RV-Archive.digest.vol-pa
March 07, 2004 - March 17, 2004
      > for.
      > Curt Hoffman
      > RV-9A Wings done, QB fuselage, tail about done
      > Cherokee N5320W
      > TR6 back to running with HS6 SUs
      > Harley Road King Classic
      > Maybe I need a sailboat
      > ----- Original Message -----
      > From: <nyman(at)bellsouth.net>
      > To:
      > Subject: RV-List: Band Saws
      > > I am looking for a band saw and I found this one at Harbor Freight.
      After
      > going thru the archives, it sounds like just about any band saw will work.
      > Anyone have experience with Central Machinery brand? Is the following a
      good
      > deal?
      > > Thanks,
      > > Steve
      > > Precision three-wheeled design cuts material up to 12'' wide and makes
      > bevel cuts from 0 to 60 Electronic variable speed switch controls the
      speed
      > of the blade from 0 to 2645 feet per minute. Three ball bearing blade
      guide
      > system eliminates the blade from slipping. Includes miter gauge, trunion
      > assembly, hex wrenches, and extra set of carbon brushes. Blade sold
      > separately.
      > > Motor: 115V, 3.5 amps, single phase
      > > Table: slotted cast aluminum: 13-1/2'' x 13-1/2''
      > > Work capacity: 12'' x 4-1/8'' high
      > > Requires 62'' blade
      > > Overall dimensions: 24-7/8''L x 13-1/2''W x 22-3/4''H
      > > Tool weight: 30 lbs.
      > > ITEM 40981-5VGA
      > > $109.99
Date: Mar 07, 2004
Subject: Re: Band Saws
The need for a metal cutting blade depends what you intend to cut with the band saw. I have had reasonable success with a simple wood blade when cutting material up to 3/16" thick when roughing out fittings from 6061 angle and .063 2024 sheet. Thinner stiff bends however. If you want to cut steel, well a metal cutting blade is pretty much needed. Equally important as the blade type and teeth per inch is controlling blade speed - usually with a series of step pulleys. These are what the low end machines lack and what makes them unsuitable for even semi-serious metal work. Jim Oke RV-3, RV-6A Winnipeg, MB ----- Original Message ----- From: "Craig Warner" <cwarner(at)twcny.rr.com> Subject: Re: RV-List: Band Saws > > I bought a Delta bench top band saw for $88 from a local building supply > store. Take the blade off and go to a machine tool supply house like Do-All. > They can recommend theeth per inch, blade width, and thickness. I bought two > blades for $16. Just watch out for metal flakes building up on the rubber > tires the blade rides on. Otherwise it works well. > > Craig warner 6A still building > ----- Original Message ----- > From: "Curt" <choffman9(at)cinci.rr.com> > To: > Subject: Re: RV-List: Band Saws > > > > > > I bought that same band saw many years ago. Very difficult to find metal > > blades for it. I had to have a few made up special. Then they easily snap > > when cutting anything of any significance. I finally sold it for $20 bucks > > with no blades. Now that I am working on the RV-9 there have only been a > > couple times when I wish I had one. But not enough to actually go buy one > > yet. If I do, I will buy a good one and one that I know there are blades > > for. > > > > Curt Hoffman > > > > RV-9A Wings done, QB fuselage, tail about done > > Cherokee N5320W > > TR6 back to running with HS6 SUs > > Harley Road King Classic > > Maybe I need a sailboat > > ----- Original Message ----- > > From: <nyman(at)bellsouth.net> > > To: > > Subject: RV-List: Band Saws > > > > > > > > > > I am looking for a band saw and I found this one at Harbor Freight. > After > > going thru the archives, it sounds like just about any band saw will work. > > Anyone have experience with Central Machinery brand? Is the following a > good > > deal? > > > > > > Thanks, > > > Steve > > > > > > Precision three-wheeled design cuts material up to 12'' wide and makes > > bevel cuts from 0 to 60 Electronic variable speed switch controls the > speed > > of the blade from 0 to 2645 feet per minute. Three ball bearing blade > guide > > system eliminates the blade from slipping. Includes miter gauge, trunion > > assembly, hex wrenches, and extra set of carbon brushes. Blade sold > > separately. > > > Motor: 115V, 3.5 amps, single phase > > > Table: slotted cast aluminum: 13-1/2'' x 13-1/2'' > > > Work capacity: 12'' x 4-1/8'' high > > > Requires 62'' blade > > > Overall dimensions: 24-7/8''L x 13-1/2''W x 22-3/4''H > > > Tool weight: 30 lbs. > > > ITEM 40981-5VGA > > > $109.99 > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 07, 2004
Hey Charli, I'm always looking for an excuse to fly:) Can I stop by on my way back from Sun N Fun and pick it up while meeting a fellow RV enthusiast? NEd ----- Original Message ----- From: "Charlie & Tupper England" <cengland(at)netdoor.com> Subject: Re: RV-List: Band Saws > > nyman(at)bellsouth.net wrote: > > > > >I am looking for a band saw and I found this one at Harbor Freight. After going thru the archives, it sounds like just about any band saw will work. Anyone have experience with Central Machinery brand? Is the following a good deal? > > > >Thanks, > >Steve > > > If you want mine (bought about 13 years ago & never made a cut without > the blade coming off), you can have it if you will come & get it. > > Charlie > Slobovia Outernational Airport, Jackson MS > > > > > >Precision three-wheeled design cuts material up to 12'' wide and makes bevel cuts from 0 to 60 Electronic variable speed switch controls the speed of the blade from 0 to 2645 feet per minute. Three ball bearing blade guide system eliminates the blade from slipping. Includes miter gauge, trunion assembly, hex wrenches, and extra set of carbon brushes. Blade sold separately. > >Motor: 115V, 3.5 amps, single phase > >Table: slotted cast aluminum: 13-1/2'' x 13-1/2'' > >Work capacity: 12'' x 4-1/8'' high > >Requires 62'' blade > >Overall dimensions: 24-7/8''L x 13-1/2''W x 22-3/4''H > >Tool weight: 30 lbs. > >ITEM 40981-5VGA > >$109.99 > > > > ________________________________________________________________________________
Date: Mar 07, 2004
Subject: RV 4 Alternator
Anyone out in RV4 land that may know who makes the smallest diameter alternator for the 0320 ...I have a friend that has the frame of the unit touching the cowl ,not the pulley!!! Thanks for any help.. John McMahon RV6 (near paint) Do Not archive ________________________________________________________________________________
Date: Mar 07, 2004
Subject: Re: > Re: Band Saws
I bought a band saw from Harbor Freight in 1982. I bought it on the phone for $300.00. A few months later a friend bought the same saw for $169.00. The same one now is $199. I have built two RV-4's plus steel tubing hangar doors and sundry other items. I used the wood cutting blade for all things aluminum,and metal cutting blade for steel. I'm still using it almost every day. I have adjusted the wheel angles so the blade stays on OK. I think it is well worth the money. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Subject: Re: RV 4 Alternator
Date: Mar 07, 2004
I have a 40 amp B&C alternator that fit my 0-360 RV-4 with plenty of clearance. Doug Weiler Hudson, WI ----- Original Message ----- From: "John Mcmahon" <rv6(at)earthlink.net> Subject: RV-List: RV 4 Alternator > > Anyone out in RV4 land that may know who makes the smallest diameter > alternator for the 0320 ...I have a friend that has the frame of the > unit touching > the cowl ,not the pulley!!! Thanks for any help.. > > John McMahon RV6 (near paint) > > Do Not archive > > ________________________________________________________________________________
Subject: intersection fairings
Date: Mar 07, 2004
Am making my own intersection fairings and wondered if the lowers are normally glassed into the wheel pants and split, or separate and "floating" as the uppers are? Dave Ford RV6 ________________________________________________________________________________
Subject: cylinder blocker
Date: Mar 07, 2004
>I'm going to fabricate some .020" >blockers out of AL, and just rivet them to the lower ramps. Exactly what I did. I had a 30 degree difference with cyl 1 being the lowest. Put a 1 inch hi wall in front of the fins on cyl #1 and now in normal cruise my temps are all same at 335 +- 1 on all cylinders. I never though getting cyl temps that close was possible. ------ Is it a good idea to make the blocker a 90deg block or more of a 45 or 60deg ramp to smoothly direct air flow to the rear cylinder? Dave Ford RV6 ________________________________________________________________________________
Date: Mar 07, 2004
Subject: Re: intersection fairings
Mine are separate and screwed to the wheel pants with #8 screws and nut plates on the wheel pants. -Mike Kraus N223RV RV-4 Flying N213RV RV-10 Empennage ________________________________________________________________________________
Subject: Re: Light Weight Gear Leg for RV-8
Date: Mar 08, 2004
I used the Grove aluminum gear on my RV-8. Got the streamlined version so no fairing is required. Saves about 15 pounds. Tracy Crook Any one know of a source for lighter weight gear legs for the RV-8. I have seen them mentioned in the past, even with brake lines enclosed. L.D. Jeffries. RV-8QB ________________________________________________________________________________
Subject: Odessy Batteries
Date: Mar 07, 2004
Hi All, I apologize for this message!! I thought I had saved the information on the Odessy batteries but apparently not. The archives suck so I need to post to the group. Where is the best place to get the PC860 with the most reasonable shipping costs? Thanks in advance. Darwin N. Barrie Chandler AZ Doin' the wiring!! ________________________________________________________________________________
Date: Mar 07, 2004
Subject: Re: Odessy Batteries
Darwin N. Barrie wrote: > >Hi All, > >I apologize for this message!! I thought I had saved the information on the Odessy batteries but apparently not. The archives suck so I need to post to the group. > >Where is the best place to get the PC860 with the most reasonable shipping costs? > >Thanks in advance. > >Darwin N. Barrie >Chandler AZ >Doin' the wiring!! > > > > Try spelling it Odyssey and maybe you won't think the archives suck so bad. :-) Jerry ________________________________________________________________________________
Date: Mar 08, 2004
Darwin, Try . Http://www.batteries4everything in California, USD $62.55 Good service to me in the land north of the border. they do have a shipping charge. It didn't seem like all that much to me at the time. Jim in Kelowna ----- Original Message ----- From: "Darwin N. Barrie" <ktlkrn(at)cox.net> Subject: RV-List: Odessy Batteries > > Hi All, > > I apologize for this message!! I thought I had saved the information on the Odessy batteries but apparently not. The archives suck so I need to post to the group. > > Where is the best place to get the PC860 with the most reasonable shipping costs? > > Thanks in advance. > > Darwin N. Barrie > Chandler AZ > Doin' the wiring!! > > ________________________________________________________________________________
Date: Mar 08, 2004
Subject: Re: Air Filter 0-360-A1A
Are you sure you have the Filter Air Box for the O-360, and not the O-320? On mine (O-360) the nose of the fiberglass box angles up and the directions said to notch the sides of the lid and angle the front up to match. My FAB contacted the cowl scoop on the left side. I made a new .062 plate mounting plate (the one that bolts to the carb) to shift the FAB to the right. ________________________________________________________________________________
Date: Mar 08, 2004
Subject: Re: transducer manifold
You may consider just plugging the non-used port (may be utilized later??) and leave it as-is.. Tailgummer RV8 (Finishing) ________________________________________________________________________________
Date: Mar 08, 2004
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Make sure to order on line. If you call to order the price doubles!!! > >Darwin, > >Try . Http://www.batteries4everything in California, USD $62.55 Good >service to me in the land north of the border. >they do have a shipping charge. It didn't seem like all that much to me at >the time. > >Jim in Kelowna > >----- Original Message ----- >From: "Darwin N. Barrie" <ktlkrn(at)cox.net> >To: ; ; > >Subject: RV-List: Odessy Batteries > > >> >> Hi All, >> >> I apologize for this message!! I thought I had saved the information on >the Odessy batteries but apparently not. The archives suck so I need to post >to the group. >> >> Where is the best place to get the PC860 with the most reasonable shipping >costs? >> >> Thanks in advance. >> >> Darwin N. Barrie >> Chandler AZ >> Doin' the wiring!! >> >> > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 08, 2004
Thanks, I appreciate the tip. Just getting ready to order. Darwin ----- Original Message ----- From: "Scott Bilinski" <bilinski@kyocera-wireless.com> Subject: Re: RV-List: Odessy Batteries <bilinski@kyocera-wireless.com> > > Make sure to order on line. If you call to order the price doubles!!! > > > > > >Darwin, > > > >Try . Http://www.batteries4everything in California, USD $62.55 Good > >service to me in the land north of the border. > >they do have a shipping charge. It didn't seem like all that much to me at > >the time. > > > >Jim in Kelowna > > > >----- Original Message ----- > >From: "Darwin N. Barrie" <ktlkrn(at)cox.net> > >To: ; ; > > > >Subject: RV-List: Odessy Batteries > > > > > >> > >> Hi All, > >> > >> I apologize for this message!! I thought I had saved the information on > >the Odessy batteries but apparently not. The archives suck so I need to post > >to the group. > >> > >> Where is the best place to get the PC860 with the most reasonable shipping > >costs? > >> > >> Thanks in advance. > >> > >> Darwin N. Barrie > >> Chandler AZ > >> Doin' the wiring!! > >> > >> > > > > > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > ________________________________________________________________________________
Date: Mar 08, 2004
$80.09 door to door from Sunn Battery (that was in March of 2003). Higher price, but just a $5.50 flat shipping fee, which ended up being cheaper overall than Batteries4Everything, especially for CA buyers (no tax). )_( Dan RV-7 N714D http://www.rvproject.com (I posted this same exact message I don't know how many times...so DO NOT ARCHIVE) ----- Original Message ----- From: "Darwin N. Barrie" <ktlkrn(at)cox.net> Subject: Re: RV-List: Odessy Batteries > > Thanks, I appreciate the tip. Just getting ready to order. > > Darwin > ----- Original Message ----- > From: "Scott Bilinski" <bilinski@kyocera-wireless.com> > To: > Subject: Re: RV-List: Odessy Batteries > > > <bilinski@kyocera-wireless.com> > > > > Make sure to order on line. If you call to order the price doubles!!! > > > > > > > > > >Darwin, > > > > > >Try . Http://www.batteries4everything in California, USD $62.55 Good > > >service to me in the land north of the border. > > >they do have a shipping charge. It didn't seem like all that much to me > at > > >the time. > > > > > >Jim in Kelowna > > > > > >----- Original Message ----- > > >From: "Darwin N. Barrie" <ktlkrn(at)cox.net> > > >To: ; ; > > > > > >Subject: RV-List: Odessy Batteries > > > > > > > > >> > > >> Hi All, > > >> > > >> I apologize for this message!! I thought I had saved the information on > > >the Odessy batteries but apparently not. The archives suck so I need to > post > > >to the group. > > >> > > >> Where is the best place to get the PC860 with the most reasonable > shipping > > >costs? > > >> > > >> Thanks in advance. > > >> > > >> Darwin N. Barrie > > >> Chandler AZ > > >> Doin' the wiring!! > > >> > > >> > > > > > > > > > > > > Scott Bilinski > > Eng dept 305 > > Phone (858) 657-2536 > > Pager (858) 502-5190 > > > > > > ________________________________________________________________________________
Subject: DiVilbiss PLUS Spray Gun for sale.
Date: Mar 08, 2004
I have a DeVilbiss PLUS suction feed spray gun for sale. It includes 1.6 mm and 1.8 mm tips, a #410 spray cap, and stainless steel cup. Used to paint one RV6. New it was $289, will sell for $175 and Ill pay shipping to anywhere in continental US. Please contact off list. Thanks Fran Malczynski RV-6 N594EF Olcott, NY ebbfmm(at)yahoo.com ________________________________________________________________________________
Subject: Oil on my windscreen - Part 3
Date: Mar 08, 2004
Just to finish up the story that started when I noticed oil on my windscreen a couple of weeks ago. After doing some research on the web and talking to Bart Lalonde at Aerosport, it seems like the best adhesive for installing the crankcase nose seal is a 3M product #847 Scoth-Grip Rubber and Gasket Adhesive. I know it sticks to skin real well! After gluing the seal back in, I taped off the area, removed one of the prop bolt bushings, and drilled and tapped 10-32 holes in the bosses on the crankcase. I then fabricated some covers out of 0.062 aluminum, bolted them on, and saftied the bolts. While the plane was down, I also fixed a fuel leak in my gascolator and replaced a leaking tank drain on my left tank. Finally, I added a blocking plate on #1 cylinder to try and equalize my CHTs. Finally got it all back together and took her up on Saturday. CHTs are much closer, though still a little warm, and no oil leaks. I'll jerk the cowling off after a couple more hours and check everything. As a side note, I noticed that my exhaust bracket between my two Vetterman exhaust pipes was broken after only 30 hours! I need to call Larry and order his new kit to hang it from the engine. Back to flying. Doug Medema RV-6A N276DM ________________________________________________________________________________
Subject: Backer board for interior panels
Date: Mar 08, 2004
Dear All, I am sprucing up the interior of my RV. One of the things I'm attempting to do is make it warmer and quieter for my wife. To that end I have some leather for upholstery, and some foil backed. 3/8 inch foam. I plan to make a sandwich with the leather, foam, and a backer board. My question is what to use for a backer board. I have some Luan, but it is heavy. I'm hoping the list can provide some other ideas for a rigid, light backer board. Thanks, Don Mei ________________________________________________________________________________
Subject: OdYssey
Date: Mar 08, 2004
Thanks everyone. After evaluation the cost difference and calculating a UPS shipping rate I went with Batteries4everything. With the shipping to AZ I saved a few bucks. Maybe get them a little sooner. Darwin N. Barrie Chandler AZ ________________________________________________________________________________
Date: Mar 08, 2004
Subject: "We Love RV's" Gathering at Leeward Air Ranch
You are invited to view a Photo Album from Esten Spears. Hope you like the RV8/P51 formation shots. It was a real handful for the RV Pilots since the 25 knot gusts and turbulence pushed them around a lot more than the P51. Sign up with Club Photo today and get 25 cent 4x6 prints! Photo Album: http://www.clubphoto.com/reward.php?id=2100661&mid=members16_esten814128&pwd Top 5 reasons to join Club Photo today! 1) Get quality prints from that new digital camera you got 2) Share photos online 3) Send in film, get prints, and share the pictures online 4) Buy great photo gifts for the holidays You can join today at ... http://www.clubphoto.com/_cgi-bin/members/sign_up.pl ________________________________________________________________________________
Date: Mar 08, 2004
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
I used POLYBOARD Durable, Waterproof Corrugated Polyethylene Board. Obtained from http://www.airtexinteriors.com/catalogue/misc.htm Lightweight, Easy to handle, fireproof, cheap. You can see some results here. Go to finishing/interior http://www.mstewart.net/michael/rv/index.htm Good stuff. Mike -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Donald Mei Subject: RV-List: Backer board for interior panels Dear All, I am sprucing up the interior of my RV. One of the things I'm attempting to do is make it warmer and quieter for my wife. To that end I have some leather for upholstery, and some foil backed. 3/8 inch foam. I plan to make a sandwich with the leather, foam, and a backer board. My question is what to use for a backer board. I have some Luan, but it is heavy. I'm hoping the list can provide some other ideas for a rigid, light backer board. Thanks, Don Mei = = = = ________________________________________________________________________________
Subject: Re: "We Love RV's" Gathering at Leeward Air Ranch
Date: Mar 08, 2004
Esten, What state is this Air Park located in? (might consider retiring there). Chuck ----- Original Message ----- From: Esten Spears <ewspears(at)comcast.net> Subject: RV-List: "We Love RV's" Gathering at Leeward Air Ranch > > You are invited to view a Photo Album from Esten Spears. > > Hope you like the RV8/P51 formation shots. It was a real handful for the RV Pilots since the 25 knot gusts and turbulence pushed them around a lot more than the P51. > > Sign up with Club Photo today and get 25 cent 4x6 prints! > > Photo Album: > http://www.clubphoto.com/reward.php?id=2100661&mid=members16_esten814128&pwd > Top 5 reasons to join Club Photo today! > 1) Get quality prints from that new digital camera you got > 2) Share photos online > 3) Send in film, get prints, and share the pictures online > 4) Buy great photo gifts for the holidays > > You can join today at ... > > http://www.clubphoto.com/_cgi-bin/members/sign_up.pl > > ________________________________________________________________________________
Date: Mar 08, 2004
From: "Frank Eldridge" <eldridge(at)legis.state.ga.us>
Subject: Re: Safety Concern
January 1, 2003, I had a forced landing in a RV6A. After a ground roll of about 20 feet in a swampy area the plane ended up on its back. I found myself in the baggage compartment unhurt. I had always thought that I could kick plexiglass in the canopy out, but I could not. I always carry a pocket knife with a three inch locking blade and I was able to take that knife and break a hole in the canopy to get out. The only blood in the airplane was where I cut my hands on the plexiglass breaking a larger hole in order to extract myself. I strongly recommend to all my RV friends that they carry a knife like mine in their pocket because in my case I could not have got to a tool in the cockpit of the airplane. I have followed RV accidents very closely since mine, and a large number wind up on their back. So, please get a knife and keep it in your pocket when flying an RV. There is a story about my accident posted on Doug Reeves Van's Air Force Web page. Here is the link to m! y particular article: http://www.vansairforce.net/articles/FrankEldridge0.pdf Best of luck, Frank ________________________________________________________________________________
From: "Dr. Kevin P. Leathers" <DrLeathers(at)822heal.com>
Subject: Thorp S18 plans
Date: Mar 08, 2004
Hello RV List, A friend of mine is looking for a set of Thorp (Lu Sunderland) S18 plans. They are no longer available separately from the kit. If anyone has a set for sale, please contact me directly at DrLeathers(at)822HEAL.com BTW, here is a site with info on the Thorp aircraft http://www.t18.net/about.htm Thanks Doc a.. To visit your group on the web, go to: http://groups.yahoo.com/group/Bearhawk/ b.. To unsubscribe from this group, send an email to: Bearhawk-unsubscribe(at)yahoogroups.com ________________________________________________________________________________
Date: Mar 08, 2004
Your adjustment arm and belt may need changing to a smaller belt, not the alternator. See if using a shorter belt gets the alternator body closer to the engine. ________________________________________________________________________________
Date: Mar 08, 2004
On my first two RV's, I made them part of the wheel pant. I plan to do the same on my third one that is nearing completion. Jim Cone 3-peat offender ________________________________________________________________________________
Date: Mar 08, 2004
I had the problem of the alt hitting the cowl with more than a 2g pull. I got 2 belts about .5 and 1.0 shorter. Cut off the bolt hole in the alt belt tension bracket and installed another hole. The alt now is tucked up a little higher and does not hit anymore. > >Your adjustment arm and belt may need changing to a smaller belt, not the >alternator. See if using a shorter belt gets the alternator body closer to >the engine. > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
From: Richard Meske <rmeske@gcfn.org> (SquirrelMail authenticated user rmeske) by www.gcfn.org with HTTP; Mon,
8 Mar 2004 14:47:22.-0500(at)matronics.com (EST)
Date: Mar 08, 2004
Subject: Re: Safety Concern (NEW Tool for the job)
Check out the NEW nifty tool for just this purpose at: www.aircraftextras.com Rich > > > January 1, 2003, I had a forced landing in a RV6A. After a ground roll > of about 20 feet in a swampy area the plane ended up on its back. I > found myself in the baggage compartment unhurt. I had always thought > that I could kick plexiglass in the canopy out, but I could not. I > always carry a pocket knife with a three inch locking blade and I was > able to take that knife and break a hole in the canopy to get out. The > only blood in the airplane was where I cut my hands on the plexiglass > breaking a larger hole in order to extract myself. I strongly > recommend to all my RV friends that they carry a knife like mine in > their pocket because in my case I could not have got to a tool in the > cockpit of the airplane. I have followed RV accidents very closely > since mine, and a large number wind up on their back. So, please get a > knife and keep it in your pocket when flying an RV. There is a story > about my accident posted on Doug Reeves Van's Air Force Web page. Here > is the link to m! y particular article: > http://www.vansairforce.net/articles/FrankEldridge0.pdf > > Best of luck, > > Frank > > -- Rich ________________________________________________________________________________
Date: Mar 08, 2004
Subject: experience with prop governor on fresh engine
Date: Mar 08, 2004
I started my engine (AeroSport IO-360-A1B6) for the first time on Saturday, and everything went perfectly with the exception of the prop (Hartzell C2YK) not cycling. At 1700 RPM, I pulled the prop control all the way out and nothing happened after 3 seconds. Back to full forward. Another try, nothing happened for 5 seconds. Total running time was about 9 minutes. I figured, and others mentioned, that the likelihood is that oil is still slowly getting up to the prop hub, and that eventually it'll work. I temporarily disconnected the end of the prop oil hose and it there was oil there. Cool, I guess I can live with this for now...look forward to testing it again on the 2nd run. Today I ran it for the second time to do some more tests. At 1800 RPM, I pulled the prop control and held it for 5 seconds, nothing. Repeated that, nothing. Then, finally on the 3rd try it started to cycle. After a few cycles, the most I could get it to do was drop from 1800 RPM down to 1650 or so. That's with the prop control pulled out and held out for several seconds. Today's engine running time, 6 minutes. Total engine running time, 15 minutes. Now...I have to throw out a couple of data points: a) I have the "new" Jihostroj (aka "MT") prop governor that I bought from Van's with my FWF kit. b) Because of limited cable travel, the arm on the governor doesn't hit the full-out stop. I have the cable adjusted so that the governor arm does hit the fine pitch stop, but when I pull the control all the way out, it goes maybe 75% of the way through the arc. Van's FWF instructions mentioned that it's not critical that the coarse pitch stop be hit...but of course I'm skeptical. So here are my questions: 1) I would like to see a bigger RPM drop than 150 RPM! I expect it would be capable of producing a 500 RPM drop or thereabouts. Is it normal behavior that a prop hub would take a while to fill up and become responsive? Has anybody else experienced this, where eventually the hub fills up enough to be normally responsive? I'd rather not keep running the engine on the ground if I can avoid it. 2) Does anybody know if Jihostroj or any other supplier makes/sells a shorter arm for the governor? That would at least rule out the arm travel issue being the cause. 3) On my next and theoretically final engine run before flight, I'm going to do a full power run-up. Should I just wait until I do that test to see if the prop becomes more responsive? If anybody has any tips before I start diving in deeper please let me know. Thanks in advance, )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: Dynon flush mount
Date: Mar 08, 2004
> >Anyone out there have pictures of the Dynon flush mounted? > >Thanks. >Ken Go thee here: http://home.comcast.net/~jwdanie/Panel/panel.html Brian Denk RV8 N94BD RV10 '51 ________________________________________________________________________________
Date: Mar 08, 2004
Subject: Re: experience with prop governor on fresh engine
>b) Because of limited cable travel, the arm on the governor doesn't hit the >full-out stop. I have the cable adjusted so that the governor arm does hit >the fine pitch stop, but when I pull the control all the way out, it goes >maybe 75% of the way through the arc. Van's FWF instructions mentioned that >it's not critical that the coarse pitch stop be hit...but of course I'm >skeptical. You should be fine, I have the same govenor but with the WW 151 prop. I used the "factory demo prop" which was shimmed tightly and it would cycle down in RPM but did not have enough umph to climb back up to starting RPM. Now I have my prop installed and it cycles just fine. This is just an example of a tight prop and not so tight prop. >1) I would like to see a bigger RPM drop than 150 RPM! I expect it would be >capable of producing a 500 RPM drop or thereabouts. Is it normal behavior >that a prop hub would take a while to fill up and become responsive? Has >anybody else experienced this, where eventually the hub fills up enough to >be normally responsive? I'd rather not keep running the engine on the >ground if I can avoid it. I bet you need to run it up a little higher on the RPM. New prop could be stiff, as mentioned above. Try 2k RPM if it does not work there then somethig is wrong, in my opinion but I am no expert. > >2) Does anybody know if Jihostroj or any other supplier makes/sells a >shorter arm for the governor? That would at least rule out the arm travel >issue being the cause. If you need a shorter arm then somehting else is wrong. >3) On my next and theoretically final engine run before flight, I'm going to >do a full power run-up. Should I just wait until I do that test to see if >the prop becomes more responsive? Full power??? What are you going to tie it to? You are going to tie it down right? At full power on my 8a I tied it to a tree (a big one) and I drag the tires and jump the chocks on all three wheels before I even get to full power. Surprised the rope streached that much!! > >If anybody has any tips before I start diving in deeper please let me know. I am sure that at higher RPM the prop will cycle fiine.....I hope. Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 08, 2004
Beware on take off that if there is air in the govenor system the RPM will surge and REALLY get your attention. I saw this happen a few weeks back on a guys rocket. Really got his attention!! > >I started my engine (AeroSport IO-360-A1B6) for the first time on Saturday, >and everything went perfectly with the exception of the prop (Hartzell C2YK) >not cycling. At 1700 RPM, I pulled the prop control all the way out and >nothing happened after 3 seconds. Back to full forward. Another try, >nothing happened for 5 seconds. Total running time was about 9 minutes. > >I figured, and others mentioned, that the likelihood is that oil is still >slowly getting up to the prop hub, and that eventually it'll work. I >temporarily disconnected the end of the prop oil hose and it there was oil >there. Cool, I guess I can live with this for now...look forward to testing >it again on the 2nd run. > >Today I ran it for the second time to do some more tests. At 1800 RPM, I >pulled the prop control and held it for 5 seconds, nothing. Repeated that, >nothing. Then, finally on the 3rd try it started to cycle. After a few >cycles, the most I could get it to do was drop from 1800 RPM down to 1650 or >so. That's with the prop control pulled out and held out for several >seconds. Today's engine running time, 6 minutes. Total engine running >time, 15 minutes. > >Now...I have to throw out a couple of data points: > >a) I have the "new" Jihostroj (aka "MT") prop governor that I bought from >Van's with my FWF kit. > >b) Because of limited cable travel, the arm on the governor doesn't hit the >full-out stop. I have the cable adjusted so that the governor arm does hit >the fine pitch stop, but when I pull the control all the way out, it goes >maybe 75% of the way through the arc. Van's FWF instructions mentioned that >it's not critical that the coarse pitch stop be hit...but of course I'm >skeptical. > >So here are my questions: > >1) I would like to see a bigger RPM drop than 150 RPM! I expect it would be >capable of producing a 500 RPM drop or thereabouts. Is it normal behavior >that a prop hub would take a while to fill up and become responsive? Has >anybody else experienced this, where eventually the hub fills up enough to >be normally responsive? I'd rather not keep running the engine on the >ground if I can avoid it. > >2) Does anybody know if Jihostroj or any other supplier makes/sells a >shorter arm for the governor? That would at least rule out the arm travel >issue being the cause. > >3) On my next and theoretically final engine run before flight, I'm going to >do a full power run-up. Should I just wait until I do that test to see if >the prop becomes more responsive? > >If anybody has any tips before I start diving in deeper please let me know. > >Thanks in advance, >)_( Dan >RV-7 N714D >http://www.rvproject.com > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 08, 2004
Subject: RE: RV-List: Backer board for interior panels --> I used POLYBOARD Durable, Waterproof Corrugated Polyethylene Board. Obtained from http://www.airtexinteriors.com/catalogue/misc.htm Lightweight, Easy to handle, fireproof, cheap. You can see some results here. Go to finishing/interior http://www.mstewart.net/michael/rv/index.htm Good stuff. Mike Mike: I do not believe polyethylene in any form is fireproof. It is a polymerized hydrocarbon that may have color added. If it is black, the color is carbon black. If you've ever seen a polyethylene fire you'll want to be elsewhere. The soot is unbelievable. Gordon Comfort N363GC ________________________________________________________________________________
Date: Mar 08, 2004
Dan, First of all, DO NOT fly it unless it works properly on the ground. If the propr system still has air nasty things can/will happen if you try to fly it. Vans is right about the control arm on the prop governor. It does not need to travel the full length as long as it works OK. At this point it isn't yet know if it is working ok so I would wait. Brand new props and the new Jihostrou governor are tight to start out with. I would suggest doing some more ground run first. Try going up to 2500 and cycling the prop then. And I would tie the plane to something very heavy first. Mike Robertson >From: "Dan Checkoway" <dan(at)rvproject.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: experience with prop governor on fresh engine >Date: Mon, 8 Mar 2004 12:56:58 -0800 > > >I started my engine (AeroSport IO-360-A1B6) for the first time on Saturday, >and everything went perfectly with the exception of the prop (Hartzell >C2YK) >not cycling. At 1700 RPM, I pulled the prop control all the way out and >nothing happened after 3 seconds. Back to full forward. Another try, >nothing happened for 5 seconds. Total running time was about 9 minutes. > >I figured, and others mentioned, that the likelihood is that oil is still >slowly getting up to the prop hub, and that eventually it'll work. I >temporarily disconnected the end of the prop oil hose and it there was oil >there. Cool, I guess I can live with this for now...look forward to >testing >it again on the 2nd run. > >Today I ran it for the second time to do some more tests. At 1800 RPM, I >pulled the prop control and held it for 5 seconds, nothing. Repeated that, >nothing. Then, finally on the 3rd try it started to cycle. After a few >cycles, the most I could get it to do was drop from 1800 RPM down to 1650 >or >so. That's with the prop control pulled out and held out for several >seconds. Today's engine running time, 6 minutes. Total engine running >time, 15 minutes. > >Now...I have to throw out a couple of data points: > >a) I have the "new" Jihostroj (aka "MT") prop governor that I bought from >Van's with my FWF kit. > >b) Because of limited cable travel, the arm on the governor doesn't hit the >full-out stop. I have the cable adjusted so that the governor arm does hit >the fine pitch stop, but when I pull the control all the way out, it goes >maybe 75% of the way through the arc. Van's FWF instructions mentioned >that >it's not critical that the coarse pitch stop be hit...but of course I'm >skeptical. > >So here are my questions: > >1) I would like to see a bigger RPM drop than 150 RPM! I expect it would >be >capable of producing a 500 RPM drop or thereabouts. Is it normal behavior >that a prop hub would take a while to fill up and become responsive? Has >anybody else experienced this, where eventually the hub fills up enough to >be normally responsive? I'd rather not keep running the engine on the >ground if I can avoid it. > >2) Does anybody know if Jihostroj or any other supplier makes/sells a >shorter arm for the governor? That would at least rule out the arm travel >issue being the cause. > >3) On my next and theoretically final engine run before flight, I'm going >to >do a full power run-up. Should I just wait until I do that test to see if >the prop becomes more responsive? > >If anybody has any tips before I start diving in deeper please let me know. > >Thanks in advance, >)_( Dan >RV-7 N714D >http://www.rvproject.com > > One-click access to Hotmail from any Web page download MSN Toolbar now! http://clk.atdmt.com/AVE/go/onm00200413ave/direct/01/ ________________________________________________________________________________
Date: Mar 08, 2004
In a message dated 03/08/2004 1:03:05 PM Pacific Standard Time, dan(at)rvproject.com writes: At 1700 RPM, I pulled the prop control all the way out and nothing happened after 3 seconds. Back to full forward. Another try, nothing happened for 5 seconds. (Stuff Cut) Today I ran it for the second time to do some more tests. At 1800 RPM, I pulled the prop control and held it for 5 seconds, nothing. Repeated that, nothing. Then, finally on the 3rd try it started to cycle. After a few cycles, the most I could get it to do was drop from 1800 RPM down to 1650 or so. That's with the prop control pulled out and held out for several seconds. Today's engine running time, 6 minutes. Total engine running time, 15 minutes. Hello Dan, On the Hartzell and MT Propeller, the hydraulic propeller has a piston that oil pressure moves in one direction only. There wouldn't normally be any oil in the oil line, crankshaft or the back side of the hydraulic propeller piston on a new installation. Holding the propeller control back will fill the oil line and crankshaft, but it just pushes the air forward into the propeller hub on the first cycle. Cycling the prop control several times will purge the air out of the prop hub. Cycling the prop should be on your checklist as part of the engine run up. On the Lycoming IO-360 engine in my Cherokee Arrow, before I pulled the power back after the mag check at 1800 RPM, I would cycle the prop control until I saw a 500 RPM drop. It usually took two or three cycles for this to occur. On each cycle, I only held the prop control back briefly before it was in the high RPM position again. Jim Ayers Less Drag Products, Inc. An OEM Distributor for MT Propeller ________________________________________________________________________________
Subject: finishing up sequence of events?
Date: Mar 08, 2004
I'm at this stage too. I am planning on using VAN's battery box forward on my -6A but can anyone tell if there will be an interference problem with the prop governor planned for my engine? I would like to mount the box and cut the hole for the cabin heat box prior to mounting the engine. Seems like best to do that prior to engine mounting. Marty in Brentwood TN From: "Vince Himsl" <vhimsl(at)turbonet.com> Subject: RE: RV-List: finishing up sequence of events? Hello, I am there now....It is sort of a chicken and the egg stage isn't it! Well, here's what I am doing: Check with Van's Web Site as they have some additional notes/instructions about mounting the wings, the cowl and I believe the canopy. Main thing is they say to leave off all the engine doodads as they get in the way when mounting the cowl. I haven't mounted the top deck as I am concentrating on firewall penetrations in the vain hope of minimizing the crawling around inside when the top deck is on. I have the engine mounted. Some say to wait till you have mounted the firewall stuff, but I need the engine on to get an idea of where everything goes. I have been held up as I really need to have an idea of the panel before I proceed. I have decided on NO fuel/pressure/copper/etc. lines in the cockpit. NO Vacuum instruments. I elaborate as you need to know this before you start punching holes in the firewall. Everything on the firewall will be nutplated so you can imagine trying to do it with the top deck on. Are you using Lightspeed Electronic Ignition? Then you need to have a Manifold Pressure line to it and the coax cables need to seperated from the return sensor wires. This kind of circular detail can drive one crazy! Another reason I mention the panel is that the side sections (RV-8) of it are best dealt with before permanent installation of the top deck. My ignition switch will go on the right and potentially the carb/cabin heat will go on the left. Also if you can nail down the electrical wire routing (again firewall penetrations) you will be ahead of the game. With apologies to the traditionalists, I am going with Aeroelectric Bob's recommendations. There are other things you can be doing in parallel such as the upholstery, seats, cabin wiring, but you already know that. So wrapping it all up: Focus on the firewall and instrument side penetrations (and fuel lines, but you probably have already done that). Mount the top deck Then pick up with the plans at the Canopy. Of course, that is the game plan for today. Tomorrow could be another story. Regards, Vince Himsl RV8 - SB Finish "Aerosport and Lightspeed, but still procrastinating on the canopy" -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV8ter(at)aol.com Subject: RV-List: finishing up sequence of events? Engine and finishing kit on the way. So what's the preferred order of events between now and riveting on the forward top fuse skin? I can see some things are on an equal level. Here's what I'm thinking. No vacuum system for me. I want to put a Lightspeed on one set of plugs but will wait until after 25 hour fly off. Mount the engine, install engine accessories, fit cowl, exhaust, baffles, oil cooler, fuel and oil hoses/lines, throttle, mixture, governor cables from cockpit, engine monitoring cables and sensors, finish panel, ???, cut canopy, rivet on top skin, finish front baggage door, install windscreen, ??? What have I got out of order or am missing? thanks, lucky ________________________________________________________________________________
Date: Mar 08, 2004
rv-list
Subject: prop governor
Hi Here is a question for those in the know... How would I know which prop governor (woodward, hartzell, et all) would work on a RV with a IO-360 A1B so I don't accidentaly get a feathering governor or one that goes to fine pitch or one that goes to course pitch on oil loss, etc......... Is there a reference list for governors somewhere ??? Thanks Gert -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Subject: diodes
Date: Mar 08, 2004
Thanks Dan, That's kinda what I was thinking. Most of the internal regs are hooked up to both the main diode output and the extra "trio" diodes so I always figured it started on the main, then kicked over to the trio, while comparing the two to monitor overall function. W W., The extra 3 diodes in a pack are called the diode trio (at least in GM alternators). Its function is to provide power to the field (rotor). By using the trio, there is isolation from the battery in a car where there is no main relay as in an airplane. In a car the alternator diodes are hot 24/7. The team I was on back in about 1966 (4 of us at Delco Radio in Kokomo, IN plus some in Anderson, IN at Delco Remy) came up with the idea of putting the idiot light between the diode trio (field +) and the switched battery, and found that it detected about 90% of the faults and required no additional circuitry. Some of today's regulators are much more sophisticated at detecting faults, and many regulate off of the trio voltage if the normal voltage sense line gets unhooked thereby preventing a complete runaway. Hope this helps explain the 3 extra diodes. Dan (Retired electrical automotive engineer) RV-7A ( almost done ________________________________________________________________________________
Subject: RV 10 Tail cone top skins
Date: Mar 08, 2004
For those that have not reached this stage and are concerned about damage to the bottom of the tail cone when riveting, this worked well for me. In my kit there was a large sheet of one inch low density board, I cut pieces to fit between the frames and wide enough to rest on the outboard stiffeners. Then used these as templates to cut identical pieces of plywood from salvage from the shipping containers. With the low density foam board on the bottom and the plywood on top this distributed the weight evenly and gave the piece of mind needed for this part of the process. Eustace Bowhay Blind Bay, B.C. RV 10 # 30- Ribs on L/H wing ________________________________________________________________________________
Subject: Fw: XCOM, Pilot, Lightspeed and customer service.
Date: Mar 08, 2004
Tom Friedland, California, Europa, wrote in the Aeroelectric List:- Hi Rob and anyone else interested in XCom products.. BEWARE! I bought an intercom from them and also had them make up a wiring harness to connect the intercom and switch between two Microair 760s. The intercom appears to be good, clear, light and small. HOWEVER, harness they supplied is totally inadequate. First of all, many the cables were mislabeled which of course meant they were connected incorrectly by me. I emailed Michael Coates, their honcho, and was told he would get right back to me. Did he, NO. I then asked him if I could return the harness to him or at least could he send me a wiring diagram. NO RESPONSE. I have attempted to contact him many times and asked at least if he would send back the $$ I had paid for the harness. NO RESPONSE. Since then, Microair has sent me a proper wiring diagram and I find that XCom did it entirely wrong, used the wrong kind of switch, etc. BEWARE... This customer feedback is very useful. I have recently suffered at the hands of Pilot. Their ear seals on my PA17-76 ANR headset had deteriorated markedly and I emailed them for help since it was within the five year warranty. Unlike the glowing reports of superior customer service from Lightspeed owners I was sorely disappointed. Pilot emailed me saying that everyone knows that ear seals are only good for about twelve months and that if I want a permanent solution I must send $25 for the silicone type. I replied that I felt ear seals on a product with a five year warranty should actually last five years or more. This failed to impress them and I was sent the old type as a replacement - the ones that "everyone knows only last a year". Their words! I suppose they are waiting for my check for $25 sometime next March or April! As Tom Friedland said about XCOM if you are considering a Pilot product, BEWARE! Rob Rob W M Shipley N919RV (res) Fuselage .....still! ________________________________________________________________________________
Date: Mar 08, 2004
Got it working tonight, after talking to Ken Balch, Tom Green at Van's, Bart at AeroSport Power, and after reading various helpful responses (thanks!). Took off the governor oil hose, blew it out to confirm it wasn't blocked. Nothing but a little oil came out, and it was clear. I tweaked the prop cable and governor arm adjustments and got a *tiny* bit more travel. It now gets maybe 80% of full travel. Tom Green confirmed that you don't need full governor actuation, as long as the fine pitch stop is hit. Then I ran it up to 2000 RPM instead of 1800, and I was getting 400-500 RPM drops and the prop was much more responsive. Problem seems to have gone away...not quite sure which of the above factors did it...would have done more isolation testing if I wasn't trying to minimize ground run-time. I figure I'm done running this puppy until first flight. Thanks again for the responses, )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: experience with prop governor on fresh engine > I started my engine (AeroSport IO-360-A1B6) for the first time on Saturday, > and everything went perfectly with the exception of the prop (Hartzell C2YK) > not cycling. At 1700 RPM, I pulled the prop control all the way out and > nothing happened after 3 seconds. Back to full forward. Another try, > nothing happened for 5 seconds. Total running time was about 9 minutes. > > I figured, and others mentioned, that the likelihood is that oil is still > slowly getting up to the prop hub, and that eventually it'll work. I > temporarily disconnected the end of the prop oil hose and it there was oil > there. Cool, I guess I can live with this for now...look forward to testing > it again on the 2nd run. > > Today I ran it for the second time to do some more tests. At 1800 RPM, I > pulled the prop control and held it for 5 seconds, nothing. Repeated that, > nothing. Then, finally on the 3rd try it started to cycle. After a few > cycles, the most I could get it to do was drop from 1800 RPM down to 1650 or > so. That's with the prop control pulled out and held out for several > seconds. Today's engine running time, 6 minutes. Total engine running > time, 15 minutes. > > Now...I have to throw out a couple of data points: > > a) I have the "new" Jihostroj (aka "MT") prop governor that I bought from > Van's with my FWF kit. > > b) Because of limited cable travel, the arm on the governor doesn't hit the > full-out stop. I have the cable adjusted so that the governor arm does hit > the fine pitch stop, but when I pull the control all the way out, it goes > maybe 75% of the way through the arc. Van's FWF instructions mentioned that > it's not critical that the coarse pitch stop be hit...but of course I'm > skeptical. > > So here are my questions: > > 1) I would like to see a bigger RPM drop than 150 RPM! I expect it would be > capable of producing a 500 RPM drop or thereabouts. Is it normal behavior > that a prop hub would take a while to fill up and become responsive? Has > anybody else experienced this, where eventually the hub fills up enough to > be normally responsive? I'd rather not keep running the engine on the > ground if I can avoid it. > > 2) Does anybody know if Jihostroj or any other supplier makes/sells a > shorter arm for the governor? That would at least rule out the arm travel > issue being the cause. > > 3) On my next and theoretically final engine run before flight, I'm going to > do a full power run-up. Should I just wait until I do that test to see if > the prop becomes more responsive? > > If anybody has any tips before I start diving in deeper please let me know. > > Thanks in advance, > )_( Dan > RV-7 N714D > http://www.rvproject.com > ________________________________________________________________________________
Date: Mar 09, 2004
Subject: Re: Backer board for interior panels
I used .016 aluminum ________________________________________________________________________________
Date: Mar 09, 2004
Subject: Rudder Trailing Edge Sealant
Fellow Listers: Please bare with me as I am a new builder. I have searched the archives for an answer to my question by have yet to find it. I used PC-7 two-part epoxy paste I found at my local Ace Hardware to seal my -7 rudder trailing edge. I've had some experience with this stuff before as I used it several several years ago to seal a gas tank leak (more like pour instead of a leak) in a friend's classic Ford Mustang. However, I never had to *remove* it from the Mustang tank. In my overzealous session of sealant application, I used a bit too much and the sealant oozed up through the holes as I clocoed it together. In retrospect, I should have clamped the trailing edge very well to squeeze out the excess sealant or went back after inserting clecoes, remove each one and wipe it clean. I, however, did not do this. Now I have this epoxy stuff on my trailing edge skings. Let me tell you, this stuff is not going anywhere! I even tried using a little aluminum brissled scuffing brush. The brush did a helluva job removing alcad but none of the sealant. I figure I can probably take my die grinder and Scotch Bright wheel to it but I a bit concerned with the thickness (or lack thereof) of the skin. Also, the Scotch Bright wheel/pad will not get into the dimpled holes. I also tried using my deburring bit I got from Cleaveland. This worked well to get rid of the heavy build-up of sealeant, but in the dimples where the sealant is hardened on one side of the dimple, the deburring tool seeems to like the each away at the metal but not at the sealant. Ok listers, any ideas? Jamie RV-7A Rudder ________________________________________________________________________________
Date: Mar 09, 2004
Subject: Re: Rudder Trailing Edge Sealant
Okay listers one question leeds to another. The text of the empanage instructions seemed to indicate that the purpose of the sealant in the rudder was to help insure a straight trailing edge by holding the edge straight during riveting. I've been experimenting with various pieces of scrap and have found that the edge will rivet up "string straight" just by alternating sides with the rivet heads. Is the sealant really necessary? Carroll Jernigan RV-7A Wings ________________________________________________________________________________
Subject: Thanks for the Info
Date: Mar 09, 2004
Thanks for the info on the Airtex Polyboard. I just ordered it. Details for any other builders: 48 x 80 sheet is $12 Shipping is $16 for any quantity between 1 and 6 sheets. So if you can purchase with others it drops delivered cost per sheet. Don "All of us need to be reminded that the federal government did not create the states; the states created the federal government!"---Ronald Reagan Frustrated with dial-up? Lightning-fast Internet access for as low as ________________________________________________________________________________
Date: Mar 09, 2004
They make a "paint remover" that says it will remove epoxy. ----- Original Message ----- From: "Jamie Painter" <jdpainter(at)jpainter.org> Subject: RV-List: Rudder Trailing Edge Sealant > > Fellow Listers: > > Please bare with me as I am a new builder. I have searched the archives > for an answer to my question by have yet to find it. > > I used PC-7 two-part epoxy paste I found at my local Ace Hardware to seal > my -7 rudder trailing edge. I've had some experience with this stuff > before as I used it several several years ago to seal a gas tank leak > (more like pour instead of a leak) in a friend's classic Ford Mustang. > > However, I never had to *remove* it from the Mustang tank. In my > overzealous session of sealant application, I used a bit too much and the > sealant oozed up through the holes as I clocoed it together. In > retrospect, I should have clamped the trailing edge very well to squeeze > out the excess sealant or went back after inserting clecoes, remove each > one and wipe it clean. > > I, however, did not do this. Now I have this epoxy stuff on my trailing > edge skings. Let me tell you, this stuff is not going anywhere! I even > tried using a little aluminum brissled scuffing brush. The brush did a > helluva job removing alcad but none of the sealant. I figure I can > probably take my die grinder and Scotch Bright wheel to it but I a bit > concerned with the thickness (or lack thereof) of the skin. Also, the > Scotch Bright wheel/pad will not get into the dimpled holes. > > I also tried using my deburring bit I got from Cleaveland. This worked > well to get rid of the heavy build-up of sealeant, but in the dimples > where the sealant is hardened on one side of the dimple, the deburring > tool seeems to like the each away at the metal but not at the sealant. > > Ok listers, any ideas? > > Jamie > RV-7A Rudder > > ________________________________________________________________________________
Subject: Very Nice Leather for RV Interiors
Date: Mar 09, 2004
Dear All, I am trying to gauge the market for a product that I may be able to make available to builders. I have access to very nice Leather Hides. These hides are tanned in such a way that the result is much like the leather in a nice car. They are soft but durrable. (I have access to analine leather which is softer and buttery smooth, but thats not appropriate in an RV where you have to stand on the seat to get in. The surface of analine leather is porous) Depending on quantity I would be able to provide the leather to builders for a cost of anywhere from $150 to $175 per hide. These hides are roughly 50 sq ft. One hide should be more than enough for any 2 seat RV including Seats, trim, stick boots. If you want to do all the side panels, you may need 2. Pretty much any color is available. Any interest in this?? Best regards, Don Mei RV-4 3B9 - Chester, CT "All of us need to be reminded that the federal government did not create the states; the states created the federal government!"---Ronald Reagan ________________________________________________________________________________
Date: Mar 09, 2004
I strongly agree and I carry the mini backpack axe made by Gerber. It has a composite handle and is a compact and light extraction tool. I have the pouch rivited to the lower panel and the axe fits perfectly. Wayne Petrus RV8A ________________________________________________________________________________
Subject: BNC fuel tank bulkhead fittings
Date: Mar 09, 2004
Thought I would provide the list with some recent challenges and finding of the capacitive sending units from Vans, and more specifically, issues surrounding the in tank, inboard rib , bulkhead fitting. My trouble started with irratic fuel tank readings. It was all over the place from the gage reading "open" circuit, to wrong reading to correct ones. I replaced the coax, connectors, and so forth and was not able to find the problem. A phonecall to my buddy Delta A&P mechanic Scott Solberg revealed a potential risk, the tank bulkhead BNC connector. Apparently these are common sources of failures in the heavy's and he suggested I take a look. A closer inspection found that I had in fact, fuel weeping coming out of the center pin of the connector. I pulled the tank, pulled the access plate and covered the back of the fitting with proseal. I remounted the tank. 4 flight hours later, problem is back, worse than ever. When I pulled the tank this time, with an intention of replacing the connector, I noticed the white insulator in the bnc connector was deteriorated, cracked, and crumbling. Turns out the connector is not fuel proof and is does dry out and crack. My connector has only been in the fuel for 2.5 years. So, I decided there was no sense in replacing the connector with another one. I was able to push out the center pin of the bulkhead fitting and pull my 22 gauge wire through it and have it hanging outside the tank. I prosealed it in place and now have what I feel is a permanent solution to the problem. The gauge only needs to get the signal from the center conductor, and have a ground back to the tank. I did find this bnc connector issue in the archives but do not recall anyone ever really discussing it. So a word to the wise... Devise a better method of getting the wire out of the tank other than the bnc connector. Once the plastic insulator gets fuel on it, it will deteriorate. Oh and one more thing. One of my nightmares was getting the screws out of the mounted tank w/o chipping the tank paint. After chipping paint off the tank of about 30 screws, I found a solution. A number 6 aluminum fuel line has the same inside diameter as a number 8 screw head. I took the tube to the belt sander and sanded a sharp tapered edge so the I could turn the tube over the screw head and it would cut the paint. This worked really well and I would recommend this for any first time screw removal where the screw was painted in place. Regards, Michael Stewart Tank doesn't leak, and the gauge is back working. ________________________________________________________________________________
Subject: RE: RV 10 Tail cone top skins
Date: Mar 09, 2004
Mr. Bowhay; Why do I get this feeling that your "10" will have a set of floats???!!! Bruce Breckenridge 40018 ________________________________________________________________________________
Date: Mar 09, 2004
do you have a picture? where can you get the axe? On Mar 9, 2004, at 8:54 AM, Dwpetrus(at)aol.com wrote: > > I strongly agree and I carry the mini backpack axe made by Gerber. It > has a > composite handle and is a compact and light extraction tool. I have > the pouch > rivited to the lower panel and the axe fits perfectly. > > Wayne Petrus > RV8A > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > Jason Sneed Commercial Lending Officer First National Bank and Trust ________________________________________________________________________________
From: "John Wiegenstein" <N727JW(at)hellerwiegenstein.com>
Subject: Weatherstrip Adhesive
Date: Mar 09, 2004
Just finishing up those last details, and I'm having trouble getting the weatherstrip in front of the canopy on my -6 tipup to stay in place. I've tried 3M 8008 weatherstrip adhesive, and also Permatex weatherstrip cement, but the problem with both is that while they stick well to the metal structure, they don't adhere well to the rubber. I've cleaned the rubber before use with AcryliClean, to make sure there's no residue, etc. but still no luck. Any recommendations on an adehsive that works, or a better technique? TIA - John H. Wiegenstein Hansville, WA RV-6 #23961 - N727JW (reserved) ________________________________________________________________________________
Date: Mar 09, 2004
Subject: Re: Weatherstrip Adhesive
I would bond in place with a silicone that is made specifically for bonding rubber. If that does not work use a silicone primer such as: DOW CORNING 1200 RTV PRIME COAT/CLEAR This stuff makes a big difference. > > >Just finishing up those last details, and I'm having trouble getting the >weatherstrip in front of the canopy on my -6 tipup to stay in place. I've >tried 3M 8008 weatherstrip adhesive, and also Permatex weatherstrip cement, >but the problem with both is that while they stick well to the metal >structure, they don't adhere well to the rubber. I've cleaned the rubber >before use with AcryliClean, to make sure there's no residue, etc. but still >no luck. > >Any recommendations on an adehsive that works, or a better technique? TIA - > >John H. Wiegenstein >Hansville, WA >RV-6 #23961 - N727JW (reserved) > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 09, 2004
Dave, Mine split on the wheel pant line and are glassed to the wheel pant. Bob Fairings-Etc www.fairings-etc.com ________________________________________________________________________________
Date: Mar 09, 2004
Subject: Aluminum MT Propeller group buy
Hi All, I am just starting a group buy for the aluminum 2 blade MT Propeller for the Lycoming 360 engine. I need to have 16 firm orders, so I can place one order for the group. I am also accepting the names from people that would be interested in a future group buy. This is the NEW aluminum 2 blade MT Propeller that does NOT have a midrange RPM restriction on the Lycoming 360 engine. The propeller for this group buy is the MTV-15-C/183-402 propeller including spinner. The group buy price is $5,350 completely assembled in Southern California (eliminating $610 to $760 in customer shipping and assembly costs). Shipping the assembled propeller to the individual customer would be extra. Typically less than $150 shipped UPS Ground when sent to Florida or Washington State. Please respond off list to lessdragcom(at)aol.com Jim Ayers Less Drag Products, Inc. lessdragcom(at)aol.com ________________________________________________________________________________
Date: Mar 09, 2004
Subject: AirVenture Cup Race
Anyone planning to enter this year's race? The route has changed ... race is from Dayton to Oshkosh. Airventure Race 2004 Len Leggette, RV-8A Greensboro, NC N910LL 214 hrs ________________________________________________________________________________
Date: Mar 09, 2004
Subject: [ Rob Ray ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Rob Ray Subject: RV3 pictures... http://www.matronics.com/photoshare/smokyray@yahoo.com.03.09.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: RE: Leeward Air Ranch
Date: Mar 09, 2004
Chuck, Leeward Air Ranch is just SE of Ocala, Florida. It is truly RV Heaven. 6250' X 200' Allweather Turf that's as smooth as a pool table. There have been 30 RV's born at Leeward Air Ranch. just over a hundred residents and over half of them are either homebuilders or Warbird/Antique Restorers. We have all jigs, special tools, fixtures, and expertise right here on the airranch to handle most any aircraft related project. Esten Spears, RV8A, 80922, N922ES (reserved), Leeward Air Ranch, Ocala, FL From: "C. Rabaut" <crabaut(at)coalinga.com> Subject: Re: RV-List: "We Love RV's" Gathering at Leeward Air Ranch Esten, What state is this Air Park located in? (might consider retiring there). Chuck ----- Original Message ----- From: Esten Spears <ewspears(at)comcast.net> Subject: RV-List: "We Love RV's" Gathering at Leeward Air Ranch > > You are invited to view a Photo Album from Esten Spears. > > Hope you like the RV8/P51 formation shots. It was a real handful for the RV Pilots since the 25 knot gusts and turbulence pushed them around a lot more than the P51. > ________________________________________________________________________________
Subject: Re: RE: Leeward Air Ranch
Date: Mar 09, 2004
Esten, where will I find your photo album?? Pictures from last Sat's get together?? Started out in my Citabria but my ground speed was 50 mph at 1500 feet. It would have been a major X-country. I have a six ready to assy and paint. Sorry I missed out. JW ----- Original Message ----- From: Esten Spears<mailto:ewspears(at)comcast.net> To: rv-list(at)matronics.com Sent: Tuesday, March 09, 2004 1:29 PM Subject: RV-List: RE: Leeward Air Ranch Chuck, Leeward Air Ranch is just SE of Ocala, Florida. It is truly RV Heaven. 6250' X 200' Allweather Turf that's as smooth as a pool table. There have been 30 RV's born at Leeward Air Ranch. just over a hundred residents and over half of them are either homebuilders or Warbird/Antique Restorers. We have all jigs, special tools, fixtures, and expertise right here on the airranch to handle most any aircraft related project. Esten Spears, RV8A, 80922, N922ES (reserved), Leeward Air Ranch, Ocala, FL From: "C. Rabaut" <crabaut(at)coalinga.com<mailto:crabaut(at)coalinga.com>> Subject: Re: RV-List: "We Love RV's" Gathering at Leeward Air Ranch Esten, What state is this Air Park located in? (might consider retiring there). Chuck ----- Original Message ----- From: Esten Spears <ewspears(at)comcast.net<mailto:ewspears(at)comcast.net>> Subject: RV-List: "We Love RV's" Gathering at Leeward Air Ranch > > You are invited to view a Photo Album from Esten Spears. > > Hope you like the RV8/P51 formation shots. It was a real handful for the RV Pilots since the 25 knot gusts and turbulence pushed them around a lot more than the P51. > ________________________________________________________________________________
Date: Mar 09, 2004
My question is what to use for a backer board. I have some Luan, but it is heavy. I'm hoping the list can provide some other ideas for a rigid, light backer board. Don, Use the corregated plastic they use for all those unsightly signs that people stick all over the roadways. (Lose 20 pounds in one week; Earn $$$ at home on your computer; We buy homes for cash!; etc) The plastic is light, water resistant, bonds easily to fabric or leather and you will be doing the environment a favor by removing the signs from the roadway. Signs posted on telephone poles and on the public right-of-way are illegal and you can remove them with impunity. Have at it! Ron Schreck RV-8 Gold Hill, NC ________________________________________________________________________________
Date: Mar 09, 2004
I had good luck with 3M 8008 Weather-strip adhesive, but only after carefully preparing the surfaces. For the rubber weather-strip, I wiped the bonding surface with acetone, scrubbed with (grey) Scotchbrite and wiped with acetone, again. The rubber gasket on my -4 canopy has been on for about 2 years and still seems well-bonded. Good luck, Dean >From: "John Wiegenstein" <N727JW(at)hellerwiegenstein.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Weatherstrip Adhesive >Date: Tue, 9 Mar 2004 08:02:12 -0800 > > > >Just finishing up those last details, and I'm having trouble getting the >weatherstrip in front of the canopy on my -6 tipup to stay in place. I've >tried 3M 8008 weatherstrip adhesive, and also Permatex weatherstrip cement, >but the problem with both is that while they stick well to the metal >structure, they don't adhere well to the rubber. I've cleaned the rubber >before use with AcryliClean, to make sure there's no residue, etc. but >still >no luck. > >Any recommendations on an adehsive that works, or a better technique? TIA >- > >John H. Wiegenstein >Hansville, WA >RV-6 #23961 - N727JW (reserved) > > Get a FREE online computer virus scan from McAfee when you click here. ________________________________________________________________________________
"'pilots2(at)yahoo.com'"
Subject: 21 years
Date: Mar 09, 2004
Hey Bilinski, your 21 years got stolen right out of my hangar by some guy named Reuven Silberman? pilots2(at)yahoo.com ain't life a bitch ________________________________________________________________________________
Date: Mar 09, 2004
From: Gert <gert(at)execpc.com> rv-list Subject: RV-List: prop governor Check with your prop/governer rebuilder. I have purchased many cheap (200/300$) governers and had them reconfigured for my application by the prop shop. There are interchangable bleed and bypass orfices, check valves, counter weights that can be matched for your application. In my case, I told my rebuilder that I have a certain model Hart$ell prop with a lycoming 260hp 0-540. He matched up the innerds of the governer, verivied all bearings and declaired it airworthy and it workes fine. I got a Pesto brand, which is the same as a Woodward (or Garwin) in that Woodward purchased the rights from Pesto and Garwin and others for manufacture under the Woodward name.....most of the internal parts are interchangable, reversable and seldom wear out in that they are bathed in oil all the time. Locate some used rebuildable cores, verify the model number with a rebuilder and your engine/prop application to see if the core is useable in you specific circumstance. Found my cores on Barnstormers and E-bay, Mikes Pro-Prop in Pennsylvania rebuilt them for me. If memory serves, I paid about 225 for a core and another 195 dollars for the rebuild. (Not a FAA/PMA/TSO/Certified Yellow taged/Certified Paper trail/taged item....the governer had a repair tag only from the rebuilder). In my case and application it worked out great to get a working, calabrated and useable governer for about 400 dollars total.. How would I know which prop governor (woodward, hartzell, et all) would work on a RV with a IO-360 A1B so I don't accidentaly get a feathering governor or one that goes to fine pitch or one that goes to course pitch on oil loss, etc......... Is there a reference list for governors somewhere ??? Thanks Gert ________________________________________________________________________________
Date: Mar 09, 2004
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Re: 21 years
Which one is he? Oh yea, the goof ball in front of Steve. Ok he has it for one month then he is on my list!! http://www.sdccd.net/public/events/we/Online/May2003/flyboys.jpg > >Hey Bilinski, > >your 21 years got stolen right out of my hangar by some guy named Reuven >Silberman? > >pilots2(at)yahoo.com > >ain't life a bitch > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 09, 2004
Subject: Re: >Re:Wing Attach Questions
With a Nyloc nut you should have at least one thread through the nut(As previously stated,be able to catch your fingernail on it). You must not have more than four threads showing(The nut will be bottomed on the threads). Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Mar 09, 2004
Mike, Sorry to here about this. Glad you have solved the problem. When you get a chance would you please send me a few of the air to air photo's Mitchell took on the Kentucky trip? Thanks, Mike Mckenna -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Stewart, Michael (ISS Atlanta) Subject: RV-List: BNC fuel tank bulkhead fittings Thought I would provide the list with some recent challenges and finding of the capacitive sending units from Vans, and more specifically, issues surrounding the in tank, inboard rib , bulkhead fitting. ________________________________________________________________________________
Subject: Aligning gear leg fairings
Date: Mar 09, 2004
If you flew your airplane without gear leg fairings and it flew straight--without needing rudder trim, then you "aligned" and strapped on leg fairings and now you need right rudder all of a sudden, which way would you turn the trailing edge of the fairings, from the pilots perspective? (Of course I'm asking this for a friend--yea thats it) Dave Ford RV6 ________________________________________________________________________________
Date: Mar 09, 2004
Subject: Re: [ Rob Ray ] : New Email List Photo Share Available!
I notice that it was placarded for non-aerobatics only. Why would that be? Is it something common in RV-3s that I should have known about? Regards, Paul RV-7 or 8 preview plans stage On 3/9/04 09:44, "Email List Photo Shares" wrote: > > > > A new Email List Photo Share is available: > > Poster: Rob Ray > > > Subject: RV3 pictures... > > > http://www.matronics.com/photoshare/smokyray@yahoo.com.03.09.2004/index.html > > > o Main Photo Share Index > > http://www.matronics.com/photoshare > > o Submitting a Photo Share > > If you wish to submit a Photo Share of your own, please include the > following information along with your email message and files: > > 1) Email List or Lists that they are related to: > 2) Your Full Name: > 3) Your Email Address: > 4) One line Subject description: > 5) Multi-line, multi-paragraph description of topic: > 6) One-line Description of each photo or file: > > Email the information above and your files and photos to: > > pictures(at)matronics.com > > > > > ________________________________________________________________________________
Date: Mar 09, 2004
Subject: Re: Aligning gear leg fairings
They would turn just like the wheels of a car. If you want them to turn right (so you won't have to hold the rudder) turn them to the right (trailing edge to the left). That's a lot of reversals! Dan RV-7A (almost done) In a message dated 3/9/04 9:00:55 PM US Eastern Standard Time, dford(at)michweb.net writes: > > > If you flew your airplane without gear leg fairings and it flew > straight--without needing rudder trim, then you "aligned" and strapped on leg fairings > and now you need right rudder all of a sudden, which way would you turn the > trailing edge of the fairings, from the pilots perspective? (Of course I'm > asking this for a friend--yea thats it) > > Dave Ford > RV6 > ________________________________________________________________________________
Date: Mar 09, 2004
I am going to do mine, too. I made panels of 1/2 inch foil backed foam and have cut material, thin cloth (light wt) and was not planning any "backer board". Do I need it? hal At 09:26 AM 3/8/2004, you wrote: > >Dear All, > >I am sprucing up the interior of my RV. One of the things I'm attempting to >do is make it warmer and quieter for my wife. > >To that end I have some leather for upholstery, and some foil backed. 3/8 >inch foam. I plan to make a sandwich with the leather, foam, and a backer >board. > >My question is what to use for a backer board. I have some Luan, but it is >heavy. I'm hoping the list can provide some other ideas for a rigid, light >backer board. > >Thanks, > >Don Mei > > ________________________________________________________________________________
Date: Mar 09, 2004
Subject: Re: Wing Attach Questions...
Bolt can go in either way. With the 6A some *MUST* go in facing opposite of convention as I recall. In any case, convention is nut aft if there are no other restrictions. Washer under nut, usually, since the turning nut would otherwise scratch the member. Washer under bolt head if turning the bolt to tighten. No black magic, just protect the expensive part from being scored and scratched with a cheap washer. K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Subject: SteinAir
Date: Mar 09, 2004
Just received a Dynon EFIS D-10 (shielded) harness, ALTRAK Altitude Hold Auto-Pilot harness and Trio Avionics EZ Pilot (wing-leveler auto-pilot) harness from SteinAir today. The quality is OUTSTANDING!!!! And to top it off... the prices for the harnesses were less than what it would have cost me in material alone, not to mention the time and aggravation to wire them myself.... I'm somewhat "electronically challenged". I highly recommend anyone needing a harness for your Dynon, ALTRAK, or EZ Pilot contact Stein. I could have wired these harnesses myself..... but why?. At the prices he charges and quality of the harnesses... I am $$$ and time ahead by ordering them from SteinAir (www.steinair.com). The customer support is the best I have ever experienced. Stein actually made all my harnesses and shipped them out within 24 hours of placing the order. (Dynon harness was on the shelf... but the ALTRAK and EZ Pilot harnesses were built within hours of my order and shipped the very next day!) SteinAir is now offering Toggle Switch Covers in a variety of colors (black, red, white, yellow and green). They really dress of the panel and make identifying toggle switches easier than reading placards and labels. Again, the price is right. The covers are listed on the website under SWITCHES. I can't say enough good things about SteinAir. The service/customer support is superb and the harnesses are AWESOME!!!! Very professional. Stein is also a fellow RV builder/owner (repeat offender with 2 RV-6s) and I think we should all support these guys every chance we get. Sorry to rant.... I just had to publically show my appreciation to a guy in this business who deserves some KUDOS for a job well done. Jack Lockamy Camarillo, CA RV-7A wiring (seeing the light at the end of the tunnel.... Thanks Stein!) NOTE: I am not affiliated with SteinAir. Just a very satisfied customer. ________________________________________________________________________________
Subject: RV3/4 Round cowl inlet size
Date: Mar 09, 2004
Hi Listers, I'm considering using round cowl inlets and an aluminum plenum on my RV3 with an 0320. Does anyone know the proper dia. of a round inlet and how this compares to the size/area of Van's std oblong inlet. Thanks, Rick Fogerson RV3 engine baffling Boise, ID ________________________________________________________________________________
Date: Mar 10, 2004
Subject: Re: RV3/4 Round cowl inlet size
The number I just read was outlet is 78% smaller than inlet. > >Hi Listers, >I'm considering using round cowl inlets and an aluminum plenum on my RV3 >with an 0320. Does anyone know the proper dia. of a round inlet and how >this compares to the size/area of Van's std oblong inlet. >Thanks, >Rick Fogerson >RV3 engine baffling >Boise, ID > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 10, 2004
Call Dave Anders at (559) 627-3375. He has it all worked out and sells the machined rings for each size engine. John -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Rick Fogerson Subject: RV-List: RV3/4 Round cowl inlet size Hi Listers, I'm considering using round cowl inlets and an aluminum plenum on my RV3 with an 0320. Does anyone know the proper dia. of a round inlet and how this compares to the size/area of Van's std oblong inlet. Thanks, Rick Fogerson RV3 engine baffling Boise, ID ________________________________________________________________________________
Subject: RV-List Digest Shipping Heavy stuff - Good idea (Cheap way to
ship & Move heavy items)
Date: Mar 10, 2004
Some may be aware of this concept in shipping large, heavy boxes or engines....I wasn't until I read this post from the Zenair list. It involves use of a shipping broker, (like a travel agent for boxes). Also, I too have used the home depo stake bed truck for aviation related local moves of heavy stuff. Can't beat the price. I moved a heavy engine from the hanger to the house for about 23$. I timed the use of the truck with some heavy item I purchased from Home Depo..I recall I purchased a pallet of mulch last spring; really didn't need the mulch, but I needed the engine home and the mulch was heavy enough to rent the truck from Home Depo. ...................repost.................... Shipping Broker Idea............................. Occasionally, those of us in the Homebuilt Aircraft world, find a need to ship something too large or heavy to send by UPS. Then you start calling Freight Companies only to find that the charges are more than what the item being shipped cost. I thought I would relate my experience with this and offer some tips to make the process more bearable for others. I bought my Corvair engine from a guy in New Hampshire. Since it weighs somewhere between 250-300 pounds with the pallet, I knew UPS wasn't going to touch it. My first call to a Freight Company yielded a quote of $500. They also acted like I was bothering them with my request for a residential shipment. I made a couple of other calls that didn't go much better. A web search turned up some companies that are Freight Brokers. "What the heck is a Freight Broker?" was my first question. Apparently, they are like a travel agent for freight. Since they deal with many shipments a day, versus the few we do in a lifetime, they get a discount and we don't. I guess this is going to turn out as an advertisement, but I don't mind blowing someone's horn if I'm happy with their service/product. I ended up using Freight Quote to arrange my shipping. Wylie Yates was my advisor with this and he helped me get the cost down to $190. Wylie's number is 800-323-5441 ext. 1761. If you call him, let him know that Randy Stout told you about Freight Quote. BTW, I get nothing for this. I just told him that if I were happy with everything, I would put the word out. One of the biggest money savers in shipping is to get away from the Residential to Residential shipment. Some of these guys charge over $100 just to go to a residence. It's even more if they have to have a lift on the truck. That's $100 + on both ends if it's residential to residential. I think the best deal is to drop off and pick up at the terminal. Even if you are ordering your kit from Zenith or another business, you can request a terminal pick up. This is great if you have a pickup (if it will fit) or a trailer. They will usually load it in the truck for you at the terminal. A case of beer and a few friends will usually get it off the truck later. Uhh, don't bring out the beer until they get the truck unloaded. If you don't have a truck or trailer, and can't find someone to loan you one, check out Home Depot. Most of them have a flat bed truck you can rent by the hour for $20 or so. Even U-haul is cheaper than a residential delivery ________________________________________________________________________________
Subject: poker run
Date: Mar 10, 2004
POKER RUN When: Saturday, March 13th, 2004 8am =96 12 noon Where: Bessemer, AL (EKY) Who: Bessemer Pilots Association Cost: $10.00 The Bessemer Pilots Association will be having a March Poker Run. The event is open to any and all interested. The airports of the Poker Run will be: Pell City (PLR 2.98) (Sammies restaurant) Hartselle (5M0 2.05) Cullman (3A1 2.25) Jasper (JFX 2.76) Bessemer (EKY 2.87) You may start at any airport, but you MUST end at Bessemer. At each airport, stop by the FBO and pickup a card and sign the airport=92s Poker Run Log. When you turn in your cards at Bessemer, you can pay the $10 registration fee which includes lunch. All proceeds will be placed in a pot which will be awarded to the pilot with the best hand. Pilots are encouraged to bring a friend and introduce them to the joys of General Aviation. They may register for a hand as well, but all players are limited to one (1) hand. For questions, email Glenn Wilson at pilot(at)ekybpa.org or check out our website at: http://www.ekybpa.org/ Jason Sneed Commercial Lending Officer First National Bank and Trust www.highland-parks.com/n242ds/ ________________________________________________________________________________
Date: Mar 10, 2004
Subject: RV6 slider defrosters
to the 6 slider drivers...especially in the Northern climates. Have some "muffin" fans that I purchased a couple of years ago that were intended for installation in the top forward skin just aft of the windscreen on my 6 slider for clearing the windscreen on cold days. Have the wiring etc.finished and will soon be putting the top forward skin on. Now am flip/flopping on the need for the fans. Would appreciate comments/advise on the merits of putting the in the fans. Dale Ensing ________________________________________________________________________________
Date: Mar 10, 2004
Subject: RV-7A Painter needed
Is there an experienced RV painter in the Indianapolis or Northern Indiana area who would like the job of painting my RV-7A? It has not flown yet, and I can bring you all the parts on a trailer. Dan Hopper (located near Grissom ARB in North Central IN) ________________________________________________________________________________
Date: Mar 10, 2004
From: Charlie & Tupper England <cengland(at)netdoor.com>
Subject: Alternate pitot location (was [Fwd: RE: [BD4] Heated Pitot] )
Thought this might be of interest as a backup pitot location. The cooling plenum location has been tested by a RV repeat offender & it worked for him. Since it works on more than one airframe, I thought it worth mentioning. I'll let him chime in if he's willing. Charlie -------- Original Message -------- Subject: RE: [BD4] Heated Pitot Date: Wed, 10 Mar 2004 00:17:13 -0800 From: Steve Mahoney <mahoney(at)viclink.com> <bd4@northwest-aero.com> Craig, In regards to Pitot heat.I built one that consumes no electrical power. I too had some of the same concerns about the current draw and running those big heavy wires that far out on the wing. Besides that, those heated pitot tubes are big and add drag. I too fly IFR (some) I pick my battles very carefully as the BD is a hand full for me in actual conditions and I really don;t have that much IFR time in it yet. I < snipped> Enough story ........and on to the details of problem solving ..... I noted some time back that when I was doing cooling tests, I installed a small pitot tube in the front right air inlet to make some pressure measurements and this location mapped almost perfectly to my airspeed indicator, even at slow speed and high angles of attack. So I made one out of brass, as this conducts heat very well and stuck it between the fins on the forward cylinder. I have a small switch so I can select the airspeed indicator source from either the heated Cylinder or the pitot tube on the wing. It works well for me as my air inlets are oversized and thus map to the airspeed indicator fairly closely. Consumes no Juice . I will try the post a copy of pictures of this on the web at bd-4.org Steve Mahoney ________________________________________________________________________________
Subject: Audio Isolation Amplifier in my intercom system
Date: Mar 10, 2004
Listers: I built and installed the monophonic version of the Audio Isolation Amplifier that was designed by Bob Knuckolls. I connected its output to the input of my Flightcom intercom. Unfortunately, it doesn't seem to work for me. Has anyone out there built the monophonic version with success? Can anyone tell me how I can troubleshoot it to see what is wrong? Thanks, Jordan Grant RV-6 wiring N198G Reserved ________________________________________________________________________________
Date: Mar 10, 2004
Subject: Gretz Electric elevator trim Travel question.
Hello IM in need of some help I have installed the Gretz Aero electric elevator trim kit and I can't get the correct throw in the elevator trim tab. As per van's instructions I need 35 Degrees up and 25 down the best I can seem to do is 20 up and 15 down I have played around with different size horns but with little luck. I went threw the archive's and saw others with the same problem but didn't see a solution to solve the problem. If someone has come up with a solution for this problem or tell me what I might of missed I would appreciate it. Thanks Bill H RV-6 ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Mar 10, 2004
> to the 6 slider drivers...especially in the Northern climates. > > Have some "muffin" fans that I purchased a couple of years > ago that were > intended for installation in the top forward skin just aft of > the windscreen on my > 6 slider for clearing the windscreen on cold days. Have the wiring > etc.finished and will soon be putting the top forward skin > on. Now am flip/flopping on > the need for the fans. Would appreciate comments/advise on > the merits of > putting the in the fans. > Dale Ensing Dale, put them in. I find that they are necessary when the temp is below 10F, particularly when there are two souls on board. Alex Peterson Maple Grove, MN RV6-A N66AP 443 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Mar 10, 2004
There is no reason for the travel to change since you are using the same servo. The only thing that comes to mind is the hole in the elevator spar for the cable. As the elevator moves up and down, is the cable binding and hitting the hole opening as it moves? I recall having that problem when Installing mine some time ago and had to elongate the hole for it to work properly. Mike Nellis RV-6 Fuselage N699BM 1947 Stinson 108-2 NC9666K http://bmnellis.com *** -----Original Message----- *** From: owner-rv-list-server(at)matronics.com *** [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of *** BillRVSIX(at)aol.com *** Sent: Wednesday, March 10, 2004 6:12 PM *** To: rv-list(at)matronics.com *** Subject: RV-List: Gretz Electric elevator trim Travel question. *** *** *** *** Hello IM in need of some help I have installed the Gretz *** Aero electric *** elevator trim kit and I can't get the correct throw in the *** elevator trim tab. As per *** van's instructions I need 35 Degrees up and 25 down the *** best I can seem to do *** is 20 up and 15 down I have played around with different *** size horns but with *** little luck. I went threw the archive's and saw others with *** the same problem *** but didn't see a solution to solve the problem. If someone *** has come up with a *** solution for this problem or tell me what I might of missed *** I would appreciate *** it. Thanks *** *** Bill H *** *** RV-6 *** *** *** ============= *** Matronics Forums. *** ============= *** ============= *** ============= *** *** *** *** *** *** *** ________________________________________________________________________________
Date: Mar 10, 2004
Subject: Re: Gretz Electric elevator trim Travel question.
Hmmmmm those values sound like the ones for the elevator, not the elevator trim tab. haven't seen actual rec's for the *trim tab* Gert BillRVSIX(at)aol.com wrote: > > Hello IM in need of some help I have installed the Gretz Aero electric > elevator trim kit and I can't get the correct throw in the elevator trim tab. As per > van's instructions I need 35 Degrees up and 25 down the best I can seem to do > is 20 up and 15 down I have played around with different size horns but with > little luck. I went threw the archive's and saw others with the same problem > but didn't see a solution to solve the problem. If someone has come up with a > solution for this problem or tell me what I might of missed I would appreciate > it. Thanks > > Bill H > > RV-6 > > > > > > > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Mar 10, 2004
Alex: Where did you mount your fans?? I am considering mounting mine just under the top forward skin just aft of the windscreen, but I am concerned about the magnets in the motors. Can I assume that even if you have one on each side of a possible compass mounted on the rollbar support and equal distances from the midline of the airplane, that there still would be some trouble with compass errors? This brings up another question..... Does the compass heading readout in the Dynon satisfy the Feds regarding the compass requirement? Thanks in advance Regards, Jeff Orear RV6A panel Peshtigo, WI ----- Original Message ----- From: "Alex Peterson" <alexpeterson(at)earthlink.net> Subject: RE: RV-List: RV6 slider defrosters > > > to the 6 slider drivers...especially in the Northern climates. > > > > Have some "muffin" fans that I purchased a couple of years > > ago that were > > intended for installation in the top forward skin just aft of > > the windscreen on my > > 6 slider for clearing the windscreen on cold days. Have the wiring > > etc.finished and will soon be putting the top forward skin > > on. Now am flip/flopping on > > the need for the fans. Would appreciate comments/advise on > > the merits of > > putting the in the fans. > > Dale Ensing > > Dale, put them in. I find that they are necessary when the temp is > below 10F, particularly when there are two souls on board. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 443 hours > http://www.home.earthlink.net/~alexpeterson/ > > ________________________________________________________________________________
Subject: Re: RV6 slider defrosters
Date: Mar 10, 2004
I'd recommend them for sure. I wouldn't be comfortable flying in cold weather without some kind of defroster, and that's just with one person on board. They're fairly light and they don't cost much. They work very well in simple "freestanding" mode like most people install them - you don't really need to duct any heat to them. I generally still leave the canopy cracked until I'm warmed up and ready for taxi. I keep the vent open a bit as well just to keep lots of airflow until I'm airborne. Once in the air the canopy clears right up and the fans aren't even required, though I still keep them on. Coldest flight so far -29F. I don't know how long they will last though. Mine are from the surplus store and don't sound as healthy as they used to. I think they were designed for the easy life of a heated office, and here we are using them in a cold airplane, pulling 6Gs with a shaky 'ol Lyc up front. Mine are still working so far. Curt ----- Original Message ----- From: <DWENSING(at)aol.com> Subject: RV-List: RV6 slider defrosters > > to the 6 slider drivers...especially in the Northern climates. > > Have some "muffin" fans that I purchased a couple of years ago that were > intended for installation in the top forward skin just aft of the windscreen on my > 6 slider for clearing the windscreen on cold days. Have the wiring > etc.finished and will soon be putting the top forward skin on. Now am flip/flopping on > the need for the fans. Would appreciate comments/advise on the merits of > putting the in the fans. > Dale Ensing > > ________________________________________________________________________________
Date: Mar 10, 2004
25 Degrees TAB UP travel.....................35 Degrees TAB DOWN Travel The manual trim TAB geometery is diffrent than Electric trim. Distance from the hindge pin to the Linkage atachment hole is shorter for electric trim. Check for linkage interferrence and proper alignment of the trim servo motor. John D ----- Original Message ----- From: "Gert" <gert(at)execpc.com> Subject: Re: RV-List: Gretz Electric elevator trim Travel question. > > Hmmmmm > > those values sound like the ones for the elevator, not the elevator trim > tab. haven't seen actual rec's for the *trim tab* > > Gert > > BillRVSIX(at)aol.com wrote: > > > > Hello IM in need of some help I have installed the Gretz Aero electric > > elevator trim kit and I can't get the correct throw in the elevator trim tab. As per > > van's instructions I need 35 Degrees up and 25 down the best I can seem to do > > is 20 up and 15 down I have played around with different size horns but with > > little luck. I went threw the archive's and saw others with the same problem > > but didn't see a solution to solve the problem. If someone has come up with a > > solution for this problem or tell me what I might of missed I would appreciate > > it. Thanks > > > > Bill H > > > > RV-6 > > > > > > > > > > > > > > > > -- > is subject to a download and archival fee in the amount of $500 > > > > ________________________________________________________________________________
Subject: Re: RE: RV 10 Tail cone top skins
Date: Mar 10, 2004
Hi Bruce: If I was twenty years younger, it would be an option but now it will not happen. I said that when the 6A was finished that would be my last project. That all changed when I had the opportunity to fly the RV 10 at Van's Homecoming. I asked myself "why are you considering building the 10", well after flying it I knew that if I didn't I would be regretting it for the rest of my life. When I received my emp- tail cone kit and started to work on it I realized that this was going to be a joy to build. After building two slow builds the difference is unbelievable, the way it all goes together with the pre-punching and such a great manual I look forward to heading to the shop every morning, it almost feels like I am cheating. Anyway hoping my health holds out and energy keeps up it would be a great way to celebrate my eighty-first birthday next year by flying the 10 on that day. Eustace ----- Original Message ----- From: <BBreckenridge(at)att.net> Subject: RV-List: RE: RV 10 Tail cone top skins > > Mr. Bowhay; > > Why do I get this feeling that your "10" will have a set of floats???!!! > > Bruce Breckenridge > 40018 > > ________________________________________________________________________________
Subject: Dynon/Trio report
Date: Mar 10, 2004
http://www.miramarcollege.net/programs/avim/faculty/north/gauges/index.htm is a simple website I made of a GNS 430, a Dynon D-10 and the Trio EZ pilot shooting a localizer approach in really gusty conditions. The Dynon D-10 is displaying the OAT screen with the OAT/Density Altitude/True Airspeed data on the left info screen. The OAT probe needed no offset factor as it read right on with the offset at zero. I'll need to fly it a while in smoother air to see if the TAS is similar to the steam gauge. It seemed a little off today, but I was really getting keel hauled up there today. The pics also show the GPS having some inaccuracies compared to a localizer. W ________________________________________________________________________________
Date: Mar 10, 2004
You need one and one half threads showing past the nut. BTW, an easy way to get the bolts in is to use a rivet gun with a smooth set to drive them in. It beats hammering on them and they go right in. Jim Cone 3-peat offender ________________________________________________________________________________
Subject: Gretz trim servo travel
Date: Mar 11, 2004
The trim tab horn is shorter for the electric trim. Remember the servo only has 1.2 inch travel and the cable travels more than this with the manual trim. If, as in my case, changing he horn is too much metal butchery, then do as I did and instal a ratio arm (lever) between the servo and cable end. On my RV-4 it let me get full tab travel and also let me reverse the direction of the servo to make a neater installation. Just do the maths for the correct lever ratios. John Kent (Ireland) ________________________________________________________________________________
Subject: Gretz trim Mod (addendum)
Date: Mar 11, 2004
Almost forgot to mention - getting full travel by the ratio lever will speed up the tab movement - not what you want at flaps-up speeds - you will need one of Matt's governors (or similar) to slow things down in the high speed regime. Good luck ! John Kent. ________________________________________________________________________________
Date: Mar 11, 2004
Subject: Re: Dynon/Trio report
Nice. Is the OAT available now or are you a beta tester? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Wheeler North said: > > http://www.miramarcollege.net/programs/avim/faculty/north/gauges/index.htm > > is a simple website I made of a GNS 430, a Dynon D-10 and the Trio EZ > pilot > shooting a localizer approach in really gusty conditions. > > The Dynon D-10 is displaying the OAT screen with the OAT/Density > Altitude/True Airspeed data on the left info screen. > > The OAT probe needed no offset factor as it read right on with the offset > at > zero. I'll need to fly it a while in smoother air to see if the TAS is > similar to the steam gauge. It seemed a little off today, but I was really > getting keel hauled up there today. > > The pics also show the GPS having some inaccuracies compared to a > localizer. > > W ________________________________________________________________________________
Date: Mar 11, 2004
Subject: N8WV Upgrades...
vansairforce I've just updated my upgrades page if anyone is interested: http://www.vondane.com/rv8a/finish/finish13.htm Got my new panel back from Ross at Experimental Air - www.experimentalair.com, and it looks great! -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Subject: Shipping kits from Van's
Date: Mar 11, 2004
I signed up on the Freight Quote website last night ( www.freightquote.com ) and entered the 320# wt and 97"X48"X28" of my RV-6 Finish Kit, used "Freight class of 150 (whatever that is). Went thru the "free quote" routine and noted cost - looked good. I got an e-mail last night saying I'd get a call today. This morning I received a call from one of their reps, Jim Siders, 1-800-323-5441, Ext 1812, and we settled on "Van's dock to my residence" for $370 (instead of $395 to a terminal 10 miles away) . Job will be done by Bullet Freight. Van's would have used ABF and shipped "Van's to ABF Terminal" 10 miles from my house for $395 and I'd have to scrounge a truck or trailer to pick the crate up at the terminal and unload at my house. So, I save a litle bit in money and save more in time and effort by having it come direct to my home. I would have done terminal to terminal and saved even more except that Bullet has no terminal in my area. The next lowest price from Freight Quote was SAIA. They have a terminal here and would have charged $354 for "Van's to terminal" with me picking up at terminal. Would have saved me only $16 over Bullet bringing it to my door - not worth the extra work by me. I made final payment Monday, Van's was posting payments today, and will put my kit out for crating later today to be ready for pickup next week. Barbara has no problem with us choosing our own shipping company. She just needs a name & number to call to request pickup. I paid Freight Quote today. Very little effort or time spent. David ----- Original Message ----- From: "pcondon" <pcondon(at)mitre.org> Subject: RV-List: RV-List Digest Shipping Heavy stuff - Good idea (Cheap way to ship & Move heavy items) > > I ended up > using Freight Quote to arrange my shipping. . Wylie's number is > 800-323-5441 ext. 1761. If you call him, let him know that Randy Stout told > you about Freight Quote. BTW, I get nothing for this. I just told him that > if I were happy with everything, I would put the word out. > ________________________________________________________________________________
Subject: Non-RV related Hanger related
Date: Mar 11, 2004
I am thinking about buying a 3000 square foot hanger and I was wondering if you guys that know something about metal buildings could give me a price per square foot for metal buildings. It has the more expensive electric folding door. I am just looking for an estimate. It is built on concrete and has a slab in front of the hanger also. Thanks Jason Sneed RV-6 (may be getting a new home) ________________________________________________________________________________
Date: Mar 11, 2004
Subject: Re: Shipping kits from Van's
David Carter wrote: > > I signed up on the Freight Quote website last night ( www.freightquote.com ) > and entered the 320# wt and 97"X48"X28" of my RV-6 Finish Kit, used "Freight > class of 150 (whatever that is). Went thru the "free quote" routine and > noted cost - looked good. I got an e-mail last night saying I'd get a call > today. This morning I received a call from one of their reps, Jim Siders, > 1-800-323-5441, Ext 1812, and we settled on "Van's dock to my residence" for > $370 (instead of $395 to a terminal 10 miles away) . Job will be done by > Bullet Freight. Freight Quote has been used quite a bit with mostly good outcomes for shipping several of the StalkerV6 car kits. By the way, my new cruise missile is now running! http://home.hiwaay.net/~sbuc/stalkerv6 Sam Buchanan (RV-6, 552 hrs) ________________________________________________________________________________
Date: Mar 11, 2004
Subject: Re: Non-RV related Hanger related
In a message dated 3/11/2004 12:30:48 PM Eastern Standard Time, n242ds(at)cox.net writes: > I am thinking about buying a 3000 square foot hanger Dude, you must have an enormous trench coat to put on that hanger! Seriously, my neighbor's hangar door is electric bifold and cost more than my RV-6A complete kit did back in '94. I don't remember exact figures, but those puppies are worth some serious bucks. They're also interesting to operate if the power is out ;-) I hear 50x100 foot metal buildings being advertized all the time for around 19k, but I am sure shipping and erection add considerably to the cost, not to mention the concrete floor, wiring, and other amenities. Seems like hangars are scarce these days, and probably an excellent investment when at the right location. -Bill B owner of humble but effective homebuilt metal hangar on sod strip. ________________________________________________________________________________
dan(at)rvproject.com, rv7boy(at)yahoo.com, drwalker(at)powernet.net, jhallrv4(at)comcast.net, n1cxo320(at)salidaco.com, klaus(at)yosemite.net, RV-List(at)matronics.com, mikesrv6(at)yahoo.com, rosales(at)bigfoot.com, randy(at)rv-8.com, n667sr(at)comcast.net
Subject: Carson City Fly-in
Date: Mar 11, 2004
I have just received the final information on the rooms available for our fly-in. The Pinion Plaza Resort 1-877-519 -5567 is $89.00 a night + 10% tax on top. Carson Station Hotel (6 rooms avail.) 1-800-501-2929 is $66.00 a night + tax on top. When making reservations state that you are a guest with the EAA Chapter 403 Fly-in. Suites are also available at the Pinion but start at $112.00 a night if you wish. These rates will be in effect Mar. 15th through Apr. 8th after that they will go to the public and at a higher rate. Frustrated with dial-up? Lightning-fast Internet access for as low as ________________________________________________________________________________
Date: Mar 11, 2004
Wow, I'm impressed. I hope to just be able to "fog a mirror" when I reach 80!! Go for it Eustace. Will this be on Float? Marty in Brentwood TN (still can't seem to get my first project airborne) From: "Eustace Bowhay" <ebowhay(at)jetstream.net> Subject: Re: RV-List: RE: RV 10 Tail cone top skins Hi Bruce: If I was twenty years younger, it would be an option but now it will not happen. I said that when the 6A was finished that would be my last project. That all changed when I had the opportunity to fly the RV 10 at Van's Homecoming. I asked myself "why are you considering building the 10", well after flying it I knew that if I didn't I would be regretting it for the rest of my life. When I received my emp- tail cone kit and started to work on it I realized that this was going to be a joy to build. After building two slow builds the difference is unbelievable, the way it all goes together with the pre-punching and such a great manual I look forward to heading to the shop every morning, it almost feels like I am cheating. Anyway hoping my health holds out and energy keeps up it would be a great way to celebrate my eighty-first birthday next year by flying the 10 on that day. Eustace ----- Original Message ----- From: <BBreckenridge(at)att.net> Subject: RV-List: RE: RV 10 Tail cone top skins > > Mr. Bowhay; > > Why do I get this feeling that your "10" will have a set of floats???!!! > > Bruce Breckenridge > 40018 > > ________________________________________________________________________________
Date: Mar 11, 2004
Anyone, know if these inlets and plenum will these work on a -6 and does Dave have a web site to view these? Marty in Brentwood TN From: John <aflyer(at)direcway.com> Subject: RE: RV-List: RV3/4 Round cowl inlet size Call Dave Anders at (559) 627-3375. He has it all worked out and sells the machined rings for each size engine. John -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Rick Fogerson Subject: RV-List: RV3/4 Round cowl inlet size Hi Listers, I'm considering using round cowl inlets and an aluminum plenum on my RV3 with an 0320. Does anyone know the proper dia. of a round inlet and how this compares to the size/area of Van's std oblong inlet. Thanks, Rick Fogerson RV3 engine baffling Boise, ID ________________________________________________________________________________
Date: Mar 11, 2004
Is the hanger a kit? Ross ----- Original Message ----- From: "C. Rabaut" <crabaut(at)coalinga.com> Subject: Re: RV-List: Non-RV related Hanger related > > I'm moving "away" from big government... > > -buying into a 40 acre, 1800' dirt strip $25,000 > -one 40' x 60' concrete slab (self pour/level ?) $ 2,300 > -one 40' x 60' arch style hanger (blew away once > during construction) > $6,900 > -lots of work (no marketable value) $ > 0 > -tons of other odds & ends (electrical, plumbing, etc) $3,000 > ------------------------------------------------- > ---------------- > -having your own private dirt strip > "priceless" ________________________________________________________________________________
Date: Mar 11, 2004
> Alex: > > Where did you mount your fans?? I am considering mounting > mine just under the top forward skin just aft of the > windscreen, but I am concerned about the magnets in the > motors. Can I assume that even if you have one on each side > of a possible compass mounted on the rollbar support and > equal distances from the midline of the airplane, that there > still would be some trouble with compass errors? I mounted them to the fuse forward top skin, just in front of the instrument panel. It took a little creativity to cram them in amongst the avionics, but it worked out. Don't know about the effect upon the compass, which is in the right panel. One of these days I'll swing it. Alex Peterson Maple Grove, MN RV6-A N66AP 443 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: weight and balance
Date: Mar 11, 2004
http://www.rvproject.com/wab.html That's a javascript web form that I now use for weight & balance (CG) calculations. Feel free to steal that HTML file and tweak it according to your own plane's data. The WAP (mobile phone) version is coming soon... I love having more time to code now that the plane is "done." Hehehheh...yeah, right. 8-) )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Mar 11, 2004
Subject: Re: weight and balance
Hey, Dan, I tried to "Save page as..." and put it somewhere on my mo-sheen; then when I opened that saved file, I could input weights for the passenger, etc., but the matrix to calculate the moments and cg wouldn't work. Any idea why not? Thanks! Randy BTW, I tried to send you a note and some pictures (of me in Thule, Greenland, and Honduras) and got a reply that the files were too big. Any other address I can send them to, or should I try to shrink 'em somehow? Dan Checkoway wrote: > >http://www.rvproject.com/wab.html > >That's a javascript web form that I now use for weight & balance (CG) >calculations. Feel free to steal that HTML file and tweak it according to >your own plane's data. > >The WAP (mobile phone) version is coming soon... > >I love having more time to code now that the plane is "done." >Hehehheh...yeah, right. 8-) > >)_( Dan >RV-7 N714D >http://www.rvproject.com > > > > -- Randy Richter richterrbb(at)earthlink.net -7QB Kit in hibernation ________________________________________________________________________________
From: "John Wiegenstein" <n727jw(at)hellerwiegenstein.com>
Subject: EL Panel/Glareshield Lighting
Date: Mar 11, 2004
Just an update for those who responded to my earlier inquries re: panel lighting options. After poking around the 'net to see what there was, I ended up ordering an Electroluminescent green tape strip kip from Startech. Here's the link: http://www.mutantmods.com/itemdetail.cfm?ProductID=ELTAPEGN I ordered thru Buy.com, for a total cost of about $18. The kit arrived today, with a 4 foot long strip of green EL tape, a nice, compact transformer that runs off 12VDC, and connectors. Mocking it up where my glareshield will be shows that it gives lots of light, in a nice, even, soft green hue. I have the B&C dimmer for the other panel items (avionics) and the dimming curve for them seems to match well with the EL strip. My glareshield overhangs the panel by only about 1.5 inches, and if I had left a longer overhang it would position the EL strip further away from the panel and help give better light towards the bottom of the panel. But, so far it looks like it will be a slick setup for panel lighting, at very low cost, and should give very long life. John Wiegenstein Hansville, WA RV-6 N727JW (reserved) ________________________________________________________________________________
Date: Mar 11, 2004
From: "Richard E. Tasker" <retasker(at)optonline.net>
I don't know what browser you are using, but if you can "view page source" then save that it works just fine when opened. Thanks, Dan for this resource! Dick Tasker Randy Richter wrote: > >Hey, Dan, > >I tried to "Save page as..." and put it somewhere on my mo-sheen; then >when I opened that saved file, I could input weights for the passenger, >etc., but the matrix to calculate the moments and cg wouldn't work. > >Any idea why not? > >Thanks! >Randy > > > ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Date: Mar 12, 2004
Will James has inlets and plenum for the six. James > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Emrath > Sent: Thursday, March 11, 2004 7:08 PM > To: rv-list(at)matronics.com > Subject: RV-List: RV3/4 Round cowl inlet size > > > Anyone, know if these inlets and plenum will these work on a -6 and does > Dave have a web site to view these? > Marty in Brentwood TN > > > From: John <aflyer(at)direcway.com> > Subject: RE: RV-List: RV3/4 Round cowl inlet size > > > Call Dave Anders at (559) 627-3375. He has it all worked out and sells the > machined rings for each size engine. > > John > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Rick Fogerson > Subject: RV-List: RV3/4 Round cowl inlet size > > > Hi Listers, > I'm considering using round cowl inlets and an aluminum plenum on my RV3 > with an 0320. Does anyone know the proper dia. of a round inlet and how > this compares to the size/area of Van's std oblong inlet. Thanks, Rick > Fogerson RV3 engine baffling Boise, ID > > ________________________________________________________________________________
Date: Mar 12, 2004
jason, i just completed a metal building hangar that is 70 ft wide by 84 ft deep and 18 ft at the roof eves. it has a 2/12 roof pitch and a standing seem roof. the building came to approx 35,000$ not including the hyd door that i installed that came to about 7,000$. the concrete for mime ran a little high at about 12,000$. and i have two walk doors and also a 10 x 10 roll up door, included with hanger price. tom kimsey warner robins ga. building came from about 10 miles north of valdosta ,Ga. if i can help with any thing else let me know. tom kimsey ps i did it all - age 62 ________________________________________________________________________________
Date: Mar 12, 2004
I was wondering if you had tested it with your radios or a handheld radio on. I seem to remember that the transformers for the electroluminescent (sp??) lighting can be noisy?? Then on the other hand, for $18 what the heck? Don "All of us need to be reminded that the federal government did not create the states; the states created the federal government!"---Ronald Reagan Get business advice and resources to improve your work life, from bCentral. ________________________________________________________________________________
From: Richard Meske <rmeske@gcfn.org> (SquirrelMail authenticated user rmeske) by www.gcfn.org with HTTP; Fri,
12 Mar 2004 08:18:38.-0500(at)matronics.com (EST)
Date: Mar 12, 2004
Subject: Re: EL Panel/Glareshield Lighting
Don, We sell EL Lighting with inverters. NO one has complained about noise from our systems to this date. They are designed for low power and low electromatic radiation. The lights can easily be dimmed as well by varying the DC to the inverter from the +12V. GOOD LUCK with your project! Rich www.aircraftextras.com > > I was wondering if you had tested it with your radios or a handheld > radio on. I seem to remember that the transformers for the > electroluminescent (sp??) lighting can be noisy?? > > Then on the other hand, for $18 what the heck? > > Don > > > "All of us need to be reminded that the federal government did not > create the states; the states created the federal > government!"---Ronald Reagan > > Get business advice and resources to improve your work life, from > bCentral. > > -- Rich ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <Fred.Stucklen(at)UTCFuelCells.com>
Subject: RE: EL Panel/Glare shield Lighting
Date: Mar 12, 2004
Listers, I've installed the same EL strip into my Tip Up RV-6A. I have about 4.5" of glare shield overhang (it makes BIG difference on canopy reflections). I've installed one .5" wide in close to the panel, and am planning a second one further out on the bottom of the glare shield to better illuminate of the lower panel areas. The single unit does a very nice job of lighting up panel areas that were previously dark. IMO, they do not replace instrument lighting, but rather compliment it by lowering the contrast between the panel and the instruments. The unit works well on the dimmer, but does have some flicker at some levels (due to the 'beat frequency' between the inverter freq and the digital dimmer circuit I am using). I might have to filter the dimmed voltage to this unit to eliminate the flicker.... I have also installed two 50* white LEDs near the top latch of the canopy (on either side of the canopy safety latch). These are used as general cabin lighting. Each has a small reflector that helps widen out the light beam. I have found that by focusing the right side LED towards the left panel area (and conversely the left side LED towards the right panel area) passenger head shadows are nearly eliminated. These two LEDs will light up the panel sufficiently for safe flight in the event of a panel lighting failure..... I'm also planning on adding similar white LEDs in the baggage area. I'd like to have better cabin lighting of the 'hat rack' area where maps & charts are usually stored during long trips. I've also contemplated putting the same lighting into the foot well areas...... Fred Stucklen RV-6A N926RV 155 Hrs Just an update for those who responded to my earlier inquries re: panel lighting options. After poking around the 'net to see what there was, I ended up ordering an Electroluminescent green tape strip kip from Startech. Here's the link: http://www.mutantmods.com/itemdetail.cfm?ProductID=ELTAPEGN I ordered thru Buy.com, for a total cost of about $18. The kit arrived today, with a 4 foot long strip of green EL tape, a nice, compact transformer that runs off 12VDC, and connectors. Mocking it up where my glareshield will be shows that it gives lots of light, in a nice, even, soft green hue. I have the B&C dimmer for the other panel items (avionics) and the dimming curve for them seems to match well with the EL strip. My glareshield overhangs the panel by only about 1.5 inches, and if I had left a longer overhang it would position the EL strip further away from the panel and help give better light towards the bottom of the panel. But, so far it looks like it will be a slick setup for panel lighting, at very low cost, and should give very long life. John Wiegenstein Hansville, WA RV-6 N727JW (reserved) ________________________________________________________________________________
Date: Mar 12, 2004
I used the same material on my RV-6A with lighting throughout the panel, and the power supply was in close proximity to all of my circuit breakers. I had no interference from the system. Paul Besing RV-6A Sold RV-10 Soon http://www.lacodeworks.com/besing Kitlog Pro Builder's Log Software http://www.kitlog.com ----- Original Message ----- From: "Donald Mei" <don_mei(at)hotmail.com> Subject: RV-List: EL Panel/Glareshield Lighting > > I was wondering if you had tested it with your radios or a handheld radio > on. I seem to remember that the transformers for the electroluminescent > (sp??) lighting can be noisy?? > > Then on the other hand, for $18 what the heck? > > Don > > > "All of us need to be reminded that the federal government did not create > the states; the states created the federal government!"---Ronald Reagan > > Get business advice and resources to improve your work life, from bCentral. > > ________________________________________________________________________________
Date: Mar 12, 2004
Subject: F1 QB wings for sale
For sale. One complete set of F1 wings. Contact me off list if interested. Danny Melnik F1 #25 Melbourne (FL) Rocket Factory vft(at)aol.com 407-687-3126 ________________________________________________________________________________
Date: Mar 12, 2004
Subject: Ugrades Update...
vansairforce Got my panel done and ready to paint... I also got my new moving map software yesterday and have been playing around with this morning... It's the Mountain Scope Moving Map stuff from www.pcavionics.com... So far I think it's VERY COOL... I have posted a bunch of screen shots and info to my site... http://www.vondane.com/rv8a/finish/finish13.htm -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Subject: Upgrades Update...
Date: Mar 12, 2004
Maybe you can check out all that new equipment in route to our fly-in if you can make it? Your new panel is going to be pretty trick. (Carson City Fly-in) Bruce >From: Bill VonDane <bill(at)vondane.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com, rv8list(at)yahoogroups.com, vansairforce > >Subject: RV-List: Ugrades Update... >Date: Fri, 12 Mar 2004 10:16:29 -0700 > > >Got my panel done and ready to paint... > >I also got my new moving map software yesterday and have been playing >around >with this morning... It's the Mountain Scope Moving Map stuff from >www.pcavionics.com... So far I think it's VERY COOL... I have posted a >bunch of screen shots and info to my site... > >http://www.vondane.com/rv8a/finish/finish13.htm > >-Bill VonDane >EAA Tech Counselor >RV-8A ~ N8WV ~ Colorado Springs >www.vondane.com >www.creativair.com >www.epanelbuilder.com > > One-click access to Hotmail from any Web page download MSN Toolbar now! http://clk.atdmt.com/AVE/go/onm00200413ave/direct/01/ ________________________________________________________________________________
Subject: Re: N8WV Upgrades...
Date: Mar 12, 2004
Bill, I`m running 125hp and was using a Sterba 68x68. Bought a 68x66 from a guy with a -3 and performance was same, (1900 static rpm and 170mph at 2700rpm.). Sent the 68x66 to Sterba and requested 2200 static and no speed loss on top end. I got it back and it`s 68x62 now and my tach reads 2050 static. Used a friends tach checker and found it`s realy turning 2250rpm static (perfect). I still cruise at about 160mph @ 2500rpm. Sterba got the prop baqck in a couple weeks and didn`t charge anything. Good man to work with. My tach is accurate at 2500rpm but I don`t trust it anymore. What would you do with it? Red Milner RV-4 79KM based @ UES ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> Subject: RV-List: N8WV Upgrades... > > I've just updated my upgrades page if anyone is interested: > http://www.vondane.com/rv8a/finish/finish13.htm > > Got my new panel back from Ross at Experimental Air - > www.experimentalair.com, and it looks great! > > -Bill VonDane > EAA Tech Counselor > RV-8A ~ N8WV ~ Colorado Springs > www.vondane.com > www.creativair.com > www.epanelbuilder.com > > > _____________________________________________________ > ________________________________________________________________________________
Date: Mar 12, 2004
I haven't mounted my fans yet, but they will go in the fuse forward top skin, centered in front of each occupant, in front of the instrument panel and just inside the windshield (6A-Slider.) I also wondered about the effect on the mag compass. I set my fans on my work shop table and hooked them up to a power supply. I positioned a boy scout compass between the fans and turned them on. No movement on the compass. I repositioned the compass to several other areas, above the fans, beside each fan, forward, back, etc. I never saw any movement in the compass between fans on and fans off. I even left the compass in place between the fans, and then removed the fans one at a time - again no movement. Moving the compass anywhere near the power supply; however, induced big errors. Thus, I am comfortable that the fans won't cause compass errors once mounted. Charlie Brame RV-6A N11CB San Antonio ------------------------------- > From: "Alex Peterson" <alexpeterson(at)earthlink.net> > Subject: RE: Fans causing compass errors ...was... RV-List: RV6 slider defrosters > > > > > > Alex: > > > > Where did you mount your fans?? I am considering mounting > > mine just under the top forward skin just aft of the > > windscreen, but I am concerned about the magnets in the > > motors. Can I assume that even if you have one on each side > > of a possible compass mounted on the rollbar support and > > equal distances from the midline of the airplane, that there > > still would be some trouble with compass errors? > > I mounted them to the fuse forward top skin, just in front of the > instrument panel. It took a little creativity to cram them in amongst > the avionics, but it worked out. Don't know about the effect upon the > compass, which is in the right panel. One of these days I'll swing it. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 443 hours > http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: Dave Anders phone number
Date: Mar 12, 2004
I was told to contact Dave Anders at 559-627-3375 for round cowl inlets by 3 different people on the list. Tried twice (carefully) and each time got the same person who didn't know a Dave Anders. Does anyone have a different (correct?) number? Thanks, Rick Fogerson ________________________________________________________________________________
Date: Mar 12, 2004
Subject: Re: Carson City Fly-in
This Carson City --- Nevada? When? hal ________________________________________________________________________________
Date: Mar 12, 2004
Sad but here it won't buy a lot in town. hal Paso Robles, CA (but the Apricot trees are in full bloom!) At 03:00 PM 3/12/2004, you wrote: > >Up here 40 acres would cost between 100,000 to >120,000 Rochester Mn area. ________________________________________________________________________________
Date: Mar 13, 2004
I agree with an earlier post. I think that you are applying the elevator up and down requirements to the trim tab. Charles Becker N464CB RV8A(e) Wings -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of jakent(at)unison.ie Subject: RV-List: Gretz trim servo travel The trim tab horn is shorter for the electric trim. Remember the servo only has 1.2 inch travel and the cable travels more than this with the manual trim. If, as in my case, changing he horn is too much metal butchery, then do as I did and instal a ratio arm (lever) between the servo and cable end. On my RV-4 it let me get full tab travel and also let me reverse the direction of the servo to make a neater installation. Just do the maths for the correct lever ratios. John Kent (Ireland) ________________________________________________________________________________
Date: Mar 13, 2004
Subject: Prop Governor Dimension
Listers, I have an old style Hartzell governor which measures seven and a half inches from the mounting flange face to the rear of the unit. I have not mounted my IO-360B1E on my RV-8 yet, so I can't accurately measure the firewall clearance. Can someone tell me what the clearance is from the governor mounting flange to the firewall and I would be interested to know the size of some other governors. I may be able to make a swap for a different model or brand if this one won't fit. Thanks. Ron Schreck RV-8 Gold Hill, NC ________________________________________________________________________________
Date: Mar 13, 2004
Subject: F6111
Ok, I ready to install the F6111L & R, those little pcs. that go above the baggage area on the top skin sides for the sliding canopy. I guess they need to be cut off to fit. How much? Top and bottom or only top or bottom? I seem to remember someone saying how much they had to cut. -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Slowbuild wings-QB Fuse :-) ________________________________________________________________________________
Subject: e: EL Panel/Glareshield Lighting
Date: Mar 13, 2004
Fred Stucklen Rich, But you are not competing with the cost... $89 instead of $18.00 for essentially the same product... Fred Stucklen RV-6A N926RV 155 Hrs Don, We sell EL Lighting with inverters. NO one has complained about noise from our systems to this date. They are designed for low power and low electromatic radiation. The lights can easily be dimmed as well by varying the DC to the inverter from the +12V. GOOD LUCK with your project! Rich www.aircraftextras.com ________________________________________________________________________________
Date: Mar 13, 2004
>>> >>>Jason Sneed wrote: >>> >>> >>> >>>> >>>>I am thinking about buying a 3000 square foot hanger and I was >>>>wondering if you guys that know something about metal buildings could >>>>give me a price per square foot for metal buildings. It has the more >>>>expensive electric folding door. I am just looking for an estimate. It >>>>is built on concrete and has a slab in front of the hanger also. >>>> >>>>Thanks >>>> >>>> >>>>Jason Sneed >>>>RV-6 (may be getting a new home) >>>> Nine of the eleven hangars here at Slobovia Outernational (in Mississippi) are 'chicken houses' erected by a guy who stays very busy building...chicken houses. Shop-built (engineered, of course) trusses with 2X6 purlins & Galvalume metal roofing. The builder expects a reasonably level surface. He comes out one day & shoots leveled spots for & pours the foundation pads for the trusses. The next day they start erecting the trusses & within 3 or 4 days you have a shed to park under. I believe that the current price is about $2.25-$2.50 per sq ft, parts & labor. Add the cost of slab, door, walls, etc to that. Painted Galvalume metal for walls runs around 60 cents per sq ft. The various owners here have researched almost every possible idea for hangar construction, & this is by far the cheapest in this area. One advantage is that if money is tight, you can protect the plane for very little initial cash outlay. Another advantage if you have unstable soil (we do) is that you can park planes, vehicles, tractors, etc under the shed for months to pack the soil hard before actually pouring the slab. If you are willing to do it all yourself & just need an RV sized hangar (30' span), drop me a line for a way to do it even cheaper that that. Charlie ________________________________________________________________________________
Subject: Request: Information for Kitplanes Article (Interiors/Exteriors)
Date: Mar 13, 2004
Hello! I am writing an article for Kitplanes magazine that will feature builders who have distinctive interiors and/or exteriors. My deadline is rather short, so if you could email me as soon as possible, hopefully by Tuesday, that will give me enough time to put it together. Here are some of the criteria I'm looking for: Interiors that are (one or any combination): 1. creative 2. inexpensive 3. very comfortable 4. lightweight 5. generally cool and different 6. distinctive in some way. Exteriors that are: 1.. stunningly attractive 2.. original design 3.. historically accurate 4.. distinctive in some way Other things to keep in mind: 1. How you came to design your interior/exterior (How you got your idea) 2. The reasons why you did it as you did 3. What benefits you had in mind 4. Any unexpected benefits (and/or pitfalls) there were 5. What you learned 6. How many hours you've flown with it (if completed) 7. How much of the work did you do yourself? 8. Did you have any professional assistance? How much? 9. The equipment and tools you used 10. How much time it took to build and install 11. The cost of building it. 12. Would you do it again the same way? Why? Here are the photo requirements for Kitplanes: Photos must be 300 dpi at a size large enough to use in the magazine, which is usually at least 3 x 3 inches. If an image is 300 dpi at 1 x 1 inch, it won't be big enough to do any good. Hard copy photos are good, too. Thanks so much - I really appreciate your help! best regards, Cory Emberson Hayward, CA [KHWD] 510.599.4409 cory(at)lightspeededit.com ________________________________________________________________________________
Date: Mar 13, 2004
Subject: Re: F6111
Bobby, If your F6111 pieces are the same as mine, cut off the top at 1 3/8 inch (measured along a "centerline" running through the tooling holes) above the tooling holes. Don't cut yet! They should be cut at about a 30 degree angle with the bottom sides being longer than the top sides. That's 30 degrees from just whacking it off at 90 degrees. You will angle back the flanges to fit flush to the bulkhead as you trim it to fit. Draw vertical lines 1/4 inch inboard of the center of the corner holes that hold the corrugated baggage plate in place. The tooling holes end up just in front of this line (about 5/8 inch). If I had done mine that way it would look great. I cut off too much! That's easy to do. It would be better to cut long to begin with to be sure what I said will work for you. There has to be a twist in them to fit the skin. But this information should help. Once the top is done, incrementally trim the bottom until the center line of the flange lies under the holes in the skin and the bottom just almost touches the longeron. I think 1/16 inch from the longeron looks good. This information is as I measured it on my airplane. Hope this helps you get a good fit. Dan Hopper RV-7A (almost done) > > Ok, I ready to install the F6111L &R, those little pcs. that go above > the baggage area on the top skin sides for the sliding canopy. I guess > they need to be cut off to fit. How much? Top and bottom or only top or > bottom? I seem to remember someone saying how much they had to cut. > > -- > Surfing the Web from Hopkinsville, KY > Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ > RV7A Slowbuild wings-QB Fuse :-) > ________________________________________________________________________________
Date: Mar 13, 2004
Cy, I live in the middle of Indiana about that distance from Chicago. Where is your strip. If its close maybe I can give up on mine! Dan (Walton, IN) In a message dated 3/13/04 10:44:20 AM US Eastern Standard Time, pa201950(at)yahoo.com writes: > Only bad thing about this setup is > that the strip is only 1,100 ft. long and it is 160 > miles from where I live. The good thing is that I have > an RV-6 that can get there in an hour,land and take > off from this short strip,and if it is a nice day I > can taxi up in the yard of the farm house so my RV is > about 30 ft. from the door. Can you imagine being > downtown Chicago fighting the traffic and in a couple > of hours being out in the middle of nowhere sitting on > the front porch smoking a cigar and looking at your RV > sitting on your own grass strip!! > > --- Cy Galley wrote: > > > ________________________________________________________________________________
Date: Mar 13, 2004
The dates are Apr. 30th through May 2nd. The 30th is set up for early arrivals. You can find more info. on vansaircraft.com under FLY-IN SCHEDULE. That will forward you to the host sight. Thanks for the interest and hope you and some others can make it. Bruce >From: kempthornes <kempthornes(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Carson City Fly-in >Date: Fri, 12 Mar 2004 16:18:38 -0800 > > >This Carson City --- Nevada? When? > >hal > > Find things fast with the new MSN Toolbar includes FREE pop-up blocking! http://clk.atdmt.com/AVE/go/onm00200414ave/direct/01/ ________________________________________________________________________________
Date: Mar 13, 2004
Subject: RV-4 N504RV Flew today
Hey listers: Thanks to many of you who support and are active on the RV-List, My RV-4, N504RV flew from Nut Tree Airport today. First flight, 40 minutes, to 9,000 feet, ended with ground observing smoke and a leaky gasket to the prop gov. Otherwise, COOOOOL! This is Van's #1305, began in 1984 by Ret Col Don Disbrow (diseased). After 7 years of love and pain, it flies. A great feeling and a debt to you all on the list. Also Van's, who always had a rough idea of what my problems where but a solution just the same. Mike Seager was a big help in getting me ready for the first flight and all the help from the local Hanger bums at the Nut Tree. My wife Ronni and kids Casey and Kelly, yes your dad is still alive and now will be home a bit more. A great bunch of people and a life-time high! Dave Aronson RV-4 N504RV ________________________________________________________________________________
Date: Mar 13, 2004
Bobby, If your F6111 pieces are the same as mine, cut off the top at 1 3/8 inch (measured along a "centerline" running through the tooling holes) above the tooling holes.=A0 Don't cut yet!=A0 They should be cut at about a 30 degree angle with the bottom sides being longer than the top sides.=A0 That's 30 degrees from just whacking it off at 90 degrees.=A0 You will angle back the flanges to fit flush to the bulkhead as you trim it to fit.=A0 Draw vertical lines 1/4 inch inboard of the center of the corner holes that hold the corrugated baggage plate in place.=A0 The tooling holes end up just in front of this line (about 5/8 inch).=A0 If I had done mine that way it would look great.=A0 I cut off too much!=A0 That's easy to do.=A0 It would be better to cut long to begin with to be sure what I said will work for you.=A0 There has to be a twist in them to fit the skin.=A0 But this information should help.=A0 Once the top is done, incrementally trim the bottom until the center line of the flange lies under the holes in the skin and the bottom just almost touches the longeron.=A0 I think 1/16 inch from the longeron looks good. This information is as I measured it on my airplane. Hope this helps you get a good fit. Dan Hopper RV-7A (almost done) > > Ok, I ready to install the F6111L &R, those little pcs. that go above > the baggage area on the top skin sides for the sliding canopy. I guess > they need to be cut off to fit. How much? Top and bottom or only top or > bottom? I seem to remember someone saying how much they had to cut. > > -- > Surfing the Web from Hopkinsville, KY > Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ > RV7A Slowbuild wings-QB Fuse :-) > ________________________________________________________________________________
Date: Mar 13, 2004
Cy, I live in the middle of Indiana about that distance from Chicago.=A0 Where is your strip.=A0 If its close maybe I can give up on mine! Dan (Walton, IN) In a message dated 3/13/04 10:44:20 AM US Eastern Standard Time, pa201950(at)yahoo.com writes: > Only bad thing about this setup is > that the strip is only 1,100 ft. long and it is 160 > miles from where I live. The good thing is that I have > an RV-6 that can get there in an hour,land and take > off from this short strip,and if it is a nice day I > can taxi up in the yard of the farm house so my RV is > about 30 ft. from the door. Can you imagine being > downtown Chicago fighting the traffic and in a couple > of hours being out in the middle of nowhere sitting on > the front porch smoking a cigar and looking at your RV > sitting on your own grass strip!! > > --- Cy Galley wrote: > > > ________________________________________________________________________________
Date: Mar 13, 2004
Subject: Re: F6111
Date: Mar 13, 2004
At 03:51 PM 3/13/2004, you wrote: > >The dates are Apr. 30th through May 2nd. The 30th is set up for early >arrivals. You can find more info. on vansaircraft.com under FLY-IN SCHEDULE. >That will forward you to the host sight. Thanks for the interest and hope >you and some others can make it. Bruce Thanks for the invite, Bruce! I did the linking and jumping and found that indeed, the fly in is at CARSON CITY , NEVADA. (Not carson city, NY.) It has so far been a somewhat secretive event so it must really be worth attending - maybe the SR71 will fly by or the Wright Flyer or even the RV11? hal (This Paso Robles Zinfandel is some good wine!) ________________________________________________________________________________
Date: Mar 13, 2004
Subject: Re: F6111
I'll try one more time. Bobby, If your F6111 pieces are the same as mine, cut off the top at 1 3/8 inch (measured along a "centerline" running through the tooling holes) above the tooling holes. Don't actually cut yet! The pieces should be cut at about a 30 degree angle with the bottom sides being longer than the top sides. That's 30 degrees from just cutting it off at 90 degrees. You will angle back the flanges to fit flush to the bulkhead as you trim it to fit. Draw a vertical line on each side 1/4 inch inboard of the center of the corner holes that hold the corrugated baggage plate in place. The tooling holes end up just in front of this line (about 5/8 inch). If I had done mine that way it would look great. I cut off too much! That's easy to do. It would be better to cut long to begin with to be sure what I said will work for you. There has to be a twist in them to fit the skin. But this information should help. Once the top is done, incrementally trim the bottom until the center line of the flange lies under the holes in the skin and the bottom just almost touches the longeron. I think 1/16 inch from the longeron looks good. This information is as I measured it on my airplane. Hope this helps you get a good fit. Dan Hopper RV-7A (almost done) In a message dated 3/13/04 10:01:56 AM US Eastern Standard Time, bhester(at)hopkinsville.net writes: > > Ok, I ready to install the F6111L &R, those little pcs. that go above > the baggage area on the top skin sides for the sliding canopy. I guess > they need to be cut off to fit. How much? Top and bottom or only top or > bottom? I seem to remember someone saying how much they had to cut. > > -- > Surfing the Web from Hopkinsville, KY > Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ > RV7A Slowbuild wings-QB Fuse :-) > > ________________________________________________________________________________
Date: Mar 14, 2004
Dave, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A >From: David Aronson <aronsond(at)pacbell.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: RV-4 N504RV Flew today >Date: Sat, 13 Mar 2004 17:51:20 -0800 (PST) > > >Hey listers: >Thanks to many of you who support and are active on the RV-List, My RV-4, >N504RV flew from Nut Tree Airport today. First flight, 40 minutes, to >9,000 feet, ended with ground observing smoke and a leaky gasket to the >prop gov. Otherwise, COOOOOL! Get business advice and resources to improve your work life, from bCentral. ________________________________________________________________________________
Date: Mar 13, 2004
Subject: F6111
Bobby, Here's what I did....NOTHING. I threw mine away. My skins are plenty stiff and those things are just plain ugly : ). Tip came from my building mentor and friend, Mr. Paul Rosales!! Rick Gray in Ohio at the Buffalo Farm http://rv6rick.tripod.com/ohiovalleyrvators/index.html feel free to archive : ) Bobby, If your F6111 pieces are the same as mine, cut off the top at 1 3/8 inch (measured along a "centerline" running through the tooling holes) above the tooling holes.=A0 Don't cut yet!=A0 They should be cut at about a 30 degree angle with the bottom sides being longer than the top sides.=A0 That's 30 degrees from just whacking it off at 90 degrees.=A0 You will angle back the flanges to fit flush to the bulkhead as you trim it to fit.=A0 Draw vertical lines 1/4 inch inboard of the center of the corner holes that hold the corrugated baggage plate in place.=A0 The tooling holes end up just in front of this line (about 5/8 inch).=A0 If I had done mine that way it would look great.=A0 I cut off too much!=A0 That's easy to do.=A0 It would be better to cut long to begin with to be sure what I said will work for you.=A0 There has to be a twist in them to fit the skin.=A0 But this information should help.=A0 Once the top is done, incrementally trim the bottom until the center line of the flange lies under the holes in the skin and the bottom just almost touches the longeron.=A0 I think 1/16 inch from the longeron looks good. This information is as I measured it on my airplane. Hope this helps you get a good fit. Dan Hopper RV-7A (almost done) > > Ok, I ready to install the F6111L &R, those little pcs. that go above > the baggage area on the top skin sides for the sliding canopy. I guess > they need to be cut off to fit. How much? Top and bottom or only top or > bottom? I seem to remember someone saying how much they had to cut. > > -- > Surfing the Web from Hopkinsville, KY > Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ > RV7A Slowbuild wings-QB Fuse :-) ________________________________________________________________________________
Date: Mar 14, 2004
I have the same number and it was GOOD last time I called it 3 years ago. I have a work phone number of (559) 625-2744. May want to try that. If they do not know them, my suggestion would be to look them up on the FAA Database to see if they moved. I was told they were building a house at "Lake California Air Park" (38CA). Lake California is in Northern California near Redding. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,442 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: "Rick Fogerson" <rickf(at)cableone.net> Subject: RV-List: Dave Anders phone number Date: Fri, 12 Mar 2004 15:06:25 -0700 I was told to contact Dave Anders at 559-627-3375 for round cowl inlets by 3 different people on the list. Tried twice (carefully) and each time got the same person who didn't know a Dave Anders. Does anyone have a different (correct?) number? Thanks, Rick Fogerson Find things fast with the new MSN Toolbar includes FREE pop-up blocking! http://clk.atdmt.com/AVE/go/onm00200414ave/direct/01/ ________________________________________________________________________________
Subject: Re: Request: Information for Kitplanes Article (Interiors/Exteriors)
Date: Mar 13, 2004
Look at Jim Noram's Razmataz. ----- Original Message ----- From: "Cory Emberson" <bootless(at)earthlink.net> Subject: RV-List: Request: Information for Kitplanes Article (Interiors/Exteriors) > > Hello! > > I am writing an article for Kitplanes magazine that will feature builders who have distinctive interiors and/or exteriors. > > My deadline is rather short, so if you could email me as soon as possible, hopefully by Tuesday, that will give me enough time to put it together. > > Here are some of the criteria I'm looking for: > > Interiors that are (one or any combination): > > 1. creative > 2. inexpensive > 3. very comfortable > 4. lightweight > 5. generally cool and different > 6. distinctive in some way. > > Exteriors that are: > > 1.. stunningly attractive > 2.. original design > 3.. historically accurate > 4.. distinctive in some way > Other things to keep in mind: > > 1. How you came to design your interior/exterior (How you got your idea) > 2. The reasons why you did it as you did > 3. What benefits you had in mind > 4. Any unexpected benefits (and/or pitfalls) there were > 5. What you learned > 6. How many hours you've flown with it (if completed) > 7. How much of the work did you do yourself? > 8. Did you have any professional assistance? How much? > 9. The equipment and tools you used > 10. How much time it took to build and install > 11. The cost of building it. > 12. Would you do it again the same way? Why? > > > Here are the photo requirements for Kitplanes: Photos must be 300 dpi at a size large enough to use in the magazine, which is usually at least 3 x 3 inches. If an image is 300 dpi at 1 x 1 inch, it won't be big enough to do any good. Hard copy photos are good, too. > > Thanks so much - I really appreciate your help! > > best regards, > > Cory Emberson > Hayward, CA [KHWD] > 510.599.4409 > cory(at)lightspeededit.com > > ________________________________________________________________________________
Date: Mar 14, 2004
Listers, I must have caught you all on a bad day or you are all out flying on a beautiful weekend as nobody responded to my inquiry. I'll try again: I have an old style Hartzell governor which measures seven and a half inches from the mounting flange face to the rear of the unit. I have not mounted my IO-360B1E on my RV-8 yet, so I can't accurately measure the firewall clearance. Can someone tell me what the clearance is from the governor mounting flange to the firewall and I would be interested to know the size of some other governors. I may be able to make a swap for a different model or brand if this one won't fit. Thanks. Ron Schreck RV-8 Gold Hill, NC ________________________________________________________________________________
Date: Mar 14, 2004
Subject: Re: F6111
Bobby, I built a -6A which uses the same part, not that this means it fits the same. I do not recall where or how I trimmed it. I simply developed the line where it was to go based on measurements from the plans and where the top skin just aft of the canopy ended and trimmed it to fit. I drew the rivet line and drilled the holes first and arranged the position of the -6111 to hit a drawn centreline on the flange. If you are lucky the -7A kits will be prepunched along this line. Others have noted the ends must be trimmed at an angle and that the piece gets a degree of twist when being installed. I'll enclose a picture of the finished item which may help. Jim Oke RV-6A Wpg, MB ----- Original Message ----- From: "Bobby Hester" <bhester(at)hopkinsville.net> Subject: RV-List: F6111 > > Ok, I ready to install the F6111L & R, those little pcs. that go above > the baggage area on the top skin sides for the sliding canopy. I guess > they need to be cut off to fit. How much? Top and bottom or only top or > bottom? I seem to remember someone saying how much they had to cut. > > -- > Surfing the Web from Hopkinsville, KY > Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ > RV7A Slowbuild wings-QB Fuse :-) > > ________________________________________________________________________________
Date: Mar 14, 2004
Subject: Upcoming HUGE fly in !!!
A great day for flying indeed !!! Went out to Brunswick county for their EAA meeting/lunch. flew back to Burlington, a few touch and goes; Siler City for gas and then back to South East. By the way - The organizers of the Lumberton Fly in " Mid Atlantic Fly in" came and spoke at the EAA meeting. Check out the web site: www.midatlanticflyin.com . The guy organizing it was facilities coordinator for Sun & Fun for 12 years. He expects it to be huge !!! And considering it is in our back yard I think the RV Wing should make a "Big Appearance". Check it out and spread the word. Ed Ditch - N925RV - 6A eregensburg(at)triad.rr.com ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Mar 14, 2004
The Gretz electric trim in my 6A had insufficient authority to trim the plane in all configurations. In particular, on final with full flaps, I had to exert some stick back pressure. I do not like flying an out-of-trim plane, so in retrospect the manual trim would have been a better solution. I chose the electric trim to get rid of that big knob that seemed to be in the wrong place! Regards, Dennis Persyk N600DP sold Pictures at http://home.att.net/~dpersyk/rv6a.htm From: "Charles Becker" <ctbecker(at)charter.net> Subject: RE: RV-List: Gretz trim servo travel I agree with an earlier post. I think that you are applying the elevator up and down requirements to the trim tab. Charles Becker N464CB RV8A(e) Wings -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of jakent(at)unison.ie Subject: RV-List: Gretz trim servo travel The trim tab horn is shorter for the electric trim. Remember the servo only has 1.2 inch travel and the cable travels more than this with the manual trim. If, as in my case, changing he horn is too much metal butchery, then do as I did and instal a ratio arm (lever) between the servo and cable end. On my RV-4 it let me get full tab travel and also let me reverse the direction of the servo to make a neater installation. Just do the maths for the correct lever ratios. John Kent (Ireland) ________________________________________________________________________________
Subject: LA Area Visit?
Date: Mar 14, 2004
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I'm going to be in the LA area (Manhattan Beach) for the next couple of weeks on business. I'm building an RV-10 and would very much like to visit area builders to see projects in various stages of completion. Of course, I'm also will to discuss RV-10 specifics with anybody interested. I recently took delivery of my wings and am finishing up the tailcone (as soon as I can reduce my travel schedule). Bob ________________________________________________________________________________
Date: Mar 14, 2004
Think you sent this to the wrong person. ----- Original Message ----- From: <Hopperdhh(at)aol.com> Subject: Re: RV-List: Non-RV related Hanger related > > > Cy, > I live in the middle of Indiana about that distance from Chicago. Where is > your strip. If its close maybe I can give up on mine! > Dan (Walton, IN) > > > In a message dated 3/13/04 10:44:20 AM US Eastern Standard Time, > pa201950(at)yahoo.com writes: > > > Only bad thing about this setup is > > that the strip is only 1,100 ft. long and it is 160 > > miles from where I live. The good thing is that I have > > an RV-6 that can get there in an hour,land and take > > off from this short strip,and if it is a nice day I > > can taxi up in the yard of the farm house so my RV is > > about 30 ft. from the door. Can you imagine being > > downtown Chicago fighting the traffic and in a couple > > of hours being out in the middle of nowhere sitting on > > the front porch smoking a cigar and looking at your RV > > sitting on your own grass strip!! > > > > --- Cy Galley wrote: > > > > > > > ________________________________________________________________________________
Subject: Reminder: The First Palmetto RV FlyIn Cookout - March 20th
Date: Mar 14, 2004
The Palmetto Wing of Van's Air Force Invites any and all RV pilots/flyers/builders/etc. to the FIRST PALMETTO RV FLYIN COOKOUT Saturday, March 20th Columbia Downtown Owens Field Airport Columbia, SC Palmetto Burgers and Carolina Dogs Grills will be fired up at 11:00 AM No Program No Vendors No Speeches No Organization No Charge (Donations Accepted) Just good food, RV's, and friendly conversation. www.airnav.com/airport/KCUB Note right traffic for runway 13 If you plan to come email Ken.Harrill(at)Columbia.SC so we can buy enough food. ________________________________________________________________________________
Subject: O-360 Filter air box
Date: Mar 14, 2004
I am nearing the point where I will be doing the fiberglass work for the cowl inlet nozzle. I need some advise as to the dimension between the cowl inlet (unfinished) and the front of the filtered air box before doing the glass work? In other words how long does the glass nozzle need to be? The foam block Van supplies is about 2" wide. I assume the dimension needs to be less than 2" but how much less? Tommy Walker 6A, Ridgetop, TN ________________________________________________________________________________
Subject: Re: Ugrades Update...
Date: Mar 14, 2004
Bill, I've been watching these PDA-based solutions for some time, and have used a simple one in my glider with great success to run glide computer software. As I contemplate what to put in the panel of my new RV-3B project these look attractive but I still have two major concerns... 1. The PocketPC operating system is a typical Microsoft product and is complicated and bloated code and therefore prone to crashing, and managing it does require some real understanding of it. Anyone concerned about OS stability? 2. The interface looks like it requires a stylus -- anyone concerned about using a stylus while bouncing around in a cockpit? Thoughts on these? Randy Lervold RV-8, 368 hrs, sold RV-3B, starting construction ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> Subject: RV-List: Ugrades Update... > > Got my panel done and ready to paint... > > I also got my new moving map software yesterday and have been playing around > with this morning... It's the Mountain Scope Moving Map stuff from > www.pcavionics.com... So far I think it's VERY COOL... I have posted a > bunch of screen shots and info to my site... > > http://www.vondane.com/rv8a/finish/finish13.htm > > -Bill VonDane > EAA Tech Counselor > RV-8A ~ N8WV ~ Colorado Springs > www.vondane.com > www.creativair.com > www.epanelbuilder.com > > ________________________________________________________________________________
Date: Mar 14, 2004
Subject: Re: O-360 Filter air box
In a message dated 3/14/04 10:43:01 AM Pacific Standard Time, twsurveyor(at)msn.com writes: << I need some advise as to the dimension between the cowl inlet (unfinished) and the front of the filtered air box before doing the glass work? In other words how long does the glass nozzle need to be? >> You will probably get half a dozen different answers to this. The way I did it is to finish the FAB first and then trim the inlet end of the FAB so that it was reasonably "square" with the cowl inlet. Then the length of the glass nozzle is whatever it takes to extend to within about 3/8" of the FAB inlet. I made mine initially almost touching the FAB and then trimmed it to get the spacing for the air seal and it wound up about 1 1/2" long. I have seen several that are much shorter. Just make certain that you can drop the cowl down past the front of the FAB when it is finished. Hope this helps. Harry Crosby Pleasanton, California RV-6, final assembly ________________________________________________________________________________
Date: Mar 14, 2004
Both of your points were a concern of mine when I had to decide on panel layout, especially #2. That's why I stayed with Garmin. I'm very happy with my Garmin 196. I love the latest techno-geek stuff, but the Garmin's are still the best as far as functionality, IMO. - Larry Bowen. RV-8 FWF Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Randy Lervold [mailto:randy@rv-8.com] > Sent: Sunday, March 14, 2004 2:08 PM > To: rv-list(at)matronics.com; vansairforce; rv-3(at)yahoogroups.com > Subject: Re: RV-List: Ugrades Update... > > > > Bill, > > I've been watching these PDA-based solutions for some time, > and have used a simple one in my glider with great success to > run glide computer software. As I contemplate what to put in > the panel of my new RV-3B project these look attractive but I > still have two major concerns... > > 1. The PocketPC operating system is a typical Microsoft > product and is complicated and bloated code and therefore > prone to crashing, and managing it does require some real > understanding of it. Anyone concerned about OS stability? > > 2. The interface looks like it requires a stylus -- anyone > concerned about using a stylus while bouncing around in a cockpit? > > Thoughts on these? > > Randy Lervold > RV-8, 368 hrs, sold > RV-3B, starting construction > > > ----- Original Message ----- > From: "Bill VonDane" <bill(at)vondane.com> > To: ; ; > "vansairforce" > Subject: RV-List: Ugrades Update... > > > > > > Got my panel done and ready to paint... > > > > I also got my new moving map software yesterday and have > been playing > around > > with this morning... It's the Mountain Scope Moving Map stuff from > > www.pcavionics.com... So far I think it's VERY COOL... I > have posted > > a bunch of screen shots and info to my site... > > > > http://www.vondane.com/rv8a/finish/finish13.htm > > > > -Bill VonDane > > EAA Tech Counselor > > RV-8A ~ N8WV ~ Colorado Springs > > www.vondane.com > > www.creativair.com > > www.epanelbuilder.com ________________________________________________________________________________
Date: Mar 14, 2004
Subject: AIRPORT THREATS-not RV related
Folks International Speedway Corporation of Daytona, Florida is collecting information about possible track sites in the pacific northwest. It is quite disturbing, as there is alot that comes with the building of a "major" racing facility. In my neck of the woods, at least(I believe they are looking along the I-5 corridor in WA & OR) there are three possible sites that may be considered. ALL THREE sites, if developed, would adversely affect general aviation via TFR's. TWO of these are just South of Arlington Municipal Airport, home of the EAANW Fly-In. If a dot was placed on the map in the approx. center of the proposed track site, and a 3NM radius drawn, either of those two sites would "totally encompass" the airport. The patrons at the airport are pursuing various methods to ensure the final siting is not too close to any airport, much less this one. We will also be working to get out the word to homeowners, since there are ALOT of these folks that would also be adversely affected. We are NOT Anti-NASCAR here, but we are certainly hoping that there will be a way for ISC to meet their "criteria" for a site without beating down airports and homeowners. There are other sites also being considered. It is my thought that if there is enough visibility given to Arlington Municipal Airport along with other airports in general, that it may play into their decision as to where to site a facility. If there is any interest by the folks on this list, it would be appreciated if contact could be made with Thomas Valley, Director of Corporate Development, International Speedway Corporation, 1801 International Speedway Blvd., Daytona, Florida 32114. The phone number is 386-254-2700. There are two lines of thought to me right now. One is the fact that these folks be made to understand things in a Post 9/11 mentality. The other is that if they just plain don't care about these matters, that they understand that some of these sites might be mired in litigation should that become necessary. Generally, I would think that they are looking for a big bang for the buck without alot of unforseen headaches. There may be other sites that would work better in that regard, like ones that are set just a little farther from subdivisions and airports. Any help in attempting to preserve our "little piece of paradise" would be greatly appreciated. James Nice WA State ________________________________________________________________________________
Subject: RST Audio Panel
Date: Mar 14, 2004
List, Looked in the archives, but did not get a lot of recent info. Have people had good results with the RST audio panel and the latest electronics (Garmin 430, etc.)? Line clarity (intercom) will be one of the most important features for me. Does the RST compare well against the pricey ones (Apollo, Garmin, etc.)? Sure seems like a bargain for under $300 for a new kit if it works well. Thanks, Scott 7A Wings Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Date: Mar 14, 2004
Ron, I don't know that this will help, but on my RV-8A with Superior XP-IO-360-B1B, I have 7-9/16" from the flange to the firewall, and 2" clear from the firewall to the closest part of the Czechoslovakian governor I bought from Van's. Terry RV-8A #80729 wiring Listers, I must have caught you all on a bad day or you are all out flying on a beautiful weekend as nobody responded to my inquiry. I'll try again: I have an old style Hartzell governor which measures seven and a half inches from the mounting flange face to the rear of the unit. I have not mounted my IO-360B1E on my RV-8 yet, so I can't accurately measure the firewall clearance. Can someone tell me what the clearance is from the governor mounting flange to the firewall and I would be interested to know the size of some other governors. I may be able to make a swap for a different model or brand if this one won't fit. Thanks. Ron Schreck RV-8 Gold Hill, NC ________________________________________________________________________________
Date: Mar 14, 2004
RV-List message posted by: "Randy Lervold" <randy@rv-8.com> > >Bill, > >I've been watching these PDA-based solutions for some time, and have used a >simple one in my glider with great success to run glide computer software. >As I contemplate what to put in the panel of my new RV-3B project these >look >attractive but I still have two major concerns... > >1. The PocketPC operating system is a typical Microsoft product and is >complicated and bloated code and therefore prone to crashing, and managing >it does require some real understanding of it. Anyone concerned about OS >stability? > >2. The interface looks like it requires a stylus -- anyone concerned about >using a stylus while bouncing around in a cockpit? > >Thoughts on these? > >Randy Lervold >RV-8, 368 hrs, sold >RV-3B, starting construction Absolutely valid concerns! I'm planning on a mini PC in my RV10...moving map GPS, MP3's, DVD, flight planning software, etc. My main concerns are ops sys, and user interface. Oh, the survivability of hard drives in a choppy flight environment gives me pause as well, but this will not be a safety of flight concern...merely an annoyance. I'm planning on this solely as a nice-to-have item, and can aviate/navigate/communicate just fine without it. Oh, it also rates very high on the "cool factor" scale. ;) The Windows CE is a faster booting op sys for sure, but how or if it can be employed on a conventional hard disk PC, I simply don't know yet. For interface, I'm thinking touch screen LCD (pricey, but what isn't these days?). Complimentary to that, or as sole means of interface, a mini keyboard or trackball tucked away under the panel somewhere, but handy to either right or left seat occupant, could be done. It's all a pipe dream now, but it's being done. See myglasscockpit.com. Brian Denk RV8 N94BD RV10 '51 Get a FREE online computer virus scan from McAfee when you click here. ________________________________________________________________________________
Subject: Re: RST Audio Panel
Date: Mar 14, 2004
Scott: I am sure you will get lots of opinions about RST audio panels. For the money they are only as good as your workmanship during construction. I have built two of them, the last one had the built in intercom, it was OK but not as good as a separate Intercom panel. My RST I could never get rid of the noise in the normal position from the alternator, a whine used all the normal methods to get ride of noise to no avail. Finally I went to a older King KMA-20 which works a lot better. I really feel if you have more than one radio a quality audio panel makes the install work a lot better. My opinion only, good luck on your choice. Harvey Sigmon RV-6A flying ----- Original Message ----- From: <tx_jayhawk(at)excite.com> Subject: RV-List: RST Audio Panel > > > List, > > Looked in the archives, but did not get a lot of recent info. Have people had good results with the RST audio panel and the latest electronics (Garmin 430, etc.)? Line clarity (intercom) will be one of the most important features for me. Does the RST compare well against the pricey ones (Apollo, Garmin, etc.)? > > Sure seems like a bargain for under $300 for a new kit if it works well. > > Thanks, > Scott > 7A Wings > > Join Excite! - http://www.excite.com > The most personalized portal on the Web! > > ________________________________________________________________________________
Subject: Cleveland Brake Assembly
Date: Mar 14, 2004
I can't recall how I assembled my Cleveland brakes 10 years ago to get both the input high pressure lines on the top of the caliber assembly....I suspect I merely changed the location of the bleeder port thingy that Cleveland supplied...that way both input lines were on top and the bleeder thingys were on the bottom after installation...if my recollection is right it wouldn't make any difference which 'port' is used as the high pressure input. Does that sound right? A friend building an RV7 is scratching his head as to how I did it...so am I ! Does my shaky memory sound right? John ________________________________________________________________________________
Date: Mar 14, 2004
Subject: Re: Non-RV related Hanger related
If you are willing to do it all yourself & just need an RV sized hangar (30' span), drop me a line for a way to do it even cheaper that that. Charlie Charlie: you've stood in my 36x48x12 hangar recently, a homebuilt pole building with engineered trusses on 4 foot centers, and I've got about $10k in it all-up (slab, sides, roof, doors, water & electric). I bet you can get him in a 30 foot span for cheap if he's willing to swing his own hammer :-) -Bill Boyd Clifton Forge, VA ________________________________________________________________________________
Subject: Re: Cleveland Brake Assembly
Date: Mar 14, 2004
Yes On Mar 14, 2004, at 3:35 PM, John wrote: > > I can't recall how I assembled my Cleveland brakes 10 years ago to > get both > the input high pressure lines on the top of the caliber assembly....I > suspect I merely changed the location of the bleeder port thingy that > Cleveland supplied...that way both input lines were on top and the > bleeder > thingys were on the bottom after installation...if my recollection is > right > it wouldn't make any difference which 'port' is used as the high > pressure > input. > > Does that sound right? A friend building an RV7 is scratching his head > as to > how I did it...so am I ! > > Does my shaky memory sound right? > > John > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Mar 14, 2004
Subject: Items for Sale
Time for the garage sale of leftover items from my project. All items are new-in-box, unless noted. All prices include UPS shipping to anywhere in the lower 48, anywhere else, contact me and we'll work something out. Jeff Point Milwaukee, WI RV-6 signed off, ready to fly, waiting for the weather to improve... Complete Alternator Kit 60 AMP Part Number = ES ALTERNATOR 60A KIT Price = $250.00 ES 14684: A small lightweight high output unit that is capable of developing 60 amperes (12 volt DC). This unit is INTERNALLY voltage regulated and will work fine with any of the batteries sold by Van's Aircraft. ES ALTERNATOR 60A KIT: Kit includes the alternator and a bracket for mounting on boss mount style Lycoming engines. Was bolted to the engine briefly, but never run. Sell for $240. Passenger brakes for overhead mounted rudder bars (RV-6/6A, 7/7A, 9/9A) Part Number = BRAKE DUAL OVERHEAD Price = $170.00 Allows complete control from either seat. Kit includes master cylinders, hoses and all hardware. New in box, never opened. Sell for $160. Gascolator Part Number = GAS-5 Price = $76.00 Quick Drain Bottom Part Number = CAV-110 Price = $8.90 Made of anodized aluminum, with a simple disc screen. The bottom is tapered so it drains completely. The side is drilled for mounting.Note: Quick drain for bottom is NOT INCLUDED. If not using a primer system, you must also purchase the brass plug for the primer port. New, never installed. Both for $80. I'll throw in the $.64 brass plug if you need it. Hose VA-139 FUEL SUPPLY HOSE 16.50"X3/8" $62.50 3/8" Aeroquip hose with firesleeve, used for fuel supply lines. New, never used. Sell for $55. ________________________________________________________________________________
Subject: Re: RV-4 N504RV Flew today
Date: Mar 14, 2004
Congrats Dave. Glad to see another 'antique" RV-4 take to the skies. Enjoy!!!!!!!!!!!!!! Doug Weiler Hudson, WI RV-4, N722DW, a 12-year project > >From: David Aronson <aronsond(at)pacbell.net> > >Reply-To: rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: RV-List: RV-4 N504RV Flew today > >Date: Sat, 13 Mar 2004 17:51:20 -0800 (PST) > > > > > >Hey listers: > >Thanks to many of you who support and are active on the RV-List, My RV-4, > >N504RV flew from Nut Tree Airport today. First flight, 40 minutes, to > >9,000 feet, ended with ground observing smoke and a leaky gasket to the > >prop gov. Otherwise, COOOOOL! > > Get business advice and resources to improve your work life, from bCentral. > > ________________________________________________________________________________
Date: Mar 14, 2004
Sounds right to me. That's how I did mine. One can change them as you describe, by swapping the "thingys" Steve Struyk RV-8, N842S (res.) St. Charles, MO wiring ----- Original Message ----- From: "John" <n1cxo320(at)salidaco.com> Subject: RV-List: Cleveland Brake Assembly > > I can't recall how I assembled my Cleveland brakes 10 years ago to get both > the input high pressure lines on the top of the caliber assembly....I > suspect I merely changed the location of the bleeder port thingy that > Cleveland supplied...that way both input lines were on top and the bleeder > thingys were on the bottom after installation...if my recollection is right > it wouldn't make any difference which 'port' is used as the high pressure > input. > > Does that sound right? A friend building an RV7 is scratching his head as to > how I did it...so am I ! > > Does my shaky memory sound right? > > John > > ________________________________________________________________________________
Subject: Re: Gretz trim servo travel
Date: Mar 14, 2004
Did you ever run out of nose down trim? Jeff Dowling ----- Original Message ----- From: "Dennis Persyk" <dpersyk(at)worldnet.att.net> Subject: RE: RV-List: Gretz trim servo travel > > The Gretz electric trim in my 6A had insufficient authority to trim the > plane in all configurations. In particular, on final with full flaps, I had > to exert some stick back pressure. I do not like flying an out-of-trim > plane, so in retrospect the manual trim would have been a better solution. I > chose the electric trim to get rid of that big knob that seemed to be in the > wrong place! > > Regards, > > Dennis Persyk N600DP sold > Pictures at http://home.att.net/~dpersyk/rv6a.htm > > From: "Charles Becker" <ctbecker(at)charter.net> > Subject: RE: RV-List: Gretz trim servo travel > > > I agree with an earlier post. I think that you are applying the elevator up > and down requirements to the trim tab. > > Charles Becker > N464CB RV8A(e) > Wings > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of jakent(at)unison.ie > Subject: RV-List: Gretz trim servo travel > > > The trim tab horn is shorter for the electric trim. Remember the servo only > has 1.2 inch travel and the cable travels more than this with the manual > trim. > If, as in my case, changing he horn is too much metal butchery, then do as > I did and instal a ratio arm (lever) between the servo and cable end. On my > RV-4 it let me get full tab travel and also let me reverse the direction of > the servo to make a neater installation. Just do the maths for the correct > lever ratios. John Kent (Ireland) > > ________________________________________________________________________________
Date: Mar 14, 2004
Subject: O-290D2 cylinders wanted
A freind of mine, who is not on the Internet, is looking for servicable O-290D2 cylinders for his RV-3. Please call him, if you have a lead or what he wants. Mike: 813-884-4600. Finn ________________________________________________________________________________
Subject: Crossover Exhaust with Mufflers?
Date: Mar 14, 2004
Does anyone have mufflers on their Lycoming powered RV? What's your experience been? Would you do it again? Has anyone installed the exhaust system with Mufflers from http://www.aircraftexhaust.net yet? I'm installing an O-320 and a fixed pitch Sensenich prop which has a 2600 red-line. I'm thinking this should limit my tip speed noise somewhat so before I buy an exhaust system without mufflers I was wondering if anyone has ANYTHING (good or bad) to say about a system with mufflers as it applies to an RV. Thanks, Tony Kirk RV-6A Finish http://members.accesstoledo.com/jkirk/rv6a/index.htm ________________________________________________________________________________
Subject: Re: AIRPORT THREATS-not RV related
Date: Mar 15, 2004
one thing to consider is the revenue produced by "hosting" a NASCAR race. every driver, owner, and crew fly to the race site. that is, there will be at least 43 drivers, somewhere around 25 owners, and several hundred crew members, and the sponsors and their associates, and fans that fly in in RV's and Spam cans. all of these people will be looking for food, hotels, and jet-A and 100LL. also, they will need a tie down spot or hanger, and many other things. so some of the revenue generated could be used to effect airport repairs or upgrades, parks, and other civic and economic ventures in your community. just another way to look at a 3 to 4 day hold on flying out of your home airport. another possibility to look at is moving your plane to another airport and rent your hanger to someone flying in. My only interest in NASCAR is as a fan. and I lived in Florence, South Carolina. it is fifteen minutes from Darlington raceway. twice a year, the race would "come to town". The impact on the community is tremendous. restaurants, hotels, stores, and many other businesses would do millions in revenue. NASCAR is also extremely committed to communities that they visit. as I said, just another way to look at the situation. thank you, Tommy Mead bigun73(at)msn.com ----- Original Message ----- From: JNice51355(at)aol.com<mailto:JNice51355(at)aol.com> To: rv-list(at)matronics.com Sent: Sunday, March 14, 2004 2:56 PM Subject: RV-List: AIRPORT THREATS-not RV related Folks International Speedway Corporation of Daytona, Florida is collecting information about possible track sites in the pacific northwest. It is quite disturbing, as there is alot that comes with the building of a "major" racing facility. In my neck of the woods, at least(I believe they are looking along the I-5 corridor in WA & OR) there are three possible sites that may be considered. ALL THREE sites, if developed, would adversely affect general aviation via TFR's. TWO of these are just South of Arlington Municipal Airport, home of the EAANW Fly-In. If a dot was placed on the map in the approx. center of the proposed track site, and a 3NM radius drawn, either of those two sites would "totally encompass" the airport. The patrons at the airport are pursuing various methods to ensure the final siting is not too close to any airport, much less this one. We will also be working to get out the word to homeowners, since there are ALOT of these folks that would also be adversely affected. We are NOT Anti-NASCAR here, but we are certainly hoping that there will be a way for ISC to meet their "criteria" for a site without beating down airports and homeowners. There are other sites also being considered. It is my thought that if there is enough visibility given to Arlington Municipal Airport along with other airports in general, that it may play into their decision as to where to site a facility. If there is any interest by the folks on this list, it would be appreciated if contact could be made with Thomas Valley, Director of Corporate Development, International Speedway Corporation, 1801 International Speedway Blvd., Daytona, Florida 32114. The phone number is 386-254-2700. There are two lines of thought to me right now. One is the fact that these folks be made to understand things in a Post 9/11 mentality. The other is that if they just plain don't care about these matters, that they understand that some of these sites might be mired in litigation should that become necessary. Generally, I would think that they are looking for a big bang for the buck without alot of unforseen headaches. There may be other sites that would work better in that regard, like ones that are set just a little farther from subdivisions and airports. Any help in attempting to preserve our "little piece of paradise" would be greatly appreciated. James Nice WA State ________________________________________________________________________________
Date: Mar 15, 2004
Sounds right to me. A couple weeks back I was at this step and on one of the brakes just removed the bleeder fitting and put it in the opposite side hole. This allowed both lines to be a the top of the bake assemblies. My A&P was here at the time and those were his instructions. Ron ----- Original Message ----- From: "John" <n1cxo320(at)salidaco.com> Subject: RV-List: Cleveland Brake Assembly > > I can't recall how I assembled my Cleveland brakes 10 years ago to get both > the input high pressure lines on the top of the caliber assembly....I > suspect I merely changed the location of the bleeder port thingy that > Cleveland supplied...that way both input lines were on top and the bleeder > thingys were on the bottom after installation...if my recollection is right > it wouldn't make any difference which 'port' is used as the high pressure > input. > > Does that sound right? A friend building an RV7 is scratching his head as to > how I did it...so am I ! > > Does my shaky memory sound right? > > John > > ________________________________________________________________________________
Subject: Narco AT150 Pin Orientation
Date: Mar 15, 2004
List: Those that have installed AT150 Transponders.......... If you are looking at the back of the radio, Which side is pin 1 for the molex connector? Is pin one on the right or the left? I have an installation manual and for the life of me I cannot see where that is designated. They do show a diagram for a connnector for a voltage converter which I do not need, but not for the transponder. Any help is much appreciated. Regards, Jeff Orear RV6A Panel Peshtigo, WI ________________________________________________________________________________
Date: Mar 15, 2004
Subject: Alternator Indicator Light hookup
Does anyone on the List know if an indicator light can be hooked up to the unused Yellow wire on Van's 35 amp system? Dan (for Weasel) ________________________________________________________________________________
Date: Mar 15, 2004
In a message dated 3/14/04 1:15:33 PM Central Standard Time, randy@rv-8.com writes: > 2. The interface looks like it requires a stylus -- anyone concerned about > using a stylus while bouncing around in a cockpit? Hi Randy- I'm using 2 PDAs built into my panel (EFIS & GPS) and when the going gets bumpy they sometimes do require several stabs to hit the right thing. Some time ago I saw some little plastic styluses (styli?) that just slipped over your fingertip (think Halloween witches fingernails!) that looked like a good solution with a little pad of velcro on top of it for storage under the glareshield. Problem is, I haven't been able to find any locally or on the internet- Anyone know where to get these? Mark Phillips - RV-6A N51PW - 50+ hours of grin! 8-) ________________________________________________________________________________
Subject: Re: Narco AT150 Pin Orientation
Date: Mar 15, 2004
Jeff: Looking from the back of the connector the left side is number 1. Looking very close at the connector you will see the numbers. ----- Original Message ----- From: "Jeff Orear" <jorear(at)new.rr.com> Subject: RV-List: Narco AT150 Pin Orientation > > List: > > Those that have installed AT150 Transponders.......... > > If you are looking at the back of the radio, Which side is pin 1 for the molex connector? Is pin one on the right or the left? > > I have an installation manual and for the life of me I cannot see where that is designated. They do show a diagram for a connnector for a voltage converter which I do not need, but not for the transponder. > > Any help is much appreciated. > > Regards, > > Jeff Orear > RV6A > Panel > Peshtigo, WI > > ________________________________________________________________________________
Date: Mar 15, 2004
Subject: Microaor 760 Comm
vansairforce Anyone have any experience with having a Microair Radio repaired? Is there a repair shop in the US? -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Date: Mar 15, 2004
Subject: Re: > Re: Narco AT 150 Pin Orientation
I can't give you a definite answer without removing the top skin from our RV-4. The numbers are stamped in the plastic of the connector on top. They are TINY though. I rubbed a black felt pen over them before I started wiring the connector,to make them more visible. Hope this helps, Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers do not arvhive ________________________________________________________________________________
Subject: Sat. Bar-BQ
Date: Mar 15, 2004
To all flying RV'ers, RV builders, or just thinking about building, for the best slow smoked pork bar-bq in the Southeast (imho) plus hamburgers, hotdogs, ham and all the other fixins come to our fly-in this Sat.Mar. 20th at Love's Landing Airpark (97FL) located 10 mi. North of Leesburg Fl. airport. This is the Mar. event for FL wing of Van's Airforce. There will be coffee and doughnuts for the early birds and lunch at noon. No programs, just a lot of RV tales and fellowship. For more info plus picture and satellite image look under activities calendar on Doug Reeve's great site- http://www.vansairforce.net/ or ollie-6a@prodigy.net Note: This is private airport; land at your own risk. Ollie Washburn 6A ________________________________________________________________________________
Date: Mar 15, 2004
I have a the new iPAQ 5555 and have been messing with it since day one, installing crap and whipping it and installing more crap, and I have never had a lockup of any kind... Not that it will never happen, but I think they are really getting good now... The 5555 has the 400 MHz XScale processor and 128 MB of onboard SDRAM, and I added an 128 MB SD card so I have plenty of storage space... It also have built in Wi-Fi/WLAN and Bluetooth... The Bluetooth is nice because I can use a Bluetooth GPS receiver and have no wires to dink with in the cockpit... Oh, and the battery is replaceable like a cell phone! Probably one of the nicest features... One more thing, if I don't want anyone else to use the thing I can set the security to only unlock after it scans and recognizes my fingerprint... Pretty freakin cool, and it actually works! Anyway, this is my 4th iPAQ and easily the best... There are a lot of guys here at work that have different variations on the palm, and nothing compares in my opinion... Other software I am running on it right now: Airport Insight - http://www.notamd.com/ FB FltLog - http://www.frontbeach.com/pocketlog/basic/ I am also looking at some checklist apps now, there are a lot of them! -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs www.vondane.com www.creativair.com www.epanelbuilder.com ----- Original Message ----- From: "Randy Lervold" <randy@rv-8.com> Subject: Re: RV-List: Ugrades Update... Bill, I've been watching these PDA-based solutions for some time, and have used a simple one in my glider with great success to run glide computer software. As I contemplate what to put in the panel of my new RV-3B project these look attractive but I still have two major concerns... 1. The PocketPC operating system is a typical Microsoft product and is complicated and bloated code and therefore prone to crashing, and managing it does require some real understanding of it. Anyone concerned about OS stability? 2. The interface looks like it requires a stylus -- anyone concerned about using a stylus while bouncing around in a cockpit? Thoughts on these? Randy Lervold RV-8, 368 hrs, sold RV-3B, starting construction ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> Subject: RV-List: Ugrades Update... > > Got my panel done and ready to paint... > > I also got my new moving map software yesterday and have been playing around > with this morning... It's the Mountain Scope Moving Map stuff from > www.pcavionics.com... So far I think it's VERY COOL... I have posted a > bunch of screen shots and info to my site... > > http://www.vondane.com/rv8a/finish/finish13.htm > > -Bill VonDane > EAA Tech Counselor > RV-8A ~ N8WV ~ Colorado Springs > www.vondane.com > www.creativair.com > www.epanelbuilder.com > > ________________________________________________________________________________
Date: Mar 15, 2004
In a message dated 3/14/04 2:37:03 PM Pacific Standard Time, n1cxo320(at)salidaco.com writes: << Does my shaky memory sound right? >> Yes Harry Crosby Pleasanton, California RV-6, final assembly ________________________________________________________________________________
Date: Mar 15, 2004
Randy, I would not want to use any windows products in flight crital computers. However, it is being done today by Avidine. There are several Electronic Flights Bag products that allow no paper in the cockpit that are windows based. For my own flying I have been using some map software on an Ipaq. I have never had the Ipaq lockup in flight (I have had problems with the GPS but not the Ipaq) I reboot the ipaq before each flight and only run my flight software. As for using a stylus, it can get tricky. I only fly VFR so route changes don't happen to often in the air. You can get a finger tip stylus that some people realy seem to like and make selection easier if you bouncing around. One other thing that helps is to have a place to brace your hand when your trying to touch the screen. Hope this helps, Alan Kritzman Cedar Rapids, IA RV-8 I've been watching these PDA-based solutions for some time, and have used a simple one in my glider with great success to run glide computer software. As I contemplate what to put in the panel of my new RV-3B project these look attractive but I still have two major concerns... 1. The PocketPC operating system is a typical Microsoft product and is complicated and bloated code and therefore prone to crashing, and managing it does require some real understanding of it. Anyone concerned about OS stability? 2. The interface looks like it requires a stylus -- anyone concerned about using a stylus while bouncing around in a cockpit? Thoughts on these? Randy Lervold ________________________________________________________________________________
Date: Mar 15, 2004
Subject: Re: Microaor 760 Comm(add T-2000)
Hi Bill- I had a problem with mine shortly after initial installation- e-mailed Australia and got instructions for return, boxed it up and took it to the post office. Was back with no charge after about 10-12 days, IIRC. While we're airing our Micros, has anyone else had the NO COMM error on their T-2000? Happens when I try to punch in a new code. According to manual, it may have to go back to Oz as well... Mark Phillips ________________________________________________________________________________
Date: Mar 15, 2004
In a message dated 3/15/04 12:29:55 PM Central Standard Time, N13eer(at)aol.com writes: > As for using a stylus, it can get tricky. I only fly VFR so route changes > don't happen to often in the air. You can get a finger tip stylus that some > people realy seem to like and make selection easier if you bouncing around. > One other thing that helps is to have a place to brace your hand when your > trying to touch the screen. Found the fingertip sylus at: http://www.truetip.com/ It's irritating that they require you to open an "account" to buy a $10 item, though...... Mark Phillips ________________________________________________________________________________
Date: Mar 15, 2004
Subject: First Flight
RV-6 N187CF, aka The Spruce Moose, took to the skies today for the first time. The flight was about 25 minutes, during which we climbed out to 5,000 ft. over the airport, checked temps and such, and came back for a landing. It flies like a dream, with only a slight heaviness to the right wing. Stats: RV-6 tip-up, slow build kit #25728, started 9/99. Approx. 1800 hours build time over 4 1/2 years. Aerosport Power O-360/ Ed Sterba 70X82 prop. Basic IFR panel w/ Dynon Heavy, but very comfortable Oregon aero seats 1,067lbs empty (surprisingly heavy, I question the scales...) I didn't get much in the way of numbers, other than a climb of 1500fpm at 100 kts. CHTs never went above 400, on a brand new engine. Lots of little things to be tweaked over the next few weeks. Many thanks to Matt for the list, as well as all listers who have been such a help over the years. Thanks to Alex Dedominicis for the transition training, which was a tremendous help. And of course, thanks Van for such a great design. Pictures and numbers will follow when time allows. Jeff Point RV-6 FLYING! Milwaukee, WI ________________________________________________________________________________
Date: Mar 15, 2004
Thanks, Shemp! I'm running out the door now, but will write back this evening. best, Cory ----- Original Message ----- From: "Shemp" <shempdowling(at)earthlink.net> Subject: Re: RV-List: Request: Information for Kitplanes Article (Interiors/Exteriors) > > Look at Jim Noram's Razmataz. > > > ----- Original Message ----- > From: "Cory Emberson" <bootless(at)earthlink.net> > To: > Subject: RV-List: Request: Information for Kitplanes Article > (Interiors/Exteriors) > > > > > > Hello! > > > > I am writing an article for Kitplanes magazine that will feature builders > who have distinctive interiors and/or exteriors. > > > > My deadline is rather short, so if you could email me as soon as possible, > hopefully by Tuesday, that will give me enough time to put it together. > > > > Here are some of the criteria I'm looking for: > > > > Interiors that are (one or any combination): > > > > 1. creative > > 2. inexpensive > > 3. very comfortable > > 4. lightweight > > 5. generally cool and different > > 6. distinctive in some way. > > > > Exteriors that are: > > > > 1.. stunningly attractive > > 2.. original design > > 3.. historically accurate > > 4.. distinctive in some way > > Other things to keep in mind: > > > > 1. How you came to design your interior/exterior (How you got your idea) > > 2. The reasons why you did it as you did > > 3. What benefits you had in mind > > 4. Any unexpected benefits (and/or pitfalls) there were > > 5. What you learned > > 6. How many hours you've flown with it (if completed) > > 7. How much of the work did you do yourself? > > 8. Did you have any professional assistance? How much? > > 9. The equipment and tools you used > > 10. How much time it took to build and install > > 11. The cost of building it. > > 12. Would you do it again the same way? Why? > > > > > > Here are the photo requirements for Kitplanes: Photos must be 300 dpi at a > size large enough to use in the magazine, which is usually at least 3 x 3 > inches. If an image is 300 dpi at 1 x 1 inch, it won't be big enough to do > any good. Hard copy photos are good, too. > > > > Thanks so much - I really appreciate your help! > > > > best regards, > > > > Cory Emberson > > Hayward, CA [KHWD] > > 510.599.4409 > > cory(at)lightspeededit.com > > > > > > ________________________________________________________________________________
Date: Mar 15, 2004
Subject: Re: Crossover Exhaust with Mufflers?
>... I was wondering if anyone >has ANYTHING (good or bad) to say about a system with mufflers as it applies >to an RV. You did say ANYTHING - right? :-) Thanks for looking into this. I really feel we all need to do our little part to keep aviation available to our children and grandchildren. Reducing the noise factor helps. We added a pretty serious muffler on our club's Piper Cherokee, which *greatly* reduced the noise, and I really didn't notice any difference in power output. Clearly there was a reduction, but I could not sense it while flying. It's completely under the cowl, so no additional drag. You don't see people that live near a lake complaining about the sailboats out there! -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
From: "Norman Younie" <rv6capt(at)pacificcoast.net>
Subject: TV Camera for Sale
Date: Mar 15, 2004
I know a few guys are thinking about installing cameras on their aircraft. Here's a camera that I can get for whoever is interested. This is just the camera, receiver, antenna and transformers - they work on 9V, NTSC system 380 lines, color and sound. Quality is excellent. You will still need a recorder to record the images. The photo pretty much speaks for itself. If anyone wants more information, contact me at rv6capt(at)pacificcoast.net $78 (US) each set ________________________________________________________________________________
Subject: Re: Carson City Fly-in
Date: Mar 15, 2004
NO SR-71 or RV-11 but we will have the RV-10. And yes this event is in Nevada. This fly-in will be our first so we'll see how many it drawls. Bruce >From: kempthornes <kempthornes(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Carson City Fly-in >Date: Sat, 13 Mar 2004 18:51:05 -0800 > > >At 03:51 PM 3/13/2004, you wrote: > > > >The dates are Apr. 30th through May 2nd. The 30th is set up for early > >arrivals. You can find more info. on vansaircraft.com under FLY-IN >SCHEDULE. > >That will forward you to the host sight. Thanks for the interest and hope > >you and some others can make it. Bruce >Thanks for the invite, Bruce! > >I did the linking and jumping and found that indeed, the fly in is at >CARSON CITY , NEVADA. (Not carson city, NY.) > >It has so far been a somewhat secretive event so it must really be worth >attending - maybe the SR71 will fly by or the Wright Flyer or even the >RV11? > >hal >(This Paso Robles Zinfandel is some good wine!) > > One-click access to Hotmail from any Web page download MSN Toolbar now! http://clk.atdmt.com/AVE/go/onm00200413ave/direct/01/ ________________________________________________________________________________
Subject: Re: First Flight
Date: Mar 15, 2004
Bless you & "the Moose" Jeff... and here's wishing Calm Blue Skies to you both. ----- Original Message ----- From: Jeff Point <jpoint(at)mindspring.com> Subject: RV-List: First Flight > > RV-6 N187CF, aka The Spruce Moose, took to the skies today for the first > time. The flight was about 25 minutes, during which we climbed out to > 5,000 ft. over the airport, checked temps and such, and came back for a > landing. It flies like a dream, with only a slight heaviness to the > right wing. > > Stats: > RV-6 tip-up, slow build kit #25728, started 9/99. > Approx. 1800 hours build time over 4 1/2 years. > Aerosport Power O-360/ Ed Sterba 70X82 prop. > Basic IFR panel w/ Dynon > Heavy, but very comfortable Oregon aero seats > 1,067lbs empty (surprisingly heavy, I question the scales...) > > I didn't get much in the way of numbers, other than a climb of 1500fpm > at 100 kts. CHTs never went above 400, on a brand new engine. Lots of > little things to be tweaked over the next few weeks. > > Many thanks to Matt for the list, as well as all listers who have been > such a help over the years. Thanks to Alex Dedominicis for the > transition training, which was a tremendous help. And of course, thanks > Van for such a great design. > > Pictures and numbers will follow when time allows. > > Jeff Point > RV-6 FLYING! > Milwaukee, WI > > ________________________________________________________________________________
Date: Mar 15, 2004
From: Charlie & Tupper England <cengland(at)netdoor.com>
SportAV8R(at)aol.com wrote: > >If you are willing to do it all yourself & just need an RV sized hangar >(30' span), drop me a line for a way to do it even cheaper that that. > >Charlie > >Charlie: you've stood in my 36x48x12 hangar recently, a homebuilt pole building with engineered trusses on 4 foot centers, and I've got about $10k in it all-up (slab, sides, roof, doors, water & electric). I bet you can get him in a 30 foot span for cheap if he's willing to swing his own hammer :-) > >-Bill Boyd >Clifton Forge, VA > Hi Bill, First, pencil in the 1st Saturday in June so ya'll can come on down to Slobovia & eat whatever we decide to cook for our next flyin. Just throw in a couple of sleeping bags & we'll find a place out of the heat for you to sleep. It might even be a bed! Now, on to the hangar: $10k is really impressive considering that your hangar is complete with door, power, water, etc. I added a 30' X 48' 'lean-to' to my hangar about 5 years ago, & the metal purlins (rafters) & roofing came to about $1500. The slab was around $2k, with me doing the form work but paying for the pour & finishing. I believe I could do a bare bones 30x50 for under $5k. I keep threatening to write a magazine article about it, but priorities..... Come see us & bring the family. Charlie ________________________________________________________________________________
Date: Mar 15, 2004
Hi Bill No direct experience but check with American Avionics in Seattle. If I remember correctly they said that normally the Microair goes back to Australia for warranty work but that they did have complete circuit boards for the Microair. George in Langley ----------- Anyone have any experience with having a Microair Radio repaired? Is there a repair shop in the US? -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs www.vondane.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Date: Mar 15, 2004
Subject: Party invitation (was: Non-RV related Hanger related)
OOPS; thought this was going straight to Bill, but consider it your pre invitation announcement for our next weekend party here at Slobovia Outernational (MS71) near Jackson MS. Details to follow. Charlie -------- Original Message -------- Subject: Re: RV-List: Non-RV related Hanger related Date: Mon, 15 Mar 2004 19:18:12 -0600 From: Charlie & Tupper England <cengland(at)netdoor.com> SportAV8R(at)aol.com wrote: > >If you are willing to do it all yourself & just need an RV sized hangar >(30' span), drop me a line for a way to do it even cheaper that that. > >Charlie > >Charlie: you've stood in my 36x48x12 hangar recently, a homebuilt pole building with engineered trusses on 4 foot centers, and I've got about $10k in it all-up (slab, sides, roof, doors, water & electric). I bet you can get him in a 30 foot span for cheap if he's willing to swing his own hammer :-) > >-Bill Boyd >Clifton Forge, VA > Hi Bill, First, pencil in the 1st Saturday in June so ya'll can come on down to Slobovia & eat whatever we decide to cook for our next flyin. Just throw in a couple of sleeping bags & we'll find a place out of the heat for you to sleep. It might even be a bed! Now, on to the hangar: $10k is really impressive considering that your hangar is complete with door, power, water, etc. I added a 30' X 48' 'lean-to' to my hangar about 5 years ago, & the metal purlins (rafters) & roofing came to about $1500. The slab was around $2k, with me doing the form work but paying for the pour & finishing. I believe I could do a bare bones 30x50 for under $5k. I keep threatening to write a magazine article about it, but priorities..... Come see us & bring the family. Charlie ________________________________________________________________________________
Date: Mar 15, 2004
From: "Ted Hultzapple" <thultzap(at)rochester.rr.com>
Subject: Intake scoop for Sam James cowl.
Date: Mar 15, 2004
Hello listers, I am building an RV8A with an O-360 carb engine. What Intake scoop should I use for the intake air? Van's sells one for the RV4 and one for the RV6, but none for the 8. Ted H. ________________________________________________________________________________
Date: Mar 15, 2004
> Absolutely valid concerns! I'm planning on a mini PC in my > RV10...moving map GPS, MP3's, DVD, flight planning software, etc. > My > main concerns are ops sys, and user interface. Oh, the survivability of > hard drives in a choppy flight environment gives me pause as well, but > this will not be a safety of flight concern...merely an annoyance. > I'm planning on this solely as a nice-to-have item, and can > aviate/navigate/communicate just fine without it. Oh, it also rates > very high on the "cool factor" scale. ;) I'm planning a similar setup for my RV-10. Proven (non-Bill Gates) systems for primary aviate/navigate/communicate. Glass panel (tablet PC such as Motion M1300VA with indoor/outdoor display) for large moving map, weather (WxWorx.com), CD/DVD, flight planning S/W, etc. I've also been concerned about hard drive survivability. I think a viable solution is to remove the hard drive entirely and go with solid state main memory (USB thumb drive, or similar). There are already bootable thumb drives, so it appears this approach could be undertaken today. By the time my RV-10 is ready to have the tablet PC mounted I should be able to get a lot more tablet PC for the money, with huge solid state "hard drive" available for a fraction of today's price. Now, if WxWorx/XM will just come down from that $50/month price point... Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 600 hrs RV-10 #40059 under construction http://www.geocities.com/timrv6a -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD - 600 hrs RV-10 #40059 under construction http://www.geocities.com/timrv6a ________________________________________________________________________________
Date: Mar 15, 2004
Subject: Re: OT: Oshkosh bound...
Ken, The ground at OSH is sandy and rocky and difficult to get the screw-in tie down anchors to go into. You may want to make sure you have some good tiedowns that will work in that kind of soil. They were described on the EAA web site last year. I haven't looked this year. Each one has three long "nails" that drive into the ground. I used to use the "medium dog size" corkscrew type but those aren't too good up there. Dan RV-7A ( getting closer -- hope to fly this Spring) ________________________________________________________________________________
Date: Mar 15, 2004
Maybe I'm remembering this wrong from bleeding brakes in my old auto-shop days, but isn't the bleeder valve ("thingy") supposed to be at the top? It's purpose is to purge the system / caliper of air and the air naturally floats to the top in the caliper piston cavity. Having the bleeder at the bottom may allow trapped air to stay in the caliper. Maybe aircraft calipers are different but it seems they should function the same as on an auto. Doug Fischer -9A ----- Original Message ----- From: "Ron Walker" <ron(at)walker.net> Subject: Re: RV-List: Cleveland Brake Assembly > > Sounds right to me. A couple weeks back I was at this step and on one of the > brakes just removed the bleeder fitting and put it in the opposite side > hole. This allowed both lines to be a the top of the bake assemblies. My A&P > was here at the time and those were his instructions. > > Ron > > ----- Original Message ----- > From: "John" <n1cxo320(at)salidaco.com> > To: > Subject: RV-List: Cleveland Brake Assembly > > > > > > I can't recall how I assembled my Cleveland brakes 10 years ago to get > both > > the input high pressure lines on the top of the caliber assembly....I > > suspect I merely changed the location of the bleeder port thingy that > > Cleveland supplied...that way both input lines were on top and the bleeder > > thingys were on the bottom after installation...if my recollection is > right > > it wouldn't make any difference which 'port' is used as the high pressure > > input. > > > > Does that sound right? A friend building an RV7 is scratching his head as > to > > how I did it...so am I ! > > > > Does my shaky memory sound right? > > > > John > > > > > > ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Mar 15, 2004
> > Maybe I'm remembering this wrong from bleeding brakes in my > old auto-shop days, but isn't the bleeder valve ("thingy") > supposed to be at the top? It's purpose is to purge the > system / caliper of air and the air naturally floats to the > top in the caliper piston cavity. Having the bleeder at the > bottom may allow trapped air to stay in the caliper. Maybe > aircraft calipers are different but it seems they should > function the same as on an auto. > > Doug Fischer > -9A Doug, they are different. The "bleeder" is on the bottom, but hydraulic fluid (don't use brake fluid!) is pumped into this port and pushed all the way through the master cylinders and on to the reservoir. Actually quite simple to do, and you don't need two people, either. Alex Peterson Maple Grove, MN RV6-A N66AP 445 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Mar 15, 2004
Maybe it is simple on your airplane, but on a -4 it is usually a real P.I.T.A. -4s tend to have a loop above the master cylinder and I have never been able to back-bleed them, I always have to push it down from the top with my finger over the bleeder. It takes a bunch of fluid and makes a big mess. One of the worst airplanes I know of to bleed the brakes on. I have talked to others who tell the same story on the -4. Doug Rozendaal > Actually > quite simple to do, and you don't need two people, either. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 445 hours > http://www.home.earthlink.net/~alexpeterson/ > > ________________________________________________________________________________
Date: Mar 15, 2004
Most A/P's bleed the brakes with a pressure pot, from the bottom up. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Douglas A. Fischer Subject: Re: RV-List: Cleveland Brake Assembly Maybe I'm remembering this wrong from bleeding brakes in my old auto-shop days, but isn't the bleeder valve ("thingy") supposed to be at the top? ________________________________________________________________________________
Subject: Re: Intake scoop for Sam James cowl.
Date: Mar 15, 2004
> Hello listers, I am building an RV8A with an O-360 carb engine. What Intake > scoop should I use for the intake air? Van's sells one for the RV4 and one > for the RV6, but none for the 8. > Ted H. Ted, I believe I used the one for the RV-6... http://www.rv-8.com/Cowl.htm Have fun! Randy Lervold RV-8, 368 hrs, sold RV-3B, starting construction ________________________________________________________________________________
Date: Mar 16, 2004
Jeff, CONGRATULATIONS and WELL DONE !!! Chuck & Dave Rowbotham RV-8A >From: Jeff Point <jpoint(at)mindspring.com> >Reply-To: rv-list(at)matronics.com >To: RV List >Subject: RV-List: First Flight >Date: Mon, 15 Mar 2004 14:42:57 -0600 > > >RV-6 N187CF, aka The Spruce Moose, took to the skies today for the first >time. The flight was about 25 minutes, during which we climbed out to >5,000 ft. over the airport, checked temps and such, and came back for a >landing. It flies like a dream, with only a slight heaviness to the >right wing. > >Stats: >RV-6 tip-up, slow build kit #25728, started 9/99. >Approx. 1800 hours build time over 4 1/2 years. >Aerosport Power O-360/ Ed Sterba 70X82 prop. >Basic IFR panel w/ Dynon >Heavy, but very comfortable Oregon aero seats >1,067lbs empty (surprisingly heavy, I question the scales...) > >I didn't get much in the way of numbers, other than a climb of 1500fpm >at 100 kts. CHTs never went above 400, on a brand new engine. Lots of >little things to be tweaked over the next few weeks. > >Many thanks to Matt for the list, as well as all listers who have been >such a help over the years. Thanks to Alex Dedominicis for the >transition training, which was a tremendous help. And of course, thanks >Van for such a great design. > >Pictures and numbers will follow when time allows. > >Jeff Point >RV-6 FLYING! >Milwaukee, WI > > One-click access to Hotmail from any Web page download MSN Toolbar now! http://clk.atdmt.com/AVE/go/onm00200413ave/direct/01/ ________________________________________________________________________________
Date: Mar 16, 2004
> > Maybe it is simple on your airplane, but on a -4 it is > usually a real P.I.T.A. -4s tend to have a loop above the > master cylinder and I have never been able to back-bleed > them, I always have to push it down from the top with my > finger over the bleeder. It takes a bunch of fluid and makes > a big mess. One of the worst airplanes I know of to bleed the > brakes on. I have talked to others who tell the same story on the -4. > > Doug Rozendaal Doug, you need to time your inverted flight just right, combined with a little knife edge..... on a more serious note, is the tubing, from which these loops above the master cylinders are made, too large a diameter? Such that fluid/air gets mixed up? I would think that shoving it in from the bottom of the wheel cylinders quickly enough would take care of the mixing. It does require attaching a tube to the top of the reservoir to catch the extra fluid belching out the top. Alex Peterson Maple Grove, MN RV6-A N66AP 445 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Mar 16, 2004
For some reason, the RV series started with the master cylinders installed up-side down creating a loop. It needs to be corrected with the lines always going down hill. Otherwise you WILL have problem. Don't feel you are alone. The Bonanza is difficult because the brake line goes down hill due to the dihedral of the wing. You can make it easier by jacking up the other side. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or sportpilot(at)eaa.org Always looking for articles for Sport Pilot ----- Original Message ----- From: "Doug Rozendaal" <dougr(at)petroblend.com> Subject: Re: RV-List: Cleveland Brake Assembly > > Maybe it is simple on your airplane, but on a -4 it is usually a real > P.I.T.A. -4s tend to have a loop above the master cylinder and I have never > been able to back-bleed them, I always have to push it down from the top > with my finger over the bleeder. It takes a bunch of fluid and makes a big > mess. One of the worst airplanes I know of to bleed the brakes on. I have > talked to others who tell the same story on the -4. > > Doug Rozendaal > > > > Actually > > quite simple to do, and you don't need two people, either. > > > > Alex Peterson > > Maple Grove, MN > > RV6-A N66AP 445 hours > > http://www.home.earthlink.net/~alexpeterson/ > > > > > > ________________________________________________________________________________
Date: Mar 16, 2004
rv8list(at)yahoogroups.com, "vansairforce " Hey Mark... Good news... I called Microair last night and talked to one of their techs... I told him the two things I THOUGHT I might have done to damage my radio, which was; key the mic without an antenna, and operate the radio with too low a voltage, and he told me neither one of those should have damaged the radio... He told me to make a test cable and power up the radio on the bench... So I went back out to the hangar last night, did that and it worked fine... Hooked everything back up in the plane again.....It all worked perfectly... (I've had a battery charger on for a day at this point) ...so I guess the low voltage that my battery was putting out wasn't enough for things to work properly... So anyway, I don't need to get my radio repaired after all... he also told me to have it repaired, if need be, would only be about two weeks turn around, and he has never seen one that was more than $100 to fix... -Bill ----- Original Message ----- From: <menavrat(at)rockwellcollins.com> Subject: Microaor 760 Comm Ok Bill, don't leave us hangin', the suspense is killing me....did yours break? What happened to it? --Mark Navratil Cedar Rapids, Iowa RV-8A N2D fwf....with Microair Comm for my panel.... From: Bill VonDane <bill(at)vondane.com> Subject: RV-List: Microaor 760 Comm vansairforce Anyone have any experience with having a Microair Radio repaired? Is there a repair shop in the US? -Bill VonDane EAA Tech Counselor RV-8A ~ N8WV ~ Colorado Springs ________________________________________________________________________________
Date: Mar 16, 2004
Subject: RE: RV-List: Cleveland Brake Assembly > > Maybe it is simple on your airplane, but on a -4 it is > usually a real P.I.T.A. -4s tend to have a loop above the > master cylinder and I have never been able to back-bleed > them, I always have to push it down from the top with my > finger over the bleeder. It takes a bunch of fluid and makes > a big mess. One of the worst airplanes I know of to bleed the > brakes on. I have talked to others who tell the same story on the -4. > > Doug Rozendaal Doug, you need to time your inverted flight just right, combined with a little knife edge..... on a more serious note, is the tubing, from which these loops above the master cylinders are made, too large a diameter? Such that fluid/air gets mixed up? I would think that shoving it in from the bottom of the wheel cylinders quickly enough would take care of the mixing. It does require attaching a tube to the top of the reservoir to catch the extra fluid belching out the top. Alex Peterson I am using the nylon tubing for the brakes on the -4 so the fluid is visible. I've found that by keeping the fluid reservoir filled and with the bottom bleeder open, air bubbles, if they exist will flow down into the brake assembly. From there, some are expelled but not all. After closing the bleeder such air that is still in the brake assy will rise to the top and appear at the elbow fitting. After the air stops collecting, cracking the fitting will allow it to escape. Sometimes this must be done more than once but it does a good job of ridding the system of air. Gordon Comfort N363GC ________________________________________________________________________________
Date: Mar 16, 2004
The cure for this is to use a vacuum bleeder and bleed from the bottom. You can get one from your local auto parts store. If you contact Steve Wood @ RVator(at)aol.com he can help you get one if you aren't able to find one where you live. Karl RV-8 in Indy -----Original Message----- From: Gordon and Marge [mailto:gcomfo(at)tc3net.com] Subject: RE: RV-List: Cleveland Brake Assembly Subject: RE: RV-List: Cleveland Brake Assembly > > Maybe it is simple on your airplane, but on a -4 it is > usually a real P.I.T.A. -4s tend to have a loop above the > master cylinder and I have never been able to back-bleed > them, I always have to push it down from the top with my > finger over the bleeder. It takes a bunch of fluid and makes > a big mess. One of the worst airplanes I know of to bleed the > brakes on. I have talked to others who tell the same story on the -4. > > Doug Rozendaal Doug, you need to time your inverted flight just right, combined with a little knife edge..... on a more serious note, is the tubing, from which these loops above the master cylinders are made, too large a diameter? Such that fluid/air gets mixed up? I would think that shoving it in from the bottom of the wheel cylinders quickly enough would take care of the mixing. It does require attaching a tube to the top of the reservoir to catch the extra fluid belching out the top. Alex Peterson I am using the nylon tubing for the brakes on the -4 so the fluid is visible. I've found that by keeping the fluid reservoir filled and with the bottom bleeder open, air bubbles, if they exist will flow down into the brake assembly. From there, some are expelled but not all. After closing the bleeder such air that is still in the brake assy will rise to the top and appear at the elbow fitting. After the air stops collecting, cracking the fitting will allow it to escape. Sometimes this must be done more than once but it does a good job of ridding the system of air. Gordon Comfort N363GC __________________________________ The information contained in this email and any accompanying documents is intended for the sole use of the recipient to whom it is addressed, and may contain information that is privileged, confidential, and prohibited from disclosure under applicable law. If you are not the intended recipient, or authorized to receive this on behalf of the recipient, you are hereby notified that any review, use, disclosure, copying, or distribution is prohibited. If you are not the intended recipient(s), please contact the sender by e-mail and destroy all copies of the original message. Thank you. ________________________________________________________________________________
Date: Mar 16, 2004
Subject: RV8 horizontal stabilizer mounting problem
Ouch. I goofed while drilling the holes for the forward spar on the HS. I'm not sure what to do, and I would appreciate any advice you can offer. I've got pictures and details on my site, and I would be happy to hear any advice or tips or tricks. http://www.rv8.ch/article.php?story 04031620072395 Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Mar 16, 2004
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Re: RV8 horizontal stabilizer mounting problem
I had a problem something like this and just added another angle bracket on the other side, drilled and added an additional bolt on each side with Van's blessing. > >Ouch. I goofed while drilling the holes for the forward >spar on the HS. I'm not sure what to do, and I would >appreciate any advice you can offer. I've got pictures >and details on my site, and I would be happy to hear >any advice or tips or tricks. > > http://www.rv8.ch/article.php?story 04031620072395 > >Thanks, >Mickey > > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 16, 2004
Subject: OSH tie-downs
So what are the best tie-downs for OSH? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 16, 2004
-----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Bilinski Subject: Re: RV-List: RV8 horizontal stabilizer mounting problem I had a problem something like this and just added another angle bracket on the other side, drilled and added an additional bolt on each side with Van's blessing. > >Ouch. I goofed while drilling the holes for the forward >spar on the HS. I'm not sure what to do, and I would >appreciate any advice you can offer. I've got pictures >and details on my site, and I would be happy to hear >any advice or tips or tricks. > > http://www.rv8.ch/article.php?story 04031620072395 > >Thanks, >Mickey > > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 16, 2004
Subject: Re: K&N Filter...
In a message dated 3/16/04 4:58:15 PM US Eastern Standard Time, bill(at)vondane.com writes: > > Anyone have their K&N filter handy that could give me the part number off > it? > > Thanks! > > > -Bill VonDane Bill, The one for the IO-360 is 33-2060. I think that is the K&N number. Vans number is E-33-2060. Dan RV-7A (almost done) ________________________________________________________________________________
Date: Mar 16, 2004
Subject: Re: OSH tie-downs?
Scott and others... I'm kinda biased, but I think my titanium Ti-downs are by far the best Tie-down option for OshKosh and anywhere else, for that matter *smile* I wandered all over the OshKosh grounds the last two fly-in's, screwing in the Ti-downs in all over the place, and they worked most excellently there....I think that anyone that's used them will agree... Less than two pounds total for the kit, easy to use, and extremely strong. Two years ago, I got a kick outta seeing the big barrell of broken doggie tie-downs there at Osh...shoulda taken a picture of that. Sincerely, Randy Simpson Airtime Mfg. http://www.airtimemfg.com p.s. I'm working overtime trying to get caught up on orders right now...If you've ordered a set or kit, they'll be shipped soon. My little note here on the RV-list from a couple weeks ago was very successful, orderwise. Five kits are going in the mail today, with the rest to follow later this week, hopefully... pp.s. After this coming friday (the first day of spring), the $10 RV-list discount is going away, along with the free shipping... ------------ > >So what are the best tie-downs for OSH? > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 16, 2004
These are the best I've found....highly recommended. http://www.airtimemfg.com/ Read Sam B.'s product review at: http://home.hiwaay.net/~sbuc/journal/tidowns.html Laird > >So what are the best tie-downs for OSH? > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 > > ________________________________________________________________________________
Date: Mar 16, 2004
Scott Bilinski wrote: > >So what are the best tie-downs for OSH? > 12" nails from home depot. You can use 3 at each tiedown pushed in like a teepee with the rope wound around the apex. Useful in sand, clay and hardpan (with a handy hammer). Cheap and easily replaced. Linn > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 > > > > ________________________________________________________________________________
Date: Mar 16, 2004
Subject: RV-List: RV8 horizontal stabilizer mounting problem Ouch. I goofed while drilling the holes for the forward spar on the HS. I'm not sure what to do, and I would appreciate any advice you can offer. I've got pictures and details on my site, and I would be happy to hear any advice or tips or tricks. http://www.rv8.ch/article.php?story 04031620072395 Thanks, Mickey Hi Mickey I remember having edge distance problems in this area also. If Vans says not to worry I would accept that, however just to make myself feel even better I would make a 1/8" doubler plate that extends outboard far enough to have proper hole edge distance (if possible) and inboard far enough to pick up on the inboard bolt. On another point if it is (was) the final installation the inboard bolt looks long, make sure the nut is not bottoming out on the bolt shank. George in Langley ________________________________________________________________________________
Date: Mar 16, 2004
Scott, you know better than to ask for the "best" of anything on this list:-) My choice is the titanium ti-downs. They only like dog stakes, otherwise no comparison. They absolutely won't break and you can twist them with enough force to penetrate any soil and rocks and get deep enough to anchor firmly in almost anything, even the SnF sand. I've used them with my Citabria and Navion at both OSH & SnF with no fear. I voted with my wallet... I thought enough of them to buy 10 sets for Xmas gifts one year. Regards, Greg Young - Houston (DWH) RV-6 N6GY ...project Phoenix Navion N5221K - just an XXL RV-6A > > --> <bilinski@kyocera-wireless.com> > > So what are the best tie-downs for OSH? > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 16, 2004
Mickey, How about using a one legged nut plate instead of an AN365 nut? I "think" the number is MS21051-L3 The nutplate would be attached to the angle in question with 2 AN426AD-3 rivets. The nutplate would be anchored to the angle through those 2 rivets, which would not be near any edge. Charlie Kuss > >Ouch. I goofed while drilling the holes for the forward >spar on the HS. I'm not sure what to do, and I would >appreciate any advice you can offer. I've got pictures >and details on my site, and I would be happy to hear >any advice or tips or tricks. > > http://www.rv8.ch/article.php?story 04031620072395 > >Thanks, >Mickey > > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > ________________________________________________________________________________
Date: Mar 16, 2004
Scott Bilinski wrote: > >So what are the best tie-downs for OSH? > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 > Here's the triple spike system someone mentioned: http://www.theclaw.com/products/claw.php Just some Mississippi good ol' boys tryin' to make a livin'. Give 'em a call; we need the money down here. :-) Charlie (no financial ties to them) ________________________________________________________________________________
Date: Mar 17, 2004
Scott: I have used the same ones for 5 of the past 6 AirVenture Oshkosh. I purchased them from Randy Simpson at http://www.airtimemfg.com/ Check the archives about 6 years ago to see what I and everyone else had to say. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,442 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: Scott Bilinski <bilinski@kyocera-wireless.com> Subject: RV-List: OSH tie-downs Date: Tue, 16 Mar 2004 13:39:54 -0800 <bilinski@kyocera-wireless.com> So what are the best tie-downs for OSH? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 http://clk.atdmt.com/AVE/go/onm00200415ave/direct/01/ ________________________________________________________________________________
Date: Mar 16, 2004
From: "thomas a. sargent" <sarg314(at)earthlink.net>
Mickey: The same thing happened to me. Mine is QB and when they built that section they just didn't overlap the angle enough with the longeron. So, I drilled the hole properly centered in the longeron and it came out looking exactly like your picture on the inside. Given the dimensions of that angle that's rivetted in there, you don't have much choice. On the advice of Vans I cut a strip of 1/8" 6061 Aluminum (I cut it out of a piece of angle I had laying around) and made it long enough so that it fit over those last 2 bolt holes. I was careful to make it extend as far outboard as it could and then drilled it to the 2 existing holes. I had to do that on each side. So, I have these 2 extra piece of 1/8" AL in there forevermore. It serves as a sort of doubler and gives adequate edge distance (well, much better edge distance, anyway) and a sound place to tighten the bolt against. -- Tom Sargent, RV-6A canopy. Mickey Coggins wrote: > >Ouch. I goofed while drilling the holes for the forward >spar on the HS. I'm not sure what to do, and I would >appreciate any advice you can offer. I've got pictures >and details on my site, and I would be happy to hear > > > ________________________________________________________________________________
Date: Mar 17, 2004
From: "Frank van der Hulst (Staff WG)" <F.vanderHulst(at)ucol.ac.nz>
I'd hate to take money away from your Mississippi boys, but US$120 is *way* too steep for me. However, it does look like the kind of thing that *any* good ol' RV builder could put together on a Saturday afternoon with a few 12" nails, a few 3/16" bolts, and some bits of .063" angle aluminum. The only tricky thing would be how to attach the nails to the ends of the arms at the right angle... anyone got any ideas there? In fact, you could probably make them a bit smaller and lighter than the original... it looks like (apart from stability issues) you would only need *one* of the official Claw's to hold an RV down. Of course, the limiting factor is th strength of the soil that you nail these into! But maybe for RVs you could get away with 6" nails? Or maybe you could make it all out of Titanium? :-) Of course, you would have to buy your own hammer ;-) Frank > Here's the triple spike system someone mentioned: > > http://www.theclaw.com/products/claw.php Learn real skills for the real world - Apply online at http://www.ucol.ac.nz or call 0800 GO UCOL (0800 46 8265) or txt free 3388 for more information and make a good move to UCOL Universal College of Learning. Enrol with a public institute and be certain of your future ________________________________________________________________________________
Subject: Alternator Belts
Date: Mar 16, 2004
Went shopping for an alternator belt today and couldn't find a local parts shop that carried Gates. They all sold the same brand called Dayco Top Cog. My question has to do with belt quality. These belts have a ribbed back. When I questioned the fact that less material may make them less durable, the response was they were more durable since the ribs made them more flexible and they ran cooler. What is the skinny on belt quality/durability? Is this for real or just a way to sell cheap belts to a naive belt buyer, like me? Thanks ________________________________________________________________________________
Date: Mar 16, 2004
> >Scott Bilinski wrote: > <bilinski@kyocera-wireless.com> >> >>So what are the best tie-downs for OSH? >> >> >>Scott Bilinski >>Eng dept 305 >>Phone (858) 657-2536 >>Pager (858) 502-5190 >> > >Here's the triple spike system someone mentioned: > >http://www.theclaw.com/products/claw.php > >Just some Mississippi good ol' boys tryin' to make a livin'. > >Give 'em a call; we need the money down here. :-) > >Charlie >(no financial ties to them) --------------- Listers, here's a little story. Since I make a living making titanium Ti-downs for airplanes, I'm always interested in other types of aircraft Tie-downs. I first heard about "the claw" this past year while at the Arlington, WA fly-in. While wandering around, looking at all the cool planes, I met Bruce Bohannan and "The Flying Tiger". I'm sure most of you have heard about this record-breaking pilot and his HIGHLY modified RV-4. http://www.pilotjournal.com/content/2003/septoct/images/tiger/plane.jpg The Tiger was tied down with the wimpy, weak doggie tie-downs. Being the kidder I am, I began to tease Bruce about him holding his awesome plane down with such crummy tie-downs. Bruce explained to me that he has a really good tie-down kit called "the claw", but didn't have them with him because he didn't have space in his plane to carry them, and they were HEAVY (8 lbs). Of course, I had to show him my titanium Ti-downs. He checked to see if the Ti-down kit would fit in his little glovebox sized cargo compartment, and yep, they fit easily in there. I offered to give him a kit, but he declined because he didn't know if the owner of the Flying Tiger had an exclusive deal with the maker of "the claw", as they had given him the kit. We chatted for a while, and discovered that we both were planning to be at OshKosh in a coulple of weeks, and he'd talk to the Tiger's owner to see if he could use my Ti-downs. At OshKosh, I wandered around and finally found the Exxon display, Flying Tiger, Bruce, and the Tiger's owner (sorry, I can't remember his name at the moment). Yep, it'd be no problem if Bruce used my Ti-downs, so I gave him a kit, and they gave me 3 Flying Tiger T-shirts. A little later the same day, while wandering around the vendor displays, I came across the guy (Bill Alexander) selling "the claw"... At first, I just looked at them, with enough interest for him to hold up a kit for me to see closer, and he informed me that they "only weigh 8 lbs, complete". I was kinda biting my lip, trying to decide if I should tell him who I was. I was wearing a "Flying Tiger" T-shirt that Bruce had given me, and Bill pointed at the picture on my shirt and said "that plane uses "the claw"... I shoulda just kept my mouth shut, but I blurted out "not anymore", before I could stop myself. I kicked myself later for saying that. Bill wanted to know what I meant by "not anymore", so I told him Bruce was using my titanium Ti-downs now. I let Bill know that Bruce spoke highly of his "claw", but he just didn't have room to carry them. Bill told me that he had alot of people tell him as they walked by that they already had some great titanium Ti-downs they'd bought at OshKosh the year before. We chatted pleasantly for another 10-15 minutes before I wished him well with his business and moved on. I did see quite a few of his "claw" kits holding down planes there, so I know he did sell some. There are some other Tie-down kits available... Fly-ties is one...(6 lb. kit) http://www.flyties.com/airplanes.htm Screw its, is another...and pretty cheap...(weight unknown) http://www.mcp.com.au/screwits/ I personally think my titanium Ti-downs are the World's Best aircraft Tie-downs, but like I said in an earlier message, I'm biased. Keep on flying, and make sure you anchor your plane good, no matter what system you use. Sincerely, Randy Simpson Airtime Mfg. http://www.airtimemfg.com p.s. When I met Bruce Bohannan at Arlington, he happend to be chatting with my all-time hero...Bob "Hurricane" Hannah, multi time National motocross champion and past unlimited Reno air racer... I got to hang out with Bob, and while eating lunch, he told me a great story of his experience of almost losing his Piper Supercub in a sneak windstorm (due to it not being tied down) while hunting rockchucks on a mesa out in the boonies...he went totally nuts over my Ti-downs, and now has a kit in his plane at all times... ________________________________________________________________________________
Subject: some questions from a new guy
Date: Mar 17, 2004
From: "ed \240" <ed_88@hotmai... After about a year of lurking and considering I am getting real closing to ordering an rv-8a kit. Although before I take the plunge I was hoping for a little advice. 1) How do I find find builders in the seattle area? If I join eaa, will the web page tell me there to go to meet other builders? From reading the various web builde's logs out there, it looks like knowiing others is vital to building a top quality kit. 2) How long should I expect to spend building a quickbuild rv-8a? I have built various rc models, and consider myself OK with mechanical things. However I have never worked with sheet metal or riviting before. 3) Would you consider the emp kit a good way to see if I am cut out for home building? 4) I've never actually flown in an rv before. I assume it makes sense to go to the factory and get a demo flight? Is there anything else I should do while I am down there? Sorry for the long list of questions, but I am getting real close to placing an order :) --Eddie http://clk.atdmt.com/AVE/go/onm00200415ave/direct/01/ ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling(at)earthlink.net>
Date: Mar 17, 2004
Does anyone have horror stories about RV's blowing away in the wind? This all seems a bit excessive. Jeff Shemp Dowling ________________________________________________________________________________
Date: Mar 17, 2004
Subject: Re: Alternator Belts
Mike, Dayco is a good brand as far as I know. It makes sense that increasing the area may help get rid of the heat -- a little. Gates is sold by NAPA. That's what I used. Dan RV-7A (almost done) In a message dated 3/17/04 12:44:15 AM US Eastern Standard Time, hollandm(at)pacbell.net writes: > > > Went shopping for an alternator belt today and couldn't find a local parts > shop that carried Gates. They all sold the same brand called Dayco Top Cog. > My question has to do with belt quality. These belts have a ribbed back. > When I questioned the fact that less material may make them less durable, the > response was they were more durable since the ribs made them more flexible and > they ran cooler. > > What is the skinny on belt quality/durability? Is this for real or just a > way to sell cheap belts to a naive belt buyer, like me? > > Thanks > > ________________________________________________________________________________
Subject: Engine monitoring
Date: Mar 17, 2004
I just wanted to let you know that Stern Tech's engine monitor is now shipping! It is a graphical engine monitor which can be configured for any engine up to 8 cylinders. The user can change the display layout and even sensors calibration. Now you can have an engine monitor the way you want it. If you have any questions please feel free to call me or email me. Regards, Trampas Stern 1-877-820-6590 ________________________________________________________________________________
Date: Mar 17, 2004
Subject: Re: some questions from a new guy
Eddie, You came to the right place for answers. I bet you get offered about 10 rides in RV-8s. I expected to finish my RV-7A (slow build) in about 2 years. Its going to be almost 3. And I'm retired. The quick build, in my opinion, won't save you as much time as you may think. The sheet metal work goes pretty fast with the prepunched kits. The instrument panel, canopy, wiring, and firewall forward is what really slowed me down. Van's says, I think, about 1600 hours to build an 8. I have gone over 2200 on my 7A, but I'm slow. Everyone starts with the empennage. Yes, that will at least give you a pretty good idea of what you're up against. Tenacity is the real virtue that will get you to the end. I'm sure you'll get lots of opinions, this is just mine of course! Go for it, Dan RV-7A (almost done!) In a message dated 3/17/04 2:53:22 AM US Eastern Standard Time, ed_88(at)hotmail.com writes: > > > > After about a year of lurking and considering I am getting real closing > to ordering an rv-8a kit. Although before I take the plunge I was hoping for > > a little advice. > > 1) How do I find find builders in the seattle area? If I join eaa, will > the web page tell me there to go to meet other builders? From reading the > various web builde's logs out there, it looks like knowiing others is vital > to building a top quality kit. > > 2) How long should I expect to spend building a quickbuild rv-8a? I > have built various rc models, and consider myself OK with mechanical things. > > However I have never worked with sheet metal or riviting before. > > 3) Would you consider the emp kit a good way to see if I am cut out for > home building? > > 4) I've never actually flown in an rv before. I assume it makes sense > to go to the factory and get a demo flight? Is there anything else I should > do while I am down there? > > > Sorry for the long list of questions, but I am getting real close to > placing an order :) > --Eddie > > ________________________________________________________________________________
Date: Mar 17, 2004
Does anyone know where I can get a titanium hammer to save weight? In a message dated 3/16/04 10:48:17 PM US Eastern Standard Time, F.vanderHulst(at)ucol.ac.nz writes: > > In fact, you could probably make them a bit smaller and lighter than the > original... it looks like (apart from stability issues) you would only > need *one* of the official Claw's to hold an RV down. Of course, the > limiting factor is th strength of the soil that you nail these into! But > maybe for RVs you could get away with 6" nails? > > Or maybe you could make it all out of Titanium? :-) > > Of course, you would have to buy your own hammer ;-) > > Frank ________________________________________________________________________________
Date: Mar 17, 2004
I have been at one fly-in where a guy did NOT tie down his RV. A gust of wind came up and blew it into another RV and they traded some paint but no dented metal. This was ONE RV'er that I would not have wanted to be. He was just about KICKED OUT of the RV parking area for not securing his aircraft. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,442 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: "Jeff Dowling" <shempdowling(at)earthlink.net> Subject: Re: RV-List: OSH tie-downs Date: Wed, 17 Mar 2004 02:13:39 -0600 Does anyone have horror stories about RV's blowing away in the wind? This all seems a bit excessive. Jeff Shemp Dowling Get rid of annoying pop-up ads with the new MSN Toolbar FREE! http://clk.atdmt.com/AVE/go/onm00200414ave/direct/01/ ________________________________________________________________________________
Date: Mar 17, 2004
> > Does anyone know where I can get a titanium hammer to save weight? > Not titanium, but look at: http://www.mcmaster.com/ page 2680, plastic lightweight hammer. Alex Peterson Maple Grove, MN RV6-A N66AP 445 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Mar 17, 2004
Mike My personal opinion is to stay away from Dayco. As an auto mechanic, I've had numerous instances of installing Dayco's belts, only to have to replace them for free due to "belt squeek". I no longer will use any Dayco products. (Their radiator hoses are flimsy) Avoid Pep Boys, Discount Auto, etc. type "off" brands. The money saved is not worth the extra work of having to remove the cowl and prop to change out an alternator belt sooner than absolutely necessary. Ask your local independent auto parts store, if he can get Gates or Bando (used by most Japanese OEMs) brand of belts. Another good brand that is less expensive is called Pro One. I'm really impressed with the quality of this company's products. They cost less than Gates but are of good quality. Charlie Kuss > >Went shopping for an alternator belt today and couldn't find a local parts shop that carried Gates. They all sold the same brand called Dayco Top Cog. My question has to do with belt quality. These belts have a ribbed back. When I questioned the fact that less material may make them less durable, the response was they were more durable since the ribs made them more flexible and they ran cooler. > >What is the skinny on belt quality/durability? Is this for real or just a way to sell cheap belts to a naive belt buyer, like me? > >Thanks > > ________________________________________________________________________________
Date: Mar 17, 2004
> >We've decided to make our first pilgrimage to Oshkosh this summer and > >we're going to camp on the grounds. I've read the EAA's survival guide, > >but I'd some specific recommendations about what to bring. What sort of > >tent, sleeping bag, etc. Should I just go down to REI and have at it? > > I'd hate to purchase or pack anything unnecessary. > > Things to take to Oshkosh: 1 Cash 2 Credit Cards (take several so you have backups as you reach your credit limit) 3 More Cash 4 Your best walking shoes Everything will cost more than you ever thought. Don't let it slow you down, just be prepared. You'll have a great time. Grizz http://moneycentral.msn.com/tax/home.asp ________________________________________________________________________________
Date: Mar 17, 2004
Mike, I've been running the Dayco 'Top Cog' for nearly three years now with over 300 hours. Trouble free, so far. Visually, still looks fine. Bob ======================================== Hopperdhh(at)aol.com wrote: > >Mike, >Dayco is a good brand as far as I know. It makes sense that increasing the >area may help get rid of the heat -- a little. > >Gates is sold by NAPA. That's what I used. > >Dan RV-7A (almost done) > > >In a message dated 3/17/04 12:44:15 AM US Eastern Standard Time, >hollandm(at)pacbell.net writes: > > > >> >>Went shopping for an alternator belt today and couldn't find a local parts >>shop that carried Gates. They all sold the same brand called Dayco Top Cog. >>My question has to do with belt quality. These belts have a ribbed back. >>When I questioned the fact that less material may make them less durable, the >>response was they were more durable since the ribs made them more flexible and >>they ran cooler. >> >>What is the skinny on belt quality/durability? Is this for real or just a >>way to sell cheap belts to a naive belt buyer, like me? >> >>Thanks >> >> >> >> > > > > ________________________________________________________________________________
Date: Mar 17, 2004
Mike My 7A is only to the wing stage but I do have a lot of experience with belts. I design and install air conditioner compressor mounts for cars and trucks that were not equipped with air from the factory. We have used a lot of the Dayco TopCog belts and they really do have a longer life provided they are not used in an installation that requires an idler pulley running on the back of the belt. The negative flex angle coupled with the idler contact will disintegrate the belt very quickly. With this exception they do a great job. Carroll Jernigan RV-7A Wings ________________________________________________________________________________
Subject: Grip wires
Date: Mar 17, 2004
List, I'm at the point of running wires to my RC Allen grip and I'm not sure how to get the wires inside the stick. I've searched the archives but still have not formulated a plan of attack. Just where, and how, is the best place to enter the stick and still offer as much protection from chaffing as possible, yet allow flexibility? I've got both elevator and aileron trim plus PTT wiring as well. Steve Struyk St. Charles, MO RV-8, wiring ________________________________________________________________________________
Date: Mar 17, 2004
Hopperdhh(at)aol.com wrote: > > >Does anyone know where I can get a titanium hammer to save weight? > Argh.... Maybe it should be inflatable, too? :-) :-) :-) A hammer that weighs next to nothing..... is worth next to nothing, methinks. Think about it. Bob ________________________________________________________________________________
Subject: OT: Oshkosh bound...
Date: Mar 17, 2004
> > > >We've decided to make our first pilgrimage to Oshkosh this > summer and > > >we're going to camp on the grounds. I've read the EAA's survival > > >guide, but I'd some specific recommendations about what to bring. > > >What sort of tent, sleeping bag, etc. Should I just go > down to REI > > >and have at it? I'd hate to purchase or pack anything unnecessary. > > > > Things to take to Oshkosh: > > 1 Cash > 2 Credit Cards (take several so you have backups as you > reach your credit > limit) > 3 More Cash > 4 Your best walking shoes > > Everything will cost more than you ever thought. Don't let it > slow you down, > just be prepared. > > You'll have a great time. > > Grizz I'd add one more imporant thing, which is a hot button for me, and that is that they charge a minimum of 3 nights' camping. This feels like a gouge if one only wants to stay one night. I've decided to only go for the day (I'm only 1.5 hours away by RV) because of it. Alex Peterson Maple Grove, MN RV6-A N66AP 445 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: Re: Grip wires
Date: Mar 17, 2004
I drilled a hole near the pivot point to minimize motion. Be sure and use AWG 22, and the good stuff (tefzel) for chafe resistance. On Mar 17, 2004, at 6:46 AM, Steve Struyk wrote: > > List, > > I'm at the point of running wires to my RC Allen grip and I'm not sure > how to get the wires inside the stick. I've searched the archives but > still have not formulated a plan of attack. Just where, and how, is > the best place to enter the stick and still offer as much protection > from chaffing as possible, yet allow flexibility? I've got both > elevator and aileron trim plus PTT wiring as well. > > Steve Struyk > St. Charles, MO > RV-8, wiring > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Mar 17, 2004
What do you mean IF you join EAA? Where are you going to get the support that the EAA's Technical Counselor program offers? Where are you going to the expertise for Test Flying your new RV-8? Van has a factory pilot to give you some transition training in an RV-6 but the EAA has also has gotten a waiver so there are probably several RV-8 pilots that can give you some prior transition training before you try the same in your new RV. This is very important when going for that first flight. The local EAA Chapter also probably has a tool library for that special one-time use tooling. There will be interested EAA members that can lend a hand when it comes to inspecting and repositioning. In my EAA Chapter, we have several completed RV-8s and several on the way. Each helps each other even though they are many miles apart. The Chapter has had project reviews of these projects along the way. Second pair of eyeballs is extremely helpful. Another builder can help you over the tough spots and help you avoid mistakes. The Question is WHEN are you going to join the EAA? Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or sportpilot(at)eaa.org Always looking for articles for Sport Pilot ----- Original Message ----- From: "ed " <ed_88(at)hotmail.com> Subject: RV-List: some questions from a new guy > > > After about a year of lurking and considering I am getting real closing > to ordering an rv-8a kit. Although before I take the plunge I was hoping for > a little advice. > > 1) How do I find find builders in the seattle area? If I join eaa, will > the web page tell me there to go to meet other builders? From reading the > various web builde's logs out there, it looks like knowiing others is vital > to building a top quality kit. > > 2) How long should I expect to spend building a quickbuild rv-8a? I > have built various rc models, and consider myself OK with mechanical things. > However I have never worked with sheet metal or riviting before. > > 3) Would you consider the emp kit a good way to see if I am cut out for > home building? > > 4) I've never actually flown in an rv before. I assume it makes sense > to go to the factory and get a demo flight? Is there anything else I should > do while I am down there? > > > Sorry for the long list of questions, but I am getting real close to > placing an order :) > --Eddie > > http://clk.atdmt.com/AVE/go/onm00200415ave/direct/01/ > > ________________________________________________________________________________
Date: Mar 17, 2004
I would also include sunglasses and a hat... Of course if you have cash you can purchase them... Regards, Trampas Stern Stern Technologies 4321 Waterwheel Dr Raleigh NC 27606 919-832-8441 Ext. 12 (voice) 919-832-8441 (fax) www.sterntech.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Alex Peterson Subject: RE: RV-List: OT: Oshkosh bound... > > > >We've decided to make our first pilgrimage to Oshkosh this > summer and > > >we're going to camp on the grounds. I've read the EAA's survival > > >guide, but I'd some specific recommendations about what to bring. > > >What sort of tent, sleeping bag, etc. Should I just go > down to REI > > >and have at it? I'd hate to purchase or pack anything unnecessary. > > > > Things to take to Oshkosh: > > 1 Cash > 2 Credit Cards (take several so you have backups as you > reach your credit > limit) > 3 More Cash > 4 Your best walking shoes > > Everything will cost more than you ever thought. Don't let it > slow you down, > just be prepared. > > You'll have a great time. > > Grizz I'd add one more imporant thing, which is a hot button for me, and that is that they charge a minimum of 3 nights' camping. This feels like a gouge if one only wants to stay one night. I've decided to only go for the day (I'm only 1.5 hours away by RV) because of it. Alex Peterson Maple Grove, MN RV6-A N66AP 445 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Mar 17, 2004
> > > >Went shopping for an alternator belt today and couldn't find a local parts shop that carried Gates. They all sold the same brand called Dayco Top Cog. My question has to do with belt quality. These belts have a ribbed back. When I questioned the fact that less material may make them less durable, the response was they were more durable since the ribs made them more flexible and they ran cooler. > > > >What is the skinny on belt quality/durability? Is this for real or just a way to sell cheap belts to a naive belt buyer, like me? > > > >Thanks > > Mike, I've had a Dayco belt last less than 20 hours, I have since insisted on Gates and while they are a bit more expensive and harder to find, they are well worth the effort. Peace of Mind, etc. Have you tried searching on the internet for your particular Gate belt size? Ed Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC > > > ________________________________________________________________________________
Date: Mar 17, 2004
Mike, When I was much younger, playing around with Small Block Cheys and such, I found a good running high winder would roll the belts over in the pullies. When this belt came along, the news spread quickly that it did not roll over. Now when I look for belts, Dayco Top Cog (Outside Mass is what we called them) is the only thing I use. As V-belts go IMHO they are the best John D ----- Original Message ----- From: "Mike Holland" <hollandm(at)pacbell.net> Subject: RV-List: Alternator Belts > > Went shopping for an alternator belt today and couldn't find a local parts shop that carried Gates. They all sold the same brand called Dayco Top Cog. My question has to do with belt quality. These belts have a ribbed back. When I questioned the fact that less material may make them less durable, the response was they were more durable since the ribs made them more flexible and they ran cooler. > > What is the skinny on belt quality/durability? Is this for real or just a way to sell cheap belts to a naive belt buyer, like me? > > Thanks > > ________________________________________________________________________________
Date: Mar 17, 2004
> > 1) How do I find find builders in the seattle area? Ed: Try the RV Finder, http://www.rvproject.com/registry/rvfinder.jsp If you do a search for 25 miles around Seattle, WA, you'll get a list of 5 registered RV-8s and 63 other types of RVs, complete with owner's names and addresses. Tedd McHenry Surrey, BC ________________________________________________________________________________
Date: Mar 17, 2004
Lets see 3 lb. titanium hammer = 3 lb. 3 lb. steel hammer = 3 lb. What weighs more, a pound of feathers or a pound of lead? GZ Bob U. wrote: > > >Hopperdhh(at)aol.com wrote: > > > >> >> >>Does anyone know where I can get a titanium hammer to save weight? >> >> >> > >Argh.... >Maybe it should be inflatable, too? :-) :-) :-) > >A hammer that weighs next to nothing..... >is worth next to nothing, methinks. > >Think about it. > > >Bob > > > > ________________________________________________________________________________
Date: Mar 17, 2004
I worked on my slow build has many hours as possible, which worked out to ~30 hrs a week, and thats with a full time job, and I am married. I had one good helper for everything except paint. Neither of us have ever built a plane before but we are both good mechanically and he is better than me electrically and I better than him in the paint dept. 2 years to the month it flew painted and I did the painting which added months. It flew with out the gear leg fairings completed. My motivation for getting it done so fast was to go fly a rental plane. Here are my tips for getting it done quickly: 1- Get buy in from the wife on the amount of time it is going to take. 2- Get the wife to help if at all interested. 3- Have a helper either for the entire project or for specific parts, mechanical, electrical, paint etc. 4- A helper is a MUST for getting it done in a reasonable amount of time. 5- Knowing someone who has a arm with 2 elbows is also helpful. > >Eddie, > >You came to the right place for answers. I bet you get offered about 10 >rides in RV-8s. > >I expected to finish my RV-7A (slow build) in about 2 years. Its going to be >almost 3. And I'm retired. The quick build, in my opinion, won't save you >as much time as you may think. The sheet metal work goes pretty fast with the >prepunched kits. The instrument panel, canopy, wiring, and firewall forward >is what really slowed me down. Van's says, I think, about 1600 hours to build >an 8. I have gone over 2200 on my 7A, but I'm slow. > >Everyone starts with the empennage. Yes, that will at least give you a >pretty good idea of what you're up against. Tenacity is the real virtue >that will >get you to the end. > >I'm sure you'll get lots of opinions, this is just mine of course! > >Go for it, >Dan >RV-7A (almost done!) > > >In a message dated 3/17/04 2:53:22 AM US Eastern Standard Time, >ed_88(at)hotmail.com writes: > >> >> >> >> After about a year of lurking and considering I am getting real closing >> to ordering an rv-8a kit. Although before I take the plunge I was hoping for >> >> a little advice. >> >> 1) How do I find find builders in the seattle area? If I join eaa, will >> the web page tell me there to go to meet other builders? From reading the >> various web builde's logs out there, it looks like knowiing others is vital >> to building a top quality kit. >> >> 2) How long should I expect to spend building a quickbuild rv-8a? I >> have built various rc models, and consider myself OK with mechanical things. >> >> However I have never worked with sheet metal or riviting before. >> >> 3) Would you consider the emp kit a good way to see if I am cut out for >> home building? >> >> 4) I've never actually flown in an rv before. I assume it makes sense >> to go to the factory and get a demo flight? Is there anything else I should >> do while I am down there? >> >> >> Sorry for the long list of questions, but I am getting real close to >> placing an order :) >> --Eddie >> >> > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 17, 2004
The question is which weighs more a pound of feathers or a pound of gold? ________________________________________________________________________________
Date: Mar 17, 2004
Bummer on the problem. Had a few myself. My recommendation: option 1: Check with Van's. Get a recommended fix from them on your specific situation. option 2: Fix it as per the plans (replace metal). IMVHO, this is far too critical to do anything different. I personally wouldn't want to have the worry from that attachment detract from the enjoyment of flying. BTW - looks like you may need a little more shim under the angle in your pic. Good luck. Bryan Jones -8 www.LoneStarSquadron.com Houston, Texas >Ouch. I goofed while drilling the holes for the forward >spar on the HS. I'm not sure what to do, and I would >appreciate any advice you can offer. I've got pictures >and details on my site, and I would be happy to hear >any advice or tips or tricks. > > http://www.rv8.ch/article.php?story 04031620072395 > >Thanks, >Mickey > > Find a broadband plan that fits. Great local deals on high-speed Internet ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Date: Mar 17, 2004
Ed, Go fly the RV-8A at Van's and take your check book. Just finished mine RV-8A 888FP and WOW best aircraft I have ever flown. Sincerely, Noel Simmons Blue Sky Aviation, Inc. Phone & Fax: 406-538-6574 noel(at)blueskyaviation.net www.blueskyaviation.net <http://www.blueskyaviation.net> -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of ed Subject: RV-List: some questions from a new guy After about a year of lurking and considering I am getting real closing to ordering an rv-8a kit. Although before I take the plunge I was hoping for a little advice. 1) How do I find find builders in the seattle area? If I join eaa, will the web page tell me there to go to meet other builders? From reading the various web builde's logs out there, it looks like knowiing others is vital to building a top quality kit. 2) How long should I expect to spend building a quickbuild rv-8a? I have built various rc models, and consider myself OK with mechanical things. However I have never worked with sheet metal or riviting before. 3) Would you consider the emp kit a good way to see if I am cut out for home building? 4) I've never actually flown in an rv before. I assume it makes sense to go to the factory and get a demo flight? Is there anything else I should do while I am down there? Sorry for the long list of questions, but I am getting real close to placing an order :) --Eddie http://clk.atdmt.com/AVE/go/onm00200415ave/direct/01/ ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Date: Mar 17, 2004
The belts that NAPA carry are made by Gates ... at least the ones I looked at (and bought). James > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ed Anderson > Sent: Wednesday, March 17, 2004 9:08 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Alternator Belts > > > > > > > >Went shopping for an alternator belt today and couldn't find a local > parts shop that carried Gates. They all sold the same brand called Dayco > Top Cog. My question has to do with belt quality. These belts have a > ribbed back. When I questioned the fact that less material may make them > less durable, the response was they were more durable since the ribs made > them more flexible and they ran cooler. > > > > > >What is the skinny on belt quality/durability? Is this for > real or just > a way to sell cheap belts to a naive belt buyer, like me? > > > > > >Thanks > > > > > > Mike, I've had a Dayco belt last less than 20 hours, I have since insisted > on Gates and while they are a bit more expensive and harder to find, they > are well worth the effort. Peace of Mind, etc. Have you tried > searching on > the internet for your particular Gate belt size? > > Ed > > Ed Anderson > RV-6A N494BW Rotary Powered > Matthews, NC > > > > > > > > ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Mar 17, 2004
There are a bunch of guys in the Seattle area building RV's....if they dont introduce themselves you can probably get a list from Vans. Also go the the fly-ins close by this summer...Arlington,Scappoose and the homecoming come to mind Building time ALWAYS varies by the individual....some guys can do a quick build in a year ...but not too many Empennage is a perfect way to get a taste of building. Not too expensive, but a good sampling of the skills you will need to build. When in Portland go to a restarant called the Veritable Quandry....order the osso bucco (veal) :) mmmmmmmmm Evan ----- Original Message ----- From: "ed " <ed_88(at)hotmail.com> Subject: RV-List: some questions from a new guy > > > After about a year of lurking and considering I am getting real closing > to ordering an rv-8a kit. Although before I take the plunge I was hoping for > a little advice. > > 1) How do I find find builders in the seattle area? If I join eaa, will > the web page tell me there to go to meet other builders? From reading the > various web builde's logs out there, it looks like knowiing others is vital > to building a top quality kit. > > 2) How long should I expect to spend building a quickbuild rv-8a? I > have built various rc models, and consider myself OK with mechanical things. > However I have never worked with sheet metal or riviting before. > > 3) Would you consider the emp kit a good way to see if I am cut out for > home building? > > 4) I've never actually flown in an rv before. I assume it makes sense > to go to the factory and get a demo flight? Is there anything else I should > do while I am down there? > > > Sorry for the long list of questions, but I am getting real close to > placing an order :) > --Eddie > > http://clk.atdmt.com/AVE/go/onm00200415ave/direct/01/ > > ________________________________________________________________________________
Date: Mar 17, 2004
Nice pictures. Maintaining good edge distances on through-bolted angles is always difficult. I would recommend replacing the angle. Remove the HS from the tail, drill out the rivets on the HS spar and reinstall a new piece of angle. When you make the new angle, taper it to fit closely between the longerons and radius the ends so it fits with as much material (edge distance) as possible. It will take only a few hours and give years of satisfaction. Good luck, Dean RV-4 186 hours >From: Mickey Coggins <mick-matronics(at)rv8.ch> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: RV8 horizontal stabilizer mounting problem >Date: Tue, 16 Mar 2004 20:39:06 +0100 > > >Ouch. I goofed while drilling the holes for the forward >spar on the HS. I'm not sure what to do, and I would >appreciate any advice you can offer. I've got pictures >and details on my site, and I would be happy to hear >any advice or tips or tricks. > > http://www.rv8.ch/article.php?story 04031620072395 > >Thanks, >Mickey > > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > >
March 07, 2004 - March 17, 2004
RV-Archive.digest.vol-pa
