RV-Archive.digest.vol-nl
September 06, 2002 - September 12, 2002
      more
      edge distance. The optical ripple on the bottom edge of the canopy you
      commented about? It is now small enough to be hidden by the canopy frame.
      Because my company has grown since you bought from me I now have access
      to
      tints I didn't have before. ( I can afford minimum orders) I have a light
      grey tint which is what you wanted.
      As we both know an advantage to a clear canopy and windshield is that it
      is
      the best for night flight. Next time you are up in the pitch dark under
      the
      clouds on a moonless night you may be thanking me.
      Lycoming is still comming out with AD's for their 50 year old engines. I
      hope
      to get all the bugs out of my canopies in a year or so.
      Thanks again for organizing the group order and for your business.
      Todd Silver
Subject:
Date: Sep 06, 2002
<<<<>>>>>> Codependant??? don't they have special hospitals for those with this problem, oh yeah, Sam already covered that? never mind ;{) ________________________________________________________________________________
Date: Sep 06, 2002
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Re: More Tap and Die Questions...
Bill Marvel wrote: > > > Steve: > > I do not recall encountering this on my 8A. It sounds as though the pilot hole > you drilled for the tap may have been too small. This would allow the tap to > push the walls outboard. > > Recheck the drill size called out for the tap and that the drill you have is the > correct one. > This should not happen. > > Bill Marvel > 8A 130 hours So Cal. > > sjhdcl(at)kingston.net wrote: > > > > > I found when taping my flap control arms, the outside of the aluminum tubing > > bulged a bit. > > > > Steve > > RV7A > > misc fuse stuff > > Or the tap is dull/worn and/or tapping "dry" without cutting compound. -- Bob McC ________________________________________________________________________________
"RV List"
Subject: Golden West Air Race
Date: Sep 06, 2002
The Aircraft Spruce Golden West Race was run today from Apple Valley Airport. Where were the RV series aircraft???? It turns out that only 19 planes entered. The was only one Harmon Rocket and one RV-8. There were 8 or 9 plastic planes. :-( Anyway, I wasn't able to find any results. Tom Gummo Bouncing Three Pointers and Smooth as Glass Two Pointers :-) ________________________________________________________________________________
Subject: UNF 1/4-28
Date: Sep 06, 2002
Not sure of this got answered. Universal National Fine thread 1/4" shank, 28 threads per inch or Universal National Coarse thread 1/4" shank, 20 threads per inch Home Depot or any good hardware store sells both ________________________________________________________________________________
Subject: Re: Rocket-List: Golden West Air Race
Date: Sep 06, 2002
Thats OK Tom everyone will get another chance on the Oct.11th Copperstate Race. IF Jim (A/S Pres.) follows thru with plans for a high HP class at Copperstate maybe we'll get the RV and Rocket racers at APV on the 10th and ready to race on the 11th. For more info get a hold of Aircraft Spruce and express your interest in same. KABONG --- Original Message ----- From: "Tom Gummo" <t.gummo(at)verizon.net> Subject: Rocket-List: Golden West Air Race > --> Rocket-List message posted by: "Tom Gummo" > > The Aircraft Spruce Golden West Race was run today from Apple Valley > Airport. > Where were the RV series aircraft???? > It turns out that only 19 planes entered. > The was only one Harmon Rocket and one RV-8. > There were 8 or 9 plastic planes. :-( > Anyway, I wasn't able to find any results. > > Tom Gummo > Bouncing Three Pointers and Smooth as Glass Two Pointers :-) > > ________________________________________________________________________________
Subject: Re: canopy question
Date: Sep 06, 2002
I'm about there but I'm going to use #6 stainless steel screws. Didn't drill the front two holes. They will get the full row on the bottom where it attaches to the frame. Norman Hunger RV6A Delta BC > For all you guys who have bonded on the canopy bubble using Proseal, Lexel, or whatever. How did you attach the aluminum side skirts without adding rivets??? > > If you glued it on.... how did you clamp it down until the glue sets???? > > I gotta know! > > Vince > F-1H Rocket ________________________________________________________________________________
Subject: Re: Wiring B8 stick grip
Date: Sep 07, 2002
> I notice that the Infinity grip has 17 conductors, (obviously doesn't use a > common ground). I could rewire the B8 grip to give me two connectors from > each switch like Infinity ..or... I can just go buy an Infinity switch. (I > really like the feel of the B8 as it is the same grip we used in AF > fighters (former life). Somebody out there have any other ideas? If not, > can you tell me where to get the 17-pin connector that Infinity uses? I have the Infinity grips. They come with a thick tail holding 18 wires three feet long. Longer lengths can be custom ordered. The wire is top quaility. The grips can be split in half and all the switches exposed. They are just a bunch of little toggles with the wires painstakinly soldered on. A factor for me in their large price is the fact that a couple of hours work for an amature is already done by having them come with the wire bundle pre-done. As for a connector, I had looked high and low. Ended up with a large molex connector on the right side from Digikey and the left side is hardwired in, no connector. Most of the switches have the two grips wired in parallel. I don't plan on having the passenger stick installed much. RV6's can be flown from each seat with only the left grip installed. Other than that I've always got George. All switches on the grips will be duplicated on the panel. (I think, not there yet) Norman Hunger RV6A Delta BC ________________________________________________________________________________
From: "Jim Norman" <jnorman(at)intermapsystems.com>
Subject: IK-2000 update (was: ACS 2002 engine monitor)
Date: Sep 07, 2002
Listers, just wanted to bring you up to speed again on the IK2000 and why I think you should all look at this before you buy engine instruments. (I have no connection to this company, just own and love the instrument). Its great that we have such good choices now!!!, but I took a trip and saw a couple of planes being built yesterday that were using VM1000 engine monitoring systems... making me think that there "may" be other choices out there that do MORE functions for LESS money. Two days ago Dan Checkoway wrote a nice letter here (attached below) that indicated all of the individual instruments that would be needed to match what is included in the recently released ACS 2002 engine monitor. With the exception of an ammeter and hour meter, the IK2000 gives you everything listed here also PLUS it gives you indicated airspeed, Mode C altitude, altitude deviation, and density altitude -- at a price (including ALL sensors) of $2675. So according to Dan's calculations, you save $824 over the gauges priced, simplify wiring, save lots of weight, gain tri-colored bargraphs made up on individual traffic-light-quality LEDs (and digital displays), and have a unit that is easy to upgrade in the future, comes fully customized to your specific engine and is composed of two separate modules and multiple (four I believe) independent microprocessors, so you wont face the possibility of a blank screen if theres a processor or screen failure. Best of all, you really can tell with just an instantaneous glance if all parameters are within normal limits. The bargraphs all point in the same direction so your scan wont have to interpret vertical indications as well as circular gauge-like indications. And the bright colors dont fight each other if somethings out of limits, youll see just a yellow LED bar or red LED bar for that parameter you wont have to figure out where the white line falls among all those colors. I-K Technologies has been shipping units for over a year. There are a handful of RV's flying with these (including Van's RV9A), and I know of a couple others that will be in the air within a few weeks. Mine took less than one hour to hook up, and EVERY parameter worked the first time I fired it up. I can't tell you how easy it is to see a bunch of green LEDs all in a row to know that every thing is ok. If I want to know the exact temperature, its there in a digital readout, but I don't need that most of the time... I just need to glance and see that there are no yellow or red LEDs. Also, the unit is programmed for your engine/prop/ignition/fuel system. Parameters (limits) are set according to what you are using up front. See it here. http://www.i-ktechnologies.com/ik2000/ Thanks for the forum... meant NOT to be a sales pitch (I have NO relationship with these guys), but when I get a good product, I want to share it with the rest of you. Happy shopping, no flames intended. jim Tampa > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dan Checkoway > To: rv-list(at)matronics.com > Subject: Re: RV-List: ACS 2002 engine monitor > > > This isn't exactly what you're asking for...but it might be interesting > nonetheless. I did the math and figured out how much it would cost to go > with individual needle-style gauges (plus a few digital toys) vs. the ACS > 2002, and here's what I came up with: > > Oil Pressure $58 IE VOP100, IE 411K > Oil Temperature $45 IE VOT250, IE 02017-00, VA-147 > Fuel Pressure $58 IE VFP50, IE 411L > Manifold Pressure $121 IE VMP35, IE VMP INSTALL KIT > Tach $101 IE VTACH3500, IE VTACHGEN 12 > Engine Monitor $1,439 IE UBG-16 > Fuel Qty. $345 IE FL-2C > Fuel Flow $775 IE FP-5 > Voltmeter $31 IE VV16 > Ammeter $49 IE VAM40, IE VAMSHUNT40 > Hour Meter $70 IE R8864, IE SPDT PRES-15 SW > OAT/Chron. $410 Davtron M803 > ============================= > Total: $3,500 > ________________________________________________________________________________
vansairforce(at)yahoogroups.com
Subject: RV8A Quick build
Date: Sep 07, 2002
I just recieved my RV8A Qb fuselage. Vans does not give a clue where they left off with the quick build and where I need to start. Any advice? http://www.hotmail.com ________________________________________________________________________________
Date: Sep 07, 2002
Subject: Re: RV8A Quick build
Al: My short answer is to just start reading the fuselage assembly plans as written and note the first thing mentioned that is not done. Start there. That is how I started. Then there's the longer answer -- As I recall, the first thing was drilling the floor into place. In truth, you can probably do anything you want as long as you don't permanently enclose something that you have to get to later. Totally independent projects include: Floor Front and rear seat backs After floor, front seat ramp Canopy track on aft fuselage Throttle quadrant assembly Lower instrument console assembly, left and right Static system installation Flap drive cover installation Forward and rear baggage compartment installation ELT location and installation Step installation (caution-rudder cable may contact step requiring a welded "U channel" in the step to provide clearance) Identify wire runs and install snap grommets Install aft control column hanger Assemble rudder pedals Install brake master cylinder and flex lines All those just pop right to mind as I write this. I am sure there are more things, but these will keep you busy for a long time.... A few suggestions not mentioned in the plans: 1. Drill a drain hole or two through the bottom skin on the aft side of each of the fuselage bulkheads. No water drainage is provided otherwise. The aft side is the high side when the 8A is on the gear and this is where water will accumulate. Also, note my post from last week on water accumulation in the belly. You will have to attend to this later when you can pour in water and locate the low spots. Also, plan to seal the seam where the lower fuselage panel extends beyond the fuselage as part of the bottom wing fairing. This is a major water leakage path in all RVs with a nose gear. 2. Before installing the gear weldments to the spar, be sure to run a ream through all the wing attach bolt holes in the weldment. All of the powder coated components in the kit have the coating on the ID of holes, making them too small. Normally you can do these as you go. However, if you follow the "do as you go" method, you will not get to the 8 wing attach holes per weldment until the wing is being fitted. At that point the weldments are bolted to the spar and there is no easy way to clean out the powder coating on the remaining holes. Do it now. 3. Put a large access panel in the bulkhead that forms the aft side of the forward baggage compartment. This will give you much improved access to your instruments. 4. Although shown in the drawing, make a special note to rivet onto the weldments the shim called out in drawing 30A, just to the left of section R-R. Finding this after installing the weldments would not make you happy. No, I did not make that mistake. I made others :-). 5. Lay your HS on the fuselage right now and make absolutely sure that the forward spar lies on top of the bulkhead through which it is to be bolted. Specifically, be sure the F810C and D align with the HS814 with sufficient edge clearance for the AN 3 bolts that go through there to hold the HS down. In my case there was not enough edge clearance. I did some measurements and phoned them up to Gus at Van's. He did the same measurements and we found that my QB fuselage was off by 1/4 inch. That was precisely the edge clearance I needed but did not have. I had to make up a larger F810C and D to solve the problem. Best to find that out now while things are accessible. Anyway, those are my thoughts. Frankly, I loved the fuselage. Many of the projects mentioned above are small enough that you can get them done in a day. You really accomplish something in a short time period and get a lot of satisfaction from it. Man, we're having fun now... Bill Marvel Al Grajek wrote: > > I just recieved my RV8A Qb fuselage. Vans does not give a clue where they > left off with the quick build and where I need to start. Any advice? > > http://www.hotmail.com > -- Bill Marvel Home/office 310 832 7617 P.O. Box 784 Cell 310 293 2013 San Pedro, CA 90733 Fax 310 832 5334 One good deed beats 100 good intentions... ________________________________________________________________________________
Subject: Infinity Stick Grips
Date: Sep 07, 2002
I would appreciate some info from other Infinity Stick Grip users. What length of wire was required for front and rear grips in the RV-8 (for ordering purposes). They come with 3 feet, and it's $2.00 per foot over that. Measuring from the rear seat stick, I came up with 11 feet, worst case scenario. Stick button/switch functions will be the same for pilot and rear seater. Thanks in advance. Ken Brooks Roscoe, IL N1903P resvd - starting panel and stick wiring ________________________________________________________________________________
Date: Sep 07, 2002
>I would appreciate some info from other Infinity Stick Grip users. What >length of wire was required for front and rear grips in the RV-8 (for >ordering purposes). Stick button/switch functions will be the same for >pilot and rear seater. Hmmmm. Not sure I would have a wired grip in the back. I worry about my rear seaters having a push-to-talk some days, which is not even on the rear stick grip. I think PIC needs switches that run flaps, landing lights, radio frequencies, etc. Not sure the back seater needs to be doing any of that, especially inadvertently. I have an Infinity grip up front which I LOVE, by the way, and have a simple wooden grip in the back. The stick is usually not installed when a passenger is back there unless it is someone that is going to fly whom I know well, then they still get the "wing removal lever" lecture. Having it hard wired would preclude removal. Maybe not the best idea. But that is just IMHO. Michael ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: flying the wing - GO OUT AND TRY IT
Date: Sep 07, 2002
These are mostly alfalfa pastures and crop duster strips. All at sea-level and only in the mornings. I used to fly my Champ into them all the time. That's probably why I land the way I do. Don't worry, I'm not going to be visiting them unless I feel CERTAIN that my RV-4 will be able to handle them. Looking at the size of the tires, I'll probably steer clear of all but the best crop duster strips. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Mike Nellis [mailto:mike(at)bmnellis.com] Subject: Re: RV-List: flying the wing - GO OUT AND TRY IT Scott, I suppose any strip that is shorter than what you've previously landed on could be considered short. It's been my experience that 1200' is, indeed, a pretty short landing field. Toss in some bushes or short trees at the approach end or a little xwind and you've got you're work cut out for yourself. I know all the stories about bush pilots and how they land in less than 300' (or whatever distance the story teller cares to embellish) but that's certainly not the norm. The 1200' airports that you mention flying into, are they public use or private? I don't know about your area, but of the 272 public use airports within a 200nm radius of my home base, none are less than 1500' publish length. I'd be curious to find a web site where I could look up and find how many public airports have lengths of less than 1500' in the U.S. Maybe there is a site where we can specify a search of all public airports greater than 1500' then compare those results with a search of the total number of public use airports in the U.S. I think that would interesting. Mike > > Maybe I'm assuming too much. Is 1200' considered a short strip? Because > those are the runway lengths I go into frequently. 3000' is long and > luxurious in my opinion. Maybe that's why my instructors (and myself) are > hung up on three-point full-stall landings. I've always treated every > landing as a short field landing. Power-off approach too. However I will > agree with Jerry and others who have said you can't fly every single > airplane the same as all the others. Every airplane requires it's own > specific technique and I am sooooo looking forward to figuring out my -4!! > > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: Mike Nellis [mailto:mike(at)bmnellis.com] > Sent: Wednesday, September 04, 2002 9:33 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: flying the wing - GO OUT AND TRY IT > > > My feelings exactly Sam. Although not flying the RV yet, I rarely land the > Stinson in 3 points unless I'm going into a very short field. When getting > my tailwheel training about 250 hours ago my instructor didn't want me even > playing around with 3 pointers. In fact, in all of my 5 hours of tailwheel > instruction I don't recall even performing a "wheel" landing. > > However, when the time comes to get into that 1200' strip you need to > pointed with nose to the air and praying to the God of Landings (at least in > the Stinson by this inexperienced tailwheel pilot). > > Mike Nellis - http://bmnellis.com > Georgetown, TX > Fuselage > RV6 N699BM Reserved > 1947 Stinson 108-2 N9666K > ----- Original Message ----- > From: "Sam Buchanan" <sbuc(at)hiwaay.net> > To: > Subject: Re: RV-List: flying the wing - GO OUT AND TRY IT > > > > > > > > Jerry Springer wrote: > > > > > > > > One thing Scott is that we can certainly get a good discussion going. > :) > > > Your examples of the planes you use to fly does not hold up well > discussing > > > RV landing techniques. Those airplanes can do "full stall three point > landings" > > > very easy. The RV-4 pilots with the short gear well also find that their > > > airplanes land different than the RV-6 with longer gear. Everyone should > land > > > the best way they are comfortable with, but do not get so rigid in > landing > > > techniques that you cannot adjust to the situation. IMO and someone from > Van's > > > can correct me, I do not believe the tail wheel spring assembly and rear > > > fuselage area were designed to take the beating of consistent tail > > > wheel first landings. I do not necessarily do wheel landings I use > attitude, > > > I try to get close to the runway and set up my landing attitude and hold > > > that tell it touches down. Hopefully it is about three point. for you > guys that > > > believe you need to be full stalled each time you land yes you are > going to > > > hit the tailwheel first. > > > Anyone that says they well never wheel land are in my opinion afraid > > > of them and well never really learn the full ability of their airplane. > > > I would bet money that the guy that says it is ground for firing if > > > someone wheel lands the tow planes probably doesn't know how or is > afraid > > > of them. This is very interesting reading different peoples thoughts on > > > this subject. > > > One more thought how many of you tailwheel pilots transition to > > > main wheels on takeoff roll. Think about it, if you do why do you > > > do it? > > > Jerry > > > > > > > > > Hello. My name is Sam Buchanan. I am here because I have a confession to > > make. I don't know exactly how it started, and I certainly didn't think > > it would progress this far. It's not like I planned it or anything, or > > even wanted it to happen! It was so innocent at first, but before > > long.....I was hooked. It even feels natural now.....almost as if it was > > meant to be! It all started when I stated getting disgusted with how > > inconsistent my three point landings were becoming. I started seeing > > other tailwheel pilots at airshows landing their planes on just the main > > wheels. It looked so...........good! > > > > It sorta creeps up on you, just one wheel landing now and > > then.........but then.......it gets control of you. The urge becomes > > stronger and stronger......so strong that you can't wait until you have > > the chance to do another......then another.....then...........another!! > > > > Yes, and this is so hard to say......I have become an RV wheel-lander! > > > > There, I feel SO much better! I no longer worry about redicule from that > > hateful group of RV-listers that cast a disgusting gaze in my direction > > as I grease on another wheel landing. No longer do I have to "explain" > > the "RV Skip" after trying to force my reluctant RV-6 to the tarmac in a > > three-pointer. > > > > I FEEL LIBERATED!!!!!!! Now I can land my plane any way I want! All I > > have to do is have full flaps as I cross the numbers (this results in > > maximum nose-down attitude), keep a little power, and fly down to the > > runway. I have even figured out how to make the first turn-off! > > > > No more RV-Skips! No more "multiple landings! No more getting current > > with one lap around the pattern! I can fly! I can land! I am a bird!! > > > > I.....I......I'm getting carried away......who are those men in the > > white suits........I HATE needles.........does this mean I lose my third > > class medical???? > > > > Do they make ultralights with tailwheels???? > > > > Sam Buchanan (reformed RV-6 pilot) > > > > > > ________________________________________________________________________________
Date: Sep 07, 2002
Subject: Re: Barrys Heads Up, was Flaps
One of the guys working the tent for Van's at OSH, meantioned a good tip: With the flaps full up, mark the edge of the top of the flaps on the fuselage. NEVER open the flap rod hole up above that! It would be very ugly. Barry Pote Rv9a Eric Newton wrote: > > > Yep - Kyle is exactly right. I looked at countless pictures of RV-6(a)'s on > the internet before I finally accepted the fact that I actually had to make > some ugly holes in the sides of my fuselage. ________________________________________________________________________________
Date: Sep 04, 2002
Subject: Re: alternate canopies
On Wednesday, September 4, 2002, at 02:21 PM, glen j matejcek wrote: > Does anyone have feedback on the cost/quality/weight > advantages/disadvantages of various vendors compared to Van's? Hi Glen. I don't have any experience with the "stock" Van's canopy, but I am happy with the quality/fit/price of my RV8 canopy from Todd's Custom Canopies. Very little trimming, optically good, and available in a slightly darker tint than Van's. James Freeman RV8 QB N9TN reserved slowly finishing.... ________________________________________________________________________________
Subject: vertical stabilizer offset
Date: Sep 07, 2002
A builder of an RV7 I met recently told me his preview plans showed an offset for the vertical stabilizer when mounted to the fuselage. Can anyone verify this and what the offset measurement is? Dave Ford RV6 ________________________________________________________________________________
Subject: alternate canopies
Date: Sep 07, 2002
I just posted a new progress picture that shows the "real dark" tint that Todd can get nowadays. www.lazy8.net/rv8.htm Strictly a day-VFR airplane! From the inside, it is about equal to an average pair of sunglasses. John, Pagosa Springs, CO -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of James Freeman Subject: Re: RV-List: alternate canopies On Wednesday, September 4, 2002, at 02:21 PM, glen j matejcek wrote: > Does anyone have feedback on the cost/quality/weight > advantages/disadvantages of various vendors compared to Van's? Hi Glen. I don't have any experience with the "stock" Van's canopy, but I am happy with the quality/fit/price of my RV8 canopy from Todd's Custom Canopies. Very little trimming, optically good, and available in a slightly darker tint than Van's. James Freeman RV8 QB N9TN reserved slowly finishing.... ________________________________________________________________________________
Date: Sep 07, 2002
Subject: Re: QB and electrical questions
In a message dated 9/7/02 10:54:04 PM Eastern Daylight Time, Cbradley1967(at)cs.com writes: << I plan to start a RV-7 soon, and have a couple questions. Which option saves more time, the QB wing or the QB Fuse? My guess: The wings. Lots dimples and rivets. I have little experience reading electrical diagrams and building electrical devices. Can any of you recommend a text book or other source to help me practice before I have to wire the RV? Get with your local EAA chapter, a local RV builder, or a Tech Counselor. You'll find someone who can show you the simple techniques used on an airplane. There really isn't much to it - it just gets more confusing and intimidating with every additional wire you run. I have Bob Nuckolls book and plan to utilize some ideas, but I need a more elementary, practical book to get me started. Thanks, C. Bradley Ellenberger >> Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Subject: RE: alternate canopies--feedback on Todd's Canopies
Date: Sep 07, 2002
From: "Todd Wenzel" <TWenzel@heartland-software.com>
Yes there were shipping company problems with the canopies that Todd Silver sent to me. The last (3rd) canopy that Todd sent me was finally in a real shipping crate constructed of plywood. If the first was sent that way I don't think there would have been any problems. My biggest beef with Todd Silver is his lack of follow through and lack of any sense of urgency to delivering me replacement canopies. I had called multiple times and send multiple emails to Todd Silver. I had to basically threaten to get any response. For the 3rd canopy I had to pay the shipping since Todd Silver apparently is seriously under capitalized. Keep in mind that the shipping was already in the price of the canopy when I ordered it ($475). Todd said he would refund the shipping costs after the canopy arrived safely - if the canopy was damaged, I would refuse delivery again and not pay for the shipping on the 3rd canopy. Well, it took weeks of prodding to get a check from Todd reimbursing me for the 2nd shipping charge. Total time span for this fiasco: 10 months! In Todd's defense, he did eventually get a nice tinted 1/4" canopy to me and reimbursed the double shipping charges I paid. He also apparently went through a divorce during this time period which probably contributed to the problems I was having getting a canopy. I've got it celcoed on the 8A now and it looks good. I was REAL careful when installing it since I was not confident Todd would stand by his guarantee of a free replacement if I damaged it during installation. I'm not out of the woods yet, but am over the worst part (I think). My experience with Todd is probably not typical based on what I've read on this list. However, I was VERY disappointed with his lack of follow through and the lengths I had to go to get him back on task. If I treated my customers that way I wouldn't be in business very long. The short of it is the canopy looks good. I'm happy with it now. Todd Silver is a good guy with good intentions. I think I understand a little of the personal and financial problems he was experiencing during this 10 month period. However, business is business. If you promise something, you better be willing and able to deliver it. It is MUCH better to manage your customer's expectations up front rather than avoid an obvious problem hoping it will go away. It never does go away and only gets worse. If you are looking at an alternate canopy, Todd Silver's are good. If you don't want his darker tint or the 1/4" thickness, then you are probably better off staying with Van's. You WILL NOT save ANY money going with a "non-Van's" canopy - but you will not pay much more. Is the 1/4" worth it? Beats me. Is the tint worth it? That's up to your personal preference. I wanted a tint to help a little with the green-house effect and, I'll admit it, I think it looks "cool". Just my opinion and my experiences - take them for what they're worth. Todd Wenzel Delafield, WI USA RV-8AQB - Finish Kit TWenzel@Heartland-Software.com -----Original Message----- From: Charlie Kuss [mailto:chaskuss(at)bellsouth.net] Subject: Re: RV-List: RE: alternate canopies--feedback on Todd's Canopies > My own experience from Todd Silver...good product, LOUSY SERVICE, ok > price. BTW, it will cost MORE to buy a "3rd party" canopy than you will > receive credit by excluding it from your finishing kit order. I don't > have the numbers in front of me, but I think the "credit" from vans was > around $325-$375, and the cost of the canopy and shipping from Todd > Silver will be well over $500. Remember that Todd's prices no longer > include shipping, so be prepared to add around $100 to $150 to his > prices. > > Todd Wenzel > Delafield, WI USA > RV-8AQB - Finish Kit > TWenzel@Heartland-Software.com Listers, I've mentioned this thread on the list to Todd Silver. He is a member of my EAA Chapter. He asked me to forward his explanation of what transpired with Todd Wenzel's canopy. It is because of the problems he had with this one particular trucking company that he dropped the free shipping. FYI, Todd Silver had to "eat" the shipping on the canopies which arrived at Todd Wenzel's damaged. He was not able to to even collect insurance on the second damaged canopy. It seems that he was not able to get one of his other trucking firms to deliver to Todd Wenzel's area. His comments to me are below. Charlie Kuss RV-8A fuselage Boca Raton, Fl. Charlie, I sent Todd a canopy. The crate looked like a forklift blade went through it. I sent him a second canopy. The crate looked like it was dragged from FL to WI. I sent him a third canopy. It got there undamaged. He was upset that he had to wait so long to get his canopy. I guess I would be too. I stopped prepaying shipping. I now ask that the customer pays for the shipping when the crate arrives in good condition. Since I started doing this I haven't had one problem with trucking companies trashing crates. Todd Silver ________________________________________________________________________________
Subject: Re: Stall speed - pitot tube orientaton
Date: Sep 07, 2002
Glen, Thanks for your excellent info. Your assessment of "local relative wind" being parallel to lower wing skin regardless of AOA seems valid to me. Saves a lot of "Rube Goldberg" options that I was spouting out. Where did you find this "short mast pitot tube" and "Gretz mast"? Brand name, part number, which company sells? Sorry for the uneducated question but I haven't done any shopping for these parts yet (wings not yet mounted). Could you give a description of where you mounted "sufficiently far back" - maybe a measurement aft to to the edge of wing skin just in front of flap, and a distance outboard from side of fuselage or that stubby section of skin that sticks out from fuselage that the wing slides over when installed? David Carter ----- Original Message ----- From: "glen j matejcek" <aerobubba(at)compuserve.com> Subject: RV-List: Stall speed - pitot tube orientaton > > David- > > Re: "As I believe that a fixed, single hole pitot tube is the primary > cause of the low speed errors (air is not directed straight into the pitot > tube at high AOA),..." > > One of the several reasons I chose a short mast pitot tube on a Gretz mount > is that the pitot pressure orifice is sufficiently far back along the wing > chord and close to the wing skin that the local relative wind should always > be essentially parallel to the wing skin / pitot axis. If memory serves, > the Cessna pitot tubes tend to be mounted relatively forward along the > chord, perhaps inducing the errrors you speak of.... > > Glen > -8 QB, fuse upside down ________________________________________________________________________________
Date: Sep 07, 2002
Subject: Re: Flutter (was: flying the wing - GO OUT AND TRY IT)
> >Amen to Kevin's comments on flutter. It's a bit of a black art kinda >thing to predict accurately. I guess I started this thread but unintentionally. I really meant to suggest that the GO OUT AND TRY IT proclamation is dangerous. Thinking, flight planning, theorizing etc help prevent nasty outcomes. But while on the topic of flutter analysis and other 21st century hoodoo, let me mention what I have experienced. I did computer simulation using a piece of software developed by IBM called GPSS. General Purpose Simulation System. I simulated manufacturing facilities so that different process and machine arrangements could be tried without the enormous expense of actually changing the factory. The 'models' as they are called are not the real thing, of course and could easily be off. Even if some are way off, it is still cheaper and faster than rearranging the factories. Simulations are not analyses, however. It is something of a black art. Hollman and others are surely wrong to refer to them as 'flutter analysis' as if it were always correct. I believe the same applies to computer studies of aerodynamics which obviate the need for much of the wind tunnel testing of the past. My opinion is that any kind of pre-flight thinking, computer use etc that can be done should be done in an effort to save lives and lovely little airplanes. DON'T JUST GO OUT AND TRY IT!! K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Subject: Re: Infinity Stick Grips
Date: Sep 07, 2002
I agree with Michael. I wouldn't want all the controls in the rear seat. If you do decide to install them, maybe put in a "co pilot disconnect" switch to shut off the capability of the rear stick. FWIW, the Infinity grips are great. I loved mine, and would put them in again. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Ken Brooks" <kdbrv8r(at)charter.net> Subject: RV-List: Infinity Stick Grips > > I would appreciate some info from other Infinity Stick Grip users. What > length of wire was required for front and rear grips in the RV-8 (for > ordering purposes). They come with 3 feet, and it's $2.00 per foot over > that. Measuring from the rear seat stick, I came up with 11 feet, worst > case scenario. Stick button/switch functions will be the same for pilot > and rear seater. Thanks in advance. > > Ken Brooks > Roscoe, IL > N1903P resvd - starting panel and stick wiring > > ________________________________________________________________________________
Subject: requesting advice on spark plug tools
Date: Sep 07, 2002
Our local RV group is considering adding to our tool collection, and I'm looking for advice/experience on spark plug maintenance tools. Among the tools that we collectively own is a condition inspection kit that includes a spark plug vibrator cleaner, a small "canvas-bag" type abrasive cleaner, and an inexpensive gapping tool. What we're looking at upgrading to is a professional cleaner/tester such as the Champion CT-4754AV. Sacremento Skyranch carries a similar unit, the Vixen SPCT100, that is less than half the price (looks suspiciously similar to the one sold by ATS under their name). Anyone have experience with either of these? Is it really worth the big bucks to get one? I don't much like the canvas bag cleaner and we don't currently have any way to test them either. The other thing we're looking at is a gap-setting tool. The Champion model 2500 looks to be pretty neat -- stick the gauge in there and pull the handle and you're done. Is it really that simple? If so this would be a great addition to our collection. Any thoughts from people who have experience with these tools would be helpful. Our group will be discussing this at the next meeting. Randall Henderson, RV-6 N6R (~400 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Subject: 3 questions (fuel selector and nut types)
Date: Sep 08, 2002
1) I've heard a lot of opinions that you should use the Andair fuel selector instead of the Van's stock fuel selector since the Andair one is much smoother to operate. I'm just getting started with my fuselage, sorting through the hardware bags, and I tried out the stock Van's selector -- it's very smooth through the full range of motion. Is the Andair selector *that* much better and worth the extra money? 2) I'm not an A&P, so go easy on me...when would you use an AN365-1032 nut as opposed to an AN365-1032A nut? The "A" version has a yellow insert and is slightly thicker, while the "B" version has a green insert (as far as I've seen). 3) I can't tell a bit of difference between an AN365-428 and AN365-428A. Same color insert, same dimensions, same threads. Is there any difference? Thanks in advance, )_( Dan RV-7 N714D (fuselage) http://www.rvproject.com ________________________________________________________________________________
Date: Sep 08, 2002
David You can buy short mounts and heated pitot tubes from Warren Gretz at Gretz Aero. See the RV Yeller Pages for contact info. The Gretz mount is a good, well proven way to add a heated pitot tube, if you need one. I recommend that if you do this, that you don't put the static source on the tube, as that has been shown on some RVs to lead to static system errors. We don't need heated static ports, even if we fly IFR. Unheated aft fuselage static ports have a very good service history on many aircraft types. You aren't going to collect ice back there unless you decide to do sustained sideslips with large rudder deflections. Note: The Gretz pitot tube mount puts the pitot tube in about the same location as Van's design because there is nothing wrong with Van's design. You are trying to solve a problem (pitot system error) that probably doesn't exist. I have seen results of flight testing of quite a few pitot-static systems, and the results match the theory - i.e. pitot system errors are very unlikely (except for leaks). Static system errors are the real problem. Glen is correct that the airflow under the wing will be roughly aligned with the pitot tube. I've seen results from tests done by NACA that showed that as long as the local airflow is aligned within about 15 degrees of the pitot tube the resulting error will be very small. Van's pitot tube location easily meets this criteria. If you are looking for a mod to make to the airplane just because you like building more than flying, then fill your boots. But if you are thinking about moving the pitot tube to improve its accuracy you are wasting your time and money. Take care, Kevin Horton RV-8 (spinner, cowling) Ottawa, Canada http://members.rogers.com/khorton/rv8.html > >Glen, > >Thanks for your excellent info. Your assessment of "local relative wind" >being parallel to lower wing skin regardless of AOA seems valid to me. >Saves a lot of "Rube Goldberg" options that I was spouting out. > >Where did you find this "short mast pitot tube" and "Gretz mast"? Brand >name, part number, which company sells? Sorry for the uneducated question >but I haven't done any shopping for these parts yet (wings not yet mounted). >Could you give a description of where you mounted "sufficiently far back" - >maybe a measurement aft to to the edge of wing skin just in front of flap, >and a distance outboard from side of fuselage or that stubby section of skin >that sticks out from fuselage that the wing slides over when installed? > >David Carter > >----- Original Message ----- >From: "glen j matejcek" <aerobubba(at)compuserve.com> >To: >Subject: RV-List: Stall speed - pitot tube orientaton > > >> >> David- >> >> Re: "As I believe that a fixed, single hole pitot tube is the primary >> cause of the low speed errors (air is not directed straight into the pitot >> tube at high AOA),..." >> >> One of the several reasons I chose a short mast pitot tube on a Gretz >mount >> is that the pitot pressure orifice is sufficiently far back along the wing >> chord and close to the wing skin that the local relative wind should >always >> be essentially parallel to the wing skin / pitot axis. If memory serves, >> the Cessna pitot tubes tend to be mounted relatively forward along the >> chord, perhaps inducing the errrors you speak of.... >> >> Glen > > -8 QB, fuse upside down ________________________________________________________________________________
Date: Sep 08, 2002
Subject: Re: vertical stabilizer offset
Hi Dave- Yeah, I noticed it in the plans revisions on page 19 of the second 2002 RVator- I don't see a dimension for the offset, it looks like it's set by the F-781 attach plate (pre-punched of course?!) but looks like about 1/8" or 3/16" to the left... ...oh yeah, and I saw this about a month after I drilled the V.S. spar for my -6A!! From the PossumWorks Mark Dave Ford wrote: > > A builder of an RV7 I met recently told me his preview plans showed an > offset for the vertical stabilizer when mounted to the fuselage. Can > anyone verify this and what the offset measurement is? > > Dave Ford > RV6 ________________________________________________________________________________
Date: Sep 08, 2002
Ken and others, I saw your post to the rv-list about your Infinity grips. I have a couple thoughts that I'll pass along. I'm building a -6, so adjust your thought accordingly. First, think out your switches carefully and while looking at a picture, envision using the switches for each function. There are physical options for switches that have to be though out. Momentary, (as in push to talk, comm flip flop and starter engage), push for on push for off (as for landing lights and/or wig-wag), lever with and without momentary feature (flaps). For flaps, you have the option of momentary on both the up and the down positions. The guy at Infinity suggests momentary only on the down, thinking that on a go-around, you want the flaps up and have other things to think about other than holding that switch. I mention this, because when you call your order in, these questions have to be answered, and you wouldn't want to be rushed and make a wrong decision. The switches are hard to replace because of the confines of the handle and lack of a service loop in the wire. The length of the wire is something I should have more carefully considered. I ordered two (2) feet extra and is just enough (on a -6) to run the wires down the handle, loop around the control tube and into a bulkhead CPC plug to allow stick removal. From the CPC to a meeting place where the wires from both handles come together under the passenger seat. (It is not going to be fun when I have to go in and make changes to the wiring.) Some switch functions have to be isolated so that only one handle works at a time. To accomplish this, I isolated the ground return through a single pole switch on the panel. This opens a bag of worms where you have press on/press off switches on the handle. There is no simple way to tell the state of a switch when changing the handle authority, therefore except for flaps (lever type switch), my second handle is not wired with those functions that have a push on/push off switch. One last thought, the flap and trim switches activate relays that direct power to the respective servos. The ground path for the relay(s) goes through the SPST (stick authority) switch on the panel. You can find articles in the archives on wiring your own relay box or buy the relay circuitry from available sources. Someone also mentioned the use of a simpler solid state switching device, but I haven't hear from anyone who actually made one work. Good Luck with your project Tom Barnes -6 Buffalo Grove, IL ________________________________________________________________________________
Date: Sep 08, 2002
Sorry, needed one more "ell" http://www.lazy8.net/rv8.html john -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of John Huft Subject: RE: RV-List: alternate canopies I just posted a new progress picture that shows the "real dark" tint that Todd can get nowadays. www.lazy8.net/rv8.htm Strictly a day-VFR airplane! From the inside, it is about equal to an average pair of sunglasses. John, Pagosa Springs, CO -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of James Freeman Subject: Re: RV-List: alternate canopies On Wednesday, September 4, 2002, at 02:21 PM, glen j matejcek wrote: > Does anyone have feedback on the cost/quality/weight > advantages/disadvantages of various vendors compared to Van's? Hi Glen. I don't have any experience with the "stock" Van's canopy, but I am happy with the quality/fit/price of my RV8 canopy from Todd's Custom Canopies. Very little trimming, optically good, and available in a slightly darker tint than Van's. James Freeman RV8 QB N9TN reserved slowly finishing.... ________________________________________________________________________________
Date: Sep 08, 2002
Subject: Re: 3 questions (fuel selector and nut types)
> 2) I'm not an A&P, so go easy on me...when would you use an > AN365-1032 nut > as opposed to an AN365-1032A nut? The "A" version has a yellow insert > and > is slightly thicker, while the "B" version has a green insert (as far > as > I've seen). > > 3) I can't tell a bit of difference between an AN365-428 and > AN365-428A. > Same color insert, same dimensions, same threads. Is there any > difference? Dan, I'm wondering if this is just a typo? I sorted out my fuselage kit yesterday and there are only 1032 and 428 part numbers for the AN365 nuts (some of the other sizes have 'A' suffixes, though). I also went back to the wing kit and found the same. Lastly, I went online to to Van's "The List" and did a search - only 1032 and 428 are listed. I suspect the green vs yellow inserts are just a different manufacturer. Jim Daniels ________________________________________________________________________________
Subject: Roll Bar - plan discrepancies
Date: Sep 08, 2002
Folks, I'm in the process of installing my roll bar...RV6A slider QB #60431. Here's my problem: Plans sheet SC-1B (as well as old preview plan SC-1) shows the aft edge of the roll bar (not base plate) 33 1/4" aft of the forward face of the firewall and 3 1/8" aft of the 604 bulkhead riser. Plans sheet SC-4 (old - preview plans...the new ones don't show it at all) also shows that the base plates for the roll bar weldments are 5 1/2" from front to back. The base plates for my roll bar weldments are only 5 1/4" from front to back. If I place the aft edge of the roll bar (again - not the base plate) as far aft as called for, the forward bolt hole for the base plate to canopy deck attachment falls around the forward 604 bulkhead riser plate. What is the correct dimension for placement of the roll bar? Do I have an incorrectly assembled roll bar? Did I miss a plans change? I have a digital photo in case anyone thinks they know but aren't sure... Please advise, Ralph Capen ________________________________________________________________________________
Date: Sep 08, 2002
Subject: Re: Primer for fiberglass parts
Ron, Use whatever you are going to use on the plane. Wipe with acetone, sand with about 320 grit paper and squirt away. This is assuming the pin holes have been filled. Bob Fairings-Etc ________________________________________________________________________________
Date: Sep 08, 2002
Dan Checkoway wrote: > - I'm just getting started with my fuselage, > sorting through the hardware bags, and I tried out the stock Van's > selector -- it's very smooth through the full range of motion. Is the > Andair selector *that* much better and worth the extra money? I'm using the stock unit from Van's and have found absolutely nothing wrong with it. Of course, it has only 130 hours TTSN and is a couple of years old, so I have no long-term history on it. > ..when would you use an AN365-1032 nut > as opposed to an AN365-1032A nut? The "A" version has a yellow insert and > is slightly thicker, while the "B" version has a green insert (as far as > I've seen). > > 3) I can't tell a bit of difference between an AN365-428 and AN365-428A. > Same color insert, same dimensions, same threads. Is there any difference? > I have no idea what the "A" designation is for. The color usually pertains to the manufacturer. Unless some specification calls out one versus the other, I would consider them to be interchangeable. Bill Marvel ________________________________________________________________________________
Subject: Aerospace Logic Guages
Date: Sep 08, 2002
RV LIst, I'm posting this for a friend with a RV6. We seen the Aerospace Logic egt guage, at the Oswego RV forum. He is interested about installing it. Has anybody used or had any dealing with them. Thanks in advance. Tom Yeager RV8 fuselage ________________________________________________________________________________
Date: Sep 08, 2002
From: Gary & Carolyn Zilik <zilik(at)bewellnet.com>
Dan Checkoway wrote: > > 1) I've heard a lot of opinions that you should use the Andair fuel > selector instead of the Van's stock fuel selector since the Andair one is > much smoother to operate. I'm just getting started with my fuselage, > sorting through the hardware bags, and I tried out the stock Van's > selector -- it's very smooth through the full range of motion. Is the > Andair selector *that* much better and worth the extra money? Some people prefer the pricey Andair valve over the standard. Both work well and I would suggest using the supplied valve and saving the money for some other item. > > > 2) I'm not an A&P, so go easy on me...when would you use an AN365-1032 nut > as opposed to an AN365-1032A nut? The "A" version has a yellow insert and > is slightly thicker, while the "B" version has a green insert (as far as > I've seen). As far as I know the green or yellow insert AN365-1032 are the same except for the color. I have never seen the "A" suffex applied to these nuts. > > > 3) I can't tell a bit of difference between an AN365-428 and AN365-428A. > Same color insert, same dimensions, same threads. Is there any difference? The AN365-428 is a drilled shank bolt for use with castelated nuts and a cotter key. The AN365-428A has no holes drilled anywhere and is for use with fiber or metal self locking nuts. Gary Zilik ________________________________________________________________________________
Subject:
Date: Sep 08, 2002
Does anyone know of an RV8 QB project either started or not started for sale. AL Malecha www.azflyer(at)theriver.com ________________________________________________________________________________
Date: Sep 08, 2002
> Open mouth, insert foot. Please disregard the following reply. I totally misread the question. Sorry Gary > > > 3) I can't tell a bit of difference between an AN365-428 and AN365-428A. > > Same color insert, same dimensions, same threads. Is there any difference? > > The AN365-428 is a drilled shank bolt for use with castelated nuts and a cotter > key. The AN365-428A has no holes drilled anywhere and is for use with fiber or > metal self locking nuts. > > Gary Zilik > ________________________________________________________________________________
Date: Sep 08, 2002
Bill, I think you might have nailed it...probably just a different manufacturer. I'm guessing Van's found a mfr that makes thinner (and thus LIGHTER) nuts...still haven't called or emailed them to confirm that, but I suspect you're right. Anyway, here are some photos which show the obvious physical differences between the thicker "A" and the thinner "non-A" nuts: http://www.rvproject.com/nuts.html )_( Dan > > ..when would you use an AN365-1032 nut > > as opposed to an AN365-1032A nut? The "A" version has a yellow insert and > > is slightly thicker, while the "B" version has a green insert (as far as > > I've seen). > > > > 3) I can't tell a bit of difference between an AN365-428 and AN365-428A. > > Same color insert, same dimensions, same threads. Is there any difference? > > > > I have no idea what the "A" designation is for. The color usually pertains to > the manufacturer. Unless some specification calls out one versus the other, I > would consider them to be interchangeable. ________________________________________________________________________________
Date: Sep 08, 2002
Dan Checkoway wrote: > > > Bill, > > I think you might have nailed it...probably just a different manufacturer. > I'm guessing Van's found a mfr that makes thinner (and thus LIGHTER) > nuts...still haven't called or emailed them to confirm that, but I suspect > you're right. > > Anyway, here are some photos which show the obvious physical differences > between the thicker "A" and the thinner "non-A" nuts: > > http://www.rvproject.com/nuts.html Dan; In the photos you show, the nuts where only the hex is a different height but the overall nut height is the same, this is simply a manufacturer difference. i.e. Company "A" vs Company "B". In the photos which you show one nut as being physically about half the height of the other, the full height nut is a "standard" nut the half height nut is a "shear" nut only to be used to secure a bolt used in shear and NEVER to be used in a tension application. These are the equivalent to standard bolts and "shear" bolts which also have thin heads. -- Bob McC ________________________________________________________________________________
Subject: Andair fuel selector valve
Date: Sep 08, 2002
I think the big advantage of the Andair valve over the one that comes from Vans is that it has a lock-out so you can't accidentally turn it off when switching tanks. It has a button you have to lift to turn it to off. Terry RV-8A #80729 Canopy Seattle ________________________________________________________________________________
Date: Sep 08, 2002
The photo looks like the difference in a 364 (Shear nut) and a 365 (regular nut)..... Brandon Dixon -----Original Message----- From: Dan Checkoway [mailto:dan(at)rvproject.com] rv7-list(at)matronics.com; SoCAL-RVlist(at)yahoogroups.com Subject: Re: RV-List: 3 questions (fuel selector and nut types) Bill, I think you might have nailed it...probably just a different manufacturer. I'm guessing Van's found a mfr that makes thinner (and thus LIGHTER) nuts...still haven't called or emailed them to confirm that, but I suspect you're right. Anyway, here are some photos which show the obvious physical differences between the thicker "A" and the thinner "non-A" nuts: http://www.rvproject.com/nuts.html )_( Dan > > ..when would you use an AN365-1032 nut > > as opposed to an AN365-1032A nut? The "A" version has a yellow insert and > > is slightly thicker, while the "B" version has a green insert (as far as > > I've seen). > > > > 3) I can't tell a bit of difference between an AN365-428 and AN365-428A. > > Same color insert, same dimensions, same threads. Is there any difference? > > > > I have no idea what the "A" designation is for. The color usually pertains to > the manufacturer. Unless some specification calls out one versus the other, I > would consider them to be interchangeable. ________________________________________________________________________________
Date: Sep 08, 2002
Subject: Re: Roll Bar - plan discrepancies
Ralph; I did this bit on a slowbuild last winter and I have to think that the roll bar is a bit flexible in how it is positioned. In other words a 1/2" forward or back won't matter much if the fit to the other components in the area is OK. There is ample trim material in the canopy to ensure that you can develop a good fit regardless of a 1/2" change in the roll bar position. Dwg SC-2 gives yet another dimension - section C-C says 2 1/2" from the aft face of the 604 to the centreline of the roll bar tube. No surprise that your roll bar base plate is a different than the plans - Van's suppliers do change a things a bit sometimes. Two issues to watch for. As per C-C of dwg SC-4, make sure that the forward AN3 bolt in the base plate is located to leave enough room to get the nut on forward of the front side of the 604. I don't think the plans give a dimension for this hole so its a "suit yourself" situation. Likewise for the aft AN4 bolt. These nuts are tricky to get on at the best of times - so choose a roll bar location and bolt locations that will cause the least added grief! The other thing to watch is the side length of the F-6106 top forward fuselage skin. Do a trial fit and make sure that the overlap over the roll bar is what you need for however you plan to do the windscreen, canopy, canopy skirt, fuse skin join. (They all meet just about there.) Placing the roll bar too far back or trimming the aft side of the skin will leave a gap that you will have to make up somehow. (Guess how I know...) Jim Oke RV-6A slowwww build, finally painting! ----- Original Message ----- From: "Ralph E. Capen" <recapen(at)earthlink.net> Subject: RV-List: Roll Bar - plan discrepancies > > Folks, > > I'm in the process of installing my roll bar...RV6A slider QB #60431. > > Here's my problem: > > Plans sheet SC-1B (as well as old preview plan SC-1) shows the aft edge > of the roll bar (not base plate) 33 1/4" aft of the forward face of the > firewall and 3 1/8" aft of the 604 bulkhead riser. > > Plans sheet SC-4 (old - preview plans...the new ones don't show it at > all) also shows that the base plates for the roll bar weldments are 5 > 1/2" from front to back. > > The base plates for my roll bar weldments are only 5 1/4" from front to > back. If I place the aft edge of the roll bar (again - not the base > plate) as far aft as called for, the forward bolt hole for the base > plate to canopy deck attachment falls around the forward 604 bulkhead > riser plate. > > What is the correct dimension for placement of the roll bar? Do I have > an incorrectly assembled roll bar? Did I miss a plans change? > > I have a digital photo in case anyone thinks they know but aren't > sure... > > Please advise, > Ralph Capen > > ________________________________________________________________________________
Date: Sep 08, 2002
Dan; Looking at your photos, I think that both of your 10-32 nuts are MS20365 (AN365) nuts but from different suppliers. The "thin 428" nut I suspect is actually an MS20364 (= AN364) nut. Van's supplies just a few of these - the canopy roller bolts come to mind - so check your count of these ones. The "fat 428A nut" looks like a garden variety MS20365 (= AN 365) nut which is used in much larger quantities in the aircraft. Have a look at the Wicks online catalog (www.wicksaircraft.com) at page 85 for the difference between a 364 and 365 nut. Jim Oke RV-6A ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> ; Subject: Re: RV-List: 3 questions (fuel selector and nut types) > > Bill, > > I think you might have nailed it...probably just a different manufacturer. > I'm guessing Van's found a mfr that makes thinner (and thus LIGHTER) > nuts...still haven't called or emailed them to confirm that, but I suspect > you're right. > > Anyway, here are some photos which show the obvious physical differences > between the thicker "A" and the thinner "non-A" nuts: > > http://www.rvproject.com/nuts.html > > )_( Dan > > > > ..when would you use an AN365-1032 nut > > > as opposed to an AN365-1032A nut? The "A" version has a yellow insert > and > > > is slightly thicker, while the "B" version has a green insert (as far as > > > I've seen). > > > > > > 3) I can't tell a bit of difference between an AN365-428 and > AN365-428A. > > > Same color insert, same dimensions, same threads. Is there any > difference? > > > > > > > I have no idea what the "A" designation is for. The color usually > pertains to > > the manufacturer. Unless some specification calls out one versus the > other, I > > would consider them to be interchangeable. > > ________________________________________________________________________________
Date: Sep 08, 2002
Subject: [ Kevin ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Kevin Subject: Dual Tanks http://www.matronics.com/photoshare/rv8r300@attbi.com.09.08.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Sep 08, 2002
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)mcleodusa.net>
Subject: Re: requesting advice on spark plug tools
The old Champion spark plug cleaner/testers were pretty hard to beat. I dont have any of them but was alway able to borrow a champion. The bag types look a little "cheesey", but I have never used one. I run some platinum plugs for many years and never do anything to them. The problem I see with the champion is storage, since you will not be using it that often. But if that is not a problem, I would go for it. Also you might look on EBAY for one in the automotive. Just do a search once in a while and see what comes up. A used on would be as good as a new one and there is really nothing that cannot be fixed in one if it needed it... Phil in Litchfield, IL Randall Henderson wrote: > > Our local RV group is considering adding to our tool collection, and I'm > looking for advice/experience on spark plug maintenance tools. > > Among the tools that we collectively own is a condition inspection kit that > includes a spark plug vibrator cleaner, a small "canvas-bag" type abrasive > cleaner, and an inexpensive gapping tool. > > What we're looking at upgrading to is a professional cleaner/tester such as > the Champion CT-4754AV. Sacremento Skyranch carries a similar unit, the > Vixen SPCT100, that is less than half the price (looks suspiciously similar > to the one sold by ATS under their name). Anyone have experience with either > of these? Is it really worth the big bucks to get one? I don't much like the > canvas bag cleaner and we don't currently have any way to test them either. > > The other thing we're looking at is a gap-setting tool. The Champion model > 2500 looks to be pretty neat -- stick the gauge in there and pull the handle > and you're done. Is it really that simple? If so this would be a great > addition to our collection. > > Any thoughts from people who have experience with these tools would be > helpful. Our group will be discussing this at the next meeting. > > Randall Henderson, RV-6 N6R (~400 hrs) > Portland, OR > www.vanshomewing.org > ________________________________________________________________________________
Date: Sep 08, 2002
Subject: [ David Fried ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: David Fried Subject: C-GZDF, Taperwing 6 http://www.matronics.com/photoshare/davefried@rogers.com.09.08.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Subject: EIS 4000 manual - online ?
Date: Sep 08, 2002
Is there a user's manual or operating manual in a file for the EIS 4000 ? I couldn't see one on their webpage. Thanks, Amit. http://www.hotmail.com ________________________________________________________________________________
Date: Sep 08, 2002
Hello all, I do handle heated pitot tubes and manufacture my heated pitot tube mounting bracket kits that are designed to install easily on any RV. You can see my Gretz Aero website of parts and kits at http://www.gretzaero.com I am also available to answer questions at info(at)gretzaero.com or you can contact me on my cell phone that is on at all times at 720-308-0010 or leave me a message on 303-770-3811 ----- Original Message ----- From: "Kevin Horton" <khorto1537(at)rogers.com> Subject: Re: RV-List: Stall speed - pitot tube orientaton > > David > > You can buy short mounts and heated pitot tubes from Warren Gretz at > Gretz Aero. See the RV Yeller Pages for contact info. > > The Gretz mount is a good, well proven way to add a heated pitot > tube, if you need one. I recommend that if you do this, that you > don't put the static source on the tube, as that has been shown on > some RVs to lead to static system errors. We don't need heated > static ports, even if we fly IFR. Unheated aft fuselage static ports > have a very good service history on many aircraft types. You aren't > going to collect ice back there unless you decide to do sustained > sideslips with large rudder deflections. > > Note: The Gretz pitot tube mount puts the pitot tube in about the > same location as Van's design because there is nothing wrong with > Van's design. You are trying to solve a problem (pitot system error) > that probably doesn't exist. I have seen results of flight testing > of quite a few pitot-static systems, and the results match the theory > - i.e. pitot system errors are very unlikely (except for leaks). > Static system errors are the real problem. > > Glen is correct that the airflow under the wing will be roughly > aligned with the pitot tube. I've seen results from tests done by > NACA that showed that as long as the local airflow is aligned within > about 15 degrees of the pitot tube the resulting error will be very > small. Van's pitot tube location easily meets this criteria. > > If you are looking for a mod to make to the airplane just because you > like building more than flying, then fill your boots. But if you are > thinking about moving the pitot tube to improve its accuracy you are > wasting your time and money. > > Take care, > > Kevin Horton RV-8 (spinner, cowling) > Ottawa, Canada > http://members.rogers.com/khorton/rv8.html > > > > > >Glen, > > > >Thanks for your excellent info. Your assessment of "local relative wind" > >being parallel to lower wing skin regardless of AOA seems valid to me. > >Saves a lot of "Rube Goldberg" options that I was spouting out. > > > >Where did you find this "short mast pitot tube" and "Gretz mast"? Brand > >name, part number, which company sells? Sorry for the uneducated question > >but I haven't done any shopping for these parts yet (wings not yet mounted). > >Could you give a description of where you mounted "sufficiently far back" - > >maybe a measurement aft to to the edge of wing skin just in front of flap, > >and a distance outboard from side of fuselage or that stubby section of skin > >that sticks out from fuselage that the wing slides over when installed? > > > >David Carter > > > >----- Original Message ----- > >From: "glen j matejcek" <aerobubba(at)compuserve.com> > >To: > >Subject: RV-List: Stall speed - pitot tube orientaton > > > > > >> > >> David- > >> > >> Re: "As I believe that a fixed, single hole pitot tube is the primary > >> cause of the low speed errors (air is not directed straight into the pitot > >> tube at high AOA),..." > >> > >> One of the several reasons I chose a short mast pitot tube on a Gretz > >mount > >> is that the pitot pressure orifice is sufficiently far back along the wing > >> chord and close to the wing skin that the local relative wind should > >always > >> be essentially parallel to the wing skin / pitot axis. If memory serves, > >> the Cessna pitot tubes tend to be mounted relatively forward along the > >> chord, perhaps inducing the errrors you speak of.... > >> > >> Glen > > > -8 QB, fuse upside down > > ________________________________________________________________________________
Date: Sep 08, 2002
I recently installed the Gretz Aero heated pitot (sans static) and was very pleased both with Gretz and the quality of the product. I got the RV-friendly mounting bracket kit and that made things very, very straightforward. If you can cut a decent hole in your wing skin, the rest is pretty much idiot-proof. I can vouch for Gretz Aero producing good stuff in that department. You might get the install kit and think to yourself, man this is simple stuff, I could have made this myself easily...but for me it was worth the money to save the hassle and head scratching. Here are some pictures of the installation process, in case anybody wants 'em for reference: http://www.rvproject.com/20020722.html#pitot http://www.rvproject.com/20020724.html )_( Dan RV-7 N714D (fuselage) http://www.rvproject.com ----- Original Message ----- From: "gretz aero" <warrengretz(at)gretzaero.com> Subject: Re: RV-List: Stall speed - pitot tube orientaton > > Hello all, > I do handle heated pitot tubes and manufacture my heated pitot tube mounting > bracket kits that are designed to install easily on any RV. > You can see my Gretz Aero website of parts and kits at > http://www.gretzaero.com I am also available to answer questions at > info(at)gretzaero.com or you can contact me on my cell phone that is on at all > times at 720-308-0010 or leave me a message on 303-770-3811 > ----- Original Message ----- > From: "Kevin Horton" <khorto1537(at)rogers.com> > To: > Subject: Re: RV-List: Stall speed - pitot tube orientaton > > > > > > David > > > > You can buy short mounts and heated pitot tubes from Warren Gretz at > > Gretz Aero. See the RV Yeller Pages for contact info. > > > > The Gretz mount is a good, well proven way to add a heated pitot > > tube, if you need one. I recommend that if you do this, that you > > don't put the static source on the tube, as that has been shown on > > some RVs to lead to static system errors. We don't need heated > > static ports, even if we fly IFR. Unheated aft fuselage static ports > > have a very good service history on many aircraft types. You aren't > > going to collect ice back there unless you decide to do sustained > > sideslips with large rudder deflections. > > > > Note: The Gretz pitot tube mount puts the pitot tube in about the > > same location as Van's design because there is nothing wrong with > > Van's design. You are trying to solve a problem (pitot system error) > > that probably doesn't exist. I have seen results of flight testing > > of quite a few pitot-static systems, and the results match the theory > > - i.e. pitot system errors are very unlikely (except for leaks). > > Static system errors are the real problem. > > > > Glen is correct that the airflow under the wing will be roughly > > aligned with the pitot tube. I've seen results from tests done by > > NACA that showed that as long as the local airflow is aligned within > > about 15 degrees of the pitot tube the resulting error will be very > > small. Van's pitot tube location easily meets this criteria. > > > > If you are looking for a mod to make to the airplane just because you > > like building more than flying, then fill your boots. But if you are > > thinking about moving the pitot tube to improve its accuracy you are > > wasting your time and money. > > > > Take care, > > > > Kevin Horton RV-8 (spinner, cowling) > > Ottawa, Canada > > http://members.rogers.com/khorton/rv8.html > > > > > > > > > >Glen, > > > > > >Thanks for your excellent info. Your assessment of "local relative wind" > > >being parallel to lower wing skin regardless of AOA seems valid to me. > > >Saves a lot of "Rube Goldberg" options that I was spouting out. > > > > > >Where did you find this "short mast pitot tube" and "Gretz mast"? Brand > > >name, part number, which company sells? Sorry for the uneducated > question > > >but I haven't done any shopping for these parts yet (wings not yet > mounted). > > >Could you give a description of where you mounted "sufficiently far > back" - > > >maybe a measurement aft to to the edge of wing skin just in front of > flap, > > >and a distance outboard from side of fuselage or that stubby section of > skin > > >that sticks out from fuselage that the wing slides over when installed? > > > > > >David Carter > > > > > >----- Original Message ----- > > >From: "glen j matejcek" <aerobubba(at)compuserve.com> > > >To: > > >Subject: RV-List: Stall speed - pitot tube orientaton > > > > > > > > > >> > > >> David- > > >> > > >> Re: "As I believe that a fixed, single hole pitot tube is the primary > > >> cause of the low speed errors (air is not directed straight into the > pitot > > >> tube at high AOA),..." > > >> > > >> One of the several reasons I chose a short mast pitot tube on a Gretz > > >mount > > >> is that the pitot pressure orifice is sufficiently far back along the > wing > > >> chord and close to the wing skin that the local relative wind should > > >always > > >> be essentially parallel to the wing skin / pitot axis. If memory > serves, > > >> the Cessna pitot tubes tend to be mounted relatively forward along the > > >> chord, perhaps inducing the errrors you speak of.... > > >> > > >> Glen > > > > -8 QB, fuse upside down > > > > > > ________________________________________________________________________________
Date: Sep 08, 2002
I bought the bag type from Northern Hydralics and it works great. Earl RV4 "Phil Sisson, Litchfield Aerobatic Club" wrote: > > The old Champion spark plug cleaner/testers were pretty hard to beat. > I dont have any of them but was alway able to borrow a champion. The bag types > look a little "cheesey", but I have never used one. > > I run some platinum plugs for many years and never do anything to them. The > problem I see with the champion is storage, since you will not be using it that > often. > > But if that is not a problem, I would go for it. Also you might look on EBAY for > one in the automotive. Just do a search once in a while and see what comes up. > > A used on would be as good as a new one and there is really nothing that cannot > be fixed in one if it needed it... > > Phil in Litchfield, IL > > Randall Henderson wrote: > > > > > Our local RV group is considering adding to our tool collection, and I'm > > looking for advice/experience on spark plug maintenance tools. > > > > Among the tools that we collectively own is a condition inspection kit that > > includes a spark plug vibrator cleaner, a small "canvas-bag" type abrasive > > cleaner, and an inexpensive gapping tool. > > > > What we're looking at upgrading to is a professional cleaner/tester such as > > the Champion CT-4754AV. Sacremento Skyranch carries a similar unit, the > > Vixen SPCT100, that is less than half the price (looks suspiciously similar > > to the one sold by ATS under their name). Anyone have experience with either > > of these? Is it really worth the big bucks to get one? I don't much like the > > canvas bag cleaner and we don't currently have any way to test them either. > > > > The other thing we're looking at is a gap-setting tool. The Champion model > > 2500 looks to be pretty neat -- stick the gauge in there and pull the handle > > and you're done. Is it really that simple? If so this would be a great > > addition to our collection. > > > > Any thoughts from people who have experience with these tools would be > > helpful. Our group will be discussing this at the next meeting. > > > > Randall Henderson, RV-6 N6R (~400 hrs) > > Portland, OR > > www.vanshomewing.org > > > ________________________________________________________________________________
Date: Sep 08, 2002
Subject: Re: RV8-List:
there was one on the white p[ages this morning...I also have a RV8A qb 99/95%completed if you are interisted... Al Malecha wrote: > --> RV8-List message posted by: "Al Malecha" > > Does anyone know of an RV8 QB project either started or not started for > sale. > AL Malecha > www.azflyer(at)theriver.com > ________________________________________________________________________________
Subject: Electrical Gyros for Sale
Date: Sep 08, 2002
I'm selling my two electrical gyros, ie, the DG and artificial horizon. These are RC Allen gyros, each of which have been run regularly until removed from my airplane two weeks ago in my latest panel redesign. They are not under warranty from the manufacturer (actually the DG still has a few weeks of warranty left), but I will guarantee them for thirty days to afford the buyer a chance to inspect them. Each is supplied with the appropriate connector, so all one has to do is splice the two wires to power and ground. The horizon has the RV panel tilt of of 8 degrees installed and is placarded as such on the side by the manufacturer. The DG was purchased on 9-21-01, the horizon on 8-28-00. The new price for these gyros is about $1,850 each. I'm asking $1,500 each. Jerry Carter RV-8A 150 hrs ________________________________________________________________________________
Subject: Re: Air-Conditioning in an RV6
Date: Sep 08, 2002
Putting an air conditioner in is completey doable. Wouldn't be any heavier than an inverted oil system. Look for a system out of a very small car. There are custom aftermarket auto kits available in the states. Some one indicated C of G would be a problem but I've noticed that many people put Hartzell constant speed props on RV6's which weigh some thing like 50 lbs more than a wood prop and look how far forward that weight is. If an RV6 can handle that range of C of G then an air conditioner should be no problem. Are you going with a wood prop? C of G would be of no concern. Going with a constant speed? Use one of the new composite props that are something like twenty pounds lighter than the Hartzell constant speed prop. C of G would be of no concern. You'll be able to find a complete air conditioning system for under 20 lbs. To each his own, if you want it, do it. Norman Hunger RV6A Canada no air conditioner required go ahead and archive > David Roseblade wrote: > > > > > Listers, > > > > Has anyone contemplated putting an AC in an RV6?, we fly out here in the > > Persian Gulf, where the temp is HOT ie today was 40 C + 60% humidity, our > > 1976 vintage! PA 28's have a factory fit AC, but are not that effective. > > > > I would probably install a lightweight Japanese compressor driven by the > > engine (dual pulley flywheels are available) an electrically operated > > evaporator door with a switch on the throttle quadrant which would cut off > > the compressor and retract the evaporator door for take-off (should I forget > > to do it). If there are any installations installed I would be interested on > > what parts were used and effectiveness. > > > > n.b Only needed below 8000' > > > > Regards > > > > David Roseblade > > > > RV6A - Finish kit - working canopy in air conditioned comfort. > > Dubai, UAE ________________________________________________________________________________
Subject: Re: Regarding RV-7A empennage parts with vinyl coating
Date: Sep 08, 2002
I did not like the rust underneath the powder coating on the few steel parts that were done when I got my finishing kit. This was a few years ago when Van first started shipping stuff with the powder coat. I much prefer my own quality control cleaning and prepping, then priming with super korapon, then painting with Sherwin Williams Sunfire. I feel no production line can match the quality that I have put into every piece of my airplane. If doing another kit, I will order without the powder coat. I understand it is an option but Van will not reduce the price. Oh well..... Norman Hunger RV6A West coast of Canada where moisture is a major concern. > Like I said in the opening line "it's (arguably) probably....... > > That pretty much sums it up. > > Mike > > > > > What you're seeing is the powder coating. It's (arguably) probably the > best > > > coating you can have on your steel parts. > > > > I don't want to start a fight, but just out of curiosity, I would like to > > hear your view of the facts (the testable hypothesis that is science) that > > supports this statement. Or did you really mean IMHO (religion or belief > not > > necessarily based on factual evidence)? > > > > -GV (RV-6A N1GV 566hrs) > > > > > > ________________________________________________________________________________
Subject: Impulse mag
Date: Sep 08, 2002
Listers; I suspect the pins in the impulse mag have become worn since it is taking some cranking to start it all of a sudden. When the Sears Die Hard garden tractor battery starts to give out, the engine starts. I think that is an indication of the pins being worn. Are mags very difficult to repair? Where are parts available? If I do not do it, who repairs them and what does it cost? The mags were new about 450 hours ago. John Kitz N721JK Ohio ________________________________________________________________________________
Date: Sep 08, 2002
Norman wrote: > > > Putting an air conditioner in is completey doable. Wouldn't be any heavier > than an inverted oil system. Look for a system out of a very small car. > There are custom aftermarket auto kits available in the states. > > Some one indicated C of G would be a problem but I've noticed that many > people put Hartzell constant speed props on RV6's which weigh some thing > like 50 lbs more than a wood prop and look how far forward that weight is. > If an RV6 can handle that range of C of G then an air conditioner should be > no problem. > > Are you going with a wood prop? C of G would be of no concern. Going with a > constant speed? Use one of the new composite props that are something like > twenty pounds lighter than the Hartzell constant speed prop. C of G would be > of no concern. You'll be able to find a complete air conditioning system for > under 20 lbs. > > To each his own, if you want it, do it. > > Norman Hunger > RV6A Canada > no air conditioner required > go ahead and archive > > > David Roseblade wrote: > > > > > > > > > Listers, > > > > > > Has anyone contemplated putting an AC in an RV6?, we fly out here in the > > > Persian Gulf, where the temp is HOT ie today was 40 C + 60% humidity, > our > > > 1976 vintage! PA 28's have a factory fit AC, but are not that effective. > > > > > > I would probably install a lightweight Japanese compressor driven by the > > > engine (dual pulley flywheels are available) an electrically operated > > > evaporator door with a switch on the throttle quadrant which would cut > off > > > the compressor and retract the evaporator door for take-off (should I > forget > > > to do it). If there are any installations installed I would be > interested on > > > what parts were used and effectiveness. > > > > > > n.b Only needed below 8000' > > > > > > Regards > > > > > > David Roseblade > > > > > > RV6A - Finish kit - working canopy in air conditioned comfort. > > > Dubai, UAE > I used a Vintage Air after market unit in my 1967 Camaro they now make some really small units that might be adapted to aircraft use. http://www.vintageair.com/vintage.htm This link takes you to their home page then check out the *universal evaporator* button. Jerry ________________________________________________________________________________
Subject: Re: Impulse mag
Date: Sep 08, 2002
The first question is always what brand of mags are they. There are several ADs on Bendix mags and their impulses. There are limits to the play in the weight pins. You might find a mechanic that will have the tools, manuals, and most importantly the expertise to check and o'haul if necessary. But there are other things that make starting difficult. Plugs and plug gaps come to mind. Have you cleaned and gaps your plugs? This is frequently the problem when it comes to hard starting. Have you done a compression check? You might have an exhaust valve hanging. I would check the compression and clean the plugs before I got excited about the mags. Then I would check the static timing of the mags before their removal. If the above didn't fix the starting problem, I would replace the points and condensor and re-time the mags internally, re-install, and time the mags to the engine. If that simple replacement didn't work, I would buy either re-built Bendix or if Slick's, factory new which would be the cheaper route. ----- Original Message ----- From: "John Kitz" <JKITZ1(at)columbus.rr.com> Subject: RV-List: Impulse mag > > Listers; > I suspect the pins in the impulse mag have become worn since it is > taking some cranking to start it all of a sudden. When the Sears Die > Hard garden tractor battery starts to give out, the engine starts. I > think that is an indication of the pins being worn. > Are mags very difficult to repair? Where are parts available? If I do > not do it, who repairs them and what does it cost? > The mags were new about 450 hours ago. > John Kitz > N721JK > Ohio > > ________________________________________________________________________________
Date: Sep 08, 2002
John: You have wandered into an area where the answer really is: It all depends. The pricing policy of Slick (Unison) is such that it does not take many needed parts to make the price of a new mag the way to go. They do this intentionally to get the old junkers out of the market and newer ones in your airplane. If you are quite certain that the problem is in the mag, the best way to go about tearing into it is to get a copy of the overhaul manual. I think it costs about 40 dollars and has step by step procedures for disassembling, inspecting and reassembling the mag. However, some of this requires either special tools or some ingenuity to get around them. Don't know what you mean by "pins," unless it is the stop pin in the frame that catches the impulse coupling pawls as the engine begins to rotate. If this has failed you will not hear the distinct clanking sound that the mag makes. But you could also have bad points, condenser or coil, all of which would cause operational problems. Frankly, I think your best bet is to get someone who knows the mag to look at the problem and give you some feedback. You can get parts and mags from Chief, Aircraft Spruce, etc. IF the problem is in the mag (have you looked at spark plug gaps?), only some testing will determine if it is more cost effective to fix it or replace it. Bill Marvel John Kitz wrote: > > Listers; > I suspect the pins in the impulse mag have become worn since it is > taking some cranking to start it all of a sudden. When the Sears Die > Hard garden tractor battery starts to give out, the engine starts. I > think that is an indication of the pins being worn. > Are mags very difficult to repair? Where are parts available? If I do > not do it, who repairs them and what does it cost? > The mags were new about 450 hours ago. > John Kitz > N721JK > Ohio > -- Bill Marvel Home/office 310 832 7617 P.O. Box 784 Cell 310 293 2013 San Pedro, CA 90733 Fax 310 832 5334 One good deed beats 100 good intentions... ________________________________________________________________________________
Date: Sep 08, 2002
John, If you can hear the click of the impulse when you trun the prop, it isn't the impulses. They have two functions. One to retard the spark. Two, to increase the rotational speed of the mag to provide a hotter spark when starting. So if you here the click of the impulse, both those things are happening. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org Always looking for articles for the Experimenter ----- Original Message ----- From: "John Kitz" <JKITZ1(at)columbus.rr.com> Subject: RV-List: Impulse mag > > Listers; > I suspect the pins in the impulse mag have become worn since it is > taking some cranking to start it all of a sudden. When the Sears Die > Hard garden tractor battery starts to give out, the engine starts. I > think that is an indication of the pins being worn. > Are mags very difficult to repair? Where are parts available? If I do > not do it, who repairs them and what does it cost? > The mags were new about 450 hours ago. > John Kitz > N721JK > Ohio > > ________________________________________________________________________________
Subject: Tank gap
Date: Sep 08, 2002
Ok, I sealed up the baffle on the left tank. Everything seemed to go real well until I placed the tank on the spar. The tank has a increasing gap from zero at the inboard end to about a 1/16" gap at the outboard end.It's enough that the holes to the splice piece don't line up and the screws into the platenuts on the spar don't want to go in after about half way up the tank from the inboard end. They go in easy at the inboard side. I didn't fully coat the tank baffle brackets per the instructions so am surpised if it is too much proseal. I suppose there could be too much between the ribs and the skin although the rivets went in real nice there. All the rivets to the tank from the baffle went in nice. Now what. Is there some fix to this or do I either live with the gap or start all over. Curt Hoffman RV-9A wings 1968 Mustang 302 convertible Piper Cherokee N5320W ________________________________________________________________________________
Date: Sep 08, 2002
Subject: Re: Aerospace Logic Guages
I talked to them at length about their products. They seem quite knowledgeable and helpful. They offer an additional discount when you purchase more than one instrument. I told them I was not interested in the cht if it came with the ring type probes abd they offered the bayonet type for $18 more total! I have not received them yet but should in a few days. Stewart, RV4 flying... ________________________________________________________________________________
Date: Sep 08, 2002
Dan Checkoway wrote: > > 2) I'm not an A&P, so go easy on me...when would you use an AN365-1032 nut > as opposed to an AN365-1032A nut? The "A" version has a yellow insert and > is slightly thicker, while the "B" version has a green insert (as far as > I've seen). > > 3) I can't tell a bit of difference between an AN365-428 and AN365-428A. > Same color insert, same dimensions, same threads. Is there any difference? > I just looked these nuts up in the Aircraft Spruce catalog. As far as the thin nuts, they are should be AN364 = (thin) stop nuts for use in structural applications were the bolt is loaded primarily in shear or in any application where the tensile strength of a regular height AN365 is not required. The different color plastic insert is just a different supplier. AN364 and AN365 stop nuts that end in an "A" are CAD Plateded, those that have no A at the end are commercial grade stainless. AN365-428 should be stainless, AN365-428A should be CAD plated. -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Working on the wings :-) ________________________________________________________________________________
Date: Sep 08, 2002
Subject: Re: Tank gap
In a message dated 9/8/02 9:14:45 PM Eastern Daylight Time, choffman9(at)cinci.rr.com writes: << Ok, I sealed up the baffle on the left tank. Everything seemed to go real well until I placed the tank on the spar. The tank has a increasing gap from zero at the inboard end to about a 1/16" gap at the outboard end.It's enough that the holes to the splice piece don't line up and the screws into the platenuts on the spar don't want to go in after about half way up the tank from the inboard end. They go in easy at the inboard side. I didn't fully coat the tank baffle brackets per the instructions so am surpised if it is too much proseal. I suppose there could be too much between the ribs and the skin although the rivets went in real nice there. All the rivets to the tank from the baffle went in nice. Now what. Is there some fix to this or do I either live with the gap or start all over. Curt Hoffman RV-9A wings 1968 Mustang 302 convertible Piper Cherokee N5320W >> First, take the tank off and look at it carefully. Look at the spar attachment area too. Make darned sure there is nothing obvious that is preventing the tank from sliding into place. If that doesn't work, hammer maintenance probably will: Take a wood block. Place it against the leading edge of your wing. Make sure it bridges two or more ribs. Take a hammer - ball peen, claw, sledge, or whatever, and tap the wood block to encourage the tank into place. Be sure to only tap in locations that line up with ribs. A little force will go a long way... Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Sep 08, 2002
From: glen j matejcek <aerobubba(at)compuserve.com>
Subject: Stall speed - pitot tube orientaton
Hi Dave- I got my pitot and mast from Aircraft Spruce. If I recall correctly, the pitot was slightly cheaper at Wicks, but they didn't carry the mast. In the latest Sruce catalog, they're on pg 337, top right. I used the #AN5812-12 pitot-only tube and Van's static kit, along with the Gretz mast # 10-01950. The pitot tube is made by Aero Instrument Co., Inc., 14901 Emery Ave., Cleveland, Oh 44135. Mfg's part number P. H. 502-12 CR. I have no idea if they sell direct or what they would charge. The mounting mast seems to me to be pretty well thought out and executed. Gretz Aero: Warren Gretz, 3664 E Lake Dr., Littleton, CO 80212. 303-770-3811, info(at)gretzaero.com, www.gretzaero.com. I mounted my pitot (on my rv-8QB) just outboard of the rib that is just outboard of the most outboard inspection cover, just aft of the spar. That puts it about a foot outboard and a couple inches aft of the stock vans location. by placing it there, the pitot and mount are accessible for mx, but still pick up the spar and a rib for strength and rigidity. That position puts the pitot in the section of skin I had to install, simplifying the whole process. I ran my pitot pressure line between the axis of the ail bellcrank and the spar web. It took a little tinkering and fiddling before I convinced myself I was gonna drill in the right spot, but I really like the way it turned out. At the moment, the bracket is in the stored wing, and the mast and tube are in a drawer (somewhere, I think....) so I can't do any damage with or to the mast sicking out of the bottom skin. Pretty slick, I think. Wish I'd a thought of it... Glen RV-8QB, patiently awaiting mating with it's wings... ________________________________________________________________________________
Date: Sep 08, 2002
In a message dated 9/8/02 9:14:45 PM Eastern Daylight Time, choffman9(at)cinci.rr.com writes: > Ok, I sealed up the baffle on the left tank. Everything seemed to go > real well until I placed the tank on the spar. > The tank has a increasing gap from zero at the inboard end to about a > 1/16" gap at the outboard end.It's enough that the holes to the splice > piece don't line up and the screws into the platenuts on the spar don't > want to go in after about half way up the tank from the inboard end. > They go in easy at the inboard side Hi Curt, The same thing happened to me on my RV-4. It turned out to be just a little proseal that had squeezed out from under the baffle. I trimmed it off & everything fit fine. Hal Benjamin RV-4, Fuselage Long Island, NY ________________________________________________________________________________
Date: Sep 08, 2002
Curt Hoffman wrote: > > Ok, I sealed up the baffle on the left tank. Everything seemed to go > real well until I placed the tank on the spar. > The tank has a increasing gap from zero at the inboard end to about a > 1/16" gap at the outboard end.It's enough that the holes to the splice > piece don't line up and the screws into the platenuts on the spar don't > want to go in after about half way up the tank from the inboard end. > They go in easy at the inboard side. > I didn't fully coat the tank baffle brackets per the instructions so am > surpised if it is too much proseal. I suppose there could be too much > between the ribs and the skin although the rivets went in real nice > there. All the rivets to the tank from the baffle went in nice. > Now what. Is there some fix to this or do I either live with the gap or > start all over. > > Curt Hoffman > RV-9A wings > 1968 Mustang 302 convertible > Piper Cherokee N5320W > When I installed my tank I started putting the screws in at the top of the splice plate and then from the outboard end then worked toward the inboard end the holes on the inboard end did not look like they were going to align, but with each screw they pulled in closer and closer untill it finally went on. Maybe that might work for you. -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Working on the wings :-) ________________________________________________________________________________
Date: Sep 08, 2002
Subject: Strength of riveted joints
Bill Marvel posted a very interesting message to the RV-List a few days about the strength of riveted joints. The message summarized the actual pull tests between aluminum coupons with different types of rivets, and with various rivet conditions (over-driven, correctly driven, under-driven). With Bill's permission, I have put his original message on my web site, so it is permanently available. See: http://members.rogers.com/khorton/rvlinks/marvelrivets.html -- Kevin Horton RV-8 (spinner, cowling) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
Subject: Pointer ELT?
Date: Sep 08, 2002
Not much in the archives about the Pointer brand ELT. Anybody using one? Feedback? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com>
Subject: Re: Flutter (was: flying the wing - GO OUT AND TRY IT)
Date: Sep 08, 2002
----- Original Message ----- From: "3 rotor" <rv8r300(at)attbi.com> Subject: Re: RV-List: Flutter (was: flying the wing - GO OUT AND TRY IT) > > when I first started a conversation with this man after he started ripping > the -8, I was going to "straighten" him out as far as the -8 story, I was in > fact at a sailplane convention. The more he spoke the more I realized this > guy wasn't just spouting off, but was a professional flutter expert, Include me among those who are skeptical about Martin Hollman. Having talked with the man, sat with him while he "held court with those who came by to pay obiesance to him and looked at the Stallion, I concluded he was consummately skilled at tooting his own horn. He jumped, nay leaped to the conclusion that the RV-8 wing failure was flutter induced without a scintilla of evidence to support the idea. As has been said, he offered to do flutter analysis for free but when someone suggested he actually do it, it was suddenly to cost money. But the crowning event, for me, was the affair referred to already about Cringley or whingley or whoever was going to build and fly an airplane in 30 days. That he had no hope in hell of succeeding made the exercise amusing. But the insult was when, after spending 3 weeks, or whatever, to bring the fuselage to the point where it looked a little like a boat, the word came down that the designer had made a mistake and the wing location was so badly misplaced that it would be necessary to start over. The designer of course was Martin Hollman (and you can bet he did not do it for free). I doubt if the producers got their money back. Gordon Comfort N363GC ________________________________________________________________________________
Date: Sep 08, 2002
> >Folks, > >I'm in the process of installing my roll bar...RV6A slider QB #60431. Mainly, make sure it is square with the fuselage. K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Sep 08, 2002
Well, okay, you've burst my bubble! I guess I am easily impressed. So Martin Hollman is a fraud. Sniff... I'm going out into the garden now to eat worms and its all your fault. K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Sep 08, 2002
-----Original Message----- From: John Kitz <JKITZ1(at)columbus.rr.com> Date: Sunday, September 08, 2002 6:02 PM Subject: RV-List: Impulse mag > >Listers; >I suspect the pins in the impulse mag have become worn since it is >taking some cranking to start it all of a sudden. When the Sears Die >Hard garden tractor battery starts to give out, the engine starts. I >think that is an indication of the pins being worn. >Are mags very difficult to repair? Where are parts available? If I do >not do it, who repairs them and what does it cost? >The mags were new about 450 hours ago. >John Kitz >N721JK >Ohio > > >John, My experience with Slick mags has been 3 failed coils in 825 hrs. They are fairly easy to change if you have a way to remove the wedges that secure them (I use a modified slide hammer ). Aircraft Spruce carries them for about $140??? If the secondary winding has infinite resistance then its a sure bet the coil is the culprit. Unfortunately, the coil can pass a resistance test (about 17K ohms) and still fail to produce a satisfactory spark since this test puts no load on it. You do need to know how to time the mag both internally and to the engine to do this work. If you are unfamiliar with this then try finding soneone to help. Its not especially difficult. Ivan Haecker RV-4 825hrs ================================================================== > > ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Re: Pointer ELT?
In a message dated 9/8/2002 8:06:55 PM Pacific Daylight Time, Larry(at)bowenaero.com writes: > Not much in the archives about the Pointer brand ELT. Anybody using > one? Feedback? I had one in my old Kitfox and it worked fine. Replacement batteries were a little pricey though. -GV (RV-6A N1GV 566hrs) ________________________________________________________________________________
Subject: my next RV will have folding wings!!!!!
Date: Sep 08, 2002
we snuck into the Reno air race preparations today, well actually flew in with tower permission (OK, so maybe Lyle doesn't know us personally, but...) This made flying into OSH child's play. On final, six T-4's on knife edge passed directly in front of me at perhaps 50 above the ground and what, 220 mph? forcing me to do a 360 while, to my amazement, the tower said nothing! (well, they did warn us to watch for traffic) ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Rollbar
Hi Ralph... I'm just finishing up my canopy, thank God, on my RV6a QB # 60534 so am very familiar with the parts you mention. I just went out to look at mine and refresh my memory on the piece you're concerned with. My measurments are the same as yours in that the rear of the roll bar is 33.25" aft of the firewall and the base plate is 5.25". At the time I installed this I had minimal room to place the forward bolt and remember a couple other builders complained of this also. Don't know why Van's skimped on the length of the baseplate, but no matter. In my opinion, the fore/aft placement of the rollbar is not that critical. What is critical is to give yourself enough room to insert the forward bolt. Possibly your F604 might be off by .25" and that would be enough to cause your problem, hard to say. I would carefully place the rollbar making sure it is at 90 deg. to the canopy deck/longeron and has room for the forward bolt and nut. If you have to move it forward by .25", should not matter a whit. Just means the canopy will slide forward another .25", that's all. Hope this helps and if you need further assistance with the canopy, email me directly. jerry2dt(at)aol.com Cheers, Jerry Cochran Wilsonville, Oregon RVa/finish kit In a message dated 9/8/02 11:57:33 PM, rv6-list-digest(at)matronics.com writes: << Folks, I'm in the process of installing my roll bar...RV6A slider QB #60431. Here's my problem: Plans sheet SC-1B (as well as old preview plan SC-1) shows the aft edge of the roll bar (not base plate) 33 1/4" aft of the forward face of the firewall and 3 1/8" aft of the 604 bulkhead riser. Plans sheet SC-4 (old - preview plans...the new ones don't show it at all) also shows that the base plates for the roll bar weldments are 5 1/2" from front to back. The base plates for my roll bar weldments are only 5 1/4" from front to back. If I place the aft edge of the roll bar (again - not the base plate) as far aft as called for, the forward bolt hole for the base plate to canopy deck attachment falls around the forward 604 bulkhead riser plate. What is the correct dimension for placement of the roll bar? Do I have an incorrectly assembled roll bar? Did I miss a plans change? I have a digital photo in case anyone thinks they know but aren't sure... Please advise, Ralph Capen >> ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Re: [ David Fried ] : New Email List Photo Share Available!
Congratulations David, I have been waiting for you to get your tapered wing into the air. I am interested in flight reports especially stall, spin and performance characteristics. I cannot recall, did you build any twist (ie washout) into this wing? Doug Gray ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Infinity Stick Grips
Listers- Food for thought- Murphy's law dictates that if I were to put my starter button on my stick grip, there WOULD come a time while folding a chart, eating a sandwich, or whatever that I accidentally engage it.... Glen Soon to be re-employed and furiously filling out order forms.... ________________________________________________________________________________
Subject: Re: Infinity Stick Grips
Date: Sep 09, 2002
Figure out your longest wiring run, add two feet, and order that much wire. I didn't do this and ended up having to find comparable wire (number of pairs) and do the mother-of-all splice bundles . . . and all of this was a pain. Rick Jory RV8A ----- Original Message ----- From: Ken Brooks <kdbrv8r(at)charter.net> Subject: RV-List: Infinity Stick Grips > > I would appreciate some info from other Infinity Stick Grip users. What > length of wire was required for front and rear grips in the RV-8 (for > ordering purposes). They come with 3 feet, and it's $2.00 per foot over > that. Measuring from the rear seat stick, I came up with 11 feet, worst > case scenario. Stick button/switch functions will be the same for pilot > and rear seater. Thanks in advance. > > Ken Brooks > Roscoe, IL > N1903P resvd - starting panel and stick wiring > > ________________________________________________________________________________
Date: Sep 09, 2002
There are dozens of -8's of varying "aileron system tightness" and configuration that have been flying thousands of hours with no reported flutter symptoms. Mine alone has ~430 hrs and behavior no different than publically discussed here and at other public forums (BIG knock on wood!). I'm pretty conservative - rarely flown into the yellow - but there are those I've witnessed flying the heck out of their -8's (fast and high load factors). They're still holding together and (gratefully) keeping the limits of the envelope well proven. About the factory -8 accident. I recall hearing nothing about aileron damage symptomatic of flutter. While other companies might try and conceal a weakness of their product, I cannot believe Van would even consider it. Flutter discussions can be like metallurgical discussions, in that they *can* go from firm science to opinion and grayness pretty quickly. At work, I've been in situations where the resident "metallurgical expert" spews out things like "the failure was due to grain boundary fatigue corrosion errosion due to chloride stress delmination and dilution, blah, blah, blah..." Say what?!?! How do you tell the manager that their favorite "metallurgist" sounds pretty smart, but is really full of hot air? Sounds like what *may* be happening here. Bryan Jones -8 Pearland, Texas ________________________________________________________________________________
Date: Sep 09, 2002
5.0.11 |July 24, 2002) at 09/09/2002 09:31:02 AM, Serialize complete at 09/09/2002 09:31:02 AM > > Ken and others, > Some switch functions have to be isolated so that only one handle > works at a time. To accomplish this, I isolated the ground return > through a single pole switch on the panel. This opens a bag of worms > where you have press on/press off switches on the handle. There is no > simple way to tell the state of a switch when changing the handle > authority, therefore except for flaps (lever type switch), my second > handle is not wired with those functions that have a push on/push off > switch. You can alleviate this problem by using momentary ON switches to toggle the state of a latching relay. -- James o o o o o o o . . . _______________________ _______=======_T___ o _____ |James Madill | |Duke Univ Med Ctr| >.][__n_n_| D[ ====|____ |james.madill(at)duke.edu| | (919) 286-6384 | (________|__|_[____/____]_|_____________________|_|_________________| _/oo O-O-O ` oo oo 'o o o o o o` 'o o o o` -+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+- <http://www.duke.edu/~madil001/> ________________________________________________________________________________
Subject: RV8 fuel access hole ????
Date: Sep 09, 2002
I'm utilizing the flop tube in my left tank (RV8). The plans don't cover the hole in the baffle very well. Should it be just large enough for the sender or similar to the access opening in the normal tank? I did order a cover plate from Van's so maybe that means the larger size. Thanks, Jack Textor RV8 DSM Jack Textor PERSONNEL INCORPORATED PLACEMENTS / OUTPLACEMENTS TESTING / TEMPORARY STAFFING Serving Clients For More Than 39 Years 604 Locust, Suite 516 Des Moines, IA 50309 515-243-7687 phone 515-243-3350 fax www.iaJobs.com jack(at)iaJobs.com ________________________________________________________________________________
Date: Sep 09, 2002
Contact Jeff : jeff(at)jarlin.com her has an RV8 that is in progress. He may be interested?. Dave ----- Original Message ----- From: "Al Malecha" <azflyer(at)theriver.com> Subject: RV-List: > > Does anyone know of an RV8 QB project either started or not started for > sale. > AL Malecha > www.azflyer(at)theriver.com > > > > > > ________________________________________________________________________________
Subject: Lycoming for sale
Date: Sep 09, 2002
Posted for Lance Newman Lycoming 0320H2AD, 1100 SMOH at Mattituck airbase. Running engine with logs, includes mechanical fuel pump (new). Mag, wire harness and plugs, Marvel Carb, Stock Starter. All accessories in running condition. Engine has been in dry long term storage. $5900 obo. Lance Newman Maple Valley, WA 425-413-1764 mailto:lance.newman(at)siemens.com ________________________________________________________________________________
From: "Vincent Welch" <welchvincent(at)hotmail.com>
Date: Sep 09, 2002
I ordered my front grip as standard and one additional foot of wire for my rear stick. Both cables end near the right gear mount on an RV-8A. I made up a harness for each stick with AMP plugs to connect to the corresponding stick (made the front stick connector male and the rear female so they don't get mixed up). All switches run to terminal strips to make changes easy. I used a 3PDT switch for the rear stick disable switch. I do have a start button on the front stick ONLY but there is a covered toggle switch on the panel that is a start enable. This allows me to have my right hand on the stick and left on the throttle during starting. After the engine is running, the guarded switch is closed which disables the start button on the stick. Vince Welch RV-8A >From: glen j matejcek <aerobubba(at)compuserve.com> >Reply-To: rv-list(at)matronics.com >To: "INTERNET:rv-list(at)matronics.com" >Subject: RV-List: Infinity Stick Grips >Date: Mon, 9 Sep 2002 09:05:08 -0400 > > >Listers- > >Food for thought- Murphy's law dictates that if I were to put my starter >button on my stick grip, there WOULD come a time while folding a chart, >eating a sandwich, or whatever that I accidentally engage it.... > >Glen >Soon to be re-employed and furiously filling out order forms.... > > ________________________________________________________________________________
Date: Sep 09, 2002
I have one in my RV-4. It did have to be modified by the factory to prevent interference in my comm radio when flying near a local antenna farm with strong AM/FM transmitters. Since then it has been fine. Doug Weiler N464 EM Hudson, WI ----- Original Message ----- From: <Vanremog(at)aol.com> Subject: Re: RV-List: Pointer ELT? > > In a message dated 9/8/2002 8:06:55 PM Pacific Daylight Time, > Larry(at)bowenaero.com writes: > > > > Not much in the archives about the Pointer brand ELT. Anybody using > > one? Feedback? > > I had one in my old Kitfox and it worked fine. Replacement batteries were a > little pricey though. > > -GV (RV-6A N1GV 566hrs) > ________________________________________________________________________________
Date: Sep 09, 2002
That's why you have an "enable starter" toggle switch on the panel or console -- Without it on, the button on the stick is not hot. -Larry --- glen j matejcek wrote: > > Listers- > > Food for thought- Murphy's law dictates that if I were to put my starter > button on my stick grip, there WOULD come a time while folding a chart, > eating a sandwich, or whatever that I accidentally engage it.... > > Glen > Soon to be re-employed and furiously filling out order forms.... > > > > > > > http://finance.yahoo.com ________________________________________________________________________________
Date: Sep 09, 2002
My plan for getting around this is to have two switches, one on the Infinity grip and one on my Throttle, and require that *both* be pushed to engage the starter. Murphy's law may still say that I could concievably push both at the same time by accident, but i'm willing to take that chance... It seems pretty remote. The Throttle I have is an ex-F-105 throttle, that has an "ignition" button (for in-air-restart, presumably). It also has a "speed brakes" control (extend-hold-retract), which should work quite nicely as a control for the electric flaps. -RB4 rv7 "at" b4.ca RV-7 Empennage glen j matejcek wrote: > > Listers- > > Food for thought- Murphy's law dictates that if I were to put my starter > button on my stick grip, there WOULD come a time while folding a chart, > eating a sandwich, or whatever that I accidentally engage it.... > > Glen > Soon to be re-employed and furiously filling out order forms.... ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Re: EIS 4000 manual - online ?
Try calling Greg or Sandy at 616-583-8000 and ask them to send you, either by e-mail or snail mail, a copy of user's the manual. Harry Crosby Pleasanton, California RV-6, electrical stuff ________________________________________________________________________________
Date: Sep 09, 2002
Glen, We have 120 hrs on our 8A and have not accidentally engaged the start button. It is far enough out of the way - it's a non issue. If you have a fuel injected engine - I'd highly recommend it on the grip - to the right of the collie hat. Chuck & Dave Rowbotham Rv-8A >From: glen j matejcek <aerobubba(at)compuserve.com> >Reply-To: rv-list(at)matronics.com >To: "INTERNET:rv-list(at)matronics.com" >Subject: RV-List: Infinity Stick Grips >Date: Mon, 9 Sep 2002 09:05:08 -0400 > > >Listers- > >Food for thought- Murphy's law dictates that if I were to put my starter >button on my stick grip, there WOULD come a time while folding a chart, >eating a sandwich, or whatever that I accidentally engage it.... > >Glen >Soon to be re-employed and furiously filling out order forms.... > > http://www.hotmail.com ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Intercome
Hi: I have the Flight comm Intercom, 403mc. model; I am ready to wire this thing, and see that the mic.& hdp jacks have three tabs, for wire connection each. The mic. jack does not show grd. connection, for pilot or copilot, unit is grounded i pressume? On the hdph jack is ground the center pin.? Thanks in advance for your suggestions. Bert rv6a working on the pannel Sign up for Internet Service under $10 dollars a month, at http://isp.BlueLight.com ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: XP-360 Engine and Vans Cowling
Date: Sep 09, 2002
Does anyone know what cowling choice through Vans goes with the XP-360 engine by Superior? What about XP-360 fuel injection? Larry ________________________________________________________________________________
Date: Sep 09, 2002
Amit, I don't have a copy of their manual electronically, and don't think there's one on the Grand Rapids Technologies website. I'd call Greg Toman (his phone number is on the website) and I'll be he would send you something either electronically or by snailmail. --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing... ------------------------------------------------------ writes: > Is there a user's manual or operating manual in a file for the EIS > 4000 ? I > couldn't see one on their webpage. > Thanks, > Amit. > ________________________________________________________________________________
Subject: C-GZDF - First Flight of DF-6 (Taperwing)
Date: Sep 09, 2002
Sorry for the delay. I wanted to wait until the photos came up on Matt's website. http://www.matronics.com/photoshare/davefried@rogers.com.09.08.2002/index.html After about 6 years of building effort, my aircraft, 21145 was finally ready to fly. Life has a funny way of intruding on what I do for fun, that 6 year period was spread out over 11+ years. The delay happily forgotten the moment there was air under the tires. Caveats ********** I have not calibrated the pitot/static system so the airspeeds quoted may be in error. I am a low time pilot with no tailwheel time and haven't flown in ten years. I do not have calibrated fingertips or feet. First flight ************ Saturday, August 31 2002, 1.2 hours with test pilot Dick Van Vliet at the controls. Dick is a former bush pilot with nearly 14000 hours in single engine aircraft. He has tested a number of homebuilt built aircraft including RVs and currently flies an Auster. Dick is also a flight instructor and will provide transition training. Snags: Intermittent turn coordinator Low vacuum suction Prop slinging grease from blade roots Second flight **************** Monday, Sept 2, Dick and myself, 1.2 hours. Snags: Intermittent turn coordinator now working!? Vacuum suction still low (adjusted wrong way) MAP line disconnected at firewall (missed tightening that one) Prop slinging grease from blade roots Third flight ************* Friday, Sept 6, Dick and myself, 1.4 hours. Snags: Vacuum suction still low (needs more adjustment) Tailwheel lock jammed on landing Tailwheel lock cable failed trying to free latch Prop slinging grease from blade roots (I hear that this takes about 10 hours to stop). Comments ************* It flies hands off with rudder as required depending on power setting. The flaps up stall happens at 50 kt and is gentle with a minor left wing drop. Flaps down stall happens at 39 kt indicated with a more significant left wing drop. A bit of power is required to fly at 60 kt indicated and the plane seems to be quite comfortable there. Max speed flown was 160 kt indicated at 24 square. The view out the tip up canopy and over the nose in flight is unreal. On the ground, it is a bit of a challenge to see out. That is improving somewhat as I learn how to adjust the seat and seat cushions. Control forces ****************** The stick controls are light and responsive throughout the speed range. No more than finger tip pressure was required. Range of motion at low speed was about 3 inches from centre at low speed and about half that at higher speeds. The elevator gets rather light (1 finger instead of 2) just prior to stall. The spring bias aileron trim is powerful. I adjusted it about 1/4 inch right to level the wings. On the ground it looks centred. I don't know where I started from. Elevator trim is also quite powerful. I don't think I moved it more than a half turn to trim any where above 80 kt indicated. In slow flight, considerably more trim is required (no fingers). The rudder was heavier than I expected. My big feet touch the pedals closer to the torque tube than most, perhaps this reduces mechanical advantage. There is a 1/2 inch floor board over the stiffeners and that doesn't help. I'm not sure yet, but I think that I would like to have a cabin adjustable rudder trim (any ideas?). Landing/Taxi **************** The first few landings included skips and bounces but at no time did the plane seem uncontrollable. I had visions of groundloops but it doesn't appear to be unstable on the ground. My tailwheel is either locked or free castering (no chains). When free, it steers on the ground with feet on the rudder pedals. The brakes are doing the work with just foot pressure. The test pilot prefers to leave the tailwheel free and we will go that route for a while. At least until I can repair the latch cable and figure out why the latch jammed. I am going to be working on my flying skills for a while before I get into performance testing. The latter should probably wait until I get the gear fairings on. I will gave a go at airspeed system errors using my GPS. The homemade pitot tube that I put on the wing has a leak between the total and static chamber. I am planning to change that for a Piper blade-type pitot/static. Does anybody have any experience with calibrating one of those on an RV? What a nice little airplane. My thanks to Van for a fine design. Further testing will reveal if my wing mod has added a small increment to that. More to come... David Fried C-GZDF DF-6 ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Panel Labels
List, I am about to label up my RV-8 panel and cockpit and was looking for some recommendations on the best approach. My panel is "Van's gray" and am looking to use black lettering. I would like to do this right the first time and make it look professional. Give me some help here, Tom C. RV-8 Fastback ________________________________________________________________________________
Date: Sep 09, 2002
Subject: FW: [Info] New brandname for TAE Jet Fuel Engines
---------- From: "Thielert Aircraft Engines" <info@tae-engines.com> Date: Mon, 9 Sep 2002 15:59:54 +0200 Subject: [Info] New brandname for TAE Jet Fuel Engines ===================================================================== T A E - I N F O M A I L N o. 0 6 / 2 0 0 2 from 9 September 2002 Best legibility Courier New font face ===================================================================== Dear Sir or Madam, shortly before receiving the supplement type certification for installing our certified jet fuel aircraft engine in Piper PA 28 and Cessna 172, we would like to inform you about some key, market-related news at this point: I. CENTURION Engines - jet fuel aircraft engines from TAE New website: http://www.centurion-engines.com We hope to provide you with interesting information and are pleased about your interest. Yours faithfully Thielert Aircraft Engines GmbH I. CENTURION ENGINES - JET FUEL AIRCRAFT ENGINES FROM TAE The certified jet fuel aircraft engine from Thielert Aircraft Engines GmbH is currently known under the name "TAE 125". This term for the device type referred to the overall development and certification process. With the market entry, which is now complete, TAE products from the jet fuel engine range are being given a new, catchy trade name: TAE 125 is now called "C E N T U R I O N 1.7" Hence, our high-performance engine with 228kW (310 HP), for which we are expecting the fully-functioning prototype by the end of the year, also has a new name: TAE 310 is now called "C E N T U R I O N 4.0" To start with, the Centurion 1.7 99kW (135 HP) engine is available for Cessna 172 and Piper PA 28 in the retrofit from the Centurion product family. The Centurion 1.7 is already being used in new aeroplanes, for example in the DA40 from Diamond Aircraft Industries GmbH. Please visit us on our new additional website for further information about the CENTURION jet fuel aircraft engines from TAE: < http://www.centurion-engines.com > "CENTURION" is a protected TAE trademark, which is registered in word and image. TAE is the producer of Centurion diesel aeroplane engines and system partner of the aviation and automotive industry. _____ THIELERT AIRCRAFT ENGINES GMBH__________________________________ Platanenstrasse 14 09350 Lichtenstein Germany Tel: +49 37204 6960 Fax: +49 37204 69650 mailto:info@tae-engines.com http://www.tae-engines.com _____ CENTURION - JET A-ENGINES FOR GA BUILT BY TAE___________________ http://www.centurion-engines.com ________________________________________________________________________________
Date: Sep 09, 2002
The web site is really: http://www.matronics.com/photoshare/davefried@rogers.com.09.08.2002/index.ht ml Bob Hassel -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of davefried Subject: RV-List: C-GZDF - First Flight of DF-6 (Taperwing) Sorry for the delay. I wanted to wait until the photos came up on Matt's website. http://www.matronics.com/photoshare/davefried@rogers.com.09.08.2002/index.html After about 6 years of building effort, my aircraft, 21145 was finally ready to fly. Life has a funny way of intruding on what I do for fun, that 6 year period was spread out over 11+ years. The delay happily forgotten the moment there was air under the tires. Caveats ********** I have not calibrated the pitot/static system so the airspeeds quoted may be in error. I am a low time pilot with no tailwheel time and haven't flown in ten years. I do not have calibrated fingertips or feet. First flight ************ Saturday, August 31 2002, 1.2 hours with test pilot Dick Van Vliet at the controls. Dick is a former bush pilot with nearly 14000 hours in single engine aircraft. He has tested a number of homebuilt built aircraft including RVs and currently flies an Auster. Dick is also a flight instructor and will provide transition training. Snags: Intermittent turn coordinator Low vacuum suction Prop slinging grease from blade roots Second flight **************** Monday, Sept 2, Dick and myself, 1.2 hours. Snags: Intermittent turn coordinator now working!? Vacuum suction still low (adjusted wrong way) MAP line disconnected at firewall (missed tightening that one) Prop slinging grease from blade roots Third flight ************* Friday, Sept 6, Dick and myself, 1.4 hours. Snags: Vacuum suction still low (needs more adjustment) Tailwheel lock jammed on landing Tailwheel lock cable failed trying to free latch Prop slinging grease from blade roots (I hear that this takes about 10 hours to stop). Comments ************* It flies hands off with rudder as required depending on power setting. The flaps up stall happens at 50 kt and is gentle with a minor left wing drop. Flaps down stall happens at 39 kt indicated with a more significant left wing drop. A bit of power is required to fly at 60 kt indicated and the plane seems to be quite comfortable there. Max speed flown was 160 kt indicated at 24 square. The view out the tip up canopy and over the nose in flight is unreal. On the ground, it is a bit of a challenge to see out. That is improving somewhat as I learn how to adjust the seat and seat cushions. Control forces ****************** The stick controls are light and responsive throughout the speed range. No more than finger tip pressure was required. Range of motion at low speed was about 3 inches from centre at low speed and about half that at higher speeds. The elevator gets rather light (1 finger instead of 2) just prior to stall. The spring bias aileron trim is powerful. I adjusted it about 1/4 inch right to level the wings. On the ground it looks centred. I don't know where I started from. Elevator trim is also quite powerful. I don't think I moved it more than a half turn to trim any where above 80 kt indicated. In slow flight, considerably more trim is required (no fingers). The rudder was heavier than I expected. My big feet touch the pedals closer to the torque tube than most, perhaps this reduces mechanical advantage. There is a 1/2 inch floor board over the stiffeners and that doesn't help. I'm not sure yet, but I think that I would like to have a cabin adjustable rudder trim (any ideas?). Landing/Taxi **************** The first few landings included skips and bounces but at no time did the plane seem uncontrollable. I had visions of groundloops but it doesn't appear to be unstable on the ground. My tailwheel is either locked or free castering (no chains). When free, it steers on the ground with feet on the rudder pedals. The brakes are doing the work with just foot pressure. The test pilot prefers to leave the tailwheel free and we will go that route for a while. At least until I can repair the latch cable and figure out why the latch jammed. I am going to be working on my flying skills for a while before I get into performance testing. The latter should probably wait until I get the gear fairings on. I will gave a go at airspeed system errors using my GPS. The homemade pitot tube that I put on the wing has a leak between the total and static chamber. I am planning to change that for a Piper blade-type pitot/static. Does anybody have any experience with calibrating one of those on an RV? What a nice little airplane. My thanks to Van for a fine design. Further testing will reveal if my wing mod has added a small increment to that. More to come... David Fried C-GZDF DF-6 ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Re: Panel Labels
In a message dated 9/9/02 5:19:32 PM Eastern Daylight Time, Ski2001a(at)aol.com writes: << List, I am about to label up my RV-8 panel and cockpit and was looking for some recommendations on the best approach. My panel is "Van's gray" and am looking to use black lettering. I would like to do this right the first time and make it look professional. Give me some help here, Tom C. RV-8 Fastback >> I took my panel to a vinyl sign shop and they made and attached all the labels for $50. The lettering is crisp, applied straight, and has stuck well for two years. I'd go that way again. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Re: XP-360 Engine and Vans Cowling
I have an XP 0360 and I am installing Van's O-360, no problems. Ted Gauthier Pontiac, Mi. ----- Original Message ----- From: "LarryRobertHelming" <lhelming(at)sigecom.net> Subject: RV-List: XP-360 Engine and Vans Cowling > > Does anyone know what cowling choice through Vans goes with the XP-360 > engine by Superior? What about XP-360 fuel injection? > > Larry > > ________________________________________________________________________________
Subject: Re: Strength of riveted joints
Date: Sep 08, 2002
This was an excellent report in my opinion. I will however like to add that most structural problems with riveted joints are due to lop sided, bent over, cracked, dented, etc rivets rather than over or under driven rivets. It is nice to see numbers showing that if you happen to overdrive a rivet but its otherwise ok, then its probably better to leave it and not drill it out. If however, the rivet gun slips and makes a dimple or if the rivet sets to one side, the structural integrity will not be as high. Damaged rivets is one thing that is hard to duplicate in the lab since every imperfect rivet is slightly different. Good job Bill on getting numbers like this for new (and not so new) builders to see and reflect on. Oh yeah, and prime those lap joints well. They are the number 1 place for corrosion to find a home. Steve Hurlbut RV7A ----- Original Message ----- From: "Kevin Horton" <khorto1537(at)rogers.com> Subject: RV-List: Strength of riveted joints > > Bill Marvel posted a very interesting message to the RV-List a few > days about the strength of riveted joints. The message summarized > the actual pull tests between aluminum coupons with different types > of rivets, and with various rivet conditions (over-driven, correctly > driven, under-driven). > > With Bill's permission, I have put his original message on my web > site, so it is permanently available. > > See: http://members.rogers.com/khorton/rvlinks/marvelrivets.html > > -- > Kevin Horton RV-8 (spinner, cowling) > Ottawa, Canada > http://members.rogers.com/khorton/rv8.html > > ________________________________________________________________________________
Date: Sep 09, 2002
Jack, The easy way to do this: - Buy a "blank" end rib cover to replace the cover made to hold the fuel sender. Van's sells these for just this purpose. - Use the end rib cover that is now replace as a template to make the hole in the baffle plate (the hole in the baffle plate is the exact size of the sender hole in the end plate). Be VERY CAREFUL to align the holes as you need for the fuel sender orientation. These holes ARE NOT symmetrical. - After the hole is made, trim the end rib plate to into a donut shape, this is now used as a backing plate to strengthen the baffle mounted fuel sender. Carl Froehlich RV-8A (flying) Vienna, VA -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jack Textor Subject: RV-List: RV8 fuel access hole ???? I'm utilizing the flop tube in my left tank (RV8). The plans don't cover the hole in the baffle very well. Should it be just large enough for the sender or similar to the access opening in the normal tank? I did order a cover plate from Van's so maybe that means the larger size. Thanks, Jack Textor RV8 DSM Jack Textor PERSONNEL INCORPORATED PLACEMENTS / OUTPLACEMENTS TESTING / TEMPORARY STAFFING Serving Clients For More Than 39 Years 604 Locust, Suite 516 Des Moines, IA 50309 515-243-7687 phone 515-243-3350 fax www.iaJobs.com jack(at)iaJobs.com ________________________________________________________________________________
Date: Sep 08, 2002
Subject: Re: vertical stabilizer offset
I forget how much offset I did on my 6A but it was not enough. A healthy offset will lessen the need for a wedge on the rudder to keep the ball centered at cruise. Will Cretsinger, Arlington, Texas Mark Phillips wrote: > > > Hi Dave- > > Yeah, I noticed it in the plans revisions on page 19 of the second 2002 > RVator- I don't see a dimension for the offset, it looks like it's set by the > F-781 attach plate (pre-punched of course?!) but looks like about 1/8" or > 3/16" to the left... ...oh yeah, and I saw this about a month after I > drilled the V.S. spar for my -6A!! > > >From the PossumWorks > Mark > > Dave Ford wrote: > > > > > A builder of an RV7 I met recently told me his preview plans showed an > > offset for the vertical stabilizer when mounted to the fuselage. Can > > anyone verify this and what the offset measurement is? > > > > Dave Ford > > RV6 > ________________________________________________________________________________
"RV List"
Subject: New Class for Copperstate Race in Oct.
Date: Sep 09, 2002
Below is an email I just recieved from Jim Irwin of Aircraft Spruce. Below that is the news release for the race. Anyway, if enough people will enter, he will start a new 180+ HP or unlimited class for the race. Time to show off those bigger engines. John Harmon, you were going to Copperstate anyway, why don't you set the pace? As long as there are no more than two other unlimited racers, I might be able to get a third place plaque. :-) Tom Gummo Apple Valley, CA EAA Chapter 768 Pres Owner of the Slowest and Ugliest Harmon Rocket - N561FS but It is mine, It is paid for, and It flys great. (Thanks Van and John) ----- Original Message ----- From: "Jim Irwin" <jji(at)aircraftspruce.com> Subject: Re: Velocity Crash > Tom, > > Thanks for the nice email on Friday regarding the Golden West Air Race and > the update on the Velocity Crash. I'm glad that the guys got out of the > aircraft OK! We appreciate all of the help you gave us once again at Apple > Valley; we enjoy sponsoring these races and working with the good people at > EAA Chapter 768. We certainly can have an unlimited class for the > Copperstate and if we get enough entrants above 180 hp we will add the class > for the race in October; put the word out! > > Thanks again for all your help, and we'll see you next month. > > Best Regards, > > Jim Irwin > President, Aircraft Spruce > AIRCRAFT SPRUCE SCHEDULES SEVENTH ANNUAL COPPERSTATE DASH AIR RACE Corona, CA - Aircraft Spruce & Specialty will host the sixth annual Copperstate Dash Air Race this October on Friday the 11th. Co-sponsored by the EAA, the 286-nautical mile race is run between Apple Valley Airport (APV) in Victorville, CA and Coolidge Airport (P08), south of Phoenix. Most participants fly in the race and then visit the Copperstate Fly-In at the new Phoenix Regional Grand Valley (A39) Airport which runs October 10 - 13. The race is open to homebuilt and certificated aircraft, which race in separate categories. The four categories consist of Millennium, for aircraft with engines up to 180 horsepower; Phoenix for up to 160 horsepower; Flash Gordon for up to 120 horsepower and the Road Runners for those with 90 horsepower or less. Each category will have separate divisions for Experimentals and factory built aircraft. Pilots race against the clock and the three fastest times in each group are the winners. Plaques and gift certificates totaling $4,000 are presented to the winners each year during the Copperstate Fly-In Awards Banquet. Any pilot with current ratings and an appropriate airworthy aircraft can enter. There is a $30 non-refundable entry fee, payable to Aircraft Spruce, due with each entry form. All pilots must carry a $1 million liability policy that covers their flying to, during, and after the race. Temporary fuselage fuel tanks are not allowed and all pilots are required to obey the FARs. The race requires VFR conditions enroute, which has never been a problem in the past. "The Copperstate Dash is an exciting air race," said Aircraft Spruce President Jim Irwin. "People participate to have fun, and judging from the quips we hear on the radio, they do have a good time. Some people take the race very seriously, of course, but a lot of people simply run the course to be able to say they spent a day as an air race pilot. Many of the competitors come back year after year. It's a great way to get to a fly-in." Entry forms can be obtained by calling Jerry Aguilar at Aircraft Spruce & Specialty: (800) 824-1930; fax (909) 372-0555; or write to Jerry at 225 Airport Circle, Corona, CA 91720. Forms must be submitted by October 7. ________________________________________________________________________________
Date: Sep 09, 2002
Here's a couple for you guys using the Infinity stick and switches: Are you running the starter lead direct or using a relay? Are you running a Vans flap motor direct or using a relay? Infinity claims a 6A rating on the push button switch but doesn't list a rating on the toggle used for the flaps. Thanks, Russ HRII ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Drag increase due to too high cowling inlets
I went to the EAA Chapter 486 RV Fly-in at Fulton, NY (FZY) last weekend. I spent quite a bit of time looking at cowlings, as I have just started working on mine. I noted one thing that is worth thinking about if you want to reduce drag. I'm building an RV-8. Van specifies the height of the air inlets as 2 5/8 to 2 3/4 inches (IIRC). I didn't have a ruler with me, but it was quite clear that many RVs have air inlets that are quite a bit larger than called for on the RV-8 plans. These RVs also had quite a large flat area extending above and/or below the spinner, which also supports my theory that their cowl halves weren't trimmed as much at the front as Van intended. So what, you ask? Well, if the height of the cooling air inlets is increased, the amount of air that goes into the cowling increases. If we look at the aircraft as our frame of reference, all this air has to slow down to pretty close to zero speed. Or, looking at the earth as our frame of reference, all this air has to be accelerated from a stop to the speed of the RV. This acceleration requires a force to be exerted on the air by the aircraft, and this force is felt by the aircraft as drag. I did a very rough back of the envelope calculation, and if the air inlet height on both sides is increased by 1/2 inch, that gives about a 4% drag increase, and would cause a speed decrease of about 2 kt for a 160 hp RV, and about 2.25 kt for a 200 hp RV. If the inlet height is one inch too high, you can about double those numbers. This calculation ignores the drag of the flat part of the cowl that may be exposed above and below the spinner if the front part of the cowl has more height than Van intended. So, the real effect could be greater than this back of the envelope calculation would suggest. Caveat - this calculation used quite a few simplifications. Total drag of a nominal aircraft was calculated based on Van's 75% cruise numbers, and an assumed 79% prop efficiency (obtained from a Hartzell prop efficiency map). Drag increase calculation assumed that the air entering the cowling was at free stream ambient conditions, and that the air was slowed to 10% of its initial velocity (relative to the aircraft). So, if you want to get Van's performance numbers, be sure to pay attention to the height of the air inlets on the cowl. Take care, -- Kevin Horton RV-8 (spinner, cowling) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
From: "Sally and George" <aeronut58(at)hotmail.com>
Subject: Re: RV8-List: Drag increase due to too high cowling inlets
Date: Sep 09, 2002
Kevin has a good point. Another thing to consider, if you're working on your cowl: Set it up with the top of the spinner about 1/4 inch higher than the top of the cowl. That's because, after 100 hours or so, the engine will sag slightly on the mounts. If you set up initially with a the spinner matching the cowl contour, you will later have an unsightly step down from cowl to spinner. 1/4" worked just fine for me, but you could also add a little more, just in case. Having the spinner slightly higher than the cowl looks okay, but the converse is not true. George Kilishek RV-8 N888GK 80+ hours ----- Original Message ----- From: Kevin Horton Subject: RV8-List: Drag increase due to too high cowling inlets --> RV8-List message posted by: Kevin Horton I went to the EAA Chapter 486 RV Fly-in at Fulton, NY (FZY) last weekend. I spent quite a bit of time looking at cowlings, as I have just started working on mine. I noted one thing that is worth thinking about if you want to reduce drag. I'm building an RV-8. Van specifies the height of the air inlets as 2 5/8 to 2 3/4 inches (IIRC). I didn't have a ruler with me, but it was quite clear that many RVs have air inlets that are quite a bit larger than called for on the RV-8 plans. These RVs also had quite a large flat area extending above and/or below the spinner, which also supports my theory that their cowl halves weren't trimmed as much at the front as Van intended. So what, you ask? Well, if the height of the cooling air inlets is increased, the amount of air that goes into the cowling increases. If we look at the aircraft as our frame of reference, all this air has to slow down to pretty close to zero speed. Or, looking at the earth as our frame of reference, all this air has to be accelerated from a stop to the speed of the RV. This acceleration requires a force to be exerted on the air by the aircraft, and this force is felt by the aircraft as drag. I did a very rough back of the envelope calculation, and if the air inlet height on both sides is increased by 1/2 inch, that gives about a 4% drag increase, and would cause a speed decrease of about 2 kt for a 160 hp RV, and about 2.25 kt for a 200 hp RV. If the inlet height is one inch too high, you can about double those numbers. This calculation ignores the drag of the flat part of the cowl that may be exposed above and below the spinner if the front part of the cowl has more height than Van intended. So, the real effect could be greater than this back of the envelope calculation would suggest. Caveat - this calculation used quite a few simplifications. Total drag of a nominal aircraft was calculated based on Van's 75% cruise numbers, and an assumed 79% prop efficiency (obtained from a Hartzell prop efficiency map). Drag increase calculation assumed that the air entering the cowling was at free stream ambient conditions, and that the air was slowed to 10% of its initial velocity (relative to the aircraft). So, if you want to get Van's performance numbers, be sure to pay attention to the height of the air inlets on the cowl. Take care, -- Kevin Horton RV-8 (spinner, cowling) Ottawa, Canada http://members.rogers.com/khorton/rv8.html Get mor ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Subject: Cleaning Nosewheel Bearings
Date: Sep 09, 2002
I have a question concerning the use of Varsol for cleaning the nosewheel bearings. Eustace has a really good post in the archives - but it pertains to the main wheel bearings. Instead of a retainer clip, etc., the nose wheel bearings have a type of neoprene encased seal. In cleaning the bearing I soaked them in Varsol for many hours, then brushed them before blowing them out with air. I am concerned that the Varsol my not be compatible with these seals. Will the Varsol soaking make these seals dry out, crack or fail to perform in some way. Am I paranoid about this. Is the Varsol friendly for a long exposure??? It appears impossible to use the Timken.com site by end customers. I rubbed the parts with a lithium white grease until I get an answer. Thanks for any help. Ernest Kells - RV-9A O235-N2C, Wood Prop Finish Kit 40% Complete ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Mounting Wings...
More questions for the more experienced of ya'll......I exhausted the archives tonight and didn't come up with much to answer my question..... Im currently finishing up the wings on a QB 6A (wings are already drilled to match the fuse mounts and landing gear mounts) and would like to do the final mounting ( rear spar attach and foward support)...along with all the associated fuel lines and wiring..... I have the fuse on a jig (not on gear), level, and the wing spar in the fuse with supports for the wing to keep the bolt holes aligned.....but only room in the garage to do one wing at a time.....(envy guys with a large shop or big hangar...=).....) Once I have the wing bolted in with every other bolt or so...do I dare do the alignment for sweep and angle of incidence and drill the rear spar per the instructions without the other wing on at the same time?? Its seems you can do the angle of incidence easy enough one at a time with the fuse level....but I'm more concerned about the sweep....can I drop a plumb along the certer of the fuse...and then along the LE of the wing to set the sweep.....then when measuring to a point on the aft portion of the fuse, just ensure both wings are the same when the second one is attached (separately also).....??? I know doing this in a hangar with both wings at the same time is optimum...just wondering if anyone has done it one at a time as I would like to get as much done as possible before moving to the airport...(as it may be sometime!!!).. Thanks again for all your help.....!! Kurt Klewin, RV6A Finishing.... ________________________________________________________________________________
Date: Sep 09, 2002
Larry, Go with what ever matches the Lycoming O-360-A1A from Vans. the XP-360 is a matchup size for size dimensionally speaking. Jim in Kelowna ----- Original Message ----- From: "LarryRobertHelming" <lhelming(at)sigecom.net> Subject: RV-List: XP-360 Engine and Vans Cowling > > Does anyone know what cowling choice through Vans goes with the XP-360 > engine by Superior? What about XP-360 fuel injection? > > Larry > > ________________________________________________________________________________
Date: Sep 09, 2002
Subject: Re: Mounting Wings...
In a message dated 9/9/02 10:58:30 PM Eastern Daylight Time, KAKlewin(at)aol.com writes: << More questions for the more experienced of ya'll......I exhausted the archives tonight and didn't come up with much to answer my question..... Im currently finishing up the wings on a QB 6A (wings are already drilled to match the fuse mounts and landing gear mounts) and would like to do the final mounting ( rear spar attach and foward support)...along with all the associated fuel lines and wiring..... I have the fuse on a jig (not on gear), level, and the wing spar in the fuse with supports for the wing to keep the bolt holes aligned.....but only room in the garage to do one wing at a time.....(envy guys with a large shop or big hangar...=).....) Once I have the wing bolted in with every other bolt or so...do I dare do the alignment for sweep and angle of incidence and drill the rear spar per the instructions without the other wing on at the same time?? Its seems you can do the angle of incidence easy enough one at a time with the fuse level....but I'm more concerned about the sweep....can I drop a plumb along the certer of the fuse...and then along the LE of the wing to set the sweep.....then when measuring to a point on the aft portion of the fuse, just ensure both wings are the same when the second one is attached (separately also).....??? I know doing this in a hangar with both wings at the same time is optimum...just wondering if anyone has done it one at a time as I would like to get as much done as possible before moving to the airport...(as it may be sometime!!!).. Thanks again for all your help.....!! Kurt Klewin, RV6A Finishing.... >> Setting sweep and incidence is critical and you only get to do it once unless you're into a frightening amount of rework. Do what I did: Find a volunteer for a Saturday. Turn the airplane 90 degrees so one wing is inside the garage and the other wing sticks out the garage door. Turn off the circuit breaker for your garage door opener. With your helper's aid, set incidence and sweep and drill the rear attach points. You'll need the helper because you'll probably take the wings on and off a couple of times before the alignment is good enough to drill the rear attach holes. Once you've drilled the holes, put a bolt in 'em and go ahead and rig your ailerons and mount the wingtips so they match the ailerons. It'll probably take most of a day, but you won't need to mount both wings at the same time again until you're at the airport. Next, pull a wing off and complete the plumbing, wiring, and flap rigging on the remaining wing. Switch wings and do it again. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Sep 09, 2002
In a message dated 9/9/2002 8:40:16 AM Pacific Daylight Time, dougweil(at)pressenter.com writes: > I have one in my RV-4. It did have to be modified by the factory to prevent > interference in my comm radio when flying near a local antenna farm with > strong AM/FM transmitters. Since then it has been fine. > Ah, now I remember. There was that one ECO to fix the issue Doug mentioned.. -GV (RV-6A N1GV 566hrs) ________________________________________________________________________________
Date: Sep 09, 2002
if you are concerned about saving time, I'd say doing one wing at a time is far more time consuming and risky. Wait until you are in the hangar, it'll take but a few hours. My hangar mate and I both took 12 hours to install all the 56 bolts on our -6A's, but we got real picky about washers and exposed thread count. The bolts behind the gear sockets are REAL fun, find yourself some forceps to hold the nuts with and a good mirror. ----- Original Message ----- From: <KAKlewin(at)aol.com> Subject: RV-List: Mounting Wings... > > More questions for the more experienced of ya'll......I exhausted the > archives tonight and didn't come up with much to answer my question..... > > Im currently finishing up the wings on a QB 6A (wings are already drilled to > match the fuse mounts and landing gear mounts) and would like to do the final > mounting ( rear spar attach and foward support)...along with all the > associated fuel lines and wiring..... > > I have the fuse on a jig (not on gear), level, and the wing spar in the fuse > with supports for the wing to keep the bolt holes aligned.....but only room > in the garage to do one wing at a time.....(envy guys with a large shop or > big hangar...=).....) > > Once I have the wing bolted in with every other bolt or so...do I dare do the > alignment for sweep and angle of incidence and drill the rear spar per the > instructions without the other wing on at the same time?? Its seems you can > do the angle of incidence easy enough one at a time with the fuse > level....but I'm more concerned about the sweep....can I drop a plumb along > the certer of the fuse...and then along the LE of the wing to set the > sweep.....then when measuring to a point on the aft portion of the fuse, > just ensure both wings are the same when the second one is attached > (separately also).....??? > > I know doing this in a hangar with both wings at the same time is > optimum...just wondering if anyone has done it one at a time as I would like > to get as much done as possible before moving to the airport...(as it may be > sometime!!!).. > > Thanks again for all your help.....!! > > Kurt Klewin, RV6A Finishing.... > > ________________________________________________________________________________
Date: Sep 09, 2002
> > Another thing to consider, if you're working on your cowl: > Set it up wit= h the top of the spinner about 1/4 inch higher > than the top of the cowl. That's because, after 100 hours or > so, the engine will sag slightly on t= he mounts. This does not always happen - my plane is exactly one year old today with 200 hours, and there is no perceptable sag in the engine. These are whatever mounts Van sells or at least sold a couple years back. Alex Peterson Maple Grove, MN RV6-A N66AP 200 hours ________________________________________________________________________________
Date: Sep 09, 2002
I propped my garage door open and built a temporary wall and roof to extend the garage about 7 feet so I could have enough room to do both wings. It's been that way for eight or nine months now and the neighbors haven't complained. It makes it nice for rigging flaps and ailerons and such too. Good luck with the rigging. Take your time and do it carefully. Ed Holyoke 6QB -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of KAKlewin(at)aol.com Subject: RV-List: Mounting Wings... More questions for the more experienced of ya'll......I exhausted the archives tonight and didn't come up with much to answer my question..... Im currently finishing up the wings on a QB 6A (wings are already drilled to match the fuse mounts and landing gear mounts) and would like to do the final mounting ( rear spar attach and foward support)...along with all the associated fuel lines and wiring..... I have the fuse on a jig (not on gear), level, and the wing spar in the fuse with supports for the wing to keep the bolt holes aligned.....but only room in the garage to do one wing at a time.....(envy guys with a large shop or big hangar...=).....) Once I have the wing bolted in with every other bolt or so...do I dare do the alignment for sweep and angle of incidence and drill the rear spar per the instructions without the other wing on at the same time?? Its seems you can do the angle of incidence easy enough one at a time with the fuse level....but I'm more concerned about the sweep....can I drop a plumb along the certer of the fuse...and then along the LE of the wing to set the sweep.....then when measuring to a point on the aft portion of the fuse, just ensure both wings are the same when the second one is attached (separately also).....??? I know doing this in a hangar with both wings at the same time is optimum...just wondering if anyone has done it one at a time as I would like to get as much done as possible before moving to the airport...(as it may be sometime!!!).. Thanks again for all your help.....!! Kurt Klewin, RV6A Finishing.... ________________________________________________________________________________
Date: Sep 09, 2002
Subject: [ Kevin ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Kevin Subject: Reno Race Photos... http://www.matronics.com/photoshare/rv8r300@attbi.com.09.09.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Subject: Re: C-GZDF - First Flight of DF-6 (Taperwing)
Date: Sep 10, 2002
----- Original Message ----- From: Laird Owens <owens(at)aerovironment.com> Subject: Re: RV-List: C-GZDF - First Flight of DF-6 (Taperwing) > Can you give us some details about the wing? Airfoil, span, wing > area, washout (if any) percent thickness at the tip? I also notice a > fairly big control horn for the aileron. > > And how about the engine/prop, and empty weight of your RV. > > Laird RV-6 580 hrs What I did (from a posting dated Feb 95....) To use the fuselage design without modification, the wing chord at the fuselage side is unchanged (58 in. @ Y=22.5 in.). Inboard of this point the spars mate to the fuselage in the usual way. Although the structure has been restressed and resized as required, it goes together like the standard wing. Things generally scale down moving out toward the tip. The airfoil section, incidence, dihedral and twist are unchanged. The mainspar remains at 30% chord and is unswept. Aspect ratio was increased from 4.76 to 6.0 Fixing the span at 25 ft. set the average chord to 50 in. at Y=75 in.. With the chord known at the fuselage side and mid span, a linear taper gave a tip chord of 38.6 in. at Y=150 in.. Wing area of the new planform is 104.2 ft. 2 compared with 111.2 ft. 2 for the rectangular wing. Each flap is 1 ft. longer and the fuel tanks one rib bay longer. Fuel capacity is 40 USG in total. It took me long enough to get it finished but now it is and so the fun begins. The engine is an overhauled Lyc 360, injected, 9.0 to 1 cr, ported and polished. The builder claims a little better than 180 hp. The prop is a Hartzell. Never mind the performance part, the weight of it helps keep the C.G. where I want it. Empty weight came out at 1054 pounds. This will increase as I add gear fairings upholstery, lights and paint. The flight physician convinced me to put my sweet self on a diet. The aircraft's loaded weight might actually decrease ;) I managed to convince myself that the roll damping characteristic of the longer wing would reduce roll power. There is a 6 inch sheet metal aileron extension outboard of the hinge to increase the area. The leading edge of the balance matches the rest of the aileron. It is not a balance horn if that is what you meant. Dave ________________________________________________________________________________
Subject: RV-8 interest
Date: Sep 10, 2002
I am interested in learning more about the RV-8, especially with regards to it's aerobatic capabilities and performance. Is there anyone out there in the in the metropolitan D.C. area who built/flies one and would be willing to educate me? I am a military pilot thinking about owning an airplane suitable for both weekend acrobatics and cross-country trips. My friends indicate the RV-8 may fit both my desires and budget. Any help would be appreciated. My individual e-mail account is watrousd(at)ndu.edu . Thank You. Don W. ________________________________________________________________________________
Date: Sep 10, 2002
Dave, Talked to one of Van's guys recently, don't remember who, and he said they are centering the VS and using a rudder tab. Might be worth while to E-mail Van's and confirm this. Dale Walker RV7 ________________________________________________________________________________
Date: Sep 10, 2002
Alex Peterson wrote: > > > > > > Another thing to consider, if you're working on your cowl: > > Set it up wit= h the top of the spinner about 1/4 inch higher > > than the top of the cowl. That's because, after 100 hours or > > so, the engine will sag slightly on t= he mounts. > > This does not always happen - my plane is exactly one year old today > with 200 hours, and there is no perceptable sag in the engine. These are > whatever mounts Van sells or at least sold a couple years back. Same here. The anticipated "sag" never occurred. Fortunately, I messed up and got the spinner aligned correctly during the initial fit-up. ;-) Sam Buchanan (RV-6, 418 hrs) ________________________________________________________________________________
Date: Sep 10, 2002
I am thinking about making fiberglass plug inserts for my conventional cowling that would adapt the factory oval, large inlets to smaller, circular inlets as in the Holey Cowl design. If I did so, should I make the diameter equal to the height (smallest dimension) of the factory inlets, or would I need to remove some original cowl material to get the round inlets a bit larger? I would appreciate a suggested starting diameter for round inlets, in other words. Will this change play heck with my cylinder cooling, which is presently very good and very well balanced? I am tempted to "leave well enough alone," but the heat is on to get all the anticipated speed mods done at one time, so I only have to repitch my Sensenich _once_ after all the clean-up and hop-up is finished. Thanks in advance. Bill Boyd RV-6A 250 hrs- 160 hp ________________________________________________________________________________
Date: Sep 10, 2002
From: "Michael J. Robbins" <michael.j.robbins(at)verizon.net>
Subject: SF Bay Area Airports
SF Bay RVers; I am planning a trip to the SF bay on Friday from Seattle and thinking of going into Palo Alto, since that is the closest airport to our destination. Is that a good choice for overnighting my just completed and still waiting for that first dent RV-8? And how do I get into there from the north? Contact Bay Approach? And will they talk to us little guys flying VFR? Thanks. Mike Robbins RV-8 N88MJ 82 hours Seattle area ________________________________________________________________________________
Date: Sep 10, 2002
Bill Benedict once told me that they put yarns on the inlets once and noticed that the interior portion of the rextangular opening actually flowed forward. Apparently the right opening has less flow also. You will notice some planes with assymetrical openings now. I would try making some temp inserts before chopping the cowl. I, in fact, made some for mine but haven't tried them yet. My original round outlets were formed around 4" pvc union couplings. Slice them first so they can easily be removed. Kevin ----- Original Message ----- From: <SportAV8R(at)aol.com> Subject: Re: RV-List: Re: RV8-List: Drag increase due to too high cowling inlets > > I am thinking about making fiberglass plug inserts for my conventional > cowling that would adapt the factory oval, large inlets to smaller, circular > inlets as in the Holey Cowl design. If I did so, should I make the diameter > equal to the height (smallest dimension) of the factory inlets, or would I > need to remove some original cowl material to get the round inlets a bit > larger? I would appreciate a suggested starting diameter for round inlets, > in other words. > > Will this change play heck with my cylinder cooling, which is presently very > good and very well balanced? I am tempted to "leave well enough alone," but > the heat is on to get all the anticipated speed mods done at one time, so I > only have to repitch my Sensenich _once_ after all the clean-up and hop-up is > finished. > > Thanks in advance. > > Bill Boyd > RV-6A 250 hrs- 160 hp > > ________________________________________________________________________________
From: "Jim Norman" <jnorman(at)intermapsystems.com>
Date: Sep 10, 2002
Bill, I have the Sam James Cowl (aka, the Holy Cowl). I just measured the air intakes for you, they are 4.75 inches in diameter, each. My thoughts: 1) Looks can't be beat; 2) speed increases are as much (or more???) from the associated plenum and not just the round inlets which allow less air and flow with less drag); 3) the amount of work you are thinking about (by grafting this on yourself) is huge, and not to be undertaken lightly or underestimated. So, don't do it without putting in a plenum, its probably wasted time. And, prepare to waste a month or more on this one mod. jim Tampa -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of SportAV8R(at)aol.com Subject: Re: RV-List: Re: RV8-List: Drag increase due to too high cowling inlets I am thinking about making fiberglass plug inserts for my conventional cowling that would adapt the factory oval, large inlets to smaller, circular inlets as in the Holey Cowl design. If I did so, should I make the diameter equal to the height (smallest dimension) of the factory inlets, or would I need to remove some original cowl material to get the round inlets a bit larger? I would appreciate a suggested starting diameter for round inlets, in other words. Will this change play heck with my cylinder cooling, which is presently very good and very well balanced? I am tempted to "leave well enough alone," but the heat is on to get all the anticipated speed mods done at one time, so I only have to repitch my Sensenich _once_ after all the clean-up and hop-up is finished. Thanks in advance. Bill Boyd RV-6A 250 hrs- 160 hp ________________________________________________________________________________
Date: Sep 10, 2002
I saw an expert on cooling drag speak at an EAA Meeting a year or so ago, and he stated that it is now fairly well understood that cowl openings spaced some distance from the spinner are the most efficient. It turns out that if the opening goes all the way to the spinner (as on Vans cowlings), local flow right next to the spinner is actually reversed (i.e. flow goes out the front). If you move the opening out a couple of inches from the spinner, you can actually reduce the opening size quite a bit and still have enough air flow for cooling. Sorry I don't have a suggestion for a starting diameter, but I'd be surprised if you need to enlarge the inlets very much. jason -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of SportAV8R(at)aol.com Subject: Re: RV-List: Re: RV8-List: Drag increase due to too high cowling inlets I am thinking about making fiberglass plug inserts for my conventional cowling that would adapt the factory oval, large inlets to smaller, circular inlets as in the Holey Cowl design. If I did so, should I make the diameter equal to the height (smallest dimension) of the factory inlets, or would I need to remove some original cowl material to get the round inlets a bit larger? I would appreciate a suggested starting diameter for round inlets, in other words. Will this change play heck with my cylinder cooling, which is presently very good and very well balanced? I am tempted to "leave well enough alone," but the heat is on to get all the anticipated speed mods done at one time, so I only have to repitch my Sensenich _once_ after all the clean-up and hop-up is finished. Thanks in advance. Bill Boyd RV-6A 250 hrs- 160 hp ________________________________________________________________________________
Subject: Re: SF Bay Area Airports
Date: Sep 10, 2002
Palo Alto is a great airport for transients...but Oakland typically has much cheaper fuel, and Kaiser is a very friendly FBO at OAK...they'll give you rides to the Bart station, call you a cab ahead of time, etc. But if you go into PAO it's about $8/night for transient and it's very laid back. After getting off rwy 31 (used to be 30 until last year or so) you can just follow the "green line" (a green line painted on the taxiway) to the transient rows. It takes you on a kind of round-about route in order to avoid the 31 runup area, hooks right down taxiway Delta, but it goes right by the pumps and ends up on the west end of the transient rows, I believe November and Oscar (and the grass). Getting into PAO from the north, ask Bay Approach for the "Bay Tour" and tell them you're unfamiliar. You should be able to get a nice Golden Gate - SF city - SFO routing, and then usually they'll tell you to remain "south and west of 101" around the SFO area. Just follow 101 right down to PAO. Watch out for San Carlos' airspace, though...stay above 2000' or ask for a transition. Another option is to go along the coast down to Half Moon Bay and then cut over the hills directly to PAO. That way you can avoid the class B. But again, watch out for cutting into SQL class D. Coming that way will put you on a 45 to right downwind for 31, more or less. Just one word of caution...the PAO controllers don't really know what a "low approach" is. I think they usually associate that with a missed instrument approach. So they don't expect you to be going 200 when you come up behind that 152 that just did a touch and go. 8 ) Hope this helps, )_( Dan RV-7 N714D (fuselage) http://www.rvproject.com ----- Original Message ----- From: "Michael J. Robbins" <michael.j.robbins(at)verizon.net> Subject: RV-List: SF Bay Area Airports > > SF Bay RVers; > > I am planning a trip to the SF bay on Friday from Seattle and thinking of > going into Palo Alto, since that is the closest airport to our > destination. Is that a good choice for overnighting my just completed and > still waiting for that first dent RV-8? And how do I get into there from > the north? Contact Bay Approach? And will they talk to us little guys > flying VFR? > > Thanks. > > Mike Robbins > RV-8 N88MJ 82 hours > Seattle area > > ________________________________________________________________________________
Date: Sep 10, 2002
Mike, I'm at Reid Hillview (RHV) just south of Palo Alto, I work in Sunnyvale, and live in Cupertino. RHV is a much bigger Airport and is easy to get to. Neither airport has hanger space available unless you can talk to an FBO or maintenance facility And convince them of your need. We've got an EAA mtg. tonight and I can ask around for you. Grab a Street Atlas, and follow along..... Flying into either airport...I'd fly down I-5 to Vacaville (I-505) over to Concord (Buchanan Field), follow 680 (stay below 6000') which will pass through the Hills at the Sunol Grade. This will dump you out at Fremont, East of Palo Alto and north of San Jose.If you decide on San Jose (RHV), stay East of (I-880) to remain out of the San Jose (SJC) Class C. If you go into Palo Alto, check the Sectionals for the narrow path over the Bay Avoiding San Jose's airspace. I'd get a VFR Terminal Area Chart for San Francisco to review. In either case you can avoid talking to Bay Approach. Watch for aircraft coming through the Sunol Grade and coming over Calaveras Reservoir for RHV. A lot of Palo Alto traffic comes through Sunol. It is busy in the Bay Area. Moffett Field (NASA and Air National Guard) is close to Palo Alto and tucked into San Jose's Class C. San Jose (RHV) is much more open and easy to get in and out of. Call me at 408-257-3281 H or 408-530-6605 W and I can clarify with you. My work email is ed_cole(at)maximhq.com Let me know when your coming, how long your staying for and your general destination. I'll do what I can to help you out. Ed Cole RV6A N2169D Flying RV6A N648RV Finishing -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael J. Robbins Subject: RV-List: SF Bay Area Airports SF Bay RVers; I am planning a trip to the SF bay on Friday from Seattle and thinking of going into Palo Alto, since that is the closest airport to our destination. Is that a good choice for overnighting my just completed and still waiting for that first dent RV-8? And how do I get into there from the north? Contact Bay Approach? And will they talk to us little guys flying VFR? Thanks. Mike Robbins RV-8 N88MJ 82 hours Seattle area ________________________________________________________________________________
Date: Sep 10, 2002
I've combined two different posts because they have a common point regarding the "reversed" or "forward" flow of cooling air at the inlet. I found the information from the "cooling expert" interesting in contrast to what we learn in Paser's "Speed with Economy". To quote some dead guy, "Is there nothing on which we can place our finger and say "This is so, this is correct"?" The point that inlets are more efficient spaced away from the spinner is 180 degrees out from Paser's conclusion that air spilling off the spinner and flowing directly into the inlet works better. I must say that Paser's description matches my own understanding of physics. He moved his inlets inward and decreased their size and picked up speed. Kent also describes the way cooling air can back up inside the cowl when the inlet size exceeds the exhaust size - IOW the inlets let in more air than can escape down and out of the cowl, so it escapes forward. All of this ties in with the use of plenums to make the flow of air from inlet to exhaust more efficient. This increase in efficiency can be translated to more speed only by reducing the inlet size and thereby reducing cooling drag. Bill, I like your idea of inserting plugs into the standard inlets to experiment with different sizes. That would allow you to find the "right" size to minimize cooling drag yet retain sufficient cooling. I've been wondering how to play with that without making permanent changes to the cowl. In summary, Kent Paser accounts for reversed air flow at the inlet saying, in effect, there is more air coming in than can get out the bottom, hence it reverses direction to get out however it can... and, air doesn't like to change direction - it hits the spinner, flows off and if you let it flow directly into the inlet then you have reduced drag. Sorry for the long post but I find this stuff REALLY interesting and can hardly wait to get my own in the air to experiment with the plenum. One thing more - Ken Paser backs up his experiments with hard data - "I did this and got so many MPH change" - although he sometimes combines a lot of small changes before he reports a result. Not to poo-poo the EAA "expert"... but can he say as much? >Bill Benedict once told me that they put yarns on the inlets once and >noticed that the interior portion of the rextangular opening actually >flowed forward. > I saw an expert on cooling drag speak at an EAA Meeting a year or so > ago, and he stated that it is now fairly well understood that cowl > openings spaced some distance from the spinner are the most > efficient. It turns out that if the opening goes all the way to the > spinner (as on Vans cowlings), local flow right next to the spinner > is actually reversed (i.e. flow goes out the front). If you move the > opening out a couple of inches from the spinner, you can actually > reduce the opening size quite a bit and still have enough air flow > for cooling. ==== Michael E. Thompson (Grobdriver(at)yahoo.com) Austin, TX, USA RV-6 in progress, N140RV Ex-AX1 Sub Hunter, P-3 (B/B-TACMOD/C) Orion Aircrew, PP-G,ASEL, Motorglider Driver and Unlimited Air Race Nut! 9-11: A tribute to the more than 3,000 lives lost http://dir.remember.yahoo.com/tribute ________________________________________________________________________________
Date: Sep 10, 2002
> Another option is to go along the coast down to Half Moon Bay and then cut > over the hills directly to PAO. That way you can avoid the class B. But > again, watch out for cutting into SQL class D. Coming that way will put you > on a 45 to right downwind for 31, more or less. Um, *left* downwind...sorry. 8 ) )_( Dan ________________________________________________________________________________
Date: Sep 10, 2002
BILL-SAM JAMES SELLS THE FIBERGLASS ROUND INLETS WITH THE RIGHT RADIUS WHICH IS VERY IMPORTANT-TOM Whelan Farms Airport / CT01 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 e-mail: wfact01(at)aol.com Telephone: 203-266-5300 Fax: 203-266-5140 President, EAA Chapter 1097 EAA Technical Counselor RV-8 Lycoming IO540 (Getting Close) ________________________________________________________________________________
inlets
Date: Sep 10, 2002
Steve Barnard's cowl was based on a NASA grant given to Mississippi State for the" Study of Aerodynamics of Horizontally-opposed aircraft engine installations " With a 200hp IO360 with a constant speed prop, Steve claimed 220mph at 8500' density altitude, full throttle, 2700 RPM Economy cruise= 205 mph ROC=2700 FPM Stall--full flaps= 53mph Ed Cole RV6A N2169D Flying RV6A N648RV Finishing --with Bernard's Original Cowl and 200hp IO-360 > -----Original Message----- > From: Mike Thompson [SMTP:grobdriver(at)yahoo.com] > Sent: Tuesday, September 10, 2002 11:19 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Re: RV8-List: Drag increase due to too high > cowling inlets > > > I've combined two different posts because they have a common point > regarding the "reversed" or "forward" flow of cooling air at the inlet. > Maxim Home Page: http://www.maxim-ic.com Products Page: http://www.maxim-ic.com/MaximProducts/products.htm New Products: http://dbserv.maxim-ic.com/new_products.cfm Datasheets: http://dbserv.maxim-ic.com/l_datasheet3.cfm The information contained in this message is confidential and may be legally privileged. The message is intended solely for the addressee(s). If you are not the intended recipient, you are hereby notified that any use, dissemination, or reproduction is strictly prohibited and may be unlawful. If you are not the intended recipient, please contact the sender by return e-mail and destroy all copies of the original message. ________________________________________________________________________________
Date: Sep 10, 2002
Subject: RV4 fuel tanks
Listers, Does anyone know of ways to increase the fuel capacity of the RV4? I am concerned that the 32 gals avail with 180 hp is really not enough for serious cross country type flying. I have heard in the past that some innovative and creative RVers have solved this problem. Please let me know how this can be done cost effectively. Thanks! Scott ________________________________________________________________________________
Date: Sep 10, 2002
Subject: Firewall construction questions
Date: Sep 10, 2002
First of all...this is for an RV-7 taildragger with an IO-360-A1B6... 1) F-601TD is the "brake plate" that goes on the lower left of the firewall. Is there any harm in drilling the two 7/16" holes through the plate and firewall now, or should I wait until I'm setting up the master cylinders and all that? 2) F-601Z is the "aux fuel firewall doubler" that goes on the bottom of the firewall and has two -4 nutplates for the "Facet Elec Fuel Pump" (apparently). I guess the question is twofold: a) Dwg 36 says "IF REQ'D; NOT PROVIDED IN KIT" -- does everybody use this type of fuel pump with the IO-360-A1B6? b) I assume I should wait until I have the pump in hand to drill the nutplate holes using the mounting brackets as a drill template...right? Thanks in advance, )_( Dan RV-7 N714D (fuselage) http://www.rvproject.com ________________________________________________________________________________
Date: Sep 10, 2002
Subject: Re: "mag" drop with electronic ignition
Bob, Boyd isn't the first person to report better performance (i.e. higher horsepower) from the use of EI. Others on the RV-List have made similar claims. Klaus Savier at LSE told me at OSH that his system will increase power by 3-5 hp if memory serves me correctly, and Bart Lalonde at Aerosport Power says without a doubt that it shows up on the dyno at about 4 hp increase for an O-360. My humble understanding is that the combination of spark advance and hotter spark allows more complete burning of the mixture in the combustion chamber, instead of having part of mixture still uselessly burning as it exits the exhaust valve (this is why replacing mags with EI results in lower EGT's). Anyway the more complete combustion results in either greater efficiency at a given power setting, or greater power at a given fuel flow. Neither will radically change your performance or range, but the change is *measurable* both in theory and in reports from actual operation.... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing with dual LSE Plasma ignitions.... - From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: "mag" drop with electronic ignition --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" >--> AeroElectric-List message posted by: "Boyd C. Braem" > >The EI IS doing all the work! In my airplane (with a '98 LSE EI), with the EI >on, performance data from Vx, Vy and top speed are completely unaffected as to >the Bendix mag being on or off. RPM drop during run-up is -200 >rpm. After mag >"rebuild" at 400 hrs, there's no change in performance data. Performance with >the single mag, alone, is Horrible--it's like I have a 160 hp -360 or >something. Did anyone claim that the performance of your airplane would change in any observable way? If someone told you that you can expect any increase in horsepower or markedly lower operating costs for fuel was either in error or blowing smoke . . . Bob . . . ________________________________________________________________________________
Date: Sep 10, 2002
David, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A (120 hrs) >From: "davefried" <davefried(at)rogers.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: C-GZDF - First Flight of DF-6 (Taperwing) >Date: Mon, 9 Sep 2002 17:08:49 -0400 > ________________________________________________________________________________
Date: Sep 10, 2002
Subject: Re: RE: alternate canopies--feedback on Todd's Canopies
As far as canopee pricing is concerned, I went straight to the horses (Van's) mouth > Hi Folks > > What's the price of a replacement canopee for a RV8 ?? > > What price do I subtract from the finishing kit if I get an alternative > canopee and not buy yours ?? > > > Thanks > > Gert > > > #80721 > > The canopy in the kit is $392. A replacement canopy is $523.08. > Alternatively, sometimes we have a canopy with a slight blemish > available for $340 > Anne I went with Todd's canopee because of the replacement value Todd promises in case of breakage, the tint and the 1/4 inch thickness. I was one of the original group orders I have not installed my canopee yet, however, my canopee was delivered in a cardboard box nailed to a 2x2 framework. The box arrived with several 2x2 frames cracked and splintered, but as far as I can tell at this point I do not have any damage to my canopee other than a possible scuff mark at the apex of the canopee. This was all shear luck as my canopee was just laid unsecured in the cardboard box, free to rattle around, that's what scuffed the top, hopefully it is only the clingwrap covering the canopee at the moment. Gert ________________________________________________________________________________
Date: Sep 10, 2002
cowling inlets The theory as I understand it is that an inlet which is not spaced away from an upstream surface ingests lower energy boundary layer air. The boundary layer is slowed down by surface friction and thickness of the boundary layer is proportional to the amount of surface upstream of the inlet. The further back on the fuselage the inlet is the greater the spacing required to prevent ingestion of boundary layer air. I dont know if there is a significant boundary layer right at the front of the cowl caused by the spinner. Another effect is that of the prop, particularly a wood prop (or any other type with a very thick root section). The closer to the root end of the prop, the thicker (and potentially draggier) it is. Tracy Crook with his Mazda powered RV4 suffered a dramatic coolant temperature increase when he switched from a wood prop to an Ivoprop which had a particularly draggy root section. The Mustangs (like Paser's) use a 16" spinner so this effect would presumably be less noticeable than with an RV spinner. If the stock RV cowl exhibits flow reversal at cruise speeds this would seem to suggest to me that it might benefit from a combination of somewhat smaller inlets and an adjustable cowl flap. Has anyone experimented with cowl flaps? Mike Wills RV-4 firewall forward details; Mazda powered > >The point that inlets are more efficient spaced away from the spinner >is 180 degrees out from Paser's conclusion that air spilling off the >spinner and flowing directly into the inlet works better. I must say >that Paser's description matches my own understanding of physics. He >moved his inlets inward and decreased their size and picked up speed. > >Kent also describes the way cooling air can back up inside the cowl >when the inlet size exceeds the exhaust size - IOW the inlets let in >more air than can escape down and out of the cowl, so it escapes >forward. ________________________________________________________________________________
Subject: Vx & Vy
Date: Sep 10, 2002
I've been doing new flight testing after my overhaul/new Aymar prop on my RV-3. I'm getting a Vy of 105 KIAS, and a Vx of 70 KIAS. I realize that every airplane is a bit different, but is a 35 knot spread bewteen Vx and Vy "normal" for RV's? I've crunched the numbers a few times, and I have good confidence in my raw data. Did the stopwatch/block climb procedure as has been covered in recent issues of "Sport Aviation." Still, this spread seems pretty big when compared to those found in write-ups about your basic spam cans in AOPA "Pilot" or "Flying." These Vx/Vy spreads always seem to be 10 to 15 mph apart. Now I know that an RV is no "spam can" - thank goodness, heck, that's why we fly RV's and not stuff from Wichita or elsewhere - but I can't help but wonder if I did something wrong in my testing. Randy Compton Gulf Breeze, FL RV-3A N148CW ________________________________________________________________________________
Date: Sep 10, 2002
Subject: Re: RV4 fuel tanks
You could purchase a set of rocket tanks. I believe there are two different capacities out there of which both are considerably more than the RV4. RV 4 273Sb in CO. ________________________________________________________________________________
Date: Sep 10, 2002
Subject: Re: RV8-List: RV-8 interest
Hi Don, I'm at the same stage as you, having just developed an intense interest in a RV 8 project. I have done a lot of reading and investigation into the project by first joining the national EAA (Experimental Aircraft Association) and the local chapter, 186. As a result I have made a lot of friends in the area who have completed or are in process of building RV8's. I would be happy to talk to you about my findings. I'm in the Mt.Vernon area and I work for NASA in DC. Also check out the web sites. Doug Ritter 703-360-5219 home 202-358-0025 work >--> RV8-List message posted by: "Watrous, Donald" > >I am interested in learning more about the RV-8, especially with regards to >it's aerobatic capabilities and performance. Is there anyone out there in >the in the metropolitan D.C. area who built/flies one and would be willing >to educate me? I am a military pilot thinking about owning an airplane >suitable for both weekend acrobatics and cross-country trips. My friends >indicate the RV-8 may fit both my desires and budget. Any help would be >appreciated. My individual e-mail account is watrousd(at)ndu.edu > . Thank You. > >Don W. > > ________________________________________________________________________________
Date: Sep 10, 2002
From: "Michael J. Veth" <vethm(at)vsrtechnology.com>
Bob, Check out the Ignition Dynamics reports that CAFE did. Very interesting reading. http://www.cafefoundation.org/research.htm Mike Veth RV-8A Wings Dayton, OH czechsix(at)juno.com wrote: > > Bob, > > Boyd isn't the first person to report better performance (i.e. higher > horsepower) from the use of EI. Others on the RV-List have made similar > claims. Klaus Savier at LSE told me at OSH that his system will increase > power by 3-5 hp if memory serves me correctly, and Bart Lalonde at > Aerosport Power says without a doubt that it shows up on the dyno at > about 4 hp increase for an O-360. My humble understanding is that the > combination of spark advance and hotter spark allows more complete > burning of the mixture in the combustion chamber, instead of having part > of mixture still uselessly burning as it exits the exhaust valve (this is > why replacing mags with EI results in lower EGT's). Anyway the more > complete combustion results in either greater efficiency at a given power > setting, or greater power at a given fuel flow. Neither will radically > change your performance or range, but the change is *measurable* both in > theory and in reports from actual operation.... > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D finishing with dual LSE Plasma ignitions.... > - > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > Subject: AeroElectric-List: Re: "mag" drop with electronic ignition > > --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" > > > >--> AeroElectric-List message posted by: "Boyd C. Braem" > > > > >The EI IS doing all the work! In my airplane (with a '98 LSE EI), with > the EI > >on, performance data from Vx, Vy and top speed are completely unaffected > as to > >the Bendix mag being on or off. RPM drop during run-up is -200 > >rpm. After mag > >"rebuild" at 400 hrs, there's no change in performance data. > Performance with > >the single mag, alone, is Horrible--it's like I have a 160 hp -360 or > >something. > > Did anyone claim that the performance of your airplane would > change in any observable way? > > > > If someone told you that you can expect any increase in > horsepower or markedly lower operating costs for fuel > was either in error or blowing smoke . . . > > Bob . . . > ________________________________________________________________________________
Date: Sep 10, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
BrownScottA(at)aol.com wrote: > > > Listers, > > Does anyone know of ways to increase the fuel capacity of the RV4? I am > concerned that the 32 gals avail with 180 hp is really not enough for serious > cross country type flying. I have heard in the past that some innovative and > creative RVers have solved this problem. Please let me know how this can be > done cost effectively. Thanks! > > Scott > You can get (expensive) tip tanks from Van's. ________________________________________________________________________________
Date: Sep 10, 2002
I went with the Lightspeed on the right side with a freshly overhauled Slick mag on the left as part of my O-320's major overhaul...and frankly I haven't seen much change at all. The fuel burn is somewhat better (lower gph at cruise) and the climb performance is a little, and I mean little, better than before. But all of this could be due to the fresh overhaul as much as from the Lightspeed. I hate to say it, but my post-overhauled, modified firewall-forward RV-3 looks to be the same ol' girl, just a different dress. Randy Compton Gulf Breeze, FL RV-3A N148CW ________________________________________________________________________________
Date: Sep 10, 2002
tip tanks don't give you much extra volume and area lot of work. If you are building you can extend the existing tanks or create extra leading edge tanks with minimal work. Ferry tanks are the easiest and cheapest if you don't have a passenger. I made mine just like the wing tanks, sheet AL, ribs and rivets and plenty of pro-seal. I plumbed an additional valve to the existing one and now have 5 possible inlets. Baggage area tanks quickly hit the weight limits of balance. My -6A has a 18.4 gallon baggage area ferry tank. "Bladder Buster" tanks extended the wing, but they are out of business I believe. With an oxygen system you can seriously decrease your fuel burn by flying at 16,000'. My O-320 burns under 5.0 gal/hr at 16K, 145kts., that's 11 hrs of flying with my ferry tank. Kevin ----- Original Message ----- From: "Charlie and Tupper England" <cengland(at)netdoor.com> Subject: Re: RV-List: RV4 fuel tanks > > BrownScottA(at)aol.com wrote: > > > > > > Listers, > > > > Does anyone know of ways to increase the fuel capacity of the RV4? I am > > concerned that the 32 gals avail with 180 hp is really not enough for serious > > cross country type flying. I have heard in the past that some innovative and > > creative RVers have solved this problem. Please let me know how this can be > > done cost effectively. Thanks! > > > > Scott > > > You can get (expensive) tip tanks from Van's. > > ________________________________________________________________________________
Date: Sep 10, 2002
on our trip to AK last year, my Jeff Rose ignition , 160hp, beat the 150hp Bendix powered -6A by $10+ at every fill-up. Our planes are identical otherwise. I think that trip alone paid for the ignition! Kevin ________________________________________________________________________________
Subject: viruses
Date: Sep 10, 2002
With the introduction of the KLEZ virus, it is no longer possible to assume that the person in the 'from:' field is really the sender. Spammers have known for some time how to alter the sender info to hide themselves, usually using some obviously made-up email address. KLEZ does the same thing but makes it more plausible by stealing addresses from the infected machine's address book and email files. The best protection is to never open an attachment unless you are specifically expecting them; if you get an unexpected file, check with the sender before opening it - no virus yet knows how to automatically respond to such queries. This includes files received from your parents, spouses, etc. - people whose machines are infected generally don't know it. Good anti-virus software helps. Most of it not only can identify and remove many known viruses but can also detect and prevent virus-like activity. Unfortunately, the latter capability can interfere with normal activities, like Windows Installer trying to update or remove a program, and so often gets disabled. Another good source of info is www.nai.com in addition to the ones mentioned by other 'listers. I use one of the 'riskiest' email programs (Outlook) and spend a huge amount of time on the Internet and have yet to be infected. However, I do get the occasional virus (haven't received on addressed from myself yet, that must've been weird :> ) sent to me; I just delete the attachment file. While Outlook may have some dangerous features, it can be set to deny attachments and, in fact, I filter much spam with it. Other email programs have similar facilities. (Please don't ask me for instructions; I'm not an expert on these programs and only have slight experience with a few of them.) If you do receive a virus, notify your service provider, preferably emailing them a copy of the suspect email (sans attachment) so that they can look in their logs and see where it came from. Most ISPs only accept email from users on their networks or other ISPs; remote sending has been disappearing in response to, for instance, non-AOL users sending spam via AOL mail servers. In any case, only the ISP has any hope of determining the sender. On the Anesthesia domain at Univ. of Chicago, we were able to detect our people who were infected (in fact, we filtered viruses at the mail server so we often knew who had them before anyone else did) and were also able to catch incoming viruses. However, our efforts to coordinate with other providers met with mixed results; many ISPs care little beyond their own domains due to the size of the problem. Not all ISPs can filter the email through their system; they have no way to respond to the angry users who got an email with no attachment because the filter stopped it - it was tough for us with only 200 - 300 users. Patrick Kelley - RV-6A - patiently? waiting for fuselage kit Flion Consulting - Computer and Networking Support -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of 3 rotor Subject: Re: RV-List: viruses it came directly from you (well, that's what it read as ) and was the CLEF virus, or something like that. I haven't had another case for several days now. ________________________________________________________________________________
Date: Sep 10, 2002
3 rotor wrote: > > > on our trip to AK last year, my Jeff Rose ignition , 160hp, beat the 150hp > Bendix powered -6A by $10+ at every fill-up. Our planes are identical > otherwise. I think that trip alone paid for the ignition! Kevin > I think you will find that if two RV's (same model) fly at the same speed in 150-160K cruise range, the 150hp engine will always use more fuel, everything else being more or less equal. It is just a matter of the lower-powered engine having to work harder to keep up....... This is precisely the situation I found when I was flying my 150 hp RV-6 with other 160hp RV-6A's. It is interesting to note that the 200hp constant-speed prop RV-8 in our group will use less gas than the O-320's at about 160K! My 160hp O-320 will now cruise 10K faster with the same fuel flow as the old 150hp version. Sam Buchanan (RV-6, 418 hrs) "The RV Journal" http://thervjournal.com ________________________________________________________________________________
Date: Sep 10, 2002
In a message dated 9/10/02 9:49:49 PM Eastern Daylight Time, sbuc(at)hiwaay.net writes: << My 160hp O-320 will now cruise 10K faster with the same fuel flow as the old 150hp version. Sam Buchanan (RV-6, 418 hrs) "The RV Journal" http://thervjournal.com >> Woah there!... Didn't you also repitch the prop, change intersection fairings, change gear leg fairings, and change wheel pants? Do those mod's contribute to the 10 knot improvement, or is the entire 10 knot improvement entirely due to the engine rebuild/compression change? Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Sep 10, 2002
inlets > >I am thinking about making fiberglass plug inserts for my conventional >cowling that would adapt the factory oval, large inlets to smaller, circular >inlets as in the Holey Cowl design. If I did so, should I make the diameter >equal to the height (smallest dimension) of the factory inlets, or would I >need to remove some original cowl material to get the round inlets a bit >larger? I would appreciate a suggested starting diameter for round inlets, >in other words. > >Will this change play heck with my cylinder cooling, which is presently very >good and very well balanced? I am tempted to "leave well enough alone," but >the heat is on to get all the anticipated speed mods done at one time, so I >only have to repitch my Sensenich _once_ after all the clean-up and hop-up is >finished. > >Thanks in advance. > >Bill Boyd Here's what I would do, for what it's worth. First, I would make sure I had good data on the current configuration. I would want to be sure I knew what CHTs and oil temperature to expect at using my normal climb speed and power, and in cruise at whatever altitude and power I normally used. I would want enough data so that I knew how the engine temperatures varied with various outside air temperatures. I would also want be very sure I knew what my cruise speed was under a particular condition of interest. You should have the test technique nailed down well enough that all this data is very repeatable. If you can't get repeatable data you have no way to evaluate the effect of changes. One trick for checking cruise speed - if you climb to altitude and level off, it will take a long, long time to finally reach a stable speed. If you know from experience what IAS to expect, you can climb a bit above the test altitude, then dive down and accelerate to this IAS, set power and wait a bit to see what speed you get. Cruise speed testing is much more repeatable if you can do it with the throttle fully open, so you always get the same MP. Once you know the cruise and cooling perf of the current configuration (including in a worst case hot summer condition), you can start making changes and evaluating the effects. Personally, I wouldn't bother trying to do a round inlet mod - too much work. But, I would make up some inserts to go in the inboard or outboard edge of the air inlet, and use some duct tape to hold them in place. This way you could try reducing the air inlet area by filling in the inboard edge, and then try the same area reduction by filling in the outboard edge instead to see the difference. If you want to get the maximum performance improvement, you'll probably want to use a plenum chamber type system. This should reduce the cooling air leaks, and let you get equal cooling with less air (i.e. smaller inlet air area). Keep us posted, -- Kevin Horton RV-8 (spinner, cowling) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
Date: Sep 10, 2002
Don Watrous wrote: I am interested in learning more about the RV-8, especially with regards to it's aerobatic capabilities and performance. Is there anyone out there in the in the metropolitan D.C. area who built/flies one and would be willing to educate me? I am a military pilot thinking about owning an airplane suitable for both weekend acrobatics and cross-country trips. My friends indicate the RV-8 may fit both my desires and budget. Any help would be appreciated. My individual e-mail account is watrousd(at)ndu.edu . Thank You.< Don, some time ago one of the magazines, KIt Planes or Sport Aviation, had in their "aircraft completed and restored" photo section an RV-8 built by a very high-time retired fighter jock whose comment was that it was "the best airplane he ever flew". You can take this as the hearsay that it is, but my high-time building partner, who flew F-104s and F-16s for the Norwegian AF, after flying the Van's demo RV-8, said to me "we have to build this airplane". My suggestion is to hook up with someone in your area and take a hop, or fly out to Van's and take the $60,000 free ride. Have fun! Andy Johnson, fuselage systems 'n stuff. ________________________________________________________________________________
Date: Sep 10, 2002
KBoatri144(at)aol.com wrote: > > > In a message dated 9/10/02 9:49:49 PM Eastern Daylight Time, sbuc(at)hiwaay.net > writes: > > << My 160hp O-320 will now cruise 10K faster with the same fuel flow as the > old 150hp version. > > Sam Buchanan (RV-6, 418 hrs) > "The RV Journal" http://thervjournal.com >> > > Woah there!... Didn't you also repitch the prop, change intersection > fairings, change gear leg fairings, and change wheel pants? Do those mod's > contribute to the 10 knot improvement, or is the entire 10 knot improvement > entirely due to the engine rebuild/compression change? > The better cruise performance I referenced occurred after the engine overhaul. Ok...ok....maybe a little of the boost came from the fresh engine, but I think if you search the archives and talk to pilots who have experience with both 150hp and 160 hp in the same plane that you will find the 160hp will be more efficient at cruise speeds. These numbers are very hard to nail down precisely because there are so many variables, but I feel safe in making the general assumptions I have stated. Notice I didn't mention increase in top speed after all the mods were made; that resulted in more than 10K increase! :-) I only stated changes in speed at a specific fuel flow following the change from 150hp to 160hp. The prop was repitched only to bring it into standard specs for a 160hp engine. By the way, some of the other speed improvements occurred after I sealed the aileron and elevator gaps with NASCAR stickers. I also used a large hammer to "fair" in some of the protrusions where the rudder cables exit and the tail wheel spring protrudes. The new chrome tailpipe extensions also added a knot or two, but I lost that gain when I added the "Heart of Dixie" license plate to the lower cowl...... Sam Buchanan ________________________________________________________________________________
Date: Sep 10, 2002
Roger Crandell wrote: --> RV6-List message posted by: Roger Crandell Does anyone have six ms21053L08K platenuts (anchor nuts) which you would sell? These are single eared, 8-32, countersunk, black steel platenuts. I have tired all sources and no one stocks them. If they special order, they have a large minimum order quantity. Yes, there are other options to these, but these would work the best for my specific application. I am building an RV6A. I hope to finish by March 2003. Thanks Roger I am assuming you are able to get #8 platenuts in non countersunk single ear variety. I use these and simply added a .040 shim and countersunk the shim. Pt --------------------------------- 9-11: A tribute to the more than 3,000 lives lost ________________________________________________________________________________
Subject: Oswego RV Forum
Date: Sep 10, 2002
Does anyone have a list of the prize winning RV's from this past weekend at the RV Forum in Oswego? Jim Cimino RV-8 sn 80039 N7TL 75+ Hrs. http://www.geocities.com/jcimino.geo/ (570)842-4057 ________________________________________________________________________________
Date: Sep 10, 2002
Subject: Re: Strength of riveted joints
> >Oh yeah, and prime those lap joints well. They are the number 1 place for >corrosion to find a home. Joints are the number one corrosion spots because water collects there and etc, etc. Prime yes, but also don't have joints, laps etc where water can collect and not drain back out. CHEM 101: What is the most powerful solvent on planet earth??? ANS( water ). Took me a long time to figure this out. It will dissolve aluminum or make it wish it was dissolved! K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Sep 10, 2002
Let's see now. Same airplane at same speed should in theory produce the same amount of aerodynamic drag which will require the same amount of thrust horsepower to balance said drag. Re-pitching the prop could change the advance ratio vs. prop efficiency curve a bit so possibly the engine needs to produce less mechanical horsepower to provide the same thrust horsepower. Producing less mechanical horsepower requires less chemical energy = fuel. Then to, the engine specific fuel consumption is presumably improved a bit by the slightly higher compression ratio, this being the usual method to get the extra ten horses out of the same cubic inch "swept volume" in the cylinders in the 160 hp O-320s. Interesting that the fuel consumption numbers are so noticeably better. BTW, how does one go about arranging gap seals with NASCAR stickers?? Any special driver or sponsor name required ?? Will Greenpeace stickers or last years political campaign bumper stickers do ?? Inquiring minds need to know, Sam. Jim Oke Winnipeg, MB RV-6A (just found out how many pinholes are in an S type cowl after the first primer coat; well, no, actually I lost count......) ----- Original Message ----- From: "Sam Buchanan" <sbuc(at)hiwaay.net> Subject: Re: RV-List: Re: "mag" drop with electronic ignition > > > KBoatri144(at)aol.com wrote: > > > > > > In a message dated 9/10/02 9:49:49 PM Eastern Daylight Time, sbuc(at)hiwaay.net > > writes: > > > > << My 160hp O-320 will now cruise 10K faster with the same fuel flow as the > > old 150hp version. > > > > Sam Buchanan (RV-6, 418 hrs) > > "The RV Journal" http://thervjournal.com >> > > > > Woah there!... Didn't you also repitch the prop, change intersection > > fairings, change gear leg fairings, and change wheel pants? Do those mod's > > contribute to the 10 knot improvement, or is the entire 10 knot improvement > > entirely due to the engine rebuild/compression change? > > > > > The better cruise performance I referenced occurred after the engine > overhaul. Ok...ok....maybe a little of the boost came from the fresh > engine, but I think if you search the archives and talk to pilots who > have experience with both 150hp and 160 hp in the same plane that you > will find the 160hp will be more efficient at cruise speeds. > > These numbers are very hard to nail down precisely because there are so > many variables, but I feel safe in making the general assumptions I have > stated. > > Notice I didn't mention increase in top speed after all the mods were > made; that resulted in more than 10K increase! :-) I only stated > changes in speed at a specific fuel flow following the change from 150hp > to 160hp. The prop was repitched only to bring it into standard specs > for a 160hp engine. > > By the way, some of the other speed improvements occurred after I sealed > the aileron and elevator gaps with NASCAR stickers. I also used a large > hammer to "fair" in some of the protrusions where the rudder cables exit > and the tail wheel spring protrudes. The new chrome tailpipe extensions > also added a knot or two, but I lost that gain when I added the "Heart > of Dixie" license plate to the lower cowl...... > > Sam Buchanan > > ________________________________________________________________________________
Subject: Re: RV8-List: Drag increase due to too high cowling inlets
Date: Sep 10, 2002
I agrre with Kevin about modifying your inlet shape. Think about the air passage inside the cowl, many places to clean up sharp corners. I've seen baffles to prevent cooling air from escaping from around the spinner and help it smoothly go to the rear for instance. I have read a lot about exhaust augmentation where the exhaust boost is used to accelerate the cooling air as it leaves the cowl. Don't get too busy with the inlet when so much can be done downstream which won't even mess up your paint job (not that it ever stopped me:-) Kevin (Lane) ----- Original Message ----- From: "Kevin Horton" <khorto1537(at)rogers.com> Subject: Re: RV-List: Re: RV8-List: Drag increase due to too high cowling inlets > > > > >I am thinking about making fiberglass plug inserts for my conventional > >cowling that would adapt the factory oval, large inlets to smaller, circular > >inlets as in the Holey Cowl design. If I did so, should I make the diameter > >equal to the height (smallest dimension) of the factory inlets, or would I > >need to remove some original cowl material to get the round inlets a bit > >larger? I would appreciate a suggested starting diameter for round inlets, > >in other words. > > > >Will this change play heck with my cylinder cooling, which is presently very > >good and very well balanced? I am tempted to "leave well enough alone," but > >the heat is on to get all the anticipated speed mods done at one time, so I > >only have to repitch my Sensenich _once_ after all the clean-up and hop-up is > >finished. > > > >Thanks in advance. > > > >Bill Boyd > > Here's what I would do, for what it's worth. > > First, I would make sure I had good data on the current > configuration. I would want to be sure I knew what CHTs and oil > temperature to expect at using my normal climb speed and power, and > in cruise at whatever altitude and power I normally used. I would > want enough data so that I knew how the engine temperatures varied > with various outside air temperatures. I would also want be very > sure I knew what my cruise speed was under a particular condition of > interest. You should have the test technique nailed down well enough > that all this data is very repeatable. If you can't get repeatable > data you have no way to evaluate the effect of changes. > > One trick for checking cruise speed - if you climb to altitude and > level off, it will take a long, long time to finally reach a stable > speed. If you know from experience what IAS to expect, you can climb > a bit above the test altitude, then dive down and accelerate to this > IAS, set power and wait a bit to see what speed you get. Cruise > speed testing is much more repeatable if you can do it with the > throttle fully open, so you always get the same MP. > > Once you know the cruise and cooling perf of the current > configuration (including in a worst case hot summer condition), you > can start making changes and evaluating the effects. Personally, I > wouldn't bother trying to do a round inlet mod - too much work. But, > I would make up some inserts to go in the inboard or outboard edge of > the air inlet, and use some duct tape to hold them in place. This > way you could try reducing the air inlet area by filling in the > inboard edge, and then try the same area reduction by filling in the > outboard edge instead to see the difference. > > If you want to get the maximum performance improvement, you'll > probably want to use a plenum chamber type system. This should > reduce the cooling air leaks, and let you get equal cooling with less > air (i.e. smaller inlet air area). > > Keep us posted, > -- > Kevin Horton RV-8 (spinner, cowling) > Ottawa, Canada > http://members.rogers.com/khorton/rv8.html > > ________________________________________________________________________________
Date: Sep 10, 2002
From: Jaye and Scott Jackson <jayeandscott(at)shaw.ca>
Yikes! What a project! Russ P should send you a Christmas card after all this. What a great looking cockpit and panel. ----- Original Message ----- From: "gert" <gert(at)execpc.com> Subject: Re: RV-List: RE: alternate canopies--feedback on Todd's Canopies > > As far as canopee pricing is concerned, I went straight to the horses > (Van's) mouth > > > > Hi Folks > > > > What's the price of a replacement canopee for a RV8 ?? > > > > What price do I subtract from the finishing kit if I get an alternative > > canopee and not buy yours ?? > > > > > > Thanks > > > > Gert > > > > > > #80721 > > > > > > The canopy in the kit is $392. A replacement canopy is $523.08. > > Alternatively, sometimes we have a canopy with a slight blemish > > available for $340 > > Anne > > > I went with Todd's canopee because of the replacement value Todd > promises in case of breakage, the tint and the 1/4 inch thickness. I was > one of the original group orders > > > I have not installed my canopee yet, however, my canopee was delivered > in a cardboard box nailed to a 2x2 framework. The box arrived with > several 2x2 frames cracked and splintered, but as far as I can tell at > this point I do not have any damage to my canopee other than a possible > scuff mark at the apex of the canopee. This was all shear luck as my > canopee was just laid unsecured in the cardboard box, free to rattle > around, that's what scuffed the top, hopefully it is only the clingwrap > covering the canopee at the moment. > > Gert > > ________________________________________________________________________________
Date: Sep 11, 2002
So Cal RV Group
Subject: RV Kit Problems
Hi all: For those still building, in particular with the QB fuselage for the -8 series and probably any of the wings, I wanted to pass on two problems I ran into with the kit. Both of these were confirmed by Vans but it appears to be just the "luck of the draw" that I encountered them. 1. QB -8 series fuselage. See drawing 27. The fuselage support angle to which the forward HS spar is bolted was mislocated by about 1/8 inch too far aft. This meant that the 4 AN3 bolts that hold the forward spar to the fuselage had insufficient edge clearance. The fix was to drill out and remove the F-810 C angle and F-810 D spacer and replace them with corresponding parts that were wider. Van sent the material and I made up the components. Due to access problems, I also had to replace the 8 AN470AD4-6 rivets through the F-810C angle and F-810 bulkhead with AN3 bolts. You can learn if you have this problem by placing the horizontal stab in place, clamping it to the F-811B bars and measuring to see if the forward edge of the HS 814 angle in the stabilizer is approximately aligned with the forward edge of the F-810C angle in the fuselage. If it is not, you may have the edge clearance problem. 2. Fuel leak through wing tank access plate. This problem may exist in all of the planes but I am not sure of that. Therefore I will explain it generically. Everyone has a round plate on the inboard tank rib for fuel tank access and/or sender mounting. A gasket is provided to seal the plate to rib junction. Note this area carefully. There is also a small tooling hole in the rib near the spar that is supposed to be covered by the gasket. The hole has to be covered because it constitutes a direct opening to the tank. However, at least in my installation, the outer edge of the hole was just about tangent to the gasket. Since the rest of the hole was covered, except for this tiny edge, I did not notice the potential problem and did a leak test with the wing temporarily mounted on the fuselage. That is when I noticed the leak. I had sealed all the screw threads and was surprised to see a leak around the O.D. of the access plate, where I assumed it had come through a nutplate. Disassembly identified the hole as the source and some tank sealant on the inside of the tank to cover the hole more fully cured the problem. In short, pay attention to this hole location relative to the gasket. If it is not well within the edges of the gasket, you will have to seal it separately. Bill Marvel -- Bill Marvel Home/office 310 832 7617 P.O. Box 784 Cell 310 293 2013 San Pedro, CA 90733 Fax 310 832 5334 One good deed beats 100 good intentions... ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Ellison Throttle Body Question
Hi - I have a question for someone who has experience installing an Ellison Throttle Body in either an RV-8 or an RV-4. I have an RV-8A that I am putting an XP-360 engine on. Superior is keeping the carburetor (and giving me a credit) but I have to order the throttle body and have it sent to the build shop. Which leads to the question... When I order the throttle body, I have to tell them whether I want the throttle linkage on the front (toward the prop) or in the back (toward the firewall). The throttle movement is actually PERPENDICULAR to the thrust line (at least that is how Ellison recommends the set up). I talked to Van's, but their advice was not real solid. Their Ken Kruger used to have an RV-6 with the Ellison, but they were telling me that I would probably be changing it to where the throttle movement was PARALLEL to the thrust line. With that in mind, their recommendation was to order it with the throttle linkage in the back. Of course, my throttle is on the left (as opposed the the center for the RV-6), so my options are different. I can see where with the RV-6 and the center throttle you could (and maybe would) want the throttle movement fore and aft... Regardless, I'm thinking that I won't really want to change this around - if Ellison recommends a certain throttle linkage orientation, then that's what I want to keep. However, even in my state of ignorance, I'm thinking that I would still be better off ordering it with the throttle linkage in the back. The hurdle (that I can see from photos etc. that I have found on builders' web sites) is working around/staying clear of these exhaust system. Whether this would be more easily done mounting the throttle linkage on the firewall side or on the prop side, I do not know. Of course, in reality it may not matter - back or front would work just fine. What do you think? Thanks! Scott Brumbelow #80077 ________________________________________________________________________________
Date: Sep 11, 2002
George, When I did my cowl I carefully collected data on engine sag. In fact I put together a spreadsheet with all the data and broke all the configurations out.... O-320/fixed, O-320 c/s, O-360 fixed, O-360 c/s, IO-360 (angle valve) fixed... etc. To make a long story short I concluded from the reported data that my configuration (carbureted O-360 c/s) would sag 3/16", therefore I positioned my cowl a bit low relative to the spinner with this in mind. I now have 255 hours on the plane and it has not dropped at all. In fact my spinner still looks too high which bugs me every time I look at it. So, did yours really drop, and how much? Randy Lervold RV-8, 255 hrs, standard mounts from Van's www.rv-8.com > --> RV8-List message posted by: "Sally and George" > Another thing to consider, if you're working on your cowl: Set it up wit> h the top of the spinner about 1/4 inch higher than the top of the cowl. > That's because, after 100 hours or so, the engine will sag slightly on t> he mounts. If you set up initially with a the spinner matching the cowl > contour, you will later have an unsightly step down from cowl to spinner.> 1/4" worked just fine for me, but you could also add a little more, jus> t in case. Having the spinner slightly higher than the cowl looks okay, > but the converse is not true. > > George Kilishek > RV-8 N888GK > 80+ hours ________________________________________________________________________________
Date: Sep 11, 2002
Scott: Depends on what your goals are, but I really find that my 32 gal RV-4 (180hp with C/S, Bendix FI) is really very suitable. I consistently burn right at 8 gph (22" mp, 2400 rpm) at altitude. This yields 170 knots TAS. I find that a 2:45 leg is perfectly doable with an hour reserve on landing. I really don't like sitting in this little bitty airplane any longer than that anyway. I have flown some legs at high altitude (as high as 13,500) and the fuel consumption drops to 7 gph. But oxygen is really needed here for long periods of time. Doug Weiler Hudson WI > > Does anyone know of ways to increase the fuel capacity of the RV4? I am > concerned that the 32 gals avail with 180 hp is really not enough for serious > cross country type flying. I have heard in the past that some innovative and > creative RVers have solved this problem. Please let me know how this can be > done cost effectively. Thanks! > > Scott > ________________________________________________________________________________
Date: Sep 11, 2002
Hi all: With all this discussion about engine sag, which I have not experienced in 25 years and several airplanes, I have to ponder something. Is everyone aware that the shock mounts for dynafocal mount Lycs have one rubber biscuit that is harder than the other at all four positions? You have to install them so that the weight of the engine when sitting on the ground rests on the hard biscuit. This means that for the top mounts, the hard biscuit has to be on the aft side of the engine mount and on the bottom mounts the hard ones have to be on the forward side of the mount. I can't tell you the number of airplanes I have seen over the years with them reversed, or even random. If you do reverse them, the soft mounts will take a set and the engine will sag over time. Bill Marvel Randy Lervold wrote: > > George, > > When I did my cowl I carefully collected data on engine sag. In fact I put > together a spreadsheet with all the data and broke all the configurations > out.... O-320/fixed, O-320 c/s, O-360 fixed, O-360 c/s, IO-360 (angle valve) > fixed... etc. To make a long story short I concluded from the reported data > that my configuration (carbureted O-360 c/s) would sag 3/16", therefore I > positioned my cowl a bit low relative to the spinner with this in mind. I > now have 255 hours on the plane and it has not dropped at all. In fact my > spinner still looks too high which bugs me every time I look at it. > > So, did yours really drop, and how much? > > Randy Lervold > RV-8, 255 hrs, standard mounts from Van's > www.rv-8.com > > > --> RV8-List message posted by: "Sally and George" > > > Another thing to consider, if you're working on your cowl: Set it up wit> > h the top of the spinner about 1/4 inch higher than the top of the cowl. > > That's because, after 100 hours or so, the engine will sag slightly on t> > he mounts. If you set up initially with a the spinner matching the cowl > > contour, you will later have an unsightly step down from cowl to spinner.> > 1/4" worked just fine for me, but you could also add a little more, jus> > t in case. Having the spinner slightly higher than the cowl looks okay, > > but the converse is not true. > > > > George Kilishek > > RV-8 N888GK > > 80+ hours > -- Bill Marvel Home/office 310 832 7617 P.O. Box 784 Cell 310 293 2013 San Pedro, CA 90733 Fax 310 832 5334 One good deed beats 100 good intentions... ________________________________________________________________________________
Date: Sep 11, 2002
Good point Bill. I followed Van's diagram on this EXACTLY however. Randy > > Hi all: > > With all this discussion about engine sag, which I have not experienced in 25 > years and several airplanes, I have to ponder something. > > Is everyone aware that the shock mounts for dynafocal mount Lycs have one rubber > biscuit that is harder than the other at all four positions? You have to > install them so that the weight of the engine when sitting on the ground rests > on the hard biscuit. This means that for the top mounts, the hard biscuit has > to be on the aft side of the engine mount and on the bottom mounts the hard ones > have to be on the forward side of the mount. I can't tell you the number of > airplanes I have seen over the years with them reversed, or even random. > > If you do reverse them, the soft mounts will take a set and the engine will sag > over time. > > Bill Marvel > > > Randy Lervold wrote: > > > > > George, > > > > When I did my cowl I carefully collected data on engine sag. In fact I put > > together a spreadsheet with all the data and broke all the configurations > > out.... O-320/fixed, O-320 c/s, O-360 fixed, O-360 c/s, IO-360 (angle valve) > > fixed... etc. To make a long story short I concluded from the reported data > > that my configuration (carbureted O-360 c/s) would sag 3/16", therefore I > > positioned my cowl a bit low relative to the spinner with this in mind. I > > now have 255 hours on the plane and it has not dropped at all. In fact my > > spinner still looks too high which bugs me every time I look at it. > > > > So, did yours really drop, and how much? > > > > Randy Lervold > > RV-8, 255 hrs, standard mounts from Van's > > www.rv-8.com > > > > > --> RV8-List message posted by: "Sally and George" > > > > > Another thing to consider, if you're working on your cowl: Set it up wit> > > h the top of the spinner about 1/4 inch higher than the top of the cowl. > > > That's because, after 100 hours or so, the engine will sag slightly on t> > > he mounts. If you set up initially with a the spinner matching the cowl > > > contour, you will later have an unsightly step down from cowl to spinner.> > > 1/4" worked just fine for me, but you could also add a little more, jus> > > t in case. Having the spinner slightly higher than the cowl looks okay, > > > but the converse is not true. > > > > > > George Kilishek > > > RV-8 N888GK > > > 80+ hours > > > > > -- > Bill Marvel Home/office 310 832 7617 > P.O. Box 784 Cell 310 293 2013 > San Pedro, CA 90733 Fax 310 832 5334 > > One good deed beats 100 good intentions... > > ________________________________________________________________________________
Date: Sep 11, 2002
Randy - Brian recently fixed his sag after reinstalling his rebuilt engine. Two of those large washers added to the lower mount points did it. Takes maybe an hour and an engine hoist. Pulling out one bolt at a time isn't too bad a chore, nothing like the original installation. I assume that the opposite would fix your plane. I, too, have had no sag after 800+ hours (but then we all know how gently I fly :-) Kevin ________________________________________________________________________________
Date: Sep 11, 2002
RANDY-THE COWL SHOULD BE SET WITH THE ENGINE IN THRUST-POWER-MODE-SITTING SAGGED ON THE GROUND AND ALIGNED IS ONLY FOR THOSE THAT WANT TO LOOK GOOD-BUT NOT TO GO FAST-TOM Whelan Farms Airport / CT01 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 e-mail: wfact01(at)aol.com Telephone: 203-266-5300 Fax: 203-266-5140 President, EAA Chapter 1097 EAA Technical Counselor RV-8 Lycoming IO540 (Getting Close) ________________________________________________________________________________
Date: Sep 11, 2002
--- On Wed 09/11, 3 rotor rv8r300(at)attbi.com wrote: ------------------------------------------------ Changed your e-mail? Keep your contacts! Use this free e-mail change of address service from Return Path. Register now! ________________________________________________________________________________
Date: Sep 11, 2002
cowling inlets But doesn't the swinging prop and all the wind make cowl installation a lot more difficult? :-) Brad Benson, Software Architect Computer Data Strategies, Inc. Ph. 651-730-4156 / Fax 651-730-4161 Veteran of the Bermuda Triangle Expeditionary Force. 1990-1951 *********** REPLY SEPARATOR *********** On 9/11/2002 at 1:27 PM WFACT01(at)aol.com wrote: > >RANDY-THE COWL SHOULD BE SET WITH THE ENGINE IN THRUST-POWER-MODE-SITTING >SAGGED ON THE GROUND AND ALIGNED IS ONLY FOR THOSE THAT WANT TO LOOK >GOOD-BUT >NOT TO GO FAST-TOM > >Whelan Farms Airport / CT01 >249 Hard Hill Road North >PO Box 426 >Bethlehem, CT 06751 >e-mail: wfact01(at)aol.com >Telephone: 203-266-5300 >Fax: 203-266-5140 >President, EAA Chapter 1097 >EAA Technical Counselor >RV-8 Lycoming IO540 (Getting Close) > > ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Todd's Canopy
Have had excellent support from Todd Silver throughout purchase and installation of one of his tinted (1/4 inch) -8A canopies. It looks great and seemed impossible to break during drilling, scraping, etc. He has kept all promises, delivery dates, etc... If I were to build another plane I would get the canopy from his company. Colby Mosier FWF -8A ________________________________________________________________________________
Date: Sep 11, 2002
> Apparently the right opening has less flow also. You will notice > some planes with assymetrical openings now. I guess that's why my right two cylinders both average about 15 degrees higher than the left. Possibly due to the rotation direction of the prop? Randy Lervold RV-8, 255 hrs. ________________________________________________________________________________
From: "Wilson, James Mike" <james.mike.wilson(at)intel.com>
Subject: Hi-Torque Starters - Hi Compression Pistons
Date: Sep 11, 2002
One experience, I have a high compression Lyc IO 360 originally configured with new Sky-Tec. I spent 8 months and nearly $800 total in mods and new equipment trying to get clean starts. When it did start, it was only after a full over night on the charger and then could only get two good cranks before the engine would not turn over. Finally broke down and bought a B&C on friends advice, haven't had a problem since and haven't had to use the charger since. Mike -----Original Message----- From: Steve Kimmel [mailto:chs-kimmels(at)worldnet.att.net] Subject: RV-List: Hi-Torque Starters - Hi Compression Pistons Fellow listers, Installed in the O-320 in my -6A are high compression (10-1) pistons. My starter has been decidedly anemic in rotating the engine, and I am interested to know if anyone has had a positive experience with one particular brand of "Hi-Torque" starter or another. My starter has recently failed, and if an upgrade is available now is the time. Looking for your advice. Steve Kimmel N4357R ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Engine Sag
And, you also have to take g-loading into account. It's a rare flight that I don't have at least 3g's ticked off on the meter. Flying solo, I'll take it up to +6 g but with passenger I never exceed 3.5 g (utility category). I had correctly positioned muffins and had almost 1/4" of sag after 300 hrs (IO-540, so I'm throwing a little more weight around). My original mount muffins (I found out later) were not designed for aerobatic loads. Anybody else with NO sag that does aerobatics? Note: Since talking with the Hartzell people about the prop extension on the C/S prop I try to stay under +4.5 g's. Boyd. Randy Lervold wrote: > > Good point Bill. I followed Van's diagram on this EXACTLY however. > > Randy > > > > > Hi all: > > > > With all this discussion about engine sag, which I have not experienced in > 25 > > years and several airplanes, I have to ponder something. > > > > Is everyone aware that the shock mounts for dynafocal mount Lycs have one > rubber > > biscuit that is harder than the other at all four positions? You have to > > install them so that the weight of the engine when sitting on the ground > rests > > on the hard biscuit. This means that for the top mounts, the hard biscuit > has > > to be on the aft side of the engine mount and on the bottom mounts the > hard ones > > have to be on the forward side of the mount. I can't tell you the number > of > > airplanes I have seen over the years with them reversed, or even random. > > > > If you do reverse them, the soft mounts will take a set and the engine > will sag > > over time. > > > > Bill Marvel > > > > > > Randy Lervold wrote: > > > > > > > > George, > > > > > > When I did my cowl I carefully collected data on engine sag. In fact I > put > > > together a spreadsheet with all the data and broke all the > configurations > > > out.... O-320/fixed, O-320 c/s, O-360 fixed, O-360 c/s, IO-360 (angle > valve) > > > fixed... etc. To make a long story short I concluded from the reported > data > > > that my configuration (carbureted O-360 c/s) would sag 3/16", therefore > I > > > positioned my cowl a bit low relative to the spinner with this in mind. > I > > > now have 255 hours on the plane and it has not dropped at all. In fact > my > > > spinner still looks too high which bugs me every time I look at it. > > > > > > So, did yours really drop, and how much? > > > > > > Randy Lervold > > > RV-8, 255 hrs, standard mounts from Van's > > > www.rv-8.com ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Spray can primer?
What are the part numbers and where can I get the spray can primers that are self etching . I just have the flaps and ailerons to prime so don't think I want to do the alodine procedure for just the few parts I need to make to finish up the kit. The rest of the RV 4 has been protected by what looks to be green zinc chromate and could have been done over alodined aluminum. I recall someone talking about a PPG primer that did the etching as long as the metal had been cleaned with MEK or Acetone. Pat Long Bay City, Michigan (989)684-0581 Working on an RV-4 Email: PGLong(at)aol.com ________________________________________________________________________________
Date: Sep 11, 2002
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)mcleodusa.net>
Subject: Re: Spray can primer?
Hello Pat. I started out with a couple of cans of PPG primer. It seemed to do everything that I expected. (it even has kind of a nice smell-hope that is not a sign of a glue sniffer). Then one day, the last can went empty. In the mean time, the company where I bought it went out of business. The nearest place that carried it now was about 50 miles away. I Made a trip down and bout a couple more cans. Actually you should buy a case when you buy it. It is a little more expensive than regular primers. Then I got to snooping around and I found one at NAPA. #7220 Self etching, adheres to steel, aluminum, and stainless steel... Cost is about half. I got a couple of cans and took it home and started studying it. Ah ha, on the bottom of the can, I found a number that was the same number that was on the PPG can.... It looks like the PPG and even smells like it... (still kind of a pleasant smell).... NAPA also has zinc chromate in yellow and green colors, in spray cans.... Phil Sisson Litchfield, IL PGLong(at)aol.com wrote: > > What are the part numbers and where can I get the spray can primers that are > self etching . I just have the flaps and ailerons to prime so don't think I > want to do the alodine procedure for just the few parts I need to make to > finish up the kit. The rest of the RV 4 has been protected by what looks to > be green zinc chromate and could have been done over alodined aluminum. I > recall someone talking about a PPG primer that did the etching as long as the > metal had been cleaned with MEK or Acetone. > > Pat Long > Bay City, Michigan > (989)684-0581 > Working on an RV-4 > Email: PGLong(at)aol.com > ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Re: Firewall construction questions
The Facet fuel pump from Van's (unless he's added another model) is for carburated engines and doesn't slop enough pressure for FI systems. Look up Airflow Performance in the Yeller Pages. Dan Checkoway wrote: > > First of all...this is for an RV-7 taildragger with an IO-360-A1B6... > > 1) F-601TD is the "brake plate" that goes on the lower left of the firewall. > Is there any harm in drilling the two 7/16" holes through the plate and > firewall now, or should I wait until I'm setting up the master cylinders and > all that? > > 2) F-601Z is the "aux fuel firewall doubler" that goes on the bottom of the > firewall and has two -4 nutplates for the "Facet Elec Fuel Pump" > (apparently). I guess the question is twofold: > a) Dwg 36 says "IF REQ'D; NOT PROVIDED IN KIT" -- does everybody use this > type of fuel pump with the IO-360-A1B6? > b) I assume I should wait until I have the pump in hand to drill the > nutplate holes using the mounting brackets as a drill template...right? > > Thanks in advance, > )_( Dan > RV-7 N714D (fuselage) > http://www.rvproject.com > ________________________________________________________________________________
Date: Sep 11, 2002
Try Napa 7220. I've used it and it works well. John McDonnell RV7A Fuse ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Re: Engine Sag
BOYD-LORD MOUNTS ARE MAKING-ARCOBATIC MOUNTS -NO-SAG EXPERIMENTAL ONLY-TOM Whelan Farms Airport / CT01 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 e-mail: wfact01(at)aol.com Telephone: 203-266-5300 Fax: 203-266-5140 President, EAA Chapter 1097 EAA Technical Counselor RV-8 Lycoming IO540 (Getting Close) ________________________________________________________________________________
Date: Sep 11, 2002
One other alternative, Sherwin-Williams 988. It's a grey self-etching primer good on steel, aluminum, etc. There's two variants, 988 comes in a rattle can, 980 comes in a gallon can (you provide the propellant). -RB4 Phil Sisson, Litchfield Aerobatic Club wrote: > > Hello Pat. > > I started out with a couple of cans of PPG primer. It seemed to do everything > that I expected. (it even has kind of a nice smell-hope that is not a sign of a > glue sniffer). > > Then one day, the last can went empty. In the mean time, the company where I > bought it went out of business. > > The nearest place that carried it now was about 50 miles away. I Made a trip down > and bout a couple more cans. > > Actually you should buy a case when you buy it. It is a little more expensive > than regular primers. > > Then I got to snooping around and I found one at NAPA. #7220 Self etching, > adheres to steel, aluminum, and stainless steel... > > Cost is about half. I got a couple of cans and took it home and started studying > it. Ah ha, on the bottom of the can, I found a number that was the same number > that was on the PPG can.... It looks like the PPG and even smells like it... > (still kind of a pleasant smell).... > > NAPA also has zinc chromate in yellow and green colors, in spray cans.... > > > Phil Sisson Litchfield, IL > > PGLong(at)aol.com wrote: > > >> >>What are the part numbers and where can I get the spray can primers that are >>self etching . I just have the flaps and ailerons to prime so don't think I >>want to do the alodine procedure for just the few parts I need to make to >>finish up the kit. The rest of the RV 4 has been protected by what looks to >>be green zinc chromate and could have been done over alodined aluminum. I >>recall someone talking about a PPG primer that did the etching as long as the >>metal had been cleaned with MEK or Acetone. >> >>Pat Long >>Bay City, Michigan >>(989)684-0581 >>Working on an RV-4 >>Email: PGLong(at)aol.com >> ________________________________________________________________________________
From: "Scott Johnson" <scottjohnson345(at)attbi.com>
Subject: Advice on nosewheel shimmy needed on few hundred hour RV6A
Date: Sep 11, 2002
I have an RV6A with a few hundred hours. When it was new, I needed to tighten the front nosewheel nut after a few hours and then there was no shimmy when applying brakes to stop at about 30mph. Everything looks good and tight, but the shimmy has returned and the nut cannot be tightened anymore. Please note the plane has the wood dampening rods on the landing gear and I am running about 37 pounds of air in all my tires. Does anybody have any recommendations. (Is is possible to cause a shimmy if the nut is to tight ?) Thanks Scott / Chicago ________________________________________________________________________________
Date: Sep 11, 2002
What are the part numbers and where can I get the spray can primers that are self etching . Sherwin Williams makes a self etching primer in a can, part # 988. Available at S-W auto paint stores (not the house paint stores) about $5 a can. The best spray nozzle I have ever used in a rattle can. It is even on Van's list of recommended primers. Available any color you like, as long as it's grey. Not as durable as epoxy, but still pretty good stuff. It doesn't require etch/alodine, I just scuff the surface with scotchbrite pads and clean well with MEK, acetone or the like. Jeff Point RV-6 N187CF (reserved) getting ready to cut the $$$ canopy Milwaukee WI ________________________________________________________________________________
Date: Sep 11, 2002
Sherwin-Williams 988 in a rattle can is great for small parts etc. You can get it in a bulk can too but I don't know the number. If you can get a commercial account at one of their automotive stores it is around 5 bucks a can. I stumbled on it and several of the local experienced builders liked it better than other things they had been using. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of JTAnon(at)aol.com Subject: Re: RV-List: Spray can primer? Try Napa 7220. I've used it and it works well. John McDonnell RV7A Fuse ________________________________________________________________________________
From: "Sally and George" <aeronut58(at)hotmail.com>
Date: Sep 11, 2002
Randy: Yes, mine has dropped about 3/16" in 80 hours. I have a carbureted O-360 with Sensenich metal prop and standard mounts from Vans. My spinner is still about 1/16" above the cowl line (started out 1/4" high), but nobody can see that without running a straight edge along the junction. Don't know if the thing is finished settling yet, but it seems to be done. From what I've seen, Randy, your plane looks great. I'd never notice that your spinner wasn't perfectly aligned with the cowl top. George Kilishek N888GK >From: "Randy Lervold" <randy@rv-8.com> >Reply-To: rv8-list(at)matronics.com >To: >Subject: Re: RV8-List: Drag increase due to too high cowling inlets >Date: Wed, 11 Sep 2002 09:20:57 -0700 > >--> RV8-List message posted by: "Randy Lervold" <randy@rv-8.com> > >George, > >When I did my cowl I carefully collected data on engine sag. In fact I put >together a spreadsheet with all the data and broke all the configurations >out.... O-320/fixed, O-320 c/s, O-360 fixed, O-360 c/s, IO-360 (angle >valve) >fixed... etc. To make a long story short I concluded from the reported data >that my configuration (carbureted O-360 c/s) would sag 3/16", therefore I >positioned my cowl a bit low relative to the spinner with this in mind. I >now have 255 hours on the plane and it has not dropped at all. In fact my >spinner still looks too high which bugs me every time I look at it. > >So, did yours really drop, and how much? > >Randy Lervold >RV-8, 255 hrs, standard mounts from Van's >www.rv-8.com > > > > --> RV8-List message posted by: "Sally and George" > > > > Another thing to consider, if you're working on your cowl: Set it up >wit> > h the top of the spinner about 1/4 inch higher than the top of the cowl. > > That's because, after 100 hours or so, the engine will sag slightly on >t> > he mounts. If you set up initially with a the spinner matching the cowl > > contour, you will later have an unsightly step down from cowl to >spinner.> > 1/4" worked just fine for me, but you could also add a little more, >jus> > t in case. Having the spinner slightly higher than the cowl looks okay, > > but the converse is not true. > > > > George Kilishek > > RV-8 N888GK > > 80+ hours > > ________________________________________________________________________________
Date: Sep 11, 2002
From: Aircraft Technical Book Company <winterland(at)rkymtnhi.com>
Subject: Re: Advice on nosewheel shimmy needed on few hundred hour RV6A
Same thing happened to me. I tightened the nut as much as it would go until the washers were completely flat and still only had about 10 lbs breakout. Tom Green suggested a new set of washers. Seems like the old ones lost some of their springiness. When I compared the two sets the concaveity (spelling) of the new set was only 5-6 thousandths more then the other. With them I was able to tighten the breakout to about 17 lbs which was enough to stop the shimmy. Andy > > > I have an RV6A with a few hundred hours. > > When it was new, I needed to tighten the front nosewheel nut after a few > hours and then there was no shimmy when applying brakes to stop at about > 30mph. > > Everything looks good and tight, but the shimmy has returned and the nut > cannot be tightened anymore. > > Please note the plane has the wood dampening rods on the landing gear > and I am running about 37 pounds of air in all my tires. > > Does anybody have any recommendations. > > (Is is possible to cause a shimmy if the nut is to tight ?) > > Thanks > > Scott / Chicago > ________________________________________________________________________________
Subject: Aerocomposites Prop
Date: Sep 11, 2002
There seems to be some recent interest on this rv-list in Aerocomposites, Inc. propellers. I have said previously on the list what I learned about them while at OSH in July and that I was still considering their prop for our RV-8. I e-mailed John Violette, the designer of the prop, recently with some questions. I have copied my letter and the response by Harry Griswold, VP Marketing, for those interested. It's pretty long, so those not interested can delete now, or fast-forward to the next post, if you get the digest. My letter to John: After talking with you at OSH last month, my partner Ed and I were quite impressed with your product. You did say that at present, ACI does not have a 3-blade propeller in the 69" range like the MT prop that we are also considering (Ken's note: ACI does have a 72" 3-blade CS for $12,500 plus spinner kit). We like the idea of the 3-blade for noise reduction. The RV-8 that we are building has quite a loud cockpit and anything we can do to reduce noise is considered along with propeller performance. That being said, you might just be able to convince us that we don't need 3 blades for a quiet prop. What do you say? We are having Aerosport Power build us a new custom engine. Basically, it will be a 180 hp Lycoming (or Superior equivalent) O-360 with Airflow Performance F.I. and one mag/one Lightspeed Engineering E.I. We plan on using the standard pistons. I believe they are 8.7:1 compression. At OSH, you mentioned that you are using an RV-8 to flight test one of your props. Can you relay any comments so far from this program? Do you have any digital photos of your prop on the RV-8 that you might be able to attach to an e-mail to me? I think it is safe to say that ACI and MT are the two companies from which we will select our prop. I've read every word on your website, Ed and I both like what we heard from you at OSH and are anxious to get some more info. Also, can you give us the e-mail address of the pilot with the RV-8 who is testing the prop? Our RV-8 will be flying on Oct 1st of next year (how's THAT for confidence?). While we don't have to have a prop right away, it won't be long, so we need to make a decision fairly soon (for planning purposes at least). Oh yes, one more question -- Are custom colors available for your prop, and if so, how much extra will it cost. That's about it for now. We really appreciate your efforts and think you have a winning formula. I look forward to your reply. And here is Harry's response: Ken: Thanks for your email with questions and summarizing your conversation with John Violette. One of our 2-bladed propellers would be ideal for your RV-8 application. While more blades generally reduces noise (more but smaller pressure pulses on windshield), the first order effect for noise is driven by blade tip diameter. With our 2-bladed propeller noise will be significantly reduced over aluminum propellers. The lighter blades results in lower reflected shock (vibration) back into the airframe due to piston firings. Also the blades are very stiff which means that they do not vibrate (ring) when excited with aerodynamic loads or pulses from engine firings. We will be testing our 2-bladed propellers on an RV-8 and Tango II soon and will make the data available to you. We can arrange for custom color blades for which we can quote you the extra cost separately. We have had excellent response to our propellers from the RV, Team Rocket, Lancair, Express, Glasair, Seawind and other experimental builder groups. At the recent Oshkosh race from Kitty Hawk to Wisconsin there were two aircraft entered with our propeller and they won 2nd and 3rd Place in the race. We are still offering our Oshkosh Air Show 2002 pricing made possible by the growing number of propeller orders we have received and the resulting quantity hardware buys we can now place with our suppliers. Our propeller delivery lead-time for customers is now two months where we are working a partial second shift to meet specific customer needs for shorter delivery times. We are offering special Oshkosh Air Show 2002 pricing which you can take advantage of with an advance propeller deposit of $1000 (fully refundable). The pricing for our 3-bladed, constant speed (hydraulic) propellers is $12,500 plus spinner kit. The price for our 2-bladed propellers is $9,500 plus spinner kit. We offer the most advanced technology propellers in General Aviation with excellent demonstrated performance . Here are just a few of the advantages you will enjoy with an AeroComposites propeller. AeroComposite Propeller Benefits Outstanding environmental compatibility (e.g. float plane applications) Lightest propeller blades yet with high polar moment of inertia Quieter propeller/aircraft operation with low vibration Patented fail-safe blade retention system that is best in aviation Low aerodynamic drag blades that are thin and attractive Provide shorter takeoff roll, improved climb rate, and faster cruise Very durable and long life blades that are also repairable Composite blades that are 5 times stronger than aluminum or wood Durable two part urethane paint providing years of blade protection Nickel leading edge sheath protection with 8000 hour service life rating Fiberglass tubular braided socks protect against blade delamination Airfoil shape does not degrade with service like aluminum blades Molded in mesh on both surfaces provides excellent lightning protection Offset blade designs minimizes blade bending stresses during operation Blade tip sweep balances bearing loads and reduces tip mach numbers Reliable one piece housing hub construction uses large diameter bearings Resin is non-hydroscopic avoiding water absorption and freeze damage . . . and Many More Benefits ! ! ! The aerodynamic performance of our propellers is outstanding. You might be interested in the following. Recently we asked Rick Schrameck, president of Aero Supercharger Solutions, LLC., if he would flight test our 3-bladed, constant speed AeroComposites propeller (72 inch diameter) on his supercharged Lancair Legacy aircraft which he agreed to do. The powerplant in his aircraft is a Continental IO-550N engine (310 horsepower, normally aspirated) equipped with Rick's supercharger unit which developed 350 horsepower at all altitudes tested. During all flight tests there were two pilots on board, takeoff was with full fuel load plus 50 lbs of baggage on-board. The gross weight of the aircraft for all testing was 2420 lbs at takeoff where the dry aircraft weighs in at 1440 lbs. The flight test results reported to us by Rick are impressive. With the AeroComposites propeller, Rick reported a shorter takeoff roll, a climb rate of 3100 ft/min from 3,000 to 15,000 ft altitude at constant 160 knot airspeed. This represented an increase of 1100 ft/min in climb rate for his Legacy. At 15,000 ft altitude, the high power cruise was recorded at 345 mph, which Rick stated represents an increase in cruise speed of 21 mph for his aircraft. Rick has since placed an order for an AeroComposites propeller. See the article on Rick's Legacy in the current September issue of Sport Aviation magazine (page 48-56, see comment about AeroComposite propeller performance on bottom of page 56). In another Lancair IVP application (geared engine, 1800 rpm in cruise) the takeoff roll at 2200 rpm for our 3-bladed propeller was half (900 ft) of the takeoff roll distance (1800 ft) compared with his 5-bladed MT propeller. Our climb rate was 1000 ft/min higher and our propeller cruised faster than the MT propeller at every altitude. Currently, we are working with a website developer in Cincinnati to upgrade our AeroComposites website (www.aerocomposites.com) to include more informative information on our products (test data, testimonials, product information, etc.). The new website/look will be in place by the end of October. Please visit our website for more in-depth information on our propellers. Thanks again for your interest in our propellers. I hope we have an opportunity to support your RV-8 project. Harry Griswold VP Marketing ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Re: RV4-List Digest: 2 Msgs - 08/19/02
Subject: Re: Vx & Vy
Date: Sep 11, 2002
----- Original Message ----- From: "Boyd C. Braem" <bcbraem(at)comcast.net> Subject: Re: RV-List: Vx & Vy > Your Vx speed sounds in the ball-park, but Vy seems too fast. It probably > should be closer 85-90 KIAS (you do mean knots and not mph?) Yep, I am talking knots. Correct me if I'm wrong, but Vy should be the speed at the apex of the curve of speed vs. climb rate. I timed climbs of 1000 ft in 10 knot increments from 60 through 130, then calculated the vertical speed. I plotted these points, found my old "French curve" from my college junk, and faired in the curve through the data points. All of the points fell in line fairly well. I didn't have any that were far off where you're having to guess a bit when applying the french curve. Graphed it on two separate sheets, and the apex occurred at 105 both times. > which will also be very close to your "best glide" speed. That's what is odd. Once again using stopwatch vs. altitude block, I found my calculated minimum sink rate to be -710fpm at a tad above 70 KIAS. I could do the testing again, but I'm not sure it would come out much different. Again, I have pretty good confidence in my numbers. The testing was done between 0700 and 0800, giving smooth air which made speed control fairly easy. So, maybe this is just the way my RV-3 is. Randy Compton Gulf Breeze, FL RV-3A N148CW ________________________________________________________________________________
Date: Sep 11, 2002
I've got a handful ---if you still need them contact me directly, Ralph Capen Richardson, TX ----- Original Message -----
> --> RV6-List message posted by: Loren Pettis > > > Roger Crandell wrote: > --> RV6-List message posted by: Roger Crandell > > Does anyone have six ms21053L08K platenuts (anchor nuts) which you would > sell? These are single eared, 8-32, countersunk, black steel > platenuts. I have tired all sources and no one stocks them. If they > special order, they have a large minimum order quantity. Yes, there are > other options to these, but these would work the best for my specific > application. I am building an RV6A. I hope to finish by March 2003. > > Thanks > > Roger > > > I am assuming you are able to get #8 platenuts in non countersunk single ear variety. I use these and simply added a .040 shim and countersunk the shim. > > Pt > > > --------------------------------- > 9-11: A tribute to the more than 3,000 lives lost > > ________________________________________________________________________________
Date: Sep 11, 2002
Loren, Good idea. Thanks for the input. Roger Loren Pettis wrote: > --> RV6-List message posted by: Loren Pettis > > Roger Crandell wrote: > --> RV6-List message posted by: Roger Crandell > > Does anyone have six ms21053L08K platenuts (anchor nuts) which you would > sell? These are single eared, 8-32, countersunk, black steel > platenuts. I have tired all sources and no one stocks them. If they > special order, they have a large minimum order quantity. Yes, there are > other options to these, but these would work the best for my specific > application. I am building an RV6A. I hope to finish by March 2003. > > Thanks > > Roger > > I am assuming you are able to get #8 platenuts in non countersunk single ear variety. I use these and simply added a .040 shim and countersunk the shim. > > Pt > > --------------------------------- > 9-11: A tribute to the more than 3,000 lives lost > ________________________________________________________________________________
Date: Sep 11, 2002
Subject: IK-2000 Flight & Engine Monitor
Does anyone have pictures of the IK-2000 Flight & Engine Monitor installed in your instrument panel? I am strongly considering installing this unit in my RV6 and was interested in seeing what others have done. Thanks Roger ________________________________________________________________________________
Subject: Re: Infinity Stick Grips
Date: Sep 11, 2002
> Here's a couple for you guys using the Infinity stick and switches: > > Are you running the starter lead direct or using a relay? > > Are you running a Vans flap motor direct or using a relay? > Using two relays for the flaps. The wiring diagram for this was published many times on this list. Check out this totaly excellant RV builders website. http://www.lacodeworks.com/besing/ Check out this page in particular to see how to put relays on the flap motor that allows you to use small switches in various stick grips.. http://www.lacodeworks.com/besing/flap.htm Big thanks to Paul and all the others like him for putting together these informative websites that make it possible for so many others to build fine aircraft. Norman Hunger RV6A Delta BC ________________________________________________________________________________
From: "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net>
Subject: Alternate Static Source Valve
Date: Sep 11, 2002
I'm considering installing an alternate static source (cabin air) selection valve. Has anyone installed one of these? If so, could you please provide the source? I found a panel mounted fuel flow valve in the 2001 2002 Aircraft Spruce catalog, p154, p/n FFV04 for $7.00. Would this work in the static air system? Thanks Gabe A Ferrer (RV6. N2GX reserved. SE Florida) ferrergm(at)bellsouth.net Cell: 561 758 8894 Night or FAX: 561 622 0960 ________________________________________________________________________________
Date: Sep 11, 2002
> > Everything looks good and tight, but the shimmy has returned > and the nut cannot be tightened anymore. Scott, what do you mean by the above? Are the two Belleville washers completely collapsed? Alex Peterson Maple Grove, MN RV6-A N66AP 200 hours ________________________________________________________________________________
Subject: Vx & Vy
Date: Sep 11, 2002
> While I agree that Randy's Vy sounds a bit high, I wonder if there is > something interesting about his prop. I found something very interesting when doing Vy tests. I ran the tests last year, but if I recall correctly (I don't have the stuff here), they were run from 3000msl to 4000msl, temp something around 50F. I stabilized on a test airspeed at a few hundred feet below 3000', and applied full throttle, full prop. I kept the ball centered, and adjusted pitch to nail the airspeed. I then timed the time it took to go from 3000' to 4000'. What I found was at all airspeeds from 70KIAS to 120KIAS, the time to climb 1000' was between 30 and 33 seconds for all airspeeds in the range. I determined that best rate was difficult to nail down, as the differences were so small. I'm sure with numerous repetitions, it could be determined. I know the illusion I get when climbing at 120KIAS is that the rate is not that high, but a glance at the VSI confirms the rate. Torch away - Alex Peterson Maple Grove, MN RV6-A N66AP 200 hours, doing annual, including cooling modifications, report to follow ________________________________________________________________________________
Date: Sep 11, 2002
Scott: Get new Belleville washers from Van and install them on the nose strut. These are the angled washers that came with your kit and get compressed when you tighten that nut. If you have the nut all the way down, the washers are shot. This is a typical problem on Grummans also. Bill Marvel Scott Johnson wrote: > > I have an RV6A with a few hundred hours. > > When it was new, I needed to tighten the front nosewheel nut after a few > hours and then there was no shimmy when applying brakes to stop at about > 30mph. > > Everything looks good and tight, but the shimmy has returned and the nut > cannot be tightened anymore. > > Please note the plane has the wood dampening rods on the landing gear > and I am running about 37 pounds of air in all my tires. > > Does anybody have any recommendations. > > (Is is possible to cause a shimmy if the nut is to tight ?) > > Thanks > > Scott / Chicago > -- Bill Marvel Home/office 310 832 7617 P.O. Box 784 Cell 310 293 2013 San Pedro, CA 90733 Fax 310 832 5334 One good deed beats 100 good intentions... ________________________________________________________________________________
Subject: Cowls Too High/Cooling Drag Etc
Date: Sep 12, 2002
Kent Passer is certainly a guru to be copied in experimental aircraft world, but one question. Does anyone know anything about Dave Anders' RV-4? If you don't know about it, it is a remarkable RV with an honest to God 250 mph top speed. (breathed on IO 360) Lots of aerodynamic trickery. Do an internet search on his CAFE test. Really impressive. Am I correct in thinking that he keeps the details pretty close to the vest?? Best regards, Don Mei Americans used to roar like lions for liberty: Now they bleat like sheep for security Norman Vincent Peale ________________________________________________________________________________
From: "Stan & Eilene VanGrunsven" <stanvan(at)pacifier.com>
Date: Sep 11, 2002
In response to Boyd's letter (see below)....... About 6 years ago while I was doing cowling on the 6A, I talked to Bill Benedict about the inlet size/outlet size dilema. He had done a test with temp. probes and found a 70 degree F increase from inlet to below the cylinders. If my expansion chart numbers were correct, that would amount to about 11% volume increase. Many RV-6,-6A builders have cut the outlet at an angle to get a proportionate increase in opening size and reduce the pressure inside the cowl. Stan Van Grunsven RV-6A 670 hrs Subject: Re: RV-List: Re: RV8-List: Drag increase due to too high cowling inlets Hey! What's happening to all the exit/exhaust air during this discussion? If the air is cooling the engine that means it has to expand, so that at least 2-3 times the volume of inlet air has to get out of the cowl ________________________________________________________________________________
Date: Sep 11, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
Alex Peterson wrote: > > > > While I agree that Randy's Vy sounds a bit high, I wonder if there is > > something interesting about his prop. > > I found something very interesting when doing Vy tests. I ran the tests > last year, but if I recall correctly (I don't have the stuff here), they > were run from 3000msl to 4000msl, temp something around 50F. I > stabilized on a test airspeed at a few hundred feet below 3000', and > applied full throttle, full prop. I kept the ball centered, and > adjusted pitch to nail the airspeed. I then timed the time it took to > go from 3000' to 4000'. What I found was at all airspeeds from 70KIAS > to 120KIAS, the time to climb 1000' was between 30 and 33 seconds for > all airspeeds in the range. I determined that best rate was difficult > to nail down, as the differences were so small. I'm sure with numerous > repetitions, it could be determined. > > I know the illusion I get when climbing at 120KIAS is that the rate is > not that high, but a glance at the VSI confirms the rate. > > Torch away - > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 200 hours, doing annual, including cooling modifications, > report to follow > If memory serves, Van talked about this in an old RVator. Recommended 'best' rate was 120 something (can't remember if it was kts or mph). The conclusion was that @ 120 the rate was the same as the 1.3 number & you cover a lot more ground with better cooling. Too sleepy to hunt for the article. Charlie RV-4 (sold) ________________________________________________________________________________
Subject: "mag" drop with electronic ignition
Date: Sep 12, 2002
I haven't finished reading to the end of the summary but had to chime in. Why does the 160 hp get better fuel consumption than a 150hp at the same speed. All else being equal, very simple. A 160 hp O-320 has a higher compression ratio than a similar 150 hp and that is really the only difference. If you think about it. At the same speed, the 2 aircraft engines need to produce the same power. One may be able to produce 160 vs 150, but at the same speed, they are producing the same power. So, if they are producing the same power, the one with the lower specific fuel consumption ( (# fuel/hp)/hr)will use less fuel. Lycoming specs, please don't ask me to look them up, but I have in the past, show the 160 hp having a lower specific fuel consumption than the 150 hp. I love it when theory, factory info, and anecdotal evidence all line up. Don Mei That is why the general understanding is that upping the compression ratio is "free" power. Limitation is of course detonation. Americans used to roar like lions for liberty: Now they bleat like sheep for security Norman Vincent Peale ________________________________________________________________________________
Subject: Possum Fritters
Date: Sep 12, 2002
Paul (Bessing) Nutria fritters for you?? mmmm good Don Mei Americans used to roar like lions for liberty: Now they bleat like sheep for security Norman Vincent Peale MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide.aspx ________________________________________________________________________________
Date: Sep 11, 2002
From: "Harry Hawkins" <hawkbud(at)mail.speednetllc.com>
I installed a Grand Rapids Tech in my six and am very happy with it ---------- Original Message ----------------------------------
Date: Wed, 11 Sep 2002 19:52:08 -0600 >--> RV6-List message posted by: Roger Crandell > >Does anyone have pictures of the IK-2000 Flight & Engine Monitor >installed in your >instrument panel? I am strongly considering installing this unit in my >RV6 and was interested >in seeing what others have done. > >Thanks > >Roger > > ________________________________________________________________________________
Date: Sep 11, 2002
> I'm considering installing an alternate static source (cabin > air) selection valve. > > Has anyone installed one of these? If so, could you please > provide the source? I used silicone tubing for plumbing in the static equipment behind the panel. I put a barbed connector in just under and forward of the bottom of the panel, and alternate static is simply disconnecting the tube. Can't get any simpler. Alex Peterson Maple Grove, MN RV6-A N66AP 200 hours ________________________________________________________________________________
Date: Sep 11, 2002
>I'm considering installing an alternate static source (cabin air) selection >valve. > >Has anyone installed one of these? If so, could you please provide the >source? > I used a Curtis CCA 1550 quick drain valve which is readily available. I made a bracket and installed it under the left armrest on my 6-A. It is easy to connect into the static line at that location and does not use up panel space. George McNutt Langley, B.C. ________________________________________________________________________________
From: "Stephen Johnson" <spjohnsn(at)ix.netcom.com>
Subject: Vibration transmission on RV's
Date: Sep 11, 2002
Hi all, There exists an aerobatic version of the engine mount muffins which are stiffer than stock. They are in Van's accessory catalog. I suspect the stiffer mounts would eliminate engine sag. I'm going with the 200 hp IO-360-A1B6 and constant speed prop, which is the heaviest possible combination. The only justification for not buying the stiffer mounts is vibration transmision from the engine. I'd like a subjective read on how severe the vibration is with the RV series. I took the famous $60,000 ride in the 8A demo ship, and never gave vibration a second thought. I may have been too excited, frankly to be very critical. I'm building an 8, but I think this is something which may be common to the whole family. Please include engine and prop information when replying. Steve Johnson RV-8 #80121 fuse ________________________________________________________________________________
Date: Sep 11, 2002
Subject: Re: Cowls Too High/Cooling Drag Etc
In a message dated 9/11/02 10:31:56 PM Eastern Daylight Time, don_mei(at)hotmail.com writes: << Am I correct in thinking that he keeps the details pretty close to the vest?? Best regards, Don Mei >> I don't think so. The CAFE article was pretty thorough. I've seen pictures of the aircraft's cowl, cooling plenum, fairings, reworked tailwheel (no steering links and a wheel that looks like it is from a set of inline skates), and well faired main wheels and tires, which are of the smaller Lamb variety. A few years ago, he added a turtledeck to the rear fuselage. Something to remember is that he winds the engine up to somewhat higher than recommended speeds (2900 RPM comes to mind), so the engine is generating significantly more than stock horsepower. Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Subject: Re: RV4-List: Spray can primer?
Date: Sep 11, 2002
Pat, I use a spray can product from Sherwin Williams labelled GBP 988. It is distributed at SW automotive finishes stores. It says on the can it is a self etching primer. The finish is light gray. Sprays easily, and seems to be "fairly" durable. Tom Chapman RV-4- 985 hours Building RV-8-fuse ----- Original Message ----- > --> RV4-List message posted by: PGLong(at)aol.com > > What are the part numbers and where can I get the spray can primers that are > self etching . > Pat Long > Bay City, Michigan ________________________________________________________________________________
Date: Sep 11, 2002
Why would this be needed? Isn't there enough redundancy with two static ports, one on each side of the fuse? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of George McNutt > Sent: Wednesday, September 11, 2002 11:12 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Alternate Static Source Valve > > > > > >I'm considering installing an alternate static source (cabin air) > >selection valve. > > > >Has anyone installed one of these? If so, could you please > provide the > >source? > > > > I used a Curtis CCA 1550 quick drain valve which is readily > available. I made a bracket and installed it under the left > armrest on my 6-A. It is easy to connect into the static line > at that location and does not use up panel space. > > George McNutt > Langley, B.C. > ________________________________________________________________________________
Subject: Re: Vibration transmission on RV's
Date: Sep 12, 2002
> >Hi all, > >There exists an aerobatic version of the engine mount muffins which are >stiffer than stock. They are in Van's accessory catalog. I suspect the >stiffer mounts would eliminate engine sag. I'm going with the 200 hp >IO-360-A1B6 and constant speed prop, which is the heaviest possible >combination. The only justification for not buying the stiffer mounts is >vibration transmision from the engine. I'd like a subjective read on how >severe the vibration is with the RV series. I took the famous $60,000 ride >in the 8A demo ship, and never gave vibration a second thought. I may have >been too excited, frankly to be very critical. I'm building an 8, but I >think this is something which may be common to the whole family. Please >include engine and prop information when replying. > >Steve Johnson > >RV-8 #80121 >fuse I have an RV8, O-360 with Sensenich metal 72FM8-83 prop. It's mounted via the regular, non-aerobatic rubber bagels. Startup is the worst time of all..and can really tweak the airplane when it lights off. I have some hairline cracks in the paint around the base of my windshield and I'm pretty sure it's from this wracking the fuselage goes through. Lycosaurs shake like mad. No way around it. I have to wonder why they didn't design it to fire one cylinder, then the one opposite almost simultaneously, then back to the other side, and so on. It doesn't. Silly thing fires both cylinders on one side, THEN the other two. No wonder it slams right and left on startup. I'd go with the regular mounts and hope for the best. Harder biscuits will only intensify the vibration impulses to the airframe....your pricey panel gadgets, and your butt. Brian Denk RV8 N94BD 299 hrs. ________________________________________________________________________________
Date: Sep 11, 2002
> > ----- Original Message ----- > From: "Boyd C. Braem" <bcbraem(at)comcast.net> > To: > Subject: Re: RV-List: Vx & Vy > > > > > which will also be very close to your "best glide" speed. > > That's what is odd. Once again using stopwatch vs. altitude block, I found > my calculated minimum sink rate to be -710fpm at a tad above 70 KIAS. > Keep in mind that the minimum sink speed is probably not the same as best glide speed. Ole glider pilot. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Sep 11, 2002
Does insufficient exit area explain the fact that the oil door bulges out in flight even though it is behind the high pressure plenum area? Clearly, there is pressure here in the "low pressure" portion of the cowling. Bill Marvel Stan & Eilene VanGrunsven wrote: > > In response to Boyd's letter (see below)....... > > About 6 years ago while I was doing cowling on the 6A, I talked to Bill > Benedict about the inlet size/outlet size dilema. He had done a test > with temp. probes and found a 70 degree F increase from inlet to below > the cylinders. > If my expansion chart numbers were correct, that would amount to about > 11% volume increase. > Many RV-6,-6A builders have cut the outlet at an angle to get a > proportionate increase in opening size and reduce the pressure inside the > cowl. > > Stan Van Grunsven > RV-6A 670 hrs > > Subject: Re: RV-List: Re: RV8-List: Drag increase due to too high cowling > inlets > > > Hey! What's happening to all the exit/exhaust air during this > discussion? > If the air is cooling the engine that means it has to expand, so that at > least 2-3 times the volume of inlet air has to get out of the cowl > -- Bill Marvel Home/office 310 832 7617 P.O. Box 784 Cell 310 293 2013 San Pedro, CA 90733 Fax 310 832 5334 One good deed beats 100 good intentions... ________________________________________________________________________________
Date: Sep 11, 2002
One stick control of the flaps is easily done with one relay. See http://www.infinityaerospace.com/Flap.pdf for details. Russ ----- Original Message ----- From: "Norman" <nhunger(at)sprint.ca> Subject: Re: RV-List: Infinity Stick Grips > > > > Here's a couple for you guys using the Infinity stick and switches: > > > > Are you running the starter lead direct or using a relay? > > > > Are you running a Vans flap motor direct or using a relay? > > > > Using two relays for the flaps. The wiring diagram for this was published > many times on this list. Check out this totaly excellant RV builders > website. > http://www.lacodeworks.com/besing/ > Check out this page in particular to see how to put relays on the flap motor > that allows you to use small switches in various stick grips.. > http://www.lacodeworks.com/besing/flap.htm > Big thanks to Paul and all the others like him for putting together these > informative websites that make it possible for so many others to build fine > aircraft. > > Norman Hunger > RV6A Delta BC > > ________________________________________________________________________________
Date: Sep 12, 2002
Subject: Re: Alternate Static Source Valve
In a message dated 9/11/2002 6:54:55 PM Pacific Daylight Time, ferrergm(at)bellsouth.net writes: > I found a panel mounted fuel flow valve in the 2001 2002 Aircraft Spruce > catalog, p154, p/n FFV04 for $7.00. Would this work in the static air > system? To open a second (shared) static source in the cockpit, yes, but it won't shut off the other, presumably defective, source. This would theoretically average both sources as long as the other source wasn't otherwise fully blocked. On the other hand, its big brother, p/n FFV03 (for $12.50), would switch quite nicely from one source to the other, discretely. -GV (RV-6A N1GV 566hrs) ________________________________________________________________________________
Date: Sep 12, 2002
In a message dated 9/11/2002 3:48:12 PM Pacific Daylight Time, scottjohnson345(at)attbi.com writes: > When it was new, I needed to tighten the front nosewheel nut after a few > hours and then there was no shimmy when applying brakes to stop at about > 30mph. > > Everything looks good and tight, but the shimmy has returned and the nut > cannot be tightened anymore. If they have lost their mojo then replace them. If they still have their spring you could also make sure that they are good and rusty, free of any lubricants and/or bead blast them to increase their stiction (static friction). Many people "over grease" their nose gear bushings and that would be a bad thing to do. -GV (RV-6A N1GV 566hrs) ________________________________________________________________________________
From: "Jack Gageby" <jackgageby(at)worldnet.att.net>
Date: Sep 11, 2002
MAR-HYDE Single Stage Pretreatment Primer, Light Gray, No. 5111. Try an automotive paint supply store in your area. ----- Original Message ----- From: <PGLong(at)aol.com> Subject: RV4-List: Spray can primer? > --> RV4-List message posted by: PGLong(at)aol.com > > What are the part numbers and where can I get the spray can primers that are > self etching . I just have the flaps and ailerons to prime so don't think I > want to do the alodine procedure for just the few parts I need to make to > finish up the kit. The rest of the RV 4 has been protected by what looks to > be green zinc chromate and could have been done over alodined aluminum. I > recall someone talking about a PPG primer that did the etching as long as the > metal had been cleaned with MEK or Acetone. > > Pat Long > Bay City, Michigan > (989)684-0581 > Working on an RV-4 > Email: PGLong(at)aol.com > > ________________________________________________________________________________
Date: Sep 11, 2002
I too used a Curtis CCA 1550. See http://www.edt.com:80/homewing/rhproject/cabinlts.html for installation details. As for whether its needed or not -- who knows for sure? Blocked ports are one thing but I guess the theory is that something could get in the tube an clog it up. For VFR only it really wouldn't make much sense, but for IFR its probably better safe than sorry since its a relatively easy/inexpensive thing to do. Randall Henderson, RV-6 N6R (~400 hrs) Portland, OR www.vanshomewing.org > >I'm considering installing an alternate static source (cabin air) selection > >valve. > > > >Has anyone installed one of these? If so, could you please provide the > >source? > > > > I used a Curtis CCA 1550 quick drain valve which is readily available. > I made a bracket and installed it under the left armrest on my 6-A. > It is easy to connect into the static line at that location and does not use > up panel space. ________________________________________________________________________________
Date: Sep 12, 2002
I purchased an alternate static valve used in a C-172 from Wentworth salvage for $19. Rick McBride ________________________________________________________________________________
Date: Sep 12, 2002
Norman, We are runing the start button and flap motor thru relays. Chuck & Dave Rowbotham RV-8A (120 hrs) >From: "Norman" <nhunger(at)sprint.ca> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: Infinity Stick Grips >Date: Wed, 11 Sep 2002 18:52:35 -0700 > > > > Here's a couple for you guys using the Infinity stick and switches: > > > > Are you running the starter lead direct or using a relay? > > > > Are you running a Vans flap motor direct or using a relay? > > > >Using two relays for the flaps. The wiring diagram for this was published >many times on this list. Check out this totaly excellant RV builders >website. >http://www.lacodeworks.com/besing/ >Check out this page in particular to see how to put relays on the flap >motor >that allows you to use small switches in various stick grips.. >http://www.lacodeworks.com/besing/flap.htm >Big thanks to Paul and all the others like him for putting together these >informative websites that make it possible for so many others to build fine >aircraft. > >Norman Hunger >RV6A Delta BC > > MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide.aspx ________________________________________________________________________________
From: "Jim Norman" <jnorman(at)intermapsystems.com>
Date: Sep 12, 2002
I have new pictures taken this week. I'll post them (as soon as Stein Bruch posts them for me!) They fit in a "standard radio stack" cutout... nothing special. jim tampa -----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Roger Crandell rv7-list(at)matronics.com Does anyone have pictures of the IK-2000 Flight & Engine Monitor installed in your instrument panel? I am strongly considering installing this unit in my RV6 and was interested in seeing what others have done. Thanks Roger ________________________________________________________________________________
Date: Sep 12, 2002
Subject: Flap Actuator Attachment...
Good Morning Listers.... More work in the garage of course leads to more questions!!! Been searching the archives and vans www links for a picture or description of how/where to attach the F-659 (Flap Actuator Rod) to the flap. (Building a 6A QB) I was about the do some drilling last night and thought better of it until I have a better Idea of what I should do. The instructions don't say hardly anything and the plans are limited in direction (#40/42/46). I guess I have 2 main questions.... 1. Where on the flap attach bracket (attached to the inboard portion of the flap) do I drill the hole to attach the actuator rod?? Is it best to maybe start with flaps set to 40 degrees and find a good attach point... 2. On cutting the hole in the fuse for the actuator rod...I have read in the archives that this ends up being a "J" shaped hole, which I can understand as the F-659 travels up and down....my concern is that it looks like that the way mine is set up that the hole will (in addition to coming out the bottom of the fuse) will come out the side of the fuse when in the full retracted position...?? Does this seem correct. Thanks again for all the help.... Kurt in OKC ________________________________________________________________________________
Date: Sep 12, 2002
I would use naptha, (coleman lantern fluid) to clean the parts. Works better than MEK or acetone. I used Marhyde self-etching primer, worked real well. A little pricey but the cans are 20 oz. as I recall. John Danielson ________________________________________________________________________________
Date: Sep 12, 2002
From: glen j matejcek <aerobubba(at)compuserve.com>
Subject: Flight Suits
>Who can point me at a weblink that has some of those nomex suits the >race car guys use? >Thanks, >Norman Hunger >RV6A Hi Norman- Flight Suits, of 1675 Pioneer way, El Cajon, CA 92020 has a big booth at OSH each year. One end has special order / one off stuff that either never got picked up, or was returned for some reason. At 6' 5" and 250#, I found a plain black suit that fit great for $82.95 brand new. I think it listed for closer to $400.... Glen Indy rv8 on hold for the next 2 months... ________________________________________________________________________________
Date: Sep 12, 2002
Re "whether it is needed or not. . . Blocked ports. . .something could get in the tube and clog it up" Water, ice. If you don't tie the static tubing so it slants up from the side-of-fuselage port, then water can get in, and, on some nice cold VFR day, you take off and get above the freezing level. . .blocked port. Or, over time, get condensation in the line and you don't have a procedure for draining or purging the line (blowing it out), same thing, regardless of how you route your lines. David Carter ----- Original Message ----- From: "Randall Henderson" <randallh(at)attbi.com> Subject: Re: RV-List: Alternate Static Source Valve > > I too used a Curtis CCA 1550. See > http://www.edt.com:80/homewing/rhproject/cabinlts.html for installation > details. > > As for whether its needed or not -- who knows for sure? Blocked ports are > one thing but I guess the theory is that something could get in the tube an > clog it up. For VFR only it really wouldn't make much sense, but for IFR its > probably better safe than sorry since its a relatively easy/inexpensive > thing to do. > > Randall Henderson, RV-6 N6R (~400 hrs) > Portland, OR > www.vanshomewing.org > > > >I'm considering installing an alternate static source (cabin air) > selection > > >valve. > > > > > >Has anyone installed one of these? If so, could you please provide the > > >source? > > > > > > > I used a Curtis CCA 1550 quick drain valve which is readily available. > > I made a bracket and installed it under the left armrest on my 6-A. > > It is easy to connect into the static line at that location and does not > use > > up panel space. > > ________________________________________________________________________________
Subject: Vx & Vy test procedure
Date: Sep 12, 2002
Not to beat this to death, but.... I thinking about reflying the test. Darn, gotta go fly some more :-) Here's the question: In "Sport Aviation" the test was timed through 500ft blocks. I wondering if this is too small a climb for accurate data. With climb rates of 1800 to 2000 fpm at the lower pressure alt, the times are short, ie. 16 to 18 secs in the block, and that just a small error in hacking the clock could have a measurable effect. I'm thinking that a block of 1000ft might be better, or even 1500 ft. Any suggestions on this? For my RV-3, I could see where a 500ft block would suffice when heavy and timing a climb at a high pressure alt, such as 7500ft or 9500ft. But it just seems tight at low alt when the -3 is really wanting to scoot. Randy Compton Gulf Breeze, FL RV-3 N148CW Lyc O-320, 9:1 pistons, Lightspeed on right side Aymar prop ________________________________________________________________________________
Subject: Re: Flap Actuator Attachment...
Date: Sep 12, 2002
Kurt, Take your best guess from the plans as to where to drill the holes in the flap ends, then round out the holes in the fuselage to provide clearence for the flap rods. Some of that clearence will probably go up around to the side of the fuselage as you suspect. The main thing is to try and keep as much, if not all, of the hole in the fuselage covered up by the extended part of the flaps when they are retracted. There may be others with better suggestions but that is what I did and it worked out ok for me. Mike Robertson RV-8A, 6A, and 9A >From: KAKlewin(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Flap Actuator Attachment... >Date: Thu, 12 Sep 2002 08:34:47 EDT > > >Good Morning Listers.... > >More work in the garage of course leads to more questions!!! Been >searching >the archives and vans www links for a picture or description of how/where >to >attach the F-659 (Flap Actuator Rod) to the flap. (Building a 6A QB) I was >about the do some drilling last night and thought better of it until I have >a >better Idea of what I should do. The instructions don't say hardly >anything >and the plans are limited in direction (#40/42/46). I guess I have 2 main >questions.... > >1. Where on the flap attach bracket (attached to the inboard portion of >the >flap) do I drill the hole to attach the actuator rod?? Is it best to maybe >start with flaps set to 40 degrees and find a good attach point... > >2. On cutting the hole in the fuse for the actuator rod...I have read in >the >archives that this ends up being a "J" shaped hole, which I can understand >as >the F-659 travels up and down....my concern is that it looks like that the >way mine is set up that the hole will (in addition to coming out the bottom >of the fuse) will come out the side of the fuse when in the full retracted >position...?? Does this seem correct. > >Thanks again for all the help.... > >Kurt in OKC > > MSN Photos is the easiest way to share and print your photos: http://photos.msn.com/support/worldwide.aspx ________________________________________________________________________________
Subject: RV-6 for sale:
Date: Sep 12, 2002
Fellow Listers: One of our local MN Wing members has his RV-6 for sale. He recently completed -6 #2 and now #1 is available. Details are available at our website here: http://www.pressenter.com/~dougweil/mnwing/id76.htm Thanks Doug Weiler MN Wing ________________________________________________________________________________
Date: Sep 12, 2002
Well, I haven't seen anyone mention this one yet, it's a rattle can self etching primer made by SEM products, Inc. in Charlotte, NC, comes in light gray, P/N 39683, green and I think white. I get it at a local automotive paint supply store here in the East Bay. It's as tough as the Vari-Prime I used to use and a lot less trouble to use for small parts. Harry Crosby Pleasanton, California RV-6, electrical stuff ________________________________________________________________________________
Date: Sep 12, 2002
Check out www.rdaviation.com they have a pneumatic change over toggle switch used by gliders for their VSI systems. I am intending to use one for selecting between my pitot static head static and fuselage static system. It panel mounts and looks like a standard electrical switch. On the web site look under Instruments then installation accessories, they are not cheep though 33.55 that's about US$ 50 plus postage. Regards Marcus RV-8 wings ________________________________________________________________________________
Subject: Hose testing
Date: Sep 12, 2002
Where can I verify the testing specs on aeroquip hose, specifically 666 hose. It's rated to 1500 working pressure, so I test to 3000 for 30 seconds? I'm assuming a local speed shop can do this for me. No? Thx, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Sep 12, 2002
Subject: Re: Vx & Vy test procedure
> >Not to beat this to death, but.... > >I thinking about reflying the test. Darn, gotta go fly some more :-) > >Here's the question: In "Sport Aviation" the test was timed through 500ft >blocks. I wondering if this is too small a climb for accurate data. With >climb rates of 1800 to 2000 fpm at the lower pressure alt, the times are >short, ie. 16 to 18 secs in the block, and that just a small error in >hacking the clock could have a measurable effect. I'm thinking that a block >of 1000ft might be better, or even 1500 ft. > >Any suggestions on this? For my RV-3, I could see where a 500ft block would >suffice when heavy and timing a climb at a high pressure alt, such as 7500ft >or 9500ft. But it just seems tight at low alt when the -3 is really wanting >to scoot. > >Randy Compton >Gulf Breeze, FL >RV-3 N148CW >Lyc O-320, 9:1 pistons, Lightspeed on right side >Aymar prop > Randy, I do this sort of stuff for a living. When we're doing climb or descent tests for score, we like to chose an altitude block that will give at least one minute at the highest rate of climb or descent you expect. This will give a larger time difference between test points, and reduce the impact of small differences in how accurately you hit the stopwatch. Too large a block leads to pilot fatigue, and the accuracy starts to fall, as it is hard to concentrate on holding the airspeed for too long. Too long a test also reduces safety, as you will be pretty much head in the cockpit for the duration of each run. It is really nice if you can have a friend you trust fly chase (a very, very loose formation) to watch for traffic. The winds will likely change over this large an altitude block, and changes in head wind or tail wind component will cause your airspeed to increase or decrease as you go through the wind shear. You then need to raise or lower the nose to get back on the target speed, which affects your rate of climb or descent for a short period. So, to minimize this effect, you want to do the tests at 90 degrees to the expected wind. Be sure to do every test on the same heading, so that any wind shears will affect all runs the same (this assumes the wind at each altitude remains the same for the duration of your tests). For even more accuracy, you can do each speed twice, with the heading on the two runs 180 deg apart, and average the calculated rate of climb or descent for the two points. This helps further remove any effect of wind shears. Good luck, -- Kevin Horton RV-8 (spinner, cowling) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
Subject: Panel
Date: Sep 12, 2002
Today, I received my Modular Instrument Panel from Affordable Panels, and all I can say is WOW!!! I was very impressed with the panel kit. I feel like I just stroke gold. I mean, even the packaging was superb. I swear I fondle the pieces for an hour before I put them back in the box. Being the cheapest bastard that ever lived, I couldn't bring myself to spend any extra money on a panel. After all, you get one from Van's in the kit. But after seeing my friends at the airport under their panels on an almost daily basis, I thought forget that. I am getting this panel. As a matter of fact, I am sending Van his panel back for a $40 credit (I hope). I have spent a small fortune in this kit already and the bird is getting a very basic VFR panel with an IFR upgrade in the not so near future when funds allow it. The gentleman I spoke to over the phone when I ordered the panel kit, said my panel was the third one shipped to New Jersey alone. Has anyone else on the list gotten one of these things? John RV-9A Fuselage ________________________________________________________________________________
Date: Sep 12, 2002
> >> which will also be very close to your "best glide" speed. > >That's what is odd. Once again using stopwatch vs. altitude block, I found >my calculated minimum sink rate to be -710fpm at a tad above 70 KIAS. > >I could do the testing again, but I'm not sure it would come out much >different. Again, I have pretty good confidence in my numbers. The testing >was done between 0700 and 0800, giving smooth air which made speed control >fairly easy. So, maybe this is just the way my RV-3 is. > >Randy Compton >Gulf Breeze, FL >RV-3A N148CW > Speed for minimum sink is not best glide speed. Make a graph that has airspeed on one axis, and rate of descent on the other. Each axis has to extend all the way down to zero. Draw a curve through all the test points using your trusty "french curve". Take a ruler and put one end where the two axis cross (the 0,0 point). Draw a straight line that goes from the 0,0 point that is tangent to the curve that your drew through the test points. The airspeed where this tangent line hits the curve is your best glide speed. -- Kevin Horton RV-8 (spinner, cowling) Ottawa, Canada http://members.rogers.com/khorton/rv8.html ________________________________________________________________________________
Subject: Re: Hose testing
Date: Sep 12, 2002
I believe you should check it at 1.5 the expected working pressure.Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org Always looking for articles for the Experimenter ----- Original Message ----- From: "Larry Bowen" <Larry(at)bowenaero.com> Subject: RV-List: Hose testing > > Where can I verify the testing specs on aeroquip hose, specifically 666 > hose. It's rated to 1500 working pressure, so I test to 3000 for 30 > seconds? I'm assuming a local speed shop can do this for me. No? > > Thx, > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > ________________________________________________________________________________
Date: Sep 12, 2002
In a message dated 9/12/02 6:30:23 PM Eastern Daylight Time, Larry(at)bowenaero.com writes: << Where can I verify the testing specs on aeroquip hose, specifically 666 hose. It's rated to 1500 working pressure, so I test to 3000 for 30 seconds? I'm assuming a local speed shop can do this for me. No? Thx, - Larry Bowen Larry(at)BowenAero.com >> Most hydraulic shops can test AN hoses. Personally, I would test it to its rated strength or less, not 2x rated strength. Testing at 3000 PSI might do undetectable damage that would wait until a BAD time to manifest itself in a leak or broken hose. Also, why test a hose that will never see over 150 PSI at 20+ times its working load? Kyle Boatright 0-320/Aymar Demuth RV-6 Slider Kennesaw, GA http://www.angelfire.com/my/rv6 ________________________________________________________________________________
Date: Sep 12, 2002
Why? Don't know. I thought the standard might be 2X for 30 seconds. Don't know where I got that from.... Thanks for your input. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of > KBoatri144(at)aol.com > Sent: Thursday, September 12, 2002 8:32 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Hose testing > > > > In a message dated 9/12/02 6:30:23 PM Eastern Daylight Time, > Larry(at)bowenaero.com writes: > > << Where can I verify the testing specs on aeroquip hose, > specifically 666 hose. It's rated to 1500 working pressure, > so I test to 3000 for 30 seconds? I'm assuming a local > speed shop can do this for me. No? > > Thx, > > - > Larry Bowen > Larry(at)BowenAero.com >> > > Most hydraulic shops can test AN hoses. Personally, I would > test it to its > rated strength or less, not 2x rated strength. Testing at > 3000 PSI might do > undetectable damage that would wait until a BAD time to > manifest itself in a > leak or broken hose. Also, why test a hose that will never > see over 150 PSI > at 20+ times its working load? > > Kyle Boatright > 0-320/Aymar Demuth RV-6 Slider > Kennesaw, GA > http://www.angelfire.com/my/rv6 > > > ========== > ========== > ========== > ========== > > > ________________________________________________________________________________
Date: Sep 12, 2002
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Paul Besing wrote: > > > Here's the schmatic for the one I did. It is for one switch, using two > relays. If you want to use two grips, then you essentially double this > schematic. The only fault with this one is that if both switches on both > grips are pressed at the same time, it trips the breaker. Not a big deal, > because it never happened, and very rarely did the passenger actually have > the grip while in the pattern. Worked great, and still does. > > http://www.lacodeworks.com/besing/flap.htm By making a very slight modification to this circuit, the possibility of a short is totally eliminated and you can still use multiple inputs. The switch pressed first will have precedence and no matter which way the other switches are selected there will be no short. To do this the positive coil wire to each relay is fed from the normally closed positive contact on the opposite relay instead of being constantly live via the + feed wire. i.e. The lower right coil connection of the "up" relay shown in the schematic would instead of being fed live power as shown be connected to the lower (unused) normally closed switched contact of the "down" relay and the same corresponding change would be made for the "up" relay coil. This sounds very complicated in words but in reality is extremely simple and eliminates the possibility of having a direct short when engaging both relays. NOT a good thing. VERY hard on relay contacts. I have no way to show a modified schematic but could e-mail anyone interested a modified schematic directly if contacted off list. -- Bob McC ________________________________________________________________________________
Date: Sep 12, 2002
Hi Scott, In addition to replacing the washers, you have no need to have anywhere close to 37 psi in your nosewheel. 18 or 19 psi would be more like it. Replace your washers and reduce your nose tire pressure and I'll bet you the problem disappears, although in my experience it doesn't disappear forever. I think it tends to be a recurring problem. Good luck and best wishes, Jack Abell Scott Johnson wrote: > > I have an RV6A with a few hundred hours. > > When it was new, I needed to tighten the front nosewheel nut after a few > hours and then there was no shimmy when applying brakes to stop at about > 30mph. > > Everything looks good and tight, but the shimmy has returned and the nut > cannot be tightened anymore. > > Please note the plane has the wood dampening rods on the landing gear > and I am running about 37 pounds of air in all my tires. > > Does anybody have any recommendations. > > (Is is possible to cause a shimmy if the nut is to tight ?) > > Thanks > > Scott / Chicago > ________________________________________________________________________________
Subject: Cooling - a little long and geeky
Date: Sep 12, 2002
Since the topic of cooling is currently hot on this list, pun intended, I thought I'd post what I've been up to on my 6A with regards to cooling. Some may recall that a few months ago I queried others regarding what to do to get more margin for summer climbs, etc. I instrumented my plane with a simple manometer, or loop of tubing, which compares pressures in the cowl above the engine (Pt) with
September 06, 2002 - September 12, 2002
RV-Archive.digest.vol-nl
