RV-Archive.digest.vol-oz
March 02, 2004 - March 07, 2004
Subject: Baffle/cooler problem
> > I have an oil cooler dilemma. The cutout I made on the rear baffle is > 1/4" too low, allowing the middle mounting bolt on the inboard side to > interfere with the cylinder head cooling fins. This is on an O-360 with > a Aero-Classics cooler. > > See here: > http://bowenaero.com/pix/lowcooler.jpg > > Possible fixes: > > 1. Replace/reconstruct all baffling for that corner, next time raising > the cooler 1/4". (sigh) > > 2. Use only one bolt (the upper one) on the inboard side. > > 3. Use short bolt with head fwd in middle hole. Might clear > cylinder.... > > 4. Relieve cylinder head cooling fins as needed to clear bolt/nutplate. > (cringe) > > 5. Other > > Ideas? Thoughts? > > Thanks, > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > ________________________________________________________________________________
Subject: tip-up canopy strut brace
Date: Mar 02, 2004
A while back I remember seeing somebody had a simple, elegant way to keep the tip-up canopy propped up (pretty sure it was on an RV-6). It was something that slipped over the shaft of the gas strut when the canopy was open, preventing the canopy from coming down inadvertently. Anybody out there know whaddamean? Was it just a piece of aluminum tubing? I forget! )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: Re: Weight/balance program
Date: Mar 02, 2004
Here are two wt&bal websites I've collected. I use the first one. Haven't tried the 2nd. http://www.mrkent.com/flying/wt-bal/login.asp http://www.florintsev.com/wb/ David Carter ----- Original Message ----- From: "David Aronson" <aronsond(at)pacbell.net> Subject: RV-List: Weight/balance program > > hey listers: > I have looked in the archives but can't find weight and balance program. Anyone with a program I would appreciate it. > Dave Aronson > RV4 N504RV > FINALLY FINISHED<) inspection Saturday > > ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Re: Van's vs Electric Bob's approach
At 05:32 PM 3/1/2004, you wrote: >Just be sure that you REALLY understand this system because when you land >in the middle of North Dakota with an electrical problem YOU are going to >be the expert - the mechanic on duty at the FBO isn't going to know squat >about it. My experience with mechanics and electrical problems is limited to two incidents, one where a very young mechanic needed a little help understanding alternators and regulators and the other, a very senior IA said we'd have to remove the alternator and send it in. I gave a gentle tug to the field lead and it fell off. Reconnect and problem fixed. He still charged me for half an hour! He may have muttered, "Darn, another alternator sale lost!" My Debonair is mysterious enough but it does have a wiring diagram. (What are those battery cable going to the panel?) Finally, if you think Bob's systems are difficult, stay well away from modern automobiles! K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Mar 02, 2004
>I have an oil cooler dilemma. The cutout I made on the rear baffle is >1/4" too low, allowing the middle mounting bolt on the inboard side to >interfere with the cylinder head cooling fins. This is on an O-360 with >a Aero-Classics cooler. > >See here: >http://bowenaero.com/pix/lowcooler.jpg > >Possible fixes: > >1. Replace/reconstruct all baffling for that corner, next time raising >the cooler 1/4". (sigh) > >2. Use only one bolt (the upper one) on the inboard side. > >3. Use short bolt with head fwd in middle hole. Might clear >cylinder.... > >4. Relieve cylinder head cooling fins as needed to clear bolt/nutplate. >(cringe) > >5. Other > >Ideas? Thoughts? > >Thanks, > >- >Larry Bowen Use flush screw and dimple/countersink as needed. No more interference with cooling fins. Brian Denk RV8 N94BD RV10 '51 Frustrated with dial-up? Lightning-fast Internet access for as low as ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Re: tip-up canopy strut brace
Dan Checkoway wrote: > > A while back I remember seeing somebody had a simple, elegant way to keep > the tip-up canopy propped up (pretty sure it was on an RV-6). It was > something that slipped over the shaft of the gas strut when the canopy was > open, preventing the canopy from coming down inadvertently. > > Anybody out there know whaddamean? Was it just a piece of aluminum tubing? > I forget! > > )_( Dan > RV-7 N714D > http://www.rvproject.com Dan, slit a couple of lengths of rubber fuel hose and slip them over the strut shafts. Works like a charm. Sam Buchanan ________________________________________________________________________________
Date: Mar 02, 2004
Hi Dan, Go to your local hardware store and look at the screen door mechanisms. (Like our struts). There is a simple locking device that can be fabricated that will lock them in the up position. It simply slides down to the cylinder and prevents the shaft from retracting. Darwin ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: tip-up canopy strut brace > > A while back I remember seeing somebody had a simple, elegant way to keep > the tip-up canopy propped up (pretty sure it was on an RV-6). It was > something that slipped over the shaft of the gas strut when the canopy was > open, preventing the canopy from coming down inadvertently. > > Anybody out there know whaddamean? Was it just a piece of aluminum tubing? > I forget! > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Re: Baffle/cooler problem
In a message dated 3/2/04 6:20:31 AM Pacific Standard Time, Larry(at)bowenaero.com writes: << I have an oil cooler dilemma. The cutout I made on the rear baffle is 1/4" too low, allowing the middle mounting bolt on the inboard side to interfere with the cylinder head cooling fins. This is on an O-360 with a Aero-Classics cooler. >> I had a similar problem Larry, same engine and seven row Aeroclassics, except in my case it was the bottom bolt that interfered with the cylinder fins. I just put the cooler on my drill press and put a new hole bolt hole through the mounting flanges between the bottom and middle hole. Seems like it will work fine but I'm not flying yet. I used nut plates on the forward side of the rear baffle for the oil cooler mounting bolts. I also had to cut away aft inboard cooler mounting flange around the middle bolt hole to clear the engine mount, so used a short bolt just through the forward inboard hole in that location. Hope this helps. Harry Crosby Pleasanton, California RV-6, final assembly ________________________________________________________________________________
Date: Mar 02, 2004
Another cool program for W&B: http://bidasst.bizland.com/rv8wbp.htm You can set it up for a RV4 or whatever, Then it calculates the change in W&B over the duration of the flight! Forgot where I found it. Warren http://ahyup.com ________________________________________________________________________________
Date: Mar 02, 2004
I have survived one night VFR Alternator failure in a spam can. My RV 6A is getting the Bob's electric experience with dual alternators and a RG battery that will give me an hour in the air if both fail. Of course it is also getting a very good IFR panel at the same time. I bought a 300 hour old 6 with a basic VFR panel and I no longer want to fly at night without an IFR capable plane. Matthew M. Jurotich NASA/Goddard Space Flight Center Swales contractor to the JWST ISIM Systems Engineer m/c : 443 e-mail mail to: phone : 301-286-5919 fax : 301-286-7021 JWST URL: <http://ngst1.gsfc.nasa.gov ________________________________________________________________________________
Date: Mar 02, 2004
Bob's system is so simple I could understand it on one read. I read it again to make sure I was not kidding myself. Matthew M. Jurotich NASA/Goddard Space Flight Center Swales contractor to the JWST ISIM Systems Engineer m/c : 443 e-mail mail to: phone : 301-286-5919 fax : 301-286-7021 JWST URL: <http://ngst1.gsfc.nasa.gov ________________________________________________________________________________
Subject: tricks for keeping clean, draining preservative oil
Date: Mar 02, 2004
I'm about to drain the inhibiting/preservative oil from the engine, and I'm curious if there are any neat tricks for keeping everything relatively clean as the oil pours out the bottom plug holes? )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Mar 02, 2004
Dave, If you have an PC type computer, try the program I wrote several years ago. Go to: http://www.matronics.com/enclosures.html/ Then go to August 29, 2001 (way at the bottom of the list). There you can download a CG program. Then just run the program and it should install itself on your computer and then have fun. Let me know what you think. You can change any of the parameters you want. It defaults to the numbers in Van's manuals back then. Email me directly if you have a question. Tom ----- Original Message ----- From: "David Aronson" <aronsond(at)pacbell.net> Subject: RV-List: Weight/balance program > > hey listers: > I have looked in the archives but can't find weight and balance program. Anyone with a program I would appreciate it. > Dave Aronson > RV4 N504RV > FINALLY FINISHED<) inspection Saturday > > ________________________________________________________________________________
Subject: Oshkosh Camping Question
Date: Mar 02, 2004
I'm not an outdoorsman but plan on flying the RV to OSH again this year and now trying camping with it. My question is what tent (brand & type) would you experienced RV-campers suggest? I will be alone and the tent won't be used except for this and perhaps a few more years for RV events. Ideas? John ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Re: Dynon Pitot
> >Their first version is unheated, but their goal is to offer a heated one, >not sure if it is available yet. > >Heated should only be required for icing, not all IFR though, or am I >misremembering that??? > >W I guess it depends on what part of the world you are flying in, and what time of the year. If you are going to fly IFR you need to be ready to fly in cloud. If you are flying in cloud above the freezing level, you could hit icing conditions. If your airframe starts icing up you are probably OK if you take immediate action to exit the icing conditions. That may be a climb or a descent or a 180, depending on the situation. If your pitot ices up, and you can descent below the freezing level, that will probably work out OK. But if your pitot ices up and the situation dictates a climb then it might get pretty interesting. You could try to rely on the met forecasts to stay below the freezing level. But the met guys don't always get it right, and it is real hard to stay below the freezing level but above the minimum IFR altitude in many parts of the world for much of the year. We are not required to follow FAR 23, but it is smart to review what it says, as those requirements usually have their root in lessons learned in accidents. FAR 23.1323(d) says "If certification for instrument flight rules or flight in icing conditions is requested, each airspeed system must have a heated pitot tube or an equivalent means of preventing malfunction due to icing." So, if you plan to fly IFR I highly recommend a heated pitot. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Re: Dimple or countersink 904/976/922
Matthew, I too called Vans about this. I was told to dimple anything up to and including .040". I believe the spar flange there is .040. It is better to dimple than to countersink because countersinking weakens the .040 more than dimpling does. Dimpling makes a very strong joint, stronger than the rivet alone, because of the interlocking of the two materials in shear. The reason for countersinking where they say is to avoid having to countersink the floor reinforcement angles to clear the dimples, which would leave them very thin where the shop heads would set. Hope this helps, Dan N766DH RV-7A (working on gear fairings) In a message dated 2/29/04 1:41:46 PM US Eastern Standard Time, matthew(at)n523rv.com writes: > > I'm about ready to disassemble the center section assembly but before I do, > I need some input. The F-972 floor skin overlaps the F-976 center section > skin which in turn sits on the flange of the 904 E&F. The plans note four > places you should countersink the 976/904 because this is where the floor angles > attach on the inside. This implies that you should dimple the rest. The > flange on the 904 is pretty thick, and dimpling this plus the two skins could > leave a not so hot mating surfaces between them all. > > I'm thinking I'll countersink the entire row of 976 skin/904 flange and > dimple the 972 skin to sit inside the countersink. Is this what others did?? Am > I missing something?? > > > Matthew Brandes > Van's RV-9A (Wings) > EAA Chapter 91 &868 > www.n523rv.com > matthew(at)n523rv.com > > ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Re: Oshkosh Camping answer
Hi John, Been there. No need to get real fancy, but a basic tent (I just upgraded to a lightweight Coleman 7'x7' dome tent since Oshkosh) for about $40.00, and get a coleman air bed with a battery powered airpump. Having that six inches of air floatation while sleeping makes for a good nights sleep, WAY BETTER than those 2" pads, I've found. Of course, you'll need a good set of Ti-downs, to hold your RV down while parked there at Homebuilt heaven *wink*. That's all you need to take to Osh (besides money)...tent, airbed, sleeping bag, Ti-downs, RV...everything else is just fluff... Sincerely Randy Simpson Ultralight flying, aircamping adventurer p.s. here's a little ditty from an aircamping adventure last summer... http://www.airtimemfg.com/greenpetereservoir/aircamping.htm > >I'm not an outdoorsman but plan on flying the RV to OSH again this year and >now trying camping with it. My question is what tent (brand & type) would >you experienced RV-campers suggest? I will be alone and the tent won't be >used except for this and perhaps a few more years for RV events. Ideas? > >John > > ________________________________________________________________________________
Date: Mar 02, 2004
I strongly agree with item no. 4 of Stein Bruch's reply. I bought the wiring kit from Van's to speed up the wiring of my RV-7A, but found the kit to be money wasted, about half of it was, anyway. In buying the kit, I bought a lot of heavy gauge wire (starter and battery cable) which was not used. They sell you every length you could possibly use with terminals installed. You will only use 4 out of the 10 heavy (4 gauge) wires they sell you. I would say they "give" you, but you are BUYING it. I found Van's terminal block system unnecessary because every one of the posts only goes to a circuit breaker. Therefore, why not just wire your lights, radio, etc., directly to the breaker and save the weight and space? That's what I did. The wiring kit was the first time I felt that I got a bad deal from Van's. I'm not a complainer (usually!) so I let it pass, and just used parts from the kit and wrote it off to experience. Maybe someone on the RV-List will benefit from this advice. Get the documentation, then buy what you need, either from Van's or somewhere else. Buy or borrow a heavy crimping tool for the 4 to 10 gauge wire. Definitely use aircraft quality wire and terminals. Most of the stuff you find today in the auto parts stores is not high quality. I had not heard of Electric Bob at the time I was wiring my plane, or I'm sure I'd gone his route. I may redo some of it, but its done now and I want to fly the airplane first. Dan RV-7A N766DH (almost done in IN) 4) Very few people actually build a panel to match the kit that Van's > sells. Many of them end up cutting up Van's Wiring kit to use the wire, in > which case it's almost a total waste of money (ok, not total waste--just > overpriced). If you build a panel to their specs, it works fine. > But....Add a Dynon, autopilot, GPS, engine monitor, etc.. and you'll need a > lot more. That being said, if you are buying the Van's kit just for the > wire and terminals, it's way more expensive than just buying the raw > materials themselves. > > Cheers, > Stein Bruch > RV6's, Minneapolis > > ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Re: tricks for keeping clean,draining preservative oil
BE SURE to put a good funnel under the drain hole prior to removing the plug !!! Then don't drop the plug in the drain pan. Oil won't kill you unless ,you drink it ?/! Good luck Dan;C'mon & get flying, Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Re: Oshkosh Camping Question
John wrote: > >I'm not an outdoorsman but plan on flying the RV to OSH again this year and >now trying camping with it. My question is what tent (brand & type) would >you experienced RV-campers suggest? I will be alone and the tent won't be >used except for this and perhaps a few more years for RV events. Ideas? > >John > Sure. By far, the best tent I've owned is a dome tent. Get a tent with a rain fly so the tent can breathe. In cooler weather it's rather unpleasant to roll over, hit the side of the tent and get rained on!!! Check the height of the tent. It's always nice to be able to bend over and pull your long pants on!!! Try and find a tent that will fit in it's little bag and be about 18" long. The length of the pole segments will decide how long the package is. Also, don't just buy cheap. The better tents are worth the extra bucks. Linn > > > > ________________________________________________________________________________
Date: Mar 02, 2004
John As a EAA Ambassador Volunteer that camps out there every year and drives people around in a golf cart my I suggest you decide where you are going to camp first Choice ONE is camp with your plane, but now you are out next to the west end of 9-27. This can be a hike to get anywhere. There is a shuttle bus and golf carts . Or you may be at the way south end 18-36. Advantages you are near your plane at night Choice TWO is to camp in Camp Scholler just to adjacent to AIRVENTURE Buildings. Advantages are you can park your plane and show it off with the rest of the RV's. There is a grocery store at Camp Scholler and more showers etc. The other big advantage is you can easily get over to Dick Martins camp sight in the woods and drink his beer. If you don't know Dick, he is the one on the RV Flight line with an all aluminum hopped up RV8 and a straw hat As for camping gear get a big tent & seam seal. If the tents says its a two man don't believe then get a four man they are not that big E mail me for other suggestions Dane Sheahen RV8a 140hrs dane(at)mutualace.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Subject: RV-List: Oshkosh Camping Question I'm not an outdoorsman but plan on flying the RV to OSH again this year and now trying camping with it. My question is what tent (brand & type) would you experienced RV-campers suggest? I will be alone and the tent won't be used except for this and perhaps a few more years for RV events. Ideas? John ________________________________________________________________________________
From: "Clifford Begnaud" <shoeless(at)barefootpilot.com>
Date: Mar 02, 2004
John, I started camping well over 40 years ago. After all these years, I can tell you one thing; don't buy your tent at k-mart, Wal-Mart, target or any other mass retailer. Bite the bullet and go to a bonifide outdoor shop and buy a "QUALITY" tent. The cheap ones will leak when it rains, and they will likely be blown down in a strong wind. If they are not blown down they will keep you up at night when it's windy because of the poor construction and poor fit, look for a tight fitting rain fly. A quality tent will have a lifetime guarantee. Also, get some heavy duty tent stakes to use at Oshkosh. Every year I see a tent or two go flying by on a windy afternoon. I also see numerous cheap tents that are well staked but they just get blown over and the tent poles are usually broken. If the price of a quality tent is too much to bear, try to find a used one. If there is a college in your town, there's always some rich kids selling the nice tent that mommy bought them because they used it once in their back yard and now they need to buy some new Nike's or baggy pants (or worse). Here's a few quality brands to look for: North Face, Marmot, Mountain Hardware, Sierra Designs, Kelty, REI, EMS, Black Diamond, Eureka, MSR. There's probably a few others but these will be the most common. Avoid getting those giant size tents that are big enough to park a car in. They are the most likely to be damaged in strong winds. A medium to low profile tent that allows you to upright inside is best. Bon Marche, Cliff > I'm not an outdoorsman but plan on flying the RV to OSH again this year and > now trying camping with it. My question is what tent (brand & type) would > you experienced RV-campers suggest? I will be alone and the tent won't be > used except for this and perhaps a few more years for RV events. Ideas? > > John ________________________________________________________________________________
Subject: Alternator Warning Light Circuit
Date: Jun 01, 2004
Hi Rob I might have posted this once before but not sure so I'll do it again. I have a big red idiot light wired up in my four just as you describe. It is in my post flight shut down scan and so far it has saved me leaving the master on a couple of times. If you look at your alternator, you will see a terminal in the plug that indicates that it is for a light. If it you can't find this you need to identify which terminal is for the light. The light is wired so it illuminates from a power source when the master is turned on. The ground side of the light is wired to the terminal on the alternator that you have identified as the one for an idiot light. While the alternator is not turning this terminal provides the ground for the light and it is illuminated. Once the alternator is turning and producing power, it sends power to this terminal and as the light now has power coming from two sides and no ground, it goes out. If the alternator begins to fail slowly, the terminal becomes more and more of a ground and the light begins to illuminate, just as it does in a car. Seems to work for me, although I haven't had the alternator quite in flight as yet. I got this explanation how they work from an old guy in an alternator rebuild shop. Cheers. Joe Hine RV4 C-FYTQ -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Rob McAnally Subject: RV-List: Alternator Warning Light Circuit Hi, Does anyone have a circuit to suit the following request. I want to install an alternator warning light similar to auto installations. i.e. light illuminates when the master switch is on and the engine is not running, but goes out as soon as the alternator provides greater than the battery voltage back to the system. I have stock Vans equipment, a 35amp Nippondenso alternator and an adjustable regulator (case to ground, voltage in, centre stud voltage to the alternator). I have a couple of circuits that are a little confusing and wonder if anyone has ideas for this equipment. Regards Rob ________________________________________________________________________________
Date: Mar 02, 2004
From: "thomas a. sargent" <sarg314(at)earthlink.net>
I am just aboout to install my tip-up canopy struts. I'm puzzled that this is even necessary. The struts seem pretty stout. How can the canopy come down inadvertently? Are you referring to slow gas leaks in the strut or do they just not work very well? -- Tom Sargent >----- Original Message ----- >From: "Dan Checkoway" <dan(at)rvproject.com> >To: >Subject: RV-List: tip-up canopy strut brace > > >A while back I remember seeing somebody had a simple, elegant way to keep >the tip-up canopy propped up (pretty sure it was on an RV-6). It was >something that slipped over the shaft of the gas strut when the canopy was >open, preventing the canopy from coming down inadvertently. > >Anybody out there know whaddamean? Was it just a piece of aluminum > > >tubing? > > > > > ________________________________________________________________________________
"RV List" , "Bruce MacInnes"
Subject: Re: Cool oil temps cure
Date: Mar 02, 2004
Thanks Bruce - I have the E2A in my -4 - what size ball valve and where did you get it? To you listers - this should be self ezplanatory. Jim ---- Original Message ----- From: "Bruce MacInnes" <m_motorsports(at)hotmail.com> Subject: RE: Cool oil temps cure Jim, The cooler baffles don't work. I have a stainless steel ball valve inline to my cooler with a push-pull cable to the panel. It is the only thing that will get the job done on my 0-320 E2D powered RV-4. As I understand it, a fully closed vernatherm still flows some oil, most likely to prevent oil from congealing in the cooler. I try to open my valve (slowly) on every flight to prevent this problem...This system has been in place for many years, is very convenient, and is perfect on long flights (to Florida) when the temperature changes...Feel free to post this to the RV-list. I do not subscribe, but I do like to chec it out...Information on this can be found in the archives. Bruce MacInnes Senior Instructor The Skip Barber Racing School 860-435-4270 W 413-229-8853 H N 14 FT - 463 TT ________________________________________________________________________________
Subject: Toggle Switches
Date: Mar 02, 2004
Vince, Here's one source: http://pegasusautoracing.com/pdfs/048.pdf Part No. 4428 near upper right corner of page. Chris Heitman RV-9A N94ME http://my.execpc.com/~cjh/rv9a.html -----Original Message----- The majority of the toggle switches that I purchased came without anti-rotation washers. I have looked in several catalogs (Newark, etc.) and can not find them listed separately. Can one of you guys tell me where I can buy anti-rotation washers separately? Vince Welch --- ________________________________________________________________________________
Date: Mar 02, 2004
> I am just aboout to install my tip-up canopy struts. I'm puzzled that > this is even necessary. The struts seem pretty stout. How can the > canopy come down inadvertently? Are you referring to slow gas leaks in > the strut or do they just not work very well? Am I correct in assuming you have a nosewheeler? My theory is that enough headwind, plus the tail-on-ground attitude, would be enough to force the canopy down and ruin my day. I just want to take every precaution possible to keep that sucker from coming down inadvertently. The gas struts do seem to weaken with age, according to the reports I've read, but I'm paranoid even with my "new" ones (~2 years since receiving them). They're stout, and you have to pull the canopy down a fair way before the struts give out, but I ain't takin' any chances! 8-) )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "thomas a. sargent" <sarg314(at)earthlink.net> Subject: Re: RV-List: tip-up canopy strut brace > > -- > Tom Sargent > > >----- Original Message ----- > >From: "Dan Checkoway" <dan(at)rvproject.com> > >To: > >Subject: RV-List: tip-up canopy strut brace > > > > > >A while back I remember seeing somebody had a simple, elegant way to keep > >the tip-up canopy propped up (pretty sure it was on an RV-6). It was > >something that slipped over the shaft of the gas strut when the canopy was > >open, preventing the canopy from coming down inadvertently. > > > >Anybody out there know whaddamean? Was it just a piece of aluminum > > > > > >tubing? > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Electric Bob Weekend Class This Week in Groton, CT
Date: Mar 02, 2004
The class is $150 but the book is not included. It is discounted to $20 with the class and can be shipped to your house prior to the class. I'm signed up for the class in Kalamazoo, MI on 20-21 March 04. I hope to learn a bunch because I'm planning a 2-screen GRT EFIS and Engine Monitor and I'm an electrical idiot! Doug Fischer -9A 90706 Wings ----- Original Message ----- From: "Donald Mei" <don_mei(at)hotmail.com> Subject: RV-List: Electric Bob Weekend Class This Week in Groton, CT > > > Sorry for the blatant ad copy, but our EAA chapter is hosting Electric Bob > this weekend in Groton, CT and I thought now might be a good time for > another pitch. > > You can sign up for the 2 day class at his web site: > www.aeroelectric.com > Cost is I THINK $150 and that includes his book. > > If you'd like to attend but are worried about a place to stay, give me a > call. (860-625-7853) We'll find something cheap, or free (my house, pending > my wife's approval) for you. > > Best regards, > > Don Mei > Vice President EAA 334 > RV-4 > 3B9 - Chester, CT > > > "All of us need to be reminded that the federal government did not create > the states; the states created the federal government!"---Ronald Reagan > > Find things fast with the new MSN Toolbar includes FREE pop-up blocking! > http://clk.atdmt.com/AVE/go/onm00200414ave/direct/01/ > > ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Van's alternator
> I had a bad experience with Van's " rebuilt" alternator.I disassenbled the end bells > to cut a cooling hole in it for the diodes.after it was opened, I found one broken > diode and all leads were poorly soldered or not soldered at all. The wires had been > so hot , the insulation was melted back on them. The outside had been glass beaded > but the inside was a mess. Not "rebuilt" as I had paid for. It was the 35 amp > nipondenso. I would recommend buyers to check out their local auto supply first. > Unfortunately a lot of stuff gets bought way in advance and the 30 day return policy > has long been expired when it is time to install it. I also wrote it off to > experience. > > Hopefully I can buy a set of diodes for it. Has anyone ever replaced them or know if > they are available? > > Phil in Illinois Phil, the alternator is a NipponDenso as used on 1976-1979 Honda Civic CVCC without air conditioning. A common number you can find in Duralast and other reman alternators is 14184. About $49.00 at Advance Auto and Autozone. When I replaced my Vans alternator recently, I left the fan on the 14184. Sam Buchanan ________________________________________________________________________________
Date: Mar 02, 2004
Subject: Re: Strobe power supply repair
FWIW, I had an Aeroflash strobe power supply go bad, flat rate around $45 for repair. Works great now! -Mike Kraus ________________________________________________________________________________
Date: Mar 02, 2004
Tom Gummo wrote: > >Dave, > >If you have an PC type computer, try the program I wrote several years ago. >Go to: > >http://www.matronics.com/enclosures.html/ > >Then go to August 29, 2001 (way at the bottom of the list). There you can >download a CG program. Then just run the program and it should install >itself on your computer and then have fun. > >Let me know what you think. You can change any of the parameters you want. >It defaults to the numbers in Van's manuals back then. Email me directly if >you have a question. > >Tom > ================================== I've been using your program since it appeared in 2001. It's the best. Kudos!!! Many thanks. Bob ________________________________________________________________________________
Date: Mar 02, 2004
They have just opened up a new camp ground with new show house I believe west of the tower for home builts. Check the EAA web site. www.eaa.org Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or sportpilot(at)eaa.org Always looking for articles for Sport Pilot ----- Original Message ----- From: "Dane Sheahen" <dane(at)mutualace.com> Subject: RE: RV-List: Oshkosh Camping Question > > John > > As a EAA Ambassador Volunteer that camps out there every year and drives > people around in a golf cart my I suggest you decide where you are going to > camp first > > Choice ONE is camp with your plane, but now you are out next to the west end > of 9-27. This can be a hike to get anywhere. There is a shuttle bus and > golf carts . Or you may be at the way south end 18-36. Advantages you are > near your plane at night > > Choice TWO is to camp in Camp Scholler just to adjacent to AIRVENTURE > Buildings. Advantages are you can park your plane and show it off with the > rest of the RV's. There is a grocery store at Camp Scholler and more > showers etc. The other big advantage is you can easily get over to Dick > Martins camp sight in the woods and drink his beer. If you don't know Dick, > he is the one on the RV Flight line with an all aluminum hopped up RV8 and a > straw hat > > As for camping gear get a big tent & seam seal. If the tents says its a two > man don't believe then get a four man they are not that big > > E mail me for other suggestions > > Dane Sheahen > RV8a 140hrs > dane(at)mutualace.com > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John > Sent: Tuesday, March 02, 2004 3:53 PM > To: rv-list(at)matronics.com > Subject: RV-List: Oshkosh Camping Question > > > I'm not an outdoorsman but plan on flying the RV to OSH again this year and > now trying camping with it. My question is what tent (brand & type) would > you experienced RV-campers suggest? I will be alone and the tent won't be > used except for this and perhaps a few more years for RV events. Ideas? > John > > ________________________________________________________________________________
Subject: Fuel Tank Fit
Date: Mar 02, 2004
All, Currently fitting my fuel tank to my wings. I followed Dan C's method of aligning, and I have the tank aligned perfectly (L to R). The only problem I see is that the leading edge on the tank protrudes *slightly* more than the leading edge on the outboards section. I would estimate the protrusion to be about the thickness of the skin. Anyone else experience this? I did remove the plastic already. My only thoughts might be to sand the surface of the z-brackets down a bit. Only concern might be that's a lot of work (x7) and I am afraid I may mess it up worse. Am I being too picky here? I thought I saw a similar post recently but could not dig it up in the archives. Thanks, Scott 7A Wings Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Date: Mar 03, 2004
> > Hopefully I can buy a set of diodes for it. Has anyone ever replaced >them or know if > > they are available? > > > > Phil in Illinois > > >Phil, the alternator is a NipponDenso as used on 1976-1979 Honda Civic >CVCC without air conditioning. A common number you can find in Duralast >and other reman alternators is 14184. About $49.00 at Advance Auto and >Autozone. When I replaced my Vans alternator recently, I left the fan on >the 14184. > >Sam Buchanan I just received a 14184 per Sam's specs from Autozone. It's a rebuild, but appears to be very nicely done...very clean, spins smoothly, etc. I don't plan to split the case to check diodes unless curiosity gets the best of me! It will be kept as a spare, and if needed, the fan will stay on. Brian Denk RV8 N94BD RV10 '51 ________________________________________________________________________________
Subject: Wiring the Nuckolls way or .......
Date: Mar 02, 2004
Dave RV6 So Cal EAA Technical Counselor Wrote "Guys, Just be sure that you REALLY understand this system because when you land in the middle of North Dakota with an electrical problem YOU are going to be the expert - the mechanic on duty at the FBO isn't going to know squat about it. And of course there's the poor shmuck that you sell it to later on...." He's absolutely right. Of course with up to date wire books and well labelled wiring a competent electrician should be well able to follow the logic of Bob's designs. The key is the up to date wire books and the carefully labelled wires. Rob Rob W M Shipley N919RV (res) Fuselage .....still! ________________________________________________________________________________
Subject: RTV corrosion
Date: Mar 02, 2004
Jeff wrote: Subject: Re: Trailing edge of new rudder "used clear RTV on the trailing edge of my elevator" I have heard, (you know that can be, though) that RTV may corrode aluminum. Probably the acetic acid as it cures. Something to watch. This was noted by some people that used it to cure the oil-canning of -4 and -6 type control surfaces. Also, keep it away from your canopy, unless it's the type approved for electronics. Once again, just stuff from past threads on this forum. FWIW etc. Jeff This is quite correct and easily dealt with. Make sure that any silicone / rtv you use on metal is the neutral cure type. Rob Rob W M Shipley N919RV (res) Fuselage .....still! ________________________________________________________________________________
Date: Mar 03, 2004
> > >The gas struts do seem to weaken with age, according to the reports I've >read, but I'm paranoid even with my "new" ones (~2 years since receiving >them). They're stout, and you have to pull the canopy down a fair way >before the struts give out, but I ain't takin' any chances! 8-) > > Even if only one of them goes, it could cause your canopy to come crashing down in a most disturbing way. This happened to me shortly after finishing the canopy, due to a defective strut. Try unhooking one of them, and see how well the other holds the canopy up. Van's replaced it free of charge. I'm glad I didn't have to bargain with them to replace the canopy destroyed as a result of the failed strut! Jeff Point RV-6 inspection this saturday Milwaukee WI > > > > ________________________________________________________________________________
Date: Mar 03, 2004
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net>
Subject: Re: Van's alternator
Sam Buchanan wrote: > > > > I had a bad experience with Van's " rebuilt" alternator.I disassenbled the end bells > > to cut a cooling hole in it for the diodes.after it was opened, I found one broken > > diode and all leads were poorly soldered or not soldered at all. The wires had been > > so hot , the insulation was melted back on them. The outside had been glass beaded > > but the inside was a mess. Not "rebuilt" as I had paid for. It was the 35 amp > > nipondenso. I would recommend buyers to check out their local auto supply first. > > Unfortunately a lot of stuff gets bought way in advance and the 30 day return policy > > has long been expired when it is time to install it. I also wrote it off to > > experience. > > > > Hopefully I can buy a set of diodes for it. Has anyone ever replaced them or know if > > they are available? > > > > Phil in Illinois > > Phil, the alternator is a NipponDenso as used on 1976-1979 Honda Civic > CVCC without air conditioning. A common number you can find in Duralast > and other reman alternators is 14184. About $49.00 at Advance Auto and > Autozone. When I replaced my Vans alternator recently, I left the fan on > the 14184. > > Sam Buchanan Thanks Sam, this is real good information. PS ________________________________________________________________________________
Subject: Dynon Info
Date: Mar 03, 2004
Hi all, don't know if this is general knowledge, but I thought this response was good enough to share with the list. I finally bit the bullet and ordered my Dynon and associated toys. Tony and Monte have been really great to deal with. Would like to throw out a big thanks to Dynon just for making a good pitot tube for a reasonable price. Every little victory adds up. Eric Thanks for your order, we look forward to receiving it and we'll get it processed as soon as it's received. The wing tip is the preferred location for the remote compass. This gets the remote compass as far away from the panel and ferrous materials (engine, engine mount, landing gear, etc.) as possible. If you have a strobe power supply in the wing tip, you'll want to install the compass as far away from the box as possible (within the wing tip). The EFIS-D10 "samples" the remote compass 64 times/second and averages these samples. Even with the comet flash strobes, there is only small amount of time, relative to the sampling rate, that any significant interference can be generated by the strobe power supply. The remote compass will sense the strobes as they discharge but the user probably won't notice any change on the EFIS-D10 display (due to the averaging and large number of samples taken each second). Now that you understand how the EFIS-D10 gathers and processes compass signals, it explains why electric gyro's (being continuous sources of interference) are the most problematic to correct. As a side note, if you ever think you may be installing our ER Tanks, mount the remote compass at least 1 foot behind the main spar. Then you won't have to move it should you install ER Tanks at a later date. (The ER Tanks slide into the first nose rib lightening hole forward of the spar) If there's anything else Monte or I can do for you, please don't hesitate to contact us. Tony Munday and Monte McDavid SafeAir1 817-821-4957 (TM) 817-939-2695 (MM) ________________________________________________________________________________
Subject: Mounting Instruments
Date: Mar 03, 2004
03/03/2004 08:10:24 AM Hi All, I am mounting my flight instruments in the control panel. What type of screws are the best to use? Do I need to use brass or stainless? Are aircraft grade screws required since this is non-structural? Thanks in advance, Tom RV-7A ________________________________________________________________________________
Subject: I39 fly-in queries
Date: Mar 03, 2004
First, congratulations to Dana and his EAA chapter, friends and family for an outstanding start to our flying season. Second, who are these folks Dana mentioned from Pontiac, MI? Did you mean us, from Tecumseh, MI, and just get your Indian chiefs confused? If there are active RV-ers from Pontiac, not far from here by RV, we would like to know them and perhaps get together. Thanks. Gordon and Marge N363GC ________________________________________________________________________________
Date: Mar 03, 2004
A fan is definitely necessary. My friend had the Van's 35 amp fail and take out most of his electronics. (Another plug for Bob's buss.) I opened up the alternator and although it still worked, it was toast. The regulator had failed. The reason Van's removes the fan may be that it rotates backwards for the airplane. Check this, but even so it may be better to have it. An alternator is only about 50% efficient, and really depends on lots of airflow for cooling. Dan (retired automotive engineer) RV-7A N766DH (almost done) In a message dated 3/2/04 10:30:59 PM US Eastern Standard Time, sbuc(at)hiwaay.net writes: > > Phil, the alternator is a NipponDenso as used on 1976-1979 Honda Civic > CVCC without air conditioning. A common number you can find in Duralast > and other reman alternators is 14184. About $49.00 at Advance Auto and > Autozone. When I replaced my Vans alternator recently, I left the fan on > the 14184. > > Sam Buchanan > ________________________________________________________________________________
Date: Mar 03, 2004
Subject: EZ-Pilot display update
Just wanted to update my experiences with the Trio Avionics EZ-Pilot autopilot. I have flown the unit with the new LCD display and am completely pleased with it. The LCD eliminates the only problem that an RV pilot would have with the system. I won't rehash info that is in the archives, but the EZ-Pilot is a plug-n-play replacement for the Navaid head and has a feature set far more advanced than the Navaid. The EZ-Pilot is also completely solid-state and uses those cool new sensors like the other AHRS systems. The Trio website: http://www.trioavionics.com My previous comments on this autopilot: http://home.hiwaay.net/~sbuc/journal/EZ_Pilot.htm Sam Buchanan ________________________________________________________________________________
Date: Mar 03, 2004
lucky macy wrote: > > > For a new build, any mods required to make the Autozone bought one work in > the RV in the first place? Just buy the appropriate boss or case mount > bracket from Vans and we're set? > > How about the 60 Amp internally regulated version? Is there a reason folks > don't use it more often in the first place other than it's more expensive? > Same question about it with respect to buying it local cheaper and mount > without modification. The 14184 will fit perfectly in the Vans bracket. Note that Vans part number for their alternator is........14184. :-) Somebody pulls the fan off the Vans unit but the alternator will work just fine with the fan in place. As for internally regulated alternators, you might read, *ahem*, 'Lectic Bob's discourses on this subject. The internally regulated alternators are a bit more difficult to set up for over-voltage protection than the externally regulated units and that is why Bob recommends the external regulator. He has an inexpensive OV module that can be easily wired into an external regulator circuit. There are many internally regulated alternators on RVs without over-voltage protection. The argument is that the things work fine on cars, why not on our planes? It really comes down to whether or not you want to trust your high doll$$$$$r avionics to the regulator in the alternator. Sam Buchanan ================ > ----Original Message Follows---- > From: "Brian Denk" <akroguy(at)hotmail.com> > To: rv-list(at)matronics.com > Subject: RE: RV-List: Van's alternator > Date: Wed, 03 Mar 2004 04:26:42 +0000 > > > > > > Hopefully I can buy a set of diodes for it. Has anyone ever replaced > >them or know if > > > they are available? > > > > > > Phil in Illinois > > > > > >Phil, the alternator is a NipponDenso as used on 1976-1979 Honda Civic > >CVCC without air conditioning. A common number you can find in Duralast > >and other reman alternators is 14184. About $49.00 at Advance Auto and > >Autozone. When I replaced my Vans alternator recently, I left the fan on > >the 14184. > > > >Sam Buchanan > > > I just received a 14184 per Sam's specs from Autozone. It's a rebuild, but > appears to be very nicely done...very clean, spins smoothly, etc. I don't > plan to split the case to check diodes unless curiosity gets the best of me! > It will be kept as a spare, and if needed, the fan will stay on. > > Brian Denk > RV8 N94BD > RV10 '51 ________________________________________________________________________________
Subject: Re: Mounting Instruments
Date: Mar 03, 2004
Page 93 of the 03/04 spruce catalog ... brass instrument screws - MS24693 is the part. The brass construction will not interfere with the compass readings. Ron ----- Original Message ----- From: <tacaruth(at)ralcorp.com> Subject: RV-List: Mounting Instruments > > > Hi All, > > I am mounting my flight instruments in the control panel. What type of > screws are the best to use? Do I need to use brass or stainless? Are > aircraft grade screws required since this is non-structural? > > Thanks in advance, > > Tom > RV-7A > > ________________________________________________________________________________
Date: Mar 03, 2004
tacaruth(at)ralcorp.com wrote: > > >Hi All, > >I am mounting my flight instruments in the control panel. What type of >screws are the best to use? Do I need to use brass or stainless? Are >aircraft grade screws required since this is non-structural? > >Thanks in advance, > >Tom >RV-7A > Typically the instruments are mounted with black anodized brass screws. They weigh less than steel and are non-magnetic. Aesthetically, however, I guess it depends on the color of your instrument panel. There are many grades of 'stainless' screws, so test with a magnet to be sure. I wouldn't use cad-plated (aircraft) screws because of the cost. Generally, in deciding whether to use common hardware Vs. aircraft bolts, you need to look at the application. Aircraft bolts/screws will bend without fracturing (and they'll bend a lot) while stuff from the hardware store will typically fracture. Tensile strength can be fairly equal depending on the grade of the common hardware. Linn > > > > ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling(at)earthlink.net>
Date: Mar 03, 2004
Has anyone tested one of these? My oil temp is hovering around the published opening temp of 108 C in cold weather and seems to be staying there. Jeff Dowling RV-6A, N915JD 18 hours Chicago/Louisville ----- Original Message ----- From: "Dean Pichon" <deanpichon(at)msn.com> Subject: RE: RV-List: Cool oil temps cure > > Hi Jim, > > I have the same problem with my -4. On cold days, I cannot get the oil > temperature above 150F -even with the downstream side of the cooler blocked. > I plan to block the upstream side as I have been told this is much more > effective though much less easily done. I don't believe the Vernatherm > valve is your problem - assuming you have one. Vernatherm valves are > normally open, and close upon a rise in temperature. They contain a wax > pill much like car thermostats. As the heat of the oil melts the wax, it > expands thereby extending a piston. This piston extension blocks a hole > that otherwise returns oil to the engine. The alternate path (Vernatherm > extended) shunts the oil through the cooler. Even when the Vernatherm valve > is cold, it leaks (by design) oil through the cooler. > > Regarding the manual valve, I've never heard of such a system, but it would > probably help - assuming you were comfortable with any safety issues. I > suggest you try blocking the upstream side of the cooler and let me know how > it works! > > Good luck, > > Dean > RV-4 > Worcester, MA > 180 Hrs > > >From: "Jim Anglin" <jlanglin44(at)earthlink.net> > >Reply-To: rv-list(at)matronics.com > >To: "RV List" > >Subject: RV-List: Cool oil temps cure > >Date: Mon, 1 Mar 2004 08:14:30 -0800 > > > > > >My -4 won't get the oil temps above 150 even with a plate blocking off the > >inlet. Someone told me there was an oil control valve that could be > >installed to manually regulate the flow of oil to the cooler. I know this > >could be potentially dangerous but notwithstanding that does anyone know if > >this info is bogus and if not who would sell these valves? > > > >Jim > > > > > > Learn how to help protect your privacy and prevent fraud online at Tech > > ________________________________________________________________________________
Date: Mar 03, 2004
Subject: Need name of engine shop
Listers, What was the name of the engine shop in Oklahoma mentioned recently on the list? I couldn't find it in the archives. Thanks, Dan RV-7A (almost done) ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Date: Mar 03, 2004
> >I am mounting my flight instruments in the control panel. What type of > >screws are the best to use? Do I need to use brass or stainless? Are > >aircraft grade screws required since this is non-structural? I painted my panel in medium gray (not so reflective in sunlight). The black brass instrument screws (Page 93 of ACS) look really neat in the panel. I chose the pan head MS35214 screws. For the six big holes I used nut rings (Vans Catalogue and Page 342 of ACS). They allow you to install and remove those instruments from the front. The screws match the above pan head screws used everywhere else. Cool. Ernest Kells - RV-9A O235-N2C, Wood Prop 90% Complete - electrical and pre-paint ________________________________________________________________________________
Subject: Michigan RV's
Date: Mar 03, 2004
RV's in Michigan, My plan was to attend the RV event in Kentucky however I did not make it. I am sorry that I did not attend, I heard it was a really great time. Yes, I am from Pontiac, Mi. We have at least 6 RV's based here and at least another dozen builders and flying RV's in the area. Great group of guys, just give us a call, we also welcome new friends. Ted Gauthier, RV-6 125hours DAR Pontiac, Mich. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Gordon and Marge Subject: RV-List: I39 fly-in queries First, congratulations to Dana and his EAA chapter, friends and family for an outstanding start to our flying season. Second, who are these folks Dana mentioned from Pontiac, MI? Did you mean us, from Tecumseh, MI, and just get your Indian chiefs confused? If there are active RV-ers from Pontiac, not far from here by RV, we would like to know them and perhaps get together. Thanks. Gordon and Marge N363GC = = = = ________________________________________________________________________________
Subject: Re: Need name of engine shop
Date: Mar 03, 2004
Are you looking for DIVCO in Tulsa (1-800-874-1351)? ----- Original Message ----- From: Hopperdhh(at)aol.com To: rv-list(at)matronics.com Sent: Wednesday, March 03, 2004 9:30 AM Subject: RV-List: Need name of engine shop Listers, What was the name of the engine shop in Oklahoma mentioned recently on the list? I couldn't find it in the archives. Thanks, Dan RV-7A (almost done) ________________________________________________________________________________
Date: Mar 03, 2004
Subject: Airworthiness Inspection
Group... Had an opportunity to observe airworthiness inspection yesterday. My advice... if you get a chance to watch one, do it. You will learn a heap of stuff. I took away from this that before your "final", you should tear that baby down and do a formal "condition inspection" yourself, using the checklist and paying a LOT of attention to tiny details, like proper safety wire, anti chafing, nuts, bolts, washers. The inspector in this case, Mike Robertson, was beyond thorough, and I got a new appreciation for the work these guys do. Jerry Cochran RV6a...flying one, building one. ________________________________________________________________________________
From: "Albert Gardner" <spudnut(at)worldnet.att.net>
Date: Mar 03, 2004
ACS also sells an Instrument Mounting Nut (pg 86) that attach a nut on the back of each mounting hole of an instrument. These nuts stay with the instrument and make installation easy. The nuts come in different lengths for use with instrument that different thicknesses. They are non-magnetic and take 6-32 machine screws. Albert Gardner RV-9A 872RV Yuma, AZ ----- Original Message ----- From: "Ernest Kells" <ernest.kells(at)sympatico.ca> Subject: Re: RV-List: Mounting Instruments > > > >I am mounting my flight instruments in the control panel. What type of > > >screws are the best to use? Do I need to use brass or stainless? Are > > >aircraft grade screws required since this is non-structural? > > I painted my panel in medium gray (not so reflective in sunlight). The black > brass instrument screws (Page 93 of ACS) look really neat in the panel. I > chose the pan head MS35214 screws. For the six big holes I used nut rings > (Vans Catalogue and Page 342 of ACS). They allow you to install and remove > those instruments from the front. The screws match the above pan head > screws used everywhere else. Cool. > Ernest Kells - RV-9A O235-N2C, Wood Prop > 90% Complete - electrical and pre-paint ________________________________________________________________________________
Date: Mar 03, 2004
they do case work only. ----Original Message Follows---- From: <klwerner(at)comcast.net> Subject: Re: RV-List: Need name of engine shop Date: Wed, 3 Mar 2004 10:36:04 -0700 Are you looking for DIVCO in Tulsa (1-800-874-1351)? ----- Original Message ----- From: Hopperdhh(at)aol.com To: rv-list(at)matronics.com Sent: Wednesday, March 03, 2004 9:30 AM Subject: RV-List: Need name of engine shop Listers, What was the name of the engine shop in Oklahoma mentioned recently on the list? I couldn't find it in the archives. Thanks, Dan RV-7A (almost done) Learn how to help protect your privacy and prevent fraud online at Tech ________________________________________________________________________________
Subject: Re: Airworthiness Inspection
Date: Mar 03, 2004
Mike did mine and required a condition inspection be done with the appropriate checklist prior to him doing the inspection. Ross N9PT ----- Original Message ----- From: <Jerry2DT(at)aol.com> Subject: RV-List: Airworthiness Inspection > > Group... > > Had an opportunity to observe airworthiness inspection yesterday. My > advice... if you get a chance to watch one, do it. You will learn a heap of stuff. I > took away from this that before your "final", you should tear that baby down > and do a formal "condition inspection" yourself, using the checklist and paying > a LOT of attention to tiny details, like proper safety wire, anti chafing, > nuts, bolts, washers. The inspector in this case, Mike Robertson, was beyond > thorough, and I got a new appreciation for the work these guys do. > > Jerry Cochran > RV6a...flying one, building one. > ________________________________________________________________________________
Date: Mar 03, 2004
Thanks for the replies. I was wanting to know good places to send out parts for overhaul. Crankcase: Divco Crankshaft, Connecting rods, Camshaft, Lifters: ??? Cylinders: ??? Where/Who are the preferred shops for someone who does their own assembly? Thanks, Dan RV-7A N766DH (almost done) Working on a spare engine! ________________________________________________________________________________
Date: Mar 03, 2004
Subject: Van's alternator - $18 at Pep boys
For grins, I called up Pep Boys. Part number 14184, from an civic years 76 - 79 without AC is $18.00. The same alternator for the airconditioned version can be had for 34.99. This is a remanufactured one but the guy swears it's with new parts even at that price :-). The only "catch" is that the name NipponDenso was nowhere to be found but Pro Start and Bosch were the names associated with it in the lookup. What do you guys think? Someone already have to scoop on this? ________________________________________________________________________________
"Rv8-List" , "Rv9-List" , "Rv-List"
Subject: Quick Fit Tabs for Ground Blocks
Date: Mar 03, 2004
Hi Guys, Just a quick update. Awhile back people were looking for the ground block tabs separate from fuse blocks and pre-made ground blocks. I now have several hundred in stock. They have 10 tabs, (2 double rows of 5), are the 1/4 faston, with holes for mounting to a brass bar, bulkhead, etc.. Basically, you can "roll your own" ground blocks now, and it's much cheaper than buying one already made. I thought about making ground blocks, but it's easier just to sell the tabs, and let the builder make their own if they like. They are listed under "Accessories" on my website. Also, under switches you'll see some new Vinyl Toggle switch boots in 6 colors. They really dress up the switches nice! Last thing.....I now have all the 4 conductor shielded wire in stock for the Dynon Harnesses, and all harnesses/kits from this point forward will be delivered with Shielded wire as standard. Happy building and have a great day. Cheers, Stein Bruch http://www.steinair.com ________________________________________________________________________________
Date: Mar 03, 2004
Ted, I know this would be a good cross country flight for you guys up there but myself and Chapter 403 have put together RV APPRECIATION DAY, a fly-in that will be held Apr. 30th through May 2nd at the Carson City, NV. Airport. We have additional information on the fly-in on VansAircaft web sight. vansaircraft.com under Fly-in Schedule. Check it out if you guys are interested and weather permits. Thak you, Bruce >From: "Ted Gauthier" <TGauthier(at)comcast.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RE: RV-List: Michigan RV's >Date: Wed, 3 Mar 2004 12:15:24 -0500 > > >RV's in Michigan, > >My plan was to attend the RV event in Kentucky however I did not make >it. I am sorry that I did not attend, I heard it was a really great >time. Yes, I am from Pontiac, Mi. We have at least 6 RV's based here >and at least another dozen builders and flying RV's in the area. Great >group of guys, just give us a call, we also welcome new friends. > >Ted Gauthier, RV-6 125hours >DAR >Pontiac, Mich. > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Gordon and >Marge >To: rv-list(at)matronics.com >Subject: RV-List: I39 fly-in queries > > >First, congratulations to Dana and his EAA chapter, friends and family >for an outstanding start to our flying season. Second, who are these >folks Dana mentioned from Pontiac, MI? Did you mean us, from Tecumseh, >MI, and just get your Indian chiefs confused? If there are active RV-ers >from Pontiac, not far from here by RV, we would like to know them and >perhaps get together. Thanks. > >Gordon and Marge >N363GC > > >= >= >= >= > > ________________________________________________________________________________
Date: Mar 03, 2004
Subject: Re: Van's vs Electric Bob's approach
No vacuum pump or instruments, therefore reasonable prudence says an all electric IFR panel should have two independent sources of power. B&C sells two nice vacuum pump pad alternator. Matthew M. Jurotich NASA/Goddard Space Flight Center Swales contractor to the JWST ISIM Systems Engineer m/c : 443 e-mail mail to: phone : 301-286-5919 fax : 301-286-7021 JWST URL: <http://ngst1.gsfc.nasa.gov ________________________________________________________________________________
Date: Mar 03, 2004
How about: Crankcase: DIVCO / Tulsa, OK Crankshaft, Connecting rods, Camshaft, Lifters: AIRCRAFT SPECIALTIES / Tulsa, OK Cylinders: GIBSON AIRCRAFT / El Reno, OK (Or ECI, SUPERIOR) ----- Original Message ----- From: Hopperdhh(at)aol.com To: rv-list(at)matronics.com Sent: Wednesday, March 03, 2004 12:02 PM Subject: Re: RV-List: Need name of engine shop Thanks for the replies. I was wanting to know good places to send out parts for overhaul. Crankcase: Divco Crankshaft, Connecting rods, Camshaft, Lifters: ??? Cylinders: ??? Where/Who are the preferred shops for someone who does their own assembly? Thanks, Dan RV-7A N766DH (almost done) Working on a spare engine! ________________________________________________________________________________
Date: Mar 03, 2004
Hopperdhh(at)aol.com wrote: > >Thanks for the replies. > >I was wanting to know good places to send out parts for overhaul. > > Crankcase: Divco > Crankshaft, Connecting rods, Camshaft, Lifters: ??? > D&S Camcorp (386) 426-0670 > Cylinders: ??? > D&S engines used to do mine, but they're out of the cylinder business now. Linn >Where/Who are the preferred shops for someone who does their own assembly? > >Thanks, Dan >RV-7A N766DH (almost done) >Working on a spare engine! > > > > ________________________________________________________________________________
Date: Mar 03, 2004
Subject: Re: Van's alternator - $18 at Pep boys
RV8ter(at)aol.com wrote: > > > For grins, I called up Pep Boys. Part number 14184, from an civic years 76 - 79 without AC is $18.00. The same alternator for the airconditioned version can be had for 34.99. > > This is a remanufactured one but the guy swears it's with new parts even at that price :-). > > The only "catch" is that the name NipponDenso was nowhere to be found but Pro Start and Bosch were the names associated with it in the lookup. > > What do you guys think? Someone already have to scoop on this? I looked on the Advance Auto Parts site and there are several alternators listed for the 1977 Honda Civic CVCC, and not all of them are 14184. You might want to compare the $18.00 unit to a 14184 to make sure it is the same alternator. There are scores of alternators that can be used on our planes (after all, they only have to charge the battery), but the 14184 is small and externally regulated making it suitable for our use. The Nippon brand wasn't on the 14184 I recently purchased. Sam Buchanan ________________________________________________________________________________
Date: Mar 03, 2004
In a message dated 3/3/2004 4:47:43 PM Eastern Standard Time, sbuc(at)hiwaay.net writes: The Nippon brand wasn't on the 14184 I recently purchased. Sam Buchanan forgot to ask, was the Nippon not being on the label of your recent 14184 purchase a good thing or a bad thing? ie, will work with Van's alternator kit just as good as the one Van's sells or not? thx, lucky ________________________________________________________________________________
Date: Mar 03, 2004
At 01:52 PM 3/2/2004, you wrote: > >I'm not an outdoorsman I am. My newest tent, my seventh, is a Coleman Sundome 7'X7'. Adequate and cheap. Oshkosh proven. If you want to keep your plane really light get a one man back pack tent. I have a Eureka and love it. Whatever you get be sure you get a fly that covers as much tent as possible - few cover enough IMHO. Keeping the tent from getting wet helps you stay dry. When it rains at OSH, the wind blows too. Also take a water bottle and a P bottle. You can certainly get better tents and being able to get a good night's in the outdoors is essential to your becoming an outdoorsman. K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Mar 03, 2004
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
SSBnb3Qgb25lIG9mIHRoZSBib3NjaCBvbmVzIGNyb3NzIHJlZmVyZW5jZWQgdG8gdGhlIDE0eHh4 IG51bWJlci4gSXQgd29yayBmb3IgYWJvdXQgdGhlIHNhbWUgMjUwIGhvdXJzIGFzIHRoZSBWYW5z IG9uZS4gSXQgd2FzIG5vdCB1bnRpbGwgSSBnb3QgdGhlIFN1c3VraSA2MCBhbXAgaW50ZXJuYWxs eSByZWd1bGF0ZWQsIGxpZ2h0ZXIsIG1vcmUgYW1wIHVuaXQsIHRoYXQgSSBzdG9wcGVkIHRvYXN0 aW5nIHRoZW0uIE15IFN1c3VraSB1bml0IGhhcyBsYXN0ZWQgYWJvdXQgNjAwIGhvdXJzIHdpdGhv dXQgdG9hc3RpbmcuIEkgYmVsaWV2ZSBJIHJlYWQgc29tZXdoZXJlIGluIHRoZSBhZXJvbGV0cmlj IHNpdGUgd2h5IHRoZSBTdXN1a2kgdW5pdCB3YXMgZmFyIHN1cGVyaW9yLiBEb3VibGUgZmFuLCBy YXRlZCBmb3IgdGhlIGhpZ2ggcnBtJ3MgaXQgdHVybnMgYW5kIHNvIGZvcnRoLiBJdCBpcyBhICQx MzBpc2ggdW5pdC4gQnV0IHRoZSBsaWZldGltZSB3YXJyYW50ZWUsIGFuZCBsYWNrIG9mIGhlYWRh Y2hlIGZhY3RvciwgY29tYmluZWQgd2l0aCB0aGUgaW5jcmVhc2VkIGFtcHMgd2hpY2ggSSBuZWVk ZWQgcnVubmluZyBhbiBhbGwgZWxlY3RyaWMgcGxhbmUgd2l0aCBubyBtYWdzLCBtYWRlIHRoaXMg YWx0ZXJuYXRvciBhIG11Y2ggYmV0dGVyIGNob2ljZSBmbyBtZS4NCiANCk1pa2UNCmRvIG5vdCBh cmNoaXZlLg0KIA0KDQoJLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0gDQoJRnJvbTogb3duZXIt cnYtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBvbiBiZWhhbGYgb2YgU2FtIEJ1Y2hhbmFuIA0K CVNlbnQ6IFdlZCAzLzMvMjAwNCA0OjQzIFBNIA0KCVRvOiBydi1saXN0QG1hdHJvbmljcy5jb20g DQoJQ2M6IA0KCVN1YmplY3Q6IFJlOiBSVi1MaXN0OiBWYW4ncyBhbHRlcm5hdG9yIC0gJDE4IGF0 IFBlcCBib3lzDQoJDQoJDQoNCgktLT4gUlYtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogU2FtIEJ1 Y2hhbmFuIDxzYnVjQGhpd2FheS5uZXQ+DQoJDQoJDQoJUlY4dGVyQGFvbC5jb20gd3JvdGU6DQoJ Pg0KCT4gLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IFJWOHRlckBhb2wuY29tDQoJPg0K CT4gRm9yIGdyaW5zLCBJIGNhbGxlZCB1cCBQZXAgQm95cy4gIFBhcnQgbnVtYmVyIDE0MTg0LCBm cm9tIGFuIGNpdmljIHllYXJzIDc2IC0gNzkgd2l0aG91dCBBQyBpcyAkMTguMDAuICBUaGUgc2Ft ZSBhbHRlcm5hdG9yIGZvciB0aGUgYWlyY29uZGl0aW9uZWQgdmVyc2lvbiBjYW4gYmUgaGFkIGZv ciAzNC45OS4NCgk+DQoJPiBUaGlzIGlzIGEgcmVtYW51ZmFjdHVyZWQgb25lIGJ1dCB0aGUgZ3V5 IHN3ZWFycyBpdCdzIHdpdGggbmV3IHBhcnRzIGV2ZW4gYXQgdGhhdCBwcmljZSAgOi0pLg0KCT4N Cgk+IFRoZSBvbmx5ICJjYXRjaCIgaXMgdGhhdCB0aGUgbmFtZSBOaXBwb25EZW5zbyB3YXMgbm93 aGVyZSB0byBiZSBmb3VuZCBidXQgUHJvIFN0YXJ0IGFuZCBCb3NjaCB3ZXJlIHRoZSBuYW1lcyBh c3NvY2lhdGVkIHdpdGggaXQgaW4gdGhlIGxvb2t1cC4NCgk+DQoJPiBXaGF0IGRvIHlvdSBndXlz IHRoaW5rPyAgU29tZW9uZSBhbHJlYWR5IGhhdmUgdG8gc2Nvb3Agb24gdGhpcz8NCgkNCgkNCglJ IGxvb2tlZCBvbiB0aGUgQWR2YW5jZSBBdXRvIFBhcnRzIHNpdGUgYW5kIHRoZXJlIGFyZSBzZXZl cmFsDQoJYWx0ZXJuYXRvcnMgbGlzdGVkIGZvciB0aGUgMTk3NyBIb25kYSBDaXZpYyBDVkNDLCBh bmQgbm90IGFsbCBvZiB0aGVtDQoJYXJlIDE0MTg0LiBZb3UgbWlnaHQgd2FudCB0byBjb21wYXJl IHRoZSAkMTguMDAgdW5pdCB0byBhIDE0MTg0IHRvIG1ha2UNCglzdXJlIGl0IGlzIHRoZSBzYW1l IGFsdGVybmF0b3IuIFRoZXJlIGFyZSBzY29yZXMgb2YgYWx0ZXJuYXRvcnMgdGhhdCBjYW4NCgli ZSB1c2VkIG9uIG91ciBwbGFuZXMgKGFmdGVyIGFsbCwgdGhleSBvbmx5IGhhdmUgdG8gY2hhcmdl IHRoZSBiYXR0ZXJ5KSwNCglidXQgdGhlIDE0MTg0IGlzIHNtYWxsIGFuZCBleHRlcm5hbGx5IHJl Z3VsYXRlZCBtYWtpbmcgaXQgc3VpdGFibGUgZm9yDQoJb3VyIHVzZS4NCgkNCglUaGUgTmlwcG9u IGJyYW5kIHdhc24ndCBvbiB0aGUgMTQxODQgSSByZWNlbnRseSBwdXJjaGFzZWQuDQoJDQoJU2Ft IEJ1Y2hhbmFuDQoJDQoJDQoJXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCglfLT0gICAgICAgICAgICAgIC0g VGhlIFJWLUxpc3QgRW1haWwgRm9ydW0gLQ0KCV8tPSBUaGlzIGZvcnVtIGlzIHNwb25zb3JlZCBl bnRpcmVseSB0aHJvdWdoIHRoZSBDb250cmlidXRpb25zDQoJXy09IG9mIExpc3QgbWVtYmVycy4g IFlvdSdsbCBuZXZlciBzZWUgYmFubmVyIGFkcyBvciBhbnkgb3RoZXINCglfLT0gZm9ybSBvZiBk aXJlY3QgYWR2ZXJ0aXNpbmcgb24gdGhlIE1hdHJvbmljcyBGb3J1bXMuDQoJXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCglfLT0gISEgTkVXICEhDQoJXy09IEFMTCBORVcgTElTVCBDSEFUISEgaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2NoYXQNCglfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KCV8tPSBMaXN0IFJlbGF0 ZWQgSW5mb3JtYXRpb24NCglfLT0gIFBvc3QgTWVzc2FnZTogICBydi1saXN0QG1hdHJvbmljcy5j b20NCglfLT0gIFVOL1NVQlNDUklCRTogICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vc3Vic2Ny aXB0aW9uDQoJXy09ICBMaXN0IEZBUTogICAgICAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL0ZB US9SVi1MaXN0Lmh0bQ0KCV8tPSAgU2VhcmNoIEVuZ2luZTogIGh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9zZWFyY2gNCglfLT0gIDctRGF5IEJyb3dzZTogICBodHRwOi8vd3d3Lm1hdHJvbmljcy5j b20vYnJvd3NlL3J2LWxpc3QNCglfLT0gIEJyb3dzZSBEaWdlc3RzOiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vZGlnZXN0L3J2LWxpc3QNCglfLT0gIExpdmUgTGlzdCBDaGF0OiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY2hhdA0KCV8tPSAgQXJjaGl2ZXM6ICAgICAgIGh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9hcmNoaXZlcw0KCV8tPSAgUGhvdG8gU2hhcmU6ICAgIGh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9waG90b3NoYXJlDQoJXy09ICBMaXN0IFNwZWNpZmljOiAgaHR0cDovL3d3dy5t YXRyb25pY3MuY29tL3J2LWxpc3QNCglfLT0gIE90aGVyIExpc3RzOiAgICBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vZW1haWxsaXN0cw0KCV8tPSAgVHJvdWJsZSBSZXBvcnQgIGh0dHA6Ly93d3cu bWF0cm9uaWNzLmNvbS90cm91YmxlLXJlcG9ydA0KCV8tPSAgQ29udHJpYnV0aW9uczogIGh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCglfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KCQ0K CQ0KCQ0KCQ0KCQ0KDQo ________________________________________________________________________________
Date: Mar 03, 2004
RV8ter(at)aol.com wrote: > > In a message dated 3/3/2004 4:47:43 PM Eastern Standard Time, sbuc(at)hiwaay.net > writes: > The Nippon brand wasn't on the 14184 I recently purchased. > > Sam Buchanan > forgot to ask, was the Nippon not being on the label of your recent 14184 > purchase a good thing or a bad thing? ie, will work with Van's alternator kit > just as good as the one Van's sells or not? > > thx, > lucky It will work just fine. The Nippon brand wasn't on Vans's unit either; matter of fact it didn't have *any* marking. Keep in mind all the alternator does is keep the battery charged; there is no black art here. :-) Just think.....the alternator will have a lifetime warranty as long as you own that '77 Civic. ;-) Sam Buchanan ________________________________________________________________________________
Date: Mar 03, 2004
Sure but I'm pretty sure it will be backwards as that's been written here before. The fan is press fit however and a decent gear puller should be able to get rid of it. ________________________________________________________________________________
Subject: Dynon Heated Pitot Availability
Date: Mar 03, 2004
FYI...information I got from Dynon on the Heated Pitot Scott 7A Wings From: Gloria Hee [mailto:temp(at)dynondevelopment.com] Subject: RE: Heated Pitot Availability We hope to have the heated AOA/Pitot probe available the end of this month. It should work in the place of any heated pitot but it will not be TSOd. There are no options when ordering the pitot. -----Original Message----- From: Scott_Haskins(at)Dell.com [mailto:Scott_Haskins(at)Dell.com] Subject: Heated Pitot Availability Can you confirm when the new heated pitot will be available? Also, will it work only with the Dynon, or in the place of any heated pitot application? Are there any options when ordering the pitot? Thanks, Scott Haskins Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Date: Mar 03, 2004
From: Charlie & Tupper England <cengland(at)netdoor.com>
Subject: Re: Sun N Fun camping
Brian Kraut wrote: > >I am driving to SNF. Can anyone tell me if you can bring a tent and camp somwehere there if you didn't fly in? If so, can you camp with your vehicle so you can lock up your stuff instead of having to carry it all out to the parking lot and back every day. > snipped Hi Brian, Yes, you can camp with your car. Expect a fairly long commute to the flight line if you don't arrive at least 2 days early, but it's still nowhere near as bad as OSH. FWIW, I've never heard of anyone losing anything out of a campsite at a major flyin. I guess it happens, but it's got to be pretty rare or we would hear more about it. Has anyone on the list lost anything while camping at SNF or OSH? Charlie ________________________________________________________________________________
Date: Mar 03, 2004
RV8ter(at)aol.com wrote: > >Sure but I'm pretty sure it will be backwards as that's been written here >before. The fan is press fit however and a decent gear puller should be able to >get rid of it. > The external fan will still work (just not quite as efficiently) even when spun backward. I've seen it confirmed on a test bench with the alternator spun both ways. I've not observed this with an internal fan model, but I expect similar results. Any auto-electric shop, & probably even AutoZone, could spin one up for you if you want to check it for yourself. Charlie ________________________________________________________________________________
Date: Mar 03, 2004
Charlie & Tupper England wrote: > >RV8ter(at)aol.com wrote: > > > >> >>Sure but I'm pretty sure it will be backwards as that's been written here >>before. The fan is press fit however and a decent gear puller should be able to >>get rid of it. >> >> >> > >The external fan will still work (just not quite as efficiently) even >when spun backward. I've seen it confirmed on a test bench with the >alternator spun both ways. I've not observed this with an internal fan >model, but I expect similar results. Any auto-electric shop, & probably >even AutoZone, could spin one up for you if you want to check it for >yourself. > > >Charlie > > The fan turning backwards well work fine, it has worked great on my internal regulated non-electric Bob electrical system for over 1000 hours. :) Jerry ________________________________________________________________________________
Date: Mar 03, 2004
Sorry Sam, but the alternator not only has to charge the battery, it also has to supply power for everything in the airplane. The electrical equipment in the airplane runs off the alternator not the battery. The battery is used only for starting and backup for the alternator. Dave Sam Buchanan wrote: >There are scores of alternators that can >be used on our planes (after all, they only have to charge the battery), > > > > ________________________________________________________________________________
Date: Mar 03, 2004
Dave Bristol wrote: > > >Sorry Sam, but the alternator not only has to charge the battery, it also has to supply power for everything in the airplane. The electrical equipment in the airplane runs off the alternator not the battery. > >The battery is used only for starting and backup for the alternator. > > >Dave > ========================================== Not exacty. AFAIK -- 1.An alternator will not excite without a battery. 2. If you remove the battery as a load for the alternator, the voltage can soar to well over 100 volts unless there is circuitry to prevent it.. Bob ======================================== >Sam Buchanan wrote: > > > >>There are scores of alternators that can >>be used on our planes (after all, they only have to charge the battery), >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Mar 03, 2004
It works regardless of rotation so there is no need to remove. Might not be as efficient but at 6000 rpm it doesn't make any difference. ----- Original Message ----- From: <RV8ter(at)aol.com> Subject: Re: RV-List: Van's alternator - $18 at Pep boys > > Sure but I'm pretty sure it will be backwards as that's been written here > before. The fan is press fit however and a decent gear puller should be able to > get rid of it. > > ________________________________________________________________________________
Date: Mar 03, 2004
Subject: Re: Dynon Info
EricHe(at)FlexSolPackaging.com wrote: > > Hi all, don't know if this is general knowledge, but I thought this response was good enough to share with the list. I finally bit the bullet and ordered my Dynon and associated toys. Tony and Monte have been really great to deal with. Would like to throw out a big thanks to Dynon just for making a good pitot tube for a reasonable price. Every little victory adds up. Hi all, Just as an fyi, I sent e-mail to Dynon, and received a reply that they will be at Sun-n-Fun with a display booth, C-23. They also indicated that the OAT option should be available in a couple of weeks. Don't know if they will have a "show special" price, but one can hope... :-) -Dj ________________________________________________________________________________
Date: Mar 03, 2004
SportAV8R(at)aol.com wrote: > > And what's the deal with a ban on backpacks and coolers? No backpacks? Are they nuts? Are they banning purses? If not, I guess I will have a very big purse that I can conveniently carry on my back... Or maybe it s baby carrier - yeah, that's it! A carrier for all the things I am buying for my "baby".. *wink* Seriously, how do these people expect us to carry all our junk without a backpack? -Dj ________________________________________________________________________________
Date: Mar 03, 2004
Bob U. wrote: >>he battery is used only for starting and backup for the alternator. >> >> >>Dave >> >> >> >========================================== > >Not exacty. > >AFAIK -- >1.An alternator will not excite without a battery. > True >2. If you remove the battery as a load for the alternator, the voltage >can soar to well over 100 volts unless there is circuitry to prevent it.. > Well, that's what the regulator is there for. If the alternator is excited (I love that word!) and then the battery is removed, the regulator should keep the voltage level constant ..... provided that the field is still getting regulated voltage from the alternator output. As long as the regulator stays intact, the system should function normally. Linn >Bob > ________________________________________________________________________________
Date: Mar 03, 2004
Subject: Re:Van's Alternator
Dave: I think you'll find the electrical system draws power from the battery and alternator. They are both connected to the power buss, and if the load exceeds the output of the alternator,then power comes from the battery. My alternator has no name on it anywhere. I was told it is Nipondenso,from a Toyota. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Subject: flap motor failure
Date: Mar 03, 2004
I have just 30 hours on my RV6 and had a flap motor failure today, could not extend flaps, landed & got to the flap motor, gave it a rap while holding switch and flaps extended. I know others have had failures according to archives but this should not be happening. Has Van's been known to be exchanging or upgrading these kit motors of 3-4 years old? I have cleaned the contacts, but how long will that last? Dave Ford RV6 ________________________________________________________________________________
Date: Mar 03, 2004
DNA: not not archive
Subject: [PLEASE READ] Virus Laden Spam Purports To Be From Matronics...
Dear Listers, First let me say that I normally don't condone the sharing of warnings about Internet viruses on the Matronics Email Lists. I don't want to start a storm of discussion regarding computer viruses on the Lists, so please just note the information below and refrain from commenting to the List. The circumstances I describe below are disturbing enough that I felt an explanation is necessary. That being said... There is a new email-bourne virus running rampant on the Internet that is cleverly disguising itself as legitimate email warning of such things as: "your email account is disabled because of unauthorized access" "Some of our clients complained about the spam (negative e-mail content) outgoing from your e-mail account" "Probably, you have been infected by a proxy-relay trojan server. In order to keep your computer safe, follow the instructions." "Our main mailing server will be temporary unavailable for next two days, to continue receiving mail in these days you have to configure our free auto-forwarding service." All of these messages include an attachment that you are instructed to click upon to "Get more information", "clean the virus from your system", or "check your system for infections". These enclosures all contain a virus that will infect your system and propagate even more copies of the original message. The disturbing part of these messages is that they appear to be coming from very legitimate addresses and have very legitimate, convincing dialog. For example, I have received a number of them today that appear to be from "support(at)matronics.com", "management(at)matronics.com", "administration(at)matronics.com", and "staff(at)matronics.com". The text of the messages seems believable enough, and given the forged source address, seem even more legitimate. Please be assured that no one at Matronics.com will be sending you these kinds of messages. If you receive one, it is a spam/virus that has forged headers and was sent to you from someone other than Matronics. Delete the message and the attachment promptly. Invest in a copy of Norton Antivirus and keep the definitions up dated on a daily basis. Again, I want to stress that I *DO NOT* want a big discussion of viruses on the Matronics Email Lists. Please do not reply to this email with any comments. You may write to me directly at dralle(at)matronics.com if you wish, but do not include the List. Since many of these appear to come from matronics.com, I wanted to assure everyone that Matronics wasn't the real source of these messages. Let's be careful out there and keep those virus definitions up to date! Today alone, the Matronics spam filter and virus blocking appliance has filtered out 11,550 spam messages and 375 viruses! That's just in an 18 hour period! Best regards, Matt Dralle Matronics Email List Administrator -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Mar 03, 2004
I am fairly sure without the "ballast" of the battery, your regulator will quickly give up the ghost. I know the battery filters out the ripple of the current and many electrical noises within the system. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or sportpilot(at)eaa.org Always looking for articles for Sport Pilot ----- Original Message ----- From: "linn walters" <lwalters2(at)cfl.rr.com> Subject: Re: RV-List: Van's alternator - $18 at Pep boys > > Bob U. wrote: > > >>he battery is used only for starting and backup for the alternator. > >> > >> > >>Dave > >> > >> > >> > >========================================== > > > >Not exacty. > > > >AFAIK -- > >1.An alternator will not excite without a battery. > > > True > > >2. If you remove the battery as a load for the alternator, the voltage > >can soar to well over 100 volts unless there is circuitry to prevent it.. > > > Well, that's what the regulator is there for. If the alternator is > excited (I love that word!) and then the battery is removed, the > regulator should keep the voltage level constant ..... provided that the > field is still getting regulated voltage from the alternator output. As > long as the regulator stays intact, the system should function normally. > Linn > > >Bob > > > > ________________________________________________________________________________
Date: Mar 04, 2004
In a message dated 3/3/2004 6:56:16 AM Pacific Standard Time, lwalters2(at)cfl.rr.com writes: Typically the instruments are mounted with black anodized brass screws. Linn meant black oxided brass screws. Brass can't be anodized. GV (RV-6A N1GV flying 675 hrs) ________________________________________________________________________________
Date: Mar 04, 2004
In a message dated 3/3/2004 6:13:17 AM Pacific Standard Time, tacaruth(at)ralcorp.com writes: I am mounting my flight instruments in the control panel. What type of screws are the best to use? Do I need to use brass or stainless? I would recommend the corrosion resistant steel (stainless) just because I think they look better longer. Most of the commonly available ANSI variety industrial fasteners are 300 series (nonmagnetic). GV (RV-6A N1GV flying 682 hrs) ________________________________________________________________________________
Date: Mar 04, 2004
Speaking of show specials - is this pretty common? I've got a lot of stuff to buy, and I can wait until SNF. Do people usually require cash or can you "buy" and then have them ship and pay for it later? Thanks, Mickey >Don't know if they will have a "show special" price, but one >can hope... :-) -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Mar 04, 2004
Subject: MT Propeller Group Buy for Lycoming 320
Hi All, MTV-17-C/178-59 electric CS propeller for Lycoming O-320 engine. The is a 70" diameter 2 blade propeller including spinner and electric governor. Delivered assembled to your door in the USA. I need 16 orders to get an assembled in Southern California price of $7,100 as a group buy. I have 7 now. Approximate extra cost of $150 to deliver to your door in the USA. (Across USA.) If I don't get 16 orders, the price would be $7,600 assembled in Southern California. Approximate extra cost of $150 to deliver to your door in the USA. (Across USA.) The hydraulic 70" diameter 2 blade MT propeller can be included in this order. MTV-11-C/178-59 hydraulic CS propeller including spinner. $6,700 assembled in Southern California. Approximate extra cost of $150 to deliver to your door in the USA. (Across USA.) As part of a 16 person group buy, $6,250 assembled in Southern California. Approximate extra cost of $150 to deliver to your door in the USA. (Across USA.) Contact me at jim(at)lessdrag.com if you are interested in this group buy. Jim Ayers OEM Distributor for MT Propeller ________________________________________________________________________________
vansairforce(at)yahoogroups.com
Subject: fuel return line / Mooney engine question
Date: Mar 04, 2004
I have an IO-360-A1B6D from a Mooney. The markings on the FI servo said Bendix RSA-SAD1 Precision Air Motor Corp FC MAB I don't have any Lycoming/Mooney documentation with the engine. I will get an overhaul manual but I doubt it will tell me this question. Any idea if a fuel return line was used on the Mooney? Even if it wasn't used on the Mooney, would it ever a *bad* concept to implement on a RV? Does the return need to go to a fuel tank or just Teed back to the fuel line upstream of the fuel selector vavle? My tanks are *done* so I'm hopinig not to go there. thanks, lucky ----Original Message Follows---- From: "David Rogers" <davidrgr(at)comcast.net> Subject: RE: [rv8list] Re: FloScan transducer mounting Date: Wed, 3 Mar 2004 21:02:17 -0500 What are the pros/cons of one system over the other ? Does the Airflow Perf unit give you more HP ? How does the Bendix system eliminate the need for the fuel return ? Dave R. RV-8 (wings) -----Original Message----- From: mahlon_r [mailto:mahlon_russell(at)teledyne.com] Subject: [rv8list] Re: FloScan transducer mounting Brian, The Precison/Bendix fuel injection system that comes standard on a Lycoming IO-360 does not need or use a fuel return. If on the other hand, you are going to use a AirFlow performance fuel injection system the fuel return is required. Good Luck, Mahlon -- In rv8list(at)yahoogroups.com, "bcross2160rv8" wrote: > Hi Folks > > On this subject, I have been trying to figure out for awhile what > type of fuel valve do I require. > > I plan to use an IO360 with the Andair fuel valve. What I do not know > is if I need to get the expensive one which returns a portion of the > fuel to the tank selected? I assume that in the injected models, > some of the fuel has to be returned to tank to keep the fuel cool. I > am obviously over my head on this one & would really appreciate some > advice on this. > > Thanks very much. > > Brian #81844 > > > -- In rv8list(at)yahoogroups.com, "Danny King" wrote: > > Guys, > > I saw a flying RV-8 the other day with all of the fuel components > hanging on the firewall or motor mount. I ask him if he was having > any weird fuel pressure readings. He said that his fuel pressure > readings were all over the place. He had an angle valve I0360 200 hp > engine. I couldn't help but flash back to my first homebuilt. It > was a Pitts S1S with a PS-5C pressure carb and Christen Inverted > system. I mounted the Pitts electric Airborne boast pump on the > firewall along with the gascolator. All was well after that first > flight on December 15, 1983 but by the late spring of 1984 I got a > real scare when the fuel pressure started to drop. The Bendix PS- 5C > requires approx. 14 psi to work. It is kinda like a throttle body > injection (part carburetor and part fuel injection). I found that > the Texas heat, and having those fuel components on the firewall side > was incompatible! I replumbed the Pitts and moved all fuel > components to cockpit side of the firewall. All my problems went > away! > > > > When planning the Doll's fuel system, I took the lessons learned > and followed the very simple Grumman AA1 setup. The Grumman AA- 1A > I owned for 23 years DID NOT HAVE A GASCOLATOR. In fact it used a > tank drains at the low point just like the RV-8. If you drain your > tanks prior to the first flight, then there will be no water in the > system. > > Second, if all fuel system plumbing is behind the firewall, there > will be no vapor lock (fuel boiling) problems. The Doll is set up > this way. After the (through the firewall) fitting, there is a 303 > hose to the engine fuel pump, and the rest is the way Lycoming ships > the engine to you! > > > > I also had a fuel flow transducer in my Grumman AA1-A. It was > mounted just after the fuel valve, and it work perfectly! So I put > the transducer in the Doll right after the elbow fitting coming out > of the bottom of the fuel valve. Nearly 400 hours later, you guessed > it... it works perfectly! When I refuel, the total fuel to refill > the Doll, and the amount used on the Electronics International fuel > computer are within 1/10 of a gal. > > > > I decided to aim the vent line tubes strait down, and I did not > turn them into the slip stream. I cut them off at an angle to cause > some pressurization. I thought about the bug issue as well. > > > > I'm not an engineer, and I am not saying that I did it the best > way. Therefore, I only offer this as a away that I have found to be > successful on my former Grumman AA1-A, Pitts S1S, and the Doll. > > > > Danny King > > Beautiful Doll 80434 > > ========================== > > ----- Original Message ----- > > From: Jross10612@a... > > To: rv8list(at)yahoogroups.com > > Cc: chaskuss@y... > > Sent: Wednesday, March 03, 2004 7:32 AM > > Subject: [rv8list] FloScan transducer mounting > > > > > > Charlie: > > > > I have my FloScan transducer mounted between the fuel injector > servo and the > > distribution block. It is mounted on a small plate that I made; > that plate > > meets at two tubes in the engine mount and is attached by two > Adel clamps. > > Flexible hose (firesleeved) is used to run in and out of the > transducer, with > > straight fittings on the transducer itself. There is a gently > curved fitting on the > > flexible hose on the outlet side. I have a blast tube pointed at > the > > transducer, which runs to the top rear engine baffle. Between the > engine mounts, Adel > > clamp rubber and flexible fuel lines, I think I have the > vibration problem > > under control. The cooling should be a non issue because of the > blast tube. (At > > least when there is airflow when moving) > > > > There really is no place to put the FloScan transducer which > meets all > > concerns we can think of. Talk to Don Rivera at Airflow > Performance and he will tell > > you not to install one at all; he is just too concerned about > bubbles and > > cavitation. > > > > I have tried to pick a place to mount the transducer that meets > all > > requirements as best as possible. I fully agree with your > comments about the thermal > > concerns of a transducer that is made of several materials, but > I've tried to > > minimize that issue as best that I can. The blast tube in the > photo of the > > installation is not seen well in the photo due to the engine lord > mount. > > > > > > > > Anyway, roll your own and don't go too crazy trying to engineer > every issue > > into a solution that considers everything. > > > > I have a wing root mounted gascolator. I'm thinking about > removing it because > > it may be of dubious value. All of the plumbing and potential for > leaks may > > well negate the benefit of the gascolator. But old ideas die > hard, and the > > gascolator is a place for filtration and for water to settle out > as fuel passes > > through it. But then all of the turns in the tubing, gentle as > they are may be a > > place for fuel turbulence to start. I'll probably leave it in > because of the > > filter in the gascolator and he fact that I have not installed > any other > > filter. On the other hand Danny King (as well as others) have > been operating just > > fine without a gascolator. > > > > My point is that if you talk to a fuel system engineer (like > Caesar Gonazales > > of Cessna fame) and follow all of the engineering principles and > accepted > > practices when designing a fuel system you will end up with a > compromise > > somewhere. One of the things about the RV airplanes is the poorly > designed fuel vent > > system. It's a major no-no to use 1/4 " fuel vent lines simply > because a single > > drop of water may freeze in the vent line and cause fuel flow > problems. > > Couple this with the fuel vents facing forward into the > slipstream on the RV-8 and > > you have a real potential for fuel vent icing if you were to fly > into any > > freezing rain. Or maybe even bugs on a hot day could obstruct the > fuel vent. But > > then the RV-8 was intended to be a VFR sport plane and not to be > flown IFR. > > > > If I had it to do over I'd put 3/8" fuel vent lines in my > airplane. Why Van > > did not do this in the first place is puzzling. On the other > hand, we don't > > seem to hear about fuel vent problems on the RV airplanes either. > > > > Anyway, just food for thought. > > > > Jon Ross > > 80094 Wing Paint > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > Information exchange for builders of Vans Aircraft RV-8 kits. > > > > IF YOU WISH TO UNSUBSCRIBE, PLEASE SEND AN EMAIL TO : > > > > rv8list-unsubscribe(at)egroups.com > > > > > > > > ADVERTISEMENT > > > > > > > > > > -- > ---------- > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/rv8list/ > > > > b.. To unsubscribe from this group, send an email to: > > rv8list-unsubscribe(at)yahoogroups.com > > of > Service. > > > > > > > > [Non-text portions of this message have been removed] Information exchange for builders of Vans Aircraft RV-8 kits. IF YOU WISH TO UNSUBSCRIBE, PLEASE SEND AN EMAIL TO : rv8list-unsubscribe(at)egroups.com _____ * To visit your group on the web, go to: http://groups.yahoo.com/group/rv8list/ * To unsubscribe from this group, send an email to: rv8list-unsubscribe(at)yahoogroups.com Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed] Find things fast with the new MSN Toolbar includes FREE pop-up blocking! http://clk.atdmt.com/AVE/go/onm00200414ave/direct/01/ ________________________________________________________________________________
Date: Mar 04, 2004
Cy Galley wrote: > >I am fairly sure without the "ballast" of the battery, your regulator will >quickly give up the ghost. > This hasn't been my (limited) experience. It may be due to differences in regulators or due to the fact that there was some load available, although the battery wasn't part of it. I don't see any reason, technically, for the system to run away with a fully functioning regulator. Maybe someone else can help out here. >I know the battery filters out the ripple of the >current and many electrical noises within the system. > The diode array in the alternator does 99% of the ripple removing. Under full load, the remaining ripple may become noticeable in cheap intercoms etc. It is true that the battery will filter some of the crap that ends up on the power bus, but it's a poor filter .... otherwise we wouldn't be chasing strobe and flasher noise. In this case 'it all depends' may be useful as electrical systems are, by their nature, terribly dynamic. Linn > >Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh >Editor, EAA Safety Programs >cgalley(at)qcbc.org or sportpilot(at)eaa.org > >Always looking for articles for Sport Pilot > > ________________________________________________________________________________
Date: Mar 04, 2004
Mickey Coggins wrote: > >Speaking of show specials - is this pretty common? > Yes. You can bargain a little better towards the end of the show if they have the stuff in stiock. they don't want to pack it all up, haul it 'home' and then unpack it again! You can always get a price at one vendor, have him write it on a business card and leverage another vendor. Walking back and forth a few times can be rewarding ..... but also a waste of time. >I've got a lot of stuff to buy, and I can wait >until SNF. Do people usually require cash or >can you "buy" and then have them ship and pay >for it later? > Actually, I've done it both ways. You can buy it at the show and have it shipped from their home base and avoid sales tax (in FL) most of the time. Linn > >Thanks, >Mickey > > > > >>Don't know if they will have a "show special" price, but one >>can hope... :-) >> >> > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > > > ________________________________________________________________________________
Date: Mar 04, 2004
linn walters wrote: > >Cy Galley wrote: > > > >> >>I am fairly sure without the "ballast" of the battery, your regulator will >>quickly give up the ghost. >> >> >> >This hasn't been my (limited) experience. It may be due to differences >in regulators or due to the fact that there was some load available, >although the battery wasn't part of it. I don't see any reason, >technically, for the system to run away with a fully functioning >regulator. Maybe someone else can help out here. > I've had a regulator "give up the ghost" with diasterout results and expensive results, so it DOES happen. > > > >>I know the battery filters out the ripple of the >>current and many electrical noises within the system. >> >> >> >The diode array in the alternator does 99% of the ripple removing. >Under full load, the remaining ripple may become noticeable in cheap >intercoms etc. It is true that the battery will filter some of the crap >that ends up on the power bus, but it's a poor filter .... otherwise we >wouldn't be chasing strobe and flasher noise. In this case 'it all >depends' may be useful as electrical systems are, by their nature, >terribly dynamic. > >Linn > A battery provides "ripple free" DC. The alternator cannot. For my money, I prefer to think of the battery as the provider of electrical power and the alternator to keep the battery charged. YMMV. Bob ________________________________________________________________________________
Subject: .
Date: Mar 04, 2004
Subject: .
Date: Mar 04, 2004
Subject: Tulsa Engine Services
Date: Mar 04, 2004
>>>>Listers, What was the name of the engine shop in Oklahoma mentioned recently on the list? I couldn't find it in the archives. Thanks, Dan RV-7A (almost done) >>>>> Sounds like you are doing your own rebuild. I just did that so I thought I'd give you a run down on what I found. Maybe it will benefit someone. If you want your steel parts refurbed in Tulsa you are looking for Aircraft Specialties Inc. They did all of my internal parts, resurfaced everything and yellow tags for everything for $1800.00 . They sold me a rebuild kit that contains all hardware you'll need for $800.00. There's your bottom end overhaul. BTW, most of the cost is the connecting rod bolts. Ouch! My cases were done by Divco. For $700.00 they line bore, check for cracks, resurface everything. They are absolutely beautiful when you get them back. Next engine, I will do the same thing, but I might be tempted to give ole Monte Barret a call and ask him how much he wants to assemble and test the thing. Monte builds high perf competition aerobatic engines. He's right next door to Aircraft Specialties. He chased down some parts for me and was great to work with and was more than reasonable. Basically you could disassemble your engine ship it off and get back a fresh engine. You would be skipping the markup the builders charge you to ship your parts out. When a builder ships a crank out, from my experience, they charge you near double the cost of the machine shops price. If you have a bendix fuel injection, Air Flow Performance made my entire FI system brand spanking new for $650.00, they replace everything but the body. For Mags I found a guy named Howard Libersky in Okechobee, Fl that rebuilt each mag completely for $120.00 flat out. He's been doing mags since they were cutting edge technology. His number is (863-467-6464). I put new ECI Titan cylinders on since it was not much more than having my old work cylinders reworked. All told, I figure I've got about $13,500.00 invested and I'm damn confident in my engine (big thanks to Charlie Kuss). Hope it helps Eric Henson ________________________________________________________________________________
Date: Mar 04, 2004
Subject: Mag impulse assembly
I need an impulse assembly for a slick magneto, part number M3529. Anyone have an extra one for sale or can suggest a source? AC Spruce is out of stock. George ________________________________________________________________________________
Date: Mar 04, 2004
Subject: Vans Seat Cushion Kit for Sale
Hey guys: I have an unused Van's seat cushion kit in the original box for sale. Paid $195 will let go for $160 and I will pay the shipping in the US. Interested Thanks, Scott Morrow ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Date: Mar 04, 2004
Lucky My Bendix RSA-???? does not need a return line the continental fuel injection is the one that needs the return line. Noel -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of lucky macy vansairforce(at)yahoogroups.com Subject: RV-List: fuel return line / Mooney engine question I have an IO-360-A1B6D from a Mooney. The markings on the FI servo said Bendix RSA-SAD1 Precision Air Motor Corp FC MAB I don't have any Lycoming/Mooney documentation with the engine. I will get an overhaul manual but I doubt it will tell me this question. Any idea if a fuel return line was used on the Mooney? Even if it wasn't used on the Mooney, would it ever a *bad* concept to implement on a RV? Does the return need to go to a fuel tank or just Teed back to the fuel line upstream of the fuel selector vavle? My tanks are *done* so I'm hopinig not to go there. thanks, lucky ----Original Message Follows---- From: "David Rogers" <davidrgr(at)comcast.net> Subject: RE: [rv8list] Re: FloScan transducer mounting Date: Wed, 3 Mar 2004 21:02:17 -0500 What are the pros/cons of one system over the other ? Does the Airflow Perf unit give you more HP ? How does the Bendix system eliminate the need for the fuel return ? Dave R. RV-8 (wings) -----Original Message----- From: mahlon_r [mailto:mahlon_russell(at)teledyne.com] Subject: [rv8list] Re: FloScan transducer mounting Brian, The Precison/Bendix fuel injection system that comes standard on a Lycoming IO-360 does not need or use a fuel return. If on the other hand, you are going to use a AirFlow performance fuel injection system the fuel return is required. Good Luck, Mahlon -- In rv8list(at)yahoogroups.com, "bcross2160rv8" wrote: > Hi Folks > > On this subject, I have been trying to figure out for awhile what > type of fuel valve do I require. > > I plan to use an IO360 with the Andair fuel valve. What I do not know > is if I need to get the expensive one which returns a portion of the > fuel to the tank selected? I assume that in the injected models, > some of the fuel has to be returned to tank to keep the fuel cool. I > am obviously over my head on this one & would really appreciate some > advice on this. > > Thanks very much. > > Brian #81844 > > > -- In rv8list(at)yahoogroups.com, "Danny King" wrote: > > Guys, > > I saw a flying RV-8 the other day with all of the fuel components > hanging on the firewall or motor mount. I ask him if he was having > any weird fuel pressure readings. He said that his fuel pressure > readings were all over the place. He had an angle valve I0360 200 hp > engine. I couldn't help but flash back to my first homebuilt. It > was a Pitts S1S with a PS-5C pressure carb and Christen Inverted > system. I mounted the Pitts electric Airborne boast pump on the > firewall along with the gascolator. All was well after that first > flight on December 15, 1983 but by the late spring of 1984 I got a > real scare when the fuel pressure started to drop. The Bendix PS- 5C > requires approx. 14 psi to work. It is kinda like a throttle body > injection (part carburetor and part fuel injection). I found that > the Texas heat, and having those fuel components on the firewall side > was incompatible! I replumbed the Pitts and moved all fuel > components to cockpit side of the firewall. All my problems went > away! > > > > When planning the Doll's fuel system, I took the lessons learned > and followed the very simple Grumman AA1 setup. The Grumman AA- 1A > I owned for 23 years DID NOT HAVE A GASCOLATOR. In fact it used a > tank drains at the low point just like the RV-8. If you drain your > tanks prior to the first flight, then there will be no water in the > system. > > Second, if all fuel system plumbing is behind the firewall, there > will be no vapor lock (fuel boiling) problems. The Doll is set up > this way. After the (through the firewall) fitting, there is a 303 > hose to the engine fuel pump, and the rest is the way Lycoming ships > the engine to you! > > > > I also had a fuel flow transducer in my Grumman AA1-A. It was > mounted just after the fuel valve, and it work perfectly! So I put > the transducer in the Doll right after the elbow fitting coming out > of the bottom of the fuel valve. Nearly 400 hours later, you guessed > it... it works perfectly! When I refuel, the total fuel to refill > the Doll, and the amount used on the Electronics International fuel > computer are within 1/10 of a gal. > > > > I decided to aim the vent line tubes strait down, and I did not > turn them into the slip stream. I cut them off at an angle to cause > some pressurization. I thought about the bug issue as well. > > > > I'm not an engineer, and I am not saying that I did it the best > way. Therefore, I only offer this as a away that I have found to be > successful on my former Grumman AA1-A, Pitts S1S, and the Doll. > > > > Danny King > > Beautiful Doll 80434 > > ========================== > > ----- Original Message ----- > > From: Jross10612@a... > > To: rv8list(at)yahoogroups.com > > Cc: chaskuss@y... > > Sent: Wednesday, March 03, 2004 7:32 AM > > Subject: [rv8list] FloScan transducer mounting > > > > > > Charlie: > > > > I have my FloScan transducer mounted between the fuel injector > servo and the > > distribution block. It is mounted on a small plate that I made; > that plate > > meets at two tubes in the engine mount and is attached by two > Adel clamps. > > Flexible hose (firesleeved) is used to run in and out of the > transducer, with > > straight fittings on the transducer itself. There is a gently > curved fitting on the > > flexible hose on the outlet side. I have a blast tube pointed at > the > > transducer, which runs to the top rear engine baffle. Between the > engine mounts, Adel > > clamp rubber and flexible fuel lines, I think I have the > vibration problem > > under control. The cooling should be a non issue because of the > blast tube. (At > > least when there is airflow when moving) > > > > There really is no place to put the FloScan transducer which > meets all > > concerns we can think of. Talk to Don Rivera at Airflow > Performance and he will tell > > you not to install one at all; he is just too concerned about > bubbles and > > cavitation. > > > > I have tried to pick a place to mount the transducer that meets > all > > requirements as best as possible. I fully agree with your > comments about the thermal > > concerns of a transducer that is made of several materials, but > I've tried to > > minimize that issue as best that I can. The blast tube in the > photo of the > > installation is not seen well in the photo due to the engine lord > mount. > > > > > > > > Anyway, roll your own and don't go too crazy trying to engineer > every issue > > into a solution that considers everything. > > > > I have a wing root mounted gascolator. I'm thinking about > removing it because > > it may be of dubious value. All of the plumbing and potential for > leaks may > > well negate the benefit of the gascolator. But old ideas die > hard, and the > > gascolator is a place for filtration and for water to settle out > as fuel passes > > through it. But then all of the turns in the tubing, gentle as > they are may be a > > place for fuel turbulence to start. I'll probably leave it in > because of the > > filter in the gascolator and he fact that I have not installed > any other > > filter. On the other hand Danny King (as well as others) have > been operating just > > fine without a gascolator. > > > > My point is that if you talk to a fuel system engineer (like > Caesar Gonazales > > of Cessna fame) and follow all of the engineering principles and > accepted > > practices when designing a fuel system you will end up with a > compromise > > somewhere. One of the things about the RV airplanes is the poorly > designed fuel vent > > system. It's a major no-no to use 1/4 " fuel vent lines simply > because a single > > drop of water may freeze in the vent line and cause fuel flow > problems. > > Couple this with the fuel vents facing forward into the > slipstream on the RV-8 and > > you have a real potential for fuel vent icing if you were to fly > into any > > freezing rain. Or maybe even bugs on a hot day could obstruct the > fuel vent. But > > then the RV-8 was intended to be a VFR sport plane and not to be > flown IFR. > > > > If I had it to do over I'd put 3/8" fuel vent lines in my > airplane. Why Van > > did not do this in the first place is puzzling. On the other > hand, we don't > > seem to hear about fuel vent problems on the RV airplanes either. > > > > Anyway, just food for thought. > > > > Jon Ross > > 80094 Wing Paint > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > Information exchange for builders of Vans Aircraft RV-8 kits. > > > > IF YOU WISH TO UNSUBSCRIBE, PLEASE SEND AN EMAIL TO : > > > > rv8list-unsubscribe(at)egroups.com > > > > > > > > ADVERTISEMENT > > > > > > > > > > -- > ---------- > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/rv8list/ > > > > b.. To unsubscribe from this group, send an email to: > > rv8list-unsubscribe(at)yahoogroups.com > > of > Service. > > > > > > > > [Non-text portions of this message have been removed] Information exchange for builders of Vans Aircraft RV-8 kits. IF YOU WISH TO UNSUBSCRIBE, PLEASE SEND AN EMAIL TO : rv8list-unsubscribe(at)egroups.com _____ * To visit your group on the web, go to: http://groups.yahoo.com/group/rv8list/ * To unsubscribe from this group, send an email to: rv8list-unsubscribe(at)yahoogroups.com Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed] Find things fast with the new MSN Toolbar includes FREE pop-up blocking! http://clk.atdmt.com/AVE/go/onm00200414ave/direct/01/ ________________________________________________________________________________
Subject: Re: Vans Seat Cushion Kit for Sale
Date: Mar 04, 2004
This is probably the 3rd or 4th time i've seen someone selling their Van's seat cushions in the past few months. Is there something about them that is disliked ? What are you guys going with instead ? I'm curious because I'm at the point of needing some cushions and perhaps you guys have some insight to share ? Ron ________________________________________________________________________________
Subject: Re: Halon fire extinguishers-size
Date: Mar 04, 2004
Bert, I assume you are talking about the hand-held extinguishers. There should be an FAA recommendation or requirement (for those "other" airplanes) that would provide a reasonable value of size. The Cessna 172 that I fly has an extinguisher on the floor between the seats - about a foot long. Probably any aviation mechanic could tell you the size. On the other hand, I'm planning to put in a wand system in my engine compartment to kill any fire that starts up there. Haven't decided how big a tank yet - want about 15 seconds total discharge time, if I remember correctly. David ----- Original Message ----- From: <bertrv6(at)highstream.net> > > > Hi: > > Have a question, I see there are 3 sizes of halon extinguishers, what > is best size use for our rv6? > > > Comments appreciated > > > Bert > rv6a ________________________________________________________________________________
Subject: Re: flap motor failure
Date: Mar 04, 2004
> I have just 30 hours on my RV6 and had a flap motor failure today, could not extend flaps, landed & got to the flap motor, gave it a rap while holding switch and flaps extended. I know others have had failures according to archives but this should not be happening. Has Van's been known to be exchanging or upgrading these kit motors of 3-4 years old? I have cleaned the contacts, but how long will that last? > > Dave Ford > RV6 I to have had this problem. On the advice of Van's I clean it and then applied one (just ONE!!!) drop of Three-In-One oil to the top of the flap motor shaft. No problems since (in the RV-4, the motor is mounted vertically which makes this easy). Doug Weiler MN Wing ________________________________________________________________________________
Date: Mar 04, 2004
How can you get the battery out of the circuit? It must be there for no other reason than to excite the field. STATOR Surrounding the rotor is another set of coils, three in number, called the stator. The stator is fixed to the shell of the alternator, and does not turn. As the rotor turns within the stator windings, the magnetic field of the rotor sweeps through the stator windings, producing an electrical current in the windings. Because of the rotation of the rotor, an alternating current is produced. As, for example, the north pole of the magnetic field approaches one of the stator windings, there is little coupling taking place, and a weak current is produced, As the rotation continues, the magnetic field moves to the center of the winding, where maximum coupling takes place, and the induced current is at its peak. As the rotation continues to the point that the magnetic field is leaving the stator winding, the induced current is small. By this time, the south pole is approaching the winding, producing a weak current in the opposite direction. As this continues, the current produced in each winding plotted against the angle of rotation of the rotor has the form shown in figure 2. The three stator windings are spaced inside the alternator 120 degrees apart, producing three separate sets, or "phases," of output voltages, spaced 120 degrees apart, as shown in figure 3. OUTPUT DIODES A/C voltage is of little use in a D/C system, such as used in an airplane, so it has to be converted to D/C before it can be used. This conversion to D/C takes place in the "output diodes" and in the "diode trio." Diodes have the property of allowing current to flow in only one direction, while blocking current flow in the other direction. The output diodes consist of six diodes, one pair for each winding. One of the pair is for the negative half cycle, and the other for the positive half cycle. As a result of this diode rectification, the output of the alternator looks as shown in figure 4. Surprisingly enough, the output of the alternator is not a pure D/C as one might expect, but a pulsating D/C. Because there are three windings, each with a positive and a negative half, by the time the voltage is passed through the diodes, there are six pulsations for each rotation of the rotor. This is close enough to D/C for most automotive components. Critical components, such as radios, have their own internal filtering circuits to further smooth out the waveform to a purer D/C. This doesn't look like your quoted 99% to me. ----- Original Message ----- From: "linn walters" <lwalters2(at)cfl.rr.com> Subject: Re: RV-List: Van's alternator - $18 at Pep boys > > Cy Galley wrote: > > > > >I am fairly sure without the "ballast" of the battery, your regulator will > >quickly give up the ghost. > > > This hasn't been my (limited) experience. It may be due to differences > in regulators or due to the fact that there was some load available, > although the battery wasn't part of it. I don't see any reason, > technically, for the system to run away with a fully functioning > regulator. Maybe someone else can help out here. > > >I know the battery filters out the ripple of the > >current and many electrical noises within the system. > > > The diode array in the alternator does 99% of the ripple removing. > Under full load, the remaining ripple may become noticeable in cheap > intercoms etc. It is true that the battery will filter some of the crap > that ends up on the power bus, but it's a poor filter .... otherwise we > wouldn't be chasing strobe and flasher noise. In this case 'it all > depends' may be useful as electrical systems are, by their nature, > terribly dynamic. > > Linn > > > > >Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh > >Editor, EAA Safety Programs > >cgalley(at)qcbc.org or sportpilot(at)eaa.org > > > >Always looking for articles for Sport Pilot > > > > > > > ________________________________________________________________________________
From: "Kyle Boatright" <kyle.boatright(at)adelphia.net>
Subject: Exhaust Bracket Failure
Date: Mar 04, 2004
Looks like the exhaust hanging hardware on my airplane needs to be changed every 100 hours or so. When I pulled the cowl for my condition inspection, I found that one of the angles in the Vetterman exhaust hanging system had failed. That was at about 220 hours. Previously (at about 100 hours in service) I experienced a failure in the previous version of the exhaust hanging system. Has anyone worked out an exhaust hanging system that is reliable over the long term? Tom at Van's indicated that lots of folks have experienced failures in this area over the years, despite numerous revisions in the hardware and attachement of the hangars. Thanks in advance, KB ________________________________________________________________________________
Date: Mar 04, 2004
> >It works regardless of rotation so there is no need to remove. Might not be >as efficient but at 6000 rpm it doesn't make any difference. Honda spins the engine backwards from everyone else. Why use a Honda alternator when every other brand in the world spins in the correct direction? ________________________________________________________________________________
Subject: Camping at OSH
Date: Mar 04, 2004
I have camped at OSH every year for the past, what 16? years I suppose. I have seen tents come and go, literally (Hey, isn't that Dave's tent rolling by over there?). The best I have found for relatively little money for what you get are the Cabela tents, specifically the Alaskan Guide Model. I have the 4 man for me, myself and I and my wife when she can come. Holds everything I cram in it. At OSH it can RAIN which will get in your tent. My Cabela's is the driest I have used or seen. It also can BLOW there, either nature or some twin trying to blast himself out of his tire ruts. The Cabela tents can be secured at multiple points and stay put. Search the archives under CAMPING AT OSH and read message 99850 April 02 babble for some more hints about camping there. Some things will be changed as there will now be Custom Camping west of the forum tents. YEA. You HAVE to fly to OSH, and it is GREAT to camp there, even if you are not that accustom to the great out doors. Early morning, smell of coffee and someone cooking bacon, sun not up yet but orange glow over the lake, conversation you can't quite make out over behind you to your left, two P-51s and an F4U taking off in sequence 200 yards from your tent roar the quiet away and are gone, quiet again except for someone somewhere saying "cool!". Friends you only see at OSH, stumble out of their tent and crawl over to yours, set up a chair and, smiling blurry-eyed, hold out their cup for a bit of hot joe. Can't wait. Michael RV-4 N232 Suzie Q ________________________________________________________________________________
Date: Mar 04, 2004
What is "(The ER Tanks slide into the first nose rib lightening hole forward of the spar) " Inquiring minds want to know. Cecil > > Hi all, don't know if this is general knowledge, but I thought this > response was good enough to share with the list. I finally bit the > bullet and ordered my Dynon and associated toys. Tony and Monte have > been really great to deal with. Would like to throw out a big thanks > to Dynon just for making a good pitot tube for a reasonable price. > Every little victory adds up. > > Eric > Thanks for your order, we look forward to receiving it and we'll get > it processed as soon as it's received. > The wing tip is the preferred location for the remote compass. This > gets the remote compass as far away from the panel and ferrous > materials (engine, engine mount, landing gear, etc.) as possible. If > you have a strobe power supply in the wing tip, you'll want to > install the compass as far away from the box as possible (within the > wing tip). The EFIS-D10 "samples" the remote compass 64 times/second > and averages these samples. Even with the comet flash strobes, there > is only small amount of time, relative to the sampling rate, that > any significant interference can be generated by the strobe power > supply. The remote compass will sense the strobes as they discharge > but the user probably won't notice any change on the EFIS-D10 > display (due to the averaging and large number of samples taken each > second). Now that you understand how the EFIS-D10 gathers and > processes compass signals, it explains why electric gyro's (being > continuous sources of interference) are the most problematic! > to correct. > As a side note, if you ever think you may be installing our ER > Tanks, mount the remote compass at least 1 foot behind the main > spar. Then you won't have to move it should you install ER Tanks at > a later date. (The ER Tanks slide into the first nose rib lightening > hole forward of the spar) > If there's anything else Monte or I can do for you, please don't > hesitate to contact us. > Tony Munday and Monte McDavid > SafeAir1 > 817-821-4957 (TM) > 817-939-2695 (MM) ________________________________________________________________________________
Subject: RV-List New EFIS instrument add & company in Kitplanes
Date: Mar 04, 2004
Has anyone contacted the Canadian company who is advertising in the back of Kitplanes magazine which advertises single unit, replacement electrical/LCD display flight instruments ?? I am at work and the magazine is at home........ Noticed the add in the new (latest) mailing of Kitplane magazine, in the back section of the mag,- last night while I should have been doing my taxes and houseold billing...... ________________________________________________________________________________
Date: Mar 04, 2004
Subject: Re: Oshkosh Camping Question
From: Laird Owens <owens(at)aerovironment.com> "And be sure not to mix up the two.... :-)" Owen . . . you didn't---- Oh My God Cecil ________________________________________________________________________________
Subject: Honda alternator
Date: Mar 04, 2004
If the Honda spins backwards from every other car engine then it would be turning the same direction that aircrat engines turn and the alternator would be even better?? Right?? ----- Original Message ----- From: "Bill Dube" <bdube(at)al.noaa.gov> Subject: Re: RV-List: Van's alternator - $18 at Pep boys > > > > >It works regardless of rotation so there is no need to remove. Might not be > >as efficient but at 6000 rpm it doesn't make any difference. > > Honda spins the engine backwards from everyone else. Why use a > Honda alternator when every other brand in the world spins in the correct > direction? > > ________________________________________________________________________________
Date: Mar 04, 2004
They sell extended range tanks - fuel "cylinders" that slide into the rib lightening holes. Take a look at www.safeair1.com Dick Tasker cecilth(at)juno.com wrote: > >What is "(The ER Tanks slide into the first nose rib lightening hole >forward of the spar) " >Inquiring minds want to know. >Cecil > > > > >> >>Hi all, don't know if this is general knowledge, but I thought this >>response was good enough to share with the list. I finally bit the >>bullet and ordered my Dynon and associated toys. Tony and Monte have >>been really great to deal with. Would like to throw out a big thanks >>to Dynon just for making a good pitot tube for a reasonable price. >>Every little victory adds up. >> >>Eric >>Thanks for your order, we look forward to receiving it and we'll get >>it processed as soon as it's received. >>The wing tip is the preferred location for the remote compass. This >>gets the remote compass as far away from the panel and ferrous >>materials (engine, engine mount, landing gear, etc.) as possible. If >>you have a strobe power supply in the wing tip, you'll want to >>install the compass as far away from the box as possible (within the >>wing tip). The EFIS-D10 "samples" the remote compass 64 times/second >>and averages these samples. Even with the comet flash strobes, there >>is only small amount of time, relative to the sampling rate, that >>any significant interference can be generated by the strobe power >>supply. The remote compass will sense the strobes as they discharge >>but the user probably won't notice any change on the EFIS-D10 >>display (due to the averaging and large number of samples taken each >>second). Now that you understand how the EFIS-D10 gathers and >>processes compass signals, it explains why electric gyro's (being >>continuous sources of interference) are the most problematic! >> to correct. >>As a side note, if you ever think you may be installing our ER >>Tanks, mount the remote compass at least 1 foot behind the main >>spar. Then you won't have to move it should you install ER Tanks at >>a later date. (The ER Tanks slide into the first nose rib lightening >>hole forward of the spar) >>If there's anything else Monte or I can do for you, please don't >>hesitate to contact us. >>Tony Munday and Monte McDavid >>SafeAir1 >>817-821-4957 (TM) >>817-939-2695 (MM) >> >> > > > > ________________________________________________________________________________
Date: Mar 04, 2004
Subject: Re: Exhaust Bracket Failure
on 3/4/04 11:03 AM, Kyle Boatright at kyle.boatright(at)adelphia.net wrote: > > Looks like the exhaust hanging hardware on my airplane needs to be changed > every 100 hours or so. When I pulled the cowl for my condition inspection, I > found that one of the angles in the Vetterman exhaust hanging system had > failed. That was at about 220 hours. Previously (at about 100 hours in > service) I experienced a failure in the previous version of the exhaust > hanging system. > > Has anyone worked out an exhaust hanging system that is reliable over the long > term? Tom at Van's indicated that lots of folks have experienced failures in > this area over the years, despite numerous revisions in the hardware and > attachement of the hangars. > Kyle, I started off with lots of failures and have finally gotten it to where I have not had any for a few hundred hours. I can't remember everything I have done because it has been a gradual upgrading, but here are some of the things, half stolen from other listers and half my own ideas. I replaced the original Vetterman tubing with heavier wall tubing. I believe this stuff is auto brake line. The smashed ends with the holes, that Vetterman uses to make attachements are where mine almost always broke, no matter how careful I was making the smashes smooth. Now I use clamps on the tubing captured with silver soldered wire around the tubing on each side of the clamp. Rather than one clamp on the engine mount at each attach point I use two bridged with a piece of heavy aluminum. I eliminated the cross brace, which was a failure point and have found the exhaust hangs just fine straight down from its mounting point. It can't break if it isn't there. I have still found failures of one clamp occasionally but that hasn't caused a problem. And finally I safety wire things so a failure doesnt' let the exhaust go anywhere, although I have found it tends to stay pretty much in place, even with a complete failure on one side. I haven't tried any of Larry's updated mounting solutions. All of this is on an RV-6 with O-360. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Subject: Re: Van's alternator - $18 at Pep boys
Date: Mar 04, 2004
Cy meant to say ROTOR, not stator at the beginning of his message. The electormagnetic field is created by electricity being fed into the rotor windings. This creates the magnetic field. Charlie Kuss > > From: "Cy Galley" <cgalley(at)QCBC.ORG> > Date: 2004/03/04 Thu PM 12:29:52 EST > To: > Subject: Re: RV-List: Van's alternator - $18 at Pep boys > > ________________________________________________________________________________
bill(at)vondane.com, banderson(at)polyvision.com, dan(at)rvproject.com, rv7boy(at)yahoo.com, drwalker(at)powernet.net, jacki(at)jackim.com, jhallrv4(at)comcast.net, n1cxo320(at)salidaco.com, RV-List(at)matronics.com, mikesrv6(at)yahoo.com, rosales(at)bigfoot.com, n667sr(at)comcast.net
Subject: RSVP for Carson City Fly-in
Date: Mar 04, 2004
Hello Everyone, I am sending this e-mail out 8 weeks in advance to get an idea of the crowd we may be dealing with. We have set aside a block of 40 rooms at the Pinion Plaza Resort so don't hesitate on that. I have been told if the rooms do not reserve by a certain time they will release them for other costumers. So far I have received raffle/door prizes from Aerox Aviation Oxygen Systems, Avery Tools, and Aircraft Spruce. We are working on a couple more and will post those donations as soon as I get word. Please mark your calendars and plan for this event. I ask anyone that wishes to participate in this event to RSVP in the next couple of weeks so we can get an idea for food preparations and chapter members we need to recruit to make this fly-in a success. Thanks to you all that are supporting and donating to this fly-in. We will see you here. Bruce One-click access to Hotmail from any Web page download MSN Toolbar now! http://clk.atdmt.com/AVE/go/onm00200413ave/direct/01/ ________________________________________________________________________________
Date: Mar 04, 2004
Subject: Engine For Sale
My new AeroSport engine has arrived. I would like to find a new home for my old engine with about 900hrs on it SMOH. It is a 180HP O-360A1D off of a Mooney. The engine was removed from a flying airplane when the owner changed to a 200HP IO-360 angle valve. The engine includes the starter and rebuilt Bendix "shower of sparks" mags with the vibrator. I need the vacuum pump and the prop governor. I bought the engine to test fly my RV-6 without having to worry about breaking in a new engine. I have flown it about 85hrs without any problems. The airplane is really fast, I hope I see a big difference in airspeed after spending the money for the AeroSport. I will not be installing the new engine right away so come hear it run and fly the airplane. I am asking $12,500 Cash Copeland RV-6 N46FC Hayward, Ca ________________________________________________________________________________
Date: Mar 04, 2004
I had the same problem after about 80 hours... I made some new brackets and now, 80 hours later, they are good as new... http://www.vondane.com/rv8a/engine/engine3.htm - bottom of page... -Bill ----- Original Message ----- From: "Kyle Boatright" <kyle.boatright(at)adelphia.net> Subject: RV-List: Exhaust Bracket Failure Looks like the exhaust hanging hardware on my airplane needs to be changed every 100 hours or so. When I pulled the cowl for my condition inspection, I found that one of the angles in the Vetterman exhaust hanging system had failed. That was at about 220 hours. Previously (at about 100 hours in service) I experienced a failure in the previous version of the exhaust hanging system. Has anyone worked out an exhaust hanging system that is reliable over the long term? Tom at Van's indicated that lots of folks have experienced failures in this area over the years, despite numerous revisions in the hardware and attachement of the hangars. Thanks in advance, KB ________________________________________________________________________________
Date: Mar 04, 2004
Subject: Re: Tulsa Engine Services
Good info. It seems there's no overhaul manual specific to IO-360s. It looks like there's just one generic manual for direct drive engines non turbo charged engines. Is that right? What documentation, Lycoming or otherwise, did you accumulate? thanks, lucky In a message dated 3/4/2004 9:24:01 AM Eastern Standard Time, EricHe(at)FlexSolPackaging.com writes: >>>>Listers, What was the name of the engine shop in Oklahoma mentioned recently on the list? I couldn't find it in the archives. Thanks, Dan RV-7A (almost done) >>>>> Sounds like you are doing your own rebuild. I just did that so I thought I'd give you a run down on what I found. Maybe it will benefit someone. If you want your steel parts refurbed in Tulsa you are looking for Aircraft Specialties Inc. They did all of my internal parts, resurfaced everything and yellow tags for everything for $1800.00 . They sold me a rebuild kit that contains all hardware you'll need for $800.00. There's your bottom end overhaul. BTW, most of the cost is the connecting rod bolts. Ouch! My cases were done by Divco. For $700.00 they line bore, check for cracks, resurface everything. They are absolutely beautiful when you get them back. Next engine, I will do the same thing, but I might be tempted to give ole Monte Barret a call and ask him how much he wants to assemble and test the thing. Monte builds high perf competition aerobatic engines. He's right next door to Aircraft Specialties. He chased down some parts for me and was great to work with and was more than reasonable. Basically you could disassemble your engine ship it off and get back a fresh engine. You would be skipping the markup the buil! ders charge you to ship your parts out. When a builder ships a crank out, from my experience, they charge you near double the cost of the machine shops price. If you have a bendix fuel injection, Air Flow Performance made my entire FI system brand spanking new for $650.00, they replace everything but the body. For Mags I found a guy named Howard Libersky in Okechobee, Fl that rebuilt each mag completely for $120.00 flat out. He's been doing mags since they were cutting edge technology. His number is (863-467-6464). I put new ECI Titan cylinders on since it was not much more than having my old work cylinders reworked. All told, I figure I've got about $13,500.00 invested and I'm damn confident in my engine (big thanks to Charlie Kuss). Hope it helps Eric Henson ________________________________________________________________________________
Date: Mar 04, 2004
In a message dated 3/4/04 3:21:55 PM Eastern Standard Time, n5lp(at)warpdriveonline.com writes: > Rather than one clamp on the engine mount at each attach point I use two > bridged with a piece of heavy aluminum. > > Are you attaching the exaust pipes hangers from the engine mount rather than from lower case bolts as indicated in the vettermans instructions? Scott Morrow RV-6A 90% ________________________________________________________________________________
Date: Mar 04, 2004
The exhaust hangers were one of the most problematic parts of my RV for the first couple hundred hours. I don't know how many variations I tried, but they'd always break. I finally gave up trying to hang them off the motor mount and now support them off the sump bolts. Been great for the last 500 hrs. Laird RV-6/O-360 950 hrs SoCal > >on 3/4/04 11:03 AM, Kyle Boatright at kyle.boatright(at)adelphia.net wrote: > >> >> >> Looks like the exhaust hanging hardware on my airplane needs to be changed >> every 100 hours or so. When I pulled the cowl for my condition >>inspection, I >> found that one of the angles in the Vetterman exhaust hanging system had >> failed. That was at about 220 hours. Previously (at about 100 hours in >> service) I experienced a failure in the previous version of the exhaust >> hanging system. >> >> Has anyone worked out an exhaust hanging system that is reliable >>over the long >> term? Tom at Van's indicated that lots of folks have experienced >>failures in >> this area over the years, despite numerous revisions in the hardware and > > attachement of the hangars. >> ________________________________________________________________________________
Date: Mar 04, 2004
> > In a message dated 3/4/04 3:21:55 PM Eastern Standard Time, > n5lp(at)warpdriveonline.com writes: > > > Rather than one clamp on the engine mount at each attach point I use two > > bridged with a piece of heavy aluminum. > > > > > > Are you attaching the exaust pipes hangers from the engine mount rather than > from lower case bolts as indicated in the vettermans instructions? > I am attaching to the engine mount as indicated in the Vetterman instructions that I got. Apparently there are different versions of his system. I think I got my exhaust about 1998 or 1999. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Date: Mar 04, 2004
Subject: Re: MP/Ram Air Question
A few comments: 1. The ambient pressure is directly related to the pressure altitude, but the pressure does not vary with temperature. So, there is no direct relationship between density altitude and ambient pressure. So forget all about density altitude for this discussion. Just consider pressure altitude (i.e. what the altimeter reads when you set it to 29.92). 2. There are a whole bunch of different pressures that we can talk about, and it is hard to have a clear discussion unless we are sure we are talking about the same pressures. Ambient pressure (or static pressure) - the actual pressure in the atmosphere at the altitude in question. There is a direct relationship between ambient pressure and pressure altitude. You can find the equations for the relationship between pressure altitude and ambient pressure at: http://williams.best.vwh.net/avform.htm#Altimetry Dynamic pressure - this is the pressure increase due to speed, in simple terms. http://www.centennialofflight.gov/essay/Dictionary/Dynamic_Pressure/DI142.htm Total pressure - this is the sum of ambient pressure and dynamic pressure. It is the pressure that we get if we take the air and slow it down to zero speed (looking at it from the perspective of the aircraft). This is the pressure that we could get inside the induction air scoop, if we actually could get the air to come to a stop relative to the aircraft. In reality, the air has to keep moving, as the engine needs to keep consuming it, so we can never get the pressure quite this high. Pressure before the air filter - this pressure will generally be somewhat less than the total pressure, unless we manage to position our intake to get some pressure increase due to the propeller. Pressure after the air filter - air will not flow unless there is a pressure differential, so the pressure after the filter has to be lower than the pressure ahead of the filter. The pressure loss as the air goes through the filter seems to be about 1" HG, at least based on what some people have reported. Manifold pressure - this is the pressure that we have at the intake manifold, right next to the intake port. There are pressure losses as the air flows through the carb (or fuel injection servo) and the intake manifold plumbing. So, the manifold pressure will be equal to the ambient pressure + dynamic pressure - small error because the air never actually goes to zero speed - pressure loss through the air filter - pressure loss through the carb and intake manifold. So, depending on how fast we going (which will largely determine the dynamic pressure), and what the various pressure losses are, the manifold pressure may be more or less than the ambient pressure. So, you are seeing about a 1" pressure increase due to ram air. Which pressure has increased by 1"? 1" relative to what? The manifold pressure? What do you mean by ram air? Do you mean that you have a way to bypass the air filter? Or do you mean that you are looking at the pressure increase due to motion (i.e. the dynamic pressure)? There is no rocket science to increasing manifold pressure, but the laws of physics will place limits on what you can do. Going faster will increase the dynamic pressure, which will increase the total pressure, which will mean more manifold pressure. Sort of a Catch 22 here - you want to go faster, so you want more manifold pressure. But you'll get more manifold pressure if you can figure out how to go faster. Have an air inlet with the lowest amount of frictional losses. The frictional losses are at the outside surface of the air inlet. So, you want the shape that has the least amount of circumference for a given area - i.e. a circle. Turbulence causes pressure losses, so you want smooth contours, and gentle changes in contour. No steps, or rapidly increasing areas. You want the shortest possible inlet duct, as that minimizes the frictional losses. You might get some benefit from having the air inlet further away from the prop hub, so you could get some pressure increase from the prop. Lopresti claimed to have gotten some benefit from this effect, but it could have been all smoke and mirrors. You want a smooth surface to the intake ducting and the intake manifold, to reduce the frictional losses. You want an air filter with the lowest pressure drop. Good luck, Kevin Horton > >Dont remember where I came up with 1"???? Somewhere somebody posted the >calculated pressure available at 8k density alt for a standard day?. Well >we have had a few standard days here in the last month, I checked and saw >1" more than calculated at 185 MPH. Have no idea if this is right. I have >paid real attention to detail on sealing up everything I can on the air >box. It pained me to even add the drain hole for the FAB. > >Now after all this I just remember I was told that you cannot use the >barometric pressure as a comparison/base line to MP. Any info on this? How >and why are they different? If barometric pressure is 30.0 would max >manifold pressure also be the same barring any losses in the system? > > >> >>Hi Scott, >> >>I am still learning about these things but maybe I can help. I'm curious >>how you deduced the 1" MP increase due to ram air? It is interesting because >>at 170 mph you can expect about 1" of mercury pressure available at the air >>box. This can be calculated based on the formula for the dynamic pressure of >>a fluid where >> >>P = (V**2 d)/288 g >> >>where: >> >> P = lbs per sq. inch (psi) >>V = Velocity in feet per second (1mph = 1446 fps) >>d = density of air in pounds pwe cu. ft., standard sea level air density >>0.0762 pounds per cubic foot. >>g = acceleration of gravity in feet per second (32.2 feet per second) >> >>Based on this formulation at: >> >>170 mph =~1"hg >>300 mph =~3"hg >> >>To increase your Ram air pressure you can eliminate pressure drops, across >>air filters, induction systems, etc. For example a poorly designed air box >>may have a large pressure drop. Porting of the intake manifold and intake >>chambers on the head can help reduce pressure drop. Keep in mind that you >>are working with rather small increases in performance here for increasingly >>higher dollar costs. If you have the Van's FAB then you probably have a very >>low psi drop air box already. >> >>Your Fellow RV Enthusiast, >>Ned >> >>----- Original Message ----- >>From: "Scott Bilinski" <bilinski@kyocera-wireless.com> >>To: >>Subject: RV-List: MP/Ram Air Question >> >> >><bilinski@kyocera-wireless.com> >>> >>> Is there anyone out there who understands MP, ram air induction, and what >>> can be done to increase ram air pressure? I appear to be seeing about 1" >>MP >>> increase due to ram air. Can I get more? Is there a limit? Would a bigger >>> FAB help? Larger snorkel intake? Smaller snorkel intake? Any advice >>> appreciated. >>> >>> > >> Scott Bilinski > >> >>> >> >> > >Scott Bilinski ________________________________________________________________________________
Subject: alternators
Date: Mar 04, 2004
Honda civic engines are one of the very few that spin like a aircraft engine, so their fans should work. I'm not sure my cowl would not hit the external fan though if one were installed. RE reverse spinning the alt is no problem as long as you are below roughly 50% rated duty. The main problem with auto alternators is they are not rated for continous duty as aircraft ones are. Then you reduce cooling by reverse spinning the fan and removing the external one (if it had one) and ba da bing melted parts. I have tested them on the bench at load both ways and they will smoke quicker when going backwards, but they will smoke either way if held at rated power for too long. That's why I built the big one out of a toyota solara. http://www.miramarcollege.net/programs/avim/faculty/north/alternator/index.h tm W ________________________________________________________________________________
Date: Mar 04, 2004
>>Engine (valves) won't last long with no filter - grit gets >>onto valve seats and then valves burn rapidly due to hot gas blow-by. >> >>David >> I've had rings get wiped out, but never valves operating crop dusters on dirt roads with leaking air boxes. For the record, there a model of Mooney that allows one to bypass the filter for improved ram air performance. Also for the record, I have an early Vans intake air setup in my RV-3. No filtering unless the carb heat is actuated. Over 700 hours on the engine with compression in the mid 70's and oil consumption is less than a quart in 20 hours. I do pull carb heat while taxiing on the ground to keep the engine clean of damaging abrasive particles. Would a full time air filter be better for longevity? Most likely at the expense of ramn air performance. At any rate, seems Van was not too concerned when he engineered my early version RV-3 air intake. Bob ________________________________________________________________________________
Subject: Re: alternator cooling
Date: Mar 04, 2004
Listers, Has anyone actually studied the airflow conditions surrounding the alternators positioned as they are in the cowlings of Vans RV line? I have seen little indication that the direction of airflow in the alternator's confined area of the average RV cowling is clearly understood. Keep in mind that there is no direct air flow to or from the line of flight outside airflow. Airflow in this comparatively cramped corner of the forward lower cowling might well be considerably dynamically turbulent with very little actual definable flow direction or rate of flow. All air movement in the area of the alternator is pre-heated by engine cooling and further by exhaust system radiant and convective sources. Cooling therefore is an issue. The direction of rotation of the stock cooling fan/s is likely to be a somewhat moot point. Having the fan/s turn in the fan designer's intended direction where possible would be the preferred choice. Adding an additional fan on the units that have only one, might be possible? but may not be worth the effort. Blast air is suggested `if not a must' and is not uncommonly applied by aiming a blast air tube in the general direction of the alternator. Having the blast air tube fitted to some form of duct that improves the cooling effect might be desirable on any alternator. The same treatment focused on the electronics housing for internally regulated regulator types can only help in the overall. Of course having additional blast air tubes could help but a line has to be drawn somewhere. These alternators survive well in deplorable conditions in the automobiles that they were designed for. It could be said that though the conditions under the engine of an RV are different, they are also deplorable at least from any imaginary ideal condition point of view. If anyone cares to add to my understanding or shed light on my lack thereof please do so. I live to learn, Jim in Kelowna ________________________________________________________________________________
Subject: Re: alternators
Date: Mar 04, 2004
Good information and I like that you have actually tested the alternators. I always wondered how my "Certified" aircraft was able to get the Ford alternator certified while running it backwards. They didn't even bother to change the fan. The fan runs backwards... Go figure. ----- Original Message ----- From: "Wheeler North" <wnorth(at)sdccd.cc.ca.us> Subject: RV-List: alternators > > Honda civic engines are one of the very few that spin like a aircraft > engine, so their fans should work. I'm not sure my cowl would not hit the > external fan though if one were installed. > > RE reverse spinning the alt is no problem as long as you are below roughly > 50% rated duty. The main problem with auto alternators is they are not rated > for continous duty as aircraft ones are. Then you reduce cooling by reverse > spinning the fan and removing the external one (if it had one) and ba da > bing melted parts. > > I have tested them on the bench at load both ways and they will smoke > quicker when going backwards, but they will smoke either way if held at > rated power for too long. > > That's why I built the big one out of a toyota solara. > > http://www.miramarcollege.net/programs/avim/faculty/north/alternator/index.h > tm > > W > > ________________________________________________________________________________
Date: Mar 04, 2004
Hi Larry, Since then Larry is recommending attaching the exhaust to the engine sump bolts. I broke mine multiple times until I hung them from the two rear corner sump bolts. Now the exhaust moves with the engine, nearly 200 hrs trouble free since then. It'll only take you an hour or two to make the change, and no more exhaust hanger problems! Cheers, Stein Bruch RV6's, Minneapolis http://www.steinair.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Larry Pardue Subject: Re: RV-List: Exhaust Bracket Failure > > In a message dated 3/4/04 3:21:55 PM Eastern Standard Time, > n5lp(at)warpdriveonline.com writes: > > > Rather than one clamp on the engine mount at each attach point I use two > > bridged with a piece of heavy aluminum. > > > > > > Are you attaching the exaust pipes hangers from the engine mount rather than > from lower case bolts as indicated in the vettermans instructions? > I am attaching to the engine mount as indicated in the Vetterman instructions that I got. Apparently there are different versions of his system. I think I got my exhaust about 1998 or 1999. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Date: Mar 04, 2004
W, Thanks for the great web site and sharing your alternator knowledge. I was a technician for Delco Radio (now Delphi Delco Electronics) back in the mid to late 60's working on GM's electronic voltage regulator-in-the-alternator program which first came out on the '68 Pontiac in limited production. Within about 3 years it was across the board on all GM cars. At the time even silicon transistors were not too common. When I first heard what the temperatures were in the alternator, and what accuracy of regulation we were expected to achieve, I wondered if I was working for a bunch of idiots! Anyway, I had the pleasure of getting to know some of the brightest minds in the business. My '63 Ford was one of the first, if not the first, to have a regulator inside the alternator. I took off the generator and made brackets and installed one of the Delco Remy alternators which was consigned to me by the company. My first impression of Van's 35 amp installation with no fan was that it won't last long. Guess what, it didn't. My friend and instructor finished his RV-9A and the first thing that failed was the charging system. I opened up the alternator and found solder balls and soot. Has anyone had any LUCK with these things with no fan? A blast tube alone will not get the air where its needed, although a blast tube may bring in some cool air for the alternator fan to pick up, if it has one. The problem is that if you have to crank the engine long, or otherwise run the battery down, the alternator will overheat before you get it to the end of the runway to take off. You could baby it by leaving the field breaker turned off, but who wants to have to remember to do that? Not a good situation. Right now I have Van's 60 amp kit installed on my yet to fly RV-7A, but I really like your approach. At the first sign of a problem, I'm going that route. Thanks again, Dan N766DH (almost done in Indiana) In a message dated 3/4/04 5:34:45 PM US Eastern Standard Time, wnorth(at)sdccd.cc.ca.us writes: > > That's why I built the big one out of a toyota solara. > > http://www.miramarcollege.net/programs/avim/faculty/north/alternator/index.h > tm > > W > > ________________________________________________________________________________
Date: Mar 04, 2004
Listers, Rather than flatten the tubes or silver solder to them, I just put a little flare on them with my flaring tool -- just enough to increase the diameter about like putting a bead on the tube. A bead would be ideal. After flaring the tubing, smooth it up on a Scotchbrite wheel so it doesn't cut the rubber tubing. Dan RV-7A (almost done) In a message dated 3/4/04 6:46:33 PM US Eastern Standard Time, stein(at)steinair.com writes: > Since then Larry is recommending attaching the exhaust to the engine sump > bolts. I broke mine multiple times until I hung them from the two rear > corner sump bolts. Now the exhaust moves with the engine, nearly 200 hrs > trouble free since then. It'll only take you an hour or two to make the > change, and no more exhaust hanger problems! > > Cheers, > Stein Bruch > RV6's, Minneapolis > http://www.steinair.com > > ________________________________________________________________________________
Date: Mar 04, 2004
Subject: Re: Honda alternator
> >If the Honda spins backwards from every other car engine then it would be >turning the same direction that aircrat engines turn and the alternator >would be even better?? Right?? Then why are folks complaining that the fan is backwards? ________________________________________________________________________________
Date: Mar 04, 2004
Subject: finishing up sequence of events?
Engine and finishing kit on the way. So what's the preferred order of events between now and riveting on the forward top fuse skin? I can see some things are on an equal level. Here's what I'm thinking. No vacuum system for me. I want to put a Lightspeed on one set of plugs but will wait until after 25 hour fly off. Mount the engine, install engine accessories, fit cowl, exhaust, baffles, oil cooler, fuel and oil hoses/lines, throttle, mixture, governor cables from cockpit, engine monitoring cables and sensors, finish panel, ???, cut canopy, rivet on top skin, finish front baggage door, install windscreen, ??? What have I got out of order or am missing? thanks, lucky ________________________________________________________________________________
Date: Mar 04, 2004
You probably ought to install the Lightspeed up front. It's a good size box that needs to be mounted on the cabin side of the firewall with penetrations for 2 coil leads, manifold pressure and timing pick-up and direct-to-battery power. The Hall effect sensor uses a 9-pin D-sub that needs a large opening to pass through even if you remove its shell. You really don't want to do all that after the skin is on. Engine side would certainly be easier but cabin side was recommended several years ago unless Klaus has changed it recently. Regards, Greg Young - Houston (DWH) RV-6 N6GY ...project Phoenix Navion N5221K - just an XXL RV-6A > > > Engine and finishing kit on the way. So what's the preferred > order of events > between now and riveting on the forward top fuse skin? I can > see some things > are on an equal level. > > Here's what I'm thinking. No vacuum system for me. I want to put a > Lightspeed on one set of plugs but will wait until after 25 > hour fly off. > > Mount the engine, > install engine accessories, > fit cowl, > exhaust, > baffles, > oil cooler, > fuel and oil hoses/lines, > throttle, mixture, governor cables from cockpit, > engine monitoring cables and sensors, > finish panel, > ???, > cut canopy, > rivet on top skin, > finish front baggage door, > install windscreen, > ??? > > What have I got out of order or am missing? > > thanks, > lucky > ________________________________________________________________________________
Date: Mar 04, 2004
Hello, I am there now....It is sort of a chicken and the egg stage isn't it! Well, here's what I am doing: Check with Van's Web Site as they have some additional notes/instructions about mounting the wings, the cowl and I believe the canopy. Main thing is they say to leave off all the engine doodads as they get in the way when mounting the cowl. I haven't mounted the top deck as I am concentrating on firewall penetrations in the vain hope of minimizing the crawling around inside when the top deck is on. I have the engine mounted. Some say to wait till you have mounted the firewall stuff, but I need the engine on to get an idea of where everything goes. I have been held up as I really need to have an idea of the panel before I proceed. I have decided on NO fuel/pressure/copper/etc. lines in the cockpit. NO Vacuum instruments. I elaborate as you need to know this before you start punching holes in the firewall. Everything on the firewall will be nutplated so you can imagine trying to do it with the top deck on. Are you using Lightspeed Electronic Ignition? Then you need to have a Manifold Pressure line to it and the coax cables need to seperated from the return sensor wires. This kind of circular detail can drive one crazy! Another reason I mention the panel is that the side sections (RV-8) of it are best dealt with before permanent installation of the top deck. My ignition switch will go on the right and potentially the carb/cabin heat will go on the left. Also if you can nail down the electrical wire routing (again firewall penetrations) you will be ahead of the game. With apologies to the traditionalists, I am going with Aeroelectric Bob's recommendations. There are other things you can be doing in parallel such as the upholstery, seats, cabin wiring, but you already know that. So wrapping it all up: Focus on the firewall and instrument side penetrations (and fuel lines, but you probably have already done that). Mount the top deck Then pick up with the plans at the Canopy. Of course, that is the game plan for today. Tomorrow could be another story. Regards, Vince Himsl RV8 - SB Finish "Aerosport and Lightspeed, but still procrastinating on the canopy" -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV8ter(at)aol.com Subject: RV-List: finishing up sequence of events? Engine and finishing kit on the way. So what's the preferred order of events between now and riveting on the forward top fuse skin? I can see some things are on an equal level. Here's what I'm thinking. No vacuum system for me. I want to put a Lightspeed on one set of plugs but will wait until after 25 hour fly off. Mount the engine, install engine accessories, fit cowl, exhaust, baffles, oil cooler, fuel and oil hoses/lines, throttle, mixture, governor cables from cockpit, engine monitoring cables and sensors, finish panel, ???, cut canopy, rivet on top skin, finish front baggage door, install windscreen, ??? What have I got out of order or am missing? thanks, lucky ________________________________________________________________________________
Date: Mar 04, 2004
Subject: Langley Fly-in 2004
The Langley Aero Club and Van's Air Force Western Canada Wing are holding the third annual Langley Fly-in on Saturday, June 12, 2004 at Langley airport (CYNJ), Langley, BC (~20 nm north of Bellingham, WA). Keep an eye on the Fly-in web page for details, http://www.vansairforce.org/CYNJ For U.S. visitors, there's a link on the web page to Randall Henderson's excellent border-crossing information page -- everything the first-time border-crosser needs to know. There will be awards for homebuilts, seminars on RV-related topics, and a representative from Van's Aircraft. Naturally, we're encouraging anyone who wants to fly in, regardless of what type of airplane you have. If you plan to attend, and especially if you plan to fly in, please take the time to sign the Guest Book on the Fly-in web page. http://www.vansairforce.org/CYNJ/guestbook/lac_sign.html That will help us plan facilities such as food and washrooms. Tedd McHenry Van's Air Force Western Canada Wing tedd(at)vansairforce.org www.vansairforce.org ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Mar 04, 2004
With using a blast air tube for cooling the alternator, is there any concern about flying into rain and having rain water coming through the tube onto the back of the alternator? Indiana Larry, RV7 Tip-up TMX-O-360 ACS2002 Dynon CNS430 Digitrak JeffRose Firewall Forward ----- Original Message ----- From: "Jim Jewell" <jjewell(at)telus.net> Subject: Re: RV-List: alternator cooling > > Listers, > > Has anyone actually studied the airflow conditions surrounding the > alternators positioned as they are in the cowlings of Vans RV line? > > I have seen little indication that the direction of airflow in the > alternator's confined area of the average RV cowling is clearly understood. > Keep in mind that there is no direct air flow to or from the line of flight > outside airflow. > Airflow in this comparatively cramped corner of the forward lower cowling > might well be considerably dynamically turbulent with very little actual > definable flow direction or rate of flow. > > All air movement in the area of the alternator is pre-heated by engine > cooling and further by exhaust system radiant and convective sources. > Cooling therefore is an issue. > The direction of rotation of the stock cooling fan/s is likely to be a > somewhat moot point. > Having the fan/s turn in the fan designer's intended direction where > possible would be the preferred choice. > Adding an additional fan on the units that have only one, might be possible? > but may not be worth the effort. > Blast air is suggested `if not a must' and is not uncommonly applied by > aiming a blast air tube in the general direction of the alternator. > Having the blast air tube fitted to some form of duct that improves the > cooling effect might be desirable on any alternator. The same treatment > focused on the electronics housing for internally regulated regulator types > can only help in the overall. > Of course having additional blast air tubes could help but a line has to be > drawn somewhere. > > These alternators survive well in deplorable conditions in the automobiles > that they were designed for. It could be said that though the conditions > under the engine of an RV are different, they are also deplorable at least > from any imaginary ideal condition point of view. > > > If anyone cares to add to my understanding or shed light on my lack thereof > please do so. > > I live to learn, > > Jim in Kelowna > > ________________________________________________________________________________
Subject: Help me stop my engine
Date: Mar 04, 2004
For the last 2 months I have had a problem I can not figure out and wanted to see if anyone has a direction to point me. I have a 6 with a o-360 with the airflow performance fuel injection system. When I shutdown, the engine is dieseling really bad. I did not know the term dieseling but it basically means the engine will not shutdown fuel gets ignited somehow and keeps turning the engine over. I pull the mixture to idle cut off and then hit the electronic ignition and the mag and the master. I do all this with about 1000 rpm. Before this started happening I could shutdown any way I wanted with no problem. The only way to get the prop to stop spinning and vibrating the heck out of the airplane is to shove the mixture to full rich while everything else is off and the engine is just dieseling. Not only is this causing damage (exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) all the top plugs, this made no difference. Has anyone had this happen? What should I do next? I am suspect of the mixture control but last time I checked the control was hitting the stop. The only thing I did right before this happened was add avblend to the oil (I know that should have nothing to do with the problem). The oil has been changed since the avblend and I still have the problem. Any ideas to help my RV not come off as a clunker on the flight line? Jason Sneed Commercial Lending Officer First National Bank and Trust http://www.highland-parks.com/n242ds/index.html ________________________________________________________________________________
Date: Mar 04, 2004
Subject: MP/Ram Air Question
Well, thanks guys, a useful discussion. I have spent the last couple of months developing a ram/alternate/filtered air system. When I am finished I will offer parts for sale...see me at sun n fun. I have been testing the ram pressure rise by noting the manifold pressure before I start the engine, then again at the same altitude 5 miles south of the airport at cruise speed. I live in the mountains so that is easy, though it happens at 7650 msl. More to follow. John Huft RV8 flying -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kevin Horton Subject: Re: RV-List: MP/Ram Air Question A few comments: 1. The ambient pressure is directly related to the pressure altitude, but the pressure does not vary with temperature. So, there is no direct relationship between density altitude and ambient pressure. So forget all about density altitude for this discussion. Just consider pressure altitude (i.e. what the altimeter reads when you set it to 29.92). 2. There are a whole bunch of different pressures that we can talk about, and it is hard to have a clear discussion unless we are sure we are talking about the same pressures. Ambient pressure (or static pressure) - the actual pressure in the atmosphere at the altitude in question. There is a direct relationship between ambient pressure and pressure altitude. You can find the equations for the relationship between pressure altitude and ambient pressure at: http://williams.best.vwh.net/avform.htm#Altimetry Dynamic pressure - this is the pressure increase due to speed, in simple terms. http://www.centennialofflight.gov/essay/Dictionary/Dynamic_Pressure/DI142.ht m Total pressure - this is the sum of ambient pressure and dynamic pressure. It is the pressure that we get if we take the air and slow it down to zero speed (looking at it from the perspective of the aircraft). This is the pressure that we could get inside the induction air scoop, if we actually could get the air to come to a stop relative to the aircraft. In reality, the air has to keep moving, as the engine needs to keep consuming it, so we can never get the pressure quite this high. Pressure before the air filter - this pressure will generally be somewhat less than the total pressure, unless we manage to position our intake to get some pressure increase due to the propeller. Pressure after the air filter - air will not flow unless there is a pressure differential, so the pressure after the filter has to be lower than the pressure ahead of the filter. The pressure loss as the air goes through the filter seems to be about 1" HG, at least based on what some people have reported. Manifold pressure - this is the pressure that we have at the intake manifold, right next to the intake port. There are pressure losses as the air flows through the carb (or fuel injection servo) and the intake manifold plumbing. So, the manifold pressure will be equal to the ambient pressure + dynamic pressure - small error because the air never actually goes to zero speed - pressure loss through the air filter - pressure loss through the carb and intake manifold. So, depending on how fast we going (which will largely determine the dynamic pressure), and what the various pressure losses are, the manifold pressure may be more or less than the ambient pressure. So, you are seeing about a 1" pressure increase due to ram air. Which pressure has increased by 1"? 1" relative to what? The manifold pressure? What do you mean by ram air? Do you mean that you have a way to bypass the air filter? Or do you mean that you are looking at the pressure increase due to motion (i.e. the dynamic pressure)? There is no rocket science to increasing manifold pressure, but the laws of physics will place limits on what you can do. Going faster will increase the dynamic pressure, which will increase the total pressure, which will mean more manifold pressure. Sort of a Catch 22 here - you want to go faster, so you want more manifold pressure. But you'll get more manifold pressure if you can figure out how to go faster. Have an air inlet with the lowest amount of frictional losses. The frictional losses are at the outside surface of the air inlet. So, you want the shape that has the least amount of circumference for a given area - i.e. a circle. Turbulence causes pressure losses, so you want smooth contours, and gentle changes in contour. No steps, or rapidly increasing areas. You want the shortest possible inlet duct, as that minimizes the frictional losses. You might get some benefit from having the air inlet further away from the prop hub, so you could get some pressure increase from the prop. Lopresti claimed to have gotten some benefit from this effect, but it could have been all smoke and mirrors. You want a smooth surface to the intake ducting and the intake manifold, to reduce the frictional losses. You want an air filter with the lowest pressure drop. Good luck, Kevin Horton <bilinski@kyocera-wireless.com> > >Dont remember where I came up with 1"???? Somewhere somebody posted the >calculated pressure available at 8k density alt for a standard day?. Well >we have had a few standard days here in the last month, I checked and saw >1" more than calculated at 185 MPH. Have no idea if this is right. I have >paid real attention to detail on sealing up everything I can on the air >box. It pained me to even add the drain hole for the FAB. > >Now after all this I just remember I was told that you cannot use the >barometric pressure as a comparison/base line to MP. Any info on this? How >and why are they different? If barometric pressure is 30.0 would max >manifold pressure also be the same barring any losses in the system? > > >> >>Hi Scott, >> >>I am still learning about these things but maybe I can help. I'm curious >>how you deduced the 1" MP increase due to ram air? It is interesting because >>at 170 mph you can expect about 1" of mercury pressure available at the air >>box. This can be calculated based on the formula for the dynamic pressure of >>a fluid where >> >>P = (V**2 d)/288 g >> >>where: >> >> P = lbs per sq. inch (psi) >>V = Velocity in feet per second (1mph = 1446 fps) >>d = density of air in pounds pwe cu. ft., standard sea level air density >>0.0762 pounds per cubic foot. >>g = acceleration of gravity in feet per second (32.2 feet per second) >> >>Based on this formulation at: >> >>170 mph =~1"hg >>300 mph =~3"hg >> >>To increase your Ram air pressure you can eliminate pressure drops, across >>air filters, induction systems, etc. For example a poorly designed air box >>may have a large pressure drop. Porting of the intake manifold and intake >>chambers on the head can help reduce pressure drop. Keep in mind that you >>are working with rather small increases in performance here for increasingly >>higher dollar costs. If you have the Van's FAB then you probably have a very >>low psi drop air box already. >> >>Your Fellow RV Enthusiast, >>Ned >> >>----- Original Message ----- >>From: "Scott Bilinski" <bilinski@kyocera-wireless.com> >>To: >>Subject: RV-List: MP/Ram Air Question >> >> >><bilinski@kyocera-wireless.com> >>> >>> Is there anyone out there who understands MP, ram air induction, and what >>> can be done to increase ram air pressure? I appear to be seeing about 1" >>MP >>> increase due to ram air. Can I get more? Is there a limit? Would a bigger >>> FAB help? Larger snorkel intake? Smaller snorkel intake? Any advice >>> appreciated. >>> >>> > >> Scott Bilinski > >> >>> >> >> > >Scott Bilinski ________________________________________________________________________________
Subject: Re: Help me stop my engine
Date: Mar 04, 2004
Lower your idle. Jim ----- Original Message ----- From: "Jason Sneed" <n242ds(at)cox.net> Subject: RV-List: Help me stop my engine > > For the last 2 months I have had a problem I can not figure out and > wanted to see if anyone has a direction to point me. I have a 6 with a > o-360 with the airflow performance fuel injection system. When I > shutdown, the engine is dieseling really bad. I did not know the term > dieseling but it basically means the engine will not shutdown fuel gets > ignited somehow and keeps turning the engine over. I pull the mixture > to idle cut off and then hit the electronic ignition and the mag and > the master. I do all this with about 1000 rpm. Before this started > happening I could shutdown any way I wanted with no problem. The only > way to get the prop to stop spinning and vibrating the heck out of the > airplane is to shove the mixture to full rich while everything else is > off and the engine is just dieseling. Not only is this causing damage > (exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) > all the top plugs, this made no difference. Has anyone had this > happen? What should I do next? I am suspect of the mixture control but > last time I checked the control was hitting the stop. The only thing I > did right before this happened was add avblend to the oil (I know that > should have nothing to do with the problem). The oil has been changed > since the avblend and I still have the problem. > > Any ideas to help my RV not come off as a clunker on the flight line? > > > Jason Sneed > Commercial Lending Officer > First National Bank and Trust > http://www.highland-parks.com/n242ds/index.html > > ________________________________________________________________________________
Date: Mar 04, 2004
Jason, I have heard that this is the biggest reason for installing the purge valve with an Airflow Performance fuel injection system. For some reason the mixture apparently doesn't always shut the fuel off enough to stop the engine. Pulling the purge valve diverts the fuel from the injectors to the return line and the engine quits. Note that this is not from my own experience. I am still at the wiring stage, but my Superior XP-IO-360-B1B came from Bart with the purge valve already installed. A call to Airflow Performance ought to get you an authoritative answer. Terry RV-8A #80729 wiring For the last 2 months I have had a problem I can not figure out and wanted to see if anyone has a direction to point me. I have a 6 with a o-360 with the airflow performance fuel injection system. When I shutdown, the engine is dieseling really bad. I did not know the term dieseling but it basically means the engine will not shutdown fuel gets ignited somehow and keeps turning the engine over. I pull the mixture to idle cut off and then hit the electronic ignition and the mag and the master. ________________________________________________________________________________
Date: Mar 04, 2004
Hi Larry, Rain water should not be an issue. For me the fret level is very low in regard to the amount of water that might find it's way to the alternator via the blast tube. I am quite sure that the cars boats etc.that these units live in subject them to more moisture road filth and various other chemical pollution (anti freeze etc.) than your aircraft will see before TBO comes around. Firewall Forward huh, have baffling fun ! [:-) Jim in Kelowna From: "LarryRobertHelming" <lhelming(at)sigecom.net> Subject: Re: RV-List: alternator cooling > > With using a blast air tube for cooling the alternator, is there any concern > about flying into rain and having rain water coming through the tube onto > the back of the alternator? > > Indiana Larry, RV7 Tip-up TMX-O-360 ACS2002 Dynon CNS430 Digitrak JeffRose > Firewall Forward ________________________________________________________________________________
Date: Mar 04, 2004
I'll give them a call tomorrow.... The weird thing is that the engine went 275 hours without having this problem. Thanks, Jason On Mar 4, 2004, at 10:21 PM, Terry Watson wrote: > > Jason, > > I have heard that this is the biggest reason for installing the purge > valve > with an Airflow Performance fuel injection system. For some reason the > mixture apparently doesn't always shut the fuel off enough to stop the > engine. Pulling the purge valve diverts the fuel from the injectors > to the > return line and the engine quits. > > Note that this is not from my own experience. I am still at the wiring > stage, but my Superior XP-IO-360-B1B came from Bart with the purge > valve > already installed. A call to Airflow Performance ought to get you an > authoritative answer. > > Terry > RV-8A #80729 wiring > > > For the last 2 months I have had a problem I can not figure out and > wanted to see if anyone has a direction to point me. I have a 6 with a > o-360 with the airflow performance fuel injection system. When I > shutdown, the engine is dieseling really bad. I did not know the term > dieseling but it basically means the engine will not shutdown fuel gets > ignited somehow and keeps turning the engine over. I pull the mixture > to idle cut off and then hit the electronic ignition and the mag and > the master. > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > Jason Sneed Commercial Lending Officer First National Bank and Trust ________________________________________________________________________________
Date: Mar 04, 2004
Jim... Tried that.... It is worse when I shutdown at 600 rpm. On Mar 4, 2004, at 10:17 PM, Jim Cimino wrote: > > Lower your idle. > Jim > > ----- Original Message ----- > From: "Jason Sneed" <n242ds(at)cox.net> > To: > Subject: RV-List: Help me stop my engine > > >> >> For the last 2 months I have had a problem I can not figure out and >> wanted to see if anyone has a direction to point me. I have a 6 with a >> o-360 with the airflow performance fuel injection system. When I >> shutdown, the engine is dieseling really bad. I did not know the term >> dieseling but it basically means the engine will not shutdown fuel >> gets >> ignited somehow and keeps turning the engine over. I pull the mixture >> to idle cut off and then hit the electronic ignition and the mag and >> the master. I do all this with about 1000 rpm. Before this started >> happening I could shutdown any way I wanted with no problem. The only >> way to get the prop to stop spinning and vibrating the heck out of the >> airplane is to shove the mixture to full rich while everything else is >> off and the engine is just dieseling. Not only is this causing damage >> (exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) >> all the top plugs, this made no difference. Has anyone had this >> happen? What should I do next? I am suspect of the mixture control but >> last time I checked the control was hitting the stop. The only thing I >> did right before this happened was add avblend to the oil (I know that >> should have nothing to do with the problem). The oil has been changed >> since the avblend and I still have the problem. >> >> Any ideas to help my RV not come off as a clunker on the flight line? >> >> >> Jason Sneed >> Commercial Lending Officer >> First National Bank and Trust >> http://www.highland-parks.com/n242ds/index.html >> >> > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > Jason Sneed Commercial Lending Officer First National Bank and Trust ________________________________________________________________________________
Date: Mar 05, 2004
Jason Sneed wrote: > >For the last 2 months I have had a problem I can not figure out and >wanted to see if anyone has a direction to point me. I have a 6 with a >o-360 with the airflow performance fuel injection system. When I >shutdown, the engine is dieseling really bad. I did not know the term >dieseling but it basically means the engine will not shutdown fuel gets >ignited somehow and keeps turning the engine over. I pull the mixture >to idle cut off and then hit the electronic ignition and the mag and >the master. I do all this with about 1000 rpm. Before this started >happening I could shutdown any way I wanted with no problem. The only >way to get the prop to stop spinning and vibrating the heck out of the >airplane is to shove the mixture to full rich while everything else is >off and the engine is just dieseling. Not only is this causing damage >(exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) >all the top plugs, this made no difference. Has anyone had this >happen? What should I do next? I am suspect of the mixture control but >last time I checked the control was hitting the stop. The only thing I >did right before this happened was add avblend to the oil (I know that >should have nothing to do with the problem). The oil has been changed >since the avblend and I still have the problem. > >Any ideas to help my RV not come off as a clunker on the flight line? > > >Jason Sneed >Commercial Lending Officer >First National Bank and Trust >http://www.highland-parks.com/n242ds/index.html > Well, I suspect that you may have a worn idle cutoff valve, or an intake leak, or both. The intake leak is easier to diagnose. Take a vacuum cleaner that you can attach the hose to the output. Clean the vacuum really good, and stuff the hose in the intake, and seal with a couple of rags. Turn the vacuum on ans spray really soapy water all over the intake system. Bubbles will tell you where the leaks are. 'Course this works much better with the cowl off. If no leaks are found, then you might try putting the throttle a little way in and then moving the mixture to idle cut-off ..... and if it still diesels, open up the throttle. That should create a really lean condition and stop the dieseling. If that doesn't work, then we have the carb. The carb is harder to diagnose and I don't have any good way to test it. The option may be to send it off for a rebuild. Good luck, Linn > > > > ________________________________________________________________________________
Date: Mar 04, 2004
The idle speed is a good answer but here is something else. Do you have a primer? If so, make sure it is locked in the off position and not allowing just enough fuel to pass into a couple of cylinders. It could be locked but still allowing fuel to pass. Might want to check it. Ross Scroggs Locust Grove, Ga. RV4 #3911 Wings ----- Original Message ----- From: "Jason Sneed" <n242ds(at)cox.net> Subject: RV-List: Help me stop my engine > > For the last 2 months I have had a problem I can not figure out and > wanted to see if anyone has a direction to point me. I have a 6 with a > o-360 with the airflow performance fuel injection system. When I > shutdown, the engine is dieseling really bad. I did not know the term > dieseling but it basically means the engine will not shutdown fuel gets > ignited somehow and keeps turning the engine over. I pull the mixture > to idle cut off and then hit the electronic ignition and the mag and > the master. I do all this with about 1000 rpm. Before this started > happening I could shutdown any way I wanted with no problem. The only > way to get the prop to stop spinning and vibrating the heck out of the > airplane is to shove the mixture to full rich while everything else is > off and the engine is just dieseling. Not only is this causing damage > (exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) > all the top plugs, this made no difference. Has anyone had this > happen? What should I do next? I am suspect of the mixture control but > last time I checked the control was hitting the stop. The only thing I > did right before this happened was add avblend to the oil (I know that > should have nothing to do with the problem). The oil has been changed > since the avblend and I still have the problem. > > Any ideas to help my RV not come off as a clunker on the flight line? > > > Jason Sneed > Commercial Lending Officer > First National Bank and Trust > http://www.highland-parks.com/n242ds/index.html > > ________________________________________________________________________________
Date: Mar 04, 2004
Thanks Ross... I have a boost pump that I just turn on until I get 4 GPH on the fuel flow gauge then turn it off and hit the started button. Thanks, Jason On Mar 4, 2004, at 10:59 PM, Ross Scroggs wrote: > > The idle speed is a good answer but here is something else. Do you > have a > primer? > If so, make sure it is locked in the off position and not allowing just > enough fuel to pass > into a couple of cylinders. It could be locked but still allowing > fuel to > pass. Might want > to check it. > > Ross Scroggs > Locust Grove, Ga. > RV4 #3911 Wings > > ----- Original Message ----- > From: "Jason Sneed" <n242ds(at)cox.net> > To: > Subject: RV-List: Help me stop my engine > > >> >> For the last 2 months I have had a problem I can not figure out and >> wanted to see if anyone has a direction to point me. I have a 6 with a >> o-360 with the airflow performance fuel injection system. When I >> shutdown, the engine is dieseling really bad. I did not know the term >> dieseling but it basically means the engine will not shutdown fuel >> gets >> ignited somehow and keeps turning the engine over. I pull the mixture >> to idle cut off and then hit the electronic ignition and the mag and >> the master. I do all this with about 1000 rpm. Before this started >> happening I could shutdown any way I wanted with no problem. The only >> way to get the prop to stop spinning and vibrating the heck out of the >> airplane is to shove the mixture to full rich while everything else is >> off and the engine is just dieseling. Not only is this causing damage >> (exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) >> all the top plugs, this made no difference. Has anyone had this >> happen? What should I do next? I am suspect of the mixture control but >> last time I checked the control was hitting the stop. The only thing I >> did right before this happened was add avblend to the oil (I know that >> should have nothing to do with the problem). The oil has been changed >> since the avblend and I still have the problem. >> >> Any ideas to help my RV not come off as a clunker on the flight line? >> >> >> Jason Sneed >> Commercial Lending Officer >> First National Bank and Trust >> http://www.highland-parks.com/n242ds/index.html >> >> > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > Jason Sneed Commercial Lending Officer First National Bank and Trust ________________________________________________________________________________
Date: Mar 04, 2004
Hi Jason, Not being a fuel injection person I cannot supply precise touble shooting information. However, dieseling can only occur when fuel is allowed to continue to flow into the combustion chambers even though you seemingly have shut it off. This would indicate things such as an internal valve is not sealing as it should, a sticking throttle staying open a bit might allow fuel to flow or as suggested a primming circut could be involved. Have you been watching the EGTs and CHTs for abnormal behavior. If extra fuel is getting through the system throughout the normal engine operation modes it might be promoting excess carbon buildup in the cylinders. This also would be consistant with the kind of running on that you describe. A call to the maker of your injection system is in order. I am inclined to suggest that you should not run this engine again until some serious trouble shooting is done and satisfactory results are achived. In serious cases internal engine damage due to dieseling is also quite possible. Let us know how it works out, good luck, Jin in Kelowna ----- Original Message ----- From: "Jason Sneed" <n242ds(at)cox.net> Subject: RV-List: Help me stop my engine > > For the last 2 months I have had a problem I can not figure out and > wanted to see if anyone has a direction to point me. I have a 6 with a > o-360 with the airflow performance fuel injection system. When I > shutdown, the engine is dieseling really bad. I did not know the term > dieseling but it basically means the engine will not shutdown fuel gets > ignited somehow and keeps turning the engine over. I pull the mixture > to idle cut off and then hit the electronic ignition and the mag and > the master. I do all this with about 1000 rpm. Before this started > happening I could shutdown any way I wanted with no problem. The only > way to get the prop to stop spinning and vibrating the heck out of the > airplane is to shove the mixture to full rich while everything else is > off and the engine is just dieseling. Not only is this causing damage > (exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) > all the top plugs, this made no difference. Has anyone had this > happen? What should I do next? I am suspect of the mixture control but > last time I checked the control was hitting the stop. The only thing I > did right before this happened was add avblend to the oil (I know that > should have nothing to do with the problem). The oil has been changed > since the avblend and I still have the problem. > > Any ideas to help my RV not come off as a clunker on the flight line? > > > Jason Sneed > Commercial Lending Officer > First National Bank and Trust > http://www.highland-parks.com/n242ds/index.html > > ________________________________________________________________________________
Date: Mar 04, 2004
Jason, I want to reiterate what Terry said. Read the AFP manual and you'll see that they even state (I forget where, but it's in there), that pulling the mixture will still allow X fuel flow, and that the purge valve is the way they encourage shutdowns. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Terry Watson" <terry(at)tcwatson.com> Subject: RE: RV-List: Help me stop my engine > > Jason, > > I have heard that this is the biggest reason for installing the purge valve > with an Airflow Performance fuel injection system. For some reason the > mixture apparently doesn't always shut the fuel off enough to stop the > engine. Pulling the purge valve diverts the fuel from the injectors to the > return line and the engine quits. > > Note that this is not from my own experience. I am still at the wiring > stage, but my Superior XP-IO-360-B1B came from Bart with the purge valve > already installed. A call to Airflow Performance ought to get you an > authoritative answer. > > Terry > RV-8A #80729 wiring > > > For the last 2 months I have had a problem I can not figure out and > wanted to see if anyone has a direction to point me. I have a 6 with a > o-360 with the airflow performance fuel injection system. When I > shutdown, the engine is dieseling really bad. I did not know the term > dieseling but it basically means the engine will not shutdown fuel gets > ignited somehow and keeps turning the engine over. I pull the mixture > to idle cut off and then hit the electronic ignition and the mag and > the master. > > ________________________________________________________________________________
Subject: RSA Injection Basics, was (Help me stop my engine) .
Date: Mar 05, 2004
I'll pre-emp this by saying I'm not trying to flame anyone here, I just can't think of the politically correct words to type, and since I'm a "tell it like it is" kind of guy, here you go! OK....Time for a quick lesson on injection....Obviously more than a couple people could use some basics on injection (really, I mean this helpfully, not sarcastically). #1) The RSA/AFP injection systems are pretty simple, not much to go wrong. #2) The RSA/AFP injection system does NOT use a separate primer circuit at all...see #3) #3) The RSA/AFP injection system is a constant flow system, meaning that (hopefully) anytime the mixture is not in ICO, fuel is flowing into the intake ports if either the engine is running or the mixture is not in ICO. Priming is accomplished by moving the mixture to rich, and turning on the boost pump for a specified amount of time (seems different on each persons Lyc), usually 4-8 seconds. These fuel systems run around 20-30psi, instead of 2-4psi for the carb's. #4) The AFP purge valve is usually installed to help starting, NOT stopping a F.I. Lyc. The problem with the RSA type system that has the bare Stainless Steel distribution lines above the cylinder, is that usually after shutdown, the fuel remaining in distribution lines is boiled and ends up in the intake ports, resulting in a "pseudo" flooded engine - more like just an abundance of fuel/vapors. Since a typical FI system has the metered fuel line running from the servo up to the spider on top of the engine routed between cylinders #1 & #3, all of these components contribute to quick heat soaking if fuel is not moving through them. The spider/flow divider has a small ball/check valve installed in them to help with this phenomenon. #5) The thought behind the purge valve is to allow an operator to circulate fresh cool fuel to the flow divider before starting the engine and gettin rid of all the vapor bubbles in the line to that point. At least that's the claim, in real life, I've seen little benefit on heat soaked engine/hot day combinations between my -360 w/o a purge valve and the guys that have them installed. Without electronic ignition, they all can be a bear to start when hot/hot. #6) Using the purge valve to shutoff the engine is not a wise thing, you're just "bandaiding" the real problem, which obviously is with the servo / ICO itself. #7) The Servo uses "blast tubes" to measure the air moving through the servo. These only start working above a normal idle, as at normal idle, the butterfly is almost completely close. Hence the Idle circuit builit into the servo. This is an adjustable circuit which allows the operator to adjust a flow of fuel relative to the throttle being at idle. Like I just said, the idle mixture adjustment is hooked to the throttle, NOT the mixture, so you adjust the fuel flow at idle accordingly. Here's where I would start. Check the adjustment on the idle mixture arm, it's the little square threaded portion with the spring keeper / star shaped wheel in the center of it. Make sure that hasn't either moved a great deal or even come disconnected. Make sure you are still getting a small rise in RPM right before ICO. If not, then it's a prett good indication that the idle mixture is out of adjustment. Either way, I would start with the idle mixture adjustment. This can be done with the engine idling and you can adjust it with the engine running. WARNING -DO NOT DO THIS ALONE, make sure someone is in the cockpit holding the breaks, and WARNING - WATCH THE PROP, always keep one hand holding onto the engine mount. The smart thing to do is basically sit on the wheel with the L/G between your legs to keep yourself from accidentally falling into the prop. This is for a TD, don'e know about a nosewheel airplane. If you're not comfortable working on a running engine, DON'T do it, get someone who is experienced to do it. Too many accidents have happened that way! The fact that you're having problems at slower idle would also point the the above diagnosis. You should easily be able to get these things to lope along at 550-650RPM. When idling, do you get any backfiring, or is the exhaust puffing white or black colored smoke?? Also indicates something amiss with the idle mixture or as mentioned earlier, a possible induction leak, althought an induction lead shouldn't have any bearing on the engine continuing to get fuel after ICO. OK, that's it for my rant. The idle mixture can be a finiky thing when out of adjustment, so I'd start there. If no progress, then something else is wrong. Last thing, check the mixture arm on the servo to make sure it has't moved a notch or something like that - I've seen it happen! The servo's should be good for at least 1500hrs, or engine TBO if taken care of and kept in adjustment. Usually the rubber diaphrams wear out, and the throttle arm bushings wear, but rarely to they just plain quit working. Best of luck, keep us informed! Cheers, Stein Bruch RV6's, Minneapolis (1 injected & 1 carb'd). http://www.steinair.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jason Sneed Subject: RV-List: Help me stop my engine For the last 2 months I have had a problem I can not figure out and wanted to see if anyone has a direction to point me. I have a 6 with a o-360 with the airflow performance fuel injection system. When I shutdown, the engine is dieseling really bad. I did not know the term dieseling but it basically means the engine will not shutdown fuel gets ignited somehow and keeps turning the engine over. I pull the mixture to idle cut off and then hit the electronic ignition and the mag and the master. I do all this with about 1000 rpm. Before this started happening I could shutdown any way I wanted with no problem. The only way to get the prop to stop spinning and vibrating the heck out of the airplane is to shove the mixture to full rich while everything else is off and the engine is just dieseling. Not only is this causing damage (exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) all the top plugs, this made no difference. Has anyone had this happen? What should I do next? I am suspect of the mixture control but last time I checked the control was hitting the stop. The only thing I did right before this happened was add avblend to the oil (I know that should have nothing to do with the problem). The oil has been changed since the avblend and I still have the problem. Any ideas to help my RV not come off as a clunker on the flight line? Jason Sneed Commercial Lending Officer First National Bank and Trust http://www.highland-parks.com/n242ds/index.html ________________________________________________________________________________
Date: Mar 05, 2004
Subject: Re: RSA Injection Basics, was (Help me stop my engine) .
Stein, thanks for FI 101. I know more about the system than I did before. In my post, I read over the FI part. Sorry. As for the induction leak .... it just makes it easier for the small amount of fuel available to get enough air to burn. My question is with the purge valve. Is this a manual valve? If not, how does it distinguish between vapor and liquid??? Linn Stein Bruch wrote: > >I'll pre-emp this by saying I'm not trying to flame anyone here, I just >can't think of the politically correct words to type, and since I'm a "tell >it like it is" kind of guy, here you go! > >OK....Time for a quick lesson on injection....Obviously more than a couple >people could use some basics on injection (really, I mean this helpfully, >not sarcastically). > >#1) The RSA/AFP injection systems are pretty simple, not much to go wrong. > >#2) The RSA/AFP injection system does NOT use a separate primer circuit at >all...see #3) > >#3) The RSA/AFP injection system is a constant flow system, meaning that >(hopefully) anytime the mixture is not in ICO, fuel is flowing into the >intake ports if either the engine is running or the mixture is not in ICO. >Priming is accomplished by moving the mixture to rich, and turning on the >boost pump for a specified amount of time (seems different on each persons >Lyc), usually 4-8 seconds. These fuel systems run around 20-30psi, instead >of 2-4psi for the carb's. > >#4) The AFP purge valve is usually installed to help starting, NOT stopping >a F.I. Lyc. The problem with the RSA type system that has the bare >Stainless Steel distribution lines above the cylinder, is that usually after >shutdown, the fuel remaining in distribution lines is boiled and ends up in >the intake ports, resulting in a "pseudo" flooded engine - more like just an >abundance of fuel/vapors. Since a typical FI system has the metered fuel >line running from the servo up to the spider on top of the engine routed >between cylinders #1 & #3, all of these components contribute to quick heat >soaking if fuel is not moving through them. The spider/flow divider has a >small ball/check valve installed in them to help with this phenomenon. > >#5) The thought behind the purge valve is to allow an operator to circulate >fresh cool fuel to the flow divider before starting the engine and gettin >rid of all the vapor bubbles in the line to that point. At least that's the >claim, in real life, I've seen little benefit on heat soaked engine/hot day >combinations between my -360 w/o a purge valve and the guys that have them >installed. Without electronic ignition, they all can be a bear to start >when hot/hot. > >#6) Using the purge valve to shutoff the engine is not a wise thing, you're >just "bandaiding" the real problem, which obviously is with the servo / ICO >itself. > >#7) The Servo uses "blast tubes" to measure the air moving through the >servo. These only start working above a normal idle, as at normal idle, the >butterfly is almost completely close. Hence the Idle circuit builit into >the servo. This is an adjustable circuit which allows the operator to adjust >a flow of fuel relative to the throttle being at idle. Like I just said, >the idle mixture adjustment is hooked to the throttle, NOT the mixture, so >you adjust the fuel flow at idle accordingly. > >Here's where I would start. Check the adjustment on the idle mixture arm, >it's the little square threaded portion with the spring keeper / star shaped >wheel in the center of it. Make sure that hasn't either moved a great deal >or even come disconnected. Make sure you are still getting a small rise in >RPM right before ICO. If not, then it's a prett good indication that the >idle mixture is out of adjustment. > >Either way, I would start with the idle mixture adjustment. This can be >done with the engine idling and you can adjust it with the engine running. >WARNING -DO NOT DO THIS ALONE, make sure someone is in the cockpit holding >the breaks, and WARNING - WATCH THE PROP, always keep one hand holding onto >the engine mount. The smart thing to do is basically sit on the wheel with >the L/G between your legs to keep yourself from accidentally falling into >the prop. This is for a TD, don'e know about a nosewheel airplane. If >you're not comfortable working on a running engine, DON'T do it, get someone >who is experienced to do it. Too many accidents have happened that way! > >The fact that you're having problems at slower idle would also point the the >above diagnosis. You should easily be able to get these things to lope >along at 550-650RPM. > >When idling, do you get any backfiring, or is the exhaust puffing white or >black colored smoke?? Also indicates something amiss with the idle mixture >or as mentioned earlier, a possible induction leak, althought an induction >lead shouldn't have any bearing on the engine continuing to get fuel after >ICO. > >OK, that's it for my rant. The idle mixture can be a finiky thing when out >of adjustment, so I'd start there. If no progress, then something else is >wrong. Last thing, check the mixture arm on the servo to make sure it has't >moved a notch or something like that - I've seen it happen! The servo's >should be good for at least 1500hrs, or engine TBO if taken care of and kept >in adjustment. Usually the rubber diaphrams wear out, and the throttle arm >bushings wear, but rarely to they just plain quit working. > >Best of luck, keep us informed! > >Cheers, >Stein Bruch >RV6's, Minneapolis (1 injected & 1 carb'd). > >http://www.steinair.com > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jason Sneed >To: rv-list(at)matronics.com >Subject: RV-List: Help me stop my engine > > >For the last 2 months I have had a problem I can not figure out and >wanted to see if anyone has a direction to point me. I have a 6 with a >o-360 with the airflow performance fuel injection system. When I >shutdown, the engine is dieseling really bad. I did not know the term >dieseling but it basically means the engine will not shutdown fuel gets >ignited somehow and keeps turning the engine over. I pull the mixture >to idle cut off and then hit the electronic ignition and the mag and >the master. I do all this with about 1000 rpm. Before this started >happening I could shutdown any way I wanted with no problem. The only >way to get the prop to stop spinning and vibrating the heck out of the >airplane is to shove the mixture to full rich while everything else is >off and the engine is just dieseling. Not only is this causing damage >(exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) >all the top plugs, this made no difference. Has anyone had this >happen? What should I do next? I am suspect of the mixture control but >last time I checked the control was hitting the stop. The only thing I >did right before this happened was add avblend to the oil (I know that >should have nothing to do with the problem). The oil has been changed >since the avblend and I still have the problem. > >Any ideas to help my RV not come off as a clunker on the flight line? > > >Jason Sneed >Commercial Lending Officer >First National Bank and Trust >http://www.highland-parks.com/n242ds/index.html > > > > ________________________________________________________________________________
Subject: New Grand Rapids 4000 EIS for sale
Date: Mar 05, 2004
Never installed 4000 for sale. Save over $100. I ordered this unit thinking I would be ready to fly before Tracy Crook at RWS had his EIS ready for market for my 9A rotary. He held to schedule but I didn't :>( His unit is disigned with the rotary in mind so I would rather use it now. Call for details, I will pay for shipping Bernie Kerr 772 466 6701 ________________________________________________________________________________
Subject: Navaid Autopilot Operation
Date: Mar 05, 2004
For those of you who have the Navaid autopilot, read on. The rest of you can ignore this note. After flying my Velocity for a year, I decided to try to improve the operation of my Navaid autopilot. (Sorry, but I follow the RV list since there are 10 times more RV's than Velocities - you use the same engines and avionics as Velocities - thanks for the great answers and information!!!!) The Navaid has been working great in wing leveler mode - but I haven't been real happy with they way it tracked the GPS signals via the Porcine coupler. (I had already had the Porcine chip replaced because they had problems with the aviation data stream that comes out of panel mounted GPS's) I finally figured it out (after reading the manual again - for the 10th time!) I had "jinked" the servo for the correct trim position. The Navaid's left hand knob is used to trim the plane for level flight, the right hand knob is used to make turns. I repeat "left hand knob is used to trim the plane for level flight, the right hand knob is used to make turns." If you are trying to fly straight and level, DO NOT USE the right hand knob - use the trim knob!!! (This is a duh-huh, but if you didn't understand this subtelty, it makes a huge difference!) When putting the Navaid in track mode - make sure the right hand knob is straight up. The trim knob is in what ever position is required to maintain straight ahead flight. Then after engaging track mode, use the trim knob to put the plane on course if the Navaid is not tracking the course as desired. This last sentence is critically important to getting good tracking performance. I used to cuss the Navaid because it didn't seem to be holding the correct track. If you use the trim knob to establish the plane on track, it tracks PERFECTLY!!!! A HAPPY NAVAID USER! Ronnie Brown ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Mar 05, 2004
> > For the last 2 months I have had a problem I can not figure out and > wanted to see if anyone has a direction to point me. I have a > 6 with a > o-360 with the airflow performance fuel injection system. When I > shutdown, the engine is dieseling really bad. I did not know the term > dieseling but it basically means the engine will not shutdown > fuel gets > ignited somehow and keeps turning the engine over. I pull the mixture > to idle cut off and then hit the electronic ignition and the mag and > the master. I do all this with about 1000 rpm. Before this started > happening I could shutdown any way I wanted with no problem. The only > way to get the prop to stop spinning and vibrating the heck > out of the > airplane is to shove the mixture to full rich while > everything else is > off and the engine is just dieseling. Not only is this causing damage > (exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) > all the top plugs, this made no difference. Has anyone had this > happen? What should I do next? I am suspect of the mixture > control but > last time I checked the control was hitting the stop. The > only thing I > did right before this happened was add avblend to the oil (I > know that > should have nothing to do with the problem). The oil has been changed > since the avblend and I still have the problem. > > Any ideas to help my RV not come off as a clunker on the flight line? > Something is likely wrong with the idle mixture. The idle mixture should be adjusted exactly per the AFP manual, it is spelled out in great detail there. You are correct in wondering what has changed, though. What happens if you run it at 1500 rpm, and pull the mixture out? Is the idle mixture linkage tight? Maybe it worked loose, and went rich. Alex Peterson Maple Grove, MN RV6-A N66AP 443 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Mar 05, 2004
Jason Sneed wrote: > >For the last 2 months I have had a problem I can not figure out and >wanted to see if anyone has a direction to point me. I have a 6 with a >o-360 with the airflow performance fuel injection system. When I >shutdown, the engine is dieseling really bad. I did not know the term >dieseling but it basically means the engine will not shutdown fuel gets >ignited somehow and keeps turning the engine over. I pull the mixture >to idle cut off and then hit the electronic ignition and the mag and >the master. I do all this with about 1000 rpm. Before this started >happening I could shutdown any way I wanted with no problem. > >Jason Sneed >Commercial Lending Officer >First National Bank and Trust >http://www.highland-parks.com/n242ds/index.html > True "dieseling", as I understand it, is caused by at least by at least one 'hotspot' in a combustion chamber. Sounds to me like something in the combustion chamber is acting like a glowplug. Rid yourself of that source and you may once again be a happy camper. I suggest reading the spark plugs for abnormalities and for carbon buildup. Also, check the the plugs for thin sharp edges while you're at it. Anybody got a borescope? Good luck. Bob ________________________________________________________________________________
Date: Mar 05, 2004
> > AFP recommends turning off the engine by activating the fuel > bypass valve. Pulling the mixture all the way back still > allows enough fuel to barely keep the engine running. I tried > killing the engine this way once, it was painful. This should not be - with AFP the engine should stop when at idle with the mixture pulled completely to ICO. Their instructions are very clear about how to adjust the idle mixture. If it doesn't quit when the mixture is pulled at idle, you are probably idling way too rich. Alex Peterson Maple Grove, MN RV6-A N66AP 443 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: Re: shut-down procedure
Date: Mar 05, 2004
This is what my airflow manual says to do but it does not work for me. When the engine is dieseling I even tried going to full throttle and it just keeps sputtering. Oddly enough if at the very end of shutdown and when the engine just starts to diesel I go full rich on the mixture the engine stops which makes NO sense to me. Thanks for all the help and suggestions! Jason On Mar 5, 2004, at 8:19 AM, Mlfred(at)aol.com wrote: > Hey Jason: > > I found a work-around for this run-on problem: > When you pull the mix to ICO, push the throttle about 1/2 open and the > thing will quit cleanly. Works every time for me...credit the old > round engine guys for this one... > > Stein had some other very good comments. > > cheers > Mark > Team Rocket > > Any ideas to help my RV not come off as a clunker on the flight line? > > > Jason Sneed > Commercial Lending Officer > First National Bank and Trust > http://www.highland-parks.com/n242ds/index.html > Jason Sneed Commercial Lending Officer First National Bank and Trust ________________________________________________________________________________
Date: Mar 05, 2004
Jason Sneed wrote: > >This is what my airflow manual says to do but it does not work for me. >When the engine is dieseling I even tried going to full throttle and >it just keeps sputtering. Oddly enough if at the very end of shutdown >and when the engine just starts to diesel I go full rich on the mixture >the engine stops which makes NO sense to me. > >Thanks for all the help and suggestions! > >Jason > ========================================= Makes sense to me, if you have a combustion chamber hot spot. The raw fuel snuffs the hotspot, just like pouring water on a fire. Pull your plugs. See if you have a ton of soot. If so, the engine has been running far too rich in some mode. P.S. If I'm wrong, never mind. Bob ________________________________________________________________________________
Subject: Fwd: help me stop my engine
Date: Mar 05, 2004
Begin forwarded message: > From: Mahlon_Russell(at)teledyne.com > Date: March 5, 2004 9:06:44 AM CST > To: n242ds(at)cox.net > Subject: help me stop my engine > > > Jason, I tried to post this to the list but I am not a member so it > didn't > go through..too bad I think it could be helpful to others. I monitor > the > list from the web and don't subscribe because I can't get any more > email > the I already get..just too much to deal with. so anyway I hope this > helps > you out! you might forward it to the list if you think it would help > others. > Jason, > From the description of your situation I think you might have two > problems. > For what is happening to your engine, you need to have a fuel supply > and a > ignition supply. It can not run-on or diesel without ignition and > fuel. So > it sounds to me like you have 1.) an ignition source you shouldn't > have and > also 2.) a fuel source you shouldn't have. Two independent systems and > two > different troubleshooting scenarios. > The way I would troubleshoot the problem is as follows: > Lets look at the fuel situation first. > The mixture control on the AFP fuel servo is not the Idle cut off > device, > if you have a purge valve. The idle cut off device is the purge/idle > cutoff > valve. To trouble shoot if it is working correctly, Place the mixture > control valve in full lean and the purge/Idle cutoff valve in idle > cutoff. > Disconnect the fuel injection lines at the fuel nozzles. Turn the boost > pump on and observe if there is fuel coming out any of the lines where > you > disconnected them from the nozzles. There should be no observable flow > at > the lines, an occasional drip is ok, but no flow allowed. If there is > flow, > you need to get the flow divider and purge/idle cutoff assembly > checked out > and or reworked. If there isn't any flow another way you can get fuel > into > the engine while you are trying to shut it off, is through a fuel > injection > nozzle that has a blocked air bleed or has a cracked line supplying it > fuel. The nozzles are vented and when you close the Idle cut-off valve > you > put a stop to fuel flow. The natural sucking action of the intake > system is > exposed to the outlet of the fuel nozzles in each intake port. The > vents in > the nozzles relive that suction, and no fuel is drawn from the lines, > into > the intake ports, to keep the engine running. If one of the vents is > restricted it will allow this suction to pull fuel out of the other > lines > and will keep the engine running. Likewise, a cracked line will allow > the > fuel to be drawn in, as it acts a relieve to the Idle cut-off valve. > It's > like putting a straw into a glass of soda. Put your finger on the end > of > the straw and you can lift the straw out of the soda and the soda will > stay > in the straw until you lift your finger and then the soda pours out of > the > straw. The crack in the line is acting like lifting your finger off > the end > of the straw. To check the nozzles for the clogged vent condition, > remove > them and blow into them with your mouth, while holding a finger over > the > outlet hole. You will then be blowing air into the nozzle and out the > vent. > If the vent is restricted or plugged you will be able to tell. To > check for > cracked line, do a visual inspection..common place for problems is > where > the ball end is silver soldered onto the line. Another place the > engine > can get fuel from is from an internal leak inside the servo. To check > this > remove the line that feeds the flow divider and plug it on the fuel > servo > side. Now turn the boost pump on for a minute or two. With the pump on > observe the impact tubes( small tubes pointing into the air flow) at > the > mouth of the servo. They should not have fuel coming out of them. If > they > do you need to get the servo serviced as the servo is acting like a > carburetor and supplying the fuel to keep the engine running. Lastly > if you > have the overboard drain from the engine driven fuel pump teed into the > intake manifold drain, the fuel pump could be leaking and supplying > fuel to > the intake system though the drain network. If you have the fuel pump > drain > "teed in" disconnect from the drain network temporarily, and see if the > engine shuts down OK. If it does, you need a new fuel pump. I assume > that > you don't have manual primmer system, if you do, disconnect it, to make > sure it isn't the source of the fuel. Other than these things there is > no > other way, that I know of, for fuel to get into the engine, so I think > it > must be one of these that is supplying the fuel for the engine to be > able > to run on. > Fixing the fuel situation will make the engine shut off but it won't > fix > problem 2.) which is how that fuel getting lit off with no ignition > source? > First thing we need to do is make sure the ignition systems are off > when we > think they are. To do this with the engine running, first turn off the > electronic ignition system and master switch then momentarily turn the > mag > off. When doing this you need to be quick, on the mag switch, as > letting > the engine run down for more that a second or so with the ignition > turned > off and than turning the ignition back on, can light off un-burnt fuel > that > has collected in the exhaust system and cause a rather loud backfire, > as > well as, possible exhaust system damage. The engine should quit if we > are > killing the ignition. If it doesn't we need to figure out which system > is > still on. To do this, I would disconnect the sparkplug leads for the > electronic system, start the engine on the mag, and then shut off the > mag, > if the engine continues to run, you have mag or mag switch issues, if > it > doesn't, I would reverse the situation and start on the electronic > system > and then shut it off. If the engine doesn't quit, you have electronic > ignition or wiring issues with it. Either of these situations are bad > as we > have a engine that can inadvertently start with prop movement, because > one > of the ignition systems is actually on, when we think it is off. Be > very > careful moving the prop on this engine, until you are sure that that > is a > safe practice!! If the engine does not quit, using either trouble > shooting > scenario, then we have a hot spot in the cylinders, that is acting > like a > glow plug, that was igniting the fuel, This is a bad thing that can > have > some potential catastrophic results for the engine, as it can cause > pre-ignition and eventually detonation. There is no easy way to > troubleshoot this but it is normally caused by an ignition system that > is > out of whack and not timed correctly or some really bad quality fuel. > If > you ran the engine using only one of the ignition systems, the > offending > one should be able to be discovered, in that the engine shouldn't > develop > the hot spot if the bad ignition source hasn't been turned on and used. > Therefore after a run with only one ignition system used and if it > shuts > down OK it should point the finger at the other system. That or a > complete > ignition systems tune up is in order. If you are using av-gas fuel > shouldn't be an issue. If you are using MoGas try some av-gas for a > while. > If you remove the fuel source and the ignition source you will have a > correctly configured system and an engine that will shut down. If you > only > fix the fuel system or the offending ignition system you will have an > engine that will shut down but still isn't configured the way it > should be. > If it's the fuel that's an issue you are lucky that the only problem > you > have is it won't shut off! > Hope this helps. > Good Luck, > Mahlon > > Jason Sneed Commercial Lending Officer First National Bank and Trust ________________________________________________________________________________
Date: Mar 05, 2004
> > Sputters if I shutdown at 600 rpm or 1300 rpm. Top plugs were pretty > clean, have not had time to pull the bottom yet. I have been told the > electronic ignition plugs are usually cleaner but I do not know that > from experience. > > Thanks! On Mar 5, 2004, at 8:48 AM, Alex Peterson wrote: > > >> >> AFP recommends turning off the engine by activating the fuel >> bypass valve. Pulling the mixture all the way back still >> allows enough fuel to barely keep the engine running. I tried >> killing the engine this way once, it was painful. > > This should not be - with AFP the engine should stop when at idle with > the mixture pulled completely to ICO. Their instructions are very > clear > about how to adjust the idle mixture. If it doesn't quit when the > mixture is pulled at idle, you are probably idling way too rich. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 443 hours > > http://www.home.earthlink.net/~alexpeterson/ > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > Jason Sneed Commercial Lending Officer First National Bank and Trust ________________________________________________________________________________
From: "Ross Schlotthauer" <rv7maker(at)hotmail.com>
Subject: Help me stop my engine
Date: Mar 05, 2004
John, Call airflow performance. They are very familiar with this problem and as I understand it, it is the biggest weakness in the AFP system. Ross Schlotthauer RV-7 >From: Jason Sneed <n242ds(at)cox.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Help me stop my engine >Date: Thu, 4 Mar 2004 21:58:34 -0600 > > >For the last 2 months I have had a problem I can not figure out and >wanted to see if anyone has a direction to point me. I have a 6 with a >o-360 with the airflow performance fuel injection system. When I >shutdown, the engine is dieseling really bad. I did not know the term >dieseling but it basically means the engine will not shutdown fuel gets >ignited somehow and keeps turning the engine over. I pull the mixture >to idle cut off and then hit the electronic ignition and the mag and >the master. I do all this with about 1000 rpm. Before this started >happening I could shutdown any way I wanted with no problem. The only >way to get the prop to stop spinning and vibrating the heck out of the >airplane is to shove the mixture to full rich while everything else is >off and the engine is just dieseling. Not only is this causing damage >(exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) >all the top plugs, this made no difference. Has anyone had this >happen? What should I do next? I am suspect of the mixture control but >last time I checked the control was hitting the stop. The only thing I >did right before this happened was add avblend to the oil (I know that >should have nothing to do with the problem). The oil has been changed >since the avblend and I still have the problem. > >Any ideas to help my RV not come off as a clunker on the flight line? > > >Jason Sneed >Commercial Lending Officer >First National Bank and Trust >http://www.highland-parks.com/n242ds/index.html > > Get business advice and resources to improve your work life, from bCentral. ________________________________________________________________________________
Date: Mar 05, 2004
Jason, Don't want beat a dead horse here but the purge valve WILL solve both the shut down hot start problems. I put up with difficult starting and stopping for 2 years before I installed one and I wouldn't even consider not having one on an AFP system. Dave Jason Sneed wrote: > >This is what my airflow manual says to do but it does not work for me. >When the engine is dieseling I even tried going to full throttle and >it just keeps sputtering. Oddly enough if at the very end of shutdown >and when the engine just starts to diesel I go full rich on the mixture >the engine stops which makes NO sense to me. > >Thanks for all the help and suggestions! > >Jason > > >On Mar 5, 2004, at 8:19 AM, Mlfred(at)aol.com wrote: > > > >>Hey Jason: >> >>I found a work-around for this run-on problem: >>When you pull the mix to ICO, push the throttle about 1/2 open and the >>thing will quit cleanly. Works every time for me...credit the old >>round engine guys for this one... >> >>Stein had some other very good comments. >> >>cheers >>Mark >>Team Rocket >> >>Any ideas to help my RV not come off as a clunker on the flight line? >> >> >>Jason Sneed >>Commercial Lending Officer >>First National Bank and Trust >>http://www.highland-parks.com/n242ds/index.html >> >> >> > > >Jason Sneed >Commercial Lending Officer >First National Bank and Trust > > > > ________________________________________________________________________________
Subject: Alternators - Reliability, Preventive Replacement
Date: Mar 05, 2004
Now we're getting into a topic that interests me. Alternator reliability and preventive replacement. Knowing I can purchase an alternator for $38 to $18 is good. What I don't know is what's the typical lifespan for these pieces of equipment when used in an aircraft and turning faster than typical automotive applications. As far as a failure mode, I worry about shaft bearings. They're a pretty high rpm component, with questionable sealed lubrication and questionable cooling (got external cooling, but who knows just how adequate it really is). Even though it has almost 4 yrs and 600 hrs of trouble free operation, I'm considering replacing mine on a *preventive* basis Spending $40 now to replace a 75% "used" alternator is much better than the thing locking up, burning up the drive belt and possibly damaging something nearby. Not to mention the pain in the a## of it happening away from home and either having to fix it or fly home on battery alone. Any thoughts on preventive replacement? Who's had Van's alternator failures? Why did it fail? How many hours was it used? Did you have cooling? Lots of questions, but even a few answered will help us all (me!) make better decisions. Bryan Jones -8 www.LoneStarSquadron.com Houston, Texas >One person's experiences with an alternator is not a definitive study. >What >ever experience that person has is 100% for him and him alone. It may or >may >not be a generalized condition. It may be that one case in 1000s that >sometimes happens. If it is a failure then every thing is o.k. but if it >is >the one case of success, then we have big problems. Reiterating one's >opinion doesn't change the overall failure rate. Remember most of us are >Amateur Builders. Of course, we have strong opinions, but they aren't >necessarily the silent majorities nor statistically significant. They can >be >used for guidance. ________________________________________________________________________________
Date: Mar 05, 2004
Subject: Re: Carbon panel
> >I would simply use a layer of 6 oz glass then a layer of 5.9 oz carbon fiber >cloth. The carbon is there to give the look the glass is there to save you >money. You could do this as a flat panel then cut it to the instrument panel >or you could use the panel as your plate. > >Carbon and glass is available from www.CSTsales.com This is where I buy >supplies for my model lay-ups. They also have vacuum bagging video. I like these folks. They are very helpful and also have some nifty "how-to" videos. http://www.fibreglast.com/ They are a bit pricey, however. I would suggest that you do the lay-up with a combination of carbon fiber and Kevlar. The carbon fiber has poor impact resistance and cracks rather easily. Backing the carbon layer(s) with a Kevlar layer greatly enhances the impact resistance and arrests cracks even before they become apparent. Where you can afford the thickness, it would be wise to add a thin sheet of foam, balsa, or honeycomb into the lay-up. 1/4" or 1/8" of any of these materials in the middle of the lay-up is all it will take. This will make the panel MUCH stronger. You could use a glass plate for a form, but I much prefer Formica. With just a little wax, it releases very easily and leaves a very nice surface finish. You can also drill it, cut it, glue it, and bend it into simple curved shapes. Drilling and gluing allow you to easily secure mold "plugs" for instrument recesses, switch recesses, vents, etc. You can also drill a hole or two, (then carefully fill with bee's wax,) so you can blow the part loose with compressed air when it has cured. ________________________________________________________________________________
From: "Kevin Warren" <kevin.m.warren(at)vanderbilt.edu>
Subject: Safety Question
Date: Mar 05, 2004
Has anyone read any NTSB reports of RVs doing an endo (flipping upside-down) in rough field landing or the like? I was trying to envision an emergency egress strategy in the event such a thing happened, especially if fuel were leaking. Thanks, Kevin ________________________________________________________________________________
Date: Mar 05, 2004
Has anyone read any NTSB reports of RVs flipping upside-down in rough field landing or the like? I was trying to envision an emergency egress strategy in the event such a thing happened, especially if fuel were leaking. Thanks, Kevin ________________________________________________________________________________
Date: Mar 05, 2004
I would not recommend Kevlar for this application because at some point you are going to have to sand the edges to conform to the panel. Kevlar will "fuzz" with no method to recover. Good points on sandwiching things for added depth. Darwin N. Barrie Chandler AZ ----- Original Message ----- From: "Bill Dube" <bdube(at)al.noaa.gov> Subject: Re: RV-List: Carbon panel > > > > > >I would simply use a layer of 6 oz glass then a layer of 5.9 oz carbon fiber > >cloth. The carbon is there to give the look the glass is there to save you > >money. You could do this as a flat panel then cut it to the instrument panel > >or you could use the panel as your plate. > > > >Carbon and glass is available from www.CSTsales.com This is where I buy > >supplies for my model lay-ups. They also have vacuum bagging video. > > I like these folks. They are very helpful and also have some nifty > "how-to" videos. http://www.fibreglast.com/ > > They are a bit pricey, however. > > I would suggest that you do the lay-up with a combination of > carbon fiber and Kevlar. The carbon fiber has poor impact resistance and > cracks rather easily. Backing the carbon layer(s) with a Kevlar layer > greatly enhances the impact resistance and arrests cracks even before they > become apparent. > > Where you can afford the thickness, it would be wise to add a thin > sheet of foam, balsa, or honeycomb into the lay-up. 1/4" or 1/8" of any of > these materials in the middle of the lay-up is all it will take. This will > make the panel MUCH stronger. > > You could use a glass plate for a form, but I much prefer Formica. > With just a little wax, it releases very easily and leaves a very nice > surface finish. You can also drill it, cut it, glue it, and bend it into > simple curved shapes. Drilling and gluing allow you to easily secure mold > "plugs" for instrument recesses, switch recesses, vents, etc. You can also > drill a hole or two, (then carefully fill with bee's wax,) so you can blow > the part loose with compressed air when it has cured. > > ________________________________________________________________________________
Date: Mar 05, 2004
Bill Dube wrote: > I would suggest that you do the lay-up with a combination of > carbon fiber and Kevlar. The carbon fiber has poor impact resistance and > cracks rather easily. Backing the carbon layer(s) with a Kevlar layer > greatly enhances the impact resistance and arrests cracks even before they > become apparent. Dana and I are still in the development stage on the carbon fiber panel so the jury is still out - but we have a pretty good idea of where we are going to end up. We are more interrested in having the look of a carbon fiber panel than we are in the structural and/or weight advantages. We decided early on that Kevlar probably wasn't going to be in the final solution. More because it is simply a pain to work with than anything else. I just don't know how to make all of the instrument cut outs, holes and trim the final edges. Kevlar is so tough that it resists cutting. On an instrument panel, you would have little "frizzies" where ever you had to cut through it. And, you can't sand them away, they just get worse the more you try to sand them. ________________________________________________________________________________
From: "Kyle Boatright" <kyle.boatright(at)adelphia.net>
Subject: Cylinder Blocker
Date: Mar 05, 2004
One thing I'm planning to do during this year's condition inspection is add a cylinder blocker in front of the #1 cylinder, which (hopefully) will reduce the 40 or so degree CHT difference between #3 and the rest of the cylinders. There is plenty in the archives on the effectiveness of this technique, but I can't find a picture or any specifics on how tall to make the blocker in front of the head vs in front of the barrel of the cylinder. I'd sure appreciate some dimensions and/or a picture to use as a go-by or at least to give me a good starting point. Thanks in advance, Kyle Boatright ________________________________________________________________________________
Date: Mar 05, 2004
I coundn't do that again if I tried. Just imagine a cup of coffee on the desk, notebook computer in your lap and the phone rings. When the incident was all through playing out, the coffee was covering the desk, phone was in hand and the unfinished e-mail reply was sent. Oh well. Here is how I was going to finish my last post: Bill Dube wrote: > > I would suggest that you do the lay-up with a combination of > carbon fiber and Kevlar. The carbon fiber has poor impact resistance and > cracks rather easily. Backing the carbon layer(s) with a Kevlar layer > greatly enhances the impact resistance and arrests cracks even before they > become apparent. > > Where you can afford the thickness, it would be wise to add a thin > sheet of foam, balsa, or honeycomb into the lay-up. 1/4" or 1/8" of any of > these materials in the middle of the lay-up is all it will take. This will > make the panel MUCH stronger Dana and I are still in the development stage on the carbon fiber panel so the jury is still out - but we have a pretty good idea of where we are going to end up. We are more interrested in having the look of a carbon fiber panel than we are in the structural and/or weight advantages we might gain from the composites. We decided early on that Kevlar probably wasn't going to be in the final solution. More because it is simply a pain to work with than anything else. I just don't know how to make all of the instrument cut outs, holes and trim the final edges. Kevlar is so tough that it resists cutting. On an instrument panel, you would have little "frizzies" where ever you had to cut through it. And, you can't sand them away, they just get worse the more you try to sand them. I do like the idea of using the Rutan sandwich construction techniques to strengthen the panel. We will probably do that around the radio stack but not anywhere else. The main reason is, we are going to use this panel on three RV-7's that are under construction. As is usually the case, no two panels are alike. Making all of the panels the same, without the internal core material, we can make instrument cutouts where ever we want. I have had good experiences buying carbon from http://www.discountcomposite.com/ infact, this is where the carbon we are using came from. Stay tuned. As in every development project, everything is subject to change :-) Steve Eberhart RV-7A - still working on wings and now the panel as well ________________________________________________________________________________
Date: Mar 05, 2004
I've seen pictures of various tools kept in the cockpit for breaking the plexi - The question should have been more specific and I guess it's pretty much been answered... is there enough room to squeeze out? It appears that for the average person at least, there is. Thanks! Kevin ________________________________________________________________________________
Date: Mar 05, 2004
Subject: Exhaust Bracket Failure
Subject: RV-List: Exhaust Bracket Failure Looks like the exhaust hanging hardware on my airplane needs to be changed every 100 hours or so.=A0 sounds like you might have a problem with vibration. until you get it solved, you will continually be replacing stuff like this. investing in a dynamic balance might be easily worth it -not to mention the increased comfort. -scott ________________________________________________________________________________
Date: Mar 05, 2004
Subject: Re: iPAQ Pilot Log...
Bill VonDane wrote: > > Anyone know of a good, free, pilot logbook for the iPAQ? By far the most flexible, is Pocket Excel, which comes with the iPaq. Set up whatever columns you want, and track them. I looked for ages for a better (and free) program, and never found one. There's one that's quite good called DS Pilot Log, it was the best of the dedicated programs that I could find, and it was reasonably economical ($20, I think). It looks like the interface has changed since I last used it, it's up to version 2.0 now. But i've since switched back to Palm, the iPaq's inability to interface with anything but a Windows PC started to become an issue (I run Linux at home). My Tungsten T3 is smaller, lighter, faster, and syncs to all of my computers. -Rob ________________________________________________________________________________
Subject: Re: alternator cooling
Date: Mar 05, 2004
> > Jim in Kelowna > > From: "LarryRobertHelming" <lhelming(at)sigecom.net> > Subject: Re: RV-List: alternator cooling > > > > > > With using a blast air tube for cooling the alternator, is there any > concern > > about flying into rain and having rain water coming through the tube onto > > the back of the alternator? > > > > Indiana Larry, RV7 Tip-up TMX-O-360 ACS2002 Dynon CNS430 Digitrak JeffRose > > Firewall Forward > Just a comment on alternators. I too had problems with Van's Honda alternator in my previously RV-4. Bought another from Vans. The new owner just reported to me that it has conked out again. I installed a B&C 40 amp alternator in my new RV-4. B&C tells me they have sold thousands and almost no reported failures. They are a well engineered unit as you all know. Not cheap, but reliable. Then the question arises, how come, after 10 years of use, the alternator in my 1993 Saturn finally failed. 120,000 plus miles which I figured translated to over 3000 hours of use. Now that's reliability!! Doug Weiler Hudson, WI ________________________________________________________________________________
Date: Mar 05, 2004
Sounds like the Bronco II I got rid of last year. Had it for 14 years, 309,000 miles (no typos there). It was still running on the original engine build AND alternator when I donated it!!! --- Doug Weiler wrote: > Then the question arises, how come, after 10 years > of use, the alternator in > my 1993 Saturn finally failed. 120,000 plus miles > which I figured > translated to over 3000 hours of use. Now that's > reliability!! > > Doug Weiler > Hudson, WI > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > __________________________________ http://search.yahoo.com ________________________________________________________________________________
Date: Mar 05, 2004
Call Vetterman at 605 745 5932. He has a "new" exhaust mounting kit that works. I got it from him for $10. No problems for 105 hours. Gabe A Ferrer RV6 N2GX 105 hours South Florida Email: ferrergm(at)bellsouth.net Cell: 561 758 8894 Night Phone: 561 622 0960 Fax: 561 622 0960 ________________________________________________________________________________
Date: Mar 05, 2004
Subject: Re: alternator maintenance
After 100 K to 150 K miles (1000 hours? given the higher RPM) its pretty normal for alternator brushes to wear out. They can be replaced for about $5 or $6. Its a good investment in preventative maintenance if you have gotten this far with the alternator. Let it go too long and the slip rings will get ruined. Alternators are very easy to work on. Mark the case so you can get it back the same way, not 90 or 120 or 180 degrees out. Most have a hole where you load and hold the brushes with a plastic or wooden stick -- the new brushes sometimes come with the stick. Pull it out after you put the case halves back together. Dan RV-7A (almost done) In a message dated 3/5/04 6:33:00 PM US Eastern Standard Time, skylor4(at)yahoo.com writes: > > > Sounds like the Bronco II I got rid of last year. Had > it for 14 years, 309,000 miles (no typos there). It > was still running on the original engine build AND > alternator when I donated it!!! > > > --- Doug Weiler wrote: > > >Then the question arises, how come, after 10 years > >of use, the alternator in > >my 1993 Saturn finally failed. 120,000 plus miles > >which I figured > >translated to over 3000 hours of use. Now that's > >reliability!! > > > >Doug Weiler > >Hudson, WI > > > ________________________________________________________________________________
Subject: Re: Cylinder Blocker
Date: Mar 05, 2004
Kyle, I also had about a 40 degree difference between cylinders 1 & 3 and fixed it with the blocker as you describe. Here is a picture for reference. http://home.bellsouth.net/p/s/community.dll?ep=87&subpageid=134196&ck You can start with speed tape or something similar until you get the right size, but the size shown will get you pretty close. Pat Hatch RV-4 RV-6 RV-7 QB (Building) Vero Beach, FL ----- Original Message ----- From: "Kyle Boatright" <kyle.boatright(at)adelphia.net> Subject: RV-List: Cylinder Blocker > > One thing I'm planning to do during this year's condition inspection is add a cylinder blocker in front of the #1 cylinder, which (hopefully) will reduce the 40 or so degree CHT difference between #3 and the rest of the cylinders. There is plenty in the archives on the effectiveness of this technique, but I can't find a picture or any specifics on how tall to make the blocker in front of the head vs in front of the barrel of the cylinder. > > I'd sure appreciate some dimensions and/or a picture to use as a go-by or at least to give me a good starting point. > > Thanks in advance, > > Kyle Boatright > > ________________________________________________________________________________
Subject: alternator notes
Date: Mar 05, 2004
Without the battery any changing load device will cause the VR to have a hard time keeping the V stable since a sudden change in load will not be compensated for by the battery at the speed of light and electrons coming out of it. It takes time for the VR to wind up the field's magnetism which is much slower to react. The battery also provides a large stable "sense" reservoir for the VR to sense and adjust its output as needed. by the by, a few technical additions to the below, a DC generator "field" is actually AC, the commutator causes this, but the armature sees it as DC since the phase of the armature and field are aligned for that to happen. Although alternators are "schematically" phased 120degs they are actually wound to have a bunch of three phase events per actual "pulley" revolution. (this is what destroys most student's brains when trying to understand my alternator lessons) But because diodes need a small amount of voltage to switch they don't completely get rid of the AC on top of the DC. Most diode rectifiers have a 4th bridge pair that I think is used to compare V for the internal regulator so it knows when a failure is occuring in a main diode. This is how it knows when to activate the idiot light. But I've never proven this. But I mention it so you don't get worried if you see eight diodes when you are looking for six in the rectifier plate. RE Vans units. I have seen/repaired about ten of these units now, and none of them are the same in regards to their delivered condition. The last one I saw was not rebuilt by any stretch of the imagination, and Vans didn't question paying the bill for it to be fixed properly. It needed a new regulator, a rectifier and a good bath. So the variety of failures you folks have discribed (many years to 35 hours) is no surprise. RE cooling, the denso's cool from either end as the inlets and then out the side outlets. If you want to blast them, blast the back where the rectifier plate is, but blast into the end port, not into one of the side ports. They are mostly rain proof. The only place where water could cause a problem is on the field brushes, and these are ususally somewhat well covered. I wouldn't try driving one underwater though, regardless of the results produced by Mr. Denver's experiments. Even if the brushes do get wet the field only sees an amp or so at most. W From: "Cy Galley" <cgalley(at)QCBC.ORG> Subject: Re: RV-List: Van's alternator - $18 at Pep boys How can you get the battery out of the circuit? It must be there for no other reason than to excite the field. STATOR Surrounding the rotor is another set of coils, three in number, called the stator. The stator is fixed to the shell of the alternator, and does not turn. As the rotor turns within the stator windings, the magnetic field of the rotor sweeps through the stator windings, producing an electrical current in the windings. Because of the rotation of the rotor, an alternating current is produced. As, for example, the north pole of the magnetic field approaches one of the stator windings, there is little coupling taking place, and a weak current is produced, As the rotation continues, the magnetic field moves to the center of the winding, where maximum coupling takes place, and the induced current is at its peak. As the rotation continues to the point that the magnetic field is leaving the stator winding, the induced current is small. By this time, the south pole is approaching the winding, producing a weak current in the opposite direction. As this continues, the current produced in each winding plotted against the angle of rotation of the rotor has the form shown in figure 2. The three stator windings are spaced inside the alternator 120 degrees apart, producing three separate sets, or "phases," of output voltages, spaced 120 degrees apart, as shown in figure 3. OUTPUT DIODES A/C voltage is of little use in a D/C system, such as used in an airplane, so it has to be converted to D/C before it can be used. This conversion to D/C takes place in the "output diodes" and in the "diode trio." Diodes have the property of allowing current to flow in only one direction, while blocking current flow in the other direction. The output diodes consist of six diodes, one pair for each winding. One of the pair is for the negative half cycle, and the other for the positive half cycle. As a result of this diode rectification, the output of the alternator looks as shown in figure 4. Surprisingly enough, the output of the alternator is not a pure D/C as one might expect, but a pulsating D/C. Because there are three windings, each with a positive and a negative half, by the time the voltage is passed through the diodes, there are six pulsations for each rotation of the rotor. This is close enough to D/C for most automotive components. Critical components, such as radios, have their own internal filtering circuits to further smooth out the waveform to a purer D/C. This doesn't look like your quoted 99% to me. ________________________________________________________________________________
Date: Mar 05, 2004
> >I would not recommend Kevlar for this application because at some point you >are going to have to sand the edges to conform to the panel. Kevlar will >"fuzz" with no method to recover. Indeed, you will get fuzz at the edges. It is possible to trim any exposed edges with rubber molding, etc. ________________________________________________________________________________
Date: Mar 05, 2004
> >For those who have not worked with Kevlar.....my opinion of it is it is too >hard to work with, too hard to cut and the edges are totally unacceptable in >our applications. Actually, it can be easy to cut if you buy cheap scissors instead of expensive ones. Look for scissors that have a coarsely-ground cutting edge. $5 or $6 plastic-handle office scissors. The high-quality scissors have a very smooth, finely-ground cutting edge. The Kevlar slides a bit, wads up, and jams in the scissors. The cheap scissors have a rough enough cutting edge to grip the cloth so it doesn't slip and wad up. After a while the coarse edge starts to smooth out and the cheap scissors don't work so well to cut Kevlar. At that point, you can either regrind them with a course wheel, retire them to fiberglass and carbon cutting, or simply throw them away. > Formica, sure you can but I wanted a gloss finish and get >much better results from plate glass. You can get different finishes with >formica. In the picture posted, I used three layers of 5.7 set at 90,45 & >90. On a full carbon panel, I'm thinking some carbon fiber angles made by >laying up on a 3/4 x 3/4 piece of angle alum as reinforcement instead of >using foam as panel space pretty well uses up available area. An 1/8" or 1/16" sheet of balsa in the lay-up should not take up much room and will keep the panel from flexing or "oil canning". The balsa will bond much better to the epoxy and will not cause cracking with temperature changes. ________________________________________________________________________________
Date: Mar 05, 2004
> >Dana and I are still in the development stage on the carbon fiber panel >so the jury is still out - but we have a pretty good idea of where we >are going to end up. We are more interrested in having the look of a >carbon fiber panel than we are in the structural and/or weight >advantages we might gain from the composites. We decided early on that >Kevlar probably wasn't going to be in the final solution. More because >it is simply a pain to work with than anything else. I just don't know >how to make all of the instrument cut outs, holes and trim the final >edges. Kevlar is so tough that it resists cutting. On an instrument >panel, you would have little "frizzies" where ever you had to cut >through it. And, you can't sand them away, they just get worse the more >you try to sand them. This is a fact. You would have to plan the panel so that no cut edges would show. >I do like the idea of using the Rutan sandwich construction techniques >to strengthen the panel. We will probably do that around the radio >stack but not anywhere else. The main reason is, we are going to use >this panel on three RV-7's that are under construction. As is usually >the case, no two panels are alike. Making all of the panels the same, >without the internal core material, we can make instrument cutouts where >ever we want. Mold the holes instead of cutting them. Arrange plastic disks on the flat mold plate where you wanted the round instruments to go. You would machine the disks to provide the exact recess (or hole edge) that you wanted. You could also place rectangles for square instruments. Secure the disks so they don't shift during the lay-up. Wax and smooth the joint between the plate and the each disk so epoxy won't get under them. You bag the front layers (with a peel ply) over this negative mold. Once the first lay-up has cured, pull the peel ply, add the spacer and back lay-up, then bag again. (It might be possible to do it all in one step, once you got the process down, but it could be difficult to get the front layer to come out perfectly.) When you pull the part, you have a perfect recessed hole (or plain hole) for each instrument. Just trim off the flange flash from the back with a cut-off wheel. The small flange around each hole will make the panel much stronger and durable. Recessed holes and cut-outs would look super slick and would also increase the strength of the panel. ________________________________________________________________________________
Date: Mar 05, 2004
Subject: Re: alternator notes
W., The extra 3 diodes in a pack are called the diode trio (at least in GM alternators). Its function is to provide power to the field (rotor). By using the trio, there is isolation from the battery in a car where there is no main relay as in an airplane. In a car the alternator diodes are hot 24/7. The team I was on back in about 1966 (4 of us at Delco Radio in Kokomo, IN plus some in Anderson, IN at Delco Remy) came up with the idea of putting the idiot light between the diode trio (field +) and the switched battery, and found that it detected about 90% of the faults and required no additional circuitry. Some of today's regulators are much more sophisticated at detecting faults, and many regulate off of the trio voltage if the normal voltage sense line gets unhooked thereby preventing a complete runaway. Hope this helps explain the 3 extra diodes. Dan (Retired electrical automotive engineer) RV-7A ( almost done) In a message dated 3/5/04 8:24:46 PM US Eastern Standard Time, wnorth(at)sdccd.cc.ca.us writes: > > Most diode rectifiers have a 4th bridge pair that I think is used to compare > V for the internal regulator so it knows when a failure is occuring in a > main diode. This is how it knows when to activate the idiot light. But I've > never proven this. But I mention it so you don't get worried if you see > eight diodes when you are looking for six in the rectifier plate. > ________________________________________________________________________________
Date: Mar 05, 2004
After rereading my earlier post, you may be referring to different diodes that I was thinking of. Those extra diodes may be zener diodes for transient suppression. They clamp the battery line to about 30 volts or so to protect the electronic equipment in the car (airplane). There is a tradeoff as to what voltage to clamp to because it takes more current to supress 20 volts than 40 volts. Of course we would like to clamp to 16 volts, but that is too hard to do reliably and at a reasonable cost. Dan ________________________________________________________________________________
Subject: Vetterman Crossover for sale
Date: Mar 05, 2004
I have a Vetterman Crossover Exhaust system for parallel valve 0-320's and 0-360's that fits the RV-6,7,8,and 9 including the "A" models that I'm not going to use. It's currently listed at $775 through Van's. I'll let someone have it for $675. It includes the muff and mounting stuff, everything you would get if you ordered it from Van's. I've had it installed on the engine but the engine has never been run so it's as good as new. I also have Van's Gascolator (GAS-5) that I won't be using. $76 from Van's, $60 from me. New, never used. Thanks, Steve Hamer -4 flying -6 finishing s.hamer(at)verizon.net ________________________________________________________________________________
Date: Mar 05, 2004
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net>
Doug Weiler wrote: > Just a comment on alternators. I too had problems with Van's Honda > alternator in my previously RV-4. Bought another from Vans. The new owner > just reported to me that it has conked out again. > > I installed a B&C 40 amp alternator in my new RV-4. B&C tells me they have > sold thousands and almost no reported failures. They are a well engineered > unit as you all know. Not cheap, but reliable. > > Then the question arises, how come, after 10 years of use, the alternator in > my 1993 Saturn finally failed. 120,000 plus miles which I figured > translated to over 3000 hours of use. Now that's reliability!! > > Doug Weiler > Hudson, WI No fault of Van's. but I think he didn't get the rebuild quality that he thought he was getting. Like I said in an earlier post, mine appears to have had the outside glass bead blasted and resold as a re-build when It really wasnt even taken apart. Some guys have had great luck and others havent had as good. The one I got woudlnt have made it past the first run-up. This thread has given some good input though and a lot of good ideas. Phil ________________________________________________________________________________
Date: Mar 06, 2004
Subject: wood props and IFR
Hi all, I'm looking for some advice from more experienced pilots than I. I have a Ted Hendrickson wooden prop on my plane, and I'd like to start training for my instrument rating. I've read that wood props don't like the rain, and get beat up pretty badly. Basically, I'm wondering is a little rain going to really trash the prop, or would it take hours and hours of rain flying to cause damage? The prop has about 1050 hours on it, but was freshly refurbished by Sensenich about 50 hours ago, nice fresh clear coat, looks beautiful. Thanks, -Dj ________________________________________________________________________________
Date: Mar 06, 2004
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Kyle, check my website. Under flying/135hr report. I too had several broken ones. My fix has lasted over 1000 hours since. Mike -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kyle Boatright Subject: RV-List: Exhaust Bracket Failure Looks like the exhaust hanging hardware on my airplane needs to be changed every 100 hours or so. When I pulled the cowl for my condition inspection, I found that one of the angles in the Vetterman exhaust hanging system had failed. That was at about 220 hours. Previously (at about 100 hours in service) I experienced a failure in the previous version of the exhaust hanging system. Has anyone worked out an exhaust hanging system that is reliable over the long term? Tom at Van's indicated that lots of folks have experienced failures in this area over the years, despite numerous revisions in the hardware and attachement of the hangars. Thanks in advance, KB = = = = ________________________________________________________________________________
Date: Mar 06, 2004
The AFP preferred shutdown method is to pull the purge valve. Mike -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jason Sneed Subject: RV-List: Help me stop my engine For the last 2 months I have had a problem I can not figure out and wanted to see if anyone has a direction to point me. I have a 6 with a o-360 with the airflow performance fuel injection system. When I shutdown, the engine is dieseling really bad. I did not know the term dieseling but it basically means the engine will not shutdown fuel gets ignited somehow and keeps turning the engine over. I pull the mixture to idle cut off and then hit the electronic ignition and the mag and the master. I do all this with about 1000 rpm. Before this started happening I could shutdown any way I wanted with no problem. The only way to get the prop to stop spinning and vibrating the heck out of the airplane is to shove the mixture to full rich while everything else is off and the engine is just dieseling. Not only is this causing damage (exhaust breakage) it is dangerous. Tonight I cleaned (sand blasted) all the top plugs, this made no difference. Has anyone had this happen? What should I do next? I am suspect of the mixture control but last time I checked the control was hitting the stop. The only thing I did right before this happened was add avblend to the oil (I know that should have nothing to do with the problem). The oil has been changed since the avblend and I still have the problem. Any ideas to help my RV not come off as a clunker on the flight line? Jason Sneed Commercial Lending Officer First National Bank and Trust http://www.highland-parks.com/n242ds/index.html = = = = ________________________________________________________________________________
Subject: Help me stop my engine....
Date: Mar 06, 2004
Here is a note from Air Flow Performance that I got when thinking about ordering the system without a purge valve. Seems like this could be your problem. Regards Dennis Parker 71041 From: Airflow Performance <mailto:airflow2(at)bellsouth.net> Subject: Re: Fw: Fuel Injection System for IO360 for RV7 See the attached excel files for the special kits with no purge valve. Be a where that the purge valve provides cures to the hot start problems and also provides positive ICO with no fuel bleed off into the engine. You may experience engine run on at shut down, hot start problems, flooding, and fuel dripping out the air intake after shut down with out the purge valve option. This is normal and will not be covered under any warrantee claims. Don Rivera Airflow Performance 111 Airflow Drive Spartanburg, SC 29306 Phone: 864-576-4512 Fax: 864-576-0201 E-Mail: Airflow2(at)bellsouth.net ________________________________________________________________________________
Subject: Re: Wood props and IFR
Date: Mar 06, 2004
Dj, I flew IFR with a wood prop the first two years I had my ticket. To make a long story short, I had to refinish my prop three times in two years. The fact that I slowed the engine to less than 2000 rpm in rain probably saved me from refinishing it more often. I finally broke down and bought a Sensenich metal prop. I've been happy with it so far and the peace of mind you get is priceless. I once informed Indy ATC that I had to slow down because I had a wood prop and I was in heavy rain. The woman responded with " Do you want to declare an emergency" Jim Nolan N444JN ________________________________________________________________________________
Date: Mar 06, 2004
Subject: Re: Exhaust Bracket Failure
Listers, My RV4 has 954 hrs on the hanging system with no problems. It is the older set up using hose and alum flat bar stock. It attaches to the 4 pipe tubes (2 each side) and the outboard corner bolts of the sump. I do have a wood prop and balance ring installed. Perhaps the failures are prop vibration issues Stewart RV4 Colorado ________________________________________________________________________________
Date: Mar 06, 2004
Subject: Re: Van's alternator - $18 at Pep boys
Mike, What is the part number of your Susuki 60 amp alternator? Or can you tell where and what to ask for? Dan RV-7A (almost done) In a message dated 3/6/04 2:20:11 AM US Eastern Standard Time, mstewart(at)iss.net writes: > > mstewart(at)iss.net> > > I got one of the bosch ones cross referenced to the 14xxx number. 22$. > It worked for about the same 250 hours as the Vans one did. It was not > until I got the Susuki 60 amp internally regulated, lighter, more amp > unit, that I stopped toasting them. My Suzuki unit has lasted about 600 > hours without toasting. I believe I read somewhere in the aeroeletric > site why the Suzuki unit was far superior. Double fan, rated for the > high rpm's it turns and so forth. It is a $130ish unit. But the lifetime > warrantee, and lack of headache factor, combined with the increased amps > which I needed running an all electric plane with no mags, made this > alternator a much better choice fo me. > > Mike > ________________________________________________________________________________
Date: Mar 06, 2004
Subject: non-U.S. parts suppliers
I am trying to find some distributors for my instrument lights in other countries. Since there are a lot of builders on the list in places other than the U.S. could you please tell me where you buy your parts and instruments. Please reply directly to me at brian.kraut(at)engalt.com, not to the list. Thanks. Brian Kraut www.engalt.com/aviation.htm ________________________________________________________________________________
Subject: transducer manifold
Date: Mar 06, 2004
Can anyone recommend a two port (two transducer) manifold. Van's sells a three port unit, but I only need two. I can cut off one port on the Van's unit, but would rather not do that. Thanks Roger Crandell Find things fast with the new MSN Toolbar includes FREE pop-up blocking! http://clk.atdmt.com/AVE/go/onm00200414ave/direct/01/ ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Mar 06, 2004
I bet I could get flat sheets laser cut....never tried carbon fiber but the laser cuts metals, plywood and plastics with no problems. I just had an RV6 (aluminum stock one)panel cut for a friend of mine and it turned out awsome. I got to do the whole layout on Autocad and then watch the laser cut it perfectly....the cut is just a few thousands thick. Evan ----- Original Message ----- From: "Bill Dube" <bdube(at)al.noaa.gov> Subject: Re: RV-List: Carbon panel > > > > > >Dana and I are still in the development stage on the carbon fiber panel > >so the jury is still out - but we have a pretty good idea of where we > >are going to end up. We are more interrested in having the look of a > >carbon fiber panel than we are in the structural and/or weight > >advantages we might gain from the composites. We decided early on that > >Kevlar probably wasn't going to be in the final solution. More because > >it is simply a pain to work with than anything else. I just don't know > >how to make all of the instrument cut outs, holes and trim the final > >edges. Kevlar is so tough that it resists cutting. On an instrument > >panel, you would have little "frizzies" where ever you had to cut > >through it. And, you can't sand them away, they just get worse the more > >you try to sand them. > > This is a fact. You would have to plan the panel so that no cut > edges would show. > > > >I do like the idea of using the Rutan sandwich construction techniques > >to strengthen the panel. We will probably do that around the radio > >stack but not anywhere else. The main reason is, we are going to use > >this panel on three RV-7's that are under construction. As is usually > >the case, no two panels are alike. Making all of the panels the same, > >without the internal core material, we can make instrument cutouts where > >ever we want. > > Mold the holes instead of cutting them. > > Arrange plastic disks on the flat mold plate where you wanted the > round instruments to go. You would machine the disks to provide the exact > recess (or hole edge) that you wanted. You could also place rectangles for > square instruments. Secure the disks so they don't shift during the lay-up. > Wax and smooth the joint between the plate and the each disk so epoxy won't > get under them. > > You bag the front layers (with a peel ply) over this negative > mold. Once the first lay-up has cured, pull the peel ply, add the spacer > and back lay-up, then bag again. (It might be possible to do it all in one > step, once you got the process down, but it could be difficult to get the > front layer to come out perfectly.) > > When you pull the part, you have a perfect recessed hole (or plain > hole) for each instrument. Just trim off the flange flash from the back > with a cut-off wheel. The small flange around each hole will make the panel > much stronger and durable. Recessed holes and cut-outs would look super > slick and would also increase the strength of the panel. > > ________________________________________________________________________________
Date: Mar 06, 2004
Rain will do a good number on the finish,wood and fiberglass leading edge even. I've had pretty good success using the 3M wing leading edge tape on the prop leading edge. Michel -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dj Merrill Subject: RV-List: wood props and IFR Hi all, I'm looking for some advice from more experienced pilots than I. I have a Ted Hendrickson wooden prop on my plane, and I'd like to start training for my instrument rating. I've read that wood props don't like the rain, and get beat up pretty badly. Basically, I'm wondering is a little rain going to really trash the prop, or would it take hours and hours of rain flying to cause damage? The prop has about 1050 hours on it, but was freshly refurbished by Sensenich about 50 hours ago, nice fresh clear coat, looks beautiful. Thanks, -Dj ________________________________________________________________________________
Date: Mar 06, 2004
"rv7-list(at)matronics.com"
Subject: -7 wing leading edge 'glitch' ?
-7/-8 builders, Has anyone noticed a slight dip about an inch above & below (back of the actual apex) the rolled leading edge of their tank skins & leading edge skins? While handling one of my cleco'd tanks, I felt the dip, & thought I had somehow dented the leading edge. On further inspection, the 'dips' are slight valleys running the entire length of the LE & are identical on all 4 skins. On the top side, it's about where the 2nd rivet will be in each rib. It seems unlikely that it's due to the ribs, because there is no difference in the valley mid way between ribs. I might be good at messing stuff up, but I ain't THAT good. Thanks, Charlie ________________________________________________________________________________
Date: Mar 06, 2004
Subject: Re: -7 wing leading edge 'glitch' ?
Charlie, Yeah, its there. I had never noticed it before. Do you mean like it was rolled a little too far at the leading edge? Don't fix it or mine will look bad. Dan RV-7A (almost done) In a message dated 3/6/04 7:29:32 PM US Eastern Standard Time, cengland(at)netdoor.com writes: > > > -7/-8 builders, > > Has anyone noticed a slight dip about an inch above &below (back of the > actual apex) the rolled leading edge of their tank skins &leading edge > skins? > > While handling one of my cleco'd tanks, I felt the dip, &thought I had > somehow dented the leading edge. On further inspection, the 'dips' are > slight valleys running the entire length of the LE &are identical on > all 4 skins. On the top side, it's about where the 2nd rivet will be in > each rib. It seems unlikely that it's due to the ribs, because there is > no difference in the valley mid way between ribs. > > I might be good at messing stuff up, but I ain't THAT good. > > Thanks, > > Charlie > > ________________________________________________________________________________
Date: Mar 06, 2004
Subject: Re: >Re:wood props and IFR
Rain will definitely ruin a wood prop. On one of our first flights in our RV-4 ,we were flying with another RV-4. I had the urethane leading edge and the other had just clear tape. After 3 1/2 hours @ 1800 RPM I had only minor chipping on the paint edges at the tip ; the other had about 1/4" of the wood chewed off the leading edge ! One trashed prop. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
"rocket-list" , "Roger Graham" , "Paul Ray" , "Allen Mecum"
Subject: Re: [SoCAL-RVlist] Apple Valley Today, Chino Sunday
Date: Mar 06, 2004
The official count was 26 RV's with one HRII flown in. We at EAA 768 also had three Young Eagle flights, made room for the Short Wing Piper club, 7 fly-in's for them. Several other production types mixed with the Arco guys and the "usual APV suspects". We were missing only an RV-3, HR-1, F-1 and an HRIII to have had a complete set of ALL the RV types. We refer to 561FS as an RV-4 on steroids. If you missed out on the feed and the talk, TOUGH TOE NAILS. We had a great time and will hold another "informal" RV fly-in feed for all those that missed out this time. Friday was also a good day at APV. Got 561FS's test flights completed on the new engine and the "quad" prop. When was the last time you saw 5 Howards and a Ryan land at your airport during the week. Apple Valley Airport is just a great place to spend flying or hanger time. If anyone who attended didn't get enough to eat, that was your fault. Ron Caraway cooked up just about everything we had but it was good to the last bite. Thanks to all for the great examples of RV's and the hanger "flying". Ya'll com back y'ear KABONG ----- Original Message ----- From: Paul (Rosie) Rosales To: SoCAL-RVlist(at)yahoogroups.com Sent: Saturday, March 06, 2004 4:44 PM Subject: [SoCAL-RVlist] Apple Valley Today, Chino Sunday We had a GREAT turnout of RVs today at Gummo's EAA Mexican outdoor barbeque at Apple Valley (APV) with, I'm told, 25 RVs plus one Rocket in attendance! Weather was awesome; nice and comfortable, with NO WIND, a rarity out this way ;-) It was fun Tom! The flyout for tomorrow (Sunday) to Chino is being finalized, and I will post more a bit later tonight. Thanks to all the RVs for joining us to Apple Valley (and a few more to Agua Dulce afterwards)!!! Rosie a.. To visit your group on the web, go to: http://groups.yahoo.com/group/SoCAL-RVlist/ b.. To unsubscribe from this group, send an email to: SoCAL-RVlist-unsubscribe(at)yahoogroups.com ________________________________________________________________________________
Date: Mar 06, 2004
In a message dated 3/5/2004 11:23:40 PM Pacific Standard Time, mstewart(at)iss.net writes: Has anyone worked out an exhaust hanging system that is reliable over the long term? Absolutely GV (RV-6A N1GV flying 682 hrs) ________________________________________________________________________________
Date: Mar 07, 2004
Subject: Re: Fiber post lights; was non-U.S. parts suppliers
Brian, I would be interested in this light, but I think the presentation on your website and in your brochure would be much more compelling if you had a picture that actually demonstrated the illumination created by the light instead of illumination OF the light by a flash bulb. How well does its light cover the instrument? How bright is the illumination? What actually is the cost? Randy Brian Kraut wrote: > >I am trying to find some distributors for my instrument lights in other countries. Since there are a lot of builders on the list in places other than the U.S. could you please tell me where you buy your parts and instruments. Please reply directly to me at brian.kraut(at)engalt.com, not to the list. Thanks. > >Brian Kraut >www.engalt.com/aviation.htm > > > > -- Randy Richter richterrbb(at)earthlink.net -7QB Kit in hibernation ________________________________________________________________________________
From: "Youne Hippoman" <youne.hippoman(at)sympatico.ca>
Date: Mar 07, 2004
Yes. I have dips above and below, on both leading edges and both fuel tanks skins. This is normal and has nothing to do with the ribs. It happens because the apex part of the skin is a permanent curve (machine formed) in the aluminium structure whereas the aft top and bottom curves are temporary (i.e. if you remove the clecoes, the skin opens back to a 90 degree angle). When the skin is left open, there is absolutely no dip at all. But, when we force the skin to fold, a bulge is formed where the permanent and the temporary curves meet. Blame it on molecular structure memory, not Van's!!! In theory, if we keep on forcing the skin to fold (don't do that, it may create permanent damage to the skin), we will reach a point where the dip will disappear. But, the plane won't fly with such a wing profile!!! I would rather keep the bulge and fly the plane. You will also notice the same dip in the rudder skin, but it's harder to detect because it is less deep. You may need a couple of drinks with the lights turned off in order to feel the dip in the rudder skin. Youne Hippoman Montreal, Qc, Canada (RV-7A Center Fuselage) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Charlie England Subject: RV-List: -7 wing leading edge 'glitch' ? -7/-8 builders, Has anyone noticed a slight dip about an inch above & below (back of the actual apex) the rolled leading edge of their tank skins & leading edge skins? While handling one of my cleco'd tanks, I felt the dip, & thought I had somehow dented the leading edge. On further inspection, the 'dips' are slight valleys running the entire length of the LE & are identical on all 4 skins. On the top side, it's about where the 2nd rivet will be in each rib. It seems unlikely that it's due to the ribs, because there is no difference in the valley mid way between ribs. I might be good at messing stuff up, but I ain't THAT good. Thanks, Charlie ________________________________________________________________________________
Date: Mar 06, 2004
From: kempthornes <kempthornes(at)earthlink.net> suppliers
suppliers Post lights were hot stuff FORTY years ago. hal ________________________________________________________________________________
Date: Mar 07, 2004
Light Aero in the UK has post lights listed in their catalog, you will find them on the web. Eugene ________________________________________________________________________________
Subject: TruTrak Auto-pilot w/turn coordinator
Date: Mar 07, 2004
I had a chance to look at the new TruTrak unit yesterday at the Casa Grande Arizona, Cactus Antique Aircraft fly-in. They will initially have two units available, one with roll control like the Digitrak unit and a plain turn coordinator without any autopilot functions. No altitude functions on the Autopilot unit, roll control only for now. I really liked the way the units looked and the way the display moved. However, the small size (2 1/4 ) really made the turn coordinator not very satisfactory for me. This would be a great instrument if it were in a 3 inch format. Same is true for the autopilot unit, the display is just too small to use if you had to use it as a primary flight instrument. I did like the way the airplane stayed level and the horizon pivoted around the axis, this was a nice representation and would be really easy to fly from. If they bring out a bigger unit, I would probably buy one in a flash. Mel Jordan RV-6A N6JX Tucson ________________________________________________________________________________
Subject: Re: TruTrak Auto-pilot w/turn coordinator
Date: Mar 07, 2004
Hi Mel, I saw the unit too and was very impressed, especially the price. He told me the unit IS available in the standard size, so I ordered one. The 2.25" was for display. Very, very cool and will look perfect under my Dynon. Darwin N. Barrie Chandler AZ ----- Original Message ----- From: "N6JX" <n6jx(at)earthlink.net> Subject: RV-List: TruTrak Auto-pilot w/turn coordinator > > I had a chance to look at the new TruTrak unit yesterday at the Casa Grande > Arizona, Cactus Antique Aircraft fly-in. They will initially have two > units available, one with roll control like the Digitrak unit and a plain > turn coordinator without any autopilot functions. No altitude functions on > the Autopilot unit, roll control only for now. > > I really liked the way the units looked and the way the display moved. > However, the small size (2 1/4 ) really made the turn coordinator not very > satisfactory for me. This would be a great instrument if it were in a 3 > inch format. Same is true for the autopilot unit, the display is just too > small to use if you had to use it as a primary flight instrument. I did > like the way the airplane stayed level and the horizon pivoted around the > axis, this was a nice representation and would be really easy to fly from. > If they bring out a bigger unit, I would probably buy one in a flash. > > Mel Jordan > RV-6A N6JX > Tucson > > ________________________________________________________________________________
Date: Mar 07, 2004
Subject: Instrument lighting with LEDs
RV Listers, I just bought some cheap LED flashlights at a hamfest (a fly mart for ham radio people) and am thinking of using them to illuminate my panel. I bought 10 of these flashlights to experiment with because they have some optics to control the light pattern that I thought might help. I want a very low cost approach. Bright LEDs are readily available now at Radio Shack and many mail order houses like Digikey. I am thinking of mounting them under the glare shield aimed at the instruments. Has anyone else done this? LED stands for light emitting diode for any who don't already know. There are some really bright LEDs available today. They are much more efficient than light bulbs which radiate a lot of energy at longer wavelengths than light. They are also more reliable. Many traffic lights and taillights on cars are now LEDs, and I have heard that LED headlights for cars are not too far off. Dan RV-7A (almost done) ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: Air Filter 0-360-A1A
Date: Mar 07, 2004
List, I have run into a problem with the clearance on my FAB 360 airbox being close to rubbing the cowl air scope? The K&N Air Filter supplied is exactly 7" x 3 1/2 " O.D. I would be fine if the Air Filter was only 3 1/4" High? Has anyone else ran into this? It would appear the front my Airbox needs to angle up more to use the existing filter? Sure don't want to cut the box to increase the upward angle and re-glass? Tom in Ohio ________________________________________________________________________________
Date: Mar 07, 2004
What page of the new Sport Aviation is this product on? Charlie Kuss > >Hi Mel, > >I saw the unit too and was very impressed, especially the price. He told me >the unit IS available in the standard size, so I ordered one. The 2.25" was >for display. Very, very cool and will look perfect under my Dynon. > >Darwin N. Barrie >Chandler AZ >----- Original Message ----- >From: "N6JX" <n6jx(at)earthlink.net> >To: >Subject: RV-List: TruTrak Auto-pilot w/turn coordinator > > >> >> I had a chance to look at the new TruTrak unit yesterday at the Casa >Grande >> Arizona, Cactus Antique Aircraft fly-in. They will initially have two >> units available, one with roll control like the Digitrak unit and a plain >> turn coordinator without any autopilot functions. No altitude functions >on >> the Autopilot unit, roll control only for now. >> >> I really liked the way the units looked and the way the display moved. >> However, the small size (2 1/4 ) really made the turn coordinator not very >> satisfactory for me. This would be a great instrument if it were in a 3 >> inch format. Same is true for the autopilot unit, the display is just too >> small to use if you had to use it as a primary flight instrument. I did >> like the way the airplane stayed level and the horizon pivoted around the >> axis, this was a nice representation and would be really easy to fly from. >> If they bring out a bigger unit, I would probably buy one in a flash. >> >> Mel Jordan >> RV-6A N6JX >> Tucson >> >> > > ________________________________________________________________________________
Date: Mar 07, 2004
Darwin N. Barrie wrote: > >Hi Mel, > >I saw the unit too and was very impressed, especially the price. He told me >the unit IS available in the standard size, so I ordered one. The 2.25" was >for display. Very, very cool and will look perfect under my Dynon. > >Darwin N. Barrie >Chandler AZ > > > Did you get the standard size 3 1/8" turn coordinator without the autopilot? I am interested in that. Was it the same price as the 2 1/4" $395 I will be very interested in hearing your report after you receive it. -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Slowbuild wings-QB Fuse :-) ________________________________________________________________________________
Date: Mar 07, 2004
Charlie Kuss wrote: > >What page of the new Sport Aviation is this product on? >Charlie Kuss > > > Sport Aviation, March 2004, page 55 Not on their web site yet, seem like that would be the first place to have it. -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Slowbuild wings-QB Fuse :-) ________________________________________________________________________________
Date: Mar 07, 2004
Does anyone know if this is considered a trade up purchase (getting trade-in value for original purchase of the digitrak) for someone already having a digitrak and wanting to replace with the new wing leveler with TC? Indiana Larry, RV7 Tip-up TMX-O-360 ACS2002 Dynon CNS430 Digitrak Firewall Forward ----- Original Message ----- From: "Darwin N. Barrie" <ktlkrn(at)cox.net> Subject: Re: RV-List: TruTrak Auto-pilot w/turn coordinator > > Hi Mel, > > I saw the unit too and was very impressed, especially the price. He told me > the unit IS available in the standard size, so I ordered one. The 2.25" was > for display. Very, very cool and will look perfect under my Dynon. > > Darwin N. Barrie > Chandler AZ > ----- Original Message ----- > From: "N6JX" <n6jx(at)earthlink.net> > To: > Subject: RV-List: TruTrak Auto-pilot w/turn coordinator > > > > > > I had a chance to look at the new TruTrak unit yesterday at the Casa > Grande > > Arizona, Cactus Antique Aircraft fly-in. They will initially have two > > units available, one with roll control like the Digitrak unit and a plain > > turn coordinator without any autopilot functions. No altitude functions > on > > the Autopilot unit, roll control only for now. > > > > I really liked the way the units looked and the way the display moved. > > However, the small size (2 1/4 ) really made the turn coordinator not very > > satisfactory for me. This would be a great instrument if it were in a 3 > > inch format. Same is true for the autopilot unit, the display is just too > > small to use if you had to use it as a primary flight instrument. I did > > like the way the airplane stayed level and the horizon pivoted around the > > axis, this was a nice representation and would be really easy to fly from. > > If they bring out a bigger unit, I would probably buy one in a flash. > > > > Mel Jordan > > RV-6A N6JX > > Tucson > > > > > > ________________________________________________________________________________
Date: Mar 07, 2004
Yes, according to Richard Martin who was representing TruTrak the turn coordinator alone is available in the 3 1/8" version. They only had the 2.25" for display. It is very cool. It looks like much like a standard Artificial Horizon with out the pitch component. Standard looking slip/skid ball. The unit is electric and spools up immediately. The display unit had an internal battery so people could test it out. The bank indicator is very sensitive. Just from the 10 minutes I played with it I believe it is the perfect addition to the Dynon or other EFIS. Darwin N. Barrie Chandler AZ ----- Original Message ----- From: "Bobby Hester" <bhester(at)hopkinsville.net> Subject: Re: RV-List: TruTrak Auto-pilot w/turn coordinator > > Darwin N. Barrie wrote: > > > > >Hi Mel, > > > >I saw the unit too and was very impressed, especially the price. He told me > >the unit IS available in the standard size, so I ordered one. The 2.25" was > >for display. Very, very cool and will look perfect under my Dynon. > > > >Darwin N. Barrie > >Chandler AZ > > > > > > > Did you get the standard size 3 1/8" turn coordinator without the > autopilot? I am interested in that. Was it the same price as the 2 1/4" > $395 I will be very interested in hearing your report after you receive it. > > -- > Surfing the Web from Hopkinsville, KY > Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ > RV7A Slowbuild wings-QB Fuse :-) > > ________________________________________________________________________________
Subject: The First Palmetto RV FlyIn Cookout
Date: Mar 07, 2004
The Palmetto Wing of Van's Air Force Invites any and all RV pilots/flyers/builders/etc. to the FIRST PALMETTO RV FLYIN COOKOUT Saturday, March 20th Columbia Downtown Owens Field Airport Columbia, SC Palmetto Burgers and Carolina Dogs Grills will be fired up at 11:00 AM No Program No Vendors No Speeches No Organization No Charge (Donations Accepted) Just good food, RV's, and friendly conversation. www.airnav.com/airport/KCUB Note right traffic for runway 13 Taxi toward the east end of the field (toward Rwy 31) and look for the crowd. If you plan to come email Ken.Harrill(at)Columbia.SC so we can buy enough food. ________________________________________________________________________________
Subject: Band Saws
Date: Mar 07, 2004
I am looking for a band saw and I found this one at Harbor Freight. After going thru the archives, it sounds like just about any band saw will work. Anyone have experience with Central Machinery brand? Is the following a good deal? Thanks, Steve Precision three-wheeled design cuts material up to 12'' wide and makes bevel cuts from 0 to 60 Electronic variable speed switch controls the speed of the blade from 0 to 2645 feet per minute. Three ball bearing blade guide system eliminates the blade from slipping. Includes miter gauge, trunion assembly, hex wrenches, and extra set of carbon brushes. Blade sold separately. Motor: 115V, 3.5 amps, single phase Table: slotted cast aluminum: 13-1/2'' x 13-1/2'' Work capacity: 12'' x 4-1/8'' high Requires 62'' blade Overall dimensions: 24-7/8''L x 13-1/2''W x 22-3/4''H Tool weight: 30 lbs. ITEM 40981-5VGA $109.99 ________________________________________________________________________________
Subject: Band Saws
Date: Mar 07, 2004
Date: Mar 07, 2004
Thanks. I will check them out. ---------- Original Message ---------------------------------- From: MMcs139808(at)aol.com Date: Sun, 7 Mar 2004 03:45:43 EST > >Light Aero in the UK has post lights listed in their catalog, you will find >them on the web. > >Eugene > > ________________________________________________________________________________
Subject: Re: Band Saws
Date: Mar 07, 2004
Hi Steve, I bought that saw when it was on sale last month for $99. I took it back for a refund. It was an alright saw but is primariuly for cutting wood. I took it back because the guide wheels are NOT adjustable. Harbor Freight has no metal cuting saw blades for it. I did order a 50' 24 tPI blade and had some welded to fit (62") but when I tried to install them they were too thick. That is when I found that the guide wheels would not adjust. Hope this helps, Ned ----- Original Message ----- From: <nyman(at)bellsouth.net> Subject: RV-List: Band Saws > > I am looking for a band saw and I found this one at Harbor Freight. After going thru the archives, it sounds like just about any band saw will work. Anyone have experience with Central Machinery brand? Is the following a good deal? > > Thanks, > Steve > > Precision three-wheeled design cuts material up to 12'' wide and makes bevel cuts from 0 to 60 Electronic variable speed switch controls the speed of the blade from 0 to 2645 feet per minute. Three ball bearing blade guide system eliminates the blade from slipping. Includes miter gauge, trunion assembly, hex wrenches, and extra set of carbon brushes. Blade sold separately. > Motor: 115V, 3.5 amps, single phase > Table: slotted cast aluminum: 13-1/2'' x 13-1/2'' > Work capacity: 12'' x 4-1/8'' high > Requires 62'' blade > Overall dimensions: 24-7/8''L x 13-1/2''W x 22-3/4''H > Tool weight: 30 lbs. > ITEM 40981-5VGA > $109.99 > > ________________________________________________________________________________
Date: Mar 07, 2004
From: Charlie & Tupper England <cengland(at)netdoor.com>
nyman(at)bellsouth.net wrote: > >I am looking for a band saw and I found this one at Harbor Freight. After going thru the archives, it sounds like just about any band saw will work. Anyone have experience with Central Machinery brand? Is the following a good deal? > >Thanks, >Steve > If you want mine (bought about 13 years ago & never made a cut without the blade coming off), you can have it if you will come & get it. Charlie Slobovia Outernational Airport, Jackson MS > >Precision three-wheeled design cuts material up to 12'' wide and makes bevel cuts from 0 to 60 Electronic variable speed switch controls the speed of the blade from 0 to 2645 feet per minute. Three ball bearing blade guide system eliminates the blade from slipping. Includes miter gauge, trunion assembly, hex wrenches, and extra set of carbon brushes. Blade sold separately. >Motor: 115V, 3.5 amps, single phase >Table: slotted cast aluminum: 13-1/2'' x 13-1/2'' >Work capacity: 12'' x 4-1/8'' high >Requires 62'' blade >Overall dimensions: 24-7/8''L x 13-1/2''W x 22-3/4''H >Tool weight: 30 lbs. >ITEM 40981-5VGA >$109.99 > ________________________________________________________________________________
Date: Mar 07, 2004
Subject: Light Weight Gear Leg for RV-8
Any one know of a source for lighter weight gear legs for the RV-8. I have seen them mentioned in the past, even with brake lines enclosed. L.D. Jeffries. RV-8QB ________________________________________________________________________________
Date: Mar 07, 2004
Subject: 2 new building resources
Tired of riveting on parts that you later learn to be defective? Yep, there it is, right in the archives, other people have gotten the bad part too. Van's even knows about it, but for some reason they didn't tell the rest of us... Found errors in the documentation? Sure, we all have. You probably realized the problem before you hurt your airplane, but what about the next guy? Reduce the amount of suffering in the RV community. Register any parts defects and construction manual errors you find, so new builders can go and make notes *before* they repeat history: http://hmb.dyndns.org/~eastham/rv/defect.html (parts defects) http://hmb.dyndns.org/~eastham/rv/manual.html (construction manual errata) Please invest a moment to help us newbies! :) Regards, Paul RV-9A wings http://hmb.dyndns.org/~eastham/rv ________________________________________________________________________________
Subject: re: Instrument lighting with LEDs
Date: Mar 07, 2004
Check our HYPERLINK "http://www.lumileds.com"www.lumileds.com for their line of Luxeon Star LED's that I bought from HYPERLINK "http://www.luxeonstar.com"www.luxeonstar.com . The new Audi A8 will feature what appears to be their 5W star's in a 5 light cluster for headlamps. I built some nav lights using 3 of their star LED's and a simple current regulator using an LM317 and a 3.6 Ohm resistor for my RV-10 project. The light output is definitely brighter than a typical incandescent source and the current draw is about 1 amp compared to 2.5 amps for a reg. bulb. A link to the current regulator circuit is at: HYPERLINK "http://linear1.org/gm/archives/00000147.php"http://linear1.org/gm/archi ves/00000147.php I plan on using the Star LED's for the interior as well. They are available with different lens patterns, colors, and outputs. Although they cost about $10 a piece, they are easy to mount and 1 Star is a lot brighter than multiple $2 super brights. They also sell some wide dispersion board mount styles that many of the auto vendors currently use for IP lighting. The concept I have is a to use one of each of the primaries clustered in a color mixing flood configuration so that I can change the interior lighting to any color I want. Other ideas- the local PC stores are selling EL strip lighting kits with 12V inverters for less than $20. Although designed to light up your PC box (don't ask me why!) I think that they would make great under-glareshield lights for real cheap. Robin Wessel rv-10 wings Tigard, OR HYPERLINK "http://robin.getbiz.net"http://robin.getbiz.net --- ________________________________________________________________________________
Date: Mar 07, 2004
I bought that same band saw many years ago. Very difficult to find metal blades for it. I had to have a few made up special. Then they easily snap when cutting anything of any significance. I finally sold it for $20 bucks with no blades. Now that I am working on the RV-9 there have only been a couple times when I wish I had one. But not enough to actually go buy one yet. If I do, I will buy a good one and one that I know there are blades for. Curt Hoffman RV-9A Wings done, QB fuselage, tail about done Cherokee N5320W TR6 back to running with HS6 SUs Harley Road King Classic Maybe I need a sailboat ----- Original Message ----- From: <nyman(at)bellsouth.net> Subject: RV-List: Band Saws > > I am looking for a band saw and I found this one at Harbor Freight. After going thru the archives, it sounds like just about any band saw will work. Anyone have experience with Central Machinery brand? Is the following a good deal? > > Thanks, > Steve > > Precision three-wheeled design cuts material up to 12'' wide and makes bevel cuts from 0 to 60 Electronic variable speed switch controls the speed of the blade from 0 to 2645 feet per minute. Three ball bearing blade guide system eliminates the blade from slipping. Includes miter gauge, trunion assembly, hex wrenches, and extra set of carbon brushes. Blade sold separately. > Motor: 115V, 3.5 amps, single phase > Table: slotted cast aluminum: 13-1/2'' x 13-1/2'' > Work capacity: 12'' x 4-1/8'' high > Requires 62'' blade > Overall dimensions: 24-7/8''L x 13-1/2''W x 22-3/4''H > Tool weight: 30 lbs. > ITEM 40981-5VGA > $109.99 > > ________________________________________________________________________________
Subject: Re: Light Weight Gear Leg for RV-8
Date: Mar 07, 2004
http://www.groveaircraft.com/rv8.html ----- Original Message ----- From: <Fly2eat(at)aol.com> Subject: RV-List: Light Weight Gear Leg for RV-8 > > Any one know of a source for lighter weight gear legs for the RV-8. I have > seen them mentioned in the past, even with brake lines enclosed. L.D. > Jeffries. RV-8QB > > ________________________________________________________________________________
Date: Mar 08, 2004
From: "Frank van der Hulst (Staff WG)" <F.vanderHulst(at)ucol.ac.nz>
Paul, This is similar to what I had in mind when I began the "Bunny's Guide to RV Building" site. See http://www.matronics.com/rv-list/bunnys-guide/rv/bunny/ It doesn't really aim to correct specific 'errors' in the Manual -- more like fill in many of the gaps. Similarly with 'parts defects' -- it's more about how to work-around slightly mis-fitting parts than to document whether or not they are mis-fitting. I suspect that some RV-9 (and a lot of RV-7 stuff) will still be more-or-less the same as the RV-6, so its probably worth your while having a skim through. Frank (self-appointed keeper of the Guide) Reduce the amount of suffering in the RV community. Register any parts defects and construction manual errors you find, so new builders can go and make notes *before* they repeat history: Learn real skills for the real world - Apply online at http://www.ucol.ac.nz or call 0800 GO UCOL (0800 46 8265) or txt free 3388 for more information and make a good move to UCOL Universal College of Learning. Enrol with a public institute and be certain of your future ________________________________________________________________________________
Date: Mar 07, 2004
From the picture in Sport Aviation, it looks as though when you upgrade to the Autopilot combo version you lose the skid ball. That makes it an AP / Turn-and-Bank and not an AP / Turn Coordinator. Since I'm looking for IFR eventually, this doesn't really save anything for me, since I still want an actual TC. Maybe the Standard size instrument varies from the photo and has the ball. I'm considering a TruTrak AP and a combo AP/ TC (like the S-Tec) would be nice, but from the pic it looks like the TruTrak falls short of this. Too bad. Doug Fischer -9A Wings ----- Original Message ----- From: "Darwin N. Barrie" <ktlkrn(at)cox.net> Subject: Re: RV-List: TruTrak Auto-pilot w/turn coordinator > > Yes, according to Richard Martin who was representing TruTrak the turn > coordinator alone is available in the 3 1/8" version. They only had the > 2.25" for display. > > It is very cool. It looks like much like a standard Artificial Horizon with > out the pitch component. Standard looking slip/skid ball. The unit is > electric and spools up immediately. The display unit had an internal battery > so people could test it out. The bank indicator is very sensitive. > > Just from the 10 minutes I played with it I believe it is the perfect > addition to the Dynon or other EFIS. > > Darwin N. Barrie > Chandler AZ > ----- Original Message ----- > From: "Bobby Hester" <bhester(at)hopkinsville.net> > To: > Subject: Re: RV-List: TruTrak Auto-pilot w/turn coordinator > > > > > > Darwin N. Barrie wrote: > > > > > > > >Hi Mel, > > > > > >I saw the unit too and was very impressed, especially the price. He told > me > > >the unit IS available in the standard size, so I ordered one. The 2.25" > was > > >for display. Very, very cool and will look perfect under my Dynon. > > > > > >Darwin N. Barrie > > >Chandler AZ > > > > > > > > > > > Did you get the standard size 3 1/8" turn coordinator without the > > autopilot? I am interested in that. Was it the same price as the 2 1/4" > > $395 I will be very interested in hearing your report after you receive > it. > > > > -- > > Surfing the Web from Hopkinsville, KY > > Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ > > RV7A Slowbuild wings-QB Fuse :-) > > > > > > ________________________________________________________________________________
Date: Mar 07, 2004
I bought a Delta bench top band saw for $88 from a local building supply store. Take the blade off and go to a machine tool supply house like Do-All. They can recommend theeth per inch, blade width, and thickness. I bought two blades for $16. Just watch out for metal flakes building up on the rubber tires the blade rides on. Otherwise it works well. Craig warner 6A still building ----- Original Message ----- From: "Curt" <choffman9(at)cinci.rr.com> Subject: Re: RV-List: Band Saws > > I bought that same band saw many years ago. Very difficult to find metal > blades for it. I had to have a few made up special. Then they easily snap > when cutting anything of any significance. I finally sold it for $20 bucks > with no blades. Now that I am working on the RV-9 there have only been a > couple times when I wish I had one. But not enough to actually go buy one > yet. If I do, I will buy a good one and one that I know there are blades
March 02, 2004 - March 07, 2004
RV-Archive.digest.vol-oz
