RV-Archive.digest.vol-qj
January 11, 2005 - January 19, 2005
      >Matthew Brandes,
      >Van's RV-9A (Finish Kit)
      >EAA Chapter 868/91/1329
      >www.n523rv.com <http://www.n523rv.com/>
Subject: Garmin 430 memory power
Date: Jan 11, 2005
I've seen several messages in the archives referring to hooking up some power pins on the Garmin 430 to an always-on bus for frequency memory retention, which 1) strikes me as odd that the 430 would need that and 2) don't see any references to this in the Garmin installation manual. Who knows the real deal here? Mitch Faatz RV-6A Finish Kit Auburn, CA ________________________________________________________________________________
Subject: Re: Garmin 430 memory power
Date: Jan 11, 2005
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Not required. Mike --- Original Message --- From: "Mitch Faatz" <mitchf(at)skybound.com> Subject: RV-List: Garmin 430 memory power I've seen several messages in the archives referring to hooking up some power pins on the Garmin 430 to an always-on bus for frequency memory retention, which 1) strikes me as odd that the 430 would need that and 2) don't see any references to this in the Garmin installation manual. Who knows the real deal here? Mitch Faatz RV-6A Finish Kit Auburn, CA ________________________________________________________________________________
Date: Jan 11, 2005
Subject: Re: battery charging
> >Hopperdhh(at)aol.com wrote: > > >So I take it you would not recommend keeping a "float" type charger on > >whenever the plane is in the hangar? > > > > >I don't know how dangerous leaving a lead acid battery on float charge >is, but I have read that if you do leave it on float charge you need to >be sure the charge voltage is no more than 13.8V for a 12V battery. Any >higher and it will damage the battery. That may be why the tractor >battery Dan Hopper mentioned had an untimely demise. For a cycle >charge, the charge voltage can be as high as 15V. That is correct. An inexpensive "dumb" charger can go to too high of a voltage. The float voltage is dependant on temperature, but Hawker recommends 13.6 volts for their AGM batteries. I should note that in general, AGMs have very low self-discharge rates. That is, they stay charged pretty long on the shelf. Thus, if there is no draw (like for the memory in your radio) you would only need to top off your AGM two or three times per year, perhaps less. Here is a link to some useful technical information about Hawker batteries: http://www.rosebatteries.com/whitepapers/hawker_whitepaper.html ________________________________________________________________________________
Subject: Plenum Pics
Date: Jan 11, 2005
Several people have asked for pictures of my plenum. If I have missed anyone please let me know or maybe someone can take them and post them. I would be happy to answer any questions. Thanks John Furey RV6A O-320 300 hrs ________________________________________________________________________________
"RV List"
Subject: canopy bow drag
Date: Jan 11, 2005
Thanks for the input so far! Pro's for the tip over: simple light better visibility easier ingress/egress Pro's for the slider: safety in fixed windscreen (thanks Doug) safety in stronger windscreen (my original reason for exploring this option) cool factor (well, it does count; doesn't it?) My reasoning so far goes like this: I think I can build a slider with very little to no weight penalty to a tip-over; and I like having that fixed windscreen in case of a bird strike; and I have significantly changed my cockpit layout such that ingress/egress to the pilot would be fine with the slider. I also think I can build the canopy bow to minimize visibility impairment and drag (all composite bow and canopy frame/skirt). So far the slider is winning. Any more input ?? cheers, Larry E. James Bellevue, WA HR2 fuselage/systems ________________________________________________________________________________
Subject: Now THIS is an idea!
Date: Jan 11, 2005
I purchased a pair of Clarity Aloft head sets that are very similar at OSH. I find them very comfortable and use them more than my Bose X. www.clarityaloft.com John Rv6A ________________________________________________________________________________
Date: Jan 11, 2005
>Several people have asked for pictures of my plenum. If I have missed anyone >please let me know or maybe someone can take them and post them. I would be >happy to answer any questions. and Ill put them up in my gallery. -- John www.rivetbangers.com - A marriage of web and email. No ads, just builders www.spikesplace.org/cgi-php/serendipity - Build Log --- ________________________________________________________________________________
Date: Jan 11, 2005
Done. John's plenum pictures may be found at: http://www.rivetbangers.com/cgi-php/gallery/inprogress/johnFureysPlenum3 http://www.rivetbangers.com/cgi-php/gallery/inprogress/johnFureysPlenum2 http://www.rivetbangers.com/cgi-php/gallery/inprogress/johnFureysPlenum1 Beautiful work John, it looks excellent! -- John RV-9A 91074 www.rivetbangers.com - Building more than RV's www.spikesplace.org/cgi-php/serendipity - Builder's Log --- ________________________________________________________________________________
Date: Jan 11, 2005
Subject: Re: Plenum Pics
In a message dated 01/11/2005 7:26:03 PM Central Standard Time, john(at)fureychrysler.com writes: John Furey RV6A O-320 300 hrs >>> I see you HAVE tested them- and the survey says? Mark ________________________________________________________________________________
Date: Jan 11, 2005
Thanks ________________________________________________________________________________
Date: Jan 11, 2005
I would say that they were very effective. Unfortunately I took them off in an act of desperation to get my cyl head temps down only to find the culprit was the casting flash that was a thread on this list about a week later. Cleaning the flashing made about 30 degree difference. JF ________________________________________________________________________________
Date: Jan 11, 2005
Does the absence of usual airflow over the crankcase drive oil temperatures up at all? Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Furey Subject: RE: RV-List: Plenum Pics I would say that they were very effective. Unfortunately I took them off in an act of desperation to get my cyl head temps down only to find the culprit was the casting flash that was a thread on this list about a week later. Cleaning the flashing made about 30 degree difference. JF ________________________________________________________________________________
Subject: double countersunk rivnut
Date: Jan 11, 2005
Does anyone make a rivnut that is both countersunk in the back to go in a dimpled hole and also countersunk on the face so you can attach an access plate that is dimpled with a countersunk screw? I was thinking of trying to countersink a regular rivnut, but it doesn't look like there is near enough material on the head to do this. Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Subject: Attaching flaps
Date: Jan 12, 2005
Hi all, I'm just about ready to attach my flaps to the wings but I haven't riveted on the bottom skins yet. Is it necessary to rivet the bottom skins on first to accurately drill the flap hinge or can I use a heap of clecoes on the skin. I'd prefer to leave the skins off for as long as possible so I can take longer to decide on wiring and also I haven't got my pitot tube yet (waiting for the heated Dynon). It would be good to drill it out now so I can get on with the countersinking dimpling etc. and then finally prime the flap brace etc. and put it on the shelf until I'm ready to rivet. Also which kit has the NACA duct that is glued/riveted under the wing, it would be nice to put that on now before the skin is riveted on. Greg 82070 RV8 ________________________________________________________________________________
Date: Jan 12, 2005
In a message dated 1/11/05 9:10:02 PM Central Standard Time, kathleen(at)rv7.us writes: > Does the absence of usual airflow over the crankcase drive oil temperatures > up at all? >>>> Hi Kathleen- My dual plenums are very similar to Johns, just lower toward the rear with the tops installed with screws- oil temps stay between 175-190 degrees, regulated when necessary (rarely) by a butterfly valve in my oil cooler inlet (firewall mounted). This is on a 150hp Lycoming. Fotos if interested. From The PossumWorks in TN Mark Phillips ________________________________________________________________________________
Date: Jan 12, 2005
In a message dated 1/11/05 4:39:37 AM US Eastern Standard Time, 1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net writes: I don't know how dangerous leaving a lead acid battery on float charge is, but I have read that if you do leave it on float charge you need to be sure the charge voltage is no more than 13.8V for a 12V battery. Any higher and it will damage the battery. That may be why the tractor battery Dan Hopper mentioned had an untimely demise. For a cycle charge, the charge voltage can be as high as 15V. Chris, You're absolutely right about the voltage limit for floating the battery. I think the voltage varies with temperature -- being higher at lower temperatures and visa-versa. But by limiting the voltage, the current will drop to almost zero and the loss of electrolyte will therefore drop dramatically. The charger that I used (which is very common) was a simple transformer/rectifier with no regulation. This type of charger will very likely eventually over-voltage the battery. Thanks for reminding me of that. Dan Hopper Walton, IN RV-7A Waiting for the runway to dry or freeze to go flying again. ________________________________________________________________________________
Date: Jan 12, 2005
My oil temps are so low I put a butterfly valve to cut off all the air and I seldom see anything above 200 on the hotest days during climb. John ________________________________________________________________________________
Subject: RE: Attaching flaps
Date: Jan 12, 2005
You can leave the skins unriveted and just clecoed, Greg, but the main problem is getting the hinge, skin and flap brace to line up properly for drilling. The flap brace is going to sag a bit and if you were to cleco it too, then the hinge doesn't fit flush against the brace for drilling. One solution is to squeeze a couple of temporary rivets attaching the flap brace to the skin (I think I used just three...one in the middle and one near -- but not exactly at -- each end. I'd use a very small rivet so that the shop head is also quite small. And then it's easier to mount hinge and clamp it in place. Then, after you drill all the holes ('cept for those were the rivets are, of course, you can take the flap/hinge off....drill out the temporary rivets...remount the assembly using clecoes this time and drill out the holes where the temporary rivets were. Bob St. Paul From: "Greg@itmack" <greg(at)itmack.com> Subject: RV-List: Attaching flaps Hi all, I'm just about ready to attach my flaps to the wings but I haven't riveted on the bottom skins yet. Is it necessary to rivet the bottom skins on first to accurately drill the flap hinge or can I use a heap of clecoes on the skin. I'd prefer to leave the skins off for as long as possible so I can take longer to decide on wiring and also I haven't got my pitot tube yet (waiting for the heated Dynon). It would be good to drill it out now so I can get on with the countersinking dimpling etc. and then finally prime the flap brace etc. and put it on the shelf until I'm ready to rivet. Also which kit has the NACA duct that is glued/riveted under the wing, it would be nice to put that on now before the skin is riveted on. Greg 82070 RV8 ________________________________________________________________________________
Subject: Re: Now THIS is an idea!
Date: Jan 12, 2005
Not all the sound comes in through the headset. Some of it comes in right through your head. Years ago I learned that I could hear a handheld radio in my noisy Skywagon cockpit, without a headset, if I pressed the speaker to my chin, right through my beard. I got the idea on an earlier flight, in the backseat of another plane, when the top of my head intermittently touched the ceiling and I heard lots of noise at those times. Try pressing some part of your head to some part of the airframe next time you go flying and you'll see. Dave Paule Boulder, CO ________________________________________________________________________________
Date: Jan 12, 2005
I think the $100 difference may be because the AuriComm doesn't mention a Music/Cell phone interface. ________________________________________________________________________________
Subject: RV wing tip lenses
Date: Jan 12, 2005
I am in the process of installing the wing tip lenses (VA-172) on my RV8 and can't find much in the plans as to a recommended method. Any recommendations? Thanks. George ________________________________________________________________________________
Date: Jan 12, 2005
Subject: Double Sided Tape...
vansairforce I am looking for some GOOD double sided tape... The kind that just looks like a strip of glue when you peel the paper off, and really stick GOOD!!! ...not the foam crap! Anyone have any leads on this stuff? -Bill VonDane RV-8A - Colorado www.rv8a.com ________________________________________________________________________________
Subject: Ed Sterba Prop
Date: Jan 12, 2005
I'm about to test fly an RV-6A that were completing. Have an IO-360 which was put together by B.A.P. and an Ed Sterba wood prop. I don't have the cash for a constant speed prop yet but have never flown behind wood. Question I have is to anyone that may have a wood prop or who has had one. How are they? Anyone ever flown behind a prop by Sterba? I live in Arizona so most of the year am not in the rain and the RV is hangared. I'd appreciate any comments. Ivan McLaws ________________________________________________________________________________
From: "Wayne @ Aircraft Engravers" <wayne(at)engravers.net>
Subject: Re: Double Sided Tape...
Date: Jan 12, 2005
Bill, We have some really good double faced tape to hold the placards we make. The manufacturer states that the more heat and humidity the stronger it bonds. It can be removed, but you'll have to work at it. Send me your address and how much you want and I'll send some right out to you. Wayne Cahoon Aircraft Engravers (860) 653-2780 (860) 653-7324 Fax http://www.engravers.net ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> ; "vansairforce" Subject: RV-List: Double Sided Tape... > > I am looking for some GOOD double sided tape... The kind that just looks > like a strip of glue when you peel the paper off, and really stick GOOD!!! > ...not the foam crap! > > Anyone have any leads on this stuff? > > > -Bill VonDane > RV-8A - Colorado > www.rv8a.com > > > ________________________________________________________________________________
Date: Jan 12, 2005
From: Scott Bilinski <bilinski@kyocera-wireless.com>
There are numerous places that carry it. The good stuff IS EXPENSIVE, were talking $50~75 per roll. The kind you are talking about is adhesive only. I would try and find local distributors. McMaster-Carr has good stuff but not adhesive only. A place called R.S. Hughes, carries it, closest place to you is in Denver 303-371-9440. Just make sure your sitting down when they give you the price. Some of the tapes now days are amazing. I once say a strip of foam tape it was 2 pieces stuck to itself. No matter how hard you pulled it would not come apart it would stretch 1/2 inch plus, and then go pack together, amazing stuff. > >I am looking for some GOOD double sided tape... The kind that just looks >like a strip of glue when you peel the paper off, and really stick GOOD!!! >...not the foam crap! > >Anyone have any leads on this stuff? > > >-Bill VonDane >RV-8A - Colorado >www.rv8a.com > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Jan 12, 2005
In a message dated 1/12/05 10:24:50 AM Central Standard Time, bill(at)vondane.com writes: > I am looking for some GOOD double sided tape... The kind that just looks > like a strip of glue when you peel the paper off, and really stick GOOD!!! > ...not the foam crap! >>>> Scotch VHB available from McMaster-Carr is available in .020 thickness- It's foam, but pretty thin. This is some absolutely tenacious stuff- you better put it exactly where you want it 'cause you pretty much have to cut/grind it off. Not cheap, tho... http://www.mcmaster.com/ Go to page 3205 Mark Phillips ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Subject: Re: double countersunk rivnut
Date: Jan 12, 2005
Not sure I understand what you are asking for here but sounds like you want to dimple the rivet holes on a nutplate (countersunk screw type)....I just stick them in my dimple die and give em a good hard whack with a steel hammer. Works great, but is very hard on the dimple dies. I have a couple of sets of them and just use my oldest set for this. I just did a bunch of them last night for the countersunk screws on my wing inspection plates. All installed and looking good. Evan Johnson RV10 wings almost finished.... www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ----- Original Message ----- From: "Brian Kraut" <brian.kraut(at)engalt.com> Subject: RV-List: double countersunk rivnut > > Does anyone make a rivnut that is both countersunk in the back to go in a > dimpled hole and also countersunk on the face so you can attach an access > plate that is dimpled with a countersunk screw? I was thinking of trying to > countersink a regular rivnut, but it doesn't look like there is near enough > material on the head to do this. > > Brian Kraut > Engineering Alternatives, Inc. > www.engalt.com > > ________________________________________________________________________________
Subject: battery charging
Date: Jan 12, 2005
Actually, it's pretty easy to get a timer for week long cycles. Used to do it for my r.c. planes all the time. Just get two timers. The first one turns the second one on for a set amount of time and then the second one runs the charger. Do any combo you want and it works very well. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Chris W Subject: Re: RV-List: battery charging <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net> Hopperdhh(at)aol.com wrote: >So I take it you would not recommend keeping a "float" type charger on >whenever the plane is in the hangar? > > Another option to float charging that is supposed to be better for the battery, is to have the charger on a timer so it comes on for an hour a day. Get to thinking about it, that is for NiCd's. Lead acid batteries go a few weeks before there is much self discharge, where a NiCd self discharges a significant amount in the first 24 hours. If you were going to do that to a lead acid battery, an hour or 2 a week would probably be plenty. Now the trick is finding a timer that lets you go in week long cycles. Chris W ________________________________________________________________________________
Subject: Re: Ed Sterba Prop
Date: Jan 12, 2005
Ivan, Ed Sterba is a good man and makes good props. I have two of his props and have been using them for over 3yrs. A wood prop absorbs a lot of vibration and smooths things out. For the money and looks I like wood. Red Milner RV-4 N79KM based@UES ----- Original Message ----- From: "Ivan McLaws" <toejam(at)cybertrails.com> Subject: RV-List: Ed Sterba Prop > > I'm about to test fly an RV-6A that were completing. Have an IO-360 which was put together by B.A.P. and an Ed Sterba wood prop. I don't have the cash for a constant speed prop yet but have never flown behind wood. > > Question I have is to anyone that may have a wood prop or who has had one. How are they? Anyone ever flown behind a prop by Sterba? > > I live in Arizona so most of the year am not in the rain and the RV is hangared. > > I'd appreciate any comments. > > Ivan McLaws > > > _____________________________________________________ > ________________________________________________________________________________
Date: Jan 12, 2005
From: Hal Kempthorne <hal_kempthorne(at)sbcglobal.net>
Dan Parker demonstrated Scotch VHB tape to the Santa Clara CA chapter 6 or 7 years ago. He made up some 'coupons' of aluminum about .020 thick. He made a few using the tape to hold two skins together and a few using rivets. Pulling on them, the riveted ones came apart first with the rivets tearing out. I bought a roll I think about 50 feet for about $90. I've used it in a few places on my RV6a with no problems in 170 hours. I was going to use it to stick rudder skins to stiffeners but Van pointed out that flutter testing may need to be redone so I didn't use it there. Had I been on to it earlier I would have done seats, floors etc When tape or glue is needed I tend to think that 3M Scotch is best. hal RV6a "Valentine" N7HK Fiveonepw(at)aol.com wrote: In a message dated 1/12/05 10:24:50 AM Central Standard Time, bill(at)vondane.com writes: > I am looking for some GOOD double sided tape... ________________________________________________________________________________
Date: Jan 12, 2005
I have flown with Ed and his props since the early 80's and his workmanship has been outstanding. I built a Sonerai as did Ed and we put on many hours on wood props. My RV4 has 241 hrs on a 68x74 and flys like a champ -- what else? Good flying! Clyde Seager RV4 N28CS ________________________________________________________________________________
Date: Jan 12, 2005
Only a couple things to know about wood props: 1. Don't fly in the rain, and if do fly in the rain slow the rpm down as much as possible or you will grind up the varnish and the wood. Polyurethane leading edge inserts help, but they don't solve the problem. 2. Don't over torque the prop bolts, follow the manufacturers recommendations for torque and retorque. and if you smell something like burning paper, look for a fire on the ground. If you don't see one, you better land, because your prop might be working loose. Tailwinds, Doug Rozendaal ----- Original Message ----- From: "Ivan McLaws" <toejam(at)cybertrails.com> Subject: RV-List: Ed Sterba Prop > > I'm about to test fly an RV-6A that were completing. Have an IO-360 which > was put together by B.A.P. and an Ed Sterba wood prop. I don't have the > cash for a constant speed prop yet but have never flown behind wood. > > Question I have is to anyone that may have a wood prop or who has had one. > How are they? Anyone ever flown behind a prop by Sterba? > > I live in Arizona so most of the year am not in the rain and the RV is > hangared. > > I'd appreciate any comments. > > Ivan McLaws > > > ________________________________________________________________________________
Date: Jan 12, 2005
Subject: Plenum Pics (separate individual plenums)
John did nice work and there is no arguing with success. However in the book: Speed with Economy by Kent Paser, which chronicles the improvements on a Mustang II over 20 years, taking it from about 180mph to something like +230mph on a O-320, Kent tried the separate individual L&R plenums and found a cooling imbalance between the right and left bank, impart due to prop wash (in essence P-factor). He went to the one piece plenum. With this change he gained speed and lowered temps in the process. Get the book, worth it. Further an article in EAA, Sport Aviation, about engine cooling and plenums, based on a NASA report, concludes that more plenum volume improves cooling acting as a reservoir. Just another thought, John has a nice design. Even if there was a balance issue, you could restrict the cool side inlet. John has good L&R balance anyway so go figure. However, it proves a (good) plenum will cool well and be more efficient than soft seals. The soft seals work but no matter how well you make them they will leak more than a plenum. The above NASA reference found up to 50% cooling leakage in GA aircraft and seals wear and get worse over time. I think the plenum in someways is easier to install. I had seals on my RV-4; My current RV-7 project will have a single volume plenum. The ease of plenum construction for one cover vs. separate inner baffles is a factor. Good work John. Cheers, G ________________________________________________________________________________
Date: Jan 12, 2005
Subject: 12v blankets
vansairforce they have a ton of these on ebay for like $20! http://tinyurl.com/4mxey -Bill ----- Original Message ----- From: Bill VonDane Subject: Re: [RV-8] back seat heat How about this heating blanket!? http://www.sportsimportsltd.com/12volheathea.html -Bill ----- Original Message ----- From: Joel Harding Subject: Re: [RV-8] back seat heat Another alternative for warming the GIB would be a 12 V heating pad. You could sit on it, warm the tootsies one at a time, drape it over your head for that chilly draft on the back of your neck, or just fold it up and use it for a pillow. I could go on, but you get the idea. The down side is the extra cord floating around the cabin, but for only forty bucks it might be worth a try. It's on the same web page Dane mentioned, under Automotive Seat Heaters. Joel Harding (Still waiting for the paint man to finish) On Jan 3, 2005, at 6:57 AM, Dane Patterson wrote: I ordered my rear seat heat kit from Sports Imports LTD. http://www.sportsimportsltd.com/afcarseathea.html A Two Element kit for the seat bottom and the seat back sells for about $130.00. They work great for the back seat and my wife is very pleased with them. I don't think they would work for the front seat. The elements are heating pads which can be cut in length but not in width. The front seats on an RV-8 are very narrow, so this could be a problem, unless you wrap the element around the sides, and maybe the back? The elements go inside the cushion between the foam seat cushion and the cover, so they aren't really visible. You might want to order the kit and sent the elements to who ever makes up your seats. Oregon Aero glues everything together when they make their seats, so if they can incorporate the heating elements into the seats, it'll save you the trouble of having to peal the seat covers off the cushions and re-glueing them back down. Once you have all the drafts from leaking canopy skirts, etc. the electric elements in the rear seats should provide all the heat necessary for your GIB. They draw about 3 - 4 Amps until they are warm, and the thermostat cuts down the current to about 1 - 2 Amps. David Rogers wrote: Dane, Where'd you get them from ? What brand name are they ? details please. Thanks, Dave R. RV-8, Fuselage N173DR (reserved) 76 Grumman AA-1B/160hp N1649R -----Original Message----- From: Dane Patterson [mailto:DanePatterson(at)charter.net] Sent: Sunday, December 12, 2004 6:35 PM To: RV-8(at)yahoogroups.com Subject: Re: [RV-8] back seat heat I put electric seat heaters in the cushions of the back seat. My wife loves them. Dane Patterson On Dec 12, 2004, at 2:42 AM, n767rk wrote: what have builders done in the past for heat to the back seat of an RV 8. Ron Korn =95 To visit your group on the web, go to: http://groups.yahoo.com/group/RV-8/ =95 To unsubscribe from this group, send an email to: RV-8-unsubscribe(at)yahoogroups.com ________________________________________________________________________________
Date: Jan 12, 2005
Just to clarify the Battery Tender, Jr. is great to maintain, as the way you Gents are using it. However, you can NOT fully charge a depleted battery, like an Odyssey, with this kind of charger. Per the manufactures recommendation this kind of charger should be use only on a fully charged battery. The reason is the Battery Tender Jr. and similar chargers do not have the current capacity to deep charge the battery. To fully charge you need a higher amp charger. Cheers G RV-4, RV-7 (project) ________________________________________________________________________________
Date: Jan 12, 2005
I was in the same boat- not enough cash for a C/S. I ended up with a Sterba. It is a good prop and very smooth. However if you do encounter rain reduce RPM to 2000 or less or you'll sand blast the leading edges clean off. Watch the CG with the light prop, you might look at a Landol balancer ring. Jeff Point RV-6 Milwaukee WI > > ________________________________________________________________________________
Date: Jan 11, 2005
I bought one of those lightweight, in-the-ear passive headsets at Oshkosh last year. It's called Clarity Aloft. You can see it at http://www.clarityaloft.com. It really took me by surprise. This headset also uses the EAR foam replaceable earpieces. Works great. I've tried Lightspeed and Flightcom Denali ANR headsets and they can't attenuate the frequencies of noise we get in our RV's without affecting intercom and comm quality. I've never tried Bose ANRs which I've heard are well worth their price. The Clarity Aloft is pretty spendy, too, at $700 list. I paid $499 at Oshkosh which I think might be closer to what the market will bear. Mike Hilger RV-6 N207AM 650 hrs ________________________________________________________________________________
Date: Jan 12, 2005
Subject: -8A upper gear leg fairings...
vansairforce Anyone have some good ideas / photos of how to attach the upper gear leg fairings on an -8A? -Bill ________________________________________________________________________________
Date: Jan 12, 2005
Subject: Re: -8A upper gear leg fairings...
I split my fairings down the back side and bonded then on with goop. then bonded the split together with goop. Goop is great because it can be worked apart and will come off a surface by rubbing it. Of course I am making this sound much easier than it is but there again how often do you plane to remove the upper fairings? Oh, Goop can also be painted. Household Goop, Plumbers Goop Marine Goop, all at Home Depot, and its all the same stuff > >Anyone have some good ideas / photos of how to attach the upper gear leg >fairings on an -8A? > >-Bill > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Subject: Re: [VAF Mailing List] Double Sided Tape...
Date: Jan 12, 2005
Bill, If you have a good specialty auto paint and trim place in your area they will have the stuff for auto trim. I have some and it is great but you've only got one shot to get it right!!! If you don't have such a place let me know and I'll pick it up for you. Darwin N. Barrie Chandler AZ ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> ; "vansairforce" Subject: [VAF Mailing List] Double Sided Tape... > > > I am looking for some GOOD double sided tape... The kind that just looks > like a strip of glue when you peel the paper off, and really stick GOOD!!! > ...not the foam crap! > > Anyone have any leads on this stuff? > > > -Bill VonDane > RV-8A - Colorado > www.rv8a.com > > > Help save the life of a child. Support St. Jude Children's Research Hospital's > 'Thanks & Giving.' > http://us.click.yahoo.com/6iY7fA/5WnJAA/Y3ZIAA/1yWplB/TM > > Online help on this group at: > http://help.yahoo.com/help/groups/ > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/vansairforce/ > > <*> To unsubscribe from this group, send an email to: > vansairforce-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > ________________________________________________________________________________
Date: Jan 12, 2005
I have over 800 hours on a Bernie Warnke wood prop and it is wonderful to fly behind. It is as smooth as they come, looks wonderful on the ground and, after all those hours, still looks brand new. I do have a Landol harmonic balancer with it. Wood doesn't have enough inertia to keep things slowly winding down after shutdown. It always gives me chest pain to see an engine "slam" to a stop with just the wood prop on board. The balancer gives the engine more weight to swing into and also puts your CG ahead. Nice combination. Smoooooth................. Rain: yes, it will beat up any prop, including metal. I throttle back to 2100 and have had no erosion problems. I check prop bolt torque every oil change and after several months if the oil isn't ready yet. I have found them rarely at the lower end of the torque, never lose. Usually they are where they were when I checked them last. I keep the prop waxed with carnauba wax that keeps it slick, makes taking bugs off a snap and keeps the water out and looking new. Warnke props are the best looking in the business but he is not making props in this plane of existence any more. Sterba is also a good bet. Michael RV-4 N232 Suzie Q ________________________________________________________________________________
Date: Jan 12, 2005
Subject: Turbo Normalize
So who is the resident expert on turbocharging lycomings in an Rv ? I need to ask some simple questions.. Danny.. ________________________________________________________________________________
Date: Jan 12, 2005
777 hrs. on a 68 X 74 Sterba prop in front of 160 horses. All I do is use Carnuba wax,check the torque every 3 months,and keep on flying. I have the dampener installed and it is a smooth combination. Also,Ed Sterba is about the easiest person in the airplane world to work with and get along with. He seems known as one who always goes the "extra mile". I had a prop chewed up a little by the cowl pins.(my fault) Sent it back to Ed,he worked on it,returned it to me better than new in only a few days. Total cost-$00.00 --- Ivan McLaws wrote: > > > I'm about to test fly an RV-6A that were completing. > Have an IO-360 which was put together by B.A.P. and > an Ed Sterba wood prop. I don't have the cash for a > constant speed prop yet but have never flown behind > wood. > > Question I have is to anyone that may have a wood > prop or who has had one. How are they? Anyone ever > flown behind a prop by Sterba? > > I live in Arizona so most of the year am not in the > rain and the RV is hangared. > > I'd appreciate any comments. > > Ivan McLaws > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ http://my.yahoo.com ________________________________________________________________________________
Date: Jan 12, 2005
Hello Bill, I got some at Lowes or Home Depot. It's about 2" wide and was located in the area where they sell carpet. Works great. Bill Gill RV-7 Fuse & Finish Kansas City, MO -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Darwin N. Barrie RV-8(at)yahoogroups.com; rv-list(at)matronics.com Subject: RV-List: Re: [VAF Mailing List] Double Sided Tape... Bill, If you have a good specialty auto paint and trim place in your area they will have the stuff for auto trim. I have some and it is great but you've only got one shot to get it right!!! If you don't have such a place let me know and I'll pick it up for you. Darwin N. Barrie Chandler AZ ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> ; "vansairforce" Subject: [VAF Mailing List] Double Sided Tape... > > > I am looking for some GOOD double sided tape... The kind that just looks > like a strip of glue when you peel the paper off, and really stick GOOD!!! > ...not the foam crap! > > Anyone have any leads on this stuff? > > > -Bill VonDane > RV-8A - Colorado > www.rv8a.com > > > Help save the life of a child. Support St. Jude Children's Research Hospital's > 'Thanks & Giving.' > http://us.click.yahoo.com/6iY7fA/5WnJAA/Y3ZIAA/1yWplB/TM > > Online help on this group at: > http://help.yahoo.com/help/groups/ > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/vansairforce/ > > <*> To unsubscribe from this group, send an email to: > vansairforce-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > ________________________________________________________________________________
Date: Jan 12, 2005
Bill VonDane wrote: > >I am looking for some GOOD double sided tape... The kind that just looks >like a strip of glue when you peel the paper off, and really stick GOOD!!! >...not the foam crap! > >Anyone have any leads on this stuff? > > >-Bill VonDane >RV-8A - Colorado >www.rv8a.com > http://www.google.com/search?hl=en&q=3m+structural+adhesive+tape&btnG=Google+Search ________________________________________________________________________________
Subject: Re: Turbo Normalize
Date: Jan 12, 2005
> So who is the resident expert on turbocharging lycomings in an Rv ? I need to ask some simple questions.. If you're interested in turbocharging, or tubonormalizing, you really should read the lastest version of the RVator. Good article by Ken Krueger. Randy Lervold ________________________________________________________________________________
Subject: Golf Clubs in RV-8
Date: Jan 12, 2005
Received-SPF: none Anyone come up with a good way to take the golf clubs along in the RV-8? Jim Cimino RV-8 SN 80039 150+ Hours ________________________________________________________________________________
Date: Jan 12, 2005
Do a search for "3M VHB" (Very High Bond). It's available in lots of thicknesses from 2 mils on up. I work for in an adhesives group at on of the national labs and we use this stuff all of the time. I did a quick web search, here's one vendor. http://www.uline.com/Group_240.asp?pricode=wi849&wcw=google Good luck, Guy > >I am looking for some GOOD double sided tape... The kind that just looks >like a strip of glue when you peel the paper off, and really stick GOOD!!! >...not the foam crap! > >Anyone have any leads on this stuff? ________________________________________________________________________________
Subject: Re: Golf Clubs in RV-8
Date: Jan 12, 2005
Check out this 6 mod from from Doug Reeve's site: http://www.vansairforce.net/BuilderMods/NormanHunger/luggagecompartment_skirack.htm I'm considering one of these: http://www.travalite.com/ just an idea, 8's fuse is smaller, maybe a belly tank? Dave Cordner RV7A-2nd wing, fuse ordered ----- Original Message ----- From: "Jim Cimino" <jcimino(at)echoes.net> Subject: RV-List: Golf Clubs in RV-8 > > Anyone come up with a good way to take the golf clubs along in the RV-8? > > Jim Cimino > RV-8 SN 80039 > 150+ Hours > > > ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jan 12, 2005
Hal, do you happen to have the part number off the package. Thinking 4611 might be the right one. Description from 3M. Strangely enough, I think I sell this stuff and never thought about it. 3M VHB Tapes utilize high performance adhesives which have excellent longterm holding power. VHB tapes have been used for many applications in the construction industry, including the manufacture of architectural panels for curtain walls and exterior building cladding. VHB tapes are ideal for use in many interior and exterior industrial applications. In many situations they can replace rivets, spot welds, liquid adhesives, and other permanent fasteners. VHB tapes are also ideal for bonding a variety of substrates, including most metals, sealed wood, glass, many plastics, composites and painted surfaces. See this link> http://multimedia.mmm.com/mws/mediawebserver.dyn?7777771amfi7oYv7HYv777OkuFR uuuuT- Linn, if 4611 is the right thing, I will check and see what our cost is on it. Got to be able to beat $90. Bill Schlatterer 7a qb/fuse Arkansas -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Hal Kempthorne Subject: Re: RV-List: Double Sided Tape... Dan Parker demonstrated Scotch VHB tape to the Santa Clara CA chapter 6 or 7 years ago. He made up some 'coupons' of aluminum about .020 thick. He made a few using the tape to hold two skins together and a few using rivets. Pulling on them, the riveted ones came apart first with the rivets tearing out. I bought a roll I think about 50 feet for about $90. I've used it in a few places on my RV6a with no problems in 170 hours. I was going to use it to stick rudder skins to stiffeners but Van pointed out that flutter testing may need to be redone so I didn't use it there. Had I been on to it earlier I would have done seats, floors etc When tape or glue is needed I tend to think that 3M Scotch is best. hal RV6a "Valentine" N7HK Fiveonepw(at)aol.com wrote: In a message dated 1/12/05 10:24:50 AM Central Standard Time, bill(at)vondane.com writes: > I am looking for some GOOD double sided tape... ________________________________________________________________________________
"'owner-rv-list-server(at)matronics.com '"(at)matronics.com
Subject: AN Hose fittings/plenums
Date: Jan 12, 2005
non-swaged AN hose fittings were designed by AN spec to be reused. AC 43.13-1B has some info in this regard as does AC 65-9A and or -15A. That said, if they have seen a fire don't reuse them. Never install them without a mandrel. Visually ensure that no flap has been cut inside, and pressure test them as appropriate. item two Somewhere I remember someone saying that pressure flow in/around complex shapes works better if there is a pressure reservior of sufficient size around the complex shape??? For this reason I made my plenum as large as possible. The main reason I made a plenum was that there is a history of the lower hinges getting torn out, so it seemed like the extra force pushing up on the cowl could be reduced with a plenum. One thought I have had is to play with was the lower baffle outlet sizes. Not yet clear in my head on how to easily play with this, but it would be interesting to see if one could balance CHTs from this. RE comment on engine ops without a plenum,,, Don't do it for long or at high power. We run engines on test stands all the time, and they will get nicely ruin't if the student's forget the plenum install prior to a run. The cylinders seem to do alright, but there are places on the cyl heads that really get toasty... W ________________________________________________________________________________
Subject: Pressure
Date: Jan 12, 2005
Foretunately static pressure in a diverging duct will increase, and in a converging duct will decrease. Otherwise our friendly high volume turbine relatives would not work so very well. On the other hand, I do believe that anytime you change the shape, size, or turn the flow in a duct you will lose a small amount of dynamic pressure, which is converted into heat via turbulence and friction. But then static pressure and dynamic pressure are not the same thing, yet are often either confused or mis-stated thereby leading to confusion. W ________________________________________________________________________________
Subject: smoking hole
Date: Jan 12, 2005
<<<<<<< A lead-acid battery won't generate gas until the last portion of the charge. It must reach "gassing voltage" which is a bit over 13 volts. Thus, the highest risk for explosion is a battery that is just become fully charged.>>>>>>>>>>>>>> Although I have read this to be true, and experienced it everytime I have ever charged a battery, interestingly enough the three times I've seen a normal lead acid battery explode they were mostly dead, and had been fast charging at about 100 amps for less then 15 minutes. That said, in two of the cases, I was looking in the general direction of the explosion and did not see any flash, nor was there any evidence of heat damage, so I have always assumed they were pressure explosions not combustion explosions. I have also never seen an AGM blow, but mine does tend to get very warm if charged higher then 14.2V. They say they can't do boom. I don't care what they say. When I have seen batteries blow, I was more than 20 feet away, in one case I had a wall between myself and the battery, and I couldn't hear for a while due to the strength of the concussion. And in the one that was installed in a car the hood was torn partly off even though it was open at the time of failure. There is no way this is worth testing inside my airplane. (On an interesting side note, after that failure, I went outside to inspect the damage, and while viewing the wreckage the not-so-light top of the battery came wafting back to earth at a significant Gallelain velocity. Next time this happens I'm thinking of sending Mike Neville off to fetch the top before it hurts anybody.) RE trickle/float chargers, I used to believe in these until I had an experience similar to Dan's where I returned to find a smoking hole in the battery bench. The charger had gone nuts, fused its circuit protection into a lovely conductive circuit, along with its regulator and then proceeded to gag that poor battery with electrons until it did Richard Pryor imitations. I no longer leave batteries charging unattended. W ________________________________________________________________________________
Date: Jan 13, 2005
i like the solution that's out there on the rv8 yahoo list in the pictures or files area. Two large golf club sized tubes integrated in the rear fuselage. if you aren't a yahoo member and member of that group you most likely can't view them. But it would only take a minute to join if that was the case. what the heck, found the link for you. http://photos.groups.yahoo.com/group/rv-8/vwp?.dir=/golf+clubs&.src=gr&.dnm=clubs2.jpg&.view=t&.done=http%3a//photos.groups.yahoo.com/group/rv-8/lst%3f%26.dir=/golf%2bclubs%26.src=gr%26.view=t -------------- Original message -------------- > > Anyone come up with a good way to take the golf clubs along in the RV-8? > > Jim Cimino > RV-8 SN 80039 > 150+ Hours > > > > > > i like the solution that's out there on the rv8 yahoo list in the pictures or files area. Two large golf club sized tubes integrated in the rear fuselage. if you aren't a yahoo member and member of that group you most likely can't view them. But it would only take a minute to join if that was the case. what the heck, found the link for you. http://photos.groups.yahoo.com/group/rv-8/vwp?.dir=/golf+clubs.src=gr.dnm=clubs2.jpg.view=t.done=http%3a//photos.groups.yahoo.com/group/rv-8/lst%3f%26.dir=/golf%2bclubs%26.src=gr%26.view=t -------------- Original message -------------- -- RV-List message posted by: "Jim Cimino" Anyone come up with a good way to take the golf clubs along in the RV-8? Jim Cimino RV-8 SN 80039 150+ Hours ww.matronics.com/FAQ/RV-List.htm ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Re: Cleveland static ports
I remember reading somewhere some time ago about airspeed indicator error using the Cleveland static ports vs. Van's rivets. Searched archives, didn't find specifics. I believe my airspeed indicator is reading low and wondering if the Cleveland static ports may have something to do with it. Anyone with actual experience on this issue? Dale Ensing RV6A N118DE ________________________________________________________________________________
Subject: Long overdue site update
Date: Jan 13, 2005
For those of you still interested in my RV-6A web site (and let me humbly say that it's nowhere near the quality of Dan Checkoway's), I have finally gotten around to updating it. There are several new chapters mostly covering the bottom fuselage skins and some of the interior. Enjoy. Oh, it's at http://www.flion.com/rv6a/Default.htm. Patrick Kelley - RV-6A - fabricating seats ________________________________________________________________________________
Subject: Battery Chargers
Date: Jan 13, 2005
I noticed this thread the other day, but have not studied all postings. I have seen postings stating voltage limitations, etc, but havent seen anything that recommended a specific charger. Living in the NW where we do experience long periods of weather unsuitable for VFR flight, I would like to find a charger that would trickle for long periods. Anything come to mind? Additionally, are any RVers using remote batter connectors.....to keep from having to dig to the battery to charge it? Thanks for any help. Tony Marshall RV6 N91CM Polson, MT ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Re: smoking hole
Wheeler North wrote: >Although I have read this to be true, and experienced it everytime I have >ever charged a battery, interestingly enough the three times I've seen a >normal lead acid battery explode they were mostly dead, and had been fast >charging at about 100 amps for less then 15 minutes. That said, in two of >the cases, I was looking in the general direction of the explosion and did >not see any flash, nor was there any evidence of heat damage, so I have >always assumed they were pressure explosions not combustion explosions. > > You won't see an explosion of the battery as a flash because it is caused by the hydrogen and oxygen which combine colorlessly. Your explosion was probably caused by the mixture, probably under some pressure, igniting. I had this occur on my BMW motorcycle once (flooded battery). It was on a charger for a while then sitting a bit. When I rolled it out of the garage and tried to start it, the battery exploded. Fortunately, the battery is not very large and is pretty much shrouded so I still have my manhood, although there was acid all over the place. I was a little surprised :-) . Dick Tasker ________________________________________________________________________________
Subject: Bouncing
Date: Jan 13, 2005
Sometimes this internet thing is a life saver and then it can be a real pain! I just wanted to know is there a way to prevent your Yahoo account from bouncing? It works great for a couple weeks or months then I get a post that I have been "Reactivated". Why did I start getting bounced if I had not changed my settings and check into the groups frequently? Puzzling? I guess the end result is that I get reactivated to continue to view messages and discuss issues that come up in the construction. Thanks for listening(reading), Bruce G. RV8 Wings ________________________________________________________________________________
Date: Jan 13, 2005
We went with the Cleveland static ports (they look great) but they with painting they come out flush - still trying to resolve. Fortunately we have the static port on the pitot. If I had to do it again we'd go with Van's rivets. Chuck Rowbotham RV-8A >From: DWENSING(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Cleveland static ports >Date: Thu, 13 Jan 2005 09:27:19 EST > > >I remember reading somewhere some time ago about airspeed indicator error >using the Cleveland static ports vs. Van's rivets. Searched archives, >didn't find >specifics. I believe my airspeed indicator is reading low and wondering if >the Cleveland static ports may have something to do with it. >Anyone with actual experience on this issue? >Dale Ensing >RV6A N118DE > > ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Re: Bouncing
> -----Original Message----- > From: "BRUCE GRAY" <brucerv84us(at)hotmail.com> > To: RV-List(at)matronics.com > Date: Thu, 13 Jan 2005 08:34 (CDT) > Subject: RV-List: Bouncing > > > Sometimes this internet thing is a life saver and then it can be a real > pain! > I just wanted to know is there a way to prevent your Yahoo account from > bouncing? It works great for a couple weeks or months then I get a post that > I have been "Reactivated". > Why did I start getting bounced if I had not changed my settings and check > into the groups frequently? Puzzling? > I guess the end result is that I get reactivated to continue to view > messages and discuss issues that come up in the construction. > Thanks for listening(reading), > Bruce G. > RV8 Wings > Does your internet provider have any type of spam blocker? If it does it might block a message from the yahoo group by accident and cause the yahoo group to start bouncing. Mine has a blocker and it also has a area that you can goto to list addresses that you do not ever want it to block. I use to get bounces alot. I don't get bounced any more and I think it might be because I did this. ------- Surfing the web from Hopkinsville, KY RV7A web site: http://www.geocities.com/hester-hoptown/RVSite ________________________________________________________________________________
Date: Jan 13, 2005
Chuck, I bought the Cleavelands as well. I noticed the "flush" problem before paint or riveting. I chucked them up in a lathe and removed .030" off the face. This allowed them to protrude into the airstream. However, after priming and painting them (prior to riveting) I noted that they did not protrude very far anymore. I removed another .030" and now they are fine. Anyone else who bought these, consider removing .060" off the face of the port to allow it to protrude farther from the tailcone side skin. Charlie Kuss ---- Charles Rowbotham wrote: > > We went with the Cleveland static ports (they look great) but they with > painting they come out flush - still trying to resolve. Fortunately we have > the static port on the pitot. If I had to do it again we'd go with Van's > rivets. > > Chuck Rowbotham > RV-8A > > >From: DWENSING(at)aol.com > >Reply-To: rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: Re: RV-List: Cleveland static ports > >Date: Thu, 13 Jan 2005 09:27:19 EST > > > > > >I remember reading somewhere some time ago about airspeed indicator error > >using the Cleveland static ports vs. Van's rivets. Searched archives, > >didn't find > >specifics. I believe my airspeed indicator is reading low and wondering if > >the Cleveland static ports may have something to do with it. > >Anyone with actual experience on this issue? > >Dale Ensing > >RV6A N118DE > > > > > > > > > > ________________________________________________________________________________
From: "Maureen & Bob Christensen" <mchriste(at)danvilletelco.net>
Date: Jan 13, 2005
Why do they need to protrude . . . mine are flush . . . not flying yet?! But, the turtle back is on and there plumbed so will probably stay the way they are?? Thanks, Bob ----- Original Message ----- From: <chaztuna(at)adelphia.net> Subject: Re: RV-List: Cleveland static ports > > Chuck, > I bought the Cleavelands as well. I noticed the "flush" problem before paint or riveting. I chucked them up in a lathe and removed .030" off the face. This allowed them to protrude into the airstream. However, after priming and painting them (prior to riveting) I noted that they did not protrude very far anymore. I removed another .030" and now they are fine. Anyone else who bought these, consider removing .060" off the face of the port to allow it to protrude farther from the tailcone side skin. > Charlie Kuss > > ---- Charles Rowbotham wrote: > > > > We went with the Cleveland static ports (they look great) but they with > > painting they come out flush - still trying to resolve. Fortunately we have > > the static port on the pitot. If I had to do it again we'd go with Van's > > rivets. > > > > Chuck Rowbotham > > RV-8A > > > > >From: DWENSING(at)aol.com > > >Reply-To: rv-list(at)matronics.com > > >To: rv-list(at)matronics.com > > >Subject: Re: RV-List: Cleveland static ports > > >Date: Thu, 13 Jan 2005 09:27:19 EST > > > > > > > > >I remember reading somewhere some time ago about airspeed indicator error > > >using the Cleveland static ports vs. Van's rivets. Searched archives, > > >didn't find > > >specifics. I believe my airspeed indicator is reading low and wondering if > > >the Cleveland static ports may have something to do with it. > > >Anyone with actual experience on this issue? > > >Dale Ensing > > >RV6A N118DE > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 13, 2005
I agree: I don't understand this thread. I thought all static ports were supposed to be as flush as possible to get the best signal... Scott in Vancouver ----- Original Message ----- From: "Maureen & Bob Christensen" <mchriste(at)danvilletelco.net> Subject: Re: RV-List: Cleveland static ports > > > Why do they need to protrude . . . mine are flush . . . not flying yet?! > But, the turtle back is on and there plumbed so will probably stay the way > they are?? > > Thanks, > Bob > > > ----- Original Message ----- > From: <chaztuna(at)adelphia.net> > To: > Subject: Re: RV-List: Cleveland static ports > > >> >> Chuck, >> I bought the Cleavelands as well. I noticed the "flush" problem before > paint or riveting. I chucked them up in a lathe and removed .030" off the > face. This allowed them to protrude into the airstream. However, after > priming and painting them (prior to riveting) I noted that they did not > protrude very far anymore. I removed another .030" and now they are fine. > Anyone else who bought these, consider removing .060" off the face of the > port to allow it to protrude farther from the tailcone side skin. >> Charlie Kuss >> >> ---- Charles Rowbotham wrote: > >> > >> > We went with the Cleveland static ports (they look great) but they with >> > painting they come out flush - still trying to resolve. Fortunately we > have >> > the static port on the pitot. If I had to do it again we'd go with >> > Van's >> > rivets. >> > >> > Chuck Rowbotham >> > RV-8A >> > >> > >From: DWENSING(at)aol.com >> > >Reply-To: rv-list(at)matronics.com >> > >To: rv-list(at)matronics.com >> > >Subject: Re: RV-List: Cleveland static ports >> > >Date: Thu, 13 Jan 2005 09:27:19 EST >> > > >> > > >> > >I remember reading somewhere some time ago about airspeed indicator > error >> > >using the Cleveland static ports vs. Van's rivets. Searched archives, >> > >didn't find >> > >specifics. I believe my airspeed indicator is reading low and >> > >wondering > if >> > >the Cleveland static ports may have something to do with it. >> > >Anyone with actual experience on this issue? >> > >Dale Ensing >> > >RV6A N118DE >> > > >> > > >> > >> > >> > >> > >> > >> > >> >> > > > ________________________________________________________________________________
Date: Jan 13, 2005
Another option. Expensive, but ready-made: http://bowenaero.com/mt3/archives/2002/02/static_ports.html - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com chaztuna(at)adelphia.net said: > > Chuck, > I bought the Cleavelands as well. I noticed the "flush" problem before > paint or riveting. I chucked them up in a lathe and removed .030" off the > face. This allowed them to protrude into the airstream. However, after > priming and painting them (prior to riveting) I noted that they did not > protrude very far anymore. I removed another .030" and now they are fine. > Anyone else who bought these, consider removing .060" off the face of the > port to allow it to protrude farther from the tailcone side skin. > Charlie Kuss > > ---- Charles Rowbotham wrote: >> >> >> We went with the Cleveland static ports (they look great) but they with >> painting they come out flush - still trying to resolve. Fortunately we >> have >> the static port on the pitot. If I had to do it again we'd go with Van's >> rivets. >> >> Chuck Rowbotham >> RV-8A >> >> >From: DWENSING(at)aol.com >> >Reply-To: rv-list(at)matronics.com >> >To: rv-list(at)matronics.com >> >Subject: Re: RV-List: Cleveland static ports >> >Date: Thu, 13 Jan 2005 09:27:19 EST >> > >> > >> >I remember reading somewhere some time ago about airspeed indicator >> error >> >using the Cleveland static ports vs. Van's rivets. Searched archives, >> >didn't find >> >specifics. I believe my airspeed indicator is reading low and wondering >> if >> >the Cleveland static ports may have something to do with it. >> >Anyone with actual experience on this issue? >> >Dale Ensing >> >RV6A N118DE >> > >> > >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Cleveland static ports
Date: Jan 13, 2005
I have heard that there are errors associated with flush ports, perhaps it tends to create a little vacuum in the port. I've heard that people have built up little dams in front of ports to alleviate this, perhaps by creating a little local turbulence. All of this is hearsay and worth everything you paid for it. Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Jackson Subject: Re: RV-List: Cleveland static ports I agree: I don't understand this thread. I thought all static ports were supposed to be as flush as possible to get the best signal... Scott in Vancouver ----- Original Message ----- From: "Maureen & Bob Christensen" <mchriste(at)danvilletelco.net> Subject: Re: RV-List: Cleveland static ports > > > Why do they need to protrude . . . mine are flush . . . not flying yet?! > But, the turtle back is on and there plumbed so will probably stay the way > they are?? > > Thanks, > Bob > > > ----- Original Message ----- > From: <chaztuna(at)adelphia.net> > To: > Subject: Re: RV-List: Cleveland static ports > > >> >> Chuck, >> I bought the Cleavelands as well. I noticed the "flush" problem before > paint or riveting. I chucked them up in a lathe and removed .030" off the > face. This allowed them to protrude into the airstream. However, after > priming and painting them (prior to riveting) I noted that they did not > protrude very far anymore. I removed another .030" and now they are fine. > Anyone else who bought these, consider removing .060" off the face of the > port to allow it to protrude farther from the tailcone side skin. >> Charlie Kuss >> >> ---- Charles Rowbotham wrote: > >> > >> > We went with the Cleveland static ports (they look great) but they with >> > painting they come out flush - still trying to resolve. Fortunately we > have >> > the static port on the pitot. If I had to do it again we'd go with >> > Van's >> > rivets. >> > >> > Chuck Rowbotham >> > RV-8A >> > >> > >From: DWENSING(at)aol.com >> > >Reply-To: rv-list(at)matronics.com >> > >To: rv-list(at)matronics.com >> > >Subject: Re: RV-List: Cleveland static ports >> > >Date: Thu, 13 Jan 2005 09:27:19 EST >> > > >> > > >> > >I remember reading somewhere some time ago about airspeed indicator > error >> > >using the Cleveland static ports vs. Van's rivets. Searched archives, >> > >didn't find >> > >specifics. I believe my airspeed indicator is reading low and >> > >wondering > if >> > >the Cleveland static ports may have something to do with it. >> > >Anyone with actual experience on this issue? >> > >Dale Ensing >> > >RV6A N118DE >> > > >> > > >> > >> > >> > >> > >> > >> > >> >> > > > ________________________________________________________________________________
Date: Jan 13, 2005
I'm not a engineer . . . but this is what I thought I understood? It's a static vent or drain . . . they are flush on many spam cans?! The designer (Van's) should have place them (on the drawing) in an area where the pressure is as "neutral" as possible?! Bob ----- Original Message ----- From: "Ed Holyoke" <bicyclop(at)pacbell.net> Subject: RE: RV-List: Cleveland static ports > > I have heard that there are errors associated with flush ports, perhaps > it tends to create a little vacuum in the port. I've heard that people > have built up little dams in front of ports to alleviate this, perhaps > by creating a little local turbulence. All of this is hearsay and worth > everything you paid for it. > > Ed Holyoke > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Jackson > To: rv-list(at)matronics.com > Subject: Re: RV-List: Cleveland static ports > > > I agree: I don't understand this thread. > I thought all static ports were supposed to be as flush as possible to > get > the best signal... > Scott in Vancouver > ----- Original Message ----- > From: "Maureen & Bob Christensen" <mchriste(at)danvilletelco.net> > To: > Subject: Re: RV-List: Cleveland static ports > > > > > > > > Why do they need to protrude . . . mine are flush . . . not flying > yet?! > > But, the turtle back is on and there plumbed so will probably stay the > way > > they are?? > > > > Thanks, > > Bob > > > > > > ----- Original Message ----- > > From: <chaztuna(at)adelphia.net> > > To: > > Subject: Re: RV-List: Cleveland static ports > > > > > >> > >> Chuck, > >> I bought the Cleavelands as well. I noticed the "flush" problem > before > > paint or riveting. I chucked them up in a lathe and removed .030" off > the > > face. This allowed them to protrude into the airstream. However, after > > priming and painting them (prior to riveting) I noted that they did > not > > protrude very far anymore. I removed another .030" and now they are > fine. > > Anyone else who bought these, consider removing .060" off the face of > the > > port to allow it to protrude farther from the tailcone side skin. > >> Charlie Kuss > >> > >> ---- Charles Rowbotham wrote: > > > >> > > >> > We went with the Cleveland static ports (they look great) but they > with > >> > painting they come out flush - still trying to resolve. Fortunately > we > > have > >> > the static port on the pitot. If I had to do it again we'd go with > >> > Van's > >> > rivets. > >> > > >> > Chuck Rowbotham > >> > RV-8A > >> > > >> > >From: DWENSING(at)aol.com > >> > >Reply-To: rv-list(at)matronics.com > >> > >To: rv-list(at)matronics.com > >> > >Subject: Re: RV-List: Cleveland static ports > >> > >Date: Thu, 13 Jan 2005 09:27:19 EST > >> > > > >> > > > >> > >I remember reading somewhere some time ago about airspeed > indicator > > error > >> > >using the Cleveland static ports vs. Van's rivets. Searched > archives, > >> > >didn't find > >> > >specifics. I believe my airspeed indicator is reading low and > >> > >wondering > > if > >> > >the Cleveland static ports may have something to do with it. > >> > >Anyone with actual experience on this issue? > >> > >Dale Ensing > >> > >RV6A N118DE > >> > > > >> > > > >> > > >> > > >> > > >> > > >> > > >> > > >> > >> > > > > > > > > ________________________________________________________________________________
Date: Jan 13, 2005
I thought is was about breaching the boundry layer. That could be B5 tho... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Maureen & Bob Christensen said: > > > > I'm not a engineer . . . but this is what I thought I understood? > > It's a static vent or drain . . . they are flush on many spam cans?! > > The designer (Van's) should have place them (on the drawing) in an area > where the pressure is as "neutral" as possible?! > > Bob > > ----- Original Message ----- > From: "Ed Holyoke" <bicyclop(at)pacbell.net> > To: > Subject: RE: RV-List: Cleveland static ports > > >> >> I have heard that there are errors associated with flush ports, perhaps >> it tends to create a little vacuum in the port. I've heard that people >> have built up little dams in front of ports to alleviate this, perhaps >> by creating a little local turbulence. All of this is hearsay and worth >> everything you paid for it. >> >> Ed Holyoke >> >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com >> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Jackson >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: Cleveland static ports >> >> >> I agree: I don't understand this thread. >> I thought all static ports were supposed to be as flush as possible to >> get >> the best signal... >> Scott in Vancouver >> ----- Original Message ----- >> From: "Maureen & Bob Christensen" <mchriste(at)danvilletelco.net> >> To: >> Subject: Re: RV-List: Cleveland static ports >> >> >> > >> > >> > Why do they need to protrude . . . mine are flush . . . not flying >> yet?! >> > But, the turtle back is on and there plumbed so will probably stay the >> way >> > they are?? >> > >> > Thanks, >> > Bob >> > >> > >> > ----- Original Message ----- >> > From: <chaztuna(at)adelphia.net> >> > To: >> > Subject: Re: RV-List: Cleveland static ports >> > >> > >> >> >> >> Chuck, >> >> I bought the Cleavelands as well. I noticed the "flush" problem >> before >> > paint or riveting. I chucked them up in a lathe and removed .030" off >> the >> > face. This allowed them to protrude into the airstream. However, after >> > priming and painting them (prior to riveting) I noted that they did >> not >> > protrude very far anymore. I removed another .030" and now they are >> fine. >> > Anyone else who bought these, consider removing .060" off the face of >> the >> > port to allow it to protrude farther from the tailcone side skin. >> >> Charlie Kuss >> >> >> >> ---- Charles Rowbotham wrote: >> > >> >> > >> >> > We went with the Cleveland static ports (they look great) but they >> with >> >> > painting they come out flush - still trying to resolve. Fortunately >> we >> > have >> >> > the static port on the pitot. If I had to do it again we'd go with >> >> > Van's >> >> > rivets. >> >> > >> >> > Chuck Rowbotham >> >> > RV-8A >> >> > >> >> > >From: DWENSING(at)aol.com >> >> > >Reply-To: rv-list(at)matronics.com >> >> > >To: rv-list(at)matronics.com >> >> > >Subject: Re: RV-List: Cleveland static ports >> >> > >Date: Thu, 13 Jan 2005 09:27:19 EST >> >> > > >> >> > > >> >> > >I remember reading somewhere some time ago about airspeed >> indicator >> > error >> >> > >using the Cleveland static ports vs. Van's rivets. Searched >> archives, >> >> > >didn't find >> >> > >specifics. I believe my airspeed indicator is reading low and >> >> > >wondering >> > if >> >> > >the Cleveland static ports may have something to do with it. >> >> > >Anyone with actual experience on this issue? >> >> > >Dale Ensing >> >> > >RV6A N118DE >> >> > > >> >> > > >> >> > >> >> > >> >> > >> >> > >> >> > >> >> > >> >> >> >> >> > >> > >> > >> >> > > ________________________________________________________________________________
Date: Jan 13, 2005
I used Van's low-tech pop rivet static ports and my a/s and altimeter readings are dead accurate. Doug Weiler N722DW RV-4, 160 hours > > ----- Original Message ----- > From: <chaztuna(at)adelphia.net> > To: > Subject: Re: RV-List: Cleveland static ports > > >> >> Chuck, >> I bought the Cleavelands as well. I noticed the "flush" problem before > paint or riveting. I chucked them up in a lathe and removed .030" off the > face. This allowed them to protrude into the airstream. However, after > priming and painting them (prior to riveting) I noted that they did not > protrude very far anymore. I removed another .030" and now they are fine. > Anyone else who bought these, consider removing .060" off the face of the > port to allow it to protrude farther from the tailcone side skin. >> Charlie Kuss >> >> ---- Charles Rowbotham wrote: > >> > >> > We went with the Cleveland static ports (they look great) but they with >> > painting they come out flush - still trying to resolve. Fortunately we > have >> > the static port on the pitot. If I had to do it again we'd go with >> > Van's >> > rivets. >> > >> > Chuck Rowbotham >> > RV-8A >> > >> > >From: DWENSING(at)aol.com >> > >Reply-To: rv-list(at)matronics.com >> > >To: rv-list(at)matronics.com >> > >Subject: Re: RV-List: Cleveland static ports >> > >Date: Thu, 13 Jan 2005 09:27:19 EST >> > > >> > > >> > >I remember reading somewhere some time ago about airspeed indicator > error >> > >using the Cleveland static ports vs. Van's rivets. Searched archives, >> > >didn't find >> > >specifics. I believe my airspeed indicator is reading low and >> > >wondering > if >> > >the Cleveland static ports may have something to do with it. >> > >Anyone with actual experience on this issue? >> > >Dale Ensing >> > >RV6A N118DE >> > > >> > > >> > >> > >> > >> > >> > >> > >> >> > > > ________________________________________________________________________________
Date: Jan 13, 2005
Dale I am having the same problem with my static system. Speed reads low and altitude is off in the air. Waukegan Avionics shop tested the system on the ground and it checks out fine. I believe it is sucking out just a little air. Opening the alt static port corrects some of the problem. I did find two cracks in the tubing near the barbed fittings, so I replaced every bit of line and tossed out those barbed fittings. Things got worse? I believed the leak near the blind encoder compensated for the little bit of suction. I believe this all started after painting. There is a tiny little depression around Cleveland Static Ports caused by the paint. My plan is to find a heated Piper pitot mast with a static port built in. Anyone have a better idea? Dane Sheahen N838RV RV8a >From: DWENSING(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Cleveland static ports >Date: Thu, 13 Jan 2005 09:27:19 EST > > >I remember reading somewhere some time ago about airspeed indicator error >using the Cleveland static ports vs. Van's rivets. Searched archives, >didn't find >specifics. I believe my airspeed indicator is reading low and wondering if >the Cleveland static ports may have something to do with it. >Anyone with actual experience on this issue? >Dale Ensing >RV6A N118DE > > ________________________________________________________________________________
Date: Jan 13, 2005
Lucky, I can't get anywhere with this link. What is the name of the group? Jim ----- Original Message ----- From: "lucky" <luckymacy(at)comcast.net> Subject: Re: RV-List: Golf Clubs in RV-8 > > i like the solution that's out there on the rv8 yahoo list in the pictures or files area. Two large golf club sized tubes integrated in the rear fuselage. if you aren't a yahoo member and member of that group you most likely can't view them. But it would only take a minute to join if that was the case. > > what the heck, found the link for you. > > http://photos.groups.yahoo.com/group/rv-8/vwp?.dir=/golf+clubs&.src=gr&.dnm=clubs2.jpg&.view=t&.done=http%3a//photos.groups.yahoo.com/group/rv-8/lst%3f%26.dir=/golf%2bclubs%26.src=gr%26.view=t > > -------------- Original message -------------- > > > > > Anyone come up with a good way to take the golf clubs along in the RV-8? > > > > Jim Cimino > > RV-8 SN 80039 > > 150+ Hours > > > > > > > > > > > > > > i like the solution that's out there on the rv8 yahoo list in the pictures or files area. Two large golf club sized tubes integrated in the rear fuselage. if you aren't a yahoo member and member of that group you most likely can't view them. But it would only take a minute to join if that was the case. > > what the heck, found the link for you. > > http://photos.groups.yahoo.com/group/rv-8/vwp?.dir=/golf+clubs.src=gr.dnm=clubs2.jpg.view=t.done=http%3a//photos.groups.yahoo.com/group/rv-8/lst%3f%26.dir=/golf%2bclubs%26.src=gr%26.view=t > > -------------- Original message -------------- > > -- RV-List message posted by: "Jim Cimino" > > Anyone come up with a good way to take the golf clubs along in the RV-8? > > Jim Cimino > RV-8 SN 80039 > 150+ Hours > > > ww.matronics.com/FAQ/RV-List.htm > > ________________________________________________________________________________
Date: Jan 13, 2005
Drill the port out to .030 and insert Van's pop rivet? Mike Ducote N63PM RV6 ----- Original Message ----- From: "Dane Sheahen" <dane(at)mutualace.com> Subject: RE: RV-List: Cleveland static ports > > Dale > I am having the same problem with my static system. Speed reads low and > altitude is off in the air. Waukegan Avionics shop tested the system on the > ground and it checks out fine. I believe it is sucking out just a little > air. Opening the alt static port corrects some of the problem. I did find > two cracks in the tubing near the barbed fittings, so I replaced every bit > of line and tossed out those barbed fittings. Things got worse? I believed > the leak near the blind encoder compensated for the little bit of suction. > I believe this all started after painting. There is a tiny little > depression around Cleveland Static Ports caused by the paint. My plan is to > find a heated Piper pitot mast with a static port built in. > > Anyone have a better idea? > > Dane Sheahen > N838RV RV8a > > ________________________________________________________________________________
From: "LML Klingmuller" <l_klingmuller(at)earthlink.net>
Subject: Handheld nav/com radio
Date: Jan 13, 2005
I am thinking of buying a backup hand held radio with the VOR option similar to the SP-200A model sold by Sporty's. My questions are 1) would the unit work with the short flexible antenna attached to the unit or would the radio require an antenna connector to the airplanes com antenna? 2) is Sporty the best on the market for $299 with the VOR option? and 3) can I just plug my headset in case the radio goes blank and still have good communications? Some of the utralight seem to use these units. Some are louse when transmitting (lots of background noise) while others seem to be acceptable. ________________________________________________________________________________
Date: Jan 13, 2005
Glue a dome from a rivet or whatever onto the flush static port. If nothing else it might help isolate the problem. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Mike Ducote [mailto:mikejd1(at)cox.net] > Sent: Thursday, January 13, 2005 6:52 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Cleveland static ports > > > Drill the port out to .030 and insert Van's pop rivet? > > Mike Ducote > N63PM RV6 > ----- Original Message ----- > From: "Dane Sheahen" <dane(at)mutualace.com> > To: > Subject: RE: RV-List: Cleveland static ports > > > > > > Dale > > I am having the same problem with my static system. Speed > reads low and > > altitude is off in the air. Waukegan Avionics shop tested > the system on > the > > ground and it checks out fine. I believe it is sucking out > just a little > > air. Opening the alt static port corrects some of the > problem. I did > find > > two cracks in the tubing near the barbed fittings, so I > replaced every bit > > of line and tossed out those barbed fittings. Things got worse? I > believed > > the leak near the blind encoder compensated for the little > bit of suction. > > I believe this all started after painting. There is a tiny little > > depression around Cleveland Static Ports caused by the > paint. My plan is > to > > find a heated Piper pitot mast with a static port built in. > > > > Anyone have a better idea? > > > > Dane Sheahen > > N838RV RV8a > > > > > > > ======== > ======== > ======== > > > > > > ________________________________________________________________________________
From: "Wayne Pedersen" <wayne(at)pedersentransport.com>
Subject: aluminum panel finish
Date: Jan 13, 2005
I seen a panel in a RV6a that was anodized in "clear". It gave the cockpit a high tech look and the pilot said that there was no issues with glare etc. Now here is my dilemma. Despite being extra careful cutting and shaping the panel I still managed to get a couple of scratches and "polished" areas on it were the scotchbrite pad hit it in deburring. These need to be eliminated before anodizing or they will show through. I want to create a satin/brushed finish on the aluminum before anodizing but the anadizor couldn't give me any ideas how to do that. It there a procedure that I can use to create the Satin or brushed look on the aluminum? Thanks - remember this list hasn't failed me yet..... Wayne S.Alberta RV7a panel work in -35 weather -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Date: Jan 13, 2005
This is from the recent Aeroelectric list archives. It's part of a discussion about battery maintainers, and this is by Bob Nuckolls. Terry During my RAC sponsored battery study earlier this year I asked about this technology at both Hawker and Concord. The Hawker guy (marketing type) didn't have an opinion and was not familiar with them. Concord guy (vp of marketing but technically very savy guy) said they tried on an old battery that they ran through a couple of discharge-recharge cycles and recovered a lot of the battery's capacity . . . but repeated the experiment on a similar battery with similar results but without the "de-sulfator" . . . I have one that I purchased and used it on a barely functional battery pulled from my father-in-law's car. After a week .1C charge/ 1C discharge cycles, I measured an increase in capacity from about 10 a.h. (barely started the car) to about 16 a.h. Cranking current test values rose moderately from about 150A to 220A. I wouldn't say these critters will RECOVER a battery. I just haven't had time to set up the experiment to compare the life of two new batteries run on the same cycles but with de-sulfator installed on one battery. It's on the list of things to do. In the mean time, every battery manufacturer I talked to was unanimous in their endorsement of battery maintainers . . . ESPECIALLLY for flooded batteries. I use the Battery Minders here in the shop. I picked up the Harbor Freight product to check it out. I'm running a battery down now and will put a data acquisition system on it to see how it compares with the Battery Minder. Anyone wanting to diddle with the desulfators can do a Google search and get a TON of data on products to purchase and projects to build. Bob . . . ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Oil cooler attached to engine mount
List, Recently there was a discussion here about attaching the oil cooler to the engine mount instead of the rear baffle. There were even a couple of links showing the cooler installed this way. I'm preparing for my first annual and contemplating moving the oil cooler from the baffle as I've already had to re-work the baffle due to crack/break from the vibration of the oil cooler. Question... how did you attach the cooler to the mount? Pictures would be appreciated. Thanks, Doug -7A __________________________________ http://my.yahoo.com ________________________________________________________________________________
Subject: Re: aluminum panel finish
Date: Jan 13, 2005
> Very carefully with a belt sander. The wider the better. You also need > to make a 'fence' so that each pass is parallel to the first. The > machine I saw that does 'brushed aluminum' uses a belt about 4' wide and > 4' long (4'X8' belt!!!), very coarse grit. > Linn This sounds way too aggressive to me. We use these wheels, mostly on stainless to create a uniform brushed surface: http://checkoway.com/url/?s=7add016d This may be hard to do now that you have your holes cut out. I think I might experiment with using a relatively fine abrasive, 180 grit maybe on a flatboard sander to take long passes down the length of the panel and see how you like that look. Any large woodworking shop will have a drum surface sander which probably could put a uniform finish on your panel in about a minute... http://checkoway.com/url/?s=ad01dc6b Good luck! ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Oil cooler flanges cracking revisited
I know this is yesterday's news, but I finally got around to looking at and modifying my oil cooler mounts. I have the same setup as Dan did and he experienced some pretty bad cracking. I was going to put washers under the spacers, but at the urging of the local greybeard A&P I put some Al angle in there as well. Cheap hardware store angle is better for this than aircraft grade, because it does not have the radius fillet on the inner corner, making it easier to drill the holes close to the edge. Pics at http://home.mindspring.com/~rv6/RV6site/plenum.htm about 2/3 down the page. Jeff Point RV-6 Milwaukee WI ________________________________________________________________________________
Date: Jan 13, 2005
Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
"RV9 Group"
Subject: RV-9A kit
Date: Jan 13, 2005
After a lot of soul searching I am getting out of aviation and sticking with cars, boats, and motorcycles. Selling my cherokee and the kit is next. I know, I know. But, I gotta do what I gotta do. My Harley is calling. RV-9A: QB fuselage, 95% complete wings, 70% complete empennage, fully primed, dual lights, brakes and steps, AOA installed in wing. Cost around $22,000 to buy equivalent new now, cost around $16,500 for all the parts to me. Will look for around $15,000. Curt Hoffman Cincinnati area contact at choffman9(at)cinci.rr.com ________________________________________________________________________________
Date: Jan 13, 2005
Wayne 2-3 minutes soaking in a vat of AlumiPrep (or similar) diluted 5 to 1 with water will give you a nice satin finish. Charlie Kuss > >I seen a panel in a RV6a that was anodized in "clear". It gave the cockpit a >high tech look and the pilot said that there was no issues with glare etc. > >Now here is my dilemma. Despite being extra careful cutting and shaping the >panel I still managed to get a couple of scratches and "polished" areas on >it were the scotchbrite pad hit it in deburring. These need to be eliminated >before anodizing or they will show through. I want to create a satin/brushed >finish on the aluminum before anodizing but the anadizor couldn't give me >any ideas how to do that. It there a procedure that I can use to create the >Satin or brushed look on the aluminum? > >Thanks - remember this list hasn't failed me yet..... > >Wayne >S.Alberta RV7a panel work in -35 weather > > >-- >Checked by AVG Anti-Virus. > > ________________________________________________________________________________
Date: Jan 13, 2005
In a message dated 1/13/05 9:32:52 PM Eastern Standard Time, azpilot(at)extremezone.com writes: > . Replaced with the pop rivet method > and worked fine. Paul, How did you go about changing the Cleveland ports to the pop rivets? Dale Ensing ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Re: RV-9A kit
do you have any pics to email of the kit and work done. thanks, Wayne Petrus ________________________________________________________________________________
Date: Jan 13, 2005
I didn't replace them. The gentleman who bought my airplane did it, and subsequently told me that it fixed the problem. I'm not sure how he did it, actually. I am in agreement with the poster that said the installation is hokey. I mean come on, a Pop Rivet? It was a no brainer to put the cleveland ports there, but it sounds as if there are some common issues with that. Paul Besing RV-6A Sold RV-10 Soon Kitlog Builder's Software www.kitlog.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of DWENSING(at)aol.com Subject: Re: RV-List: Cleveland static ports In a message dated 1/13/05 9:32:52 PM Eastern Standard Time, azpilot(at)extremezone.com writes: > . Replaced with the pop rivet method > and worked fine. Paul, How did you go about changing the Cleveland ports to the pop rivets? Dale Ensing ________________________________________________________________________________
Date: Jan 13, 2005
On Jan 13, 2005, at 9:16 PM, Evan and Megan Johnson wrote: > > > I for one think the pop rivet looks hokey as hell. Yeah, but it works :-) > " I certainly would > like to know why a flush port would not work as well as a pop rivet. Because it's been tried and it works. The location apparently doesn't provide a perfect "static" source, but the local flow effects of the pop rivet dome offset this. If Kevin Horton is reading this thread he could explain it better > I have > just recently installed a pair of flushies on my tailcone and they look > cool.......but if they don't work as well I will certainly reconsider. You can add kludges to make them work (a dam behind the port will raise pressure/lower IAS, and one ahead of the port will have the opposite effect). I have seen this done on factory aircraft, but it's just easier to copy what's worked in the past rather than reinvent. > . Frankly the biggest issue I > had with the rivet is the method of attachment to the tubing....gobs of > sealant just doesn't feel right Me too. I can tell you what I did, although I'm sure there are better methods. I couldn't get the sealant to work right for me, so I got some small (.125 OD IIRC) brass tubing from the hobby shop and flared the ends of two pieces about an inch long. I glued these over the "shop head" of the pop rive with JB-weld. This gave me a nice place to put the tubing, looked OK, and required no great skill. > Liking this debate! Me too James Freeman getting closer ________________________________________________________________________________
Date: Jan 13, 2005
Lots of talk about Cleveland but it's not clear if is this related specifically to the Cleveland design/brand. I just bought a set from ACS because I also didn't like the looks of the pop rivet but now you have me wondering if this problem pertains to the Cleveland design or all "flush" designs. Is this also a problem with the ACS ports? BTW,... by "flush" do you mean that nothing of the port extends past the skin or just that the port orifice is flush with area immediately surrounding it. My ports look about like a quarter resting on the skin with a hole in the middle. Thanks Bill S 7a QB/fuse -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of James Freeman Subject: Re: RV-List: Cleveland static ports On Jan 13, 2005, at 9:16 PM, Evan and Megan Johnson wrote: > > > I for one think the pop rivet looks hokey as hell. Yeah, but it works :-) > " I certainly would > like to know why a flush port would not work as well as a pop rivet. Because it's been tried and it works. The location apparently doesn't provide a perfect "static" source, but the local flow effects of the pop rivet dome offset this. If Kevin Horton is reading this thread he could explain it better > I have > just recently installed a pair of flushies on my tailcone and they look > cool.......but if they don't work as well I will certainly reconsider. You can add kludges to make them work (a dam behind the port will raise pressure/lower IAS, and one ahead of the port will have the opposite effect). I have seen this done on factory aircraft, but it's just easier to copy what's worked in the past rather than reinvent. > . Frankly the biggest issue I > had with the rivet is the method of attachment to the tubing....gobs of > sealant just doesn't feel right Me too. I can tell you what I did, although I'm sure there are better methods. I couldn't get the sealant to work right for me, so I got some small (.125 OD IIRC) brass tubing from the hobby shop and flared the ends of two pieces about an inch long. I glued these over the "shop head" of the pop rive with JB-weld. This gave me a nice place to put the tubing, looked OK, and required no great skill. > Liking this debate! Me too James Freeman getting closer ________________________________________________________________________________
Date: Jan 13, 2005
In a message dated 1/13/2005 4:24:22 P.M. Pacific Standard Time, wayne(at)pedersentransport.com writes: Despite being extra careful cutting and shaping the panel I still managed to get a couple of scratches and "polished" areas on it were the scotchbrite pad hit it in deburring. These need to be eliminated before anodizing or they will show through. I want to create a satin/brushed finish on the aluminum before anodizing but the anodizer couldn't give me any ideas how to do that. It there a procedure that I can use to create the Satin or brushed look on the aluminum? =============================== Find a machine shop that does "graining" for a brushed or sanded appearance or have it "glass bead blasted" for a matte finish. GV (RV-6A N1GV O-360-A1A, C/S, Flying 736hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jan 13, 2005
In a message dated 1/13/2005 8:29:20 P.M. Pacific Standard Time, billschlatterer(at)sbcglobal.net writes: Lots of talk about Cleveland but it's not clear if is this related specifically to the Cleveland design/brand. I just bought a set from ACS because I also didn't like the looks of the pop rivet but now you have me wondering if this problem pertains to the Cleveland design or all "flush" designs. Is this also a problem with the ACS ports? =========================== Cleveland doesn't make these ports, Cleaveland Tool does. My ACS ones work great and they are flush. GV (RV-6A N1GV O-360-A1A, C/S, Flying 736hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Re: Handheld nav/com radio
clamav-milter version 0.80j on localhost I can't speak for the Sporty's model but I have a 10 year old Icom A22. This has been replace with a model that is cheaper and has more features. 1) The "rubber ducky" antenna seems to do a fine job both directions. This radio has a standard BNC antenna connector which is the same as your aircraft radio . Hooking in to the aircraft antenna would certainly increase the range. 2) $299 is a pretty good deal for a hand held and I doubt if you can find anything cheaper. The Icom A24 is $425. 3) The SP200 user's manual lists a headset adapter on page 29. You plug in the adapter and the radio speaker and microphone are disabled. Not sure if this is included but I couldn't find it on the list of accessories for sale. Here is the link to the user's manual. http://www.sportys.com/pdf/sp200.pdf I like using my radio when driving. I'll tune in ATIS or AWOS. Mark LML Klingmuller wrote: > >I am thinking of buying a backup hand held radio with the VOR option similar to the SP-200A model sold by Sporty's. >My questions are 1) would the unit work with the short flexible antenna attached to the unit or would the radio require an antenna connector to the airplanes com antenna? 2) is Sporty the best on the market for $299 with the VOR option? and 3) can I just plug my headset in case the radio goes blank and still have good communications? >Some of the utralight seem to use these units. Some are louse when transmitting (lots of background noise) while others seem to be acceptable. > > > > ________________________________________________________________________________
Date: Jan 13, 2005
This is going back many years ago I think, but Kevin Horton was part of a team that did some static port testing on an airline type of plane. Kevin posted quite a bit of information on the RV-List but also had a very good link on his website that I bookmarked talking about static ports. Unfortunately, Kevin has totally revamped his website (very very nice I might add) and my link doesn't work anymore. Maybe someone who's interested can find the article(s). http://go.phpwebhosting.com/~khorton/rv8/ >>> >>> >>>We went with the Cleveland static ports (they look great) but they with >>>painting they come out flush - still trying to resolve. Fortunately we >>>have >>>the static port on the pitot. If I had to do it again we'd go with Van's >>>rivets. >>> >>>Chuck Rowbotham >>>RV-8A >>> >>> >>> >>>>From: DWENSING(at)aol.com >>>>Reply-To: rv-list(at)matronics.com >>>>To: rv-list(at)matronics.com >>>>Subject: Re: RV-List: Cleveland static ports >>>>Date: Thu, 13 Jan 2005 09:27:19 EST >>>> >>>> >>>>I remember reading somewhere some time ago about airspeed indicator >>>> >>>> >>>error >>> >>> >>>>using the Cleveland static ports vs. Van's rivets. Searched archives, >>>>didn't find >>>>specifics. I believe my airspeed indicator is reading low and wondering >>>> >>>> >>>if >>> >>> >>>>the Cleveland static ports may have something to do with it. >>>>Anyone with actual experience on this issue? >>>>Dale Ensing >>>>RV6A N118DE >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >> >> > > > > -- Mike Nellis Austin, TX CMRA #32 Honda RC51 '97 YZF1000 '47 Stinson 108-2; RV6 (Fuselage) http://bmnellis.com ________________________________________________________________________________
Date: Jan 14, 2005
Subject: Re: battery charging
In a message dated 1/12/2005 9:29:52 A.M. Pacific Standard Time, davemader(at)bresnan.net writes: So I take it you would not recommend keeping a "float" type charger on >whenever the plane is in the hangar? ================================== I have used the three BRW EZ Charger battery tenders I've had for over 20 yrs on various planes, cars and motorcycles unattended and they work well. They have reverse polarity protection, put out 13.3VDC and are two stage 600mA max and step down to 35mA unattended. I think they are still in business and the last numbers I have for them are 312-369-5675 (and Tollfree 800-426-6008). GV (RV-6A N1GV O-360-A1A, C/S, Flying 736hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jan 13, 2005
Hello Wayne I have used Draino dissolved about 1 - 2 tablespoons in a glass pan to etch 1 foot square radio panels. Wear goggles and do it outside. It smokes and stinks a lot but makes a nice satin finish. Blair Amundsen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Wayne Pedersen Subject: RV-List: aluminum panel finish I seen a panel in a RV6a that was anodized in "clear". It gave the cockpit a high tech look and the pilot said that there was no issues with glare etc. Now here is my dilemma. Despite being extra careful cutting and shaping the panel I still managed to get a couple of scratches and "polished" areas on it were the scotchbrite pad hit it in deburring. These need to be eliminated before anodizing or they will show through. I want to create a satin/brushed finish on the aluminum before anodizing but the anadizor couldn't give me any ideas how to do that. It there a procedure that I can use to create the Satin or brushed look on the aluminum? Thanks - remember this list hasn't failed me yet..... Wayne S.Alberta RV7a panel work in -35 weather -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Date: Jan 14, 2005
This is something that I specifically noticed and then started taking a look at on production air planes. I have yet to see a "Flush" static port. I have looked at a C182, C210, C335, PC6 Pilatus Porter, Baron BE55 and last but not least my own RV7. All of them have the static port protrude into the air stream. Not one of them are flush. As my RV7 is yet to fly I cannot comment on the actual result, but I am betting that the flush mount of the static port has a lot to do with the problems that are being reported. I have also heard (as someone else commented) that the port needs to protrude its head above the boundary layer. Also not sure whether that is urban legend or the truth. As I hope to fly in the next two weeks I will post my results once I see how it works out. Dennis RV7 71041 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill Schlatterer Subject: RE: RV-List: Cleveland static ports Lots of talk about Cleveland but it's not clear if is this related specifically to the Cleveland design/brand. I just bought a set from ACS because I also didn't like the looks of the pop rivet but now you have me wondering if this problem pertains to the Cleveland design or all "flush" designs. Is this also a problem with the ACS ports? BTW,... by "flush" do you mean that nothing of the port extends past the skin or just that the port orifice is flush with area immediately surrounding it. My ports look about like a quarter resting on the skin with a hole in the middle. Thanks Bill S 7a QB/fuse -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of James Freeman Subject: Re: RV-List: Cleveland static ports On Jan 13, 2005, at 9:16 PM, Evan and Megan Johnson wrote: > > > I for one think the pop rivet looks hokey as hell. Yeah, but it works :-) > " I certainly would > like to know why a flush port would not work as well as a pop rivet. Because it's been tried and it works. The location apparently doesn't provide a perfect "static" source, but the local flow effects of the pop rivet dome offset this. If Kevin Horton is reading this thread he could explain it better > I have > just recently installed a pair of flushies on my tailcone and they look > cool.......but if they don't work as well I will certainly reconsider. You can add kludges to make them work (a dam behind the port will raise pressure/lower IAS, and one ahead of the port will have the opposite effect). I have seen this done on factory aircraft, but it's just easier to copy what's worked in the past rather than reinvent. > . Frankly the biggest issue I > had with the rivet is the method of attachment to the tubing....gobs of > sealant just doesn't feel right Me too. I can tell you what I did, although I'm sure there are better methods. I couldn't get the sealant to work right for me, so I got some small (.125 OD IIRC) brass tubing from the hobby shop and flared the ends of two pieces about an inch long. I glued these over the "shop head" of the pop rive with JB-weld. This gave me a nice place to put the tubing, looked OK, and required no great skill. > Liking this debate! Me too James Freeman getting closer ________________________________________________________________________________
Subject: Re: Static ports Cleveland/Van's/others....
Date: Jan 14, 2005
There is a much nicer way!!! Technically better - uses AN type connections if desired. Much prettier - and "aircraft quality" (what-ever that is ! ) to boot. Step 1 : find a dead Grumman (AA1, AA5, similar) Step 2 : extract static system (usually left in the carcass) and clean up Step 3 : install in RV -- End of procedure.. John Kent RV-4 EI-DIY Ireland ________________________________________________________________________________
Date: Jan 14, 2005
True. I preflight a C-172 everyday, and the static port is a raised circle about the size of a quarter with a hole in it. The circle is raised about 1/8" if I were to guess without looking at it. Someone could make a non-recessed machined port, ala cleveland that still would be a much better installation than a pop rivet. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dennis Parker Subject: RE: RV-List: Cleveland static ports This is something that I specifically noticed and then started taking a look at on production air planes. I have yet to see a "Flush" static port. I have looked at a C182, C210, C335, PC6 Pilatus Porter, Baron BE55 and last but not least my own RV7. All of them have the static port protrude into the air stream. Not one of them are flush. As my RV7 is yet to fly I cannot comment on the actual result, but I am betting that the flush mount of the static port has a lot to do with the problems that are being reported. I have also heard (as someone else commented) that the port needs to protrude its head above the boundary layer. Also not sure whether that is urban legend or the truth. As I hope to fly in the next two weeks I will post my results once I see how it works out. Dennis RV7 71041 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill Schlatterer Subject: RE: RV-List: Cleveland static ports Lots of talk about Cleveland but it's not clear if is this related specifically to the Cleveland design/brand. I just bought a set from ACS because I also didn't like the looks of the pop rivet but now you have me wondering if this problem pertains to the Cleveland design or all "flush" designs. Is this also a problem with the ACS ports? BTW,... by "flush" do you mean that nothing of the port extends past the skin or just that the port orifice is flush with area immediately surrounding it. My ports look about like a quarter resting on the skin with a hole in the middle. Thanks Bill S 7a QB/fuse -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of James Freeman Subject: Re: RV-List: Cleveland static ports On Jan 13, 2005, at 9:16 PM, Evan and Megan Johnson wrote: > > > I for one think the pop rivet looks hokey as hell. Yeah, but it works :-) > " I certainly would > like to know why a flush port would not work as well as a pop rivet. Because it's been tried and it works. The location apparently doesn't provide a perfect "static" source, but the local flow effects of the pop rivet dome offset this. If Kevin Horton is reading this thread he could explain it better > I have > just recently installed a pair of flushies on my tailcone and they look > cool.......but if they don't work as well I will certainly reconsider. You can add kludges to make them work (a dam behind the port will raise pressure/lower IAS, and one ahead of the port will have the opposite effect). I have seen this done on factory aircraft, but it's just easier to copy what's worked in the past rather than reinvent. > . Frankly the biggest issue I > had with the rivet is the method of attachment to the tubing....gobs of > sealant just doesn't feel right Me too. I can tell you what I did, although I'm sure there are better methods. I couldn't get the sealant to work right for me, so I got some small (.125 OD IIRC) brass tubing from the hobby shop and flared the ends of two pieces about an inch long. I glued these over the "shop head" of the pop rive with JB-weld. This gave me a nice place to put the tubing, looked OK, and required no great skill. > Liking this debate! Me too James Freeman getting closer ________________________________________________________________________________
Date: Jan 14, 2005
On Jan 14, 2005, at 12:32 AM, Dennis Parker wrote: > > This is something that I specifically noticed and then started taking a > look at on production air planes. I have yet to see a "Flush" static > port. I know of at least one: we used to own a 1978 Cessna 337. The static ports were flush (very small holes in the skin). Curiously, they were located well forward on the fuselage, maybe 4 feet behind the front propeller. I would have thought this would be a "dirty air" location, but they worked perfectly. The pitot source consisted of two small holes drilled in the leading edge of the left wing strut. A previous airplane (Navion) had a disc insert in the skin of the aft fuse, like the Cleveland, but it had a machined "nipple" around the hole that looked a lot like a pop rivet head. > ________________________________________________________________________________
Subject: Re: Cleveland static ports
Date: Jan 14, 2005
I have the Cleveland flush ports also. Mine are literally flush. While painting it was obvious that the port would be recessed to the paint surface, so dispite all the placards I've seen around static ports that said "do not paint" I painted them, and color sanded and polished them with rest of the plane. Then I ran a drill bit thru the center hole to clean it out. I figured I had nothing to loose because I'd have to put a rivet in it anyway after flight testing. So far no rivet and no problem. I read about the same AS, and Alt as 3 other planes I've flown alongside of, and I've held it just over the runway to 90kts and my altimeter reading didn't change. I'm not suggesting anyone else do this, but it worked for me. Chris Brooks ________________________________________________________________________________
Subject: Re: How to Rebuild an 200hp IO 360 A1A
Date: Jan 14, 2005
I found a 200hp IO 360 A1A advertised for sale. The ad reads. 200hp IO 360 A1A. First Run. NDH, Cleaned, Painted, New Starter, Rings, scamshaft, Bearings, Exhaust Valves, Magnetos, etc, Log book. Not Certified, you assemble. $15000.00Canadian Dollars, $12400.00US dollars. I havent called the seller yet, I thought I would check with you guys to find out. 1)How hard is it to rebuild one of these? About the same as a regular car engine I would imagine??? 2)Where would I find a good, detailed, laymens manual on rebuilding these engines? 3)What do you think of the price? Im a strong believer that if you arent getting something with a warranty you should get it very cheap to make up for the most sever of possibilities ie cracked case, cracked crank ect. 4)What questions should I ask when I call? I know most of us buy our engines already rebuilt buy reputable companies but I do believe the experimental category allows us to rebuild engines and use them as uncertified in experimental planes. Kevin Yellowknife, NT, Canada RV-8 Wanna Be Builder From: "Chris Brooks" <brooksrv6(at)hotmail.com> Subject: Re: RV-List: Cleveland static ports Date: Fri, 14 Jan 2005 08:47:50 -0600 I have the Cleveland flush ports also. Mine are literally flush. While painting it was obvious that the port would be recessed to the paint surface, so dispite all the placards I've seen around static ports that said "do not paint" I painted them, and color sanded and polished them with rest of the plane. Then I ran a drill bit thru the center hole to clean it out. I figured I had nothing to loose because I'd have to put a rivet in it anyway after flight testing. So far no rivet and no problem. I read about the same AS, and Alt as 3 other planes I've flown alongside of, and I've held it just over the runway to 90kts and my altimeter reading didn't change. I'm not suggesting anyone else do this, but it worked for me. Chris Brooks ________________________________________________________________________________
Subject: Belly com antenna
Date: Jan 14, 2005
I've got a question for the avionics gurus out there. Background: RV4, Flybuddy LORAN with belly antenna, Terra Tx720 with antenna midway between aft canopy and vert. stab.. The problem: Installed GX50 GPS unit, with antenna under canopy just aft of rear seat. coax run opposite side of fuse as com coax. Distance between antennas = 32". I get interference on ALL the freqs listed in installation manual; total signal loss on GPS when transmitting. Various other freqs - no problem. I've bought another antenna to match the hole left from the LORAN antenna on the belly. A friend is building a Low-loss RF switch, so I can use either antenna, as I expect blind spots with belly antenna, especially on the ground. Theory is that I can use the belly antenna when on approach, and avoid signal loss. The belly ant. is just aft the firewall and an inch or so starboard of centerline, between the gearlegs. Does anyone else have a com ant. there? Does anyone have a similar GPS antenna mount with no interference? Could the problem be the Terra? I don't want to move either antenna and patch holes. John DeCuir RV-4, N204CP 460 hrs TTAE Salinas, CA ________________________________________________________________________________
Date: Jan 14, 2005
Hi All- Well,, I didn't sleep in a holiday inn express last night, but I did get a pretty good night's sleep... My rationalization here is that the rivet is very cheap and effective when applied correctly, and as such fits Van's bill perfectly. But, the shape of the fuselage by itself as well as the shape of the rivet head each cause variations on the local static pressure just as an airfoil does. Given that the rivet head should cause a slight reduction in the local static pressure, it follows that it should be located somewhere where the static pressure tends to be higher. The farther aft you go on that flat fuselage side, the higher the pressure, a la pressure recovery wheel pants. So, if I were to employ flush static ports instead of the rivet heads, I'd move them farther forward. How far forward? Wherever the designer of the original system suggested.... gm ________________________________________________________________________________
Date: Jan 14, 2005
Hi Wayne- I don't know for sure about bare aluminum, but the grey scotchbrite pads (fine) do a great job of putting a scratch less, matte finish on paint. The white (extra fine) will tend to burnish a shine back into the surface. Check with woodworking suppliers, if you're interested. Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jan 14, 2005
Subject: Re: Alternator mounting problem
I purchased a 87-89 Suzuki Samari alternator from Autozone. Used their web and saved a few $$. Alternator was $96 plus $50-60 for core charge. Rated at 55 amps, Lifetime warranty. Made a bracket to mount it. Basically duplicated the one that was on the engine with the original alternator except distance between mounting lugs was changed to match the new alternator. Purchase the "adjustment" bracket from Autozone for $10, chrome plated. Had to cut to fit. Building an RV-4 and needed the smallest I could get to clear the cowl. Wally Hunt Rockford, IL Finishing Kit ________________________________________________________________________________
Date: Jan 14, 2005
I used a new green scotchbrite pad under a palm sander on some map pockets. It makes a nice matte finish in about three seconds. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Glen Matejcek said: > > Hi Wayne- > > I don't know for sure about bare aluminum, but the grey scotchbrite pads > (fine) do a great job of putting a scratch less, matte finish on paint. > The white (extra fine) will tend to burnish a shine back into the surface. > Check with woodworking suppliers, if you're interested. > > > Glen Matejcek > aerobubba(at)earthlink.net > > ________________________________________________________________________________
Date: Jan 14, 2005
> >I remember reading somewhere some time ago about airspeed indicator error >using the Cleveland static ports vs. Van's rivets. Searched archives, >didn't find >specifics. I believe my airspeed indicator is reading low and wondering if >the Cleveland static ports may have something to do with it. >Anyone with actual experience on this issue? >Dale Ensing >RV6A N118DE I'm on the road this week, working very long days, so I wasn't keeping up to date on the RV-List. The ideal static port would be at a location where the pressure was equal to the free stream pressure at every flight condition. Unfortunately, the air flow has to accelerate and decelerate as it goes around the aircraft, and Bernoulli's Law tells us that this will cause the pressure to change. At any given flight condition there are a number of locations on the aircraft where the pressure is equal to the free stream static pressure. But, if you change flight conditions, these locations end up somewhere else. It is very, very difficult to find a good location for static ports. Van's static port is a domed head pop rivet. Some people are offended by the protruding head, and replace it with something that is flatter, like the Cleaveland or ACS static ports. But you need to realize that Van isn't stupid, and there is a reason why he used a protruding static port - it works. The airflow will have to accelerate a bit as it goes over that domed head, and this will cause the pressure to fall. In other words, if you have a more flush static port, at the same location, this port will sense a higher pressure. ASI readings are a function of the difference between pitot and static pressures, so the flatter static port will lead to lower ASI readings. I've seem info from several builders who have modified the flush static ports to make them more like Van's design, and they reported that the accuracy of their ASI and altimeter improved. I have also seen messages from two builders who are sure that their ASI is accurate with the flatter static ports. And I bet most RVers have no idea how accurate their ASI and altimeter are at all. Every RV is a bit different, due to small changes in skin contour ahead of the static port, so every one will have a slightly different static system error. And every ASI has a different instrument error. If you are lucky, the error in your ASI will cancel out the error in your static system. If your ASI reads a bit low, that is no big deal, except you should lower your max flap speed and VNE a bit to compensate. But, if you fly IFR you need to understand that static system errors also affect the altimeter. I wouldn't want to be shooting instrument approaches without knowing what errors my altimeter had, and compensating for them. You also have to understand that ASIs have instrument error too, so at first glance there is no way of knowing whether your problem is ASI instrument error, pitot-static leaks, static system error or a problem with the way you determined the ASI accuracy. I've got a bunch of info on my web site on how to check the ASI accuracy using a homemade water manometer. Then, I've got info on how to do static system accuracy flight testing, including a spreadsheet to crunch the data. See: http://members.rogers.com/khorton/rvlinks/ssec.html The whole list of links on pitot-static systems is at: http://go.phpwebhosting.com/~khorton/rv8/phplinks/index.php?PID=47 Kevin Horton RV-8 (Finishing Kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Subject: KX125 Ign noise followup
Date: Jan 14, 2005
I thought it might be healpful to post the outcome of my noise problem. All sugestions tried, no help, I ended up putting on both mag filters. (tedious job) and noise gone. charlie heathco ________________________________________________________________________________
Date: Jan 14, 2005
Subject: OC Pix
In a message dated 1/14/2005 12:04:23 A.M. Pacific Standard Time, rv-list-digest(at)matronics.com writes: From: "D. Jones" <dljinia(at)yahoo.com> Subject: RV-List: Oil cooler attached to engine mount --> RV-List message posted by: "D. Jones" List, Recently there was a discussion here about attaching the oil cooler to the engine mount instead of the rear baffle. There were even a couple of links showing the cooler installed this way. I'm preparing for my first annual and contemplating moving the oil cooler from the baffle as I've already had to re-work the baffle due to crack/break from the vibration of the oil cooler. Question... how did you attach the cooler to the mount? Pictures would be appreciated. Thanks, ________________________________________________________________________________
Date: Jan 14, 2005
> I have used the three BRW EZ Charger battery tenders I've had for over 20 > yrs on various planes, cars and motorcycles unattended and they work well. > They have reverse polarity protection, put out 13.3VDC and are two stage 600mA > max and step down to 35mA unattended. I think they are still in business and > the last numbers I have for them are > 312-369-5675 (and Tollfree 800-426-6008). And here is their website :-) : http://batterytender.com/ ________________________________________________________________________________
Date: Jan 14, 2005
In a message dated 1/13/05 12:27:48 PM Pacific Standard Time, dcw(at)nomadwi.com writes: << I used Van's low-tech pop rivet static ports and my a/s and altimeter readings are dead accurate. >> Mine also! My simple minded thinking was that Van would have changed to flush ports long ago if required for accuracy, but that's just me. Harry Crosby Pleasanton, California RV-6, flying! ________________________________________________________________________________
Date: Jan 14, 2005
In a message dated 1/13/05 3:07:02 PM Pacific Standard Time, dane(at)mutualace.com writes: << Anyone have a better idea? >> Use Van's pop rivet static ports, they work! Harry Crosby Pleasanton, California RV-6, flying! ________________________________________________________________________________
Subject: Cleveland static ports
Date: Jan 14, 2005
>I for one think the pop rivet looks hokey as hell. The kits are super tight >in most regards but every once in a while I come across something like the >static ports that makes me stop and ask myself "REALLY?" I certainly would >like to know why a flush port would not work as well as a pop rivet. Well, I thought the same thing. I guess I didn't care for the pop rivet and went with the flush port. I put it where Van recommended. It looks better IMHO and, by the way, works just fine. My altimeter, ROC and AIS are very accurate. I think AIS is the most telling. This is on the -4 and would be different probably on the other -s. I don't remember it being $20 but it all blends in after a while. How it works may have more to do with the placement than what you put there. I have not seen a pop rivet or other protruding port on a production or military aircraft. Unfortunately, you would have to experiment to find another place and how do you do that? I'm not sure what the answer is. It involves a little bit of builder luck, I suppose. The static system is a system and involves all components working right, including the pitot source. Hmmmmm. The debate rages. Michael RV-4 N232 Suzie Q ________________________________________________________________________________
Date: Jan 14, 2005
>200hp IO 360 A1A. First Run. NDH, Cleaned, Painted, New Starter, Rings, >scamshaft, Bearings, Exhaust Valves, Magnetos, etc, Log book. Not >Certified, >you assemble. $15000.00Canadian Dollars, $12400.00US dollars. >1)How hard is it to rebuild one of these? About the same as a regular car >engine I would imagine??? Not a lot different, but there are little tricks that will come back and bite you if you don't follow the right course. Find a knowledgable, experienced A&P who's rebuilt them to learn some of these tricks and tips. >2)Where would I find a good, detailed, laymens manual on rebuilding these >engines? I bought one from Wag-Aero I believe. Look for Lycoming -320/-360 overhaul manual. You'll need the parts manual too. >3)What do you think of the price? Im a strong believer that if you arent >getting something with a warranty you should get it very cheap to make up >for the most sever of possibilities ie cracked case, cracked crank ect. Sounds like it's in pieces... might be a problem with something like the crank or case. Sounds pretty high $$ for a disassembled engine. What's new and what's old? But I haven't been looking lately. >4)What questions should I ask when I call? Why is it in parts? What's damaged? What was it on? All logs available? Sudden stoppage/prop strikes history? Crank flange runout? Cylinder bores? Camshaft been ground? AD's complied with? What type of mags? What type of fuel system? All parts available? >I know most of us buy our engines already rebuilt buy reputable companies >but I do believe the experimental category allows us to rebuild engines and >use them as uncertified in experimental planes. Yep. you could strap a Briggs & Stratten go-cart engine on if you wanted to. I rebuilt mine and used a certified propeller combination. This got me a 25 hr phase 1 test period. My buddy bought a brand spankin new O-360 and a new Senesich metal prop and had to fly a 40-hr Phase 1. Just the way it goes. Bryan Jones Houston ________________________________________________________________________________
Date: Jan 14, 2005
Subject: Grove RV-8 Gear
The time has come......if you want RV-8 Grove aerodynamic gear call NOW. They are starting production next week and it may be next year for the next run. 13 sets are being made and I am # 4. There is only a couple extra sets. (The price has gone up $110) RV-4 RV-8 QB....wings Sal Capra Lakeland, FL. My Home Page ________________________________________________________________________________
Date: Jan 14, 2005
I can take some tonight or tomorrow and send. I haven't taken any with my digital yet. All were with film. I'll send some tomorrow. Curt Hoffman ----- Original Message ----- From: <Dwpetrus(at)aol.com> Subject: Re: RV-List: RV-9A kit > > do you have any pics to email of the kit and work done. > > thanks, > Wayne Petrus > > ________________________________________________________________________________
Date: Jan 14, 2005
Kosta Lewis wrote: > > > >>I for one think the pop rivet looks hokey as hell. The kits are super >> >> >tight > > >>in most regards but every once in a while I come across something like >> >> >the > > >>static ports that makes me stop and ask myself "REALLY?" I certainly >> >> >would > > >>like to know why a flush port would not work as well as a pop rivet. >> >> > >Well, I thought the same thing. I guess I didn't care for the pop rivet >and went with the flush port. I put it where Van recommended. It looks >better IMHO and, by the way, works just fine. My altimeter, ROC and AIS >are very accurate. I think AIS is the most telling. This is on the -4 >and would be different probably on the other -s. I don't remember it >being $20 but it all blends in after a while. > >How it works may have more to do with the placement than what you put >there. I have not seen a pop rivet or other protruding port on a >production or military aircraft. Unfortunately, you would have to >experiment to find another place and how do you do that? I'm not sure >what the answer is. It involves a little bit of builder luck, I suppose. > >The static system is a system and involves all components working right, >including the pitot source. Hmmmmm. The debate rages. > > >Michael >RV-4 N232 Suzie Q > > I think what most of you are missing is not what works and what does not work but what the designer had in mind. Yes we can use whatever we feel like using and each is entitled to do so. Remember the RV series aircraft are the "best bang for the buck" on the market, and this is only possible because Van has taken the time to design an aircraft that is reasonably fast and IMO looks very nice. YES he could use all of the fanciest and newest expensive gadgets and the nicest looking static port he could find but this was not his mission. Van's mission and vision for RVs was to make a safe, fast, fun AND AFFORDABLE airplane for the most people. IF he had used all the best, great looking parts money could buy I am not sure that I would have been able to afford to built an airplane as great as an RV. I think that when a lot of you complain about the "hokey" looking parts you are not taking into account the affordable design mission Van had when he designed the RV's. I know that $20 here and there is not a big deal to a lot of you but I also believe that there are a lot of you in the same boat as me that may not be building or flying an RV if it were more expensive. The pop rivet static ports works as well as any other static port and helps keep the kit affordable. Rather than complain that the parts are "hokey" just buy and use what you like. Jerry(soon to be 16 years flying my hokey static port RV-6)Springer PS Michael not picking on you just using your comments to add mine to the thread :-) ________________________________________________________________________________
Date: Jan 14, 2005
Subject: Re: > Re: Belly comm antenna
The antenna mounted between the gear legs should work OK. Possibly a little shading by gear legs but you probably won't notice it. I have a handheld "Rubber Ducky" antenna on the belly of our Rv-4, mounted under the left step plate in front of the main spar. It works fine in all the places I have flown. I have a second one mounted on the belly behind the baggage compartment and it works fine too. It only takes a bulkhead BNC connector to mount one of them and a cap to cover it if not used. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Jan 14, 2005
Gotta a link? The time has come......if you want RV-8 Grove aerodynamic gear call NOW. They are starting production next week and it may be next year for the next run. 13 sets are being made and I am # 4. There is only a couple extra sets. (The price has gone up $110) RV-4 RV-8 QB....wings Sal Capra Lakeland, FL. My Home Page ________________________________________________________________________________
Subject: Forum Web Address
Date: Jan 14, 2005
Last week a fellow posted link to a new forum for Kitplane builders. I liked the forum and book marked it but alas the book mark is no more. Can somone repost the link? Thanks ________________________________________________________________________________
Date: Jan 14, 2005
thanks, I will be expecting them. Wayne ________________________________________________________________________________
Subject: RE: Aluminum panel finish
Date: Jan 14, 2005
I've seen a plane with a "tooled" look on the firewall. I believe this was done with an angle air grinder and a Scotch Bright disk. The swirls were quarter circle in size I think this was done by masking completed swirls. One could certainly "experiment" and come up with something. Someone mentioned using Drano as an acid etch. Got me to thinking, I've used Purple Power Cleaner from the Auto store that might etch the surface and not be as aggressive an action and so immersion might take longer. Marty in Brentwood TN From: "Wayne Pedersen" <wayne(at)pedersentransport.com> Subject: RV-List: aluminum panel finish I seen a panel in a RV6a that was anodized in "clear". It gave the cockpit a high tech look and the pilot said that there was no issues with glare etc. Now here is my dilemma. Despite being extra careful cutting and shaping the panel I still managed to get a couple of scratches and "polished" areas on it were the scotchbrite pad hit it in deburring. These need to be eliminated before anodizing or they will show through. I want to create a satin/brushed finish on the aluminum before anodizing but the anadizor couldn't give me any ideas how to do that. It there a procedure that I can use to create the Satin or brushed look on the aluminum? Thanks - remember this list hasn't failed me yet..... Wayne S.Alberta RV7a panel work in -35 weather I've seen a plane with a "tooled" look on the firewall. I believe this was done with an angle air grinder and a Scotch Bright disk. The swirls were quarter circle in size I think this was done by masking completed swirls. One could certainly "experiment" and come up with something. Someone mentioned using Drano as an acid etch. Got me to thinking, I've used Purple Power Cleaner from the Auto store that might etch the surface and not be as aggressive an action and so immersion might take longer. Marty in Brentwood TN From: "Wayne Pedersen" wayne(at)pedersentransport.com Subject: RV-List: aluminum panel finish -- RV-List message posted by: "Wayne Pedersen" wayne(at)pedersentransport.com I seen a panel in a RV6a that was anodized in "clear". It gave the cockpit a high tech look and the pilot said that there was no issues with glare etc. Now here is my dilemma. Despite being extra careful cutting and shaping the panel I still managed to get a couple of scratches and "polished" areas on it were the scotchbrite pad hit it in d eburring. These need to be eliminated before anodizing or they will show through. I want to create a satin/brushed finish on the aluminum before anodizing but the anadizor couldn't give me any ideas how to do that. It there a procedure that I can use to create the Satin or brushed look on the aluminum? Thanks - remember this list hasn't failed me yet..... Wayne S.Alberta RV7a panel work in -35 weather ________________________________________________________________________________
Date: Jan 14, 2005
I for one think the pop rivet looks hokey as hell. >>>> I for another just couldn't get a decent connection to the tube! Take a stainless allen head screw (10-32), drill a #50 hole through it, reshape the head to look just like a poprivet head, polish and install with a nut. The threads hold a tube quite nicely with no additional fittings, just use some sealant so there's no leakage past the threads (I used that miracle of all adhesives, GOOP) Works great- less bandwidth... Mark at The PossumWorks in TN ________________________________________________________________________________
Subject: Re: Grove RV-8 Gear
Date: Jan 15, 2005
Are the standard axles, wheels and wheel pants used with the grove landing gear? > > Gotta a link? > > > The time has come......if you want RV-8 Grove aerodynamic gear > call NOW. They are starting production next week and it may be next year > for > the next run. 13 sets are being made and I am # 4. There is only a couple > extra sets. > (The price has gone up $110) > > > RV-4 > RV-8 QB....wings > > Sal Capra > Lakeland, FL. > My Home Page > > ________________________________________________________________________________
Date: Jan 14, 2005
Take a look here to see if this helps with your decision: http://www.aerosportpower.com/pricing.htm These are good people to do business with. ________________________________________________________________________________
Date: Jan 14, 2005
Subject: Re:Oil cooler attached to engine mount
Doug, I just finished mine yesterday, pix under "photos" on left side. Go to bottom and "select all" to see them. _http://groups.yahoo.com/group/XP-360Forum/_ (http://groups.yahoo.com/group/XP-360Forum/) You have to join the list to view them, but you can cancel afterward. HTH... Jerry Cochran In a message dated 1/14/2005 12:04:23 A.M. Pacific Standard Time, rv-list-digest(at)matronics.com writes: From: "D. Jones" <dljinia(at)yahoo.com> Subject: RV-List: Oil cooler attached to engine mount --> RV-List message posted by: "D. Jones" List, Recently there was a discussion here about attaching the oil cooler to the engine mount instead of the rear baffle. There were even a couple of links showing the cooler installed this way. I'm preparing for my first annual and contemplating moving the oil cooler from the baffle as I've already had to re-work the baffle due to crack/break from the vibration of the oil cooler. Question... how did you attach the cooler to the mount? Pictures would be appreciated. Thanks, Doug -7A ________________________________________________________________________________
Date: Jan 14, 2005
Hmmm, was it for RV builders? www.rivetbangers.com is for RV builders and is a little bit less known. -- jrs -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kevin Williams Subject: RE: RV-List: Forum Web Address Last week a fellow posted link to a new forum for Kitplane builders. I liked the forum and book marked it but alas the book mark is no more. Can somone repost the link? Thanks --- ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Jan 14, 2005
Please do not misunderstand me guys....I think my RV 10 kit is absolutely wonderful! The engineering is spectacular and I have yet to have a part not just snap right into place. The very few items I am electing to change are all for purely cosmetic reasons and my vanity. I chose to change the static ports because I like the hardware better and I think this airframe deserves it. While I do understand that the pennies add up to the dollars I feel like this was well spent and fairly insignificant in the scope of this project. My target budget is 70 to 80 thousand by the time its finished and I will be proud if it comes in there. The place I am really going to control myself is the panel :) Build on....and thanks for all of the great information. Evan Johnson www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ----- Original Message ----- From: "Jerry Springer" <jsflyrv(at)comcast.net> Subject: Re: RV-List: Cleveland static ports > > Kosta Lewis wrote: > > > > > > > > >>I for one think the pop rivet looks hokey as hell. The kits are super > >> > >> > >tight > > > > > >>in most regards but every once in a while I come across something like > >> > >> > >the > > > > > >>static ports that makes me stop and ask myself "REALLY?" I certainly > >> > >> > >would > > > > > >>like to know why a flush port would not work as well as a pop rivet. > >> > >> > > > >Well, I thought the same thing. I guess I didn't care for the pop rivet > >and went with the flush port. I put it where Van recommended. It looks > >better IMHO and, by the way, works just fine. My altimeter, ROC and AIS > >are very accurate. I think AIS is the most telling. This is on the -4 > >and would be different probably on the other -s. I don't remember it > >being $20 but it all blends in after a while. > > > >How it works may have more to do with the placement than what you put > >there. I have not seen a pop rivet or other protruding port on a > >production or military aircraft. Unfortunately, you would have to > >experiment to find another place and how do you do that? I'm not sure > >what the answer is. It involves a little bit of builder luck, I suppose. > > > >The static system is a system and involves all components working right, > >including the pitot source. Hmmmmm. The debate rages. > > > > > >Michael > >RV-4 N232 Suzie Q > > > > > I think what most of you are missing is not what works and what does not > work but what the designer had in mind. > Yes we can use whatever we feel like using and each is entitled to do > so. Remember the RV series aircraft are > the "best bang for the buck" on the market, and this is only possible > because Van has taken the time to design an aircraft > that is reasonably fast and IMO looks very nice. YES he could use all > of the fanciest and newest expensive gadgets > and the nicest looking static port he could find but this was not his > mission. Van's mission and vision for RVs was to make > a safe, fast, fun AND AFFORDABLE airplane for the most people. IF he > had used all the best, great looking parts > money could buy I am not sure that I would have been able to afford to > built an airplane as great as an RV. I think that when a > lot of you complain about the "hokey" looking parts you are not taking > into account the affordable design mission Van had > when he designed the RV's. I know that $20 here and there is not a big > deal to a lot of you but I also > believe that there are a lot of you in the same boat as me that may not > be building or flying an RV if it were more expensive. > The pop rivet static ports works as well as any other static port and > helps keep the kit affordable. Rather than complain > that the parts are "hokey" just buy and use what you like. > > Jerry(soon to be 16 years flying my hokey static port RV-6)Springer > > PS Michael not picking on you just using your comments to add mine to > the thread :-) > > ________________________________________________________________________________
Subject: Rod end bearings - Loc-tite or not
Date: Jan 14, 2005
I'm doing a final fit of my elevators to the HS and I'm wondering if I should loc-tite the nut on the rod end bearing. I didn't use anything for the rod end bearing to the plate nut since it's so tight anyway. Should I have? Thanks! Karie Daniel RV-7A QB Sammamish, WA. ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling(at)earthlink.net>
Subject: Re: Rod end bearings - Loc-tite or not
Date: Jan 14, 2005
I just put anti-sabotage (finger nail polish) overlapping the nut/bolt and check it on preflight to see if the nut is backing off. Locknuts shouldnt come loose anyway. Shemp/Jeff Dowling RV-6A, N915JD 150 hours Chicago/Louisville ----- Original Message ----- From: "Karie Daniel" <karie4(at)comcast.net> Subject: RV-List: Rod end bearings - Loc-tite or not > > I'm doing a final fit of my elevators to the HS and I'm wondering if I > should loc-tite the nut on the rod end bearing. I didn't use anything for > the rod end bearing to the plate nut since it's so tight anyway. Should I > have? > > Thanks! > > Karie Daniel > RV-7A QB > Sammamish, WA. > > > ________________________________________________________________________________
Date: Jan 14, 2005
> >Last week a fellow posted link to a new forum for Kitplane builders. I >liked the forum and book marked it but alas the book mark is no more. Can >somone repost the link? I've seen pointers to two newish forums lately: 1. Van's Air Force World Wide Wing Forum - http://www.vansairforce.com/community/index.php The VAF WWW Forum is part of the VAF WWW web site, and is hosted by Doug Reeves, who is running a large number of RV related Yahoo e-mail groups. It is RV only. It it getting a fair bit of traffic, and it looks like a winner. 2. Wings Forum - http://www.wingsforum.com/ The Wings Forum is aimed at all types of homebuilt aircraft, with specific sections for different families, and sections for things that are common to all types. This one is in its early days, and its too early to say whether it will reach critical mass or not. I volunteered to moderate the Flight Test forum. The Flight Test forum is certainly glacial, as the only two posts were made by myself. But, if you have any flight testing issues to discuss, and prefer a web forum, I welcome your questions. ________________________________________________________________________________
Subject: Hooker harness
Date: Jan 14, 2005
I just replaced my old belts with Hookers and found the shoulder harness attach points into the lap belt are opposite what I think they should be. They have a 90 degree bend in them and look like they should fit together flush. They way they go together now they seem to interfere. Has anyone else found this? Oh yeah, and the lap belt mounting points on the harness have a bushing that really spreads the attach points on the plane. Im wondering if I should drill out the plane attach points to allow the bushing to fit through. On the same subject, for anyone considering installing a crotch strap, make sure you install them forward enough so they wont come up through your cushion. I thought I was forward enough but it turns out the buckle has to come forward on top of the seat pan and under the cushion before it comes up to meet the lap belt. This keeps the buckle under the cushion and makes it a pain in the a@# to adjust. Shemp/Jeff Dowling RV-6A, N915JD 150 hours Chicago/Louisville ________________________________________________________________________________
Date: Jan 14, 2005
Where did you get that shroud for your oil cooler? I've been looking for something like that but can't find anything. Jerry2DT(at)aol.com wrote: > > >Doug, > >I just finished mine yesterday, pix under "photos" on left side. Go to >bottom and "select all" to see them. _http://groups.yahoo.com/group/XP-360Forum/_ >(http://groups.yahoo.com/group/XP-360Forum/) >You have to join the list to view them, but you can cancel afterward. HTH... > >Jerry Cochran > >In a message dated 1/14/2005 12:04:23 A.M. Pacific Standard Time, >rv-list-digest(at)matronics.com writes: > >From: "D. Jones" <dljinia(at)yahoo.com> >Subject: RV-List: Oil cooler attached to engine mount > >--> RV-List message posted by: "D. Jones" > >List, >Recently there was a discussion here about attaching >the oil cooler to the engine mount instead of the rear >baffle. There were even a couple of links showing the >cooler installed this way. I'm preparing for my first >annual and contemplating moving the oil cooler from >the baffle as I've already had to re-work the baffle >due to crack/break from the vibration of the oil >cooler. > >Question... how did you attach the cooler to the >mount? Pictures would be appreciated. > >Thanks, >Doug -7A > > > > -- Scott VanArtsdalen Van Arts Consulting Services 3848 McHenry Ave Suite #155-184 Modesto, CA 95356 209-986-4647 www.rivetbangers.com Now with email!! How you want it, When you want it. ________________________________________________________________________________
Date: Jan 14, 2005
As soon as I saw the cheesy static port for the 7a I tossed it. Not on this nice of an airplane. The allen head screw sounds good and I did a similar mod with a small c.s. screw,drilled and tightened it with a nut and tube fit fine. Flush. Take a stainless allen head screw (10-32), drill a > #50 hole through it, > reshape the head to look just like a poprivet head, > polish and install with a nut. > The threads hold a tube quite nicely with no > additional fittings, just use > some sealant so there's no leakage past the threads > (I used that miracle of all > adhesives, GOOP) Works great- less bandwidth... > > Mark at The PossumWorks in TN > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ http://info.mail.yahoo.com/mail_250 ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Re: static ports
> >Curious question (I haven't got there yet) ..... is there only one >static port or one on each side??? >Linn A single static port could work quite fine, if you always had the ball centred (or more accurately, had zero sideslip, which is not quite the same thing in a single-engine prop-driven aircraft). But, if you ever develop some sideslip, the airflow pattern around the rear fuselage changes, and that screws up the accuracy of the static port. If you have two ports, the one on the other side will see approximately the opposite pressure change. If we connect the two ports to the static system with a T fitting, the higher pressure on one will cancel out the lower pressure on the other. There will be some airflow from one port to the other, if the sideslip causes one to be in a higher pressure area than the other. The pressure at the mid-point of the line between the two ports will be the average of the pressures at each port. This means that the T that connects the two ports to the main static line should be in the mid-point of the line between the two ports. Kevin Horton RV-8 (Finishing Kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Date: Jan 15, 2005
In a message dated 1/14/05 6:39:44 PM Eastern Standard Time, kevinsky18(at)hotmail.com writes: > Gotta a link? > > > Grove Aircraft Company - Aluminum Landing Gear http://www.groveaircraft.com/landing_gear.html Yes the stock wheels and axles are used. The Aero gear do not require gear leag fearings and are finished alum with the brake line drilled through the center of the gear. Also saves weight They aint cheap....they sure are pretty though. Sal Capra Lakeland, FL My Home Page http://hometown.aol.com/cbrxxdrv/index.html ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Re: RV-Static Ports was Cleveland Static Ports
Static Ports are exactly like Real Estate ~~ Location, Location, Location No matter how expensive or non-expensive, the location is the important factor! The major companies spend many dollars getting the correct location for the static source. Two, one on each side at the location suggested by the designer is the best bet. The static source must also be the same distance from fuselage skin as the designer suggests. With only one, if you are slipping or skidding just a very little will make a BIG difference. Try it! We have been experimenting with a combined pitot & AOA mount and are finally ready for production, but the static will remain where the designer wanted it! One of my customers has been doing research trying to relocate the static source for their aircraft kits, lots of work, and still not completed after nearly a year! Elbie Mendenhall EM Aviation www.riteangle.com ________________________________________________________________________________
Date: Jan 15, 2005
Hi Jeff, Are you sure you don't have the left/right shoulder harnesses on backwards? Try swapping them over your shoulders and they should fit perfectly. I have hookers in both my -6's and they work fine. Oh, and don't forget to simply grind down those bushings to fit! Cheers, Stein. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jeff Dowling Subject: RV-List: Hooker harness I just replaced my old belts with Hookers and found the shoulder harness attach points into the lap belt are opposite what I think they should be. They have a 90 degree bend in them and look like they should fit together flush. They way they go together now they seem to interfere. Has anyone else found this? Oh yeah, and the lap belt mounting points on the harness have a bushing that really spreads the attach points on the plane. Im wondering if I should drill out the plane attach points to allow the bushing to fit through. On the same subject, for anyone considering installing a crotch strap, make sure you install them forward enough so they wont come up through your cushion. I thought I was forward enough but it turns out the buckle has to come forward on top of the seat pan and under the cushion before it comes up to meet the lap belt. This keeps the buckle under the cushion and makes it a pain in the a@# to adjust. Shemp/Jeff Dowling RV-6A, N915JD 150 hours Chicago/Louisville ________________________________________________________________________________
Date: Jan 15, 2005
Doing the actual rebuild/assembly isn't all that difficult. There are some unusual bits if you have no experience...such as using a silk thread between the case halves to prevent leaks (saw this on a rebuild video shot at Mattituck). There also are some special tools you'll need, so don't forget to add those to the cost of the engine. But the actual procedures aren't fundamentally different from those you use for a car engine. You're still torquing bolts, pre-lubing parts, compressing rings, setting timing, etc. etc. The big problem is the parts. Aircraft engine parts fail differently than auto engine parts do. Cylinders crack, for example, often in such a way that you cannot see the problem with the naked eye. A good shop will magnaflux or zyglo inspect the parts to determine if they're okay. A fly-by-night operation may not, or worse, may simply say that they have. What I'm saying here is that if you, having no specific knowledge of airplane engines, show up and see this nice-looking pile of FRESHLY PAINTED (there's an alarm bell!) parts, you won't be able to tell just by looking at them if they're any good or not. Just asking the seller if they're okay in no way guarantees that they are in fact serviceable. Caveat emptor. Since having a reliable engine can literally be a life-or-death matter, does it not make sense to be patient, put some more money in the bank and just buy one from a reputable, expert shop with a long track record (e.g. Mattituck, Penn Yan, etc.)? I'm just a casual wrench-spinner, confident enough in my own ability to feel comfortable assembling something like an engine. But an engine assembled by me (who has never rebuilt an airplane engine) from parts of unknown and unproven quality is not something I'd want to trust my life to. ----------------------------------------------------- Andrew Douglas ________________________________________________________________________________
Date: Jan 15, 2005
In a message dated 1/14/05 11:35:53 AM US Eastern Standard Time, kevinsky18(at)hotmail.com writes: I found a 200hp IO 360 A1A advertised for sale. The ad reads. 200hp IO 360 A1A. First Run. NDH, Cleaned, Painted, New Starter, Rings, scamshaft, Bearings, Exhaust Valves, Magnetos, etc, Log book. Not Certified, you assemble. $15000.00Canadian Dollars, $12400.00US dollars. Kevin, If I had it to do over again, I would not use the angle valve engine -- its too heavy. Dan Hopper Walton Indiana USA (Go Colts!) RV-7A N766 dh IO-360-C1E6 converted to -A1B6 (this is like the -A1A except it has counterweights) Flying since July but not since December! ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Static ports - rivets too short?
I used Van's pop rivets and the static system seems to work OK. The only problem I had was that the rivets were too short. There was only about 1/8 inch to put the plastic line over. I wish the rivets were about 1/2 inch long. Were they just out of the longer rivets when they shipped my kit? Dan Hopper Walton, IN RV-7A - Flying N766DH ________________________________________________________________________________
Subject: Re: Hooker harness
Date: Jan 15, 2005
I have the pads and buckles on top. If I cross them over, they will be criss crossed with the pads upside down and the buckles into my chest. Is your white identifying label stitched into the harness facing up or down. I may be able to simply pull the ends out of the buckles and switch em. Shemp ----- Original Message ----- From: "Stein Bruch" <stein(at)steinair.com> Subject: RE: RV-List: Hooker harness > > Hi Jeff, > > Are you sure you don't have the left/right shoulder harnesses on > backwards? > Try swapping them over your shoulders and they should fit perfectly. I > have > hookers in both my -6's and they work fine. > > Oh, and don't forget to simply grind down those bushings to fit! > > Cheers, > Stein. > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jeff Dowling > To: rv-list(at)matronics.com > Subject: RV-List: Hooker harness > > > I just replaced my old belts with Hookers and found the shoulder harness > attach points into the lap belt are opposite what I think they should be. > They have a 90 degree bend in them and look like they should fit together > flush. They way they go together now they seem to interfere. Has anyone > else found this? Oh yeah, and the lap belt mounting points on the harness > have a bushing that really spreads the attach points on the plane. Im > wondering if I should drill out the plane attach points to allow the > bushing > to fit through. > > On the same subject, for anyone considering installing a crotch strap, > make > sure you install them forward enough so they wont come up through your > cushion. I thought I was forward enough but it turns out the buckle has > to > come forward on top of the seat pan and under the cushion before it comes > up > to meet the lap belt. This keeps the buckle under the cushion and makes > it > a pain in the a@# to adjust. > > Shemp/Jeff Dowling > RV-6A, N915JD > 150 hours > Chicago/Louisville > > > ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Re: Static ports - rivets too short?
Mine were about the same as yours. I didn't know there were longer ones. I used a zip tie on there to clamp down on the tubing. Mickey Hopperdhh(at)aol.com wrote: > > > I used Van's pop rivets and the static system seems to work OK. The only > problem I had was that the rivets were too short. There was only about 1/8 > inch to put the plastic line over. I wish the rivets were about 1/2 inch long. > Were they just out of the longer rivets when they shipped my kit? > > > Dan Hopper > Walton, IN > RV-7A - Flying > N766DH > -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
Date: Jan 15, 2005
In a message dated 1/14/05 2:29:28 PM Pacific Standard Time, lwalters2(at)cfl.rr.com writes: << one on each side >> Yes. Harry Crosby Pleasanton, California RV-6, flying!!! ________________________________________________________________________________
Date: Jan 15, 2005
In a message dated 1/14/05 9:09:49 PM Pacific Standard Time, shempdowling(at)earthlink.net writes: << I just replaced my old belts with Hookers and found the shoulder harness attach points into the lap belt are opposite what I think they should be. They have a 90 degree bend in them and look like they should fit together flush. They way they go together now they seem to interfere. Has anyone else found this? Shemp: I have Hookers in my RV-6 and noticed early on that it was easy to get the shoulder harness crossed so that they seemed to interfere. I just rotate them at the point they attach to the cable and no longer have a problem. << Oh yeah, and the lap belt mounting points on the harness have a bushing that really spreads the attach points on the plane. Im wondering if I should drill out the plane attach points to allow the bushing to fit through. >> I filed the bushings so that there was just enough still allow the belt clip to rotate in the attach points when the blot was tightened. Seems to work well. << On the same subject, for anyone considering installing a crotch strap, make sure you install them forward enough so they wont come up through your cushion. I thought I was forward enough but it turns out the buckle has to come forward on top of the seat pan and under the cushion before it comes up to meet the lap belt. This keeps the buckle under the cushion and makes it a pain in the a@# to adjust. >> Yes. With my Cleveland seats DJ puts a slot for the crotch to poke through and it is a real pain to adjust. Fortunately I find that I never have to adjust the crotch strap once it is set correctly. It is a nuisance to remove the seats, however. Harry Crosby Pleasanton, California RV-6, flying! ________________________________________________________________________________
Date: Jan 15, 2005
In a message dated 1/15/05 8:10:29 AM Pacific Standard Time, shempdowling(at)earthlink.net writes: << white identifying label stitched into the harness facing up >> I'm pretty sure that is correct but I'll check today and let you know. Harry Crosby Pleasanton, California RV-6, flying!!! ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Re: Oil cooler attached to engine mount
Scott, I laid it up from carbon fibre. Fun, but too time consuming. I'll probably go with aluminum for the one coming off the baffle. If you want to make one out of carbon or glass, email me directly and I can maybe help. Jerry Cochran jerry2dt(at)aol.com From: Scott VanArtsdalen <svanarts(at)yahoo.com> Subject: Re: RV-List: Re:Oil cooler attached to engine mount Where did you get that shroud for your oil cooler? I've been looking for something like that but can't find anything. ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Wingwalk material
Howdy folks- I've noticed Wicks and ACS are carrying clear wingwalk material. Anyone tried this stuff? Tried to remove it? I also seem to recall seeing some grey wingwalks out there- sources please? http://www.wicksaircraft.com/catalog/product_detail.php/pid=9691~subid=2565/in dex.html http://www.aircraftspruce.com/catalog/appages/clearwingwalk.php Thanks! Mark ________________________________________________________________________________
Subject: Minimum Realistic Field Length
Date: Jan 15, 2005
All, Since the plane is still in storage while I look for a home (building withdrawl), I have been evaluating several airpark possibilities. I would be interested in hearing from others what they believe the minimum safe runway lenth would be. I know it is highly subjective, but I would like to hear from others with experience. For reference...the plane with be a 7A, O360, with FP prop. Also, there is no real obstacles to think of (never heard of the Kansas Rockies), and field elevation is approx 1000'. Would a 1400' runway be doable? I know it would be on the short side (go-around if things don't look just right), but would it be safe? Thanks for the help, Scottwww.scottsrv7a.com Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Wing walk material
Have you investigated anti-slip material for diving boards and motor home steps? Howdy folks- I've noticed Wicks and ACS are carrying clear wingwalk material. Anyone tried this stuff? Tried to remove it? I also seem to recall seeing some grey wingwalks out there- sources please? http://www.wicksaircraft.com/catalog/product_detail.php/pid=9691~subid=2565/ in dex.html http://www.aircraftspruce.com/catalog/appages/clearwingwalk.php Thanks! Mark ________________________________________________________________________________
Date: Jan 15, 2005
I've heard others complain that non-black wing-walk material shows dirt too easily and is very hard or impossible to clean. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Fiveonepw(at)aol.com [mailto:Fiveonepw(at)aol.com] > Sent: Saturday, January 15, 2005 5:04 PM > To: rv-list(at)matronics.com > Subject: RV-List: Wingwalk material > > > Howdy folks- > > I've noticed Wicks and ACS are carrying clear wingwalk > material. Anyone tried this stuff? Tried to remove it? I > also seem to recall seeing some grey wingwalks out there- > sources please? > > http://www.wicksaircraft.com/catalog/product_detail.php/pid=96 > 91~subid=2565/in > dex.html > http://www.aircraftspruce.com/catalog/appages/clearwingwalk.php > > Thanks! > Mark > > > ======== > Matronics Forums. > ======== > ======== > > > > > > ________________________________________________________________________________
Subject: Re: Minimum Realistic Field Length
Date: Jan 15, 2005
The airplane will be able to do 1400', we have flown in and out of 1200' with a fixed-pitched O-320 RV-6. It is up to you. Jim Jim Cimino RV-8 SN 80039 150+ Hours ----- Original Message ----- From: <tx_jayhawk(at)excite.com> Subject: RV-List: Minimum Realistic Field Length > > All, Since the plane is still in storage while I look for a home (building withdrawl), I have been evaluating several airpark possibilities. I would be interested in hearing from others what they believe the minimum safe runway lenth would be. I know it is highly subjective, but I would like to hear from others with experience. For reference...the plane with be a 7A, O360, with FP prop. Also, there is no real obstacles to think of (never heard of the Kansas Rockies), and field elevation is approx 1000'. Would a 1400' runway be doable? I know it would be on the short side (go-around if things don't look just right), but would it be safe? Thanks for the help, Scottwww.scottsrv7a.com > > Join Excite! - http://www.excite.com > The most personalized portal on the Web! > > ________________________________________________________________________________
Date: Jan 15, 2005
At 1,400 ft.,it doesn't depend on the plane,it depends on the pilot-period. Practice,practice,practice on longer grass strips marked off so you know what you can do. The airplane is a constant,the pilot is the large variable. --- wrote: > > > All, Since the plane is still in storage while I > look for a home (building withdrawl), I have been > evaluating several airpark possibilities. I would > be interested in hearing from others what they > believe the minimum safe runway lenth would be. I > know it is highly subjective, but I would like to > hear from others with experience. For > reference...the plane with be a 7A, O360, with FP > prop. Also, there is no real obstacles to think of > (never heard of the Kansas Rockies), and field > elevation is approx 1000'. Would a 1400' runway be > doable? I know it would be on the short side > (go-around if things don't look just right), but > would it be safe? Thanks for the help, > Scottwww.scottsrv7a.com > > Join Excite! - http://www.excite.com > The most personalized portal on the Web! > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Where to Cut holes in ribs for conduit?
(not processed: message from valid local sender) Dear Sirs, I am at the point where it is time to cut the holes in the ribs for the conduit (that I got through vans) that contains the wires ran down the wings... can you tell me where the best place to do this is? They mention using the tooling holes at the rear of the spar, but that looks like it is awfully close to the pushrods when looking at the DWG for the wing... so where do you guys put it? Also, do you only run one conduit down the wing? I imaging that only one is necessary but I do not want to try to cut holes in the ribs later if I am forgetting something. On another related issue, what items are you needing to run wires for in the wings? I can think of landing lights, positioning tip lights, AOA instrument... anything else? is there any radio, GPS, EFIS wires or anything else that is ran in the wings that I should consider while doing this? - Matt Johnson http://www.rv7a.com ________________________________________________________________________________
Date: Jan 15, 2005
I would say that once you got your short field landings down pat, it would be managable. They stop fairly quickly once you get the wheels planted. You'll find it wanst to float. Just practice a lot and I think that 1400 feet would be fine. tx_jayhawk(at)excite.com wrote: > > All, Since the plane is still in storage while I look for a home (building withdrawl), I have been evaluating several airpark possibilities. I would be interested in hearing from others what they believe the minimum safe runway lenth would be. I know it is highly subjective, but I would like to hear from others with experience. For reference...the plane with be a 7A, O360, with FP prop. Also, there is no real obstacles to think of (never heard of the Kansas Rockies), and field elevation is approx 1000'. Would a 1400' runway be doable? I know it would be on the short side (go-around if things don't look just right), but would it be safe? Thanks for the help, Scottwww.scottsrv7a.com > > > > -- Scott VanArtsdalen Van Arts Consulting Services 3848 McHenry Ave Suite #155-184 Modesto, CA 95356 209-986-4647 www.rivetbangers.com Now with email!! How you want it, When you want it. ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Re: Wingwalk material
I bought some medium gray anti-skid stuff at the local hardware store. It was on a roll and they just cut a bunch off for me. It sticks REALLY well. Fiveonepw(at)aol.com wrote: > >Howdy folks- > >I've noticed Wicks and ACS are carrying clear wingwalk material. Anyone >tried this stuff? Tried to remove it? I also seem to recall seeing some grey >wingwalks out there- sources please? > >http://www.wicksaircraft.com/catalog/product_detail.php/pid=9691~subid=2565/in >dex.html >http://www.aircraftspruce.com/catalog/appages/clearwingwalk.php > >Thanks! >Mark > > > > -- Scott VanArtsdalen Van Arts Consulting Services 3848 McHenry Ave Suite #155-184 Modesto, CA 95356 209-986-4647 www.rivetbangers.com Now with email!! How you want it, When you want it. ________________________________________________________________________________
Date: Jan 15, 2005
Without Obstacles I'd say "EASY PEASY"!! Even with obstacles, it's still doable, but you have to be much more carefull. Takeoffs will be easy, but with the FP prop, you'll need to keep the approach close to nuts on (No sloppy, extra fast approaches). I fly a similar setup off a grass strip that isn't a whole lot longer and can always (almost) land with a decent amount of runway to spare. If it's not going my way during the approach, I simply go around and try it again, and again if need be. Just my 2 cents. Cheers, Stein Bruch RV6's, Minneapolis -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of tx_jayhawk(at)excite.com Subject: RV-List: Minimum Realistic Field Length All, Since the plane is still in storage while I look for a home (building withdrawl), I have been evaluating several airpark possibilities. I would be interested in hearing from others what they believe the minimum safe runway lenth would be. I know it is highly subjective, but I would like to hear from others with experience. For reference...the plane with be a 7A, O360, with FP prop. Also, there is no real obstacles to think of (never heard of the Kansas Rockies), and field elevation is approx 1000'. Would a 1400' runway be doable? I know it would be on the short side (go-around if things don't look just right), but would it be safe? Thanks for the help, Scottwww.scottsrv7a.com ________________________________________________________________________________
Subject: Re: Wing walk material
Date: Jan 15, 2005
I previously owned an RV-4 with the clear wing walk material. It had yellowed (even though the airplane bad been hangared) and look pretty bad after about 5 years. I removed and installed a nice black wing walk. Looked much better. Doug Weiler RV-4, N722DW > > Howdy folks- > > I've noticed Wicks and ACS are carrying clear wingwalk material. Anyone > tried this stuff? Tried to remove it? I also seem to recall seeing some > grey > wingwalks out there- sources please? > > http://www.wicksaircraft.com/catalog/product_detail.php/pid=9691~subid=2565/ > in > dex.html > http://www.aircraftspruce.com/catalog/appages/clearwingwalk.php ________________________________________________________________________________
Subject: Where to Cut holes in ribs for conduit? (not processed:
Date: Jan 15, 2005
Matt I just completed this task on RV6 wings. Take a look at the "Routing of wires and tubes in the Wing" in the Construction FAQ section at http://www.vansaircraft.com/public/confaq.htm This article should pretty much answer all your questions. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Matt Johnson Subject: RV-List: Where to Cut holes in ribs for conduit? (not processed: message from valid local sender) Dear Sirs, I am at the point where it is time to cut the holes in the ribs for the conduit (that I got through vans) that contains the wires ran down the wings... can you tell me where the best place to do this is? They mention using the tooling holes at the rear of the spar, but that looks like it is awfully close to the pushrods when looking at the DWG for the wing... so where do you guys put it? Also, do you only run one conduit down the wing? I imaging that only one is necessary but I do not want to try to cut holes in the ribs later if I am forgetting something. On another related issue, what items are you needing to run wires for in the wings? I can think of landing lights, positioning tip lights, AOA instrument... anything else? is there any radio, GPS, EFIS wires or anything else that is ran in the wings that I should consider while doing this? - Matt Johnson http://www.rv7a.com ________________________________________________________________________________
Subject: Re: Where to Cut holes in ribs for conduit? (not processed:
Date: Jan 15, 2005
Low and aft is my recommendation. Van's has a Construction FAQ about this: http://www.vansaircraft.com/pdf/Wing_Wiring.pdf http://www.vansaircraft.com/public/confaq.htm )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Matt Johnson" <matt(at)n559rv.com> Subject: RV-List: Where to Cut holes in ribs for conduit? (not processed: message from valid local sender) > > Dear Sirs, > > I am at the point where it is time to cut the holes in the ribs for the > conduit (that I got through vans) that contains the wires ran down > the wings... can you tell me where the best place to do this is? They > mention using the tooling holes at the rear of the spar, but that > looks like it is awfully close to the pushrods when looking at the DWG > for the wing... so where do you guys put it? Also, do you only run > one conduit down the wing? I imaging that only one is necessary but I do > not want to try to cut holes in the ribs later if I am forgetting > something. > > On another related issue, what items are you needing to run wires for in > the wings? I can think of landing lights, positioning tip lights, > AOA instrument... anything else? is there any radio, GPS, EFIS wires or > anything else that is ran in the wings that I should consider > while doing this? > > - Matt Johnson > http://www.rv7a.com > > ________________________________________________________________________________
Date: Jan 15, 2005
Subject: cutting teflon hose
I have some stainless steel braided teflon hose that I'll be using for oil and fuel. Is it OK to use a dremel cut-off disk to cut this type of hose? -- Thanks, Tom Sargent, RV-6A, firewall ________________________________________________________________________________
Date: Jan 15, 2005
Subject: HS404 Notch
Hi folks, I was on page 6-2, preparing the ribs. It says, "notch the aft end of HS-404 ribs to fit around HS-810 & HS-814." In doing so, I cut a little too much metal and don't have a flush fit. Is this critical (i.e., do I send to Vans for new HS-404's and start over)? The line that was supposed to be flush against 810 & 814 is not particularly straight and has as much as 2mm gap. I did this fiasco by first drillin a small hole at what I thought would be the corner of the notch and then cutting with snips. Done over, I would use a much smaller drill bit and a band saw. Thoughts? Michael Wynn RV-8, Starting the empennage EAA 0219782 AOPA 665085 San Ramon, California ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Re: Where to Cut holes in ribs for conduit? (not processed: message
... In a message dated 01/15/2005 8:41:41 PM Central Standard Time, matt(at)n559rv.com writes: I am at the point where it is time to cut the holes in the ribs for the conduit (that I got through vans) that contains the wires ran down the wings... can you tell me where the best place to do this is? They mention using the tooling holes at the rear of the spar, but that looks like it is awfully close to the pushrods when looking at the DWG for the wing... so where do you guys put it? Also, do you only run one conduit down the wing? I imaging that only one is necessary but I do not want to try to cut holes in the ribs later if I am forgetting something. >>>>>> I made a simple jig that held each rib firmly in the same position- a short piece of 2x12 with wood blocks nailed at several places around the edge of the rib. I clamped this to the table of my drill press and used a step drill to make each hole in the same location, production line style. Mine are about 2" behind the spar, about 1" below the top skin (-6A). Took about 10 minutes to drill all the ribs for each wing. The holes were sized for a single length of 5/8 CPVC. Installing the CPVC took about 5 seconds (chamfer the end you insert- slips right through) Once the wires are shoved through (another couple of minutes), and the tube is just where ya want it, GOOP the outer end to the end rib and move on to other stuff... My tips house the typical landing/taxi/postion and strobe lights (including the power supplies), and the right wingtip also has the Navaid wing leveler servo- still lots of room for antenna wire if desired. Fotos if interested- From The PossumWorks in TN Mark Phillips ________________________________________________________________________________
Date: Jan 15, 2005
Plan on doing your initial flight testing off a longer strip, and don't land at your strip until you have mastered the aircraft. Kevin Horton > >Without Obstacles I'd say "EASY PEASY"!! > >Even with obstacles, it's still doable, but you have to be much more >carefull. Takeoffs will be easy, but with the FP prop, you'll need to keep >the approach close to nuts on (No sloppy, extra fast approaches). I fly a >similar setup off a grass strip that isn't a whole lot longer and can always >(almost) land with a decent amount of runway to spare. If it's not going my >way during the approach, I simply go around and try it again, and again if >need be. > >Just my 2 cents. > >Cheers, >Stein Bruch >RV6's, Minneapolis > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of >tx_jayhawk(at)excite.com >To: rv-list(at)matronics.com >Subject: RV-List: Minimum Realistic Field Length > > > All, Since the plane is still in storage while I look for a home (building >withdrawl), I have been evaluating several airpark possibilities. I would >be interested in hearing from others what they believe the minimum safe >runway lenth would be. I know it is highly subjective, but I would like to >hear from others with experience. For reference...the plane with be a 7A, >O360, with FP prop. Also, there is no real obstacles to think of (never >heard of the Kansas Rockies), and field elevation is approx 1000'. Would a >1400' runway be doable? I know it would be on the short side (go-around if >things don't look just right), but would it be safe? Thanks for the help, >Scottwww.scottsrv7a.com ________________________________________________________________________________
Subject: BlueSky Aviation
Date: Jan 15, 2005
I would like to share my story regarding Bluesky Aviation Aka Noel Simmons to any and all interested parties. I have pictures during final construction to back up my claims & repairs that had to be done to correct what he had done to my airplane and charged me for. I was hoping to reach the 10 & 9 list can anyone confirm off list if I reached you as well. Regards Mike Comeaux mcomeaux(at)bendnet.com ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Re: cutting teflon hose
Yes. Wrap the ends you plan to cut with electrical tape and cut em off. We used to make lots of brake lines and used a similar tool to do the job. I don't recommend a hacksaw, makes a mess of the ends. -- Mike Nellis Austin, TX CMRA #32 Honda RC51 '97 YZF1000 '47 Stinson 108-2; RV6 (Fuselage) http://bmnellis.com sarg314 wrote: > >I have some stainless steel braided teflon hose that I'll be using for >oil and fuel. Is it OK to use a dremel cut-off disk to cut this type of >hose? >-- >Thanks, >Tom Sargent, RV-6A, firewall > > > > ________________________________________________________________________________
Date: Jan 16, 2005
Here is how I did it: http://www.rv8.ch/article.php?story 041026231058140 http://www.rv8.ch/article.php?story 041214233000234 Stuff that I've run through there are: 1) position lights 2) strobe wires (rather fat bundle) 3) landing/taxi lights 4) 2 x 1/8" AOA plastic tubing Still to come may be the EFIS magnometer wires, unless I put them in the fuselage. Mickey Matt Johnson wrote: > > Dear Sirs, > > I am at the point where it is time to cut the holes in the ribs for the > conduit (that I got through vans) that contains the wires ran down > the wings... can you tell me where the best place to do this is? They > mention using the tooling holes at the rear of the spar, but that > looks like it is awfully close to the pushrods when looking at the DWG > for the wing... so where do you guys put it? Also, do you only run > one conduit down the wing? I imaging that only one is necessary but I do > not want to try to cut holes in the ribs later if I am forgetting > something. > > On another related issue, what items are you needing to run wires for in > the wings? I can think of landing lights, positioning tip lights, > AOA instrument... anything else? is there any radio, GPS, EFIS wires or > anything else that is ran in the wings that I should consider > while doing this? > > - Matt Johnson > http://www.rv7a.com > -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
Date: Jan 15, 2005
Hi Tom, I watched a pro cut some with a cutting wheel in a chopsaw. I came home and got out the dremel, worked just fine. I only broke a few cutting discs, Per hose {;-) Use a couple of wraps of masking tape tightly over the cut point so that the wire does not fray too much. (saves the fingers from those nasty little wire stabs for one thing) Another wrap of tape wrapped once around so that it's edges line up at the cut point will help get a straight cut. Be sure to carefully clean out the hose. Remove the tape when assembling the hose and fittings. Tape over the fitting ends (cover) untill the hose is to be installed. Happy hosing {[;-) Jim in Kelowna ----- Original Message ----- From: "sarg314" <sarg314(at)comcast.net> Subject: RV-List: cutting teflon hose > > I have some stainless steel braided teflon hose that I'll be using for > oil and fuel. Is it OK to use a dremel cut-off disk to cut this type of > hose? > -- > Thanks, > Tom Sargent, RV-6A, firewall > > > ________________________________________________________________________________
Date: Jan 16, 2005
Amen to that. I was flying off of a 5,000 foot runway on my first flight. Damn near used all of it on the first landing. Almost had to go around. Paul Besing RV-6A Sold RV-10 Soon Kitlog Builder's Software www.kitlog.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kevin Horton Subject: RE: RV-List: Minimum Realistic Field Length Plan on doing your initial flight testing off a longer strip, and don't land at your strip until you have mastered the aircraft. Kevin Horton > >Without Obstacles I'd say "EASY PEASY"!! > >Even with obstacles, it's still doable, but you have to be much more >carefull. Takeoffs will be easy, but with the FP prop, you'll need to keep >the approach close to nuts on (No sloppy, extra fast approaches). I fly a >similar setup off a grass strip that isn't a whole lot longer and can always >(almost) land with a decent amount of runway to spare. If it's not going my >way during the approach, I simply go around and try it again, and again if >need be. > >Just my 2 cents. > >Cheers, >Stein Bruch >RV6's, Minneapolis > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of >tx_jayhawk(at)excite.com >To: rv-list(at)matronics.com >Subject: RV-List: Minimum Realistic Field Length > > > All, Since the plane is still in storage while I look for a home (building >withdrawl), I have been evaluating several airpark possibilities. I would >be interested in hearing from others what they believe the minimum safe >runway lenth would be. I know it is highly subjective, but I would like to >hear from others with experience. For reference...the plane with be a 7A, >O360, with FP prop. Also, there is no real obstacles to think of (never >heard of the Kansas Rockies), and field elevation is approx 1000'. Would a >1400' runway be doable? I know it would be on the short side (go-around if >things don't look just right), but would it be safe? Thanks for the help, >Scottwww.scottsrv7a.com ________________________________________________________________________________
Date: Jan 16, 2005
Follow Kevins advice and as someone else said , practice on a longer field to be sure you can do the landing the SAME way every time. I practiced on an airport with 800' to the turnoff , and when I could stop by the turn-off , I practiced some more. I fly from our 1100' grass strip with 150 HP/ wood prop RV-4 - solo only. I think it would get my wife and me out BUT those odds aren't good enough to put us at risk. Be safe and fly happy. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Jan 16, 2005
(not processed: message from valid local sender) So there is no problem running the wing leveler, AOA tube or antenna wires in the same conduit as the power wires? - Matt -----Original Message----- From: Fiveonepw(at)aol.com Date: Sat, 15 Jan 2005 23:05:59 EST Subject: Re: RV-List: Where to Cut holes in ribs for conduit? (not processed: message ... > > In a message dated 01/15/2005 8:41:41 PM Central Standard Time, > matt(at)n559rv.com writes: > I am at the point where it is time to cut the holes in the ribs for the > conduit (that I got through vans) that contains the wires ran down > the wings... can you tell me where the best place to do this is? They > mention using the tooling holes at the rear of the spar, but that > looks like it is awfully close to the pushrods when looking at the DWG > for the wing... so where do you guys put it? Also, do you only run > one conduit down the wing? I imaging that only one is necessary but I > do > not want to try to cut holes in the ribs later if I am forgetting > something. > >>>>>> > > I made a simple jig that held each rib firmly in the same position- a > short > piece of 2x12 with wood blocks nailed at several places around the edge > of the > rib. I clamped this to the table of my drill press and used a step > drill to > make each hole in the same location, production line style. Mine are > about 2" > behind the spar, about 1" below the top skin (-6A). Took about 10 > minutes to > drill all the ribs for each wing. The holes were sized for a single > length of > 5/8 CPVC. Installing the CPVC took about 5 seconds (chamfer the end > you > insert- slips right through) Once the wires are shoved through > (another couple of > minutes), and the tube is just where ya want it, GOOP the outer end to > the > end rib and move on to other stuff... > > My tips house the typical landing/taxi/postion and strobe lights > (including > the power supplies), and the right wingtip also has the Navaid wing > leveler > servo- still lots of room for antenna wire if desired. > > Fotos if interested- > > From The PossumWorks in TN > Mark Phillips > > > > > > ________________________________________________________________________________
Subject: Re: How to Rebuild an 200hp IO 360 A1A
Date: Jan 16, 2005
Personally, I would be cautious about dealing with a Canadian company. I know there are some good ones but some things to be aware of, 1) Customs fees and, 2) potential state sales taxes. I am in a nightmare ordeal with a Canadian engine company. I am currently out $25K, plus $1300 in Customs fees and another $1500 in State sales taxes. The Customs and State sales taxes were not disclosed by the company for obvious reasons. Additionally, we are now forced to take legal action. Although the "borders" do present some obstacles they are not insurmountable. They were for a few others screwed by the company. These folks did not get an engine or their money back but did not go after them. Darwin N. Barrie Chandler AZ Owner of nearly completed RV that may never fly thanks to a Canadian company. ________________________________________________________________________________
Date: Jan 16, 2005
You can make your own custom wing walk anti-slip surface that matches the paint perfectly. It is better than clear plastic if you want something to blend in. I had my plane professionally painted and wanted to use the clear plastic, but the painter talked me out of it. He painted on the wind walk areas that matched the color of the plane exactly. I watched him and don't recall the exact details but this is the general idea: First he did NOT use the commercial walk paint that leaves a rough surface because it will not match your paint exactly. He made is own anti-skid-walk paint: Tape the area off, any pattern your heart desires; Protect the adjacent areas; Prep the surface and lay down wet paint; Apply anti-skid "sand"; Re-spray paint over the top with the finish coat. It matches the plane perfectly, is even and thin. I believe the "sand" is made for this purpose, and it is fine sand that comes in different colors. I think he got it at the hardware store. Using a shaker or screen he evenly spread the sand out on the wet paint. You blow the excess off, let it tack and paint. Straight forward. It makes a perfect rough surface (not too rough) that is color matched, and in 600 hours never wore thru or off. Even if it did start to wear-off, it would be the same color as the plane. The jet glow paint never wore. It has a nice look, subtle and discreet but still gives a safe walk area. Good Luck. G --------------------------------- ________________________________________________________________________________
Date: Jan 16, 2005
Keep in mind that Hooker will correct any problem. Too long, straps pulling down instead of up to tighten, need loosening straps? Just call them. Mine work great. They even shortened and re-sewed all the extra on the shoulder straps. Looks a lot better. No charge. To the original thread - I think you have them switched right and left Larry Olson RV6 DVT Flying ><< I just replaced my old belts with Hookers and found the shoulder harness >attach points into the lap belt are opposite what I think they should >be. They >have a 90 degree bend in them and look like they should fit together flush. >They way they go together now they seem to interfere. Has anyone else found >this? ________________________________________________________________________________
Date: Jan 16, 2005
Mark, Worst mistake I ever made. Put it on and thought cool! I can still see the color of my wings through it. Then it gets dirty, then you try to clean it and you can't, then you try to take it off. What a mess. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Fiveonepw(at)aol.com Subject: RV-List: Wingwalk material Howdy folks- I've noticed Wicks and ACS are carrying clear wingwalk material. Anyone tried this stuff? Tried to remove it? I also seem to recall seeing some grey wingwalks out there- sources please? http://www.wicksaircraft.com/catalog/product_detail.php/pid=9691~subid=2565/ in dex.html http://www.aircraftspruce.com/catalog/appages/clearwingwalk.php Thanks! Mark ________________________________________________________________________________
Date: Jan 16, 2005
If you're putting a VOR in your bird, I recommend running coax to one or your wingtips for your antenna. You can use that black corrugated plastic tubing as a good, light conduit. Any auto store will have this. Shemp/Jeff Dowling RV-6A, N915JD 150 hours Chicago/Louisville ----- Original Message ----- From: "Mickey Coggins" <mick-matronics(at)rv8.ch> Subject: Re: RV-List: Where to Cut holes in ribs for conduit? > > Here is how I did it: > > http://www.rv8.ch/article.php?story 041026231058140 > > http://www.rv8.ch/article.php?story 041214233000234 > > Stuff that I've run through there are: > > 1) position lights > 2) strobe wires (rather fat bundle) > 3) landing/taxi lights > 4) 2 x 1/8" AOA plastic tubing > > Still to come may be the EFIS magnometer wires, unless > I put them in the fuselage. > > Mickey > > > Matt Johnson wrote: >> >> Dear Sirs, >> >> I am at the point where it is time to cut the holes in the ribs for the >> conduit (that I got through vans) that contains the wires ran down >> the wings... can you tell me where the best place to do this is? They >> mention using the tooling holes at the rear of the spar, but that >> looks like it is awfully close to the pushrods when looking at the DWG >> for the wing... so where do you guys put it? Also, do you only run >> one conduit down the wing? I imaging that only one is necessary but I do >> not want to try to cut holes in the ribs later if I am forgetting >> something. >> >> On another related issue, what items are you needing to run wires for in >> the wings? I can think of landing lights, positioning tip lights, >> AOA instrument... anything else? is there any radio, GPS, EFIS wires or >> anything else that is ran in the wings that I should consider >> while doing this? >> >> - Matt Johnson >> http://www.rv7a.com >> > > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 Wiring > > > ________________________________________________________________________________
Date: Jan 16, 2005
I used Van's black wing walk with the model logo on it. It has always drawn compliments. Very easy to clean, looks great. Still on there after 7.5 years and many stompings, approx 3000 sorties. Still a good anti skid surface. It appears to be a modern 3M product, not the old ugly black things found on older airplanes. Am I the only one who likes the "stock" wing walk?? Denis On Jan 15, 2005, at 7:01 PM, Scott VanArtsdalen wrote: > > I bought some medium gray anti-skid stuff at the local hardware store. > It was on a roll and they just cut a bunch off for me. It sticks > REALLY > well. > > Fiveonepw(at)aol.com wrote: > >> >> Howdy folks- >> >> I've noticed Wicks and ACS are carrying clear wingwalk material. >> Anyone >> tried this stuff? Tried to remove it? I also seem to recall seeing >> some grey >> wingwalks out there- sources please? >> >> http://www.wicksaircraft.com/catalog/product_detail.php/ >> pid=9691~subid=2565/in >> dex.html >> http://www.aircraftspruce.com/catalog/appages/clearwingwalk.php >> >> Thanks! >> Mark >> >> >> >> > > -- > Scott VanArtsdalen > Van Arts Consulting Services > 3848 McHenry Ave > Suite #155-184 > Modesto, CA 95356 > 209-986-4647 > www.rivetbangers.com > Now with email!! > How you want it, > When you want it. > > ________________________________________________________________________________
Date: Jan 16, 2005
> > > > All, Since the plane is still in storage while I look for a home >(building > >withdrawl), I have been evaluating several airpark possibilities. I >would > >be interested in hearing from others what they believe the minimum safe > >runway lenth would be. I know it is highly subjective, but I would like >to > >hear from others with experience. For reference...the plane with be a >7A, > >O360, with FP prop. Also, there is no real obstacles to think of (never > >heard of the Kansas Rockies), and field elevation is approx 1000'. Would >a > >1400' runway be doable? I know it would be on the short side (go-around >if > >things don't look just right), but would it be safe? Thanks for the >help, > >Scottwww.scottsrv7a.com 1000' field elevation? Must be nice! Density altitude here in Albuquerque can often get to 8500' on hot summer days. Takes 1000' just to get the tail up! I'd also dearly love an airpark situation. Just lost two real estate deals at one locally due to piss poor timing. But, I digress. If it wasn't for the runway requirements here, I'd just buy some land out in the middle of nowhere and make my own strip. Would need a couple hundred acres though! Could rent it out to NASA as another backup Space Shuttle landing site. Best of luck to you and yes, practice until you can plant that airplane exactly where you want it every time. Need to have a built-in training factor for muscle memory when you're returning from a long trip with fuel AND mental bandwidth levels running low. Brian Denk RV8 N94BD RV10 '51 ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Re: battery charging
Regardless of the debate about trickle charges and charging, one thing that comes to mind talking about any charger left hooked to your Plane. In a hanger this is a FIRE DANGER. As a few mentioned a case where a battery just blew up ("Blew up real good it did"). It apparently can happen, and charging can set this off, even if the battery was working normally up to that point. I don't know the history of the AGM (absorbed glass mat) or SLA batteries. The "FIRE CODE" for most structures, including commercial buildings like hangers have rules regarding extension cords plugged into chargers or anything for that matter. I am pretty sure it is against "code" to have extension cords plugged in and un-attended. We had fire dept inspections. The Chief would leave warning to occupants (subject to fine) if they found extension cords plugged in. Apparently extension cords are a common cause of fires. Add the danger of that rare but possible case where a battery has an internally short, overheating itself or the charger or both. I just am not comfortable leaving a charger hooked-up and un-attended. In my opinion there is some fire risk. Do it at your own risk, but what about the adjacent hangers. I wounder if insurance would pay off if a battery charger or it's extension chord were the cause of a fire. I know some of the modern chargers have internal short sensing and protection. I also can't believe it but apparently some chargers do not have short or fuse protection. Be careful. G (RV-4, RV-7) --------------------------------- ________________________________________________________________________________
Subject: Final Inspection?
Date: Jan 16, 2005
Bert: EAA members have a lot of this info at their fingertips. Here is what the EAA says you need. http://members.eaa.org/home/govt/issues/inspection_guide_airplane.asp Info on registering and licensing. http://members.eaa.org/home/homebuilders/registering/register.html EAA List of AB DARs. http://members.eaa.org/home/govt/help/ab_dar.asp In the EAA DAR Directory, look for EAA Volunteer DAR. They only charge expenses. There are 2 in Flordia. Looks like many states have at least one except for Texas and California where there are 4 in each state. All the links require EAA membership. Give one of the AB DARs a call and see what they can do for you. If you have a friendly FSDO / MIDO, they also can help. The problem in California is that they have been known to come out but it sometimes takes weeks. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,621 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: bertrv6(at)highstream.net Subject: RV-List: Final Inspection? Date: Sun, 16 Jan 2005 11:15:15 -0500 Hi: I am ready for the final Inspection. I understand I have to have the Alt.and Transponder certified before, the Inspection. What is the bet way to do this, and least expensive? they want $300 for this hour job? HOw about the Static system, can I do that... After this is completed, what is the fastest way to get an Inpector to certify the aircraft..it seems is very difficult here in FL. to get some one. Must one have to pay an DAR, $300 ? Any suggestions on this, is appreciated it... Bert rv6a ________________________________________________________________________________
From: "Joe & Jan Connell" <jconnell(at)rconnect.com>
Subject: Choosing an Engine Monitor JPI EDM-700 vs EI UBG-16-4M
Date: Jan 16, 2005
Greetings, I'm building an RV-9A with an Aerosport Power O-320 and a FP prop. I'm trying choose between a JPI EDM-700 vs a EI UBG-16-4M for the engine monitor. The price through Chief Aircraft is almost a wash. Since all of the aviation mags have both of them as advertisers, there is no neutral party I can find to evaluate them. Either one would be fine with me, but I'd like your insights... Thanks... Joe Connell, RV-9A, N95JJ, finishing Stewartville, MN ________________________________________________________________________________
Subject: How to Rebuild an 200hp IO 360 A1A
Date: Jan 16, 2005
There must be more to the story. I bought my Superior XP-IO-360-B1B from Aero Sport Power in British Columbia. It couldn't have been easier. I think I recall a $35 or $50 customs fee, arranged by Aero Sport Power, and I also think I paid $150 for crating and shipping. I am very pleased with the engine and the entire transaction. The state sales tax will be just like everything else on the airplane - due when I register it. I'm also a little concerned about your characterization of the company only as a Canadian company. Obviously, something went very wrong on your engine purchase, but I'm willing to bet that it had very little to do with the fact that it was located in Canada. As for the state sales tax, that has to be Arizona's rules. What ever happened, it has to be a real bummer. We count on the people we deal with to make their agreements in good faith. I hope you get your money back, but when you do, I would recommend Aero Sport Power as a source for your engine. And they are in Canada. Terry RV-8A #80729 Installing oil cooler Seattle -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Darwin N. Barrie Subject: Re: RV-List: How to Rebuild an 200hp IO 360 A1A Personally, I would be cautious about dealing with a Canadian company. I know there are some good ones but some things to be aware of, 1) Customs fees and, 2) potential state sales taxes. I am in a nightmare ordeal with a Canadian engine company. I am currently out $25K, plus $1300 in Customs fees and another $1500 in State sales taxes. The Customs and State sales taxes were not disclosed by the company for obvious reasons. Additionally, we are now forced to take legal action. Although the "borders" do present some obstacles they are not insurmountable. They were for a few others screwed by the company. These folks did not get an engine or their money back but did not go after them. Darwin N. Barrie Chandler AZ Owner of nearly completed RV that may never fly thanks to a Canadian company. ________________________________________________________________________________
Subject: Shutdown problems and fuel selector valve
Date: Jan 16, 2005
I have been having trouble shutting down my engine, the first case I had was a slipping mixture cable but now the engine does not stop at idle cut off and when the prop does stop it just starts turning the opposite direction. so I finally removed the fuel control servo and I am shipping it back to airflow performance. I spoke with the builder of my airplane and he mentioned he had the same problem shutting down at one point and he just would turn the fuel selector to off and when the engine began to starve he would shutdown and the engine would quit. so, I tried this approach before I removed the servo and no joy, the engine would stumble but not quit. I pushed the plane in the hangar and the fuel inlet hose and the outlet hose were both hanging from the engine.... Hummmm, I turned the fuel selector to off and hit the boost pump. Sure enough fuel was pouring out of the hose I let about a 1/2 gallon run out to make sure it was really pumping fuel from the tanks... My question is.... Is this normal? I would think that if you turn the fuel selector to off then no fuel would go past the firewall. Don at airflow wants to sell me a purge valve but I really do not want to go that route because most people say it is really for hot starts not shutting down. Plus, I like to find the root of a problem not just spending more money to take care of a problem by added heavy expensive stuff. Any and all comment welcome! Jason ________________________________________________________________________________
Date: Jan 16, 2005
I have delt with both companies and own products from both. I have found each to offer a great product and fantastic service. I don't think you can make a mistake either way.(i currently have a JPI 700) John Furey RV6A O-320 CS ________________________________________________________________________________
Subject: heated pitot
Date: Jan 16, 2005
I had wanted to put a heated pitot in the 9A I am building. I saw the letter from Gretz Aero in the archives, and was thinking of getting the Gretz mounting kit and the GA1000 probe if it becomes available. I have been unable to contact Gretz, either by phone or email. I do not want to buy the $900 plus probe from Aircraft Spruce. Does anyone know of other options, mounting kits, etc. Gar Pessel Fairbanks, AK building on and happily flying a 6, once it warms up again. ________________________________________________________________________________
Date: Jan 17, 2005
Darwin: I, as well as many others, have had very good dealing with Canadians. I have had more bad dealings with people here in the US than I have had in Canada. (Greater % of dealing have been negative with companies in the US where I live and am a resident.) Would it be better to say that "...YOU DO NOT FOR ANY REASON ON GODS GREEN EARTH WANT TO DEAL WITH CROSSFLOW!!!! I AM CURRENTLY OUT $26,0000 AND MY NEIGHBOR IS OUT $15,000. Contact me off line for details." From: AZ_RVList Arizona-RV List at yahoogroups.com Fri Jan 14, 2005 5:55 pm The name of the company is now out for all to see and you did not have to post it to this forum to have it out here. I hope that this does not make it difficult for any litigation that is taking place. I just want to set the record straight that all my fellow Canadian aviators are great people. Too bad that they have been keeping secret from the rest of North America how great a vacation value British Columbia is. If I were going to buy an Experimental engine for my amateur built RV aircraft, Canadian company PowerSport would be one of the top 3 picks for a Lycoming (or Lycoming clone) engine. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,621 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ------Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Darwin N. Barrie Subject: Re: RV-List: How to Rebuild an 200hp IO 360 A1A Personally, I would be cautious about dealing with a Canadian company. I know there are some good ones but some things to be aware of, 1) Customs fees and, 2) potential state sales taxes. I am in a nightmare ordeal with a Canadian engine company. I am currently out $25K, plus $1300 in Customs fees and another $1500 in State sales taxes. The Customs and State sales taxes were not disclosed by the company for obvious reasons. Additionally, we are now forced to take legal action. Although the "borders" do present some obstacles they are not insurmountable. They were for a few others screwed by the company. These folks did not get an engine or their money back but did not go after them. Darwin N. Barrie Chandler AZ Owner of nearly completed RV that may never fly thanks to a Canadian company. ________________________________________________________________________________
Subject: Re: Choosing an Engine Monitor JPI EDM-700 vs EI UBG-16-4M
Date: Jan 16, 2005
> I'm building an RV-9A with an Aerosport Power O-320 > and a FP prop. I'm trying choose between a JPI EDM-700 > vs a EI UBG-16-4M for the engine monitor. The price > through Chief Aircraft is almost a wash. Since all of the > aviation mags have both of them as advertisers, there is > no neutral party I can find to evaluate them. Either one would > be fine with me, but I'd like your insights... You might want to consider one of the more comprehensive engine monitor systems. The Advanced Flight Systems ACS2002 (soon to be AF-2500) is the pick of the litter imho. Here's a comparison... http://www.advanced-control-systems.com/MonitorComparisons/monitorscomparison.htm You may find that it ends up cheaper given the other instruments you don't have to buy. Randy Lervold RV-3, fuselage RV-8, sold ________________________________________________________________________________
Subject: Interior paint recommendation
Date: Jan 16, 2005
Hi builders, Just want to post my thoughts on painting my interior this weekend. First off - use an HVLP gravity feed (pot on top) gun. It uses about 1/3 to 1/4 of the paint a suction feed uses. Almost no overspray. No kidding. I went with a Sharppe Cobalt series gun with 1.6 mm tip at 30 PSI. Best $130 I spent so far. Second - I really like the Jet-Flex water reducible interior polyurethane. Water cleanup. Only rates a 2 on health hazard (about the same as cake). Zero on flammability & other stuff. Fast cure, and very tough. Not as tough as the 2 part brain killer, but at 90% who cares. This is a Sherwin Williams product and I used a quart to paint the whole interior, under the panel, and inside the ski tunnel. About $38 FWIW. I wish they had this for exterior paint! DIY no problemo! Now to glue the canopy on. Kelly Patterson RV-6A tipper PHX, AZ ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Re: Cleveland static ports
Kevin Horton wrote: > > > > >> >>I remember reading somewhere some time ago about airspeed indicator error >>using the Cleveland static ports vs. Van's rivets. Searched archives, >>didn't find >>specifics. I believe my airspeed indicator is reading low and wondering if >>the Cleveland static ports may have something to do with it. >>Anyone with actual experience on this issue? >>Dale Ensing >>RV6A N118DE >> >> > >I'm on the road this week, working very long days, so I wasn't keeping up >to date on the RV-List. > >The ideal static port would be at a location where the pressure was equal >to the free stream pressure at every flight condition. Unfortunately, the >air flow has to accelerate and decelerate as it goes around the aircraft, >and Bernoulli's Law tells us that this will cause the pressure to >change. At any given flight condition there are a number of locations on >the aircraft where the pressure is equal to the free stream static >pressure. But, if you change flight conditions, these locations end up >somewhere else. It is very, very difficult to find a good location for >static ports. > >Van's static port is a domed head pop rivet. Some people are offended by >the protruding head, and replace it with something that is flatter, like >the Cleaveland or ACS static ports. But you need to realize that Van isn't >stupid, and there is a reason why he used a protruding static port - it >works. The airflow will have to accelerate a bit as it goes over that >domed head, and this will cause the pressure to fall. In other words, if >you have a more flush static port, at the same location, this port will >sense a higher pressure. ASI readings are a function of the difference >between pitot and static pressures, so the flatter static port will lead to >lower ASI readings. > >I've seem info from several builders who have modified the flush static >ports to make them more like Van's design, and they reported that the >accuracy of their ASI and altimeter improved. I have also seen messages >from two builders who are sure that their ASI is accurate with the flatter >static ports. And I bet most RVers have no idea how accurate their ASI and >altimeter are at all. Every RV is a bit different, due to small changes in >skin contour ahead of the static port, so every one will have a slightly >different static system error. And every ASI has a different instrument >error. If you are lucky, the error in your ASI will cancel out the error >in your static system. > >If your ASI reads a bit low, that is no big deal, except you should lower >your max flap speed and VNE a bit to compensate. But, if you fly IFR you >need to understand that static system errors also affect the altimeter. I >wouldn't want to be shooting instrument approaches without knowing what >errors my altimeter had, and compensating for them. > >You also have to understand that ASIs have instrument error too, so at >first glance there is no way of knowing whether your problem is ASI >instrument error, pitot-static leaks, static system error or a problem with >the way you determined the ASI accuracy. > >I've got a bunch of info on my web site on how to check the ASI accuracy >using a homemade water manometer. Then, I've got info on how to do static >system accuracy flight testing, including a spreadsheet to crunch the >data. See: > >http://members.rogers.com/khorton/rvlinks/ssec.html > >The whole list of links on pitot-static systems is at: > >http://go.phpwebhosting.com/~khorton/rv8/phplinks/index.php?PID=47 > >Kevin Horton >RV-8 (Finishing Kit) >Ottawa, Canada >http://go.phpwebhosting.com/~khorton/rv8/ > I'm one of the guys Kevin helped (over 5 years ago). I've never been too interested in indicated airspeed except knowing what it reads when I'm about to stall. I had noticed that my cruise ASI indication (RV-4) in still air was about 10 kts below what the LORAN was telling me & just wrote it off as normal aircraft quality stuff. The only reason I got concerned about this issue was that after an altimeter I failure & replacement I happened to glance at the new altimeter while doing a 200+mph pass down the runway at my home strip. I discovered that I was flying about 75' below field elevation & surviving the experience. Kevin asked if I had flush static ports; I did. He advised adding 'bumps' over the ports; I did (heads from 3/16" pop rivets, RTV'd over the ports). Not only did it remove the plane's ability to fly 75' below field elevation at 200mph, but it improved my cruise speed by 10 kts :-) (ASI now agreed with LORAN in still air). Charlie (Thanks again, Kevin.) ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Re: static ports
Kevin's explanation for putting the T midpoint between the two ports makes sense, yet the plans for the 7 and 9 have the T on one side. Since I'm just about to install my pop rivet static system, does anyone have any comments about which location is better? Thanks, Mark Irvine, CA ________________________________________________________________________________
Subject: Re: battery charging - better charger?
Date: Jan 16, 2005
All the discussion about "trickle chargers", "float chargers", "cooking the battery", "boiling or otherwise losing electrolyte" - the charger I bought from Wal-mart, Schumacher, for about $25 (1998), has a selectable 2 or 10 amp charge rate. I have monitored it (by hooking up my multimeter to its leads on the battery terminals) on several batteries over the past 7 years and here's how it operates, which seems ideal to me: It slowly increases voltage until it reaches about 14.2v (If I remember correctly, or slightly higher) (on my multimeter I have clipped onto the charger's clips), then SHUTS OFF (green light comes on. Now the battery is self-discharging and slowly goes down to 13.0 V (12.99) at which time the charging current is turned back on, starts at 13.5 or so and slowly builds up again to 14.2v and shuts off again. A battery that was badly discharged, would take a long time to reach 14.2 and shutdown for freefall, but would freefall rather rapidly (maybe a minute to reach 13.0). A fully charged battery would discharge very slowly (15' or more) and when it came on at 12.99v, it would reach 14.2 in about the blink of an eye - 1 second or so and do another very slow freefall. So, the fully charged battery was only being "momentarily pulsed" with current, not continuously - no boiling or losing electrolyte. Isn't this about as good as one could want? David ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Re: Shutdown problems and fuel selector valve
clamav-milter version 0.80j on zoot.lafn.org Jason, Sounds like you have a plumbing problem - the valve should shut the fuel off completely. My guess is that either the valve is bad (unlikely) or it's installed incorrectly. However your problem with the engine not shutting down with the mixture control is NORMAL in most airplanes with AFP fuel injection. Mine did the same thing after about 50 hours and Don at AFP told me the same thing - install the purge valve. I did so reluctantly, but it's one of the best mods I've done on the airplane! It not only shuts down cleanly, but it starts reliably every time no mater how hot it is. I'd do it again in a minute! I recommend that anyone with AFP seriously consider installing the purge valve. Dave RV6, So Cal EAA Technical Counselor and Flight Advisor Jason Sneed wrote: > >I have been having trouble shutting down my engine, the first case I >had was a slipping mixture cable but now the engine does not stop at >idle cut off and when the prop does stop it just starts turning the >opposite direction. so I finally removed the fuel control servo and I >am shipping it back to airflow performance. I spoke with the builder of >my airplane and he mentioned he had the same problem shutting down at >one point and he just would turn the fuel selector to off and when the >engine began to starve he would shutdown and the engine would quit. > >so, I tried this approach before I removed the servo and no joy, the >engine would stumble but not quit. I pushed the plane in the hangar and >the fuel inlet hose and the outlet hose were both hanging from the >engine.... Hummmm, I turned the fuel selector to off and hit the boost >pump. Sure enough fuel was pouring out of the hose I let about a 1/2 >gallon run out to make sure it was really pumping fuel from the >tanks... > >My question is.... Is this normal? I would think that if you turn the >fuel selector to off then no fuel would go past the firewall. > >Don at airflow wants to sell me a purge valve but I really do not want >to go that route because most people say it is really for hot starts >not shutting down. Plus, I like to find the root of a problem not just >spending more money to take care of a problem by added heavy expensive >stuff. > >Any and all comment welcome! > >Jason > > > > ________________________________________________________________________________
Date: Jan 16, 2005
I bought some of the clear wing walk material from aircraft spruce. I cut this to the appropriate size, rounded the corners. I then painted this wing walk material with the paint I used to paint my plane, PPG Concept. I then peeled the backing off the wing walk material and applied it to the plane. This has been on the plane for 300 hours and shows now wear. Paint still looks good. John Danielson -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com Subject: RV-List: Wingwalk material Howdy folks- I've noticed Wicks and ACS are carrying clear wingwalk material. Anyone tried this stuff? Tried to remove it? I also seem to recall seeing some grey wingwalks out there- sources please? http://www.wicksaircraft.com/catalog/product_detail.php/pid=9691~subid=2 565/in dex.html http://www.aircraftspruce.com/catalog/appages/clearwingwalk.php Thanks! Mark ________________________________________________________________________________
Date: Jan 16, 2005
Some of us with long memories wouldn't buy a free lunch from JPI, but it's your problem only if you choose to make it yours. Check the archives back a few years to see what they tried to do to our man Matt and his Matronics. Terry -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Joe & Jan Connell Subject: RV-List: Choosing an Engine Monitor JPI EDM-700 vs EI UBG-16-4M Greetings, I'm building an RV-9A with an Aerosport Power O-320 and a FP prop. I'm trying choose between a JPI EDM-700 vs a EI UBG-16-4M for the engine monitor. The price through Chief Aircraft is almost a wash. Since all of the aviation mags have both of them as advertisers, there is no neutral party I can find to evaluate them. Either one would be fine with me, but I'd like your insights... Thanks... Joe Connell, RV-9A, N95JJ, finishing Stewartville, MN ________________________________________________________________________________
Date: Jan 16, 2005
Ah shoot. So I will have ASI errors then with my static ports. Take a look at them in my RV file if you get a chance. hope the link works. http://f1.pg.briefcase.yahoo.com/mark2nite mark riverside,ca --- Charlie England wrote: > > > Kevin Horton wrote: > > > > > > > > > > > >> > >>I remember reading somewhere some time ago about > airspeed indicator error > >>using the Cleveland static ports vs. Van's rivets. > Searched archives, > >>didn't find > >>specifics. I believe my airspeed indicator is > reading low and wondering if > >>the Cleveland static ports may have something to > do with it. > >>Anyone with actual experience on this issue? > >>Dale Ensing > >>RV6A N118DE > >> > >> > > > >I'm on the road this week, working very long days, > so I wasn't keeping up > >to date on the RV-List. > > > >The ideal static port would be at a location where > the pressure was equal > >to the free stream pressure at every flight > condition. Unfortunately, the > >air flow has to accelerate and decelerate as it > goes around the aircraft, > >and Bernoulli's Law tells us that this will cause > the pressure to > >change. At any given flight condition there are a > number of locations on > >the aircraft where the pressure is equal to the > free stream static > >pressure. But, if you change flight conditions, > these locations end up > >somewhere else. It is very, very difficult to find > a good location for > >static ports. > > > >Van's static port is a domed head pop rivet. Some > people are offended by > >the protruding head, and replace it with something > that is flatter, like > >the Cleaveland or ACS static ports. But you need > to realize that Van isn't > >stupid, and there is a reason why he used a > protruding static port - it > >works. The airflow will have to accelerate a bit > as it goes over that > >domed head, and this will cause the pressure to > fall. In other words, if > >you have a more flush static port, at the same > location, this port will > >sense a higher pressure. ASI readings are a > function of the difference > >between pitot and static pressures, so the flatter > static port will lead to > >lower ASI readings. > > > >I've seem info from several builders who have > modified the flush static > >ports to make them more like Van's design, and they > reported that the > >accuracy of their ASI and altimeter improved. I > have also seen messages > >from two builders who are sure that their ASI is > accurate with the flatter > >static ports. And I bet most RVers have no idea > how accurate their ASI and > >altimeter are at all. Every RV is a bit different, > due to small changes in > >skin contour ahead of the static port, so every one > will have a slightly > >different static system error. And every ASI has a > different instrument > >error. If you are lucky, the error in your ASI > will cancel out the error > >in your static system. > > > >If your ASI reads a bit low, that is no big deal, > except you should lower > >your max flap speed and VNE a bit to compensate. > But, if you fly IFR you > >need to understand that static system errors also > affect the altimeter. I > >wouldn't want to be shooting instrument approaches > without knowing what > >errors my altimeter had, and compensating for them. > > > >You also have to understand that ASIs have > instrument error too, so at > >first glance there is no way of knowing whether > your problem is ASI > >instrument error, pitot-static leaks, static system > error or a problem with > >the way you determined the ASI accuracy. > > > >I've got a bunch of info on my web site on how to > check the ASI accuracy > >using a homemade water manometer. Then, I've got > info on how to do static > >system accuracy flight testing, including a > spreadsheet to crunch the > >data. See: > > > >http://members.rogers.com/khorton/rvlinks/ssec.html > > > >The whole list of links on pitot-static systems is > at: > > > >http://go.phpwebhosting.com/~khorton/rv8/phplinks/index.php?PID=47 > > > >Kevin Horton > >RV-8 (Finishing Kit) > >Ottawa, Canada > >http://go.phpwebhosting.com/~khorton/rv8/ > > > > I'm one of the guys Kevin helped (over 5 years ago). > I've never been too > interested in indicated airspeed except knowing what > it reads when I'm > about to stall. I had noticed that my cruise ASI > indication (RV-4) in > still air was about 10 kts below what the LORAN was > telling me & just > wrote it off as normal aircraft quality stuff. The > only reason I got > concerned about this issue was that after an > altimeter I failure & > replacement I happened to glance at the new > altimeter while doing a > 200+mph pass down the runway at my home strip. I > discovered that I was > flying about 75' below field elevation & surviving > the experience. > > Kevin asked if I had flush static ports; I did. He > advised adding > 'bumps' over the ports; I did (heads from 3/16" pop > rivets, RTV'd over > the ports). Not only did it remove the plane's > ability to fly 75' below > field elevation at 200mph, but it improved my cruise > speed by 10 kts :-) > (ASI now agreed with LORAN in still air). > > deleted from this > space> > > Charlie > (Thanks again, Kevin.) > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > === message truncated == __________________________________ http://info.mail.yahoo.com/mail_250 ________________________________________________________________________________
Subject: Re: heated pitot
Date: Jan 16, 2005
Hi Gar, I have a Cessna heated pitot that I bought a while back at a wrecker. It will be used in place of the Dynon heated Pitot that I hope will come into production soon. Dynon already produces the non heated model that I think will be upgradeable to heated type by adding the heater when it comes available. Dynons stated price for the unheated pitot is $199.00 http://www.dynondevelopment.com/index.html I took a look at how Cessna approached the mounting issue. I built my own mounting bracket section for the Cessna unit. Rocket science does not apply here. I hand formed mine out of .032 sheet material and had a friend weld the parts. The outcome is quite satisfactory and should also fit the newer Dynon unit. Hand drawn picture available. Photos also. I expect that the serviceable used units will be few and far between now that the new unit prices have skyrocketed. The used prices will likely be reflecting today's new unit pricing by now. $900.00!, It is hard to believe that the cost of an already existing and in production design heated pitot could jump that much. Maybe that's in "monopoly" money?!{[;-` Jim in Kelowna ----- Original Message ----- From: "Gar Pessel" <pessel(at)ptialaska.net> Subject: RV-List: heated pitot > > I had wanted to put a heated pitot in the 9A I am building. I saw the > letter from Gretz Aero in the archives, and was thinking of getting the > Gretz mounting kit and the GA1000 probe if it becomes available. I have > been unable to contact Gretz, either by phone or email. I do not want to > buy the $900 plus probe from Aircraft Spruce. Does anyone know of other > options, mounting kits, etc. > > Gar Pessel Fairbanks, AK building on and happily flying a 6, once it > warms up again. > > > ________________________________________________________________________________
Date: Jan 17, 2005
I have an Airflow Performance system in my -4 and use an Andair fuel selector to control the fuel flow. Although I do not shut down the engine with the Andair valve, I do know that in the OFF position, it allows no flow. For what it's worth, I have the purge valve option in my aircraft and have had no problems for the 3 years I have been flying my plane. Dean RV-4 Bolton, MA ----Original Message Follows---- From: Jason Sneed <n242ds(at)cox.net> Subject: RV-List: Shutdown problems and fuel selector valve Date: Sun, 16 Jan 2005 19:06:39 -0600 I have been having trouble shutting down my engine, the first case I had was a slipping mixture cable but now the engine does not stop at idle cut off and when the prop does stop it just starts turning the opposite direction. so I finally removed the fuel control servo and I am shipping it back to airflow performance. I spoke with the builder of my airplane and he mentioned he had the same problem shutting down at one point and he just would turn the fuel selector to off and when the engine began to starve he would shutdown and the engine would quit. so, I tried this approach before I removed the servo and no joy, the engine would stumble but not quit. I pushed the plane in the hangar and the fuel inlet hose and the outlet hose were both hanging from the engine.... Hummmm, I turned the fuel selector to off and hit the boost pump. Sure enough fuel was pouring out of the hose I let about a 1/2 gallon run out to make sure it was really pumping fuel from the tanks... My question is.... Is this normal? I would think that if you turn the fuel selector to off then no fuel would go past the firewall. Don at airflow wants to sell me a purge valve but I really do not want to go that route because most people say it is really for hot starts not shutting down. Plus, I like to find the root of a problem not just spending more money to take care of a problem by added heavy expensive stuff. Any and all comment welcome! Jason http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Jan 17, 2005
> I have a Cessna heated pitot that I bought a while back at a wrecker. It > will be used in place of the Dynon heated Pitot that I hope will come into > production soon. Dynon already produces the non heated model that I think > will be upgradeable to heated type by adding the heater when it comes > available. > Dynons stated price for the unheated pitot is $199.00 > http://www.dynondevelopment.com/index.html > > I took a look at how Cessna approached the mounting issue. I built my own > mounting bracket section for the Cessna unit. Rocket science does not apply > here. I hand formed mine out of .032 sheet material and had a friend weld > the parts. The outcome is quite satisfactory and should also fit the newer > Dynon unit. I too decided that I would use a Cessna pitot instead of shelling out $900.00 bucks for a pretty one. Getting the pitot to fit the Gretz mount is trivial. There's basically a stair-step toward the top of the pitot that needs to be lengthened about .125 inches or so. You'll also need to file down just a bit of 'diameter' from the stair-step to make it work. Here are some pictures: http://rv.jpainter.org/?view=entry&date 04-10-20 And here's a shot of it temporarily mounted on the wing. http://rv.jpainter.org/images/2004-12-18.401.jpeg The only concern I have about this is the length of the mount. It seems *really* long. Does anyone monitoring the list have any recommendations on shortening the pitot? Is this a bad move that will lead to unpredictable results? Thanks, Jamie -- Jamie D. Painter RV-7A wings N622JP (reserved) http://rv.jpainter.org ________________________________________________________________________________
Date: Jan 17, 2005
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Re: Wing walk material
I used the 3M anti slip stuff, which is made from rubber material. The down side is it is about .040 thick and comes in 4" wide roll so you have to double up. The good side is it will never wear out. The standard sand paper type stuff, well I think it is no good. While working on the plane in the summer I was getting in and out of the cockpit many times on a hot day and the adhesive that holds the sand in place softened and came up. Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Subject: Washington, DC RV Hanger.
Date: Jan 17, 2005
We have tickets to the Inauguration this Thur. We want to fly in on Wed night and out Thur night. Any suggestion on where to fly into given the TFRs? Any chance I could get a hanger for the RV nearby? ERic-- ________________________________________________________________________________
Date: Jan 17, 2005
Hi Joe, I'm using the UBG. I'm not sure if its the same as you are asking about, but it is a 2 inch bar graph (orange display) with 4 EGT's, 4 CHT's and OAT. It does log data, but I have never used that feature. I had to use a separate dimmer control (which came with it) which doesn't work real well (not much range), because it is not compatible with my other lights, but that's not much of a problem really. If you are like me and have a basic low-tech panel, I think it is an OK way to go. Support has been good. I sent the original EGT probes back to EI and got the quick response ones. Later I needed some more terminals to shorten up the wiring, and EI sent them no charge. They were very good to deal with. Dan Hopper Walton, IN RV-7A (Flying since July) In a message dated 1/16/05 8:05:16 P.M. US Eastern Standard Time, jconnell(at)rconnect.com writes: Greetings, I'm building an RV-9A with an Aerosport Power O-320 and a FP prop. I'm trying choose between a JPI EDM-700 vs a EI UBG-16-4M for the engine monitor. The price through Chief Aircraft is almost a wash. Since all of the aviation mags have both of them as advertisers, there is no neutral party I can find to evaluate them. Either one would be fine with me, but I'd like your insights... Thanks... Joe Connell, RV-9A, N95JJ, finishing Stewartville, MN ________________________________________________________________________________
Date: Jan 17, 2005
In a message dated 1/17/05 12:52:31 A.M. US Eastern Standard Time, m schrimmer(at)pacbell.net writes: --> RV-List message posted by: Mark Schrimmer Kevin's explanation for putting the T midpoint between the two ports makes sense, yet the plans for the 7 and 9 have the T on one side. Since I'm just about to install my pop rivet static system, does anyone have any comments about which location is better? Thanks, Mark Irvine, CA Mark, I put the T in the center with equal lengths of tubing on each side. It may not matter because the holes in the static ports are much smaller than the tubing which connects them to the T. Still, its easy to relocate the T to the top of the bulkhead. Dan Hopper Walton, IN RV-7A (Flying) ________________________________________________________________________________
Date: Jan 17, 2005
Gary released the company name. As I said in the beginning there are many good one in Canada, Aerosport being one of them. Regarding Crossflow we have documented several similar business dealings that would fall into a trend or pattern. I believe a reputable company, like Aerosport, probably discloses any potential "other" charges that might be incurred. Had I known I was going to get tagged with an additional $3000, that would have been a deal breaker for sure. The Canadian aviators that I have met have been great, especially the RV guys. In summary, my point wasn't to condemn Canada in anyway but to make US buyers aware that you can and will get slapped with some potentially heavy additional costs. If we were to survey the list I believe there would be a healthy volume of members that didn't know. Darwin N. Barrie Chandler AZ ________________________________________________________________________________
Date: Jan 17, 2005
This may sound a little odd, but I still like the looks of the old-style round analog instrumets. I don't want a glass cockpit (well most days). I wish the ACS CPU could drive analog instrument heads while still providing the alarms and recording capabilities. I'm inclined to buy all analog engine instruments and the UBG-16 and fuel totalizer for the simple cosmetics of it. The same goes for the primary flight instruments. The price difference between old style and new is not that much. And for what you get with the new stuff (ACS, Dynon), it's a better deal. Although I've never flown behind an ACS or Dynon unit. Has anyone wished they had thier old-style instruments and guages? Even a little? Or does it depend on the plane. Keep the old-style instruments and guages for the cubs and champs? Slayden RV8 Fuse --- Randy Lervold wrote: > > > I'm building an RV-9A with an Aerosport Power O-320 > > and a FP prop. I'm trying choose between a JPI EDM-700 > > vs a EI UBG-16-4M for the engine monitor. The price > > through Chief Aircraft is almost a wash. Since all of the > > aviation mags have both of them as advertisers, there is > > no neutral party I can find to evaluate them. Either one would > > be fine with me, but I'd like your insights... > > You might want to consider one of the more comprehensive engine > monitor > systems. The Advanced Flight Systems ACS2002 (soon to be AF-2500) is > the > pick of the litter imho. Here's a comparison... > http://www.advanced-control-systems.com/MonitorComparisons/monitorscomparison.htm > > You may find that it ends up cheaper given the other instruments you > don't > have to buy. > > Randy Lervold > RV-3, fuselage > RV-8, sold > > > > > > > > > ________________________________________________________________________________
Date: Jan 17, 2005
Jason, Actually if you have an airflow performance you really should have the purge/shutoff valve. The Airflow design keeps the mixture valve from totally seating during shutdown. That way the valve won't get hammered. Teh purge valve is not just for hot starting. It is also used for shutdown. I just leave the mixture in whatever position and shut the engine down with the purge valve. I also circulate the fuel before starting to get any air bubbles out of the system, whether it is cold or hot. Works great. And we have not had any problems at all with it. Mike Robertson >From: Jason Sneed <n242ds(at)cox.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Shutdown problems and fuel selector valve >Date: Sun, 16 Jan 2005 19:06:39 -0600 > > >I have been having trouble shutting down my engine, the first case I >had was a slipping mixture cable but now the engine does not stop at >idle cut off and when the prop does stop it just starts turning the >opposite direction. so I finally removed the fuel control servo and I >am shipping it back to airflow performance. I spoke with the builder of >my airplane and he mentioned he had the same problem shutting down at >one point and he just would turn the fuel selector to off and when the >engine began to starve he would shutdown and the engine would quit. > >so, I tried this approach before I removed the servo and no joy, the >engine would stumble but not quit. I pushed the plane in the hangar and >the fuel inlet hose and the outlet hose were both hanging from the >engine.... Hummmm, I turned the fuel selector to off and hit the boost >pump. Sure enough fuel was pouring out of the hose I let about a 1/2 >gallon run out to make sure it was really pumping fuel from the >tanks... > >My question is.... Is this normal? I would think that if you turn the >fuel selector to off then no fuel would go past the firewall. > >Don at airflow wants to sell me a purge valve but I really do not want >to go that route because most people say it is really for hot starts >not shutting down. Plus, I like to find the root of a problem not just >spending more money to take care of a problem by added heavy expensive >stuff. > >Any and all comment welcome! > >Jason > > ________________________________________________________________________________
Subject: Large connector thru firewall
Date: Jan 17, 2005
Guys, I'm afraid my LASAR brain will not fit in the very limited space on the firewall of the RV-3B I'm building. The good news is that I have plenty of space just aft of the firewall. In order to mount it aft of the firewall I'll need to pass the two magneto connectors through the firewall. Looks like I'll need a 1.5" hole to get them through. Once they are through they are normal sized wire bundles. I'm scratching my head as to a method of accomplishing this... the eyeball connectors use a 1.125" hole, those common grommet w/ss shields only go up to 1.25". Any ideas for other methods? Randy Lervold www.rv-3.com ________________________________________________________________________________
Date: Jan 17, 2005
From: Scott Bilinski <bilinski@kyocera-wireless.com> UBG-16-4M
UBG-16-4M My 2$ (could not find the cent symbol) opinion is that how can you afford not to know what is going on in your $20K plus engine? A engine monitor will find problems before you do, allowing more time to hopefully land safely. I have the VM-1000 and love it. Its about 9 instruments in one, and saves large amounts of panel space. In cruise mode it can watch the engine for you and let you know when anything changes more than ???? 5%. This is a great function for the longer trips. I am not pushing the VM-1000, but I am pushing a engine monitor, I think it is a must have with no good excuses not to have one. > >This may sound a little odd, but I still like the looks of the >old-style round analog instrumets. I don't want a glass cockpit (well >most days). I wish the ACS CPU could drive analog instrument heads >while still providing the alarms and recording capabilities. > >I'm inclined to buy all analog engine instruments and the UBG-16 and >fuel totalizer for the simple cosmetics of it. The same goes for the >primary flight instruments. The price difference between old style and >new is not that much. And for what you get with the new stuff (ACS, >Dynon), it's a better deal. > >Although I've never flown behind an ACS or Dynon unit. Has anyone >wished they had thier old-style instruments and guages? Even a little? > >Or does it depend on the plane. Keep the old-style instruments and >guages for the cubs and champs? > >Slayden >RV8 Fuse > >--- Randy Lervold wrote: > > > > > > I'm building an RV-9A with an Aerosport Power O-320 > > > and a FP prop. I'm trying choose between a JPI EDM-700 > > > vs a EI UBG-16-4M for the engine monitor. The price > > > through Chief Aircraft is almost a wash. Since all of the > > > aviation mags have both of them as advertisers, there is > > > no neutral party I can find to evaluate them. Either one would > > > be fine with me, but I'd like your insights... > > > > You might want to consider one of the more comprehensive engine > > monitor > > systems. The Advanced Flight Systems ACS2002 (soon to be AF-2500) is > > the > > pick of the litter imho. Here's a comparison... > > >http://www.advanced-control-systems.com/MonitorComparisons/monitorscomparison.htm > > > > You may find that it ends up cheaper given the other instruments you > > don't > > have to buy. > > > > Randy Lervold > > RV-3, fuselage > > RV-8, sold > > > > > > > > > > > > > > > > > > > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Subject: RE: heated pitot
Date: Jan 17, 2005
I found a used Cessna heated pitot on eBay for less than $150. There are some listed there now (search on 'heated pitot'). Dennis Glaeser ________________________________________________________________________________
Subject: Re: Large connector thru firewall
Date: Jan 17, 2005
If the leads are long enough, you could put them through the side of the fuselage under one of the cowl cheek enxtensions, and not cut the holes in your firewall. This is what I did for the coax cable for my LSI system, even though I could have gone through the firewall. You may be able to find some rubber grommets to fill a 1.5" hole. If not, you could fabricate a removable two-piece patch out of aluminum to cover the large hole, but with a smaller hole for the grommet. Rion ----- Original Message ----- From: "Randy Lervold" <randy(at)romeolima.com> Subject: RV-List: Large connector thru firewall > > Guys, > I'm afraid my LASAR brain will not fit in the very limited space on the > firewall of the RV-3B I'm building. The good news is that I have plenty of > space just aft of the firewall. In order to mount it aft of the firewall > I'll need to pass the two magneto connectors through the firewall. Looks > like I'll need a 1.5" hole to get them through. Once they are through they > are normal sized wire bundles. I'm scratching my head as to a method of > accomplishing this... the eyeball connectors use a 1.125" hole, those > common > grommet w/ss shields only go up to 1.25". Any ideas for other methods? > > Randy Lervold > www.rv-3.com > > > ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Jan 17, 2005
> I'll need a 1.5" hole to get them through. Once they are > through they are normal sized wire bundles. Randy, can you make two SS sheet metal pieces which overlap? Hard to describe with words, but imagine this: cut a circle of the SS (can get from McMaster) about 2.25" in diameter, cut a hole in the middle large enough for the wire-only grommet, then cut a slot just wide enough for the wire bundle, from this smaller hole to an edge. The second piece would overlap the slot. Done appropriately, it should mount up with two, maybe three screws. Alex Peterson RV6-A 569 hours (supposed to get above zero tomorrow, finally) Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jan 17, 2005
Try this link to ACS for heated pitot only for experimental use. Part @ 10-01022 12 volt $398.00 still high but better than nothing and better than $900. This is the L shaped variety. Have been told that you can find them in aircraft junkyards for less than $100 but have had no luck. http://www.aircraftspruce.com/catalog/inpages/homepitot.php If anyone knows a reason why this would be inappropriate, please holler as I am planning on putting one in my 7. Bill Schlatterer 7a QB -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Gar Pessel Subject: RV-List: heated pitot I had wanted to put a heated pitot in the 9A I am building. I saw the letter from Gretz Aero in the archives, and was thinking of getting the Gretz mounting kit and the GA1000 probe if it becomes available. I have been unable to contact Gretz, either by phone or email. I do not want to buy the $900 plus probe from Aircraft Spruce. Does anyone know of other options, mounting kits, etc. Gar Pessel Fairbanks, AK building on and happily flying a 6, once it warms up again. ________________________________________________________________________________
Date: Jan 17, 2005
Putting mine high center fuse to make them self draining as well. Low spot is the static port. Someone else recommended this and I only assume that it will work OK. Seems like it should. Bill S 7a Arkansas -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Mark Schrimmer Subject: RV-List: Re: static ports Kevin's explanation for putting the T midpoint between the two ports makes sense, yet the plans for the 7 and 9 have the T on one side. Since I'm just about to install my pop rivet static system, does anyone have any comments about which location is better? Thanks, Mark Irvine, CA ________________________________________________________________________________
Date: Jan 17, 2005
There were quite a few posts on this subject on one of the groups a week ago. I like the eye balls but one guy had picts of lightweight flanges and short pipe made out of railing for the handicapped. i.e. shower support rails. looked pretty good. mark p.s. now i know who to call if I need to figure out where the six wires on the LASAR go. ________________________________________________________________________________
Subject: RV8 windscreen for sale
Date: Jan 17, 2005
Posting for a friend. Van's RV8 windscreen for sale. Asking $50 plus postage. Contact off list at: cloudchasers73768(at)hotmail.com Jerry Calvert N296JC RV6 Edmond Ok ________________________________________________________________________________
Date: Jan 18, 2005
I'm with you Steve. Very comfortable behind the old "Steam Gauges". These young Bucks that enjoy the electrons flying around, I don't understand. Some of the posts about technical things I just delete. It's a bugger not being up with the play. When I look at my old fashioned six stack, I know just what is going on. I have however, gone with the ACS 2002 in my 7. It is right up there in price, but it is quality, and monitors all the engine functions. You will hear when your engine stops, but flying your aircraft to a sucessful conclusion is the thing that matters. Stan. -------Original Message------- From: rv-list(at)matronics.com Date: Tuesday, January 18, 2005 08:57:49 Subject: Re: RV-List: Choosing an Engine Monitor JPI EDM-700 vs EI UBG-16-4M This may sound a little odd, but I still like the looks of the old-style round analog instrumets. I don't want a glass cockpit (well most days). I wish the ACS CPU could drive analog instrument heads while still providing the alarms and recording capabilities. I'm inclined to buy all analog engine instruments and the UBG-16 and fuel totalizer for the simple cosmetics of it. The same goes for the primary flight instruments. The price difference between old style and new is not that much. And for what you get with the new stuff (ACS, Dynon), it's a better deal. Although I've never flown behind an ACS or Dynon unit. Has anyone wished they had thier old-style instruments and guages? Even a little? Or does it depend on the plane. Keep the old-style instruments and guages for the cubs and champs? Slayden RV8 Fuse --- Randy Lervold wrote: > > > I'm building an RV-9A with an Aerosport Power O-320 > > and a FP prop. I'm trying choose between a JPI EDM-700 > > vs a EI UBG-16-4M for the engine monitor. The price > > through Chief Aircraft is almost a wash. Since all of the > > aviation mags have both of them as advertisers, there is > > no neutral party I can find to evaluate them. Either one would > > be fine with me, but I'd like your insights... > > You might want to consider one of the more comprehensive engine > monitor > systems. The Advanced Flight Systems ACS2002 (soon to be AF-2500) is > the > pick of the litter imho. Here's a comparison... > http://www.advanced-control-systems com/MonitorComparisons/monitorscomparison.htm > > You may find that it ends up cheaper given the other instruments you > don't > have to buy. > > Randy Lervold > RV-3, fuselage > RV-8, sold > > ________________________________________________________________________________
Date: Jan 18, 2005
Randy, I had the same problem with my dual Lightspeed EI setup. I went to the aircraft aisle at Home Depot and got a 1 1/2 inch aluminum electrical conduit connector. It has slightly over 1 1/2 inch ID and is about 1/8 inch thick casting. It has a threaded end with a large nut that will attach it to the firewall. After routing all your wires, tubes, etc., pack it with RTV and wrap the firewall end with firestop fabric and secure with two hose clamps. I am putting nearly all of my firewall forward wires through this one hole. Ron Schreck RV-8 Gold Hill Airpark, NC From: "Randy Lervold" <randy(at)romeolima.com> Subject: Large connector thru firewall Guys, I'm afraid my LASAR brain will not fit in the very limited space on the firewall of the RV-3B I'm building. The good news is that I have plenty of space just aft of the firewall. In order to mount it aft of the firewall I'll need to pass the two magneto connectors through the firewall. Looks like I'll need a 1.5" hole to get them through. Once they are through they are normal sized wire bundles. I'm scratching my head as to a method of accomplishing this... the eyeball connectors use a 1.125" hole, those common grommet w/ss shields only go up to 1.25". Any ideas for other methods? Randy Lervold www.rv-3.com ________________________________________________________________________________
Date: Jan 18, 2005
I would recommend using a bulkhead (firewall) connector. This is a little more work to install, but is provides much easier removal for subsequent maintenance/repair. Amphenol make a series of excellent bulkhead connectors. These connectors have three basic parts - a connector mounted to the firewall that accepts a plug from either side of firewall, a plug on the engine side for the Lasar engine wiring, and a plug on the pilot side of the firewall for the wires from the Lasar "brain". This technique is quite common on the Lancair series of aircraft as well as many military aircraft. Good Luck, Dean ----Original Message Follows---- From: "Randy Lervold" <randy(at)romeolima.com> Subject: RV-List: Large connector thru firewall Date: Mon, 17 Jan 2005 11:42:42 -0800 Guys, I'm afraid my LASAR brain will not fit in the very limited space on the firewall of the RV-3B I'm building. The good news is that I have plenty of space just aft of the firewall. In order to mount it aft of the firewall I'll need to pass the two magneto connectors through the firewall. Looks like I'll need a 1.5" hole to get them through. Once they are through they are normal sized wire bundles. I'm scratching my head as to a method of accomplishing this... the eyeball connectors use a 1.125" hole, those common grommet w/ss shields only go up to 1.25". Any ideas for other methods? Randy Lervold www.rv-3.com http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Subject: Re: Orlando RV forced landing
Date: Jan 18, 2005
We checked out this story today with the Minneapolis FSDO. Here's what one of our reporters sent me. "The FAA says the hydraulic failure and the bullet hole are unrelated. Here's another interesting bit: the hole is on the top the wing. They speculate someone fired a deer rifle in the air and the bullet struck the plane at "low energy" on the way down." "Rest of the investigation is being turned over to FBI (haven't heard back from them yet)." Regards, Bob Collins St. Paul ________________________________________________________________________________
Subject: Dynon ramblings & Electronic HSI
Date: Jan 18, 2005
All, I have flown the latest and greatest version of the D-10 software for about 20 hours or so and I now have the confidence in this version to rip out my vacuum system. I have been holding back because I could have easily pulled out the Dynon and replaced it with my vacuum gyro in moments. But with 18 months of experience and now that we have a good stable software package I am ready to make the leap into the land of no vacuum pump. Great Work Guys!!!!! That means the DG will go as well. I won't miss it because I have not even been setting it lately because I don't use it at all. Now for what I want. I want Dynon to build an HSI. Not a big fancy one with moving maps and waypoint displays and all that, just a simple HSI that encorporates GPS switching and ennunciator functions, Approach, enroute and OBS modes for GPS. An RMI feature would be nice also but not essential so you could display both VOR and GPS info simaltaneously. Also a feature that would switch the autopilot driver. VOR, GPS-NAV, GPS Track or Heading bug. I've seen the Blue Mountain product is coming, and maybe that is the answer, but I really like the form factor, the customer service, and the display of the Dynon. I am not sure the folks at Dynon understand how many people would buy an HSI. Most home builts do not have HSI's and several pilots have never flown with one, but it is not because they would not love one if they used it, just because the trainers they learned in did not have one. This would replace a DG, a VOR Head, a GPS annunciator, any Autopilot switch gear, and a backup display for the D-10 If they could do this at the $2000 price point, they would sell like cordwood. So my objective it make them understand that this would be a big market. (are you listening Doug Medema?) Everybody pile on. Tailwinds, Doug "I wanna a HSI" Rozendaal ________________________________________________________________________________
Subject: Re: Minimum Realistic Field Length
Date: Jan 18, 2005
If you haven't bought the property yet, one consideration for a longer strip might be whether or not you want other pilots to land at your field. Of course, a short field could also screen out some of the pilots you may not want to visit you. Does your mother-in-law fly an RV? :) Don -----Original Message----- From: Oldsfolks(at)aol.com [mailto:Oldsfolks(at)aol.com] Subject: RV-List: Re: Minimum Realistic Field Length Follow Kevins advice and as someone else said , practice on a longer field to be sure you can do the landing the SAME way every time. I practiced on an airport with 800' to the turnoff , and when I could stop by the turn-off , I practiced some more. I fly from our 1100' grass strip with 150 HP/ wood prop RV-4 - solo only. I think it would get my wife and me out BUT those odds aren't good enough to put us at risk. Be safe and fly happy. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers advertising on the Matronics Forums. ________________________________________________________________________________
From: "Maureen & Bob Christensen" <mchriste(at)danvilletelco.net>
Subject: Re: Dynon ramblings & Electronic HSI
Date: Jan 17, 2005
Doug, Sounds a lot like the BMA Lite . . . I agree with you . . . and the BMA product is not totally proven at this point . . . in fact the G3 version hasn't shipped yet as far as I know. It does however show a lot of promise with the ultimate goal is a "TSO'd version" of the Lite at around $3000 with GPS and nav head function built in, if it works will be one of the best bargains out there! Bob ----- Original Message ----- From: "Doug Rozendaal" <dougr(at)petroblend.com> Subject: RV-List: Dynon ramblings & Electronic HSI > > All, > > I have flown the latest and greatest version of the D-10 software for about > 20 hours or so and I now have the confidence in this version to rip out my > vacuum system. I have been holding back because I could have easily pulled > out the Dynon and replaced it with my vacuum gyro in moments. But with 18 > months of experience and now that we have a good stable software package I > am ready to make the leap into the land of no vacuum pump. Great Work > Guys!!!!! > > That means the DG will go as well. I won't miss it because I have not even > been setting it lately because I don't use it at all. > > Now for what I want. I want Dynon to build an HSI. Not a big fancy one > with moving maps and waypoint displays and all that, just a simple HSI that > encorporates GPS switching and ennunciator functions, Approach, enroute and > OBS modes for GPS. An RMI feature would be nice also but not essential so > you could display both VOR and GPS info simaltaneously. Also a feature that > would switch the autopilot driver. VOR, GPS-NAV, GPS Track or Heading bug. > > I've seen the Blue Mountain product is coming, and maybe that is the answer, > but I really like the form factor, the customer service, and the display of > the Dynon. I am not sure the folks at Dynon understand how many people > would buy an HSI. Most home builts do not have HSI's and several pilots have > never flown with one, but it is not because they would not love one if they > used it, just because the trainers they learned in did not have one. > > This would replace a DG, a VOR Head, a GPS annunciator, any Autopilot > switch gear, and a backup display for the D-10 If they could do this at the > $2000 price point, they would sell like cordwood. > > So my objective it make them understand that this would be a big market. > (are you listening Doug Medema?) Everybody pile on. > > Tailwinds, > Doug "I wanna a HSI" Rozendaal > > ________________________________________________________________________________
Subject: Minimum Realistic Field Length
Date: Jan 18, 2005
Scott, If you haven't bought the property yet, one consideration for a longer strip might be whether or not you want other pilots to land at your field. Of course, a short field could also screen out some of the pilots you may not want to visit you. Does your mother-in-law fly an RV? :) Don -----Original Message----- From: tx_jayhawk(at)excite.com [mailto:tx_jayhawk(at)excite.com] Subject: RV-List: Minimum Realistic Field Length All, Since the plane is still in storage while I look for a home (building withdrawl), I have been evaluating several airpark possibilities. I would be interested in hearing from others what they believe the minimum safe runway lenth would be. I know it is highly subjective, but I would like to hear from others with experience. For reference...the plane with be a 7A, O360, with FP prop. Also, there is no real obstacles to think of (never heard of the Kansas Rockies), and field elevation is approx 1000'. Would a 1400' runway be doable? I know it would be on the short side (go-around if things don't look just right), but would it be safe? Thanks for the help, Scottwww.scottsrv7a.com advertising on the Matronics Forums. ________________________________________________________________________________
Date: Jan 18, 2005
>>>"The FAA says the hydraulic failure and the bullet hole are unrelated. Here's another interesting bit: the hole is on the top the wing. They speculate someone fired a deer rifle in the air and the bullet struck the plane at "low energy" on the way down." I'm not one for conspiracy theories but realy what are the chances of someone first being stupid enough to fire a gun near an airport. Second having that bullet go up and come down striking this fellows plane. The fellow not seeing the hole on his walk around or seeing it and deciding to fly with the hole anyways. Then just coincedently has an unrelated failure that causes a forced landing. This is under the assumption that the bullet hole happened while the plane was on the ground. Don't get me started on the odds of a "random" bullet going up then coming down on the top surface of a moving plane all in the same flight that the fellow has an unrelated failure. Either this guy is the most unlucky fellow in the world or someone isn't giving all the facts. If this fellow indeed has a low velocity bullet hole impact on the top surface of his wing, then I would think the more likely possibility was that some yahoo took a shoot at him while he was doing aerobatics. By the time the bullet reached the plane at altitude it slowed down to the point of "low velocity" ________________________________________________________________________________
Date: Jan 18, 2005
Looks like 2 RV-6's in the incident report over the weekend. Get the N number and do a Google search to find the owner. http://www.faa.gov/avr/aai/A_0118_N.txt Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
From: "Stucklen, Frederic W UTPWR" <Fred.Stucklen(at)UTCFuelCells.com>
Subject: Heated Pitot
Date: Jan 18, 2005
Bill, After looking for a reasonably priced heated pitot for over a year, I settled on this one too. Jon Johansson is making these in AU.... First thing I did was break it while mounting it on my plane! It turns out that the inner tube is plain old 3030 thin wall, (soft) alum threaded on each end with a 1/4" - 28 die, set for an oversized thread. (NOT a pipe thread). I'm not sure how well this would have held up to vibration over the long run... The inner (soft) tube broke when I bumped it after it was mounted onto the wing. After finding out Jon wanted almost $100 for a simple 6" threaded tube, I made my own out of THICK walled 2020-T3 alum tube (Total cost, including the die & die handle, was under $50!). I am still using this modified part, but could have just as easily made my own from a block of alum, for a lot less money. I'm very surprised that nobody else is offering a similar unit. The heater element is a standard Cessna part (Search the RV-List for a part number). the rest is different size tubing (available from spruce), a milled "Bullet" node piece, and a Cessna P/N heater element. Also, in hindsight, once you have the basic "L" shaped part of any one of the certified units already out there, you could easily repair/modify it to be heated by purchasing the basic components (Tubing & heater element) and shaping your own nose piece. this would probably be the least expensive route.... I'm using Gretz's mounting kit.... ===================================== Fred Stucklen RV-6A N926RV billschlatterer(at)sbcglobal.net> Try this link to ACS for heated pitot only for experimental use. Part @ 10-01022 12 volt $398.00 still high but better than nothing and better than $900. This is the L shaped variety. Have been told that you can find them in aircraft junkyards for less than $100 but have had no luck. <http://www.aircraftspruce.com/catalog/inpages/homepitot.php> http://www.aircraftspruce.com/catalog/inpages/homepitot.php If anyone knows a reason why this would be inappropriate, please holler as I am planning on putting one in my 7. Bill Schlatterer 7a QB ________________________________________________________________________________
Date: Jan 18, 2005
Subject: Re: Orlando RV forced landing N654PJ
In a message dated 1/18/05 1:21:21 PM Eastern Standard Time, bilinski@kyocera-wireless.com writes: > > > > Looks like 2 RV-6's in the incident report over the weekend. Get the N > number and do a Google search to find the owner. > > http://www.faa.gov/avr/aai/A_0118_N.txt > You know......I was standing on the flight line when a RV-6 was leaving LAL at the fly-in and made the comment 3 times that I smelled gas.......MO-gas. The owner of the leaving RV-6 said he had just stuck the tanks and that must be it...I asked if he was running car gas and he said yes. I can not tell you who he was or what the tail number was but I think he had his dog and wife with him.......sure hope this was not the plane that never made the runway and if it was he had a leak and should be glad there was no fire. The owner listed to the RV 6 ....N654PJ is Paul Pajak. RV-4 RV-8 QB....wings Sal Capra Lakeland, FL. My Home Page ________________________________________________________________________________
Date: Jan 18, 2005
Kevin wrote... Don't get me started on the odds of a "random" bullet going up then coming down on the top surface of a moving plane all in the same flight that the fellow has an unrelated failure. From what's been described so far, I'd say the odds were 100%. Chuck ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling(at)earthlink.net>
Subject: Passing fire codes for hangar homes
Date: Jan 18, 2005
HELP. I purchased a lot at an airpark several months ago and just found out the county has adopted a new fire code restricting the size of the hangar to 2000 sq ft. I had planned on a 3000. Im wondering if anyone has dealt with this and knows of a way around it. I believe its a fire code issue so maybe a fire wall or sprinkler system would fit the bill. One of the subdivision requirements is that the hangar must be attached to the house. tia Shemp/Jeff Dowling RV-6A, N915JD 150 hours Chicago/Louisville ________________________________________________________________________________
Date: Jan 18, 2005
>>>HELP. I purchased a lot at an airpark several months ago and just found >>>out the county has adopted a new fire code restricting the size of the >>>hangar to 2000 sq ft. I had planned on a 3000. Im wondering if anyone >>>has dealt with this and knows of a way around it. I believe its a fire >>>code issue so maybe a fire wall or sprinkler system would fit the bill. >>>One of the subdivision requirements is that the hangar must be attached >>>to the house. Don't call it a hanger, Call it a 4 car garage with a large single opening door. . . . ________________________________________________________________________________
Date: Jan 18, 2005
>>Kevin wrote... >>Don't get me started on the odds of a "random" bullet going up then coming down on the top surface of a moving plane all in the same flight that the fellow has an unrelated failure. >>From what's been described so far, I'd say the odds were 100%. >>Chuck Hmm another possibility, someone shot directly at the cockpit and the prop struck the bullet deflecting it down onto the top of the wing. . . Anyways all seems way to weird to me. . . ________________________________________________________________________________
Subject: Edmonton Alberta
Date: Jan 18, 2005
I'm up in Yellowknife at the moment and I'm coming down to Edmonton, Alberta for my once in 6 month visit. I'll only be in town this weekend Friday Morning 21st - Sunday 23rd. I'm still in the deciding stage and have yet to actually see a live project. I would love to meet any RV builders and see their works in progress. I would also love to get up for a flight and would be more than happy to pay for a ride along in any RV, weather and time permitting. So if you are in or around the Edmonton area and are in the process of building or have a flying RV and have some time to spare this weekend please send me an E-mail to kevinsky18(at)hotmail.com Kevin Yellowknife, NT, Canada RV-8 Wanna Be Builder ________________________________________________________________________________
Date: Jan 18, 2005
From: jim & terri truitt <jimteri1(at)earthlink.net>
Highly inprobable random incidents do occur. If I didn't personally know the woman in the following story, I would have thought "no way". A few years ago, in my former home town of Evansville, Indiana, a woman who lives next door to my former residence, went outside with her two dogs near midnight on New Years Eve. As she bent over to pick up one of the dogs, a bullet hit her in the back of her neck. No rounds fired in the neighborhood. Doctors and police officers surmise from the angle of the impact and the relatively shallow penetration that a stray bullet, fired into the air by some moron, hit her on it's fall to earth. She was knocked down and was hospitalized, but has recovered. I, too, have often wondered about stray rounds fired in the middle east. ________________________________________________________________________________
Date: Jan 18, 2005
The first thing you need to find out is "What code"? Don't be afraid to ask. Are they using the "International Fire Code" or "NFPA", you also need to know what version. 2000 or the 2003 code. What you are talking about sounds like a local code or a subdivision or property rule. Ask for help by getting a copy of the section they are referencing. Explain that you are a citizen and not a builder who will know how to look up the code. Many of the larger hangers can get around a problem by adding a sprinkler system, however that may cost you more than you have planned. I would suggest going right to the top guy. Go knock on the Fire Marshals door and talk to him. I think that you will find that many things can be resolved if you talk it over. Go see him in person. I can't tell you how many times I have seen things get changed after someone has been very involved finding out the real code. Not a rule that someone has made. We call them shirt pocket rules and they change all the time. If it is not in the code, you will have a strong case. Sometimes an inspector will tell you something that he has been doing for years or he believes to be true only to find out it is not in the code. The inspector may not back down, but his boss has the authority to over rule. Go see the Fire Marshal, when you see him you can tell him that you are just trying to get a better understanding. Note: In some jurisdictions the "Building Director" may be the authority so you may also have to talk to him. I would start with the Fire Marshal. Good luck, Ted Gauthier, RV-6 Fire Marshal, and DAR West Bloomfield Michigan -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kevin Williams Subject: RE: RV-List: Passing fire codes for hangar homes >>>HELP. I purchased a lot at an airpark several months ago and just found >>>out the county has adopted a new fire code restricting the size of the >>>hangar to 2000 sq ft. I had planned on a 3000. Im wondering if anyone >>>has dealt with this and knows of a way around it. I believe its a fire >>>code issue so maybe a fire wall or sprinkler system would fit the bill. >>>One of the subdivision requirements is that the hangar must be attached >>>to the house. Don't call it a hanger, Call it a 4 car garage with a large single opening door. . . . ________________________________________________________________________________
Date: Jan 18, 2005
Subject: new years celebration
This past new years, a man was killed by a bullet fired into the air. Posice were called and confiscated the weapon .... cops put two and two together (imagine that!) and arrested the celebrant. Orlando FL, I think Linn jim & terri truitt wrote: > >Highly inprobable random incidents do occur. If I didn't personally know the woman in the following story, I would have thought "no way". >A few years ago, in my former home town of Evansville, Indiana, a woman who lives next door to my former residence, went outside with her two dogs near midnight on New Years Eve. As she bent over to pick up one of the dogs, a bullet hit her in the back of her neck. No rounds fired in the neighborhood. Doctors and police officers surmise from the angle of the impact and the relatively shallow penetration that a stray bullet, fired into the air by some moron, hit her on it's fall to earth. >She was knocked down and was hospitalized, but has recovered. >I, too, have often wondered about stray rounds fired in the middle east. > > > > -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Subject: Re: Passing fire codes for hangar homes
Date: Jan 18, 2005
You will need a firewall on the house side. You might put a firewall between to sides of the hanger or use a firewall to separate the work area from the plane storage area. Or have a hangar on each side of the house. But I would talk to the county building department before you set up a design and ask them for their input. They will have to approve your design before you build anyway. Anything that I might write may not meet with their approval. Cy Galley EAA Safety Programs Editor Always looking for ideas and articles for EAA Sport Pilot ----- Original Message ----- From: "Kevin Williams" <kevinsky18(at)hotmail.com> Subject: RE: RV-List: Passing fire codes for hangar homes > > >>>HELP. I purchased a lot at an airpark several months ago and just found > >>>out the county has adopted a new fire code restricting the size of the > >>>hangar to 2000 sq ft. I had planned on a 3000. Im wondering if anyone > >>>has dealt with this and knows of a way around it. I believe its a fire > >>>code issue so maybe a fire wall or sprinkler system would fit the bill. > >>>One of the subdivision requirements is that the hangar must be attached > >>>to the house. > > > Don't call it a hanger, Call it a 4 car garage with a large single opening > door. . . . > > ________________________________________________________________________________
Date: Jan 18, 2005
>Wow, for what it's worth, when I was staying with a friend in Arizona >learning to fly, a teenage girl was hit in the head while she was >swinging in her back yard with her parents. It killed her. Her name was Shannon. There is now a law in AZ called "Shannon's Law" that makes random firing into the air a felony Go figure,,, ________________________________________________________________________________
Subject: Garmin iQue 3600a
Date: Jan 18, 2005
Hey Gang! Garmin has entered the palm top gps flight information arena with this product. http://www.garmin.com/products/iQue3600a Ideas and Opinions please Jim in Kelowna ________________________________________________________________________________
Date: Jan 18, 2005
>I'm not one for conspiracy theories but realy what are the chances of >someone first being stupid enough to fire a gun near an airport. Come on out to Oakdale, Ca. I'll introduce you to some of the local hunters. :-) They do fire their guns near the airport and we politely ask them to leave. No planes have been shot down thus far. I'll keep my fingers crossed. -- Scott VanArtsdalen Van Arts Consulting Services 3848 McHenry Ave Suite #155-184 Modesto, CA 95356 209-986-4647 www.rivetbangers.com Now with email!! How you want it, When you want it. ________________________________________________________________________________
Date: Jan 18, 2005
Subject: Re: Garmin iQue 3600a
I think this really blows. I just bought an iQue 3600 for my car and now they come out with this. I should have waited a little longer. It works great in the car. And it's small enough you can use when you're walking from the airport trying to find that $100 hamburger. Or put it in the rental car with the street level maps. You can plug the mp3 player into the intercom for in-flight music. The iQue3600a has more internal memory but you will still probably want an expansion card. Two thumbs up. > Hey Gang! Garmin has entered the palm top gps flight information arena with this product. http://www.garmin.com/products/iQue3600a Ideas and Opinions please Jim in Kelowna ________________________________________________________________________________
Date: Jan 18, 2005
The problem is that they are calling it a garage, which dictates the max sq ftage. ----- Original Message ----- From: "Kevin Williams" <kevinsky18(at)hotmail.com> Subject: RE: RV-List: Passing fire codes for hangar homes > >>>>HELP. I purchased a lot at an airpark several months ago and just found >>>>out the county has adopted a new fire code restricting the size of the >>>>hangar to 2000 sq ft. I had planned on a 3000. Im wondering if anyone >>>>has dealt with this and knows of a way around it. I believe its a fire >>>>code issue so maybe a fire wall or sprinkler system would fit the bill. >>>>One of the subdivision requirements is that the hangar must be attached >>>>to the house. > > > Don't call it a hanger, Call it a 4 car garage with a large single opening > door. . . . > > > ________________________________________________________________________________
Date: Jan 18, 2005
Jim Jewell wrote: >Garmin has entered the palm top gps flight information arena with this >product. >http://www.garmin.com/products/iQue3600a > > Just my opinion, I may be wrong... I think for the money, the Garmin 96C is a better deal, and $400 cheaper. $699US instead of $1099US (list prices). http://www.garmin.com/products/gpsmap96c/ Or, if the larger screen is a must, the Garmin 196, despite having a monochrome screen, is an excellent unit at $799US (list). http://www.garmin.com/products/gpsmap196/ People make a big deal about colour, but I think the screen on my old Garmin GPSIII was excellent, as it was simple, *very* high contrast, and very readible in all lighting conditions. Personally, I bought a Garmin 76CS (still comparing list prices, $549US, but I paid $649CDN). http://www.garmin.com/products/gpsmap76cs/ The 76CS had a couple of interesting features that I found worthwhile (copied from the Garmin website): - Barometric sensor with automatic pressure trend recording - Elevation computer provides current elevation, ascent/descent rate, minimum/ maximum elevation, total ascent and descent, average and maximum ascent and descent rate (not mentioned on the website is "glide ratio to destination"). The first is useful for predicting upcoming weather trends, and the second neglects to mention the most interesting feature, which is "glide ratio to destination". Your engine has quit, and you're now deadstick. You hit "nearest airport" on the GPS and get distance, bearing, etc. All good, right? How do you know if you can make it? With the 76CS, if you know your airplane's best glide ratio, you know instantly if that airport is an option. However, the 76CS is *NOT* an aviation GPS, and as such does not have an aviation database. I fly with a hardcopy of the CFS (Canada Flight Supplement), which gives me airport info like runways, frequencies, etc. In addition, I have a database of waypoints of Canadian airports that I keep up-to-date myself as data changes, that I can upload to the GPS. The GPS gives me the navigational aids, I take care of looking out for airspace and finding frequencies on my own. I find this to be an ideal (and economical) arrangement. If Garmin made the 96 model with a barometric altimeter included, I would have considered it very seriously, but right now, for me, the 76CS does what I want. Hope this helps! -Rob ________________________________________________________________________________
Date: Jan 19, 2005
Yeah, stupidity knows no bounds, either by geography or interest group. The guy in the hangar behind me (a pilot and hangar owner) has been seen laying on his back, firing his gun straight up in the air ON THE AIRPORT. Go figure. Greg > > >I'm not one for conspiracy theories but realy what are the > chances of > > >someone first being stupid enough to fire a gun near an airport. > > Come on out to Oakdale, Ca. I'll introduce you to some of > the local hunters. :-) They do fire their guns near the > airport and we politely ask them to leave. No planes have > been shot down thus far. I'll keep my fingers crossed. ________________________________________________________________________________
Date: Jan 18, 2005
re: new years' eve random shooting- I recall reading in a book about WW2 that, on Okinawa, about 50-75 soldiers were shot to death on V-J day, from troops celebrating by firing their weapons. The person who related the story spent the night in his foxhole with his helmet on, while spent rounds dropped all around him. Scott in Vancouver ----- Original Message ----- From: "jim & terri truitt" <jimteri1(at)earthlink.net> Subject: RV-List: Re: Orlando RV forced landing > > Highly inprobable random incidents do occur. If I didn't personally know > the woman in the following story, I would have thought "no way". > A few years ago, in my former home town of Evansville, Indiana, a woman > who lives next door to my former residence, went outside with her two dogs > near midnight on New Years Eve. As she bent over to pick up one of the > dogs, a bullet hit her in the back of her neck. No rounds fired in the > neighborhood. Doctors and police officers surmise from the angle of the > impact and the relatively shallow penetration that a stray bullet, fired > into the air by some moron, hit her on it's fall to earth. > She was knocked down and was hospitalized, but has recovered. > I, too, have often wondered about stray rounds fired in the middle east. > > > ________________________________________________________________________________
Date: Jan 19, 2005
Subject: Suspicious Aircraft Debris Pictures
Hello everyone, I would like, first and foremost, to apologize in advance for my off topic post since it won't be about RV airplane building techniques. A friend of mine showed me some pictures of a debris found at an airplane crash site. As soon as I saw the pictures, I could not believe that this was an actual airplane crash debris. You can see the pictures of the debris in those two links below: http://renovation.pentagon.mil/Phoenix/9-11-2001/a26-DSC_0446-1.jpg http://t2news.navy.m7z.net/management/photodb/photos/010911-N-6157F-001.jpg (it's the same part with different angles, lighting and lenses) I know that most of you are very familiar with aircraft metals and aircraft riveting techniques. I also know that few of you might even have worked on Boeings a few times so I ask you to please look carefully at the two pictures above and tell me if you think it is possible for an aircraft component to be detached in a crash and still leaving the rivet locations as seen relatively undamaged. I mean, I think that a part pulled away from it's rivets would be severely damaged (dimpled, torn or bruised) around the areas were rivets once were Please look at it and tell me what you think, I know you will understand what I mean the second you look closely at the pictures. So I would like to know if you think this is possibly a part torn away from a crashed airplane or if you think it might be something else. I know this is not the in the subject theme of this forum and I understand that answers to my question might have some political implications so please contact me off list if you prefer at guy_cotnoir(at)msn.com Thanx, Guy Cotnoir Toronto, Canada ________________________________________________________________________________
Date: Jan 19, 2005
If it had WIFI, it would be a deal. Problem is that PDA's nowadays are much more useful with WIFI since airports, resturaunts, etc are offering wireless internet connections. Paul Besing RV-6A Sold RV-10 Soon Kitlog Builder's Software www.kitlog.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Rob Prior Subject: Re: RV-List: Garmin iQue 3600a Jim Jewell wrote: >Garmin has entered the palm top gps flight information arena with this >product. >http://www.garmin.com/products/iQue3600a > > Just my opinion, I may be wrong... I think for the money, the Garmin 96C is a better deal, and $400 cheaper. $699US instead of $1099US (list prices). http://www.garmin.com/products/gpsmap96c/ Or, if the larger screen is a must, the Garmin 196, despite having a monochrome screen, is an excellent unit at $799US (list). http://www.garmin.com/products/gpsmap196/ People make a big deal about colour, but I think the screen on my old Garmin GPSIII was excellent, as it was simple, *very* high contrast, and very readible in all lighting conditions. Personally, I bought a Garmin 76CS (still comparing list prices, $549US, but I paid $649CDN). http://www.garmin.com/products/gpsmap76cs/ The 76CS had a couple of interesting features that I found worthwhile (copied from the Garmin website): - Barometric sensor with automatic pressure trend recording - Elevation computer provides current elevation, ascent/descent rate, minimum/ maximum elevation, total ascent and descent, average and maximum ascent and descent rate (not mentioned on the website is "glide ratio to destination"). The first is useful for predicting upcoming weather trends, and the second neglects to mention the most interesting feature, which is "glide ratio to destination". Your engine has quit, and you're now deadstick. You hit "nearest airport" on the GPS and get distance, bearing, etc. All good, right? How do you know if you can make it? With the 76CS, if you know your airplane's best glide ratio, you know instantly if that airport is an option. However, the 76CS is *NOT* an aviation GPS, and as such does not have an aviation database. I fly with a hardcopy of the CFS (Canada Flight Supplement), which gives me airport info like runways, frequencies, etc. In addition, I have a database of waypoints of Canadian airports that I keep up-to-date myself as data changes, that I can upload to the GPS. The GPS gives me the navigational aids, I take care of looking out for airspace and finding frequencies on my own. I find this to be an ideal (and economical) arrangement. If Garmin made the 96 model with a barometric altimeter included, I would have considered it very seriously, but right now, for me, the 76CS does what I want. Hope this helps! -Rob ________________________________________________________________________________
Subject: Re: Suspicious Aircraft Debris Pictures
Date: Jan 19, 2005
You're right, that certainly is off topic for an RV forum. I am sure that there is some sort of conspiracy theory chat room out there that may be a bit more receptive. As for the particular piece in question, who knows how it came to be in such a condition with the rivet holes in tact...I am thinking maybe it had something to do with the fact that plane it was attached to was flown in to some of the thickest concrete walls ever made at speeds approaching 600 mph! I was there when this happened...I saw the plane and the gaping hole it left...I saw the injured and dying as they fled from the pentagon...I personally saw the devastation this caused and I could not be more offended by the extremists who not only perpetrated this incident, but who now question whether or not this was one big government plot to fool the world. I apologize if this post is too pointed, as an RV builder I am sorry if you are offended. I just wanted to let you know that there were some people (yes even RV builders out here) who lived through this and don't appreciate where you were going with this post. Just my 2 cents, Will ________________________________________________________________________________
From: "Wayne @ Aircraft Engravers" <wayne(at)engravers.net>
Date: Jan 19, 2005
To Jeff, First, who are "they" Secondly, have whomever is drawing up your plans to label it "HANGAR" TBC ----- Original Message ----- From: "Jeff Dowling" <shempdowling(at)earthlink.net> Subject: Re: RV-List: Passing fire codes for hangar homes > > The problem is that they are calling it a garage, which dictates the max > sq > ftage. > > > ----- Original Message ----- > From: "Kevin Williams" <kevinsky18(at)hotmail.com> > To: > Subject: RE: RV-List: Passing fire codes for hangar homes > > >> >>>>>HELP. I purchased a lot at an airpark several months ago and just >>>>>found >>>>>out the county has adopted a new fire code restricting the size of the >>>>>hangar to 2000 sq ft. I had planned on a 3000. Im wondering if anyone >>>>>has dealt with this and knows of a way around it. I believe its a fire >>>>>code issue so maybe a fire wall or sprinkler system would fit the bill. >>>>>One of the subdivision requirements is that the hangar must be attached >>>>>to the house. >> >> >> Don't call it a hanger, Call it a 4 car garage with a large single >> opening >> door. . . . >> >> >> > > > ________________________________________________________________________________
Date: Jan 19, 2005
Guy Cotnoir wrote: > tell me if you think it is possible for an aircraft > component to be detached in a crash and still leaving the rivet locations > as > seen relatively undamaged. It MUST be, the photo proves it. The crash happened, and there lies that part with intact rivets. If that part was from the nose cone I would say impossible, however, if it's from any aft area or some part that got scraped off along the ground as it came in I could logically see it sitting there with intact rivets. I don't see your point AT ALL. TBC ________________________________________________________________________________
Date: Jan 19, 2005
Guy, That most assuredly could be aircraft debris. In all the aircraft accidents I have seen it still amazes me what I will find destroyed and what I will find relatively intact. Mike Robertson >From: "Guy Cotnoir" <guy_cotnoir(at)msn.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Suspicious Aircraft Debris Pictures >Date: Wed, 19 Jan 2005 07:59:51 -0500 (Eastern Standard Time) > > >Hello everyone, >I would like, first and foremost, to apologize in advance for my off topic >post since it won't be about RV airplane building techniques. > >A friend of mine showed me some pictures of a debris found at an airplane >crash site. As soon as I saw the pictures, I could not believe that this >was >an actual airplane crash debris. You can see the pictures of the debris in >those two links below: > >http://renovation.pentagon.mil/Phoenix/9-11-2001/a26-DSC_0446-1.jpg >http://t2news.navy.m7z.net/management/photodb/photos/010911-N-6157F-001.jpg >(it's the same part with different angles, lighting and lenses) > >I know that most of you are very familiar with aircraft metals and aircraft >riveting techniques. I also know that few of you might even have worked on >Boeings a few times so I ask you to please look carefully at the two >pictures above and tell me if you think it is possible for an aircraft >component to be detached in a crash and still leaving the rivet locations >as >seen relatively undamaged. > >I mean, I think that a part pulled away from it's rivets would be severely >damaged (dimpled, torn or bruised) around the areas were rivets once were >Please look at it and tell me what you think, I know you will understand >what I mean the second you look closely at the pictures. > >So I would like to know if you think this is possibly a part torn away from >a crashed airplane or if you think it might be something else. > >I know this is not the in the subject theme of this forum and I understand >that answers to my question might have some political implications so >please >contact me off list if you prefer at guy_cotnoir(at)msn.com > >Thanx, >Guy Cotnoir >Toronto, Canada > >
January 11, 2005 - January 19, 2005
RV-Archive.digest.vol-qj
