RV-Archive.digest.vol-of
September 03, 2003 - September 15, 2003
      it a very severe dutch roll of about 50 degrees of bank each way,
      with a period of only 12 seconds, that is it only took 12 seconds to
      go from 50 deg left wing down, to 50 deg right wing down, and back to
      50 deg left wing down.  In pitch, it was in a phugoid at the same
      time with pitch attitudes varying from 15 deg up to 5 deg down, with
      a period of about 90 seconds.  The airspeed was varying by over 100
      kt at times, and the altitude by up to 5,000 ft.  All this time the
      crew was trying to use changes of engine thrust to establish some
      sort of control.  It must have been pandemonium in the cabin.
      Keep the wings firmly attached.
      Kevin Horton         RV-8 (finishing kit)
      Ottawa, Canada
      http://go.phpwebhosting.com/~khorton/rv8/
Date: Sep 03, 2003
Subject: Breather vent
Hey thanx for all your inputs. Joel Graber -4 finishing The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Subject: Radio Calls...
Date: Sep 03, 2003
Can someone give me some example of how to properly call an "initial" and a "360 Overhead"? Thanks! Bill VonDane RV-8A www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Date: Sep 03, 2003
Subject: Re: Canopy decks...slider
Hi Jeff; My experience with a -6A slider was to leave the canopy decks unriveted until fairly late in the game - certainly until after the windscreen bow was fitted. There is some interesting match drilling needed to get the bolt holes drilled that fasten the bow to the longerons (that little joggled spacer has to fit in too) that would be quite hard to do if the canopy decks were riveted on too soon. Having said this, when I started work on the canopy frame and plexi, it seemed like a good idea to have the canopy decks securely in place when drilling the canopy rails to the decks, etc. I recall putting in perhaps five rivets a side for this reason and then later drilling them out to improve access to the instrument panel area. (I wanted to keep the IF-6110s removable as long as possible and so could not rivet the IF-6113s - eventually I riveted the join first and then put them both on at the same time). There are unfortunately no particularly good or satisfying ways to run wiring from the panel area back past the cockpit. Trimming some good sized pieces off the tops of the IF-604 bulkhead is a start but you also have to deal with the IF-604E and IF-604F channel pieces too. Then there are the canopy bow bolts that stick down there too so it no fun running a wire bundle through the area. Same thing really at the IF-605 when you have to get around that big piece of angle that reinforces the top corner. Running a piece of 1/2 PVC conduit just under the IF-620 armrest might be a reasonable compromise. I ran my wing wiring in through the fuse side aft of the spar and under the seat. Went forward through the spar web 2"-3" out from the centre-line and then out under the gear leg socket, then forward and then up the IF-602 to reach the panel area. A nuisance but I could see no practical way to run wiring from the wing up the inside of the IF-604 to reach the panel. You have the right idea though - have a wiring route planned and holes drilled, etc. before you start riveting things together. Jim Oke Winnipeg, Man RV-6A C-GKGZ ----- Original Message ----- From: "Jeff Orear" <jorear(at)new.rr.com> Subject: RV-List: Canopy decks...slider > > Greetings Listers: > > Those of you who have done a slider on a 6 or 7....The Justice instructions indicate that the canopy decks F-6110 and F-6113 should not be riveted on until the finish kit construction. I am ready to start fitting my roll-bar to the fuselage and was wondering if anyone had riveted them on regardless of what the Justice instructions say. I assume his concern was routing wires to the aft of the fuselage as well as running wires up to the panel from the wings. Seems to me I can accomplish those things with these decks riveted in. > > Am I missing something here? > > Thanks in advance > > > Regards, > > Jeff Orear > RV6A > finish kit > Peshtigo, WI > > ________________________________________________________________________________
Subject: Re: Radio Calls...
Date: Sep 03, 2003
Bill, "Experimental xxx, Initial." You can include a mileage, as in "Experimental xxx, 2 mi Initial." In the Air Force, the "standard" initial was 3 - 5 miles. If you are at a military, or a joint use field (ABQ, for example) realize that the overhead pattern altitude is usually published and is 500 feet above the rectangular altitude (sometimes 1,000' above). By the way, most controllers that I've ever dealt with are familiar with an Overhead. And none of the AF guys I know add the "360" to the title. In fact, the other day, the pattern was a little crazy at Centennial (KAPA) and I requested to break out of the 35 pattern and just report Initial for 28. Worked like a charm. If the direction of the break is not published, the controller may ask which way you want to break. Also (AF, again) you typically break from the threshold to the 3,000' mark. Midfield or departure end breaks are not "standard" but can either be requested by you or the controller for spacing. Hope that helps. Keith Hughes Parker, CO T-38 IP, Capt, USAF emeritus ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> Subject: RV-List: Radio Calls... > > Can someone give me some example of how to properly call an "initial" and a "360 Overhead"? > > Thanks! > > > Bill VonDane > RV-8A > www.vondane.com > www.creativair.com > www.epanelbuilder.com > > ________________________________________________________________________________
Date: Sep 03, 2003
Bill, Check out http://www1.faa.gov/atpubs/AIM/Chap5/aim0504.html#5-4-24 It has some info on overheads or your copy of the AIM. Feel free to ask me direct questions. Tom Gummo t.gummo(at)verizon.net ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> Subject: RV-List: Radio Calls... > > Can someone give me some example of how to properly call an "initial" and a "360 Overhead"? > > Thanks! > > > Bill VonDane > RV-8A > www.vondane.com > www.creativair.com > www.epanelbuilder.com > > ________________________________________________________________________________
Date: Sep 04, 2003
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net>
Subject: Re: dutch roll
From the FBI freedom of information report. Flight 007 was shot down by Soviet pilot Lt. Col. Osipovich on Sept 1, 1983. It alledgedly spent about 10 minutes until it went into the Sea of Japan at the speed of sound. The fuselage was not found on a mountain. It has never been found. Dutch Rolls..... Hmmmmm .......................... Phil, building RV-6, worked on fuel tanks tonight, messy.. ________________________________________________________________________________
Date: Sep 03, 2003
This little phrase from the AIM link below... "Overhead maneuver patterns are developed at airports where aircraft have an operational need to conduct the maneuver. " Says that you should not use this at an uncontrolled field unless you specifically know that the operational need exists and a documented procedure also exists. We had one person do these maneuvers at our private airpark, and it caused great confusion to anyone else in the pattern -- especially since she would break to the left or right depending on whim.... really confusing others in the pattern, especially with a slow biplane. At a pilot's meeting, we could find no "operational need", so the practise has been stopped.... However, it a tower is controlling it, go for it..... gil A > >Bill, > >Check out > >http://www1.faa.gov/atpubs/AIM/Chap5/aim0504.html#5-4-24 > >It has some info on overheads or your copy of the AIM. > >Feel free to ask me direct questions. > >Tom Gummo >t.gummo(at)verizon.net > >----- Original Message ----- >From: "Bill VonDane" <bill(at)vondane.com> >To: ; >Subject: RV-List: Radio Calls... > > > > > > Can someone give me some example of how to properly call an "initial" and >a "360 Overhead"? > > > > Thanks! > > > > > > Bill VonDane > > RV-8A > > www.vondane.com > > www.creativair.com > > www.epanelbuilder.com > > > > > > ________________________________________________________________________________
Date: Sep 04, 2003
>Club" > >From the FBI freedom of information report. Flight 007 was shot down by Soviet >pilot Lt. Col. Osipovich on Sept 1, 1983. > >It alledgedly spent about 10 minutes until it went into the Sea of >Japan at the >speed of sound. > >The fuselage was not found on a mountain. It has never been found. > >Dutch Rolls..... Hmmmmm The accident that Wheeler described was almost certainly Japan Airlines Flight 123. The rear pressure bulkhead failed at a spot where a repair had been made. The cabin air escaping from the large hole in the pressure bulkhead effectively inflated the vertical tail and blew it off, severing lines from all four hydraulic systems. The aircraft flew around in a severe Dutch roll oscillation with no flight controls for about 32 minutes, eventually crashing into the side of Mt. Osutaka. There is an excellent account of this accident in Air Disaster, Vol. 2, by MacArthur Job. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Subject: Overhead Approaches was:Radio Calls...
Date: Sep 04, 2003
There are lots of good reasons for using and practicing Overhead approaches. Certainly those doing overheads need to be considerate of those using square patterns. An Overhead approach is a great tool to use and to practice because it is the best way to accomplish a deadstick landing. Glide over the point of intended landing at a known altitude, do a decending 360 and land. Also it is the best way to break up formations and get a group of airplanes on the ground in a short period of time. In a blind airplane like a Stearman or a WWII fighter it is the only way you can see where you are going or what is happening on the runway you are landing on. A square pattern in a Mustang at slow speed in traffic is dangerous. Imagine blindly driving up the downwind at 175 mph? No thanks. NOTHING you can do will better prepare you for an engine out landing than regular practice of 360 overheads at idle power. Tailwinds, Doug Rozendaal ________________________________________________________________________________
Date: Sep 04, 2003
autolearn=ham version=2.53 Virtually all of my last 800 hours of landings have been overheads. I call them out "Tower good afternoon, RV N686MS, 6m SE, inbound for the initial (optional direction for the break here), Papa (information)" Or, for even more fun if the pattern is quiet, or if your tower guys are known to clear the pattern for your fun activities: "Tower good-afternoon, RV N686MS, 6m SE, inbound, low approach, carrier break, (optional direction for the break here), Papa (information)" I got this last one approved Monday landing in class B Baltimore. With a 737 landing parallel. That pilot made a comment about me having "too much fun!" I could hardly argue. I always do initials when I can for: 1. Fun factor 2. Safety. As Doug stated. You can not overemphasize this. There are countless reasons why this is the safest way to land 3. Fun Factor 4. The on-lookers really do enjoy watching the 3g pitchup, power drop, rip around landing of the low approach carrier break landings. 5. Did I mention the fun factor? I can't think of any tower that did not know what I was talking about. Mike Stewart -----Original Message----- From: Doug Rozendaal [mailto:dougr(at)petroblend.com] Subject: RV-List: Overhead Approaches was:Radio Calls... There are lots of good reasons for using and practicing Overhead approaches. Certainly those doing overheads need to be considerate of those using square patterns. An Overhead approach is a great tool to use and to practice because it is the best way to accomplish a deadstick landing. Glide over the point of intended landing at a known altitude, do a decending 360 and land. Also it is the best way to break up formations and get a group of airplanes on the ground in a short period of time. In a blind airplane like a Stearman or a WWII fighter it is the only way you can see where you are going or what is happening on the runway you are landing on. A square pattern in a Mustang at slow speed in traffic is dangerous. Imagine blindly driving up the downwind at 175 mph? No thanks. NOTHING you can do will better prepare you for an engine out landing than regular practice of 360 overheads at idle power. Tailwinds, Doug Rozendaal ________________________________________________________________________________
Subject: Re: Tinted canopies.
Date: Sep 04, 2003
I believe the tinted canopy you saw at OSH this year is made by "Todd's Canopy". Glenn in Arizona, -9A wings ordered. ----- Original Message ----- From: "Dana Overall" <bo124rs(at)hotmail.com> Subject: RV-List: Tinted canopies. > > I don't some searching around in the archives and have communicated off list > with some listers concerning a darker canopy than the ________________________________________________________________________________
Subject: Re: Overhead Approaches was:Radio Calls...
Date: Sep 04, 2003
Thanks for all the input on this! I fully intend to master this procedure for exactly the reasons Doug outlined below... I often fly formation with other RV, and if I ever have to land dead stick this is how I would accomplish it... Regarding the message: "We had one person do these maneuvers at our private airpark, and it caused great confusion to anyone else in the pattern -- especially since she would break to the left or right depending on whim.... really confusing others in the pattern, especially with a slow biplane. At a pilot's meeting, we could find no "operational need", so the practice has been stopped...." I believe that if the overhead is done properly, NO ONE else in the patter will be affected by you at all.....and I HATE to hear when someone decides that someone else doesn't "NEED" to do something and either tries to succeeds in stopping them... None of us NEED to fly anyway, right? no offence, just my opinion... -Bill VonDane RV-8A www.vondane.com www.creativair.com www.epanelbuilder.com ----- Original Message ----- From: "Doug Rozendaal" <dougr(at)petroblend.com> Subject: RV-List: Overhead Approaches was:Radio Calls... There are lots of good reasons for using and practicing Overhead approaches. Certainly those doing overheads need to be considerate of those using square patterns. An Overhead approach is a great tool to use and to practice because it is the best way to accomplish a deadstick landing. Glide over the point of intended landing at a known altitude, do a decending 360 and land. Also it is the best way to break up formations and get a group of airplanes on the ground in a short period of time. In a blind airplane like a Stearman or a WWII fighter it is the only way you can see where you are going or what is happening on the runway you are landing on. A square pattern in a Mustang at slow speed in traffic is dangerous. Imagine blindly driving up the downwind at 175 mph? No thanks. NOTHING you can do will better prepare you for an engine out landing than regular practice of 360 overheads at idle power. Tailwinds, Doug Rozendaal ________________________________________________________________________________
Date: Sep 04, 2003
Subject: Great Paint and painting website
http://www.autobodystore.com/cgi-bin/config.pl?index Try this URL. You can purchase painting related goodies and get advice.The daily chat section from a paint web site(see above URL) is very much like Matts (Matronics) there is a search capability so all you painting,primer and paint related questions can be researched. I also purchased my hobbyair breathing system, DA special finish paint sander and Devilbiss gravity spray gun from them. ________________________________________________________________________________
Date: Sep 04, 2003
There is a major safety issue here. When using localized or specialized jargon, or terminology that only make sense to a select few then the folks not in on the secret language or jargon are unaware of the event(s) taking place around them. I have been at airports where military wantabees or others used this specialized jargon only to cause major problems and confusion in the pattern. I guess that they felt cool using the jargon, the other pilots in the pattern felt otherwise..... In reply to: Bill, "Experimental xxx, Initial." You can include a mileage, as in "Experimental xxx, 2 mi Initial." In the Air Force, the "standard" initial was 3 - 5 miles. If you are at a military, or a joint use field (ABQ, for example) realize that the overhead pattern altitude is usually published and is 500 feet above the rectangular altitude (sometimes 1,000' above). By the way, most controllers that I've ever dealt with are familiar with an Overhead. And none of the AF guys I know add the "360" to the title. In fact, the other day, the pattern was a little crazy at Centennial (KAPA) and I requested to break out of the 35 pattern and just report Initial for 28. Worked like a charm. If the direction of the break is not published, the controller may ask which way you want to break. Also (AF, again) you typically break from the threshold to the 3,000' mark. Midfield or departure end breaks are not "standard" but can either be requested by you or the controller for spacing. Hope that helps. Keith Hughes Parker, CO T-38 IP, Capt, USAF emeritus ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Date: Sep 04, 2003
Gil, Not to be too picky but where does it say this? (See >>>> below) I just read it and did not get " ... you should not ...". Maybe I missed something. Want to know as we do it all the time at our uncontrolled field and have done it at the nearby Towered airport with no problems. James > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Gil Alexander > Sent: Thursday, September 04, 2003 2:31 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Radio Calls... > > > This little phrase from the AIM link below... > > "Overhead maneuver patterns are developed at airports where aircraft have > an operational need to conduct the maneuver. " > >>>>>>>>>>> Says that you should not use this at an uncontrolled field unless you > specifically know that the operational need exists and a documented > procedure also exists. > > We had one person do these maneuvers at our private airpark, and > it caused > great confusion to anyone else in the pattern -- especially since she > would break to the left or right depending on whim.... really confusing > others in the pattern, especially with a slow biplane. At a pilot's > meeting, we could find no "operational need", so the practise has been > stopped.... > > However, it a tower is controlling it, go for it..... > > gil A > > > > > >Bill, > > > >Check out > > > >http://www1.faa.gov/atpubs/AIM/Chap5/aim0504.html#5-4-24 > > > >It has some info on overheads or your copy of the AIM. > > > >Feel free to ask me direct questions. > > > >Tom Gummo > >t.gummo(at)verizon.net > > > >----- Original Message ----- > >From: "Bill VonDane" <bill(at)vondane.com> > >To: ; > >Subject: RV-List: Radio Calls... > > > > > > > > > > Can someone give me some example of how to properly call an > "initial" and > >a "360 Overhead"? > > > > > > Thanks! > > > > > > > > > Bill VonDane > > > RV-8A > > > www.vondane.com > > > www.creativair.com > > > www.epanelbuilder.com > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 04, 2003
Subject: gasoline seasonal blending
Anyone know when the refineries begin to switch over to winter gasoline blends (with allegedly higher vapor pressure for easier starts)? I try to buy all the high-test I'm going to need for the upcoming year during the summer months to avoid the possible vapor lock issues with winter blend mogas, but this year in particular there is a financial incentive to wait until longer after Labor Day for the inevitable price drop. Right now, high test is selling for nearly what some FBO's discount their 100LL down to. I'd like to snag some better prices for the '03-'04 fuel supply without buying any high vapor pressure stuff, but not sure how late in the year I can still make the purchase. Any ideas, besides the obvious one of calling a gasoline refinery and hoping they will talk to me about putting their automotive product into my airplane? Thanks. -Bill B ________________________________________________________________________________
Date: Sep 04, 2003
Done properly with consideration and decent communication, there's no more safety issue with overhead approaches than with any other approved maneuver. Overhead approach is in the AIM and the calls aren't jargon - they're proper. Else the tower folks might not participate quite so readily. One thing that my buddies and I have found helpful if the pattern has a couple of others flying is to make a little more descriptive calls, keeping those in mind who might be ignorant of the maneuver. "123AB, flight of four, 2 mile initial (straight in approach to) 17, overhead (break left turn to midfield downwind, full stop)." This gets the point across. If we don't think we can mix safely, we stay outside the pattern until we get spacing from those in a "convenional" pattern, or we go elsewhere. Blasting into the pattern with minimal calls and not spacing properly with the "rectangular" pattern guys is unsafe. But in my 16 years flying, I've yet to be cut off or offended by someone doing an overhead. Been cut off by boneheads making non standard and even standard entries to rectangular patterns plenty though. We get no problems from the local Class D airport. They have no preference as best I can tell, never missing a beat when we call as a flight requesting the overhead. Bottom line - consideration and looking for traffic are required with all approaches. Bryan Jones -8 Pearland, Texas >There is a major safety issue here. When using localized or specialized >jargon, or terminology that only make sense to a select few then the >folks not in on the secret language or jargon are unaware of the >event(s) taking place around them. I have been at airports where >military wantabees or others used this specialized jargon only to cause >major problems and confusion in the pattern. I guess that they felt cool >using the jargon, the other pilots in the pattern felt otherwise..... Fast, faster, fastest: Upgrade to Cable or DSL today! https://broadband.msn.com ________________________________________________________________________________
Date: Sep 04, 2003
I like flying the overhead because I can see all the traffic in the pattern and enter with enough airspeed/altitude to make the runway incase of engine failure. I report 5 out and request the overhead. 99% of the time the tower clears me for that and asks me to report a 1 mile initial, sometimes restricted to an altitude 500' over the pattern altitude. After reporting, he'll fit me in the pattern by having me break at some point along the runway. If theres other traffic, I'll square it off to fit into the pattern. If nobody is in the pattern, I'll do the short 360. I hate straight in's. I feel really vulnerable to an engine failure. I end up 3 out, slow behind a 172 or something. If the motor coughs, I'm dead. The tower guys are really good to us RV's. I remember them once saying over the freq that "We like you guys....you fly tight patterns!" I don't know how many times I've be on initial, and they'll tell the down wind traffic to extend and clear me #1. It doesn't get any better than that. P M Condon wrote: >There is a major safety issue here. When using localized or specialized >jargon, or terminology that only make sense to a select few then the >folks not in on the secret language or jargon are unaware of the event(s) taking place around them. If a pilot doesn't understand the phraseology he hears in the pattern, look it up in the aim, call the tower, or ask the pilot over the freq. It's all part of the learning process. Laird RV-6 SoCal ________________________________________________________________________________
Subject: Grounding
Date: Sep 04, 2003
The RV-8 is in the final stages. I am now running the wiring. If I use the airframe for grounding my lights, fuel pump, etc. will I have a noise problem? I am using Van's wiring kit for a starting point. thanks Jim Muegge RV-8 wiring ________________________________________________________________________________
Subject: Re: Radio Calls, pattern ops, training
Date: Sep 04, 2003
>Date: Thu, 4 Sep 2003 10:40:29 -0700 > > >I like flying the overhead because I can see all the traffic in the >pattern and enter with enough airspeed/altitude to make the runway >incase of engine failure. > >I report 5 out and request the overhead. 99% of the time the tower >clears me for that and asks me to report a 1 mile initial, sometimes >restricted to an altitude 500' over the pattern altitude. After >reporting, he'll fit me in the pattern by having me break at some >point along the runway. If theres other traffic, I'll square it off >to fit into the pattern. If nobody is in the pattern, I'll do the >short 360. > >I hate straight in's. I feel really vulnerable to an engine failure. >I end up 3 out, slow behind a 172 or something. If the motor coughs, >I'm dead. > >The tower guys are really good to us RV's. I remember them once >saying over the freq that "We like you guys....you fly tight >patterns!" I don't know how many times I've be on initial, and >they'll tell the down wind traffic to extend and clear me #1. It >doesn't get any better than that. > This all brings to mind my two main concerns with modern pilot training: the lack of spin training (not just spin awareness...but SPINS!!!) and the teaching of bomber sized rectangular patterns for light single engine aircraft. I've found myself in the midst of ridiculously large patterns many times at my home base, with spam strung out all over the place. Long, slow and low finals tighten up my nether regions in a big way. I learned to fly via the Air Force Aero club, which always emphasized the need for staying tight to the runway, being prepared for an engine out at any time, then reduce power as needed. In this way, an engine failure is no big deal. This training no doubt helped me greatly when my engine sputtered and wheezed a few years ago in the RV. My gliding, circling descent to a remarkably nice landing proved that overhead approaches WORK. Brian Denk RV8 N94BD FOURTH annual due this month! http://www.msnmessenger-download.com/tracking/reach_emoticon ________________________________________________________________________________
Subject: Re: Grounding
Date: Sep 04, 2003
> >The RV-8 is in the final stages. I am now running the wiring. If I use >the airframe for grounding my lights, fuel pump, etc. will I have a >noise problem? I am using Van's wiring kit for a starting point. > >thanks > >Jim Muegge >RV-8 wiring It's impossible to say positively yes or no. Best bet is to home run every circuit to a common ground bus as near to the battery as practical. Brian Denk RV8 N94BD Compare Cable, DSL or Satellite plans: As low as $29.95. https://broadband.msn.com ________________________________________________________________________________
Subject: Overhead pattern ( was: Radio Calls...)
Date: Sep 04, 2003
> > You bring up an excellent point. I often hear towers, or myself, explaining > exactly what is about to happen to those who ask. It is a learning > experience for all when they are unsure, and it is explained. The "initial" > procedure is an FAA recognized maneuver, and those that don't know what it > is, should ask. As always, any pilot who is not exactly sure what's going on > around them, especially in a pattern, should key up and ask immediately. I have spent most of my flying carreer building an RV-7 and my AIM is at home so I'll 'key up' and ask. What is an overhead, and why would one use it? I think I have the general idea but don't know the details, and I want to be sure. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Canopy http://www.myrv7.com ________________________________________________________________________________
Date: Sep 04, 2003
Bill, I've heard all kinds of initial and overhead calls...and the controllers seem to get the picture as long as you say something close. But, this is how we were taught to do it in the late 90's when I was in flight school in Kingsville, TX, and how most fleet Marine and Navy squadrons do it. "Tower, Devil 255 flight of two, initial, for the break" or "...for the carrier" meaning 600' AGL Aircraft Carrier pattern. The airforce calls it the overhead, I believe. The tower typically responds, "Roger 255, number 1 for the carrier, report the numbers." Meaning you're first in line to land, report back to the tower when you arrive over the runway numbers at the approach end. Then, as the approach end numbers slide under the nose you say, "255, numbers."...look over at your dash two all sucked in nice and tight, give him the 'kiss-off' signal, and freakin' yank that sucker around!!...all the while chopping throttle and dropping flaps (at the appropriate speeds of course), and speed breaks, and the barn door, and anything else you think might get you slowed down to gear speed by the 180 position. :) You started this thing at around 450kts!!! Honestly, it's not as violent a maneuver as I'm making it sound. But there is the unwritten rule of all fighter pilots. 'You might look like hell anywhere else, but you better look good at the break..." Anyway, if this doesn't paint the picture, I probably can go dig up my old flight school manuals and give it to you verbatim. Clayton Henderson RV-7 Fuselage -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill VonDane Subject: RV-List: Radio Calls... Can someone give me some example of how to properly call an "initial" and a "360 Overhead"? Thanks! Bill VonDane RV-8A www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Subject: Canopy decks...slider
Date: Sep 04, 2003
> > Greetings Listers: > > > > Those of you who have done a slider on a 6 or 7....The Justice > instructions indicate that the canopy decks F-6110 and F-6113 > should not be riveted on until the finish kit construction. > I am ready to start fitting my roll-bar to the fuselage and > was wondering if anyone had riveted them on regardless of > what the Justice instructions say. I assume his concern was > routing wires to the aft of the fuselage as well as running > wires up to the panel from the wings. Seems to me I can > accomplish those things with these decks riveted in. > > > > Am I missing something here? The single best advice I ever got on building these planes is to never rivet anything until you cannot proceed without doing so. If you can fit the rollover bar with the decks clecoed on, then do so. You might run wires, fuel tank vents, etc. in this example. Alex Peterson Maple Grove, MN RV6-A N66AP 368 hours www.usfamily.net/web/alexpeterson ________________________________________________________________________________
Date: Sep 04, 2003
James ... it's in the section of the AIM talking about IFR procedures at control tower airports. Check out the whole AIM section, and see what it covers. The "operational need" is an exception.... and as an exception it needs to be documented. Our airpark uses the AIM (the best general descriptive document available)as a baseline, and developed our traffic patterns from it. The particular biplane mentioned did not help matters by cutting in front of planes already in the standard rectangular pattern, and then "dropping down" from pattern height over mid-field in a overhead pattern to land first. To the people in the pattern, this was extremely confusing and a safety hazard. Our Aviation Committee decided that the AIM was the baseline and we did not have an operational need - no formation flying at our field. Other non-controlled fields that have formation flying at them have developed, and published, overhead patterns. Towered airports are no problem as long as the tower agrees. At non-towered, are you interupting the flow of planes that are following the FAA recommended procedures in the AIM? Does this become a safety/liability hazard. (We actually own our strip) gil A -------Original Message------- From: "James E. Clark" <james(at)nextupventures.com> Subject: RE: RV-List: Radio Calls... > Gil, Not to be too picky but where does it say this? (See >>>> below) I just read it and did not get " ... you should not ...". Maybe I missed something. Want to know as we do it all the time at our uncontrolled field and have done it at the nearby Towered airport with no problems. James > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Gil Alexander > Sent: Thursday, September 04, 2003 2:31 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Radio Calls... > > > This little phrase from the AIM link below... > > "Overhead maneuver patterns are developed at airports where aircraft have > an operational need to conduct the maneuver. " > >>>>>>>>>>> Says that you should not use this at an uncontrolled field unless you > specifically know that the operational need exists and a documented > procedure also exists. > > We had one person do these maneuvers at our private airpark, and > it caused > great confusion to anyone else in the pattern -- especially since she > would break to the left or right depending on whim.... really confusing > others in the pattern, especially with a slow biplane. At a pilot's > meeting, we could find no "operational need", so the practise has been > stopped.... > > However, it a tower is controlling it, go for it..... > > gil A > > > > > >Bill, > > > >Check out > > > >http://www1.faa.gov/atpubs/AIM/Chap5/aim0504.html#5-4-24 > > > >It has some info on overheads or your copy of the AIM. > > > >Feel free to ask me direct questions. > > > >Tom Gummo > >t.gummo(at)verizon.net > > > >----- Original Message ----- > >From: "Bill VonDane" <bill(at)vondane.com> > >To: ; > >Subject: RV-List: Radio Calls... > > > > > > > > > > Can someone give me some example of how to properly call an > "initial" and > >a "360 Overhead"? > > > > > > Thanks! > > > > > > > > > Bill VonDane > > > RV-8A > > > www.vondane.com > > > www.creativair.com > > > www.epanelbuilder.com > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 04, 2003
If you do a really good job sheilding your wires (I prefer solder sleeves to the pigtail method) you shouldn't have a problem. Commo headset wires should have an open ground at one end, and as long as the shield is grounded to the intercom or similar unit, it won't have a chance to pick up any noise. I grounded my aeroflash strobes at the wingtip (two power supplies) and ran the bundle with the wires going to my headset jacks. No problems. Shielding is the key. As Brian said, I would ground most everything you can at a single source (Bob Knuckoll's grounding blocks are great). But things that aren't feasible shouldn't hurt. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Nebr RV-8" <nebrrv8(at)earthlink.net> Subject: RV-List: Grounding > > The RV-8 is in the final stages. I am now running the wiring. If I use > the airframe for grounding my lights, fuel pump, etc. will I have a > noise problem? I am using Van's wiring kit for a starting point. > > thanks > > Jim Muegge > RV-8 wiring > > ________________________________________________________________________________
Subject: Dynon remote Mag sensor installed!
Date: Sep 04, 2003
Dynon update. I recieved my mag sensor a couple weeks ago and finally last week I built a wiring harness. I was soldered it up but did not have the Mag sensor installed. I turned on the EFIS and the screen turned blue and nothing! Oh S--- I thought I screwed up my wiring. I double checked everything and all was well. I could not turn the unit off. Only a blue screen. I took out the internal battery and thought maybe I could get a reboot. No luck, blue screen. I called Doug M. at Dynon and he said I probably EFDed the unit and to send it back. I overnighted it Fri and got it back today. with Labor day, they turned it in one day. More great service!!! I got it back without a bill.... maybe one is coming??? Doug said the protection on the Mag sensor circuit is pretty low so you have to be very careful taking static precautions. I told him I knew all about condom precautions, but I did not know squat about computers. He said, "that was a Dynamic activity and this is static." Becareful and UNPLUG YOUR Dynon EFIS and Mag Sensor if you are working on the wiring!!!! I mounted my Mag sensor on the shelf in the baggage of my -4. I did not have a smart level so I got it as close as I could with a spirit level. I took a cord off of an old mouse and wired that in for my serial port cable. Think before you mount the sensor. I mounted the mag sensor over a screw that holds the baggage bulkhead in so I will move it before I calibrate it. I hooked it all up and it worked great! Without calibration the compass is off no more than 7 degrees on any of the 4 cardinal headings. Dead on West and North, about 5 off South and 7 off East. The biggest problem so far is laptops. I don't have one so I borrowed one. It did not have a serial port. USB only. So I borrowed another, I checked to make absolutely sure it had a serial port! it did, I got to the hanger, got all set up and went to plug in my floppy disc, No disc drive!! CD only!!!! I will find a laptop! or a long cord for my desktop if I have too! Anyway I continue to be happy with the Dynon, the heading mode seems to lag just a bit. When turning to a heading it seems I might want to roll out just a bit early... but only one quick flight so far. Hopefully I can find a laptop, get it calibrated and then go try some approaches. What a machine!!!! Tailwinds, Doug Rozendaal ________________________________________________________________________________
Date: Sep 04, 2003
Subject: Tuned Exhaust for O-360?
I know most of us are using Vetterman exhaust, but I was wondering if there is a tuned exhaust system available to fit in an RV-7 with an O-360? Any ideas? Any word on performance? Price? Thanks for any help! -Mike Kraus ________________________________________________________________________________
Date: Sep 04, 2003
Subject: Re: flea market supplier??
Yes that is them, I remember the leather too ... Yes real nice people with nice neat lay out of his stuff.... Thanks Gert and all who responded... Phil, Finishing second tank this week and flying in December.. RV-6 Gert wrote: > > Them are the nice people with the cheap wemac vents.... > > B&B Aircraft supplies > P.O. box 37 > 202 S. Center > Gardner, KS 66030 > > Dan & E.J. brown > > fax 913-884-6533 > ________________________________________________________________________________
Date: Sep 05, 2003
As for the USAF side of things. 1. Normally you set your self and formation lined up with the landing runway, usually 1-3nm from the approach end of the runway at pattern altitude. The typical radio call is: "Viper 11 flight initial" or "Viper 11 flight of 4 initial" or "Viper 11 flight 3 mile initial" Tower will normally follow with "Roger Viper 11, report base". Variations 2 and 3 above are technique and useful when trying to give the tower additional information. 2. Prior to or upon reaching the approach end of the runway, lead gives the pitchout signal (spinning index finger in a circular motion) and upon a headnod from #2, he pitches out (the USAF doesn't use the kiss-off signal). Lead will normally then pitch out over the numbers or as directed by tower. The pitch out is Usually a 45-80degree bank turn using 2-max alowable G with the throttle in idle to bleed down airspeed to final turn airspeed. (the more G, the more fun it is, plus the tighter the patters). Number two will wait the briefed time delay and follow (usually 5 seconds). 3. Lead will rollout, continue to slow and configure (gear and flaps). Wingman line up directly behind lead (left/right and up/down) and follow with 3 and 4 matching the spacing and timing of #2. 4. Upon reaching a position abeam the point on final you desire to roll-out of the final turn (typically 1/4 to 1nm), you start a decending turn and make the following radio call: The typical radio call is "Viper 11 base gear-down fullstop" or "Viper 11 base gear-down touch-n-go" Some people also add right or left to the base call. #2, #3, and #4 will repeat this when they reach the base position. 5. The final turn is flown in a constant decent and constant turn to roll out on final to allow you to stabilize and correct for glidepath and crosswind. (USAF requires fighters and trainers to roll out at 1nm and 300ft for a 3deg glide path). This is a quick description of the USAF way. There are differences between the USAF and USN way of flying the overhead pattern. Having been an instructor in the USAF AT-38 and F-16s and the Navy T-34C at Whiting NAS, I have instructed both ways. Overall the USAF way is easier to learn, (one altitude, no decending break, allows a rollout on final further from the runway, allows a constant rate of turn on final vs a changing bank/rate of turn the Navy pattern requires due to the base position being abeam the touchdown point). The overhead pattern lets a formation of aircraft go from close/fingertip formation to a trail formation in minimum time and minimum airspace. It eliminates the need for wingmen to slow down or perform massive s-turning to obtain spacing on final. It also allows aircraft to get to the runway in minimum time for fuel or threat. Just my 2 cents. Thanks to everyone for all the great info and emails. Bill Sipher RV-4 writes: > > Bill, > > I've heard all kinds of initial and overhead calls...and the > controllers > seem to get the picture as long as you say something close. But, > this > is how we were taught to do it in the late 90's when I was in > flight > school in Kingsville, TX, and how most fleet Marine and Navy > squadrons > do it. > > "Tower, Devil 255 flight of two, initial, for the break" or "...for > the > carrier" meaning 600' AGL Aircraft Carrier pattern. The airforce > calls > it the overhead, I believe. > > The tower typically responds, "Roger 255, number 1 for the carrier, > report the numbers." Meaning you're first in line to land, report > back > to the tower when you arrive over the runway numbers at the > approach > end. > > Then, as the approach end numbers slide under the nose you say, > "255, > numbers."...look over at your dash two all sucked in nice and > tight, > give him the 'kiss-off' signal, and freakin' yank that sucker > around!!...all the while chopping throttle and dropping flaps (at > the > appropriate speeds of course), and speed breaks, and the barn door, > and > anything else you think might get you slowed down to gear speed by > the > 180 position. :) You started this thing at around 450kts!!! > > Honestly, it's not as violent a maneuver as I'm making it sound. > But > there is the unwritten rule of all fighter pilots. 'You might look > like > hell anywhere else, but you better look good at the break..." > > Anyway, if this doesn't paint the picture, I probably can go dig up > my > old flight school manuals and give it to you verbatim. > > Clayton Henderson > RV-7 Fuselage > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill > VonDane > To: rv-list(at)matronics.com; rv8list(at)yahoogroups.com > Subject: RV-List: Radio Calls... > > > Can someone give me some example of how to properly call an > "initial" > and a "360 Overhead"? > > Thanks! > > > Bill VonDane > RV-8A > www.vondane.com > www.creativair.com > www.epanelbuilder.com > > > > > > > > > > The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Sep 04, 2003
Mr Condon, First of all.... I am NOT a military pilot "wantabee". I'm a military pilot "ustabee". And the verbiage that I specified in the post you quoted was not "specialized jargon". It is quite standardized jargon going back many, many years. As others have said, the Overhead is printed in the AIM. If you are confused, then I suggest you either a) Ask. Or b). Read you AIM. There are many tools a good pilot can put in his "toolbag" that will help everyone. Airmanship.... it's the difference between being an "airplane driver" and a real pilot. Keith Hughes ----- Original Message ----- From: "P M Condon" <pcondon(at)mitre.org> Subject: Re: RV-List: Radio Calls... > > There is a major safety issue here. When using localized or specialized > jargon, or terminology that only make sense to a select few then the > folks not in on the secret language or jargon are unaware of the > event(s) taking place around them. I have been at airports where > military wantabees or others used this specialized jargon only to cause > major problems and confusion in the pattern. I guess that they felt cool > using the jargon, the other pilots in the pattern felt otherwise..... > > > In reply to: > > > Bill, > > "Experimental xxx, Initial." You can include a mileage, as in > "Experimental > xxx, 2 mi Initial." In the Air Force, the "standard" initial was 3 - 5 > miles. If you are at a military, or a joint use field (ABQ, for > example) > realize that the overhead pattern altitude is usually published and is > 500 > feet above the rectangular altitude (sometimes 1,000' above). By the > way, > most controllers that I've ever dealt with are familiar with an > Overhead. > And none of the AF guys I know add the "360" to the title. In fact, the > other day, the pattern was a little crazy at Centennial (KAPA) and I > requested to break out of the 35 pattern and just report Initial for 28. > Worked like a charm. If the direction of the break is not published, > the > controller may ask which way you want to break. Also (AF, again) you > typically break from the threshold to the 3,000' mark. Midfield or > departure end breaks are not "standard" but can either be requested by > you > or the controller for spacing. > > Hope that helps. > > Keith Hughes > Parker, CO > T-38 IP, Capt, USAF emeritus > > ________________________________________________________________________________
Subject: Re: Aileron skins
Date: Sep 05, 2003
> >Working on the ailerons for my 8. Is there a top/bottom to the skins? They >are marked left and right, but no top and bottom. Ken, I haven't seen a public response to your question so I'll fire one off. A couple things orient the skin the correct way. As a reference the first prepunched rivet hole on the inboard side is a little over 1.5" while the same hole on the outboard is a little over an inch. Now take the spar marked either left or right. With the outboard and inboard rivet holes spaced differently, the correct spar will only fit in one way. Now you have a left and right aileron. The >1.5 rivet hole spacing is the inboard side of the aileron, thus it defines the top of the skin. Now just take our sharpie out and mark everything. http://www.msnmessenger-download.com/tracking/reach_emoticon ________________________________________________________________________________
From: "Wayne R. Couture" <commando@cox-internet.com>
Subject: Re: Tuned Exhaust for O-360?
Date: Sep 05, 2003
I've called a half dozen manufacturers to ask the same thing, all said no. If you find someone, let me know. Wayne ----- Original Message ----- From: <N223RV(at)aol.com> Subject: RV-List: Tuned Exhaust for O-360? > > I know most of us are using Vetterman exhaust, but I was wondering if there > is a tuned exhaust system available to fit in an RV-7 with an O-360? > > Any ideas? Any word on performance? Price? > > Thanks for any help! > -Mike Kraus > > ________________________________________________________________________________
Date: Sep 05, 2003
I ran into the same dilemma when building two RV6 aircraft with LYC IO-360-B1B engines. I designed the exhaust system based on data gathered from numerous sources and had Vernon Rich in Phoenix (DVT airport) build for me. Each primary tube is exactly 40" long and flow into a 11" collector aligned with the aircraft centerline. The first flight is scheduled for next month and performance details will become available then. Greg Schmidt RV6S N250GS Phoenix DVT ________________________________________________________________________________
Date: Sep 05, 2003
Subject: canopy tinitin
I can't find anyone in the archives that has a darker canopy the the 2514. I am looking at a bronze/smoke 2404 with 49% penetration to go with my spartan gold stripping/black. Anybody out there with anything darker than 59% care to talk? I'm sorry but I don't remember the person's name with the beautiful red 8 with the really, really dark canopy that posted something here about his paint job..........the one at Oshkosh this year. Send me something off list if you do not see this as beneficial to all. I have to make a decision by the beginning of the week. The shop is only a couple hours from my house so I am just going to drive and pick my canopy up instead of having it drop shipped or shipped to Van's and supplied with my finish kit. Dana Overall Richmond, KY Hey Dana: We sell the 2404 with the F1 kits as an option --- we have one on the demo ship. It's much cooler than the 2514, even with a sunshade on the 2514! I think something darker would not be good for night VFR. I've seen the -8 you refer to -- very nice work, and striking to look at. You'll be happy with the 2404, IMHO. Cheers Mark Team Rocket ________________________________________________________________________________
Date: Sep 05, 2003
You might check with Sky Dynamics: http://www.skydynamics.com/homepage.html Sam Buchanan ==================== "Wayne R. Couture" wrote: > > > I've called a half dozen manufacturers to ask the same thing, all said no. > If you find someone, let me know. > > Wayne > > ----- Original Message ----- > From: <N223RV(at)aol.com> > To: ; > Subject: RV-List: Tuned Exhaust for O-360? > > > > > I know most of us are using Vetterman exhaust, but I was wondering if > there > > is a tuned exhaust system available to fit in an RV-7 with an O-360? > > > > Any ideas? Any word on performance? Price? > > > > Thanks for any help! > > -Mike Kraus > > ________________________________________________________________________________
Date: Sep 05, 2003
Mike Sky Dynamics makes 4 into 1 tuned exhausts for the RV series. They do a lot of business with the acro crowd. http://www.skydynamics.com/homepage.html There aren't any photos of their exhaust on the web page. You can also contact Custom Aircraft Parts. They make 4 into 1 exhausts for the tail wheel RVs http://www.customaircraft.com/ Charlie Kuss > >I know most of us are using Vetterman exhaust, but I was wondering if there >is a tuned exhaust system available to fit in an RV-7 with an O-360? > >Any ideas? Any word on performance? Price? > >Thanks for any help! >-Mike Kraus > > ________________________________________________________________________________
Date: Sep 05, 2003
Subject: XCOM What's up
I e-mail from their site yesterday, a request for an update as to when they projected my transceivers would be shipped. It was returned as "Host Unknown". Anybody else hear from them. I'm redoing my panel this winter and was going to use a pair of their radios. Still got some time, but getting concerned. Casper ________________________________________________________________________________
Date: Sep 05, 2003
Charlie Kuss wrote: > > > Mike > Sky Dynamics makes 4 into 1 tuned exhausts for the RV series. They do a lot of business with the acro crowd. > http://www.skydynamics.com/homepage.html > There aren't any photos of their exhaust on the web page. Here are photos: http://www.skydynamics.com/homepage.html http://www.skydynamics.com/homepage.html Sam Buchanan =================================== > > > > >I know most of us are using Vetterman exhaust, but I was wondering if there > >is a tuned exhaust system available to fit in an RV-7 with an O-360? > > > >Any ideas? Any word on performance? Price? > > > >Thanks for any help! > >-Mike Kraus > > ________________________________________________________________________________
Date: Sep 05, 2003
Subject: Re: XCOM What's up
Garry Legare wrote: > I e-mail from their site yesterday, a request for an update as to when > they projected my transceivers would be shipped. It was returned as > "Host Unknown". Anybody else hear from them. I'm redoing my panel this > winter and was going to use a pair of their radios. Still got some time, > but getting concerned. > Casper There can be temporary glitches in the DNS lookup that will give you that error. I would just double check the email address and try again a few hours later. -- Chris Woodhouse 3147 SW 127th St. Oklahoma City, OK 73170 405-691-5206 chrisw(at)programmer.net N35 20.492' W97 34.342' "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin, 1759 Historical Review of Pennsylvania ________________________________________________________________________________
Subject: AOPA news
Date: Sep 05, 2003
There was a familiar name in this morning's AOPA e-mail newsletter: VOLUNTEER OF THE MONTH-RANDALL HENDERSON Two years after his appointment as the AOPA Airport Support Network volunteer for Seaside Municipal Airport in Seaside, Oregon, Randall Henderson is the vice chairman and liaison to state and federal government agencies for the city airport committee. His efforts at the airport include convincing the City of Seaside to commit to keeping the airport, applying for a federal grant, and creating a nine-member airport committee. Henderson credits the ASN program, its resources, and the credibility of his ASN volunteer status with creating the incentive and confidence to follow through with the challenge of saving an airport. Why not join the program and help your airport? See AOPA Online. ________________________________________________________________________________
Date: Sep 05, 2003
Subject: AEIO-360 engine for sale
Listers, Our local EAA Chapter held a picnic at Willis Gliderport in Boynton Beach recently. While speaking to the son in law of our host, I noticed a low time 360 engine sitting on a pallet in his hanger. I asked him about it. He told me that it was an AEIO-360-A1E (200 hp) engine with 70 hours TT since new. It was removed from an aircraft to install a Lycoming AEIO-540 engine. I thought someone on the list might be interested in it. I'm interested, but don't have that sort of cash. The engine has a Monte Barrett forward facing sump, so you could eliminate the intake snorkel. For more info please contact Chris Meyer directly at Chrism2(at)bellsouth.net or by phone at (561)737-6306 Price is $25,000 or best offer. I do have several photos I can send off list to anyone interested, I can email them to you. Charlie Kuss RV-8A cockpit systems stuff ________________________________________________________________________________
From: "Crosley, Rich" <RCROSLEY(at)HRTEXTRON.TEXTRON.COM>
Subject: re: rv-list: grounding
Date: Sep 05, 2003
Jim, I am also building an "8" and using Van's wiring kit. I added B&C's grounding block in addition. I ran a wire from the back side of the firewall ground to the bulkhead behind the instrument panel and ground everything there to the block. Might try that. Here is the web site. http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?26X358218 Rich Crosley Palmdale, CA RV-8 wiring and engine ________________________________________________________________________________
Subject: Wiring the Lasar system
Date: Sep 05, 2003
I bought the l Lasar system for my O-360 but didn't receive any installation information. Van's says they don't supply wiring info. Does any one have the data or do I buy the manual from Unison? Thanks Rich Crosley Palmdale, CA RV-8 ________________________________________________________________________________
Subject: grounding
Date: Sep 05, 2003
In my -8, I have a couple of grounding blocks behind the instrument panel wired to the main airframe ground fwd of the firewall. Everything else - strobe transformer, land lights, nav lights,aux fuel pump, etc - is all grounded through the airframe. No noise filters on the mag p-leads either, and (fortunately) have essentially no "electrical noise" or other negative effects evident. my 2 Bryan Jones -8 Pearland, Texas >I am also building an "8" and using Van's wiring kit. I added B&C's >grounding block in addition. I ran a wire from the back side of the >firewall >ground to the bulkhead behind the instrument panel and ground everything >there to the block. Might try that. Here is the web site. >http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?26X358218 Compare Cable, DSL or Satellite plans: As low as $29.95. https://broadband.msn.com ________________________________________________________________________________
Subject: grounding
Date: Sep 05, 2003
Thanks guys. That is how I will do it. Jim Muegge -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV_8 Pilot Subject: RV-List: grounding In my -8, I have a couple of grounding blocks behind the instrument panel wired to the main airframe ground fwd of the firewall. Everything else - strobe transformer, land lights, nav lights,aux fuel pump, etc - is all grounded through the airframe. No noise filters on the mag p-leads either, and (fortunately) have essentially no "electrical noise" or other negative effects evident. my 2 Bryan Jones -8 Pearland, Texas >I am also building an "8" and using Van's wiring kit. I added B&C's >grounding block in addition. I ran a wire from the back side of the >firewall >ground to the bulkhead behind the instrument panel and ground everything >there to the block. Might try that. Here is the web site. >http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?26X358218 Compare Cable, DSL or Satellite plans: As low as $29.95. https://broadband.msn.com ________________________________________________________________________________
Subject: Re: Gasoline seasonal blending
Date: Sep 05, 2003
From: "Bruce Anthony" <bruce.anthony(at)holidaycompanies.com>
Bill, The federal mandate requires that low RVP gasoline be sold at retail between June 1 and September 15 each year. Smart retailers are probably there before September 15th as the penalties are pretty severe. I am not sure if that changes for so-called ozone non-attainment areas or not. Where do you live? Is there any particular reason why you don't want to use higher vapor pressure gasoline? Just wondering. Bruce Anthony N942CB reserved Rosemount, Minnesota In the empennage stage still ________________________________________________________________________________
Subject: Dynon delivery
Date: Sep 05, 2003
List: Thought those that are interested in the Dynon might like to know that they are ahead of schedule with production. I ordered my unit (number 423) at Oshkosh and was told that delivery would be in 12 weeks. Got the call today that it has been shipped out and will be here next week. That makes it a 6 week lead time to date. Guess I better get moving on my panel!! Regards, Jeff Orear RV6A finish kit Peshtigo, WI ________________________________________________________________________________
Date: Sep 05, 2003
Subject: Re: Wiring the Lasar system
In a message dated 9/5/03 2:11:45 PM Eastern Daylight Time, RCROSLEY(at)HRTEXTRON.TEXTRON.COM writes: > I bought the l Lasar system for my O-360 but didn't receive any > installation > information. Van's says they don't supply wiring info. Does any one have > the data or do I buy the manual from Unison? > > Contact Unison. If I remember correctly, they gave me the manual and also a VCR tape on installation - free. I purchased the LASAR with the engine from Aero Sport Power. Dale Ensing Aero Plantation North Carolina ________________________________________________________________________________
Date: Sep 05, 2003
Where do you live? Is there any particular reason why you don't want to use higher vapor pressure gasoline? Yeah, Bruce: vapor lock. I hope to avoid it. I believe I have experienced it several times on startup at a mountain airport (3800MSL) after a quick stop and restart (5-10 minutes to heat-soak); either vapor lock or an over-rich condition which allows a start but the engine sputters and dies, becoming very difficult to restart. I never want to face this on takeoff if it's vapor lock, so I try to stack the deck in my favor. -Bill ________________________________________________________________________________
Subject: Re: re: radio calls
Date: Sep 05, 2003
I would like to add something here. Even if you don't know anything about the overhead pattern, it should not effect the way you fly your pattern. The pilot calling INITIAL at a uncontrolled field has the responsibility to fit his plane or flight into the other aircraft already in the pattern. At a controlled field, the controller should be doing this. Knowledge is power. Now that you know a little about the pattern, you should know where to look for this traffic. This is in case he / she makes a mistake and breaks into you. (I would not want to die just because I am right or have the right of way. Your point!) The break over the numbers only works if there is no one already on downwind. With a plane on downwind, I would delay the break (turn to downwind) until I knew I had proper spacing on the aircraft in front of me. In other words, I would wait until all the downwind traffic passed me and then I would break and follow them in. No radio, well we are all to look around the pattern and avoid aircraft that don't see us. Have fun. Too bad we all can't get together for a little face to face time as a 15 minute briefing would answer just about everybody's questions. Again, anybody with questions can please contact me off the list and I will do my best to answer them. Tom t.gummo(at)verizon.net ________________________________________________________________________________
Date: Sep 05, 2003
I purchased an O-360 with the Laser system installed from Vans. I received a full manual with it. If you can't get it from Unison, let me know. I can make a copy and send it to you. Richard > >I bought the l Lasar system for my O-360 but didn't receive any installation >information. Van's says they don't supply wiring info. Does any one have >the data or do I buy the manual from Unison? > >Thanks > >Rich Crosley >Palmdale, CA >RV-8 > > Richard B. Rauch Email: richardr(at)apcon.com APCON, Inc. 17938 SW Upper Boones Ferry Rd. Portland, OR 97224 USA Ph: (503)639-6700 Fax: (503)639-6740 Web: www.apcon.com ________________________________________________________________________________
Subject: Alternator for Lycoming
Date: Sep 06, 2003
Does anyone know what automotive alternator (make and model of the vehicle), that the Lycoming alternator is copied from? My alternator shop says it is a 60-70's Chrysler or Ford but didn't know exactly which one. Ronnie Brown ________________________________________________________________________________
Date: Sep 06, 2003
I downloaded a LASAR manual (service letter SL1-96) from their website in PDF format a while ago. maybe snoop around on their website. Richard B. Rauch wrote: > > I purchased an O-360 with the Laser system installed from Vans. I received a full manual with it. > > If you can't get it from Unison, let me know. I can make a copy and send it to you. > > Richard > > > >> >>I bought the l Lasar system for my O-360 but didn't receive any installation >>information. Van's says they don't supply wiring info. Does any one have >>the data or do I buy the manual from Unison? >> >>Thanks >> >>Rich Crosley >>Palmdale, CA >>RV-8 >> >> >> > > > Richard B. Rauch > Email: richardr(at)apcon.com > > APCON, Inc. > 17938 SW Upper Boones Ferry Rd. > Portland, OR 97224 USA > Ph: (503)639-6700 > Fax: (503)639-6740 > > Web: www.apcon.com > > > > > > > > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Subject: Re: Alternator for Lycoming
Date: Sep 06, 2003
The alternator that came with my 0 SMOH O-320 has an Elecrosystems Inc plate on it that says "Orig Mfg-- Ford" , Mod-- 00315 - 15V, Pt No-DOFF10300J. It's a large heavy brute and didn't use it on my -6A, so that is why I had it kicking around in my basement. Cheers! --Henry Hore ________________________________________________________________________________
Date: Sep 06, 2003
I've been following this thread with great interest. I keep reading that you call initial 1 to 3 miles out. My question is: is this your first contact with the tower or do you contact them 5 to 10 miles as i think most of us do and inform them of your intentions? Phil Tom Gummo wrote: > >I would like to add something here. > >Even if you don't know anything about the overhead pattern, it should not >effect the way you fly your pattern. The pilot calling INITIAL at a >uncontrolled field has the responsibility to fit his plane or flight into >the other aircraft already in the pattern. At a controlled field, the >controller should be doing this. > >Knowledge is power. Now that you know a little about the pattern, you >should know where to look for this traffic. This is in case he / she makes >a mistake and breaks into you. (I would not want to die just because I am >right or have the right of way. Your point!) > >The break over the numbers only works if there is no one already on >downwind. With a plane on downwind, I would delay the break (turn to >downwind) until I knew I had proper spacing on the aircraft in front of me. >In other words, I would wait until all the downwind traffic passed me and >then I would break and follow them in. > >No radio, well we are all to look around the pattern and avoid aircraft that >don't see us. > >Have fun. > >Too bad we all can't get together for a little face to face time as a 15 >minute briefing would answer just about everybody's questions. > >Again, anybody with questions can please contact me off the list and I will >do my best to answer them. > >Tom >t.gummo(at)verizon.net > > ________________________________________________________________________________
Subject: Radio Calls...
Date: Sep 06, 2003
Yeah, but I ask the List... Which way seems more fun!!!! :) CH -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of sipherrv(at)juno.com Subject: Re: RV-List: Radio Calls... As for the USAF side of things. 1. Normally you set your self and formation lined up with the landing runway, usually 1-3nm from the approach end of the runway at pattern altitude. The typical radio call is: "Viper 11 flight initial" or "Viper 11 flight of 4 initial" or "Viper 11 flight 3 mile initial" Tower will normally follow with "Roger Viper 11, report base". Variations 2 and 3 above are technique and useful when trying to give the tower additional information. 2. Prior to or upon reaching the approach end of the runway, lead gives the pitchout signal (spinning index finger in a circular motion) and upon a headnod from #2, he pitches out (the USAF doesn't use the kiss-off signal). Lead will normally then pitch out over the numbers or as directed by tower. The pitch out is Usually a 45-80degree bank turn using 2-max alowable G with the throttle in idle to bleed down airspeed to final turn airspeed. (the more G, the more fun it is, plus the tighter the patters). Number two will wait the briefed time delay and follow (usually 5 seconds). 3. Lead will rollout, continue to slow and configure (gear and flaps). Wingman line up directly behind lead (left/right and up/down) and follow with 3 and 4 matching the spacing and timing of #2. 4. Upon reaching a position abeam the point on final you desire to roll-out of the final turn (typically 1/4 to 1nm), you start a decending turn and make the following radio call: The typical radio call is "Viper 11 base gear-down fullstop" or "Viper 11 base gear-down touch-n-go" Some people also add right or left to the base call. #2, #3, and #4 will repeat this when they reach the base position. 5. The final turn is flown in a constant decent and constant turn to roll out on final to allow you to stabilize and correct for glidepath and crosswind. (USAF requires fighters and trainers to roll out at 1nm and 300ft for a 3deg glide path). This is a quick description of the USAF way. There are differences between the USAF and USN way of flying the overhead pattern. Having been an instructor in the USAF AT-38 and F-16s and the Navy T-34C at Whiting NAS, I have instructed both ways. Overall the USAF way is easier to learn, (one altitude, no decending break, allows a rollout on final further from the runway, allows a constant rate of turn on final vs a changing bank/rate of turn the Navy pattern requires due to the base position being abeam the touchdown point). The overhead pattern lets a formation of aircraft go from close/fingertip formation to a trail formation in minimum time and minimum airspace. It eliminates the need for wingmen to slow down or perform massive s-turning to obtain spacing on final. It also allows aircraft to get to the runway in minimum time for fuel or threat. Just my 2 cents. Thanks to everyone for all the great info and emails. Bill Sipher RV-4 writes: > > Bill, > > I've heard all kinds of initial and overhead calls...and the > controllers > seem to get the picture as long as you say something close. But, > this > is how we were taught to do it in the late 90's when I was in > flight > school in Kingsville, TX, and how most fleet Marine and Navy > squadrons > do it. > > "Tower, Devil 255 flight of two, initial, for the break" or "...for > the > carrier" meaning 600' AGL Aircraft Carrier pattern. The airforce > calls > it the overhead, I believe. > > The tower typically responds, "Roger 255, number 1 for the carrier, > report the numbers." Meaning you're first in line to land, report > back > to the tower when you arrive over the runway numbers at the > approach > end. > > Then, as the approach end numbers slide under the nose you say, > "255, > numbers."...look over at your dash two all sucked in nice and > tight, > give him the 'kiss-off' signal, and freakin' yank that sucker > around!!...all the while chopping throttle and dropping flaps (at > the > appropriate speeds of course), and speed breaks, and the barn door, > and > anything else you think might get you slowed down to gear speed by > the > 180 position. :) You started this thing at around 450kts!!! > > Honestly, it's not as violent a maneuver as I'm making it sound. > But > there is the unwritten rule of all fighter pilots. 'You might look > like > hell anywhere else, but you better look good at the break..." > > Anyway, if this doesn't paint the picture, I probably can go dig up > my > old flight school manuals and give it to you verbatim. > > Clayton Henderson > RV-7 Fuselage > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill > VonDane > To: rv-list(at)matronics.com; rv8list(at)yahoogroups.com > Subject: RV-List: Radio Calls... > > > Can someone give me some example of how to properly call an > "initial" > and a "360 Overhead"? > > Thanks! > > > Bill VonDane > RV-8A > www.vondane.com > www.creativair.com > www.epanelbuilder.com > > > > > > > > > > The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Sep 06, 2003
Phil, Yes, contact the tower as far out as possible. The tower will most likely then tell you to Report a "X" nm Initial. Then just follow their directions. Takes the guess work out of it when using the tower. I have had towers tell me to report a 5 nm Initial. I think the 1-3 nm range is so that you can avoid over flying something on the ground where a fixed distance might force you to fly near/over a school or tower, etc, etc. Love this list, love the RV series Tom Gummo Apple Valley, Ca ----- Original Message ----- From: "Phat Phil" <phugoid(at)comcast.net> Subject: Re: RV-List: re: radio calls > > I've been following this thread with great interest. > I keep reading that you call initial 1 to 3 miles out. > My question is: is this your first contact with the tower or do you > contact them 5 to 10 miles as i think most of us do > and inform them of your intentions? > > Phil > > > Tom Gummo wrote: > > > > >I would like to add something here. > > > >Even if you don't know anything about the overhead pattern, it should not > >effect the way you fly your pattern. The pilot calling INITIAL at a > >uncontrolled field has the responsibility to fit his plane or flight into > >the other aircraft already in the pattern. At a controlled field, the > >controller should be doing this. > > > >Knowledge is power. Now that you know a little about the pattern, you > >should know where to look for this traffic. This is in case he / she makes > >a mistake and breaks into you. (I would not want to die just because I am > >right or have the right of way. Your point!) > > > >The break over the numbers only works if there is no one already on > >downwind. With a plane on downwind, I would delay the break (turn to > >downwind) until I knew I had proper spacing on the aircraft in front of me. > >In other words, I would wait until all the downwind traffic passed me and > >then I would break and follow them in. > > > >No radio, well we are all to look around the pattern and avoid aircraft that > >don't see us. > > > >Have fun. > > > >Too bad we all can't get together for a little face to face time as a 15 > >minute briefing would answer just about everybody's questions. > > > >Again, anybody with questions can please contact me off the list and I will > >do my best to answer them. > > > >Tom > >t.gummo(at)verizon.net > > > > > > ________________________________________________________________________________
Date: Sep 06, 2003
Subject: 9th Annual RV Forum, EAA486 Fulton NY
GETTING CLOSE....see you there??? Counting now some 23 RV's from Mid Atlantic RV Wing of Van's Air Force now planning to make the trip. That is just 1 group, which provided @12 last year (out of the 56= RV's). If you want to se RV's and perhaps beg a ride you really have some of the best odds here ever!!! Not to late to attend drop us a line at: Bill Hodge..... DRmotorHD(at)aol.com David McManmon.... McManD(at)aol.com September 12, 2003 Friday night fly in, cook out and camp out. The EAA 486 General meeting night too. September 13, 2003 Saturday technical seminars all day, meals provided to paid attendee's. Then a nice dinner banquet with a presentation. This year Mr. Kirk House, ex-Director Curator of the Glenn Cirtiss Museum will talk about the books on Glenn he wrote, and how Glenn was the ultimate Experimenter! September 14, 2003 Sunday AM our great pancake breakfast and perhaps a coordinated fly out for lunch, planes, weather and pilots willing. see us at www.eaachapter486.com Last year over 56 RV's and 25 SPAM's flew in with over 150 attendee's. There was Mike Seager and the Factory RV6 doing instruction and manufacturers like Lycoming and Aerospace logic with tables displaying and selling their wares. I could go on...but you get the picture...just ask some one who has been there the $45 is easily worth it. Hope to See you all there. Respectfully, David McManmon President EAA 486 RV6 Flying, Builder, Pilot N58DM DNA ________________________________________________________________________________
Date: Sep 06, 2003
From: Charlie & Tupper England <cengland(at)netdoor.com>
Subject: Slobovia Outernational Airport flyin/party
You are all cordially invited to the next flyin lunch/supper/all-weekend-long hangar party at Slobovia Outernational Airport, 10 miles north of Jackson MS on October 17-19, 2003. If flying fun isn't enough reason to party, it's wedding anniversary time for two families here, so come & help us celebrate. Overnighters are welcome any time after noon on Friday, and are welcome to stay through Sunday. Bring your bed roll and if desired, a tent. We have lots of indoor floor space & even more outdoor tent space, so come on down! We had a great turnout in July with about 45 planes, including around 20 RV's. We are hoping for at least twice that number in October. The noon meal on Saturday will again be 'pulled pork', thanks to the wonderful wives here in our strange corner of the universe. If you can stay for the hangar party Saturday night, we plan on having pizza & 'beverages' with a live band for entertainment. Bring your dancin' shoes. You can get info about our airport at airnav.com http://www.airnav.com/airport/MS71 Update: runway length is now 4800 feet. Disclaimer: Slobovia is a private airport. Pilots operate at their own risk. If you need driving directions or more info, feel free to email me at cengland(at)netdoor.com or call at 601-879-9596. FAA Identifier: MS71 Lat/Long: 32-29-42.508N / 090-17-34.325W 32-29.70847N / 090-17.57208W 32.4951411 / -90.2928681 (estimated) Elevation: 250 ft. / 76 m (estimated) Variation: 03E (1985) From city: 1 mile N of POCAHONTAS, MS Airport Operations Airport use: Private use. Permission required prior to landing Activation date: 11/1988 Sectional chart: MEMPHIS <http://www.airnav.com/ad/click/taHR0cDovL3d3dy5hdnNob3.uY29tL3NlY3Rpb25hbGNoYXJ0cy5odG1sP3Jl+LZj05MyBhdnNob3..> Control tower: no ARTCC: MEMPHIS CENTER FSS: GREENWOOD FLIGHT SERVICE STATION [1-800-WX-BRIEF] Attendance: UNATNDD Wind indicator: yes Segmented circle: no Lights: RDO REQ Beacon: unknown Airport Communications UNICOM: 122.75 WX ASOS at HKS (10 nm S): 120.625 (601-354-4037) WX ASOS at JAN (16 nm SE): PHONE 601-932-2822 Nearby radio navigation aids VOR radial/distance VOR name Freq Var JAN <http://www.airnav.com/cgi-bin/navaid-info?id=JAN&type=VORTAC&name=JACKSON>r258/6.4 JACKSON VORTAC 112.60 05E NDB name Hdg/Dist Freq Var ID BRENZ <http://www.airnav.com/cgi-bin/navaid-info?type=NDB&id=JH&name=BRENZ> 340/5.2 260 02E JH .--- .... RAYMOND <http://www.airnav.com/cgi-bin/navaid-info?type=NDB&id=RYB&name=RAYMOND> 024/13.1 375 03E RYB .-. -.-- -... VICKSBURG <http://www.airnav.com/cgi-bin/navaid-info?type=NDB&id=VKS&name=VICKSBURG> 061/35.8 382 03E VKS ...- -.- ... Airport Services Runway Information Runway 15/33 Dimensions: 3540 x 80 ft. / 1079 x 24 m Surface: turf RUNWAY 15 RUNWAY 33 Traffic pattern: left left Obstructions: 70 ft. trees, 200 ft. from runway none ________________________________________________________________________________
Date: Sep 07, 2003
Subject: Re: Slobovia Outernational Airport flyin/party
Hi ya'll. Appreciate the invite. I enjoyed the last shindig and would love to come back. Unfortunately that is the same date as the annual RV fly in at Las Cruces, NM which several of us have already planned for....but if WX or ?? fouls that trip MS71 will be our alternate. Thanks and hope u have a blast. Doug Preston RV8 N127EK BHM ________________________________________________________________________________
Date: Sep 07, 2003
Subject: Plemun
Dan I have what you need,I will try to send your way later today!! John McMahon (rv6 ) ________________________________________________________________________________
Date: Sep 07, 2003
Subject: Re: photos of aluminum plenums
> If anybody has any photos of an aluminum plenum (dog house), can you > please > send them my way? I'm just trying to gather perspective (aka: steal > ideas) > before building mine. Dan, Here are a couple web sites I stashed away. I'd be interested if you get any additional pointers. You know, this would make a great after market item for one of our entrepreneurial builders out there. http://www.geocities.com/CapeCanaveral/Hangar/5379/eng1.html http://rv8a.tripod.com/plenum.html Jim Daniels ________________________________________________________________________________
Date: Sep 07, 2003
I don't think they have to be exactly the same (rounded shape) as the cowl inlets. Most of plenums I have seen, mine included, made the inlets square, and it is not too difficult to seal the area with airseal as you describe. With a conventional baffle system, you use airseal fabric to seal the bottom and sides in much the same way, with a plenum you are just adding the top to be sealed as well. I did it with two pieces on each side, top and bottom. The trick, and the most difficult part of designing/ building the plenum IMHO, is to get the inlets to align as close as possible to the cowl inlets (assuming the cowl is fit) as this makes it much easier to seal the inlets. Still having trouble with my scanner, as soon as I sort it out I will send the pics I promised last night. Jeff Point Dan Checkoway wrote: ________________________________________________________________________________
Date: Sep 07, 2003
There is an exception to the square inlets mentioned below. However, it's not an aluminum plenum... The original Steve Barnhard (sp?) cowl uses a round inlet - actually a turned aluminum piece that is held in place by a groove in the upper and lower cowls. It is connected to the plenum with a tubular piece of rubber (truck inner tube) clamped at both ends. The tube connects to a fiberglass molded inlet to the plenum area. The cowl pieces can be seen here.... http://www.rv-8.com/Cowl.htm#The%20Cowl And I think this is the same part - just updated from Steve's..... http://www.jamesaircraft.com/ gil in Tucson > >I don't think they have to be exactly the same (rounded shape) as the >cowl inlets. Most of plenums I have seen, mine included, made the >inlets square, and it is not too difficult to seal the area with airseal >as you describe. With a conventional baffle system, you use airseal >fabric to seal the bottom and sides in much the same way, with a plenum >you are just adding the top to be sealed as well. I did it with two >pieces on each side, top and bottom. The trick, and the most difficult >part of designing/ building the plenum IMHO, is to get the inlets to >align as close as possible to the cowl inlets (assuming the cowl is fit) >as this makes it much easier to seal the inlets. > >Still having trouble with my scanner, as soon as I sort it out I will >send the pics I promised last night. > >Jeff Point > >Dan Checkoway wrote: > > RV-6A, #20701 .. fitting out firewall... 77 Tiger N28478 at 57AZ ________________________________________________________________________________
Subject: Alternator
Date: Sep 07, 2003
The Pelican alternator sold by ACS is off of a Chevy Sprint Spectrum. It is a small 65 amp alternator that is self regulating and has automatic overheat protection that resets when an overheated condition is resolved. I have one and it works well. Jim Cone 3peat offender From: "Ronnie Brown" <romott(at)adelphia.net> Subject: RV-List: Alternator for Lycoming Does anyone know what automotive alternator (make and model of the vehicle), that the Lycoming alternator is copied from? "Are you still wasting your time with spam?... There is a solution!" Protected by GIANT Company's Spam Inspector The most powerful anti-spam software available. http://www.giantcompany.com ________________________________________________________________________________
Date: Sep 07, 2003
Hi, Normally with a tower controlled field I would call them within 10nm of the field and tell them that you wish to wish to report initial for the Overhead. I would tipically say something like: "Lubbock Tower, Viper 11, ten nautical miles west of the field for Initial Rwy 30" (assuming I had the atis and knew what the active runway was). Then normally tower will have you report initial (the 1-3nm call). Some towers will just then say "Roger Viper 11 report base". Which is clearance to initial, clearance to break and you don't need to call initial with this clearance. The next call is the base call. Obviously while flying from a position west of the field to set up on the initial going west, I would fly my aircraft to an outside downwind position, turn a 3-5nm "90 to initial" position (like a wide base), then turn initial down the runway active runway (duty runway for our Navy folks). I think that everyones had had great comments on the subject. And common sense always applies. But the overhead pattern and calls are always easier to draw and talk about vs just text on in an email. (a picture is definitely worth a 1000s words) v/r Bill Sipher RV-4 writes: > > I've been following this thread with great interest. > I keep reading that you call initial 1 to 3 miles out. > My question is: is this your first contact with the tower or do you > > contact them 5 to 10 miles as i think most of us do > and inform them of your intentions? > > Phil > > > Tom Gummo wrote: > > > > >I would like to add something here. > > > >Even if you don't know anything about the overhead pattern, it > should not > >effect the way you fly your pattern. The pilot calling INITIAL at > a > >uncontrolled field has the responsibility to fit his plane or > flight into > >the other aircraft already in the pattern. At a controlled field, > the > >controller should be doing this. > > > >Knowledge is power. Now that you know a little about the pattern, > you > >should know where to look for this traffic. This is in case he / > she makes > >a mistake and breaks into you. (I would not want to die just > because I am > >right or have the right of way. Your point!) > > > >The break over the numbers only works if there is no one already > on > >downwind. With a plane on downwind, I would delay the break (turn > to > >downwind) until I knew I had proper spacing on the aircraft in > front of me. > >In other words, I would wait until all the downwind traffic passed > me and > >then I would break and follow them in. > > > >No radio, well we are all to look around the pattern and avoid > aircraft that > >don't see us. > > > >Have fun. > > > >Too bad we all can't get together for a little face to face time as > a 15 > >minute briefing would answer just about everybody's questions. > > > >Again, anybody with questions can please contact me off the list > and I will > >do my best to answer them. > > > >Tom > >t.gummo(at)verizon.net > > > > > > > =============== > > > > > > > > The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Sep 07, 2003
From: "BillDube(at)killacycle.com" <BillDube(at)killacycle.com>
Subject: Squeezer on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2552765392&category=31482&rd=1 Looks like a pretty good deal on a squeezer with dies. This unit is set up for 1/4" shank dies, but I'd bet that a regular 214 style C-yoke with a 3/16" push rod would fit. Regardless, it's a heck of a deal as it is. Bill Dube http://www.killacycle.com/Lights.htm ________________________________________________________________________________
Subject: May 2003
Date: Sep 07, 2003
Listers: Until this may, I needed to add air to my tires every 2 to 3 weeks. Definite pain for a non-tinker oriented RVer such as myself. When I changed the tires at the annual in May this year, I went to Michelin Air-Stop tubes. Since that time I have not needed to add air. I haven't checked the pressure since I don't want to lose air, but it pulls out of the hangar just fine. Now I'm getting jazzed. Can I make it until LOE 3? Can I make it six months? Nine months? Maybe just change the air at every annual, like an oil change. If I would have had the tubes before, I probably would not have added the little air fill doors on the wheel pants. These tubes are some of the best money I have ever spent. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Sep 07, 2003
Subject: re: Radio Calls
I too have been reading with great interest this thread about INITIALS. You are never too old to learn. Never having done it nor realized it was a procedure not necessarily reserved for the military (laughable in my Cessna 150) I have been witnessing the practice for years and never put two and two together. You see, here in St.Louis, the Air National Guard is based and routinely flies out of Lambert Field. From the airport observation area across Lindbergh Boulevard, I have witnessed on countless occasions a tight formation flight of of 3 or 4 F-15's returning from a training flight at relatively high speed and smartly breaking right to a downwind, distance between planes ever increasing to maintain equal spacing , deploying the speed brakes, gear, slowing waaaay down in the process, blending base to final in one smooth 180 arc and landing on 12R one after another in perfect unison. This all the while as busy airline traffic is (was) coming and going with no noticeable disruption of traffic. I've seen the whole sequence happen even with a distant airliner on a long final sharing the same runway. Makes perfect sense. I'll sure be happy when I have an airplane worthy of the procedure! Rick Galati RV-6A FWF --------------------------------- ________________________________________________________________________________
Subject: Re: May 2003
Date: Sep 07, 2003
Larry, Larry, Larry, Change the air at every annual!!? Ain't yah never herd of, "if it ain't broke don't fix er". If you got air in them tires what don't leak out, then I'm sayin don't be lettin any of it out no-how! Jim in still smoking Kelowna ----- Original Message ----- From: "Larry Pardue" <n5lp(at)carlsbad.net> Subject: RV-List: May 2003 > > Listers: > > Until this may, I needed to add air to my tires every 2 to 3 weeks. > Definite pain for a non-tinker oriented RVer such as myself. > > When I changed the tires at the annual in May this year, I went to Michelin > Air-Stop tubes. Since that time I have not needed to add air. I haven't > checked the pressure since I don't want to lose air, but it pulls out of the > hangar just fine. > > Now I'm getting jazzed. Can I make it until LOE 3? Can I make it six > months? Nine months? Maybe just change the air at every annual, like an > oil change. > > If I would have had the tubes before, I probably would not have added the > little air fill doors on the wheel pants. These tubes are some of the best > money I have ever spent. > > Larry Pardue > Carlsbad, NM > > RV-6 N441LP Flying > http://www.carlsbadnm.com/n5lp/index.htm > > ________________________________________________________________________________
Date: Sep 07, 2003
Subject: Good deal on an engine?
Hi listers, I have a very good friend who was once building a HyperBipe but gave up on the project after buying almost everything he has to complete the airplane. He has offered to sell me the engine and propeller but neither of us knows what either are worth. Here is what I know about each: The engine is an IO360-B1E, rated at 180 HP at 2700 RPM. It was overhauled a few years ago and I know it got new rings, bearings and valves. However the engine has been sitting on his hangar floor ever since and the plug holes and accessory holes have been open to the air all that time. I see a slight surface rust on some of the accessory gears but the valves and cylinders are bright and shinny. I suppose they have a good coating of lubricant that is doing it's job. Two bendix mags of unknown condition are included. They are all in one piece and include all the plug wires. They both turn freely. A new Airflow Performance fuel injector is included as well as a used Prestolite starter and a used alternator of unknown make. The prop is a Hartzell CS 2-blade that was rebuilt after a prop strike incident. The blades were bent and although the rebuild was done by a reputable propellor shop they could not yellow tag it because the bent tips were bent past the allowable angle to meet certification standards. It is legal to use on an experimental aircraft. I haven't seen the prop governor but I assume there is one somewhere in the hangar. I'll keep looking. If the engine is suitable in other respects I assume that the rear-facing injection can be remedied with a new sump. Given the information above I welcome the list's comments on estimating the value of the engine and prop and the cost of replacing the sump. Have at it guys. Thanks for your help. Ron Schreck RV-8 Gold Hill Airpark, NC PS: Anyone interested in a HyperBipe? ________________________________________________________________________________
Date: Sep 08, 2003
> > Listers: > > Until this may, I needed to add air to my tires every 2 to 3 weeks. > Definite pain for a non-tinker oriented RVer such as myself. > > When I changed the tires at the annual in May this year, I went to Michelin > Air-Stop tubes. Since that time I have not needed to add air. I haven't > checked the pressure since I don't want to lose air, but it pulls out of the > hangar just fine. > > Now I'm getting jazzed. Can I make it until LOE 3? Can I make it six > months? Nine months? Maybe just change the air at every annual, like an > oil change. > > If I would have had the tubes before, I probably would not have added the > little air fill doors on the wheel pants. These tubes are some of the best > money I have ever spent. > > Larry Pardue > Carlsbad, NM > Thanks for the review on the Air-Stop tubes, Larry. I also find that having to haul an air tank out to the hangar ever couple of weeks to top off the tires is bothersome. I looked at the Air-Stop tubes, but decided at their price I would wait until I found some evidence that the were worth their money. Thanks again, let us know 3 month, 6 months from now how they are doing. Ed Anderson N494BW RV-6A Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ________________________________________________________________________________
Subject: Re: Good deal on an engine?
Date: Sep 08, 2003
----- Original Message ----- From: <Ronschreck99(at)aol.com> Subject: RV-List: Good deal on an engine? > > Hi listers, > > I have a very good friend who was once building a HyperBipe but gave up on > the project after buying almost everything he has to complete the airplane. He > has offered to sell me the .... SNIP on estimating the value of the engine and prop and the > cost of replacing the sump. Have at it guys. Thanks for your help. > > Ron Schreck > RV-8 > Gold Hill Airpark, NC > > PS: Anyone interested in a HyperBipe? > Ron, is this Marshall Seymour's HyperBipe Project? I stopped and visited with Marshall and Glen? several years ago and Marshall showed me his HyperBipe project, I must say I was impressed. I presume that Glen has finished his RV? I fly a rotary powered RV-6 and occassionally fly over Gold Hill airpark, guess I should stop by for another visit and see your RV-8 project. Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ________________________________________________________________________________
Date: Sep 08, 2003
Subject: Re: to Danny Melnik
vft(at)aol.com Danny ________________________________________________________________________________
Date: Sep 08, 2003
Subject: Air-Stop tubes
Ed Anderson wrote: > > > > > > Listers: > > > > Until this may, I needed to add air to my tires every 2 to 3 weeks. > > Definite pain for a non-tinker oriented RVer such as myself. > > > > When I changed the tires at the annual in May this year, I went to > Michelin > > Air-Stop tubes. Since that time I have not needed to add air. I haven't > > checked the pressure since I don't want to lose air, but it pulls out of > the > > hangar just fine. > > > > Now I'm getting jazzed. Can I make it until LOE 3? Can I make it six > > months? Nine months? Maybe just change the air at every annual, like an > > oil change. > > > > If I would have had the tubes before, I probably would not have added the > > little air fill doors on the wheel pants. These tubes are some of the > best > > money I have ever spent. > > > > Larry Pardue > > Carlsbad, NM > > > > Thanks for the review on the Air-Stop tubes, Larry. I also find that having > to haul an air tank out to the hangar ever couple of weeks to top off the > tires is bothersome. I looked at the Air-Stop tubes, but decided at their > price I would wait until I found some evidence that the were worth their > money. > > Thanks again, let us know 3 month, 6 months from now how they are doing. > I have had the Air-Stop tubers for a couple of years, and they are the real deal. I usually have to flip the tires a couple of times a year, and that is the only time I add air. I air up the tires to about 35 lbs, and they are still in the mid-twenties six months later. Sam Buchanan ________________________________________________________________________________
Date: Sep 08, 2003
Ron - Sounds like a good boat anchor to me... BTW, what was your friends name and phone no?! ;) Just kidding. I've been out of the engine market several years, but just from what you describe, the package might be worth somewhere between $10 to $20K. Sorry for the wide range, but there seem to be lots of variables. A known prop strike, sitting unprotected with rust showing, not knowing who did the previous work, what plane was it on before, got any log books, any of the engine components yellow tagged when the previous work was done? If I was the purchaser, I don't think I'd be able to hang it and fly. I'd most certainly want to tear it down (prop included) due to the prop strike, corrosion, questionable background, etc., driving the price down. Also, that rear facing induction system sounds like it might work fine with the "snorkel" (?) induction system. Eliminates the need for the lower cowl air intake. my 2 cents Bryan Jones -8 Pearland, Texas >I have a very good friend who was once building a HyperBipe but gave up on >the project after buying almost everything he has to complete the airplane. > He >has offered to sell me the engine and propeller but neither of us knows >what >either are worth. Here is what I know about each: The engine is an >IO360-B1E, >rated at 180 HP at 2700 RPM. It was overhauled a few years ago and I know >it Fast, faster, fastest: Upgrade to Cable or DSL today! https://broadband.msn.com ________________________________________________________________________________
Subject: My static system woes
Date: Sep 08, 2003
Fellow listers, I have been getting my radio stack up and running - and in order to verify my transponder, I need to test my static system. That's where the fun begins! I can't even get the fitting on the back of the altimeter to hold without dropping vacuum. I'm using the blue anidized AN fittings with aluminum tubing on the instrument panel to a pair of bulkhead fittings (1 pitot and 1 static) then aft to the rest of the system. I started with just the altimeter as that instrument should be leak-free in order to function correctly. The archives have a reference to plumbers pipe dope for the plastic fittings - but nothing for the aluminum AN fittings. I have also found the listings on acceptable leakdown rates etc. What I would really like to know is how the system is supposed to show and when - during the testing process?! If my system is completely assembled (pitot/static and VSI/ASI), I know that the VSI has a built in 'leak', the ASI uses static for something (but I can't remember what it's impact is during testing). I know that this info is somewhere out there as everyone that is flying should have had this stuff checked...... Thanks, Ralph Capen ________________________________________________________________________________
Subject: Re: Air-Stop tubes
Date: Sep 08, 2003
Where is the best place to buy these tubes ... I want to order TODAY !!!!! Thanks !! Len Leggette, RV-8A Greensobro, NC N910LL 136 hrs ----- Original Message ----- From: Sam Buchanan <sbuc(at)hiwaay.net> Subject: RV-List: Air-Stop tubes > > > Ed Anderson wrote: > > > > > > > > > > Listers: > > > > > > Until this may, I needed to add air to my tires every 2 to 3 weeks. > > > Definite pain for a non-tinker oriented RVer such as myself. > > > > > > When I changed the tires at the annual in May this year, I went to > > Michelin > > > Air-Stop tubes. Since that time I have not needed to add air. I haven't > > > checked the pressure since I don't want to lose air, but it pulls out of > > the > > > hangar just fine. > > > > > > Now I'm getting jazzed. Can I make it until LOE 3? Can I make it six > > > months? Nine months? Maybe just change the air at every annual, like an > > > oil change. > > > > > > If I would have had the tubes before, I probably would not have added the > > > little air fill doors on the wheel pants. These tubes are some of the > > best > > > money I have ever spent. > > > > > > Larry Pardue > > > Carlsbad, NM > > > > > > > Thanks for the review on the Air-Stop tubes, Larry. I also find that having > > to haul an air tank out to the hangar ever couple of weeks to top off the > > tires is bothersome. I looked at the Air-Stop tubes, but decided at their > > price I would wait until I found some evidence that the were worth their > > money. > > > > Thanks again, let us know 3 month, 6 months from now how they are doing. > > > > > I have had the Air-Stop tubers for a couple of years, and they are the > real deal. I usually have to flip the tires a couple of times a year, > and that is the only time I add air. I air up the tires to about 35 lbs, > and they are still in the mid-twenties six months later. > > Sam Buchanan > > ________________________________________________________________________________
Date: Sep 08, 2003
> > >Where is the best place to buy these tubes ... I want to order TODAY !!!!! > >Thanks !! > >Len Leggette, RV-8A >Greensobro, NC N910LL >136 hrs > Len, I just received a set from Spruce the other day. My fourth annual is due this month and I'm going to install them. I'm tired of pumping up my tires all the time! I was ordering other stuff, so I got the tubes as well. To just order the tubes, I'd try Desser tire first. Might have better pricing. Brian Denk RV8 N94BD ________________________________________________________________________________
Date: Sep 08, 2003
Brian: I tried Dresser but they show some kind of "new age" leak proof tube but not the Michelin Air Stop ??? Len ----- Original Message ----- From: Brian Denk <akroguy(at)hotmail.com> Subject: Re: RV-List: Air-Stop tubes > > > > > > > >Where is the best place to buy these tubes ... I want to order TODAY !!!!! > > > >Thanks !! > > > >Len Leggette, RV-8A > >Greensobro, NC N910LL > >136 hrs > > > > Len, > > I just received a set from Spruce the other day. My fourth annual is due > this month and I'm going to install them. I'm tired of pumping up my tires > all the time! I was ordering other stuff, so I got the tubes as well. To > just order the tubes, I'd try Desser tire first. Might have better pricing. > > Brian Denk > RV8 N94BD > > ________________________________________________________________________________
Date: Sep 08, 2003
Len, check with Van's. I believe they carry a "slow leak" tube now. > From: "Len Leggette" <len(at)jessicacharles.com> > Reply-To: rv-list(at)matronics.com > Date: Mon, 8 Sep 2003 10:47:15 -0400 > To: > Subject: Re: RV-List: Air-Stop tubes > > > Where is the best place to buy these tubes ... I want to order TODAY !!!!! > > Thanks !! > > Len Leggette, RV-8A > Greensobro, NC N910LL > 136 hrs > > > ----- Original Message ----- > From: Sam Buchanan <sbuc(at)hiwaay.net> > To: > Subject: RV-List: Air-Stop tubes > > >> >> >> Ed Anderson wrote: >>> >>> >>>> >>>> Listers: >>>> >>>> Until this may, I needed to add air to my tires every 2 to 3 weeks. >>>> Definite pain for a non-tinker oriented RVer such as myself. >>>> >>>> When I changed the tires at the annual in May this year, I went to >>> Michelin >>>> Air-Stop tubes. Since that time I have not needed to add air. I > haven't >>>> checked the pressure since I don't want to lose air, but it pulls out > of >>> the >>>> hangar just fine. >>>> >>>> Now I'm getting jazzed. Can I make it until LOE 3? Can I make it six >>>> months? Nine months? Maybe just change the air at every annual, like > an >>>> oil change. >>>> >>>> If I would have had the tubes before, I probably would not have added > the >>>> little air fill doors on the wheel pants. These tubes are some of the >>> best >>>> money I have ever spent. >>>> >>>> Larry Pardue >>>> Carlsbad, NM >>>> >>> >>> Thanks for the review on the Air-Stop tubes, Larry. I also find that > having >>> to haul an air tank out to the hangar ever couple of weeks to top off > the >>> tires is bothersome. I looked at the Air-Stop tubes, but decided at > their >>> price I would wait until I found some evidence that the were worth their >>> money. >>> >>> Thanks again, let us know 3 month, 6 months from now how they are doing. >>> >> >> >> I have had the Air-Stop tubers for a couple of years, and they are the >> real deal. I usually have to flip the tires a couple of times a year, >> and that is the only time I add air. I air up the tires to about 35 lbs, >> and they are still in the mid-twenties six months later. >> >> Sam Buchanan >> >> > > > > > > ________________________________________________________________________________
Subject: Michelin Airstop Tubes
Date: Sep 08, 2003
List: This may be a first .... AC$ is actually cheaper than someone !!!!! $5 per tube less than Dresser. Len Leggette RV-8A Greensboro, NC N910LL 136 hrs ________________________________________________________________________________
Subject: SIRS Navigator Compass Adjustment Tool
Date: Sep 08, 2003
I've torn my shop apart but cannot find the adjustment tool for my SIRS Navigator compass. It is a special plastic tool that fits over a small triangle in the compass to allow adjusting the compass. I looked on their web site and I can buy one for $7.00, but Van's doesn't carry it. Just wondering if anyone on the list has a spare laying around? Doug Medema RV-6A N276DM almost ready for inspection! ________________________________________________________________________________
Date: Sep 08, 2003
Len Leggette wrote: > > > Brian: > > I tried Dresser but they show some kind of "new age" leak proof tube but not > the Michelin Air Stop ??? Here is the link at Desser for the Air-Stops: http://shop.desser.com/iwwida.pvx?;item?item_no=TU%20500-5%20MN%20%20%20%201&source=sc (be sure you paste the entire link to one line) Sam Buchanan ========================= > ________________________________________________________________________________
Date: Sep 08, 2003
FWIW I have been told and I don't know if it is true... that aircraft tires leak more than regular tires because they have to use a softer rubber compound to meet the low temp performance on the TSO. I have also been told, and I don't know if it is true.... that nitrogen leaks slower than air because N2 molecules are larger than air molecules. I know that air is 80 some percent Nitrogen, but if the 17% O2 leaked out that would lower the pressure.... Anybody know? Any trivial pursuit players out there???? Tailwinds, Doug ----- Original Message ----- From: "Len Leggette" <len(at)jessicacharles.com> Subject: Re: RV-List: Air-Stop tubes > > Brian: > > I tried Dresser but they show some kind of "new age" leak proof tube but not > the Michelin Air Stop ??? > > Len > ----- Original Message ----- > From: Brian Denk <akroguy(at)hotmail.com> > To: > Subject: Re: RV-List: Air-Stop tubes > > > > > > > > > > > > > > >Where is the best place to buy these tubes ... I want to order TODAY > !!!!! > > > > > >Thanks !! > > > > > >Len Leggette, RV-8A > > >Greensobro, NC N910LL > > >136 hrs > > > > > > > Len, > > > > I just received a set from Spruce the other day. My fourth annual is due > > this month and I'm going to install them. I'm tired of pumping up my > tires > > all the time! I was ordering other stuff, so I got the tubes as well. To > > just order the tubes, I'd try Desser tire first. Might have better > pricing. > > > > Brian Denk > > RV8 N94BD > > > > > > ________________________________________________________________________________
Date: Sep 08, 2003
I can't answer as to the relative size of the molecules, But I have always been told that the tube must retain its flexibility at 40 below. Natural rubber has been the only tube material that has been able to do this. Now I guess they have compounded a synthetic that meets this FAA requirement. Cy Galley - Bellanca Champion Club Newsletter Editor & EAA TC www.bellanca-championclub.com Actively supporting Aeroncas every day Quarterly newsletters on time Reasonable document reprints ----- Original Message ----- From: "Doug Rozendaal" <dougr(at)petroblend.com> Subject: Re: RV-List: Air-Stop tubes > > FWIW > I have been told and I don't know if it is true... that aircraft tires leak > more than regular tires because they have to use a softer rubber compound to > meet the low temp performance on the TSO. > > I have also been told, and I don't know if it is true.... that nitrogen > leaks slower than air because N2 molecules are larger than air molecules. I > know that air is 80 some percent Nitrogen, but if the 17% O2 leaked out that > would lower the pressure.... > > Anybody know? Any trivial pursuit players out there???? > > Tailwinds, > Doug > > ----- Original Message ----- > From: "Len Leggette" <len(at)jessicacharles.com> > To: > Subject: Re: RV-List: Air-Stop tubes > > > > > > Brian: > > > > I tried Dresser but they show some kind of "new age" leak proof tube but > not > > the Michelin Air Stop ??? > > > > Len > > ----- Original Message ----- > > From: Brian Denk <akroguy(at)hotmail.com> > > To: > > Subject: Re: RV-List: Air-Stop tubes > > > > > > > > > > > > > > > > > > > > > >Where is the best place to buy these tubes ... I want to order TODAY > > !!!!! > > > > > > > >Thanks !! > > > > > > > >Len Leggette, RV-8A > > > >Greensobro, NC N910LL > > > >136 hrs > > > > > > > > > > Len, > > > > > > I just received a set from Spruce the other day. My fourth annual is > due > > > this month and I'm going to install them. I'm tired of pumping up my > > tires > > > all the time! I was ordering other stuff, so I got the tubes as well. > To > > > just order the tubes, I'd try Desser tire first. Might have better > > pricing. > > > > > > Brian Denk > > > RV8 N94BD > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 08, 2003
Doug and all, I don't play a chemist on TV but I do teach chemistry at the local junior college. Nitrogen molecule is smaller than the Oxygen molecule. Both are diatomic, which means that they have two atoms in the natural molecule. I would think that Nitrogen would escape first if size was the only function. The most other junk in the air have more than two atoms, water-H two O, has three; carbon dioxide- C O two, has three; etc, etc and therefore are bigger yet. There are some trace amount of other stuff but I don't think there is enough to make a difference. Now to answers Doug's question. The total pressure of a enclosed gas system, the inside of a inner tube - for example, is the sum of the partial pressures of all the components. So if one of the components is able to leak out, the pressure would go down. So, yes the pressure would go down if either Nitrogen or Oxygen was able to leak out. Tom Gummo Part Time Instructor of Chem 100 at Victor Valley Community College Outstanding Graduate in Chemistry at Cal Poly - Pomona, 1970 Retired F-4G Fighter Pilot Instructor Pilot for Wild Weasels Pres EAA Local Chapter 768 - Apple Valley Airport (soon to be term limited out of a job) :-) Air Boss of the Apple Valley Air Fair 2002 and 2003 NO MATTER WHAT I HAVE DONE IN LIFE, DOUG GETS TO FLY ALL TYPE OF WW-II AIRCRAFT, SO I HAVE TO JUST KEEP ON HATING HIM. P.S. - Doug, there is always a Rocket Ride waiting for you if you get out this way. ----- Original Message ----- From: "Doug Rozendaal" <dougr(at)petroblend.com> Subject: Re: RV-List: Air-Stop tubes > > FWIW > I have been told and I don't know if it is true... that aircraft tires leak > more than regular tires because they have to use a softer rubber compound to > meet the low temp performance on the TSO. > > I have also been told, and I don't know if it is true.... that nitrogen > leaks slower than air because N2 molecules are larger than air molecules. I > know that air is 80 some percent Nitrogen, but if the 17% O2 leaked out that > would lower the pressure.... > > Anybody know? Any trivial pursuit players out there???? > > Tailwinds, > Doug > > ----- Original Message ----- > From: "Len Leggette" <len(at)jessicacharles.com> > To: > Subject: Re: RV-List: Air-Stop tubes > > > > > > Brian: > > > > I tried Dresser but they show some kind of "new age" leak proof tube but > not > > the Michelin Air Stop ??? > > > > Len > > ----- Original Message ----- > > From: Brian Denk <akroguy(at)hotmail.com> > > To: > > Subject: Re: RV-List: Air-Stop tubes > > > > > > > > > > > > > > > > > > > > > >Where is the best place to buy these tubes ... I want to order TODAY > > !!!!! > > > > > > > >Thanks !! > > > > > > > >Len Leggette, RV-8A > > > >Greensobro, NC N910LL > > > >136 hrs > > > > > > > > > > Len, > > > > > > I just received a set from Spruce the other day. My fourth annual is > due > > > this month and I'm going to install them. I'm tired of pumping up my > > tires > > > all the time! I was ordering other stuff, so I got the tubes as well. > To > > > just order the tubes, I'd try Desser tire first. Might have better > > pricing. > > > > > > Brian Denk > > > RV8 N94BD > > > > > > > > > > > > ________________________________________________________________________________
"'rv9-list(at)matronics.com'" , "'wing(at)vansairforce.org'"
Subject: First flight of C-FSTB
Date: Sep 08, 2003
I'm very pleased to announce that RV-9endurance, kit # 90113, has now become an airplane. Power is supplied by a Turbocharged 13B Mazda rotary engine, with a 76" 3-blade IVO Magnum with electronic constant speed governor. It was built from a standard kit and engine was rebuilt myself from a junkyard engine. Everything was done myself, including paint & upholstery. I'm extremely pleased with and proud of the results. The plane fly's exactly as I remembered from my demo flight 3 years ago. Very easy to fly. The engine is very smooth & quiet. So far I've not used any boost at all as we've been very conservative with it. As I'm a student pilot, I now am looking forward to finishing my training in my own plane. Test pilot for the first 3 flights is an experienced commercial bush pilot, however as he was unfamiliar with the rotary engine (but very interested in it), I was along as flight engineer. This worked very well as all he had to do was fly the plane. All other duties were my responsibility. As my test pilot/instructor has had to return to his regular flying job, testing is on hold for a week. I'm still in the "Holy ****, I can't believe it's flying" phase, so next flights will begin to put the plane through it's paces. As every first flight report before has stated, It really is worth all the sacrifices and hard work, so keep on pounding! I found the building process to be tremendously enjoyable, particularly the FWF development of an alternative engine, however it sure is pretty damn cool to be flying it now! :-) Thanks to the FlyRotary group and the AeroElectric list for all the knowledge that is freely shared. The adventure continues...... S. Todd Bartrim Turbo 13B RX-9endurance C-FSTB http://www3.telus.net/haywire/RV-9/C-FSTB.htm "Imagination is more important than knowledge" -Albert Einstein ________________________________________________________________________________
Date: Sep 08, 2003
I put Air-Stop tubes in when I changed my tires in January. I think I added two pounds during my annual in June. I always had to add air to the old tubes. I agree...the best money I've ever spent. Jim James Cimino RV-8 SN 80039 100+ Hours 570-842-4057 http://www.geocities.com/jcimino.geo/ ----- Original Message ----- From: "Sam Buchanan" <sbuc(at)hiwaay.net> Subject: RV-List: Air-Stop tubes > > > Ed Anderson wrote: > > > > > > > > > > Listers: > > > > > > Until this may, I needed to add air to my tires every 2 to 3 weeks. > > > Definite pain for a non-tinker oriented RVer such as myself. > > > > > > When I changed the tires at the annual in May this year, I went to > > Michelin > > > Air-Stop tubes. Since that time I have not needed to add air. I haven't > > > checked the pressure since I don't want to lose air, but it pulls out of > > the > > > hangar just fine. > > > > > > Now I'm getting jazzed. Can I make it until LOE 3? Can I make it six > > > months? Nine months? Maybe just change the air at every annual, like an > > > oil change. > > > > > > If I would have had the tubes before, I probably would not have added the > > > little air fill doors on the wheel pants. These tubes are some of the > > best > > > money I have ever spent. > > > > > > Larry Pardue > > > Carlsbad, NM > > > > > > > Thanks for the review on the Air-Stop tubes, Larry. I also find that having > > to haul an air tank out to the hangar ever couple of weeks to top off the > > tires is bothersome. I looked at the Air-Stop tubes, but decided at their > > price I would wait until I found some evidence that the were worth their > > money. > > > > Thanks again, let us know 3 month, 6 months from now how they are doing. > > > > > I have had the Air-Stop tubers for a couple of years, and they are the > real deal. I usually have to flip the tires a couple of times a year, > and that is the only time I add air. I air up the tires to about 35 lbs, > and they are still in the mid-twenties six months later. > > Sam Buchanan > > ________________________________________________________________________________
Subject: Re: Avery or Cleveland?
Date: Sep 07, 2003
I have the Cleaveland 3/32" dimple die which I bought and an Avery die which I won in a door prize. Of the two I prefer the Cleaveland as its made of stainless steel and still has a good polish after 8 years whereas the Avery is now dull. But the Cleaveland one was (is?) more expensive. The 1/8" die is an Avery and it worked fine. All the other dies I made myself on my lathe and therefore cannot comment further. Cheers!!--Henry Hore ________________________________________________________________________________
Date: Sep 08, 2003
> I have also been told, and I don't know if it is true.... > that nitrogen leaks slower than air because N2 molecules are > larger than air molecules. I know that air is 80 some > percent Nitrogen, but if the 17% O2 leaked out that would > lower the pressure.... > > Anybody know? Any trivial pursuit players out there???? Yeah, I could just imagine: "Top the tanks with 100LL and put a little more gaseous plutonium in the mains" Alex Peterson Maple Grove, MN RV6-A N66AP 369 hours www.usfamily.net/web/alexpeterson updated! ________________________________________________________________________________
Subject: Re: Michelin Airstop Tubes now RV10 interiors
Date: Sep 08, 2003
> >Brian: > >Actually I am going into the RV Upholstery business. I have a new website >and will be posting pictures and options very soon. I have built several >sets to date, 52 leathers colors to choose from and about 70 fabrics. The >seats for RVs are pretty easy when you are use to manufacturing high end >upholstery. I'll let you and the list know when my site is up. > >Len Great! I look forward to seeing what you may come up with for the -10. I can see some very elaborate interiors showing up in these a/c in the near future. For me, my mission is comfort...and that means noise reduction and a comfy ride. Gotta figure out how to mount a DVD player in the roof for Skyler to watch on the long trips! Brian Denk RV8 N94BD ________________________________________________________________________________
Date: Sep 08, 2003
I have several dimple die sets from Cleveland that look very good after 12 years and make a very good dimple. They are made from stainless steel. Last week I borrowed a #8 screw die set from an RV8 builder/neighbor that is so corroded I don't think I will use it. He says it is only a couple years old. Have been very pleased with everything purchased from Cleveland. Dale Ensing RV6A ________________________________________________________________________________
Subject: to Danny Melnik
Date: Sep 08, 2003
This is just what I'm looking for. Please let Matt know. I'm also still receiving tons of email regarding RV topics. I would just like to get the pics only. Thanks, Leslye -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of VFT(at)aol.com Subject: Re: RV-List: to Danny Melnik vft(at)aol.com Danny direct advertising on the Matronics Forums. ________________________________________________________________________________
Subject: SP-200
Date: Sep 09, 2003
Does anyone have any experience with the hand held SP-200 NAV/COM from Sporty's? Looks like it may do the same job as the ICOM but with a LOC function. Thanks Steve Glasgow ________________________________________________________________________________
Date: Sep 09, 2003
In a message dated 9/9/2003 3:02:37 AM Eastern Daylight Time, rv-list-digest(at)matronics.com writes: > > Ron - > > Sounds like a good boat anchor to me... BTW, what was your friends name and > > phone no?! ;) > > Just kidding. I've been out of the engine market several years, but just > from what you describe, the package might be worth somewhere between $10 to > $20K. Sorry for the wide range, but there seem to be lots of variables. A > known prop strike, sitting unprotected with rust showing, not knowing who > did the previous work, what plane was it on before, got any log books, any > of the engine components yellow tagged when the previous work was done? > > If I was the purchaser, I don't think I'd be able to hang it and fly. I'd > most certainly want to tear it down (prop included) due to the prop strike, > corrosion, questionable background, etc., driving the price down. Also, > that rear facing induction system sounds like it might work fine with the > "snorkel" (?) induction system. Eliminates the need for the lower cowl air > intake. > > my 2 cents > > Bryan Jones -8 > Pearland, Texas > > >I have a very good friend who was once building a HyperBipe but gave up on > >the project after buying almost everything he has to complete the airplane. > > > He > >has offered to sell me the engine and propeller but neither of us knows > >what > >either are worth. Here is what I know about each: The engine is an > >IO360-B1E, > >rated at 180 HP at 2700 RPM. It was overhauled a few years ago and I know > >it > Actually I know a lot about the engine. It came to an engine overhaul shop in pieces and they rebuilt it with a reconditioned crank to certified specs. The log book and yellow tags are right here. The prop was overhauled by a reputable shop as well. My only concern is possible damage to the engine due to sitting open (in the hangar) for 5 years. It has been covered by a tarp but the plug holes and accessory holes are open. The rear sump has been dealt with before according to the archives. Anyone know the cost to swap it with a front induction? Or, anyone have one to trade? Thanks. Ron Schreck RV-8 ________________________________________________________________________________
Date: Sep 09, 2003
Hi Ron, Just as a comparasion, the engine I fly behind is an AEIO-360 (180)hp that has 800TTSNEW, and I paid $9500.00 for it last year. A new Superior/ECI 360 will be somewhere between $15-22K. in the end, it's worth what someone will pay for it....if it were me, I'd probably ask somewhere between $10-12K for it. I think it's going to be hard to get a bunch more, just because of the fact that it has been sitting "un-pickled" and "open" for a period of time, and depending on the environment, could have some spotty corrosion in the cylinders (if they are steel), and possibly on the crank as well. At the very least, I would recommend whoever buys it to do a cursory tear-down inspection just to look it over. The engine could be a great deal, and I wouldn't hesitate to use it, just make sure everything looks good. Other than that, it's just a bunch of people's opinions! Cheers, Stein Bruch RV6's, Minneapolis http://www.steinair.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ronschreck99(at)aol.com Subject: RV-List: Re: Good deal on an engine? Actually I know a lot about the engine. It came to an engine overhaul shop in pieces and they rebuilt it with a reconditioned crank to certified specs. The log book and yellow tags are right here. The prop was overhauled by a reputable shop as well. My only concern is possible damage to the engine due to sitting open (in the hangar) for 5 years. It has been covered by a tarp but the plug holes and accessory holes are open. The rear sump has been dealt with before according to the archives. Anyone know the cost to swap it with a front induction? Or, anyone have one to trade? Thanks. Ron Schreck RV-8 ________________________________________________________________________________
Subject: Re: First flight of C-FSTB
Date: Sep 09, 2003
Todd, CONGRATULATIONS and WELL DONE !!!!! Chuck & Dave Rowbotham RV-8A >From: "Bartrim, Todd" <sbartrim(at)mail.canfor.ca> >Reply-To: rv-list(at)matronics.com >To: "'rv-list(at)matronics.com'" , >"'rv9-list(at)matronics.com'" , >"'wing(at)vansairforce.org'" >Subject: RV-List: First flight of C-FSTB >Date: Mon, 8 Sep 2003 14:06:14 -0700 > > > I'm very pleased to announce that RV-9endurance, kit # 90113, has >now become an airplane. Power is supplied by a Turbocharged 13B Mazda >rotary >engine, with a 76" 3-blade IVO Magnum with electronic constant speed >governor. It was built from a standard kit and engine was rebuilt myself >from a junkyard engine. Everything was done myself, including paint & >upholstery. I'm extremely pleased with and proud of the results. > The plane fly's exactly as I remembered from my demo flight 3 >years >ago. Very easy to fly. The engine is very smooth & quiet. So far I've not >used any boost at all as we've been very conservative with it. > As I'm a student pilot, I now am looking forward to finishing my >training in my own plane. Test pilot for the first 3 flights is an >experienced commercial bush pilot, however as he was unfamiliar with the >rotary engine (but very interested in it), I was along as flight engineer. >This worked very well as all he had to do was fly the plane. All other >duties were my responsibility. > As my test pilot/instructor has had to return to his regular >flying >job, testing is on hold for a week. I'm still in the "Holy ****, I can't >believe it's flying" phase, so next flights will begin to put the plane >through it's paces. > As every first flight report before has stated, It really is worth >all the sacrifices and hard work, so keep on pounding! I found the >building >process to be tremendously enjoyable, particularly the FWF development of >an >alternative engine, however it sure is pretty damn cool to be flying it >now! >:-) > Thanks to the FlyRotary group and the AeroElectric list for all >the >knowledge that is freely shared. > >The adventure continues...... > >S. Todd Bartrim >Turbo 13B >RX-9endurance >C-FSTB >http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > "Imagination is more important than knowledge" > -Albert Einstein > > ________________________________________________________________________________
Date: Sep 09, 2003
In the new products section of the current Kitplanes, there is a piece about a combo cd/mp3/dvd player from PS Engineering. With a little fiberglass work I'm sure you could install an overhead lcd screen for rear passengers or possibly individual screens in the back of the headrests. Andrew Rayhill RV-10 ________________________________________________________________________________
Date: Sep 09, 2003
Both top quality, a pleasure to do business with and both stand behind their products 100% in my experience. I have never been disappointed with anything I have purchased from either of them. Unfortunately I can't say that about some of the other tool suppliers. FWIW I'd consider the new style Cleveland hand squeezer if I was starting from scratch, but then my Avery aqueezer has worked perfectly well for me so far. In the long run you'll most likely end up buying from both of them. Harry Crosby Pleasanton, California RV-6, firewall forward ________________________________________________________________________________
Date: Sep 09, 2003
From: Frederick Oldenburg <foldenburg(at)earthlink.net>
Subject: Avery or Cleveland
Heads: Avery Tails: Cleveland Heads it is! (Just Kidding) I did order the Avery kit today though. Thanks to all for their input! Fred Oldenburg RV-7A - Empennage Kit Ordered http://rv.oldsack.com ________________________________________________________________________________
Date: Sep 09, 2003
Subject: Dynon Magnetometer Calibration Question
I have question about calibrating the Dynon External Magnetometer. I noticed the magnetometer was pitch sensitive (i.e. changes the heading based on pitch angle). I have a tail dragger, so it would make sense to calibrate the magnetometer with the tail up in flight position. I called Dynon and asked if I should raise the tail to in flight position for the calibration process and they said it was not necessary. I did not question them any further, but the more I think about it, I don't understand why. The magnetometer clearly does not know it is in a tail dragger or a nose dragger, therefore I would think it would make a difference. Or does it have something to do with the relation of the head unit to the magnetometer, and as long as they are at the same angle, it does not matter. But after calibration if you lift the tail, the heading does change. Clearly, I'm confused. Anyone else have any ideas or experience in this area? I was hoping to calibrate tomorrow. Thanks! Mike Kraus N223RV RV-4 ________________________________________________________________________________
Date: Sep 09, 2003
Flip a coin. They both are great. There are a few things that each one carries that are unique, so you will probably order some from one and some from the other. People say that Cleveland's dimple dies are better, but I don't know if that is substantiated. I bought Cleveland tools for the tool kit, but spent my fair share of money with Avery. Either one is a great bet. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ________________________________________________________________________________
Subject: Sticking Tailwheel Swivel
Date: Sep 09, 2003
I couldn't find any info in the archives on this one, so here goes: I have about 50 hours total on my RV-6 so far, and I find that my tailwheel pivot point (full swivel) tends to start sticking every 10-15 hours or so. I can still kick it free so it isn't a major hazard when it starts to stick, but it's a sure sign that I need to grease it again. I'm using standard automotive wheel bearing grease. To make things more inconvenient, I find the grease fitting totally useless. What happens is that grease will fill up and begin to leak out under the top washer, but nothing gets to the bottom bearing surface, where I need it. The only solution is to disassemble the swivel and manually grease 'er up. I can live with this, but is this normal procedure for you other tailwheel drivers? I operate off of grass but the tailwheel area generally stays pretty clean, although it does get slightly mucky after a rain. Did I leave out a washer or something? I don't recall having one for this assembly. Comments appreciated. Curt RV-6, 50 hours. Took up my first passenger last night. Oh man, this is fun. If I'm not flying I'm thinking about the next flight. Help me, I'm addicted and my gas bills are out of control! I'm exhausted from getting up at 5:00 AM every day to go flying before work! ________________________________________________________________________________
Date: Sep 09, 2003
Subject: Re: Dynon Magnetometer Calibration Question
I believe it is because the magnetometer provides a correction signal for the system build into the main unit, That's why the main unit AND the magnetometer have to be installed within a few tenth's of a degree axis angle in all 3 planes. if this holds true, then it shouldn't matter if you are propped up or sitting down on the tailwheel as the relative angle between the main unit and the magnetometer unit does not change. Just thinking out loud.......... Gert N223RV(at)aol.com wrote: > > I have question about calibrating the Dynon External Magnetometer. I noticed > the magnetometer was pitch sensitive (i.e. changes the heading based on pitch > angle). I have a tail dragger, so it would make sense to calibrate the > magnetometer with the tail up in flight position. > > I called Dynon and asked if I should raise the tail to in flight position for > the calibration process and they said it was not necessary. I did not > question them any further, but the more I think about it, I don't understand why. > The magnetometer clearly does not know it is in a tail dragger or a nose > dragger, therefore I would think it would make a difference. Or does it have > something to do with the relation of the head unit to the magnetometer, and as long > as they are at the same angle, it does not matter. But after calibration if > you lift the tail, the heading does change. > > Clearly, I'm confused. Anyone else have any ideas or experience in this > area? I was hoping to calibrate tomorrow. Thanks! > Mike Kraus > N223RV RV-4 > > > > > > > > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Sep 09, 2003
Subject: Avery or Cleveland?
I really like Avery too, but I did have one small problem I was disappointed that Avery couldn't help me with. The chuck key on my Sioux did not fit right. It would slip then the bits would always slip. When I called they acted like this was really a weird problem and I ended up finding a chuck in and old tool box and the problem was gone. I have and will buy from them again. Wayne -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Paul Besing Subject: Re: RV-List: Avery or Cleveland? Flip a coin. They both are great. There are a few things that each one carries that are unique, so you will probably order some from one and some from the other. People say that Cleveland's dimple dies are better, but I don't know if that is substantiated. I bought Cleveland tools for the tool kit, but spent my fair share of money with Avery. Either one is a great bet. Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ________________________________________________________________________________
Date: Sep 10, 2003
I think as long as it is in the same attitude as the D10 it doesn't matter. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com 2003 - The year of flight! > -----Original Message----- > From: N223RV(at)aol.com [mailto:N223RV(at)aol.com] > Sent: Tuesday, September 09, 2003 9:20 PM > To: rv-list(at)matronics.com > Subject: RV-List: Dynon Magnetometer Calibration Question > > > > I have question about calibrating the Dynon External > Magnetometer. I noticed > the magnetometer was pitch sensitive (i.e. changes the > heading based on pitch > angle). I have a tail dragger, so it would make sense to > calibrate the > magnetometer with the tail up in flight position. > > I called Dynon and asked if I should raise the tail to in > flight position for > the calibration process and they said it was not necessary. > I did not > question them any further, but the more I think about it, I > don't understand why. > The magnetometer clearly does not know it is in a tail > dragger or a nose > dragger, therefore I would think it would make a difference. > Or does it have > something to do with the relation of the head unit to the > magnetometer, and as long > as they are at the same angle, it does not matter. But after > calibration if > you lift the tail, the heading does change. > > Clearly, I'm confused. Anyone else have any ideas or > experience in this > area? I was hoping to calibrate tomorrow. Thanks! > Mike Kraus > N223RV RV-4 ________________________________________________________________________________
Subject: PPG/Dupont web sites
Date: Sep 10, 2003
I am in the aircraft refinishing business and was interested in the comments Re: PPP/Dupont web sites. I have had the occasion to do business with both paint suppliers and my feelings are the same for both. These Goliath's, in the paint business, are not interested in the aviation segment of the refinishing business, there primary focus is to the automotive refinishers for obvious reasons. There experience with refinishing aircraft is limited, at best. Request for information results in a reply from people that have no idea how to deal with the painting of aluminum. A typical response is "Well I once painted an aluminum fire truck". There are mfg.'s who do cater to aircraft painting "Jet-Glo" by Sherwin Williams," Randolph Products"," PRC Desoto", a PPG subsidiary, "AlumaGrip".To name a few. However I find that at least some of these focus on larger aircraft, again for obvious reasons. Dick Jason prestige(at)sover.net ________________________________________________________________________________
Date: Sep 10, 2003
Subject: Navaid head for sale
I am posting this for a friend who is not on the list. If interested please contact him directly. Unused Navaid head for sale. $475. Contact Ed Seigler at ed.seigler(at)tbe.com ________________________________________________________________________________
Date: Sep 10, 2003
The Dynon has numerous errors when below ~30 kts pitot pressure. The unit may not fully understand that you are changing pitch when you simply raise the tail without pitot information. How much does the heading change between taildown and tail up? Tailwinds, Doug Rozendaal > > I have question about calibrating the Dynon External Magnetometer. I noticed > the magnetometer was pitch sensitive (i.e. changes the heading based on pitch > angle). I have a tail dragger, so it would make sense to calibrate the > magnetometer with the tail up in flight position. ________________________________________________________________________________
Date: Sep 10, 2003
Does that mean you've got to give it the 8 degree panel tilt? Ed Holyoke 6 QB > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Gert > Sent: Tuesday, September 09, 2003 8:48 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Dynon Magnetometer Calibration Question > > > I believe it is because the magnetometer provides a correction signal > for the system build into the main unit, That's why the main unit AND > the magnetometer have to be installed within a few tenth's of a degree > axis angle in all 3 planes. > > if this holds true, then it shouldn't matter if you are propped up or > sitting down on the tailwheel as the relative angle between the main > unit and the magnetometer unit does not change. > > > Just thinking out loud.......... > > > Gert > N223RV(at)aol.com wrote: > > > > > I have question about calibrating the Dynon External Magnetometer. I > noticed > > the magnetometer was pitch sensitive (i.e. changes the heading based on > pitch > > angle). I have a tail dragger, so it would make sense to calibrate the > > magnetometer with the tail up in flight position. > > > > I called Dynon and asked if I should raise the tail to in flight > position for > > the calibration process and they said it was not necessary. I did not > > question them any further, but the more I think about it, I don't > understand why. > > The magnetometer clearly does not know it is in a tail dragger or a nose > > dragger, therefore I would think it would make a difference. Or does it > have > > something to do with the relation of the head unit to the magnetometer, > and as long > > as they are at the same angle, it does not matter. But after > calibration if > > you lift the tail, the heading does change. > > > > Clearly, I'm confused. Anyone else have any ideas or experience in this > > area? I was hoping to calibrate tomorrow. Thanks! > > Mike Kraus > > N223RV RV-4 > > > > > > > > > > > > > > > > > > > -- > is subject to a download and archival fee in the amount of $500 > > > > > ________________________________________________________________________________
Subject: Empennage Ship Date
Date: Sep 10, 2003
Ok all you "10" builders - I talked to Van's Tuesday around noonish and here's the latest: They will be mailing out an information packet later this week or early next. The first 40 tail kits will be ready to go around the 22nd of this month. At this point, they're planning on filling 40 kits per month until the initial order (of a bit over a 100 kits) is taken care of. Bruce #18 ________________________________________________________________________________
Subject: Molecules
Date: Sep 10, 2003
I would expect that the issue isn't about molecular size, as the difference between the two ain't much. If the issue exists its more a function of permeability of the membrane, much like your lungs are permeable to both O2 and N2, but more so with O2. Avagadro's Law states that all gas molucules not involved in a chemical reaction will demand the same volume of space per molecule at equal temps/pressures, therefore appropriately contributing their portion of partial pressure. This should include while they are being crammed through a leak. It doesn't matter what type of gas molecule it is. ________________________________________________________________________________
Date: Sep 10, 2003
Subject: Re: flying into reno?
Carson City ________________________________________________________________________________
Date: Sep 10, 2003
Subject: QB fuse: What else to order with?
Well, the day has arrived. Van's says the fuse is ready to ship. I meant to put together a list of items to order with the fuse like the ELT but it slipped my mind until now. Anyone have a list of items that I might as well get in this shipment? BTW, what are most folks using for ELTs? There was a brand I wrote down but now can't find the info. Seems there was one relatively low cost brand most folks were happy to use but I can't remember it. It might be the one Van's sells. thanks, lucky ________________________________________________________________________________
Date: Sep 10, 2003
Subject: Dual com switching
Electronic Gurus, I'm redoing my panel this winter and installing dual coms amongst other things. I already have a good intercom and don't need marker beacon display. Does anybody know of a small, com only audio panel type set up. Also is there any good way of using a single antenna with the two coms. On my Q2 (way back in 1980) I used a multi-pole switch. Surely something else is available today. Appreciate any help. Electronically challenged. "Casper" ________________________________________________________________________________
Date: Sep 08, 2003
Subject: Imported Altimeter
The altimeter in my Eagle is stuck on 3,000 feet and it has already been repaired several times, so my intent is to replace it with a new one. It appears that new ones are $500 for US made and $200 for imported. I don't fly anything close to IFR, so the cheap part of me says to buy the cheap one, however the Eagle really vibrates a lot, so the other part of me says to spend the money for a good one. Anyone have good or bad experience with the imported altimeters?? Bruce Green 84 Christen Eagle The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Sep 10, 2003
Subject: Las Crucis
Anyone have info on the Las Crucis flyin this October? Stewart ________________________________________________________________________________
Subject: Re: SIRS adjustment tool
Date: Sep 10, 2003
Straight down...... Just keep digging and you will get there. Craig Hiers > PS, while were on the subject of compasses, when one is at the North Pole, > which way is South? > ________________________________________________________________________________
Subject: Re: Las Crucis
Date: Sep 10, 2003
> > >Anyone have info on the Las Crucis flyin >this October? > >Stewart Hey Stewart, As usual, the details are on Doug Reeve's vansaircraft.net site. Sign up there on the guestbook, as they are using it as a planning tool for food, potties and such. I plan to depart from AEG (Double Eagle in Albuquerque) Friday morning, and will return Sunday. It's a great event. You don't want to miss it! All the cool cats are staying at the Hampton Inn. :) Brian Denk RV8 N94BD RV10 40051 ________________________________________________________________________________
Date: Sep 10, 2003
Subject: Re: Slow build
Heck, with all the glass stuff out now, us 7 guys would have space on the right side of the panel to put one, HUM... Dana, I can see it now, set the auto pilot and watch a movie. Just keep that King IFR video close in case the weather turns. You -7 guys with all that panel space. Alan Kritzman RV-8, 90 hours of just enjoying the view. ________________________________________________________________________________
Subject: Re: Molecules
Date: Sep 10, 2003
As I recall Avagadro's Number, the "same volume" is per mole of an (ideal) gas - not molecule. One mole of any gas occupies 22.4 liters at STP. That being said, I agree completely that the size difference between N2 and O2 is insignificant. ----- Original Message ----- From: Wheeler North Subject: RV-List: Molecules I would expect that the issue isn't about molecular size, as the difference between the two ain't much. If the issue exists its more a function of permeability of the membrane, much like your lungs are permeable to both O2 and N2, but more so with O2. Avagadro's Law states that all gas molucules not involved in a chemical reaction will demand the same volume of space per molecule at equal temps/pressures, therefore appropriately contributing their portion of partial pressure. This should include while they are being crammed through a leak. It doesn't matter what type of gas molecule it is. ________________________________________________________________________________
Subject: Molecules
Date: Sep 10, 2003
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 > From: Dean Pichon > As I recall Avagadro's Number, the "same volume" is per mole of > an (ideal) gas - not molecule. One mole of any gas occupies 22.4 True enough, but since a mole is a fixed number of molecules (6.022e23, IIRC), the same holds for molecules. - -- Dan Brown, KE6MKS, dan(at)familybrown.org "Since all the world is but a story, it were well for thee to buy the more enduring story rather than the story that is less enduring." -- The Judgment of St. Colum Cille -----BEGIN PGP SIGNATURE----- iQA/AwUBP1+74H6CI7gsQbX8EQIckwCg5NxnNYqHByI34EE39fTgpAB6FzgAnjgZ 96iLm+XSnTKyU4K5vIUMht8P =pDQn -----END PGP SIGNATURE----- ________________________________________________________________________________
Date: Sep 10, 2003
From: "Lockamy, Jack L NA" <jack.lockamy(at)navy.mil>
Does the external magnetometer also have to be mounted with 8 degrees of tilt to match the panel tilt where the EFIS resides? Jack Lockamy (waiting on my Dynon and ext. magnetometer) Camarillo, CA RV-7A ________________________________________________________________________________
Date: Sep 11, 2003
Good on ya ...sound like a very smart cookie!! Chris and Susie VH-MUM VK3GI ----- Original Message ----- From: "Bartrim, Todd" <sbartrim(at)mail.canfor.ca> Subject: RV-List: First flight of C-FSTB > > I'm very pleased to announce that RV-9endurance, kit # 90113, has > now become an airplane. Power is supplied by a Turbocharged 13B Mazda rotary > engine, with a 76" 3-blade IVO Magnum with electronic constant speed > governor. It was built from a standard kit and engine was rebuilt myself > from a junkyard engine. Everything was done myself, including paint & > upholstery. I'm extremely pleased with and proud of the results. > The plane fly's exactly as I remembered from my demo flight 3 years > ago. Very easy to fly. The engine is very smooth & quiet. So far I've not > used any boost at all as we've been very conservative with it. > As I'm a student pilot, I now am looking forward to finishing my > training in my own plane. Test pilot for the first 3 flights is an > experienced commercial bush pilot, however as he was unfamiliar with the > rotary engine (but very interested in it), I was along as flight engineer. > This worked very well as all he had to do was fly the plane. All other > duties were my responsibility. > As my test pilot/instructor has had to return to his regular flying > job, testing is on hold for a week. I'm still in the "Holy ****, I can't > believe it's flying" phase, so next flights will begin to put the plane > through it's paces. > As every first flight report before has stated, It really is worth > all the sacrifices and hard work, so keep on pounding! I found the building > process to be tremendously enjoyable, particularly the FWF development of an > alternative engine, however it sure is pretty damn cool to be flying it now! > :-) > Thanks to the FlyRotary group and the AeroElectric list for all the > knowledge that is freely shared. > > The adventure continues...... > > S. Todd Bartrim > Turbo 13B > RX-9endurance > C-FSTB > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > "Imagination is more important than knowledge" > -Albert Einstein > > ________________________________________________________________________________
Date: Sep 11, 2003
Subject: Re: Sticking Tailwheel Swivel
I had this problem and was to do with those 3 little pieces inside the swivel bit. You need to oil that area not grease. Mine actually broke that part and got new bits and oiled only in that area . the rest had grease but have to disassemble to do it as that nipple was useless. I regrease and oil the bits every 50 hours. I fly from grass and sealed strip . Hope this helps!! Chris and Susie VH-MUM VK3GI ----- Original Message ----- From: "Curt Reimer" <cgreimer(at)mb.sympatico.ca> Subject: RV-List: Sticking Tailwheel Swivel > > I couldn't find any info in the archives on this one, so here goes: > > I have about 50 hours total on my RV-6 so far, and I find that my tailwheel > pivot point (full swivel) tends to start sticking every 10-15 hours or so. I > can still kick it free so it isn't a major hazard when it starts to stick, > but it's a sure sign that I need to grease it again. I'm using standard > automotive wheel bearing grease. > > To make things more inconvenient, I find the grease fitting totally useless. > What happens is that grease will fill up and begin to leak out under the top > washer, but nothing gets to the bottom bearing surface, where I need it. The > only solution is to disassemble the swivel and manually grease 'er up. > > I can live with this, but is this normal procedure for you other tailwheel > drivers? I operate off of grass but the tailwheel area generally stays > pretty clean, although it does get slightly mucky after a rain. Did I leave > out a washer or something? I don't recall having one for this assembly. > > Comments appreciated. > > Curt > > RV-6, 50 hours. Took up my first passenger last night. Oh man, this is fun. > If I'm not flying I'm thinking about the next flight. Help me, I'm addicted > and my gas bills are out of control! I'm exhausted from getting up at 5:00 > AM every day to go flying before work! > > ________________________________________________________________________________
Date: Sep 11, 2003
Subject: Bad Day at the Satellite Factory---Humor?
Guys and Gals- Check out http://www.spaceref.com/news/viewsr.html?pid=10299 See what nasty things can happen at Lockheed Martin when folks from other programs borrow your bolts without telling you. This occurred just last weekend. -GV (RV-6A N1GV 648hrs) ________________________________________________________________________________
Date: Sep 10, 2003
Subject: Re: LCD
Dana, there are plenty of in-dash DVD players out there, none of which are very affordable. Here's a few: http://www.crutchfield.com/cgi-bin/S-RqKQZivPxXa/ProdGroup.asp?c=3&g=129100&s=0&cc=01&avf=N Jeff Point ________________________________________________________________________________
Date: Sep 11, 2003
From: "BillDube(at)killacycle.com" <BillDube(at)killacycle.com>
At 03:06 PM 9/8/03, you wrote: > > I'm very pleased to announce that RV-9endurance, kit # 90113, has >now become an airplane. Power is supplied by a Turbocharged 13B Mazda rotary >engine, with a 76" 3-blade IVO Magnum with electronic constant speed >governor. VERY impressive! Great website too! I have head that with the turbo installed, it is possible to eliminate the muffler. Have you run the engine up with, and without, the muffler? Bill Dube http://www.killacycle.com/Lights.htm ________________________________________________________________________________
Date: Sep 11, 2003
Hi Curt, I filed a shallow groove down from the grease nipple to allow a path for the grease to follow, seems to work. Cheers, Arthur Whitehead RV-8 Tailwheel swivelling fine so far, 70hrs. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Curt Reimer Subject: RV-List: Sticking Tailwheel Swivel I couldn't find any info in the archives on this one, so here goes: I have about 50 hours total on my RV-6 so far, and I find that my tailwheel pivot point (full swivel) tends to start sticking every 10-15 hours or so. I can still kick it free so it isn't a major hazard when it starts to stick, but it's a sure sign that I need to grease it again. I'm using standard automotive wheel bearing grease. To make things more inconvenient, I find the grease fitting totally useless. What happens is that grease will fill up and begin to leak out under the top washer, but nothing gets to the bottom bearing surface, where I need it. The only solution is to disassemble the swivel and manually grease 'er up. I can live with this, but is this normal procedure for you other tailwheel drivers? I operate off of grass but the tailwheel area generally stays pretty clean, although it does get slightly mucky after a rain. Did I leave out a washer or something? I don't recall having one for this assembly. Comments appreciated. Curt RV-6, 50 hours. Took up my first passenger last night. Oh man, this is fun. If I'm not flying I'm thinking about the next flight. Help me, I'm addicted and my gas bills are out of control! I'm exhausted from getting up at 5:00 AM every day to go flying before work! ________________________________________________________________________________
Date: Sep 11, 2003
Thought I'd reply to this (just for fun...) > your lungs are permeable to both O2 > and N2, but more so with O2. > I don't know that this is true. The partial pressure of atmospheric gases crossing alveolar membranes remains proportional. > Avagadro's Law states that all gas molucules not involved in a chemical > reaction will demand the same volume of space per molecule at equal > temps/pressures, therefore appropriately contributing their portion of > partial pressure. This should include while they are being crammed through a > leak. It doesn't matter what type of gas molecule it is. > > Agreed. Robert > ________________________________________________________________________________
Date: Sep 11, 2003
Does anyone have information on spoilers that can be installed in an RV-10? I saw an article on a Mooney some time back that had them installed. Thank You Rick Conti The Boeing Company office: 703 - 872 - 4602 cell: 703 - 472 - 8592 If you're looking for a cute saying....fuhgeddaboudit -----Original Message----- From: BBreckenridge(at)att.net [mailto:BBreckenridge(at)att.net] Subject: RV-List: Empennage Ship Date Ok all you "10" builders - I talked to Van's Tuesday around noonish and here's the latest: They will be mailing out an information packet later this week or early next. The first 40 tail kits will be ready to go around the 22nd of this month. At this point, they're planning on filling 40 kits per month until the initial order (of a bit over a 100 kits) is taken care of. Bruce #18 ________________________________________________________________________________
Subject: Re: Empennage Ship Date
Date: Sep 11, 2003
The de-facto setup for Mooneys is typically the Precise Flight speedbrake system: http://www.preciseflight.com/sb.html )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Conti, Rick" <rick.conti(at)boeing.com> Subject: RE: RV-List: Empennage Ship Date > > Does anyone have information on spoilers that can be installed in an RV-10? I saw an article on a Mooney some time back that had them installed. > > Thank You > Rick Conti > The Boeing Company > office: 703 - 872 - 4602 > cell: 703 - 472 - 8592 > If you're looking for a cute saying....fuhgeddaboudit > > > -----Original Message----- > From: BBreckenridge(at)att.net [mailto:BBreckenridge(at)att.net] > To: RV-List(at)matronics.com; RV10-list(at)matronics.com > Subject: RV-List: Empennage Ship Date > > > Ok all you "10" builders - I talked to Van's Tuesday around noonish and here's the latest: > They will be mailing out an information packet later this week or early next. The first 40 tail > kits will be ready to go around the 22nd of this month. At this point, they're planning on filling > 40 kits per month until the initial order (of a bit over a 100 kits) is taken care of. > > Bruce > #18 > > ________________________________________________________________________________
Date: Sep 11, 2003
It should be mounted so it is in the same position as the EFIS. From the installation guide. "The EDC-D10 must be mounted such that its orientation is as closely aligned with the EFIS-D10 as possible. It should be mounted with the long axis parallel to the wings, the electrical connector facing toward the front of the plane, and the mounting tabs on the bottom. The bracket used to hold the EDC-D10 must account for all differences in angles between the EFIS-D10 and the EDC-D10. This includes pitch, roll, and yaw. We recommend you use an electronic level that reads to 1/10th of a degree to make sure the EDC-D10 is aligned with the EFIS-D10 in pitch and roll to better than 2/10th of a degree." Ross Mickey ----- Original Message ----- From: "Lockamy, Jack L NA" <jack.lockamy(at)navy.mil> Subject: Re: RV-List: Dynon Magnetometer Calibration Question > > Does the external magnetometer also have to be mounted with 8 degrees of tilt to match the panel tilt where the EFIS resides? > > Jack Lockamy > (waiting on my Dynon and ext. magnetometer) > Camarillo, CA > RV-7A ________________________________________________________________________________
Date: Sep 11, 2003
Subject: Ignition Harness
I am looking for a source for 1/2 a harness for a Slick Magneto. The other side is Lightspeed electronic ignition. Spruce, Chief, Sky Ranch can't help. Any other sources? I would prefer a Champion harness. As an alternative, is anyone converting to electronic ignition with an unwanted harness on their hands or want to split a harness with me? Thanks in advance. Aloha Greg --------------------------------- ________________________________________________________________________________
Date: Sep 11, 2003
By "spoiler" do you mean speed brakes? I was a Mooney dealer until their 2001 implosion. The speed brakes on the modern Mooney are made by Precise Flight in Bend, Oregon. The retail cost of them is about $4,000 (that's a wag, because I have only seen an "installed" price). The work great for slowin' down or goin' down. I use them on every flight in a Mooney. I don't know whether they're necessary on an RV, but of course "necessary" is rarely the prime consideration on our aircraft. Keith Vasey Seattle RV-8 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Conti, Rick Subject: RE: RV-List: Empennage Ship Date Does anyone have information on spoilers that can be installed in an RV-10? I saw an article on a Mooney some time back that had them installed. Thank You Rick Conti The Boeing Company office: 703 - 872 - 4602 cell: 703 - 472 - 8592 If you're looking for a cute saying....fuhgeddaboudit -----Original Message----- From: BBreckenridge(at)att.net [mailto:BBreckenridge(at)att.net] Subject: RV-List: Empennage Ship Date Ok all you "10" builders - I talked to Van's Tuesday around noonish and here's the latest: They will be mailing out an information packet later this week or early next. The first 40 tail kits will be ready to go around the 22nd of this month. At this point, they're planning on filling 40 kits per month until the initial order (of a bit over a 100 kits) is taken care of. Bruce #18 ________________________________________________________________________________
Subject: Re: Ignition Harness
Date: Sep 11, 2003
Greg, I had to do this a couple of years ago on my -8A. Sorry I can't remember the part number now. Give Unisyn a call (their number is on their web site). Tell them what you are doing and they will give you a part number and tell you how to order it . They are very easy and pleasent to work with. Mike Robertson >From: Greg Grigson <iflyhawaii2(at)yahoo.com> >Reply-To: rv-list(at)matronics.com >To: RVList >Subject: RV-List: Ignition Harness >Date: Thu, 11 Sep 2003 09:16:28 -0700 (PDT) > > > I am looking for a source for 1/2 a harness for a Slick Magneto. The >other side is Lightspeed electronic ignition. Spruce, Chief, Sky Ranch >can't help. Any other sources? I would prefer a Champion harness. > > As an alternative, is anyone converting to electronic ignition with an >unwanted harness on their hands or want to split a harness with me? > >Thanks in advance. >Aloha >Greg > > >--------------------------------- > > ________________________________________________________________________________
Date: Sep 11, 2003
I have sent an email to Precise Flight asking about spoilers and the RV-10. Many wouldn't think spoilers are "necessary" on an RV-10, but the advantages seem high. Thank You Rick Conti The Boeing Company office: 703 - 872 - 4602 cell: 703 - 472 - 8592 If you're looking for a cute saying....fuhgeddaboudit -----Original Message----- From: Keith Vasey [mailto:keith(at)galvinflying.com] Subject: RE: RV-List: Empennage Ship Date By "spoiler" do you mean speed brakes? I was a Mooney dealer until their 2001 implosion. The speed brakes on the modern Mooney are made by Precise Flight in Bend, Oregon. The retail cost of them is about $4,000 (that's a wag, because I have only seen an "installed" price). The work great for slowin' down or goin' down. I use them on every flight in a Mooney. I don't know whether they're necessary on an RV, but of course "necessary" is rarely the prime consideration on our aircraft. Keith Vasey Seattle RV-8 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Conti, Rick Subject: RE: RV-List: Empennage Ship Date Does anyone have information on spoilers that can be installed in an RV-10? I saw an article on a Mooney some time back that had them installed. Thank You Rick Conti The Boeing Company office: 703 - 872 - 4602 cell: 703 - 472 - 8592 If you're looking for a cute saying....fuhgeddaboudit -----Original Message----- From: BBreckenridge(at)att.net [mailto:BBreckenridge(at)att.net] Subject: RV-List: Empennage Ship Date Ok all you "10" builders - I talked to Van's Tuesday around noonish and here's the latest: They will be mailing out an information packet later this week or early next. The first 40 tail kits will be ready to go around the 22nd of this month. At this point, they're planning on filling 40 kits per month until the initial order (of a bit over a 100 kits) is taken care of. Bruce #18 ________________________________________________________________________________
Date: Sep 11, 2003
Thanks for all the ideas. I should be able to come up with something over the next few days. With aloha, Greg Greg Grigson wrote: I am looking for a source for 1/2 a harness for a Slick Magneto. The other side is Lightspeed electronic ignition. Spruce, Chief, Sky Ranch can't help. Any other sources? I would prefer a Champion harness. As an alternative, is anyone converting to electronic ignition with an unwanted harness on their hands or want to split a harness with me? Thanks in advance. Aloha Greg --------------------------------- --------------------------------- ________________________________________________________________________________
Date: Sep 11, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Why not put the money of spoilers into a nice constant speed. Then you wont need spoilers. > >I have sent an email to Precise Flight asking about spoilers and the RV-10. >Many wouldn't think spoilers are "necessary" on an RV-10, but the advantages >seem high. > >Thank You >Rick Conti >The Boeing Company >office: 703 - 872 - 4602 > cell: 703 - 472 - 8592 >If you're looking for a cute saying....fuhgeddaboudit > > >-----Original Message----- >From: Keith Vasey [mailto:keith(at)galvinflying.com] >To: rv-list(at)matronics.com >Subject: RE: RV-List: Empennage Ship Date > > >By "spoiler" do you mean speed brakes? I was a Mooney dealer until their >2001 implosion. The speed brakes on the modern Mooney are made by Precise >Flight in Bend, Oregon. The retail cost of them is about $4,000 (that's a >wag, because I have only seen an "installed" price). The work great for >slowin' down or goin' down. I use them on every flight in a Mooney. I don't >know whether they're necessary on an RV, but of course "necessary" is rarely >the prime consideration on our aircraft. > >Keith Vasey >Seattle >RV-8 > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Conti, Rick >To: rv-list(at)matronics.com; RV10-list(at)matronics.com >Subject: RE: RV-List: Empennage Ship Date > > >Does anyone have information on spoilers that can be installed in an RV-10? >I saw an article on a Mooney some time back that had them installed. > >Thank You >Rick Conti >The Boeing Company >office: 703 - 872 - 4602 > cell: 703 - 472 - 8592 >If you're looking for a cute saying....fuhgeddaboudit > > >-----Original Message----- >From: BBreckenridge(at)att.net [mailto:BBreckenridge(at)att.net] >To: RV-List(at)matronics.com; RV10-list(at)matronics.com >Subject: RV-List: Empennage Ship Date > > >Ok all you "10" builders - I talked to Van's Tuesday around noonish and >here's the latest: >They will be mailing out an information packet later this week or early >next. The first 40 tail >kits will be ready to go around the 22nd of this month. At this point, >they're planning on filling >40 kits per month until the initial order (of a bit over a 100 kits) is >taken care of. > >Bruce >#18 > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Sep 11, 2003
Subject: RV6A flap to fuse fit.
Have a concern that needs some expert review. My lower inboard flap skins do not align well with the fuse. The flap is too high in relation to the fuse and the over lapping skin must bend when the flaps are retracted. Anyone else have this problem? and what did you do about it? Dale Ensing ________________________________________________________________________________
Date: Sep 11, 2003
Subject: heat muff confusion
checked the archives...which only added to the confusion. Is the universal heat muff in the new Van's catalog a Robbins muff? anyone?... ________________________________________________________________________________
Date: Sep 11, 2003
Subject: Kentucky Flyin
Flyin Rough River State Park - Falls of the Rough - 2I3 Friday 9/12 thru Sunday 9/14 Lodge walking distance from the runway Camp with your plane Meet in the Lodge Friday evening for war stories and drinks -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Slowbuild wings-QB Fuse :-) ________________________________________________________________________________
Date: Sep 11, 2003
From: Charlie & Tupper England <cengland(at)netdoor.com>
Subject: E-714 right elevator counterweight trimming
Well, a quick archive search didn't turn up much, so here's my contribution. Not presented as 'the' way to do it, just 'a' way to do it. A table saw with a carbide blade works fine for removing most of the lead except for the area that must be radiused (got to avoid those stress risers in those fishin' sinkers ;-) ) Set the blade height to remove the thickness desired & make multiple passes like cutting a dado. Or do what I did if you want to risk fingers & thumbs: make one cut across the nose using the rip fence then one cut across the face using the cross-cut guide. You get to keep a chunk of the lead, but it's a lot more risky. I then used a 1/4" shank, 1/2" diameter rotary file, cylindrical, round top (USATCO p/n 452HSS is similar) to mill the radius. I chucked it in my drill press, adjusted the table height so that the tip of the cutter just missed the surface left by the table saw, & made multiple very shallow & slow cuts until the side of the cutter reached my limit mark on the counterweight. I know there's a better way. Somebody just needs to share how.... Charlie ________________________________________________________________________________
Subject: Re: RV6A flap to fuse fit.
Date: Sep 11, 2003
Dale, I would joggle the flap skin, i.e., put a little step in the skin so that it mates with the fuselage. Pat Hatch RV-4 RV-6 RV-7 QB (Building) Vero Beach, FL ----- Original Message ----- From: <DWENSING(at)aol.com> Subject: RV-List: RV6A flap to fuse fit. > > Have a concern that needs some expert review. > My lower inboard flap skins do not align well with the fuse. The flap is too > high in relation to the fuse and the over lapping skin must bend when the > flaps are retracted. Anyone else have this problem? and what did you do about it? > Dale Ensing > > ________________________________________________________________________________
Date: Sep 11, 2003
Yup. Had that same issue on my RV-7 on both flaps. I trimmed and joggled the lower flap skin edge so that it sits flush. I might chop the whole inboard end off if I don't end up happy with how it looks when it's final-assembled, but it looked ok when I did my initial wing mating. Lemme know if you want photos (or just dig through my web site for wing mating stuff...). )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: <DWENSING(at)aol.com> Subject: RV-List: RV6A flap to fuse fit. > > Have a concern that needs some expert review. > My lower inboard flap skins do not align well with the fuse. The flap is too > high in relation to the fuse and the over lapping skin must bend when the > flaps are retracted. Anyone else have this problem? and what did you do about it? > Dale Ensing > > ________________________________________________________________________________
Subject: Duckworks Lighting Question
Date: Sep 11, 2003
I'm installing my duckworks landing light and there is a rib shaped template. Section 2.4 of the plans say to fit the template into the leading edge (ok so far) then mark the 2 locations. On the template it's marked "A" and "B" which I can safely say is the 2 locations. The next step says to drill the 6 holes! Each rib according to the template gets 2 holes, not three. OK so now I go to the drawing and I see three holes are supposed to be in each rib. Two at the top and one at the bottom! What in the wide wide world of sports am I missing here? Recommended web site with pics? As always thanks for your help. BTW...... Cutting that hole out was almost as much fun as slow dancing on a bed of hot coals! Karie Daniel Sammamish, WA RV-7A QB ________________________________________________________________________________
Subject: Re: Duckworks Lighting Question
Date: Sep 11, 2003
The idea is that you would have two angles at which you could install the mounting plate. You'll probably only use one, but it's nice to have options... 8-) Tailwheel folks might use one orientation, and nosedraggers may use another orientation. Or, point one up for taxi, one down for landing (or however you see fit). The plate is still adjustable to some extent once you pick two mounting points, but the third point gives you even greater flexibility. http://www.rvproject.com/20020624.html (right wing, some pics) http://www.rvproject.com/20020727.html (left wing, more pics) Have fun, )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Karie Daniel" <karie4(at)comcast.net> Subject: RV-List: Duckworks Lighting Question > > I'm installing my duckworks landing light and there is a rib shaped template. Section 2.4 of the plans say to fit the template into the leading edge (ok so far) then mark the 2 locations. On the template it's marked "A" and "B" which I can safely say is the 2 locations. > > The next step says to drill the 6 holes! Each rib according to the template gets 2 holes, not three. OK so now I go to the drawing and I see three holes are supposed to be in each rib. Two at the top and one at the bottom! What in the wide wide world of sports am I missing here? > > Recommended web site with pics? > > As always thanks for your help. > > BTW...... Cutting that hole out was almost as much fun as slow dancing on a bed of hot coals! > > Karie Daniel > Sammamish, WA > RV-7A QB > > ________________________________________________________________________________
From: "Kyle Boatright" <kyle.boatright(at)adelphia.net>
Date: Sep 12, 2003
There are two bottom holes. This give you an adjustment for the angle of the light beam in theory, you should be able to adjust the light(s) for either a level or 3 point attitude, depending on gear type and the landing attitude you favor. KB ----- Original Message ----- From: "Karie Daniel" <karie4(at)comcast.net> Subject: RV-List: Duckworks Lighting Question > > I'm installing my duckworks landing light and there is a rib shaped template. Section 2.4 of the plans say to fit the template into the leading edge (ok so far) then mark the 2 locations. On the template it's marked "A" and "B" which I can safely say is the 2 locations. > > The next step says to drill the 6 holes! Each rib according to the template gets 2 holes, not three. OK so now I go to the drawing and I see three holes are supposed to be in each rib. Two at the top and one at the bottom! What in the wide wide world of sports am I missing here? > > Recommended web site with pics? > > As always thanks for your help. > > BTW...... Cutting that hole out was almost as much fun as slow dancing on a bed of hot coals! > > Karie Daniel > Sammamish, WA > RV-7A QB > > ________________________________________________________________________________
Subject: RV-7 IO-360 baffle question
Date: Sep 11, 2003
Configuration: Van's IO-360 baffle kit, RV-7, drawing OP-4. Does part 20 (right front inlet floor stiffener) go on TOP or BELOW part 10 (right front inlet floor). I believe the plans imply the stiffener on top, but that seems like unnecessarily disturbing the flow a little bit -- the little lip formed by the height of the stiffener. Any advice? Thanks in advance, )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: Trim tab ?s
Date: Sep 12, 2003
All, Any tips on getting the final little bit of bend on the trim tab? I got the most of it done, but the inboard ends puff out (don't sit flush). Will the pop rivets pull it flush? Also, the countersink got away from me on one of the holes on the trim tab spar. It is actually bigger than the -4. Should I squeeze down a 4 to make it a little fatter? Any other standard rivets I could put it there? I am trying to avoid buying another spar for one bad hole. Thanks, Scott 7A Emp/Wings Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Date: Sep 12, 2003
Scott, I don't understand what you mean by, "a nice constant speed". If you mean a propeller, why do you think it will eliminate the need for spoilers? Thank You Rick Conti The Boeing Company office: 703 - 872 - 4602 cell: 703 - 472 - 8592 If you're looking for a cute saying....fuhgeddaboudit -----Original Message----- From: Scott Bilinski [mailto:bilinski@kyocera-wireless.com] Subject: RE: RV-List: Empennage Ship Date Why not put the money of spoilers into a nice constant speed. Then you wont need spoilers. > >I have sent an email to Precise Flight asking about spoilers and the RV-10. >Many wouldn't think spoilers are "necessary" on an RV-10, but the advantages >seem high. > >Thank You >Rick Conti >The Boeing Company >office: 703 - 872 - 4602 > cell: 703 - 472 - 8592 >If you're looking for a cute saying....fuhgeddaboudit > > >-----Original Message----- >From: Keith Vasey [mailto:keith(at)galvinflying.com] >To: rv-list(at)matronics.com >Subject: RE: RV-List: Empennage Ship Date > > >By "spoiler" do you mean speed brakes? I was a Mooney dealer until their >2001 implosion. The speed brakes on the modern Mooney are made by Precise >Flight in Bend, Oregon. The retail cost of them is about $4,000 (that's a >wag, because I have only seen an "installed" price). The work great for >slowin' down or goin' down. I use them on every flight in a Mooney. I don't >know whether they're necessary on an RV, but of course "necessary" is rarely >the prime consideration on our aircraft. > >Keith Vasey >Seattle >RV-8 > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Conti, Rick >To: rv-list(at)matronics.com; RV10-list(at)matronics.com >Subject: RE: RV-List: Empennage Ship Date > > >Does anyone have information on spoilers that can be installed in an RV-10? >I saw an article on a Mooney some time back that had them installed. > >Thank You >Rick Conti >The Boeing Company >office: 703 - 872 - 4602 > cell: 703 - 472 - 8592 >If you're looking for a cute saying....fuhgeddaboudit > > >-----Original Message----- >From: BBreckenridge(at)att.net [mailto:BBreckenridge(at)att.net] >To: RV-List(at)matronics.com; RV10-list(at)matronics.com >Subject: RV-List: Empennage Ship Date > > >Ok all you "10" builders - I talked to Van's Tuesday around noonish and >here's the latest: >They will be mailing out an information packet later this week or early >next. The first 40 tail >kits will be ready to go around the 22nd of this month. At this point, >they're planning on filling >40 kits per month until the initial order (of a bit over a 100 kits) is >taken care of. > >Bruce >#18 > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Sep 12, 2003
Probably bad choice of words, should have said something like, just use a constant speed prop because they act like a speed brake. If you have flown an RV you know the very steep approach angle on final with the CS and no power applied. RV's are slippery aircraft and can be a little challenging for the new pilot to slow down if they are not using a constant speed prop. With a CS they descend very rapidly when the throttle is pulled back and prop at fine pitch. Maybe I completely misunderstand your requirements for the spoilers but with a 650 ft landing distance at gross you can make it into some pretty short fields, with CS of course. Can you tell us where/how you plane to use the spoilers? > >Scott, > >I don't understand what you mean by, "a nice constant speed". If you mean a >propeller, why do you think it will eliminate the need for spoilers? > >Thank You >Rick Conti >The Boeing Company >office: 703 - 872 - 4602 > cell: 703 - 472 - 8592 >If you're looking for a cute saying....fuhgeddaboudit > > >-----Original Message----- >From: Scott Bilinski [mailto:bilinski@kyocera-wireless.com] >To: rv-list(at)matronics.com >Subject: RE: RV-List: Empennage Ship Date > > >Why not put the money of spoilers into a nice constant speed. Then you wont >need spoilers. > > >> >>I have sent an email to Precise Flight asking about spoilers and the RV-10. >>Many wouldn't think spoilers are "necessary" on an RV-10, but the advantages >>seem high. >> >>Thank You >>Rick Conti >>The Boeing Company >>office: 703 - 872 - 4602 >> cell: 703 - 472 - 8592 >>If you're looking for a cute saying....fuhgeddaboudit >> >> >>-----Original Message----- >>From: Keith Vasey [mailto:keith(at)galvinflying.com] >>To: rv-list(at)matronics.com >>Subject: RE: RV-List: Empennage Ship Date >> >> >> >>By "spoiler" do you mean speed brakes? I was a Mooney dealer until their >>2001 implosion. The speed brakes on the modern Mooney are made by Precise >>Flight in Bend, Oregon. The retail cost of them is about $4,000 (that's a >>wag, because I have only seen an "installed" price). The work great for >>slowin' down or goin' down. I use them on every flight in a Mooney. I don't >>know whether they're necessary on an RV, but of course "necessary" is rarely >>the prime consideration on our aircraft. >> >>Keith Vasey >>Seattle >>RV-8 >> >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Conti, Rick >>To: rv-list(at)matronics.com; RV10-list(at)matronics.com >>Subject: RE: RV-List: Empennage Ship Date >> >> >> >>Does anyone have information on spoilers that can be installed in an RV-10? >>I saw an article on a Mooney some time back that had them installed. >> >>Thank You >>Rick Conti >>The Boeing Company >>office: 703 - 872 - 4602 >> cell: 703 - 472 - 8592 >>If you're looking for a cute saying....fuhgeddaboudit >> >> >>-----Original Message----- >>From: BBreckenridge(at)att.net [mailto:BBreckenridge(at)att.net] >>To: RV-List(at)matronics.com; RV10-list(at)matronics.com >>Subject: RV-List: Empennage Ship Date >> >> >> >>Ok all you "10" builders - I talked to Van's Tuesday around noonish and >>here's the latest: >>They will be mailing out an information packet later this week or early >>next. The first 40 tail >>kits will be ready to go around the 22nd of this month. At this point, >>they're planning on filling >>40 kits per month until the initial order (of a bit over a 100 kits) is >>taken care of. >> >>Bruce >>#18 >> >> > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Date: Sep 12, 2003
I put mine below. Sincerely, Noel Simmons Blue Sky Aviation, Inc. Phone: 866-859-0390 Fax: 406-538-6574 noel(at)blueskyaviation.net www.blueskyaviation.net <http://www.blueskyaviation.net> -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dan Checkoway Subject: RV-List: RV-7 IO-360 baffle question Configuration: Van's IO-360 baffle kit, RV-7, drawing OP-4. Does part 20 (right front inlet floor stiffener) go on TOP or BELOW part 10 (right front inlet floor). I believe the plans imply the stiffener on top, but that seems like unnecessarily disturbing the flow a little bit -- the little lip formed by the height of the stiffener. Any advice? Thanks in advance, )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: Re: RV-7 IO-360 baffle question
Date: Sep 12, 2003
Thanks. I got a response from Ken Krueger this morning, who confirmed that it does go below. )_( Dan ----- Original Message ----- From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net> Subject: RE: RV-List: RV-7 IO-360 baffle question > > I put mine below. > > Sincerely, > > Noel Simmons > Blue Sky Aviation, Inc. > Phone: 866-859-0390 > Fax: 406-538-6574 > noel(at)blueskyaviation.net > www.blueskyaviation.net <http://www.blueskyaviation.net> > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dan Checkoway > To: rv-list(at)matronics.com; RV7and7A(at)yahoogroups.com > Subject: RV-List: RV-7 IO-360 baffle question > > > Configuration: Van's IO-360 baffle kit, RV-7, drawing OP-4. > > Does part 20 (right front inlet floor stiffener) go on TOP or BELOW part 10 > (right front inlet floor). I believe the plans imply the stiffener on top, > but that seems like unnecessarily disturbing the flow a little bit -- the > little lip formed by the height of the stiffener. > > Any advice? > > Thanks in advance, > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ________________________________________________________________________________
Date: Sep 12, 2003
Subject: Re: Full Size Plans
In a message dated 9/12/2003 8:33:26 AM Pacific Daylight Time, foldenburg(at)earthlink.net writes: > How big are the full size plans? I'm trying to decide on an easel or > bulletin board setup in the shop. > > The plans are about 2 ft x 3 feet. I put a cork bullitin board on the shop wall. As the small pieces come together to become BIG pieces, floor space fills up fast! Kim Nicholas RV9A - almost ready to move to the hanger!!!! ________________________________________________________________________________
Date: Sep 12, 2003
> >How big are the full size plans? "D" sized. About 36" x 24". ________________________________________________________________________________
Subject: Aft top skin F6112
Date: Sep 12, 2003
List: I am currently scratching my head about where to trim the aft top skin, F6112, for my slider-equipped 6A. There are no drawings depicting the dimensions of the arc that is cut out of the forward edge of this skin. All that is said in the instructions is to cut it to match the slider frame. Is this a critical cut? I assume that you don't want to cut too much off so that the rear canopy skirt will overlap this skin adequately. Can anyone give me a ball park idea here? How far away from the center of F606 is the forward edge of your F6112 skin at the top center of the fuselage? Also, how far from F624 is the edge of this skin at the longerons? Thanks in advance folks..... Regards, Jeff Orear RV6A finish kit.....slider under way Peshtigo, WI ________________________________________________________________________________
Subject: Full Size Plans
Date: Sep 12, 2003
> > How big are the full size plans? I'm trying to decide on an easel or > > bulletin board setup in the shop. > > > > I built an easel on wheels, which I found most excellent as I would simply roll it over to wherever I was working. It would have been a pain in the patootie to have to walk over to the wall everytime I needed to refer to something. However I'm lucky enough to have had a large shop to work in. In a smaller shop where space is an issue, you would also be much closer to the walls. Another issue is that you often need to refer to several sheets within a short span of time. You would need to have a lot of sheets on the wall or continually be reposting them. With the easel, you just pull the current one to the top of the pile. S. Todd Bartrim Turbo 13B RX-9endurance C-FSTB http://www3.telus.net/haywire/RV-9/C-FSTB.htm "Imagination is more important than knowledge" -Albert Einstein RE: RV-List: Full Size Plans How big are the full size plans? I'm trying to decide on an easel or bulletin board setup in the shop. I built an easel on wheels, which I found most excellent as I would simply roll it over to wherever I was working. It would have been a pain in the patootie to have to walk over to the wall everytime I needed to refer to something. However I'm lucky enough to have had a large shop to work in. In a smaller shop where space is an issue, you would also be much closer to the walls. Another issue is that you often need to refer to several sheets within a short span of time. You would need to have a lot of sheets on the wall or continually be reposting them. With the easel, you just pull the current one to the top of the pile. S. Todd Bartrim Turbo 13B RX-9endurance C-FSTB http://www3.telus.net/haywire/RV-9/C-FSTB.htm Imagination is more important than knowledge -Albert Einstein ________________________________________________________________________________
Date: Sep 12, 2003
Subject: Adding lead to elevator counterweights after painting??
Guys, After painting my elevators, they are both trailing edge heavy. I did not trim the L elevator counterweights at all (due to weight of trim tab and servo on that side), and on the right side I trimmed the lead such that it was still overbalanced when unpainted, anticipating that the paint would make it balance "about right". I seriously underestimated the amount of weight the paint would add (the dark blue Sherwim williams Genesis I'm spraying takes 3 coats to get complete coverage). So...I imagine I'm not the first to have this problem, what have others done to add weight to the elevators after painting? The best idea I've come up with so far is to pop rivet in a small aluminum baffle aft of the existing counterweight lead and then pour in an epoxy/lead shot slurry. Let dry, mask off rest of elevator and touch up the area with paint to make it look decent... What say ye RVators? --Mark Navratil Cedar Rapids, Iowa RV-8A N2D in painting hell... The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Sep 12, 2003
Subject: Early report from 9th Annual RV Forum, EAA486 Fulton NY
From the KFZY field report, 6 RV's have already flown in to the Forum. With the field based RV aircraft and diehard RV plane locals we will have at least 15 on the field Saturday. Mike Seager in the Van's factory Aircraft has made it also and the lessons have begun. KFZY Oswego County, Fulton NY Saturday looks to be intermittent scattered rain forecast, but VFR otherwise, it is a bummer to the south though.... Get there early, spend the night as Sunday after the great pancake breakfast, it looks VFR favorable. You'll have a great time! Hope to see you there the event goes on rain or shine, classes will be held. Thanks to the many RV wanna be's who are driving too...and yes they do make up the majority of our guests! It is not to late, preregistration not required. Get in that car now, what are you waiting for? So once again Thanks to all who are comming!!! David McManmon President, EAA 486 RV6 N58DM Builder-Pilot Previous Post edited below: September 12, 2003 Friday night fly in, cook out and camp out. The EAA 486 General meeting night too. September 13, 2003 Saturday technical seminars all day, meals provided to paid attendee's. Then a nice dinner banquet with a presentation. This year Mr. Kirk House, ex-Director Curator of the Glenn Cirtiss Museum will talk about the books on Glenn he wrote, and how Glenn was the ultimate Experimenter! September 14, 2003 Sunday AM our great pancake breakfast and perhaps a coordinated fly out for lunch, planes, weather and pilots willing. see us at www.eaachapter486.com Last year over 56 RV's and 25 SPAM's flew in with over 150 attendee's. There was Mike Seager and the Factory RV6 doing instruction and manufacturers like Lycoming and Aerospace logic with tables displaying and selling their wares. I could go on...but you get the picture...just ask some one who has been there the $45 is easily worth it. Hope to See you all there. Respectfully, David McManmon President EAA 486 RV6 Flying, Builder, Pilot N58DM DNA ________________________________________________________________________________
Subject: First flight of C-FSTB - Noise
Date: Sep 12, 2003
> I have head that with the turbo installed, it is possible > to > eliminate the muffler. Have you run the engine up with, and without, > the > muffler? > > > Bill Dube >
http://www.killacycle.com/Lights.htm Hi Bill; Yes I did run without the muffler, however I had no exhaust pipe at all, just the outlet directly from the turbo. (exhaust materials were held up at customs at this point). It sounded much like an outboard motor out of water. Certainly quieter than a Lyc and it is quiet enough to eliminate the muffler, however I really want a quiet airplane, as like most pilots, I'm hoping one day to have my own airstrip at home. Even though I live in a rural setting, there is always some jack*** that will complain about noise. In Europe noise regulations have resulted in strict regulations that ban overflight of some cities (any Europeans on the list feel free to correct me). I just feel that if us North Americans are more proactive in managing our own noise emissions, we won't be forced to comply with unreasonable laws. Just one man's opinion.... S. Todd Bartrim Turbo 13B RX-9endurance C-FSTB http://www3.telus.net/haywire/RV-9/C-FSTB.htm "Imagination is more important than knowledge" -Albert Einstein RE: RV-List: First flight of C-FSTB - Noise I have head that with the turbo installed, it is possible to eliminate the muffler. Have you run the engine up with, and without, the muffler? Bill Dube LED(at)Killacycle.com http://www.killacycle.com/Lights.htm Hi Bill; Yes I did run without the muffler, however I had no exhaust pipe at all, just the outlet directly from the turbo. (exhaust materials were held up at customs at this point). It sounded much like an outboard motor out of water. Certainly quieter than a Lyc and it is quiet enough to eliminate the muffler, however I really want a quiet airplane, as like most pilots, I'm hoping one day to have my own airstrip at home. Even though I live in a rural setting, there is always some jack*** that will complain about noise. In Europe noise regulations have resulted in strict regulations that ban overflight of some cities (any Europeans on the list feel free to correct me). I just feel that if us North Americans are more proactive in managing our own noise emissions, we won't be forced to comply with unreasonable laws. Just one man's opinion.... S. Todd Bartrim Turbo 13B RX-9endurance C-FSTB http://www3.telus.net/haywire/RV-9/C-FSTB.htm Imagination is more important than knowledge -Albert Einstein ________________________________________________________________________________
Subject: Re: Adding lead to elevator counterweights after painting??
From: glenn.williams(at)businessacft.bombardier.com
Date: Sep 12, 2003
09/12/2003 01:44:58 PM have you thought about adding washers to the screws that attach the lead? HMMMM ________________________________________________________________________________
Subject: Re: Aft top skin F6112
Date: Sep 12, 2003
This is really not a very critical cut at all. What I did was make sure I had several inches forward of the trailing edge of the canopy skirt, then eyeball the curve as is shown on the plans, just wag it. What you will encounter is that as you fit the canopy, you will have to trim off much of the lower part of the skin, especially near the longerons, to keep from interfereing with the canopy frame, etc. In the end I realized I had wasted way too much time pondering this. Pat Hatch RV-4 RV-6 RV-7 QB (Building) Vero Beach, FL ----- Original Message ----- From: "Jeff Orear" <jorear(at)new.rr.com> Subject: RV-List: Aft top skin F6112 > > List: > > I am currently scratching my head about where to trim the aft top skin, F6112, for my slider-equipped 6A. There are no drawings depicting the dimensions of the arc that is cut out of the forward edge of this skin. All that is said in the instructions is to cut it to match the slider frame. > > Is this a critical cut? I assume that you don't want to cut too much off so that the rear canopy skirt will overlap this skin adequately. > > Can anyone give me a ball park idea here? How far away from the center of F606 is the forward edge of your F6112 skin at the top center of the fuselage? Also, how far from F624 is the edge of this skin at the longerons? > > Thanks in advance folks..... > > > Regards, > > Jeff Orear > RV6A > finish kit.....slider under way > Peshtigo, WI > > ________________________________________________________________________________
Date: Sep 12, 2003
Subject: Oswego Co KFZY RV Forum update
Just left the airport.... Meeting night was held, Mike Seager after his flight lessons gave the group a little talk about Van's State of the Business and the unfortunate Red RV6 Oshkosh incident. There is a flying RV6 sans cowls set up in hanger to give a seminar and to discuss his automotive style built fuel injection system. As well the trailer delivered RV8 sans tail/wings but sporting the Subaru Engine FWF package for another seminar....SO WHOLE and apart RV's we got em. 7 RV's yes 3, 6, 7, 8, 9 but no 4's yet ....all tied down, 1 or 2 spams there too already,not including the field based planes. There are 6 or so other RV's there (kind you tow behind the truck and there is more than 10 tenst set up for the overnight campers who don't want to miss the morning roll call.... man these RV builders are a dedicated bunch. Shaping up for a great forum. Regards David McManmon President, EAA 486 N58DM RV6 Builder/Pilot DNA ________________________________________________________________________________
Date: Sep 12, 2003
I got mine from Mattituck. Jim Bean RV8 ________________________________________________________________________________
Date: Sep 13, 2003
Subject: RV-6 question: Rivet Spacing on F-606
There are two rows of rivets joining the forward and aft side skins at F-606. I know the rows are spaced 1" apart, but what is the vertical spacing between the rivet supposed to be? I suspect it is 1.25" since this spacing is used universally around this area plus the drawing 'looks' to be about this distance. I am confused by a note on the drawing pointing to the curved transition bend at the bottom of the bulkhead where it says 3/4" spacing. I assume this is only for the area of the bend. What spacing have others used? What is the spacing on the RV-7? Doug Gray ________________________________________________________________________________
Date: Sep 13, 2003
Why not go to your local tire store and pick up some of the 'stick-on lead weights' which are used on the inside of mag wheels for balancing? They come in various weights, they're small, hold well, and so cheap the tire store operator may just give you a handful FREE.... I've used them successfully on other aircraft for balancing control surfaces. Jack Lockamy Camarillo, CA ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling(at)earthlink.net>
Subject: engine contol cable lengths?
Date: Sep 13, 2003
Im ready to run my engine control cables and am looking for the proper lengths. I have an O-360 F1A6 with a Bendix fuel inj and cs prop. The prop gov is a front top mount. Controls will be mounted side by side under the center of the panel on a 6a. Is anyone using this configuration? Thanks Jeff Dowling RV-6A almost Chicago/Louisville ________________________________________________________________________________
Date: Sep 13, 2003
Yes, the spacing should be 1.25" or less. I found that 1.25" worked on the stringers and longerons, but needed to be modified on the bulkheads. I shoulda bought a rivet fan; doing it arithmetically is a pain. Anyway, there's a couple of other rows not called out. I was informed that unless it was specifically called out a different spacing or size, assume 3- rivets at 1.25" spacing on the fuse skins. Patrick Kelley - RV-6A - Finally putting skins on his fuselage -----Original Message----- There are two rows of rivets joining the forward and aft side skins at F-606. I know the rows are spaced 1" apart, but what is the vertical spacing between the rivet supposed to be? I suspect it is 1.25" since this spacing is used universally around this area plus the drawing 'looks' to be about this distance. I am confused by a note on the drawing pointing to the curved transition bend at the bottom of the bulkhead where it says 3/4" spacing. I assume this is only for the area of the bend. What spacing have others used? What is the spacing on the RV-7? Doug Gray ________________________________________________________________________________
Date: Sep 13, 2003
Subject: Getting rid of all my old art work
> LAST CHANCE DISPOSAL SALE - Artists Inventory of Aviation Prints. 12,000 or > more, signed, proofs, and artists proofs of aircraft: Spitfire, P-40, > AWACS/KC135, Shuttle, Piccard Balloon, Christen Eagle, F-14, F-15, Thunderbirds > (76), Wildcat, F5E, and Skyhawks. Artist member ASAA and USAF Art Program. Make > offer including shipping. Located Phoenix, Im 74 and these have been in air > conditioned storage for the last 20 years. Time to move them or dump them. I > stopped marketing them in 1984 when I moved to Phoenix. > > Pass the word to anyone interested > > Hal Rozema > EAA 390982 > ZENITH VSTOL CH701/3300 N701PF > theplanefolks.net > hal(at)thecaddesigner.net > > ________________________________________________________________________________
Subject: Re: RV-6 question: Rivet Spacing on F-606
Date: Sep 13, 2003
>Yes, the spacing should be 1.25" or less. I found that 1.25" worked on >the stringers and longerons, but needed to be modified on the bulkheads. >>>>I shoulda bought a rivet fan; doing it arithmetically is a pain. >>> Why spend money on a rivet FAN?? I used some of my wife's elastic "Spandex" ribbon that was in her sowing basket. The stuff I have is 5/16" wide and you can cut a suitable length, say 2' and slightly stretch it out over a steel rule (or marks on a table)and mark a line every inch on the elastic with your Sharpie and number them from 0 to 20 (or whatever). Then when it comes to marking the hole spacing on the aluminum, using a tailor's tape measure you can find out how many rivets you need to put in between the first and last one for your particular spacing. Stretch the elastic for the number of holes you need and mark on the aluminum for 1 1/4", 1 1/2" etc. spacing that you require. You'd be surprised how linearly that elastic stretches to the wider than calibrated marks on your elastic tape. Works like a charm even on curved surfaces where the fan does not and won't scratch the aluminum skin. Try it, you'll like it! Cheers!!--Henry Hore ________________________________________________________________________________
Date: Sep 13, 2003
Subject: [ Pat Long ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Pat Long Subject: Cracks in Wood Prop Hub Bore
http://www.matronics.com/photoshare/PGLong@aol.com.09.13.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Sep 13, 2003
Subject: [ John McMahon ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: John McMahon Subject: Plenum http://www.matronics.com/photoshare/rv6@earthlink.net.09.13.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Sep 13, 2003
Subject: Re: Phone Jack Fiber Washers
All- If anyone out there has a spare set of phone jack insulating washers, that normally come with all of the name brand 4-place intercoms, would you mind donating one set (one fiber shoulder washer and one fiber flat washer) to the cause of my buddy John Hyde's Fokker D7 replica? I had a few extra from the last three planes I built, but apparently gave them away to others over the years. The D7 is a single seater sans intercom but needs them for the Microair Com mic plug. TIA -GV (RV-6A N1GV 648hrs) ________________________________________________________________________________
Date: Sep 13, 2003
Only problem with that is that if one of those baby's comes loose it can jam your elevator. They should be permanently attached. Dave -6 flying CPM, EAA Tech Counselor Jack Lockamy wrote: > >Why not go to your local tire store and pick up some of the 'stick-on lead weights' which are used on the inside of mag wheels for balancing? They come in various weights, they're small, hold well, and so cheap the tire store operator may just give you a handful FREE.... > >I've used them successfully on other aircraft for balancing control surfaces. > >Jack Lockamy >Camarillo, CA > > > > ________________________________________________________________________________
Date: Sep 14, 2003
Subject: R V Fly-in Fall Classic (M54)
Just to remind all this upcoming week-end the Fall Classic R V fly-in near Nashville,Tn (M54) at Lebanon,Tn 20 miles east of Nashville....... There will be a fly Mart this year..Y'all come John McMahon 615-452-8742 R V6 Paint near future ________________________________________________________________________________
Subject: F-1 Rocket Quickbuild for sale
Date: Sep 14, 2003
Interested in a RV-4 or RV-8? The F-1 Rocket is another tandem 2-seater but with a lot more performance. I am selling kit #111 with the tailkit for $31,500. There is no work done so there should be no problem with the 51% rule. If you would like more information on the F-1, visit http://www.teamrocketaircraft.com/. Contact info: E-mail nateaf(at)hotmail.com Phone: 310-416-1686 Location: Los Angeles Nate Elliott ________________________________________________________________________________
Date: Sep 14, 2003
Subject: Re: RE: [SoCAL-RVlist] Carb Ice over the Santa Monicas? Redux
(very long) Grasping at straws: - How about looking for an induction system leak? (crack/hole in the rubber hoses that join induction system components; loose screws/bolts holding the carb to the engine). - How about dirty/clogged/defective air filter? Tim****** Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD - First Flight 18 Dec 99 http://www.geocities.com/timrv6a ****** ________________________________________________________________________________
Date: Sep 14, 2003
I think in the olden days, before Van sold the pre-formed wieghts, people would mix lead shot in epoxy and pour it in place. Maybe you could try that.... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > > Only problem with that is that if one of those baby's comes > loose it can > jam your elevator. They should be permanently attached. > > Dave -6 flying CPM, EAA Tech Counselor > > Jack Lockamy wrote: > > > > >Why not go to your local tire store and pick up some of the > 'stick-on > >lead weights' which are used on the inside of mag wheels for > balancing? > >They come in various weights, they're small, hold well, and so cheap > >the tire store operator may just give you a handful FREE.... > > > >I've used them successfully on other aircraft for balancing control > >surfaces. > > > >Jack Lockamy > >Camarillo, CA ________________________________________________________________________________
Subject: Lycoming Alternator Update
Date: Sep 14, 2003
I found and fixed my alternator problem. There was a broken wire between the field slip ring and the field winding. I added a U shaped piece of wire to reach beyond the broken end of the field wire and soldered it back together. It worked fine for one hour yesterday. Here's what I found out while researching this problem: My alternator is made by Hitachi and used on 81-87 Mazda (probably not RX-7's) per NAPA parts manual and does not have an internal voltage regulator. I have a VR-600 solid state regulator mounted on the firewall. Don George built my Lycoming IO360C1C and says he obtained my alternator from AirTec at 1-800-366-4746. They supply non- certified alternators for the homebuilt crowd. Also, someone says the Velocity factory sells an internally regulated alternator for $200 I also got an email from | Hi Ronnie, | I think the actual P/N of the alternator you may have is a Mitsubishi | 186-0355 or 14700. It may help in your quest for brushes! If you need a | replacement we sell the complete set up: belt, alt. mounts brackets and | hardware for $245.00. I agree expensive by automotive standards! | Good Luck, | Mahlon | Mahlon also sent the following: | Hi Ronnie, | It depends on where your engine came from or what application you are | trying to mimic. | Pipers used Mopar and Prestolite on O-320's | Cessna used Ford on O-320's | Beech used Ford and Prestolite on O-320's | Can't remember what Bellanca and some of the others used but basically they | all used some version of Ford, Prestolite or Mopar. To further complicate | things the mounting brackets and ring gear support assemblies were | different for each of the installations. IE belt that fit a ford alt. | pulley doesn't fit a MOPAR flywheel and same thing for the mounting | brackets. You really need to know what brackets and what flywheel you have | to make the correct determination of what's the right Alternator. If you | let me know what you have I will try to check it out for you On Monday when | I am back in the shop. If you are totally confused feel free to call me at | 1-800-624-6680 ext 305 and maybe I can better explain verbally. | Anyway I hope this helps, | Mahlon Russell | From: "Jim and Bev Cone" <jimnbev(at)olypen.com> Subject: RV-List: Alternator The Pelican alternator sold by ACS is off of a Chevy Sprint Spectrum. It is a small 65 amp alternator that is self regulating and has automatic overheat protection that resets when an overheated condition is resolved. I have one and it works well. Jim Cone Another post from kr shultz" From: "Cy Galley" <cgalley(at)qcbc.org>
Subject: Re: F-1 Rocket Quickbuild for sale
Date: Sep 14, 2003
Work done has NO bearing on 51% rule... NONE! Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Nate" <nateaf(at)earthlink.net> Subject: RV-List: F-1 Rocket Quickbuild for sale > > Interested in a RV-4 or RV-8? The F-1 Rocket is another tandem 2-seater but with a lot more performance. I am selling kit #111 with the tailkit for $31,500. There is no work done so there should be no problem with the 51% rule. If you would like more information on the F-1, visit http://www.teamrocketaircraft.com/. > > Contact info: E-mail nateaf(at)hotmail.com > Phone: 310-416-1686 > Location: Los Angeles > > Nate Elliott > > ________________________________________________________________________________
Date: Sep 14, 2003
Redux (very long) Tim Lewis wrote: > >Grasping at straws: >- How about looking for an induction system leak? (crack/hole in the >rubber hoses that join induction system components; loose screws/bolts >holding the carb to the engine). >- How about dirty/clogged/defective air filter? > >Tim****** >Tim Lewis -- HEF (Manassas, VA) >RV-6A N47TD - First Flight 18 Dec 99 >http://www.geocities.com/timrv6a >****** > Another possibility is sticking valves. A friend's Cub with a C90 Continental gave him fits for months (years?) until he pulled the cylinders & cleaned the lead off the valve stems & guides. Symptom was intermittant & unpredictable rough running. Charlie ________________________________________________________________________________
Date: Sep 14, 2003
>I think in the olden days, before Van sold the pre-formed weights, >people would mix lead shot in epoxy and pour it in place. Maybe you >could try that.... Yep, that was in the instructions for the elevators on the -6. Except the Manual advised to pour molten lead and to line the corners of the cavity where the lead is poured with aluminum foil beforehand (to prevent molten lead from pouring out of seems) Don't know if the -7 elevators have an angle of aluminum across the width of the area where the lead goes, to act as a dam, but this could be easily added if you intend to go this way. The kit even provided four 1/4-20 hardware bolts to install (2 per elevator) to pour the lead around them.The dam was positioned 3" aft from the forard end of the counter weight arm and I found that the resulting balance was a tad heavy when the cavity was filled to the brim with lead. Easy to drill holes to get balance right after painting. (Sometimes design changes to make things easier don't work out that way!) Cheers!!----Henry Hore ________________________________________________________________________________
Date: Sep 14, 2003
Subject: Re: Lycoming Alternator Update
Ronnie, How many amp output is that alternator? Jim Streit 90073 fuse Ronnie Brown wrote: > > >I found and fixed my alternator problem. There was a broken wire between the field slip ring and the field winding. I added a U shaped piece of wire to reach beyond the broken end of the field wire and soldered it back together. It worked fine for one hour yesterday. > >Here's what I found out while researching this problem: > >My alternator is made by Hitachi and used on 81-87 Mazda (probably not RX-7's) per NAPA parts manual and does not have an internal voltage regulator. I have a VR-600 solid state regulator mounted on the firewall. Don George built my Lycoming IO360C1C and says he obtained my alternator from AirTec at 1-800-366-4746. They supply non- certified alternators for the homebuilt crowd. > >Also, someone says the Velocity factory sells an internally regulated alternator for $200 > >I also got an email from > > >| Hi Ronnie, >| I think the actual P/N of the alternator you may have is a Mitsubishi >| 186-0355 or 14700. It may help in your quest for brushes! If you need a >| replacement we sell the complete set up: belt, alt. mounts brackets and >| hardware for $245.00. I agree expensive by automotive standards! >| Good Luck, >| Mahlon >| > >Mahlon also sent the following: > > >| Hi Ronnie, >| It depends on where your engine came from or what application you are >| trying to mimic. >| Pipers used Mopar and Prestolite on O-320's >| Cessna used Ford on O-320's >| Beech used Ford and Prestolite on O-320's >| Can't remember what Bellanca and some of the others used but basically they >| all used some version of Ford, Prestolite or Mopar. To further complicate >| things the mounting brackets and ring gear support assemblies were >| different for each of the installations. IE belt that fit a ford alt. >| pulley doesn't fit a MOPAR flywheel and same thing for the mounting >| brackets. You really need to know what brackets and what flywheel you have >| to make the correct determination of what's the right Alternator. If you >| let me know what you have I will try to check it out for you On Monday when >| I am back in the shop. If you are totally confused feel free to call me at >| 1-800-624-6680 ext 305 and maybe I can better explain verbally. >| Anyway I hope this helps, >| Mahlon Russell >| > >From: "Jim and Bev Cone" <jimnbev(at)olypen.com> >Subject: RV-List: Alternator > > >The Pelican alternator sold by ACS is off of a Chevy Sprint >Spectrum. It is a small 65 amp alternator that is self regulating and has automatic >overheat protection that resets when an overheated condition is resolved. >I have one and it works well. > >Jim Cone > >Another post from kr shultz" Think it is a Suzuki Samurai 1995 to 2001 > > > > ________________________________________________________________________________
Subject: RE: [SoCAL-RVlist] Carb Ice over the Santa Monicas? Redux
(very long)
Date: Sep 14, 2003
Hi Bruce, Is the wobble test applicable to a Continental O-200? I'll talk to an AI about it. I stuck a valve (I think) on my old C-150 when I reduced power too fast at high altitude and it backfired in the exhaust a few times before clearing up but it didn't feel at all like this problem. Thanks for the idea, Ed Holyoke > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Bruce Gray > Sent: Sunday, September 14, 2003 10:10 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: RE: [SoCAL-RVlist] Carb Ice over the Santa Monicas? > Redux (very long) > > > Do yourself a favor and check the valves for sticking, lead buildup. Do > the infamous 'wobble check' service bulletin. It sure sounds like > sticking valves to me. > > Bruce > www.glasair.org > > ________________________________________________________________________________
Date: Sep 14, 2003
> >All- > >If anyone out there has a spare set of phone jack insulating washers, that >normally come with all of the name brand 4-place intercoms, would you mind >donating one set (one fiber shoulder washer and one fiber flat >washer) to the cause >of my buddy John Hyde's Fokker D7 replica? > >I had a few extra from the last three planes I built, but apparently gave >them away to others over the years. The D7 is a single seater sans >intercom but >needs them for the Microair Com mic plug. > >TIA > >-GV (RV-6A N1GV 648hrs) > GV, If you get stuck, I just successfully made some insulating washers for a couple of phone jacks I had. I cut off a piece of a snap bushing to make a plastic bushing for the body of the jack to go in, and a I made some washers from styrene sheet I found at a hobby store. Slightly ugly, but the jacks are not in plain sight so I don't care. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Subject: Installation Requirements
Date: Sep 15, 2003
Listers, Is there any knowledgeable FAA type listers that can answer these questions for me. 1. Can I legally install, test and fill out the evaluation sheet on an IFR GPS unit without FAA FSDO intervention. 2. Can I legally install, test and sign off a Sensenich prop installation on my RV-4 / Lycoming engine without FAA FSDO intervention. 3. Can I legally raise the gross weight of my aircraft, test fly, document V speeds and sign off the change without going thru the FAA FSDO. The trouble I have is, I get one answer from the FSDO and another from a MIDO and still another from a DAR. I learned how to read but the interpretation of the rules by everyone concerned are as different as the interpretations of the bible. Jim Nolan N444JN May be legal / may not be legal ________________________________________________________________________________
Date: Sep 14, 2003
Subject: RV-7 fully punched tail left elevator instructions & recovery
methods First, let me say that Van's A/C makes wonderful kits & I'm very grateful that I don't have to mine the ore like the old days. That said, I'm pretty frustrated with the quality of the instructions right now. For those who have gone before me building a 'fully prepunched' -7 tail, I'm referring to the 11th step on page 6-10 & following steps. After clecoing & drilling the skin to the skeleton, we are told to, and I quote, "Disassemble the elevator. Deburr, dimple and prime the parts as desired." Has anyone followed this direction & been able to complete the construction of the elevator without paying for a new E606PP trim spar? Because 3 steps later we are told to machine countersink the top of E606PP. Thanks, Charlie (For those of you who are just starting, be forewarned; this isn't the first set of inconsistent instructions you will encounter.) ________________________________________________________________________________
methods
Date: Sep 14, 2003
Countersinking is generally reserved for skins over (or including; there is some debate here) .040". Dimpling is not restricted to .040" and under, but ya better be able to drive good dimples in the thicker material . Seriously, there is a grey area where you can make your own choice. Some people think you get better consistency from dimpling; others think countersinking makes for better craftsmanship. I countersunk my .040" skins before I found out I could make the choice. If I had to do it over, every skin and thin bulkhead would be dimpled; everything over .040" countersunk. The plans are often ambiguous because there is more than one correct way to do things. Because of the possible variations, it is never enough to rely simply on the plans and instructions; you must also use the hat/neck seperator. Reading up on construction techniques helps, as does builder's assistance and Tech Counselors. And Sport Aviation this month made nice mention of the centers that guide you through the tail kit to teach you the basics of RV construction. Patrick Kelley - RV-6A - aft side skins going on First, let me say that Van's A/C makes wonderful kits & I'm very grateful that I don't have to mine the ore like the old days. That said, I'm pretty frustrated with the quality of the instructions right now. For those who have gone before me building a 'fully prepunched' -7 tail, I'm referring to the 11th step on page 6-10 & following steps. After clecoing & drilling the skin to the skeleton, we are told to, and I quote, "Disassemble the elevator. Deburr, dimple and prime the parts as desired." Has anyone followed this direction & been able to complete the construction of the elevator without paying for a new E606PP trim spar? Because 3 steps later we are told to machine countersink the top of E606PP. Thanks, Charlie (For those of you who are just starting, be forewarned; this isn't the first set of inconsistent instructions you will encounter.) ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Sep 14, 2003
I remember my golfing days of old when we used lead tape to add a bit of weight to the back of a golf club. This stuff should work and/or you could epoxy it in. Take a look at a golf supply house like Golf Works for lead tape. Indiana Larry, RV7 Tip-up TMX-O-360 ACS2002 Dynon CNS430 Digitrak On Finish Kit ----- Original Message ----- From: "Elsa & Henry" <elsa-henry@darlor-watch.com> Subject: Re: RV-List: Adding lead to elevator counterweights after painting?? <elsa-henry@darlor-watch.com> > > > >I think in the olden days, before Van sold the pre-formed weights, > >people would mix lead shot in epoxy and pour it in place. Maybe you > >could try that.... > > Yep, that was in the instructions for the elevators on the -6. Except the > Manual advised to pour molten lead and to line the corners of the cavity > where the lead is poured with aluminum foil beforehand (to prevent molten > lead from pouring out of seems) Don't know if the -7 elevators have an angle > of aluminum across the width of the area where the lead goes, to act as a > dam, but this could be easily added if you intend to go this way. The kit > even provided four 1/4-20 hardware bolts to install (2 per elevator) to pour > the lead around them.The dam was positioned 3" aft from the forard end of > the counter weight arm and I found that the resulting balance was a tad > heavy when the cavity was filled to the brim with lead. Easy to drill holes > to get balance right after painting. > > (Sometimes design changes to make things easier don't work out that way!) > > Cheers!!----Henry Hore > > ________________________________________________________________________________
Subject: More Dynon IFR
Date: Sep 14, 2003
Last Thursday I departed into a 500 ft ceiling, flew 2 ILSes, crossed through a front, and got over an hour of real IFR with the Dynon. I would be lying if I told you there was not a touch of apprehension sticking my nose through a front knowing that there would be some bumps inside. Both the Dynon and the Navaid worked very well. The heading on the Dynon wanders a little bit sometimes. Not really a problem, a minor annoyance, I just have to becareful not to chase it. I havent ripped out the DG yet and in the clouds I was thinking that I may not get in a hurry to do that...... I am debating whether I would rather have a DG or a Horizon if I was going to keep the vacuum system..... Dunno...... leaning toward the DG, but I may still take the whole vacuum system out. I have done a little light IFR in a -6 before, but this is really my first "real" RV-IFR. I am pleased with how nicely the -4 handles it is really quick, but it is also fairly stable. The Navaid is a BIG HELP! and so is the Rocky Encoder altitude alerter. I believe if you can not fly IFR without an autopilot, you should not fly IFR at all, without the autopilot, IFR in the -4 I turned of the autopilot for a while and I can do it, but, without an A/P, you would sure want to keep the fuel in balance, and have your charts folded before you took off. On a long trip you would get pretty tired. I have about 30 hours on the Dynon. So far, sooo gooood. Tailwinds, Doug Rozendaal ________________________________________________________________________________
Date: Sep 14, 2003
Jim, I'm sure you'll get lots of different answers but here's mine. 1. IFR GPS install No problem / no FSDO Part 43 of the FARs does not apply per 43.1(b)("This part does not apply to any aircraft for which an experimental airworthiness certificate has been issued, unless a different kind of airworthiness certificate had previously been issued for that aircraft"). This means no 337 is necessary. It could be argued that compliance with AC 20-138, "Airworthiness Approval of Global Positioning System (GPS) Navigation Equipment for use as a VFR and IFR Supplemental Navigation System" is necessary but technically Advisory Circulars are "advisory". I feel that compliance with the AC is not that hard and would be a prudent thing to do. 2.Prop install Maybe a FSDO You can do the work. FSDO involvement depends on your individual operating limitations. Older ones required FSDO notification and sign off of any major change along with a fly-off period as specified by the FSDO. If this is the case use the FSDO involvement as an oppourtunity to get your operating limitations changed to the newer type. Newer limitations require only a logbook entry with a standard fly off period. 3.Gross weight change Almost certainly a FSDO At the least the plane would have to be returned to the initial test phase with the approval of the FSDO. I would welcome Mike Robertson's input on these questions. Stan Blanton Listers, Is there any knowledgeable FAA type listers that can answer these questions for me. 1. Can I legally install, test and fill out the evaluation sheet on an IFR GPS unit without FAA FSDO intervention. 2. Can I legally install, test and sign off a Sensenich prop installation on my RV-4 / Lycoming engine without FAA FSDO intervention. 3. Can I legally raise the gross weight of my aircraft, test fly, document V speeds and sign off the change without going thru the FAA FSDO. The trouble I have is, I get one answer from the FSDO and another from a MIDO and still another from a DAR. I learned how to read but the interpretation of the rules by everyone concerned are as different as the interpretations of the bible. Jim Nolan N444JN May be legal / may not be legal ________________________________________________________________________________
Date: Sep 14, 2003
B & C has them, $0.50 a set. http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?24X358218 __________________________________ http://sitebuilder.yahoo.com ________________________________________________________________________________
From: "Brett Morawski" <brett.morawski@buckeye-express.com>
Subject: Primer performance & edge finishing - Yes I checked the archives
& not trying to start a primer war
Date: Sep 15, 2003
I researched all the primer issues I could find and made my decision a while back but I thought it was worth checking back one more time. I'm curious about how well all the different primer methods are holding out in the real world. Most of the responses in the archives deal with what people were planning to use as they were building. What I'd like to know is: What method/system did you use? How long has your RV been flying? What part of the world you're in - near salt/fresh water/next to a coal burning plant, hangered/outside? How well is your primer performing? If you had to do it over what would you do differently? Also, how anal were you in finishing/deburring/rounding off the edges of all the ribs, spars and skins and have you had any cracking issues that make you wish you had been more anal? Brett Morawski 8 (8A?) emp ready to prime, wing ordered ________________________________________________________________________________
methods
Date: Sep 15, 2003
Charlie, I did the exact same thing. They have you c-sink the elevator trim tab spar (606) so that you don't have to do anything to the hinge (I am told it gets wavy if you dimple it). To fix mine, I ended up leaving the dimple in the top of the 606 and just c-sinking the hinge (rather than dimpling it). I just finished it up, and I do not think it would have come out any nicer the other way. I agree on the instructions...some of them have steps out of order. I have started reading ahead a little bit before starting any section, and that seems to help. Scott 7A Emp/Wings --- On Sun 09/14, Charlie & Tupper England < cengland(at)netdoor.com > wrote: From: Charlie & Tupper England [mailto: cengland(at)netdoor.com] Date: Sun, 14 Sep 2003 19:55:07 -0500 Subject: RV-List: RV-7 fully punched tail left elevator instructions & recovery methods First, let me say that Van's A/C makes wonderful kits & I'm very grateful that I don't have to mine the ore like the old days. That said, I'm pretty frustrated with the quality of the instructions right now. For those who have gone before me building a 'fully prepunched' -7 tail, I'm referring to the 11th step on page 6-10 & following steps. After clecoing & drilling the skin to the skeleton, we are told to, and I quote, "Disassemble the elevator. Deburr, dimple and prime the parts as desired." Has anyone followed this direction & been able to complete the construction of the elevator without paying for a new E606PP trim spar? Because 3 steps later we are told to machine countersink the top of E606PP. Thanks, Charlie (For those of you who are just starting, be forewarned; this isn't the first set of inconsistent instructions you will encounter.) Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
From: "Bob Hodgson" <bob(at)hodgson252.freeserve.co.uk>
Date: Sep 15, 2003
Ed, Magneto switch? If fuel system OK, suspect ignition. But there's 8 plugs and 2 mags, and you're losing all power intermittently with both mags on. Common point in ign. system is mag switch. May be loose connection in the switch causing trouble only in thinner air at altitude?? Were the successful test flights at low altitude? FWIW - I'm no engineer but as the List Experts haven't solved this yet, I thought I would throw this in! Bob UK - RV3B (canopy) ----- Original Message ----- > From: "Ed Holyoke" <bicyclop(at)pacbell.net> > Subject: RV-List: RE: [SoCAL-RVlist] Carb Ice over the Santa Monicas? Redux (very long) > > Today I loaded it up and headed out to Oceano. Stopped for 80 octane at > SZP and continued. Over Lake Cachuma and at 6500 ft I noticed some > roughness and about 50 rpm drop. The carb ice detector was not sounding > (and it's not shy- it's gone off several times during runup and power > reductions). I pulled carb heat anyway and went full throttle. The rpm > degraded some more and then seemed to recover slightly then dropped to > 1500 and immediately came back up to about 2500. It them proceeded to > cycle back and forth between 2500 and 1500 continuously. I experimented > with throttle, carb heat and mixture and was unable to find a sweet spot > where it would run normally. The mixture control did have an effect on > rpm as did the carb heat. If I pulled the throttle back to about 1600, > it seemed to run OK, but more throttle put it back in cycling mode. By > this time I was over Santa Ynez at about 4000' and, low and behold it > seemed to run fine at any throttle setting. I landed. > > > > > Carb ice is a convenient diagnosis, but I'm freaked out by the way it > > surged to full power and back to nothing and then died only to return > to > > (apparently) full power after several minutes of gliding. In > retrospect, ________________________________________________________________________________
Subject: Re: Primer performance & edge finishing - Yes I checked the archives
Date: Sep 15, 2003
----- Original Message ----- From: "Brett Morawski" <brett.morawski@buckeye-express.com> Subject: RV-List: Primer performance & edge finishing - Yes I checked the archives & not trying to start a primer war <brett.morawski@buckeye-express.com> > > I researched all the primer issues I could find and made my decision a while > back but I thought it was worth checking back one more time. > > I'm curious about how well all the different primer methods are holding out > in the real world. Most of the responses in the archives deal with what > people were planning to use as they were building. > > What I'd like to know is: > > What method/system did you use? I primed, at a minimum, at least one of two inside surfaces where two metal parts came together. I used DP40LF. > > How long has your RV been flying? Hope to be flying in 6-8 months. > > What part of the world you're in - near salt/fresh water/next to a coal > burning plant, hangered/outside? I plan to keep plane indoors in hanger and I live in southern Indiana with moderate temps and somewhat sweltering humidity at times in the summer. > > How well is your primer performing? It DPnnLF is tuff stuff and two part epoxy mix. Key is to clean and prepare the metal before spraying on the primer. Lots of info in archives about this process so I won't redo that. > > If you had to do it over what would you do differently? Priming takes a lot of time doing it my way. If I were doing it over, I'd identify all the parts that are not alclad finished and prime them as soon as my parts arrived and get most of it done right up front before fabricating to finished size. > > Also, how anal were you in finishing/deburring/rounding off the edges of all > the ribs, spars and skins and have you had any cracking issues that make you > wish you had been more anal? I assume you mean conscientious. I try to be very attentive to smoothing all edges, and sharp corners and smoothing inside corners. Filing, deburring, and the sand/emory wheeling all edges makes a nicer and safer plane and a bit lighter too. > > > Brett Morawski > 8 (8A?) emp ready to prime, wing ordered Hope this helps and contributes to our cause. Indiana Larry, RV7 Tip-up TMX-O-360 ACS2002 Dynon CNS430 Digitrak On Finish Kit ________________________________________________________________________________
From: "Scott Brown" <scottbrown(at)precisionjet.com>
Subject: JON JOHANSEN SEATS
Date: Sep 15, 2003
Listers, I have a pair of new Jon Johansen seats for sale. I will sell them for their cost, and I will pick up the shipping. I purchased them for $450 each. Please respond offline...Thanks! Scott ________________________________________________________________________________
methods
Date: Sep 15, 2003
Charlie, I almost did the same thing. Since then, my sequence of building involves using the instructions as the order to do things (not always in the best order) and the plans for what to do. When you get to the fuselage you almost HAVE to do it this way or you will miss much. Clayton Henderson RV-7 Fuselage -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie & Tupper England Subject: RV-List: RV-7 fully punched tail left elevator instructions & recovery methods First, let me say that Van's A/C makes wonderful kits & I'm very grateful that I don't have to mine the ore like the old days. That said, I'm pretty frustrated with the quality of the instructions right now. For those who have gone before me building a 'fully prepunched' -7 tail, I'm referring to the 11th step on page 6-10 & following steps. After clecoing & drilling the skin to the skeleton, we are told to, and I quote, "Disassemble the elevator. Deburr, dimple and prime the parts as desired." Has anyone followed this direction & been able to complete the construction of the elevator without paying for a new E606PP trim spar? Because 3 steps later we are told to machine countersink the top of E606PP. Thanks, Charlie (For those of you who are just starting, be forewarned; this isn't the first set of inconsistent instructions you will encounter.) ________________________________________________________________________________
Date: Sep 15, 2003
Subject: Re: More Dynon IFR
>The heading on the Dynon wanders a little bit sometimes. Not really a >problem, a minor annoyance, I just have to becareful not to chase it. I >havent ripped out the DG yet and in the clouds I was thinking that I may not >get in a hurry to do that...... I am debating whether I would rather have a >DG or a Horizon if I was going to keep the vacuum system..... Dunno...... >leaning toward the DG, but I may still take the whole vacuum system out. Doug What about using a GPS for a back up instead of a DG? Bob ________________________________________________________________________________
Date: Sep 15, 2003
I concur!! Mike Robertson Das Fed >From: "Cy Galley" <cgalley(at)qcbc.org> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: F-1 Rocket Quickbuild for sale >Date: Sun, 14 Sep 2003 10:13:27 -0500 > > >Work done has NO bearing on 51% rule... NONE! >Cy Galley >Editor, EAA Safety Programs >cgalley(at)qcbc.org or experimenter(at)eaa.org > > >----- Original Message ----- >From: "Nate" <nateaf(at)earthlink.net> >To: >Subject: RV-List: F-1 Rocket Quickbuild for sale > > > > > > Interested in a RV-4 or RV-8? The F-1 Rocket is another tandem 2-seater >but with a lot more performance. I am selling kit #111 with the tailkit >for >$31,500. There is no work done so there should be no problem with the 51% >rule. If you would like more information on the F-1, visit >http://www.teamrocketaircraft.com/. > > > > Contact info: E-mail nateaf(at)hotmail.com > > Phone: 310-416-1686 > > Location: Los Angeles > > > > Nate Elliott > > > > > > ________________________________________________________________________________
Subject: Re: Installation Requirements
Date: Sep 15, 2003
Jim, You need to first look at your aircraft's Operating Limitations. If the Ops Limits are more than a couple of years old they probably state that you need FAA approval prior to incorporating any major changes. If they are newer then they proobably state that you can make the major change yourself, place the aircraft back into Phase 1 test flying for a minimum of 5 hours, and sign that off when done. That is the bottom line. Whatever YOUR Ops Limits state is what it is. However, If you have the older Ops Limits you can get them amended to the newer style by simply applying to your local FSDO for them. If you have any questions give me a call at (503) 681-5537. Mike Robertson Das Fed >From: "Jim Nolan" <jimnolan(at)insightbb.com> >Reply-To: rv-list(at)matronics.com >To: "RV List" >Subject: RV-List: Installation Requirements >Date: Mon, 15 Sep 2003 04:37:34 -0500 > > >Listers, > Is there any knowledgeable FAA type listers that can answer these >questions for me. >1. Can I legally install, test and fill out the evaluation sheet on an IFR >GPS unit without FAA FSDO intervention. >2. Can I legally install, test and sign off a Sensenich prop installation >on my RV-4 / Lycoming engine without FAA FSDO intervention. >3. Can I legally raise the gross weight of my aircraft, test fly, document >V speeds and sign off the change without going thru the FAA FSDO. > The trouble I have is, I get one answer from the FSDO and another from a >MIDO and still another from a DAR. I learned how to read but the >interpretation of the rules by everyone concerned are as different as the >interpretations of the bible. >Jim Nolan >N444JN >May be legal / may not be legal > > ________________________________________________________________________________
Date: Sep 15, 2003
Subject: Dynon for VFR panel, was: More Dynon IFR
The Dynon unit has gotten a lot of discussion going. I am building my RV-7A as a VFR fun machine. May be IFR later but initially VFR only. The Dynon with the magnatometer gives me everything I need to be VFR legal, I think. Altitude, airspeed, compass, needle and ball plus a lot more. If I loose the dynon then I would like something that is going to let me know when I am getting close to a stall in the landing configuration and an indication of what direction I am flying. For everything else I can just look outside. I know about what pattern altitude looks like and as long as I am not stalling, exactly how fast I am going is a luxury. My panel is going to consist of a Dynon with magnatometer, separate angle of attack with the indicator mounted on top of the glare shield. The angle of attack is the backup for the airspeed indicator and a GPS is the backup for the compass and altimeter. I could be talked into a basic needle and ball but it currently isn't in the plans. I don't see where I need a belt and suspenders and duct tape just to hold up my pants :-) Steve Eberhart RV-7A - building ailerons Bob wrote: > > >>The heading on the Dynon wanders a little bit sometimes. Not really a >>problem, a minor annoyance, I just have to becareful not to chase it. I >>havent ripped out the DG yet and in the clouds I was thinking that I may not >>get in a hurry to do that...... I am debating whether I would rather have a >>DG or a Horizon if I was going to keep the vacuum system..... Dunno...... >>leaning toward the DG, but I may still take the whole vacuum system out. > > > Doug > > What about using a GPS for a back up instead of a DG? > > Bob > > > > > > > ________________________________________________________________________________
Date: Sep 15, 2003
Subject: Painting metallics
Guys, What's the trick to painting single-stage metallics and getting the flakes to lay down in a uniform fashion? The only metallic I'm using on my plane is a single-stage silver (SherWill Genesis) that I'm applying to the leading edges of the wings, empennage, and flaps. The first thing I sprayed was the empennage leading edges. Per the recommendation of a local paint guy, I sprayed two coats--the first coat was across (perpendicular to) the leading edge, wait 10 mins for it to tack up, and the second coat was along the leading edge (i.e. a 90 degree cross coat to the first coat). This was on the empennage with the parts hanging in the booth LE down. Great results. Couple days ago I sprayed silver on the "LE" of my flaps (the part that will get covered by UHMW). I did everything the same as on the empennage except the parts were laying flat on sawhorses. This time the flakes look weird....kinda splotchy with an uneven pattern. Wondering if painting it on a vertical surface helps "align" the flakes better due to the tug of gravity than on a horizontal surface where they seem to just lay as the fell? Anybody with metallic painting experience that can offer some insight or suggestions? I still need to do my wing LE's and want them to look good... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D painting...learning everything the hard way... The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Sep 15, 2003
Subject: Re: Dynon for VFR panel, was: More Dynon IFR
Steven Eberhart wrote: > > > The Dynon unit has gotten a lot of discussion going. I am building my > RV-7A as a VFR fun machine. May be IFR later but initially VFR only. > The Dynon with the magnatometer gives me everything I need to be VFR > legal, I think. Altitude, airspeed, compass, needle and ball plus a lot > more. If I loose the dynon then I would like something that is going to > let me know when I am getting close to a stall in the landing > configuration and an indication of what direction I am flying. For > everything else I can just look outside. I know about what pattern > altitude looks like and as long as I am not stalling, exactly how fast I > am going is a luxury. > > My panel is going to consist of a Dynon with magnatometer, separate > angle of attack with the indicator mounted on top of the glare shield. > The angle of attack is the backup for the airspeed indicator and a GPS > is the backup for the compass and altimeter. I could be talked into a > basic needle and ball but it currently isn't in the plans. > > I don't see where I need a belt and suspenders and duct tape just to > hold up my pants :-) > > Steve Eberhart > RV-7A - building ailerons Steve, add the Rocky Mountain uMonitor for engine instruments and you will have everything you need for **daytime VFR** in two instruments. A GPS will provide everything you need for Dynon backup. Cool! Wait until you hear the comments at pancake breakfasts when they see your empty panel.... ;-) Sam Buchanan (Dynon arriving in a couple of hours) ________________________________________________________________________________
Date: Sep 15, 2003
Subject: Primer Selection (was "Primer performance & edge finishing")
Hi Brett, I have never added to the primer wars before but I have been a victim of some of the misguidance from the List (shame on me). I can't answer all your specific questions because I'm not flying yet, but I am painting, and having done plenty of research for painting I can offer a bit of insight on what I've learned about primers FWIW to those who are just getting started (and how I would do it over if I had the opportunity). All this information about primers is available by talking to paint companies (Dupont, Sherwin Willims, PPG, etc) or reading their spec sheets on the internet. Problem is most of us don't do that until we're at the finishing end of the project, so a lot of interior primer decisions are made based on hearsay or what somebody else used. I used a self-etching primer on all interior areas of my airplane because that's what "worked" for many others on the RV List and it was easy and inexpensive. Based on what I've learned since then, I think it's mostly a waste of time and money and just adds weight for a very marginal corrosion protection benefit. The main purpose of self-etching primers is to clean (etch) the metal really well for a good "bite" over which you must paint a sealing primer (usually an epoxy primer) if you want to provide real corrosion protection. The epoxy primer will seal out moisture and salts and other nasties that try to attack the aluminum. The self-etching primers (any brand that I'm aware of) are NOT sealing primers...this is pretty obvious from reading the data sheets. In fact the Sherwin Williams self-etching primer says to recoat the product with a sealer within 4 hours if you want it to do any good, otherwise you must reprime with self-etching before sealing with a topcoat. If anyone is aware of a spec sheet for a self-etching primer that specifically calls out good stand-alone corrosion resistance *without recoating using a sealer* I would sure like to know about it (and would recommend using such a product if it existed). There are some epoxy primers that are DTM (direct-to-metal) which don't require a self-etching primer underneath. If you MUST coat everything with primer and you only want one coat, I'd use an epoxy DTM if I had to do it over. Main disadvantages to this is cost and weight...the Sherwin Williams epoxy DTM primer I'm using on the outside of the airplane is 3-4 times the cost of the self-etching primer, and it also goes on a bit thicker (and I think you get what you pay for in terms of corrosion resistance). All that said...if I *really* had to do it over...I would hit the rivet seams with epoxy DTM primer (any leading brand), leave the rest of the interior plain ol' alcad, and put it together. Lots of spam cans flying around with plain unprimed alclad interiors that were built 50 years ago and are still airworthy. Most serious corrosion you see is in joints where moisture and dirt get stuck and attack the metal (hence the benefit of epoxy DTM primer in these areas)...a *very light* surface oxidation on alclad is doesn't do any structural harm and is common on interior skins of aformentioned spam. If I lived in a really corrosive environment (i.e. near saltwater) I would etch and alodine the interior before priming the joints. Etch/Alodine adds no weight and offers good surface corrosion protection. If I were building a seaplane and wanted the absolute best corrosion protection at minimum weight and no expenses spared, I would etch, alodine and then use epoxy DTM sealing primer over the entire interior surface. That's about as good as it gets from my research. Humbled by painting, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D still stuck in painting hell... From: "Brett Morawski" <brett.morawski@buckeye-express.com> Subject: RV-List: Primer performance & edge finishing - Yes I checked the archives & not trying to start a primer war I researched all the primer issues I could find and made my decision a while back but I thought it was worth checking back one more time. I'm curious about how well all the different primer methods are holding out in the real world. Most of the responses in the archives deal with what people were planning to use as they were building. What I'd like to know is: What method/system did you use? How long has your RV been flying? What part of the world you're in - near salt/fresh water/next to a coal burning plant, hangered/outside? How well is your primer performing? If you had to do it over what would you do differently? Also, how anal were you in finishing/deburring/rounding off the edges of all the ribs, spars and skins and have you had any cracking issues that make you wish you had been more anal? Brett Morawski 8 (8A?) emp ready to prime, wing ordered The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Subject: Installation requirements
Date: Sep 15, 2003
The requirement for FAA FSDO involvment depends entirely upon your operating limitations. The changes you suggested are probably going to be considered major alterations by most FSDOs so your limitations may call for either 5 hours fly off with log book entry or they may call for a reissue of the special airworthiness cert operating limitations to include the changes. If the latter, have your cert operating limits updated to include the 5 hour fly off version. In any event it doesn't matter what interpretations you hear about, it only matters that you follow the interpretation of the FAA entity you are doing business with. These changes should be able to be handled by your local FSDO so ask them what they want, before you make the changes. W ________________________________________________________________________________
Date: Sep 15, 2003
Subject: paint weight and coats required
Guys, I thought I'd offer some insight for those of you who are interested in saving weight on your paint job. I have learned (again, the hard way) that for a given color, certain paint brands cover (or "hide") better than others, and from a weight/time/money standpoint, obviously the fewer coats it takes to cover the plane the better. I knew before I started painting that some colors tend to need more coats than others....for example I've heard that yellow airplanes tend to be a bit heavier (or is this hearsay??) due to more coats needed. Anyway my paint scheme (T-6A JPATS in USAF markings) is mostly blue and white with red stripe. I am using Sherwin Williams Genesis series which is an acrylic urethane (designed to replace the Sunfire acrylic urethane series). I picked the Genesis paint over DuPont Imron 5000 (the two offerings from my local paint shop) because it is a bit less expensive and easier to buff out any small flaws. Being a novice painter I thought this was a good thing. But the downside I've discovered is that the single-stage dark blue color that I'm using requires at least 3 wet coats to get full color coverage. This is over a grey primer, and I might get by with only two coats using a black or dark blue tinted primer. Anyway it's a real bummer because it takes more time and most of all adds WEIGHT. I've tried to keep my airplane light so this is discouraging. Several people I've talked to who've used dark blue DuPont Imron or PPG Concept have said they only needed 1-2 coats. Dave Wilson for example (who's nice USAF-themed red/white/blue RV-8 was featured a few weeks ago in RV of the Week) told me he only needed a single coat of each color, with PPG Concept). If I had known this, I'd have used Imron or Concept instead of Genesis just for weight savings, and ironically, might even save money since less paint is required (even though Imron is more expensive than Genesis). The twist according to local painters I've talked to is that while this is true for dark blue, it may be just the opposite for a different color. For example, I was told that red Imron doesn't cover as well as red Genesis. Ah, too bad my whole airplane isn't red instead of just the stripe : ) The one and only advantage to using 3 coats of dark blue Genesis is that it does have great "depth"....a really nice wet look with a single-stage paint that if buffed out would probably rival a 2-stage (clearcoat). But the reason I would not clearcoat an airplane--or use dark blue Genesis again--is because IMHO the weight gain and expense and time to apply is not worth the slightly nicer looks you get compared to using minimal coats of a good-hiding single-stage paint. Why didn't somebody tell me all this before I started? : ) --Mark Navratil Cedar Rapids, Iowa RV-8A N2D painting....crying....painting....whining... The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Sep 15, 2003
From: michael michael <top_gun_toronto(at)yahoo.ca>
Subject: gear leg weight RV steel rods
Dear fellow RV builders. I dont have the Fues kit yet. I`m working on the wing. I was wondering if anyone out there knows the weight of the landing gear legs. Just the steel rods themselves with no extras....I looked in the archives & couldnt find anything about this, just listings for CG related stuff. thanks Michael RV-7 --------------------------------- ________________________________________________________________________________
Subject: Dynon Report
Date: Sep 15, 2003
Folks, I have two things to report. First, the AOA indicator correctly indicates a stall when nose down inverted in a split S. Its kinda cool because the plane falls upwards then falls down and starts flying again. I didn't do this more than once as I don't know that this manuvere is not the safest one as it could be how one gets into an inverted flat spin. But the AOA was right on as it didn't stall until in the red. Its also kinda cool to be pointed almost straight down inverted and be just above stall speed hanging there for a few moments. Second thing, I finally had the time to move the compass module to a location in the right wing where the landing light would go if one were there. It has been a real excercise to find a location that is more than 12" away from any wire or iron in this plane. Getting the angles right was also a bear. Aluminum was too flimsy and changed as one tightened things, so I used two peices of 2"x5"x3/4" spruce. The bottom peice I used to establish the longitudinal axis, and the top peice established the lateral axis. It was very difficult to get both axis sanded into one piece. The top piece then has four SS flush machine screws sticking up threw it before being bonded to the bottom peice. (Use a magnet to test your SS hardware as I found some SS hardware that was magnetic) The assembly was then bonded to the inside skin just aft of the leading edge. This got it within 0.3deg on both axis, and I final trimed it with mylar tape shims. The module is then held in place with the 1" nylon standoff type nuts found in electronic supply stores as they are very easy to get to inside that dark hole. I also found a 9 pin RS232 type connector made out of plastic at frys. Its the type that traps and wedges the wires, IDC-9F-Blue female Frys # 1655696. I then used nylon screws to attach it. This type of connector has no support for the wires so be sure to secure it with one of the mounting nuts for the unit. I didn't have time to test fly it or calibrate it with a compass rose, but I did recalibrate it to the steam compass and current inclination for my airport and it seemed to be right on for the four major points. W ________________________________________________________________________________
Date: Sep 15, 2003
Subject: New SPAM and Virus Filtering Appliance At Matronics...
Dear Listers, I will be installing a new SPAM and virus blocking appliance this evening or tomorrow. The installation will involve some changes in the Matronics DNS MX records, and will impact how incoming email is handled. While I expect these changes to be transparent to all of the List subscribers, things might go differently... ;-) The Lists get bombarded with tons of SPAM messages and viruses each day and fortunately my custom filters have been extremely effective at filtering most of this from redistribution. Its time to move to the next level of technology, however, and this SPAM and Virus filtering appliance seems like an excellent solution. I will post a follow up message later in the week when things have stabilized and I have some filter statistics to share. Best regards, Matt Dralle Matronics Email List Admin. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Sep 15, 2003
AMEN Guys! There are actually people doing just that. My current project is just about as minimal as you can get. Here's my panel: Dynon Efis Garmin 196 IK-2000 Engine Monitor UPSAT TXPDR ICOM Radio It's probably the most bare RV6 panel I've ever seen, but it should be simple, light, and FAST! Oops, almost forgot to mention, my "filler" on the right side of the panel is a flush mounted map box, but nothing else! Cheers, Stein Bruch RV6's, Minneapolis http://www.steinair.com >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Steve, add the Rocky Mountain uMonitor for engine instruments and you will have everything you need for **daytime VFR** in two instruments. A GPS will provide everything you need for Dynon backup. Cool! Wait until you hear the comments at pancake breakfasts when they see your empty panel.... ;-) Sam Buchanan (Dynon arriving in a couple of hours) ________________________________________________________________________________
Date: Sep 15, 2003
>2. Can I legally install, test and sign off a Sensenich prop installation >on my RV-4 / Lycoming engine without FAA FSDO intervention. Check your operating limitations that the FAA gives you when they sign off the A/C. Mine state any major mods (this includes prop), I have to document in the A/C log and return to the "original" test area, as outline in the operating limitations and fly 5 test hours and document the results. >3. Can I legally raise the gross weight of my aircraft, test fly, document >V speeds and sign off the change without going thru the FAA FSDO. If you look hard enough, you will find someone who will give you the answer that you want. IMO, the answer is no. This is a really complicated area. My FSDO inspector would not allow me to increase my gross weight above the stated gross weight in the builders manual. I pointed out that others had done so with no problems. He asked me if I thought I was smarter than the designer (Van), did I have any engineering evaluations to support my request? Then he told me, that in a previous life he had been an A/C insurance accident investigator. His job was to find a reason why the insurance company did not have to pay (violations of the FAR, no medical, A/C maintenance problems etc.). He called Vans aircraft asking them for a letter that stated the A/C could be safely flown at a higher gross weight, Van flatly refused to issue a letter. He told me that in his opinion, changing the gross weight would be a real insurance debate, but only after the accident, not to mention lawsuits from the injured parties. At this time I read between the lines, If I wanted my aircraft to get signed off, I would keep the designed gross weight, and he pointed out that it is difficult to establish the exact weight of an aircraft after a crash. Of course there are other ways around the gross weight problem without documenting it. NOTE: he never told me I could fly above gross weight. > The trouble I have is, I get one answer from the FSDO and another from > a MIDO and still another from a DAR. I learned how to read but the > interpretation of the rules by everyone concerned are as different as the > interpretations of the bible. You can do anything you want until you get caught and have to pay the consequences. As my Uncle who was an Air Force Flight Safety Officer told me when I was complaining about the FAA Regs "The Regs are written in BLOOD!" Bob RV6 NightFighter ________________________________________________________________________________
Date: Sep 15, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Re: Primer Selection (was "Primer performance & edge
finishing") I talked to vans a while back and one of the guys there mentioned just using the selfetching primer with the top coat, keeps things really light this way. Reading about all this protection, isnt that what the top coat is for? > > >Hi Brett, > >I have never added to the primer wars before but I have been a victim of >some of the misguidance from the List (shame on me). I can't answer all >your specific questions because I'm not flying yet, but I am painting, and >having done plenty of research for painting I can offer a bit of insight on >what I've learned about primers FWIW to those who are just getting started >(and how I would do it over if I had the opportunity). All this information >about primers is available by talking to paint companies (Dupont, Sherwin >Willims, PPG, etc) or reading their spec sheets on the internet. Problem is >most of us don't do that until we're at the finishing end of the project, so >a lot of interior primer decisions are made based on hearsay or what >somebody else used. > >I used a self-etching primer on all interior areas of my airplane because >that's what "worked" for many others on the RV List and it was easy and >inexpensive. Based on what I've learned since then, I think it's mostly a >waste of time and money and just adds weight for a very marginal corrosion >protection benefit. The main purpose of self-etching primers is to clean >(etch) the metal really well for a good "bite" over which you must paint a >sealing primer (usually an epoxy primer) if you want to provide real >corrosion protection. The epoxy primer will seal out moisture and salts and >other nasties that try to attack the aluminum. The self-etching primers >(any brand that I'm aware of) are NOT sealing primers...this is pretty >obvious from reading the data sheets. In fact the Sherwin Williams >self-etching primer says to recoat the product with a sealer within 4 hours >if you want it to do any good, otherwise you must reprime with self-etching >before sealing with a topcoat. If! > anyone is aware of a spec sheet for a self-etching primer that specifically >calls out good stand-alone corrosion resistance *without recoating using a >sealer* I would sure like to know about it (and would recommend using such a >product if it existed). There are some epoxy primers that are DTM >(direct-to-metal) which don't require a self-etching primer underneath. If >you MUST coat everything with primer and you only want one coat, I'd use an >epoxy DTM if I had to do it over. Main disadvantages to this is cost and >weight...the Sherwin Williams epoxy DTM primer I'm using on the outside of >the airplane is 3-4 times the cost of the self-etching primer, and it also >goes on a bit thicker (and I think you get what you pay for in terms of >corrosion resistance). > >All that said...if I *really* had to do it over...I would hit the rivet >seams with epoxy DTM primer (any leading brand), leave the rest of the >interior plain ol' alcad, and put it together. Lots of spam cans flying >around with plain unprimed alclad interiors that were built 50 years ago and >are still airworthy. Most serious corrosion you see is in joints where >moisture and dirt get stuck and attack the metal (hence the benefit of epoxy >DTM primer in these areas)...a *very light* surface oxidation on alclad is >doesn't do any structural harm and is common on interior skins of >aformentioned spam. If I lived in a really corrosive environment (i.e. near >saltwater) I would etch and alodine the interior before priming the joints. >Etch/Alodine adds no weight and offers good surface corrosion protection. >If I were building a seaplane and wanted the absolute best corrosion >protection at minimum weight and no expenses spared, I would etch, alodine >and then use epoxy DTM sealing pr! >imer over the entire interior surface. That's about as good as it gets from >my research. > >Humbled by painting, > >--Mark Navratil >Cedar Rapids, Iowa >RV-8A N2D still stuck in painting hell... > > >From: "Brett Morawski" <brett.morawski@buckeye-express.com> >Subject: RV-List: Primer performance & edge finishing - Yes I checked the >archives >& not trying to start a primer war > ><brett.morawski@buckeye-express.com> > >I researched all the primer issues I could find and made my decision a while >back but I thought it was worth checking back one more time. > >I'm curious about how well all the different primer methods are holding out >in the real world. Most of the responses in the archives deal with what >people were planning to use as they were building. > >What I'd like to know is: > > What method/system did you use? > > How long has your RV been flying? > > What part of the world you're in - near salt/fresh water/next to a coal >burning plant, hangered/outside? > > How well is your primer performing? > > If you had to do it over what would you do differently? > >Also, how anal were you in finishing/deburring/rounding off the edges of all >the ribs, spars and skins and have you had any cracking issues that make you >wish you had been more anal? > > >Brett Morawski >8 (8A?) emp ready to prime, wing ordered > >The best thing to hit the internet in years - Juno SpeedBand! >Surf the web up to FIVE TIMES FASTER! > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
From: "Crosley, Rich" <RCROSLEY(at)HRTEXTRON.TEXTRON.COM>
Subject: LASAR QUESTION
Date: Sep 15, 2003
The Lasar ignition requires a RPM input. Does the Van's tach work with the Lasar system directly or is some modification required? Rich Crosley, RV-8 Palmdale, CA ________________________________________________________________________________
Subject: Re: Primer Selection (was "Primer performance & edge finishing")
Date: Sep 15, 2003
That's what I did and it is working just fine... PPG DX1791 wash primer under DCC Concept. After 3 years and 350 hrs I have no adhesion problems at all. See www.rv-8.com/Paint.htm for the materials and techniques I used. Randy Lervold ----- Original Message ----- From: "Scott Bilinski" <bilinski@kyocera-wireless.com> Subject: Re: RV-List: Primer Selection (was "Primer performance & edge finishing") <bilinski@kyocera-wireless.com> > > I talked to vans a while back and one of the guys there mentioned just > using the selfetching primer with the top coat, keeps things really light > this way. Reading about all this protection, isnt that what the top coat is > for? > > > > > > > >Hi Brett, > > > >I have never added to the primer wars before but I have been a victim of > >some of the misguidance from the List (shame on me). I can't answer all > >your specific questions because I'm not flying yet, but I am painting, and > >having done plenty of research for painting I can offer a bit of insight on > >what I've learned about primers FWIW to those who are just getting started > >(and how I would do it over if I had the opportunity). All this information > >about primers is available by talking to paint companies (Dupont, Sherwin > >Willims, PPG, etc) or reading their spec sheets on the internet. Problem is > >most of us don't do that until we're at the finishing end of the project, so > >a lot of interior primer decisions are made based on hearsay or what > >somebody else used. > > > >I used a self-etching primer on all interior areas of my airplane because > >that's what "worked" for many others on the RV List and it was easy and > >inexpensive. Based on what I've learned since then, I think it's mostly a > >waste of time and money and just adds weight for a very marginal corrosion > >protection benefit. The main purpose of self-etching primers is to clean > >(etch) the metal really well for a good "bite" over which you must paint a > >sealing primer (usually an epoxy primer) if you want to provide real > >corrosion protection. The epoxy primer will seal out moisture and salts and > >other nasties that try to attack the aluminum. The self-etching primers > >(any brand that I'm aware of) are NOT sealing primers...this is pretty > >obvious from reading the data sheets. In fact the Sherwin Williams > >self-etching primer says to recoat the product with a sealer within 4 hours > >if you want it to do any good, otherwise you must reprime with self-etching > >before sealing with a topcoat. If! > > anyone is aware of a spec sheet for a self-etching primer that specifically > >calls out good stand-alone corrosion resistance *without recoating using a > >sealer* I would sure like to know about it (and would recommend using such a > >product if it existed). There are some epoxy primers that are DTM > >(direct-to-metal) which don't require a self-etching primer underneath. If > >you MUST coat everything with primer and you only want one coat, I'd use an > >epoxy DTM if I had to do it over. Main disadvantages to this is cost and > >weight...the Sherwin Williams epoxy DTM primer I'm using on the outside of > >the airplane is 3-4 times the cost of the self-etching primer, and it also > >goes on a bit thicker (and I think you get what you pay for in terms of > >corrosion resistance). > > > >All that said...if I *really* had to do it over...I would hit the rivet > >seams with epoxy DTM primer (any leading brand), leave the rest of the > >interior plain ol' alcad, and put it together. Lots of spam cans flying > >around with plain unprimed alclad interiors that were built 50 years ago and > >are still airworthy. Most serious corrosion you see is in joints where > >moisture and dirt get stuck and attack the metal (hence the benefit of epoxy > >DTM primer in these areas)...a *very light* surface oxidation on alclad is > >doesn't do any structural harm and is common on interior skins of > >aformentioned spam. If I lived in a really corrosive environment (i.e. near > >saltwater) I would etch and alodine the interior before priming the joints. > >Etch/Alodine adds no weight and offers good surface corrosion protection. > >If I were building a seaplane and wanted the absolute best corrosion > >protection at minimum weight and no expenses spared, I would etch, alodine > >and then use epoxy DTM sealing pr! > >imer over the entire interior surface. That's about as good as it gets from > >my research. > > > >Humbled by painting, > > > >--Mark Navratil > >Cedar Rapids, Iowa > >RV-8A N2D still stuck in painting hell... > > > > > >From: "Brett Morawski" <brett.morawski@buckeye-express.com> > >Subject: RV-List: Primer performance & edge finishing - Yes I checked the > >archives > >& not trying to start a primer war > > > ><brett.morawski@buckeye-express.com> > > > >I researched all the primer issues I could find and made my decision a while > >back but I thought it was worth checking back one more time. > > > >I'm curious about how well all the different primer methods are holding out > >in the real world. Most of the responses in the archives deal with what > >people were planning to use as they were building. > > > >What I'd like to know is: > > > > What method/system did you use? > > > > How long has your RV been flying? > > > > What part of the world you're in - near salt/fresh water/next to a coal > >burning plant, hangered/outside? > > > > How well is your primer performing? > > > > If you had to do it over what would you do differently? > > > >Also, how anal were you in finishing/deburring/rounding off the edges of all > >the ribs, spars and skins and have you had any cracking issues that make you > >wish you had been more anal? > > > > > >Brett Morawski > >8 (8A?) emp ready to prime, wing ordered > > > >The best thing to hit the internet in years - Juno SpeedBand! > >Surf the web up to FIVE TIMES FASTER! > > > > > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > ________________________________________________________________________________
Subject: Re: LASAR QUESTION
Date: Sep 15, 2003
Van's tach uses input from a mechanical transducer connected to the tach drive -- doesn't take input from the LASAR. Randy Lervold RV-8, 355 hrs. ----- Original Message ----- From: "Crosley, Rich" <RCROSLEY(at)HRTEXTRON.TEXTRON.COM> Subject: RV-List: LASAR QUESTION > > The Lasar ignition requires a RPM input. Does the Van's tach work with the > Lasar system directly or is some modification required? > > Rich Crosley, RV-8 > Palmdale, CA > > ________________________________________________________________________________
Date: Sep 15, 2003
Subject: Re: gear leg weight RV steel rods
Just for fun I drew up the gear leg from the RV-6 Preview plans dwg # 45 dated 3/22/99. According to my CAD software (SolidWorks 2001 Plus) There are 78.14 cubic inches of 4140 steel in that gear leg. I don't have a density for 4140 but I generally use .283 lb/in 3 for all steel alloys and that makes it 22.11 lbs. -- Chris Woodhouse 3147 SW 127th St. Oklahoma City, OK 73170 405-691-5206 chrisw(at)programmer.net N35 20.492' W97 34.342' "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin, 1759 Historical Review of Pennsylvania ________________________________________________________________________________
Date: Sep 15, 2003
> >>3. Can I legally raise the gross weight of my aircraft, test fly, document >>V speeds and sign off the change without going thru the FAA FSDO. > >If you look hard enough, you will find someone who will give you the answer >that you want. IMO, the answer is no. This is a really complicated >area. My FSDO inspector would not allow me to increase my gross weight >above the stated gross weight in the builders manual. I pointed out that >others had done so with no problems. He asked me if I thought I was >smarter than the designer (Van), did I have any engineering evaluations to >support my request? Then he told me, that in a previous life he had been >an A/C insurance accident investigator. His job was to find a reason why >the insurance company did not have to pay (violations of the FAR, no >medical, A/C maintenance problems etc.). He called Vans aircraft asking >them for a letter that stated the A/C could be safely flown at a higher >gross weight, Van flatly refused to issue a letter. He told me that in his >opinion, changing the gross weight would be a real insurance debate, but >only after the accident, not to mention lawsuits from the injured >parties. At this time I read between the lines, If I wanted my aircraft to >get signed off, I would keep the designed gross weight, and he pointed out >that it is difficult to establish the exact weight of an aircraft after a >crash. Of course there are other ways around the gross weight problem >without documenting it. NOTE: he never told me I could fly above gross >weight. > How does the FSDO decide what gross weight to accept if you design an aircraft yourself? If you manage to talk a FSDO into accepting the weight increase, I'm not sure where insurance enters into it. Does your insurance policy say you have to abide by Van's recommended gross weight? But if the insurance people manage to figure out you were flying at a weight higher than is in your limitations, then that gives them a golden reason to deny coverage. I wouldn't say it was that hard to figure out how heavy you were in many cases. The empty weight is recorded. The weights of the people can probably be established fairly closely. Luggage etc in the crash can be weighed, unless there is a fire. If you filled the plane up before the flight the fuel on board can be estimated fairly closely based on time airborne before the crash. If I determined that I was going to fly at XXXX lbs, I would rather have that value in the operating limitations than not. I would have thought a weight increase was simply a major mod. Once you have the operating limitations that allow you to do major mods without FSDO approval, you could go back into the test phase, test at the higher gross weight, and change the operating limitations. But I'm no expert in the FARs, so my opinion isn't worth much. Just remember that the laws of physics haven't changed just because you increased the allowable gross weight. If you increase the weight you need to fly more conservatively. I would not increase the landing weight above Van's number. If I was above Van's recommended weight I would only takeoff from a smooth, hard surface runway. Reduce the allowable g when over Van's recommended weight to keep the total lift required the same. Reduce VNO when over Van's recommended weight. Realize that some of the operating speeds need to be increased if you increase the weight - speed for best glide, speed for best angle of climb, speed for best rate of climb and desired final approach speed will all increase. Depending on the results of your handling testing, you may need to tweak the forward and aft CG limits when at the higher weight. Fly safe, -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Subject: Fw: AeroElectric-List: Ground block location
Date: Sep 15, 2003
Fwd'd from Aeroelectric List for RV-specific response. DC ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Ground block location > --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" > > >--> AeroElectric-List message posted by: WHigg1170(at)aol.com > > > >Hello I have a question on the B&C 24 terminal ground block location. I don't > >have the engine or mount and I want to place the ground block on the cabin > >side of the firewall but don't know were to put it so it won't be in the > >way and > >also still use vans #2 cables that came with the wiring harness kit. Thanks > > > >Bill > >RV-6 > > Can any RV builders help Bill out with this? > > Bob . . . > > ________________________________________________________________________________
Subject: Re:Short Field
Date: Sep 15, 2003
Just HOW short a field are you talking about?? I fly our RV-4(150 HP) from our 1100 ft. grass strip @460 MSL in summer or winter. I have just installed vortex generators from Larry Vetterman for enough margin to take my wife along. Bob Olds Charleston,Arkansas ________________________________________________________________________________
Date: Sep 15, 2003
Mark: Just finished painting my -8 with 2 stage paint (HOK). My suggestion would be to try to do metallics with 2 stage paint rather than single stage. It is really not that much more work and you can even clear over your single stage paint to get an even cover over taped edges. Short of that, I would suggest that you might try to put your first coat down dry (medium dry) so that the metallic has a chance to spread evenly over the surface, then try to come in gradually thicker with the 2nd or 3rd coat to get your gloss. Horizontal surfaces usually get a thicker coat (because of gravity) so you may find that aligning the parts vertically is simply getting you a finer coverage, which is what you want with metallic. The way to get that on horizontal is to turn the material quantity knob on your gun in. The advantage of the 2 stage here is you can keep putting the metallic down dry, then gloss it up with the clear. I am by no means an expert on this, but thought I would chime in. -Mike Sices RV-8 - final assembly -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of czechsix(at)juno.com Subject: RV-List: Painting metallics Guys, What's the trick to painting single-stage metallics and getting the flakes to lay down in a uniform fashion? The only metallic I'm using on my plane is a single-stage silver (SherWill Genesis) that I'm applying to the leading edges of the wings, empennage, and flaps. The first thing I sprayed was the empennage leading edges. Per the recommendation of a local paint guy, I sprayed two coats--the first coat was across (perpendicular to) the leading edge, wait 10 mins for it to tack up, and the second coat was along the leading edge (i.e. a 90 degree cross coat to the first coat). This was on the empennage with the parts hanging in the booth LE down. Great results. Couple days ago I sprayed silver on the "LE" of my flaps (the part that will get covered by UHMW). I did everything the same as on the empennage except the parts were laying flat on sawhorses. This time the flakes look weird....kinda splotchy with an uneven pattern. Wondering if painting it on a vertical surface helps "align" the flakes better due to the tug of gravity than on a horizontal surface where they seem to just lay as the fell? Anybody with metallic painting experience that can offer some insight or suggestions? I still need to do my wing LE's and want them to look good... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D painting...learning everything the hard way... The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! --- Incoming mail is certified Virus Free. --- ________________________________________________________________________________
Subject: Ground block location
Date: Sep 15, 2003
Here is a picture of mine. Worked fine here. http://www.lacodeworks.com/besing/wiring.htm Paul Besing RV-6A Sold (Waiting on the RV-10) http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "David Carter" <dcarter(at)datarecall.net> Subject: RV-List: Fw: AeroElectric-List: Ground block location > > Fwd'd from Aeroelectric List for RV-specific response. > > DC > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > To: > Subject: Re: AeroElectric-List: Ground block location > > > > --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" > > > > > >--> AeroElectric-List message posted by: WHigg1170(at)aol.com > > > > > >Hello I have a question on the B&C 24 terminal ground block location. I > don't > > >have the engine or mount and I want to place the ground block on the > cabin > > >side of the firewall but don't know were to put it so it won't be in the > > >way and > > >also still use vans #2 cables that came with the wiring harness kit. > Thanks > > > > > >Bill > > >RV-6 > > > > Can any RV builders help Bill out with this? > > > > Bob . . . > > > > > > ________________________________________________________________________________
Date: Sep 15, 2003
Subject: Lightspeed Cross country
Listers, I have to share a recent experience. I have owned a pair of Cross Country ANR headsets for about 2 years and have been very pleased with them. It is possible that there are better ANR units, but the overall cost and weight and comfort are a great bargain in my view. But a couple months ago I got the power box caught in the seatbelt of my RV-3 and I pulled the wires loose. I sent an email to Lightspeed to see if they would send me the wiring layout so I could reconnect the broken wire. They really did not want to do this, preferring to get the unit back and check it out fully. I asked how much, and they said "free." I sent the unit back, and sure enough, I got my headset back in less than a week as good as new (new power cord) and absolutely free except for the shipping to get it to them. In every way I had contact with the company, they were absolutely customer and quality oriented. I cannot remember better service from anyone. BTW, someone said their mike seemed to let in too much noise. My current plane, an RV-6, is very noisy (as proven with a borrowed headset), but the audio coming from the mike on the Lightspeed is superb. The mike is directional and needs to be rotated 180 degrees if you change from right side to left side, so maybe the problem was a mike pointed at the noise rather than at the mouth. I am totally satisfied with this great product. Jim Van Laak RV-6 N79RL ________________________________________________________________________________
Subject: Re: Fw: AeroElectric-List: Ground block location
Date: Sep 15, 2003
Yep I willsend a pic John McMahon RV 6 (soon to paint) ----- Original Message ----- From: "David Carter" <dcarter(at)datarecall.net> Subject: RV-List: Fw: AeroElectric-List: Ground block location > > Fwd'd from Aeroelectric List for RV-specific response. > > DC > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > To: > Subject: Re: AeroElectric-List: Ground block location > > > > --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" > > > > > >--> AeroElectric-List message posted by: WHigg1170(at)aol.com > > > > > >Hello I have a question on the B&C 24 terminal ground block location. I > don't > > >have the engine or mount and I want to place the ground block on the > cabin > > >side of the firewall but don't know were to put it so it won't be in the > > >way and > > >also still use vans #2 cables that came with the wiring harness kit. > Thanks > > > > > >Bill > > >RV-6 > > > > Can any RV builders help Bill out with this? > > > > Bob . . . > > > > > > ________________________________________________________________________________
Date: Sep 15, 2003
From: "BillDube(at)killacycle.com" <BillDube(at)killacycle.com>
Below is all very good advice. The only thing I would cation about is putting the base coat down dry. If you put the base coat down dry, and don't let it flow out a bit, it leads to orange peel in the clear coat. You can wet sand the clear coat with 1200 to remove the orange peel, but it adds quite a bit of work to the process. At 07:43 PM 9/15/03, you wrote: > >Mark: > >Just finished painting my -8 with 2 stage paint (HOK). My suggestion would >be to try to do metallics with 2 stage paint rather than single stage. It >is really not that much more work and you can even clear over your single >stage paint to get an even cover over taped edges. Short of that, I would >suggest that you might try to put your first coat down dry (medium dry) so >that the metallic has a chance to spread evenly over the surface, then try >to come in gradually thicker with the 2nd or 3rd coat to get your gloss. >Horizontal surfaces usually get a thicker coat (because of gravity) so you >may find that aligning the parts vertically is simply getting you a finer >coverage, which is what you want with metallic. The way to get that on >horizontal is to turn the material quantity knob on your gun in. The >advantage of the 2 stage here is you can keep putting the metallic down dry, >then gloss it up with the clear. > >I am by no means an expert on this, but thought I would chime in. > >-Mike Sices >RV-8 - final assembly > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of >czechsix(at)juno.com >To: rv-list(at)matronics.com >Subject: RV-List: Painting metallics > > >Guys, > >What's the trick to painting single-stage metallics and getting the flakes >to lay down in a uniform fashion? The only metallic I'm using on my plane >is a single-stage silver (SherWill Genesis) that I'm applying to the leading >edges of the wings, empennage, and flaps. The first thing I sprayed was the >empennage leading edges. Per the recommendation of a local paint guy, I >sprayed two coats--the first coat was across (perpendicular to) the leading >edge, wait 10 mins for it to tack up, and the second coat was along the >leading edge (i.e. a 90 degree cross coat to the first coat). This was on >the empennage with the parts hanging in the booth LE down. Great results. > >Couple days ago I sprayed silver on the "LE" of my flaps (the part that will >get covered by UHMW). I did everything the same as on the empennage except >the parts were laying flat on sawhorses. This time the flakes look >weird....kinda splotchy with an uneven pattern. Wondering if painting it on >a vertical surface helps "align" the flakes better due to the tug of gravity
September 03, 2003 - September 15, 2003
RV-Archive.digest.vol-of
