RV-Archive.digest.vol-pv
September 26, 2004 - October 06, 2004
      > help prevent the same situation such as putting proseal around the front
      > to
      > dampen vibration?
      > Dave Figgins empennage
      > -----Original Message-----
      > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DonEavesRV6
      > Subject: RV-List: Rudder Cracks @ Last Rivet On Forward End of Stiffeners
      > I Discovered cracks on my RV6 Rudder running from the last rivet on the
      > forward end of the stiffeners behind the spar - Did not have any cracks on
      > the trailing edge which is in Vans instructions to add a gob of tank /
      > pro-seal -
      > Searched the archives and found 38+- post under Rudder Cracks - Many were
      > about forward cracks - Most fixed the problem by stop drilling the
      > cracks -
      > Noted the RV10 rudder attaches the forward end of stiffeners to the spar -
      > I discovered 1 crack on an RV4 @ my airport - I suspect if we did a fleet
      > inspection we would find more aircraft with cracks in the rudder and
      > elevator at either end of the stiffeners -
      > I use slips to landing and attribute my cracks to that and engine run-up
      > shaking - Anyway this is a point needing structural improvement in future
      > rudders and noted Vans attached the forward end of the stiffeners on the
      > 10.
      > I plan to build a new rudder - I will attach the stiffeners to the spar -
      > Don Eaves
      > RV6 Flown 235 +- Hrs - Currently installing:  Garman 155XL GPS, KN53 Nav
      > and
      > Autopilot.
      > advertising on the Matronics Forums.
Date: Sep 26, 2004
From: Kevin Horton <khorton01(at)rogers.com> Stiffeners
Subject: Rudder Cracks @ Last Rivet On Forward End of
Stiffeners I believe that RV-6s had 0.016" rudder skins. My RV-8 has 0.020" rudder skins. If the RV-7 has the thicker rudder skins that might be enough to address the problem. Don - how thick is your rudder skin? Kevin Horton > > As I am just in the process of doing the rudder for my -7A (and just cut >the stiffeners to length yesterday :( ) is there anything I should do to >help prevent the same situation such as putting proseal around the front to >dampen vibration? > > >Dave Figgins empennage > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DonEavesRV6 >To: rv-list(at)matronics.com >Subject: RV-List: Rudder Cracks @ Last Rivet On Forward End of Stiffeners > >--> > >I Discovered cracks on my RV6 Rudder running from the last rivet on the >forward end of the stiffeners behind the spar - Did not have any cracks on >the trailing edge which is in Vans instructions to add a gob of tank / >pro-seal - > >Searched the archives and found 38+- post under Rudder Cracks - Many were >about forward cracks - Most fixed the problem by stop drilling the cracks - >Noted the RV10 rudder attaches the forward end of stiffeners to the spar - > >I discovered 1 crack on an RV4 @ my airport - I suspect if we did a fleet >inspection we would find more aircraft with cracks in the rudder and >elevator at either end of the stiffeners - > >I use slips to landing and attribute my cracks to that and engine run-up >shaking - Anyway this is a point needing structural improvement in future >rudders and noted Vans attached the forward end of the stiffeners on the 10. >I plan to build a new rudder - I will attach the stiffeners to the spar - > >Don Eaves >RV6 Flown 235 +- Hrs - Currently installing: Garman 155XL GPS, KN53 Nav and >Autopilot. > ________________________________________________________________________________
Subject: Re: Rudder Cracks @ Last Rivet On Forward End of Stiffeners
Date: Sep 26, 2004
Don, In building my RV-3B empennage, which also has the .016 rudder and elevator skins, I researched this quite a bit not wanting to get the cracking myself. I considered upsizing to .020 skins but Van talked me out of it. I used the approach detailed here... http://www.romeolima.com/RV3works/Airframe/airframe.htm#Empennage Randy Lervold ----- Original Message ----- From: "DonEavesRV6" <DonEavesRV6(at)midsouth.rr.com> Subject: RV-List: Rudder Cracks @ Last Rivet On Forward End of Stiffeners > > I Discovered cracks on my RV6 Rudder running from the last rivet on the forward end of the stiffeners behind the spar - > Did not have any cracks on the trailing edge which is in Vans instructions to add a gob of tank / pro-seal - > > Searched the archives and found 38+- post under Rudder Cracks - > Many were about forward cracks - > Most fixed the problem by stop drilling the cracks - > Noted the RV10 rudder attaches the forward end of stiffeners to the spar - > > I discovered 1 crack on an RV4 @ my airport - > I suspect if we did a fleet inspection we would find more aircraft with cracks in the rudder and elevator at either end of the stiffeners - > > I use slips to landing and attribute my cracks to that and engine run-up shaking - > Anyway this is a point needing structural improvement in future rudders and noted Vans attached the forward end of the stiffeners on the 10. > I plan to build a new rudder - I will attach the stiffeners to the spar - > > Don Eaves > RV6 Flown 235 +- Hrs - Currently installing: Garman 155XL GPS, KN53 Nav and Autopilot. > > ________________________________________________________________________________
Subject: Flap useage for short field takeoff
Date: Sep 26, 2004
I'll be a RV6 owner in the next couple days. 150hp fixed pitch Props Inc prop. RPM on rollout is 2250. I would have prefered a constant speed for my short field but that is not the case at this time. My strip is 1500', 25' obstruction on one end, turf, mowed short and well packed, 1500' elv. I have 700 plus hours in tailwheel and operate a Sonex, Citabria, and RANS experimentals with no problems from this strip. After searching the archives on short field performance of the RV, I see many posts on landing, nearly none on takeoff. I have landed two different RV6's and don't feel landing will be the big issue. My question is on flap usage for short, possibly soft field takeoff. What is working the best? Some flaps, no flaps, flaps deployed just before rotation? I plan on practicing at a local grass strip for a few hours before I try my strip and would like to here some combinations that have worked for others. Thanks Frank Cuba Silver Creek NE ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: Flap useage for short field takeoff
Date: Sep 26, 2004
I use half flaps on short field takeoffs. Full flaps gets you off the ground a little sooner, but acceleration really suffers once airborne. With a 1500' strip, I think your landings will be much more interesting than your takeoffs. KB ----- Original Message ----- From: "Frank Cuba" <collrev(at)hamilton.net> Subject: RV-List: Flap useage for short field takeoff > > I'll be a RV6 owner in the next couple days. 150hp fixed pitch Props Inc > prop. RPM on rollout is 2250. I would have prefered a constant speed for > my short field but that is not the case at this time. My strip is 1500', > 25' obstruction on one end, turf, mowed short and well packed, 1500' elv. > I have 700 plus hours in tailwheel and operate a Sonex, Citabria, and RANS > experimentals with no problems from this strip. > After searching the archives on short field performance of the RV, I > see many posts on landing, nearly none on takeoff. I have landed two > different RV6's and don't feel landing will be the big issue. > My question is on flap usage for short, possibly soft field takeoff. > What is working the best? Some flaps, no flaps, flaps deployed just before > rotation? > I plan on practicing at a local grass strip for a few hours before I > try my strip and would like to here some combinations that have worked for > others. > > Thanks > Frank Cuba > Silver Creek NE > > > ________________________________________________________________________________
Date: Sep 26, 2004
From: Hal / Carol Kempthorne <kempthornes(at)earthlink.net> Stiffeners
Stiffeners Stiffeners Making small changes in the design of the rudder such as attaching stiffeners to spar might call for flutter testing - or am I wrong? hal ________________________________________________________________________________
Date: Sep 26, 2004
Stiffeners > Stiffeners > >Making small changes in the design of the rudder such as attaching >stiffeners to spar might call for flutter testing - or am I wrong? > Anything that adds weight aft of the hinge line would probably reduce the airspeed at which flutter would occur. The sensitivity to the added weight increases as the distance from the hinge line increases. Minor changes at the rudder spar would be have less effect on flutter than adding an electric rudder trim tab. I've seen several RVs with electric rudder trim tabs, and none of them have had flutter accidents to my knowledge. A minor weight increase at the rudder spar would probably have a minimal effect on flutter speed, in my opinion. But I am not an aero-elastic flutter specialist, so this opinion is worth what was paid for it. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Subject: Rudder Oil Canning Question - was Cracks @ Last Rivet
Date: Sep 26, 2004
Oil Canning Change? I have a question for anyone about to do the leading edge bend (curl) on their rudder. I seem to have acquired some oil canning of the rudder skins (7A) that I don't think was there before I rolled the skin leading edge. Could someone about to do this leading edge bend check to see if they notice any before/after change in oil canning of the skins (between stiffeners) after doing the bend and let me know. The oil canning on the 7A rudder skins is more of a rolling in/out motion in the skin between the stiffeners similar to what I have on my 6A (no cracks at 335 hrs). Thanks, George McNutt Langley BC 6A flying 7A waiting for wings. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jeff Orear Subject: Re: RV-List: Rudder Cracks @ Last Rivet On Forward End of Stiffeners Dave: I'll chime in here with one suggestion. From what I have gathered from previous discussions on the topic, one factor that contributes to these cracks is preloading the skin. If you do not pre-bend the skin sides at their forward edge so that they overlap each other without needing to force them into position, you will put too much stress on the area where the stiffeners end. The skin tends to try to bow out just past the rudder spar if you need to hold the skins together with a lot of force to form the leading edge. Just watch that area as you Pre-form the skins and you will see what I mean. Hope this helps. Regards, Jeff Orear RV6A N782P (reserved) firewall forward Peshtigo, WI ----- Original Message ----- From: "David Figgins" <2004nospam(at)earthlink.net> Subject: RE: RV-List: Rudder Cracks @ Last Rivet On Forward End of Stiffeners > > As I am just in the process of doing the rudder for my -7A (and just cut > the stiffeners to length yesterday :( ) is there anything I should do to > help prevent the same situation such as putting proseal around the front > to > dampen vibration? > > > Dave Figgins empennage > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DonEavesRV6 > To: rv-list(at)matronics.com > Subject: RV-List: Rudder Cracks @ Last Rivet On Forward End of Stiffeners > > --> > > I Discovered cracks on my RV6 Rudder running from the last rivet on the > forward end of the stiffeners behind the spar - Did not have any cracks on > the trailing edge which is in Vans instructions to add a gob of tank / > pro-seal - > > Searched the archives and found 38+- post under Rudder Cracks - Many were > about forward cracks - Most fixed the problem by stop drilling the > cracks - > Noted the RV10 rudder attaches the forward end of stiffeners to the spar - > > I discovered 1 crack on an RV4 @ my airport - I suspect if we did a fleet > inspection we would find more aircraft with cracks in the rudder and > elevator at either end of the stiffeners - > > I use slips to landing and attribute my cracks to that and engine run-up > shaking - Anyway this is a point needing structural improvement in future > rudders and noted Vans attached the forward end of the stiffeners on the > 10. > I plan to build a new rudder - I will attach the stiffeners to the spar - > > Don Eaves > RV6 Flown 235 +- Hrs - Currently installing: Garman 155XL GPS, KN53 Nav > and > Autopilot. > > > advertising on the Matronics Forums. > ________________________________________________________________________________
Subject: List: fuel injection
Date: Sep 26, 2004
There should be three port- fuel in, fuel out, and fuel inlet pressure to the gauge. Precision airmotive has a free DVD on maintenance, troubleshooting, and hot starting the RSA system. The manuals on operation and service, Training, and Troubleshooting are about $15 each. 360-651-8282, www.precisionairmotive,com Glen Matejcek aerobubba(at)earthlink.net > From: "n255gh(at)frontiernet.net" <n255gh(at)frontiernet.net> > Subject: RV-List: fuel injection > > > > To rv-list > > I have a io 320 e2b with a bendix rsa 5ad1 fuel injection system. I'm > looking for a good book or other form of information that would show > me how to pipe it up.It has three piping port one is fuel supply, the > other is metered fuel and, there is another small line that goes > somewhere. I have no idea. Any help would be appreciated. > > ________________________________________________________________________________
Subject: RV8 Wing Kit For Sale
Date: Sep 26, 2004
0.00 DATE_IN_FUTURE_03_06 Date: is 3 to 6 hours after Received: date RV8 pre-punched wing kit for sale. Materials are in the original shipment crates. Kit includes the capacitive fuel sender and two leading edge landing / taxi lights. Located in the Atlanta area. Also have a partially completed RV8 empennage that I will also sell with the wing kit. Contact me at e-mail aferg(at)incoservices.com. ________________________________________________________________________________
Date: Sep 26, 2004
Half flaps is my recommendation. The problem will come in getting your RV stopped. The engine will take care of the takeoff,but the pilot is the big variable on the landing. Practice slow flight a lot at altitude,ect.,so you can bring it in slow. --- Kyle Boatright wrote: > > > I use half flaps on short field takeoffs. Full flaps > gets you off the ground > a little sooner, but acceleration really suffers > once airborne. > > With a 1500' strip, I think your landings will be > much more interesting than > your takeoffs. > > KB > > > ----- Original Message ----- > From: "Frank Cuba" <collrev(at)hamilton.net> > To: > Subject: RV-List: Flap useage for short field > takeoff > > > > > > > I'll be a RV6 owner in the next couple days. 150hp > fixed pitch Props Inc > > prop. RPM on rollout is 2250. I would have > prefered a constant speed for > > my short field but that is not the case at this > time. My strip is 1500', > > 25' obstruction on one end, turf, mowed short and > well packed, 1500' elv. > > I have 700 plus hours in tailwheel and operate a > Sonex, Citabria, and RANS > > experimentals with no problems from this strip. > > After searching the archives on short field > performance of the RV, I > > see many posts on landing, nearly none on takeoff. > I have landed two > > different RV6's and don't feel landing will be the > big issue. > > My question is on flap usage for short, > possibly soft field takeoff. > > What is working the best? Some flaps, no flaps, > flaps deployed just before > > rotation? > > I plan on practicing at a local grass strip for > a few hours before I > > try my strip and would like to here some > combinations that have worked for > > others. > > > > Thanks > > Frank Cuba > > Silver Creek NE > > > > > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
Date: Sep 26, 2004
.020 Don Eaves RV6 Flying ----- Original Message ----- From: "Kevin Horton" <khorton01(at)rogers.com>; <Stiffeners(at)columbus.rr.com> Subject: RE: RV-List: Rudder Cracks @ Last Rivet On Forward End of Stiffeners Stiffeners > > I believe that RV-6s had 0.016" rudder skins. My RV-8 has 0.020" > rudder skins. If the RV-7 has the thicker rudder skins that might be > enough to address the problem. > > Don - how thick is your rudder skin? > > Kevin Horton > > > > > > As I am just in the process of doing the rudder for my -7A (and just cut > >the stiffeners to length yesterday :( ) is there anything I should do to > >help prevent the same situation such as putting proseal around the front to > >dampen vibration? > > > > > >Dave Figgins empennage > > > > > >-----Original Message----- > >From: owner-rv-list-server(at)matronics.com > >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DonEavesRV6 > >To: rv-list(at)matronics.com > >Subject: RV-List: Rudder Cracks @ Last Rivet On Forward End of Stiffeners > > > >--> > > > >I Discovered cracks on my RV6 Rudder running from the last rivet on the > >forward end of the stiffeners behind the spar - Did not have any cracks on > >the trailing edge which is in Vans instructions to add a gob of tank / > >pro-seal - > > > >Searched the archives and found 38+- post under Rudder Cracks - Many were > >about forward cracks - Most fixed the problem by stop drilling the cracks - > >Noted the RV10 rudder attaches the forward end of stiffeners to the spar - > > > >I discovered 1 crack on an RV4 @ my airport - I suspect if we did a fleet > >inspection we would find more aircraft with cracks in the rudder and > >elevator at either end of the stiffeners - > > > >I use slips to landing and attribute my cracks to that and engine run-up > >shaking - Anyway this is a point needing structural improvement in future > >rudders and noted Vans attached the forward end of the stiffeners on the 10. > >I plan to build a new rudder - I will attach the stiffeners to the spar - > > > >Don Eaves > >RV6 Flown 235 +- Hrs - Currently installing: Garman 155XL GPS, KN53 Nav and > >Autopilot. > > > > ________________________________________________________________________________
From: "David Fenstermacher" <dfenstermacher(at)earthlink.net>
Date: Sep 26, 2004
Alan - your email is bouncing. I use earthlink. I am VERY interested. I am woking on the control surfaces for the tail and was about to order the wing (takes 6 weeks). Anyway, give me a call @ 703-878-2042 or email me your phone number and we can talk. Dave > [Original Message] > From: Alan Ferguson <aferg(at)incoservices.com> > To: > Date: 9/26/2004 7:11:52 PM > Subject: RV-List: RV8 Wing Kit For Sale > > > RV8 pre-punched wing kit for sale. Materials are in the original > shipment crates. Kit includes the capacitive fuel sender and two > leading edge landing / taxi lights. Located in the Atlanta area. Also > have a partially completed RV8 empennage that I will also sell with the > wing kit. Contact me at e-mail aferg(at)incoservices.com. > > ________________________________________________________________________________
From: "mimartin(at)sweetwaterhsa.com" <mimartin(at)sweetwater.com>
Subject: KLX-135A
Date: Sep 26, 2004
I'm wondering how much others have paid for the KLX-135A GPS COM. I ordered from Aircraft Spruce & Specialty and was shocked at the price $3048.00. Is this now the price others are paying? Mickey Martin RV6 ________________________________________________________________________________
Date: Sep 27, 2004
Subject: Boelube, How to use?
How does one use Boelube? I have a little stick of the stuff and it seems hard and crumbly, somewhat like a cross between wax and soap. I rubbed a drill on it and it seemed like nothing happened. I then switched to cutting oil. Cutting oil is visible on the tool or bit, makes me think it is working. How do you know if the Boelube is working? Warren Pondering a little stick of Boelube http://ahyup.com RV-9A (in many small parts) ________________________________________________________________________________
Date: Sep 27, 2004
Subject: Re: Boelube, How to use?
In a message dated 9/27/2004 12:23:12 AM Central Daylight Time, warren(at)ahyup.com writes: > How does one use Boelube? I have a little stick of the stuff and it > seems hard and crumbly, somewhat like a cross between wax and soap. I > rubbed a drill on it and it seemed like nothing happened. I then > switched to cutting oil. Cutting oil is visible on the tool or bit, > makes me think it is working. How do you know if the Boelube is working? > > Most people simply "drill" their drill bit into the BoeLube which puts a thin coating on their drill. It is not necessary to put globs of the stuff on your drill bit, a small coating works fine. BoeLube is awesome stuff and is used in every single aircraft factory I have ever visited. If you are not comfortable using the paste version, BoeLube also makes a liquid version which comes in a 4oz bottle. (Shameless Plug: you can find it on our website at - www.browntool.com ). Happy Drilling, Michael Brown Brown Aviation Tool Supply Co. Oklahoma City, OK www.browntool.com 1-800-587-3883 ________________________________________________________________________________
Date: Sep 27, 2004
>> How does one use Boelube? I have a little stick of the stuff and it >> seems hard and crumbly, somewhat like a cross between wax and soap. I >> rubbed a drill on it and it seemed like nothing happened. I then >> switched to cutting oil. Cutting oil is visible on the tool or bit, >> makes me think it is working. How do you know if the Boelube is >> working? > > Most people simply "drill" their drill bit into the BoeLube which puts > a thin > coating on their drill. It is not necessary to put globs of the stuff > on your > drill bit, a small coating works fine. BoeLube is awesome stuff and > is used > in every single aircraft factory I have ever visited. > > If you are not comfortable using the paste version, BoeLube also makes > a > liquid version which comes in a 4oz bottle. (Shameless Plug: you can > find it on > our website at - www.browntool.com ). I was shown to get the drill bit hot by drilling into a 2x4 at the very beginning of the work session. You then simply touch the bit to the BoeLube, which melts a little bit of it onto the bit. Cutting into .032 sheetmetal (especially with pre-punched holes doesn't keep the bit hot enough to melt the BoeLube for the next application, so you will need to redo the 2x4 drilling every time. If you're drilling new holes in sheetmetal or drilling into aluminum angle, it will likely keep enough heat for re-application. When doing it like this, you can see a liquid get sucked up onto the bit from the BoeLube tube. Waiting a few seconds and it will harden back into a waxy film on the tip of the bit. Steve ________________________________________________________________________________
Subject: Re: [RV-8] First Flight
Date: Sep 27, 2004
Joel, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A > ----- Original Message ----- > From: Joel Harding > To: RV-8(at)yahoogroups.com > Sent: Sunday, September 26, 2004 11:20 PM > Subject: [RV-8] First Flight > > > On Saturday afternoon at five o clock the parts box was empty, the > inspection was complete, and there were no reasons left not to fly, so > I did. After eight years of building, kit number 80004 finally became > airborne, and what a treat it was. > Joel Harding (ex builder) > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Sep 27, 2004
In a message dated 9/27/04 1:48:45 AM Eastern Daylight Time, BrownTool(at)aol.com writes: > Most people simply "drill" their drill bit into the BoeLube which puts a > thin > coating on their drill. It is not necessary to put globs of the stuff on > your > drill bit, a small coating works fine. BoeLube is awesome stuff and is used > > in every single aircraft factory I have ever visited. > > If you are not comfortable using the paste version, BoeLube also makes a > liquid version which comes in a 4oz bottle. OR.....stop by your neighborhood bearing supply house and pick up an aerosol can of Molykote 557 which works equaly well and much easier to apply. A little spray on the tool whenever you need it. Also, works great on micro countersink cutters and saw blades. Dale Ensing RV6A inspection soon ________________________________________________________________________________
Date: Sep 27, 2004
Subject: Re: EAA Chapter 898 FLY IN Sat Oct 2,2004 @ MJX
Toms River New Jersey ________________________________________________________________________________
Date: Sep 27, 2004
Toms River ,NJ ________________________________________________________________________________
Date: Sep 27, 2004
Toms River, New Jersey ________________________________________________________________________________
Date: Sep 27, 2004
Subject: Re: RV-List:Alternator cooling duct
Does anybody sell a small flange that can be flush mounted to the front baffle floor and connected to the black nylon flex tubing for cooling the alternator? Or, any suggestions on how to make one? Dale Ensing RV6A ________________________________________________________________________________
Date: Sep 27, 2004
http://www.aircraftspruce.com/catalog/appages/ductflanges.php Not exactly what you asked for, since they only sell 1" and larger, but you can use 1" SCAT or whatever. Or just make your own flange out of aluminum. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: <DWENSING(at)aol.com> Subject: Re: RV-List:Alternator cooling duct > > > Does anybody sell a small flange that can be flush mounted to the front > baffle floor and connected to the black nylon flex tubing for cooling the > alternator? > Or, any suggestions on how to make one? > Dale Ensing > RV6A > > ________________________________________________________________________________
Date: Sep 27, 2004
They sell 5/8" scat tubing but I have never found 5/8" flanges. I turned one myself on my lathe. I have seen some installations where the flex tubing is just screwed into the hole. Does not look good (IMHO) but seems to work. Gary DWENSING(at)aol.com wrote: > > >Does anybody sell a small flange that can be flush mounted to the front >baffle floor and connected to the black nylon flex tubing for cooling the >alternator? >Or, any suggestions on how to make one? >Dale Ensing >RV6A > > > > ________________________________________________________________________________
Date: Sep 27, 2004
Dale... Just rill a hole big enough to take and hole a piece of the black corrugated wire loom stuff, just like you would for your mag blast tubes... Then use a small clamp on the alternator bracket to direct and hold the tube... http://www.rv8a.com/engine/finish116.jpg -Bill VonDane RV-8A - Colorado Springs EAA Tech Counselor www.vondane.com www.rv8a.com www.creativair.com www.epanelbuilder.com ----- Original Message ----- From: <DWENSING(at)aol.com> Subject: Re: RV-List:Alternator cooling duct Does anybody sell a small flange that can be flush mounted to the front baffle floor and connected to the black nylon flex tubing for cooling the alternator? Or, any suggestions on how to make one? Dale Ensing RV6A ________________________________________________________________________________
Date: Sep 27, 2004
In a message dated 9/27/04 11:38:00 AM Eastern Daylight Time, bill(at)vondane.com writes: > Just rill a hole big enough to take and hole a piece of the black > corrugated > wire loom stuff, just like you would for your mag blast tubes... Hi Bill, Thanks. Was trying to avoid the air flow disturbance of the plastic loom sticking up thru the floor of the baffle. Guess I can start out with that and continue looking for a neat aluminum flange to add later. Dale ________________________________________________________________________________
Date: Sep 27, 2004
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Aircraft Spruce sells the flanges. The down side is they are for 1.0 OD tubing minimum. 5~6 bucks if I remember correctly. > >In a message dated 9/27/04 11:38:00 AM Eastern Daylight Time, >bill(at)vondane.com writes: > > > > Just rill a hole big enough to take and hole a piece of the black > > corrugated > > wire loom stuff, just like you would for your mag blast tubes... > >Hi Bill, >Thanks. Was trying to avoid the air flow disturbance of the plastic loom >sticking up thru the floor of the baffle. Guess I can start out with that and >continue looking for a neat aluminum flange to add later. >Dale > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Sep 27, 2004
I'm not sure you would get any determinable air flow disturbance... The air is pressurized in there anyway... -Bill ----- Original Message ----- From: <DWENSING(at)aol.com> Subject: Re: RV-List:Alternator cooling duct In a message dated 9/27/04 11:38:00 AM Eastern Daylight Time, bill(at)vondane.com writes: > Just rill a hole big enough to take and hole a piece of the black > corrugated > wire loom stuff, just like you would for your mag blast tubes... Hi Bill, Thanks. Was trying to avoid the air flow disturbance of the plastic loom sticking up thru the floor of the baffle. Guess I can start out with that and continue looking for a neat aluminum flange to add later. Dale ________________________________________________________________________________
Subject: Lift Reserve Indicator (LRI)
Date: Sep 27, 2004
I flew over the mountains to Grand Junction, CO, (GJT) this morning for a bi-annual transponder check. That went well. Upon take off to return I rotated by reference to my LRI (my usual practice) and then cross checked against my air speed indicator. Guess what? No air speed indication, no VSI, no altimeter either. Obviously something was left unconnected at the radio shop. I had to quickly decide if I wanted to land without those instruments at GJT or continue over the mountains via Monarch Pass, around 11,00 or so. I decided to use my AnywhereMap's indication of GPS altitude and ground speed and the LRI for stall safety margin and completed the hour-long flight. Entry into the pattern went well, lots of visual clues. On long final I sort of wished the update rate on GPS altitude was a bit faster, but the LRI kept me well above stall speed. Landing went very normal. Moral of the story? I don't know for certain, except it was damm nice to have the AnywhereMap GPS and the LRI as backup. (Trouble turned out to be a picnched hose...everything WAS connected.) FWIW John at Salida, CO ________________________________________________________________________________
Subject: Re: Elevator balancing/counter weights
Date: Sep 27, 2004
You know I hate getting older and having too much information in the aging brain. I went to my notes over the weekend and reviewed them.. I have found that I balanced the elevators a little NOISE heavy, not tail heavy. Sorry to one and all for my mis-information. Send your flames Mike Robertson >From: Oldsfolks(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Re: Elevator balancing/counter weights >Date: Fri, 24 Sep 2004 21:45:47 EDT > > >I had read that a positive balance(slightly nose heavy) was preferable on >elevators. You must also allow for (guestimate if unpainted) the >difference >after painting. I had my RV-4 counterweights nose down by 3" or so before >painting and they were about 1" down after paint. Testing to 235 MPH has >been done >with do vibration or flutter. > >Bob Olds RV-4 , N1191X >A&P , EAA Tech. Counselor >Charleston,Arkansas >Real Aviators Fly Taildraggers > > Get ready for school! Find articles, homework help and more in the Back to ________________________________________________________________________________
Subject: Elevator balancing/counterweights
Date: Sep 27, 2004
Like I said on an earlier post, I got my brain working as* backwards. I reviewed my notes and found that it is supposed to be slighlty nose heavy, not trailing edge heavy. Sorry, Mike >From: Kevin Horton <khorton01(at)rogers.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RE: RV-List: Elevator balancing/counterweights >Date: Fri, 24 Sep 2004 22:35:53 -0400 > > > > > >Michey, > > > >There used to be an AC with all kinds of generic information but that one >is > >long gone. Now almost all info is fond in manufacturer's maintenance >manuls > >(IE, Cessna, Piper). What you need to do is to suspend the control >surface > >from the hinges, then either add or remove weight from the counterweight > >until the trailing edge and counterweights are on the same horizontal >plane. > > More specifically for the RV's I have found that if the trailing edge >is > >slightly heavy the controls seem to respond better and there is less >chance > >of control flutter at high speeds. By being slightly heavy I mean the > >trailing edge 1-2 inches below the horizontal plane of the center of the > >counter weight leading edge. > > > >Just understand that Van's flutter analysis and flight testing is >only valid if the elevators are balanced the way he says. Making the >trailing edge heavier will increase the stick force per g, and reduce >the tendency for a pilot induced oscillation. But it will increase >the likelihood of aeroelastic flutter. >-- >Kevin Horton RV-8 (finishing kit) >Ottawa, Canada >http://go.phpwebhosting.com/~khorton/rv8/ > > ________________________________________________________________________________
Date: Sep 27, 2004
Dale, Just did this job a few days ago. I used a 10350-4 ALUM FLANGE 1" bought from Spruce to which I mated a short length of 1" sceet with a 032-9 Oetiker clamp. Rick Galati RV-6A N307R "finishing" Does anybody sell a small flange that can be flush mounted to the front baffle floor and connected to the black nylon flex tubing for cooling the alternator? Or, any suggestions on how to make one? Dale Ensing RV6A ________________________________________________________________________________
Date: Sep 27, 2004
Thanks, all, for the comments and suggestions. In addition to your advice, I had a chat with Ken at Van's and he said that if you just put on the weights as shipped, it won't make much difference one way or the other. He said the aircraft is not very sensitive to elevator balance. I'm building an 8, so I'm not sure if his comment is only valid for the 8, or for all their models. My elevators are currently slightly nose heavy, and I suspect that will balance out a bit once they get painted. I already have the electric trim installed. Thanks again, Mickey >Like I said on an earlier post, I got my brain working as* backwards. I >reviewed my notes and found that it is supposed to be slighlty nose heavy, >not trailing edge heavy. > > >> .... >> >>Just understand that Van's flutter analysis and flight testing is >>only valid if the elevators are balanced the way he says. Making the >>trailing edge heavier will increase the stick force per g, and reduce >>the tendency for a pilot induced oscillation. But it will increase >>the likelihood of aeroelastic flutter. -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Subject: Re: Lift Reserve Indicator (LRI)
Date: Sep 27, 2004
All, This is not directed at you John, obviously you had no problems, but this is a common problem among the pilots I see giving BFRs. Pilots get real jumped up when I cover the airspeed indicator. Loss of airspeed should not be a big deal! The LRI is a great tool and I have nothing against lots of back ups, (You should see my panel, lotsa backups) However, in day VMC conditions, anyone who has any concerns whatsoever about safely flying their airplane without an airspeed indicator doesn't need a back up, they need some practice. Cover it up and go practice! With an instructor of a safety pilot if need be, but go practice!!! IFR or at night is a little more interesting, I lost the pitot heat while IMC in a C210 once and lost airspeed, needless to say there was ice on the wings too. When it came time to shoot the ILS, I took my handheld GPS out of batterysaver mode (they update about 3 times more often) and I told my pax to read the GPS ground speed every few seconds. There was nothing to it, but an LRI would have been a nice addition that day. Even with out the GPS, it would have been manageable, but I would have been smokin' down the approach you can bet! On BFRs I cover the ASI and most decent pilots are within 5 mph of normal speeds once they quit freaking out. The purpose of training is to provide a conditioned response to a set of circumstances with a positive outcome. This provides certainty of a positive outcome and that is really important, because once you lose certainty in a successful outcome, the outcome becomes certain and that is certainly not good! FWIW, This theory applies to business, and marriage as well as aviation. Tailwinds, Doug Rozendaal ----- Original Message ----- From: "John" <n1cxo320(at)salidaco.com> Subject: RV-List: Lift Reserve Indicator (LRI) Snip > > Entry into the pattern went well, lots of visual clues. On long final I sort > of wished the update rate on GPS altitude was a bit faster, but the LRI kept > me well above stall speed. Landing went very normal. > > Moral of the story? I don't know for certain, except it was damm nice to > have the AnywhereMap GPS and the LRI as backup. (Trouble turned out to be a > picnched hose...everything WAS connected.) > > FWIW > > John at Salida, CO ________________________________________________________________________________
Subject: Catto props...3 vs 2 blade
Date: Sep 27, 2004
List: I am about to make a decision on a prop for my 150 hp -6A. I have read all I could in the archives regarding the use of a 3 blade Catto prop, and I also talked with as many RV pilots that I could who were using this prop while at OSH this past summer. I have not seen or heard any bad comments on the prop, and I am wondering if all who are using it still would recommend it. Also, what are the advantages/disadvantages of using a 3 blade vs a two blade? Is the 3 blade that much smoother and quieter than a 2 blade? I am not looking for maximum speed or climb in my prop. I am a flat-lander (Wisconsin) and am just looking for a good all-around prop. Smooth and quiet are up there on the list for me. Sure would like to hear from those in the know. Regards, Jeff Orear RV6A N782P (reserved) About to close up the top forward skin Peshtigo, WI ________________________________________________________________________________
Subject: Prop noise
Date: Sep 27, 2004
With all the messages on props, I just read an interesting article from the Calif. Pilots Assoc. newsletter relating to prop noise. It states that as prop tip speeds approaches transonic range (625mph (736mph mach 1)) the noise level takes a tremendous jump. For our 72" props this equates to 2900rpm for the onset of transonic prop speeds. So I think any RV prop is going to be relatively quiet. For comparison, my Cessna has a prop speed of 610mph at 2500rpm cruise, where an RV would have a prop speed of 535mph at that rpm. Doug (RV-7a in progress) ________________________________________________________________________________
Subject: CHT's at altitude
Date: Sep 27, 2004
I have an RV-6 0-360 (9:1 pistons) with the airflow performance FI system. I have one mag and the bottom plugs are running on a Jeff Rose electronic ignition. I normally cruise in the 4,500-6,500 foot range. During the summer months when the OAT is in the 75-85 degree range my CHT's run about 390-410 at cruise at peak EGT. 60 degrees rich of peak I may see a 10 degree CHT drop. Lean of peak operation gets CHT's down to 370-385. I think these numbers are pretty normal. My question is, when I try to cruise at 9,500 or above my CHT's are 450 at peak and 430 at 60 degrees rich. Lean of peak operation still has CHT's over 400. My theory is that since the air is thinner at 9,500 and above it has less cooling effect. I would think the decrease in OAT would make up for the thinner air but it does not. I would really like to take advantage of better tailwinds at altitude plus I have an O2 system I have never used. I recently spent a bunch of money fixing a warped exhaust valve, and everything I have read says the best way to not have valve problems is to keep CHT's low. Engine has 900 hours since new and 375 since a top overhaul. Baffles have been replaced, I opened the bottom of the cowl some and I feel like the cowl is sealed very well. I have also inspected my cooling fins, they appear fine with no flashing. Oil temps run 180 in cruise. Any input on this issue would be great. Jason Sneed ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: Catto props...3 vs 2 blade
Jeff; I have a 150 hp RV-6A and use the Sensenich 70CM prop sold through Van's (the max 2600 rpm one). I do not have a lot of other RV-6 experience to compare it to but am pleased with the noise, vibration and general smoothness level - IOW, I consider them at the low end of other light aircraft I have flown/flown in. I do run a (wood) Pacesetter 200 on my RV-3 and it is a lot rougher. Apart from the 2 vs 3 blade issue, I feel the mass and stiffness of the prop are what makes for a lot smoother operation. Performance is good too, BTW. I am quite satisfied with my 0-320, Sensenich fixed pitch set-up. Jim Oke RV-6A Wpg, MB ----- Original Message ----- From: "Jeff Orear" <jorear(at)new.rr.com> Subject: RV-List: Catto props...3 vs 2 blade > > List: > > I am about to make a decision on a prop for my 150 hp -6A. I have read > all I could in the archives regarding the use of a 3 blade Catto prop, and > I also talked with as many RV pilots that I could who were using this prop > while at OSH this past summer. > > I have not seen or heard any bad comments on the prop, and I am wondering > if all who are using it still would recommend it. > > Also, what are the advantages/disadvantages of using a 3 blade vs a two > blade? Is the 3 blade that much smoother and quieter than a 2 blade? > > I am not looking for maximum speed or climb in my prop. I am a > flat-lander (Wisconsin) and am just looking for a good all-around prop. > Smooth and quiet are up there on the list for me. > > Sure would like to hear from those in the know. > > > Regards, > > Jeff Orear > RV6A N782P (reserved) > About to close up the top forward skin > Peshtigo, WI > > > ________________________________________________________________________________
Date: Sep 27, 2004
Subject: Re: CHT's at altitude
Jason, While the temps are (barely) within what Lycoming allows, I think they are about 50 degrees higher than mine are. I have an IO-360-C1E6 with -A!A sump. This is an angle valve head so it may not be an apples and apples comparison. My suggestion would be to retard the timing to 25 degrees to see if the advanced timing of the electronic ignition is raising the CHTs. This doesn't make perfect sense to me, but something is making your CHTs higher than normal. Dan Hopper RV-7A N766DH (Flying -- 55 hours since July 7, 2004) In a message dated 9/27/04 9:38:27 PM US Eastern Standard Time, n242ds(at)cox.net writes: > > > I have an RV-6 0-360 (9:1 pistons) with the airflow performance FI > system. I have one mag and the bottom plugs are running on a Jeff Rose > electronic ignition. I normally cruise in the 4,500-6,500 foot range. > During the summer months when the OAT is in the 75-85 degree range my > CHT's run about 390-410 at cruise at peak EGT. 60 degrees rich of peak > I may see a 10 degree CHT drop. Lean of peak operation gets CHT's down > to 370-385. I think these numbers are pretty normal. > > My question is, when I try to cruise at 9,500 or above my CHT's are 450 > at peak and 430 at 60 degrees rich. Lean of peak operation still has > CHT's over 400. My theory is that since the air is thinner at 9,500 and > above it has less cooling effect. I would think the decrease in OAT > would make up for the thinner air but it does not. I would really like > to take advantage of better tailwinds at altitude plus I have an O2 > system I have never used. > > I recently spent a bunch of money fixing a warped exhaust valve, and > everything I have read says the best way to not have valve problems is > to keep CHT's low. > > Engine has 900 hours since new and 375 since a top overhaul. Baffles > have been replaced, I opened the bottom of the cowl some and I feel > like the cowl is sealed very well. I have also inspected my cooling > fins, they appear fine with no flashing. Oil temps run 180 in cruise. > Any input on this issue would be great. > > > Jason Sneed > > ________________________________________________________________________________
Date: Sep 27, 2004
Subject: new address
Please change my address to avheath(at)sbcglobal.net Please let me know that you received this note. Bob ________________________________________________________________________________
Date: Sep 27, 2004
Subject: Re: engine oil leak
In a message dated 9/21/04 7:53:31 PM US Eastern Standard Time, Rquinn1(at)aol.com writes: > > Andy, We also had an oil leak that, even with the help of the experts, we > could not locate. Then one of the best A&Ps came over and looked and said > that > I should cut my oil vent hose on such an angle that would give the case a > slight vacuum. I did and the leak was cured. > Rollie &Rod > RV6A with about 86 hours (and a clean cowl) > Along these lines -- when the rings seat (if the engine is new or freshly overhauled) the blowby will lessen, which will lower the crankcase pressure, and the leak may cure itself. I have one of these kind of leaks too. It seems to come from the left front of the engine in the area of the prop governor. There is a lot of stuff in the way which keeps me from seeing that area of the case. Anyway, I still intend to take Stein's excellent advice to try to find it, but it doesn't seem to be as bad as it was early on. Dan Hopper RV-7A N766DH (Flying -- 55 hours since 7/7/04) ________________________________________________________________________________
Date: Sep 27, 2004
Subject: Nose Wheel Fork Bolt Holes
I just assembled my nose wheel, no problems. I slid the wheel with the big spacers into the nose fork and slid the bolt in with the wheel centered, one side aligned with the bolt hole the hole on the other side is at least a half hole off. If I try to force the bolt in the wheel cocks to one side and the spacers are not flat on each side on the fork, they are cocked also. Is this normal and I need to do something to make it work. It appears to me that the holes are not aligned properly and the part needs to be replaced. -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Slowbuild wings-QB Fuse :-) ________________________________________________________________________________
Date: Sep 28, 2004
In a message dated 9/27/2004 8:31:38 AM Pacific Daylight Time, zilik(at)direcpc.com writes: They sell 5/8" scat tubing but I have never found 5/8" flanges. I turned one myself on my lathe. =================================== Aha! A market looking for a product. Who will be the new entrepreneur that picks up this baton and runs with it? GV (RV-6A N1GV O-360-A1A C/S, flying 719 hrs) ________________________________________________________________________________
Subject: prop bolt torque
Date: Sep 28, 2004
I have a wooden prop and was checking the torque. I set my torque wrench to the desired setting of 25 ft lb and check the bolts. They all were =>25 ft lbs as none of them moved when checked. My question is do you back off the bolts and then retorque or is the method I used sufficient? Scott Frierson N162RV RV6A Flying 26hrs ________________________________________________________________________________
Date: Sep 28, 2004
I have the same set up as you do and usually run 360 CHT at those altitudes mentioned. Where are your temp probes in the head or under the spark plugs. Its also a good idea to stay away from peak EGT over about 60% power. I am at peak EGT for only 5~10 seconds not long enough for the heads to get as warm as you mentioned. What power settings are you running at? Have you backed the timing off 5 degrees due to the higher compression? Timing makes a big difference on CHTS. As far as cooling goes at altitude yes you have less air, but you are also going faster because there is less resistance which should make up for less air. Coming back from the Reno air races I went up to 15.5 to use a tail wind and the head temps were about 360F at 55% power and 50 degrees LOP. > >I have an RV-6 0-360 (9:1 pistons) with the airflow performance FI >system. I have one mag and the bottom plugs are running on a Jeff Rose >electronic ignition. I normally cruise in the 4,500-6,500 foot range. >During the summer months when the OAT is in the 75-85 degree range my >CHT's run about 390-410 at cruise at peak EGT. 60 degrees rich of peak >I may see a 10 degree CHT drop. Lean of peak operation gets CHT's down >to 370-385. I think these numbers are pretty normal. > >My question is, when I try to cruise at 9,500 or above my CHT's are 450 >at peak and 430 at 60 degrees rich. Lean of peak operation still has >CHT's over 400. My theory is that since the air is thinner at 9,500 and >above it has less cooling effect. I would think the decrease in OAT >would make up for the thinner air but it does not. I would really like >to take advantage of better tailwinds at altitude plus I have an O2 >system I have never used. > >I recently spent a bunch of money fixing a warped exhaust valve, and >everything I have read says the best way to not have valve problems is >to keep CHT's low. > >Engine has 900 hours since new and 375 since a top overhaul. Baffles >have been replaced, I opened the bottom of the cowl some and I feel >like the cowl is sealed very well. I have also inspected my cooling >fins, they appear fine with no flashing. Oil temps run 180 in cruise. >Any input on this issue would be great. > > >Jason Sneed > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Subject: Re: prop bolt torque
Date: Sep 28, 2004
Scott: If you trust your torque wrench is calibrated correctly - "all were =>25 ft " Back each off each bolt - retorqueing to proper torque - in an alternating pattern - until you have checked 2 times - until all are @ 25 ft lbs. Remember wood props require retorqueing after your 1 operation and at increasing intervals of operation until you notice little or no loosing - Then you will still need to check @ least every condition inspection. Some experienced wood prop operators may give you a better condition check time frame that works for them - Don Eaves RV6 Flying 235+ ----- Original Message ----- From: "james frierson" <tn3639(at)hotmail.com> Subject: RV-List: prop bolt torque > > I have a wooden prop and was checking the torque. I set my torque wrench > to > the desired setting of 25 ft lb and check the bolts. They all were =>25 ft > lbs as none of them moved when checked. My question is do you back off the > bolts and then retorque or is the method I used sufficient? > > Scott Frierson > N162RV > RV6A Flying 26hrs > > > > ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: Nose Wheel Fork Bolt Holes
In a message dated 9/27/04 10:54:46 PM US Eastern Standard Time, bhester(at)hopkinsville.net writes: > > I just assembled my nose wheel, no problems. I slid the wheel with the > big spacers into the nose fork and slid the bolt in with the wheel > centered, one side aligned with the bolt hole the hole on the other side > is at least a half hole off. If I try to force the bolt in the wheel > cocks to one side and the spacers are not flat on each side on the fork, > they are cocked also. Is this normal and I need to do something to make > it work. It appears to me that the holes are not aligned properly and > the part needs to be replaced. > > -- > Surfing the Web from Hopkinsville, KY > Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ > RV7A Slowbuild wings-QB Fuse :-) > > This one should go back to Vans. Mine fit very well. Dan Hopper RV-7A N766DH (Flying since 7/7/04 -- 55 hours now) ________________________________________________________________________________
Subject: Rudder - RV6 & Original RV7 Compatability
Date: Sep 28, 2004
1st let me thank all who have offered the Original Rudder off there RV7 - Or may want to - It is not compatible with the RV6 - From a call to Vans and Van's Service Bulletin 02-6-1: The original RV7 rudder will not work on a RV6 without changing to the RV7 Vertical stabilizer - Both are larger than the 6 - The current RV7 Rudder is a RV9 Rudder with the RV7 Sttabilizer Good news I can still get the parts I need to build a new RV6 rudder if I cannot find one out there on the list - Thanks Don Eaves RV6 Flying 235+ Hours ________________________________________________________________________________
From: "Aircraft Technical Book Company" <winterland(at)rkymtnhi.com>
Subject: oil leak discovered
Date: Sep 28, 2004
I have discovered the source of most of my oil leaks. It was a 5 minute fix that will now be a routine part of my annual. My crankcase breather port ties into a flexible hose which then clamps onto a 10" stainless tube which is welded directly into the left side exhaust pipe. This setup injects blowby into the hot exhaust causing most of it to burn or atomize and much less of it to coat the belly of my clean airplane. What has happened over the years is that sludge has built up and solidified at the juncture of the breather tube and exhaust causing a blockage, thus pressurizing the case, and pushing oil out of almost every possible seam. Opening up the blockage immediately cured about 3/4 of the leaks. Replacing the quick drain O-rings and retorquing the valve covers got rid of much of the rest. So much for fretting cases and $10,000 overhauls. ; ) Andy ----- Original Message ----- From: <Hopperdhh(at)aol.com> Subject: Re: RV-List: engine oil leak > > In a message dated 9/21/04 7:53:31 PM US Eastern Standard Time, > Rquinn1(at)aol.com writes: > > > > > Andy, We also had an oil leak that, even with the help of the experts, we > > could not locate. Then one of the best A&Ps came over and looked and said > > that > > I should cut my oil vent hose on such an angle that would give the case a > > slight vacuum. I did and the leak was cured. > > Rollie &Rod > > RV6A with about 86 hours (and a clean cowl) > > > > Along these lines -- when the rings seat (if the engine is new or freshly > overhauled) the blowby will lessen, which will lower the crankcase pressure, and > the leak may cure itself. > > I have one of these kind of leaks too. It seems to come from the left front > of the engine in the area of the prop governor. There is a lot of stuff in > the way which keeps me from seeing that area of the case. Anyway, I still > intend to take Stein's excellent advice to try to find it, but it doesn't seem to > be as bad as it was early on. > > Dan Hopper > RV-7A > N766DH (Flying -- 55 hours since 7/7/04) > > ________________________________________________________________________________
Date: Sep 28, 2004
Jason, that is way too hot. I advise that you get a digital voltmeter and connect it to the advance output on the ignition, then go fly with it to see how many degrees of advance there is at altitude. IIRC 10mV/degree advance. So .01V would be 1 degree advance, .25V would be 25 degrees advance, etc. It could be the MAP sensor is faulty and your timing is advancing too far BTDC with altitude. That could easily cause high temperatures. Regards, Bob Japundza RV-6 flying F1 qb under const. > >My question is, when I try to cruise at 9,500 or above my CHT's are 450 > >at peak and 430 at 60 degrees rich. Lean of peak operation still has > >CHT's over 400. My theory is that since the air is thinner at 9,500 and > >above it has less cooling effect. I would think the decrease in OAT > >would make up for the thinner air but it does not. I would really like > >to take advantage of better tailwinds at altitude plus I have an O2 > >system I have never used. ________________________________________________________________________________
Date: Sep 28, 2004
CLR 1.1.4322) Thanks for the reply, after reading it, I called Vans and they said that does happen sometimes. I have to send it back with a note that the holes are misalined and they'll send me a new one. > -----Original Message----- > From: Fiveonepw(at)aol.com > To: bhester(at)hopkinsville.net > Date: Tue, 28 Sep 2004 09:41 (CDT) > Subject: RV-List: Nose Wheel Fork Bolt Holes > > > > Hi Bobby- I met you at the Lebanon fly-in. I'd sure take this up with Vans, > particularly if the bottom of the two side plates are parallel- either the > holes are mis-drilled, the side plates are not welded in the correct postion > or > the thing somehow got bent! Mine was perfectly straight. > > Mark Phillips, Columbia TN, -6A N51PW > > ------- Surfing the web from Hopkinsville, KY RV7A web site: http://www.geocities.com/hester-hoptown/RVSite PEhUTUw+PEZPTlQgRkFDRT1hcmlhbCxoZWx2ZXRpY2E+PEhUTUw+PEZPTlQg IFNJWkU9MiBQVFNJWkU9MTAgRkFNSUxZPSJTQU5TU0VSSUYiIEZBQ0U9IkFy aWFsIiBMQU5HPSIwIj5IaSBCb2JieS0gSSBtZXQgeW91IGF0IHRoZSBMZWJh bm9uIGZseS1pbi4mbmJzcDsgSSdkIHN1cmUgdGFrZSB0aGlzIHVwIHdpdGgg VmFucywgcGFydGljdWxhcmx5IGlmIHRoZSBib3R0b20gb2YgdGhlIHR3byBz aWRlIHBsYXRlcyBhcmUgcGFyYWxsZWwtIGVpdGhlciB0aGUgaG9sZXMgYXJl IG1pcy1kcmlsbGVkLCB0aGUgc2lkZSBwbGF0ZXMgYXJlIG5vdCB3ZWxkZWQg aW4gdGhlIGNvcnJlY3QgcG9zdGlvbiBvciB0aGUgdGhpbmcgc29tZWhvdyBn b3QgYmVudCEmbmJzcDsgTWluZSB3YXMgcGVyZmVjdGx5IHN0cmFpZ2h0LjxC Uj4NCjxCUj4NCk1hcmsgUGhpbGxpcHMsIENvbHVtYmlhIFROLCAtNkEgTjUx UFc8L0ZPTlQ+PC9IVE1MPg0K ________________________________________________________________________________
Subject: reply to various stuff
Date: Sep 28, 2004
Use the black wire conduit hose, pop through a tight hole, then take a hot iron and flatten the part sticking up into a flange. Practice this before attempting on your baffle. Lost ASI. One good reason for manual pitch trim is the marks I have on the trim cable control shaft. I can set this to a specific spot and the plane will fly within one or two knots of a known airspeed for any given mark. This operates independantly of all other systems, and in fact I can do it by feel with my eyes closed. To become confident in this one must really go out and practice flying slow speed with trim only, using throttle only for vertical speed management, and keeping your hand off the stick except for turbulence corrections. RE high CHTs, suggest testing temps on one mag to establish one mag baseline, then set mag to 20-23Deg BTDC and test again on the one mag, then, if temps are lower, turn on the other system and see if temps climb. This will verify that timing is the cause (or at least a solution), based upon your engine's/airframe's capacity to cool. If this proves true I believe you can back the suggested timing values for the Rose system back a few degrees just like you would a mag and it won't know the difference. Also, expect EGTs to climb slightly, and I would be suprised if you are able to tell the difference in max power output. W ________________________________________________________________________________
Subject: re: Flap useage for short field takeoff
Date: Sep 28, 2004
Frank, The reason it isn't mentioned much is because even with poor technique, an RV like yours can get off the ground in less than 700 ft easily. I am not an exceptional pilot, but I am proficient. I fly my RV on final at 70 mph. I think thats pretty good. But it still takes me much farther to land than to take off. 1/2 fuel, alone, with 1/2 flaps, I am off in a shade over 300 ft. My plane has a climb prop, that helps, but even still you will have a lot more margin on takeoff than on landing. as an aside, I flew into a 1600 ft grass strip (wheel pants removed) this weekend. It was a total non-event. Don Mei RV-4 O-320 ________________________________________________________________________________
Subject: re: Lift Reserve Indicator (LRI)
Date: Sep 28, 2004
John, It is good to hear that everything worked out, but let me play devil's advocate. I'd suggest that you should aim for a level of proficiency where NONE of those items are necessary for a safe comfortable flying experience. (in good VFR conditions). Every few months or so, I will practice flying with no ASI, VSI, Altimeter. I practice stalls before attempting to refresh my memory as to the pitch attitude, wind noise, etc. In the end its always a non event. Our gadgets and toys are nice and can contribute greatly to safety, but they are not a substitute for proficiency in pure seat of the pants flying. Again, this is not a criticism in any way. You had those other tools at your disposal, so you used them. It just reminded me that we should stay current, and proficient using even fewer tools than you had at your disposal. Don Mei p.s. If it hasn't already been said already, don't use the GPS Groundspeed indicator in the pattern. If there is any wind, it can get you in trouble. You're better off going by sound and pitch. ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: >Re: oil leak discovered
My crankcase vent line goes to about 1/8" from the exhaust pipe and points at the pipe. This burns the oil spray without the welded-in tube ( and NO plug in the tube ) Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: >Re: prop bolt torque
I found that it takes about 5 ft/lbs to turn my 7/16" bolts in the prop hub (bolts not into the flange). I then add this 5 ft/lbs to the 25 and torque to 30. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Sep 28, 2004
I would recommend a whistle hole in your vent line, regardless of type of termination. This gives you insurance against blockage, and will also tell you end is blocked, by slobbering for you. Denis On Sep 28, 2004, at 2:10 PM, Oldsfolks(at)aol.com wrote: > > My crankcase vent line goes to about 1/8" from the exhaust pipe and > points at > the pipe. This burns the oil spray without the welded-in tube ( and > NO plug > in the tube ) > > > Bob Olds RV-4 , N1191X > A&P , EAA Tech. Counselor > Charleston,Arkansas > Real Aviators Fly Taildraggers > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Sep 28, 2004
Jeff, Have you received any comments about the cato props? Im almost to the stage I need to order the prop.A friend of mine has one but hasnt installed it. Sure is pretty thou. Mark Phillips Williamsville,ILlinois RV-6 Finishing ----- Original Message ----- From: "Jeff Orear" <jorear(at)new.rr.com> Subject: RV-List: Catto props...3 vs 2 blade > > List: > > I am about to make a decision on a prop for my 150 hp -6A. I have read > all I could in the archives regarding the use of a 3 blade Catto prop, and > I also talked with as many RV pilots that I could who were using this prop > while at OSH this past summer. > > I have not seen or heard any bad comments on the prop, and I am wondering > if all who are using it still would recommend it. > > Also, what are the advantages/disadvantages of using a 3 blade vs a two > blade? Is the 3 blade that much smoother and quieter than a 2 blade? > > I am not looking for maximum speed or climb in my prop. I am a > flat-lander (Wisconsin) and am just looking for a good all-around prop. > Smooth and quiet are up there on the list for me. > > Sure would like to hear from those in the know. > > > Regards, > > Jeff Orear > RV6A N782P (reserved) > About to close up the top forward skin > Peshtigo, WI > > > ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: reply to various stuff
>Lost ASI. One good reason for manual pitch trim is the marks I have on the >trim cable control shaft. I can set this to a specific spot and the plane >will fly within one or two knots of a known airspeed for any given mark. >This operates independantly of all other systems, and in fact I can do it by >feel with my eyes closed. To become confident in this one must really go out >and practice flying slow speed with trim only, using throttle only for >vertical speed management, and keeping your hand off the stick except for >turbulence corrections. Try this with a bunch of weight in the baggage compartment some day and you'll see a big change in the airspeed vs trim setting relationship. You can't guarantee how much weight you'll have in the baggage compartment if the ASI ever fails, so it is worth doing the practice with various loadings so you will be ready for whatever happens. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
"RV Matronics List"
Subject: Windshield Frame
Date: Sep 28, 2004
on mail5 I visited a local builder who had fabricated an aluminum panel at the base of the windshield and along the canopy frame on both an RV-6A and -7A. It looked very nice and neat and he said he did it because he didn't like fiberglass (I understand that!). It was screwed in place to both the cowl and the screen and sealed with silicone. Has anybody else done this? I'm considering doing this because of the neat appearance and also I think replacing a cracked screen would be infinitely easier. Any thoughts out there in RV Land? Doug Fischer 90706 Wings Jenison, MI ________________________________________________________________________________
Date: Sep 28, 2004
I check the torque about once a month. Sooner if the plane spent any length of time in a very low humidity environment. I don't loosen the nuts to check the torque. If they don't move when the wrench indicates 20lbs. then I leave them alone. It is rare that they move unless I have had the prop off recently. This is on a -4 with an O-320 and a Sterba prop with over 1000 hrs. in S. Cen. TX. Works for me in my circumstances. Also I might add that my "wrench" is a cheap fish weighing scale that I attach to the box end of a long combination wrench. The open end is placed on the nuts. That way I don't have to take the top cowl off. The torque is read in "fish pounds". I calibrate it with a 20lb. weight. Ivan Haecker ----- Original Message ----- From: "james frierson" <tn3639(at)hotmail.com> Subject: RV-List: prop bolt torque > > I have a wooden prop and was checking the torque. I set my torque wrench to > the desired setting of 25 ft lb and check the bolts. They all were =>25 ft > lbs as none of them moved when checked. My question is do you back off the > bolts and then retorque or is the method I used sufficient? > > Scott Frierson > N162RV > RV6A Flying 26hrs > > > ________________________________________________________________________________
Subject: RV Jacks at Harbor Freight
Date: Sep 28, 2004
Harbor Freight has a 24" hydraulic jack that extends to 44". It is currently on sale for $40.00 regularly $60.00. The ad actually says "Not for Aircraft use" so it must be perfect for jacking up RV's. It has a 5/8" inch hole in the piston and a fitting on the base. I removed the base fitting which gave the jack a flat base and drilled four holes in the corners and bolted on a larger steel plate to make it more stable. The top of the piston can be fitted with all sorts of adapters of your own design. I have an RV8 so used a 5/8" bolt and a couple pieces of angle iron to make a platform. It works perfect at the top of the gear leg between the attach bolts. You could also make a fitting to jack at the tie down point. I don't personally like jacking there but a lot of guys do it. Anyway if you need a jack check it out. Rich Crosley RV8, painting Palmdale, CA ________________________________________________________________________________
Subject: Best way to sell an RV these days
Date: Sep 29, 2004
Hello all, After much soul-searching and hand-wringing, I've decided to sell my RV-6A. Since I have been off the RV list and pretty much out of touch since the construction phase was over, I need to return for advice from my fellow builders. How can I best get up to speed with resale prices on RVs? In looking at a few online ads in Trade-A-Plane, it appears they are selling for more than they were just a few years ago. Is an ad in Trade-A-Plane still considered the best "bang for the buck" in reaching the wide number of potential buyers or is selling through the Internet, like Barnstormers.com, a better way now? I'm located in Mid-Michigan, but of course since the airplane is finished it could easily be flown cross-country by any buyer. Any up-to-date advice or insight would be appreciated. Cheers, Paul Paul Lein 1555 South Brinton Road Mt. Pleasant, MI 48858-9628 Tel. 989 644-2451 Fax 989 644-6098 pj115(at)journey.com ________________________________________________________________________________
Date: Sep 29, 2004
Subject: 2 VS 3 BLADES CATTO
Hello All For all interested, here's my 2 cents on the issue. I went from a Warnke wood prop ( Good prop by the way) to a 3 Bladded Catto Prop and I did not regret it ever. The smoothest and extra ground clearance ( 64 X 70 ) were plus in the decision to go this way. Not to mention the great look and good comments on how beautiful it looks whenever I go to a Fly-In. It's built very solid. I flew thru moderate rain at 120 Knots indicated and did not even shipped the paint off the tips. I wouldn't try that with a wood prop. Craig Catto was also very nice to do business with. E-mail me direct if you would like pictures of my RV-4's installation. Cheers Bruno Dionne rv4(at)videotron.ca C-GDBH RV-4 ________________________________________________________________________________
Subject: Break Plumbing
Date: Sep 29, 2004
Can anyone point me to a diagram which will show how to connect side by side (RV6-A) dual breaks using the Aircraft Spruce A600 reservoirs. Thanks. dick(at)rclabs.com ________________________________________________________________________________
Subject: Wood Prop torque timing and methods and other secretes
Date: Sep 29, 2004
If you have a metal prop, you can ignore this post. >I have a wooden prop and was checking the torque. I set my torque wrench to >the desired setting of 25 ft lb and check the bolts. They all were =>25 ft >lbs as none of them moved when checked. My question is do you back off the >bolts and then retorque or is the method I used sufficient? How often do you change your oil? The cowl is off, the bolts are exposed; good time to check the torque. SO: about every 25 hours or so. If you don't fly more than 50 hours a year or more, check them every three months. Or if it has sat around all winter or other down time, check it before you take your next flight. Wood props absorb and lose moisture; they swell and contract. Metal props, of course, don't do that. SO: if you are checking the torque by just nudging up to the 25 foot-pounds, you know the torque is at least that. But what if the prop has swollen and the bolts are now at 35 foot-pounds? Back them off, come up to the proper torque. That way you know all of the bolts are at 25 pounds, not 23, 37 ,31, 28 etc. Other care and feeding: keep your prop clean. Bugs all over the prop looks bad and MAY be eating into the finish of the props. Who knows (besides spiders, that is) what is in bugs. What to clan it with after each flight: water. Avoid harsh cleaners. Once every few weeks, clean it really well with something like Dawn dish soap, rinse it well, dry it and rub a coat of carnauba wax on it. Helps protect the finish and makes the bugs WAY easier to remove. You may notice the trailing edge is actually looking worse than the leading edge if it has been exposed to moisture (rain at OSH) at all. The finish may be a little thin back there and the tell-tail sign is a little lightening of the color of the wood, like you would expect if the wood was getting wet. Because it maybe has. Clean off the above mentioned wax and put three or four coats of exterior spar varnish lightly on the trailing edge with a Q-tip, letting each coat dry before the next. If the trailing edge is DOWN, it won't run all over the rest of your prop. You shouldn't be putting it on that thick anyway; just on the trailing edge and just enough to reseal it. A bare hand run along the leading edge-trailing edge, front-back of both blades of your wood prop and a visual look should be, of course, a part of every preflight. If the finish is getting to feel rough, intervene before the structure is affected. You may need to send it in to be refinished. Or, if it is too late, shop for a new prop. I LOVE my Bernie Warnke Almost Constant Speed prop that is now almost 7 years and over 800 hours old and still looks brand new. Just like anything else: take care of it, it will take care of you. And that is a good thing. IMHO, of course. YMMV............. Michael RV-4 N232 Suzie Q ________________________________________________________________________________
Date: Sep 29, 2004
> >After much soul-searching and hand-wringing, I've decided to sell my >RV-6A. Since I have been off the RV list and pretty much out of touch >since the construction phase was over, I need to return for advice from >my fellow builders. > >How can I best get up to speed with resale prices on RVs? In looking at >a few online ads in Trade-A-Plane, it appears they are selling for more >than they were just a few years ago. Is an ad in Trade-A-Plane still >considered the best "bang for the buck" in reaching the wide number of >potential buyers or is selling through the Internet, like >Barnstormers.com, a better way now? > >I'm located in Mid-Michigan, but of course since the airplane is >finished it could easily be flown cross-country by any buyer. Any >up-to-date advice or insight would be appreciated. >Cheers, Paul > >Paul Lein Paul, List it on Doug Reeve's site....vansairforce.net. Huge amount of exposure to the RV community there. I'm selling my RV8 to a local buyer (if he can fit in the plane at 6'4"), but if that falls through, I will likely go this route. Also try posting pics/specs on local FBO bulletin boards. Barnstormers.com is another popular venue. Brian Denk RV8 N94BD RV10 '51 ________________________________________________________________________________
Subject: Which GPS should I buy
Date: Sep 29, 2004
Hi listers, I don't want to start an argument, but I need some advice on which GPS to buy. I've had the plane flying since last November and I want to buy a GPS real soon! I designed my panel thinking I would put in a HP iPAQ running Anywhere Map. Since then, I've watched some nice GPS come out like the Garmin 296 (won't fit), the Lawrence 2000C (I was really interested in this but it won't fit either), and the Garmin 96C. The 96C will fit but it has a pretty small screen. All things considered, I think I'm going with Anywhere Map. This brings up the question of which PDA. Control Vision recommends two different iPAQs, but I'm intrigued by the Dell Axim X30. The screen is a bit smaller (3.5" vs 3.8" diagonal), but the speed is quite a bit higher. Control Vision sells a package for the Axim which includes a Compact Flash mount GPS, some cables, and the Anywhere Map software. However, the X30 doesn't have a CF slot and I really don't like the idea of a flash card mount GPS anyway given I want to mount the PDA under my Dynon. Does anyone know what my options are for a GPS with the X30? Is anyone using an Axim with Anywhere Map? If so, how do you like it? Thanks in advance, Doug Medema RV-6A N276DM Hi listers, I don't want to start an argument, but I need some advice on which GPS to buy. I've had the plane flying since last November and I want to buy a GPS real soon! I designed my panel thinking I would put in a HP iPAQ running Anywhere Map. Since then, I've watched some nice GPS come out like the Garmin 296 (won't fit), the Lawrence 2000C (I was really interested in this but it won't fit either), and the Garmin 96C. The 96C will fit but it has a pretty small screen. All things considered, I think I'm going with Anywhere Map. This brings up the question of which PDA. Control Vision recommends two different iPAQs, but I'm intrigued by the Dell Axim X30. The screen is a bit smaller (3.5" vs 3.8" diagonal), but the speed is quite a bit higher. Control Vision sells a package for the Axim which includesa Compact Flash mount GPS, some cables, and the Anywhere Map software. However, the X30 doesn't have a CF slot andI really don't like the idea of a flash card mount GPS anyway given I want to mount the PDA under my Dynon. Does anyone know what my options are for a GPS with the X30? Is anyone using an Axim with Anywhere Map? If so, how do you like it? Thanks in advance, Doug Medema RV-6A N276DM ________________________________________________________________________________
Subject: On board WX was, Which GPS should I buy
Date: Sep 29, 2004
Doug, On board WX may be a factor to consider in your purchase. I did a demo on WX worx weather for an article for IFR magazine. This is a big deal! It is real, it works, and in a few years it will be nearly as common as GPS and everybit as useful. I went to OSH to buy a system to display WX weather. I came home confused. After that, I tried an Ipaq that belonged to a friend, with anywhere map and WX Worx weather. I thought it would be great in the RV, but I was very disappointed. the screen was hard to read, I don't think a mounted Ipaq would work, because I had to tilt it to deal with glare. The anywheremap software may work ok, but when you put the wx on the map, it overloads the processor. I tried a fujitsu p-600 with an ADR screen upgrade, and it is really cool, but it is a $4000 600mhz out of date tablet pc. Being true to my Dutch heritage, I just bought a fujitsu p600f on ebay for $600 to display WX worx. I made a little box with the reciever, USB hub to split the GPS/wx data, the power supply for the tablet pc. The 600F has a transflective display. if you move it around, it is always readable, the processor is slow but acceptable, the WXworx software works really well, but it seems to be a processor hog. The recommend a 1gig machine and the fujitsu is 600mhz. The WX worx software with a GPS doesn't replace a handheld GPS, it just tells you speed and heading and that is all. Other companies have and are creating software to run on the PC platform, and I may upgrade, but I will still have a battery powered handheld GPS onboard anytime I am IFR. ( I just bought a lowrance airmap 500 and I love it!) I have flown with the 196 and 296 and they are both great units, I like the small size of the 500 and the fact that it runs over 10hrs on 2 AA bats. I have flown 3 trips with the fujistu, and I am really happy with it. It is like having the ADDS weather site in your cockpit. One thing about it, an autopilot would be almost mandatory, because it captivates alot of attention, but it is GREAT information! Tailwinds Doug Rozendaal ________________________________________________________________________________
Date: Sep 29, 2004
Doug, If you decide to go with a hand-held GPS, don't forget to have a look at the new $700 Garmin 96C. The current issue of Aviation Consumer reviews it and the similar monochrome $500 96 quite favorably. Terry Hi listers, I don't want to start an argument, but I need some advice on which GPS to buy. I've had the plane flying since last November and I want to buy a GPS real soon! ________________________________________________________________________________
Date: Sep 29, 2004
Try Barnstormers.com John Danielson -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Paul Lein Subject: RV-List: Best way to sell an RV these days Hello all, After much soul-searching and hand-wringing, I've decided to sell my RV-6A. Since I have been off the RV list and pretty much out of touch since the construction phase was over, I need to return for advice from my fellow builders. How can I best get up to speed with resale prices on RVs? In looking at a few online ads in Trade-A-Plane, it appears they are selling for more than they were just a few years ago. Is an ad in Trade-A-Plane still considered the best "bang for the buck" in reaching the wide number of potential buyers or is selling through the Internet, like Barnstormers.com, a better way now? I'm located in Mid-Michigan, but of course since the airplane is finished it could easily be flown cross-country by any buyer. Any up-to-date advice or insight would be appreciated. Cheers, Paul Paul Lein 1555 South Brinton Road Mt. Pleasant, MI 48858-9628 Tel. 989 644-2451 Fax 989 644-6098 pj115(at)journey.com ________________________________________________________________________________
Date: Sep 29, 2004
Subject: Re: Best way to sell an RV these days
Paul, Can you send me info on your RV-6A...I am lookin g to potentially buy. Larry ________________________________________________________________________________
Date: Sep 29, 2004
Subject: Re: io-360 angle valve 60 amp alternator pulley size?
I mean alternator belt...not the pulley! In a message dated 9/29/2004 9:09:32 PM Eastern Standard Time, RV8ter(at)aol.com writes: --> RV-List message posted by: RV8ter(at)aol.com What brand name and size pulley are folks using with the io-360 angle vvalve engine and 60 amp alternator? Anything here to look out for when buying car store brands, so to speak? thanks, lucky do not archive ________________________________________________________________________________
Subject: Re: Windshield Frame
Date: Sep 29, 2004
I did it for my -6 after reading about it in an RVator magazine. Was relatively easy to do and turned out great. Then I did the upper piece in aluminum as well, with similar results. Scott in Vancouver 150 hours ----- Original Message ----- From: "Douglas A. Fischer" <dfischer(at)iserv.net> Subject: RV-List: Windshield Frame > > I visited a local builder who had fabricated an aluminum panel at the base > of the windshield and along the canopy frame on both an RV-6A and -7A. It > looked very nice and neat and he said he did it because he didn't like > fiberglass (I understand that!). It was screwed in place to both the cowl > and the screen and sealed with silicone. Has anybody else done this? I'm > considering doing this because of the neat appearance and also I think > replacing a cracked screen would be infinitely easier. Any thoughts out > there in RV Land? > > Doug Fischer > 90706 Wings > Jenison, MI > > > ________________________________________________________________________________
Date: Sep 29, 2004
I have an iPAQ 5555 running AnywhereMap and it works well. I wouldn't go with a PDA that had a small screen. Get the biggest screen you can. I can run AWM, and have media player going in the background playing my MP3's with no noticeable degradation in performance. You might also check into their new hardware platform the Raven. It's going to have an integrated GPS with a large screen. Doug Rozendaal pointed out their WX offering. They also have an XM weather product now which is all the rage on the ControlVision forums. That's probably another good place to check into before buying a PDA, there are all kinds of opinions there. http://forum.controlvision.com/ They also have AnywhereMapXP which will run on a laptop or tablet PC but the caveat there is size, space, and altitude. Most hard disks have an altitude limitation of about 10,000 feet. The only thing I would warn you about re: AWM is to purchase THEIR GPS module whether it is a CF unit or a BlueTooth unit. Otherwise you won't be able to utilize WAAS. Again, do a search on their forums to find out why. -- Scott VanArtsdalen RV-4 N311SV 4-ever! -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of dmedema(at)att.net Subject: RV-List: Which GPS should I buy Hi listers, I don't want to start an argument, but I need some advice on which GPS to buy. I've had the plane flying since last November and I want to buy a GPS real soon! I designed my panel thinking I would put in a HP iPAQ running Anywhere Map. Since then, I've watched some nice GPS come out like the Garmin 296 (won't fit), the Lawrence 2000C (I was really interested in this but it won't fit either), and the Garmin 96C. The 96C will fit but it has a pretty small screen. All things considered, I think I'm going with Anywhere Map. This brings up the question of which PDA. Control Vision recommends two different iPAQs, but I'm intrigued by the Dell Axim X30. The screen is a bit smaller (3.5" vs 3.8" diagonal), but the speed is quite a bit higher. Control Vision sells a package for the Axim which includes a Compact Flash mount GPS, some cables, and the Anywhere Map software. However, the X30 doesn't have a CF slot and I really don't like the idea of a flash card mount GPS anyway given I want to mount the PDA under my Dynon. Does anyone know what my options are for a GPS with the X30? Is anyone using an Axim with Anywhere Map? If so, how do you like it? Thanks in advance, Doug Medema RV-6A N276DM Hi listers, I don't want to start an argument, but I need some advice on which GPS to buy. I've had the plane flying since last November and I want to buy a GPS real soon! I designed my panel thinking I would put in a HP iPAQ running Anywhere Map. Since then, I've watched some nice GPS come out like the Garmin 296 (won't fit), the Lawrence 2000C (I was really interested in this but it won't fit either), and the Garmin 96C. The 96C will fit but it has a pretty small screen. All things considered, I think I'm going with Anywhere Map. This brings up the question of which PDA. Control Vision recommends two different iPAQs, but I'm intrigued by the Dell Axim X30. The screen is a bit smaller (3.5" vs 3.8" diagonal), but the speed is quite a bit higher. Control Vision sells a package for the Axim which includesa Compact Flash mount GPS, some cables, and the Anywhere Map software. However, the X30 doesn't have a CF slot andI really don't like the idea of a flash card mount GPS anyway given I want to mount the PDA under my Dynon. Does anyone know what my options are for a GPS with the X30? Is anyone using an Axim with Anywhere Map? If so, how do you like it? Thanks in advance, Doug Medema RV-6A N276DM = = = = ________________________________________________________________________________
Date: Sep 30, 2004
From: Alex Peterson <alexpeterson(at)earthlink.net>
Subject: Re: On board WX was, Which GPS should I buy
Doug, I just received an Anywhere Map with XM weather system, running on an IPAQ 5500. I also agree that these systems will transform flying. I only have a few hours experience with it, all in sunlight. It is quite readable, but, with my dark sunglasses on, the IPAQ needs to also be in the sun for me to see it. Without sunglasses, it is no problem. Alex Peterson RV6A 528 hours -----Original Message----- From: Doug Rozendaal <dougr(at)petroblend.com> Subject: RV-List: On board WX was, Which GPS should I buy Doug, On board WX may be a factor to consider in your purchase. I did a demo on WX worx weather for an article for IFR magazine. This is a big deal! It is real, it works, and in a few years it will be nearly as common as GPS and everybit as useful. I went to OSH to buy a system to display WX weather. I came home confused. After that, I tried an Ipaq that belonged to a friend, with anywhere map and WX Worx weather. I thought it would be great in the RV, but I was very disappointed. the screen was hard to read, I don't think a mounted Ipaq would work, because I had to tilt it to deal with glare. The anywheremap software may work ok, but when you put the wx on the map, it overloads the processor. I tried a fujitsu p-600 with an ADR screen upgrade, and it is really cool, but it is a $4000 600mhz out of date tablet pc. Being true to my Dutch heritage, I just bought a fujitsu p600f on ebay for $600 to display WX worx. I made a little box with the reciever, USB hub to split the GPS/wx data, the power supply for the tablet pc. The 600F has a transflective display. if you move it around, it is always readable, the processor is slow but acceptable, the WXworx software works really well, but it seems to be a processor hog. The recommend a 1gig machine and the fujitsu is 600mhz. The WX worx software with a GPS doesn't replace a handheld GPS, it just tells you speed and heading and that is all. Other companies have and are creating software to run on the PC platform, and I may upgrade, but I will still have a battery powered handheld GPS onboard anytime I am IFR. ( I just bought a lowrance airmap 500 and I love it!) I have flown with the 196 and 296 and they are both great units, I like the small size of the 500 and the fact that it runs over 10hrs on 2 AA bats. I have flown 3 trips with the fujistu, and I am really happy with it. It is like having the ADDS weather site in your cockpit. One thing about it, an autopilot would be almost mandatory, because it captivates alot of attention, but it is GREAT information! Tailwinds Doug Rozendaal ________________________________________________________________________________
Date: Sep 30, 2004
Subject: Re: Which GPS should I buy
In a message dated 9/29/04 4:27:55 PM Central Daylight Time, dmedema(at)att.net writes: > . Does anyone know what my options > are for a GPS with the X30? Is anyone using an Axim > with Anywhere Map? If so, how do you like it? >>>> Hi Doug- I would definately ask Control Vision if they guarantee the same functionality using the Dell as they do with the iPAQ. I'm using a pair of Dell X5s in my panel running PCFlightSystems EFIS on one and NavGPS on the other- the nav uses a Garmin 35 and the whole thing is integrated into one system. It all works quite well except there are a number of the features such as HITS and the air data interface that do not work. PCFlightSystems has been telling me the Dell serial interface is somehow "different" from HP and that they are working to resolve the problems, but still no updates since OSH. Perhaps CV has this resolved, or the X30 is fully compatible, but I'd sure ask! From The PossumWorks in TN Mark ________________________________________________________________________________
Date: Sep 30, 2004
Subject: Re: 2 VS 3 BLADES CATTO
Fixed- foto sent off-list ________________________________________________________________________________
Date: Sep 30, 2004
Correction: My Anywhere Map XM weather system uses an IPAQ 5550, not 5500. Alex Peterson RV6A 528 hours ________________________________________________________________________________
Date: Sep 30, 2004
Are your sunglasses polarized? Non-polarized might help the situation. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Alex Peterson said: > > Doug, > > I just received an Anywhere Map with XM weather system, running on an IPAQ > 5500. I also agree that these systems will transform flying. I only have > a few hours experience with it, all in sunlight. It is quite readable, > but, with my dark sunglasses on, the IPAQ needs to also be in the sun for > me to see it. Without sunglasses, it is no problem. > > Alex Peterson > RV6A 528 hours > > -----Original Message----- > From: Doug Rozendaal <dougr(at)petroblend.com> > To: rv-list(at)matronics.com > Subject: RV-List: On board WX was, Which GPS should I buy > > > Doug, > > On board WX may be a factor to consider in your purchase. I did a demo on > WX worx weather for an article for IFR magazine. This is a big deal! It > is > real, it works, and in a few years it will be nearly as common as GPS and > everybit as useful. > > I went to OSH to buy a system to display WX weather. I came home > confused. > After that, I tried an Ipaq that belonged to a friend, with anywhere map > and > WX Worx weather. I thought it would be great in the RV, but I was very > disappointed. the screen was hard to read, I don't think a mounted Ipaq > would work, because I had to tilt it to deal with glare. > > The anywheremap software may work ok, but when you put the wx on the map, > it > overloads the processor. > > I tried a fujitsu p-600 with an ADR screen upgrade, and it is really cool, > but it is a $4000 600mhz out of date tablet pc. > > Being true to my Dutch heritage, I just bought a fujitsu p600f on ebay for > $600 to display WX worx. I made a little box with the reciever, USB hub > to > split the GPS/wx data, the power supply for the tablet pc. > > The 600F has a transflective display. if you move it around, it is always > readable, the processor is slow but acceptable, the WXworx software works > really well, but it seems to be a processor hog. The recommend a 1gig > machine and the fujitsu is 600mhz. > > The WX worx software with a GPS doesn't replace a handheld GPS, it just > tells you speed and heading and that is all. Other companies have and are > creating software to run on the PC platform, and I may upgrade, but I will > still have a battery powered handheld GPS onboard anytime I am IFR. ( I > just bought a lowrance airmap 500 and I love it!) I have flown with the > 196 > and 296 and they are both great units, I like the small size of the 500 > and > the fact that it runs over 10hrs on 2 AA bats. > > I have flown 3 trips with the fujistu, and I am really happy with it. It > is > like having the ADDS weather site in your cockpit. One thing about it, an > autopilot would be almost mandatory, because it captivates alot of > attention, but it is GREAT information! > > Tailwinds > Doug Rozendaal > > ________________________________________________________________________________
Date: Sep 30, 2004
Yes, but the rotational alignment is correct. Alex Peterson Are your sunglasses polarized? Non-polarized might help the situation. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Sep 30, 2004
Subject: Off Topic - F4 crashing into concrete wall - video
Hi, This is cool. http://69.93.149.132/files/concreteplane1.wmv It was a test to make sure that nuclear power plants are safe from planes crashing into them. Something to send to people that still think we need restricted zones over nuclear power plants. Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Sep 30, 2004
dmedema(at)att.net wrote: > > Hi listers, > > I don't want to start an argument, but I need some advice on which > GPS to buy. I've had the plane flying since last November and I want > to buy a GPS real soon! > > I designed my panel thinking I would put in a HP iPAQ running > Anywhere Map. Since then, I've watched some nice GPS come out like > the Garmin 296 (won't fit), the Lawrence 2000C (I was really > interested in this but it won't fit either), and the Garmin 96C. The > 96C will fit but it has a pretty small screen. All things > considered, I think I'm going with Anywhere Map. > > This brings up the question of which PDA. Control Vision recommends > two different iPAQs, but I'm intrigued by the Dell Axim X30. The > screen is a bit smaller (3.5" vs 3.8" diagonal), but the speed is > quite a bit higher. Control Vision sells a package for the Axim > which includes a Compact Flash mount GPS, some cables, and the > Anywhere Map software. However, the X30 doesn't have a CF slot and I > really don't like the idea of a flash card mount GPS anyway given I > want to mount the PDA under my Dynon. Does anyone know what my > options are for a GPS with the X30? Is anyone using an Axim with > Anywhere Map? If so, how do you like it? Doug, I have been using AWM with a 3765 for nearly three years. The AWM software/iPAG is a good option with many unique features for the pilot that is comfortable with using a computer in the cabin. I recently purchased a Dell X30 and think it represents a very good value and am pleased with it. The old 3765 was retired to full-time service in the RV-6 since the battery had just about expired. It stays powered up continuously on the aircraft battery so the software won't get dumped. Even though the X30 isn't being used for AWM, I use it on the car with Street Atlas and a Radio Shack DigiTraveler GPS. You can get a GPS cable for the X30 here: http://pc-mobile.net/ax3.htm I got the PX3GSP version so the X30 could be powered by the car battery cable. I use the Garmin GPS35 in the RV-6 which is a fantastic receiver. However, you probably want to check out the newer Garmin GPS18 PC which should perform as well at a lower price: http://www.gpscity.com/gps/brados/2452.1.9335267956618175890/template.html I recommend you hard wire some connections to the avionics bus so you can eliminate some of the cords and connections. The GPS will work fine on 12vdc but you need to be aware the X30 needs 5vdc so don't wire it directly to the bus!! You can either whip up a little power converter or hack the car cord. Since you are an engineer I suspect you can figure all this out...... ;-) You will find the X30/GarminGPS combo to be a robust rig with a ton of features that is continuously upgradeable. Now, having said all that, I am considering replacing both the 3765 and Lowrance 100 in the RV-6 with Lowrance's really cool Airmap 1000. The display on this thing is BIG and that is good for my increasingly hyperopic eyes. :-) Those who are considering one of the Lowrance units can download a simulator to run on a PC so you can play with the features: http://www.lowrance.com/Software/PCSoftware/demos.asp Sam Buchanan http://thervjournal.com ________________________________________________________________________________
Date: Sep 30, 2004
Subject: KLX-135A
Jim Irwins President of Aircraft Spruce has asked me to post this for him. Thank You... I noticed your posting to the RV Group on Aircraft Spruce's price being higher than others on the KLX-135A, and you were absolutely correct. We had the incorrect price on our web-site, and it has been corrected from $2729 to $2475 which is quite competitive. We asked Honeywell how Great Lakes could offer it at $2195 (below our cost) and their only guess was that they must be trying to move out old stock since they have not purchased any in several years. Regards, Jim Irwin President, Aircraft Spruce __________________________________ ________________________________________________________________________________
Subject: Flightline Interiors Work
Date: Sep 30, 2004
I just received my Oregon Aero seats for my RV6A that I sent to Abby Erdmann at Flightline Interiors. I can't say enough about how pleased I am with her work. It is FIRST CLASS. She finished them soon than promised, and the work is flawless. Thank you, Abby, for a job well done !! John at Salida, CO ________________________________________________________________________________
Subject: VRML Model of an RV?
Date: Sep 30, 2004
Anyone know where I can find a VRML model of an RV? RV-4 would be nice, but I'm not choosy. Thanks, Dave Hyde nauga(at)brick.net RV-4 in flight test ________________________________________________________________________________
Date: Sep 30, 2004
Subject: Re: Flightline Interiors Work
In a message dated 9/30/2004 7:45:58 PM Eastern Standard Time, n1cxo320(at)salidaco.com writes: --> RV-List message posted by: "John" I just received my Oregon Aero seats for my RV6A that I sent to Abby Erdmann at Flightline Interiors. I can't say enough about how pleased I am with her work. It is FIRST CLASS. She finished them soon than promised, and the work is flawless. Thank you, Abby, for a job well done !! John at Salida, CO Thanks for the report. What's the difference between her seat cushions and the Oregon Aero? ________________________________________________________________________________
Date: Sep 30, 2004
The difference is in the upholstery...Abby upholstered the Oregon Aero cushions for me...$350 for two seats. Oregon Aero wanted $375 EACH...a big difference. Abby also sells her own seat cushions which I didn't know. John ________________________________________________________________________________
Subject: Builders of the Quickbuilds
Date: Oct 01, 2004
Are these the folks building the quickbuilds? Hard to figure out if they're now offering custom build services to us now or not. Not the greatest website (check out the mission statement...!) but shows some interesting jigs in use. www.bonanzametalcrafters.com. Brian Denk RV8 N94BD RV10 '51 ________________________________________________________________________________
Date: Oct 01, 2004
Subject: Re: VRML Model of an RV?
Nauga wrote: > >Anyone know where I can find a VRML model of an RV? >RV-4 would be nice, but I'm not choosy. > >Thanks, > >Dave Hyde >nauga(at)brick.net >RV-4 in flight test > > > > I am building a RV-9A and wanted a model as a incentive. I bought a perfect wood model from Griffin Aerospace models. They will paint it the way your finished product should look or send it to you primered. 1-817-624-2320 1-866-584-0260 aeromodel(at)aol.com fred griffing good luck marcel in El paso ________________________________________________________________________________
Subject: Re: Which GPS should I buy - dimming the 196
Date: Oct 01, 2004
I had the same issue with my 196. However, *you can* lower the brightness from the two preset levels. I don't have it with me right now, but I seem to remember it being done with the contrast adjusting display. As I recall, instead of toggling left and right for contrast, toggle up and down and you'll get less or more light. Not sure if this was how I did it, but it can in fact be lowered. Bryan >Haven't heard much on readability at night. I have a Garmin 196 in my -6. >My only complain is it is much too bright at the lowest setting at night. >I >even tried to put a sheet of cling-on plastic of the darkest shade and was >still too bright to my taste. My hangar mate has a 295. His cockpit glows >during night flights. >Anh >Maryland > ________________________________________________________________________________
Subject: Which GPS should I buy - dimming the 196
Date: Oct 01, 2004
This puzzles me. With my Garmin 196, I can touch the on-off button and then dim the screen to virtually off by pushing on the bottom of the 4- way button, just like the instructions say. The sides of the 4-way button increase or decrease screen contrast. Terry >Haven't heard much on readability at night. I have a Garmin 196 in my -6. >My only complain is it is much too bright at the lowest setting at night. >I >even tried to put a sheet of cling-on plastic of the darkest shade and was >still too bright to my taste. My hangar mate has a 295. His cockpit glows >during night flights. >Anh >Maryland > ________________________________________________________________________________
Date: Oct 01, 2004
Anh, The 295 brightness and contrast is easily adjusted - Have your hanger mate check his user manual. Chuck >From: "Terry Watson" <terry(at)tcwatson.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RE: RV-List: Which GPS should I buy - dimming the 196 >Date: Fri, 1 Oct 2004 08:51:03 -0700 > > >This puzzles me. With my Garmin 196, I can touch the on-off button and >then >dim the screen to virtually off by pushing on the bottom of the 4- way >button, just like the instructions say. The sides of the 4-way button >increase or decrease screen contrast. > >Terry > > > >Haven't heard much on readability at night. I have a Garmin 196 in my >-6. > >My only complain is it is much too bright at the lowest setting at night. > >I > >even tried to put a sheet of cling-on plastic of the darkest shade and >was > >still too bright to my taste. My hangar mate has a 295. His cockpit >glows > >during night flights. > >Anh > >Maryland > > > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Oct 01, 2004
Subject: Re: Builders of the Quickbuilds
I think I recognized my RV8 fuselage in there! I know I've said it before, but it's worth saying again. I'm real impressed with the quality of my QB. The way they installed the skins on the fuselage is really top notch. Perfect overlapping seams everywhere. If only they used better primer! Mickey >Are these the folks building the quickbuilds? Hard to figure out if they're >now offering custom build services to us now or not. Not the greatest >website (check out the mission statement...!) but shows some interesting >jigs in use. > >www.bonanzametalcrafters.com. -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Oct 01, 2004
I think I "might" see a set of plans in one of the pictures. Maybe that explains the backwards bulkhead in my friend's -8 QB along with a few other oops. There should be appropriate drawings handy at every workstation. Mike __________________________________ ________________________________________________________________________________
Date: Oct 02, 2004
We have a QB here in Queenstown, New Zealand, and I often refer to it and wonder how they so neatly set some of the more difficult rivets, like the ones I drill out several times, and in the end settle for something less than I aimed for. By the time I had put together my 100th fuse. I would expect my skills to have improved. But get a load of those poor buggers that sit at that table, day after day,scrubbing and deburring. We all hate that time consuming task, but to them I suppose a job is a job Stan Jones. -------Original Message------- From: rv-list(at)matronics.com Date: Saturday, October 02, 2004 07:12:07 Subject: Re: RV-List: Builders of the Quickbuilds I think I recognized my RV8 fuselage in there! I know I've said it before, but it's worth saying again. I'm real impressed with the quality of my QB. The way they installed the skins on the fuselage is really top notch. Perfect overlapping seams everywhere. If only they used better primer! Mickey >Are these the folks building the quickbuilds? Hard to figure out if they're >now offering custom build services to us now or not. Not the greatest >website (check out the mission statement...!) but shows some interesting >jigs in use. > >www.bonanzametalcrafters.com. -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Subject: Selling my RV - followup
Date: Oct 01, 2004
Hello all, Thanks for the good advice on and off the list. I've got a spec sheet with photographs now that I'll be happy to email to any interested parties. I'm awaiting answers from a couple people that are helping me with fair market price, so I should have a target price in the next day or two. Thanks again. Paul Paul Lein 1555 South Brinton Road Mt. Pleasant, MI 48858-9628 Tel. 989 644-2451 Fax 989 644-6098 pj115(at)journey.com ________________________________________________________________________________
Date: Oct 01, 2004
I recently replaced my garmin 195 after 4 yrs of service. I chose a Garmin 296 over the large Lowrance airmap and the anywhere map for the following reasons: 1) Lowrance is FANTASTIC, but it was too large to work in an RV-4 cockpit. I didn't want to strap it to my leg as I commonly have a kneeboard strapped to my leg during cross country flights. If I owned a 6, 7, 9, or maybe even an 8, I'd definitely have looked harder at it. At 999 its a steal. 2) I flew from Seatle to CT with Anywhere Map. I was very impressed with the software, but was very disappointed with its implementation on Windows handhelds. It rebooted 2 times during the 3 day trip. This is an incredible piece of software looking for a dedicated piece of hardware to run on. 3) I knew 296 would work as advertised. It was the right size for the inside of my cockpit. It fit below my Dynon on my panel. Thoughts on the 296 now that I've owned it. 1) Display is great in bright sunlight. It is backlit, but is also very reflective so it works OK even without the backlight. 2) Battery really honestly lasts for 12 or so hours. I was pleasantly surprised. ________________________________________________________________________________
From: "David Fenstermacher" <dfenstermacher(at)earthlink.net>
Subject:
Date: Oct 01, 2004
Don't usually do this sort of thing (post about companies). But.... Check out www.clearairtools.com I got a CP-214C remanufactured squeezer for 290 bucks (with a yoke). I had a leak in the swivel and he is sending me another before I send the one I have back (no downtime). The owner is building a 6A, so he is sensitive to this sort of thing. When I mentioned that I could provide a receipt, he wasn't worried. He just wanted to make it right. I would recommend. Dave blah, blah, blah - not affiliated. David Fenstermacher dfenstermacher(at)earthlink.net Why Wait? Move to EarthLink. ________________________________________________________________________________
Subject: Re: Attaching Engine to Mount
Date: Oct 02, 2004
I'm having trouble attaching an O320 engine to the dynafocal mount. Anyone have any helpful hints? Is there a difference between the O320 and O360 mounts? Thanks, Ned ________________________________________________________________________________
Date: Oct 02, 2004
Subject: IO-360-A1B6D & D4LN-3000 dual mag pack
Thanks for the info Mahlon! Last night long after I should have been asleep I finally stumbled on some stuff by accident that I needed to know about this engine which I never ran across before including this P lead kit. I found some direct info at _http://www.sacskyranch.com/acatalog/Sacramento_Sky_Ranch_P_lead_ground_terminal_kits_292 .html_ (http://www.sacskyranch.com/acatalog/Sacramento_Sky_Ranch_P_lead_ground_terminal_kits_292.html) Unfortunately unless the kit has some kind of instruction or the book I ordered does then I'll be back asking for help :-) But the serious issue I discovered at a cessna/cardinal web site which some before me hadn't prior to engine seizing in flight was that engines with dual mags requires a special blocking plate to be installed between two gaskets on a rear mounted prop governor. _http://www.cardinalflyers.com/pub/info/govplate.htm_ (http://www.cardinalflyers.com/pub/info/govplate.htm) Lycoming SI 1438 supposedly covers this. "...Lycoming's service instruction # 1438 dated July 9, 1987 stating that ALL 4 & 6 cyl. dual mag engines with rear mount govenors must have this plate. [Emphasis added.. Webmaster]" This critical part does not show up in the engine or airframe manuals and many A&Ps apparently aren't trained/aware this according to the article. Lucky In a message dated 10/2/2004 6:02:47 AM Eastern Standard Time, mahlon_russell(at)teledyne.com writes: Lucky, There is a special P lead attachment kit that you will need. P/N LW- 382698. It is shown in the IO-360-A3B6D parts book for the engine, item number 9, Figure 28, page 4-13. Its installation on the p lead wires requires some minor soldering. It is not something you will likely to be able to fabricate on your own. Good Luck, Mahlon --- In lycoming(at)yahoogroups.com, RV8ter(at)a... wrote: > My mag book hasn't arrived yet and there's no telling it will have all I'm > looking for anyway so does someone have a picture and or a description of how > the p leads are supposed to be connected to the dual mag pack? I thnk I'm > missing some "special" connector for the leads because it's not a simple > threaded stud like I've seen before. > > D4LN-3000 is the model. > > > [Non-text portions of this message have been removed] ________________________________________________________________________________
Date: Oct 02, 2004
I doubt there's a difference. My io-360 was a royal pain in the a$$ too and when I finally finished I didn't think the next time would be any easier. There were times when you need to actually push/pull the mount to line up with the holes. I did most of that by allowing the engine with mount half attached to be lowered so that the weight of the engine would move the mount in the directions I needed it to go. In the end, the final bolt had to be socket wrenched through the hole kicking and screaming all the way. ----Original Message Follows---- From: "923te" <923te(at)cox.net> Subject: Re: RV-List: Attaching Engine to Mount Date: Sat, 2 Oct 2004 05:43:08 -0500 I'm having trouble attaching an O320 engine to the dynafocal mount. Anyone have any helpful hints? Is there a difference between the O320 and O360 mounts? Thanks, Ned ________________________________________________________________________________
Date: Oct 02, 2004
When I mounted my engine I had to have the bolts already installed tightened down before the other bolts would line up. Dale Mitchell RV-8A MN wing --- 923te <923te(at)cox.net> wrote: > <923te(at)cox.net> > > I'm having trouble attaching an O320 engine to the > dynafocal mount. Anyone > have any helpful hints? Is there a difference > between the O320 and O360 > mounts? > Thanks, > Ned > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Oct 02, 2004
Hi Ned: I refer you to the link listed below which is for the illustrated guide to engine hanging done by Jim Norman et. al. I used his techniques/tips and was able to hang my 0320 E3D in about 45 minutes. They were very helpful. Excuse the pun, but hang in there. http://www.vansairforce.net/articles/IllustratedGuideToEngineHanging/enginehanging.htm Regards, Jeff Orear RV6A N782P (reserved) firewall forward Peshtigo, WI ----- Original Message ----- From: "923te" <923te(at)cox.net> Subject: Re: RV-List: Attaching Engine to Mount > > I'm having trouble attaching an O320 engine to the dynafocal mount. Anyone > have any helpful hints? Is there a difference between the O320 and O360 > mounts? > Thanks, > Ned > > > ________________________________________________________________________________
Date: Oct 02, 2004
From: "thomas a. sargent" <sarg314(at)earthlink.net>
Subject: setting engine down.
It is becoming clear, as I contemplate engine installation, firewall penetrations, baff;es, etc., etc. that muy engine is going to spend a lot of time on the hoist before getting bolted to the plane. (I've been advised to keep it on the hoist and just move it up into position to estimate wire lengths, hoses, etc. That keeps it and the mount out of the way while working on the firewall.) So, if this is true, then I need to set the engine down a lot. I don't want to put it back in its crate because that involves bolting it to the large steel brackets that are attached to the crate and will probably be very difficult. So is it OK to set it down on the sump on some 4x4 wooden blocks? One suggstion I got was to get a couple pieces of foam insulation sold in sheets at Home Depot (about 5 inches of foam total) and set it on that. What do people normally use? -- Tom Sargent, RV-6A, Landing gear ________________________________________________________________________________
Date: Oct 02, 2004
Subject: Re: setting engine down.
thomas a. sargent wrote: > > It is becoming clear, as I contemplate engine installation, firewall > penetrations, baff;es, etc., etc. that muy engine is going to spend a > lot of time on the hoist before getting bolted to the plane. (I've been > advised to keep it on the hoist and just move it up into position to > estimate wire lengths, hoses, etc. That keeps it and the mount out of > the way while working on the firewall.) > > So, if this is true, then I need to set the engine down a lot. I don't > want to put it back in its crate because that involves bolting it to the > large steel brackets that are attached to the crate and will probably be > very difficult. > > So is it OK to set it down on the sump on some 4x4 wooden blocks? One > suggstion I got was to get a couple pieces of foam insulation sold in > sheets at Home Depot (about 5 inches of foam total) and set it on that. > What do people normally use? Tom, one way to support the engine (if the carb/injector is not installed) is to set the engine on a couple of old tires. Check out the photo near the bottom of this page to see how I transported my engine: http://home.hiwaay.net/~sbuc/journal/overhaul-3.htm Sam Buchanan ________________________________________________________________________________
Date: Oct 02, 2004
Subject: Superior XP-IO360/FF sump question
Listers... I have a Superior XP-IO360 with the new Ryton plastic forward facing sump. If anyone has the same setup, and has pix to share, I would be curious to see where/how the bracket for throttle cable was mounted. Van's bracket doesn't seem to fit. Email off list if you wish at _jerry2dt(at)aol.com_ (mailto:jerry2dt(at)aol.com) . Thanx. Jerry Cochran ________________________________________________________________________________
Date: Oct 02, 2004
From: Chris W <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net>
thomas a. sargent wrote: >So, if this is true, then I need to set the engine down a lot. > Why can't you leave the engine on the hoist? If you are concerned about loosing hydraulic pressure and it falling or slowly leaking down, why not just cut some steel tubing in half length wise and clamp it around the rod on the hoist's hydraulic cylinder between the cylinder top and the rod end clevis, then it can't fall even if it has a sudden loss of hydraulic pressure. -- Chris W Bring Back the HP 15C http://hp15c.org Not getting the gifts you want? The Wish Zone can help. ________________________________________________________________________________
Date: Oct 02, 2004
I always feel better relieving the stress on the case since the whole load goes thru one case bolt so I bought a 4 wheel garden cart from Harbor Freight. I added a piece of MDF and some old tires to support the engine. It will roll between the outriggers of the engine hoist so I can drop it on the cart to support it in place or disconnect the hoist and move them around separately. A $40 cart seemed like cheap insurance. Regards, Greg Young - Houston (DWH) RV-6 N6GY ...project Phoenix Navion N5221K - just an XXL RV-6A > --> <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net> > > thomas a. sargent wrote: > > >So, if this is true, then I need to set the engine down a lot. > > > Why can't you leave the engine on the hoist? If you are > concerned about loosing hydraulic pressure and it falling or > slowly leaking down, why not just cut some steel tubing in > half length wise and clamp it around the rod on the hoist's > hydraulic cylinder between the cylinder top and the rod end > clevis, then it can't fall even if it has a sudden loss of > hydraulic pressure. > > -- > Chris W ________________________________________________________________________________
Date: Oct 02, 2004
Subject: Glazing putty and Smooth Prime
Anybody know about using glazing putty on top of Polyfiber Smooth Prime? I'm worried about it being water based, and if there are any products to stay away from. Specifically, has anyone used a product called "Ice" made by, I believe, PPG? Is this suitable was use over Smooth Prime? Jeff Point RV-6 Milwaukee WI ________________________________________________________________________________
Date: Oct 02, 2004
thomas a. sargent wrote: > >It is becoming clear, as I contemplate engine installation, firewall >penetrations, baff;es, etc., etc. that muy engine is going to spend a >lot of time on the hoist before getting bolted to the plane. (I've been >advised to keep it on the hoist and just move it up into position to >estimate wire lengths, hoses, etc. That keeps it and the mount out of >the way while working on the firewall.) > >So, if this is true, then I need to set the engine down a lot. I don't >want to put it back in its crate because that involves bolting it to the >large steel brackets that are attached to the crate and will probably be >very difficult. > >So is it OK to set it down on the sump on some 4x4 wooden blocks? One >suggstion I got was to get a couple pieces of foam insulation sold in >sheets at Home Depot (about 5 inches of foam total) and set it on that. >What do people normally use? > Bolt the engine to the engine mount and stand it on a table with the prop flange pointing up. If you set it down on the firewall, or aluminum cut to shape of the firewall, then you can plan on where to bolt things down and the length of stuff goint through the firewall is easily measured. You can put all the plumbing in place with this setup and work on a more reasonable level than hanging in front of the firewall on a hoist. Linn ________________________________________________________________________________
Date: Oct 02, 2004
Subject: Re: >Re: setting engine down
As Linn Walters said, with the engine on the mount you can get all the measurements easier. It would also be easier to bolt the engine to the mount with the engine weight on the Lord Mounts. You should be able to put the bolts in with the engine weight compressing the mounts without having all the trouble usually associated with this chore. My 2 cents worth, Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
From: "Robert E. Lynch" <rv6lynch(at)earthlink.net>
Subject: Jefferson City, Missouri - FLY-IN!!! 10/09/04
Date: Oct 02, 2004
The 3rd Annual Jefferson City, Missouri (JEF) will be held this coming weekend October 9th!! This years event will feature Wings & Wheels with approximately 30 collector cars in attendance. Lunch will be served. See you there! For more information please eMail me off-line. Bob ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling(at)earthlink.net>
Subject: engine starter suddenly not meshing
Date: Oct 02, 2004
A strange thing happened recently to my 6a. I have an io360 with a Dick Waters/air tech starter and it has been working flawlessly for about 120 hours. It then started to not mesh with the flywheel about every other start and then worsened to all the time. I was able to put the prop in a low compression point to get it to engage. Once I took the cowl off I shimmed the starter out from the engine the thickness of a washer and reinstalled. The teeth now mesh about 1/2 their depth and the starter has engaged every time, about 10 tries now. Im wondering why something like this would develop over time. Does anyone out there have a suggestion on why this would happen over time? Shemp 6a 135 hrs Chicago/Louisville ________________________________________________________________________________
Date: Oct 03, 2004
Ahh.... could be operator error. I touch the on-off button repeatedly vice using the 4-way button. The on-off button only give you 4 settings. Anh Maryland ----- Original Message ----- From: "Terry Watson" <terry(at)tcwatson.com> Subject: RE: RV-List: Which GPS should I buy - dimming the 196 > > This puzzles me. With my Garmin 196, I can touch the on-off button and then > dim the screen to virtually off by pushing on the bottom of the 4- way > button, just like the instructions say. The sides of the 4-way button > increase or decrease screen contrast. > > Terry > > > >Haven't heard much on readability at night. I have a Garmin 196 in my -6. > >My only complain is it is much too bright at the lowest setting at night. > >I > >even tried to put a sheet of cling-on plastic of the darkest shade and was > >still too bright to my taste. My hangar mate has a 295. His cockpit glows > >during night flights. > >Anh > >Maryland > > > > > --- > > --- ________________________________________________________________________________
Subject: Oil fitting
Date: Oct 03, 2004
Maybe I'm just not looking in the right places, but I can't find a source for the 45 degree oil fitting for Lycoming engines. You know the one that you have to put in before you mount the engine. Any help? Ron Schreck Gold Hill Airpark, NC RV-8, ready to hang engine ronschreck(at)earthlink.net ________________________________________________________________________________
Date: Oct 03, 2004
Subject: Re: Oil fitting
Hi Ron, I think the fitting you mean is the 45 degree, 1/8" NPT to tube with a restritor. It is in the Van's catalog on page 13. Regards, Richard Dudley -6A getting ready to move to the airport. Ron Schreck wrote: > >Maybe I'm just not looking in the right places, but I can't find a source for the 45 degree oil fitting for Lycoming engines. You know the one that you have to put in before you mount the engine. Any help? > > >Ron Schreck >Gold Hill Airpark, NC >RV-8, ready to hang engine >ronschreck(at)earthlink.net > > > > ________________________________________________________________________________
Subject: 4 way HAT switches
Date: Oct 03, 2004
You can also purchase these trim switches from Infinity for $15 + $1 for the China Hat http://www.infinityaerospace.com/4-way-pic-and-specs.jpg ________________________________________________________________________________
Date: Oct 03, 2004
Subject: Re: 4 way HAT switches
ray allen's 4 way hat switch used on their newer line of stick grips is rated up t 15 amps and are advertised as not need a relay deck with using their trim servos so you should consider using them if you want to avoid additional cost/work/complexity. ________________________________________________________________________________
Subject: RV-List:Lasar ignition backup mode
Date: Oct 03, 2004
My Lasar Ignition system reverts to "backup" mode shortly after T/O System worked perfectly for first 7-8 flts. Shortly thereafter it started reverting to backup mode but corrected itself. This became more frequent and now remains in backup from just after T/O I have tried resetting in flt but this works for approx two minutes only. It definately works during these two min as evidenced by reduction in EGT's and smoother running of engine. Thus far I have disconnected the CHT probe, checked for loose wires,chafing and suction connection. All ok. Also re-gelled the contacts. Tests ok during ground checks. Also tried various power/RPM/mixture settings to no avail. No excessive temps in all phases of operation Any suggestions? Trevor Davis (South Africa) RV-6 with IO-320 ________________________________________________________________________________
Subject: Re: RV-List:Lasar ignition backup mode
Date: Oct 03, 2004
> My Lasar Ignition system reverts to "backup" mode shortly after T/O > System worked perfectly for first 7-8 flts. Shortly thereafter it started reverting to > backup mode but corrected itself. This became more frequent and now remains in backup from just after T/O > I have tried resetting in flt but this works for approx two minutes only. It definately works during these two min as evidenced by reduction in EGT's and smoother running of engine. Thus far I have disconnected the CHT probe, checked > for loose wires,chafing and suction connection. All ok. Also re-gelled the contacts. Tests ok during ground > checks. Also tried various power/RPM/mixture settings to no avail. No excessive temps in all phases of operation > Any suggestions? > > Trevor Davis (South Africa) RV-6 with IO-320 Trevor, The connections to the CHT sensor are a known problem with these units, they must be perfect or the unit will go into backup mode. If you simply disconnect the CHT leads it will never get into electronic mode so that won't work. Unison sometimes recomments soldering or crimping the connections rather than using spade disconnects. If that isn't it then consider sending the brain back. Their turnaround is fairly quick (although South Africa is a bit of jaunt!). BTW, for experimental aircraft LASAR can be ordered without the CHT sensor circuit, which is the way I ordered mine and recommend that others do. It is only required for certified aircraft. Randy Lervold www.rv-3.com www.rv-8.com ________________________________________________________________________________
Subject: re: rv4 cowl cheeks
Date: Oct 03, 2004
Can anyone share their experiences with the RV4 cowl cheek extensions. Specifically, how did you deal with the interference between them and the top forward skin, and also, did you use any filler to fair them to the side skins or just rivet em on and paint? Thanks. Steve Zicree Starting Finishing Kit ________________________________________________________________________________
Date: Oct 03, 2004
Avery Tools sells a set of alignment pins that I invented that makes getting the bolts in much easier. In addition to the article mentioned, I taped the rubber pucks in place and that way you don't have to worry about keeping them in place by hand. The alignment pins are fairly short and act as a lead through the holes that lines things up as they are driven through by the bolt that follows. All you have to do is tap the pin in until just before it gets to the edge of the mount and then with the bolt, give it just one good tap and then the bolt holds things aligned. I mounted my engine by myself in about 30 minutes. The pin falls out of the other side as you push the bolt through. The short pins are for the bottom bolts and the longer pins are for the top ones. Jim Cone 3-peat Offender ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: re: rv4 cowl cheeks
Date: Oct 03, 2004
A friend with a nice RV-4 simply trimmed the cheek extensions to butt against the top skin. I might shim the extensions with 0.032 and avoid trimming them. He didn't try to fair them to the side skins, and I think that's the right approach. KB ----- Original Message ----- From: "steve zicree" <szicree(at)adelphia.net> Subject: RV-List: re: rv4 cowl cheeks > > Can anyone share their experiences with the RV4 cowl cheek extensions. > Specifically, how did you deal with the interference between them and the > top forward skin, and also, did you use any filler to fair them to the > side skins or just rivet em on and paint? Thanks. > > Steve Zicree > Starting Finishing Kit > > > ________________________________________________________________________________
Date: Oct 03, 2004
Subject: sensenich prop.
I have a 70cm-78 sensenich propeller with van's spacer, spinner, and bolts for sale. This is used on a lycoming o-320 160 hp engine. Less than 200 hrs very good condition. $1500 Jerry Berger 803 663 9974 south Carolina ________________________________________________________________________________
Subject: Fuselage Order Questions
Date: Oct 03, 2004
All, Just getting ready to send in the order for the 7A fuselage kit, and I am having trouble deciding on a few options. I searched the archives, but I didn't really get all my questions answered. 1) Steps - 0, 1, or 2? - I believe I have read that there is not a real speed penalty in adding the steps. I am also thinking it would look odd to have just one. Current thinking is to go with two. I am about 5'11", and I am not super worried about accomadating passengers. That being said...if there's no speed penalty, then I guess it makes sense to add them anyway. 2) Aileron trim - manual vs electric - Where would the knob get located if it were manual? Does it interfere with anything? I went manual with the elevator. Only reason I can think to go electric is if it is logistically much cleaner with the electric. 3) Static air - I installed the Gretz mount and am waiting for the never ending Dynon heated pitot. Would I need the static kit? The plane will be IFR. Thanks, Scott 7A Wings www.scottsrv7a.com Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Subject: Re: Fuselage Order Questions
Date: Oct 03, 2004
----- Original Message ----- From: <tx_jayhawk(at)excite.com> Subject: RV-List: Fuselage Order Questions > > > All, > > Just getting ready to send in the order for the 7A fuselage kit, and I am > having trouble deciding on a few options. I searched the archives, but I > didn't really get all my questions answered. > > 1) Steps - 0, 1, or 2? - I believe I have read that there is not a real > speed penalty in adding the steps. I am also thinking it would look odd > to have just one. Current thinking is to go with two. I am about 5'11", > and I am not super worried about accomadating passengers. That being > said...if there's no speed penalty, then I guess it makes sense to add > them anyway. I'm sure the steps cost a little speed. Maybe not measurable unless you have NASA's test equipment... That said, I'd install both steps. All of your passengers won't be spry, and one day you won't be either. It is a chore for my wife to get in and out of my -6, even with the flaps down. When I park the airplane outside on overnight trips, I lock the flaps up and the canopy closed, so I've got quite a first step onto the wing and over the flap. A step would be handy. > 2) Aileron trim - manual vs electric - Where would the knob get located if > it were manual? Does it interfere with anything? I went manual with the > elevator. Only reason I can think to go electric is if it is logistically > much cleaner with the electric. In the -6, the manual trim goes between the seats, behind the fuel selector. Not in the way of anything. > 3) Static air - I installed the Gretz mount and am waiting for the never > ending Dynon heated pitot. Would I need the static kit? The plane will be > IFR. I imagine so, unless the pitot system (Gretz?) has a static port built in. > Thanks, > Scott > 7A Wings > www.scottsrv7a.com > > Join Excite! - http://www.excite.com > The most personalized portal on the Web! > > > ________________________________________________________________________________
Date: Oct 03, 2004
Subject: Re: Dynon D-10 Encoder Question
writes: > > That's wild! Thanks for the clarification. > > So with a serializer, I presume the Dynon can encode for the GPS > (GX-60) as > well. Nice. Although as far as I know, it costs just as much to > buy a > standalone serializer as it does just to buy a Sandia or Trans-Cal > dual-output encoder in the first place. > > Is the EFIS-D10 adjustable just like any other blind encoder? I > guess I > should call Dynon one of these days, but I figure the more info we > can > disseminate here the less loaded Dynon will be on the phones, the > quicker > we'll all get our units shipped. > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ----- Original Message ----- > From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net> > To: > Subject: RE: RV-List: Dynon D-10 Encoder Question > > > > > > > I just went through that thought process also. Terribly wrong I > was. The > > Dynon produces "Gray code" that the transponder needs to report > altitude. > > This should be emphasized a lot more in there literature. In my > mind this > > is another very good selling point. > > > > The plug and play panel with the Dynon turned out great, I got a > lot of > > comments on the unit "flying" on the bench. I can't say enough > about how > > impressed I am with the installation and the ease wiring it in. > > > > Noel > > Blue Sky Aviation, Inc. > > "We do builder assistance!" > > Toll Free: 866-859-0390 > > info(at)blueskyaviation.net > > www.blueskyaviation.net <http://www.blueskyaviation.net> > > > > > > -----Original Message----- > > From: owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dan > Checkoway > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: Dynon D-10 Encoder Question > > > > > > > > My understanding is that the Dynon requires an encoder INPUT, it > doesn't > > produce encoder output. I could be completely wrong. Take a look > at > > http://www.dynonavionics.com/docs/efis-d10wiring.html and you'll > see that > > "Blind encoder gray code outputs" are required. I interpret that > to mean > > "output *from* an encoder," not output *as* an encoder. > > > > I intend to confirm this with Dynon once I have the EFIS-D10 and > am wiring > > it in, assuming the installation manual doesn't make this crystal > clear. > > > > I have the Sandia SAE5-35 which seems to be one of the better > units out > > there for the price...provides both gray code and serial output > for a GPS > > (GX-60 in my case) and a transponder (GTX-320A in my case) and the > Dynon. > > Nice mechanism for quickly removing the unit from its mounting > base with > no > > tools, too. > > > > )_( Dan > > RV-7 N714D > > http://www.rvproject.com > > > > ----- Original Message ----- > > From: "LarryRobertHelming" <lhelming(at)sigecom.net> > > To: > > Subject: Re: RV-List: Dynon D-10 Encoder Question > > > > > > > > > > > Mike: From the Dynon documentation I read from the web site at > > > www.dynonavionics.com I do not see where the D10 unit performs > the > > altitude > > > encoder function. It would seem to me an external encoder would > still > be > > > needed. Some one that has installed could chime in on this > > > concern/question. > > > > > > I'd like to know if it does the encoder function that could be > output to > a > > > transponder and/or GPS. I have been looking at the Sandia > encoder for > > that > > > function. > > > . > > > Larry in Indiana, RV7 Tip-up TMX-O-360 > > > Working on Finish Kit > > > > > > Aviation in itself is not inherently dangerous. But ..... is > terribly > > > unforgiving of any carelessness, incapacity or neglect. > > > ..Author unknown > > > > > > ----- Original Message ----- > > > From: <N223RV(at)aol.com> > > > To: > > > Subject: RV-List: Dynon D-10 Encoder Question > > > > > > > > > > > > > > > > > > My Dynon D-10 is supposed to be shipped this week (FYI, I'm > order > #199). > > > I > > > > have a question about the included encoder. Is anyone flying > using > the > > > Dynon > > > > encoder? If so, how does it work (good, bad, needed > adjustment, > etc.). > > > > > > > > I am contemplating whether to keep my stand alone encoder, or > remove > it > > > and > > > > just utilize the Dynon's built in encoder. > > > > > > > > Any thoughts? > > > > > > > > Thanks > > > > Mike Kraus > > > > N223RV RV-4 Flying > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 03, 2004
Thanks to help from people on this list, and a follow-up call to Unison to confirm, it was determined that the CHT hookup is not necessary with many of Van's supplied engines. Check the model number of the Lasar controller to be sure. If it is LC1001-01, it is non CHT. I have a similar question. I fired up my Lasar equipped O-320-D1A up for the first time last week. The (optional) ennunciator light went out as soon as the engine started, but in a subsequent engine start, the light remained on, hence.....BACKUP IGNITION MODE. What do I look for to correct this? Since the engine was factory equipped with the Lasar system installed, do I still need to time it with the special LASAR timing light? Also, am I correct to assume that the mags are the impulse type? Rick Galati RV-6A "finishing" ________________________________________________________________________________
Date: Oct 03, 2004
Hi Scott, Order 2 steps. You may not need them on the -7, but on the -7A you definitely need the steps. Fly the airplane first with no trim at all. I haven't touched mine (manual), and I'm seriously thinking of taking it out and throwing it away. If you decide later that you need it, it will be just as easy to install then. Don't know about the static air. I used Vans static kit. I don't have a Dynon. Hope this helps, Dan Hopper RV-7A N766DH (Flying since 7/7/04 -- 56 fantastic hours) In a message dated 10/3/04 2:28:37 PM US Eastern Standard Time, tx_jayhawk(at)excite.com writes: > > > > All, > > Just getting ready to send in the order for the 7A fuselage kit, and I am > having trouble deciding on a few options. I searched the archives, but I > didn't really get all my questions answered. > > 1) Steps - 0, 1, or 2? - I believe I have read that there is not a real > speed penalty in adding the steps. I am also thinking it would look odd to have > just one. Current thinking is to go with two. I am about 5'11", and I am > not super worried about accomadating passengers. That being said...if there's > no speed penalty, then I guess it makes sense to add them anyway. > > 2) Aileron trim - manual vs electric - Where would the knob get located if > it were manual? Does it interfere with anything? I went manual with the > elevator. Only reason I can think to go electric is if it is logistically much > cleaner with the electric. > > 3) Static air - I installed the Gretz mount and am waiting for the never > ending Dynon heated pitot. Would I need the static kit? The plane will be IFR. > > Thanks, > Scott > 7A Wings > www.scottsrv7a.com > ________________________________________________________________________________
Subject: Bad Rivet
Date: Oct 03, 2004
I was hoping someone could help me. I just started on my RV-7A. Just finished the Horizontal stabilizer and then noticed that I had a bad rivet. The rivet is loose, but it won't come out. It's in a part that I can no longer get to the back of without drilling out a lot of rivets. If you click on a link you can see a picture of it. Does anyone have any ideas? http://kane-king.com/rv7aproject/images/BadRivet.jpg ________________________________________________________________________________
Subject: Re: Bad Rivet
Date: Oct 04, 2004
I'd drill it out and replace with a CS4-4 ( I think that's the part number... it's been 15 years since I built my RV-6). Before you paint simply put a little "bondo" in the rivit hole. As you build, keep in mind you're not building a piano.... Van told me once that you could leave out every 10th rivet and the plane would still be safe to fly. I just remembered... those rivets are 3/32nd's... so use an appropriate pop rivet of that size. John Ammeter -------------- Original message -------------- > > I was hoping someone could help me. I just started on my RV-7A. Just > finished the Horizontal stabilizer and then noticed that I had a bad rivet. > The rivet is loose, but it won't come out. It's in a part that I can no > longer get to the back of without drilling out a lot of rivets. If you click > on a link you can see a picture of it. > > Does anyone have any ideas? > > http://kane-king.com/rv7aproject/images/BadRivet.jpg > > > > > > I'd drill it out and replace with a CS4-4 ( I think that's the part number... it's been 15 years since I built my RV-6). Before you paint simply put a little "bondo" in the rivit hole. As you build, keep in mind you're not building a piano.... Van told me once that you could leave out every 10th rivet and the plane would still be safe to fly. I just remembered... those rivets are 3/32nd's... so use an appropriate pop rivet of that size. John Ammeter -------------- Original message -------------- -- RV-List message posted by: "William King" <BILL@KANE-KING.COM> I was hoping someone could help me. I just started on my RV-7A. Just finished the Horizontal stabilizer and then noticed that I had a bad rivet. The rivet is loose, but it won't come out. It's in a part that I can no longer get to the back of without drilling out a lot of rivets. If you click on a link you can see a picture of it. Does anyone have any ideas? http://kane-king.com/rv7aproject/images/BadRivet.jpg ads or any other ________________________________________________________________________________
Date: Oct 03, 2004
First off rejoice at finding it now. How embarrassing when the DAR taps on the skin and watches for dancing rivets!. Stuff a little carpet tape (double side sticky) under the head then drill it out. After clean up, put a pop rivet in. Don't worry the stub will work its way out on your initial stall tests. When I show someone how to rivet, I spend most of the time showing them how to drill out rivets. Denis On Oct 3, 2004, at 5:20 PM, William King wrote: > > I was hoping someone could help me. I just started on my RV-7A. Just > finished the Horizontal stabilizer and then noticed that I had a bad > rivet. > The rivet is loose, but it won't come out. It's in a part that I can no > longer get to the back of without drilling out a lot of rivets. If you > click > on a link you can see a picture of it. > > Does anyone have any ideas? > > http://kane-king.com/rv7aproject/images/BadRivet.jpg > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Subject: Hobbyair Quck Disconnects
Date: Oct 03, 2004
Does anyone know where I can get a quick-disconnect fitting that is compatible with those used on the HobbyAir respirator system? Thank you, Jordan Grant RV-6 Trying to paint ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Oct 03, 2004
Scott, I see in your original post that you plan to have the plane IFR. You will definitely want the aileron trim, manual is just fine. Alex Peterson Maple Grove, MN RV6-A N66AP 530 hours http://www.home.earthlink.net/~alexpeterson/ > Fly the airplane first with no trim at all. I haven't > touched mine (manual), > and I'm seriously thinking of taking it out and throwing it > away. If you > decide later that you need it, it will be just as easy to > install then. > > 2) Aileron trim - manual vs electric - Where would the knob get > > located if > > it were manual? Does it interfere with anything? I went > manual with the > > elevator. Only reason I can think to go electric is if it > is logistically much > > cleaner with the electric. > > > > 3) Static air - I installed the Gretz mount and am waiting for the > > never > > ending Dynon heated pitot. Would I need the static kit? > The plane will be IFR. > > > > Thanks, > > Scott > > 7A Wings > > www.scottsrv7a.com \ ________________________________________________________________________________
Subject: Off the shelf hardware and Spaceship One
Date: Oct 04, 2004
The Rutan boys have released videos of they're successful first X-prize launch last week. I was watching it and noticed something really cool. I heard that there was a Dynon EFIS on board but there it was in the video. So I paused the video and holy @#$% what is that. Why, its a Garmin GPS 196 on the glare shield. NASA would use a $21,000,000 custom ring laser gyro inertial system, but these guys used an off the shelf handheld GPS. Now I just wonder where they mounted the antenna. By the way, details, the video is here: http://www.scaled.com/projects/tierone/video/X-Prize-flight-1.wmv The scene where the Dynon and Garmin are visible is 1:30 into it. ________________________________________________________________________________
Date: Oct 03, 2004
Subject: Battery box - securing battery
I have a circa 1999 RV-6A kit with the Battery box in the cabin. It looks to me like the battery has to be restrained somehow or its terminals could short to the inside top of the battery battery box. The QB manual doesn't seem to mention battery installation. One could rig some sort of strap I suppose, or perhaps attach some blocks of wood or nylon to the inside of the box cover. They'd have to have just the right thickness to hold down the battery when the cover was secured. 1) What is the usual way of holding the battery out of harms way? 2) I suppose the battery cables will exit the box through large grommeted holes in the side? Is there a better/safer way to do this? Thanks. -- Tom Sargent, RV-6A ________________________________________________________________________________
Subject: Re: Battery box - securing battery
Date: Oct 04, 2004
Thomas, I believe the plans call for a couple of aluminum angle tabs that hold down the battery. One side of each tab rivets to the battery box, the other "flat" on the angle rests on top of the battery and keeps it from moving around. Your idea about using rubber grommets to protect battery cables is correct. KB ----- Original Message ----- From: "thomas a. sargent" <sarg314(at)earthlink.net> Subject: RV-List: Battery box - securing battery > > I have a circa 1999 RV-6A kit with the Battery box in the cabin. It > looks to me like the battery has to be restrained somehow or its > terminals could short to the inside top of the battery battery box. The > QB manual doesn't seem to mention battery installation. > > One could rig some sort of strap I suppose, or perhaps attach some > blocks of wood or nylon to the inside of the box cover. They'd have to > have just the right thickness to hold down the battery when the cover > was secured. > > 1) What is the usual way of holding the battery out of harms way? > > 2) I suppose the battery cables will exit the box through large > grommeted holes in the side? Is there a better/safer way to do this? > > Thanks. > > -- > Tom Sargent, RV-6A > > > ________________________________________________________________________________
Date: Oct 04, 2004
Thanks for the replies My system does have the CHT probe (LC1011-01) with a dual point "K" probe It also worked fine for the first 7-8 flights. It also "kicks in" when reset in flight as evidenced by the change in EGT's. Everything seems to work ok except that it's reverting to "backup mode" Trevor Davis ________________________________________________________________________________
Date: Oct 04, 2004
Try getting a side cutting dyke behind the head. This has worked for me. Peter > I was hoping someone could help me. I just started on my RV-7A. Just > finished the Horizontal stabilizer and then noticed that I had a bad rivet. > The rivet is loose, but it won't come out. It's in a part that I can no > longer get to the back of without drilling out a lot of rivets. If you click > on a link you can see a picture of it. > > Does anyone have any ideas? > > http://kane-king.com/rv7aproject/images/BadRivet.jpg > > ________________________________________________________________________________
Subject: Re: Off the shelf hardware and Spaceship One
Date: Oct 04, 2004
For LIVE coverage of the second attempt, tune your TV to the Science channel RIGHT been doing interviews. I watched at 2 hour program on Discovery Channel last night about the program. Robert Cutter RV4 upside down ----- Original Message ----- From: Donald Mei To: rv-list(at)matronics.com Sent: Monday, October 04, 2004 12:13 AM Subject: RV-List: Off the shelf hardware and Spaceship One The Rutan boys have released videos of they're successful first X-prize launch last week. I was watching it and noticed something really cool. I heard that there was a Dynon EFIS on board but there it was in the video. So I paused the video and holy @#$% what is that. Why, its a Garmin GPS 196 on the glare shield. NASA would use a $21,000,000 custom ring laser gyro inertial system, but these guys used an off the shelf handheld GPS. Now I just wonder where they mounted the antenna. By the way, details, the video is here: http://www.scaled.com/projects/tierone/video/X-Prize-flight-1.wmv The scene where the Dynon and Garmin are visible is 1:30 into it. ________________________________________________________________________________
Date: Oct 04, 2004
I watched that show too, it was excellent! It is on again this Thursday evening on discovery... -Bill ----- Original Message ----- From: "Robert Cutter" <rcutter(at)cupower.com> Subject: Re: RV-List: Off the shelf hardware and Spaceship One For LIVE coverage of the second attempt, tune your TV to the Science channel have been doing interviews. I watched at 2 hour program on Discovery Channel last night about the program. Robert Cutter RV4 upside down ----- Original Message ----- From: Donald Mei To: rv-list(at)matronics.com Sent: Monday, October 04, 2004 12:13 AM Subject: RV-List: Off the shelf hardware and Spaceship One The Rutan boys have released videos of they're successful first X-prize launch last week. I was watching it and noticed something really cool. I heard that there was a Dynon EFIS on board but there it was in the video. So I paused the video and holy @#$% what is that. Why, its a Garmin GPS 196 on the glare shield. NASA would use a $21,000,000 custom ring laser gyro inertial system, but these guys used an off the shelf handheld GPS. Now I just wonder where they mounted the antenna. By the way, details, the video is here: http://www.scaled.com/projects/tierone/video/X-Prize-flight-1.wmv The scene where the Dynon and Garmin are visible is 1:30 into it. ________________________________________________________________________________
Date: Oct 04, 2004
From: jim & terri truitt <jimteri1(at)earthlink.net>
Subject: RV-8 canopy
I've searched the archives on this to no avail. My 8 canopy, like everyone elses, has 1/4 to 1/2 inch opening around the bottom rear of the canopy skirt in flight, letting cold air in. My canopy skirt fits as tight as any I have seen when on the ground. All of the posts in the archives address this problem by suggesting filling the gaps with weatherstriping, or venting the tail somehow. My question is, Has anyone determined with any certainty, what causes the gap around the skirt? Is it air pressure going out, coming in, or is the canopy being pulled up by the airfoil shape? And , if the canopy is being pulled up, has anyone considered a rear canopy hold-down device to prevent the skirt from rising? I have an idea on how to hold the rear canopy down and still provide emergency egress, but I'm not sure exactly what causes the gap. If the fiberglass skirt is simply flexing outward, a hold down device won't help much. And if the problem is the skirt flexing, can the fiberglass be strenghtened to prevent the flex? I have noted some play in the fit between the nylon block and the slider track, and this does allow some upward rise in the canopy. ________________________________________________________________________________
Date: Oct 04, 2004
Subject: XP-360 Ryton plastic sump availability- was Superior XP-IO360/FF
sump question From: Jerry2DT(at)aol.com Subject: RV-List: Listers... Hey All! I'm sure I'm not the only one who would like to procure one of these sumps for use on my non-XP-360 Lycosaur. Apparently Superior has decided not to offer them on a parts basis -but only as part of a complete XP-360 engine. Well, I want one. I know Superior has to support their product owners with spares -any XP-360 owners out there willing to act as a source/middleman. Superior is gonna have to realize sooner or later that this policy is futile. If we homebuilders want something, we always find a way to get it. We have friends everywhere... Scott RV-4 N4ZW ________________________________________________________________________________
sump question
Date: Oct 04, 2004
Good Luck, Superior is keeping a REALLY tight lock on those. Tried the same thing, and basically they told the "owner" of the kit engine that if he wanted a "replacement", he'd have to send the original one back. I also asked about it at OSH and was flatly and rudely told "don't ask". Their attitude at the OSH booth was enough to make sure I won't be buying any Superior parts soon, even if they were cheaper. Turns out the ECI guys were much nicer, they parts are as good or better, and they are cheaper too - can't beat that! Now, that being said, I have it on good rumor that ECI will shortly (within a couple months) start shipping a lightweight forward facing sump for Lyc's. The difference is they decided to use Magnesium instead of plastic, and the weight is supposed to be close. I don't have any other details, other than what I heard from my ECI informants. Cheers, Stein Bruch P.S., ECI has been GREAT to deal with, and I just purchased a new ECI engine kit from Robbie Attaway for my -6. The $4,000.00 I saved over a Superior bought me a new Hartzell C/S prop!! -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bluecavu(at)aol.com Subject: RV-List: XP-360 Ryton plastic sump availability- was Superior XP-IO360/FF sump question From: Jerry2DT(at)aol.com Subject: RV-List: Listers... Hey All! I'm sure I'm not the only one who would like to procure one of these sumps for use on my non-XP-360 Lycosaur. Apparently Superior has decided not to offer them on a parts basis -but only as part of a complete XP-360 engine. Well, I want one. I know Superior has to support their product owners with spares -any XP-360 owners out there willing to act as a source/middleman. Superior is gonna have to realize sooner or later that this policy is futile. If we homebuilders want something, we always find a way to get it. We have friends everywhere... Scott RV-4 N4ZW ________________________________________________________________________________
Date: Oct 04, 2004
Hi Tom See preview drawing 48A, there is a 3/4 X 3/4 angle with 1/8 UMHW strip riveted to the inner top side of the battery box battery from shifting upwards or touching the cover. George McNutt Langley BC -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of thomas a. sargent Subject: RV-List: Battery box - securing battery I have a circa 1999 RV-6A kit with the Battery box in the cabin. It looks to me like the battery has to be restrained somehow or its terminals could short to the inside top of the battery battery box. The QB manual doesn't seem to mention battery installation. One could rig some sort of strap I suppose, or perhaps attach some blocks of wood or nylon to the inside of the box cover. They'd have to have just the right thickness to hold down the battery when the cover was secured. 1) What is the usual way of holding the battery out of harms way? 2) I suppose the battery cables will exit the box through large grommeted holes in the side? Is there a better/safer way to do this? Thanks. -- Tom Sargent, RV-6A ________________________________________________________________________________
Date: Oct 04, 2004
sump question Stein, How are you defining "rudely" here? I talked to the Superior guy at Reno this year and he was more than helpful. Of course I didn't ask him to sell me just the sump, which is one of the major selling points of the XP-360. I think I might get a little rude as well if someone asked to buy just the part that largely makes their engine unique over the others. I think anyone considering any kit engine should also check into insurance first. If you have, please give us the details. I think this is very prudent after one builder has had some recent trouble getting his New(not rebuilt) Aerosport Power engine insured. I guess it's all a matter of opinion. Ken ---------- Original Message ---------------------------------- From: "Stein Bruch" <stein(at)steinair.com> Date: Mon, 4 Oct 2004 12:13:53 -0500 > >Good Luck, > >Superior is keeping a REALLY tight lock on those. Tried the same thing, and >basically they told the "owner" of the kit engine that if he wanted a >"replacement", he'd have to send the original one back. I also asked about >it at OSH and was flatly and rudely told "don't ask". Their attitude at the >OSH booth was enough to make sure I won't be buying any Superior parts soon, >even if they were cheaper. Turns out the ECI guys were much nicer, they >parts are as good or better, and they are cheaper too - can't beat that! > >Now, that being said, I have it on good rumor that ECI will shortly (within >a couple months) start shipping a lightweight forward facing sump for Lyc's. >The difference is they decided to use Magnesium instead of plastic, and the >weight is supposed to be close. > >I don't have any other details, other than what I heard from my ECI >informants. > >Cheers, >Stein Bruch > >P.S., ECI has been GREAT to deal with, and I just purchased a new ECI engine >kit from Robbie Attaway for my -6. The $4,000.00 I saved over a Superior >bought me a new Hartzell C/S prop!! > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bluecavu(at)aol.com >To: rv-list(at)matronics.com >Subject: RV-List: XP-360 Ryton plastic sump availability- was Superior >XP-IO360/FF sump question > > >From: Jerry2DT(at)aol.com >Subject: RV-List: > > >Listers... > >Hey All! >I'm sure I'm not the only one who would like to procure one of these sumps >for use on my non-XP-360 Lycosaur. Apparently Superior has decided not to >offer >them on a parts basis -but only as part of a complete XP-360 engine. Well, I >want one. I know Superior has to support their product owners with >spares -any >XP-360 owners out there willing to act as a source/middleman. Superior is >gonna have to realize sooner or later that this policy is futile. If we >homebuilders want something, we always find a way to get it. We have friends >everywhere... > >Scott >RV-4 N4ZW > > ________________________________________________________________________________
sump question
Date: Oct 04, 2004
Hi Ken, Like you I had many past conversations with superior that were very good. So good that I was still leaning towards selecting their engine. At OSH I was still undecided about which engine; ECI or Superior to get. So, I spent time at both booths asking them to honestly tell why I should buy their engine, and please don't give me a line of "bull" because I've been working with Lyco's for years. The ECI guys approached it like this: They basically showed me the modifications they had made, and gave me some good reasons. When asked about their products verses the "other guys", they did't badmouth them at all, and in fact told me it was a good engine, but the extra few thousand $$'s didn't really buy you anything additional. When I approached the superior guys with the same method of inquiry, as soon as I mentioned ECI they started telling me what a piece of crap (quote from 2 of the guys in the booth) the ECI engine was. Now I know that's not true, I as well as MANY engine guys have been using ECI cylinders, etc... for years and I'm currently flying behind a set of ECI cylinders. That was the first turn off. A good company shouldn't have to bad mouth their competition to get business, but instead rely on the strengths of their own product. Next, I asked about buying some "parts", including the fwd facing sump, and they just basically blew me off. After they found out I knew more or as much about engines as they did, they didn't want to talk to me anymore. When pressed about their historical reliability issues with the older series Millenium cylinders, they also were quite distant and acted like it didn't exist. That also is not true, ask any long time engine shop about the older series Cylinders and you'll find most of them give you a ton of examples. Anyone who knows me can vouch that I'm not a rude and belligerent person (at least not always), and if that was the case I don't think I would have had such a drastic difference of experience between the two companies. The marketing guys seemed to treat the "Lycoming challenged" ignorant people very well (because they can), but as soon as you start mentioning their competition or asking detailed questions, they got downright defensive. In the end, I left with a very sour taste in my mouth, and not impressed with the marketing guys they had in the booth (2 of them). I know for a fact that their new engine is a good engine, as well as the ECI engine being a good one too. I was just wondering what the extra $4,000.00 bought me in a superior engine over an ECI (other than the plastic sump), and they couldn't/wouldn't tell me. If they would have done a good job, I'd be buying an SL-360 engine instead of the ECI. Good customer service means a ton to me. Regarding the insurance thing, I'll leave that to some other experts, but I think that there have been a few false rumors flying around about people "hearing about the guy......". Personally, it's not going to be a problem for me (already checked with the insurance companies), so let's just leave it at that. Maybe other people mileage will vary. Cheers, Stein Bruch RV6's, Minneapolis. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ken Simmons Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior XP-IO360/FF sump question Stein, How are you defining "rudely" here? I talked to the Superior guy at Reno this year and he was more than helpful. Of course I didn't ask him to sell me just the sump, which is one of the major selling points of the XP-360. I think I might get a little rude as well if someone asked to buy just the part that largely makes their engine unique over the others. I think anyone considering any kit engine should also check into insurance first. If you have, please give us the details. I think this is very prudent after one builder has had some recent trouble getting his New(not rebuilt) Aerosport Power engine insured. I guess it's all a matter of opinion. Ken ---------- Original Message ---------------------------------- From: "Stein Bruch" <stein(at)steinair.com> Date: Mon, 4 Oct 2004 12:13:53 -0500 > >Good Luck, > >Superior is keeping a REALLY tight lock on those. Tried the same thing, and >basically they told the "owner" of the kit engine that if he wanted a >"replacement", he'd have to send the original one back. I also asked about >it at OSH and was flatly and rudely told "don't ask". Their attitude at the >OSH booth was enough to make sure I won't be buying any Superior parts soon, >even if they were cheaper. Turns out the ECI guys were much nicer, they >parts are as good or better, and they are cheaper too - can't beat that! > >Now, that being said, I have it on good rumor that ECI will shortly (within >a couple months) start shipping a lightweight forward facing sump for Lyc's. >The difference is they decided to use Magnesium instead of plastic, and the >weight is supposed to be close. > >I don't have any other details, other than what I heard from my ECI >informants. > >Cheers, >Stein Bruch > >P.S., ECI has been GREAT to deal with, and I just purchased a new ECI engine >kit from Robbie Attaway for my -6. The $4,000.00 I saved over a Superior >bought me a new Hartzell C/S prop!! > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bluecavu(at)aol.com >To: rv-list(at)matronics.com >Subject: RV-List: XP-360 Ryton plastic sump availability- was Superior >XP-IO360/FF sump question > > >From: Jerry2DT(at)aol.com >Subject: RV-List: > > >Listers... > >Hey All! >I'm sure I'm not the only one who would like to procure one of these sumps >for use on my non-XP-360 Lycosaur. Apparently Superior has decided not to >offer >them on a parts basis -but only as part of a complete XP-360 engine. Well, I >want one. I know Superior has to support their product owners with >spares -any >XP-360 owners out there willing to act as a source/middleman. Superior is >gonna have to realize sooner or later that this policy is futile. If we >homebuilders want something, we always find a way to get it. We have friends >everywhere... > >Scott >RV-4 N4ZW > > ________________________________________________________________________________
Date: Oct 04, 2004
sump question Thanks for the reply Stein. I didn't intend my reply to be accusatory. I hope you didn't take it that way. It's just that I'm very interested in this topic because I'm close to purchasing the finish kit and engine and was leaning heavily toward the Superior with the Ryton sump. I haven't talked to the ECI guys in a while. I did talk to them at Reno last year and don't remember any impressions one way or the other. I don't remember coming away saying that's the engine I wanted. Sorry I can't be more specific than that. It's obvious now I need to seriously rethink this. I know you said lets leave it at that for the insurance, but I think that's an important part of the equation. I'm certainly no expert, but I did hear it directly from JT with the Vanguard program that the NEW Aerosport engines are not covered, yet. They are working very hard to get them on the approved list. I have no idea what their stance on kits are because I haven't asked. You've obviously found a company that will insure the kit engine. That would be good information to know. I think it would be fun and a good learning experience to build my own engine (with some good advice of course), but I don't want to do that at the expense of having an uninsurable aircraft. Thanks again for the reply and I would be very interested in insurance companies you've talked to about the kit. Ken ---------- Original Message ---------------------------------- From: "Stein Bruch" <stein(at)steinair.com> Date: Mon, 4 Oct 2004 14:32:05 -0500 > >Hi Ken, > >Like you I had many past conversations with superior that were very good. >So good that I was still leaning towards selecting their engine. At OSH I >was still undecided about which engine; ECI or Superior to get. > >So, I spent time at both booths asking them to honestly tell why I should >buy their engine, and please don't give me a line of "bull" because I've >been working with Lyco's for years. The ECI guys approached it like this: >They basically showed me the modifications they had made, and gave me some >good reasons. When asked about their products verses the "other guys", they >did't badmouth them at all, and in fact told me it was a good engine, but >the extra few thousand $$'s didn't really buy you anything additional. > >When I approached the superior guys with the same method of inquiry, as soon >as I mentioned ECI they started telling me what a piece of crap (quote from >2 of the guys in the booth) the ECI engine was. Now I know that's not true, >I as well as MANY engine guys have been using ECI cylinders, etc... for >years and I'm currently flying behind a set of ECI cylinders. That was the >first turn off. A good company shouldn't have to bad mouth their >competition to get business, but instead rely on the strengths of their own >product. Next, I asked about buying some "parts", including the fwd facing >sump, and they just basically blew me off. After they found out I knew more >or as much about engines as they did, they didn't want to talk to me >anymore. When pressed about their historical reliability issues with the >older series Millenium cylinders, they also were quite distant and acted >like it didn't exist. That also is not true, ask any long time engine shop >about the older series Cylinders and you'll find most of them give you a ton >of examples. > >Anyone who knows me can vouch that I'm not a rude and belligerent person (at >least not always), and if that was the case I don't think I would have had >such a drastic difference of experience between the two companies. The >marketing guys seemed to treat the "Lycoming challenged" ignorant people >very well (because they can), but as soon as you start mentioning their >competition or asking detailed questions, they got downright defensive. > >In the end, I left with a very sour taste in my mouth, and not impressed >with the marketing guys they had in the booth (2 of them). I know for a >fact that their new engine is a good engine, as well as the ECI engine being >a good one too. I was just wondering what the extra $4,000.00 bought me in >a superior engine over an ECI (other than the plastic sump), and they >couldn't/wouldn't tell me. If they would have done a good job, I'd be >buying an SL-360 engine instead of the ECI. Good customer service means a >ton to me. > >Regarding the insurance thing, I'll leave that to some other experts, but I >think that there have been a few false rumors flying around about people >"hearing about the guy......". Personally, it's not going to be a problem >for me (already checked with the insurance companies), so let's just leave >it at that. Maybe other people mileage will vary. > >Cheers, >Stein Bruch >RV6's, Minneapolis. > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ken Simmons >To: rv-list(at)matronics.com >Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was >Superior XP-IO360/FF sump question > > >Stein, > >How are you defining "rudely" here? I talked to the Superior guy at Reno >this year and he was more than helpful. Of course I didn't ask him to sell >me just the sump, which is one of the major selling points of the XP-360. I >think I might get a little rude as well if someone asked to buy just the >part that largely makes their engine unique over the others. > >I think anyone considering any kit engine should also check into insurance >first. If you have, please give us the details. I think this is very prudent >after one builder has had some recent trouble getting his New(not rebuilt) >Aerosport Power engine insured. > >I guess it's all a matter of opinion. > >Ken > > >---------- Original Message ---------------------------------- >From: "Stein Bruch" <stein(at)steinair.com> >Date: Mon, 4 Oct 2004 12:13:53 -0500 > >> >>Good Luck, >> >>Superior is keeping a REALLY tight lock on those. Tried the same thing, and >>basically they told the "owner" of the kit engine that if he wanted a >>"replacement", he'd have to send the original one back. I also asked about >>it at OSH and was flatly and rudely told "don't ask". Their attitude at >the >>OSH booth was enough to make sure I won't be buying any Superior parts >soon, >>even if they were cheaper. Turns out the ECI guys were much nicer, they >>parts are as good or better, and they are cheaper too - can't beat that! >> >>Now, that being said, I have it on good rumor that ECI will shortly (within >>a couple months) start shipping a lightweight forward facing sump for >Lyc's. >>The difference is they decided to use Magnesium instead of plastic, and the >>weight is supposed to be close. >> >>I don't have any other details, other than what I heard from my ECI >>informants. >> >>Cheers, >>Stein Bruch >> >>P.S., ECI has been GREAT to deal with, and I just purchased a new ECI >engine >>kit from Robbie Attaway for my -6. The $4,000.00 I saved over a Superior >>bought me a new Hartzell C/S prop!! >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bluecavu(at)aol.com >>To: rv-list(at)matronics.com >>Subject: RV-List: XP-360 Ryton plastic sump availability- was Superior >>XP-IO360/FF sump question >> >> >> >>From: Jerry2DT(at)aol.com >>Subject: RV-List: >> >> >> >>Listers... >> >>Hey All! >>I'm sure I'm not the only one who would like to procure one of these sumps >>for use on my non-XP-360 Lycosaur. Apparently Superior has decided not to >>offer >>them on a parts basis -but only as part of a complete XP-360 engine. Well, >I >>want one. I know Superior has to support their product owners with >>spares -any >>XP-360 owners out there willing to act as a source/middleman. Superior is >>gonna have to realize sooner or later that this policy is futile. If we >>homebuilders want something, we always find a way to get it. We have >friends >>everywhere... >> >>Scott >>RV-4 N4ZW >> >> > > ________________________________________________________________________________
Date: Oct 04, 2004
Subject: propeller for sale
70cm-78 sensenich propeller for sale less than 200 hrs. complete with spinner, spacer, bolts, and plates. For a lycoming 0-320 160 hp. $1500 like new 803-663-9974 Jerry Berger south carolina ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Harness shootout - Hooker vs. Schroth
Hi, I'm trying to decide on the seat belts I'll use on my RV8, and the Hooker and the Schroth are on my short list. The Hooker w/rotary buckle (340USD/seat) is much cheaper than the Schroth (470USD front, 495USD rear). Though I almost never try to economize on safety, I'm trying to figure out why the Schroth is so much more. If they are better/safer, I'll buy them, but it's not clear to me that that is the case. Anyone have any info on this? http://www.karasengineering.com/Experimental%20List%20page.htm http://www.hookerharness.com/price_list.htm Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Subject: Re: XP-360 Ryton plastic sump availability- was Superior XP-IO360/FF
sump question
Date: Oct 04, 2004
I keep seeing a $4000 dollar difference being mentioned between the Superior and the ECI? I'm not finding this difference in their quoted prices. What gives? ----- Original Message ----- From: "Stein Bruch" <stein(at)steinair.com> Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior XP-IO360/FF sump question > > Hi Ken, > > Like you I had many past conversations with superior that were very good. > So good that I was still leaning towards selecting their engine. At OSH I > was still undecided about which engine; ECI or Superior to get. > > So, I spent time at both booths asking them to honestly tell why I should > buy their engine, and please don't give me a line of "bull" because I've > been working with Lyco's for years. The ECI guys approached it like this: > They basically showed me the modifications they had made, and gave me some > good reasons. When asked about their products verses the "other guys", they > did't badmouth them at all, and in fact told me it was a good engine, but > the extra few thousand $$'s didn't really buy you anything additional. > > When I approached the superior guys with the same method of inquiry, as soon > as I mentioned ECI they started telling me what a piece of crap (quote from > 2 of the guys in the booth) the ECI engine was. Now I know that's not true, > I as well as MANY engine guys have been using ECI cylinders, etc... for > years and I'm currently flying behind a set of ECI cylinders. That was the > first turn off. A good company shouldn't have to bad mouth their > competition to get business, but instead rely on the strengths of their own > product. Next, I asked about buying some "parts", including the fwd facing > sump, and they just basically blew me off. After they found out I knew more > or as much about engines as they did, they didn't want to talk to me > anymore. When pressed about their historical reliability issues with the > older series Millenium cylinders, they also were quite distant and acted > like it didn't exist. That also is not true, ask any long time engine shop > about the older series Cylinders and you'll find most of them give you a ton > of examples. > > Anyone who knows me can vouch that I'm not a rude and belligerent person (at > least not always), and if that was the case I don't think I would have had > such a drastic difference of experience between the two companies. The > marketing guys seemed to treat the "Lycoming challenged" ignorant people > very well (because they can), but as soon as you start mentioning their > competition or asking detailed questions, they got downright defensive. > > In the end, I left with a very sour taste in my mouth, and not impressed > with the marketing guys they had in the booth (2 of them). I know for a > fact that their new engine is a good engine, as well as the ECI engine being > a good one too. I was just wondering what the extra $4,000.00 bought me in > a superior engine over an ECI (other than the plastic sump), and they > couldn't/wouldn't tell me. If they would have done a good job, I'd be > buying an SL-360 engine instead of the ECI. Good customer service means a > ton to me. > > Regarding the insurance thing, I'll leave that to some other experts, but I > think that there have been a few false rumors flying around about people > "hearing about the guy......". Personally, it's not going to be a problem > for me (already checked with the insurance companies), so let's just leave > it at that. Maybe other people mileage will vary. > > Cheers, > Stein Bruch > RV6's, Minneapolis. > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ken Simmons > To: rv-list(at)matronics.com > Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was > Superior XP-IO360/FF sump question > > > Stein, > > How are you defining "rudely" here? I talked to the Superior guy at Reno > this year and he was more than helpful. Of course I didn't ask him to sell > me just the sump, which is one of the major selling points of the XP-360. I > think I might get a little rude as well if someone asked to buy just the > part that largely makes their engine unique over the others. > > I think anyone considering any kit engine should also check into insurance > first. If you have, please give us the details. I think this is very prudent > after one builder has had some recent trouble getting his New(not rebuilt) > Aerosport Power engine insured. > > I guess it's all a matter of opinion. > > Ken > > > ---------- Original Message ---------------------------------- > From: "Stein Bruch" <stein(at)steinair.com> > Date: Mon, 4 Oct 2004 12:13:53 -0500 > > > > >Good Luck, > > > >Superior is keeping a REALLY tight lock on those. Tried the same thing, and > >basically they told the "owner" of the kit engine that if he wanted a > >"replacement", he'd have to send the original one back. I also asked about > >it at OSH and was flatly and rudely told "don't ask". Their attitude at > the > >OSH booth was enough to make sure I won't be buying any Superior parts > soon, > >even if they were cheaper. Turns out the ECI guys were much nicer, they > >parts are as good or better, and they are cheaper too - can't beat that! > > > >Now, that being said, I have it on good rumor that ECI will shortly (within > >a couple months) start shipping a lightweight forward facing sump for > Lyc's. > >The difference is they decided to use Magnesium instead of plastic, and the > >weight is supposed to be close. > > > >I don't have any other details, other than what I heard from my ECI > >informants. > > > >Cheers, > >Stein Bruch > > > >P.S., ECI has been GREAT to deal with, and I just purchased a new ECI > engine > >kit from Robbie Attaway for my -6. The $4,000.00 I saved over a Superior > >bought me a new Hartzell C/S prop!! > > > >-----Original Message----- > >From: owner-rv-list-server(at)matronics.com > >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bluecavu(at)aol.com > >To: rv-list(at)matronics.com > >Subject: RV-List: XP-360 Ryton plastic sump availability- was Superior > >XP-IO360/FF sump question > > > > > > > >From: Jerry2DT(at)aol.com > >Subject: RV-List: > > > > > > > >Listers... > > > >Hey All! > >I'm sure I'm not the only one who would like to procure one of these sumps > >for use on my non-XP-360 Lycosaur. Apparently Superior has decided not to > >offer > >them on a parts basis -but only as part of a complete XP-360 engine. Well, > I > >want one. I know Superior has to support their product owners with > >spares -any > >XP-360 owners out there willing to act as a source/middleman. Superior is > >gonna have to realize sooner or later that this policy is futile. If we > >homebuilders want something, we always find a way to get it. We have > friends > >everywhere... > > > >Scott > >RV-4 N4ZW > > > > > > ________________________________________________________________________________
Subject: Fuel Pressure
Date: Oct 04, 2004
I checked the archives did not find the answer. My fuel pressure varies between 6 and 0 with no consistency. Why does it do this and should I be doing something about it? Thanks, John Furey RV6A O-320 ________________________________________________________________________________
sump question
Date: Oct 04, 2004
sump question
Date: Oct 04, 2004
Ken - I have seen your recent thread on engine selection for your RV and wanted to invite you to our website, www.bpaengines.com, to look at Lycoming's IO-390-X kit engine. We are the sole supplier of this engine and have sold several to the RV crowd, with excellent feedback. Dick Martin has one in his RV-8 and loves the 210 hp. Please feel free to drop us a note or give us a call if you'd like any additional information. Regards, Allen Barrett Barrett Performance Aircraft, Inc. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ken Simmons Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior XP-IO360/FF sump question Thanks for the reply Stein. I didn't intend my reply to be accusatory. I hope you didn't take it that way. It's just that I'm very interested in this topic because I'm close to purchasing the finish kit and engine and was leaning heavily toward the Superior with the Ryton sump. I haven't talked to the ECI guys in a while. I did talk to them at Reno last year and don't remember any impressions one way or the other. I don't remember coming away saying that's the engine I wanted. Sorry I can't be more specific than that. It's obvious now I need to seriously rethink this. I know you said lets leave it at that for the insurance, but I think that's an important part of the equation. I'm certainly no expert, but I did hear it directly from JT with the Vanguard program that the NEW Aerosport engines are not covered, yet. They are working very hard to get them on the approved list. I have no idea what their stance on kits are because I haven't asked. You've obviously found a company that will insure the kit engine. That would be good information to know. I think it would be fun and a good learning experience to build my own engine (with some good advice of course), but I don't want to do that at the expense of having an uninsurable aircraft. Thanks again for the reply and I would be very interested in insurance companies you've talked to about the kit. Ken ---------- Original Message ---------------------------------- From: "Stein Bruch" <stein(at)steinair.com> Date: Mon, 4 Oct 2004 14:32:05 -0500 > >Hi Ken, > >Like you I had many past conversations with superior that were very good. >So good that I was still leaning towards selecting their engine. At OSH I >was still undecided about which engine; ECI or Superior to get. > >So, I spent time at both booths asking them to honestly tell why I should >buy their engine, and please don't give me a line of "bull" because I've >been working with Lyco's for years. The ECI guys approached it like this: >They basically showed me the modifications they had made, and gave me some >good reasons. When asked about their products verses the "other guys", they >did't badmouth them at all, and in fact told me it was a good engine, but >the extra few thousand $$'s didn't really buy you anything additional. > >When I approached the superior guys with the same method of inquiry, as soon >as I mentioned ECI they started telling me what a piece of crap (quote from >2 of the guys in the booth) the ECI engine was. Now I know that's not true, >I as well as MANY engine guys have been using ECI cylinders, etc... for >years and I'm currently flying behind a set of ECI cylinders. That was the >first turn off. A good company shouldn't have to bad mouth their >competition to get business, but instead rely on the strengths of their own >product. Next, I asked about buying some "parts", including the fwd facing >sump, and they just basically blew me off. After they found out I knew more >or as much about engines as they did, they didn't want to talk to me >anymore. When pressed about their historical reliability issues with the >older series Millenium cylinders, they also were quite distant and acted >like it didn't exist. That also is not true, ask any long time engine shop >about the older series Cylinders and you'll find most of them give you a ton >of examples. > >Anyone who knows me can vouch that I'm not a rude and belligerent person (at >least not always), and if that was the case I don't think I would have had >such a drastic difference of experience between the two companies. The >marketing guys seemed to treat the "Lycoming challenged" ignorant people >very well (because they can), but as soon as you start mentioning their >competition or asking detailed questions, they got downright defensive. > >In the end, I left with a very sour taste in my mouth, and not impressed >with the marketing guys they had in the booth (2 of them). I know for a >fact that their new engine is a good engine, as well as the ECI engine being >a good one too. I was just wondering what the extra $4,000.00 bought me in >a superior engine over an ECI (other than the plastic sump), and they >couldn't/wouldn't tell me. If they would have done a good job, I'd be >buying an SL-360 engine instead of the ECI. Good customer service means a >ton to me. > >Regarding the insurance thing, I'll leave that to some other experts, but I >think that there have been a few false rumors flying around about people >"hearing about the guy......". Personally, it's not going to be a problem >for me (already checked with the insurance companies), so let's just leave >it at that. Maybe other people mileage will vary. > >Cheers, >Stein Bruch >RV6's, Minneapolis. > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ken Simmons >To: rv-list(at)matronics.com >Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was >Superior XP-IO360/FF sump question > > >Stein, > >How are you defining "rudely" here? I talked to the Superior guy at Reno >this year and he was more than helpful. Of course I didn't ask him to sell >me just the sump, which is one of the major selling points of the XP-360. I >think I might get a little rude as well if someone asked to buy just the >part that largely makes their engine unique over the others. > >I think anyone considering any kit engine should also check into insurance >first. If you have, please give us the details. I think this is very prudent >after one builder has had some recent trouble getting his New(not rebuilt) >Aerosport Power engine insured. > >I guess it's all a matter of opinion. > >Ken > > >---------- Original Message ---------------------------------- >From: "Stein Bruch" <stein(at)steinair.com> >Date: Mon, 4 Oct 2004 12:13:53 -0500 > >> >>Good Luck, >> >>Superior is keeping a REALLY tight lock on those. Tried the same thing, and >>basically they told the "owner" of the kit engine that if he wanted a >>"replacement", he'd have to send the original one back. I also asked about >>it at OSH and was flatly and rudely told "don't ask". Their attitude at >the >>OSH booth was enough to make sure I won't be buying any Superior parts >soon, >>even if they were cheaper. Turns out the ECI guys were much nicer, they >>parts are as good or better, and they are cheaper too - can't beat that! >> >>Now, that being said, I have it on good rumor that ECI will shortly (within >>a couple months) start shipping a lightweight forward facing sump for >Lyc's. >>The difference is they decided to use Magnesium instead of plastic, and the >>weight is supposed to be close. >> >>I don't have any other details, other than what I heard from my ECI >>informants. >> >>Cheers, >>Stein Bruch >> >>P.S., ECI has been GREAT to deal with, and I just purchased a new ECI >engine >>kit from Robbie Attaway for my -6. The $4,000.00 I saved over a Superior >>bought me a new Hartzell C/S prop!! >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bluecavu(at)aol.com >>To: rv-list(at)matronics.com >>Subject: RV-List: XP-360 Ryton plastic sump availability- was Superior >>XP-IO360/FF sump question >> >> >> >>From: Jerry2DT(at)aol.com >>Subject: RV-List: >> >> >> >>Listers... >> >>Hey All! >>I'm sure I'm not the only one who would like to procure one of these sumps >>for use on my non-XP-360 Lycosaur. Apparently Superior has decided not to >>offer >>them on a parts basis -but only as part of a complete XP-360 engine. Well, >I >>want one. I know Superior has to support their product owners with >>spares -any >>XP-360 owners out there willing to act as a source/middleman. Superior is >>gonna have to realize sooner or later that this policy is futile. If we >>homebuilders want something, we always find a way to get it. We have >friends >>everywhere... >> >>Scott >>RV-4 N4ZW >> >> > > ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Re: alternators
Suzuki Samari alternator, 55 amps, lifetime warranty. Autozone. Go online and save $30. I paid $96 plus $50 core charge delivered. Wally Hunt RV-4 Finishing Kit ________________________________________________________________________________
Subject: Re: Fuel Pressure
Date: Oct 04, 2004
I would check the suction side of the fuel system. ----- Original Message ----- From: "John Furey" <john(at)fureychrysler.com> Subject: RV-List: Fuel Pressure > > I checked the archives did not find the answer. My fuel pressure varies > between 6 and 0 with no consistency. Why does it do this and should I be > doing something about it? > > Thanks, > John Furey RV6A O-320 > > ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Re: Harness shootout - Hooker vs. Schroth
You might want to check out crow harness. Here is a link. I have not used them but it looks like an interesting option. http://www.magnumforceracing.com/crowharness.asp Dale --- Mickey Coggins wrote: > > > Hi, > > I'm trying to decide on the seat belts I'll use on > my RV8, > and the Hooker and the Schroth are on my short list. > > > The Hooker w/rotary buckle (340USD/seat) is much > cheaper > than the Schroth (470USD front, 495USD rear). > Though > I almost never try to economize on safety, I'm > trying to > figure out why the Schroth is so much more. If they > are > better/safer, I'll buy them, but it's not clear to > me > that that is the case. Anyone have any info on > this? > > http://www.karasengineering.com/Experimental%20List%20page.htm > > http://www.hookerharness.com/price_list.htm > > Thanks, > Mickey > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 QB Wings/Fuselage > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
Subject: re: insurance
Date: Oct 04, 2004
I've personally been told by my agent at NationAir that my aircraft would not be covered with the SL engine, but the XP is fine. Lycomings are fine also. Whether or not the ECI is covered is up to the insurer, whoever that might be. I did not hear this from a guy who heard it from a guy, etc. , but rather, first hand from my agent. I am certainly not claiming one engine to be better than another, but unfortuntely the insurance companies are making the rules here. Therefore we really should consult with them BEFORE the fact. One more point: I don't think the law compels a person to insure their aircraft, but if it's held as collateral on a loan the bank will require full coverage. ________________________________________________________________________________
Date: Oct 04, 2004
Hi Mickey, We have Hooker's 5 point with the schroth buckle. Great belts and Hooker has been great to deal with when we asked them to change the pad colors. We purchased them from team rocket and they were considerably less expensive than the ones from Schroth. I agree with you about not short changing yourself on safety. Chuck Rowbotham RV-8A (300+hours) >From: Mickey Coggins <mick-matronics(at)rv8.ch> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Harness shootout - Hooker vs. Schroth >Date: Mon, 04 Oct 2004 22:20:01 +0200 > > >Hi, > >I'm trying to decide on the seat belts I'll use on my RV8, >and the Hooker and the Schroth are on my short list. > >The Hooker w/rotary buckle (340USD/seat) is much cheaper >than the Schroth (470USD front, 495USD rear). Though >I almost never try to economize on safety, I'm trying to >figure out why the Schroth is so much more. If they are >better/safer, I'll buy them, but it's not clear to me >that that is the case. Anyone have any info on this? > >http://www.karasengineering.com/Experimental%20List%20page.htm > >http://www.hookerharness.com/price_list.htm > >Thanks, >Mickey > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > ________________________________________________________________________________
Subject: I've finally got my XCOM 760 Radio
Date: Oct 04, 2004
John, How's the radio holding out? Anyone else get one of these? ----Original Message Follows---- From: <John.Morrissey(at)csiro.au> Subject: RV-List: I've finally got my XCOM 760 Radio Date: Wed, 1 Sep 2004 07:11:15 +1000 Hi All, When I got home last night I was pleased to see that my XCOM 760 radio had finally arrived (Serial Number 16). Despite the late hour I hade the unit hooked up to my base station aerial within an hour or two and all appears well. Had a couple of conversations with a couple of late night commuters and they reported good reception. I found the controls to be reasonably logical and easy to use. Off to the plane on the weekend for some air trials. Cheers John Morrissey Check out Election 2004 for up-to-date election news, plus voter tools and ________________________________________________________________________________
Subject: Re: Superior XP-IO360/FF sump question
Date: Oct 05, 2004
Jerry, I replied off list , directly to your address , with my installation of the throttle mechanism as you requested. The EMail was returned undelivered. I have several photos of the installation as well as a crude drawing of the mechanism which you may be interested in. Can you give me a working EMail or Snail Mail address ? Best wishes, Dick Jordan RV8A Finishing ----- Original Message ----- From: <Jerry2DT(at)aol.com> Subject: RV-List: Superior XP-IO360/FF sump question > > > Listers... > > I have a Superior XP-IO360 with the new Ryton plastic forward facing sump. > If anyone has the same setup, and has pix to share, I would be curious to see > where/how the bracket for throttle cable was mounted. Van's bracket doesn't > seem to fit. Email off list if you wish at _jerry2dt(at)aol.com_ > (mailto:jerry2dt(at)aol.com) . > > Thanx. > > Jerry Cochran > > ________________________________________________________________________________
Date: Oct 04, 2004
Terry Williams wrote: > > I could be wrong, but this doesn't look like anything that is available > from Dynon. Maybe you know different. Dynon hasn't admitted anything > about being a part of the Tier-One project. I believe they have: http://www.dynondevelopment.com/docs/spacenews1.html Sam Buchanan ________________________________________________________________________________
sump question
Date: Oct 04, 2004
Well, during my recent search for an engine, the cheapest I could find a Superior engine was around $19-22+K range. ECI had a special at OSH with engines starting at about $13-15K, and yes you also can get the ECI engines assembled for next to nothing with the same warranties as the superior engines. I'm building up my own, but for those choosing a pre-built engine, they still come out cheaper, even with the accessories and warranties. Once again, I'm not bashing the superior engine, just a few of their marketing folks - Their engine is a fine engine, and I have nothing ill to say about the engine (only the company/people). Cheers, Stein. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of steve zicree Subject: Re: RV-List: XP-360 Ryton plastic sump availability- was Superior XP-IO360/FF sump question I keep seeing a $4000 dollar difference being mentioned between the Superior and the ECI? I'm not finding this difference in their quoted prices. What gives? ________________________________________________________________________________
Date: Oct 04, 2004
It appears to me that a dynon is mounted up high above the primary flight display. I pointed this out to my wife last night while watching the 2 hour special on Discovery. I don't think this was there on Melville's first flight before Oshkosh when the primary display blinked out. GZ Sam Buchanan wrote: > >Terry Williams wrote: > > >> >>I could be wrong, but this doesn't look like anything that is available >>from Dynon. Maybe you know different. Dynon hasn't admitted anything >>about being a part of the Tier-One project. >> >> > > >I believe they have: > >http://www.dynondevelopment.com/docs/spacenews1.html > >Sam Buchanan > > > > ________________________________________________________________________________
sump question
Date: Oct 04, 2004
Stein, sometimes sales reps like that are a blessing in disguise if a certain fast glass co. in Oregon didn't have a couple of reps like that at OSH in '99 I would be on a different list. I'm glad I'm here. Jim Thorne 7A-QB CHD ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Cement rubber to canopy
hello all, I want to cement a rubber moulding to the front of my slider canopy (RV-8) to make a rain seal. What glue is available that won't craze the plastic? Since its a quickbuild I didn't need Proseal and don't have any about the shop. Jim Bean "Finishing" ________________________________________________________________________________
Date: Oct 04, 2004
John Furey wrote: > I checked the archives did not find the answer. My fuel pressure varies > between 6 and 0 with no consistency. Why does it do this and should I be > doing something about it? Two possibilities: A sensor/gauge problem, or a real fuel pressure problem. A lot of people here (myself included) have noticed fuel pressure fluctuations while maneuvering. Sandy at Grand Rapids, who supplied my pressure transducer, told me I could fix this by opening up the transducer vent (what she said was more along the lines of "punch some holes in the white stuff behind the vent screen." I did this and don't really see a difference. My biggest fuel pressure fluctuations were apparently temperature related - I had a fuel line run too close to an exhaust pipe. I'd regularly see fuel pressure vary from 5 to 0 psi with no change in engine operation (electric fuel pump off). Turning the electric pump on would steady it out at ~4 psi. I moved the fuel line by bypassing the gascolator(*) and it's now steady at 4-5psi electric pump on or off unless I'm maneuvering, when it still drops as low as zero (the engine keeps running) unless the boost pump is on. The engine runs steady (well, aside from the bad mag someone *finally* found) regardless of fuel pressure indications. (*) I think it's temperature related, not gascolator related, but bypassing the gascolator was the only way I could stay well clear of the exhaust given the amazingly small firewall space available on my RV-4. Hope this helps, Dave Hyde nauga(at)brick.net RV-4 in flight test, mechanic says it's 'up' again. ________________________________________________________________________________
Subject: Fuselage Order Follow-up
Date: Oct 04, 2004
All, As a follow-up to my earlier question...would anyone be able to point me to or send me a picture of the manual aileron and manual flap controls? I'm still trying to visualize what they look like and where they are located. Thanks in advance, Scott 7A Wings www.scottsrv7a.com Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Subject: Insurance Rates
Date: Oct 04, 2004
All, I just got a quote back from Falcon, and I thought I would share it for any interested. Details as follows: - RV7A - $60,000 hull value - $0 Motion, $0 Not-in-motion deductibles - 1,000,000/100,000 Liability - Total premium - $1,776/yr I am instrument rated and have 300 hrs TT (0 make and model). THanks, Scott www.scottsrv7a.com Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Date: Oct 04, 2004
Subject: Re: Fuselage Order Follow-up
tx_jayhawk(at)excite.com wrote: > > > All, > > As a follow-up to my earlier question...would anyone be able to point > me to or send me a picture of the manual aileron and manual flap > controls? I'm still trying to visualize what they look like and > where they are located. Scott, check out the last two photos on this page for the manual aileron trim system: http://home.hiwaay.net/~sbuc/journal/fuse9.html The trim works perfectly and contrary to what you might think, the springs don't alter the feel of the ailerons. And here are the manual flaps (mid-page): http://home.hiwaay.net/~sbuc/journal/fuse7.html In this case, the electric system is superior to the manual flaps. Sam Buchanan ________________________________________________________________________________
Date: Oct 05, 2004
Subject: New/Used Propeller page added to website
Hi All, I've added a new page on my website for new and used propellers being offered for sale. If you have a propeller you would like to sell; just send me an Email of what you want listed. If you are looking for a propeller, you can check the propeller page just after antenna's under Products. There is already an overhauled Hartzell CS propeller for a Lycoming 320 and a new Hartzell CS propeller for a Lycoming 360 listed. _www.lessdrag.com_ (http://www.lessdrag.com/) Regards, Jim Ayers Less Drag products, Inc. ________________________________________________________________________________
Subject: Re: RV-8 canopy
Date: Oct 05, 2004
Hi Jim, I believe the problem is due to air not moving from front to back through the entire fuselage. Some how the air backs up around the aft area of the canopy, then lift produced by the canopy creates a low pressure area and there is a tendency to lift the canopy at the back. Early on I devised a set of louvers that I installed on each aft fuselage inspection panels and I have never had a problem since I started flying Cappy=92s Toy. The louvers were stainless steel purchased form West Marine. They fit perfectly and I just riveted them to the inspection panels and later painted them. Steve Glasgow RV 8, N123GS, Cappy's Toy 140 Hours ________________________________________________________________________________
Date: Oct 05, 2004
> -----Original Message----- > From: "" <tx_jayhawk(at)excite.com> > To: rv-list(at)matronics.com > Date: Mon, 4 Oct 2004 23:09 (CDT) > Subject: RV-List: Fuselage Order Follow-up > > > > All, > > As a follow-up to my earlier question...would anyone be able to point me to > or send me a picture of the manual aileron and manual flap controls? I'm > still trying to visualize what they look like and where they are located. > > Thanks in advance, > Scott > 7A Wings > www.scottsrv7a.com > Since your building a 7A I thought you might mean manual elevator trim not flaps. If so go here: http://members.hopkinsville.net/bhester/FuseAssyPg4.htm ------- Surfing the web from Hopkinsville, KY RV7A web site: http://www.geocities.com/hester-hoptown/RVSite ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Off Topic - XPrize
Hi, Has anyone seen a number for what it would cost to build a second SpaceShipOne and a second White Knight, now that the investment in R&D has been done? Also, what does it cost in fuel and other consumables for each flight? Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Oct 05, 2004
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Talked to the winning biplane racer guy at Reno air races, he said to make sure you have no air flowing through the fuse. Seal up the entire fuse as best as possible. I think this is a better idea than letting the air out. Just the opposite of the previous post, both ideas will work, take your pick. > >Hi Jim, > > >I believe the problem is due to air not moving from front to back through >the entire fuselage. Some how the air backs up around the aft area of the >canopy, then lift produced by the canopy creates a low pressure area and >there is a tendency to lift the canopy at the back. > > >Early on I devised a set of louvers that I installed on each aft fuselage >inspection panels and I have never had a problem since I started flying >Cappy=92s Toy. The louvers were stainless steel purchased form West >Marine. They fit perfectly and I just riveted them to the inspection >panels and later painted them. > > >Steve Glasgow > >RV 8, N123GS, Cappy's Toy > >140 Hours > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Subject: Re: Off Topic - XPrize
Date: Oct 05, 2004
The only comment I heard was that a "commerical" verison is allready under construction and would be the one that Rutan & Allen, and anyone with the big bucks, would ride in. Nothing said if a "new" White Knight would have to be built to launch the larger, roomier Spaceship II. No prices was quoted. KABONG ----- Original Message ----- From: "Mickey Coggins" <mick-matronics(at)rv8.ch> Subject: RE: RV-List: Off Topic - XPrize > > Hi, > > Has anyone seen a number for what it would cost to build > a second SpaceShipOne and a second White Knight, now that > the investment in R&D has been done? Also, what does it > cost in fuel and other consumables for each flight? > > Thanks, > Mickey > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 QB Wings/Fuselage > > > ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Re: Insurance Rates
tx_jayhawk(at)excite.com wrote: > > > All, > > I just got a quote back from Falcon, and I thought I would share it for any interested. Details as follows: > > - RV7A > - $60,000 hull value > - $0 Motion, $0 Not-in-motion deductibles > - 1,000,000/100,000 Liability > - Total premium - $1,776/yr > > I am instrument rated and have 300 hrs TT (0 make and model). > Another option that apparently is not known to all RV builders is GIM and GRIM. Ground in Motion coverage provides liability and medical at all times but the hull coverage ceases once the aircraft rolls onto the active runway. Ground Not in Motion coverage includes liability and medical at all times but hull coverage ceases once the engine starts. I have used Ground Not in Motion coverage for several years since my main concern is protection of the RV while it is parked (wind, fire, theft, vandalism, hangar collapse, etc). I figure that if I ball up the RV either the incident will be so severe that I won't be around to consider the consequences or if the incident is not as dire, I am willing to accept the responsibility for my goof and will want to repair the aircraft myself. GIM and GNIM carry premiums that are much less than full hull coverage. These options are worth considering for the owner who is willing to self-insure the hull. I am not an insurance agent or expert; your agent can give you more info on these matters. Sam Buchanan ________________________________________________________________________________
Date: Oct 05, 2004
JOHN STARN wrote: > > Wonder who got the "repairman's certificate" ?. 8*) KABONG > > >>I'm just guessing on the costs. But it's refreshing to be looking at so >>few >>zeros and also to know it's an.... EXPERIMENTAL!!!!!! What I'm wondering is how they intend to deal with the "non-commercial" (no paying passengers) aspect of experimental aircraft. :-) Sam Buchanan ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Log Book Entries
What is a good reference for various log book entries? What should (and shouldn't) be annotated in each log book? Format? Examples? Etc... Thx, - Larry Bowen, RV-8 5.2 hrs Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Subject: AWM
Date: Oct 05, 2004
Doug, I would add that the AWM 12V Cig connector is about as cheap as they come. Little plastic tang inside failed allowing internal +12v spring to slide back into the V-reg circuit board causing direct short. Case was glued shut, so the repairability was marginal. Connector into IPAQ is also very weak, and needs to be properly supported. Broke two until I figured out how to support this with a tang in back of connector riveted to the bottom of the RAM mount. W ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Re: Sectional Wallpaper
Tedd McHenry wrote: > > Dana: > > I don't know about sectional wallpaper, but you might see if you can get > yourself some JNCs (Jet Navigation Charts). These are 1:2,000,000 charts that > are about 42" by 58", and cover large areas. For example, JNC 43 covers > western North America from the Baja peninsula to the tip of Vancouver Island. > Three JNCs cover all of the continental U.S.A., plus part of Mexico and Canada > (JNC 43, 44, and 45, I think). That would cover an area about 100" wide and > 60" tall. > > I don't know if anybody other than the military uses them, but if you have any > Air Force or Navy contacts they might be able to get you some. The large (57" x 120") inexpensive JNC's are available from Builders Bookstore: http://www.pilotsbooks.com/wallcharts.htm I applied the largest JNC to our hangar wall with wallpaper paste. The same could be done with sectionals. Matching up the borders is a little tedious but definitely possible. Sam Buchanan ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Magnesium sump? No thanx.
Stein, Regarding the possible use of a magnesium sump, I'd be wary because of the extreme flamability of magnesium. Picture this, you get a fuel leak inside the cowling, hits some of those 1400 deg. pipes, instant fire. You, being mentally prepared for this ugly possibility, shut off the fuel, expecting fire to go out shortly, while preparing for an engine out landing. Trouble is, now the magnesium is burning with intensity while getting plenty of oxygen, and no chance it'll go out. This is the stuff we used to make incindiary bombs from. Mr. Google tells me it burns at 1335c/2435f. What am I missing here? Jerry Cochran From: "Stein Bruch" <stein(at)steinair.com> Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior XP-IO360/FF sump question Good Luck, Superior is keeping a REALLY tight lock on those. Tried the same thing, and basically they told the "owner" of the kit engine that if he wanted a "replacement", he'd have to send the original one back. I also asked about it at OSH and was flatly and rudely told "don't ask". Their attitude at the OSH booth was enough to make sure I won't be buying any Superior parts soon, even if they were cheaper. Turns out the ECI guys were much nicer, they parts are as good or better, and they are cheaper too - can't beat that! Now, that being said, I have it on good rumor that ECI will shortly (within a couple months) start shipping a lightweight forward facing sump for Lyc's. The difference is they decided to use Magnesium instead of plastic, and the weight is supposed to be close. I don't have any other details, other than what I heard from my ECI informants. Cheers, Stein Bruch ________________________________________________________________________________
Subject: Garmin 296
Date: Oct 05, 2004
Well, If one were to propel their Garmin 296 or 196 at 25,000 kts I think it might penetrate the containment vessal of an NGS, but the readabilty in the nuclear afterglow would be insufficient during and after the test. But, I don't fully agree with the comments about the validity of the F4 test. The P&W 4000 series engines have a central core that is equal to a 4000lb tempered steel javelin. Although its somewhat hollow these in fact did make their way completely through both world trade center buildings, and the P&W 2000 series cores had similar penetration results in the pentegon after bouncing off the ground. As far as I know nothing in an F-4 has that kind of mass or penetration quality. In fact the engines were somewhat cushioned/decelerated by the front half of the aircraft in this test. It was a comparision of apples to pizza, both go down equally tasty but they come back up very differently. The rest of any airliner is just a big aluminum balloon that would bounce off the outer containment vessal, although some of the keel segments would add to the damage if the engine cores were able to shatter enough of the shell. That said, the one nuke I've been in still had several more layers of containment after the outer shell before one even got to fuel supplies, then even more to get to the hot section of the station. I would be far more concerned about a 747 hitting the side of a carrier or boomer than one of our NGS's. W ________________________________________________________________________________
Date: Oct 05, 2004
Check out FAR 43.9 and 43.11. 43.9 covers the things required for maintenance entries and 43.11 covers those things required for an inspection entry. Mike Robertson >From: "Larry Bowen" <Larry(at)bowenaero.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Log Book Entries >Date: Tue, 5 Oct 2004 11:23:22 -0400 (EDT) > > >What is a good reference for various log book entries? What should (and >shouldn't) be annotated in each log book? Format? Examples? Etc... > >Thx, > >- >Larry Bowen, RV-8 5.2 hrs >Larry(at)BowenAero.com >http://BowenAero.com > > ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Re: Magnesium sump? No thanx.
Bottom line, with a mass that big it will be very difficult to light, but, once it is lit, dont be landing in any water thinking your going to put it out!!!!! anyone know the combustion temp of Mag. > > >Stein, > >Regarding the possible use of a magnesium sump, I'd be wary because of the >extreme flamability of magnesium. Picture this, you get a fuel leak >inside the >cowling, hits some of those 1400 deg. pipes, instant fire. You, being >mentally prepared for this ugly possibility, shut off the fuel, expecting >fire to >go out shortly, while preparing for an engine out landing. Trouble is, >now the >magnesium is burning with intensity while getting plenty of oxygen, and no >chance it'll go out. This is the stuff we used to make incindiary bombs >from. >Mr. Google tells me it burns at 1335c/2435f. > >What am I missing here? > >Jerry Cochran > >From: "Stein Bruch" <stein(at)steinair.com> >Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior >XP-IO360/FF >sump question > > >Good Luck, > >Superior is keeping a REALLY tight lock on those. Tried the same thing, and >basically they told the "owner" of the kit engine that if he wanted a >"replacement", he'd have to send the original one back. I also asked about >it at OSH and was flatly and rudely told "don't ask". Their attitude at the >OSH booth was enough to make sure I won't be buying any Superior parts soon, >even if they were cheaper. Turns out the ECI guys were much nicer, they >parts are as good or better, and they are cheaper too - can't beat that! > >Now, that being said, I have it on good rumor that ECI will shortly (within >a couple months) start shipping a lightweight forward facing sump for Lyc's. >The difference is they decided to use Magnesium instead of plastic, and the >weight is supposed to be close. > >I don't have any other details, other than what I heard from my ECI >informants. > >Cheers, >Stein Bruch > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Oct 05, 2004
I'll reply with what my genuine FAA airworthiness inspector told me. He told me not to enter anything in the logbooks other than "Annual condition inspection performed on " whatever date. He specifically told me that any other maintenance items I wanted to track should be in a separate personal log. Fresno FSDO words, not mine. -- Scott VanArtsdalen RV-4 N311SV 4-ever! -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Bowen Subject: RV-List: Log Book Entries What is a good reference for various log book entries? What should (and shouldn't) be annotated in each log book? Format? Examples? Etc... Thx, - Larry Bowen, RV-8 5.2 hrs Larry(at)BowenAero.com http://BowenAero.com = = = = ________________________________________________________________________________
From: "David Fenstermacher" <dfenstermacher(at)earthlink.net>
Date: Oct 05, 2004
This raises a question for me. What is the reference for the builder's log? I am keeping a "journal" and taking lots of pictures (some with me working). Is there anything else I should be doing? I know there are commercial computer programs, but don't feel the need to buy one if I can do it in MS Word. Thanks, Dave > >What is a good reference for various log book entries? What should (and > >shouldn't) be annotated in each log book? Format? Examples? Etc... > > > >Thx, > > > >- > >Larry Bowen, RV-8 5.2 hrs > >Larry(at)BowenAero.com > >http://BowenAero.com > > ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Re: Log Book Entries
Dave, I think that is all you'll need. That's about what I did and the FAA guy (when I applied for my repairman's certificate) leafed through my steno-type log book then said, "Let's look at your pictures, they say a lot more than words." I only had about a dozen pictures. He was more than satisfied. Dan Hopper RV-7A N766DH (Flying since 7/7/04 -- about 58 hours now) In a message dated 10/5/04 1:04:21 PM US Eastern Standard Time, dfenstermacher(at)earthlink.net writes: > > dfenstermacher(at)earthlink.net> > > This raises a question for me. > What is the reference for the builder's log? > I am keeping a "journal" and taking lots of pictures (some with me working). > Is there anything else I should be doing? > I know there are commercial computer programs, but don't feel the need to > buy one if I can do it in MS Word. > > Thanks, > > Dave > > ________________________________________________________________________________
Date: Oct 05, 2004
10/05/2004 11:26:44 AM, Serialize complete at 10/05/2004 11:26:44 AM > anyone know the combustion temp of Mag. Less than that of motor oil. The old VW bugs had either a magnesium case or cylinders, and if they got coated with leaked oil, and the oil caught, the mag would light. When the fire dept shows up at the fire, they would stand around and watch it burn because there was nothing they could do about it. Scott Scott Bilinski <bilinski@kyocera-wireless.com> Sent by: owner-rv-list-server(at)matronics.com 10/05/2004 10:43 AM Please respond to rv-list To: rv-list(at)matronics.com cc: Subject: Re: RV-List: Magnesium sump? No thanx. <bilinski@kyocera-wireless.com> Bottom line, with a mass that big it will be very difficult to light, but, once it is lit, dont be landing in any water thinking your going to put it out!!!!! anyone know the combustion temp of Mag. ________________________________________________________________________________
Date: Oct 05, 2004
I have personally witnessed a volkswagen engine case ignite in a campfire. Didn't seem to take too long to catch, and once it's going, there's no putting it out. I suspect that the alloy used in the sump is probably less flammable though. ----- Original Message ----- From: "Scott Bilinski" <bilinski@kyocera-wireless.com> Subject: Re: RV-List: Magnesium sump? No thanx. <bilinski@kyocera-wireless.com> > > Bottom line, with a mass that big it will be very difficult to light, but, > once it is lit, dont be landing in any water thinking your going to put it > out!!!!! > > anyone know the combustion temp of Mag. > > > > > > > >Stein, > > > >Regarding the possible use of a magnesium sump, I'd be wary because of the > >extreme flamability of magnesium. Picture this, you get a fuel leak > >inside the > >cowling, hits some of those 1400 deg. pipes, instant fire. You, being > >mentally prepared for this ugly possibility, shut off the fuel, expecting > >fire to > >go out shortly, while preparing for an engine out landing. Trouble is, > >now the > >magnesium is burning with intensity while getting plenty of oxygen, and no > >chance it'll go out. This is the stuff we used to make incindiary bombs > >from. > >Mr. Google tells me it burns at 1335c/2435f. > > > >What am I missing here? > > > >Jerry Cochran > > > >From: "Stein Bruch" <stein(at)steinair.com> > >Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior > >XP-IO360/FF > >sump question > > > > > >Good Luck, > > > >Superior is keeping a REALLY tight lock on those. Tried the same thing, and > >basically they told the "owner" of the kit engine that if he wanted a > >"replacement", he'd have to send the original one back. I also asked about > >it at OSH and was flatly and rudely told "don't ask". Their attitude at the > >OSH booth was enough to make sure I won't be buying any Superior parts soon, > >even if they were cheaper. Turns out the ECI guys were much nicer, they > >parts are as good or better, and they are cheaper too - can't beat that! > > > >Now, that being said, I have it on good rumor that ECI will shortly (within > >a couple months) start shipping a lightweight forward facing sump for Lyc's. > >The difference is they decided to use Magnesium instead of plastic, and the > >weight is supposed to be close. > > > >I don't have any other details, other than what I heard from my ECI > >informants. > > > >Cheers, > >Stein Bruch > > > > > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > ________________________________________________________________________________
Date: Oct 05, 2004
I believe the oil pan, accessory case and engine mount arms on the O-300, arguably the most common, small block, Continental engine produced, are magnesium and they don't seem to have any problems (other then corrosion pitting). Ron. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Scott Bilinski Subject: Re: RV-List: Magnesium sump? No thanx. <bilinski@kyocera-wireless.com> Bottom line, with a mass that big it will be very difficult to light, but, once it is lit, dont be landing in any water thinking your going to put it out!!!!! anyone know the combustion temp of Mag. > > >Stein, > >Regarding the possible use of a magnesium sump, I'd be wary because of the >extreme flamability of magnesium. Picture this, you get a fuel leak >inside the >cowling, hits some of those 1400 deg. pipes, instant fire. You, being >mentally prepared for this ugly possibility, shut off the fuel, expecting >fire to >go out shortly, while preparing for an engine out landing. Trouble is, >now the >magnesium is burning with intensity while getting plenty of oxygen, and no >chance it'll go out. This is the stuff we used to make incindiary bombs >from. >Mr. Google tells me it burns at 1335c/2435f. > >What am I missing here? > >Jerry Cochran > >From: "Stein Bruch" <stein(at)steinair.com> >Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior >XP-IO360/FF >sump question > > >Good Luck, > >Superior is keeping a REALLY tight lock on those. Tried the same thing, and >basically they told the "owner" of the kit engine that if he wanted a >"replacement", he'd have to send the original one back. I also asked about >it at OSH and was flatly and rudely told "don't ask". Their attitude at the >OSH booth was enough to make sure I won't be buying any Superior parts soon, >even if they were cheaper. Turns out the ECI guys were much nicer, they >parts are as good or better, and they are cheaper too - can't beat that! > >Now, that being said, I have it on good rumor that ECI will shortly (within >a couple months) start shipping a lightweight forward facing sump for Lyc's. >The difference is they decided to use Magnesium instead of plastic, and the >weight is supposed to be close. > >I don't have any other details, other than what I heard from my ECI >informants. > >Cheers, >Stein Bruch > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Re: Sectional Wallpaper(& shameless flyin plug)
Sam Buchanan wrote: > >Tedd McHenry wrote: > > >> >>Dana: >> >>I don't know about sectional wallpaper, but you might see if you can get >>yourself some JNCs (Jet Navigation Charts). These are 1:2,000,000 charts that >>are about 42" by 58", and cover large areas. For example, JNC 43 covers >>western North America from the Baja peninsula to the tip of Vancouver Island. >>Three JNCs cover all of the continental U.S.A., plus part of Mexico and Canada >>(JNC 43, 44, and 45, I think). That would cover an area about 100" wide and >>60" tall. >> >>I don't know if anybody other than the military uses them, but if you have any >>Air Force or Navy contacts they might be able to get you some. >> >> > > >The large (57" x 120") inexpensive JNC's are available from Builders >Bookstore: > >http://www.pilotsbooks.com/wallcharts.htm > >I applied the largest JNC to our hangar wall with wallpaper paste. The >same could be done with sectionals. Matching up the borders is a little >tedious but definitely possible. > >Sam Buchanan > We did the same thing (under glass) for the top surface of our breakfast bar. I fought it tooth my wife insisted on it & of course it looks great & is the focal point of our house for visitors. I agree that it's tedious to match the edges, but no gentleman (or lady) will ever point out the flaws. :-) Come on down to Slobovia Outernational (MS71) on Oct. 16 & check it out while you eat some BBQ. Charlie ________________________________________________________________________________
Date: Oct 05, 2004
I think I mis-spoke in an earlier email. Replace Magnesium with Titanium...... We better get the thing right from the horses mouth instead of third hand from me. I'll call ECI today if I get a chance to find out what it's really going to be made of. Cheers, Stein. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jerry2DT(at)aol.com Subject: RV-List: Magnesium sump? No thanx. Stein, Regarding the possible use of a magnesium sump, I'd be wary because of the extreme flamability of magnesium. Picture this, you get a fuel leak inside the cowling, hits some of those 1400 deg. pipes, instant fire. You, being mentally prepared for this ugly possibility, shut off the fuel, expecting fire to go out shortly, while preparing for an engine out landing. Trouble is, now the magnesium is burning with intensity while getting plenty of oxygen, and no chance it'll go out. This is the stuff we used to make incindiary bombs from. Mr. Google tells me it burns at 1335c/2435f. What am I missing here? Jerry Cochran From: "Stein Bruch" <stein(at)steinair.com> Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior XP-IO360/FF sump question Good Luck, Superior is keeping a REALLY tight lock on those. Tried the same thing, and basically they told the "owner" of the kit engine that if he wanted a "replacement", he'd have to send the original one back. I also asked about it at OSH and was flatly and rudely told "don't ask". Their attitude at the OSH booth was enough to make sure I won't be buying any Superior parts soon, even if they were cheaper. Turns out the ECI guys were much nicer, they parts are as good or better, and they are cheaper too - can't beat that! Now, that being said, I have it on good rumor that ECI will shortly (within a couple months) start shipping a lightweight forward facing sump for Lyc's. The difference is they decided to use Magnesium instead of plastic, and the weight is supposed to be close. I don't have any other details, other than what I heard from my ECI informants. Cheers, Stein Bruch ________________________________________________________________________________
Date: Oct 05, 2004
Jerry, you are missing the fact that Lycoming sumps are made from cast magnesium, and have been since the birth of the Lycosaur. Regards, Bob Japundza RV-6 flying F1 qb under const. > > Stein, > > Regarding the possible use of a magnesium sump, I'd be wary because of the > extreme flamability of magnesium. Picture this, you get a fuel leak inside the > cowling, hits some of those 1400 deg. pipes, instant fire. You, being > mentally prepared for this ugly possibility, shut off the fuel, expecting fire to > go out shortly, while preparing for an engine out landing. Trouble is, now the > magnesium is burning with intensity while getting plenty of oxygen, and no > chance it'll go out. This is the stuff we used to make incindiary bombs from. > Mr. Google tells me it burns at 1335c/2435f. > > What am I missing here? > > Jerry Cochran ________________________________________________________________________________
Date: Oct 05, 2004
What kind of genuine FAA inspector is that? An airframe maintenance log is exactly that, and should have everything from oil changes, annual inspections, structural repairs, modificiations, etc.... Of course engine work is reserved for an engine log. You don't need two airframe logs. Think of the records for the aircraft just like medical records for a person. Personally, I don't write down little things like tighening a screw, but I do record any oil changes, wheel bearing packing, brake pads during the annual, etc.. Also, the statement the FAA guy told you isn't even of the proper legal terminology. The statement can be found in the AC43.13 and the annual inspection should start out saying: "I have inspected this aircraft in accordance with a XXXX inspection.....". Just my experience in the Experimental as well as certified world. Cheers, Stein Bruch RV6's, Minneapolis A&P -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Scott VanArtsdalen Subject: RE: RV-List: Log Book Entries I'll reply with what my genuine FAA airworthiness inspector told me. He told me not to enter anything in the logbooks other than "Annual condition inspection performed on " whatever date. He specifically told me that any other maintenance items I wanted to track should be in a separate personal log. Fresno FSDO words, not mine. -- Scott VanArtsdalen RV-4 N311SV 4-ever! -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Bowen Subject: RV-List: Log Book Entries What is a good reference for various log book entries? What should (and shouldn't) be annotated in each log book? Format? Examples? Etc... Thx, - Larry Bowen, RV-8 5.2 hrs Larry(at)BowenAero.com http://BowenAero.com = = = = ________________________________________________________________________________
Date: Oct 05, 2004
540's have always had cast magnesium sumps, not sure about the four-cyl. engines. My apologies in advance if I caused any confusion. Regards, Bob Japundza RV-6 flying F1 qb under const > Jerry, you are missing the fact that Lycoming sumps are made from cast > magnesium, and have been since the birth of the Lycosaur. > > Regards, > Bob Japundza > RV-6 flying F1 qb under const. > > > > > > > > Stein, > > > > Regarding the possible use of a magnesium sump, I'd be wary because of the > > extreme flamability of magnesium. Picture this, you get a fuel leak inside the > > cowling, hits some of those 1400 deg. pipes, instant fire. You, being > > mentally prepared for this ugly possibility, shut off the fuel, expecting fire to > > go out shortly, while preparing for an engine out landing. Trouble is, now the > > magnesium is burning with intensity while getting plenty of oxygen, and no > > chance it'll go out. This is the stuff we used to make incindiary bombs from. > > Mr. Google tells me it burns at 1335c/2435f. > > > > What am I missing here? > > > > Jerry Cochran > ________________________________________________________________________________
Date: Oct 05, 2004
You are missing the fact that many engines already use magnesium cases. For example the old A-65 accessory case with it's built in oil pump housing is magnesium. ----- Original Message ----- From: <Jerry2DT(at)aol.com> Subject: RV-List: Magnesium sump? No thanx. > > > Stein, > > Regarding the possible use of a magnesium sump, I'd be wary because of the > extreme flamability of magnesium. Picture this, you get a fuel leak inside the > cowling, hits some of those 1400 deg. pipes, instant fire. You, being > mentally prepared for this ugly possibility, shut off the fuel, expecting fire to > go out shortly, while preparing for an engine out landing. Trouble is, now the > magnesium is burning with intensity while getting plenty of oxygen, and no > chance it'll go out. This is the stuff we used to make incindiary bombs from. > Mr. Google tells me it burns at 1335c/2435f. > > What am I missing here? > > Jerry Cochran > > From: "Stein Bruch" <stein(at)steinair.com> > Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior > XP-IO360/FF > sump question > > > Good Luck, > > Superior is keeping a REALLY tight lock on those. Tried the same thing, and > basically they told the "owner" of the kit engine that if he wanted a > "replacement", he'd have to send the original one back. I also asked about > it at OSH and was flatly and rudely told "don't ask". Their attitude at the > OSH booth was enough to make sure I won't be buying any Superior parts soon, > even if they were cheaper. Turns out the ECI guys were much nicer, they > parts are as good or better, and they are cheaper too - can't beat that! > > Now, that being said, I have it on good rumor that ECI will shortly (within > a couple months) start shipping a lightweight forward facing sump for Lyc's. > The difference is they decided to use Magnesium instead of plastic, and the > weight is supposed to be close. > > I don't have any other details, other than what I heard from my ECI > informants. > > Cheers, > Stein Bruch > > ________________________________________________________________________________
Date: Oct 05, 2004
All the legalities notwithstanding, which type of log would you rather see if you were considering BUYING said aircraft? This point alone justifies keeping records of everything short of wiping bugs off the canopy, IMHO of course : ) ----- Original Message ----- From: "Stein Bruch" <stein(at)steinair.com> Subject: RE: RV-List: Log Book Entries > > What kind of genuine FAA inspector is that? An airframe maintenance log is > exactly that, and should have everything from oil changes, annual > inspections, structural repairs, modificiations, etc.... Of course engine > work is reserved for an engine log. You don't need two airframe logs. > > Think of the records for the aircraft just like medical records for a > person. Personally, I don't write down little things like tighening a > screw, but I do record any oil changes, wheel bearing packing, brake pads > during the annual, etc.. Also, the statement the FAA guy told you isn't even > of the proper legal terminology. The statement can be found in the AC43.13 > and the annual inspection should start out saying: "I have inspected this > aircraft in accordance with a XXXX inspection.....". > > Just my experience in the Experimental as well as certified world. > > Cheers, > Stein Bruch > RV6's, Minneapolis > A&P > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Scott > VanArtsdalen > To: rv-list(at)matronics.com > Subject: RE: RV-List: Log Book Entries > > > I'll reply with what my genuine FAA airworthiness inspector told me. He > told me not to enter anything in the logbooks other than "Annual > condition inspection performed on " whatever date. He specifically told > me that any other maintenance items I wanted to track should be in a > separate personal log. Fresno FSDO words, not mine. > > -- > Scott VanArtsdalen > RV-4 N311SV > 4-ever! > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Bowen > To: rv-list(at)matronics.com > Subject: RV-List: Log Book Entries > > > What is a good reference for various log book entries? What should (and > shouldn't) be annotated in each log book? Format? Examples? Etc... > > Thx, > > - > Larry Bowen, RV-8 5.2 hrs > Larry(at)BowenAero.com > http://BowenAero.com > > > = > = > = > = > > ________________________________________________________________________________
Date: Oct 05, 2004
I'm with you on that. I'm just passing on what was said. -- Scott VanArtsdalen RV-4 N311SV 4-ever! -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Stein Bruch Subject: RE: RV-List: Log Book Entries What kind of genuine FAA inspector is that? An airframe maintenance log is exactly that, and should have everything from oil changes, annual inspections, structural repairs, modificiations, etc.... Of course engine work is reserved for an engine log. You don't need two airframe logs. Think of the records for the aircraft just like medical records for a person. Personally, I don't write down little things like tighening a screw, but I do record any oil changes, wheel bearing packing, brake pads during the annual, etc.. Also, the statement the FAA guy told you isn't even of the proper legal terminology. The statement can be found in the AC43.13 and the annual inspection should start out saying: "I have inspected this aircraft in accordance with a XXXX inspection.....". Just my experience in the Experimental as well as certified world. Cheers, Stein Bruch RV6's, Minneapolis A&P -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Scott VanArtsdalen Subject: RE: RV-List: Log Book Entries I'll reply with what my genuine FAA airworthiness inspector told me. He told me not to enter anything in the logbooks other than "Annual condition inspection performed on " whatever date. He specifically told me that any other maintenance items I wanted to track should be in a separate personal log. Fresno FSDO words, not mine. -- Scott VanArtsdalen RV-4 N311SV 4-ever! -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Bowen Subject: RV-List: Log Book Entries What is a good reference for various log book entries? What should (and shouldn't) be annotated in each log book? Format? Examples? Etc... Thx, - Larry Bowen, RV-8 5.2 hrs Larry(at)BowenAero.com http://BowenAero.com = = = = = = = = ________________________________________________________________________________
Subject: ELT?
Date: Oct 05, 2004
With the short remaing life of the 121.5 mh ELT system, and with 406's still being relatively expensive, and with no ELT required in a single place aircraft (RV-3B), is it worth adding the weight and expense of this near-obsolete technology, or should I go sans ELT until the nextgen product becomes more mature? Randy Lervold RV-3B, fuselage www.rv-3.com ________________________________________________________________________________
Subject: ELT?
Date: Oct 05, 2004
Hey Randy, Are the EBC-502's also going. They work off both 121.5 and 243.0? If so that is a true bummer. Those thing's are small, light weight and portable. >From: "Randy Lervold" <randy(at)romeolima.com> >Reply-To: rv-list(at)matronics.com >To: , >Subject: RV-List: ELT? >Date: Tue, 5 Oct 2004 13:44:37 -0700 > > >With the short remaing life of the 121.5 mh ELT system, and with 406's >still >being relatively expensive, and with no ELT required in a single place >aircraft (RV-3B), is it worth adding the weight and expense of this >near-obsolete technology, or should I go sans ELT until the nextgen product >becomes more mature? > >Randy Lervold >RV-3B, fuselage >www.rv-3.com > > ________________________________________________________________________________
Subject: Re : Magnesium Sumps
Date: Oct 06, 2004
Seems to be a fair bit of anecdotal evidence that magnesium burns easily, but in my experience you need a lot of heat to get it to burn. If you have that much going on, you would be in trouble anyway. Even the aluminum would burn away. Heck, you can even weld the stuff ! I have no problem riding behind an engine with magnesium cases or sump. Cheers Martin in Oz ________________________________________________________________________________
Subject: Re: ELT?
Date: Oct 05, 2004
Yes, both 121.5 and 243.0 will become obsolete. ----- Original Message ----- From: "BRUCE GRAY" <brucerv84us(at)hotmail.com> Subject: RE: RV-List: ELT? > > Hey Randy, Are the EBC-502's also going. They work off both 121.5 and 243.0? > If so that is a true bummer. Those thing's are small, light weight and > portable. > > >From: "Randy Lervold" <randy(at)romeolima.com> > >Reply-To: rv-list(at)matronics.com > >To: , > >Subject: RV-List: ELT? > >Date: Tue, 5 Oct 2004 13:44:37 -0700 > > > > > >With the short remaing life of the 121.5 mh ELT system, and with 406's > >still > >being relatively expensive, and with no ELT required in a single place > >aircraft (RV-3B), is it worth adding the weight and expense of this > >near-obsolete technology, or should I go sans ELT until the nextgen product > >becomes more mature? > > > >Randy Lervold > >RV-3B, fuselage > >www.rv-3.com > > > > > > ________________________________________________________________________________
Date: Oct 05, 2004
From: Chris W <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net>
Someone on the rec.aviation.piloting news group asked a similar question with out much response a while back. However I did find out from that thread that you can download very high res tiff images of the sectionals. If people think it would be worth while I could try and past them together and make a huge map. I have a friend that has a 44" wide ink jet printer and can print any length for about 6$ per square foot. I know it is expensive but if your just doing it once. . . I will have to check to see if he can do it cheaper if it's not on that glossy photo paper he normally uses. -- Chris W Bring Back the HP 15C http://hp15c.org Not getting the gifts you want? The Wish Zone can help. ________________________________________________________________________________
Subject: Re: ELT?
Date: Oct 05, 2004
What do they have in store for us? And is it affordable? New and improved is usually expensive. >From: "Randy Lervold" <randy(at)romeolima.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: ELT? >Date: Tue, 5 Oct 2004 15:29:00 -0700 > > >Yes, both 121.5 and 243.0 will become obsolete. > > >----- Original Message ----- >From: "BRUCE GRAY" <brucerv84us(at)hotmail.com> >To: >Subject: RE: RV-List: ELT? > > > > > > Hey Randy, Are the EBC-502's also going. They work off both 121.5 and >243.0? > > If so that is a true bummer. Those thing's are small, light weight and > > portable. > > > > >From: "Randy Lervold" <randy(at)romeolima.com> > > >Reply-To: rv-list(at)matronics.com > > >To: , > > >Subject: RV-List: ELT? > > >Date: Tue, 5 Oct 2004 13:44:37 -0700 > > > > > > > > >With the short remaing life of the 121.5 mh ELT system, and with 406's > > >still > > >being relatively expensive, and with no ELT required in a single place > > >aircraft (RV-3B), is it worth adding the weight and expense of this > > >near-obsolete technology, or should I go sans ELT until the nextgen >product > > >becomes more mature? > > > > > >Randy Lervold > > >RV-3B, fuselage > > >www.rv-3.com > > > > > > > > > > > > Get ready for school! Find articles, homework help and more in the Back to ________________________________________________________________________________
Subject: ELT?
Date: Oct 05, 2004
> >With the short remaing life of the 121.5 mh ELT system, and with 406's >still >being relatively expensive, and with no ELT required in a single place >aircraft (RV-3B), is it worth adding the weight and expense of this >near-obsolete technology, or should I go sans ELT until the nextgen product >becomes more mature? > >Randy Lervold >RV-3B, fuselage >www.rv-3.com I can relate to this dilemma. Tailcone is done on the RV10, and I'd like to get the ELT installation done now, while it's easy to access everything. But, how long will today's ELT be viable? Will most likely wait til later. Much later. Brian Denk RV8 N94BD RV10 '51 ________________________________________________________________________________
Subject: ELT?
Date: Oct 05, 2004
The new ELT's at the moment are quite pricey. I looked at stocking them, but the only decently priced one out there that is (COSPAS/SARSAT) compliant for 2009+ is high $$ compared to the current $180.00 ACK & AK's. Anyway, if anyone is interested, pointer makes one in the $400.00-$500.00 range. If you're interested in one, contact me off list and we'll get you setup. Cheers, Stein Bruch http://www.steinair.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of BRUCE GRAY Subject: Re: RV-List: ELT? What do they have in store for us? And is it affordable? New and improved is usually expensive. >From: "Randy Lervold" <randy(at)romeolima.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: ELT? >Date: Tue, 5 Oct 2004 15:29:00 -0700 > > >Yes, both 121.5 and 243.0 will become obsolete. > > >----- Original Message ----- >From: "BRUCE GRAY" <brucerv84us(at)hotmail.com> >To: >Subject: RE: RV-List: ELT? > > > > > > Hey Randy, Are the EBC-502's also going. They work off both 121.5 and >243.0? > > If so that is a true bummer. Those thing's are small, light weight and > > portable. > > > > >From: "Randy Lervold" <randy(at)romeolima.com> > > >Reply-To: rv-list(at)matronics.com > > >To: , > > >Subject: RV-List: ELT? > > >Date: Tue, 5 Oct 2004 13:44:37 -0700 > > > > > > > > >With the short remaing life of the 121.5 mh ELT system, and with 406's > > >still > > >being relatively expensive, and with no ELT required in a single place > > >aircraft (RV-3B), is it worth adding the weight and expense of this > > >near-obsolete technology, or should I go sans ELT until the nextgen >product > > >becomes more mature? > > > > > >Randy Lervold > > >RV-3B, fuselage > > >www.rv-3.com > > > > > > > > > > > > Get ready for school! Find articles, homework help and more in the Back to ________________________________________________________________________________
Date: Oct 05, 2004
Jerry, I don't know that you are missing anything. However, Lycoming's 200 hp sumps are made of magnesium. Charlie Kuss > > >Stein, > >Regarding the possible use of a magnesium sump, I'd be wary because of the >extreme flamability of magnesium. Picture this, you get a fuel leak >inside the >cowling, hits some of those 1400 deg. pipes, instant fire. You, being >mentally prepared for this ugly possibility, shut off the fuel, expecting >fire to >go out shortly, while preparing for an engine out landing. Trouble is, >now the >magnesium is burning with intensity while getting plenty of oxygen, and no >chance it'll go out. This is the stuff we used to make incindiary bombs >from. >Mr. Google tells me it burns at 1335c/2435f. > >What am I missing here? > >Jerry Cochran > >From: "Stein Bruch" <stein(at)steinair.com> >Subject: RE: RV-List: XP-360 Ryton plastic sump availability- was Superior >XP-IO360/FF >sump question > > >Good Luck, > >Superior is keeping a REALLY tight lock on those. Tried the same thing, and >basically they told the "owner" of the kit engine that if he wanted a >"replacement", he'd have to send the original one back. I also asked about >it at OSH and was flatly and rudely told "don't ask". Their attitude at the >OSH booth was enough to make sure I won't be buying any Superior parts soon, >even if they were cheaper. Turns out the ECI guys were much nicer, they >parts are as good or better, and they are cheaper too - can't beat that! > >Now, that being said, I have it on good rumor that ECI will shortly (within >a couple months) start shipping a lightweight forward facing sump for Lyc's. >The difference is they decided to use Magnesium instead of plastic, and the >weight is supposed to be close. > >I don't have any other details, other than what I heard from my ECI >informants. > >Cheers, >Stein Bruch > > ________________________________________________________________________________
From: "mimartin(at)sweetwaterhsa.com" <mimartin(at)sweetwater.com>
Subject: Follow up to posting about KLX-135A
Date: Oct 05, 2004
I would like all the subscribers to know that Jim Irwin , President of Aircraft Spruce and Specialty, corrected the price on the KLX-135A and gave me a credit for the difference. They have proven that customer is # 1 and they are #1 with me. Mickey Martin RV 6 ________________________________________________________________________________
Subject: Jefferson City, MO FLY-IN 10/09/04
Date: Oct 05, 2004
Just a reminder that this Saturday is the annual Jefferson City, (JEF) MO. Fly-in. Let's make sure the RV's outnumber everything else in total! Looking forward to seeing you there. David Schaefer RV6A - N142DS - FINISHED & FLYING!!! ________________________________________________________________________________
Subject: ELT?
Date: Oct 05, 2004
I mis-spoke. The currnet 406mhz ELT's are going for betwen $1500-1800.00 and up. Sorry for the confusion. Cheers, Stein. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Stein Bruch Subject: RE: RV-List: ELT? The new ELT's at the moment are quite pricey. I looked at stocking them, but the only decently priced one out there that is (COSPAS/SARSAT) compliant for 2009+ is high $$ compared to the current $180.00 ACK & AK's. Anyway, if anyone is interested, pointer makes one in the $400.00-$500.00 range. If you're interested in one, contact me off list and we'll get you setup. Cheers, Stein Bruch http://www.steinair.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of BRUCE GRAY Subject: Re: RV-List: ELT? What do they have in store for us? And is it affordable? New and improved is usually expensive. >From: "Randy Lervold" <randy(at)romeolima.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: ELT? >Date: Tue, 5 Oct 2004 15:29:00 -0700 > > >Yes, both 121.5 and 243.0 will become obsolete. > > >----- Original Message ----- >From: "BRUCE GRAY" <brucerv84us(at)hotmail.com> >To: >Subject: RE: RV-List: ELT? > > > > > > Hey Randy, Are the EBC-502's also going. They work off both 121.5 and >243.0? > > If so that is a true bummer. Those thing's are small, light weight and > > portable. > > > > >From: "Randy Lervold" <randy(at)romeolima.com> > > >Reply-To: rv-list(at)matronics.com > > >To: , > > >Subject: RV-List: ELT? > > >Date: Tue, 5 Oct 2004 13:44:37 -0700 > > > > > > > > >With the short remaing life of the 121.5 mh ELT system, and with 406's > > >still > > >being relatively expensive, and with no ELT required in a single place > > >aircraft (RV-3B), is it worth adding the weight and expense of this > > >near-obsolete technology, or should I go sans ELT until the nextgen >product > > >becomes more mature? > > > > > >Randy Lervold > > >RV-3B, fuselage > > >www.rv-3.com > > > > > > > > > > > > Get ready for school! Find articles, homework help and more in the Back to ________________________________________________________________________________
Subject: FOR SALE
Date: Oct 05, 2004
Hello Y'all, Have a few things lying around that I should let go of. 1. IO360 200HP Vetterman RV8 exhaust. Used 400 hours, sent to Vetterman for flange repair and had no time to wait and install new system. Clean bill of health by Larry. Has 4 EGT probe holes and no mounting hardware. New $775.00 will let go for $500.00. 2. True Airspeed Indicator for RV8. Dual dial with V speed markings and lighted. Like new. ASIT260MKL. New $265.00 asking $200.00. 3. Oil cooler. Positech #4211. Latest updated version. Not the old style which gave the bad reputation. Never installed. Vans price $165.00, sell for $130.00. 4. Oil seperator. Aircraft Spruce #10570. Like new. Spruce price $38.85 cheap at $20.00. All items will be packed at no charge and shipping paid by purchaser at actual cost. George Meketa N444TX, RV8, 530 hours ________________________________________________________________________________
Subject: Tight hinge pins
Date: Oct 05, 2004
1.67 SARE_ADLTSUB2 Contains possible adult words Inserting the 0.90" hinge pins that join the top and bottom cowl requires a vice grip on the last few inches. This seems to be a lot of force and breaking a pin on insertion would be a large problem. I should note that I can't use a drill to set the pins since the outside end is bent 90 degrees. I'm hoping that the pins will wear-in somewhat after I'm flying or should I be doing something to reduce the amount of force necessary to insert the pins? As it is I'll will be replacing the originals with new pin stock before first flight. The originals accumulate a lot of wear during the construction phase. As for maintenance, how often should a person think of replacing these pins? If anyone has had them break, how on earth did you remove them? Thanks ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Re: Tight hinge pins
Mike Holland wrote: > >Inserting the 0.90" hinge pins that join the top and bottom cowl requires a vice grip on the last few inches. This seems to be a lot of force and breaking a pin on insertion would be a large problem. I should note that I can't use a drill to set the pins since the outside end is bent 90 degrees. > >I'm hoping that the pins will wear-in somewhat after I'm flying or should I be doing something to reduce the amount of force necessary to insert the pins? > >As it is I'll will be replacing the originals with new pin stock before first flight. The originals accumulate a lot of wear during the construction phase. > >As for maintenance, how often should a person think of replacing these pins? > Hmmm....Flying 15 years and have not thought about it yet. :-) > >If anyone has had them break, how on earth did you remove them? > > >Thanks > > I doubt they well break, but if they do it well most likely be at the point where you bent the 90degree bend. ________________________________________________________________________________
Date: Oct 05, 2004
Mike: I very slightly reduced the diameter of the pins by scrubbing them with red Scotchbrite pads. My pins are also bent 90 degrees at the end, and that just seemed to make spinning them in by slow-turning drill easier, as the chuck could get a grip on the bend by sticking it through the space between two of the jaws. Scott in vancouver ----- Original Message ----- From: "Mike Holland" <hollandm(at)pacbell.net> Subject: RV-List: Tight hinge pins > > Inserting the 0.90" hinge pins that join the top and bottom cowl requires > a vice grip on the last few inches. This seems to be a lot of force and > breaking a pin on insertion would be a large problem. I should note that > I can't use a drill to set the pins since the outside end is bent 90 > degrees. > > I'm hoping that the pins will wear-in somewhat after I'm flying or should > I be doing something to reduce the amount of force necessary to insert the > pins? > > As it is I'll will be replacing the originals with new pin stock before > first flight. The originals accumulate a lot of wear during the > construction phase. > > As for maintenance, how often should a person think of replacing these > pins? > > If anyone has had them break, how on earth did you remove them? > > > Thanks > > > ________________________________________________________________________________
Date: Oct 05, 2004
> > I'm hoping that the pins will wear-in somewhat after I'm flying or > should I be doing something to reduce the amount of force necessary to > insert the pins? > > You will be amazed at how they wear in. I had to use a drill on mine during construction, but after 25 hours of flying I can put them in by hand with no drill or vicegrips. Keep with it and they will loosen up. I also used some LPS spray on them the first few hours. I just spray it on a rag and wipe the pins to slick them up. - Andy Karmy RV9A Seattle WA 275hrs going strong... ________________________________________________________________________________
Date: Oct 05, 2004
Hi Mike, I have my pins set up to insert forward through the NACA vents. My hinge pins are fit quite tight and I have tried both Beolube and ordinary bar soap. Both of these materials applied to the hinge pins have provided some quite reasonable success in reducing the friction. My thought in using the bar of soap was that before painting I did not want to pollute the area with unknown chemistry. Mind you I have little or no knowledge as to the make up of either product. It just seemed to me that the parts will be rinsed (wet sanded) some time be fore being painted. In any case the overall struggle was reduced somewhat. Both materials seemed to have about the same noticable level of benefit. The pins can and in fact have broken. When installed from the front of the cowl take great care to provide a very safe and secure means of installation is needed. I do know of one case where one of the cowl hinge pins somehow became un secured and vibration allowed it to do serious ($$ rebuild $$) damage to a C.S. prop. Have fun pulling your pin...s {[g-] ! Jim in Kelowna ----- Original Message ----- From: "Mike Holland" <hollandm(at)pacbell.net> Subject: RV-List: Tight hinge pins > > Inserting the 0.90" hinge pins that join the top and bottom cowl requires > a vice grip on the last few inches. This seems to be a lot of force and > breaking a pin on insertion would be a large problem. I should note that > I can't use a drill to set the pins since the outside end is bent 90 > degrees. > > I'm hoping that the pins will wear-in somewhat after I'm flying or should > I be doing something to reduce the amount of force necessary to insert the > pins? > > As it is I'll will be replacing the originals with new pin stock before > first flight. The originals accumulate a lot of wear during the > construction phase. > > As for maintenance, how often should a person think of replacing these > pins? > > If anyone has had them break, how on earth did you remove them? > > > Thanks > > > ________________________________________________________________________________
Subject: Rivet shavers/Flush rivets on VS
Date: Oct 06, 2004
Ok - I have a couple more questions. My VS flush rivets are all flush (don't laugh) except for a few where I didn't countersink enough or the primer threw off my fit. Anyway, I was wondering if I needed to flush these up. I don't know how critical it is for these rivets to be perfectly flush when attaching to fuse. Will the fuse to VS attach accept a couple high rivets, or does it need to be perfectly flat? If I can leave them alone I won't have to buy something to cut these down. If I can't, then it leads me to my second question... Has anybody tried the Avery rivet shaver that fits in a countersink tool? A "real" rivet shaver is big bucks. OR, is there an alternative to using a rivet shaver (Dremel tool, etc.)? Thanks everybody, Dave RV-8 Emp. almost complete; wings on order. Woodbridge, VA ________________________________________________________________________________
Subject: Re: Follow up to posting about KLX-135A
Date: Oct 06, 2004
> I would like all the subscribers to know that Jim Irwin , President of Aircraft Spruce > and Specialty, corrected the price on the KLX-135A and gave me a credit for the > difference. They have proven that customer is # 1 and they are #1 with me. > Mickey Martin RV 6 > Good luck. Around here, the service hasn't been that good. I bought from them when I first started building Scooter way back in 1992 and quit buying from them, after a bit. Then, I started buying from them again around 1996 after they assured me they had changed. Yeah, sure. I stopped again. I've found their service, pricing, shipping practices, etc. not up to par with the other companies I've bought from. Today, I use Wicks for most of my day to day stuff. I only use Aircraft Spruce as a last resort when I can't find an item somewhere else. Maybe the new location in Georgia will help. I got better service out of those folks than the ones out west. I must admit that I do like their catalog. I use it for ideas before buying from somebody else. Jim Sears in KY RV-6A N198JS (Scooter) RV-7A #70317 (Building wings, fuse ordered) ________________________________________________________________________________
Subject: Sumps: Mag vs. Ryton
Date: Oct 06, 2004
Just a couple of thoughts not strung together with any particular coherence: One of the benefits of a Ryton sump and runners goes beyond the weight issue. Plastic does not conduct heat like metal. The Ryton runners will result in a cooler charge than any metal integral sump/manifold. Although certainly not as cold as an external manifold. Another exapmle of Magnesium in aircraft engine is the LOM inline engine thats somewhat popular with homebuilders. The crank case is made of magnesium. Someone mentioned titanium. Only problem with that is it is heavier than aluminum. (Titanium 40% lighter than steel and 60% lighter than aluminum) titanium is used to replace steel magnesium is used to replace aluminum Aluminum, like magnesium will burn. Its just harder to get it to start. In practice its not an issue, but aluminum will burn. The space shuttle solid rocket boosters burn aluminum. Don ________________________________________________________________________________
Subject: Re: Rivet shavers/Flush rivets on VS
Date: Oct 06, 2004
Dave: I have used the Avery rivet shaver with very good success. It takes a bit of practice and a light touch, but it worked well for me. Regards, Jeff Orear RV6A N782P (reserved) firewall forward Peshtigo, WI ----- Original Message ----- From: "David Fenstermacher" <dfenstermacher(at)earthlink.net> Subject: RV-List: Rivet shavers/Flush rivets on VS > > > Ok - I have a couple more questions. > My VS flush rivets are all flush (don't laugh) except for a few where I > didn't countersink enough or the primer threw off my fit. > Anyway, I was wondering if I needed to flush these up. I don't know how > critical it is for these rivets to be perfectly flush when attaching to > fuse. > > Will the fuse to VS attach accept a couple high rivets, or does it need to > be perfectly flat? > > If I can leave them alone I won't have to buy something to cut these down. > If I can't, then it leads me to my second question... > > Has anybody tried the Avery rivet shaver that fits in a countersink tool? > A "real" rivet shaver is big bucks. > > OR, is there an alternative to using a rivet shaver (Dremel tool, etc.)? > > Thanks everybody, > > Dave > > RV-8 > Emp. almost complete; wings on order. > Woodbridge, VA > > > ________________________________________________________________________________
From: George Neal E Capt AU/PC <Neal.George(at)maxwell.af.mil>
Date: Oct 06, 2004
I have to agree with Jim. I've had horrible service from ACS. I'll pay a premium somewhere else just to avoid them. I'd much rather give my business to the small shops and individuals that seek our business, rather than expect it - Abby, Stein, both Bills, Paul, Duck, B&C... it's a long list. Neal RV-7 N8ZG (wings) >I must admit that I do like their catalog. >I use it for ideas before buying from somebody else. >Jim Sears in KY ________________________________________________________________________________
Date: Oct 06, 2004
Scott, I'm sorry but someone misquoted you. In the Operating Limitations for your aircraft one of the first paragraphs states that the aircraft will be operated in accordance with ALL the operating rules of FAR 91. FAR 91 includes the subpart on maintenance. One of those paragraphs in that subpart states that all discrepancies will be corrected between inspections and a log entry will be made. Another one says that all logbook entries will be in accordance with FAR 43. The parts of 43 that cover logbook entries is FAR 43.9 and 43.11. I'm sory that I can't get more specific at this time but our office is in the middle of moving and my regs book is packed away. If anyone wants more specifics let me know and I will be able to do so next week. Mike Robertson Das Fed >From: "Scott VanArtsdalen" <svanarts(at)yahoo.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RE: RV-List: Log Book Entries >Date: Tue, 5 Oct 2004 10:49:00 -0700 > > >I'll reply with what my genuine FAA airworthiness inspector told me. He >told me not to enter anything in the logbooks other than "Annual >condition inspection performed on " whatever date. He specifically told >me that any other maintenance items I wanted to track should be in a >separate personal log. Fresno FSDO words, not mine. > >-- >Scott VanArtsdalen >RV-4 N311SV >4-ever! > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Bowen >To: rv-list(at)matronics.com >Subject: RV-List: Log Book Entries > > >What is a good reference for various log book entries? What should (and >shouldn't) be annotated in each log book? Format? Examples? Etc... > >Thx, > >- >Larry Bowen, RV-8 5.2 hrs >Larry(at)BowenAero.com >http://BowenAero.com > > >= >= >= >= > > Check out Election 2004 for up-to-date election news, plus voter tools and ________________________________________________________________________________
Date: Oct 06, 2004
The reference to a builder's log is not in the regulations but, rather, in the certification order, 8130.2E. Mike Robertson >From: "David Fenstermacher" <dfenstermacher(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RE: RV-List: Log Book Entries >Date: Tue, 5 Oct 2004 14:05:39 -0400 > > > >This raises a question for me. >What is the reference for the builder's log? >I am keeping a "journal" and taking lots of pictures (some with me >working). >Is there anything else I should be doing? >I know there are commercial computer programs, but don't feel the need to >buy one if I can do it in MS Word. > >Thanks, > >Dave > > > > >What is a good reference for various log book entries? What should >(and > > >shouldn't) be annotated in each log book? Format? Examples? Etc... > > > > > >Thx, > > > > > >- > > >Larry Bowen, RV-8 5.2 hrs > > >Larry(at)BowenAero.com > > >http://BowenAero.com > > > > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Subject: ELT?
Date: Oct 06, 2004
Randy, I would at least install one of the old "style" ELTs for now. They aren't that expensive and have a better chance of helping you out if something does happen than if nothing was installed. Mike R. >From: "Randy Lervold" <randy(at)romeolima.com> >Reply-To: rv-list(at)matronics.com >To: , >Subject: RV-List: ELT? >Date: Tue, 5 Oct 2004 13:44:37 -0700 > > >With the short remaing life of the 121.5 mh ELT system, and with 406's >still >being relatively expensive, and with no ELT required in a single place >aircraft (RV-3B), is it worth adding the weight and expense of this >near-obsolete technology, or should I go sans ELT until the nextgen product >becomes more mature? > >Randy Lervold >RV-3B, fuselage >www.rv-3.com > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Subject: Engine Problems
Date: Oct 06, 2004
For those of you that like engine puzzles give me some ideas. Engine is a Lyc IO-320 in an RV-9A. Here's the symptoms and some findings. During flight #4 cylinder starts showing a high EGT (about 1470) and a low CHT (about 320). All other cylinders show around 1360 EGT and 360 CHTs. All other engine parameters stay normal for temps and pressures. There are two other symptoms. The fuel pressure starts to drop off but comes right back up once the electric pump is turned on. This has no effect on the cylinder temps though. Once the high temp was noticed mixture was enriched and all temps on all cylinders went down but the #4 EGT slowly started creeping back up. Push the mixture in more and temps go down across the board again but then the #4 EGT starts creeping back up. During the approach to land there are lots of exhaust popping. (lots of fuel in exhaust). After landing, compression checks on all cylinders showed 76-78 over 80. A visual inspection of the exhaust values showed nothing wrong. A wobble check of the #4 exhaust valve indicated everything was ok. The fuel injector was pulled and found to be in good condition. The top taken off the flow divider and everything was clean. both the fuel filter and the gascolator screen were clean. The only thing found so far was the fuel line coming from the servo to the flow divider had slipped off the heat shield and was sitting directly on the exhaust pipe. The fire sleeve was charred but the fuel line (teflon braided) showed no damage and was clear. I have been working with these engines for some time but this is the first time I have come across this one. Anyone have any ideas. I am beginning to wonder if just re-routing the fuel line might fix everything. Maybe a bubble got into the #4 injector line causing the #4 cylinder to go lean?? By the way, this is a Bart engine. He has been contacted and we are going through different things there also but I wanted to get some more ideas. Thanks, Mike Robertson ________________________________________________________________________________
Date: Oct 06, 2004
Bad spark plug on #4 cylinder? Plugs can go bad without fouling. They should be pressure tested at every annual. Try running on each mag next time. If it's a bad plug the cylinder will go cold when that mag is selected. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Robertson Subject: RV-List: Engine Problems For those of you that like engine puzzles give me some ideas. Engine is a Lyc IO-320 in an RV-9A. Here's the symptoms and some findings. During flight #4 cylinder starts showing a high EGT (about 1470) and a low CHT (about 320). All other cylinders show around 1360 EGT and 360 CHTs. All other engine parameters stay normal for temps and pressures. There are two other symptoms. The fuel pressure starts to drop off but comes right back up once the electric pump is turned on. This has no effect on the cylinder temps though. Once the high temp was noticed mixture was enriched and all temps on all cylinders went down but the #4 EGT slowly started creeping back up. Push the mixture in more and temps go down across the board again but then the #4 EGT starts creeping back up. During the approach to land there are lots of exhaust popping. (lots of fuel in exhaust). After landing, compression checks on all cylinders showed 76-78 over 80. A visual inspection of the exhaust values showed nothing wrong. A wobble check of the #4 exhaust valve indicated everything was ok. The fuel injector was pulled and found to be in good condition. The top taken off the flow divider and everything was clean. both the fuel filter and the gascolator screen were clean. The only thing found so far was the fuel line coming from the servo to the flow divider had slipped off the heat shield and was sitting directly on the exhaust pipe. The fire sleeve was charred but the fuel line (teflon braided) showed no damage and was clear. I have been working with these engines for some time but this is the first time I have come across this one. Anyone have any ideas. I am beginning to wonder if just re-routing the fuel line might fix everything. Maybe a bubble got into the #4 injector line causing the #4 cylinder to go lean?? By the way, this is a Bart engine. He has been contacted and we are going through different things there also but I wanted to get some more ideas. Thanks, Mike Robertson On the road to retirement? Check out MSN Life Events for advice on how to = = = = ________________________________________________________________________________
Date: Oct 06, 2004
September 26, 2004 - October 06, 2004
RV-Archive.digest.vol-pv
