RV-Archive.digest.vol-pt
September 07, 2004 - September 17, 2004
      > of the info. It would have weighed on me heavy if something terrible
      > happened to a friend where my silence could have been a contributing
      > factor. We should be able to look at my data points and others, without
      > respect to emotion, and make decisions moving forward. Increased
      > awareness is a good thing.
      > Regards,
      > Mike Stewart
      > -----Original Message-----
      > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of N13eer(at)aol.com
      > Subject: Re: RV-List: Dynon D-10 errors
      > Mike,
      > It is not clear from your description if the pitch error was a single
      > event or an oscillation.  A couple months back I was doing some hood
      > time with a CFI in the back seat of my -8.  After leveling off after a
      > long descent (If I remember it was from 8500 down to 2500)  My Dynon
      > started pitching up and down.  It didn't just pitch up 20 deg and stay
      > there.  It was about 20 deg each way.  Since the airspeed and alt were
      > stable I just watched it, it was a little unnerving.  It damped out
      > after about 5 cycles.  At the time Dynon said they had seen an issue in
      > roll at about 1900 rpm that they could duplicate but had not seen or
      > been told of other pitch issues.  I tried to duplicate the issue but to
      > date I have not been able to.  Doug at Dynon was very interested and
      > wanted any info on being able to recreate it.
      > Alan Kritzman
      > To summarize, myself and others, have been getting errors on the horizon
      > function of the Dynon EFIS. In one case it really scared me and as a
      > result I have grounded me 6A from any IFR work. Most of the errors are a
      > lean in the roll axis by as much as 7-10 degrees. Pitch errors in my
      > case have been as much as 20 degrees. Here is a brief synopsis of what
      > and how it is happening based on some e-mail to Dynon:
Subject: Re: Brake Fluid
Date: Sep 07, 2004
ATF should be compatible with 5606 seals. Note, I said should, but I have pretty high confidence on that. Further, ATF should be compatible with 5606 if they were mixed but I have not tried that. Does anyone know what the seals in Cleveland brakes are made of?? Buna-N ATF should work as a brake fluid at any temp that we would fly an RV. ATF's typically have Pour Points in the -50F range. Having said all that, why? a well maintained brake system needs little service, a gallon of 5606 is about $15 and will last a lifetime. ATF's have all sorts of things that you do not need in your brake system, Viscosity Index improvers, friction modifiers, anti-oxidants (that only work at high temperatures) detergents (that only work at high temperatures) anti-wear agents,( that only work under high loads). Many small cheap hydraulic systems use ATF as a hydraulic fluid, because it has very low viscometrics and excellent low temp properties. That is the only reason. You may say that ATF is easier to find than 5606, but your airplane is at the airport and you can find 5606 at any airport, ATF will be more difficult. I would vote for 5606. Tailwinds, Doug Rozendaal ________________________________________________________________________________
Date: Sep 07, 2004
If cheap is the issue a gallon of 5606 at $13.95 will supply just about every airplane on the airport. Or if you are really cheap get a quart for $3.95. Or if you are really, really cheap and don't want to share with your building buddies a pint at $2.20 is enough to do the brakes on an RV. Readily available from ACS and other aircraft parts suppliers. In my experience brake fires happen when plastic brake lines are used and the heat generated by a hard brake application melts them. The latest versions of the RV don't use plastic brake lines so that should not be a problem. Agreed if you spill it and let it dry it can be a mess. Just clean it up when you spill it. By the time you figure out the proper seals to use, disassemble and reassemble the components why not just use the recommended brake fluid. This is what I recommend to new builders and I'm sticking to it. Cash Copeland A&P RV-6 Hayward, Ca In a message dated 9/7/2004 12:40:03 PM Pacific Standard Time, cgalley(at)qcbc.org writes: Auto transmission fluid has several pluses. Cheap, readily available, works well, doesn't absorb moisture, doesn't dry to a sticky mess, doesn't catch fire at as low a temperature as 5606. BUT you have to use compatible seals. Cy Galley - Chair, Emergency Aircraft Repair Safety Programs Editor - TC EAA Sport Pilot ________________________________________________________________________________
Date: Sep 07, 2004
I don't plan to move away from what is suggested by the brake components manufacturer as yet. However if I was going to look for an alternative I think I would go with DOT 5 synthetic. It costs more but my guess is that it would perform well without the unknowns (additives) etc. that non spec. products contain. I'm not sure but I suspect that DOT 5 would operate without the need to change out seals etc. Does anyone feel a strong impulse to offer up an opinion or even some data or an in the field experience report on DOT 5 synthetic? {[;-) Jim in Kelowna ----- Original Message ----- From: <JusCash(at)aol.com> Subject: Re: RV-List: Brake Fluid > > If cheap is the issue a gallon of 5606 at $13.95 will supply just about > every > airplane on the airport. Or if you are really cheap get a quart for > $3.95. > Or if you are really, really cheap and don't want to share with your > building > buddies a pint at $2.20 is enough to do the brakes on an RV. Readily > available > from ACS and other aircraft parts suppliers. > > In my experience brake fires happen when plastic brake lines are used and > the > heat generated by a hard brake application melts them. The latest > versions > of the RV don't use plastic brake lines so that should not be a problem. > Agreed if you spill it and let it dry it can be a mess. Just clean it up > when you > spill it. > > By the time you figure out the proper seals to use, disassemble and > reassemble the components why not just use the recommended brake fluid. > > This is what I recommend to new builders and I'm sticking to it. > > Cash Copeland A&P > RV-6 > Hayward, Ca ________________________________________________________________________________
Subject: Re : Brake Fluid
Date: Sep 08, 2004
I too had a similar query to Neil regarding using ATF in my RV's brakes. My previous aircraft had Cleveland copies, and the manufacturer recommended using ATF, which I happily did for 10 years without a problem. Certainly cost is not an issue and neither is availability, but flammability is. MIL-H5606 is a mineral oil-based hydraulic fluid that has been in use since the 1940's with an operating range of - 54C to 135C, but its high degree if flammability has long been recognised by the military. As a result, commercial aircraft moved to phosphate ester-based hydraulic fluids (eg Skydrol) and found a reduction in hydraulic fluid fires. A direct replacement for 5606 that is more fire resistant was developed, called MIL-H 83282, and is a synthetic hydro-carbon based fluid that is compatible with 5606 and 5606 based system materials. It has an operating range of - 40C to 205C When I went searching for MIL-H 83282 I could not buy it anything smaller than 20 litres ( 4 US Gals) so that idea went out the window. In the end I went with the garden-variety 5606 thought I felt I could have just as easily used ATF. Other than flammability, the main issue is seal compatibility. You would need to test seal compatability if you used DOT 5 synthetic fluid, and I would have a preference for DOT 5.1 which I believe is non-synthetic. Hope this helps Martin in Oz RV-6 ________________________________________________________________________________
Date: Sep 08, 2004
Date: Sep 07, 2004
I have been running synthetic ATF in my brake lines for four years and never have had ANY problems. While I was at wal-mart with the family unit picking up a giant sized pack of toilet paper and some other stuff I strolled over over to the aviation supply aisle and picked up a quart of Mobil1 Synthetic ATF for the rocket and gave a whopping $2.60 for it. No hazardous material shipping charges, no shipping charges, etc. Aeroshell lists the flash point of fluid 4 (5606) at 110 deg. C, the newer fire-resistant replacement for 5606 is aeroshell 31, flash point of 220 deg. C. Mobil1 synthetic ATF flash point: 220 deg. In fact when you compare the specs between Mobil1 and fluid 31 they're nearly identical. I will venture to say that they're (choke, gasp) the same dang thing. In a nutshell, there are two types of o-rings and seals: those that work with oil and those that work with water. Automotive brake fluid is hydroscopic (absorbs water) therefore automotive brake systems use o-rings that work with water. Big no-no with seals that work only with oil (like in aircraft brake systems). There's no good reason to say that a fluid that has been around for 50+ years is any better than a modern fluid, espicially if it has a flashpoint that is half of its modern counterpart. For some reason the good people in the aviation community refuse to think outside the box, if its cheap it can't be good, if it isn't mil-spec it can't be good, if it isn't complex it can't be good, etc. For the matter I know quite a few guys running plastic brake lines also, one RV-4 with 1500+ hours on plastic brake lines and ATF and has never had any problems. The others went to plastic after several breaks with the aluminum lines. Regards, Bob Japundza RV-6 flying, F1 under const. Indy > > If cheap is the issue a gallon of 5606 at $13.95 will supply just about every > airplane on the airport. Or if you are really cheap get a quart for $3.95. > Or if you are really, really cheap and don't want to share with your building > buddies a pint at $2.20 is enough to do the brakes on an RV. Readily available > from ACS and other aircraft parts suppliers. > > In my experience brake fires happen when plastic brake lines are used and the > heat generated by a hard brake application melts them. The latest versions > of the RV don't use plastic brake lines so that should not be a problem. > Agreed if you spill it and let it dry it can be a mess. Just clean it up when you > spill it. > > By the time you figure out the proper seals to use, disassemble and > reassemble the components why not just use the recommended brake fluid. > > This is what I recommend to new builders and I'm sticking to it. > > Cash Copeland A&P > RV-6 > Hayward, Ca > > In a message dated 9/7/2004 12:40:03 PM Pacific Standard Time, > cgalley(at)qcbc.org writes: > > Auto transmission fluid has several pluses. Cheap, readily available, works > well, doesn't absorb moisture, doesn't dry to a sticky mess, doesn't catch > fire at as low a temperature as 5606. > > BUT you have to use compatible seals. > > Cy Galley - Chair, Emergency Aircraft Repair > Safety Programs Editor - TC > EAA Sport Pilot > > > > > > ________________________________________________________________________________
Subject: Re: K1100-06 nutplate installation on e-616
Date: Sep 07, 2004
Mike Why not simply dimple the rivet holes in the nutplates and the doubler? Charlie Kuss > > From: Mike Draper <mdraper(at)nww.com> > Date: 2004/09/06 Mon PM 03:09:02 EDT > To: "'rv-list(at)matronics.com'" > Subject: RV-List: K1100-06 nutplate installation on e-616 > > ________________________________________________________________________________
Date: Sep 07, 2004
Subject: Re: > Re: Brake Fluid
Better be careful using any DOT fluids. Automotive brake fluid (Glycerine based) is NOT compatible with aircraft brake systems. You will wind up with a gooey mess which is hard to clean out of the brake system. A friend did this. Lest someone goes to buy auto brake fluid. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Sep 07, 2004
From: "thomas a. sargent" <sarg314(at)earthlink.net>
Subject: Re: how to feed the battery cable through the firewall??
I would be a little suspicious about the thru-bolt type of pass-thru. The insulating material seems to be (from the pictures, anyway) a plastic of some sort. I would think a fire would ruin that in seconds. Do they make these things with a ceramic insulator? -- Tom Sargent, RV-6A, Landing gear ________________________________________________________________________________
Date: Sep 07, 2004
I was told by Dave Ronnenberg that he didn't want Dot 5 in his building let alone in his airplane. Dot 5 is silicone based and makes it very difficult to paint a surface that is contaminated with Dot 5 and epoxy repairs were also impaired. I know he recommends tray fluid but brake fluid is your decision. The very worse fluid is ordinary auto brake fluid as it is not compatible with aircraft seals. It also absorbs moisture which will corrode brake parts. However some old bladder brakes do require the use of automotive. Cy Galley - Chair, Emergency Aircraft Repair Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: "Jim Jewell" <jjewell(at)telus.net> Subject: Re: RV-List: Brake Fluid > > I don't plan to move away from what is suggested by the brake components > manufacturer as yet. > > However if I was going to look for an alternative I think I would go with > DOT 5 synthetic. It costs more but my guess is that it would perform well > without the unknowns (additives) etc. that non spec. products contain. > I'm not sure but I suspect that DOT 5 would operate without the need to > change out seals etc. > Does anyone feel a strong impulse to offer up an opinion or even some data > or an in the field experience report on DOT 5 synthetic? {[;-) > > Jim in Kelowna > > ----- Original Message ----- > From: <JusCash(at)aol.com> > To: > Subject: Re: RV-List: Brake Fluid > > > > > > If cheap is the issue a gallon of 5606 at $13.95 will supply just about > > every > > airplane on the airport. Or if you are really cheap get a quart for > > $3.95. > > Or if you are really, really cheap and don't want to share with your > > building > > buddies a pint at $2.20 is enough to do the brakes on an RV. Readily > > available > > from ACS and other aircraft parts suppliers. > > > > In my experience brake fires happen when plastic brake lines are used and > > the > > heat generated by a hard brake application melts them. The latest > > versions > > of the RV don't use plastic brake lines so that should not be a problem. > > Agreed if you spill it and let it dry it can be a mess. Just clean it up > > when you > > spill it. > > > > By the time you figure out the proper seals to use, disassemble and > > reassemble the components why not just use the recommended brake fluid. > > > > This is what I recommend to new builders and I'm sticking to it. > > > > Cash Copeland A&P > > RV-6 > > Hayward, Ca > > ________________________________________________________________________________
Date: Sep 08, 2004
In a message dated 9/7/04 1:16:33 AM Pacific Daylight Time, neil.mo51(at)btopenworld.com writes: << About a year ago there was a thread discussing brake fluids and the use of automatic transmission oil as being a suitable substitution. >> I'm curious. Is there some reason you don't want to use aircraft brake fluid? Harry Crosby Pleasanton, California RV-6, final details ________________________________________________________________________________
From: "Dean Psiropoulos" <deanpsir(at)easystreet.com>
Subject: Landing gear intersection fairings.
Date: Sep 08, 2004
Anyone know where I can get pre-made landing gear intersection fairings for my -6A. I checked the archives and "Fairings-etc." popped up. I was able to locate the website and these look like good pieces but does anyone ELSE sell something similar? Just wondering if there's more than one vendor out there now. Thanks. Dean Psiropoulos RV-6A N197DM Survived Hurricanes Charley and Frances, wondering if Ivan will be strike 3 and I'm out, jeeeezzz is it ever gonna stop? ________________________________________________________________________________
Date: Sep 08, 2004
In a message dated 9/7/2004 7:19:41 PM Pacific Daylight Time, japundza(at)gmail.com writes: Automotive brake fluid is hydroscopic (absorbs water) therefore automotive brake systems use o-rings that work with water. =================================== Bob- Actually hygroscopic is the correct term. GV (RV-6A N1GV O-360-A1A C/S, flying 719 hrs) ________________________________________________________________________________
Subject: Why such short rivets?
Date: Sep 08, 2004
From: "ed \240" <ed_88@hotmai... Hello listers, I've recently started building the emp kit for my rv-8a, and I've run into my first question that I cant seem to find discussed in the archives. According to the plans HS609PP is supposed to be riveted to HS603PP using AN470AD4-6 rivets. But when I did a test fitting the rivet looked too short. I got out the avery gauge, and indeed it looks about 1/8" shorter than the gauge says it should be. So of course I went back to the plans, and they said the rivet size was correct. (I guess I am not the first person to wonder this.) I re-read the section in the preview plans which talks about riveting, and they mentioned the plans sometimes called for rivets that seemed too short, but they thought should work. Unfortuately this leaves me with a couple of questions: 1) How far should these "short" rivets be squeezed? Should I squeeze to the same 1/2 the radius rule as normal? Or should I squeeze farther to get more of a shop head on the rivet? 2) Why do they do this? Does using shorter rivets save weight over the course of the entire airplane? 3) Why do the plans say never to use a vibrating pencil to mark parts, then say it is ok on the rear spar of the horiz. stab? How can I tell when it is ok and when its not ok. (Ok that one has nothing to do with riveting, but I thought I would ask anyway.) Once again, the people on this list are a huge resource, I don't know who the early builders managed without it. --Eddie http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Subject: Re: Landing gear intersection fairings.
Date: Sep 08, 2004
http://www.teamrocketaircraft.com is another one to try. I just called today and was told that the intersection fairings they sell are about 3/4" longer in chord than the way Van's stock leg fairings come out. He said that the Team Rocket intersection fairings will only work with Team Rocket leg fairings, otherwise they'll require some surgery to make 'em fit. I'm just repeating what I was told...can't vouch either way. I ordered my uppers from Bob S. at Fairings, etc. They're very high quality but weren't a perfect fit. It ended up being fine with a little fiberglass/flox surgery. I ordered my lowers from him earlier today...we'll see how well they fit. )_( Dan RV-7 N714D (208 hours) http://www.rvproject.com ----- Original Message ----- From: "Dean Psiropoulos" <deanpsir(at)easystreet.com> Subject: RV-List: Landing gear intersection fairings. > > Anyone know where I can get pre-made landing gear intersection fairings for > my -6A. I checked the archives and "Fairings-etc." popped up. I was able to > locate the website and these look like good pieces but does anyone ELSE sell > something similar? Just wondering if there's more than one vendor out there > now. Thanks. > > > Dean Psiropoulos > > RV-6A N197DM > > Survived Hurricanes Charley and Frances, wondering if Ivan will be strike 3 > and I'm out, jeeeezzz is it ever gonna stop? > > ________________________________________________________________________________
Date: Sep 08, 2004
Subject: Re: Why such short rivets?
> 1) How far should these "short" rivets be squeezed? Should I squeeze to >the same 1/2 the radius rule as normal? Or should I squeeze farther to get >more of a shop head on the rivet? > On my 6 plans, I came across numerous places where the called-for rivet (and sometimes bolt) sizes were a size off. If in doubt, use the correct size rivet as indicated by your handy rivet gauge. If a rivet is so short that you have to ask the above question, than it is too short. Too short a rivet and there will not be enough material there to make a proper sized shop head. Too long and the rivet is much more likely to hobnail over on you. When debating between two sizes, I usually go with the smaller size for this reason. A correct length rivet leaves more than plenty of material, in other words a good margin for error. On the subject of shop heads, make sure you get and read the Milspec on riveting: http://home.flash.net/~gila/rivet_spec/rivet_a.htm In particular, the specifics on edge distance and shop head size. The rules of thumb (1 1/2X diameter etc.) are handy, but you'll see that the actual allowables go a little less than that. That little bit less can often be the difference between moving forward with the project, and throwing out a perfectly good piece and starting over because your edge distance was a few thousandths under 1 1/2X, but still well within the Milspec, for example. After you get enough experience (like when you've smashed all 17 gazzilion rivets in the plane) you'll be able to eyeball them and tell if they are long enough or too long, but for now use the gauge. I found by the end that I wasn't even looking at the rivet callouts, just eyeballing the thickness of the materials, grabbing the right size rivet and smashing away. Jeff Point RV-6 Milwaukee WI > > > ________________________________________________________________________________
Date: Sep 08, 2004
Eddie I am also on empennage for RV-7A and noticed same problem, squeezed them down to close to shop size (using Avery gauge) and they seem fine. You will find a couple of other areas where a rivet size is called out that either does not seem correct (on front spar they call out -7 which are too long) or the size specified is not included in the kit (-5) I ended up using the rivet cutter to get rivets the correct length. I have noted a couple of other areas where the instructions left a little to be desired on my weblog.On the marking issue I use permanent marker which shows through the mar-hyde primer. Dave RV-7A Empennage http://home.earthlink.net/~2004nospam/default.htm -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of ed Subject: RV-List: Why such short rivets? Hello listers, I've recently started building the emp kit for my rv-8a, and I've run into my first question that I cant seem to find discussed in the archives. According to the plans HS609PP is supposed to be riveted to HS603PP using AN470AD4-6 rivets. But when I did a test fitting the rivet looked too short. I got out the avery gauge, and indeed it looks about 1/8" shorter than the gauge says it should be. So of course I went back to the plans, and they said the rivet size was correct. (I guess I am not the first person to wonder this.) I re-read the section in the preview plans which talks about riveting, and they mentioned the plans sometimes called for rivets that seemed too short, but they thought should work. Unfortuately this leaves me with a couple of questions: 1) How far should these "short" rivets be squeezed? Should I squeeze to the same 1/2 the radius rule as normal? Or should I squeeze farther to get more of a shop head on the rivet? 2) Why do they do this? Does using shorter rivets save weight over the course of the entire airplane? 3) Why do the plans say never to use a vibrating pencil to mark parts, then say it is ok on the rear spar of the horiz. stab? How can I tell when it is ok and when its not ok. (Ok that one has nothing to do with riveting, but I thought I would ask anyway.) Once again, the people on this list are a huge resource, I don't know who the early builders managed without it. --Eddie http://search.msn.click-url.com/go/onm00200636ave/direct/01/ = direct advertising on the Matronics Forums. = = = ________________________________________________________________________________
Subject: Old-style RV8 Wing tips wanted
Date: Sep 08, 2004
I'm looking for a pair of the old-style, original, wing tips for an RV8. If anyone has a set they would like to sell, please contact me off list. -Don RV8 NJ Don Kugler donkugler(at)earthlink.net 908-303-6578 ________________________________________________________________________________
Subject: Re: K1100-06 nutplate installation on e-616 - Problem Solved
Date: Sep 08, 2004
I finally figured it out last night after I saw a picture on the net with different looking nutplates. Having never installed a nutplate I assumed that the nutplates I received were the correct ones. Wrong! Vans inadvertently sent me K1000-06s which are non dimpled nutplates. There was no way for the nutplate to receive a dimple from the reinforcement plate and the reinforcement plate is too thin to countersink. The nutplates they sent me would only work with pan head screws. It all makes sense now. Get Vans to send me the correct nutplates, dimple the reinforcement plate, use NAS rivets to attach. -Mike Draper RV-8 QB Message I finally figured it out last night after I saw a picture on the net with different looking nutplates. Having never installed a nutplate I assumed that the nutplates I received were the correct ones. Wrong! Vans inadvertently sent me K1000-06s which are non dimpled nutplates. There was no way for the nutplate to receive a dimple from the reinforcement plate and the reinforcement plate is too thin to countersink. The nutplates they sent me would only work with pan head screws. It all makes sense now.GetVans to send me the correct nutplates,dimple the reinforcement plate, use NAS rivets to attach. -Mike Draper RV-8 QB ________________________________________________________________________________
Subject: Re: Dynon D-10 errors
Date: Sep 08, 2004
There is indeed a vibration problem that will affect the Pitch and Roll functions of the Dynon. I saw it with my own two eyes in a Rotax 912 powered Europa. The owner has been receiving IFR training and he began noticing an pitch oscillation while in descent. It would begin oscillating about 5 degrees with a fairly high frequency, then would oscillate at 10-15 degrees at a slower frequency. He finally figured out that it was indeed engine RPM related and can adjust the RPM to cause the small oscillation or the wide oscillation and even can cause the horizon to show a complete dive (all brown). He is updating the software - Dynon has provided him with an update which has a different sampling rate and is supposed to fix the problem. The software has been loaded but we are in the midst of the remains of Frances here in NC. He should be able to fly later this week and see if he has a fix. ________________________________________________________________________________
Date: Sep 08, 2004
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Re: Austin's "Mirror"
Send me a copy! Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Sep 08, 2004
In a message dated 9/8/04 12:00:12 AM US Eastern Standard Time, deanpsir(at)easystreet.com writes: > > > Anyone know where I can get pre-made landing gear intersection fairings for > my -6A. I checked the archives and "Fairings-etc." popped up. I was able to > locate the website and these look like good pieces but does anyone ELSE sell > something similar? Just wondering if there's more than one vendor out there > now. Thanks. > > > Dean Psiropoulos > > RV-6A N197DM > Dean, When I returned to my plane at OSH, there was a card from John A. Violette president of Aero Composites, Inc. on my plane. He is in Kensington, CT. Phone 860 829 6809. Website: aerocomposites.com. I haven't seen his work. Think I'll make my own. The lower intersection fairings went pretty well, but I've been having too much fun flying to get the upper ones done yet! Dan Hopper RV-7A (flying about 41 hours) ________________________________________________________________________________
Subject: RV6a kit for sale
Date: Sep 08, 2004
I have an old, 'slow build' (not pre-punched) RV6a kit I would like to sell. Progress is; empenage, 90%, wing, 25%, fuselage, not started. I do not have a finishing kit, engine, or avionics. I have had it for several years but have done nothing on it for the last couple of years. I am asking $6,500 for the kit. Contact me email jcveld(at)mac.com or phone 269 267-2509 I am in Kalamazoo, MI ________________________________________________________________________________
"Rocket List" , "SoCal RV List"
Subject: Fw: Pt Mugu Air Show and SoCAL RVs
Date: Sep 08, 2004
Sounds like things are back on. PLEASE GET BACK WITH ME AS SOON AS POSSIBLE. After I got them to change their minds, at least we can do is show up. WHO IS GOING TO FLY TO THE PT. MUGU AIR SHOW? Which day or days.? GummiBear ----- Original Message ----- From: Boggs, William A LCDR Subject: RE: Pt Mugu Air Show and SoCAL RVs Mr. Gummo, We put our heads together this morning, and out of the pile of rocks we have come up with a proposal. While the Pt. Mugu Air Show is a "military" show, it is also a "community event." We want to be as inclusive as possible, within limits. Having said all that, we can dig up some extra bodies to make a hole in the fence Sat. & Sun. morning and evening to allow you and your group to get in and out. The arrival window would be 0645-0730, and the departure time would be after 1730. Is this doable? V/r, LCDR Bill Boggs NBVC Point Mugu Air Operations Officer Comm: (805) 989-7041 DSN: 351-7041 -----Original Message----- From: Tom Gummo [mailto:T.gummo(at)verizon.net] Subject: Re: Pt Mugu Air Show and SoCAL RVs Sir, I understand your problem and don't see a way around it. I live in Apple Valley and the other SoCal RVators are from all over the southern California area. If we fly our planes in Thursday or Friday, what am we going to do for those four days (Thursday, Friday, Saturday, and Sunday). We have no place to stay and pick me up and then do it again on Monday to get the plane. Of course not at a military field, we have flown in before the gates open and leave after the show closes or near the end. Our planes only weigh about 1000 pounds and are very easily pushed passed the prop line (crowd control line) but we would need a gate if there is a fence. I would like to thank you for your efforts at the last minute to try to make this work out. I would be glad to try again next time to make this work. Hopefully, if I can get involved early in the planning process, I would be able to clear up our needs with your requirements. There are many other issues that would need to be worked out to have the planes RON for the weekend. Also, let me take a minute to thank you and all the Pt. Mugu folks for your service to our country. My time in the barrel has passed but I see that it is in very good hands. Hand salute. Tom "GummiBear" Gummo Wild Weasel #1753 F-4G Instructor Pilot Major USAF, Retired Apple Valley, CA Harmon Rocket - II http://mysite.verizon.net/t.gummo/index.html ----- Original Message ----- From: Boggs, William A LCDR To: Swaney, Mark CAPT NAVAIRWARCENWPNDIV Bldg 36, Rm 2305 Cc: Tom Gummo ; Krumholz, Paul J LT ; Gould, Richard AE1 NAVTESTWINGPAC 561000E ; Graziano, Thomas A CDR Sent: Tuesday, September 07, 2004 4:31 PM Subject: RE: Pt Mugu Air Show and SoCAL RVs Sir, The Thurs. arrival time was to facilitate fence installation. We can adjust that to allow for the group to fly in Friday morning. After that the airfield will be closed for performer practice and finalizing field set up. We will have a few tactical aircraft arriving Friday evening, but that is on the other side of the airfield from where we will spot the RV's. Once they arrive, they need to stay for the whole weekend. V/r, LCDR Bill Boggs NBVC Point Mugu Air Operations Officer Comm: (805) 989-7041 DSN: 351-7041 -----Original Message----- From: Swaney, Mark CAPT NAVAIRWARCENWPNDIV Bldg 36, Rm 2305 Sent: Friday, September 03, 2004 17:19 To: Boggs, William A LCDR Cc: 'Tom Gummo'; Krumholz, Paul J LT; Gould, Richard AE1 NAVTESTWINGPAC 561000E Subject: RE: Pt Mugu Air Show and SoCAL RVs Importance: High Bill, This very late proposal to the RV group is completely out of line with what had been described during our earlier discussions. There is no way they can bring in their aircraft on Thursday and leave them for the weekend. It's not like you're paying them or providing fuel like you are for other acts and displays. There must be some way this can be worked out? I've worked this airshow for many years in the past doing everything from setting up seating to coordinating the performers and we've always had a way to get a few folks in and out before/after the show times. VR, CAPT Mark Swaney, USN Vice Commander, NAVAIR's Weapons Division Point Mugu & China Lake, CA Email: mark.swaney(at)navy.mil 805-989-7113 (Office) 805-816-3042 (Cellular) -----Original Message----- From: Tom Gummo [mailto:T.gummo(at)verizon.net] Sent: Friday, September 03, 2004 17:06 To: Swaney, Mark CAPT NAVAIRWARCENWPNDIV Bldg 36, Rm 2305 Subject: Fw: Pt Mugu Air Show and SoCAL RVs WOW. Tom ----- Original Message ----- From: Krumholz, Paul J LT To: Tom Gummo Cc: Boggs, William A LCDR Sent: Friday, September 03, 2004 3:39 PM Subject: RE: Pt Mugu Air Show and SoCAL RVs Tom, We are expecting 8 RVators for the show. I got the insurance papaers from Rick. I think as long as everyone has their DD2400 with them we should be good. However, there is just no way you can leave Saturday and bring in 8 different aircraft. There is too much in the way between your parking and the rwy. Our contractor is putting up the crowd control fence on Thursday afternoon, can you arrive prior to this? Sorry for the hassles, let me know what you can do. V/R, Paul -----Original Message----- From: Tom Gummo [mailto:T.gummo(at)verizon.net] Sent: Friday, September 03, 2004 15:29 To: Krumholz, Paul J LT Cc: Swaney, Mark CAPT NAVAIRWARCENWPNDIV Bldg 36, Rm 2305 Subject: Pt Mugu Air Show and SoCAL RVs Paul, Just checking in with you about the air show. I understand Capt Swaney has been working with you on our behalf. I understand Rick Gould has take my DD 2400, DD 2401, DD 2402 forms to you. You stated in one of your emails about making sure the insurance is in order. Just what paperwork will we need? Will we be able to leave Saturday evening after the show and fly in new planes Sunday? Can I leave my plane over night and stay both days? I would be glad to fly to Pt Mugu or CMA and met with you. Thanks, Tom "GummiBear" Gummo Wild Weasel #1753 F-4G Instructor Pilot, USAF, Major Retired http://mysite.verizon.net/t.gummo/index.html ________________________________________________________________________________
Date: Sep 08, 2004
Subject: Increasing Vne
Hi, The discussions about aerobatics and not exceeding Vne made me wonder what kinds of things would need to be done to increase the Vne for an RV. I guess the Rocket guys have done something in this respect, so there must be some experience. I'm mainly thinking about issues like flutter. Anything we can do without a total redesign? -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Sep 08, 2004
Bob, DOT 5 is not gylcerine based, it's silicone based. It's fairly inert. Not at all like DOT 2, 3 or 4 Charlie Kuss > > From: Oldsfolks(at)aol.com > Date: 2004/09/07 Tue PM 10:37:27 EDT > To: rv-list(at)matronics.com > Subject: RV-List: > Re: Brake Fluid > > ________________________________________________________________________________
Date: Sep 08, 2004
Stein Bruch wrote: > > The Team rocket fairings are the way to go, even with the gear legs. They > are thicker, beefier and believe it or not just look better on the plane. > When I part my 2 RV6's side by side, the one with the rocket fairings always > looks better. It just looks a bit stronger and bigger. The prices are the > same as Van's, and the intersection fairings are a fairly nice fit, but > still require some tweaking. You can see a crappy picture of them at: > http://www.steinair.com/engine.htm at the very bottom of the page. I'll get > some more pics this afternoon if anyone wants them (contactme off list). > > Anyay, just my 2 cents. Any new RV's from me will have the rocket fairings. > > FYI, my Black RV6 has the fairings from Bob at fairings, etc.. and they also > work fine. More photos and copy about the attractive Team Rocket fairings: http://home.hiwaay.net/~sbuc/journal/fairings.htm Sam Buchanan ________________________________________________________________________________
Date: Sep 08, 2004
rv-list
Subject: #6 Tefzel wire on ebay
Just noticed somebody selling (supposedly) #6 Tefzel wire for 0.89/foot and thought I pass it along. top of page price is 0.99, scroll down a little and the 'buy it now' price per foot is 0.89. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2489101063&category=26439&sspagename=WDVW -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Sep 08, 2004
Maybe, don't know, but I would use a high temp plastic material if I would make/use one. thomas a. sargent wrote: > > I would be a little suspicious about the thru-bolt type of pass-thru. > The insulating material seems to be (from the pictures, anyway) a > plastic of some sort. I would think a fire would ruin that in seconds. > Do they make these things with a ceramic insulator? > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Subject: Looking for first RV ride, Dallas area
Date: Sep 08, 2004
I'm wondering if anybody from the Dallas area can give a first RV ride to a buddy of mine. His name is Troy Whistman, and I Cc'd him on this email. He's contemplating building an RV and has never had an RV grin...any takers? Thanks in advance! )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: Re: Looking for first RV ride, Dallas area
Date: Sep 08, 2004
Best I can do is give him a look at mine under construction @ TKI this weekend and refer him to my EAA chapter at tomorrow nites meeting....... Ralph Capen N822AR RV6A - plexi and fiberglass..... ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: Looking for first RV ride, Dallas area > > I'm wondering if anybody from the Dallas area can give a first RV ride to a > buddy of mine. His name is Troy Whistman, and I Cc'd him on this email. > He's contemplating building an RV and has never had an RV grin...any takers? > > Thanks in advance! > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ________________________________________________________________________________
Date: Sep 08, 2004
Dan Checkoway wrote: > >I'm wondering if anybody from the Dallas area can give a first RV ride to a >buddy of mine. His name is Troy Whistman, and I Cc'd him on this email. >He's contemplating building an RV and has never had an RV grin...any takers? > >Thanks in advance! > >)_( Dan >RV-7 N714D >http://www.rvproject.com > I'm planning on making the flyin in Monroe LA this Saturday. If he can fly/drive there I'd be glad to accomodate. (long drive but not too bad a flight even in something slow) Charlie flying -4 -7 wings ________________________________________________________________________________
Subject: engine cores
Date: Sep 09, 2004
Keith: I have only bid on a couple of aircraft in the past. Typically you have to bid on the entire aircraft and it is always to my knowledge as is where is. http://www.aviation-salvage.com/ I purchased a wrecked Tri-Pacer of $2,600 delivered form a private party. I saw my engine run before purchasing the wreck minus wings and radios. That was 10 or twelve years ago. On the 17th, my airplane has been flying 7 years. The engine has over 4,500 hours on it. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,584 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: "rv6tc" <rv6tc(at)myawai.com> Subject: RV-List: engine cores Date: Wed, 8 Sep 2004 21:35:16 -0600 Insensitive question follows...... Given the recent disaster(s) in Florida, one would assume that a number of rebuild-able engines/ cores would soon come on the market. If that is the case, do insurance companies sell directly to individuals, or are they all going to the big name shops? I'm not sure of the procedures involved when the claims get settled to part out the remains. Info would be appreciated. Keith Hughes Denver RV-6 finish ________________________________________________________________________________
Subject: Riveting Aileron Top Skin
Date: Sep 09, 2004
List, Any suggestions on how best to rivet the aileron top skin? I am hesitant to start, as I see myself making a golf ball out of this one. I read Dan C's method...I will likely go that route if I don't get any better ideas. Thanks in advance, Scott 7A Wings done, finishing control surfaces Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Subject: RV Forum EAA Chapter 486 Fulton New York KFZY Saturday Sept.
11
Date: Sep 09, 2004
The forecast for Saturday looks very good for this RV Builder/Flyer annual event. Nice airport, excellent facility, lots of RV's from Canada and USA have attended. The Chapter will be open Friday afternoon through Sunday. Saturday activities are planned for all day and evening. Fly in to chat with other RV Builder/Flyers. Alan McKeen RV-6 N418AL ________________________________________________________________________________
Subject: Re: engine cores
Date: Sep 09, 2004
I also saw on the news that many of the airplanes in Florida are owned by older pilots, some of which weren't flying any more and they were not insured. Perhaps some of these will show up on eBay or if you have contacts in Florida, have them nose around the airports and see what might be available from individuals? As someone mentioned, you would have to buy the whole airplane but there's lots of parts you could salvage from power and starter relays to instruments and radios. ________________________________________________________________________________
Subject: Re: Riveting Aileron Top Skin
Date: Sep 09, 2004
Look at Phil B's site. Very easy using his method and can be done solo. Have a great day, Bill -------------- Original message -------------- > > > List, > > Any suggestions on how best to rivet the aileron top skin? I am hesitant to > start, as I see myself making a golf ball out of this one. I read Dan C's > method...I will likely go that route if I don't get any better ideas. > > Thanks in advance, > Scott > 7A Wings done, finishing control surfaces > > Join Excite! - http://www.excite.com > The most personalized portal on the Web! > > > > > > Look at Phil B's site. Very easy using his method and can be done solo. Have a great day, Bill -------------- Original message -------------- -- RV-List message posted by: "" List, Any suggestions on how best to rivet the aileron top skin? I am hesitant to start, as I see myself making a golf ball out of this one. I read Dan C's method...I will likely go that route if I don't get any better ideas. Thanks in advance, Scott 7A Wings done, finishing control surfaces Join Excite! - http://www.excite.com The most personalized portal on the Web! Lists: http://www.matronics.com/emaillists ________________________________________________________________________________
Date: Sep 09, 2004
Subject: Empennage kit Wanted
Wanted. Empennage kit for a RV-6. Prefer not built, but might consider partial built. Reply off line. Gerry Conrad RV-6A ....50 hrs C-GCUN RV-6 kit, Damaged empennage Montreal, Canada gwcgwc(at)videotron.ca 514-697-0656 ________________________________________________________________________________
Date: Sep 09, 2004
Subject: Engine Cores
In regards to Dave Carter's query about purchasing automotive "totals" and looking for an engine from an RX-8...Well Dave the insurance companies have a reason for not wanting to sell a private party a "Salvage" or "Total Loss" vehicle. Long story short, they only want to pay out for the vehicle once. They seem to feel that if the vehicle is sold to anyone other than a wrecking yard there is the possibility that they may have pay out on it again if it were repaired and re-insured. That's why a vehicle that gets damaged to any extent is nearly always salvaged. As a Licensed Dealer we've bought vehicles worth $30,000 for as little as $1500 that had less than $5,000 actual damage. The catch was they had "Salvage Titles" and could not be financed and most insurance companies wouldn't insure them. So they get parted out or scraped. The reason you hear that they have gone this way is to reduce or eliminate "Chop Shops", while in fact they actually perpetuate these operations. To that end, in most parts of the country that is why you have to be a Licensed Dealer to buy the salvage. Around the Pacific Northwest the insurance companies generally won't even talk to a private party, not even the owner. Can you say "Bureaucratic Involvement"? With the limited exposure I've had in dealing with aviation salvage, it's doesn't seem to be far behind in their mindset. As an option you only need a sign, a phone, a building, and pay a $150-$500 annual license fee to be a wrecking yard in some States. Just my two cents... Jim Duckett RV-7A Do Not Archieve ________________________________________________________________________________
Subject: Asphalt Hangar Floor?
Date: Sep 09, 2004
Hopefully this is RV related..... How do you seal and paint (white or light gray) an asphalt hangar floor that is dark, full of holes, greasy spots, etc.? I've been in hangars that are bare asphalt and the lighting becomes useless..... . I've been in hangars where the floor has been painted white or light-gray and everything seems brighter. I'm just looking for suggestions on material and methods to brighten up a hangar with a poor asphalt floor..... Thanks, Jack ________________________________________________________________________________
Date: Sep 09, 2004
Subject: Re: > Re:Asphalt Hangar Floor
Sawdust ?? Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Sep 09, 2004
Subject: Re: Asphalt Hangar Floor?
Jack, We did one at TOA some years ago by cleaning the floor as well as possible and then applying "thin set" concrete over the entire floor and covering it with a light grey epoxy floor paint. It wasn't perfect, but it was a LOT better then asphalt! Dave jacklockamy wrote: > >Hopefully this is RV related..... > >How do you seal and paint (white or light gray) an asphalt hangar floor that is dark, full of holes, greasy spots, etc.? > >I've been in hangars that are bare asphalt and the lighting becomes useless..... . I've been in hangars where the floor has been painted white or light-gray and everything seems brighter. > >I'm just looking for suggestions on material and methods to brighten up a hangar with a poor asphalt floor..... > >Thanks, >Jack > > > > ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Subject: Minnesota Fly-in/ camp in
Date: Sep 09, 2004
Just a last minute reminder - our annual fly-in picnic and camp-in is starting tomorrow, Friday. The picnic is Saturday at noon, bring a chair and a side dish to share. Details at: http://www.home.earthlink.net/~rvflyin/ No excuses - the weather looks great anywhere close to here this weekend! Call me at 612-419-9710 with any questions. Alex Peterson Maple Grove, MN RV6-A N66AP 521 hours ________________________________________________________________________________
Date: Sep 09, 2004
Oops, my actual phone number is 612-418-9710, sorry. > No excuses - the > weather looks great anywhere close to here this weekend! > Call me at 612-419-9710 with any questions. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 521 hours. First flight 3 years ago today! ________________________________________________________________________________
Date: Sep 09, 2004
Subject: axle nut torque
Hi all, Can someone straighten me out on a minor landing gear issue? The manual says to tighten the axle nut until all "side play" is removed but the wheel still turns smoothly. Frankly, I don't see any side play even with the axle nut removed, and the wheel turns pretty smoothly regardless of how hard I tighten by hand. So... how tight is tight? My intuition is to tighten it just barely snug, fingertip tight...? Thanks, Paul http://hmb.dyndns.org/~eastham 9A fuse/finishing ________________________________________________________________________________
Subject: Re: axle nut torque
Date: Sep 10, 2004
Hi Paul, My way: In order to assure that the bearings inner races and spacers etc are fitted mechanically tight, excess grease must be squeezed away from between the various parts. To do this it is necessary to first over tighten them somewhat. Turn the axel nut by hand until snug, rotate the wheel. Then use a wrench or some channel lock type pliers to tighten the axel nut about 1/4 to 1/2 a turn. While doing this rotate the wheel. An alternate procedure is to tighten the axel nut only until the wheel `begins' to resist being rotated. Rotating the wheel at least a few revolutions while the axel nut is "over tightened" will allow the tapered rollers to align themselves within the races while under the artificially induced load. Once this is done release the load on the bearings (back the axel nut off) then gently turn the axel nut with the tool of choice until the axel nut mechanically stops. At this point turning the nut just a quarter flat or so will apply some pre-load. After the initial flight/s it will be necessary to recheck the fit and re-adjust if or as required. I have had the pleasure of adjusting quite a number of wheel bearings and have not had any complaints about failures so far, However; I have seen several opinions as to the finer points of adjusting axel bearings. Their way: I therefore suggest that you contact one of the bearing manufacturers or Vans directly and take the above as a mere guide line as to procedure. Jim in Kelowna ----- Original Message ----- From: "Paul Eastham" <eastham(at)netapp.com> Subject: RV-List: axle nut torque > > Hi all, > Can someone straighten me out on a minor landing gear issue? The > manual says to tighten the axle nut until all "side play" is removed > but the wheel still turns smoothly. Frankly, I don't see any side > play even with the axle nut removed, and the wheel turns pretty > smoothly regardless of how hard I tighten by hand. > > So... how tight is tight? My intuition is to tighten it just barely > snug, fingertip tight...? > > Thanks, > Paul > http://hmb.dyndns.org/~eastham > 9A fuse/finishing > > > ________________________________________________________________________________
Subject: Solid State gyro Dynon D-10 errors
Date: Sep 10, 2004
That being the case - can anyone shed any light on the gyros in use on the Tru Track and other similar autopilot products. I would imagine that we should be seeing similar issues with them and I have not seen a post reporting any problems on those products? Regards Dennis 71041 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ed Anderson Subject: RV-List: Solid State gyro Dynon D-10 errors If the Dynon uses "solid state" gyros as part of their stabilization mechanism then I can see the possibility that the problem could be RPM related. Unlike the spinning mass gyro the solid state gyro rely on a vibrating electric element to establish a spatial reference plane. IF the frequency of the engine (or a harmonic of the basic engine frequency) happens to fall within the proper range then it could be influencing the vibrating element and confusing the processing of the signal from the that element. If that is the case, then perhaps better physical isolation might cure the problem. Any correlation between engine type such as the larger 360 causing more of a problem than say the 320?? Ed Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC ----- Original Message ----- From: "Jeff Point" <jpoint(at)mindspring.com> Subject: Re: RV-List: Dynon D-10 errors > > Mike, > > With about 90 hours on my D-10, I have also seen the roll error you > described on occasion. I limit my flying to VFR for now. If I ever get > my prop back I'll do some testing and see if it is RPM related. > > Jeff Point > RV-6 > Milwaukee WI > > > > > > > = = = = ________________________________________________________________________________
Subject: Re: Solid State gyro Dynon D-10 errors
Date: Sep 10, 2004
----- Original Message ----- From: "Dennis Parker" <dennis(at)k2workflow.com> Subject: RE: RV-List: Solid State gyro Dynon D-10 errors > > That being the case - can anyone shed any light on the gyros in use on > the Tru Track and other similar autopilot products. I would imagine that > we should be seeing similar issues with them and I have not seen a post > reporting any problems on those products? > > Regards > > Dennis > 71041 > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ed Anderson > To: rv-list(at)matronics.com > Subject: RV-List: Solid State gyro Dynon D-10 errors > > > If the Dynon uses "solid state" gyros as part of their stabilization > mechanism then I can see the possibility that the problem could be RPM > related. Unlike the spinning mass gyro the solid state gyro rely on a > vibrating electric element to establish a spatial reference plane. IF > the > frequency of the engine (or a harmonic of the basic engine frequency) > happens to fall within the proper range then it could be influencing the > vibrating element and confusing the processing of the signal from the > that > element. If that is the case, then perhaps better physical isolation > might > cure the problem. > > Any correlation between engine type such as the larger 360 causing > more of > a problem than say the 320?? > > Ed > > Ed Anderson > RV-6A N494BW Rotary Powered > Matthews, NC > ----- Original Message ----- > From: "Jeff Point" <jpoint(at)mindspring.com> > To: > Subject: Re: RV-List: Dynon D-10 errors > > > > > > Mike, > > > > With about 90 hours on my D-10, I have also seen the roll error you > > described on occasion. I limit my flying to VFR for now. If I ever > get > > my prop back I'll do some testing and see if it is RPM related. > > > > Jeff Point > > RV-6 > > Milwaukee WI > > > > > > > > > > > > > > > = > = > = > = > > ________________________________________________________________________________
Date: Sep 10, 2004
I don't know exactly what it is but the sealer they use for tennis courts is available in different colors. That is probably better as it is formulated for it. Lacking that industrial grade epoxy floor paint will stick to asphalt but as the aslpshalt "flakes" you will get paint colored asphalt pieces intead of asphalt colored pieces. Not sure what to prep the asphalt with as yuou use muratic acid on concrete. ----- Original Message ----- From: "jacklockamy" <jacklockamy(at)verizon.net> Subject: RV-List: Asphalt Hangar Floor? > > Hopefully this is RV related..... > > How do you seal and paint (white or light gray) an asphalt hangar floor that is dark, full of holes, greasy spots, etc.? > > I've been in hangars that are bare asphalt and the lighting becomes useless..... . I've been in hangars where the floor has been painted white or light-gray and everything seems brighter. > > I'm just looking for suggestions on material and methods to brighten up a hangar with a poor asphalt floor..... > > Thanks, > Jack > > ________________________________________________________________________________
Date: Sep 10, 2004
Among all the prior posts on this issue Paul, the following is my favorite: Tighten until you just start to feel some drag then back off a tad til the drag is gone. The grease prevents good sensing of end play & the tapered roller bearings will have a short life if they can bang around even a little. Both end play and rotational effort take some tactile sensitivity so whichever method you choose, work at it til you can feel the differences. Don't worry about using a wrench to tighten the nut. Dave Reel - RV8A ________________________________________________________________________________
Date: Sep 10, 2004
Dennis Parker wrote: > > That being the case - can anyone shed any light on the gyros in use on > the Tru Track and other similar autopilot products. I would imagine that > we should be seeing similar issues with them and I have not seen a post > reporting any problems on those products? I have seen absolutely no sensor errors (or heard any reports of them or any other type error for that matter) with my EZ-Pilot autopilot. Haven't heard any reports of sensor problems with the DigiTrak, either. Sam Buchanan http://sambuchanan.com ________________________________________________________________________________
Subject: Dynon D-10 errors
Date: Sep 10, 2004
The new software indeed seems to have fixed the problem on the Europa. This involved a change in the sampling rate. Here's a copy of the note from my Europa friend to Dynon: Hi John and Nick, I have just returned from my first test flight after loading version 1.09.04 to my D-10. I am pleased to report that I ran the plane straight and level at 100 rpm intervals from 5800 engine rpm ( 2386 prop rpm for take off) to 4000 rpm, ( 1646 prop rpm for low speed approach descent). I did not see any instability at any speed. The attitude indicator appeared to be indicating correctly during the whole flight. The turn indicator also showed no oscillation or erratic indication. This is a preliminary feedback, of course, but my problem of erratic horizon and turn indication.appears to be cured. With best regards, John ________________________________________________________________________________
Date: Sep 10, 2004
Unfortunately, We are sending back our Digitrak 200VS for the second time now for sensor errors. Both times for the roll sensor. The first time the autopilot would send the aircraft off on some unknown direction. Trying to override it caused the shear pin in the roll servo to shear. Trutrak fixed both the servo and controller quite promptly and we had everything working prior to Arlington. The second time was about two weeks ago on a long X-country flight. The aircraft started wandering about 5 degrees left and right of the flight path. As time went on it got worse. I contacted Jim at Trutrak and he confirmed that the roll sensor has gone crazy again. Trutrak has also sufferd a big blow this last week. One of their chief engineers was killed in a car accident. According to them it is going to slow things down for a few weeks until they can get the work load re-organized. Mike Robertson >From: Sam Buchanan <sbuc(at)hiwaay.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Solid State gyro Dynon D-10 errors >Date: Fri, 10 Sep 2004 09:33:42 -0500 > > >Dennis Parker wrote: > > > > That being the case - can anyone shed any light on the gyros in use on > > the Tru Track and other similar autopilot products. I would imagine that > > we should be seeing similar issues with them and I have not seen a post > > reporting any problems on those products? > > >I have seen absolutely no sensor errors (or heard any reports of them or >any other type error for that matter) with my EZ-Pilot autopilot. > >Haven't heard any reports of sensor problems with the DigiTrak, either. > >Sam Buchanan >http://sambuchanan.com > > Check out Election 2004 for up-to-date election news, plus voter tools and ________________________________________________________________________________
Date: Sep 10, 2004
Paul, For the main axle nuts on my 6A, I followed a note that came from "18 yrs of the RVator" that said: Torque 600 in/lbs, back off & retorque 120-180 in/lbs. Maybe someone can come up with the complete article for you. Regards, Chris Good West Bend, WI RV-6A 770 hrs. ----- Original Message ----- From: Paul Eastham <eastham(at)netapp.com> Date: Thu, 9 Sep 2004 22:38:54 -0700 Subject: RV-List: axle nut torque Hi all, Can someone straighten me out on a minor landing gear issue? The manual says to tighten the axle nut until all "side play" is removed but the wheel still turns smoothly. Frankly, I don't see any side play even with the axle nut removed, and the wheel turns pretty smoothly regardless of how hard I tighten by hand. So... how tight is tight? My intuition is to tighten it just barely snug, fingertip tight...? Thanks, Paul http://hmb.dyndns.org/~eastham 9A fuse/finishing -- ________________________________________________________________________________
Date: Sep 10, 2004
An RV-4 pilot here had that kind of trouble with his TruTrak Digiflight 200. He experienced the problem within a few weeks of installation. Excursions in pitch, as I recall. He said that TruTrak suspected it was vibration related and had him return the unit for new gyros and software. TruTrak told him that this was not the first instance of this problem on RV-4's. He has it back from TruTrak but hasn't flown it yet because of other work on the aircraft. This is all second hand info so it would be best to contact TruTrak directly for the straight skinny. jb > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Sam Buchanan > Sent: Friday, September 10, 2004 7:34 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Solid State gyro Dynon D-10 errors > > > Dennis Parker wrote: > > > > That being the case - can anyone shed any light on the gyros in use on > > the Tru Track and other similar autopilot products. I would imagine that > > we should be seeing similar issues with them and I have not seen a post > > reporting any problems on those products? > > ________________________________________________________________________________
Subject: TruTrak Roll Error was Solid State gyro Dynon D-10 errors
Date: Sep 10, 2004
I had similar symptoms but the problem was not roll sensor error but repairman error. It all started on a bumpy flight to Scappoose in which the shear pin broke on the aileron (roll) servo. This was one of the early shear pins that were manufactured to break a bit to early. The new ones are more beefy. TruTrak shipped me a couple of new shear pins (post haste as they always do) and I installed it a few days before I left for Oshkosh. During the entire flight, the autopilot would first rock left then right then left then right.....you get the picture. I was mystified because in the 60+ hours I used the TruTrak it had always been rock solid. At Oshkosh, Jim Younkin came out to my plane and found that the shear pin on the aileron servo was not tightened all the way into the hole on the servo arm. To help you understand this more, the shear pin is a brass screw with a large barrel head that has been machined down a bit right below the head. The head of the screw has to go all the way INTO the hole of the servo arm. Apparently, I had installed the shear pin so that the head of the screw was on top of the servo arm (like every other screw on the airplane). What was happening was that the servo arm had about a 1/16" play on each side of the shear pin. The rolling I was experiencing was just the servo taking up the slack. I installed another shear pin at Oshkosh and on the return flight the unit was rock solid again. Another thing to remember if you replace the shear pin. Don't over tighten it. Snug it in with a bit of blue lock tight. If you put to much torque on the shear pin it will weaken it at the machined point and it will shear to soon...like during moderate turbulence at 1500 feet over North Dakota...but that is another story all together. Now my TruTrak DFC 250 is rock solid again. Ross Mickey N9PT Just passed through 100 hrs -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Robertson Subject: Re: RV-List: Solid State gyro Dynon D-10 errors Unfortunately, We are sending back our Digitrak 200VS for the second time now for sensor errors. Both times for the roll sensor. The first time the autopilot would send the aircraft off on some unknown direction. Trying to override it caused the shear pin in the roll servo to shear. Trutrak fixed both the servo and controller quite promptly and we had everything working prior to Arlington. The second time was about two weeks ago on a long X-country flight. The aircraft started wandering about 5 degrees left and right of the flight path. As time went on it got worse. I contacted Jim at Trutrak and he confirmed that the roll sensor has gone crazy again. Trutrak has also sufferd a big blow this last week. One of their chief engineers was killed in a car accident. According to them it is going to slow things down for a few weeks until they can get the work load re-organized. Mike Robertson ________________________________________________________________________________
Subject: fuel injection
Date: Sep 10, 2004
List : I have a io 320 e2b with a bendix rsa 5ad1 fuel injection system. I'm looking for a good book that would show me how to pipe it up. Any help would be appreciated. n255gh ________________________________________________________________________________
Date: Sep 10, 2004
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
There have been reports of similar errors with the True Trak units, although I have not seen any on 'the list'. Early in the development of the Trio unit they experienced similar errors with a particular type of gyro. They delayed deployment, at least one year, until a new gyro, MEMS I believe became available to them. According to them ( I have spoken with them this week to inquire specifically on this mater), and my experience to date, they have not received one single report of any gyro errors of this nature. The Mems gyros are used in inertial reference systems on certified aircraft. Regards, Mike Stewart -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dennis Parker Subject: RE: RV-List: Solid State gyro Dynon D-10 errors That being the case - can anyone shed any light on the gyros in use on the Tru Track and other similar autopilot products. I would imagine that we should be seeing similar issues with them and I have not seen a post reporting any problems on those products? Regards Dennis 71041 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ed Anderson Subject: RV-List: Solid State gyro Dynon D-10 errors If the Dynon uses "solid state" gyros as part of their stabilization mechanism then I can see the possibility that the problem could be RPM related. Unlike the spinning mass gyro the solid state gyro rely on a vibrating electric element to establish a spatial reference plane. IF the frequency of the engine (or a harmonic of the basic engine frequency) happens to fall within the proper range then it could be influencing the vibrating element and confusing the processing of the signal from the that element. If that is the case, then perhaps better physical isolation might cure the problem. Any correlation between engine type such as the larger 360 causing more of a problem than say the 320?? Ed Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC ----- Original Message ----- From: "Jeff Point" <jpoint(at)mindspring.com> Subject: Re: RV-List: Dynon D-10 errors > > Mike, > > With about 90 hours on my D-10, I have also seen the roll error you > described on occasion. I limit my flying to VFR for now. If I ever get > my prop back I'll do some testing and see if it is RPM related. > > Jeff Point > RV-6 > Milwaukee WI > > > > > > > = = = = = = = = ________________________________________________________________________________
Subject: Archer Antenna & Strobe Powerpack
Date: Sep 10, 2004
I am installing a Bob Archer VOR antenna in the fiberglass 7 wingtip. I have individual strobe power units which I also intend to mount at the wingtips. Has anyone had flight experience with such a setup and have there been problems with interference (having the power supply so close to the antenna)? The instructions say to route the navlight power cable along the front of the antenna, but I am somewhat reluctant to run the strobe along the same route because of the high voltage. Any experience with this? I plan on mounting the strobe power supply on the last rib with wires running to the wingtip cutout in the typical location. I've been scratching my head about this for a few days and feel stumped because there is no way to test it until the bird takes wing. Any help -- any ideas -- are better than where I am now ..... Kathleen Evans www.rv7.us ________________________________________________________________________________
From: "John Wiegenstein" <n727jw(at)hellerwiegenstein.com>
Subject: First Flight: N727JW (RV-6 S/N 23961)
Date: Sep 10, 2004
At the risk of drawing unwanted attention from the list police for posting improper material (Herr Ashcroft and his boys will probably be putting me into some database now.....), I am VERY pleased to report that RV-6 N727JW has finally taken flight. I began work on this slow-build tipup 6 in early 1995. Family, law practice, and other hobbies meant that the project stretched out longer than many, but I kept at it. N727JW finally received its airworthiness certificate on 9/6/2004 from DAR James Devany (Joyce, WA), (TIW) in Gig Harbor, WA. The 40 minute flight went smoothly, with no squawks except a slightly heavy right wing, and the need for a small amount of right rudder trim. Power is a new O-360-A1A with a new Hartzell "blended airfoil" C/S prop, both from Van's, so takeoff and climb performance were impressive. Panel is "not quite IFR", and empty weight without paint or wheel/gear leg fairings ended up right at 1,000 lb. Mike Seager's transition course was worth every penny, and helped to make the flight as "routine" as could be expected. An absolutely fabulous feeling and experience! I'll say it again, even though its been said many times before: to all you guys (and gals) still building, keep pounding those rivets and pressing on, whatever the hardships and temporary setbacks. It WILL be finished some day, and when it is and you have taken flight, you will have joined a very small, elite group, and will experience a level of personal satisfaction and accomplishment that few people know. You will also have learned a tremendous amount of information about your aircraft specifically, and aircraft construction, certification, and design in general. To me, that can only make you (and me) a safer, better educated pilot once the bird is ready to leave the nest. And, to those who have posted advice, comments, etc. on this list and in other forums (fora?) over the years, thanks for the good information. The 'net and broadband have allowed us all to wallow in way more garbage than we might like, but it also has nuggets of great information, and this list has had many of those over the years for a lurker like me. I cannot imagine how our forebears created homebuilts before the internet and before the kits that we all enjoy today. My hat is off to them. Gotta go fly now! John H. Wiegenstein HELLER WIEGENSTEIN PLLC 19301 - 8th Ave. NE, Suite A Poulsbo, WA 98370 (360) 394-3500 (360) 394-3503 FAX johnw(at)hellerwiegenstein.com www.hellerwiegenstein.com ________________________________________________________________________________
Subject: Re: Archer Antenna & Strobe Powerpack
Date: Sep 10, 2004
Kathleen, I have Bob's VOR antenna in the wingtip of the -7 along with the strobes--but not the power supplies. I would also give Bob Archer a call, he was very helpful when I called him about my installation. Mine works perfectly and I doubt that having the power supplies on the outboard rib would have much effect at all. Bob will want you to run your strobe wires along the leading edge of the antenna along with the nav light wires. I believe this is the way he shows it on his schematic. Pat Hatch ----- Original Message ----- From: <Kathleen(at)rv7.us> Subject: RV-List: Archer Antenna & Strobe Powerpack > > > I am installing a Bob Archer VOR antenna in the fiberglass 7 wingtip. I > have individual strobe power units which I also intend to mount at the > wingtips. Has anyone had flight experience with such a setup and have there > been problems with interference (having the power supply so close to the > antenna)? > > The instructions say to route the navlight power cable along the front of > the antenna, but I am somewhat reluctant to run the strobe along the same > route because of the high voltage. Any experience with this? > > I plan on mounting the strobe power supply on the last rib with wires > running to the wingtip cutout in the typical location. I've been scratching > my head about this for a few days and feel stumped because there is no way > to test it until the bird takes wing. Any help -- any ideas -- are better > than where I am now ..... > > Kathleen Evans > www.rv7.us > > ________________________________________________________________________________
Date: Sep 10, 2004
Kathleen(at)rv7.us wrote: > > > I am installing a Bob Archer VOR antenna in the fiberglass 7 wingtip. I > have individual strobe power units which I also intend to mount at the > wingtips. Has anyone had flight experience with such a setup and have there > been problems with interference (having the power supply so close to the > antenna)? > > The instructions say to route the navlight power cable along the front of > the antenna, but I am somewhat reluctant to run the strobe along the same > route because of the high voltage. Any experience with this? Kathleen, I have exactly the setup you are describing: http://home.hiwaay.net/~sbuc/journal/sportcraft.htm > > I plan on mounting the strobe power supply on the last rib with wires > running to the wingtip cutout in the typical location. I've been scratching > my head about this for a few days and feel stumped because there is no way > to test it until the bird takes wing. Any help -- any ideas -- are better > than where I am now ..... The Sportcraft antenna and strobe power supplies will coexist very happily. :-) Sam Buchanan ________________________________________________________________________________
Date: Sep 10, 2004
I have the power packs mounted on the end rib, and an Archer antenna in the right tip. No interference......just follow the instructions as written and don't over think it. Laird RV-6 1000 hrs SoCal On Sep 10, 2004, at 1:29 PM, Kathleen(at)rv7.us wrote: > > > I am installing a Bob Archer VOR antenna in the fiberglass 7 wingtip. > I > have individual strobe power units which I also intend to mount at the > wingtips. Has anyone had flight experience with such a setup and have > there > been problems with interference (having the power supply so close to > the > antenna)? > > The instructions say to route the navlight power cable along the front > of > the antenna, but I am somewhat reluctant to run the strobe along the > same > route because of the high voltage. Any experience with this? > > I plan on mounting the strobe power supply on the last rib with wires > running to the wingtip cutout in the typical location. I've been > scratching > my head about this for a few days and feel stumped because there is no > way > to test it until the bird takes wing. Any help -- any ideas -- are > better > than where I am now ..... > > Kathleen Evans > www.rv7.us > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Sep 10, 2004
OK folks, I got it. I have mounted my first power pack on the end rib and I'll stop worrying about it. If it doesn't work out, I'll punish you all by posting irrelevant chatter on the list every day for a month (but then I'll probably get arrested by the list police, right?).... Thanks much, :-) Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Laird Owens Subject: Re: RV-List: Archer Antenna & Strobe Powerpack I have the power packs mounted on the end rib, and an Archer antenna in the right tip. No interference......just follow the instructions as written and don't over think it. Laird RV-6 1000 hrs SoCal On Sep 10, 2004, at 1:29 PM, Kathleen(at)rv7.us wrote: > > > I am installing a Bob Archer VOR antenna in the fiberglass 7 wingtip. > I > have individual strobe power units which I also intend to mount at the > wingtips. Has anyone had flight experience with such a setup and have > there > been problems with interference (having the power supply so close to > the > antenna)? > > The instructions say to route the navlight power cable along the front > of > the antenna, but I am somewhat reluctant to run the strobe along the > same > route because of the high voltage. Any experience with this? > > I plan on mounting the strobe power supply on the last rib with wires > running to the wingtip cutout in the typical location. I've been > scratching > my head about this for a few days and feel stumped because there is no > way > to test it until the bird takes wing. Any help -- any ideas -- are > better > than where I am now ..... > > Kathleen Evans > www.rv7.us > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Sep 11, 2004
Kathleen: Have had the setup you describe and it works great for the past 7 years. See Sam Buchanan's web site for what it did. Looks like a very similar set up to me except I have the Wheelen power supplies in the wing tip instead of the Aeroflash. http://home.hiwaay.net/~sbuc/journal/sportcraft.htm I can drive over to Bob Arche's house and ask any question that you may have. The 2nd Nav antenna that I have is used for the FM signal to my entertainment center. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,584 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: Kathleen(at)rv7.us Subject: RV-List: Archer Antenna & Strobe Powerpack Date: Fri, 10 Sep 2004 13:29:37 -0700 I am installing a Bob Archer VOR antenna in the fiberglass 7 wingtip. I have individual strobe power units which I also intend to mount at the wingtips. Has anyone had flight experience with such a setup and have there been problems with interference (having the power supply so close to the antenna)? The instructions say to route the navlight power cable along the front of the antenna, but I am somewhat reluctant to run the strobe along the same route because of the high voltage. Any experience with this? I plan on mounting the strobe power supply on the last rib with wires running to the wingtip cutout in the typical location. I've been scratching my head about this for a few days and feel stumped because there is no way to test it until the bird takes wing. Any help -- any ideas -- are better than where I am now ..... Kathleen Evans www.rv7.us ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Refilling Compass
Date: Sep 10, 2004
My compass has run low on fluid after 3.5 years of slooooooowly losing fluid somewhere. No idea where the leak is, because I've never noticed a drip, a damp spot, or anything other than a slowly falling fluid level. Anyway, what's involved in re-filling it? How does it come apart? How does it go back together? How tight should I torque the fasteners that hold it together? I'd appreciate the whole run-down if someone can give it. Based on advice from the list and other sources, I'm going to refill it with low odor mineral spirits. Thanks in advance, KB ________________________________________________________________________________
Date: Sep 10, 2004
Subject: Re: First Flight: N727JW (RV-6 S/N 23961)
John keep breaking our earthly bonds... and continue to touch the face of God. John Wiegenstein wrote: At the risk of drawing unwanted attention from the list police for posting improper material (Herr Ashcroft and his boys will probably be putting me into some database now.....), I am VERY pleased to report that RV-6 N727JW has finally taken flight. I began work on this slow-build tipup 6 in early 1995. Family, law practice, and other hobbies meant that the project stretched out longer than many, but I kept at it. N727JW finally received its airworthiness certificate on 9/6/2004 from DAR James Devany (Joyce, WA), (TIW) in Gig Harbor, WA. The 40 minute flight went smoothly, with no squawks except a slightly heavy right wing, and the need for a small amount of right rudder trim. Power is a new O-360-A1A with a new Hartzell "blended airfoil" C/S prop, both from Van's, so takeoff and climb performance were impressive. Panel is "not quite IFR", and empty weight without paint or wheel/gear leg fairings ended up right at 1,000 lb. Mike Seager's transition course was worth every penny, and helped to make the flight as "routine" as could be expected. An absolutely fabulous feeling and experience! I'll say it again, even though its been said many times before: to all you guys (and gals) still building, keep pounding those rivets and pressing on, whatever the hardships and temporary setbacks. It WILL be finished some day, and when it is and you have taken flight, you will have joined a very small, elite group, and will experience a level of personal satisfaction and accomplishment that few people know. You will also have learned a tremendous amount of information about your aircraft specifically, and aircraft construction, certification, and design in general. To me, that can only make you (and me) a safer, better educated pilot once the bird is ready to leave the nest. And, to those who have posted advice, comments, etc. on this list and in other forums (fora?) over the years, thanks for the good information. The 'net and broadband have allowed us all to wallow in way more garbage than we might like, but it also has nuggets of great information, and this list has had many of those over the years for a lurker like me. I cannot imagine how our forebears created homebuilts before the internet and before the kits that we all enjoy today. My hat is off to them. Gotta go fly now! John H. Wiegenstein HELLER WIEGENSTEIN PLLC 19301 - 8th Ave. NE, Suite A Poulsbo, WA 98370 (360) 394-3500 (360) 394-3503 FAX johnw(at)hellerwiegenstein.com www.hellerwiegenstein.com --------------------------------- ________________________________________________________________________________
Date: Sep 10, 2004
Subject: Re: Refilling Compass
Aircraft Spruce sell a repair kit and refil kit that should help you out. Try this link but it looks like it deals only with the Airpath Compass. I'm sure you could find a kit for your model by contacting the Mfg. The kit include the fluid and diaphram. I had mine fixed by my local A&P before I new I coiuld do it myself. http://www.aircraftspruce.com/nsearch.php?s=compass Kyle Boatright wrote: > >My compass has run low on fluid after 3.5 years of slooooooowly losing fluid somewhere. No idea where the leak is, because I've never noticed a drip, a damp spot, or anything other than a slowly falling fluid level. Anyway, what's involved in re-filling it? How does it come apart? How does it go back together? How tight should I torque the fasteners that hold it together? I'd appreciate the whole run-down if someone can give it. > >Based on advice from the list and other sources, I'm going to refill it with low odor mineral spirits. > >Thanks in advance, > >KB > > >. > > > ________________________________________________________________________________
Date: Sep 11, 2004
> > >My compass has run low on fluid after 3.5 years of slooooooowly losing >fluid somewhere. No idea where the leak is, because I've never noticed a >drip, a damp spot, or anything other than a slowly falling fluid level. >Anyway, what's involved in re-filling it? How does it come apart? How >does it go back together? How tight should I torque the fasteners that >hold it together? I'd appreciate the whole run-down if someone can give >it. > > > >Based on advice from the list and other sources, I'm going to refill it >with low odor mineral spirits. > > > >Thanks in advance, > > > >KB Same thing here, KB. My compass is flopping around with very little visible means of liquid support. Never saw a drop of fluid anywhere. Must be seeping out and evaporating. Took five years to do it. I ordered a refill/repair kit from Spruce. Bummer is that I installed the thing in a horrendous location without some form of captive nut or those grasshopper nuts thingeys. (How DID they get them off the grasshopper and what did he think about it?) Gonna be a bear to remove. Won't do THAT again on the RV10 that's for sure! Brian Denk RV8 N94BD RV10 '51 ________________________________________________________________________________
Date: Sep 10, 2004
> > > If the Dynon uses "solid state" gyros as part of their stabilization > mechanism then I can see the possibility that the problem could be RPM > related. > > Any correlation between engine type such as the larger 360 causing > more of > a problem than say the 320?? > > Ed > > Ed Anderson > RV-6A N494BW Rotary Powered > Matthews, NC > Hi Ed I'd be interested and I'm certain that Dynon would as well to know what engines are in the planes that are experiencing these problems. As you & I both know, even the smooth rotary has it's own harmonic vibrations, however in almost 40 hours of flying my Dynon I've yet to see any errors (but I'm watching closely). I'd like to hear what engine/prop/ignition combinations are involved to see if there is a common thread. When I first received my Dynon, I brought it to work at a large mill (had to show it off to the other instrument mechanics:-) and when turned on it immediately showed a ~30 degree right bank and a ~10 degree down pitch. The error remained steady at all times within the shop at the mill. The shop is solid concrete and feels rock steady, but there was something in there that was affecting the Dynon. At home it performed flawlessly again, so I brought it back to work the next day. Same error again. At that time I began to wonder if vibration or quite possibly electromagnetic interference from all the industrial equipment was the cause. After installing it I'd pretty much forgotten about that until now. Just another bit of info to consider..... Todd Bartrim (Love my Dynon) RV9Endurance 13B Turbo Rotary C-FSTB http://www3.telus.net/haywire/RV-9/C-FSTB.htm "The world will always have a place for those that bring hard work and determination to the things they do." ________________________________________________________________________________
Date: Sep 11, 2004
Congrats John! Jeff Point RV-6 slow build, 90 hours since 3-15-04 John Wiegenstein wrote: > >At the risk of drawing unwanted attention from the list police for posting >improper material (Herr Ashcroft and his boys will probably be putting me >into some database now.....), I am VERY pleased to report that RV-6 N727JW >has finally taken flight. I began work on this slow-build tipup 6 in early >1995. Family, law practice, and other hobbies meant that the project >stretched out longer than many, but I kept at it. N727JW finally received >its airworthiness certificate on 9/6/2004 from DAR James Devany (Joyce, WA), >(TIW) in Gig Harbor, WA. The 40 minute flight went smoothly, with no squawks >except a slightly heavy right wing, and the need for a small amount of right >rudder trim. Power is a new O-360-A1A with a new Hartzell "blended airfoil" >C/S prop, both from Van's, so takeoff and climb performance were impressive. >Panel is "not quite IFR", and empty weight without paint or wheel/gear leg >fairings ended up right at 1,000 lb. Mike Seager's transition course was >worth every penny, and helped to make the flight as "routine" as could be >expected. An absolutely fabulous feeling and experience! > >I'll say it again, even though its been said many times before: to all you >guys (and gals) still building, keep pounding those rivets and pressing on, >whatever the hardships and temporary setbacks. It WILL be finished some >day, and when it is and you have taken flight, you will have joined a very >small, elite group, and will experience a level of personal satisfaction and >accomplishment that few people know. You will also have learned a >tremendous amount of information about your aircraft specifically, and >aircraft construction, certification, and design in general. To me, that >can only make you (and me) a safer, better educated pilot once the bird is >ready to leave the nest. > >And, to those who have posted advice, comments, etc. on this list and in >other forums (fora?) over the years, thanks for the good information. The >'net and broadband have allowed us all to wallow in way more garbage than we >might like, but it also has nuggets of great information, and this list has >had many of those over the years for a lurker like me. I cannot imagine >how our forebears created homebuilts before the internet and before the kits >that we all enjoy today. My hat is off to them. > >Gotta go fly now! >John H. Wiegenstein >HELLER WIEGENSTEIN PLLC >19301 - 8th Ave. NE, Suite A >Poulsbo, WA 98370 >(360) 394-3500 >(360) 394-3503 FAX >johnw(at)hellerwiegenstein.com >www.hellerwiegenstein.com > > > > ________________________________________________________________________________
Date: Sep 11, 2004
In a message dated 9/10/04 9:52:40 PM US Eastern Standard Time, kboatright1(at)comcast.net writes: > > My compass has run low on fluid after 3.5 years of slooooooowly losing fluid > somewhere. No idea where the leak is, because I've never noticed a drip, a > damp spot, or anything other than a slowly falling fluid level. Anyway, > what's involved in re-filling it? How does it come apart? How does it go back > together? How tight should I torque the fasteners that hold it together? I'd > appreciate the whole run-down if someone can give it. > > Based on advice from the list and other sources, I'm going to refill it with > low odor mineral spirits. > > Thanks in advance, > > KB > > Take it out of the outer case. There is a brass plug that you take out. Pour in the new fluid. Put the plug back in. Put it back in the case. As my drill instructor used to say, "Its so simple its pathetic." Dan H RV-7A (Flying out to breakfast this morning.) ________________________________________________________________________________
Date: Sep 11, 2004
----- Original Message ----- From: "Todd Bartrim" <haywire(at)telus.net> Subject: RE: RV-List: Solid State gyro Dynon D-10 errors > > > > > > > > If the Dynon uses "solid state" gyros as part of their stabilization > > mechanism then I can see the possibility that the problem could be RPM > > related. > > > > Any correlation between engine type such as the larger 360 causing > > more of > > a problem than say the 320?? > > > > Ed > > > > Ed Anderson > > RV-6A N494BW Rotary Powered > > Matthews, NC > > > > Hi Ed > I'd be interested and I'm certain that Dynon would as well to know what > engines are in the planes that are experiencing these problems. As you & I > both know, even the smooth rotary has it's own harmonic vibrations, however > in almost 40 hours of flying my Dynon I've yet to see any errors (but I'm > watching closely). I'd like to hear what engine/prop/ignition combinations > are involved to see if there is a common thread. > When I first received my Dynon, I brought it to work at a large mill (had > to show it off to the other instrument mechanics:-) and when turned on it > immediately showed a ~30 degree right bank and a ~10 degree down pitch. The > error remained steady at all times within the shop at the mill. The shop is > solid concrete and feels rock steady, but there was something in there that > was affecting the Dynon. At home it performed flawlessly again, so I brought > it back to work the next day. Same error again. At that time I began to > wonder if vibration or quite possibly electromagnetic interference from all > the industrial equipment was the cause. After installing it I'd pretty much > forgotten about that until now. > Just another bit of info to consider..... > > Todd Bartrim (Love my Dynon) > > RV9Endurance > 13B Turbo Rotary > C-FSTB > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > "The world will always have a place for those that bring hard > work and determination to the things they do." > Hi, Todd, Since this is a "fairly" new application of the solid state gyros, its not that surprising that an Unknown Unknown should crop up. Given that these gizmos generally have a small piece of silicon that vibrates to establish spatial reference, not too big a stretch to consider that external vibration could (if of the right frequency and amplitude) cause interference. Of course, it could be something altogether different that's the cause, but the indications (I believe) is pointing toward external vibration (but, would not exclude possibly electronic interference). Ed Ed Anderson RV-6A N494BW Rotary Powered Matthews ________________________________________________________________________________
From: "David Fenstermacher" <dfenstermacher(at)earthlink.net>
Date: Sep 11, 2004
Typically "solid state" gyros are made from piezo-electric crystals. These things are cool. If you hit the crystal (imput a force), they generate electricity as a function of the force. [Typical applications - gyros, cigarette lighters, old fashion TV remote controls that didn't need batteries] If you put power (hook up electricity) to the crystal, the crystal moves. [typical applications - auto-focusers on camera lenses, and various other linear actuators] I would think that a vibratory gyro would not work very well in a high-ambient vibration environment. Maybe the software guys have a work-around. I don't know. Dave > [Original Message] > From: Ed Anderson <eanderson(at)carolina.rr.com> > To: > Date: 9/11/2004 9:35:13 AM > Subject: Re: RV-List: Solid State gyro Dynon D-10 errors > > > ----- Original Message ----- > From: "Todd Bartrim" <haywire(at)telus.net> > To: > Subject: RE: RV-List: Solid State gyro Dynon D-10 errors > > > > > > > > > > > > > > > If the Dynon uses "solid state" gyros as part of their stabilization > > > mechanism then I can see the possibility that the problem could be RPM > > > related. > > > > > > Any correlation between engine type such as the larger 360 causing > > > more of > > > a problem than say the 320?? > > > > > > Ed > > > > > > Ed Anderson > > > RV-6A N494BW Rotary Powered > > > Matthews, NC > > > > > > > Hi Ed > > I'd be interested and I'm certain that Dynon would as well to know > what > > engines are in the planes that are experiencing these problems. As you & I > > both know, even the smooth rotary has it's own harmonic vibrations, > however > > in almost 40 hours of flying my Dynon I've yet to see any errors (but I'm > > watching closely). I'd like to hear what engine/prop/ignition combinations > > are involved to see if there is a common thread. > > When I first received my Dynon, I brought it to work at a large > mill (had > > to show it off to the other instrument mechanics:-) and when turned on it > > immediately showed a ~30 degree right bank and a ~10 degree down pitch. > The > > error remained steady at all times within the shop at the mill. The shop > is > > solid concrete and feels rock steady, but there was something in there > that > > was affecting the Dynon. At home it performed flawlessly again, so I > brought > > it back to work the next day. Same error again. At that time I began to > > wonder if vibration or quite possibly electromagnetic interference from > all > > the industrial equipment was the cause. After installing it I'd pretty > much > > forgotten about that until now. > > Just another bit of info to consider..... > > > > Todd Bartrim (Love my Dynon) > > > > RV9Endurance > > 13B Turbo Rotary > > C-FSTB > > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > "The world will always have a place for those that bring hard > > work and determination to the things they do." > > > Hi, Todd, > > Since this is a "fairly" new application of the solid state gyros, its > not that surprising that an Unknown Unknown should crop up. Given that > these gizmos generally have a small piece of silicon that vibrates to > establish spatial reference, not too big a stretch to consider that external > vibration could (if of the right frequency and amplitude) cause > interference. Of course, it could be something altogether different that's > the cause, but the indications (I believe) is pointing toward external > vibration (but, would not exclude possibly electronic interference). > > Ed > > > Ed Anderson > RV-6A N494BW Rotary Powered > Matthews > > ________________________________________________________________________________
Date: Sep 12, 2004
Ah, yes, putting in the fluid (kerosene, mineral spirits paint thinner, and varsol are favourite "homebrew" replacements) is easy. Getting rid of the bubble that sits in the compass window is more difficult and can be maddeningly frustrating. Fill something like a coffee can with the fluid, submerge the compass in it and keep rotating it until the air escapes is the advice I was given. Eventually worked too. Jim Oke Wpg., MB RV-6A (equipped with a self repaired compass!) ----- Original Message ----- From: <Hopperdhh(at)aol.com> Subject: Re: RV-List: Refilling Compass > > In a message dated 9/10/04 9:52:40 PM US Eastern Standard Time, > kboatright1(at)comcast.net writes: > > > > > My compass has run low on fluid after 3.5 years of slooooooowly losing fluid > > somewhere. No idea where the leak is, because I've never noticed a drip, a > > damp spot, or anything other than a slowly falling fluid level. Anyway, > > what's involved in re-filling it? How does it come apart? How does it go back > > together? How tight should I torque the fasteners that hold it together? I'd > > appreciate the whole run-down if someone can give it. > > > > Based on advice from the list and other sources, I'm going to refill it with > > low odor mineral spirits. > > > > Thanks in advance, > > > > KB > > Take it out of the outer case. There is a brass plug that you take out. > Pour in the new fluid. Put the plug back in. Put it back in the case. As my > drill instructor used to say, "Its so simple its pathetic." > > Dan H > RV-7A (Flying out to breakfast this morning.) > ________________________________________________________________________________
Date: Sep 11, 2004
Not so with MEMs gyros. A very clever technique is responsible for their excellent resistance to shock and vibration. A highly informative article on the AD rate gyros is at the link below.... http://www.analog.com/library/analogDialogue/archives/37-03/gyro.html Note especially the paragraph titled "Immunity to Shock and Vibration". (Disclaimer - I am associated with an autopilot manufacturer that uses these devices) Jerry -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of David Fenstermacher Subject: Re: RV-List: Solid State gyro Dynon D-10 errors Typically "solid state" gyros are made from piezo-electric crystals. These things are cool. If you hit the crystal (imput a force), they generate electricity as a function of the force. [Typical applications - gyros, cigarette lighters, old fashion TV remote controls that didn't need batteries] If you put power (hook up electricity) to the crystal, the crystal moves. [typical applications - auto-focusers on camera lenses, and various other linear actuators] I would think that a vibratory gyro would not work very well in a high-ambient vibration environment. Maybe the software guys have a work-around. I don't know. Dave > [Original Message] > From: Ed Anderson <eanderson(at)carolina.rr.com> > To: > Date: 9/11/2004 9:35:13 AM > Subject: Re: RV-List: Solid State gyro Dynon D-10 errors > > > ----- Original Message ----- > From: "Todd Bartrim" <haywire(at)telus.net> > To: > Subject: RE: RV-List: Solid State gyro Dynon D-10 errors > > > > > > > > > > > > > > > If the Dynon uses "solid state" gyros as part of their stabilization > > > mechanism then I can see the possibility that the problem could be RPM > > > related. > > > > > > Any correlation between engine type such as the larger 360 causing > > > more of > > > a problem than say the 320?? > > > > > > Ed > > > > > > Ed Anderson > > > RV-6A N494BW Rotary Powered > > > Matthews, NC > > > > > > > Hi Ed > > I'd be interested and I'm certain that Dynon would as well to know > what > > engines are in the planes that are experiencing these problems. As you & I > > both know, even the smooth rotary has it's own harmonic vibrations, > however > > in almost 40 hours of flying my Dynon I've yet to see any errors (but I'm > > watching closely). I'd like to hear what engine/prop/ignition combinations > > are involved to see if there is a common thread. > > When I first received my Dynon, I brought it to work at a large > mill (had > > to show it off to the other instrument mechanics:-) and when turned on it > > immediately showed a ~30 degree right bank and a ~10 degree down pitch. > The > > error remained steady at all times within the shop at the mill. The shop > is > > solid concrete and feels rock steady, but there was something in there > that > > was affecting the Dynon. At home it performed flawlessly again, so I > brought > > it back to work the next day. Same error again. At that time I began to > > wonder if vibration or quite possibly electromagnetic interference from > all > > the industrial equipment was the cause. After installing it I'd pretty > much > > forgotten about that until now. > > Just another bit of info to consider..... > > > > Todd Bartrim (Love my Dynon) > > > > RV9Endurance > > 13B Turbo Rotary > > C-FSTB > > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > "The world will always have a place for those that bring hard > > work and determination to the things they do." > > > Hi, Todd, > > Since this is a "fairly" new application of the solid state gyros, its > not that surprising that an Unknown Unknown should crop up. Given that > these gizmos generally have a small piece of silicon that vibrates to > establish spatial reference, not too big a stretch to consider that external > vibration could (if of the right frequency and amplitude) cause > interference. Of course, it could be something altogether different that's > the cause, but the indications (I believe) is pointing toward external > vibration (but, would not exclude possibly electronic interference). > > Ed > > > Ed Anderson > RV-6A N494BW Rotary Powered > Matthews > > ________________________________________________________________________________
Date: Sep 11, 2004
From: Hal / Carol Kempthorne <kempthornes(at)earthlink.net>
Close the hangar door. Post a guard outside to honk the horn if he sees any FAA guys. Fill the compass. Don't write anything in the logbook. Open the door and go flying! An old pilot told me this is how he maintains his certified aircraft!! This is a different guy from the one who fixes a slightly bent crankshaft while still in the engine by bashing it with a sledge hammer. Alternatively, sell it on ebay on buy a new one. This keeps your insurance in force in the event of an incident. Why pay big bucks for insurance and then invalidate it to save a buck or two.? hal ________________________________________________________________________________
Date: Sep 11, 2004
rv-list
Subject: Super-2-CCA FatWire
Hi gang Anybody on the list using or planning to use the new Super-2-CCA FatWire from http://periheliondesign.com/fatwires.htm ?? if you are, how are your experiences and why was it worth dubbel the price of #2 wire?? I like the idea of less resistance as I am building an 8 with the battery in the back, but, my dutch genes rebel against the price for little appearant improvement. Yes you can throw calculations all day long showing a little weight saving (about a pound and a half) and less resistance, fact is there are plenty of RV8's out there with a rear battery and #2 wire with no problems. Gert -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Subject: O-360 Exhaust Popping, and CHTs
Date: Sep 11, 2004
Well, now that the first two flights of the RV-6 are under my belt, I'm moving from "construction" questions to "operational" questions. First, at low power settings (say, less that 14 in. MP) I am getting occasional popping from the exhaust on my O-360-A1A. I have the Van's FWF kit and exhaust. Everything seems tight on the exhaust system. The occasional popping reminds me a lot of my old GSXR-1100 Suzuki's exhaust when backing off the throttle. My suspicion is that the low backpressure exhaust system has something to do with this, and that it is not a problem per se, but I would appreciate some feedback. The archives had very little on this topic. Second, what CHTs are people seeing? I have the RMI MicroMonitor with bayonet probe in #3 cylinder. So far, I'm showing about 340-380F in cruise, the latter numbers being at, say, a 24/24 power setting and the lower at perhaps 20 inches/2300. But in climbout I am seeing anywhere from 390-430F flights have been from sea level up to about 4000MSL, on days with close to standard conditions. I think my baffles and seals are "pretty good," though I'm sure there are a few small spots that could be sealed better. Oil temps have been fine with the Niagara cooler. Any thoughts are much appreciated - TIA. John H. Wiegenstein HELLER WIEGENSTEIN PLLC 19301 - 8th Ave. NE, Suite A Poulsbo, WA 98370 (360) 394-3500 (360) 394-3503 FAX johnw(at)hellerwiegenstein.com www.hellerwiegenstein.com ________________________________________________________________________________
Date: Sep 11, 2004
If it is leaking the odds are the back diaphragm has a crack in the rubber and needs replacing. Do not mess with the front window. It can be easily cleaned with a q-tip when you have the back off to change the diaphragm. Cy Galley - Chair, Emergency Aircraft Repair Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: <Hopperdhh(at)aol.com> Subject: Re: RV-List: Refilling Compass > > In a message dated 9/10/04 9:52:40 PM US Eastern Standard Time, > kboatright1(at)comcast.net writes: > > > > > My compass has run low on fluid after 3.5 years of slooooooowly losing fluid > > somewhere. No idea where the leak is, because I've never noticed a drip, a > > damp spot, or anything other than a slowly falling fluid level. Anyway, > > what's involved in re-filling it? How does it come apart? How does it go back > > together? How tight should I torque the fasteners that hold it together? I'd > > appreciate the whole run-down if someone can give it. > > > > Based on advice from the list and other sources, I'm going to refill it with > > low odor mineral spirits. > > > > Thanks in advance, > > > > KB > > > > > > Take it out of the outer case. There is a brass plug that you take out. > Pour in the new fluid. Put the plug back in. Put it back in the case. As my > drill instructor used to say, "Its so simple its pathetic." > > Dan H > RV-7A (Flying out to breakfast this morning.) > > ________________________________________________________________________________
Date: Sep 11, 2004
KB-----My advice is to just send for the repair kit from ACS or some other supplier and this will give you the correct fluid and ALL the seals.Why not do it the right way? Ollie-------Dodging hurricanes in Fl. ----- Original Message ----- From: "Kyle Boatright" <kboatright1(at)comcast.net> Subject: RV-List: Refilling Compass > > My compass has run low on fluid after 3.5 years of slooooooowly losing > fluid somewhere. No idea where the leak is, because I've never noticed a > drip, a damp spot, or anything other than a slowly falling fluid level. > Anyway, what's involved in re-filling it? How does it come apart? How > does it go back together? How tight should I torque the fasteners that > hold it together? I'd appreciate the whole run-down if someone can give > it. > > Based on advice from the list and other sources, I'm going to refill it > with low odor mineral spirits. > > Thanks in advance, > > KB > > > ________________________________________________________________________________
Subject: Re: O-360 Exhaust Popping, and CHTs
Date: Sep 11, 2004
----- Original Message ----- From: "John Wiegenstein" <n727jw(at)hellerwiegenstein.com> Subject: RV-List: O-360 Exhaust Popping, and CHTs > > John----I have about 900 hours on my 6a with 180hp and constant speed and my #3 cyl can reach 430* in climb and thats climbing at 140 mph. In cruise it runs about 400* while the rest are 360-380*. Hotter than I like but then Fl. can be hot in the summer. Ollie---Central Fl. > Second, what CHTs are people seeing? I have the RMI MicroMonitor with > bayonet probe in #3 cylinder. So far, I'm showing about 340-380F in > cruise, > the latter numbers being at, say, a 24/24 power setting and the lower at > perhaps 20 inches/2300. But in climbout I am seeing anywhere from > 390-430F > flights have been from sea level up to about 4000MSL, on days with close > to > standard conditions. I think my baffles and seals are "pretty good," > though > I'm sure there are a few small spots that could be sealed better. Oil > temps > have been fine with the Niagara cooler. > > Any thoughts are much appreciated - TIA. > John H. Wiegenstein > HELLER WIEGENSTEIN PLLC > 19301 - 8th Ave. NE, Suite A > Poulsbo, WA 98370 > (360) 394-3500 > (360) 394-3503 FAX > johnw(at)hellerwiegenstein.com > www.hellerwiegenstein.com > > > ________________________________________________________________________________
Date: Sep 11, 2004
Cause you don't want to take that front off the compass! Good luck getting it to seal again, even with a new gasket, even with two gaskets, Fuel Lube, or Pro-Seal. Change the rear diaphragm, as it may indeed have a tiny pinhole, and go with the "plunge in a tin of alcohol and roll around until no more bubbles come out" method of filling. There, good for another fifty years. Unless the earth's magnetic field decides to reverse, of course... SCott in VAncouver RV-6, 150 hours resting on one gear leg. ----- Original Message ----- From: "Ollie Washburn" <ollie-6a(at)prodigy.net> Subject: Re: RV-List: Refilling Compass > > KB-----My advice is to just send for the repair kit from ACS or some other > supplier and this will give you the correct fluid and ALL the seals.Why > not > do it the right way? > Ollie-------Dodging hurricanes in Fl. > > ----- Original Message ----- > From: "Kyle Boatright" <kboatright1(at)comcast.net> > To: > Subject: RV-List: Refilling Compass > > >> >> My compass has run low on fluid after 3.5 years of slooooooowly losing >> fluid somewhere. No idea where the leak is, because I've never noticed a >> drip, a damp spot, or anything other than a slowly falling fluid level. >> Anyway, what's involved in re-filling it? How does it come apart? How >> does it go back together? How tight should I torque the fasteners that >> hold it together? I'd appreciate the whole run-down if someone can give >> it. >> >> Based on advice from the list and other sources, I'm going to refill it >> with low odor mineral spirits. >> >> Thanks in advance, >> >> KB >> >> >> > > > ________________________________________________________________________________
Date: Sep 11, 2004
NEVER EVER ANY ALCOHOL! ----- Original Message ----- From: "Scott Jackson" <jayeandscott(at)telus.net> Subject: Re: RV-List: Refilling Compass > > Cause you don't want to take that front off the compass! > Good luck getting it to seal again, even with a new gasket, even with two > gaskets, Fuel Lube, or Pro-Seal. > Change the rear diaphragm, as it may indeed have a tiny pinhole, and go with > the "plunge in a tin of alcohol and roll around until no more bubbles come > out" method of filling. > There, good for another fifty years. > Unless the earth's magnetic field decides to reverse, of course... > SCott in VAncouver > RV-6, 150 hours > resting on one gear leg. > ----- Original Message ----- > From: "Ollie Washburn" <ollie-6a(at)prodigy.net> > To: > Subject: Re: RV-List: Refilling Compass > > > > > > KB-----My advice is to just send for the repair kit from ACS or some other > > supplier and this will give you the correct fluid and ALL the seals.Why > > not > > do it the right way? > > Ollie-------Dodging hurricanes in Fl. > > > > ----- Original Message ----- > > From: "Kyle Boatright" <kboatright1(at)comcast.net> > > To: > > Subject: RV-List: Refilling Compass > > > > > >> > >> My compass has run low on fluid after 3.5 years of slooooooowly losing > >> fluid somewhere. No idea where the leak is, because I've never noticed a > >> drip, a damp spot, or anything other than a slowly falling fluid level. > >> Anyway, what's involved in re-filling it? How does it come apart? How > >> does it go back together? How tight should I torque the fasteners that > >> hold it together? I'd appreciate the whole run-down if someone can give > >> it. > >> > >> Based on advice from the list and other sources, I'm going to refill it > >> with low odor mineral spirits. > >> > >> Thanks in advance, > >> > >> KB > >> > >> > >> > > > > > > > > ________________________________________________________________________________
Subject: Vans Tachometer Transducer - heads up
Date: Sep 11, 2004
Back in June 2002, Mel Jordan posted a very informational post on this list. It concerned the tachometer transducer that VANs sell for their electronic tach. I followed Mel's experience and when it came time to set my EIS to the number of pulses per revolutions, I just assumed I should use the same value Mr. Jordan has found to work. Well, to make this story short and cut to the chase, I just have these lessons for anyone who is considering this route: 1. The transducer works really well (so far). 2. Maybe it is a different model transducer, but the important thing is to check for yourself how many pulses per revolutions YOUR system puts out. I am not even going to tell you the number I have, so that no one will be tempted to blindly follow this number like I did with the number Mel has found to work for him. Borrow/buy/steal a tachometer you can cross-check with. Thats all I had to say. No damage done, just a lesson learned, and thanks MGM for letting me borrow your optical tach. Amit. ________________________________________________________________________________
Subject: Re: Asphault floors
Date: Sep 11, 2004
I only get the digest and am a couple of days behind in reading them so someone may have mentioned this. but FWIW: In addition to wear and color problems, asphault can present some serious hazards when solvents are spilled on it. Some HAZ-MAT training I went through as a local vol. fireman thuroughly spooked me from putting asphault down for a garage or hanger floor. If I was forced to have an existing hanger with such a floor I'd get it sealed and then capped with a coat of concrete. DWStiles NIles MI ________________________________________________________________________________
Date: Sep 11, 2004
Subject: [ Bob Olds ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Bob Olds Subject: Vortex generators on RV-4 http://www.matronics.com/photoshare/Oldsfolks@aol.com.09.11.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Airborne!
Date: Sep 11, 2004
The day I though would never come, finally did. I flew N130WN for .8 hours today. Exhilarating, but uneventful. Ooo, ooo, ooo does it feel good! More details on my website over the coming days. Many thanks to all who have help over the years.... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Sep 11, 2004
Subject: Re: E-MAG ELECTRONIC IGNITION
You must have a constant speed prop since your producing the popping noise on decent. This is pretty normal and I think your thoughts about low backpressure and such is right on the money. CHT's seem normal for a new engine. Wait a few hours and they should drop. My number 3 runs at 360 in cruise and close to 400 on climbout at 140 mhp IAS. Gary Bruno wrote: > >Hello All > I just received an e-mail from Brad Dement from E-MAG >Electronics who let me know about their systems. I never heard of them and I >was wondering if anyone has any info on this compagny and products. > >Has anyone ever saw them in Oshkosh or S & F , or actually saw or used their >products. > >Theirs product look from the outside a lot like a Lazar System but with a >few differences. > >If you wanna have a look, go to : > > <http://www.emagair.com> www.emagair.com > >Thanks for any imputs you may have > >Bruno Dionne > >C-GDBH RV-4 > >rv4(at)videotron.ca > > > > ________________________________________________________________________________
Date: Sep 12, 2004
John, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A >From: "John Wiegenstein" <n727jw(at)hellerwiegenstein.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: First Flight: N727JW (RV-6 S/N 23961) >Received by mail server with no name > > > >I am VERY pleased to report that RV-6 N727JW >has finally taken flight. John,> >Gotta go fly now! >John H. Wiegenstein >HELLER WIEGENSTEIN PLLC >19301 - 8th Ave. NE, Suite A >Poulsbo, WA 98370 >(360) 394-3500 >(360) 394-3503 FAX >johnw(at)hellerwiegenstein.com >www.hellerwiegenstein.com > > ________________________________________________________________________________
Subject: Airborne!
Date: Sep 12, 2004
Larry, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A >From: "Larry Bowen" <Larry(at)bowenaero.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Airborne! >Date: Sat, 11 Sep 2004 20:35:33 -0400 > > >The day I though would never come, finally did. I flew N130WN for .8 hours >today. Exhilarating, but uneventful. Ooo, ooo, ooo does it feel good! >More details on my website over the coming days. Many thanks to all who >have help over the years.... > >- >Larry Bowen >Larry(at)BowenAero.com >http://BowenAero.com > > Check out Election 2004 for up-to-date election news, plus voter tools and ________________________________________________________________________________
Subject: Re: Airborne!
Date: Sep 12, 2004
Congratulations, Larry. A long time coming, but as you know - well, worth it.! Ed Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC ----- Original Message ----- From: "Larry Bowen" <Larry(at)bowenaero.com> Subject: RV-List: Airborne! > > The day I though would never come, finally did. I flew N130WN for .8 hours > today. Exhilarating, but uneventful. Ooo, ooo, ooo does it feel good! > More details on my website over the coming days. Many thanks to all who > have help over the years.... > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > ________________________________________________________________________________
Date: Sep 12, 2004
Subject: getting duct tape off Aluminum Skin
I've been re-reminded how tenacious duct tape wants to stick to Al and how paint does not. They should make paint from duct tape formula. What's the BEST cleaner for removing the glue without damaging the alclad finish? My wax remover/degreaser & alcohol doesn't phase it. ________________________________________________________________________________
Date: Sep 12, 2004
"Goof-Off" loves to eat adhesive. (Avail. at Home Depot/Lowes) Whether or not it damages the alclad - don't know. Dave > [Original Message] > From: <RV8ter(at)aol.com> > To: ; > Date: 9/12/2004 10:12:48 AM > Subject: RV-List: getting duct tape off Aluminum Skin > > > I've been re-reminded how tenacious duct tape wants to stick to Al and how > paint does not. They should make paint from duct tape formula. > > What's the BEST cleaner for removing the glue without damaging the alclad > finish? My wax remover/degreaser & alcohol doesn't phase it. > > ________________________________________________________________________________
Date: Sep 12, 2004
I've used Naptha, aka Coleman's Lanturn Fuel. Or MEK if you want to bring out the big guns. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: RV8ter(at)aol.com [mailto:RV8ter(at)aol.com] > Sent: Sunday, September 12, 2004 10:13 AM > To: rv-list(at)matronics.com; vansairforce(at)yahoogroups.com > Subject: RV-List: getting duct tape off Aluminum Skin > > > I've been re-reminded how tenacious duct tape wants to stick > to Al and how paint does not. They should make paint from > duct tape formula. > > What's the BEST cleaner for removing the glue without > damaging the alclad finish? My wax remover/degreaser & > alcohol doesn't phase it. > ________________________________________________________________________________
Subject: Re: getting duct tape off Aluminum Skin
Date: Sep 12, 2004
I've used "adhesive removing solvent" (it's name) available in any automotive paint store. It's safe for even painted surfaces. That said, for adhesive on alclad I'd use acetone. Low health risk and cheap. Don't get it near plexi or paint... ________________________________________________________________________________
Date: Sep 12, 2004
RV8ter(at)aol.com wrote: > >I've been re-reminded how tenacious duct tape wants to stick to Al and how >paint does not. They should make paint from duct tape formula. > >What's the BEST cleaner for removing the glue without damaging the alclad >finish? My wax remover/degreaser & alcohol doesn't phase it. > The best stuff is kerosene ...... and if you don't have that use mineral spirits. Put a paper towel over the tape area and keep wet until the stiff dissolves again. Good luck Linn > > > > ________________________________________________________________________________
Date: Sep 12, 2004
David Fenstermacher wrote: > >"Goof-Off" loves to eat adhesive. (Avail. at Home Depot/Lowes) >Whether or not it damages the alclad - don't know. > >Dave > It won't. Linn > > > >>[Original Message] >>From: <RV8ter(at)aol.com> >>To: ; >>Date: 9/12/2004 10:12:48 AM >>Subject: RV-List: getting duct tape off Aluminum Skin >> >> >>I've been re-reminded how tenacious duct tape wants to stick to Al and >> >> >how > > >>paint does not. They should make paint from duct tape formula. >> >>What's the BEST cleaner for removing the glue without damaging the alclad >>finish? My wax remover/degreaser & alcohol doesn't phase it. >> >> >> >> > > > > ________________________________________________________________________________
Subject: Re: [VAF Mailing List] getting duct tape off Aluminum Skin
Date: Sep 12, 2004
Get some "Goo Gone" from you local Home Depot etc. It works great on lots of things....hurts none. Ed O'Quinn ----- Original Message ----- From: <RV8ter(at)aol.com> Subject: [VAF Mailing List] getting duct tape off Aluminum Skin > I've been re-reminded how tenacious duct tape wants to stick to Al and how > paint does not. They should make paint from duct tape formula. > > What's the BEST cleaner for removing the glue without damaging the alclad > finish? My wax remover/degreaser & alcohol doesn't phase it. > > > [Non-text portions of this message have been removed] > > > http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/1yWplB/TM > > Online help on this group at: > http://help.yahoo.com/help/groups/ > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/vansairforce/ > > <*> To unsubscribe from this group, send an email to: > vansairforce-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > ________________________________________________________________________________
Subject: QB Interior Paint
Date: Sep 12, 2004
Hello, What has everyone been using to paint the interior of their QB fuselages? What prep did you do to the wash primer that was applied at the factory. Thanks, Pete ________________________________________________________________________________
Date: Sep 12, 2004
Goo Gone works great. Also very effective is Ronson lighter fluid. On items that aren't ever going to be painted or are already painted, WD40 on a soft cloth will clean well too. Darwin N. Barrie Chandler AZ ----- Original Message ----- From: "Ed O'Quinn" <edoquinn77(at)charter.net> Subject: Re: [VAF Mailing List] getting duct tape off Aluminum Skin > Get some "Goo Gone" from you local Home Depot etc. > It works great on lots of things....hurts none. > Ed O'Quinn > > ----- Original Message ----- > From: <RV8ter(at)aol.com> > To: ; > Sent: Sunday, September 12, 2004 9:12 AM > Subject: [VAF Mailing List] getting duct tape off Aluminum Skin > > > > I've been re-reminded how tenacious duct tape wants to stick to Al and how > > paint does not. They should make paint from duct tape formula. > > > > What's the BEST cleaner for removing the glue without damaging the alclad > > finish? My wax remover/degreaser & alcohol doesn't phase it. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > Online help on this group at: > > http://help.yahoo.com/help/groups/ > > > > > > > > > > > > > > > http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/1yWplB/TM > > Online help on this group at: > http://help.yahoo.com/help/groups/ > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/vansairforce/ > > <*> To unsubscribe from this group, send an email to: > vansairforce-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > ________________________________________________________________________________
Date: Sep 12, 2004
Subject: Re: QB Interior Paint
Perfectly timed question as that's what I'm doing this weekend. Friend with QB fuse just wiped everything down with painter's, lint free cloth using wax remover/degreaser the shot it with gray cockpit paint out of Spruce. It's got that rough textured finish that wears well and is super easy to touch up. Home Depot sells a brand of gray stone finish or something like that which he bought a can of because it's an almost exact match and when you spray that stuff on top of itself you can't tell you had a blemish. So, I'm repeating his process. In a message dated 9/12/2004 12:43:28 PM Eastern Standard Time, pete.howell@gecko-group.com writes: Hello, What has everyone been using to paint the interior of their QB fuselages? What prep did you do to the wash primer that was applied at the factory. Thanks, Pete ________________________________________________________________________________
Date: Sep 12, 2004
Try Goo-Gone, available at grocery stores. Or laquer thinner. ----- Original Message ----- From: <RV8ter(at)aol.com> Subject: RV-List: getting duct tape off Aluminum Skin > > I've been re-reminded how tenacious duct tape wants to stick to Al and how > paint does not. They should make paint from duct tape formula. > > What's the BEST cleaner for removing the glue without damaging the alclad > finish? My wax remover/degreaser & alcohol doesn't phase it. > > > ________________________________________________________________________________
Date: Sep 12, 2004
From: Chris W <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net>
linn walters wrote: >The best stuff is kerosene ...... and if you don't have that . . . > > If you don't have kerosene just go to the FBO and get some Jet fuel, pretty much the same thing. -- Chris W Bring Back the HP 15C http://hp15c.org Not getting the gifts you want? The Wish Zone can help. ________________________________________________________________________________
Subject: Why such short rivets?
Date: Sep 12, 2004
Eddie, I work at Alexander Technical Center in Griffin Ga as an instructor for their RV quick start tail assembly program. I have work there for two years and have been involved with over 100 tail kits. This is what I have learned. If you use the Mil-Spec Mil-R-4719A as your guide the rivets listed are too short. See http://home.flash.net/~gila/rivet_spec/rivet_a.htm The plans call for AN470AD4-5 to join the hinge brackets HS-411BPP, HS-411APP and VA-146 hinge bearing. It is too short. I use AN470AD4-6 The plans call for AN470AD4-6 to join all HS-609PP to HS-603PP. I use AN470AD4-7 To join HS-412PP, HS-609PP AND HS-603PP I use AN470AD4-8 To join HS-413PP to HS-603PP the listed rivet AN470AD4-5 is too long. I use AN470AD4-4.5 The AN470AD4-4 rivets listed to join HS-603PP to HS-706 are the correct length I find the above to be correct for both the RV7 and RV8. Mike Crowe According to the plans HS609PP is supposed to be riveted to HS603PP using AN470AD4-6 rivets. But when I did a test fitting the rivet looked too short. I got out the avery gauge, and indeed it looks about 1/8" shorter than the Gauge says it should be. --Eddie ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Sep 12, 2004
> Hello, > > What has everyone been using to paint the interior of their > QB fuselages? What prep did you do to the wash primer that > was applied at the factory. > > Thanks, > > Pete Pete, I used Imron. It is quite durable - I've got it on the rudder pedals in my 6A and no wear or chips on them in 522 hours. I'm sure other paint is equally durable, check with Valspar's reps. Alex Peterson Maple Grove, MN RV6-A N66AP 522 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: RV3 Project
Date: Sep 12, 2004
Sept Sport Aviation is listing an RV3 with engine and it sounds as if it is pretty well along in construction for $10K (want ad section) John ________________________________________________________________________________
Date: Sep 12, 2004
I guess I should have gotten on this sooner. Anyway, a few suggestions for those brave experimenters who shun ordinary compass fluid: Chicken fat will solidify at low temperatures unless you thin it with ordinary compass fluid. Jack Daniels is too expensive but some cheap rums might do. Gasoline is flammable so leaks might be bad. Also, Homeland Security might ban it. One our California airports once banned storage of any gasoline in hangars, fearing the fire hazard. Glacial acetic acid might work and would have the advantage that you will certainly know the instant it starts to leak. Downside is that eyes may swell shut before you get to the airport. You could carry dry ice along and freeze the leaking acid. Urine from a small redhaired boy who has been drinking lots of pop could be mixed equal parts by weight with sugar. After a few days in the sun this too would get your attention if it leaked. Others have any ideas? We should select the best fluid before the FAA mandates something that costs $87.07 per fill! Silly in Paso Robles, hal ________________________________________________________________________________
Date: Sep 12, 2004
In a message dated 9/12/2004 2:05:51 PM Pacific Daylight Time, kempthornes(at)earthlink.net writes: I guess I should have gotten on this sooner. Anyway, a few suggestions for those brave experimenters who shun ordinary compass fluid: ======================================== I still think that DOT 5 (silicone) brake fluid would be ideal, but have not tried it. GV (RV-6A N1GV O-360-A1A C/S, flying 719 hrs) ________________________________________________________________________________
Subject: Tools needed to build a RV tail kit
Date: Sep 12, 2004
To introduce myself first I am an A&P mechanic with an IA. I work as a Lead Mechanic for a major air line. For the past two years I have worked part time at the Alexander Technical Center at Griffin GA. as an instructor on their quick start tail assembly program. http://www.buildtofly.com/ I have been involved in over 100 tail kits. I have worked on the 6,7,8,9 and 10 kits; I am also building a RV8A myself. As each class begins I ask if the student have already purchased their tools. My hopes are that they have not as we have a good selection of tools to try from the different manufacturers. The ones that have gotten their tools before coming often say I wish I had gotten this tool or that tool instead. In the following I will try to give you a list and suggestions of tools that I have learned over the past two years. Please keep in mind that this information is my opinion and mine alone. Others may agree or disagree. There are two major suppliers of tools for the RV tail kits that I recommend Avery http://www.averytools.com/ and Cleaveland http://www5.mailordercentral.com/clevtool/home.asp both are RV builders and are good and honest people to do business with. I would buy a tool kit from Avery or Cleaveland to begin with. Both will allow you to add or subtract the tools you want to the kit. I will use both their 2004 catalogs as a guide. First if you buy Cleaveland's kit I would buy their complete airframe tool package p/n Comp-Kit 04. I would subtract from the kit: BBRP-48 Back Riveting Plate-It is a nice plate but too small in my opinion CF-80 C-Frame Riveting Tool-More about C-Frames later but if you get this one also order their C-From Table Kit CTF-48 ASRD-14 Air Swivel Regulator- I have found the round knob regulator is hard to regulate I would add to the kit: I would upgrade to the 3X Rivet gun- The 2x works good on the 3/32 rivet but not well on the 1/8 rivet. Get a 3x to work well on the 1/8 and turn down the pressure a little to do the 3/32 or better yet buy one of each. DP-8 Drive Pin Punches- This is a nice punch set you could get by with only the 3/32 and 1/8 (you will be removing a few bad rivets) LBL-13 BOELUBE Do not drill lead without it. 3MW-77S6 Light deburring wheel- You get a rougher one in the kit you need both. Go to Home Depot or Lowe's and get a grinder and install these wheels. 3MP-47 Scotch-Brite pads-you will need plenty DIE509-10 #10 SCREW DIMPLE DIES-You will need these to dimple for the screws for the lead weights SNYT-45 4in THIN NOSE YOKE- You are going to need a thin nose and a 4in nose get them both in one. SNYF-35 2.5in FLANGE NOSE YOKE- There is places where nothing else is going to reach. RSMS-75 SWIVEL FLUSH SET WITH RUBBER GUARD-You must cut some of the rubber down or you rivets will set too high CLP-20 CLEKO PLIERS-One is not enough. CLC-50 1/2in CLEKO CLAMP-You get 4. You need at least 10 CLC-100 1in CLEKO CLAMP-You get 4. You need at least 10 For the RV9 DIECS4-4 120 DEGREE DIES FOR 1/8 POP RIVETS-You use a lot of CS4-4 on the skin of your elevators they are 120 degrees. For our RV10 friends RSB-12 12in back rivet set-You will need this to back rivet the stiffeners on the elevators. The RV10 will also need BBRV10 SPECIAL BUCKING BAR-You will need this for the elevators. I would buy from Avery to complete the kit from Cleaveland 575 hand seamer 3-1/2 jaw-I use this to squeezing the trailing edge of the trim tabs. 550 3/32 vise grip dimplers- several places on ribs this is needed. 150 AIR TOOL REGULATOR-This one is easier to adjust. 1046 SPEED DEBURRING AND COUNTERSINKING TOOL 23904 4 PC. HOOK AND PICK SET-You will need a pick many times for aligning skins For the RV9 42120 SPECIAL 120 DEGREE COUNTERSINK-Used where you use CS4-4 rivets on the elevators. If you buy an Avery tool kit, I would buy the RV-3,-4-6-7-8-9and -10 builders tool kit. I would subtract from the kit 1001 22in hand rivet and dimpling tool-it is there c-frame tool a good tool but see below about a c-frame tool 10765 POLYETHYLENE DIMPLING MALLET-Goes with the c-frame tool. If you get the c-frame tool get the mallet. 500 FLUTING PLIERS- You need a pair of fluting pliers I like Cleaveland's a lot better. 1042 EDGE ROLLING TOOL- I can not get this tool to work for me. It could just be me. 3507 3M RIVETING TAPE-Works well. If you use it take it off after use it is real hard to get off later. Use Scotch Removable Magic Tape works as well and much cheaper. 9885 ANGLE DRILL KIT- Nice kit not needed for the tail kit could be used later. 1054 NBR 8 SCREW COUNTERSINK CUTTER-Not needed for the tail kit. 25500 SWIVEL HEAD POP RIVET TOOL-If you must use a hand pop tool use Cleaveland's PRS-20 it is much easier to squeeze. I would add to the kit: 7760 4in NO HOLE YOKE 7755 LONGERON YOKE 811 RIVETING TAPE-Scotch removable magic tape. 1003 BOELUBE Do not drill lead without it. 200 CLECO PLIERS-One is not enough. 1661 Light deburring wheel- You get a rougher one in the kit you need both. Go to Home Depot or Lowe's and get a grinder and install these wheels. 23904 4 PC. HOOK AND PICK SET-You will need a pick many times for aligning skins. For the RV9 42120 SPECIAL 120 DEGREE COUNTERSINK-Used where you use CS4-4 rivets on the elevators. For the RV10 630 RV10 ELEVATOR BUCKING BAR I would by from Cleaveland to complete the Avery kit:. 3MP-47 Scotch-Brite pads-you will need plenty DIE509-10 #10 SCREW DIMPLE DIES-You will need these to dimple for the screws for the lead weights EF-60 EDGE FORMER-Needed at seams HS-30 OFFSET HAND SEAMER-Used many places FP-200 FLUTING PLIERS-Used to straighten ribs For the RV9 DIECS4-4 120 DEGREE DIES FOR 1/8 POP RIVETS-You use a lot of CS4-4 on the skin of your elevators they are 120 degrees. For our RV10 friends RSB-12 12in back rivet set-You will need this to back rivet the stiffeners on the elevators. Tools that would be nice to have: PNEUMATIC SQUEEZER- In my opinion a must have. Get a 214 style. Make sure to get an adjustable set holder for it. PNEUMATIC POP RIVET GUN-Go to harbor freight or such and get one for around $40.00 LIGHTWEIGHT HOSE KITS-Makes it a lot easier to handle drills and rivet guns TATCO HAND SQUEEZER WITH 2in YOKE-Makes it a lot easier to dimple all those ribs C-FRAME DIMPLER EXPERIMENTAL AERO http://www.experimentalaero.com/ I brought a DRDT-1 dimplier and installed it at Alexander Technical Center to try it out in January this year. Boy was that a mistake. There is no way I am getting it back. It is the best I have used for dimpling. It gives best dimples; it is consistent, quiet and a one man operation. There is no way I am going back to the old c-frame hammer method. Now if I need to dimple I pack up what I have and drive 32 miles even though I have a hammer c- Frame dimplier at home. It is that much better. They now sell the DRDT-2 which has some improvement over the -1. Mike Crowe ________________________________________________________________________________
Subject: Aileron Twist
Date: Sep 12, 2004
All, I am finsihing up the riveting of the left aileron. I have riveted the top side and attached the brackets. When I lay the piece flat on a bench (clecoed) to start on the bottom, I noticed that there is approx. .145" twist in it. The instructions say to weigh it down while riveting the bottom. I seriously doubt that will take care of the twist, as I can see that piece just popping back to shape after the weight is removed. Is there anything I can do to get it back to shape before riveting the bottom? Is that amount of twist excessive (it seems to be to me). Thanks, Scott 7A Wings Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Subject: Re:Solid State gyro Dynon D-10 errors
Date: Sep 12, 2004
It would also be interesting to know what you did with the pito & static ports when you brought your unit into the shop. The Dynon unit uses these ports for additional stabilization (instead of a GPS input)....... I've been flying a Dynon D-10 unit for over 270 Hrs, and have yet to notice (It's a backup unit) any problems... Fred Stucklen RV-6a N926RV Hi Ed I'd be interested and I'm certain that Dynon would as well to know what engines are in the planes that are experiencing these problems. As you & I both know, even the smooth rotary has it's own harmonic vibrations, however in almost 40 hours of flying my Dynon I've yet to see any errors (but I'm watching closely). I'd like to hear what engine/prop/ignition combinations are involved to see if there is a common thread. When I first received my Dynon, I brought it to work at a large mill (had to show it off to the other instrument mechanics:-) and when turned on it immediately showed a ~30 degree right bank and a ~10 degree down pitch. The error remained steady at all times within the shop at the mill. The shop is solid concrete and feels rock steady, but there was something in there that was affecting the Dynon. At home it performed flawlessly again, so I brought it back to work the next day. Same error again. At that time I began to wonder if vibration or quite possibly electromagnetic interference from all the industrial equipment was the cause. After installing it I'd pretty much forgotten about that until now. Just another bit of info to consider..... Todd Bartrim (Love my Dynon) RV9Endurance 13B Turbo Rotary C-FSTB ________________________________________________________________________________
Date: Sep 12, 2004
Subject: Van's Air Force 'RV Hotel' list usage
Just heard from my neighbor that there is an RVer & wife from Dallas stranded at Bruce Campell Field near Jackson MS. I found out too late to catch them at the airport & offer assistance/lodging (they had already left for a motel). I haven't seen the following mentioned on the RV list lately so maybe it's time for a reminder & to let new arrivals know about it: http://www.vansairforce.net/rvtravelpages.htm It's a list with locations/contact numbers of RVers willing to host other RV-x travelers and/or assist with problems. Just about every state, with most major & a lot of minor cities are represented. All of us offer overnight lodging & many can offer hangar space as well. Just a reminder that help might be nearby if you need it & new friends a phone call away. Charlie flying -4, -7 wings Slobovia Outernational Airport ________________________________________________________________________________
Date: Sep 12, 2004
Subject: Mike Seager
Those that wish some check out time with Mike Seager in his new RV7 I still have some slots open Sat 18th and 17th at our Annual RV fly in at lebanon,Tn the 18th (M54) 20 miles east of Nashville... John McMahon (RV6 near paint) 615-452-8742 ________________________________________________________________________________
Date: Sep 12, 2004
Subject: Re: Refilling Compass
In a message dated 9/12/04 4:05:51 PM US Eastern Standard Time, kempthornes(at)earthlink.net writes: > Others have any ideas? We should select the best fluid before the FAA > mandates something that costs $87.07 per fill! > > Silly in Paso Robles, > > hal > Hi Hal, I posted this a few weeks ago, but here it is again: Ultra pure lamp oil from any of the Home Depot type stores. Look near the candles and that kind of stuff. This should be similar to the high grade of kerosene that the compass makers use. That's what I fly with, I'm sure the flamers will get me! Dan Hopper RV-7A (Flying 2 months now -- 43 hours) ________________________________________________________________________________
Date: Sep 12, 2004
Subject: RV List Great Plane!!
Just thinking back.......Wow!!! Got up Sat. morning and the day looked like a nice day to fly. A friend had moved from here (east mississippi ) to N. Carolina and still had a place in a hanger here. He called earlier in the week and was looking for a ride back to get hes plane. I went out my back door of the house and a few more steps brought me to the hanger. I checked over my R.C. every thing looked well. Pushed it out and climbed on board....what a nice feeling!.....went through the check list and proceeded to start the O 320. With about 2 bldes passing the plane geve a shake and the engine came to life. ( to you guys still building its a sound something like this YOU GIVE ME SOME THROTTLE AND I'M GONNA TAKE YOU SCREAMIN INTO THE AIR......) I taxi onto our private grass strip making a few s-turns thinkin how cool it is to have a tail dragger. With a short run- up cycle the prop and i'm in the air. I cruise over to Fayette Al. grab some fuel and walk up to a restaurant for a light breakfast. By this time it is about 7:15 a short walk back to the plane and i'm off again. Back in the air I climb to 9500ft above the haze and any small clouds and watch the ground speed go up to 176Kn (had a tail wind of 13kn) Thinking wow this is the way to travel. As I pass north of Atlanta the GS slows to about 164Kn the wind had become calm and stayed that way the rest of the trip. About 2hr35min after takeoff I start a 500f/m decent and in another 18min Im lookin at a 3500ft runway just south of Fayettville North Carlina. I drop in and find a guy is building a -6 on the field chat to a few guys and pick my friend up and start back. the trip back is uneventful. With the same speeds ( started about 163kn then went to about 172kn and back to 165kn the wind was in my favor all day. Just dodging a few clouds that had started to build we stop in at Pell City,Al for lunch and fuel and from there head into Miss. Drop my friend off in Abredeen Ms and then go on to the house. Do the normal fly-by(check the runway approach) then come around,Land, and push the plane in the hangar it is now 3:45 in the afternoon. MAN it was a GREAT!!!!! DAY!! all from the back yard. Yall keep poundin them rivets!! Weasel Graber -4 (75hr) Brooksville MS Get your name as your email address. Includes spam protection, 1GB storage, no ads and more Only $1.99/ month - visit http://www.mysite.com/name today! ________________________________________________________________________________
Date: Sep 13, 2004
Subject: Re: Aileron Twist
Scott; After you have the bottom skin-to-spare row of rivets in, you may well find that the aileron lays flat and remains flat. Squeezing or driving rivets can cause a subtle deformation of the parts. Usually this is an undesirable thing to be avoided, in this case it may work in your favour. So, my suggestion would be to weight the aileron down, do the riveting and then see what it looks like. With some luck the twist may simply be gone. Is 0.145 in of twist too much? Well, that is a matter of opinion. Considering the rather small area of an aileron compared to a wing panel, the aerodynamic effect will probably be insignificant at the end of the day. In other words a tiny twist in the wing will more than over-compensate for the aileron twist or the aileron twist will not be noticeable compared to the wing's effect. The other consideration is simple cosmetics - will it look nice enough at fly-ins? Keep in mind that few people will be looking that closely at your ailerons - only you will really know its there. If you press on and the other 99.5 % of your airplane is perfect and the only flaw is a slight twist in an aileron, then it would be time to go back and build a new aileron. Til then simply press on. Jim Oke RV repeat offender Wpg.., MB ----- Original Message ----- From: <tx_jayhawk(at)excite.com> Subject: RV-List: Aileron Twist > > > All, > > I am finsihing up the riveting of the left aileron. I have riveted the > top side and attached the brackets. When I lay the piece flat on a bench > (clecoed) to start on the bottom, I noticed that there is approx. .145" > twist in it. The instructions say to weigh it down while riveting the > bottom. I seriously doubt that will take care of the twist, as I can see > that piece just popping back to shape after the weight is removed. Is > there anything I can do to get it back to shape before riveting the > bottom? Is that amount of twist excessive (it seems to be to me). > > Thanks, > Scott > 7A Wings > > Join Excite! - http://www.excite.com > The most personalized portal on the Web! > > > ________________________________________________________________________________
Date: Sep 13, 2004
Thanks Jim. I appreciate the feedback. --- On Tue 09/14, Jim Oke < wjoke(at)shaw.ca > wrote: From: Jim Oke [mailto: wjoke(at)shaw.ca] Date: Mon, 13 Sep 2004 23:09:02 -0500 Subject: Re: RV-List: Aileron Twist Scott; After you have the bottom skin-to-spare row of rivets in, you may well find that the aileron lays flat and remains flat. Squeezing or driving rivets can cause a subtle deformation of the parts. Usually this is an undesirable thing to be avoided, in this case it may work in your favour. So, my suggestion would be to weight the aileron down, do the riveting and then see what it looks like. With some luck the twist may simply be gone. Is 0.145 in of twist too much? Well, that is a matter of opinion. Considering the rather small area of an aileron compared to a wing panel, the aerodynamic effect will probably be insignificant at the end of the day. In other words a tiny twist in the wing will more than over-compensate for the aileron twist or the aileron twist will not be noticeable compared to the wing's effect. The other consideration is simple cosmetics - will it look nice enough at fly-ins? Keep in mind that few people will be looking that closely at your ailerons - only you will really know its there. If you press on and the other 99.5 % of your airplane is perfect and the only flaw is a slight twist in an aileron, then it would be time to go back and build a new aileron. Til then simply press on. Jim Oke RV repeat offender Wpg.., MB ----- Original Message ----- From: <tx_jayhawk(at)excite.com> Subject: RV-List: Aileron Twist > > > All, > > I am finsihing up the riveting of the left aileron. I have riveted the > top side and attached the brackets. When I lay the piece flat on a bench > (clecoed) to start on the bottom, I noticed that there is approx. .145" > twist in it. The instructions say to weigh it down while ri veting the > bottom. I seriously doubt that will take care of the twist, as I can see > that piece just popping back to shape after the weight is removed. Is > there anything I can do to get it back to shape before riveting the > bottom? Is that amount of twist excessive (it seems to be to me). > > Thanks, > Scott > 7A Wings > > Join Excite! - http://www.excite.com > The most personalized portal on the Web! > > > =============================== Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Date: Sep 13, 2004
Pete, We used SunFire by Serwin Williams (a two part paint) has held up well. Check the archives for additional postings. Good Building, Chuck Rowbotham RV-8A >From: "Pete Howell" <pete.howell@gecko-group.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: QB Interior Paint >Date: Sun, 12 Sep 2004 11:42:05 -0500 > > >Hello, > >What has everyone been using to paint the interior of their QB fuselages? >What prep did you do to the wash primer that was applied at the factory. > >Thanks, > >Pete > > ________________________________________________________________________________
Date: Sep 13, 2004
Eddie, Could be mis-labeled parts. I any event I remember reading in the early 8 plans that the builder should confirm the correct rivet lenght. Good catch. Good Building, Chuck Rowbotham RV-8A >From: "Michael D Crowe" <rv8a(at)bellsouth.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RE: RV-List: Why such short rivets? >Date: Sun, 12 Sep 2004 14:01:51 -0400 > > >Eddie, > > I work at Alexander Technical Center in Griffin Ga as an instructor for >their RV quick start tail assembly program. I have work there for two years >and have been involved with over 100 tail kits. This is what I have >learned. >If you use the Mil-Spec Mil-R-4719A as your guide the rivets listed are too >short. See http://home.flash.net/~gila/rivet_spec/rivet_a.htm > >The plans call for AN470AD4-5 to join the hinge brackets HS-411BPP, >HS-411APP and VA-146 hinge bearing. It is too short. I use AN470AD4-6 > >The plans call for AN470AD4-6 to join all HS-609PP to HS-603PP. I use >AN470AD4-7 > >To join HS-412PP, HS-609PP AND HS-603PP I use AN470AD4-8 > >To join HS-413PP to HS-603PP the listed rivet AN470AD4-5 is too long. I use >AN470AD4-4.5 > >The AN470AD4-4 rivets listed to join HS-603PP to HS-706 are the correct >length > >I find the above to be correct for both the RV7 and RV8. > >Mike Crowe > > >According to the plans HS609PP is supposed to be riveted to HS603PP using >AN470AD4-6 rivets. But when I did a test fitting the rivet looked too >short. > >I got out the avery gauge, and indeed it looks about 1/8" shorter than the >Gauge says it should be. > >--Eddie > > ________________________________________________________________________________
Subject: fuel return line
Date: Sep 13, 2004
Hi all, I putting a fuel return line back into my tanks and since the proper aviation tubing is so expensive and hard to get here I was wondering if normal commercial grade aluminium tubing is satisfactory for the return lines and also the rest of the fuel system. One thing though the commercial stuff here is metric, but as far as I can tell only a fraction of a millimetre different. Any opions and experiences? Greg RV8 ________________________________________________________________________________
Subject: Re: Mike Seager
Date: Sep 13, 2004
John, I just got back from our Van's Homecoming/Seattle trip. I was able to get a little time with Mike in the "Old Blue" 6A while I was there. I never got "comfortable" in the plane so, if you have a slot open on Friday the 17th pencil me in. Tommy in Ridgetop ----- Original Message ----- From: John McMahon<mailto:rv6(at)earthlink.net> To: RV LIST Sent: Sunday, September 12, 2004 8:12 PM Subject: RV-List: Mike Seager Those that wish some check out time with Mike Seager in his new RV7 I still have some slots open Sat 18th and 17th at our Annual RV fly in at lebanon,Tn the 18th (M54) 20 miles east of Nashville... John McMahon (RV6 near paint) 615-452-8742 ________________________________________________________________________________
Date: Sep 13, 2004
From: Scott Bilinski <bilinski@kyocera-wireless.com>
I had really bad popping when throttled back all the way. I found that the idle mixture was too rich and this has reduced the popping by 50%. This was on a injected engine. > >You must have a constant speed prop since your producing the popping >noise on decent. This is pretty normal and I think your thoughts about >low backpressure and such is right on the money. > >CHT's seem normal for a new engine. Wait a few hours and they should >drop. My number 3 runs at 360 in cruise and close to 400 on climbout at >140 mhp IAS. > >Gary > >Bruno wrote: > > > > >Hello All > > I just received an e-mail from Brad Dement from E-MAG > >Electronics who let me know about their systems. I never heard of them and I > >was wondering if anyone has any info on this compagny and products. > > > >Has anyone ever saw them in Oshkosh or S & F , or actually saw or used their > >products. > > > >Theirs product look from the outside a lot like a Lazar System but with a > >few differences. > > > >If you wanna have a look, go to : > > > > <http://www.emagair.com> www.emagair.com > > > >Thanks for any imputs you may have > > > >Bruno Dionne > > > >C-GDBH RV-4 > > > >rv4(at)videotron.ca > > > > > > > > > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Sep 13, 2004
Subject: Re: fuel return line
In a message dated 9/13/04 7:07:31 AM US Eastern Standard Time, greg(at)itmack.com writes: > > > Hi all, > I putting a fuel return line back into my tanks and since the proper > aviation tubing is so expensive and hard to get here I was wondering if normal > commercial grade aluminium tubing is satisfactory for the return lines and also > the rest of the fuel system. One thing though the commercial stuff here is > metric, but as far as I can tell only a fraction of a millimetre different. Any > opions and experiences? > > Greg RV8 > > Greg, I don't think that the soft aluminum tubing is anything special, except that it is probably seamless. Take a piece that you are going to use and bend it back and forth a few times and see if, when and how it fails. If possible do the same with some leftover tubing from Vans. If you are happy with the results, use it. Dan Hopper RV7A (Flying 2 months -- about 43 hours now) ________________________________________________________________________________
Subject: aileron twist
Date: Sep 13, 2004
Scott, Drill out the pop rivets that close the aileron, put a small shim, say 063, under the corner that causes an opposite twist. Weight the aileron down on your flat table and re-rivet everything. Run a drill through the holes if needed. We have fixed several using this technique. Works great. Vince Frazier F-1H Rocket, N540VF http://www.usi.edu/science/chemistry/vfrazier/page1.html All, I am finsihing up the riveting of the left aileron. I have riveted the top side and attached the brackets. When I lay the piece flat on a bench (clecoed) to start on the bottom, I noticed that there is approx. .145" twist in it. The instructions say to weigh it down while riveting the bottom. I seriously doubt that will take care of the twist, as I can see that piece just popping back to shape after the weight is removed. Is there anything I can do to get it back to shape before riveting the bottom? Is that amount of twist excessive (it seems to be to me). Thanks, Scott 7A Wings ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Sep 13, 2004
Hey Greg, where are you? If you just want the 1/4" vent line stuff, its cheap and I have a bunch of extra you can have. How much do you require? More interesting is the question of why you are putting in a return line. Are you powering your 8 with something special ? inquiring minds.... Evan (530)351-1776 www.evansaviationproducts.com ----- Original Message ----- From: "Greg@itmack" <greg(at)itmack.com> Subject: RV-List: fuel return line > > Hi all, > I putting a fuel return line back into my tanks and since the proper aviation tubing is so expensive and hard to get here I was wondering if normal commercial grade aluminium tubing is satisfactory for the return lines and also the rest of the fuel system. One thing though the commercial stuff here is metric, but as far as I can tell only a fraction of a millimetre different. Any opions and experiences? > > Greg RV8 > > ________________________________________________________________________________
Date: Sep 13, 2004
I use coleman lantern fuel. Takes it right off. -- Scott VanArtsdalen RV-4 N311SV, FLYING!! When a man does all he can though it succeeds not well, blame not him that did it." -- George Washington ________________________________________________________________________________
Date: Sep 13, 2004
If you want to use rattle cans I used Sherwin Williams self etching primer and gray propeller paint. It seems to work pretty well and cheap too. I used the same on the panel. Good Luck. Dick Dial RV6 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Rowbotham Subject: RE: RV-List: QB Interior Paint Pete, We used SunFire by Serwin Williams (a two part paint) has held up well. Check the archives for additional postings. Good Building, Chuck Rowbotham RV-8A >From: "Pete Howell" <pete.howell@gecko-group.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: QB Interior Paint >Date: Sun, 12 Sep 2004 11:42:05 -0500 > <pete.howell@gecko-group.com> > >Hello, > >What has everyone been using to paint the interior of their QB fuselages? >What prep did you do to the wash primer that was applied at the factory. > >Thanks, > >Pete > > = = = = ________________________________________________________________________________
Date: Sep 14, 2004
Thanks for your offer but I've got enough 1/4" vent line. I'm in Australia and I'm seriously thinking about putting a rotary into my 8. I know everyone says that fuel return lines aren't needed for Lycomings but they do seem to be needed for other engines, so I thought I'd at least install the line into the tank and if I don't use it I can cap it off. If anyone can explain why some engines need returns to the tanks and others don't I'd be interested. For instance I was told that continentals need returns to the tanks while Lycos just join up to the fuel line again before the pump. As an expert in fuel tanks I wonder if you could give some tips. When I drilled out the filler cap flange the cap was perfectly centred and after I riveted it the cap is now off to one side, not enough to affect operation I think but just enough to annoy me as the proud builder. I took into account the slight curve of the flange when I mounted it and I got the orientation the same when I riveted it on. I spoke to another local builder and he had the same thing happen to him. I still have another tank to build so I would like to get that one perfect. Thanks Greg RV8 wings > > Hey Greg, where are you? If you just want the 1/4" vent line stuff, its > cheap and I have a bunch of extra you can have. How much do you require? > More interesting is the question of why you are putting in a return line. > Are you powering your 8 with something special ? inquiring minds.... > Evan > (530)351-1776 > www.evansaviationproducts.com > > > ----- Original Message ----- > From: "Greg@itmack" <greg(at)itmack.com> > To: ; > Subject: RV-List: fuel return line > > > > > > Hi all, > > I putting a fuel return line back into my tanks and since the proper > aviation tubing is so expensive and hard to get here I was wondering if > normal commercial grade aluminium tubing is satisfactory for the return > lines and also the rest of the fuel system. One thing though the commercial > stuff here is metric, but as far as I can tell only a fraction of a > millimetre different. Any opions and experiences? > > > > Greg RV8 > > > > > > ________________________________________________________________________________
Date: Sep 13, 2004
In a message dated 9/13/04 6:53:18 PM US Eastern Standard Time, greg(at)itmack.com writes: > As an expert in fuel tanks I wonder if you could give some tips. When I > drilled out the filler cap flange the cap was perfectly centred and after I > riveted it the cap is now off to one side, not enough to affect operation I > think but just enough to annoy me as the proud builder. I took into account > the slight curve of the flange when I mounted it and I got the orientation > the same when I riveted it on. I spoke to another local builder and he had > the same thing happen to him. I still have another tank to build so I would > like to get that one perfect. > > Thanks > Greg RV8 wings > > Hi Greg, Could you have rotated the flange after first drilling it to the tank? 180 degrees would double any error. Just a guess. Dan Hopper RV-7A (Flying 2 months now) ________________________________________________________________________________
Date: Sep 13, 2004
Subject: Re: [ Bob Olds ] : New Email List Photo Share Available!
Hey Bob, Your VG's look like my VG's (Larry Vetterman VG's) but yours appear to be mounted a little further aft than mine. How far aft of the leading edge are your VG's... and can you submit another photo from a different angle? Thanks, Chuck Email List Photo Shares wrote: A new Email List Photo Share is available: Poster: Bob Olds Lists: RV-List,RV4-List,RV6-List,RV7-List,RV8-List,RV9-List,RV10-List Subject: Vortex generators on RV-4 http://www.matronics.com/photoshare/Oldsfolks@aol.com.09.11.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com --------------------------------- ________________________________________________________________________________
Date: Sep 14, 2004
Hi Greg, I can sympathise with you regarding the outrageous costs of items that the Yanks take for granted. Nevertheless, I would be wary about substituting an unknown al. tubing in something as critical as the fuel system. The best way might be to you get a roll of 3/8" tubing from Van's and have it added to someone's crate that is about to be shipped to Oz. There is a constant stream of stuff being shipped each week. As far as a return line is concerned, I think you will find that fuel injected engines often run a return line back to the tank, but not so carburated engines. Having said that, people with carb engines can route a return line that is supposed to remove bubbles between the mechanical fuel pump and the carby inlet, back to the tank. This is referred to as a vapour return line and seems to be recommended when using mogas due to its lower Reid Vapour Pressure, or its propensity to "boil" due to elevated temperatures and lower pressures that occur due to engine heat on the ground, and when flying at altitude. I am no expert, but I put one in my carburated Lycoming-powered RV-6 in case I used unleaded fuel in the future. Hope this helps Martin in Oz ________________________________________________________________________________
Date: Sep 13, 2004
Subject: Starter woes -- PM motors
Fellow listers, This was a hot topic a few weeks ago, and it has been on my mind since then. I have a question about PM starters which I will ask after a little background. Several years ago my nephew had a Saab 99 which had 2 electric fans. This car was notorious for cracking cylinder heads. After he gave it to my stepson and I overhauled the engine, I finally figured out why it had gone through so many aluminum heads. The 2 fans were on the same 20 amp fuse and each fan alone was drawing 20 amps! The fans ran fine but they just roared -- running much faster than they should and drawing more current than they should. I finally fixed the problem (temporarily) by putting each fan on its own fuse, and my stepson drove the car for 4 more years before he finally traded it in. Recently our treadmill motor started running hotter than normal. I now have to take the cover off the motor compartment in order for the thermal cutoff to stay on. My guess is that the motor is drawing more current than normal because the permanent magnets are getting weak. I am guessing that the same thing happens to the Skytech starters (one of which is on my plane). I think what is happening is that the magnets get weak and then the PM motor draws more current than "normal." The motor then runs faster than "normal" at the design voltage in order to generate enough counter emf. This would account for the solenoids failing, instead of the motor. I am an electrical engineer, but motors are not my specialty. Here is my question. Is there a way to "recharge" the magnets in the starter to bring them back up to original strength? What is the mechanism by which these magnets weaken? There must be some motor or magnet experts reading this list. Any suggestions on how to extend the life of these PM motors? Dan Hopper RV-7A (Flying for about 2 months -- about 43 hours) ________________________________________________________________________________
Subject: SL-40 manual
Date: Sep 13, 2004
Does anybody have an electronic copy (.PDF) of an SL-40 installation manual. I'm trying to help out a friend install a used radio in his plane, and can't get one from the Garmin site..... Fred Stucklen RV-6A N926RV ________________________________________________________________________________
Subject: Re: Starter woes -- PM motors
Date: Sep 13, 2004
I am no expect on electricity, but I teach Automotive Technology and have played a lot with permanent magnet devices (starters, window motors). What I have found on cars is that the commutator on the armature gets rough after a while. What I usually do is turn the commutator and install new brushes, this has fixed every starter I have tried it on. I have not tried it on a Sky Tech though, but poor connections will cause high amperage draw. (brushes to commutator) Jim James Cimino RV-8 SN 80039 100+ Hours 570-842-4057 http://www.geocities.com/jcimino.geo/ ----- Original Message ----- From: <Hopperdhh(at)aol.com> Subject: RV-List: Starter woes -- PM motors > > Fellow listers, > > This was a hot topic a few weeks ago, and it has been on my mind since > then. > I have a question about PM starters which I will ask after a little > background. > > Several years ago my nephew had a Saab 99 which had 2 electric fans. This > car was notorious for cracking cylinder heads. After he gave it to my > stepson > and I overhauled the engine, I finally figured out why it had gone through > so > many aluminum heads. The 2 fans were on the same 20 amp fuse and each fan > alone was drawing 20 amps! The fans ran fine but they just roared -- > running much > faster than they should and drawing more current than they should. I > finally > fixed the problem (temporarily) by putting each fan on its own fuse, and > my > stepson drove the car for 4 more years before he finally traded it in. > > Recently our treadmill motor started running hotter than normal. I now > have > to take the cover off the motor compartment in order for the thermal > cutoff to > stay on. My guess is that the motor is drawing more current than normal > because the permanent magnets are getting weak. > > I am guessing that the same thing happens to the Skytech starters (one of > which is on my plane). > > I think what is happening is that the magnets get weak and then the PM > motor > draws more current than "normal." The motor then runs faster than > "normal" at > the design voltage in order to generate enough counter emf. This would > account for the solenoids failing, instead of the motor. I am an > electrical > engineer, but motors are not my specialty. > > Here is my question. Is there a way to "recharge" the magnets in the > starter > to bring them back up to original strength? What is the mechanism by > which > these magnets weaken? There must be some motor or magnet experts reading > this > list. Any suggestions on how to extend the life of these PM motors? > > Dan Hopper > RV-7A (Flying for about 2 months -- about 43 hours) > > > ________________________________________________________________________________
Date: Sep 13, 2004
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: SL-40 manual
I have all the SL40 manuals (installation, operating, service, all pdf). I downloaded all of them right after Garmin purchased UPSAT for just this reason! I have three installation manuals for different vintages (1997, 1999, 2003). What vintage is the radio and where do I email it? Please either specify which one you want or that you want all of them (about 4 MB) and if you want the operating and service manuals as well. Dick Tasker Fred Stucklen wrote: > >Does anybody have an electronic copy (.PDF) of an SL-40 installation >manual. I'm trying to help out a friend install a used radio in his >plane, and can't get one from the Garmin site..... > >Fred Stucklen >RV-6A N926RV > > ________________________________________________________________________________
Subject: pitot lines
Date: Sep 14, 2004
Does changing the diameter of the tubing from the pitot tube affect readings that instruments give? eg. pitot tube such as Dynon uses 3/16" then I convert that to 1/4" tubing to run through the wings and then back to whatever size plastic tubing that the instruments require. Doesn't changing the diameter change the pressure and thus the reading on the instrument. Regards Greg RV8 wings ________________________________________________________________________________
Date: Sep 14, 2004
Subject: Re: pitot lines
Only if you have lots of flow through the tubing does pressure change with diameter. Hopefully you do not so the tubing size matters little. Of course if you use tubing that is too large you will have slow response since the small pitot or static port holes have to change the pressure in the large volume of the tubes. Dick Tasker Greg@itmack wrote: > >Does changing the diameter of the tubing from the pitot tube affect readings that instruments give? eg. pitot tube such as Dynon uses 3/16" then I convert that to 1/4" tubing to run through the wings and then back to whatever size plastic tubing that the instruments require. Doesn't changing the diameter change the pressure and thus the reading on the instrument. > >Regards >Greg RV8 wings > > > > ________________________________________________________________________________
Date: Sep 14, 2004
Hi Greg, I ran into the same problem on my 1st tank - just enough to notice but not enough to keep it from working. I made sure to key the assembly so that it would assemble the same way. I used large vice-grips to keep everything in place while drilling, too. Regards, /\/elson Austin, TX RV-7A - left wing/tank On Mon, 13 Sep 2004 Hopperdhh(at)aol.com wrote: > > In a message dated 9/13/04 6:53:18 PM US Eastern Standard Time, > greg(at)itmack.com writes: > > > As an expert in fuel tanks I wonder if you could give some tips. When I > > drilled out the filler cap flange the cap was perfectly centred and after I > > riveted it the cap is now off to one side, not enough to affect operation I > > think but just enough to annoy me as the proud builder. I took into account > > the slight curve of the flange when I mounted it and I got the orientation > > the same when I riveted it on. I spoke to another local builder and he had > > the same thing happen to him. I still have another tank to build so I would > > like to get that one perfect. > > > > Thanks > > Greg RV8 wings ________________________________________________________________________________
Date: Sep 14, 2004
Simple answer is NO! Cy Galley - Chair, Emergency Aircraft Repair Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: "Greg@itmack" <greg(at)itmack.com> Subject: RV-List: pitot lines > > Does changing the diameter of the tubing from the pitot tube affect readings that instruments give? eg. pitot tube such as Dynon uses 3/16" then I convert that to 1/4" tubing to run through the wings and then back to whatever size plastic tubing that the instruments require. Doesn't changing the diameter change the pressure and thus the reading on the instrument. > > Regards > Greg RV8 wings > > ________________________________________________________________________________
Date: Sep 14, 2004
Thanks > > Simple answer is NO! > > Cy Galley - Chair, Emergency Aircraft Repair > Safety Programs Editor - TC > EAA Sport Pilot > > ----- Original Message ----- > From: "Greg@itmack" <greg(at)itmack.com> > To: > Subject: RV-List: pitot lines > > > > > > Does changing the diameter of the tubing from the pitot tube affect > readings that instruments give? eg. pitot tube such as Dynon uses 3/16" > then I convert that to 1/4" tubing to run through the wings and then back to > whatever size plastic tubing that the instruments require. Doesn't changing > the diameter change the pressure and thus the reading on the instrument. > > > > Regards > > Greg RV8 wings > > > > > > ________________________________________________________________________________
From: "Sims, Doug" <Doug.Sims(at)danahermotion.com>
Date: Sep 14, 2004
I used Cardinal rattle cans that are the same color as Vans powder coat on the Panel. Rustoleum battleship grey on the interior. Looks good and aheres well to S&H primer. -----Original Message----- From: J. R. Dial [mailto:jrdial@hal-pc.org] Subject: RE: RV-List: QB Interior Paint If you want to use rattle cans I used Sherwin Williams self etching primer and gray propeller paint. It seems to work pretty well and cheap too. I used the same on the panel. Good Luck. Dick Dial RV6 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Rowbotham Subject: RE: RV-List: QB Interior Paint Pete, We used SunFire by Serwin Williams (a two part paint) has held up well. Check the archives for additional postings. Good Building, Chuck Rowbotham RV-8A >From: "Pete Howell" <pete.howell@gecko-group.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: QB Interior Paint >Date: Sun, 12 Sep 2004 11:42:05 -0500 > <pete.howell@gecko-group.com> > >Hello, > >What has everyone been using to paint the interior of their QB fuselages? >What prep did you do to the wash primer that was applied at the factory. > >Thanks, > >Pete > > = = = = ________________________________________________________________________________
Date: Sep 14, 2004
Subject: to polyfuse.... or not
Wiring chores are not exactly my strong suit. So here goes. It is recommended that the comm side of a Garmin 430 go through a 10 amp breaker or fuse. I have an EXP-2V installed and the highest rated "polyfuse" on the avionics bus is 7 amps. According to Control Vision maker of the EXP-2V, " a 9 amp polyfuse circuit is roughly comparable to a 14 amp fuse or breaker. The above fuse sizes are a good match for most for most sport aircraft, your project will probably work well with this configuration." Sooooo.....marketing literature aside, is it acceptable to wire the comm through the 7 amp polyfuse on the EXP-2V? Comments please, especially those with real time experience with such a setup. Rick Galati RV-6A "finishing" ________________________________________________________________________________
Subject: VAL AVionics INS422
Date: Sep 14, 2004
Has anyboby had any experience with the INS 422 Nav? It has VOR/LOC, Glige slope and Marker beacons all in aone 3"unit. I am looking for a low cost way to go IFR. Any other suggestions? Thanks Al Grajek RV8A ________________________________________________________________________________
Date: Sep 14, 2004
I do happen to have a good tip for keeping the fuel cap centered. I learned this one from Don London who built the tanks for many years before me. What he taught me to do is to cover the fuel tank opening on the outside of the tank skin with clear packaging tape. Then you take the tank flange with the cap locked into it and stick the whole works to the tape from the inside of the tank. The cap will stick to the tape and give you a perfect reference line between it and the skin. If its not centered just pull it off and try again. When satisified, drill one hole and cleco...then do one on the other side of the flange etc....You will have to hold tight to the cap and flange so you dont just shove it off with your drill. This is an excellent time to have some band aids handy because there is a better than average chance of drilling your hand...just be careful :) It is best to do this with the tank completely unassembled. I just stand the tank skin up on its inboard end and stand in front of it when I drill. Make sure you get the contour on the flange pointing the right direction and mark it with a sharpie so you can get it back in the same orientation when you rivet. Hope this helps, it works well for me. Cheers...Evan www.evansaviationproducts.com ----- Original Message ----- From: "Greg@itmack" <greg(at)itmack.com> Subject: Re: RV-List: fuel return line > > Thanks for your offer but I've got enough 1/4" vent line. I'm in Australia > and I'm seriously thinking about putting a rotary into my 8. I know > everyone says that fuel return lines aren't needed for Lycomings but they do > seem to be needed for other engines, so I thought I'd at least install the > line into the tank and if I don't use it I can cap it off. If anyone can > explain why some engines need returns to the tanks and others don't I'd be > interested. For instance I was told that continentals need returns to the > tanks while Lycos just join up to the fuel line again before the pump. > > As an expert in fuel tanks I wonder if you could give some tips. When I > drilled out the filler cap flange the cap was perfectly centred and after I > riveted it the cap is now off to one side, not enough to affect operation I > think but just enough to annoy me as the proud builder. I took into account > the slight curve of the flange when I mounted it and I got the orientation > the same when I riveted it on. I spoke to another local builder and he had > the same thing happen to him. I still have another tank to build so I would > like to get that one perfect. > > Thanks > Greg RV8 wings > > > > > > > Hey Greg, where are you? If you just want the 1/4" vent line stuff, its > > cheap and I have a bunch of extra you can have. How much do you require? > > More interesting is the question of why you are putting in a return line. > > Are you powering your 8 with something special ? inquiring minds.... > > Evan > > (530)351-1776 > > www.evansaviationproducts.com > > > > > > ----- Original Message ----- > > From: "Greg@itmack" <greg(at)itmack.com> > > To: ; > > Subject: RV-List: fuel return line > > > > > > > > > > Hi all, > > > I putting a fuel return line back into my tanks and since the proper > > aviation tubing is so expensive and hard to get here I was wondering if > > normal commercial grade aluminium tubing is satisfactory for the return > > lines and also the rest of the fuel system. One thing though the > commercial > > stuff here is metric, but as far as I can tell only a fraction of a > > millimetre different. Any opions and experiences? > > > > > > Greg RV8 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 14, 2004
Hey Martin ... What type of valve did you use in your return line? Thanks ... Jerry Grimmonpre RV7A QB > I am no expert, but I put one in my carburated Lycoming-powered RV-6 in case > I used unleaded fuel in the future. > > Hope this helps > > Martin in Oz ________________________________________________________________________________
Subject: H.R. 5035
Date: Sep 14, 2004
HERE IS A RESPONSE ON HR 5035 FROM MY CONGRESSMAN: Introduced by Rep. Anthony Weiner (D-NY), H.R. 5035 would require the Department of Homeland Security to promulgate and enforce rules to ensure private aircraft companies provide the same passenger and property screening as is required of the major air carriers. H.R. 5035 has been referred to the House Transportation and Infrastructure Committee for consideration. However, there is little support for the bill, and I do not anticipate action being taken on it. tamccarthy e-mail: tamccarthy(at)zoomtown.com ________________________________________________________________________________
Date: Sep 14, 2004
www.lacodeworks.com/besing Click on "Paint" Paul Besing Quoting "Sims, Doug" : > > I used Cardinal rattle cans that are the same color as Vans powder coat on > the Panel. Rustoleum battleship grey on the interior. Looks good and aheres > well to S&H primer. > > -----Original Message----- > From: J. R. Dial [mailto:jrdial@hal-pc.org] > To: rv-list(at)matronics.com > Subject: RE: RV-List: QB Interior Paint > > > If you want to use rattle cans I used Sherwin Williams self > etching primer and gray propeller paint. It seems to work pretty well > and cheap too. I used the same on the panel. > Good Luck. > Dick Dial > RV6 > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles > Rowbotham > To: rv-list(at)matronics.com > Subject: RE: RV-List: QB Interior Paint > > > > Pete, > > We used SunFire by Serwin Williams (a two part paint) has held up well. > Check the archives for additional postings. > > Good Building, > > Chuck Rowbotham > RV-8A > > > >From: "Pete Howell" <pete.howell@gecko-group.com> > >Reply-To: rv-list(at)matronics.com > >To: > >Subject: RV-List: QB Interior Paint > >Date: Sun, 12 Sep 2004 11:42:05 -0500 > > > <pete.howell@gecko-group.com> > > > >Hello, > > > >What has everyone been using to paint the interior of their QB > fuselages? > >What prep did you do to the wash primer that was applied at the > factory. > > > >Thanks, > > > >Pete > > > > > > > > = > = > = > = > > ________________________________________________________________________________
Date: Sep 14, 2004
Subject: Re: to polyfuse.... or not
> According to Control Vision maker of the EXP-2V, " a 9 amp polyfuse circuit is roughly comparable to a 14 amp fuse or breaker. > I'd sure like to see the math on this one. After 45 years in electronics I thought that "9 amps" was "9 amps" not 14 amps. (Political correctness perhaps?) Could someone please enlighten me? 8>) Dave Bristol RV6 So Cal EAA Technical Counselor > > > > ________________________________________________________________________________
Subject: RE: [SoCAL-RVlist] Reno news, For those interested.
Date: Sep 14, 2004
I'll be at Reno Sat & Sun. Are there any activities planned for the RV builders/owners? ERic-- RV8 wings (828) 777-7976 ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Date: Sep 14, 2004
We had an SL-40 (COM) and now have an SL-30 (NAV/COM) connected to the NAV1 "port" of an EXP-BUS. In almost 2 years and 370+ hours, we have had no problems. I **think** it is listed as having an 8 watt amp with the 430 having a 10 watt amp. The 430A is listed as having a 16 watt amp. Of couse this does not factor in the antenna loss etc and therefore says little about the ACTUAL current draw. That you will have to find in the more detailed specs. Again, our SL30 works ... your mileage may vary. James > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Rick Galati > Sent: Tuesday, September 14, 2004 9:16 AM > To: rv-list(at)matronics.com > Subject: RV-List: to polyfuse.... or not > > > Wiring chores are not exactly my strong suit. So here goes. It > is recommended that the comm side of a Garmin 430 go through a 10 > amp breaker or fuse. I have an EXP-2V installed and the highest > rated "polyfuse" on the avionics bus is 7 amps. According to > Control Vision maker of the EXP-2V, " a 9 amp polyfuse circuit > is roughly comparable to a 14 amp fuse or breaker. The above fuse > sizes are a good match for most for most sport aircraft, your > project will probably work well with this configuration." > > Sooooo.....marketing literature aside, is it acceptable to wire > the comm through the 7 amp polyfuse on the EXP-2V? Comments > please, especially those with real time experience with such a setup. > > Rick Galati RV-6A "finishing" > > ________________________________________________________________________________
Date: Sep 14, 2004
From: Hal / Carol Kempthorne <kempthornes(at)earthlink.net>
Dave, these might be BUSH amps, where some of them never even show up. ;-) Another reason to avoid this system maybe as you believe you have protection for a wire capable of handling 10 amps. But the polyfuse is not going to pop at 9 amps but rather allow damage to the wire by admitting 14 amps. >I thought that "9 amps" was "9 amps" not 14 amps. (Political correctness >perhaps?) Could someone please enlighten me? 8>) K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Subject: Re : fuel return line
Date: Sep 15, 2004
Hi Jerry, I'll explain in a little more detail. I ran my engine fuel supply line from the selector valve to a wing root-mounted gascolator, then Facet boost pump, also in the wing root then to a T fitting on the firewall. One side goes to the engine-driven pump and the other side goes to the primer solenoid valve. ( Hit the boost pump button, then the primer switch - instant start) On the engine-driven pump outlet fitting, I have a smaller piggy-back fitting with a restrictor that routes back to the left hand tank. This is supposed to take the bubbles away before they get to the carb. A small ball valve allow me to turn off the return line. Having installed this sytem, I have had no reason to use it for its intended purpose - that is, eliminating vapour lock. Even in 40 degree C temps. May well be different if I was using mogas. Hope this helps Martin in Oz ________________________________________________________________________________
Date: Sep 14, 2004
Maybe they are Kerry amps and it depends which day you use them! ----- Original Message ----- From: "Hal / Carol Kempthorne" <kempthornes(at)earthlink.net> Subject: Re: RV-List: to polyfuse.... or not > > Dave, these might be BUSH amps, where some of them never even show up. ;-) > > Another reason to avoid this system maybe as you believe you have > protection for a wire capable of handling 10 amps. But the polyfuse is not > going to pop at 9 amps but rather allow damage to the wire by admitting 14 > amps. > > >I thought that "9 amps" was "9 amps" not 14 amps. (Political correctness > >perhaps?) Could someone please enlighten me? 8>) > > K. H. (Hal) Kempthorne > RV6-a N7HK - Three trips to OSH now. > PRB (El Paso de Robles, CA) > > ________________________________________________________________________________
Date: Sep 14, 2004
Subject: FIRST FLIGHT - WHELAN SUPER 8
September 14th: The long awaited first flight of the Whelan Super 8 took place at 13:15 in Bethlehem, CT. The aircraft performed flawlessly. Too bad we won't make Reno this year. Many thanks to all who helped make this moment possible, especially, Bill Benedict whose great friendship and eternal faith in this project will never be forgotten. Special thanks also go out to Dan Decker, the best rivet bucker in the business. Better mention the wife (PJ) too for her infinite patience. Aircraft Background: IO540 S1AD, 300+++ Horsepower, Air Flow Performance Injection, Light Speed Ignition, Carbon Fiber Cowls and many more mods than we don't have time to disclose. Mark F. "We can't wait." Regards, Tom Tom Whelan Whelan Farms Airport President EAA Chapter 1097 wfact01(at)aol.com 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 Tel: 203-266-5300 Fax: 202-266-5140 EAA Technical/Flight Advisor RV-8 540 LYC (Just Flew 9/14, Look Out!) S-51 Mustang Turbine (Under Construction) ________________________________________________________________________________
Date: Sep 14, 2004
Subject: Re: SL-40, et. al. manuals
I have had several requests for these manuals. I have no problem emailing them, but PLEASE tell me as specifically as you can what you want. I have all (installation, operation and in some cases maintenance) of the SL15, SL30, SL40 and SL70/70R manuals that were on the UPSAT web site. They are all at least 500kB and many are over 1.5MB. Lots of email accounts have a limit on attachment size and total email storage. CHECK your situation first and let me know what you can handle. I have broadband so I don't have a problem sending these, but to make my life easier, please tell me what you want and how many MB you can handle per message and per day. Dick Tasker Richard E. Tasker wrote: > >I have all the SL40 manuals (installation, operating, service, all >pdf). I downloaded all of them right after Garmin purchased UPSAT for >just this reason! > >I have three installation manuals for different vintages (1997, 1999, >2003). What vintage is the radio and where do I email it? > >Please either specify which one you want or that you want all of them >(about 4 MB) and if you want the operating and service manuals as well. > >Dick Tasker > ________________________________________________________________________________
Date: Sep 14, 2004
Dave, As I recall (those who know better, please give a better answer but don't jump on me if I am wrong or recall incorrectly) ... These Polyfuses "switch" to "off" based in part on a temp rise. This takes some finite amount of time so it does not *immediately* switch at exactly "9 amps". They may very well run at 11 amps, I am not sure. BUT you can check it by slowly increasing the amperage and see where it switched if that is a major concern. (I suspect there is some small variability is regular fuse but it is not enough to be of any concern) If some current significantly greater was shoved down the wire though, I believe the polyfuse WOULD switch quickly before you burned up the wire. All of the theory aside, 9 amps or 14 amps or 11 amps for that matter, ours has worked without problem. A short will make it switch *right now* and the radio has not caused it to switch prematurely. Nor have any of the other items. James RV6 with EXP-BUS (polyfuses) RV6A with Nuckolls "Z-14" > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dave Bristol > Sent: Tuesday, September 14, 2004 4:20 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: to polyfuse.... or not > > > > According to Control Vision maker of the EXP-2V, " a 9 amp > polyfuse circuit is roughly comparable to a 14 amp fuse or breaker. > > > I'd sure like to see the math on this one. After 45 years in electronics > I thought that "9 amps" was "9 amps" not 14 amps. (Political correctness > perhaps?) Could someone please enlighten me? 8>) > > Dave Bristol RV6 So Cal > EAA Technical Counselor > > > > > > > > > > > ________________________________________________________________________________
From: "DonEavesRV6" <DonEavesRV6(at)midsouth.rr.com>
Subject: King KN53 Coax wiring - J531, J533 Question
Date: Sep 14, 2004
King KN53 Coax wiring - J531, J533 Question: I'm installing a King KN53 Nav in my flying RV6 and I need to know which coax connectors (J531 and J533) is Glide Slop and which Localizer? Thanks in advance - Don Eaves RV6 Flying ________________________________________________________________________________
Date: Sep 14, 2004
In a message dated 9/14/2004 5:13:38 PM Pacific Daylight Time, cgalley(at)qcbc.org writes: Maybe they are Kerry amps and it depends which day you use them! ======================================== Or Bush Amps that just decided to take a year off without leave! GV (RV-6A N1GV O-360-A1A C/S, flying 719 hrs) ________________________________________________________________________________
Subject: Re: Re : fuel return line
Date: Sep 15, 2004
My RV-6A (Scooter) has no gascolator and has no return line. I use mogas most of the time. I'll add 100LL about once per year, or when the need arises such as when I'm going to be doing a quick turnaround activity like taking up Young Eagles. Then, I add about five gallons of 100LL per side. Vapor lock has not been a show stopper. Of course, my having used mogas in my airplanes since 1986 gave me a pretty good notion that it would work in the RV. My fuel line goes from the tank to the fuel selector, on to the round Facet pump on the engine side of the firewall, a T for the primer, on to the mechanical pump, and on to the carb. Nothing special. I kept it simple. I like to think that's what Van had in mind. :-) My new RV will have the same setup. I don't see any need to change what works. Jim Sears in KY RV-6A N198JS (Scooter - over 300 hours) RV-7A #70317 (Building wings) EAA Tech Counselor > I'll explain in a little more detail. I ran my engine fuel supply line from > the selector valve to a wing root-mounted gascolator, then Facet boost pump, > also in the wing root then to a T fitting on the firewall. One side goes to > the engine-driven pump and the other side goes to the primer solenoid valve. > ( Hit the boost pump button, then the primer switch - instant start) On the > engine-driven pump outlet fitting, I have a smaller piggy-back fitting with > a restrictor that routes back to the left hand tank. This is supposed to > take the bubbles away before they get to the carb. A small ball valve allow > me to turn off the return line. > > Having installed this sytem, I have had no reason to use it for its intended > purpose - that is, eliminating vapour lock. Even in 40 degree C temps. > May well be different if I was using mogas. ________________________________________________________________________________
Subject: Air Compressors
Date: Sep 15, 2004
I am about to order my RV-8A emphanage kit. Does anyone have an opinion on the type and brand of air compressor that is best for RV construction? I attended the EAA RV Builder's Course last weekend in Corona where the general consensus was to avoid the oilless models because of noise. Went to the local Sears last night and the 30 gallon model I almost bought ($299 on sale) turned out to be oilless - so I deferred. Paul Valovich ________________________________________________________________________________
Subject: Re: Air Compressors
Date: Sep 15, 2004
Paul, I am about to buy a compressor for my project. If you search Campbell Hausfeld rebuilt on the net you will find a site that you can buy reconditioned like new compressors. Free ship and no tax. A 20 gallon direct drive will cost you 200.00 and you can buy a 26 gallon direct drive for 250.00. They have a 60 gallon on sale for 399.00. I think a 26 gallon direct drive will work fine for most applications. Good luck Doug Brinlee 7A ----- Original Message ----- From: "Valovich, Paul" <pvalovich(at)dcscorp.com> Subject: RV-List: Air Compressors > > I am about to order my RV-8A emphanage kit. Does anyone have an opinion > on the type and brand of air compressor that is best for RV > construction? I attended the EAA RV Builder's Course last weekend in > Corona where the general consensus was to avoid the oilless models > because of noise. Went to the local Sears last night and the 30 gallon > model I almost bought ($299 on sale) turned out to be oilless - so I > deferred. > > Paul Valovich > > ________________________________________________________________________________
Date: Sep 15, 2004
I agree with avoiding an oil-less unit - Noise! and it will not last as long - After my oil-less gave up, I bought a upright 230 V 50 gal unit from Sam's Club and it has lasted 6+ years with old forgetful leaving it on @ the hangar for a few weeks at a time. Whatever brand Sam's, Costco or ? has should do. A Name Brand will cost you more and most are build by 1 or 2 different co's anyway. Don Eaves RV6 Flying 250+- hrs. ----- Original Message ----- From: "Valovich, Paul" <pvalovich(at)dcscorp.com> Subject: RV-List: Air Compressors > > I am about to order my RV-8A emphanage kit. Does anyone have an opinion > on the type and brand of air compressor that is best for RV > construction? I attended the EAA RV Builder's Course last weekend in > Corona where the general consensus was to avoid the oilless models > because of noise. Went to the local Sears last night and the 30 gallon > model I almost bought ($299 on sale) turned out to be oilless - so I > deferred. > > Paul Valovich > > ________________________________________________________________________________
Date: Sep 15, 2004
Jim, Not too many years ago, my friend Johnathan Crawford was flying a Beech (Whatever the cheap retractable was) when the electric pump failed and some of its components went into the mechanical pump and killed it. He dead sticked onto Brand Boulevard in Glendale, CA during rush hour. I think I'd prefer my pumps in parallel, rather than series. FWIW Jack Ford ----- Original Message ----- From: <sears(at)searnet.com> Subject: Re: RV-List: Re : fuel return line > > My RV-6A (Scooter) has no gascolator and has no return line. I use mogas > most of the time. I'll add 100LL about once per year, or when the need > arises such as when I'm going to be doing a quick turnaround activity like > taking up Young Eagles. Then, I add about five gallons of 100LL per side. > Vapor lock has not been a show stopper. Of course, my having used mogas in > my airplanes since 1986 gave me a pretty good notion that it would work in > the RV. > > My fuel line goes from the tank to the fuel selector, on to the round Facet > pump on the engine side of the firewall, a T for the primer, on to the > mechanical pump, and on to the carb. Nothing special. I kept it simple. I > like to think that's what Van had in mind. :-) My new RV will have the > same setup. I don't see any need to change what works. > > Jim Sears in KY > RV-6A N198JS (Scooter - over 300 hours) > RV-7A #70317 (Building wings) > EAA Tech Counselor > > > I'll explain in a little more detail. I ran my engine fuel supply line > from > > the selector valve to a wing root-mounted gascolator, then Facet boost > pump, > > also in the wing root then to a T fitting on the firewall. One side goes > to > > the engine-driven pump and the other side goes to the primer solenoid > valve. > > ( Hit the boost pump button, then the primer switch - instant start) On > the > > engine-driven pump outlet fitting, I have a smaller piggy-back fitting > with > > a restrictor that routes back to the left hand tank. This is supposed to > > take the bubbles away before they get to the carb. A small ball valve > allow > > me to turn off the return line. > > > > Having installed this sytem, I have had no reason to use it for its > intended > > purpose - that is, eliminating vapour lock. Even in 40 degree C temps. > > May well be different if I was using mogas. > > ________________________________________________________________________________
Date: Sep 15, 2004
Correction to previous post on air compressors. The price I listed is for belt drive units. Not the noisy direct drive units...sorry for the mistake. ----- Original Message ----- From: "Doug Brinlee" <abfbrinlee(at)att.net> Subject: Re: RV-List: Air Compressors > > Paul, > I am about to buy a compressor for my project. If you search Campbell > Hausfeld rebuilt on the net you will find a site that you can buy > reconditioned like new compressors. Free ship and no tax. A 20 gallon > direct drive will cost you 200.00 and you can buy a 26 gallon direct drive > for 250.00. They have a 60 gallon on sale for 399.00. I think a 26 gallon > direct drive will work fine for most applications. Good luck > Doug Brinlee 7A > ----- Original Message ----- > From: "Valovich, Paul" <pvalovich(at)dcscorp.com> > To: > Subject: RV-List: Air Compressors > > > > > > I am about to order my RV-8A emphanage kit. Does anyone have an opinion > > on the type and brand of air compressor that is best for RV > > construction? I attended the EAA RV Builder's Course last weekend in > > Corona where the general consensus was to avoid the oilless models > > because of noise. Went to the local Sears last night and the 30 gallon > > model I almost bought ($299 on sale) turned out to be oilless - so I > > deferred. > > > > Paul Valovich > > > > > > ________________________________________________________________________________
From: George Neal E Capt AU/PC <Neal.George(at)maxwell.af.mil>
Date: Sep 15, 2004
> an opinion on the type and brand of air compressor < I have an ancient American Champion that works very well. At 1-hp, it's considerably smaller than I would like, but I'm in cramped quarters, it's paid for, and it will do until I start sanding. Neal ________________________________________________________________________________
Date: Sep 15, 2004
Subject: WTB RV -6/6A or-7/7A
Hi, A friend of mine is having bad luck finding an RV for sale. An ex-military pilot, he likes the acrobatic feel with side-by-side seating of the -6 and -7 models. He doesn't care which end the third wheel is attached. He prefers IFR equipped. Please send me particulars and contact info! cheers, Chuck Packard YankeeRV10(at)yahoo.com _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 15, 2004
Get at least 5 HP and minium of 30 gallon and dont use an oilless. When cutting the canopy you will need the capicity to run a air cuttoff tool. IMHO. Dale Mitchell RV8A MN wing --- "Valovich, Paul" wrote: > > > I am about to order my RV-8A emphanage kit. Does > anyone have an opinion > on the type and brand of air compressor that is best > for RV > construction? I attended the EAA RV Builder's Course > last weekend in > Corona where the general consensus was to avoid the > oilless models > because of noise. Went to the local Sears last night > and the 30 gallon > model I almost bought ($299 on sale) turned out to > be oilless - so I > deferred. > > Paul Valovich > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 15, 2004
Subject: High fuel pressure
Listers, My EIS-4000 has started complaining about high fuel pressure recently. This is on an O-360-A1A with a carb & the standard low pressure engine driven fuel pump. In normal cruise, I get a fuel pressure reading somewhere between 2 & 5 psi, which is fine. The problem occurs intermittently when taxiing, & recently in the air when throttling back for a descent. The pressure climbs to 10-12 psi. Looking back a couple of years at my engine monitor logs, the pressure never used to exceed 6-7 psi. All the above readings are without the electric boost pump. In looking at the archives & other internet sources I found two suggestions: 1. The VDO pressure sensor is only good for 2-300 hrs. But this doesn't seem like a sensor problem as my cruise readings are normal. 2. The fuel pump pressure regulator is vented to the crankcase & high fuel pressure can be a symptom of breather blockage. This seems possible as I have a home-made oil separator on the breather. Maybe this is blocked & the engine is breathing through the whistle slot! I plan to check this in the next couple of days. Has anyone experienced this? Any other suggestions? Regards, Chris Good, West Bend, WI RV-6A, 775 hrs -- ________________________________________________________________________________
Date: Sep 15, 2004
Subject: Re: FIRST FLIGHT - WHELAN SUPER 8
Tom, what does it weigh? Regards, Bob Japundza RV-6 flying, F1 qb under const. > > September 14th: The long awaited first flight of the Whelan Super 8 took > place at 13:15 in Bethlehem, CT. The aircraft performed flawlessly. Too bad we > won't make Reno this year. Many thanks to all who helped make this moment > possible, especially, Bill Benedict whose great friendship and eternal faith in this > project will never be forgotten. Special thanks also go out to Dan Decker, > the best rivet bucker in the business. Better mention the wife (PJ) too for her > infinite patience. > > Aircraft Background: IO540 S1AD, 300+++ Horsepower, Air Flow Performance > Injection, Light Speed Ignition, Carbon Fiber Cowls and many more mods than we > don't have time to disclose. Mark F. "We can't wait." > > Regards, > Tom > > Tom Whelan > Whelan Farms Airport > President EAA Chapter 1097 > wfact01(at)aol.com > 249 Hard Hill Road North > PO Box 426 > Bethlehem, CT 06751 > Tel: 203-266-5300 > Fax: 202-266-5140 > EAA Technical/Flight Advisor > RV-8 540 LYC (Just Flew 9/14, Look Out!) > S-51 Mustang Turbine (Under Construction) > > > ________________________________________________________________________________
Date: Sep 15, 2004
Certain tools use a ton of air, but are real nice to have. For example, hand held disc sanders. I originally had a small oil-free type and was constantly running short on air. I traded up to a bigger conventional and still had troubles. The problem went away when I bought a conventional type, 220 volt model. The 220 volt motors will last a lot longer and produce way more air. I think mine puts out about 6 horsepower, which is plenty for all spraying and sanding. Smaller ones will work fine for riveting but will come up short on high consumption tools. Mine came from Home Depot. Steve Zicree Finishing kit, RV4 ----- Original Message ----- From: "Valovich, Paul" <pvalovich(at)dcscorp.com> Subject: RV-List: Air Compressors > > I am about to order my RV-8A emphanage kit. Does anyone have an opinion > on the type and brand of air compressor that is best for RV > construction? I attended the EAA RV Builder's Course last weekend in > Corona where the general consensus was to avoid the oilless models > because of noise. Went to the local Sears last night and the 30 gallon > model I almost bought ($299 on sale) turned out to be oilless - so I > deferred. > > Paul Valovich > > ________________________________________________________________________________
Date: Sep 15, 2004
I agree! Although I still have my 20G Sears unit, it needs it's own 20amp circuit and doesn't work well in the cold. over the long run you will be much better off without the oiless. Spend the extra $100 it's worth it. RV8 -----Original Message----- From: DonEavesRV6 [mailto:DonEavesRV6(at)midsouth.rr.com] Subject: Re: RV-List: Air Compressors I agree with avoiding an oil-less unit - Noise! and it will not last as long - After my oil-less gave up, I bought a upright 230 V 50 gal unit from Sam's Club and it has lasted 6+ years with old forgetful leaving it on @ the hangar for a few weeks at a time. Whatever brand Sam's, Costco or ? has should do. A Name Brand will cost you more and most are build by 1 or 2 different co's anyway. Don Eaves RV6 Flying 250+- hrs. ----- Original Message ----- From: "Valovich, Paul" <pvalovich(at)dcscorp.com> Subject: RV-List: Air Compressors > > I am about to order my RV-8A emphanage kit. Does anyone have an opinion > on the type and brand of air compressor that is best for RV > construction? I attended the EAA RV Builder's Course last weekend in > Corona where the general consensus was to avoid the oilless models > because of noise. Went to the local Sears last night and the 30 gallon > model I almost bought ($299 on sale) turned out to be oilless - so I > deferred. > > Paul Valovich > > ________________________________________________________________________________
Date: Sep 15, 2004
To Paul and Doug, When shopping for a compressor one of the primary things to be aware of is the capacity of the compressor itself. Many are advertised by horsepower rather than what they flow. I've seen 5H.P. compressors advertised anywhere from 3.6 to 12.5 CFM...Big Difference! and these flow rates vary in pressure from 35# to 90#. Most air tools consume anywhere from 1.5CFM for a 2X rivet gun operating at 25# to 12.5CFM for die grinders running line pressure. Depending on the make and model, paint guns eat a fair amount of air too, anywhere from 3 to 9CFM. Some of the cheap-o HVLP's can use more than a grinder. With that being said, I would recommend a compressor that flows at least 20% more than your highest normal use consumption at the highest pressure you intend to have for working pressure. Example, you plan on using all air tools in your shop as well as doing some painting. Lets say your normal consumption will be 7 CFM and your highest working pressure will be 90#. I would look for a compressor that flows at least 8.5 - 9 CFM @ 90#. Also make sure that the unit has a large enough tank so the compressor isn't running constantly. I would recommend that your tank is at least the size of your usage. Most tank are advertised in gallons instead of cubic feet. A cubic foot is 7.48 gallons. 9 X 7.48 gives you a tank size of approx. 67 Gallons. So in this case you would want to find a compressor that flows 9 CFM @ 90 # with a 60-70 gallon tank. I would also recommend that you look for a two-stage compressor. They tend to start easier, build up faster, and last longer with less maintenance than single stage and direct drives. Just a little input...Hope it helps! Jim Duckett, RV-7A N708JD Performance Engineering ________________________________________________________________________________
Date: Sep 15, 2004
Nice job Tom. I wish you were going to Reno this year. I was looking forward to seeing you race. Best to you, Rick L --- Bob J wrote: > > > Tom, what does it weigh? > > Regards, > Bob Japundza > RV-6 flying, F1 qb under const. > > > wrote: > > > > September 14th: The long awaited first flight of > the Whelan Super 8 took > > place at 13:15 in Bethlehem, CT. The aircraft > performed flawlessly. Too bad we > > won't make Reno this year. Many thanks to all who > helped make this moment > > possible, especially, Bill Benedict whose great > friendship and eternal faith in this > > project will never be forgotten. Special thanks > also go out to Dan Decker, > > the best rivet bucker in the business. Better > mention the wife (PJ) too for her > > infinite patience. > > > > Aircraft Background: IO540 S1AD, 300+++ > Horsepower, Air Flow Performance > > Injection, Light Speed Ignition, Carbon Fiber > Cowls and many more mods than we > > don't have time to disclose. Mark F. "We can't > wait." > > > > Regards, > > Tom > > > > Tom Whelan > > Whelan Farms Airport > > President EAA Chapter 1097 > > wfact01(at)aol.com > > 249 Hard Hill Road North > > PO Box 426 > > Bethlehem, CT 06751 > > Tel: 203-266-5300 > > Fax: 202-266-5140 > > EAA Technical/Flight Advisor > > RV-8 540 LYC (Just Flew 9/14, Look Out!) > > S-51 Mustang Turbine (Under Construction) > > > > > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > ________________________________________________________________________________
Subject: Hurricane stuff
Date: Sep 15, 2004
Yes, hurricanes are covered by all the insurance companies. No, coverage is not contingent upon you moving the plane out of harms way. Remaining claim free is of benefit to you for future insurability at the best rates (yes, even though a resultant loss would be an act of God and not a judgement loss on your part, i.e. fuel exhaustion, etc.) I am posting this primarily to inform the vast majority of my policy holders in the VanGuard Program that effective immediately, Phoenix (the company which underwrites the VanGuard Program) has agreed to re-imburse their customers which carry full or Ground not in motion coverage on their planes for moving their planes out of a Hurricane Warning/Watch area. AIG is the only other company which currently offers this type of re-imbursement, and the limitations (below) are almost identical. Phoenix's limitations: 1. Policy must already contain coverage F or G (Full inflight and ground or Ground not in motion). 2. Must be relocated to another airport that is at least 100 NMs outside the warning/watch area. 3. Reimbursement is limited to 50% of the total relocation cost (including ferry pilot if necessary) or $500 whichever is less. $1000 max per year. Phoenix nor any of the other companies will add physical damage coverage to policies in the affected areas, nor will they start new policies in those areas currently. No need to call and tell your agent your are or want to do this. Just keep the receipts for gas, tied down costs, and other expenses, and contact your agent after returning to your homebase to coordinate the reimbursement. Sorry to be so brief, but my girls' daycare provider is sick, and I must go get them. If you're insured elsewhere but through Phoenix or AIG, please call your agent for more details. If you are insured by NationAir, any agent here in my office can explain it to you further. JT ________________________________________________________________________________
Date: Sep 15, 2004
Jack, the fuel system in series is pretty standard amongst the commercially built aircraft I've seen. I've been flying since 1982 and haven't heard of that happening, before. I'm sure things like that can happen. However, I'd prefer to keep the fuel system simple and take the almost no risk of having one trash the other. Adding complexity to a system can oftentimes cause more problems than KISS. However, do what you have to do to make you have warm fuzzies. I'll stick with what works for me, which is having the fuel system components in series. Van's RV-6A drawings show the fuel system components in series, as well. Thanks for the input, though. Jim Sears in KY > Not too many years ago, my friend Johnathan Crawford was flying a Beech > (Whatever the cheap retractable was) when the electric pump failed and some > of its components went into the mechanical pump and killed it. > He dead sticked onto Brand Boulevard in Glendale, CA during rush hour. > I think I'd prefer my pumps in parallel, rather than series. > FWIW ________________________________________________________________________________
Date: Sep 15, 2004
Subject: Vetterman Exhaust
List, I'd like to compliment Larry Vetterman. I ordered my system from him at Van's Homecoming on Sept. 4th. He said it would arrive in "2-3 weeks". The brown van showed up yesterday , with the entire system. He flew home to SD, fabbed my system, shipped it, and arrived here in 10 days. Don't you just love folks who under-promise and over-perform? Thanks Larry!!! Not only that, but this thing is a work of art, everything fit with no mods at all. I had it bolted up to the engine in 15 min. Clearances are perfect for my engine. Needless to say, Vetterman Exhaust is highly recommended. Jerry Cochran RV6a/XPIO-360 Wilsonville, OR ________________________________________________________________________________
Subject: Re: High fuel pressure
Date: Sep 15, 2004
Chris. I had trouble with my Rocky sensor, reading high oil pressure, also a VDO and it turned out it was a bad connection. The Rocky reads higher pressure as lower resistance, ie an open reads top of scale. I assume yours is the same. Doug ----- Original Message ----- From: "Chris Good" <chrisjgood(at)lycos.com> Subject: RV-List: High fuel pressure > > Listers, > > My EIS-4000 has started complaining about high fuel pressure recently. This is on an O-360-A1A with a carb & the standard low pressure engine driven fuel pump. In normal cruise, I get a fuel pressure reading somewhere between 2 & 5 psi, which is fine. The problem occurs intermittently when taxiing, & recently in the air when throttling back for a descent. The pressure climbs to 10-12 psi. > > Looking back a couple of years at my engine monitor logs, the pressure never used to exceed 6-7 psi. All the above readings are without the electric boost pump. > > In looking at the archives & other internet sources I found two suggestions: > > 1. The VDO pressure sensor is only good for 2-300 hrs. But this doesn't seem like a sensor problem as my cruise readings are normal. > > 2. The fuel pump pressure regulator is vented to the crankcase & high fuel pressure can be a symptom of breather blockage. This seems possible as I have a home-made oil separator on the breather. Maybe this is blocked & the engine is breathing through the whistle slot! I plan to check this in the next couple of days. > > Has anyone experienced this? Any other suggestions? > > Regards, > > Chris Good, > West Bend, WI > RV-6A, 775 hrs > -- > > ________________________________________________________________________________
Date: Sep 15, 2004
I am also on empennage, after web research and in store comparison settled on 5 HP and 20 gal tank, 30 gallon is better if you have space. 20 gallon is OK for everything except air cutoff tool (intermittent use only). Get belt drive (much, much quieter) and cast iron compressor. The unit I got from Lowes is rated continuous duty cycle with 3 year warranty cost $350. Dave Figgins RV-7A empennage -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Mitchell Subject: Re: RV-List: Air Compressors Get at least 5 HP and minium of 30 gallon and dont use an oilless. When cutting the canopy you will need the capicity to run a air cuttoff tool. IMHO. Dale Mitchell RV8A MN wing --- "Valovich, Paul" wrote: > > > I am about to order my RV-8A emphanage kit. Does anyone have an > opinion on the type and brand of air compressor that is best for RV > construction? I attended the EAA RV Builder's Course last weekend in > Corona where the general consensus was to avoid the oilless models > because of noise. Went to the local Sears last night and the 30 gallon > model I almost bought ($299 on sale) turned out to be oilless - so I > deferred. > > Paul Valovich > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com = direct advertising on the Matronics Forums. = = = ________________________________________________________________________________
Date: Sep 15, 2004
Subject: Re: Rudder Cable Fairings
Trainnut01(at)aol.com wrote: > > I saw an ad recently for some alumunum fairings that install over the rudder > cables where they exit the fuselage. Now I can't remember where I saw them. > Can someone help me over a senior moment? > Carroll Jernigan > East TN > 7A Fuselage These fairings are very easy to make out of scrap material: http://home.hiwaay.net/~sbuc/journal/fuse8.html Sam Buchanan ________________________________________________________________________________
From: "Karen and Robert Brown" <bkbrown(at)ashcreekwireless.com>
Subject: gluing canopy to frame
Date: Sep 15, 2004
Hi everyone, I'm happy to be back on the list after a 6 month absence, moving (the plane was unscathed) and getting back to work. I'd like to start a thread to investigate the wisdom (and results if there are any) of gluing the canopy to the frame instead of using screws. I noticed in an earlier post from Jim Duckett in Nov. of 2001 the mention of using a product from FUSOR. In that post, Jim mentioned that adhesive manufacturer had a brand that GM uses to glue the door hinges onto the door posts in its new vehicles. Details of that post are in the archives. While all of us are building "plans built" aircraft, and the plans call for screws to be used to attach the canopy to the frame, I think the case can be made that using an adhesive might save time and might eliminate issues with cracking, while still performing the most critical task -- keeping the canopy attached to the frame in flight... I believe this is how all plexi is fixed into canopies and window panels of modern jet aircraft of almost all types, surely we can find an adhesive suitable for our application. I believe I heard that builders in South Africa were using this technique, but could find nothing like that in the archives, so maybe I was imagining it. Does anyone have real information on this?? Bob Brown Independence, OR RV-7AQB (finish) ________________________________________________________________________________
From: "czechsix(at)juno.com" <czechsix(at)juno.com>
Date: Sep 15, 2004
Subject: grass runway smoothness for RV operations
Guys, Is there any rule of thumb to know whether a grass strip is smooth enough to operate an RV out of? In this case I'm talking about a strip that is a couple years old and has only had a Cub and Stinson fly in and out of it, both of which fly slower and have bigger tires than an RV. The strip has has never been rolled, and never had an RV or anything with smaller wheels land on it...the owner expressed some concern about the RV landing on it but he isn't too familiar with the RV design so I don't know if his concerns are justified. Is there any sort of objective criteria one can use before landing an RV on it to determine whether it's smooth enough? Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing... Get your name as your email address. Includes spam protection, 1GB storage, no ads and more Only $1.99/ month - visit http://www.mysite.com/name today! ________________________________________________________________________________
Date: Sep 15, 2004
Tom, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A (Westerly, RI) >From: WFACT01(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: FIRST FLIGHT - WHELAN SUPER 8 >Date: Tue, 14 Sep 2004 20:44:32 EDT > > >September 14th: The long awaited first flight of the Whelan Super 8 took >place at 13:15 in Bethlehem, CT. The aircraft performed flawlessly. Too >bad we >won't make Reno this year. Many thanks to all who helped make this moment >possible, especially, Bill Benedict whose great friendship and eternal >faith in this >project will never be forgotten. Special thanks also go out to Dan Decker, >the best rivet bucker in the business. Better mention the wife (PJ) too for >her >infinite patience. > >Aircraft Background: IO540 S1AD, 300+++ Horsepower, Air Flow Performance >Injection, Light Speed Ignition, Carbon Fiber Cowls and many more mods than >we >don't have time to disclose. Mark F. "We can't wait." > >Regards, >Tom > > >Tom Whelan >Whelan Farms Airport >President EAA Chapter 1097 ________________________________________________________________________________
Date: Sep 15, 2004
Subject: Re: gluing canopy to frame
In a message dated 9/15/04 12:49:52 PM Central Daylight Time, bkbrown(at)ashcreekwireless.com writes: > I'd like to start a thread to investigate the wisdom (and results if there > are any) of gluing the canopy to the frame instead of using screws. FWIW, I used proseal to attach both canopy parts (tip-up) to the canopy frame and cabin frame (rollbar) to avoid exposed screws or holes in the plexi. (Screws and proseal were used for the rear skin and sides of the canopy frame) Due (I believe) to the different expansion rates of the aluminum rollbar and the plexi, as soon as the plane was exposed to some real heat in direct sunlight, the proseal separated from the plexi in some areas of the rollbar, but has held nicely to the canopy frame, which is less rigid than the rollbar. I didn't scuff the plexi prior to application which may have contributed to the separation, just thoroughly cleaned it. Other materials may hold better, but I would be concerned about the stresses from temperature variation. I you're doing a slider, this may not be as much of an issue, however....... From The PossumWorks in TN Mark -6A, 110 hours & waiting for call from painter! ________________________________________________________________________________
Date: Sep 15, 2004
Hi, I'm planning on doing this with my RV8. I don't have the details from the kitplanes article by the South African guy, but I did find some information on the web site that supplies the glue he used. I copied it onto my web site in case they move theirs: http://www.rv8.ch/article.php?story 040515213437823 Their URL is http://www.sikaindustry.com/ipd-marine-window-295 The stuff from "Barefoot Billy" Waters looks great - I'll try to contact him for more details. Additionally, I met a German guy with an RV6 http://www.rv8.ch/gallery/view_photo.php?set_albumName=Interlaken04&id=DSC01822 who glued on his canopy using the same stuff. Been flying with no trouble for about 6 years, IIRC. I'm sure this will be the recommended way to attach the canopy to the frame in about 5-10 years! :-) Mickey >In my Super 8 section, under interesting. You will see some photos of a >glue job on an 8 canopy. >http://www.mstewart.net/michael/rv/index.htm > > >>I'd like to start a thread to investigate the wisdom (and results if >>there are any) of gluing the canopy to the frame instead of using >>screws. ... > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Sep 15, 2004
Take a look at the January 2004 issue of EAA Sport Aviation. There is an article there about installing your canopy with Sikaflex 295UV adhesive. Also see http://www.rv8.ch/article.php?story 040515213437823 and http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2004-01-27.txt I am going to use this (Sikaflex 295UV) to attach my canopy. Will let the group know how it comes out. Dick Tasker Karen and Robert Brown wrote: > >Hi everyone, I'm happy to be back on the list after a 6 month absence, moving (the plane was unscathed) and getting back to work. > >I'd like to start a thread to investigate the wisdom (and results if there are any) of gluing the canopy to the frame instead of using screws. I noticed in an earlier post from Jim Duckett in Nov. of 2001 the mention of using a product from FUSOR. In that post, Jim mentioned that adhesive manufacturer had a brand that GM uses to glue the door hinges onto the door posts in its new vehicles. Details of that post are in the archives. > >While all of us are building "plans built" aircraft, and the plans call for screws to be used to attach the canopy to the frame, I think the case can be made that using an adhesive might save time and might eliminate issues with cracking, while still performing the most critical task -- keeping the canopy attached to the frame in flight... I believe this is how all plexi is fixed into canopies and window panels of modern jet aircraft of almost all types, surely we can find an adhesive suitable for our application. I believe I heard that builders in South Africa were using this technique, but could find nothing like that in the archives, so maybe I was imagining it. > >Does anyone have real information on this?? > > >Bob Brown >Independence, OR >RV-7AQB (finish) > > > > ________________________________________________________________________________
Date: Sep 15, 2004
Here is an exerp of an earlier email with glue info sent before I actually glued it. I have since glued the canopy on with good results, The one thing i would do differently is to glue the canopy on with bare minimum of glue, let this set, then go back and backfill and smooth out. for better astetics. my canopy moved a tad too much and it was hard to get an even looking result. Hi Todd Yes I definitely will try and glue. Matter of fact, talked with SIKA, the folks mentioned in my previous email and the Sport Aviation article. (Steve @ 1-888-832-7452). Very, very nice person. First words were "Sorry, we do not support your application", right after that, " now that I have said that, how can I really help you............" We talked for a while, Steve mentioned that his phone has been ringing off the hook ever since the Sport Aviation article came out. He kinda jokingly grumbled that he has had more response to an article SIKA did not write for, a use SIKA does not support in a magazine SIKA did not know about than what his total advertisement budget generated last year. Steve said I should very carefully read the info at http://www.sikaindustry.com/ipd-marine-window-295. and recommended to use SIKA 209 to cover the plexi to make it opaque, SIKA 226 for cleaning the frame and SIKAFLEX 295UV BLACK for gluing the canopy on, trying to get at least 1/8" space between the canopy and the frame. He recommends that all structural bonding is done in the BLACK urethane as it has much better UV properties. if needed, one can make filets with WHITE urethane over the black stuff, 295UV comes in black and white colors. Most places I called would only sell a case of 12 10-ounce tubes of the 295UV, Again Steve to the rescue......Jamestown Distributors @ 800-423-0030 will sell you individually, pricing: about 12 for a tube of 295UV black or white, 31 for a pint of 209 and 11 for a pint of 226. So, that's what I ordered, tube o' black&white, 226 and 209. One could say I am now committed ;-) Took me a weekend to cut the canopy. Agony, agony, agony, lots of sweat.................. if there is one thing I would do different is to not cut the rear of the canopy, till I have the front close. Originally, my canopy did not even cover half the tubes on the side frames of the slider. by dropping the front 1/8" at the time I brought the sides of the canopy till just even with the bottom of the frame. This however did 2 things, one it brought the highest point of the canopy forward as it is sliding over the roll-over bar, and two, it pulls the rear of the canopy forward. I had cut some off the rear in an attempt to make the canopy come down as a whole. ( I am 6'6", I need all the headroom I can have ;-) Well, there you have it, my experience so far for posterity, to pass along if you so wish. I will let you know what transpires when I get to the gluing bit. Let me know if you can milk any info out of Charlie, Sure would like to know what sticks better to plexi and canopy frames than Kryptonite to Superman. Gert Mickey Coggins wrote: > > Hi, > > I'm planning on doing this with my RV8. I don't have the > details from the kitplanes article by the South African > guy, but I did find some information on the web site that > supplies the glue he used. I copied it onto my web site > in case they move theirs: > > http://www.rv8.ch/article.php?story 040515213437823 > > Their URL is http://www.sikaindustry.com/ipd-marine-window-295 > > The stuff from "Barefoot Billy" Waters looks great - I'll > try to contact him for more details. > > Additionally, I met a German guy with an RV6 > http://www.rv8.ch/gallery/view_photo.php?set_albumName=Interlaken04&id=DSC01822 > who glued on his canopy using the same stuff. Been flying > with no trouble for about 6 years, IIRC. > > I'm sure this will be the recommended way to attach the > canopy to the frame in about 5-10 years! :-) > > Mickey > > > >>In my Super 8 section, under interesting. You will see some photos of a >>glue job on an 8 canopy. >>http://www.mstewart.net/michael/rv/index.htm >> >> >> >>>I'd like to start a thread to investigate the wisdom (and results if >>>there are any) of gluing the canopy to the frame instead of using >>>screws. ... >> >>-- >>Mickey Coggins >>http://www.rv8.ch/ >>#82007 QB Wings/Fuselage > > > > > > > > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Subject: Remove Aileron Twist
Date: Sep 15, 2004
All, I posted a message a few days about aileron twist, and I thought I would follow up with the results. After initially riveting the top surface of my RV7A aileron, I found that I had around 1/8" twist in the trailing edge. The insructions say to flip it over, weigh it down, then pop-rivet the bottom side. I basically did just that, but I used a LOT of weight. I cut a nice, flat board to the width of the aileron and loaded it down with four 25 lb bags of lead shot (distributed across board). That obviously kept the aileron flat on the table, while I proceeded to finish riveting the bottom edge. When I was finished, the edge came out perfectly straight...a maximum of 0.04" twist. FWIW... Thanks for the help, Scott 7A Wings - Flaps are all that's left www.scottsrv7a.com Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Sep 15, 2004
> > Guys, > > Is there any rule of thumb to know whether a grass strip is > smooth enough to operate an RV out of? In this case I'm > talking about a strip that is a couple years old and has only > had a Cub and Stinson fly in and out of it, both of which fly > slower and have bigger tires than an RV. The strip has has > never been rolled, and never had an RV or anything with > smaller wheels land on it...the owner expressed some concern > about the RV landing on it but he isn't too familiar with the > RV design so I don't know if his concerns are justified. Is > there any sort of objective criteria one can use before > landing an RV on it to determine whether it's smooth enough? > > Thanks, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D finishing... Mark, This has come up before on this list. Generally, I don't think the wheel size is the limitation in our case, the localized holes better not be so big as to be a problem. The problem comes with undulations in the strip, and the resonant frequency of the trigear setup. The trigears will really get into pitch oscillations with the right combination of speed, balance and waves in the strip. Don't try to correct for them with elevator, just freeze the elevator at the takeoff position and ride them out. Alex Peterson Maple Grove, MN RV6-A N66AP 522 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: Re: grass runway smoothness for RV operations
Date: Sep 15, 2004
Mark Navratil, I would talk to Ron White, TC for Chapter 33. As you know he flies a Long Ez. He and his wife Connie fly into the grass Village Oaks airstrip at Blue Grass Iowa without any problems. With that said it is a smooth strip. I'd have Ron look at your proposed strip. I know you can depend on what he says as he is very conservative. Cy Galley - Chair, Emergency Aircraft Repair EAA Safety Programs Editor - TC EAA Sport Pilot Chapter 75 Rock Island, IL ----- Original Message ----- From: "Alex Peterson" <alexpeterson(at)earthlink.net> Subject: RE: RV-List: grass runway smoothness for RV operations > > > > > Guys, > > > > Is there any rule of thumb to know whether a grass strip is > > smooth enough to operate an RV out of? In this case I'm > > talking about a strip that is a couple years old and has only > > had a Cub and Stinson fly in and out of it, both of which fly > > slower and have bigger tires than an RV. The strip has has > > never been rolled, and never had an RV or anything with > > smaller wheels land on it...the owner expressed some concern > > about the RV landing on it but he isn't too familiar with the > > RV design so I don't know if his concerns are justified. Is > > there any sort of objective criteria one can use before > > landing an RV on it to determine whether it's smooth enough? > > > > Thanks, > > > > --Mark Navratil > > Cedar Rapids, Iowa > > RV-8A N2D finishing... > > Mark, > This has come up before on this list. Generally, I don't think the > wheel size is the limitation in our case, the localized holes better not > be so big as to be a problem. The problem comes with undulations in the > strip, and the resonant frequency of the trigear setup. The trigears > will really get into pitch oscillations with the right combination of > speed, balance and waves in the strip. Don't try to correct for them > with elevator, just freeze the elevator at the takeoff position and ride > them out. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 522 hours > > http://www.home.earthlink.net/~alexpeterson/ > > ________________________________________________________________________________
Date: Sep 15, 2004
"RV-8(at)yahoogroups.com"
Subject: spraylat removal
Hi Folks I am trying to remove my spraylat layer from my canopy. it's coming off over about 90 percent of the canopy with no problem......however...on the remaining 10 percent it sticks better to the plexi than kryptonite to superman!! Does anybody have a good suggestion/solution to persuade the spraylat from letting go of the canopy??? Thanks in advance. Gert -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Sep 15, 2004
I walk my grass strip every once in awhile to check for ground squirrel holes,ect. If it is bumpy to your feet,it is going to chatter your wheel pants. Best bet is to wait for a good rain and then get some asphalt company to come out with a vibratory roller and beat the bumps back into the ground. It is well worth the $300-$400 it might cost. You should only have to do this once a year. Since you are in a freeze thaw area I could see this happening every spring. The key is getting a very large roller or one that is vibratory. --- "czechsix(at)juno.com" wrote: > > > > Guys, > > Is there any rule of thumb to know whether a grass > strip is smooth enough to operate an RV out of? In > this case I'm talking about a strip that is a couple > years old and has only had a Cub and Stinson fly in > and out of it, both of which fly slower and have > bigger tires than an RV. The strip has has never > been rolled, and never had an RV or anything with > smaller wheels land on it...the owner expressed some > concern about the RV landing on it but he isn't too > familiar with the RV design so I don't know if his > concerns are justified. Is there any sort of > objective criteria one can use before landing an RV > on it to determine whether it's smooth enough? > > Thanks, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D finishing... > > Get your name as your email address. > Includes spam protection, 1GB storage, no ads and > more > Only $1.99/ month - visit http://www.mysite.com/name > today! > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 15, 2004
Mark, Having not the wisdom to ask this question on the List, I have been landing on a surface like you describe with no problems. I wish it were smoother, but the RV seems to take the roughness pretty well. I would advise about 3/4 inch of clearance around the tires. I run 35 psi tire pressure in all 3 (tri-gear). I have an IO-360 up front and the nose wheel carries quite a lot of weight, so I keep back stick as much as possible when landing -- takeoffs too for that matter, except the plane just goes up if I do that! BTW has anyone put 6.00 x 6s on the mains? There seems to be plenty of room in the wheel fairings for the larger tires, and it would seem to help us country boys. Dan Hopper RV-7A N766DH flying about 43 hours now. In a message dated 9/15/04 1:08:58 PM US Eastern Standard Time, czechsix(at)juno.com writes: > > > Guys, > > Is there any rule of thumb to know whether a grass strip is smooth enough to > operate an RV out of? In this case I'm talking about a strip that is a > couple years old and has only had a Cub and Stinson fly in and out of it, both of > which fly slower and have bigger tires than an RV. The strip has has never > been rolled, and never had an RV or anything with smaller wheels land on > it...the owner expressed some concern about the RV landing on it but he isn't too > familiar with the RV design so I don't know if his concerns are justified. > Is there any sort of objective criteria one can use before landing an RV on > it to determine whether it's smooth enough? > > Thanks, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D finishing... > > ________________________________________________________________________________
Date: Sep 15, 2004
Subject: wood prop
Someone e-mailed me asking about my wood prop on an IO-360 and I have lost the address. Please e-mail again. Lee Lesher RV-8 Flying ________________________________________________________________________________
Date: Sep 16, 2004
Bob, We used SemWeld from 3M - came in a caulking type tube (you'll need one their caulking type guns - see if you can borrow one from an Auto body shop). We have 300+ hours on our canopy -No issues. It can also be painted. You might want to check the archives under my name back in 2001 - I'm pretty sure I posted a report on it. Please email me off line if you have any questions. Chuck Rowbotham RV-8A >From: "Karen and Robert Brown" <bkbrown(at)ashcreekwireless.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: gluing canopy to frame >Date: Wed, 15 Sep 2004 10:56:01 -0700 > > > >Hi everyone, I'm happy to be back on the list after a 6 month absence, >moving (the plane was unscathed) and getting back to work. > >I'd like to start a thread to investigate the wisdom (and results if there >are any) of gluing the canopy to the frame instead of using screws. I >noticed in an earlier post from Jim Duckett in Nov. of 2001 the mention of >using a product from FUSOR. In that post, Jim mentioned that adhesive >manufacturer had a brand that GM uses to glue the door hinges onto the door >posts in its new vehicles. Details of that post are in the archives. > >While all of us are building "plans built" aircraft, and the plans call for >screws to be used to attach the canopy to the frame, I think the case can >be made that using an adhesive might save time and might eliminate issues >with cracking, while still performing the most critical task -- keeping the >canopy attached to the frame in flight... I believe this is how all plexi >is fixed into canopies and window panels of modern jet aircraft of almost >all types, surely we can find an adhesive suitable for our application. I >believe I heard that builders in South Africa were using this technique, >but could find nothing like that in the archives, so maybe I was imagining >it. > >Does anyone have real information on this?? > > >Bob Brown >Independence, OR >RV-7AQB (finish) ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling(at)earthlink.net>
Subject: enabling approaches on UPSAT GX50
Date: Sep 15, 2004
I spoke with the Garmin folks about my gx50 today because I couldnt get approaches enabled. I was told the faa must first certify the install, then the instller can make the switch. Has anyone done this? I dont have the install manual with me now? Shemp 6a Chicago/Louisville ________________________________________________________________________________
Date: Sep 16, 2004
Gert, the spraylat is hard to remove when it's too thin to peel. Try masking small areas around the offending spraylat and apply a good heavy coat to dry overnight. Then just peel off in the morning.. Steve Hi Folks I am trying to remove my spraylat layer from my canopy. it's coming off over about 90 percent of the canopy with no problem......however...on the remaining 10 percent it sticks better to the plexi than kryptonite to superman!! Does anybody have a good suggestion/solution to persuade the spraylat from letting go of the canopy??? Thanks in advance. Gert -- ________________________________________________________________________________
Date: Sep 15, 2004
From: Hal / Carol Kempthorne <kempthornes(at)earthlink.net>
At 10:56 AM 9/15/2004, you wrote: > >I'd like to start a thread to investigate the wisdom (and results if there >are any) of gluing the canopy to the frame instead of using screws. Use a glue known to be kind to acrylic. Many resins are not. The wrong stuff can cause crazing and even cracking, neither of which are desirable. I suppose epoxy must be okay since it is the choice for windshield fairings attach. K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Sep 16, 2004
Subject: DYNON D10A & ENCODER PROTOCOL
Hello All Are there any listers who have installed a Dynon D10A lately and used the serial encoder for a Garmin GTX 327? Which protocol did you used and was it worth it. I presently have an Ameriking AK-350 blind encoder connected to my GTX 327 and it's working fine. So I'm wondering if there are any advantages in using this feature? Also is there anyone with a web site with pictures of the Dynon's installation? As you know a picture is worth a 1000 words.... Thanks a lot for your imputs. Bruno Dionne C-GDBH RV-4 rv4(at)videotron.ca P.S# You may reply OFF list if you wish. ________________________________________________________________________________
Date: Sep 16, 2004
Subject: Re: WTB RV -6/6A or-7/7A
I just listed my 6A on Trade a plane eregensburg(at)triad.rr.com > >Hi, > >A friend of mine is having bad luck finding an RV for sale. An >ex-military pilot, he likes the acrobatic feel with side-by-side >seating of the -6 and -7 models. He doesn't care which end the >third wheel is attached. He prefers IFR equipped. Please send me >particulars and contact info! > >cheers, >Chuck Packard >YankeeRV10(at)yahoo.com > > > >_______________________________ >Declare Yourself - Register online to vote today! >http://vote.yahoo.com > > ________________________________________________________________________________
Date: Sep 16, 2004
I also had trouble removing Spraylat from my canopy. A high pressure washer worked for me very well. I used a 2200 PSI washer and it blasted the Spraylat of easily. In about 10-15 minutes it sparkled with no damage from the pressure washer. Pat Long PGLong(at)aol.com N120PL RV4 Bay City, Michigan 3CM ________________________________________________________________________________
Subject: Specks in fuel!
Date: Sep 16, 2004
About 6 months ago specks in the fuel started to show up. During preflight when the aircraft had set for some time, when I drain fuel from under the wing I find some brown or blackish specks floating in the fuel. It takes about 6 ounces of draining to clear up the specks. I don't think it is from the fuel truck. Has anyone experienced something similar? Could it be the tanks sealer is dissolving? I have a QB RV8, 10 months since first flight with 140 hours total. Thanks, Steve Glasgow ________________________________________________________________________________
Date: Sep 16, 2004
Subject: Re: DYNON D10A & ENCODER PROTOCOL
Bruno, You need to set the GTX 327 to receive the Icarus format. I haven't installed mine yet, but I have verified this in a bench test. The microEncoder from RMI calls it the Northstar format and Transcal calls it the Trimble/Garmin format. Nothing like standards to make all of this easier. Ken ---------- Original Message ---------------------------------- From: Bruno <rv4(at)videotron.ca> Date: Thu, 16 Sep 2004 00:49:05 -0400 > >Hello All > Are there any listers who have installed a Dynon D10A lately >and used the serial encoder for a Garmin GTX 327? > > Which protocol did you used and was it worth it. I presently >have an Ameriking AK-350 blind encoder connected to my GTX 327 and it's >working fine. So I'm wondering if there are any advantages in using this >feature? > >Also is there anyone with a web site with pictures of the Dynon's >installation? As you know a picture is worth a 1000 words.... > >Thanks a lot for your imputs. > >Bruno Dionne >C-GDBH RV-4 >rv4(at)videotron.ca > >P.S# You may reply OFF list if you wish. > > ________________________________________________________________________________
Subject: alternators
Date: Sep 16, 2004
Hi all -- any photos or advice on an alternator set-up for an RV6. I've got the Vans brackets and a Bosch alternator but it seems to hit the lower cowl. Cheers Shirley RV6 ________________________________________________________________________________
Subject: Rudder Cable Fairings
Date: Sep 16, 2004
I decided not to make my own and ordered a set from Avery (p/n10728 pg 74 in catalog $9.00/pr). They are absolute junk. The only item I purchased from Avery that was not top notch. I will return them some day. I just received a beautiful set from Karen at Aviation Products, in Ojai, CA (ph 805-646-6042) p/n 5387 @$8.95/pr. She shipped them overnight and said to send a check when received. Amazing service! Just trim to size, drill, dimple, and rivet. No epoxe filler required on these. Scott Diffenbaugh diff(at)foothill.net ________________________________________________________________________________
Date: Sep 16, 2004
Subject: 2 questions
Hi Guys & Gals, Two questions. First is fairly simple; does anyone have or know where I can get a pair of Van's "Old Style" top, aluminum wing root fairings? Second is more complex; I've had an "interesting" short in my wiring for about 6 months. Everything is Fine in positive "G's" but when I get negative (anything at or exceeding -1 "G" ) my Amp meter pegs out to the + side and my KLX-135A re-sets. This is only momentarily; meaning it goes back to normal in a second or two whether I release the negative "G" loads or not. Now I've of course pulled everything apart, checked connections, re-placed the Amp meter, and bundled any wires that could possibly touch anything. I'm wondering if it could be something inside the alternator (Honda type from "Auto-Zone"). Any thoughts or "clues" would be greatly appreciated. This ones causing me to gain mo' grey hairs. Thanks, Chuck --------------------------------- ________________________________________________________________________________
Date: Sep 16, 2004
Doug, Thanks for the suggestion. If the oil separator appears to be clear, I'll check out the sensor connection. If I still get high pressure readings I'll replace the sensor. Regards, Chris. ----- Original Message ----- From: "Doug Rozendaal" <dougr(at)petroblend.com> Date: Wed, 15 Sep 2004 11:35:13 -0500 Subject: Re: RV-List: High fuel pressure Chris. I had trouble with my Rocky sensor, reading high oil pressure, also a VDO and it turned out it was a bad connection. The Rocky reads higher pressure as lower resistance, ie an open reads top of scale. I assume yours is the same. Doug ----- Original Message ----- From: "Chris Good" <chrisjgood(at)lycos.com> Subject: RV-List: High fuel pressure > > Listers, > > My EIS-4000 has started complaining about high fuel pressure recently. This is on an O-360-A1A with a carb & the standard low pressure engine driven fuel pump. In normal cruise, I get a fuel pressure reading somewhere between 2 & 5 psi, which is fine. The problem occurs intermittently when taxiing, & recently in the air when throttling back for a descent. The pressure climbs to 10-12 psi. > > Looking back a couple of years at my engine monitor logs, the pressure never used to exceed 6-7 psi. All the above readings are without the electric boost pump. > > In looking at the archives & other internet sources I found two suggestions: > > 1. The VDO pressure sensor is only good for 2-300 hrs. But this doesn't seem like a sensor problem as my cruise readings are normal. > > 2. The fuel pump pressure regulator is vented to the crankcase & high fuel pressure can be a symptom of breather blockage. This seems possible as I have a home-made oil separator on the breather. Maybe this is blocked & the engine is breathing through the whistle slot! I plan to check this in the next couple of days. > > Has anyone experienced this? Any other suggestions? > > Regards, > > Chris Good, > West Bend, WI > RV-6A, 775 hrs > -- > > -- ________________________________________________________________________________
Date: Sep 16, 2004
Subject: RAC info needed
Listers, Has anyone out there purchased and installed a Ray Allen Stick grip? I'm waiting for mine. I'd like to draw up the schematic while I wait. Could you please tell me the color codes of the wires on the servos? I also would like the color codes on the wire that they include with the grip kit. I called Ray Allen last week. He couldn't definitively tell me what the color coding was on the wires. Thanks Charlie Kuss ________________________________________________________________________________
Subject: Re: 2 questions
Date: Sep 16, 2004
Chuck: I have 2 aluminum RV-4 wing root fairings left over from my project. Never touched. Contact me off list. Doug Weiler Hudson, WI dcw(at)nomadwi.com > > Two questions. First is fairly simple; does anyone have or know where I > can get a pair of Van's "Old Style" top, aluminum wing root fairings? > > Second is more complex; I've had an "interesting" short in my wiring for > about 6 months. Everything is Fine in positive "G's" but when I get > negative (anything at or exceeding -1 "G" ) my Amp meter pegs out to the + > side and my KLX-135A re-sets. This is only momentarily; meaning it goes > back to normal in a second or two whether I release the negative "G" loads > or not. > > Now I've of course pulled everything apart, checked connections, re-placed > the Amp meter, and bundled any wires that could possibly touch anything. > I'm wondering if it could be something inside the alternator (Honda type > from "Auto-Zone"). > > Any thoughts or "clues" would be greatly appreciated. This ones causing > me to gain mo' grey hairs. Thanks, > > Chuck > > > --------------------------------- > > > ________________________________________________________________________________
Date: Sep 16, 2004
Subject: Good source for West System epoxy or equiv.
I'd like to buy some West System epoxy or something "just as good", and I'm looking for a good source. Spruce looks ok, but they won't ship it international since they claim it is "hazardous". I don't really know why it is considered hazardous. I can buy it "locally", but its about 2.5x the US price, and I can't really stomach that kind of markup. Thanks for any pointers! -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Sep 16, 2004
Jeff, It has been a while but I didn't have any trouble enabling approach on by GX-60. It must be connected to other devices for the approach function to be enabled. The following is from the install manual. I can send the PDF to you if you like. For TSO-C129a A1 (non-precision approach) operation the following connections are also required: . external lamp annunciators including "APPRCH" and "ACTIVE" . an "OBS/HLD" external annunciator (with switch) . altitude input from an altitude encoder/converter or air data computer Ken > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Jeff Dowling > Sent: Wednesday, September 15, 2004 9:24 PM > To: rv-list(at)matronics.com > Subject: RV-List: enabling approaches on UPSAT GX50 > > > I spoke with the Garmin folks about my gx50 today because I couldnt get > approaches enabled. I was told the faa must first certify the install, > then the instller can make the switch. Has anyone done this? I dont > have the install manual with me now? > > Shemp > 6a > Chicago/Louisville > > > > ________________________________________________________________________________
Date: Sep 16, 2004
If I recall, my grips came with a bunch of 24 AWG white wire. I had to do some soldering and stuff myself. No color code - all white. Jordan -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Charlie Kuss Subject: RV-List: RAC info needed Listers, Has anyone out there purchased and installed a Ray Allen Stick grip? I'm waiting for mine. I'd like to draw up the schematic while I wait. Could you please tell me the color codes of the wires on the servos? I also would like the color codes on the wire that they include with the grip kit. I called Ray Allen last week. He couldn't definitively tell me what the color coding was on the wires. Thanks Charlie Kuss ________________________________________________________________________________
Date: Sep 16, 2004
Subject: Re: Good source for West System epoxy or equiv.
Micky, Try West Marine, that's where I bought all of my West system epoxy supplies. Cannot comment as to international shipping policy though. http://www.westmarine.com/ Rick Galati RV-6A "finishing" I'd like to buy some West System epoxy or something "just as good", and I'm looking for a good source. Spruce looks ok, but they won't ship it international since they claim it is "hazardous". I don't really know why it is considered hazardous. I can buy it "locally", but its about 2.5x the US price, and I can't really stomach that kind of markup. Thanks for any pointers! -- Mickey Coggins ________________________________________________________________________________
Date: Sep 16, 2004
I get mine direct from West. www.westsystem.com Lots of good information on their web site too. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mickey Coggins Subject: RV-List: Good source for West System epoxy or equiv. I'd like to buy some West System epoxy or something "just as good", and I'm looking for a good source. Spruce looks ok, but they won't ship it international since they claim it is "hazardous". I don't really know why it is considered hazardous. I can buy it "locally", but its about 2.5x the US price, and I can't really stomach that kind of markup. Thanks for any pointers! -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage = = = = ________________________________________________________________________________
Date: Sep 16, 2004
Might try Wicks. I bought mine from them without a hazard fee but then it was a US shipment. ----- Original Message ----- From: "Rick Galati" <rick6a(at)yahoo.com> Subject: RV-List: Re: Good source for West System epoxy or equiv. > > Micky, > > Try West Marine, that's where I bought all of my West system epoxy supplies. Cannot comment as to international shipping policy though. > > http://www.westmarine.com/ > > Rick Galati RV-6A "finishing" > > > I'd like to buy some West System epoxy or something > "just as good", and I'm looking for a good source. > > Spruce looks ok, but they won't ship it international > since they claim it is "hazardous". I don't really > know why it is considered hazardous. > > I can buy it "locally", but its about 2.5x the US price, > and I can't really stomach that kind of markup. > > Thanks for any pointers! > > > -- > Mickey Coggins > > ________________________________________________________________________________
Date: Sep 16, 2004
Chuck, To the + side means the alternator is running away -- overcharging. Turn off the alternator field breaker and try it. If that fixes it, it has to be in the regulator or field circuit. If not??????? It certainly could be in the alternator, or anywhere, I guess, until you find it! Dan Hopper Automotive electrical engineer, ret. N766DH (Flying about 43 hours now.) In a message dated 9/16/04 12:50:58 PM US Eastern Standard Time, chuck515tigger(at)yahoo.com writes: > > > Hi Guys &Gals, > > Two questions. First is fairly simple; does anyone have or know where I can > get a pair of Van's "Old Style" top, aluminum wing root fairings? > > Second is more complex; I've had an "interesting" short in my wiring for > about 6 months. Everything is Fine in positive "G's" but when I get negative > (anything at or exceeding -1 "G" ) my Amp meter pegs out to the + side and my > KLX-135A re-sets. This is only momentarily; meaning it goes back to normal > in a second or two whether I release the negative "G" loads or not. > > Now I've of course pulled everything apart, checked connections, re-placed > the Amp meter, and bundled any wires that could possibly touch anything. I'm > wondering if it could be something inside the alternator (Honda type from > "Auto-Zone"). > > Any thoughts or "clues" would be greatly appreciated. This ones causing me > to gain mo' grey hairs. Thanks, > > Chuck > ________________________________________________________________________________
Date: Sep 16, 2004
Subject: Re: Specks in fuel!
on zoot.lafn.org My -6 has been doing this on the right tank since it was new (2000). It's never been a problem and none has made it to the filter but it is kind of annoying, wondering what it is. It almost has to be sealer since it's there any time I sump the tank. Maybe I should save some and analyze it. Are you seeing it in both tanks? Dave Bristol RV6 SO Cal Steve Glasgow wrote: > >About 6 months ago specks in the fuel started to show up. > >During preflight when the aircraft had set for some time, when I drain fuel >from under the wing I find some brown or blackish specks floating in the >fuel. It takes about 6 ounces of draining to clear up the specks. I don't >think it is from the fuel truck. > >Has anyone experienced something similar? Could it be the tanks sealer is >dissolving? > >I have a QB RV8, 10 months since first flight with 140 hours total. > >Thanks, >Steve Glasgow > > > > ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: Specks in fuel! on zoot.lafn.org
Date: Sep 16, 2004
Dave: I am not flaming -- Just curious and interested. Your plane has been flying for 4 years and has been doing this since day one. You are seeing bits of stuff but don't really know -- I guess you might be suggesting it is proseal ? Just wondering, did you build your own tanks or where they built by someone else? If you built them, was anything at all introduced into the tank other than proseal? Is it possible that the tanks were open to invasion by outsiders such as mud dobbers or spiders that might of planted some materials inside the tanks prior to them being sealed close? Anything other than fuel ever put into the tank that you know of? You say none of the bits made it to the filter. Let me ask, Do you have a fuel filter or the Vans gascolator? If its the gascolator, when you drain a bit from the gascolator do you have the electric fuel pump turned on? Larry ----- Original Message ----- From: "Dave Bristol" <bj034(at)lafn.org> Subject: Re: RV-List: Specks in fuel! on zoot.lafn.org > > My -6 has been doing this on the right tank since it was new (2000). > It's never been a problem and none has made it to the filter but it is > kind of annoying, wondering what it is. It almost has to be sealer since > it's there any time I sump the tank. Maybe I should save some and > analyze it. > > Are you seeing it in both tanks? > > Dave Bristol RV6 SO Cal > > Steve Glasgow wrote: > > > > >About 6 months ago specks in the fuel started to show up. > > > >During preflight when the aircraft had set for some time, when I drain fuel > >from under the wing I find some brown or blackish specks floating in the > >fuel. It takes about 6 ounces of draining to clear up the specks. I don't > >think it is from the fuel truck. > > > >Has anyone experienced something similar? Could it be the tanks sealer is > >dissolving? > > > >I have a QB RV8, 10 months since first flight with 140 hours total. > > > >Thanks, > >Steve Glasgow > > > > > > > > > > ________________________________________________________________________________
Date: Sep 16, 2004
This might be a lame idea, but do the bits float or sink in fuel? I don't know whether little crumbs of proseal would float or sink, but the fuel sender gasket is cork. It could also be something from the sending unit itself. ----- Original Message ----- From: "Dave Bristol" <bj034(at)lafn.org> Subject: Re: RV-List: Specks in fuel! on zoot.lafn.org > > My -6 has been doing this on the right tank since it was new (2000). > It's never been a problem and none has made it to the filter but it is > kind of annoying, wondering what it is. It almost has to be sealer since > it's there any time I sump the tank. Maybe I should save some and > analyze it. > > Are you seeing it in both tanks? > > Dave Bristol RV6 SO Cal > > Steve Glasgow wrote: > > > > >About 6 months ago specks in the fuel started to show up. > > > >During preflight when the aircraft had set for some time, when I drain fuel > >from under the wing I find some brown or blackish specks floating in the > >fuel. It takes about 6 ounces of draining to clear up the specks. I don't > >think it is from the fuel truck. > > > >Has anyone experienced something similar? Could it be the tanks sealer is > >dissolving? > > > >I have a QB RV8, 10 months since first flight with 140 hours total. > > > >Thanks, > >Steve Glasgow > > > > > > > > > > ________________________________________________________________________________
Date: Sep 17, 2004
This may not be relevant to your situation but I had a similar problem after I bought my Grumman back in '93. Dark specks kept showing up throughout the next year. Inspections of the aux pump and carb filters (no gascolator on a T-Cat) revealed nothing. Then, a wing drain became clogged. I removed it (under proper supervision of course) and observed a wad of sticky crud in the drain valve --- bug stuff. Same on the other side to a lesser degree. I replaced the drains after tapping them and now have screws installed when parked --- no problems since. Bob Trumpfheller FWF 7A simple project update page at: http://users.aol.com/n67bt <> ________________________________________________________________________________
Date: Sep 17, 2004
on zoot.lafn.org LarryRobertHelming wrote: > >Dave: I am not flaming -- Just curious and interested. Your plane has been >flying for 4 years and has been doing this since day one. > >You are seeing bits of stuff but don't really know -- I guess you might be >suggesting it is proseal ? > >Just wondering, did you build your own tanks or where they built by someone >else? > I built them. > >If you built them, was anything at all introduced into the tank other than >proseal? > At that time Van's recommended sealing the rear baffle with sloshing compound so that is a possibility, > >Is it possible that the tanks were open to invasion by outsiders such as mud >dobbers or spiders that might of planted some materials inside the tanks >prior to them being sealed close? > I discounted this because it's not that kind of debris, it looks like rust flakes which would be a possibility in an older airplane since the senders are subject to rust. > Anything other than fuel ever put into >the tank that you know of? > No. > >You say none of the bits made it to the filter. Let me ask, Do you have a >fuel filter or the Vans gascolator? If its the gascolator, when you drain a >bit from the gascolator do you have the electric fuel pump turned on? Larry > No gascolator. I have the AFP filter at the electric pump and have never found anything other than avgas in it. I'm going to pull that tank soon to fix a seeping access plate so I may open it up and have a look. I'll report back. Dave > >----- Original Message ----- >From: "Dave Bristol" <bj034(at)lafn.org> >To: >Subject: Re: RV-List: Specks in fuel! on zoot.lafn.org > > > > >> >>My -6 has been doing this on the right tank since it was new (2000). >>It's never been a problem and none has made it to the filter but it is >>kind of annoying, wondering what it is. It almost has to be sealer since >>it's there any time I sump the tank. Maybe I should save some and >>analyze it. >> >>Are you seeing it in both tanks? >> >>Dave Bristol RV6 SO Cal >> >>Steve Glasgow wrote: >> >> >> >>> >>>About 6 months ago specks in the fuel started to show up. >>> >>>During preflight when the aircraft had set for some time, when I drain >>> >>> >fuel > > >>>from under the wing I find some brown or blackish specks floating in the >> >> >>>fuel. It takes about 6 ounces of draining to clear up the specks. I >>> >>> >don't > > >>>think it is from the fuel truck. >>> >>>Has anyone experienced something similar? Could it be the tanks sealer >>> >>> >is > > >>>dissolving? >>> >>>I have a QB RV8, 10 months since first flight with 140 hours total. >>> >>>Thanks, >>>Steve Glasgow >>> >>> >>> >>> >>> >>> >> >> > > > > ________________________________________________________________________________
Date: Sep 17, 2004
on zoot.lafn.org They sink. Which is another reason I thought it might be rust from the sending unit. But, if it IS rust then it started VERY quickly on a new sending unit. Dave steve zicree wrote: > >This might be a lame idea, but do the bits float or sink in fuel? I don't >know whether little crumbs of proseal would float or sink, but the fuel >sender gasket is cork. It could also be something from the sending unit >itself. > >----- Original Message ----- >From: "Dave Bristol" <bj034(at)lafn.org> >To: >Subject: Re: RV-List: Specks in fuel! on zoot.lafn.org > > > > >> >>My -6 has been doing this on the right tank since it was new (2000). >>It's never been a problem and none has made it to the filter but it is >>kind of annoying, wondering what it is. It almost has to be sealer since >>it's there any time I sump the tank. Maybe I should save some and >>analyze it. >> >>Are you seeing it in both tanks? >> >>Dave Bristol RV6 SO Cal >> >>Steve Glasgow wrote: >> >> >> >>> >>>About 6 months ago specks in the fuel started to show up. >>> >>>During preflight when the aircraft had set for some time, when I drain >>> >>> >fuel > > >>>from under the wing I find some brown or blackish specks floating in the >> >> >>>fuel. It takes about 6 ounces of draining to clear up the specks. I >>> >>> >don't > > >>>think it is from the fuel truck. >>> >>>Has anyone experienced something similar? Could it be the tanks sealer >>> >>> >is > > >>>dissolving? >>> >>>I have a QB RV8, 10 months since first flight with 140 hours total. >>> >>>Thanks, >>>Steve Glasgow >>> >>> >>> >>> >>> >>> >> >> > > > > ________________________________________________________________________________
Date: Sep 17, 2004
> I decided not to make my own and ordered a set from Avery (p/n10728 pg 74 in > catalog $9.00/pr). They are absolute junk. The only item I purchased from > Avery that was not top notch. I will return them some day. > > I just received a beautiful set from Karen at Aviation Products, in Ojai, CA > (ph 805-646-6042) p/n 5387 @$8.95/pr. She shipped them overnight and said > to send a check when received. Amazing service! Just trim to size, drill, > dimple, and rivet. No epoxe filler required on these. Sounds interesting, do they have a web site where one could get a look? Randy Lervold ________________________________________________________________________________
Subject: Re: Specks in fuel! on zoot.lafn.org on zoot.lafn.org
Date: Sep 17, 2004
Rust could be from your fuel source. If you question this, just take a tractor funnel with the fine mesh screen and run your fuel thru that. You will be amazed. Cy Galley Safety Programs Editor Always looking for ideas and articles for EAA Sport Pilot ----- Original Message ----- From: "Dave Bristol" <bj034(at)lafn.org> Subject: Re: RV-List: Specks in fuel! on zoot.lafn.org on zoot.lafn.org > > They sink. Which is another reason I thought it might be rust from the > sending unit. But, if it IS rust then it started VERY quickly on a new > sending unit. > > Dave > > steve zicree wrote: > > > > >This might be a lame idea, but do the bits float or sink in fuel? I don't > >know whether little crumbs of proseal would float or sink, but the fuel > >sender gasket is cork. It could also be something from the sending unit > >itself. > > > >----- Original Message ----- > >From: "Dave Bristol" <bj034(at)lafn.org> > >To: > >Subject: Re: RV-List: Specks in fuel! on zoot.lafn.org > > > > > > > > > >> > >>My -6 has been doing this on the right tank since it was new (2000). > >>It's never been a problem and none has made it to the filter but it is > >>kind of annoying, wondering what it is. It almost has to be sealer since > >>it's there any time I sump the tank. Maybe I should save some and > >>analyze it. > >> > >>Are you seeing it in both tanks? > >> > >>Dave Bristol RV6 SO Cal > >> > >>Steve Glasgow wrote: > >> > >> > >> > >>> > >>>About 6 months ago specks in the fuel started to show up. > >>> > >>>During preflight when the aircraft had set for some time, when I drain > >>> > >>> > >fuel > > > > > >>>from under the wing I find some brown or blackish specks floating in the > >> > >> > >>>fuel. It takes about 6 ounces of draining to clear up the specks. I > >>> > >>> > >don't > > > > > >>>think it is from the fuel truck. > >>> > >>>Has anyone experienced something similar? Could it be the tanks sealer > >>> > >>> > >is > > > > > >>>dissolving? > >>> > >>>I have a QB RV8, 10 months since first flight with 140 hours total. > >>> > >>>Thanks, > >>>Steve Glasgow > >>> > >>> > >>> > >>> > >>> > >>> > >> > >> > >
September 07, 2004 - September 17, 2004
RV-Archive.digest.vol-pt
