RV-Archive.digest.vol-pc
March 27, 2004 - April 01, 2004
For those flying with an Altrak:
Did you hook the module into the static system or did you just leave it open?
The manufacturer directions indicate it can be done either way and I'm
looking for what other people are doing.
Thanks!
-Mike Kraus
N223RV RV-4 Flying
N213RV RV-10 Empennage
Subject: | IO-360 Engine problem |
Hi Walt,
Just a quick thought....have you flown your plane during the "warmer"
months? I'm not bein sarcastic, the only reason ask this, is that nicely
warmed up and hot IO's (on warm days) can have a tendency to run rough at
low RPM's due to the fuel boiling before it reaches the injector. This
usually only happens with low fuel flow and goes away at higher RPM's and
Fuel flows becuase their is cooler fuel to the injectors and more air moving
through the cowling.
At first glance I wouldn't worry, but I'd make sure you have firesleeve on
all the fuel lines, especially the line from the servo to the spider (that
will help), and the line from the engine driven pump to the servo covered in
firesleeve also.
Just my 2 cents, but I notice this phenomenon (IO-360) also during the
warmer summer months.
Stein Bruch
RV6's, Minneapolis.
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of RVEIGHTA(at)aol.com
Subject: RV-List: IO-360 Engine problem
All, my IO-360 has begun to run strange at low rpm after it has warmed up. I
noticed this when taxiing into the FBO yesterday - the engine would run
smooth, then it would drop rpm then pick back up again. At any thing above
about
1200-1300 rpm the engine is fine.
Any thoughts about what could be the cause? Improper idle mixture
adjustment
maybe? The engine should show a slight rise in rpm when the mixture lever
is
brought back to idle cutoff, but doesn't, which is an indicator of idle
mixture problem (I think).
Walt Shipley RV-8A 81 hrs
Subject: | RV-6/6A canopy headroom and headsets |
I use these.
http://www.quiettechnologies.com/index_002.htm
Bridge thickness: 0"
Larry Bowen, RV-8 FWF
Larry(at)BowenAero.com
http://BowenAero.com
> From: thomas a. sargent [mailto:sarg314(at)earthlink.net]
> Sent: Saturday, March 27, 2004 12:09 PM
> Subject: RV-List: RV-6/6A canopy headroom and headsets
> I am finally at the point where I can raise and lower a (nearly)
> finished tip-up canopy AND can install the seat cushions just
> delivered
> to me from D.J. Lauritsen. (She does nice work, BTW.) I'm
> very normal
> size - about 5' 10" and was surprised at how little room there is
> between the top of my head and the canopy. Probably less than 2
> inches. I certainly wouldn't want to sit lower than this for
> visibility
> reasons. With D.J.'s booster cushion installed, there's less than an
> inch, but I like the visibility. (I remember that Van's tips for
> landing an RV advise pilots to sit as high in the saddle as
> possible.)
> This was all done with the seat all the way back, which helps a bit.
> I then looked at my old David Clark headset and realized it would
> definitely be rubbing against the canopy because the "bridge"
> piece that
> goes across the top of my head is more than an inch thick. The
> references in the archives to headroom seem to mostly be from
> people who
> haven't picked which plane to build yet.
> So for those of you who are flying, here's the question: Do you use
> headsets with very thin bridges? Which ones? Or do you all have
> scratches on your canopies above your head?
> On the plus side, a low canopy is probably one the reasons
> these things
> go so fast. There's lots of compromises in an airplane design.
> Tom Sargent, RV-6A, Canopy
> Matronics Forums.
vansairforce
Hi all...
I decided to weigh my -8A again after the upgrades I just did... When I
weighed it after I built it I had some temporary seats installed, and did
not have the wheel pants and gear leg fairing fairings installed.....here's
what I got:
Empty weight without wheel pants and fairings: 996 lbs
Empty weight with wheel pants and fairings sitting on the wings and cowl:
1005 lbs
After a year and a half and the upgrades:
Empty weight now with interior, all fairings, new panel, and heavy starter:
1029 lbs
Still pretty light I think!
I am going to be install new "H" pistons in the next couple weeks, along
with a light weight starter. I am going to weight everything and redo the
W&B accordingly and will post the results...
-Bill VonDane
EAA Tech Counselor
RV-8A ~ N8WV ~ Colorado Springs
www.vondane.com
www.creativair.com
www.epanelbuilder.com
From: | "Brian Kraut" <brian.kraut(at)engalt.com> |
Applying carb heat will richen the mixture a little. Sounds like you may be
a little lean on the idle mixture so a quick and easy way to verify that
would be to put on the carb heat and see if that improves things.
Brian Kraut
Engineering Alternatives, Inc.
www.engalt.com
about
adjustment
is
Injected engines don't have carb heat, they have an alternate air
supply.
Bruce
www.glasair.org
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Kraut
Subject: RE: RV-List: IO-360 Engine problem
may be
Brian Kraut
www.engalt.com
up. I
above
about
adjustment
lever
is
Good point. Well, it would have a a quick and easy way to check the mixture
if it had a carb!
Brian Kraut
www.engalt.com
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bruce Gray
supply.
Bruce
www.glasair.org
may be
Brian Kraut
www.engalt.com
up. I
above
about
adjustment
lever
is
From: | "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net> |
I hooked mine up to ships static.
In hind site, I would not.
I have had my static get water in it in heavy rain and clog the system.
Delivering erroneous results while IFR. Yuk!. Has happened to me twice
and neither time was any fun partial panel woth static blocked with a
drop of water.
I have since installed a quick pull device to vent ships static to the
cockpit. My fix on that is in the archives. Simple I have a small piece
of r/c fuel line with an r/c bulkhead fitting, 1/8 inch. Through the
panel. When I want an alternate static, pull it off and presto, venting
to cabin.
But I do not think there is any up side to connecting the Altrak to
ships static.
There is a down side to doing so as my experience dictates.
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of N223RV(at)aol.com
Subject: RV-List: Altrak Question
open?
Thanks!
-Mike Kraus
N223RV RV-4 Flying
Subject: | Re: Altrak Question |
I asked the folks at TruTrak about this and they said that the accuracy is
better with the static connected. As I recall the difference was plus or minus
20 feet. I could be off there.
Bob Trumpfheller
RV7A
http://users.aol.com/n67bt (baggage compartment update)
Subject: | Re: RV-6/6A canopy headroom and headsets |
Tom: I will give you my humble opinion on canopy clearance. Background
information on myself, I am 6'4" a Bubba size frame, tall in the waist
flying a RV-6, my first RV-6 was a tip up canopy, my solution was use the
back hinge position and do not use the seatback upper securing attachment,
let the back of the seat rest on the cross channel. By doing this it gives
you a slightly recline position and for me that give about 1" clearance
using a David Clark headset. I did not notice and rubbing of canopy, but in
turburelent air you must keep the shoulder Harness snug or the head could
hit canopy. On my present RV-6A with a sliding canopy I have about the
same clearance as the tip up but it seems the seat back is slightly forward,
not as comfortable as the tip up position. The seat cushion is the normal
1" temple foam, but the back rest has minimum thickness. with your height
it should be a piece of cake, but you might need to shop for a head set that
does not have such a thick headband.
Harvey Sigmon RV-6A N602RV
----- Original Message -----
From: "thomas a. sargent" <sarg314(at)earthlink.net>
> finished tip-up canopy AND can install the seat cushions just delivered
> to me from D.J. Lauritsen. (She does nice work, BTW.) I'm very normal
> inches. I certainly wouldn't want to sit lower than this for visibility
> landing an RV advise pilots to sit as high in the saddle as possible.)
> definitely be rubbing against the canopy because the "bridge" piece that
> references in the archives to headroom seem to mostly be from people who
> On the plus side, a low canopy is probably one the reasons these things
From: | "Evan and Megan Johnson" <evmeg(at)snowcrest.net> |
Subject: | Re: hidden pitot tube |
Ooops.....you are right. I just took a quick look and missed it because my
friend who pointed it out is an A&P. I took a second, longer look this
morning and it does indeed have a blade pitot. Sorry for the misinformation.
I still think it would be cool though :)
Evan
Subject: Re: RV-List: hidden pitot tube
> Are you sure the hole is for pitot? The Katana has a hole in the leading
> edge for stall indication. The Pitot is a blade under the wing.
The placement of the pitot tube in the flow field around the airplane should
not matter much. According to theory, any local increase in the velocity of
the air (due to the shape of the wing, for instance) will cause a
equivalent decrease in local static pressure so the total (static plus
dynamic) pressure will remain unchanged. If this is compared to an accurate
static pressure source, the difference is then dynamic pressure which is
then fed to an ASI or whatever to show an airspeed indication.
The reason for the long, skinny, forward-projecting pitot tubes on some
aircraft is to move the static vents on the pitot head clear of the flow
field and get an accurate static pressure reading. If the static pressure is
sensed elsewhere, then no need for this. Look at an F-86 sometime, the pitot
tube is buried inside the engine intake duct and works fine (some models
anyway).
Jim Oke
RV-3, RV-6A
Wpg, MB
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Subject: RV-List: hidden pitot tube
> A question for those of you in the know....I was looking at a Diamond
aircraft this morning and a friend pointed out that the pitot tube is
completly hidden in the leading edge of the wing...just a 1/4 hole!? Can
this be done on an RV wing? It would be cool to have no pitot sticking out
in the wind, but I dont know if the front of the leading edge is undisturbed
air. It certainly is as it passes over the leading edge. Instinct tells me
that the air pressure would be changed right at the leading edge and the
airspeed readings would be inaccurate....but Diamond does it. Hmmmmmm any
thoughts?
> Thanks ...Evan
Mike: On my RV-6A I mounted my Altrak controller in the aft tailcone close
to the servo and left it open to the static air, works fine but caution when
the cabin heat is pulled on as the controller senses the change. If you
plan on using the A/C for IFR they recommended to hock to static system.
open?
> Thanks!
> -Mike Kraus
> N223RV RV-4 Flying
From: | "John Danielson" <Jdaniel343(at)bresnan.net> |
I am 5'6". I also have DJ seats with the booster and the child cushion. At
first I only used the booster, but was not making the best landings. I then
tried the child booster cushion and my landings greatly improved.
I still have about 1" clearance between my head and the canopy. I have
bumped my head 2 or 3 times in very turbulent air. Really not too much of a
problem in the seatbelt and harnesses are sinched down.
Van is correct in assesment of sitting a tall as possible.
John Danielson
From: | "Cory Emberson" <bootless(at)earthlink.net> |
Subject: | Santa Maria CA Flying (April 30-May 2) |
Hello everyone!
With Matt Dralle's blessing (thank you, Matt!), I'm pleased to post this announcement
for a terrific aviation fly-in weekend. SMXgig (in Santa Maria, CA) has
become the year's largest face-to-face get-together of electronically networked
aviators. We hope you'll plan to attend because we expect this year's gig to
be the best ever.
People come from all over the country (and sometimes overseas) to attend, and most of the sessions qualify for FAA Wings cards. The dates are 4/30-5/2/04 (Friday-Sunday) - it's a lot of fun, and a great chance for pilots from all over to mingle and share aviation stories, ideas, etc. The announcement below contains most of the crucial information, and you can get the rest from the website (www.smxgig.org). If you have any questions at all, just let me know, and thanks!
~~Cory Emberson
KHWD
>>> NOTICE TO AIRMEN! <<<
Announcing the Sixteenth Annual SMXgig
to be held on April 30 - May 2, 2004
at the Radisson on the Santa Maria (CA) Airport (aka SMX)
www.smxgig.org
SMXgig will be April 30 - May 2, 2004, at the Santa Maria Radisson. This year,
our featured speaker after Friday night's dinner will be Rod Machado!
"MACH 2 WITH MACHADO" is the byline Rod Machado has earned for his rapid fire delivery
at his lively safety seminars and keynote speeches. His programs are information-packed,
energetic, and humorous. He has spoken in all fifty of the
United States and in Europe sharing his fresh approach to aviation education.
If you can make it, please do. It's going to be pretty special. More information and the announcement/ registration info is available at www.smxgig.org You may also contact me by email at: cory(at)smxgig.org.
All technical sessions will be held in the Enterprise Ballroom at the SMX Radisson.
Each session will last about an hour. We schedule four tech sessions on Saturday
morning, and four on Sunday morning. Most of the speakers are set (I'm
still firming up a couple of slots - I'm working on a session about Experimentals):
MIKE BUSCH - The Art and Science of Troubleshooting
Your A frequently, that person is you. That's particularly true of problems that
occur only in-flight and/or are intermittent. This session offers methodology
for troubleshooting aimed at aircraft owners who aren't A&Ps.
ED WILLIAMS - GPS - How It Works, and How to Work It
Ed is a nuclear physicist working at Lawrence Livermore Labs. Ed does a
remarkable job of making physics phun!
BRENT BLUE, M.D. - Pilot Medicals: How to Avoid Problems with the FAA
Brent is an AME Advocate, who specializes in helping the tough cases renew their
medicals. He's a former member of EAA's medical advisory committee.
DOUG RITTER - Equipping Yourself To Survive - Personal Survival Gear for Pilots
Doug is a survival evangelist, personally driven to help pilots live through whatever comes next. www.equipped.org
PAUL MILLNER - The Future of Avgas
Paul works with ChevronTexaco, and is right in the middle of the industry developments
regarding our fuel of choice.
MARY DUFFY & UWE LEMKE - Flying in Europe
Mary and Uwe are a Scot and a German who live in the San Francisco Bay Area, but
return "home" often.
As always, each qualifying session will get you a WINGS Safety Session card.
Our Saturday evening event should be a delicious one! At 5:45 p.m., the BFUB (Big Fat Ugly Bus) will arrive at the Santa Maria Radisson to bring us to the Far Western Tavern for dinner in beautiful Guadalupe (www.farwesterntavern.com).
DOLLARS AND CENTS
Just as in previous years, there will be one flat all-encompassing "gig" fee that
covers all events that involve significant out-of-pocket costs for the organizers.
The fee is $160 per person, and will cover:
- Friday afternoon welcome party
- Friday evening dinner banquet
- Saturday and Sunday tech sessions
- Saturday afternoon lunch
- Saturday evening dinner at the Far Western Tavern in Guadalupe
- Meeting rooms and coffee service at the Santa Maria Radisson
- Transportation to (and from) the Far Western Tavern
Lodging at the SMX Radisson will cost $89.00/night for either a single or double
room, which is far below the regular hotel room rate. Be sure you check in as
a SMXgig attendee and get the special rate. We have our definitive preference
listed with the hotel for rampside rooms - early registration can only help,
but of course, the rampside rooms are subject to availability depending on how
many existing guests are in those rooms.
You do not need to register with the hotel - just give me your preferences, and
I will take care of the reservations.
Important: This year, our final rooming lists are due to the hotel on April 11,
2004 (the even of Sun 'n Fun), which will guarantee space and the group rate.
The hotel will accept additional room reservations after that, on a space- and
rate-available basis. They will try their best to accommodate us after that
date, but the hotel is already sold out for the weekend.
The website (www.smxgig.org) has detailed information about the schedule, meals, hotel accommodations, and online registration. If you'd like your own announcement/registration emailed to you, or have any other questions, just let me know. (cory(at)smxgig.org or bootless(at)earthlink.net ).
Thanks, and see you there!
best, Cory Emberson
Ok, so if I understand correctly, a hidden pitot with the front flush with
the leading edge and a static source on the side of the fuselage should work
just fine. (All theory of course) So the next question would be....if I
figure out how to heat the pitot with an element like the one in my standard
heated pitot.....is this a problem in a confined space? We are no longer in
200 mph wind. How are these things thermally regulated?
should
of
accurate
is
pitot
> anyway).
> Jim Oke
> RV-3, RV-6A
> Wpg, MB
> To:
undisturbed
> thoughts?
> > Thanks ...Evan
Hi Larry,
If asked, Would you be inclined to describe them a bit more and offer a
performance aand product evaluation opinion?
I am asking. {[;-)!
Jim in Kelowna
Subject: RE: RV-List: RV-6/6A canopy headroom and headsets
> I use these.
> > delivered
> > very normal
> > visibility
> > possible.)
> > piece that
> > people who
> > these things
> > Matronics Forums.
To answer the original poster, yes, at 5' 9" it is a problem, and I do have the
aforementioned scratches all over the inside of the canopy, over my head and
the passenger's head. It's not an area of the plexi you look through very often,
maybe during a roll if you want to get woozy, but it is noticeable when looking
in from outside on the ground. I have Lightspeeds, which have a very thick
padded headband.
I'm very interested to hear what Larry says about product performance with the
in-ear headset he uses, in particular boom mike stability issues. I have had
the Lightspeeds come off my noggin when pulling G in a turn and leaning my head
back to look for the guy I'm dogfighting. Has happened several times in fact,
So I am curious how well an ear spud can stabilize a boom mic in the aircraft
environment.
-Bill B
I got mine last year at OSH, $325 I think? Stereo. They perform well
and are very comfortable. As if I'm wearing nothing at all....on my
head, that is. I have the generic foam plugs. You can get custom ear
molds too.
On the downside, they are a little tricky to get positioned exactly
right-- the placement in the ear determines where the mic boom ends up.
Sometimes the mic is just right, other times I have to try again. They
can also be pulled out of adjustment if I turn my head far and the cord
catches on your collar, for example. But these are minor annoyances,
IMO. I like 'em. They are the only headset I've used since OSH last
year (but I still have my David Clark's too).
Larry Bowen
> From: Jim Jewell [mailto:jjewell(at)telus.net]
> Sent: Saturday, March 27, 2004 6:55 PM
> Subject: Re: RV-List: RV-6/6A canopy headroom and headsets
> Hi Larry,
> and offer a performance aand product evaluation opinion? I am
> asking. {[;-)!
> Jim in Kelowna
> From: "Larry Bowen" <Larry(at)bowenaero.com>
> To:
> > I use these.
> > > delivered to me from D.J. Lauritsen. (She does nice
> work, BTW.) I'm
> > > very normal
> > > visibility
> less than an
> > > possible.)
> helps a bit.
> "bridge" piece
> > > that
> from people
> > > who haven't picked which plane to build yet.
> Do you use
> > > things go so fast. There's lots of compromises in an airplane
> > > design.
The in-your-ear headsets may have issues in a dog-fight type scenario.
Lots of extreme head movement and big G's will like take it out of
'alignment'. But for more sedate flying and hours of cross-country,
they are perfect.
Larry Bowen
> From: SportAV8R(at)aol.com [mailto:SportAV8R(at)aol.com]
> Sent: Saturday, March 27, 2004 7:54 PM
> and I do have the aforementioned scratches all over the
> inside of the canopy, over my head and the passenger's head.
> noticeable when looking in from outside on the ground. I
> have Lightspeeds, which have a very thick padded headband.
> performance with the in-ear headset he uses, in particular
> boom mike stability issues. I have had the Lightspeeds come
> several times in fact, So I am curious how well an ear spud
> can stabilize a boom mic in the aircraft environment.
> -Bill B
> < child cushion. At first I only used the booster, but was not
> making the best landings. I then tried the child booster
> cushion and my landings greatly improved. I still have about
> 1" clearance between my head and the canopy. I have bumped my
> of a problem in the seatbelt and harnesses are sinched down.
> John Danielson>>
> Matronics Forums.
From: | "Deb and Bernard Weiss" <weissmntc(at)earthlink.net> |
I am interested in options for landing lights that will fit inside the new tips
that Van's is selling with the RV-7. Also to be included in the lens will be
the strobes.
DebBernie Weiss
Why Wait? Move to EarthLink.
I've had my seat belt and shoulder harness as tight as possible and hit
bumps in my slider 6a and wondered why the canopy did not break. A word
to the wise; remove the button from the top of your ball cap, it will
save your scull.
Z
>John Danielson
Mike,
We left it open - works great.
Chuck & Dave Rowbotham
RV-8A
>From: N223RV(at)aol.com
>To: rv-list(at)matronics.com, vansairforce(at)yahoogroups.com
>Date: Sat, 27 Mar 2004 14:01:51 EST
>open?
>Thanks!
>-Mike Kraus
>N223RV RV-4 Flying
http://toolbar.msn.com/go/onm00200415ave/direct/01/
Subject: | Dropped bucking bar--Need ding fix |
Nothing on Miracle Fill in the archives. Details please!
Allen Fulmer
DON'T USE BONDO ! Unless you want to see a crack at its edges after aroound
100 hours...use Miracle Fill....mine hasn't come loose or shown edge lifting
in 9 years...Bondo has !!
I'm not convinced that it is quite this simple. I suspect there are
at least two potential issues:
1. There should be some energy lost in the boundary layer, so the
pitot pressure may not be quite as high as it should be.
2. The stagnation point (the spot on the leading edge where the
velocity comes to zero) moves as the angle of attch changes. So I
think any hole location would only work properly at one angle of
attack.
If it was so simple to use use a hole in the wing leading edge,
manufacturers wouldn't be spending money on pitot tubes.
It would be an interesting science experiment to have a normal pitot
tube, and a hole in the leading edge, each hooked up to an ASI. Then
we could compare the readings from the two different pitot locations.
I would be very hesitant to use a wing leading edge hole as my only
pitot source until we can find definitive proof whether it would work
properly or not.
I would love to see a good picture of the F-86 pitot source that Jim
Oke mentioned. Is it a somewhat conventional pitot tube inside the
engine inlet? If so it would sidestep the boundary layer and
stagnation point issues I mentioned.
Kevin Horton
>anyway).
>Jim Oke
>RV-3, RV-6A
>Wpg, MB
>To:
>thoughts?
>> Thanks ...Evan
From: | Bobby Hester <bhester(at)hopkinsville.net> |
>save your scull.
>Z
I'm surprised that no one has metioned Peltor. They have a very thin
head band and seem to be a very good quality headset.
Surfing the Web from Hopkinsville, KY
Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/
RV7A Slowbuild wings-QB Fuse :-)
From: | "jayeandscott" <jayeandscott(at)telus.net> |
engine inlet?
I wonder if this was one of the tubes used to provide the engine's FCU with an
ambient pressure signal?
Scott in Vancouver
>anyway).
>Jim Oke
>RV-3, RV-6A
>Wpg, MB
>To:
>thoughts?
>> Thanks ...Evan
Subject: | Re: RV-List Skidding |
Tape a several strings about 6 inches long each across the top of the engine
cowling - they will show local airflow, which will probably be
affected/modified by the spiraling prop wash. We had a single yaw string on
the nose of the F-84F which was quite informative - of course we had no prop
to "modify" the straight back flow of air. It was good for showing yaw.
On a tractor prop plane, starting with several strings may reveal that 1
particular one would be best - might even try taping a second row on the
front area of the canopy - further aft from prop - but airflow will be
"splitting"/going around the canopy so don't know how true the reading will
be. See how the strings compare with the slip indicator. You might find a
combination that gives you confidence that you are flying straight.
David
Subject: RV-List: RV-List Skidding
> Hey Guys, Is it possible to have a plane flying in a skid ( sideways )
> with the turn coordinator ball in the center????
> I have already checked that the instrument was installed level to the
> aircraft. Any ideas??? Fairings out of line????
> Weasel Graber
Subject: | Info on RV8 at LOE |
There was an RV8 at Las Cruses that is owned by Marvin Brott. Anyone know him or
have an email address for him. I'd like to talk to him about his plane.
Darwin N. Barrie
Chandler AZ
Subject: | Re: IO-360 Engine problem |
what was the OAT that day?
> up. I
> above about
> adjustment
> lever is
> _-
> _-
> _-
> _-
Jason Sneed
Commercial Lending Officer
First National Bank and Trust
Subject: | Rv-List Skidding |
Hey Thanx to all for the info. on skidding I seem to have finally decided
that it is flying true!
Weasel
From: | Jerry Springer <jsflyrv(at)earthlink.net> |
>>save your scull.
>>Z
At 6'3" using Peltors I have no problem with head room. Yes I am close
to the canopy but not a problem IMO.
Make adjustments with your seat cushions. As someone else mentioned take
the seatback adjustment off and let the
seat back rest against the rail. IMO Peltors are the best non noise
canceling headsets
Jerry
OAT was around 75 F. Stein may be right, I'll try using the boost pump to see
if that improves engine run at low rpm.
Walt Shipley
P.S. Thanks guys for all the input, maybe I can get this puppy runnin' right
Subject: | capacitive fuel senders |
Hi,
I have capacitive fuel senders for my RV7, indicators from Pacific, need converter
from capacitive to voltage.
Has anyone got similar indicators? where did you get the converters?
thanks
Marcel
RV7 #71481
Subject: | RV7 and RV8 IO360 (200 HP) Air Inlet Problem |
Listners (and Vans),
I had an interesting experience last week with my RV7. I have the IO306 200
HP engine installed with the induction air intake mounted on the inlet ramp
of the baffle. I parked the plane outside for three nights and it was exposed
to approx 3 inches of rainfall during that time. When I went to start the engine,
it rotated about two blades and then stopped. I got out and tried to pull
the prop through but it would not pull through. Hum--whats going on here?
I removed the cowling and the bottom plugs and was shocked to have water
come out of the two rear cylinders. I removed the plug on the bottom of the sump,
lifted the tail and drained about a quart if water out of the induction sump.
While I had the plugs out, I engaged the starter to force any remaining water
out of the cylinders. Luckily, the starter was not damaged and upon reinstalling
the plugs, the engine started and ran fine.
I had never thought about water entering the induction system before but
you can bet I will have a cover over the air filter as well as inlet plugs on
my plane before I park it outside again. Hope this saves someone some grief in
the future. Vans, you might want to put a short blurb in the RV ator about this.
On the bright side, I found that I have very tight sealing fuel filler caps
as I had no water in the tanks.
John Henley, N57LD, 210 Hrs
From: | "Gould, Richard AE1 NAVTESTWINGPAC 561000E" <richard.j.gould(at)navy.mil> |
I would be surprised (and honestly, very curious) to see an aircraft that had a
Pitot static probe mounted flush in the LE of the wing. I wonder how it would
overcome the airflow separation at the LE. I would find it hard to believe that
a P-S system could accurately measure true impact pressure without any type
of correction.
Every small SEL GA airplane that I have seen does not have compound Pitot-Static
probe, so the equivalent static pressure would not be sensed. Every airplane
that I have worked on from Cessna's to 4-Engine Turboprops to Super Hornets has
a pitot probe that juts into the airstream. If a flush mount worked WELL, I
think it would have caught on by now.
Are you sure that it is a pitot tube for the INSTRUMENT system? How far down the
intake is it? If it were anywhere past the front edge, the air data that it
is sensing would completely off. Think about it. It would be reading an airspeed
indication while sitting on the ramp at idle! Yes turbine engines often have
pitot tubes in them, but they're not for the P-S system. They are for the engine
fuel control. Even the Engine-Driven Compressor (EDC) for cabin pressurization
on the L-188/P-3 has its own Pitot-Static probes inside its own intake.
Rick Gould
RV-4 Camarillo, CA
FLY NAVY!
__I__
--O--O--( )--O--O--
Subject: | Re: RV7 and RV8 IO360 (200 HP) Air Inlet Problem |
200 HP engine installed with the induction air intake mounted on the inlet ramp
sump, lifted the tail and drained about a quart if water out of the induction
sump. While I had the plugs out, I engaged the starter to force any remaining
water out of the cylinders. Luckily, the starter was not damaged and upon reinstalling
in the future. Vans, you might want to put a short blurb in the RV ator about
this.
caps as I had no water in the tanks.
Do you have a hole in the bottom of your filter box to drain water and
fuel that can accumulate?
Jerry
From: | "Alex Peterson" <alexpeterson(at)earthlink.net> |
One more thought on the ball being off center - if the plane is not
flying true through the air, there will be some amount of aerodynamic
load acting on the side of the fuselage. This load is not countered by
an equal load on the other side of the fuselage; hence, there will be a
lateral acceleration (this causes the ball to move toward that side).
This acceleration can be "countered" by the aircraft turning in a flat
roll attitude (as a car around a corner), or by lowering the wing on the
side of the air load to prevent the turn. Either way, the ball will
move towards the air load.
Alex Peterson
Maple Grove, MN
RV6-A N66AP 447 hours Terrible flying weather!!
http://www.home.earthlink.net/~alexpeterson/
Subject: | Re: Landing lights |
Deb and Bernie,
Check out www.creativair.com I am very happy with my installation. Also
www.killacycle.com
Ben Cunningham
RV7 Finish Kit
From: "Deb and Bernard Weiss" <weissmntc(at)earthlink.net>
Subject: RV-List: Landing lights
tips that Van's is selling with the RV-7. Also to be included in the lens
will be the strobes.
> DebBernie Weiss
> possible and hit
> break. A word
> save your scull.
I can't imagine flying without a 5 point harness, if only for very
reason stated above. I suspect that anyone who has flown in a 6/7/9
(can't speak for the seat belt geometry in the others) with a 5 point in
turbulence will be a believer. I wouldn't even contemplate not having
the 5th point, as it is so much more comfortable, not to mention safer.
I suspect that it must be the equivalent of getting several inches more
headroom.
Alex Peterson
Maple Grove, MN
> boost pump to see
> Walt Shipley
The fuel pressure in the injector lines is extremely low at idle, well
below the engine driven fuel pump pressure. If the boost pump fixes the
problem, the vapor problem is in the suction side of things (pre -
engine fuel pump), not in the injector lines.
Sorry if I missed it, what injection system do you have?
Alex Peterson
Maple Grove, MN
It's fairly common practice to drill a small "drain hole" somewhere near the
low point in the induction, to those who haven't yet, you should...for this
reason and a couple others.
Stein Bruch
RV6's, Minneapolis
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of john henley
Subject: RV-List: RV7 and RV8 IO360 (200 HP) Air Inlet Problem
IO306 200 HP engine installed with the induction air intake mounted on the
inlet ramp of the baffle. I parked the plane outside for three nights and it
was exposed to approx 3 inches of rainfall during that time. When I went to
start the engine, it rotated about two blades and then stopped. I got out
and tried to pull the prop through but it would not pull through. Hum--whats
going on here?
water come out of the two rear cylinders. I removed the plug on the bottom
of the sump, lifted the tail and drained about a quart if water out of the
induction sump. While I had the plugs out, I engaged the starter to force
any remaining water out of the cylinders. Luckily, the starter was not
damaged and upon reinstalling the plugs, the engine started and ran fine.
but you can bet I will have a cover over the air filter as well as inlet
plugs on my plane before I park it outside again. Hope this saves someone
some grief in the future. Vans, you might want to put a short blurb in the
RV ator about this.
filler caps as I had no water in the tanks.
Subject: | Used engine vibration mounts |
A local Mooney owner is installing a new engine and he received 4 new
vibration mounts with his STC engine kit so he has his current ones for sale and
said
to make him an offer if interested. The *old* ones have 670 hours on them
since new in 97.
There's no obvious damage or marks on them and he says there wasn't any
noticeable sag and that he'd probably still use them if he didn't end up getting
new ones. Is there a compression limit I can measure when I torque a bolt &
nut on them to test there usefullness?
How darn long do these things usually last anyway?
thanks,
lucky
Date: Sat, 27 Mar 2004 10:40:59 EST
Subject: used engine vibration mounts
-------------------------------1080402059
Local Mooney owner installing a new engine and he received 4 new vibration
mounts with his STC engine kit so he has his current ones for sale and said to
make him an offer if interested. The *old* ones have 670 hours on them since
new in 97.
thanks,
lucky
Local Mooney owner installing a new engine and he received 4 new vibration mounts
with his STC engine kit so he has his current ones for sale and said to make
him an offer if interested. The *old* oneshave 670 hours on them since new in
97.
There's no obvious damage or marks on them andhe says there wasn't any noticeable
sag and that he'd probablystill use them if he didn't end up getting new ones.
Is there acompression limit I can measurewhen Itorque a bolt nuton them to
thanks,
lucky
-------------------------------1080402059--
Stein,
What are the other reasons?
n a message dated 3/28/2004 10:44:36 AM Eastern Standard Time,
stein(at)steinair.com writes:
Stein Bruch
RV6's, Minneapolis
That's great for the updraft installations, but on the horizontal induction
with the snorkel the induction manifold in the sump is pretty much the low
point... Particularly for taildraggers. Covers are a prudent choice.
Greg Young - Houston (DWH)
RV-6 N6GY ...project Phoenix
Navion N5221K - just an XXL RV-6A
> somewhere near the low point in the induction, to those who
> haven't yet, you should...for this reason and a couple others.
> Cheers,
> Stein Bruch
> RV6's, Minneapolis
> I have the IO306 200 HP engine installed with the induction
> air intake mounted on the inlet ramp of the baffle. I parked
> the plane outside for three nights and it was exposed to
> stopped. I got out and tried to pull the prop through but it
> shocked to have water come out of the two rear cylinders. I
> removed the plug on the bottom of the sump, lifted the tail
> was not damaged and upon reinstalling the plugs, the engine
> system before but you can bet I will have a cover over the
> air filter as well as inlet plugs on my plane before I park
> it outside again. Hope this saves someone some grief in the
> ator about this.
> sealing fuel filler caps as I had no water in the tanks.
Well....I specifically left this one out because I'll bet it raises more
questins than it answers, but here goes.
The main reason for the drain hole is for fuel. Fuel from overpriming,
flooding, etc..
This hole or something similar to it is very common on most certified
aircraft. Mooney went as far as putting an actual drain hose from the
induction system out of the cowl, but I don't think that's needed.
That's the main one I know of, draining water is a bonus.
Stein.
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of RV8ter(at)aol.com
Subject: Re: RV-List: RV7 and RV8 IO360 (200 HP) Air Inlet Problem
Stein,
Stein Bruch
RV6's, Minneapolis
We had a very similar incident at Oshkosh one year where the induction box
filled with water because the wasn't a low point drain.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or sportpilot(at)eaa.org
Always looking for articles for Sport Pilot
Subject: RE: RV-List: RV7 and RV8 IO360 (200 HP) Air Inlet Problem
the
this
> Cheers,
> Stein Bruch
> RV6's, Minneapolis
> To: RV-List(at)matronics.com
it
to
Hum--whats
> going on here?
before
> RV ator about this.
For the IO-360 with horizontal induction, Van's FWF kit drawings do call out
the use of a sniffle valve -- with a drain tube running out the back of the
cowl.
)_( Dan
RV-7 N714D
http://www.rvproject.com
> raises more questins than it answers, but here goes.
> overpriming, flooding, etc.. This hole or something similar
> to it is very common on most certified aircraft. Mooney went
> as far as putting an actual drain hose from the induction
> Cheers,
> Stein.
To add a little to what Stein said, two holes are needed in the bottom
of the FAB, one outside the filter and one just inside, at the lowest
point. The small hole inside the filter is to let fuel out, the
outboard one to drain water which gets in.
A drain hose is a good idea on trike planes, otherwise the prime fuel
slops all over the gear and wheel fairings. Prosealing some sort of
fitting on the outside of the FAB onto which a hose can be clamped has
worked for me.
Alex Peterson
Maple Grove, MN
From: | "Curt Reimer" <cgreimer(at)mb.sympatico.ca> |
Subject: | Re: Used engine vibration mounts |
If you can get a good deal on them, I'd use them. They are usually
recommended to be changed at engine overhaul time, so every 2000 hours.
Yours have 2/3 of their life left on them, and they are relatively fresh
time-wise so why not? (If they had 670 hours but were 20 years old, I'd
probably replace them due to age.)
Curt
Subject: RV-List: Used engine vibration mounts
> since new in 97.
getting
bolt &
> thanks,
> lucky
> From: RV8ter(at)aol.com
> To: vansairforce(at)yahoogroups.com
said to
since
> new in 97.
getting
bolt &
> thanks,
> lucky
to make him an offer if interested. The *old* oneshave 670 hours on them
since new in 97.
noticeable sag and that he'd probablystill use them if he didn't end up
getting new ones. Is there acompression limit I can measurewhen Itorque a
bolt nuton them to test there usefullness?
> thanks,
> lucky
I fly with Peltor's. Thin headband, great ANR and comfortable.
Z
>>save your scull.
>>Z
On our first trip to the Bahamas the rains came down horizontal for a
number of hours. The next day we were going island hopping and when I
started my engine, it started but shook like a wet dog as it was firing
on 1 or 2 cylinders. The problem was that I had forgot to put the drain
holes in the FAB (carburated 6A) and the air box had filled with water.
I used an ice pick from the local establishment to poke two holes in the
FAB to drain the water. IMHO, the holes are and important addition for
draining both water fuel.
this.
>Jerry
Subject: | fuel tank rotation bracket |
List,
After a tremendously frustrating afternoon of getting proseal everywhere, I have
a couple of questions:
1) I made the rotation bracket, but it seems the center of the hole for the elbow
fitting did not align (extend) far enough. I checked my dims and they all
looked to be okay, so I had to drill it out to 5/8. Is that normal? It seems
that should be okay.
2) It states to use -4 rivets. Is that just to alleviate the use of c-sunk rivets?
Since edge distance is limited, it seems it would be better to c-sink the
bracket and use -3 rivets.
3) Assuming one were to completely mangle a piece of the 1x1 angle in his frustration
(wiht proseal everywhere), any reason why home depot replacement angle
wouldn't work? Is there something special about the angle vans' sends?
Thanks in advance,
Scott
7A Wings
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
>>>save your scull.
>>>Z
> canceling headsets
> Jerry
I can personally endorse the Lightspeed QFR Xcountry headset. After four
years of hitting the headband of my old 15K's on the canopy of the RV-6,
I switched to the QFR's because I am a Lightspeed fan and the QFR's have
a very narrow headband. I hardly ever contact the canopy any more.
The fact that the Xcountrys work very nicely, are very lightweight, and
cost less than $300 is an added bonus.
Sam Buchanan
I have the Bendix RSA injection system.
Walt
To those that inquired and offered the drain hole advice; there is no place for
a drain hole on the IO360 horizontal induction with the snorkel induction. The
induction sump itself is the low point. When I built my 6 a few years ago, I
drilled a weeper hole in the Fab airbox for that purpose but this system is different.
The easiest thing to do is to keep the water out. Alternatively, there
is a plug in the bottom of the induction sump that I will probably attach a
hose fitting to, along with a small valve that so that I have the option to drain
it if I should forget to cover it up and a shower comes along some day.
John Henley
> Walt
If the problem is fuel boiling in the injector (or anything post servo)
lines, I believe that there is an improvement available. It seems like
I heard that there is some stronger spring that can be put into the
distribution block in (some) Bendix systems. This functions to increase
the pressures, thereby increasing the boiling temp. I would guess the
idle mixture would have to be adjusted to compensate.
Others more knowledgeable than I need to comment.
Alex Peterson
Maple Grove, MN
I am new, and this may be a basic question. I am trying to see what
the performance benefits (or disadvantages) may be with a three bladed
prop, vs. a two bladed constant speed prop. Does anyone have any
numbers. I am looking at an RV-7A. Takeoff perfomance and climb
performance are not big numbers for me. I plan on doing a bit of aerobatics
though, and a good bit of X-C flying. In airplanes I have flown with 3
bladed props, they seemed a much better (quieter and smoother) ride, but
did not seem to make much of a difference in performance. Also, what
will this mean in terms of cost (both initial and annual)? Thanks!
Is this the F-16 Brian Walsh. If it is, when are you going to return to
Colorado and chase around the sky with the General again???
Randy Lervold has a good site and did a lot of prop testing. goto
http://www.rv-8.com and find his propellor section.
Gary Zilik
Guess it depends on what type of IO-360 you're talkin' bout.
On my IO-360-A1B6, you can see the horizontal induction sump is machined
with the sniffle valve hole right in there:
http://rvproject.com/images/2004/20040303_sniffle_valve_hole.jpg
http://rvproject.com/images/2004/20040303_sniffle_valve_installed.jpg
http://rvproject.com/images/2004/20040303_sniffle_valve_drain_tube2.jpg
http://rvproject.com/images/2004/20040303_drain_tube_side_profile.jpg
Hope this helps,
)_( Dan
RV-7 N714D
Subject: RV-List: Re: RV7 and RV8 IO360 (200 HP) Air Inlet Problem
place for a drain hole on the IO360 horizontal induction with the snorkel
induction. The induction sump itself is the low point. When I built my 6 a
few years ago, I drilled a weeper hole in the Fab airbox for that purpose
but this system is different. The easiest thing to do is to keep the water
out. Alternatively, there is a plug in the bottom of the induction sump that
I will probably attach a hose fitting to, along with a small valve that so
that I have the option to drain it if I should forget to cover it up and a
> John Henley
From: | "Frank van der Hulst (Staff WG)" <F.vanderHulst(at)ucol.ac.nz> |
Check out Ken Weir's web site at
http://www.rst-engr.com/rst/articles/KP89SEP.pdf for DIY capacitance
senders.
Subject: RV-List: capacitive fuel senders
Hi,
converter from capacitive to voltage.
thanks
Marcel
RV7 #71481
Learn real skills for the real world - Apply online
at http://www.ucol.ac.nz or call 0800 GO UCOL
(0800 46 8265) or txt free 3388 for more information
and make a good move to UCOL Universal College of
Learning.
Enrol with a public institute and be certain of your
future
Hello Brian, I don't have my 8 in the air yet, but I can safely say that a three blade prop will be quieter and some what smoother, but it will be slower than a two blade. Check out Randy Lervolds web site he did a great testing job with the older Hartzell and the new whirlwind props,www.RV-8.com,
Good Luck,
Kirk RV-8 81925
> From: Brian Walsh <fly1v1(at)yahoo.com>
> Date: 2004/03/28 Sun PM 03:20:55 EST
> Subject: RV-List: RV-7 Props
Subject: | Canopy room and headsets. |
I use these.
Larry Bowen, RV-8 FWF Larry@BowenAero.com http://BowenAero.com
Larry,
I followed the link and could find no reference on their list to price. It seems
they are only passive and have no ANR function. I would be very interested
in these if they are either relatively cheap or I can try them out to see how
they compare with conventional sets.
At 60+ and with some slight hearing loss I really appreciate the performance of
the better ANR sets and unless these can match their performance I would be unwilling
to spend much on them.
Can you tell us what you paid and how you think they compare with other specific
headsets.
Rob
Rob W M Shipley
N919RV (res) Fuselage .....still!
Subject: | hidden pitot tube - F-86 Intake Pitot Tube |
Check out the following link for a picture of the F-86 Intake
Click here: Google Image Result for
www.aircraftresourcecenter.com/AWA1/101-200/walk146_SAAF_Sabres/part2/images_Jan_Teipel/8_
Ed Flow
C-140 Flying
RV-8 Preview Plans
Subject: | Flush mounted pitot |
A quick Google search of "F-86 pitot" located a fun article on the history of
the P-86 through F-86. Note that the original mount inside the duct was
inaccurate due to the effect of engine flow.
All F-86As were initially delivered with the pitot head located inside the
air intake duct. It was found in practice that false airspeed readings could be
obtained due to the increased airflow within the intake duct, so North
American decided to move the pitot head to the tip of a short boom that extended
from
the leading edge of the starboard wingtip. All F-86As were later retrofitted
with the wingtip boom when went through IRAN (Inspect and Repair as
Necessary).
FWIW and SYA (since you asked!)...
Now this is early in my journey, and I don't have a lot of experience with
this stuff- only airplane I've every owned, built, etc., and have never played
Kevin Horton on TV or anywhere else................my 150 hp RV-6A has a really
nice Craig Catto 3-blade (it says "66"x66""on it). My test pilot says it's a
helluva prop. Without gear fairings or pants, and after multiple gps check
runs (what else do ya do for 40 hours?!) I can safely report that I'm seeing
175+ mph indicated at 2-3000' with 2700-2750 rpm, 40-60 deg. OAT. After
multiple climb tests I'm getting at best 1200 fpm solo, which is fine for me and
still blows me away, and I'm subjectively VERY happy with the fan. Makes it a
little tougher to pull the lower cowl (needs a longer slot for the nose gear leg)
Craig doesn't sell stock or pay commisions, but I'd recommend giving him a
call & hope ya don't need it real soon.......................and no, ya caint
have mine!
From The PossumWorks in TN
Mark
From: | "Eustace Bowhay" <ebowhay(at)jetstream.net> |
Hi John:
I really don't want to cause you any concern but what happened to you is
what we call hydraulicing. It is usually caused by oil draining down past
the rings on the lower cylinders on radial engines. If a cylinder has enough
liquid in it (in your case water) to prevent it from reaching top dead
center on a compression stroke and the engine is forced to turn further
because the liquid can not be compressed something has to give. Usually it
is the cylinder head partially separated from the barrel or a bent
connecting rod. If it is a bent rod it usually goes undetected until there
is failure and this can happen with very little or no warning.
To prevent this from happening on the radial engines we turned the engines
through by hand enough blades to check for hydaulicing, if in the process
any resistance was encountered we turned the engine backwards to clear any
oil. Some of the big engine starters were equipped with a clutch in the
starters so the engine could not be forced beyond a certain pressure.
At the risk of getting this post to long I will relate an experience that
happened to me some years back while flying a DeHavilland Beaver on
floats.This Beaver was equipped with the standard P & W R985 -450 HP 9 Cyl
Radial engine.
I was moving a couple of boats from one lake to another, had finished the
move and was taking off empty out of this rather small lake when the cowling
gave a couple of unusual shakes, got my attention but then ran on as ever.
During the next take-off in front of home base just as I lifted out of the
water there was a load bang and the prop stopped rigid in front of me. They
came out with a boat and towed me back to the dock.
A link rod (connecting rod) had failed and totally destroyed the engine
internally About a hundred hours previously the master cylinder had been
changed by a crew working late, they got the cylinder off and then quit for
the night covering the engine with a tarp. During the night someone moved
the propeller and unlocked the rings on another cylinder and put a slight
bend in one of the link rods. The engineer didn't think any damage was done
and said nothing about it.
Had the failure occurred under different circumstances I probably wouldn't
be writing this tonight.
Eustace Bowhay
going on here?
before but you can bet I will have a cover over the air filter as well as
inlet plugs on my plane before I park it outside again. Hope this saves
someone some grief in the future. Vans, you might want to put a short blurb
I was advised during construction (by a friend) to drill a small drain hole
in the bottom of the air filter tube just before the fuel injection throttle
body.
James Cimino
RV-8 SN 80039
100+ Hours
570-842-4057
http://www.geocities.com/jcimino.geo/
> Hi John:
enough
engines
> Radial engine.
cowling
They
for
done
> Eustace Bowhay
> From: "john henley" <henley(at)seii.net>
> To:
it
to
Hum--whats
> going on here?
have
blurb
Subject: | Re: hidden pitot tube - F-86 Intake Pitot Tube |
Yes, that looks like it.
Check the top of the duct just below the 1 in the date on the photo. The
picture is rather dark but it sure looks like a pitot tube there.
Jim Oke
Wpg., MB
Subject: RV-List: hidden pitot tube - F-86 Intake Pitot Tube
_Jan_Teipel/8_
> Ed Flow
> C-140 Flying
> RV-8 Preview Plans
From: | "thomas a. sargent" <sarg314(at)earthlink.net> |
Subject: | scratching the canopy |
Maybe everybody on the list already knows this, but some of the new
folks might not. I found a way to scratch my canopy while I was sanding
the edges.
When you get to the shaping of the edge of the canopy (rounding it off),
or any time you use coarse sand paper on the edge, be very careful how
you remove the dust that accumulates. I made a lot of fairly deep
scratches along the edge by wiping off the dust with my finger. It
looks like, and mostly is, just plexiglass dust, but apparently there is
some small amount of coarse grit that has popped off the sand paper
mixed in with it. If you press your finger firmly against the plexi and
wipe it along the edge, a few grains of abrasive will get caught between
your finger and the plexi resulting in deep scratches roughly parallel
to the edge. Use a brush. I figured it out too late.
I am now paying for my sins by polishing these scratches out. Some are
so deep that I have to start with fine sand paper (600 - 1000) and then
use the Novus coarse scratch remover followed by the fine scratch
remover. It works but it's a lot of labor. If anybody knows a way to
mechanize this process, please do tell.
Tom Sargent, RV-6A
From: | "Jim and Bev Cone" <jimnbev(at)olypen.com> |
Subject: | Re: Dropped bucking bar--Need ding fix |
I have never had any problems using Bondo. I used it any place I needed to fill
on three different planes and have not had the problems that another lister
did. Mixed well and feathered out by sanding should work fine. Auto body shops
swear by the stuff when repairing cars and if there was a consistent problem
with the paint after a time, they would know about it and stop using it.
Jim Cone
3-Peat Offender
But, why do we think this pitot tube is connected to the airspeed
system? It could be connected to the engine's fuel control unit.
I pulled out some books off my book shelf and looked at pictures of
Canadian built Sabres. The Sabre 2, 4, 5 and 6 models all had a
pitot tube mounted on a boom extending ahead of the right wing tip.
I couldn't find any good pictures of the Sabre 1 or 3 models, or of
North American built F-86s. See:
<http://www.aircraftresourcecenter.com/AWA1/101-200/walk146_SAAF_Sabres/images%20Dave%20Bekker/sabre57.jpg>
Kevin Horton
>Jim Oke
>Wpg., MB
>From: <Vinnfizz(at)aol.com>
>To:
>_Jan_Teipel/8_
>> Ed Flow
>> C-140 Flying
>> RV-8 Preview Plans
> needed to fill on three different planes and have not had the
> problems that another lister did. Mixed well and feathered out by
> sanding should work fine. Auto body shops swear by the stuff when
> repairing cars and if there was a consistent problem with the paint
> Jim Cone 3-Peat Offender
Dittos, Jim. Many times I have heard warnings on this list about the
dire consequences of using Bondo on our planes for minor ding repair but
this hasn't been supported by my experience. My RV-6 has over five years
on its paint job and there is absolutely no evidence of problems with
areas where I used Bondo and spot putty to correct small boo boos.
It is, however, important that correct technique be used regardless of
which filler is applied. I wonder if problems some have found are due to
improperly applied product.
Sam Buchanan (RV-6, 560 hrs)
http://thervjournal.com
Subject: | used MT prop for sale |
Hi All
I have for sale a 3-blade MT prop, MTV-12-B-183. This is the hydraulic
constant-speed version, 72" dia. Works with McCauley or Woodward governors.
It has 127.6 hours tach time. It is in near perfect condition, with no chips
or dings on the leading edges (an advantage of taildraggers :o)). The
spinner is painted Ferrari red.
I removed this prop from my RV-8 to replace it with an Aerocomposites
2-blade. Early testing indicates the AC is 4-5 kts faster. Climb is similar
for both. The MT is smoother.
Asking $6500 plus shipping.
John Huft
rv8tor(at)lazy8.net
From: | "Ted Hultzapple" <thultzap(at)rochester.rr.com> |
Subject: | Adjustable Rudder Pedals |
I 've changed my mind about the ground adjustable rudder pedals in my RV8A
Quickbuild. It looks like all of the attach points are in the fuselage for
the adjustable pedals. Does any one know if the rails for the ground
adjustable pedals will interfere with the in flight adjustable ones? Better,
yet, does anyone have in flight pedals that they would part with?
Ted
Subject: | accident rate in experimentals |
>I have absolutely no idea as to what semantics and data are being used
>here. But no matter how you slice it, this is a very interesting piece
>of data. I have to believe, based on my personal experience with RV's,
>that we are flying a generally safer plane that other homebuilts. Does
>anyone have some data on this?
>I realize this gets fairly complicated analyzing this stuff. I know you
>can dice any which way to say anything. But I would like to be able to
>say to friends and family with confidence 2 things:
>1. Experimentals are safer than other commercially available aircraft in
>General Aviation
I could not speak about ALL experimentals in general, but I know that MY
airplane is a tougher, more responsive machine, built with care, by the guy
who's butt is IN it when it's airborne. Can't get better quality control
than that. The experimental world is typically driven by motivated,
sincerely passionate builders/pilots who derive a significant portion of
life satisfaction from their airplanes. I then postulate that the average
experimental homebuilder/pilot is a more attentive, cautious and diligent
pilot. He knows every nuance of his airplane, every noise, squeek, rumble
and rattle. I can tell immediately if something isn't right with my RV. As
a former C-172/Katana renter, I had no idea from one airplane to the next,
just what was really going on with it.
>2. My particular plane is safer than other experimentals.
A properly built RV is, IMHO, the safest kit aircraft out there. Load
distribution is excellent, fastener density is good, no reliance upon
#$*& plastic for structural integrity....
>Can I?
Hell yeah. We're pilots. We are expected to be opinionated. ;)
Brian Denk
RV8 N94BD
RV10 '51
Van's repeat offender program member.
http://toolbar.msn.com/go/onm00200414ave/direct/01/
Fuel boiling in the injector lines is a possibility. I have this problem
after landing and about half way taxing to the hanger it starts this
miss/RPM fluxuation. Its very annoying and I have done everything I can
think of and nothing has fixed it. What helped the most was changing the
injector Nozzles to the smallest size possible. The AFP injection came with
.028 nozzles. I installed .022 and this helped the most. Just make sure
your fuel flow is the same as before changing the nozzles. What this change
does is increase the pressure in the injector lines thus raising the
boiling point. BUT, I am now adjusting each cylinder so they all peak at
the same fuel flow, by doing this I had to install larger nozzles in some
cylinders which is making the problem worse again.
>about
>Any thoughts about what could be the cause? Improper idle mixture adjustment
>maybe? The engine should show a slight rise in rpm when the mixture lever is
Scott Bilinski
Eng dept 305
Phone (858) 657-2536
Pager (858) 502-5190
Might want to check compression. It is very possible to bend a rod this way.
>going on here?
>RV ator about this.
Scott Bilinski
Eng dept 305
In a message dated 3/29/04 10:23:56 AM US Eastern Standard Time,
bilinski@kyocera-wireless.com writes:
> bilinski@kyocera-wireless.com>
You would have to check compression the automobile way, which could be
dangerous! It won't show on a leakdown test.
Dan H
RV-7A (almost done)
Subject: | Re: accident rate in experimentals |
Michael:
I gathered some safety data on RVs a few years ago. It won't answer all your
questions, but I think it will help you quantify the risk of an RV vis-a-vis
general aviation.
http://www.vansairforce.org/articles/pilotage/pil_rv_safety.shtml
Tedd McHenry
Surrey, BC
Subject: | Re: used MT prop for sale |
In a message dated 03/29/2004 5:39:38 AM Pacific Standard Time,
rv8tor(at)lazy8.net writes:
Hi All
Can you provide the full number?
It should be MTV-12-B/183-?.
The last number is the specific blade design number.
Van's Aircraft advertises the MTV-12-B/183-59 propeller for the Lycoming 360
engine. That may be the full number if you purchased it from Van's Aircraft.
One of my customers has the MTV-12-B/183-59d propeller. The "d" indicates a
specific modification to the -59 blade design.
Jim Ayers
Less Drag Products, Inc.
In a message dated 03/29/2004 7:07:12 AM Pacific Standard Time,
(Stuff Cut) I have this problem
Fuel Injector throttle bodies have internal fuel seals. When the seals fail,
raw fuel is dumped from the throttle body into the air intake manifold. (No
external leaks unless you have an intake manifold drain.)
A symptom of this can be as you described above. A rough running engine
(overly rich mixture from the additional fuel entering at the throttle body) at
low power settings.
Jim Ayers
Interesting, woould leaning make a difference?
>at
>low power settings.
>Jim Ayers
Scott Bilinski
Eng dept 305
I found a really good way to cut the canopy that is much easier than using the
cutting disk that Van's provides. It allows cutting with one pass at a fairly
high speed with little binding of the cutter. It cuts the Plexiglas like a hot
knife through butter. I used a die grinder with a 1/8 inch collet and mounted
one of the little one inch fiber cutting disks made for the Dremmel tool.
Harbor Freight sells a very small die grinder kit that has several accessories
including a 1/8 inch collet for $14.99. The item number is 47050-OVGA and is
available online at Harborfreight.com.
Jim Cone
3-Peat Offender
The Bendix injector on a Cherokee Arrow IO-360 engine leaked in the internal
seals in the throttle body. The internal fuel leak added extra fuel into the
air intake system.
I believe that in flight, leaning the mixture would over lean the fuel
injector fuel flow to compensate for the extra fuel in the intake system. Leaning
the engine in flight wasn't a problem.
However, taxiing on the ground at sea level with full rich mixture, the
engine would run rich enough that it would quit. (I think the Oakland California
Airport is near sea level.)
On the Cherokee Arrow at idle, the extra fuel would leak out of the throttle
body and into the airbox. It would then pour out of the airbox drain hole
into the bottom of the cowl. And out the bottom of the cowl onto the ground.
And that's how we found out why the engine quit as it was exiting the runway
after landing at Oakland Airport.
Jim Ayers
Subject: | IO-360 Engine problem |
Hmmm... Interesting. My understanding is that the RSA fuel servo is a
pressure regulating device. It controls the amount of fuel being spewed
from the end of the constant flow injector nozzles by adjusting the
pressure in the fuel lines. The pressure is varied by the amount of air
flow through the servo body that is sensed by it. It's possible that
there is a leak in the fuel servo diaphragms, although this would result
in a rich mixture across the board. The easiest way to check for this is
to perform the coke bottle test. Place the disconnected end of each
nozzle line in a empty coke bottle. Start the electric fuel pump with
the mixture in idle cut off. Any fuel coming from the lines? If so, your
servo needs overhaul.
Bruce
www.glasair.org
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Bilinski
Subject: Re: RV-List: IO-360 Engine problem
<bilinski@kyocera-wireless.com>
fail,
(No
engine
body)
>at
>low power settings.
>Jim Ayers
Scott Bilinski
Eng dept 305
From: | "Jeff Dowling" <shempdowling(at)earthlink.net> |
I have the same situation and the same problem.
Jeff Dowling
RV-6A, N915JD
58 hours
Chicago/Louisville
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
> > Walt
> Alex Peterson
> Maple Grove, MN
Dont think this test would apply to AFP because the fuel flow never shuts
off 100%. To kill the engine they have a bypass valve which stops the flow
to the engine by returning the fuel back to a tank.
>Bruce
>www.glasair.org
>fail,
>(No
>engine
>body)
>>at
>>low power settings.
>>Jim Ayers
>Scott Bilinski
>Eng dept 305
Scott Bilinski
Eng dept 305
Subject: | Re: scratching the canopy |
Tom
Isn't that way spray-lat was invented, you brush the latex stuff on the
plexi, then work on it, it will keep the abbrasives away unless you
really push on it.
> the edges.
> Tom Sargent, RV-6A
> Some are
> 1000) and then
> a way to
> Tom Sargent, RV-6A
Tom, use a product called Scratch-Off. It has four compounds, and a
couple thingys to put on the electric drill. Only way to go. Aircraft
Spruce sells them. The other hand rub one they have is hopeless.
Alex Peterson
Maple Grove, MN
Subject: | Dynon EMI noise problem is fixed |
I've been waiting for Dynon's approval for almost a week to send this
message...we (Dynon, Mike Stewart, and myself) had done some noise filter
testing and I was keeping it under wraps until Doug Medema from Dynon gave
me the go-ahead to spill my guts. I can't speak for Mike (hopefully he'll
chime in), but here's my perspective...
Dynon has come out with "the fix." http://www.rvproject.com/dongle.html
It's an inline noise filter that plugs into the back of the EFIS, and your
wiring harness plugs into the dongle. It couldn't get any simpler than
that...and it couldn't be any easier to install. Dynon sent it to me last
weekend, and I tried it right away. It works great -- the noise issues I
was experiencing are gone when the dongle is in place.
The photos show the test dongle...Doug mentioned the production version will
be encased. I would direct your inquiries to Dynon for specifics.
I just wanted to share the good news that the Dynon EMI noise problem
appears to be ancient history! (NOTE: I am not affiliated with Dynon in any
way other than being a satisfied customer.)
I continue to be incredibly impressed by the customer support coming from
companies, like Dynon, Advanced Control Systems, and B&C. I feel lucky that
the homebuilt avionics/electronics industry is in a position to enable small
companies like this to survive and still manage to treat the customer like a
king.
)_( Dan
RV-7 N714D
Presuming you are talking about leaning during ground operations, yes,
it would probably make it worse. The fuel flow would be less; hence,
more residence time for the fuel to get hot in the lines.
Alex Peterson
Maple Grove, MN
> never shuts off 100%. To kill the engine they have a bypass
> valve which stops the flow to the engine by returning the
Not true. The AFP instructions are very clear about this: the engine
should kill if the mixture is pulled all the way back. The minimal fuel
that goes through the system, at idle throttle setting, when the engine
is not running, would probably not even run a lawn mower.
The purge valve's function is to 1) prevent post shutdown fuel from
percolating into the engine, and 2) allow one to pump cool fuel through
the servo and other plumbing before a hot start. It is a convenient way
to shut down the engine, also.
Some of these things we talk about on this list can be quite important,
and we need to avoid speculating. Someone might believe it without
verification and bad things could happen.
Alex Peterson
Maple Grove, MN
According to the archives, we went through this the first week of March.
Here are some selected quotes from my Airflow Performance Installation &
Service Manual:
MANUAL MIXTURE CONTROL, section 3-18 (page 20, revision B)
....When "ICO" is against the plastic stop, the fuel flow is shut off to the
engine. There is approximately 1.0 to 3.0 PPH leakage in this position....
Purge Valve Assembly, Background, Section 3-40. (page 30, revision B)
...Engines, which use the high pressure diaphragm fuel pump, experience
another problem, which influences the ease of restarting the engine. By
their design the diaphragm fuel pump acts like an accumulator when the
engine is shut down. This keeps the fuel pressure on the fuel controller,
and leakage in the idle cut off circuit of the fuel controller will allow
the fuel to bleed off into the engine. THIS CAN CAUSE RUN ON IN IDLE CUT
OFF AND FLOODING OF THE ENGINE INITIALLY AFTER SHUT DOWN. (Emphasis added)
OPERATING INSTRUCTIONS FOR USING THE PURGE VALVE, section 5.5 (page 44 & 45,
Revision C)
5.5. The following instructions are recommended procedures for operating
engines with engine driven fuel pumps ...
ENGINE SHUTDOWN
* Bring engine to idle speed
* Leave mixture control "FULL RICH"
* Put purge valve control in to "OFF" position
Terry
RV-8A #80729 wiring
Seattle
Alex Peterson
Maple Grove, MN
Alex Peterson
> week of March. Here are some selected quotes from my Airflow
> Performance Installation & Service Manual:
> shut off to the engine. There is approximately 1.0 to 3.0
> revision B) ...Engines, which use the high pressure diaphragm
> fuel pump, experience another problem, which influences the
> ease of restarting the engine. By their design the diaphragm
> fuel pump acts like an accumulator when the engine is shut
> controller will allow the fuel to bleed off into the engine.
> THIS CAN CAUSE RUN ON IN IDLE CUT OFF AND FLOODING OF THE
> (page 44 & 45, Revision C)
> for operating engines with engine driven fuel pumps ...
> ENGINE SHUTDOWN
> Terry
Terry, I stand corrected, at least for the exact wording of the AFP
manual. However, it is impossible to get an engine to idle with only
0.5 gph (3pph). So, any engine that continues to run with the mixture
in idle cut off needs adjustment.
Alex Peterson
Maple Grove, MN
Subject: | Optional Side Step question |
I just spent the better part of this week installing the optional steps for my
7A and I'm impressed at how sturdy these things turned out. I'm also glad I took
the time to do it. I ran in to a small problem though... I had to grind a small
amount of the weld on one of the steps so the rivet would sit flush.
Will this weaken the weld and cause the step to crack at the weld where I did the
grinding? I can send a pic if anyone cares to see it.
Karie Daniel
RV-7A QB in progress
Sammamish, WA.
Subject: | Manual Elevator Trim |
Can anyone using Van's manual elevator trim cable please confirm the following:
When the trim tab knob is screwed IN (clockwise) the nose of the plane will go
UP, when the knob is screwed counter-clockwise.... the nose of the plane will
go DOWN.
I had the Fuel Selector Plate (F-983A) engraved as per Van's Tech Rep (knob screwed
IN/clockwise, nose down.... counter-clockwise, nose goes up) and I think
this is backwards!
Maybe I'm losing my mind....
Jack
Subject: | Re: Manual Elevator Trim |
go DOWN.
this is backwards!
>Thanks,
>Jack
Nope you had it engraved right... in -down out-up
Jerry
> following:
> plane will go UP, when the knob is screwed counter-clockwise.... the
> nose of the plane will go DOWN.
Nope. Clockwise (in) is nose down. Works the same direction as the
control stick.
Sam Buchanan
From: | Hal / Carol Kempthorne <kempthornes(at)earthlink.net> |
Subject: | Re: Optional Side Step question |
>for my 7A and I'm impressed at how sturdy these things turned out. I'm
>also glad I took the time to do it. I ran in to a small problem though...
>I had to grind a small amount of the weld on one of the steps so the rivet
>would sit flush.
>did the grinding? I can send a pic if anyone cares to see it.
Yes. After about 1000 hours cracks will appear and you can grin while
repairing them. If you haven't built several other RV's by then.
Move on towards the test phase!
K. H. (Hal) Kempthorne
RV6-a N7HK - Three trips to OSH now.
PRB (El Paso de Robles, CA)
Karie, a weld is only as strong as the thickness of the metal adjacent
to the weld. As an illustration (well a poor one is better than none!)
let's say that you had 100% penetration .... the weld puddle went all
the way to the lower surface.... and the thickness of the weld was twice
the thickness of the initial material. the weld will only be as strong
as the initial material ..... and if you ground off the excess weld
material .... it would still be as strong. Proper dressing of the
ground weld is important as stress cracks can occur along the 'grinding
marks'. Best of luck!
Linn
small amount of the weld on one of the steps so the rivet would sit flush.
>Thanks,
>Karie Daniel
>Sammamish, WA.
I just installed my manual elev trim cable in my RV-6. When turn knob CW it
goes IN and extends TAB UP which applies force to move ELEVATOR DOWN, which
LOWERS NOSE.
I was waiting to get a picture to send before making this announcement, but
here it is: I and some other folks like the "Cessna Trim Wheel"
ergonomics - roll wheel fwd, nose goes down. I used the std Van's trim
cable, secured it to front of seat/floor pan F-639? that slopes up/fwd and
hangs over spar & F-604. The knob is about on the centerline of the
fuselage, for access by pilot and passenger. The cable then runs (out in
the open) left along spar/F-604 and curves aft along pilot side of fuselage,
aft beside seat back into "tunnel" through slot cut in tunnel cover and
along side elevator push tube through the std hole for the cable, and on, as
per plans.
- This orients the Van's knob to work just like the Cessna "wheel" -
roll it fwd for nose down.
I have Autocad .dwg drawings of the two brackets and their location on
F-639.
David Carter
----- Original Message -----
Subject: RV-List: Manual Elevator Trim
following:
will go UP, when the knob is screwed counter-clockwise.... the nose of the
plane will go DOWN.
(knob screwed IN/clockwise, nose down.... counter-clockwise, nose goes up)
and I think this is backwards!
> Thanks,
> Jack
From: | "Ross Schlotthauer" <rv7maker(at)hotmail.com> |
Dan,
Any word if they will be sending these out to all their customers?
>From: "Dan Checkoway" <dan(at)rvproject.com>
>To:
>Subject: RV-List: Dynon EMI noise problem is fixed
>Date: Mon, 29 Mar 2004 17:14:47 -0800
>will
>any
>that
>small
>a
>king.
>)_( Dan
>RV-7 N714D
http://moneycentral.msn.com/tax/home.asp
Your second sentence correctly reflects the operation of the elevator trim
knob. The trim cable is attached to the underside of the trim tab.
Therefore, if you push on the knob that action "lengthens" the cable or
pushes on the underside of the trim tab forcing the trim tab upward. The
air stream force on the trim tab (while it is up) forces the elevator down.
Of course, when the elevator goes down, the tail plane goes up and the nose
of the aircraft points downward. The opposite happens when the knob is
pulled.
Ed
Ed Anderson
RV-6A N494BW Rotary Powered
Matthews, NC
following:
plane will go DOWN.
> Thanks,
> Jack
Subject: | Re: RV-List Digest: 41 Msgs - 03/29/04 |
I am looking for information on the Schroth Restraint System seat belts. They
used to be available through Morris Technologies, Inc.
Can somebody please let me know who is now repping these seat belts for the
RV's.
A response, off list, to DFaile(at)aol.com is acceptable.
david faile
fairfield ct
rv6
Jim, you are correct, it is the -59 blade, and I did buy it from Van's.
LeastDrag93066(at)aol.com
Subject: Re: RV-List: used MT prop for sale
Hi All
Aircraft.
Jim Ayers
That is backwards for elevator trim. Clockwise is IN or forward and just
like the stick, is nose DOWN. Out is back or CCW is up just like the stick.
Gary A. Sobek
1,449 + Flying Hours So. CA, USA
http://SoCAL_WVAF.rvproject.com
----Original Message Follows----
Date: Mon, 29 Mar 2004 20:22:12 -0800
following:
go UP, when the knob is screwed counter-clockwise.... the nose of the plane
will go DOWN.
screwed IN/clockwise, nose down.... counter-clockwise, nose goes up) and I
Jack
From: | "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net> |
Yes Mike will chime in. Here is my update to Doug. Bottom line, my noise is gone.
Doug,
Preliminary results show you have struck gold.
Flew 2 hours yesterday, and ran through my test routine on the ground and only
the barest minimum of noise can now be detected.
I did run " braid from a stud post on the unit to a good ground source.
Did not test whether or not that had any effect. Next time I am in there I will
remove it and see if there is any difference.
But, looks like you have a real good solution for me.
I did try both shielded and non-shielded to the remote compass and there was no
difference(with the new dongle in place). Also I ran the power from the dynon
back to the main buss and that too had no effect(with the dongle in place). So
here are my findings.
Before filter:
Shielding wire to compass helped
Moving to another power buss helped
After filter:
Going back to main buss had no effect
Shielded or non shielded also had no effect
Conclusion: EMI filter working very well. No need to shield wire to compass or
run power from another buss
While sitting quietly on the ramp, engine off, and pulling squelch on a com, and
turning Dynon on and off. Only the slightest change in white noise can be observerd.
Mostly on the lower 121-118 freq range. That's real good news.
So, when you are ready, ill let others know my results.
Good work Doug.
Mike Stewart
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Checkoway
king.
)_( Dan
RV-7 N714D
Interesting when I called them they told me NOT to stop the engine this way
because it will not be clean stoppage of the fuel, and the engine may bump
and stumble. Use the purge/bypass valve only. Although I guess your right
the engine will still stop this way but boy does it bump and stumble. I
also have dual EI I wonder if this makes it worse by being able to ignite a
mixture that mags would have trouble with?
My system is 1 1/2 years old maybe our manuals are different? If I remember
I will read that part again.
Scott Bilinski
Eng dept 305
From: | Gene Gottschalk <geneg(at)sled.gsfc.nasa.gov> |
Subject: | RV6A Project For Sale |
I have an RV6A project for sale. The empanage is done. The left wing is
done. The right wing is done except for the main skins and aileron. The
fuselage is in the jig and ready for the wing attachment and gear drilling
to be turned over and the fuselage top started. It includes the finishing
kit and every thing needed to finish except the firewall forward and
radios. It includes almost every option Van's offers.
Please contact me back channel if interested. It is located in the
Baltimore/Washing DC area.
Contact me at:
Hello,
I have read that Bondo will absorb moisture, and, if true, would be a
poor filler to use
on airplanes. As one who has built a LongEz as well, I would prefer
using dry micro made with
epoxy, or even using phenolic bubbles with epoxy instead,
Glen
RV9 tail
From: | "Lockamy, Jack L" <jack.lockamy(at)navy.mil> |
Thanks David, Jerry S., and Sam B. for clearing this up for me....
Jack
From: | Frederick Oldenburg <foldenburg(at)earthlink.net> |
I'm about to start my rudder. I understand that you are supposed to use a sealant
(usually proseal) on the trailing edge. I noticed that there are two different
stock numbers for this in the Spruce catalog, one for a pint and one for a
quart. I have never used this stuff before. Will a pint be enough for just the
rudder?
http://www.aircraftspruce.com/catalog/appages/ps890.php
Fred
Fred Oldenburg
N270S (Reserved) RV-7A - Empennage
http://www.rv.oldsack.com
From: | "Crosley, Rich" <RCROSLEY(at)HRTEXTRON.TEXTRON.COM> |
Subject: | Re: Canopy Cutting |
Another great canopy cutting method is to use a Roto-Zip tool with a 1/4"
mandrel and a cutting wheel. A cutting wheel a little thicker than Van's
works best, Van's wheel tends to wobble at high RPM's. Also works great on
fiberglass.
Rich Crosley
RV-8, baffles and cowl
Subject: | Re: Was bondo, now Plastic Planes |
Glen,
I've got a friend starting to build a Long-Ez (I know, I know...
"Friends don't let friends build plastic planes"). Got any recommendations
for a list or chat group he can go to for support/camaraderie, he's stuck
out in the middle of nowhere (Barstow area)? Thanks,
Chuck
Subject: RV-List: bondo
> Hello,
> poor filler to use
> Glen
> RV9 tail
Fred
That sealer is to help get at straight trailing edge. If you drill carefully
and install the rivets from alternating sides you don't need it. A pint is
enough but some of those pints come in tubes that require mixing the entire thing
all at once.
Carroll Jernigan
7A Wings
In a message dated 3/30/04 10:35:57 AM US Eastern Standard Time,
foldenburg(at)earthlink.net writes:
> sealant (usually proseal) on the trailing edge. I noticed that there are two
> different stock numbers for this in the Spruce catalog, one for a pint and one
> for a quart. I have never used this stuff before. Will a pint be enough for
> just the rudder?
> Thanks,
> Fred
Fred,
A pint will be way, way more than enough.
Based on some postings on this list though, I just built my replacement RV-9
rudder and didn't use any sealer. The trick is to start in the center and
alternate sides that the shop head goes on.
I got a "little wavy" trailing edge but it is almost perfectly straight on
the average. Maybe I didn't countersink the EX piece enough, or did something
else wrong, but it is acceptable, I think. I don't think Pro Seal would have
helped. I did use a blob of blue RTV between the stiffeners at the rear though
-- to avoid cracking that has been a problem on RV-6s.
Dan Hopper
RV-7A (almost done)
From: | "Evan and Megan Johnson" <evmeg(at)snowcrest.net> |
FYI....It's cheaper through Vans.
From: "Frederick Oldenburg" <foldenburg(at)earthlink.net>
Subject: RV-List: Proseal
one for a quart. I have never used this stuff before. Will a pint be enough
for just the rudder?
> Thanks,
> Fred
> Fred Oldenburg
Chuck,
Yes, I believe the list is canard-aviators(at)yahoogroups.com
It is one I used to subscribe to. I am up to the point of adding the tops
to my fuel tanks, which is the last construction step. Then it is
filling and sanding,
primer, electrical, instruments and wiring. I have no engine for it either.
I decided recently that I could not ignore the ease of sale, and resale
value of the RV series.
I could spend $30k on the longez and only get 30k back out of it. Where
I could make money
on the RV9!
Glen
C. Rabaut wrote:
>Glen,
> Chuck
>From: G B <microsys(at)alltel.net>
>To: RV List
>>Hello,
>>poor filler to use
>>Glen
>>RV9 tail
Subject: | Pitot tube bracket |
Thanks to all who participated in the flush pitot tube conversation. I had a friend
give me a regular old stick out in the wind heated pitot so I'm going to
use it (AN 5812 type). I dont however have a pitot bracket to mount it with. The
instructions in the box say to build one using streamline tubing (2.023 X .857
X .049 wall) Spruce has it but the minimum cut charge is more money than the
steel. Anybody out there have some of this stuff you would be willing to part
with? I need about 6 inches or so. If not I will probably just buy a Gretz
kit and be done with it. I wonder if my wife would notice if I cut a chunk out
of the middle of her bike frame? Hmmmmm.....
Thanks again ....Evan
>Hi Harry-
>Vy after numerous climbs from 2000' shows 1200fpm max. Most runs were at
>about 40-50 OAT and higher than average baros. This might not sound like much
>compared to a 180 hp C.S., but as far as I'm concerned, it's going up plenty
>quick. Once the pants are on, I'll let y'all know what the real deal is...
>Overall, very happy with the prop! Still blows me away that I can climb out
>solo, turn x-wind, and look down at the whole airport from pattern altitude!
>Gawd what an airplane! 8-)
>Mark
Mark,
Are you using the VSI to figure out your rate of climb, or are you
using the altimeter and stop watch?
VSIs may have large errors, so it is much more accurate to use the
altimeter and stop watch.
What rpm are you getting at Vy?
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
Subject: | Re: Pitot tube bracket |
Hello Evan,
I made mine with .032 aluminum scrap and shaped it to conform to the Cessna
pitot that I have. A bit of welding done by an associate to close the
tapered end and add the flush mount bracket, cost me a sandwich and coffee.
To get an idea of how flimsy the FAA approved Cessna mount is, lightly grasp
one that is mounted and operational (with owner permission of course) and
give it a wiggle. For the higher speed aircraft somewhat stronger than that
will be required. In comparison to Cessna mine with doublers is on there!!
almost suitable for tie down.
Jim in Kelowna
----- Original Message -----,
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Subject: RV-List: Pitot tube bracket
a friend give me a regular old stick out in the wind heated pitot so I'm
going to use it (AN 5812 type). I dont however have a pitot bracket to mount
it with. The instructions in the box say to build one using streamline
tubing (2.023 X .857 X .049 wall) Spruce has it but the minimum cut charge
is more money than the steel. Anybody out there have some of this stuff you
would be willing to part with? I need about 6 inches or so. If not I will
probably just buy a Gretz kit and be done with it. I wonder if my wife would
notice if I cut a chunk out of the middle of her bike frame? Hmmmmm.....
From: | "Tommy Norman" <tie-norman(at)comcast.net> |
Subject: | Finish Drill / Deburr Pre-punched holes? |
Several builders have suggested that you don't need to finish drill and
deburr holes that came pre-punched from Vans; just dimple and go (unless
you have to match-drill through the hole). I wanted to get some
opinions from the group before I start setting rivets on my -10 VS. I
know this would save a great deal of time but I am leaning towards the
long route. All opinions appreciated.
Tommy
>Thanks,
>Tommy
The prepunched holes are not properly sized for the dimple die pilot. So,
there will be some localized stress risers and cracking around the hole.
There was a set of pics posted somewhere recently with super close-up
images. Sure enough. Cracks around the hole perimeter. Were they bad
enough to possibly someday elongate into a problem? I have no idea.
After building an RV8 (prepunched skins but no matched hole structural
members), I am much more tolerant of less than textbook perfect form in
riveting, deburring and smoothing. Still, I don't personally feel
comfortable with smashing that dimple pilot through holes that aren't large
enough to accept them.
To each his own. You have to be able to sleep at night with your
workmanship standards.
Brian Denk
RV8 N94BD
RV10 '51 elevators
Subject: | Re: Finish Drill / Deburr Pre-punched holes? |
Bottom line.....Dont take the short cut!
>Thanks,
>Tommy
Scott Bilinski
Eng dept 305
"To each his own. You have to be able to sleep at night with your
> workmanship standards."
Forget the "...sleep at night..." stuff,
It's when the "G" meter starts passing thru 3 or 4 that would concern me.
*Just an opinion that's guaranteed to be worth at least as much as you paid
for it.
Subject: RE: RV-List: Finish Drill / Deburr Pre-punched holes?
> >Thanks,
> >Tommy
large
> Brian Denk
> RV8 N94BD
> RV10 '51 elevators
Subject: | Re: CNC Panel cutting |
Tommy Walker wrote:
> Two or three weeks ago there was a thread on the list about a fellow who, from
a "panel builder" file, would auto-cad a full scale panel drawing. Then after
the builder was satisfied he would CNC cut your panel.
> Does anyone have information on how to contact this fellow?
Ross Schlotthauer
http://www.experimentalair.com/
I just sent him my panel to be cut about
a week ago.
Tim Coldenhoff
www.deru.com/~rv9a
90338 - electrical/finishing
Subject: | K&N air filter E-3450 deal(?) |
I was shopping for a replacement K&N air filter today on the internet
and came across what appears to be a good deal for anyone interested in
having a spare K&N E-3450, the standard air filter that fits the FAB360
air box set up(Filter Height: 2.5 in (64 mm)Inside Diameter: 6.25 in
(159 mm)Outside Diameter: 7.75 in (197 mm)). The filter on my RV4 has
1200+ hours on it and the wire mesh is beginning to show a couple of
tiny fatigue cracks in it.
A place called Pierce Manifolds in Gilroy, CA has a close-out clearance
sale listing on their website for E-3450 filters at $4 each (Van's lists
them for $27.83). I called and they said that they had ordered a bunch
by mistake and had been unable to find a use for them.
I ordered a few for my local RV pals and myself. If anybody else wants
to give these guys a try, their order desk phone number is 800 874 3728.
Mark
RV4
KAWO
Subject: | Where to buy #4 Stainless Screws? |
I am having problems finding a place to buy those
#440-(6) or (8)Stainless Steel Machine Screws.
I have checked Wicks on line catalog and came up
blank.
I bought a big package at OSH several years ago for my
wing tips and now that supply is running out.
Dan DeNeal
rv6a N256GD
Tommy,
The first that I heard of not match drilling was at either OSH or Sun-n-Fun a
year or two ago. It was from Jan Ennenfelner who at that time was building a
-9. He said that he looked under a microscope (or maybe it was a magnifier)
and couldn't tell the difference whether he deburred or not. I got home and
tried it. He was right. But, you know what, after that I deburred before and
after I dimpled the holes!
Dan Hopper
RV-7A (almost done and sleeping very well!)
In a message dated 3/30/04 6:06:17 PM US Eastern Standard Time,
tie-norman(at)comcast.net writes:
> Thanks,
> Tommy
Subject: | CNC Panel cutting |
Here's another one, an RV-8 builder/pilot in the Everett Washington area:
http://rvwoody.com/ Have a look at his website.
Terry
from a "panel builder" file, would auto-cad a full scale panel drawing. Then
after the builder was satisfied he would CNC cut your panel.
Tommy Walker
6A, Ridgetop, TN
From: | Richard Scott <rscott(at)cascadeaccess.com> |
Based on my limited experience, I think time saved by not drilling &
deburring is insignificant.
Suppose you spend 20 seconds drilling and deburring each hole & that's
probably about twice what you would really spend drilling & deburring, but
we have to add in time to cleco things together & take them apart. For
10,000 rivets, you save 55 hours on the whole project. A project in which
you invest, say, 2,000 hours. You have saved 3% of your time.
Now, you go to dimple. My male die goes into the hole easily. Yours does
not fit in the hole & you have to force it in. When I press the go lever
on my pneumatic squeezer, depending on part orientation, the aluminum
sitting on the male die, which is sitting on the ram, gets pushed straight
into the female die, every time, 100% so far. Yours may sometimes slip out
of position unless you spent time forcing your die into the hole. And to
avoid this kind of problem, you have to take more time to be more
careful. Hmmm, that's time you subtract from that 55 hours you
saved. Plus you have to add in time to replace or repair the parts you
ruin because the part slipped off the die & you got a big dent where you
shouldn't.
If time is so important, get a pneumatic squeezer. Dimpling goes really
fast. Get an adjustable ram for it from Avery & you save adjustment time &
lots of frustration.
Get a pneumatic cleco tool from The Yard for $25. Makes pulling out large
numbers of clecos go faster & it's easier on your hands.
Get a number of drills. Set up one with a 3/32 bit, another with 1/8, etc.
Put a coarse or medium belt on your belt sander.
Read instructions ahead of time. Order "optional" rivets & other things
before you need them so you don't stall waiting for parts orders.
If you enjoy music, get a good stereo & it will make all that drilling &
deburring go faster & you won't care.
Richard Scott
9 Emp. & wings are in the barn, waiting for me.
Subject: | Exhaust Ball Joints |
On my Vetterman exhaust system 300 hrs, I notice the ball joints on both sides
of the engine seem to be getting loose. How much play should be expected to be
normal. Mine are loose enough that you can rotate them by hand, is this normal
wear? My pipes are secured the old way by clamps at the aft end of the pipes
at the lower fuselage. Any help appreciated.
Harvey Sigmon RV-6A N602RV
From: | "Robert E. Lynch" <rv6lynch(at)earthlink.net> |
Subject: | Re: Where to buy #4 Stainless Screws? |
Dan try microfastners.com
From: | Garey Wittich <gareywittich2000(at)yahoo.com> |
Subject: | A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL |
rv7-list(at)matronics.com, rv8-list(at)matronics.com
For helpful information see:
See Nov 03 Archieves:
"A GUIDE TO AIRCRAFT PAINTING & CORROSION
CONTROL"
Dan
Try http://www.microfasteners.com/
Mauri
RV-8 wings (forever)
Subject: RV-List: Where to buy #4 Stainless Screws?
> blank.
> Dan DeNeal
> rv6a N256GD
I purchased mine at Cleaveland Aircraft Tools. They still have them in
their catalog as a kit and I bet you can purchase them as screws only.
http://www5.mailordercentral.com/clevtool/prodinfo.asp?number=WHS220&variation=&aitem=17&mitem=17
Gary A. Sobek
Date: Tue, 30 Mar 2004 16:27:12 -0800 (PST)
blank.
Dan DeNeal
rv6a N256GD
Subject: | "Warm" master relay |
rv-list(at)matronics.com, vansairforce(at)yahoogroups.com
My friend has a newly aquired RV-6 and has noticed the master relay gets
"very warm" while flying. Does anyone know if this is normal, or if there could
be an issue? I cannot get to my master relay in my -4 due to it being covered
by my center console.
Thanks for any help!
-Mike Kraus
N223RV RV-4 Flying
N213RV RV-10 Empennage
Subject: | Goodyear Flight Custom III Tires |
Everyone at my airport swears they get 3X the tire wear with the Goodyear
Flight Custom III tires. Has anyone tried these, and do they fit in the wheel
pants? I've heard horror stories of people trying new tires and having them
wear holes in the wheel pants. Thanks
-Mike Kraus
N223RV RV-4 Flying
Subject: | [ H.Ivan Haecker ] : New Email List Photo Share Available! |
From: | Email List Photo Shares <pictures(at)matronics.com> |
A new Email List Photo Share is available:
Poster: H.Ivan Haecker
Subject: The Other Two Best RVs...
http://www.matronics.com/photoshare/baremetl@gvtc.com.03.30.2004/index.html
o Main Photo Share Index
o Submitting a Photo Share
If you wish to submit a Photo Share of your own, please include the
following information along with your email message and files:
2) Your Full Name:
3) Your Email Address:
Email the information above and your files and photos to:
In a message dated 3/30/04 4:28:01 PM Pacific Standard Time,
rv6apilot(at)yahoo.com writes:
<< I am having problems finding a place to buy those
Try Cleveland Tool.
Harry Crosby
Pleasanton, California
RV-6, final assembly
I get all mine at the local boat store. They are of high quality but not
cheap.
From: | Bobby Hester <bhester(at)hopkinsville.net> |
>Tommy Walker
>6A, Ridgetop, TN
You can try http://www.affordablepanels.com/custom_work.htm also. I'm
not sure if he does the stock panels, but zip off an email and ask. Good
price. I might be sending mine to him soon.
Surfing the Web from Hopkinsville, KY
Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/
RV7A Slowbuild wings-QB Fuse :-)
Use 80 grit sandpaper on the aluminum and you will have no problems with adhesion.
Jim Cone
3-Peat Offender
From: | "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net> |
Subject: | Re: "Warm" master relay |
> -Mike Kraus
> N223RV RV-4 Flying
Mine Runs HOT. It is not too hot to touch, but it is too hot to keep holding on
to.
I was concerned about it. Haven't flown yet, (I'm starting to wonder if I will??
I called Van's and I was told " don't worry about it".
I have left it on for days while burning in the solid state stuff. It hasn't burned
up yet.
Phil in Illinois
In a message dated 3/30/2004 4:28:01 PM Pacific Standard Time,
Try Olander listed in the Yeller Pages.
GV (RV-6A N1GV flying 685 hrs)
Subject: | Scroth Seat Belts |
Looking for the source of Schroth seat belts for RV's. Does anybody have a
contact name and address?
david faile
rv6
fairfield ct
David,
We got our's from Team Rocket. They are Hooker belts with the Schroth buckle
- excellent quality and considerably less expensive. You can also call
Hooker direct. In either case, they have a great selection of belt and pad
colors.
Good Building,
Chuck & Dave Rowbotham
RV-8A (see you at S-N-F)
>From: DFaile(at)aol.com
>Subject: RV-List: Scroth Seat Belts
>Date: Wed, 31 Mar 2004 06:28:58 EST
>david faile
>rv6
>fairfield ct
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
After three years of building my slow build here is my somewhat experienced
opinion: Please, above all else Tommy, consider the advice of the plane's
designer. If Vans instructs it should be drilled and deburred with his
design and materials, then that should tell you something. If Vans says it
is optional, then you can have some confidence in taking whichever route you
choose. My concern is the plane's design and the experience behind the
design and how it will stand up not only on first flight -- but 10, or 20
years from now if micro metal tears begin to corrode and rivet strength is
reduced.
However, it is your plane and Vans did not make you sign a contract stating
we will build it per his instructions. If you deviate from the designer's
building plan, in all honesty -- you should stand ready to have those fully
displayed to anyone who rides with you or to whom you entertain selling the
plane to at a later time and your insurance company. I think those things
right there make the drilling and deburring worth your time, not counting
the added risk on the lives of you and your co-pilot. JMHO.
Indiana Larry, RV7 TipUp
TMX-O-360 ACS2002 Dynon CNS430 Digitrak
JeffRose Flightline Interiors
Firewall Forward, Wiring
Subject: RV-List: Finish Drill / Deburr Pre-punched holes?
> Thanks,
> Tommy
Subject: | Re: Scroth Seat Belts |
David, check Aircraft Spruce, page 178.
Walt Shipley
In a message dated 3/30/04 4:30:15 PM Central Standard Time,
khorton01(at)rogers.com writes:
All data based on testing using Mike Stewarts test cards. Climbs started at
1500', speed established, timed for 1 minute after passing through 2000'.
Also do not have leg fairings or pants installed yet. I am using dual plenums,
which may be affecting speeds, but no way to confirm.
120 mph = 900'
110 mph = 1100'
100 mph = 1150'
90 mph = 1200'
RPM on all climbs were in the neighborhood of 2200-2250, IIRC (did not
record, too busy trying to maintian airspeed- I know, Bombardier wouldn't ask me
back!)
I made a few informal tests a few weeks later which seemed to confim the
above numbers. Seems fairly in line with other's results considering I'm seeing
175+ mph @ 2500' and 2700+ rpm. (a/s checked multiple times with gps runs per
M.S. test cards and is in close agreement with a/s indicated by
PCFlightSystems airdata interface)
Does this sound about right?
Mark - 150 hp -6A, Craig Catto 66x66 3-blade
Subject: | Re: Goodyear Flight Custom III Tires |
In a message dated 3/30/2004 10:26:49 PM Eastern Standard Time,
N223RV(at)aol.com writes:
> wheel
> -Mike Kraus
> N223RV RV-4 Flying
Mike:
I have these ... my Aero Trainers from Vans only lasted less than 100 hrs
... I have the Flight Custom IIIs with over 125 hrs on them and absolutely no
sign of wear. I used the no leak tubes from Michelin and hardly ever have to
put air in the tires.
Love them.
Len Leggette, RV-8A
Greensboro, NC N910LL
222 hrs
I don't think I'd use 80 grit on a stressed skin. I agree that it should
work fine to enhance adhesion but I'd be concerned about stress risers
and future cracks.
Dave
RV6 So Cal EAA Technical Counselor
>Jim Cone
>3-Peat Offender
vansairforce
So... I pulled my cylinders off last night to start latest upgrade, and
found two bad lifters and a cam lobe that is about 40% worn off... I don't
have the $$ right now to fix it, so I guess I'll just have an expensive
paperweight for a while...
I posted some pix on my site, but there kinda blurry... I must be getting
old, can't hold the damn camera still any more...
http://www.vondane.com/rv8a/upgrades/upgrades2.htm
-Bill VonDane
EAA Tech Counselor
RV-8A ~ N8WV ~ Colorado Springs
www.vondane.com
www.creativair.com
www.epanelbuilder.com
I broke two 3/32" dimple dies by punching them into holes that were too tight.
They are hardened and the male tip fractures & breaks off. Cleveland tools replaced
them for me free of charge, but I now drill all holes per the plan instructions.
Just another tidbit to add to the sage advice already dispensed on
this topic.
Dave Reel - RV8A
Subject: | Re: engine woes... |
> -Bill VonDane
Bill, I feel for you since you have described the same thing I found
when the cylinders were pulled off my E2D. It seems the lobe on the cam
that shares two lifters is usually the first to go and spalling of those
lifters with the resulting destruction of the lobe is not unusual. It is
probably due to corrosion which probably occurred in my engine when it
was seeing little use for a few years before I bought it.
You have a couple of choices; you can go ahead and take out the bank
loan and do a complete overhaul or you can just split the cases, install
a new cam, have the lifters reground/replaced, and put everything back
together. If the crank journals check within specs you should see many
more hours of service from just the reassembly. If you want to maximize
service and resale, the overhaul might be in order.
Regardless, I know the sinking feeling you get when you look into the
case and see the wasted lifters and cam. Fortunately, splitting the
cases is not an insurmountable or even difficult job especially if you
have access to somebody with Lycoming experience. Plus, the satisfaction
of knowing *exactly* what is in your engine will add to your confidence
in your plane.
Here is the link to my engine rebuild:
http://home.hiwaay.net/~sbuc/journal/overhaul.htm
Best wishes, and enjoy your rebuilt engine!
Sam Buchanan
I had a '73 Mercedes 450SE gasoline burning V-8. Had some sensor problems
that caused it not to run too well in winter and consequently, car didn't
get driven much. Retired from AF, moved to warmer climate and had time to
do some checking when it seemed never to run right anymore - found lots of
flat spots on pax side cam lobes and replaced cam shaft. Used crocus cloth
and polished pilot side cam lobes - then drilled larger hole into cam
support block to match size of hole in V-8 block, to increase oil flow to
the side that failed prematurely. On a VW engine, had spalling of cam
bearing shells - found that only 1 side of crankcase had the little oil slot
under the hole in bearing shell - other side never got oil!! So, used
Dremel and cut the little v-groove into "plain" side of case so oil traveled
around to both shells and came out hole in middle of both instead of just 1.
But, to the point, this is probably a classic case that
illustrates/justifies installing a "pre-oiler" - a quart can in engine
compartment plumbed to the main oil galley or some external hose or block
like oil cooler or filter - with a single in-out fitting in bottom of can
with valve that is open when engine is running (fills can with oil, with air
compressed and trapped in top), then you close the valve before engine
shutdown (run up to get full oil pressure first). Then, before start, you
open the valve and the compressed air in top forces out the oil so it fills
the oil galley - and lubs camshafts, etc.
David
Subject: Re: RV-List: engine woes...
don't
getting
> > -Bill VonDane
> in your plane.
> Sam Buchanan
I was advised by an engineer at Van's that match drilling is required to remove
the work-hardened area around the punched holes, and that their tests indicated
failure to do so would significantly reduce the fatigue life of the airframe.
That opinion is from an experienced engineer with inside knowledge, and is
consistent with my understanding of metallurgy, as a mechanical engineer, so I
give it a lot of weight. I will always match drill until I hear otherwise from
Van's, and I would not buy a used RV if I knew the builder had not.
Some have argued that we all deviate from Van's plans, and that this is just
one more example of something that's up to the builder. I agree with the first
part, but not the second. All the riveting on my RV will be either in
accordance with Van's instructions, AC-43.13, or MIL-R-47196A, to the best of
my ability. The freedom to decide in no way justifies deciding badly, or from
ignorance.
Tedd McHenry
Surrey, BC
Well Said Jim,
Excellent post.
Archiving it.
After 1100 hours in 2 years in a 6A, I can tell you there are a ton of
things I am doing differently on my current 8 project, off plans,
against Van's recommendations, and better.
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Sears
Subject: Re: RV-List: Finish Drill / Deburr Pre-punched holes?
Again, I can't tell anyone on the list that they should dimple without
match
drilling. That must be left up to the individual builder. However, I
do
get a kick out of the notes that discuss how important it is to follow
Van's
instructions to the letter because there is a reason for it. If
everyone
had an opportunity to look at some of the RVs flying out there real
close,
they would quickly discover that this is really good in theory; but, it
isn't followed very well. I believe the Harmon Rocket that eventually
led
to the RV-8, as I see it, is a good example of how we drift from the
norm.
Putting gascolators at wing roots, using fuel filters, etc. are others
we
hear about often on this list. We all deviate a little somewhere to
make us
feel better about our projects. Riveting is one of those. How many
times
have you changed to a different rivet size because the ones called out
in
the plans just didn't work? I know I have because I knew there was no
way
the called out rivet would work. Does that mean I should lose sleep
over
it; or, should I be content that I've done something that might well
have
been better than had I done just what the plans called for?
Anyway, I said I'd tested and looked closely at examples of each kind of
dimple, matched drilled and not matched drilled. I could not see the
difference.
Granted, I was not using a high powered microscope to look at them; but,
I
did look pretty closely with a magnifying glass. Both types of dimpling
deformed the hole edges, even though I made sure I was not forcing the
dimpler into the holes. I actually got a better rivet fit by not match
drilling. It was a little loose; but, it wasn't excessive.
Rather than getting into the theory side of it, I'd like to know of
someone
who has not match drilled, is doing aerobatics that puts real stresses
on
the airframe, and has had rivets popping off or cracks appearing that
can be
attributed to the lack of match drilling. Don't just discuss the
theory.
Show me that it's actually happening. I'm the practical builder, not
the
theorist. If you can show me, I'll listen. I'm willing to learn from
the
experiences of others.
I'm not trying to be hard headed. I'm also not trying to get out of
work
because I really enjoy building RVs. My working on my third project
should
tell you that. I just find it hard to believe that I can drill a hole
better than the machine can punch it. I should know. While building
Scooter, I drilled a lot of holes. It's like the deburring discussion.
One
can find discussions that say one must debur every hole and can read
books
that say otherwise! I've even read on this list about companies that
don't
do it, at all! Now, that gave me heart burn; but, they may very well
be
right. In this world of excessive litigation, they stand to lose a lot
more
than me and are not deburring, anyway.
Again, I'm not telling anyone it's OK to not match drill. At the same
time,
I'm going to look at it with an open mind and not worry about 10-20
years
down the road. I can assure you that other things will crop up for me
to
worry about more so than those holes. Engine failures, electrical
problems,
etc. come to mind as more recurrent issues for some of us than rivets
coming
out and cracks forming. Now, canopy cracks are a different problem and
do
make me worry a bunch. :-(
Jim Sears in KY
RV-6A N198JS (Scooter)
RV-7A #70317 (Cleaning engine parts, need to finish tail, ordered wings)
EAA Tech Counselor
Lycoming engines are known for eating camshafts. The only fix that I'm
aware of is the Nye Nozzle case mod, (spray nozzles are installed to
spray oil on the cam), and a preoiler. Engine start is your worst time
for cam oiling.
http://www.chuckneyent.com/neynozzle.html
Bruce
www.glasair.org
Subject: | Dielectric grease |
Trivia question: dielectric grease is used in some applications because of
it's special properties with regard to how it conducts electricity. Does it
provide better conductivity, or does it insulate? This has bothered me for
years and I need to know, plus it's probably a good thing to have in the
archives.
Thanks to those more knowledeable than me.
Randy Lervold
RV-8, RV-3B
comments below!
>>-Bill VonDane
Almost a sure thing. Long periods of idleness almost guarantee cam
follower and lifter failure. It may have been salvageable if two
cylinders had been removed and the followers looked at before running
for an extended time. The cam and the cam follower can usually be
reground before major damage occurs. Sometimes the cam follower is just
too far gone.
If you're going to split the case anyway, it's false economy not to go
for a major overhaul. Been there done that, and the second time around
(in too short a time) it was a full major. I'm happier, and the engine
is happier.
Actually, with just a little 'engine' knowledge, the overhaul manual and
the parts manual (these cover more than one 'model' but are specific so
get the one for your engine). Depending on the age of the engine (in
years, not necessarily hours) since major if there was one, I'd send the
case off to Divco and have it overhauled and the mods (if any)
installed. That was around $600 for my O-360, and money well spent.
The hardest part is splitting the case .... and you can do it without
the fixture ..... but the rest of the tools you most likely have in your
tool box.
>in your plane.
And your knowledge. Find an A&P that will work with you .... but get
one with some engine rebuilding experience. Buy him a case of beer ...
After you're done working!
Wish I had taken pics. I didn't give it much thought!
Linn
>Sam Buchanan
Insulates
Trampas Stern
Stern Technologies
4321 Waterwheel Dr
Raleigh NC 27606
919-832-8441 Ext. 12 (voice)
919-832-8441 (fax)
www.sterntech.com
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Randy Lervold
Subject: RV-List: Dielectric grease
archives.
Randy Lervold
RV-8, RV-3B
Subject: | Re: Finish Drill / Deburr Pre-punched holes |
When people ask me for advice on buying a used RV, one of the things I tell
them is to go to the Matronics search engine, and punch in the owner's name
and/or the aircraft's registration. You'll learn all about the problems
the builder had during construction, and you may even learn things he
wouldn't want you to know (like skipping fundamental steps in construction
that the kit manufacturer considers mandatory).
As a mechanical engineer, I know that punching the holes will work harden
the material around the edge of the hole. You can't see it with a
magnifying glass, and i'd be surprised if you could see it with a
microscope. Drilling out the hole just a small amount will remove most, if
not all, of that work hardening. If that work hardened area is not
removed, you can be sure that the fatigue life of the aircraft will suffer
as a result.
Whether it means you knocked 1000 hours or 10 hours off the life of the
aircraft, nobody could tell unless they knew exactly what conditions the
airplane has been, and will be, subject to during it's service life. But
why would you knowingly shorten the life of your aircraft? It's really a
small step, and one that goes quite quickly.
Personally, I want my aircraft to have the highest resale value possible in
the unlikely event that I want to sell it at some point. Cutting corners
in construction, and admitting it on a public, archived, mailing list,
isn't the way to ensure that high resale value.
-Rob
Subject: | BFR and Training in an Experimental |
I have heard people talk about training for their PPL, Instrument ticket, etc in
an experimental. I assume you are allowed to get a BFR also in an experimental.
Is this true, and if so where in the regulations does it say this is possible.
My flight instructor is asking and I can't seem to find any info either
way in the FAR's. Thanks
-Mike Kraus
Subject: | Re: Dielectric grease |
Not so much insulate as isolate from oxygen and other oxidizers. In the case
of ignition and other high voltage circuits it seals the insulators
together, not allowing moisture or foreign elements to penetrate the
insulation seal.
John D
it
> archives.
> Randy Lervold
> RV-8, RV-3B
From: | "Gordon Robertson" <grobertson(at)verizon.net> |
I found it useful to get a power screwdriver (eg Black and Decker) and put
the deburrer tool in the chuck. This is then dedicated to that job
forever, and eliminated the carpal tunnel syndrome possibility of all those
10,000 deburrs
Gordon Robertson
RV8 ready for engine
Does anyone know, or have any idea, what might happen if a direct short
was applied across the terminals of the Odyssey PC680 battery. Would the
battery blow up?
Just Curious,
Gary
Subject: | PC680 battery box |
Just found this on the internet and it looks pretty cool. Brushed
aluminum and ready to bolt on. No fabrication needed and it's FAA
approved too!
http://www.odysseybatteries.com/pc680hd.htm
Gary
Subject: | Re: PC680 What If |
There is a vent hole on the top of the battery that will vent if need be.
It is covered with the product label and states do not cover this
area....about .5 dia
>battery blow up?
>Just Curious,
>Gary
Scott Bilinski
Eng dept 305
From: | "Coers, John" <John.Coers(at)fkilogistex.com> |
I think I'm going to stop match drilling too. I think my choice of PRIMER
will keep the skins from cracking. Not that my plane will have much stress
on it anyway, since it's a tricycle gear with a slider canopy. I mean, if I
were to build a taildragger with a tip up canopy and some inferior PRIMER
(non zinc chromate) then yes I might want the strength that match drilling
provides.
Have a nice day :-)
From: | "Jim.Truitt(at)usdoj.gov" <Jim.Truitt(at)usdoj.gov> |
(Receipt Notification Requested)
FYI - I just spoke to Cindy at Pierce Manifolds. All of the K&N filters
(E-3450) are sold. She was quite amazed at the power of the RV list.
Subject: | Subaru Engines... |
vansairforce
You know I just don't understand why anyone would pay $22K for an engine
that you can buy new from Sub for less than $5K!?
I'm sorry... I'm sure this will piss some people off, but why does this
$hit cost so much!
-Bill
According to 'lectric Bob it takes about an amp of current just to keep the
master relay closed. Thats why he likes to see a simple switch on the
essential bus. Since an amp is more than a SL 40 uses while on and not
transmitting.
I don't know, but 12 watts is certainly enough to get something that small
pretty warm.
Don
"All of us need to be reminded that the federal government did not create
the states; the states created the federal government!"---Ronald Reagan
Jim:
> Of course, you'd also be one in a hundred that
> might even think to ask the question. :-)
I design punched sheet aluminuam parts for a living, and they are always
punched and then rivited straight after, with no match drilling. But they
aren't airplane parts, and fatigue isn't much of an issue in the products I
design.
If your plans don't say to match drill, I can understand why you might think
it's not necessary. But in my airplane, I will always remove the work-hardened
material around the hole, until I see evidence that it's NOT required. I can't
see the percentage in taking that chance just to save a few hours of building
time. Maybe that explains why you've built three and I'm still working on my
first.
It's possible that the dimpling relieves the residual stress created by the
punching. But I'd want to see some test results before I counted on that.
> I don't have a copy of MIL-R-47196A.
In an earlier post you talked about deviating from rivet sizes called out in
the plans, and wondering if that was okay. MIL-R-47196A will give you the
answers you need. You can get a copy at
http://home.flash.net/~gila/rivet_spec/rivet_a.htm
or
http://www.vansairforce.org/reference/MIL-R-47196A_MI.pdf
Tedd McHenry
Surrey, BC
These lists are great, thanks to all for your opinions.
I was originally leaning towards match drilling and deburring. Now
after hearing everyone's opinions and talking with Vans, I am defiantly
going this route. Matter of fact, I went ahead and match drilled my VS
already. Deburring and dimpling will commence tonight.
I am in no way looking for shortcuts that will compromise the longevity
of the aircraft, or more importantly, safety. This craft is not only
for my pleasure flying, but it is also a means of transportation for my
wife and two small kids. Therefore, I will take the utmost care in
producing the highest quality product that I can.
Vans sited the following reasons for following this process:
* If one piece is punched during warm temperatures and the other during
the cooler temperatures, the holes could be different sizes. Dimpling
will not fully correct this deviation. The rivet will fill the smaller
of the two when squeezed but not necessarily the larger.
* The time it takes for this process is accounted for in the 51% builder
time. The inference I drew from this was that if you did the quick
build, and did not match drill and deburr, you would not be building 51%
of the plane and therefore would not be legal???
* During the hole punching process, there are vertical shear marks left
in the skin and they also detected very minute cracks. Since the holes
are punched smaller than the final drill size, the shear marks and
cracks will be removed during the finish drilling process.
Thanks again,
Tommy
Frisco, TX
-10 40201
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tommy Norman
Tommy
> hundred that might even think to ask the question. :-) Personally,
> I'd be guilty of not asking and would be looking at the riveting, the
> engine installation, the wiring, attachments, general condition, etc.
I think in the case of the RV's, with so much information available online
about them, it wouldn't take long for a prospective buyer to become quite
savvy about the ins and outs of RV-building. They may not have the skills
to build it themselves, but you can be sure they'll learn what questions to
ask.
It's interesting that the first thing you mention you would look at is the
riveting, but you wouldn't consider something that would reduce the life of
the riveted joint to be significant.
> I just had to get out my new manual and preview plans. Whoa! There is
> no mention of limited life of the airframe from the lack of match
> drilling.
True. But the manual can't tell you how to do every little thing, either,
or it'd be 3 feet thick instead of one binder's worth. You have to make
some choices on your own, based on the instructions provided. If the
instructions didn't say that drilling out was necessary, and it was just us
here on the 'list telling you you need to drill them out, I could
understand your position. But the designer spells it out in both the
manual and in direct feedback to customers when they ask. Why second guess
him, when you (by your own admission) don't have the engineering knowledge
to argue the point?
> Well chosen words, Tedd. That's what we should be doing. However,
> there is no mention that I could find about work hardened holes in Van's
> instructions and my copy of AC 43.13.
Keep in mind that the work hardening is a result of the punching process,
so AC43.13 wouldn't mention it. Van doesn't mention it because once the
holes are drilled out, you've removed that work hardened area. So if
you're following the plans, it becomes irrelevant.
> I
> remember a while back that one builder left out one small piece in the
> tail. It cost him his life. A small deviation from plans that was a
> structural item.
You might want to keep that in mind every time you dimple a hole you didn't
drill out first.
> Much deviation is done on our craft.
And deviation is good, as long as you're not mucking with the structure of
the aircraft without some solid engineering analysis first. Moving a fuel
line isn't going to make your plane fall out of the sky, and the worst
thing that will happen without a gascolator is that your engine will quit
and you'll have to deadstick.
> Bob, I wouldn't even try to do it before dimpling the hole. My test was
> made after I'd dimpled each hole. I would think that a work hardened
> metal would show stress cracks around the hole when dimpled. One way
> showed no worse than the other. Both ways deformed the holes some.
You would be wrong about seeing stress cracks from work hardening. Work
hardening is a microscopic change in the metallurgy, it will still look
intact and uncracked under magnifying glass and probably under a microscope
too.
> Remember, I'm not an engineer. I'm just an average builder in the
> boondocks who knows no better and have discovered that my holes are
> perfectly aligned, will accept rivets well, and can be dimpled without
> forcing the dimpler into the hole. Why is it not in the manual if it's
> that important?
Because it's expected that a prospective builder will take the time to
learn the skills to build an airplane properly, not start re-engineering it
and rationalizing the changes with some limited scope of knowledge they
posess. A builder with an engineering background (like me) will know when
it's safe to deviate from the design and when to ask advice if it's
unclear. A builder without the engineering background should probably
simply stick to the plans and builder's manual, unless they know someone
who can provide them with some engineering expertise. And the best place
for a "builder in the boondocks" with internet access to start is at
www.vansaircraft.com. Don't take my (or anyone's) word for it. Call Vans,
and ask them.
> I just think that my drilling may not be as
> good as the machine's hole. That may cause a small alignment problem
> later. Remember that I drilled all but a very few in my -6A. I know
> what making holes bigger does. I can cause things to shift. Thus, the
> need for jigs.
On my -7 kit, the holes are only drilled out once all the components are
aligned in their final configuration. Every second cleco, drill the holes,
shift the Clecos by one, drill the other holes. Disassemble, dimple,
reassemble, rivet. Alignment shouldn't be an issue.
> As for service life, I'm not sure anyone can really predict that. A
> quick look at the old DC-3s will enforce that one. :-)
Sure, but every one of those holes was drilled out. 8-)
-Rob
In a message dated 3/31/04 5:23:17 PM US Eastern Standard Time,
Tommy,
You may have misunderstood this point. I think the rivets will fill small
and large holes both. The difference would be along the length of the parts.
Dan
RV-7A (almost done)
Subject: | Re: [VAF Mailing List] Subaru Engines... |
Go to http://www.eggenfellneraircraft.com/ and click on the spinning
"new" link. He explains it there. It is not just the cost of the
engine. You are paying for a lot more than just the engine.
Chris
> engine
> this
> $hit cost so much!
> -Bill
> Online help on this group at:
> http://help.yahoo.com/help/groups/
> ADVERTISEMENT
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/vansairforce/
> To unsubscribe from this group, send an email to:
> vansairforce-unsubscribe(at)yahoogroups.com
> Service.
Subject: | Re: Subaru Engines... |
My friend has already made three, repeat three, emergency landings with his
Subaru engine....my Lycoming hasn't made any and it's been flying eight
times longer....you get what you pay for.
John at Salida, CO
Subject: | Re: PC680 battery box |
I called this company and the polished version is $39.95 and the black is
$43.95 both in stock and available.
I'm doing a dual battery set and kicked around mounting the two back to back
on the floor near the front. A simple cover could be fabricated and hinged
to provide easy access. Any thoughts or comments?
Darwin N. Barrie
Chandler AZ
Subject: RV-List: PC680 battery box
> approved too!
> Gary
Pretty general statement that needs clarification.
1) What type of Subie? Did he build it or was it one of the known
manufacturers?
2) What was the nature of the problem? Root cause?
I've seen Lycomings go on the first take off but it is generally some
associated event that caused the problem. Let's have all the facts before
slamming Subarus.
Darwin N. Barrie
Chandler AZ
Subject: Re: RV-List: Subaru Engines...
his
> John at Salida, CO
Subject: | Attachments to all RV-List messages |
All of the emails I am getting from the RV-List have attachments on them
with the same title as the email.
Why?
Ross Mickey
RV6A
Also think about the location of the contactors and the wires to/from them
when considering mounting the battery. Van's battery box has provision for
installing 2 contactors. With two batteries back to back on the firewall
and with an overvoltage contactor and a cross feed contactor, I have 5
contactors all within inches of each other. It is working out pretty well,
but that's after redoing it a few times.
Your idea still sounds good to me. (It sounds like you are building a
side-by-side RV.)
Terry
RV-8A wiring and stuff
Seattle
Darwin N. Barrie
Chandler AZ
Jim Sears wrote:
> Since this discussion is starting to turn nasty, I'll just back off and let
> it slide. You've made your point that I may not be so sharp because I live
> in the boondocks. In fact, I'm probably not smart enough to build my -7A
> just because I'm willing to challenge an issue. Hmmm. I really thought I
> had this building thing going OK. My RV-6A has about 300 hours on it. The
> RV-9A I helped to build is flying quite well. I really thought I knew how
> to build. Others I know seem to think so. Maybe I don't. I guess my
> building a new -7A will tell it for me. Maybe not. :-)
> Jim Sears in KY
> RV-7A #70317
> EAA Tech Counselor
Ok Jim, since you live way too far out in the boonies to know how to
safely build an airplane, I will be in KY Saturday to fly your plane
back to Alabama for safe keeping. Some of my buddies will be up there in
a truck to pick up the RV-7A you are workin' on.
They last thing we want happening is for some unlucky slob to buy one of
your planes and have the thing turn to dust while he is airborne.
Good grief, I bet you didn't dip each rivet in primer before you stuck
it in the hole either! Bet you didn't even take a Q-tip and primer the
inside of the holes. Maybe we better disassemble your RV-6; I'm not sure
I feel safe flying it!!!!!!
See you Saturday,
Sam Buchanan
The bottom line answer is that "yes" you can. As far as the FARs go this is
a case of not what the regs say but of not what they say. The regs do not
say anything about a restriction on which category of aircraft you use to
get a rating or BFR as long as the yeqrly (annual) condition inspection is
done and there are no discrepancies on the aircraft. This is all covered by
FAR Part 91.
Mike Robertson
Das Fed
>From: N223RV(at)aol.com
>To: vansairforce(at)yahoogroups.com, rv-list(at)matronics.com
>Subject: RV-List: BFR and Training in an Experimental
>Date: Wed, 31 Mar 2004 13:07:17 -0500
>etc in an experimental. I assume you are allowed to get a BFR also in an
>experimental. Is this true, and if so where in the regulations does it say
>this is possible. My flight instructor is asking and I can't seem to find
>any info either way in the FAR's. Thanks
>-Mike Kraus
From: | Charlie & Tupper England <cengland(at)netdoor.com> |
>Darwin N. Barrie
>Chandler AZ
>From: "Gary Zilik" <zilik(at)excelgeo.com>
>To:
Do they weigh less than a few pieces of angle & a nylon strap? :-)
"Simplicate & add lightness." (wish I could give proper credit for that
quote....)
From: | "Frank van der Hulst (Staff WG)" <F.vanderHulst(at)ucol.ac.nz> |
My understanding is that by the far the vast majority of engine failures
of homebuilts are due to one of the ancillary (fuel, ignition, cooling,
etc) systems failing, not the engine itself. If that's true, then on
average you are about as likely to have a failure with a Lyc as with a
Subaru.
Perhaps a more accurate throwaway line would be... you get what you
build.
Frank
> with his
> eight times longer....you get what you pay for.
Learn real skills for the real world - Apply online
at http://www.ucol.ac.nz or call 0800 GO UCOL
(0800 46 8265) or txt free 3388 for more information
and make a good move to UCOL Universal College of
Learning.
Enrol with a public institute and be certain of your
future
From: | Paul Parashak <pavel_gaijin(at)yahoo.com> |
I know for a fact that one of the surest ways to accelerate metal failures
is to introduce a flaw. These miniscule cracks and stress areas that are
left in are prime areas for crack propagation.
I am a submarine officer in the USN and we do extensive testing on metals to
ensure that metals used (primarily high alloy steels and not aluminum) are
free of detectable preexisting flaws.
I plan on drilling / deburring and dimpling all of the prepunched holes on
my RV-7 (or 8 if I can convince my wife).
Paul Parashak
Preview plans stage.
> remove
> indicated
I
> from
> first
> ignorance.
> Tedd McHenry
> Surrey, BC
Gotta stir this pot just a little more.
First, for the record ;-) , I've got lots of #30 & #40 drill bits, &
I've worn some out on my relatively new RV-7 project. I also have a
deburring tool & use it regularly.
I asked Van, his on self, face to face, in person, at OSH last summer
when they were going to go ahead & punch the holes 'full size' & save us
all some build time. His answer (his *only* answer) was that there was
enough variation in drilling patterns that they preferred to continue
the match drilling thing for now.
I tried a little experiment on some prepunched angle this afternoon. An
untouched hole would accept about a #41 or #42 bit (~.090 on my cheap
calipers). I dimpled one hole 'raw', one after debur only, one after
drill only, and one after standard #40 drill & debur. Final sizes varied
from .100 to .110 depending on actions taken, with .110 after using
recommended technique. The interesting thing is that the
drilled/deburred & dimpled hole edge looked roughest of all the samples.
The convex side edge had 'ripples' obviously caused by the debur tool
chattering. It's a standard 3-flute tool available from Avery, et al.
(learned that when I got sued once.) Has anyone else seen anything
similar after standard drill/debur/dimple?
If you are getting so anal about drilling, I would propose that you use a
chucking reamer instead of a drill. At least that way you will get a round
smooth hole. You don't get smooth nor round with a drill bit.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or sportpilot(at)eaa.org
Always looking for articles for Sport Pilot
to
> ask.
of
> > drilling.
us
guess
> to argue the point?
> > I
> > structural item.
didn't
> drill out first.
microscope
> too.
> > that important?
it
Vans,
> and ask them.
> > need for jigs.
holes,
> -Rob
Subject: | Re: Navaid servo installation under seat |
In a message dated 3/31/04 1:21:33 PM Pacific Standard Time, mstewart(at)iss.net
writes:
<< Does anyone have pictures of a WORKING installation under the seat for
an rv-6? >>
I'm certain you will get other offers but you could call Navaid at
423-267-3311 and ask them for RV-6 under seat installation sketches and they will
send
you some.
Harry Crosby
What is done with the punched lightening holes in the ribs. They aren't
drilled and they are flanged which is much like dimpling.
let
live
my -7A
I
The
how
> > Jim Sears in KY
> > RV-7A #70317
> > EAA Tech Counselor
> See you Saturday,
> Sam Buchanan
Charlie,
When I said I deburred after drilling, deburring and dimpling, I meant deburr
the back side where it is stretched from the dimpling operation. 3/32 is
.09375 inches. As you pointed out, after you dimple the hole measures about .100
inches or more. That's quite a stretch from 3/32, and that's why the hole
looks rough. A quick turn of my "blue tool" from Avery's shines it right up.
Actually, I didn't do this to the whole airplane. Even I am not that
particular. BTW my bits from Avery drill a round hole when turned at high RPM
in my
Sioux air drill -- at least most of the time.
Now, let me stir a little more. Let me tell you about my riveting technique.
I have been pre-squeezing my 3/32 rivets up to about .100 in my hand
squeezer before beating on the skin of the airplane with the air hammer. I found
that the shorter, fatter rivets always drive straight, and the skin looks a lot
better after I'm done. The rivets do that anyway, why beat up the airplane
doing it? Also, I always use about a 3 inch strip of Vans special riveting tape
over just one rivet. I use the same piece of tape for up to about 20 rivets,
moving it about 1/8 inch each rivet. It protects the skin and the tool, and
gives a better target to aim at. It does take a little more time, but it
really did improve my riveting.
What do you think?
Dan Hopper
RV-7A (almost done)
In a message dated 3/31/04 8:50:38 PM US Eastern Standard Time,
cengland(at)netdoor.com writes:
> First, for the record ;-) , I've got lots of #30 ( drill bits, &
> deburring tool &use it regularly.
> when they were going to go ahead &punch the holes 'full size' &save us
> drill only, and one after standard #40 drill &debur. Final sizes varied
> drilled/deburred &dimpled hole edge looked roughest of all the samples.
> Charlie
In a message dated 3/31/04 9:21:33 PM US Eastern Standard Time,
jcoers(at)bellsouth.net writes:
> It was that thingy call the spar.
Are you talking about the horizontal stab or vertical stab? How did he get
it to stick to the airplane at all?
From: | "Charles Becker" <ctbecker(at)charter.net> |
"'vansairforce'"
I'm certainly sorry to hear about your situation. How many hours were on
the core?
Charlie Becker
N464CB RV8A(e)
Wings
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill VonDane
Subject: RV-List: engine woes...
-Bill VonDane
EAA Tech Counselor
www.vondane.com
www.creativair.com
>Tedd, I'm betting the person selling that airplane to you isn't going to
>tell you whether he match drilled it, or not. He's going to be showing you
>the virtues of his airplane. Of course, you'd also be one in a hundred that
>might even think to ask the question. :-) Personally, I'd be guilty of
>not asking and would be looking at the riveting, the engine installation,
>the wiring, attachments, general condition, etc. I'm betting most of the
>rest of us would, as well.
In my experience, if a builder is too lazy to build the airplane the way
the kit manufacturer recommended, you'll see other evidence elsewhere,
you won't have to be told about the way he drilled the holes.
And I mean it when I say lazy. Not match drilling is just a way to save
time and effort, it will NOT make it a better airplane.
Dave Bristol
Hopperdhh(at)aol.com wrote:
> Charlie,
.100
in my
I have a question.
If a driven rivet pulls up tight enough to prevent any relative motion
between the rivet and the two pieces of aluminum, or the aluminum pieces
to each other, how can cracks propagate from the rough edges of the
rivet hole?
No movement, no cracks, right?
Sam Buchanan
Sam Buchanan
If I remember correctly, the cam lobes and followers are not pressure
oiled. The only oil they get is from "splash", and if that is indeed the
case then pre-oiling will not do much for cam wear.
Dave Bristol
From: | Larry G RV-7 N697RV <edge540t(at)direcway.com> |
I cant agree with you any more the reamer dose allot better job for round
and smother hole. I started on the
wings with the reamer instead of a drill bit when I could.
It don't leave the nasty drill burr.
> From: "Rob Prior" <rv7(at)b4.ca>
> To:
online
quite
skills
> to
> > ask.
the
> of
is
> > > drilling.
either,
> us
> guess
knowledge
> > to argue the point?
Van's
process,
> > > I
> > > structural item.
> didn't
> > drill out first.
of
fuel
quit
was
> microscope
> > too.
it's
> > > that important?
> it
when
place
> Vans,
> > and ask them.
the
> > > need for jigs.
> holes,
> > -Rob
No, that's not correct. No relative movement is required to propagate cracks,
only stress. In fact, under the right conditions cracks can propagate while
the part is sitting on the shelf (for example, stress corrosion cracks).
Tedd McHenry
Surrey, BC
Which is why you also need the Ney Nozzle mod. To spray oil on the
lobes.
Bruce
www.glasair.org
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Bristol
block
can
with air
you
fills
Dave Bristol
I might also suggest your local Radio Shack for the #4 SS screws.
Greg
Uh oh......are you saying that Vans is shipping airframe kits that
possibly have stress corrosion cracks propagating while the parts are in
the warehouse, being shipped to us, and sitting in our shops waiting to
be assembled?
How can we be assured that the "right conditions" are not present which
can enable stress corrosion cracks from occurring while Vans is cutting
out the parts for my kit? Apparently these insidious cracks may be
propagating due to no negligence on my part.
Or should I insist that some of the guys in the factory at Vans go ahead
and polish all the edges of the kit parts so I won't be faced with
stress corrosion cracks on my brand new parts. Goodness knows having the
parts trucked all the way across the country to the boonies of Alabama
is plenty stressful.
How do I know those kit parts aren't getting stressed out? Is there such
a thing as stress corrosion crack syndrome (SCCS)? I can't stand the
thought of paying a lot of money for a kit that is already stressed out
before I have a chance to stress it out in my shop.
I am finding this whole idea to be very stressful. Matter of fact I
think I may be cracking up. Somebody deburr me.....quick! No, even
better, ream me out! And while you are at it, gimme a shot of epoxy
primer! I'm too young to succumb to SCCS!!
Sam Buchanan
From: | Hal / Carol Kempthorne <kempthornes(at)earthlink.net> |
At 02:00 PM 3/31/2004, you wrote:
>I will always remove the work-hardened material around the hole
>first.
There is something to this! There can be some difference in the level of
craftmanship or maybe perfection from one RV to another and yet both still
be safe flying machines. We know that some of our tools look and perform
alike but one is built to last longer tho usually at a higher price.
Personally, I think most RV accidents will be pilot error and a few will be
due to components attached to the airframe rather than the airframe itself.
K. H. (Hal) Kempthorne
RV6-a N7HK - Three trips to OSH now.
PRB (El Paso de Robles, CA)
Your friend's Subaru was a roll-your-own junkyard special.
My friend just rolled over 450 hours on his Eggenfellner Subaru and reports
that it has yet to miss a beat or use any oil between 50-hour changes. He
sends the oil out for spectroscopic analysis every time, and every time it
comes back "no wear."
So I guess you're right, you do get what you pay for. What you pay for with an
Eggenfellner is a complete, tested package. As someone else pointed out, the
auxilliaries are where you're most likely to have a problem, and that is the
key advantage of a well engineered package.
I'm not bad-mouthing roll-your-own engine conversions. I really admire the
people who do it well, and I'd like to do it myself, eventually. But one
person's problem-plagued installation is not a reflection on a well-engineered
package like Eggenfellner's.
Tedd McHenry
Surrey, BC
One of the first things I encountered when I started my -9 was a roughness
when I ran my fingers across holes I had deburred with the Avery 3 flute
tool. So I looked at the hole with a strong hand lens & saw
chattering. Tried more pressure, less pressure, spin faster, slower &
every thing else I could think of to eliminate it. Talked to Bob Avery who
sent me another bit but still had the problem. Finally ordered the single
flute bit & the chattering is 90% reduced. Also found that if I tilt the
handle of my tool outward (to give a flatter angle) as I spin it, it does a
nicer job & does it in only one turn.
Richard Scott
9 Emp
Charley, et al
I always cleco matching parts together, match drill, deburr, and dimple. I
use only the Avery 6 flute chatterless deburr tool after discovering that
the 3 flute tools in combination with cordless screwdrivers leaves what
resemble tiny gear teeth (ripples) around the holes. The 6 flute leaves a
smooth clean deburr and works well for countersinking flanges for nutplate
rivets. A piece of 1/4 inch rod, a short piece of 1/4 inch I D al tube, and
5 minute epoxy make a nice extension for the tool. I normally use a light
cordless slow speed drill for deburring whenever possible. By the way, this
same drill with a 3 flute tool would leave the same "gear tooth" effect as
the cordless screwdriver because of gear train resonance in both drives.
Dean Van Winkle
Retired Aero Engineer
RV-9A Fus/Finish
From: "Charlie & Tupper England" <cengland(at)netdoor.com>
> Charlie
From: | "James E. Clark" <james(at)nextupventures.com> |
Thanks Gary.
But just so I feel better, I must say ... Arrrggghhh!! ;-)
I **JUST** finished installing a dual set of the earlier steel ones! (Cut
out eight (~2") lightening holes in each box).
James
> [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Gary Zilik
> Sent: Wednesday, March 31, 2004 2:22 PM
> approved too!
> Gary
Listers,
My father and I are building an RV-7 and my Dad will be spending a month
down in Australia in the Brisbane area, I just wanted to see if there
was anyone he could visit so he could get an RV fix. Drop me an e-mail
off line to contact me.
Keith Uhls
keithuhls(at)juno.com
RV-7 finish kit (90% done 90 % to go)
N7KU
>is
>by
>FAR Part 91.
>Mike Robertson
>Das Fed
Mike,
I'm currently dealing with this issue. I'm due for my BFR. I asked a local
CFI/RV8 builder, who has flown with me a few times before, to do the review
for me. He respectfully declined, saying the flight was supposed to be
"instructional" in nature. My RV8 does not have back seat controls except
for the stick. So, he could not "teach" me anything requiring his input on
the controls.
My last BFR was done by the local flight school chief instructor. He was
more than willing to do it. First time RV flight for him! He never once
expressed any concern about the specific requirements of the flight, the
airplane, or any other issue. We flew, we talked for an hour on the ground,
and he signed me off.
So, is the first guy right, or the second guy? Time to rent spam and just
get it over with?
Brian Denk
RV8 N94BD
RV10 '51
Subject: | new RV-7 needs left rudder in cruise |
Well, I'm steadily flying off my 25 hours, and after 3.6, I can say that
this plane needs 1/2 ball of LEFT rudder in cruise. I'm operating without
wheel pants and without leg fairings. My philosophy is that I want to get
the airplane perfectly trimmed up hands-off before I add the fairings...that
way I'll know if the fairings are straight and are not imparting any turning
tendencies.
Ok, back to this need for left rudder...
The RV-7 has a built-in VS offset as per the plans -- the VS leading edge is
located approximately 1/4" to the left of the aircraft centerline. I gotta
assume that this offset is what's causing the need for left rudder.
Before I go drilling out rivets and making a new VS front spar to HS
mounting plate, tweaking the intersection fairing, etc., can somebody
confirm my thinking?
I don't want to overshoot, though -- part of me wants to slot the bolt holes
in the plate at first, get the VS dialed in where it needs to be, and *then*
make the permanent plate. Bad idea to slot those bolt holes?
)_( Dan
RV-7 N714D
http://www.rvproject.com
Subject: | Re: BFR and Training in an Experimental |
Your instructor should at least 5 hours in that plane before he
teaches in it. Then its ok. That is what I have found out so far. But
the problem for anyone wanting to do this is finding an instructor who
will use your plane. Also remember your plane has to have the 40 hours
on it before 2 people can go up in it.
Brett
p.s. by the way the 40 is all most on my XL. A couple more nice days
and its done.
I'm guessing you were joking here, but just in case you weren't or in case
someone reading your post misinterprets it, I'll give a stright-up answer.
In a nutshell, you can be confident this isn't happening if everyone involved
in designing and making the parts follows accepted practices. Not certain, but
confident. The aircraft industry has invested a phenomenal amount of effort
into determining how to make, install, maintain, and use parts in such as way
as to minimize problems such as stress corrosion cracking. And, in the case of
parts from Van's, I think it's fairly safe to assume that appropriate practices
have been followed, right up until the parts arrive in your shop in Van's
carefully designed crate. After that, it's up to you.
When I described crack propagation in parts sitting on the shelf I was talking
about something that can and has happened, but I was not suggesting that this
was a risk with parts in your RV kit. I was simply pointing out that your
assertion (that relative movement of the parts was required to propagate
cracks) isn't correct. Cracks produced in the production process (including by
the kit builder) can propagate into failure in many different ways, and it
behooves us to learn to avoid making those cracks as best we can.
Tedd McHenry
Surrey, BC
Local RVrs told me that they had no problem getting their BFR done in a RV8
as long as it was equipped with the rear seat rudder pedals and throttle along
with the obvious control stick. That ended up being the only reason I
bothered with installing the rear seat rudder pedals.
lucky
In a message dated 4/1/2004 12:47:15 AM Eastern Standard Time,
akroguy(at)hotmail.com writes:
>is
>by
>FAR Part 91.
>Mike Robertson
>Das Fed
Mike,
the controls.
get it over with?
Brian Denk
RV8 N94BD
RV10 '51
Subject: | Re: Finish Drill / Deburr Pre-punched holes? |
I
> rivets.
Dean just brought up another point that interests me; so, I'm speaking up
again, after all. :-)
I have the old style deburring tool that has less cutters. I know mine must
have the chatter ripples around them, even though I was very careful to
debur the holes as instructed. With that, I must have weakened every hole I
drilled in my -6A. Does this mean that my RV is going to start falling
apart; or, can I be assured that it's going to be holding together for many
years to come? I'd not ask the question; but, I'm betting nearly every RV
built before the prepunched stuff used an Avery debur tool, or one of the
same quality, and has those ripples. Does this mean that all of
us -3, -4, -6, etc. builders now have that to worry about along with those
guys and gals who are not match drilling? Maybe match drilling is the
least of our worries? I just wonder what Van and company used on their old
blue RV-6A. Hmmm.
Now, do I ground Scooter to keep it from falling apart in flight; or, do I
just ignore this discussion and keep on flying it? I think you know the
answer to that! I'm going to keep on flying it and do my usual condition
inspection each year where I look for cracks, etc., that may be forming. So
far, I've seen nothing like that. It's now in its fifth year of flying.
However, I think I'll add that single flute debur tool to my wish list. I
don't want my new -7A to fall apart in flight, either. :-)
Jim Sears in KY
EAA Tech Counselor
In a message dated 3/31/04 10:18:53 PM US Eastern Standard Time,
sbuc(at)hiwaay.net writes:
> I have a question.
> rivet hole?
> Sam Buchanan
> Sam Buchanan
Right Sam,
I actually came to the same conclusion during the night! These dimpled
rivets have a lot going for them. To really understand what a great joint it is
requires a lot of analysis. I just did a test sample, and carefully drilled it
apart. The hole actually expands to about .106 when you drive the rivet to
specs. Maybe you don't have to get in there (fortunately!) and deburr it
because (I speculate) the driving process compresses the "bad" surface and stress
relieves it anyway. Or maybe the joint under compression holds the "bad" area
from moving and propagating any stress cracks.
Dan Hopper
RV-7A (almost done)
I believe the TMX-360 experimental engines by Mattituck now include the
pressure lines to lubricate these areas. If interested, anyone could
further verify this by contacting Mahon Russell at Mattituck at
Mahlon_Russell(at)teledyne.com
----- Original Message -----
air
you
fills
> Dave Bristol
Subject: | Re: new RV-7 needs left rudder in cruise |
Interesting, left rudder.
What are you using to judge the required rudder? The Dynon? The ball on my
Dynon display I find to not be very accurate.
In any case you thinking is correct. Offsetting the rudder to the left
side causes the aircraft nose to turn right. I have the same 1/4" offset
in my VS and it flies straight. Too much displacement of the VS to the
left would require left rudder to correct.
I wouldn't elongate the bolt holes as a temporary movement. Either rivet
on an aluminum plate to the plate of the VS (flush rivet with head aft)
and then drill new bolt holes slightly offset from the previous holes. Ask
Van's about this one as well. This is only a temporary fix to judge the
new flight attitude.
An easier fix in my opinion is to use the wheelpants to offset the need
for rudder. If the required rudder is small just adjust the angle the gear
leg fairing are installed at. They're easy to change since the attachement
at the top of the gear leg is a simple clamp.
Before starting to tweak anything on your airplane, make sure the
instrument telling you left rudder is reading perfectly.
How the the rudder on take-off and climb? How much right rudder do you
require?
Steve
RV7A
65 hours
> fairings...that
> turning
> tendencies.
> is
> gotta
> holes
> *then*
> )_( Dan
> RV-7 N714D
From: | "Alex Peterson" <alexpeterson(at)earthlink.net> |
> can say that this plane needs 1/2 ball of LEFT rudder in
> cruise. I'm operating without wheel pants and without leg
> fairings. My philosophy is that I want to get the airplane
> fairings...that way I'll know if the fairings are straight
> and are not imparting any turning tendencies.
It might be interesting to know why the ball is showing left now in your
current configuration, but not important. What really matters is what
is needed after you put all the fairings on. Two things will change -
the fairings will perhaps have a yawing affect one way or the other,
and, importantly, the airspeed will be higher. I have mine trimmed,
with a little tab on the rudder like most have, for typical cruise
settings. If I simply put the nose down for a shallow descent without
changing power, something like 10 - 15 knots extra speed, the ball moves
to the left.
Too many potentially offsetting variables to try to chase. I'd recommend
that you put the fairings on. The ball just might be centered, and the
engine will be happier too with the increased cooling air.
Alex Peterson
Maple Grove, MN
RV6-A N66AP 447 hours
http://www.home.earthlink.net/~alexpeterson/
Subject: | Finish Drill / Deburr Pre-punched holes? |
Chattering of cutting tools, such as a deburring tool, is probably due
to the rake angle being wrong. If the actual cutting surface is trying
to "dig in", it will cause the chattering. Opposing flutes of the three
flute cutter then compete with each other, causing the chatter. Get out
your eyepiece, and have a close look. The cutter needs to "scrape"
across the surface, instead of trying to plow itself deeper. A decent
starting point would be to have the forward edges be about 90 degrees to
the direction they are moving. Take a grinder or Dremel to the cutters
to get the angle right.
Alex Peterson
Maple Grove, MN
Actually I would put all the fairings on first then trim as necessary. They
do make a difference!!
>tendencies.
>)_( Dan
>RV-7 N714D
Scott Bilinski
Eng dept 305
Phone (858) 657-2536
Pager (858) 502-5190
Using the fairngs to center the ball causes more drag than a rudder trim tab.
>require?
>Steve
>RV7A
>65 hours
>> fairings...that
>> turning
>> tendencies.
>> is
>> gotta
>> holes
>> *then*
>> )_( Dan
>> RV-7 N714D
Scott Bilinski
Eng dept 305
Charlie, There are # 30 and #40 reamers available that may eliminate some
your concerns.
Dale W. RV-7
Subject: | new RV-7 electrical problem fixed |
Dan C,
I'm waiting for the report on the electrical problem.
Dan H.
RV-7A (almost done)
"'vansairforce'"
When I bought it the log book showed 1576 SMOH and 350 STOH... TT was in
the neighborhood of 4500 hours...
When I took it apart it had 1738 SMOH and 512 STOH...
-Bill
Subject: [rv8list] RE: RV-List: engine woes...
the core?
Charlie Becker
N464CB RV8A(e)
Wings
-Bill VonDane
EAA Tech Counselor
www.vondane.com
www.creativair.com
Subject: | More on Engine... |
vansairforce
Hey all...
I removed the engine from the plane last night and disassembled it... At
least it doesn't look any worse than it did yesterday...
The case and crank look great, to me anyway, but I am going to have it all
looked at my by my engine guru tonight or tomorrow... Hopefully I can get
by with polishing the crank, may have it all balanced at a local shop here
too... New bearings all around, and new cam and tappets... I may have the
case reconditioned too if my A&P deems it necessary... We'll see... It
also looks like I will need a new left mag gear, as the fuel pump drive lobe
on it is pitted pretty bad... Will be checking for any ADs that need to be
done as well...
I have posted a lot more photos on my site:
-Bill VonDane
EAA Tech Counselor
www.vondane.com
www.creativair.com
Subject: | Sensenich Prop 180 HP and spinner for sale |
I have decided to install a constant speed prop so have a new - never
installed Sensenich Prop plus Sensenich spinner for sale.
I bought it from Van's model 72FM8S9-1 (85)
Spinner is from Sensenich
I am looking sell as a unit; total price of $2100 plus shipping: current cost
is around $2375 plus shipping.
Please reply off list to - djb6a(at)cs.com or dave(at)lysine.com
Dave Burnham
RV6A N64FN (res)
Lincolnshire, IL
847-478-0748 home
773-867-0161 work
"'vansairforce'"
The moral to this story, for those still looking for an engine is, don't
buy an engine on it's 3rd or 4th run. By that time, everything that
rotates, slides, or squiggles needs to be replaced.
Can you tell how many hours were on the cam? Was it replaced at the last
OH or just reground?
Bruce
www.glasair.org
Subject: Re: [rv8list] RE: RV-List: engine woes...
in
-Bill
on
the core?
Charlie Becker
N464CB RV8A(e)
Wings
don't
getting
-Bill VonDane
EAA Tech Counselor
www.vondane.com
www.creativair.com
My wife and I will be visiting our daughter in a couple of weeks who is
studying in Canberra Australia. Any Ausi builders in the Sidney or
Canberra? We will be there from Apr 14th thru Apr 22nd.
My daughter says I need to brush up on the slang!!
Jim Muegge
RV-8 Painting
Nebraska, USA
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Keith T Uhls
Subject: RV-List: Land down under
Listers,
Keith Uhls
N7KU
Subject: | Re: new RV-7 electrical problem fixed |
Sorry, been so busy flying this thing! 8-)
I had two problems:
***** Problem #1:
The B&C voltage regulator's low voltage warning circuit was continuously
flashing at me, despite the bus voltage being held at a consistent 14.2
according to the gauge. It appeared that the VR was doing its job. I ran
through B&C's troubleshooting guide, which comes with the VR. Every single
parameter checked out fine.
So I called B&C and told 'em what was happening and they suspected it was a
shorted lamp flasher circuit. Their advice at first was, you're probably
fine, just pull the light out if it's bothering you. Um, no...this is a new
aircraft, I want everything working perfectly. They understood, and told me
to ship the VR back to them and mark it "AOG" (aircraft on ground) to
expedite a repair at their cost.
Meanwhile, I drove over to Spruce and snagged a brand new replacement
regulator, popped it in, fired it up, and everything worked fine. I didn't
change a thing...the low voltage light went out just fine when the
alternator was switched on. So anyway, I'm sending the old one back for
repair, and it'll become my spare when it comes back (or I'll sell it).
***** Problem #2:
The ACS2002 engine monitor screen/CPU died. The symptoms were a brief
period of erroneous readings, and then the screen went black. I spoke to
Rob Hickman, who advised me that there are multiple power supplies (5v, 10v,
etc.) and that one may have burned out...he asked me to check the voltage at
various pins on the analog box. I did that, and everything checked out
perfectly. When the unit was powered on, the screen would go black...you
could see it was doing something...but it wouldn't boot up. Rob suspected
that something burned out in the screen/CPU (I won't even pretend like I
know what anything is in there). So he replaced the screen for me. Rob was
like..."How's the weather down there?" and actually offered to fly the new
screen down that same day (Monday) in his RV-4. Now that's service!!! But
that wasn't necessary...instead he overnighted the new screen to me.
On Tuesday around noon I got the new screen. I installed it, powered it up,
and it came up just fine. Next step was to swap out the clock chip and use
the one from the old unit. The clock chip stores all of your configuration
data (fuel tank calibration, sensor calibrated ranges, logged hobbs/tach
times, etc.). That would have been painful to lose all that. Fortunately,
after swapping the clock chip the thing came right back up with my old
settings. Beautiful!
The cool part is that the ACS2002 actually continued logging data even after
the tish fit the han. I was able to dump it to my PC using Rob's serial PC
software, and in Excel you can see where the funkiness began. Rob is
currently evaluating the data, and I'm shipping the old screen up to him for
a complete dissection. He said this is the first failure he's had.
On Tuesday afternoon, since everything was looking good, I went flying. The
VR and the ACS2002 worked perfectly!!! CHTs were all green (315-330F), oil
temp was a little high (226F), but that's ok for now. I've been using the
ACS2002 to dump data from my flights and graph them. It is too much fun to
go back and look at it after the fact. Trying to remember all the
parameters and trends when flying those first flights is difficult. And
writing everything down when you're busy flying the plane can bee too much.
Nice to be able to click on a graph later to see the parameter values.
http://www.rvproject.com/data/ (warning, those files are pretty big)
Yesterday I made two flights. The first one went perfectly. The second one
I strayed away from the airport and out to the test area ("the box").
Everything was going great until the RPM indication started fluctuating --
upward. It was erratic and displaying as high as 3000 RPM (you can see it
on the graph). I headed straight for home (via the route prescribed by my
op lims).
When I got down I called Rob and he suggested checking the connections at
the RPM sensor that plugs into the mag. I cut off the heat shrink and saw
one wire had broken loose from a fast-on connector. Interesting... So I
crimped on a new connector, and we'll go from there.
I gotta say that despite the big hiccup on the first flight, the ACS2002 is
the coolest thing under the sun. And speaking of sun, it almost seems
*more* readable in direct sunlight. I don't know how that works, but
something cool is happening there to make the colors really stand out.
Support from Advanced Control Systems has been excellent, and it has been a
pleasure dealing with Rob & Ken.
The Dynon is also very sunlight readable. Better than I would have
expected. I'm still building up my trust in it, and I haven't done the
magnetic calibration yet (it desperately needs it). My panel-mounted
compass is all over the place...it's not gonna be a reliable indicator in
that position, but as long as I get the Dynon calibrated accurately then I'm
not worried about it.
The AeroSport engine is running GREAT! CHTs are now down to 290-315, oil
temp has dropped to 195-205, and oil consumption is a little lower than I
would expect for a break-in. Maybe 1/2 quart during these 3.6 hours. Other
than the characteristic "RV popping" on base & final when the throttle is
pulled back (I'm still running full rich, too), it has run strong and
smooth. The Airflow Performance system with the purge valve has made
startup a non-event. The engine is tight, no leaks. I have a tiny leak at
the prop governor...I need to check the nuts to make sure they're tight, and
possibly replace the gasket. That's it!
This is just great fun. The challenges obviously change when you start
flying, and as far as I can tell it's gonna still be a project for a while!
)_( Dan
RV-7 N714D
Subject: RV-List: new RV-7 electrical problem fixed
> Dan C,
> Dan H.
> RV-7A (almost done)
I have not had any problems getting a BFR in my RV-4. I have rear seat
rudder peddles and no throttle.
I currently have about 300 hours in the plane and I even have a local
instructor volunteer to do a BFR for FREE if I would just take him for a ride in
it.
Rob Hickman
RV-4 N401RH
RV-10 N402RH; S/N: 40204 (Vertical Stab Done!)
Subject: | Overhaul Videos... |
vansairforce
Anyone have the Lycoming engine overhaul videos I could borrow?
-Bill VonDane
EAA Tech Counselor
RV-8A ~ N8WV ~ Colorado Springs
www.vondane.com
www.creativair.com
www.epanelbuilder.com
Subject: | Re: engine woes... |
As Tracy Crook was saying:
> (1360 hours of Hmmmm,
So descriptive. :>
-Kysh
| 'Life begins at 120kias' - http://www.lapdragon.org/flying |
| CBR-F4 streetbike - http://www.lapdragon.org/cbr |
| 1968 Mustang fastback - http://www.lapdragon.org/mustang |
| Got 'nix? - http://www.infrastructure.org/ |
| KG6FOB - http://www.lapdragon.org/ham |
| Give blood: Play Hockey! http://www.unixdragon.com/ |
Subject: | Training in Experimental |
You can do any trainig in an experimental. Provided it has the
equipment/capabilities/specifications necessary for the endorsement/license.
I chose not to do primary training in my RV because for $50/hr, I preferred
to learn how to land in someone elses plane.
I do my BFR's in my RV. Until I got the Dynon, the instrument part of it
was quite challenging. Great fun though. ASI, Altimeter, ROC indicator
and GPS HSI.
One big concern if I wanted to do primary in my RV would be to confirm I was
indemnified by the insurance company. On your BFR, you are PIC, so if you
were insured, you are insured. For primary training you'll need to run your
instructor by and have him added to your insurance.
If Sky Smith is reading this, any wisdom on this topic?
Don
Can anyone recommend an equivalent product to "UHMW tape" called for in the plans
to use on the Canopy Latch handle? (The only place I can find it is at VANs
and that takes a week to get...)
Ben Cunningham
RV7 finish kit
http://www.mcmaster.com/
Type in UHMW tape.
>plans to use on the Canopy Latch handle? (The only place I can find it is at
>VANs and that takes a week to get...)
>Ben Cunningham
>RV7 finish kit
Scott Bilinski
Eng dept 305
McMaster sells it, too. http://www.mcmaster.com They sell different
thicknesses and all that.
)_( Dan
Subject: RV-List: UHMW tape
the plans to use on the Canopy Latch handle? (The only place I can find it
is at VANs and that takes a week to get...)
> Ben Cunningham
> RV7 finish kit
> Wouldn't it be nice to be able to go back to the early 1940s
> when swarms of hurriedly trained employees were turning out
> thousands of C-47s/DC-3s at prodigious wartime production
> rates and see what drilling/deburring tools and techniques
> those folks were using? I have trouble believing that every
> C-47 rivet hole was carefully drilled and deburred with just
> the right 6-fluted tool, etc. Yet many of these airplanes are
> still flying around 60 years later with 30,000 (+) flying
> hours on them.
Interesting that you mentioned DC3's. My dad told me that in the 50's
and 60's, when he would occasionally fly DC3's, he would notice stop
drilled cracks everywhere on those planes. And those planes are much
older now...
It is all about probability. Cracks will occur on all airplanes, the
question is how often and how soon. Proper techniques won't eliminate
them, just reduce the number and/or delay their onset.
Alex Peterson
Maple Grove, MN
> I received my original RV-3 checkout for insurance purposes
> in an RV-6 with the CFI who built it. A really neat situation
> for us within reach of Jefferson City, MO. Ditto for BFR's
I got a checkout from the same guy. I've since heard that
he's no longer instructing in his own RV. I have this nagging
feeling the two might be related.
Dave Hyde
RV-4 in flight test
nauga(at)brick.net
From: | "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net> |
> Ben Cunningham
> RV7 finish kit
Get hold of Stien Burch on this website and you can have it in about a couple of
days at about half the cost of Vans...
Phil.....
I believe the grease your talking about is used mainly on transistors
for heat transfer to the heat sink it's attached to. Usually it is used in
conjunction with some sort of dielectric between the transistor and the heat
sink for electrical isolation.
Wayne
it
> archives.
> Randy Lervold
> RV-8, RV-3B
Dan,
Don't forget that the power setting changes the amount of rudder that's
needed so when you do get it trimmed, that setting will only be good for
one particular power setting. That's why some airplanes have adjustable
rudder trim.
Dave
>tendencies.
>)_( Dan
>RV-7 N714D
Subject: Re: RV-List: BFR and Training in an Experimental
I'm not sure where the 5 hour requirement came from.
I just got a BFR in my Velocity from a CFI who had never flown in a canard, let
alone a Velocity. I taught him about Velocities while he gave me a very thorough
BFR, including reading sectionals, airspace rules, runway incursion (from
AOPA), stalls, instrument flight, a practice instrument approach, emergency engine
out, recovery from unusual attitudes, etc. He thoroughly enjoyed the Velocity
and I got a great BFR.
I have a friend who is getting his instrument rating instruction in his Europa
from his CFII. There are some DE's who will give the check ride in a homebuilt.
I think it is mostly a matter of the individual CFI/CFII and what he/she is willing
or unwilling to do. (Some folks still don't think homebuilts are safe!!!)
I'm amazed that the CFI building a RV8 refused to give a BFR to a fellow RV'er????
Keep looking.
Ronnie Brown
Velocity 173 Elite RG
Dan,
A local "4-peater" (RV6, RV6A, RV8A, RV7A) recently discovered that he
needed a little left rudder as well. His philosophy is "put a rivet in every
hole and the airplane is gonna be a straight as you need to worry about". So
he did NOT make any changes other than taking the "rudder trim" from EPM.AV
( http://www.epm-avcorp.com/ ) that I had bought, sticking it on and
flying. He says it flies straight now at cruise configuration (all fairings
installed).
You may in fact introduce a LOT more errors by changing the offset,
especially BEFORE all the fairings are on and locked down.
Just an opinion.
James
It is really up to the instructor. Most instructors, if they don't know you
well, will want full controls at their access just in case. During a BFR
they are, technically, the PIC if an accident should happen. It really
comes down to the question of whether or not a BFR is a check or
instructional. If you go with the instructional mode then the regs say that
the CFI must have full access to the controls at all times.
Mike R.
>From: "Brian Denk" <akroguy(at)hotmail.com>
>Subject: RE: RV-List: BFR and Training in an Experimental
>Date: Thu, 01 Apr 2004 05:40:49 +0000
> >is
>not
>is
> >by
> >FAR Part 91.
> >Mike Robertson
> >Das Fed
>Mike,
>local
>the controls.
>ground,
>get it over with?
>Brian Denk
>RV8 N94BD
>RV10 '51
Too many experts and not enough pragmatism.
Tedd McHenry kindly posted the links for the mil rivet specs. There's a problem
here not addressed by those who feel Van's recommendations are akin to a quick
spritz with holy water. Follow directions and you will NOT meet these specs.
Charlie England's post echoes my own experiences. Match drill, deburr and
dimple and your hole will be oversize on the thinner skins by as much as twice
the allowed tolerance.
You can't buy #41 dimple dies and everyone has done it this way for years so it
works. If you match drill with a #41 instead of a #40 it works better, i.e.
the hole is tighter, you need less swell from the rivet and the recommended rivet
size is more likely to work. I'm sure the theoreticians out there won't like
this suggestions much, however no one at EAA, AOPA and the guys at Vans considered
it a bad idea, when I discussed it with them.
Paul Parashak is concerned about "one of the surest ways to accelerate metal failures
left in are prime areas for crack propagation." I cannot believe that he has
ever examined the holes which the average builder drills and deburrs. Look
at one with a magnifying glass. They are ugly to varying degrees but definitely
ugly. Cy Galley has a good grasp of the reality of drilling and deburring.
"If you are getting so anal about drilling, I would propose that you use a
chucking reamer instead of a drill. At least that way you will get a round smooth
hole. You don't get smooth or round with a drill bit."
If irregularities around the hole are significant, many riveted aluminium monocoque
planes would not have remained flying for as long, (or longer), than many
of us have been alive . He also makes the very pertinent observation that presumably
all the lightening holes are punched by Van's. I haven't heard any suggestions
from Van's or our list experts regarding the necessity of enlarging
these to remove the work hardened edge and the attendant stress risers.
Vans has not totally dismissed the idea of dimpling the punched hole without match
drilling. Charlie England's discussion with Van "I asked Van, his own self,
face to face, in person, at OSH last summer when they were going to go ahead
&punch the holes 'full size' &save us all some build time. His answer (his *only*
answer) was that there was enough variation in drilling patterns that they
preferred to continue the match drilling thing for now."
I also had asked Van's about the rumour I'd heard that they had experimented with
this by building a wing or wings without drilling and was told it was true
but too early to make any comments. I didn't think to ask them what plane they
were for or if they would fly them. I'll ask Ken K. next time I see him.
Van is most certainly not reluctant to tackle issues he considers dangerous for
example his stand on not using engines larger than the O 320 in a 9. He is also
notoriously conservative and yet he has not made any attempt to take on this
topic in a similar forthright fashion. This is surprising if, as our theorists
believe, this is a serious problem in practice. I wonder why.
There are many discrepancies between our practice and theory - hole condition,
size etc. and it would seem that little is known about dimpling and riveting punched
holes in practice. I have read nothing about actual stress cracks seen
in aircraft riveted together without match drilling. There is a lot of theory
flying around and virtually no practical examples. We are very unlikely to
get much information either, when we pillory the pioneers. The list punishes
non conformists and unfortunately some listers become nasty about opinions that
conflict with their own. This is NOT conducive to getting useful practical
information.
Let's be conservative or daring(reckless?) as we choose but let's learn something
from this. It's just barely possible that the theorists are overestimating
the dangers and that our pioneers can contribute something valuable. Make your
own decision on what you can sift from the differing opinions and contradictory
fact and build accordingly. It's just barely possible the pioneers are correct
and that this is an issue the majority are being overly anal about. If
so building our next project may get even easier.
March 27, 2004 - April 01, 2004
RV-Archive.digest.vol-pc
