RV-Archive.digest.vol-nb
June 30, 2002 - July 09, 2002
      RV-6A Sold (Waiting on the RV-10)
      Kitlog Pro Builder's Log Software
      http://www.kitlog.com
      ----- Original Message -----
Subject: Nut Plates Galore
> > After putting is a gazillion (yes, it seems like a gazillion) nut plates > on the floor on my RV-8, I found that a couple don't work. I tried > several screws, so I'm assuming it's the nutplate. Can I use a tap to > re-thread the nutplate, or do I have to (ack) drill them out and replace > them? Thanks for the help. > > Steve Gregory > RV-8 > Livermore, CA > > ________________________________________________________________________________
Subject: transition training
Date: Jun 30, 2002
Does anyone out there know someone in the Louisville, KY or Southern Indiana area who might provide transition training in an RV-8? I will be current in a taildragger, but need to do 20 or so landings for insurance before climbing into my airplane. Thanks, Parker Thomas Rv-8 canopy almost done, attaching cowling tomorrow! ________________________________________________________________________________
Subject: Re: Com antenna in the wing tip?
Date: Jun 30, 2002
Jeff, The comm antennas work best if they are vertically mounted, and the VOR horizontally. Dick White RV-8 N94DW Newport,OR ----- Original Message ----- From: "Jeff Bertsch" <noms1reqd(at)yahoo.com> Subject: RV-List: Com antenna in the wing tip? > > We are having problems with communication from our > RV-4. We can hear, but they can't hear us. Our radios > work OK for ground and tower, but not for approach and > center. > > The com antennas are dipole copper strips from > Advanced Electronics and they are mounted in the left > wing tip. http://www.advancedaircraft.com/ > > We checked the power output and SWR at the antenna, > and the power ranges from 2.5 to 3.9 at the antenna, > and the SWR ranges from 1.4 to 2.2, with most readings > around 1.8. I talked to the helpful folks at Advanced > Electronics, and they said their antennas need to be > mounted vertically (or at least have a > significantvertical component) to work for com, and > ours are not. > > So before I go ahead and mount a whip or blade antenna > on the belly, have any of you gurus successfully" > mounted a com antenna in the fiberglass wing tip of > you RV? If so, what kind and what do you consider to > be successfull com? Anyone have any success with the > Archer 1A antenna mounted in a wing tip? Any > installation tips? > Thanks in advance > > Jeff Bertsch > noms1reqd(at)yahoo.com > > ________________________________________________________________________________
Date: Jun 30, 2002
Just having gone through this, I want to point out, 2 of my nut plates were not ever threaded at the factory. Luckily I found these before mounting them. Marty in Brentwood TN -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Paul Besing Subject: Re: RV-List: Nut Plates Galore I tapped all nutplates when I installed them. Also, the brass #8 screws that Van's provide are not that strong. You might find that a steel screw will screw into some of the ones that the brass one's won't. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Steve Gregory" <sgregory(at)best.com> Subject: RV-List: Nut Plates Galore > > After putting is a gazillion (yes, it seems like a gazillion) nut > plates on the floor on my RV-8, I found that a couple don't work. I > tried several screws, so I'm assuming it's the nutplate. Can I use a > tap to re-thread the nutplate, or do I have to (ack) drill them out > and replace them? Thanks for the help. > > Steve Gregory > RV-8 > Livermore, CA > > ________________________________________________________________________________
Date: Jun 30, 2002
Subject: Re: 6a lower cowl corner fit?
I just fitted my cowling for a 6a this weekend also. And, like Jim's plane I too will have to add glass to close up those 2 scoops on each corner. I noticed that I have to pull the sides away from the hinge pins in order to drop the lower cowl down. Will glassing the corners restrict the flexablility that I need to pull the sides out and away from the hinge? Dan --- Paul Besing wrote: > > > I had the same problem. See > http://www.lacodeworks.com/besing/cowlp.htm to > see how I fixed mine. > > Paul Besing > RV-6A Sold (Waiting on the RV-10) > http://www.lacodeworks.com/besing > Kitlog Pro Builder's Log Software > http://www.kitlog.com > > ----- Original Message ----- > From: "Jim Jewell" <jjewell(at)telus.net> > To: > Subject: RV-List: Re: 6a lower cowl corner fit? > > > > > > > Hello Listers, > > > > I'm in search of key word and phrase suggestions > for searching the RV-list > > archives. Any how to's would help also. > > > > Kit type: > > RV6a O-360-A1A with C/S > > > > Problem: > > The bottom corners of the lower cowl do not match > the contour of the > > fuselage skins. The radius of the fuselage lower > corners is smaller and > > protrudes out from the larger radius of the cowl > itself. the result is two > > very nice intake scoops that are not in the > design. It's obvious to me > that > > some fiberglass and epoxy work to make the cowl > conform to the fuselage is > > called for. > > > > I don't remember any emails that refer to this > cowl fit anomaly; Although > I > > can still hide my own easter eggs and retrieve > them with some measure of > > success, it's all the not so long lost stuff I > find during the egg hiding > > that has me somewhat concerned. }:-)! > > > > I digress, As a plastic materials novice I can > think of several approaches > > to this fiberglass layup task but just wondered if > and how others solved > the > > puzzle. I can't quite picture a step by step > procedure that will get the > job > > done with a minimum of hassle. > > > > Jim in Kelowna > > > > > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ________________________________________________________________________________
Date: Jun 30, 2002
I didn't notice anything there. There is still a long arm that you can flex to get the hinge eyes to pop out of the side as you mentioned. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Dan DeNeal" <rv6apilot(at)yahoo.com> Subject: Re: RV-List: 6a lower cowl corner fit? > > I just fitted my cowling for a 6a this weekend also. > And, like Jim's plane I too will have to add glass to > close up those 2 scoops on each corner. I noticed that > I have to pull the sides away from the hinge pins in > order to drop the lower cowl down. Will glassing the > corners restrict the flexablility that I need to pull > the sides out and away from the hinge? > Dan > > > --- Paul Besing wrote: > > > > > > I had the same problem. See > > http://www.lacodeworks.com/besing/cowlp.htm to > > see how I fixed mine. > > > > Paul Besing > > RV-6A Sold (Waiting on the RV-10) > > http://www.lacodeworks.com/besing > > Kitlog Pro Builder's Log Software > > http://www.kitlog.com > > > > ----- Original Message ----- > > From: "Jim Jewell" <jjewell(at)telus.net> > > To: > > Subject: RV-List: Re: 6a lower cowl corner fit? > > > > > > > > > > > > Hello Listers, > > > > > > I'm in search of key word and phrase suggestions > > for searching the RV-list > > > archives. Any how to's would help also. > > > > > > Kit type: > > > RV6a O-360-A1A with C/S > > > > > > Problem: > > > The bottom corners of the lower cowl do not match > > the contour of the > > > fuselage skins. The radius of the fuselage lower > > corners is smaller and > > > protrudes out from the larger radius of the cowl > > itself. the result is two > > > very nice intake scoops that are not in the > > design. It's obvious to me > > that > > > some fiberglass and epoxy work to make the cowl > > conform to the fuselage is > > > called for. > > > > > > I don't remember any emails that refer to this > > cowl fit anomaly; Although > > I > > > can still hide my own easter eggs and retrieve > > them with some measure of > > > success, it's all the not so long lost stuff I > > find during the egg hiding > > > that has me somewhat concerned. }:-)! > > > > > > I digress, As a plastic materials novice I can > > think of several approaches > > > to this fiberglass layup task but just wondered if > > and how others solved > > the > > > puzzle. I can't quite picture a step by step > > procedure that will get the > > job > > > done with a minimum of hassle. > > > > > > Jim in Kelowna > > > > > > > > > > > > > > Contributions of > > any other form > > > > latest messages. > > other List members. > > > > http://www.matronics.com/subscription > > http://www.matronics.com/photoshare > > http://www.matronics.com/search > > http://www.matronics.com/archives > > http://www.matronics.com/emaillists > > > > > > > > > > > > ________________________________________________________________________________
Subject: Superior SL-360 buildup pics
Date: Jul 01, 2002
Listers, I was perusing the Trade A Plane ads and saw a post for an RV-6A with a website URL. The site has a very nice set of pics of the Superior SL-360 engine buildup. I've never seen this engine from this perspective. Looks like a mighty nice way to go to get a "Lycoming" that...isn't! Go to: http://www.attawayair.com/new_page_3.htm Brian Denk RV8 N94BD 293 hrs. http://www.hotmail.com ________________________________________________________________________________
Date: Jun 30, 2002
Hi Jeff and All, I have a Sportcraft COM antenna in the wingtip of my RV-3. It really shouldn't work very well, because it doesn't have very much vertical height. And the vertical height is the key to making the COM work well. (This also applies to belly mounted BENT antenna's) :-) I was 38 NM away from my home airport, and had it in sight. However, I couldn't receive ATIS - UNTIL I rolled the antenna tip up by 60 degrees. ATIS came in loud and clear. But it's not the most comfortable way to fly. :-) On another flight, I was about 10 NM from my home airport. I had the airport off my left wing (the COM antenna is in my right wingtip) and I dropped down below a ridge line (2,000' agl) so the airport was out of sight. The tower responded to my first transmission. I didn't expect them to hear my first transmission; let alone my receiving their response loud and clear. Who can figure? Jim Ayers ________________________________________________________________________________
Subject: Re: Cylinder Cooling
Date: Jun 30, 2002
----- Original Message ----- From: "Gary Graham" <beeb(at)teleport.com> Subject: RV-List: Cilinder Cooling > > These have proven to help. > > Air dams on front cylinders (#1 the biggest. #2 smaller) > > Upper cowl air smoothers (fiberglass-in the kit with a little help from the > builder) > > Baffle outlets (Test data indicates that a good starting point is 7/8" - 1" > at the barrels and > 2"- 2 1/4" at the cylinders. Slip heat resistant test plates under the > baffles to close down opening before remanufacture. The baffle kits I have > seen were not engineered in the outlet gap. > > "A" model planes may require cowl outlet enhancement such as larger outlet > and/or a "low pressure lip for overall temp reduction. > > Exit air smoother augmenter on the firewall bottom edge like the RV-8. > > What did I leave out? > > Gary > > ________________________________________________________________________________
Subject: Re: Positech oil cooler
Date: Jul 01, 2002
Hi Jim, The description you give sounds adequate. Cutting the half circle out of the aft mount flange for engine mount clearance is something I have seen others do. It sounds like the middle inner(nearest the mount) long bolt is the one you have replaced with the short bolt. This would be the preferred one if there was a choice. In my case I mounted my cooler (a Van's supplied SW Niagara copy) on a one inch outboard offset standoff. I mounted it just high enough on the rear #3 baffle to need a half circle trimmed out of the inboard flangewithout interfering with the center bolt. The offset allows the full face of the oil cooler to see cool air without picking up any heated air off of the cooling fins of #3 cylinder. I guess I will see if my theory is good in the coming year, I hope! Jim in Kelowna - 5 years and counting From: "Jim Oke" <wjoke(at)shaw.ca> > Hi Albert; > > I am building a -6A and expect the -6A and -9A engine mounts are close to > identical. The problem is that there is little room for any make of oil > cooler on the aft left baffle because of interference with the engine mount. > > I have a Positech and my solution was to cut and grind a half circle out of > one of the Positech's aft mounting flanges to fit around the offending > engine mount tube. This corresponds to one of the mounting bolt holes in the > oil cooler so I will end up with five long AN3 bolts and one short AN3 bolt > holding the cooler to the baffle. This is obviously not a Positech approved > mod but the unit looks rugged enough to do OK with this treatment. > > Jim Oke > Winnipeg, MB > RV-6A ________________________________________________________________________________
Subject: RV 7 tilt-up versus slide canopy
Date: Jul 01, 2002
I am at great pains at deciding which to use. Any bad experiences involving either one? Regards Cliff Lotter South Africa tel/fax 27-18-4621724 ________________________________________________________________________________
Subject: Re: RV 7 tilt-up versus slide canopy
Date: Jul 01, 2002
Hi Cliff, There is a real well written, non-biased article about the tip-up vs. slider by Martin Sutter. IT is located here: http://www.metronet.com/~dreeves/articles/tipupvsslider.htm Regards, Eric Newton - Long Beach, MS RV-6A - N57ME (Slider) www.ericsrv6a.com ----- Original Message ----- From: "cliff" <exodus(at)gds.co.za> Subject: RV-List: RV 7 tilt-up versus slide canopy > > I am at great pains at deciding which to use. Any bad experiences > involving either one? > Regards > Cliff Lotter > South Africa > tel/fax 27-18-4621724 > > ________________________________________________________________________________
rv-list(at)matronics.com
Subject: Web Site Update...
Date: Jul 01, 2002
Hi all... I posted some new stuff to my web site this morning... I installed my old Magellan GPS 315 in the back seat, installed a rear view mirror, and installed a chart board in the cockpit... http://vondane.com/rv8a/finish/finish11.htm -Bill VonDane RV-8A ~ N8WV ~ 34hrs ________________________________________________________________________________
Date: Jul 01, 2002
Subject: Aileron alignment QB wings
Anyone experienced a problem with the vertical alignment of the aileron? Mine seem to be 1/8 to 3/16 high checking with the airfoil template. Also the W-818 push rod is about 27 13/16 rather than 27 5/8. Van, s informs me that undrilled aileron hinges are available. Seems like perhaps it is a typical problem. Any comments will be appreciated. Dale Walker-RV7 ________________________________________________________________________________
Subject: Re: RV8 Rear spar bolt hole - major problem
Date: Jul 01, 2002
Late reply, but I felt compelled to throw my support behind Keith's comments. Do whatever you have to do to make it as Van designed it. Period. Bryan Jones, PE -8 ~420 hrs Pearland, Texas >From: "Keith Hughes" <rv6tc(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: RV8 Rear spar bolt hole - major problem >Date: Tue, 25 Jun 2002 09:32:02 -0600 > http://www.hotmail.com ________________________________________________________________________________
Subject: Several Topics
Date: Jul 01, 2002
Folks, been at the apt the last few days so have been off list. First, Con-grin-ulations Scott. Second, report on the EZtrim. I installed it with the ray allen servos and it seems to work for the first few oscillations then heads downwards slowly. BUT, I haven't had the time or flexiblitiy to get under the panel and hook the pressure line into the static source so I stopped testing/adjusting until this is done. I'm just starting its first annual so more later. Third, this is a weird one. I have been occasionally getting a small amount of air in the brake line for the right brake system between the passenger MC and the Pilot MC. I bleed it out and after a while it reappears. And there are no leaks in the system. So I decided it might have something to do with being upside down as I have been practicing aileron rolls lately. I went up and did a bunch to the right, no bubble, then did a bunch to the left and presto bubbles appeared between the master cylinders on the right brake system only??? Any thoughts??? thx Wheeler ________________________________________________________________________________
Date: Jul 01, 2002
Subject: Com antenna in the wing tip COMM problems
I think your SWR is a little hi. The reflected energy is bouncing "to & fro" within the confines of the feeder cable/coax to the antenna and disapating its energy via heat-not transmitted RF energy. Don't worry about the heat thing, there is no danger or harm of a fire or anything. A SWr of 1-1 is mathmetacally perfect but non atainable . I've tuned transmitters with a 1.1 to 1 or 1.2 to 1 that worked fine. I think 1.8 to 1 is a little hi. ALso agree with a poster on the noise issue. The RV-4 can be noisy. His suggestion will help you out. The SWR issue is limiting your effective distance. You could have a combo problem here also (cabin noise AND hi SWR). Also what is the line voltage to the transmitter ? Low voltage can reduce your effective distance also. ________________________________________________________________________________
Date: Jul 01, 2002
Subject: Re: RV-List Digest: 29 Msgs - 06/30/02
Sometimes ATC has remote antennas to handle local geography geometeries like you mentioned. With more then one antenna, reception and communications can differ if your thinking the only antenna is on the roof of the tower facility. Out west, ATC has remote comm antennas on multiple VOR stations to help in the VHF reception...... .............................. From: LeastDrag93066(at)aol.com Subject: Re: RV-List: Com antenna in the wing tip? Hi Jeff and All, I have a Sportcraft COM antenna in the wingtip of my RV-3. It really shouldn't work very well, because it doesn't have very much vertical height. And the vertical height is the key to making the COM work well. (This also applies to belly mounted BENT antenna's) :-) I was 38 NM away from my home airport, and had it in sight. However, I couldn't receive ATIS - UNTIL I rolled the antenna tip up by 60 degrees. ATIS came in loud and clear. But it's not the most comfortable way to fly. :-) On another flight, I was about 10 NM from my home airport. I had the airport off my left wing (the COM antenna is in my right wingtip) and I dropped down below a ridge line (2,000' agl) so the airport was out of sight. The tower responded to my first transmission. I didn't expect them to hear my first transmission; let alone my receiving their response loud and clear. Who can figure? Jim Ayers ________________________________________________________________________________
Date: Jul 01, 2002
Subject: Things that go BANG in the flight
"rocket-list(at)matronics.com" All-- Our RVs have several little tricks that can make things interesting, from time to time. The other day I was flying over my practice area (Florida cattle pasture/swamp, depending on the time of the year) and was just starting to point the nose down from the top of a loop and pick up speed when there was a loud bang that reverberated thru ought the cockpit, followed by several others in rapid succession. The sound was very hard to localize, but it was from my plane and it appeared the airframe had decided to start coming apart. I rolled 180 deg. and turned the loop into a sort-of-Cuban-8 and pulled power back and kept the nose up for altitude (3,000' agl). I knew there was a nice access road below me since I used it as a guide for setting my N-S/E-W lines, but I was starting to think about parachute time. However, other than the damned banging the plane seemed to be handling fine--motor sounded good--gauges looked good, no unusual vibration, all control surfaces responded and easy to maintain altitude and heading. So, I slowed to 85 KIAS(close to best glide speed and, also, max L/D so there was less stress on the airframe) and preceded back to KVNC uneventfully except for that banging. All the time keeping an "out" in sight in case the "problem" got worse. However, an old story came back to me and I started laughing on the way back about what my problem might be. After 4 yrs of Florida weather, the contact cement holding the black rubber trim strip between the wing root fairing and the fuselage had dried and become brittle and a 2 1/2 ft. section of the trim strip on top of the left wing had become loose and was flapping against the fuselage and the top of the wing. But, man, was that a scary sound! Initially, I was sure that my airplane was coming apart! At least it wasn't from seatbelts hanging outside the door. Boyd RV-Super 6/>400 hrs ________________________________________________________________________________
Date: Jul 01, 2002
> I am at great pains at deciding which to use. Any bad experiences > involving either one? The tip up gives the impression of "sitting on top of the world" when flying. No bars to obstruct ones view out the bubble. When I see photos taken in close formation, I notice the slider guys are most often leaning or bending their heads funny to see around the roll bar. Those are the same pilots that are very comphy and cool when they taxi around on hot days. Something about more elbow room..... Norman Hunger RV6A Tip Up Scotch Creek BC Way to go Scott! ________________________________________________________________________________
Date: Jul 01, 2002
You might double check the couple that don't work and make sure they are the right size nut plates. Nut plates for #8 screws are close to the same size nutplate for an AN-3-x bolt and the difference doesn't just jump out at you. I managed to install two #8 screw nutplates along with the nutplates for several AN-3 bolts in my FAB. I tried tapping them out, but finally gave up and drilled out the #8 plates and put in the right sized ones. Charlie RV-6A, N11CB (Res.) San Antonio ---------------------------------- From: Steve Gregory <sgregory(at)best.com> Subject: RV-List: Nut Plates Galore After putting is a gazillion (yes, it seems like a gazillion) nut plates on the floor on my RV-8, I found that a couple don't work. I tried several screws, so I'm assuming it's the nutplate. Can I use a tap to re-thread the nutplate, or do I have to (ack) drill them out and replace them? Thanks for the help. Steve Gregory RV-8 Livermore, CA ________________________________________________________________________________
Subject: Garmin 295
Date: Jul 01, 2002
Has anyone split a Garmin 295 GPS at the seam and mounted it semi-permanently in the panel? Any problems with the viewing angle or otherwise? Pictures? General advice? Thanks, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Subject: Re: Garmin 295
Date: Jul 01, 2002
I split a Garmin Pilot III and also angled it... http://www.rv-8.com/Pictures/Mvc-525x.jpg I have since replaced that unit with a 295 and this time did not split it, but did angle it... http://www.rv-8.com/Pictures/Dscn0346x.jpg Both installations worked very well. Randy Lervold RV-8, 190 hrs. Home Wing VAF ----- Original Message ----- From: "Larry Bowen" <Larry(at)bowenaero.com> Subject: RV-List: Garmin 295 > > Has anyone split a Garmin 295 GPS at the seam and mounted it > semi-permanently in the panel? Any problems with the viewing angle or > otherwise? Pictures? General advice? > > Thanks, > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > ________________________________________________________________________________
Subject: Prop Guard
Date: Jul 01, 2002
Van's news letter, the RVator, has a short blurb regarding how well PropGuard worked for the writer...there is precious little in the archives, and I wondered if anyone "out there" has tried this product. ________________________________________________________________________________
Date: Jul 01, 2002
Subject: sealing rivet holes in canopy
As I put in the rivets and screws through the canopy and into the frame, should/can I put a sealant in the holes to prevent water from dripping in? WHat is safe to use that won't damage the canopy? Thanks, Kim Nicholas RV9A finish kit - the end in sight??? ________________________________________________________________________________
Date: Jul 01, 2002
Subject: Re: sealing rivet holes in canopy
Kim I use Pro Seal ...It is also used in the Pitts for the same purpose!!! John McMahon Wiring Knicholas2(at)aol.com wrote: > >As I put in the rivets and screws through the canopy and into the frame, >should/can I put a sealant in the holes to prevent water from dripping in? >WHat is safe to use that won't damage the canopy? > >Thanks, > >Kim Nicholas >RV9A finish kit - the end in sight??? > > ________________________________________________________________________________
Subject: First Flight N44PH (long)
Date: Jul 02, 2002
Wow, what a rush, for the second time a first flight in an RV that I built myself, just an incredible experience I don't care how often you do it. For me it is bigger than my T-38 solo ride some 36 years ago, even this second time. Took off from Rwy 11R at Vero Beach a little after 7 p.m. this evening--it finally stopped raining here for the first time in about 2 weeks, but it was a great evening with high clouds and no wind. Thanks to Ernie Raudenbush for flying chase in his gorgeous Lancair ES. I was looking at CHT's around 400 degrees with the high being cylinder #3 that got up to about 445. Highest oil temp was about 195 F in the climb and settled back to 183 at 75% power at 7,500 feet. I got the humongous Stewart Warner 8432R oil cooler so I was kind of relieved that I got the desired effect after going through all the effort to mount this monster behind cylinder #4 on the rear baffle. Thanks to Randall Henderson for some good ideas on how to support this area, however I felt I needed to beef it up even more than Randall did. This is the oil cooler used on the IO-540's. Thanks to Eustace Bowhay and Bart LaLonde for a great engine! CHT's in cruise ranged from about 300 to 348 with #3 cylinder again being the highest. I checked ground speed on reciprocal headings: 188 mph and 207 mph, this was at 75% power at 7,500 feet. I wanted to get a leg up on the break-in process so kept it at 75% power for most of the flight. I think we were up about 45 minutes total. Autopilot worked great (S-Tec 30), I highly recommend it. Too many toys to play with on the first flight, but most everything seemed to work just fine. Airplane is set up IFR with the UPS stack including the MX-20 and GX-60 GPS, SL30 Nav/Com and SL-70 transponder. By the way, I have Jeff Rose's dual electronic ignition which worked perfectly--dual batteries a la Bob Nuckolls, I could go on all night but I better cut this short. Started a long power-on descent ending up over the airport about 4,000 feet and just did a wide 360 on to final and kept it up good and high, put the flaps down to 20 on final and made a normal 3-point landing. Things that need to be fixed: left wing a little heavy, idle set a little too low (engine almost quit on roll out). Thanks to all the folks on this list for the past 3 years that kept this interesting, especially Eric Henson for the humor, Gary VanRemortel for the Yeller Pages, Matt for the List, Piedmont Builders Group, and all the others for their valuable input. Oh yeah, don't want to forget Austin's great stories and a special thanks to Jerry Springer for staying with the list even though he built his RV-6 about 50 years ago! Pat Hatch RV-4, N17PH @ VRB, 700 hrs TT 0-320, Hartzell C/S RV-6, N44PH, 0.7 hrs TT 0-360, Hartzell C/S ________________________________________________________________________________
Subject: Re: Things that go BANG in the flight/Safety
Date: Jul 02, 2002
Subject: RV-List: Things that go BANG in the flight > > All-- > > Our RVs have several little tricks that can make things interesting, > from time to time. > > The other day I was flying over my practice area (Florida cattle > pasture/swamp, depending on the time of the year) and was just starting > to point the nose down from the top of a loop and pick up speed when > there was a loud bang .............. Boyd & List A salute and hardy "Here Here" for sharing this story! Ditto to Ed Anderson and Van's for publishing Ed's "war story" in the 3rd issue of the 2002 RVator. These are operational experiences from which we can all learn a great deal. In the USAF, as well as other military and commercial flight operations, the pilots impose plenty of good natured competition and pressure on each other trying to answer Iceman's question to Maverick in the movie Top Gun, "Have you figured out who is the best yet?" Another etched in stone tradition says that if you really scare yourself or successfully recover from a difficult situation, you are duty bound to relate your experience to the entire group assembled at the regular Safety Meeting. In return for this challenge to your pride, your peers are duty bound to offer only a toast of thanks without any of the usual ribbing. We are rapidly becoming part of a 3000-airplane fleet with the individual airplanes accumulating what I would guess are more flight hours per airframe than other homebuilts. This operational experience base, if shared, can help all of us to improve our skills and build a reputation for not only flying the most successful experimental sport aircraft ever, but also being part of the group that sets a new standard for safety and proficiency in sport aviation. I think we are well on are way to achieving that admirable goal. The virtual Safety Meeting is open for discussion, keep the stories coming! Dick Sipp N250DS RV-4 Eagle Neck Airpark Georgia ________________________________________________________________________________
Date: Jul 01, 2002
Subject: Re: Com antenna in the wing tip COMM problems
Indeed the cockpit is extremely noisy. Even the best noise cancelling mic has problems under the tight canopy. I think it is a combination of the high noise level and the tightly enclosed space, because I have been in noisier planes that were easer to communicate in. Jeff Bertsch noms1reqd(at)yahoo.com --- P M Condon wrote: > > > I think your SWR is a little hi. The reflected > energy is bouncing "to & > fro" within the confines of the feeder cable/coax to > the antenna and > disapating its energy via heat-not transmitted RF > energy. Don't worry > about the heat thing, there is no danger or harm of > a fire or anything. > A SWr of 1-1 is mathmetacally perfect but non > atainable . I've tuned > transmitters with a 1.1 to 1 or 1.2 to 1 that > worked fine. I think 1.8 > to 1 is a little hi. > > ALso agree with a poster on the noise issue. The > RV-4 can be noisy. His > suggestion will help you out. The SWR issue is > limiting your effective > distance. You could have a combo problem here also > (cabin noise AND hi > SWR). Also what is the line voltage to the > transmitter ? Low voltage > can reduce your effective distance also. > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > http://sbc.yahoo.com ________________________________________________________________________________
Subject: Things that go BANG in the flight/Safety
Date: Jul 02, 2002
>I think we are well on are way to achieving that admirable goal. The >virtual Safety Meeting is open for discussion, keep the stories coming! OK. As I was reading Boyd's post, I thought I knew what had happened as it had happened to me once. I was out doing loops in the Cub one afternoon, and, as I came over the top and starting down the back side, I heard a loud *BANG*. No idea at the time. I pulled out v e r y gently and actually looked back at the tail and was somewhat surprised to see it still attached. Got home, looked at things and found nothing. Played with it in my mind for a while and finally figured it out. Went out next day and did another loop and, as I came over the top, slammed the throttle closed, like one would if you suddenly were looking straight down at Ma Earth and didn't want to overspeed on the way down. The backfire from the engine was the same as the day before: BANG. Changed my thought process during a loop. Stupid manner of throttle control anyway. Fly and learn. Michael ________________________________________________________________________________
Date: Jul 02, 2002
--- Knicholas2(at)aol.com wrote: > > As I put in the rivets and screws through the canopy and into the > frame, > should/can I put a sealant in the holes to prevent water from > dripping in? > WHat is safe to use that won't damage the canopy? Kim, Take a look at the following: http://www.edt.com/homewing/justice/finish.html This is the finishing kit section of "The Justice Files", accessible through Kevin Horton's web site. In it, Frank suggests a way to seal the canopy that will address your question - and for more than just the rivet holes - there's the entire length of skirts to be concerned about! He has you run a bead of sealant along the skirts (side and rear) and then cleco them in place. After the sealant sets up, rivet it closed. Works great, and the rivets are protected behind a solid seal between the whole length of the skirts and plexi. I used a product suggested on the list called Lexel - plexiglass-safe, clear and easy to use. Have fun! Mike Thompson Austin, TX -6 N140RV (Reserved) FWF http://sbc.yahoo.com ________________________________________________________________________________
Subject: Fuel Selector Labeling
Date: Jul 02, 2002
Everyone, I own a C140 and found this neat plate to label the fuel selector in their newsletter. I called the guy that makes them and asked him to make one for my RV6. It is a great looking plate. He is selling them for $15. Please see the picture I posted on the picture share. His address is: James L. Alago 895 Garfield Ave Lansdale, PA 19446-5570 (610)584-6193 He doesn't have email, but feel free to email me, and I will try to help. Patty Gillies RV-6, SC gillies-patty(at)sc.edu ________________________________________________________________________________
Date: Jul 02, 2002
Subject: Re: First Flight N44PH (long)
In a message dated 7/1/2002 9:56:40 PM Pacific Daylight Time, pat_hatch(at)msn.com writes: > Thanks to all the folks on this list for the past 3 years that kept this > interesting, especially Eric Henson for the humor, Gary VanRemortel for t> he Yeller Pages, Matt for the List, Piedmont Builders Group, and all the > others for their valuable input. Oh yeah, don't want to forget Austin's > great stories and a special thanks to Jerry Springer for staying with the> list even though he built his RV-6 about 50 years ago! Glad to be of service and thanks for the plug. Helping the RV community to make better and safer airplanes is what it's all about. -GV (RV-6A N1GV 532hrs) ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Subject: Hartzell Next Generation Technology
Date: Jul 02, 2002
They following item was published in the Aero-news-net today (July 2, 2002). It includes a couple of links for further reading on the topic. Ernest Kells - RV-9A O235-N2C, Wood Prop Finish Kit 20% Complete Hartzell: Next-Gen Prop Technology Comprehensive New Blade Mfg Process May Represent Industry's First Major Tech Leap Since The 80s Hartzell Propeller has just unveiled a generational leap in manufacturing with its new propeller blade manufacturing process. The new process represents a $3 million investment in technology and demonstrates the commitment of Hartzell to driving improvements in all aspects of its propeller business. Overall, the new process greatly improves the accuracy of manufacturing, reducing blade-to-blade weight and aerodynamic variability. The result for pilots and passengers is smoother running propellers. "Much has been made of blueprinted engines; this advancement in propeller blade manufacturing is its equivalent -- the 'blueprinted' propeller, which will cover our entire product line and be available to all of our customers at no additional cost." said Joe Brown, Co-President responsible for the manufacturing operations at Hartzell. The new process also makes dramatic reductions in setup and changeover times, requires no special tooling and directly utilizes design engineering generated CAD 3-D solid models ... all of which makes the incorporation of new designs, including Hartzell's new technology "blended airfoil" scimitar blade designs more practical. Some of the results of these improvements have been seen in Hartzell's most-recent propeller designs for Cirrus, Lancair, Adam Aircraft, and Bruce Bohannon's record breaking Flyin' Tiger, as well as for its own Top PropTM program. One example of the improved accuracy is in the machining of propeller blade shanks. This particular process establishes all the other dimensions of the blade, and is now controlled to .0001" (2.5 microns). The airfoil is then produced from the computer-generated solid model, cut in a single pass using a 7-axis mill. This process employs tool and part probing to ensure accuracy while operating at feed rates up to 900 IPM (inches per minute). In addition to the machining equipment, a new Non-Destructive Test (NDT) cell provides more reliable blade testing. The environmentally friendly semi-automated "Dynamic Cloud" fluorescent penetrant inspection process eliminates procedure and operator variability to produce accurate results and ensure blades are free from even the most miniscule surface flaws. FMI: www.hartzellprop.com For the WHOLE story, go to http://www.aero-news.net/news/sport.cfm?ContentBlockID=4506 ________________________________________________________________________________
Date: Jul 02, 2002
Jim or others: Has anyone had experience mounting the Positech cooler in front of the engine (pilot side) per the alternate location in the RV-9A drawing. Since I have an O-235 N2C with a planned wood prop, I am always interested in putting stuff more forward for W&B concerns. What are the implications - effectiveness of the cooler, ineffectiveness of engine cooling, hose lengths and routing, etc. Thanks for any help. Ernest Kells - RV-9A O235-N2C, Wood Prop Finish Kit 20% Complete > The description you give sounds adequate. Cutting the half circle out of the > aft mount flange for engine mount clearance is something I have seen others > do. It sounds like the middle inner(nearest the mount) long bolt is the one > you have replaced with the short bolt. This would be the preferred one if > there was a choice. ________________________________________________________________________________
Date: Jul 02, 2002
Subject: wiring panel
Hi: Well I have postponed the electrical part as long as I could, but I must get with it. This is something I dreaded all the time...Electrical is not one of my abilities. My first question, where can i buy the special crimper for the very little wires, like the ones on the electric trim. I tired soldering, forget it, cannot do it, so can I just crimper these little rascals? I went to radio shack, the did not know what I was talking about... This is the one for now, and thanks in advance for your replies... Bert rv6a Inst. panel... ________________________________________________________________________________
Date: Jul 02, 2002
What do y'all think about using that Lexel along the fwd canopy frame bow -- with *NO* rivets? Normal rivets/proseal along the sides. (I'm refering to the RV-8 canopy). I don't see how this area would be under great stress, unless the canopy is wide open in flight. Crazy idea? -Larry --- Mike Thompson wrote: > > --- Knicholas2(at)aol.com wrote: > > > > As I put in the rivets and screws through the canopy and into the > > frame, > > should/can I put a sealant in the holes to prevent water from > > dripping in? > > WHat is safe to use that won't damage the canopy? > > Kim, > > Take a look at the following: > > http://www.edt.com/homewing/justice/finish.html > > This is the finishing kit section of "The Justice Files", accessible > through Kevin Horton's web site. > In it, Frank suggests a way to seal the canopy that will address your > question - and for more than just the rivet holes - there's the entire > length of skirts to be concerned about! > > He has you run a bead of sealant along the skirts (side and rear) and > then cleco them in place. After the sealant sets up, rivet it closed. > Works great, and the rivets are protected behind a solid seal between > the whole length of the skirts and plexi. > > I used a product suggested on the list called Lexel - plexiglass-safe, > clear and easy to use. > > Have fun! > > Mike Thompson > Austin, TX > -6 N140RV (Reserved) > FWF > > > http://sbc.yahoo.com > > > > > > > > http://sbc.yahoo.com ________________________________________________________________________________
Subject: Re: wiring panel
Date: Jul 02, 2002
Have you bought Bob Knuckolls (sp?) book 'The Aeroelectric Connection'? It is a must in my opinion. I learned a lot and I do electrical stuff for a living. He also has a website (http://www.aeroelectric.com) and there is the mailing list. aeroelectric(at)matronics.com Soldering should not be that hard. If you are finding it difficult then you probably don't have the right equipment. Go get a 25W soldering iron and some scrap wire and some really small (24AWG) rosin core solder and practice. You'll find that it is not that difficult to master. The key is making sure that everything is clean and remember that solder does not stick to anything that is not hot. Oh and STAY OUT OF RADIO SHACK. There is very little in that store that I would trust in my airplane. It is a great place to get stuff for hobby or educational type projects but everything they have there is sub-par. You will want to stay with MIL spec. connectors, crimping tools etc. and you will not find these at RS. The sales droids there will not likely ever know what you are talking about anyway. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) http://www.myrv7.com Fuselage Airplanes never win battles with the ground. The best the airplane can hope for is a draw. ----- Original Message ----- From: <Bertrv6(at)aol.com> Subject: RV-List: wiring panel > > Hi: > > Well I have postponed the electrical part as long as I could, but I must > get with it. This is something I dreaded all the time...Electrical is not > one > of my abilities. > > My first question, where can i buy the special crimper for the very little > wires, > like the ones on the electric trim. I tired soldering, forget it, cannot do > it, so > can I just crimper these little rascals? I went to radio shack, the did not > know > what I was talking about... > > This is the one for now, and thanks in advance for your replies... > > > Bert > > rv6a > > Inst. panel... > > ________________________________________________________________________________
From: "rodney.woodard" <rodney.woodard(at)attbi.com>
Subject: I'm baaaack...
Date: Jul 02, 2002
Hello Everybody, I decided to take the plunge and re-subscribe to an rv-list. I searched back through the archives and found that I've been doing this on and off for about 6 years. Man, how time flys. In any case, I've made some small progress on my RV-3 kit in the last year or so. I'm about to finish up the tail kit. I've been in no hurry because I don't really have the funds set aside for the wing kit. In fact, I probably won't order the wing kit until sometime next year. I've recently submitted a link to my website to Van's for inclusion on their web links listing. I've had amazing response. I would have never guessed that so many people look at that site so often. I'm only going to subscribe to the RV-3 list due to the volume of e-mails received by subscribing to the main list. I'm no expert, but I'd be willing to answer questions based on my limited experience! Best regards to all, Rod Woodard www.woodardfamily.com/RV3Project.htm RV-3 #11339 in progress RV-3 N99RV sold Jan 2000 Northern Colorado ________________________________________________________________________________
Subject: Pro-Seal wait time.
Date: Jul 02, 2002
I Pro-Sealed my stiffeners in a couple of days ago. I didn't mix up quite enough, so I didn't do the gas cap. I did the cap today. How long should I wait until I put it in the cradle and buck all the ribs? Wanta get these things done. Dana Overall Richmond, KY http://rvflying.tripod.com MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide.aspx ________________________________________________________________________________
Date: Jul 02, 2002
Bert, I understand - I was not too enthusiastic about the wiring either but in the end it was not so bad. A couple of hints to avoid going nuts. 1. Take it one insturment, one wire at a time. (It got overwhelming when I thought about the "big" picture). 2. Put a label on EACH end of VERY wire - use your computer (Excell) to print little strips of 7 pt. font, roll it into tiny rolls and fit it on the wire and put clear heat shrink. I followed the example of others and labeled example: pitot switch<>pitot 10A fuse. That way you know where each wire is going. It takes alot of time, but you will thank me with massive quantities of beer and chips after all the wires are stretched out. 3. Be sure to place everything on the sub panel in a location that you can reach when the plane is all done and you are on your back, under the panel, swearing like a sailor. I have moved a couple of things already in anticipation of spending time on my back. 4. Allow LOTS of time. It took me longer than I expected - but then, EVERYTHING takes me longer than expected.... Keep on chuggin'... Kim Nicholas RV9A - finishing & wiring..... ________________________________________________________________________________
Subject: Re: Pro-Seal wait time.
Date: Jul 02, 2002
Press on. I waited overnight between proseal sessions and that was fine. Russ HRII > > > I Pro-Sealed my stiffeners in a couple of days ago. I didn't mix up quite > enough, so I didn't do the gas cap. I did the cap today. How long should I > wait until I put it in the cradle and buck all the ribs? > > Wanta get these things done. > > Dana Overall ________________________________________________________________________________
Date: Jul 02, 2002
24 HOURS if you mixed the batch right Glenn --- Dana Overall wrote: > > > > I Pro-Sealed my stiffeners in a couple of days ago. > I didn't mix up quite > enough, so I didn't do the gas cap. I did the cap > today. How long should I > wait until I put it in the cradle and buck all the > ribs? > > Wanta get these things done. > > Dana Overall > Richmond, KY > http://rvflying.tripod.com > > > MSN Photos is the easiest way to share and print > your photos: > http://photos.msn.com/support/worldwide.aspx > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ==== Glenn Williams 8A A&P N81GW http://sbc.yahoo.com ________________________________________________________________________________
Date: Jul 02, 2002
Go for it. Proseal has a fairly short working time in any case but once the stiffeners were riveted in you would not be able to disturb the joints. Using solvent during preparation and clean up should not cause a problem either. I worried about cleaning the flush heads (thought I might seep solvent into the rivet joint) but the proseal prevents it and the solvent evaporates quickly. I waited a week before balloon testing (probably overkill - overnight would be fine) and only had one pin-hole - a too-deep flute in an end-rib with not enough proseal. Patrick Kelley - RV-6A project in transit -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dana Overall Subject: RV-List: Pro-Seal wait time. I Pro-Sealed my stiffeners in a couple of days ago. I didn't mix up quite enough, so I didn't do the gas cap. I did the cap today. How long should I wait until I put it in the cradle and buck all the ribs? Wanta get these things done. Dana Overall Richmond, KY http://rvflying.tripod.com MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide.aspx ________________________________________________________________________________
Subject: Re: S-TEC Autopiilot installation - Altitude Hold not working
Date: Jul 02, 2002
Dear listers, I really appreciated the input concerning the S-TEC altitude hold problem I had. The list is a great source of corporate wisdoms. Turned out to be just like George Meketa said. Great troubleshooting hints from his part. Worked great. Poor quality control at the factory though!! Claude Heiniger ----- Original Message ----- From: Meketa <acgm(at)gvtc.com> Subject: Re: RV-List: S-TEC Autopiilot installation - Altitude Hold not working > > Claude > > It sounds like the wires to the pitch servo motor need to be swapped. > These are the two wires that actually run the motor. Look at the supplied > blueprint diagram and swap the wires at the harness end before the servo. > All servos are wired the same way. If you switch the wires at the servo end > of the plug a factory repaired ar replaced servo will again do the same > thing. > > I flew in a friends 182 on the initial auto pilot test flight (S-TEC 30) and > it > would act as you mentioned. The auto pilot would start a pitch up or down > and would progress into a steep accent or decent. The motor was going in > the wrong direction. > > A simple ground test would be to suck on the static source with the altitude > hold engaged and watch the yoke. It should push in for a decent. If it pulls > back things are working backwards. > > If you have no diagram and need wire colors let me know. I have all the info > at > the airport. > > George Meketa > RV8 / S-TEC 30 > > > > > I would appreciate comments from list members who have installed an > > S-TEC autopilot (50 series). > > > > This has just been installed in a Cessna 310 and as the airplane was > > test flown, it was impossible to have the Altitude mode hold altitude. > > It would either push the nose over and go out of trim and dive or > > initiate a steep climb. > > > > The Sensor was tested on a static system box and behaved like another > > one that works ok. It seems like, on a ground test that the servo will > > not hold the yoke in positon, rather go forward on it. > > > > If any one has had a run-in with such a problem, I would appreciate your > > comments. > > > > Greetings from Europe > > > > Claude Heiniger > > A&P, CFII, ATP > > Stby for a RV-7 when the time is ripe! > > ________________________________________________________________________________
Subject: Re: N747ES FLYS !!!!1
Date: Jul 02, 2002
Scot, CONGRATULATIONS !!! and WELL DONE !!!! Chuck Dave Rowbotham RV-8A -- RV-List message posted by: ABAYMAN(at)aol.com HI GANG just a little excited right now since my 4.5 year project left the grips of gravity and made a picture perfect takeoff, circled the pattern for 20 minutes and the a perfect landing. a small oil leak was quickly fixed, and an aileron was squeezed ________________________________________________________________________________
Date: Jul 02, 2002
Pat, CONGRATULATIONS and WELL DONE !!! Chuck Dave Rowbotham RV-8A ________________________________________________________________________________
Date: Jul 02, 2002
Ernest, We originally had ours mounted on the rear baffle but had the start of the same type of baffle cracking Van's experienced. We also rec'd the updated cooler replacement and it was going to be a very tight fit. We reinstalled it on the firewall (right side). We built a mount and reinforced the cockpit side of the firewall. Our battery is in the rear baggage comp. Works well. Chuck Dave Rowbotham RV-8A From: "Ernest Kells" <ERNEST.KELLS(at)SYMPATICO.CA> Reply-To: rv-list(at)matronics.com To: Subject: Re: RV-List: Positech oil cooler Date: Tue, 2 Jul 2002 10:10:35 -0400 -- RV-List message posted by: "Ernest Kells" Jim or others: Has anyone had experience mounting the Positech cooler in front of the engine (pilot side) per the alternate location in the RV-9A drawing. Since I have an O-235 N2C with a planned wood prop, I am always interested in putting stuff more forward for WB concerns. What are the implications - effectiveness of the cooler, ineffectiveness of engine cooling, hose lengths and routing, etc. Thanks for any help. Ernest Kells - RV-9A O235-N2C, Wood Prop Finish Kit 20% Complete The description you give sounds adequate. Cutting the half circle out of the aft mount flange for engine mount clearance is something I have seen others do. It sounds like the middle inner(nearest the mount) long bolt is the one you have replaced with the short bolt. This would be the preferred one if there was a choice. ________________________________________________________________________________
Subject: Re: Prop Guard
Date: Jul 02, 2002
John, We have PropGuard installed on our c/s prop - 200hp IO-360. No problems at all - only missingare nicks in the prop. Highly recommended and easy to install. Excellent investment! Chuck Dave Rowbotham RV-8A (25 hours on prop guard) From: "John" <N1CXO320(at)SALIDACO.COM> Reply-To: rv-list(at)matronics.com To: Subject: RV-List: Prop Guard Date: Mon, 1 Jul 2002 18:11:48 -0600 -- RV-List message posted by: "John" Van's news letter, the RVator, has a short blurb regarding how well PropGuard worked for the writer...there is precious little in the archives, and I wondered if anyone "out there" has tried this product. MSN Photos is the easiest way to share and print your photos: Click Here ________________________________________________________________________________
Subject: FIRST FLIGHT
Date: Jul 03, 2002
RV6 VH-MUM Broadford Australia 30June2002 Bloody awesome!!!!!!!!!!!!!!!!Does it go!!!!!!!!!!!!!!!! Chris and Susie VH-MUM ________________________________________________________________________________
Date: Jul 02, 2002
> Van's news letter, the RVator, has a short blurb regarding how well > PropGuard worked for the writer...there is precious little in the > archives, and I wondered if anyone "out there" has tried this product. I love it. Wouldn't fly for long without it, certainly not in rain or on poor quality runways (rocks). Protects my investment in my CS prop. First 90 hours without prop guard, last 300 hrs with it. Tim ****** Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD - First Flight 18 Dec 99
http://www.geocities.com/timrv6a ****** ________________________________________________________________________________
Subject: Installation of a Garmin 295
Date: Jul 02, 2002
From: "Jerry Calvert" <rv6(at)cox.net> Subject: Re: RV-List: Installation of a Garmin 295 Bruno, I mounted my 295 in a cutout in the panel of my -6. The viewing angle is, in my opinion, fairly critical and the graphics will all but disapear when the viewing angle between eyes and screen is not perpendicular. The sun will also wash it out as is the case with other GPS's. So, a position under the glare shield or shaded area is prefered. I would go with a RAM mount and just sit in the plane, in the sun, with the GPS on and move it around to find a good position for you. Jerry Calvert Edmond Ok -6 ------------------------------------------------ Hello Jerry I tried it with the GPS mounted on a knee board and like you said if the viewing angle is not uptimum it's very hard to see the display very well,specially if running on batteries. The RAM Mounts seems to be a good idea but I would need to built a bracket for it. Cheers Bruno ________________________________________________________________________________
Date: Jul 02, 2002
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> Subject: RE: RV-List: Installation of a Garmin 295 I'd be interested in knowing too as I haven't found a good place to mount my GPS III. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 Hello Scott I saw a few RVs " 4 & 6" at a fly-in last week end and most of the "4" had theirs GPS III mounted on the glare shield at eye level,it seems to be a good place for it. The "6" had theirs mounted either in the panel in front or to the right of the pilot or installed on side mount like the Rams. Hope this help Bruno ________________________________________________________________________________
Subject: Re: I'm baaaack...
Date: Jul 02, 2002
As Kevin points out, my RV-3 list message went both to the RV-3 list and the main rv-list. I would have never seen the responses had Kevin not forwarded them to me. Hmm. The dilemna is whether or not I want to subscribe to the main list to see ALL the rv-list messages or if I want to leave people thinking that I'm just not responding.... BTW, I figured something was up when I received e-mail from several people I haven't heard from in quite a while. Best regards, Rod Woodard RV-3 #11339 in progress www.woodardfamily.com ________________________________________________________________________________
Date: Jul 02, 2002
Subject: N109RV first flight
N109RV had it's first flight on Tuesday evening. It flew beautifully but a high cyl head temp cut the flight short. We will try again in the morning when it is cool. The ambient temperature was 90deg. Paul Baird 90355 RV-9A Flying! ________________________________________________________________________________
Date: Jul 02, 2002
Subject: Latest RVator?
When did the 3rd RVator issue start arriving? I haven't got mine yet :-( -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Working on the wings :-) ________________________________________________________________________________
Date: Jul 02, 2002
Subject: Re: Fuel Selector Labeling
Patty Gillies wrote: > > Everyone, > > I own a C140 and found this neat plate to label the fuel selector in their > newsletter. I called the guy that makes them and asked him to make one for > my RV6. It is a great looking plate. He is selling them for $15. Please > see the picture I posted on the picture share. His address is: > > James L. Alago > 895 Garfield Ave > Lansdale, PA 19446-5570 > (610)584-6193 > > He doesn't have email, but feel free to email me, and I will try to help. > > Patty Gillies > RV-6, SC > gillies-patty(at)sc.edu Could not find the picture, where is it? -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Working on the wings :-) ________________________________________________________________________________
Subject: RV6A Quickbuild Kit for Sale
Date: Jul 02, 2002
Just an fyi : I'm selling an RV-6A Quickbuild kit purchased in July 2000 on Ebay. The item number is 1839120531 and the link is: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1839120531 I've included a scanned invoice for actual description of included items and options. I've got only about 100 hours of work done on it so far with mostly time spent on sheet metal work such as seats, floor, flaps, etc. Wings are still crated as delivered from factory. Its been inspected by a local EAA technical advisor (who is a retired A&P/AI) with no problems or concerns. No tools are included. Kit is in Minneapolis, MN Thanks, Gary S. ________________________________________________________________________________
Date: Jul 02, 2002
Subject: used comm radios
My budget is already pretty badly broken, but I still would like to have 2 radios. The RST audio panel kit at about $250 sounds like a good low cost choice for the audio panel. I plan on the Bendix KX-125 nav/com, so another Silvercrown radio below it would at least match style-wise, but they seem to run around $900 new. Do you save much by buying a yellow tagged radio? Is there a good source of such things? -- Tom Sargent. ________________________________________________________________________________
Subject: Re: Latest RVator?
Date: Jul 02, 2002
Got mine late last week, and I am usually among the last. Jeff Point Milwaukee WI RV6 Finish kit When did the 3rd RVator issue start arriving? I haven't got mine yet :-( ________________________________________________________________________________
Date: Jul 02, 2002
Subject: Re: used comm radios
> >My budget is already pretty badly broken, but I still would like to have >2 radios. For VFR? Why? > The RST audio panel kit at about $250 sounds like a good low Why an audio panel? Why do things have to match? Another RV owner here says he flew many years in the Navy with just one radio. Why can't we? I haven't had a radio failure since the days of the Mark 16. K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Jul 02, 2002
That's "Lexel". I got it at Ace Hardware. Clear, paintable, won't harm the plexi, cleans up with naptha or alcohol (both of which are also ok on plexi). Don's right -- clean up before letting it set too long. Randall ----- Original Message ----- From: "Don Jordan" <dons6a(at)juno.com> Subject: Re: RV-List: sealing rivet holes in canopy > > Randall Henderson recommended Lexan. I got it at Home depot. I wish you > were near. I used 1 per cent of it. > use naptha to clean up, right then. I waited a day or two, It was a job > to clean off. > > It looks like a clear chaucking. > > Don Jordan - N6DJ - RV6A > Arlington, Tx ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: Navaid Dimmer
Date: Jul 03, 2002
List, Has anyone who has installed a Navaid found a way to use a dimmer control for the LED Display? I have put a small dimmer control in the panal just for the trim, flap and S-Tec Alt. Hld. LED Readouts. Finishing up wiring this week then Fiberglas City on the RV6-A! Tom in Ohio ________________________________________________________________________________
Subject: RV6 tilt-up Canopy fitting
Date: Jul 03, 2002
Thanks all for the help with my canopy - It's now cut and fitted (whew!), and awaiting hole enlarging over the 4th of July. I have created another problem for myself, in that the forward edge of the canopy has a gap of about 1/4" all across the front canopy skin - the pesky thing moved up on me during the night. Do I need to be concerned about this? Do I need to secure this with little brackets a la Sam Buchanan? Should I do the fiberglas lay-up right over the gap? Any suggestions would be appreciated. Safe and peaceful 4th of July to all, Peter Peter Blake 60 Beverly Drive Kintnersville, PA 18930 RV6 tilt-up N899PB reserved ________________________________________________________________________________
Date: Jul 03, 2002
Gary, What happened? I saw you had a bid at $12,000... did you get burnt by one of those fake bidders? Chuck ----- Original Message ----- From: Gary Strong <gstrong(at)att.net> Subject: RV-List: RV6A Quickbuild Kit for Sale > > Just an fyi : > I'm selling an RV-6A Quickbuild kit purchased in July 2000 on Ebay. The > item number is 1839120531 and the link is: > http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1839120531 > > I've included a scanned invoice for actual description of included items > and options. I've got only about 100 hours of work done on it so far > with mostly time spent on sheet metal work such as seats, floor, flaps, > etc. Wings are still crated as delivered from factory. Its been > inspected by a local EAA technical advisor (who is a retired A&P/AI) > with no problems or concerns. No tools are included. Kit is in > Minneapolis, MN > > Thanks, > > Gary S. > > ________________________________________________________________________________
Date: Jul 03, 2002
From: Ross Schlotthauer <rdschlotthauer(at)yahoo.com>
Subject: Pro seal curing time
Rvrs, Could anyone confirm for me how their Pro-seal has cured? After several weeks mine is like a fairly hard rubber but you can definately cut into it with your fingernail. I saw some the other day that was as hard as wood on another plane. Please advise. Thanks, Ross Schlotthauer RV7 wings 75% Coeur d'Alene, ID http://sbc.yahoo.com ________________________________________________________________________________
Date: Jul 03, 2002
Ross, I know what your talking about. It had been several years since I played with some pro-seal and just recently had occasion to do so. After 3 weeks I was still unsure it was "fully" cured; but it was/is as soon as it hardens to that rubbery state. This was confirmed by my local AP-IA and numerous others that advised me "off-list". Chuck ----- Original Message ----- From: Ross Schlotthauer <rdschlotthauer(at)yahoo.com> Subject: RV-List: Pro seal curing time > > Rvrs, > > Could anyone confirm for me how their Pro-seal has > cured? After several weeks mine is like a fairly hard > rubber but you can definately cut into it with your > fingernail. I saw some the other day that was as hard > as wood on another plane. Please advise. > > Thanks, > > Ross Schlotthauer > RV7 wings 75% > Coeur d'Alene, ID > > http://sbc.yahoo.com > > ________________________________________________________________________________
Subject: Instruction (long clarification)
Date: Jul 03, 2002
I guess there has been some confusion. Perhaps I have not understood some of the questions I have gotten lately (including those from Ken Scott at the factory.) regarding coverage for instruction. Specifically, I believe some of you might be under the misconception that you would not be covered by your insurance policy while receiving instruction in your airplane (whether an RV or production plane.) The following text was in response to a posting on my discussion board. (original text of inquiry posted below this response.) I would like to clarify some things regarding instruction. There can be coverage on an individuals Pleasure and Business policy (thru the VanGuard Program or any other company for that matter). Most policies would cover losses while training was occurring (if both the CFI and the instructee were both named pilots.) Or in the case of production aircraft, the instructee could be named on the policy and the instructor could either be named or qualify under the open pilot warranty (homebuilts don't get OPW's ... they are all named pilots only.) So to say that there would never be coverage under a P + B policy while training is occurring would be false. What I think people are confusing that with is a CFI who owns an RV and wants to do transition training in it. Coverage for that would be much different. That would need a commercial policy that would include coverage for instruction. That coverage is more expensive than a Pleasure and Business (P+B) policy because there is greater risk of an accident. But, the cost thru the program is actually very reasonable when compared to single aircraft instruction policies on production aircraft. And, as far as I am aware the VanGuard program (and possibly AVEMCO... I'm not sure) is the only place to get such coverage. The insurance companies are still going to require prior time in type or checkouts prior to coverage being valid for a pilot in an RV, so to the insurance companies it isn't as if they are afraid someone is not going to get a checkout. If the policy has a requirement that the pilot receive a checkout from a CFI, and the pilot does not get it, but flies the plane anyway, then the company would likely not pay for the claim. As far as renters coverage, there is only one company writing that type of coverage other than AVEMCO, and neither policy covers Experimentals (I am pretty sure AVEMCO's doesn't, and very sure AIG's doesn't). If you were doing training in a production aircraft, AIG's non-owned coverages are better than AVEMCO's, and would likely be available. However, the policy length is one year, and it is 50% earned at inception (if you got the coverage and used it for one week and cancelled the policy, you would only get 50% of your premium back.) John "JT" Helms Branch Manager NationAir Insurance Agency Pleasure and Business Branch Original posting that this is in response to: A question regarding insurance came up on one of the RV lists yeaterday regarding insurance coverage for an RV for the purpose of transition training. Since the FAA has allowed owners to be compensated for the use of their airplanes for use in transition training, what is the reality of the insurance world. I hear that some are having to pay full primary flight school insurance premiums for limited use as a transition trainer. The other rumor is that your primary insurance will not cover any damage if it is determined that the pilot in command is receiving any sort of training from an instructor. What would be the insurance ramifications of obtaining additional flight training in your certified aircraft? Say someone is working on their IFR rating in their own plane or getting a complex rating for their new whiz bang folding gear gas guzzler? If they had a near earth experience and bent some alumunum, would their in motion insurance cover the repairs or would the insurance holder say that they were in training and try to fall back on the instructor's liability insurance? Is there some type of policy such as a renters policy that would cover a plane not owned by you for training? Maybe a short time liability policy or an in motion policy that would cover the airplane being used? It looks like it would be in the insurance writers best interest to have some policy that is not so expensive that you drive most CFI's out of the transition training area and make transition training so expensive that people will ignore it and try to fly a plane that they are not ready to fly. What are your thoughts on this. You might post on one of the RV groups to get more coverage Regards Larry Perryman N194DL near completion ________________________________________________________________________________
Date: Jul 03, 2002
Subject: Re: Navaid Dimmer
Hi Tom, I found that the Navaid lighting is not very bright and didn't need a dimmer. As a matter of fact I installed a UMA light bezel on it to match the lighting of the rest of my instruments. Cash Copeland RV6 Hayward, Ca > List, Has anyone who has installed a Navaid found a way to use a dimmer > control for the LED Display? I have put a small dimmer control in the > panal just for the trim, flap and S-Tec Alt. Hld. LED Readouts. > Finishing up wiring this week then Fiberglas City on the RV6-A! > > Tom in Ohio ________________________________________________________________________________
Date: Jul 03, 2002
Subject: Re: Pro seal curing time
proseal is made to be flexible. Let me give you a small history lesson (as you can see proseal is one of my specialties) Proseal was designed in the 40's specifically for the B-29 bomber. The wings were long and flexible and were very prone to leaks, proseal cured the problem. heres the answer to your question. You want it to be black in color (Very dark grey to black) the darker the color the quicker the curing time and the harder the proseal will be. Even in it's darkest form it will still be flexible. If your friends is as hard as wood I would doubt that it is proseal. (could be epoxied over proseal) anyway if your batch starts to set up on you use MEK to soften it up and get some more working time out of it. (be advised that after using mek the batch will cure faster still. hope this helps Glenn Williams A&P Fort Worth, Texas --- Ross Schlotthauer wrote: > > > Rvrs, > > Could anyone confirm for me how their Pro-seal has > cured? After several weeks mine is like a fairly > hard > rubber but you can definately cut into it with your > fingernail. I saw some the other day that was as > hard > as wood on another plane. Please advise. > > Thanks, > > Ross Schlotthauer > RV7 wings 75% > Coeur d'Alene, ID > > http://sbc.yahoo.com > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ==== Glenn Williams 8A A&P N81GW http://sbc.yahoo.com ________________________________________________________________________________
Date: Jul 03, 2002
Subject: Re: vsi problem
dear listers, what would cause a VSI to show zero on the ground and 1000 ft decent in level flight? scott tampa ________________________________________________________________________________
Date: Jul 03, 2002
In a message dated 7/2/2002 9:54:39 PM Pacific Daylight Time, randallh(at)attbi.com writes: > That's "Lexel". I got it at Ace Hardware. Clear, paintable, won't harm the > plexi, cleans up with naptha or alcohol (both of which are also ok on > plexi). That's naphtha. -GV (RV-6A N1GV 525hrs) ________________________________________________________________________________
Subject: vsi problem
Date: Jul 03, 2002
Did you mistakenly hook it to the pitot instead of static? Pat Kelley - RV-6A project in transit -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of ABAYMAN(at)aol.com Subject: Re: RV-List: vsi problem dear listers, what would cause a VSI to show zero on the ground and 1000 ft decent in level flight? scott tampa ________________________________________________________________________________
Date: Jul 03, 2002
From: Jaye and Scott Jackson <jayeandscott(at)shaw.ca>
Perhaps it would behave like that if it were hooked up to the pitot system instead of the static system... Scott in Vancouver -6 painting ----- Original Message ----- From: <ABAYMAN(at)aol.com> Subject: Re: RV-List: vsi problem > > dear listers, > what would cause a VSI to show zero on the ground and 1000 ft decent in level > flight? > scott > tampa > > ________________________________________________________________________________
Date: Jul 03, 2002
Dear Scott, Hmmm, Accurate when standing still, but a 1000ft error when in motion? Are your static ports located as per plans? Any possible low pressure turbulence in this area? Good luck troubleshooting, and a Very Happy 4th of July! Konrad ABQ ----- Original Message ----- From: <ABAYMAN(at)aol.com> Subject: Re: RV-List: vsi problem > > dear listers, > what would cause a VSI to show zero on the ground and 1000 ft decent in level > flight? > scott > tampa > > ________________________________________________________________________________
Date: Jul 03, 2002
Subject: Re: RV-List: vsi problem > > dear listers, > what would cause a VSI to show zero on the ground and 1000 ft decent in level > flight? > scott > tampa > Scott, I had the very same problem with my orginal VSI and finally determined that apparently when I installed it in the panel, the paint in the panel hole caused sufficient friction that when I tightened the mounting screws I cracked the case of the VSI. It drove me batty for months thinking it was my static system before finding the cracked case. Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC ________________________________________________________________________________
Subject: Big Mistake...
Date: Jul 03, 2002
Hello, I went to the workshop today with every intention of making some serious headway toward finishing my elevators. I picked up the elevator control horn and instantly recognized a big mistake... I incorrectly placed the root rib (E-304) on the right elevator spar. In order for the control horn to fit, the web of the rib (E-304) must form the correct angle with the spar (E-302). I did at least a couple of things incorrectly: (1) I cyphered the angle of the root roob which wasn't exactly the angle of the steel rudder control horn. I also (incorrectly) had already drilled the skeleton to the skin... when I should have waited until I had at least drilled the control horn to the spar & rib. The control horn would have set the angle and the holes through the skin would have followed from there. (2) This was the dumb/obvious mistake... When I riveted the rib to the spar, I set the rib about an inch outboard on the spar rather than making the web of the rib and the web of the spar line up and form a nice angle for the rudder control horn. This is hard to descibe but was immediately apparent when I picked up the control horn. This is the first really big screw-up for me with this RV-3 project. I'm thinking I'll create a section on my web site specfically for mistakes. I didn't take pictures today so things will have to wait until at least Sunday when I get home from work. The good news from all this is that the total cost of the mistake including a new spar, new elevator skin, new ribs(2) and new stiffener material is about $65. Throw in about $40 for shipping and handling and I end up with a $100 mistake. I suppose if this is the most expensive mistake I make, I'll be happy! Best regards to all. Rod Woodard RV-3 #11339 1 step forward; 2 steps back! www.woodardfamily.com ________________________________________________________________________________
From: "Michel Boucher" <michelboucher594(at)rogers.com>
Date: Jul 03, 2002
Your static must be blocked the VSI is acting like an Altimeter, probably if you went higher it will indicate more of a descent. Your airspeed and Altimeter must be erroneous also. Be carefull! Michel RV3 RV8 forever painting -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of ABAYMAN(at)aol.com Subject: Re: RV-List: vsi problem dear listers, what would cause a VSI to show zero on the ground and 1000 ft decent in level flight? scott tampa ________________________________________________________________________________
From: "Glenn & Judi" <dirtyrottenscoundrels(at)attbi.com>
Date: Jul 03, 2002
I had a similar problem on my first flight. VSI was actually reading backwards. After many hours of confusion, I replaced the instrument entirely. Problem gone. It was a bad VSI. The instrument shop said that they aren't worth rebuildling. -Glenn Gordon N442E ----- Original Message ----- From: <ABAYMAN(at)aol.com> Subject: Re: RV-List: vsi problem > > dear listers, > what would cause a VSI to show zero on the ground and 1000 ft decent in level > flight? > scott > tampa > > ________________________________________________________________________________
Date: Jul 03, 2002
I'd be curious as to what you finally determine to be the cause. I can't believe it is a blocked static, because that should cause the instrument to not read anything. The reason I think it is hooked to the pitot is because straight and level flight would deliver nearly constant pressure which the instrument should interpret as a descent. In fact, I would expect the pitot to deliver enough pressure to indicate a maximum rate but then again it is a pretty small opening. Since you mentioned level flight explicitly, I would guess you see different indications when you change pitch attitude or airspeed. Anyway, color me curious. Patrick Kelley - RV-6A project in transit -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of ABAYMAN(at)aol.com Subject: Re: RV-List: vsi problem dear listers, what would cause a VSI to show zero on the ground and 1000 ft decent in level flight? scott tampa ________________________________________________________________________________
Subject: Re: FIRST FLIGHT
Date: Jul 04, 2002
Chris Susie, CONGRATULATIONS and WELL DONE !! Chuck Dave Rowbotham RV-8A (flying) From: "chris mcgough" <RV6(at)SSC.NET.AU> Reply-To: rv-list(at)matronics.com To: Subject: RV-List: FIRST FLIGHT Date: Wed, 3 Jul 2002 06:23:40 +1000 -- RV-List message posted by: "chris mcgough" RV6 VH-MUM Broadford Australia 30June2002 Bloody awesome!!!!!!!!!!!!!!!!Does it go!!!!!!!!!!!!!!!! Chris and Susie VH-MUM MSN Photos is the easiest way to share and print your photos: Click Here ________________________________________________________________________________
Subject: Re: N109RV first flight
Date: Jul 04, 2002
Paul, CONGRATULATIONS and WELL DONE !! Chuck Dave Rowbotham RV-8A From: Paulbaird(at)aol.com Reply-To: rv-list(at)matronics.com To: rv-list(at)matronics.com Subject: RV-List: N109RV first flight Date: Tue, 2 Jul 2002 22:08:48 EDT -- RV-List message posted by: Paulbaird(at)aol.com N109RV had it's first flight on Tuesday evening. It flew beautifully but a high cyl head temp cut the flight short. We will try again in the morning when it is cool. The ambient temperature was 90deg. Paul Baird 90355 RV-9A Flying! MSN Photos is the easiest way to share and print your photos:
Subject: Single Radio - was used com radios
Date: Jul 04, 2002
Re the use of 2 radios. I live in the Northeast, about halfway between Boston and NY class bravos. As a result, most of my X country flying involves flight following and occasionally includes a clearance into Class Bravo. I have a KY 197 and occasionally have to get a "temporary frequency Change" to check ASOS/ATIS at my destination airport. I was thinking of adding a radio but reallywould like to keep my RV-4 as light as possible. I recently flew in an UPSAT SL-40 equipped plane. This allows you to monitor the standby with priority given to the active frequency. Suddenly 1 radio can do everything I need. Will be ordering as soon as I save up the $$. Then I'll have a nice KY 197 for sale. Don Mei RV-4 N92CT 3B9 - Chester, CT Americans used to roar like lions for liberty: Now they bleat like sheep for security Norman Vincent Peale
http://www.hotmail.com ________________________________________________________________________________
Date: Jul 03, 2002
Hal: The spam cans I've rented have had pretty frequent radio failures. But having 2 radios made it a minor event. So, from that experience, redundancy is my main reason. There is some convenience too: If you have 2 radios and an audio panel you can monitor one frequency while using another for xmit/receive. As for the VOR, it's a *completely* independent (from GPS) means of navigation. I actually saw one time when my GPS couldn't get enough satellites for a long time. Any system can fail. Yes, I'll be VFR, but I'll have a gyro horizon and a turn coordinator too. I don't plan on ever getting into a zero visibility situation, but the atmosphere is a chaotic thing which doesn't care about my plans. If it does happen, I mean to keep the right side up. Another reason for all this is to make the plane more "standard", should I ever want to sell it. kempthornes wrote: > > > > > >My budget is already pretty badly broken, but I still would like to have > >2 radios. > > For VFR? Why? > > > The RST audio panel kit at about $250 sounds like a good low > > Why an audio panel? > > Why do things have to match? > > Another RV owner here says he flew many years in the Navy with just one > radio. Why can't we? I haven't had a radio failure since the days of the > Mark 16. > > K. H. (Hal) Kempthorne > RV6-a N7HK flying! > PRB (El Paso de Robles, CA) -- Tom Sargent. ________________________________________________________________________________
Date: Jul 04, 2002
Hi George, Is there a site on the web for this equipment? Jim in Kelowna Hi Jim For information on UPSAT they have a nice web site with product info, installation manuals etc. and some wiring diagrams at www.upsat.com/ George McNutt Langley B.C. - flying, 40 hrs. ________________________________________________________________________________
Date: Jul 04, 2002
Re: Is there a site on the web for this equipment For Info Try: http://www.upsat.com/sl40.shtml http://www.upsat.com/sl40.shtml (same thing but with GPS also) also go to avionicswest.com click ups panel mount, gpswithoutmovingmap When you see sl40, click the review section. and you will get a review. Regards, Don RV-4 3B9 - Chester, CT Americans used to roar like lions for liberty: Now they bleat like sheep for security Norman Vincent Peale http://www.hotmail.com ________________________________________________________________________________
Date: Jul 04, 2002
Thanks for the input Cash after testing the Navaid I believe you are correct. The Navaid lighting is not bright enough to bother me at night. Tom in Ohio ----- Original Message ----- From: <JusCash(at)aol.com> Subject: Re: RV-List: Navaid Dimmer > > Hi Tom, > I found that the Navaid lighting is not very bright and didn't need a dimmer. > As a matter of fact I installed a UMA light bezel on it to match the > lighting of the rest of my instruments. > Cash Copeland > RV6 Hayward, Ca > > > List, Has anyone who has installed a Navaid found a way to use a dimmer > > control for the LED Display? I have put a small dimmer control in the > > panal just for the trim, flap and S-Tec Alt. Hld. LED Readouts. > > Finishing up wiring this week then Fiberglas City on the RV6-A! > > > > Tom in Ohio > > ________________________________________________________________________________
Date: Jul 04, 2002
Subject: vsi problems
I have sent new vsi's back a couple of times for the same problem (imports). The problem was a leak in the glass to case interface. A case crack would do the same thing. If you have a vsi that you can reseal the glass from the front it is a minor repair. Total disassembly is a chore. You can test two ways: Use vasoline(sp) to make a light seal around the glass edge or remove instrument and lightly pressurize port so you can test with soapy water. Field repairs: Pro seal et al for external cracks etc. Other instruments can read errors with the same problem but they can be found with static systems checks (usually). The vsi has a calibrated leak IFIRC and case leaks are no-no. Remember to break the glass when your static ports get plugged by micro-daubbers. Experts jump in. Gary ________________________________________________________________________________
Date: Jul 04, 2002
Tom, the trim may be a little bright at night but It has a wire coming out of it that will dim it if you apply 12V + DC. I hooked this wire of mine to the Nav light lead and it dims when they come on. It is a preset value. not adjustable dimming. Works great. Phil Sisson Litchfield, IL Tom & Cathy Ervin wrote: > > Thanks for the input Cash after testing the Navaid I believe you are > correct. The Navaid lighting is not bright enough to bother me at night. > Tom in Ohio > ----- Original Message ----- > From: <JusCash(at)aol.com> > To: > Subject: Re: RV-List: Navaid Dimmer > > > > > Hi Tom, > > I found that the Navaid lighting is not very bright and didn't need a > dimmer. > > As a matter of fact I installed a UMA light bezel on it to match the > > lighting of the rest of my instruments. > > Cash Copeland > > RV6 Hayward, Ca > > > > > List, Has anyone who has installed a Navaid found a way to use a dimmer > > > control for the LED Display? I have put a small dimmer control in the > > > panal just for the trim, flap and S-Tec Alt. Hld. LED Readouts. > > > Finishing up wiring this week then Fiberglas City on the RV6-A! > > > > > > Tom in Ohio > > > > > ________________________________________________________________________________
Date: Jul 04, 2002
Subject: RV-6/6A fuselage jig for sale
Listers--We have a straight wooden RV6/6A fuselage jig available that has built two RV's. We paid $90 for it and now don't need it because we got a quick-build fuselage. Any takers? --LeRoy Johnston, 614-848-5863 (Columbus, Ohio). ________________________________________________________________________________
Subject: Closed end rivets
Date: Jul 04, 2002
Anything special about popping in these closed end rivets for the baffle and ribs? Getting ready to install the baffle, couldn't find anything in the archives. Dana Overall Richmond, KY http://rvflying.tripod.com http://www.hotmail.com ________________________________________________________________________________
Date: Jul 04, 2002
Subject: Re: Closed end rivets
Nothing special about the rivets, just have to make sure your rivet tool has a narrow enough nose to fit next to the Z-brackets. Make sure of that before you have the pro seal mixed up. Most pop rivet guns can be ground down enough to fit if it is to big. This is assuming your building a 9, or that the brackets are similar on the 7. Tom in Ohio, RV9A wings, tanks finished writes: > > Anything special about popping in these closed end rivets for the > baffle and > ribs? Getting ready to install the baffle, couldn't find anything > in the > archives. > > Dana Overall > Richmond, KY > http://rvflying.tripod.com > > > http://www.hotmail.com > > > > > messages. > > > > > > > ________________________________________________________________________________
Subject: Plexiglass
Date: Jul 04, 2002
I have seen lots of information on working with Plexiglas, but very little of it addresses the subject of how to finish the cut edges nice and smooth. Except I hear "don't use a torch". How do you guys recommend smoothing and finishing cut edges of the canopy? Gary RV-9A ________________________________________________________________________________
Subject: Re: Plexiglass
Date: Jul 04, 2002
Avery sells a scraping tool that will make the edges very nice and smooth. It works great. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Gary" <rv9er(at)3rivers.net> Subject: RV-List: Plexiglass > > I have seen lots of information on working with Plexiglas, but very > little of it addresses the subject of how to finish the cut edges nice > and smooth. Except I hear "don't use a torch". > > How do you guys recommend smoothing and finishing cut edges of the > canopy? > > Gary > RV-9A > > ________________________________________________________________________________
Date: Jul 04, 2002
In a message dated 7/4/02 8:14:31 PM Eastern Daylight Time, rv9er(at)3rivers.net writes: << I have seen lots of information on working with Plexiglas, but very little of it addresses the subject of how to finish the cut edges nice and smooth. Except I hear "don't use a torch". How do you guys recommend smoothing and finishing cut edges of the canopy? Gary RV-9A >> Avery and Cleveland both sell a scraping tool that works well. Another thing you can do is get a sanding block and smooth the edge progressively, beginning with say 150 grit, then progressing to somethign finer - at least 400 grit. Plan to spend a few hours on this mundane task. In the end, you want a rounded edge without any nicks that can be felt by running your finger down the edge. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Subject: 6A gear legs for sale
Date: Jul 04, 2002
Larry at TTD changed his plane from a -6A to a -6 after only flying it less than a year. He will sell all his extra parts at half of Van's new price, preferably all together. This includes the nose gear, wheel, pant, fairing, two main gear legs, leg sockets, engine mount and both the steps. There is absloutely nothing wrong with these parts. It would be a great deal if you haven't already ordered these parts for your plane yet. E-mail me off-line and I will get you in touch with Larry. Kevin Lane N3773(at)attbi.com ________________________________________________________________________________
Date: Jul 04, 2002
Tom Dana and Listers, When trying to reach into tight areas with pop rivets the tool is often frustratingly close to but not getting the job done. It just so happens that the tail end or shank of the rivets are more than long enough to reach the grippers inside most rivet pulling tools. Look at a pulled rivet "shank" to get an idea of the extra length. Using an approximately 5/8" long piece of small diameter thick wall Brass tubing (from the local hobby shop) and a narrow strip of .032 Alclad with a hole drilled at one end it is possible to reach deeper into tight areas. A simular extention could be made by center drilling a short length of steel rod, a bolt shank or what have you. This modification also effectively narrows the nose of the tool as well. The tube acts as an extension. The strip with the hole match drilled to the shank size of the rivet acts to replace the face of the tool mandrel. Slip the rivet shank into the drilled strip, then into the extension and then into the tool. Take aim you are now ready to shoot. {:-)! With the tool that I have here at hand I can extend the tool's reach by slightly more than 5/8", your mileage might vary. The drilled piece of .032 will also act to provide a temporary right sized mandrel face for that missing mandrel situation. Also if you find that the rivets you are pulling end up with a burr or a sharp edge around the hole in the center of the head drill another strip with a hole that matches the rivet shank size as close as is possible and the rivet heads will now be right. I have strips with various hole sizes on each end that I use every time I pull rivets. For the common sizes I have one strip drilled at both ends on a string attached to the rivet tool. Jim in Kelowna > > Nothing special about the rivets, just have to make sure your rivet > tool has a narrow enough nose to fit next to the Z-brackets. Make sure of > that before you have the pro seal mixed up. Most pop rivet guns can be > ground down enough to fit if it is to big. > This is assuming your building a 9, or that the brackets are similar on > the 7. > Tom in Ohio, > RV9A wings, tanks finished > > > writes: > > > > Anything special about popping in these closed end rivets for the > > baffle and > > ribs? Getting ready to install the baffle, couldn't find anything > > in the > > archives. > > > > Dana Overall > > Richmond, KY > > http://rvflying.tripod.com > > > > > > http://www.hotmail.com ________________________________________________________________________________
Date: Jul 04, 2002
Along this note, I've Frey Steel Jig with "Bird-cage" option (holds the front and rear spar dimentions very accurate) for the RV-6, in Nashville TN. Delivery possible. Price negotiable. Asking $600. Marty in Brentwood TN. Do no Archive -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of JhnstnIII(at)aol.com Subject: RV-List: RV-6/6A fuselage jig for sale Listers--We have a straight wooden RV6/6A fuselage jig available that has built two RV's. We paid $90 for it and now don't need it because we got a quick-build fuselage. Any takers? --LeRoy Johnston, 614-848-5863 (Columbus, Ohio). ________________________________________________________________________________
Date: Jul 04, 2002
Hi Gary, I used a file then sanded with a block using progressively finer grits, it took very little time. Some use a shaped scraper they buy or make from a gound hacksaw blade then sandpaper. Jim in Kelowna > > I have seen lots of information on working with Plexiglas, but very > little of it addresses the subject of how to finish the cut edges nice > and smooth. Except I hear "don't use a torch". > > How do you guys recommend smoothing and finishing cut edges of the > canopy? > > Gary > RV-9A > > ________________________________________________________________________________
Date: Jul 04, 2002
use a belt sander, works perfect and leaves a great finish. ________________________________________________________________________________
Subject: Plexiglas
Date: Jul 04, 2002
A 1" or 2" scotch bright wheel in an air grinder works well. Carl Froehlich RV-8A (Airworthiness certificate received last week) Vienna, VA -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Gary Subject: RV-List: Plexiglass I have seen lots of information on working with Plexiglas, but very little of it addresses the subject of how to finish the cut edges nice and smooth. Except I hear "don't use a torch". How do you guys recommend smoothing and finishing cut edges of the canopy? Gary RV-9A ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: RV-6/6A fuselage jig for sale
Date: Jul 04, 2002
I have a wooden jig that is available soon. It has been used to build three fuse, two being RV8s and now an RV7. I paid $90 which is what the value of the lumber is in it. I'll sell for $75 off if anyone is interested. Larry in Indiana ----- Original Message ----- From: "emrath" <emrath(at)comcast.net> Subject: RE: RV-List: RV-6/6A fuselage jig for sale > > Along this note, I've Frey Steel Jig with "Bird-cage" option (holds the > front and rear spar dimentions very accurate) for the RV-6, in Nashville > TN. Delivery possible. Price negotiable. Asking $600. > Marty in Brentwood TN. > Do no Archive > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of > JhnstnIII(at)aol.com > To: rv-list(at)matronics.com > Subject: RV-List: RV-6/6A fuselage jig for sale > > > Listers--We have a straight wooden RV6/6A fuselage jig available that > has > built two RV's. We paid $90 for it and now don't need it because we got > a > quick-build fuselage. Any takers? --LeRoy Johnston, 614-848-5863 > (Columbus, > Ohio). > > ________________________________________________________________________________
Subject: Re: 6A gear legs for sale
Date: Jul 04, 2002
Larry does have e-mail lleeman400(at)aol.com the legs have 187 hrs on them. ----- Original Message ----- From: "3 rotor" <rv8r300(at)attbi.com> Subject: RV-List: 6A gear legs for sale > > Larry at TTD changed his plane from a -6A to a -6 after only flying it less > than a year. He will sell all his extra parts at half of Van's new price, > preferably all together. This includes the nose gear, wheel, pant, fairing, > two main gear legs, leg sockets, engine mount and both the steps. There is > absloutely nothing wrong with these parts. It would be a great deal if you > haven't already ordered these parts for your plane yet. > E-mail me off-line and I will get you in touch with Larry. Kevin Lane > N3773(at)attbi.com > > ________________________________________________________________________________
Subject: pop riveting tips
Date: Jul 04, 2002
Tom Dana and Listers, When trying to reach into tight areas with pop rivets the tool is often frustratingly close to but not getting the job done. It just so happens that the tail end or shank of the rivets are more than long enough to reach the grippers inside most rivet pulling tools. Look at a pulled rivet "shank" to get an idea of the extra length. Using an approximately 5/8" long piece of small diameter thick wall Brass tubing (from the local hobby shop) and a narrow strip of .032 Alclad with a hole drilled at one end it is possible to reach deeper into tight areas. A simular extention could be made by center drilling a short length of steel rod, a bolt shank or what have you. This modification also effectively narrows the nose of the tool as well. The tube acts as an extension. The strip with the hole match drilled to the shank size of the rivet acts to replace the face of the tool mandrel. Slip the rivet shank into the drilled strip, then into the extension and then into the tool. Take aim you are now ready to shoot. {:-)! With the tool that I have here at hand I can extend the tool's reach by slightly more than 5/8", your mileage might vary. The drilled piece of .032 will also act to provide a temporary right sized mandrel face for that missing mandrel situation. Also if you find that the rivets you are pulling end up with a burr or a sharp edge around the hole in the center of the head, drill another strip with a hole that matches the rivet shank size as close as is possible and the rivet heads will now be right. I have strips with various hole sizes on each end that I use every time I pull rivets. For the common sizes I have one strip drilled at both ends on a string attached to the rivet tool. Jim in Kelowna ________________________________________________________________________________
Date: Jul 05, 2002
Subject: F-1 Rocket for Sale
F-1 ROCKET KIT, ENGINE, PROP,INSTRUMENTS FOR SALE I have for sale an F-1 Rocket kit, a completely overhauled IO-540 C4B5 engine (overhauled by Don George), and a new Hartzell 3-bladed prop. Instrumentation includes but not limited to: new Garmin 250XL radio, fuel guages, fuel pressure, EI volt/ammeter, manifold pressure guage, and more. Also included is a NavAid autopilot unit. Unit servo is installed and attached to the torgue tube. Wings are closed up and I have position and strobe lights as well as a tail white light. Also included is a F-1 Rocket tailgroup. Skeleton is built, ready to be skinned. This F-1 Rocket kit is extremely far along in its build. Electrical sub-panel complete including all circuit breakers installed. Interior Fuselage is complete. Fuel system complete with the exception of the installation of the electric fuel pump (included). Engine has the airflow performance kit, starter, alternator, Rose electronic ignition with the ring gear for high powered engines. Master solenoid, starter solenoid are included. Almost everything needed to complete rocket is included. Rocket could be flying in approx 5 months with some effort. Will consider the first $85,000. Please no tire kickers. Call 561-848-3418 or cell 561-373-3797. ________________________________________________________________________________
Subject: Thread locker and plexiglas
Date: Jul 05, 2002
I'm looking for a thread locker for use on the screws I'm using to mount my canopy - I know from experience and the archives that Loctite is a no-no around plastics. I saw a reference to a thread locker called Vibritite, which they claim is not anaerobic product and can be used on plastic. Do any of you have experience with plexi-compatible thread lockers? Thanks and best regards, Peter Blake RV6 tilt-up N899PB reserved ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Looking for Picture
Hi Listers: Up until my computer crashed a month ago whereafter I had to reload all my software, I was using a picture of a RV-8 as the background of my screen. I'd like to recover this picture but don't recall who's it was and a search in the archive has not surfaced this. Does anyone have a RV-8 painted yellow with black markings and can you mail or point me to a link of a picture of it? Marty in Brentwood, TN Do no Archive ________________________________________________________________________________
From: "Vincent Welch" <welchvincent(at)hotmail.com>
Subject: Manifold Pressure
Date: Jul 05, 2002
Hey Guys, I am just looking over my engine installation (IO-360)and trying to get a clear picture in my mind of what has to be accomplished and how to do it. Looking at the Lycoming manuals, there is a picture of the manifold pressure connection location. That location is currently covered with a plate that is held on with two screws. I am assuming that if I remove this plate that there will be a threaded hole underneath? Do I just use a normal pipe to tube fitting and run a 1/4" hose to a manifold pressure sensor mounted on the firewall? I have been looking and I don't find any information on mounting the fly wheel. Do I pull the plugs, rotate no. 1 to TDC, then mount the starter ring aligned with some mark? I am assuming that there is some procedure, otherwise how could the timing ever be checked with a timing light? Vince RV-8A ________________________________________________________________________________
Subject:
Date: Jul 05, 2002
Ref. Peter Blake on thread locker and Plexiglas. I used a small dab of ProSeal. We already have it so cost isn't a factor, it's plexiglas safe, and I can't think of any negatives except for mess but in such small quantities it is controllable. Dick DeCramer N500DD RV6 Slider wiring done, cowl next Northfield, MN ________________________________________________________________________________
Date: Jul 05, 2002
Paul, Obviously GPS isn't going to be obsolete any time soon but it was only a few years ago that my Garmin 55AVD looked like the best GPS ever - it couldn't get much better. Well, it did! It got a LOT better, and I have no reason to believe that in another 5 years it won't get that much better again. So it just could be that in a few years you might be stuck with a GPS that you'd like to replace but can't because you'd have to replace everything again. And, yes you can fly with 40 year old nav equipment but do you really want to? I don't. Dave Date: How soon do you supposed GPS is going to be obsolete? Most in the industry are saying that GPS is going to make the VOR obsolete. DARPA spent a fortune putting up those satellites, and it is slowly becoming the standard for civilian and military aviation, as well as oceanic navigation. I personally do not see GPS going away during the next 50 years. Granted there will be enhancements in GPS technology, but understand that we can fly airplanes that have 40 year old navigation equipment in them today. I bet that 40 years from now we will be able to fly with 40 year old GPS equipment as well. Paul Besing ________________________________________________________________________________
Date: Jul 05, 2002
Subject: T&C pinout
I have a TC-001 Turn and bank indicator. On the back it is marked 1-POS 2-GND 3-NOT USED. The pins of the connector are unmarked. Look at the instrument from the back (facing aft as it is mounted in the A/C) the pins are in a triangle, two long the top, and one on the bottom. Could someone tell me which pin is 1, 2, and three? I sure don't want to hook it up backward. Thanks, Gary Liming ________________________________________________________________________________
Date: Jul 05, 2002
Subject: ELT antenna mount where?
On the RV8A there seems to be no "good" spot to mount the ELT antenna. Under the bottom it probably would be ripped off in a crash landing and the slide back canopy uses up the top rear of the fueselage. Looking for ideas. Wayne Petrus RV8A finish kit-FF kit ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Re: Wing Root plumbing
heres dons e-mail, but he monitors this list but is too shy to post :-) twofeathersrv6(at)aol.com good luck scott tampa ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Re: Manifold Pressure
Vince, look closely at your flywheel. one hole is larger than the others. Almost un-noticable. This will only fit on in one way. When you get it on, the timing marks will be true. Let me know if you have a problem, I will get the book out.. Phil Sisson at Litchfield, IL Pitt's S1S N1GB, RV6 someday..... Vincent Welch wrote: > > Hey Guys, > > I am just looking over my engine installation (IO-360)and trying to get a > clear picture in my mind of what has to be accomplished and how to do it. > Looking at the Lycoming manuals, there is a picture of the manifold pressure > connection location. That location is currently covered with a plate that > is held on with two screws. I am assuming that if I remove this plate that > there will be a threaded hole underneath? Do I just use a normal pipe to > tube fitting and run a 1/4" hose to a manifold pressure sensor mounted on > the firewall? > > I have been looking and I don't find any information on mounting the fly > wheel. Do I pull the plugs, rotate no. 1 to TDC, then mount the starter > ring aligned with some mark? I am assuming that there is some procedure, > otherwise how could the timing ever be checked with a timing light? > > Vince > RV-8A > ________________________________________________________________________________
Date: Jul 05, 2002
Vince, also, I have a flywheel right here in the computer room. I started looking at it. Cant tell which hole is bigger. I started sticking fingers in the holes. One hole let my index finger go in to past first knuckle. Other 5 holes wouldnt let knuckle in... (Hillbilly micrometer) Phil at Litchfield, IL Vincent Welch wrote: > > Hey Guys, > > I am just looking over my engine installation (IO-360)and trying to get a > clear picture in my mind of what has to be accomplished and how to do it. > Looking at the Lycoming manuals, there is a picture of the manifold pressure > connection location. That location is currently covered with a plate that > is held on with two screws. I am assuming that if I remove this plate that > there will be a threaded hole underneath? Do I just use a normal pipe to > tube fitting and run a 1/4" hose to a manifold pressure sensor mounted on > the firewall? > > I have been looking and I don't find any information on mounting the fly > wheel. Do I pull the plugs, rotate no. 1 to TDC, then mount the starter > ring aligned with some mark? I am assuming that there is some procedure, > otherwise how could the timing ever be checked with a timing light? > > Vince > RV-8A > ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Re: VSI again
ok listers, i disconnected the vsi from the static system and allowed it to breath cockpit air. it is working perfectly now. what gives? the airspeed indicator seems to read about 10mph higher which i would expect because i didn't block off the tube that used to go to the VSI. any thoughts? scott tampa ________________________________________________________________________________
Subject: Pictures of the EFIS-D10 available
Date: Jul 05, 2002
Hello listers. We have posted several pictures of our EFIS-D10 on our website www.dynondevelopment.com. One of them is the unit installed in my (unfinished) panel; the other two were taken during a flight test in a C180. We will be at both Arlington and Oshkosh this summer. Stop by and say hello. Doug Medema Dynon Development RV-6A #21140 wiring up the panel ________________________________________________________________________________
Date: Jul 05, 2002
I am interested in the engine mount and nose gear leg. What engine is the mount built for? Thanks Rollie & Rod ________________________________________________________________________________
Date: Jul 05, 2002
My flywheel (from an O-320 via Aerosport Power) has the "0" (the numeral zero) stamped adjacent the hole which fits the crankshaft lug with the shoulder on it. Requires a careful look to see it. (My fingers all fit through all the holes - so the HB micro method will not work for me.) Jim Oke RV-6A CYWG ----- Original Message ----- From: "Phil Sisson" <sisson(at)mcleodusa.net> Subject: Re: RV-List: Manifold Pressure > > Vince, also, I have a flywheel right here in the computer room. I started > looking at it. Cant tell which hole is bigger. I started sticking fingers in the > holes. One hole let my index finger go in to past first knuckle. Other 5 holes > wouldnt let knuckle in... > (Hillbilly micrometer) > > Phil at Litchfield, IL > > Vincent Welch wrote: > > > > > Hey Guys, > > > > I am just looking over my engine installation (IO-360)and trying to get a > > clear picture in my mind of what has to be accomplished and how to do it. > > Looking at the Lycoming manuals, there is a picture of the manifold pressure > > connection location. That location is currently covered with a plate that > > is held on with two screws. I am assuming that if I remove this plate that > > there will be a threaded hole underneath? Do I just use a normal pipe to > > tube fitting and run a 1/4" hose to a manifold pressure sensor mounted on > > the firewall? > > > > I have been looking and I don't find any information on mounting the fly > > wheel. Do I pull the plugs, rotate no. 1 to TDC, then mount the starter > > ring aligned with some mark? I am assuming that there is some procedure, > > otherwise how could the timing ever be checked with a timing light? > > > > Vince > > RV-8A > > > > ________________________________________________________________________________
Subject: VSI again
Date: Jul 05, 2002
First guess is you're static ports are not quite in the right place on the fuselage. Try taping a small piece of .032 aluminum just in front of the ports and go flying again and see if that fixes it. Bob RV8-423 still working on fuselage. Will it ever end? -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of ABAYMAN(at)aol.com Subject: Re: RV-List: VSI again ok listers, i disconnected the vsi from the static system and allowed it to breath cockpit air. it is working perfectly now. what gives? the airspeed indicator seems to read about 10mph higher which i would expect because i didn't block off the tube that used to go to the VSI. any thoughts? scott tampa ________________________________________________________________________________
Date: Jul 05, 2002
I, like many others, mounted mine under the empennage fairing. The base of the antenna is mounted to the 810 bulkhead. I used a scrap piece of fiberglass to secure the end of the antenna from bouncing around. Carl Froehlich RV-8A (FSDO airworthiness certificate awarded last week) Vienna, VA -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dwpetrus(at)aol.com Subject: RV-List: ELT antenna mount where? On the RV8A there seems to be no "good" spot to mount the ELT antenna. Under the bottom it probably would be ripped off in a crash landing and the slide back canopy uses up the top rear of the fueselage. Looking for ideas. Wayne Petrus RV8A finish kit-FF kit ________________________________________________________________________________
Subject: moving wings
Date: Jul 05, 2002
I'm moving my RV6A project and am trying to decide how to package/protect the wings. I sent the note below to Van's and will see what they say, but are there others out there that have successfully moved RV wings by setting them in a trailer/truck leading edge down? How are the QB wings packaged for delivery? Thanks for your input, and here's the note with the details that I sent Van's asking about this: I'm prepping for the 3rd x-ctry u-haul move of my RV6A project due to another military move (this move completes first round trip for the tail section as I'm moving back into my house from 2 tours ago...). This is a ~2500 mile trip from Indiana to Washington state. My question is on moving the wings. Last time I moved them both horizontally w/ bottoms resting on foam padding. This time I'd like to stand them up vertical against the walls of the u-haul, resting them on the leading edges. Is there adequate strength in the leading edge to support the wing if I load and protect the wing as described below? Plan is to tape pillows along the length of leading edges (two body-length pillows per wing), then with padding on top & bottom sides of wing (thin foam b/w wing and trailer walls), set the wings leading edge down on 5" HD foam. The 5" foam would be 12 inch wide strips with a 5&1/2 foot length under the inboard 5&1/2 feet of the leading edge with another 15 inch long piece at the outboard end. If the leading edge down method is likely to damage the wings then I will find a way to do it horizontally again. Thanks for your help, Chris Hand RV-6A, #23559 ckhand(at)kiva.net ________________________________________________________________________________
Subject: VSI again
Date: Jul 05, 2002
That proves the static was plugged. Do not block off the line, that is your static from the cabin. I have an alternate static in my RV3 which selects cabin air when open and there is only a small difference between that and the one port static. Michel RV3 1100 hrs RV8 painting -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of ABAYMAN(at)aol.com Subject: Re: RV-List: VSI again ok listers, i disconnected the vsi from the static system and allowed it to breath cockpit air. it is working perfectly now. what gives? the airspeed indicator seems to read about 10mph higher which i would expect because i didn't block off the tube that used to go to the VSI. any thoughts? scott tampa ________________________________________________________________________________
Subject: Re: ELT antenna mount where?
Date: Jul 05, 2002
http://www.rv-8.com/Pictures/Mvc-447x.jpg ----- Original Message ----- From: <Dwpetrus(at)aol.com> Subject: RV-List: ELT antenna mount where? > > On the RV8A there seems to be no "good" spot to mount the ELT antenna. Under > the bottom it probably would be ripped off in a crash landing and the slide > back canopy uses up the top rear of the fueselage. Looking for ideas. > > Wayne Petrus > RV8A finish kit-FF kit ________________________________________________________________________________
Subject: Re: moving wings
Date: Jul 05, 2002
Chris, I too moved my wings, but I did it leading edge up. The following assumes that you have not cut off the 1" spar extension that protrudes from the tip rib. I made two stands to support the spar at both ends out of 2 x 6's and bolted them to the spar at inboard and outboard ends. On the outboard end I drilled four 3/16" holes for lag screws and fastened the 1" extension to the stand. I then joined the two stands at the bottom with a long 2 x 4 to stiffen the structure. This also works great if you're going to paint the wings off the fuselage. This is a very stable arrangement for traveling--I had the ailerons and flaps installed but if you do this you might want to put two 2 X 4's along the bottom to support the flaps and ailerons. Pat Hatch RV-4 RV-6 >From: "Chris & Kellie Hand" <ckhand(at)kiva.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: moving wings >Date: Fri, 5 Jul 2002 18:56:49 -0500 > > >I'm moving my RV6A project and am trying to decide how to package/protect >the wings. >I sent the note below to Van's and will see what they say, but are there >others out there that have successfully moved RV wings by setting them in a >trailer/truck leading edge down? >How are the QB wings packaged for delivery? > >Thanks for your input, and here's the note with the details that I sent >Van's asking about this: > >I'm prepping for the 3rd x-ctry u-haul move of my RV6A project due to >another military move (this move completes first round trip for the tail >section as I'm moving back into my house from 2 tours ago...). This is a >~2500 mile trip from Indiana to Washington state. > >My question is on moving the wings. Last time I moved them both >horizontally w/ bottoms resting on foam padding. This time I'd like to >stand them up vertical against the walls of the u-haul, resting them on the >leading edges. Is there adequate strength in the leading edge to support >the wing if I load and protect the wing as described below? > >Plan is to tape pillows along the length of leading edges (two body-length >pillows per wing), then with padding on top & bottom sides of wing (thin >foam b/w wing and trailer walls), set the wings leading edge down on 5" HD >foam. The 5" foam would be 12 inch wide strips with a 5&1/2 foot length >under the inboard 5&1/2 feet of the leading edge with another 15 inch long >piece at the outboard end. > >If the leading edge down method is likely to damage the wings then I will >find a way to do it horizontally again. >Thanks for your help, > >Chris Hand >RV-6A, #23559 >ckhand(at)kiva.net > > Pat Hatch RV-4, N17PH @ VRB, 700 hrs TT 0-320, Hartzell C/S RV-6, N44PH, Flying 0-360, Hartzell C/S MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide.aspx ________________________________________________________________________________
Date: Jul 06, 2002
Here's where I put mine: http://vondane.com/rv8a/wiring/panel27.jpg -Bill ----Original Message Follows---- From: Dwpetrus(at)aol.com Subject: RV-List: ELT antenna mount where? Date: Fri, 5 Jul 2002 13:50:52 EDT On the RV8A there seems to be no "good" spot to mount the ELT antenna. Under the bottom it probably would be ripped off in a crash landing and the slide back canopy uses up the top rear of the fueselage. Looking for ideas. Wayne Petrus RV8A finish kit-FF kit http://www.hotmail.com ________________________________________________________________________________
Date: Jul 05, 2002
Chris, I too moved my wings horizontally in a U-Crawl. I made crates out of 2 x 10s & Plywood. At each end the spar was anchored to the crate to keep them from sliding around. (Dado for the root end and blocks at the tip) Blankets above and below. The crates were sturdy enough to stack on top of each other with other plane parts, etc., on top. They made it from Tallahassee to The Big Crab Apple with no problem. Good Luck! Hal Benjamin RV-4, Flippin floppy fuselage parts around the jig Long Island New York ________________________________________________________________________________
Date: Jul 05, 2002
The 'T' stand has been describe before; however, here is what I did. I built a bottom frame of 2x4 that measured 4' by 6'. This frame was mounted on casters so I could move it easily. Along each 6' edge I erected a 1' fence and made a 3' fence down the center parallel to them. I then draped some carpet somewhat loosely over the fence crossmembers. This gave me two cradles. I set the wings into the cradles leading edge down and tilted toward the center fence. When it came time to move, the whole thing - cradle and wings - was moved out to the truck and the wings were temporarily placed on padding on the ground. The cradle was placed into the truck and 2x4 was nailed to the bed so that it blocked the casters from rolling or turning. The cradle was oriented so that the wings would run fore/aft and the wings would have room to be centered on the cradle. Once the wings were in place, cargo straps were run from side to side in the truck to prevent the wings from sliding in the cradle. I got my wings and most of my apartment furnishings in a 17' Ryder truck. It went from Ann Arbor to Chicago with the cab door open so I could see if anything moved; nothing did. Unfortunately the pictures I took did not come out. However, I will be moving again (this time a 28' truck from Chicago to Flagstaff) in a couple of weeks, using the same cradle. This time I hope to get better pictures; I ditched my old low-res camera for a megapixel camera. I'd snap a photo of the cradle now but the wings are in storage until I'm ready to load the truck, surrounded by boxes and such, so you'll have to be patient. Hope the description helped. Patrick Kelley - RV-6A project in transit -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Chris & Kellie Hand Subject: RV-List: moving wings I'm moving my RV6A project and am trying to decide how to package/protect the wings. I sent the note below to Van's and will see what they say, but are there others out there that have successfully moved RV wings by setting them in a trailer/truck leading edge down? How are the QB wings packaged for delivery? Thanks for your input, and here's the note with the details that I sent Van's asking about this: I'm prepping for the 3rd x-ctry u-haul move of my RV6A project due to another military move (this move completes first round trip for the tail section as I'm moving back into my house from 2 tours ago...). This is a ~2500 mile trip from Indiana to Washington state. My question is on moving the wings. Last time I moved them both horizontally w/ bottoms resting on foam padding. This time I'd like to stand them up vertical against the walls of the u-haul, resting them on the leading edges. Is there adequate strength in the leading edge to support the wing if I load and protect the wing as described below? Plan is to tape pillows along the length of leading edges (two body-length pillows per wing), then with padding on top & bottom sides of wing (thin foam b/w wing and trailer walls), set the wings leading edge down on 5" HD foam. The 5" foam would be 12 inch wide strips with a 5&1/2 foot length under the inboard 5&1/2 feet of the leading edge with another 15 inch long piece at the outboard end. If the leading edge down method is likely to damage the wings then I will find a way to do it horizontally again. Thanks for your help, Chris Hand RV-6A, #23559 ckhand(at)kiva.net ________________________________________________________________________________
Date: Jul 05, 2002
Van's guys packed my QBs partially complete wings on moving pads, leading edge down and strapped to the side of the UHaul truck. The wings are sturdy. And, it flies beautifully! K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Subject: confirm specs
Date: Jul 05, 2002
I flew to Camarillo last weekend. For the first time I cruised at 16,500' with oxygen. I have a new fuel flow meter that I am still calibrating, although it seems to be right on as far as fuel remaining. I was able to get at 2300 rpm, 150kts, 4.3 gph and at 2200rpm, 140kts, 3.8 gph! I have a 160hp with sensenich fp prop, jeff rose ignition on the right mag, on my -6A. Do these figures match others with the same equipment? It works out to 36 nm per gallon max. which is almost double the 20 mpg I get at 1500'. With my ferry tank (18.4 gals) behind me I was able to fly from Salem OR to Camarillo CA and back, thus able to pay $1.95/gal vs $2.50 at Camarillo! Kevin Portland OR ________________________________________________________________________________
Date: Jul 05, 2002
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Re: T&C pinout
Gary Liming wrote: > > I have a TC-001 Turn and bank indicator. On the back it is marked > 1-POS 2-GND 3-NOT USED. > > The pins of the connector are unmarked. Look at the instrument from the > back (facing aft as it is mounted in the A/C) the pins are in a triangle, > two long the top, and one on the bottom. Could someone tell me which pin > is 1, 2, and three? I sure don't want to hook it up backward. > > Thanks, > > Gary Liming > Gary; If you look VERY closely at the area at the base of the pins through a magnifying glass you may find that, in fact, the pins are labelled. In most cases these connectors have identifying legends moulded in or etched adjacent to each pin. Very tiny sometimes, and very hard to read, but usually present. Good luck, -- Bob McC ________________________________________________________________________________
Subject: ELT Antenna Location
Date: Jul 05, 2002
The New RV-List Archive Web Search Engine ------- Here is a copy of a message from the archives that speaks to where the ELT antenna must be located. .... that TSO on the new ELT requirements is TSO C-91a. Among other things it tightened the requirement for activation at lower G-forces, called for a remote annunciator, and an EXTERNAL antenna. As I recall it, you could, as you indicated you are able to, continue to use the older version made under TSO C-91 until such time as it fails. Then a replacement must meet the new requirements of TSO C-91Aa. =0C End Msg: #79 --- -- Please support this service by making your Contribution today! -- --- ------- Return to the Matronics Email List Homepages ________________________________________________________________________________
Date: Jul 05, 2002
Subject: VSI again
There has to something else going on here. Problems at the static port could lead to errors in the sensed static pressure, which would lead to errors in the airspeed indication and altimeter. But, in level flight at a constant airspeed the sensed static pressure, although in error, would be constant, so the VSI would be constant. So, there is definitely something else going on, but darned if I know what. Other listers reported similar problems caused by a defective VSI. It might be interesting to try installing a VSI that works properly in another aircraft. That would help focus the search for the problem. Kevin Horton > > First guess is you're static ports are not quite in the right place on the >fuselage. Try taping a small piece of .032 aluminum just in front of the >ports and go flying again and see if that fixes it. > > Bob RV8-423 still working on fuselage. Will it ever end? > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of ABAYMAN(at)aol.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: VSI again > > >ok listers, >i disconnected the vsi from the static system and allowed it to breath >cockpit air. it is working perfectly now. what gives? the airspeed indicator >seems to read about 10mph higher which i would expect because i didn't block >off the tube that used to go to the VSI. >any thoughts? >scott >tampa > ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Four New Email Lists At Matronics!!
Dear Listers, I've just added four new email Lists to the current lineup at Matronics. These new lists include: KRNet: krnet-List(at)matronics.com The RANS KR1 and KR2 Series Cub: cub-List(at)matronics.com The Piper J-3 Cub RV10: rv10-List(at)matronics.com The New 4-place RV from Van's! Europa: europa(at)matronics.com The Slick European Composite All the usual features are available with the new Lists including the search engine, archive download, 7-day List browse, and PhotoShare! To sign up for any or all of the new lists, please go to the List Subscription page and put in your email address and select the Lists of your choice. The URL for the Subscription page is: http://www.matronics.com/subscibe Don't forget that its your posts that generate traffic on the respective Lists! Post an introduction and a description of your project or dreams! Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jul 05, 2002
I still think it's a leaking case or glass, as you no longer have the differential between cabin and static port pressures. Finn ABAYMAN(at)aol.com wrote: > > ok listers, > i disconnected the vsi from the static system and allowed it to breath > cockpit air. it is working perfectly now. what gives? the airspeed indicator > seems to read about 10mph higher which i would expect because i didn't block > off the tube that used to go to the VSI. > any thoughts? > scott > tampa ------------------------------------------- Introducing NetZero Long Distance Unlimited Long Distance only $29.95/ month! Sign Up Today! www.netzerolongdistance.com ________________________________________________________________________________
Date: Jul 05, 2002
I hung mine from the rails on the walls. That of course requires the wing tips still be off. Finn Chris & Kellie Hand wrote: > > I'm moving my RV6A project and am trying to decide how to package/protect > the wings. > I sent the note below to Van's and will see what they say, but are there > others out there that have successfully moved RV wings by setting them in a > trailer/truck leading edge down? > How are the QB wings packaged for delivery? > > Thanks for your input, and here's the note with the details that I sent > Van's asking about this: > > I'm prepping for the 3rd x-ctry u-haul move of my RV6A project due to > another military move (this move completes first round trip for the tail > section as I'm moving back into my house from 2 tours ago...). This is a > ~2500 mile trip from Indiana to Washington state. > > My question is on moving the wings. Last time I moved them both > horizontally w/ bottoms resting on foam padding. This time I'd like to > stand them up vertical against the walls of the u-haul, resting them on the > leading edges. Is there adequate strength in the leading edge to support > the wing if I load and protect the wing as described below? > > Plan is to tape pillows along the length of leading edges (two body-length > pillows per wing), then with padding on top & bottom sides of wing (thin > foam b/w wing and trailer walls), set the wings leading edge down on 5" HD > foam. The 5" foam would be 12 inch wide strips with a 5&1/2 foot length > under the inboard 5&1/2 feet of the leading edge with another 15 inch long > piece at the outboard end. > > If the leading edge down method is likely to damage the wings then I will > find a way to do it horizontally again. > Thanks for your help, > > Chris Hand > RV-6A, #23559 > ckhand(at)kiva.net ------------------------------------------- Introducing NetZero Long Distance Unlimited Long Distance only $29.95/ month! Sign Up Today! www.netzerolongdistance.com ________________________________________________________________________________
Date: Jul 05, 2002
Subject: [With Good URL This Time!] Four New Email Lists At Matronics!!
[Typo in the subscribe page URL last time - SORRY! -Matt] Dear Listers, I've just added four new email Lists to the current lineup at Matronics. These new lists include: KRNet: krnet-List(at)matronics.com The RANS KR1 and KR2 Series Cub: cub-List(at)matronics.com The Piper J-3 Cub RV10: rv10-List(at)matronics.com The New 4-place RV from Van's! Europa: europa(at)matronics.com The Slick European Composite All the usual features are available with the new Lists including the search engine, archive download, 7-day List browse, and PhotoShare! To sign up for any or all of the new lists, please go to the List Subscription page and put in your email address and select the Lists of your choice. The URL for the Subscription page is: http://www.matronics.com/subscribe Don't forget that its your posts that generate traffic on the respective Lists! Post an introduction and a description of your project or dreams! Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Re: ELT Antenna Location
Date: Jul 05, 2002
As much as I hate reading legalese, I wanted to get all the details on this issue. 1) TSO-C91a: http://av-info.faa.gov/tso/Tsocur/C91a.doc I could find positively no requirement for an antenna to be externally mounted. All I see is that each component of the system must be marked with the applicable TSO number. This TSO seems to be strictly about markings. 2) FAR Part 91.207 where you can see that you can't *newly* install a TSO-C91 ELT: http://www.rvproject.com/fars.jsp?part=91&search=c91#match1 It does mention that every 12 calendar months, part of the required inspection is to inspect for "proper installation." Now, I don't know if that means adherence to the letter to the product's installation instructions, or whether "proper" is defined in some other place I haven't seen yet...info on this would be helpful. 3) Here's a decent article on requirements and operation of ELTs: http://www.avionicswest.com/articles/eltupdate.htm This article mentions the differences between TSO-C91 and TSO-C91a ELTs...and it does mention: - C91a ELTs have "a beefier mounting rack" - C91a ELTs have better transmitters to prevent drifting off frequency - C91a ELTs have a redesigned inertia (G) switch to lower false alarms - C91a ELTs require a cabin-mounted annunciator panel However...I can't figure out where this article gets its information. From the manufacturers? I can't find any written regulations on this stuff. I did my best to find a copy of the original TSO-C91 but couldn't find it...perhaps the information is in there? Anyway, maybe a call to the FSDO is in order? I'm going to continue to assume that mounting an ELT antenna internally, while possibly not optimal, is legal...at least until I hear or read otherwise from a qualified source. )_( Dan dan @ rvproject . com http://www.rvproject.com ----- Original Message ----- From: "John" <n1cxo320(at)salidaco.com> Subject: RV-List: ELT Antenna Location > > The New RV-List Archive Web Search Engine > > > ------- > > > Here is a copy of a message from the archives that speaks to where the > ELT antenna must be located. > > .... that TSO on the new ELT requirements is TSO C-91a. Among other > things it > tightened the requirement for activation at lower G-forces, called for a > remote annunciator, and an EXTERNAL antenna. As I recall it, you could, > as > you indicated you are able to, continue to use the older version made > under > TSO C-91 until such time as it fails. Then a replacement must meet the > new > requirements of TSO C-91Aa. > > > =0C > End Msg: #79 > > > --- > > -- Please support this service by making your Contribution today! -- > --- > > > ------- > Return to the Matronics Email List Homepages > > ________________________________________________________________________________
Date: Jul 05, 2002
In a message dated 7/5/2002 9:39:40 AM Pacific Daylight Time, gary(at)liming.org writes: > I have a TC-001 Turn and bank indicator. On the back it is marked > 1-POS 2-GND 3-NOT USED. > > The pins of the connector are unmarked. Look at the instrument from the > back (facing aft as it is mounted in the A/C) the pins are in a triangle, > two long the top, and one on the bottom. Could someone tell me which pin > is 1, 2, and three? I sure don't want to hook it up backward. > Gary- It's actually stranger yet. Both the TC connector and the mate are MIL-C-5015 series connectors used since Christ was a corporal and that insert arrangement has contacts designated A, B and C. All military connectors are required to have non-ambiguous contact markings. For this specification, these markings should be molded into the thermoset plastic (DAP) dielectric of the connector on both the front and back faces as raised characters. A is +, B is - and C is unused. Look under magnification and you should be able to make them out. -GV (RV-6A N1GV 533hrs) ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Re: Thread locker and plexiglas
In a message dated 7/5/2002 6:49:54 AM Pacific Daylight Time, pblake(at)epix.net writes: > I'm looking for a thread locker for use on the screws I'm using to mount my > canopy - I know from experience and the archives that Loctite is a no-no > around plastics. I saw a reference to a thread locker called Vibritite, > which they claim is not anaerobic product and can be used on plastic. Do > any of you have experience with plexi-compatible thread lockers? Vibra-Tite does work well in some applications . It is a red/orange fluorescent dyed acrylic resin with I believe a Ketone solvent in it. Contrary to the Loctite threadlockers that are applied wet, assembled and then cure in the absence of oxygen, Vibra-Tite is applied to the fastener and allowed to flash off the solvent, then assembled. It probably would work very well on the canopy but not in a high heat area. It is available from fastener supply houses such as Olander. -GV (RV-6A N1GV 532hrs) ________________________________________________________________________________
Date: Jul 06, 2002
> >As much as I hate reading legalese, I wanted to get all the details on this >issue. > >1) TSO-C91a: > > http://av-info.faa.gov/tso/Tsocur/C91a.doc > >I could find positively no requirement for an antenna to be externally >mounted. All I see is that each component of the system must be marked with >the applicable TSO number. This TSO seems to be strictly about markings. > The TSO simply references an RTCA document which contains most of the requirements. "New models of emergency locator transmitter equipment that are to be so identified and that are manufactured on or after the date of this TSO must meet the standards set forth in Radio Technical Commission for Aeronautics (RTCA) Document No. DO-183, "Minimum Operational Performance Standards for Emergency Locator Transmitters; Automatic Fixed - ELT (AF), Automatic Port able - ELT (AP), Automatic Deployable - ELT (AD), Survival - ELT (S); Operating on 121.5 and 243.0 Megahertz," Section 2.0, dated May 13, 1983." So, to get the complete story we need to find RTCA DO-183. RTCA sells their documents, so I doubt we'll find a copy on the web. -- Kevin Horton RV-8 (installing engine & electrics) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
Date: Jul 06, 2002
You got a U-Haul truck to fly ? Van's guys packed my QBs partially complete wings on moving pads, leading edge down and strapped to the side of the UHaul truck. The wings are sturdy. And, it flies beautifully! K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) do not achhive. ________________________________________________________________________________
Date: Jul 06, 2002
Subject: smoke
I am contemplating adding a smoke system to my RV6.Question? What flow of oil is needed to produce a good smoke trail? I also am thinking of installing my front top foreword skin with riv-nuts to have access to stuff under panel. Has anyone been-there-done-that? Sincerely: Doyal ________________________________________________________________________________
Subject: Pictures of my paint job
Date: Jul 06, 2002
I finally got a chance to post the pictures of the paint work on my RV-8. Comments are welcome. Thanks, Jim Jim Cimino RV-8 sn 80039 N7TL 50+ Hrs. http://www.geocities.com/jcimino.geo/ (570)842-4057 ________________________________________________________________________________
Date: Jul 06, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: Re: smoke
doyal plute wrote: > > > I am contemplating adding a smoke system to my RV6.Question? What flow > of oil is needed to produce a good smoke trail? > I also am thinking of installing my front top foreword skin with > riv-nuts to have access to stuff under panel. Has anyone > been-there-done-that? > Sincerely: > Doyal > A friend's air show Swift had a 337 approved system consisting of a 5 gal metal outboard motor fuel tank & Holly electric fuel pump strapped behind the seats feeding a nozzle welded into the exhaust. For a far less expensive approach, see http://www.kcdawnpatrol.org/smoke.htm The rest of this site is pretty interesting as well, if you aren't familiar with the Dawn Patrol guys. Charlie ________________________________________________________________________________
Subject: Leading Edge Skins
Date: Jul 06, 2002
Needs some opinions :> ) I'm the third owner of my RV-4 wing kit. I pulled out the leading edge skins and found a slight wrinkle in both of the skins and as always, on the top surface of both. These are very slight but noticeable. Anybody have any good ideas on how to remove these, if possible? These skins are probably about $100 a piece and I hate to spend the money if I don't have to. Thanks in advance, Ross Scroggs Conyers, Ga. RV-4 #3911 ________________________________________________________________________________
Date: Jul 06, 2002
writes: > > > I am assuming that if I remove this plate that there will be a threaded hole underneath? Do I just use a normal > pipe to tube fitting and run a 1/4" hose to a manifold pressure sensor > mounted on the firewall? *************************************************** I think the MP is taken off the number 3 jug . I put my transducer from Van's on the 668 sub panel. It goes full scale when I key the mic. one of these days I plain to fix it. ************************************************** > I have been looking and I don't find any information on mounting the > fly wheel. Do I pull the plugs, rotate no. 1 to TDC, then mount the > starter ring aligned with some mark? I am assuming that there is some > procedure, otherwise how could the timing ever be checked with a timing light? > > Vince > RV-8A ************************************************* the number one crankpin on the crankshaft lines up with the stepped bushing in the flange. so at TDC for #1, the larger hole in the flywheel will be at your 9 0'clock facing the engine. Lycomings vary from none( I have heard) to two ways of marking the flywhell. On the rear of the flywheel at the top that lines up with the case split and on the front that lines up with a little hole on the starter about you 4 o'clock. Mine has bolth & show the 0 & 25 degrees. Check your number of teeth that needs to go with the gear on the starter. When you install the mags, bring her up to the 25 degree advance mark. Then the impluse will retard the timing to zero for starting & let it run at approximently 25 degrees BTDC. Don Jordan - N6DJ - RV6A Arlington, Tx ******************************* ________________________________________________________________________________
Subject: VSI
Date: Jul 06, 2002
Scott, this may be late as I'm catching up on the list but the VSI works upon a calibrated leak from static to changing static inside the unit. If that leak is plugged inside you'ld get that response. If it was hooked to Pitot you get vsi changes with airspeed changes. If static was plugged you'ld get zero vsi, fixed alt and asi would vary with altitude as well as airspeed. the cracked case could do it as well as the pressure in a RV cockpit is not very stable. W ________________________________________________________________________________
Date: Jul 06, 2002
Subject: Re: VSI
wheeler i verified today that the static line is connected correctly, i blew and sucked though both ports, no restriction either way. blocked off on side and blew through it good pressure to the gauges. but it shows zero on the ground and 1000 ft decent while flying. with it diconnected, it works fine, but the other static/pitot gauges are off since i didn't block the vsi connector. i'm at a lost. scott tampa flying ________________________________________________________________________________
Subject: Re: VSI
Date: Jul 06, 2002
> > wheeler > i verified today that the static line is connected correctly, i blew and > sucked though both ports, no restriction either way. blocked off on side and > blew through it good pressure to the gauges. but it shows zero on the ground > and 1000 ft decent while flying. with it diconnected, it works fine, but the > other static/pitot gauges are off since i didn't block the vsi connector. i'm > at a lost. > scott > tampa > flying > Scott, I had the same symptoms with my VSI when I first flew. I also messed around with static system only to find out (finally) that the VSI case was cracked. If you have checked everything else a cracked case may be the problem. Ed Anderson Matthews, NC ________________________________________________________________________________
Subject: VSI
Date: Jul 06, 2002
Scott, your case is cracked or leaking. By disconnecting from Static you are no longer measuring the difference between static and cabin, which is what you measure when the case leaks. VSI's use only static measured against "slow" static through a very small calibrated leak. Your case leak is causing it to read cabin on one side and static on the other. By disconnecting it you are reading cabin against "semi slow" cabin and you may have also possibly affected ASI and Alt if you didn't plug the static line from the VSI. To test this do a static system test on the VSI. Use a long piece of clear hose with a two or three foot low spot in it. Fill the low spot part way with water, but not enough to go into the VSI, just enough to make a manometer. Hook one end up to the VSI and when you lift the open end of the hose, pressure should build as the water tries to move down the hose. The VSI should read a rise then return to 0 and the water should NOT reach an equal level. If the case is leaking the water will equalize. Again use a long enough hose to not get any water in the VSI. Using the lips blowing on the inlet technique can break its little heart, so avoid it. w ________________________________________________________________________________
Subject: Re: Carb Heat/Alternate Source....
Date: Jul 06, 2002
Kurt... I bought a carb heat muff from Rick Robbins... You can contact Rick at 303-422-9389... http://vondane.com/rv8a/engine/finish118.jpg http://vondane.com/rv8a/engine/finish117.jpg -Bill ----Original Message Follows---- From: KAKlewin(at)aol.com Subject: RV-List: Carb Heat/Alternate Source.... Date: Sat, 06 Jul 2002 14:00:55 -0400 Im wondering if anyone has used a carb heat air set up other than the small alum. cylinder attachment and short 2" hose (sold by vans) going to the FAB? Mainly want to get as much heat in there as possible given the increasing number of carb heat related eng. problems in recent years. I dont have the eng yet (Planning on O-360-A1A)..but would you be able to install a second heat muff (robbins) on the opposite exhaust from the one for the cabin heat, and route the scatt tube to the FAB? Just wondered if anyone has installed a carb heat system this way or knows if this might be a viable option...thanks... Kurt OKC, OK RV6A Finishing... http://www.hotmail.com ________________________________________________________________________________
Date: Jul 06, 2002
Could you post it to the photoshare? You are over dl quota so it is not possible to view your url. Patrick Kelley - RV-6A project in transit -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Cimino Subject: RV-List: Pictures of my paint job I finally got a chance to post the pictures of the paint work on my RV-8. Comments are welcome. Thanks, Jim Jim Cimino RV-8 sn 80039 N7TL 50+ Hrs. http://www.geocities.com/jcimino.geo/ (570)842-4057 ________________________________________________________________________________
Date: Jul 06, 2002
Scott-- Your VSI works "OK" when the static input is open to cockpit air but reads 1,000 ft descent when connected to the static line and flying S&L? The airspeed indicator and altimeter are working correctly, as far as you can tell? To get a negative VSI indication, the static system has to be showing an increase in pressure at the static port(s) or in the static line. If you're flying S&L the VSI should read "0". If the VSI case is cracked, there will be no pressure differential and the VSI will also read "0" or with a slight lag depending on the size of the leak. If you're getting leakage from the pitot system into the static lines then your VSI will show negative when the plane is in motion, unless your rate of climb is fast enough to offset the pitot leakage. Have you tried gently sucking/blowing on the static ports to see how all three static instruments respond and then gently blow into the pitot tube to see if the VSI or altimeter reacts along with the airspeed indicator? If you suck on a static port (with the other one taped over) the VSI should show a positive trend and the altimeter will show an increase. If you then block the static port with your tongue (see Vince Frazier's web site for a humorous account of this procedure) the VSI will go back to "0" (the VSI has a calibrated restrictor "leak" inside the case which will gradually equalize pressure if there is no pressure change from the static source--it will happen very fast if there is a leak in the case of the VSI) and the altimeter should hold its position for at least a minute. Now set the altimeter to some positive value with the Kollsman knob and gently blow into the port. The VSI should show negative and the altimeter will decrease. The airspeed indicator shold not move if you're either sucking or blowing. Now gently blow into the pitot tube. The airspeed indicator should increase but the VSI and altimeter should stay put. If the VSI or the altimeter respond to the pitot "blow" then you've got leakage. This assumes that the VSI, itself, is working correctly as manufactured. Hope this helps. Gotta get yo' a** flyin', gumbo boy. Boyd. ABAYMAN(at)aol.com wrote: > > ok listers, > i disconnected the vsi from the static system and allowed it to breath > cockpit air. it is working perfectly now. what gives? the airspeed indicator > seems to read about 10mph higher which i would expect because i didn't block > off the tube that used to go to the VSI. > any thoughts? > scott > tampa ________________________________________________________________________________
Subject: Re: Pictures of my paint job
Date: Jul 06, 2002
Pat, I got the problem at my web site fixed...you should not have any problem getting in now. Jim ----- Original Message ----- From: "Patrick Kelley" <webmaster(at)flion.com> Subject: RE: RV-List: Pictures of my paint job > > Could you post it to the photoshare? You are over dl quota so it is not > possible to view your url. > > Patrick Kelley - RV-6A project in transit > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Cimino > To: RV-LIST > Subject: RV-List: Pictures of my paint job > > > I finally got a chance to post the pictures of the paint work on my > RV-8. Comments are welcome. > Thanks, > Jim > > Jim Cimino > RV-8 sn 80039 N7TL 50+ Hrs. > http://www.geocities.com/jcimino.geo/ > (570)842-4057 > > ________________________________________________________________________________
Date: Jul 06, 2002
In a message dated 7/6/2002 11:06:28 AM Pacific Daylight Time, KAKlewin(at)aol.com writes: > I'm wondering if anyone has used a carb heat air set up other than the small > alum. cylinder attachment and short 2" hose (sold by vans) going to the > FAB? Mainly want to get as much heat in there as possible given the > increasing number of carb heat related eng. problems in recent years. IMO, the 2" hose is probably okay, but the small muff is somewhat inadequate to keep you well out of trouble. I had Rick Robbins make me an 8" long muff for the front crossover pipe. I draw the incoming air from the warmer underside engine cooling air and it seems to work fairly well with an engine rpm drop comparable to the mag check with full carb heat application at runup. I can't give you any real world numbers at this moment, but I think it is double the capacity of the Van's version. I do have a CAT gauge and have never seen the temp get below 5 deg C in the presence of moisture. Negative only in very dry winter air. Both cases no ice. -GV (RV-6A N1GV 532hrs) ________________________________________________________________________________
Subject: Re: smoke
Date: Jul 06, 2002
Typical airshow smoke systems pump 1/2 to 1 gallon/ minute. It makes a huge mess of your airplane. Oil and sooty residue. Several different systems will work, many use a boat gas tank, an RV pump, or an electric fuel pump( not a clicker, a real rotary fuel pump) some use RV water pumps but the seals tend to not like oil and fail. If you do not put a solenoid up near the exhaust manifold you will not get good clean cut offs when you stop smoking. and you can get exhaust in the hose. Put the nozzle about where you would install an EGT probe, (couple inches from the flange. Ask any performer, Smoke systems are a perpetual pain in the butt. BTW, did I mention I sell smoke oil???? Tailwinds, Doug Rozendaal Pink Panther (RV-4) for sale.... ----- Original Message ----- From: "doyal plute" <dplute(at)onemain.com> Subject: RV-List: smoke > > I am contemplating adding a smoke system to my RV6.Question? What flow > of oil is needed to produce a good smoke trail? > I also am thinking of installing my front top foreword skin with > riv-nuts to have access to stuff under panel. Has anyone > been-there-done-that? > Sincerely: > Doyal > > ________________________________________________________________________________
Date: Jul 06, 2002
Subject: spreadsheet to convert airspeeds
Someone asked awhile back if there was a spreadsheet to convert between IAS and TAS. It seemed that there wasn't one online, so I finally sat down and cranked one out. It is an Excel spreadsheet, zipped, found at: http://members.rogers.com/khorton/rvlinks/asi.zip It was produced fairly quickly, so I'm looking for any comments on format, etc. Kevin Horton ________________________________________________________________________________
Date: Jul 07, 2002
Subject: VideoCam'sInCockpit
Has anyone done this ? I want the real-time video to be available to both pilot and passenger in Harmon Rocket (tandem) with selectable views. Probably a LCD in front and back. Would involve mounting some lipstick cameras here and there on the airframe, inside and out. Views I'm interested in are 1) taxi 2) wide angle shot forward from tail 3) passenger monitor 4) instrument panel view If a cam had joystick and wiggle room like an automobile mirror, the back-seater could entertain onself with views every which way. Where does one buy this stuff ? Little 12v cameras ? Must be a catalog. I've seen it on display in Singapore...in fact bought a little 12v 4x4 LCD there and ran it off my JVC video cam. Etc. John Meyers Rocket 1/2 done, Golden, CO ________________________________________________________________________________
Date: Jul 06, 2002
Subject: Extra Seat To Oshkosh
I have an extra seat in my Seneca for the trip to Oshkosh. I am based in Aurora, OR and am looking for someone to help with some conversation and company. RV-8A Finish Kit Richard Rauch rbr(at)apcon.com ________________________________________________________________________________
Subject: smoke
Date: Jul 06, 2002
I would not attempt to make that forward skin removable for several reasons: 1) with my engine hung, without the top skin on and with the side skins clecoed to the upper longeron, I saw considerable deflection and bowing of the side skins when the clecos were removed. I even had some clecos pop off the longeron. That tells me there is a significant static load (let alone flight loads) that will be born by the rivets holding that skin, i.e. it's a significant structural member. 2) the skin goes under the windshield complicating removal. 3) assuming you meant nut plates instead of the pop-rivet type rivnuts (a no-no for structure) you would need to mount them on the longeron. That would entail 2 add'l rivet holes for each screw and an enlarged hole for the screw vs rivet. That's a lot of additional holes in the primary structural member of the aircraft and would make me real nervous. 4) I think it would be difficult to seal that skin-firewall-cowling joint and make it removable. That said, you could build access panels in the skin between the firewall and subpanel. With appropriate doublers and structural fasteners you could preserve the strength. But it's probably more useful to just make the panel and radio stack removable instead. Regards, Greg Young - Houston (DWH) RV-6 N6GY - project Phoenix Navion N5221K - a size XXL RV-6A > > I am contemplating adding a smoke system to my RV6.Question? What flow > of oil is needed to produce a good smoke trail? > I also am thinking of installing my front top foreword skin with > riv-nuts to have access to stuff under panel. Has anyone > been-there-done-that? > Sincerely: > Doyal > ________________________________________________________________________________
Date: Jul 06, 2002
Subject: Re: VideoCam'sInCockpit
> >Has anyone done this ? > >I want the real-time video to be available to both pilot and passenger in >Harmon Rocket (tandem) with selectable views. Probably a LCD in front and >back. Would involve mounting some lipstick cameras here and there on the >airframe, inside and out. Views I'm interested in are 1) taxi seeing immediately in front of nose> 2) wide angle shot forward from tail 3) >passenger monitor 4) instrument panel view rear-seater can look at something up there> > >If a cam had joystick and wiggle room like an automobile mirror, the >back-seater could entertain onself with views every which way. > >Where does one buy this stuff ? Little 12v cameras ? Must be a catalog. >I've seen it on display in Singapore...in fact bought a little 12v 4x4 LCD >there and ran it off my JVC video cam. Etc. > >John Meyers Rocket 1/2 done, Golden, CO Probably start looking here http://www.nutsvolts.com/ I had a subscription to this for several years. Had lots of small video stuff advertised. Mike Mike McGee, RV-4 N996RV, O320-E2G, Hillsboro, OR 13B in gestation mode ________________________________________________________________________________
Date: Jul 07, 2002
Michael McGee wrote: > >I want the real-time video to be available to both pilot and passenger in > >Harmon Rocket (tandem) with selectable views. > >Where does one buy this stuff ? Michael: Try www.mcmelectronics.com. They sell many different models. I bought a $50 monochrome camera there which I have found to be very useful as a building aid. I use it to inspect the shop heads on rivets in otherwise unaccessable places, guide a long drill bit when back drilling the wing root fairings, etc. I thought about mounting a small camera looking forward and down so I could see if another plane was below me on short final. But it's hard to find a good display that's also very compact and visible in daylight. I guess there are some, but they're expensive. -- Tom Sargent. ________________________________________________________________________________
Date: Jul 07, 2002
If you are interested in a little experimentation you may be able to cobble something together with the X-Com systems. They have 12 volt remote cameras etc. Display could be just about any type of video monitor. Ed C-140 flying RV-8 hopeful ________________________________________________________________________________
Subject: RV-6 Speed Question
Date: Jul 07, 2002
Looking for some comparisons to any of you who may have a similar RV-6 configuration. I believe mine is slow(er) by RV standards. Here's relevant data: RV-6, 967 lbs empty (no fuel, no oil) Lycoming O-320-A1A, 150hp, 670 hours SMOH Aymar Demuth wood prop Old-style wheel pants (not the newer pressure recovery type) Aluminium gear leg fairings No wheel pant/gear leg or gear leg/fuselage intersection fairings "dirty" ram air-scoop/cowl interface - about a 0.25 inch gap 2 inch temp probe sticking out the side of the fuselage Ailerons and flaps do not appear to be dragging no adverse rudder trim required cowl/air-intake not as clean as others I've seen, but not far away from ordinary Typical performance data based on many cross country runs, and specific flights to gather airspeed data: Altimeter - 30.05 in Hg OAT - 59 degrees Farenheit (15 deg C) Altitude - 8500 ft Full Throttle RPM - 2520 rpm MP - 22 in Hg Indicated Airspeed - 128 KIAS (147 mph) Density Altitude - 10,257 ft Pressure Altitude - 8379 ft While these numbers are from one flight, they are consistent with many other flights, 4-legged GPS data runs, etc. Observations: - True airspeed is typically in the 147 - 149 KTAS (169 - 171 mph) - the prop is overpitched, only gettting about 72% power out of the configuration I am in the process of fairing the ram air scoop, building wheel pant intersection fairings, and the temp probe has been removed, but I haven't flown it yet because the fiberglass is still setting up. Is this typical, or is there something I've missed to pick up more speed? Gregg Costabile N96AN, flying RV-7 empennage ________________________________________________________________________________
Date: Jul 07, 2002
Subject: Re: RV-6 Speed Question
Gregg wrote: > > Looking for some comparisons to any of you who may have a similar RV-6 > configuration. I believe mine is slow(er) by RV standards. > > Here's relevant data: > > RV-6, 967 lbs empty (no fuel, no oil) > Lycoming O-320-A1A, 150hp, 670 hours SMOH > Aymar Demuth wood prop > Old-style wheel pants (not the newer pressure recovery type) > Aluminium gear leg fairings > No wheel pant/gear leg or gear leg/fuselage intersection fairings > "dirty" ram air-scoop/cowl interface - about a 0.25 inch gap > 2 inch temp probe sticking out the side of the fuselage > Ailerons and flaps do not appear to be dragging > no adverse rudder trim required > cowl/air-intake not as clean as others I've seen, but not far away from > ordinary > > Typical performance data based on many cross country runs, and specific > flights to gather airspeed data: > > Altimeter - 30.05 in Hg > OAT - 59 degrees Farenheit (15 deg C) > Altitude - 8500 ft > Full Throttle > RPM - 2520 rpm > MP - 22 in Hg > Indicated Airspeed - 128 KIAS (147 mph) > Density Altitude - 10,257 ft > Pressure Altitude - 8379 ft > > While these numbers are from one flight, they are consistent with many > other flights, 4-legged GPS data runs, etc. > > Observations: > - True airspeed is typically in the 147 - 149 KTAS (169 - 171 mph) > - the prop is overpitched, only gettting about 72% power out of the > configuration > > I am in the process of fairing the ram air scoop, building wheel pant > intersection fairings, and the temp probe has been removed, but I > haven't flown it yet because the fiberglass is still setting up. Is > this typical, or is there something I've missed to pick up more speed? > > Gregg Costabile > N96AN, flying > RV-7 empennage > You cannot start asking for comparisons tell you get all your fairing work done. With no fairings and the engine and prop you have sounds like you are doing ok for speed. Jerry ________________________________________________________________________________
Date: Jul 07, 2002
> >Has anyone done this ? > >I want the real-time video to be available to both pilot and passenger in >Harmon Rocket (tandem) with selectable views. Probably a LCD in front and >back. Would involve mounting some lipstick cameras here and there on the >airframe, inside and out. I'm doing this in mine. I have made wing mounts for each wing and the tail, I plan on a solid state monitor and jacks for a video camrecorder on the panel with a camera select switch. I had good luck with the color camera from Matco (www.matco.com) Some pics of the camera mounts on www.liming.org/ch801/instrument12.jpg and the wing mounts on www.liming.org/ch801/wings3.html I've been looking around at some of the 4-5" monitors. Gary Liming ________________________________________________________________________________
Date: Jul 07, 2002
Gregg- I was amazed to see 5 kts increase when I put the new wheelpants on, even without the intersection fairings. Actually, my wheelpants came from a prototype mold and don't have the pressure recovery curve, they are straight, but still the large, symmetric size. I have also reduced the engine air opening to the size of the carb, 1 3/4", without any pressure loss. I also installed sailplane gap seals on the empennage, although that difference was hard to measure. Kevin ________________________________________________________________________________
Subject: Fiberglass canopy fairing
Date: Jul 07, 2002
I am ready to fiberglass the front of the canopy to the canopy frame (Tip-up). Does the glass need to be "roughed up" with sand paper in the area that will be in contact with the fiberglass. What grit, 180 or so? Tommy Walker 6A Tipper Ridgetop, TN ________________________________________________________________________________
Date: Jul 07, 2002
Subject: Re: Fiberglass canopy fairing
ti tommy i put the little clips to hold the plastic in place, as i didn't want to make stress cracks on the plastic. see sam buchannon 's website for good pixs of this install. good luck scott tampa RV6A 0360 C/S FLYING ________________________________________________________________________________
Date: Jul 07, 2002
Subject: [ Patty Gillies ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Patty Gillies Subject: Fuel Selector Plate (labeling) http://www.matronics.com/photoshare/gillies-patty@sc.edu.07.07.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Subject: Fuel Selector Labeling
Date: Jul 07, 2002
For those who haven't bought a fuel selector yet, you might want to note that the Andair valve includes a very good looking labeling plate in thier price. http://www.andair.co.uk/ This valve is way more expensive than Van's but a surprising number of completed RV's are sporting them. (mine will) Does Van still include the fuel selector valve in the finishing kit? If so you can get a discount by asking for it to be removed when you order your kit. FYI - you can ask for any component to be removed from your kit when you place your order and Van will reduce your price by the amount of that part. For example I got my finishing kit without a cowl to leave me the option of going with the reputedly faster Sam James cowl (no website). Regards, Norman Hunger RV6A Delta BC ________________________________________________________________________________
From: "Glenn Gordon" <dirtyrottenscoundrels(at)attbi.com>
Subject: RV-6 Flap Speeds
Date: Jul 07, 2002
Can I start to bring in the flaps above the white arc? If so, what speeds are you using for 10,20,& 30 degree flap positions? If at all possible, I would prefer slowing the plane down partially with the flaps rather than having to bring the engine power way back. Any thoughts? Thanks, Glenn Gordon N442e ________________________________________________________________________________
Date: Jul 07, 2002
Subject: Re: RV-6 Flap Speeds
> > > >Can I start to bring in the flaps above the white arc? If so, what speeds >are you using for 10,20,& 30 degree flap positions? > >If at all possible, I would prefer slowing the plane down partially with the >flaps rather than having to bring the engine power way back. Any thoughts? > >Thanks, >Glenn Gordon >N442e > This is a question better put to the engineers at Van's. They are the ones who know what loads the flap system was designed to handle, and what the aerodynamic loads are at various flap angles and speeds. All the folks on this list would just be guessing. -- Kevin Horton RV-8 (installing engine & electrics) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
Date: Jul 07, 2002
Kevin Horton wrote: > > > >> >> >> >>Can I start to bring in the flaps above the white arc? If so, what speeds >>are you using for 10,20,& 30 degree flap positions? >> >>If at all possible, I would prefer slowing the plane down partially with the >>flaps rather than having to bring the engine power way back. Any thoughts? >> >>Thanks, >>Glenn Gordon >>N442e >> >> >> > >This is a question better put to the engineers at Van's. They are >the ones who know what loads the flap system was designed to handle, >and what the aerodynamic loads are at various flap angles and speeds. >All the folks on this list would just be guessing. > > And I well say without guessing don't do it. You don't need to use flaps to slow down above the white arc. You do have to learn to plan ahead. The flap speeds are published for a reason and that includes a safety margin. Just wondering why would you not want to bring engine power back? Jerry ________________________________________________________________________________
Subject: Re: painting canopy
Date: Jul 07, 2002
people that have painted the plastic canopy part that is aboue the front sliding frame,has any one had a problem with the canopy cracking or crazing because of this,will be using the sherwin williams evercoat urathane paint to do this and to paint the rear skirt,very close to the jetglo paint of theirs,would like to hear from others on this before doing this, thanks frank goggio fayetetteville nc rv6A ________________________________________________________________________________
Date: Jul 07, 2002
There was a really nice install done on a velocity. http://www.rguerra.com/velocity/ look for the link to the wing cam... Bob Hassel Bob Hassel bob.hassel(at)directlink.net Email: bob.hassel(at)genuity.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Vinnfizz(at)aol.com Subject: RV-List: VideoCam'sInCockpit If you are interested in a little experimentation you may be able to cobble something together with the X-Com systems. They have 12 volt remote cameras etc. Display could be just about any type of video monitor. Ed C-140 flying RV-8 hopeful ________________________________________________________________________________
Date: Jul 07, 2002
Subject: Bug Cleaners, Fly-ins, and a Politician
I needed to wash the plane this weekend. I was going to a couple of fly-ins, and wanted to knock a month's worth of bugs off. With this in mind, I was at the local Walmart buying some random items, and happened upon a huge stack of windshield washer fluid @ $1.98/gallon. "Dissolves and Removes Bugs and Road Grime" said the label. A light went on in my head and I threw a gallon in the cart. The next morning, I filled my 24 ounce squirt bottle with it, and went at the airplane. A good squirt on the leading edges, prop, etc, a little scrubbing, a rinse with a hose, and the bugs were gone. Much easier than with soap and water, and every bit as good as the "aircraft bug remover" I've purchased for $8.00 a quart. I didn't try it on the Plexiglas, not knowing what the results would be, but I heartily recommend it for bug removal on painted surfaces. Following the wash job, I flew over to the Cracker Fly-in at Gainesville, GA, where I was met by a very pleasant and attractive greeter named Pam. Before I could ask for her phone number, I was sidetracked by a group of RV builders and people considering building RV's. I enjoyed talking with the airplane folks, but I really need to work on my priorities... After baking in the sun for a couple of hours, it was off to a fly-in at a grass strip owned by Cary Rhodes. Cary is a local RV-7 builder. He has a ~2,000 x 40 foot strip, with one (good) way in and out and about 1600' really usable. Since it was so hot outside (upper 90's) and my car air conditioner needed the work, I drove to Cary's strip, and suffered many insults from my friends who flew in. They accused me of not trusting my flying skills. I asked them to stand downwind while they teased me. When I got there, there were 30-40 aircraft, primarily of the Cub, Champ, Taylorcraft, Maule, and ultralight variety. There was a nice RV-4 which was built/flown by Henry Herring. I wouldn't have believed it possible, but two guys did a very smooth and tight formation landing in a C-172 and a Maule. Pretty impressive on a 40' x 1600' strip. In addition to the airplanes, there were probably 200 people including the band, the people swimming in the pool, and the local Congressman - Bob Barr. After a while, a group of us gathered under a big tent to grade the landings of arriving aircraft. Since it was literally 100F in the shade, everyone was in shorts and other appropriate garb for the day's Death Valley like conditions. Except, that is, the Congressman, who walked over to us, resplendent in his suit, complete with wingtips and cuffed pants. After a few pleasantries, someone asked if he wanted a plane ride. He said he only had a few minutes, but he'd love a ride. Well, we couldn't disappoint a Congressman, could we? In mere seconds, he found himself strapped into an ex-Italian airforce Super Cub owned and piloted by someone he'd never seen before in his life. His assistant got several good pictures of the event. Twenty minutes later, the Super Cub landed and discharged a somewhat sweaty Congressman, who enjoyed his flight thoroughly (according to the pilot, who has an RV-7 in his future). After the Congressman left, we did a thorough debrief with the Cub pilot: Did you spin, roll, or loop him? No. Did you use your one on one audience with the Congressman to point out how the private aviator is getting abused these days? No. Since you own a construction business, did you get yourself lined up to put new siding on the White House or Capital? No. In the end, we concluded that if you're running for reelection and attend a grass roots fly-in, you MUST go flying with a total stranger. Somewhat like kissing babies, but with a more serious downside... Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Jul 07, 2002
Gregg, I would say you are right on with your mensuration. Mr. Van Grunsven says a 150 HP six will cruise at 187 MPH with 75% power at 8,000 feet, and 169 with 55%. Extrapolating those values to 72% would yield 185 for 72% power. I would WAG that you are achieving less than 72% and quite possibly less than 70% of 150 considering the non optimum prop, and with a temp correction on the power.. If you are missing the cuff fairings as well as the old style pants and leg fairings, then I would say that you are missing about 12 to 15 MPH there also. By sheer coincidence I returned yesterday from a x country in my 6A which I flew at around 55% power and got 180 MPH TAS, which is about average for the summertime for my plane. 55% of my 180 is close to 70% of a 150. Therefore I predict you should achieve Van's advertised 187 MPH on a cooler day, at 8,000 density altitude and with the best fairings. What's nice about that lower power is the consumption which is 7GPH. I flew 3+59 going East and landed with 8 gallons. Let us know how you do. Denis > From: "Gregg" <gogators(at)arc.net> > Reply-To: rv-list(at)matronics.com > Date: Sun, 7 Jul 2002 11:18:14 -0500 > To: > Subject: RV-List: RV-6 Speed Question > > > Looking for some comparisons to any of you who may have a similar RV-6 > configuration. I believe mine is slow(er) by RV standards. > > Here's relevant data: > > RV-6, 967 lbs empty (no fuel, no oil) > Lycoming O-320-A1A, 150hp, 670 hours SMOH > Aymar Demuth wood prop > Old-style wheel pants (not the newer pressure recovery type) > Aluminium gear leg fairings > No wheel pant/gear leg or gear leg/fuselage intersection fairings > "dirty" ram air-scoop/cowl interface - about a 0.25 inch gap > 2 inch temp probe sticking out the side of the fuselage > Ailerons and flaps do not appear to be dragging > no adverse rudder trim required > cowl/air-intake not as clean as others I've seen, but not far away from > ordinary > > Typical performance data based on many cross country runs, and specific > flights to gather airspeed data: > > Altimeter - 30.05 in Hg > OAT - 59 degrees Farenheit (15 deg C) > Altitude - 8500 ft > Full Throttle > RPM - 2520 rpm > MP - 22 in Hg > Indicated Airspeed - 128 KIAS (147 mph) > Density Altitude - 10,257 ft > Pressure Altitude - 8379 ft > > While these numbers are from one flight, they are consistent with many > other flights, 4-legged GPS data runs, etc. > > Observations: > - True airspeed is typically in the 147 - 149 KTAS (169 - 171 mph) > - the prop is overpitched, only gettting about 72% power out of the > configuration > > I am in the process of fairing the ram air scoop, building wheel pant > intersection fairings, and the temp probe has been removed, but I > haven't flown it yet because the fiberglass is still setting up. Is > this typical, or is there something I've missed to pick up more speed? > > Gregg Costabile > N96AN, flying > RV-7 empennage > > > > > > ________________________________________________________________________________
Date: Jul 07, 2002
Subject: Re: Bug Cleaners, Fly-ins, and a Politician
KBoatri144(at)aol.com wrote: > > > I needed to wash the plane this weekend. I was going to a couple of fly-ins, > and wanted to knock a month's worth of bugs off. With this in mind, I was at > the local Walmart buying some random items, and happened upon a huge stack of > windshield washer fluid @ $1.98/gallon. "Dissolves and Removes Bugs and Road > Grime" said the label. A light went on in my head and I threw a gallon in > the cart. > > The next morning, I filled my 24 ounce squirt bottle with it, and went at the > airplane. A good squirt on the leading edges, prop, etc, a little scrubbing, > a rinse with a hose, and the bugs were gone. Much easier than with soap and > water, and every bit as good as the "aircraft bug remover" I've purchased for > $8.00 a quart. I didn't try it on the Plexiglas, not knowing what the > results would be, but I heartily recommend it for bug removal on painted > surfaces. ----------------------------------- I've been using windshield washer fluid for bug removal on the painted part of the plane for a couple years now; I haven't seen any adverse impact on the paint. I don't even use the hose rinse, just spray the cleaner on the wing leading edges, cowl, and gear fairings, then wipe dry with a cotton cloth (or a blue paper towel in a pinch). The active ingredient seems to be a low grade alcohol. As Kyle advised, I would not use it on plexi. Sam Buchanan (RV-6) "The RV Journal" http://thervjournal.com ________________________________________________________________________________
Date: Jul 07, 2002
Subject: mag/electronic
I have the dual mag on my IO-360 (RV8A). Kinda wonder how much redundancy that dual mag (with one drive) really gives me. Would like to go electronic on one set of plugs. Who knows about killing half of a dual mag? What are the best electronic options? Will appreciate any experience/knowledge on this subject. Thanks. Jimmy 8A--230 hours ________________________________________________________________________________
Subject: Flap Actuator Safety Wire
Date: Jul 07, 2002
I'm starting the installation of electric flaps on RV-7A. Instructions say to drill a small hole at an angle through the actuator arm for securing of the safety wire. The actuator arm looks like hardened steel that is going to be very difficult to drill through (even harder at an angle). Any body made alternate arrangements for the safety wire? Suggestions? Steve Hurlbut RV-7A O-360 A1A Fuselage http://members.kingston.net/sjhdcl/rv7a.htm ________________________________________________________________________________
From: "Alison and Neil McLeod" <bedrock(at)theriver.com>
Subject: Re: Flap Actuator Safety Wire
Date: Jul 07, 2002
It really wasn't that hard to drill, with my trusty air drill, once I tried using a brand new sharp bit. Neil ----- Original Message ----- From: "Steve J Hurlbut" <sjhdcl(at)kingston.net> Subject: RV-List: Flap Actuator Safety Wire > > I'm starting the installation of electric flaps on RV-7A. > Instructions say to drill a small hole at an angle through the actuator arm > for > securing of the safety wire. The actuator arm looks like hardened steel that > is going to be very difficult to drill through (even harder at an angle). > > Any body made alternate arrangements for the safety wire? > Suggestions? > > Steve Hurlbut > RV-7A > O-360 A1A > Fuselage > http://members.kingston.net/sjhdcl/rv7a.htm > > ________________________________________________________________________________
Date: Jul 08, 2002
----Original Message Follows---- From: "Gregg" <gogators(at)arc.net> Subject: RV-List: RV-6 Speed Question Date: Sun, 7 Jul 2002 11:18:14 -0500 Looking for some comparisons to any of you who may have a similar RV-6 configuration. I believe mine is slow(er) by RV standards. Here's relevant data: RV-6, 967 lbs empty (no fuel, no oil) Lycoming O-320-A1A, 150hp, 670 hours SMOH Aymar Demuth wood prop Old-style wheel pants (not the newer pressure recovery type) Aluminium gear leg fairings No wheel pant/gear leg or gear leg/fuselage intersection fairings "dirty" ram air-scoop/cowl interface - about a 0.25 inch gap 2 inch temp probe sticking out the side of the fuselage Ailerons and flaps do not appear to be dragging no adverse rudder trim required cowl/air-intake not as clean as others I've seen, but not far away from ordinary Typical performance data based on many cross country runs, and specific flights to gather airspeed data: Altimeter - 30.05 in Hg OAT - 59 degrees Farenheit (15 deg C) Altitude - 8500 ft Full Throttle RPM - 2520 rpm MP - 22 in Hg Indicated Airspeed - 128 KIAS (147 mph) Density Altitude - 10,257 ft Pressure Altitude - 8379 ft While these numbers are from one flight, they are consistent with many other flights, 4-legged GPS data runs, etc. Observations: - True airspeed is typically in the 147 - 149 KTAS (169 - 171 mph) - the prop is overpitched, only gettting about 72% power out of the configuration I am in the process of fairing the ram air scoop, building wheel pant intersection fairings, and the temp probe has been removed, but I haven't flown it yet because the fiberglass is still setting up. Is this typical, or is there something I've missed to pick up more speed? Gregg Costabile N96AN, flying RV-7 empennage Gregg: Sounds correct to me. I did not see any speed change without the gear interection fairings. If there is one, it is very hard to measure. Have only flown with the 2 piece wheel pants. There is a good 8 knots speed increase with them on. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,122.5+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide.aspx ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Exhaust for sale
I have a Snowline stainless exhaust, still in box for RV4. Never on engine. It looks complete, with heat box, less hangers and flange gaskets. Will take $300 + shipping. FOr info: Twoaviators(at)lexcominc.net Thanks, Dan ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Chrome spinner shop - Looking for -
I am looking for a shop to chrome my spinner. Does anyone have a shop they could reccommend ? Needs to be a aviation spec./qualitity shop, not your typical Harley chrome shop.... ________________________________________________________________________________
Subject: Fw: RV4-List: ALERT - GroupShield ticket number OA240_1026099217_SARAH_1
was generated
Date: Jul 08, 2002
Hey Guys (&Gals), I think someone out there's trying to "get" us. My system caught & cleaned an email from this acepilot(at)win.bright.net Chuck ----- Original Message ----- From: GroupShield for Exchange (SARAH) <NAIDRURYSARAH(at)lib.drury.edu> Subject: RV4-List: ALERT - GroupShield ticket number OA240_1026099217_SARAH_1 was generated > Action Taken: > The attachment was quarantined from the message and replaced with a text > file informing the recipient of the action taken. > > To: > rv4-list-admin(at)matronics.com > > From: > acepilot > > Sent: > 1194951808,29500977 > > Subject: > RV4-List: A good tool > > Attachment Details:- > > Attachment Name: top[1].exe > File: top[1].exe > Infected? Yes > Repaired? No > Blocked? No > Deleted? No > Virus Name: W32/Klez.h@MM > > ________________________________________________________________________________
Date: Jul 08, 2002
Subject: RV-6 Flap Speeds - reducing airspeed quickly -
In order to reduce speed with out loading the flaps or bringing the power way back, try reducing power and climbing. I use this procedure to slow down. A quick climb will get me into flap configuration speed very quickly. With proper flight planning,I should not need to do this and my instructor would chastize (me for doing this)....so he dosen't know I practice this procedure and use it. This procedure works very well in my old Bonanza and other fast, slippery aircraft. My cub, on the otherhand, will SLOW down when the power is pulled so I don't climb to reduce speed.. Can I start to bring in the flaps above the white arc? If so, what speeds are you using for 10,20,& 30 degree flap positions? If at all possible, I would prefer slowing the plane down partially with the flaps rather than having to bring the engine power way back. Any thoughts? Thanks, Glenn Gordon N442e ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Re: Chrome spinner shop - Looking for -
I owned a motorcycle shop for 29 years. Aluminum is tough to do a long lasting chrome job to. One of the best platers in the country, I think is named "BROWNs" and they are down south (Kentucky? Virginia?). You may want to consider polishing it and having it 'cleared'. I never tried clear powder coat, but powder coat is tough. Barry Pote RV9a P M Condon wrote: > > > I am looking for a shop to chrome my spinner. Does anyone have a shop > they could reccommend ? Needs to be a aviation spec./qualitity shop, > not your typical Harley chrome shop.... > > ________________________________________________________________________________
was generated
Date: Jul 08, 2002
I'm only replying to this because I have expertise in the field (MCSE); sorry if this is out of line, Matt. The klez virus is nasty because when it infects a system it not only emails itself to all the addresses it can find on the system, it also lies about where it came from - making it exceedingly difficult to track. Chances are that 'acepilot' does not have the virus but his address is found on a system that does. The proper way to deal with viruses is 1)never open an unsolicited attachment, 2)use anti-virus software to screen files you do open, and 3)report viruses to your Internet Service Provider. While the ISPs are beginning to find #3 is a pain in the b**t, they have the best chance of tracing a message back to its true origin. In reference to #1, if your Mom sends you an email with an attachment, it is prudent to email her back and ask if she really sent that. No virus yet has the ability to respond to queries like that. If Mom says, 'I didn't send anything' then forward it to your ISP and delete it from your system. The point is, don't trust the apparent sender; that name in the 'from' field may be a lie. Also, be sure your email does not open attachments automatically. True, you lose a lot of nice features that way, but it's the safe thing to do. Sad that a few people out there have to spoil it for us all. Last comment: Judi and I put confirmation info in our messages to each other when we send attachments. No virus is capable of doing that, either. A typical note might be : 'Here's a photo I thought you'd like. Just to confirm it's me; we saw Men In Black II last night.' With that, I can tell it really was from her and can open the attachment without having to track her down and asking. When in doubt, ask for verification, though. Patrick Kelley - RV-6A project in transit: 10 days to move -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of C. Rabaut Subject: RV-List: Fw: RV4-List: ALERT - GroupShield ticket number OA240_1026099217_SARAH_1 was generated Hey Guys (&Gals), I think someone out there's trying to "get" us. My system caught & cleaned an email from this acepilot(at)win.bright.net Chuck ----- Original Message ----- From: GroupShield for Exchange (SARAH) <NAIDRURYSARAH(at)lib.drury.edu> Subject: RV4-List: ALERT - GroupShield ticket number OA240_1026099217_SARAH_1 was generated > Action Taken: > The attachment was quarantined from the message and replaced with a text > file informing the recipient of the action taken. > > To: > rv4-list-admin(at)matronics.com > > From: > acepilot > > Sent: > 1194951808,29500977 > > Subject: > RV4-List: A good tool > > Attachment Details:- > > Attachment Name: top[1].exe > File: top[1].exe > Infected? Yes > Repaired? No > Blocked? No > Deleted? No > Virus Name: W32/Klez.h@MM > > ________________________________________________________________________________
Date: Jul 08, 2002
Subject: mag/electronic ignition
Tried this post before; evidently did not get it on the list. I have, in my 8A, an IO-360 with dual mag. Kinda wonder about the redundancy of two mags with one drive. Am interested in putting electronic ignition on one set of plugs. What experience out there on killing one side of a dual mag and adding electronic? What would be the best options?? Thanks. Jimmy 8A--230 hours ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Oshkosh Meetings
Hi, gang -- For those of you new to the RV-8 community, we've had meetings each year at Oshkosh of RV-8/8a builders -- and anyone else interested -- a couple of times during the convention. We meet each other, put faces with the names we've read about over the last few months and years, swap lies and tips, and generally start the day with some new friendships. The meetings are not exclusive to RV-8/8a builders, and are open to anyone with an interest in meeting other RV-8 builders. The gatherings are informal, and you're required to supply your own coffee and doughnuts (since we can't seem to count on Bob Dimeo to remember to bring them!), and have been held on Thursday and Sunday mornings under a tree in the Theater in the Woods at around 9:00. I don't mind hosting the meetings again, since there's not much to it other than to bring a few old Sharpies and some nametags (yes, you have to wear a name tag). However, if anybody out there has more grandiose ideas or wants to take the bull by the horns and become the new "moderator", let me know. However it works out, it's a great time to meet those we've come to know online and shake a few friendly hands. Let me know if I should plan meetings or leave it up to someone else. --Don McNamara N8RV ________________________________________________________________________________
Subject: Re: mag/electronic ignition
Date: Jul 08, 2002
That is a common set up for our airplanes. Many have the Jeff Rose (Electroair) ignition and others have Laser, etc. Personally, I found that the Electroair ignition is very straightforward and simple to install. It starts very smooth, and saves about 1.5 Gallons/hour in cruise at altitude. My vote goes for the Electroair. It is only about $800 and is well worth it. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: <HillStw(at)aol.com> Subject: RV-List: mag/electronic ignition > > Tried this post before; evidently did not get it on the list. > > I have, in my 8A, an IO-360 with dual mag. Kinda wonder about the redundancy > of two mags with one drive. > > Am interested in putting electronic ignition on one set of plugs. > > What experience out there on killing one side of a dual mag and adding > electronic? > > What would be the best options?? > > Thanks. > > Jimmy 8A--230 hours > > ________________________________________________________________________________
Subject: Flap actuator safety
Date: Jul 08, 2002
Yeah, Steve. I used Locktite. Gary _______ From: "Steve J Hurlbut" <sjhdcl(at)kingston.net> Subject: RV-List: Flap Actuator Safety Wire I'm starting the installation of electric flaps on RV-7A. Instructions say to drill a small hole at an angle through the actuator arm for securing of the safety wire. The actuator arm looks like hardened steel that is going to be very difficult to drill through (even harder at an angle). Any body made alternate arrangements for the safety wire? Suggestions? Steve Hurlbut RV-7A O-360 A1A Fuselage ________________________________________________________________________________
Date: Jul 08, 2002
Does anyone know if Jeff Rose is represented at OSH? -Larry --- Paul Besing wrote: > > That is a common set up for our airplanes. Many have the Jeff Rose > (Electroair) ignition and others have Laser, etc. Personally, I found that > the Electroair ignition is very straightforward and simple to install. It > starts very smooth, and saves about 1.5 Gallons/hour in cruise at altitude. > > My vote goes for the Electroair. It is only about $800 and is well worth > it. > > Paul Besing > RV-6A Sold (Waiting on the RV-10) > http://www.lacodeworks.com/besing > Kitlog Pro Builder's Log Software > http://www.kitlog.com > > > ----- Original Message ----- > From: <HillStw(at)aol.com> > To: > Subject: RV-List: mag/electronic ignition > > > > > > Tried this post before; evidently did not get it on the list. > > > > I have, in my 8A, an IO-360 with dual mag. Kinda wonder about the > redundancy > > of two mags with one drive. > > > > Am interested in putting electronic ignition on one set of plugs. > > > > What experience out there on killing one side of a dual mag and adding > > electronic? > > > > What would be the best options?? > > > > Thanks. > > > > Jimmy 8A--230 hours > > > > > > > > > > > > http://sbc.yahoo.com ________________________________________________________________________________
Subject: "Emergency" Cell Phone Offer
Date: Jul 08, 2002
W while back there was a posting to the rv-list of a cell phone offer for a phone for $59.95 with a $30 rebate, and service for 15 minutes for $10/month. I just checked on this and it is only available in Texas, and also the rebate has changed...too bad. FWIW ________________________________________________________________________________
Date: Jul 08, 2002
Why does it need to be an aviation shop? That's the beauty of experimentals. I had plenty of things chromed and powder coated at a Harley chrome shop. Chrome is chrome, as long as it looks good. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "P M Condon" <pcondon(at)mitre.org> Subject: RV-List: Chrome spinner shop - Looking for - > > I am looking for a shop to chrome my spinner. Does anyone have a shop > they could reccommend ? Needs to be a aviation spec./qualitity shop, > not your typical Harley chrome shop.... > > ________________________________________________________________________________
Date: Jul 08, 2002
In a message dated 7/8/02 11:41:38 AM Eastern Daylight Time, lcbowen(at)yahoo.com writes: << Does anyone know if Jeff Rose is represented at OSH? -Larry >> The Orndorffs sell his system. If you see them, they can tell you all about it. Jeff himself doesnt' usually go to the shows. Probably the best way to get information is to call Jeff directly. He's extremely polite and informative on the telephone. His number is in the yeller pages. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Jul 07, 2002
Are you dampening it for vibration? If so How. I've been pondering this myself. Cecil > > > > >Has anyone done this ? > > > >I want the real-time video to be available to both pilot and > passenger in > >Harmon Rocket (tandem) with selectable views. Probably a LCD in > front and > >back. Would involve mounting some lipstick cameras here and there > on the > >airframe, inside and out. > > I'm doing this in mine. I have made wing mounts for each wing and > the > tail, I plan on a solid state monitor and jacks for a video > camrecorder on > the panel with a camera select switch. I had good luck with the > color > camera from Matco (www.matco.com) > > Some pics of the camera mounts on > www.liming.org/ch801/instrument12.jpg > > and the wing mounts on www.liming.org/ch801/wings3.html > > I've been looking around at some of the 4-5" monitors. > > Gary Liming > > > > > messages. > > > > > > ________________________________________________________________________________
From: "Keith Vasey/Galvin Flying Svc" <keith(at)galvinflying.com>
Date: Jul 08, 2002
I agree with Paul, it doesn't need to be an aviation shop; Especially since a "chrome" spinner is considered "unauthorized" by the FAA whether it's on an Experimental or not. Evidently they are concerned about safety of flight is the spinner becomes "dechromed" in flight. They sure look great though, and my guess is that the infraction is similar to using your cell phone in flight or removing your mattress tags. I know several people who own a chrome spinner and a polished spinner (production aircraft). They put the polished spinner on the aircraft when they take it in for annual because the IA won't sign off the aircraft as airworthy with a Chromed spinner. Keith Vasey -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Paul Besing Subject: Re: RV-List: Chrome spinner shop - Looking for - Why does it need to be an aviation shop? That's the beauty of experimentals. I had plenty of things chromed and powder coated at a Harley chrome shop. Chrome is chrome, as long as it looks good. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "P M Condon" <pcondon(at)mitre.org> Subject: RV-List: Chrome spinner shop - Looking for - > > I am looking for a shop to chrome my spinner. Does anyone have a shop > they could reccommend ? Needs to be a aviation spec./qualitity shop, > not your typical Harley chrome shop.... > > ________________________________________________________________________________
Subject: Flying Blind: Small Plane Accidents
Date: Jul 08, 2002
And you should read some of the opinion posts... grrrr Patrick Kelley - RV-6A project in transit - 10 days to move -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jeff Orear Subject: Re: RV-List: Flying Blind: Small Plane Accidents Geeze!! Just the title of the show, "Flying *BLIND*: Small Plane Accidents." Ticks me off! When is the media going to get it straight??? Gimme a Break! Regards, Jeff Orear RV6A fuse Peshtigo, WI ________________________________________________________________________________
Date: Jul 08, 2002
Just a hypothetical question...if you ran a combo of one traditional mag and electronic to replace the other, wouldn't the timing of each typically be slightly off? I wonder how combustion would get distributed in the jugs with the sparks happening slightly offset? Might lessen cylinder life somehow? Just hypothetical. )_( Dan ----- Original Message ----- From: <HillStw(at)aol.com> Subject: RV-List: mag/electronic ignition > > Tried this post before; evidently did not get it on the list. > > I have, in my 8A, an IO-360 with dual mag. Kinda wonder about the redundancy > of two mags with one drive. > > Am interested in putting electronic ignition on one set of plugs. > > What experience out there on killing one side of a dual mag and adding > electronic? > > What would be the best options?? > > Thanks. > > Jimmy 8A--230 hours > > ________________________________________________________________________________
Date: Jul 08, 2002
I'll give this one a shot...typically the electronic ignition will fire up to 41 degrees BTDC while the mag always fires at 25 degress BTDC. The electronic ignition provides a much hotter spark and provides a more consistent burn pattern, pretty much nulifying the effect of the mag (which in this case is only acting as a backup). You can try this by shutting off your mag in flight, and note that there is very little, if any, change. Shut off the electronic ignition though, and you will definitely notice the change. On takeoff the electronic ignition is also firing at 25 degrees, it is only when manifold pressure begins to decrease as you climb that the electronic spark "advances" thus giving you more power and efficiency at the higher altitudes. Pat Hatch RV-4 Flying RV-6 Flying >From: "Dan Checkoway" <dan(at)rvproject.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: mag/electronic ignition >Date: Mon, 8 Jul 2002 10:54:35 -0700 > > >Just a hypothetical question...if you ran a combo of one traditional mag >and >electronic to replace the other, wouldn't the timing of each typically be >slightly off? I wonder how combustion would get distributed in the jugs >with the sparks happening slightly offset? Might lessen cylinder life >somehow? > >Just hypothetical. > >)_( Dan > >----- Original Message ----- >From: <HillStw(at)aol.com> >To: >Subject: RV-List: mag/electronic ignition > > > > > > Tried this post before; evidently did not get it on the list. > > > > I have, in my 8A, an IO-360 with dual mag. Kinda wonder about the >redundancy > > of two mags with one drive. > > > > Am interested in putting electronic ignition on one set of plugs. > > > > What experience out there on killing one side of a dual mag and adding > > electronic? > > > > What would be the best options?? > > > > Thanks. > > > > Jimmy 8A--230 hours > > > > > > Pat Hatch RV-4, N17PH @ VRB, 700 hrs TT 0-320, Hartzell C/S RV-6, N44PH, Flying 0-360, Hartzell C/S ________________________________________________________________________________
Date: Jul 08, 2002
I have a polished aluminum spinner from GBI (George & Becki Orndorff) on my O360 C/S RV6. It is an exact replica of the stock fiberglass spinner so no mods are necessary to the cowling. Polishes real nice with Mothers Metal Polish. Cash Copeland Hayward, Ca > > I am looking for a shop to chrome my spinner. Does anyone have a shop > they could reccommend ? Needs to be a aviation spec./qualitity shop, > not your typical Harley chrome shop.... > ________________________________________________________________________________
Date: Jul 08, 2002
Just my 2 cents about chromed aluminum parts in general. In a past life I used to do annuals on GA aircraft, and as stated, no A&P should sign off a chromed aluminum part. The reasons are quite simple. Aluminum cannot be directly chromed, as chrome will only stick to ferrous metals. In order to get chrome to stick to the aluminum parts, they must first be flashed with copper, then chromed over that. This process inherently weakens the metal from a metalurgical standpoint, hence the lack of aluminum "chromed" parts on production aircraft. Before someone starts flaming me, I'm only the messenger. IMHO, spinners are fine, there is no reason not to chrome a spinner, other than cost. If I wasn't so lazy, I'd polish mine, I've seen some beautiful jobs done on spinners, Overall, I say if you want chrome, do it! Cheers, Stein Bruch RV6, Minneapolis, finishing wingtips and getting ready to paint. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Keith Vasey/Galvin Flying Svc Subject: RE: RV-List: Chrome spinner shop - Looking for - I agree with Paul, it doesn't need to be an aviation shop; Especially since a "chrome" spinner is considered "unauthorized" by the FAA whether it's on an Experimental or not. Evidently they are concerned about safety of flight is the spinner becomes "dechromed" in flight. They sure look great though, and my guess is that the infraction is similar to using your cell phone in flight or removing your mattress tags. I know several people who own a chrome spinner and a polished spinner (production aircraft). They put the polished spinner on the aircraft when they take it in for annual because the IA won't sign off the aircraft as airworthy with a Chromed spinner. Keith Vasey ________________________________________________________________________________
Date: Jul 08, 2002
Paul Besing wrote: > > > Why does it need to be an aviation shop? That's the beauty of > experimentals. I had plenty of things chromed and powder coated at a Harley > chrome shop. Chrome is chrome, as long as it looks good. > > Paul Besing > RV-6A Sold (Waiting on the RV-10) > http://www.lacodeworks.com/besing > Kitlog Pro Builder's Log Software > http://www.kitlog.com > > ----- Original Message ----- > From: "P M Condon" <pcondon(at)mitre.org> > To: > Subject: RV-List: Chrome spinner shop - Looking for - > > > > > I am looking for a shop to chrome my spinner. Does anyone have a shop > > they could reccommend ? Needs to be a aviation spec./qualitity shop, > > not your typical Harley chrome shop.... > > > > > Paul, actually chrome is not just chrome the process is different when parts are to be used for aviation. If you are just speaking of chrome over alum them maybe you are right but don't take any type of structural part to just any chrome shop. I am speaking of parts like control stick and rudder pedals etc. Jerry ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Re: Bart's engines????
JR, AERO SPORT POWER (BART LALONDE) 800-667-0522 250-376-2955 http://www.aerosportpower.com ENGINES FOR EXPERIMENTAL AIRCRAFT Installed mine last weekend - it is a work of art. Dave Burnham 6A ________________________________________________________________________________
Date: Jul 08, 2002
Aerosport power 250-376-2955 - www.aerosportpower.com Wayne Petrus RV8A finish kit ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Fatal RV Crash/Insurance Question/6 kit for sale!
I was involved (passenger) with serious injury in a fatal RV-4 crash on May 15, in Jonesboro, Arkansas. The pilot some may know, was 72 yrs. old Bill Nolan a former Osh judge. Question: How do I find out if Bill had insurance on ME? I have mounting medical bills, missed work since accident. Bill has no immediate family members. ALSO, I have completed tail kit and one wing nearly completed (prepunched), with chrome heated pitot and spars phlogiston. I will sell wayyyyy cheap-make offer. Contact me off list for serious offers only. I am too ill to play games. My fly days are done guys-at least for now! BTW, The 150 HP engine quit at low/slow altitude. Bob Paulovich, Bryant, Arkansas ________________________________________________________________________________
Subject: Re: RV-6/6A fuselage jig for sale
Date: Jul 08, 2002
Subject: RE: RV-List: RV-6/6A fuselage jig for sale > > Along this note, I've Frey Steel Jig with "Bird-cage" option (holds the > front and rear spar dimentions very accurate) for the RV-6, in Nashville > TN. Delivery possible. Price negotiable. Asking $600. > Marty in Brentwood TN. Marty, Do you have digital pics available on the Jig that you could email to me? Thanks, Konrad Werner ABQ - NM ________________________________________________________________________________
Subject: Re: RV6-List: smoke
Date: Jul 08, 2002
Doyal, I installed nut plates and screws on that front forward skin and I was glad I did. According to Chris Heinz (Zenair University) one stainless screw equals four rivets. I don't know much about smoke but hope I never see any of that stuff trailing me. Bill ________________________________________________________________________________
Subject: Gear leg stiffeners
Date: Jul 08, 2002
Anybody recall the name/address of the guy who sells pre-fabbed gear leg stiffeners for RV-6's? Phone number or e-mail address would be great. Thanks much. David Davenport RV-6 N168DD Finishing up details ________________________________________________________________________________
Subject: Re: Fatal RV Crash/Insurance Question/6 kit for sale!
Date: Jul 08, 2002
Bob, Sorry that you were injured, glad your still here to talk about it. I can only tell you that the VanGuard Program did not insure Mr. Nolan. I did quote him about 2.5 years ago, but he never bound coverage thru us. My guess would be that either he was uninsured or he was insured by AVEMCO, or AIG (considering he was over 70 years old, and neither of those companies has an age limit). You would really be stabbing in the dark, by calling those companies directly, though. My recommendation would be to secure legal counsel for yourself, and let them approach the Nolan family, or the counsel responsible for Mr. Nolan's estate. Regardless of whether he was insured or not, I would think you should recover from his estate for your medical expenses (at a minimum.) You may also want to contact the FAA and the NTSB. I thought the NTSB investigated all aviation deaths, but their site has no record of that crash occuring. The FAA site only shows accidents in the last 10 days and is extremely preliminary (not a lot of information). John "JT" Helms Branch Manager NationAir Insurance Agency Pleasure and Business Branch ----- Original Message ----- From: <Bobpaulo(at)aol.com> Subject: RV-List: Fatal RV Crash/Insurance Question/6 kit for sale! I was involved (passenger) with serious injury in a fatal RV-4 crash on May 15, in Jonesboro, Arkansas. The pilot some may know, was 72 yrs. old Bill Nolan a former Osh judge. Question: How do I find out if Bill had insurance on ME? I have mounting medical bills, missed work since accident. Bill has no immediate family members. ALSO, I have completed tail kit and one wing nearly completed (prepunched), with chrome heated pitot and spars phlogiston. I will sell wayyyyy cheap-make offer. Contact me off list for serious offers only. I am too ill to play games. My fly days are done guys-at least for now! BTW, The 150 HP engine quit at low/slow altitude. Bob Paulovich, Bryant, Arkansas ________________________________________________________________________________
Date: Jul 08, 2002
I painted that part to match the airframe and it worked great. 2 years, and no signs of any distress to the canopy. I thought it would probably get scratched where it passes under the windscreen fairing, but there is no wear at all. I used PPG Concept. Ed Bundy - RV6A N427EM 500+ hours 160hp 0320 w/Sensenich 70x78 Eagle, ID ebundy(at)velocitus.net > people that have painted the plastic canopy part that is aboue the front > sliding frame,has any one had a problem with the canopy cracking or crazing > because of this,will be using the sherwin williams evercoat urathane paint > to do this and to paint the rear skirt,very close to the jetglo paint of > theirs,would like to hear from others on this before doing this, thanks > frank goggio fayetetteville nc rv6A ________________________________________________________________________________
Date: Jul 08, 2002
I think some of the responses missed the fact that you *do* have wheel pants and gear leg fairings, just no intersection fairings. I found that the intersection fairings made no measurable change in speed on mine. It does seem that you're down a little on speed. One thing I notice is that you're getting 3/4"-1" less MP than I do in that setting. I'm not sure what your air intake setup is like, but it looks like you aren't getting the full ram-air effect. That might be worth 2-3mph or so. I found that the pressure recovery wheel pants also made about a 4-6mph difference over my old style wheel pants. I get 188-191mph TAS (RV6A with 160hp) in your scenario. So, starting with my 190mph: You lose 2-3mph due to the 10hp deficit, but make it back with 2-3mph gain (6 vs 6A). Minus 5mph for the old style wheel pants, minus 2mph due to ram-air, maybe 2mph less efficiency with a wood prop, and I would think you should see around 180mph TAS. I get 2560rpm out of my Sensenich, with a wood prop you could re-pitch it to turn more RPM, but at a higher fuel burn. Any idea what your fuel burn is? You may have a low fuel burn that equates to the TAS you're getting. I'm burning 8-8.5gph at these numbers. Ed Bundy - RV6A N427EM 500+ hours 160hp 0320 w/Sensenich 70x78 Eagle, ID ebundy(at)velocitus.net > Looking for some comparisons to any of you who may have a similar RV-6 > configuration. I believe mine is slow(er) by RV standards. > > Here's relevant data: > > RV-6, 967 lbs empty (no fuel, no oil) > Lycoming O-320-A1A, 150hp, 670 hours SMOH > Aymar Demuth wood prop > Old-style wheel pants (not the newer pressure recovery type) > Aluminium gear leg fairings > No wheel pant/gear leg or gear leg/fuselage intersection fairings > "dirty" ram air-scoop/cowl interface - about a 0.25 inch gap > 2 inch temp probe sticking out the side of the fuselage > Ailerons and flaps do not appear to be dragging > no adverse rudder trim required > cowl/air-intake not as clean as others I've seen, but not far away from > ordinary > > Typical performance data based on many cross country runs, and specific > flights to gather airspeed data: > > Altimeter - 30.05 in Hg > OAT - 59 degrees Farenheit (15 deg C) > Altitude - 8500 ft > Full Throttle > RPM - 2520 rpm > MP - 22 in Hg > Indicated Airspeed - 128 KIAS (147 mph) > Density Altitude - 10,257 ft > Pressure Altitude - 8379 ft > > While these numbers are from one flight, they are consistent with many > other flights, 4-legged GPS data runs, etc. > > Observations: > - True airspeed is typically in the 147 - 149 KTAS (169 - 171 mph) > - the prop is overpitched, only gettting about 72% power out of the > configuration > > I am in the process of fairing the ram air scoop, building wheel pant > intersection fairings, and the temp probe has been removed, but I > haven't flown it yet because the fiberglass is still setting up. Is > this typical, or is there something I've missed to pick up more speed? ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Re: Gear leg stiffeners
DAVID DAVENPORT wrote: > > > Anybody recall the name/address of the guy who sells pre-fabbed gear leg > stiffeners for RV-6's? Phone number or e-mail address would be great. > Thanks much. > > David Davenport > RV-6 N168DD > Finishing up details > Would this be the guy you are looking for? http://www.metronet.com/~dreeves/turtlewooddesign/roger.htm Jerry ________________________________________________________________________________
Date: Jul 08, 2002
Subject: UPS SL-60 (Was Single Radio, Was used com radios)
Tom, I have a new, in the box, unused, SL-60 for sale. It includes the antenna, installation brackets and hardware, etc. I ordered the SL-60 from Van's in March of 2001, so the warranty is good for another year. I paid Van $2379 plus shipping. I am willing to sell for $2300, and I'll gladly pay the shipping. I decided to switch to an IFR approach capable GPS/Comm. I tried to return the SL-60 to Van's, but they wouldn't accept it as it is (was) a special order. Been procrastinating about putting it up for sale on eBay and/or advertising it in the RVator. If you are interested, contact me back channel for snail mail address and phone number. Charlie Brame RV-6A N11CB (res.) San Antonio -------------------------------------------- Subject: Re: RV-List: Single Radio - was used com radios George: I hadn't looked at the the UPSAT apollo series - always thought they were too expensive. I have to confess the SL60 is making me rethink my radio configuration. I already have an old EC-10x GPS - the one with the huge display - so I haven't been concerned with getting GPS into the panel. But the SL60 seems to be nearly the same price as the KX-125 with lots more features. Maybe I should just rely on my hand-held nav/com for back up and VOR function. -- Tom Sargent. RV-6A ________________________________________________________________________________
Subject: DON'T DO THIS! (and a fuel drain question)
Date: Jul 08, 2002
First the fuel drain question...I installed the drain in my first fuel tank by basically tightening the crap out of it. It still stands out more than I would have expected: http://www.rvproject.com/images/20020708_drain.jpg Is this normal? I assume so, but let me know so I can sleep better. Ok, now for the "DON'T DO THIS" column for the day. I'm installing flop tubes in my tanks, and a few weeks ago I fabricated and drilled the attach angle for my first tank. The plans didn't really say much about the flop tube installation or where exactly to drill the six rivet holes to attach the angle to the inboard rib. The plans just kind of *suggest* where they should go. So I drilled 'em where it looked right, and where it looked like there was good clearance and all that. Well, today I went to actually rivet and seal the sucker on there, and check out what I found: http://www.rvproject.com/20020708.html The rivets totally interfered with the flop tube fitting nut! Dang! Well, I thought I was going to have to leave those holes and drill two new ones, just filling the gaping holes with Proseal. That would suck. I'm sure it would seal, but it would be ugly and lurking in the back of my mind. But after a few minutes of cursing and brainstorming, I realized that I could countersink those holes and use AN426AD4-7 flush head rivets in there...and that's what I ended up doing. It all worked out, but the moral of the story is: TAKE CARE when drilling those rivet holes!!! Think before you drill! Ok, enough from me... )_( Dan ________________________________________________________________________________
Date: Jul 08, 2002
You could also have fabricated a washer to fit under the nut and raise it above the rivet heads, but I like your method - very pretty. As for the drain, it is correct. DON'T tap it out; you want the drain to be the lowest point in your tank. If it protrudes into the tank, it can allow a bubble of water to sit on the bottom, waiting to be sucked into your fuel lines. Once the wing is in place, you will see that the drains are in no danger of catching anything (though you might want to remove them after pressure checking so that handling during assembly does not damage them.) Onward through the fog! Patrick Kelley - RV-6A project in transit - 10 days to move -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Checkoway rv-list(at)matronics.com Subject: RV-List: DON'T DO THIS! (and a fuel drain question) First the fuel drain question...I installed the drain in my first fuel tank by basically tightening the crap out of it. It still stands out more than I would have expected: http://www.rvproject.com/images/20020708_drain.jpg Is this normal? I assume so, but let me know so I can sleep better. Ok, now for the "DON'T DO THIS" column for the day. I'm installing flop tubes in my tanks, and a few weeks ago I fabricated and drilled the attach angle for my first tank. The plans didn't really say much about the flop tube installation or where exactly to drill the six rivet holes to attach the angle to the inboard rib. The plans just kind of *suggest* where they should go. So I drilled 'em where it looked right, and where it looked like there was good clearance and all that. Well, today I went to actually rivet and seal the sucker on there, and check out what I found: http://www.rvproject.com/20020708.html The rivets totally interfered with the flop tube fitting nut! Dang! Well, I thought I was going to have to leave those holes and drill two new ones, just filling the gaping holes with Proseal. That would suck. I'm sure it would seal, but it would be ugly and lurking in the back of my mind. But after a few minutes of cursing and brainstorming, I realized that I could countersink those holes and use AN426AD4-7 flush head rivets in there...and that's what I ended up doing. It all worked out, but the moral of the story is: TAKE CARE when drilling those rivet holes!!! Think before you drill! Ok, enough from me... )_( Dan ________________________________________________________________________________
Date: Jul 08, 2002
Barry, The plating shop Mr. Condon refers to is indeed called Brown's Plating. They are located in Paducah, Kentucky. I used to own a motorcycle shop. I built a fair number of custom bikes for customers. Brown's is by FAR the best shop I ever dealt with when you need parts chromed. They really know their business and are very fair to deal with. They will re plate any part you are unhappy with. They specialize in motorcycle parts. Don't tell em it's for an airplane!! Go to: http://www.brownsplating.com/ Charlie Kuss covered in gray PPG Delta paint (painted fuselage stuff today) Boca Raton, Fl. > >I owned a motorcycle shop for 29 years. Aluminum is tough to do a long >lasting chrome job to. One of the best platers in the country, I think >is named "BROWNs" and they are down south (Kentucky? Virginia?). >You may want to consider polishing it and having it 'cleared'. I never >tried clear powder coat, but powder coat is tough. > >Barry Pote RV9a > >P M Condon wrote: >> >> >> I am looking for a shop to chrome my spinner. Does anyone have a shop >> they could reccommend ? Needs to be a aviation spec./qualitity shop, >> not your typical Harley chrome shop.... >> >> > > ________________________________________________________________________________
Date: Jul 08, 2002
The problem involves "embrittlement" caused by the > various chemicals used in the plating process. This changes the characteristics of the aluminium (as > you accuratly state) and may result in cracking. NOT good. We are getting close here... The process is hydrogen embattlement caused by the electroplating process. It can cause micro cracking which in a stressed part can lead to serious cracking. If a chrome shop has the facility and knows the application for the part they will bake the part in an oven to remove the elemental hydrogen atoms. There are also plating techniques that can reduce this in the first place. You can encounter the same embattlement process when welding. Depending on the parts you are working on it may be wise to use an aviation savvy facility. If you are plating your valve covers the Harley shop may be just fine... Dave Burton, RV6, wings ________________________________________________________________________________
Date: Jul 08, 2002
Charlie, I was the motorcycle guy referring Mr Condon to Browns. I never used them, but knew they were good. Barry Charlie Kuss wrote: > > > Barry, > The plating shop Mr. Condon refers to is indeed called Brown's Plating. They are located in Paducah, Kentucky. I used to own a motorcycle shop. I built a fair number of custom bikes for customers. Brown's is by FAR the best shop I ever dealt with when you need parts chromed. They really know their business and are very fair to deal with. They will re plate any part you are unhappy with. They specialize in motorcycle parts. Don't tell em it's for an airplane!! Go to: > http://www.brownsplating.com/ > > Charlie Kuss > covered in gray PPG Delta paint (painted fuselage stuff today) > Boca Raton, Fl. > > > > >I owned a motorcycle shop for 29 years. Aluminum is tough to do a long > >lasting chrome job to. One of the best platers in the country, I think > >is named "BROWNs" and they are down south (Kentucky? Virginia?). > >You may want to consider polishing it and having it 'cleared'. I never > >tried clear powder coat, but powder coat is tough. > > > >Barry Pote RV9a > > > >P M Condon wrote: > >> > >> > >> I am looking for a shop to chrome my spinner. Does anyone have a shop > >> they could reccommend ? Needs to be a aviation spec./qualitity shop, > >> not your typical Harley chrome shop.... > >> > >> > > > > > ________________________________________________________________________________
Date: Jul 08, 2002
> >As for the drain, it is correct. DON'T tap it out; you want the drain >to be the lowest point in your tank. If it protrudes into the tank, it >can allow a bubble of water to sit on the bottom, waiting to be sucked >into your fuel lines. Even if you were to let it seat completely against the flange, it is still the lowest part in the tank. I didn't get a picture before closing it up, but the o-ring seat is well below the skin. Jim Daniels ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Taxation with penalty and interest!!!! Builder Beware in Illinois
I received my N number last month (June) and the State of Illinois sent me a request for registering my plane to the Illinois Dept of Transportation. That cost is $20 for two years. But they did not want it registered until I receive the Airworthiness Certificate on the plane. They told me to call the Dept of Revenue to figure what my takes will be. When I called their office and explained I had been working on this kit for 8 years, they said I should have been paying a use tax during the building process. A "USE TAX" I exclaimed!!! What is that? They said that whenever I buy anything out of state and that company does not charge a sales tax, that I was suppose to turn around and send 6.25% whethin 30 days of purchase. I told them I had never heard of such a tax. Nobody ever does that!!! I was then told that their will be penalties and interest assocated with all purchases that had not been taxed. They also said that they could not go back past 6 years to collect taxes and anything I bought from an individual is also tax exempt. Also, anything I bought in the State of Illinois would already have been taxed and that is exempt. That leaves out alot. I bought my wings and tail from an individual. I bought my engine & prop from an individual. I started my project 8 years ago buying a lot of stuff up front which is now exempt. But that leaves my fuselage and finish kit to deal with. Maybe if I wait for another 4 years I won't have to pay anything. Dan DeNeal Just wondering if finishing is a good idea! http://sbc.yahoo.com ________________________________________________________________________________
Date: Jul 08, 2002
Bob, I was just wondering if you still had the wing and tail kit available. I will be honest and tell you up front that I was putting pennies together for the tail kit and have $1000 I can offer. If you have no offers, or just want to sell it right now, let me know. Thanks for your time, and I'm sorry about the accident, but happy to hear you are still hear talking! Mel Ewing --- Bobpaulo(at)aol.com wrote: > > I was involved (passenger) with serious injury in a > fatal RV-4 crash on May > 15, in Jonesboro, Arkansas. The pilot some may know, > was 72 yrs. old Bill > Nolan a former Osh judge. > Question: How do I find out if Bill had insurance on > ME? I have mounting > medical bills, missed work since accident. Bill has > no immediate family > members. > ALSO, I have completed tail kit and one wing nearly > completed (prepunched), > with chrome heated pitot and spars phlogiston. I > will sell wayyyyy cheap-make > offer. Contact me off list for serious offers only. > I am too ill to play > games. > My fly days are done guys-at least for now! > BTW, The 150 HP engine quit at low/slow altitude. > Bob Paulovich, Bryant, > Arkansas > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > http://sbc.yahoo.com ________________________________________________________________________________
Subject: virus
Date: Jul 08, 2002
Guys and Girls Just thought I would pass this along....I hope no one got caught. Seems we have some kind of an A hole trying to suck us into a virus. I got a message today from someone calling himself "acepilot" and the subject made it look like a list message but there were attachments. I did not open this but the attachments are a jpg file and a exe file both called "top" (no quotes). I also got a message that appears to be from Matts system admin (?) advising that the message was sent but they stopped it (apparently didn't do a good job) and that the virus is called - W32/Klez.H@m m. The two m's at the end are togeather but I seperated them in this message. Hope this helps. Joe Hine RV4 C-FYTQ ________________________________________________________________________________
Date: Jul 08, 2002
Mel, Give me a call tomorrow 501.847.1967 after 12:00 noon. You just happen to be the first mail I opened. Your offer is reasonable and I can throw in some other things. Bob ________________________________________________________________________________
Date: Jul 08, 2002
A small carbide-tipped burr (similar to a dentist's drill) in a Dremel tool will go through about anything. Jim Hasper - RV-7 just starting empennage ----- Original Message ----- From: "Steve J Hurlbut" <sjhdcl(at)kingston.net> Subject: RV-List: Flap Actuator Safety Wire > > I'm starting the installation of electric flaps on RV-7A. > Instructions say to drill a small hole at an angle through the actuator arm > for > securing of the safety wire. The actuator arm looks like hardened steel that > is going to be very difficult to drill through (even harder at an angle). ________________________________________________________________________________
Date: Jul 08, 2002
Are you responding to the questio of an access port in the top of the panel? If you did that successfully, do you have a drawing or picture? jp bill mosley wrote: > --> RV6-List message posted by: "bill mosley" > > Doyal, > > I installed nut plates and screws on that front forward skin and I was > glad I did. According to Chris Heinz (Zenair University) one stainless > screw equals four rivets. I don't know much about smoke but hope I never > see any of that stuff trailing me. > > Bill > ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Re: Fiberglass canopy fairing
Tommy There is no point in sanding the plexiglass, Not much will stick to it. You might want to use silicon seal to ' gasket' the fiberglass - plexiglass joint. This will bond the two together somewhat. Bob Fairings-Etc ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Re: RV-List Digest: 26 Msgs - 07/07/02
would like to hear from anyone that has tried or has any experience with with the ready made buss bar panels such as the exp2 jim clark napa ca rv 8 finishing kit ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Re: RV8-List Digest: 1 Msgs - 07/07/02
any one tried the ready made buss bar systems such as the exp2 ? jim clark rv8 finishing kit napa ca ________________________________________________________________________________
Subject: Re: Carb Heat/Alternate Source
Date: Jul 08, 2002
> Im wondering if anyone has used a carb heat air set up other than the small > alum. cylinder attachment and short 2" hose (sold by vans) going to the FAB? I hate to repeat the "check the archives" mantra, but there has been some good (and not so good) discussion of this in the past, so its worth a look there. Also check my site for pix of how I made a custom flange that closes off the gaps where the scat tube goes into the airbox. Unfortunately I don't have "before" numbers but I do have "after". www.edt.com/homewing/rhproject/fwallfwd.html. Randall Henderson, RV-6 N6R (~375 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Date: Jul 09, 2002
In a message dated 7/8/2002 7:54:27 AM Pacific Daylight Time, azpilot(at)extremezone.com writes: > Personally, I found that > the Electroair ignition is very straightforward and simple to install. It > starts very smooth, and saves about 1.5 Gallons/hour in cruise at altitude. Sorry, but I have to examine this statement a little closer. Assuming a 180 hp Lycoming producing 65% power (117 hp) and burning 8.2 gph, properly leaned, that is a BSFC of 0.42 lbs/hp/hr and is what I typically see in my application with two mags. If we reduce that normal fuel consumption by 1.5 gph and we're still producing the same hp (same rpm, same MP, same altitude) we suddenly have an engine that has an incredible BSFC of 0.34 lbs/hp/hr, believe it or not. Not. -GV (RV-6A N1GV 532hrs) ________________________________________________________________________________
Date: Jul 09, 2002
In a message dated 7/8/2002 9:38:02 AM Pacific Daylight Time, azpilot(at)extremezone.com writes: > Why does it need to be an aviation shop? That's the beauty of > experimentals. I had plenty of things chromed and powder coated at a > Harley > chrome shop. Chrome is chrome, as long as it looks good. Not hardly. A mil-spec shop is the only way to go. I believe in the general prohibition against chrome plating (and other platings that are prone to hydrogen embrittlement) when applied to structural parts, as the plating is inherently shortening the life of the part. Even when the process is followed immediately by baking it is dicey business. Only the good shops control the entire process to the degree that the risks are minimized. -GV (RV-6A N1GV) ________________________________________________________________________________
Date: Jul 08, 2002
How about just polishing the AL spinner? I guess how good it would look would depend on the alloy, etc. but there are lots of polished AL planes out there that look fabulous, and no plating involved. Randall Henderson, RV-6 N6R (~375 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Date: Jul 09, 2002
Wayne: Is Bart Lalonde; Fax250-376-1995 Tel: 250-376-1223 NO 800 no. 2965 Airport Road Kamloops, B.C. Canada, V2B 7w8 Bert ________________________________________________________________________________
Subject: Re: DON'T DO THIS! (and a fuel drain question)
Date: Jul 09, 2002
Dan, I had exactly the same problem and fixed it buy putting a relief cut on the nut itself. It worked great. You can chuck the nut in a drill press by using a mandrel and using a file. Alternately, a belt sander would make quick work of the those pesky points. In my case I used a small jewelers lathe that I had hanging around the shop. See it here http://bmnellis.com/images/Wings/Tanks/DCP01658.JPG Mike ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: DON'T DO THIS! (and a fuel drain question) > > First the fuel drain question...I installed the drain in my first fuel tank > by basically tightening the crap out of it. It still stands out more than I > would have expected: > > http://www.rvproject.com/images/20020708_drain.jpg > > Is this normal? I assume so, but let me know so I can sleep better. Ok, > now for the "DON'T DO THIS" column for the day. > > I'm installing flop tubes in my tanks, and a few weeks ago I fabricated and > drilled the attach angle for my first tank. The plans didn't really say > much about the flop tube installation or where exactly to drill the six > rivet holes to attach the angle to the inboard rib. The plans just kind of > *suggest* where they should go. So I drilled 'em where it looked right, and > where it looked like there was good clearance and all that. > > Well, today I went to actually rivet and seal the sucker on there, and check > out what I found: > > http://www.rvproject.com/20020708.html > > The rivets totally interfered with the flop tube fitting nut! Dang! Well, > I thought I was going to have to leave those holes and drill two new ones, > just filling the gaping holes with Proseal. That would suck. I'm sure it > would seal, but it would be ugly and lurking in the back of my mind. > > But after a few minutes of cursing and brainstorming, I realized that I > could countersink those holes and use AN426AD4-7 flush head rivets in > there...and that's what I ended up doing. It all worked out, but the moral > of the story is: > > TAKE CARE when drilling those rivet holes!!! Think before you drill! > > Ok, enough from me... > )_( Dan > > ________________________________________________________________________________
Date: Jul 08, 2002
I stand corrected then. I was not aware of the fatigue factor with chroming parts. Randall had a good point, polished alluminum seems to be the way to go, if metal fatigue from chroming is an issue. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com . ----- Original Message ----- From: <Vanremog(at)aol.com> Subject: Re: RV-List: Chrome spinner shop - Looking for - > > In a message dated 7/8/2002 9:38:02 AM Pacific Daylight Time, > azpilot(at)extremezone.com writes: > > > > Why does it need to be an aviation shop? That's the beauty of > > experimentals. I had plenty of things chromed and powder coated at a > > Harley > > chrome shop. Chrome is chrome, as long as it looks good. > > Not hardly. A mil-spec shop is the only way to go. I believe in the general > prohibition against chrome plating (and other platings that are prone to > hydrogen embrittlement) when applied to structural parts, as the plating is > inherently shortening the life of the part. Even when the process is > followed immediately by baking it is dicey business. Only the good shops > control the entire process to the degree that the risks are minimized. > > -GV (RV-6A N1GV) > > ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Eng.monitor unit..Grand rapids....
Hi: Any one that has installed the EIS monitor unit, from Grand rapids Tech, maybe able to help with my question... I would like to see, photo or schematic, exactly how are the two small resistors, ( one is 27 other 39 I believe) the ones I have look the same to me) connected to the magnetos, and unit... I started wiring the unit, instructions call to start with the Tach... Do one solder these small units to a wire, then connect to mags? Any help on this appreciated.. Bert rv6a ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Re: A&E Hogwash
Boy kids- What a hatchet job was done to GA in that one hour. I was dumbfounded and I just don't know what to say except good googly moogly have we got a PR problem? To get some reference point, it would have been beneficial to know how other sporting pursuits (boating, hunting, four-wheeling, football, soccer, bicycling, surfing, kayaking, strength training, mountain climbing, etc.) measure up as far as injury numbers? I thought we had highway deaths of 40,000/yr. This is a big country and the injury rate stated for GA just doesn't strike me right away as that high. I do suppose that if we all just stayed home, sat on the couch and watched TV, like they seem to want us to, we could all just die peacefully of blood clots or hardening of the arteries. Rant off. -GV (RV-6A N1GV 532hrs) ________________________________________________________________________________
Date: Jul 09, 2002
Oh, NOW he wants Coffee!! Bob -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Don McNamara Subject: RV-List: Oshkosh Meetings Hi, gang -- For those of you new to the RV-8 community, we've had meetings each year at Oshkosh of RV-8/8a builders -- and anyone else interested -- a couple of times during the convention. We meet each other, put faces with the names we've read about over the last few months and years, swap lies and tips, and generally start the day with some new friendships. The meetings are not exclusive to RV-8/8a builders, and are open to anyone with an interest in meeting other RV-8 builders. The gatherings are informal, and you're required to supply your own coffee and doughnuts (since we can't seem to count on Bob Dimeo to remember to bring them!), and have been held on Thursday and Sunday mornings under a tree in the Theater in the Woods at around 9:00. I don't mind hosting the meetings again, since there's not much to it other than to bring a few old Sharpies and some nametags (yes, you have to wear a name tag). However, if anybody out there has more grandiose ideas or wants to take the bull by the horns and become the new "moderator", let me know. However it works out, it's a great time to meet those we've come to know online and shake a few friendly hands. Let me know if I should plan meetings or leave it up to someone else. --Don McNamara N8RV ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Re: RV-8 fuselage jig for sale
My fuselage is out of the jig and upright! Jig built according to plans out of 2 x 6 with plywood gussets glued and screwed at all corners. $125 buys it. Located in the Omaha, NE area. I need to get rid of it as my shop is getting full!! Jim ________________________________________________________________________________
Date: Jul 09, 2002
All, You could try Electroless nickel plating. It doesn't have the embrittlement problems of Chrome, sticks to alloy like the proverbial does to blankets (they use it for plating racing motorcycle cylinders!) and can be polished to a lustre as good as chrome. I understand it can also be "tinted" to give various shades of colour but with a depth to the lustre unavailable in chrome. Lots of the custom car and m-cycle guys over here plate their wheels and other bits with it and some say it has a tougher surface than chrome and so is easier to clean and more resistant to scratching! just my .2c worth Graham Jones Kilmore, Australia. ----- Original Message ----- From: "P M Condon" <pcondon(at)mitre.org> Subject: RV-List: Chrome spinner shop - Looking for - > > I am looking for a shop to chrome my spinner. Does anyone have a shop > they could reccommend ? Needs to be a aviation spec./qualitity shop, > not your typical Harley chrome shop.... > > ________________________________________________________________________________
Subject: Investigative Reports TV show
Date: Jul 09, 2002
As usual, the media has a field day with small plane accidents, dramatizing the dangers and providing no perspective on risk. Over 2000 people are killed each year riding ATV's. Thanks to AOPA for representing the facts! Peter Blake RV6 tilt-up N899PB reserved .....To get some reference point, it would have been beneficial to know how other sporting pursuits (boating, hunting, four-wheeling, football, soccer, bicycling, surfing, kayaking, strength training, mountain climbing, etc.) ..... ________________________________________________________________________________
Date: Jul 09, 2002
Subject: RV-8 fuselage jig & Wings Cradle Available
List: FREE to a good home .... fuselage jig as well as wing cradle on casters. Located at the Winston Salem airport in North Carolina. Len Leggette, RV-8A Greensboro, N.C. N910LL (res) Final 90% ________________________________________________________________________________
Date: Jul 09, 2002
reposted to archives ----- Original Message ----- From: "Jim Jewell" <jjewell(at)telus.net> Subject: RV-List: mag/electronic ignition > > Hi Dan, > If you have thoughts of comparing timing of present day automotive > ignition systems with the timing of existing conventional aircraft > ignition discard these thoughts altogether. > > Automobiles have utilized mechanical and vacuum advance in their > ignition systems for very many years. It became a must almost as soon > as traffic was invented. The concept existed at the beginning of the > century, the 20th that is. The throttle on an automobile is constantly > manipulated while driving on all but level flat roads. Also automobile > engines run through wider RPM. ranges in different gears as needs > demand. The need to almost continually monitor and correctly adjust the > timing and mixture is far less do-able than controlling the throttle. It > is also far too distracting. Therefore the timing rate and mixture > control rate has become auto mated. (grin!). > > Conventional aircraft engines for the most part use two magnetos. One of > them is internally timed at 0 degrees for ease of starting. Once started > that magneto automatically advances to 25 degrees advance. The rate at > which this advance takes place is all but instantaneous. > > When the internal parts of the engine are in motion the mixture reaches > the cylinder and is compressed, It takes an amount of time for the > explosive force to build to a useful level. That period of time does not > change, a given amount and percentage of a fuel air mixture will burn at > a given rate regardless. It's just chemistry. > Speeding up the engine will not speed up the rate of combustion. This > fact brings on the need to fire the ignition earlier as RPM. is > increased,so as to have the explosive force at it's peak just as the > piston's position allows it to best transmit the controlled explosive > energy to the crankshaft. > It so happens that ignition firing at 25 degrees B.T.D.C. will > effectively support engine RPM. from idle and on up to about 3,000 RPM.. > At least the folks that determined the design of the mags seem to have > decided this to be true. > > Note that I said effectively, I did not say ideally. For the most part, > the 25 degree figure is only just acceptably in the ball park by modern > standards. > This brings into play the use of the mixture control adding or leaning > fuel mixture to keep the engine from being damaged. Expecting a pilot to > keep the mixture exactly right when there are many other demands to be > met, means that at best he will often be chasing the mixture settings > required by the ever changing conditions. > Just to add further complications, keep in mind that the indicators > (gauges and instincts) that the pilot in control commonly uses to judge > the right control setting to be needed have a time lapse and a less than > 100% accuracy built in by the very nature of the whole system's design. > This serves to ensure that the best that can be done is to almost catch > up to the ever elusive correct mixture setting. > Then of course there is the differing levels of knowledge, training, > and attitudes of each and every P.I.C. that tend to add a further > somewhat interesting wrinkle to the game plan. > > I was not alive or present when the decisions where made, So I cannot > say why the magnetos where not designed with a mechanism that would fire > the ignition spark earlier as the RPM increased, like it or not, they > weren't. > > The advent of computer aided electronic ignition for aircraft brings us > technically closer to the century that we live in. With the computer > sensing many various conditions and making timing decisions at the rate > of 250,000 or more times per second we can set the throttle and mixture > as we have in the past and cruise on, secure to a reasonable degree of > certainty that the fire is being lit at precisely the right time. > > With one mag and one E.I. as we climb higher and or increase the RPM. > beyond the often suggested "24 square" the requirement for more than 25 > degrees timing is met by the E.I.. If in the meantime the mag is firing > late by some percentage it then provides little more than an after > firing that serves to clean up any un-burnt gases. This in the overall > produces a cleaner running more efficient power plant. > > Add another E.I thereby eliminating the remaining mag and introduce > electronic fuel injection controlled by some added computer capacity, > link the works together, say goodbye to the mixture control and wham > your in the 20th. century. > It's called Fadec. Use a search engine and enter engine controls. > Fadec is available now. > In the near future (it's in the works) additional computer capacity and > some more sensors will eliminate the constant speed prop pitch control > and zap 21st.century here we come. > The era of get in the aircraft, insert the key, start the engine,warm it > up as temperature conditions require and fly the aircraft with no > thought to mixture or pitch control settings is on the horizon. I > believe it's called EPiC. Use a search engine and enter engine controls> > > Don't get the wrong idea, the complexity of flying will still be with > us. However the office desk will be slightly less cluttered, it will > otherwise be business as usual. > > Anyhow Dan, the answer to your question is in the fact that the E.I. > system that you refer to changes the engine timing precisely according > to need. So in fact when the engine is at idle and assuming that they > are both set correctly they will both be timed right. At engine speeds > above idle there will be various times when the E.I. will at the correct > timing while the mag timing will be more or less slightly wrong to no > ill effect > > > Jim in Kelowna I still need to learn > > > > > > Just a hypothetical question...if you ran a combo of one traditional > mag and > > electronic to replace the other, wouldn't the timing of each typically > be > > slightly off? I wonder how combustion would get distributed in the > jugs > > with the sparks happening slightly offset? Might lessen cylinder life > > somehow? > > > > Just hypothetical. > > > > )_( Dan > > > > Subject: RV-List: mag/electronic ignition > > > > > > > > > > Tried this post before; evidently did not get it on the list. > > > > > > I have, in my 8A, an IO-360 with dual mag. Kinda wonder about the > > redundancy > > > of two mags with one drive. > > > > > > Am interested in putting electronic ignition on one set of plugs. > > > > > > What experience out there on killing one side of a dual mag and > adding > > > electronic? > > > > > > What would be the best options?? > > > > > > Thanks. > > > > > > Jimmy 8A--230 hours > > ________________________________________________________________________________
From: "Ollie Washburn" <skybolt-aviator(at)msn.com>
Date: Jul 09, 2002
I would think you could just disconnect the plug wires.I had this mag on a Cardinal RG and it has 3 nylon or plastic gears,1 drive and 1 for each mag.Over time these gears can get brittle and the teeth break off quite easily.At least they did on mine,but luckly it was teeth on right mag.I replaced mag with a 3000 series which was supposed to be better. Ollie--6A Central Fl >From: HillStw(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: mag/electronic >Date: Sun, 7 Jul 2002 22:22:19 EDT > > >I have the dual mag on my IO-360 (RV8A). Kinda wonder how much redundancy >that dual mag (with one drive) really gives me. >Would like to go electronic on one set of plugs. >Who knows about killing half of a dual mag? What are the best electronic >options? >Will appreciate any experience/knowledge on this subject. > >Thanks. >Jimmy 8A--230 hours > > ________________________________________________________________________________
Subject: Re: mag/electronic ignition
Date: Jul 09, 2002
Jimmy, When we recently overhauled our engine (IO-360 A1B6) (200hp), we upgraded our Bendix mags to a new Slick mag (with impluse coupler) (starting mag) and installed Jeff Rose's EI inplace of the other Mag. We also have the SLickStart unit installed with an 18 amp Powersonic gel battery. The engine startes readily and is running well. With the EI we idle very smoothly at low RPM (500-600) and have now seen any plug fowling. The EI fires the lower plugs, while the Mag fires the top plugs. Chuck & Dave Rowbotham RV-8A (80 hrs) http://www.hotmail.com ________________________________________________________________________________
Date: Jul 09, 2002
GV, I agree with your comments!! You might want to ask the same questions of the "Investigative Reports" people. Shouldn't they examine all these other activities and rank order them by numbers of fatalities and injuries. Surely the automobile would get the prize. I am also sure that they could find bereaved family members of traffic fatalities to interview for emotional effect. Vanremog(at)aol.com wrote: > > > Boy kids- > > What a hatchet job was done to GA in that one hour. I was dumbfounded and I > just don't know what to say except good googly moogly have we got a PR > problem? > > To get some reference point, it would have been beneficial to know how other > sporting pursuits (boating, hunting, four-wheeling, football, soccer, > bicycling, surfing, kayaking, strength training, mountain climbing, etc.) > measure up as far as injury numbers? I thought we had highway deaths of > 40,000/yr. This is a big country and the injury rate stated for GA just > doesn't strike me right away as that high. > > I do suppose that if we all just stayed home, sat on the couch and watched > TV, like they seem to want us to, we could all just die peacefully of blood > clots or hardening of the arteries. > > Rant off. > > -GV (RV-6A N1GV 532hrs) > ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Chrome spinner shop - Looking for
There is a reason I want to use a "aviation" shop here. I fully realize the benefits of experimental class, and not being required to use FAA/PMA or $TC'ed items. (There is debate on the legality of this chroming anyway on 'real' airplanes........new Rockwell's are shipped with these spinners from the factory) The preparation process for chroming alimumum, especially a thin piece of sheet aluiomum that needs to be demential intact to fit when complete. Hydrogen embrittlement and other 'gotyas' need to be understood and worked with. That's why I am seeking a shop that does spinners (and other stuff)....... ________________________________________________________________________________
Date: Jul 09, 2002
Bob, thanks for the note, I'll call today after noon your time. I am located in montana, which might pose a problem, do you feel everything could be packaged for shipping without much trouble? MEL --- Bobpaulo(at)aol.com wrote: > > Mel, Give me a call tomorrow 501.847.1967 after > 12:00 noon. You just happen > to be the first mail I opened. Your offer is > reasonable and I can throw in > some other things. > Bob > > > > Contributions of > any other form > > latest messages. > other List members. > > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > http://sbc.yahoo.com ________________________________________________________________________________
Subject: Chrome spinner shop - Looking for -
Date: Jul 09, 2002
>> Why does it need to be an aviation shop? That's the beauty of >> experimentals. I had plenty of things chromed and powder coated at a >> Harley >> chrome shop. Chrome is chrome, as long as it looks good. >Not hardly. A mil-spec shop is the only way to go. Ask the guys that chrome plated their valve covers only to find chrome in their oil screens/filters because the chrome on the inside of the cover flaked off. Comes from improper preparation of the part. Michael ________________________________________________________________________________
Date: Jul 09, 2002
Jim Jewell said: > I ruled out the above ideas because of the weight, clutter, complication, > and the plugged solid with scat tubing appearance. Ditto > In any case do include a means to allow an uninterrupted flow of air through > the muff at all times. you do not want excess heat to build up inside the > heat muff. I considered this before I made the flange that closes off the gaps going into the airbox. Went ahead with it on the theory that, with the Robbins muff, there's no blast air tube forcing air into the muff -- it's open on the top so air will pretty much just swirl around in there if the bottom of the SCAT tube is closed off. So far so good with my set-up. Randall Henderson, RV-6 N6R (~375 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Illinois
Date: Jul 09, 2002
See the most recent Sport Aviation for an article about this. This applies almost everywhere, how it is applied varies widely (as well as the dodges you can get away with), and has been discussed on the list in the past. IIRC, the best advice is to value your aircraft according to the receipts as opposed to real (or resale) value and pay as you get the components to avoid penalties and lock the rate - parts are cheaper than the value of a finished AC. Patrick Kelley - RV-6A project in transit - 9 days to move -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan DeNeal Subject: RV-List: Taxation with penalty and interest!!!! Builder Beware in Illinois I received my N number last month (June) and the State of Illinois sent me a request for registering my plane to the Illinois Dept of Transportation. That cost is $20 for two years. But they did not want it registered until I receive the Airworthiness Certificate on the plane. They told me to call the Dept of Revenue to figure what my takes will be. When I called their office and explained I had been working on this kit for 8 years, they said I should have been paying a use tax during the building process. A "USE TAX" I exclaimed!!! What is that? They said that whenever I buy anything out of state and that company does not charge a sales tax, that I was suppose to turn around and send 6.25% whethin 30 days of purchase. I told them I had never heard of such a tax. Nobody ever does that!!! I was then told that their will be penalties and interest assocated with all purchases that had not been taxed. They also said that they could not go back past 6 years to collect taxes and anything I bought from an individual is also tax exempt. Also, anything I bought in the State of Illinois would already have been taxed and that is exempt. That leaves out alot. I bought my wings and tail from an individual. I bought my engine & prop from an individual. I started my project 8 years ago buying a lot of stuff up front which is now exempt. But that leaves my fuselage and finish kit to deal with. Maybe if I wait for another 4 years I won't have to pay anything. Dan DeNeal Just wondering if finishing is a good idea! http://sbc.yahoo.com ________________________________________________________________________________
Date: Jul 09, 2002
FREE to a good home .... fuselage jig as well as wing cradle on casters. Located at the Winston Salem airport in North Carolina. Yeah, Len. That's the RV spirit. I gave my gig away 5 years ago and, I believe at least 5 other fuselages have been build on it since. My only stipulation was for whoever used it to also give it away and write on it the aircraft number and who/when it was completed. I feel like a god father to these aircraft. One guy blew it and traded the jig for a used refrigerator for his hanger. Michael ________________________________________________________________________________
Illinois
Date: Jul 09, 2002
Maybe if I wait for another 4 years I won't have to pay anything. Dan DeNeal Just wondering if finishing is a good idea! OH, yeah. Finishing is a REALLY good idea. Just you wait. You can't let The Taxman get you down. Let me tell you how it will be. There's one for you nineteen for me, cuz I'm the Taxman, yeah, I'm the Taxman. (George) Michael ________________________________________________________________________________
Date: Jul 09, 2002
Subject: N109RV RV-9A
Hello everyone, I have over 5 hours on the plane now and everything is working great. All engine parameters are in the green. The airplane flies better than we could have hoped for. I took off in 150 feet this morning and landed in 300 ft. Hard to believe, but true. It climbs like a homesick angel, 1500 feet per minute on a hot day. It stalls at 42 miles per hour with flaps or 44 with flaps up. The stalls are straight forward with a little buffet and the nose only drops about five degrees. It is stable yet responsive and a total delight to fly. I will try to get some jpeg pictures sent out. I don't have any digital pictures of the finished product at this time. Will keep you posted, Paul 90355 ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: A&E Hogwash
Date: Jul 09, 2002
My wife turned the TV off because she got tired of hearing me yelling. In a somber, serious tone: "It is estimated that at least one small aircraft crashes each day. This is equivalent to 3 jumbo jets crashing per year. If that were happening, people would be screaming for change." That was some "industry expert." I guess he doesn't know how many cars crash per day. I wonder how many Greyhound buses that adds up to? That show was a huge piece of excrement, in my never to be humble opinion. -- Scott VanArtsdalen, MCSE, CCNA Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Vanremog(at)aol.com [mailto:Vanremog(at)aol.com] Subject: Re: RV-List: A&E Hogwash Boy kids- What a hatchet job was done to GA in that one hour. I was dumbfounded and I just don't know what to say except good googly moogly have we got a PR problem? To get some reference point, it would have been beneficial to know how other sporting pursuits (boating, hunting, four-wheeling, football, soccer, bicycling, surfing, kayaking, strength training, mountain climbing, etc.) measure up as far as injury numbers? I thought we had highway deaths of 40,000/yr. This is a big country and the injury rate stated for GA just doesn't strike me right away as that high. I do suppose that if we all just stayed home, sat on the couch and watched TV, like they seem to want us to, we could all just die peacefully of blood clots or hardening of the arteries. Rant off. -GV (RV-6A N1GV 532hrs) ________________________________________________________________________________
Date: Jul 09, 2002
If it makes you feel any better, the ratings for this show are so low that hardly anybody watches it. ;-) Sam Buchanan ================= "Van Artsdalen, Scott" wrote: > > > My wife turned the TV off because she got tired of hearing me yelling. > > In a somber, serious tone: "It is estimated that at least one small aircraft > crashes each day. This is equivalent to 3 jumbo jets crashing per year. If > that were happening, people would be screaming for change." That was some > "industry expert." I guess he doesn't know how many cars crash per day. I > wonder how many Greyhound buses that adds up to? That show was a huge piece > of excrement, in my never to be humble opinion. > > -- > Scott VanArtsdalen, MCSE, CCNA > Network Manager > Union Safe Deposit Bank > 209-946-5116 > ________________________________________________________________________________
Date: Jul 09, 2002
If you really want your blood pressure to rise, see the comments at the website. There's one guy, tagline 'atc' who belongs in an institution. On second thought, perhaps we'd be better off avoiding the website. Patrick Kelley - RV-6A project in transit (Chicago to Flagstaff) in 9 days -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Denk Subject: RE: RV-List: A&E Hogwash Excrement indeed! *** snipped the rest *** ________________________________________________________________________________
Date: Jul 09, 2002
02:23:08 PM I kept thinking about that statistic you always hear. "More people are killed each year by being kicked by mules than by aviation related accidents". I mean, something has got to be done about this danger to us all. There simply must be more restrictions on mules in this country, if not it won't be long until our streets are no longer safe from rogue bands of jackasses. I'm told they are already running amok in Washington D.C. Eric "Van Artsdalen, Scott" (at)matronics.com on 07/09/2002 12:52:48 PM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RE: RV-List: A&E Hogwash My wife turned the TV off because she got tired of hearing me yelling. In a somber, serious tone: "It is estimated that at least one small aircraft crashes each day. This is equivalent to 3 jumbo jets crashing per year. If that were happening, people would be screaming for change." That was some "industry expert." I guess he doesn't know how many cars crash per day. I wonder how many Greyhound buses that adds up to? That show was a huge piece of excrement, in my never to be humble opinion. -- Scott VanArtsdalen, MCSE, CCNA Network Manager Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Vanremog(at)aol.com [mailto:Vanremog(at)aol.com] Subject: Re: RV-List: A&E Hogwash Boy kids- What a hatchet job was done to GA in that one hour. I was dumbfounded and I just don't know what to say except good googly moogly have we got a PR problem? To get some reference point, it would have been beneficial to know how other sporting pursuits (boating, hunting, four-wheeling, football, soccer, bicycling, surfing, kayaking, strength training, mountain climbing, etc.) measure up as far as injury numbers? I thought we had highway deaths of 40,000/yr. This is a big country and the injury rate stated for GA just doesn't strike me right away as that high. I do suppose that if we all just stayed home, sat on the couch and watched TV, like they seem to want us to, we could all just die peacefully of blood clots or hardening of the arteries. Rant off. -GV (RV-6A N1GV 532hrs) ________________________________________________________________________________
Date: Jul 09, 2002
Subject: flying builders going to OshKosh
Hey everybody: who all from the 8/8A team who has a flying bird is going to make the trek to OshKosh this year? I would like to meet any of you that are intersted. If any of youse guys (that's my New York impression) are interested contact me off list or on list at willig10(at)yahoo.com I have followed a couple of you guys through completion and just want to get to know you so that in the future I have an excuse to "go somewhere" I would really like to meet denk and Vondane any suggestions where we should do this deed? I know the 8 group meets in the theater in the woods maybe this would be a good idea let me know your thoughts. Glenn Williams 8a A&P Fort Worth, TX finishing (finally) ==== Glenn Williams 8A A&P N81GW http://sbc.yahoo.com ________________________________________________________________________________
Date: Jul 09, 2002
Illinois --- Brian Denk wrote: > > > > Man, this kind of taxation strong arm tactic drives > me nuts. > > I say SCREW 'EM. If they have the resources to > bother you for a few bills, > then they certainly have the resources to go nail > some other guy or > corporation that would yield a LOT more revenue. > You are hardly worth their > effort. You bought a few boxes of aluminum pieces. > That cost, oh, say > about $39.95. (What the hell do those dweebs know > about building airplanes > anyway??) > Unfortunatly, since their are almost 3,000 of these airplanes having been built, the tax man is getting a little wiser and smarter by now! The tax man even asked me if it was Van's Aircraft kit. Dan in Tax land http://sbc.yahoo.com ________________________________________________________________________________
Date: Jul 09, 2002
Of course, if you want to see some staggering numbers, read this article about deaths from common medicine. http://www.codexalimentarius.org/read_article2.php?art_no=290 MEL --- Eric.J.Henson(at)chase.com wrote: > Eric.J.Henson(at)chase.com > > > I kept thinking about that statistic you always > hear. "More people are > killed each year by being kicked by mules than by > aviation related > accidents". I mean, something has got to be done > about this danger to us > all. There simply must be more restrictions on mules > in this country, if > not it won't be long until our streets are no longer > safe from rogue bands > of jackasses. I'm told they are already running amok > in Washington D.C. > > Eric >
June 30, 2002 - July 09, 2002
RV-Archive.digest.vol-nb
