RV-Archive.digest.vol-oq
December 15, 2003 - December 27, 2003
      $60K. Interested in your experiences regarding prices, customer service,
      etc...
      >  I checked the archives but found nothing real recent and assume that the
      market, and thus prices are probably somewhat volatile, so would like
      current info.
      >  I understand that there are are only a couple of underwriters (maybe only
      one?) so once I've asked an agent for a quote I'm locked into that agent and
      quote for 60 days. Is this info correct? If so, I would sure like to know
      where the best deal is before asking for a quote.
      >  The current owner has the airplane insured with the VanGuard program.
      > Mike Wills
      > RV-4 (perpetually under construction)
      > RV-6A (almost!)
Date: Dec 15, 2003
Subject: Re: Cracked Canopy
Dane, I cracked the canopy on my six during installation. The crack eminated from a screw hole on the frame and was 3/4 of an inch long. I stop drilled it with 3/32nd plexiglass drill bit and filled the hole with epoxy. 12 years and 800 hours later it still looks like the day I finished it. Good Luck Bill Mahoney Sherman, CT RV-6 N747W ________________________________________________________________________________
Date: Dec 15, 2003
Subject: fuel filters
Yes I've perused the archives, but I'd appreciate the latest and greatest on what is a good choice on a generic automotive fuel filter with AN-3 or -4 NPT fittings.... No, not getting into a gascolator vs. filter fight!!! From The PossumWorks in TN Mark - -6A, starting to look like an airplane!!!!!! ________________________________________________________________________________
Date: Dec 15, 2003
Subject: Re: fuel filters
You're lucky--I'd whip your butt if you got a (hot start retarding device) gascolator. There are several fuel filter brands out there--look for clear plastic barrel, 120 (?) micron filter (cleanable and re-useable) and a max fuel flow of about twice what you think your engine will use. Jeez, I really miss that "ripsteel" handle. Love, Boyd. On Monday, December 15, 2003, at 08:40 PM, Fiveonepw(at)aol.com wrote: > > Yes I've perused the archives, but I'd appreciate the latest and > greatest on > what is a good choice on a generic automotive fuel filter with AN-3 or > -4 NPT > fittings.... > > No, not getting into a gascolator vs. filter fight!!! > > From The PossumWorks in TN > Mark - -6A, starting to look like an airplane!!!!!! > ________________________________________________________________________________
Date: Dec 15, 2003
Jeez, what was I thinking, probably the best one out there is from Air Flow Performance. On Monday, December 15, 2003, at 09:33 PM, Boyd Braem wrote: > > You're lucky--I'd whip your butt if you got a (hot start retarding > device) gascolator. There are several fuel filter brands out > there--look for clear plastic barrel, 120 (?) micron filter (cleanable > and re-useable) and a max fuel flow of about twice what you think your > engine will use. > > Jeez, I really miss that "ripsteel" handle. > > Love, > > Boyd. > > > On Monday, December 15, 2003, at 08:40 PM, Fiveonepw(at)aol.com wrote: > >> >> Yes I've perused the archives, but I'd appreciate the latest and >> greatest on >> what is a good choice on a generic automotive fuel filter with AN-3 or >> -4 NPT >> fittings.... ________________________________________________________________________________
Date: Dec 15, 2003
Weldon-5 and a syringe will do the trick nicely. Paul Besing RV-6A Sold (RV-10 soon) http://www.lacodeworks.com/besing Kitlog Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Dane Sheahen" <dane(at)mutualace.com> Subject: RV-List: Cracked Canopy > > > I am looking for advice on what to do with a carked canopy. First off I > have already drilled a small hole to stop the crack. > This is the second winter for my RV8a. I flew the plane last week and I > came back this week and there is the crack. The RV is in an unheated hangar > and the temperature got down to 10 degrees the other night. First real cold > day of the season, so I am assuming that had something to do with it. Last > winter we had periods of cold weather that were colder and for longer > periods of time. > The crack starts at the skirt and goes up about 1 1/2 inches. > Any suggestions? > > Dane Sheahen > RV8a driver > > ________________________________________________________________________________
Subject: Re: AOPA Airport Database...
Date: Dec 15, 2003
It's available if you are an Anywheremap subscriber. Karie Daniel Sammamish, WA RV-7A QB ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> Subject: RV-List: AOPA Airport Database... > > Anyone know where you can get the AOPA Airport Database for the iPAQ? I found it for the Palm... > > I recently bought Airport Insight for my iPAQ and it is very nice; has all the info, and is updated regularly for only $40 a year, but I wanted to see about the AOPA database... > > Thanks! > > -Bill VonDane > EAA Tech Counselor > RV-8A ~ N8WV > www.vondane.com > www.creativair.com > www.epanelbuilder.com > > ________________________________________________________________________________
Subject: Copper Stock tip....
Date: Dec 15, 2003
To those interested; My RV-7/9 plans sheet 31A calls for two (2) .063 x 2-7/8" copper strips to be manufactured by the builder to connect the master contactor and starter contactor on the firewall. (The copper stock is NOT supplied in the kit.) Rather than hunt for the stock and purchase a mere 6" of material.....I found a solution. I took a 2-7/8" piece of 3/8" copper tube I had laying around, put it in my vice, and squeezed the crap out of it! Came out perfect! 1/2" wide x 2-7/8" long..... .190 thickness (plans call for 2 pieces of .063 so I am a few thousands over....). Jack Lockamy Camarillo, CA RV-7A QB N174JL reserved ________________________________________________________________________________
Subject: IK-2000 vs RMI vs GR EIS vs ?
Date: Dec 16, 2003
Thanks Sam. Just what I was looking for. Now my new question of the day. Anyone have a strong opinion on using the IK-2000 vs Rocky Mountain Engine monitor vs the Grand Rapids EIS? Any other brand I left out? I don't want to spend $4k+ for engine info so I've been looking at these systems without a clear winner coming up. At first glance the RMI doesn't show all 4 cylinders at once for leaning purposes, right? The Grand Rapid seems to require too much pilot interaction to get to the page you want and to read the tiny bar graphs. The IK-2000 goes the other way to me. Uses too much panel space for the 8 and paying for backup instruments I don't want from that system... lucky >From: Sam Buchanan <sbuc(at)hiwaay.net> >Reply-To: vansairforce(at)yahoogroups.com >To: vansairforce(at)yahoogroups.com >Subject: [VAF Mailing List] labels >Date: Mon, 15 Dec 2003 12:15:00 -0600 > >lucky macy wrote: > > > Doug, > > Do you have a link to a discussion on labeling panels? Labeling sounds > > trivial but as I start to look into label makers I see a wide range in >price > > and types. Is there a *best* type of label for our purposes? A >recommended > > font type or size? Any technique that works better than others for >ensuring > > the labels stay on past the first month? etc. > > >I'm not Doug but here is one option: > >http://home.hiwaay.net/~sbuc/journal/panel2.html > >Scroll down to the bottom of the page. These labels still look >good-as-new after four years and 525 flight hrs. Matter of fact, I have >"No Step" on the flaps and they still look great after being on the >exterior of the plane. > >Sam Buchanan >http://thervjournal.com > >================== > > Shop online for kids toys by age group, price range, and toy category at MSN Shopping. No waiting for a clerk to help you! http://shopping.msn.com ________________________________________________________________________________
Date: Dec 16, 2003
Hi Lucky, We have the RMI Monitor and encoder. Both were easy to build and the support from RMI was great. (e.g. when I finished the encoder it would completely run thru it's state-up routine. I call RMI and they asked me to send it to them, which I did. I had it back in 5 days. They said I had forgot to trim off three leads - which they did plus calibrated the unit for me - No Charge). Regarding the ability to see all four cyl at the same time - true. But we bought their four position switch and it's very high quality. You quickly find out which cyl peaks first and thats where I generally have it positioned. Then you simply cyclic through all cyls every so often. We also have the audio alarm output wired directly to the pilot's headset jack, so if we get an alarm (have set both high and low alarm values) we get an audible alarm in addition to the visual alarm. The RMI is not the most sofisicated system but it's simple (we have EGT and CHT for all cyl on the monitor) and it's been 100% reliable and is very cost effective. Will use both the MOnitor and encoder in our next RV. Hope this helps and happy Holidays - Fly Safe, Chuck & Dave Rowbotham RV-8A >From: "lucky macy" <luckymacy(at)hotmail.com> >Reply-To: rv-list(at)matronics.com >To: vansairforce(at)yahoogroups.com, rv-list(at)matronics.com >Subject: RV-List: IK-2000 vs RMI vs GR EIS vs ? >Date: Tue, 16 Dec 2003 07:10:49 -0500 > > >Thanks Sam. Just what I was looking for. > >Now my new question of the day. > >Anyone have a strong opinion on using the IK-2000 vs Rocky Mountain Engine >monitor vs the Grand Rapids EIS? Any other brand I left out? I don't want >to spend $4k+ for engine info so I've been looking at these systems without >a clear winner coming up. > >At first glance the RMI doesn't show all 4 cylinders at once for leaning >purposes, right? The Grand Rapid seems to require too much pilot >interaction to get to the page you want and to read the tiny bar graphs. >The IK-2000 goes the other way to me. Uses too much panel space for the 8 >and paying for backup instruments I don't want from that system... > >lucky > > > >From: Sam Buchanan <sbuc(at)hiwaay.net> > >Reply-To: vansairforce(at)yahoogroups.com > >To: vansairforce(at)yahoogroups.com > >Subject: [VAF Mailing List] labels > >Date: Mon, 15 Dec 2003 12:15:00 -0600 > > > >lucky macy wrote: > > > > > Doug, > > > Do you have a link to a discussion on labeling panels? Labeling >sounds > > > trivial but as I start to look into label makers I see a wide range in > >price > > > and types. Is there a *best* type of label for our purposes? A > >recommended > > > font type or size? Any technique that works better than others for > >ensuring > > > the labels stay on past the first month? etc. > > > > > >I'm not Doug but here is one option: > > > >http://home.hiwaay.net/~sbuc/journal/panel2.html > > > >Scroll down to the bottom of the page. These labels still look > >good-as-new after four years and 525 flight hrs. Matter of fact, I have > >"No Step" on the flaps and they still look great after being on the > >exterior of the plane. > > > >Sam Buchanan > >http://thervjournal.com > > > >================== > > > > > >Shop online for kids toys by age group, price range, and toy category at >MSN Shopping. No waiting for a clerk to help you! http://shopping.msn.com > > Tired of slow downloads and busy signals? Get a high-speed Internet connection! Comparison-shop your local high-speed providers here. https://broadband.msn.com ________________________________________________________________________________
Date: Dec 16, 2003
> Anyone have a strong opinion on using the IK-2000 vs Rocky > Mountain Engine > monitor vs the Grand Rapids EIS? Any other brand I left out? > I don't want > to spend $4k+ for engine info so I've been looking at these > systems without > a clear winner coming up. > > At first glance the RMI doesn't show all 4 cylinders at once > for leaning > purposes, right? The Grand Rapid seems to require too much pilot > interaction to get to the page you want and to read the tiny > bar graphs. > The IK-2000 goes the other way to me. Uses too much panel > space for the 8 > and paying for backup instruments I don't want from that system... > I have the RMI, and I really like everything about it EXCEPT only one CHT/EGT. I would probably pay up next time and get something showing all four. If one is chugging along, and a valve starts to go, a four channel EGT would notify you immediately. Alex Peterson Maple Grove, MN RV6-A N66AP 423 hours www.usfamily.net/web/alexpeterson ________________________________________________________________________________
From: "Michael D. Crowe" <tripacer(at)bellsouth.net>
Subject: interior fabric testing
Date: Dec 16, 2003
All, Does anyone know of a shop that can test and certify fabric to be used in a certified aircraft? Mike Crowe ________________________________________________________________________________
Date: Dec 16, 2003
Subject: Re: IK-2000 vs RMI vs GR EIS vs ?
That's the beauty of the EIS... Monitor all 4 for less $ than the RMI... I have one in my -8A and love it... Would definitely use one again... -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV www.vondane.com www.creativair.com www.epanelbuilder.com ----- Original Message ----- From: "Alex Peterson" <alexpeterson(at)usjet.net> Subject: RE: RV-List: IK-2000 vs RMI vs GR EIS vs ? I have the RMI, and I really like everything about it EXCEPT only one CHT/EGT. I would probably pay up next time and get something showing all four. If one is chugging along, and a valve starts to go, a four channel EGT would notify you immediately. Alex Peterson Maple Grove, MN RV6-A N66AP 423 hours www.usfamily.net/web/alexpeterson ________________________________________________________________________________
Subject: Re: Night Vision Goggle Observations (Long)
Date: Dec 13, 2003
Paul, The value I see in night vision goggles (no pun intended) is as an emergency device in the event of a night time power failure. The fan quits at night over rural area. It is too dark to discerne a suitable landing area. So you reach into a compartment, pull out the goggles, and bingo - you have a reasonable ability to select a landing site with at least the confidence of being able to walk away. From 3-4000' altitude, I'd want to be able to distinguish mountains from valleys, open fields, wooded areas, ponds and rivers, dirt roads, unlit buildings, and other major obstructions. As I got lower, I'd want to see powerlines, fences, train tracks, ground slope, large berms, and perhaps some clues to ground texture - (for example the direction of the furrows on a plowed field) I'd also need to be able to see some instruments, at least airspeed or an AOA. From your experience, (even at the $5,000 level) is this yet a reasonable expectation? Andy ________________________________________________________________________________
Date: Dec 16, 2003
vansairforce Oh yeah, I forgot the link to the Airport Insight software I bought, it's pretty cool! http://www.notamd.com/ ----- Original Message ----- From: Bill VonDane Subject: AOPA Airport Database... Anyone know where you can get the AOPA Airport Database for the iPAQ? I found it for the Palm... I recently bought Airport Insight for my iPAQ and it is very nice; has all the info, and is updated regularly for only $40 a year, but I wanted to see about the AOPA database... Thanks! -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Date: Dec 16, 2003
Subject: Re: Copper Stock tip....
> >To those interested; > >My RV-7/9 plans sheet 31A calls for two (2) .063 x 2-7/8" copper strips to >be manufactured by the builder to connect the master contactor and starter >contactor on the firewall. (The copper stock is NOT supplied in the >kit.) Rather than hunt for the stock and purchase a mere 6" of >material.....I found a solution. Here are a couple of pictures of the style of connection that some of the top EV drag racing folks use: http://68.111.220.234:81/ghiamonster/images/batteryconnectors.jpg and http://www.killacycle.com/kcclose2.jpg In EV drag racing, you are striving for light weight, maximum conductivity per pound, reliability, vibration immunity, and reasonable cost. This is exactly what you are looking for on an airplane. These straps are made with 3/4" or 1" copper braid and short sections of 1/2 inch (trade size) copper pipe. You use multiple layers of braid to create "thicker" conductors as needed. To handle 500 amps or so, you would use about three layers of 3/4" braid. You insert the braid into the short sections of copper pipe and then pound the pipe flat with a hammer or a hydraulic press. You then make a hole in the flattened pipe to form a "terminal". If you have the tool available, it is best to punch this hole using a sheet metal punch, instead of drilling it. While drilling works, punching the hole helps to bind the wire strands to the terminal a bit better. The main advantage of this style of strap is its flexibility. It puts no stress on the connections and allows movement and vibration without loosening the connections. The flattened pipe terminals have some "spring" and thus keep tension on the contacts even if the bolts are not fully tightened or have loosened slightly over time. I've routinely pushed over 1100 amps through the straps on the bike. I have occasionally pushed up to 1400 amps through them when setting records. These are made with three layers of 3/4" braid. I have never had a problem or a failure with these style straps on the bike. Conversely, I had nothing but troubles with other connection methods. ________________________________________________________________________________
Subject: Re: interior fabric testing
Date: Dec 16, 2003
I believe that most aviation interior shops do this in house as it is a rather simple flame test. Apply flame until the fabric flames, remove flame and flame must auto-extinguish in a certain time frame. You will find the procedure at... APPENDIX F TO PART 23 - TEST PROCEDURE Acceptable test procedure for self-extinguishing materials for showing compliance with 23.853, 23.855 and 23.1359. Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Michael D. Crowe" <tripacer(at)bellsouth.net> Subject: RV-List: interior fabric testing > > All, > > Does anyone know of a shop that can test and certify fabric to be used in > a certified aircraft? > > Mike Crowe > > ________________________________________________________________________________
Date: Dec 16, 2003
> Anyone have a strong opinion on using the IK-2000 vs Rocky Mountain Engine > monitor vs the Grand Rapids EIS? Any other brand I left out? I don't want > to spend $4k+ for engine info so I've been looking at these systems without > a clear winner coming up. I went witht e GRT based on value/features. One thing you need to determine is how involved you want to be in monitoring your engine systems. Steam gauges show you everything at once and require you to scan them on a regular basis to determine if anything is out-of-whack. Large display solid state units let you scan everything at a glace and add the warning feature. I decided early on that I wanted the engine monitor to do the scaning for me and warn me when something is amiss and I wanted to minimize panel space. The GRT 4000 fits the bill. It automatically goes to the appropriate page when something is out of range. The customizable first two pages allow you to pick those items you are most interested in seeing right away. My home page shows rpm/MP, oil temp and pressure, fuel flow, fuel pressure and highest EGT. I have a switch on my Infinity grip that forwards and reverses the pages on the monitor. These two features, customizable pages and stick controlled paging, make the unit extremely efficient to meet my needs. Ross Mickey RV6A N9PT 18 hours and counting ________________________________________________________________________________
Subject: LA GA Airports
Date: Dec 16, 2003
Greetings all: Weather permitting (big if!!), my wife and I are planning to fly my RV-4 to the LA area around Jan 1st. Our final destination will be around the Carson, CA area. A couple days later the plan is to fly down to San Diego for a couple days and then back home via Tucson. Can anyone recommend a GA airport in this local LA area? I have been in to LAX a zillion times, but I don't think it's a real good RV airport!!! Thanks Doug Weiler Hudson, WI ________________________________________________________________________________
Date: Dec 16, 2003
>I took a 2-7/8" piece of 3/8" copper tube I had laying around, put it in my vice, and squeezed the crap out of >it! Came out perfect! 1/2" wide x 2-7/8" long..... .190 thickness (plans call for 2 pieces of .063 so I am a few >thousands over....). I did all my firewall forward and wiring stuff, on my -6A, a few years ago when a F-F kit was probably a gleam in Van's eye. I mounted my master and starter solenoids side-by-side on the on a bracket just above the battery box. I too, decided to connect the master to starter solenoids using a copper strap wide enough to be able to be drilled to fit the solenoid's contact studs. I took a piece of 1/2" copper water pipe, sawed it down the center on my band-saw, pounded the two pieces flat and after edge clean-up put them together and shaped them into a semi-circle to fit to the solenoid's studs. Prior to final installation, I fitted two layers of shrink-tubing on the straps. Makes an easy installation and has more copper cross-section than a #2 wire. You all, may be interested in an event that happened on my 1972 Mercury station wagon: I went to start it one day and got no response other than an unusual sounding "click"! Investigation revealed that the starter solenoid (which was mounted on the right-front fender well housing) was not contacting from the battery to the starter. So I took it apart and found that the circular contact disc had come away from the solenoid plunger (broken rivet) and had jammed between the battery terminal and the case of the solenoid. Now, if that had been a metal case instead of plastic, I would have had a hellova fire to contend with! So when I bought Van's solenoids, I was pleased to see that the starter one was plastic cased, (in fact just like my Ford one), BUT-- I was not happy to see the Master solenoid was all metal! Thinking what would happen if the same scenario happened on this solenoid as what happened on the Ford one, I mounted it on a piece of fiberglass PC board material and insulating washers on the mounting screws, effectively insulating the case from the airframe.---Just a precaution! BTW, In an early RVator, the late Bill Benedict had a great tip, especially good for acro drivers that pull a lot of positive G's: Mount the starter solenoid upside down, so that the solenoid actuating mass does not get deflected by the +G's to the point it may engage the starter! Not a happy occurrence! (maybe this is covered in the newer kit plans?--Dunno) Cheers!!----Henry Hore ________________________________________________________________________________
Subject: Dec 17.
Date: Dec 16, 2003
Go fly tomorrow! Whether you subscribe to the Wrights being truly the first to fly a powered, controlled flight or not, it was a magical day indeed. Get out and burn some avgas folks. I understand the EAA website will have a "post your flight" log of some sort to note your flight. I'm heading over to Falcon Field (Mesa, Az) to visit my dad and celebrate the day...as well as his birthday! I plan to be RV grinnin' at 0835 local. Here's to you, Orv and Wil. Brian Denk RV8 N94BD Albuquerque, NM Take advantage of our best MSN Dial-up offer of the year six months ________________________________________________________________________________
Date: Dec 16, 2003
Thanks Mickey. I didn't know the page was traversable via grip switch. How difficult is it to tailor the info on each page and the actual pages you wantto see? How does the leaning function actually work in practice? thx, lucky In a message dated 12/16/2003 1:13:31 PM Eastern Standard Time, rmickey(at)ix.netcom.com writes: > Anyone have a strong opinion on using the IK-2000 vs Rocky Mountain Engine > monitor vs the Grand Rapids EIS? Any other brand I left out? I don't want > to spend $4k+ for engine info so I've been looking at these systems without > a clear winner coming up. I went witht e GRT based on value/features. One thing you need to determine is how involved you want to be in monitoring your engine systems. Steam gauges show you everything at once and require you to scan them on a regular basis to determine if anything is out-of-whack. Large display solid state units let you scan everything at a glace and add the warning feature. I decided early on that I wanted the engine monitor to do the scaning for me and warn me when something is amiss and I wanted to minimize panel space. The GRT 4000 fits the bill. It automatically goes to the appropriate page when something is out of range. The customizable first two pages allow you to pick those items you are most interested in seeing right away. My home page shows rpm/MP, oil temp and pressure, fuel flow, fuel pressure and highest EGT. I have a switch on my Infinity grip that forwards and reverses the pages on the monitor. These two features, customizable pages and stick controlled paging, make the unit extremely efficient to meet my needs. Ross Mickey RV6A N9PT 18 hours and counting ________________________________________________________________________________
Date: Dec 16, 2003
Subject: Re: LA GA Airports
Hi Doug, TOA (Zamperini Field, or Torrance, as it used to be called) is very close to Carson, and is GA friendly. It's just South of LAX and you can get in from the East without getting into LAX's class B. It's pretty complex airspace, so a little preplanning and a VFR terminal chart is highly recommended. You might stop at Chino (CNO) for some site seeing at the Planes of Fame museum, if you have the time. I can put you in touch with an RV-8 pilot who flies out of TOA if you want to talk to a local. Feel free to email me personally if you need more info. Laird RV-6 Whiteman (near Burbank) SoCal owens(at)aerovironment.com > >Greetings all: > >Weather permitting (big if!!), my wife and I are planning to fly my RV-4 to >the LA area around Jan 1st. Our final destination will be around the >Carson, CA area. A couple days later the plan is to fly down to San Diego >for a couple days and then back home via Tucson. > >Can anyone recommend a GA airport in this local LA area? I have been in to >LAX a zillion times, but I don't think it's a real good RV airport!!! > >Thanks > >Doug Weiler >Hudson, WI > > ________________________________________________________________________________
Subject: Re: Dec 17.
Date: Dec 16, 2003
> > Go fly tomorrow! Whether you subscribe to the Wrights being truly the first > to fly a powered, controlled flight or not, it was a magical day indeed. > > Get out and burn some avgas folks. I understand the EAA website will have a > "post your flight" log of some sort to note your flight. I'm heading over > to Falcon Field (Mesa, Az) to visit my dad and celebrate the day...as well > as his birthday! I plan to be RV grinnin' at 0835 local. > > Here's to you, Orv and Wil. > > Brian Denk > RV8 N94BD > Albuquerque, NM Great suggestion Brian. I'll be holding down the right seat of a NWA 757 from Portland to Minneapolis at the appointed hour tomorrow instead of celebrating in my -4. But I'll toast their memory and the future of aviation with an extra bag of pretzels. Doug Weiler Hudson, WI ________________________________________________________________________________
Date: Dec 16, 2003
I would suggest Fullerton Airport. It's close to Disneyland and Knots, and pretty easy to get in and out of and they love GA (especially RV's!). http://www.ci.fullerton.ca.us/airport/ Ron. -----Original Message----- From: Doug Weiler [mailto:dougweil(at)pressenter.com] Subject: RV-List: LA GA Airports Greetings all: Weather permitting (big if!!), my wife and I are planning to fly my RV-4 to the LA area around Jan 1st. Our final destination will be around the Carson, CA area. A couple days later the plan is to fly down to San Diego for a couple days and then back home via Tucson. Can anyone recommend a GA airport in this local LA area? I have been in to LAX a zillion times, but I don't think it's a real good RV airport!!! Thanks Doug Weiler Hudson, WI ________________________________________________________________________________
Subject: Jon Johanson
Date: Dec 16, 2003
Jon is safely back in Australia. Eustace Bowhay ________________________________________________________________________________
Date: Dec 16, 2003
Subject: Hawaii
Anyone know a good place to rent a cessna on Oahu? Pat Allender RV-4 ________________________________________________________________________________
Date: Dec 16, 2003
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net>
Brian Denk wrote: > > Go fly tomorrow! Whether you subscribe to the Wrights being truly the first > to fly a powered, controlled flight or not, it was a magical day indeed. > > Get out and burn some avgas folks. I understand the EAA website will have a > "post your flight" log of some sort to note your flight. I'm heading over > to Falcon Field (Mesa, Az) to visit my dad and celebrate the day...as well > as his birthday! I plan to be RV grinnin' at 0835 local. > > Here's to you, Orv and Wil. > > Brian Denk > RV8 N94BD > Albuquerque, NM People at 3LF-Litchfield, IL will start festivities in late morning and hopefully carry on into the late evening. An RV-3, Pitt's, Luscombe 8a, Cessna 140, will be out of their hangars and whatever/whoever straggles in.... sure would like to see a Curtiss biplane or a Stearman come over the trees and wave or land. I also say, here's to you Orv and Wil....... Phil in Litchfield, IL ________________________________________________________________________________
Subject: Re: Hawaii
Date: Dec 16, 2003
Hi Pat, I rented Moore Air's Cardinal a couple of years ago: http://www.mooreair.com/ You can check the planes and their schedule using Schedule Master before you go. They were nice folks to deal with and I got a nice "tour" on my checkout with lots of sights pointed out. Busy airport, I was delayed getting back down one time with an F-15 emergency landing blocking the runway... he pulled about a mile of arresting cable down the runway with him. Safe landing though. (the F-18 :-) I really recommend renting a plane while you are there. Flying around gives you a great view of the whole island. Watch those trade winds and remember that you are in IFR conditions on a severe clear day if you go between the islands. Have fun! Dave Burton RV6, wings ________________________________________________________________________________
Date: Dec 16, 2003
Subject: Re: Hawaii
In a message dated 12/16/03 4:12:34 PM Pacific Standard Time, dburton(at)nwlink.com writes: << remember that you are in IFR conditions on a severe clear day if you go between the islands. >> I'm a low timer, please explain the above. Harry Crosby Pleasanton, California RV-6, firewall forward ________________________________________________________________________________
Date: Dec 16, 2003
Subject: Re: Jon Johanson
Thanks Eustace; I had been watching for more news about Jon's return. Bob Olds A&P , EAA Tech. Counselor RV-4 , N1191X , Flying Now Charleston, Arkansas "Real Aviators Fly Taildraggers" ________________________________________________________________________________
Date: Dec 16, 2003
Subject: Re: Insurance Questions
I got a quote from the EAA insurance out fit and then found Avemco got me the same liability for about half the premium for my RV-4. No hull coverage. Bob Olds A&P , EAA Tech. Counselor RV-4 , N1191X , Flying Now Charleston, Arkansas "Real Aviators Fly Taildraggers" ________________________________________________________________________________
Subject: Re: Hawaii
Date: Dec 16, 2003
Hi Harry, The distance between some of the islands is great enough that you are completely out of sight of land. The air is filled with salt and humidity and the sea just fades into the sky. You can't tell up from down, even if it's a clear day. Weird feeling! Beautiful though. Dave Burton Hawaiian Native I don't tan now, I rust... (Seattle) ----- Original Message ----- From: <HCRV6(at)aol.com> Subject: Re: RV-List: Hawaii > > In a message dated 12/16/03 4:12:34 PM Pacific Standard Time, > dburton(at)nwlink.com writes: > > << remember that you are in IFR conditions on a severe clear day if you go > between the islands. >> > > I'm a low timer, please explain the above. > > Harry Crosby > Pleasanton, California > RV-6, firewall forward > > ________________________________________________________________________________
Date: Dec 16, 2003
Excuse the shameless promotion, but its worth checking out the EM2 engine monitor which is finally in production. It's about 1/4th the cost of the $4k systems and has the same (or more) functionality. I agree with the comments made by others about the importance of keeping the really important engine info visible when viewing alternate pages. I went with a 4 line display so that all the main parameters could stay in place on the top & bottom lines all the time. You can check it out at www.rotaryaviation.com The water cooled (rotary engine) version is shown but a Lycoming version is also available. Tracy Crook In a message dated 12/16/2003 1:13:31 PM Eastern Standard Time, rmickey(at)ix.netcom.com writes: > Anyone have a strong opinion on using the IK-2000 vs Rocky Mountain Engine > monitor vs the Grand Rapids EIS? Any other brand I left out? I don't want > to spend $4k+ for engine info so I've been looking at these systems without > a clear winner coming up. ________________________________________________________________________________
Subject: To Cork or not to Cork?
Date: Dec 16, 2003
I am ready to secure the plates in the root rib and need to get some feedback on whether to use the cork gaskets or not. The archives were not friendly on this search. Any thoughts? Darwin N. Barrie Chandler AZ ________________________________________________________________________________
Date: Dec 16, 2003
----- Original Message ----- From: "Boyd Braem" <bcbraem(at)comcast.net> Subject: Re: RV-List: Dec 17. > > Keith-- > > Who was the veteran test pilot that did an aileron-roll over Seattle > when they rolled out the -747? I believe he was fired and then hired > back the next day > Tex Johnston. Boeing Dash 80. Quite a bit before the 747. My old buddy Ned Wilson had the cockpit photo on his den wall. Larry Pardue Carlsbad, NM http://n5lp.net ________________________________________________________________________________
Date: Dec 16, 2003
Subject: Re: To Cork or not to Cork?
> > I am ready to secure the plates in the root rib and need to get some > feedback on whether to use the cork gaskets or not. The archives were > not friendly on this search. > I used the cork with liberal but not excessive amounts of proseal on both sides of the cork plus a filet of proseal around the plates and the socket screws I used to secure the plates. Before prosealing around the screws, I stubbed out a ground wire for the fuel quantity sender - historically most fuel gage problems have been with the ground. Two years with no leaks and no ground prob. Dan Krueger RV6A N926DK Flying ________________________________________________________________________________
Date: Dec 17, 2003
The Discovery Wings channel shows video of the Dash 80 during that manuver. It is one of their Historical moments and they show it quite frequently. Usually show one or the other at the end of each session. Very impressive! Paul LeDoux RV8-QB ________________________________________________________________________________
Date: Dec 17, 2003
Eustace, Thanks for the update. Chuck >From: "Eustace Bowhay" <ebowhay(at)jetstream.net> >Reply-To: rv-list(at)matronics.com >To: "rv list" >Subject: RV-List: Jon Johanson >Date: Tue, 16 Dec 2003 12:46:02 -0800 > > >Jon is safely back in Australia. > >Eustace Bowhay > > Grab our best dial-up Internet access offer: 6 months @$9.95/month. ________________________________________________________________________________
Date: Dec 17, 2003
Beware the difference between per person (what AVEMCO offers... limits anyone's bodily injury to $100,000) vs what all other companies offer (per passenger.... person's outside the plane who are injured aren't limited to $100,000). Also, beware that AVEMCO sublimits family members of yours to 25% of that sublimit. JT ----- Original Message ----- From: <Oldsfolks(at)aol.com> Subject: RV-List: Re: Insurance Questions I got a quote from the EAA insurance out fit and then found Avemco got me the same liability for about half the premium for my RV-4. No hull coverage. Bob Olds A&P , EAA Tech. Counselor RV-4 , N1191X , Flying Now Charleston, Arkansas "Real Aviators Fly Taildraggers" ________________________________________________________________________________
Date: Dec 17, 2003
I agree - the GRT EIS 4000 is a great value, takes up very little panel space (mine is at the bottom of the radio stack), alarms limits can be set on about any input, and support is great! The display is very visible in any light and the character size is large enough for my old eyes to read easily, I use mine like an educated idiot light. I don't have to scan any engine instruments - the EIS lets me know if anything is out of limits. After 110 hours of flying with it, I haven't found ANYTHING I don't like about it. It is easily customizable, alarms are easily set, and it has an RS232 output for recording engine data to a laptop. I just used it to do the GAMI fuel injector balance test. It worked perfectly. The engine leaning functions are described at http://hometown.aol.com/enginfosys/leanpage.htm . The digital leaning page are easier to read and understand than the fancy bar graphs IMHO. I had planned on the VM-1000 but glad I didn't pay the additional bucks and take up the additional limited panel space. My understanding is he VM has very limited to non existent user customizing available. What see you get is what you get. Ronnie Brown From: RV8ter(at)aol.com Subject: Re: RV-List: IK-2000 vs RMI vs GR EIS vs ? Thanks Mickey. I didn't know the page was traversable via grip switch. How difficult is it to tailor the info on each page and the actual pages you wantto see? How does the leaning function actually work in practice? thx, lucky In a message dated 12/16/2003 1:13:31 PM Eastern Standard Time, rmickey(at)ix.netcom.com writes: > Anyone have a strong opinion on using the IK-2000 vs Rocky Mountain Engine > monitor vs the Grand Rapids EIS? Any other brand I left out? I don't want > to spend $4k+ for engine info so I've been looking at these systems without > a clear winner coming up. I went witht e GRT based on value/features. One thing you need to determine is how involved you want to be in monitoring your engine systems. Steam gauges show you everything at once and require you to scan them on a regular basis to determine if anything is out-of-whack. Large display solid state units let you scan everything at a glace and add the warning feature. I decided early on that I wanted the engine monitor to do the scaning for me and warn me when something is amiss and I wanted to minimize panel space. The GRT 4000 fits the bill. It automatically goes to the appropriate page when something is out of range. The customizable first two pages allow you to pick those items you are most interested in seeing right away. My home page shows rpm/MP, oil temp and pressure, fuel flow, fuel pressure and highest EGT. I have a switch on my Infinity grip that forwards and reverses the pages on the monitor. These two features, customizable pages and stick controlled paging, make the unit extremely efficient to meet my needs. Ross Mickey RV6A N9PT 18 hours and counting ________________________________________________________________________________
From: "Aircraft Technical Book Company" <winterland(at)rkymtnhi.com>
Date: Dec 14, 2003
I've yet to use a cork gasket that didn't eventually leak. Forget the cork. Just pro-seal the access plates onto the tank using a few sealing rivets or platenuts to cinch it down. If you ever need to remove the cover plates, just take a small propane torch and lightly heat the pro-seal. The plate will come right off. Andy Builder's Bookstore www.buildersbooks.com ________________________________________________________________________________
Date: Dec 17, 2003
From: Charlie Kuss <chaskuss(at)bellsouth.net> to Cork?
Subject: Re: Fuel tank access cover sealing was To Cork or not
to Cork? Darwin, I used the cork gaskets without any sealer on my fuel tank access plates. I have no leaks. I've even removed and reused the cork gaskets several times with out leakage. HOWEVER, I built my tanks using NAS1473-A08 fuel tank nutplates (available at Wicks Aircraft). http://www.wicksaircraft.com/gotopage.php?page=88 If you use the standard K1000 nutplates supplied by Vans, you should consider either applying a sealer to the gasket, using ProSeal to replace the gasket, or obtaining a set of #8 self sealing screws. These screws have a sealing O-ring under the head of the screw. They are available from McMaster-Carr. You will need: 8-32 x 1/2" Part # 90825A816 If you prefer to use a 3/4" long unit they are Part # 90825A819 http://www.mcmaster.com/ Please note that if you decide to use these screws, they come with silicone rubber o-rings. You will need to request a change to Viton rubber o-rings. The silicone rubber does not hold up to gasoline. Ask them to substitute Viton O-rings for the Silicone ones or simply purchase a bag of the appropriate size Viton O-rings (they sell them as well) Charlie Kuss RV-8A instrument panel Boca Raton, Fl. PS I changed the subject line to make archive searching easier. > >I am ready to secure the plates in the root rib and need to get some feedback on whether to use the cork gaskets or not. The archives were not friendly on this search. > >Any thoughts? > >Darwin N. Barrie >Chandler AZ > > ________________________________________________________________________________
Date: Dec 17, 2003
Subject: pouring rain at Kitty Hawk
Just turned on C-Span and it is pouring down rain at Kitty Hawk :-( Bush is speaking and they haven't said yet what the plans are for the flight. Steve Eberhart ________________________________________________________________________________
Subject: Re: pouring rain at Kitty Hawk
From: "Jamie D. Painter" <rvbuilder(at)earthlink.net>
Date: Dec 17, 2003
For those of us stuck in the office today, you can watch the activities on-line at c-span.org. On Wed, 2003-12-17 at 09:49, Steven Eberhart wrote: > > Just turned on C-Span and it is pouring down rain at Kitty Hawk :-( > Bush is speaking and they haven't said yet what the plans are for the > flight. > > Steve Eberhart > > > > > > ________________________________________________________________________________
Date: Dec 17, 2003
Date: Dec 17, 2003
"just take a small propane torch" If your going to do that PLEASE MAKE SURE THE TANK IS DEAD such as steamed out or blown down with air till the tank is vapor free Just a thought has anyone machined the access cover for O-ring's? Lee Anoka MN RV-3 wing ________________________________________________________________________________
Subject: Vacuum shut off valve mcmaster carr
Date: Dec 17, 2003
> > Help, recently someone posted a McMaster-Carr valve to use as > a vacuum shut off for aerobatics. Does anyone have the part > number handy. I couldnt find it in the archives. > > Jeff Dowling > 1.5 hours 6a > Jeff, go to http://www.usfamily.net/web/alexpeterson/misc.htm Alex Peterson Maple Grove, MN RV6-A N66AP 424 hours www.usfamily.net/web/alexpeterson ________________________________________________________________________________
Subject: The Wright Stuff
Date: Dec 17, 2003
Following the history of the Wright brothers and the methods of discovery and of trial and error they undertook to accomplish what they did 100 years ago today makes me proud and amazed. It probably should never have happened. But it did. It is their gift to us flyers, now a century later, putting together our own flying machines and breaking the bonds that held man to earth for tens of thousands of years before the first flight. If that doesn't inspire you to get back out into your garage/hanger and get to work, you just ain't paying attention. The wind is blowing here today but you can bet I am going to celebrate this amazing century of flight with a flight of my own. It is a great honor and privilege to be able to just walk out to the airplane and go flying. The wonderful machine Van gave us, the talent I had to put it together, the skill I was taught to fly it, the country we have to fly in....lots to be thankful for. Way to go, Orville and Wilber. Thanks. Michael RV-4 232 Suzie Q Tuned in to CNN, waiting. Doesn't look good for weather today ________________________________________________________________________________
Date: Dec 17, 2003
They are going to try again at 2:00 pm eastern time. ----- Original Message ----- From: "Steven Eberhart" <newtech(at)newtech.com> Subject: RV-List: pouring rain at Kitty Hawk > > Just turned on C-Span and it is pouring down rain at Kitty Hawk :-( > Bush is speaking and they haven't said yet what the plans are for the > flight. > > Steve Eberhart > > ________________________________________________________________________________
Date: Dec 17, 2003
I'm on CSpan.org, but i'm getting a call in open forum. No Kitty Hawk coverage. Paul Besing ----- Original Message ----- From: "Jamie D. Painter" <rvbuilder(at)earthlink.net> Subject: Re: RV-List: pouring rain at Kitty Hawk > > For those of us stuck in the office today, you can watch the activities > on-line at c-span.org. > > On Wed, 2003-12-17 at 09:49, Steven Eberhart wrote: > > > > Just turned on C-Span and it is pouring down rain at Kitty Hawk :-( > > Bush is speaking and they haven't said yet what the plans are for the > > flight. > > > > Steve Eberhart > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 17, 2003
Yeah, they were doing live video feeds from Kitty Hawk but cut away after the flight was scrubbed. They said they'll be back to the NC feed at 2:00 p.m. I'm going to try to find some more feeds. On Wed, 2003-12-17 at 11:05, Paul Besing wrote: > > I'm on CSpan.org, but i'm getting a call in open forum. No Kitty Hawk > coverage. > > Paul Besing > > ----- Original Message ----- > From: "Jamie D. Painter" <rvbuilder(at)earthlink.net> > To: > Subject: Re: RV-List: pouring rain at Kitty Hawk > > > > > > > For those of us stuck in the office today, you can watch the activities > > on-line at c-span.org. > > > > On Wed, 2003-12-17 at 09:49, Steven Eberhart wrote: > > > > > > Just turned on C-Span and it is pouring down rain at Kitty Hawk :-( > > > Bush is speaking and they haven't said yet what the plans are for the > > > flight. > > > > > > Steve Eberhart > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 17, 2003
Subject: Re: The Wright Stuff
I wish the Wright followers well. It's a lot of fun. Also read, http://www.deepsky.com/~firstflight/ Hal Rozema theplanefolks.net Kosta Lewis wrote: > > Following the history of the Wright brothers and the methods of > discovery and of trial and error they undertook to accomplish what they > did 100 years ago today makes me proud and amazed. It probably should > never have happened. But it did. It is their gift to us flyers, now a > century later, putting together our own flying machines and breaking the > bonds that held man to earth for tens of thousands of years before the > first flight. If that doesn't inspire you to get back out into your > garage/hanger and get to work, you just ain't paying attention. > > The wind is blowing here today but you can bet I am going to celebrate > this amazing century of flight with a flight of my own. It is a great > honor and privilege to be able to just walk out to the airplane and go > flying. The wonderful machine Van gave us, the talent I had to put it > together, the skill I was taught to fly it, the country we have to fly > in....lots to be thankful for. > > Way to go, Orville and Wilber. Thanks. > > Michael > RV-4 232 Suzie Q > > Tuned in to CNN, waiting. Doesn't look good for weather today > ________________________________________________________________________________
Subject: vortex generators
From: glenn.williams(at)businessacft.bombardier.com
Date: Dec 17, 2003
12/17/2003 12:27:20 PM I need to be educated. I do not see how vortex generators cancel out adverse yaw. I understand how the generators keep the airflow attached in slow flight and lower stall speed. I do not however see that they make the tail "bigger". Is it possible that the v shape induces a stability augmentation over the wings to aid in this? i.e. making the wings track straighter due to the v shape glued on the wings and assisting in the adverse yaw problem? thanks Glenn Williams ________________________________________________________________________________
From: Mark Antenbring <mantenbring(at)pangaeainc.com>
Subject: RV7 Electric elevator trim
Date: Dec 17, 2003
So far the empennage instructions provide a lot of detail and hand-holding, but when I get to the electric elevator trim, it's a big mystery. I've had to make a lot of assumptions in that area so far. The next assumption I have to make is that I have to cut the threaded bolt (trim push rod) to a proper length, unless I want the trim tab sticking up full time. That would cause some forward stick pressure eh? Has any one got an accurate method to cut this push rod to length? Is a hacksaw ok to use on this rod? ________________________________________________________________________________
Subject: Re: RV7 Electric elevator trim
Date: Dec 17, 2003
I used the Gretz relocation kit for my 6A. I might suggest that it eliminates a lot of the issues that I had with both the manual and stock electric trim systems. my .02... Ralph Capen ----- Original Message ----- From: "Mark Antenbring" <mantenbring(at)pangaeainc.com> Subject: RV-List: RV7 Electric elevator trim > > So far the empennage instructions provide a lot of detail and hand-holding, > but when I get to the electric elevator trim, it's a big mystery. I've had > to make a lot of assumptions in that area so far. The next assumption I have > to make is that I have to cut the threaded bolt (trim push rod) to a proper > length, unless I want the trim tab sticking up full time. That would cause > some forward stick pressure eh? Has any one got an accurate method to cut > this push rod to length? Is a hacksaw ok to use on this rod? > > ________________________________________________________________________________
Subject: Re: vortex generators
Date: Dec 17, 2003
I have no idea why it SEEMS to make some difference in yaw reduction. The whole thing is a subjective feeling. The only rough and ready 'test' I could concieve of is to have to fairly identical RV's fly together in the same conditions and see what difference there is. Unfortunately it isn't practical to fly the single plane with the vortex generators and then without in the same conditions...to awkward and conditions change too fast. Someone else had suggested they noticed a yaw reduction with their vortex generators; I had rather forgoten about it until I was getting kicked around so much today, and it occured to me how the yaw that I used to see just wasn't there. Obviously one flight does not a conclusion make, but there's something going on. John ________________________________________________________________________________
Date: Dec 17, 2003
Subject: Remembrance of 100th anniversary of flight
It's been a reflective sort of day as I've done something most unusual for me-I pinned various aviation pins on my tie and wore them all day.( I normally am 'Mr. Decorum' and avoid tacky when I can. ) I've been shocked at how many folks in the office and out at lunch had no appreciation for the 100th Anniv.celebration nor aviation in general. To them,it might as well have been National John Deer Tractor day or something. But, considering the impact of aviation on our economy,our transportation,our defense,our mobility, and our recreation, it has apparently lost much of its mystique and appeal to this generation. Any ideas about what we can do to help motivate the next generation so they will someday celebrate the 200th anniverary?? Today, my pins represented the facets of aviation I've enjoyed in the 50 + years since I took my first ride in a J-3 all those years ago. Almost no one even noticed the odd tie decorations. No one asked what any of them meant to me. So, I'll share some of their meaning with you,my RV family. One pin represents my first solo at age 16. Another working at the FBO 40-60 hours a week all thru college. Another is my USAF wings earned at age 22 and those wonderful young days on active duty. Oh, to be a young Lt. again with orders to 'go put some time on that airplane' again! You never appreciate what you have until you no longer have it, do you? One pin represented the tumultuous times of airline deregulation and stress at Eastern AIrlines, once the proudest and free world's largest air carrier. Another pin represented the wonderful AF Reserve duties. Caribou's and 130's ! Ground school and flying with the late Charlie Burnett. The Citation pin representing the corporate flying days with their busyness. And the best pin of all, now representing the newest phase of life,where aviation has once again come full circle for me no longer as a 'job', but as fun as I've become part of the RV world. Pure and simple fun! To my pilot father and uncle,to all the instructors, war-story tellers, hanger-flyers,mechanics and lineboys, schedulers,ground school and simulator guys, and airport bums who have put up with me all these years-Thanks! Congratulations on making my 50 years in aviation so wonderful! Vern P.S. I still look up when I hear a plane pass overhead like I did as a toddler. Guess I always will! ________________________________________________________________________________
Date: Dec 17, 2003
Oh, I didn't read Glenn's message too closely...he asked about ADVERSE yaw - well the RV has so little that it is never a consideration...I was speaking of inadvertent yaw caused by flying in turbulence...that's where the difference seemed to come in....turning in a 'spam can' where you need rudder/aileron coordination to handle adverse yaw is something I don't see in my RV. Heavy atmospheric turbulence would normally twist the RV around fairly heavily. John ________________________________________________________________________________
Date: Dec 17, 2003
The RV series (at least the -3, -4, -6) have very little adverse yaw (and the wings on the Super 6 are clipped 7 inches)--in fact, if you were not a perfectionist you could just keep your feet on the floor. Best way to fly with adverse yaw is to fly a glider--swing that tail around. On Wednesday, December 17, 2003, at 05:12 PM, John wrote: > > Oh, I didn't read Glenn's message too closely...he asked about ADVERSE > yaw - > well the RV has so little that it is never a consideration...I was > speaking > of inadvertent yaw caused by flying in turbulence...that's where the > difference seemed to come in....turning in a 'spam can' where you need > rudder/aileron coordination to handle adverse yaw is something I don't > see > in my RV. Heavy atmospheric turbulence would normally twist the RV > around > fairly heavily. > > John > ________________________________________________________________________________
Date: Dec 17, 2003
Subject: Tundra Tires?
I've seen pictures of floats on an RV, but has anyone tried Tundra tires on an RV? (I didn't find anything in the archives.) ________________________________________________________________________________
Date: Dec 17, 2003
Of course I think that www.sterntech.com has the best, but I designed it. Regards, Trampas -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ronnie Brown Subject: Re: RV-List: IK-2000 vs RMI vs GR EIS vs ? I agree - the GRT EIS 4000 is a great value, takes up very little panel space (mine is at the bottom of the radio stack), alarms limits can be set on about any input, and support is great! The display is very visible in any light and the character size is large enough for my old eyes to read easily, I use mine like an educated idiot light. I don't have to scan any engine instruments - the EIS lets me know if anything is out of limits. After 110 hours of flying with it, I haven't found ANYTHING I don't like about it. It is easily customizable, alarms are easily set, and it has an RS232 output for recording engine data to a laptop. I just used it to do the GAMI fuel injector balance test. It worked perfectly. The engine leaning functions are described at http://hometown.aol.com/enginfosys/leanpage.htm . The digital leaning page are easier to read and understand than the fancy bar graphs IMHO. I had planned on the VM-1000 but glad I didn't pay the additional bucks and take up the additional limited panel space. My understanding is he VM has very limited to non existent user customizing available. What see you get is what you get. Ronnie Brown From: RV8ter(at)aol.com Subject: Re: RV-List: IK-2000 vs RMI vs GR EIS vs ? Thanks Mickey. I didn't know the page was traversable via grip switch. How difficult is it to tailor the info on each page and the actual pages you wantto see? How does the leaning function actually work in practice? thx, lucky In a message dated 12/16/2003 1:13:31 PM Eastern Standard Time, rmickey(at)ix.netcom.com writes: > Anyone have a strong opinion on using the IK-2000 vs Rocky Mountain Engine > monitor vs the Grand Rapids EIS? Any other brand I left out? I don't want > to spend $4k+ for engine info so I've been looking at these systems without > a clear winner coming up. I went witht e GRT based on value/features. One thing you need to determine is how involved you want to be in monitoring your engine systems. Steam gauges show you everything at once and require you to scan them on a regular basis to determine if anything is out-of-whack. Large display solid state units let you scan everything at a glace and add the warning feature. I decided early on that I wanted the engine monitor to do the scaning for me and warn me when something is amiss and I wanted to minimize panel space. The GRT 4000 fits the bill. It automatically goes to the appropriate page when something is out of range. The customizable first two pages allow you to pick those items you are most interested in seeing right away. My home page shows rpm/MP, oil temp and pressure, fuel flow, fuel pressure and highest EGT. I have a switch on my Infinity grip that forwards and reverses the pages on the monitor. These two features, customizable pages and stick controlled paging, make the unit extremely efficient to meet my needs. Ross Mickey RV6A N9PT 18 hours and counting ________________________________________________________________________________
Subject: RV-4 Kit for Sale
Date: Dec 17, 2003
Hi RV List Some time back I planned to build a RV-4, purchased the wing and empennage kit. I started building the horizontal stabilizer, then got busy at work and didn't work on it for a couple of years. In 2001 I lost my medical, and after more than 2 years of fighting with the FAA I got it back in October, but only for 6 months. It has become very costly too much trouble to pursue, so I will be applying for the new Sport Pilot license. The bottom line is, I need to sell my RV-4 wing and empennage kit. The wing kit is the standard RV-4 wing and is unopened. The empennage kit is the standard empennage kit with the heavy skins and the only work that has been done is on the horizontal stabilizer. The skins are drilled, not dimpled. I want to sell the wing and empennage kit together and I am asking $4,000 for them. I am located in Fresno, CA. Steve Gandy s.gandy(at)comcast.net Aeronca L-3C N48540 Kitfox 6 N540KF (Building) ________________________________________________________________________________
From: "Randy Compton" <thecomptons(at)bellsouth.net>
Subject: Re: Dec 17th 2003 100 Years / What did you do today to celebrate?
Date: Dec 17, 2003
----- Original Message ----- From: "Don Eaves" <doneaves(at)midsouth.rr.com> Subject: RV-List: Dec 17th 2003 100 Years / What did you do today to celebrate? > What did you do today to celebrate 100 years of powered flight? > > Don Eaves > doneaves(at)midsouth.rr.com > RV 6 Flying 200 + Hrs. Like others on the "List", I flew today...but I had to settle on flying the Cub. The exhaust pipe on my #4 cylinder broke off at the flange at the cylinder head while flying yesterday. What a picture-perfect day here! Severe VFR with 18 knots of post-cold front wind right down the runway. Tower caught on to what I was up to when I hung out in the hold-short for a while before calling for takeoff really were on to me. At 1035 I gave the Cub about half throttle - with the good wind straight on the beak it was in the air VERY quickly - I flew down the runway about 20 feet or so in the air, and after counting 12 seconds I eased it back down and taxied back in. Made for a great logbook entry. So, while I didn't get to fly my RV, I rationalized it away by at least knowing I was flying a plane only a few steps improved over the Flyer. That's what I did today to celebrate 100 years of powered flight...that, and also give thanks to God that this incredible invention has allowed me to earn a pretty darn good living all the while having fun doing it! Randy Compton RV-3 N148CW Gulf Breeze, FL ________________________________________________________________________________
Subject: 100 years
Date: Dec 17, 2003
Well, today was a great day to celebrate 100 years of powered flight by flying around Southern California. I did have one incident though. At about 40 kts taking off from Big Bear the canpoy latch popped open. It didn't unlatch but the overcenter was un-overcentered. The interesting thing was that it made loud pop noise, then things got abnormally windy. I saw the handle and went to reclose it, but the plane was still taking off, so I readjusted my priorities and aborted the take-off as I really have no idea, nor any interest in finding out what it would do if I didn't get it re-latched tight. I apparently didn't get the handle twisted all the way over center when closing it, because I could find nothing wrong with it, and it worked fine for the rest of the day. It is nice to know that it will talk to you right about the time you are thinking about pulling back on the stick. W ________________________________________________________________________________
Date: Dec 17, 2003
I jacked around with this thing for a couple of hours myself trying to figure out full up then full down trim and the correct size to cut the rod. I ultimately moved on but it's on my TO DO list of things I need to come back and wrap up. Please share any info you get. Karie Daniel RV-7A Sammamish, WA (jacking around with the wings now) :-) ----- Original Message ----- From: "Mark Antenbring" <mantenbring(at)pangaeainc.com> Subject: RV-List: RV7 Electric elevator trim > > So far the empennage instructions provide a lot of detail and hand-holding, > but when I get to the electric elevator trim, it's a big mystery. I've had > to make a lot of assumptions in that area so far. The next assumption I have > to make is that I have to cut the threaded bolt (trim push rod) to a proper > length, unless I want the trim tab sticking up full time. That would cause > some forward stick pressure eh? Has any one got an accurate method to cut > this push rod to length? Is a hacksaw ok to use on this rod? > > ________________________________________________________________________________
Date: Dec 17, 2003
Subject: [ Jim Jewell ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Jim Jewell Subject: Homemade Baffle Pass Through Fitting http://www.matronics.com/photoshare/jjewell@telus.net.12.17.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Dec 17, 2003
----- Original Message ----- From: <RV8ter(at)aol.com> > How difficult is it to tailor the info on each page and the actual pages you > want to see? Not difficult. Greg provides a worksheet that makes it easy to lay out what you want and input into the unit. > How does the leaning function actually work in practice? Very well. I can either monitor the actual temp of the hottest cylinder that is displayed on my home page or I can go to the leaning page. On the first, you have to see what the peak temp is then enrichen till you are 50-100 from peak. On the leaning page, the actual temperature changes to degrees from peak once the cylinder reaches peak. Makes it a bit easier. The unit has other functions to help when you change altitudes and peak may change. I don't use the bar graph function. Ross ________________________________________________________________________________
Subject: What did you do today to celebrate?
Date: Dec 17, 2003
I celebrated the 100 years by giving flight instruction as I do most days. Two flights in Cessnas, one in an Archer. The local Boise NBC affiliate came down and interviewed me for my thoughts on aviation and the new licenses. They asked me if the new format would in any way discourage terrorists. I told them that you don't need any piece of paper (or plastic) to buy and fly an aircraft. Fortunately that was edited out, some people might take it wrong. It was hard to put into words just what flying means to me without getting choked up a little and looking like a dork. Oh well. I get to fly around all day in little airplanes. Even after 3 years of full time instructing, it's still a thrill to fling a little airplane around the sky, and especially to share the joy of someone elses first flight, first solo, and checkride. Cammie Patch RV7a ailerons ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Redimple The Skin?
Speaking of the DRDT-1, have any of you guys had any experience with it? I'm putting my shop tools together, and I'm considering one of these tools instead of a C-frame. Any comments or input? Thanks! > >This thread makes me really excited about my DRDT-1 frame that's on the back >of a Fed Ex truck headed my way ( http://www.experimentalaero.com/ )! > >I've done most of my emp using the standard Avery frame. While it wasn't >mounted I did have really straight skins and fairly consistent results - >mostly my arms just wore out :o) > >Hence the new dimpling frame. --- ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Re: Remembrance of 100th anniversary of flight
>... >I've been shocked at how many folks in the office and out at lunch had no appreciation for the 100th Anniv.celebration nor aviation in general. To them,it might as well have been National John Deer Tractor day or something. > >But, considering the impact of aviation on our economy,our transportation,our defense,our mobility, and our recreation, it has apparently lost much of its mystique and appeal to this generation. > >Any ideas about what we can do to help motivate the next generation so they will someday celebrate the 200th anniverary?? Hi Vern, Actually, this is nothing more than a sign of the incredible success that aviation enjoys. Those of us in the software world strive to make systems that the users don't even know or care are there. We have not gotten there yet, but we've only been at it for 60 years or so, not 100! I celebrated the 100th with a nice flight in our club Cherokee over the Jura mountains here in western Switzerland. Plenty of snow and cross country skiers to look at, bright sunshine, and totally smooth air. Looking forward to a little night VFR this evening! -- Mickey Coggins GSM: +41-79-210-3762 FAX: +41-86-079-210-3762 http://www.rv8.ch/ #82007 Empennage complete, waiting for wings to arrive ________________________________________________________________________________
Date: Dec 18, 2003
Thanks to all of you guys that responded to my query. I thought that there would be a definitive answer to my question, but alas that was not to be. This could easily become the next "primer war" as there were evenly split sides as to the structural integriy of a countersunk .032 skin. :-) I just wanted to relay what I've learned from this. - Whatever hammer you use, wear hearing protection. It may sound odd, but I found I was hitting the dimpler softer when I didn't wear protection - I guess subconsciously I was not liking the loud bang. - I bought a dead blow plastic hammer (28oz). This solves the noise problem, you still have to make sure your dimple is sharp (well formed) though! - Van's said that there "shouldn't be any problem structurally" with the partially dimpled/finished with a deburring tool holes. I drilled out the rivets that stood a little too proud and re-did them so that I didn't have to shave them, the rest I left as they were. - I used the Avery pop rivet dimpling tool to improve the dimples on the ones that I could. - The second skin will be completely redimpled and re-primed. Lesson learned. Phil ________________________________________________________________________________
Subject: Avery "flat" rivet set problem
Date: Dec 18, 2003
I was having the WORST time with getting the shop head of my squeezed rivets to not cleat as I squeezed them. I ended up using a gun on quite a few rivets that should have been done with my rather expensive squeezer. I finally called Avery and had a discussion with them about it. It turns out that they had a run of flat sets that the guy who was doing the finish polishing got a little aggressive about his duty. The set, instead of being flat had a significant crown to it - thus if you didn't get the rivet PERFECTLY in the center it would run down the hill on the set. Let's just say that I am damn good at drilling out rivets at this point in my RV career! If you are having trouble that may sound like this, take the flat set out of your squeezer, hold it up to the light and put the edge of a steel scale on it. You will see a really bad crown to the set, instead of it being flat. Three days after my call, I had a brand new set - problem solved. Phil ________________________________________________________________________________
Subject: Slider unlatched in flight
Date: Dec 18, 2003
The other day I took off with my RV-6A canopy unlatched despite using the check-list. Dumb, but it happened. The canopy was closed but not latched. It took a few seconds to translate the cold air (New York State) draftiness to the problem. Short strip; too late to cancel the takeoff. I immediately attempted to close the canopy as second priority to flying the airplane at all costs. I had a lot of concern that the canopy would tend to slide rearward and create more problems. Once at altitude I attempted to slow the aircraft sufficient to relieve pressure and close the canopy, to no avail. I continued in the pattern and landed, only releasing a hold on the canopy handle when over the threshold. No damage other than my pride. Doubt if it will happen again (once is enough!), but figured other builder/flyers would appreciate the input. I cannot say enough positive about the aircraft under these circumstances; flew beautifully, the main challenge being flying with the right hand holding the canopy latch handle. I felt no tendancy for the canopy to move rearward, despite my concern that it would. Hope this helps! Larry Greeno N446A #24495 ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Re: Slider unlatched in flight
GreenoL wrote: > >The other day I took off with my RV-6A canopy unlatched despite using the check-list. Dumb, but it happened. The canopy was closed but not latched. It took a few seconds to translate the cold air (New York State) draftiness to the problem. Short strip; too late to cancel the takeoff. I immediately attempted to close the canopy as second priority to flying the airplane at all costs. I had a lot of concern that the canopy would tend to slide rearward and create more problems. Once at altitude I attempted to slow the aircraft sufficient to relieve pressure and close the canopy, to no avail. I continued in the pattern and landed, only releasing a hold on the canopy handle when over the threshold. No damage other than my pride. Doubt if it will happen again (once is enough!), but figured other builder/flyers would appreciate the input. I cannot say enough positive about the aircraft under these circumstances; flew beautifully, the main challenge being flying with the r! >ight hand holding the canopy latch handle. I felt no tendancy for the canopy to move rearward, despite my concern that it would. Hope this helps! > >Larry Greeno >N446A #24495 > ============================================== FWIW.... In flight pressure forces my RV-3 slider canopy nearly CLOSED. Cannot open it more than an inch or two in flight. Perhaps you have a similar condition or situation? Bob ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Headsets
vansairforce Just an opinion... I had the opportunity to fly with a friend of mine yesterday and wear one of the new Lightspeed 3G headsets... I'm sorry to say that I didn't like them at all... The weren't that comfortable and the noise canceling was disappointing... The aircraft was a BD4 with a 180 C/S, It's a pretty loud aircraft, and the noise canceling DID work, but it was still very loud... I have a set of LS QFR Cross Country's and LOVE them! I should have taken a set in the plane to compare, but didn't think about it... I have had other LS head sets as well, and still don't think anything compares to the Cross Country's. I think I am going to upgrade mine to the new CC2's pretty soon... my plane is so quiet to me that I don't eve think about it, and have had many comments from pax about how quiet it is... For the money you cant beat them! Lightspeed G3: $460 Lightspeed CC2: $275 -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Date: Dec 18, 2003
From: "David E. Nelson" <david.nelson(at)pobox.com>
celebrate? Myself and another flying buddy took a day off from work and rented two Pipers from Gergetown, TX (KGTU) and flew over to Burnet, TX (KBMQ) to visit the flying museum and make a donation. Great day to fly!! /\/elson Austin, TX RV-7A - Emp Don Eaves wrote: > What did you do today to celebrate 100 years of powered flight? -- ~~ ** ~~ If you didn't learn anything when you broke it the 1st ~~ ** ~~ time, then break it again. ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Re: Dec 17th 2003 100 Years / What did you do today tocelebrate?
> What did you do today to celebrate 100 years of powered flight? Took the day off work to celebrate. Got to the airport at 8am. First task was to scrape a couple of inches of snow from in front of the hangar. Decided the wheel pants needed to come off (another 'snow' thing). ceiling was 1200. So switched to Plan B & timed our departure so that we lifted off at exactly 9:35. Flew a friend, Bruce, 110 miles northwest to Wausau to pick up the Cessna Cardinal he had been forced to leave there at the weekend. Stayed VFR at 1000-1500 AGL - it's a good job Wisconsin is flat! Minimal braking effect on ice at Wausau. The taildraggers were having a tough time taxiing, but no problem for the 6A. Tops were reported at 3500-4500 with mixed reports of ice & no ice. Decided to return IFR. After a couple of minutes in the clouds, broke out on top with a clear blue sky & bright sunshine. Tailwind enabled 180 Kts ground speed at 65% power at 7000 ft. Not bad without wheel pants. It doesn't get much better. Both Minneapolis & Chicago Centers were particularly jovial. Vectored into the clouds for the VOR 13 approach at West Bend & picked up a trace of ice - maybe 1/8" on the leading edges. Broke out at 1200 AGL, circled to land 31. By the time Bruce landed, the coffee was brewed. Our final task was to hang the 1/6 scale Wright Flyer model in our Chapter building. A group of us put in more than 500 hrs constructing this model earlier in the year. It's been on display, but we wanted to hang it on the centennial anniversary. We've come long way in 100 years. Chris Good, http://rv.supermatrix.com West Bend, WI RV-6A N86CG, 640 hrs in 3.5 yrs Free Poetry Contest. Win $10,000. Submit your poem @ Poetry.com! http://ad.doubleclick.net/clk;6750922;3807821;l?http://www.poetry.com/contest/contest.asp?Suite=A59101 ________________________________________________________________________________
Date: Dec 18, 2003
I had a similar experience with the "Tilt Up" canopy. Shortly after lift-off there was a pop followed by a tremendous increase in noise level - seat cushion severely distored. Quickly recognized what the problem was at approx 110 MPH on climbout. Recalling the many admonizments to "fly the aircraft" as first priority, I slowed to 85 MPH but continued to 3000 MSL. There at around 75 mph, I attempted to pull the canopy shut (it was open approx 3-4" at the roll bar end), even putting my full weight on the canopy handle I could not quite get it down far enough for the Latch to engage. Recalling a similar reported incident, I pull full flaps and sure enough it releived sufficent pressure for me to get the canopy down and latched. Lesson is the RV-6A will fly quite fine with the canopy open despite the increased noise level. So as many before have stated, don't worry about the canopy until you are at a safe altitude to worry about it or simply come back around and land. I think if you keep the airspeed under 100 MPH and keep a little increased pad for approach and landing speeds in case the air distrubance does affect flow over the tail surfaces and you should be just fine. Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ----- Original Message ----- ________________________________________________________________________________
Date: Dec 18, 2003
Very interesting. Every VG kit I've been able to find just supplies wing VGs. How does the increased elevator authority affect trim sensitivity during landing? Any increase in elevator authority during cruise? Did you use a kit or roll your own? Do you also have vertical stab VGs? Thanks <blanton(at)alaska.net> VG's on both sides of the VS may affect yaw qualities ... they may create an effect like a "virtually" larger VS. I know the VG's on the underside of my HS dramatically increased elevator authority as if the HS and elevator were larger. B. Matthew M. Jurotich NASA/Goddard Space Flight Center Swales contractor to the JWST ISIM Systems Engineer m/c : 443 e-mail mail to: phone : 301-286-5919 fax : 301-286-1736 JWST URL: <http://ngst1.gsfc.nasa.gov ________________________________________________________________________________
Subject: Futher Reflections
Date: Dec 18, 2003
I just wanted to add a few more reflections on my thoughts while my canopy was flapping open in the breeze. My first instinct when it happened was there is a problem, indentify it and fix it. I immediately saw the canopy latch was repositioned so I went to relatch it, and it hit me that now was not the time to be fully diagnosing the problem when I still had the option to not fly. Since not flying was the more conservative choice I redjusted my focus and aborted, while notifying the guy behind me of the change in plans. This goes back to the discussion of why we make choices. I often make choices without really considering the criteria of why I made the choice. This is normal and is often called an autonoimic decision. It saves huge amounts of time. But in aviation one really must have a criteria for making most of our choices. For me most things are a binary choice, either this or that option. Sometimes there are more options in a given choice, but my criteria is always, which is the most conservative, or safe of the group. And I have found that I always know which is the safest of the options if I take the time to study/think about the criteria. By keeping this simple is was only a short second for me to realize that aborting the take off was the safer option rather then trying to do something else while taking off even though that was contrary to my instincts once I thought I had indentified the problem. Anyways food for thought. W ________________________________________________________________________________
Subject: TruTrak DFC Tray's
Date: Dec 18, 2003
I have been troubleshooting an intermittent problem with my TruTrak DFC250 autopilot. It is the one in the standard avionics tray. In talking with Jim Yonkin, I found out that two years ago they determined that the trays they were using were very slightly to long which could lead to the contacts not fully seating. This is the first I had heard about it and pass it along for any of you with older DFC trays. Ross Mickey N9PT ________________________________________________________________________________
Subject: Re: Dec. 17th 2003 100 years / What did you do today tocelebrate?
Date: Dec 18, 2003
>taidraggers were having a tough time taxiing but the 6a had no problem< I`ve been flying taildraggers in the midwest for 6yrs. and don`t see noserollers having any advantage. What do they fly in Alaska? Taildraggers rule there. Greg Milner RV-4 79KM Waukesha,Wi. UES ________________________________________________________________________________
Date: Dec 18, 2003
When landing a conventionally configured aircraft, especially with the wing flaps extended, a lot of "aft stick" is needed to overcome the nose down pitching moment that slow flight requires plus even more to rotate the nose upwards to flare the aircraft before touchdown. Aft stick means the trailing edge of the elevator moves up so the tail surface becomes a curved, cambered surface producing lift in the downwards sense. (Think of an upside down wing with the flaps extended.) Anything that can be done to improve the lifting characteristics of the tailplane-elevator combination, such as turbulators that will help keep the airflow attached on the underside of the tail, will provide more downward lift which the pilot sees as more "nose up" pitch authority when landing. Turbulators are one method. I recall seeing some aircraft with a reverse slotted horizontal tail leading edge in the past (one of the higher performance Cessna singles possibly) that accomplish the same thing. A British aircraft called the Buccaneer used blowing boundary layer control on the tailplane to get acceptable landing characteristics for aircraft carrier use at the cost of considerable plumbing complexity but it worked. Similar theory would apply to vertical stab turbulators that should provide better lift characteristics to the fin-rudder combination that provide restoring forces to yawing motions and so (perhaps) better yaw stability to the aircraft. Lots more pilot oriented aerodynamics at http://www.av8n.com/how/ Jim Oke Wpg., MB RV-3 RV-6A ----- Original Message ----- From: "Matt Jurotich" <mjurotich(at)hst.nasa.gov> Subject: Re: RV-List: vortex generators > > > Very interesting. Every VG kit I've been able to find just supplies wing > VGs. How does the increased elevator authority affect trim sensitivity > during landing? Any increase in elevator authority during cruise? Did you > use a kit or roll your own? Do you also have vertical stab VGs? > > Thanks > > <blanton(at)alaska.net> > > VG's on both sides of the VS may affect yaw qualities ... they may > create an effect like a "virtually" larger VS. I know the VG's on the > underside of my HS dramatically increased elevator authority as if the > HS and elevator were larger. > > B. > > > Matthew M. Jurotich > > NASA/Goddard Space Flight Center > Swales contractor to the > JWST ISIM Systems Engineer > > m/c : 443 > e-mail mail to: > phone : 301-286-5919 > fax : 301-286-1736 > > > JWST URL: <http://ngst1.gsfc.nasa.gov > > ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Re: Futher Reflections (canopy pops)
I was reading just yesterday but I forgot the acronym already. What I took away from it was a four step routine when problems arise. I think it went like this: Continue to fly the airplane Analyze the situation Take action Land They made the obvious but apparently often overlooked point that it is easier and safer to resolve problems while on the ground. AOPA Pilot I believe. With some strange (erroneous?) pie charts. K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Dec 18, 2003
I too have flown without latching the slider canopy. No problem, flew once for about 10 minutes to get to a better airfield for landing. I could not get the canopy latched in flight, but I wonder, can it be opened in flight for the purpose of bailing out? Using a parachute for acrobatics is of little use, If I can not get the canopy open. Any experiences out there? Bob RV6 NightFighter ________________________________________________________________________________
Date: Dec 18, 2003
From: kempthornes <kempthornes(at)earthlink.net> celebrate?
Subject: Re: The next 100 years? WAS: What did you do today to
celebrate? Hi Chris and all, >We've come long way in 100 years. You are right about that. I flew my Debonair which I seem unable to sell. My Rv6a has no panel as it is getting updated for IFR. As I prepare to order my Dynon EFIS and a Trio autopilot, I wonder just how far will we go in the next 100 years? I suppose it is inevitable - the pilot will be a chip. We will get in, touch in our destination and go. The Plasmatron engine will whisk us along at several times the speed of sound. Today we are free - while some men travel to the moon, others ride horses for the fun of it. I landed just before a beautiful sunset. The Debonair is for sale see it at www.moonrovers.com K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Dec 18, 2003
Subject: more on: Cockpit "Audio out" to videocamera
vansairforce I'm back on this subject... Earlier in the year I bought a HI8 video camera. A Sony TRV318... It's a nice camera, and had all the features I wanted (or thought I wanted), including a good price...but I see that it doesn't have an audio in jack! Can anyone tell me about any cameras that do have this feature? I am probably going to get a new one and then sell mine... Thanks!! -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Subject: Re: Headsets
Date: Dec 18, 2003
Bill, The best deal I have found on these is at Avionicswest.com for $270 and 11.67 shipping. Do you have a better source? Ross Mickey ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> Subject: RV-List: Headsets > > Just an opinion... > > I had the opportunity to fly with a friend of mine yesterday and wear one of the new Lightspeed 3G headsets... I'm sorry to say that I didn't like them at all... The weren't that comfortable and the noise canceling was disappointing... The aircraft was a BD4 with a 180 C/S, It's a pretty loud aircraft, and the noise canceling DID work, but it was still very loud... > > I have a set of LS QFR Cross Country's and LOVE them! I should have taken a set in the plane to compare, but didn't think about it... I have had other LS head sets as well, and still don't think anything compares to the Cross Country's. I think I am going to upgrade mine to the new CC2's pretty soon... my plane is so quiet to me that I don't eve think about it, and have had many comments from pax about how quiet it is... > > For the money you cant beat them! > > Lightspeed G3: $460 > Lightspeed CC2: $275 > > -Bill VonDane > EAA Tech Counselor > RV-8A ~ N8WV ~ Colorado Springs > www.vondane.com > www.creativair.com > www.epanelbuilder.com ________________________________________________________________________________
Date: Dec 18, 2003
It's been awhile since I installed the trim motor and I can't remember exactly how came up with the length of the rod. My rod is 2 1/8" plus the distance on each end that it is screwed in to the clevis. Hope that helps. Steve Nyman RV7QB MEM ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Re: more on: Cockpit "Audio out" to videocamera
> >I'm back on this subject... Earlier in the year I bought a HI8 video >camera. A Sony TRV318... It's a nice camera, and had all the features I >wanted (or thought I wanted), including a good price...but I see that it >doesn't have an audio in jack! > >Can anyone tell me about any cameras that do have this feature? I am >probably going to get a new one and then sell mine... > >Thanks!! Hi Bill, Many of these cameras (don't know specifically about yours) use the same audio and video out jacks for audio and video in during recording. Check the camera manual or their website before going to something different. In fact, almost zero cameras have a separate audio in jack that I've been able to find. Gary Liming ________________________________________________________________________________
Subject: Pitot Tubes
Date: Dec 18, 2003
Working on RV-7 Wings with a Gertz heated pitot tube (one bay outboard tie down) and plan on installing a DigiTrack autopilot (servo gets in way). All this requires running the pitot tubes (static/dynamic) some other way. I am thinking about "pie-panning" (covering up) for lack of a better word, the second lightening holes aft of the spar to hold the snap bushings for the pitot tubes. Anyone done this or have a better suggestion? Thanks. Happy Holidays Don Harker Gurnee ,IL RV-7A Wings ________________________________________________________________________________
Subject: RV-6 / 6a kit for sale
Date: Dec 18, 2003
From: "Kuebler, Scott" <skuebler(at)CANNONDESIGN.COM>
RV-6 / 6a kit for sale. Empennage: Complete except for fiberglass tips. Includes electric elevator trim kit. All parts are alodined and primed with Marhyde primer. Wings & Phlogiston Spar: Both skeletons assembled. All skins drilled to both wings, ready for final riveting. Flaps and ailerons complete, but not fitted. Both tanks are complete and sealed. Includes electric aileron trim kit. All parts are alodined and primed with Deft epoxy primer (Mil-P-23377G). Both kits are the pre-punched versions purchased in 1997 & 1998 by myself. Construction is excellent. Preview plans and Orndorff videos are included for both kits. Price: $4750 If all items were purchased separately the price would be more than $6500 for unassembled kits. The tools are not for sale; I will be keeping them to guarantee that I will build another RV in the near future! Happy Holidays, Scott Kuebler Buffalo, NY 716-695-1987 home 716-510-0318 cell skuebler(at)cannondesign.com ________________________________________________________________________________
Date: Dec 18, 2003
Hi Ross, $269.95 w/ free shipping from: http://www.flightessentials.net/index.asp?PageAction=VIEWPROD&ProdID=548 I just purchased a Lightspeed 20XL2 w/ free shipping from these folks and it showed up three days later in Austin, TX. Regards, /\/elson Austin, TX RV-7A - Emp On Thu, 18 Dec 2003, Ross Mickey wrote: > > Bill, > > The best deal I have found on these is at Avionicswest.com for $270 and > 11.67 shipping. Do you have a better source? > > Ross Mickey > > > ----- Original Message ----- > From: "Bill VonDane" <bill(at)vondane.com> > To: ; ; "vansairforce" > > Subject: RV-List: Headsets > > > > > > Just an opinion... > > > > I had the opportunity to fly with a friend of mine yesterday and wear one > of the new Lightspeed 3G headsets... I'm sorry to say that I didn't like > them at all... The weren't that comfortable and the noise canceling was > disappointing... The aircraft was a BD4 with a 180 C/S, It's a pretty loud > aircraft, and the noise canceling DID work, but it was still very loud... > > > > I have a set of LS QFR Cross Country's and LOVE them! I should have taken > a set in the plane to compare, but didn't think about it... I have had > other LS head sets as well, and still don't think anything compares to the > Cross Country's. I think I am going to upgrade mine to the new CC2's pretty > soon... my plane is so quiet to me that I don't eve think about it, and > have had many comments from pax about how quiet it is... > > > > For the money you cant beat them! > > > > Lightspeed G3: $460 > > Lightspeed CC2: $275 > > > > -Bill VonDane > > EAA Tech Counselor > > RV-8A ~ N8WV ~ Colorado Springs > > www.vondane.com > > www.creativair.com > > www.epanelbuilder.com > > > > > > > -- ~~ ** ~~ If you didn't learn anything when you broke it the 1st ~~ ** ~~ time, then break it again. ________________________________________________________________________________
Subject: Re: Pitot Tubes
Date: Dec 18, 2003
----- Original Message ----- From: "Don Harker" <dpharker(at)worldnet.att.net> > Working on RV-7 Wings with a Gertz heated pitot tube (one bay outboard tie > down) and plan on installing a DigiTrack autopilot (servo gets in way). All > this requires running the pitot tubes (static/dynamic) some other way. I am > thinking about "pie-panning" (covering up) for lack of a better word, the > second lightening holes aft of the spar to hold the snap bushings for the > pitot tubes. Anyone done this or have a better suggestion? > Thanks. Happy Holidays I installed a Piper style P/S just outboard of the access panel and was also able to install the TruTrak servo. The P/S is aft of the servo. I cut a new access panel behind the servo so I could access the D sub connector without removing the servo. Ross Mickey RV6A N9PT ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Re: To Cork or not to Cork?
In a message dated 12/17/03 6:22:15 AM Pacific Standard Time, winterland(at)rkymtnhi.com writes: << If you ever need to remove the cover plates, just take a small propane torch and lightly heat the pro-seal. >> No flame intended, but having witnessed several "empty" fuel tank explosions, this seems pretty high risk to me. Harry Crosby Pleasanton, California RV-6, firewall forward ________________________________________________________________________________
Date: Dec 18, 2003
The TruTrak servo can be mounted in either wing, so that you do not have to worry about it getting in the way. Andrew Barker TruTrak Flight Systems 479-751-0250 www.trutrakap.com ----- Original Message ----- From: "Ross Mickey" <rmickey(at)ix.netcom.com> Subject: Re: RV-List: Pitot Tubes > > > ----- Original Message ----- > From: "Don Harker" <dpharker(at)worldnet.att.net> > > Working on RV-7 Wings with a Gertz heated pitot tube (one bay outboard tie > > down) and plan on installing a DigiTrack autopilot (servo gets in way). > All > > this requires running the pitot tubes (static/dynamic) some other way. I > am > > thinking about "pie-panning" (covering up) for lack of a better word, the > > second lightening holes aft of the spar to hold the snap bushings for the > > pitot tubes. Anyone done this or have a better suggestion? > > Thanks. Happy Holidays > > I installed a Piper style P/S just outboard of the access panel and was also > able to install the TruTrak servo. The P/S is aft of the servo. I cut a > new access panel behind the servo so I could access the D sub connector > without removing the servo. > > Ross Mickey > RV6A > N9PT > > ________________________________________________________________________________
Date: Dec 18, 2003
The Buccaneer S.2B is an unusual plane. I got some time in one from 12 Squadron, RAF Lossiemouth after spending a bunch of time putting the pilot's fingers back together when his GIB closed the canopy on his hand--those silly Scots. Tho, they throw some great parties. Boyd. On Thursday, December 18, 2003, at 12:12 PM, Jim Oke wrote: > > A > British aircraft called the Buccaneer used blowing boundary layer > control on > the tailplane to get acceptable landing characteristics for aircraft > carrier > use at the cost of considerable plumbing complexity but it worked. ________________________________________________________________________________
Date: Dec 18, 2003
I've spent a lot of time researching cameras lately. My final choice is the Canon Optura 300, but it sell for around $1000. I really like the Canon line though, and the ZR70 also looks like a great camera. I believe they all have an audio out, but double check first. cammie do no archive -----Original Message----- I'm back on this subject... Earlier in the year I bought a HI8 video camera. A Sony TRV318... It's a nice camera, and had all the features I wanted (or thought I wanted), including a good price...but I see that it doesn't have an audio in jack! Can anyone tell me about any cameras that do have this feature? I am probably going to get a new one and then sell mine... Thanks!! -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Date: Dec 18, 2003
>Date: Thu, 18 Dec 2003 09:24:27 -0800 > >celebrate? > >The SoCal group had a good day. We got 10 RV's together, formed two >flights of four, and two solos trailing. We did flyovers at 10 >airports. Got some nice comments from controllers (and one not so >nice...) > >We ended up at Mojave. We got there too late to see Rutan's rocket, >but Burt was in the Cafe, all smiles. > >One of our RVer's (Trish) is a school teacher and arranged to have us >overflew her school in the Lake Arrowhead area (very close to the >recent forest fires). You could hear the kids screaming in the >background when she was transmitting to us from the ground. The even >announced it over the school PA, so we had something like 400 kids >watching us go over. Hopefully that will spark some of them. > >The day started with a take off at 7:30, and a roll at 7:35. The day >ended up at Trish's hangar for a BBQ. Think I put 4 hours on the RV >:-) > >It was a Good Day. > >Happy Holidays, everyone. > >Laird RV-6 >SoCal Birdman, You SoCal cats sure know how to party! I went solo, but also had a really sweet centennial flight. My dad's birthday is also Dec 17. So, off I went in 94BD to Mesa. Az to say HI, have lunch, and apply an RV grin to "da kid's" face. As I walked out to my plane after the obligatory pee and swig of coffee, I saw a local Pitt's driver buddy warming up his Lycosaur. "Are you here for the same reason I am?" He asked. "Hell yeah! 0835 we take Rwy 22 and salute the boys from Dayton" was my reply. We did so. Off we went, and formed up on upwind. Man, you have to throttle Waaaaaaay back to stay tight on a fixed pitch S1S! After a wing wag and a snappy salute, he rolled over and split-s'ed back towards the airport as I throttled up for cruise to Mesa. What a glorious day...severe clear, syrupy smooth air, and showing 195mph groundspeed. Nirvana folks, NIRVANA. An hour and 45 and I was rolling out on rwy 4R at Falcon Field. Parked at Anzios restaurant (very nice place I might add) and waited for Pop to show up. He did, we ate, we laughed, we took pics, then we went to the CAF Arizona Wing museum. Awesome! The B-17G "Sentimental Journey" was undergoing year-end refurb and overhaul. I refreshed my memory banks from my flight in her back in '95. I'll never forget it...especially the time in the left seat. The grey haired CAF'ers were doing their usual fabulous job of tweaking, cleaning, wrenching and polishing. (What WILL WE DO when they're gone?) In the background was heard Glenn Miller tunes to add to the scene. The SNJ5 was stripped for rewire and gear work. The B-25 is looking great and should be airworthy soon. I almost wish I could jump ahead to retirement so I can do this kind of work for free, and immerse myself in "the greatest generation". All this I owe to two dreamers from Ohio, and grampa Van. You see, I have adopted him as my grandpa. Our first born was not my son Skyler, but my RV8! The next addition to the family will be the RV10. True to form these days, babies just keep getting bigger! Peace, folks. Go fly, share your love of flight with others, and don't forget what it took to make this all possible. Brian Denk RV8 N94BD RV10 51 ________________________________________________________________________________
Date: Dec 18, 2003
Subject: 100th Anniversary of Fitst Flight
Dec 17 started out cold (below freezing) in the Austin area, but quickly began to warm, actually and figuratively, with bright blue skies and nearly calm winds. After telephone and email coordinating with about 25 formation takeoff, making a radio call "Falcon Flight is taking off to celebrate the 100th year of the Wright Bros first flight". After takeoff, we joined up with three others coming from the north, rendezvoused with another pilot over another field, and proceeded as a 7-ship to San Marcos. After TV interviews planeside, I briefed the 25 pilots gathered to participate in the flyover. We started engines on a time hack and taxied out as Centennial Flight consisting of Falcon Flight of 12, Bonanza Flight of 6, Warbird Flight of 4, Singles Flight of 4 in trail, and a photo aircraft. After formation takeoffs and a large circular overhead joinup, Centennial Flight proceeded on course with Austin Approach monitoring. Falcon Flight of 12 (10 RVs, a Mustang II, and a T-18) configured into the shape of a canard airplane to represent the Wright Flyer (see picture), Bonanza Flight of 6 took a mile spacing and fell into a Delta configuration, Warbird Flight of 4 (a T-6, T-34, and 2 Yaks) took a Diamond shape, and Singles Flight (C-177, Skybolt, L-4, and L-5) followed in a spaced out trail. The Arrow photo airplane flew along side with the TV videographer. Centennial Flight flew to the IP and then the Capitol, making the 1235 TOT exactly. A crowd of government officials, TV station and newspaper photographers, families, and the public viewed the flyover and it made all 4 TV station evening news broadcasts and the morning Austin American-Statesman front page, second section. Centennial Flight proceeded north for another 10 miles before splitting up and heading back to our home dromes with a sense that we had well celebrated the 100th Anniversary of the first flight. An email debrief of the formation followed. Stu McCurdy ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Re: Avery "flat" rivet set problem
What is a "significant crown"? My flat sets are not flat. I thought that they had to have some crown or there would be a significant chance of marking the skin with the edge of the die. Dick Tasker, 90573 Fuselage Phil N wrote: > >I was having the WORST time with getting the shop head of my squeezed >rivets to not cleat as I squeezed them. I ended up using a gun on quite >a few rivets that should have been done with my rather expensive >squeezer. I finally called Avery and had a discussion with them about >it. It turns out that they had a run of flat sets that the guy who was >doing the finish polishing got a little aggressive about his duty. The >set, instead of being flat had a significant crown to it - thus if you >didn't get the rivet PERFECTLY in the center it would run down the hill >on the set. Let's just say that I am damn good at drilling out rivets >at this point in my RV career! > >If you are having trouble that may sound like this, take the flat set >out of your squeezer, hold it up to the light and put the edge of a >steel scale on it. You will see a really bad crown to the set, instead >of it being flat. > >Three days after my call, I had a brand new set - problem solved. > >Phil > > > > ________________________________________________________________________________
Date: Dec 18, 2003
No flame taken. Why not use a heat gun? HCRV6(at)aol.com wrote: > >In a message dated 12/17/03 6:22:15 AM Pacific Standard Time, >winterland(at)rkymtnhi.com writes: > ><< If you ever need to remove the cover plates, just take a small propane >torch and lightly heat the pro-seal. >> > >No flame intended, but having witnessed several "empty" fuel tank explosions, >this seems pretty high risk to me. > >Harry Crosby >Pleasanton, California >RV-6, firewall forward > > > > ________________________________________________________________________________
Date: Dec 18, 2003
The Canadian glider pilot instruction manual uses the word S.O.A.R. which stands for: Situation - recognize what's wrong and what the likely result will be if no action is taken. Options - look for practical options to correct what's wrong and select the best one Action - put the selected course of action into effect Reassess - to see if the situation is getting better, if yes continue what you're doing, if no go back to S and repeat the process. SOAR is a nice catchy word for glider pilots but the basic philosophy seems sound for most segments of aviation. Jim Oke Wpg, MB RV-3, RV-6A, ASW-20 ----- Original Message ----- From: "kempthornes" <kempthornes(at)earthlink.net> Subject: Re: RV-List: Futher Reflections (canopy pops) > > I was reading just yesterday but I forgot the acronym already. What I took > away from it was a four step routine when problems arise. I think it went > like this: > > Continue to fly the airplane > > Analyze the situation > > Take action > > Land > > They made the obvious but apparently often overlooked point that it is > easier and safer to resolve problems while on the ground. > > AOPA Pilot I believe. With some strange (erroneous?) pie charts. > > > K. H. (Hal) Kempthorne > RV6-a N7HK - Three trips to OSH now. > PRB (El Paso de Robles, CA) > > ________________________________________________________________________________
Date: Dec 18, 2003
Matthew, you may by now have noted Jim's eloquent post of this morning: From: Jim Oke <wjoke(at)shaw.ca> Subject: Re: RV-List: vortex generators Date: December 18, 2003 8:12:30 AM AST To: rv-list(at)matronics.com (Jim's notes copied to bottom of page here) He put it down quite well. In my experience, the VG "kit's" most worth their salt are of the sort which Chuck White of Micro-Aero sells. These are test-flown & STC'd but one could certainly learn from observing and "roll one's own". It may be that for production/STC's stuff that Mr. White may have a patent on the wings, HS, VS bit, but in my view that's the way to go. VG's may not be as prevalent in your neighborhood as up here in Alaska but if you can find a few AC wearing them, do look closely. Some kits have the wing VG's nearer to or further back from the leading edge. Once again, I'd try to emulate the "Micro-Aero" recipe. http://www.microaero.com/ Regards, Blanton http://homepage.mac.com/blanton 1051V: wing: Robertson STOL, Sportsman STOL, Wing-X STOL, Deemer's tips, Micro-Aero VG's on wing, VS, HS (underside, of course) (40'2" span vs. 36' for most Cessnas, plus significantly increased depth of chord span-wide due to the Sportsman airfoil being carried through the custom Wing-X extensions and Deemers tips. Almost forgot the Precise Flight speed brakes. "The wing is the thing". On Dec 18, 2003, at 7:11 AM, Matt Jurotich wrote: > > > Very interesting. Every VG kit I've been able to find just supplies > wing > VGs. How does the increased elevator authority affect trim sensitivity > during landing? Any increase in elevator authority during cruise? > Did you > use a kit or roll your own? Do you also have vertical stab VGs? > > Thanks > > <blanton(at)alaska.net> > > VG's on both sides of the VS may affect yaw qualities ... they > may > create an effect like a "virtually" larger VS. I know the VG's > on the > underside of my HS dramatically increased elevator authority as > if the > HS and elevator were larger. > > B. > > > Matthew M. Jurotich > > NASA/Goddard Space Flight Center > Swales contractor to the > JWST ISIM Systems Engineer > > m/c : 443 > e-mail mail to: > phone : 301-286-5919 > fax : 301-286-1736 > > > JWST URL: <http://ngst1.gsfc.nasa.gov > > ........................................................................ ........................................................................ ........................................... When landing a conventionally configured aircraft, especially with the wing flaps extended, a lot of "aft stick" is needed to overcome the nose down pitching moment that slow flight requires plus even more to rotate the nose upwards to flare the aircraft before touchdown. Aft stick means the trailing edge of the elevator moves up so the tail surface becomes a curved, cambered surface producing lift in the downwards sense. (Think of an upside down wing with the flaps extended.) Anything that can be done to improve the lifting characteristics of the tailplane-elevator combination, such as turbulators that will help keep the airflow attached on the underside of the tail, will provide more downward lift which the pilot sees as more "nose up" pitch authority when landing. Turbulators are one method. I recall seeing some aircraft with a reverse slotted horizontal tail leading edge in the past (one of the higher performance Cessna singles possibly) that accomplish the same thing. A British aircraft called the Buccaneer used blowing boundary layer control on the tailplane to get acceptable landing characteristics for aircraft carrier use at the cost of considerable plumbing complexity but it worked. Similar theory would apply to vertical stab turbulators that should provide better lift characteristics to the fin-rudder combination that provide restoring forces to yawing motions and so (perhaps) better yaw stability to the aircraft. Lots more pilot oriented aerodynamics at http://www.av8n.com/how/ Jim Oke Wpg., MB RV-3 RV-6A ________________________________________________________________________________
Date: Dec 18, 2003
> > If you ever need to remove the cover plates, >just take a small propane torch and lightly heat the pro-seal. The plate >will come right off. An even quicker way to get that plate off is to use a big torch and stick it in the filler hole! do not do this hal ________________________________________________________________________________
Date: Dec 18, 2003
From: Blanton Fortson <blanton(at)alaska.net> tocelebrate?
tocelebrate? >>What do they fly in Alaska? Taildraggers rule there.<< HEY, both my Alaska bushplanes have been nose-draggers, with the big Landis fork (and an 8.50x6 nose tire, at least) (Landis PA28/C206 nose fork for 7.00x6 and larger tires) On both the 172xp and the 206 (http://homepage.mac.com/blanton) I flew 24" mains and the largest tire I could fit in that big Piper nose fork. On Dec 18, 2003, at 8:15 AM, Greg Milner wrote: > >> taidraggers were having a tough time taxiing but the 6a had no >> problem< > > I`ve been flying taildraggers in the midwest for 6yrs. and don`t see > noserollers having any advantage. What do they fly in Alaska? > Taildraggers rule there. > > Greg Milner > RV-4 79KM > Waukesha,Wi. UES > > > _- > ====================================================================== > _-> _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Dec 18, 2003
> What did you do today to celebrate 100 years of powered flight? The weather here in So.St.Paul, MN was great, temps in the 20's, and I had the day off. So out came the -6, and away I flew down Mark Twain's Mississippi past LaCrosse, WI to Prairie du Chien. The walls of the FBO are covered with photos of visiting aircraft (Michael - Susie-Q was there!) and I had a nice time visiting with the locals and reflecting on the last 100 years of flight. Then off toward home to start the SECOND 100 years... Mike Hilger RV-6, N207AM, 500 hrs So.St.Paul, Minnesota (SGS) ________________________________________________________________________________
Date: Dec 18, 2003
"No flame intended" That's such a fitting phrase for this topic :-) But on a serious note the industry standard for the flash point on gas is -25 to -35 degree witch means that the gas will flash from the heat source from your heat gun or the spark from the brushes in your hair dryer will ignite the vapor. I clean gas tanks for a living and granted were talking about a 30 gal tank and not a 3 million gal tank but the rules are the same. I=E2=80=99ve heard more stories than you can shake a stick at and would hate to hear another one from the RV community. Lee Anoka MN RV-3 Wing ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Gas tank explosion hazard (Was: To Cork or not to Cork?)
> >In a message dated 12/17/03 6:22:15 AM Pacific Standard Time, >winterland(at)rkymtnhi.com writes: > ><< If you ever need to remove the cover plates, just take a small propane >torch and lightly heat the pro-seal. >> > >No flame intended, but having witnessed several "empty" fuel tank explosions, >this seems pretty high risk to me. The best way I have ever heard to reduce the risk of fire and explosion is to toss a few cups of dry ice pellets in the tank about twenty minutes before you begin work. ________________________________________________________________________________
Date: Dec 18, 2003
Video camera "MIC" jack? Audio IN. My past experience with the "MIC" input to a video camera has been the camera automatic gain control. If there is no outside noise, the automatic gain increases to a level that it has noise (static). Probably not a problem with the engine running, though. Jim Ayers ________________________________________________________________________________
Date: Dec 18, 2003
> What did you do today to celebrate 100 years of powered flight? I stood in the pouring rain, soaked to the skin and listened to the President. I watched the EAA first flight clock count down to Zero standing right beside the replica flyer sitting inside Ford/EAA tent while it poured rain outside. I flew my new RV-4 over the Wright Brothers Memorial at Kill Devil Hill. Wow! "What I did not do" was fly the Corsair (as advertised here) because it did not get out of North Dakota. But that is OK, I did fly the Mustang with the Hornet during Monday's show and it was pretty cool! On Wednesday they scrubbed all the afternoon flying and then the WX broke. At the airport they told us, "anybody who wanted to to go fly, go fly down the runway at First Flight Airport! It was incredible! In retrospect, we should have organized a group of RVs to do a flyover. 20/20 hindsight...... Tailwinds, Doug Rozendaal The trip home today from MQI to MCW was a fun one.....7 hours of Ifr, Ice, & 30 to 50 kt headwinds.... I climbed to 12,000 ft to get on top. Still climbing 600 fpm @ 100 Kias with a half an inch of mixed ice, mostly clear.... Boy am I glad I don't have a Glasair or a Lancair!!!! ________________________________________________________________________________
Date: Dec 18, 2003
I put the Trutrak servo in the right wing with Trutrak's right wing kit, as they suggested. Wayne -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ross Mickey Subject: Re: RV-List: Pitot Tubes ----- Original Message ----- From: "Don Harker" <dpharker(at)worldnet.att.net> > Working on RV-7 Wings with a Gertz heated pitot tube (one bay outboard tie > down) and plan on installing a DigiTrack autopilot (servo gets in way). All > this requires running the pitot tubes (static/dynamic) some other way. I am > thinking about "pie-panning" (covering up) for lack of a better word, the > second lightening holes aft of the spar to hold the snap bushings for the > pitot tubes. Anyone done this or have a better suggestion? > Thanks. Happy Holidays I installed a Piper style P/S just outboard of the access panel and was also able to install the TruTrak servo. The P/S is aft of the servo. I cut a new access panel behind the servo so I could access the D sub connector without removing the servo. Ross Mickey RV6A N9PT = = = = ________________________________________________________________________________
From: "Mickey & Paula" <mimartin(at)sweetwaterhsa.com>
Subject: Third World?
Date: Dec 18, 2003
mimartin(at)sweetwaterhsa.com 307-382-5621 Dear Sir: I am writing to you express my concerns with what seems to business as usual with government agencies. My husband is a private pilot, on February 10, 2003 he had his physical to renew his medical certificate. He waited several months to hear from the F.A.A. Then he asked the Experimental Aircraft Association representative Susan Sedlachek to see if she could find out what was happening. She told him that F.A.A. wanted additional information which my husband and the F.A.A. approved physician provided. He then waited another few months until July 24th before he heard that he was being rejected because of hypertension, type II diabetes and some incorrect information sent by his personal physician. He wrote a letter with additional information and his personal physician also wrote a letter explaining errors in original information. He sent this packet with delivery confirmation request by U.S. Postal Service. The F.A.A. signed this delivery confirmation card on Sept 19, 2003. This packet of information was ignored?, misplaced? Now on December 11th he spoke with Susan Sedlachek who again contacted F.A.A. and they had no record of the information sent in September. He made copies of everything and resubmitted the packet by fax. We still have no answer. If this isn't bad enough we know other pilots who have experienced the same sort of delays and problems. There are businesses who offer to take your paperwork from desk to desk at the F.A.A. to expedite the process. Professional pilots have no recourse but to pay this added expense to be sure they receive the necessary certificate to remain current. Few private pilots can justify the expense. In the same way the F.A.A. has now taken over 2 years to decide what rules will apply to the new 'Sport' pilot classification. The final rule has been delayed and delayed again, the final rule has yet to be made public. This is not the only government agency that operates in the same manner. We have a friend who has paid a lawyer several thousands of dollars to expedite his application for papers to work and stay in the United States. This lawyer is to help them understand the forms for the Immigration & Naturalization Service and to again carry the papers from desk to desk at I.N.S. This all seems to me very like stories I have read of third world countries where nothing gets done without a little something the grease the hand. What is becoming of our country? RV6 Builder ________________________________________________________________________________
Subject: Re: Dec 17th 2003 100 Years / What did you do today to celebrate?
Date: Dec 18, 2003
I didn't have a chance to take a flight in my RV-6 on the 17th due to the fact that she is all fueled up and ready to launch tomorrow (Friday) morning for the trip of a lifetime. From Winnipeg, MB Canada I will be heading southwest though the Dakotas, Nebraska, Kansas, etc. to Tucumcari, NM for the night, then onto Mesa (FFZ) on Saturday, wx permitting, for Christmas with my folks. 85 hrs on the bird so far, and this will be my first flight into the U.S., my first really long cross country and my first encounter with mountains, although I am planning on flying the "low" route via TCS and DMN. Man, am I pumped! Thanks Orville and Wilbur! Curt RV-6 C-GACR ________________________________________________________________________________
Date: Dec 18, 2003
We just discussed this a week ago - you need a Radio Shack 42-2142A "Attenuating Audio Cable" (1/8 mono jacks on each end) plus a 274-325 mono-to-mono Audio Adapter (accepts 1/2" mono phone plug, fits 1/4" mono phone jack)" It is always the case that aircraft intercom and radio audio amplitude is too great to be handled by an audio or video recorder which causes distortion, not static. You have to reduce the amplitude. The cited attenuating cable has a resister inside that cuts the amplitude going into the recorder. I just flight tested mine last week and it worked. David ----- Original Message ----- From: <LeastDrag93066(at)aol.com> Subject: Re: RV-List: more on: Cockpit "Audio out" to videocamera > > Video camera "MIC" jack? Audio IN. > > My past experience with the "MIC" input to a video camera has been the camera > automatic gain control. If there is no outside noise, the automatic gain > increases to a level that it has noise (static). Probably not a problem with the > engine running, though. > > Jim Ayers > > ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Dec 17th - The RV grin
I celebrated Dec 17th by getting in a RV for the first time. Seen plenty of RV's but have never been in one. Gave myself a good grin. See me in a RV at http://ahyup.com/beta/ Warren ________________________________________________________________________________
Date: Dec 18, 2003
Subject: Flight test reviews
Has anyone out there got an article in electronic form on an RV-9 flight test or flight review? Or perhaps a pointer to such? Thanks. Blanton Fortson ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Wingtips
Hello RV-Builders I put on the Wingtips last summer and I thought I would never have to worry about them ever again. There are people telling about wingtips becoming loose and eventually falling off due to the rivets pulling out of the fiberglass. I decided against the option of being able to take the aileron-pushrods out without removing the wings and riveted them on using the supplied pop-rivets. The plans were asking for reinforcement aluminum-strips and I have seen builders using epoxy, screws or proseal to put the fiberglass parts on. I watched the edge-distance clearances and even the remaining thickness after countersinking the fiberglass looked ok to me. I do work with fiberglass a lot and I just cant see those rivets pulling out. So there are no aluminum strips on my wingtips. Instead I used a heavy duty sealing-adhesive to "glue" the fiberglass parts on while pulling the pop rivets. No doupt that an additional strip would have made a stronger attachement but unfortunately my wing has already been finished and painted. Is there anyone out there who is flying a RV without the strips and both wingtips still on the plane? Do they really become loose after a while. Do I have a to saw the tips off again in order to add the strips or something else? Thank you for your answer Thomas, RV-4, just about to start the engine -- +++ GMX - die erste Adresse fr Mail, Message, More +++ Neu: Preissenkung fr MMS und FreeMMS! http://www.gmx.net ________________________________________________________________________________
Subject: Looking for Bret Marquis
Date: Dec 19, 2003
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Does anyone have his current contact information? He is a very old list member. Early 90's. Thanks Michael Stewart Quality Assurance 404.236.3363 GO ISS! "Why is it doing that and how do I make it stop?" What an old pilot said while learning a new computerized cockpit ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Clecoes - 3/23"
Listers, Since I'm in the last stages of building, I do not need many of my 3/32 clecoes. I'd be glad to sell a couple of hundred for 2/3 of the going price. I will cover shipping. You can't have too many clecoes. Please contact me off list. Richard Dudley ________________________________________________________________________________
Subject: bad dies
Date: Dec 19, 2003
SNIP It turns out that they had a run of flat sets that the guy who was doing the finish polishing got a little aggressive about his duty. The set, instead of being flat had a significant crown to it - SNIP Don't be shy about taking your dies over to the belt sander and sanding them flat. The rough surface will help keep the rivet from sliding around and clinching. Sand blasting the face of the flat set also works well. I have a few untouched (nice and shiny) flat sets for use on the skin side of the work, but for the shop head side I always grab the flat sets with the coarse finish. Take it FWIW, I drilled out hundreds of rivets on my first RV. On the Rocket I almost never drilled any out. Vince Frazier 1946 Stinson, NC97535, FOR SALE F-1H Rocket, N540VF, Crazy Horse <http://www.usi.edu/science/chemistry/vfrazier/page1.html> ________________________________________________________________________________
Date: Dec 19, 2003
Another way to (somewhat) safely heat up a gas tank is to plumb the exhaust from your car into the the tank. Use the shopvac plastic hose, attach tightly to car exhause, start car, shove other end into tank opening with a lot of gap so you don't over pressure the tank. Go make some coffee. By the time you return, the atmosphere in the tank will be moist and flooded with exhaust that will not ignite. Be sure all the tank bays are flooded with the exhaust and be sure you don't get a static spark from shoving the plastic hose in. From here you could apply heat with a heat gun....but I am still chicken to take a torch or open flame to a tank. Other folks do, the old timer who showed me this trick has done it for years...he said its a old farmers trick used to repair and soulder fuel tanks on tractors. I've seen car repair stations do this too. You may want to consider cutting (fly cut) some new access holes. This heat thing in a fuel tank dosen't sound safe.......oh well, back to juggling running chain saws. ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Propellers
There has been some great prop. comparison testing done recently, but unfortunately it did not include the new "Blended Airfoil" c.s. Hartzell. Van's is now offering this prop. in both 72" and 74" models for the 7A. Any thoughts as to what the performance difference would be between the two on an O-360? TIA for the info and I hope you all have a great and safe holiday. Dave 7A Wiring ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Re: Wingtips
Thomas; I think this is one of those "why worry" situations. The very worst that could happen is that after years of use you might see a few of those pop-rivets getting loose and wobbly - not "likely" just "might". Anyway, the actual in-flight stresses on the typical RV wingtips must be quite small and these things are hardly a critical item (safe where they might interfer with aileron travel). Thus any "wingtip falling off" problem should be easily spotted in plenty of time to do a fix. Might be a bit of work fixing up the paint, but that's years off into the future if ever. FWIW, I pop-riveted my RV-3 tips on about 15 years ago (I think I used a backing strip but its been a long time now) and I see not a hint of any stress or problem with the poprivets. This despite a lot of outdoor storage in some extreme climate conditions such as +35 C to -35 C every year. In short, there are better things to worry about. Press on and go flying and see what happens. Jim Oke RV-3, RV-6A Winnipeg, MB ----- Original Message ----- From: "Thomas Lukasczyk" <Lukasczyk(at)gmx.net> Subject: RV-List: Wingtips > > Hello RV-Builders > > > I put on the Wingtips last summer and I thought I would never have to worry > about them ever again. There are people telling about wingtips becoming > loose > and eventually falling off due to the rivets pulling out of the fiberglass. > I decided against the option of being able to take the aileron-pushrods out > without removing the wings and riveted them on using the supplied > pop-rivets. > The plans were asking for reinforcement aluminum-strips and I have seen > builders using epoxy, screws or proseal to put the fiberglass parts on. I > watched > the edge-distance clearances and even the remaining thickness after > countersinking the fiberglass looked ok to me. I do work with fiberglass a > lot and I > just cant see those rivets pulling out. > So there are no aluminum strips on my wingtips. Instead I used a heavy duty > sealing-adhesive to "glue" the fiberglass parts on while pulling the pop > rivets. > No doupt that an additional strip would have made a stronger attachement but > unfortunately my wing has already been finished and painted. > Is there anyone out there who is flying a RV without the strips and both > wingtips still on the plane? Do they really become loose after a while. Do I > have a to saw the tips off again in order to add the strips or something > else? > > Thank you for your answer > > > Thomas, RV-4, just about to start the engine > > -- > +++ GMX - die erste Adresse fr Mail, Message, More +++ > Neu: Preissenkung fr MMS und FreeMMS! http://www.gmx.net > > ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Tank Dies
Listers, I have a pair of 3/32" tank dimpling dies that I no longer need. I built my -6A tanks with them. They were purchased from Cleaveland. You can have them for $20. Please reply off line. Richard Dudley ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Transition Training...
vansairforce Anyone doing RV tailwheel training in the neighborhood of Colorado Springs, CO? -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
From: "LML Klingmuller" <l_klingmuller(at)earthlink.net>
Subject: Re: Free Steamboat Condo../ or Marble, Colorado.
Date: Dec 19, 2003
Hey Bill, Count me in when you open up your doors next year!!! I will beer and a sleeping bag. I am getting bored flying to Front Range (Colorado) airports. For those who want to do some mountain flying, the Colorado Pilots Association (www.ColoradoPilott.org) has a yearly flying to Marble. It is a private grass strip on the other side of Aspen. Flying there does require mountain flying experiment. You may consider participate in a one day course the CPA puts on once a year. Anyhow, I was surprised that the owner never saw an RV there, so lets show those Wichita AP makers there are other planes flying. LML Klingmuller l_klingmuller(at)earthlink.net Why Wait? Move to EarthLink. ________________________________________________________________________________
Subject: Flying with Bob Archer Com Antennas?
Date: Dec 19, 2003
Can any of you out there flying with these antennas advise on their performance? Thanks in advance. Glenn in Tucson, -9A Wings, Fuselage ordered. ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Re: Flying with Bob Archer Com Antennas?
I've got his VOR antenna in the wingtip and it works fine.... Laird RV6 SoCal > >Can any of you out there flying with these antennas advise on their >performance? Thanks in advance. > >Glenn in Tucson, -9A Wings, Fuselage ordered. ________________________________________________________________________________
Date: Dec 19, 2003
I have heard the VOR/Nav antennas are fine, but there has been problems with the Com, any feedback on Com antennas specifically would be appreciated. ----- Original Message ----- From: "Laird Owens" <owens(at)aerovironment.com> Subject: Re: RV-List: Flying with Bob Archer Com Antennas? > > I've got his VOR antenna in the wingtip and it works fine.... > > Laird RV6 > SoCal > ________________________________________________________________________________
Date: Dec 19, 2003
----- Original Message ----- From: "Laird Owens" <owens(at)aerovironment.com> > I've got his VOR antenna in the wingtip and it works fine.... Laird, Could you describe how yours is positioned? Mine is as vertical as I could get it right at the end of the aluminum wing where it meets the tip. My reception is quite abit lower than my standard comm antenna mounted on my belly. Ross RV6A N9PT ________________________________________________________________________________
Date: Dec 19, 2003
Ross, It sounds like your confusing the VOR antenna I have and the COM antenna. I've heard the COM antenna doesn't work well in the wingtip, but I've also 2 local friends that like theirs. Anyway, in case you did mean the VOR antenna, mine is mounted on the upper surface of the old style wingtips, just as the instructions say. I think Sam has some pictures and a review on his web site, the RV journal. Good luck. Laird > > >----- Original Message ----- >From: "Laird Owens" <owens(at)aerovironment.com> >> I've got his VOR antenna in the wingtip and it works fine.... > >Laird, > >Could you describe how yours is positioned? Mine is as vertical as I could >get it right at the end of the aluminum wing where it meets the tip. My >reception is quite abit lower than my standard comm antenna mounted on my >belly. > >Ross >RV6A N9PT > > ________________________________________________________________________________
Date: Dec 19, 2003
Subject: RV-7A kit for sale
This is one of those "Holy Toledo" posts ---- I will be leaving Lander, Wyoming for just south of Jacksonville, FL on January 7 to start a new job on Jan.12 I either have to sell my RV-7A project lickity split, or figure out how to transport it and store it for about 6 months.......... I have an empennage kit, completed except for fiberglass. It has the older rudder, but I have the new rudder kit from vans still in the box. I have a wing kit, 1st wing started, in the midst of sealing tanks -- 2d wing untouched. Flaps and ailerons about 85% done. I have a QB fuselage kit that I have opened and inventoried but not done anything to. When I add up the invoices, it exceeds $19,000 in parts. If you came to Lander, WY and used a U Haul or truck to drive away with it, I'd help you load it and let it all go for $15,000. I can guarantee (in writing) that all the parts are there. Need to hear from you before Jan. 3 No tools to be sold -- I hope to start anew someday...........and I also have a flying RV-6A that I have to maintain! Terri Watson N1977D flying N8862T reserved windsaloft(at)rmisp.com ________________________________________________________________________________
Subject: Re: Propellers
Date: Dec 19, 2003
Dave, If maximum performance is what you're after various bits of data I've seen would indicate the 74" is the choice. It will have a higher tip speed at a given rpm however and will therefore be a little bit noisier. Of course the 1" greater radius puts you that much closer to gravel etc. also. Because you have a nosewheel, and because any performance improvement will be very small, I'd use the 72" with any -A model. FWIW, Randy Lervold www.rv-8.com > > There has been some great prop. comparison testing done recently, but > unfortunately it did not include the new "Blended Airfoil" c.s. > Hartzell. Van's is now offering this prop. in both 72" and 74" models > for the 7A. Any thoughts as to what the performance difference would be > between the two on an O-360? TIA for the info and I hope you all have a > great and safe holiday. > > Dave > 7A Wiring > > ________________________________________________________________________________
Subject: Antenna/radio reception
Date: Dec 19, 2003
>Last weekend I heard a radio call from an airport 100 miles away. Is it >normal to have this kind of reception. I never had this happen with rental >planes. I was headed to OSH one year and was on 123.00 for the next field I had to listen to, which is also home frequency. I was 86nm out and heard someone announce left downwind for 15. I thought what the hell and called back that pattern for 15 was right pattern. "Oh, OK. Right pattern? OK." He called back. I have a belly mounted fiberglass (Dorne & Margolin) antennae and ICOM A200 radio. FBO radio man a while back said he always knows it's me because the radio broadcast is so loud. Gotta love it. Michael RV-4 N232 Suzie Q ________________________________________________________________________________
Date: Dec 19, 2003
In a message dated 12/19/2003 1:22:06 PM Central Standard Time, Fiveonepw(at)aol.com writes: Something y'all might want to consider is using hinges just like the cowling sides- I recently did sheared tips this way and am very pleased with the results- no ugly screws and they can be on/off in minutes- make that less than a minute when I get all the epoxy cleaned out of the holes and don't need to grab the drill... Hay that's a good idea but how do you fasten the hinge pin? Lee Anoka MN RV-3 wing ________________________________________________________________________________
Date: Dec 20, 2003
Subject: Re: Dec 17th 2003 100 Years / What did you do today tocelebrate?
>What did you do today to celebrate 100 years of powered flight? I had nothing planned, off to work as usual, not a peep about the special day on national radio or in the one Sydney daily newspaper I saw. The journalists either slept through the event or just found it a little ho hum to bother with. 3pm... tap tap tap on the outside office window, security door blocks marketing staff access, she's waving some form of ticket. "GD can't make it, someone suggested you might like to go..6:45 for 7pm start tonight ... do you want the ticket?" The ticket - for the Royal Aeronautical Society - Sydney branch - Centenary of Flight Dinner - venue the Powerhouse Museum - Turbine Gallery (lots of aircraft hanging on wires from the ceiling). Manner from Heaven, how could I not go..... This was the big end of town event - Qantas, Virgin, Boeing, Rolls-Royce, Emirates and a number of the minors who have operated locally, CEOs and chairmen of these significant organisations or their representatives in Australia. Guest speakers were two aviation journalists (Jeff Watson and Tom Ballantyne) plus Max Hazelton, founder of a significant local (Australian that is) airline. I had first met Max Hazelton, at the time was chairman and CEO of Hazelton Airlines, he was in the left hand seat flying single pilot RPT flight from Cudal to Sydney Airport (NSW). I had talked my way into the RH seat. The flight was a full on IFR approach to very close to the minimums - Max Hazelton language of choice was 'pilotage'. The journalists spoke well and presented a video made to commemorate the event and presented news of another Wright Flyer replica built in South Australia, due of course to be flown that day. Pioneer Aussie Aviators were either present or spoken about. Lawrence Hargraves, in particular since he was acknowledged by the Wright bros to have contributed to their effort to attain powered flight. (No mention of Jon Johanson tho...) I had a wow of a time with all these aviation enthusiasts and even though they were from the other end of town, not the sport aircraft people I normally associate with, the excitement and appreciation of sharing the celebration together in the environment was a great privilege. Various item of memorabilia were auctioned off raising an inordinate amount of money in support of the Royal Flying Doctor Service. .... $4500 for an RR Olympus turbine blade...can you believe it? To top it all off I won one of the door prizes, a glider flight. I think I'll enjoy that... The 17th turned out to be a most memorable day for me, a fitting way to celebrate the centenary of powered flight. Doug Gray ________________________________________________________________________________
Date: Dec 19, 2003
Subject: RV-List Prop Bolts
Hey Girls(or Guys), I was in the process of installing my prop tonight and it seems that the set of studs that i have here with the motor are about 1/8" to long. They protrude through the prop flange and hit the hub housing before the flange tightens on the flywheel assembly. So guess I need shorter studs to solve the problem. I checked Aircraft Spruce and didn't see any studs listed. Is there some sort of spec. for this stud (i.e. 125000 or 160000 psi ) that I can use to locate something locally or do I need to contact Hartsel? Oh by the way it's a 0-320 with a Hartsel C/S. Weasel Graber -4 wanting to start engine!!! Brooksville MS ________________________________________________________________________________
Date: Dec 20, 2003
Subject: Re: Baffle Measurements....
I believe if you look at the directions, the airseal is 1.5" above and below the aluminum (3" wide strips). As far as rivet spacing, I think I used about 1.5" between rivets, but varied it to ensure it all laid down flat. I used a posterboard and laid it up next to the baffles and traced around the top where the airseal rivets. I then offset the lines up and down by 1.5" each and cut them out for templates. I also used soft aluminum rivets and aluminum washers instead of the pull rivets, I thought it gave a more professional look and I had the supplies handy. Be sure to make all the templates of the seals and lay them out on the airseal first, so you know you will have enough material to finish the job. On my RV-4 I had very little to spare even after meticulously laying out the patterns. Don't forget to at least cleco in the fiberglass inlet ducts in the upper cowl and cut the baffles down for clearance in this area before installing the airseal. I learned this trick from experience..... Hope this helps! -Mike Kraus N223RV Flying RV-4 N213RV building RV-10 ________________________________________________________________________________
Subject: Cork or not to Cork?
Date: Dec 19, 2003
Thanks to everyone that provided their experiences. I got about a 50-50 response on corking vs. not corking. The biggest issue seemed to be that cork would be easier to open up again should the need arise. I decided to use the cork and the task is done. I used 8x32 stainless socket head screws. They worked great. Wings installed today. On a final note, I don't care if I ever see Proseal again in this life time!!!!!!! Anyone know how long this stuff will be on my hands? Darwin N. Barrie Chandler AZ Crossflow Subaru ________________________________________________________________________________
Date: Dec 19, 2003
Subject: For Sale - RV-6 Almost done with a panel to die for
Listers, My RV-6 is for sale. It is almost done. Sheet metal work is pretty much done, Canopy is pretty much done except for fiberglass. Cowling is cut and fitted but hinges not on permanent, Engine is installed, baffles are fitted and installed but no chaffe rubber yet, panel installed complete, wiring done, wings test fitted. 0-360A1A Lycoming from Aerosport, New Constant Speed prop from Vans I have everything to finish this airplane except the paint. Serious buyers contact me off list for further details. Tim Bryan tim(at)bryantechnology.com Redmond, Oregon ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Re: Note from Dynon on OAT
> > >One of my upsets with the Dynon was the lack of availability or OAT, and >hence, true airspeed. A very very valuable tool when flying above >sealevel. Hi Mike, I have done nothing since flight training days more than estimate TAS using the 2% per 1000 feet thing. I didn't even use that when I was flying below sea level and I suffered no pain! Especially with GPS, is seems to me of little value. I tried to find how/why to use TAS in several flying books to no avail. Please say what value you see in knowing the TAS. I'm rebuilding my panel - tying up loose wiring etc!! Probably Dynon and Trio. K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Dec 20, 2003
Subject: Re: RV-List Prop Bolts
smoothweasel(at)juno.com wrote: > > Hey Girls(or Guys), >I was in the process of installing my prop tonight and it seems that the >set of studs that i have here with the motor are about 1/8" to long. They >protrude through the prop flange and hit the hub housing before the >flange tightens on the flywheel assembly. > Something is definitely amiss. The prop flange bushings do come in different lengths depending on their use (FP Vs. CS), but unless the engine has been converted, it shouldn't matter. One bushing is a little larger dia than the others, and that's what indexes the flywheel to the crank. You may not have the flywheel indexed correctly. Take out #1 plug and rotate crank to the compression stroke and place the piston at TDC (Top Dead Center). Now fit the flywheel up on the crank with the 0 at the top. The 0 on the backside of the flywheel should align itself with the case parting line. and should fit flush with the flange. Metal props are counterbored to take the extended length of the bushings, if there are any. I'm not sure of wood props are counterbored or not. The other way to get around changing the bushings (they ain't cheap) would be to get a prop spacer and add it to the stack. Problem is, that'll push the prop forward and you'll have a larger gap between spinner and cowl. Nothing's simple, is it???? Good luck. Linn > So guess I need shorter studs >to solve the problem. I checked Aircraft Spruce and didn't see any studs >listed. Is there some sort of spec. for this stud (i.e. 125000 or 160000 >psi ) that I can use to locate something locally or do I need to contact >Hartsel? Oh by the way it's a 0-320 with a Hartsel C/S. > > > > >Weasel Graber >-4 wanting to start engine!!! >Brooksville MS > > > ________________________________________________________________________________
Subject: Re: RV-7A kit for sale
Date: Dec 20, 2003
Hi Terri ... I'm interested and can pick it up with my Dakota pickup and a trailer, real soon. I'd have a certified check for you when I arrive. Send your phone number and I'll call you. Or you can call me 847-669-0939 ... your option. I'm in Northern Illinois, retired, and need something to build and fly. Looking forward to your reply. Jerry Grimmonpre jerry(at)mc.net ----- Original Message ----- From: <windsaloft(at)rmisp.com> Subject: RV-List: RV-7A kit for sale > > This is one of those "Holy Toledo" posts ---- > > I will be leaving Lander, Wyoming for just south of Jacksonville, FL on > January 7 to start a new job on Jan.12 > > I either have to sell my RV-7A project lickity split, or figure out how to > transport it and store it for about 6 months.......... > > I have an empennage kit, completed except for fiberglass. It has the > older rudder, but I have the new rudder kit from vans still in the box. > > I have a wing kit, 1st wing started, in the midst of sealing tanks -- 2d > wing untouched. Flaps and ailerons about 85% done. > > I have a QB fuselage kit that I have opened and inventoried but not done > anything to. > > When I add up the invoices, it exceeds $19,000 in parts. If you came to > Lander, WY and used a U Haul or truck to drive away with it, I'd help you > load it and let it all go for $15,000. I can guarantee (in writing) that > all the parts are there. Need to hear from you before Jan. 3 > > No tools to be sold -- I hope to start anew someday...........and I also > have a flying RV-6A that I have to maintain! > > Terri Watson > N1977D flying > N8862T reserved > windsaloft(at)rmisp.com > > ________________________________________________________________________________
Date: Dec 20, 2003
> > > I tried to find how/why to use TAS in several flying books to no > avail. Please say what value you see in knowing the TAS. > I find the TAS display on my Rocky Mountain MicroEncoder very useful for picking cruising altitudes. By making a quick comparison of TAS and GS during the climb I can instantly see the head or tailwind component. In cruise it is interesting, but not essential information, to see the effects of lift and sink on speed. Sometimes you can see you are in gentle down wave that is killing your speed. Remedied by altering course one way or the other. It is also a quick and dirty way of seeing if I am running about the cruise power I want to. I know I normally cruise around 165 knots. If it is something different I figure out why. Approaching the airport I can see whether to expect wind shear. If I am showing a 30 knot headwind at a thousand feet but the surface wind is 5 knots, watch out. This happened a week ago to me. There are enough nice things about TAS display that I would hate to give it up. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Date: Dec 20, 2003
In a message dated 12/19/03 7:34:06 PM Central Standard Time, Leesafur(at)aol.com writes: > Hay that's a good idea but how do you fasten the hinge pin? > The will clip to the inside of the rib that installs in the rear of the tip. There is about a one inch offset from the pin line and the surface of the rib. Haven't done it yet, but the plan is to install a platenut in the outboard side of the rib, about 3" from the rear, then make a little nylon block with a couple of holes drilled through it fore/aft for the pins, and one through the block for a #8 screw into the platenut. Best wishes and happy holidaze from The PossumWorks Mark - plumbing the depths of the cockpit........... ________________________________________________________________________________
Date: Dec 20, 2003
Weasel(?), All you ever wanted to know about prop bushing on Lycoming engines is here.... http://www.lycoming.textron.com/support/publications/maintenancePublications/serviceInstructions/SI1098G.pdf good luck .... gil in Tucson > >smoothweasel(at)juno.com wrote: > > > > > Hey Girls(or Guys), > >I was in the process of installing my prop tonight and it seems that the > >set of studs that i have here with the motor are about 1/8" to long. They > >protrude through the prop flange and hit the hub housing before the > >flange tightens on the flywheel assembly. > > >Something is definitely amiss. The prop flange bushings do come in >different lengths depending on their use (FP Vs. CS), but unless the >engine has been converted, it shouldn't matter. One bushing is a little >larger dia than the others, and that's what indexes the flywheel to the >crank. You may not have the flywheel indexed correctly. Take out #1 >plug and rotate crank to the compression stroke and place the piston at >TDC (Top Dead Center). Now fit the flywheel up on the crank with the 0 >at the top. The 0 on the backside of the flywheel should align itself >with the case parting line. and should fit flush with the flange. Metal >props are counterbored to take the extended length of the bushings, if >there are any. I'm not sure of wood props are counterbored or not. The >other way to get around changing the bushings (they ain't cheap) would >be to get a prop spacer and add it to the stack. Problem is, that'll >push the prop forward and you'll have a larger gap between spinner and >cowl. Nothing's simple, is it???? Good luck. >Linn > > > So guess I need shorter studs > >to solve the problem. I checked Aircraft Spruce and didn't see any studs > >listed. Is there some sort of spec. for this stud (i.e. 125000 or 160000 > >psi ) that I can use to locate something locally or do I need to contact > >Hartsel? Oh by the way it's a 0-320 with a Hartsel C/S. > > > > > > > > > >Weasel Graber > >-4 wanting to start engine!!! > >Brooksville MS > > > > > > > > RV-6A, #20701 .. fitting out firewall... 77 Tiger N28478 at 57AZ ________________________________________________________________________________
Date: Dec 20, 2003
I'm actually curious more about how the hinges rivet to the wing. On the RV-7 the wingtip tucks inside the wing skin, so there wouldn't be much room for hinges. On yours did you chop off the wingtip flange so it butts up against the wing skin edge, and then you've got half the hinge on the wing skin, half the hinge on the wingtip? Something like that? Just curious how you've made it work...photos would be great, too. Thanks, )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: <Fiveonepw(at)aol.com> Subject: Re: RV-List: Wingtips > > In a message dated 12/19/03 7:34:06 PM Central Standard Time, > Leesafur(at)aol.com writes: > > > Hay that's a good idea but how do you fasten the hinge pin? > > > > The will clip to the inside of the rib that installs in the rear of the tip. > There is about a one inch offset from the pin line and the surface of the > rib. Haven't done it yet, but the plan is to install a platenut in the outboard > side of the rib, about 3" from the rear, then make a little nylon block with a > couple of holes drilled through it fore/aft for the pins, and one through the > block for a #8 screw into the platenut. > > Best wishes and happy holidaze from The PossumWorks > Mark - plumbing the depths of the cockpit........... > > ________________________________________________________________________________
Date: Dec 20, 2003
Subject: Re:Cork or not to Cork?
The pro-seal will grow off your hands in a month or two ! Bob Olds A&P , EAA Tech. Counselor RV-4 , N1191X , Flying Now Charleston, Arkansas "Real Aviators Fly Taildraggers" ________________________________________________________________________________
Date: Dec 20, 2003
In a message dated 12/20/03 10:02:22 AM Central Standard Time, dan(at)rvproject.com writes: > I'm actually curious more about how the hinges rivet to the wing. On the > RV-7 the wingtip tucks inside the wing skin, so there wouldn't be much room > for hinges. > > On yours did you chop off the wingtip flange so it butts up against the wing > skin edge, and then you've got half the hinge on the wing skin, half the > hinge on the wingtip? Something like that? > > Just curious how you've made it work...photos would be great, too. > Hi Dan- The hinge attaches to the wing skin with a strip of .040 spacer to offset the thickness of the glass. It's the same size hinge as used on the cowling and just fits the skin extension with the eyes sticking out past the edge. (I'm assuming the -7 has the 1/2" extra skin past the outer rib? I got one of them obsolete -6A's) Yes, the flange on the tips is removed except for the front 5" on the top and about 3" on the bottom. This sits inside the wing skin and holds the front in position and the majority of the hinge is fairly straight for easy removal/insertion. A couple of other notes: Install the hinge to the wing first, install the outer half of the hinge with holes pre-drilled for the rivets, insert a foam airfoil rib to hold the tips shape, duct-tape the tip firmly in position, then drill through the glass and the holes in the hinge, doin' the cleko thing as you go. You have to have a light inside the wingtip to do this- I have small access panels in the bottom of my wing in the last bay that I could insert the light with, but I would imagine you could rig a light attached to a rod that extends through a hole drilled in the front of the tip (easy repair) to manipulate a light- (any RV builder can do this- you installed a canopy, right?!) I also sanded most of the gel coat off the tip along the hinge line to allow more light to shine through the holes. I've got a so-so fo-to I'll send ya... I also drilled 1/4" holes in the hinges between the rivet holes for "flox rivets" - (probably overkill), and installed the rear 2/3 of the foam rib with fiberglass about 2" outboard of the hinges to help hold the shape of the tip- I'd probably do this regardless of how you stick 'em on. I spent more time trying to massage the damn warps out of the tips than installing the hinges anyway!! I can't say if this was more trouble than screws as I've never done one that way, but I do like the way it looks and the easy access to strobes, Navaid servo, wire conduit, antennas etc.- another advantage to removable tips is access for removing aileron pushtubes if necessary... I remember a story on the list years ago about a builder who rivetted on the tips, then installed the wings only to see the pushtubes leaning against the workbench- uh-oh!!! I just bolted on my wings, so I know what he went through, but I also now know there is ONE advantage to a taildragger! But ONLY one!! 8 ) Have fun & good luck- good work on the diary! Mark ________________________________________________________________________________
Subject: Jacking up gear legs for wheel mtnce.
Date: Dec 20, 2003
How are you guys jacking up RV-6 gear legs for wheel maintenance when you've done the gear stiffening modification. I've seen the attachment that can go onto the gear leg that Van's sells, but the u-bolt in that arrangement would seem to crush the wood in the stiffener. Any flashes of brilliance would be appreciated. ________________________________________________________________________________
Date: Dec 20, 2003
I think I am being misinterpreted......I am talking about the studs that hold the prop on. Not the alignment bushings. thanx weasel > > Hey Girls(or Guys), >I was in the process of installing my prop tonight and it seems that the >set of studs that i have here with the motor are about 1/8" to long. They >protrude through the prop flange and hit the hub housing before the >flange tightens on the flywheel assembly. > Something is definitely amiss. The prop flange bushings do come in different lengths depending on their use (FP Vs. CS), but unless the engine has been converted, it shouldn't matter. One bushing is a little larger dia than the others, and that's what indexes the flywheel to the crank. You may not have the flywheel indexed correctly. Take out #1 plug and rotate crank to the compression stroke and place the piston at TDC (Top Dead Center). Now fit the flywheel up on the crank with the 0 at the top. The 0 on the backside of the flywheel should align itself with the case parting line. and should fit flush with the flange. Metal props are counterbored to take the extended length of the bushings, if there are any. I'm not sure of wood props are counterbored or not. The other way to get around changing the bushings (they ain't cheap) would be to get a prop spacer and add it to the stack. Problem is, that'll push the prop forward and you'll have a larger gap between spinner and cowl. Nothing's simple, is it???? Good luck. Linn > So guess I need shorter studs >to solve the problem. I checked Aircraft Spruce and didn't see any studs >listed. Is there some sort of spec. for this stud (i.e. 125000 or 160000 >psi ) that I can use to locate something locally or do I need to contact >Hartsel? Oh by the way it's a 0-320 with a Hartsel C/S. > > > > >Weasel Graber >-4 wanting to start engine!!! >Brooksville MS > > > ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Dec 20, 2003
rub some baby oil into your hands....it helps a bunch....trust me. Evan ----- Original Message ----- From: <Oldsfolks(at)aol.com> Subject: RV-List: Re:Cork or not to Cork? > > The pro-seal will grow off your hands in a month or two ! > > > Bob Olds A&P , EAA Tech. Counselor > RV-4 , N1191X , Flying Now > Charleston, Arkansas > "Real Aviators Fly Taildraggers" > > ________________________________________________________________________________
Subject: Re: Jacking up gear legs for wheel mtnce.
Date: Dec 20, 2003
Go for the Avery jack kit. No doubt!!! It's incredibly simple, very safe, and it doesn't require any sort of clamping. It jacks the plane up from the wheel, where balance is not as big of an issue. http://www.averytools.com/showoneitem.cfm?primarykey=618&cat=0&kit=0 For 35 bucks you can't go wrong. It only takes a few hours to modify the axle nut and then you're done. If you want photos showing the jack stand and axle nut modification, here they are: http://www.rvproject.com/20030411.html (scroll halfway down the page and you can't miss it) Best of luck, )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "DAVID DAVENPORT" <ddavenport5(at)nc.rr.com> Subject: RV-List: Jacking up gear legs for wheel mtnce. > > How are you guys jacking up RV-6 gear legs for wheel maintenance when you've done the gear stiffening modification. I've seen the attachment that can go onto the gear leg that Van's sells, but the u-bolt in that arrangement would seem to crush the wood in the stiffener. Any flashes of brilliance would be appreciated. > > ________________________________________________________________________________
Date: Dec 20, 2003
Subject: Propeller Performance
Netscape/7.1 (ax) Listers. A couple of weeks ago the hot topic on the list was about how the hartzell sweet spot is around 2600 rpm. I have flown umpteen times since then and the air has been too rough for any flight tests. Well this morning it was smooth. I now post some results. DA = 8205' MSL (I blew my calculations) OAT 63 Deg F RPM MAP IAS TAS 2600 24.0 188 207 2500 24.0 185 203 Two runs for each and averaged. Manifold and RPM are from mechanical gauges. For some reason she just would not spin up to 2700 this morning. Later this afternoon after it was good and hot I could get 2650 but no more. I need to adjust the governor. I plan on doing more when I get the chance. Happy holidays to all Gary Zilik ________________________________________________________________________________
Date: Dec 20, 2003
> How are you guys jacking up RV-6 gear legs for wheel > maintenance when you've done the gear stiffening > modification. I've seen the attachment that can go onto the > gear leg that Van's sells, but the u-bolt in that arrangement > would seem to crush the wood in the stiffener. Any flashes of > brilliance would be appreciated. > There are certainly many ways, but I use an inexpensive little floor jack supported on a few concrete blocks to lift the desired wing. I screw in a cast iron eye bolt into the tie down, and jack against that. I orient the floor jack laterally so that as I lift, the wheels of the floor jack allow it to move laterally. It seems that a couple 12" concrete blocks and some strips of plywood do the trick. BTW, this also allows for periodic removal of the gear leg for inspection. After about 350 hours and two years I did just this, and found that most of the grease I had put in at installation had disappeared, with some galled areas. Alex Peterson Maple Grove, MN RV6-A N66AP 424 hours www.usfamily.net/web/alexpeterson ________________________________________________________________________________
Date: Dec 21, 2003
SSANCjEuIGdyYWIgYSBzdG9vbCBhbmQgYSBib2F0IGN1c2hpb24gKG9uZSBvZiB0aG9zZSB0aHJv dyBhcm91bmQgb25lcy4gT3IgYW55IHBpbGxvdyBvciB3aGF0IGV2ZXIpDQoyIGdldCB1bmRlcm5l YXRoIHRoZSB3aW5nDQozLiBHZXQgb25lIG9yIDIgcmlicyBpbiBmcm9tIHRoZSB3aW5ndGlwDQo0 IFVzZSBteSBsZWdzIHdpdGggbXkgYmFjayBvbiB0aGUgc3BhciwgDQo1LiByYWlzZSBpdCB1cA0K Ni4gU2xpZGUgdGhlIHN0b29sIHVuZGVyIHRoZSB3aW5nIGF0IHRoZSBzcGFyLCBib2F0IGN1c2hp b24gb24gdG9wIG9mIHN0b29sLg0KNy4gV2FobGEsIHdoZWVsIG9mZiB0aGUgZ3JvdW5kIGluIGxl c3MgdGhhbiAxMCBzZWNvbmRzLg0KIA0KVGhpcyBpcyBxdWl0ZSBkb2FibGUgZXZlbiBmdWxsIG9m IGZ1ZWwgYW5kIHRha2VzIG5vIHRpbWUgYXQgYWxsLCBpcyBzYWZlLCBhbmQgbGVhdmVzIHRoZSB3 aGVlbCBhcmVhIGNsZWFyIHRvIGdldCB5b3VyIHdvcmsgZG9uZS4NCiANCkV2ZW4gZWFzaWVyIHRv IGxvd2VyIGl0LiBKdXN0IHJhaXNlIGl0IHVwLCBhbmQgc2xpZGUgdGhlIHN0b29sIG91dCBhbmQg eW91ciBkb25lLg0KIA0KSSBkbyB0aGlzIGV2ZW4gZm9yIHB1dHRpbmcgYWlyIGluIHRoZSB0aXJl cyBhcyBJIGNhbiBlYXNpbHkgcm90YXRlIHRoZSB3aGVlbCB0byBnZXQgdG8gdGhlIHN0ZW0uDQpN aWtlDQogDQogDQoNCgktLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLSANCglGcm9tOiBvd25lci1y di1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIG9uIGJlaGFsZiBvZiBBbGV4IFBldGVyc29uIA0K CVNlbnQ6IFNhdCAxMi8yMC8yMDAzIDEwOjE4IFBNIA0KCVRvOiBydi1saXN0QG1hdHJvbmljcy5j b20gDQoJQ2M6IA0KCVN1YmplY3Q6IFJFOiBSVi1MaXN0OiBKYWNraW5nIHVwIGdlYXIgbGVncyBm b3Igd2hlZWwgbXRuY2UuDQoJDQoJDQoNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTog IkFsZXggUGV0ZXJzb24iIDxhbGV4cGV0ZXJzb25AdXNqZXQubmV0Pg0KCQ0KCQ0KCT4gSG93IGFy ZSB5b3UgZ3V5cyBqYWNraW5nIHVwIFJWLTYgZ2VhciBsZWdzIGZvciB3aGVlbA0KCT4gbWFpbnRl bmFuY2Ugd2hlbiB5b3UndmUgZG9uZSB0aGUgZ2VhciBzdGlmZmVuaW5nDQoJPiBtb2RpZmljYXRp b24uIEkndmUgc2VlbiB0aGUgYXR0YWNobWVudCB0aGF0IGNhbiBnbyBvbnRvIHRoZQ0KCT4gZ2Vh ciBsZWcgdGhhdCBWYW4ncyBzZWxscywgYnV0IHRoZSB1LWJvbHQgaW4gdGhhdCBhcnJhbmdlbWVu dA0KCT4gd291bGQgc2VlbSB0byBjcnVzaCB0aGUgd29vZCBpbiB0aGUgc3RpZmZlbmVyLiBBbnkg Zmxhc2hlcyBvZg0KCT4gYnJpbGxpYW5jZSB3b3VsZCBiZSBhcHByZWNpYXRlZC4NCgk+DQoJDQoJ VGhlcmUgYXJlIGNlcnRhaW5seSBtYW55IHdheXMsIGJ1dCBJIHVzZSBhbiBpbmV4cGVuc2l2ZSBs aXR0bGUgZmxvb3INCglqYWNrIHN1cHBvcnRlZCBvbiBhIGZldyBjb25jcmV0ZSBibG9ja3MgdG8g bGlmdCB0aGUgZGVzaXJlZCB3aW5nLiAgSQ0KCXNjcmV3IGluIGEgY2FzdCBpcm9uIGV5ZSBib2x0 IGludG8gdGhlIHRpZSBkb3duLCBhbmQgamFjayBhZ2FpbnN0IHRoYXQuDQoJSSBvcmllbnQgdGhl IGZsb29yIGphY2sgbGF0ZXJhbGx5IHNvIHRoYXQgYXMgSSBsaWZ0LCB0aGUgd2hlZWxzIG9mIHRo ZQ0KCWZsb29yIGphY2sgYWxsb3cgaXQgdG8gbW92ZSBsYXRlcmFsbHkuICBJdCBzZWVtcyB0aGF0 IGEgY291cGxlIDEyIg0KCWNvbmNyZXRlIGJsb2NrcyBhbmQgc29tZSBzdHJpcHMgb2YgcGx5d29v ZCBkbyB0aGUgdHJpY2suDQoJDQoJQlRXLCB0aGlzIGFsc28gYWxsb3dzIGZvciBwZXJpb2RpYyBy ZW1vdmFsIG9mIHRoZSBnZWFyIGxlZyBmb3INCglpbnNwZWN0aW9uLiAgQWZ0ZXIgYWJvdXQgMzUw IGhvdXJzIGFuZCB0d28geWVhcnMgSSBkaWQganVzdCB0aGlzLCBhbmQNCglmb3VuZCB0aGF0IG1v c3Qgb2YgdGhlIGdyZWFzZSBJIGhhZCBwdXQgaW4gYXQgaW5zdGFsbGF0aW9uIGhhZA0KCWRpc2Fw cGVhcmVkLCB3aXRoIHNvbWUgZ2FsbGVkIGFyZWFzLg0KCQ0KCUFsZXggUGV0ZXJzb24NCglNYXBs ZSBHcm92ZSwgTU4NCglSVjYtQSBONjZBUCA0MjQgIGhvdXJzDQoJd3d3LnVzZmFtaWx5Lm5ldC93 ZWIvYWxleHBldGVyc29uDQoJDQoJDQoJXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCglfLT0gICAgICAgICAg ICAgIC0gVGhlIFJWLUxpc3QgRW1haWwgRm9ydW0gLQ0KCV8tPSBUaGlzIGZvcnVtIGlzIHNwb25z b3JlZCBlbnRpcmVseSB0aHJvdWdoIHRoZSBDb250cmlidXRpb25zDQoJXy09IG9mIExpc3QgbWVt YmVycy4gIFlvdSdsbCBuZXZlciBzZWUgYmFubmVyIGFkcyBvciBhbnkgb3RoZXINCglfLT0gZm9y bSBvZiBkaXJlY3QgYWR2ZXJ0aXNpbmcgb24gdGhlIE1hdHJvbmljcyBGb3J1bXMuDQoJXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCglfLT0gISEgTkVXICEhDQoJXy09IEFMTCBORVcgTElTVCBDSEFUISEgaHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL2NoYXQNCglfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KCV8tPSBMaXN0 IFJlbGF0ZWQgSW5mb3JtYXRpb24NCglfLT0gIFBvc3QgTWVzc2FnZTogICBydi1saXN0QG1hdHJv bmljcy5jb20NCglfLT0gIFVOL1NVQlNDUklCRTogICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v c3Vic2NyaXB0aW9uDQoJXy09ICBMaXN0IEZBUTogICAgICAgaHR0cDovL3d3dy5tYXRyb25pY3Mu Y29tL0ZBUS9SVi1MaXN0Lmh0bQ0KCV8tPSAgU2VhcmNoIEVuZ2luZTogIGh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9zZWFyY2gNCglfLT0gIDctRGF5IEJyb3dzZTogICBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vYnJvd3NlL3J2LWxpc3QNCglfLT0gIEJyb3dzZSBEaWdlc3RzOiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vZGlnZXN0L3J2LWxpc3QNCglfLT0gIExpdmUgTGlzdCBDaGF0OiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vY2hhdA0KCV8tPSAgQXJjaGl2ZXM6ICAgICAgIGh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9hcmNoaXZlcw0KCV8tPSAgUGhvdG8gU2hhcmU6ICAgIGh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9waG90b3NoYXJlDQoJXy09ICBMaXN0IFNwZWNpZmljOiAgaHR0cDov L3d3dy5tYXRyb25pY3MuY29tL3J2LWxpc3QNCglfLT0gIE90aGVyIExpc3RzOiAgICBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vZW1haWxsaXN0cw0KCV8tPSAgVHJvdWJsZSBSZXBvcnQgIGh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS90cm91YmxlLXJlcG9ydA0KCV8tPSAgQ29udHJpYnV0aW9uczog IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCglfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KCQ0KCQ0KCQ0KCQ0KCQ0KDQo ________________________________________________________________________________
Subject: Fw: Thank you from Jon Johanson
Date: Dec 21, 2003
----- Original Message ----- From: "Jon Johanson" <jonj(at)senet.com.au> Subject: Thank you from Jon Johanson > Hi, > There are so many people I want to say thanks to. I hope the attached will > help to do that and to provide some interesting facts. > > Please feel free to forward the attached letter to anyone you think may be > interested. > > Season's greetings and regards, > > > Jon Johanson ________________________________________________________________________________
Date: Dec 21, 2003
Perhaps I'm missing something. How can you get a wheel off to change a tire or grease a bearing when jack and jack point are inserted in the axle from outside the wheel? Please enlighten. Dave Reel - RV8A ________________________________________________________________________________
From: "Kyle Boatright" <kyle.boatright(at)adelphia.net>
Date: Dec 21, 2003
I wondered that myself once upon a time. Anyway, here's how you do it... 1) Jack up the wheel using the jack fixture that inserts into the axle. 2) Slide the wheel outboard. 3) Put a wood block under the axle so the axle rests on it when you lower the jack. This block must be tall enough to prevent the wheel from touching the ground. 4) Lower the jack and remove the jack fixture. 5) Pull the wheel off. 6) Reverse the procedure to remount the wheel. KB ----- Original Message ----- From: "DAVID REEL" <dreel(at)cox.net> Subject: Re: RV-List: Jacking up gear legs for wheel mtnce. > > Perhaps I'm missing something. How can you get a wheel off to change a tire or grease a bearing when jack and jack point are inserted in the axle from outside the wheel? Please enlighten. > > Dave Reel - RV8A > > ________________________________________________________________________________
Date: Dec 21, 2003
A word of caution about using the tie down point and a jack to raise the wing to remove the wheels. I have done this using a bolt welded onto a pipe cap that fit over the head of a bottle jack...prevents any chance of slipping...BUT there seems to be some pressures on the fuel tank, because after doing this I found a small fuel leak that was not present before using the tie-down point to jack up the wing...might just have been a coincidence, but I bought the axle jack and feel better about using it....removing fuel tanks and fixing leaks is not as much fun as you might expect. John ________________________________________________________________________________
Date: Dec 21, 2003
- jack it up - loosen axle nut - slide wheel over on the shaft - lower jack, lowering axle onto blocks - pull jack stand out of axle - wheel is free )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "DAVID REEL" <dreel(at)cox.net> Subject: Re: RV-List: Jacking up gear legs for wheel mtnce. > > Perhaps I'm missing something. How can you get a wheel off to change a tire or grease a bearing when jack and jack point are inserted in the axle from outside the wheel? Please enlighten. > > Dave Reel - RV8A > > ________________________________________________________________________________
Subject: Jon Johanson's Thank you Letter
Date: Dec 21, 2003
The following is a attachment that was part of Jon's thank you letter. I tried to forward it to the list but realize this didn't work so will send it as a post by myself. It is long but I think it is something that all RVer's would be interested in. Eustace Bowhay Dear friends: Since returning to Adelaide last Tuesday afternoon I haven't had time to think, let alone work out what day it is. I am only just becoming aware of the tremendous amount of help that so many offered to the "mission control" team in Adelaide over the past eleven days - A mission control like no other, as so many people around the world have discovered. Thank you does not seem to cover my gratitude adequately, still all I can say is thank you, thank you, thank you. What an amazing couple of weeks it has been. On the 17th of December the 100th anniversary of the first powered flight - achieved by a couple of home builders in their experimental aircraft, the Wright Flyer. On the 8th of December, almost 100 years later, it was another home built, experimental aircraft that was flown solo over the South Pole. RV-4TE VH-NOJ, the first aircraft to be flown solo to the South Pole. It is all a bit hard to believe. Despite the years of planning and knowing that we could do this safely, it has happened quickly enough for me to be tempted to feel that it is all a dream. Over the eleven days we were away, VH-NOJ carried me 8,282 nautical miles (15,338 km) in 61 hours and 15 minutes at an average speed of 135 knots (250 kph). The years of planning to conquer the South Pole safely have paid off with even the bureaucrats getting their moment in the sun. In time the bureaucracy will be forgotten, as it should be, and only the achievement will be remembered. Something that should never be forgotten though, is the generosity of one adventurous spirit to another - Polly Vacher and her team's selfless generosity in allowing me to use some of the fuel to safely complete my polar flight. How disappointing it must have been for Polly not to be able to reach her goal, but how typical of a team who have dedicated their time to helping disabled people gain their ultimate freedom through FLYING SCHOLARSHIPS FOR THE DISABLED ww.reachforthesky(at)btinternet.com May I again say thank you to everyone and wish you season's greetings and a happy prosperous new year. Kind Regards Jon Johanson An ordinary Australian doing extraordinary things. Pilot: Jon Johanson License: Australian Air Transport License (ATPL) with command multi engine instrument rating (CIR). Total flying experience: 5.890 hrs. Total time on type (RV 4) 3,242 hrs. Previous Polar experience: Northern Canada flight in company with Eustace Bowhay who has a life time of arctic experience, Yellowknife to the Northern Canadian coast, 1998. Trans -Polar flight, CYZF (Yellowknife) - CYEU (Eureka) - ENSB (Longyear, Spitsbergen) 2000. Aircraft: RV 4TE VH-NOJ Engine: AERO SPORT POWER (I0-360 M1B6) 180 HP. Turbo normalized, 5.8 litre four cylinder horizontally opposed, air cooled with programmable ignition. Fuel: Avgas/Mogas Fuel burn: Average 30 litres per hour, (Uses 10 litres per 100km, slightly better than a V6 Toyota Camry). Speed: Average 162kts (300 kph) Range: Still air average - 5,832 nm (10,800km) Endurance: Average - 36 hours non stop. Safety Equipment: EMERGENCY CHEST PACK Singe place life raft Life Jacket 406 satellite/GPS emergency locator beacon 121.5/243 emergency locator beacon Emergency flares Desalination unit Emergency rations (7 days) Water Sun Block Signaling mirror Anti emetic medicine General first aid equipment Safety Knife POLAR SURVIVAL PACK Polar, down sleeping bag Space blanket Thermal protection mattress Polar bivvy (sleeping bag tent) Backpackers pillow Electrically heated jacket, pants, socks and gloves Freezer over-suit Thermal underwear Nomex fire resistant flying suit Leather extreme weather hiking boots Sponsors: Aero Sport Power - Engine building Air BP/Castrol - Fuel and oil Andair - Quality fuel selectors etc. Aviaquip - Aircraft part supplies Bennet Built - Carbon fiber wheel spats Custom Aero - Custom aircraft rebuild, engine/turbo fit and tune Dayton Signs - Sign writing Fairydown - Discount polar survival equipment Garmin - GPS technology Good Year - Aircraft tyres JPinstruments - Engine monitoring instruments Lightspeed Engineering - electronic ignition Micro Aerodynamics Inc. - Vortex generators MT Propeller - Custom built, three blade constant speed propeller QBE Aviation - Insurance Riverina Airmotive- Engine tuning and consultancy ________________________________________________________________________________
Date: Dec 21, 2003
----- Original Message ----- From: "Laird Owens" <owens(at)aerovironment.com> > Ross, > It sounds like your confusing the VOR antenna I have and the COM > antenna. I've heard the COM antenna doesn't work well in the > wingtip, but I've also 2 local friends that like theirs. > Laird You are right. I have the Com antenna and find it very weak compared to my belly mounted standard com antenna. Since my Apollo GX 60 GPS/COM has a monitoring function, I am only using the Nav/Com as a backup and will probably leave it as is. If there are folks who are satisfied with tier Com wingtip installations, I would like to know how they installed them. Ross Mickey N9PT 20 hours....almost there ________________________________________________________________________________
Date: Dec 21, 2003
Dave, I hate to even mention this, but hey I've got a really good delete key, so hear goes. What I've done many times is crouch under the wing with my shoulder blades against the wing spar and just lift it up. I have a piece of foam between my back and the underside of the wing. I have the axle nut loose, the brake caliper apart. and a appropriate sized block of wood or auto jack stand ready to put in place. An assistant just undoes the axle nut the rest of the way, slides the wheel assembly off and sets the stand under the axle. Of coarse all the caveats about hurting your back etc. do apply. Also it's a lot easier if you have no fuel in the tanks. If you use both the jacking/ tie down point on a tail dragger at the same time they will fall on their nose. Casper Have a great holiday season. DAVID DAVENPORT wrote: > >How are you guys jacking up RV-6 gear legs for wheel maintenance when you've done the gear stiffening modification. I've seen the attachment that can go onto the gear leg that Van's sells, but the u-bolt in that arrangement would seem to crush the wood in the stiffener. Any flashes of brilliance would be appreciated. > > > > ________________________________________________________________________________
Date: Dec 21, 2003
Subject: Rod end bearing length
While doing the final fit of my elevators and pushrods, I found that the rear pushrod is a bit too short, maybe 3/16 inch. Each rod end bearing has about 3/16 inch less than the required 1/2 of the threads screwed in. It occured to me that by using more than one jamb nut (essentially double-nutting the jamb nuts) I could reduce the length of exposed thread so that the bearings could not back out at either end. Is this acceptable practice? Jeff Point RV-6 at airport, final assembly Milwaukee WI ________________________________________________________________________________
Date: Dec 21, 2003
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: Rod end bearing length
You should ask Vans, but my I believe that it is not the fact that the thread is "exposed" but the fact there is not enough thread length that is screwed into the end fitting. Adding jam nuts will not affect that. For example, if we carried your solution to the extreme we could end up with only one thread in the fitting and the rest "covered" by jam nuts - not likely very airworthy :-) ! just my $0.02 Dick Tasker, RV9A 90573 Jeff Point wrote: > >While doing the final fit of my elevators and pushrods, I found that the >rear pushrod is a bit too short, maybe 3/16 inch. Each rod end bearing >has about 3/16 inch less than the required 1/2 of the threads screwed >in. It occured to me that by using more than one jamb nut (essentially >double-nutting the jamb nuts) I could reduce the length of exposed >thread so that the bearings could not back out at either end. Is this >acceptable practice? > >Jeff Point >RV-6 at airport, final assembly >Milwaukee WI > ________________________________________________________________________________
Date: Dec 21, 2003
Or, just attach a screw clamp to the gear leg just below the fairing and use any floor or scissors jack. The clamp can be turned and left on the gear leg. If you use a "jack fixture" then you'll have to cart it around with you unless you have some other way of jacking the airplane. Dave -6, So Cal Kyle Boatright wrote: > >I wondered that myself once upon a time. Anyway, here's how you do it... > >1) Jack up the wheel using the jack fixture that inserts into the axle. > >2) Slide the wheel outboard. > >3) Put a wood block under the axle so the axle rests on it when you lower >the jack. This block must be tall enough to prevent the wheel from touching >the ground. > >4) Lower the jack and remove the jack fixture. > >5) Pull the wheel off. > >6) Reverse the procedure to remount the wheel. > >KB >----- Original Message ----- >From: "DAVID REEL" <dreel(at)cox.net> >To: "rvlist" >Subject: Re: RV-List: Jacking up gear legs for wheel mtnce. > > > > >> >>Perhaps I'm missing something. How can you get a wheel off to change a >> >> >tire or grease a bearing when jack and jack point are inserted in the axle >from outside the wheel? Please enlighten. > > >>Dave Reel - RV8A >> >> >> >> > > > > ________________________________________________________________________________
Date: Dec 21, 2003
Jeff Point wrote: > > While doing the final fit of my elevators and pushrods, I found that the > rear pushrod is a bit too short, maybe 3/16 inch. Each rod end bearing > has about 3/16 inch less than the required 1/2 of the threads screwed > in. It occured to me that by using more than one jamb nut (essentially > double-nutting the jamb nuts) I could reduce the length of exposed > thread so that the bearings could not back out at either end. Is this > acceptable practice? > > Jeff Point > RV-6 at airport, final assembly > Milwaukee WI > Jeff, using an additional nut should work fine as long as you are satisfied that enough thread is engaged in the pushrod to insure safety. I have also seen spacers installed between the nut and bearing to prevent the rod from rotating and "unscrewing" one of the bearings. Your suggestion accomplishes the same objective. Sam Buchanan http://thervjournal.com ________________________________________________________________________________
From: "Mickey & Paula" <mimartin(at)sweetwaterhsa.com>
Subject: Camloc Fasteners RV6
Date: Dec 21, 2003
Is there any dis-advantage to using the camloc fasteners for the cowling rather than the hinges used in the plans? It looks like the hinge pins would be a nuisance. ________________________________________________________________________________
Date: Dec 21, 2003
> > While doing the final fit of my elevators and pushrods, I > found that > > the > > rear pushrod is a bit too short, maybe 3/16 inch. Each rod > end bearing > > has about 3/16 inch less than the required 1/2 of the > threads screwed > > in. It occured to me that by using more than one jamb nut > (essentially > > double-nutting the jamb nuts) I could reduce the length of exposed > > thread so that the bearings could not back out at either > end. Is this > > acceptable practice? > > > > Jeff Point > > RV-6 at airport, final assembly > > Milwaukee WI > > > > Jeff, using an additional nut should work fine as long as you are > satisfied that enough thread is engaged in the pushrod to > insure safety. > I have also seen spacers installed between the nut and bearing to > prevent the rod from rotating and "unscrewing" one of the > bearings. Your > suggestion accomplishes the same objective. > > Sam Buchanan > http://thervjournal.com I would agree, but an additional requirement is that enough threads are captured EVEN if the whole thing rotates all the way towards one end. If there is any doubt, buy a new tube and rebuild the thing. Otherwise, you will lie awake wondering about it, as you should. Alex Peterson Maple Grove, MN RV6-A N66AP 424 hours www.usfamily.net/web/alexpeterson ________________________________________________________________________________
Subject: Re: Camloc Fasteners RV6
Date: Dec 21, 2003
The hinges are a nuisance for some people. I had problems, and used Skybolt fasteners along the top and bottom. I kept the hinges on the sides, which seemed to provide a better grip along the sides. Paul Besing RV-6A Sold (RV-10 Soon) http://www.lacodeworks.com/besing Kitlog Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Mickey & Paula" <mimartin(at)sweetwaterhsa.com> Subject: RV-List: Camloc Fasteners RV6 > > Is there any dis-advantage to using the camloc fasteners for the cowling rather than the hinges used in the plans? > It looks like the hinge pins would be a nuisance. > > ----- Original Message ----- From: "Mickey & Paula" <mimartin(at)sweetwaterhsa.com> Subject: RV-List: Camloc Fasteners RV6 > > Is there any dis-advantage to using the camloc fasteners for the cowling rather than the hinges used in the plans? > It looks like the hinge pins would be a nuisance. > > ________________________________________________________________________________
Date: Dec 21, 2003
Jeff, I'd be concerned about WHY it's too short - something is amiss somewhere. Have you checked the front pushrod to see if it's adjusted too short? Or is the rear tube actually cut too short? I'd want to correct the cause of the problem, not just fix the symptom. Dave Bristol -6 So Cal, EAA Technical counselor Jeff Point wrote: > >While doing the final fit of my elevators and pushrods, I found that the >rear pushrod is a bit too short, maybe 3/16 inch. Each rod end bearing >has about 3/16 inch less than the required 1/2 of the threads screwed >in. It occured to me that by using more than one jamb nut (essentially >double-nutting the jamb nuts) I could reduce the length of exposed >thread so that the bearings could not back out at either end. Is this >acceptable practice? > >Jeff Point >RV-6 at airport, final assembly >Milwaukee WI > > > > ________________________________________________________________________________
Date: Dec 21, 2003
Alex Peterson wrote: > > >>>While doing the final fit of my elevators and pushrods, I >> >>found that >> >>>the >>>rear pushrod is a bit too short, maybe 3/16 inch. Each rod >> >>end bearing >> >>>has about 3/16 inch less than the required 1/2 of the >> >>threads screwed >> >>>in. It occured to me that by using more than one jamb nut >> >>(essentially >> >>>double-nutting the jamb nuts) I could reduce the length of exposed >>>thread so that the bearings could not back out at either >> >>end. Is this >> >>>acceptable practice? >>> >>>Jeff Point >>>RV-6 at airport, final assembly >>>Milwaukee WI >>> >> >>Jeff, using an additional nut should work fine as long as you are >>satisfied that enough thread is engaged in the pushrod to >>insure safety. >>I have also seen spacers installed between the nut and bearing to >>prevent the rod from rotating and "unscrewing" one of the >>bearings. Your >>suggestion accomplishes the same objective. >> >>Sam Buchanan >>http://thervjournal.com > > > I would agree, but an additional requirement is that enough threads are > captured EVEN if the whole thing rotates all the way towards one end. > If there is any doubt, buy a new tube and rebuild the thing. Otherwise, > you will lie awake wondering about it, as you should. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 424 hours > www.usfamily.net/web/alexpeterson I am assisting the builders of a Pitts S-1 as their EAA Tech Counselor. We discussed the remote possibility of having an aileron pushrod rotate enough to disconnect a rod end bearing if the bearings aren't installed properly; one idea we pursued (even after insuring adequate threads were inside the pushrod) was to put a length of rubber hose on the rod end bearings to prevent a bearing from unscrewing more than a turn or so even if the lock nut was completely loose. After studying this setup, I think it will be included in all rod end bearing installations I make from now on. Sam Buchanan ________________________________________________________________________________
Date: Dec 22, 2003
>... one idea we pursued (even after insuring adequate threads were >inside the pushrod) was to put a length of rubber hose on the rod end >bearings to prevent a bearing from unscrewing more than a turn or so >even if the lock nut was completely loose. ... Hi Sam, I'm having a bit of trouble understanding how this would work. Perhaps my morning cup of caffeine has not yet gotten into the bloodstream. Do you have any pictures of this you can point me to? Thanks, Mickey -- Mickey Coggins GSM: +41-79-210-3762 FAX: +41-86-079-210-3762 http://www.rv8.ch/ #82007 Empennage complete, waiting for wings to arrive ________________________________________________________________________________
Date: Dec 22, 2003
The major disadvantage is cost, about $450 from Skybolt. They usually have a 30% off sale around the major airshows, I bought mine last year during Sun and Fun (not at the show) and saved a bundle. They make cowl removal a snap, I highly recommend them. Jeff Point Mickey & Paula wrote: > >Is there any dis-advantage to using the camloc fasteners for the cowling rather than the hinges used in the plans? >It looks like the hinge pins would be a nuisance. > > > > ________________________________________________________________________________
Date: Dec 22, 2003
Thanks to all who responded about the rod ends. In the end, I remade the forward tube by shortening it about 3/4 inch (it was too long, even with the bearings screwed in all the way) which solved the problem with the rear pushrod. I tested both by rotating them to both extremes and the rod ends remain intact. On a related note, someone mentioned the minimum thread engagement. What is the minimum thread engagement for a rod end bearing? For example, the elevator and rudder bearings, where the bearing rotating out is not an issue. While getting everything ready for final assmebly, I removed and inspected the bearings. I was surprised to find that some of them were only engaged into the nutplates about 5 threads (as shown by the wear marks on the threads.) This is using the proper dimensions for the elevator/ HS gap. Is this normal? There sure is a lot to this "final assembly" stuff... Jeff Point RV-6 final assembly Milwaukee, WI > > ________________________________________________________________________________
Date: Dec 22, 2003
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net>
Jeff Point wrote: > > Thanks to all who responded about the rod ends. In the end, I remade > the forward tube by shortening it about 3/4 inch (it was too long, even > with the bearings screwed in all the way) which solved the problem with > the rear pushrod. I tested both by rotating them to both extremes and > the rod ends remain intact. > > On a related note, someone mentioned the minimum thread engagement. > What is the minimum thread engagement for a rod end bearing? For > example, the elevator and rudder bearings, where the bearing rotating > out is not an issue. While getting everything ready for final assmebly, > I removed and inspected the bearings. I was surprised to find that some > of them were only engaged into the nutplates about 5 threads (as shown > by the wear marks on the threads.) This is using the proper dimensions > for the elevator/ HS gap. Is this normal? > > There sure is a lot to this "final assembly" stuff... > > Jeff Point > RV-6 final assembly > Milwaukee, WI Jeff, a rule of thumb that an aircraft bolt salesman told me a long time ago was " the grip of the threads should be at least the diameter of the bolt." He said anything less is not enough thread grip. He said anything more is ok but the grip becomes less and less with the threads that are farther in. This is what I have used over the years and it seems to work out OK. I feel that one Jam nut is sufficient. If I were concerned about the Jam nut coming loose, I would dab some epoxy on it, after it is TIGHT. Just a small dab where threads meet the nut. Phil Phil ________________________________________________________________________________
Date: Dec 22, 2003
In a message dated 12/22/03 12:51:43 AM Central Standard Time, mick-matronics(at)rv8.ch writes: > I'm having a bit of trouble understanding how this would > work. Perhaps my morning cup of caffeine has not yet gotten > into the bloodstream. Do you have any pictures of this you > can point me to? > My caffeine may have started to work- for the rod to rotate, both jam nuts must be loose. One bearing MUST screw INTO the rod. If you have the hose covering all the threads on both ends, it ain't going far before it hits that rubber cushion. Same for other forms of spacers- pretty slick, Sam- On a related note: It there any reason NOT to use lock washers on these jam nuts, such as an internal-tooth washer? From The PossumWorks Mark - rigging controls next couple of daze- how timely!! 8 ) ________________________________________________________________________________
Date: Dec 22, 2003
Mickey Coggins wrote: > > >>... one idea we pursued (even after insuring adequate threads were >>inside the pushrod) was to put a length of rubber hose on the rod end >>bearings to prevent a bearing from unscrewing more than a turn or so >>even if the lock nut was completely loose. ... > > > Hi Sam, > > I'm having a bit of trouble understanding how this would > work. Perhaps my morning cup of caffeine has not yet gotten > into the bloodstream. Do you have any pictures of this you > can point me to? > > Thanks, > Mickey > Mickey, the caffeine is probably fine; the pushrod setup is a little confusing it you haven't gotten to that point in your project. The pushrods under consideration are those that have rod end bearings on both ends. If the locknuts on both bearings loosened, the rod could rotate even though the bearings are still trapped by the bellcranks. The bearings have opposing threads; one is right-hand, the other is left-hand. So, if the rod rotates, one bearing will be screwed into the rod as the other is being screwed out of the rod. The discussion has been about how to stop the rotation of the rod before one of the bearings is screwed all the way out of the rod. There are three ways to prevent this from happening: 1) Mechanically secure one of the bearings to the pushrod via a cotter key, safety wire, peening the threads, welding, etc. 2) Be sure enough threads are engaged in the rod so the bearing being screwed into the rod bottoms out before the opposing bearing can be screwed completely out of the rod. If at least half of the threads of each bearing is in the rod when fitted, this will prevent the bearings from disconnecting from the rod even though there may be minimal threads engaged if the rod rotates all the way. 3) As a belt and suspenders method, the spacer can be used to prevent one of the bearings from screwing into the rod which would also prevent the opposing bearing from detaching from the rod. Whew! This whole situation is addressed because each bearing has opposing threads which is often overlooked by builders who haven't thought through this process. Obviously, if a pushrod is trapped by a non-rotating fastener on one end, this whole scenario is not possible. Hope this doesn't require an additional dose of caffeine! :-) Sam Buchanan ________________________________________________________________________________
Date: Dec 22, 2003
Sam Buchanan wrote: >This whole situation is addressed because each bearing has >opposing threads which is often overlooked by builders who haven't >thought through this process. --- Sam, I just have to ask -- why use opposing thread pitch anyway? Wouldn't it be better to just use identical rod ends? I must be missing something else here... Steve ________________________________________________________________________________
Date: Dec 22, 2003
Minor correction - the threads are the same rotation on both ends. When the rod rotates about the rod ends the length does not change. Turnbuckles (cables? How quaint!) have right and left hand threads so they can be shortened or lengthened. The accepted way to protect the turnbuckle from backing out is with safety wire. Sam doesn't often mis-speak - nice to know he's human. Greg > > > Mickey, the caffeine is probably fine; the pushrod setup is a little > confusing it you haven't gotten to that point in your project. > > The pushrods under consideration are those that have rod end > bearings on > both ends. If the locknuts on both bearings loosened, the rod could > rotate even though the bearings are still trapped by the > bellcranks. The > bearings have opposing threads; one is right-hand, the other is > left-hand. So, if the rod rotates, one bearing will be > screwed into the > rod as the other is being screwed out of the rod. The discussion has > been about how to stop the rotation of the rod before one of the > bearings is screwed all the way out of the rod. There are > three ways to > prevent this from happening: ________________________________________________________________________________
Date: Dec 22, 2003
I have both on my 6 and if I had to do it all over again, I would absolutely, positively, without question....... use the cam locks. Im sure the pins will get a lot easier after some more use but the camlocks are great. If you dont mind using both, I would suggest using hinge pins to hold the top and bottom cowls together and camlocks to secure it to the fuse. Its easy making the backing plates and attaching them to the fuse and there's plenty of room. Attaching them to the fiberglass takes more work and there's little room. Besides, the pins holding the halves together are pretty easy to remove/install. Good luck Jeff Dowling A whole 1.5 ----- Original Message ----- From: "Mickey & Paula" <mimartin(at)sweetwaterhsa.com> Subject: RV-List: Camloc Fasteners RV6 > > Is there any dis-advantage to using the camloc fasteners for the cowling rather than the hinges used in the plans? > It looks like the hinge pins would be a nuisance. > > ________________________________________________________________________________
Subject: Propellers
Date: Dec 22, 2003
I have the 74" blended airfoil prop on my 8A and have 11.5" tip to ground clearance. I have to taxi on an unimproved dirt/sod taxiway to get to my runway and have not had any problems so far. Even found grass fragments stuck in the castering nut but the prop tip was clean. Not sure if the 7A has a shorter nose strut or not but one thing is sure, the prop tip on both models will take some hits as time goes on and while the 74" can be cleaned up and cut back to a 72", the 72" may end up being scrap. Ron. -----Original Message----- From: Randy Lervold [mailto:randy@rv-8.com] Subject: Re: RV-List: Propellers Dave, If maximum performance is what you're after various bits of data I've seen would indicate the 74" is the choice. It will have a higher tip speed at a given rpm however and will therefore be a little bit noisier. Of course the 1" greater radius puts you that much closer to gravel etc. also. Because you have a nosewheel, and because any performance improvement will be very small, I'd use the 72" with any -A model. FWIW, Randy Lervold www.rv-8.com > > There has been some great prop. comparison testing done recently, but > unfortunately it did not include the new "Blended Airfoil" c.s. > Hartzell. Van's is now offering this prop. in both 72" and 74" models > for the 7A. Any thoughts as to what the performance difference would be > between the two on an O-360? TIA for the info and I hope you all have a > great and safe holiday. > > Dave > 7A Wiring > > ________________________________________________________________________________
Date: Dec 22, 2003
Greg Young wrote: > > Minor correction - the threads are the same rotation on both ends. When the > rod rotates about the rod ends the length does not change. Turnbuckles > (cables? How quaint!) have right and left hand threads so they can be > shortened or lengthened. The accepted way to protect the turnbuckle from > backing out is with safety wire. Sam doesn't often mis-speak - nice to know > he's human. > > Greg Thank you Greg! I guess I needed the caffeine shot!! You are indeed correct; however, my mistake doesn't change the fact that the rod CAN come apart if it rotates enough to unscrew one of the bearings. I got the thread thing confused with turnbuckles. Thanks for the catch. :-) Sam Buchanan ________________________________________________________________________________
Date: Dec 22, 2003
Canyon wrote: > > Sam Buchanan wrote: > >>This whole situation is addressed because each bearing has >>opposing threads which is often overlooked by builders who haven't >>thought through this process. > > --- > Sam, I just have to ask -- why use opposing thread pitch > anyway? Wouldn't it be better to just use identical rod ends? I must > be missing something else here... > > Steve Steve, you are correct; I screwed up by stating the bearings have opposing threads. What I was trying to say was that as one bearing is being turned into the rod, the other one will be turning out of the rod. The control rod can come apart if it rotates far enough to unscrew one of the bearings from the rod. The rubber hose spacer prevents this from happening. Wow...........I need a big cup of coffee........ Sam Buchanan ________________________________________________________________________________
Date: Dec 22, 2003
Sam Buchanan wrote: >Steve, you are correct; I screwed up by stating the bearings have >opposing threads. What I was trying to say was that as one bearing is >being turned into the rod, the other one will be turning out of the rod. --- Sam, Hey, no problem -- I'm getting some more coffee myself. Too early Monday for me to be thrashing my way through details anyway. :-) Regards, Steve ________________________________________________________________________________
Date: Dec 22, 2003
Subject: MAC trim servo malfunction: field report
Last week I had a failure of my elevator trim servo afer landing at a friend's airstrip. The servo would not return to takeoff trim from the landing trim position. Wiggling the wires and closely inspecting the mechanism didn't help, and it looked like I was facing a brief flight home while holding a lot of forward stick pressure in cruise. Finally, at the last minute, the buttons seemed to come alive again and I was able to dial in the correct trim for takeoff. The trim responded normally for in-cruise adjustments, but seemed to quit working again as I was setting up final approach trim. Back in the hangar, I confirmed that the trim module seemed electrically dead and the tab itself was able to move freely when disconnected from the servo. A 9v battery and clip leads applied directly to the MAC servo did not move the motor, so the problem had to be in there and not in the ship's wiring or switches. I pulled the servo from the elevator and immediately saw evidence of mud dauber wasp activity in the area. There were several mud nests between the servo housing and the mounting bracket. I opened the servo housing and found just a few specks of dirt inside, but it was enough to cause the malfunction. As soon as I cleaned that out, the servo worked normally on the 9v battery. I deduced that the grit that had entered the housing was interfering with the limit switch follower that is designed to be activated by the servo rod only at the extremes of travel. Any friction between these two mating parts will cause premature activation of the micro-switches and shut down the servo just as if the travel limit has been reached. Dirt particles cause the slide to be carried along by the servo rod and can produce erratic behavior in the limit switch mechanism. The final nagging question was how the wasp's dirt could have gotten inside such a well-designed and sealed unit. It turns out there is an Achilles heel: the square-section, gear-driven plastic rod that attaches to the clevis has a groove in the outer part of its length, and the wasp had filled that with mud, too. When the rod is half in and half out of the servo housing, the channel or longitudinal groove in the rod allows access to the inside of the housing. When the rod is fully extended or retracted, the rod fully fills the square hole in the housing and the unit remains impenetrable. These little wasp critters are quite resourceful! I hope the silicone sealant I have placed in this groove will prevent a return of the problem, as there is no way to escape the onslaught of these insects in the summer months, and they work very quickly. Listers might want to check your MAC trim servo installations for existing damage and then fill this groove with some kind of sealant. Just be sure whatever you use won't mechaniclaly bind the servo if it should come loose. -Bill Boyd ________________________________________________________________________________
Date: Dec 22, 2003
Subject: propeller indexing and engine smoothness
Over the weekend I had to pull the cowl and prop to make repairs on a broken aluminum alternator tension arm, and thought while I had the prop off anyway I would try a suggestion I had read about in the Sky Ranch Engineering Manual. It says that a flat four engine will run more smoothly if the prop is indexed to be in the same plane as the crank pins, meaning it is horizontal when the pistons are at top or bottom dead center. This orientation is 60 degrees away from the indexing that is traditional for Lycomings, which is a concession to ease of hand-propping. Well, I tried it and it works. The difference in smoothness was noticable from very first startup, and the engine is (subjectively) smoother at all rpm ranges. The prop now stops at about 1 o'clock position viewed from the front, as opposed to the traditional 10 o'clock position. The compression stroke is felt much lower down in the swing, making it indeed very awkward and dangerous to hand prop as you have to bend way over to pull it through. But since I never hand prop my plane, I consider it worth the trade off. I'm going to take a wild guess and say the vibration level is about half what it was before. I find myself now wondering if the dynamic balance I was considering before would even be worth the cost and effort. Now, if only we could solve the exhaust pulse floor vibration as easily ;-) -Bill Boyd ________________________________________________________________________________
Date: Dec 22, 2003
The only downside is the cost, but I think it's well worth it. I have one of each, my first RV6 has the pins, the 2nd has the Skybolt fasteners. Several huge advantages to me. #1) They were quicker and easier to install. #2) You can get the cowling off in a matter of seconds with no cussing, scraped or burnt hands, etc.. #3) I think they look good. I was nervous about how they would look compared to my pin installation, but it looks quite nice. Anyway, if you can afford it, I would at least use them for the top and bottoms of the cowl. Sides are optional, but I like having them all the way around. Just my 2 cents! Cheers, Stein Bruch RV6's, Minneapolis. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Mickey & Paula Subject: RV-List: Camloc Fasteners RV6 Is there any dis-advantage to using the camloc fasteners for the cowling rather than the hinges used in the plans? It looks like the hinge pins would be a nuisance. ________________________________________________________________________________
From: "Sam Mourning" <sammourning(at)earthlink.net>
Subject: For Sale RV-9A Tail, Wings, Fuse, Engine, Tools, Extras
Date: Dec 22, 2003
For Sale: RV-9A Tail (finished), Wings (finished) Fuse (nearing quickbuild stage), Tool set (including pneumatic squeezer and 3 yokes), Engine O-320-H2AD (first run), and extras. $21,000. Would prefer not to separate. Details at http://www.vondane.com/forsale/rv9a/ ________________________________________________________________________________
Date: Dec 22, 2003
I suggest there are two issues of concern here: 1) that the pushrod should not be allowed to rotate sufficiently that one end actually comes loose (yes, that's a no-brainer !); 2) that enough threads stay engaged at both rodend bearings to withstand the max push/pull force that is expected, (a bit more complicated to analyse). IOW, a couple of threads only may not be enough to carry the loads and cause a failure which would have the same effect as one end coming completely unscrewed. The rubber tubing idea would help both situations if the starting config was OK and the length of the tube was selected properly keeping in mind that this is a belt and suspenders add-on to the jam nuts with/or without locktite. Jim Oke RV-3, RV-6A Winnipeg, MB ----- Original Message ----- From: "Sam Buchanan" <sbuc(at)hiwaay.net> Subject: Re: RV-List: Rod end bearing length > > Canyon wrote: > > > > > Sam Buchanan wrote: > > > >>This whole situation is addressed because each bearing has > >>opposing threads which is often overlooked by builders who haven't > >>thought through this process. > > > > --- > > Sam, I just have to ask -- why use opposing thread pitch > > anyway? Wouldn't it be better to just use identical rod ends? I must > > be missing something else here... > > > > Steve > > > Steve, you are correct; I screwed up by stating the bearings have > opposing threads. What I was trying to say was that as one bearing is > being turned into the rod, the other one will be turning out of the rod. > > The control rod can come apart if it rotates far enough to unscrew one > of the bearings from the rod. The rubber hose spacer prevents this from > happening. > > Wow...........I need a big cup of coffee........ > > Sam Buchanan > > ________________________________________________________________________________
Date: Dec 23, 2003
Subject: Re:Camloc Fasteners RV6
Subject: Camloc Fasteners RV6 From: Mickey & Paula (mimartin(at)sweetwaterhsa.com) Date: Sun Dec 21 - 5:04 PM Is there any dis-advantage to using the camloc fasteners for the cowling rather than the hinges used in the plans? It looks like the hinge pins would be a nuisance. Mick, Cost may be among the considerations here. Camloc kits can get relatively expensive. You do have a couple of options though. As an inexpensive alternative, I installed the hinges per plans except where the (curved) upper cowl ties into the firewall flange. I fabricated a .050 strap similar in concept to what you would fab up if installing camloc receptacles but instead, installed a total of 24 #8 floating nutplates around the perimeter using tooling (a nutplate jig) to assure quality and repeatability. See http://www.eaa32.org/MembersProjects/Galati/galati.htm to see the strap. The upper cowl is attached with #8 SS screws and stainless Tinnerman washers. This arrangement has worked very well on my spam can and countless other airplanes out there and in 14 years, I have not had to replace a single nutplate. Cosmetically, the screws are no better or worse looking than camlocs for less overall cost. Worn screws are a simple matter to discard and replace. Admittedly if seconds count, in a head to head race with a camlock fitted cowl, it will take you a bit longer to remove using a power screw driver. That said, in a speed race, both fastening systems would lose out to exceptionally installed hinges. I'm not absolutely certain, and I'm sure someone will offer up a dutiful correction if I'm wrong, but I *think* the EAA's Young Eagle RV-6As use screws and nutplates to attach the entire cowl. In the end, you do have a couple of viable options. Rick Galati RV-6A Finishing --------------------------------- ________________________________________________________________________________
Date: Dec 23, 2003
i WNET TO THE LOCAL STEEL YARD, BOUGHT A 7/8" ROUND STEEL BAR 2FT LONG. PLUGS INTO THE AXLE WITH ENOUGH ROOM UNDERNEATH TO SLIDE A FLOOR JACK. jOHN dANIELSON ________________________________________________________________________________
Subject: more comfy tools
Date: Dec 23, 2003
Listers, In the never ending quest to make sheet metal work more pleasant, I bought a can of "Plasti-dip" at Harbor Freight and coated the handles of my cleco pliers. Neat stuff! Sometimes just the thought of handling ice cold metal tools during a wintertime building session is enough to make you want to stay on the couch. It took three dips to get a good thickness on the handles. I also bought a can of the stuff in aerosol can to spray the grip of my air drill and maybe the rivet gun too. A 14 oz can of the dip is $7, and I found it in red, yellow, black and clear. Brian Denk RV8 N94BD RV10 51 ________________________________________________________________________________
Date: Dec 23, 2003
John, That should work great in the shop but how about when you have a problem in the middle of Oklahoma? That's a lot of extra weight to carry around in the baggage compartment. Dave JDaniel343(at)aol.com wrote: > >i WNET TO THE LOCAL STEEL YARD, BOUGHT A 7/8" ROUND STEEL BAR 2FT LONG. PLUGS INTO THE AXLE WITH ENOUGH ROOM UNDERNEATH TO SLIDE A FLOOR JACK. >jOHN dANIELSON > > > > ________________________________________________________________________________
Date: Dec 23, 2003
I really only use this in the shop, but I don't think it weighs any more than the thing Avery sells. John Danielson ________________________________________________________________________________
Subject: Re: more comfy tools
Date: Dec 23, 2003
High Brian, Another option for comfy tools: Early on in my quest to build my 6A (horizontal stab) I encountered severe pain in my hand that radiated up my into arm when using the bare handled cleco pliers. I also noted that the bare handles where cold and tended to slip out of my grasp. because of the potential for damaging skins etc. I chose to cut lengths of the glue filled heat shrink and apply them to the cleco plier handles. After doing this I noticed the pains went away, the pliers where warmer to the hand and they stayed in hand better reducing the likelihood of dropped tool damage a bit. I had a screwdriver that seemed to hit the same nerve and the heat shrink improved that situation as well. The best of the season to all!, Jim in Kelowna ----- Original Message ----- From: "Brian Denk" <akroguy(at)hotmail.com> Subject: RV-List: more comfy tools > > Listers, > > In the never ending quest to make sheet metal work more pleasant, I bought a > can of "Plasti-dip" at Harbor Freight and coated the handles of my cleco > pliers. Neat stuff! Sometimes just the thought of handling ice cold metal > tools during a wintertime building session is enough to make you want to > stay on the couch. > > It took three dips to get a good thickness on the handles. I also bought a > can of the stuff in aerosol can to spray the grip of my air drill and maybe > the rivet gun too. A 14 oz can of the dip is $7, and I found it in red, > yellow, black and clear. > > Brian Denk > RV8 N94BD > RV10 51 > > ________________________________________________________________________________
Date: Dec 23, 2003
User-Agent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.4) Gecko/20030624 Netscape/7.1 (ax)
I wasn't knocking your idea John, in fact I agree - why buy something fancy when something simple will suffice. My point was why carry a special tool when a clamp that weighs only a couple of ounces, fastened to the gear leg, will work perfectly with almost any jack, in the shop or in the middle of Oklahoma. Dave JDaniel343(at)aol.com wrote: > >I really only use this in the shop, but I don't think it weighs any more than the thing Avery sells. >John Danielson > > > > ________________________________________________________________________________
Date: Dec 23, 2003
Subject: Bob Archer, the antenna expert.
MIME-Version: 1.0 Content-Transfer-Encoding: 7bit Content-Type: text/plain; charset="US-ASCII" Hi All, If any of you have a concern about the installation of your antenna(s), please give Bob Archer a call. He is very willing to discuss whatever antenna installation you have, or would like to have. Bob's phone number is (310) 316-8796. You may get an answering machine. Just leave your name and number, so he can call you back. There are more ways to install an antenna wrong, than there are correct ways. It's too frustration for me to even think of all the antenna problems friends of mine have created for themselves over the years. At least by talking to Bob, you'll have a good chance of creating a good antenna installation. Jim Ayers PS I have more stories about antennas than I have heard about Ivoprop. ________________________________________________________________________________
Subject: 4-40 plate nuts
Date: Dec 23, 2003
I'm looking for a source for 4-40 plate nuts. These are the same ones that Cleveland uses in the wingtip attach kit. I have sent them an email to see if I can just buy the plate nuts. ACS smallest version is 6-32. Anyone know of another source? Darwin N. Barrie Chandler AZ ________________________________________________________________________________
Subject: 4-40 plate nuts (disregard)
Date: Dec 23, 2003
ACS hard catalog doesn't have them, the online version does and it finally came back on line!! Thanks, Darwin ________________________________________________________________________________
Date: Dec 24, 2003
Hi All, If any of you have a concern about the installation of your antenna(s), please give Bob Archer a call. He is very willing to discuss whatever antenna installation you have, or would like to have. Bob's phone number is (310) 316-8796. You may get an answering machine. Just leave your name and number, so he can call you back. There are more ways to install an antenna wrong, than there are correct ways. It's too frustration for me to even think of all the antenna problems friends of mine have created for themselves over the years. At least by talking to Bob, you'll have a good chance of creating a good antenna installation. Jim Ayers PS I have more stories about antennas than I have heard about Ivoprop. :-) ________________________________________________________________________________
Date: Dec 24, 2003
Subject: Re: Bob Archer, the antenna expert.
Sorry about the multiple postings. I'm using AOL 9.0. Sometimes it sends the message and says so. Sometimes it sends the message, and doesn't say so. Sometimes it doesn't send the message. Sometimes it just lock up my computer. For this message, I had all of the above happen. Sorry. Jim Ayers ________________________________________________________________________________
Subject: Riveting wing leading edge ribs...anyone use pop rivets?
Date: Dec 24, 2003
I'm having the expected trouble riveting the leading edge ribs on my RV-7 wings....the list archives spell out various techniques involving grinding down offset rivet sets, use of hockey tape, manufacturing special bucking bars to enable back riveting etc. It occurs to me that it would be extremely simple to just use pop rivets. Has anyone done this? Would there be reduced structural integrity? Is there any reason not to, other than one's sense of aesthetics? Is there a recommended pop-rivet spec to use? Thanks, Jerry RV-7A Wings Tampa, FL ________________________________________________________________________________
Date: Dec 24, 2003
>>>I'm looking for a source for 4-40 plate nuts. These are the same ones that Cleveland uses in the wingtip attach kit. When you get the screws that attach the wing tips, get twice the number you think you will need as they are easy to strip out and you'll wind up needing extra. IMHO. Michael ________________________________________________________________________________
Date: Dec 24, 2003
Subject: Re: 4-40 plate nuts
In a message dated 12/23/2003 8:29:29 PM Pacific Standard Time, ktlkrn(at)cox.net writes: I'm looking for a source for 4-40 plate nuts. These are the same ones that Cleveland uses in the wingtip attach kit. I have sent them an email to see if I can just buy the plate nuts. How many do you need. I have some of the floating type that I would be glad to send you. GV (RV-6A flying 675 hrs) ________________________________________________________________________________
Subject: F-631 cabin frame
Date: Dec 24, 2003
I am proceeding very cautiously with the F-631 cabin frame (roll bar) for my RV-6A tip-up. The plans call out a nominal width measurement and what seems to be a strict height measurement. My fuselage is slightly wider at the F-605 bulkhead than normal, but I set up the F-631 width to compensate for that. To do this, I attached blocks to my work surface that define the width and height. The problem is this: As expected, there is a gap at the top center (shouldn't be a problem), but at the bottom, the inboard corners are about 1/8" higher than the outboard corners, which prevents the F-631 from lying flat on the structure. Should I trim this angle so the entire bottom of the F-631 sits flat? If I do, the overall height measurement will be a little lower than is called out. Am I worried too much? Thanks in advance for the help, and I want to wish everybody a Merry Christmas (or whatever you celebrate this time of year), and a Happy New Year. Jim Bower St. Louis RV-6A N143DJ Expand your wine savvy and get some great new recipes at MSN Wine. http://wine.msn.com ________________________________________________________________________________
From: Richard Meske <rmeske@gcfn.org> (SquirrelMail authenticated user rmeske) by www.gcfn.org with HTTP; Wed,
24 Dec 2003 13:26:41.-0500(at)matronics.com (EST)
Date: Dec 24, 2003
If you check the Matronics archives, there was a guy that purchased a batch earlier from Wicks on a special order. Just read it today. Rich Aircraft Extras, Inc. ________________________________________________________________________________
Date: Dec 24, 2003
.Thanks ----- Original Message ----- From: "Richard Meske (SquirrelMail authenticated user rmeske) by www.gcfn.org with HTTP" <rmeske@gcfn.org>; ; <24 Dec 2003 13:26:41.-0500(at)matronics.com (EST)> Subject: Re: RV-List: 4-40 plate nuts > > If you check the Matronics archives, there was a guy that purchased a batch > earlier from Wicks on a special order. Just read it today. > > Rich > Aircraft Extras, Inc. > > ________________________________________________________________________________
Date: Dec 24, 2003
Subject: Ballistic parachutes on RVs
From: Jeff Peltier <jeffpeltier(at)BRSparachutes.com>
Hello RV owners, Due to the very high interest exhibited by Vans owners over the years, we've currently entered into the design phase regarding the installation of BRS ballistic emergency parachute systems to Vans RV-6,-7 and -9. We have purchased a new fuselage for the purpose of static structural pull tests, and may be interested in acquiring other fuselages or parts for the various tests required of this effort. We are also open to any questions or comments that you may have regarding parachute installation on Vans aircraft. Any input will be appreciated. We would really like to hear from you. Jeff Peltier Design Engineer BRS INC. (651)457-7491 ________________________________________________________________________________
Date: Dec 24, 2003
I need almost 80. I think I found them at ACS. They were listed in the on-line catalog but not the hard copy. Darwin ----- Original Message ----- From: <Vanremog(at)aol.com> Subject: Re: RV-List: 4-40 plate nuts > > In a message dated 12/23/2003 8:29:29 PM Pacific Standard Time, > ktlkrn(at)cox.net writes: > I'm looking for a source for 4-40 plate nuts. These are the same ones that > Cleveland uses in the wingtip attach kit. I have sent them an email to see if I > can just buy the plate nuts. > How many do you need. I have some of the floating type that I would be glad > to send you. > > > GV (RV-6A flying 675 hrs) > > ________________________________________________________________________________
Date: Dec 24, 2003
I have gotten in the habit of "seasoning" all nut plates by using a steel socket head screw and some Boelube. Seems to loosen them up for easier final installation. Darwin ----- Original Message ----- From: "Kosta Lewis" <mikel(at)dimensional.com> Subject: RE: RV-List: 4-40 plate nuts > > >>>I'm looking for a source for 4-40 plate nuts. These are the same ones > that Cleveland uses in the wingtip attach kit. > > When you get the screws that attach the wing tips, get twice the number > you think you will need as they are easy to strip out and you'll wind up > needing extra. IMHO. > > Michael > > ________________________________________________________________________________
Date: Dec 24, 2003
Subject: Re: Ballistic parachutes on RVs
Very few accidents in RVs are such that a ballistic a chute would have helped. I realize that there were a couple structure failures that would have MAYBE saved a pilot but over all you are wasting your time. IMO!!! Jerry Jeff Peltier wrote: > >Hello RV owners, >Due to the very high interest exhibited by Vans owners over the years, we've >currently entered into the design phase regarding the installation of BRS >ballistic emergency parachute systems to Vans RV-6,-7 and -9. We have >purchased a new fuselage for the purpose of static structural pull tests, >and may be interested in acquiring other fuselages or parts for the various >tests required of this effort. We are also open to any questions or >comments that you may have regarding parachute installation on Vans >aircraft. Any input will be appreciated. We would really like to hear from >you. > > >Jeff Peltier >Design Engineer >BRS INC. >(651)457-7491 > > > > ________________________________________________________________________________
Date: Dec 24, 2003
Hi Jeff, Great news. I'll bite. How about the RV8? Can this be installed as a retrofit? Mickey >Hello RV owners, >Due to the very high interest exhibited by Vans owners over the years, we've >currently entered into the design phase regarding the installation of BRS >ballistic emergency parachute systems to Vans RV-6,-7 and -9. We have >purchased a new fuselage for the purpose of static structural pull tests, >and may be interested in acquiring other fuselages or parts for the various >tests required of this effort. We are also open to any questions or >comments that you may have regarding parachute installation on Vans >aircraft. Any input will be appreciated. We would really like to hear from >you. > > >Jeff Peltier >Design Engineer >BRS INC. >(651)457-7491 -- Mickey Coggins GSM: +41-79-210-3762 FAX: +41-86-079-210-3762 http://www.rv8.ch/ #82007 Empennage complete, waiting for wings to arrive ________________________________________________________________________________
Date: Dec 24, 2003
I would think the -10 would give you the best potential for customers - but I have a friend that would fly in my 6A if I had one of those chutes..... my .02 ----- Original Message ----- From: "Jeff Peltier" <jeffpeltier(at)BRSparachutes.com> Subject: RV-List: Ballistic parachutes on RVs > > Hello RV owners, > Due to the very high interest exhibited by Vans owners over the years, we've > currently entered into the design phase regarding the installation of BRS > ballistic emergency parachute systems to Vans RV-6,-7 and -9. We have > purchased a new fuselage for the purpose of static structural pull tests, > and may be interested in acquiring other fuselages or parts for the various > tests required of this effort. We are also open to any questions or > comments that you may have regarding parachute installation on Vans > aircraft. Any input will be appreciated. We would really like to hear from > you. > > > Jeff Peltier > Design Engineer > BRS INC. > (651)457-7491 > > ________________________________________________________________________________
Date: Dec 24, 2003
Jerry, What about the flights into IMC that we seem to have too often? Wouldn't a chute work in that situation, assuming of course the pilot realized that s/he was in trouble? Mickey >Very few accidents in RVs are such that a ballistic a chute would have >helped. I realize that there were a >couple structure failures that would have MAYBE saved a pilot but over >all you are wasting your time. >IMO!!! > >Jerry -- Mickey Coggins GSM: +41-79-210-3762 FAX: +41-86-079-210-3762 http://www.rv8.ch/ #82007 Empennage complete, waiting for wings to arrive ________________________________________________________________________________
Date: Dec 24, 2003
It would seem reasonable to me to have an agency such as the EAA petition the FAA to allow aircraft with BRS installed to perform aerobatics WITHOUT it's occupants having to wear parachutes!!! Now THAT would be a great deal! Ron. -----Original Message----- From: Mickey Coggins [mailto:mick-matronics(at)rv8.ch] Subject: Re: RV-List: Ballistic parachutes on RVs Jerry, What about the flights into IMC that we seem to have too often? Wouldn't a chute work in that situation, assuming of course the pilot realized that s/he was in trouble? Mickey >Very few accidents in RVs are such that a ballistic a chute would have >helped. I realize that there were a >couple structure failures that would have MAYBE saved a pilot but over >all you are wasting your time. >IMO!!! > >Jerry -- Mickey Coggins GSM: +41-79-210-3762 FAX: +41-86-079-210-3762 http://www.rv8.ch/ #82007 Empennage complete, waiting for wings to arrive ________________________________________________________________________________
Subject: Re: F-631 cabin frame
Date: Dec 25, 2003
Jim, does your plans say position the brace 1/4 inch below top center of roll bar? If so, then Van's has again ignored "free support" from builders who point out errors in their drawings. If it shows 13/16ths or something on that order, then they have fixed the error. I used Intellicad to create a the side view of fuselage in that area and the roll bar and brace, etc. Sent it to Van's - never a response. I'm away from home for Christmas until the following Sat, Sun, or Mon so don't have my exact measurement. You are on the right track laying out a pattern on the workbench and putting in physical blocks to hold the width dimension for the two "feet". You need a line and block at top center, with a line below to show the height "from feet to top" - which you have to calculate with trig since they don't show that dimension in the plane of the roll bar. Mine is finished and fits perfectly on the fuselage. Give me a call on my cell phone 409-718-8518 or at my son's home 512-266-6955. David Carter RV-6 tip-up Nederland, Texas > > I am proceeding very cautiously with the F-631 cabin frame (roll bar) for my > RV-6A tip-up. The plans call out a nominal width measurement and what seems > to be a strict height measurement. My fuselage is slightly wider at the > F-605 bulkhead than normal, but I set up the F-631 width to compensate for > that. To do this, I attached blocks to my work surface that define the > width and height. > > The problem is this: As expected, there is a gap at the top center > (shouldn't be a problem), but at the bottom, the inboard corners are about > 1/8" higher than the outboard corners, which prevents the F-631 from lying > flat on the structure. > > Should I trim this angle so the entire bottom of the F-631 sits flat? If I > do, the overall height measurement will be a little lower than is called > out. Am I worried too much? > > Thanks in advance for the help, and I want to wish everybody a Merry > Christmas (or whatever you celebrate this time of year), and a Happy New > Year. > > Jim Bower > St. Louis > RV-6A N143DJ --------------------------------------------- This message was sent using EXP Webmail. http://www.exp.net ________________________________________________________________________________
Subject: Re: RV and Ballastic Chute
Date: Dec 24, 2003
> Hi Jeff, > > I don't know if the RV crowd is that good a market for the ballistic > chute. I have a total of 12 minutes glider time in an RV over two > occasions all resulting in a safe, no-damage touch-down. One after a 12 > Miles glide from 9500 MSL. I personally, would not have been tempted to use > the ballistic chute, had one been installed. > > However, I can imagine scenarios where they might be more appealing. > Certainly, if I found myself in IFR conditions and on verge of losing > control the chute would undoubtedly have appeal as a "last chance". I think > that perhaps the RV-10 might be a more likely market for the chute. Nothing > against the chute, I know it has saved a number of lives. But, its just not > for me in an RV-6. I suspect that should I ever really want it that I would > be in a situation that it would be outside a reliable deployment envelope. > > FW > > Sincerely > > Ed Anderson > > > Ed Anderson > RV-6A N494BW Rotary Powered > Matthews, NC > eanderson(at)carolina.rr.com > ________________________________________________________________________________
Date: Dec 24, 2003
If a BRS wasn't cost or weight prohibitive I would be interested. It's already proven to save lives, I curious if it would lower insurance premiums also? It could pay for it's self over a few years if so. Karie Daniel RV-7A QB Sammamish, WA. Merry Christmas All! ----- Original Message ----- From: "Jeff Peltier" <jeffpeltier(at)BRSparachutes.com> Subject: RV-List: Ballistic parachutes on RVs > > Hello RV owners, > Due to the very high interest exhibited by Vans owners over the years, we've > currently entered into the design phase regarding the installation of BRS > ballistic emergency parachute systems to Vans RV-6,-7 and -9. We have > purchased a new fuselage for the purpose of static structural pull tests, > and may be interested in acquiring other fuselages or parts for the various > tests required of this effort. We are also open to any questions or > comments that you may have regarding parachute installation on Vans > aircraft. Any input will be appreciated. We would really like to hear from > you. > > > Jeff Peltier > Design Engineer > BRS INC. > (651)457-7491 > > ________________________________________________________________________________
Date: Dec 24, 2003
Jim: The hight of your roll bar critical. Don't drill the roll bar in untill you are sure of the height. Also make sure the angle is correct. The bottom will take care of itself. I've built two RVs with tip-up canopy's and both could have been better. Doyle RV7A 160hrs 180 Cspeed what an awsome airplane. ________________________________________________________________________________
Date: Dec 24, 2003
Subject: Pneumatic rivet squeezer
Hi All, Looking to purchase a Pneumatic rivet squeezer. Anyone wanting to sell, please email at - plaurence@the-beach.net thanks peter ________________________________________________________________________________
Date: Dec 24, 2003
I have heard of two Cirrus aircraft where the parachutes saved the life of it's occupant. One was clear VFR test flight after maintenance when a part (aileron) fell off (I think). Many other small experimentals also. Seems like a good idea to provide another measure of safety and another escape route for something unexpected. Why not! Jack RV9A -- ________________________________________________________________________________
Subject: Re: Jacking up gear legs for wheel mtnce
Date: Dec 25, 2003
The axles that came with my finish kit from Van's for my "8" are solid axles. They only have a 3/4 dia. hole 3/4" deep. Not enough area to pick up 1/2 an airplane, I wouldn't think. You must have drilled axles. If you are using a 7/8" bar down the center of a 1.25 axle, I think I'd be a little concerned about the axle wall thickness. I know on Cessna 170's you check to see if the airplane has solid or drilled axles. A broken axle on landing will ruin your day . Rich Crosley RV-8, engine, Palmdale, CA ________________________________________________________________________________
Date: Dec 25, 2003
On the leading edge installation, I used solid rivets where I could get a good one, and pop rivets where the quality of my blind rivet installation would be in doubt. The way I see it, a good blind rivet (as long as it's structurally ok) is better than a badly installed solid rivet. I am more interested in a good strong airframe than a champion aircraft. Cammie I'm having the expected trouble riveting the leading edge ribs on my RV-7 wings....the list archives spell out various techniques involving grinding down offset rivet sets, use of hockey tape, manufacturing special bucking bars to enable back riveting etc. It occurs to me that it would be extremely simple to just use pop rivets. Has anyone done this? Would there be reduced structural integrity? Is there any reason not to, other than one's sense of aesthetics? Is there a recommended pop-rivet spec to use? Thanks, Jerry RV-7A Wings Tampa, FL ________________________________________________________________________________
Date: Dec 25, 2003
David, Thanks for the help! After reading the replies to my post, and doing a little more thinking, I reached the following conclusion: I am going to jig those parts so as to eliminate the gap at top center. In so doing, the height dimension is exactly 1/4" shorter than called on the plans. HOWEVER, the plans show the F-631 dimension from the top of the F-605 to the top of the F-631 (measured on a slant). This means that if the 631 itself is shorter, no big deal. Just compensate by moving it up on the feet until the correct distance has been achieved. As to the 1/4" distance from the roll bar top to the top of the brace...my plans still have 1/4" called out. I have seen various treatments of that topic, from 0 to the full 1/4". If I am not mistaken, that gap is really meaningless as the top of that brace does not contact anything, right? (Or wrong?) Happy new year Jim >From: dcarter(at)datarecall.net >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: F-631 cabin frame >Date: Thu, 25 Dec 2003 00:51:41 GMT > > >Jim, does your plans say position the brace 1/4 inch below top center of >roll >bar? If so, then Van's has again ignored "free support" from builders who >point out errors in their drawings. If it shows 13/16ths or something on >that >order, then they have fixed the error. > >I used Intellicad to create a the side view of fuselage in that area and >the >roll bar and brace, etc. Sent it to Van's - never a response. > >I'm away from home for Christmas until the following Sat, Sun, or Mon so >don't >have my exact measurement. > >You are on the right track laying out a pattern on the workbench and >putting >in physical blocks to hold the width dimension for the two "feet". You >need a >line and block at top center, with a line below to show the height "from >feet >to top" - which you have to calculate with trig since they don't show that >dimension in the plane of the roll bar. > >Mine is finished and fits perfectly on the fuselage. > >Give me a call on my cell phone 409-718-8518 or at my son's home >512-266-6955. > >David Carter >RV-6 tip-up >Nederland, Texas > > > > > I am proceeding very cautiously with the F-631 cabin frame (roll bar) >for my > > RV-6A tip-up. The plans call out a nominal width measurement and what >seems > > to be a strict height measurement. My fuselage is slightly wider at the > > F-605 bulkhead than normal, but I set up the F-631 width to compensate >for > > that. To do this, I attached blocks to my work surface that define the > > width and height. > > > > The problem is this: As expected, there is a gap at the top center > > (shouldn't be a problem), but at the bottom, the inboard corners are >about > > 1/8" higher than the outboard corners, which prevents the F-631 from >lying > > flat on the structure. > > > > Should I trim this angle so the entire bottom of the F-631 sits flat? >If I > > do, the overall height measurement will be a little lower than is called > > out. Am I worried too much? > > > > Thanks in advance for the help, and I want to wish everybody a Merry > > Christmas (or whatever you celebrate this time of year), and a Happy New > > Year. > > > > Jim Bower > > St. Louis > > RV-6A N143DJ > > >--------------------------------------------- >This message was sent using EXP Webmail. >http://www.exp.net > > Get reliable dial-up Internet access now with our limited-time introductory ________________________________________________________________________________
Subject: Elevator bolt ?s / Misc.
Date: Dec 25, 2003
Here are the first two: * bolt/nut part number that attaches elevator c-weight (new style) AN509-10R24 screw AN960-10 washer AN365-1032 nut (two of each per elevator) * bolt/nut that attaches elevator to HS AN3-7A bolt AN960-10 washer AN365-1032 nut (also 2 of each per elevator). HTH. Radomir ________________________________________________________________________________
Date: Dec 25, 2003
Jim, 1. Gap at top center is not a "strength" issue. Can have a gap - the 2 plates that connect the halves provide 100% of the strength. Butting the ends together adds nothing, so don't worry about the gap, if you should find, on reflection (about things to follow), that you might need a bit of a gap. 2. About the top brace distance down from top: It is true that is has nothing to do with the canopy material. However, it really is quite a big deal in getting the brace to hit the right spot on the baggage bulkhead and for the bottoms of the 631 roll bar to be positioned correctly for-aft so as to be CENTERED over the seat back AND some piece under it that you have to find on the drawings - otherwise, edge distances are if'y (luck or not). - I went to a flyin and observed a flying RV-6 with the feet about 3/4 inch too far forward and therefore the bolts coming straight up thru seat back stuff was NOT through all the structural stuff - it was only through a single piece of sheet. (wish I had the drawing in front of me) - From the drawings, I drew the underlying stuff on top of the seat back to show the boundaries of where the feet could go and drew a centerline, then drew the shape of the roll bar feet angles in that area to help me position the roll bar correctly. Then all kind of convoluted measuring to check ht - the seat back brace sags in the middle where the ht dimention is supposed to be checked, so I shimmed and. . . . . . - If you wait until I get home Sat or Mon I can tell you exactly what the dimension is for brace down from top. Use that and then trim bottoms if needed and everything fits fine - in the areas you have drawn. - In any case, you may have to trim off part of the inner edge of the bottoms of the roll bar to get the height dimension correct. There really is no way from the plans to get all this stuff right - jigging like you are doing is the key - plus don't shy away from the simple trig to get the height dimension the plans don't give you. 3. Just a word of caution about "moving the roll bar bottoms up on the feet (angles)" to get the height dimension called out in the plans: There is the normal issue of edge distance at top of feet/angles and bottom of roll bar ends that will impose some degree of limit on how much you can trim the feet. David ph away from home = 512-266-6955 & cell 409-718-8518 > > David, > > Thanks for the help! After reading the replies to my post, and doing a > little more thinking, I reached the following conclusion: > > I am going to jig those parts so as to eliminate the gap at top center. In > so doing, the height dimension is exactly 1/4" shorter than called on the > plans. HOWEVER, the plans show the F-631 dimension from the top of the > F-605 to the top of the F-631 (measured on a slant). This means that if the > 631 itself is shorter, no big deal. Just compensate by moving it up on the > feet until the correct distance has been achieved. > > As to the 1/4" distance from the roll bar top to the top of the brace...my > plans still have 1/4" called out. I have seen various treatments of that > topic, from 0 to the full 1/4". If I am not mistaken, that gap is really > meaningless as the top of that brace does not contact anything, right? (Or > wrong?) > > Happy new year > > Jim --------------------------------------------- This message was sent using EXP Webmail. http://www.exp.net ________________________________________________________________________________
Subject: Ballistic parachutes tests
Date: Dec 26, 2003
From: "Frank van der Hulst (Staff WG)" <F.vanderHulst(at)ucol.ac.nz>
SSdsbCBiaXRlIG9uIHRoZSAiV2h5IG5vdCEiLi4uDQogDQoxLiBXaGV0aGVyIG9yIG5vdCBhIEJS UyBzYXZlZCB0aGUgbGl2ZXMgb2YgdGhlIENpcnJ1cyBwaWxvdHMgaXMgc3BlY3VsYXRpdmUuDQog DQoyLiBNb3N0IGZvcmNlZCBsYW5kaW5ncyBhcmUgZHVlIHRvIGxhY2sgb2YgZnVlbCAtLSBiZXR0 ZXIgdG8gdXNlIHRoZSBCUlMgc3BhY2Uvd2VpZ2h0IGZvciBhbiBleHRyYSB0YW5rDQogDQozLiBN b3N0IGNyYXNoZXMgYXJlIGR1ZSB0byBwaWxvdCBlcnJvciAtLSBiZXR0ZXIgdG8gdXNlIHRoZSBC UlMgcHJpY2UgZm9yIGJldHRlciB0cmFpbmluZw0KIA0KNC4gVGhlIHNpemUvd2VpZ2h0IG9mIGEg QlJTIHdpbGwgdHVybiBhIDItcGxhY2UgUlYgaW50byBlZmZlY3RpdmVseSBhIHNpbmdsZS1wbGFj ZS4NCiANCjUuIFBvcHBpbmcgdGhlIEJSUyB3aWxsIHNhdmUgeW91ciBsaWZlIGF0IHRoZSBjb3N0 IG9mIHdyaXRpbmcgb2ZmIHlvdXIgYWlyY3JhZnQgYW5kIGdpdmluZyB5b3Ugc2V2ZXJlIGluanVy aWVzLi4uIGdpdmVuIHRoaXMgYW5kICg0KSwgcGVyc29uYWwgcGFyYWNodXRlKHMpIGZvciBwaWxv dCBhbmQgcGFzc2VuZ2VyIGFyZSBiZXR0ZXIgdmFsdWUgaW4gZXZlcnkgc2Vuc2UNCiANCjYuIFdo ZW4gcGVvcGxlIHBlcmNlaXZlIHRoYXQgdGhleSBoYXZlICJhbm90aGVyIG1lYXN1cmUgb2Ygc2Fm ZXR5IGFuZCBhbm90aGVyIGVzY2FwZSByb3V0ZSBmb3Igc29tZXRoaW5nIHVuZXhwZWN0ZWQiLCB0 aGV5IHRha2UgbW9yZSByaXNrcy4NCiANCkZyYW5rDQogDQogDQoNCgktLS0tLU9yaWdpbmFsIE1l c3NhZ2UtLS0tLSANCglGcm9tOiBqYWNrIGVja2RhaGwgW21haWx0bzplY2tkYWhsQGRlbGxtYWls LmNvbV0gDQoJU2VudDogVGh1IDI1LzEyLzIwMDMgNDo1NyBwLm0uIA0KCVRvOiBydi1saXN0QG1h dHJvbmljcy5jb20gDQoJQ2M6IA0KCVN1YmplY3Q6IFJWLUxpc3Q6IEJhbGxpc3RpYyBwYXJhY2h1 dGVzIHRlc3RzPU1TR0lEX0ZST01fTVRBX0hFQURFUg0KCQ0KCQ0KDQoJLS0+IFJWLUxpc3QgbWVz c2FnZSBwb3N0ZWQgYnk6ICJqYWNrIGVja2RhaGwiIDxlY2tkYWhsQGRlbGxtYWlsLmNvbT4NCgkN CglJIGhhdmUgaGVhcmQgb2YgdHdvIENpcnJ1cyBhaXJjcmFmdCB3aGVyZSB0aGUgcGFyYWNodXRl cyBzYXZlZCB0aGUgbGlmZSBvZiBpdCdzIG9jY3VwYW50LiBPbmUgd2FzIGNsZWFyIFZGUiB0ZXN0 IGZsaWdodCBhZnRlciBtYWludGVuYW5jZSB3aGVuIGEgcGFydCAoYWlsZXJvbikgZmVsbCBvZmYg KEkgdGhpbmspLiBNYW55IG90aGVyIHNtYWxsIGV4cGVyaW1lbnRhbHMgYWxzby4gIFNlZW1zIGxp a2UgYSBnb29kIGlkZWEgdG8gcHJvdmlkZSBhbm90aGVyIG1lYXN1cmUgb2Ygc2FmZXR5IGFuZCBh bm90aGVyIGVzY2FwZSByb3V0ZSBmb3Igc29tZXRoaW5nIHVuZXhwZWN0ZWQuIFdoeSBub3QhICBK YWNrIFJWOUENCgktLQ0KCQ0KDQo ________________________________________________________________________________
Date: Dec 25, 2003
As rv6tc was saying: > > Weight, cost, complexity. And a false sense of security... -Kysh -- | 'Life begins at 120kias' - http://www.lapdragon.org/flying | | CBR-F4 streetbike - http://www.lapdragon.org/cbr | | 1968 Mustang fastback - http://www.lapdragon.org/mustang | | Got 'nix? - http://www.infrastructure.org/ | | KG6FOB - http://www.lapdragon.org/ham | | Give blood: Play Hockey! http://www.unixdragon.com/ | ________________________________________________________________________________
Date: Dec 25, 2003
>From what I remember from flying a Cirrus with a BRS, the descent rate is >around 1500 fpm on impact with the ground. Cirrus occupants have the >benefit >of seats that are designed to "crumple" from the vertical load this descent >causes. Also, the only approved spin recovery in a Cirrus is the deployment >of the BRS, I don't think the RV series has a record of getting into >unrecoverable spins that would need a BRS. What appears to be a necessary >safety feature in a Cirrus might not in demand in the RV world. >Cammie >RV7a >Ailerons Say WHAAAT?!? The only way to recover a Cirrus from a spin is to blow the chute? Egads. How do such airplanes get sold, and more to the point, who would buy one? I'm striking the Cirrus from my "would like to fly someday" list. Brian Denk RV8 N94BD RV10 51 headed my way. Make your home warm and cozy this winter with tips from MSN House & Home. http://special.msn.com/home/warmhome.armx ________________________________________________________________________________
Date: Dec 25, 2003
Personally, I would use a personal chute pack if I were wanting to come down in a chute. There is a little bit of control available. I dont think there is any control in the BRS. Then on the other hand, you can just go fly it.. And have fun.............. Cost for two good used packs.... $800 to 1600, new ones about 1100 or 1200 each. cost to repack both of them.... about $300 per year >Just an oppinion, Phil > > > > ________________________________________________________________________________
Subject: Rv Christmas
Date: Dec 25, 2003
Hi Listers , And a merry Christmas and even better New Year to you all. Another Christmas. And where are we with the RV, our timeline, and mission statement ..flying wise ? A mystical day, in a sense, Christmas before the frenzy of driving, dinner, family, kids, job, time,...more time we need to get to where we want to be...RV wise, we don't talk about it much, we just have this goal.... Finish it and fly it...consummation...... And for those fortunate to be done, time on our side and finished, the hangar door is our holy grail... In my part of the world, rain was forecast, but as usual, they are only 50 % right...Expert weather man that I am, I am batting just as good an average as the TV weather man, in that my forecast says that the weather today will be much like it was yesterday...and my average is pretty good. Yes, there is a cloudbase about 3,000...but light and pink underneath and lightwind. A good day to fly when so many others have other things to do and agendas of far more import. Do you secretly sense a kind of thrill when you unlock the hangar door and see your RV spinner the first to greet you and tell you that all the work and time and money and lies and budget fudging are standing here, waiting for you to open the doors all the way and let me out and start the engine and listen to nothing else but the prop and exhaust and the monotone of ATIS and finally lift your gaze to clear taxi ? Even though I try each time to stay straight on the painted line as throttle up pulls me along, I always stagger a bit and before I can feel I have command enough to make this horse track straight...the wheels are no longer exacting any drag for they are free of the tarmac and we are rising swiftly. It is as easy as that ! I don't even mind the noise, and it drowns everything else, but I have things to do, and enjoying the falling away landscape seems to be the uppermost .. Turn off the boost pump, trim a bit, throttle the noise back, get a smug smile at what the GPS is saying and look around.....ain't this a special way to spend part of a Christmas day ?... Later, at the table, with family dear, and kids and spouses and in-laws....this is a special time of get together and values, but an RV pilot has already had their " religious experience " this day... Ever been to a stadium out of season ? when all the seats are empty and the crowd and noise are but a memory ? Weird. Well, landing at a normally busy field on Christmas day to find it empty, the coffee shop closed and dark and no other sounds of airplanes starting up or taxiing in is equally weird.... Are we the only airplane guys in the sky today ? Heading home with the wind at our backs and GPS telling amazing stories, home field appears at 10 o'clock and nobody else is talking to the tower...at first, I wonder if the radio is working....no voices.... But good old radio does work and a voice bids " straight in " from 6 miles out....or more.... My landings are never the same as to how far out I get serious, but finally I quit looking at the airspeed and just how high or low the nose seems to be from the paint lines and somehow the RV finds her own glidepath and the tires kiss the blacktop.......now rolling out is something else again because I think I am a lousy pilot and I get a shimmy and try to kil it by back pressure, and it works..for a while.....by this time...it is time to clear active and why I have to monitor ground beats me as there is no other life around..but home we go and put her away and before closing the doors, my hand on the cowling feels the warmth of life and I sense the wonder of all these parts that bore me up once more for my " fix ".... I believe I am addicted.... At locking up, my thoughts turn to those I have known or read about who no longer have a Christmas for whatever reason and those who made it safe for me to enjoy what others paid the ultimate price for me to savour. God bless you all, and those forever young.. Austin. ________________________________________________________________________________
Subject: RV-6 wings for sale
Date: Dec 25, 2003
Fellow Listers: A quick re-posting of this for a local friend here in Minneapolis: RV-6 wings from partially completed kit. The wings are 90% finished and includes center section components. Price reduced to $3000 Contact me off list and I'll forward your inquiry. Thanks Doug Weiler Hudson, WI ________________________________________________________________________________
Date: Dec 25, 2003
Paul: Don't do aerobatics your butt can't cash. ? What does that mean. Doyle RV7A ________________________________________________________________________________
Date: Dec 26, 2003
>Question is...... >Will you feel the same if/when the NTSB reports document >that the BRS chute is not nearly the panacea many envision. > >Unfounded confidence seems to be the rule rather then the >exception in today's technical world and hype is the life blood >of the folks in marketing. Hi Bob, I could not agree more. If the reports show that the BRS does not increase safety, then I won't consider it further. I guess if you went back to the Matronics archives from the 30's :-) you would find the same debate about aircraft ejection seats. Not much debate any longer on that topic! Happy Boxing Day! -- Mickey ________________________________________________________________________________
Date: Dec 26, 2003
David, I will give you a call either Saturday or Monday to get your measurements on this. Meanwhile, I think I will put this part on hold and work on something else...there's never a shortage of side jobs to do! I will also draw this on the computer in CorelDraw. Believe it or not, this handles measurements very well and I can get a lot of information from it. Trig never was one of my strong subjects, and it's been about 35 years since I had it, so I think I'll let the electrons do my calculations for me. Jim >From: dcarter(at)datarecall.net >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: F-631 cabin frame >Date: Thu, 25 Dec 2003 20:11:35 GMT > > >Jim, > >1. Gap at top center is not a "strength" issue. Can have a gap - the 2 >plates that connect the halves provide 100% of the strength. Butting the >ends >together adds nothing, so don't worry about the gap, if you should find, on >reflection (about things to follow), that you might need a bit of a gap. > >2. About the top brace distance down from top: It is true that is has >nothing to do with the canopy material. However, it really is quite a big >deal in getting the brace to hit the right spot on the baggage bulkhead and >for the bottoms of the 631 roll bar to be positioned correctly for-aft so >as >to be CENTERED over the seat back AND some piece under it that you have to >find on the drawings - otherwise, edge distances are if'y (luck or not). > - I went to a flyin and observed a flying RV-6 with the feet about 3/4 >inch too far forward and therefore the bolts coming straight up thru seat >back >stuff was NOT through all the structural stuff - it was only through a >single >piece of sheet. (wish I had the drawing in front of me) > - From the drawings, I drew the underlying stuff on top of the seat >back >to show the boundaries of where the feet could go and drew a centerline, >then >drew the shape of the roll bar feet angles in that area to help me position >the roll bar correctly. Then all kind of convoluted measuring to check ht >- >the seat back brace sags in the middle where the ht dimention is supposed >to >be checked, so I shimmed and. . . . . . > - If you wait until I get home Sat or Mon I can tell you exactly what >the >dimension is for brace down from top. Use that and then trim bottoms if >needed and everything fits fine - in the areas you have drawn. > - In any case, you may have to trim off part of the inner edge of >the >bottoms of the roll bar to get the height dimension correct. There really >is >no way from the plans to get all this stuff right - jigging like you are >doing >is the key - plus don't shy away from the simple trig to get the height >dimension the plans don't give you. > >3. Just a word of caution about "moving the roll bar bottoms up on the feet >(angles)" to get the height dimension called out in the plans: There is >the >normal issue of edge distance at top of feet/angles and bottom of roll bar >ends that will impose some degree of limit on how much you can trim the >feet. > >David > ph away from home = 512-266-6955 & cell 409-718-8518 > > > > > David, > > > > Thanks for the help! After reading the replies to my post, and doing a > > little more thinking, I reached the following conclusion: > > > > I am going to jig those parts so as to eliminate the gap at top center. >In > > so doing, the height dimension is exactly 1/4" shorter than called on >the > > plans. HOWEVER, the plans show the F-631 dimension from the top of the > > F-605 to the top of the F-631 (measured on a slant). This means that if >the > > 631 itself is shorter, no big deal. Just compensate by moving it up on >the > > feet until the correct distance has been achieved. > > > > As to the 1/4" distance from the roll bar top to the top of the >brace...my > > plans still have 1/4" called out. I have seen various treatments of >that > > topic, from 0 to the full 1/4". If I am not mistaken, that gap is >really > > meaningless as the top of that brace does not contact anything, right? >(Or > > wrong?) > > > > Happy new year > > > > Jim > > >--------------------------------------------- >This message was sent using EXP Webmail. >http://www.exp.net > > Enjoy a special introductory offer for dial-up Internet access limited ________________________________________________________________________________
Subject: Re: Riveting wing leading edge ribs...anyone use pop rivets?
Date: Dec 26, 2003
With two people all the leading edge rivets are reachable with a little effort. I had discussed all the techniques with Vans and they said you could substitute a few pops in there, but give it a try first. With another builder on the gun, I was able to use my normal bucking bar to get them all. I did not make up the special bar although I said I would if necessary. My bar, which I think I got from Avery is about 3" x 1" x 2" with a taper on one end and rounded on the other end. Fits nicely in the palm of the hand and I can get it virtually anywhere. I use this bar a lot. With the taper on one end the sort of pointy end gets into the corners nicely. We started with all the ones we could easily see and do and used the same bar so we got into a rhythem on how long to hit the rivets. Then moved on to the ones we couldn't see while we were doing it where we would just go by the same amount of time to hit. Once you get in the rhythem it seems to go easier then it looks when you are trying to figure out how to get at some of them. You are bucking in the blind on a few but that's not a problem. I used a small mirror on a stem to check the shop heads but we could pretty much tell how they were by feel. My reco- get an experienced person on the gun and you hold the bar and go for it. Feels good when done. Curt Hoffman RV-9A wings done for now- working on tail Quick build fuselage now in basement Piper Cherokee N5320W 1974 TR6 HD Road King Classic (Maybe I need a boat too) ----- Original Message ----- From: "Cammie Patch" <cammie(at)sunvalley.net> Subject: RE: RV-List: Riveting wing leading edge ribs...anyone use pop rivets? > > On the leading edge installation, I used solid rivets where I could get a > good one, and pop rivets where the quality of my blind rivet installation > would be in doubt. The way I see it, a good blind rivet (as long as it's > structurally ok) is better than a badly installed solid rivet. I am more > interested in a good strong airframe than a champion aircraft. > Cammie > > > I'm having the expected trouble riveting the leading edge ribs on my > RV-7 wings....the list archives spell out various techniques involving > grinding down offset rivet sets, use of hockey tape, manufacturing > special bucking bars to enable back riveting etc. It occurs to me that > it would be extremely simple to just use pop rivets. Has anyone done > this? Would there be reduced structural integrity? Is there any > reason not to, other than one's sense of aesthetics? Is there a > recommended pop-rivet spec to use? > > Thanks, > Jerry > RV-7A > Wings > Tampa, FL > > ________________________________________________________________________________
Subject: Ballistic Chutes
Date: Dec 26, 2003
Questions to ponder when building an RV 1. Do I need a backup Radio if I intend to fly IFR----No, because the one I have is the best on the market. 2. Do I need a dedicated Carb heat muff-----No, because the Lycomings have the carb sitting on the hot oil pan and that will keep ice from forming. 3. Do I need a Heated pitot------No, because I'm not going to be dumb enough to fly in those conditions. 4. Do I need a backup electrical system-----No, because I haven't got a lot of extra power consuming crap like radios, heated pitots and gauges that a good pilot doesn't need. 5. Do I need more training----No, because the training I have has made me proficient up to this point. 6. Do I think I'd ever need a Ballistic Chute if it were available for my RV------ YOU ADD YOUR REASON Have a happy Holiday everyone. Jim Nolan N444JN ________________________________________________________________________________
Subject: Re: Ballistic Chutes
Date: Dec 26, 2003
I disagree with at least two of your premises... The heat muff as although the Lycoming location reduces, it doesn't eliminate carb icing. The other is the pitot heat as you say you are going to fly IFR. Maybe you have heard needle, ball and airspeed in emergency. Pitot heat gives you the chance to still have airspeed when in a cloud under freezing conditions. Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Jim Nolan" <jamespnolan(at)earthlink.net> Subject: RV-List: Ballistic Chutes > > Questions to ponder when building an RV > 1. Do I need a backup Radio if I intend to fly IFR----No, because the one I > have is the best on the market. > 2. Do I need a dedicated Carb heat muff-----No, because the Lycomings have > the carb sitting on the hot oil pan and that will keep ice from forming. > 3. Do I need a Heated pitot------No, because I'm not going to be dumb enough > to fly in those conditions. > 4. Do I need a backup electrical system-----No, because I haven't got a lot > of extra power consuming crap like radios, heated pitots and gauges that a > good pilot doesn't need. > 5. Do I need more training----No, because the training I have has made me > proficient up to this point. > 6. Do I think I'd ever need a Ballistic Chute if it were available for my > RV------ YOU ADD YOUR REASON > Have a happy Holiday everyone. > Jim Nolan > N444JN > > ________________________________________________________________________________
Date: Dec 26, 2003
In a message dated 12/26/2003 4:26:04 AM Pacific Standard Time, choffman9(at)cinci.rr.com writes: I used a small mirror on a stem to check the shop heads but we could pretty much tell how they were by feel. Braille rivet inspection. If you press on the formed head with your finger, it will leave an impression of the formed rivet head on your finger, briefly. You can then "see" the formed rivet head without needing a mirror. Jim Ayers RV-3 ________________________________________________________________________________
From: "Wayne Pedersen" <wayne(at)pedersentransport.com>
Subject: Christmas gift
Date: Dec 26, 2003
My youngest daughter gave me a Van's calendar for Christmas. While I was flipping through it I was describing each plane. I got to the RV10 and my wife asked "Is that the new four seater ?" I did the best to answer her questions on it and then she said "You are going to build that once you are done your -7a aren't you?" To which I responded "That's another big time and resource commitment" "Doesn't matter", she said "I think you better build it and I will help" Hmmmmm looks like I am in a tough spot people. I have to look forward to building another RV !!!! Merry Christmas Wayne S.Alberta RV 7-a working on panel P.S. My wife is working on her private license and YES she does have a sister ! --- ________________________________________________________________________________
Date: Dec 26, 2003
Mickey Coggins wrote: > > > > >>Question is...... >>Will you feel the same if/when the NTSB reports document >>that the BRS chute is not nearly the panacea many envision. >> >>Unfounded confidence seems to be the rule rather then the >>exception in today's technical world and hype is the life blood >>of the folks in marketing. >> >> > >Hi Bob, > >I could not agree more. If the reports show that the BRS >does not increase safety, then I won't consider it further. > >I guess if you went back to the Matronics archives from >the 30's :-) you would find the same debate about aircraft >ejection seats. Not much debate any longer on that topic! > >Happy Boxing Day! > >-- >Mickey > > > You are right I never see a debate about ejection seats from Piper, Cessna, Beech or any other non military manufacturered aircraft. :-) Jerry ________________________________________________________________________________
Date: Dec 26, 2003
>Date: Fri, 26 Dec 2003 09:06:24 -0700 > > > >My youngest daughter gave me a Van's calendar for Christmas. While I was >flipping through it I was describing each plane. I got to the RV10 and my >wife asked "Is that the new four seater ?" I did the best to answer her >questions on it and then she said "You are going to build that once you are >done your -7a aren't you?" To which I responded "That's another big time >and >resource commitment" "Doesn't matter", she said "I think you better build >it >and I will help" > >Hmmmmm looks like I am in a tough spot people. I have to look forward to >building another RV !!!! > >Merry Christmas > >Wayne >S.Alberta >RV 7-a working on panel > >P.S. > >My wife is working on her private license and YES she does have a sister ! Oh yes indeed, you're lucky! My wife let me build my RV8, then probably figured it was out of my blood...which it WAS, as attested by four years of RV grins and almost no sheet metal work. But then, along came our little boy, and the need for more seats. Then, Van works his magic and the -10 is born. After Deb tried on the -10 at LOE3, she was positively jazzed, and wanted me to get started NOW! I had already placed my empecone order at OSH (courtesy of my fine friends from the SoCal RV squadron). So, it was just a matter of playing the waiting game. My -10 kit is somewhere enroute to my shop as I write this. Santa must have run out of gross weight margin on his sleigh so Roadway Trucking had to help out. I'm reaaallly looking forward to building again, but am also scared half to death. Oh well, great things never happen until you cry, sweat and bleed a little, and we're not just talking financially here. :) Brian Denk RV8 N94BD RV10 51 Expand your wine savvy and get some great new recipes at MSN Wine. http://wine.msn.com ________________________________________________________________________________
Date: Dec 26, 2003
Subject: Chutes for RVs
Dear RV enthusiasts, Thanks for the speedy replies! I always find it fascinating how fast people are willing to throw in their 2 cents. And of course, the opinions usually run to each side of the spectrum. The folks without a strong opinion- one way or the other- don't bother to write. Based on some of the responses, I'd like to dispel a few myths and maybe educate a few people on what we do. At BRS, we are the FIRST to advise that the parachute IS NOT the "panacea" that some would think we believe it is. It is never an excuse for poor building practices, maintenance, training or piloting skills. Our manuals state that clearly. It is primarily for those occasions when all other means of problem solving have been expended. As of the first part of December, BRS have saved the lives of at least 159 individuals (we don't always get reports of all saves). A deployment on a Cirrus aircraft in late 2002 was our first save on a CERTIFIED aircraft. That aircraft is now flying again, by the way. In business for 22 years, over 17,000 units delivered. Nearly 1% of all units delivered have been used in real, life-saving events! In comparison, airbags in cars have saved (?) 1 person for every 50,000 units. These government mandated safety devices have killed at least 80 children under the age of 12. Ballistic parachutes have never actually KILLED anyone, that we are aware of. I'm all for airbags, however. Used correctly, save lives! Parachutes are not a mysterious device which sometimes open and sometimes don't. It is not a matter of luck or special dispensation from God which makes a parachute deploy. It is the same phenomenon which makes your wing create lift. The air passing over the outside of the parachute as its towed by its payload, creates a low pressure area on the outside- literally causing it to be "sucked" open by the atmosphere around it! (In fact, the purpose of the patented Slider on BRS parachutes is to keep the 'chute from opening TOO fast). "George in Langley" shared a concern about dangers of deploying over water. I have a couple comments about that. - Ditching an airplane, especially a low wing fixed gear airplane is extreme bad news. The airplane WILL be very violently thrown on its back. If the canopy doesnt shatter, it will probably remain secured in place against the external pressures caused by the surrounding water and the weight of the sinking aircraft. You're upside down in a bowl filling with very cold and debris filled water, trying to extract yourself and your panicking, flailing armed 14 year old neighbor kid (his first Young Eagle ride) from this mess that YOU, as PIC and manufacturer of the aircraft, are responsible for. - It is not the fault of the parachute system that you may have been over water in the event you have to use it- it is the event itself. - It would be infinitely safer to contact the water in a controlled vertical descent, that would more than likely leave you right side up. Descent under parachute gives you the time to plan your escape. "Phil from Litchfield Aerobatic club" would rather use a personal chute pack system. - At this time, its still the requirement for aerobatic flight- there is no provision for waiver with ballistic chute. - Having just rode in an RV-6 2 days ago, I would have to surmise that you would have to be a very tiny individual to fit in the aircraft with a parachute on AND still be able to get out of it when you need to. - An experienced skydiver would most likely need to be out and clear of the aircraft at least 1,500' agl. This would be quite a stretch for most pilots and passengers, especially seeing that most people tend to stay with the aircraft far too long. - 100% useless at traffic pattern alt or less. In ending, every pilot flies with his own unique circumstances. We must weigh the risks each time we take-off. We will take-off (hopefully) only when we have assured ourselves that the benefits of this particular flight are greater than the probability of experiencing the worst possible outcome. As PICs, we tend to accept that risk for the joy and satisfaction our hobby gives us. Your passengers generally don't share your exact outlook. When they fly with you they place their lives in your competence, skill and decision making abilities. I'm in engineering, not the sales department. This is meant to spawn a bit more thinking into the matter. Can't wait to read the replies after this one. Jeff Peltier Design Engineer BRS INC jeffpeltier(at)BRSparachutes.com ________________________________________________________________________________
Date: Dec 26, 2003
Austin, As I've said many time before - THANKS. Take Care and best wishes for a great New Year, Chuck Rowbotham RV-8A >From: "austin" <austin(at)uniserve.com> >Reply-To: rv-list(at)matronics.com >To: "rv-list rv-list" >Subject: RV-List: Rv Christmas >Date: Thu, 25 Dec 2003 13:49:32 -0800 > > >Hi Listers , > And a merry Christmas and even better New Year to you >all. >Another Christmas. >And where are we with the RV, our timeline, and mission statement ..flying >wise ? >A mystical day, in a sense, Christmas before the frenzy of driving, dinner, >family, kids, job, time,...more time we need to get to where we want to >be...RV wise, we don't talk about it much, we just have this goal.... >Finish it and fly it...consummation...... >And for those fortunate to be done, time on our side and finished, the >hangar door is our holy grail... >In my part of the world, rain was forecast, but as usual, they are only 50 >% >right...Expert weather man that I am, I am batting just as good an average >as the TV weather man, in that my forecast says that the weather today will >be much like it was yesterday...and my average is pretty good. >Yes, there is a cloudbase about 3,000...but light and pink underneath and >lightwind. >A good day to fly when so many others have other things to do and agendas >of >far more import. >Do you secretly sense a kind of thrill when you unlock the hangar door and >see your RV spinner the first to greet you and tell you that all the work >and time and money and lies and budget fudging are standing here, waiting >for you to open the doors all the way and let me out and start the engine >and listen to nothing else but the prop and exhaust and the monotone of >ATIS >and finally lift your gaze to clear taxi ? > Even though I try each time to stay straight on the painted line as >throttle up pulls me along, I always stagger a bit and before I can feel I >have command enough to make this horse track straight...the wheels are no >longer exacting any drag for they are free of the tarmac and we are rising >swiftly. >It is as easy as that ! > I don't even mind the noise, and it drowns everything else, but I >have >things to do, and enjoying the falling away landscape seems to be the >uppermost .. >Turn off the boost pump, trim a bit, throttle the noise back, get a smug >smile at what the GPS is saying and look around.....ain't this a special >way >to spend part of a Christmas day ?... >Later, at the table, with family dear, and kids and spouses and >in-laws....this is a special time of get together and values, but an RV >pilot has already had their " religious experience " this day... > Ever been to a stadium out of season ? when all the seats are >empty >and the crowd and noise are but a memory ? > Weird. >Well, landing at a normally busy field on Christmas day to find it empty, >the coffee shop closed and dark and no other sounds of airplanes starting >up >or taxiing in is equally weird.... >Are we the only airplane guys in the sky today ? >Heading home with the wind at our backs and GPS telling amazing stories, >home field appears at 10 o'clock and nobody else is talking to the >tower...at first, I wonder if the radio is working....no voices.... >But good old radio does work and a voice bids " straight in " from 6 miles >out....or more.... >My landings are never the same as to how far out I get serious, but finally >I quit looking at the airspeed and just how high or low the nose seems to >be >from the paint lines and somehow the RV finds her own glidepath and the >tires kiss the blacktop.......now rolling out is something else again >because I think I am a lousy pilot and I get a shimmy and try to kil it by >back pressure, and it works..for a while.....by this time...it is time to >clear active and why I have to monitor ground beats me as there is no other >life around..but home we go and put her away and before closing the doors, >my hand on the cowling feels the warmth of life and I sense the wonder of >all these parts that bore me up once more for my " fix ".... >I believe I am addicted.... >At locking up, my thoughts turn to those I have known or read about who no >longer have a Christmas for whatever reason and those who made it safe for >me to enjoy what others paid the ultimate price for me to savour. >God bless you all, and those forever young.. >Austin. > > Working moms: Find helpful tips here on managing kids, home, work and yourself. http://special.msn.com/msnbc/workingmom.armx ________________________________________________________________________________
Date: Dec 26, 2003
>Date: Thu, 25 Dec 2003 22:43:08 -0600 > > >Paul: Don't do aerobatics your butt can't cash. ? What does that mean. >Doyle RV7A To me it means, don't get into something you can't finish....don't start a loop too slow and not be prepared to deal with a spin at the top. Brian Denk RV8 N94BD another "wannabe pilot" but learning more every time I fly. Enjoy a special introductory offer for dial-up Internet access limited ________________________________________________________________________________
Subject: RBS
Date: Dec 26, 2003
Sometimes you guys remind me of my grandchildren! Offer them candy and they may say "no I don't like that", only because they have never tried it. I say let the engineers work on it, show us what they come up with and how it might help us, then maybe we can make an intelligent decision. Till then I'm keeping an open mind! Later, Steve Glasgow ________________________________________________________________________________
Date: Dec 26, 2003
Subject: Shoulder harness
Listers, I finally found the document that talks about shoulder belt attachment points and the rule says, less than 30 deg. above the shoulders and no more than 5 deg below the shoulders. The document is AC-21-34 and can be found at: http://www2.faa.gov/avr/afs/safety/harness/AC%2021-34.pdf It will tell you more than you ever wanted to know about seat belt and shoulder harness installation! Dave -6, So Cal EAA Technical Counselor ________________________________________________________________________________
Date: Dec 26, 2003
Subject: BRS
I just looked at the BRS website and it looks like an appropriate system for an RV6 would be about $11,000.00. (More than a third of the cost of my airplane) I personally think that eleven thousand dollars could be better spent on ratings and equipment. Yes, I do believe that it would add a measure of safety but the cost, both in dollars and in weight will most likely never be in my budget. If I ever get that paranoid about flying my own airplane, I'll buy an airline ticket. Dave ________________________________________________________________________________
Date: Dec 26, 2003
Subject: Re: -7 tail kit for sale
New, unopened RV-7 tail kit for sale. Located in Tampa FL. $1200 delivered in FL. Plus shipping elsewhere. email Mark Conner (Not Linn) @ mconner7(at)tampabay.rr.com ________________________________________________________________________________
Date: Dec 26, 2003
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
QXMgYWx3YXlzLiBZb3Ugcm9jayBBdXN0aW4uIA0KSSBmbGV3IHgtbWFzLCBjYW1lIGhvbWUgZXho YXVzdGVkLCByZWFkIHlvdXIgcG9zdC4gVGhlbiByYW4gYmFjayBvdXQgdG8gdGhlIGFpcnBvcnQg YW5kIGZsZXcgYWdhaW4hLg0KVGhhbmtzDQpNaWtlDQo2QSAxMTAwIGhvdXJzDQpkbyBub3QgYXJj aGl2ZQ0KDQoJLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0gDQoJRnJvbTogb3duZXItcnYtbGlz dC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBvbiBiZWhhbGYgb2YgYXVzdGluIA0KCVNlbnQ6IFRodSAx Mi8yNS8yMDAzIDQ6NDkgUE0gDQoJVG86IHJ2LWxpc3QgcnYtbGlzdCANCglDYzogDQoJU3ViamVj dDogUlYtTGlzdDogUnYgQ2hyaXN0bWFzDQoJDQoJDQoNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBv c3RlZCBieTogImF1c3RpbiIgPGF1c3RpbkB1bmlzZXJ2ZS5jb20+DQoJDQoJSGkgTGlzdGVycyAs DQoJICAgICAgICAgICAgICAgICAgICAgQW5kIGEgbWVycnkgQ2hyaXN0bWFzIGFuZCBldmVuIGJl dHRlciBOZXcgWWVhciB0byB5b3UNCglhbGwuDQoJQW5vdGhlciBDaHJpc3RtYXMuDQoJQW5kIHdo ZXJlIGFyZSB3ZSB3aXRoIHRoZSBSViwgb3VyIHRpbWVsaW5lLCBhbmQgbWlzc2lvbiBzdGF0ZW1l bnQgLi5mbHlpbmcNCgl3aXNlID8NCglBIG15c3RpY2FsIGRheSwgaW4gYSBzZW5zZSwgQ2hyaXN0 bWFzIGJlZm9yZSB0aGUgZnJlbnp5IG9mIGRyaXZpbmcsIGRpbm5lciwNCglmYW1pbHksIGtpZHMs IGpvYiwgdGltZSwuLi5tb3JlIHRpbWUgd2UgbmVlZCB0byBnZXQgdG8gd2hlcmUgd2Ugd2FudCB0 bw0KCWJlLi4uUlYgd2lzZSwgd2UgZG9uJ3QgdGFsayBhYm91dCBpdCBtdWNoLCB3ZSBqdXN0IGhh dmUgdGhpcyBnb2FsLi4uLg0KCUZpbmlzaCBpdCBhbmQgZmx5IGl0Li4uY29uc3VtbWF0aW9uLi4u Li4uDQoJQW5kIGZvciB0aG9zZSBmb3J0dW5hdGUgdG8gYmUgZG9uZSwgdGltZSBvbiBvdXIgc2lk ZSBhbmQgZmluaXNoZWQsIHRoZQ0KCWhhbmdhciBkb29yIGlzIG91ciBob2x5IGdyYWlsLi4uDQoJ SW4gbXkgcGFydCBvZiB0aGUgd29ybGQsIHJhaW4gd2FzIGZvcmVjYXN0LCBidXQgYXMgdXN1YWws IHRoZXkgYXJlIG9ubHkgNTAgJQ0KCXJpZ2h0Li4uRXhwZXJ0IHdlYXRoZXIgbWFuIHRoYXQgSSBh bSwgSSBhbSBiYXR0aW5nIGp1c3QgYXMgZ29vZCBhbiBhdmVyYWdlDQoJYXMgdGhlIFRWIHdlYXRo ZXIgbWFuLCBpbiB0aGF0IG15IGZvcmVjYXN0IHNheXMgdGhhdCB0aGUgd2VhdGhlciB0b2RheSB3 aWxsDQoJYmUgbXVjaCBsaWtlIGl0IHdhcyB5ZXN0ZXJkYXkuLi5hbmQgbXkgYXZlcmFnZSBpcyBw cmV0dHkgZ29vZC4NCglZZXMsIHRoZXJlIGlzIGEgY2xvdWRiYXNlIGFib3V0IDMsMDAwLi4uYnV0 IGxpZ2h0IGFuZCBwaW5rIHVuZGVybmVhdGggYW5kDQoJbGlnaHR3aW5kLg0KCUEgZ29vZCBkYXkg dG8gZmx5IHdoZW4gc28gbWFueSBvdGhlcnMgaGF2ZSBvdGhlciB0aGluZ3MgdG8gZG8gYW5kIGFn ZW5kYXMgb2YNCglmYXIgbW9yZSBpbXBvcnQuDQoJRG8geW91IHNlY3JldGx5IHNlbnNlIGEga2lu ZCBvZiB0aHJpbGwgd2hlbiB5b3UgdW5sb2NrIHRoZSBoYW5nYXIgZG9vciAgYW5kDQoJc2VlIHlv dXIgUlYgc3Bpbm5lciB0aGUgZmlyc3QgdG8gZ3JlZXQgeW91IGFuZCB0ZWxsIHlvdSB0aGF0IGFs bCB0aGUgd29yaw0KCWFuZCB0aW1lIGFuZCBtb25leSBhbmQgbGllcyBhbmQgYnVkZ2V0IGZ1ZGdp bmcgYXJlIHN0YW5kaW5nIGhlcmUsIHdhaXRpbmcNCglmb3IgeW91IHRvIG9wZW4gdGhlIGRvb3Jz IGFsbCB0aGUgd2F5IGFuZCBsZXQgbWUgb3V0IGFuZCBzdGFydCB0aGUgZW5naW5lDQoJYW5kIGxp c3RlbiB0byBub3RoaW5nIGVsc2UgYnV0IHRoZSBwcm9wIGFuZCBleGhhdXN0IGFuZCB0aGUgbW9u b3RvbmUgb2YgQVRJUw0KCWFuZCBmaW5hbGx5IGxpZnQgeW91ciBnYXplIHRvIGNsZWFyIHRheGkg Pw0KCSAgICAgICBFdmVuIHRob3VnaCBJIHRyeSBlYWNoIHRpbWUgdG8gc3RheSBzdHJhaWdodCBv biB0aGUgcGFpbnRlZCBsaW5lIGFzDQoJdGhyb3R0bGUgdXAgcHVsbHMgbWUgYWxvbmcsIEkgYWx3 YXlzIHN0YWdnZXIgYSBiaXQgYW5kIGJlZm9yZSBJIGNhbiBmZWVsIEkNCgloYXZlIGNvbW1hbmQg ZW5vdWdoIHRvIG1ha2UgdGhpcyBob3JzZSB0cmFjayBzdHJhaWdodC4uLnRoZSB3aGVlbHMgYXJl IG5vDQoJbG9uZ2VyIGV4YWN0aW5nIGFueSBkcmFnIGZvciB0aGV5IGFyZSAgZnJlZSBvZiB0aGUg dGFybWFjIGFuZCB3ZSBhcmUgcmlzaW5nDQoJc3dpZnRseS4NCglJdCBpcyBhcyBlYXN5IGFzIHRo YXQgIQ0KCSAgICAgSSBkb24ndCBldmVuIG1pbmQgdGhlIG5vaXNlLCBhbmQgaXQgZHJvd25zIGV2 ZXJ5dGhpbmcgZWxzZSwgYnV0IEkgaGF2ZQ0KCXRoaW5ncyB0byBkbywgYW5kIGVuam95aW5nIHRo ZSBmYWxsaW5nIGF3YXkgbGFuZHNjYXBlIHNlZW1zIHRvIGJlIHRoZQ0KCXVwcGVybW9zdCAuLg0K CVR1cm4gb2ZmIHRoZSBib29zdCBwdW1wLCB0cmltIGEgYml0LCB0aHJvdHRsZSB0aGUgbm9pc2Ug YmFjaywgZ2V0IGEgc211Zw0KCXNtaWxlIGF0IHdoYXQgdGhlIEdQUyBpcyBzYXlpbmcgYW5kIGxv b2sgYXJvdW5kLi4uLi5haW4ndCB0aGlzIGEgc3BlY2lhbCB3YXkNCgl0byBzcGVuZCBwYXJ0IG9m IGEgQ2hyaXN0bWFzIGRheSA/Li4uDQoJTGF0ZXIsIGF0IHRoZSB0YWJsZSwgd2l0aCBmYW1pbHkg ZGVhciwgYW5kIGtpZHMgYW5kIHNwb3VzZXMgYW5kDQoJaW4tbGF3cy4uLi50aGlzIGlzIGEgc3Bl Y2lhbCB0aW1lIG9mIGdldCB0b2dldGhlciBhbmQgdmFsdWVzLCBidXQgYW4gUlYNCglwaWxvdCBo YXMgYWxyZWFkeSBoYWQgdGhlaXIgIiByZWxpZ2lvdXMgZXhwZXJpZW5jZSAiIHRoaXMgZGF5Li4u DQoJICAgICAgICAgRXZlciBiZWVuIHRvIGEgc3RhZGl1bSBvdXQgb2Ygc2Vhc29uID8gd2hlbiBh bGwgdGhlIHNlYXRzIGFyZSBlbXB0eQ0KCWFuZCB0aGUgY3Jvd2QgYW5kIG5vaXNlIGFyZSBidXQg YSBtZW1vcnkgPw0KCSAgICAgIFdlaXJkLg0KCVdlbGwsIGxhbmRpbmcgYXQgYSBub3JtYWxseSBi dXN5IGZpZWxkIG9uIENocmlzdG1hcyBkYXkgdG8gZmluZCBpdCBlbXB0eSwNCgl0aGUgY29mZmVl IHNob3AgY2xvc2VkIGFuZCBkYXJrIGFuZCBubyBvdGhlciBzb3VuZHMgb2YgYWlycGxhbmVzIHN0 YXJ0aW5nIHVwDQoJb3IgdGF4aWluZyBpbiBpcyBlcXVhbGx5IHdlaXJkLi4uLg0KCUFyZSB3ZSB0 aGUgb25seSBhaXJwbGFuZSBndXlzIGluIHRoZSBza3kgdG9kYXkgPw0KCUhlYWRpbmcgaG9tZSB3 aXRoIHRoZSB3aW5kIGF0IG91ciBiYWNrcyBhbmQgR1BTIHRlbGxpbmcgYW1hemluZyBzdG9yaWVz LA0KCWhvbWUgZmllbGQgYXBwZWFycyBhdCAxMCBvJ2Nsb2NrIGFuZCBub2JvZHkgZWxzZSBpcyB0 YWxraW5nIHRvIHRoZQ0KCXRvd2VyLi4uYXQgZmlyc3QsIEkgd29uZGVyIGlmIHRoZSByYWRpbyBp cyB3b3JraW5nLi4uLm5vIHZvaWNlcy4uLi4NCglCdXQgZ29vZCBvbGQgcmFkaW8gZG9lcyB3b3Jr IGFuZCBhIHZvaWNlIGJpZHMgIiBzdHJhaWdodCBpbiAiIGZyb20gNiBtaWxlcw0KCW91dC4uLi5v ciBtb3JlLi4uLg0KCU15IGxhbmRpbmdzIGFyZSBuZXZlciB0aGUgc2FtZSBhcyB0byBob3cgZmFy IG91dCBJIGdldCBzZXJpb3VzLCBidXQgZmluYWxseQ0KCUkgcXVpdCBsb29raW5nIGF0IHRoZSBh aXJzcGVlZCBhbmQganVzdCBob3cgaGlnaCBvciBsb3cgdGhlIG5vc2Ugc2VlbXMgdG8gYmUNCglm cm9tIHRoZSBwYWludCBsaW5lcyBhbmQgc29tZWhvdyB0aGUgUlYgZmluZHMgaGVyIG93biBnbGlk ZXBhdGggYW5kIHRoZQ0KCXRpcmVzIGtpc3MgdGhlIGJsYWNrdG9wLi4uLi4uLm5vdyByb2xsaW5n IG91dCBpcyBzb21ldGhpbmcgZWxzZSBhZ2Fpbg0KCWJlY2F1c2UgSSB0aGluayBJIGFtIGEgbG91 c3kgcGlsb3QgYW5kIEkgZ2V0IGEgc2hpbW15IGFuZCB0cnkgdG8ga2lsIGl0IGJ5DQoJYmFjayBw cmVzc3VyZSwgYW5kIGl0IHdvcmtzLi5mb3IgYSB3aGlsZS4uLi4uYnkgdGhpcyB0aW1lLi4uaXQg aXMgdGltZSB0bw0KCWNsZWFyIGFjdGl2ZSBhbmQgd2h5IEkgaGF2ZSB0byBtb25pdG9yIGdyb3Vu ZCBiZWF0cyBtZSBhcyB0aGVyZSBpcyBubyBvdGhlcg0KCWxpZmUgYXJvdW5kLi5idXQgaG9tZSB3 ZSBnbyBhbmQgcHV0IGhlciBhd2F5IGFuZCBiZWZvcmUgY2xvc2luZyB0aGUgZG9vcnMsDQoJbXkg aGFuZCBvbiB0aGUgY293bGluZyBmZWVscyB0aGUgd2FybXRoIG9mIGxpZmUgYW5kIEkgc2Vuc2Ug dGhlIHdvbmRlciBvZg0KCWFsbCB0aGVzZSBwYXJ0cyB0aGF0IGJvcmUgbWUgdXAgb25jZSBtb3Jl IGZvciBteSAiIGZpeCAiLi4uLg0KCUkgYmVsaWV2ZSBJIGFtIGFkZGljdGVkLi4uLg0KCUF0IGxv Y2tpbmcgdXAsIG15IHRob3VnaHRzIHR1cm4gdG8gdGhvc2UgSSBoYXZlIGtub3duIG9yIHJlYWQg YWJvdXQgd2hvIG5vDQoJbG9uZ2VyIGhhdmUgYSBDaHJpc3RtYXMgZm9yIHdoYXRldmVyIHJlYXNv biBhbmQgdGhvc2Ugd2hvIG1hZGUgaXQgc2FmZSBmb3INCgltZSB0byBlbmpveSB3aGF0IG90aGVy cyBwYWlkIHRoZSB1bHRpbWF0ZSBwcmljZSBmb3IgbWUgdG8gc2F2b3VyLg0KCUdvZCBibGVzcyB5 b3UgYWxsLCBhbmQgdGhvc2UgZm9yZXZlciB5b3VuZy4uDQoJQXVzdGluLg0KCQ0KCQ0KCV8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09DQoJXy09ICAgICAgICAgICAgICAtIFRoZSBSVi1MaXN0IEVtYWlsIEZvcnVt IC0NCglfLT0gVGhpcyBmb3J1bSBpcyBzcG9uc29yZWQgZW50aXJlbHkgdGhyb3VnaCB0aGUgQ29u dHJpYnV0aW9ucw0KCV8tPSBvZiBMaXN0IG1lbWJlcnMuICBZb3UnbGwgbmV2ZXIgc2VlIGJhbm5l ciBhZHMgb3IgYW55IG90aGVyDQoJXy09IGZvcm0gb2YgZGlyZWN0IGFkdmVydGlzaW5nIG9uIHRo ZSBNYXRyb25pY3MgRm9ydW1zLg0KCV8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoJXy09ICEhIE5FVyAhIQ0K CV8tPSBBTEwgTkVXIExJU1QgQ0hBVCEhIGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jaGF0DQoJ Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCglfLT0gTGlzdCBSZWxhdGVkIEluZm9ybWF0aW9uDQoJXy09ICBQ b3N0IE1lc3NhZ2U6ICAgcnYtbGlzdEBtYXRyb25pY3MuY29tDQoJXy09ICBVTi9TVUJTQ1JJQkU6 ICAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL3N1YnNjcmlwdGlvbg0KCV8tPSAgTGlzdCBGQVE6 ICAgICAgIGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9GQVEvUlYtTGlzdC5odG0NCglfLT0gIFNl YXJjaCBFbmdpbmU6ICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vc2VhcmNoDQoJXy09ICA3LURh eSBCcm93c2U6ICAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Jyb3dzZS9ydi1saXN0DQoJXy09 ICBCcm93c2UgRGlnZXN0czogaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2RpZ2VzdC9ydi1saXN0 DQoJXy09ICBMaXZlIExpc3QgQ2hhdDogaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NoYXQNCglf LT0gIEFyY2hpdmVzOiAgICAgICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vYXJjaGl2ZXMNCglf LT0gIFBob3RvIFNoYXJlOiAgICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vcGhvdG9zaGFyZQ0K CV8tPSAgTGlzdCBTcGVjaWZpYzogIGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9ydi1saXN0DQoJ Xy09ICBPdGhlciBMaXN0czogICAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2VtYWlsbGlzdHMN CglfLT0gIFRyb3VibGUgUmVwb3J0ICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vdHJvdWJsZS1y ZXBvcnQNCglfLT0gIENvbnRyaWJ1dGlvbnM6ICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29u dHJpYnV0aW9uDQoJXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCgkNCgkNCgkNCgkNCgkNCg0K ________________________________________________________________________________
Date: Dec 27, 2003
QSBjb3VwbGUgb2YgY29tbWVudHMgYWJvdXQgZGl0Y2hpbmcuLi4NCiANCjEuIEkga25vdyBvZiBh IGxvdy13aW5nIGZpeGVkLWdlYXIgYWlycGxhbmUgKFBpcGVyIFdhcnJpb3IsIEkgdGhpbmspIHdo aWNoIGRpdGNoZWQgYW5kIGRpZCBOT1QgZ2V0IHRocm93biBvbiBpdHMgYmFjay4gTm9yIGRpZCBp dCBzaW5rIGltbWVkaWF0ZWx5IChidXQgdGhlIGZhY3QgdGhhdCB0aGUgZnVlbCB0YW5rcyB3ZXJl IGZ1bGwgb2YgYWlyIG1heSBoYXZlIGFzc2lzdGVkIHRoZXJlKS4gVGhlIG9jY3VwYW50cyBnb3Qg b3V0IG9mIHRoZSBjb2NrcGl0IGFuZCBzYXQgb24gdGhlIGZsb2F0aW5nIHBsYW5lIGZvciAxNSBt aW51dGVzIG9yIG1vcmUuDQogDQogDQpSZWdhcmRpbmcgImluZmluaXRlbHkgc2FmZXIgdG8gY29u dGFjdCB0aGUgd2F0ZXIgaW4gYSBjb250cm9sbGVkIHZlcnRpY2FsIGRlc2NlbnQiLi4uDQogDQoy LiBVbmRlciBhIEJSUywgeW91IGFyZSBpbiBhbiBVTkNPTlRST0xMRUQgZGVzY2VudC4NCiANCjMu IFlvdXIgZGVzY2VudCBtYXkgbm90IGJlIHZlcnRpY2FsLi4uIGlmIHRoZSB3aW5kIGlzIGJsb3dp bmcgMTVrdHMsIHlvdSdsbCBhbHNvIGJlIG1vdmluZyBhdCAxNWt0cyBob3Jpem9udGFsbHkuDQog DQo0LiBJJ3ZlIGdvdCB0byB3b25kZXIgd2hlcmUgeW91IGxpdmUuLi4gbm90IG5lYXIgYW4gb2Nl YW4sIEkgZ3Vlc3MuIFdhdGVyIHJvdW5kIGhlcmUgaXMgbm90IGZsYXQuLi4gd2F2ZXMgbWF5IGJl IDNtIChvciBtb3JlKSBpbiBoZWlnaHQuIEFzc3VtaW5nIHdpbmQgaXMgcHJlc2VudCwgbW9zdCBs aWtlbHkgKGFsdGhvdWdoIG5vdCBjZXJ0YWlubHkpIHlvdXIgbW90aW9uIHdpbGwgYmUgaW4gYXBw cm94aW1hdGVseSB0aGUgc2FtZSBkaXJlY3Rpb24gYXMgdGhlIHdhdmVzLCBidXQgZmFzdGVyLiBT byB5b3UncmUgbGlrZWx5IHRvIGxhbmQgb24gdGhlIGJhY2tzaWRlIG9mIGEgd2F2ZSB0aGF0J3Mg bW92aW5nIGF3YXkgZnJvbSB5b3UuIFdoYXRldmVyLCBpdCdzIGxpa2VseSB0aGF0IHlvdSB3b24n dCBsYW5kIGZsYXQgb24gdGhlIHdhdGVyLg0KIA0KRnJhbmsNCiANCg0KCS0tLS0tT3JpZ2luYWwg TWVzc2FnZS0tLS0tIA0KCUZyb206IEplZmYgUGVsdGllciBbbWFpbHRvOmplZmZwZWx0aWVyQEJS U3BhcmFjaHV0ZXMuY29tXSANCglTZW50OiBTYXQgMjcvMTIvMjAwMyAxMDo1MCBhLm0uIA0KCVRv OiBydi1saXN0QG1hdHJvbmljcy5jb20gDQoJQ2M6IA0KCVN1YmplY3Q6IFJWLUxpc3Q6IENodXRl cyBmb3IgUlZzDQoJDQoJDQoNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogSmVmZiBQ ZWx0aWVyIDxqZWZmcGVsdGllckBicnNwYXJhY2h1dGVzLmNvbT4NCgkNCgkiR2VvcmdlIGluIExh bmdsZXkiIHNoYXJlZCBhIGNvbmNlcm4gYWJvdXQgZGFuZ2VycyBvZiBkZXBsb3lpbmcgb3ZlciB3 YXRlci4NCglJIGhhdmUgYSBjb3VwbGUgY29tbWVudHMgYWJvdXQgdGhhdC4NCgktIERpdGNoaW5n IGFuIGFpcnBsYW5lLCBlc3BlY2lhbGx5IGEgbG93IHdpbmcgZml4ZWQgZ2VhciBhaXJwbGFuZSBp cyBleHRyZW1lDQoJYmFkIG5ld3MuIFRoZSBhaXJwbGFuZSBXSUxMIGJlIHZlcnkgdmlvbGVudGx5 IHRocm93biBvbiBpdHMgYmFjay4gSWYgdGhlDQoJY2Fub3B5IGRvZXNudCBzaGF0dGVyLCBpdCB3 aWxsIHByb2JhYmx5IHJlbWFpbiBzZWN1cmVkIGluIHBsYWNlIGFnYWluc3QgdGhlDQoJZXh0ZXJu YWwgcHJlc3N1cmVzIGNhdXNlZCBieSB0aGUgc3Vycm91bmRpbmcgd2F0ZXIgYW5kIHRoZSB3ZWln aHQgb2YgdGhlDQoJc2lua2luZyBhaXJjcmFmdC4gIFlvdSdyZSB1cHNpZGUgZG93biBpbiBhIGJv d2wgZmlsbGluZyB3aXRoIHZlcnkgY29sZCBhbmQNCglkZWJyaXMgZmlsbGVkIHdhdGVyLCB0cnlp bmcgdG8gZXh0cmFjdCB5b3Vyc2VsZiBhbmQgeW91ciBwYW5pY2tpbmcsIGZsYWlsaW5nDQoJYXJt ZWQgMTQgeWVhciBvbGQgbmVpZ2hib3Iga2lkIChoaXMgZmlyc3QgWW91bmcgRWFnbGUgcmlkZSkg ZnJvbSB0aGlzIG1lc3MNCgl0aGF0IFlPVSwgYXMgUElDIGFuZCBtYW51ZmFjdHVyZXIgb2YgdGhl IGFpcmNyYWZ0LCBhcmUgcmVzcG9uc2libGUgZm9yLg0KCS0gSXQgaXMgbm90IHRoZSBmYXVsdCBv ZiB0aGUgcGFyYWNodXRlIHN5c3RlbSB0aGF0IHlvdSBtYXkgaGF2ZSBiZWVuIG92ZXINCgl3YXRl ciBpbiB0aGUgZXZlbnQgeW91IGhhdmUgdG8gdXNlIGl0LSBpdCBpcyB0aGUgZXZlbnQgaXRzZWxm Lg0KCS0gSXQgd291bGQgYmUgaW5maW5pdGVseSBzYWZlciB0byBjb250YWN0IHRoZSB3YXRlciBp biBhIGNvbnRyb2xsZWQgdmVydGljYWwNCglkZXNjZW50LCB0aGF0IHdvdWxkIG1vcmUgdGhhbiBs aWtlbHkgbGVhdmUgeW91IHJpZ2h0IHNpZGUgdXAuICBEZXNjZW50IHVuZGVyDQoJcGFyYWNodXRl IGdpdmVzIHlvdSB0aGUgdGltZSB0byBwbGFuIHlvdXIgZXNjYXBlLg0KCQ0KCQ0KDQo ________________________________________________________________________________
Date: Dec 27, 2003
Subject: Re: Chutes for RVs
Jerry Springer wrote: > >Here is my reply, after reading yours I want a BRS even less than >before. You use scare tactics and untruths >to try to justify your chute on an RV. Using an example of a young >eagle, (scare tactic) saying you have to be a tiny >person to exit an RV-6. (untrue) I am 6'3" 210 lb. and would not have a >problem getting out. Yes I have jumped out of >airplanes before still do not see a need for ballistics in an RV. BRS >were originally designed for ultralights that were having >structural failures in the early stages. I believe that is still the >best use of ballistic chutes after reading your saves and all the > malfunctions on the airplanes they are installed on. >BTW tell us what Van thinks of using ballistic chutes on his design? You >say it is not an excuse for poor building >practices, well I doubt very much that anyone is going to build their >airplane poorly and say to him/herself I well just use a >a BRS. So I guess I am still waiting for the myths you are going to >dispel. By your 2 cent comment seems like you >are not happy with the comments that don't agree with yours. BTW I >noticed in your saves list only one Cirrus >listed wasn't there another one where the chute did not deploy >correctly? March 2002 I believe. >Of course this is all my opinions and others should do as they feel best >for them. >Jerry > Jerry, I agree with most your assessment above and would like to add my two cents worth. 1. I read that the Cirrus that is back flying was a FREAK SAVE. The report I read stated that tree branches or some such broke the fall of the aircraft sufficiently before it hit the ground - if it even hit the ground, allowing the airframe to be reused at practical costs. Other Cirrus deployments were not so 'press-worthy' , it seems. 2. I believe the scenario describing a low wing plane ditching over water is probably the best and safest use of a ballistic chute since my luck would have me landing directly on a flag pole, in busy rush hour traffic, the Indy 500 or being bounced down a mountain slope in 30 knot winds.... provided the seat in an RV can be modified to prevent the occupants from breaking their backs on impact. Using the standard pan used in my RV would be a killer. Dunno if three inches of TEMP-R-FOAM or some such can save my delicate spine and vertebrae so I might swim to shore. [Yes, good judgment would minimize flying outside of gliding distance to shore in the first place, but ya never know what kind of superior fool will fool a foolproof airplane.] ;-) 3. YMMV P.S. Anybody know how the famous Jim Handbury died? I was told his death was caused by a test parachute that tangled in the control surfaces of the aircraft.he was piloting. Bob ________________________________________________________________________________
Date: Dec 27, 2003
>Jerry, > >I agree with most your assessment above and would like to add my two >cents worth. > >1. I read that the Cirrus that is back flying was a FREAK SAVE. The >report I read stated that tree branches or some such broke the fall of >the aircraft sufficiently before it hit the ground - if it even hit the >ground, allowing the airframe to be reused at practical costs. Other >Cirrus deployments were not so 'press-worthy' , it seems. > >2. I believe the scenario describing a low wing plane ditching over >water is probably the best and safest use of a ballistic chute since my >luck would have me landing directly on a flag pole, in busy rush hour >traffic, the Indy 500 or being bounced down a mountain slope in 30 knot >winds.... provided the seat in an RV can be modified to prevent the >occupants from breaking their backs on impact. Using the standard pan >used in my RV would be a killer. Dunno if three inches of TEMP-R-FOAM >or some such can save my delicate spine and vertebrae so I might swim to >shore. [Yes, good judgment would minimize flying outside of gliding >distance to shore in the first place, but ya never know what kind of >superior fool will fool a foolproof airplane.] ;-) > >3. YMMV > >P.S. >Anybody know how the famous Jim Handbury died? I was told his death was >caused by a test parachute that tangled in the control surfaces of the >aircraft.he was piloting. > I forgot to add -- The above only applies if, BIG IF.... if the ballistic chute can be made to deploy properly and repeatedly in the first place. This is hardly a 'given' at this point and I'd hate to assume anything that would jeopardize my next 50 years of successful flight. :-) Bob - over 50 years of successful flight ________________________________________________________________________________
Subject: battery
Date: Dec 27, 2003
Based upon note I have seen here, I recently bought an Odessey 580 battery for my RV8A, with an IO-360 (200HP) Lyc. The batt is much thinner than the old G-25. So thin that I wonder if it has enough capacity to handle this engine?? What are your experiences with it?? Thanks. Jimmy Hill ________________________________________________________________________________
Date: Dec 27, 2003
Subject: Re: battery
Don't know about a 580, but I know the 680 spins my O-360 much better than the Concorde RGB I had before. Jerry jimmy(at)jhill.biz wrote: > >Based upon note I have seen here, I recently bought an Odessey 580 battery for my RV8A, with an IO-360 (200HP) Lyc. The batt is much thinner than the old G-25. > > >So thin that I wonder if it has enough capacity to handle this engine?? >What are your experiences with it?? > >Thanks. > >Jimmy Hill > > > > ________________________________________________________________________________
Date: Dec 27, 2003
From: michael michael <top_gun_toronto(at)yahoo.ca>
Subject: Chutes for RVs...Captain going down with the ship...;)
Dear Pilots... There was once a time that parachutes were not given out to pilots, because it was seen as promoting cowardice,.... I think the jury is out...I do think that we will all watch the 1st RV planes equipped with this device very carefully(wether you like the idea or not, your interest is peaked)..... But I can tell you one thing... If the BRS does work.....If it saves the life of one sorry ass pilot then the debate was worth it.....There has never been a time when a revolutionary idea was not met with resistance(regarless if you like the messenger or not)..... I feel there is allot of the "Captain going down with the ship"...mentality floating around. .... One of 2 things are going to happen.....This system will begin to save lives.....or it wont.....I beg the question...why not see if it does save lives ....the benefits far outweigh the loss.....I say to the dis believers....hold your tongue.....you can always do the "I told you so" later & show us all, how enlighten you are....but until then...lets let this play out.....give them enough rope.....lets see what happens.....This has me riveted....we could be at a major junction in aviation...This could be one of those....I remember when stories, unfolding before your eyes.. Michael In Toronto --------------------------------- ________________________________________________________________________________
Date: Dec 27, 2003
Good idea. I have done something similar by accidently kneeling on a rivet and leaving an impression in my knee : ) Curt Hoffman RV-9A wings done for now- working on tail Quick build fuselage now in basement Piper Cherokee N5320W 1974 TR6 HD Road King Classic (Maybe I need a boat too) ----- Original Message ----- From: <LeastDrag93066(at)aol.com> Subject: Re: RV-List: Riveting wing leading edge ribs...anyone use pop rivets? > > In a message dated 12/26/2003 4:26:04 AM Pacific Standard Time, > choffman9(at)cinci.rr.com writes: > I used > a small mirror on a stem to check the shop heads but we could pretty much > tell how they were by feel. > Braille rivet inspection. > > If you press on the formed head with your finger, it will leave an impression > of the formed rivet head on your finger, briefly. You can then "see" the > formed rivet head without needing a mirror. > > Jim Ayers > RV-3 > > ________________________________________________________________________________
Date: Dec 27, 2003
From: "thomas a. sargent" <sarg314(at)earthlink.net>
Subject: Re: Ballistic parachutes on RVs - getting out
Bryan: I have often wondered about getting out in flight. I am building a tip-up. How do you get the thing open in flight short of smashing the plexiglass? I've always heard that neither the tip-up nor the slider can be opened in flight because aerodynamic forces exert too much pressure. I've built the emergency release mechanism into my plane, but the canopy would still be held in by the gas struts. (I installed the emergency release to make it easier to remove the canopy for maintainance purposes.) Or can I install removable pins in the mounts for the gas struts? -- Tom Sargent - RV-6A RV_8 Pilot wrote: > >Re. opening a canopy in flight. > >I feel very confident saying I could easily get a canopy open in almost all >cases with two of the RV configurations (that would be the slider and tip >over). But, *getting out* of a spinning, damaged airplane is another story >entirely. > ________________________________________________________________________________
Date: Dec 27, 2003
Jerry: Thanks. I was mistaken; what I have is the 680. Guess I just need to install it. Jimmy ----- Original Message ----- From: "Jerry Springer" <jsflyrv(at)earthlink.net> Subject: Re: RV-List: battery > > Don't know about a 580, but I know the 680 spins my O-360 much better > than the Concorde RGB I had before. > > Jerry > > jimmy(at)jhill.biz wrote: > > > > >Based upon note I have seen here, I recently bought an Odessey 580 battery for my RV8A, with an IO-360 (200HP) Lyc. The batt is much thinner than the old G-25. > > > > > >So thin that I wonder if it has enough capacity to handle this engine?? > >What are your experiences with it?? > > > >Thanks. > > > >Jimmy Hill > > > > > > > > > > ________________________________________________________________________________
Date: Dec 27, 2003
Michael D Hilger wrote: > > > > >>Of course this is all my opinions and others should do as they feel >>best >>for them. >>Jerry >> >> > > > Jerry, > > How about if you and Bob U both take a pill and let those who are >interested >BE interested... > > Mike Hilger > RV-6 N207AM 500 hrs > Sorry that you feel this way, Mike... But, I'm not obliged to write what pleases you or be silent. That's not what a freedom of speech is about. If you find my comments not to your liking, control yourself by not reading what I post, rather than attempting to police or control me. It's the adult thing to do. Bob ________________________________________________________________________________
Date: Dec 27, 2003
From: Jeff Peltier <jeffpeltier(at)BRSparachutes.com>
On 12/27/03 5:39 AM, "Bob U." wrote: > > >> Jerry, >> >> I agree with most your assessment above and would like to add my two >> cents worth. >> >> 1. I read that the Cirrus that is back flying was a FREAK SAVE. The >> report I read stated that tree branches or some such broke the fall of >> the aircraft sufficiently before it hit the ground - if it even hit the >> ground, allowing the airframe to be reused at practical costs. Other >> Cirrus deployments were not so 'press-worthy' , it seems. >> >> 2. I believe the scenario describing a low wing plane ditching over >> water is probably the best and safest use of a ballistic chute since my >> luck would have me landing directly on a flag pole, in busy rush hour >> traffic, the Indy 500 or being bounced down a mountain slope in 30 knot >> winds.... provided the seat in an RV can be modified to prevent the >> occupants from breaking their backs on impact. Using the standard pan >> used in my RV would be a killer. Dunno if three inches of TEMP-R-FOAM >> or some such can save my delicate spine and vertebrae so I might swim to >> shore. [Yes, good judgment would minimize flying outside of gliding >> distance to shore in the first place, but ya never know what kind of >> superior fool will fool a foolproof airplane.] ;-) >> >> 3. YMMV >> >> P.S. >> Anybody know how the famous Jim Handbury died? I was told his death was >> caused by a test parachute that tangled in the control surfaces of the >> aircraft.he was piloting. >> > I forgot to add -- > The above only applies if, BIG IF.... > if the ballistic chute can be made to deploy properly and repeatedly in > the first place. This is hardly a 'given' at this point and I'd hate to > assume anything that would jeopardize my next 50 years of successful > flight. :-) > > Bob - over 50 years of successful flight > > > > > > Hi Bob, The Cirrus save you mention is not considered a "freak" save by any means. When airplanes are drop tested to determine spinal loads on the occupants, its done on very hard concrete-virtually anything else is gravy to us. The trees in that incident also served to pitch the aircraft forward just prior to touchdown, forcing the nose assembly to absorb virtually all the impact, not the mains as designed. The fact is that when an in-flight emergency occurs you can't always dictate where you'll be. What we do know is that emergencies will occur whether you have a way out or not. Jim Handbury died while tossing small parachutes out the door of his C150 not while testing ballistic chutes. One of the chutes got hung-up on his horizontal stabilizer and he was no longer able to control it. He was wearing a personal safety chute, but didn't quite make it out of the airplane. Jeff Peltier ________________________________________________________________________________
Date: Dec 27, 2003
Subject: Re: BRS
December 15, 2003 - December 27, 2003
RV-Archive.digest.vol-oq
