RV-Archive.digest.vol-nn
September 24, 2002 - October 02, 2002
From: | "Garth Shearing" <garth(at)Islandnet.com> |
Subject: | Re: RV8A Canopy skirts |
I think your problem is similar to the one we had on the RV6A. I riveted a
little .025 thick tab on the outside of the front of the canopy skirt at the
bottom just above the rail. The tab, about one half by one half inch square
exposed ahead of the canopy, was bent inboard slightly so that when the
canopy moves forward, the tab causes the canopy to spring inboard.
Not very elegant, but works.
I don't know what might get in the way of this solution in this area on your
RV8, so it may or may not be practical.
Garth Shearing
VariEze and 80% RV6A
Victoria BC Canada
----- Original Message -----
Subject: RV-List: RV8A Canopy skirts
> I've got the canopy skirts drilled and clecoed to the frame and everything
> seems to fit pretty good. However, I'm having an interference problem
where
> the front leading edge of the skirts meet the aft trailing edge of the top
> forward fuselage skin. During fitting, the skirt overlapped the top skin
> but when I slide the canopy aft and then try to close it again, the skirt
> and the skin butt up to each other (since they lie on the same plane)
> preventing the canopy from closing the last 1/2". The obvious solution is
> to trim the aft edge of the top fuselage skin forward about 1/2" (up to
the
> roll bar ribs) but that will eliminate the last topskin-to-longeron rivet.
> Doesn't seem like a big deal losing that rivet or the extra material but
> wanted to be sure I'm not overlooking something and was wondering what
> others have done to deal with this.
> Thanks,
> Ron
> RV-8A
From: | Brian Halkett <brian_halkett(at)yahoo.com> |
Subject: | Re: RV8-List: RV8A Canopy skirts |
Ron,
Don't you have that thing flying yet? :-)
I had to trim both the al. (f-821??) and the
fiberglass skirt. I don't remember having to remove
any rivets?? You should be able to trim the skirt
almost all the way back to back to the canopy frame on
each side.
If you want e-mail me off-line and I'll e-mail you
some pics.
Brian Halkett
N184BH - 215hrs
Current RV of the Week
--- "van Bladeren, Ron" wrote:
> --> RV8-List message posted by: "van Bladeren, Ron"
> interference problem where
> on the same plane)
> forward about 1/2" (up to the
> was wondering what
> Thanks,
> Ron
> RV-8A
> Contributions of
> any other form
> latest messages.
> other List members.
> http://www.matronics.com/subscription
> http://www.matronics.com/photoshare
> http://www.matronics.com/search
Listers,
I have a garmin 195 for sale with all the accessories. I have been using it
in an RV6 and it works wonderfully. I am asking $595 OBO for it. Please email
me offline if you are interested.
Scott
Trim the forward skin to clear the fully closed and latched canopy
frame/bubble/skirt assembly. The windshield fairing layup will mold OVER
the forward edge of the skirt on both sides as much as you find cosmetically
appealing. A few layers of duct tape on the forward end of the skirt will
keep the finished fairing layup from scuffing the paint on the skirt as the
canopy slides into the full forward and locked position. The skirt tucks
under the fairing quite nicely this way.
Brian Denk
RV8 N94BD
301 hrs.
Randy's gaining on me!
>the
>square
>your
>Garth Shearing
>Victoria BC Canada
>From: van Bladeren, Ron <rwv(at)nwnatural.com>
>To:
>everything
>where
>top
>skin
>skirt
>is
>the
>rivet.
> > Thanks,
> > Ron
> > RV-8A
http://www.geocities.com/CapeCanaveral/Hangar/9656/akroshomepage.htm
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
From: | "Sally and George" <aeronut58(at)hotmail.com> |
Ron:
I had exactly the same interference issue and solved it by trimming the
bottom of the canopy skirt in the area of the interference. Works fine and
looks fine.
George Kilishek
N888GK
90 hours
>From: "van Bladeren, Ron" <rwv(at)nwnatural.com>
>Reply-To: rv8-list(at)matronics.com
>To: "'rv8-list(at)matronics.com'"
>Subject: RV8-List: RV8A Canopy skirts
>Date: Tue, 24 Sep 2002 11:47:07 -0700
>where
>to trim the aft edge of the top fuselage skin forward about 1/2" (up to the
>Thanks,
>Ron
>RV-8A
http://www.hotmail.com
From: | "Wiethe, Philip (P.J.)" <pwiethe(at)ford.com> |
Subject: | Carburated IO-360 |
I am looking at having someone put together an angle valve motor for me and they
gave me the option of doing the standard fuel injection or going with a carburator.
I am curious if anyone out there is running a carburated IO-360 (angle
valve motor) and what their thoughts are. I guess it may come down to personal
preference - I would just like to hear some pro's and cons of going with either
setup for an RV.
Phil (8A emp, almost finished)
List:
My inspection was today and the DAR wants me to write a plan for the testing
period (40 hour). Example: Hour 1 - climb to x altitude, stalls, etc. Hour
2 - Hour 3- Hour 4 through 10 ... on and on.
Anybody had to do this or any type of plan I can follow.
Len Leggette RV-8A
N901LL (res)
Greensboro, N.C.
Inpection Tuesday !!!
Can anyone or everyone, advise me which bag of parts contains the screw
or is it bolt for the handle to latch attachment for the sliding canopy
along with the cotter pin? These are part numbers AN23-10 bolt/screw
and MS24665-132 cotter pin as shown on SC-1B drawing.
I did find the washers and castle nut. Just cannot seem to locate these
parts. A search of the bag parts list on Matronic's site doesn't show
this in any bags that I've received. I received my finishing kit in Feb,
it has the slider with the square side tubes on the canopy frame.
Thanks in advance
Marty in Brentwood, RV-6A slider
Ron:
I faced the same problem you did and elected to trim back the canopy skirt
instead of trimming the 821 panel. It worked out OK but in retrospect I should
have cut the panel and left the skirt intact. The reason is just aesthetics,
but your suggestion is what I would do if I had to do it again.
Bill Marvel
Bill Marvel Home/office 310 832 7617
P.O. Box 784 Cell 310 293 2013
San Pedro, CA 90733 Fax 310 832 5334
One good deed beats 100 good intentions...
Len:
I had my signoff in April and had no requirement to do this as part of the
paperwork. However, if the DAR says he wants it you'll have tol come up with
something.
For a first cut, try Van's chapter in the assembly manual on flight test. You
can probably put together an outline from that and then expand upon it for the
DAR's requirement. Later you can do what you really want to do per your flight
test plan developed in a more relaxed manner.
Bill Marvel
Lenleg(at)aol.com wrote:
> List:
> Len Leggette RV-8A
> N901LL (res)
> Greensboro, N.C.
Subject: | Re: Which parts bag |
Marty,
Same slider frame - got mine last July...
My bag 901 has an AN23-8 bolt...902-1 has the castle nut 907 has a
MS24665-283 cotter pin...closest that I could come to the exact match...they
were with my finish kit. Hope they fit - haven't tried them yet! Please
let me know
There is a listing for the exact cotter pin but it's in a bag marked for a
RV8A rear seat...which I didn't get.
Ralph Capen
Slider 6A
Subject: RV-List: Which parts bag
> Thanks in advance
Len,
I have attached a spread sheet written by another RV8 builder. It is a BETA
version so if you find anything you think needs changing, please let me
know. The spreadsheet will eventually be posted on the www.eaa.org web
site.
My other suggestions are to get with your local EAA Flight Advisor and get
some Transitional Training. Your Flight Advisor has a testing manual and can
assist you making your first flight a safe flight.
You can phone Jan Streblow at headquarters to find who has an RV8 to rent to
obtain Transitional Training. or e-mail jstreblow(at)eaa.org
Cy Galley
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Subject: RV-List: Inspection
> List:
testing
Hour
> Len Leggette RV-8A
> N901LL (res)
> Greensboro, N.C.
Subject: | Active experimental countries. |
Which country outside of the U.S., Canada, U.K., and Austrailia is most
active in building and flying experimental and light aircraft?
Hi Bradley,
I would be a little cautious in assuming that the UK is a hotbed of experimental
builders. I am an expat and have just returned from a somewhat depressing visit.
As soon as I arrived I visited my local airfield, Shoreham, in Sussex and visited
the PFA office. This was a nice office of several rooms with at least three
people in attendance. Clearly a centre of some importance and I was confident
of finding other RV builders at the field possibly even an RV9 builder such
as myself.
The chap at the desk seemed quite flustered when I asked if they had a list of
builders and when I explained my interest went off to enquire. He returned to
say that they didn't have any builders there at the field. I said that this
was a bit of a disappointment but that I would be pleased to visit other builders
also. He apologised for not being clear. THERE WERE NO EXPERIMENTALS AT
THE FIELD - UNDER CONSTRUCTION OR OTHERWISE!!!! Shoreham is an airfield serving
a local area with a population of perhaps 500,000 in one of the wealthier areas
of the country.
I am no expert on flying in the UK since I couldn't afford it whilst I lived there
but GA is fee based and I believe that fees are levied for contacting ATC,
(note controlled airspace begins at 3,000'), getting weather, filing flight plans
and landings. The cost of landing at Shoreham was $18 - maybe you can negotiate
a bulk rate for touch and go's! The cost of fuel and parts are inflated
by very high levels of taxation. I think that most people of modest means
who already have a licence and fly regularly do so out of private grass strips
and stay under 3,000' and avoid any contact with ATC.
This should be a real warning to us all regarding fee based GA and stealth taxes
such as VAT. This is now 171/2% and has reached this level step by step. BE
WARNED.
I'd think twice about visiting the UK if you're seeking a builder friendly country.
Good luck
Rob
Rob W M Shipley
RV9A fuse. N919RV resvd.
Subject: | IFR and Autopilots |
> call from Jim Younkin in the middle of the day. He answered
> every question I could think to ask. When I mentioned NavAid
> to him, he didn't have anything negative to say about their
> autopilot, he just informed me of the differences between the
> two. He then faxed me the installation drawings for my RV4. I
> then went to his web sight to find out who the hell Jim
> Younkin was. I always want to know at what experience level
> someone is before I take their advice or buy their product.
> I couldn't believe a man of that knowledge level would
> spend 15 minutes on the phone with ME. If you haven't visited
> his web site, do so. I hope I like the Digitrak, cause I
> ordered one the same day.
I spent an evening tipping a few with Jim Younkin this past May, at our
Twin Cities RV Forum. Jim is a very interesting person indeed. He
knows more about autopilots than anyone around, period. He has been
developing stuff for over 50 years. He flew to our forum in an RV9A
equipped with three of his DigiTrak autopilots. What you see is what
you get with this guy. What was written above doesn't surprise me at
all. How many people do you know who start companies involving
significant development when they are in their 70's?
Alex Peterson
Maple Grove, MN
RV6-A N66AP 210 hours
Wow. Sounds like a lot to ask for. I've never heard of a DAR asking for an
hour by hour plan. Most just ask for some type of test flight plan. If you
tell them that you are going by the flight test standards in AC 90-89A, I
would think that should suffice. It's an FAA publication that specifically
outlines how to flight test an airplane! My DAR was VERY thorough, and this
worked fine for him when he asked for a test flight plan.
Paul Besing
RV-6A Sold (Waiting on the RV-10)
Kitlog Pro Builder's Log Software
http://www.kitlog.com
> List:
testing
Hour
> Len Leggette RV-8A
> N901LL (res)
> Greensboro, N.C.
DAR is an acronym for Designated Airworthiness Representative. A DAR is
responsible for assuring the presented aircraft is airworthy and meets
all requirements of the experimental certificate.
The DAR is not responsible for the test phase of the project. His
responsibility ends when he hands you the "pink slip" that states your
aircraft is ready for flight.
Sounds like your DAR is treading on ground that is beyond his
jurisdiction. I don't know if he is amenable to having this explained to
him by you or others that are better informed than him or not. However,
this individual needs to be educated as to how he is not responsible in
any way with how the test phase is conducted as long as it meets the
requirements of your temporary flight limitations.
Sam Buchanan (RV-6)
> Paul Besing
> From: <Lenleg(at)aol.com>
> To:
> > List:
> testing
> Hour
> > Len Leggette RV-8A
> > N901LL (res)
> > Greensboro, N.C.
From: | "Konrad Werner" <Connywerner(at)wans.net> |
> Must be nice to have so much vacation time! Where do I get a job like
> yours....Ooops, forgot - I'm being forced to go to Hawaii next week for
> work!
> Cheers,
> Stein.
Dear Stein,
What a Bummer, want to trade time next week? You take a well deserved week
off, and I go to work for you on your behalf.
Konrad Werner
ABQ, NM
----Original Message Follows----
Subject: Re: RV-List: Inspection
Date: Tue, 24 Sep 2002 22:48:04 -0500
Sam Buchanan (RV-6)
Sam:
5 years ago, I had to have a Flight Test Plan. The DAR was an old time
friend and he did not care. The FAA FSDO required the DAR to get one for
their review before the FAA would allow the DAR to issue the Airworthiness
Certificate. This appears to be one of those things that varies not only
from DAR but from FSDO to FSDO.
If you know of a regulation that states where it is not required, please
advise so that we can pass this info on to others.
Gary A. Sobek
1,192 + Flying Hours So. CA, USA
http://SoCAL_WVAF.rvproject.com
Hello all,
I have an RV-6 almost completed. It is now in an unheated hangar. The
engine which has not run for a while was previously in my heated
garage. I am concerned that if I don't get the aircraft flying and
the engine running normally before cold weather hits, I will have
condensation and corrosion problems. Anyone have suggestions
regarding heaters or other solutions? At present I am trying to avoid
removal of the engine to take it back to the heated garage. I
remember how much work and time it was installing it. Does anyone
have experience with add on block heaters ie Van's or Tanis?
George
Cy:
Thanks for the info. I have done my transition training with Mike Seager.
Len Leggette RV-8A
N901LL (res)
Greensboro, N.C.
Inpected Tuesday !!
Hey Len...
You can DL a copy of the cards I used here:
http://www.vondane.com/flightdata/index.htm
Good luck on your inspection!
-Bill
www.vondane.com
List:
Hour
Len Leggette RV-8A
N901LL (res)
Greensboro, N.C.
>List:
>testing
>Hour
>Len Leggette RV-8A
>N901LL (res)
>Greensboro, N.C.
You're almost ready to go! Great news, Len. My FAA inspector didn't ask
for a written flight test plan. He did want to know what my plan for the
first flight was going to be. I think he just wanted to make sure that I
wasn't going to perform a roll on takeoff followed by a low inverted pass or
some other form of stupidity.
You'll prove the airworthiness of the airplane within minutes. I mean, if
it climbs out, is fully responsive to control inputs, and can be stalled and
recovered normally, the rest is just working out the details. I would do as
he asks, be brief and concise, or even ask for an example that he might
have. You are ultimately responsible for the safe operation of the
airplane, so adapt as needed.
Maybe Kevin has a test profile of some sort? He's "da Man" in the flight
testing arena.
Brian Denk
RV8 N94BD
301 hrs.
When I fiberglassed the strip that goes over the wind screen, I extended a
"lip" that covers the "seam" between the forward fuselage skin and the
canopy skirt. Of course, to do this close the canopy and put electrical
tape (or better still, a sheet of clear plastic like what is used to make
transparencies for overhead projections) over the skirt portion (so the
fiberglass won't stick). This makes for a good "transition" into the canopy
skirt. Contact off line if you need more details.
Rick Jory RV8A
where
the
> Thanks,
> Ron
> RV-8A
This particular DAR was flexible in some areas and extremely not in others.
Wayne Williams had flown his 8A in for the inspection and the DAR couldn't
believe that his passed without the fuel cap placard. He wants me to put the
data plate inside the plane and another one near the tail. Told him I had
never heard of that and he says that is the way most planes are done. The
tail plate only needs the make, model, & serial number.
I didn't want to argue too much with the guy. Most of the things he was
willing to listen on and that was good enough for me.
Len Leggette RV-8A
N901LL (res)
Greensboro, N.C.
Flying in a week !!
> From: Sam Buchanan <sbuc(at)hiwaay.net>
> Sam Buchanan (RV-6)
> Sam:
> Gary A. Sobek
I guess I would be more interested in seeing a regulation stating it
*is* required. There is no doubt that various "interpretations" of the
FARS exist among different FSDOs, even though some of the
interpretations defy logic. If our interpretation of the regs is based
on requiring anything that isn't specifically prohibited, then we have
opened a very nasty can of worms!
Having a test flight plan is highly recommended for a successful and
valid test flight phase; however, I think it would be hard (impossible?)
to prove per the FARS that possession of a written test plan is
necessary in order to receive the flight authorization.
Sam Buchanan
Subject: | Alternator breaker/fuse |
I have a 35 amp alternator (from Vans) - should I use a 35 amp breaker for
the output? The reason I ask is I have these aeroelectric "fat" inline
fuses, but note that they are rated at 60amps. I also note that Spruce
sells "60/70 amp circuit breakers for alternators." Thanks in advance
Mike Sices
RV8 wiring
Gurnee, IL
List:
One more thing about the inpection by the DAR. He is requiring me to label
the buttons and functions on my Infinity Grip. How in the heck am I suppose
to do that. He says it is a new FAA requirement.
Len Leggette RV-8A
N901LL (res)
Greensboro, N.C.
Flying in a week !!
Subject: | Re: Alternator breaker/fuse |
>Mike Sices
>RV8 wiring
>Gurnee, IL
A 35 amp breaker on a 35 amp alternator pretty much guarantees that the
breaker will be opening up under some conditions. A sample would be a
cold weather, low battery, start, where the alternator is going to be
putting out more than 35 amps. If it is a breaker you can get to, maybe
you could live with it. A 35 amp fuse would be unacceptable in my book.
Look for something around 45 amps. I personally don't see a problem with
a 60.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
09/25/2002 10:46:38 AM
Len,
I labeled the infinity grip using a prepared sheet of labels from Aircraft
Spruce. The format was white 1/8 inch lettering on black background. After
a year of flying they are still on and look as good as new.
David Rowbotham
N712CR RV-8a 125hrs
Lenleg(at)aol.com
Sent by: To: RV-list(at)matronics.com
owner-rv-list-server@mat cc:
ronics.com Subject: RV-List: Inspection
09/25/2002 09:59 AM
Please respond to
rv-list
List:
suppose
Len Leggette RV-8A
N901LL (res)
Greensboro, N.C.
Flying in a week !!
George,
I went thru the same transistion in building you are talking about without
any apparent effects. The gradual one time change from heated environment to
unheated is not a problem in my opinion. As for not being run for a period
of time my engine was delivered new in 1999 and fired up the first time in
2002. It was on the airframe for one and one half years in the unheated
hanger.I have completed my RV6A and close to 60 hours. I believe the
condensation is only a problem in the heat up and cool down cycles following
engine operation, and that is not usually an issue either if you get engine
temp up to 180 to cook out any moisture.
Dick Seiders
-----Original Message-----
Date: Wednesday, September 25, 2002 8:36 AM
>--> RV6-List message posted by: George Frost
>Hello all,
>Thanks,
>George
George:
I don't think that heat or cold, alone, make any difference at all. The
worst thing you can do is run the engine on the ground and then shut it down
for a prolonged period. Moisture from combustion will then condense in the
oil and cause internal corrosion. That is why it is recommended to fly the
aircraft whenever you start the engine. In doing so, you create enough heat
for long enough to boil this moisture away.
As to your situation, you probably want to look into Lycoming's
recommendations for pickling an engine for long term storage on the
airplane. I would certainly not pull it off and take it back to your
garage. Many, many engines have to endure your scenario and somehow they get
through it.
Bill Marvel
George Frost wrote:
> Hello all,
> Thanks,
> George
Ron:
I did the same thing Rick did as described below. Some builders choose to have
a butt joint between the canopy skirt and the 821 panel in front of it. This
looks nice but also provides a water leakage path. Since I built my airplane
for transportation, rain and all, I made the overlap that is described. It
works very well.
Bill Marvel
> Rick Jory RV8A
Mike:
That's precisely what I did in my 8A and it works fine. Since I spent the
past 25 years with certified airplanes, I admit to following their basic
designs, flaws and all. 60 amp alternators have 60 amp breakers, ditto 40 amp
alternators with 40 amp breakers. I suspect there is a world of knowledge out
there as to why something else is preferable, but this design has worked fine
for me on many airplanes, including the RV.
Bill Marvel
> Mike Sices
> RV8 wiring
> Gurnee, IL
From: | "Wilson, James Mike" <james.mike.wilson(at)intel.com> |
George,
Heat only if you can keep the temp. constant.
I recommend simply wrapping with blankets (not plastic) to prevent exposure
to rapid changes in air temp. outside the engine (i.e. in the mornings).
Rapid drop in temp. causes condensation on objects which do not change as
fast (i.e. metal). If you slow direct exposure, condensation is reduced or
eliminated. This leaves the metal subject only to the moisture in the
ambient air which does not seem to have huge impact except over long periods
of time (i.e. year or more). I had my fresh engine wrapped in unheated
environments (garage and hanger for 4 years with no noticeable corrosion. I
live in Portland OR so we do have moist air. I also remove the cowl and wrap
engine in the winter when usage is less frequent. I hate to think it might
feel a draft in the cold mornings.
From: George Frost [mailto:ghfrost(at)earthlink.net]
Subject:
Hello all,
George
From: | "van Bladeren, Ron" <rwv(at)nwnatural.com> |
Subject: | RE: RV8-List: RV8A Canopy skirts |
Thanks George. I thought about trimming the skirt but then it wouldn't be
inline with the leading edge of the canopy bow. That's why I'm leaning
towards trimming the top skin aft edge since it protrudes about 1" aft of
the windscreen/roll bar edge. After trimming, it would then line up with
the aft edge of the forward side skin.
Ron.
From: Sally and George [mailto:aeronut58(at)hotmail.com]
Subject: Re: RV8-List: RV8A Canopy skirts
--> RV8-List message posted by: "Sally and George"
Ron:
looks fine.
George Kilishek
N888GK
90 hours
>where
>Thanks,
>Ron
>RV-8A
Thanks Bill (again!). That's what I'll do.
Ron.
--> RV8-List message posted by: Bill Marvel
Ron:
should
aesthetics,
Bill Marvel
the
From: | kempthornes <kempthornes(at)earthlink.net> |
Does the FAA tell DARs to just go out there and "do your own thing"?
How about we ask the EAA to work on standardizing what these clowns
do? Better still, create a document that says what DARs and FAA inspectors
might do and publish it for all of us then we will know what to prepare for
and they will know what to require? Is this just too simple?
Cy Galley - who can we talk to at EAA?
K. H. (Hal) Kempthorne
RV6-a N7HK flying!
PRB (El Paso de Robles, CA)
Want to add smoke to my RV8 project. Anyone have a name of a quality
tank/system builder?
Francis Butler
Butler Machinery Co.
(701) 298-1758 direct
(701) 476-3208 fax
francis_butler@butler-machinery.com
Wow. This is news to me. For the time being I'd type in the functions in
an Excel-like program . . . using small (6 pt) type. Print on white,
sticky-back label stock. If push comes to shove, you can laminate the top
surface, but regardless, cut them, peel off the back, stick them on the
Infinity. Another thought could be a small panel diagram that delineates
what each button does. Good luck. I guess I'll have to come up with
something on my Infinity grip as well.
Rick Jory
> List:
label
suppose
> Len Leggette RV-8A
> N901LL (res)
> Greensboro, N.C.
> Flying in a week !!
That sounds like an easy solution, but I would caution all to "be carefull
what you wish for".
Yes, there is a large deal of variance between on DAR and another, but look
at that as a positive and not a negative. Anytime you want to Fed's to
regulate things better, you end up with a bunch of legal gobbelty-gook that
makes life worse.
I'd submit that an easier solution is to search out the "better" DAR's. You
are not required to use a local DAR, for example, I live in Minneapolis, but
am using a DAR from the Chicago office - why, for some of the very reasons
brought out below. My DAR has done MANY, MANY RV's, and hundres of other
homebuilts.
DAR's are no different in their discrepancies than Check Ride pilots, A&P
DME's, etc.. It's basic human nature.
Stein Bruch
RV6, Minneapolis (Using a "Foregin" DAR for my inspection).
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of kempthornes
RV6-a N7HK flying!
At this point, if it were me, I would find another DAR... This guy sounds
ridiculous to work with...
-Bill
www.vondane.com
List:
Len Leggette RV-8A
N901LL (res)
Greensboro, N.C.
Flying in a week !!
Subject: | 200 bhp wood propeller |
can someone recommend a wood propeller for my 200 bhp rv-8 ??
want cruise propeller.
have 72 " margie warnkee propeller today- but pitch too fine and runs at
2950 rpm and 160+ kts
appreciate help
regards terje kobro
norway
Subject: | Lord mount orientation |
Hi Greg,
Sorry for the tardy response, but I think this is the info you're
looking for regarding Lord J-6230-1 mount orientation.
When viewed from the cockpit (looking forward towards the engine
compartment), the index marks go as follows:
Left lower mount 10 o'clock (i.e., up and outboard)
Left upper mount 2 o'clock
Right upper mount 4 o'clock
Right lower mount 8 o'clock
I now have about 500 hard hours on mine and they continue to perform
quite well. I'll never go back to the 'cheap' conical mount bushing
again. I originally mounted my Lord J-6230-1 mounts without any
particular orientation and then changed then to the factory recommended
positions after about 200 hrs. I can't say that I noticed much
difference. Both ways were dramatically superior to the old conical
bushings.
For those who have a conical mount O 320 and are unfamiliar, I'd suggest
you check Lord conical mounts out for yourself. The J-6230-1 mounts
are more expensive than the traditional bushing, but effectively put
lots more rubber bushing material to work at dampening. Yet, the
overall mount is stiffer with less engine flex in acro.
My Hartzell CS had already been dynamically balanced to a high degree
which certainly helped. Still, adding the Lord mounts made a dramatic
difference in airframe vibration. They seem to be holding up OK, too.
Just one view based on my personal experience. As the saying goes, your
mileage may vary.
Mark
RV4
KAWO
________
Subject: RV-List: Lord mount orientation???
I just got the new J-6230-1 Lord mount bushings from Vans and I have no
orientation marks on my conical engine mount to help me install them
correctly. Can anyone help me make sure I get them installed correctly?
Greg Hunsicker
Subject: | Rv's in Italy or France? |
I will be in Italy and France the last part of November, any RV flyers there?
Scott Bilinski
Eng dept 8220
Phone (858) 657-2536
Pager (858) 502-5190
From: | "hal merritt" <merritthal(at)hotmail.com> |
For any one doing their electrical I have 8 Potter-brumfield w58 series breakers
for sale, 1 one amp 2 two amp 3 three amp 2 four amp. I will take 50 dollars
U.S. for all
Subject: | Re: RV8-List: 200 bhp wood propeller |
To eliminate guess work, I would call the closest propeller manufacturer
near you and either have them make something for you or at least tell you
what you need. Since you started with a 72 " margie warnkee I would call
them and give them the performance numbers form the prop you tried, and
they can recommend one that will work best.
>--> RV8-List message posted by: terje.kobro(at)platou.com
>appreciate help
>regards terje kobro
>norway
Scott Bilinski
Eng dept 8220
Len: Check http://www.vansairforce.org/
It is the Western Canada Wing of Van's AF. They have detailed operating manuals
and flight test proceedure cards made up for RV-6's. Look for the links on
the home page above.
Gary
List:
Len Leggette RV-8A
N901LL (res)
Greensboro, N.C.
Subject: | Re: Rv's in Italy or France? |
Here is a name and email of a fellow I've been chatting with:
"jean-claude.chauvet(at)libertysurf.fr"
I don't know where, exactly, he is but he's building a 6A and seems to
be around several other RVs.
Have fun and don't eat too much Gellato!
- Mike
> flyers there?
> Scott Bilinski
> Eng dept 8220
Michael E. Thompson (Grobdriver(at)yahoo.com)
Austin, TX, USA
RV-6 in progress, N140RV
Ex-AX1 Sub Hunter, P-3 (B/B-TACMOD/C) Orion Aircrew,
PP-G,ASEL, Motorglider Driver and Unlimited Air Race Nut!
Sam, You may be right, but if the DAR says that he won't sign until xyz
happens, xyz will happen or you will have to pay a different DAR for another
inspection or wait for a very long time for the FSDO to change his mind. AND
you still have to pay the present DAR. He gets paid whether you pass or fail
the inspection.
Cy Galley
> > Sam Buchanan (RV-6)
> > Sam:
for
Airworthiness
only
> > Gary A. Sobek
> Sam Buchanan
Just do it. You and I know that they will quickly wear or fall off. It is
his interpretation and you can either do it like he requests or wait until
the FSDO either says yea or nay.
Don't sweat the small stuff.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Always looking for articles for the Experimenter
> List:
label
suppose
> Len Leggette RV-8A
> N901LL (res)
> Greensboro, N.C.
> Flying in a week !!
Talk to govt(at)eaa.org
Cy Galley
inspectors
for
> RV6-a N7HK flying!
> the inspection.
> Cy Galley
Well......in any case, just put out the word locally that this
particular DAR is a bit flaky, and he will soon become irrelevant.
Sorry you have had to endure this case of nit-pickin'. Most DARs are
really good folks who know their stuff; however, the new technology
appearing in many panels is creating a situation where some of them are
going to have to be "educated".
My plane was the first Rocky Mountain Instruments installation my DAR
had seen, but once I explained their features, he readily bought it off
even though it didn't have the traditional faces with red "never exceed"
markings.
My concern is that silly stuff like your DAR is enforcing will become
mainstream if it isn't nipped right now; then future builders will have
to put up with even more nonsense.
Sam Buchanan
From: | "Aircraft Technical Book Company" <winterland(at)rkymtnhi.com> |
Hey Sam, here's an idea for your web site. Why don't you compile a list
from us of RV friendly DARS by region and post them on a page on your site.
Put down what they charge too. Most of these guys are in it for the money
and its about time they have to deal with a little market pressure too. It
does work both ways.
Andy
another
AND
fail
> > the inspection.
Subject: | Alernator Breaker/fuse |
From: | "Martin Hone" <martin.hone(at)tradergroup.com.au> |
Mike,
I had the same query, and couldn't understand why most of the information available
seemed to specify a 60 A fuse for the alternator lead.
Eventually Electic Bob advised that a 40 A fuse would be fine for a 35A alternator.
A higher rated fuse could be handy on the occasssional really cold day with
flat battery situation, or if you have a higher rated alternator.
Has anyone used a Cole Hersee 40A sealed circuit breaker on their RV ? It is standard
fitment as the main fuse on Harleys, is small, easy to mount and with stud
terminals ?
Martin in Oz
Good idea! I'll run this idea past Doug Reeves since his site would be a
great place to have the DAR list.
It definitely works both ways. We had a local DAR who tried to rob one
of our builders with an exorbitant fee.......and nobody has seen that
DAR since.
Sam Buchanan
> Andy
Subject: | Re: RV8-List: Rv's in Italy or France? |
--> RV8-List message posted by: Scott Bilinski
Scott Bilinski
Eng dept 8220
Scott, contact Van's. They will provide a list of RV folks in Italy and
France, I know there are some in france as I checked this myself 4 yrs ago
prior to a trip there. Unfortunately, I did not have time to look anyone up.
Andy Johnson, N808JH res.
Subject: | RE: RV-List Digest: 15 Msgs - 09/18/02 |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=
Subject: | RE: RV-List Digest: 29 Msgs - 09/19/02 |
U2VydmVyIA0KCVNlbnQ6IEZyaSA5LzIwLzIwMDIgMTo1NiBBTSANCglUbzogUlYtTGlzdCBEaWdl
c3QgTGlzdCANCglDYzogDQoJU3ViamVjdDogUlYtTGlzdCBEaWdlc3Q6IDI5IE1zZ3MgLSAwOS8x
OS8wMg0KCQ0KCQ0KDQoJKg0KCQ0KLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t
IC0tLQ0KCSAgICAgICAgICAgICAgICAgICAgIFRvdGFsIE1lc3NhZ2VzIFBvc3RlZCBUaHUgMDkv
MTkvMDI6IDI5DQoJDQotLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t
ZTogMTI6MDM6MzIgQU0gUFNUIFVTDQoJRnJvbTogU3BlZWR5MTFAYW9sLmNvbQ0KCVN1YmplY3Q6
IFJWLUxpc3Q6IFdpbmcgS2l0IEZvciBTYWxlDQoJDQoJLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0
ZWQgYnk6IFNwZWVkeTExQGFvbC5jb20NCgkNCglJIGhhdmUgYSBSVi04LzhBIHdpbmcga2l0IGZv
ciBzYWxlLiAgSXQgaXMgcGFydGlhbGx5IGZpbmlzaGVkDQp3aXRoIHN1cGVyYg0KCXdvcmttYW5z
aGlwIGFuZCBoYXMgYSBwaGxvbmdzdG9uIHNwYXIuICBJIGJvdWdodCBhbm90aGVyIGd1eXMNCnBy
b2plY3QgaW4NCglvcmRlciB0byBnZXQgaGlzIGVtcGVubmFnZSBhbmQgSSBkb24ndCBuZWVkIHRo
ZSB3aW5nIGtpdCBzaW5jZSBJDQpoYXZlIGEgUUINCglraXQuICBJIGNhbiBzZW5kIGRpZ2l0YWwg
cGhvdG9zLiAgSSB3aWxsIGluc3VyZSBhbGwgcGFydHMgYXJlDQppbmNsdWRlZC4gDQoJVmFuJ3Mg
Y3VycmVudCBwcmljZSBpcyAkNTE1NSArIHNoaXBwaW5nLiAgSSB3aWxsIHNlbGwgZm9yICQyOTAw
DQorIHNoaXBwaW5nLiANCglJIHdpbGwgYnVpbGQgYSBjcmF0ZSB0byBzaGlwIGl0IGlmIHlvdSBw
YXkgZm9yIHRoZSBtYXRlcmlhbHMgdG8NCmJ1aWxkIGl0LiANCglMb2NhdGVkIGluIFRhbXBhLCBG
TC4gIDgxMy0zMTgtOTA3NA0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KX19fX19fX19fX19f
X19fDQpfX19fX19fXw0KCVRpbWU6IDA0OjIxOjI2IEFNIFBTVCBVUw0KCUZyb206IGJpbGwgc2hv
b2sgPGJpbGxzaG9vazIwMDBAeWFob28uY29tPg0KCVN1YmplY3Q6IFJWLUxpc3Q6IERlbnZlciBQ
ZW9wbGUNCgkNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogYmlsbCBzaG9vaw0KPGJp
bGxzaG9vazIwMDBAeWFob28uY29tPg0KCQ0KCUhlbGxvIFJWIGxpc3QuLml0J3MgYmVlbiBhIGxp
dHRsZSB3aGlsZS4gIExpZmUgb3ZlciB0aGUgcGFzdA0KeWVhciBoYXMgYmVlbi4ud2VsbCBpbnRl
cmVzdGluZy4gIFRoZQ0KCWxhc3QgcGFydCBvZiB3aGljaCBoYXMgYnJvdWdodCBtZSBmcm9tIE9y
bGFuZG8gdG8gRGVudmVyLiAgSQ0Kd291bGQgbGlrZSB0byBnZXQgaW52b2x2ZWQgaW4gdGhlDQoJ
YnVpbGRlciBncm91cCBoZXJlIGFuZCBhbSBsaWtlbHkgbG9va2luZyBmb3Igc29tZSBoYW5nZXIg
c3BhY2UNCmluIHdoaWNoIHRvIGJ1aWxkLi4uLnNvIGlmIHlvdSdyZQ0KCW9uZSBvZiB0aGUgRGVu
dmVyIHR5cGVzLi5zZW5kIG1lIGFuIGVtYWlsIHBsZWFzZS4NCgkNCglCaWxsIFNob29rDQoJLTQg
d2luZ3MNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCl9fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KX19fX19f
X18NCglUaW1lOiAwNTowNzo1NiBBTSBQU1QgVVMNCglGcm9tOiBiYXJyeSBwb3RlIDxiYXJyeXBv
dGVAY29tY2FzdC5uZXQ+DQoJU3ViamVjdDogUmU6IFJWLUxpc3Q6IEZpcnN0IEZsaWdodCBQcmVw
YXJhdGlvbg0KCQ0KCS0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBiYXJyeSBwb3RlDQo8
YmFycnlwb3RlQGNvbWNhc3QubmV0Pg0KCQ0KCURvbiwNCgkNCglPbmUgb2YgdGhlIGJlc3QgZm9y
dW1zIEkgYXR0ZW5kZWQgYXQgT3Noa29zaCwgdGhpcyB5ZWFyLCB3YXMNClByZXAgZm9yDQoJMXN0
IGZsaWdodCwgZ2l2ZW4gYnkgdGhlIEVBQS4gSSB3aWxsIGxpc3QgZnJvbSBteSBub3Rlcywgc29t
ZSBvZg0KdGhlDQoJdGhpbmdzIGhlIHNhaWQuDQoJDQoJTG9jYWwgdGVjaCByZXAgaGFzIG1hdGVy
aWFscyBvbiAxc3QgZmxpZ2h0IHByZXAuIFRhbGsgdG8gaGltLg0KCQ0KCTIwJSBvZiBBTEwgaG9t
ZWJ1aWx0IGFjY2lkZW50cyBjb21lIG9uIHRoZWlyIDFzdCAyIGZsaWdodHMuIEFORA0KaXQncyBu
b3QNCgltZWNoYW5pY2FsLiBJdCdzIG1vc3RseSBwaWxvdCBwcm9ibGVtcy4NCgkNCglJbnZpdGUg
dGhlIGxvY2FsIGZpcmUgZGVwYXJ0bWVudCB0byBjb21lIHNlZSB5b3VyIHBsYW5lIGJlZm9yZQ0K
dGhlIDFzdA0KCWZsaWdodCBhbmQgdGhlbiBhZ2FpbiBmb3IgdGhlIGZsaWdodC4NCglBbGVydCBm
aXJzdCBhaWQgc3F1YWQsIHRoZSBzYW1lIHdheS4gQm9uZGluZyBoZWxwcyB3aGVuIHRoZQ0KY2hp
cHMgYXJlDQoJZG93bi4NCgkNCglXYWxrIHRoZSBhaXJwb3J0LCB0aGUgd2F5IHNvbWUgSW5keSBy
YWNlcnMgZG8gYmVmb3JlIHRoZSByYWNlLg0KUGxhbiB5b3VyDQoJb3B0aW9ucy4NCgkNCglGbHkg
b25seSBpbiAiY29uZXMgb2Ygc2FmZXR5Ii4NCgkNCglIYXZlIHNvbWVvbmUgb24gZ3JvdW5kIHdp
dGggaGFuZCBoZWxkLg0KCSAxLiBZb3UgaGF2ZSBzaG9ydCBub3RlcyAoY2hlY2tsaXN0KSBmb3Ig
aGFuZGxpbmcgdmFyaW91cw0KCWVtZXJnZW5jaWVzLiAgICAgVGhleSBoYXZlIGRldGFpbGVkIGxp
c3QgdG8gcmVhZCB5b3UuIFlvdSBzYXkNCidGSVJFIiwNCgl0aGV5IHN0YXJ0IHJlYWRpbmcgdGhl
IEZJUkUgZGV0YWlscy4NCgkgMi4gTm90aWNlIGFuZCByZXBvcnQsIHRha2Ugb2ZmIHNwZWVkLCB0
byBncm91bmQgcGVyc29uLiBUaGV5DQpjYW4gICANCglyZW1pbmQgeW91IG9mIGl0IHdoZW4gaXQg
Y29tZXMgdGltZSB0byBsYW5kLiBBZGQgdG8gaXQgZm9yDQpzYWZldHkuIE5ldmVyDQoJZ28gYmVs
b3cgaXQuDQoJICAgIFRoaXMgaXMgcGFydGljdWxhcmx5IGhlbHBmdWwgaWYgeW91IGRvbid0IGdl
dCB0byBkbyBzdGFsbHMNCgliZWZvcmUgICAgIGxhbmRpbmcuDQoJDQoJR2V0IHdpdGggYSBnb29k
IGluc3RydWN0b3IgYW5kIGZseSB0aGUgc2FtZSBraW5kIG9mIHBsYW5lIHlvdQ0KaW50ZW5kIHRv
DQoJJ3Rlc3QnLg0KCQ0KCUlmIHlvdSBhcmUgZ29pbmcgdG8gd2VhciBoZWxtZXRzIGFuZCBmaXJl
IHN1aXRzIGFuZCBnbG92ZXMgYW5kDQpjaHV0ZXMsDQoJc3RhcnQgd2VhcmluZyBhbmQgZmx5aW5n
IHdpdGggdGhlbSwgd2VsbCBpbiBhZHZhbmNlLiBUaGluZ3MgYXJlDQoJZGlmZmVyZW50IHdpdGgg
dGhhdCBzdHVmZiBvbi4NCgkNCglFbGltaW5hdGUgYXMgbWFueSAnbmV3IGV4cGVyaWVuY2VzJyBm
cm9tIHlvdXIgMXN0IGZsaWdodCBhcyB5b3UNCmNhbi4NCglUaGF0IGNvdmVycyBhIGxvdCBvZiBn
cm91bmQuDQoJDQoJIkN1cnJlbmN5IiBpcyBtb3JlIHRoYW4gMyB0YWtlb2ZmcyBhbmQgbGFuZGlu
Z3MuDQoJDQoJQmUgYWJsZSB0byBmaW5kIGFsbCBjb250cm9scyBhbmQgc3dpdGNoZXMgYmxpbmRm
b2xkZWQuIElmIHlvdQ0KaGF2ZQ0KCXNtb2tlLCBpdCB3aWxsIGJlIGxpa2UgYmVpbmcgYmxpbmQu
DQoJDQoJUGxhbiBmb3IgYWxsIGVtZXJnZW5jaWVzLg0KCQ0KCVdyaXRlIGRvd24geW91ciBwZXJz
b24gbWluaW11bXMgYW5kIHNob3cgYW5kIHRlbGwgdGhlbSB0bw0KZXZlcnlvbmUuIFRoZXkNCgl3
aWxsIGhlbHAgeW91IGN1cmIgeW91ciBhcHBldGl0ZSAndG8gZ28nLg0KCQ0KCTFzdCBmbGlnaHQg
ZnJlcXVlbmN5IGlzIDEyMy40NS4NCgkNCglMb3cgc3BlZWQgdGF4aToNCgkgMS4gZ2VhciBhdHRh
Y2hlZD8NCgkgMi4gYnJha2VzIGRyYWdnaW5nPyAgRG9uJ3Qgb3ZlcmhlYXQgdGhlbSENCgkNCglX
aGVuIGV2ZXIgeW91IGFyZSBpbiB0aGUgcGxhbmUsIGJlIHByZXBhcmVkIGZvciBmbGlnaHQhDQoJ
DQoJVGhleSBkaWQgbm90IHRoaW5rIG11Y2ggb2YgaGlnaCBzcGVlZCB0YXhpIHdvcmsuIEl0IHRv
byBvZnRlbg0KYmVjb21lcw0KCTFzdCBmbGlnaHQuDQoJDQoJSWYgeW91IGRvbid0IG5lZWQgZmxh
cHMgdG8gdGFrZSBvZmYsIGRvbid0IHVzZSB0aGVtIG9uIDFzdA0KZmxpZ2h0LiBKdXN0DQoJYW5v
dGhlciB0aGluZyB0aGF0IGNvdWxkIGdvIHdyb25nLg0KCQ0KCUNoYXNlIHBsYW5lIG5vdCByZWFs
bHkgYSBnb29kIGlkZWEuIERvIG9ubHkgaWYgdGhlIGNoYXNlciBoYXMNCmxvdHMgb2YNCglleHBl
cmllbmNlIGF0IGl0IGFuZCB0aGVuLCBrZWVwIGhpbSB3ZWxsIGFib3ZlIHlvdSAob3V0IG9mIHlv
dXINCndheSkuDQoJDQoJQWZ0ZXIgdGFrZW9mZiwgY29udGludWUgZG93biB0aGUgcnVud2F5IGFz
IGxvbmcgYXMgdGhlcmUgaXMgb25lDQp1bmRlcg0KCXlvdS4gWW91IG1pZ2h0IG5lZWQgaXQuDQoJ
DQoJRG9uJ3QgdGhpbmsgYWJvdXQgdHVybmluZyB0aWxsIGF0IGxlYXN0IDUwMCBmZWV0IGZyb20g
dGhlDQpncm91bmQuDQoJDQoJQ2xpbWIgdG8gMyB0aW1lcyBwYXR0ZXJuIGFsdGl0dWRlIGZvciB5
b3VyIHRlc3RpbmcuDQoJIFRlc3QgcGF0dGVybiBzcGVlZHMuIERvIGEgcHJldGVuZCBsYW5kaW5n
LiBEbyBpdCB0d2ljZSBiZWZvcmUNCmxhbmRpbmcuDQoJDQoJMXN0IHBvd2VyIHJlZHVjdGlvbiBz
aG91bGQgYmUgYXQgYWx0aXR1ZGUuIFlvdXIgZ3JlYXRlc3QgY2hhbmNlDQpvZiBhbg0KCWVuZ2lu
ZSBwcm9ibGVtIGlzIHdoZW4geW91IHRvdWNoIHRoZSBjb250cm9scy4NCgkNCgkiUmVkdWNlIGdy
aXAgcHJlc3N1cmUiIQ0KCQ0KCVRoYXQncyB0aGUgMXN0IGZsaWdodCBhY2NvcmRpbmcgdG8gdGhl
IEVBQS4NCgkNCgkybmQgRmxpZ2h0Og0KCSAgTk9UIFRIRSBTQU1FIERBWSBBUyBUSEUgMVNUISAg
MXN0IGZsaWdodCB0YWtlcyBhIGxvdCBvdXQgb2YNCnlvdS4NCgkgIEdlbmVyYWxseSB0aGUgc2Ft
ZSBhcyB0aGUgMXN0Lg0KCQ0KCUZseSB3aXRoIGZ1bGwgZnVlbC4gV2hpbGUgZnVlbCBidXJucywg
cGFydGlhbCB0YW5rcyBjYW4gZXhwbG9kZS4NCgkNCgkyIG1pc3Rha2VzIHRoYXQgY2F1c2UgcHJv
YmxlbXMuDQoJICAxLiBDaGFuZ2luZyB0aGUgbWFudWZhY3R1cmVyJ3MgZnVlbCBzeXN0ZW0uDQoJ
ICAyLiBDaGFuZ2luZyAiICAgIiAgICAgICAgICAgICAgaGFybmVzcyBtb3VudGluZyBzeXN0ZW0u
DQoJDQoJUGxlYXNlIGtlZXAgaW4gbWluZCB0aGF0IHRoZXNlIGFyZSBteSBub3Rlcywgbm90IEdv
c3BlbC4gR2V0DQp0aGlzIGluZm8NCglmcm9tIHRoZSBzb3VyY2UgKEVBQSkuDQoJDQoJQmFycnkg
UG90ZSBSVjlhIGZpbmlzaGluZw0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KX19fX19fX19f
X19fX19fDQpfX19fX19fXw0KCVRpbWU6IDA3OjEzOjIxIEFNIFBTVCBVUw0KCUZyb206IHJ2OGRy
aXZlciA8cnY4dG9yQGNvbWNhc3QubmV0Pg0KCVN1YmplY3Q6IFJWLUxpc3Q6IFJlOiBSVjgtTGlz
dDogV2luZyBLaXQgRm9yIFNhbGUNCgkNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTog
cnY4ZHJpdmVyIDxydjh0b3JAY29tY2FzdC5uZXQ+DQoJDQoJSSdkIGJlIGludGVyZXN0ZWQgaW4g
c2VlaW5nIHlvdXIgcGljcy4gIENhbiB5b3Ugc2VuZCBvciBwb3N0DQp0aGVtPw0KCQ0KCVRoYW5r
cywNCglrZXZpbg0KCQ0KCU9uIFRodSwgMTkgU2VwIDIwMDIgMDM6MDI6MDkgLTA0MDAgKEVEVCks
IFNwZWVkeTExQGFvbC5jb20NCndyb3RlOg0KCT4tLT4gUlY4LUxpc3QgbWVzc2FnZSBwb3N0ZWQg
Ynk6IFNwZWVkeTExQGFvbC5jb20NCgk+DQoJPkkgaGF2ZSBhIFJWLTgvOEEgd2luZyBraXQgZm9y
IHNhbGUuICBJdCBpcyBwYXJ0aWFsbHkgZmluaXNoZWQNCndpdGgNCgk+c3VwZXJiIHdvcmttYW5z
aGlwIGFuZCBoYXMgYSBwaGxvbmdzdG9uIHNwYXIuICBJIGJvdWdodCBhbm90aGVyDQpndXlzDQoJ
PnByb2plY3QgaW4gb3JkZXIgdG8gZ2V0IGhpcyBlbXBlbm5hZ2UgYW5kIEkgZG9uJ3QgbmVlZCB0
aGUgd2luZw0Ka2l0DQoJPnNpbmNlIEkgaGF2ZSBhIFFCIGtpdC4gIEkgY2FuIHNlbmQgZGlnaXRh
bCBwaG90b3MuICBJIHdpbGwNCmluc3VyZQ0KCT5hbGwgcGFydHMgYXJlIGluY2x1ZGVkLiAgVmFu
J3MgY3VycmVudCBwcmljZSBpcyAkNTE1NSArDQpzaGlwcGluZy4gIEkNCgk+d2lsbCBzZWxsIGZv
ciAkMjkwMCArIHNoaXBwaW5nLiAgSSB3aWxsIGJ1aWxkIGEgY3JhdGUgdG8gc2hpcA0KaXQgaWYN
Cgk+eW91IHBheSBmb3IgdGhlIG1hdGVyaWFscyB0byBidWlsZCBpdC4gIExvY2F0ZWQgaW4gVGFt
cGEsIEZMLg0KODEzLQ0KCT4zMTgtOTA3NA0KCT4NCgk+DQoJPl8tDQoJPg0KCQ0KPj09PT09PT09
PT09PQ0KCT5fLQ0KCT4NCgkNCj49PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCgk+bWVzc2FnZXMuDQoJPl8tDQoJPg0K
CQ0KPj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PQ0KCT5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vIF8tDQoJPg0KCQ0K
Pj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PQ0KCT49PQ0KCT4NCgk+DQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQpf
X19fX19fX19fX19fX18NCl9fX19fX19fDQoJVGltZTogMDc6MTU6NTUgQU0gUFNUIFVTDQoJRnJv
bTogIk1pa2UgTmVsbGlzIiA8bWlrZUBibW5lbGxpcy5jb20+DQoJU3ViamVjdDogUlYtTGlzdDog
RjYwMiBRdWVzdGlvbg0KCQ0KCS0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiTWlrZSBO
ZWxsaXMiIDxtaWtlQGJtbmVsbGlzLmNvbT4NCgkNCglDYW4gc29tZW9uZSBwb2ludCBtZSBpbiB0
aGUgZGlyZWN0aW9uIHRvIHRoZSBsb2NhdGlvbiAoaW4gdGhlDQpwbGFucykgd2hlcmUgaXQgY2Fs
bHMgb3V0IHRoZSByaXZldCB0eXBlIHdoZW4gYXR0YWNoaW5nIHRoZSBGNjAyIHRvIHRoZQ0KdG9w
IGxvbmdlcm9uLg0KCQ0KCU1pa2UgTmVsbGlzICBodHRwOi8vd3d3LmJtbmVsbGlzLmNvbQ0KCUF1
c3RpbiwgVFgNCglTdGluc29uIDEwOC0yIE45NjY2Sw0KCVJWLTYgTjY5OUJNICAoRnVzZWxhZ2Up
VGltZTogMDc6MTU6NTYgQU0gUFNUIFVTDQoJRnJvbTogIk1pa2UgTmVsbGlzIiA8bWlrZUBibW5l
bGxpcy5jb20+DQoJU3ViamVjdDogUlYtTGlzdDogRjYwMiBRdWVzdGlvbg0KCQ0KCS0tPiBSVi1M
aXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiTWlrZSBOZWxsaXMiIDxtaWtlQGJtbmVsbGlzLmNvbT4N
CgkNCglDYW4gc29tZW9uZSBwb2ludCBtZSBpbiB0aGUgZGlyZWN0aW9uIHRvIHRoZSBsb2NhdGlv
biAoaW4gdGhlDQpwbGFucykgd2hlcmUgaXQgY2FsbHMgb3V0IHRoZSByaXZldCB0eXBlIHdoZW4g
YXR0YWNoaW5nIHRoZSBGNjAyIHRvIHRoZQ0KdG9wIGxvbmdlcm9uLg0KCQ0KCU1pa2UgTmVsbGlz
ICBodHRwOi8vd3d3LmJtbmVsbGlzLmNvbQ0KCUF1c3RpbiwgVFgNCglTdGluc29uIDEwOC0yIE45
NjY2Sw0KCVJWLTYgTjY5OUJNICAoRnVzZWxhZ2UpDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJ
X19fX19fX19fX19fX19fX18NCl9fX19fX19fDQoJVGltZTogMDc6MzQ6MjcgQU0gUFNUIFVTDQoJ
RnJvbTogRmx5bG93MzhAYW9sLmNvbQ0KCVN1YmplY3Q6IFJWLUxpc3Q6IFBpbG90IGVtZXJnZW5j
eSBjaHV0ZXMgZm9yIHNhbGUNCgkNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogRmx5
bG93MzhAYW9sLmNvbQ0KCQ0KCQ0KCT4yIFBpbG90IEVtZXJnZW5jeSBDaHV0ZXMgRm9yIFNhbGUu
IFVzZWQgaW4gbXkgUlY0IGZvciA2IG1vbnRocy4NClZlcnkNCgk+Y29tcGFjdC4NCgk+ID4gQ2h1
dGUgMSBpcyBhIFJlZCAyNicgZm9vdCBNaWNybyBTb2Z0aWUgd2l0aCBRdWljayByZWxlYXNlDQpi
dWNrbGVzLiQ1NTAuMDANCglMb3dlcmVkIGZyb20gJDc1MC4wMC4gTUZHLiBKdW5lLTE5ODgsIGl0
IGlzIGEgU1RST05HIE1pZCBMaXRlDQoyNicgY2Fub3B5DQoJPlRoZSBjb250YWluZXIgaXMgYSBN
aWNybyBTb2Z0aWUgYW5kIHdhcyBNRkcuICBNYXkgMTk4OS4gSXQgd2FzDQp1c2VkIGEgZmV3DQoJ
PnRpbWVzIGluIDE5OTMgYnV0IHRoYXRzIGFib3V0IGl0IGV4Y2VwdCBmb3IgbXkgb2NjYXNpb25h
bCB1c2UNCmxhc3QgeWVhci4NCgk+DQoJPiA+IENodXRlIDIgaXMgYSBCbHVlIHdpdGggcmVkIHRy
aW0gIE5hdGlvbmFsIGJhY2twYWNrIDM2MCB3aXRoDQpzaGVlcHNraW4NCgk+cGFkZGluZy4+VGhl
IE5hdGlvbmFsIDM2MCB3YXMgTUZHLiBEZWMuIDE5ODUuIDI0JyBQaGFudG9tDQpDYW5vcHkuDQoJ
PiA+IFdBUyAkNTc1LjAwIG5vdyAkNDUwLjAwPkJvdGggY2h1dGVzIHdlcmUgcmVwYWNrZWQgbGFz
dCB5ZWFyDQphbmQgYXJlIGluDQoJZXhjZWxsZW50ID5jb25kaXRpb24uPiA+IExvY2F0ZWQgaW4g
U291dGhlcm4gQ2FsaWZvcm5pYS4gSSBQYWlkDQokMTQ1MC4wMCBmb3INCglib3RoLCBJIHdpbGwg
c2VsbCAgZm9yDQoJPiQ5NTAgZm9yIGJvdGguIEJ1eWVyIFBheXMgc2hpcHBpbmcuIExvY2F0ZWQg
aW4gU291dGhlcm4NCkNhbGlmb3JuaWEsIEkgY2FuDQoJbWVldCBwb3NzaWJseSBoYWxmIHdheSB0
byBwaWNrIHVwIGRlcGVuZGluZyBvbiBkaXN0YW5jZS4NCgk+ID4gQ29udGFjdCBXaWxsIFdoaXRl
c2lkZSA4MTgtMzU5LTExMDYgd2hpdGVzaWRlQGFvbC5jb20NCgkNCgkNCgkNCgkNCgkNCgkNCgkN
CgkNCgkNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fXw0KX19fX19fX18NCglUaW1lOiAwNzozNDoyOSBBTSBQU1Qg
VVMNCglGcm9tOiBGbHlsb3czOEBhb2wuY29tDQoJU3ViamVjdDogUlYtTGlzdDogUGlsb3QgZW1l
cmdlbmN5IGNodXRlcyBmb3Igc2FsZQ0KCQ0KCS0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5
OiBGbHlsb3czOEBhb2wuY29tDQoJDQoJDQoJPjIgUGlsb3QgRW1lcmdlbmN5IENodXRlcyBGb3Ig
U2FsZS4gVXNlZCBpbiBteSBSVjQgZm9yIDYgbW9udGhzLg0KVmVyeQ0KCT5jb21wYWN0Lg0KCT4g
PiBDaHV0ZSAxIGlzIGEgUmVkIDI2JyBmb290IE1pY3JvIFNvZnRpZSB3aXRoIFF1aWNrIHJlbGVh
c2UNCmJ1Y2tsZXMuJDU1MC4wMA0KCUxvd2VyZWQgZnJvbSAkNzUwLjAwLiBNRkcuIEp1bmUtMTk4
OCwgaXQgaXMgYSBTVFJPTkcgTWlkIExpdGUNCjI2JyBjYW5vcHkNCgk+VGhlIGNvbnRhaW5lciBp
cyBhIE1pY3JvIFNvZnRpZSBhbmQgd2FzIE1GRy4gIE1heSAxOTg5LiBJdCB3YXMNCnVzZWQgYSBm
ZXcNCgk+dGltZXMgaW4gMTk5MyBidXQgdGhhdHMgYWJvdXQgaXQgZXhjZXB0IGZvciBteSBvY2Nh
c2lvbmFsIHVzZQ0KbGFzdCB5ZWFyLg0KCT4NCgk+ID4gQ2h1dGUgMiBpcyBhIEJsdWUgd2l0aCBy
ZWQgdHJpbSAgTmF0aW9uYWwgYmFja3BhY2sgMzYwIHdpdGgNCnNoZWVwc2tpbg0KCT5wYWRkaW5n
Lj5UaGUgTmF0aW9uYWwgMzYwIHdhcyBNRkcuIERlYy4gMTk4NS4gMjQnIFBoYW50b20NCkNhbm9w
eS4NCgk+ID4gV0FTICQ1NzUuMDAgbm93ICQ0NTAuMDA+Qm90aCBjaHV0ZXMgd2VyZSByZXBhY2tl
ZCBsYXN0IHllYXINCmFuZCBhcmUgaW4NCglleGNlbGxlbnQgPmNvbmRpdGlvbi4+ID4gTG9jYXRl
ZCBpbiBTb3V0aGVybiBDYWxpZm9ybmlhLiBJIFBhaWQNCiQxNDUwLjAwIGZvcg0KCWJvdGgsIEkg
d2lsbCBzZWxsICBmb3INCgk+JDk1MCBmb3IgYm90aC4gQnV5ZXIgUGF5cyBzaGlwcGluZy4gTG9j
YXRlZCBpbiBTb3V0aGVybg0KQ2FsaWZvcm5pYSwgSSBjYW4NCgltZWV0IHBvc3NpYmx5IGhhbGYg
d2F5IHRvIHBpY2sgdXAgZGVwZW5kaW5nIG9uIGRpc3RhbmNlLg0KCT4gPiBDb250YWN0IFdpbGwg
V2hpdGVzaWRlIDgxOC0zNTktMTEwNiB3aGl0ZXNpZGVAYW9sLmNvbQ0KCQ0KCQ0KCQ0KCQ0KCQ0K
CQ0KCQ0KCQ0KCQ0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fDQpfX19fX19fXw0KCVRpbWU6IDA3OjM1OjM1IEFN
IFBTVCBVUw0KCUZyb206IEZseWxvdzM4QGFvbC5jb20NCglTdWJqZWN0OiBSVi1MaXN0OiBDaHV0
ZXMgZm9yIHNhbGUNCgkNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogRmx5bG93MzhA
YW9sLmNvbQ0KCQ0KCQ0KCT4yIFBpbG90IEVtZXJnZW5jeSBDaHV0ZXMgRm9yIFNhbGUuIFVzZWQg
aW4gbXkgUlY0IGZvciA2IG1vbnRocy4NClZlcnkNCgk+Y29tcGFjdC4NCgk+ID4gQ2h1dGUgMSBp
cyBhIFJlZCAyNicgZm9vdCBNaWNybyBTb2Z0aWUgd2l0aCBRdWljayByZWxlYXNlDQpidWNrbGVz
LiQ1NTAuMDANCglMb3dlcmVkIGZyb20gJDc1MC4wMC4gTUZHLiBKdW5lLTE5ODgsIGl0IGlzIGEg
U1RST05HIE1pZCBMaXRlDQoyNicgY2Fub3B5DQoJPlRoZSBjb250YWluZXIgaXMgYSBNaWNybyBT
b2Z0aWUgYW5kIHdhcyBNRkcuICBNYXkgMTk4OS4gSXQgd2FzDQp1c2VkIGEgZmV3DQoJPnRpbWVz
IGluIDE5OTMgYnV0IHRoYXRzIGFib3V0IGl0IGV4Y2VwdCBmb3IgbXkgb2NjYXNpb25hbCB1c2UN
Cmxhc3QgeWVhci4NCgk+DQoJPiA+IENodXRlIDIgaXMgYSBCbHVlIHdpdGggcmVkIHRyaW0gIE5h
dGlvbmFsIGJhY2twYWNrIDM2MCB3aXRoDQpzaGVlcHNraW4NCgk+cGFkZGluZy4+VGhlIE5hdGlv
bmFsIDM2MCB3YXMgTUZHLiBEZWMuIDE5ODUuIDI0JyBQaGFudG9tDQpDYW5vcHkuDQoJPiA+IFdB
UyAkNTc1LjAwIG5vdyAkNDUwLjAwPkJvdGggY2h1dGVzIHdlcmUgcmVwYWNrZWQgbGFzdCB5ZWFy
DQphbmQgYXJlIGluDQoJZXhjZWxsZW50ID5jb25kaXRpb24uPiA+IExvY2F0ZWQgaW4gU291dGhl
cm4gQ2FsaWZvcm5pYS4gSSBQYWlkDQokMTQ1MC4wMCBmb3INCglib3RoLCBJIHdpbGwgc2VsbCAg
Zm9yDQoJPiQ5NTAgZm9yIGJvdGguIEJ1eWVyIFBheXMgc2hpcHBpbmcuIExvY2F0ZWQgaW4gU291
dGhlcm4NCkNhbGlmb3JuaWEsIEkgY2FuDQoJbWVldCBwb3NzaWJseSBoYWxmIHdheSB0byBwaWNr
IHVwIGRlcGVuZGluZyBvbiBkaXN0YW5jZS4NCgk+ID4gQ29udGFjdCBXaWxsIFdoaXRlc2lkZSA4
MTgtMzU5LTExMDYgd2hpdGVzaWRlQGFvbC5jb20NCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkN
Cl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fXw0KX19fX19fX18NCglUaW1lOiAwODoyMDoyMSBBTSBQU1QgVVMNCglG
cm9tOiBrZW1wdGhvcm5lcyA8a2VtcHRob3JuZXNAZWFydGhsaW5rLm5ldD4NCglTdWJqZWN0OiBS
b3N0ZWQgYnk6IGtlbXB0aG9ybmVzDQo8a2VtcHRob3JuZXNAZWFydGhsaW5rLm5ldD4NCgkNCglB
dCAwMzo0MyBQTSA5LzE4LzIwMDIgLTA0MDAsIHlvdSB3cm90ZToNCgk+LS0+IFJWLUxpc3QgbWVz
c2FnZSBwb3N0ZWQgYnk6ICJCb3lkIEMuIEJyYWVtIg0KPGJjYnJhZW1AY29tY2FzdC5uZXQ+DQoJ
Pg0KCT5Gb3Igc2VyaW91cyB3ZWF0aGVyIGZseWluZyBvbiBhIG1vcmUgdGhhbiBvY2Nhc2lvbmFs
IGJhc2lzIEkNCndvdWxkIHdhbnQgYW4NCgk+YXV0byBwaWxvdCB3aXRoIGFsdGl0dWRlIHNlbnNp
bmcgYW5kIGEgeWF3IGRhbXBlciAoVHJ1VHJhYydzDQpERkMgMzAwLCBmb3INCgk+ZXhhbXBsZSwg
YW5kIG9ubHkgJDExLDAwMCkuDQoJDQoJT3IganVzdCBsZWF2ZSB0aGUgUlYgaW4gdGhlIGhhbmdh
ciBhbmQgdGFrZSB0aGUgS2luZyBBaXIuDQoJDQoJaGFsDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJ
DQoJDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX18NCl9fX19fX19fDQoJVGltZTogMDk6MzM6MzkgQU0gUFNUIFVT
DQoJU3ViamVjdDogUkU6IFJWLUxpc3Q6IFdpbmcgS2l0IEZvciBTYWxlDQoJRnJvbTogIldpbGxp
YW0gQWxsZW4gKFZvbHQpIiA8YS13YWxsZW5AbWljcm9zb2Z0LmNvbT4NCgkNCgktLT4gUlYtTGlz
dCBtZXNzYWdlIHBvc3RlZCBieTogIldpbGxpYW0gQWxsZW4gKFZvbHQpIg0KPGEtd2FsbGVuQG1p
Y3Jvc29mdC5jb20+DQoJDQoJSSB3b3VsZCBiZSBpbnRlcmVzdGVkIGluIHRoZSBwaWMncy4gIElz
IHRoaXMgeW91ciBmaXJzdCBwcm9qZWN0DQpvciBoYXZlDQoJeW91IGJ1aWx0IGJlZm9yZT8gIEhv
dyBsb25nIGFnbyBkaWQgeW91IHB1cmNoYXNlIHRoaXMgd2luZyBhbmQNCmhvdyBsb25nDQoJaGF2
ZSB5b3UgYmVlbiB3b3JraW5nIG9uIGl0PyAgSSBhc3N1bWUgdGhhdCBhbGwgdGhlIFJWOCB3aW5n
cw0KYXJlIG1hdGNoDQoJaG9sZWQuLi5hbSBJIGNvcnJlY3Q/DQoJDQoJVGhhbmtzLA0KCQ0KCS1X
aWxsDQoJDQoJLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0NCglGcm9tOiBTcGVlZHkxMUBhb2wu
Y29tIFttYWlsdG86U3BlZWR5MTFAYW9sLmNvbV0NCglTdWJqZWN0OiBSVi1MaXN0OiBXaW5nIEtp
dCBGb3IgU2FsZQ0KCQ0KCS0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBTcGVlZHkxMUBh
b2wuY29tDQoJDQoJSSBoYXZlIGEgUlYtOC84QSB3aW5nIGtpdCBmb3Igc2FsZS4gIEl0IGlzIHBh
cnRpYWxseSBmaW5pc2hlZA0Kd2l0aA0KCXN1cGVyYg0KCXdvcmttYW5zaGlwIGFuZCBoYXMgYSBw
aGxvbmdzdG9uIHNwYXIuICBJIGJvdWdodCBhbm90aGVyIGd1eXMNCnByb2plY3QgaW4NCgkNCglv
cmRlciB0byBnZXQgaGlzIGVtcGVubmFnZSBhbmQgSSBkb24ndCBuZWVkIHRoZSB3aW5nIGtpdCBz
aW5jZSBJDQpoYXZlIGENCglRQg0KCWtpdC4gIEkgY2FuIHNlbmQgZGlnaXRhbCBwaG90b3MuICBJ
IHdpbGwgaW5zdXJlIGFsbCBwYXJ0cyBhcmUNCmluY2x1ZGVkLg0KCQ0KCVZhbidzIGN1cnJlbnQg
cHJpY2UgaXMgJDUxNTUgKyBzaGlwcGluZy4gIEkgd2lsbCBzZWxsIGZvciAkMjkwMA0KKw0KCXNo
aXBwaW5nLiANCglJIHdpbGwgYnVpbGQgYSBjcmF0ZSB0byBzaGlwIGl0IGlmIHlvdSBwYXkgZm9y
IHRoZSBtYXRlcmlhbHMgdG8NCmJ1aWxkDQoJaXQuIA0KCUxvY2F0ZWQgaW4gVGFtcGEsIEZMLiAg
ODEzLTMxOC05MDc0DQoJDQoJDQoJPQ0KCT0NCgk9DQoJPQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0K
CQ0KCQ0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fDQpfX19fX19fXw0KCVRpbWU6IDExOjI4OjUyIEFNIFBTVCBV
Uw0KCUZyb206ICJKb2huIEhlbG1zIiA8amhlbG1zQGkxLm5ldD4NCglTdWJqZWN0OiBSVi1MaXN0
OiBMb29raW5nIGZvciBTdGV2ZSBCcm93bg0KCQ0KCS0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVk
IGJ5OiAiSm9obiBIZWxtcyIgPGpoZWxtc0BpMS5uZXQ+DQoJDQoJb2YgKG9yIGZvcm1lcmx5IG9m
KSBNb250cm9zZSwgTU4NCgkNCglSVi04IGJ1aWxkZXIuDQoJDQoJSGlzIGluc3VyYW5jZSBwb2xp
Y3kgaXMgZXhwaXJpbmcgdGhpcyB3ZWVrZW5kIGFuZCBhbGwgbXkgbnVtYmVycw0KZm9yIGhpbSBh
cmUgYmFkLg0KCQ0KCVN0ZXZlLCBpZiB5b3UncmUgb3V0IHRoZXJlIHBsZWFzZSBjb250YWN0IG1l
IGFzYXAgYXQgODc3IDQ3NQ0KNTg2MC4NCgkNCglEbyBub3QgYXJjaGl2ZQ0KCQ0KCUpvaG4gIkpU
IiBIZWxtcw0KCUJyYW5jaCBNYW5hZ2VyDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQpfX19f
X19fX19fX19fX18NCl9fX19fX19fDQoJVGltZTogMTI6MTY6MjIgUE0gUFNUIFVTDQoJU3ViamVj
dDogUlYtTGlzdDogTG9va2luZyBmb3IgU2VhdHRsZSBhcmVhIFJWOCBidWlsZGVyL2ZseWVycw0K
CUZyb206ICJXaWxsaWFtIEFsbGVuIChWb2x0KSIgPGEtd2FsbGVuQG1pY3Jvc29mdC5jb20+DQoJ
DQoJLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJXaWxsaWFtIEFsbGVuIChWb2x0KSIN
CjxhLXdhbGxlbkBtaWNyb3NvZnQuY29tPg0KCQ0KCVNvcnJ5IGZvciB0aGUgcG9zdCB0byB0aG9z
ZSB3aG8gZG9uJ3QgbGl2ZSBpbiB0aGUgU2VhdHRsZSBhcmVhLg0KCQ0KCQ0KCUknbSBsb29raW5n
IGF0IGJ1aWxkaW5nIGFuIFJWOCBhbmQgd291bGQgbG92ZSB0byBtZWV0IHNvbWUNCnBlb3BsZSBp
biBteQ0KCWxvY2FsIGFyZWEgd2hvIGFyZSBmbHlpbmcgUlY4J3MgYW5kIHdvdWxkbid0IG1pbmQg
c2hvd2luZyBtZQ0KdGhlaXIgcGxhbmUNCglhcyB3ZWxsIGFzIGFuc3dlciBzb21lIG9mIG15IHF1
ZXN0aW9ucyByZWdhcmRpbmcgdGhpcyB0YXNrIEknbQ0KYWJvdXQgdG8NCgl0YWtlIG9uLiBJIGxp
dmUgaW4gTm9ydGggQmVuZCBhbmQgY3VycmVudGx5IGZseSBvdXQgb2YgS1JOVC4gSSdtDQpkb3du
DQoJdGhlcmUgcXVpdGUgYSBiaXQgbGF0ZWx5IHdvcmtpbmcgb24gbW9yZSByYXRpbmdzLCBsaWNl
bnNlJ3MgYW5kDQp3aGF0DQoJZXZlciBlbHNlIEkgY2FuIGZvb2wgdGhlbSBpbnRvIGdpdmluZyBt
ZSA7LSkgSSdtIGVzcGVjaWFsbHkNCmludGVyZXN0ZWQNCglpbiBhbnkgb25lIHdobyBpcyB1c2lu
ZyB0aGVpciBwbGFuZSBmb3IgQWVyb2JhdGljcyBhbmQvb3IgSUZSLA0KYW5kIEkNCglkb24ndCBt
ZWFuIGF0IHRoZSBzYW1lIHRpbWUgOi0pISAgQW55b25lIHdobyB3aWxsIHRhbGsgdG8gbWUNCnJl
cGx5DQoJZGlyZWN0bHkgdG8gbWUuDQoJDQoJDQoJVGhhbmtzIQ0KCQ0KCQ0KCS1XaWxsIEFsbGVu
VGltZTogMTI6MjQ6NTAgUE0gUFNUIFVTDQoJRnJvbTogIkJyaWFuIERlbmsiIDxha3JvZ3V5QGhv
dG1haWwuY29tPg0KCVN1YmplY3Q6IFJWLUxpc3Q6IEZ3ZDogZmxpZ2h0IGluc3RydWN0aW9uIGlu
IGEgUlYNCgkNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIkJyaWFuIERlbmsiDQo8
YWtyb2d1eUBob3RtYWlsLmNvbT4NCgkNCglUaGlzIHdhcyBzZW50IHRvIG1lIGRpcmVjdGx5LCBi
dXQgSSB0aGluayBoZSBtZWFudCB0byBwb3N0IGl0DQp2aWEgYSBsYXJnZXINCglmb3J1bS4NCgkN
CglCcmlhbiBEZW5rDQoJUlY4IE45NEJEDQoJDQoJDQoJPkZyb206IGRhcmlvIGwgdG9mZmVuZXR0
aSA8ZGFyZ2ludG9mZkBqdW5vLmNvbT4NCgk+VG86IGFrcm9ndXlAaG90bWFpbC5jb20NCgk+U3Vi
amVjdDogZmxpZ2h0IGluc3RydWN0aW9uIGluIGEgUlYNCgk+RGF0ZTogV2VkLCAxOCBTZXAgMjAw
MiAyMzoyODoyOSAtMDYwMA0KCT4NCgk+SG93ZHkhIUFtIG9uZSBvZiB0aGUgaGFwcHkgYnVpbGRl
cnMgb2YgUlZzIGluIHRoZSBFbCBQYXNvDQpyZWdpb24gYW4NCgk+c2V2ZXJhbCBoYXZlIHRha2Ug
bGlrZSB0aGV5IHdvdWxkIGxpa2Ugc29tZSB0aW1lIGluIGFuIFJWDQpiZWZvcmUgdGhleQ0KCT50
YWtlIHRoZXJlIG93biB1cCBmb3IgYSBmaXJzdCB0aW1lLiBOb3cgdGhhdCB0aGUgbGF3IGhhcw0K
Y2hhbmdlZCB3aGVyZQ0KCT5vbmUgY2FuIGluc3RydWN0IGluIGFuIGV4cGVyaW1lbnRhbCBsaWtl
IGFpcmNyYWZ0IHdlIHdvbmRlciBpZg0KaXQgY291bGQNCgk+YmUgbGV0IGtub3duIHRoYXQgdGhl
cmUgYSBzb21lIGluIHRoaXMgYXJlYSB3aG8gd291bGQgbGlrZSB0bw0KcGFydGFrZSBpbg0KCT5h
IGZldyBob3VycyBldGMgZXRjIGV0Yy4gUGVyaGFwcyB0aG91Z2ggeW91ciBlZmZvcnRzIHlvdSBj
b3VsZA0KcHVibGlzaA0KCT5zYW1lLi5BcHByZWNpYXRlIHlvdXIgZWZmb3J0cyx3ZSB3aWxsIGJl
IGRyaXZpbmcgaW4gZnJvbSBFbA0KUGFzbyxob3BlIGluDQoJPmFub3RoZXIgc2l4IG1vbnRocyBJ
IGNvdWxkIGJlIGFibGUgIHRvIGZseSB1cC4uSW0gYSBWb2x1bnRlZXINCmF0IHRoZSBXYXINCgk+
RWFnbGUgQWlyIE11c2V1bSx3ZSB3aWxsIGJlIHJlYWR5IGZvciB5b3UgYW5kIHRoYW5rcyBmb3Ig
dGhlDQpwbHVnLiBEYXJpbw0KCT5Ub2ZmZW5ldHRpIFJWIDdBLiBBbnkgaW5zdHVjdG9yIGluIHRo
ZSBhcmVhLS1FYXN0IG9yIFdlc3QgY291bGQNCmNvbnRhY3QNCgk+bWUtIEkgd2lsbCBwYXNzIHRo
ZSB3b3JkIGFsb25nLi4NCgk+RGFyZ2ludG9mZkBKdW5vLmNvbQ0KCQ0KCQ0KCQ0KaHR0cDovL3d3
dy5nZW9jaXRpZXMuY29tL0NhcGVDYW5hdmVyYWwvSGFuZ2FyLzk2NTYvYWtyb3Nob21lcGFnZS5o
dG0NCgkNCgkNCglodHRwOi8vd3d3LmhvdG1haWwuY29tDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJ
X19fX19fX19fX19fX19fX19fX18NCl9fX19fX19fDQoJVGltZTogMDE6MDA6MDAgUE0gUFNUIFVT
DQoJRnJvbTogTWFyayBQaGlsbGlwcyA8cmlwc3RlZWxAZWRnZS5uZXQ+DQoJU3ViamVjdDogUlYt
TGlzdDogV29vZCBQcm9wcw0KCQ0KCS0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBNYXJr
IFBoaWxsaXBzIDxyaXBzdGVlbEBlZGdlLm5ldD4NCgkNCglIb3dkeSBMaXN0LQ0KCQ0KCUhhdmUg
YmVlbiBwcm9wLXNob3BwaW5nIGFuZCBhbSBsb29raW5nIGZvciBmb3RvcyAob3IgbGlua3MgdG8N
CmZvdG9zKSBvZg0KCUNhdHRvLCBTdGVyYmEsIFdhcmtlLCBBeW1hciwgUHJvcHMgSW5jLiwgV2Fs
a2VyIG9yIGFueW9uZSBlbHNlDQp5b3UgZm9sa3MNCgltaWdodCByZWNvbW1lbmQuICAgVGhleSBh
bGwgbWFrZSBncmVhdCBwcm9wcyAoanVzdCBhc2sgdGhlbSEpDQphbmQgYWxsDQoJcGVyZm9ybSAi
YXJvdW5kIFZhbnMgIydzIChqdXN0IGFzayB0aGVtISkgc28gaXQgYWxtb3N0IGJvaWxzDQpkb3du
IHRvIGhvdw0KCWNvb2wgdGhleSBsb29rIHBhcmtlZCBvbiB0aGUgbm9zZS4gIElmIHlvdSd2ZSBn
b3QgcGljdHVyZXMgb3INCmxpbmtzDQoJc2hvd2luZyB0aGVzZSBwcm9wcyBmb3IgKG9yIGluc3Rh
bGxlZCBvbikgYW4gTy0zMjAgUlYsIHBsZWFzZQ0Kc2VuZCB0aGVtDQoJdG8gbWUgb2ZmLWxpc3Qu
DQoJDQoJVGhhbmtzIGZyb20gdGhlIFBvc3N1bVdvcmtzDQoJTWFyayAgLSAgY2Fub3B5IGFsbW9z
dCBkb25lLSBuZWVkIHRvIGdldCBmb3J3YXJkIG9mIHRoZQ0KZmlyZXdhbGwhICAtIGRvDQoJbm90
IGFyY2hpdmUNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCl9fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KX19f
X19fX18NCglUaW1lOiAwMToyNzoyOCBQTSBQU1QgVVMNCglGcm9tOiBERmFpbGVAYW9sLmNvbQ0K
CVN1YmplY3Q6IFJWLUxpc3Q6IFN0aWNrIEdyaXAgV2lyaW5nDQoJDQoJLS0+IFJWLUxpc3QgbWVz
c2FnZSBwb3N0ZWQgYnk6IERGYWlsZUBhb2wuY29tDQoJDQoJSSdtIGxvb2tpbmcgZm9yIHNvbWUg
d2F5cyBhbmQgc3VnZ2VzdGlvbnMgb24gZ2V0dGluZyB0aGUgc3RpY2sNCmdyaXAgd2lyZXMgb3V0
DQoJb2YgdGhlIGNvbnRyb2wgc3RpY2tzIG9uIG15IFJWNi4gSSBoYXZlbid0IGZvdW5kIG11Y2gN
CmluZm9ybWF0aW9uIGluIHRoZQ0KCWFyY2hpdmVzLg0KCQ0KCVdoYXQgaGF2ZSBidWlsZGVycyBk
b25lIHRvIGdldCB0aGUgd2lyZXMgb3V0IG9mIHRoZSBib3R0b20vc2lkZQ0Kb2YgdGhlDQoJY29u
dHJvbCBzdGlja3M/DQoJDQoJVGhhbmsgeW91IGZvciByZXNwb25kaW5nIG9mZiBsaXN0IHRvIERG
YWlsZUBhb2wuY29tDQoJDQoJRG8gbm90IGFyY2hpdmUNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkN
CgkNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fXw0KX19fX19fX18NCglUaW1lOiAwMjoxMDoyMiBQTSBQU1QgVVMN
CglGcm9tOiAiUGF1bCBCZXNpbmciIDxhenBpbG90QGV4dHJlbWV6b25lLmNvbT4NCglTdWJqZWN0
OiBSZTogUlYtTGlzdDogU3RpY2sgR3JpcCBXaXJpbmcNCgkNCgktLT4gUlYtTGlzdCBtZXNzYWdl
IHBvc3RlZCBieTogIlBhdWwgQmVzaW5nIg0KPGF6cGlsb3RAZXh0cmVtZXpvbmUuY29tPg0KCQ0K
CURyaWxsIGEgaG9sZSBhYm92ZSB0aGUgbGlua2FnZSBhbmQgcnVuIHRoZW0gb3V0IHRocm91Z2gg
dGhlIHNpZGUNCm9mIHRoZQ0KCXN0aWNrLCBub3QgdGhlIGJvdHRvbS4gIFB1dCBhIGdyb21tZXQg
aW4gdGhlcmUgYW5kIHlvdSBhcmUgZG9uZS4NCgkNCglQYXVsIEJlc2luZw0KCVJWLTZBIFNvbGQg
KFdhaXRpbmcgb24gdGhlIFJWLTEwKQ0KCWh0dHA6Ly93d3cubGFjb2Rld29ya3MuY29tL2Jlc2lu
Zw0KCUtpdGxvZyBQcm8gQnVpbGRlcidzIExvZyBTb2Z0d2FyZQ0KCWh0dHA6Ly93d3cua2l0bG9n
LmNvbQ0KCQ0KCS0tLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLS0NCglGcm9tOiA8REZhaWxlQGFv
bC5jb20+DQoJU3ViamVjdDogUlYtTGlzdDogU3RpY2sgR3JpcCBXaXJpbmcNCgkNCgkNCgk+IC0t
PiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBERmFpbGVAYW9sLmNvbQ0KCT4NCgk+IEknbSBs
b29raW5nIGZvciBzb21lIHdheXMgYW5kIHN1Z2dlc3Rpb25zIG9uIGdldHRpbmcgdGhlIHN0aWNr
DQpncmlwIHdpcmVzDQoJb3V0DQoJPiBvZiB0aGUgY29udHJvbCBzdGlja3Mgb24gbXkgUlY2LiBJ
IGhhdmVuJ3QgZm91bmQgbXVjaA0KaW5mb3JtYXRpb24gaW4gdGhlDQoJPiBhcmNoaXZlcy4NCgk+
DQoJPiBXaGF0IGhhdmUgYnVpbGRlcnMgZG9uZSB0byBnZXQgdGhlIHdpcmVzIG91dCBvZiB0aGUN
CmJvdHRvbS9zaWRlIG9mIHRoZQ0KCT4gY29udHJvbCBzdGlja3M/DQoJPg0KCT4gVGhhbmsgeW91
IGZvciByZXNwb25kaW5nIG9mZiBsaXN0IHRvIERGYWlsZUBhb2wuY29tDQoJPg0KCT4gRG8gbm90
IGFyY2hpdmUNCgk+DQoJPg0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KX19fX19fX19fX19f
X19fDQpfX19fX19fXw0KCVRpbWU6IDAzOjQ0OjI0IFBNIFBTVCBVUw0KCUZyb206IEtldmluIEhv
cnRvbiA8a2hvcnRvMTUzN0Byb2dlcnMuY29tPg0KCVN1YmplY3Q6IFJFOiBSVi1MaXN0OiBXaW5n
IEtpdCBGb3IgU2FsZQ0KCQ0KCS0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBLZXZpbiBI
b3J0b24NCjxraG9ydG8xNTM3QHJvZ2Vycy5jb20+DQoJDQoJPi0tPiBSVi1MaXN0IG1lc3NhZ2Ug
cG9zdGVkIGJ5OiAiV2lsbGlhbSBBbGxlbiAoVm9sdCkiDQo8YS13YWxsZW5AbWljcm9zb2Z0LmNv
bT4NCgk+DQoJPkkgd291bGQgYmUgaW50ZXJlc3RlZCBpbiB0aGUgcGljJ3MuICBJcyB0aGlzIHlv
dXIgZmlyc3QgcHJvamVjdA0Kb3IgaGF2ZQ0KCT55b3UgYnVpbHQgYmVmb3JlPyAgSG93IGxvbmcg
YWdvIGRpZCB5b3UgcHVyY2hhc2UgdGhpcyB3aW5nIGFuZA0KaG93IGxvbmcNCgk+aGF2ZSB5b3Ug
YmVlbiB3b3JraW5nIG9uIGl0PyAgSSBhc3N1bWUgdGhhdCBhbGwgdGhlIFJWOCB3aW5ncw0KYXJl
IG1hdGNoDQoJPmhvbGVkLi4uYW0gSSBjb3JyZWN0Pw0KCT4NCgk+VGhhbmtzLA0KCT4NCgk+LVdp
bGwNCgk+DQoJDQoJVGhlIFJWLTggd2luZyBraXRzIG9ubHkgYmVjYW1lIG1hdGNoIGhvbGVkIHJl
Y2VudGx5LiAgVGhlDQpvcmlnaW5hbA0KCWtpdHMgaGFkIHByZXB1bmNoZWQgc2tpbnMsIGJ1dCBt
b3N0IG9mIHRoZSB1bmRlcmx5aW5nIHN0cnVjdHVyZQ0KaGFkDQoJdG8gYmUgZHJpbGxlZCB0byBm
aXQgdGhlIHNraW5zLg0KCS0tDQoJS2V2aW4gSG9ydG9uICAgICAgICAgUlYtOCAoc3Bpbm5lciwg
Y293bGluZykNCglPdHRhd2EsIENhbmFkYQ0KCWh0dHA6Ly9tZW1iZXJzLnJvZ2Vycy5jb20va2hv
cnRvbi9ydjguaHRtbA0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KX19fX19fX19fX19fX19f
DQpfX19fX19fXw0KCVRpbWU6IDAzOjQ3OjU2IFBNIFBTVCBVUw0KCVN1YmplY3Q6IFJWLUxpc3Q6
IExvb2tpbmcgZm9yIFNlYXR0bGUgYXJlYSBSVjggYnVpbGRlci9mbHllcnMNCglGcm9tOiAiV2ls
bGlhbSBBbGxlbiAoVm9sdCkiIDxhLXdhbGxlbkBtaWNyb3NvZnQuY29tPg0KCQ0KCS0tPiBSVi1M
aXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiV2lsbGlhbSBBbGxlbiAoVm9sdCkiDQo8YS13YWxsZW5A
bWljcm9zb2Z0LmNvbT4NCgkNCglTb3JyeSBmb3IgdGhlIHBvc3QgdG8gdGhvc2Ugd2hvIGRvbid0
IGxpdmUgaW4gdGhlIFNlYXR0bGUgYXJlYS4NCgkNCgkNCglJJ20gbG9va2luZyBhdCBidWlsZGlu
ZyBhbiBSVjggYW5kIHdvdWxkIGxvdmUgdG8gbWVldCBzb21lDQpwZW9wbGUgaW4gbXkNCglsb2Nh
bCBhcmVhIHdobyBhcmUgZmx5aW5nIFJWOCdzIGFuZCB3b3VsZG4ndCBtaW5kIHNob3dpbmcgbWUN
CnRoZWlyIHBsYW5lDQoJYXMgd2VsbCBhcyBhbnN3ZXIgc29tZSBvZiBteSBxdWVzdGlvbnMgcmVn
YXJkaW5nIHRoaXMgdGFzayBJJ20NCmFib3V0IHRvDQoJdGFrZSBvbi4gSSBsaXZlIGluIE5vcnRo
IEJlbmQgYW5kIGN1cnJlbnRseSBmbHkgb3V0IG9mIEtSTlQuIEknbQ0KZG93bg0KCXRoZXJlIHF1
aXRlIGEgYml0IGxhdGVseSB3b3JraW5nIG9uIG1vcmUgcmF0aW5ncywgbGljZW5zZSdzIGFuZA0K
d2hhdA0KCWV2ZXIgZWxzZSBJIGNhbiBmb29sIHRoZW0gaW50byBnaXZpbmcgbWUgOy0pIEknbSBl
c3BlY2lhbGx5DQppbnRlcmVzdGVkDQoJaW4gYW55IG9uZSB3aG8gaXMgdXNpbmcgdGhlaXIgcGxh
bmUgZm9yIEFlcm9iYXRpY3MgYW5kL29yIElGUiwNCmFuZCBJDQoJZG9uJ3QgbWVhbiBhdCB0aGUg
c2FtZSB0aW1lIDotKSEgIEFueW9uZSB3aG8gd2lsbCB0YWxrIHRvIG1lDQpyZXBseQ0KCWRpcmVj
dGx5IHRvIG1lLg0KCQ0KCQ0KCVRoYW5rcyENCgkNCgkNCgktV2lsbCBBbGxlbg0KCQ0KCQ0KCQ0K
CQ0KCQ0KCQ0KCQ0KCQ0KCQ0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQpfX19fX19fXw0KCVRpbWU6IDA0OjQ4
OjM0IFBNIFBTVCBVUw0KCUZyb206IEdSRU5JRVJAYW9sLmNvbQ0KCVN1YmplY3Q6IFJlOiBSVi1M
aXN0OiBGaXJzdCBGbGlnaHQgUHJlcGFyYXRpb24NCgkNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBv
c3RlZCBieTogR1JFTklFUkBhb2wuY29tDQoJDQoJTWlrZSBJIGp1c3QgZmxldyBteSBSVi00IGZv
ciB0aGUgZmlyc3QgdGltZSBsYXN0IEZyaWRheS4gIEl0IHdhcw0KYSBmYW50YXN0aWMNCglleHBl
cmllbmNlIGFuZCBJIGZvdW5kIHRoZSBwbGFuZSBhIGpveSB0byBmbHkgYWZ0ZXIgSSBnb3Qgb3Zl
cg0KdGhlIGluaXRpYWwNCglzaG9jayBvZiB0aGUgdGFrZW9mZiAtLSBpdCBtb3ZlcyBvdXQgdmVy
eSBicmlza2x5IGFuZCBjbGltYnMNCmxpa2UgYSBzaG90LiANCglBbGwgb3RoZXIgaW1wcmVzc2lv
bnMgYXJlIHN0aWxsIHZhZ3VlIGFuZCBldmVuIHRob3VnaCBJIGhhdmUgYQ0KY291cGxlIG9mIG1v
cmUNCglmbGlnaHRzIHNpbmNlLCBJIHN0aWxsIGNhbnQgZ2V0IHBhc3QgdGhlIGZ1biBwYXJ0LiAg
SSBmbGV3IGFuDQpob3VyIHdpdGggTWlrZQ0KCWluIE9zd2VnbyBhdCB0aGUgZmx5LWluIGFuZCB0
aGF0IHdhcyB2ZXJ5IGhlbHBmdWwuICBJIGhhZCBhbHNvDQpwdXQgaW4gYSBmZXcNCglob3VycyBp
biBhIERlY2F0aGxvbiB0byBicnVzaCB1cCB0YWlsIHdoZWVsIHRlY2huaXF1ZXMuIEkgaGFkDQpj
YXJlZnVsbHkNCglwbGFuZWQgdGhlIGZpcnN0IGZsaWdodCwgYnV0IG9uY2UgSSBnb3QgaW4gdGhl
IGFpciBhbGwgSSBjb3VsZA0KZG8gaXMgZ3JpbiBhbmQNCgllbmpveSB0aGUgZXhwZXJpZW5jZS4g
IEkgZmxldyBmb3IgaGFsZiBhbiBob3VyLCBjb3ZlcmVkIG1vcmUNCmdyb3VuZCB0aGFuIEkNCgl3
b3VsZCBoYXZlIGJlbGlldmVkIHBvc3NpYmxlLCBzZXQgdXAgZm9yIGEgdmVyeSBwcmVjaXNlIHBh
dHRlcm4NCmFuZA0KCWRpc2NvdmVyZWQgdGhhdCB0aGUgUlYgbGFuZHMgYmV0dGVyIHRoYXQgYW55
IHRhaWwgd2hlZWwgYWlycGxhbmUNCkkgaGF2ZSBldmVyDQoJZmxvd24uICBHb29kIGx1Y2ssIGFu
ZCBlbmpveS4NCgkNCglSYXkgR3Jlbmllcg0KCU4yMFJHDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJ
X19fX19fX19fX19fX19fX19fX18NCl9fX19fX19fDQoJVGltZTogMDQ6NDk6MzMgUE0gUFNUIFVT
DQoJRnJvbTogRG91ZyBSaXR0ZXIgPGQuZC5yaXR0ZXJAdmVyaXpvbi5uZXQ+DQoJU3ViamVjdDog
UlYtTGlzdDogUmU6IFJWOC1MaXN0OiBXaW5nIEtpdCBGb3IgU2FsZQ0KCQ0KCS0tPiBSVi1MaXN0
IG1lc3NhZ2UgcG9zdGVkIGJ5OiBEb3VnIFJpdHRlcg0KPGQuZC5yaXR0ZXJAdmVyaXpvbi5uZXQ+
DQoJDQoJVmVyeSBpbnRlcmVzdGVkLiAgSG93IG9sZCAod2hlbiBib3VnaHQpIGFuZCBwbGVhc2Ug
c2VuZCBwaWNzLg0KCQ0KCURvdWcgUml0dGVyDQoJZC5kLnJpdHRlckB2ZXJpem9uLm5ldA0KCQ0K
CQ0KCUF0IDAzOjAyIEFNIDkvMTkvMDIgLTA0MDAsIHlvdSB3cm90ZToNCgk+LS0+IFJWOC1MaXN0
IG1lc3NhZ2UgcG9zdGVkIGJ5OiBTcGVlZHkxMUBhb2wuY29tDQoJPg0KCT5JIGhhdmUgYSBSVi04
LzhBIHdpbmcga2l0IGZvciBzYWxlLiAgSXQgaXMgcGFydGlhbGx5IGZpbmlzaGVkDQp3aXRoIHN1
cGVyYg0KCT53b3JrbWFuc2hpcCBhbmQgaGFzIGEgcGhsb25nc3RvbiBzcGFyLiAgSSBib3VnaHQg
YW5vdGhlciBndXlzDQpwcm9qZWN0IGluDQoJPm9yZGVyIHRvIGdldCBoaXMgZW1wZW5uYWdlIGFu
ZCBJIGRvbid0IG5lZWQgdGhlIHdpbmcga2l0IHNpbmNlDQpJIGhhdmUgYSBRQg0KCT5raXQuICBJ
IGNhbiBzZW5kIGRpZ2l0YWwgcGhvdG9zLiAgSSB3aWxsIGluc3VyZSBhbGwgcGFydHMgYXJlDQpp
bmNsdWRlZC4NCgk+VmFuJ3MgY3VycmVudCBwcmljZSBpcyAkNTE1NSArIHNoaXBwaW5nLiAgSSB3
aWxsIHNlbGwgZm9yICQyOTAwDQorIHNoaXBwaW5nLg0KCT5JIHdpbGwgYnVpbGQgYSBjcmF0ZSB0
byBzaGlwIGl0IGlmIHlvdSBwYXkgZm9yIHRoZSBtYXRlcmlhbHMgdG8NCmJ1aWxkIGl0Lg0KCT5M
b2NhdGVkIGluIFRhbXBhLCBGTC4gIDgxMy0zMTgtOTA3NA0KCT4NCgk+DQoJDQoJDQoJDQoJDQoJ
DQoJDQoJDQoJDQoJDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX18NCl9fX19fX19fDQoJVGltZTogMDU6MTg6MjAg
UE0gUFNUIFVTDQoJRnJvbTogZ2xlbiBqIG1hdGVqY2VrIDxhZXJvYnViYmFAY29tcHVzZXJ2ZS5j
b20+DQoJU3ViamVjdDogUlYtTGlzdDogUlYtOCdzIGFyb3VuZCBBVEwNCgkNCgktLT4gUlYtTGlz
dCBtZXNzYWdlIHBvc3RlZCBieTogZ2xlbiBqIG1hdGVqY2VrDQo8YWVyb2J1YmJhQGNvbXB1c2Vy
dmUuY29tPg0KCQ0KCQ0KCS0tLS0tLS0tLS0tLS1Gb3J3YXJkZWQgTWVzc2FnZS0tLS0tLS0tLS0t
LS0tLS0tDQoJDQoJRnJvbTogICBnbGVuIGogbWF0ZWpjZWssIDExMDYxMCwzMzA1DQoJICAgICAg
IA0KCQ0KCVJFOiAgICAgUlYtOCdzIGFyb3VuZCBBVEwNCgkNCglIaSBBbGwtDQoJDQoJUmVjZW50
IGV2ZW50cyBoYXZlIGNhdXNlZCBtZSB0byBuZWVkIHRvIHVuc3Vic2NyaWJlIChhbmQgc3RvcA0K
d29yayBvbiBteQ0KCS04KSBmb3IgYWJvdXQgdGhlIG5leHQgMiBtb250aHMuICBUaGV5IGFsc28g
YXJlIGNhdXNpbmcgbWUgdG8gYmUNCmluIHRoZSBBVEwNCglhcmVhIGZyb20gdGhlIGxhc3Qgd2Vl
ayBvZiBTZXAgdGhyb3VnaCB0aGUgZmlyc3Qgd2VlayBvZiBOb3YuDQpJdCB3aWxsIGJlIGENCgl2
ZXJ5IGJ1c3kgdGltZSBmb3IgbWUsIGJ1dCBJJ2QgbG92ZSB0byBzZWUgc29tZSBhcmVhIHByb2pl
Y3RzIGlmDQp0aGUNCglwbGFuZXRzIHNob3VsZCBoYXBwZW4gdG8gYWxpZ24gcHJvcGVybHkuLi4g
SWYgYW55b25lIGFibGUgdG8NCmxpbmsgdXAsDQoJcGxlYXNlIGNvbnRhY3QgbWUgb2ZmIGxpc3Qu
DQoJDQoJVGhhbmtzIGluIGFkdmFuY2UgZm9yIHlvdXIgdGltZSBhbmQgY29uc2lkZXJhdGlvbiEN
CgkNCglHbGVuDQoJcnYtOCBpbiBJbmR5LCBhZnQgc3BhciBhdHRhY2ggZHJpbGxlZCAoUGhldyEp
VGltZTogMDY6MTg6MzQgUE0gUFNUIFVTDQoJRnJvbTogYmFycnkgcG90ZSA8YmFycnlwb3RlQGNv
bWNhc3QubmV0Pg0KCVN1YmplY3Q6IFJWLUxpc3Q6IHggbiBudW1iZXIgdXBkYXRlIHJlcXVlc3Rl
ZA0KCSAgIFJWLUxpc3QgRGlnZXN0IExpc3QgPHJ2LWxpc3QtZGlnZXN0QG1hdHJvbmljcy5jb20+
DQoJDQoJLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IGJhcnJ5IHBvdGUNCjxiYXJyeXBv
dGVAY29tY2FzdC5uZXQ+DQoJDQoJQSB3aGlsZSBiYWNrIGEgcG9zdGVyIHNhaWQgdGhhdCBoZSB0
aG91Z2h0IGl0IHdhcyBwb3NzaWJsZSB0bw0KZ2V0IGFuICJYIg0KCXByZWZpeCBmb3IgYW4gbiBu
dW1iZXIsIGJhc2VkIG9uIHRoZSB0aGUgZXhwZXJpbWVudGFsIGNhdGVnb3J5Lg0KCQ0KCUhhcyBh
bnlvbmUgcmVzZXJ2ZWQgb3IgYWN0dWFsbHkgcmVjZWl2ZWQgYW4gWCBudW1iZXIgZm9yIGFuIFJW
Pw0KCQ0KCUJhcnJ5IFBvdGUgUlY5YSBmaW5pc2hpbmcNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkN
X19fX19fX19fX19fX19fX19fXw0KX19fX19fX18NCglUaW1lOiAwNzoyMjozMiBQTSBQU1QgVVMN
CglGcm9tOiAiTGFycnkgQm93ZW4iIDxMYXJyeUBib3dlbmFlcm8uY29tPg0KCVN1YmplY3Q6IFJW
LUxpc3Q6IFRDIFJlYnVpbGQgUmVjb21tZW5kYXRpb25zPw0KCQ0KCS0tPiBSVi1MaXN0IG1lc3Nh
Z2UgcG9zdGVkIGJ5OiAiTGFycnkgQm93ZW4iDQo8TGFycnlAQm93ZW5BZXJvLmNvbT4NCgkNCglJ
IGhhdmUgYSB0dXJuIGNvb3JkaW5hdG9yIGluIG5lZWQgb2YgYSByZWJ1aWxkLiAgQ2FuIGFueW9u
ZQ0KcmVjb21tZW5kIGENCglzaG9wIHRvIGRvIHRoaXMuICBQcmVmZXJhYmx5IG5lYXIgTkMgb3Ig
b24gdGhlIGVhc3QgY29hc3Qgb2YgdGhlDQpVUz8NCgkNCglUaHgNCgkNCgktDQoJTGFycnkgQm93
ZW4NCglSVi04IHBhbmVsL2Z3Zg0KCUxhcnJ5QEJvd2VuQWVyby5jb20NCglodHRwOi8vQm93ZW5B
ZXJvLmNvbQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQpfX19f
X19fXw0KCVRpbWU6IDA5OjQ1OjM0IFBNIFBTVCBVUw0KCUZyb206ICJOb3JtYW4iIDxuaHVuZ2Vy
QHNwcmludC5jYT4NCglTdWJqZWN0OiBSZTogUlYtTGlzdDogQWx0ZXJuYXRlIFN0YXRpYyBTb3Vy
Y2UgVmFsdmUNCgkNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIk5vcm1hbiIgPG5o
dW5nZXJAc3ByaW50LmNhPg0KCQ0KCT4gV2h5IHdvdWxkIHRoaXMgYmUgbmVlZGVkPyAgSXNuJ3Qg
dGhlcmUgZW5vdWdoIHJlZHVuZGFuY3kgd2l0aA0KdHdvIHN0YXRpYw0KCT4gcG9ydHMsIG9uZSBv
biBlYWNoIHNpZGUgb2YgdGhlIGZ1c2U/DQoJDQoJSG93IGFib3V0IHJlZ3M/IERvZXMgYW4gSUZS
IHdhbnRhIGJlIG5lZWQgdGhpcz8gQ2FuYWRpYW5zPw0KCQ0KCU5vcm1hbiBIdW5nZXINCglSVjZB
IERlbHRhIEJDDQoJRG8gbm90IGFyY2hpdmUNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCgkNCl9f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fXw0KX19fX19fX18NCglUaW1lOiAwOTo1MjozNSBQTSBQU1QgVVMNCglGcm9t
OiAiS2FyaWUgRGFuaWVsIiA8a2FyaWVkNEBhdHRiaS5jb20+DQoJICAgIlJWLUxpc3QgRGlnZXN0
IExpc3QiIDxydi1saXN0LWRpZ2VzdEBtYXRyb25pY3MuY29tPg0KCVN1YmplY3Q6IFJlOiBSVi1M
aXN0OiB4IG4gbnVtYmVyIHVwZGF0ZSByZXF1ZXN0ZWQNCgkNCgktLT4gUlYtTGlzdCBtZXNzYWdl
IHBvc3RlZCBieTogIkthcmllIERhbmllbCINCjxrYXJpZWQ0QGF0dGJpLmNvbT4NCgkNCglUaGlz
IGlzIHdoYXQgaXMgb24gdGhlIEZBQSB3ZWIgc2l0ZSByZWdhcmRpbmcgTiBudW1iZXJzLg0KCQ0K
CVRoZSBGQUEgbm8gbG9uZ2VyIGlzc3VlcyBudW1iZXJzIGJlZ2lubmluZyB3aXRoICJOQyIsICJO
WCIsDQoiTlIiLCBvciAiTkwiLg0KCU9uIHNvbWUgb2xkZXIgYWlyY3JhZnQsIHRoZXNlIG51bWJl
cnMgbWF5IGJlIGRpc3BsYXllZCBpbg0KYWNjb3JkYW5jZSB3aXRoDQoJRkFSIDQ1LjIyDQoJDQoJ
RG9lc24ndCBzb3VuZCBsaWtlIHlvdSBjYW4gdXNlIFggYW55IGxvbmdlci4NCgktLS0tLSBPcmln
aW5hbCBNZXNzYWdlIC0tLS0tDQoJRnJvbTogImJhcnJ5IHBvdGUiIDxiYXJyeXBvdGVAY29tY2Fz
dC5uZXQ+DQoJPHJ2LWxpc3QtZGlnZXN0QG1hdHJvbmljcy5jb20+DQoJU3ViamVjdDogUlYtTGlz
dDogeCBuIG51bWJlciB1cGRhdGUgcmVxdWVzdGVkDQoJDQoJDQoJPiAtLT4gUlYtTGlzdCBtZXNz
YWdlIHBvc3RlZCBieTogYmFycnkgcG90ZQ0KPGJhcnJ5cG90ZUBjb21jYXN0Lm5ldD4NCgk+DQoJ
PiBBIHdoaWxlIGJhY2sgYSBwb3N0ZXIgc2FpZCB0aGF0IGhlIHRob3VnaHQgaXQgd2FzIHBvc3Np
YmxlIHRvDQpnZXQgYW4gIlgiDQoJPiBwcmVmaXggZm9yIGFuIG4gbnVtYmVyLCBiYXNlZCBvbiB0
aGUgdGhlIGV4cGVyaW1lbnRhbA0KY2F0ZWdvcnkuDQoJPg0KCT4gSGFzIGFueW9uZSByZXNlcnZl
ZCBvciBhY3R1YWxseSByZWNlaXZlZCBhbiBYIG51bWJlciBmb3IgYW4NClJWPw0KCT4NCgk+IEJh
cnJ5IFBvdGUgUlY5YSBmaW5pc2hpbmcNCgk+DQoJPg0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0KCQ0K
X19fX19fX19fX19fX19fX19fDQpfX19fX19fXw0KCVRpbWU6IDA5OjU2OjI4IFBNIFBTVCBVUw0K
CUZyb206IEppbSBPa2UgPHdqb2tlQHNoYXcuY2E+DQoJU3ViamVjdDogUlYtTGlzdDogUmU6IFJW
Ni1MaXN0OiBGNjAyIFF1ZXN0aW9uDQoJDQoJLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6
IEppbSBPa2UgPHdqb2tlQHNoYXcuY2E+DQoJDQoJTWlrZSwNCgkNCglJIHRoaW5rIHRoYXQgd291
bGQgYmUgb25lIG9mIFZhbidzICJ1c2UgeW91ciBpbml0aWF0aXZlIg0Kc2l0dWF0aW9ucyB0aGF0
DQoJYmVjb21lIG1vcmUgZnJlcXVlbnQgaW4gdGhlIGxhdGVyIHN0YWdlcyBvZiBjb25zdHJ1Y3Rp
b24uDQoJDQoJTG9va2luZyBhdCBteSBwcmV2aWV3IHBsYW5zICh0aGUgb25seSBvbmVzIEkga2Vl
cCBhdCBob21lKSBvbg0KZHdnIDMxLCBkZXRhaWwNCglEIGF0IG1pZHBhZ2UganVzdCBsZWZ0IG9m
IGNlbnRyZSBzaG93cyB0aGUgRjYwMiBhbmQgMy80IiBhbmdsZQ0Kam9pbiAoYnV0DQoJZG9lc24n
dCBtZW50aW9uIGEgcml2ZXQgc2l6ZSkuIERldGFpbCBGIGp1c3QgYmVzaWRlIGl0IHNob3dzIGhv
dw0KdG8gam9pbg0KCUY2MDIgdG8gdGhlIGxvd2VyIGxhcmdlIHNpemUgYW5nbGUuIFRoZSBmd2Qg
ZnVzZSBzaWRlIHZpZXcgZ2l2ZXMNCmEgaGludCBvZg0KCWhvdyB0aGUgdGFiIGF0IHRoZSB0b3Ag
b2YgdGhlIDYwMiBpcyBiZW50IC0gc2VlIHRoZSB1cHBlciBSSCBvZg0KZHdnIDI1IGZvcg0KCXRo
ZSB0YWIgc2l6ZSBhbmQgYmVuZC4NCglCdXQsIEkgdGhpbmsgeW91IGFyZSByaWdodCwgdGhlcmUg
aXMgbm8gbWVudGlvbiBvZiBob3cgdG8gZmFzdGVuDQp0aGUgRjYwMiB0bw0KCXRoZSB1cHBlciBs
b25nZXJvbi4NCgkNCglBcyBJIHJlY2FsbCwgSSB1c2VkIGFuIEFOIDQyNi00IG9mIHN1aXRhYmxl
IGxlbmd0aCBjb3VudGVyc3Vuaw0KaW50byB0aGUNCglsb25nZXJvbiB0byBnZXQgYSBmbHVzaCBz
dXJmYWNlLiBJZiB5b3UgaGF2ZSBhIHNsaWRlciB0aGUgRjYxMDUNCmFuZCBGNjExMA0KCXdpbGwg
bmVlZCB0byBmaXQgb250byB0aGUgdG9wIG9mIHRoZSBsb25nZXJvbi4gVGlwLXVwIGd1eXMgYXJl
DQpub3QgYXMNCgljcml0aWNhbCBpbiB0aGlzIGFyZWEuIERvbid0IHRoaW5rIHRoaXMgaXMgdG9v
IGNyaXRpY2FsIGEgcml2ZXQNCmFzIGxvbmcgYXMNCgl0aGUgRjYwMiBpc24ndCBmcmVlIHRvIHdv
YmJsZSBiYWNrIGFuZCBmb3J0aC4NCgkNCglHb29kIGx1Y2sgIQ0KCQ0KCUppbSBPa2UNCglSVi0z
DQoJUlYtNkEgKG9yYW5nZXBlZWxpbmcgYWthIHBhaW50aW5nIHVuZGVyd2F5ICEpDQoJDQoJDQoJ
LS0tLS0gT3JpZ2luYWwgTWVzc2FnZSAtLS0tLQ0KCUZyb206ICJNaWtlIE5lbGxpcyIgPD4NCglT
dWJqZWN0OiBSVjYtTGlzdDogRjYwMiBRdWVzdGlvbg0KCQ0KCQ0KCT4gLS0+IFJWNi1MaXN0IG1l
c3NhZ2UgcG9zdGVkIGJ5OiAiTWlrZSBOZWxsaXMiDQo8bWlrZUBibW5lbGxpcy5jb20+DQoJPg0K
CT4gQ2FuIHNvbWVvbmUgcG9pbnQgbWUgaW4gdGhlIGRpcmVjdGlvbiB0byB0aGUgbG9jYXRpb24g
KGluIHRoZQ0KcGxhbnMpIHdoZXJlDQoJaXQgY2FsbHMgb3V0IHRoZSByaXZldCB0eXBlIHdoZW4g
YXR0YWNoaW5nIHRoZSBGNjAyIHRvIHRoZSB0b3ANCmxvbmdlcm9uLg0KCT4NCgk+IE1pa2UgTmVs
bGlzICBodHRwOi8vd3d3LmJtbmVsbGlzLmNvbQ0KCT4gQXVzdGluLCBUWA0KCT4gU3RpbnNvbiAx
MDgtMiBOOTY2NksNCgk+IFJWLTYgTjY5OUJNICAoRnVzZWxhZ2UpDQoJPg0KCT4NCgkNCgkNCgkN
CgkNCgkNCgkNCgkNCgkNCgkNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f
X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KX19fX19fX18NCglUaW1lOiAxMDow
MDo0NiBQTSBQU1QgVVMNCglGcm9tOiBSb2JlcnQgTWNDYWxsdW0gPHJvYmVydC5tY2NhbGx1bTJA
c3ltcGF0aWNvLmNhPg0KCVN1YmplY3Q6IFJlOiBSVi1MaXN0OiBBbHRlcm5hdGUgU3RhdGljIFNv
dXJjZSBWYWx2ZQ0KCQ0KCS0tPiBSVi1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBSb2JlcnQgTWND
YWxsdW0NCjxyb2JlcnQubWNjYWxsdW0yQHN5bXBhdGljby5jYT4NCgkNCglOb3JtYW4gd3JvdGU6
DQoJPg0KCT4gSG93IGFib3V0IHJlZ3M/IERvZXMgYW4gSUZSIHdhbnRhIGJlIG5lZWQgdGhpcz8g
Q2FuYWRpYW5zPw0KCT4NCgk+IE5vcm1hbiBIdW5nZXINCgkNCgkNCglOb3JtYW47DQoJSSBtYXkg
YmUgaW5jb3JyZWN0LCBidXQgaXQgaXMgbXkgYmVsaWVmIHRoYXQgdGhvc2Ugb2YgdXMgaW4NCkNh
bmFkYSB3aXNoaW5nIHRvIGZseSBJRlIgbXVzdCBoYXZlIGFuDQoJYWx0ZXJuYXRlIHN0YXRpYyBz
b3VyY2UuDQoJSSBrbm93IHRoYXQgYWxsIHRoZSByZW50YWxzIEkndmUgZmxvd24gaGF2ZSB0aGVt
Lg0KCS0tDQoJQm9iIE1jQw0KCURPIE5PVCBBUkNISVZFDQoJDQoJDQoJDQoJDQoJDQoJDQoJDQoJ
X19fX19fX19fX19fX19fX19fX18NCl9fX19fX19fDQoJVGltZTogMTA6MTM6NTUgUE0gUFNUIFVT
DQoJRnJvbTogIkxhcnJ5IEJvd2VuIiA8TGFycnlAYm93ZW5hZXJvLmNvbT4NCglTdWJqZWN0OiBS
Vi1MaXN0OiBFTFQgYW50ZW5uYWU/DQoJDQoJLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6
ICJMYXJyeSBCb3dlbiINCjxMYXJyeUBCb3dlbkFlcm8uY29tPg0KCQ0KCUkgaGF2ZSBhIFBvaW50
ZXIgMzAwMCBFTFQuICBUaGUgYW50ZW5uYWUgaXMgdG9vIGxvbmcgdG8gZml0DQpiZWhpbmQgdGhl
DQoJZW1wZW5uYWdlIGZhaXJpbmcuICBDYW4gaXQgYmUgY3V0IDMiIHNob3J0ZXIgd2l0aG91dCBl
ZmZlY3RpbmcNCglwZXJmb3JtYW5jZT8NCgkNCglPcg0KCQ0KCUFueW9uZSBoYXZlIGEgc3BhcmUg
RUxUIGFudGVubmFlIHRoZXkgd2FudCB0byBzZWxsIGZyb20gdGhlIEFDSw0Kb3INCglBbWVyaS1L
aW5nIEVMVHM/ICBJIGFzc3VtZSB0aGV5IGhhdmUgYSBCTkMgY29ubmVjdG9yIHRvby4gIFRoZXkN
CnNlZW0gdG8NCgliZSBzaG9ydGVyIC8gbW9yZSBmbGV4aWJsZSBhbmQgZml0IGluIHRoZSBlbXBl
bm5hZ2UgbmljZWx5Lg0KCQ0KCVRoYW5rcywNCgkNCgktDQoJTGFycnkgQm93ZW4NCglMYXJyeUBC
b3dlbkFlcm8uY29tDQoJaHR0cDovL0Jvd2VuQWVyby5jb20NCgkNCgkNCgkNCgkNCgkNCgkNCgkN
CgkjIyMgRGlnZXN0IE1vZGUgTWVzc2FnZSBLZXkgIyMjDQoJDQoJDQoJDQoJDQoJDQoJDQpfLT09
PT09PT09PT09PT0NCj0NCglfLT0gICAgICAgICAgICAgICAgICAtIFRoZSBSVi1MaXN0IEVtYWls
IEZvcnVtIC0NCglfLT0gICBUaGlzIGZvcnVtIGlzIHNwb25zb3JlZCBlbnRpcmVseSB0aHJvdWdo
IHRoZSBDb250cmlidXRpb25zDQpvZg0KCV8tPSAgIExpc3QgbWVtYmVycy4gIFlvdSdsbCBuZXZl
ciBzZWUgYmFubmVyIGFkcyBvciBhbnkgb3RoZXINCmZvcm0NCglfLT0gICBvZiBkaXJlY3QgYWR2
ZXJ0aXNpbmcgb24gdGhlIE1hdHJvbmljcyBGb3J1bXMuDQoJDQpfLT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj0N
CglfLT0gISEgTkVXICEhDQoJXy09ICAgQnJvd3NlIExpc3Q6ICBVc2UgeW91ciB3ZWIgYnJvd3Nl
ciB0byB2aWV3IHRoZSBsYXRlc3QNCm1lc3NhZ2VzLg0KCV8tPSAgIFBob3RvIFNoYXJlOiAgU2hh
cmUgcGhvdG9zIGFuZCBmaWxlcyB3aXRoIG90aGVyIExpc3QNCm1lbWJlcnMuDQoJDQpfLT09PT09
PT09PT09PT0NCj0NCglfLT0gICBMaXN0IFJlbGF0ZWQgSW5mb3JtYXRpb24NCglfLT0gICAgICBQ
b3N0IE1lc3NhZ2U6ICBydi1saXN0QG1hdHJvbmljcy5jb20NCglfLT0gICAgICBVTi9TVUJTQ1JJ
QkU6ICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vc3Vic2NyaXB0aW9uDQoJXy09ICAgICAgUGhv
dG8gU2hhcmU6ICAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL3Bob3Rvc2hhcmUNCglfLT0gICAg
ICBCcm93c2UgTGlzdDoNCmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9icm93c2VsaXN0L3J2LWxp
c3QNCglfLT0gICAgICBTZWFyY2ggRW5naW5lOiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vc2Vh
cmNoDQoJXy09ICAgICAgQXJjaGl2ZXM6ICAgICAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Fy
Y2hpdmVzDQoJXy09ICAgICAgTGlzdCBTcGVjaWZpYzogaHR0cDovL3d3dy5tYXRyb25pY3MuY29t
L3J2LWxpc3QNCglfLT0gICAgICBPdGhlciBMaXN0czogICBodHRwOi8vd3d3Lm1hdHJvbmljcy5j
b20vZW1haWxsaXN0cw0KCV8tPSAgICAgIENvbnRyaWJ1dGlvbnM6IGh0dHA6Ly93d3cubWF0cm9u
aWNzLmNvbS9jb250cmlidXRpb24NCglfLT0gICAgICBNYXRyb25pY3M6ICAgICBodHRwOi8vd3d3
Lm1hdHJvbmljcy5jb20vDQoJDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09
PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj0NCgkNCgkNCgkNCgkNCgkNCg0K
George
Don't bother with heating it. Likely most of the GA fleet reside in
un-heated hangers. Just rotate it by hand frequently to keep the Cyl. bores
wet with oil
Peter
-----Original Message-----
Date: Wednesday, September 25, 2002 8:49 AM
>--> RV6-List message posted by: George Frost
>Hello all,
>I have an RV-6 almost completed. It is now in an unheated hangar. The
>engine which has not run for a while was previously in my heated
>garage. I am concerned that if I don't get the aircraft flying and
>the engine running normally before cold weather hits, I will have
>condensation and corrosion problems. Anyone have suggestions
>regarding heaters or other solutions? At present I am trying to avoid
>removal of the engine to take it back to the heated garage. I
>remember how much work and time it was installing it. Does anyone
>have experience with add on block heaters ie Van's or Tanis?
>Thanks,
>George
Has anyone tried to upgrade Matco brakes with new linings and rotors???? Jim
Brown, Matawan, NJ RV-3 & 4, a20driver(at)aol.com
Subject: | Leading edge rolling and drilling |
Regarding the leading edges of the rudder and elevators...
Is there any reason I can't drill the holes for the pop rivets to final size before
rolling up the aluminum? It seems like it would be much easier to drill on
a flat surface.
Since the holes are already pre-drilled, if they don't line up properly I have
much bigger problems..
Thanks.
-Geoff Evans
RV-8 rudder
Noooo! All you'll do is to scrape whatever oil is on the cylinder wall
off.
If you're set in wanting to rotate the crank, get a garden sprayer with
an aerosol tip, fill it with preservative oil, pull the top plug of each
cylinder, and load the cylinders up with preservative oil before you
rotate and again after you rotate. Then all you'll have to worry about
is scraping the oil film off the bearing surfaces.
Bruce
www.glasair.org
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Peter Dugdale
Subject: RV-List: Re:
George
bores
wet with oil
Peter
> >List:
>>My inspection was today and the DAR wants me to write a plan for the
>>testing
>>period (40 hour). Example: Hour 1 - climb to x altitude, stalls, etc.
>>Hour
>>2 - Hour 3- Hour 4 through 10 ... on and on.
>>Anybody had to do this or any type of plan I can follow.
>>Len Leggette RV-8A
>>N901LL (res)
>>Greensboro, N.C.
> >Inpection Tuesday !!!
>Maybe Kevin has a test profile of some sort? He's "da Man" in the flight
>testing arena.
>Brian Denk
>RV8 N94BD
>301 hrs.
I'm working on my test cards, but they are a long way from being
finished. I do have links to a few sets of test cards on my Flight
Test Links site - look in the General "How To" Info section:
http://members.rogers.com/khorton/ftlinks.html#General
Kevin Horton RV-8 (cowling, wing tip lights)
Ottawa, Canada
http://members.rogers.com/khorton/rv8.html
Subject: | Re: Flight Cards was Inspection |
I used Bill's flight cards and found them very usefull. They really helped
out, and they are so easy to download. My FAA inspector saw that I had a
file cabinet of information, plans, records, pictures and receipts, and I
think he was afraid to ask to see my flight test plan, he knew I would dive
into the file drawer and show him one, then he would have to read it!
But we did talk about flight testing, he was trying to pass on some good
common sense, that not everyone has enough of!
Bill, thanks for the cards, they are great.
> Hey Len...
> You can DL a copy of the cards I used here:
> http://www.vondane.com/flightdata/index.htm
> Good luck on your inspection!
> -Bill
> www.vondane.com
> One more thing about the inpection by the DAR. He is requiring me to
label
> the buttons and functions on my Infinity Grip. How in the heck am I
suppose
> to do that. He says it is a new FAA requirement.
Make a drawing or photo of it in your Aircraft Flight Manual and label
it there. It would serve the same function as labeling the stick itself.
If it is a new FAA requirement, have him show you the regulation that
specifically lists labeling a stick grip. Is there a label on your
control stick that lists its functions? How about the rudder pedals?
Shouldn't give them any ideas.
My Infinity stick has its functions listed in the Flight Manual
according to the color of the switch. It was adequate for my inspector.
Sheesh. A man can get picky.
Michael
Subject: | Re: Alternator breaker/fuse |
Hello Yall
A 35 amp alternator may easily put out 45 amps at full output.
The breaker/fuse is to protect the wire, not the alternator or
other components. Wire sized for 60 or more amps with a 60 amp
breaker/fuse would be an acceptable way to go. IMHO
George Meketa
RV8 152 hours
> > I have a 35 amp alternator (from Vans) - should I use a 35 amp breaker
for
> > the output? The reason I ask is I have these aeroelectric "fat" inline
> > fuses, but note that they are rated at 60amps. I also note that Spruce
> > sells "60/70 amp circuit breakers for alternators." Thanks in advance
> > Mike Sices
> > RV8 wiring
> > Gurnee, IL
From: | "Paul Besing" <azpilot(at)extremezone.com> |
FWIW, my 40 amp alternator never put out more than about 30 amps. That's
when the battery was almost dead, and would have every light and radio on.
Paul Besing
RV-6A Sold (Waiting on the RV-10)
Kitlog Pro Builder's Log Software
http://www.kitlog.com
----- Original Message -----
Subject: Re: RV-List: Alternator breaker/fuse
> Hello Yall
> George Meketa
> RV8 152 hours
> for
inline
Spruce
> > > Mike Sices
> > > RV8 wiring
> > > Gurnee, IL
From: | "Wilson, James Mike" <james.mike.wilson(at)intel.com> |
Right, didn't catch the fact that it had been run. My engine was a fresh
rebuild, it had been buttered with an oil STP mix which had been used prior
to the rebuild during which it had set for a very long time. I was told
after receiving the engine to NOT turn the crank until I was ready to run it
or the preservative would be scrapped off. Cylinders are the most
vulnerable, good idea to spray oil into them some how.
From: Wilson, James Mike [mailto:james.mike.wilson(at)intel.com]
Subject: RV-List: RE:
George,
Heat only if you can keep the temp. constant.
I recommend simply wrapping with blankets (not plastic) to prevent exposure
to rapid changes in air temp. outside the engine (i.e. in the mornings).
Rapid drop in temp. causes condensation on objects which do not change as
fast (i.e. metal). If you slow direct exposure, condensation is reduced or
eliminated. This leaves the metal subject only to the moisture in the
ambient air which does not seem to have huge impact except over long periods
of time (i.e. year or more). I had my fresh engine wrapped in unheated
environments (garage and hanger for 4 years with no noticeable corrosion. I
live in Portland OR so we do have moist air. I also remove the cowl and wrap
engine in the winter when usage is less frequent. I hate to think it might
feel a draft in the cold mornings.
From: George Frost [mailto:ghfrost(at)earthlink.net]
Subject:
Hello all,
George
Subject: | Re: smoke systems |
Here's a link to a homebuilt system, FWIW...
<http://www.kcdawnpatrol.org/smoke.htm>
On Wed, 25 Sep 2002, BUTLER, FRANCIS wrote:
> Want to add smoke to my RV8 project. Anyone have a name of a quality
> tank/system builder?
> Francis Butler
> Butler Machinery Co.
> (701) 298-1758 direct
> (701) 476-3208 fax
> francis_butler@butler-machinery.com
Regards, J.
flying: Zenair STOL CH701/582 C-IGGY , >230 hrs.
building: Sonex #325, engine probably Jabiru 3300/6/120hp
| J. Davis, M.Sc. (comp_sci) | email: jd(at)uwo.ca |
| SysMgr, research programmer | voice: (519) 646 6100 x64166 |
| Lawson Research Institute | fax: (519) 646 6135 |
| London, Ontario | lriweb.sjhc.london.on.ca/~jd |
For every action, there is an equal and opposite government program.
Subject: | Re: Lord mount orientation |
In a message dated 9/25/2002 10:49:31 AM Pacific Daylight Time,
motodd(at)worldnet.att.net writes:
> I now have about 500 hard hours on mine and they continue to perform
> quite well. I'll never go back to the 'cheap' conical mount bushing
> again. I originally mounted my Lord J-6230-1 mounts without any
> particular orientation and then changed then to the factory recommended
> positions after about 200 hrs. I can't say that I noticed much
> difference. Both ways were dramatically superior to the old conical
> bushings.
> For those who have a conical mount O 320 and are unfamiliar, I'd suggest
> you check Lord conical mounts out for yourself. The J-6230-1 mounts
> are more expensive than the traditional bushing, but effectively put
> lots more rubber bushing material to work at dampening. Yet, the
> overall mount is stiffer with less engine flex in acro.
With ALL rubber goodies (grommets, boots, isolators, etc.), the trick to
getting them to last, not lose their elasticity and not ozone crack is to
coat them generously all over with DC-4 silicone grease while they are nice,
new and supple. This is not to say that your new Lord mounts are not
superior to the generic brand, but whatever the original quality, the
rubber's longevity will be extended significantly just by doing this simple
act.
-GV (RV-6A N1GV 566hrs)
Gentlemen,
I have a small problem. I bought my -6 in Jan of this year, Since then I have gone
through two alternators. The alternator that is one the plane is the 14184
from Vans. The first one was from Vans ($99.00) the second one from Discount
Auto ($19.95).
Has anyone had this problem before? How about the other one (14684) from Van's?
I understand that it is a 60 amp alternator. I have tried to locate it from the
parts houses but Pep Boy says that it is a NAPA number and NAPA says they never
heard of it. Does anyone know what car it's from? Does anyone have a better
suggestion?
Paul
From: | "Garth Shearing" <garth(at)Islandnet.com> |
Subject: | Re: RV-6 Alternator |
Is it possible your alternator is simply running too fast? I looked into
this awhile ago and came to the conclusion that the alternator RPM should be
around 5500 or so. Work out the pulley ratios and see what the actual
operating RPM is.
There is quite a bit of other info about potential problems in the archives.
Garth Shearing
VariEze and 80% RV6A
Victoria BC Canada
have gone through two alternators. The alternator that is one the plane is
the 14184 from Vans. The first one was from Vans ($99.00) the second one
from Discount Auto ($19.95).
Van's? I understand that it is a 60 amp alternator. I have tried to locate
it from the parts houses but Pep Boy says that it is a NAPA number and NAPA
says they never heard of it. Does anyone know what car it's from? Does
anyone have a better suggestion?
> Paul
Paul:
Give us something to start with. What is the failure mode? How long did they
last? What are the electrical demands on it? Is it a belt breaking problem,
a bracket breaking problem, a wire breaking problem (internal or external) an
overheat problem, a circuit breaker problem, etc.?
Bill Marvel
Paul Brown wrote:
> Gentlemen,
gone through two alternators. The alternator that is one the plane is the 14184
Auto ($19.95).
the parts houses but Pep Boy says that it is a NAPA number and NAPA says they
never heard of it. Does anyone know what car it's from? Does anyone have a better
suggestion?
> Paul
Bill Marvel Home/office 310 832 7617
P.O. Box 784 Cell 310 293 2013
San Pedro, CA 90733 Fax 310 832 5334
One good deed beats 100 good intentions...
Bob Nuckolls says the alternater can't be ran to fast. Should run at
least fast enough at idle to keep the aircraft from needing to use the
battery while on the ground. Talk to him. Aeroelectric
(bob.nuckolls(at)cox.net).
Cecil Hatfield
writes:
> into
> should be
> actual
> operating RPM is.
> archives.
> Garth Shearing
> Victoria BC Canada
> then I
> plane is
> one
> (14684) from
> locate
> and NAPA
> Does
> > Paul
> messages.
Subject: | RV6A Kit For sale - $12000.00! |
Well, I must part with my project. I got short on time, funds, and patients.
I would love to finish it, but I just can't seem to find any of the above.
Currently this project is in storage in Cumming Georgia, which is north east
of Atlanta.
RV6A - Approx: 1000hrs completed, $12000.00
This project is ready for the finishing kit to be ordered. That would give
you just enough time to complete the odds and ends left open at this point.
Empennage 90% complete, Needs Fiberglass tips attached & electric trim
finished.
Wings are 95% complete, bottom skin left un-riveted, Tips needs attaching.
Fuselage mostly done, Upright, Seats done, Floors Done. Instrument panel
not cut.
Primed inside and under lapping skins with Sherwinn Williams Wash Primer.
I have information and pictures posted at
http://users.adelphia.net/~check6/rv6a/index.htm .
Any questions, please let me know.
Jim Kelley
I've had some alternator problems, they all went away when I switched to a
Mark Landoll automotive (Nissan I think) alternator. Real nice unit and it
comes with an external regulator attached, for $75. A possible reason for
going throught alternators may be a lack of cooling, installing a bast tube
is suppose to help.
> Paul
From: | "James E. Clark" <jclark(at)conterra.com> |
I could be wrong but I ***THINK*** those alternators are supplied to Van's
by a company and that they are "re-worked". Seems I called about the plug on
the back of the 35A model and was given the number of the guy.
If my memory is correct I called him and he said I would not find it at the
local auto parts store.
Maybe I dreamed this but I think that was the case.
James
> [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Paul Brown
> Sent: Thursday, September 26, 2002 2:16 PM
> To: rv6-list(at)matronics.com
> Subject: RV-List: RV-6 Alternator
> Gentlemen,
> then I have gone through two alternators. The alternator that is
> one the plane is the 14184 from Vans. The first one was from Vans
> ($99.00) the second one from Discount Auto ($19.95).
> (14684) from Van's? I understand that it is a 60 amp alternator.
> I have tried to locate it from the parts houses but Pep Boy says
> that it is a NAPA number and NAPA says they never heard of it.
> Does anyone know what car it's from? Does anyone have a better suggestion?
> Paul
Subject: | Fuel System Schematic |
From: | "Martin Hone" <martin.hone(at)tradergroup.com.au> |
Hi Listers,
I have a schematic of my fuel system if anyone is interested.
It has the wing-root mounted gascolator and boost pump, with a vapor return line
to the tank. I can supply digital pic of the wing root setup as well. Contact
me off-line.
Martin in Oz
Subject: | Moving an RV (well...actually moving the parts) |
A question for the assembled multitudes...
I'm moving to the south Wayne County, Michigan area soon, and I'm going to be hauling
a U-haul load of mostly boxed "stuff" (books...lotsa books...clothes...etc).
My RV tail section is finished and I've riveted together the
skeleton of the left wing...and drilled/dimpled the skins to the ribs. Right wing
is still in pieces and I don't have the fuse or finish kit.
Has anyone tried moving assembled or semi-assembled parts by simply laying the
pieces on top of boxes? Natch, I'd have to figure out a way to keep the parts
from shifting side-to-side, and keep them separated, but it seems to me
as though with a bit of padding, that having the parts on top of the boxes might
be a workable (and cheap) way to truck the parts, rather than having to build
a cradle or jig for them.
Opinions, pro/con solicited and welcomed.
Semper Fi
RV-6 (wish I had it finished so I could FLY it up there...*sigh*)
I'm posting for a friend who needs to reprop an o-320 powered RV-4. He
wants a FP wood, and has settled on an Ed Sterba prop, but wanted to
know if there was any significant history of problems, etc. before
ordering..
James Freeman
From: | Jim Streit <wooody98(at)directvinternet.com> |
Subject: | Panels for RV-7/9 slider builders |
Any RV-7/9 builders who wonder how they are going to get to the back of
their instrument panels to install and or service their instruments
should check out http://www.affordablepanels.com/
Over the years I have had to lay on the floor in my car to get behind
the instrument panel to replace a bulb or look for a rattle. As you are
probably already aware, that is no fun. I saw an ad for a new removable
panel
for RV-7/9 sliders and decided that I had to have one. I placed the
order last week and today the "Brown truck" pulled up in front of my
house with my new purchase. Although I did not see any damage on the
shipping box, I was anxious to get the panel out of the box to make sure
that everything had arrived in one piece as I have had some bad
experiences in the past. The excellent packing job assured that the
panel arrived in first class condition. The panel looks even BETTER
than on the affordable panel web page and the pictures don't do it
justice. The panel pieces, being laser cut, fit together perfectly.
This looks like something that was made for the space shuttle. All of
the hardware including the clecoes used to install the panel was there.
I also purchased the sub panel for the switches, which is easy to remove
to get to the back of the switches for servicing. I am extremely
pleased with the panel and I can't wait to install the
panel in my "9". I'll post pictures on my web site as soon as I install
it in my airplane
Jim Streit
90073
Fuse
09/26/2002 09:37:42 PM
Need help bucking rivets in the San Jose area? So do I. Let's help each
other get that darn thing out of the garage!
Sam Ray
str(at)us.ibm.com
Paul
My point is that the breaker/fuse amperage should be at least the
actual total output of the alternator, not the advertised output, and
not more than the capacity of the wire. Oversizing the breaker/fuse
along with the wire is an acceptable way to go.
I true 40 amp alternator should put out at least 40 amps. I ran
my advertised as 35 amp Vans alternator on a test bench and
it put out just over 40 amps full fielded. It had 120 hours on it
when I got it and now has 150 more. If it craps out I may go to
a B&C. With wiring and a breaker for 60 amps it would be
an easy upgrade. If the wire was too small for the new output it
would have to be upsized along with the breaker/fuse.
How was your ampmeter wired? As a true ampmeter showing
current to and from the battery or as a load meter showing actual
alternator output current? You may never see actual alternator
output when wired in the standard ampmeter configuration. You
would have to add up all items drawing current on the alternator side
of the meter/shunt and add them to the positive charge meter reading
to get current alternator output. When wired as a loadmeter you install
the meter/shunt in the alternator output line. This will indicate true
alternator output, but no meter indication of battery charge or discharge
rate. Both systems have advantages and disadvantages. The ideal way
may be to have two shunts and a switch to go from one to the other.
You now have both systems with only one amp/load meter.
George Meketa
RV-8, 152 hours
> Paul Besing
> From: "Meketa" <acgm(at)gvtc.com>
> To:
> > Hello Yall
> > George Meketa
> > RV8 152 hours
breaker
> > for
> inline
> Spruce
advance
> > > > Mike Sices
> > > > RV8 wiring
> > > > Gurnee, IL
Subject: | Re: Panels for RV-7/9 slider builders |
Sorry to be a skeptic, but I see a potential problem here. The panel layout
with the removable subpanels are a great idea. Where I think it could fault
is that the forward fuselage skin determines the shape of the top of the
panel. If you have a plug and play instrument panel, it may or may not fit
underneath your top skin. When Steve Davis did my panel, we had to keep
adjusting the radius of the top of the panel so that it would fit the same
all the way around, beneath the skin. That is why Steve doesn't do pre cut
instrument panels, because they all fit differently.
Food for thought anyway. Where this guy would do great is if you sent your
pre cut panel to him to modify. I think that would be less headache.
Paul Besing
From: "Jim Streit" <wooody98(at)directvinternet.com>
Subject: RV-List: Panels for RV-7/9 slider builders
> panel
> it in my airplane
> Jim Streit
> 90073
> Fuse
George:
> I ran
Out of curiosity, if a 35 amp alternator can put out 40 amps with full buss
voltage on the field, does doing so shorten its life any? Does doing so cause
excess heat? What determines the life of the alternator - bearing wear, brush
wear, field coil overheating, stator overheating, rectifier failure? Something
else? Will an alternator that is required to produce only 50% of its rated
capacity last longer than if it is producing its full capacity? Am interested
in any info you can provide.
Bill Marvel
From: | "flyseaplane" <flyseaplane(at)netzero.net> |
Subject: | Re: RV6-List: RV-6 Alternator |
Please send a picture of it to me at my e-mail address. I work at AutoZone
and I'll match it up for you. I need FRONT and BACK pictures. 14684 is a
good number of an Autozone Import alternator, but I won't say that is the
same alternator unless I can compare pictures.
Later,
Linc
Introducing NetZero Long Distance
Unlimited Long Distance only $29.95/ month!
Sign Up Today! www.netzerolongdistance.com
Subject: | Re: Ed Sterba props |
I had a Sterba prop on my first RV6A, now owned by my friend. I feel it was
the smoothest best performing prop I have flown behind. It was delivered on
time and inexpensive compared to the others. Ed was always available to
answer questions. That was 3~4 years ago and I assume things are the same.
John Furey
RV6A
From: | "Vern Darley,II" <vern(at)mindspring.com> |
Subject: | RV Hanger and Co-op at Falcon Field, Peachtree City, GA |
"I have a short time in which to find 8-10 RV owners/builders to move into a large
brand new hanger at Falcon Field here in Peachtree City, GA. Other aircraft
owners are making offers.The first one with a deposit gets it. It is next to
the new Aircraft Spruce location, so parts and camaraderie show be plentiful.
I would anticipate installing a basic shop and having some tools, benches, jigs,
electricity, and air available to share. Depending on the number we can squeeze
in, monthly fees should be $200-225 each. We can encourage and help one another.
We can develop a check out program. Formation and acro training could
take place. Or, we could even sit around and tell warstories, and 'advise' while
others work!
If you or someone you know is in the South Atlanta region and has a flying RV
or is building one in a garage or basement, now is the time to lock in a spot.
Please pass this on. Limited time! Please contact me if you are interested. First
come-first serve. If not enough come forward, we'll loose this rare opportunity.
Email me ASAP. Day/time determines your spot."
Vern Darley
P.O. Box 2526
Peachtree City,GA 30269
cell 770 310-7169
T hanger T-18
Alternators are limited by their current carrying capacity of the armature
and the rectifier. This ultimately translates to heat rejection. The field
can usually take up to about 5 amps for any of them up to about 60A output.
I have seem some 110 amp units used in highly digital cars that had in
excess of 5 amps for the field.
Manufacturing wise they may use the same armature for both units with a
different rectifiers.
More RPM = more voltage which the reg then limits. So output is dependant on
load and current carrying capacity. Exceeding this causes heat, heat makes
things melt, etc. To stop more failures it you need to determine what
failed, then respond accordingly. This will require disassembly and testing,
and running on a test bench with a scope.
If either armature or field failed its probably too much load for the
cooling available, if the rectifier failed it could also be poor cooling and
vibration, if the reg failed it could be cheap or all of the above.
Also note that most internal regulators keep output voltage too high. I've
seen from 14.7V to 15.8V from a stock new unit. Lead Acid batteries like it
at exactly 13.68V, or Batt V plus 1V, higher V tends to shorten their life
span due to excessive heat. Its also harder on light bulbs and electric
motors as they are designed with a specific voltage in mind. The higher
voltage makes them run at a higher current = more heat than needed for the
job. Most digital circuits don't care as they self regulate input V.
W
I agree, Sterba props are very good, and the price is definitely right! Ed
has been great too. I didn't even buy mine new from him, I got it used but
never flown, and he said he will still re-pitch it for me for free if I
needed it...
-Bill
www.vondane.com
Subject: Re: RV-List: Ed Sterba props
John Furey
RV6A
Paul,
No apologies for being a skeptic; however, before this becomes a concern to anyone,
I'll respond to your comment.
The scenario you describe is not as much of an issue anymore with the pre-punched
kits. True, with the RV-6, there were some differences between builders fuselages,
which affected the fit, but not with the new kits. This is the reason
Van's sells a pre-punched instrument panel for the RV-6 as a square (unfinished)
panel, so that every builder does its own fit. Furthermore, the possible
differences between fuselages of different RV-6s is the main reason why we do
not sell a Modular Panel kit for it.
We would like to stress to the list's audience that we have sold many panels to
date, and have yet to have anyone complain about the fit. As a matter of fact,
we are praised on a regular basis as to the quality and fit of the product.
The best way to judge a product is to see it in action. We welcome anyone contemplating
the purchase of Modular Panel to browse our website and/or call us
with specific questions. We are always happy to talk to builders/future friends
and answer any concerns. Our goal, from the start, was to produce a show
quality product and we believe we have done it.
Fabian Lefler
>>> azpilot(at)extremezone.com 09/27/02 12:15AM >>>
Paul Besing
> panel
> it in my airplane
> Jim Streit
> 90073
> Fuse
Hello Yall
I will attempt to answer your questions. Some of the answers
are from experience and some from theory or common sense.
buss
At only 40 amps there is likely little extra heat to shorten alternator
life.
On a rebuilt unit the combination of parts installed can be from several
interchangable units and give a different output depending on this. If able
I will go to the alternator shop today, before leaving for Abilene, and ask
them what trends they see. I have no control of the actual max alternator
output of a particular unit, but must size the associated wiring properly to
handle it.
Something
> else?
It depends on the manufacturer and application. Certain designs have certain
pattern failures. I have no personal failure experience with Van's unit
except that many?? have reportes failures. What type of failure I do
not know.
This also depends on the manufacturer and output of the unit. On a 0-60
amp unit high percentage demands (up to 80%) may do little to lower unit
life. Units with higher amp output may be more failure prone under these
conditions. I used to never worry about letting the alternator recharge
the battery on older cars. After charging system work is performed on newer
cars, which often have very high outputs, I always fully charge the battery
before letting them leave the shop. Long term high output can shorten their
life
Hope this helps
George Meketa / ASE master mechanic and shop owner
RV8
> > I ran
buss
cause
brush
Something
rated
interested
> Bill Marvel
Subject: | DAR page now available |
Thanks to Doug Reeves, guru-in-chief of the "Vans World Wide Wing"
website, and all-around nice guy, there is now a place for us to list
DARs with whom we have had good experience and can recommend to other
builders.
Here is the link:
http://www.metronet.com/~dreeves/dar.htm
Hopefully this will become a good listing of DARs available to RVers
everywhere; this list is intended only for recommendations and is not a
place to blast somebody you don't like (I don't think Doug would allow
critical reports, anyway).
If you have a flying RV, and found your DAR to be a nice person who was
reasonable, thorough, and fair, and that individual has not already been
listed, please submit info to Doug so builders coming along behind us
can take advantage of our experience.
Thanks in advance for your support of the list,
Sam Buchanan (RV-6)
I was in on a conference call with EAA this past week and someone said the
FAA no longer does inspections. The local FAA inspector recently inspected
six homebuilts at no charge and seemed miffed when he heard about someone
else getting a DAR. Does anyone know if the FAA is quiting this or is it just
a time constraint thing?
Earl RV4
Sam Buchanan wrote:
> Good idea! I'll run this idea past Doug Reeves since his site would be a
> great place to have the DAR list.
> It definitely works both ways. We had a local DAR who tried to rob one
> of our builders with an exorbitant fee.......and nobody has seen that
> DAR since.
> Sam Buchanan
> Aircraft Technical Book Company wrote:
> > Hey Sam, here's an idea for your web site. Why don't you compile a list
> > from us of RV friendly DARS by region and post them on a page on your site.
> > Put down what they charge too. Most of these guys are in it for the money
> > and its about time they have to deal with a little market pressure too. It
> > does work both ways.
> > Andy
James.......I would highly recommend Ed Sterba. He is completely honest, stands
behind his props, and produces an excellent product.
I have a Sterba prop on my Cygnet, and it performs very well. I bought the plane
used and moved it to a higher elevation than it was originally propped for.
Even though I didn't buy the propellor from him, he repitched it, refinished
it, and mailed it back to me........No Charge. Not even for shipping.
A friend has a Sterba on his RV-4 and is equally pleased. The prices are reasonable
as well.
Gary
RV-9A project
ordering..
James Freeman
From: | "Chris & Kellie Hand" <ckhand(at)earthlink.net> |
Subject: | Re: Moving an RV (well...actually moving the parts) |
John,
I've moved my RV6A project cross country 3 times in the last 5 years, twice
using a U-Haul trailer. The finished parts (horiz/vert stabs, elevators,
ailerons, flaps) I've done just as you are asking - laid them on top of
boxes and other stuff. Just wrapped them individually in blankets, towels,
bubble wrap, or whatever was available and that worked fine. I tried a
short distance without wrapping and found the skins got scuffed up even
driving on roads I thought were smooth so I recommend wrapping and taping at
least with towels or something.
Good luck with the move!
Chris Hand
RV6A, working on fuselage
Subject: RV-List: Moving an RV (well...actually moving the parts)
be hauling a U-haul load of mostly boxed "stuff" (books...lotsa
books...clothes...etc). My RV tail section is finished and I've riveted
together the
Right wing is still in pieces and I don't have the fuse or finish kit.
the pieces on top of boxes? Natch, I'd have to figure out a way to keep the
parts from shifting side-to-side, and keep them separated, but it seems to
me
might be a workable (and cheap) way to truck the parts, rather than having
to build a cradle or jig for them.
> Semper Fi
> John
It all depends on the work load and which FDSO your airplane resides. Cy
Galley
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Subject: Re: RV-List: Inspection
just
> Earl RV4
> > DAR since.
> > Sam Buchanan
list
site.
money
too. It
> > > Andy
In a message dated 9/27/02 1:14:44 PM Eastern Daylight Time,
efortner(at)vnet.net writes:
<< I was in on a conference call with EAA this past week and someone said the
Earl RV4 >>
Call your local FSDO.
Some have a policy that they don't inspect homebuilts.
Others will inspect it "when they have time" (i.e. They may never get to it.)
Others are very helpful.
Even if "your" FSDO or MIDO has a policy against inspecting homebuilts, you
might be surprised at the service you can get if you know the right person or
know someone who knows the right person...
Kyle Boatright
0-320/Aymar Demuth RV-6 Slider
Kennesaw, GA
http://www.angelfire.com/my/rv6
Subject: | Re: 6A Flying (long) |
Congratulations Austin.
Harry Crosby
Pleasanton, California
RV-6, electrical stuff (forever it seems)
Subject: | Question: when to drill F-688 gusset? |
I've got a question about drilling the F-688 aft top fuselage
gusset...when's the best time to drill that sucker? RV-7 tip-up in case
that matters.
I assume once the skeleton of the aft fuselage is together and square, you
can lay it right on there and back-drill outward, but I figured I'd ask in
case you're supposed to drill it sooner than that.
)_( Dan
RV-7 N714D (fuselage)
http://www.rvproject.com
Subject: | Garmin 195 for sale |
Listers,
I have a garmin 195 for sale with all the accessories. I have been using it
in an RV6 and it works wonderfully. I am asking $550 OBO for it. Please email
me offline if you are interested.
Scott
For anyone that was considering the Superior XP-360 engine kit, they have
quit selling it. Now they only sell the completed engine.
As I was interested in this and it's no longer available, has anyone heard
of, or had any experience with the outfit that was featured in last month's
Kitplanes, ECI? They are advertising an O-360 kit, but I can't say I have
ever heard of them.
Keith Hughes
RV-6 (engine-less)
Denver (is that snow?!?)
It's my understanding that ECI has been doing the same sort of "stuff"
that Superior is known for, but longer. My O-360 was built by a local
A&P using new components from ECI. The A&P spoke highly of
them.........FWIW, but I haven't run the engine yet.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rv6tc
> Sent: Saturday, September 28, 2002 12:12 PM
> Subject: RV-List: engines
> kit, they have quit selling it. Now they only sell the
> completed engine.
> anyone heard of, or had any experience with the outfit that
> was featured in last month's Kitplanes, ECI? They are
> advertising an O-360 kit, but I can't say I have ever heard of them.
> Thanks,
> Keith Hughes
> RV-6 (engine-less)
Hi All,
I don't have an ECI engine, but I have an Uncle who builds experimetal
engines for lots of the "hotrod" (Lancair/Glassair) crowd. He's built many
engins, and swears by the ECI components. Most of his engines are wayyyyy
above normal rated horsepower. After building and "rebuilding" lots of
engines over the years, he claims the ECI cylinders are the best. I did a
lot of research on engines before I bought one, and when I need to overhaul
mine it will get ECI parts. He had a lot of bad cylinders from Lyc,
Continental, Superior, and ECI, and showed me how the ECI cylinders were
better (in his opinion).
Take it for what it's worth, but at least coming from a very experience
"old-timer" engine man, I'll take his word.
Stein Bruch
RV6, Minneapolis
Inspection next weekend! Getting REAL anxious to fly!
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Larry Bowen
Subject: RE: RV-List: engines
Larry Bowen
> completed engine.
> Thanks,
> Keith Hughes
> RV-6 (engine-less)
SoCAL-RVlist
Subject: | Ultralight info wanted |
Ok so this isn't RV related....but I used the word RV (twice now) in
a sentence, so I guess it's ok and it is at least flying related.
I'm looking for an ultralight kit to build for a friend (my RV is
flying fine, thank you) and I don't have a good idea of what kits are
out there right now.
If you have some suggestions of places I could start I would appreciate it.
PLEASE EMAIL ME DIRECTLY AT:
owens(at)aerovironment.com
to keep this non RV subject from taking up bandwidth on the list.
Thank you in advance.
Laird
RV-6 600 hrs
SoCal (currently displaced to Kauai for a work assignment...I know,
rough duty! But I miss my RV :-(
From: | "Steve J Hurlbut" <sjhdcl(at)kingston.net> |
Subject: | Aluminum Fuel Lines |
I'm trying to install the 3/8" fuel supply line in RV7A.
I'm starting at the centre section and I can get the tubing routed up to
the main gear web but then how do I manage to turn the tight corner, avoid
rubbing
the gear leg, avoid kinking the tube, through the rubber grommet and
then onto the fuel pick up line. The area is too tight for a tube bender.
Any ideas? I've tried twice and just ended up ruining the tubing.
Steve
Rv7A
(was looking forward to this part)
From: | "Gordon or Marge Comfort" <gcomfo(at)tc3net.com> |
Subject: | Re: RV8/8A cooling ramp cracking |
Subject: RV-List: Re: RV8/8A cooling ramp cracking
> Anyone with an 8 or 8A have any cracking occurring in the air exit
> cooling ramp on the belly?
Can anyone explain why the cooling ramp is adjustable?
Gordon Comfort
N363GC
In a message dated 9/28/02 3:32:21 PM Eastern Daylight Time,
gcomfo(at)tc3net.com writes:
Gordon Comfort
N363GC >>
The stock one ain't...
Kyle Boatright
Kennesaw, GA
it is not
Gert
> Gordon Comfort
> N363GC
> Gordon Comfort
> N363GC >>
>Kyle Boatright
>Kennesaw, GA
I seem to recall reading somewhere that Van originally planned to
have the front end of the ramp (and curved air guide) move up and
down to vary the cooling air exit area. This would basically be a
cowl flap, and could allow some performance increase. I thought
about trying to do this, but I couldn't come up with a simple, robust
way to do it, so I gave up.
Ottawa, Canada
Subject: | Re: Aluminum Fuel Lines |
Use a steel braided hose instead. Once you use one, though, you will want
to throw away the tubing bender and flaring tool and do them all that way!
Paul Besing
Subject: RV-List: Aluminum Fuel Lines
> rubbing
> Steve
> Rv7A
Use "trouble free" flexible hose. A bit more expensive, but you'll be done
in 1/5th of the time. I used this where complicated bends were not much
fun!
Good Luck
Stein Bruch
RV6, Minneapolis, Inspection next Sat!
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Steve J Hurlbut
rubbing
Steve
Rv7A
hi listers,
Can anyone tell if there's a problem fitting a IO-360-A1B6D to a RV-8? This is
the "same" engine as Vans sells, but it has the BendixD4LN-3000 impulse coupling
dual magneto.
Marcel
VansRv4GRVMJ(at)btinternet.com
Get rid of the Dual mag. It is the source of many, many problems.
Subject: RV-List: rv8 engine
> hi listers,
This is the "same" engine as Vans sells, but it has the BendixD4LN-3000
impulse coupling dual magneto.
> Thanks
> Marcel
In a message dated 9/28/02 6:19:44 PM Eastern Daylight Time,
VansRV4GRVMJ(at)btinternet.com writes:
> hi listers,
> is the "same" engine as Vans sells, but it has the BendixD4LN-3000 impulse
> Thanks
> Marcel
I used an IO360-A3B6D and it fits fine. I did opt out of the dual mag and
installed dual electronic ignition but it will fit with the dual mag.
Rick McBride
Subject: | RV-6 riveting cowl hinge segment at firewall |
List,
I have a number of rivets at the fuselage firewall (side and bottom) that I
can not squeeze because the engine mount is in the way. All along, I had planned
to jack everything up and move the engine-on-mount forward a few inches to
accomplish this, but now, I don't have the guts to try that.
Can someone tell me how to buck these most difficult to get to rivets. I will
use pop rivets only as a last resort, before pulling the engine mount loose.
I'm sure every tail wheel builder faces this task, but I'm going goofey thinging
about it.
Thanks in advance.
Tom Barnes -6
Subject: | Re: RV-6 riveting cowl hinge segment at firewall |
In a message dated 9/28/02 9:12:17 PM Eastern Daylight Time,
skytop(at)megsinet.net writes:
<< List,
that I can not squeeze because the engine mount is in the way. All along, I
had planned to jack everything up and move the engine-on-mount forward a few
inches to accomplish this, but now, I don't have the guts to try that.
I will use pop rivets only as a last resort, before pulling the engine mount
loose. I'm sure every tail wheel builder faces this task, but I'm going
goofey thinging about it.
Thanks in advance.
Tom Barnes -6 >>
Tom,
Use Cherry Max structural rivets in those locations. Far easier to spend a
few dollars on these high quality pop rivets than to have to pull off the
engine and mount. Note that the Cherry Max rivets have pretty tight
requirements on length - you need to make sure you use the right size.
Aircraft Spruce is one source.
Kyle Boatright
Kennesaw, GA
> you'll be done in 1/5th of the time. I used this where
> complicated bends were not much fun!
> routed up to the main gear web but then how do I manage to
> turn the tight corner, avoid rubbing the gear leg, avoid
> kinking the tube, through the rubber grommet and then onto
> bender. Any ideas? I've tried twice and just ended up ruining
> the tubing.
A couple things - one can use the flexible lines as suggested above, but
it is expensive and will involve some maintenance eventually. If you
choose to go the aluminum tube route, be sure to get a good bender.
Also, buy a big coil of the tubing (it is cheap), and don't be afraid to
try different routings. I don't think it is a big deal if it takes 4 or
more tries to get it right. 4 tries might only take 30 minutes. If it
is difficult to get one piece of tubing to work, don't be afraid to put
a connector in the middle of a run.
Alex Peterson
Maple Grove, MN
RV6-A N66AP 211 hours
> List,
> and bottom) that I can not squeeze because the engine mount
> is in the way. All along, I had planned to jack everything
> get to rivets. I will use pop rivets only as a last resort,
> before pulling the engine mount loose. I'm sure every tail
> wheel builder faces this task, but I'm going goofey thinging about it.
These rivets get a lot of stress, and are often the "smoking" rivets one
hears about on the 6's, particularly right at the inboard ends of the
bottom hinge lines. You might find someone who has "modified", i.e.,
ground away, a squeezer so that it will work. I believe I also used a
special bucking bar in that area.
Alex Peterson
Maple Grove, MN
Tom,
Use Cherry Rivets. God's gift to impossible rivets! Done correctly, you
won't notice much of a difference, other than the hole in the center (which
can easily be filled later).
Much easier than goofing around with the engine mount!
Stein Bruch
RV6, Minneapolis
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Tom Barnes
Subject: RV-List: RV-6 riveting cowl hinge segment at firewall
List,
Thanks in advance.
Tom Barnes -6
From: | "Sally and George" <aeronut58(at)hotmail.com> |
RV8 for sale to RV Listers first. Ad goes in TradeAPlane next month. 90
TT, 85 since remanufacture on 180 HP O360A4M. Sensenich prop. Day/night
VFR. Full gyro panel. Intercom, King Nav, King GPS, King Transponder/Mode
C. Room in panel for ILS to make it IFR. Orndorff interior. Rear seat
rudder pedals. Cabin heat. Aileron trim. G meter. All interior parts
primed. A sweet flying, good looking RV8. $65,000 firm. Contact off-line
at aeronut58(at)hotmail.com for pictures or more information.
Here's a little tip that will save you a lot of time bending tubing. Go
down to your local welding supply house and pickup some soft aluminum
welding rods. Shape the rod by hand to your exact bend needs, until it
fits just right, mark to length with a felt tip pen and then use this as
a pattern to bend your aluminum tube off the airplane.
When you're done with one piece of welding rod, just roll it on a table
to straighten out - ready to use on the next bend.
Bruce
www.glasair.org
Subject: | Re: Ultralight info wanted |
In a message dated 9/28/2002 11:01:51 AM Pacific Daylight Time,
owens(at)aerovironment.com writes:
Laird-
I would think that the Titan Tornado would be a fun build for a sheet metal
type guy.
-GV (RV-6A N1GV 570hrs)
We have a LASAR ignition system on the IO-360 in our RV-4, and up to now have been
very happy with its performance, but....
Recently the cockpit ignition light stays illuminated indicating that the mags
are in "backup" mode, i.e. they are using the points and have fixed 25 degree
timing. The engine runs great, but of course is nearly impossible to start.
Tomorrow we begin troubleshooting. If anyone has any experience or tips with this
equipment, I would most appreciate it.
First question is where do you connect your PC to download the trouble codes? It
is not clear in the instructions, and although it says to connect the serial
cable, I see no serial connector. Is it the canon plug on the bottom of the
computer box? Also, it is not clear in the instructions how to get the trouble
codes. Do they download as soon as you connect or do you have to crank or start
the engine?
Thanks in advance!
Jeff Bertsch
noms1reqd(at)yahoo.com
Subject: | Re: LASAR Ignition |
I would contact Harry Fenton at Slick... Harry(at)unisonindustries.com He is
their service engineer and also an A&P, IA. He can tell you what you need to
know.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Always looking for articles for the Experimenter
Subject: RV-List: LASAR Ignition
have been very happy with its performance, but....
mags are in "backup" mode, i.e. they are using the points and have fixed 25
degree timing. The engine runs great, but of course is nearly impossible to
start.
with this equipment, I would most appreciate it.
codes? It is not clear in the instructions, and although it says to connect
the serial cable, I see no serial connector. Is it the canon plug on the
bottom of the computer box? Also, it is not clear in the instructions how
to get the trouble codes. Do they download as soon as you connect or do you
have to crank or start the engine?
> Thanks in advance!
> Jeff Bertsch
I, too, have a Lasar system in my -4. When I needed help during installation,
I spoke with Harry. He is sometimes difficult to get on the phone, but very helpful.
During installation, I borrowed the serial cable from him - no cost,
not even shipping. He provided all the help required.
Good luck.
Dean
Subject: Re: RV-List: LASAR Ignition
know.
start.
> Thanks in advance!
> Jeff Bertsch
I did the same thing on my RV4. Ended up pulling the engine mount. I think I would
have made a mess trying to do it any other way.
Earl RV4
Tom Barnes wrote:
> List,
I can not squeeze because the engine mount is in the way. All along, I had planned
will use pop rivets only as a last resort, before pulling the engine mount loose.
thinging about it.
> Thanks in advance.
> Tom Barnes -6
There is nothing wrong with using pop rivets here. You will never see it.
Just use some steel structural pop rivets, instead of the alluminum ones.
Paul Besing
Subject: Re: RV-List: RV-6 riveting cowl hinge segment at firewall
I would
> Earl RV4
> Tom Barnes wrote:
> > List,
rivets. I will use pop rivets only as a last resort, before pulling the
engine mount loose. I'm sure every tail wheel builder faces this task, but
> > Thanks in advance.
> > Tom Barnes -6
From: | Charles Brame <charleyb(at)earthlink.net> |
Steve,
Can you add more info about "trouble free" flexible hose. Is this a
brand or a description? My experience with flexible hose is that it
requires a larger radius bend than regular aluminum fuel lines. I made
good use of flexible hoses on my brake lines, but found I had to use
aluminum lines for the fuel, especially in tight spaces around the
selector valve.
Charlie Brame
RV-6A N11CB (res.)
San Antonio
> From: "Stein Bruch"
> Subject: RE: RV-List: Aluminum Fuel Lines
> fun!
> Good Luck
> Stein Bruch
The Titan doesn't even come close to qualifying as a "true" Ultralight.
Its just too fast and heavy. The Tornado is a fun little plane, but for
the money you could almost build a RV-3. :-)
I loved my Titan (2 Place, Rotax 582), but there is a reason it is gone
and I am building a RV-7 now.
Nick
Vanremog(at)aol.com
Subject: Re: RV-List: Ultralight info wanted
Laird-
metal
type guy.
Charlie,
I used plain old Aeroquip steel braided hose. You are right about the bend
radius being tighter with aluminum. The reason the flexible stuff is easier
in some instances is that very complex routings can be accomplished much
easier than with rigid line. I have all aluminum lines in and out of my
selector/fuel pump/filter installation.
The flexible line is just very fast and easy, and in my case I was
"retrofitting" a normal tank with an inverted pickup, and didn't want to cut
a bunch of new holes for routing, but still wanted the line hid behind my
interior panels, hence the flexible line.
It is MUCH more expensive, and everyone is right, bending rigid line is also
fairly easy and quick. I'm not advocating that one completely replaces
aluminum lines with flexible one, just that in "some" cases it MAY be
easier.
Good luck and happy building,
Stein Bruch
RV6, Minneapolis, Inspection next Sat.
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Charles Brame
Steve,
selector valve.
Charlie Brame
RV-6A N11CB (res.)
San Antonio
> From: "Stein Bruch"
done
> fun!
> Good Luck
> Stein Bruch
Jeff:
I run the Laser on an 0-320. On rare occassions I have this problem too.
It will either not come back after the mag check or the computer drops off
after a rapid throttle change. In all of these cases, cycling the master
switch has resulted in a return to normal operation. Thankfully this has
been quite rare.
Dick Sipp
start.
> Thanks in advance!
> Jeff Bertsch
Jeff, if you want to connect your PC you'll need the cable they sell for it.
I installed one in my plane but haven't used it yet. One thing that could be
causing your problem is to check the CHT circuit sensor and connections. I'm
told the connections especially must be perfect or you will get a fault.
Some units don't have the CHT circuit, consider yourself lucky if you don't.
Dick, LASAR automatically goes into backup mode temporarily with any sharp
reduction in manifold pressure -- it's part of the program. I don't see the
benefit in this but that's the way they do it.
Randy Lervold
RV-8, 268 hrs, O-360 A1A w/LASAR
www.rv-8.com
> Jeff:
> been quite rare.
> Dick Sipp
> From: "Jeff Bertsch" <noms1reqd(at)yahoo.com>
> To: "RVlist"
the
25
to
> start.
connect
you
> > Thanks in advance!
> > Jeff Bertsch
> with any sharp reduction in manifold pressure -- it's part of
> the program.
It goes into backup mode whenever the manifold pressure drops below 5
inches mercury. A few seconds after MP is above 5, and it will shut off
the light.
Alex Peterson
Maple Grove, MN
My wife and I plan to fly our 8A from Okla. to North Dakota soon, merely
because we have not been there.
What are some good stops/places to see on that route?
Thanks.
hillstw(at)aol.com
RV8A
When using the flex hose, is there any concern in using 90 degree fitting to
attach to the fuel selector? I suspect the turn into the fuel selector will
be too tight to use a flex hose with a straight fitting. How tight a corner can
I turn with a flexible hose? Tight enough to turn the 90 degree bend after
exiting the main gear weldment?
I'll probably end up using the expensive hoses with 90 degree end fittings. Of
course the fuel pressure test run will ensure sufficient fuel flow after
everything is finished.
Thankx again,
Steve Hurlbut
RV7A
Quoting dmasys :
> up to
> avoid
> > rubbing
> bender.
> This wasn't easy. I prebent the curve leading up to the fuel selector
> with a lever-type tubing bender and then fed the tubing from center
> outward, rebending as the lines advanced. You do have to do some of
> it with your fingers rather than with a tubing bender. Got a few
> surface nicks in the fuel line going around the sharp edges of the
> landing gear weldments, and dressed these out with emery cloth after
> finishing the bends.
> -Dan Masys
> Sell a Home for Top $
> http://us.click.yahoo.com/RrPZMC/jTmEAA/MVfIAA/1yWplB/TM
> Van's Air Force - World Wide Wing
> www.vansaircraft.net
Subject: | Need help on starter decision making. |
From: | "Wier, Daniel C." <daniel(at)thegreatwhite.net> |
Good morning and hello for a newbie outside of Lexington, Kentucky.
I have been watching and reading the list and searching every RV site I can find,
Visiting some very nice people who are building, and talking to many others.
I thank everyone of you who have given me help and now am getting ready to
start. I have a few questions.
Where I am building my shop is in a room off one side of an open garage. the area
I will be building in is 20x10 and seems to be large enough, but will be open
to the outside air. Will this pose a problem for mosture in building each
section of the aircraft and anything else you can think of? I have almost all
the tools I need to start the first kit, but wanted to know what size dimple
dies I need.
I am also building a web based application for tracking progress of RV building
that would show a top and side view of the plane and a user can click on any
part of the plane and display the log of that part with pictures below. Also
each part would be color coded to the progress on it. The whole thing would have
a simple owner tool for inputing the daily log, pictures, time, money spent
that day, ect. The app would keep track of the total cost, cost per section,
time and time per section auctomaticly for the owner. If anyone is interested
in this, I would be willing to hand out the source once it is finished.
Thanks and I apriciate all the health,
Daniel Wier
Daniel(at)thegreatwhite.net
For Inspectors it is a time contraint thing as management on high has
decided that GA is not as important in the political arena as the big air
carriers are. We have been informed that because there are DARs out there
we, as Inspectors, should give up on Experimental certifications.
Personally, I feel this is the wrong approach, but, then again, I am just a
General Aviation Inspector. I still manage to fit Experiemtnal
certifications into my schedule as I can and will continue to do so unless
directed specifically not to.
Mike Robertson
Das Fed
RV-8A, 6A, 9A
>From: Earl Fortner <efortner(at)vnet.net>
>Date: Fri, 27 Sep 2002 12:55:00 -0400
>just
>Earl RV4
> > DAR since.
> > Sam Buchanan
>list
>site.
>money
>too. It
> > > Andy
http://www.hotmail.com
Subject: | 6A Flying (long) |
From: | "Gannon, Terence" <Terence.Gannon(at)trican.ca> |
Austin -- great news and congratulations!! Sounds like things went
really well! Please keep the list posted as things progress in the next
little while. 'til then...best regards...TCG
SoCAL-RVlist
Subject: | TruTrak's Digitrak Report part 2 (long) |
Hi all,
I posted an initial flight report on the Digitrak autopilot I
installed in my RV-6 a month ago (see previous report below).
I thought I'd give an update now I've been flying with it awhile and
have been on a couple long trips with it.
And before we start, I'm not trying to start a Trutrak vs Navaid war.
I'm trying to state my experience with my Digitrak. That's all. I
don't have any time behind an RV with a Navaid, so I can't compare
them.
When I posted the last report, I didn't know how the Digitrak would
act in turbulence. Now I know-It works awesome. I've been bounced
around quite a bit while it was engaged and it brings the airplane
back to level after an upset very well every time. I felt
comfortable keeping the AP engaged while riding it out.
Next was how well the AP would hold a course heading over a long
period. Again, awesome. I set up a direct course over a couple of
hundred long mile leg, set the Digitrak to the same track and sat
back. As the GPS direct course changed a degree once in awhile (due
to the great circle routing), I would press the arrow key on the AP
once to keep the direct course on the GPS and the AP display the
same. I'd say it was less than 1/4 mile off course by the end of the
leg. Not bad.
So as far as I can tell, it's a great product with good value.
The one glaring difference between the Digitrak and the Navaid was
that that the Navaid would follow around a multi track course. While
with the Digitrak, you would have to press the defeat switch on the
stick (or turn it off), turn to the new course, and reengage it.
That's not a big deal in my opinion because all of my flying is
"Direct To", and it holds a course line so well.
But apparently, the guys at TruTrak thought that it was a big enough
feature deficit that they needed to add that feature. I saw that
they announced it last month that it would be available October 1 for
an additional cost.
A couple of days after I posted my initial report, I got an email
from the guys at TruTrak that said they were looking for a couple of
beta testers for the new software. Hmmm, that sounds like fun!
So, a couple of days later, I have a beta controller with the new
software sitting in my RV. It was a simple swap of taking the old
controller (the part that bolts into the panel) and installing a
replacement. No new wire runs or any other changes. That was easy
(so anybody who buys a standard unit, then wants to upgrade can do so
easily).
I had about 2 weeks worth of testing before I got shipped out of
state on a business trip (to Kauai of all places.....rough duty, I
know. I guess that's why my call sign is "Lucky"). The last version
I was testing was working great before I left.
The last version (and it might have changed slightly in the last 2
weeks) I was testing would tell you by when it saw a GPS track
active in the GPS. (It does that when the AP is engaged by flashing a
symbol in the display every once in a while). That could be direct
track or a dog leg course. You tell the AP to track that course by
pressing both of the arrow buttons for a moment. The display starts
flashing heading changes as it steers the airplane to intercept the
course.
And the intercept is a thing of beauty! Depending on where or how
far you are off track, it steers to a intercept heading, and starts
turning on course before it intercepts the course. Most of the time,
it levels out right on the course line, sometimes it comes up short
by, maybe an 1/8 mile, but then kinda snuggles up to the course line
and then holds it. It may wander a degreee or two one way or another,
but it holds that course very well.
If a dog leg course is programmed in the GPS, the Digitrak will fly
to the waypoint, overfly it, then correct back to the course. It
comes back to the course like an intercept with generally no
overshoot. (I understand that the Navaid overflys the waypoint as
well, then steers back to the course in the same fashion, but that
the intercept may not be as good).
Of course the optimum would be if the AP knew a turn was coming up
and turned in early, but that is true GPS Steering, and you need to
go to the next level of TruTrak AP to get that. It's also more
expensive for the GPS Steering).
So if you feel you need to have an AP that follows a dog leg course,
or be able to intercept a given course, than this new software is for
you. (Not everyone needs to do this, and the way that the basic
Digitrak holds a course, a frugal pilot may want to forgo the extra
option. It's up to the individual.)
In conclusion, I really like my new Digitrak. The new software is
working great and I think it's a great product. It is comparable to
the Navaid, and I THINK it may be superior in a few ways, but they
both have their strength and weaknesses. It's great to have another
option for a low cost auto pilot for our RV's on the market.
So there you go. I hope you all take this report is the spirit in
which it is offered.
And the disclaimer: I did get the keep the software upgrade for my
efforts. But I also burned that much in AVGas during the testing, so
it's not like I got rich off of it. And it was a pleasure working
with the guys from TruTrak.
Laird RV-6 600hrs
(Kauai, but much too soon back to SoCal)
Previous post from 8/23/02
Subject: DigiTrak Initial Test Report
Hi all,
I just installed my TruTrak "DigiTrak" auto pilot (that I ordered at
Oshkosh) this week and test flew it last night. I thought I'd give a
quick report with a more detailed report later once I live with it
for awhile.
Background:
My RV-6 has 570 hours of non AP use. I've been lusting after a wing
leveler for awhile (for convience and safety) and while out of my
mind at Oshkosh, I decided to jump in.
A couple of reasons I decided on the TruTrak were:
1) Comparative cost to Navaid.
2) Quick delivery time.
3) Touted as having better performance in turbulence.
4) TruTrak's upgrade policy. (The will upgrade you for only the
difference of the unit your choosing to upgrade to. This was a biggie
because I would like to someday have altitude hold capability).
5) Wanted to try something different. (This may always come back to bite you).
The only drawback I see compared to Navaid is that it doesn't track a
course. (If I were TruTrak, I'd be working on that, and you never
know, they might be). This isn't a big drawback in my mind if you can
manually sync up GPS Direct Track and the heading of the Display.
I did the mechanical installation of the servo one day, and the
wiring stuff over the next two evenings (with help from my father).
I decided to put the servo out on the wing tip and attach it to the
aileron bellcrank via a pushrod. I used parts from Van's stock
aileron pushrod assy to create the pushrod. Easy to get and didn't
have to reengineer much. (The reason I installed the servo in the
wingtip was only for ease of installation and serviceability. The
suggested installation has the servo in the same bay as the aileron
belcrank, and while it looks like it would work, access would be very
difficult, so I chose the wingtip. I paid a small weight penalty for
the added weight of the pushrod, but I also designed a lighter
bracket to attach the servo to the wing tip rib). I'll put up some
pictures when I have the chance.
I had to call Andrew at TruTrak to confirm the pin output of my
Garmin 250XL for the GPS info that the DigiTrak needs. I faxed him
some of the pages of the Garmin installation and he called me right
back to confirm that it was Pin 19 that needed to be used. Great
service. Thanks Andrew.
I finished the installation yesterday and turned on the main power
for a smoke check. No smoke....So far, so good. Next came the set
up of the DigiTrak. 4 simple tasks described in the installation
manual. Even though I had the GPS up and locked on, I wasn't getting
an indication from the DigiTrak that it was. Hmmm....Oh, I forgot to
set up the GPS to output to that channel. No big deal, went to the
set up page on the Garmin, changed output 2 from OFF to Positioning,
exit, and presto....DigiTrak was happily receiving a signal. (Also
for an installation note for others using a Garmin 250XL, it uses a
9600 baud rate).
With the ground set up complete, I fired up the RV and headed off to
the practice area. I hit the ON button and a track heading appeared
on DigiTrak display, and it held the wings level. That's a good
start. There is some setup of the devise that is required while
inflight that has to do with servo override torque and turbulence
settings that I got set initially. Will play with those a little
more when I find some good turbulence (I love the note in the manual
"DigiTrak LOVES turulence"), but that will come later.
Next was a quick test of the heading hold. I manually synced up a
GPS course on the GPS to the display on the DigiTrak head. It held
that very well. If you watch the GPS ground track, you see a very
mild change from one degree left, to one degree right over, maybe, a
20 second period. Nothing you can feel in the airplane, but you see
it on the GPS display. The next long trip will give me a feel for how
well it holds over long periods. Very well, I suspect.
Next was a test of the turn command. Press the Left or Right button
for 1.5 seconds and it commands a standard rate turn in that
direction until you again press a button or disengage it with the
stick switch. When you tell the AP to stop the turn, it rolls out
and holds that new heading. Pretty cool.
On test was to command the turn, trim the elevator and see what
happened. It just went round and round and round....5 times. Never
got confused, as some might have suggested. I timed a few of these
and one was exactly 2 minutes, another was 10 sec different. I need
the timing tests just to see how consistent it it. Worked the same
left or right.
Next I got it set on a heading, then turned the GPS off. The heading
display changed to 3 dashed lines indicating it wasn't getting any
track info. It happily held a heading and I didn't see any drift on
the compass for a minute or two. That's cool.
I set a course for home, set the DigiTrak and left it alone while I
watched for traffic and generally twiddled my fingers.....Hmmmm, so
this is what Auto Pilots are all about....Pretty cool.
(Unfortunately, I don't have any time behind a Navaid so I can't
compare the two).
That's about all I have right now. It's working as advertised and
I'm looking forward to trying it out on a long trip to learn more
about it and see how it works in turbulence. I report again when I
get a good feel for how it's working. (So when was Las Cruses
again???)
Let me know if anybody has any particular tests they want me to run,
and I'll see what you can do.
Laird RV-6
SoCal
Subject: | Aluminum Fuel Lines > |
If you need to make an immediate turn in your lane after a bulkhead, use a
bulkhead elbow union, AN833-6D, Wicks online catalog p138, $5.70, (90
degree, a 45 deg is AN837-6D); and AN924-6D nut, Wicks online catalog p140,
$.60: Then if one line needs replacing, you don=B9t need access to both sides
of the bulkhead, and the tube is much easier to fabricate and install.
John Veld, retired Air Force tinbender, slow build RV6-A
From: | "Paul Besing" <azpilot(at)extremezone.com> |
To answer your questions, yes, yes, and yes. I used steel hose throughout
the project. From the fuel selector I have 90 fittings and snake it past
the gear weldment. Then one line goes to the wing via a straight bulkhead
fitting. Another line goes to the fuel pump and then to the firewall. Even
the bend at the front of the floor and up the firewall worked fine. I then
have a 90 degree bulkhead fitting on the firewall, to pass the fuel line
through. No problems in over 100 hours.
Paul Besing
RV-6A Sold (Waiting on the RV-10)
Kitlog Pro Builder's Log Software
http://www.kitlog.com
----- Original Message -----
Subject: RV-List: Re: Aluminum Fuel Lines
to
will
corner can
fittings. Of
> Thankx again,
> Steve Hurlbut
> RV7A
> Quoting dmasys :
> > up to
> > avoid
> > > rubbing
> > bender.
> > -Dan Masys
Subject: | Firesleeve dressing? |
I've seen firesleeve installations where the ends of the firesleeve
looked sealed or dressed in something. It looks like the end was dipped
in some very watery RTV-like stuff. What is this stuff, and where can I
get it?
Larry Bowen
Where can I find some mag clamps -- The little blocks that hold the
slick mags in position on the engine? I need another pair to mount the
Jeff Rose EI.
Larry Bowen
Subject: | Re: Firesleeve dressing? |
Larry: The Fire sleve end dip can be found in Aircraft Spruce Catalog page
121 lower right hand corner P/N 5027 .
Subject: | Transition Training |
I just got back from transition training with Mike Seager this past Friday.
This was only my third time in an RV and my first time flying one. What a
nice flying airplane and what a nice guy. So what I had to drive 10 hours
to get to Vernonia. So what that I ate dinner at the Disfunctional Redneck
Pizza Parlor (it's okay, I'm a redneck myself). So what I slept in a bed
that was more like a hammock. So what the walls were paper thin and I got
to listen to every TV program, every snore, every... never mind. So what
that I could barely reach the rudder pedals in the factory RV-6. I got to
actually fly one of these beauties! It really was fun! The plane's
handling was exceptional. For those of you who haven't flown one, who have
maybe flown mostly Wichita aircraft (like myself), this thing don't handle
like a Cessna!
There were actually a couple of things that surprised me about how it
handled. First, it wasn't as hard to slow down as I had imagined it to be.
I'm used to Citabrias, and Champs, where you pull the throttle back abeam
your landing point. I was really intimidated by the slipperyness of the
RVs. But it turned out to be no problem. Just throttle back to 1800 rpm
out on the 45 and you'll be good to go.
The other surprising thing was how it stalled. Exactly opposite of what I'm
used to. The power-off stalls are very abrupt and the power-on stalls are
fairly docile. The extreme pitch-up attitude was pretty disconcerting to me
as well during the power-on stall.
Builders, if you haven't got any stick time in these things go get some.
They are great flying airplanes but they do have a few gotchas. If at all
possible take the transition training with Mike. You will never find a more
patient flight instructor. That really is a testament to his character,
that he can still be so patient after all the transition training he's
given. Oh, and if you do travel to Vernonia for the training and stay the
night, be sure to mention to Mike how great the picture quality was on your
TV. Yes that's an inside joke and you'll just have to wait for Mike's
response to find out what that means.
Oh, I almost forgot. Mike only teaches three point landings. ;-)
Scott VanArtsdalen, MCSE, CCNA
Network Manager
Union Safe Deposit Bank
209-946-5116
Transition Training
I just got back from transition training with Mike Seager this past Friday. This
was only my third time in an RV and my first time flying one. What a nice flying
airplane and what a nice guy. So what I had to drive 10 hours to get to Vernonia.
So what that I ate dinner at the Disfunctional Redneck Pizza Parlor (it's
okay, I'm a redneck myself). So what I slept in a bed that was more like
a hammock. So what the walls were paper thin and I got to listen to every TV program,
every snore, every... never mind. So what that I could barely reach the
rudder pedals in the factory RV-6. I got to actually fly one of these beauties!
It really was fun! The plane's handling was exceptional. For those of you
who haven't flown one, who have maybe flown mostly Wichita aircraft (like myself),
this thing don't handle like a Cessna!
There were actually a couple of things that surprised me about how it handled.
First, it wasn't as hard to slow down as I had imagined it to be. I'm used to
Citabrias, and Champs, where you pull the throttle back abeam your landing point.
I was really intimidated by the slipperyness of the RVs. But it turned out
to be no problem. Just throttle back to 1800 rpm out on the 45 and you'll be
good to go.
The other surprising thing was how it stalled. Exactly opposite of what I'm used
to. The power-off stalls are very abrupt and the power-on stalls are fairly
docile. The extreme pitch-up attitude was pretty disconcerting to me as well during
the power-on stall.
Builders, if you haven't got any stick time in these things go get some. They are
great flying airplanes but they do have a few gotchas. If at all possible take
the transition training with Mike. You will never find a more patient flight
instructor. That really is a testament to his character, that he can still
be so patient after all the transition training he's given. Oh, and if you do
travel to Vernonia for the training and stay the night, be sure to mention to
Mike how great the picture quality was on your TV. Yes that's an inside joke and
you'll just have to wait for Mike's response to find out what that means.
Network Manager
209-946-5116
Thanks. I was able to find it in the ACS catelog online using the part
number you provided, but not in my 2001-2002 paper catelog. Anyway ....
$65! That seems a little steep for the dozen or so hose ends I have.
Is it worth it? Is everyone else doing this?
Larry Bowen
> -----Original Message-----
> TColeE(at)aol.com
> Sent: Monday, September 30, 2002 11:41 AM
> Subject: Re: RV-List: Firesleeve dressing?
> Catalog page
1998 RV-6A with sliding canopy, 200TT , 200 since overhaul on 200 HP
IO360A1B. 200 hrs on Hartzell CS prop. Day/night VFR. Full gyro panel.
Intercom, Transponder/Mode
C, engine analyser and more. Cabin heat. Electric elevator and aileron
trim. G meter. All interior parts primed. US$80K Contact off-line
at marc_guay(at)hotmail.com for pictures or more information.
Marc Guay
Ottawa Ontario
Canada
CF-WUV
Hello Larry,
Recently I had to shorten one of my oil lines. When the time came to apply
the dressing, I found the remainder of the small amount that had been given
to me for the job had set up.
It seems that once the original can is opened it will begin to set up. If
this is the case, be wary about bying a larger volume than you will need.
In place of the original material I used some red RTV.. The RTV. though not
as nice to use worked out well enough that I will use it again for dressing
future mods or repairs.
I hope this helps,
Jim in Kelowna
Subject: RE: RV-List: Firesleeve dressing?
> Larry Bowen
> > TColeE(at)aol.com
> > Catalog page
From: | kempthornes <kempthornes(at)earthlink.net> |
Subject: | Re: North Dakota |
DIrect? Sorry, HillStw, but there isn't anything to see there.
I grew up in Kansas, nothing there. I have been to weddings and Navy
training in Oklahoma, nothing there. I have criss-crossed Nebraska several
times to and from Oshkosh, nothing there. South Dakota has the Black
HIlls, badly eroded lands which many midwesterners find disgusting. The
Park service will not appreciate any of the erosion control measures you
might feel like implementing. I don't recall which Dakota has the stone
heads. We lived in Minot but I don't remember it.
I suppose you've been to the Grand Canyon, the Ozarks, Santa Fe, the
Rockies, the Pima Air Museum?
There's not much in California either.
K. H. (Hal) Kempthorne
RV6-a N7HK flying!
PRB (El Paso de Robles, CA)
>Larry Bowen
Well no. I went down to WalMart and bought a can of tool handle dip for
a few bucks. Not sure what it is actually called but it works nifty.
Trouble is, when I revealed this to the list someone thought I was
endangering my life and the lives of others because maybe this stuff can
burn. Of course there is a total of about 1 ounce of the stuff in the
whole airplane.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Hal,
How is that Alzheimer's medication working?
Nothing to see in California?? Do we live in the same State?
The "Stone heads" are in the Black Hills of South Dakota.
Rapid City was one of ours stops this summer flying the
RV6A across the country. I found Mt. Rushmore and the Black Hills
fascinating. The people and the FBO were all great.
Ed Cole
RV6A N2169D Flying
RV6A N648RV Finishing
> From: kempthornes [SMTP:kempthornes(at)earthlink.net]
> Sent: Monday, September 30, 2002 10:19 AM
> Subject: Re: RV-List: North Dakota
> several
> RV6-a N7HK flying!
Maxim Home Page:
http://www.maxim-ic.com
Products Page:
http://www.maxim-ic.com/MaximProducts/products.htm
New Products:
http://dbserv.maxim-ic.com/new_products.cfm
Datasheets:
http://dbserv.maxim-ic.com/l_datasheet3.cfm
The information contained in this message is confidential
and may be legally privileged. The message is intended
solely for the addressee(s). If you are not the intended
recipient, you are hereby notified that any use, dissemination,
or reproduction is strictly prohibited and may be unlawful.
If you are not the intended recipient, please contact the sender
by return e-mail and destroy all copies of the original message.
From: | "Ernest Kells" <ernest.kells(at)sympatico.ca> |
Subject: | Adapting Exhaust Sysem for O-235 N2C |
Can someone with O-235 and/or O-320 experience could help me. I will be
installing an O-235 N2C on an RV-9A pretty soon. Vans nearest exhaust is
the Vetterman one for the 320/360 (EA EXH W/MUFF). I asked Gus at Vans
what I should order. He said to order the above - - and modify it myself to
fit the O-235. He couldn't remember what they did to put it on the O-235 in
the first factory prototype. The prototype shop remembers it as "wasn't too
bad". This is stainless steel. The nearest shop I trust is over 200
miles away. I could shorten a pipe or two - but I can't lengthen one or
change angles of bend, etc., myself.
Does someone know what the changes would be (the bad news)?? Thanks.
P.S.: The Fab Air Box will fit really good - I have to remake one part,
using the existing as a template.
P.P.S.: The baffle kit will be probably be much different - I may order
just the plans and make it myself.
(Just a heads-up for others considering the O-235.)
Subject: | Re: Need help on starter decision making. |
Hello Daniel,
If you have any mild steel stuff that has been stored long term in the area
that you propose to build in and these items are not been adversely effected
by ambient humidity and weather over the years, you might be alright to
build there.
If things such as nails, tools, cans, steel wool etc. rust quickly and
easily, give serious consideration to temporarily enclosing the area and
providing at least a small source of heat.
It sounds to me to be quite a small area to build in, can it be added to
with simple temporary extensions as the building proceeds?
As to the dimple dies a set of 3/32" and 1/8" will get you started. Go to
Vans web site and look into "resources" for tool suppliers and other useful
links. The various tool suppliers catalogs will outline and describe in
detail the tools needed for the Vans RV series aircraft.
A trip to Sun and Fun in Florida could be a good idea for picking up lots of
tools, ideas and basic supplies. While there stop in at the Fantasy of
Flight museum for a while.
Happy building,
Jim in Kelowna
From: "Wier, Daniel C." <daniel(at)thegreatwhite.net>
Subject: RV-List: Need help on starter decision making.
can find, Visiting some very nice people who are building, and talking to
many others. I thank everyone of you who have given me help and now am
getting ready to start. I have a few questions.
the area I will be building in is 20x10 and seems to be large enough, but
will be open to the outside air. Will this pose a problem for mosture in
building each section of the aircraft and anything else you can think of? I
have almost all the tools I need to start the first kit, but wanted to know
what size dimple dies I need.
building that would show a top and side view of the plane and a user can
click on any part of the plane and display the log of that part with
pictures below. Also each part would be color coded to the progress on it.
The whole thing would have a simple owner tool for inputing the daily log,
pictures, time, money spent that day, ect. The app would keep track of the
total cost, cost per section, time and time per section auctomaticly for the
owner. If anyone is interested in this, I would be willing to hand out the
> Daniel Wier
Subject: | Re: RV-6 Alternator |
14684 fits Suzuki's Samurai 86-95 , and 89 Sick kicks...from the Lester
catalog. This is a LESTER#.
Barry Pote RV9a fuselage finishing
> Has anyone had this problem before? How about the other one (14684) from Van's?
I understand that it is a 60 amp alternator. I have tried to locate it from
the parts houses but Pep Boy says that it is a NAPA number and NAPA says they
never heard of it.
Hi again Daniel,
In Van's web site look into "required tools" under "building an RV" for the
tools suggested and tool suppliers sites.
Jim in Kelowna
Subject: Re: RV-List: Need help on starter decision making.
> Hello Daniel,
area
effected
> build there.
useful
of
> Happy building,
> Jim in Kelowna
> To:
I
know
it.
the
the
the
> > Daniel Wier
Subject: | Re: Transition Training |
Having had some training from Mike, I can strongly endorse Scott's remarks.
Also, for those of you a long way from the Pacific Northwest, I can attest
to the quality of transition training received from Alex DiDomenicus,out of
Arlington, TX (Dallas area).
Whoever you get it from, get some before you try to fly your RV.
George Kilishek
>From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
>To: "'rv-list(at)matronics.com'"
>Subject: RV-List: Transition Training
>Date: Mon, 30 Sep 2002 09:08:25 -0700
>like a Cessna!
>I'm
>me
>more
>Network Manager
>209-946-5116
>Transition Training
>actually fly one of these beauties! It really was fun! The plane's handling
>was exceptional. For those of you who haven't flown one, who have maybe
>flown mostly Wichita aircraft (like myself), this thing don't handle like a
>Cessna!
>RVs. But it turned out to be no problem. Just throttle back to 1800 rpm out
>Network Manager
>209-946-5116
Interesting about the firesleeve end dip stuff, now, can someone explain how
you use or apply the stuff? Surely you don't literally dip the end of the
completed hose in it and I can't imagine trying to assemble a hose with the
ends of the firesleeve gooped up with something. Hope someone out there can
shed some light on this.
Harry Crosby
Subject: | Re: Adapting Exhaust Sysem for O-235 N2C |
Ernest,
Call and talk to Larry Vetterman. He will know what you need and will either
modify your exhaust that you bought from Van's or exxchange it for one that
will fit. I can't remember his phone number but it is available in the
archives, from Van's, or on the RV Yellow Pages.
MIke Robertson
RV-8A, 6A, and 9A
>From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
>To: "\(RV LIST\)"
>Subject: RV-List: Adapting Exhaust Sysem for O-235 N2C
>Date: Mon, 30 Sep 2002 14:38:34 -0400
>to
>in
>too
Subject: | Opps! Messed up my horiz. stab skin! |
My RV7 is no longer perfect! I was getting the hang of my pneumatic
squeezer to dimple the skin on the horizontal stabilizer (after practicing
on some scrap even!) and before I knew what I had done I had punched a hole
(with dimple of course) in the skin where there was no hole! The "extra"
hole is about 3/4" from the inboard end of the skin so it will not hit a
rib. It is on the bottom so whatever repairs I effect will probably only
bother me.
Question is: what is the best way to fill the hole?
Allen Fulmer
RV7 empenage
N880AF reserved
Subject: | Re: Opps! Messed up my horiz. stab skin! |
No worries. Debur it well, slap an AN426AD3-3 in there, and call it a day.
8
)_( Dan
Subject: RV-List: Opps! Messed up my horiz. stab skin!
hole
> bother me.
> Thanks,
> Allen Fulmer
> RV7 empenage
> N880AF reserved
Allen:
Put a rivet in the new hole and move on. If you don't tell anyone it's
there, then I won't! ;
Jeff Orear
RV6A
fuselage....drilling landing gear mounts this weekend
Peshtigo, WI
hole
> bother me.
> Thanks,
> Allen Fulmer
> RV7 empenage
> N880AF reserved
a Flat head rivet for tyhe proper size.
hole
> bother me.
> Thanks,
> Allen Fulmer
> RV7 empenage
> N880AF reserved
>bother me.
>Thanks,
>Allen Fulmer
I'd take a close look at the new hole to make sure there weren't any
signs of cracks. Any cracks, or sharp edges should probably be
removed with a small round needle file. Then just put a rivet in it.
Kevin Horton RV-8 (cowling, wing tip lights)
Ottawa, Canada
http://members.rogers.com/khorton/rv8.html
Allen,
Put a 426 shortened rivet in the hole to fill it in,
then fill the head in with superfil only you will know.
ray
hole
> bother me.
> Thanks,
> Allen Fulmer
> RV7 empenage
> N880AF reserved
I assumed you dip it before assembly on the hose, then let it dry.
Larry Bowen
> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)aol.com
> Sent: Monday, September 30, 2002 4:39 PM
> someone explain how
> the end of the
> hose with the
> Harry Crosby
From: | "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net> |
Subject: | Oil Door With Torsion Coils |
I would like to install oil door hinges with torsion coils, or similar
mechanism, to keep the oil door open. Two camlocs would normally keep the
door closed.
Does anyone know where I could buy such hinges?
Any other suggestions would be appreciated.
Thanks.
Gabe A Ferrer (RV6, SE Florida, N2GX reserved, I think that I'm getting
close to finishing?)
Cell: 561 758 8894
Night or FAX: 561 622 0960
Just a headsup to those considering desser retreads. While they should wear
like iron, they are definitely taller than non-retreads. They may not fit
if your wheel pants are tight.
Don Mei
RV-4 N92CT
3B9 - Chester, CT
Americans used to roar like lions for liberty: Now they bleat like sheep for
security
Norman Vincent Peale
Subject: | Re: Desser Retreads |
Now you tell me. I ordered a pair and there sure is a lot of tread on the
tires. I was able to sell them for what I paid for them to a friend who was
just ordering his finishing kit and he deleated his from the order. I would
have really liked to have been able to use them. Terry E. Cole
>was
>would
TC,
I just received a set of Desser retreads. These particular ones are built
on Aero Trainer 6 ply carcasses. By no means would they pass as "new", but
the recap tread is thick and feels really tough....which is good....because
we high density altitude types touchdown at ludicrous speed! I'm down for
annual now and might mount them up if I decide to not rotate the Condors.
My tires wear on the insides so a right-left/inside-outside swap might yield
another year's use at my current rate of RVating.
Hope to see ya at LOE again.
Brian Denk
RV8 N94BD
302 hrs of tire squeeking glee.
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
Subject: | pictures of bending longerons? |
Anybody have any online (or emailable) pictures of bending the longerons?
I've got a half decent picture in my head of how I'm going to do it, but a
photo or two would help complete the picture a bit. Any tips and tricks or
advice are much appreciated.
Thanks in advance,
)_( Dan
Hi Harry,
I applied the stuff that was given to me with a short haired stiff brush.
When fresh out of the container it applied easy and soaked into the white
fuzz so much that a second and even a third coat was in order.
Jim in Kelowna
how
the
can
> Harry Crosby
> to the main gear web but then how do I manage to turn the tight
> corner, avoid rubbing the gear leg, avoid kinking the tube, through
> the rubber grommet and then onto the fuel pick up line. The area is
> too tight for a tube bender. Any ideas? I've tried twice and just
As I recall, I used the "spring" tube bender for that area. It's a set of
cheap ($10) springs of various sizes, into which one inserts the tube to
be bent. Then one bends the tubing and the spring together. The
spring helps distribute the bend and supports the tube to minimize
kinking.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD - First Flight 18 Dec 99
http://www.geocities.com/timrv6a
I have made my own firesleeve end dip by thinning Red RTV with MEK to a syrup
consistency.
> get it?
Brian,
We installed our Dresser retrads about 50 hrs ago and didn't have aproblem
with our wheel pants. They still look good - no wear that we can see.
Chuck & Dave Rowbotham
rv-8A
>From: "Brian Denk" <akroguy(at)hotmail.com>
>Subject: Re: RV-List: Desser Retreads
>Date: Tue, 01 Oct 2002 03:30:46 +0000
>the
> >was
> >would
>TC,
>yield
>Brian Denk
>RV8 N94BD
Larry et al,
I have seen the firesleeve ends finished with red RTV as some have mentioned.
The tool dip stuff sounds OK too. $65 for firesleeve dip sounds outrageous.
A very nice way to finish the end is to apply a section of heat shrink tubing over
the installed firesleeve. Install the firesleeve, add a 2" section of shrink
tubing, shrink it down and put your clamp or safety wire over the shrink tubing.
Remember to put the shrink tubing on before you tighten all the fittings...
doh!
Of course, the shrink tubing can melt in the event of a fire, so you might not
want to rely on it as the only firesleeve clamp, although it makes a very neat
installation that way i.e, without using a metal clamp.
You can get shrink tubing in all different sizes at any electronics or electrical
supply house.
Vince
F-1H Rocket
Subject: | RV-4's at Cooking Lake, Edmonton, Canada |
Hi all,
I'm a British RV-4 builder who is soon to be found hanging around Cooking
Lake, Edmonton for a month (6th Oct thru 4th Nov) aquiring my Canadian PPL.
If any RV-4 folk are in the area - builders, flyers, wannabe's and want to
talk -4, please email me direct.
Also of interest would be information of a local EAA chapter.
Many thanks,
Bruce Naylor
RV-4
From: | "Stephen Johnson" <spjohnsn(at)ix.netcom.com> |
Subject: | Re: pictures of bending longerons? |
Dan,
I had good luck by clamping the longerons between long sections of 2x4 and
bending rather than using a hammer. I had to cut an angle in one of the 2x4
sections for clearance. This wan't my idea, but I can't remember where I
heard about it. A definite two person job.
Steve Johnson
RV-8 #80121 fuse
Subject: RV-List: pictures of bending longerons?
or
> Thanks in advance,
> )_( Dan
Folks,
cheap trick on the tool/firesleeve dip stuff. It uses a fairly strong
solvent that tends to wick right through the vinyl lid they supply with the
can it comes in. This is designed such that you will use it only once and
then have to buy more when you go to use it again in three months.
I've had a can of the tool dip in my hangar refer with two layers of
Aluminum foil between the can and the vinyl cap for about three years now
and it keeps the stuff nice and runny fresh.
Also, make sure you don't mistake it for the peanut butter jar :{)
RE use on firesleeve, who gives a poop if it will burn. Firesleeve is
designed to give you about five minutes of flying time to get to the ground
before allowing more fuel to be added to the fire. The slight sizzle from a
small amount of end dip won't effect this much, particularly if the dipped
portion is over the metal fitting.
W
Subject: | Paint quantities |
Greetings RV Listers,
I am seriously considering painting the outside of my RV-6A myself. I
would be very interested in comments from others who have done their own
painting. Among my questions are:
* Type and brand of paint
* Type of surface preparation
* Primer (not to awaken the war)
* Quantity of primer, paint, activator, thinner or other components.
* Were you happy with the result?
Thanks in advance.
Richard Dudley
-6A N331RD
version=2.41
On Tue, 1 Oct 2002, Stephen Johnson wrote:
> Dan,
This is what I did, but I had no trouble doing it myself. Just clamp
the longeron to something big and heavy (I used a 50# anvil), then lean on
the 2x4. You do need to bend quite a bit past the target point to allow
for springback.
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 Delayed, building a bed.
1/4 Starduster II N23UT flying
In a message dated 9/30/02 5:39:43 PM Pacific Daylight Time,
afulmer(at)charter.net writes:
<< The "extra" hole is about 3/4" from the inboard end of the skin so it will
not hit a
bother me. >>
With a rivet.
Harry Crosby
In a message dated 9/30/02 9:10:20 PM Pacific Daylight Time,
advice are much appreciated. >>
I followed the illustration and text in the instruction manual (RV-6) and
mine came out fine with just a touch of final tweaking to get things aligned.
If the 7 manual doesn't include those instructions maybe I could fax those
pages to you.
Harry Crosby
Give up. You've ruined the project. It'll never fly straight and people
will laugh at you. Sell the pneumatic riveter to me at half price.
Chuck : )
practicing
> hole
"extra"
only
> > bother me.
> > Thanks,
> > Allen Fulmer
> > RV7 empenage
> > N880AF reserved
May I add one to your list?
* Paint before fisrt flight, or not?
Larry Bowen
> Richard Dudley
> Sent: Tuesday, October 01, 2002 1:22 PM
> Subject: RV-List: Paint quantities
> myself. I would be very interested in comments from others
> who have done their own painting. Among my questions are:
> Thanks in advance.
> Richard Dudley
> -6A N331RD
Subject: | Re: Paint quantities |
I painted my own plane and have documented the process at...
www.rv-8.com/Paint.htm
To answer Larry Bowen's subsequent question on whether to paint before or
after flight, I would personally recommend before. You can paint the plane
in pieces which is far easier and yields better work, and with reasonable
care you won't get any scratches, I didn't.
Randy Lervold
RV-8 268 hrs
www.rv-8.com
Home Wing VAF
> Thanks in advance.
> Richard Dudley
> -6A N331RD
Yep, been there. Thanks anyway.
Subject: | Re: Oil Door With Torsion Coils |
In a message dated 9/30/2 9:44:47 PM, ferrergm(at)bellsouth.net writes:
Gabe,
I have seen such a hinge on an oil door, but when I went to the source the
builder told me he got it, they no longer had them. I ended up making my own
hidden spring loaded hinge by copying the gas cap door on my truck. Riveted
some .032 or .040 (can't remember) to a piece of piano hinge and bent it
around like the one on the truck. Then removed one section of hinge and put a
spring in there. I think I used a spring off of a toggle bolt. The opening
for the door has a flange for the door to rest on and is held shut by one
hartwell latch. My door is fairly small, so you might want two latches for a
large door. I also rounded the corners instead of making them square for
looks. You can do this by using one of those round, cut anything, blades for
a hack saw to cut the corners.
Hope this helps.
Pat Allender - RV-4
doing first condition inspection - can't believe it's been a year!
> < mechanism, to keep the oil door open. Two camlocs would normally keep the
> door closed. >>
Below is what I did.
Ross Mickey
RV6A
From: ABAYMAN(at)aol.com Date: Sep 10, 2001 Subject: Re: streamlined oil
cooler door
Listers
some of you were waiting on my pictures of my oil door, go to the link below
and see them. at the bottom of this is the steps i took to achieve the
results.
http://members5.clubphoto.com/scott351659/504362/owner-b6b0.phtml
enjoy
scott
tampa
Stream lined oil cooler door
by Scott Reviere
1. cut away the recess in the coweling as you would normally do.
2. find the best contour of the oil door and place it under the hole you
now
have in the coweling
3. trace the area of the oil door and leave it slightly longer.
4. cut the traced area out of the door, and measure carefully and cut at an
angle
( slant ) through the center, so you have 2 pieces that bevel where they
mate
in the middle.
5. use the hinges that came with the kit and remove 2 eyes in the center of
2 pieces for each door. ( you have 2 doors now that you cut the main oil
door
in half)
6. insert a mouse trap spring in the missing eyelets and insert the pin.
do this on both hinges so you have a mouse trap spring on each door. rivit
the hinges to the cowel.
7. to keep the door from popping up through the cowel, rivit strips of the
oil door you removed earlier when you trimed the door to fit. you have to
make a spacer under each of the strips, so the doors will end up flush with
the outside of the coweling.
8. put a very thin coat of epoxy mixed with microballoons and sand as
necessary to acheive a perfect contour, gap around the doors, and center
seam.
9. make sure you don't get epoxy in the springs or hinges.
10. sand the strips inside to make a nice looking surrounding of the door.
11. with the center seam at a slanted cut, the top door closes first, and
the
bottom door closes last every time so the seam will hardly be noticable.
note.
when this is done, you can adjust the tension of the mouse springs as
necessary by bending the ends and curling them down toward the cowel. you
can
make the doors as tight or as loose as you want.
by luck, mine turned out like this.
you press the doors inward a little and they snap back.
you press them in all the way and they lock open ( the spring binds )
you press them again and the snap back.
it didn't take long to do this, and is lighter, more streamlined, and is
easier to open and close, no moving parts or hardware latches. also being
able to have it stay open after flights to relieve built up heat in the
engine compartment is a extra benifit.
well that's my contribution to the list for the week.
hope you enjoy it
scott reviere
tampa, fla
rv6a N747ES reserved O360 c/s
> Thanks in advance.
> Richard Dudley
> -6A N331RD
Details of my painting saga:
http://home.hiwaay.net/~sbuc/journal/paint1.html
Yes, I was happy with the results, and VERY happy I painted the plane
before flying it!
Sam Buchanan (RV-6)
In a message dated 10/1/02 1:33:01 PM Eastern Daylight Time, rhdudley(at)att.net
writes:
Thanks in advance.
Richard Dudley
-6A N331RD >>
First thing - my paint job is very good for something created in a garage by
a first time painter. I learned a lot during the process, and am very proud
to stand by my airplane at a fly-in and tell everyone that not only did I
build the airplane and engine, I also designed the paint scheme and sprayed
the paint. On the other hand, painting is a miserable process (IMO), and I'm
not sure I'd do it again without better facilities than my garage and back
yard.
I used Dupont Centari, which is a catalyzed enamel. If I had it to do over,
I'd probably go with PPG Concept, which gets high marks from anyone who uses
it. As a primer, use whatever the product rep says is compatible with your
top coat. An epoxy is best, but there are many non-epoxy primers that are
just fine.
My surface prep was wiping down with a wax/grease remover, then a mild etch
and scuff with scotchbrite, then rinse, then wipe again with the wax/grease
remover.
Properly done, you could paint an airplane with a gallon of primer, 3
sprayable gallons of paint (assuming a solid base coat), plus trim paint. If
you're not "up" on paint, a sprayable gallon of paint includes reducer,
catylist, and the paint itself. You'd need a gallon of thinner for clean-up,
etc. If you're a first time painter, you'll probably need more of everything
because you'll sand off paint, and have to respray, or you'll run into
problems and have to dispose of a pint of mixed paint here and another pint
there. Pretty soon, the waste adds up. FYI, wasted paint is expensive. A
sprayable quart of Imron or Centari costs $40 or more...
You also need a bazillion mixing cups and sticks, nitrile gloves, and a
forced air breathing system, which you could make for $25 using instructions
you can find in the archives.
Kyle Boatright
0-320/Aymar Demuth RV-6 Slider
Kennesaw, GA
http://www.angelfire.com/my/rv6
From: | "Jim Norman" <jnorman(at)intermapsystems.com> |
The easy answer here is to buy a Cessna oil door hinge.
It is hidden completly, and has a spring that holds the door open. Very
slick, quite simple, and looks fantastic.
I'm not sure what model of Cessna this comes from, but I have one, and it is
perfect for this application.
See pictures here:
http://www.steinair.com/jn/
Click on the "Misc" link to see open and closed version of this door.
jim
Tampa
> Does anyone on the list know if the cables that come
> from vans have had any problem with
> the amount of throw or travel amount..With
> my RV6 (180) cable stated in Vans Catalog (41.5)
> I find that the throw is only 2.3 inches .The mixture arm
> travel is 2.65 inches !!! And the same cable in ACS cat shows
> the same cable to have a throw of 3.37 inches..
If you look in Aircraft Spruce's catalog, there is a page which
describes the variables on control cables like the ones made by ACS
(btw, this is not Aircraft Spruce). When the cables are straight (an
unlikely case), their travel is full. For each degree of bend in the
cable, there is a decrease in the travel. One must take this into
account when getting cables. Van's cables will not get you the amount
of throw you need if there are bends in the cable (unless they have
changed what they stock in the last couple years).
Alex Peterson
Maple Grove, MN
I have an O-290G which has a leaky fuel pump. I would appreciate advice regarding
the cost and ease of rebuilding this. I have decent mechanical skills but
no experience in this area. Where would I find directions for rebuilding this
and what parts might I need and where are these to be found.
I f this isn't viable how about using a pair of electric pumps instead?
Thanks for your help guys.
Rob
Rob W M Shipley.
RV9A fuselage. N919RV resvd.
Subject: | Re: Mixture Cable |
Van's cable will give you the proper throw, as long as you order the one for
the RV-9. It is slightly longer and is perfect for an O-360 RV-6. I went
through 3 mixture cables from Van's and Spruce before I found this out. Why
Van's sells a mixture cable that will not work, is beyond me, but the RV-9
cable will work.
Paul Besing
Subject: RE: RV-List: Mixture Cable
> Alex Peterson
> Maple Grove, MN
Subject: | Seat Rib attachment to F604 |
I've got a question that I don't see mentioned in the archives. How have others
dealt with fitting the seat ribs to the F-604? The 604 is a supposed to be
positioned at a slight angle (vertically), therefore, the seat rib flange does
not sit flush on the 604. The top (bottom of the fuselage) of the rib touches
just right but the opposite end of the flange is about 1/8" away from the 604.
The only solution I can see is to:
1. Shim the Rib
2. cut a slit in the flange and bend it so that it fits appropriately.
Any other ideas?
Mike Nellis http://www.bmnellis.com
Austin, TX
Stinson 108-2 N9666K
RV-6 N699BM (Fuselage)
1. Shim the Rib
Any other ideas?
Austin, TX
Subject: | Update on: Opps! Messed up my horiz. stab skin! |
Thanks for all the help on fixing an errant hole in the skin. I clecoed the
rib back in place to make sure I had room for the shop head of a flush rivet
and sad to say, the hole is right over the radius of the flange and web.
The countersink actually holds the skin off the rib a little. Looks like I
can probably flatten the metal out and then fill it with something before
finish priming and painting.
Is that the right way to handle the repairs?
Allen Fulmer
RV7 empenage
N880AF reserved
Alexander City, AL
Hello Richard;
I am at about the 80% mark in painting my RV-6A so perhaps I can offer some
useful comments. First of all, I would second all of Kyle's words in the
message below. Painting your airplane yourself is certainly doable but it's
lots of work, it's a long messy job and requires lots of dedicated shop
space. Assuming you section off a part of your shop or garage with poly to
use as a paint booth, it is going to be out of action for two to three weeks
and probably longer. There is a learning curve in spraying paint to make
your way up which will cost you some time and wasted paint but you will get
there eventually!
Paying a pro to do the job will bypass most of the above as he will have the
shop space and spray equipment ready to go and he will be far ahead on the
learning curve for personal skills. Having said this, painting is about 90%
preparation and 10% actual paint application. Doing your own preparation and
letting a pro do the final spray job would be a good way to go. Most amateur
builders handle the various bits and pieces of their project often enough
that there will likely be an accumulation of dings, gouges and whatever to
deal with plus probably some mis-driven rivets, gun slips, etc. In other
words lots of fiddly little bits of filling, sanding, and re-priming will be
needed. Paying a pro to do this work will cost lots just on the time
involved, so better to look after this yourself. The ability to pace the
work and take the time to suit yourself about fixing all the small details
is one of the advantages of doing your own painting.
I am using PPG Omni paint on my project. This is a somewhat lower cost line
than the PPG Concept paint that others have reported using. I'm not penny
pinching but just being realistic about what I needed plus I found a
supplier who went out of his way to be helpful to a beginner and that's the
main product line he carried.
My process for aluminum surfaces:
- wash with TSP (a heavy duty grease cutting detergent)
- scrub with scothbrite to break the surface shine
- treat with alodine solution
- degrease with MX 190 cleaner (it's mostly naptha)
- spray thin coat MP176 etch primer
- spray MP 170 expoxy primer
- spray MTK Acrylic Urethane topcoat
Looks complicated but it is possible to go from bare aluminum to final
colour in a single session (3-4 hours) for small components (eg, a vertical
stab).
For fiberglass components (after finish sanding, filling, etc.)
- degrease with MX190
- spray with MP 170 epoxy primer
- spray on MP 182 2K urethane surfacer
- sand as required
- final coat of MP 170 epoxy primer
- MTK Acrylic Urethane topcoat
The surfacer is to deal with the dreaded "pinhole" situation. The later type
"S" cowlings have a lot of weave and pinholes (mine had anyway) and the MP
182 "surfacer" stuff did surprisingly well in coping with this. Expect to
spend a lot of hours of hand sanding the cowlings and other fiberglass
parts.
I am using a solid yellow paint scheme and will add vinyl lettering and
pinstriping. I expect to use about 2 US gals of MTK urethane paint (yellow
top coat), 1.5 US gals of epoxy primer, 2 qts of etch primer, and one quart
of surfacer. Plus there are catylsts and hardeners needed for each of the
above. Plus I will use about 1/2 gal each of reducer and cleaner. Plus about
1.5 gals of plain lacquer thinner for gun and general clean-up.
Others things to figure in, paint gun (to suit your price range - lots of
choices out there), suitable compressor to run the spray gun (likely a
bigger one than you got along with when riveting), materials for paint booth
(I used 100 ft of 1x2 wood strips, plus 60x8 ft of poly), exhaust fan for
paint booth, mask with air supply, goggles, 3-4 pairs of rubber gloves,
lots of paper towels, masking tape and paper, a couple of tyvek disposable
coveralls, lots of sandpaper. So you can see the cost do add up rather
quickly when it is paint time. Makes one think again about getting a pro to
do the job!
Jim Oke
Winnipeg, MB
RV-6A
Subject: Re: RV-List: Paint quantities
> writes:
> Thanks in advance.
> Richard Dudley
> -6A N331RD >>
by
proud
sprayed
I'm
> yard.
over,
uses
your
> just fine.
etch
wax/grease
> remover.
If
clean-up,
everything
pint
A
instructions
> Kyle Boatright
> Kennesaw, GA
Subject: | Re: Update on: Opps! Messed up my horiz. stab skin! |
Hi Allen,
That'll do it!
Jim in Kelowna
Subject: RV-List: Update on: Opps! Messed up my horiz. stab skin!
the
rivet
I
> Thanks,
> Allen Fulmer
> RV7 empenage
> N880AF reserved
> Alexander City, AL
Subject: | Re: RV6-List: Seat Rib attachment to F604 |
Make sure the F604 is tilted the correct direction and correct amount of
tilt. Also, check the attach points at the F605. If seat rib is too high
at the F605, it will give a gap on the other end of the seat rib at the
F604. Shims shouldn't be necessary.
Jerry Calvert
Edmond Ok
RV-6 N296JC(res)
Subject: RV6-List: Seat Rib attachment to F604
> --> RV6-List message posted by: "Mike Nellis"
others dealt with fitting the seat ribs to the F-604? The 604 is a supposed
to be positioned at a slight angle (vertically), therefore, the seat rib
flange does not sit flush on the 604. The top (bottom of the fuselage) of
the rib touches just right but the opposite end of the flange is about 1/8"
away from the 604.
> 1. Shim the Rib
> Any other ideas?
> Austin, TX
door closed.
Thanks.
Cell: 561 758 8894
Mike,
I just fit those ribs on my circa-1999 kit and this is my second kit. I can
assure you they should fit flush. I suspect you have the angle of the F-604
reversed. The spacing of the F-604 from the firewall is 29 1/2 at the floor
end (top in the jig) and 29 15/16 at the longeron end (on the jig). That
spacing sets your wing incidence.
Greg Young - Houston (DWH)
RV-6 N6GY - project Phoenix
Navion N5221K - just an XXL RV-6A
> How have others dealt with fitting the seat ribs to the F-604?
> The 604 is a supposed to be positioned at a slight angle
> (vertically), therefore, the seat rib flange does not sit flush
> from the 604.
> 1. Shim the Rib
> Any other ideas?
> Austin, TX
Gabe,
Go to http://www.mcmaster.com/
type "spring cabinet hinge" in the FIND window.
Scroll down and look at items #1-5
I used item #11205A35 for my hinges. To find it,
search under "weldable concealed hinges"
I used those hinges in combination with a single
hartwell latch. Incidentally, the door will hold itself
open with a slight axial misalignment of the two
concealed hinges.
I made my oil door out of .063 2024T3 Aluminum. I have
seen to many fiberglass doors distort and from the
engine heat. The aluminum door has been trouble-free.
It looks great too!
Hope this helps.
-Glenn Gordon
RV-6, N442E
> door closed.
> Thanks.
> Cell: 561 758 8894
Subject: | Fuel Pressure Problem |
Hi,
I am getting high fuel pressure readings. I am almost
positive that I have a bad transducer.
With the engine off, should I have a fuel pressure
reading other than zero?
With the engine off, what kind of rise in fuel pressure
should I see when I turn the aux pump on?
Glenn Gordon
Hello,
I'm in the market for an RV6, looking for a good IFR cross country machine. Just
sold my Mooney and want to get a plane that does not cost as much to maintain
but is just as fast (prefer faster!).
I've seen lots of speed claims with both the -320 and -360 engines, what are you
owners actually seeing for cruise speeds and fuel burns with these engines?
I'd really appreciate any tips/suggestions on the gotchas to look for when shopping
for a nice RV6.
Thanks in Advance,
Reggie Smith
I have used stainless steel wire ties (Mcmaster-CARR) cost about a
dollar each. I dressed up the fuzzy ends of the firesleeve with red RTV
and closed off the end with one of the S/S wire ties. Looks like the
real thing. Also, the lawn sprinkler/irrigation supply stores here
sells the S/S crimp type hose clamps. You use a nipper or dykes to pull
or squeeze the clamp closed. I used these also on the fire sleeve and it
looks & works great. Either of these two S/S clamps make the hose look
finished and not like "harry homeowner" did it.....(which he did)
Subject: | Seeking an RV 6/7/8 |
Hello,
I'm in the market for an RV6/7/8 (prefer the 6), looking for a good IFR cross country
machine. Just sold my Mooney and want to get a plane that does not cost
as much to maintain but is just as fast (prefer faster!).
for a nice RV6.
Thanks in Advance,
Reggie Smith
Subject: | Reminder Coastal Georgia Fall Fly In |
A quick reminder: the Coastal Georgia Fall Fly-In is Oct 19. at Eagle Neck Airpark,
1GA0. We're located on the Georgia coast half way between Savannah and St.
Simons. 5 RVs on the airport.
Please RVSP off line and we'll send you a flyer and airport briefing.
This airpark is featured on the cover of the current General Aviation News.
Dick & Vicki Sipp
912 832-4813
rsipp(at)earthlink.net
Allen:
That should work fine for you in this situation. As to the right way to handle
repairs, man does that open a new war!!
Bill Marvel
Allen Fulmer wrote:
> I clecoed the
> T
Subject: | Re: Fuel Pressure Problem |
What kind of fuel pressure monitoring system are you using?
Ed Perry
eperry(at)san.rr.com
Subject: RV-List: Fuel Pressure Problem
> Hi,
> Thanks,
> Glenn Gordon
I've mentioned this before but here is a perfect example of using your EAA
Chapter
to benefit all builders.
Have the Chapter buy seldom used tools that are required by all but only
used a few times
when building your airplane. This would include flaring tools, magneto
timers, etc.
A Band Clamp tool is only $125 through Chief Aircraft. Firesleeve clamps are
around
$1.75 each but can be found cheaper on the Internet.
This will give your hoses a professional look
Ed Cole
RV6A N2169D Flying
> From: P M Condon [SMTP:pcondon(at)mitre.org]
> Sent: Wednesday, October 02, 2002 6:42 AM
> Subject: RV-List: Re: Firesleeve dressing?
Maxim Home Page:
Products Page:
New Products:
Datasheets:
From: | "Randall Henderson" <randallh(at)attbi.com> |
Here's what I'd recommend:
Make up a yellow arrow sticker like the ones used on military planes to
point out emergency canopy release, etc. Print "THE FLAW" on it, and affix
it to your plane pointing at the hole. No one will ever need to look further
for THE FLAW in your airplane!
Randall Henderson, RV-6 N6R (~400 hrs)
Portland, OR
www.vanshomewing.org
Subject: | Fw: Rocket-List: cowl pressure |
Okay, having said that give us the solution that utilizes that lost 70%
flow (or a large portion thereof).
Subject: Re: Rocket-List: cowl pressure
> --> Rocket-List message posted by: LesDrag(at)aol.com
> I never have understood why everyone used the top of the cowl for part of
the
> baffling. It causes all of the cowl surfaces to be providing upward
> pressure. (Bernoulli's on the outside top surface, "pressure" on forward
3/4
> of the inside top surface, impact pressure exceeding bernoulli's on the
> outside bottom surface, and "vacuum" on the inside bottom surface.)
> It is also very inefficient. In the typical Van's cowl (which is cleaner
> than most manufacturers), there is a 70% net flow loss in the air just
going
> from the air inlet to the engine cylinders.
> JMHO
> Jim Ayers
> Less Drag Products, Inc.
I am using an Electronics International FP-5L.
I suspect I have a bad transducer.
-Glenn Gordon
N442E
> Ed Perry
> From: <dirtyrottenscoundrels(at)attbi.com>
> To:
> > Hi,
> > Thanks,
> > Glenn Gordon
Subject: | Re: Paint Quantities |
Thanks to all the responses to my questions about painting both brief
and with details.
Richard Dudley
-6A
I would contact EI and let them know what is going on. I have heard that
they have real good customer service. I am using the EIS-4000 and I know
that you have to program it to get the proper readings, but I don't know
about the EI ones.
Ed Perry
Subject: Re: RV-List: Fuel Pressure Problem
> -Glenn Gordon
> N442E
> > Ed Perry
> > To:
> > > Hi,
> > > Thanks,
> > > Glenn Gordon
I would recommend *not* doing this, because you'll be left with a hole
that's been stretched once, compressed once, and may have tiny stress
cracks on the inside of it as a result. If you flatten it out, at least
run a slightly-larger-than-the-hole sized drill through it to clean it
up before you fill/sand/prime it.
Alternatively, you could leave the dimple as-is, clean it up with a
drill bit (a good idea either way), notch the top of the rib for
clearance, continue with construction, and fill the hole later. I don't
think you'll be compromising anything significantly structural to worry
about (although i't's possible there are others who disagree).
Oh, and you might want to wait until you've riveted the tail together
before bothering to fill it, the banging may shake loose any filler you
add now (but I think you already thought of that judging from your
wording below).
-RB4
Just notch the rib enough to clear the rivet head.
> From: "Allen Fulmer" <afulmer(at)charter.net>
> To:
> the
> rivet
like
> I
before
Subject: | Alum tubing vs. flexible fuel lines |
Guys,
One thing to keep in mind regarding this thread about using flexible hoses in place
of rigid aluminum fuel lines is that in addition to the greater expense,
flexible hoses also tend to be significantly heavier. If you count ounces as
you build your airplane this is worth considering.
Another thing to keep in mind is that flexible lines will vibrate more (unless
well-clamped at regular intervals), and more vibration can increase the tendency
to vapor lock.
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D canopy skirts...
I think the CV Boot clamp tool at NAPA is about $15 and works fine
Subject: RE: RV-List: Re: Firesleeve dressing?
> Chapter
> used a few times
> timers, etc.
are
> around
> Ed Cole
> RV6A N2169D Flying
> > To: rv-list(at)matronics.com
> Maxim Home Page:
> Products Page:
> New Products:
> Datasheets:
Subject: | Re: Seeking an RV6 |
Subject: RV-List: Seeking an RV6
> Hello,
machine. Just sold my Mooney and want to get a plane that does not cost as
are you owners actually seeing for cruise speeds and fuel burns with these
engines?
shopping for a nice RV6.
> Thanks in Advance,
> Reggie Smith
get a mousetrap. scavenge the spring.
Or go to Lowes or Home Depot and buy one outright.
Vince
Where did you learn this? Vapor lock is caused by the fuel going below
it's vapor pressure point and vaporizing. The vapor point of fuel is
directly proportional to it's temperature. Higher fuel temp - higher
vapor pressure. Vibration might cause fuel foaming - not vapor lock.
Now, you've got at least one flexible line in your fuel system that
connects to your engine. I don't see the harm in having one more.
Bruce
www.glasair.org
SNIP
(unless well-clamped at regular intervals), and more vibration can
increase the tendency to vapor lock.
--Mark Navratil
Cedar Rapids, Iowa
September 24, 2002 - October 02, 2002
RV-Archive.digest.vol-nn
