RV-Archive.digest.vol-mh
February 01, 2002 - February 07, 2002
1977 Aerostar
Available soon
Call for details
1980 Cessna 152
$21,800
1974 Cessna 172 Full IFR
$48,000
1976 Cessna 172 IFR
$48,000
1975 CESSNA 172 Ultra Clean, Must See
IFR, GPS, King Digital with ADF DME $54,000.00
EMPLOYMENT OPPORTUNITIES
Flight Instructor for CPC Busy fax resume (818) 896-9541
Call Bill @ 818 896-6442
Or Fax @ 818 896-9541
Please see www.vistaaviation.com for complete inventory
Powered by List Builder
To unsubscribe follow the link:
http://lb.bcentral.com/ex/manage/subscriberprefs?customerid=13738&subid=8D3FA857420D3253&msgnum=37
Subject: | Alternate air for fuel injection |
Blank i like the idea of a cable operated door. It would let you check
the condition of the filter by just opening the door and checking the
manifold pressure. It would also put the door on the outside of the
plenum so when it wears out the parts will fall off of not into the
engine. There is a lot of vibration and the spring loaded doors need to
be checked for wear at annual and are missed quite often.
i checked my door is 2 1/2" square, all 4 corners are 7/16" radius , the
opening in the plenum is 2 1/8" square, all 4 corners are 1/4" radius,
the door is made from .050 alum sandwich with rubber gasket between. It
has the aircraft extruded hinge material and a torsion spring to hold it
closed.
Dennis and Fran Flamini N564DF race#53 Chicago
Subject: | Access plate removal; was Fuel Tank Sender (Gaskets) |
Get a standard 1" wide putty knife and sharpen the end a little. Now with a
small ball peen hammer tap the sharpened putty knife between the access
plate and the tank. Don't forget to remove the screws first. What your doing
is cutting the proseal. In less than 1 minute you should have the access
plate and tank parted. It is real easy. Using a heat gun would only push the
operation to a Rube Goldberg status.
Gary Zilik
Michael J. Robbins wrote:
> ----- Original Message -----
> From: "Gary Zilik" <zilik(at)bewellnet.com>
> It is not hard to get the
> access plate off the tank if prosealed in place. A sharpened putty knife
> slid
> between the tank and plate and it pops right off.
> > Gary Zilik
> Does it help to warm it up with a heat gun first? I have to remove my
> access plates to add the anti-rotation bracket to both tanks. I've been
> putting it off for two years, but need to do it soon as I hope to be in
> the air in a couple of months. I used proseal and the cork gaskets on
> the access covers, and Titeseal on the senders.
> Mike Robbins
> RV8Q 80591 N88MJ
> Starting engine baffles (what a poor set of instructions!)
Subject: | Varaprime Temperature? |
I like to spray above freezing. I do make sure the parts and paint is
warmed up. I also use a faster converter; I think it is 618 or maybe 615,
not sure.
Jack
RV8, wings
DSM
Subject: | Re: Access plate removal; was Fuel Tank Sender (Gaskets) |
Just wanted to thank everyone for their input/corrections/enlightenment
regarding fuel tank sender sealing.
Rob Acker (redoing access covers, proseal with no gaskets).
>All of you guys are right and it just depends on what stage of deviation you
>are talking about. Toe-in helps prevent the initiation of the yaw though
>its tendency to keep a straight track, but toe-out helps recovery by virtue
>of loading up the outside wheel. Personally, I'd rather the toe-out because
>I may not put that bad boy on the deck in perfect alignment. Prevention
>(toe-in) or correctability (toe-out)... that's the big difference.
>Cheers,
>Dave
I don't know from theory? Both the toe-in and the toe-out people seem to
have some good points.
I do know that my RV-6 has quite a bit of toe-in in the three point
attitude and has pretty much neutral toe in a level attitude; this from
actual measurement, although it varies a lot with how much weight is on
the gear. I also know it has very docile ground handling in either
attitude. My steering springs are loose, per Van's specs. I have
observed many RV's with tight springs or even a fairly direct steering
rod. All these arrangements are reputed to work well also. Docile
handling in every case.
I think anyone with ground handling problems needs to look for gross
problems, either in brakes or gear geometry far from Van's specs.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
>>Cheers,
>>Dave
>Larry Pardue
>Carlsbad, NM
>RV-6 N441LP Flying
Larry,
Based on your observations of how the gear moves as the weight on it
varies, do you have any idea what happens in the three point attitude
as more weight comes onto one wheel, and less on the other (as would
happen when a ground loop started). How the wheel alignment varies
in a dynamic situation like that probably goes a long way to
explaining why some aircraft types resist ground loops, and others
seem to look for any excuse to go off in the weeds.
Kevin Horton RV-8 (installing engine & electrics)
Ottawa, Canada
http://eccentrix.com/misc/rv8/rv8.html
From: | "Builder's Bookstore" <winterland(at)rkymtnhi.com> |
Subject: | for purists only |
Those nearing the later stages of building are soon to be confronted with the
first of Van's little surprises. The fact that your "all metal" airplane is
not really all metal, but actually contains quite a bit of fiberglass. For
those purists among us, there is an alternative. You can make your wheel
pants, various fairings, and even the cowl out of sheet metal and thus fly a
true all metal RV.
The skills to do this are shown in detail in a new set of videos by Kent
White (The Tin Man). The first, Shrinking Magic goes through the basic
skills of forming, shrinking, and stretching metal. The second Shaping Wheel
Pants advances upon these skills and uses them to actually construct a
finished part. Both these videos are long and detailed, and although not
fancy hollywood productions do impart a great deal of knowledge and
experience.
Personally, the more I watch the Tin Man do his stuff the more I thank Van
for all that glass. But that's me. Those looking to take the time to learn
and apply a true art to their projects may actually appreciate this
alternative.
In the Sheet Metal section of Builder's Bookstore.
Also New:
1] GAS WELDING ALUMINUM Also by "The Tin Man" excellent welding video;
very detailed and uses a special camera lens that shows clearly in detail the
actual weld as it happens. In the Welding section.
2] 4130 CHROMEMOLY AIRFRAME CONSTRUCTION Also by "The Tin Man" The skills
to build or refurbish a steel tubed airframe like a Piper Cub, Stinson, etc.
(not RV related). In the Welding section
3] AC-43.13 Acceptable Methods of Aircraft Repair has just been revised again
with the new edition to be available on March 1st. I'm not sure of the exact
changes, but do know it involves over 200 pages. We are now taking pre orders
for early March shipments. In the Airframe - General Skills section.
Andy
Builder's Bookstore
http://www.buildersbooks.com
800 780-4115
What are Van's specs for toe in or out?
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Larry Pardue
Subject: RE: RV-List: RV-3 PROBLEM
you
because
>Cheers,
>Dave
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
The shield idea may have merit.
I'll try wrapping one with foil, and grounding the foil, this weekend.
I have totally checked the ground plane and provided different ones just to
be sure, all to no effect.
them damm electrons, I seem to remember that everything we know about them
is still theory
more later
thx
W
Subject: | Where to buy SHIM PLATES for starter? |
Does anybody know of a place to buy shim plates that
bolt under the starter. Had my starter rebuilt and now
fits too tight on the ring gear. I am putting this on
an O-320H2AD engine with a prestolight starter MZ4222.
Dan DeNeal
trying to finish a todo list that just keep getting
longer!!
RV6a
"The fuselage must be level, both lengthwise and crosswise,... Under a
no-load condition, the axles should have no toe-in or toe-out, as is
shown in SK-70."
RV-6 Section 10 Manual
Larry Pardue
Carlsbad, NM
RV-6 N441LP
01:19:48 PM
Which begs the question, what have people observed when changing out the
springs for the Jantzi steering arm, which I intend to do.
Eric
Larry Pardue (at)matronics.com on 02/01/2002 11:31:47 AM
Sent by: owner-rv-list-server(at)matronics.com
cc:
you
virtue
because
>Cheers,
>Dave
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
From: | "Wayne Bonesteel" <rv8tor3(at)charter.net> |
Wow I can't believe all this proseal stuff, I used the cork gaskets with
Permatex both sides of the gasket and screws, Leak tested OK and
no leaks in 2 years.
Wayne RV-4 flying.
Based on all the feedback on this thread, sounds like I might ought to
re move my rubber gaskets and do the Proseal thing!
a small ball peen hammer tap the sharpened putty knife between the access
ing is cutting the proseal. In less than 1 minute you should have the
access
It is not hard to get the access plate off the tank if prosealed in
place.
A sharpened putty knif slid between the tank and plate and it pops right
off. Does it help to warm it up with a heat gun first? I have to remove
my
>Sent: 2/2/20 6:43 AM
>Received: 2/1/02 11:13 AM
>From: Kevin Horton, khorton(at)cyberus.ca
>Larry,
>Ottawa, Canada
This is from memory, but I did spend some time thinking about it when I
checked the gear alignment and was startled to see how much toe in the is
in the three point attitude with my RV-6.
The varying toe-in/toe-out on the RV-6 gear, in three point attitude, is
due to the camber. Camber is most with the least weight on the gear.
With increasing weight it would go to zero then as the gear splayed out
with increasing weight, or a hard landing, presumably the gear would go
toe-out.
Hold your hands side by side with the palms facing and fingers down.
This is the landing gear. Tilt your hands so the fingers are closer to
each other. This is the camber. As long as the fingers point straight
down there is no toe-in. Now point the fingers slightly away from your
body. This is the gear geometry in three point attitude. The toe-in is
obvious.
Larry Pardue
Carlsbad, NM
RV-6 N441LP
Subject: | Re: RV-3 PROBLEM |
You want the tires to roll straight, the objective of toe in is to allow for
bearing clearances and rolling friction (which will twist the legs open),
this rolling friction load will vary depending on load and attitude.
Van drills the legs for us now and we don't have to worry about it.
Wayne
RV-4 flying
Good luck. Let me know what happens. We had an ice storm last night and
today, so I bet I can't go flying for a while. My plane is parked outside
and it will take a while to get free of ice.
Steve Soule
From: Wheeler North [mailto:wnorth(at)sdccd.cc.ca.us]
Subject: RV-List: Vans Gauges
is still theory
more later
thx
W
From: | "Perry Rhoads" <perryrhoads(at)ctnet.net> |
I recently put the Jantzi link on my RV-3. Very little change from the
spring/chain setup. My RV-3 is VERY easy the fly. No problems with ground
handling or landing/ takeoff at all.
The original builder(not me) apparently did an excellent job af alignment.
Perry Rhoads
Carlinville, IL
RV-3 N96GW
> Eric
> To:
> cc:
> you
> virtue
> because
> >Cheers,
> >Dave
> Larry Pardue
> Carlsbad, NM
> RV-6 N441LP Flying
Seems like the easiest solution is to put a wheel up front!!!
Dave Burnham
RV6A
Subject: | AOA service bulletin |
Fellow Listers:
I received this service bulletin from Jim Frantz regarding his angle of
attack instrument. He wanted to be sure this was distributed throughout the
RV community.
Doug Weiler
MN Wing
Subject: AOA Sport or Pro with RV pre-calibrated chip
For RVs installing or flying the AOA Sport with the pre-calibrated chip, it
is important that the flap switch be wired correctly. There are three ways
to wire the flap switch and only one will be correct depending upon when we
shipped the calibrated chip. Please go to www.angle-of-attack.com and
click on the green bar "Service Instructions" link for a copy of Service
Instruction 0201 (SI0201) and more details.
A revised calibration verification checklist (Calibrate Verify CL) is also
available from the link to the AOA FTP site. Instructions for an Internet
Explorer download are also available via the green bar link. Let me know
if the verification checklist works for your RV and if it passed the
verification.
James B. Frantz
Proprietary Software Systems, Inc.
LFrantz(at)compuserve.com
Subject: | Re: Radio Callsign |
> And some want you to describe the "type" (or was that "class"?) as "Hotel
> I may have this wrong on the speeds but there are three "types/classes)"
of
> experimentals:
> HXA ...<100kts
> HXB ... 100-200kts
> HXC ... >200kts
> This is based on a recent conversation with an FSS when I tried to file
with
> A/C type being "RV".
RV4, RV6, and RV8 are now officially listed in the "type" designation. The
problem is that many controllers aren't aware of it. I use "romeo victor
eight" and then if there is any hesitation I quickly add "hotel xray bravo".
I'm probably running about 50/50 with approach and enroute controllers
recognizing the RVx designation.
Randy Lervold
RV-8 #80500, 143.5 hrs
www.rv-8.com
Home Wing VAF
From: | "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> |
List, I was wondering if anyone who has installed or is about to
install the Vans Triangle Heater Box could give me the following
information:
1) Is the 2" hole on the firewall side of the box centered?
2) Am I correct that the size of the box (Against the
Firewall) is 3 1/4" Wide by 5 1/8" High?
I was able to borrow a 2" Greenlee Knockout to make my firebox
holes then my boxes didn't arrive! I can only use the Greenlee Tool for
the weekend. Can anyone bail me out??
Tom in Tropical Ohio
From: | "martin heisler" <martinheisler(at)hotmail.com> |
hi , there was a past arcticle in sport aviation about the super rv6 . can
anyone tell me which issue this was in? i can then locate the magazine from
someone , once i know the issue.....thanks
Send and receive Hotmail on your mobile device: http://mobile.msn.com
Subject: | Re: Heater Box Help |
Hi Tom,
As it happens I'm holding one in my shop soiled hand.
the base dimensions are exactly:
5-1/16" long "high"
3-1/4" wide
The cabin inlet hole "firewall side" is not centered lengthwise.
It is a 2" hole. The center of this hole is 1-27/32" from the cabin/cockpit
entry end of the base. The hole is centered width wise.
Let me know if this info needs clarifying
Jim in Kelowna
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: RV-List: Heater Box Help
> information:
Hi;
I did the hole cutting for a Van's heat control box myself recently.
Three holes are needed, top - 3/16" hole for upper mounting bolt, center -
2" dia for hot air flow, and bottom - 3/16" hole for lower mounting bolt.
I am working from memory, but I think the two 3/16 holes were 4 1/2" apart.
The 2" hole was 1 3/4" or so below the upper 3/16 hole (measuring center to
center). This assumes that you are mounting the item with the hinge and the
operating arm at the top. (Other orientations are possible.)
I didn't take an overall measurement but your numbers (3 1/4" x 5 1/8") look
right.
You would probably be safe to cut your 2" hole planning up 1 3/4" for one
hole and 2 3/4" down for the other hole to make sure you're not running into
anything important. Best leave the 3/16" holes until later when you have you
hot air box in hand to check these dimensions.
Jim Oke
CYWG
RV-3 (flying when its not too cold)
RV-6 (tinkering inside, most any temp)
> information:
Subject: | Re: rv 6 6cylinder |
Why not do an article search on the EAA web site www.eaa.org
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Always looking for articles for the Experimenter
From: "martin heisler" <martinheisler(at)hotmail.com>
Subject: RV-List: rv 6 6cylinder
From: | "Doug Bell" <dbell(at)manisteenational.com> |
Guys,
Any of you who have installed fm/cd players have a recommendation for a
model of antenna good for the fm band and the placement of such. Our
plan like many others is to place the transponder and bent whip comm
antenna under the belly on opposite sides of the 8...approx where the
footwells are for hte rear seater.
Thanks for any input.
Doug Bell
8qb
Manistee, MI
Subject: | Re: wire braided hose |
What is a 'Friction blade'?
Doug Gray
Eric.J.Henson(at)chase.com wrote:
> I used to work for a shop that made steel braided hoses for everything from
> little cute avionics hoses to fuel transfer hoses for Bath and Ingalls ship
> building. These were 8" steel braided hoses. Everyone of them was cut the
> same way Bill describes. Friction blade in a chop saw, cut through the
> masking tape. I used to watch them beat the stainless crimp collars on
> those things with a big wooden mallet. It was a big pain every time they
> did it and required a good vocabulary of profanity to get the things on. It
> was a little scarry when the C-17 fuel lines would come back from leak test
> with leaks and they would just beat the collars with the Big Wood Hammer
> until they sealed. Anyone here fly C-17's, not me thanks. They did say that
> until they get pressure for a while and tend to relax inside the collars
> that they were a little tempramental.
> Eric
Jim, I think I got it? The 2" Hole is 1-27/32 down from the top edge of the
box if looking at it mounted on the Firewall from the engine compartment?
Thanks, Tom in
much Colder Ohio than the 60's this morning!
Subject: Re: RV-List: Heater Box Help
> Hi Tom,
> 5-1/16" long "high"
> 3-1/4" wide
cabin/cockpit
> Jim in Kelowna
> To:
> > information:
In a message dated 02/01/2002 10:26:41 AM Pacific Standard Time,
n5lp(at)carlsbad.net writes:
> shown in SK-70."
> Larry Pardue
> Carlsbad, NM
> RV-6 N441LP
You also need to verify that the gear leg bolt is a tight fit in each gear
leg to engine mount attachment.
Unlike the RV-4 and later kit types, these parts didn't come predrilled from
Van's.
Jim Ayers
RV-3 N47RV sn 50
Subject: | Vari-Prime Information |
Here's what DuPont says in their Tech Mnaual...
I assume you know the general description of the material and basic prep
procedures, so I won't get into that.
620S is the fast Converter and 614S is the slow. Mixing Ratio is 1:1.
Any additives ( accelerators, acid, flex agents, fish eye eliminators,
and so on ) are highly NOT RECOMMENDED!
You can pretty much undercoat over with just about all DuPont
undercoats. We generally use ChromaPrime . Do Not use Lacquer Based
primers or sealers! It is a good idea to treat aluminum with 225S/226S
for best results. If your going to shoot steel parts only clean
them...VariPrime doesn't like 244S or any other Conditioner.
As far as temperature goes, DuPont looks at everything at 68 degrees or
more (shop or booth temperature). Part of how it works is extothermic.
Meaning it needs some outside warmth to convert. Sure it will flash at
lower temperatures but...it may not (won't) bond as well as when using
the proper air temperature.
When shooting it at 68-72 degrees, flash time is 5 minutes.
Undercoating can be done after 30 minutes dry time and sanding, if
needed, after an hour or so. The maximum dry time is 24 hours, after
that it has to be sanded before you can apply any other coats.
One thing to remember is it needs to "wet out". That is don't force dry
it. You need to apply at least 2 wet coats of variprime for proper
protection for aluminum.
Hope this gives you some insight on the product. If you still have
questions...e-mail me and I'll see if I can't get you an answer...
Jim D. N708JD
Performance Engineering
Tom,
If you intend to mount the Cabin heat door assembly with its scat tube
fitting pointing in the down position, (that is pointing toward the exhast
heat muff) the `center' of the cabin heat firewall hole will be as you
describe.
As someone else said don't worry about drilling the mounting screw holes
until you have the unit on hand.
The mounting screw hole centers on the unit I have here are 1/4" from the
edges and centered on the width of each end.
Up here in the cold Canada north the snow is melting fast today
The best to you,
Jim in Kelowna
the
> Thanks, Tom
in
> From: "Jim Jewell" <jjewell(at)telus.net>
> To:
> > Hi Tom,
> > 5-1/16" long "high"
> > 3-1/4" wide
> cabin/cockpit
> > Jim in Kelowna
> > To:
> > > information:
for
--- Doug Bell wrote:
> Guys,
> a
> Doug Bell
> 8qb
> Manistee, MI
Doug:
I have Bob Archer's VOR antennae in each wing tip. One is used for the
VOR/GS and the other for the FM stereo. Works great. Even a homemade
FM antenna in the wing tip should work ok.
Gary A. Sobek
1,002.9+ Flying Hours So. CA, USA
http://SoCAL_WVAF.tripod.com
Subject: | aileron galvanized pipe question |
When drilling skin 1/8 inch to the galvanized pipe I ended up with about half
my holes waaaaaaaaayyyyyyyyyy to big (very very oblong). Large enough that
the hole will not be filled after the rivet is in place. I think the rivet
will set at one end of the oblong hole but I still have room almost for two
rivets. I guess it was the angle and or a dull bit along with heat.
Suggestions for repair? Or rivet the dang thing and use a little putty at
paint time. My concern is that air will/mositure will enter the aileron.
Thanks, Bob
Is there an oops pop rivet for an oversized 1/8 inch hole?
for an fm antenna you can use a regular radio coax from the auto supply .
plug one end into your radio the other end clean off the outer plastic and
sheilding only for about 3 ft. the inner cable is still covered and
protecting the inner cable.
this could be placed possibly along your front canopy bow/roll bar. under
the top of your glare shield if it is composite or as far out as a wing tip.
i have used this under the glare shied of a composite aircraft and it worked
fine.
i have seen another one run up the center top inside of a rv4 and it works
very well.......
In a message dated 2/1/2002 3:36:23 PM Pacific Standard Time,
dbell(at)manisteenational.com writes:
I routed RG-58 cable down the right wing and terminated it in a female BNC
bulkhead mount connector attached to the tip rib. I put a BNC male connector
on the end of a 42" length of RG-58. I stripped about 32" of the jacket and
sleeving from the other end and draped it inside the wingtip with a few tacks
of RTV over the length to hold it. It works excellent in all conditions
-GV (N1GV)
From: | "Randall Henderson" <randallh(at)attbi.com> |
Subject: | Re: Radio Question |
Tom Gummo said:
> When I transmit, I can't hear a "sidetone" or my own voice
> while talking.
I don't know about the King but some radios have a pot that you can adjust
for more or less sidetone. On my terra its adjusted with a small screwdriver
through a little hole in the housing (radio needs to be removed to access
it.) There should be something about it in the radio's manual.
Randall Henderson, RV-6 N6R (~300 hrs)
Portland, OR
www.vanshomewing.org
From: | "Steve Hurlbut" <hurlbut_steve(at)hotmail.com> |
Subject: | Re: aileron pipe |
I would use a Cherry Max rivet size 5 countersunk. Probably 5-3 or 5-4.
You can even get 6- Cherry Max if the hole is really that big.
These holes are easy to elongate. You should drill the holes with #40 bit
first and then enlarge it to full size after. Too late now but an easy fix.
Steve
RV-7A
Wings almost done
>From: Bobpaulo(at)aol.com
>Subject: RV-List: aileron pipe
>Date: Fri, 1 Feb 2002 23:24:02 EST
Thanks for the htoughts on the FM antenna guys, after being at golf shows
for the last three weekends, finally a Saturday in the shop withthe plane
all day...whew...it is still winter isn't it?
Thanks again,
Doug Jr
8qb
Subject: Re: RV-List: FM Antenna
connector
and
tacks
> -GV (N1GV)
Subject: | Fuel lube and Nylaflow |
Anyone know if Fuel Lube is
OK for use on/around Nylaflow
tubing?
Dave Hyde
nauga(at)brick.net
RV-4, #@%&*
brakes
From: | Gary & Carolyn Zilik <zilik(at)bewellnet.com> |
Subject: | Re: aileron galvanized pipe question |
How about running down to the hardware store and buying a new pipe and drill bits
and try it again.
Gary
> Thanks, Bob
To clarify, its the skin that has the elongated holes not the pipe.
Subject: | Re: RV6-List: unsubscribe |
In a message dated 02/01/2002 7:32:51 PM Pacific Standard Time,
rv6flier(at)yahoo.com writes:
> Doug:
The VOR frequencies are 108 to 118 Mhz. FM frequencies end at 108 Mhz, right
below the VOR frequencies. A VOR antenna should still work pretty well
between 88.9 Mhz and 108 Mhz, especially with the output power of the FM
stations.
Jim Ayers
RV-3 N47RV sn 50
(I have an unused VOR antenna in the wingtip, but where can I mount the FM
receiver?) :-)
Subject: | Re: Fuel lube and Nylaflow |
I believe is harmless to Nylaflow. I actually found Fuel lube most helpful
on the Nylon fittings! It seemed to give me a much better feel for when I
was approaching terminal tightness. Without Fuel Lube, the nylon fittings
would turn with great resistance throughout the whole tightening process and
I never knew where to stop. This led to leaks in the brake plumbing. With
Fuel Lube applied, the fitting spun in easily until they reached a good
degree of seal, at which rotation the torque suddenly increased
dramatically. That's when I stopped.
Dennis Persyk 6A N600DP 113 hours
Subject: RV-List: Fuel lube and Nylaflow
> tubing?
> Dave Hyde
> nauga(at)brick.net
> RV-4, #@%&*
brakes
Does NAPA have a similar product to Fuel Lube?
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of nauga(at)brick.net
tubing?
Dave Hyde
nauga(at)brick.net
RV-4, #@%&*
brakes
In a message dated 2/1/02 8:25:41 PM Pacific Standard Time, Bobpaulo(at)aol.com
writes:
<< Is there an oops pop rivet for an oversized 1/8 inch hole? >>
Check Wicks page 101, Cherry Q rivets and Cherry N rivets up to 3/16 or
Cherry Max 5/32. I just happen to have the Wicks catalog in front of me,
Spruce has the same hardware and I think they have larger Cherry Max sizes.
Harry Crosby
Pleasanton, California
RV-6, finish kit stuff
> Eric
Here ya go:
http://home.HiWAAY.net/~sbuc/journal/steering_link.html
Sam Buchanan (RV-6)
"The RV Journal" http://thervjournal.com
Subject: | Close Tolerance Bolts |
3 Questions:
1.) How do you get those close tolerance bolts in the holes of the wing
spar? They seem a little too 'close tolerance' for me. Spent 5 min getting
one in and then 5 min getting it out. Use a little lube? Obviously I don't
want to drill the hole out or sand the bolt to maintain the close tolerance.
2.) The AN426AD4-14 rivets that attach the vertical bars (F704G) to the
F-704B to F-704D seem too short. I called Van's and they said just rivet
them any way but they have not had any other builders bring this up. Have
others experienced this?
3.) Is building the wooden block that represents the spar really necessary?
Isn't the distance between the F-704A and F-704B determined by the F-704H x
2?
Thankx again
Steve
RV-7A
Kingston, Ontario
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
From: | "Chris Santschi" <rv8pilot(at)hotmail.com> |
Just where can you find Fuel Lube?
Chris S RV8 Working on fuel lines.
Hello all,
I have the chance to buy a
complete rv-6 still in the crates.It
was bought and never started. There is
no damage at all and wanted to know how
much it is worth.He said make offer but
I'm not sure what it's worth.
Subject: | HELP my O320 H2ad and AD's |
I did not build my RV so I am forced to use an A&P for the annual.
The mechanic seems to think that all of the AD's in my O320 H2ad need to be
complied with. I am under the impression that since this is an
experimental, there is no need. I am trying to avoid the oil pump impeller
AD which is costly. Anyone out there know the answer AND can cite chapter
and verse? Thanks
mailto:rblum(at)pacbell.net
Bob Blum
N710EH
From: | "Paul Besing" <azpilot(at)extremezone.com> |
Any of the mail order places, or at a local FBO. I got mine in a parts shop
by the airport. They repack it into small makeup sized tins, which is very
handy, considering that is enough to do about 3 airplanes. The large thing
you buy from spruce and such you will never use up!
Paul Besing
RV-6A N197AB Arizona
First Flight 22 July 01
Kitlog Pro Builder's Log Software
http://www.kitlog.com
Subject: RV-List: Fuel Lube
Tom,
On my King 135a there is a jumper wire on the back
of the radio to enable a side tone.
ray,
rv6a
Subject: Re: RV-List: Radio Question
> > while talking.
screwdriver
> Portland, OR
Aahh er, a few notes on wheel alignment.
Toe is distance between wheel fronts vs wheel rears
Toe-in is fronts closer than rears
Camber is distance between wheel tops vs bottoms
Negative is tops in
Castor is the angle fore or aft that the steering pivot axis for a steerable
wheel pivots on.
Motorcycles and nose gears call this rake. The more positive castor, or rake
the more stable it is but the less steerable it is. Chopper motorcycles have
maximum rake. Cessnas have minimum rake.
Steering inclination is this same angle but it's a measure of pivot axis
inboard or outboard rather than fore and aft.
Trail is the distance between the pivot line of the steerable wheel and the
axel of the same wheel. The combination of rake and trail on motorcycles and
many tricycle aircraft puts the axel in front of and above the steering
pivot line causing steering centering due to the weight of the vehicle. In a
tail wheel the axel line is behind the pivot line. The pivot line should
just about vertical. If it has a slight rearward rake (Bottom end aft of top
end) this will tend to straighten the tail wheel. If its the other way
around and you release the steering lock the wheel will pivot forward and
you will look really silly out on the runup ramp climbing out to lift up
your tail and reset your tailwheel. (Been there, done that)
The previous discussion on toe-in isn't taking into account the flexibility
of the gear. The reason for toe-in in cars is that the wheel assembly and
steering linkages all have some flexibility and play. As the vehicle turns
the wheel is side loaded some. If it is toed-out the outboard wheel will
flex to toed-in, and this will cause the wheel to "jump" to a new track. The
way it feels is like taking a step while doing straight legged monster
immitations, shifting weight from one foot to the other. As you begin to
turn the car suddenly shifts weight to the outside wheel as it shifts from
toe-out to toe-in on a new, tighter track.
If it has slight toe-in instead, then it will still shift weight due to
centrifugal force but it will be more gradual. And I have tested this many
times in both cars and aircraft, as I was the shop foreman in several shops,
both aircraft and auto, that provided alignment services amongst other
things.
In all cases the normal specified amount of toe-in is less than 1 degree to
none. Front of tire to rear of tire should be within 1/16" or less. The most
accurate way to measure this is to set a lasar protractor on the wheel rim
and project the beam out 20 ft either way to your tape measure, measuring to
an accurate projected centerline of the aircraft, then use a little math to
back calculate the actual toe for each wheel.
Another part of this discussion that makes it all a little mute is braking.
These gear will flex to toe-out if any brake is applied. And from what I've
seen of most of the newer rudder pedal assemblies is you can't apply rudder
without inadvertanly applying a little brake. At least this is true for 6's
and 8's. I know this because I've tested a number of them. Just have someone
rock your plane back and forth while you stuff in some rudder pedal and see
if the brake drags. The pedal pivot points are too low, and once again,
Van's doesn't consider this to be a problem.
One final note; Don't trust Vans predrilled alignment. Mine were: left 2 3/4
deg toe-out, right 1 7/8 deg toe-out. This wore a set of tires out in the
first 15 TO&L operations because the dummy (me) still trusted Vans in all
things measureable.
Wheeler
Subject: | Re: marker beacon/transponder ant |
dear listers
how close can the marker beacon antenia be to the transponder antenia?
scott
tampa
Subject: | Re: HELP my O320 H2ad and AD's |
A fellow who sold his RV in this area ran into the same problem. The buyer
stipulated that the plane undergo a condition inspection by an A&P. The A&P
required that the ADs be complied with. It was an expensive condition
inspection. I believe that most A&Ps will require AD compliance, regs
notwithstanding. I keep a service bulletin and AD compliance log with my
plane to maintain its salability.
Subject: RV-List: HELP my O320 H2ad and AD's
be
impeller
> and verse? Thanks
> Bob Blum
> N710EH
I have seen the shaft in a o-360
that was not changed and broke 10,000
oh-o even if it exp. I would still have
the ad's complied with they are there
for a reason "to keep you alive" just a
thought.
Jeff Garrett
RV-7a
812W reserved
Blum
>and verse? Thanks
>Bob Blum
>N710EH
>_-
Email Forum -
through the Contributions of
banner ads or any other form
Matronics Forums.
>_-
browser to view the latest messages.
files with other List members.
>_-
http://www.matronics.com/subscription
http://www.matronics.com/browselist/rv-
list
http://www.matronics.com/search
http://www.matronics.com/archives
http://www.matronics.com/rv-list
http://www.matronics.com/emaillists
>_-
Considering you can buy a -7 for $16,000 I wouldn't pay more than about
$12,000 for it, if it has the finish kit.
Paul Besing
Subject: RV-List: RV-6 Kit
<FtpBandit@web-unwired.net>
> Hello all,
> Thanks
RV7and7A
Subject: | Wing Skin Fit Problem :-( |
Ok, guys, I got the main ribs clecoed to the Front and Rear spars and
decided to trial fit the top skins to make sure everything looked like
it was going to fit ok. The inboard skin does not fit the holes in the
Frt. spar like they should. The out board skin fits great. Here are some
pictures of the problem. If you are past this in the building process,
please let me know if you had the same fit and how you went about
getting it to fit better. I did try the other skin and it fit the same
way.
Here is a link to the pictures:
http://www.geocities.com/hester-hoptown/RVSite/WingSkinFit.html
Surfing the Web from Hopkinsville, KY
Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/
Starting RV7A wings :-)
No chapter and verse yet, but I am looking.
Just ask the A&P which AD's would apply if you had a Chevy engine, or
Mazda, or Briggs & Stratton, etc....
Sam Buchanan
> and verse? Thanks
> Bob Blum
> N710EH
From: | "Jordan Grant" <JordanGrant(at)bigfoot.com> |
Subject: | RV6 Fuse Jig North Texas |
My fuselage is now out of the jig!!!
The all-wooden jig (used successfully for 2 RV-6s) is available for free
if anyone needs it. It is located at Wichita Valley Airport in Wichita
Falls, Texas. (About 2 hours north of Fort Worth). Contact me if
interested.
Happy Building,
Jordan Grant
Subject: | Paint Gun Problem |
I have a small 'detail' paint gun that I got from Harbor Freight.
Periodically, when I'm trying to spray Vari-Prime on some parts, the gun
will get all messed up and it will not 'atomize' the paint. The paint
comes out very splotchy, not a smooth, even coat. So I play with the
settings, blow some MEK through it, take some parts off and then put it
back together. Sometimes it works, sometimes it doesn't. I have to
fiddle with it for a long time to get it to work again. And then, all of
a sudden, its perfect again!
Can anyone tell me what is causing this kind of painting problem?
Thanks guys,
Jordan Grant
RV-6 N198G (reserved)
Painting fuselage parts.
Subject: | Re: Wing Skin Fit Problem :-( |
It's been a long time for me to remember...but it seems like on my -6 there
were inboard top skins and inboard bottom skins. Take a look a switching
some skins...
Jerry Calvert
Edmond Ok -6
Subject: RV-List: Wing Skin Fit Problem :-(
> way.
From: | "Bill or Heather Cowden" <cowdens(at)peoplepc.com> |
Subject: | rear seat rudder pedals |
I have decided to not install the pedals I bought. They are powder
coated white. Vans gets $92 for them, let me know what you are willing
to give.
I also want to go with electric aileron trim and am willing to sell or
trade up my manual set.
Seems like I remember seeing a kit of this nature that was about a 1991
vintage. If the one you are looking at is similar to this one....a lot has
been changed since then that decreases the labor, changed the design , new
enhancements, etc., that this kit will not have and could add additional
costs to the builder in this situation. These things should be taken into
account in determing value. Sometimes bargains don't turn out to be
bargains...and then again, sometimes they become a deal of the lifetime! I
guess it is like a used car....worth what ever someone will pay.
I would get an experienced RV'er and have them look the kit over, get with
Van's and see what the approximate cost of the kit was(if not known) and
shoot them a price if it looks like something you could live with.
Jerry Calvert
Edmond Ok -6
> Hello all,
> Thanks
Subject: | Re: Paint Gun Problem |
There are three answers to paint gun problems that I'm really familiar with
1 Plugged vent hole.
2 Spray nozzle not TIGHT.
3 Paint not strained and the proper viscosity.
good luck
Dave "ex body and fender" Burton
Try playing around with the air pressure and the "screw" for the amount of
paint used. I've had similar problems with my "touch up" paint gun and
don't really know the answer, maybe someone on the List will know. Try
putting a marble in the paint cup to enable you to keep the paint stirred
well.
Marty in Brentwood TN
Subject: RV-List: Paint Gun Problem
> Thanks guys,
> Jordan Grant
From: | Jerry Springer <jsflyrv(at)earthlink.net> |
in 1987 to 1989 kits were about $7,600 that is what I paid for mine during
the time I was building it in 87-89. I would say the kits have increased
in value about 3% per year. Take that into consideration and then make offer
based on age of kit. I would offer somewhat less than the original price
depending on age.
Jerry
> Paul Besing
> From: <FtpBandit@web-unwired.net>
> To:
> > Hello all,
> > Thanks
From: | "John Bright" <john.bright(at)bigfoot.com> |
Dear Jordan:
I have a different paint gun but it has an annular chamber around the needle
that gets completely full of pigment over time so it must be dis-assembled
and cleaned. Paint has an amazing amount of pigment.
John Bright
RV6A pre-punched, wings
Newport News, VA
757-886-1161
> the gun
> Jordan Grant
My 93 kit cost me around $11,500 and that is before the prepunch. I
probably would not offer more than $8-10K if it is the complete kit. Yes,
the prepunch ones cost more nowadays, but consider the amount of labor hours
saved I would have gladly paid todays asking price back then.
Ed Anderson
RV-6A N494BW
Matthews, NC
> Hello all,
> Thanks
Subject: | RV-6 Kit on Ebay |
Here is one for those who are interested...
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1697333492&r=0&t=0&sh
owTutorial=0&ed=1012833868&indexURL=0&rd=1
Darryl DuRossette
RV-3 in many pieces
I used the nav antenna in my Stinson for years for the FM radio - just use a nav
coupler and connect it as if it's another nav radio.
Dave -6, So Cal
LeastDrag93066(at)aol.com wrote:The VOR frequencies are 108 to 118 Mhz. FM
> stations.
> Jim Ayers
Subject: | GPS antenna connector |
My GPS antenna has a screw on type female end. My coax cable has a BNC
female end. How do I connect the two? Is there some fancy male/male
TNC/BNC connector?
Ross Mickey
RV6A
Subject: | Power supply for strobe lights |
Would someone help me understand the advantages and disadvantages of a
separate power supply for each strobe. I want to have three strobes, one on
each wing and one on the rudder. I also plan to have exterior (not wing tip)
antennas on the belly of the fuselage. My two primary objectives are:
1. maximum brightness, and
2. minimum communication interference.
If my antenna leads do not run down my wings but are on the fuselage, do I
need separate strobe power supplies? If yes, do I need three supplies? Are
the systems sold by Van's good? Thanks.
Pete Hunt
RV6 QB - attaching ailerons
N216PH (reserved)
In a message dated 02/02/2002 8:58:31 PM Eastern Standard Time,
JordanGrant(at)bigfoot.com writes:
> The paint
Jordan,
Check to see if the gun has a little vent hole in the cap that's plugged up
with primer.
Hal Benjamin
RV-4, Ailerons
Long Island, NY
Subject: | Paint gun problems |
Jordan,
Not knocking you but, when it comes to paint guns, like everything
else...you get what you pay for!
We've tried those "cheapie" guns in the past for just primer (back
before catalyzed and two-part stuff) and I can tell you...they ain't
worth the hassle to start with IMHO.
With any gun you need to throughly clean it after each use. That
includes breaking it down to clean it.
Smaller guns like the Binks 15 (what harbour Freight's touch up guns are
fashioned after) and simular "touch-up" guns are even more critical
because their ports and nozzles are so much smaller compared to
production guns.
One of the biggest problems with the "Taiwan guns" is they aren't made
that well to start with. The fluid nozzles don't seal well and the air
caps are poorly made. They are just different enough (Copyright Laws)
that none of Binks parts will fit. What your problem sounds like is
several problems combined.
First VariPrime has a pot life of 72 hours. After that it will spray
just as you discribe. It doesn't harden in the cup for days and days.
Another cause could be the fluid nozzle or air cap, or both are not
tight and/or sealing properly. They both work together to create a
pressure differential so the product is drawn up the pick-up tube,
through the fluid nozzle and atomized by the air cap. your pick-up tube
could be occluded too if your not breaking it down and cleaning it.
your local PBE supplier should have a cleaning brush kit to clean you
gun with.
One last thing. You don't need to use expensive MEK to clean you gun.
Ask you PBE guy for some "Wash Thinner". It's a lot cheaper and does a
great job.
My suggestion is get a good gun like the Binks 18 or simular. It's made
for light production and has a nice spread for panel work yet, it can be
"turned down" for small parts without much overspray and still have a
nice pattern. One of ours is nearing 30 years old without any problems
other than a kit every couple of years.
Hope this helps...
Jim D. N708JD
Hi Jordan,
I think I've got the same gun. My problem was that I was trying to use the
gun's paint cup as my mixing cup. Big no-no, it seems. The thick stuff would
go straight to the bottom and the reducer never really mixed properly. I'd
waste half the cup trying to get the mixture to atomize. Some friends of mine
politely told me that I am truly as dumb as I look and that I need to invest
in a separate mixing cup AND a strainer/funnel. $2.50 and a trip to the local
paint supply store later, the gun seems to have healed itself. Operator
error.... gets me every time!
Best regards,
Rod Woodard
RV-3 #11339 under way
In a message dated 2/2/02 6:58:21 PM Mountain Standard Time,
> Thanks guys,
> Jordan Grant
In a message dated 2/2/02 8:58:28 PM Eastern Standard Time,
<< I have a small 'detail' paint gun that I got from Harbor Freight.
Can anyone tell me what is causing this kind of painting problem? >>
I have a small touch up gun too. It experienced a similar problem
(repeatedly), which I traced to a seal in the gun getting dry. Usually, the
problem occurred when I was priming stuff outside in fading sunlight, and had
absolutely no time to spend on fixing spray problems. As it turns out,
vari-prime can be applied using a flashlight for illumination...
If you've got the same gun, unscrew the needle assembly and set the needle
and spring aside. There is a little "cap" that the needle passes through as
it enters the head of the gun. Remove this cap and extract the little cork
seal that fits down inside the cap. Clean the seal with MEK, or your solvent
of choice, then lubricate it with a drop of air tool oil or a smear of
chapstick before reassembing the gun. This entire operation will take about
2 minutes and the gun will work just fine (until the next spray session).
Kyle Boatright
0-320/Aymar Demuth RV-6 Slider
Kennesaw, GA
http://www.angelfire.com/my/rv6
Subject: | flexible fuel line |
I'm using Van's Airflow Performance fuel pump kit that mounts on the
floor. I want to hook up 2 flexible lines to hook up the fuel filter
that mounts beside the pump so when the filter is cleaned I can dismount
the filter to control any fuel spillage. Since I know nothing about
these flexible fuel lines yet--how flexible are they? One of my lines
has to make a 180 deg. turn in about a 4 inch radius. To control cost I
would like to avoid the costly 45 and 90 deg. fittings. Is there one
better hose to use since I see there are nearly a dozen choices of hose
to use?
Dave Ford
RV6
I just fitted these on my 7A and they fit perfectly. On your web page is
that a picture of your right wing? If it is the left wing then you have the
skins on the wrong side. Good luck.
John RV7A Wings.
Subject: Re: RV-List: Wing Skin Fit Problem :-(
there
> some skins...
> Jerry Calvert
> Edmond Ok -6
> From: "Bobby Hester" <bhester(at)apex.net>
> To: "RV-List" ; "RV7and7A"
> > way.
There are two completely different schools of thought on this one.
#1, Keep the engine certified and comply with ALL AD's. Costly, and
contrary to prior belief, not all AD's are issued out of safety concerns.
Yeah, the oil pump impellers were weak on some engines, but if you ask and
"old-time" engine builder who has seen hundreds of them, they will tell you
that they'll easily last 8,000 hours before they need replacing, as does
other parts of the engine. I know I'm going to get flamed for this, but I
used to work for an Aircraft Mfg. (who will remain un-named) who was pushing
for a serious AD on the wood wing spars. Why, not because they were faily
(they had small cracks, but nothing concerning safety of flight) but the
real reason was that this particular Mfg. had the ONLY metal wing you can
buy. No matter what people think, plain old money still drives a lot of
things. That being said, there are still some very serious AD's, especially
on the H2AD that definately must be complied with if you plan on using the
engine very long, however the oil pump AD is not one of them.
#2, Let some AD's expire and make the engine experimental. This is what
I've done with my AEIO-360. Since I'm putting and "experimental" sensenich
prop on it, it makes no difference whether or not the engine is certified.
I still will have 40 hrs. to fly off.
I have complied with the important AD's, but will not be complying with the
Oil Pump AD, as my engine only has 600hrs SNEW, and the original set will
most likely last me until I overhaul the engine, at which time I'll comply
with the AD.
I know I'm walking on thin ice here concerning peoples strong opinions about
AD's, but I've been around the block a few times working with airplanes from
Citabrias to 747's and everything in between. While I by no means know
everything, I DO know that some AD's can be left.
If you can't find anyone to give you a straight answer, I'd be happy to come
inspect your plane for you as I'm an A&P that's current. Contact me off
list and I'd be happy to discuss this issue with you.`
Please remember this is just my humble opinion and should be taken as such.
Each person needs to make up their own mind reagarding AD's, etc.. for
engines installed on experimental aircraft.
Stein Bruch
RV6, Minneapolis
Almost finished with the finish kit.
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bob Blum
and verse? Thanks
Bob Blum
N710EH
and verse? Thanks<
Well well well...
Maybe we can re-start the recent flame war over "airplane" vs "auto" engines
and resale value about now?? How valuable is an Lycoming-equipped aircraft
engine with a bunch of non-complied AD's? Would it be less valuable than a
subaru-equipped airplane? Or, from a buyer's perspective, would it be "more
valuable", yet so expensive to bring into compliance that the extra "value"
evaporates??
Hmmmmm..... Just thinking out loud for the benefit of all you
Lycosaur-lovers out there!
Ed Winne
RV9A (haven't bought an engine yet)
Palmyra PA
I believe the oil pump ad is a reasonable one to comply
with. I have replaced a few and some have not been changed
for previous ad's. You can find a new gear and shaft for around
$235 which will be fine if the housing is compatible and serviceable.
I have done them with the engine on the airplane and it is no big deal.
Of course you will probably be paying for labor.
Stewart RV4 CO.
In a message dated 2/2/2002 6:23:56 PM Pacific Standard Time,
dburton(at)nwlink.com writes:
4 Packing around needle leaking.
Fred (Flintstone) LaForge RV-4 180 cs EAA Tech Counselor in
SO.CAL.
> John RV7A Wings.
> From: "Jerry Calvert" <rv6bldr(at)home.com>
> To:
> there
> > some skins...
> > Jerry Calvert
> > Edmond Ok -6
> > > way.
Yes, it is the right wing! I have double checked to insure I have the correct
skins in the correct positions. I will be going to the hanger again today and
check it out again. Looks like I will be contacting Vans monday on this one I
think the hols are just too far off to try and use. I'll check the bottom skins
today also.
From: | "Nancy and Walter Shipley" <wshipley(at)esper.com> |
Subject: | Lycoming oil impeller AD |
I bought a Lycoming IO-360B4A to which AD96-09-10 applied. In checking with
my mechanic, we discovered this AD references two types of oil impellers -
the first was made of sintered iron, the second was made of aluminum. To
find out which type of impeller you have you need to check your serial
number against the serial numbers outlined in this AD.
My mechanic said he has performed this AD on many O-320 & O-360 engines,
and invariably, the sintered iron impeller showed signs of wear, some of
which were severely worn. He said however, that he had never found an
aluminum impeller with significant wear.
My engine has the aluminum impeller, so I feel I can operate the engine
safely, but resale is certainly an issue to consider.............
FWIW Walt Shipley RV8A Flying soon?
From: | "alisonandneil" <alisonandneil(at)msn.com> |
Subject: | Fuel tank fitting safety |
I'm ready to close up my tanks after doing the inverted fuel system mods.
The question I have is, is there any need to safety the threaded fittings in
the flop tube. I do not want these, or any other fuel fittings fittings to
come apart in flight yet there seems to be no provision to safety these.
Neil
-7 wings
I put some pro seal on these as will as pro sealing in the o-ring on the end
of the pickup.
Carl Froehlich
RV-8A - almost done
Vienna, VA
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of alisonandneil
Subject: RV-List: Fuel tank fitting safety
Neil
-7 wings
Subject: | Speaking of Tank Fittings |
I just finished installing my vent fitting to the inboard tank rib. I used
a washer on each side of the rib which snugged the fitting up nicely in test
fit. After pro sealing and tightening the nut firmly I can rotate the
fitting using a fair amount of finger power. Do you think the fresh pro
seal is acting as a lubricant and will be fine when it sets, or should I
clean it all up and re-inspect while I can?
Jim
-6 tanks
Subject: RE: RV-List: Fuel tank fitting safety
end
> of the pickup.
> Carl Froehlich
> RV-8A - almost done
> Vienna, VA
In a message dated 2/2/02 3:21:56 PM Pacific Standard Time,
rv8pilot(at)hotmail.com writes:
<< Just where can you find Fuel Lube? >>
Aircraft Spruce, page 314 of 2001/2002 catalog (Fuelube, PN 09-25300)
Harry Crosby
In a message dated 2/2/02 4:22:42 PM Pacific Standard Time,
wnorth(at)sdccd.cc.ca.us writes:
<< One final note; Don't trust Vans predrilled alignment. Mine were: left 2
3/4
things measureable. >>
Good explanation, thanks, but I'm left with one nagging question. How did
you fix the above misalignment?
Harry Crosby
Let the pro seal set up. It is wonderful stuff.
Carl.
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jim Larsen
Subject: RV-List: Speaking of Tank Fittings
Jim
-6 tanks
end
> of the pickup.
> Carl Froehlich
> RV-8A - almost done
> Vienna, VA
Subject: | Cowl fit - clearance for paint |
How much gap are you leaving between the upper and lower cowl halves and
beteeen the cowl and fuselage to allow for paint?
Thanks in advance.
-Don
RV8 - NJ
Thanks one and all for the info.
Chris RV8 80881 Slicker fittings from now on.
Festus MO.
Subject: | Re: Paint gun problems |
Thanks to all that replied!
Just before I sent that message, I decided to soak the whole gun in some MEK
overnight to try to get as much of the old Vari-Prime out of it as possible.
Today, after reading the replies, I decided to take it apart and make sure I
cleaned as much of the inside as possible. So far, so good. Unfortunately,
when I went to put it back together, the rubber seals in the gun
disintegrated! They may have been worn out already, but my guess is that the
MEK softened them up and then I finished them off when I tried to stuff it
all back together.
So much for that $20 Harbor Freight spray gun - I don't think finding and
buying new seals for that thing would be worth the time and expense. I guess
I'll go buy a new, fancier one. Anybody know where I can get one of those
Binks guns?
Thanks again,
Jordan Grant
N198G (reserved)
Subject: RV-List: Paint gun problems
> Jordan,
> production guns.
> gun with.
> great job.
> Hope this helps...
> Jim D. N708JD
Jordan,
You found out what I forgot to mention in my last post....they use
cheaper gaskets and seals that degrade when intorduced to MEK or Toulene.
Your best bet for finding a good gun at a fair price is your local PBE
supplier. look in your phone book under Autobody Suppliers or Paint,
Body, and Equipment Suppliers. Places like NAPA and Home Depot
generally have the same or just a little better quality than what Harbor
Freight does.
Also, there are some good less expensive HVLP guns out there, like the
DeVilbliss "Finish Line", that work very well but, they are far more
critical as far as cleaning goes. IMHO I'd say stay with Binks or
DeVilbliss for quality, price, parts, and performance.
Another inexpensive way to properly mix your products is to take a
wooden mixing stick and measure what you think you'll need. Use a ruler
and mark the stick with a ball point pen. VariPrime is a 1:1 Ratio.
The average paint cup is 5" so a full cup of ready to shoot product
would be 2.5" of primer and 2.5" of converter. Just mix what you need
in the cup, stir and shoot. Immediately clean your gun after your done
shooting!
One thing to point out is that ALL the products on the market now are
very "Ratio Critical". That is when they say "One to One" they mean
1:1, not kinda close.
Hope this is helping...
Jim D.
Okay, you guys are an opinionated bunch (and I mean that in the highest
regard (uh huh, right)) and I need some opinions. I have one more hose to
make. It's the oil line that runs from the engine to the oil cooler. The
problem is that I mounted my oil cooler on the firewall about 6-8 inches
from the fitting on the engine. My buddies tell me there is no way to get a
straight hose run from there to the bottom of the oil cooler. Suggestions
are to either make a long loop or else connect it to the top of the oil
cooler and connect the oil return line at the bottom. Any reasons why this
could not be done? Any other suggestions? I'm using Aeroquip 303 hose
w/firesleeve.
Subject: | Re: Oil Hose Help |
Hi Scott,
My "opinion" is if you don't like the idea of a long looped hose move the
oil cooler. The reason a very short hose won't work has to do with engine
movement which will destroy the short line.
As for the oil line attachment top or bottom, look in the archives and go
with the best advice you can get out of Vans or failing that, your nearest
homebuilt friendly aircraft mechanic.
In any case do allow enough length between anything connecting the engine
and firewall keeping in mind engine movement and its effects on such
connections.
Jim in Kelowna
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: RV-List: Oil Hose Help
a
this
> w/firesleeve.
RV7and7A
Subject: | Wing Skin Fit Update |
I update my site with more pictures. I tried the inner top skin on the
other spar and it fit great. So what it boils down to is that the holes
in my RH Frt Spar between ribs 6 and 8 are off location by almost
1/32(too far inboard). I think, if I back drill the holes
from the spar to the skin, it will all work out ok.
Also my mail box messed up today and I lost three message before I could
read them from:
PeterHunt1(at)aol.com, peter decraene, and Agustin Aparicio Ortiz
Please send your message to me again.
RV7and7A
read them from:
Woops! forgot the link:
I have some very very minor dents in my ailerons on top of course. Regardless
I would like to fix. Does anyone know if using Superfil on these thin control
surfaces is advisable? Thanks, Bob
I'm using superfill to fill a few small dings (Ok, they're dents-and I won't
say how they got there, my bucking bar had a mind of it's own for a few
seconds...stupid thing) and mine too are on top of one aileron. As long as
you don't have too think of an application, you'll be fine.
Stein Bruch
RV6, Minneapolis.
Almost ready for a hangar.
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bobpaulo(at)aol.com
Subject: RV-List: aileron dents
Regardless
control
Subject: | Aileron dent PROBLEM SOLVED |
Yes, I solved it. I now am going to order a new skin!!!!
The dents although minor were cased by the dimple die. I used the nail/blind
puller method-small semi circle from die. I thought I would REVERSE or in
other words set the dimple on the opposite side to get the crease out and
reset on the proper (top) side. I have had success a time or two, but not
with this thin a skin. When I tried this the entire dimple popped out. I now
have a 5 to 6/32 hole with no dimple. Yes, give me the dumb a__ __ award for
the month. I thought about going with a larger flush but it will stand out
like a sore thumb-at least to me. Way to big for an oops. Oh well....my wife
told me, "leave it alone your going to make it worse." Another hard lesson
learned. Bob
Subject: | PageMaker prompts you for the filter |
Index codes are imported.
- Dot leaders for indexes, lists, tables of authorities, and table of contents
- Draw objects
- Drop caps
- Equations
- Figures
- Graphics
- Headers and footers
- Inline graphics
- Kerning
- Named character styles
- Overstrike text
- Page and column breaks
- Right hyphenation zones
- Shading
- Sound
- Table of authorities entries
- Text art
- Text created with WordPerfect Fonts/Character sets (Arabic, Cyrillic, Greek,
Hebrew, Japanese, Multinational, Phonetic)
- Watermarks
Files
- Files saved in "WordPerfect 6 Export" format from Macintosh WordPerfect 3.0 or
3.1
- Password-protected WordPerfect files
NOTES
In addition to features not imported, please note the following differences in
formatting and styles after importing a WordPerfect file.
Tabs
- Hard tabs set in WordPerfect are replaced by default tab settings for the line
in which they occur.
Subject: | Re: RV8-List: rear seat rudder pedals |
I would keep the pedals and not install aileron trim. I have rear pedals and
aileron trim (manual).
Stan Mehrhoff
Subject: | Re: How to rivet trim tab spar/skin/hinge? |
On Mon, 4 Feb 2002 Don.Alexander(at)AstenJohnson.com wrote:
> I've gotta ask...
> Is this some sort of diabolical torture test. If we can figure out how to
> close the trim tab out, we win the right to build the wings, right?
> I am using the squeezer with every funky, contrived, jury rig that I can
> come up with to give me clearance over the hinge eyes, yet still allow
> squeezing of the tail. Are there any thoughts on how to do this with only
> two hands?
I am building a -7 but the trim tab is essentially the same. IIRC it
wasn't that much trouble. First remove the extra half of the hinge by
pulling the hinge wire. You should be able to use any of the yokes,
except the flat nose undrilled one. I put the small 1/16" die on the
movable ram of the squeezer. The 1/16" die squeezes the shop head while
the fixed part of the yoke goes on the manufactured head. The ram comes
up nicely behind the rolled part of the hinge and lets you squeeze the
rivet. My 1/16" die is a smaller diameter than the thicker flat dies
and is the same diameter as the ram of my squeezer.
If you need pictures let me know and I will retrieve my trim tab from my
finished parts storage (mother-in-law's garage) and shoot some pictures.
Steve Eberhart
RV-7A - just a whole bunch of aluminum, in various states of attachment,
filling up my half of the garage. Some of it looks like it might belong
on the back end of an airplane. The rest looks like it might, some day,
help hold it up in the air.... but what do I know.
N14SE reserved
Hi fellow RVer's,
I was looking the panel in a Pitt's over the weekend. The color of the
panel was black and looked like it had some
sort of non-skid material applied to it. Does anybody know about this
type of paint and how it is applied?
Gary Gunn,RV-6
Ask Van's. They use the same thing for the RV-7 panel.
Steve
RV-7A
Kingston, Ont
>From: "Gary Gunn" <ggunn(at)qwest.net>
>Subject: RV-List: panel panel
>Date: Mon, 04 Feb 2002 09:20:03 -0700
>Hi fellow RVer's,
>Thanks,
>Gary Gunn,RV-6
Subject: | Re: Power supply for strobe lights |
Hey, Pete: I chose the single power unit for several reasons. I have the
power unit close to the firewall as possible putting the weight forward in
the -4. I have the wing tip lights with red/green and white with the strobe
in one unit. Again, less weight in the tail. I have NO strobe noise with the
lines running with other wires. I guess it comes down to where you want the
units to be. I'm not sure how much the wing tip power units weigh, but that
would be weight in the wing tips rather than in the fuselage. (So? You may
not even notice any effect).
Michael
From: | Mark Schrimmer <mschrimmer(at)pacbell.net> |
Subject: | Sealing fuel tank baffle and skin to end ribs |
"rv-list-matronics.com"
I notice there's a small gap at the top and bottom corners where the skin,
baffle and end ribs of the fuel tanks come together. Do I need to plug this
with a small piece of aluminum, or will Proseal fill the holes when you push
the bafffle into place?
Mark Schrimmer
RV-9A wings
Irvine, CA
Subject: | Re: Sealing fuel tank baffle and skin to end ribs |
I sealed mine with Proseal, then added another coat of it later on after the
first coat cured.
Jim Bower
Haven't leak tested tanks yet (pray for me)
>From: Mark Schrimmer <mschrimmer(at)pacbell.net>
>To: RV-9 List , "rv-list-matronics.com"
>Subject: RV-List: Sealing fuel tank baffle and skin to end ribs
>Date: Mon, 04 Feb 2002 09:23:50 -0800
>push
>Mark Schrimmer
>RV-9A wings
>Irvine, CA
Subject: | RV-6 Engine Cooling |
Hi,
I have a question regarding the air inlet/outlet area
ratio on an RV-6. Here is the configuration:
RV-6
O-360-A1A
3 Blade Wood Prop w/harmonic dampener
Old style polyester resin cowling.
inlet area = 42 square inches
outlet area = 41.5 square inches
The test pilot that might test fly my plane here in the
next couple of weeks insists that I need more outlet
area for proper cooling. He says the proper ratio
should be 1:1.5 - 1:2. Does it seem reasonable to start
enlarge the outlet area prior to the first flight per
his recommendation? He says that all the RV's he has
test flown have needed this modification.
Thank you,
Glenn Gordon
N442E
From: | "F. Parker Thomas" <me(at)parkerthomas.com> |
Subject: | pipe thread adapter |
Hi -
Does anyone know where I could find a fitting with a 5/8 pipe thread on one
end and an 8D AN nipple on the other? My engine came plumbed a little
differently so I'm going to use a different port for the oil cooler return.
ACS had no idea.
Thanks.
Parker
F. Parker Thomas
PO Box 190894
San Francisco, CA 94119
Dear Mark:
Instructions for the -6 say to rivet a small piece of thin aluminum to the
rib web to reduce the size of this space.
John Bright
Newport News, VA
757-886-1161
this
push
> Mark Schrimmer
> RV-9A wings
> Irvine, CA
From: | A&P-IA Bookstore <winterland(at)rkymtnhi.com> |
Subject: | Re: RV-6 Engine Cooling |
Glenn,
Same basic configuration except I've got a 2 blade prop. With a same stock
Van's cowl and baffle kit and firewall mounted oil cooler fed with a 3" scat
tube, mine cools absolutely fine. In fact it cools too well, so that on all
but the hottest days I've got to close off the oil cooler inlet with a
butterfly valve.
Fly it first and see, realizing that if your engine is new, it might take a
couple dozen hours till it starts to cool down. If it's still running hot,
figure out why. There is nothing wrong with Van's cowl design.
Andy
Builder's Bookstore
http://buildersbooks.com
> Hi,
> RV-6
> O-360-A1A
Subject: | Oil hose question |
I didn't see this show up on the list so I am re-posting the question.
I am finishing my RV-4. I have mounted my oil cooler on the firewall.
There is one hose I just can't seem to make fit. It is the hose that brings
the hot oil to the cooler. The two fittings are approx. 8 inches from one
another. A mechanic friend tells me that there is no good way to get a hose
in there. Either it will have to be very long or we'll have to use some
weird fittings which will involve removing my spin-on filter adapter. I
think it may work if I reverse the connections to the oil cooler. I have it
mounted vertically and had hot oil going in the bottom and out the top.
Would there be any problems reversing them as I think I'll get a better hose
run. C'mon I know you guys are an opinionated bunch, let me have some
opinions!
Should have mounted it like yours, Larry. :-)
Scott VanArtsdalen, MCSE, CCNA
Network Administrator
Union Safe Deposit Bank
209-946-5116
Gary,
I believe that type of paint is referred to as "wrinkle finish" My father
used it in his AcroSport Biplane on his panel. Absolutely no glare. I have
seen it in a few rv's and others at Oshkosh. It should be available at any
automotive store. You spray it on and then bake it in an oven to get it to
wrinkle if I remember correctly.
Doug Bell
8 qb, Manistee, Mi
----- Original Message -----
> Hi fellow RVer's,
> Thanks,
> Gary Gunn,RV-6
Subject: | Re: pipe thread adapter |
Dear Parker:
To my knowledge there is no 5/8 NPT thread. Pipes are called out by nominal
ID.
Nominal ID - OD
1/16 - 0.3125
1/8 - 0.405
1/4 - 0.540
3/8 - 0.675
1/2 - 0.84
and on up
Maybe you have 3/8 pipe.
John Bright
Newport News, VA
757-886-1161
> Does anyone know where I could find a fitting with a 5/8 pipe thread...
Folks,
Chapter and Verse
There is nothing in CFR14 Part 39 that exempts experimentals from
Airworthiness Directives, nor will there ever be. If it has a data plate
then the AD that specifies that data plate must be complied with as
described in the specific AD. If it has no data plate then it is difficult
to apply the AD as you don't know what the engine is. Even then, they can
issue the AD against the specific aircraft if there is reasonable cause to
believe a dangerous condition exists.
There have even been AD's directly issued against one line of Experimentals
using a specific engine regardless of whether the data plate was still
intact.
ADs can also be issued against individuals and FBOs as well. They are the
FAA's Big Hammer, to be used in the event that a dangerous condition exists.
And they can be issued against anything Aviation. And yes, the FAA has
abused this all encompassing power, but it hasn't happened very often.
The oil pump AD was a total bust for Lycoming, They decided to fix something
that didn't need fixing, then it did need fixing, then the unneeded fix's
fix needed fixing, and now they are mostly back to where they started. As of
mid last year all engines that incorporated these parts have to comply with
the AD. It will require a new oil pump housing, new gears and a drill hole
in the accessory case. If you're really good the old housing can have the
idler gear shaft pushed out and be machined .003" over so that the new shaft
that is now a part of the floating gear can spin freely. As far as I can
tell that's the only difference between the old and the new housings.
Generally most ADs that are issued are in response to the manufacturer's
findings. The FAA doesn't have the ability to keep up with every part of
every airplane, and the manufacturers are motivated to rat themselves out or
else face severe civil litigation issues.
But mostly I would consider that peace of mind while flying is worth a whole
lot more than the cost of complying with these ADs.
thx
Wheeler
IA, A&P Instructor
I used the "crinkle paint" from a auto paint store on my panel. It didn't
need an oven but there were temperature limits on the can. I sat my panel
after spraying in the summer sunlight here in the desert and it worked fine.
However, I seem to remember a test not working properly as the temperature
was a little low.
Tom Gummo
Apple Valley, CA
Subject: Re: RV-List: panel panel
> Gary,
have
any
to
> Doug Bell
> 8 qb, Manistee, Mi
> From: Gary Gunn <ggunn(at)qwest.net>
> To:
> > Hi fellow RVer's,
> > Thanks,
> > Gary Gunn,RV-6
My friend used wrinkle paint out of a rattle can no baking needed. Came out
good.
you can see his pane in Van's 2002 calendar March.
Scott,
You can plumb the oil cooler whichever way works best for you. The cooler
doesn't care which way the oil flows through it. There are "some" people
who believe that it must flow from bottom to top in order to remove air,
etc... but in reality it just doesn't matter that much. There is air in all
over in that engine, and the oil cooler doesn't act as an "air remover" as
some may lead you to believe.
Anyway, plumb it whichever way works best for your install.
Stein Bruch, A&P
RV6, MSP
Almost ready for the hgr.
opinions!
209-946-5116
Gary, It's called wrinkle finish and can be mixed in any color at automotive
stores. You just spray it on like any other spray paint. As it dries it
dries to a wrinkle finish. It does not have to be baked or any other
special treatment.
Jim Streit
90073 wings
Gary Gunn wrote:
> Hi fellow RVer's,
> Thanks,
> Gary Gunn,RV-6
I had no trouble squeezing those rivets either, I don't remember which yoke
I used though. Put the wire back in the side you are riveting after taking
the halves apart to help avoid damage.
Neil
Subject: Re: RV-List: How to rivet trim tab spar/skin/hinge?
> > I've gotta ask...
to
only
> > two hands?
> Steve Eberhart
> N14SE reserved
Subject: | Antenna placement, flip up canopy water seal |
Hi,
I would like some info in two areas,
I am planning on mounting two com antennas in line under the fuselage
center. How close to the exhaust area would be OK. It seems that some
exhaust heat might be helpful to prevent ice accumulation if one
would blunder into icing. I would not want excess heat to affect the
antennas however. Any experience on his?
Does anyone have a positive method of sealing the forward edge of the
flip up canopy to prevent water leakage into the cockpit,
particularly into the avionics?
> > > > > 1. I've smoked fatter joints than that.
> > > > > 2. Ahhhh, it's cute.
> > > > > 3. Why don't we just cuddle?
> > > > > 4. You know they have surgery to fix that.
> > > > > 5. Make it dance.
> > > > > 6. Can I paint a smiley face on it?
> > > > > 7. Wow, and your feet are so big.
> > > > > 8. It's OK, we'll work around it.
> > > > > 9. Will it squeak if I squeeze it?
> > > > > 10. Oh no... a flash headache.
> > > > > 11. (giggle and point)
> > > > > 12. Can I be honest with you?
> > > > > 13. How sweet, you brought incense.
> > > > > 14. This explains your car.
> > > > > 15. Maybe if we water it, it'll grow.
> > > > > 16. Why is God punishing me?
> > > > 17. At least this won't take long.
> > > > > 18. I never saw one like that before.
> > > > > 19. But it still works, right?
> > > > > 20. It looks so unused.
> > > > > 21. Maybe it looks better in natural light.
> > > > > 22. Why don't we skip right to the cigarettes?
> > > > > 23. Are you cold?
> > > > > 24. If you get me real drunk first.
> > > > > 25. Is that an optical illusion?
> > > > > 26. What is that?
> > > > > 27. It's a good thing you have so many other talents.
> > > > > 28. Does it come with an air pump?
> > > > > 29. So this is why you're supposed to judge people on personality.
> > > > > 30. I guess this makes me the early bird.
Subject: | Re: Oil hose question |
Scott:
My Aerosport 0-360 (non-flying RV-4) has a 45 degree steel fitting at the
"oil out to the cooler" port. The "oil in from the cooler" port is just to
the left and down from the breather outlet. My flying RV-4 (AEIO-360) also
is plumbed this way. I don't really see a problem in running hoses (I have
an oil filter adapter on both airplanes). According to Lycoming's book, it
is also permissible to use the port immediately below the breather port as a
"oil out to the cooler" port. A big issue with the RV-4 in the winter here
in MN/WI is trying to keep the oil temp up. I have my oil cooler blocked
off entirely and yet still only get around 140 degrees oil temp on a below
freezing day. A local RV-6 pilot has his oil lines plumbed using the
"outlet to the cooler" port below the breather. His oil temps stay right at
160-180 regardless of OAT and his cooler is not blocked at all. He claims
this routing allows oil temp to be better controlled by the veri-therm.
Don't know, but it seems to work for him.
Doug Weiler
MN Wing
From: | "Craig Chipley" <craigchipley(at)hotmail.com> |
Black wrinkle finish in a spray can
>Hi fellow RVer's,
>Thanks,
>Gary Gunn,RV-6
From: | "Bill and Joy Mosley, Mosley Living Trust, NABA, Inc." <mosley(at)sedona.net> |
Subject: | Re: RV6-List: Antenna placement, flip up canopy water seal |
George,
I've had excellent success with Van's stick on antenna. I have one on the
wind screen for com and another behind the roll bar for the ELT. Why would
you want all that drag from externals.
I had a leak on my tip up. I had installed the weather-strip on the fuselage
only. When I put another on the canopy, so the front of one touch the rear
edge of the other, the leak stopped. Give it a try.
Subject: | Re: Antenna placement, flip up canopy water seal |
George,
In addition to a good quality seal on the canopy, I fabricated a marine
canvas cover that covers the entire top of the instrument panel. It velcros
to the back of the instrument panel and to the sub panel. It also velcros to
the top of the longerons. Should any water get by the seal, or when opening
the canopy in the rain, the canvas will stop it. Also looks good, and covers
all the wiring and plumbing behind the panel. Canvas is available in just
about any color you want.
Bill Mahoney
Sherman, CT
RV-6 N747W
Subject: | new RV Story video update |
To the 70 (+/-) people who gave a $50 or more donation to this list during the
recent annual fund raiser, and are anxiously awaiting your "thank you" copy of
the
promissed RV Story video.
According to Van's a few days ago, it will be available in 2-3 weeks. At this
point, labels are made, boxes are prepared, and the new videos will go out to you
the day they arrive.
For anybody who did not get a chance to participate in the fundraiser but who
still wants one of the new videos, they are now also available for pre-order on
Builders Bookstore on the "Van's RV Specific" page, also to be shipped in 2-3
weeks.
Andy
Builder's Bookstore
http://www.buildersbooks.com
eCharts
http://eCharts.cc
From: | George Kilpatrick <aeronut58(at)yahoo.com> |
Scott:
The cooler will work fine with the hoses reversed.
George
N888GK
Flying
--- "Van Artsdalen, Scott"
wrote:
> Scott"
> opinions!
> 209-946-5116
> Contributions of
> any other form
> latest messages.
> other List members.
> http://www.matronics.com/photoshare
Subject: | Electric Flaps RV-4 installation drawings wanted. |
Evening all,
This RV building is a bit like playing with dominos!!
I installed underfloor lockers, then got hold of a Century 1 autopilot. The servo
fitted best on the left side of the fuselage due to the lockers. I next got
a good deal on a pair of infinity grips, with you've guessed it - auto-pilot
interrupt, but also a tempting set of electric flap and trim switches. Having
got another good deal on a trim servo (thanks Stein!) I am doing my wn take on
the Gretz manual to electric trim conversion. (The local CableCraft was able
to use the original trim cable to make several shorter cables).
NOW - the problem...... The push rod for the autopilot servo runs right through
where the electric flap actuator needs to be (normally that is!!) I have figured
out that a RV-6 actuator will work on the right hand side of the fuselage
allowing mirror image linkages to operate the flaps. I have installed the structure
to hold the motor end of the actuator ,using a RV-6 builder friends actuator
to check that the motor does not interfere with the torque tube, etc.
So far so good - BUT - trying to work out the appropriate linkages an so forth
to connect to the flap system, and the size and position for the arm to have my
tame welder put on the flap weldment is doing my head in !!
Please, please if anyone has a copy of the drawings for the RV-4 electric flap
conversion could you please contact me off-list at " jakent(at)unison.ie ".
Also , you may have guessed, I am in the market for a RV-6 electric flap actuator
- any offers??
Thanks ... John Kent (getting a little "off piste" (think about it!) with these
modifications! )
5/32" and if you are really anal, turn the head down to the 1/8 size.
Subject: | Re: Electric Flaps RV-4 installation drawings wanted. |
Hi John,
What about doing some 360's on the Airport roundabout on Monday and think of
a better solution for the sparks under the floor.........
Checked the ad's no luck sofar. The 1800 is a bit steep and I don't want to
spend that type of money before the garage goes up.
The pulsar is coming along nicely, just to sand the aft lower fuse tomorrow
and she'll be ready for paint. I was able to rent a spraybooth for 70/day
at the Tech where I'm doing the brickie course.
Missed out on the ma4-5 carb that was on the rv-list, sold before I could
contact your man. real shame too, 75 hrs TTSN.
Marcel
p.s have to come up soon to see your progress and paint interior?
From: | "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> |
Jordan, I have 2 Binks Guns and love both of them, MG-1 and MACH 1 HVLP
Pressure Feed and pot for painting upside down (Bottom of fuselage).
Contact Ron at 910-330-2901 in NC or go to his WebSite
www.discountautobodysupply.com for the best prices I know of and quick
service. If you don't see the model you want call him as he can get anything
you want. I have done a lot of auto restorations and Ron has always been an
honest guy to ask any paint related questions.
Tom in Ohio
Subject: Re: RV-List: Paint gun problems
MEK
possible.
I
the
> all back together.
guess
> Binks guns?
> Thanks again,
> Jordan Grant
> N198G (reserved)
> From: "Jim Duckett" <perfeng(at)3rivers.net>
> To:
> > Jordan,
> > production guns.
> > gun with.
> > great job.
> > Hope this helps...
> > Jim D. N708JD
Subject: | training at Lycoming |
Hi Listers,
Has anyone done any of the courses offered by Lycoming at Penn College?
Is/are the course(s) useful?
other comments?
Marcel
Subject: | RE: RV8-List: rear seat rudder pedals |
I disagree about the aileron trim. I have electric and use it on every
flight.
Greg Miller
RV8 N89GM
-----Original Message-----
[mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of N188rv(at)aol.com
Subject: Re: RV8-List: rear seat rudder pedals
--> RV8-List message posted by: N188rv(at)aol.com
and
Stan Mehrhoff
From: | Emmanuelle Richard <frenchflyer21(at)yahoo.com> |
My RV4 needs a canopy cover. What types are
available? Pro/cons? Thanks.
Subject: | Prop considerations |
Hi guys,
I have pretty much made up my mind to buy a metal sensenich, and still
probably will...but. Some little bird has been nagging at me to look at
either a 2 or 3 bladed wood or composite "catto, prince, warnke, etc.." type
prop.
Can anyone who has used any of the above or both send me some comments
either way???
I have a 180 h.p. IO-360, so please only those with a similar engine
respond.
Thanks in advance,
Stein Bruch
RV6, MSP
Almost finished :)
When you have about a 5/8" Hole it is for 1/2" pipe as the pipe is sized by
the ID not the OD.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Always looking for articles for the Experimenter
Subject: Re: RV-List: pipe thread adapter
Dear Parker:
ID.
Nominal ID - OD
1/16 - 0.3125
1/8 - 0.405
1/4 - 0.540
3/8 - 0.675
1/2 - 0.84
and on up
John Bright
Newport News, VA
757-886-1161
From: | Robert McCallum <robert.mccallum2(at)sympatico.ca> |
Parker;
There is no such thing as a 5/8" pipe thread. If it physically measures approximately
5/8" OD then
it is a 3/8" pipe thread and the fitting you require should be readily available
from all the usual
sources such as Aircraft Spruce or whomever you personally favour. You probably
threw them with the
5/8" pipe size. Pipe threads are measured by "nominal pipe size" a figure which
bears no physical
relationship to any actual dimension on the pipe. It is an approximation of the
inside diameter. (It
was the actual inside diameter years ago when the system was invented and pipe
was made out of iron.
Modern materials being stronger has allowed the manufacturers to make the ID larger
but they had to
retain the original OD and thread to remain compatible with older existing systems.)(
Hope this is
slightly clearer than mud)
Good Luck
Bob McC
"F. Parker Thomas" wrote:
> Hi -
> ACS had no idea.
> Thanks.
> Parker
Gary,
Wrinkle paint is available in spray cans at auto supply stores. It has to be
applied very heavy and allowed to air dry. If there are any light spots,
those spots will not wrinkle. Consider that if you use this, you will not be
able to use the transparent labels such as Casio or Brother to identify
switches, etc.
Bill RV-8 Tiger-Kat
> Hi fellow RVer's,
> Thanks,
> Gary Gunn,RV-6
I'm not a IA or A&P, nor did I spend last night at Holiday Inn (or
whatever) BUT did spend 20+ years as plumbing and A/C contractor. The key
words in sizing pipe are Pipe & Tube. Back in the old days pipe was threaded
and made of thick walled materials, some one came up with the idea of a
"standard". The inside diameter (ID) was stated in (nominal) inches and
varied with the thickness of the material used. BUT the OD was the same size
so a single set of pipe dies could be used to cut "standard" threads.
Copper "pipe" comes in various wall thickness M, L,K and hardness. The
fittings for copper are type "L" BUT fit all three because the OD is the
same. Copper "Tube" size is OD and used mainly in Air Conditioning, brake
lines, medical piping etc.
Bottom line: 1/2" NPT "pipe" is closer to 7/8" OD (before the tapered
threads) BUT is called 1/2". You will run into the same type of problem when
you try converting from pipe threads to plastic/aluminum/copper tube ("Tube"
size). Your 5/8" OD threads are 3/8 NPT (National Pipe Thread). Do Not
Acrhive KABONG
by
> the ID not the OD.
> From: "John Bright" <john.bright(at)bigfoot.com>
> To:
> Dear Parker:
nominal
> ID.
> Nominal ID - OD
> 1/16 - 0.3125
> 1/8 - 0.405
> 1/4 - 0.540
> 3/8 - 0.675
> 1/2 - 0.84
> and on up
> John Bright
> Newport News, VA
> 757-886-1161
Subject: | Re: tools for sale |
Hey, they're here! looks nice, I'll try them out tomorrow. I'm gonna'
hafta' build another plane now. thanks, Kevin
From: | "Richard D. Fogerson" <rickf(at)velocitus.net> |
Subject: | Engine Plenum - Great Idea or Big Hassle? |
I have seen some people installing aluminum and fiberglass plenums for
engine cooling rather than the standard baffle system. This looks
interesting to me from an esthetic and efficiency standpoint but
something bothers me about it. You must remove it in addition to the
cowl to see or get to the top of the engine.
How long does that take to remove?
Do you consider that to be a big hassle?
Does it concern you about not being able to see the engine without
removing it?
Lastly, would you do it if you had it to do over again and why?
I would appreciate your responses as I am considering doing this but
don't want to invest the time if I'm going to reqret it later. Thanks,
Rick Fogerson, RV3 wings, Boise, ID.
From: | "Clark, Thomas IFC" <Tom.Clark(at)UTCFuelCells.com> |
Seattle area builders,
I will be at Boeing the week of the 11th and was wondering if there is any
local -8 builders in the later stages of construction that would like visit
from someone at a similar state. We can trade this is what I was thinking
stories!! I will be bored in a hotel Monday through Thurs. night.
Tom Clark
RV-8 Fastback
Subject: | Help with Van's horizontal air induction system |
This question is for those using Van's horizontal air induction system
that takes engine air from in front of the #2 cylinder. Van's says it's
okay to take engine air and oil cooling air both from the left side of
the engine. Are any of you doing that and is there no significant
difference in cooling from the left vs the right cylinders?
Thanks, Rick Fogerson
RV3 Wings
Boise, ID
Sorry, I misspoke, looking at my manual it is NOT 1/2 pipe but 3/8" pipe.
the ID not the OD.
Dear Parker:
ID.
Nominal ID - OD
1/16 - 0.3125
1/8 - 0.405
1/4 - 0.540
3/8 - 0.675
1/2 - 0.84
and on up
John Bright
Newport News, VA
757-886-1161
the ID not the OD.
Dear Parker:
ID.
Nominal ID - OD
1/16 - 0.3125
1/8 - 0.405
1/4 - 0.540
3/8 - 0.675
1/2 - 0.84
and on up
John Bright
Newport News, VA
757-886-1161
From: | Carroll Bird <catbird(at)taylorelectric.com> |
Subject: | Re: canopy cover |
I got mine from Becki Orndorff. works very nice. Carroll Bird RV-4, 200 Hrs
Subject: | Super Sound Proofing Request |
Hello,
I am finally at the stage where I can do something besides rivet
aluminum. I am going to order the Super Sound Proofing in my RV-8 and
would appreciate some input from anyone who has installed it.
Specifically, how much and what kind of the stuff to order and if it
really worked!
Vince Himsl
RV-8 SB Canoe
Moscow, ID USA
Subject: | RV Finder (web tool) |
Ok, it was only a matter of time before I broke down and built this:
http://www.rvproject.com:8000/rvfinder.jsp
Enter your zip code, select a radius, and you can find all the registered
RVs of various types that are located nearby.
Enjoy!
)_( Dan
dan(at)rvproject.com
Subject: | Re: coupling Garmin handheld to a Garmin panel mount |
Although I don't have a 300XL IFR, I do have two Garmin 195 GPSs that I link together
on a regular basis. I have one panel mounted and one on a clip on mount
that I use to do my flight planning and then upload the flight plan to my panel
mounted GPS for my flight. I have been using this for the past few months
and I love it. As cheep as used 195s are getting it's really nice to have access
to both a moving map and a big HSI at the same time.
If my memory serves me right, I used the universal data cable with the Garmin 195
connector on one end and just loose wires on the other end. I hooked up power
and ground and swapped the data transmit and receive so the units could talk
to each other.
The software end is even easier. Just put one unit in the slave mode and use
the other units software menu to send or receive data from the slave. It's easy
and at 9600 baud it works pretty fast.
- Jim Andrews
RV-8A ( Flying and loving it )
On Sun, 27 Jan 2002 10:17:43
Robin Wessel wrote:
>Listers-
>Reading the manual for my Garmin 300XL IFR gps I noticed that it supports
>the slaving of a Garmin aviation handheld. Apparently entering a route and
>goto command only has to be entered from the panel mount. I am considering
>buying a 195 or a Pilot III to add some additional situational awareness as
>well as have an excuse to buy another toy.
>Does anyone have any experience as to how well this works?
>thanks,
>robin wessel
>RV-6A Tigard, OR- 85 hours
From: | "Jim Norman" <jnorman(at)intermapsystems.com> |
I've posted on this subject before. As one of those with a fiberglass
(actually carbon fiber) plenum, I would not do it again. I would make a
plenum, but I would make it out of aluminum rather than glass. Too much of
a hassle.
Jim
Tampa.
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Richard D.
Fogerson
Subject: RV-List: Engine Plenum - Great Idea or Big Hassle?
removing it?
Subject: | Re: Engine Plenum - Great Idea or Big Hassle? |
Mine takes about 90 seconds. It is attached at the front with 4 screws and
attached at the back and two sides with hinges. I take out four screws,
pull
four pieces of hinge pin and its off. Mine is aluminum not fiberglass.
No.
> removing it?
No.
Yes. For the same reason I did it in the first place. Efficiency and
reduction of pressure inside the top cowl. And as someone pointed out, it
is a great place to put my wiring supplies as I wade through miles of white
spaghetti.
Ross Mickey
RV6A
N9PT
Subject: | Re: RV Finder (web tool) |
From: | Denis Walsh <deniswalsh(at)earthlink.net> |
Totally Awesome. Works great. Looks good.
Thanks.
Denis
Depends on the method of attaching it
YES
> removing it?
No, not much to see.
No. I can see no gain in the installation I currently have (metal).
I see from the current RVator that the new RV-8 empennage kits are "as
prepunched as the RV-7 and RV-9" kits. That's nice for the empennage
builder, but what about the wings and fuselage? Has anyone received a recent
RV-8 wing or fuselage kit? I understood that the wing and fuselage skins
were pre-punched, but are the wing ribs and fuselage bulkheads/firewall also
computer-matched and pre-punched?
Steve Soule
Huntington, Vermont
Got mine from DJ Lauretson at Cleveland Tools. It works well, fits well and
protects the canopy. I am not familiar with the others enough to make a
comparison, however, but DJ does nice work on everything, including
interiors.
Michael
This is awesome!
What database are you pulling off of? I ask because several local
registered RV's that I know of don't show up.
Rob Acker (RV-6).
> registered RVs of various types that are located nearby.
> Enjoy!
> )_( Dan
SoCAL-RVlist(at)yahoogroups.com
Hi Dan,
So when's the international version coming out? Ya never know some of you yanks
might want to come done and visit some of us Aussies on day!!
Looks cool!
rv7-list(at)matronics.com; SoCAL-RVlist(at)yahoogroups.com
Subject: RV-List: RV Finder (web tool)
Enjoy!
)_( Dan
Geeez Steve... The next thing you'll want is for all the parts to actually
FIT...
anonymous (and envious) RV-4 manufacturer
Subject: RV-List: New RV-8 kits
recent
also
> Steve Soule
> Huntington, Vermont
Rick,
I built mine out of Van's stock baffle kit, one sheet of #40 aluminum for the cap,
and some stiffners for the attachment points. Screws all the way around for
a nice tight fit. Takes about 5 minutes to remove with an electric screw driver.
Not a big deal since the top of my cowl takes that long to remove. During
preflight I can see a lot of the number 1 and 2 cylinders through the air
inlets so if I'm throwing oil or some obvious problem, I will catch it. I also
painted it inside and out with high temperature white paint to help show off
any problems in a hurry.
I have found that oil temps are rock solid 180 to 185. By having all that air
contained instead of blowing against the top of your cowl, you are relieving a
ton of stress on all the attach points of your cowl and oil filler door. There
are none of the blow by issues to deal with that you normally have with conventional
baffle seal.
Did it take longer? Yes. About twice as long.
Was it worth it? Would I do it again? Definitely!
It's a better design, there's no question about that. I'm sure if folks could
order one right out of Van's catalog, it would be a big seller.
- Jim Andrews
RV-8A ( see my pics at rv8a(at)tripod.com )
On Mon, 4 Feb 2002 21:43:04
>removing it?
The -7 and -8 wings are identical and are both match drilled now...
-Bill
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of C. Rabaut
Subject: Fw: RV-List: New RV-8 kits
actually FIT...
recent
> skins were pre-punched, but are the wing ribs and fuselage
> bulkheads/firewall
also
> Steve Soule
> Huntington, Vermont
I just implemented a fix...it used to only recognize models that had dashes,
like "RV-6". Now it'll recognize those registered without the dash as well,
like "RV6".
Should be good to go now.
At some point I'll also add a mode where you can opt to wait MUCH LONGER and
get results from all states, not just the same one as the location you
enter. That way, if you live close to a state border you're not hosed.
Unfortunately, it cranks the query time way up...to about 4-5 minutes.
)_( Dan
Subject: Re: RV-List: RV Finder (web tool)
> This is awesome!
> Rob Acker (RV-6).
> > Enjoy!
> > )_( Dan
Subject: | Re: Seattle Visit |
In a message dated 2/5/2002 7:44:32 AM Pacific Standard Time,
Tom.Clark(at)UTCFuelCells.com writes:
<< Seattle area builders,
from someone at a similar state. >>
I live in Kent (south of the Boeing Field) and finishing the fuse on an RV9A.
I realize that it is NOT an RV8, but I think you will see my RV9 and wish
you had one too! I would be happy to have you visit to swap construction
lies and make airplane noises if an RV8 offer does not come along.
Kim Nicholas
Subject: | More cowl camlock questions |
Fellow Listers:
I am in the process of installing my new S glass cowling for my -4 (this is
the second time around having trashed the old polyester cowl).
I have decided to use Camlocks on the top cowl to firewall and at the
longitudinal cowling split line) but I have not purchased them yet. For
those that have done this, what camlock series did you use (the Skybolt kit
is rather pricey at $300)? The choices are the 2700 series or the 4002
series. Can the 2700 series be used on the relatively thin S glass cowl
(the S glass is .040 thick). Or must you use the 4002 series which require
a grommet. Can the S glass be countersunk successfully for either
installation (since it is thinner than the poly) or did you have to resort
to the "plus flush" type of grommet for the 4002 series.
Hope all this makes sense.
Doug Weiler
MN Wing
> what about those of us who registered our planes with a space in between
the
> V and the number... like "RV 6". Will you recognize those as well as the
> ones registered with no space or a dash?
A lot of people have been asking about different patterns of model numbers.
If there are any uber-geeks out there (I'm not pointing fingers) who might
want to help enhance this tools ability to recognize RV model number
patterns, here's the regular expression I'm using:
.*RV[-[:space:]]?[[:digit:]]+(A)?.*
It now supports missing dashes, using a space instead of a dash, etc. If
anybody has suggestions on how to improve that, just let me know.
)_( Dan
Sure enough, I looked up the "missing" RV's and they did not have
the "normal" model number. One was RV6-A instead of RV-6A, etc.
> dashes, like "RV-6". Now it'll recognize those registered without the
> dash as well, like "RV6".
Subject: | Re: More cowl camlock questions |
Doug,
There is a page on my web site that lists part numbers and all...
http://www.rv-8.com/Cowl.htm
Go to the "Cowl fasteners" section on that page. The Skybolt version of the
4002 series Camlocks is the only way to go.
Randy Lervold
RV-8 #80500, 143.5 hrs
www.rv-8.com
Home Wing
> Fellow Listers:
is
kit
require
> Thanks
> Doug Weiler
> MN Wing
> removing it?
Rick,
I did a fiberglass plenum on my RV-8. The plenum, in combiination with my
cowl, was a lot of extra work. If I had it to do over again I not do it this
way. I would still do the plenum, because I think the benefits are worth it,
but with the standard cowl inlets. You can see my installation at...
BTW, the slickest plenum I've seen as used with a standard cowl is Gary
Zilik's installation on his RV-6.
http://www.geocities.com/CapeCanaveral/Hangar/5379/index.html
Look on the Firewall forward page.
Randy Lervold
Home Wing
98% or more completed from quick build...painted....extra canopy...rear
rudder peds...VFR day....0320..SMOH...160hp....new C/S prop...NO PIX,
sorry....new upholstry...vettermann
exhaust...Com11B....transpond......rocket gear fairings...$65,000
jollyd(at)ipns.com
Thanks Bill,
That seems like a great simple solution to prevent canopy leakage.
I'm glad I asked.
I did get previous feed back from a request about the use of internal
com antennas and got a very strong negative response about garbled
transmissions using internal antennas. What has been your experience
and did you do something to prevent this. Low drag and elimination of
icing problems does seem like a very good idea if I can make it work
reliably.
George
--- Larry Bowen wrote:
> How do I get to the pics through the email address?
That was Jim's mistake, Larry. You can get to his site through Van's
links, or straight to it from here:
http://rv8a.tripod.com/engine.html
Jim is a local builder (now flyer) and his work is just great!
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Firewall Forward
http://greetings.yahoo.com
I would endorse the negative responses to the Tape type antenna on the
canopy. A friend was using one from Van's in a tip up canopy 6 and it was
hopeless. Very short range in most directions (like 500 yards in some, air
to air) also difficult to copy him at times. Replaced with bottom mounted
and all OK now. Some antennas come with a graph showing drag at various
speeds. It is obviously supplied for very high speed aircraft as the drag at
our speeds is very small. FWIW Regards, Brian
> reliably.
> George
A textured powder coat will give you this effect.
Rick Jory (RV8A)
> Hi fellow RVer's,
> Thanks,
> Gary Gunn,RV-6
From: | "Ken Stribling" <bbattery(at)bendcable.com> |
Subject: | Re: Super Sound Proofing Request |
Check out Soundsuckers .com for sound proofing foams and pads, Talk to
Gretchen
Subject: RV-List: Super Sound Proofing Request
> Hello,
> really worked!
> Thanks,
> Vince Himsl
> RV-8 SB Canoe
> Moscow, ID USA
Subject: | Mag compass in panel? |
I'm messing around trying to freeze the design of the instrument
panel on my RV-8. My preferred layout has the magnetic compass in
the panel, rather than on top of the glareshield (I want my g-meter
on top of the glareshield). The compass will be one hole down and
right from the DG (which is electric), and just to the left of the
Grand Rapids EIS engine monitor. You can see a poor quality
rendition of my proposed layout at:
<http://eccentrix.com/misc/rv8/finishing_kit/fk05.html>.
I'm wondering whether I have much chance to make this work, or
whether I will probably run into problems getting the compass swung
OK. I would love to hear from people who have a compass in the panel
- how did the compass swing go? What type of compass do you have?
What electrically powered stuff is in the vicinity of your compass.
Yes, I have wondered how much I will actually use the compass, given
I've got a GPS. But, I guess I'm an old fashioned kind of guy, and I
still hope to get the compass swung reasonably close.
Kevin Horton RV-8 (installing engine & electrics)
Ottawa, Canada
http://eccentrix.com/misc/rv8/rv8.html
George,
I simply installed the antenna according to the instructions. Van says to
install the $7 foil antenna on the windscreen soldered to a bulkhead fitting
just above the glare shield. The foil runs vertically up the Plexiglas and
wraps around the top side. I tried to attach the foil inside the nose wheel
fairing with no success. Van says they receive and transmit clear signals up
to 100 miles, that's my experience also. What more can you ask. Refer to the
antenna article in the October '93 RV ATOR. My GPS antenna is mounted on the
glare shield and works just fine, I don't use a VOR, if I did I would run
the foil (or a 1/2 by 22" piece of aluminum) horizontally on the bottom of
the Cowl. If I were doing it again, I would even try mounting the
transponder antenna inside of the cowl.
Subject: | Re: RV8-List: Mag compass in panel? |
Mine is mounted in the upper right part of the panel and has almost no
deviation.
Bryan Jones -8
Pearland, Texas
Join the worlds largest e-mail service with MSN Hotmail.
http://www.hotmail.com
Subject: | Re: Mag compass in panel? |
In a message dated 2/5/02 10:04:26 PM Eastern Standard Time,
khorton(at)cyberus.ca writes:
<< I'm wondering whether I have much chance to make this work, or
What electrically powered stuff is in the vicinity of your compass. >>
My Compass is in the panel adjacent to my electric turn coordinator. I was
able to successfully swing the compass in the N/S axis, but I'm not
particularly happy with the results on the E/W axis - I've probably got a 20
degree inaccuracy. I don't find this to be a big problem, and my only other
nav devices are eyeballs, a map, and a handheld GPS I use infrequently.
If you look in the archives, you'll see some advise on how to manage
electronic interference. I think Electric Bob (Bob Nuckolls w/ the
Aeroelectric Connection) has posted on this several times.
Kyle Boatright
Kennesaw, GA
Doug;
I followed Randy's lead and installed Skybolt camlocks on the firewall end
only. You can't install them on the split lines (at least on the 8) because
the new cowls are so stiff. Only countersinking required is on the .062
aluminum. I like the fasteners, but Skybolt has some problems with their
kit, namely they don't come with any instructions and some of the supplied
templates are useless. They have instructions on their website, but they
are incorrect for their new fasterners. Their sales director had no idea
they were shipping kits without instructions, so I don't think they have any
internal communications.
Mike Robbins
RV8Q 80591 N88MJ engine baffles
Subject: RV-List: Mag compass in panel?
> Thanks,
> Ottawa, Canada
Kevin,
I don't know what type engine instruments you may be planning to use.
However, their are apparently air core and iron core types. The iron core
types have strong permanent magnets in them (they are also cheaper in cost).
I liked the instruments and installed them which ruled out placing the
Whiskey compass any where near them. In fact its over on the right side of
my RV-6 panel. I now have one of the new $50 electronic (interference
compensating) compasses which is stuck to my windscreen.
The point being if you are considering putting your compass in your panel
make certain your engine instruments are not "iron" core but the "air" core
type. FWIW
Ed Anderson
Subject: | More speed, more features |
Unfortunately I'm not talking about an RV...
But I am talking about the RV finder web tool. I made some major speed
enhancements and it now supports "over the border" queries. Basically
you're no longer tied to just the state you entered. It'll pull in RVs from
any state, sorted by distance.
So, for example, if you do a query for "Reno, NV", you get lots of nearby
California RVs as well.
Still not international, but one thing at a time.
)_( Dan
Have recently completed and 8 with camlock everywhere no problem.
Subject: | Gretz Pitot Tubes |
I would like to have some feed back re: Warren's pitot tubes-primarly from
those of you that are flying with such. I am interested in the accuracy
of... Thanks, Bob
From: | "Eustace Bowhay" <ebowhay(at)jetstream.net> |
Hi Kevin:
Tried panel mounting in my RV6 and had to move it onto the glare shield,
heading changed every time you turned something else on. Just today ordered
another pedestal mounted for the 6A as I believe it is a mandatory item.
The sad side it is sort of a useless item, even in the best of conditions
only gives a rough idea of which way one is pointed. In the arctic was
totally unreliable. I have used the DG for directional reference most of my
life. Set it to the runway heading prior to take-off and know its rate of
precession, then in combination with the ADF would fly a accurate heading.
Don't recall looking at a compass in the past 40 years.
All this changed with the advent of GPS, all I am putting in the 6A is the
Garmin combination comm gps a transponder and a comm 2.
Eustace Bowhay Blind Bay, B.C. Finishing wiring 6A
> Thanks,
> Ottawa, Canada
From: | "Randall Henderson" <randallh(at)attbi.com> |
Vans sells two styles of canopy cover -- regular, and light-weight.
I got the light-weight one and to be honest, I don't know what advantage
there is to the heavier type. Mine keeps the rain off, has a nice thin liner
that doesn't scratch the canopy, folds up to a very compact size, and cost a
whole lot less. Since 99% of us keep our planes hangared and likely mainly
use the canopy cover when traveling, the lighter weight alone seems like a
pretty important factor (is to me anyhow). In fact the heaver covers'
thicker liners look to me like they could be prone to trap small pieces of
grit.
I'm not writing this to badmouth the heavier covers, just relating my
experience/thoughts. I am wondering if I'm missing something since a lot of
people seem to be buying the other kind. The only advantage that I can see
is that heavier/thicker ones might last longer. Perhaps someone with the
other type can give an opposing view? :-}
Randall Henderson, RV-6 N6R (~300 hrs)
Portland, OR
www.vanshomewing.org
[snip]
Kevin,
I think if you put it there, it has a good chance of being a "placeholder"
to satisfy the FAA (or Transport Canada in your case).
I too tried to put it in my panel and found that most of the electronic
instruments I have would throw off the compass. The only way I could
eliminate significant interference was to move some instruments around AND
put the compass on the top of the glareshield. The fuel gauge (Westach)
would throw it off, as did the Matronics Fuel Scan. The radios weren't so
bad. Don't remember about the TC. But the only way to be sure is get the
different instruments (preferably powered up) and hold the compass next to
them in various orientations.
If I were VFR only I'd have put it wherever was most convenient, but my bird
is IFR and I really wanted the compass to mean something, so I rearranged my
panel to minimize interference.
Another option is one of those newfangled electronic compasses. I think
there's a boat unit that has a very light remote sensing unit (Bob Haan has
one in his panel). Or maybe one of those cool CoPilot LCD display ones could
work. I'm from the old school but I wouldn't hesitate to replace the old
whiskey compass with a better electronic version especially if it ran off
A/C power and had a battery back-up. Still waiting for someone to come out
with a version that has remote sensing, an LCD display, pseudo-analog
"vertical card" format, and 2 1/4" round form factor.
Portland, OR
Subject: | Gear box F802A&B |
A few days ago I made an inquire about a template for drilling the holes
on the F802 A&B that are at the bottom end of the bulkhead .
At the risk of sounding rude did anyone get the message .It was my first
go at asking a question on the list and I am not sure if I did it
correctly.Any answer would be appreciated if only to cater to my
technical insecurities.
Colin.
Learn to love your wet compass, treat it with respect and care for it just
might save your life some day. Like it saved mine, that night many years
ago, during a snow storm, when I had to shoot a needle/ball/airspeed ILS
approach down to 200 and 1/2 into Denver Stapleton after losing all my gyros
in a C-310Q.
I just love that mag compass....
Bruce
Glasair III
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Eustace Bowhay
Subject: Re: RV-List: Mag compass in panel?
Hi Kevin:
of
Randall is correct on this. If you want a cover just to keep the dust off
the canopy while it's parked in your hangar, or you need one for those trips
where you'll be tied down overnight, the light weight version is the way to
go. I bought the heavy weight cover from GBI, who could very well be making
the ones for Van's, and have been very pleased with it. Granted, it is
heavier; but, I don't have a hangar and park mine on the ramp. Longevity
was an issue for me. Mine has lasted for over two years of day to day
weather of all types. I expect it will last at least another year. If so,
it's been well worth the price I paid.
As for the comment about grit under the cover, I think one can get that
under any cover. One just has to be careful to wash the cover from time to
time to prevent as much damage as possible. So far, mine has been fine,
even in dusty conditions.
Jim Sears in KY
RV-6A N198JS
EAA Tech Counselor
Mike,
It's certainly true that Skybolt has some internal communications issues
regarding the inclusion of relevant instructions with their camloc kits. That
said, it's not too hard to figure out how to install the puppies by
extrapolating from the RV-4 instructions on their website. The one gotcha I
experienced was pulling all the little black pins from my adjustable receptacles
before installing them, instead of waiting until all the depth adjustments had
been made. I lost about an hour getting those pins back in...
I had no trouble installing the camlocs along my cowling's split lines.
Ken Balch
RV-8 #81125 (N118KB)
Ashland, MA
final, final, final details before going to the airport later this month
> Mike Robbins
Subject: | Re: Mounting oil pressure sensor, Thoughts |
> Question;
> Have any of you folks actually seen a engine mounted sending unit broken
off
> by vibration, or do any of you know of anyone that has witnessed such an
> circumstance?
The hangar next to mine still houses remnants of a what had been a brand new
Questair on which this happened. The pilot, who spent a cold night in a high
mountain meadow, bruised and battered and wrapped in pieces of aluminum from
the rolled-up ball that had been the plane, was able to walk out the next
day. He regailed our RV group with the story some time back at a meeting. He
expressed frustration that the manufacturer (of either the sensor, the
engine or the kit -- I don't remember which) had told him it was okay to
hang the sensor off of there. I do recall that it was one of the heavier
sensor types, but I can't say for sure that it wasn't on any kind of
extension. Regardless, it was enough to convince me to mount mine remotely
(even though the C-182 I occasionally fly has had an factory installed, FAA
sanctioned engine-mounted sensor since its manufacture in 1957!)
Portland, OR
I mounted Van's compass in the panel of my 6A. In the hangar as I was
installing more stuff I was pointed south and the compass was correct to
within 3 degrees. I kept installing more stuff. One day a friend who was
monitoring my (slow) progress came over and said " Hey, your compass is
off!"
Sure enough, it wasoff about 15 degrees pointing south. I swung it crudely
in the hangar, but it was not quite where I wanted it.
I have since swung it multiple times and still get errors of 10 degrees on
E/W. I can't seem to tweak out the error.
Somewhere along the timeline of installing stuff I introduced a magnitized
component within a foot or so of the compass, probably a screw -- instrument
mounting screws are all brass of course. Ticks me off!
Dennis Persyk 6A N600DP 113 hours
From: | "Sally and George" <aeronut58(at)hotmail.com> |
Subject: | Re: RV8-List: Gear box F802A&B |
Colin:
The "template" for drilling F802 A & B at the bottom are the holes you
drilled in the F-802G & H floor angles. See drawing 24, secion D-D (lower
left hand corner of the sheet).
George
N888GK
Flying
>From: "colin jordan" <cjordan(at)silk.net>
>Reply-To: rv8-list(at)matronics.com
>To:
>Subject: RV8-List: Gear box F802A&B
>Date: Tue, 5 Feb 2002 23:45:23 -0800
>--> RV8-List message posted by: "colin jordan"
>Colin.
I just had my PA28R180 anualed. The mechanic found a small piece of magnet
taped to the bottom of the compass which was mounted on top of the panel.
He removed it and said he could not put it back and pass the inspection.
After
that I could not swing the compass. The compass was factory mounted and I
suspect when the previous owner replaced the radios the magnet was added
to make the compass track properly. Anyway I had to mount the compass
on the center post of the windscreen several inches above the previous
position to make it work. So I would be careful to make sure the compass is
away from electronics that might produce a magnetic field affecting the
compass
and also any steel or iron objects that might retain magnetisim.
Earl RV4
> Thanks,
> Ottawa, Canada
From: | Ken Harrill <KHarrill(at)osa.state.sc.us> |
If you plan to install a used Hartzell C/S prop like Van's sells, make sure
to have it overhauled before you fit your spinner and cowling. The prop
shop sets the internal high pitch stop ( some call it course pitch)
specifically for the model aircraft, such as RV-6. This stop will affect
the fit of your spinner which could then affect the space between the
spinner and cowl.
My prop came off of a Mooney M20C and has the same model designation as the
prop sold by Van's. I fitted my spinner and cowl last spring and had the
prop overhauled last fall. When doing the final assembly last week, the
prop blade would contact the rear bulkhead at max high pitch. I shimmed the
bulkhead with washers to get the required clearance and, then, the cowl
would not go on. The prop shop said that the max high pitch for a Mooney
M20C is 28 degrees and that it is 37.5 for an RV-6.
It appears that I have the following options:
1. Grind off the rear edge of the spinner/bulkhead and hope to get
enough clearance.
2. Reinforce the inside of the cowl at the front and grind off the cowl
aft of the spinner, including my beautiful new paint. Then refinish and
repaint the cowl.
3. Put washers between the engine and the engine mount, moving the
engine and prop forward. Will probably require adjustment to the air scoop
and baffling.
4. Give up, sell the project, and buy some golf clubs and a bottle of
Jack Daniels.
Ken Harrill
RV-6
Columbia, SC
From: | "Crosley, Rich" <RCROSLEY(at)HRTEXTRON.TEXTRON.COM> |
Are most folks using Vans "rivet" static port or one of the nicer looking
after market ports. Do both work equally well?
Rich Crosley
RV-8 fuselage
Subject: | Re: pitot systems |
Rich,
We used Cleveland Tools' - The were easy to install and paint - looks and
works well.
Chuck & Dave Rowbotham
RV-8A (Niantic, CT)
>From: "Crosley, Rich" <RCROSLEY(at)HRTEXTRON.TEXTRON.COM>
>To: "'rv-list(at)matronics.com'"
>Subject: RV-List: pitot systems
>Date: Wed, 6 Feb 2002 10:52:06 -0800
>Rich Crosley
>RV-8 fuselage
Send and receive Hotmail on your mobile device: http://mobile.msn.com
I would say to get the correct ratio, close down the inlet first, most RVs I
know of fly too cold, not too hot. Fly it, and if you have cooling
problems, then engineer a fix. Fix the problem, not the solution.
Bob Busick
Subject: RV-List: RV-6 Engine Cooling
> Hi,
> RV-6
> O-360-A1A
> Thank you,
> Glenn Gordon
> N442E
I hope I am not violating Matronics policy with the following.
I received a private response to my question about antenna location,
that is full of useful knowledge to all. I am therefore sending it to
entire list. I have also included my private response in the belief
that it also might include a little useful knowledge.
George (private, not on RV-list),
I had a knee jerk reaction when I saw "elimination of icing problems" in
relation to external antennae. I'm all for looking at things from all
angles and considering, in advance, various problems and "what if's". I'm
age 61 and have 5000 hrs in fighters, some time in light airplanes; I'm
responding with only the best wishes for you. So,.....
The very fact that you would consider getting the antenna "indoors" out of
the ice makes me wonder what else you think about ice. I personally won't
fly into icing conditions or snow. I have, once, picked up a light bit of
rime ice climbing up thru a thin layer of non-precipitating stratus cloud.
If that is all you are thinking of encountering, then I can relax about your
view that it would be nice not to stress the antenna with that bit of extra
wt for a few moments until it sublimates off.
But if you think that ice on an antenna is a significant matter, then I
wonder how you come to that frame of mind. In my frame of reference, ice on
an antenna would be a micro-problem compared to the deadly and potentially
unrecoverable effects of ice on the airfoils and parts of the fuselage.
Unless you are flying a twin or bigger with pneumatic boots on leadings
edges - or hot air from jet engine compressor bleed system into the leading
edges - and have deicing fluid to squirt onto your prop, you simply must
avoid icing - thus antenna icing becomes a non-issue.
If I am going to fly above the freezing level and have reason to believe
that I may encounter clouds enroute, then I will only fly if the freezing
level is at least 2000 feet AGL, so that if I accumulate ice, I can descend
and melt it off before disaster occurs. I have intentionally flight planned
to go south of a front - south of a direct route home - so that the surface
was above freezing. I wound up landing short of home and staying overnight
until the forecast and actuality of freezing precip moved off east, at which
time I flew on home in VMC, behind the goo.
David Carter
Thanks David,
I too am scared of ice. I was only thinking of the possible use of
heat to delay ice forming on an antenna while getting out of an
unpredicted icing situation as quickly as possible, without losing
communication capability. Sorry I conveyed the opposite attitude.
I once had an encounter in unpredicted ice where a request for an
immediate change of altitude was met by the usual "stand by one". A
lot other aircraft were making the same request and I stood by a lot
longer than one while nervously watching ice accumulate.
The best advice I have gotten related to this is from my
nephew-in-law, a Marine F-4 pilot. He had left the Corp. and was
flying OV-10s in the reserve. He said their policy was to tell ATC
they were leaving the altitude and would take any heading. This may
be common knowledge but it was the first time I heard it. It seems a
quick way to get out of a bad situation and simplify sorting of
aircraft by ATC.
Thanks again for your very informative response and interest in pilot safety.
George
Check the archives, then decide. There has been a lot of discussion in the
past. One school claims the pop rivets actually work better ostensibly
because they protrude thru the boundary layer. The machined ones sure look
nice, are easier to attach the tubing and work well on jets. I never saw
clear winner in the arguments - seems to be a personal preference thing. I
used the pops.
Greg Young
RV-6 N6GY RIP
searching for Navion...
> nicer looking
> Rich Crosley
> RV-8 fuselage
There's also options 5 and 6...
5. Carefully and symmetrically relieve the backplate where the blades touch.
6. Leave it alone and let the backplate flex. You will seldom hit the high
pitch stops. Seems I remember someone asked Van's and this was their
recommendation. It's probably in the archives.
Greg Young
RV-6 N6GY RIP
> sells, make sure
> cowling. The prop
> will affect
> spinner and cowl.
> designation as the
> and had the
> last week, the
> I shimmed the
> then, the cowl
> for a Mooney
> hope to get
> enough clearance.
> grind off the cowl
> refinish and
> repaint the cowl.
> mount, moving the
> the air scoop
> and baffling.
> and a bottle of
> Jack Daniels.
> Ken Harrill
> RV-6
> Columbia, SC
I think your mechanic was wrong to remove.
Cy Galley
After
compass
Earl RV4
> Thanks,
> Ottawa, Canada
Rich:
I used Van's pop rivet. Works fine.
George
N888GK
flying
--- "Crosley, Rich"
> Rich Crosley
> RV-8 fuselage
> Contributions of
> any other form
> latest messages.
> other List members.
> http://www.matronics.com/subscription
> http://www.matronics.com/search
From: | "Doug Bell" <dbell(at)manisteenational.com> |
Subject: | Garmin Transponder install question |
Guys,
I have the most basic Garmin 320a transponder and have recently wired it all
up. This was my first attempt at installing with the little d-sub pin
connectors. I bought the good crimper from B& C and think I did all things
correctly.
My situation is this....when I hook up the witing harness plug to the unit I
am not getting the power to stay on. I have checked all the connections for
continuity and I'm good there.
Question: For those who are knowledgable in the d-sub pin
connectors....when installed into the wire connection plug, the little pins
have a little play once they are snapped in. I can move the littel pin in
and out about 1/16 inch...maybe less. Is this normal. Maybe I will need to
rewire the plug if it is not?
Doug Bell, Jr.
8qb
Subject: | Ellison TBI and Matronics Fuelscan |
Guys,
My brother stopped into the hanger this weekend and took some good pics of
our installation of the Ellison Throttle body on our O 360 A4M with the
throttle and mixture cables clearly visible. I have some good pics of the
install of the transducers ( Flow and Pressure ) for our Fuelscan unit as
well.
The files are big, and I still am not sure how to post these things
anywhere.
If these can be helpful to anyone, I will gladly send them to you.
Doug Bell
8qb
Subject: | Re: RV6-List: icing/antennas |
>--> RV6-List message posted by: George Frost
>aircraft by ATC.
The relevant portions of the FARs are part 91.123, and 91.3. The first
says, basically that you must comply with ATC clearances and instructions
unless deviation is necessary to handle an emergency, the second says that
the Pilot In Command, alone, is ultimately responsible for the safe
operation of his aircraft.
As a pilot, and long-time controller, I can tell you that there are many
situations that would preclude you getting an immediate altitude change or
revised clearance just because you encountered some ice. The controller
has no equivalent to far 91.123, that is, the controller does NOT have
emergency authority to deviate from his first priority duty which is to
separate aircraft and issue safety alerts.
If you require my assistance in my sector I WILL do everything I legally
can, consistent with my duty priorities and orders, to help you.
Philosophically, however, I will not be very sympathetic. To be blunt, if
you are operating at or near the freezing level, in cloud or visible
moisture, whether or not an airmet or pireps of icing exist, you are
screwing up.
If you don't want to pick up ice, and you shouldn't want to, don't fly in
icing conditions. You don't have to be there, the OAT indicator is there
for a reason, forcasts, airmets, and briefings aren't just to fill a
square, and ice is ALWAYS avoidable. If that means you don't get to fly
today, then I guess it means you don't get to fly today.
The time to ask for a different altitude or route is not after you start
picking up ice, but rather, before you get into conditions were ice is likely.
Flying into icing conditons rates a close second to "inadvertant" VFR
flight into instrument conditions on my list of stupid pilot tricks. Just
don't.
- Mike
hartmann(at)sound.net
Subject: | RE: RV8-List: Gear box F802A&B |
I replied, check the archives. Sorry you didn't get my message. Don't
worry, if you say something others don't like you'll hear about it.
Welcome to the wild west of the internet!
Vince Himsl
RV8 SB Fuselage Canoe
Moscow, ID USA
From: | "Paul Besing" <azpilot(at)extremezone.com> |
Subject: | Re: Garmin Transponder install question |
I have this same transponder. Yes, they can have a little play. Not 1/16"
but a little. I would check the screw that mounts it to the tray. You can
adjust it to pull the unit in tighter into the rack.
Paul Besing
RV-6A N197AB Arizona
First Flight 22 July 01
Kitlog Pro Builder's Log Software
http://www.kitlog.com
Subject: RV-List: Garmin Transponder install question
> Guys,
all
things
> correctly.
I
for
pins
to
> Thanks,
> Doug Bell, Jr.
> 8qb
Ya, this is a slow responding bunch sometimes...no really, there isn't a lot
of traffic on this group (thankfully). One thing I recommend is to be
descriptive of the item you're working on--some of us have forgotten the
part numbers but dearly remember the problem.
Hey, here's a recommendation for you who have no finished the instr panel:
cut a BIG access hole in the bulkhead separting the instrument bay from the
forward luggage bay. I riveted nut plates around the perimeter then cut a
cover for it. In maintenance, it has saved me no end of grief when mucking
about behind the panel.
Greg Miller
RV8 N89GM, 105 flying hours now.
[mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of colin jordan
Colin.
Subject: | Re: Cowl fit - clearance for paint |
> How much gap are you leaving between the upper and lower cowl halves and
> beteeen the cowl and fuselage to allow for paint?
You will know after you start flying why this post made me laugh out loud. I
remember a builder of a -6 some time ago laying down STRANDS of fiberglass
to get the space between his cowling halves JUST right. Then he started
flying. The gaps get pretty big, with all the movement of the various parts.
Just cut the thing and don't worry about a few pecometers of paint. You will
not get it that close, and if you do, it won't stay that close.
Michael
Subject: | RE: RV8-List: Super Sound Proofing Request |
Vince,
I went through the decision process on that too, but was told it doesn't do
much good. Now that I'm flying behind a fixed Sensenich, I understand. After
the first flight I had to buy a noise canceling headset. The noise is *very*
intense, but it's in the low frequencies, where sound pads don't do much to
attenuate it, but the headset works great.
You might think it will at least provide thermal insulation, but again it
turned out for me that plugging all the drafts is about impossible. So a
barrier to conductive heat transfer doesn't help much when the problem is
convective transfer, ah..wind chill!
I put two heaters in mine too, one on each exhaust pipe. Warm from the waist
down this time of year.
Greg Miller
Idaho Falls, ID
[mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Vince
Subject: RV8-List: Super Sound Proofing Request
--> RV8-List message posted by: "Vince"
Hello,
really worked!
Vince Himsl
RV-8 SB Canoe
Moscow, ID USA
Subject: | RE: RV8-List: Mag compass in panel? |
Ah, nice panel design! but where's the car stereo/CD player? Looks like it
would fit under your audio panel--they are a bit wider than a plane radio.
That is the location I put mine, and it's perfect. My left hand is either on
the throttle, and/or just above it on the flap switch (where your left most
breaker is) or adjusting the stereo volume.
When you put the stereo in make sure you put one of those radio shack power
conditioners on it, or the CD spindle motor A/C power noise will leak into
you intercom and ruin Led Zeppelin. Part number 270-030, about 5$ and very
worth it.
I put my compass where your G meter is and have not had to recalibrate it.
Greg
N89GM
[mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Kevin Horton
Subject: RV8-List: Mag compass in panel?
--> RV8-List message posted by: Kevin Horton
Ottawa, Canada
Subject: | Re: RE: RV8-List: Gear box F802A&B |
The RV-List is a great list for generic RV questions, etc. But for
RV-8 or -8A specific questions there is another e-mail list that
seems to be better, IMHO. Try the rv8 list at yahoo,
<http://groups.yahoo.com/group/rv8list/>. There aren't near as many
messages, but the signal to noise ratio is a lot higher, and there
seem to be more RV-8/8A guys there than on the RV-List.
Kevin Horton
>Greg Miller
>From: owner-rv8-list-server(at)matronics.com
>Colin.
I'm figuring by the time I get this thing flying I'll be able to buy
a $20 iPod that'll hold every song every written :). Seriously, I've
got a portable CD player now that I might use, but I'm hoping the
iPod prices will come down a bit by then.
Take care,
Kevin
>--> RV8-List message posted by: "G. Miller"
>worth it.
>Greg
>N89GM
>To: rv8-list(at)matronics.com; rv8list(at)yahoogroups.com
>Thanks,
>Ottawa, Canada
From: | "Bob Japundza" <Bob.Japundza(at)realmed.com> |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Subject: | RE: RV8-List: Gear box F802A&B |
I just tried that site. First I saw an obstrusive colorful blinking
advetisement. End of site.
Greg
-----Original Message-----
[mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Kevin Horton
Subject: Re: RV-List: RE: RV8-List: Gear box F802A&B
--> RV8-List message posted by: Kevin Horton
The RV-List is a great list for generic RV questions, etc. But for
RV-8 or -8A specific questions there is another e-mail list that
seems to be better, IMHO. Try the rv8 list at yahoo,
<http://groups.yahoo.com/group/rv8list/>. There aren't near as many
messages, but the signal to noise ratio is a lot higher, and there
seem to be more RV-8/8A guys there than on the RV-List.
Kevin Horton
>Ya, this is a slow responding bunch sometimes...no really, there isn't a
lot
>of traffic on this group (thankfully). One thing I recommend is to be
>descriptive of the item you're working on--some of us have forgotten the
>part numbers but dearly remember the problem.
>Hey, here's a recommendation for you who have no finished the instr panel:
>cut a BIG access hole in the bulkhead separting the instrument bay from the
>forward luggage bay. I riveted nut plates around the perimeter then cut a
>cover for it. In maintenance, it has saved me no end of grief when mucking
>about behind the panel.
>Greg Miller
>RV8 N89GM, 105 flying hours now.
>From: owner-rv8-list-server(at)matronics.com
>[mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of colin jordan
>To: rv8-list(at)matronics.com
>Subject: RV8-List: Gear box F802A&B
>--> RV8-List message posted by: "colin jordan"
>A few days ago I made an inquire about a template for drilling the holes
>on the F802 A&B that are at the bottom end of the bulkhead .
>At the risk of sounding rude did anyone get the message .It was my first
>go at asking a question on the list and I am not sure if I did it
>correctly.Any answer would be appreciated if only to cater to my
>technical insecurities.
>Colin.
Subject: | Re: Mag compass in panel? |
My compass is in the panel. It is as accurate as any one I have seen
in a "Spam Can". There is NO electrical wiring near it. Also no steel
other than the rollover windshield bow. (Stainless steel does not
count.) Have only made one small adjustment. There is some error but
it is very small. Did not check the error when I was north of the
Arctic Circle this summer.
Gary A. Sobek
1,002.9+ Flying Hours So. CA, USA
http://SoCAL_WVAF.tripod.com
http://greetings.yahoo.com
Subject: | Engine Plenum - Great Idea or Big Hassle? |
From: | "Bob Japundza" <Bob.Japundza(at)realmed.com> |
Do it. It can save you some potential hassle down the road. I don't
think it is much more work over the on/off/on/off sequences you go
through matching the baffles to the cowl.
I also suggest an oil cooler door so you can adjust oil temperature.
Another one of my do-overs, and if I had the time I'd retrofit that to
my airplane.
On my F1 I am definitely going to make an aluminum plenum that is
removable, along with some removable covers to permit getting to the top
plugs without taking the entire plenum off. The cowl hinges take a
beating, cowl rivets start showing, paint cracks, etc. In another year
or two I will have to redo my cowl (its the old crap polyester cowl.)
You'd be surprised how much the cowl blows up in flight and the
subsequent stress that is put on the piano hinges, esp. if you're doing
rolls or any high-g stuff. With the plenum you won't have the stresses
on the cowl and attach hardware that you have with the baffles in
contact with the top cowl except around the inlets. After prolonged
periods of not keeping the airplane clean I'll have very light streaks
of black dust coming from the cowl hinges, and they show signs of wear
after 270 hours. I'd really hate to have to replace the hinges on the
firewall side and ruin the paint. So in that respect alone I'm doing it
differently on the new airplane. I don't think maintenance will be much
of an issue. Once you have the bugs worked out of your airplane
hopefully taking the cowling off between oil changes will be a rare
event anyway.
Bob Japundza
RV-6 N244BJ O-360C/S flying 270 hours
F1 QB under const.
From: "Richard D. Fogerson" <rickf(at)velocitus.net>
Subject: RV-List: Engine Plenum - Great Idea or Big Hassle?
I have seen some people installing aluminum and fiberglass
plenums for
engine cooling rather than the standard baffle system. This
looks
interesting to me from an esthetic and efficiency standpoint but
something bothers me about it. You must remove it in addition to the
cowl to see or get to the top of the engine.
How long does that take to remove?
Do you consider that to be a big hassle?
Does it concern you about not being able to see the engine
without
removing it?
Lastly, would you do it if you had it to do over again and why?
I would appreciate your responses as I am considering doing this
but
don't want to invest the time if I'm going to reqret it later.
Rick Fogerson, RV3 wings, Boise, ID.
From: | "Owens, Laird" <Owens(at)aerovironment.com> |
That in itself is worth a donation to Matt......
THANKS MATT for no advertisements!
Laird
SoCal
From: rv-list(at)matronics.com on Wed, Feb 6, 2002 7:27 PM
Subject: RE: RV-List: RE: RV8-List: Gear box F802A&B
Greg
Kevin Horton
lot
>Greg Miller
>Colin.
Subject: | re: RV-List, Propeller bolts |
Does anyone know of a good source for AN77 prop bolts? I don't know the
dash number but it measures 8 3/8" from the bottom of the head to the
end of the bolt. The diameter is 7/16". The thread length is
approximately 1 3/16". I only need one for replacement. Any help will
be appreciated.
Leon York, RV6A
I've all but decided not to do as you suggest...because I figure I can
unscrew the center section of the panel and gain access. What's wrong
with this plan?
Larry Bowen
RV-8 fwd baggage door
Larry(at)BowenAero.com
http://BowenAero.com
> [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of G. Miller
> instr panel: cut a BIG access hole in the bulkhead separting
> the instrument bay from the forward luggage bay. I riveted
> nut plates around the perimeter then cut a cover for it. In
> Greg Miller
Subject: | RE: RV8-List: Panel access |
I designed my panel to come out the way you suggest, so I can take it home
to work on it. I have many times now. But before it comes out, I use the
access panel to disconnect many items, following is my panel removal
checklist:
Center Panel Removal Procedure
1. From cockpit, under rear of stereo, remove vacuum filter hoses (2),
unscrew vacuum filter (platenut), and set aside.
2. Open forward baggage door, and rear instrument panel access door.
3. Disconnect Horizon gyro filter and vacuum hoses, verify label, and cover
openings with tape.
4. Disconnect Direction gyro filter and vacuum hoses, verify label, and
cover openings with tape.
5. Disconnect 24-pin (carefully!) Molex connector.
6. Disconnect fuel pump switch 2-pin Molex connector.
7. Disconnect six-pin connector from pigtail in 14, above KMA-24/KX-155
8. Disconnect EGT 2-pin Molex connector.
9. Disconnect CHT 2-pin Molex connector.
10. Disconnect single (in 3-pin) Molex connector: radio master power.
11. Unscrew turn coordinator plug from T/C
12. Disconnect wire harness from EPM
13. Disconnect manifold pressure tube from EPM
14. Disconnect comm. antenna BNC, under access port opening, coax #H
15. Disconnect MB antenna BNC, behind KX-155, coax #70
16. Disconnect G/S antenna BNC from triplexer, bottom inboard, behind KX-155
17. Disconnect VOR antenna BNC from triplexer, top inboard, behind KX-155
18. Disconnect FM antenna from triplexer, top outboard, behind KX-155
19. Disconnect pitot tube at A/S indicator, verify label, and cover opening
with tape.
20. Disconnect static tube at A/S indicator, verify label, and cover opening
with tape.
21. Disconnect encoder static tube at VSI, verify label, and cover opening
with tape.
22. Disconnect large serial port type connector from intercom, above
KMA-24/KX-155. Inboard screw needs to be loosened first. Upon install
tighten inboard screw!
23. Vans CHT: detach thermocouple cable from top two terminals. Yellow to
(inboard), red to (outboard). Unscrew from panel first and lower for
access.
24. Remove GPS mount
25. Cockpit, remove center panel screws.
26. Carefully work panel straight back.
27. End
Greg
[mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Larry Bowen
Subject: RV8-List: Panel access
--> RV8-List message posted by: "Larry Bowen"
with this plan?
Larry Bowen
> Greg Miller
Subject: | Re: More cowl camlock questions |
In a message dated 2/6/2002 4:52:02 AM Pacific Standard Time,
kbalch1(at)mediaone.net writes:
> The one gotcha I
> experienced was pulling all the little black pins from my adjustable
> receptacles
> before installing them, instead of waiting until all the depth adjustments
> had
> been made. I lost about an hour getting those pins back in...
I tossed the pins and just pulled a double loop of safety wire thru mine
(from the inside like a cotter pin) and bent the tails around the underside
lip. Much easier to adjust later.
-GV (N1GV)
Subject: | Re: Looking for Mitch Faatz |
In a message dated 2/5/2002 8:58:24 PM Pacific Standard Time,
rickf(at)velocitus.net writes:
> I am interested in an aluminum plenum with round inlets for my RV3 and I
> understand that Mitch Faatz has experience with that configuration. I've
> tried mfaatz(at)avidyne.com but it does not work. Is Mitch on the list
> and/or does anyone have a current email address for him.
Mitch left Avidyne and is back in Silicon Valley where he belongs. The
latest address I have for him is
-GV (N1GV)
Subject: | Re: Engine Plenum - Great Idea or Big Hassle? |
Hi All,
I built the baffling on my RV-3 with a Lycoming O-290 to match the existing
cowl. It was easier to make and install than "standard" baffling, sealed to
the engine and cowl air inlets and included access to R&R the top plugs
without removing the baffling.
I am building an improved set of baffling for my RV-4 with an IO-540. :-)
I expect it to be close to a bolt on installation, even though I'll need to
provide access for the occasional injector maintenance.
It works. It is very efficient. It can be very easy.
BTW, the air leakage around "standard" baffling keeps the cowl cool around
the exhaust pipes. A sealed baffling allows the exhaust pipes to blister the
paint unless the inside of the cowl is protected.
Jim Ayers
RV-3 N47RV sn 50 LOM M332 engine (sealed duct baffling comes installed by the
factory on the engine) :-)
RV-3 sn 306 Lyc. O-290 engine (sealed duct baffling)
RV-4 / HR2 Lyc. IO-540 engine (sealed duct baffling)
Leon,
We have a 7/16 bolt which measures 8.469 from under the head and has 1.156
threads. We sell singles or kits of 6 bolts and 6 washers. I'll warn you now
though that this bolt is not cheap. Give a call if you are interested.
717-569-0435
Ed Zercher
Sensenich Propeller Manufacturing Company
Subject: | Re: RE: RV8-List: Mag compass in panel? |
08:05:55 AM
Amazon has the PC versions with 20 gig for $75.00 reconditioned. They'll be
$199 by the end of the year. The days are numbered on the old CD format.
Eric
Kevin Horton (at)matronics.com on 02/06/2002 09:21:53 PM
Sent by: owner-rv-list-server(at)matronics.com
cc:
Subject: RV-List: RE: RV8-List: Mag compass in panel?
I'm figuring by the time I get this thing flying I'll be able to buy
a $20 iPod that'll hold every song every written :). Seriously, I've
got a portable CD player now that I might use, but I'm hoping the
iPod prices will come down a bit by then.
Take care,
Kevin
>--> RV8-List message posted by: "G. Miller"
>Ah, nice panel design! but where's the car stereo/CD player? Looks like it
>would fit under your audio panel--they are a bit wider than a plane radio.
>That is the location I put mine, and it's perfect. My left hand is either
on
>the throttle, and/or just above it on the flap switch (where your left
most
>breaker is) or adjusting the stereo volume.
>When you put the stereo in make sure you put one of those radio shack
power
>conditioners on it, or the CD spindle motor A/C power noise will leak into
>you intercom and ruin Led Zeppelin. Part number 270-030, about 5$ and very
>worth it.
>I put my compass where your G meter is and have not had to recalibrate it.
>Greg
>N89GM
>To: rv8-list(at)matronics.com; rv8list(at)yahoogroups.com
>Subject: RV8-List: Mag compass in panel?
>I'm messing around trying to freeze the design of the instrument
>panel on my RV-8. My preferred layout has the magnetic compass in
>the panel, rather than on top of the glareshield (I want my g-meter
>on top of the glareshield). The compass will be one hole down and
>right from the DG (which is electric), and just to the left of the
>Grand Rapids EIS engine monitor. You can see a poor quality
>rendition of my proposed layout at:
><http://eccentrix.com/misc/rv8/finishing_kit/fk05.html>.
>I'm wondering whether I have much chance to make this work, or
>whether I will probably run into problems getting the compass swung
>OK. I would love to hear from people who have a compass in the panel
>- how did the compass swing go? What type of compass do you have?
>What electrically powered stuff is in the vicinity of your compass.
>Yes, I have wondered how much I will actually use the compass, given
>I've got a GPS. But, I guess I'm an old fashioned kind of guy, and I
>still hope to get the compass swung reasonably close.
>Thanks,
>Kevin Horton RV-8 (installing engine & electrics)
>Ottawa, Canada
>http://eccentrix.com/misc/rv8/rv8.html
I put an access panel in the bulkhead, but I also made my panel tip down
and out very easily without adding ANY weight...
http://vondane.com/rv8a/wiring/wire4.htm
-Bill VonDane
Colorado Springs, CO
RV-8A - http://vondane.com/rv8a/
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of G. Miller
Subject: RV-List: RE: RV8-List: Panel access
home to work on it. I have many times now. But before it comes out, I
use the access panel to disconnect many items, following is my panel
removal
checklist:
(2),
door.
and cover
openings with tape.
label, and
KMA-24/KX-155
power.
#H
behind KX-155
behind KX-155
KX-155
cover opening
with tape.
cover opening
with tape.
cover opening
with tape.
above
Yellow to +
access.
27. End
Greg
with this plan?
Larry Bowen
> panel: cut a BIG access hole in the bulkhead separting the instrument
> bay from the forward luggage bay. I riveted nut plates around the
> perimeter then cut a cover for it. In maintenance, it has saved me no
> end of grief when mucking about behind the panel.
> Greg Miller
From: | "Eric Newton" <enewton57(at)cableone.net> |
Subject: | ATC initial contact protocal |
Recently, someone was asking about the proper phraseology for initial
and subsequent call ups to ATC when flying our RV's. Here is an excerpt
I just found directly out of the AIM:
2. Breezy Six One Three Romeo Experimental (omit "Experimental" after
initial contact).
So in my case, I'll be calling in as "RV 57 Mike Echo Experimental" on
the initial contact and then simply "57 Mike Echo" thereafter.
Question for those ATC types out there - Should I say "RV 57 ME
experimental" or should it be Romeo Victor 57 Mike Echo experimental"?
Eric Newton - Long Beach, MS
RV-6A N57ME (Flying)
www.ericsrv6a.com
Subject: | Re: ATC initial contact protocal |
> excerpt
> initial contact).
> on
> experimental"?
> www.ericsrv6a.com
Eric:
I use RV 157 Golf Sierra Experimental in the US and RV November 157
Golf Sierra Experimental in Canada. Hope that the ATC types pipe up if
there is something wrong with this.
When asked type of aircraft in the US, I replay Romeo Victor Six slash
Golf. Golf is for approach certified GPS and not the VFR variety. The
type changes in Canada and I must look up what follows the slash.
Hotel Xray Bravo is the international type followed by the slash and
international equipment.
Hope this helps.
Gary A. Sobek
From: | "Todd W. Rudberg" <todd_rudberg(at)yahoo.com> |
Subject: | IO360-B1(a-f or so) |
I am looking for one. The one I purchased from Wentworth Aircraft did
not work out and is on its way back. Does anybody have a lead on one?
I have cash in hand.
Anybody out there purchased an XP motor yet? I am also considering the
kit. Please reply off list to keep spam down.
Todd W. Rudberg
RV-8 Fuse(N232TB Reserved)
mailto:todd_rudberg(at)yahoo.com
www.geocities.com/todd_rudberg
Home: (425)290-7526
Cell: (425)870-5300
From: | "Steve Hurlbut" <hurlbut_steve(at)hotmail.com> |
Subject: | Fuselage Bulkheads RV-7 |
I'm in the process of straigtening the fuselage bulkheads. F-707, 705, 706
etc (I think. Don't have the plans at work right now). They need A LOT of
fluting since they are very distorted. Did others experience this as well?
They are not critically bent, but they sure look warped and flimsy. Thankx
Back to work,
Steve Hurlbut
RV-7A
Finishing Wings (looking ahead)
Subject: | Re: RE: RV8-List: Super Sound Proofing Request |
Greg,
Am I hearing I should leave my RV-6 firewall bare (...I've already hinted
that I want a noise cancelling headset for my b-day )?
General consensus seems to lean towards some type of pad aids both noise
and heat coming into the cockpit (good in summer, bad in winter). However
I'd love to leave it off for build time/weight savings if it doesn't do
much good.
Others' experiences?
Rob Acker (another ID RV )
> Vince,
> I went through the decision process on that too, but was told it
> doesn't do much good. Now that I'm flying behind a fixed Sensenich, I
> understand. After the first flight I had to buy a noise canceling
> headset. The noise is *very* intense, but it's in the low frequencies,
> where sound pads don't do much to attenuate it, but the headset works
> great.
> You might think it will at least provide thermal insulation, but again
> it turned out for me that plugging all the drafts is about impossible.
> So a barrier to conductive heat transfer doesn't help much when the
> problem is convective transfer, ah..wind chill!
> I put two heaters in mine too, one on each exhaust pipe. Warm from the
> waist down this time of year.
> Greg Miller
> Idaho Falls, ID
> [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Vince
> Subject: RV8-List: Super Sound Proofing Request
> --> RV8-List message posted by: "Vince"
> Hello,
> I am finally at the stage where I can do something besides rivet
> aluminum. I am going to order the Super Sound Proofing in my RV-8 and
> would appreciate some input from anyone who has installed it.
> Specifically, how much and what kind of the stuff to order and if it
> really worked!
> Thanks,
> Vince Himsl
> RV-8 SB Canoe
> Moscow, ID USA
February 01, 2002 - February 07, 2002
RV-Archive.digest.vol-mh
