RV-Archive.digest.vol-my
June 07, 2002 - June 16, 2002
      Ed uses a simple 4' long pipe with hundreds of holes drilled
      along it & a 'fishmouth' end on the pipe. He had his prop
      balanced at the EAA chapter hangar so we were exposed to
      several high-power static runs. It was a bit louder than a
      typical Lyc with crossover exhaust, but probably not any
      louder than a 4-pipe Lyc. However, it is quite different
      (higher pitched & sharper edged due to the way the exhaust
      port opens). I guess a good analogy would be the difference
      between the pleasing sound of a radial vs a 4 cyl Lyc. No
      real volume difference, but one is less irritating.
      Tracy is using a Spintech brand stainless muffler which
      seems to be surviving well & also seems to tame the exhaust
      pulses pretty well. I walked out to the ramp hoping to hear
      what it sounded like on takeoff. A T-6 had just landed & was
      taxiing on the parallel taxiway as Tracy took off. With the
      T-6 idling & the RV at full throttle, I couldn't hear the
      rotary RV at all on takeoff.
      Both seem to be surviving well (earlier stuff didn't) & they
      both deal with the heat by hanging them under the belly of
      the plane, outside of the cowl. While neither are very
      pretty at the moment, they are works-in-progress & probably
      look no worse than most prototyping projects from
      manufacturers.
      The nice thing about these engines is that the core is
      almost completely bulletproof when looking at catastrophic
      failure modes. Even a complete loss of coolant (this has
      happened to a couple of guys) seems to result in only an
      engine replacement at about the same cost as 3 Lyc cylinders
      after you fly to a convenient airport & land.
      Tracy says that his fuel consumption closely tracks a 180hp
      Lyc on a similar airframe at similar speeds.
      The biggest downside is the extra work because there is no
      cookie-cutter installation with these engines.
Subject: Painting top of dashboard
Date: Jun 07, 2002
You can search the RV-List archives under "Last Flight Report". You'll find a recent post that has some links plus the original postings from last year. Greg > > Greg, > > You can't leave us hanging... sounds like a good story. > What's the rest of > it? How did it happen? Some of us are new to the list and > have not heard the > whole story. > > Thanks > Dave C, Sacramento > -7 tail done, waiting for wings ________________________________________________________________________________
Date: Jun 07, 2002
Subject: EFIS/Lite update
Here is an update concerning the installation of a Blue Mountain Avionics EFIS/Lite in my RV-6 for those of you who have been asking me about the progress of this project. At this moment there is a Lite installed in 399SB in a test fixture hung beneath the panel. The reason for this arrangement is due to the great deal of hacking that will be required for me to install the Lite in the very confined space available in my panel. I want to work out any kinks in the unit and gain confidence in its capabilities before committing atrocities to the panel. ;-) How is the testing going so far? I think quite well for a technology that is still very much a work in progress. Getting the instrument has been an exercise in patience but the delays were not totally unexpected due to the fact that there are no similar units on the market at this price point. Greg Richter is on the cutting edge of bringing true inertial platforms to the experimental market at prices that mortals can afford. One aspect of the Blue Mtn experience that has been pleasant is Greg's willingness to incorporate suggestions for enhancing the display in the Lite. I have made several "observations", and it seems nearly all of them have resulted in software enhancements, some of which were rewritten as I waited in the shop! I am sure he will not accommodate every suggestions made, but there is no doubt the product is improving on a nearly daily basis. I have flown the instrument sufficiently to determine that this is probably going to be a watershed technology once the kinks are ironed out. Watching the attitude indicator follow the plane and realizing there are NO moving parts in the box is truly mindboggling! I am going to hold off on making public judgment of the various functions of the unit until I have had enough time for me to fly the system in its entirety, for Greg to add whatever adjustments we find useful, and for me to give a fair representation of what I find. A major issue yet to be resolved is the actual installation of the unit in a tilted and confined panel, but there are ideas in the works that hopefully will allow the EFIS/Lite to be utilized in nearly any aircraft, and all RVs in particular. Sam Buchanan (RV-6) "The RV Journal" http://thervjournal.com ________________________________________________________________________________
Subject: nomex
Date: Jun 08, 2002
Hi Folks, Greg Young wrote: "I WILL be wearing Nomex and a helmet..." Good idea. I wear a military-style nomex flight suit when flying for fun. Having had the "flaming airplane experience," I can tell you that nomex is money well spent. I am not in the protective clothing/equipment business, but I would like to see us (sport aviation types) consider making this our own standard equipment. Most of us didn't wear helmets when riding bikes as youngsters. Now we insist on them for ourselves as well as our kids. A change in attitude is all it takes. While helmets and nomex suits aren't cheap, if you watch for sales you can save a few $$. I just ordered a suit from the closeout section of the Flightsuits web site (www.flightsuits.com) for $99. There are several other suppliers as well. If you want custom fit, etc., figure on $200 plus. If you are ever exposed to flame, you'll be glad you aren't wearing one of those nylon flight jackets. Mine melted. Fortunately, I had a nomex flight suit on underneath it. Needless to say, I'm a nomex fan now. Note - this stuff is not heat proof. In other words, if you're wearing nomex gloves and stick your hand into a flame, you're going to get burned. The nomex will not ignite, though, so when you pull your hand out of the fire, it won't continue to burn. This can make a difference in the severity of injury. I'm not an expert in this field - perhaps there are some listers out there with experience/training in crash/fire/rescue who would be willing to comment for the benefit of the group. For what it's worth. Fly safely. Tim - Pittsburgh ________________________________________________________________________________
Subject: 10 Hr Report & Lean Carb (long)
Date: Jun 08, 2002
Hi George My name is David Powell based in England At present doing test flying like yourself (G-ODEE) My Engine, Carb and Prop are the same as yours I to have a lean running engine and have been given so much conflicting information on what carb I should be using I am very interested in the results you obtained by drilling the carb appreciate it if you could let me know David Powell ---------------------------------------------- Hi Dave My engine is much better since I drilled the carb jet from #42 to #38 but that is still not enough. As I mentioned in my 10 hour report the engine was previously running on the lean side of peak temperature, any leaning with the mixture control and the cylinder head temperature immediately dropped. Since drilling the carb jet to #38 I think that the engine is now running just on the rich side of peak temperature. Leaning with mixture control at 10,000 feet now gives me a 5 degree F increase in head temperature before temperature peaks and starts to lean drop. Cylinder temperatures in climb & cruise are now 5 - 10 degrees cooler. Next week I will remove the carb and open the jet up some more, think I will try a #37 drill bit but am tempted to jump to a #36. George McNutt Langley B.C. (I will also post this message to RV-list for others who are interested) ________________________________________________________________________________
Subject: nomex
Date: Jun 08, 2002
-----Original Message----- From: KostaLewis [mailto:mikel(at)dimensional.com] Subject: RE: RV-List: nomex >>"I WILL be wearing Nomex and a helmet..." >Good idea. I wear a military-style nomex flight suit when flying for fun. >I am not in the protective clothing/equipment business, but I would like to >see us (sport aviation types) consider making this our own standard >equipment. I agree here and have agreed before. Suzie Q has not flown without me wearing my Nomex suit and helmet. Overkill? Perhaps. My coconut would be just too close to the pavement if we decide to scrape along it upside down. I am so used to wearing the gear, I would feel pretty naked without it. I have not, thank the stars, had the flaming airplane experience but have talked to several that have, one in an RV-4. Found him standing in the doughnut line at OSH. Didn't like the scars on his arms. He had plenty to say about Nomex. Check the archives about this; it's been discussed. Most folks are OK not wearing protective gear. Fine with me. I'll be wearing mine, and not to look like Joe Cool. My wife is thankful for me trying to keep me looking the way I do. Helmet: Custom fit from Flight Suits, Ltd. Worth every penny. Nomex flight suit: friends in or out of the Air Force, wanting to get rid of their "bags". Nomex jacket: Flight Suits, Ltd. Do NOT wear Nylon while flying. Or, if you do, take one of your old ones and set a match to it and see what happens. Then go buy a Nomex. Nylon is OK to wear to the movies or shopping. Gloves: deer hide. Too hot in the summer? Naa. I wear shorts and T-shirt underneath. And have the vents wide open. IMHO Michael ________________________________________________________________________________
Subject: RV-7/9 Rudder
Date: Jun 08, 2002
I am relaying some information sent to me from someone who linked to my website from the Van's link page. This is the first I have heard of this and have not been able to document it yet from my e-mail to Van's support. I am not listing the senders name, just relaying the information sent too me. Anybody know what is going on??? >>>I just thought I would let you know that I called Van's yesterday to >>>verify what I had been hearing about the rudder on the RV-7. They >>>explained the spin testing on the RV-6 outfitted to reflect the RV-7 and >>>that it looked OK. When they did the spin tests on the actual production >>>plane they were not satisfied with the results. They tested again using >>>the rudder off the RV-9 and now they like it. So, Van will be sending a >>>letter out giving us the option of switching over to the RV-9 rudder. The >>>tech I talked to said I should definitely hold off on building the >>>rudder.<<< Dana Overall Richmond, KY 7 emp, including rudder completed, wings delivery 6/14 http://rvflying.tripod.com ________________________________________________________________________________
Subject: nomex
Date: Jun 08, 2002
Subject: Sensenich spinner for metal prop
Date: Jun 09, 2002
Hello everyone, I'm upgrading to the Sensenich 70CM7S9 metal propeller. I see that Sensenich lists on their web site a complete spinner assembly for that prop. The rear bulkhead is 13 inches. Has anyone out there is RV-land used this spinner? What did you think of it? Stephen Soule Huntington, Vermont RV-6A N227RV ________________________________________________________________________________
Date: Jun 09, 2002
I was surprised at the spinner when I got it. It was very well built and plug and play.. I didn't have to touch a thing except paint and swapping the cad plated stuff for stainless. I'd buy for every bird I build.. Steven DiNieri Rv-6a N221RV -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Stephen J. Soule Subject: RV-List: Sensenich spinner for metal prop Hello everyone, I'm upgrading to the Sensenich 70CM7S9 metal propeller. I see that Sensenich lists on their web site a complete spinner assembly for that prop. The rear bulkhead is 13 inches. Has anyone out there is RV-land used this spinner? What did you think of it? Stephen Soule Huntington, Vermont RV-6A N227RV ________________________________________________________________________________
Date: Jun 09, 2002
Subject: Re: RV-List Digest: 8 Msgs - 06/08/02
I would look on some of the Sports Car Club of America websites for people who are selling used racing helmets. The SA90 (Special Applications 1990) rating is now expired for professional racing. These helmets if kept in good condition are more than adequate for any use and ironically much safer than the military style helmets. I race a Formula1 Tunnel hull boat and I use a Bell SA01 open faced helmet with a flight oxygen mask over the military helmet with the oxygen mask. I want to be sure I have the latest in "bead-all" liners with kevlar. Most of the military helmets are minimums for safety and are just a low bid winner for protection. I do not think they ever took into consideration what a steel rollcage would do to a helmet as Simpson and Bell have. Accept no others, these are the industry standard in safety. David Wilks http://www.davidawilks.com ________________________________________________________________________________
From: "James & Shalise Cash" <jcash(at)granbury.com>
Subject: New RV-7 rudder design?
Date: Jun 09, 2002
Hi everybody, Is it true that the RV-7 rudder has been redesigned since it's original release? I heard something about the counterbalance being "taller." I know the design has changed from the RV-6, and the stabilizer is taller. Has anything changed in the RV-7 tail? I'm looking at a tail kit that was produced in 2001. It is an RV-6 tail, with an RV-7 "conversion" kit. Just wanting to know if there have been any upgrades. Thanks, Jimmy Cash ________________________________________________________________________________
Date: Jun 09, 2002
Subject: Re: RV-7/9 Rudder
According to the Second Issue, 2002 RVator the spin tests performed on the RV-7 demonstrator meet FAA requirements for standard category aircraft but not for aerobatic category :-( THe article ended saying that they were going to try a larger rudder. Guess the RV-9 rudder is larger than the RV-7 rudder. Wonder what Van's position is going to be on replacement rudders? THe aerobatic capabilities was the main reason I chose the RV-7 over the RV-9. Steve On Sat, 8 Jun 2002, Dana Overall wrote: > > I am relaying some information sent to me from someone who linked to my > website from the Van's link page. This is the first I have heard of this > and have not been able to document it yet from my e-mail to Van's support. > > I am not listing the senders name, just relaying the information sent too > me. Anybody know what is going on??? > > >>>I just thought I would let you know that I called Van's yesterday to > >>>verify what I had been hearing about the rudder on the RV-7. They > >>>explained the spin testing on the RV-6 outfitted to reflect the RV-7 and > >>>that it looked OK. When they did the spin tests on the actual production > >>>plane they were not satisfied with the results. They tested again using > >>>the rudder off the RV-9 and now they like it. So, Van will be sending a > >>>letter out giving us the option of switching over to the RV-9 rudder. The > >>>tech I talked to said I should definitely hold off on building the > >>>rudder.<<< > > Dana Overall > Richmond, KY > 7 emp, including rudder completed, wings delivery 6/14 > http://rvflying.tripod.com > > Steve Eberhart RV-7A - just a whole bunch of aluminum, in various states of attachment, filling up my half of the garage. Some of it looks like it might belong on the back end of an airplane. The rest looks like it might, some day, help hold it up in the air.... but what do I know. N14SE reserved ________________________________________________________________________________
Date: Jun 09, 2002
What kind of aerobatics do you want to do? If you want to do competition type aerobatics built a Pitts, if you just want to play it well do just about anything you want it to do the way it is. Personaly I think the large rudders are ugly. Jerry Steven Eberhart wrote: > > > According to the Second Issue, 2002 RVator the spin tests performed on the > RV-7 demonstrator meet FAA requirements for standard category aircraft but > not for aerobatic category :-( THe article ended saying that they were > going to try a larger rudder. Guess the RV-9 rudder is larger than the > RV-7 rudder. > > Wonder what Van's position is going to be on replacement rudders? THe > aerobatic capabilities was the main reason I chose the RV-7 over the RV-9. > > Steve > > On Sat, 8 Jun 2002, Dana Overall wrote: > > > > > I am relaying some information sent to me from someone who linked to my > > website from the Van's link page. This is the first I have heard of this > > and have not been able to document it yet from my e-mail to Van's support. > > > > I am not listing the senders name, just relaying the information sent too > > me. Anybody know what is going on??? > > > > >>>I just thought I would let you know that I called Van's yesterday to > > >>>verify what I had been hearing about the rudder on the RV-7. They > > >>>explained the spin testing on the RV-6 outfitted to reflect the RV-7 and > > >>>that it looked OK. When they did the spin tests on the actual production > > >>>plane they were not satisfied with the results. They tested again using > > >>>the rudder off the RV-9 and now they like it. So, Van will be sending a > > >>>letter out giving us the option of switching over to the RV-9 rudder. The > > >>>tech I talked to said I should definitely hold off on building the > > >>>rudder.<<< > > > > Dana Overall > > Richmond, KY > > 7 emp, including rudder completed, wings delivery 6/14 > > http://rvflying.tripod.com > > > > > > Steve Eberhart > RV-7A - just a whole bunch of aluminum, in various states of attachment, > filling up my half of the garage. Some of it looks like it might belong > on the back end of an airplane. The rest looks like it might, some day, > help hold it up in the air.... but what do I know. > N14SE reserved > ________________________________________________________________________________
From: "Wayne R. Couture" <commando@cox-internet.com>
Subject: RV-8A engine mount
Date: Jun 09, 2002
Fellow RV'ers, I didn't want to get into anything difficult today, so I thought I'd mount the engine mount. Well, as it turns out it's not that easy. I got the four corner bolts in OK after having to cut the bottom air exhaust, but what do I do with the two inboard bottom holes? They come out beneath the floor and above the bottom skin. This area is riveted, pro sealed and totally inaccessible. This is a QB by the way. Anyone been through this? Thanks in advance! Wayne RV-8A QB #80737 ________________________________________________________________________________
Subject: Re: RV-8A engine mount
Date: Jun 09, 2002
Wayne, There should be two holes (about the size of a half dollar) the bolts go in from the engine side for these two. You will have enough room to get a wrench in there. Good Building, Chuck Dave Rowbotham RV-8A (Westerly airport) From: "Wayne R. Couture" <COMMANDO@COX-INTERNET.COM> Reply-To: rv-list(at)matronics.com To: Subject: RV-List: RV-8A engine mount Date: Sun, 9 Jun 2002 12:44:03 -0500 -- RV-List message posted by: "Wayne R. Couture" <COMMANDO@COX-INTERNET.COM> Fellow RV'ers, I didn't want to get into anything difficult today, so I thought I'd mount the engine mount. Well, as it turns out it's not that easy. I got the four corner bolts in OK after having to cut the bottom air exhaust, but what do I do with the two inboard bottom holes? They come out beneath the floor and above the bottom skin. This area is riveted, pro sealed and totally inaccessible. This is a QB by the way. Anyone been through this? Thanks in advance! Wayne RV-8A QB #80737 ________________________________________________________________________________
Date: Jun 09, 2002
Subject: Sealing fuel tank access covers
The general consensus (in the archives) for sealing fuel tank access covers is to use only proseal (without cork gasket), then screw covers on. Questions: (1) What keeps fuel from seeping out around the screws or must I also cover the screws and nutplates with proseal? If so, will I later be able to remove the screws? (2) How are all of you measuring small amounts of proseal by weight as per instructions of 10 to 1 by weight? Pete Hunt RV-6 216PH (reserved) Starting instrument panel ________________________________________________________________________________
Date: Jun 09, 2002
Subject: Low fuel indicators and canopy alternatives
Listers--Check out www.aircraftextras.com. Very neat optical fuel sensor has been added, along with optically perfect canopies which can be ordered either clear or tinted. We're putting optical low fuel sensors in our RV-6, as well as tip-up slider modification. LeRoy Johnston, Ohio, wings almost done. ________________________________________________________________________________
Date: Jun 09, 2002
From: "Todd Wenzel" <TWenzel@heartland-software.com>
Wayne, I mounted my QB engine mount about a month ago. You should have an access hole (for each bolt) on the bottom of the fuse right where the inboard bottom bolts would go. The access holes are about 3/4-1" diameter. You will have a little bit a playing around when installing the washers and nuts with needle-nose pliers through the access holes. Good Luck! Todd Wenzel Delafield, WI RV-8AQB - Finish Kit/Canopy mailto:TWenzel@Heartland-Software.com -----Original Message----- From: Wayne R. Couture [mailto:commando@cox-internet.com] Subject: RV-List: RV-8A engine mount Fellow RV'ers, I didn't want to get into anything difficult today, so I thought I'd mount the engine mount. Well, as it turns out it's not that easy. I got the four corner bolts in OK after having to cut the bottom air exhaust, but what do I do with the two inboard bottom holes? They come out beneath the floor and above the bottom skin. This area is riveted, pro sealed and totally inaccessible. This is a QB by the way. Anyone been through this? Thanks in advance! Wayne RV-8A QB #80737 ________________________________________________________________________________
Date: Jun 09, 2002
Pete, I went the over-kill method and used the cork gasket with proseal. I know that the gasket will be sacrificed if I need to remove the plate. It should work just fine without the gasket provided you use proseal. For the screws, apply proseal around the threads before you screw them in. I don't know how easy it will be removing them later, but you don't have any choice. You shouldn't need to cover the plate nuts since they are completely covered by the plate which will have proseal on it. As far as mixing: I bought a pretty cool electronic postal scale at Wal-Mart for $20. You can tare any container and switch to grams for finer resolution - it works great and highly recommended. I mixed my small batches in old yogurt containers. Good luck! Todd Wenzel Delafield, WI RV-8AQB - Finish Kit/Canopy mailto:TWenzel@Heartland-Software.com -----Original Message----- From: PeterHunt1(at)aol.com [mailto:PeterHunt1(at)aol.com] Subject: RV-List: Sealing fuel tank access covers The general consensus (in the archives) for sealing fuel tank access covers is to use only proseal (without cork gasket), then screw covers on. Questions: (1) What keeps fuel from seeping out around the screws or must I also cover the screws and nutplates with proseal? If so, will I later be able to remove the screws? (2) How are all of you measuring small amounts of proseal by weight as per instructions of 10 to 1 by weight? Pete Hunt RV-6 216PH (reserved) Starting instrument panel ________________________________________________________________________________
Date: Jun 09, 2002
Subject: Re: Sealing fuel tank access covers
Don't forget to pressure check your tanks after the proseal sets up. I found a couple of leaking screws. Check the archives for more info on pressure checking tanks. Cash Copeland > Pete, > I went the over-kill method and used the cork gasket with proseal. I know > that the gasket will be sacrificed if I need to remove the plate. It should > work just fine without the gasket provided you use proseal. For the screws, > apply proseal around the threads before you screw them in. I don't know how > easy it will be removing them later, but you don't have any choice. You > shouldn't need to cover the plate nuts since they are completely covered by > the plate which will have proseal on it. As far as mixing: I bought a > pretty cool electronic postal scale at Wal-Mart for $20. You can tare any > container and switch to grams for finer resolution - it works great and > highly recommended. I mixed my small batches in old yogurt containers. Good > luck! > > Todd Wenzel > Delafield, WI > RV-8AQB - Finish Kit/Canopy > mailto:TWenzel@Heartland-Software.com > > > -----Original Message----- > From: PeterHunt1(at)aol.com [mailto:PeterHunt1(at)aol.com] > To: RV-list(at)matronics.com > Subject: RV-List: Sealing fuel tank access covers > > > > The general consensus (in the archives) for sealing fuel tank access covers > > is to use only proseal (without cork gasket), then screw covers on. > Questions: (1) What keeps fuel from seeping out around the screws or must > I > also cover the screws and nutplates with proseal? If so, will I later be > able to remove the screws? (2) How are all of you measuring small amounts > of > proseal by weight as per instructions of 10 to 1 by weight? > > Pete Hunt > RV-6 216PH (reserved) > Starting instrument panel ________________________________________________________________________________
Subject: Re: Sensenich spinner for metal prop
Date: Jun 09, 2002
I have used the Sensenich spinner and it is extremely well made however it is heavy. In my experience they have always been great to deal with. And I believe they have a money back guarantee. John Furey 2nd RV6A O-320 Sensenich 28hrs----- Original Message ----- From: Stephen J. Soule <SSoule(at)pfclaw.com> Subject: RV-List: Sensenich spinner for metal prop > > Hello everyone, > > I'm upgrading to the Sensenich 70CM7S9 metal propeller. I see that Sensenich > lists on their web site a complete spinner assembly for that prop. The rear > bulkhead is 13 inches. Has anyone out there is RV-land used this spinner? > What did you think of it? > > Stephen Soule > Huntington, Vermont > RV-6A N227RV > > ________________________________________________________________________________
Date: Jun 09, 2002
Yeah, and check the fuel senders too !! found that with proseal on the screws I lost continuety, grounding that is, for the fuel sender. Couldn't figure out why I had correct resistance between the sender pick up and the sender body but nothing between the sender pick-up and the airframe... ran a separate grounding wire from the sender body to the wing to ensure proper grounding. Gert -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Jun 09, 2002
10 to 1 scale on a budget: I used a paint stirring stick (6" long or so) and drilled holes spaced at 0, .5, and 5" spacing. I hung a dixie cup from stations 0 and 5", and used the .5" station for the pivot point (suspended from a piece of safety wire). Then balance the dixie cups with washers, pennys, whatever, until the cups balance. Then add activator to station 5" and adhesive to station 0 in quantities that bring the cups pack to level. 10 to 1 by weight on a budget. Tim ****** Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD - First Flight 18 Dec 99 http://www.geocities.com/timrv6a ****** ________________________________________________________________________________
Date: Jun 09, 2002
There should be access holes in the bottom to put the nuts on and tighten. Len Leggette RV-8A N901LL (res) Greensboro, N.C. Hanger # 23 at INT ________________________________________________________________________________
Subject: RV-11 Motorglider
Date: Jun 09, 2002
Hey guys, I'm surprised no one has mentioned this interesting paragraph on page 17 of the June 2002 issue of EAA's Sport Aviation, (listing the discussions at the aviation forum on this year's Oshkosh): "Dick VanGrunsven will discuss the four-place RV-10 and the RV-11 motorglider, new airplanes in development at Van's Aircraft." I thought I was paying pretty good attention but I hadn't heard a word about the RV-11. Terry ________________________________________________________________________________
Subject: Re: RV-11 Motorglider
Date: Jun 09, 2002
I was expecting a motorglider or at least an aluminum sailplane, based on Vans's extensive discussion, in the RVator, of the design challenges involved in gliders, specifically metal ones, which are rare today except as trainers. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm > > Hey guys, > > I'm surprised no one has mentioned this interesting paragraph on page 17 of > the June 2002 issue of EAA's Sport Aviation, (listing the discussions at the > aviation forum on this year's Oshkosh): > > "Dick VanGrunsven will discuss the four-place RV-10 and the RV-11 > motorglider, new airplanes in development at Van's Aircraft." > > I thought I was paying pretty good attention but I hadn't heard a word about > the RV-11. > > Terry > > ________________________________________________________________________________
Date: Jun 10, 2002
I just mixed the proseal to obtain the "battleship gray" I kept seeing referenced in the archives. I didn't measure by wieght or vol. Seems to have worked ok. It passed the "spray with soapy water, look for bubbles" test. On the inspection covers, I used the cork gasket, slathered with fuel lube. Numerous people told me I was destined for a leaky failure. One guy said it should work fine -- that's the way he did it on the helicopters he maintained. I've considered changing it, but haven't yet...... - Larry Bowen RV-8, canopy soon..... Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > > > 10 to 1 scale on a budget: I used a paint stirring stick (6" > long or so) > and drilled holes spaced at 0, .5, and 5" spacing. I hung a > dixie cup > from stations 0 and 5", and used the .5" station for the pivot point > (suspended from a piece of safety wire). Then balance the dixie cups > with washers, pennys, whatever, until the cups balance. Then add > activator to station 5" and adhesive to station 0 in quantities that > bring the cups pack to level. 10 to 1 by weight on a budget. > > Tim > ****** > Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD - First Flight 18 Dec 99 http://www.geocities.com/timrv6a > ****** > ________________________________________________________________________________
Date: Jun 09, 2002
I saw the plane in the prototype shop several years ago, but no said much about it, so I thought perhaps it was for someone else. It had a 4 cylinder 4 cycle tractor style engine(Jabiru I think). I didn't see the prop so don't know if it was a retractable style. The fuse was all metal of course. There is an Irv Prue sailplane in Tehachapi that is the most beatutiful sheet metal work I have ever seen, even some 30 years later. Kevin ----- Original Message ----- From: "Terry Watson" <terrywatson3(at)attbi.com> Subject: RV-List: RV-11 Motorglider > > Hey guys, > > I'm surprised no one has mentioned this interesting paragraph on page 17 of > the June 2002 issue of EAA's Sport Aviation, (listing the discussions at the > aviation forum on this year's Oshkosh): > > "Dick VanGrunsven will discuss the four-place RV-10 and the RV-11 > motorglider, new airplanes in development at Van's Aircraft." > > I thought I was paying pretty good attention but I hadn't heard a word about > the RV-11. > > Terry > > ________________________________________________________________________________
Subject: Re: Shattered Sliding Canopy
Date: Jun 10, 2002
08:10:27 AM Hate to be morbid, but how did it happen? I've heard of lots of cracks forming, but shattered? Sorry to hear of your loss, that sucks plenty. Ya might want to keep the windscreen incase you "Laird" into a bird some day. Eric ________________________________________________________________________________
Date: Jun 10, 2002
You might also want to check with these folks...their canopy appears to cost less and is guaranteed not to break and will be replaced free if it does: http://www.aircraftextras.com If you contact them, let us know how it works out... Max ----- Original Message ----- From: <Eric.J.Henson(at)chase.com> Subject: Re: RV-List: Shattered Sliding Canopy > > > Hate to be morbid, but how did it happen? I've heard of lots of cracks > forming, but shattered? Sorry to hear of your loss, that sucks plenty. Ya > might want to keep the windscreen incase you "Laird" into a bird some day. > > Eric > > ________________________________________________________________________________
Date: Jun 10, 2002
I used the Sensenich spinner assembly with their prop on my RV-4, the whole assembly just bolts on, much faster than trimming, cutting and fabricating the fiberglass spinner. It is spun alum. with floating nutplates, ypu cam polish or paint it. Wayne RV-4 flying. Lake Tahoe Calif. I'm upgrading to the Sensenich 70CM7S9 metal propeller. I see that Sensenich lists on their web site a complete spinner assembly for that prop. The rear bulkhead is 13 inches. Has anyone out there is RV-land used this spinner? What did you think of it? ________________________________________________________________________________
Date: Jun 10, 2002
Subject: Re: 10 Hr Report & Lean Carb (long)
gmcnutt(at)intergate.ca writes: > My engine is much better since I drilled the carb jet from #42 to #38 but > that is still not enough. > > As I mentioned in my 10 hour report the engine was previously running on > the > lean side of peak temperature, any leaning with the mixture control and the > cylinder head temperature immediately dropped. > > Since drilling the carb jet to #38 I think that the engine is now running > just on the rich side of peak temperature. Leaning with mixture control at > 10,000 feet now gives me a 5 degree F increase in head temperature before > temperature peaks and starts to lean drop. Cylinder temperatures in climb & > cruise are now 5 - 10 degrees cooler. > > Next week I will remove the carb and open the jet up some more, think I > will > try a #37 drill bit but am tempted to jump to a #36. > > George McNutt > George- I would urge you to ignore (relatively) the CHT's and focus on EGT for leaning and jetting purposes. There is much on this in the archives (try my screen name and a few key words like carb, jet, drill for in interesting read on my personal experience. I overdid it and ended up with a rich carb.) My problems in this regard were solved by getting the richer carb (again, the Marvel part no. will be in the archives) which I bought from a builder with a stock Lycoming 160 hp from Vans who decided to go to fuel injection before his first flight, so I got a brand new carb at an excellent price. I worry you may hurt yourself or your engine if you try to jet based on cylinder head temps. As far as I know, only exhaust gas temps are suitable for this purpose. Be safe- Bill B ________________________________________________________________________________
Subject: nomex flight suits and seat belts
Date: Jun 10, 2002
Another source for fire resistant stuff is Simpson Racing www.simpsonraceproducts.com You can get anything imaginable... helmets, gloves, boots, socks and even custom made nomex suits... a bit pricey, but nice and much cheaper than skin grafts. I just bought a set of 5 point seat belts for the Rocket from them. Cost about $100. Don't get the Latch F/X system seat belts as the buckle is too big for aircraft use (IMHO). Get the Standard Latch and Link and you'll be fine. It's just like the stuff we're use to. They also make a cam lock seat belt... it looks OK but is twice the price. FWIW, I went to the army surplus and bought a nomex flight suit and nomex gloves. Chicks dig the flight suits... even my wife! LOL Vince F-1H Rocket ________________________________________________________________________________
Subject: Century III manual Needed
Date: Jun 10, 2002
Anybody have an installation manaul for a Century III AP I can get a copy of? I am trying to do some troubleshooting and need some wiring diagrams. Thanks. Richard Bibb ________________________________________________________________________________
Date: Jun 10, 2002
You have plenty of company, including myself. When I did it I called the company that makes the windshield and explained the problem. The person I spoke with said he was helping his friend that weekend and did the same thing. He took mercy on me and found one that had a blemish on the part that I did not need and saved me quite a bit. The billing still came through Vans. May be worth a try ? John Furey RV6A ________________________________________________________________________________
Date: Jun 10, 2002
rv8list , rv-list
Subject: Prop Swap Numbers...
I have posted some information on a prop swap I made this weekend and would like some input on the results... http://vondane.com/rv8a/flightdata/index.htm What is the consensus on running the Lycosour above 2700 RPM? It's REAL smooth at that RPM... Thanks... -Bill VonDane RV-8A N8WV http://vondane.com/rv8a ________________________________________________________________________________
Subject: ELT antenna orientation
Date: Jun 10, 2002
I never saw anyone answer the question: Can an antenna splitter be used on the ELT to feed 2 or more antennae? David Carter ----- Original Message ----- From: "Konrad Werner" <Connywerner(at)wans.net> Subject: Re: RV-List: ELT antenna orientation > > Dear electronically inclined Listers! > I know this has been probably beat to death already, but I'm rather (let's > say) challenged, when it comes to radiowaves & electronics. > Here my question: > Is it possible to put in more than one ELT antenna with some kind of > signal-splitter? > Like one antenna in each wingtip, and maybe even a third one in the > tailcone, just to cover thy Bacon(s) in ANY crash scenario? > (Of course hoping to never have to use the ELT anyway!) > Any input would be appreciated. > Konrad ________________________________________________________________________________
Date: Jun 10, 2002
Subject: Spark Plug Grommets for baffles
Hello Listers, I have been looking for the double grommets that go in the baffle for the upper spark plug wires. I don't know what they are even called, or where to get them. Can someone help with a source? Thanks Tim Bryan RV-6 Just about baffled out N616TB ________________________________________________________________________________
Subject: Re: Prop Swap Numbers...
Date: Jun 10, 2002
I couldn't connect to the archives right now so I can't find the story, but a lister told us about his experience running high RPM. The part I remember is that the pilot had a mechanic passenger with him who commented, just before the castastrophic engine failure, about how smooth it was running. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm > > >I have posted some information on a prop swap I made this weekend and >would like some input on the results... > >http://vondane.com/rv8a/flightdata/index.htm > >What is the consensus on running the Lycosour above 2700 RPM? It's REAL >smooth at that RPM... > >Thanks... > > >-Bill VonDane >RV-8A N8WV >http://vondane.com/rv8a > > ________________________________________________________________________________
Date: Jun 10, 2002
Subject: Re: Spark Plug Grommets for baffles
In a message dated 6/10/02 5:08:50 PM Eastern Daylight Time, tim(at)bryantechnology.com writes: > tim(at)bryantechnology.com Tim, You can get them through Aircraft Spruce page 239 for $3.95. However, I have two brand new, never opened that I'm not going to use. I'll sell for half price plus $1.00 shipping. Rick McBride rickrv6(at)aol.com ________________________________________________________________________________
Date: Jun 11, 2002
While on holidays over there from Aus we did some flying at Aurora near Denver. There is a shop there that has aircraft parts and they got some for us . Sorry have not got the phone no but the bloke that runs the shop runs the field so just look them up. Chris and Susie VH-MUM ----- Original Message ----- From: "Tim Bryan" <tim(at)bryantechnology.com> Subject: RV-List: Spark Plug Grommets for baffles > > > Hello Listers, > > I have been looking for the double grommets that go in the baffle for the > upper spark plug wires. I don't know what they are even called, or where to > get them. Can someone help with a source? > > Thanks > Tim Bryan > RV-6 Just about baffled out > N616TB > > ________________________________________________________________________________
Date: Jun 10, 2002
Larry Pardue wrote: >I couldn't connect to the archives right now so I can't find the story, >but a lister told us about his experience running high RPM. > >The part I remember is that the pilot had a mechanic passenger with him >who commented, just before the castastrophic engine failure, about how >smooth it was running. > >Larry Pardue >Carlsbad, NM > I believe it was Tom Martin when flying his RV4. He did not replace some of the valve springs when the engine was rebuilt and they are not that strong to begin with. I believe the valves floated, and so did he, safely into his own bean field. Roger ________________________________________________________________________________
Date: Jun 10, 2002
Subject: Terra
I would like to buy a working Terra TX 760D as a back-up while my existing one is repaired. If you have one gathering dust, give me a call or e-mail. e-mail: billy.wilson(at)lmco.com Home: 817-732-3879 Work: 972-603-9719 Cell: 817-808-9580 Billy Wilson Senior Engineering Specialist Lockheed Martin Missiles and Fire Control - Dallas Work: 972-603-9719 Fax: 972-603-9275 email: billy.wilson(at)lmco.com ________________________________________________________________________________
Date: Jun 10, 2002
Sounds like that new prop is quite a climb prop. I'd stay away from a constant cruise of 2800 rpm. First, it's 100 rpm over redline and second you'll do nothing but burn more fuel for only 5 mph gain over the original prop. Even at 2700 rpm redline, and 2 mph slower than the original prop, you're still going to be burning more fuel than the original prop. With the wheel pants installed the climb is the same with both props so this fact begs the question....why would you want to turn the higher rpm's and higher fuel burn for only 5 mph gain? Are you sure about the climb rates? With the higher rpm's of the second prop I would expect to see higher climb rates. BTW, the heading at the top of the columns is wrong. You've got the Warnke and Sterba as having the same pitch. Mike Nellis - http://bmnellis.com Georgetown, TX Building Fuselage ..... Finally RV6 N699BM Reserved 1947 Stinson 108-2 N9666K ----- Original Message ----- From: "Bill VonDane" <n8wv(at)earthlink.net> ; "rv-list" Subject: RV-List: Prop Swap Numbers... > > I have posted some information on a prop swap I made this weekend and would like some input on the results... > > http://vondane.com/rv8a/flightdata/index.htm > > What is the consensus on running the Lycosour above 2700 RPM? It's REAL smooth at that RPM... > > Thanks... > > > -Bill VonDane > RV-8A N8WV > http://vondane.com/rv8a > > ________________________________________________________________________________
Date: Jun 10, 2002
I can't get into the archives either, but I saved some of the messages from that thread. He did say the engine was running real smooth before the valve failed. He said he would never exceed redline again. Whenever the archives come back up, search for Tom Martin and you'll find the goods. The interesting parts I saved explain how helicopter versions of our engines use a higher redline, but the cams are different. Apparently the different cam profile is easier on the valves. I certainly wouldn't deliberately exceed redline, but its all a question of your risk tolerance. Kevin > >I couldn't connect to the archives right now so I can't find the story, >but a lister told us about his experience running high RPM. > >The part I remember is that the pilot had a mechanic passenger with him >who commented, just before the castastrophic engine failure, about how >smooth it was running. > >Larry Pardue >Carlsbad, NM > >RV-6 N441LP Flying >http://www.carlsbadnm.com/n5lp/index.htm > > >> >> >>I have posted some information on a prop swap I made this weekend and >>would like some input on the results... >> >>http://vondane.com/rv8a/flightdata/index.htm >> >>What is the consensus on running the Lycosour above 2700 RPM? It's REAL >>smooth at that RPM... >> >>Thanks... >> >> >>-Bill VonDane >>RV-8A N8WV >>http://vondane.com/rv8a > > >> ________________________________________________________________________________
Date: Jun 10, 2002
> >In a message dated 6/10/02 5:08:50 PM Eastern Daylight Time, >tim(at)bryantechnology.com writes: > > >> tim(at)bryantechnology.com > >Tim, > >You can get them through Aircraft Spruce page 239 for $3.95. However, I have >two brand new, never opened that I'm not going to use. I'll sell for half >price plus $1.00 shipping. > >Rick McBride >rickrv6(at)aol.com > Beware the ones sold by Spruce. I bought one, listed as for 5 mm wires. It had the correct part number on it, but it had 7.5 mm holes. And they screwed up the shipping which cost me an extra $40. ACS is now my supplier of last resort. -- Kevin Horton RV-8 (installing engine & electrics) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
Date: Jun 10, 2002
This would be Kevin Kennelly, KenAero, 303-361-9630 John -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of chris mcgough Subject: Re: RV-List: Spark Plug Grommets for baffles While on holidays over there from Aus we did some flying at Aurora near Denver. There is a shop there that has aircraft parts and they got some for us . Sorry have not got the phone no but the bloke that runs the shop runs the field so just look them up. Chris and Susie VH-MUM ----- Original Message ----- From: "Tim Bryan" <tim(at)bryantechnology.com> Subject: RV-List: Spark Plug Grommets for baffles > > > Hello Listers, > > I have been looking for the double grommets that go in the baffle for the > upper spark plug wires. I don't know what they are even called, or where to > get them. Can someone help with a source? > > Thanks > Tim Bryan > RV-6 Just about baffled out > N616TB > > ________________________________________________________________________________
Date: Jun 10, 2002
Subject: Re: RV-List Digest: 23 Msgs - 06/09/02
Hello Listers, l am currently flying an RV-4 with a sensenich wood prop and a Mark Landoll Harmonic Balancer installed with it. l am wondering if any of you have had any experience with being able to have this set up balanced and what were the results? My mechanic says that he can,t see any reason why his balance machine would not work with this setup, but also added that he has never done a balance job on this kind of setup......... Any comments based on experience?..... Thanks in advance guys........... George ________________________________________________________________________________
Date: Jun 10, 2002
I may be off on the climb rate of the Warnke... I need to do some more testing... The plane seems to accelerate mush faster and is definitely off the ground sooner, so it SHOULD be climbing better... The Warnke and Sterba both have the same dimensions: 68x72 -Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Nellis Subject: Re: RV-List: Prop Swap Numbers... Sounds like that new prop is quite a climb prop. I'd stay away from a constant cruise of 2800 rpm. First, it's 100 rpm over redline and second you'll do nothing but burn more fuel for only 5 mph gain over the original prop. Even at 2700 rpm redline, and 2 mph slower than the original prop, you're still going to be burning more fuel than the original prop. With the wheel pants installed the climb is the same with both props so this fact begs the question....why would you want to turn the higher rpm's and higher fuel burn for only 5 mph gain? Are you sure about the climb rates? With the higher rpm's of the second prop I would expect to see higher climb rates. BTW, the heading at the top of the columns is wrong. You've got the Warnke and Sterba as having the same pitch. Mike Nellis - http://bmnellis.com Georgetown, TX Building Fuselage ..... Finally RV6 N699BM Reserved 1947 Stinson 108-2 N9666K ----- Original Message ----- From: "Bill VonDane" <n8wv(at)earthlink.net> ; "rv-list" Subject: RV-List: Prop Swap Numbers... > > I have posted some information on a prop swap I made this weekend and would like some input on the results... > > http://vondane.com/rv8a/flightdata/index.htm > > What is the consensus on running the Lycosour above 2700 RPM? It's > REAL smooth at that RPM... > > Thanks... > > > -Bill VonDane > RV-8A N8WV > http://vondane.com/rv8a > > ________________________________________________________________________________
Date: Jun 10, 2002
I question your statement; "Even at 2700 rpm redline, and 2 mph slower than the original prop, you're still going to be burning more fuel than the original prop"... Would it not be true that if I were running the engine at full throttle; 21.9" MAP @ 2530 RPM I would burn more fuel that if I were running the engine at 20.9" MAP @ 2700 RPM? Doesn't throttle position and manifold pressure equate to fuel burn more that RPM? -Bill -----Original Message----- From: Bill VonDane [mailto:n8wv(at)earthlink.net] Subject: RE: RV-List: Prop Swap Numbers... I may be off on the climb rate of the Warnke... I need to do some more testing... The plane seems to accelerate mush faster and is definitely off the ground sooner, so it SHOULD be climbing better... The Warnke and Sterba both have the same dimensions: 68x72 -Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Nellis Subject: Re: RV-List: Prop Swap Numbers... Sounds like that new prop is quite a climb prop. I'd stay away from a constant cruise of 2800 rpm. First, it's 100 rpm over redline and second you'll do nothing but burn more fuel for only 5 mph gain over the original prop. Even at 2700 rpm redline, and 2 mph slower than the original prop, you're still going to be burning more fuel than the original prop. With the wheel pants installed the climb is the same with both props so this fact begs the question....why would you want to turn the higher rpm's and higher fuel burn for only 5 mph gain? Are you sure about the climb rates? With the higher rpm's of the second prop I would expect to see higher climb rates. BTW, the heading at the top of the columns is wrong. You've got the Warnke and Sterba as having the same pitch. Mike Nellis - http://bmnellis.com Georgetown, TX Building Fuselage ..... Finally RV6 N699BM Reserved 1947 Stinson 108-2 N9666K ----- Original Message ----- From: "Bill VonDane" <n8wv(at)earthlink.net> ; "rv-list" Subject: RV-List: Prop Swap Numbers... > > I have posted some information on a prop swap I made this weekend and would like some input on the results... > > http://vondane.com/rv8a/flightdata/index.htm > > What is the consensus on running the Lycosour above 2700 RPM? It's > REAL smooth at that RPM... > > Thanks... > > > -Bill VonDane > RV-8A N8WV > http://vondane.com/rv8a > > ________________________________________________________________________________
Date: Jun 10, 2002
In a message dated 6/10/02 7:39:27 PM Eastern Daylight Time, khorto1537(at)rogers.com writes: > Beware the ones sold by Spruce. I bought one, listed as for 5 mm > wires. It had the correct part number on it, but it had 7.5 mm > holes. And they screwed up the shipping which cost me an extra $40. > ACS is now my supplier of last resort. > -- > Kevin Horton RV-8 (installing engine & electrics) > Ottawa, Canada > http://members.rogers.com/khorton/rv8.html > Bummer on the shipping. I checked the holes in mine, and you're right, they're 7.5mm. According to their catalog all they sell is 5mm. However, I checked my old harness, which I'm not using, and the wires are 7mm. It appears you can get lightweight later harnesses which are 5mm or the older style which are 7mm. I learned something new today. Rick ________________________________________________________________________________
Date: Jun 10, 2002
If you have the Harmonic Balancer and not just the flywheel; additional balancing probably won't help. Contact Mark Landoll. The harmonic Balancer works at all rpms not just the normal cruise number. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org Always looking for articles for the Experimenter ----- Original Message ----- From: <SSPRING83(at)aol.com> Subject: RV-List: Re: RV-List Digest: 23 Msgs - 06/09/02 Hello Listers, l am currently flying an RV-4 with a sensenich wood prop and a Mark Landoll Harmonic Balancer installed with it. l am wondering if any of you have had any experience with being able to have this set up balanced and what were the results? My mechanic says that he can,t see any reason why his balance machine would not work with this setup, but also added that he has never done a balance job on this kind of setup......... Any comments based on experience?..... Thanks in advance guys........... George ________________________________________________________________________________
Date: Jun 10, 2002
The Lycoming power charts should, in theory, allow you to figure out the power produced at each of these conditions. In practice, they are a PITA to use. However, the relationship between these power settings should be about the same for the O-360 as it is for the O-320, given the large similarity between the two engines. Looking at the spreadsheet I wrote to emulate the power charts for the O-360, I see the following powers: 8,000 ft, std temperature, 21.9 MAP, 2530 rpm = 139 hp 8,000 ft, std temperature, 20.9 MAP, 2700 rpm = 136 hp So, it is likely that the 2530 rpm case is still producing more power on the O-320, and hence is burning more fuel. As far as the climb rates go, don't rely too heavily on the VSI. I've seen sigificant VSI errors. You will get a better number by using the altimeter and a stop watch. Kevin > >I question your statement; "Even at 2700 rpm redline, and 2 mph slower >than the original prop, you're still going to be burning more fuel than >the original prop"... > >Would it not be true that if I were running the engine at full throttle; >21.9" MAP @ 2530 RPM I would burn more fuel that if I were running the >engine at 20.9" MAP @ 2700 RPM? Doesn't throttle position and manifold >pressure equate to fuel burn more that RPM? > >-Bill > > >-----Original Message----- >From: Bill VonDane [mailto:n8wv(at)earthlink.net] >To: 'rv-list(at)matronics.com' >Subject: RE: RV-List: Prop Swap Numbers... > > >I may be off on the climb rate of the Warnke... I need to do some more >testing... The plane seems to accelerate mush faster and is definitely >off the ground sooner, so it SHOULD be climbing better... > >The Warnke and Sterba both have the same dimensions: 68x72 > >-Bill > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Nellis >To: rv-list(at)matronics.com >Subject: Re: RV-List: Prop Swap Numbers... > > >Sounds like that new prop is quite a climb prop. I'd stay away from a >constant cruise of 2800 rpm. First, it's 100 rpm over redline and >second you'll do nothing but burn more fuel for only 5 mph gain over the >original prop. Even at 2700 rpm redline, and 2 mph slower than the >original prop, you're still going to be burning more fuel than the >original prop. With the wheel pants installed the climb is the same >with both props so this fact begs the question....why would you want to >turn the higher rpm's and higher fuel burn for only 5 mph gain? > >Are you sure about the climb rates? With the higher rpm's of the second >prop I would expect to see higher climb rates. > >BTW, the heading at the top of the columns is wrong. You've got the >Warnke and Sterba as having the same pitch. > >Mike Nellis - http://bmnellis.com >Georgetown, TX >Building Fuselage ..... Finally >RV6 N699BM Reserved >1947 Stinson 108-2 N9666K >----- Original Message ----- >From: "Bill VonDane" <n8wv(at)earthlink.net> >To: "vansairforce" ; "rv8list" >; "rv-list" >Subject: RV-List: Prop Swap Numbers... > > >> >> I have posted some information on a prop swap I made this weekend and >would like some input on the results... >> >> http://vondane.com/rv8a/flightdata/index.htm >> >> What is the consensus on running the Lycosour above 2700 RPM? It's >> REAL >smooth at that RPM... >> >> Thanks... >> >> >> -Bill VonDane >> RV-8A N8WV >> http://vondane.com/rv8a >> >> > > >>>>> > -- Kevin Horton RV-8 (installing engine & electrics) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
Date: Jun 10, 2002
I don't think so. I'm not the expert here, but the mixture setting for 2500 rpm is going to be less than that of an engine turning 2700 rpm regardless of throttle position. In this scenario the throttle is WFO in both cases. Leaned to 50 deg rich/lean of peak (take your pick) it stands to reason that the engine turning 2500 rpm is going to require less fuel. It would take a fuel flow gauge to verify that though. Think of it like a constant speed prop. If I have the throttle WFO and set the prop for 2700 rpm I'll burn more fuel than if I set the prop at 2500 rpm. If Along the same line, if I'm running my CS prop engine in cruise at 2700 rpm and back it down to 2500 rpm I'll have to readadjust my mixture (less fuel). Mike Nellis - http://bmnellis.com Georgetown, TX Waiting to start Fuselage RV6 N699BM Reserved 1947 Stinson 108-2 N9666K ----- Original Message ----- From: "Bill VonDane" <n8wv(at)earthlink.net> Subject: RE: RV-List: Prop Swap Numbers... > > I question your statement; "Even at 2700 rpm redline, and 2 mph slower > than the original prop, you're still going to be burning more fuel than > the original prop"... > > Would it not be true that if I were running the engine at full throttle; > 21.9" MAP @ 2530 RPM I would burn more fuel that if I were running the > engine at 20.9" MAP @ 2700 RPM? Doesn't throttle position and manifold > pressure equate to fuel burn more that RPM? > > -Bill > > > -----Original Message----- > From: Bill VonDane [mailto:n8wv(at)earthlink.net] > To: 'rv-list(at)matronics.com' > Subject: RE: RV-List: Prop Swap Numbers... > > > I may be off on the climb rate of the Warnke... I need to do some more > testing... The plane seems to accelerate mush faster and is definitely > off the ground sooner, so it SHOULD be climbing better... > > The Warnke and Sterba both have the same dimensions: 68x72 > > -Bill > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Nellis > To: rv-list(at)matronics.com > Subject: Re: RV-List: Prop Swap Numbers... > > > Sounds like that new prop is quite a climb prop. I'd stay away from a > constant cruise of 2800 rpm. First, it's 100 rpm over redline and > second you'll do nothing but burn more fuel for only 5 mph gain over the > original prop. Even at 2700 rpm redline, and 2 mph slower than the > original prop, you're still going to be burning more fuel than the > original prop. With the wheel pants installed the climb is the same > with both props so this fact begs the question....why would you want to > turn the higher rpm's and higher fuel burn for only 5 mph gain? > > Are you sure about the climb rates? With the higher rpm's of the second > prop I would expect to see higher climb rates. > > BTW, the heading at the top of the columns is wrong. You've got the > Warnke and Sterba as having the same pitch. > > Mike Nellis - http://bmnellis.com > Georgetown, TX > Building Fuselage ..... Finally > RV6 N699BM Reserved > 1947 Stinson 108-2 N9666K > ----- Original Message ----- > From: "Bill VonDane" <n8wv(at)earthlink.net> > To: "vansairforce" ; "rv8list" > ; "rv-list" > Subject: RV-List: Prop Swap Numbers... > > > > > > I have posted some information on a prop swap I made this weekend and > would like some input on the results... > > > > http://vondane.com/rv8a/flightdata/index.htm > > > > What is the consensus on running the Lycosour above 2700 RPM? It's > > REAL > smooth at that RPM... > > > > Thanks... > > > > > > -Bill VonDane > > RV-8A N8WV > > http://vondane.com/rv8a > > > > > > ________________________________________________________________________________
Date: Jun 10, 2002
I'm not sure what you mean by WFO, but in the case of the 2700 RPM example, the engine is throttled back to get the 2700... Full throttle would produce 2800 RPM... -Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Nellis Subject: Re: RV-List: Prop Swap Numbers... I don't think so. I'm not the expert here, but the mixture setting for 2500 rpm is going to be less than that of an engine turning 2700 rpm regardless of throttle position. In this scenario the throttle is WFO in both cases. Leaned to 50 deg rich/lean of peak (take your pick) it stands to reason that the engine turning 2500 rpm is going to require less fuel. It would take a fuel flow gauge to verify that though. Think of it like a constant speed prop. If I have the throttle WFO and set the prop for 2700 rpm I'll burn more fuel than if I set the prop at 2500 rpm. If Along the same line, if I'm running my CS prop engine in cruise at 2700 rpm and back it down to 2500 rpm I'll have to readadjust my mixture (less fuel). Mike Nellis - http://bmnellis.com Georgetown, TX Waiting to start Fuselage RV6 N699BM Reserved 1947 Stinson 108-2 N9666K ----- Original Message ----- From: "Bill VonDane" <n8wv(at)earthlink.net> Subject: RE: RV-List: Prop Swap Numbers... > > I question your statement; "Even at 2700 rpm redline, and 2 mph slower > than the original prop, you're still going to be burning more fuel > than the original prop"... > > Would it not be true that if I were running the engine at full > throttle; 21.9" MAP @ 2530 RPM I would burn more fuel that if I were > running the engine at 20.9" MAP @ 2700 RPM? Doesn't throttle position > and manifold pressure equate to fuel burn more that RPM? > > -Bill > > > -----Original Message----- > From: Bill VonDane [mailto:n8wv(at)earthlink.net] > To: 'rv-list(at)matronics.com' > Subject: RE: RV-List: Prop Swap Numbers... > > > I may be off on the climb rate of the Warnke... I need to do some > more testing... The plane seems to accelerate mush faster and is > definitely off the ground sooner, so it SHOULD be climbing better... > > The Warnke and Sterba both have the same dimensions: 68x72 > > -Bill > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Nellis > To: rv-list(at)matronics.com > Subject: Re: RV-List: Prop Swap Numbers... > > > Sounds like that new prop is quite a climb prop. I'd stay away from a > constant cruise of 2800 rpm. First, it's 100 rpm over redline and > second you'll do nothing but burn more fuel for only 5 mph gain over > the original prop. Even at 2700 rpm redline, and 2 mph slower than > the original prop, you're still going to be burning more fuel than the > original prop. With the wheel pants installed the climb is the same > with both props so this fact begs the question....why would you want > to turn the higher rpm's and higher fuel burn for only 5 mph gain? > > Are you sure about the climb rates? With the higher rpm's of the > second prop I would expect to see higher climb rates. > > BTW, the heading at the top of the columns is wrong. You've got the > Warnke and Sterba as having the same pitch. > > Mike Nellis - http://bmnellis.com > Georgetown, TX > Building Fuselage ..... Finally > RV6 N699BM Reserved > 1947 Stinson 108-2 N9666K > ----- Original Message ----- > From: "Bill VonDane" <n8wv(at)earthlink.net> > To: "vansairforce" ; "rv8list" > ; "rv-list" > Subject: RV-List: Prop Swap Numbers... > > > > > > I have posted some information on a prop swap I made this weekend > > and > would like some input on the results... > > > > http://vondane.com/rv8a/flightdata/index.htm > > > > What is the consensus on running the Lycosour above 2700 RPM? It's > > REAL > smooth at that RPM... > > > > Thanks... > > > > > > -Bill VonDane > > RV-8A N8WV > > http://vondane.com/rv8a > > > > > > ________________________________________________________________________________
Subject: Re: Engine Overhaul Shop
Date: Jun 10, 2002
Steve They are not that close to Brampton, but I would direct you to Atlantic Aero Engines in the industiral park near YHZ. Real good people to deal with and I've never heard anything bad about them. Joe Hine C-FYTQ Fredericton ----- Original Message ----- From: <sjhdcl(at)kingston.net> Subject: RV-List: Engine Overhaul Shop > > > Anybody know of an engine overhaul shop in or near Brampton, Ontario? > Or a source (website) where I can search for one? > > Thank you > Steve Hurlbut > Kingston, Ont > RV-7A > > ________________________________________________________________________________
Date: Jun 10, 2002
----- Original Message ----- From: "Bill VonDane" <n8wv(at)earthlink.net> Subject: RE: RV-List: Prop Swap Numbers... > > I question your statement; "Even at 2700 rpm redline, and 2 mph slower > than the original prop, you're still going to be burning more fuel than > the original prop"... > > Would it not be true that if I were running the engine at full throttle; > 21.9" MAP @ 2530 RPM I would burn more fuel that if I were running the > engine at 20.9" MAP @ 2700 RPM? Doesn't throttle position and manifold > pressure equate to fuel burn more that RPM? > > -Bill > Its a bit complicated due to the interaction of throttle, manifold pressure and rpm. At 2700 rpm the engine is capable of ingesting more cubic feet of air per minute than at 2530 rpm at the same throttle setting. So no question if both at same throttle setting, 2700 rpm produces more HP. Here are some rough back of the envelope considerations. The higher rpm would produce 2530/2700 = (1-.937) = approx 6.3% more HP all other factors being equal. Now if you run 21.9" MAP compared to 20.9" Map that 1" difference in manifold pressure at the same rpm it would produce approx 1/29.92 = 3.3% more HP all other factors being equal. So for the parameters you mention its likely that the overall HP gain still goes to the 2700 rpm by a factor of approx 3 %. FWIW Ed Anderson eanderson(at)carolina.rr.com ________________________________________________________________________________
Subject: Safety and operating costs
Date: Jun 10, 2002
A lot has already been posted on the list on engine handling and is in the archives. As I have said before I am more interested in safety and keeping the engine costs down than I am in performance. Proper handling of the Lycomings (0320-0360) that we are using in our RV's is very straight forward. The Lycoming manual states that they should not be run continuously at more than 75% of rated power this is in the area of 2400 RPM &24 inches of manifold pressure. Experience has shown that limiting full throttle operation to one minute unless safety is an issue and climbing at 75% and cruise at 65% (2300-2400 & 21 inches), this coupled with proper leaning, the settings I use are full rich to 3500 ft, maintaining 300-400 F on the rich side of peak during the climb then peak -50 when stabilized in cruise.gives the best service life. Exceeding the red line RPM never becomes an issue if the governor is set right in the case of a constant speed. A bit harder with a fixed pitch, but if it is pitched right for your engine, like turning 2400 at 21-22 inches in cruise and the red line airspeed is observed it doesn't require much throttle changing. I have found flying at power settings higher than the ones mentioned is all cost and very little gain. The difference in speed for example between 75 % and 65% is in the order of 5-6 miles an hour. The RV does aerobatics just fine at a 65% setting. For those interested in a more detailed run down on engine handling got to "The care and feeding of Lycoming engines" in the archives. Eustace Bowhay- Blind Bay, B.C. ________________________________________________________________________________
Subject: Re: Safety and operating costs
Date: Jun 10, 2002
COST to gain the following years of experience yourself: EXPENSIVE! Free Advice from an experienced RV-Pilot like Eustace: PRICELESS!! Sincerely, Konrad > Subject: RV-List: Safety and operating costs > > > A lot has already been posted on the list on engine handling and is in > the archives. As I have said before I am more interested in safety and > keeping the engine costs down than I am in performance. > > Proper handling of the Lycomings (0320-0360) that we are using in our > RV's is very straight forward. The Lycoming manual states that they > should not be run continuously at more than 75% of rated power this is > in the area of 2400 RPM &24 inches of manifold pressure. > > Experience has shown that limiting full throttle operation to one minute > unless safety is an issue and climbing at 75% and cruise at 65% > (2300-2400 & 21 inches), this coupled with proper leaning, the settings > I use are full rich to 3500 ft, maintaining 300-400 F on the rich side > of peak during the climb then peak -50 when stabilized in cruise.gives > the best service life. > > Exceeding the red line RPM never becomes an issue if the governor is set > right in the case of a constant speed. A bit harder with a fixed pitch, > but if it is pitched right for your engine, like turning 2400 at 21-22 > inches in cruise and the red line airspeed is observed it doesn't > require much throttle changing. > > I have found flying at power settings higher than the ones mentioned is > all cost and very little gain. The difference in speed for example > between 75 % and 65% is in the order of 5-6 miles an hour. The RV does > aerobatics just fine at a 65% setting. > > For those interested in a more detailed run down on engine handling got > to "The care and feeding of Lycoming engines" in the archives. > > Eustace Bowhay- Blind Bay, B.C. ________________________________________________________________________________
Subject: GPS PRICES
Date: Jun 11, 2002
Hello Listers This message is directed to our canadians RV'ers.I'm planning on buying a Garmin 295 GPS in a near future and I would like to know if anyone knows of a good place (Price)where I could find such a unit. I'm also looking for a place to buy new disk brakes for my RV-4 so if you guys know a good shop please feel free to let me know. Thanks in advance.. Bruno Dionne Flying RV-4 C-GDBH rv4(at)videotron.ca ________________________________________________________________________________
Date: Jun 11, 2002
In a message dated 6/10/2002 2:08:56 PM Pacific Daylight Time, tim(at)bryantechnology.com writes: > I have been looking for the double grommets that go in the baffle for the > upper spark plug wires. I don't know what they are even called, or where > to > get them. Can someone help with a source? They are available from... surprise! ACS P/N 375 on pg 238 of my 2000/2001 catalog. -GV (N1GV) ________________________________________________________________________________
Subject: protective barrier skin cream?
Date: Jun 10, 2002
Can anybody out there recommend a protective barrier cream for your skin (human skin, not RV skin)? I've seen several products at this point and I'm swimming in confusion over which ones actually protect you from harsh elements (i.e. ProSeal, etc.) and which ones are just dirt & grime barriers. Gloves in a Bottle? West Systems 831? Debba? Any advice is appreciated... )_( Dan RV-7 N714D (tanks) http://www.rvproject.com ________________________________________________________________________________
Date: Jun 10, 2002
Subject: Re: GPS PRICES
At 10:05 PM 6/10/2002 Monday, you wrote: > >Hello Listers > This message is directed to our canadians RV'ers.I'm planning >on buying a Garmin 295 GPS in a near future and I would like to know if >anyone knows of a good place (Price)where I could find such a unit. ><...snip...> >Bruno Dionne >Flying RV-4 C-GDBH >rv4(at)videotron.ca Bruno, Below are the best couple of prices I could find on the Internet. Can't speak to either's customer service, though. Interesting that the only difference between the 295 and the Street Pilot III is the software... and, well, $600...! Nice of Garmin to allow you to use the Street Pilot Software on the 295. Probably doesn't work the other way around, though... ;-) JA Air ------ $1299 http://www.jaair.com/mailorder/shoppingcart.asp?CartValue=1||301||GPSMAP+295+Color+Navigator||1299 AvionicsWest ------------ $1289 http://www.avionicswest.com/articles/garmins295.html Matt Dralle RV-4 1763 - N442RV ________________________________________________________________________________
Subject: ELTs and their antenna's
Date: Jun 11, 2002
I have been reading a lot of questions about ELTs and their aerials, I hope the following helps. I have some experience in searching for ELTs from a C130 in the South Atlantic, a place I would not like to be lost. When we start the search for an ELT we start at about 10,000 feet, to increase the horizon (12.3 multiplied by the square root of your height in 100's of feet i.e. 10,000 feet = 123 Nm). At this height once we detect a signal we will home towards it, once 'on top' we will mark the position and start an orbiting decent around the marked position. Once at low level, about 250 feet, we will home back towards the mark position and try to detect the signal again and then hopefully spot the survivor. The point of explaining this is to understand what affect the aerial position has. As I am sure you know a dipole aerial has radiation pattern that is shaped like a doughnut with a hole in the middle! Directly above the aerial (if it is mounted vertically) there is very little signal therefore when we look for the 'on top' we get a 'cone of silence' above the aerial which we use to locate the survivor. However, if the aerial is not vertical this 'cone of silence' could be quite some distance to one side of the survivor, which is why we have to get lower and try to detect the signal again. This is why it is important to try to set up your ELT aerial in the vertical post crash. It makes the job of the rescue services much easier, you also get the maximum range in all directions. It is still possible to home to the ELT with the aerial in any position, you are just reducing the chances of detection and speed of location considerably if its not vertical. The next point, splitting the signal from the ELT to 2 aerials, if the signal is split you now have 2 transmitting aerials with half the power each. Half the power means quarter the range! (inverse square law) Add to this the interference pattern of the 2 aerials (constructive and destructive interference) and in some directions you will get no signal and others the full signal (as much as a single aerial without the split) but the average will be a lot less than the single aerial, as you can tell I would not recommend it. If I install an ELT (not required in the UK, I think the country is too small, if you crash its probably going to be in someone's garden!) I would try to install it in the cabin with the aerial vertical at shoulder height and attached to the ELT. The logic being if the cabin is so damaged that the ELT does not work I probably will not require rescuing, and with the roll bar the aerial should be protected and be near vertical even if upside-down. There are also the minimum number of points of failure with the aerial on the ELT, and it could be quickly removed during the escape from a burning or sinking aircraft. This is just my opinion but I hope it helps. Building an RV-8 just started the wings. ________________________________________________________________________________
Date: Jun 11, 2002
REAP-MailScanner: Found to be clean These grommets are supplied with new harnesse, Unison any case, I picked up a couple from a local aircraft maintenance base for free. Cheers Arthur Whitehead RV-8 finishing ----- Original Message ----- From: "Tim Bryan" <tim(at)bryantechnology.com> Subject: RV-List: Spark Plug Grommets for baffles > > > Hello Listers, > > I have been looking for the double grommets that go in the baffle for the > upper spark plug wires. I don't know what they are even called, or where to > get them. Can someone help with a source? > > Thanks > Tim Bryan > RV-6 Just about baffled out > N616TB > > ________________________________________________________________________________
Subject: Re: ELT antenna orientation
Date: Jun 11, 2002
I don't see a reason why you can't, but I can see a few drawbacks. First, the splitter will divide the power of the ELT to each antenna, so if you lose one there will only be half the power to the other. Also, if one of the two antenna's is missing, there will be an impedance mismatch causing a high Standing Wave Ratio (SWR) further reducing your effective radiated power to the remaining antenna. ----- Original Message ----- From: "David Carter" <dcarter(at)datarecall.net> Subject: Fw: RV-List: ELT antenna orientation > > I never saw anyone answer the question: Can an antenna splitter be used on > the ELT to feed 2 or more antennae? > > David Carter > > ----- Original Message ----- > From: "Konrad Werner" <Connywerner(at)wans.net> > To: > Subject: Re: RV-List: ELT antenna orientation > > > > > > Dear electronically inclined Listers! > > I know this has been probably beat to death already, but I'm rather (let's > > say) challenged, when it comes to radiowaves & electronics. > > Here my question: > > Is it possible to put in more than one ELT antenna with some kind of > > signal-splitter? > > Like one antenna in each wingtip, and maybe even a third one in the > > tailcone, just to cover thy Bacon(s) in ANY crash scenario? > > (Of course hoping to never have to use the ELT anyway!) > > Any input would be appreciated. > > Konrad > > ________________________________________________________________________________
Subject: Plus/Minus both wings
Date: Jun 11, 2002
Need some opinions here. My wings are due to be delivered this Friday. Remember, I am a CPA so I have lots of free time during the summer. I am seriously considering building both wings at the same time. Would some people who have done this, or those who decided not too, please chime in and let me know some pitfalls (I know, the same mistake twice), tips, BS, hints or bombs to avoid. Build two movable frames or just one big one?? Dana Overall (don't plan on doing 6+ spins anyway) Richmond, Ky RV-7 emp., wings trucking across country http://rvflying.tripod.com ________________________________________________________________________________
Date: Jun 11, 2002
Subject: Re: Plus/Minus both wings
If you have the space to build both wings I think you'll find it goes much quicker. I built two Jigs out of unistrut steel and anchored one to the wall. I left about four feet between the two and found that was plenty to move around. Larry Gagnon RV6 Finishing Kit N6LG (reserved) ________________________________________________________________________________
Subject: Canopies
Date: Jun 11, 2002
>>> You might also want to check with these folks...their canopy appears to cost less and is guaranteed not to break and will be replaced free if it does: http://www.aircraftextras.com If you contact them, let us know how it works out... . Or try Todd at Todd's Canopies. His address is BSILVER05(at)aol.com His canopies are about 25% cheaper, include shipping, and he guarantees to replace them if you crack them. His optical quality is excellent, can provide in different thicknesses and shades. I got 1/4 inch thick in darker smoke shade for my RV8. I found the service to be quick and friendly. Gordon Robertson RV8 finishing ________________________________________________________________________________
Date: Jun 11, 2002
From: "Dr. Arthur Glaser" <airplane(at)megsinet.net>
I got my 295 a couple of years ago from Avionics West. Tom was very knowledgeable and their service was excellent. Art Glaser BRUNO wrote: > > Hello Listers > This message is directed to our canadians RV'ers.I'm planning > on buying a Garmin 295 GPS in a near future and I would like to know if > anyone knows of a good place (Price)where I could find such a unit. > I'm also looking for a place to buy new disk brakes for my RV-4 > so if you guys know a good shop please feel free to let me know. > > Thanks in advance.. > > Bruno Dionne > Flying RV-4 C-GDBH > rv4(at)videotron.ca > ________________________________________________________________________________
Date: Jun 11, 2002
-----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dana Overall Subject: RV-List: Plus/Minus both wings * RV-List message posted by: "Dana Overall" Need some opinions here. My wings are due to be delivered this Friday. Remember, I am a CPA so I have lots of free time during the summer. I am seriously considering building both wings at the same time. Would some people who have done this, or those who decided not too, please chime in and let me know some pitfalls (I know, the same mistake twice), tips, BS, hints or bombs to avoid. Build two movable frames or just one big one?? Dana Overall (don't plan on doing 6+ spins anyway) Richmond, Ky RV-7 emp., wings trucking across country http://rvflying.tripod.com Dana, * I am building one at a time. Primarily because my space is limited, but also I believe less boring because I move on to a new section more quickly. * Jack Textor * RV8, 2nd wing * DSM ________________________________________________________________________________
Date: Jun 11, 2002
Dana, I built both wings at the same time. It believe that it saved me time to do the same operation on each in a fairly short time period. It is easy to forget the detail that was learned and problems solved if the time period is too long between doing the first one and the second one. It is clear (to me) that much detail would be forgotten if on wing was completed before starting the second one. My jig arrangement consisted of two fixed columns secured to the floor and the ceiling with brackets on each to support the ends of the spars and a second set of brackets for the rear spars. The wings were underside-to-underside. The only disadvantage of this arrangement that I can think of is that it required crawling under to access the space between the wings. This was only a small nuisance. Two moveable frames would avoid the crawling under problem but would require more space and would significantly increase the complexity of the jigging. One of the important considerations is that precise levelling of the spars as well as stability of the jigging is important. This would be difficult to accomplish with moveable jigs. My garage floor (and I expect most garage floors) is pitched toward the door. Much of the measuring and setup of the spars and ribs is dependent upon spars being level and ribs being plumb. Hope this is some help in making a decision. Regards, Richard Dudley -6A finishing N331RD reserved Dana Overall wrote: > > > Need some opinions here. My wings are due to be delivered this Friday. > Remember, I am a CPA so I have lots of free time during the summer. I am > seriously considering building both wings at the same time. Would some > people who have done this, or those who decided not too, please chime in and > let me know some pitfalls (I know, the same mistake twice), tips, BS, hints > or bombs to avoid. Build two movable frames or just one big one?? > > Dana Overall (don't plan on doing 6+ spins anyway) > Richmond, Ky > RV-7 emp., wings trucking across country > http://rvflying.tripod.com > ________________________________________________________________________________
Date: Jun 11, 2002
Subject: Landmark Birthday
Y'all! George's birthday is the 18th and this is one of those landmark years - though I probably shouldn't tell you which one! I thought perhaps if y'all knew that you might help me in recognizing his special day! Thanks! Becki Orndorff GeoBeck, Inc. 940-648-0841 ________________________________________________________________________________
Date: Jun 11, 2002
Dana, I debated with this issue as well. In the end, I decided to build them simultaneously. I couldn't imagine doing one wing and then get set to do it all over again for the other one. Progress seemed slower, but it wasn't. If you look at the drawings, you'll see that they show the left wing only. Whenever I was fitting or duplicating parts for the right wing, I could always go back to the left wing and see what I had done there and minimize screw ups. This was a definite plus. The negative was the lack of space. The wings get really big in a hurry, and if you are building in tight quarters, you'll lose your available space that much quicker. As far as the jig, I built a movable wingjig for my setup (picture enclosed). It was a weekend's worth of work and $200 to build it. I built it because I wanted to be able to open my garage door whenever I was working on the project and the Van's recommended jig would not have allowed it. At night, I don't mind being closed in, but on nice days it makes me feel good that I am enjoying the outdoor a bit and watching my kids play. The true advantage of the jig is that allows me to work on both sides of the wings at the same time without having to turn them each time. I have 3.5 feet of clearance between the two. Also, my wing construction coincided with hurricane season. If one came our way, I wanted to roll the project out of the garage and into the house and put the cars in the garage. Perhaps too much thought went into it, but you never know. Regards, Fabian RV-9A (Rolled over canoe last night) >>> bo124rs(at)hotmail.com 06/11/02 08:32AM >>> Need some opinions here. My wings are due to be delivered this Friday. Remember, I am a CPA so I have lots of free time during the summer. I am seriously considering building both wings at the same time. Would some people who have done this, or those who decided not too, please chime in and let me know some pitfalls (I know, the same mistake twice), tips, BS, hints or bombs to avoid. Build two movable frames or just one big one?? Dana Overall (don't plan on doing 6+ spins anyway) Richmond, Ky RV-7 emp., wings trucking across country http://rvflying.tripod.com ________________________________________________________________________________
Subject: canopy source
Date: Jun 11, 2002
<<<<<<<<<http://www.aircraftextras.com If you contact them, let us know how it works out>>>>>>>>>>>>. Hmmmmm, that address shows the same pictures that Todd Silverman has on his website. Why not go straight to the source? Todd Silverman appears to be the manufacturer. He gives the same guarantee and his prices are very competitive and the quality is top notch. http://www.kgarden.com/todd/ I just had a custom bubble made for my Rocket and it turned out great. You can see a couple pics of the prototype bubble on my website. I'll post more pics as I finish the installation. I predict that if Todd keeps doing what he's been doing that several other canopy manufacturers will be losing a lot of sales! Vince Frazier 1946 Stinson, NC97535, flying F-1H Rocket, "Six Shooter", N540VF reserved, canopy installation stage http://www.usi.edu/science/chemistry/vfrazier/page1.html ________________________________________________________________________________
Date: Jun 11, 2002
Dana, I built an "H" frame and built both wings at the same time. It went much faster and there were no mistakes that I can remember. I built two verticle posts out of 2 two by fours and made the cross beam out of the same (actually, it was the same frame I used on the empennage as described in the plans). On the verticle posts, I attached a horizontal two by four about 5 feet long. I braced the horizontal pieces with the strapping material from the crates...very sturdy! I then picked up some two by two aluminum angle from Lowes and cut 4 pieces...2 about 3" long and 2 about 8" long. I mounted the wing spars on the 8" long end and drilled a 1/8" hole in the center of the other end and clecoed the spar through the last rib mounting hole. I will be glad to send you some pictures in a couple of days (I can't get to my pictures on my computer until I get back from my trip). I think it saved me almost have the time it would have taken to do the wings seperately. Max >From: "Dana Overall" <bo124rs(at)hotmail.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Plus/Minus both wings >Date: Tue, 11 Jun 2002 08:32:26 -0400 > > >Need some opinions here. My wings are due to be delivered this Friday. >Remember, I am a CPA so I have lots of free time during the summer. I am >seriously considering building both wings at the same time. Would some >people who have done this, or those who decided not too, please chime in >and >let me know some pitfalls (I know, the same mistake twice), tips, BS, hints >or bombs to avoid. Build two movable frames or just one big one?? > >Dana Overall (don't plan on doing 6+ spins anyway) >Richmond, Ky >RV-7 emp., wings trucking across country >http://rvflying.tripod.com > > ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Date: Jun 11, 2002
>>message posted by: "Dana Overall" >> Need some opinions here.......I am seriously considering building both wings at the same time......<< I had the room to build both wings at the same time. I believe that the RV-9A wings would present the same building issues as the RV-7 ? ? ? I elected to use one frame. However, I built all of the small items at the same time. For example, I would fabricate both the Left and Right thing-ama-jig, finish them and prime a bunch of stuff in batches so they would be ready to install. This includes almost all components of the gas tanks - even the tank skins. The only exception was items that had operations to be done "in assembly". I think that this approach removes a lot of the inefficiencies of "one wing at a time". Ernest Kells - RV-9A O235-N2C, Wood Prop Finish Kit 15% Complete ________________________________________________________________________________
Date: Jun 11, 2002
Subject: Re: Landmark Birthday
Becki, tell George that being thirty isn't all that bad!! ;-) Sam Buchanan ========================= OrndorffG(at)aol.com wrote: > > > Y'all! > George's birthday is the 18th and this is one of those landmark years > - though I probably shouldn't tell you which one! I thought perhaps if y'all > knew that you might help me in recognizing his special day! Thanks! > > Becki Orndorff > GeoBeck, Inc. > 940-648-0841 ________________________________________________________________________________
Date: Jun 11, 2002
You're going to need a lot of clecoes as well. Maybe do all the filing and cleaning up, priming of parts for both wings but when it comes time to drilling and riveting I personally would rather do 1 wing at a time. I felt like I was still heavy into the learning process while building the wings. There are additional concerns such as wiring, pitot tude, bell cranks, fuel sealant, lights, push rods that you didn't experience with the emp. When I'm in the learning process I built 1 wing at a time and I did learn as I went and the 2nd wing was better. The simpler jig you'll build for the 1 wing will save you time as well. Unless the wings are on back order of course then you have time to build what you need for 2 wings. I built mine 1 at a time and I would do it that way again. Good luck Steve RV-7A fuse Quoting Dana Overall : > > Need some opinions here. My wings are due to be delivered this Friday. > Remember, I am a CPA so I have lots of free time during the summer. I am > seriously considering building both wings at the same time. Would some > people who have done this, or those who decided not too, please chime in and > > let me know some pitfalls (I know, the same mistake twice), tips, BS, hints > > or bombs to avoid. Build two movable frames or just one big one?? > > Dana Overall (don't plan on doing 6+ spins anyway) > Richmond, Ky > RV-7 emp., wings trucking across country > http://rvflying.tripod.com > > > > > > ________________________________________________________________________________
Date: Jun 11, 2002
I saw one on Ebay the other day. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) http://www.myrv7.com Fuselage Airplanes never win battles with the ground. The best the airplane can hope for is a draw. ----- Original Message ----- From: "BRUNO" <rv4(at)videotron.ca> Subject: RV-List: GPS PRICES > > Hello Listers > This message is directed to our canadians RV'ers.I'm planning > on buying a Garmin 295 GPS in a near future and I would like to know if > anyone knows of a good place (Price)where I could find such a unit. > I'm also looking for a place to buy new disk brakes for my RV-4 > so if you guys know a good shop please feel free to let me know. > > Thanks in advance.. > > Bruno Dionne > Flying RV-4 C-GDBH > rv4(at)videotron.ca > > ________________________________________________________________________________
Date: Jun 11, 2002
Plus - The plane flies better with two wings Minus- The plane is heavier with both wings. Seriously, build both wings at the same time if you have the room. Construct your jig with enough room between the wings and easy access between the wings. http://www.excelgeo.com/zilik/rv6/wing8lrg.jpg shows how I jigged my wings. To get between the wings all I had to do was duck under the brace for the main spar. You will need twice the clecos to do both wings Gary Zilik ________________________________________________________________________________
Date: Jun 11, 2002
The number of clecos needed to do both wings is substantial; however, you will need them for the fuselage anyways. So, why not get them early and do both wings? Just my $0.02 Fabian >>> sjhdcl(at)kingston.net 06/11/02 10:03AM >>> You're going to need a lot of clecoes as well. Maybe do all the filing and cleaning up, priming of parts for both wings but when it comes time to drilling and riveting I personally would rather do 1 wing at a time. I felt like I was still heavy into the learning process while building the wings. There are additional concerns such as wiring, pitot tude, bell cranks, fuel sealant, lights, push rods that you didn't experience with the emp. When I'm in the learning process I built 1 wing at a time and I did learn as I went and the 2nd wing was better. The simpler jig you'll build for the 1 wing will save you time as well. Unless the wings are on back order of course then you have time to build what you need for 2 wings. I built mine 1 at a time and I would do it that way again. Good luck Steve RV-7A fuse Quoting Dana Overall : > > Need some opinions here. My wings are due to be delivered this Friday. > Remember, I am a CPA so I have lots of free time during the summer. I am > seriously considering building both wings at the same time. Would some > people who have done this, or those who decided not too, please chime in and > > let me know some pitfalls (I know, the same mistake twice), tips, BS, hints > > or bombs to avoid. Build two movable frames or just one big one?? > > Dana Overall (don't plan on doing 6+ spins anyway) > Richmond, Ky > RV-7 emp., wings trucking across country > http://rvflying.tripod.com > > > > > > ________________________________________________________________________________
Subject: Air vent confusion
Date: Jun 11, 2002
Guys, I am tired of my backseaters whining about my rear seat air vent leaking cold air on them and decided I had to bite the bullet and spend the $150 on the aluminum version of the Van's plastic air vent. I thought I had seen a message posted that p/n 13-03600 in the Spruce catalog was a drop-in replacement and ordered one. It's NOT. This part number is a smaller vent that would require more adapting than I'm willing to do. Does anyone have accurate information on where to get the aluminum no-leak replacement? (btw, the black plastic vent in my panel seals completely when closed, must be the only one in existence!) On behalf of my backseaters, thanks! Randy Lervold RV-8, 172.8 hrs www.rv-8.com ________________________________________________________________________________
Date: Jun 11, 2002
Subject: Re: protective barrier skin cream?
Dan, When I worked exclusively with composites we used to use Ply No. 9 gel. available at Aircraft Spruce. But I found that gloves are the way to go when using "The Black/Grey Death". When the gloves become a mess, just shed them and put on another pair. Another tip get extra napkins every time you eat at a fast food place and have a pile of them handy when doing any work with epoxy , Pro Seal, etc. Hope this helps, and thanks again for your weather web work. It made planning the trip up to Langley and back easier. Garry " Casper" Dan Checkoway wrote: > > Can anybody out there recommend a protective barrier cream for your skin > (human skin, not RV skin)? > > I've seen several products at this point and I'm swimming in confusion over > which ones actually protect you from harsh elements (i.e. ProSeal, etc.) and > which ones are just dirt & grime barriers. > > Gloves in a Bottle? > West Systems 831? > Debba? > > Any advice is appreciated... > )_( Dan > RV-7 N714D (tanks) > http://www.rvproject.com > ________________________________________________________________________________
Subject: Re: Air vent confusion
Date: Jun 11, 2002
Randy, Somewhere in Van's instructions is a paragraph about using proseal to make the vents air-tight. I haven't gotten around to doing mine yet (they aren't installed) but it sure sounded like it would work. Have you tried that? Terry > > > (btw, the black plastic vent in my panel seals completely when closed, must > be the only one in existence!) ________________________________________________________________________________
Date: Jun 11, 2002
Hello Fabian, I'm ready to put this together and liked your idea. Could you forward the picture of your moveable double wing jig to me (it didn't make it to the RV-list). I can post it to my web sight if you wish. Thanks in advance, Mike Mike McGee, RV-4 N996RV, O320-E2G, Aurora, OR 13B in gestation mode, 9A under construction > >Dana, ><> >As far as the jig, I built a movable wingjig for my setup (picture >enclosed). It was a weekend's worth of work and $200 to build it. I built >it because I wanted to be able to open my garage door whenever I was >working on the project and the Van's recommended jig would not have >allowed it. At night, I don't mind being closed in, but on nice days it >makes me feel good that I am enjoying the outdoor a bit and watching my >kids play. The true advantage of the jig is that allows me to work on both >sides of the wings at the same time without having to turn them each time. >I have 3.5 feet of clearance between the two. Also, my wing construction >coincided with hurricane season. If one came our way, I wanted to roll the >project out of the garage and into the house and put the cars in the >garage. Perhaps too much thought went into it, but you never know. > >Regards, > >Fabian >RV-9A >(Rolled over canoe last night) ________________________________________________________________________________
Subject: RE:Builder Assistance
Date: Jun 11, 2002
Hi Guys, We have a Glasair builder on the east coast who's looking for someone to travel to his location and help with FWF and hydraulic systems installation. Any one know of anybody interested? Thanks, Bruce www.glasair.org ________________________________________________________________________________
Date: Jun 11, 2002
Look in "21 Years of the RV-ator". There's a blurb about putting a bead of RTV on the inside of the vent body. The aluminum vents you speak of are a lot smaller, but they seal better. I don't think the adapter is a big deal, unless it would interfere with something. Jim Bower >From: "Randy Lervold" <randy@rv-8.com> >Reply-To: rv-list(at)matronics.com >To: , >Subject: RV-List: Air vent confusion >Date: Tue, 11 Jun 2002 09:07:16 -0700 > > >Guys, > >I am tired of my backseaters whining about my rear seat air vent leaking >cold air on them and decided I had to bite the bullet and spend the $150 on >the aluminum version of the Van's plastic air vent. I thought I had seen a >message posted that p/n 13-03600 in the Spruce catalog was a drop-in >replacement and ordered one. It's NOT. This part number is a smaller vent >that would require more adapting than I'm willing to do. Does anyone have >accurate information on where to get the aluminum no-leak replacement? > >(btw, the black plastic vent in my panel seals completely when closed, must >be the only one in existence!) > >On behalf of my backseaters, thanks! >Randy Lervold >RV-8, 172.8 hrs >www.rv-8.com > > Join the worlds largest e-mail service with MSN Hotmail. http://www.hotmail.com ________________________________________________________________________________
Date: Jun 11, 2002
I built both wings for my RV-6 at the same time on a fixed wing jig. I would definitely do so again. My approach was to complete a step on one wing and once I got it right complete that step on the other wing. That way I didn't forget how I did it before getting to the same job on the other side. I alternated from one wing to the other to balance the mistakes :-). Harry Crosby Pleasanton, California RV-6, electrical stuff ________________________________________________________________________________
Date: Jun 11, 2002
Hey Becki: Tell George thirty is so bad I guess....I can't remember its been so long ago....NJ forever, Jim Brown ________________________________________________________________________________
Date: Jun 11, 2002
Here ! Here !! Chuck & Dave >From: Sam Buchanan <sbuc(at)hiwaay.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Landmark Birthday >Date: Tue, 11 Jun 2002 08:48:32 -0500 > > >Becki, tell George that being thirty isn't all that bad!! ;-) > >Sam Buchanan > >========================= > >OrndorffG(at)aol.com wrote: > > > > > > Y'all! > > George's birthday is the 18th and this is one of those landmark >years > > - though I probably shouldn't tell you which one! I thought perhaps if >y'all > > knew that you might help me in recognizing his special day! Thanks! > > > > Becki Orndorff > > GeoBeck, Inc. > > 940-648-0841 > > ________________________________________________________________________________
Date: Jun 11, 2002
I would add to this a statistical problem. Depending on where one of the antenna leads is cut, there may be no power output from the ELT. This is basic transmission line theory (and practice!). An open or shorted antenna lead can appear as a dead short at the junction of the two leads, hence, no power out. Garth Shearing VariEze and 80% RV6A Victoria BC Canada ----- Original Message ----- From: Wayne R. Couture <commando@cox-internet.com> Subject: Re: RV-List: ELT antenna orientation <commando@cox-internet.com> | | I don't see a reason why you can't, but I can see a few drawbacks. First, | the splitter will divide the power of the ELT to each antenna, so if you | lose one there will only be half the power to the other. Also, if one of | the two antenna's is missing, there will be an impedance mismatch causing a | high Standing Wave Ratio (SWR) further reducing your effective radiated | power to the remaining antenna. | | | ----- Original Message ----- | From: "David Carter" <dcarter(at)datarecall.net> | To: "RV-list" | Subject: Fw: RV-List: ELT antenna orientation | | | > | > I never saw anyone answer the question: Can an antenna splitter be used | on | > the ELT to feed 2 or more antennae? | > | > David Carter | > | > ----- Original Message ----- | > From: "Konrad Werner" <Connywerner(at)wans.net> | > To: | > Subject: Re: RV-List: ELT antenna orientation | > | > | > > | > > Dear electronically inclined Listers! | > > I know this has been probably beat to death already, but I'm rather | (let's | > > say) challenged, when it comes to radiowaves & electronics. | > > Here my question: | > > Is it possible to put in more than one ELT antenna with some kind of | > > signal-splitter? | > > Like one antenna in each wingtip, and maybe even a third one in the | > > tailcone, just to cover thy Bacon(s) in ANY crash scenario? | > > (Of course hoping to never have to use the ELT anyway!) | > > Any input would be appreciated. | > > Konrad | > | > | | | | | | | | ________________________________________________________________________________
Subject: Aircraft operating costs
Date: Jun 11, 2002
Hello, I have been lurking on ond off the list for awhile and hope someone can help me. I am seriously considering building an RV9 but theres one question that needs an answer to. Can someone tell me how much it costs to keep an RV flying. This will be my first aircraft so I have no idea what it takes to keep it flying in tip top condition. Any help estimating the costs will be appreciated. Thanks, Paul ________________________________________________________________________________
Subject: Pink Panther for sale
Date: Jun 11, 2002
I have inspected one too many cellphone towers up close and personally so in the interest of seeing my next birthday... I found an IFR -4 that suits me. Hence, the pink panther is for sale. 1994 735 TTAF ~635SMOH IO-320 160 hp solid crank Bernie Warnke prop VFR Val 760 Com AT-50 w/enc Flybuddy Loran Turn/Bank G-meter Aeroflash lights & strobes no panel lights A great flying airplane!!! I have flown it all over the country and would leave tommorrow for anywhere. I will miss her. The wheel and deal price is $45,000 The no BS buy it and fly it home price is $40,000 Tailwinds, Doug Rozendaal ________________________________________________________________________________
Date: Jun 11, 2002
Thirty what...Dog years? ;-) Have a great day! Max >From: "Charles Rowbotham" <crowbotham(at)hotmail.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Landmark Birthday >Date: Tue, 11 Jun 2002 18:52:40 +0000 > > >Here ! Here !! > >Chuck & Dave > > > >From: Sam Buchanan <sbuc(at)hiwaay.net> > >Reply-To: rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: Re: RV-List: Landmark Birthday > >Date: Tue, 11 Jun 2002 08:48:32 -0500 > > > > > >Becki, tell George that being thirty isn't all that bad!! ;-) > > > >Sam Buchanan > > > >========================= > > > >OrndorffG(at)aol.com wrote: > > > > > > > > > Y'all! > > > George's birthday is the 18th and this is one of those landmark > >years > > > - though I probably shouldn't tell you which one! I thought perhaps >if > >y'all > > > knew that you might help me in recognizing his special day! Thanks! > > > > > > Becki Orndorff > > > GeoBeck, Inc. > > > 940-648-0841 > > > > > > MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide.aspx ________________________________________________________________________________
Date: Jun 11, 2002
Subject: Re: Aircraft operating costs
Paul Kuta wrote: > > > Hello, > > I have been lurking on ond off the list for awhile and hope someone > can help me. I am seriously considering building an RV9 but theres one > question that needs an answer to. Can someone tell me how much it costs to > keep an RV flying. > > This will be my first aircraft so I have no idea what it takes to > keep it flying in tip top condition. Any help estimating the costs will be > appreciated. > > Thanks, > > Paul Paul, you need to sum all your fixed cost (hangar, insurance, annual inspection, etc, etc...), add hourly costs (fuel, oil, routine maintenance, overhaul reserve, etc.....) and divide by the estimated number of hours flown each year. It is up to you as to whether or not you amortize the cost of the plane. I suspect that by the time you do that (and don't include the cost of the plane) that you are going to be looking at around $50-60.00 per hour, about the same as flying a Cessna 152 or 172 with simple panel. Sam Buchanan (RV-6......fifty bucks per hour) "The RV Journal" http://thervjournal.com ________________________________________________________________________________
Date: Jun 11, 2002
Paul, as you probably already know, there are a lot of variables. Engine size, hangered or not, etc. But I figure about $45 an hour if you fly 200 hrs/yr, and about $58 an hour if you fly 100 hrs/yr. Hope this gives you a general idea. I'm sure some of the other guys on the list will chime in on this thread! Tommy 6A Ridgetop, TN ----- Original Message ----- From: Paul Kuta Subject: RV-List: Aircraft operating costs Hello, I have been lurking on ond off the list for awhile and hope someone can help me. I am seriously considering building an RV9 but theres one question that needs an answer to. Can someone tell me how much it costs to keep an RV flying. This will be my first aircraft so I have no idea what it takes to keep it flying in tip top condition. Any help estimating the costs will be appreciated. Thanks, Paul ________________________________________________________________________________
Date: Jun 11, 2002
Paul, I'll give it a stab based on the 3.5 yrs my RV6 has been flying here in Colorado Springs. These are ball park figures and high/low ranges. Assumes you do the work yourself. Operating costs: Hourly: $16/hr for gas, 160hp ( $2/gal, 8 gal/hr ) $0.60/hr for oil & filter ( 50 hr oil chg: 8 qts @ $1.50/qt, $12 filter, 4 qts added between chg) $0.50/hr for tires ( $100/ main gear set, 200 hrs/set ) Monthly: $175-$250 hangar rent Annual: $400 - $1,600 ins ( value of RV, liablilty only or full coverage, tail wheel or conv gear, pilot experience) Bi-annual: $200-$300 for transponder & static system certification Other cost to consider: reserve for engine overhaul and/or repair Bob Hall, RV-6 Coorado Springs. ________________________________________________________________________________
Date: Jun 11, 2002
When I built mine, I didn't plan on selling it anytime soon. I had a new engine with a 2000 hour TBO. I figured that since I would probably sell it before I needed an overhaul (Like less than 1000 hours) I wouldn't factor in the cost of an overhaul. It just didn't really make sense. Now, if you have a mid time engine, by all means factor it in, because more than likely you will need to pull a cylinder or two at some point. I figured only about $30/hour variable cost (Including gas). I didn't include hanger or insurance, as I have to pay those anyway, and I felt it wasn't a "real" hourly cost. I figured it as a cost of owning an airplane, not what the airplane cost to fly. Now, granted I only had 80 hours on it when I sold it, so there wasn't much to go wrong. But, after looking at many people's flying airplanes, if you take care of it, the only real maintence costs I can see would be consumables like tires, brakes, seals, hoses, oil, filters, etc. That stuff doesn't add up to all that much really. Leave yourself $500 a year for the annual condition inspection to replace hoses, brakes, tires and such and I bet you would be fine for the first few years. RV's are simple enough (if you make it that way) that as long as you keep everything tight and don't hit any taxi lights, you shouldn't incurr much expense other than the obvious. Again, I only had 80 hours on my plane when I sold it, so don't really take my word for it, as I could very well be off base. Ask a high time guy like Gary Sobek and I bet you could get some more accurate numbers. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Paul Kuta" <greif10(at)mindspring.com> Subject: RV-List: Aircraft operating costs > > Hello, > > I have been lurking on ond off the list for awhile and hope someone > can help me. I am seriously considering building an RV9 but theres one > question that needs an answer to. Can someone tell me how much it costs to > keep an RV flying. > > This will be my first aircraft so I have no idea what it takes to > keep it flying in tip top condition. Any help estimating the costs will be > appreciated. > > Thanks, > > Paul > > ________________________________________________________________________________
Date: Jun 11, 2002
What's a "Pink Panther"? ----- Original Message ----- From: Doug Rozendaal <dougr(at)petroblend.com> Subject: RV-List: Pink Panther for sale > > I have inspected one too many cellphone towers up close and personally so in > the interest of seeing my next birthday... I found an IFR -4 that suits me. > Hence, the pink panther is for sale. > > 1994 > 735 TTAF > ~635SMOH > IO-320 160 hp solid crank > Bernie Warnke prop > VFR > Val 760 Com > AT-50 w/enc > Flybuddy Loran > Turn/Bank > G-meter > Aeroflash lights & strobes > no panel lights > > > A great flying airplane!!! I have flown it all over the country and would > leave tommorrow for anywhere. I will miss her. > > The wheel and deal price is $45,000 > The no BS buy it and fly it home price is $40,000 > > Tailwinds, > Doug Rozendaal > > ________________________________________________________________________________
Date: Jun 11, 2002
> > Can anybody out there recommend a protective barrier cream for your skin > > (human skin, not RV skin)? > > Dan I've used a product called invisible glove, but not sure where it can be purchased. It's worth it, if you can find it. forrest RV8 wings ________________________________________________________________________________
Subject: Re: Pink Panther for sale
Date: Jun 11, 2002
Duh!!! Sooooooo Sooooorrrryyyyy! It is an RV-4 of some infamy because it is pink, not really pink, but it has a panther on the tail. Long time listers remember when I terrorized this list with stories etc.... Again, many apoligies... Tailwinds, Doug Rozendaal ----- Original Message ----- From: "C. Rabaut" <crabaut(at)coalinga.com> Subject: Fw: RV-List: Pink Panther for sale > > What's a "Pink Panther"? > > > ----- Original Message ----- > From: Doug Rozendaal <dougr(at)petroblend.com> > To: > Subject: RV-List: Pink Panther for sale > > > > > > I have inspected one too many cellphone towers up close and personally so > in > > the interest of seeing my next birthday... I found an IFR -4 that suits > me. > > Hence, the pink panther is for sale. > > > > 1994 > > 735 TTAF > > ~635SMOH > > IO-320 160 hp solid crank > > Bernie Warnke prop > > VFR > > Val 760 Com > > AT-50 w/enc > > Flybuddy Loran > > Turn/Bank > > G-meter > > Aeroflash lights & strobes > > no panel lights > > > > > > A great flying airplane!!! I have flown it all over the country and would > > leave tommorrow for anywhere. I will miss her. > > > > The wheel and deal price is $45,000 > > The no BS buy it and fly it home price is $40,000 > > > > Tailwinds, > > Doug Rozendaal > > > > > > ________________________________________________________________________________
Date: Jun 11, 2002
>>I've used a product called invisible glove, but not sure where it can be >>purchased. It's worth it, if you can find it. I agree. It is not the same as Gloves in a Bottle. That is also good stuff but for a different purpose. Invisible Gloves #1211 is made by Sun Magic Intl P.O. Box 410541 out of Melbourne FL 32941-0541. Last number I have is 407-259-1847. It is available from the part sources. I think Chief and Aircraft Spruce carry it. It's good stuff. I have used it with fiberglass resin, changing oil (makes cleanup MUCH easier), etc. I have a pint tub of the stuff that says 3 year shelf life and I have had the same tub for 5+ years and it's still going. Michael ________________________________________________________________________________
Date: Jun 11, 2002
Phil Birkelbach wrote: > > I saw one on Ebay the other day. > > Godspeed, > > Phil Birkelbach - Houston Texas > RV-7 N727WB (Reserved) > http://www.myrv7.com > Fuselage Check that out and should should be able to get a new one for a little bit less ;-) -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Working on the wings :-) ________________________________________________________________________________
Date: Jun 11, 2002
Subject: Amount of Plastic Brake Line Needed - RV-6A - Dual Brakes
Many months ago, I installed the brake fluid reservoir high up on my firewall to give good clearance from the reinforcement angles when installing the plastic T-fitting - an RV-list tip, by the way. Looked just fine all the time I was wiring, etc. Then, a few days ago it was time to install the actual brake lines. I have a -6A with dual L&R brakes so the two lines from left to right and then the supply lines all had to be cut from the 9 foot length of heavy duty nylon tube that Van's supplies with the dual brake kit. So two long pieces cut and fitted with a reasonable bit of slack to allow for pedal movement, one piece cut to length to go from the reservoir to the supply side of a cylinder, one more to go and guess how much tubing I was short - about 14 - 15 inches. Guess who wishes he had mounted the reservoir about 7 inches lower on the firewall now.... Let's see, $7.70 US for a 9 foot piece of tubing of which I only need 2 ft, plus currency exchange plus postage, plus a $5 customs service fee - call it $25 CDN to fix this one up. No, this is not a complaint or a whine, just a note for the archives and advice to those builders looking at installing their brake fluid reservoirs soon. Put it up too high and 9 feet will NOT be enough tubing for the lines you need to install later on. Consider yourselves cautioned on this one now ! Jim Oke Winnipeg, MB RV-6A - in the endless tinkering stage. ________________________________________________________________________________
Date: Jun 12, 2002
----Original Message Follows---- From: "Bob Hall" <robjhall(at)adelphia.net> Subject: Re: RV-List: Aircraft operating costs Date: Tue, 11 Jun 2002 16:41:07 -0600 Paul, I'll give it a stab based on the 3.5 yrs my RV6 has been flying here in Colorado Springs. These are ball park figures and high/low ranges. Assumes you do the work yourself. Operating costs: Hourly: $16/hr for gas, 160hp ( $2/gal, 8 gal/hr ) $0.60/hr for oil & filter ( 50 hr oil chg: 8 qts @ $1.50/qt, $12 filter, 4 qts added between chg) $0.50/hr for tires ( $100/ main gear set, 200 hrs/set ) Monthly: $175-$250 hangar rent Annual: $400 - $1,600 ins ( value of RV, liablilty only or full coverage, tail wheel or conv gear, pilot experience) Bi-annual: $200-$300 for transponder & static system certification Other cost to consider: reserve for engine overhaul and/or repair Bob Hall, RV-6 Coorado Springs. Looks like Bob hit everything very close to California Costs. In SoCAL, I average $2.30 / GAL gas ($16.79/hr) and the Constant Speed prop O-320 averages 7.3 GPH. I average $1.16 / hour multi weight oil and filter. Also add 4 quarts between changes. I do use the more expensive Goodyear tires (~$150 / set) and they have been lasting 350-400 hours. Hangar $350 / Month My Insurance for Libality only $385 / year was $420 last year. Time for maintenance averages one (1) hour for every ten (10) hours flying. Paul Rosales is going to pass me in hours and he reports one (1) hour maintenance for eleven to twelve (11 - 12) hours of flying. Paul is very good at checking AirNav.com for fuel prices and routes his trips for lowest fuel costs. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,082.2+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com http://www.hotmail.com ________________________________________________________________________________
Subject: Brake fluid reservoir
Date: Jun 11, 2002
Fellow Listers: A quick and simple question. How high should I fill my brake reservoir? All the way to the top? (Van's unit). Doug Weiler Hudson, WI ________________________________________________________________________________
Subject: 1000 hour RV's
Date: Jun 11, 2002
I think there was a discussion on this some time ago, but looking at Gary Sobeks recent message and "signature", it dawned on me that there are probably SEVERAL RVs out there that have crossed the 1,000 hour mark. Now I am sure this does not compare to the first flight but this is a milestone that anyone who makes should get a pat on the back for. A friend has a Long-Eze that had crossed 1000 hours and he was given a little gold plaque to attach to the plane. Soooo.... Wouldn't it be nice if someone like Van's "recognized" those extra special birds? The plaque would probably cost about $1.00 or so, but the thought would be extra special. Any idea as to how many have crossed 1000 hours?? What thinketh ye, the list??? James Duly impressed and 1000 hours away from getting the FIRST flight hour! ;-) "If you don't make dust, you eat dust" ________________________________________________________________________________
Date: Jun 11, 2002
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Dan Checkoway wrote: > > Can anybody out there recommend a protective barrier cream for your skin (human skin, not RV > skin)? > > Gloves in a Bottle? > West Systems 831? > Debba? > > Any advice is appreciated... > )_( Dan > RV-7 N714D (tanks) > http://www.rvproject.com > Many years of experience in building and servicing formula race cars has shown that a product called PR-88 is one of the better "invisible gloves in a can". This works with fibreglass resin, grease, grime, paint, harsh solvents etc., etc. It is available from some automotive jobbers, industrial supply outlets, hobby outlets etc. -- Bob McC ________________________________________________________________________________
Date: Jun 11, 2002
Subject: Re: Amount of Plastic Brake Line Needed - RV-6A - Dual Brakes
Hi Jim, I had an oposite but equal problem. I don't know how my reservoir is compared to you but I had brake line left over. Now I am concerned there is not enough to allow the full movement of the pedals without chafing the line I will be buying more also and the 2' I have left is worthless. Funny but I guess that is why it is an experimental. We experiment and Van collects. Tim Bryan RV-6 N616TB FWF plus ________________________________________________________________________________
Date: Jun 11, 2002
In a message dated 6/11/2002 12:48:16 PM Pacific Daylight Time, greif10(at)mindspring.com writes: > I have been lurking on and off the list for a while and hope someone > can help me. I am seriously considering building an RV9 but there's one > question that needs an answer to. Can someone tell me how much it costs to > keep an RV flying. > > This will be my first aircraft so I have no idea what it takes to > keep it flying in tip top condition. Any help estimating the costs will be > appreciated. A new plane with new O-320 engine and simple instruments will cost around $50K nonrecurring. Let's assume you keep the plane in a hangar, do your own maintenance, you fly 200hr/yr (twice the average), nothing out of the ordinary goes wrong and you keep the plane for 10 years. Recurring costs will roughly be as follows: $5/hr goes to engine rebuild fund ($10,000 after 2000hr TBO) but may be less. $12/hr goes for hangar fees (rough guess, but your area may be cheaper or more expensive) $1/hr for new mags or electronic ignition. $1/hr for oil, filter and analysis (assume done every 50 operating hr) $20/hr for fuel (based on 7.7 gph and $2.60/gal) $0.20/hr for biennial transponder recert $1/hr for misc stuff that will break and need replacement That's a little over $40/hr or $670/month. -GV (N1GV) ________________________________________________________________________________
Date: Jun 11, 2002
How high should I fill my brake reservoir? All the way to the top? (Van's unit). Well, that would be one way to find out how full you should fill it because it will overflow to the level that you should keep it. I keep mine about 1/2 to 3/4 inch low. You don't need all that fluid. It will drop as your pads wear. I check it at oil changes. Michael ________________________________________________________________________________
Date: Jun 11, 2002
Subject: Cracking Canopy on installation
I had a dozen requests to elaborate on the circumstances that let the destruction of my canopy. Sorry for the delay but I just received my new XP-360 FADEC engine (gorgeous). Anyway, I had to tweak the canopy frame to line up with the roll bar and rails. When I clamped on the canopy, it pulled the corners out by approx 1 =BD=93 and pulled the top down =BD=93. Here is where I started making mistakes. Before I figured out that the canopy/frame had stretched out I drilled/clecoed all the holes. While the canopy was clecoed to the frame, I squeezed the frame back into shape. Nothing happened but I think it definitely stressed the plastic. Everything was fine, so I moved on to the windshield. After I completed the windshield, I tried to match up the canopy/windshield. At that time I noticed the sides of the canopy were bowed out about =BD=94. This time I took the plastic off the frame and reshaped the canopy frame to match the roll bar and windshield. Unfortunately when I put the plastic back on, it pulled the canopy frame out again. The bow was gone but it was just about =BD=94 wide. Well =BD=94 isn=92t much so I thought I could just squeeze a bit and that=92s when it exploded. Several chunks went flying across the garage. Of course when I spoke with Tom at Van=92s, he said that you should not flex the plastic on the frame. Now I know. Luckily, I was able to get another canopy from Van=92s at a discount. The canopy manufacturer had a second or a blem as the call it, with a scratch on the windshield portion. Strategy for the second go round: the canopy frame is about an 1=94 narrow and =BD=94 tall. I believe that when the plastic is clamped on it will spread back out and be very close to just right. Anyway I will be an expert soon. Back to the FADEC manual as I wait for the new canopy. Gary Coonan Rockvale, TN RV-7 N696TT (Finishing) gcoonan(at)comcast.net ________________________________________________________________________________
Date: Jun 11, 2002
COST?? RV's don't cost, they pay! Think what psychiatrists cost! Check out the price of whiskey. Look at all the skills the builder develops that save money on honey do's. Cost accounting is a difficult subject. What is the time value of the money invested? What are the missed financial opportunities like losing your butt in the stock market? Here are the costs: M money cost A annual inspection D depreciation or more properly, decline in value H hangar or tie down I insurance T taxes - nobody has yet mentioned these goblins The above are fixed costs that come whether you fly the plane or watch others fly. The below are more likely the actual cost of flying F fuel E engine reserve for overhaul or replacement M maintenance costs directly related to flights P pilot maintenance costs, training, charts etc I instruments and avionics wear and tear To go fly for an hour costs FEMPI which seems to be about twice the cost of fuel. The per hour cost to own and fly the airplane goes down as you fly more since the MADHIT is divided by more hours. Therefore, to save money one must go flying as often as one can bear to! QED. K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Subject: Re: 1000 hour RV's
Date: Jun 11, 2002
I thought that along the Van's Air Force theme line that we should come up with some bars to put on our planes. They could represent various aspects of building, indicating things like slow build/quick build, number of years to complete, maybe even purple hearts for drilled fingers. Long-EZ guys are great. They gave me a plaque for beating several of them at Jackpot, NV! Kevin ----- Original Message ----- From: "James E. Clark" <jclark(at)conterra.com> Subject: RV-List: 1000 hour RV's > > I think there was a discussion on this some time ago, but looking at Gary > Sobeks recent message and "signature", it dawned on me that there are > probably SEVERAL RVs out there that have crossed the 1,000 hour mark. > > Now I am sure this does not compare to the first flight but this is a > milestone that anyone who makes should get a pat on the back for. A friend > has a Long-Eze that had crossed 1000 hours and he was given a little gold > plaque to attach to the plane. > > Soooo.... Wouldn't it be nice if someone like Van's "recognized" those extra > special birds? The plaque would probably cost about $1.00 or so, but the > thought would be extra special. > > Any idea as to how many have crossed 1000 hours?? > > What thinketh ye, the list??? > > James > > Duly impressed and 1000 hours away from getting the FIRST flight hour! ;-) > > > "If you don't make dust, you eat dust" > > ________________________________________________________________________________
Date: Jun 11, 2002
you might think about finding a partner. I share my hangar with another -6A. We built a ramp (from scrap lumber even) and store both planes in one 40' T hangar. In the 5 years we've been there it has saved us over $6,000 in rent.(at $237/mo) That's some serious money! Kevin ________________________________________________________________________________
Date: Jun 11, 2002
Another possibility: I've heard that the plastic brake lines are prone to melting/leaking if the operator happens to ride the brakes one too many times or for a little too long. The solution to this is to use a proper brake line from the brake back up to some point on the gearleg... Maybe a proper brake line with fittings on it to span the 7" per side would be a better investment in the long run, even if it's more $$$ now (brake lines are something like 3-4x the cost of the plastic tubing, i'm led to believe). Speaking totally from hearsay here, i'm nowhere near far along enough on my kit to know if any of this is true, it's just what i've heard from other builders/flyers. And yes, I know that the *real* solution is to learn not to ride the brakes, but... 8-) -Rob P rv7 "at" b4.ca RV-7 Empennage Jim Oke wrote: > >Many months ago, I installed the brake fluid reservoir high up on my firewall to give good clearance from the reinforcement angles when installing the plastic T-fitting - an RV-list tip, by the way. Looked just fine all the time I was wiring, etc. > >Then, a few days ago it was time to install the actual brake lines. I have a -6A with dual L&R brakes so the two lines from left to right and then the supply lines all had to be cut from the 9 foot length of heavy duty nylon tube that Van's supplies with the dual brake kit. So two long pieces cut and fitted with a reasonable bit of slack to allow for pedal movement, one piece cut to length to go from the reservoir to the supply side of a cylinder, one more to go and guess how much tubing I was short - about 14 - 15 inches. Guess who wishes he had mounted the reservoir about 7 inches lower on the firewall now.... > >Let's see, $7.70 US for a 9 foot piece of tubing of which I only need 2 ft, plus currency exchange plus postage, plus a $5 customs service fee - call it $25 CDN to fix this one up. > >No, this is not a complaint or a whine, just a note for the archives and advice to those builders looking at installing their brake fluid reservoirs soon. Put it up too high and 9 feet will NOT be enough tubing for the lines you need to install later on. Consider yourselves cautioned on this one now ! > >Jim Oke >Winnipeg, MB >RV-6A - in the endless tinkering stage. > > -- --------- Rob Prior rv7 "at" b4.ca ----------------------------- Stop dreaming... Start flying ________________________________________________________________________________
Subject: Prince Propellors
Date: Jun 11, 2002
Hello, I searched the archives, but didn't find any reference to Prince P-tip fixed pitch propellers. Does anyone have any experience with them? I found them in my '01-'02 Aircraft Spruce catalog (pg 163). They are a scimitar shaped wood core composite prop that, according to the write up, change pitch by up to 4" through flexing depending on the airspeed and forces of a climb vs. cruise configuration. In climb it has less pitch and in cruise at higher speed it provides more pitch. The write up also claims, due to unique tip design, that a 68" P-tip prop will move as much air as a standard 72" prop allowing for a bit less diameter and therefore less "flat plate" drag from the prop. Are these design claims to-good-to-be-true theory, or does this prop really function as the Spruce catalog write up tells? Thanks, Pete E. ________________________________________________________________________________
Date: Jun 12, 2002
In a message dated 6/11/2002 8:47:57 PM Pacific Daylight Time, Vanremog(at)aol.com writes: > A new plane with new O-320 engine and simple instruments will cost around > $50K nonrecurring. Let's assume you keep the plane in a hangar, do your own > > maintenance, you fly 200hr/yr (twice the average), nothing out of the > ordinary goes wrong and you keep the plane for 10 years. Recurring costs > will > roughly be as follows: > > $5/hr goes to engine rebuild fund ($10,000 after 2000hr TBO) but may be > less. > $12/hr goes for hangar fees (rough guess, but your area may be cheaper or > more expensive) > $1/hr for new mags or electronic ignition. > $1/hr for oil, filter and analysis (assume done every 50 operating hr) > $20/hr for fuel (based on 7.7 gph and $2.60/gal) > $0.20/hr for biennial transponder recert > $1/hr for misc stuff that will break and need replacement > > That's a little over $40/hr or $670/month. > > Oops! I forgot hull and liability insurance and lunch. That brings the total to $50/hr (a good round number). -GV (N1GV) ________________________________________________________________________________
Subject: 10 Hr Report & Lean Carb (long)
Date: Jun 11, 2002
- gmcnutt(at)intergate.ca writes: > My engine is much better since I drilled the carb jet from #42 to #38 but > that is still not enough. > > As I mentioned in my 10 hour report the engine was previously running on > the > lean side of peak temperature, any leaning with the mixture control and the > cylinder head temperature immediately dropped. > > Since drilling the carb jet to #38 I think that the engine is now running > just on the rich side of peak temperature. Leaning with mixture control at > 10,000 feet now gives me a 5 degree F increase in head temperature before > temperature peaks and starts to lean drop. Cylinder temperatures in climb & > cruise are now 5 - 10 degrees cooler. > > Next week I will remove the carb and open the jet up some more, think I > will > try a #37 drill bit but am tempted to jump to a #36. > > George McNutt > George- I would urge you to ignore (relatively) the CHT's and focus on EGT for leaning and jetting purposes. There is much on this in the archives (try my screen name and a few key words like carb, jet, drill for in interesting read on my personal experience. I overdid it and ended up with a rich carb.) My problems in this regard were solved by getting the richer carb (again, the Marvel part no. will be in the archives) which I bought from a builder with a stock Lycoming 160 hp from Vans who decided to go to fuel injection before his first flight, so I got a brand new carb at an excellent price. I worry you may hurt yourself or your engine if you try to jet based on cylinder head temps. As far as I know, only exhaust gas temps are suitable for this purpose. Be safe- Bill B Hi Bill Thanks for the concern, I had reviewed many of Gary Corde and your post's in the archives on this subject. I did drill the carb jet out one more time from # 38 to # 36 and it seems just right for my 160 HP installation. I am now able to lean the engine at 9,000 feet and get an increase of 50 RPM and an increase in CHT of 20 plus degrees F. Finally I am running on the rich side of best power mixture, and this is where I want to be. I can glide throttle closed, mixture rich and carb heat on at 9000 feet without the engine mis-behaving and have good engine response on simulated go arounds so it's still not overly rich. George McNutt Langley, B.C. ________________________________________________________________________________
Date: Jun 12, 2002
Subject: Re: canopy source
HI-JUST RECEIVED TWO OF TODDS CANOPYS-THEY LOOK GREAT AND GOOD SERVICE-TOO-TOM Whelan Farms Airport / CT01 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 e-mail: wfact01(at)aol.com Telephone: 203-266-5300 Fax: 203-266-5140 President, EAA Chapter 1097 EAA Technical Counselor RV-8 Lycoming IO540 (Getting Close) ________________________________________________________________________________
Subject: Ellison TBI
Date: Jun 12, 2002
Anybody have any experience with the Ellison Throttle Body Injection? I am looking for opionions and drawbacks that sort of thing. I am toying with the idea of an Airflow Performance FI system or an Ellison TBI. The winner would be installed on an O-360 or XP-360. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) http://www.myrv7.com Fuselage Airplanes never win battles with the ground. The best the airplane can hope for is a draw. ________________________________________________________________________________
Date: Jun 12, 2002
> > > Hello, > > I have been lurking on ond off the list for awhile and hope >someone >can help me. I am seriously considering building an RV9 but theres one >question that needs an answer to. Can someone tell me how much it costs to >keep an RV flying. > > This will be my first aircraft so I have no idea what it takes to >keep it flying in tip top condition. Any help estimating the costs will be >appreciated. > >Thanks, > >Paul > Paul, Like you, I had many concerns about being able to afford just to own and maintain an RV before I even considered what it would cost to build it. I try not to dig too deep into the exact dollar figure required to operate it hourly to go get that burger on a Saturday morning. If I do, I find that it is some really scary number. Do I really "pay" that much to fly it? No, not really. The biggest expenses occur at one time, and I usually know it's coming and plan my finances accordingly. For instance, insurance and hangar fees. I know how much the hangar costs every month ($257). It is due the same time, every month, and I look at it as long term protection for my cherished airplane. I have a rough estimate of my insurance bill every December (approx. $1400), so I feed a savings account out of every paycheck that adds up to that amount and a bit more. The other expenses...fuel, oil, filters, cleaning materials, etc, I find that I can budget out of my spare change that most any employed person has available via the closest ATM. I have had two instances of unplanned, expensive repairs: two cracked jugs, one found at annual and the other during a spot check during an oil change. Oh well, that's what credit cards are for. Bottom line is that if you truly desire to own an RV, you WILL find a way to do it. I equate it to the other typical guy-hobbies...fishing, boating, golf, hunting, motorcycles, etc. You just make it happen as best you can. Best of luck to you, Brian Denk RV8 N94BD 291 hrs. of grins ________________________________________________________________________________
Date: Jun 12, 2002
Subject: Re: Fuel Prices (Was operating costs)
In a message dated 6/12/2002 5:24:39 AM Pacific Daylight Time, azpilot(at)extremezone.com writes: > Gary, did you say $2.60/ Gallon? > > I'm paying $1.85 here in Arizona. You wouldn't be in California would you? > Of course. In the ultimate land of supply and demand they just keep on ratcheting up the prices to see if we will continue to pay. -GV (N1GV) ________________________________________________________________________________
Subject: Fuel Prices (Was operating costs)
Date: Jun 12, 2002
Not to mention the $700/mo. hangers at RHV San Jose, CA !!! Ed Cole RV6A N2169D Flying RV6A N648Rv Finishing > -----Original Message----- > From: Vanremog(at)aol.com [SMTP:Vanremog(at)aol.com] > Sent: Wednesday, June 12, 2002 8:09 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Fuel Prices (Was operating costs) > > > In a message dated 6/12/2002 5:24:39 AM Pacific Daylight Time, > azpilot(at)extremezone.com writes: > > > > Gary, did you say $2.60/ Gallon? > > > > I'm paying $1.85 here in Arizona. You wouldn't be in California would > you? > > > > Of course. In the ultimate land of supply and demand they just keep on > ratcheting up the prices to see if we will continue to pay. > > -GV (N1GV) > > > > > Maxim Home Page: http://www.maxim-ic.com Products Page: http://www.maxim-ic.com/MaximProducts/products.htm New Products: http://dbserv.maxim-ic.com/new_products.cfm Datasheets: http://dbserv.maxim-ic.com/l_datasheet3.cfm The information contained in this message is confidential and may be legally privileged. The message is intended solely for the addressee(s). If you are not the intended recipient, you are hereby notified that any use, dissemination, or reproduction is strictly prohibited and may be unlawful. If you are not the intended recipient, please contact the sender by return e-mail and destroy all copies of the original message. ________________________________________________________________________________
Date: Jun 12, 2002
> Not to mention the $700/mo. hangers at RHV San Jose, CA !!! > > Ed Cole > RV6A N2169D Flying > RV6A N648Rv Finishing Ed, Just SEVEN HUNDRED BUCKS? Doesn't sound to bad if it is a 100x100 Building that could be shared! Don't tell us it isn't? KLW And please: > DEW KNOT ARKYV < ________________________________________________________________________________
Date: Jun 12, 2002
Subject: Ferry flight
Are there any experienced RV4 pilots out there who might be interested in flying an RV from Virginis to California? If so call Art at 510 541 4979 Cell/510 278 0260 home..Art Stavro ________________________________________________________________________________
Date: Jun 12, 2002
> >Not to mention the $700/mo. hangers at RHV San Jose, CA !!! There are hangars available at RHV???? Last I heard people were dying of old age before reaching the top of the list. I am in a share hangar and have a spot big enuf for RV, work bench, drill press and shelf for only $250. K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Jun 12, 2002
Subject: Re: Ellison TBI
> >Anybody have any experience with the Ellison Throttle Body Injection? I have a friend who races a Pitts S1 with an Ellison at Reno. Since he has gotten the little bipe to go 199.7 mph, partly due to using my Sensenich prop, he seems happy. He always has aircraft weight on his mind but I don't hear much about fuel economy. Have you any specific questions? K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Jun 12, 2002
Becky, You are a mean rascal! Bruce Knoll ----- Original Message ----- From: OrndorffG(at)aol.com Subject: RV-List: Landmark Birthday Y'all! George's birthday is the 18th and this is one of those landmark years - though I probably shouldn't tell you which one! I thought perhaps if y'all knew that you might help me in recognizing his special day! Thanks! Becki Orndorff GeoBeck, Inc. 940-648-0841 ________________________________________________________________________________
Date: Jun 12, 2002
Subject: Landmark Birthday
Donald.Bailey(at)bnsf.com, BERRY42MSP(at)aol.com, sirs(at)neosoft.com, cannady(at)dellepro.com, sgross(at)imagin.net, kendra-hart(at)home.com, Marykalbert(at)aol.com, kiser(at)avpaxp1.ncifcrf.gov, Bmaynard507(at)cs.com, JParis(at)maycpa.com, Cnursetx(at)aol.com, Orndorffma(at)aol.com, orndorffs(at)enterprise.navy.mil, electroair(at)juno.com, linsaxon(at)bvunet.net, bsaxon(at)bellatlantic.net, m.silva(at)bpf-cpa.com, rv-list-digest(at)matronics.com, vetxaust(at)gwtc.net, barryvisl(at)msn.com, willig10(at)yahoo.com Hi! George's birthday is the 18th and this is one of those landmark years - though I probably shouldn't tell you which one! I thought perhaps if y'all knew that you might help me in recognizing his special day! Thanks! Becki Orndorff ________________________________________________________________________________
Date: Jun 12, 2002
Hey Kevin: Would you by any chance have a photo or a sketch of the ramp you built to get two RV's in a 40' hangar. If you do and could mail it to me at 5732 Highbluff Terrace, Pleasanton, CA 94588 or describe it to me on e-mail I'd sure appreciate it. Thanks. Harry Crosby Pleasanton, California RV-6, electrical stuff ________________________________________________________________________________
Date: Jun 12, 2002
Happy Birthday and Many Happy Returns George. How's it feel to be 30 ;-), I can't remember that far back?. Harry Crosby Pleasanton, California RV-6, electrical stuff ________________________________________________________________________________
Date: Jun 12, 2002
yes wayne i know louisana is cheap, just as sure as you will probably blow a tire or bend a rim getting to the airport, because all the roads suck so bad. i quess it balances out 1 way or another. scott tampa cajun born and raised ayyyyy yeeeeeeeee ________________________________________________________________________________
Subject: Re: GPS PRICES
Date: Jun 12, 2002
Hi Bruno I would check on ebay for 295's I've seen some good deals on new ones as well as used ones. Other than that, going to Oshkosh and buying one at the show would probably be the best price. You could probably get it back over the border without paying taxes as well. As for the breaks, an old AME and 4 owner friend of mine helped me change my pads a couple of weeks ago and we use a set of Piper Astec (sp?) pads, you only need one wheels worth and just cut them in half. Works fine and is cheaper., Cheers Joe Hine RV4 C-FYTQ ----- Original Message ----- From: "BRUNO" <rv4(at)videotron.ca> Subject: RV-List: GPS PRICES > > Hello Listers > This message is directed to our canadians RV'ers.I'm planning > on buying a Garmin 295 GPS in a near future and I would like to know if > anyone knows of a good place (Price)where I could find such a unit. > I'm also looking for a place to buy new disk brakes for my RV-4 > so if you guys know a good shop please feel free to let me know. > > Thanks in advance.. > > Bruno Dionne > Flying RV-4 C-GDBH > rv4(at)videotron.ca > > ________________________________________________________________________________
Subject: Re: Fuel Prices - SE CT
Date: Jun 12, 2002
All, LANMAR Aviaition @ Groton-New London airport > $2.05/gal Chuck & Dave Rowbotham RV-8A http://www.hotmail.com ________________________________________________________________________________
Date: Jun 12, 2002
Subject: Need engine guru!!!
Have RV6, with Lycoming 0-360. Slick mags, bendix fuel injection. Starts perfect, smooth with normal mag drop. AS the engine warms up it runs rougher and rougher. Eventually will barely run at all, what the heck is going on here? Checked the mags timing, replaced plugs, pulled injectors and all seemed to be "peeing" uniformly. Turned on the boost pump, nothing helped. It is obviously heat related, I am looking to send the fuel injection system back to have it checked out, any other thoughts? Thanks. ________________________________________________________________________________
Subject: Re: Fuel Prices - Denver, CO
Date: Jun 12, 2002
GXY from the truck on the weekends: $1.75 weekdays: 1.80. A little gas war is going on between FBO's this summer. FTG Hangar rent (my 3rd), $230.00/mo includes water/heat/elec/toilet Estimated cost of own/fly my 6A on an hourly basis: $43.00 Gary in Pine Junction Colorado Smokey the Bear says "Only YOU can prevent Forest Fires!" ________________________________________________________________________________
Date: Jun 12, 2002
I don't really have any specific questions. I guess I am really trying to spark a pros / cons debate on the Ellison vs. Carb vs. Airflow Performance FI. I can't really see myself going with a carb over the Ellison if it is a reasonably reliable alternative because it doesn't seem to be that much more expensive than a carb and not any more difficult to install. But I may want to spend the extra $$$ and go with the AP FI, if the advantages are there but I have zero experience and I just wanted the opinions of those who have gone before. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) http://www.myrv7.com Fuselage Airplanes never win battles with the ground. The best the airplane can hope for is a draw. ----- Original Message ----- From: "kempthornes" <kempthornes(at)earthlink.net> Subject: Re: RV-List: Ellison TBI > > > > >Anybody have any experience with the Ellison Throttle Body Injection? > > > I have a friend who races a Pitts S1 with an Ellison at Reno. Since he has > gotten the little bipe to go 199.7 mph, partly due to using my Sensenich > prop, he seems happy. > > He always has aircraft weight on his mind but I don't hear much about fuel > economy. > > Have you any specific questions? > > K. H. (Hal) Kempthorne > RV6-a N7HK flying! > PRB (El Paso de Robles, CA) > > ________________________________________________________________________________
Date: Jun 12, 2002
List: Not sure I want to spill the beans on a good thing, but I lease the hunk of dirt my 40x30 hangar sits on for $187.00/year. That's life in God's Country....NE Wisconsin. DNA Regards, Jeff Orear RV6A Riveting fuse skeleton Peshtigo, WI ----- Original Message ----- From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> Subject: RE: RV-List: Aircraft operating costs > > I built the T-hangar myself but I lease the spot it sits on for $35 / month. > Oakdale, California. ( O27 ) > > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > ________________________________________________________________________________
Date: Jun 12, 2002
Subject: RV-6 panel wiring
For those who have wired their panels, do you feel that wiring runs in the subpanel area be run as low in the subpanel area as possible and thus be easily accessable from underneath, as opposed to drilling holes in the subpanel ribs and running wires. I have the top skin off so my first thought is to just run the main runs thru the ribs but I'm not sure if this would be such a good idea once the top skin is on. Appreciate any recommendations and comments. Gary Gunn RV-6 panel and finish kit. ________________________________________________________________________________
Subject: great fuel deals
Date: Jun 12, 2002
With all this talk about fuel prices and stuff, I wanted to share this...I'm sure most of you must already know about AirNav, but in case you don't: http://www.airnav.com/fuel/greatdeals/pocket1.html There's also a "find me the best deal closest to me" feature: http://www.airnav.com/fuel/local.html )_( Dan dan @ rvproject . com http://www.rvproject.com ________________________________________________________________________________
Subject: Gas/Hangar rent
Date: Jun 12, 2002
100LL $2.19 Hangar $110 to $125 from the City. All are Tees with blacktop, electric Overhead bifold doors, lights and one electric outlet and half wall between stalls. Older hangars are less than the newer and possibly a smaller but all can hold two RV's. Privately owned hangars are slightly cheaper if and when available. Dick DeCramer Faribault Municipal Airport 40 Miles out of Minneapolis ________________________________________________________________________________
Subject: Engine guru
Date: Jun 12, 2002
I am NOT an engine guru but it sounds like you "may" have valve (s?) sticking. Run it until it is hot and the condition is appearing and then check compression. One cylinder colder than the others may be a symptom of a sticking valve. Sometimes when a shorted magneto coil heats up will then misfire causing this as well? Good luck Dick DeCramer Shade tree mechanic ________________________________________________________________________________
Date: Jun 12, 2002
Subject: Re: Engine guru
We also had a similar problem on a C172 and it was a cracked exhaust valve guide. Pull valve covers and look for black carbon buildup. Wayne Petrus RV8A finish kit ________________________________________________________________________________
Subject: RE: RV8-List: Need engine guru!!!
Date: Jun 12, 2002
What opinions does the guy who built the engine have to offer? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of TwoAviators > Sent: Wednesday, June 12, 2002 1:06 PM > To: rv8-list(at)matronics.com > Subject: RV8-List: Need engine guru!!! > > > --> RV8-List message posted by: TwoAviators > > > Have RV6, with Lycoming 0-360. Slick mags, bendix fuel > injection. Starts perfect, smooth with normal mag drop. AS > the engine warms up it runs rougher and rougher. Eventually > will barely run at all, what the heck is going on here? > > Checked the mags timing, replaced plugs, pulled injectors and > all seemed to be "peeing" uniformly. Turned on the boost > pump, nothing helped. It is obviously heat related, I am > looking to send the fuel injection system back to have it > checked out, any other thoughts? > > Thanks. > > ________________________________________________________________________________
Subject: Re: RV-6 panel wiring
Date: Jun 12, 2002
You can still get to everything pretty well underneath, as long as you don't have the wires to high up on the sub panel. what I would do is make sure you have everything right and wait until you start your engine. Then when you know that all of your engine instruments are working, and so are your avionics, then you can rivet the top skin on. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Gary Gunn" <ggunn(at)qwest.net> Subject: RV-List: RV-6 panel wiring > > For those who have wired their panels, do you feel that wiring runs in the > subpanel area be run as low in the subpanel area as possible and thus be > easily accessable from underneath, as opposed to drilling holes in the > subpanel ribs and running wires. I have the top skin off so my first thought > is to just run the main runs thru the ribs but I'm not sure if this would be > such a good idea once the top skin is on. > > Appreciate any recommendations and comments. > > Gary Gunn > RV-6 panel and finish kit. > > ________________________________________________________________________________
Date: Jun 12, 2002
Subject: Re: RV4-List: Ferry flight
Hi Art; I'll call you tonight. I can probably do it the 2d week in July...I have 800 RV hours, and a "couple of hours" in other stuff too. Rob Ray --- art stavro wrote: > --> RV4-List message posted by: art stavro > > > Are there any experienced RV4 pilots out there who > might be interested > in flying an RV from Virginis to California? If so > call Art at 510 541 > 4979 Cell/510 278 0260 home..Art Stavro > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > http://fifaworldcup.yahoo.com ________________________________________________________________________________
Date: Jun 12, 2002
Bob Barrows the man that rebuilt the engine said send the fuel injection components to the manufacturer for check out. We will do that. Just thought Id ask if there were any other ideas. I am wondering if the capacitor in the Mag is getting hot and not working. Hopefully Paul will get it al figured out soon. I am flying to Hotlanta tomorrow, hope to fly the 8 Friday. Dan >--> RV8-List message posted by: "Larry Bowen" > >What opinions does the guy who built the engine have to offer? > >- >Larry Bowen >Larry(at)BowenAero.com >http://BowenAero.com > > >> -----Original Message----- >> From: owner-rv8-list-server(at)matronics.com >> [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of TwoAviators >> Sent: Wednesday, June 12, 2002 1:06 PM >> To: rv8-list(at)matronics.com >> Subject: RV8-List: Need engine guru!!! >> >> >> --> RV8-List message posted by: TwoAviators >> >> >> Have RV6, with Lycoming 0-360. Slick mags, bendix fuel >> injection. Starts perfect, smooth with normal mag drop. AS >> the engine warms up it runs rougher and rougher. Eventually >> will barely run at all, what the heck is going on here? >> >> Checked the mags timing, replaced plugs, pulled injectors and >> all seemed to be "peeing" uniformly. Turned on the boost >> pump, nothing helped. It is obviously heat related, I am >> looking to send the fuel injection system back to have it >> checked out, any other thoughts? >> >> Thanks. >> >> > > ________________________________________________________________________________
Date: Jun 12, 2002
Subject: RV4 Canopy for Sale
I have a new RV-4 canopy for sale. It has never been removed from the original shipping crate. It is the grey tinted canopy, Vans part number C-401. Send an email if you would like more info and some photos. Thanks Jeff Bertsch RV-4 Houston, TX Noms1reqd(at)yahoo.com http://fifaworldcup.yahoo.com ________________________________________________________________________________
Date: Jun 12, 2002
Date: Jun 12, 2002
Subject: Sensenich Prop & Spacer - Tight Fit ??
I'm currently doing the spinner and prop on my -6A. I have the 70CM Sensenich prop with the usual Van's spinner and the Sensenich 2 1/4" spacer that goes onto the propflange w/flywheel on an O-320. The problem (?) seems to be that the locating pins in the spacer are a very close or even interference fit in the prop. Putting them together looks like a BFH job (well, perhaps a nice soft rubber mallet instead) with little realistic prospect of getting them apart again. Is this the expected fit or is some action needed to "improve" the fit somewhat ?? If the former, then it looks like just one opportunity to put the spinner back plate in place before things are set in place almost permanently which will make fitting the spinner a bit trickier. Nothing I can see in the archives on this. Jim Oke RV-6A - endless tinkering stage RV-3 - field too wet to fly ! ________________________________________________________________________________
Subject: Re: Landmark Birthday
Date: Jun 12, 2002
OK I'll guess: You Can't Trust Any One Over 30 ??? Or: Lordy Lordy Look Who's 40 ??? Or: Nifty - How's it feel to be 50 ??? Whatever Age You Are - Or Want To Be! Happy Birthday George Don Eaves A Sexy Senior Citizen Of 55 Years Ana An RV Builder Who Sits On The Best Seats In The RV World! doneaves(at)midsouth.rr.com ________________________________________________________________________________
Date: Jun 12, 2002
Hello Jim, I go thru Pestigo at least twice a month. Thats why I am looking into flying north rather than driving. If you have an RV would you mind if I could take a peak one day. Reagards, Paul ----- Original Message ----- From: "Jeff Orear" <jorear(at)new.rr.com> Subject: Re: RV-List: Aircraft operating costs > > List: > > Not sure I want to spill the beans on a good thing, but I lease the hunk of > dirt my 40x30 hangar sits on for $187.00/year. That's life in God's > Country....NE Wisconsin. > > DNA > > Regards, > > Jeff Orear > RV6A > Riveting fuse skeleton > Peshtigo, WI > ----- Original Message ----- > From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> > To: > Subject: RE: RV-List: Aircraft operating costs > > > > > > > I built the T-hangar myself but I lease the spot it sits on for $35 / > month. > > Oakdale, California. ( O27 ) > > > > -- > > Scott VanArtsdalen, MCSE, CCNA > > Network Administrator > > Union Safe Deposit Bank > > 209-946-5116 > > > > ________________________________________________________________________________
Subject: relocating elevator trim servo
Date: Jun 12, 2002
At some point I came across a kit to relocate the elevator trim servo from the elevator to inside the rear of the fuselage. Anyone else seen this and have experience with it? I can no longer locate contact info. Paul R. Antoinette SGS1-26 N8672R #207 mailto:antoinep(at)rmi.net ________________________________________________________________________________
Date: Jun 13, 2002
I'm currently doing the spinner and prop on my -6A. I have the 70CM Sensenich prop with the usual Van's spinner and the Sensenich 2 1/4" spacer that goes onto the propflange w/flywheel on an O-320. The problem (?) seems to be that the locating pins in the spacer are a very close or even interference fit in the prop. Putting them together looks like a BFH job (well, perhaps a nice soft rubber mallet instead) with little realistic prospect of getting them apart again. Is this the expected fit or is some action needed to "improve" the fit somewhat ?? If the former, then it looks like just one opportunity to put the spinner back plate in place before things are set in place almost permanently which will make fitting the spinner a bit trickier. Nothing I can see in the archives on this. Jim Oke RV-6A - endless tinkering stage RV-3 - field too wet to fly ! ------------------------------------- Hi Jim It's a tight fit and thats the way it is supposed to be. You will have to take it apart at least once when you make and rivet the filler plates in the prop spinner cutout. In assembly use a larger hammer and protect the aluminum with a block of wood. I made a wood cradel to support the prop shank and used a brass punch to take it apart. George McNutt Langley B.C. ________________________________________________________________________________
Subject: Re: RE: RV8-List: Need engine guru!!!
Date: Jun 13, 2002
I just solved the very same problem with my boat. Turned out to be faulty plug wires. Worked fine when the engine was cold. As the engine warmed up, maximum rpm slowly digressed from 4000 to 0 rpm. ----- Original Message ----- From: "TwoAviators" <TwoAviators(at)lexcominc.net> Subject: RV-List: RE: RV8-List: Need engine guru!!! > > Bob Barrows the man that rebuilt the engine said send the fuel injection > components to the manufacturer for check out. > > We will do that. Just thought Id ask if there were any other ideas. I am > wondering if the capacitor in the Mag is getting hot and not working. > > Hopefully Paul will get it al figured out soon. > > I am flying to Hotlanta tomorrow, hope to fly the 8 Friday. > > Dan > > > >--> RV8-List message posted by: "Larry Bowen" > > > >What opinions does the guy who built the engine have to offer? > > > >- > >Larry Bowen > >Larry(at)BowenAero.com > >http://BowenAero.com > > > > > >> -----Original Message----- > >> From: owner-rv8-list-server(at)matronics.com > >> [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of TwoAviators > >> Sent: Wednesday, June 12, 2002 1:06 PM > >> To: rv8-list(at)matronics.com > >> Subject: RV8-List: Need engine guru!!! > >> > >> > >> --> RV8-List message posted by: TwoAviators > >> > >> > >> Have RV6, with Lycoming 0-360. Slick mags, bendix fuel > >> injection. Starts perfect, smooth with normal mag drop. AS > >> the engine warms up it runs rougher and rougher. Eventually > >> will barely run at all, what the heck is going on here? > >> > >> Checked the mags timing, replaced plugs, pulled injectors and > >> all seemed to be "peeing" uniformly. Turned on the boost > >> pump, nothing helped. It is obviously heat related, I am > >> looking to send the fuel injection system back to have it > >> checked out, any other thoughts? > >> > >> Thanks. > >> > >> > > > > > > ________________________________________________________________________________
Date: Jun 13, 2002
Subject: Re: relocating elevator trim servo
> >At some point I came across a kit to relocate the elevator trim servo >from the elevator to inside the rear of the fuselage. Anyone else seen >this and have experience with it? I can no longer locate contact info. > >Paul R. Antoinette >SGS1-26 N8672R #207 >mailto:antoinep(at)rmi.net > That sounds like Warren Gretz. http://www.gretzaero.com/ info(at)gretzaero.com Gretz Aero 3664 East Lake Drive Littleton, Colorado 80121 Phone: 303-770-3811. I've never seen his elevator trim mounting system, but I've got his heated pitot mount, and it is a first class product. -- Kevin Horton RV-8 (installing engine & electrics) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
Subject: Re: Sensenich Prop & Spacer - Tight Fit ??
Date: Jun 13, 2002
REAP-MailScanner: Found to be clean Hi, This is ment to be a tight fit, lot of info on it came with my Sensenich prop. Info was with the prop logbook. Cheers, Arthur Whitehead RV-8 finishing ----- Original Message ----- From: "Jim Oke" <wjoke(at)shaw.ca> Subject: RV-List: Sensenich Prop & Spacer - Tight Fit ?? > > I'm currently doing the spinner and prop on my -6A. > ________________________________________________________________________________
Date: Jun 13, 2002
Subject: Narco 850 wiring diagram needed
Listers, One of my friends has a Narco 859 transponder with a 15 pin (as opposed to the 25 pin) connector. He needs a wiring diagram for this unit. Can anyone help? Please contact me off list. Charlie Kuss RV-8A fuselage Boca Raton, Fl. ________________________________________________________________________________
Date: Jun 13, 2002
How about $2.95/gal for 100LL at BVY Beverly, MA Tim Whitman RV6 parted out after 600hrs, waiting for -10 ----- Original Message ----- From: "Carroll Bird" <catbird(at)taylorelectric.com> Subject: Re: Fw: RV-List: Fuel Prices (Was operating costs) > > Don't stop at Abilene Aero at ABI $2.79 per gallon. Carroll Bird > ________________________________________________________________________________
Date: Jun 13, 2002
Thanks to George and Arthur. I thought the machine work on the prop and spacer was rather too high in quality for the tight fit to be an accident. I will proceed on the understanding that later separation of prop and spacer is difficult but possible with care. Jim ----- Original Message ----- From: "George McNutt" <gmcnutt(at)intergate.ca> Subject: RE: RV-List: Sensenich Prop & Spacer - Tight Fit ?? > > > I'm currently doing the spinner and prop on my -6A. > > I have the 70CM Sensenich prop with the usual Van's spinner and the > Sensenich 2 1/4" spacer that goes onto the propflange w/flywheel on an > O-320. > > The problem (?) seems to be that the locating pins in the spacer are a very > close or even interference fit in the prop. Putting them together looks like > a BFH job (well, perhaps a nice soft rubber mallet instead) with little > realistic prospect of getting them apart again. > > Is this the expected fit or is some action needed to "improve" the fit > somewhat ?? If the former, then it looks like just one opportunity to put > the spinner back plate in place before things are set in place almost > permanently which will make fitting the spinner a bit trickier. Nothing I > can see in the archives on this. > > Jim Oke > RV-6A - endless tinkering stage > RV-3 - field too wet to fly ! > > > ------------------------------------- > > Hi Jim > > It's a tight fit and thats the way it is supposed to be. You will have to > take it apart at least once when you make and rivet the filler plates in the > prop spinner cutout. > > > In assembly use a larger hammer and protect the aluminum with a block of > wood. > I made a wood cradel to support the prop shank and used a brass punch to > take it apart. > > George McNutt > Langley B.C. > > ________________________________________________________________________________
Date: Jun 13, 2002
Try www.gretzaero.com Ed Cole ----- Original Message ----- From: "Paul R. Antoinette" <antoinep(at)rmi.net> Subject: RV-List: relocating elevator trim servo > > At some point I came across a kit to relocate the elevator trim servo > from the elevator to inside the rear of the fuselage. Anyone else seen > this and have experience with it? I can no longer locate contact info. > > Paul R. Antoinette > SGS1-26 N8672R #207 > mailto:antoinep(at)rmi.net > > > > > > ________________________________________________________________________________
Date: Jun 13, 2002
Jim, George and Arthur were correct in their explanations. What we have here is indeed, slight metal displacement when the spacer is first attached. You are placing a .0502 pin in a .050 hole. It will be very tight the first time, but it is fairly easy to remove and replace after that. The guys who have friends with presses are the lucky ones!!!!!!! Ed Zercher Sensenich Propeller Manufacturing Company ________________________________________________________________________________
Date: Jun 13, 2002
I got this set up on "Casper" almost a hundred hours and love it. Garry "Paul R. Antoinette" wrote: > > At some point I came across a kit to relocate the elevator trim servo > from the elevator to inside the rear of the fuselage. Anyone else seen > this and have experience with it? I can no longer locate contact info. > > Paul R. Antoinette > SGS1-26 N8672R #207 > mailto:antoinep(at)rmi.net > ________________________________________________________________________________
Date: Jun 13, 2002
I guess I must be in heaven. I pay $110 a month for a nice 40x80 heated/air-conditioned hangar/shop, and it is about 300 feet from where I am building our new home. I'm about a half-hour's drive north of Indianapolis. We have 12 airplanes on our airpark (8I3, Glenndale Airport), and fuel right now is $2.10 for the residents. Since we have only a 1000 gallon tank, the price of fuel is considerably higher due to the fact that we cannot take a tanker-full, which is 8000 gallons. You get a big break if they can empty the tanker. I know a guy that owns an FBO at Winchester, IN, and he sells 100LL for $1.80 a gallon. He has a 12,000 gallon tank which gets him a little negotiating power, he can wait out spikes in fuel prices and still have enough capacity for a tanker load. He told me he marks up the fuel $.30/gal. I wish there were more aviation people around like him that have a little more business sense--people go where the fuel is cheap. I know other FBO owners that try to sell fuel for $2.80 a gallon and wonder why everybody on their airport go elsewhere for fuel. DUH! We've been exploring the idea of putting in a larger tank and credit card pump on our airport, if we could find a tank setup that didn't cost a fortune. Bob RV-6 300+ hours F1 under const. > From: "Dick DeCramer" <diesel(at)rconnect.com> > Subject: RV-List: Gas/Hangar rent > > > 100LL $2.19 > Hangar $110 to $125 from the City. All are Tees with > blacktop, electric > Overhead bifold doors, lights and one electric outlet and half wall > between stalls. Older hangars are less than the newer and possibly a > smaller but all can hold two RV's. Privately owned hangars > are slightly > cheaper if and when available. > > Dick DeCramer > Faribault Municipal Airport > 40 Miles out of Minneapolis ________________________________________________________________________________
Date: Jun 13, 2002
Dear Paul, Try www.gretzaero.com and look up their Elevator Trim System. Cheers, Konrad > At some point I came across a kit to relocate the elevator trim servo > from the elevator to inside the rear of the fuselage. Anyone else seen > this and have experience with it? I can no longer locate contact info. > > Paul R. Antoinette > SGS1-26 N8672R #207 > mailto:antoinep(at)rmi.net ________________________________________________________________________________
Date: Jun 13, 2002
Is this a recent rebuild? Was the dry tappet clearance checked before first run? -----Original Message----- From: TwoAviators [mailto:TwoAviators(at)lexcominc.net] Subject: RE: RV8-List: Need engine guru!!! --> RV8-List message posted by: TwoAviators Bob Barrows the man that rebuilt the engine said send the fuel injection components to the manufacturer for check out. We will do that. Just thought Id ask if there were any other ideas. I am wondering if the capacitor in the Mag is getting hot and not working. Hopefully Paul will get it al figured out soon. I am flying to Hotlanta tomorrow, hope to fly the 8 Friday. Dan >--> RV8-List message posted by: "Larry Bowen" > >What opinions does the guy who built the engine have to offer? > >- >Larry Bowen >Larry(at)BowenAero.com >http://BowenAero.com > > >> -----Original Message----- >> From: owner-rv8-list-server(at)matronics.com >> [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of TwoAviators >> Sent: Wednesday, June 12, 2002 1:06 PM >> To: rv8-list(at)matronics.com >> Subject: RV8-List: Need engine guru!!! >> >> >> --> RV8-List message posted by: TwoAviators >> >> >> Have RV6, with Lycoming 0-360. Slick mags, bendix fuel >> injection. Starts perfect, smooth with normal mag drop. AS >> the engine warms up it runs rougher and rougher. Eventually >> will barely run at all, what the heck is going on here? >> >> Checked the mags timing, replaced plugs, pulled injectors and >> all seemed to be "peeing" uniformly. Turned on the boost >> pump, nothing helped. It is obviously heat related, I am >> looking to send the fuel injection system back to have it >> checked out, any other thoughts? >> >> Thanks. >> >> > > ________________________________________________________________________________
Subject: Carb rebuild manual
Date: Jun 13, 2002
Does anyone know where I could get a rebuild manual for the Marvel Schibler carburetor MA4-SPA? Thanks Larry Hawkins, RV-4 Farmington, NM, N-345SL, finishing. ________________________________________________________________________________
Subject: Re: Carb rebuild manual
Date: Jun 13, 2002
Goto http://www.precisionairmotive.com click on aviation then carbs and then support. Lots of information here. Gary Quoting Larry Hawkins : > > Does anyone know where I could get a rebuild manual for the Marvel > Schibler > carburetor MA4-SPA? > Thanks > Larry Hawkins, RV-4 Farmington, NM, N-345SL, finishing. > > > > > > > ________________________________________________________________________________
"aeroelectric-list"
Subject: Fw: air force using tablet PCs
Date: Jun 13, 2002
Listers, The article at the link below shows that the Air Force "could be" monitoring our homebuilt experimental movement [ grin ] . . . well, "is", in fact, paralleling us in adopting "forward thinking" technological innovations in the area of low cost, commercial off-the-shelf cockpit moving map+gps gadgets. It's a good read. David Carter ----- Original Message ----- From: "Steve Carter" [ my brother ] Subject: air force using tablet PCs > http://computerworld.com/hardwaretopics/hardware/story/0,10801,71940,00.html > ?nlid=PM ________________________________________________________________________________
Date: Jun 13, 2002
From: "Builder's Bookstore" <winterland(at)rkymtnhi.com>
> Does anyone know where I could get a rebuild manual for the Marvel Schibler > carburetor MA4-SPA? On video & CD at Builder's Bookstore, in the powerplant/accessories section. Thanks, Andy Builder's Bookstore http://buildersbooks.com ________________________________________________________________________________
Date: Jun 13, 2002
go to http://www.precisionairmotive.com/ and most everything is there Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org Always looking for articles for the Experimenter ----- Original Message ----- From: "Larry Hawkins" <lhawkins(at)giant.com> Subject: RV-List: Carb rebuild manual Does anyone know where I could get a rebuild manual for the Marvel Schibler carburetor MA4-SPA? Thanks Larry Hawkins, RV-4 Farmington, NM, N-345SL, finishing. ________________________________________________________________________________
Subject: Fuel Flow...
Date: Jun 13, 2002
Is there a relatively inexspensive fuel flow system out there for me? Remember, I am cheap AND broke... -Bill RV-8A http://vondane.com/rv8a ________________________________________________________________________________
Date: Jun 13, 2002
Subject: Re: Fuel Flow...
--- Bill VonDane wrote: > > Is there a relatively inexspensive fuel flow system out there for me? > > Remember, I am cheap AND broke... Ummm.... fuel gauge and a watch? :) Just joking! Hi Bill! Mike Thompson Austin, TX -6 N140RV (Reserved) FWF http://fifaworldcup.yahoo.com ________________________________________________________________________________
Date: Jun 13, 2002
Subject: Need Help Checking Out An RV7 Kit In Mississippi
Is there anyone out there in Mississippi that could check out a kit-in-progress for me? I'm trying to pick up an RV-7 project, but cannot get there to check it out beforehand. I'd rather not buy it COMPLETELY sight-unseen. Having another builder look it over first would really help out. We're arranging delivery for the weekend of June 22, so I'd like to get it checked, say, before the 18th or 19th. Any help would be GREATLY appreciated. Any other ideas would be appreciated as well. (No digital camera available) Thanks, -Vince -- Vince Orton About to start an RV-7A ... ________________________________________________________________________________
Date: Jun 13, 2002
Bill, here is the web page for one for $275. Fuel flow, Fuel Remaining, Low fuel alarm, etc. http://www.measureanything.com/products/AU4127/datasheet_fuel_flow_system.as p Ed Anderson RV-6A N494BW Matthews, NC ----- Original Message ----- From: "Bill VonDane" <n8wv(at)hotmail.com> Subject: RV-List: Fuel Flow... > > Is there a relatively inexspensive fuel flow system out there for me? > > Remember, I am cheap AND broke... > > -Bill > RV-8A > http://vondane.com/rv8a > > ________________________________________________________________________________
Date: Jun 13, 2002
> Is there a relatively inexspensive fuel flow system out there for me? > > > > Remember, I am cheap AND broke... > > Radio Shack sells a dual timer for about $10 that I've got velcroed to the panel of my 6A. Among other functions it simultaneoulsy shows two count-down timers. As part of my pre-flight I stick each tank, compute for 9 gph and set the proper time on each display. Fly off the left tank, the left timer runs; right tank - right timer. I find it accurate and dependable knowing for example that I've got 55 minutes in one tank and 1:20 in the other. If you want to be conservative, compute for 9.5 gph. Then you'll always have a little more gas than you thought you did. Andy ________________________________________________________________________________
Date: Jun 13, 2002
Vince, What part of Mississippi? I'm in the souther part near Biloxi. Eric Newton - Long Beach, MS RV-6A - N57ME (Flying) www.ericsrv6a.com <> <> Any other ideas would be appreciated as well. (No digital camera available) Thanks, -Vince -- Vince Orton About to start an RV-7A ... Eric Newton - Long Beach, MS RV-6A - N57ME (Flying) www.ericsrv6a.com ________________________________________________________________________________
Date: Jun 13, 2002
Bill, Check out http://www.boatfix.com/elec/standgps.asp ; look towards the bottom of the page. D. Walsh has one of these in his 6A and it works great. Gary Quoting Bill VonDane : > > Is there a relatively inexspensive fuel flow system out there for me? > > Remember, I am cheap AND broke... > > -Bill > RV-8A > http://vondane.com/rv8a > > > > > > > ________________________________________________________________________________
Date: Jun 13, 2002
Gary... Do you get everything for $192 or do you have to buy the things below as well? -Bill ----Original Message Follows---- From: Gary Zilik <zilik(at)bewellnet.com> Subject: Re: RV-List: Fuel Flow... Date: Thu, 13 Jun 2002 13:12:13 -0600 (MDT) Bill, Check out http://www.boatfix.com/elec/standgps.asp ; look towards the bottom of the page. D. Walsh has one of these in his 6A and it works great. Gary ________________________________________________________________________________
Date: Jun 13, 2002
I recently installed this gauge in my -6A too, between the selector and the electric pump. It updates every second and jumps around .2-.3 gph. I am still trying to calibrate it, unfortunately it is on the optimistic side. It seems to be under 2 gallons off over a whole tank. Unexplicably it jumps 1 gph when the fuel pump is switched on. Being a marine instrument the cable is like 24' long! Someone told me they bought the same instrument for $130. I don't know if installing it in the pressurized portion of the line would help. It says not to, but Benua had to install his(Matronics) that way to make it accurate. I would try this but it is a bunch more work and more holes in the firewall. Kevin ----- Original Message ----- From: "Ed Anderson" <eanderson(at)carolina.rr.com> Subject: Re: RV-List: Fuel Flow... > > Bill, here is the web page for one for $275. Fuel flow, Fuel Remaining, Low > fuel alarm, etc. > > http://www.measureanything.com/products/AU4127/datasheet_fuel_flow_system.as > p > > Ed Anderson > RV-6A N494BW > Matthews, NC > > ----- Original Message ----- > From: "Bill VonDane" <n8wv(at)hotmail.com> > To: ; ; > > Subject: RV-List: Fuel Flow... > > > > > > Is there a relatively inexspensive fuel flow system out there for me? > > > > Remember, I am cheap AND broke... > > > > -Bill > > RV-8A > > http://vondane.com/rv8a > > > > > > ________________________________________________________________________________
Date: Jun 13, 2002
ez(at)sensenich.com Thanks to all for your comments. As is the way with many things, the job turned out to be quite easy when I finally tackled it.. Two carefully placed blocks of wood and about 6 hits with a 3 lb. deadblow hammer, and the deed was done. Haven't try to separate the two as yet and may not have to depending on how the rest of the spinner goes. Cheers, Jim Oke YWG, MB ----- Original Message ----- From: "Jim Oke" <wjoke(at)shaw.ca> Subject: Re: RV-List: Sensenich Prop & Spacer - Tight Fit ?? > > Thanks to George and Arthur. I thought the machine work on the prop and > spacer was rather too high in quality for the tight fit to be an accident. I > will proceed on the understanding that later separation of prop and spacer > is difficult but possible with care. > > Jim > > > ----- Original Message ----- > From: "George McNutt" <gmcnutt(at)intergate.ca> > To: > Subject: RE: RV-List: Sensenich Prop & Spacer - Tight Fit ?? > > > > > > > > I'm currently doing the spinner and prop on my -6A. > > > > I have the 70CM Sensenich prop with the usual Van's spinner and the > > Sensenich 2 1/4" spacer that goes onto the propflange w/flywheel on an > > O-320. > > > > The problem (?) seems to be that the locating pins in the spacer are a > very > > close or even interference fit in the prop. Putting them together looks > like > > a BFH job (well, perhaps a nice soft rubber mallet instead) with little > > realistic prospect of getting them apart again. > > > > Is this the expected fit or is some action needed to "improve" the fit > > somewhat ?? If the former, then it looks like just one opportunity to put > > the spinner back plate in place before things are set in place almost > > permanently which will make fitting the spinner a bit trickier. Nothing I > > can see in the archives on this. > > > > Jim Oke > > RV-6A - endless tinkering stage > > RV-3 - field too wet to fly ! > > > > > > ------------------------------------- > > > > Hi Jim > > > > It's a tight fit and thats the way it is supposed to be. You will have to > > take it apart at least once when you make and rivet the filler plates in > the > > prop spinner cutout. > > > > > > In assembly use a larger hammer and protect the aluminum with a block of > > wood. > > I made a wood cradel to support the prop shank and used a brass punch to > > take it apart. > > > > George McNutt > > Langley B.C. > > ________________________________________________________________________________
Date: Jun 13, 2002
$2.95 ??? That's Airway Robbery! You got'sda move yourself to New Mexico, and fill 'er up for around 2 Bucks! KLW Dew Knot R-kyv! > How about $2.95/gal for 100LL at BVY Beverly, MA > > Tim Whitman > RV6 parted out after 600hrs, waiting for -10 ________________________________________________________________________________
Date: Jun 13, 2002
I think Matt probably has the best deal in town. Mike ----- Original Message ----- From: "Bill VonDane" <n8wv(at)hotmail.com> Subject: RV-List: Fuel Flow... > > Is there a relatively inexspensive fuel flow system out there for me? > > Remember, I am cheap AND broke... > > -Bill > RV-8A > http://vondane.com/rv8a > > ________________________________________________________________________________
Date: Jun 13, 2002
Use never seize when you assemble it. It will help with disassembly. Phil Jim Oke wrote: > >Thanks to George and Arthur. I thought the machine work on the prop and >spacer was rather too high in quality for the tight fit to be an accident. I >will proceed on the understanding that later separation of prop and spacer >is difficult but possible with care. > >Jim > > >----- Original Message ----- >From: "George McNutt" <gmcnutt(at)intergate.ca> >To: >Subject: RE: RV-List: Sensenich Prop & Spacer - Tight Fit ?? > > >> >> >>I'm currently doing the spinner and prop on my -6A. >> >>I have the 70CM Sensenich prop with the usual Van's spinner and the >>Sensenich 2 1/4" spacer that goes onto the propflange w/flywheel on an >>O-320. >> >>The problem (?) seems to be that the locating pins in the spacer are a >> >very > >>close or even interference fit in the prop. Putting them together looks >> >like > >>a BFH job (well, perhaps a nice soft rubber mallet instead) with little >>realistic prospect of getting them apart again. >> >>Is this the expected fit or is some action needed to "improve" the fit >>somewhat ?? If the former, then it looks like just one opportunity to put >>the spinner back plate in place before things are set in place almost >>permanently which will make fitting the spinner a bit trickier. Nothing I >>can see in the archives on this. >> >>Jim Oke >>RV-6A - endless tinkering stage >>RV-3 - field too wet to fly ! >> >> >>------------------------------------- >> >>Hi Jim >> >>It's a tight fit and thats the way it is supposed to be. You will have to >>take it apart at least once when you make and rivet the filler plates in >> >the > >>prop spinner cutout. >> >> >>In assembly use a larger hammer and protect the aluminum with a block of >>wood. >>I made a wood cradel to support the prop shank and used a brass punch to >>take it apart. >> >>George McNutt >>Langley B.C. >> >> > > ________________________________________________________________________________
Date: Jun 14, 2002
Listers! The Fuel flow device previously mentioned [Horizon], is manufactured in New Zealand [Navman],& is fitted as OEM on most Jabiru aircraft built in Australia...seems reliable in that application. Transducer is a bit minimal though,probably not comparable quality to Flowscan unit.. Price here in Oz,with transducer approx. $160 USD. cheers! James Connell ----- Original Message ----- From: Bill VonDane <n8wv(at)hotmail.com> Subject: Re: RV-List: Fuel Flow... > > Gary... > > Do you get everything for $192 or do you have to buy the things below as > well? > > -Bill > > > ----Original Message Follows---- > From: Gary Zilik <zilik(at)bewellnet.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: Fuel Flow... > Date: Thu, 13 Jun 2002 13:12:13 -0600 (MDT) > > > Bill, > > Check out http://www.boatfix.com/elec/standgps.asp ; look towards the bottom > of > the page. D. Walsh has one of these in his 6A and it works great. > > Gary > > ________________________________________________________________________________
Subject: Engine runout.
Date: Jun 13, 2002
After looking at several aircraft salvage websites, I've got some questions of the group. What would an acceptable runout be? I see several in the .002 all the way to .074 (rattles). Dana Overall Richmond, KY RV-7 emp. complete, wings due tomorrow http://rvflying.tripod.com MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide.aspx ________________________________________________________________________________
Subject: Alergy reaction to fiberglass dust
Date: Jun 13, 2002
Can someone tell me if there is a cure to the rash caused by the dust from my wheel pants. I'm absolutely sure this is the cause because it only affected two to three inches above my shoes. A rash began within two hours. After a few days, it began to itch. Now after six (6) weeks it is itching more than ever. The first application of Hydrocortisone relieved the itch for a week. Now, it is only effective for a day. Sure would appreciate a remedy. Thanks in advance, Tom Barnes -6 wrapping it up. ________________________________________________________________________________
Subject: RE: Lean Too
Date: Jun 13, 2002
-----Original Message----- From: D.H.Kirkwood [mailto:204dk(at)comcast.net] Sent: Thursday, June 13, 2002 4:56 AM To: gmcnutt(at)intergate.ca Subject: Lean Too George, I have a new 032 that I have been breaking in, about 30 hrs, and can't seem to keep the temperature down on climb out and feel I am running on the hot side during cruise. ----- was wondering what temps, EGT & CHT you were running before & after your fix. If I climb out at 500 to 700 FPM & 120 MPH, I go to about 440 deg on #3 in a 1000' of climb and need to level out. At 6500' cruise and an outside temp of 75 deg I was running 406 on #3 at 65% power and 420 to 427 at 75% power. EGT on the same cyl was in the 1400 deg range during these test. Been through all the baffle checks, even re-did them just to be certain. Talked to Van's last and they think my Jet nozzle needs to be replaced or drilled out. I have a 10-5217 carb that they said has a 828 jet and recommended going to a #773. Their alternate suggestion was that I insert a # drill in the existing jet to determine the size and then drill it out two additional # sizes, try it and I may need to drill further. I was wondering if talked to Van's about your problem and if you first attempted to replace your jet. Dennis Kirkwood Brighton, Michigan [George McNutt] Hi Dennis I am not a great believer in EGT's so I only have a good digital Cyl Head Temp gauge on my aircraft. Since drilling out the carb jet twice, from #42 drill size to #38 then #36 my cylinder temperatures have dropped from 20 to 30 degrees Farenheit in climb & cruise. The best way to tell how lean your engine is running is to see what the temperatures do when you lean it out at altitude, getting up up to 7 - 8 thousand feet will make it easier to see the changes. You are looking for your temperatures to increase with leaning, peak and then decrease. If you are already lean you will not see much increase. If you are really lean like I was (beyond peak temps) you will see only a decrease in temps. Without leaning a normal engine should be running rich with the mixture control in, as you lean, temperatures both CHT and EGT should increase, also power should increase, if you have a fixed pitch prop you want to see a increase in rpm. (Reference the graph on page 3.8 of the Lycoming 0-360 operators manual) On a rich running engine you could see the CHT increase by up to 80 deg F. (mine now rises 25 Deg) EGT could increase by up to 400 F and power increase by 5%. before starting to decrease. As you continue to (very slowly) lean past the max power range first the power (RPM) will start to decrease, then CHT and lastly EGT this is into the best economy range power and not something you want for takeoff & initial climb.. With the carb jet at the initial #42 drill size my engine was runnining on the lean side of peak power, as soon as I started leaning the temperature (CHT) immediately dropped, also I had no increase in RPM. When drilled to # 38 it seemed to be very slightly on the rich side of peak power, I could get a 5 degree increase in CHT but no increase in power (RPM). When drilled #36 I now see a 25 degree CHT rise and a 50 RPM increase in power. I am satisfied with that. Hope that helps, I will also post this to the RV-List for others who may have this problem. George McNutt Langley, B.C. ________________________________________________________________________________
Date: Jun 13, 2002
In a message dated 6/12/2002 9:16:10 PM Pacific Daylight Time, wjoke(at)shaw.ca writes: > Is this the expected fit or is some action needed to "improve" the fit > somewhat Jim, I have the 72FM Sensenich prop for an 0-360 and mine was a tight interference fit as yours is. Those pins need to transfer all of the thrust pulses of a Lycoming without getting loose. I think they have to be a tight fit. Regards, Dale Wotring RV-6A Flying ________________________________________________________________________________
Subject: Re: Engine runout.
Date: Jun 13, 2002
Hi Dana: The max allowable when new is .002 and the max service limit is .005. Eustace Bowhay-Blind Bay, B.C. Rigging flaps and ailerons and installing wing tips on the 6A. ----- Original Message ----- From: "Dana Overall" <bo124rs(at)hotmail.com> Subject: RV-List: Engine runout. > > After looking at several aircraft salvage websites, I've got some questions > of the group. What would an acceptable runout be? I see several in the > .002 all the way to .074 (rattles). > > Dana Overall > Richmond, KY > RV-7 emp. complete, wings due tomorrow > http://rvflying.tripod.com > > > MSN Photos is the easiest way to share and print your photos: > http://photos.msn.com/support/worldwide.aspx > > ________________________________________________________________________________
Date: Jun 13, 2002
Subject: [ Fabian Lefler ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Fabian Lefler Subject: Compressor-Tool Bench http://www.matronics.com/photoshare/FLEFLER@broward.org.06.13.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jun 13, 2002
Subject: [ Kevin ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Kevin Subject: Langley, BC RV Fly-in http://www.matronics.com/photoshare/rv8r300@attbi.com.06.13.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jun 14, 2002
Subject: List Browsing Feature!
Dear Listers, I thought I'd post a little reminder to everyone about a very slick feature of the email Lists here at Matronics. You can now use Netscape or Internet Explorer to browse the current messages on your favorite List! The List Browse Function tracks the current 7 day's worth of List messages for any given List. Indexes are updated every 30 minutes with new messages that have been posted. You can resort the message indexes by Thread, Subject, Author, or Date and easily track and find current threads. A number of List members have written to say that they love the List Browser because they can keep tabs on the latest List messages throughout the day without having to constantly check their email or wait for the Digest issue to come out. You can check out the List Browse Feature by going to the following URL and clicking on the List of your choice: http://www.matronics.com/listbrowse Enjoy! Matt Dralle Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jun 14, 2002
Subject: Re: Alergy reaction to fiberglass dust
I became alergic to the epoxy resin while building one of the other kind of planes and could not finish it ... my hands would break out and itch very badly just from the smell of the epoxy. Doctors told me the cure was to stay away from it !! Len Leggette, RV-8A Greensboro, N.C. N910LL (res) Hooking up systems ________________________________________________________________________________
Date: Jun 14, 2002
08:08:36 AM I get the same thing if I get careless. Ya got to keep it off you. But since its too late, I like to use that alloe stuff they have for sunburns. The rash takes a while to go away. I don't remember it lasting six weeks though. You musta did it up real good Tom. Sorry I don't have anything better. Eric "Tom Barnes" (at)matronics.com on 06/13/2002 08:04:18 PM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RV-List: Alergy reaction to fiberglass dust Can someone tell me if there is a cure to the rash caused by the dust from my wheel pants. I'm absolutely sure this is the cause because it only affected two to three inches above my shoes. A rash began within two hours. After a few days, it began to itch. Now after six (6) weeks it is itching more than ever. The first application of Hydrocortisone relieved the itch for a week. Now, it is only effective for a day. Sure would appreciate a remedy. Thanks in advance, Tom Barnes -6 wrapping it up. ________________________________________________________________________________
Subject: RV8 Canopy Skirt
Date: Jun 14, 2002
Fitted the canopy skirt yesterday,and a surprisingly good fit. Has anybody tried to use heat from a heat gun, not a hair dryer ,to tweak the fit a little better. Chris S RV8 80881 Festus,MO http://www.hotmail.com ________________________________________________________________________________
Date: Jun 14, 2002
A purely experimental and speculative approach: Assuming the irritating particles causing the reaction are still lodged in the skin, you might try to sweat them out. Do you have a sauna nearby? Otherwise, maybe wrapping them in plastic and running or other heavy exercise of the legs. Finn Eric.J.Henson(at)chase.com wrote: > > I get the same thing if I get careless. Ya got to keep it off you. But > since its too late, I like to use that alloe stuff they have for sunburns. > The rash takes a while to go away. I don't remember it lasting six weeks > though. You musta did it up real good Tom. Sorry I don't have anything > better. > > Eric > > "Tom Barnes" (at)matronics.com on 06/13/2002 08:04:18 PM > > Please respond to rv-list(at)matronics.com > > Sent by: owner-rv-list-server(at)matronics.com > > To: > cc: > Subject: RV-List: Alergy reaction to fiberglass dust > > > Can someone tell me if there is a cure to the rash caused by the dust > from my wheel pants. I'm absolutely sure this is the cause because it > only affected two to three inches above my shoes. A rash began within > two hours. After a few days, it began to itch. Now after six (6) weeks > it is itching more than ever. > The first application of Hydrocortisone relieved the itch for a > week. Now, it is only effective for a day. Sure would appreciate a > remedy. > Thanks in advance, > Tom Barnes -6 wrapping it up. > ________________________________________________________________________________
Date: Jun 14, 2002
I don't know. I know Walsh paid about 365.00 and got the whole thing. Almost seems to good to be true at 192. A phone call would answer the question Gary Quoting Bill VonDane : > > Gary... > > Do you get everything for $192 or do you have to buy the things below as > > well? > > -Bill > > > ----Original Message Follows---- > From: Gary Zilik <zilik(at)bewellnet.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: Fuel Flow... > Date: Thu, 13 Jun 2002 13:12:13 -0600 (MDT) > > > Bill, > > Check out http://www.boatfix.com/elec/standgps.asp ; look towards the > bottom > of > the page. D. Walsh has one of these in his 6A and it works great. > > Gary > > > > > > > ________________________________________________________________________________
Date: Jun 14, 2002
Subject: Barnard landing light for RV6
Is anyone making a landing light exactly like the one Barnard use to make for an RV6? I need one for my RV6 project. Roger ________________________________________________________________________________
Date: Jun 14, 2002
Subject: Re: Shipping costs
Mine cost about the same to North Carolina. It's my understanding that the contents of the finish kit are classified differently from ABF's point of view. More fragile, I guess, with the canopy in there than the other kits. Thus more expensive. -Larry First cut on the canopy last night .... --- Jeff Point wrote: > > ABF Freightways called yesterday to make shipping arrangements for my finish > kit next week. The costs to ship to Milwaukee WI from Van's is $330, which > is more than twice what the fuse or wing kits (with two boxes!) cost. Would > anyone who has had a finish kit shipped in the last year or so please > contact me off list. I'd like specifically to know how much it cost, where > it was shipped to, who the freight company was, and if it was delivered to > your house or picked up at their dock. > > Thanks in advance. > > Jeff Point > RV-6 N187CF, finish kit coming! > Milwaukee WI http://fifaworldcup.yahoo.com ________________________________________________________________________________
Date: Jun 14, 2002
My finish kit was shipped to Biloxi, Mississippi and i picked it up at the dock. The cost was $392.00 I agree with Larry that it must be classified as more fragile. It was also the largest box as I could barely fit it in my trailer. Regards, Eric Newton - Long Beach, MS RV-6A - N57ME (Flying www.ericsrv6a.com ----- Original Message ----- From: "Larry Bowen" <lcbowen(at)yahoo.com> Subject: Re: RV-List: Shipping costs > > Mine cost about the same to North Carolina. It's my understanding that the > contents of the finish kit are classified differently from ABF's point of view. > More fragile, I guess, with the canopy in there than the other kits. Thus > more expensive. > > -Larry > First cut on the canopy last night .... > > > --- Jeff Point wrote: > > > > ABF Freightways called yesterday to make shipping arrangements for my finish > > kit next week. The costs to ship to Milwaukee WI from Van's is $330, which > > is more than twice what the fuse or wing kits (with two boxes!) cost. Would > > anyone who has had a finish kit shipped in the last year or so please > > contact me off list. I'd like specifically to know how much it cost, where > > it was shipped to, who the freight company was, and if it was delivered to > > your house or picked up at their dock. > > > > Thanks in advance. > > > > Jeff Point > > RV-6 N187CF, finish kit coming! > > Milwaukee WI > > http://fifaworldcup.yahoo.com > > ________________________________________________________________________________
Date: Jun 14, 2002
Does that mean you can't even fly in a plastic airplane? Earl, RV4 Lenleg(at)aol.com wrote: > > I became alergic to the epoxy resin while building one of the other kind of > planes and could not finish it ... my hands would break out and itch very > badly just from the smell of the epoxy. > > Doctors told me the cure was to stay away from it !! > > Len Leggette, RV-8A > Greensboro, N.C. N910LL (res) > Hooking up systems > ________________________________________________________________________________
Date: Jun 14, 2002
Gary, Do whatever you can to make access easier after installation of the top skin. Having the wire bundles lower is probably a good idea. Use nutplates for anything attached to the ribs. Use only Phillips screws (or square/torx drive), not slotted. Use Molex or Mate-N-Loc connectors for items that may need to be replaced or removed. Etc. ....... Ken Harrill RV-6, 15 hours For those who have wired their panels, do you feel that wiring runs in the subpanel area be run as low in the subpanel area as possible and thus be easily accessable from underneath, as opposed to drilling holes in the subpanel ribs and running wires. I have the top skin off so my first thought is to just run the main runs thru the ribs but I'm not sure if this would be such a good idea once the top skin is on. Appreciate any recommendations and comments. Gary Gunn RV-6 panel and finish kit. ________________________________________________________________________________
Date: Jun 14, 2002
I had my finish kit shipped to the ABF terminal in Nashville, TN. The cost, as best as I can remember, was $320. Point being, you can save some "Jack" by picking up your "box" at the terminal. (somewhere I heard as much as 30%) Tommy Walker 6A Finishing Ridgetop, TN ----- Original Message ----- From: Eric Subject: Re: RV-List: Shipping costs My finish kit was shipped to Biloxi, Mississippi and i picked it up at the dock. The cost was $392.00 I agree with Larry that it must be classified as more fragile. It was also the largest box as I could barely fit it in my trailer. Regards, Eric Newton - Long Beach, MS RV-6A - N57ME (Flying www.ericsrv6a.com ----- Original Message ----- From: "Larry Bowen" <lcbowen(at)yahoo.com> Subject: Re: RV-List: Shipping costs > > Mine cost about the same to North Carolina. It's my understanding that the > contents of the finish kit are classified differently from ABF's point of view. > More fragile, I guess, with the canopy in there than the other kits. Thus > more expensive. > > -Larry > First cut on the canopy last night .... > > > --- Jeff Point wrote: > > > > ABF Freightways called yesterday to make shipping arrangements for my finish > > kit next week. The costs to ship to Milwaukee WI from Van's is $330, which > > is more than twice what the fuse or wing kits (with two boxes!) cost. Would > > anyone who has had a finish kit shipped in the last year or so please > > contact me off list. I'd like specifically to know how much it cost, where > > it was shipped to, who the freight company was, and if it was delivered to > > your house or picked up at their dock. > > > > Thanks in advance. > > > > Jeff Point > > RV-6 N187CF, finish kit coming! > > Milwaukee WI > > http://fifaworldcup.yahoo.com > > ________________________________________________________________________________
Date: Jun 14, 2002
Subject: Re: RE: Lean Too
I am interested in the concept George introduces here; anyone care to weigh in on this idea, that CHT is more useful for leaning than EGT? I know in my RV (fully digitally instrumented for all 4 cylinders with EGT and CHT) that CHT response time is far too slow to be convenient for leaning. I also feel that CHT depends on too many other variables (distribution of cooling air flow, ambient air temp and airspeed) to be of use here. If George is right, however, we are spending perhaps far too much on needless EGT instrumentation. In my daily aircraft operations, I reference the CHT only on the ground before takeoff (200 degree minimum temp) and during extended hot-weather climbs. I occasionally look at it during descents, but I never like what it is telling me (far in excess of 3 allowable Fahrenheit degrees per minute of "shock cooling"), so I usually ignore the numbers there. Oh, yes, and I _used_ to look at CHT's when I was trying to balance the cooling air with air dams in the cowl; now that I have achieved that, I'm almost totally focused on oil and exhaust temps for normal operations. I don't think I'm alone in this, but I'm interested in what the rest of the list community thinks - this really intrigues me. -Bill B gmcnutt(at)intergate.ca writes: > I am not a great believer in EGT's so I only have a good digital Cyl Head > Temp gauge on my aircraft ________________________________________________________________________________
Date: Jun 14, 2002
> > > Is there a relatively inexspensive fuel flow system out there for me? > > > > Remember, I am cheap AND broke... > > >Ummm.... fuel gauge and a watch? What is the fuel gauge for?? K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Jun 14, 2002
> >After looking at several aircraft salvage websites, I've got some questions >of the group. What would an acceptable runout be? I see several in the >.002 all the way to .074 (rattles). I may have reported this before - an old timer told me that runout can be corrected easily with a sledge hammer. So, the low runout you get may have been hammered. :-( K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Jun 14, 2002
> >Listers! The Fuel flow device previously mentioned [Horizon], is I wonder if this is the same HORIZON that our tech counselor was railing about a few weeks ago. He got so mad telling me of his anguish with this company that I worried for his health! Apparently the unit didn't work and neither did the replacement and the company was rude and unhelpful. Aircraft is a Dan Rhin??? Summat like that. K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Jun 14, 2002
I ran all of mine under the 668 to the firewall. I started ddrilling holes & pulled them out so I can re-wire later if needed. Don Jordan - N6DJ - RV6A Arlington, Tx ******************************* > > For those who have wired their panels, do you feel that wiring runs > in the > subpanel area be run as low in the subpanel area as possible and > thus be > easily accessable from underneath, as opposed to drilling holes in > the > subpanel ribs and running wires. I have the top skin off so my first > thought > is to just run the main runs thru the ribs but I'm not sure if this > would be > such a good idea once the top skin is on. > > Appreciate any recommendations and comments. > > Gary Gunn > RV-6 panel and finish kit. > ________________________________________________________________________________
Subject: Re: RV8 Canopy Skirt
Date: Jun 14, 2002
Chris, We used a heat gun and it worked well, just take your time. As a side note: we found the best way to drill the canopy (to minimize cracking possibility was to use a # 40 drill bit and then open up the hole with the samll Unibit) This method grabs much less than even plastic drill bits. We then attached the canopy to the frame and skrit to the canopy with Semi weld (same thing as pro-seal) froma caulking type tube that is premixed thru the nozzle and everything is held in place with 4-6 keeper AACQ pop rivets. This system is used by Pitts and Christen Eagles. The nice thing is you get a nice finish, that is paintable and while firm has some flexibility to prevent cracking later on. Hope this helps. Good Building, Chuck & Dave Rowbotham RV-8A (Flying) >From: "Chris Santschi" <rv8pilot(at)hotmail.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: RV8 Canopy Skirt >Date: Fri, 14 Jun 2002 12:16:27 +0000 > > >Fitted the canopy skirt yesterday,and a surprisingly good fit. Has anybody >tried to use heat from a heat gun, not a hair dryer ,to tweak the fit a >little better. > >Chris S RV8 80881 >Festus,MO > > >http://www.hotmail.com > > ________________________________________________________________________________
Subject: XDP4000X-List: unhappy
Date: Jun 14, 2002
All- I hooked up my xdp-4000x and it sounds like crap. I ordered the necessary cable from online and tried to tune it, but it just got worse. Is there something missing htat I need to do to get it to work. When I bypass it with rca splitters the res of my system works like a charm. I have the 6001ES running three 10' ES subs. Then 2 1805 ES's handling everything else. Aside from the problems with the 4x, there is a huge disparity between cd volume and radio volume. I mean huge!!!. I can max out radio volume and it sounds ok, then pop in a cd and half way blows mee out of the cab. Any ideas, I anm just so dissapointed right now.... From: Matt Dralle <DRALLE(at)MATRONICS.COM> Reply-To: xdp4000x-list(at)matronics.com To: Email-Lists(at)matronics.com Subject: XDP4000X-List: List Browsing Feature! Date: Fri, 14 Jun 2002 00:52:33 -0700 -- XDP4000X-List message posted by: Matt Dralle Dear Listers, I thought I'd post a little reminder to everyone about a very slick feature of the email Lists here at Matronics. You can now use Netscape or Internet Explorer to browse the current messages on your favorite List! The List Browse Function tracks the current 7 day's worth of List messages for any given List. Indexes are updated every 30 minutes with new messages that have been posted. You can resort the message indexes by Thread, Subject, Author, or Date and easily track and find current threads. A number of List members have written to say that they love the List Browser because they can keep tabs on the latest List messages throughout the day without having to constantly check their email or wait for the Digest issue to come out. You can check out the List Browse Feature by going to the following URL and clicking on the List of your choice: http://www.matronics.com/listbrowse Enjoy! Matt Dralle Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jun 14, 2002
I wondered about that also. There are to many other variables that influence CHT. EGT is the standard for setting mixture. While EGT numbers can very depending on outside conditions they are still the most reliable indicator of engine power performance. I am not sure why George said he does not trust it. George care to comment? Jerry S SportAV8R(at)aol.com wrote: > > > I am interested in the concept George introduces here; anyone care to weigh > in on this idea, that CHT is more useful for leaning than EGT? I know in my > RV (fully digitally instrumented for all 4 cylinders with EGT and CHT) that > CHT response time is far too slow to be convenient for leaning. I also feel > that CHT depends on too many other variables (distribution of cooling air > flow, ambient air temp and airspeed) to be of use here. If George is right, > however, we are spending perhaps far too much on needless EGT > instrumentation. > > > -Bill B > > gmcnutt(at)intergate.ca writes: > > > I am not a great believer in EGT's so I only have a good digital Cyl Head > > Temp gauge on my aircraft > ________________________________________________________________________________
Subject: Re: Riveting Nutplates to Fiberglass
Date: Jun 14, 2002
Use a squeezer and very soft rivets (sometimes called Tack rivets) or 3/32" aluminum pop rivets. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org Always looking for articles for the Experimenter ----- Original Message ----- From: "Steve J Hurlbut" <sjhdcl(at)kingston.net> Subject: RV-List: Riveting Nutplates to Fiberglass How do you rivet nutplates to fiberglass? I'm attaching the wing tip lens with #6 screws and nutplates but don't want to risk cracking the fiberglass with the rivet gun. Steve Hurlbut RV-7A O-360 A1A Fuselage http://members.kingston.net/sjhdcl/rv7a.htm ________________________________________________________________________________
From: "Stephen Johnson" <spjohnsn(at)ix.netcom.com>
Date: Jun 14, 2002
Tom, I think this is just the kind of information that should be in the archives, so I'm responding with the DNA edited out. Steve Johnson RV-8 Fuse ----- Original Message ----- From: "Tom Scherder" <tomscherder(at)hotmail.com> Subject: Re: RV-List: RV8 Canopy Skirt > > Chris, > When I fit the right side I was not pleased with the fit and thought about a > heat gun. I then fit the left side and it fit so well I decided to refit the > right. I worked from the back as per plan and made sure that the canopy > stayed perfectly still in place. If you don't make sure, sometimes the front > will try to lift if you have'nt yet installed the hold down bolts. The > second fit went great and now it's hard to get a peice of paper between the > skirt and the fuse when the canopy is locked closed. Good Luck. > Tom in Ky. > ----- Original Message ----- > From: "Chris Santschi" <rv8pilot(at)hotmail.com> > To: > Subject: RV-List: RV8 Canopy Skirt > > > > > > > > Fitted the canopy skirt yesterday,and a surprisingly good fit. Has > anybody > > tried to use heat from a heat gun, not a hair dryer ,to tweak the fit a > > little better. > > > > Chris S RV8 80881 > > Festus,MO > > > > > > http://www.hotmail.com > > > > > > ________________________________________________________________________________
Subject: Core beliefs
Date: Jun 14, 2002
"Remember, I am cheap AND broke..." Bill I can only admire you for sharing my own personal beliefs. Rob RV9A fuse N919RV resvd ________________________________________________________________________________
Date: Jun 14, 2002
Subject: Re: RV4-List: XDP4000X-List: unhappy
Keith; What is a XDP4000X? Wow, alot of Electrons flowing in that last message...Did you contact the manufacturer? Cheer up, as far as I know, XDP4000X doesn't have anything to do with the airplanes flight qualities... Rob Ray N557RR --- Keith Bedell wrote: > --> RV4-List message posted by: "Keith Bedell" > > > > All- > I hooked up my xdp-4000x and it sounds like > crap. I ordered the necessary cable from online and > tried to tune it, but it just got worse. Is there > something missing htat I need to do to get it to > work. When I bypass it with rca splitters the res of > my system works like a charm. I have the 6001ES > running three 10' ES subs. Then 2 1805 ES's handling > everything else. Aside from the problems with the > 4x, there is a huge disparity between cd volume and > radio volume. I mean huge!!!. I can max out > radio volume and it sounds ok, then pop in a cd and > half way blows mee out of the cab. Any ideas, I anm > just so dissapointed right now.... > > From: Matt Dralle > > Reply-To: xdp4000x-list(at)matronics.com > > To: Email-Lists(at)matronics.com > Subject: XDP4000X-List: List Browsing > Feature! > Date: Fri, 14 Jun 2002 00:52:33 -0700 > > > -- XDP4000X-List message posted > by: Matt Dralle > > > Dear Listers, > > I thought I'd post a little reminder > to everyone about a very slick feature > of the email Lists here at Matronics. > You can now use Netscape or Internet > Explorer to browse the current > messages on your favorite List! The List > Browse Function tracks the current 7 > day's worth of List messages for any > given List. Indexes are updated every > 30 minutes with new messages that > have been posted. You can resort the > message indexes by Thread, Subject, > Author, or Date and easily track and > find current threads. > > A number of List members have written > to say that they love the List > Browser because they can keep tabs on > the latest List messages throughout > the day without having to constantly > check their email or wait for the > Digest issue to come out. > > You can check out the List Browse > Feature by going to the following URL and > clicking on the List of your choice: > > http://www.matronics.com/listbrowse > > Enjoy! > > Matt Dralle > Email List Admin. > > > Matt G Dralle | Matronics | PO Box > 347 | Livermore | CA | 94551 > 925-606-1001 V | 925-606-6281 F | > dralle(at)matronics.com Email > http://www.matronics.com/ WWW | > Featuring Products For Aircraft > > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Jun 06, 2002
Subject: Re: Painting top of dashboard
Hal: In one of Bengelliss books, there is a clear drawing, and ideas on this Do not remember which book," Sport Plane Bulding,"' maybe Bert rv6a Do N0t Arcchive ________________________________________________________________________________
Date: Jun 14, 2002
Subject: Shielded wire how..
Hello: Have a question, how you do separate the, shield mesh, when connecting wire to the magnetos, and/or other places.. I have tried to unravel the strands, in order to make the pig tail... but with little success...Have tried and tried, but I know it must be a trick to do it right... Appreciate the suggestions on this.... Bert rv6a started wiring... ________________________________________________________________________________
From: "Wayne R. Couture" <commando@cox-internet.com>
Subject: Re: Shielded wire how..
Date: Jun 14, 2002
Try using a soft toothbrush type wire brush! Wayne Alexandria, LA ----- Original Message ----- From: <bertrv6(at)juno.com> Subject: RV-List: Shielded wire how.. > > Hello: > > Have a question, how you do separate the, shield mesh, when connecting > wire to the magnetos, and/or other places.. > > I have tried to unravel the strands, in order to make the pig tail... > but with little success...Have tried and tried, but I know it must be a > trick > to do it right... > > Appreciate the suggestions on this.... > > > Bert > > rv6a > started wiring... > > > > > > ________________________________________________________________________________
Date: Jun 14, 2002
Use a solder sleeve is the easiset thing to do. You trim about a 1/4" section of the insulation, slide a solder sleeve over it with a piece of wire inside, and run a heat gun over it. There you have a wire that is soldered to the shielding and is tough as nails. Works much better than the pigtail method. You can get solder sleeves from TerminalTown. Check this link out: http://www.terminaltown.com/Pages/Page73.html Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: <bertrv6(at)juno.com> Subject: RV-List: Shielded wire how.. > > Hello: > > Have a question, how you do separate the, shield mesh, when connecting > wire to the magnetos, and/or other places.. > > I have tried to unravel the strands, in order to make the pig tail... > but with little success...Have tried and tried, but I know it must be a > trick > to do it right... > > Appreciate the suggestions on this.... > > > Bert > > rv6a > started wiring... > > ________________________________________________________________________________
Date: Jun 14, 2002
Take a magic marker and mark the mesh where you want the inner wire to come out. Push back the mesh. Open a hole in the mesh at your mark with a pencil. Double back the inner wire and make the end come out the hole in the mesh. Pull the inner wire out. Pull mesh back out to close everything back to normal. Twist the mesh and crimp a connector on the end of the mesh. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org Always looking for articles for the Experimenter ----- Original Message ----- From: <bertrv6(at)juno.com> Subject: RV-List: Shielded wire how.. Hello: Have a question, how you do separate the, shield mesh, when connecting wire to the magnetos, and/or other places.. I have tried to unravel the strands, in order to make the pig tail... but with little success...Have tried and tried, but I know it must be a trick to do it right... Appreciate the suggestions on this.... Bert rv6a started wiring... ________________________________________________________________________________
Subject: Broken Mag Distributor Gear
Date: Jun 14, 2002
Just Broke my third mag distributor gear on a Bendix S4LN-20 Mag in 480 Hours. It happens on climbout. Just curious if anyone else out there with an O-360, Bendix mag on the right side, and Sensenich Metal prop have had any similar problems. I have re-shimmed the mag etc to remove all end play/bearing looseness. Drive Gears look good etc. I have heard that on some engine/prop combinations there is a flexible coupling used on the right mag to prevent gear oscillations. If anyone has more information on this or insight on such a problem please let me know. I Know, I Know; It is high time I had an electronic ignition on the right side anyway. Thanks Tom Olson RV6A ________________________________________________________________________________
Date: Jun 14, 2002
Steve when you put the D-N-A in your reply that again keeps it from the archive. :) so I edited it out of your reply. Jerry Springer Stephen Johnson wrote: > > > Tom, > > I think this is just the kind of information that should be in the archives, > so I'm responding with the --- edited out. > > Steve Johnson > RV-8 Fuse > ----- Original Message ----- > From: "Tom Scherder" <tomscherder(at)hotmail.com> > To: > Subject: Re: RV-List: RV8 Canopy Skirt > > > > > Chris, > > When I fit the right side I was not pleased with the fit and thought about > a > > heat gun. I then fit the left side and it fit so well I decided to refit > the > > right. I worked from the back as per plan and made sure that the canopy > > stayed perfectly still in place. If you don't make sure, sometimes the > front > > will try to lift if you have'nt yet installed the hold down bolts. The > > second fit went great and now it's hard to get a peice of paper between > the > > skirt and the fuse when the canopy is locked closed. Good Luck. > > Tom in Ky. > > > ----- Original Message ----- > > From: "Chris Santschi" <rv8pilot(at)hotmail.com> > > To: > > Subject: RV-List: RV8 Canopy Skirt > > > > > > > > > > > > > Fitted the canopy skirt yesterday,and a surprisingly good fit. Has > > anybody > > > tried to use heat from a heat gun, not a hair dryer ,to tweak the fit a > > > little better. > > > > > > Chris S RV8 80881 > > > Festus,MO > > > > > > > > > http://www.hotmail.com > > > > > > > > > > > ________________________________________________________________________________
Subject: DNA (was RV8 Canopy Skirt)
Date: Jun 14, 2002
I'm fairly certain you are wrong on that. Only the string "do not archive" works. Do a search in the archives for DNA. I got 174 hits. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of > Jerry Springer > Sent: Friday, June 14, 2002 8:51 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: RV8 Canopy Skirt > > > > Steve when you put the D-N-A in your reply that again keeps > it from the > archive. :) so I edited it out of your reply. > > Jerry Springer > > Stephen Johnson wrote: > > > > --> > > > > Tom, > > > > I think this is just the kind of information that should be in the > > archives, so I'm responding with the --- edited out. > > > > Steve Johnson > > RV-8 Fuse > > ----- Original Message ----- > > From: "Tom Scherder" <tomscherder(at)hotmail.com> > > To: > > Subject: Re: RV-List: RV8 Canopy Skirt > > > > > --> > > > > > > Chris, > > > When I fit the right side I was not pleased with the fit > and thought > > > about > > a > > > heat gun. I then fit the left side and it fit so well I > decided to > > > refit > > the > > > right. I worked from the back as per plan and made sure that the > > > canopy stayed perfectly still in place. If you don't make sure, > > > sometimes the > > front > > > will try to lift if you have'nt yet installed the hold > down bolts. > > > The second fit went great and now it's hard to get a > peice of paper > > > between > > the > > > skirt and the fuse when the canopy is locked closed. > Good Luck. Tom > > > in Ky. > > > > > ----- Original Message ----- > > > From: "Chris Santschi" <rv8pilot(at)hotmail.com> > > > To: > > > Subject: RV-List: RV8 Canopy Skirt > > > > > > > > > > --> > > > > > > > > > > > > Fitted the canopy skirt yesterday,and a surprisingly good fit. > > > > Has > > > anybody > > > > tried to use heat from a heat gun, not a hair dryer ,to > tweak the > > > > fit a little better. > > > > > > > > Chris S RV8 80881 > > > > Festus,MO ________________________________________________________________________________
Date: Jun 14, 2002
Sir If you do indeed have a alerigic reaction, by all means stop and get help to finish up your F-glass. The best thing you can do before working with the nasty stuff is: Cover your arms and ankles with baby powder. When your done take as cold a shower you can stand. If you take a hot one, the pores of your skin will open up and swallow the particles causing you more greif. >From: Earl Fortner <efortner(at)vnet.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Alergy reaction to fiberglass dust >Date: Fri, 14 Jun 2002 09:57:18 -0400 > > >Does that mean you can't even fly in a plastic airplane? >Earl, RV4 > >Lenleg(at)aol.com wrote: > > > > > I became alergic to the epoxy resin while building one of the other kind >of > > planes and could not finish it ... my hands would break out and itch >very > > badly just from the smell of the epoxy. > > > > Doctors told me the cure was to stay away from it !! > > > > Len Leggette, RV-8A > > Greensboro, N.C. N910LL (res) > > Hooking up systems > > > > ________________________________________________________________________________
Date: Jun 14, 2002
Subject: Re: Broken Mag Distributor Gear
There is a Lycoming Service Instruction, # 1436, which deals with just this problem on 0-360-A3A series engines. I can fax you the actual Service Instruction if you wish, just contact me off list. Garry "Casper" tcolson wrote: > > Just Broke my third mag distributor gear on a Bendix S4LN-20 Mag in 480 > Hours. It happens on climbout. > Snip ________________________________________________________________________________
Date: Jun 14, 2002
In a message dated 6/14/2002 4:06:58 PM Pacific Daylight Time, bertrv6(at)juno.com writes: > Have a question, how you do separate the, shield mesh, when connecting > wire to the magnetos, and/or other places.. > > I have tried to unravel the strands, in order to make the pig tail... > but with little success...Have tried and tried, but I know it must be a > trick > to do it right. I agree with Paul Besing that the solder sleeve way of shield termination is best, but it only works with good quality wire with an insulation that is high temp resistant. We'll assume that you already know this and are using shielded Tefzel wire. You can almost duplicate the results of the solder sleeve by using just solder and shrink sleeving. Cut the shielding back but don't tease it out so that you have about 1/4" of intact braided shielding laying over the insulated primary wire. Just flood solder over the shielding to stabilize it. Then lay a stripped wire adjacent to the shielding and lap solder it. Install shrink sleeving. A solder sleeve is essentially a solder ring with a shrink sleeve but has the additional benefit of a meltable sealing ring at both ends to render the final joint water proof. You need a good heat gun to fire off some of them, or use a lighter and just keep the sleeve in the flame, not above it. I have loads of these sleeves in all sizes and will give to you free if you stop by LVK. -GV (RV-6A N1GV 525hrs) ________________________________________________________________________________
Subject: Re: Hartzell C/S Prop AD IMPORTANT! not rv related
Date: Jun 14, 2002
> > I received an AD on my PA28R-180 for the Hartzell constant speed prop. I > have > been told by another pilot there is a free or half cost replacement > program for > the prop hub effected, but you must call Hartzell product support in > Pique, Ohio > to register before June 1, 02 to be included in this program. I called > product > support around 10 AM today and was told the AD applied only to the 540 > engine > and aerobatic engines. The AD I received from the FAA looks like it > applies to > my IO-360 even tho Hartzell says it does not. Does anyone know for sure? Earl and List: I would suggest that anyone interested in having this AD done go to the Hartzell site and read the Service Bulletin. It is somewhat difficult to understand particularly when it comes to which applications are effected. My interpretation after reading it and talking to Hartzell was that it applied to aerobatic operations and not a specific engine or aircraft. (There are some specific turbo prop aircraft models that are also effected.) At any rate I did take advantage of their offer. A complete overhaul was $1440 at a shop in GA. This includes the free hub, blade reconditioning and a new zero time log book. To install the overhauled prop, the spinner aft bulkhead will have to be relieved to clear the larger hub casting (fairly simple job) the front bulkhead will have to be replaced or have the spinner attach nut plates moved as re-assembly of the prop changes the clock position of the front bulkhead mounting relative to the aft bulkhead. I know we are not required to comply with ADs but I thought it was prudent and a good value especially for resale. Dick Sipp RV4 N250DS ________________________________________________________________________________
Subject: Fiberglass Dust Remedy
Date: Jun 14, 2002
Another thing you can do is get yourself a bottle of apple vinegar (not white vinegar) from the grocery store. Take a cold shower and use it like you would use soap on a washcloth. It dissolves the nasty stuff and rinses right away. Kind of stinks, so use regular soap afterwards. I was amazed at how it works. I used to get real itchy after working with FGlass, (not major allergic reactions, just unconfortable) and was told about this and it does wonders. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ________________________________________________________________________________
Date: Jun 15, 2002
Subject: Re: RV8-List Digest: 2 Msgs - 06/14/02
I would like to invite all RV builders, flyers and Enthusiasts to our November 15-17 Fly-In!! I am hosting this event in the name of FUN!! The host airport is Galveston, Texas at the Lonestar Flight Museum. Come join the fun and enter the show. Local EAA chapters will be making Young Eagle flights throughout the day. Phillips 66 fuel rebates and local fuel pricing will be in effect for all flyers. Saturday night we will host a banquet inside the Lonestar Flight Museum. Nothing better than dancing the night away with history surrounding us. For more information and a list of all the historic tour sites, please view our website. http://www.davidawilks.com/fly-in Hope to see you there!! David Wilks 832-282-4004 ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Jun 15, 2002
This topic is covered under aero-electric. Use the archives. ----- Original Message ----- From: <bertrv6(at)juno.com> Subject: RV-List: Shielded wire how.. > > Hello: > > Have a question, how you do separate the, shield mesh, when connecting > wire to the magnetos, and/or other places.. > > I have tried to unravel the strands, in order to make the pig tail... > but with little success...Have tried and tried, but I know it must be a > trick > to do it right... > > Appreciate the suggestions on this.... > > > Bert > > rv6a > started wiring... > > > > > > ________________________________________________________________________________
Date: Jun 15, 2002
Try using an old fashioned ice pick to do the unraveling of the shield. Bob Hassel RV9A Emp Plano, Tx > > From: "LarryRobertHelming" <lhelming(at)sigecom.net> > Date: 2002/06/15 Sat AM 08:21:22 CDT > To: > Subject: Re: RV-List: Shielded wire how.. > > > This topic is covered under aero-electric. Use the archives. > ----- Original Message ----- > From: <bertrv6(at)juno.com> > To: > Subject: RV-List: Shielded wire how.. > > > > > > Hello: > > > > Have a question, how you do separate the, shield mesh, when connecting > > wire to the magnetos, and/or other places.. > > > > I have tried to unravel the strands, in order to make the pig tail... > > but with little success...Have tried and tried, but I know it must be a > > trick > > to do it right... > > > > Appreciate the suggestions on this.... > > > > > > Bert > > > > rv6a > > started wiring... > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: Wiring Vans Hour Meter Preasure Switch
Date: Jun 15, 2002
List, I have a three post oil pressure switch from Vans that is supposed to activate a light and-or buzzer if oil pressure drops or you leave the master on. The problem is how to wire? The Three Posts on Vans Switch are marked as follows: 1)NO 2)NC 3) C ? I have wiring diagram but it calls for Three Posts marked as follows 1)P 2)S 3)I ? Can someone who has used Vans Switch tell me how to translate the Wiring Diagram to Vans Switch Post Identifiers? Better yet how did you wire Vans Hour Meter Pressure Switch? Wiring City, Tom in Ohio ________________________________________________________________________________
Date: Jun 15, 2002
Subject: Re: Wiring Vans Hour Meter Preasure Switch
hi tom the c=common, which is the wire coming from the master switch to send power to n/c ( normally closed ) or n/o ( normally open ). the n/o wire goes to the hobbs meter to engergize it when the oil pressure increases. the n/c wire goes to the oil light or buzzer which will go off when the oil pressure comes up. good luck scott tampa ________________________________________________________________________________
Date: Jun 15, 2002
Subject: Gasket source?
I need the gasket that fits between the prop governor drive and the accessory case for an O-320 E2A. I cannot find the gasket listed or shown in any of several Lycoming engine manuals. I have the gasket that fits between the governor and the drive. A local Lycoming shop says try a prop shop. The prop shop said try the engine shop. I'm out of ideas. Anybody have any success in rolling their own gaskets? I'm open to any suggestions. Charlie Brame RV-6A N11CB (Res.) San Antonio ________________________________________________________________________________
Date: Jun 15, 2002
Thanks Scott! Back to "Wire City"! Tom ----- Original Message ----- From: <ABAYMAN(at)aol.com> Subject: Re: RV-List: Wiring Vans Hour Meter Preasure Switch > > hi tom > the c=common, which is the wire coming from the master switch to send power > to n/c ( normally closed ) or n/o ( normally open ). the n/o wire goes to the > hobbs meter to engergize it when the oil pressure increases. the n/c wire > goes to the oil light or buzzer which will go off when the oil pressure comes > up. > good luck > scott > tampa > > ________________________________________________________________________________
Date: Jun 15, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
DavidAWilks(at)aol.com wrote: > > > I would like to invite all RV builders, flyers and Enthusiasts to our November 15-17 Fly-In!! I am hosting this event in the name of FUN!! The host airport is Galveston, Texas at the Lonestar Flight Museum. > > Come join the fun and enter the show. Local EAA chapters will be making Young Eagle flights throughout the day. Phillips 66 fuel rebates and local fuel pricing will be in effect for all flyers. > > Saturday night we will host a banquet inside the Lonestar Flight Museum. Nothing better than dancing the night away with history surrounding us. > > For more information and a list of all the historic tour sites, please view our website. > > http://www.davidawilks.com/fly-in > > Hope to see you there!! > > David Wilks > 832-282-4004 > David, It looks like fun, but a lot of the site is unreadable because various pictures & text overlay each other. (I'm using Netscape 4.7) Charlie ________________________________________________________________________________
Date: Jun 15, 2002
Plastics are generally classified as either thermoplastic or thermoset. Thermoset plastics are polyurethanes, epoxy resins and urea-formaldehyde compounds. Thermoplastics are PVC, polyethylene, polypropylene, polystyrene, Nylon (polyamide), Plexiglas and Teflon. The allergic reaction to uncured epoxy resin is a contact dermatitis that is similar to "Rhus" catechol dermatitis (poison ivy, poison oak, etc.). The resin very strongly binds with dermal skin proteins and has been shown in some instances to alkylate DNA, which is suggestive of being carcinogenic. Thus, once the resin has been in contact with bare skin for > 10-15 minutes, it cannot be removed by physical washing/scrubbing. (However, it is rumored that a product called "Tecnu" from Tec Laboratories, 1-800-ITCHING, developed for poison ivy, may also work for epoxy resin exposure up to several hours after contact (it doesn't appear to work for me)). Solvents that liquefy or thin resin (toluene, acetone, naphtha) can be absorbed thru the skin and then detoxified by the liver, and, in heavy/repeated doses, cause liver damage. Fiberglass dust exposure is simply a topical physical irritant (any cured epoxy resin in the dust is no longer able to react with skin proteins--tho, it's possible that some chemical could be in the mix that could cause a real allergic reaction) and can be removed by physical washing (scrubbing the area can also push the glass fragments deeper in the skin) or better, yet, by the application of wide tape to the affected skin and then peeled gently off (unless you're allergic to tape adhesive). If there are any masochists out there, you could also consider a "hot wax peel"--don't get burned. Washing with cold water appears to work better than hot water because it decreases the release of histamine from the irritated skin and histamine intensifies the itching sensation--it has nothing to do with glass fragments in your "pores". The initial allergic reaction to epoxy resin occurs 7-21 days after the sensitizing exposure (you have to be sensitized to a chemical before you can become allergic to it and the sensitizing exposure could be your first exposure or the tenth--no way to predict). Subsequent reactions occur within 12-48 hrs. The skin reaction physically resembles poison ivy (your skin has only so many ways to react). Usual treatment consists of oral (a Prednisone Dose-Pack) or intramuscular Depo-Medrol plus a strong topical steroid cream/ointment (since this is a nasty reaction, most people need both the internal and external cortisones to see any significant improvement). The earlier the treatment is started after the reaction is first noted or the exposure noted in a sensitized individual, the more effective it will be. Avoid skin contact with uncured epoxy resins. Use physical barriers (gloves, clothing, "invisible gloves", etc.--use your imagination). Do not breath the fumes in a closed in area (asthma, chronic cough, pulmonary edema). Use eye protection and a dust mask when working with fiberglass dust. Six weeks is way too long for a topical irritant dermatitis--something else has to be going on. Boyd RV-Super 6 Tom Barnes wrote: > > Can someone tell me if there is a cure to the rash caused by the dust > from my wheel pants. I'm absolutely sure this is the cause because it > only affected two to three inches above my shoes. A rash began within > two hours. After a few days, it began to itch. Now after six (6) weeks > it is itching more than ever. > The first application of Hydrocortisone relieved the itch for a > week. Now, it is only effective for a day. Sure would appreciate a > remedy. > Thanks in advance, > Tom Barnes -6 wrapping it up. ________________________________________________________________________________
Subject: Re: Gasket source?
Date: Jun 15, 2002
Order one from Pro Aero Engines Inc. their E.Mail proair(at)mail.ocos.net. Eustace Bowhay Blind Bay, B.C. ----- Original Message ----- From: "Charles Brame" <charleyb(at)earthlink.net> Subject: RV-List: Gasket source? > > I need the gasket that fits between the prop governor drive and the > accessory case for an O-320 E2A. I cannot find the gasket listed or > shown in any of several Lycoming engine manuals. I have the gasket that > fits between the governor and the drive. A local Lycoming shop says try > a prop shop. The prop shop said try the engine shop. I'm out of ideas. > > Anybody have any success in rolling their own gaskets? I'm open to any > suggestions. > > Charlie Brame > RV-6A N11CB (Res.) > San Antonio > > > > > > > ________________________________________________________________________________
Date: Jun 15, 2002
Internet Explorer 5.5 works. Jerry Calvert Edmond Ok -6 ----- Original Message ----- From: "Charlie and Tupper England" <cengland(at)netdoor.com> Subject: Re: RV-List: Re: RV8-List Digest: 2 Msgs - 06/14/02 > > DavidAWilks(at)aol.com wrote: > > > > > > I would like to invite all RV builders, flyers and Enthusiasts to our November 15-17 Fly-In!! I am hosting this event in the name of FUN!! The host airport is Galveston, Texas at the Lonestar Flight Museum. > > > > Come join the fun and enter the show. Local EAA chapters will be making Young Eagle flights throughout the day. Phillips 66 fuel rebates and local fuel pricing will be in effect for all flyers. > > > > Saturday night we will host a banquet inside the Lonestar Flight Museum. Nothing better than dancing the night away with history surrounding us. > > > > For more information and a list of all the historic tour sites, please view our website. > > > > http://www.davidawilks.com/fly-in > > > > Hope to see you there!! > > > > David Wilks > > 832-282-4004 > > > > David, > > It looks like fun, but a lot of the site is unreadable > because various pictures & text overlay each other. (I'm > using Netscape 4.7) > > Charlie > > ________________________________________________________________________________
Date: Jun 16, 2002
> ----- Original Message ----- > From: <bertrv6(at)juno.com> > To: > Subject: RV-List: Shielded wire how.. > > > > > > Hello: > > > > Have a question, how you do separate the, shield mesh, when connecting > > wire to the magnetos, and/or other places.. > > > > I have tried to unravel the strands, in order to make the pig tail... > > but with little success...Have tried and tried, but I know it must be a > > trick > > to do it right... > > > > Appreciate the suggestions on this.... > > > > > > Bert > > > > rv6a > > started wiring... > > > > > > Strip the insulation off the braid but leave the braid intact. Now solder out 3/8" from the inslation that is left behind. Very carefully take your very sharp dikes and score very lightly 1/4" out from the insulation. Now bend back and forth till it breaks. You can now throw away the unused shield. Take a short lenght of wire. (apx 3" long) Strip 1/4" piece of it and tin it with solder. Now solder this to the braid with the wire running away from the end with the center conductor. Slide a 5/8" piece of clear heat sleaving over the wire and solder connection. Fold the shield termination wire back over the heat sleaving to be next to the center conductor. Terminate the wires with a ring lug or what ever is needed. Hope this helps. This is sort of a "Homebrew" method to create one of those expensive RayChem Zap Splice connectors. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,088.8+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com ________________________________________________________________________________
Date: Jun 16, 2002
Subject: F610 &F611 angles
Hello on plan #34 it's not very clear on how to make the angles that attach to the longerons and bulkheads (F610 &F611) it looks like they have a slot in the ends similar to ones i have put in other angles seem like common practice to keep the angle from cracking but it's not real clear. thanks Bill Higgins RV 6 Pembroke ________________________________________________________________________________
Subject: K1000-4 center section attach nutplates
Date: Jun 16, 2002
I'm going to be getting to this point later today. On the wings, the 7 plans call for you to attach the K1000-4 center section attach nutplates to the forward side of the spar. Refer to DWG 11. I have found a section showing the platenuts, but no reference to the rivets. Anybody care to chime in and let me know what to use?? Pic below shows the position for these platenuts. http://rvflying.tripod.com/csnutplates.jpg BTW, it goes much faster working on two wings. After the first platenut flange learning curve, I was able to do the remaining three in just over an hour per flange. Dana Overall Richmond, KY 7 emp. wings on bench. http://rvflying.tripod.com ________________________________________________________________________________
Date: Jun 16, 2002
Subject: Re: RV-List Digest: 15 Msgs - 06/15/02
In a message dated Sun, 16 Jun 2002 2:58:43 AM Eastern Daylight Time, rv-list-digest(at)matronics.com writes: > > It looks like fun, but a lot of the site is unreadable > > because various pictures & text overlay each other. (I'm > > using Netscape 4.7) > > > > Charlie Charlie, I am trying to address the problem. I use Internet Explorer so I cannot see the differences by using another browser. I did note that the page will not print completely, so I am addressing those problems as well. I read this list everyday, so post your questions and I will do my best to answer them all. So far we have lots of donations for door prizes. One of them is a Garmin 295 and many other VERY nice items for giveaway. I am talking with many different avionics companies to coax them out of lots of great deals and parts. All these will be for the door prizes. I was told by one RV'er I should not have vendors there... what is everyone's thought on that? Would you like to see the items you are interested in, being displayed? Many enthusiasts may arrive although this is not a Public Offering. I have only advertised to aircraft owners and builders. Any and all suggestions welcome. Regards, David A. Wilks http://www.davidawilks.com/fly-in ________________________________________________________________________________
Subject: Re: F610 &F611 angles
Date: Jun 16, 2002
Hi Bill, I have a fairly descriptive text with pictures of how I did it on my website. Its at www.ericsrv6a.com. On the left, scroll down to the "Fuselage" section and then click on "Mounting Tail". The plans may have changed there depending on when you recieved your set. My plans are from the year 2000. On the George O. video, he shows notches in 3/4" x 3/4" angle. The plans I have, call for 1" x 1" angle and no notches. The angle is riveted to the bottom of the longerons and to the front of the bulkhead. The resulting gap is filled with a piece of 1/8" aluminum. Check out the pics on the website for a better idea of what I'm talking about. Hope this helps, Eric Newton - Long Beach, MS RV-6A - N57ME (Flying) www.ericsrv6a.com ----- Original Message ----- From: <WHigg1170(at)aol.com> Subject: RV-List: F610 &F611 angles > > Hello on plan #34 it's not very clear on how to make the angles that attach > to the longerons and bulkheads (F610 &F611) it looks like they have a slot in > the ends similar to ones i have put in other angles seem like common practice > to keep the angle from cracking but it's not real clear. thanks > > Bill Higgins > RV 6 > Pembroke > > ________________________________________________________________________________
Subject: Canopy cuttin'
Date: Jun 16, 2002
I'm making the initial cuts to my RV-8 canopy. I'm almost up to the lines on the canopy that represent the factory planes. Things are fitting well, but it's still about 3/8" from the rollover bar. Do I keep cutting past the lines or am I at the point where everyone else cut it in half "early"? Canopy cuttin' in Carolina, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Jun 16, 2002
From: "Michael J. Robbins" <michael.j.robbins(at)verizon.net>
Subject: First Flight - RV-8
This posting is a little late as I have been off the list changing my email address, but N88MJ, an RV-8QB first flew on Monday out of Paine Field, Everett, Washington after 4.5 years and 3600 hours of labor. It has a factory new O-360 and Hartzell CS prop with an AirFlow Performance fuel injection system. Full IFR with a Garmin 430, Garmin transponder and audio panel and ICOM second com, S-Tec 20 autopilot, all electric attitude indicator and Century HSI plus angle-of-attack. It was not without incidence. 30 seconds after takeoff what I thought was oil began spraying over the windshield. Got up to pattern altitude and decided I had to come down NOW. Landed (more of an arrival - bounced three times) with a 90 degree crosswind and little forward visibility. Turned out to be grease from the prop. Had a defective grease fitting where the ball didn't seat, so threw most of the hub grease out. A new fitting and some grease solved the problem, but maybe Hartzell should pay my laundry bill. Subsequent landings have been greasers (not on the windshield) now that I know how the 8 lands. Will post some photos on Randy Lervold's website (www.RV-8.com) in a week or so. Mike Robbins RV8Q 80591 N88MJ now flying ________________________________________________________________________________
Subject: RE: RV8-List: Canopy cuttin'
Date: Jun 16, 2002
Go slow with lots of trial fits using about 25 clamps. Took me about 20 iterations of fit (clamp all around), mark, trim, sand edges... before ready to drill. Greg -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Larry Bowen Subject: RV8-List: Canopy cuttin' --> RV8-List message posted by: "Larry Bowen" I'm making the initial cuts to my RV-8 canopy. I'm almost up to the lines on the canopy that represent the factory planes. Things are fitting well, but it's still about 3/8" from the rollover bar. Do I keep cutting past the lines or am I at the point where everyone else cut it in half "early"? Canopy cuttin' in Carolina, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Jun 16, 2002
Subject: Re: RV8-List: Canopy cuttin'
ABOVE ALL...MAKE SURE THE PLASTIC IS AS WARM AS YOU CAN GET IT..AND...GO SLOW, AND TRIAL FIT AFTER EVERY CUT.. good luck...and if you need another canopy I have an extra one.... "G. Miller" wrote: > --> RV8-List message posted by: "G. Miller" > > Go slow with lots of trial fits using about 25 clamps. Took me about 20 > iterations of fit (clamp all around), mark, trim, sand edges... before ready > to drill. > > Greg > > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Larry Bowen > To: rv8list(at)yahoogroups.com; rv8-list(at)matronics.com > Subject: RV8-List: Canopy cuttin' > > --> RV8-List message posted by: "Larry Bowen" > > I'm making the initial cuts to my RV-8 canopy. I'm almost up to the > lines on the canopy that represent the factory planes. Things are > fitting well, but it's still about 3/8" from the rollover bar. Do I > keep cutting past the lines or am I at the point where everyone else cut > it in half "early"? > > Canopy cuttin' in Carolina, > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > ________________________________________________________________________________
Date: Jun 16, 2002
Larry, I've just passed that point, am now adding 'glass fairing between windscreen & fwd fuselage. My experience was that within 1/4" of the factory lines, AND with notches cut in the canopy to avoid the frame's ribs, I was able to get a good fit all around, including having it lay on top of the rollover bar....just had to adjust front/back position and mostly adjust the 'windscreen's' match to the top fwd fuselage. Laying on the bar gave me solid support while making the parting-cut.....which, shaking hands notwithstanding, went must fine with the kit's cutting wheel. Spend lots of time getting things lined up and each step clear in your mind....there's only one attempt! Best, David >--> RV8-List message posted by: "Larry Bowen" > >I'm making the initial cuts to my RV-8 canopy. I'm almost up to the >lines on the canopy that represent the factory planes. Things are >fitting well, but it's still about 3/8" from the rollover bar. Do I >keep cutting past the lines or am I at the point where everyone else cut >it in half "early"? > David Grebe RV-8 #80354...North Wales, PA Starting Finishing Kit ________________________________________________________________________________
Date: Jun 16, 2002
Subject: Navaid servo in the cockpit of an -8A
Hello- Anybody out there mount the Navaid servo in the cockpit of an -8A? Seems to me that someone with -8 did it.... Pictures or discussion would be appreciated. Thanks Dag ==== ***************** Dag Adamson 617 513 1182 Natick, MA RV-8A Fuselage ***************** ________________________________________________________________________________
Date: Jun 16, 2002
Thanks for all of the advice. I am doing all of it. But the quesiton was, when is the bubble cut in half? Many folks say they did it earlier than the plans say. My question for those folks is: When was that? Also, how much is typically cut off the sides? I haven't done any yet. The sides are just now getting to where they touch the frame. Thanks, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of jollyd > Sent: Sunday, June 16, 2002 12:24 PM > To: rv8-list(at)matronics.com > Subject: RV-List: Re: RV8-List: Canopy cuttin' > > > > ABOVE ALL...MAKE SURE THE PLASTIC IS AS WARM AS YOU CAN GET > IT..AND...GO SLOW, AND TRIAL FIT AFTER EVERY CUT.. good > luck...and if you need another canopy I have an extra one.... > > "G. Miller" wrote: > > > --> RV8-List message posted by: "G. Miller" > > > > Go slow with lots of trial fits using about 25 clamps. Took > me about > > 20 iterations of fit (clamp all around), mark, trim, sand edges... > > before ready to drill. > > > > Greg > > > > -----Original Message----- > > From: owner-rv8-list-server(at)matronics.com > > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Larry Bowen > > To: rv8list(at)yahoogroups.com; rv8-list(at)matronics.com > > Subject: RV8-List: Canopy cuttin' > > > > --> RV8-List message posted by: "Larry Bowen" > > > > I'm making the initial cuts to my RV-8 canopy. I'm almost > up to the > > lines on the canopy that represent the factory planes. Things are > > fitting well, but it's still about 3/8" from the rollover > bar. Do I > > keep cutting past the lines or am I at the point where > everyone else > > cut it in half "early"? > > > > Canopy cuttin' in Carolina, > > > > - > > Larry Bowen > > Larry(at)BowenAero.com > > http://BowenAero.com > > > ________________________________________________________________________________
Date: Jun 16, 2002
Well, having just cracked mine last week... As you trim, allow the edge of the rear half of the plexi to overlap the canopy frame. You may have to cut it in half to do this. It really doesn't matter if it is long here, since it will be covered by the skirt, and on the inside by finishing material. I left mine too short here, and the edge distance was too short. It survived the drilling, but when I pulled the "keeper" rivets in, every hole cracked. I had no problem with the other holes, where I had at least 1/2" from the hole to the edge of the plexi, but having only 1/4" is the recipe for a crack. The plans call for 5/16" from the edge to the center of the holes, I think this is too little. If this is not clear, I could send you a picture. John, RV8qb, Pagosa Springs, CO -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Larry Bowen Subject: RV-List: Canopy cuttin' I'm making the initial cuts to my RV-8 canopy. I'm almost up to the lines on the canopy that represent the factory planes. Things are fitting well, but it's still about 3/8" from the rollover bar. Do I keep cutting past the lines or am I at the point where everyone else cut it in half "early"? Canopy cuttin' in Carolina, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Jun 16, 2002
Thanks for the advice. I've made another cut to the 'factory lines'. I'll try another fit as soon as I can get wifey to help hoist it up there. Again! It fits well in the back, and the 3.25" between the windshield and the bag door is good, so I guess I'll keep taking little bits off until it touches the roll bar. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of > David L. Grebe > Sent: Sunday, June 16, 2002 1:00 PM > To: rv8-list(at)matronics.com > Subject: Re: RV8-List: Canopy cuttin' > > > --> RV8-List message posted by: "David L. Grebe" > > Larry, I've just passed that point, am now adding 'glass > fairing between windscreen & fwd fuselage. My experience was > that within 1/4" of the factory lines, AND with notches cut > in the canopy to avoid the frame's ribs, I was able to get a > good fit all around, including having it lay on top of the
June 07, 2002 - June 16, 2002
RV-Archive.digest.vol-my
