-s flying with the 10:1s in SoCAL. All that have them
swear by them. http://www.lycon.com/nfs.htm
Lycoming certified the O-320 that I have to run on 93 octane and 8.5:1.
Many autos are running around with compression over 9:1.
The B & C alternator is the way to go. There is no better alternator
on the market at any price.
If you are planning on having a BEAUTIFUL engine installation that is
the best around, go for the chrome. If you want something to show, go
for the chrome. If you do not care what your engine looks like, DO NOT
buy the chrome.
I would purchase the Lasar ignition system. I know of 3 people that
have had Lightspeed and have had problems. One RV even removed his
after his engine self-destructed and he had a large repair bill to
overhaul it.
Gary A. Sobek
990.5+ Flying Hours So. CA, USA
http://SoCAL_WVAF.tripod.com
It depends on what altitude you are at. For the same rpm and MP, the
engine will make more power at higher altitudes. You can see this if
you run a couple of cases on the Lycoming power chart (if you can
actually find a readable one, that is).
I think the reason for more power at altitude for the same MP is
lower exhaust back pressure, and lower pressure in the crank case.
But I'm just guessing about the reason.
If you're running an O-360-A or C series, there are several power
charts on the web, including a spreadsheet that I created. See the
Engine & Propeller section of my RV Links page:
http://www.cyberus.ca/~khorton/rvlinks.html
Kevin Horton RV-8 (installing engine & electrics)
Ottawa, Canada
http://eccentrix.com/misc/rv8/rv8.html
I can't recall the technical name, but there are "flathead allen screws".
They have a countersunk head, too. If you need a flat head in thick
materials, use a socket-head cap screw in a counterbored hole.
Don
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ed Holyoke
Subject: RE: RV-List: Wingtip Attach
[edited by dwinters]
As for tank mounting, although I haven't located any, it seems that
somebody should make flathead allen screws. Has anybody seen any?
Ed Holyoke
6QB
> with airflow performance FI with lightspeed EI.
I have the Lightspeed, and like it.
I'd stick with the stock compression pistons to be sure you can use
auto gas with no detonation problems. Higher compression pistons
*might* be OK, but detonation can be hard to detect, so I would not
be willing to try that particular experiment on my airplane. For more on
autogas use see
http://www.webworksltd.com/WebPub/PetersenAviation/PetersenAvi
ation.html
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD - First Flight 18 Dec 99
http://www.geocities.com/timrv6a
> it
24 square = 48 = 75%
3 = 10%
45 = 65
42 = 55
That is what I use as a rule of thumb. It may not be exact but is
close enough for fun.
On my 320, I typically run 23 square cruise or 2300 and whatever full
throttle gives me below 23. (160 KTAS, 7 GPH) Yes when I am with a
180 HP RV, I am turning 2500 or 2600 and burning 1 GPH more fuel to go
the same speed. Flying formation or Young Eagles, I will use 2100 and
22 inches. (6 GPH, 135-140 KTAS) I always flight plan 150 KTAS.
Gary A. Sobek
Whoa! Counterflow? Tell us more.
Sam Buchanan (RV-6, always looking for a little more heat)
"The RV Journal" http://home.hiwaay.net/~sbuc/journal
and
very
muff
Sorry, I should have explained. Counterflow simply means that the exhaust
is going one way, the cabin heat air is going opposite. In our planes, the
exhaust goes aft, so the cold air goes into the muff at the aft end, hot air
out the front of the muff. I can't tell you how much this matters, only
that it will be warmer air supplied than if it is opposite. Maybe .1
degree, maybe 20 warmer. This set up in a heat exchanger maximizes the
average temperature differential between the two gasses, which maximizes
total heat transfer. Unless it is quite difficult to do this, our heater(s)
should be set up this way. It would be interesting to instrument one of our
heaters, to see how much difference this actually makes, I suspect not too
much.
Alex Peterson
Maple Grove, MN
Subject: | Lightspeed Ignition, was pistons |
In a message dated 11/28/01 9:42:17 PM Eastern Standard Time,
rv6flier(at)yahoo.com writes:
<< I would purchase the Lasar ignition system. I know of 3 people that
overhaul it.
Gary A. Sobek
http://SoCAL_WVAF.tripod.com >>
Gary,
I'm running the Rose ignition, and was wondering how your friend traced his
engine self destruction to the Lightspeed unit? With either ignition, the
only failure scenarios I see are A) Mis-timing the ignition on installation;
B) The ignition failing in a mode that would advance the ignition too far; or
C) The ignition having timing curves that were simply too aggressive "out of
the box".
Kyle Boatright
Kennesaw, GA
"Graham Murphy" , "Moore, Leroy" ,
"GEORGE MCILREATH" , "RICK MCBRIDE" ,
"LOGAN" , "RV list" ,
"Tom & Marilyn Law" ,
"Finn Lassen" , "L.Coats" ,
"Charlie Kuss" ,
"lothar klingmuller" ,
"Bernie Kerr" ,
"Rob Kermanj" , ,
, "Joel"
; cjdaron(at)aol.com ; Arthur and Christine ; Jerry Carter ; Peter and
Noeline Carpenter ; Carl ; jan bussell ; Sam Buchanan ;
Brumwellb(at)aol.com ; Steve Alan Bowman ; Bourgeouis, Gene
; Warren Bishop ; Paul Besing ; Dave Berryhill ; Dr. Bernard B. Beard ;
NORM BARTLETT ; Beagle Aviation ; ABAYMAN(at)aol.com
Do not open any attachments that may have been sent from me today or
near future.
bernie
From: | Brian Armstrong <armstrbc(at)ucsub.colorado.edu> |
i taught an engineering lab at my school once and we studied parallel flow
vs. counter flow in heat exchangers. we ran ordinary hot and cold tap
water through a heat exchanger (40 degrees F cold and 180 degrees F hot).
i seem to recall that the outflow temperature of both the hot and cold
was between 5 and 10 degrees different, depending on the flow
configuration. it was definitely noticeable. i went through the math of
why that was one time, and what i found for that particular heat exchanger
was that the average temperature difference over the length of the
interface was higher. in the case of parallel flow, the temperature of
the hot decreases as you go along the exchanger, while the temperature of
the cold increases. the two converge. in counter flow, the temperature
curves (with respect to position along the heat exchanger) remain closer
to parallel, which maintains a more constant pressure differential across
the interface. that gives the exchanger more time and more "force" by
which to transfer heat. i'm not sure how much it makes a difference in
the short section of an airplane heater muff, but i bet it's
noticeable. physically it's definitely a more effective configuration
(probably with exceptions).
brian armstrong
boulder, co
> much.
> Alex Peterson
> Maple Grove, MN
From: | Ken Harrill <KHarrill(at)osa.state.sc.us> |
November 20, 2001 - November 29, 2001
RV-Archive.digest.vol-lx
