RV-Archive.digest.vol-qp
March 08, 2005 - March 14, 2005
Subject: Re: video camera
Dan Checkoway wrote: > > Sam, > > I'm all over that. I've been wanting to have a wider angle view since day > one, but I hadn't thought I could add lenses to this camera -- it's pretty > low-end. But I looked and there sure are threads! Will see what I can > find. > > If anybody knows a cheap source for a decent wide angle lens that will fit a > JVC GR-DVL805 camera, I'm all ears! Here ya go, Dan; this is the lens I used: http://tinyurl.com/ouj0 Mount threads are 37mm. You will need an adapter (check at a camera store) if the camera threads are not 37mm. Or, you can probably just tape the thing to the front of your lens. Here is the wide-angle lens offered by JVC: http://tinyurl.com/63orf This lens are so inexpensive they are great for experimenting. You may not want to use it all the time but it is a good item to have in your equipment kit. By the way, my camera is a whole lot more "low-end" than yours! Looking forward to seeing the results! Sam Buchanan ________________________________________________________________________________
Date: Mar 08, 2005
From: Matt Jurotich <mjurotich(at)hst.nasa.gov> Major or Minor Modification
Subject: Re: Prop replacement, question for Das Fed, was:
Major or Minor Modification Minor Modification When I got my new to me RV 6A the existing operating limitations were very restrictive so I requested and got new operating limitations. I was given a generous Phase One flying area and a 5 hour re-certification for a major change. I was told that my complete panel change was minor but that putting a constant speed prop would be major and major change require a new XXXX form. Given the fly off period is only 5 hours and the area is generous, I am going to treat my panel upgrade as a major change primarily to prevent a no pay insurance situation. Matthew M. Jurotich NASA/Goddard Space Flight Center Swales contractor to the JWST ISIM Systems Engineer m/c : 443 e-mail mail to: phone : 301-286-5919 fax : 301-286-7021 JWST URL: <http://ngst1.gsfc.nasa.gov ________________________________________________________________________________
Subject: Alodine Powder Supplier?
Date: Mar 08, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
All, I'm trying to find a distributor that will sell about a pound of Alodine in it's powdered form. It goes by either Alodine 1200s or Iridite 14-2. I don't see the point of paying the large amount of extra dollars, not to mention hazmat handling charges, for water. Trying to find a distributor is turning out to be much more difficult than I expected. None seem to want to deal in small quantities and none of the local paint supply houses carry it, or they have it in liquid and charge more than AS and Wicks. BTW, I'm in the DFW area. Thanks, Michael Sausen ________________________________________________________________________________
Date: Mar 08, 2005
Subject: Whiskers on Main Spar Rivets?...
(not processed: message from valid local sender) I am sure it is probably nothing, but have any of you noticed a "whisker" effect in the gold anodizing on the main spar to wing ribs rivets? I noticed them when looking at a certain angle in the sunlight. I figured it was probably just the anodizing being compressed and is not a big deal. Am I correct? - Matt ________________________________________________________________________________
Date: Mar 08, 2005
Subject: Re: Alodine Powder Supplier?
Michael, I also tried to find small quantities of powdered Alodine. The smallest I could find was 10 pounds. I was going to buy that much and try to resell small quantities myself but I found out that the powdered form is considered an oxidizer from a hazmat perspective and the shipping charges are even higher than the normal liquid form. I didn't want to deal with that so I just went on with liquid. The powder makes a lot of sense since a pound of powder make 16 gallons of Alodine. Paul ----- Original Message ----- From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> Subject: RV-List: Alodine Powder Supplier? > > All, > > I'm trying to find a distributor that will sell about a pound of > Alodine in it's powdered form. It goes by either Alodine 1200s or > Iridite 14-2. I don't see the point of paying the large amount of extra > dollars, not to mention hazmat handling charges, for water. Trying to > find a distributor is turning out to be much more difficult than I > expected. None seem to want to deal in small quantities and none of the > local paint supply houses carry it, or they have it in liquid and charge > more than AS and Wicks. > > BTW, I'm in the DFW area. > > Thanks, > Michael Sausen > > ________________________________________________________________________________
Date: Mar 08, 2005
Subject: Prop replacement, question for Das Fed
No disrespect to the FAA inspector, but I would think more flight-testing would be prudent. Logically and practically speaking more flight test is in order to determine new: static RPM, takeoff distance, climb rates/speeds, top speed, cruise speed/fuel burn, flight RPM, glide ratio and so on. Kind of important stuff and should be done before taking passengers at least? As far as major mod, it did not change the W&B but the prop is a structural component and safety of flight item. Yes? You as the builder can put it back into a Phase I, if you feel it is necessary for safety. On the other hand your local G-man says not needed, than that is good enough as long as you (and insurance if applicable) are OK with it. Cheers George > >On the subject of major mods and operating limitations: > >I have the older operating limitations (requiring FSDO blessing for any >"major change.") I am replacing my wood Sterba experimental prop with a >wood core, fiberglass covered Catto experimental prop. Weight is about >the same, and both are fixed pitch, experimental props. According to a >local FAA inspector (who deals with a lot of homebuilts and whose >opinion is widely respected around these parts) this does not constitute >a "major change" and no new certificate is required, nor is any phase 1 >time. > >This strikes me as a bit odd. What do you think, Mike, or anybody else >who knows? > >Jeff Point, RV-6, Milwaukee WI ________________________________________________________________________________
Subject: RE: Whiskers on Main Spar Rivets?...
Date: Mar 08, 2005
Matt, I have not gotten to that point yet, however, I made a BIG mental note about that happening to many other builders and it is, as you expected, just in the anodizing material...not to worry. Will #91056 www.wills-rv9a.com ________________________________________________________________________________
Date: Mar 08, 2005
Subject: Oil Coolers on Ebay
Take a look at these and see what you think. A friend found these and wants to use one on his -6. What do you think? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4533025216&category=26442&sspagename=WDVW#ebayphotohosting Jeff Point RV-6 Milwaukee WI ________________________________________________________________________________
Subject: Re: Whiskers on Main Spar Rivets?... (not processed: message
Date: Mar 08, 2005
I saw the same thing each time I drove a rib to spar rivet. I don't think it is any big deal. Don > > I am sure it is probably nothing, but have any of you noticed a "whisker" effect > in the gold anodizing on the main spar to wing ribs rivets? I > noticed them when looking at a certain angle in the sunlight. I figured it was > probably just the anodizing being compressed and is not a big > deal. Am I correct? > > - Matt > > > > > > ________________________________________________________________________________
Date: Mar 08, 2005
Subject: Re: Oil Coolers on Ebay
Aircraft Spruce sells them for experimentals... I think this is the same as my Harrison... I would buy and use one... http://www.aircraftspruce.com/catalog/eppages/aeroclassiccooler.php -Bill ----- Original Message ----- From: "Jeff Point" <jpoint(at)mindspring.com> Subject: RV-List: Oil Coolers on Ebay Take a look at these and see what you think. A friend found these and wants to use one on his -6. What do you think? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4533025216&category=26442&sspagename=WDVW#ebayphotohosting Jeff Point RV-6 Milwaukee WI ________________________________________________________________________________
Date: Mar 08, 2005
I should clarify this. The inspector recommended (and I agree) that a test period is a good idea. My question is more about the FAA requirements. Obviously there is often a wide chasm between what is safe and prudent, and what is required. Jeff Point > >No disrespect to the FAA inspector, but I would think more flight-testing would be prudent. Logically and practically speaking more flight test is in order to determine new: static RPM, takeoff distance, climb rates/speeds, top speed, cruise speed/fuel burn, flight RPM, glide ratio and so on. Kind of important stuff and should be done before taking passengers at least? > > > > ________________________________________________________________________________
Date: Mar 08, 2005
> >Take a look at these and see what you think. A friend found these and >wants to use one on his -6. What do you think? > >http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4533025216&category=26442&sspagename=WDVW#ebayphotohosting They certainly are nice looking. Not long ago, folks on the list were talking about oil cooler failures because of the possible high pressure pulses peculiar to the Mazda rotary oil system. Because of these failures, (and the lack of failures on stock coolers,) I would be cautious about using something other than the stock Mazda oil cooler. ________________________________________________________________________________
Date: Mar 08, 2005
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net>
Bill VonDane wrote: > >Aircraft Spruce sells them for experimentals... I think this is the same as >my Harrison... I would buy and use one... > >http://www.aircraftspruce.com/catalog/eppages/aeroclassiccooler.php > >-Bill > > I would get one also. It seems exactly like my Harrison..... Phil ________________________________________________________________________________
Subject: Whiskers on Main Spar Rivets?... (not processed: message
Date: Mar 08, 2005
Matt, I too saw the same thing. I took a picture of it and showed it to Vans at sun-n-fun last year. They said do not worry about it is star facture of the anodizing coating and is not a problem. Mike Crowe I am sure it is probably nothing, but have any of you noticed a "whisker" effect in the gold anodizing on the main spar to wing ribs rivets? I noticed them when looking at a certain angle in the sunlight. I figured it was probably just the anodizing being compressed and is not a big deal. Am I correct? - Matt ________________________________________________________________________________
Date: Mar 08, 2005
I purchased one of these last week. They are the exact same model that Van's includes in the FWF kits. Aero Classic oil coolers, part # 8000075. He's been selling them for awhile, so he has a stock of them. Matthew Brandes, Van's RV-9A (Finish Kit) EAA Chapter 1329 President EAA Chapter 868 Web Editor www.n523rv.com <http://www.n523rv.com/> ________________________________________________________________________________
Date: Mar 08, 2005
Michael, Our local "industrial plastics" outet (a source for paint epoxy and composite materials) sells the Alodine crytals in small amounts pacckaged in little tins. A couple of ounces of the crystals mixed with water did the job for my 6A project. My cost some years ago was about $30.00 Canadian dollars. I'm fairly sure the by the pound price would be better. Jim in Kelowna ----- Original Message ----- From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> Subject: RV-List: Alodine Powder Supplier? > > > All, > > I'm trying to find a distributor that will sell about a pound of > Alodine in it's powdered form. It goes by either Alodine 1200s or > Iridite 14-2. I don't see the point of paying the large amount of extra > dollars, not to mention hazmat handling charges, for water. Trying to > find a distributor is turning out to be much more difficult than I > expected. None seem to want to deal in small quantities and none of the > local paint supply houses carry it, or they have it in liquid and charge > more than AS and Wicks. > > BTW, I'm in the DFW area. > > Thanks, > Michael Sausen > > > ________________________________________________________________________________
Date: Mar 08, 2005
Thanks to all who responded. This pretty well answers it. Anybody else looking for an oil cooler this looks like a great deal. Jeff Point > > ________________________________________________________________________________
Date: Mar 09, 2005
Subject: (no subject)
> Have the tail kit finished and the wing kit hardly stsrted.New York area If > interested, E-mail me at _kdh347(at)aol.com_ (mail to:kdh347(at)aol.com) or call > 845-677-3193 > Thanks Ken ________________________________________________________________________________
Date: Mar 09, 2005
Subject: RV-7 Tail and wing kit for sale
>It kills me to do this RV-7 empennage and wing kit for sale Have the tail kit finished and the wing kit hardly stsrted.New York area If > interested, E-mail me at _kdh347(at)aol.com_ (mail to:kdh347(at)aol.com) or call > 845-677-3193 > Thanks Ken PS also A complete set of tools, including pneumatic squisser. ________________________________________________________________________________
Date: Mar 09, 2005
Subject: Blue Mountain Install...
I started my Blue Mountain Sport and Autopilot install last weekend... Have the Magnetometer, AP Controller, and elevator Servo installed... I have posted some info and pix to my web site... http://www.rv8a.com/panel/panel3/installation.htm -Bill ________________________________________________________________________________
Subject: Spinners
Date: Mar 09, 2005
This is my first post in several years. I am building an older RV-6 kit and have a question regarding spinners. Has anyone on the list used the spinner supplied in the kit with a McCauley constant speed prop? If so are there any pit falls I should be aware of? Thanks for your help. Ernie Amadio Rv-6 ________________________________________________________________________________
Date: Mar 09, 2005
From: "dedgemon(at)knology.net" <dedgemon(at)knology.net>
Subject: Navaid Servo wanted
I'm looking for a Navaid servo. If you have one you'd like to sell please email me offline. Servo only, not the control head. Thanks -- David Edgemon RV-9A N42DE ________________________________________________________________________________
Subject: Yard Store rebuilt squeeze *caution*
Date: Mar 09, 2005
All, This is my own fault for assuming but I wanted to pass it along anyway to anyone considering getting a pneumatic squeeze. Be sure they have an adjustable set holder. The item "12310 Rebuilt C Squeeze" The Yard Store carries doesn't have one and when I called they just said that if it does they will list it in the description. My only experience has been with adjustable so I didn't even know that it could have a fixed holder They didn't really seem to care when I mentioned that they should say that it isn't adjustable on the website. They did offer a refund if I sent it back at my expense. My solution was to take the adjustable one out of my hand squeeze. Just wanted everyone to be mindful when dealing with them that they need to not assume anything. They didn't cheat me but they didn't exactly seem to care that I wasn't happy. Michael Sausen RV-10 40352 ________________________________________________________________________________
Date: Mar 09, 2005
Jeff, This fella has been selling these for awhile. I bought one and it *looks good*. I plan to pressure test it and will post results at some point. I also ha ve a used Harrison the same size, and it weighs more, probably because of the cast alum ends... HTH... Jerry Cochran From: Jeff Point <jpoint(at)mindspring.com> Subject: RV-List: Oil Coolers on Ebay Take a look at these and see what you think. A friend found these and wants to use one on his -6. What do you think? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4533025216& category=26442&sspagename=WDVW#ebayphotohosting Jeff Point RV-6 Milwaukee WI ________________________________________________________________________________
Date: Mar 09, 2005
Does he sell them one at a time, or will he sell additional units at the auction price. I sent a question but never got an answer. If someone on the list is the winner, I'll buy a second one from you for the auction price and whatever 'vigorish' you might want. Chuck -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jerry2DT(at)aol.com Subject: RV-List: Re: Oil Coolers on Ebay Jeff, This fella has been selling these for awhile. I bought one and it *looks good*. I plan to pressure test it and will post results at some point. I also ha ve a used Harrison the same size, and it weighs more, probably because of the cast alum ends... HTH... Jerry Cochran From: Jeff Point <jpoint(at)mindspring.com> Subject: RV-List: Oil Coolers on Ebay Take a look at these and see what you think. A friend found these and wants to use one on his -6. What do you think? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4533025216& category=26442&sspagename=WDVW#ebayphotohosting Jeff Point RV-6 Milwaukee WI ________________________________________________________________________________
Date: Mar 09, 2005
I wondered where all the coolers went that were replaced free. ----- Original Message ----- From: <Jerry2DT(at)aol.com> Subject: RV-List: Re: Oil Coolers on Ebay > > > Jeff, > > This fella has been selling these for awhile. I bought one and it *looks > good*. I plan to pressure test it and will post results at some point. I > also ha > ve a used Harrison the same size, and it weighs more, probably because of > the > cast alum ends... HTH... > > Jerry Cochran > > From: Jeff Point <jpoint(at)mindspring.com> > Subject: RV-List: Oil Coolers on Ebay > > > Take a look at these and see what you think. A friend found these and > wants to use one on his -6. What do you think? > > http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4533025216& > category=26442&sspagename=WDVW#ebayphotohosting > > Jeff Point > RV-6 > Milwaukee WI > > > ________________________________________________________________________________
Subject: Prop replacement, question for Das Fed, was: Major or Minor
Modification for electronic ignitions?
Date: Mar 09, 2005
He is correct, although I would recommend placing the aircraft into Phase 1 and doing some testing on performance differences. That you can do on your own at any time. Just make a log entry placing the aircraft into Phase 1 for testing of new prop, do whatever testing you feel is prudent, and sign it off placing the aircraft back into Phase 2. Mike Robertson >From: Jeff Point <jpoint(at)mindspring.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com.for.electronic.ignitions? >Subject: RV-List: Prop replacement, question for Das Fed, was: Major or >Minor Modification for electronic ignitions? >Date: Tue, 08 Mar 2005 00:46:57 -0600 > > >On the subject of major mods and operating limitations: > >I have the older operating limitations (requiring FSDO blessing for any >"major change.") I am replacing my wood Sterba experimental prop with a >wood core, fiberglass covered Catto experimental prop. Weight is about >the same, and both are fixed pitch, experimental props. According to a >local FAA inspector (who deals with a lot of homebuilts and whose >opinion is widely respected around these parts) this does not constitute >a "major change" and no new certificate is required, nor is any phase 1 >time. > >This strikes me as a bit odd. What do you think, Mike, or anybody else >who knows? > >Jeff Point >RV-6 >Milwaukee WI > > ________________________________________________________________________________
Date: Mar 09, 2005
Subject: Re: Yard Store rebuilt squeeze *caution*
Neither Avery nor Cleaveland indicate that an adjustable set holder comes with their squeezer and they both sell one separately, suggesting theirs also come with fixed set holders. I don't see any difference with The Yard. Maybe they could have been more understanding about your mistake, but it appears to me that is was your mistake. The Yard folks have always given me good service and on one occasion adjusted their price to me to meet the competition's price. Also, their shipping cost on small items is a better deal, as they charge only actual cost. You may also note that their price was almost $200 cheaper than that charged by Clear Air Tools http://clearairtools.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=CA&Category_Code=PRS for their rebuilt squeezers, so you got a pretty good deal. BTW, when you want additional yokes, Clear Air seems to have the best deals. Richard Scott RV-9A Wings ________________________________________________________________________________
Date: Mar 09, 2005
Care to elaborate on that? >I wondered where all the coolers went that were replaced free. > > > > > ________________________________________________________________________________
Subject: re: Spinners
Date: Mar 09, 2005
Ernie, I've mounted a McCauley constant speed prop on my not yet flying RV-8 and chose not to use Van's spinner kit. The problem with the spinner in the kit is that it's backplate is designed to mount to the rear of Hartzell hub. As I'm sure you know, the McCauley 214 hub does not have this boss for it to mount to. It's spinner backplate gets sandwiched between the hub and the prop flange (in the Mooney application), or in the Cessna application, uses "ears" that go under the prop nuts. I'm sure there is a way to make it work. Louis Smith http://members.aol.com/lousmith/page/rv.html did this on his -8 but after talking to him and others I chose an easier method. I should say easier to fabricate and not easier to pay for. The Whirlwind 200RV propeller http://www.whirlwindaviation.com/series200rv.php uses or used to use a McCauley 214 hub. They provided me with the spinner only and all I had to do is bolt it on. Then I had to rush to work for some OT to pay for it ;-) One other nice thing is that if you ever want to save a little weight up front, you can send them your hub, and they will install their blades onto your 214 hub. The Whirlwind spinner is similar to the Cessna version, that is, it uses the "ears" under the prop nuts. If your hub does not have these "ears" installed under the nuts, you will have to order the Cessna mounting ears and go through the hassle of installing them. This involves tapping the roll pin out of the castle nuts, then removing the nut from the studs. I'm fairly certain the nuts are installed with permanent locktite which makes it a bit of a pain to do. Greg Puckett Elizabeth, CO RV-8 80081 You wrote: This is my first post in several years. I am building an older RV-6 kit and have a question regarding spinners. Has anyone on the list used the spinner supplied in the kit with a McCauley constant speed prop? If so are there any pit falls I should be aware of? Thanks for your help. Ernie Amadio Rv-6 ________________________________________________________________________________
Date: Mar 09, 2005
As I said, I don't feel that I was cheated and I'm not saying that they did anything wrong. The caution is merely to new builders that might not know the difference. My only experience with squeezers was that they were adjustable so I had no idea. My new hand squeeze from Avery was adjustable. Sub $300 for a pneumatic squeeze is a good deal no matter how you look at it, I just would have like to have known about the lack of adjustment so I could have ordered one with it. That's why I posted, so other people would know. BTW, their pneumatic cleco squeeze is great! But stay away from the individual oilers for $5, they leak into the line when not in use. Michael -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Richard Scott Subject: RV-List: Re: Yard Store rebuilt squeeze *caution* Neither Avery nor Cleaveland indicate that an adjustable set holder comes with their squeezer and they both sell one separately, suggesting theirs also come with fixed set holders. I don't see any difference with The Yard. Maybe they could have been more understanding about your mistake, but it appears to me that is was your mistake. The Yard folks have always given me good service and on one occasion adjusted their price to me to meet the competition's price. Also, their shipping cost on small items is a better deal, as they charge only actual cost. You may also note that their price was almost $200 cheaper than that charged by Clear Air Tools http://clearairtools.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=CA &Category_Code=PRS for their rebuilt squeezers, so you got a pretty good deal. BTW, when you want additional yokes, Clear Air seems to have the best deals. Richard Scott RV-9A Wings ________________________________________________________________________________
Date: Mar 09, 2005
There was one brand of oil cooler that didn't work very well and the company that made them exchanged them all free. ----- Original Message ----- From: "Jeff Point" <jpoint(at)mindspring.com> Subject: Re: RV-List: Re: Oil Coolers on Ebay > > Care to elaborate on that? > >>I wondered where all the coolers went that were replaced free. >> >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 09, 2005
----- Original Message ----- From: RV Builder (Michael Sausen) Subject: RV-List: Yard Store rebuilt squeeze *caution* [i] This is my own fault for assuming but I wanted to pass it along anyway to anyone considering getting a pneumatic squeeze. Be sure they have an adjustable set holder. [/i] My pneumatic squeezer was non-adjustable; just used the washers which didn't bother me. Bought it used, and it kept it's value for seven years. Since this was used for a lot of repetitious riveting, as compared to my adjustable Avery hand squeezer being used all over the place; it just didn't have to be re-adjusted (washers) much. ________________________________________________________________________________
Date: Mar 10, 2005
Cy, You are referring to the early model Positech coolers. AeroClassics never had this problem. The problematic oil coolers were copies of the current Stewart Warner design. The AeroClassics are similar to the oil coolers sold by Niagara & Harrison. Apples to Oranges. Charlie Kuss > >There was one brand of oil cooler that didn't work very well and the company >that made them exchanged them all free. > > >----- Original Message ----- >From: "Jeff Point" <jpoint(at)mindspring.com> >To: >Subject: Re: RV-List: Re: Oil Coolers on Ebay > > > > > > Care to elaborate on that? > > > >>I wondered where all the coolers went that were replaced free. > >> > >> > >> > >> > >> > > > > > > > > ________________________________________________________________________________
Subject: Auto Pilots
Date: Mar 10, 2005
If you were going to install a wing leveler auto-pilot, which one would you buy? The obvious choices are Navaid, Trutrak and Trio. I have an RV-4 so panel space is very limited. In order to install the control head I would have to remove my turn coordinator so I was thinking it would be nice if the auto-pilot could also serve in this capacity. Then again, I have a Dynon D10A so maybe the turn coordinator loss is not that big of a deal. What are the pros and cons of these systems? Any testimonials? (There I was........1500', inverted, and running out of options. When all was but lost, I engaged the auto-pilot ........You know what I mean). Jerry Isler Donalsonville, GA RV4 N455J (not flying yet) ________________________________________________________________________________
Subject: LASAR/elecr ign
Date: Mar 10, 2005
I have been going thru archives to try to evaluate elecronic ignition. I have an A&P friend who swears by LASAR, but I have found several posts re problems with this system, but the posts are not very current. I find hardly any problems posted re LSI, or E/P-mags. I imagine e-mags are so new that not a lot is known about them yet. My research has me leaning toward the e/p-mag sys for lower cost/simplicity. Lead times it seems are out there tho. Any LASAR defenders/happy users? Charlie Heathco ________________________________________________________________________________
Date: Mar 10, 2005
Subject: The Mother of all giant scale B-52's
RV related? Well....this RC had the wingspan of an RV-4. http://www.mcgirt.net/RC/VIDEOS/Giant_B52/ ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Update... Blue Mountain Install...
I mounted the aileron servo in the wing last night.....and added some more photos and comments to my web site... http://www.rv8a.com/panel/panel3/installation.htm -Bill ________________________________________________________________________________
Subject: Odyssey Battery Installation Kit
Date: Mar 10, 2005
From: "Alexander, Don" <Don.Alexander(at)astenjohnson.com>
Listers, I am looking at purchasing an Odyssey 680 and noticed that Van's offers an installation kit for this battery for around $50. Does anyone have an idea what would be included in the kit that would make it cost $50? I'm guessing that it probably has a couple of shims in it. Don Alexander RV-8 Electrical and Panel ________________________________________________________________________________
From: "Robert E. Lynch" <rv6lynch(at)earthlink.net>
Subject: Re: LASAR/elecr ign
Date: Mar 10, 2005
Hi Charley I have a Laser on both mag, when I build my next RV it to will have Lasers on it. It is a certified system and best I can tell is no problems and I start in two blades. Sure makes the guys around jealous. BobLynch 465hrs RV6 ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Re: Auto Pilots
Jerry Isler wrote: > > If you were going to install a wing leveler auto-pilot, which one would you > buy? The obvious choices are Navaid, Trutrak and Trio. I have an RV-4 so > panel space is very limited. In order to install the control head I would > have to remove my turn coordinator so I was thinking it would be nice if the > auto-pilot could also serve in this capacity. Then again, I have a Dynon > D10A so maybe the turn coordinator loss is not that big of a deal. What are > the pros and cons of these systems? > Any testimonials? (There I was........1500', inverted, and running out of > options. When all was but lost, I engaged the auto-pilot ........You know > what I mean). Yes, dozens and dozens and dozens. Go here: http://www.matronics.com/searching/search.html Search, "wing leveler" or "autopilot" or any of the above brand names. About all that can be said about these systems up to this point has been said and is in the archives. Not trying to cut off your question, just pointing you to the answers. Sam Buchanan (RV-6, Navaid and EZ-Pilot.....not at the same time...) http://thervjournal.com ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Re: Odyssey Battery Installation Kit
not sure what you could possible need... You can cut down the existing battery tray for the odyssey... You may need some different bolts installing your battery cables... -Bill ----- Original Message ----- From: "Alexander, Don" <Don.Alexander(at)astenjohnson.com> Subject: RV-List: Odyssey Battery Installation Kit Listers, I am looking at purchasing an Odyssey 680 and noticed that Van's offers an installation kit for this battery for around $50. Does anyone have an idea what would be included in the kit that would make it cost $50? I'm guessing that it probably has a couple of shims in it. Don Alexander RV-8 Electrical and Panel ________________________________________________________________________________
Date: Mar 10, 2005
TRUTRAK TRUTRAK TRUTRAK No further discussions necessary. Bob ________________________________________________________________________________
Subject: links to Super 8?
Date: Mar 10, 2005
Hi all, I'm too poor to afford one but I got three friends agonizing over the F1or Harmon Rocket or RV-8 decision. I have heard that there is a 540 powered RV-8 option that uses Rocket style gear? Anybody got a links to 540 powered RV-8 sites? I've only been able to find one. Thank you in advance, Vince in Mojave. P.S. Hope the question ain't anathema to some of you. I don't want to hear it. Vince flyby41(at)earthlink.net ________________________________________________________________________________
Date: Mar 10, 2005
Bill, Word of advise, if those wire tiedown's are just your run of the mill Home Depot type sticky backs, they WILL let loose eventually. Especially in our aircrafts extreme environments. Michael Sausen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill VonDane Subject: RV-List: Update... Blue Mountain Install... I mounted the aileron servo in the wing last night.....and added some more photos and comments to my web site... http://www.rv8a.com/panel/panel3/installation.htm -Bill ________________________________________________________________________________
Date: Mar 10, 2005
I would go with the Pictoral Pilot from TruTrak. It gives you the turn and bank and also autopilot. Michael Sausen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jerry Isler Subject: RV-List: Auto Pilots If you were going to install a wing leveler auto-pilot, which one would you buy? The obvious choices are Navaid, Trutrak and Trio. I have an RV-4 so panel space is very limited. In order to install the control head I would have to remove my turn coordinator so I was thinking it would be nice if the auto-pilot could also serve in this capacity. Then again, I have a Dynon D10A so maybe the turn coordinator loss is not that big of a deal. What are the pros and cons of these systems? Any testimonials? (There I was........1500', inverted, and running out of options. When all was but lost, I engaged the auto-pilot ........You know what I mean). Jerry Isler Donalsonville, GA RV4 N455J (not flying yet) ________________________________________________________________________________
Subject: Spinners
Date: Mar 10, 2005
Greg, Perhaps I should have been clearer on the discription of my situation.My prop is an older McCauley Mod#2D36C14-A from a 1964 Mooney with an O360 A1A. The originalspinner and backing plates were aluminum and had cracked and been repaired several times. The rear backing plate mounted to the fly wheel/ring gear with bolts on machined pads about an inch in from the ring gear.The prop hub does not touch the backing plate at all.In fact the backing plate is completely cut away except for the flange to bolt it to the fly wheel. The backing plate looks like a bowl with the centre of the bottom cut out. I have the Vans' spinner here, and it looks like it might work.My major concern was whether or not there was enough clearance inside the spinner to accomodate the McCauley hub since it appears to be rather tall and bulky and I'd rather know before I cut into the spinner and backing plate.Obviously, if there isn't enough room after the cutting the pieces will be scrap. Thanks for the help. Ernie Amadio RV-6 #21488 ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Re: Update... Blue Mountain Install...
Michael... Thanks for the tip... They are not Home Depot type, and they are epoxies up there... -Bill ----- Original Message ----- From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> Subject: RE: RV-List: Update... Blue Mountain Install... Bill, Word of advise, if those wire tiedown's are just your run of the mill Home Depot type sticky backs, they WILL let loose eventually. Especially in our aircrafts extreme environments. Michael Sausen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill VonDane Subject: RV-List: Update... Blue Mountain Install... I mounted the aileron servo in the wing last night.....and added some more photos and comments to my web site... http://www.rv8a.com/panel/panel3/installation.htm -Bill ________________________________________________________________________________
Date: Mar 10, 2005
On 03/10 9:10, Charles Heathco wrote: > I have been going thru archives to try to evaluate elecronic ignition. I have an A&P friend who swears by LASAR, but I have found several posts re problems with this system, but the posts are not very current. I find hardly any problems posted re LSI, or E/P-mags. I imagine e-mags are so new that not a lot is known about them yet. My research has me leaning toward the e/p-mag sys for lower cost/simplicity. Lead times it seems are out there tho. Any LASAR defenders/happy users? Charlie Heathco I also went with the LASAR ignition, but I'm not flying yet (almost) so I can't provide any real-world experience yet. Installation is easy though. I can say the Bob K. (aeroelectric.com) is not very fond of them. There have been many posts on this issue in that forum wherein Bob describes the reasons why he thinks there may be better alternatives. But, I am satisfied with my choice, so far. -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: Mar 10, 2005
> I have been going thru archives to try to evaluate elecronic ignition. I > have an A&P friend who swears by LASAR, but I have found several posts re > problems with this system, but the posts are not very current. I find > hardly any problems posted re LSI, or E/P-mags. I imagine e-mags are so > new that not a lot is known about them yet. My research has me leaning > toward the e/p-mag sys for lower cost/simplicity. Lead times it seems are > out there tho. Any LASAR defenders/happy users? Charlie Heathco Charlie, I'm a very happy user. I had it installed on my RV-8 (www.rv-8.com) and also spec'd it for my RV-3B I'm now building (www.rv-3.com). One thing, if you do order it be sure and get it WITHOUT the CHT temp sensing circuit, this is a known problem area. It is required on certified installations but of course not on experimentals. I have a few comments on both of my web sites about it. Randy Lervold ________________________________________________________________________________
Date: Mar 10, 2005
Mike: You are opening a can of worms :- ) The buyer of an experimental aircraft can only do routine maintenance, as if it were a Piper or Cessna, as far as I know. Only the manufacture (builder/repairman) can make major mods, however I assume(?) an A&P or AI could do it and with the FAA's blessing. Again, as in all these matters refer to the FISDO of choice for the answer. There is no "type certificate" configuration for exp a/c, so many changes slip thru the cracks and are not tracked by the FAA. Anyone who has a second hand RV may find them self in a regulatory mess if they want to make a major changes. The best (easiest) thing would get the builder to sign the mod off if possible. However that is one of the fantastic reasons for building your own plane. Cheers George > > Mike, > > I have a question related to this very activity ... and am asking not > so much for myself (I'm still building), but just to satisfy my curiosity. > >I have had the impression that all these suggestions and requirements > have been tendered with the idea that the person doing the work is the > builder and has a repairman's certificate for the aircraft. However, what are > the rules/regs for someone who does NOT have the repairmans certificate and > who is NOT an A/P? Somehow I can't imagine that they would be in a position > to change their prop, put it into phase 1, perform the flight testing, and > sign it off putting it back in phase 2. Or can they? --------------------------------- ________________________________________________________________________________
Date: Mar 10, 2005
I had always believed this to be incorrect. The repairman certificate is required for you to sign off on the annual condition inspection. I had always thought that it was not necessary to for anything else. Therefore you could do something such as install a prop and sign it off, though it could be subject to question during the condition inspection. Might be time to hit the FAR's. -- John www.rivetbangers.com - Building more than just RV's www.spikesplace.org/cgi-php/serendipity - Builder's log ----- Original Message ----- From: <gmcjetpilot(at)yahoo.com> Subject: Re: RV-List: Prop replacement, question for Das Fed, was: > > > Mike: > > You are opening a can of worms :- ) The buyer of an experimental aircraft can only do routine maintenance, as if it were a Piper or Cessna, as far as I know. Only the manufacture (builder/repairman) can make major mods, however I assume(?) an A&P or AI could do it and with the FAA's blessing. Again, as in all these matters refer to the FISDO of choice for the answer. There is no "type certificate" configuration for exp a/c, so many changes slip thru the cracks and are not tracked by the FAA. Anyone who has a second hand RV may find them self in a regulatory mess if they want to make a major changes. The best (easiest) thing would get the builder to sign the mod off if possible. However that is one of the fantastic reasons for building your own plane. > > Cheers George ________________________________________________________________________________
Date: Mar 10, 2005
To Charlie, I have only 25 hours on the engine/LASAR system but it is working as expected. I do have the CHT sensor and not aware of any problems with it. To Randy, What kind of problems are you aware of?... or have experienced with the CHT sensor feature? Dale Ensing ________________________________________________________________________________
Date: Mar 10, 2005
Check out this document from the FAA: http://www.faa.gov/avr/afs/faa/8300/8300_vol2/2_025_00.pdf and AC650-23A: http://www.rivetbangers.com/documents/AC65-23A.pdf The repairman certificate allows an individual to perform the annual condition inspection only. I believe that any owner can alter the aircraft as they see fit. I believe this would be based on the idea that the aircraft is not certified. Anyone have a better explanation? -- John www.rivetbangers.com - Building more than just RV's www.spikesplace.org/cgi-php/serendipity - Builder's log ----- Original Message ----- From: <gmcjetpilot(at)yahoo.com> Subject: Re: RV-List: Prop replacement, question for Das Fed, was: > > > Mike: > > You are opening a can of worms :- ) The buyer of an experimental aircraft can only do routine maintenance, as if it were a Piper or Cessna, as far as I know. Only the manufacture (builder/repairman) can make major mods, however I assume(?) an A&P or AI could do it and with the FAA's blessing. Again, as in all these matters refer to the FISDO of choice for the answer. There is no "type certificate" configuration for exp a/c, so many changes slip thru the cracks and are not tracked by the FAA. Anyone who has a second hand RV may find them self in a regulatory mess if they want to make a major changes. The best (easiest) thing would get the builder to sign the mod off if possible. However that is one of the fantastic reasons for building your own plane. > > Cheers George > > > > > > Mike, > > > > I have a question related to this very activity ... and am asking not > > so much for myself (I'm still building), but just to satisfy my curiosity. > > > >I have had the impression that all these suggestions and requirements > > have been tendered with the idea that the person doing the work is the > > builder and has a repairman's certificate for the aircraft. However, what are > > the rules/regs for someone who does NOT have the repairmans certificate and > > who is NOT an A/P? Somehow I can't imagine that they would be in a position > > to change their prop, put it into phase 1, perform the flight testing, and > > sign it off putting it back in phase 2. Or can they? > > > --------------------------------- > > ________________________________________________________________________________
Date: Mar 10, 2005
> > If you were going to install a wing leveler auto-pilot, which one > would you > buy? The obvious choices are Navaid, Trutrak and Trio. I have an RV-4 > so > panel space is very limited. In order to install the control head I > would > have to remove my turn coordinator so I was thinking it would be nice > if the > auto-pilot could also serve in this capacity. Then again, I have a > Dynon > D10A so maybe the turn coordinator loss is not that big of a deal. > What are > the pros and cons of these systems? > Any testimonials? (There I was........1500', inverted, and running out > of > options. When all was but lost, I engaged the auto-pilot ........You > know > what I mean). > I have a RV-4 with a Digiflight II installed (alt hold, VS mode, and GPSS steering). It is the most amazing autopilot I have used with side of the B-757 I fly for work. It is amazingly damped in rough air, never gets off altitude more than 10 feet and tracking s GPS course within .05 of a NM. I now consider an absolute necessity for my RV-4. XC flying is a no-brainer.. comfortable and fatigue free. Save your pennies and you will consider it your best investment in your airplane. Doug Weiler N722DW, 170 hour TT ________________________________________________________________________________
Date: Mar 10, 2005
Anyone can work on a homebuilt aircraft including a trained chimp or your dog. You just have to have the condition inspection signed off by an A&P or AI. Dave gmcjetpilot(at)yahoo.com wrote: > > >Mike: > >You are opening a can of worms :- ) The buyer of an experimental aircraft can only do routine maintenance, as if it were a Piper or Cessna, as far as I know. Only the manufacture (builder/repairman) can make major mods, however I assume(?) an A&P or AI could do it and with the FAA's blessing. Again, as in all these matters refer to the FISDO of choice for the answer. There is no "type certificate" configuration for exp a/c, so many changes slip thru the cracks and are not tracked by the FAA. Anyone who has a second hand RV may find them self in a regulatory mess if they want to make a major changes. The best (easiest) thing would get the builder to sign the mod off if possible. However that is one of the fantastic reasons for building your own plane. > >Cheers George > > > > >> >>Mike, >> >>I have a question related to this very activity ... and am asking not >>so much for myself (I'm still building), but just to satisfy my curiosity. >> >>I have had the impression that all these suggestions and requirements >>have been tendered with the idea that the person doing the work is the >>builder and has a repairman's certificate for the aircraft. However, what are >>the rules/regs for someone who does NOT have the repairmans certificate and >>who is NOT an A/P? Somehow I can't imagine that they would be in a position >>to change their prop, put it into phase 1, perform the flight testing, and >>sign it off putting it back in phase 2. Or can they? >> >> > > > >--------------------------------- > > > > ________________________________________________________________________________
Date: Mar 10, 2005
Has anyone ever tried to use the electric trim servo for altitude hold? I'm not talking about rough air and turbulence, just normal VFR cross country flying. I was thinking of just giving the trim motor a little blip to steer me back to the right altitude. The pulse width could be proportional to the error. I would use a Motorola MC68HC11 processor since I have worked with that one for about 20 years. Pressure input would come from an automotive type barometric pressure sensor with enough amplification to get the error signal big enough for the processor to read it. Any thoughts? Dan Hopper RV-7A (Flying) ________________________________________________________________________________
Subject: POP rivet static port
Date: Mar 10, 2005
When installing Van's static port pop rivets.Do you set the rivet or just glue it in place? It seems to me that if you set the rivet there will be not much to attach the tubing to. GEORGE H. INMAN ghinman(at)mts.net ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Re: POP rivet static port
George, You're right, I wish those rivets were longer. I sanded off the area on the inside and set the rivets. Then used RTV (silicone) to glue and strain relieve the tubing. That way the RTV can get hold of the fuselage sides too. While you're at it put the "T" at the top of the bulkhead (centered) to get the best average pressure between the two ports. All IMHO, of course. Dan Hopper Walton, IN RV-7A (Flying) In a message dated 3/10/05 2:42:47 P.M. US Eastern Standard Time, ghinman(at)mts.net writes: When installing Van's static port pop rivets.Do you set the rivet or just glue it in place? It seems to me that if you set the rivet there will be not much to attach the tubing to. GEORGE H. INMAN ghinman(at)mts.net ________________________________________________________________________________
Date: Mar 10, 2005
Hopperdhh(at)aol.com wrote: > > Has anyone ever tried to use the electric trim servo for altitude hold? I'm > not talking about rough air and turbulence, just normal VFR cross country > flying. I was thinking of just giving the trim motor a little blip to steer me > back to the right altitude. The pulse width could be proportional to the > error. I would use a Motorola MC68HC11 processor since I have worked with that > one for about 20 years. Pressure input would come from an automotive type > barometric pressure sensor with enough amplification to get the error signal > big enough for the processor to read it. > > Any thoughts? > > Dan Hopper > RV-7A (Flying) Keep us informed on this. Phil RV6 flying ________________________________________________________________________________
Date: Mar 10, 2005
Hopperdhh(at)aol.com wrote: > > > Has anyone ever tried to use the electric trim servo for altitude hold? I'm > not talking about rough air and turbulence, just normal VFR cross country > flying. I was thinking of just giving the trim motor a little blip to steer me > back to the right altitude. The pulse width could be proportional to the > error. I would use a Motorola MC68HC11 processor since I have worked with that > one for about 20 years. Pressure input would come from an automotive type > barometric pressure sensor with enough amplification to get the error signal > big enough for the processor to read it. > > Any thoughts? > > Dan Hopper > RV-7A (Flying) Dan, the answer is "yes". Here is a link to an altitude hold unit that used the trim tab: http://members.aol.com/_ht_a/ccady/eztrim.htm Seems I heard the unit was out of production but since the page is still active, I may be wrong about that. I think I also read that the unit struggled with holding the speedy RV on altitude but worked better with slower aircraft. Sam Buchanan ________________________________________________________________________________
Date: Mar 10, 2005
On 03/10 1:40, George Inman wrote: > > When installing Van's static > port pop rivets.Do you set the rivet > or just glue it in place? > It seems to me that if you set > the rivet there will be not much to > attach the tubing to. I "pulled" the pop rivet just enough to hold it firmly in place but not all the way so that it "pops". Then push the center pull pin from the outside inwards until it comes out. The flexible tubing vans provides will go over the now spread rearend of the rivet. After the tubing is in place I RTV'd it as a security measure. http://www.rv7-a.com/129_2938.jpg -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: Mar 10, 2005
On 03/10 2:50, Hopperdhh(at)aol.com wrote: > You're right, I wish those rivets were longer. I sanded off the area on the > inside and set the rivets. Then used RTV (silicone) to glue and strain > relieve the tubing. That way the RTV can get hold of the fuselage sides too. > While you're at it put the "T" at the top of the bulkhead (centered) to get the > best average pressure between the two ports. All IMHO, of course. > > Dan Hopper > Walton, IN > RV-7A (Flying) > > > In a message dated 3/10/05 2:42:47 P.M. US Eastern Standard Time, > ghinman(at)mts.net writes: > > When installing Van's static > port pop rivets.Do you set the rivet > or just glue it in place? > It seems to me that if you set > the rivet there will be not much to > attach the tubing to. I did it just like Dan. A few more pics. see entry dated 4/11/04 http://www.rv7-a.com/fuselage_4.htm -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Subject: A/P and servos
Date: Mar 10, 2005
I've looked at the archives and come away a little confused. I have the installation kit from TruTrak that includes servos and brackets for roll and pitch. The problem I have is with the constant control resistance of the TruTrak servo. The archives indicate the Navaid servo has a clutch; thereby having no control resistance when disengaged. This is a major benefit in my book. But the same series of posts indicate there are better (digital) controls available. Could someone post a simple matrix of options currently or soon-to-be available options or combination options ?? Larry E. James Bellevue, WA HR2 -fuselage and systems- ________________________________________________________________________________
Date: Mar 10, 2005
Couldn't you slurp the altitude information from your altitude encoder before you send it to the transponder? > ... Pressure input would come from an automotive type > barometric pressure sensor with enough amplification to get the error signal > big enough for the processor to read it. > -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Re: A/P and servos
the Blue Mountain servos have magnetic clutches an no resistance when not engaged... -Bill ----- Original Message ----- From: "Larry James" <larry(at)ncproto.com> Subject: RV-List: A/P and servos I've looked at the archives and come away a little confused. I have the installation kit from TruTrak that includes servos and brackets for roll and pitch. The problem I have is with the constant control resistance of the TruTrak servo. The archives indicate the Navaid servo has a clutch; thereby having no control resistance when disengaged. This is a major benefit in my book. But the same series of posts indicate there are better (digital) controls available. Could someone post a simple matrix of options currently or soon-to-be available options or combination options ?? Larry E. James Bellevue, WA HR2 -fuselage and systems- ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Electric or manual trim?
0.20 FROM_HAS_ULINE_NUMS From": contains.an.underline.and.numbers/letters(at)matronics.com Just ordering the RV-7 empennage kit... what is the consensus on whether to go for electic or manual trim? jp --------------------------------- ________________________________________________________________________________
Date: Mar 10, 2005
> To Randy, > What kind of problems are you aware of?... or have experienced with the > CHT > sensor feature? > Dale Ensing First off, you need the correct dual pigtail CHT sensor, that is if you have a 4-channel CHT gauge. There are J-types and K-types and I forget which the LASAR requires, but it won't work correctly unless you have the correct type. Then, for some reason the connections from the sensor pigtail to the wires that go into the brain are hypersensitive. They can look perfectly good, and even test good with an ohmeter, but the slightest bit of resistance will cause the LASAR brain to fault, and when it faults the red dash light comes on and it simply goes back into fixed timing mag mode. It's not a safety issue because you still have two magnetos driving the system, but it's highly annoying and you're not getting the benefit of the advanced timing. Of course the red light is conspicuous also. What the CHT circuit does is move the advance back in incrental amounts any time the CHT is 425 degrees F or above. This was required for certification. Now most of us have fancy engine monitors with their own alarms for high CHT so if you simply eliminate the circuit you'll never have a problem. It cannot be field deactivated. My advice is to install your LASAR on a breaker switch near the master switch so it can be turned off. The simply fact is that your engine will run hotter with LASAR because it's buring the fuel/air charge more efficiently in the combustion chamber, not in the exhaust system. Therefore you need to be aware of it. On my RV-8 I learned to turn the system off for a long climbout on a hot day, then switch it back on once leveled off. Now my RV-8 had smaller cooling inlets and a plenum so it didn't have a surplus of cooling air to start with. I only had to turn it off 2-3 times in nearly 400 hours of flying. That sort of scenario is when on a cross country stop for fuel, high density altitude, high OAT, gross weight, and on a long climb. I'd takeoff normally then once my climb was established I'd turn the LASAR off, climb to 10/12/14k, then turn it back on. Just watch the CHTs and use your own judgement. All told I really like the LASAR system, and Unison support has been great, but I do think the P-mag/E-mag product has merit and may well be the system of choice in the near future, but like all the rest of you I'd like to see more field experience with the product and more experience with how the company will support it. FWIW, Randy Lervold www.rv-8.com www.rv-3.com ________________________________________________________________________________
Date: Mar 10, 2005
Larry James wrote: > > I've looked at the archives and come away a little confused. I have the > installation kit from TruTrak that includes servos and brackets for roll and > pitch. The problem I have is with the constant control resistance of the > TruTrak servo. > > The archives indicate the Navaid servo has a clutch; thereby having no > control resistance when disengaged. This is a major benefit in my book. > But the same series of posts indicate there are better (digital) controls > available. > > Could someone post a simple matrix of options currently or soon-to-be > available options or combination options ?? > > Larry E. James > Bellevue, WA HR2 -fuselage and systems- Larry, I'll take a stab at it. Navaid servo has a solenoid driven clutch which completely disengages when power is removed and has no drag. This servo, while analog and several years old, continues to function well in the field. You can drive the Navaid servo with the Navaid, EZ-Pilot, or the Navaid version of the DigiTrak. The TruTrak servo is a stepping servo motor that remains attached to the control system at all times. When it is powered down, there is a very small amount of drag that you can feel on the ground, but you won't notice it in the air. The EZ-Pilot and DigiTrak heads are both digital and use solid-state sensors instead of the mechanical gyro in the Navaid. They also offer functions, features and performance that is beyond the capability of the Navaid. When it comes to pitch control, you can go with a wing leveler and add the excellent AlTrak or one of the upcoming units from Trio Avionics. Or you can install a multi-axis system such as the TruTrak autopilots. There is also the Blue Mtn system that is an add-on for their EFIS. I do not know how the clutch is designed in the BMA servos. Maybe this didn't muddy the water too much. :-) Sam Buchanan http://thervjournal.com ________________________________________________________________________________
Date: Mar 10, 2005
I've looked the statement that the owner can do no more than he can on certified. This is FLAT OUT WRONG. Anyone can work on an experimental. One caveat and even this might be wrong. At the yearly conditional inspection, the work has to be good enough to get the plane signed off as airworthy. Cy Galley EAA Safety Programs Editor Always looking for ideas and articles for EAA Sport Pilot ----- Original Message ----- From: "Dave Bristol" <dbris200(at)sbcglobal.net> Subject: Re: RV-List: Prop replacement, question for Das Fed, was: > > Anyone can work on a homebuilt aircraft including a trained chimp or > your dog. You just have to have the condition inspection signed off by > an A&P or AI. > > Dave > > gmcjetpilot(at)yahoo.com wrote: > >> >> >>Mike: >> >>You are opening a can of worms :- ) The buyer of an experimental aircraft >>can only do routine maintenance, as if it were a Piper or Cessna, as far >>as I know. Only the manufacture (builder/repairman) can make major mods, >>however I assume(?) an A&P or AI could do it and with the FAA's blessing. >>Again, as in all these matters refer to the FISDO of choice for the >>answer. There is no "type certificate" configuration for exp a/c, so many >>changes slip thru the cracks and are not tracked by the FAA. Anyone who >>has a second hand RV may find them self in a regulatory mess if they want >>to make a major changes. The best (easiest) thing would get the builder to >>sign the mod off if possible. However that is one of the fantastic reasons >>for building your own plane. >> >>Cheers George >> >> >> >> >>> >>>Mike, >>> >>>I have a question related to this very activity ... and am asking not >>>so much for myself (I'm still building), but just to satisfy my >>>curiosity. >>> >>>I have had the impression that all these suggestions and requirements >>>have been tendered with the idea that the person doing the work is the >>>builder and has a repairman's certificate for the aircraft. However, what >>>are >>>the rules/regs for someone who does NOT have the repairmans certificate >>>and >>>who is NOT an A/P? Somehow I can't imagine that they would be in a >>>position >>>to change their prop, put it into phase 1, perform the flight testing, >>>and >>>sign it off putting it back in phase 2. Or can they? >>> >>> >> >> >> >>--------------------------------- >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Re: Prop replacement, question for Das Fed, was:
cgalley wrote: > > I've looked the statement that the owner can do no more than he can on > certified. > This is FLAT OUT WRONG. > > Anyone can work on an experimental. > > One caveat and even this might be wrong. At the yearly conditional > inspection, the work has to be good enough to get the plane signed off as > airworthy. > > Cy Galley > EAA Safety Programs Editor > Always looking for ideas and articles for EAA Sport Pilot Cy, I think you could also correctly state that *anyone* can work on a certificated aircraft. The kicker is getting an A&P/AI to make the necessary logbook entries. Sam Buchanan (overhauled two engines with A&P/AI's blessing) ________________________________________________________________________________
Date: Mar 10, 2005
Received-SPF: none I used the stock tray and made two able brackets that I bolted to the bottom to take up the space, this way if I ever want to install a full size battery all I have to do is remove the brackets and make an new hold down. I cut the piece of channel that holds the battery down to fit and used 3/4" angle for the spacers. Jim Jim Cimino N7TL RV-8 S/N 80039 15+ Hours http://www.geocities.com/jcimino.geo/ ----- Original Message ----- From: "Alexander, Don" <Don.Alexander(at)astenjohnson.com> Subject: RV-List: Odyssey Battery Installation Kit > > > Listers, > I am looking at purchasing an Odyssey 680 and noticed that Van's offers > an installation kit for this battery for around $50. Does anyone have > an idea what would be included in the kit that would make it cost $50? > I'm guessing that it probably has a couple of shims in it. > Don Alexander > RV-8 Electrical and Panel > > > ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Electric or Manual Trim ?
0.20 FROM_HAS_ULINE_NUMS From": contains.an.underline.and.numbers/letters(at)matronics.com Just ordering the RV-7 empennage kit... what is the consensus on whether to go for electic or manual trim? --------------------------------- ________________________________________________________________________________
Date: Mar 10, 2005
It won't work...I had that dream some time ago...how would electric trim "know" if you were descending or climbing a bit ? It wouldn't. You need some input regarding pressure changes not just aerodynamic forces on the elevator. John ----- Original Message ----- From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net> Subject: Re: RV-List: Auto Pilots > > > Hopperdhh(at)aol.com wrote: > >> >> Has anyone ever tried to use the electric trim servo for altitude hold? >> I'm >> not talking about rough air and turbulence, just normal VFR cross >> country >> flying. I was thinking of just giving the trim motor a little blip to >> steer me >> back to the right altitude. The pulse width could be proportional to >> the >> error. I would use a Motorola MC68HC11 processor since I have worked >> with that >> one for about 20 years. Pressure input would come from an automotive >> type >> barometric pressure sensor with enough amplification to get the error >> signal >> big enough for the processor to read it. >> >> Any thoughts? >> >> Dan Hopper >> RV-7A (Flying) > > Keep us informed on this. > Phil RV6 flying > > > ________________________________________________________________________________
Date: Mar 10, 2005
Well that's not quite true....it has been done and it's been proven to work. Simple Altitude encoded information is all the trim system needs to know. In reality it's not much different than a servo running an altitude autopilot. I'm not saying it works well or is good, but it has and will work to some extent. It's just a slimmed down "Altitude hold" on a diet! Cheers, Stein. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of John Subject: Re: RV-List: Auto Pilots It won't work...I had that dream some time ago...how would electric trim "know" if you were descending or climbing a bit ? It wouldn't. You need some input regarding pressure changes not just aerodynamic forces on the elevator. John ----- Original Message ----- From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net> Subject: Re: RV-List: Auto Pilots > > > Hopperdhh(at)aol.com wrote: > >> >> Has anyone ever tried to use the electric trim servo for altitude hold? >> I'm >> not talking about rough air and turbulence, just normal VFR cross >> country >> flying. I was thinking of just giving the trim motor a little blip to >> steer me >> back to the right altitude. The pulse width could be proportional to >> the >> error. I would use a Motorola MC68HC11 processor since I have worked >> with that >> one for about 20 years. Pressure input would come from an automotive >> type >> barometric pressure sensor with enough amplification to get the error >> signal >> big enough for the processor to read it. >> >> Any thoughts? >> >> Dan Hopper >> RV-7A (Flying) > > Keep us informed on this. > Phil RV6 flying > > ________________________________________________________________________________
Date: Mar 10, 2005
I built one of these units and worked with it for quite a while and the bottom line was that the trim servo was just too slow - it worked, but not very well, the servo just couldn't keep up with the changes. The circuit and software however, are good and my current project is to mate it to a real servo. Will let the list know how it works. Dave -6 So Cal Sam Buchanan wrote: > >Hopperdhh(at)aol.com wrote: > > >> >> >>Has anyone ever tried to use the electric trim servo for altitude hold? I'm >>not talking about rough air and turbulence, just normal VFR cross country >>flying. I was thinking of just giving the trim motor a little blip to steer me >>back to the right altitude. The pulse width could be proportional to the >>error. I would use a Motorola MC68HC11 processor since I have worked with that >>one for about 20 years. Pressure input would come from an automotive type >>barometric pressure sensor with enough amplification to get the error signal >>big enough for the processor to read it. >> >>Any thoughts? >> >>Dan Hopper >>RV-7A (Flying) >> >> > > >Dan, the answer is "yes". Here is a link to an altitude hold unit that >used the trim tab: > >http://members.aol.com/_ht_a/ccady/eztrim.htm > >Seems I heard the unit was out of production but since the page is still >active, I may be wrong about that. I think I also read that the unit >struggled with holding the speedy RV on altitude but worked better with >slower aircraft. > >Sam Buchanan > > > > ________________________________________________________________________________
Date: Mar 10, 2005
But, the mode C output only has 100' resolution so you'd be all over the sky chasing it. On the other hand, GPS altitude might work pretty good. It's not very accurate but you don't care since all you want is to maintain your present altitude. GPS altitude doesn't change with barometric pressure so you'd have to keep an eye on it, but it should work. Dave -6 So Cal Stein Bruch wrote: > >Well that's not quite true....it has been done and it's been proven to work. >Simple Altitude encoded information is all the trim system needs to know. >In reality it's not much different than a servo running an altitude >autopilot. > >I'm not saying it works well or is good, but it has and will work to some >extent. It's just a slimmed down "Altitude hold" on a diet! > >Cheers, >Stein. > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of John >To: rv-list(at)matronics.com >Subject: Re: RV-List: Auto Pilots > > >It won't work...I had that dream some time ago...how would electric trim >"know" if you were descending or climbing a bit ? It wouldn't. You need some >input regarding pressure changes not just aerodynamic forces on the >elevator. > >John > > >----- Original Message ----- >From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net> >To: >Subject: Re: RV-List: Auto Pilots > > > > >> >> >>Hopperdhh(at)aol.com wrote: >> >> >> >>> >>>Has anyone ever tried to use the electric trim servo for altitude hold? >>>I'm >>>not talking about rough air and turbulence, just normal VFR cross >>>country >>>flying. I was thinking of just giving the trim motor a little blip to >>>steer me >>>back to the right altitude. The pulse width could be proportional to >>>the >>>error. I would use a Motorola MC68HC11 processor since I have worked >>>with that >>>one for about 20 years. Pressure input would come from an automotive >>>type >>>barometric pressure sensor with enough amplification to get the error >>>signal >>>big enough for the processor to read it. >>> >>>Any thoughts? >>> >>>Dan Hopper >>>RV-7A (Flying) >>> >>> >>Keep us informed on this. >>Phil RV6 flying >> >> >> >> > > > > ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Re: links to Super 8?
I'd start with Mike Stewart! Also, email him with any/all of your questions.....he'll help you out big time. http://www.mstewart.net/ Rick Gray in Ohio at the Buffalo Farm http://rv6rick.tripod.com/ohiovalleyrvators/ Hi all, I'm too poor to afford one but I got three friends agonizing over the F1or Harmon Rocket or RV-8 decision. I have heard that there is a 540 powered RV-8 option that uses Rocket style gear? Anybody got a links to 540 powered RV-8 sites? I've only been able to find one. Thank you in advance, Vince in Mojave. P.S. Hope the question ain't anathema to some of you. I don't want to hear it. Vince flyby41(at)earthlink.net ________________________________________________________________________________
Date: Mar 10, 2005
Subject: Re: Electric or Manual Trim ?
On 14:43:34 2005-03-10 Jim Peoples wrote: > Just ordering the RV-7 empennage kit... what is the consensus on > whether to go for electic or manual trim? I don't think you'll easily find a consensus here on trim, primer, nosewheel/tailwheel, or slider/tip-up. But here's my opinion: 1. The manual trim option is the simplest, and probably the lightest, option. 2. The stock electric trim kit puts the servo in the elevator, which means you require a little bit of extra balance weight in your elevator counterbalances. I don't know how much, maybe someone here who's done it can tell us. This means you have both the extra weight of the servo, and the extra balance weight, in your tail (which is a long way from the CG in an airplane that is prone to being rear-CG sensitive). 3. Another option is to do as some others have done, which is a hybrid of the two "normal" systems. Buy the manual trim system, and the trim servo. Mount the servo on the shelf in front of the horizontal stabilizer, and drive the trim tab with it using the manual trim hardware. This system saves the extra balance weight in the elevator, and the weight of a push-pull cable all the way to the cockpit (you swap it for a light-gauge wire instead). Hope this helps! -Rob ________________________________________________________________________________
Subject: Re: The Mother of all giant scale B-52's
Date: Mar 11, 2005
Rick, Thanks for coming by. My baloon would certainly be deflated more if I built that B52 and watched it go in. Ron > > From: Rick Galati <rick6a(at)yahoo.com> > Date: 2005/03/10 Thu PM 02:43:33 GMT > To: rv-list(at)matronics.com > Subject: RV-List: The Mother of all giant scale B-52's > > ________________________________________________________________________________
Date: Mar 10, 2005
cgalley wrote: > >I've looked the statement that the owner can do no more than he can on >certified. >This is FLAT OUT WRONG. > > Anyone can work on an experimental. > >One caveat and even this might be wrong. At the yearly conditional >inspection, the work has to be good enough to get the plane signed off as >airworthy. > >Cy Galley >EAA Safety Programs Editor >Always looking for ideas and articles for EAA Sport Pilot > Even the 2nd statement isn't quite right. Experimental Homebuilts aren't considered 'Airworthy' by the FAA. If you read the boilerplate for signing off the 'annual', it says that the a/c is found to be in a condition that will allow 'safe operation'. I'm pretty sure that this stuff is covered somewhere on the EAA website. Charlie ________________________________________________________________________________
Date: Mar 10, 2005
I am currently playing with a design for a heading hold -wing leveler. I have the electronic components mocked up in a electronic simulation (PSPICE) at this point. I am still debating whether to go with the analog approach or the digital using a PIC Microchip. The digital clearly offers more move for growth and change but the complexity of the algorithms are a bit much. The analog looks to be more straight forward - but with limited growth capability. I am looking to make a simply (inexpensive) system that will start out as an manual electric aileron trim and progress from there. I believe that a Cascading set of simple OpAmp PID controllers looks to be the best bet (and least expensive) for smooth operation. This is basically two control loops - the outside loop would be comparing a heading signal to your set heading the difference would generally a roll angle requirement this would feed to the inside loop where the current roll angle would be compared to the command roll and if a difference exists the inner list would generate a roll rate command which would end up driving the servo. A small difference in heading would generate a small roll rate and a larger difference a faster roll rate (with limits of course - probably 15 deg max). Obviously quite a bit more complex than this brief description - but that's the general idea. The Unit is intended for VFR ONLY and will probably use a 1/3 scale model aircraft servo. If anyone is interested in discussing approaches off-line give me a shout. Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ----- Original Message ----- From: "Dave Bristol" <dbris200(at)sbcglobal.net> Subject: Re: RV-List: Auto Pilots > > I built one of these units and worked with it for quite a while and the > bottom line was that the trim servo was just too slow - it worked, but > not very well, the servo just couldn't keep up with the changes. The > circuit and software however, are good and my current project is to mate > it to a real servo. > Will let the list know how it works. > > Dave -6 So Cal > > Sam Buchanan wrote: > > > > >Hopperdhh(at)aol.com wrote: > > > > > >> > >> > >>Has anyone ever tried to use the electric trim servo for altitude hold? I'm > >>not talking about rough air and turbulence, just normal VFR cross country > >>flying. I was thinking of just giving the trim motor a little blip to steer me > >>back to the right altitude. The pulse width could be proportional to the > >>error. I would use a Motorola MC68HC11 processor since I have worked with that > >>one for about 20 years. Pressure input would come from an automotive type > >>barometric pressure sensor with enough amplification to get the error signal > >>big enough for the processor to read it. > >> > >>Any thoughts? > >> > >>Dan Hopper > >>RV-7A (Flying) > >> > >> > > > > > >Dan, the answer is "yes". Here is a link to an altitude hold unit that > >used the trim tab: > > > >http://members.aol.com/_ht_a/ccady/eztrim.htm > > > >Seems I heard the unit was out of production but since the page is still > >active, I may be wrong about that. I think I also read that the unit > >struggled with holding the speedy RV on altitude but worked better with > >slower aircraft. > > > >Sam Buchanan > > > > > > > > > > ________________________________________________________________________________
Date: Mar 10, 2005
I'm told that if you have serial code output available such as the Dynon D10A produces for instance, it will be in 10' resolution. Is this True? Jim in Kelowna ----- Original Message ----- From: "Dave Bristol" <dbris200(at)sbcglobal.net> Subject: Re: RV-List: Auto Pilots > > But, the mode C output only has 100' resolution so you'd be all over the > sky chasing it. On the other hand, GPS altitude might work pretty good. > It's not very accurate but you don't care since all you want is to > maintain your present altitude. GPS altitude doesn't change with > barometric pressure so you'd have to keep an eye on it, but it should > work. > > Dave -6 So Cal > > Stein Bruch wrote: > >> >>Well that's not quite true....it has been done and it's been proven to >>work. >>Simple Altitude encoded information is all the trim system needs to know. >>In reality it's not much different than a servo running an altitude >>autopilot. >> >>I'm not saying it works well or is good, but it has and will work to some >>extent. It's just a slimmed down "Altitude hold" on a diet! >> >>Cheers, >>Stein. >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of John >>To: rv-list(at)matronics.com >>Subject: Re: RV-List: Auto Pilots >> >> >> >>It won't work...I had that dream some time ago...how would electric trim >>"know" if you were descending or climbing a bit ? It wouldn't. You need >>some >>input regarding pressure changes not just aerodynamic forces on the >>elevator. >> >>John >> >> >>----- Original Message ----- >>From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net> >>To: >>Subject: Re: RV-List: Auto Pilots >> >> >> >> >>> >>> >>>Hopperdhh(at)aol.com wrote: >>> >>> >>> >>>> >>>>Has anyone ever tried to use the electric trim servo for altitude hold? >>>>I'm >>>>not talking about rough air and turbulence, just normal VFR cross >>>>country >>>>flying. I was thinking of just giving the trim motor a little blip to >>>>steer me >>>>back to the right altitude. The pulse width could be proportional to >>>>the >>>>error. I would use a Motorola MC68HC11 processor since I have worked >>>>with that >>>>one for about 20 years. Pressure input would come from an automotive >>>>type >>>>barometric pressure sensor with enough amplification to get the error >>>>signal >>>>big enough for the processor to read it. >>>> >>>>Any thoughts? >>>> >>>>Dan Hopper >>>>RV-7A (Flying) >>>> >>>> >>>Keep us informed on this. >>>Phil RV6 flying >>> >>> >>> >>> >> >> >> >> > > > ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Mar 10, 2005
> My advice is to install your LASAR on a breaker switch near > the master > switch so it can be turned off. The simply fact is that your > engine will run > hotter with LASAR because it's buring the fuel/air charge > more efficiently > in the combustion chamber, not in the exhaust system. > Therefore you need to > be aware of it. On my RV-8 I learned to turn the system off > for a long > climbout on a hot day, then switch it back on once leveled > off. Now my RV-8 I have 584 hours on my Lasar system now over the last 3.5 years, and here are some thoughts: Regarding what Randy has written above, the system does not advance past the baseline 25 degrees for the first 15 minutes of operation, allowing for a pretty good taxi and climbout for an RV. I don't believe any of the other EI's do this, and I can't say how much difference it really makes. One does need to be aware of this, as fine tuning mixture settings for cruise should wait until this period is expired. Reliability wise I have had two failures. At 342 hours, the left mag died. It was detected by a higher than normal EGT noted during a 40 minute flight, and the mag check on the return showed that the left mag was sick (not dead, but not good either). Unison sent another mag free of charge next day to me, excellent service. I left for the west coast the next day, and was thinking about that new mag when over the Rocky Mountains.... At 569 hours, during cruise flight, the engine hesitated (this tends to get one's attention) for perhaps 1/4 second, then recovered. The fault light was on indicating the system was in backup mode (mags running). Once over an airport, I checked the L/R mags, and the left was completely dead (one tends to move the switch back quite rapidly when the engine completely stops firing). Once again, Unison replaced it with a brand new one free of charge, although this took a couple weeks this time. I suspect if I had been on the road, they would have overnighted one. I never did learn what the failure was on the first mag, but the recent failure was caused by a broken rotor. So, overall, Unison really sticks behind their product, but two failures of two different left mags is a little troubling. Ignition systems are not yet trouble free - anyone's. One person here had to rebuild a lot of his cowl and baffling when an encoder wheel came off inside his Electroair during startup. Others have had problems with Lightspeed. It is impossible to say with any accuracy what anyone's system's reliability is. Given the performance afforded by EI, mainly fuel economy, I would not be interested in running my plane on standard mags. Alex Peterson RV6-A 584 hours Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Mar 10, 2005
Jim, I just did a quick Google search and found this quote. " Mode S has an altitude resolution of 25 ft, Mode C has an altitude resolution of 100 ft." I think that may be the standard, but that doesn't mean that the newer encoders couldn't have higher resolution. With that in mind, if you have a high resolution encoder, I don't see why it wouldn't be an acceptable source for autopilot altitude information. Dave Jim Jewell wrote: > >I'm told that if you have serial code output available such as the Dynon >D10A produces for instance, it will be in 10' resolution. >Is this True? > >Jim in Kelowna > >----- Original Message ----- >From: "Dave Bristol" <dbris200(at)sbcglobal.net> >To: >Subject: Re: RV-List: Auto Pilots > > > > >> >>But, the mode C output only has 100' resolution so you'd be all over the >>sky chasing it. On the other hand, GPS altitude might work pretty good. >>It's not very accurate but you don't care since all you want is to >>maintain your present altitude. GPS altitude doesn't change with >>barometric pressure so you'd have to keep an eye on it, but it should >>work. >> >>Dave -6 So Cal >> >>Stein Bruch wrote: >> >> >> >>> >>>Well that's not quite true....it has been done and it's been proven to >>>work. >>>Simple Altitude encoded information is all the trim system needs to know. >>>In reality it's not much different than a servo running an altitude >>>autopilot. >>> >>>I'm not saying it works well or is good, but it has and will work to some >>>extent. It's just a slimmed down "Altitude hold" on a diet! >>> >>>Cheers, >>>Stein. >>> >>>-----Original Message----- >>>From: owner-rv-list-server(at)matronics.com >>>[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of John >>>To: rv-list(at)matronics.com >>>Subject: Re: RV-List: Auto Pilots >>> >>> >>> >>>It won't work...I had that dream some time ago...how would electric trim >>>"know" if you were descending or climbing a bit ? It wouldn't. You need >>>some >>>input regarding pressure changes not just aerodynamic forces on the >>>elevator. >>> >>>John >>> >>> >>>----- Original Message ----- >>>From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net> >>>To: >>>Subject: Re: RV-List: Auto Pilots >>> >>> >>> >>> >>> >>> >>>> >>>> >>>>Hopperdhh(at)aol.com wrote: >>>> >>>> >>>> >>>> >>>> >>>>> >>>>>Has anyone ever tried to use the electric trim servo for altitude hold? >>>>>I'm >>>>>not talking about rough air and turbulence, just normal VFR cross >>>>>country >>>>>flying. I was thinking of just giving the trim motor a little blip to >>>>>steer me >>>>>back to the right altitude. The pulse width could be proportional to >>>>>the >>>>>error. I would use a Motorola MC68HC11 processor since I have worked >>>>>with that >>>>>one for about 20 years. Pressure input would come from an automotive >>>>>type >>>>>barometric pressure sensor with enough amplification to get the error >>>>>signal >>>>>big enough for the processor to read it. >>>>> >>>>>Any thoughts? >>>>> >>>>>Dan Hopper >>>>>RV-7A (Flying) >>>>> >>>>> >>>>> >>>>> >>>>Keep us informed on this. >>>>Phil RV6 flying >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >> >> >> > > > > ________________________________________________________________________________
Date: Mar 10, 2005
VINCE- I know of one flying but not of a web sight-TOM Tom Whelan Whelan Farms Airport President EAA Chapter 1097 wfact01(at)aol.com 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 Tel: 203-266-5300 Fax: 202-266-5140 EAA Technical/Flight Advisor RV-8 IO- 540 LYC READY FOR SUN-100 40-PLUS HRS S-51 Mustang Turbine (Under Construction) ________________________________________________________________________________
Subject: Auto Pilots
Date: Mar 11, 2005
Grey Code outputs at 100' increments, Serial 10'. As far as an autopilot that controls Altitude via the trim, Chelton is already doing it. I know they have had some 'issues' but apparently have worked them out. Nick -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Bristol Subject: Re: RV-List: Auto Pilots Jim, I just did a quick Google search and found this quote. " Mode S has an altitude resolution of 25 ft, Mode C has an altitude resolution of 100 ft." I think that may be the standard, but that doesn't mean that the newer encoders couldn't have higher resolution. With that in mind, if you have a high resolution encoder, I don't see why it wouldn't be an acceptable source for autopilot altitude information. Dave Jim Jewell wrote: > >I'm told that if you have serial code output available such as the Dynon >D10A produces for instance, it will be in 10' resolution. >Is this True? > >Jim in Kelowna > >----- Original Message ----- >From: "Dave Bristol" <dbris200(at)sbcglobal.net> >To: >Subject: Re: RV-List: Auto Pilots > > > > >> >>But, the mode C output only has 100' resolution so you'd be all over the >>sky chasing it. On the other hand, GPS altitude might work pretty good. >>It's not very accurate but you don't care since all you want is to >>maintain your present altitude. GPS altitude doesn't change with >>barometric pressure so you'd have to keep an eye on it, but it should >>work. >> >>Dave -6 So Cal >> >>Stein Bruch wrote: >> >> >> >>> >>>Well that's not quite true....it has been done and it's been proven to >>>work. >>>Simple Altitude encoded information is all the trim system needs to know. >>>In reality it's not much different than a servo running an altitude >>>autopilot. >>> >>>I'm not saying it works well or is good, but it has and will work to some >>>extent. It's just a slimmed down "Altitude hold" on a diet! >>> >>>Cheers, >>>Stein. >>> >>>-----Original Message----- >>>From: owner-rv-list-server(at)matronics.com >>>[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of John >>>To: rv-list(at)matronics.com >>>Subject: Re: RV-List: Auto Pilots >>> >>> >>> >>>It won't work...I had that dream some time ago...how would electric trim >>>"know" if you were descending or climbing a bit ? It wouldn't. You need >>>some >>>input regarding pressure changes not just aerodynamic forces on the >>>elevator. >>> >>>John >>> >>> >>>----- Original Message ----- >>>From: "Phil Sisson, Litchfield Aerobatic Club" >>>To: >>>Subject: Re: RV-List: Auto Pilots >>> >>> >>> >>> >>> >>> Club" >>>> >>>> >>>>Hopperdhh(at)aol.com wrote: >>>> >>>> >>>> >>>> >>>> >>>>> >>>>>Has anyone ever tried to use the electric trim servo for altitude hold? >>>>>I'm >>>>>not talking about rough air and turbulence, just normal VFR cross >>>>>country >>>>>flying. I was thinking of just giving the trim motor a little blip to >>>>>steer me >>>>>back to the right altitude. The pulse width could be proportional to >>>>>the >>>>>error. I would use a Motorola MC68HC11 processor since I have worked >>>>>with that >>>>>one for about 20 years. Pressure input would come from an automotive >>>>>type >>>>>barometric pressure sensor with enough amplification to get the error >>>>>signal >>>>>big enough for the processor to read it. >>>>> >>>>>Any thoughts? >>>>> >>>>>Dan Hopper >>>>>RV-7A (Flying) >>>>> >>>>> >>>>> >>>>> >>>>Keep us informed on this. >>>>Phil RV6 flying >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >> >> >> > > > > -- Checked by AVG Anti-Virus. -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Date: Mar 11, 2005
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Looking for FWF photos.
Hi all: I'm looking for any and all tips and tricks for everything firewall forward (wiring, plumbing, etc.). If you have a website with pictures of things under the engine cowl could you please send me your web addresses off-list? I'd like to look at as many as possible, it should save time and frustration and give me some ideas. Thanks. Dean Psiropoulos RV-6A N197DM Into the home stretch ________________________________________________________________________________
Subject: White Letters for Panel
Date: Mar 11, 2005
OK, I have the day off and ready to go out and buy a label maker suitable for the panel. Can someone give me the final answer to the age old question on what make/model of label maker & label paper it takes to print out quality labels with white letters that will actually stick to the panel paint over time? Prefer one I just run to to Staples or Office Max and pick up. BTW, has anyone tried this trick I saved from prior email and does it work? You can trick an ink jet to print white. Type the text. Convert the text to a 1 Bit (black and White) immage. Use an immage processing package (Photoshop, or many others) to reverse the colors. Print the immage on white paper. The printer will print a black background and leave the text blank. thx, lucky OK, I have the day off and ready to go out and buy a label maker suitable for the panel. Can someone give me the final answer to the age old question on what make/model of label maker label paper it takes to print out quality labels with white letters that will actually stick to the panel paint over time? Prefer one I just run to to Staples or Office Max and pick up. BTW, has anyone tried this trick I saved from prior email and does it work? You can trick an ink jet to print white. Type the text. Convert the text to a 1 Bit (black and White) immage. Use an immage processing package (Photoshop, or many others) to reverse the colors. Print the immage on white paper. The printer will print a black background and leave the text blank. thx, lucky ________________________________________________________________________________
Subject: Dyaton experimental race, July 24th
Date: Mar 11, 2005
I was wondering if any of our group plans to run in this race, especially any of the formation folks as they would have the requisite skills. (Mike, the super 8 gonna be ready by then?) I think it might be fun, but in my 150hp FP, it would be prop wash city for me :-) charlie heathco ________________________________________________________________________________
Date: Mar 11, 2005
From: "Lapsley R & Sandra E. Caldwell" <caldwel(at)ictransnet.com>
Subject: Bob Archer's Email/website
Does any one have a website or email for Bob Archer?. A google search does not find one. Roger ________________________________________________________________________________
Date: Mar 11, 2005
Subject: Re: White Letters for Panel
I have a $50 Brother that I got at Office Depot. I use the black tape with white letters. None of them have fallen off in almost 3 years, and it is quick and easy. John RV8 lucky wrote: > >OK, I have the day off and ready to go out and buy a label maker suitable for the panel. Can someone give me the final answer to the age old question on what make/model of label maker & label paper it takes to print out quality labels with white letters that will actually stick to the panel paint over time? Prefer one I just run to to Staples or Office Max and pick up. > >BTW, has anyone tried this trick I saved from prior email and does it work? > >You can trick an ink jet to print white. > > Type the text. > Convert the text to a 1 Bit (black and White) immage. > Use an immage processing package (Photoshop, or many others) to > reverse the colors. > Print the immage on white paper. > The printer will print a black background and leave the > text blank. > >thx, >lucky > >OK, I have the day off and ready to go out and buy a label maker suitable for the panel. Can someone give me the final answer to the age old question on what make/model of label maker label paper it takes to print out quality labels with white letters that will actually stick to the panel paint over time? Prefer one I just run to to Staples or Office Max and pick up. > >BTW, has anyone tried this trick I saved from prior email and does it work? > >You can trick an ink jet to print white. > > Type the text. > Convert the text to a 1 Bit (black and White) immage. > Use an immage processing package (Photoshop, or many others) to > reverse the colors. > Print the immage on white paper. > The printer will print a black background and leave the > text blank. > >thx, >lucky > > > > ________________________________________________________________________________
Date: Mar 11, 2005
Any particular style/brand of tape? Never used before. Does it matter whether it's laser to cartridge style printer? -------------- Original message -------------- > > I have a $50 Brother that I got at Office Depot. I use the black tape > with white letters. None of them have fallen off in almost 3 years, and > it is quick and easy. > > John > RV8 > > lucky wrote: > > > > >OK, I have the day off and ready to go out and buy a label maker suitable for > the panel. Can someone give me the final answer to the age old question on what > make/model of label maker & label paper it takes to print out quality labels > with white letters that will actually stick to the panel paint over time? > Prefer one I just run to to Staples or Office Max and pick up. > > > >BTW, has anyone tried this trick I saved from prior email and does it work? > > > >You can trick an ink jet to print white. > > > > Type the text. > > Convert the text to a 1 Bit (black and White) immage. > > Use an immage processing package (Photoshop, or many others) to > > reverse the colors. > > Print the immage on white paper. > > The printer will print a black background and leave the > > text blank. > > > >thx, > >lucky > > > >OK, I have the day off and ready to go out and buy a label maker suitable for > the panel. Can someone give me the final answer to the age old question on what > make/model of label maker label paper it takes to print out quality labels with > white letters that will actually stick to the panel paint over time? Prefer one > I just run to to Staples or Office Max and pick up. > > > >BTW, has anyone tried this trick I saved from prior email and does it work? > > > >You can trick an ink jet to print white. > > > > Type the text. > > Convert the text to a 1 Bit (black and White) immage. > > Use an immage processing package (Photoshop, or many others) to > > reverse the colors. > > Print the immage on white paper. > > The printer will print a black background and leave the > > text blank. > > > >thx, > >lucky > > > > > > > > > > > > > > Any particular style/brand of tape? Never used before. Does it matter whether it's laser to cartridge style printer? -------------- Original message -------------- -- RV-List message posted by: John Huft I have a $50 Brother that I got at Office Depot. I use the black tape with white letters. None of them have fallen off in almost 3 years, and it is quick and easy. John RV8 lucky wrote: -- RV-List message posted by: luckymacy(at)comcast.net (lucky) OK, I have the day off and ready to go out and buy a label maker suitable for the panel. Can someone give me the final answer to the age old question on what make/model of label maker label paper it takes to print out quality labels with white letters that will actually stick to the panel paint over time? Prefer one I just run to to Staples or Office Max and pick up. BTW, has anyone tried this trick I saved from prior email and does it work? You can trick an ink jet to print white. Type the text. Convert the text to a 1 Bit (black and White) immage. Use an immage processing package (Photoshop, or many others) to reverse the colors. Print the immage on white paper. The printer will print a black background and leave the text blank. thx, lucky OK, I have the day off and ready to go out and buy a label maker suitable for the panel. Can someone give me the final answer to the age old question on what make/model of label maker label paper it takes to print out quality labels with white letters that will actually stick to the panel paint over time? Prefer one I just run to to Staples or Office Max and pick up. BTW, has anyone tried this trick I saved from prior email and does it work? You can trick an ink jet to print white. Type the text. Convert the text to a 1 Bit (black and White) immage. Use an immage processing package (Photoshop, or many others) to reverse the colors. Print the immage on white paper. The printer will print a black background and leave the text blank. thx, lucky =============================================================== ________________________________________________________________________________
Date: Mar 11, 2005
Subject: Re: LASAR/elecr ign
I put about 200 hours on a LASAR system, so here are some more opinions... Alex, how do you know about the 15 minutes with no advance? I never saw any sign of this with mine, it always started overheating right away. I think you just saw that it doesn't advance the timing much at low altitude and full throttle. Since I am based at 7650 msl, and only get about 22.5" map on takeoff, my LASAR would think I was at cruise, advance the timing, and overheat on initial climbout. I did what Randy says, used a breaker switch so I could shut it off. I also had to shut it off on any hot summer day in cruise, trying to keep CHTs below 400. My new Lightspeed system does not suffer from any of this, and CHTs are about 30 dF cooler than before in any given condition. I also suffered a left mag failure at 5 hours. It was replaced promptly by Unison. Last year, my hangar neighbor made his first engine run with his LASAR system, and the "brain box" was dead. It took 3 weeks to get straighted out. Unison wants everyone to go through their dealer for service now. Harry Fenton was the greatest but he has left Unison. The problem I have with the LASAR system is that it is nothing more than a standard mag with variable timing. The spark is no hotter. The reliability is worse, since it has all the weaknesses of the mag, plus the electronic failure modes. Now I have a dual Lightspeed ignition with the crank pickup...no moving parts. Automotive spark plugs ($1.35 each). Much hotter spark, especially at idle. Easier hot starts (fuel injection). I only have about 40 hours on this system, so only time will tell of course as far as overall reliability. John Huft more opinions at http://www.lazy8.net/EI.htm Alex Peterson wrote: > > > > >>My advice is to install your LASAR on a breaker switch near >>the master >>switch so it can be turned off. The simply fact is that your >>engine will run >>hotter with LASAR because it's buring the fuel/air charge >>more efficiently >>in the combustion chamber, not in the exhaust system. >>Therefore you need to >>be aware of it. On my RV-8 I learned to turn the system off >>for a long >>climbout on a hot day, then switch it back on once leveled >>off. Now my RV-8 >> >> > >I have 584 hours on my Lasar system now over the last 3.5 years, and here >are some thoughts: Regarding what Randy has written above, the system does >not advance past the baseline 25 degrees for the first 15 minutes of >operation, allowing for a pretty good taxi and climbout for an RV. I don't >believe any of the other EI's do this, and I can't say how much difference >it really makes. One does need to be aware of this, as fine tuning mixture >settings for cruise should wait until this period is expired. > >Reliability wise I have had two failures. At 342 hours, the left mag died. >It was detected by a higher than normal EGT noted during a 40 minute flight, >and the mag check on the return showed that the left mag was sick (not dead, >but not good either). Unison sent another mag free of charge next day to >me, excellent service. I left for the west coast the next day, and was >thinking about that new mag when over the Rocky Mountains.... At 569 hours, >during cruise flight, the engine hesitated (this tends to get one's >attention) for perhaps 1/4 second, then recovered. The fault light was on >indicating the system was in backup mode (mags running). Once over an >airport, I checked the L/R mags, and the left was completely dead (one tends >to move the switch back quite rapidly when the engine completely stops >firing). Once again, Unison replaced it with a brand new one free of >charge, although this took a couple weeks this time. I suspect if I had >been on the road, they would have overnighted one. I never did learn what >the failure was on the first mag, but the recent failure was caused by a >broken rotor. > >So, overall, Unison really sticks behind their product, but two failures of >two different left mags is a little troubling. Ignition systems are not yet >trouble free - anyone's. One person here had to rebuild a lot of his cowl >and baffling when an encoder wheel came off inside his Electroair during >startup. Others have had problems with Lightspeed. It is impossible to say >with any accuracy what anyone's system's reliability is. > >Given the performance afforded by EI, mainly fuel economy, I would not be >interested in running my plane on standard mags. > >Alex Peterson >RV6-A 584 hours >Maple Grove, MN > >http://www.home.earthlink.net/~alexpeterson/ > > > > ________________________________________________________________________________
Subject: Re: Bob Archer's Email/website
Date: Mar 11, 2005
bobsantennas(at)earthlink.net ----- Original Message ----- From: "Lapsley R & Sandra E. Caldwell" <caldwel(at)ictransnet.com> Subject: RV-List: Bob Archer's Email/website > > > Does any one have a website or email for Bob Archer?. A google search > does not find one. > > Roger > > > ________________________________________________________________________________
Date: Mar 11, 2005
Brother's P-Touch . . . has a white on clear tape . . . I have one but haven't used it yet. > > Any particular style/brand of tape? Never used before. Does it matter whether it's laser to cartridge style printer? > > -------------- Original message -------------- > > > > > I have a $50 Brother that I got at Office Depot. I use the black tape > > with white letters. None of them have fallen off in almost 3 years, and > > it is quick and easy. > > > > John > > RV8 > > > > lucky wrote: > > > > > > > >OK, I have the day off and ready to go out and buy a label maker suitable for > > the panel. Can someone give me the final answer to the age old question on what > > make/model of label maker & label paper it takes to print out quality labels > > with white letters that will actually stick to the panel paint over time? > > Prefer one I just run to to Staples or Office Max and pick up. > > > > > >BTW, has anyone tried this trick I saved from prior email and does it work? > > > > > >You can trick an ink jet to print white. > > > > > > Type the text. > > > Convert the text to a 1 Bit (black and White) immage. > > > Use an immage processing package (Photoshop, or many others) to > > > reverse the colors. > > > Print the immage on white paper. > > > The printer will print a black background and leave the > > > text blank. > > > > > >thx, > > >lucky > > > > > >OK, I have the day off and ready to go out and buy a label maker suitable for > > the panel. Can someone give me the final answer to the age old question on what > > make/model of label maker label paper it takes to print out quality labels with > > white letters that will actually stick to the panel paint over time? Prefer one > > I just run to to Staples or Office Max and pick up. > > > > > >BTW, has anyone tried this trick I saved from prior email and does it work? > > > > > >You can trick an ink jet to print white. > > > > > > Type the text. > > > Convert the text to a 1 Bit (black and White) immage. > > > Use an immage processing package (Photoshop, or many others) to > > > reverse the colors. > > > Print the immage on white paper. > > > The printer will print a black background and leave the > > > text blank. > > > > > >thx, > > >lucky > > > > > > > > > > > > > > > > > > > > > > > > > > Any particular style/brand of tape? Never used before. Does it matter whether it's laser to cartridge style printer? > > -------------- Original message -------------- > > -- RV-List message posted by: John Huft > > I have a $50 Brother that I got at Office Depot. I use the black tape > with white letters. None of them have fallen off in almost 3 years, and > it is quick and easy. > > John > RV8 > > lucky wrote: > > -- RV-List message posted by: luckymacy(at)comcast.net (lucky) > > OK, I have the day off and ready to go out and buy a label maker suitable for > the panel. Can someone give me the final answer to the age old question on what > make/model of label maker label paper it takes to print out quality labels > with white letters that will actually stick to the panel paint over time? > Prefer one I just run to to Staples or Office Max and > pick up. > > BTW, has anyone tried this trick I saved from prior email and does it work? > > You can trick an ink jet to print white. > > Type the text. > Convert the text to a 1 Bit (black and White) immage. > Use an immage processing package (Photoshop, or many others) to > reverse the colors. > Print the immage on white paper. > The printer will print a black background and leave the > text blank. > > thx, > lucky > > OK, I have the day off and ready to go out and buy a label maker suitable for > the panel. Can someone give me the final answer to the age old question on what > make/model of label maker label paper it takes to print out quality labels with > white letters that will actually stick to the panel paint over time? Prefer one > I just run > to to Staples or Office Max and pick up. > > BTW, has anyone tried this trick I saved from prior email and does it work? > > You can trick an ink jet to print white. > > Type the text. > Convert the text to a 1 Bit (black and White) immage. > Use an immage processing package (Photoshop, or many others) to > reverse the colors. > Print the immage on white paper. > The printer will print a black background and leave the > text blank. > > thx, > lucky > > ============================================================== > > > ________________________________________________________________________________
Date: Mar 11, 2005
You just buy a tape cartridge that fits the label maker. They have different styles, white letters on black, black on clear, etc. It is all automatic after that. John lucky wrote: > >Any particular style/brand of tape? Never used before. Does it matter whether it's laser to cartridge style printer? > >-------------- Original message -------------- > > > >> >>I have a $50 Brother that I got at Office Depot. I use the black tape >>with white letters. None of them have fallen off in almost 3 years, and >>it is quick and easy. >> >>John >>RV8 >> >>lucky wrote: >> >> >> >>> >>>OK, I have the day off and ready to go out and buy a label maker suitable for >>> >>> >>the panel. Can someone give me the final answer to the age old question on what >>make/model of label maker & label paper it takes to print out quality labels >>with white letters that will actually stick to the panel paint over time? >>Prefer one I just run to to Staples or Office Max and pick up. >> >> >>>BTW, has anyone tried this trick I saved from prior email and does it work? >>> >>>You can trick an ink jet to print white. >>> >>>Type the text. >>>Convert the text to a 1 Bit (black and White) immage. >>>Use an immage processing package (Photoshop, or many others) to >>>reverse the colors. >>>Print the immage on white paper. >>>The printer will print a black background and leave the >>>text blank. >>> >>>thx, >>>lucky >>> >>>OK, I have the day off and ready to go out and buy a label maker suitable for >>> >>> >>the panel. Can someone give me the final answer to the age old question on what >>make/model of label maker label paper it takes to print out quality labels with >>white letters that will actually stick to the panel paint over time? Prefer one >>I just run to to Staples or Office Max and pick up. >> >> >>>BTW, has anyone tried this trick I saved from prior email and does it work? >>> >>>You can trick an ink jet to print white. >>> >>>Type the text. >>>Convert the text to a 1 Bit (black and White) immage. >>>Use an immage processing package (Photoshop, or many others) to >>>reverse the colors. >>>Print the immage on white paper. >>>The printer will print a black background and leave the >>>text blank. >>> >>>thx, >>>lucky >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > >Any particular style/brand of tape? Never used before. Does it matter whether it's laser to cartridge style printer? > >-------------- Original message -------------- > > -- RV-List message posted by: John Huft > > I have a $50 Brother that I got at Office Depot. I use the black tape > with white letters. None of them have fallen off in almost 3 years, and > it is quick and easy. > > John > RV8 > > lucky wrote: > > -- RV-List message posted by: luckymacy(at)comcast.net (lucky) > > OK, I have the day off and ready to go out and buy a label maker suitable for > the panel. Can someone give me the final answer to the age old question on what > make/model of label maker label paper it takes to print out quality labels > with white letters that will actually stick to the panel paint over time? > Prefer one I just run to to Staples or Office Max and > pick up. > > BTW, has anyone tried this trick I saved from prior email and does it work? > > You can trick an ink jet to print white. > > Type the text. > Convert the text to a 1 Bit (black and White) immage. > Use an immage processing package (Photoshop, or many others) to > reverse the colors. > Print the immage on white paper. > The printer will print a black background and leave the > text blank. > > thx, > lucky > > OK, I have the day off and ready to go out and buy a label maker suitable for > the panel. Can someone give me the final answer to the age old question on what > make/model of label maker label paper it takes to print out quality labels with > white letters that will actually stick to the panel paint over time? Prefer one > I just run > to to Staples or Office Max and pick up. > > BTW, has anyone tried this trick I saved from prior email and does it work? > > You can trick an ink jet to print white. > > Type the text. > Convert the text to a 1 Bit (black and White) immage. > Use an immage processing package (Photoshop, or many others) to > reverse the colors. > Print the immage on white paper. > The printer will print a black background and leave the > text blank. > > thx, > lucky > > > =============================================================== > > > > ________________________________________________________________________________
Date: Mar 11, 2005
Some of the label makers offer the ability to use different widths of tape, easily up to one inch wide. One of the advantages of this wide tape is that some units can print multiple lines on the tape. Some offer the ability to specify a "box" around the print which looks more professional or finished, and multiple fonts so you can choose one that is easy for you to read. Look at the features and chose the best machine, not the cheapest... and like any of these products, the manufacturer is selling the machine to you at below the cost of producing it, and then stabbing you for the supplies. The replacement cartridges can add up to a significant amount of money. For this project that's probably not a factor, but make sure that you can easily purchase the different styles or colors of cartridges in your area. Good luck, Dave ----- Original Message ----- From: "John Huft" <rv8(at)lazy8.net> Subject: Re: RV-List: White Letters for Panel > > You just buy a tape cartridge that fits the label maker. They have > different styles, white letters on black, black on clear, etc. It is all > automatic after that. > > John > > lucky wrote: > > > > >Any particular style/brand of tape? Never used before. Does it matter whether it's laser to cartridge style printer? > > > >-------------- Original message -------------- > > > > > > > >> > >>I have a $50 Brother that I got at Office Depot. I use the black tape > >>with white letters. None of them have fallen off in almost 3 years, and > >>it is quick and easy. > >> > >>John > >>RV8 > >> > >>lucky wrote: > >> > >> > >> > >>> > >>>OK, I have the day off and ready to go out and buy a label maker suitable for > >>> > >>> > >>the panel. Can someone give me the final answer to the age old question on what > >>make/model of label maker & label paper it takes to print out quality labels > >>with white letters that will actually stick to the panel paint over time? > >>Prefer one I just run to to Staples or Office Max and pick up. > >> > >> > >>>BTW, has anyone tried this trick I saved from prior email and does it work? > >>> > >>>You can trick an ink jet to print white. > >>> > >>>Type the text. > >>>Convert the text to a 1 Bit (black and White) immage. > >>>Use an immage processing package (Photoshop, or many others) to > >>>reverse the colors. > >>>Print the immage on white paper. > >>>The printer will print a black background and leave the > >>>text blank. > >>> > >>>thx, > >>>lucky > >>> > >>>OK, I have the day off and ready to go out and buy a label maker suitable for > >>> > >>> > >>the panel. Can someone give me the final answer to the age old question on what > >>make/model of label maker label paper it takes to print out quality labels with > >>white letters that will actually stick to the panel paint over time? Prefer one > >>I just run to to Staples or Office Max and pick up. > >> > >> > >>>BTW, has anyone tried this trick I saved from prior email and does it work? > >>> > >>>You can trick an ink jet to print white. > >>> > >>>Type the text. > >>>Convert the text to a 1 Bit (black and White) immage. > >>>Use an immage processing package (Photoshop, or many others) to > >>>reverse the colors. > >>>Print the immage on white paper. > >>>The printer will print a black background and leave the > >>>text blank. > >>> > >>>thx, > >>>lucky > >>> > >>> > >>> > >>> > >>> > >>> > >> > >> > >> > >> > >> > >> > > > >Any particular style/brand of tape? Never used before. Does it matter whether it's laser to cartridge style printer? > > > >-------------- Original message -------------- > > > > -- RV-List message posted by: John Huft > > > > I have a $50 Brother that I got at Office Depot. I use the black tape > > with white letters. None of them have fallen off in almost 3 years, and > > it is quick and easy. > > > > John > > RV8 > > > > lucky wrote: > > > > -- RV-List message posted by: luckymacy(at)comcast.net (lucky) > > > > OK, I have the day off and ready to go out and buy a label maker suitable for > > the panel. Can someone give me the final answer to the age old question on what > > make/model of label maker label paper it takes to print out quality labels > > with white letters that will actually stick to the panel paint over time? > > Prefer one I just run to to Staples or Office Max and > > pick up. > > > > BTW, has anyone tried this trick I saved from prior email and does it work? > > > > You can trick an ink jet to print white. > > > > Type the text. > > Convert the text to a 1 Bit (black and White) immage. > > Use an immage processing package (Photoshop, or many others) to > > reverse the colors. > > Print the immage on white paper. > > The printer will print a black background and leave the > > text blank. > > > > thx, > > lucky > > > > OK, I have the day off and ready to go out and buy a label maker suitable for > > the panel. Can someone give me the final answer to the age old question on what > > make/model of label maker label paper it takes to print out quality labels with > > white letters that will actually stick to the panel paint over time? Prefer one > > I just run > > to to Staples or Office Max and pick up. > > > > BTW, has anyone tried this trick I saved from prior email and does it work? > > > > You can trick an ink jet to print white. > > > > Type the text. > > Convert the text to a 1 Bit (black and White) immage. > > Use an immage processing package (Photoshop, or many others) to > > reverse the colors. > > Print the immage on white paper. > > The printer will print a black background and leave the > > text blank. > > > > thx, > > lucky > > > > > > ============================================================== > > > > > > > > > > ________________________________________________________________________________
Date: Mar 11, 2005
Subject: Re: Auto Pilots
Mickey and Stein, That's a good suggestion, especially if one were to go inside the encoder and tap off the data before it goes to the EPROM that encodes it into the grey code. I have traced out the circuit of both the Ameri-King and the ACK encoders, and they are practically identical. In fact, the pinouts of the 15 pin connecters are the same. There must be a story there. I don't have a Dynon, etc., so have to use the old technology stuff. Greater resolution can be had by buffering the raw digital data and using it. Only the LS 8 bits would be needed, probably, since we just want to HOLD altitude. It would be a good idea to use a separate encoder, so that the one being used for Mode-C could remain legal. Thanks, Stein, for the link to EZ-Trim. It says on the web site that he doesn't have time to build them and is supplying boards and software for whoever wants to build it. I will look over his algorithm, if possible, from the download. I am just looking for a microprocessor project, not necessarily the ultimate in altitude hold autopilot. Since I am familiar with Motorola 68HC11 and have lots of them, would not want to go with the PIC, at this time anyway. When I get tired of playing around I'll take your advice and just buy one. Thanks, to everyone else who replied. Sorry to change the subject like that. I should have started a new thread. Regards, Dan Hopper Walton IN RV-7A (Flying) In a message dated 3/10/05 4:35:32 P.M. US Eastern Standard Time, mick-matronics(at)rv8.ch writes: Couldn't you slurp the altitude information from your altitude encoder before you send it to the transponder? > ... Pressure input would come from an automotive type > barometric pressure sensor with enough amplification to get the error signal > big enough for the processor to read it. > -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
From: "Karen and Robert Brown" <bkbrown(at)ashcreekwireless.com>
Subject: Re: Odyssey Battery Installation Kit
Date: Mar 11, 2005
The Odyssey battery install kit from Van's includes a nice spot-welded steel battery enclosure (which you drill lightening holes in), a .125 alum bar you fab into a hold-down bracket, some powder coated angle steel mounting brackets which are predrilled for nutplates, some aluminum tubing for spacers on the hold-down bar and some nutplates. It really is a very secure assy which goes together and mounts quickly. I recommend it. Not that you couldn't make your own, but for what you get it's a nice package. For some pictures you can check out mine at: brownsrv7a.net/batteryboxmounted.htm or check out Dan's site at: rvproject.com/20030228.html Bob Brown RV7A - wiring/canopy ________________________________________________________________________________
Date: Mar 11, 2005
Subject: Wheel pants
Hi, I'm very "glass challenged", which is why I'm building an aluminum airplane. Anyone have any special tricks for doing the wheel pants? I'm kind of surprised that they really don't mate up very well at all. I have no idea what the manufacturing process for these items is, but it seems strange that two halves would not share a common cut. Any tips and tricks would be most appreciated! Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
Date: Mar 11, 2005
I use a Brother PT-1950. Using 3/4" black tape, white letters and up to 4 lines of framed print, it makes outstanding placards that I have used to identify components all over the airframe, including firewall forward. These electronic labelers enable you to adjust the size, font and other tools commonly found in your computer Word program. I'm told you can even download and print images via a supplied USB cable. I used smaller width tape to identify dozens upon dozens of electrical wires. Brother claims the tapes will hold up to harsh industrial conditions......we shall see. FYI, the replacement cassette tapes can be expensive. Other than the generic white tape with black print, I find it difficult to buy many of available widths and colors locally. Brother's on-line store wanted $30 for the aforementioned 3/4" black tape. I recently bought a copy at Amazon.com for about $16.00. It pays to shop around. Rick Galati RV-6A "Darla" ________________________________________________________________________________
Date: Mar 11, 2005
Subject: Re: Dyaton experimental race, July 24th
I will be there. No formation skills required. It is lots of fun, it doesn't matter where you finish (well, maybe a little). John Huft Race 13 "Nuisance" Charles Heathco wrote: > >I was wondering if any of our group plans to run in this race, especially any of the formation folks as they would have the requisite skills. (Mike, the super 8 gonna be ready by then?) I think it might be fun, but in my 150hp FP, it would be prop wash city for me :-) charlie heathco > > >. > > > ________________________________________________________________________________
Subject: Re: Prop replacement, question for Das Fed, was:
Date: Mar 11, 2005
I don't know who you are but you are mis-informed. Anybody may do the maintenance, major, minor, or otherwise, on an experimental amateur-built aircraft. The only time a "certificated" person must become involved is for the yearly condition inspection. That's its. There is nothing else. FAR 43 says right at the start that this section does not apply to Experimental aircraft. Therefore the only thing governing the maintenance of an amateur-built aircraft is the aircraft's operating limitations. Mike Robertson >From: <gmcjetpilot(at)yahoo.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Prop replacement, question for Das Fed, was: Date: > > >Mike: > >You are opening a can of worms :- ) The buyer of an experimental aircraft >can only do routine maintenance, as if it were a Piper or Cessna, as far as >I know. Only the manufacture (builder/repairman) can make major mods, >however I assume(?) an A&P or AI could do it and with the FAA's blessing. >Again, as in all these matters refer to the FISDO of choice for the answer. >There is no "type certificate" configuration for exp a/c, so many changes >slip thru the cracks and are not tracked by the FAA. Anyone who has a >second hand RV may find them self in a regulatory mess if they want to make >a major changes. The best (easiest) thing would get the builder to sign the >mod off if possible. However that is one of the fantastic reasons for >building your own plane. > >Cheers George > > > > > > Mike, > > > > I have a question related to this very activity ... and am asking not > > so much for myself (I'm still building), but just to satisfy my >curiosity. > > > >I have had the impression that all these suggestions and requirements > > have been tendered with the idea that the person doing the work is the > > builder and has a repairman's certificate for the aircraft. However, >what are > > the rules/regs for someone who does NOT have the repairmans certificate >and > > who is NOT an A/P? Somehow I can't imagine that they would be in a >position > > to change their prop, put it into phase 1, perform the flight testing, >and > > sign it off putting it back in phase 2. Or can they? > > >--------------------------------- > > ________________________________________________________________________________
Date: Mar 11, 2005
On 03/11 7:56, Karen and Robert Brown wrote: > > The Odyssey battery install kit from Van's includes a nice spot-welded steel battery enclosure (which you drill lightening holes in), a .125 alum bar you fab into a hold-down bracket, some powder coated angle steel mounting brackets which are predrilled for nutplates, some aluminum tubing for spacers on the hold-down bar and some nutplates. It really is a very secure assy which goes together and mounts quickly. I recommend it. Not that you couldn't make your own, but for what you get it's a nice package. For some pictures you can check out mine at: brownsrv7a.net/batteryboxmounted.htm > or check out Dan's site at: rvproject.com/20030228.html I made a modification to the Battery Box design from Vans. Vans design would have you slip the battery up and out of the box in order to replace it. This is a heavy battery with nothing to grab onto AND if you have anything mounted above the battery box, you may not have the clearance to remove the battery, ask me how I know... I made a quick modification which is to make the front panel of the box removable so the battery just pops out the front. I used hinges on each side to retain the front of the box. It works very well and is simple to do. http://www.rv7-a.com/firewall_finish.htm#battery box mods -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: Mar 11, 2005
Cy, If I may. The yearly condiction inspection is to determine if the aircraft is safe to operate. I know it is a play on terms but from the FAA point of view we say that the aircraft is never airworthy because it has not been evaluated and issued an type certificate, only that it is "safe to operate". Other than that you are entirely correct. Mike R. >From: "cgalley" <cgalley(at)qcbc.org> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: Prop replacement, question for Das Fed, was: >Date: Thu, 10 Mar 2005 16:07:38 -0600 > > >I've looked the statement that the owner can do no more than he can on >certified. >This is FLAT OUT WRONG. > > Anyone can work on an experimental. > >One caveat and even this might be wrong. At the yearly conditional >inspection, the work has to be good enough to get the plane signed off as >airworthy. > >Cy Galley >EAA Safety Programs Editor >Always looking for ideas and articles for EAA Sport Pilot > > >----- Original Message ----- >From: "Dave Bristol" <dbris200(at)sbcglobal.net> >To: >Subject: Re: RV-List: Prop replacement, question for Das Fed, was: > > > > > > Anyone can work on a homebuilt aircraft including a trained chimp or > > your dog. You just have to have the condition inspection signed off by > > an A&P or AI. > > > > Dave > > > > gmcjetpilot(at)yahoo.com wrote: > > > >> > >> > >>Mike: > >> > >>You are opening a can of worms :- ) The buyer of an experimental >aircraft > >>can only do routine maintenance, as if it were a Piper or Cessna, as far > >>as I know. Only the manufacture (builder/repairman) can make major mods, > >>however I assume(?) an A&P or AI could do it and with the FAA's >blessing. > >>Again, as in all these matters refer to the FISDO of choice for the > >>answer. There is no "type certificate" configuration for exp a/c, so >many > >>changes slip thru the cracks and are not tracked by the FAA. Anyone who > >>has a second hand RV may find them self in a regulatory mess if they >want > >>to make a major changes. The best (easiest) thing would get the builder >to > >>sign the mod off if possible. However that is one of the fantastic >reasons > >>for building your own plane. > >> > >>Cheers George > >> > >> > >> > >> > >>> > >>>Mike, > >>> > >>>I have a question related to this very activity ... and am asking not > >>>so much for myself (I'm still building), but just to satisfy my > >>>curiosity. > >>> > >>>I have had the impression that all these suggestions and requirements > >>>have been tendered with the idea that the person doing the work is the > >>>builder and has a repairman's certificate for the aircraft. However, >what > >>>are > >>>the rules/regs for someone who does NOT have the repairmans certificate > >>>and > >>>who is NOT an A/P? Somehow I can't imagine that they would be in a > >>>position > >>>to change their prop, put it into phase 1, perform the flight testing, > >>>and > >>>sign it off putting it back in phase 2. Or can they? > >>> > >>> > >> > >> > >> > >>--------------------------------- > >> > >> > >> > >> > > > > > > > > ________________________________________________________________________________
Date: Mar 11, 2005
> >I am currently playing with a design for a heading hold -wing leveler. I >have the electronic components mocked up in a electronic simulation (PSPICE) >at this point. I am still debating whether to go with the analog approach >or the digital using a PIC Microchip. The digital clearly offers more move >for growth and change but the complexity of the algorithms are a bit much. >The analog looks to be more straight forward - but with limited growth >capability. You can easily find PID code for the PIC or nearly any other embedded controller. Use that stock code as the core for your system and you will save yourself a ton of programming and de-bugging work. > I am looking to make a simply (inexpensive) system that will start out as >an manual electric aileron trim and progress from there. I believe that a >Cascading set of simple OpAmp PID controllers looks to be the best bet (and >least expensive) for smooth operation. This is basically two control >loops - the outside loop would be comparing a heading signal to your set >heading the difference would generally a roll angle requirement this would >feed to the inside loop where the current roll angle would be compared to >the command roll and if a difference exists the inner list would generate a >roll rate command which would end up driving the servo. That makes sense. Feed in the rate sensor information to the inner loop to keep it stable and reduce the sensitivity to noise on the heading input. Easier to do digitally, by the way. > A small difference >in heading would generate a small roll rate and a larger difference a faster >roll rate (with limits of course - probably 15 deg max). Obviously quite a >bit more complex than this brief description - but that's the general idea. >The Unit is intended for VFR ONLY and will probably use a 1/3 scale model >aircraft servo. Would that have the torque needed? Also, how do you plan to clutch the servo to allow manual over-ride? ________________________________________________________________________________
Date: Mar 11, 2005
John & Alex, a few comments... Alex: I'm with John, I've never heard of the LASAR brain waiting 15 minutes to advance, where'd ya get that? John: a couple of updates to the comments made on your site: my understanding from Bart Lalonde is that all LASARs now come with an impluse coupling, formerly called the "bush kit" at no additional cost. Indeed, the system I just got on my IO-320 indeed has an impluse coupling on the right mag. Even the system on my RV-8 which was purchased in 1999 had it and I didn't specifically order it that way. I know because I could hear the clicking, and we did manage to hand prop it one day when my starter failed and we really wanted to go flying. Maybe Bart spec'd all his units that way, he is one of the their largest dealers. Also, you mention on your site that LASAR doesn't improve the strength/quality of the spark at low rpms -- au contraire, if it's engaged (not in fault mode) you get all the benefit of a very hot spark which is why it improves starting. Lastly, you and I both had occasional cooling issues that we learned to manage, but we also both had the Sam James cowling with reduced cooling inlets. I submit that the normal RV cowl would pass enough air to prevent this. Your 10-1 pistons didn't help in this area either.... ;-) All told, I'm still a LASAR fan, although I miss Harry Fenton. There is a new guy who took his place, Steve Carter, who Doug Reeves tells me has the right attitude. My advice to other builders who ask is to keep an eye on the E-mag product which looks to me like the best solution of all IF it works and IF the company supports it properly. Time will tell. Randy Lervold ----- Original Message ----- From: "John Huft" <rv8(at)lazy8.net> Subject: Re: RV-List: LASAR/elecr ign > > I put about 200 hours on a LASAR system, so here are some more opinions... > > Alex, how do you know about the 15 minutes with no advance? I never saw > any sign of this with mine, it always started overheating right away. I > think you just saw that it doesn't advance the timing much at low > altitude and full throttle. Since I am based at 7650 msl, and only get > about 22.5" map on takeoff, my LASAR would think I was at cruise, > advance the timing, and overheat on initial climbout. I did what Randy > says, used a breaker switch so I could shut it off. I also had to shut > it off on any hot summer day in cruise, trying to keep CHTs below 400. > > My new Lightspeed system does not suffer from any of this, and CHTs are > about 30 dF cooler than before in any given condition. > > I also suffered a left mag failure at 5 hours. It was replaced promptly > by Unison. Last year, my hangar neighbor made his first engine run with > his LASAR system, and the "brain box" was dead. It took 3 weeks to get > straighted out. Unison wants everyone to go through their dealer for > service now. Harry Fenton was the greatest but he has left Unison. > > The problem I have with the LASAR system is that it is nothing more than > a standard mag with variable timing. The spark is no hotter. The > reliability is worse, since it has all the weaknesses of the mag, plus > the electronic failure modes. > > Now I have a dual Lightspeed ignition with the crank pickup...no moving > parts. Automotive spark plugs ($1.35 each). Much hotter spark, > especially at idle. Easier hot starts (fuel injection). I only have > about 40 hours on this system, so only time will tell of course as far > as overall reliability. > > John Huft > more opinions at http://www.lazy8.net/EI.htm > > > Alex Peterson wrote: > >> >> >> >> >> >>>My advice is to install your LASAR on a breaker switch near >>>the master >>>switch so it can be turned off. The simply fact is that your >>>engine will run >>>hotter with LASAR because it's buring the fuel/air charge >>>more efficiently >>>in the combustion chamber, not in the exhaust system. >>>Therefore you need to >>>be aware of it. On my RV-8 I learned to turn the system off >>>for a long >>>climbout on a hot day, then switch it back on once leveled >>>off. Now my RV-8 >>> >>> >> >>I have 584 hours on my Lasar system now over the last 3.5 years, and here >>are some thoughts: Regarding what Randy has written above, the system >>does >>not advance past the baseline 25 degrees for the first 15 minutes of >>operation, allowing for a pretty good taxi and climbout for an RV. I >>don't >>believe any of the other EI's do this, and I can't say how much difference >>it really makes. One does need to be aware of this, as fine tuning >>mixture >>settings for cruise should wait until this period is expired. >> >>Reliability wise I have had two failures. At 342 hours, the left mag >>died. >>It was detected by a higher than normal EGT noted during a 40 minute >>flight, >>and the mag check on the return showed that the left mag was sick (not >>dead, >>but not good either). Unison sent another mag free of charge next day to >>me, excellent service. I left for the west coast the next day, and was >>thinking about that new mag when over the Rocky Mountains.... At 569 >>hours, >>during cruise flight, the engine hesitated (this tends to get one's >>attention) for perhaps 1/4 second, then recovered. The fault light was on >>indicating the system was in backup mode (mags running). Once over an >>airport, I checked the L/R mags, and the left was completely dead (one >>tends >>to move the switch back quite rapidly when the engine completely stops >>firing). Once again, Unison replaced it with a brand new one free of >>charge, although this took a couple weeks this time. I suspect if I had >>been on the road, they would have overnighted one. I never did learn what >>the failure was on the first mag, but the recent failure was caused by a >>broken rotor. >> >>So, overall, Unison really sticks behind their product, but two failures >>of >>two different left mags is a little troubling. Ignition systems are not >>yet >>trouble free - anyone's. One person here had to rebuild a lot of his cowl >>and baffling when an encoder wheel came off inside his Electroair during >>startup. Others have had problems with Lightspeed. It is impossible to >>say >>with any accuracy what anyone's system's reliability is. >> >>Given the performance afforded by EI, mainly fuel economy, I would not be >>interested in running my plane on standard mags. >> >>Alex Peterson >>RV6-A 584 hours >>Maple Grove, MN >> >>http://www.home.earthlink.net/~alexpeterson/ >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 11, 2005
BOB ARCHER 310-316-8796 bobsantennas(at)earthlink.net ANTENNAE FOR COMPOSITE SURFACES I know he was still in business as of a month ago, when I bought an antenna from him. Jeff Point > > ________________________________________________________________________________
Date: Mar 11, 2005
Another alternative if you have a color printer for your computer is to print white text onto clear labels. But it will give the area around the text a bit of a dull appearance. You won't have that crisp look. I did black on clear for my gray inerior. --- Rick Galati wrote: > > I use a Brother PT-1950. Using 3/4" black tape, white letters and up to 4 lines of framed > print, it makes outstanding placards that I have used to identify components all over the > airframe, including firewall forward. These electronic labelers enable you to adjust the size, > font and other tools commonly found in your computer Word program. I'm told you can even > download and print images via a supplied USB cable. I used smaller width tape to identify > dozens upon dozens of electrical wires. Brother claims the tapes will hold up to harsh > industrial conditions......we shall see. FYI, the replacement cassette tapes can be expensive. > Other than the generic white tape with black print, I find it difficult to buy many of > available widths and colors locally. Brother's on-line store wanted $30 for the aforementioned > 3/4" black tape. I recently bought a copy at Amazon.com for about $16.00. It pays to shop > around. > > Rick Galati RV-6A "Darla" > > > > > > > -- Scott VanArtsdalen RV-4 N311SV, FLYING!! When a man does all he can though it succeeds not well, blame not him that did it." -- George Washington ________________________________________________________________________________
Date: Mar 11, 2005
Some else pointed that out as well. My point still is that all maintenance needs to be done so the person that does the conditional will approve the plane's return to service. ----- Original Message ----- From: "Mike Robertson" <mrobert569(at)hotmail.com> Subject: Re: RV-List: Prop replacement, question for Das Fed, was: > > Cy, > > If I may. The yearly condiction inspection is to determine if the > aircraft > is safe to operate. I know it is a play on terms but from the FAA point > of > view we say that the aircraft is never airworthy because it has not been > evaluated and issued an type certificate, only that it is "safe to > operate". > Other than that you are entirely correct. > > Mike R. > >>From: "cgalley" <cgalley(at)qcbc.org> >>Reply-To: rv-list(at)matronics.com >>To: >>Subject: Re: RV-List: Prop replacement, question for Das Fed, was: >>Date: Thu, 10 Mar 2005 16:07:38 -0600 >> >> >>I've looked the statement that the owner can do no more than he can on >>certified. >>This is FLAT OUT WRONG. >> >> Anyone can work on an experimental. >> >>One caveat and even this might be wrong. At the yearly conditional >>inspection, the work has to be good enough to get the plane signed off as >>airworthy. >> >>Cy Galley >>EAA Safety Programs Editor >>Always looking for ideas and articles for EAA Sport Pilot >> >> >>----- Original Message ----- >>From: "Dave Bristol" <dbris200(at)sbcglobal.net> >>To: >>Subject: Re: RV-List: Prop replacement, question for Das Fed, was: >> >> >> > >> > Anyone can work on a homebuilt aircraft including a trained chimp or >> > your dog. You just have to have the condition inspection signed off by >> > an A&P or AI. >> > >> > Dave >> > >> > gmcjetpilot(at)yahoo.com wrote: >> > >> >> >> >> >> >>Mike: >> >> >> >>You are opening a can of worms :- ) The buyer of an experimental >>aircraft >> >>can only do routine maintenance, as if it were a Piper or Cessna, as >> >>far >> >>as I know. Only the manufacture (builder/repairman) can make major >> >>mods, >> >>however I assume(?) an A&P or AI could do it and with the FAA's >>blessing. >> >>Again, as in all these matters refer to the FISDO of choice for the >> >>answer. There is no "type certificate" configuration for exp a/c, so >>many >> >>changes slip thru the cracks and are not tracked by the FAA. Anyone >> >>who >> >>has a second hand RV may find them self in a regulatory mess if they >>want >> >>to make a major changes. The best (easiest) thing would get the builder >>to >> >>sign the mod off if possible. However that is one of the fantastic >>reasons >> >>for building your own plane. >> >> >> >>Cheers George >> >> >> >> >> >> >> >> >> >>> >> >>>Mike, >> >>> >> >>>I have a question related to this very activity ... and am asking not >> >>>so much for myself (I'm still building), but just to satisfy my >> >>>curiosity. >> >>> >> >>>I have had the impression that all these suggestions and requirements >> >>>have been tendered with the idea that the person doing the work is the >> >>>builder and has a repairman's certificate for the aircraft. However, >>what >> >>>are >> >>>the rules/regs for someone who does NOT have the repairmans >> >>>certificate >> >>>and >> >>>who is NOT an A/P? Somehow I can't imagine that they would be in a >> >>>position >> >>>to change their prop, put it into phase 1, perform the flight testing, >> >>>and >> >>>sign it off putting it back in phase 2. Or can they? >> >>> >> >>> >> >> >> >> >> >> >> >>--------------------------------- >> >> >> >> >> >> >> >> >> > >> > >> > >> >> > > > ________________________________________________________________________________
Subject: Spark Plug quality/source
Date: Mar 11, 2005
Hey, something else new for me to ponder over. Any quality difference between a champion plug for 20 bucks vs an Autolite for $16? I got to buy 9 (one spare just in case) so it adds up. But Champion is what used to be in the engine so.... What say you wise ones? BTW, is ACS the place most buy online and get the 5% AOPA discount? Van's doesn't sell 'em... thx, lucky Hey, something else new for me to ponder over. Any quality difference between a champion plug for 20 bucks vs an Autolite for $16? I got to buy 9 (one spare just in case) so it adds up. But Champion is what used to be in the engine so.... What say you wise ones? BTW, is ACS the place most buy online and get the 5% AOPA discount? Van's doesn't sell 'em... thx, lucky ________________________________________________________________________________
Date: Mar 11, 2005
Here's a phone number, 310-316-8796. Harry Crosby Pleasanton, California RV-6, flying!!! ________________________________________________________________________________
Date: Mar 11, 2005
Subject: Re: POP rivet static port
In a message dated 3/10/05 11:42:47 AM Pacific Standard Time, ghinman(at)mts.net writes: << When installing Van's static port pop rivets.Do you set the rivet or just glue it in place? It seems to me that if you set the rivet there will be not much to attach the tubing to. >> I had the same concern, so I looked around the local hardware store and found the same size rivets with a longer grip. I set those with a dab of proseal and also built up a fillet of proseal around the tubing after it was attached to the rivet. It is very secure. Harry Crosby Pleasanton, California RV-6, 40 hour test time complete, Yeeehaawww! ________________________________________________________________________________
Subject: Re: O-320 E2A for sale Phx, AZ
Date: Mar 11, 2005
Do You still have the engine? I am wintering here and have a friend that needs an engine for a RV9. Ralph Koger 480 464- 9718 2528 E McKellips Lot 134 Mesa, AZ -----Original Message----- From: tomvelvick(at)cox.net <tomvelvick(at)cox.net> Date: Wednesday, January 05, 2005 3:12 PM Subject: RV-List: O-320 E2A for sale Phx, AZ > > >O-320 E2A Lycoming Engine 2279 TTSN, first run, disassembled for overhaul. Crankshaft, Cam and Rods have been overhauled by Aircraft Specialities in Tulsa, Ok. Crankshaft has standard grind on rod and main bearings, was not turned down. Crankshaft and rods were also balanced to help the engine run smoother while at Aircraft Specialities. Does not include mags or starter (bendix and heavy old starter) unless you want them for a core, but does include the carburator. This engine has the hollow crank and can be set up for constant speed. Dynafocal mount. $5000.00 I was rebuilding this engine for my rv-6a project, but came across a O-360 A1A with 600 SMOH that I bought. Contact Tom Velvick 623-979-2519 home 623-261-2906 cell see pictures at www.eaa538.org/forsale.html > > ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Subject: LASAR/elecr ign
Date: Mar 11, 2005
> > I put about 200 hours on a LASAR system, so here are some > more opinions... > > Alex, how do you know about the 15 minutes with no advance? I > never saw > any sign of this with mine, it always started overheating > right away. I > think you just saw that it doesn't advance the timing much at low > altitude and full throttle. Since I am based at 7650 msl, and > only get > about 22.5" map on takeoff, my LASAR would think I was at cruise, > advance the timing, and overheat on initial climbout. I did > what Randy > says, used a breaker switch so I could shut it off. I also > had to shut > it off on any hot summer day in cruise, trying to keep CHTs below 400. John, this 15 minute timer is described in the flight manual supplement that came with the Lasar system. It starts counting when (electrical) power is first applied, and sets the system to the "climb limit" advance, which I believe is the 25 degree baseline. After the 15 minute timer expires, the timing then begins to advance per some built in table. The manual doesn't say if all systems are so programmed. It could be only those with the CHT monitoring, I don't know. The manual also says that for those systems equipped with the CHT temperature monitor, ignition timing is retarded as the CHT begins to approach the high limit (I believe 425F), until at that high limit the timing is base, or 25 degrees in our case. Was yours CHT probe equipped? Maybe that is the difference. Alex Peterson RV6-A 584 hours Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Mar 11, 2005
Hello: I have a 360a4a that I'm thinking about selling. 275 since major, 4 new millenium cylinders chrome valve covers and chrone intakes O.H. by I.A. with great reputaion. O.H. came out of a cherokee 180 "ran out of gass" no prop strike/none. reportedly wings hit trees when he ran off the end of the runway. brian060901(at)yahoo.com Do You still have the engine? I am wintering here and have a friend that needs an engine for a RV9. Ralph Koger 480 464- 9718 2528 E McKellips Lot 134 Mesa, AZ -----Original Message----- From: tomvelvick(at)cox.net Date: Wednesday, January 05, 2005 3:12 PM Subject: RV-List: O-320 E2A for sale Phx, AZ > > >O-320 E2A Lycoming Engine 2279 TTSN, first run, disassembled for overhaul. Crankshaft, Cam and Rods have been overhauled by Aircraft Specialities in Tulsa, Ok. Crankshaft has standard grind on rod and main bearings, was not turned down. Crankshaft and rods were also balanced to help the engine run smoother while at Aircraft Specialities. Does not include mags or starter (bendix and heavy old starter) unless you want them for a core, but does include the carburator. This engine has the hollow crank and can be set up for constant speed. Dynafocal mount. $5000.00 I was rebuilding this engine for my rv-6a project, but came across a O-360 A1A with 600 SMOH that I bought. Contact Tom Velvick 623-979-2519 home 623-261-2906 cell see pictures at www.eaa538.org/forsale.html > > --------------------------------- ________________________________________________________________________________
Date: Mar 11, 2005
> I've looked the statement that the *owner* can do no more than he can on > certified. This is FLAT OUT WRONG. Anyone can work on an experimental > > Anyone can work on a homebuilt aircraft including a trained chimp or > your dog. You just have to have the condition inspection signed off by > an A&P or AI. > Cy and Youall: I don't mind being wrong, but I have did not see the rule that states a trained chimp, dog or a 5 year old can do Major Modifications, Alterations or Repairs, but I guess it is inferred by exclusion. :- ) (I say only the FSDO knows, as I stated before, and take you choice of answer.) This stuff tends to be in the land of lawyers, courts and judges. John the lawyer wrote me and says Mike, a FSDO inspector(?) has or will reply on this list addressing this? My question to the Inspector and Lawyer is as follows: (Ready to learn) Experimental aircraft are *excluded* from part 43. Is this exemption along with operating limitations, by exclusion and no contrary statement permit *anyone* to modify an experimental airplane? Anyone is someone without a pilot license, aeronautical knowledge, experience or skill (?). That does not sound like "equivalent level of safety". I don't think the **intent** is for major mods to be done by anyone, which is my opinion, "FLAT WRONG" as that may be. (Ready to learn). Part 43.1 par (b) states this part does not apply to experimental aircraft unless it previously held a type certificate." Part 43 is called "MAINTENANCE, PREVENTIVE MAINTENANCE, REBUILDING, AND ALTERATION". Part 43 specifies: What can be done, Who can do it and What records to keep, to name a few. In general the "operating limitations" typically address the 12 mo condition inspection and who can do it (namely a the repairman or A&P). Also, I agree *typically* nothing states restrictions to WHO can do major mods/repairs/alterations, so the assumption is the Chimp, Dog and 5 year old can wench on a homebuilt. That sounds like a bit of a stretch, but OK. John and Mike say it is OK. "Repairman" is called that and not "Inspector-man" mean something? To assume only because the *who* can do inspections is specified and *who* can do a major alteration is not specifically restricted, mean Spot and little Jimmy can make safety of flight mods? This is where I scratch my head. This clearly looks like someone is making an interpretation. (ready to Learn) This is what the EAA says: Who can maintain a Homebuilt? FAR Part 43 specifically states that the rules of that part do not apply to amateur-built airplanes. Therefore, any **maintenance** on an experimental airplane can be performed virtually by anyone regardless of credentials. (This does not apply to the condition inspection previously discussed). Let common sense be your guide as to what maintenance you conduct. Note: EAAs statement said nothing about major modifications, repair or alterations. The statement "Let common sense be your guide as to what maintenance you conduct" makes me think this is allowed? Yes, No. Is the EAA reglatory? What is maintenance? (Ready to learn) For the record any pilot can do "preventative" maintenance on their aircraft (certified or not), but not anyone. You must have a pilots license, Part 61 to do preventative maintenance per part 43 appendix A, Par. (c). Of course with A&P direct supervision anyone can do almost anything on an aircraft. Apparently nothing applies to an experimental aircraft. (Ready to learn) Here is the Scenario: A pilot, with no mechanical experience buys a second hand RV, makes some improper or un-airworthy mod, alteration or repair and crashes. He or his estate is being sued in a court of law, defending the modification of the aircraft, without a repairman certificate or A&P license. Also, the FAA is revoking your pilot ticket and you must defend yourself in a court, if for anything the catch all careless and reckless operation, Where is the legal precedence to defend yourself? I guess we will find out but hope not the hard way. Standing by to be amazed and astounded by FARs once again. After 20 years, may be Ill get it. (Still learning). Cheers George PS interesting web site on experimental liability, http://www.aviationlawcorp.com/content/liabhomeblt.html#disclaimer --------------------------------- ________________________________________________________________________________
Date: Mar 11, 2005
gmcjetpilot(at)yahoo.com wrote: > > > >>I've looked the statement that the *owner* can do no more than he can on >>certified. This is FLAT OUT WRONG. Anyone can work on an experimental >> >>Anyone can work on a homebuilt aircraft including a trained chimp or >>your dog. You just have to have the condition inspection signed off by >>an A&P or AI. >> >> >> > >Cy and Youall: > > >I don't mind being wrong, but I have did not see the rule that states a trained chimp, dog or a 5 year old can do Major Modifications, Alterations or Repairs, but I guess it is inferred by exclusion. :- ) (I say only the FSDO knows, as I stated before, and take you choice of answer.) > > > George you ARE aware that Mike Robertson is DAS FED? :-) Jerry ________________________________________________________________________________
Date: Mar 11, 2005
Alex, mine was equipped with the CHT probe. I once asked Harry Fenton about it, and he told me it would start to roll back the timing at 435 dF. I felt that was too high, and so I always turned it off at about 400 dF. This was about the only detail I ever got out of Harry or anyone else there, my other questions were always answered with "thats proprietary". There is no mention of the 15 minute timer on the website, only the 15 second delay after power up. I sent the supplement with the rest of my system when I sold it, so I can't look it up. Typical of me not to read all the directions. Randy, reading the LASAR website, I see they claim a spark that is "3 times more spark energy". So I will have to change my writeup. I was told that there was no difference by Dave Anders, who is one of the RVers I respect. Of course we are all wrong from time to time. I will say, however, that my hot starts are much easier with the Lightspeed system. Interesting that the LASAR system uses standard aircraft plugs, with a standard gap setting (.018), but the Lightspeed uses automotive plugs gapped at .035. We all get to make our tradeoffs. I love these experimentals! John Alex Peterson wrote: > > > >> >>I put about 200 hours on a LASAR system, so here are some >>more opinions... >> >>Alex, how do you know about the 15 minutes with no advance? I >>never saw >>any sign of this with mine, it always started overheating >>right away. I >>think you just saw that it doesn't advance the timing much at low >>altitude and full throttle. Since I am based at 7650 msl, and >>only get >>about 22.5" map on takeoff, my LASAR would think I was at cruise, >>advance the timing, and overheat on initial climbout. I did >>what Randy >>says, used a breaker switch so I could shut it off. I also >>had to shut >>it off on any hot summer day in cruise, trying to keep CHTs below 400. >> >> > >John, this 15 minute timer is described in the flight manual supplement that >came with the Lasar system. It starts counting when (electrical) power is >first applied, and sets the system to the "climb limit" advance, which I >believe is the 25 degree baseline. After the 15 minute timer expires, the >timing then begins to advance per some built in table. The manual doesn't >say if all systems are so programmed. It could be only those with the CHT >monitoring, I don't know. The manual also says that for those systems >equipped with the CHT temperature monitor, ignition timing is retarded as >the CHT begins to approach the high limit (I believe 425F), until at that >high limit the timing is base, or 25 degrees in our case. > >Was yours CHT probe equipped? Maybe that is the difference. > >Alex Peterson >RV6-A 584 hours >Maple Grove, MN > >http://www.home.earthlink.net/~alexpeterson/ > > > > ________________________________________________________________________________
Date: Mar 11, 2005
From: "Richard V. Reynolds" <rvreynolds(at)macs.net>
Subject: J.B. Aircraft Engine Service Inc
Is J.B. Aircraft Engine Service, Sebring FL (Jim Brod) a good place to buy a rebuilt engine? Richard Reynolds Norfolk, VA RV-6A ________________________________________________________________________________
Subject: Re: Confused about IO-360 180hp engines.
Date: Mar 11, 2005
Every time I think Ive got my engine decided, something comes up to confuse me. Im building a RV-8. I decided on an IO-360 180 HP engine. Im going to set it up for basic aerobatics so inverted oil system etc. Im also going with a dual electronic ignition Lasar or Light speed. Im also going to have high compression pistons put in to bump up the power closer to 195hp. Ok So I thought I had it all figured out then I started looking around for a good deal on a mid time engine and I cant believe how many different versions of the IO-360 180hp engine there are. I see vans has the IO-360 M1B listed as the default 180hp engine. Is the M1B the only 180hp engine that will fit into the RV-8 without modifying the plane? Are people buying non M1B engines and making changes to the engines so they meet M1B specs? If so what engines can be bought and converted to the M1B configuration and what engines just cant be converted at all? Argh my head hurts!! Lol your input would be appreciated. Kevin Yellowknife, NT, Canada RV-8 Wanna Be Builder ________________________________________________________________________________
Date: Mar 11, 2005
Subject: more LASAR
Just as another data point, here is a forward from the Lancair list. They have been having similar discussions. John -------- Original Message -------- Subject: [LML] Re: Slick Mag Failures Date: Fri, 11 Mar 2005 10:15:56 -0500 From: Halle, John <JJHALLE(at)stoel.com> Here is another Slick mag horror story. About three months ago, I started getting an occasional miss in my engine (once or twice a flight.) Over time, it got slightly more frequent but it was never more than one every few minutes. With some experimentation, we discovered that pulling the LASAR circuit breaker solved the problem. Also discovered that, while pulling the CB during ground run-up made a 300 rpm difference, doing so in flight made no difference to any engine parameter, regardless of the altitude at which it was done. Hooking the controller box up to a laptop resulted in a perfect test score so the box and the mags went back to Unison (where nothing happened to them for 10 days but that's another story.) Found out yesterday that the box tests perfect but BOTH mags are shot! I have 320 hrs. tach time on them. I learned the mag mantra early on (probably on my first preflight in 1967): mags are the world's most inefficient ignition system but we use them because they are SIMPLE, RELIABLE and SAFE. And I believed it as a religious doctrine. When I built my airplane, I selected the LASAR system precisely because it had not one but two of these safe, reliable things that would work no matter what if the new-fangled electronics failed. Now I discover that for the last God knows how long, I have been flying around over mountain ranges and in hard IFR with TWO mags that went in the dumpster as soon as the Rockford people saw them. As a final irony, they are pretty close to the only "Certified" parts on my engine (IO-540 exp). I am getting a discount on two replacement mags which I intend to use while I figure out what electronic system to go to. I intend to check them frequently, and I don't mean the run-up check that I have done before every take-off and that has always been perfect. Check out whatever Deakin article claims that runup checks are a complete waste of time, which I now put more stock in than I used to. I have no idea if the controller box is contributing anything but I intend to test that too when I get it reinstalled. And I still don't know why the engine missed only with the LASAR system on. Without it, I would presumably still be fat, dumb and happy (instead of being only two of the foregoing) flying around with two "shot" mags tbat do just fine on runup. -- For archives and unsub http://mail.lancaironline.net/lists/lml/ ________________________________________________________________________________
Date: Mar 11, 2005
Disregard my last post. I am "flat out wrong." So if you want to make that flying RV you just bought a twin engine Bi-plane, go for it. However you may have a hard time getting someone to give you a condition inspection. I called my FSDO and ANYONE can make a major modification to a homebuilt as long as they follow the limitations, as you all state. I also called an experimental specialty shop and they confirmed this. It is nice to be wrong for a change (again and again). Side note, the new limitations that allow modification and phase one testing without FAA notification or approval is no longer in fashion. The Fed's (at least in the SE region) want control and oversight again, so according to my local FSDO, new operating limitations will go back to requiring written approval prior to flight test again. No big deal. Feel like I slept at a Holiday Inn, Cheers George --------------------------------- ________________________________________________________________________________
Subject: Re: J.B. Aircraft Engine Service Inc
Date: Mar 11, 2005
I have cylinder work done there and found them to be very good. Ollie 6A ----- Original Message ----- From: "Richard V. Reynolds" <rvreynolds(at)macs.net> Subject: RV-List: J.B. Aircraft Engine Service Inc > > Is J.B. Aircraft Engine Service, Sebring FL (Jim Brod) a good place to > buy a rebuilt engine? > > Richard Reynolds > Norfolk, VA > RV-6A > > > ________________________________________________________________________________
Date: Mar 11, 2005
I had work on my IO-540 done there last year (various things but not really a full rebuild) and I would give them a thumbs up. Knowledgeable, pleasant to deal with, kept to the schedule and cost as about as expected (high--but no more so then anywhere else!). They were responsive on a couple of follow-up items--that weren't really their fault. So, all-in-all, from my experience, I can recommend them without reservation. Chuck -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Richard V. Reynolds Subject: RV-List: J.B. Aircraft Engine Service Inc Is J.B. Aircraft Engine Service, Sebring FL (Jim Brod) a good place to buy a rebuilt engine? Richard Reynolds Norfolk, VA RV-6A ________________________________________________________________________________
Date: Mar 11, 2005
Exactly correct. Mike R. >From: "cgalley" <cgalley(at)qcbc.org> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: Prop replacement, question for Das Fed, was: >Date: Fri, 11 Mar 2005 11:26:53 -0600 > > >Some else pointed that out as well. My point still is that all maintenance >needs to be done so the person that does the conditional will approve the >plane's return to service. > > >----- Original Message ----- >From: "Mike Robertson" <mrobert569(at)hotmail.com> >To: >Subject: Re: RV-List: Prop replacement, question for Das Fed, was: > > > > > > Cy, > > > > If I may. The yearly condiction inspection is to determine if the > > aircraft > > is safe to operate. I know it is a play on terms but from the FAA point > > of > > view we say that the aircraft is never airworthy because it has not been > > evaluated and issued an type certificate, only that it is "safe to > > operate". > > Other than that you are entirely correct. > > > > Mike R. > > > >>From: "cgalley" <cgalley(at)qcbc.org> > >>Reply-To: rv-list(at)matronics.com > >>To: > >>Subject: Re: RV-List: Prop replacement, question for Das Fed, was: > >>Date: Thu, 10 Mar 2005 16:07:38 -0600 > >> > >> > >>I've looked the statement that the owner can do no more than he can on > >>certified. > >>This is FLAT OUT WRONG. > >> > >> Anyone can work on an experimental. > >> > >>One caveat and even this might be wrong. At the yearly conditional > >>inspection, the work has to be good enough to get the plane signed off >as > >>airworthy. > >> > >>Cy Galley > >>EAA Safety Programs Editor > >>Always looking for ideas and articles for EAA Sport Pilot > >> > >> > >>----- Original Message ----- > >>From: "Dave Bristol" <dbris200(at)sbcglobal.net> > >>To: > >>Subject: Re: RV-List: Prop replacement, question for Das Fed, was: > >> > >> > >> > > >> > Anyone can work on a homebuilt aircraft including a trained chimp or > >> > your dog. You just have to have the condition inspection signed off >by > >> > an A&P or AI. > >> > > >> > Dave > >> > > >> > gmcjetpilot(at)yahoo.com wrote: > >> > > >> >> > >> >> > >> >>Mike: > >> >> > >> >>You are opening a can of worms :- ) The buyer of an experimental > >>aircraft > >> >>can only do routine maintenance, as if it were a Piper or Cessna, as > >> >>far > >> >>as I know. Only the manufacture (builder/repairman) can make major > >> >>mods, > >> >>however I assume(?) an A&P or AI could do it and with the FAA's > >>blessing. > >> >>Again, as in all these matters refer to the FISDO of choice for the > >> >>answer. There is no "type certificate" configuration for exp a/c, so > >>many > >> >>changes slip thru the cracks and are not tracked by the FAA. Anyone > >> >>who > >> >>has a second hand RV may find them self in a regulatory mess if they > >>want > >> >>to make a major changes. The best (easiest) thing would get the >builder > >>to > >> >>sign the mod off if possible. However that is one of the fantastic > >>reasons > >> >>for building your own plane. > >> >> > >> >>Cheers George > >> >> > >> >> > >> >> > >> >> > >> >>> > >> >>>Mike, > >> >>> > >> >>>I have a question related to this very activity ... and am asking >not > >> >>>so much for myself (I'm still building), but just to satisfy my > >> >>>curiosity. > >> >>> > >> >>>I have had the impression that all these suggestions and >requirements > >> >>>have been tendered with the idea that the person doing the work is >the > >> >>>builder and has a repairman's certificate for the aircraft. However, > >>what > >> >>>are > >> >>>the rules/regs for someone who does NOT have the repairmans > >> >>>certificate > >> >>>and > >> >>>who is NOT an A/P? Somehow I can't imagine that they would be in a > >> >>>position > >> >>>to change their prop, put it into phase 1, perform the flight >testing, > >> >>>and > >> >>>sign it off putting it back in phase 2. Or can they? > >> >>> > >> >>> > >> >> > >> >> > >> >> > >> >>--------------------------------- > >> >> > >> >> > >> >> > >> >> > >> > > >> > > >> > > >> > >> > > > > > > > > ________________________________________________________________________________
Date: Mar 11, 2005
Firstly, thank you for your admission. That takes some courage. As to going back to the "old" operating limitations that require FAA approval, that is not quite right. The order clearly states that the FAA does not "approve" the major change, but that you MUST notify them, get concurrence on the test area, and they reserve the right to require more than 5 hours minimum of test flight period. Again, that is per the Order 8130.2F. Mike Robertson >From: <gmcjetpilot(at)yahoo.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Re: Prop replacement, question for Das Fed, was: >Date: Fri, 11 Mar 2005 12:46:29 -0800 (PST) > > >Disregard my last post. I am "flat out wrong." So if you want to make that >flying RV you just bought a twin engine Bi-plane, go for it. However you >may have a hard time getting someone to give you a condition inspection. > >I called my FSDO and ANYONE can make a major modification to a homebuilt as >long as they follow the limitations, as you all state. I also called an >experimental specialty shop and they confirmed this. It is nice to be wrong >for a change (again and again). > >Side note, the new limitations that allow modification and phase one >testing without FAA notification or approval is no longer in fashion. The >Fed's (at least in the SE region) want control and oversight again, so >according to my local FSDO, new operating limitations will go back to >requiring written approval prior to flight test again. No big deal. > >Feel like I slept at a Holiday Inn, Cheers George > > >--------------------------------- > > ________________________________________________________________________________
Date: Mar 11, 2005
Subject: Re: Electric or Manual Trim ?
Thanks for the responses... I have found more in the archive, but these really summed up the options clearly. Today I sent my empennage order in to Van's... now if i can just get the hang of using the rv-list, there may be hope for my future. jp --------------------------------- ________________________________________________________________________________
Date: Mar 11, 2005
Subject: Re:Wheel pants
Mickey; I used a file to get a better fit between the two halves of the wheel pants. A square or flat file will do. I also used Poly-Fibre "Smooth Prime" to prime them . It goes on with a small roller and you can push down to squish it into the pinholes in that #$% &* fibre glas. A/C S has it in the glas & resins section of their catalog. Mix small amounts since it goes a long way. It washes up with water and sands into lots of snow on the floor. A couple of coats usually takes care of the pinholes. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Mar 11, 2005
Subject: Looking for FWF photos
Dean, I just finished my FWF and you are welcome to drop by for a look and a chat of what I did and why I did it. I moved the airplane from my living room to my garage last weekend and hope to have it in the air by May. Pete Hunt, Clearwater RV-6, N216PH All electric IFR panel ________________________________________________________________________________
Subject: Re: Spark Plug quality/source
Date: Mar 11, 2005
I got my last set from Van's @ $16. He sells the sutolite. they look good, work good so far. Couple hundred hours. You got to search the "list" for Plugs. DLW On Mar 11, 2005, at 10:29 AM, lucky wrote: > > Hey, something else new for me to ponder over. Any quality difference > between a champion plug for 20 bucks vs an Autolite for $16? I got to > buy 9 (one spare just in case) so it adds up. But Champion is what > used to be in the engine so.... > > What say you wise ones? > > BTW, is ACS the place most buy online and get the 5% AOPA discount? > Van's doesn't sell 'em... > > thx, > lucky > > Hey, something else new for me to ponder over. Any quality difference > between a champion plug for 20 bucks vs an Autolite for $16? I got to > buy 9 (one spare just in case) so it adds up. But Champion is what > used to be in the engine so.... > > What say you wise ones? > > BTW, is ACS the place most buy online and get the 5% AOPA discount? > Van's doesn't sell 'em... > > thx, > lucky > > ________________________________________________________________________________
Date: Mar 11, 2005
Subject: White Letters for Panel
Subject: RV-List: White Letters for Panel OK, I have the day off and ready to go out and buy a label maker suitable for the panel. Can someone give me the final answer to the age old question on what make/model of label maker & label paper it takes to print out quality labels with white letters that will actually stick to the panel paint over time? Prefer one I just run to to Staples or Office Max and pick up. I have found that the lettering on the label, if not protected with some type of overlay, wears off if touched often. The most common victims in my aircraft are carb heat and fuel selector labels and they need replacement about every 300 hrs (using Casio with gold lettering, black background on black panel). George in Langley BC ________________________________________________________________________________
Date: Mar 12, 2005
The Brother P-Touch machine I have uses laminated tapes; I doubt they'd ever wear off. -Stormy ________________________________________________________________________________
Date: Mar 12, 2005
Spruce offers a 5% discount to AOPA members?? I wish I had known that; I've dropped a fortune there over the years. -Stormy ________________________________________________________________________________
Subject: RE: Label Makers
Date: Mar 12, 2005
lucky wrote: > >OK, I have the day off and ready to go out and buy a label maker >suitable for the panel. Can someone give me the final answer to the age old question on what make/model of label maker & label paper it takes to print out quality labels with white letters that will actually stick to the panel paint over time? Prefer one I just run to Staples or Office Max and pick up. > One bit of info that may help many builders like myself... I bought the Brother P-Touch label maker then order a 1/4" "Industrial Adhesive" TZ tape from some on-line shop. The extra sticky tape clings tenaciously to wiring, panels, whatever. The backside of the 1/4" tape has a split running lengthwise and makes for simple removal of the backing. The wider tape backing is not split; requires a sharp fingernail; and are frustrating to say the least. Kelly Patterson RV-6A tip FWF & I hate fiberglass PHX, AZ ________________________________________________________________________________
Date: Mar 12, 2005
Subject: sun 100 cancelled
There is no joy in mudville. See http://www.aircraftspruce.com/sunfunracebulletin.php John Huft RV8 "Nuisance" ________________________________________________________________________________
Subject: RE: Odyssey Battery Installation Kit with Panasonic
Date: Mar 12, 2005
Walter has a great mod here that I used for another reason. My Panasonic 20 Ah battery was an interference fit in the Van's PC680 battery box as it was binding at the corners. I cut one corner of the box and installed the hinge. Now I can pull the battery by pulling the hinge pin. If you get the Panasonic, which sells for under $50 from Digikey, you will need to do this mod to the box. Kelly Patterson RV-6A with an Emag FWF PHX, AZ From: Walter Tondu <walter(at)tondu.com> I made a quick modification which is to make the front panel of the box removable so the battery just pops out the front. I used hinges on each side to retain the front of the box. It works very well and is simple to do. http://www.rv7-a.com/firewall_finish.htm#battery box mods -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Subject: RE: Wheel pants
Date: Mar 12, 2005
I hate fiberglass too Mickey, but had pretty good results with the following method. BTW - Van's plans & instructions are very good in this area. First get the pants to fit with a tight line - don't worry about a step or ridge between them, it will sand and fill. Use a random orbit sander for the smooth finish. Next buy intersection fairings from Fairings Etc. http://www.fairings-etc.com/ or your favorite supplier. These are excellent parts and only require minor fitting, sanding and glassing to the pants. You should also use a heat gun to warm any low / high spots and gently bend the glass a little at a time to shape. It is very flexible when warm. Next check out this website: http://rv8a.tripod.com/fiberglass.html and finish the fairings together. Have fun making dust. (NOT!!!) Kelly Patterson 95 % aluminum plane builder PHX, AZ From: Mickey Coggins <mick-matronics(at)rv8.ch> Subject: RV-List: Wheel pants Hi, I'm very "glass challenged", which is why I'm building an aluminum airplane. Anyone have any special tricks for doing the wheel pants? ________________________________________________________________________________
Subject: CherryMax Rivets
Date: Mar 12, 2005
What are "CherryMax" rivets. I read on a web site that a builder was using them but I have no idea what they are. ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: CherryMax Rivets
Date: Mar 12, 2005
----- Original Message ----- From: "Kevin Williams" <kevinsky18(at)hotmail.com> Subject: RE: RV-List: CherryMax Rivets > > What are "CherryMax" rivets. I read on a web site that a builder was > using > them but I have no idea what they are. > Cherrymax rivets are structural "aircraft grade" pop rivets. They are a direct structural replacement for driven rivets. In addition to the normal diameters, they also come in slightly over-diameter sizes to help in situations where the hole is larger than standard. They are very handy if you need a structural rivet in a location where you're unable to use a driven rivet. Those are the "pro's". The con's are that the rivets are expensive. I don't have a price sheet handy, but IIRC, they are 5x or more as expensive as hardware store pop rivets and probably 50x as expensive as driven rivets. Also, since they have a steel (?) center core, they are much more difficult to drill out than conventional rivets or hardware store pop rivets. KB ________________________________________________________________________________
Date: Mar 12, 2005
> >Every time I think Ive got my engine decided, something comes up to confuse >me. Im building a RV-8. I decided on an IO-360 180 HP engine. Im going >to set it up for basic aerobatics so inverted oil system etc. Im also >going with a dual electronic ignition Lasar or Light speed. Im also going >to have high compression pistons put in to bump up the power closer to >195hp. > >Ok So I thought I had it all figured out then I started looking around for a >good deal on a mid time engine and I cant believe how many different >versions of the IO-360 180hp engine there are. I see vans has the IO-360 >M1B listed as the default 180hp engine. > >Is the M1B the only 180hp engine that will fit into the RV-8 without >modifying the plane? Are people buying non M1B engines and making changes >to the engines so they meet M1B specs? If so what engines can be bought >and converted to the M1B configuration and what engines just cant be >converted at all? > >Argh my head hurts!! Lol your input would be appreciated. The IO-360-M1A and M1B are the only 180 hp IO-360s that have the fuel injection servo mounted on the front of the oil sump. That allows it to be used with Van's "horizontal induction" air box, which means you get the cowling with the smooth front (i.e. there is no protruding inlet for engine induction air intake). Other 180 hp IO-360s will work, but they have the fuel injection servo mounted on the bottom of the oil sump, similar to most carbureted versions. You need the cowling with the air induction inlet sticking out the bottom. Van really designed this setup around a carbureted engine, so there might be a bit of air box rework to make it fit - other builders should be able to give a better story here. Looking at the FAA Type Certificate Data Sheet (TCDS) for the IO-360 engines, it looks like the following 180 hp IO-360s might work: IO-360-B1B IO-360-B1C IO-360-B1D IO-360-B1F IO-360-B1F6 IO-360-B2E (fixed pitch prop only) IO-360-B2F (fixed pitch prop only) IO-360-B2F6 (fixed pitch prop only) IO-360-B4A IO-360-E1A (type 2 Dynafocal mount) IO-360-F1A (modifications to allow turbo-charging - find out what the mods are before buying this one.). IO-360-M1A (front mounted fuel injection and front mounted prop governor). IO-360-M1B (front mounted fuel injection and rear mounted prop governor). Other than the IO-360-M1A and M1B, all the above engines would have bottom mounted fuel injection servos. The following models look like they might cause grief: IO-360-B1A - it has Simmonds fuel injection, which is uncommon. I suspect you might have additional problems making it fit the airbox, etc. But I'm guessing here. IO-360-B1E - has different oil sump and induction manifolding. This might interfere with the engine mount. Further investigation needed. IO-360-B1G6 - has bed type engine mount. Not compatible with the engine mounts that Van sells. The above info is completely speculative, and is offered without any warrantee as to its accuracy. Use at your own risk. To view the TCDS, go to: http://www.airweb.faa.gov/tcds, then search for IO-360. Scroll past the Continental IO-360s to find a link to a Textron Lycoming IO-360 (there a gazillion links, one for each model of Lycoming IO-360, but they all point to the same TCDS). You'll have to click on one more link, then you'll end up viewing the TCDS. There is a section starting on page 15 that attempts to explain the differences between the various models. The explanations can be a misleading though, e.g. it says the IO-360-B1A is "Similar to IO-360-A1A except has Simmonds Type 530 fuel injector. Does not have tuned induction". That is very misleading, as the IO-360-A1A is a 200 hp, angle-valve engine, and the IO-360-B1A is a 180 hp parallel-valve engine. But if you stick with the 180 hp variants, I think the story on the differences between models is probably OK. You can also buy a carbureted O-360, and add Airflow Performance Fuel injection. This would be approximately equivalent to an IO-360-B1B. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Mar 12, 2005
Kevin Williams wrote: > >What are "CherryMax" rivets. I read on a web site that a builder was using >them but I have no idea what they are. > pop rivets on steroids They are 'aviation quality' pulled rivets. Cherry is a brand name. ________________________________________________________________________________
Subject: Sanding out paint
Date: Mar 12, 2005
Just say you painted your airplane yourself and saved $5000 to $10000, but it wasn't perfect. Did I tell you I painted it myself? I used Imron, single stage. And just say you wanted to sand it out in a few "orange peel" areas. What's the best method and stuff to use? Rich Crosley RV-8, N948RC ________________________________________________________________________________
Subject: Re: Sanding out paint
Date: Mar 12, 2005
----- Original Message ----- From: "Richard Crosley" <rcrosley(at)adelphia.net> Subject: RV-List: Sanding out paint > > Just say you painted your airplane yourself and saved $5000 to $10000, but > it wasn't perfect. Did I tell you I painted it myself? I used Imron, > single stage. And just say you wanted to sand it out in a few "orange > peel" areas. What's the best method and stuff to use? > > Rich Crosley > RV-8, N948RC It ain't easy. You need to wet sand, beginning with no coarser than 800 grit paper, progressing to 1600 and maybe a step beyond that. Then you need to buff the paint to a final sheen using a rotary buffer and an appropriate buffing compound. Your local auto body store (the one where you bought the Imron) should be able to point you in the right direction. If you have not done this before, you're likely to have at least two problems: 1) If you sand enough to remove the orange peel, you're likely to sand through the paint in a few areas - particularly rivet heads and/or panel edges. 2) If you've never used a high speed buffer before, you're likely to mess up a time or two and "catch" a panel edge with a buffing pad. This will either burn the paint, deform the edge, or rip the paint loose. One thought - if it is just a few areas, why not hire a pro for $200 to come by and spend a saturday at your shop sanding and buffing. It'll be $200 well spent (as compared to buying or renting a buffer, possibly making a mess and having to re-spray, etc.) KB ________________________________________________________________________________
From: Kendel McCarley <kmmccarley(at)earthlink.net>
Date: Mar 12, 2005
Ah... a question right up my alley. Today's project is to finish paint a '77 MG Midget (http://home.earthlink.net/~kmmccarley/77midget.html), so I'm taking a break from sanding right now. There was a good article in EAA Sport Aviation a few years back on this subject. The short of it is... - All modern paints will orange peel at least some and color sanding is a necessary thing for a show quality job - Start with an appropriate grit... from 800 to 1200 depending on imperfections - Sand each grit in a single direction... orthogonal to the previous grit. The idea is to cross-cut the grooves made by the previous grit. - 2000 grit is about the end of sanding. After that, you're into using a polisher with different compounds up to a "glaze". What I've learned from doing color sanding is... - A rough cut compound on the polisher will take over after 1600 grit - A little dish washing soap (and I do mean a little) in the water bucket will help sandpaper glide over the paint to make the process easier. Just keep dipping that paper into the soapy water. - A variety of foam rubber backing blocks help. I even use an old, thick neoprene mouse pad for a backing pad at times. - Runs and drips are easily removed with a burr put onto a razor blade and then drawn across the imperfection - Don't try to do all your sanding at once. Impatience is the enemy, so beer, bathroom, and BSing with a buddy breaks will make the job come out better. Good luck with this. I've seen some RVs with "crappy" amateur paint jobs that could be turned into gleaming projects with the application of some elbow grease. My final piece of advice would be to do just one section at a time. Once you see how well a 3' x 3' area can turn out, you'll be hooked. > > Just say you painted your airplane yourself and saved $5000 to $10000, but it wasn't perfect. Did I tell you I painted it myself? I used Imron, single stage. And just say you wanted to sand it out in a few "orange peel" areas. What's the best method and stuff to use? > > Rich Crosley > RV-8, N948RC > -- Kendel McCarley ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Mar 12, 2005
Rich, That stuff is tuff as nails!! Very hard to sand and buff back up to a nice finish. I would sand the orange peel and use Clear over the whole aircraft at this point. Imron is available in clear. Tom in Ohio ----- Original Message ----- From: "Richard Crosley" <rcrosley(at)adelphia.net> Subject: RV-List: Sanding out paint > > Just say you painted your airplane yourself and saved $5000 to $10000, but > it wasn't perfect. Did I tell you I painted it myself? I used Imron, > single stage. And just say you wanted to sand it out in a few "orange > peel" areas. What's the best method and stuff to use? > > Rich Crosley > RV-8, N948RC > > > ________________________________________________________________________________
Date: Mar 12, 2005
Subject: Re: sun 100 cancelled
The two air races that started at Apple Valley, CA (CopperState and Golden West-I think) which Aircraft Spruce sponsored have been canceled for the last several years over insurance issues. So I bet Sun-in-Fun Races don't come back either. I didn't get to see the end but did enjoy helping get them off as our EAA Chapter 768 helped Spruce organize things at APV. Tom Gummo Fired "Race Marshall" :-( ----- Original Message ----- From: "John Huft" <rv8(at)lazy8.net> Subject: RV-List: sun 100 cancelled > > There is no joy in mudville. See > > http://www.aircraftspruce.com/sunfunracebulletin.php > > John Huft > RV8 "Nuisance" > > > ________________________________________________________________________________
Date: Mar 12, 2005
> >> >>Every time I think Ive got my engine decided, something comes up to >>confuse >>me. Im building a RV-8. I decided on an IO-360 180 HP engine. Im going >>to set it up for basic aerobatics so inverted oil system etc. Kevin, Be aware that it is a pretty big pain and fairly expensive to set up an engine and fuel system for inverted flight. If all you really want to do is "basic" aerobatics you don't need to set the airplane up for inverted flight. You can do loops, rolls, cubans, split esses, snaps and sort of cheating hammerheads with a carburator and normal fuel and oil systems. That is a lot of pretty fun stuff. To do sustained inverted flight you need the inverted systems. Have you done sustained inverted flight? Do you really like negative G? Do you think all that work is worth it? Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Date: Mar 12, 2005
Subject: RV-6's on ebay
There is an RV-6 business opportunity on ebay under aircraft projects if anyone is interested. ________________________________________________________________________________
Subject: Re: Prop replacement, question for Das Fed, was:
Date: Mar 12, 2005
I question the statement about a FSDO going back and requiring permission when the current FAA order and operating limits are not written that way. Here is what Earl Lawrence had to say. Note! Once again the individuals at a FSDO make up their rules contrary to the official rules. Some one pointed out that a polite request to see the written source can be educational. Cy Galley EAA Safety Programs Editor Always looking for ideas and articles for EAA Sport Pilot ----- Original Message ----- From: "Earl Lawrence" <elawrence(at)eaa.org> Subject: RE: RV-List: Re: Prop replacement, question for Das Fed, was: Yes and No Can the region do it without violating FAA policy no. Is FAA HQ going to do anything about it NO. That is why every EAA member should only go to EAA Volunteer AB DARS as they follow the official rules not the local FAA made up ones. And no the policy is not going back to requiring FAA written approval despite what the local FAA folks wish would happen. FAA management wants those local FAA folks worrying about the airlines not some homebuilder. Earl -----Original Message----- From: cgalley [mailto:cgalley(at)qcbc.org] Subject: Fw: RV-List: Re: Prop replacement, question for Das Fed, was: Is this possible to change operating limitations for just one region. Thought the FAA was trying to standardize. ----- Original Message ----- From: <gmcjetpilot(at)yahoo.com> Subject: RV-List: Re: Prop replacement, question for Das Fed, was: > > Disregard my last post. I am "flat out wrong." So if you want to make that > flying RV you just bought a twin engine Bi-plane, go for it. However you > may have a hard time getting someone to give you a condition inspection. > > I called my FSDO and ANYONE can make a major modification to a homebuilt > as long as they follow the limitations, as you all state. I also called an > experimental specialty shop and they confirmed this. It is nice to be > wrong for a change (again and again). > > Side note, the new limitations that allow modification and phase one > testing without FAA notification or approval is no longer in fashion. The > Fed's (at least in the SE region) want control and oversight again, so > according to my local FSDO, new operating limitations will go back to > requiring written approval prior to flight test again. No big deal. > > Feel like I slept at a Holiday Inn, Cheers George > > > --------------------------------- > > ________________________________________________________________________________
Date: Mar 12, 2005
Received-SPF: none The only 180 HP fuel injected engine that is easy to install is the M-series. All others have the servo in the bottom or rear of the sump and are very tricky to set up the air system. I had purchased an IO-360-B1E with rear facing injection and did not want to go through all the hassle of setting up the induction so I purchased a set of intake tubes and a 200 HP sump and installed the sump with the servo now facing forward. The intake tubes required modification to fit the 180 HP engine. This was long before the M-series was available, so there were no stock tubes that would fit. New tubes are very expensive and I think you will have a hard time finding a used set for the 180-M. None of the brackets for the fuel and mixture that were available then would work so we had to make them also, and there is no stock exhaust that will fit my modification. I had Larry Vetermin build an exhaust for me. A friend of mine is building an RV-7 with the injection on the bottom and he is not happy with the induction so he is also doing what I did. From what he said and I have seen, the air filter set up that Van sells for the injected engine will also need to be modified for the 180 HP version even if you use the M-series engine. My engine with the modified tubes has run great and many very experience pilots have commented on it's smoothness. I did a flow test in flight and have found that the four cylinders are within 2/10's of a gallon per hour of each other which explains the smoothness. I installed a flop tube in the left take to give it inverted fuel, but not the inverted oil system because I do not care for negative g's. As someone pointed out, you can do a lot and still keep it in the positive g's. You can even do limited inverted flight as long as you give up altitude by pulling back slightly on the stick to give positive g's. I can not say what people are doing with the bottom mounted fuel injection, you may be able to use it with a scoop on the lower cowl. Jim Jim Cimino N7TL RV-8 S/N 80039 15+ Hours http://www.geocities.com/jcimino.geo/ ----- Original Message ----- From: "Kevin Horton" <khorton01(at)rogers.com> Subject: Re: RV-List: Confused about IO-360 180hp engines. > >> >>Every time I think Ive got my engine decided, something comes up to >>confuse >>me. Im building a RV-8. I decided on an IO-360 180 HP engine. Im going >>to set it up for basic aerobatics so inverted oil system etc. Im also >>going with a dual electronic ignition Lasar or Light speed. Im also going >>to have high compression pistons put in to bump up the power closer to >>195hp. >> >>Ok So I thought I had it all figured out then I started looking around for >>a >>good deal on a mid time engine and I cant believe how many different >>versions of the IO-360 180hp engine there are. I see vans has the IO-360 >>M1B listed as the default 180hp engine. >> >>Is the M1B the only 180hp engine that will fit into the RV-8 without >>modifying the plane? Are people buying non M1B engines and making changes >>to the engines so they meet M1B specs? If so what engines can be bought >>and converted to the M1B configuration and what engines just cant be >>converted at all? >> >>Argh my head hurts!! Lol your input would be appreciated. > > The IO-360-M1A and M1B are the only 180 hp IO-360s that have the fuel > injection servo mounted on the front of the oil sump. That allows it > to be used with Van's "horizontal induction" air box, which means you > get the cowling with the smooth front (i.e. there is no protruding > inlet for engine induction air intake). > > Other 180 hp IO-360s will work, but they have the fuel injection > servo mounted on the bottom of the oil sump, similar to most > carbureted versions. You need the cowling with the air induction > inlet sticking out the bottom. Van really designed this setup around > a carbureted engine, so there might be a bit of air box rework to > make it fit - other builders should be able to give a better story > here. > > Looking at the FAA Type Certificate Data Sheet (TCDS) for the IO-360 > engines, it looks like the following 180 hp IO-360s might work: > > IO-360-B1B > IO-360-B1C > IO-360-B1D > IO-360-B1F > IO-360-B1F6 > IO-360-B2E (fixed pitch prop only) > IO-360-B2F (fixed pitch prop only) > IO-360-B2F6 (fixed pitch prop only) > IO-360-B4A > IO-360-E1A (type 2 Dynafocal mount) > IO-360-F1A (modifications to allow turbo-charging - find out what > the mods are before buying this one.). > IO-360-M1A (front mounted fuel injection and front mounted prop > governor). > IO-360-M1B (front mounted fuel injection and rear mounted prop governor). > > Other than the IO-360-M1A and M1B, all the above engines would have > bottom mounted fuel injection servos. > > The following models look like they might cause grief: > IO-360-B1A - it has Simmonds fuel injection, which is uncommon. I > suspect you might have additional problems making it fit the airbox, > etc. But I'm guessing here. > > IO-360-B1E - has different oil sump and induction manifolding. This > might interfere with the engine mount. Further investigation needed. > > IO-360-B1G6 - has bed type engine mount. Not compatible with the > engine mounts that Van sells. > > The above info is completely speculative, and is offered without any > warrantee as to its accuracy. Use at your own risk. > > To view the TCDS, go to: http://www.airweb.faa.gov/tcds, then search > for IO-360. Scroll past the Continental IO-360s to find a link to a > Textron Lycoming IO-360 (there a gazillion links, one for each model > of Lycoming IO-360, but they all point to the same TCDS). You'll > have to click on one more link, then you'll end up viewing the TCDS. > > There is a section starting on page 15 that attempts to explain the > differences between the various models. The explanations can be a > misleading though, e.g. it says the IO-360-B1A is "Similar to > IO-360-A1A except has Simmonds Type 530 fuel injector. Does not have > tuned induction". That is very misleading, as the IO-360-A1A is a > 200 hp, angle-valve engine, and the IO-360-B1A is a 180 hp > parallel-valve engine. But if you stick with the 180 hp variants, I > think the story on the differences between models is probably OK. > > You can also buy a carbureted O-360, and add Airflow Performance Fuel > injection. This would be approximately equivalent to an IO-360-B1B. > -- > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > > ________________________________________________________________________________
Date: Mar 12, 2005
Subject: Airventure Cup Race -was Dyaton (Dayton?) experimental race...
This race is a blast! I've done it two years now and won my class my first year (2003). They had the 20 or so RV's in the race divided up according to displacement that year. I was fastest of the O-320 RV's with my fixed pitch 150 RV-4. Like you, I didn't think I could win either. Boy was I surprised. Last year there were fewer planes in the race, and they didn't divide up the classes. So I raced against IO-360 powered RV's and came in 4th (like 10 of us total I think). We need more RV's to show up. If you can follow instructions, fly your airplane with some degree of authority, keep your head on a swivel, and don't freak out when near other planes then you'll have no problem. Honestly, I think flying the fly-in arrival procedure at Sun-N-Fun is more dangerous and demanding. If you've flown to OSH before and shot the arrival when it's halfway busy and didn't have any issues with it all, then you have what it takes. Like Jon Huft says... it really doesn't matter who wins -we all have a ball. Really. It's a roving airplane-nut party with some fast cross-country flying thrown in. Lots of extra perks, like a catered dinner *in* the Air Force Museum -right on the museum floor with the planes. We had the whole place to ourselves for 3+ hours. You get to hang out with some really cool people too. We have some dinners at OSH too -lots of fun social time. Ya'll come race with us!!! I've heard EAA wants to nix this race -they don't think it really 'benefits the membership' -I've heard. *Everyone* who shows up for it has a really fun time. I'm convinced that if most of you came, you'd have a ball too... Scott N4ZW 'Race 74' -"Think Fast" >>> I will be there. No formation skills required. It is lots of fun, it doesn't matter where you finish (well, maybe a little). John Huft Race 13 "Nuisance" Charles Heathco wrote: > >I was wondering if any of our group plans to run in this race, especially any of the formation folks as they would have the requisite skills. (Mike, the super 8 gonna be ready by then?) I think it might be fun, but in my 150hp FP, it would be prop wash city for me :-) charlie heathco > ________________________________________________________________________________
Date: Mar 12, 2005
Thanks for the info it all helps alot. Ok so to keep the headaches down to a minimum I should really be looking for the M1B. I think this is a fairly new engine though and I suspect there won't be many out there on the used market. Larry you made some very good points about whether I want and need an inverted system. Now that it has been pointed out that I can do all I want to do with a standard no inverted system I'll probably drop the inverted bit. Kevin Yellowknife, NT, Canada RV-8 Wanna Be Builder From: "Jim Cimino" <jcimino(at)echoes.net> Subject: Re: RV-List: Confused about IO-360 180hp engines. Date: Sat, 12 Mar 2005 13:33:38 -0500 The only 180 HP fuel injected engine that is easy to install is the M-series. All others have the servo in the bottom or rear of the sump and are very tricky to set up the air system. I had purchased an IO-360-B1E with rear facing injection and did not want to go through all the hassle of setting up the induction so I purchased a set of intake tubes and a 200 HP sump and installed the sump with the servo now facing forward. The intake tubes required modification to fit the 180 HP engine. This was long before the M-series was available, so there were no stock tubes that would fit. New tubes are very expensive and I think you will have a hard time finding a used set for the 180-M. None of the brackets for the fuel and mixture that were available then would work so we had to make them also, and there is no stock exhaust that will fit my modification. I had Larry Vetermin build an exhaust for me. A friend of mine is building an RV-7 with the injection on the bottom and he is not happy with the induction so he is also doing what I did. From what he said and I have seen, the air filter set up that Van sells for the injected engine will also need to be modified for the 180 HP version even if you use the M-series engine. My engine with the modified tubes has run great and many very experience pilots have commented on it's smoothness. I did a flow test in flight and have found that the four cylinders are within 2/10's of a gallon per hour of each other which explains the smoothness. I installed a flop tube in the left take to give it inverted fuel, but not the inverted oil system because I do not care for negative g's. As someone pointed out, you can do a lot and still keep it in the positive g's. You can even do limited inverted flight as long as you give up altitude by pulling back slightly on the stick to give positive g's. I can not say what people are doing with the bottom mounted fuel injection, you may be able to use it with a scoop on the lower cowl. Jim Jim Cimino N7TL RV-8 S/N 80039 15+ Hours http://www.geocities.com/jcimino.geo/ ----- Original Message ----- From: "Kevin Horton" <khorton01(at)rogers.com> Subject: Re: RV-List: Confused about IO-360 180hp engines. > >> >>Every time I think Ive got my engine decided, something comes up to >>confuse >>me. Im building a RV-8. I decided on an IO-360 180 HP engine. Im going >>to set it up for basic aerobatics so inverted oil system etc. Im also >>going with a dual electronic ignition Lasar or Light speed. Im also going >>to have high compression pistons put in to bump up the power closer to >>195hp. >> >>Ok So I thought I had it all figured out then I started looking around for >>a >>good deal on a mid time engine and I cant believe how many different >>versions of the IO-360 180hp engine there are. I see vans has the IO-360 >>M1B listed as the default 180hp engine. >> >>Is the M1B the only 180hp engine that will fit into the RV-8 without >>modifying the plane? Are people buying non M1B engines and making changes >>to the engines so they meet M1B specs? If so what engines can be bought >>and converted to the M1B configuration and what engines just cant be >>converted at all? >> >>Argh my head hurts!! Lol your input would be appreciated. > > The IO-360-M1A and M1B are the only 180 hp IO-360s that have the fuel > injection servo mounted on the front of the oil sump. That allows it > to be used with Van's "horizontal induction" air box, which means you > get the cowling with the smooth front (i.e. there is no protruding > inlet for engine induction air intake). > > Other 180 hp IO-360s will work, but they have the fuel injection > servo mounted on the bottom of the oil sump, similar to most > carbureted versions. You need the cowling with the air induction > inlet sticking out the bottom. Van really designed this setup around > a carbureted engine, so there might be a bit of air box rework to > make it fit - other builders should be able to give a better story > here. > > Looking at the FAA Type Certificate Data Sheet (TCDS) for the IO-360 > engines, it looks like the following 180 hp IO-360s might work: > > IO-360-B1B > IO-360-B1C > IO-360-B1D > IO-360-B1F > IO-360-B1F6 > IO-360-B2E (fixed pitch prop only) > IO-360-B2F (fixed pitch prop only) > IO-360-B2F6 (fixed pitch prop only) > IO-360-B4A > IO-360-E1A (type 2 Dynafocal mount) > IO-360-F1A (modifications to allow turbo-charging - find out what > the mods are before buying this one.). > IO-360-M1A (front mounted fuel injection and front mounted prop > governor). > IO-360-M1B (front mounted fuel injection and rear mounted prop governor). > > Other than the IO-360-M1A and M1B, all the above engines would have > bottom mounted fuel injection servos. > > The following models look like they might cause grief: > IO-360-B1A - it has Simmonds fuel injection, which is uncommon. I > suspect you might have additional problems making it fit the airbox, > etc. But I'm guessing here. > > IO-360-B1E - has different oil sump and induction manifolding. This > might interfere with the engine mount. Further investigation needed. > > IO-360-B1G6 - has bed type engine mount. Not compatible with the > engine mounts that Van sells. > > The above info is completely speculative, and is offered without any > warrantee as to its accuracy. Use at your own risk. > > To view the TCDS, go to: http://www.airweb.faa.gov/tcds, then search > for IO-360. Scroll past the Continental IO-360s to find a link to a > Textron Lycoming IO-360 (there a gazillion links, one for each model > of Lycoming IO-360, but they all point to the same TCDS). You'll > have to click on one more link, then you'll end up viewing the TCDS. > > There is a section starting on page 15 that attempts to explain the > differences between the various models. The explanations can be a > misleading though, e.g. it says the IO-360-B1A is "Similar to > IO-360-A1A except has Simmonds Type 530 fuel injector. Does not have > tuned induction". That is very misleading, as the IO-360-A1A is a > 200 hp, angle-valve engine, and the IO-360-B1A is a 180 hp > parallel-valve engine. But if you stick with the 180 hp variants, I > think the story on the differences between models is probably OK. > > You can also buy a carbureted O-360, and add Airflow Performance Fuel > injection. This would be approximately equivalent to an IO-360-B1B. > -- > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > > ________________________________________________________________________________
Date: Mar 12, 2005
Received-SPF: none Kevin, I think you will have a very hard time finding an M-series engine as they have only been out for about three years. I am not sure if this is the same engine that they are using in the late model C-172 or not. If you can find a wrecked one, you can use the sump and tubes and then Van's stock exhaust will work. Jim ----- Original Message ----- From: "Kevin Williams" <kevinsky18(at)hotmail.com> Subject: Re: RV-List: Confused about IO-360 180hp engines. > > Thanks for the info it all helps alot. > > Ok so to keep the headaches down to a minimum I should really be looking > for > the M1B. I think this is a fairly new engine though and I suspect there > won't be many out there on the used market. > > Larry you made some very good points about whether I want and need an > inverted system. Now that it has been pointed out that I can do all I > want > to do with a standard no inverted system I'll probably drop the inverted > bit. > > > Kevin > > Yellowknife, NT, Canada > RV-8 Wanna Be Builder > > > From: "Jim Cimino" <jcimino(at)echoes.net> > To: > Subject: Re: RV-List: Confused about IO-360 180hp engines. > Date: Sat, 12 Mar 2005 13:33:38 -0500 > > > The only 180 HP fuel injected engine that is easy to install is the > M-series. All others have the servo in the bottom or rear of the sump and > are very tricky to set up the air system. I had purchased an IO-360-B1E > with rear facing injection and did not want to go through all the hassle > of > setting up the induction so I purchased a set of intake tubes and a 200 HP > sump and installed the sump with the servo now facing forward. The intake > tubes required modification to fit the 180 HP engine. This was long > before > the M-series was available, so there were no stock tubes that would fit. > New tubes are very expensive and I think you will have a hard time finding > a > used set for the 180-M. None of the brackets for the fuel and mixture > that > were available then would work so we had to make them also, and there is > no > stock exhaust that will fit my modification. I had Larry Vetermin build > an > exhaust for me. A friend of mine is building an RV-7 with the injection > on > the bottom and he is not happy with the induction so he is also doing what > I > did. From what he said and I have seen, the air filter set up that Van > sells for the injected engine will also need to be modified for the 180 HP > version even if you use the M-series engine. My engine with the modified > tubes has run great and many very experience pilots have commented on it's > smoothness. I did a flow test in flight and have found that the four > cylinders are within 2/10's of a gallon per hour of each other which > explains the smoothness. I installed a flop tube in the left take to give > it inverted fuel, but not the inverted oil system because I do not care > for > negative g's. As someone pointed out, you can do a lot and still keep it > in > the positive g's. You can even do limited inverted flight as long as you > give up altitude by pulling back slightly on the stick to give positive > g's. > I can not say what people are doing with the bottom mounted fuel > injection, > you may be able to use it with a scoop on the lower cowl. > Jim > > Jim Cimino > N7TL > RV-8 S/N 80039 > 15+ Hours > http://www.geocities.com/jcimino.geo/ > > > ----- Original Message ----- > From: "Kevin Horton" <khorton01(at)rogers.com> > To: > Subject: Re: RV-List: Confused about IO-360 180hp engines. > > > > > >> > >>Every time I think Ive got my engine decided, something comes up to > >>confuse > >>me. Im building a RV-8. I decided on an IO-360 180 HP engine. Im > >>going > >>to set it up for basic aerobatics so inverted oil system etc. Im also > >>going with a dual electronic ignition Lasar or Light speed. Im also > going > >>to have high compression pistons put in to bump up the power closer to > >>195hp. > >> > >>Ok So I thought I had it all figured out then I started looking around > for > >>a > >>good deal on a mid time engine and I cant believe how many different > >>versions of the IO-360 180hp engine there are. I see vans has the > >>IO-360 > >>M1B listed as the default 180hp engine. > >> > >>Is the M1B the only 180hp engine that will fit into the RV-8 without > >>modifying the plane? Are people buying non M1B engines and making > changes > >>to the engines so they meet M1B specs? If so what engines can be > >>bought > >>and converted to the M1B configuration and what engines just cant be > >>converted at all? > >> > >>Argh my head hurts!! Lol your input would be appreciated. > > > > The IO-360-M1A and M1B are the only 180 hp IO-360s that have the fuel > > injection servo mounted on the front of the oil sump. That allows it > > to be used with Van's "horizontal induction" air box, which means you > > get the cowling with the smooth front (i.e. there is no protruding > > inlet for engine induction air intake). > > > > Other 180 hp IO-360s will work, but they have the fuel injection > > servo mounted on the bottom of the oil sump, similar to most > > carbureted versions. You need the cowling with the air induction > > inlet sticking out the bottom. Van really designed this setup around > > a carbureted engine, so there might be a bit of air box rework to > > make it fit - other builders should be able to give a better story > > here. > > > > Looking at the FAA Type Certificate Data Sheet (TCDS) for the IO-360 > > engines, it looks like the following 180 hp IO-360s might work: > > > > IO-360-B1B > > IO-360-B1C > > IO-360-B1D > > IO-360-B1F > > IO-360-B1F6 > > IO-360-B2E (fixed pitch prop only) > > IO-360-B2F (fixed pitch prop only) > > IO-360-B2F6 (fixed pitch prop only) > > IO-360-B4A > > IO-360-E1A (type 2 Dynafocal mount) > > IO-360-F1A (modifications to allow turbo-charging - find out what > > the mods are before buying this one.). > > IO-360-M1A (front mounted fuel injection and front mounted prop > > governor). > > IO-360-M1B (front mounted fuel injection and rear mounted prop > governor). > > > > Other than the IO-360-M1A and M1B, all the above engines would have > > bottom mounted fuel injection servos. > > > > The following models look like they might cause grief: > > IO-360-B1A - it has Simmonds fuel injection, which is uncommon. I > > suspect you might have additional problems making it fit the airbox, > > etc. But I'm guessing here. > > > > IO-360-B1E - has different oil sump and induction manifolding. This > > might interfere with the engine mount. Further investigation needed. > > > > IO-360-B1G6 - has bed type engine mount. Not compatible with the > > engine mounts that Van sells. > > > > The above info is completely speculative, and is offered without any > > warrantee as to its accuracy. Use at your own risk. > > > > To view the TCDS, go to: http://www.airweb.faa.gov/tcds, then search > > for IO-360. Scroll past the Continental IO-360s to find a link to a > > Textron Lycoming IO-360 (there a gazillion links, one for each model > > of Lycoming IO-360, but they all point to the same TCDS). You'll > > have to click on one more link, then you'll end up viewing the TCDS. > > > > There is a section starting on page 15 that attempts to explain the > > differences between the various models. The explanations can be a > > misleading though, e.g. it says the IO-360-B1A is "Similar to > > IO-360-A1A except has Simmonds Type 530 fuel injector. Does not have > > tuned induction". That is very misleading, as the IO-360-A1A is a > > 200 hp, angle-valve engine, and the IO-360-B1A is a 180 hp > > parallel-valve engine. But if you stick with the 180 hp variants, I > > think the story on the differences between models is probably OK. > > > > You can also buy a carbureted O-360, and add Airflow Performance Fuel > > injection. This would be approximately equivalent to an IO-360-B1B. > > -- > > Kevin Horton RV-8 (finishing kit) > > Ottawa, Canada > > http://www.kilohotel.com/rv8 > > > > > > > > > ________________________________________________________________________________
Subject: Confused about IO-360 180hp engines.
Date: Mar 12, 2005
I bought an IO-360-B1B built by Aero Sport Power from Superior parts for my RV-8a. This is a nominal 180 hp engine with an Airflow Performance fuel injection system mounted on the bottom of the sump, and LightSpeed ignition on the right side. I am currently fitting the filtered air box, which I had to offset about 3/4" to the right to get it to line up with the air scoop in the cowl. This engine really seems to be designed for the RV-8/8a. I have encountered no real problems yet that were not due to me not knowing what I was doing. I would also suggest that Bart at Aero Sport Power in Kamloops would be an excellent source of information. He might also be able to rebuild or modify an engine that you might find used. Terry RV-8A Seattle -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kevin Williams Subject: Re: RV-List: Confused about IO-360 180hp engines. Thanks for the info it all helps alot. Ok so to keep the headaches down to a minimum I should really be looking for the M1B. I think this is a fairly new engine though and I suspect there won't be many out there on the used market. Larry you made some very good points about whether I want and need an inverted system. Now that it has been pointed out that I can do all I want to do with a standard no inverted system I'll probably drop the inverted bit. Kevin Yellowknife, NT, Canada RV-8 Wanna Be Builder > You can also buy a carbureted O-360, and add Airflow Performance Fuel > injection. This would be approximately equivalent to an IO-360-B1B. > -- > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > ________________________________________________________________________________
Date: Mar 12, 2005
Subject: Re: Confused about IO-360 180hp engines.
> >Kevin, > I think you will have a very hard time finding an M-series engine as they >have only been out for about three years. I am not sure if this is the same >engine that they are using in the late model C-172 or not. If you can find >a wrecked one, you can use the sump and tubes and then Van's stock exhaust >will work. The new C-172s have an IO-360-L2A, according to the C172 TCDS. The IO-360 TCDS says that this engine is similar to an IO-360-B2F, except for a lower rating (the standard rating of the L2A is 160 hp at 2400 rpm, although it has an alternate rating of 180 hp at 2700 rpm). Being similar to an IO-360-B2F means a bottom mounted fuel injection servo, and a fixed pitch prop. So, I'm not sure there is any advantage to finding one of these engines. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Mar 12, 2005
Wow, didn't expect all the varying responses. I did put all the responses in one word document for future reference. One thing someone told me was that with their powdwer coated panel, the tape wouldn't stick. I see the TZS is the super stick laminated tape, as opposed to just the TZ and it also comes in white on clear. So I thought I'd pass that along. I didn't see anything but the TZ in the local stores but you can order this super sticky stuff online cheaper than the normal stuff was in the local stores. Lucky TZS135 View Product Advisor 1/2" White on Clear Extra Strength Tape 4 of 20 matches Printer Friendly Version Estimated Street Price: $18.99 About This tape features our exclusive laminated tape process and our Extra Strength Adhesive with up to twice the adhesive strength of our Standard Laminated tapes. These labels stay on under both normal conditions and in harsh indoor and outdoor environments. Recommended for use on textured, rough or uneven surfaces. Great for slippery painted metal items or powder coated surfaces. Each tape is 26.2 ft. long. Wow, didn't expect all the varying responses. I did put all the responses in one word document for future reference. One thing someone told me was that with their powdwer coated panel, the tape wouldn't stick. I see the TZS is the super stick laminated tape, as opposed to just the TZ and it also comes in white on clear. So I thought I'd pass that along. I didn't see anything but the TZ in the local stores but you can order this super sticky stuff online cheaper than the normal stuff was in the local stores. Lucky TZS135 View Product Advisor http://www.advizia.com/brother/images/ButtonEnd.gif" width=5> 1/2" White on Clear Extra Strength Tape http://www.advizia.com/brother/images/PreviousArrow_On.gif" width=7 border=0> 4 of 20 matches http://www.advizia.com/brother/images/NextArrow_On.gif" width=7 border=0> Printer Friendly Version http://www.advizia.com/accountimages/145/1130/hires/TZS135.jpg" vspace=17> Estimated Street Price: $18.99 http://www.advizia.com/brother/images/clear.gif" width=4> http://www.advizia.com/brother/images/TabL_On.gif" width=3> About http://www.advizia.com/brother/images/TabR_On.gif" width=5> This tape features our exclusive laminated tape process and our Extra Strength Adhesive with up to twice the adhesive strength of our Standard Laminated tapes. These labels stay on under both normal conditions and in harsh indoor and outdoor environments. Recommended for use on textured, rough or uneven surfaces. Great for slippery painted metal items or powder coated surfaces. Each tape is 26.2 ft. long. http://www.advizia.com/accountimages/145/where2buy2.jpg" width=160 border=0> http://www.advizia.com/brother/images/clear.gif" width=15> http://www.advizia.com/accountimages/145/brothermall2.gif" border=0> ________________________________________________________________________________
Subject: lycoming breather tube
Date: Mar 12, 2005
Van's FW drawing shows the bottom bend of their breather tube facing forwards (looking kind of like a ram air effect is going on). They don't show any exhaust stack in relation to the breather tube. How important is it to mount the bend in the tube forward and should I have mounted the breather tube so that the overflow would have landed on the hot exhaust or just let the crap fall on the inside of the cowl? Also, they hint two adel clamps should be used but I only used one because I didn't want to hard mount the tube so much since it's attached to the shaking engine. Is that going to generally be OK or should I go with what Van's sort of drew? thx, lucky Van's FW drawing shows the bottom bend of their breather tube facing forwards (looking kind of like a ram air effect is going on). They don't show any exhaust stack in relation to the breather tube. How important is it to mount the bend in the tube forward and should I have mounted the breather tube so that the overflow would have landed on the hot exhaust or just let the crap fall on the inside of the cowl? Also, they hint two adel clamps should be used but I only used one because I didn't want to hard mount the tube so much since it's attached to the shaking engine. Is that going to generally be OK or should I go with what Van's sort ofdrew? thx, lucky ________________________________________________________________________________
Date: Mar 12, 2005
>Van's FW drawing shows the bottom bend of their breather tube facing >forwards (looking kind of like a ram air effect is going on). They don't >show any exhaust stack in relation to the breather tube. How important is >it to mount the bend in the tube forward and should I have mounted the >breather tube so that the overflow would have landed on the hot exhaust or >just let the crap fall on the inside of the cowl? > >Also, they hint two adel clamps should be used but I only used one because >I didn't want to hard mount the tube so much since it's attached to the >shaking engine. Is that going to generally be OK or should I go with what >Van's sort of drew? > > >thx, >lucky > I have my vent hose routed straight down and discharging directly over the top of one of the pipes maybe a couple of inches forward of the firewall plane. A short length of steel pipe is inserted into the hose (length of rubber radiator hose) and a single adel clamp mounts it to the engine mount. The remaining free length of rubber hose allows it to move with the wobbly shaky Lycosaur. Brian Denk RV8 N94BD RV10 '51 ________________________________________________________________________________
Date: Mar 12, 2005
I am building an RV-8 and I have an IO-360-A1A which I believe is 200HP. Are you telling me that it will not work? I also have a Hartzel CS prop. Bud Silvers -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kevin Horton Subject: Re: RV-List: Confused about IO-360 180hp engines. > >Every time I think Ive got my engine decided, something comes up to confuse >me. Im building a RV-8. I decided on an IO-360 180 HP engine. Im going >to set it up for basic aerobatics so inverted oil system etc. Im also >going with a dual electronic ignition Lasar or Light speed. Im also going >to have high compression pistons put in to bump up the power closer to >195hp. > >Ok So I thought I had it all figured out then I started looking around for a >good deal on a mid time engine and I cant believe how many different >versions of the IO-360 180hp engine there are. I see vans has the IO-360 >M1B listed as the default 180hp engine. > >Is the M1B the only 180hp engine that will fit into the RV-8 without >modifying the plane? Are people buying non M1B engines and making changes >to the engines so they meet M1B specs? If so what engines can be bought >and converted to the M1B configuration and what engines just cant be >converted at all? > >Argh my head hurts!! Lol your input would be appreciated. The IO-360-M1A and M1B are the only 180 hp IO-360s that have the fuel injection servo mounted on the front of the oil sump. That allows it to be used with Van's "horizontal induction" air box, which means you get the cowling with the smooth front (i.e. there is no protruding inlet for engine induction air intake). Other 180 hp IO-360s will work, but they have the fuel injection servo mounted on the bottom of the oil sump, similar to most carbureted versions. You need the cowling with the air induction inlet sticking out the bottom. Van really designed this setup around a carbureted engine, so there might be a bit of air box rework to make it fit - other builders should be able to give a better story here. Looking at the FAA Type Certificate Data Sheet (TCDS) for the IO-360 engines, it looks like the following 180 hp IO-360s might work: IO-360-B1B IO-360-B1C IO-360-B1D IO-360-B1F IO-360-B1F6 IO-360-B2E (fixed pitch prop only) IO-360-B2F (fixed pitch prop only) IO-360-B2F6 (fixed pitch prop only) IO-360-B4A IO-360-E1A (type 2 Dynafocal mount) IO-360-F1A (modifications to allow turbo-charging - find out what the mods are before buying this one.). IO-360-M1A (front mounted fuel injection and front mounted prop governor). IO-360-M1B (front mounted fuel injection and rear mounted prop governor). Other than the IO-360-M1A and M1B, all the above engines would have bottom mounted fuel injection servos. The following models look like they might cause grief: IO-360-B1A - it has Simmonds fuel injection, which is uncommon. I suspect you might have additional problems making it fit the airbox, etc. But I'm guessing here. IO-360-B1E - has different oil sump and induction manifolding. This might interfere with the engine mount. Further investigation needed. IO-360-B1G6 - has bed type engine mount. Not compatible with the engine mounts that Van sells. The above info is completely speculative, and is offered without any warrantee as to its accuracy. Use at your own risk. To view the TCDS, go to: http://www.airweb.faa.gov/tcds, then search for IO-360. Scroll past the Continental IO-360s to find a link to a Textron Lycoming IO-360 (there a gazillion links, one for each model of Lycoming IO-360, but they all point to the same TCDS). You'll have to click on one more link, then you'll end up viewing the TCDS. There is a section starting on page 15 that attempts to explain the differences between the various models. The explanations can be a misleading though, e.g. it says the IO-360-B1A is "Similar to IO-360-A1A except has Simmonds Type 530 fuel injector. Does not have tuned induction". That is very misleading, as the IO-360-A1A is a 200 hp, angle-valve engine, and the IO-360-B1A is a 180 hp parallel-valve engine. But if you stick with the 180 hp variants, I think the story on the differences between models is probably OK. You can also buy a carbureted O-360, and add Airflow Performance Fuel injection. This would be approximately equivalent to an IO-360-B1B. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com>
Date: Mar 12, 2005
-----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of flynlow(at)usaviator.net Subject: RE: RV-List: Confused about IO-360 180hp engines. I am building an RV-8 and I have an IO-360-A1A which I believe is 200HP. Are you telling me that it will not work? I also have a Hartzel CS prop. Bud Silvers Bud: The first factory -8 was built with a 200hp engine. Dana Overall's Feb flyin brought in several -8's with the 200hp engines. The first "snorkle" intake was developed for the forward looking servo on that aircraft. Gordon Comfort N363GC ________________________________________________________________________________
Date: Mar 12, 2005
I only listed 180 hp IO-360s, as that was what the original poster was interested in. The IO-360-A1A will be perfect. Kevin > >I am building an RV-8 and I have an IO-360-A1A which I believe is 200HP. Are >you telling me that it will not work? > >I also have a Hartzel CS prop. > >Bud Silvers > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kevin Horton >To: rv-list(at)matronics.com >Subject: Re: RV-List: Confused about IO-360 180hp engines. > > >> >>Every time I think Ive got my engine decided, something comes up to confuse >>me. Im building a RV-8. I decided on an IO-360 180 HP engine. Im going >>to set it up for basic aerobatics so inverted oil system etc. Im also >>going with a dual electronic ignition Lasar or Light speed. Im also going >>to have high compression pistons put in to bump up the power closer to >>195hp. >> >>Ok So I thought I had it all figured out then I started looking around for >a >>good deal on a mid time engine and I cant believe how many different >>versions of the IO-360 180hp engine there are. I see vans has the IO-360 >>M1B listed as the default 180hp engine. >> >>Is the M1B the only 180hp engine that will fit into the RV-8 without >>modifying the plane? Are people buying non M1B engines and making changes >>to the engines so they meet M1B specs? If so what engines can be bought >>and converted to the M1B configuration and what engines just cant be >>converted at all? >> >>Argh my head hurts!! Lol your input would be appreciated. > >The IO-360-M1A and M1B are the only 180 hp IO-360s that have the fuel >injection servo mounted on the front of the oil sump. That allows it >to be used with Van's "horizontal induction" air box, which means you >get the cowling with the smooth front (i.e. there is no protruding >inlet for engine induction air intake). > >Other 180 hp IO-360s will work, but they have the fuel injection >servo mounted on the bottom of the oil sump, similar to most >carbureted versions. You need the cowling with the air induction >inlet sticking out the bottom. Van really designed this setup around >a carbureted engine, so there might be a bit of air box rework to >make it fit - other builders should be able to give a better story >here. > >Looking at the FAA Type Certificate Data Sheet (TCDS) for the IO-360 >engines, it looks like the following 180 hp IO-360s might work: > >IO-360-B1B >IO-360-B1C >IO-360-B1D >IO-360-B1F >IO-360-B1F6 >IO-360-B2E (fixed pitch prop only) >IO-360-B2F (fixed pitch prop only) >IO-360-B2F6 (fixed pitch prop only) >IO-360-B4A >IO-360-E1A (type 2 Dynafocal mount) >IO-360-F1A (modifications to allow turbo-charging - find out what >the mods are before buying this one.). >IO-360-M1A (front mounted fuel injection and front mounted prop governor). >IO-360-M1B (front mounted fuel injection and rear mounted prop governor). > >Other than the IO-360-M1A and M1B, all the above engines would have >bottom mounted fuel injection servos. > >The following models look like they might cause grief: >IO-360-B1A - it has Simmonds fuel injection, which is uncommon. I >suspect you might have additional problems making it fit the airbox, >etc. But I'm guessing here. > >IO-360-B1E - has different oil sump and induction manifolding. This >might interfere with the engine mount. Further investigation needed. > >IO-360-B1G6 - has bed type engine mount. Not compatible with the >engine mounts that Van sells. > >The above info is completely speculative, and is offered without any >warrantee as to its accuracy. Use at your own risk. > >To view the TCDS, go to: http://www.airweb.faa.gov/tcds, then search >for IO-360. Scroll past the Continental IO-360s to find a link to a >Textron Lycoming IO-360 (there a gazillion links, one for each model >of Lycoming IO-360, but they all point to the same TCDS). You'll >have to click on one more link, then you'll end up viewing the TCDS. > >There is a section starting on page 15 that attempts to explain the >differences between the various models. The explanations can be a >misleading though, e.g. it says the IO-360-B1A is "Similar to >IO-360-A1A except has Simmonds Type 530 fuel injector. Does not have >tuned induction". That is very misleading, as the IO-360-A1A is a >200 hp, angle-valve engine, and the IO-360-B1A is a 180 hp >parallel-valve engine. But if you stick with the 180 hp variants, I >think the story on the differences between models is probably OK. > >You can also buy a carbureted O-360, and add Airflow Performance Fuel >injection. This would be approximately equivalent to an IO-360-B1B. >-- >Kevin Horton RV-8 (finishing kit) >Ottawa, Canada >http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Mar 12, 2005
Received-SPF: none Bud, There is no problem with A1A as far as I know, as long as the injector servo is facing forward. Jim Jim Cimino N7TL RV-8 S/N 80039 150+ Hours http://www.geocities.com/jcimino.geo/ ----- Original Message ----- From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com> Subject: RE: RV-List: Confused about IO-360 180hp engines. > > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of > flynlow(at)usaviator.net > To: rv-list(at)matronics.com > Subject: RE: RV-List: Confused about IO-360 180hp engines. > > > I am building an RV-8 and I have an IO-360-A1A which I believe is 200HP. > Are you telling me that it will not work? > > I also have a Hartzel CS prop. > > Bud Silvers > > Bud: The first factory -8 was built with a 200hp engine. Dana > Overall's Feb flyin brought in several -8's with the 200hp engines. The > first "snorkle" intake was developed for the forward looking servo on > that aircraft. > > Gordon Comfort > N363GC > > > ________________________________________________________________________________
Date: Mar 12, 2005
Subject: ACS MAP Hose
I'm starting to install the ACS Engine Monitor on my TXM-360 (read O-360) . . . the MAP Sensor they sent looks like you would just camp a hose on it. I planned to come off the engine with a 37 degree fitting, but maybe that's overkill? How did other hook up their MAP to the ACS unit? Thanks, Bob Christensen RV-8 to be N678RC - Engine / Panel / Finishing (Slowly!) ________________________________________________________________________________
Subject: #8 screws edge distance question
Date: Mar 12, 2005
Does the same general rules for edge distance for rivets also apply to screws and platenuts? I just started working on my RV-8 QB fuse and am installing the flooring with #8 screws and platenuts as called out in the plans. When I trial fit the 829APP prepunched floor skin, the #8 screw holes line up outboard of the centerlines on both right and left sides. The best I can get is 1/4 edge distance to the center of the #8 screw holes. Will this work? Thanks in advance for the replies. -Mike Draper RV-8 QB Fuse Does the same general rules for edge distance for rivets also apply to screws and platenuts? I just started working on my RV-8 QB fuse and am installing the flooring with #8 screws and platenuts as called out in the plans. When I trial fit the 829APPprepunched floor skin, the #8 screw holes line up outboard of the centerlines on both right and left sides. The best I can get is 1/4 edge distance to the center of the #8 screw holes. Will this work? Thanks in advance for the replies. -Mike Draper RV-8 QB Fuse ________________________________________________________________________________
Date: Mar 12, 2005
Subject: Re: CherryMax Rivets
In a message dated 3/12/05 5:46:39 AM Pacific Standard Time, kevinsky18(at)hotmail.com writes: << What are "CherryMax" rivets. I read on a web site that a builder was using the but I have no idea what they are. >> They are a high quality blind rivet that can be substituted for a solid rivet in some applications. The oversize ones are roughly equivalent in shear strength to a solid rivet of that nominal size. Check your Aircraft Spruce catalog on page 96 for a brief description and a list of the ones they carry. The CherryMax grip gauge is a must for proper determination of grip length when using CherryMax rivets. Harry Crosby Pleasanton, California RV-6, flying! ________________________________________________________________________________
Subject: Re: lycoming breather tube
Date: Mar 12, 2005
Let's get something clear. Are you talking about the air/oil breather tube, the tank vents, or the mechanical fuel pump breather tube? The air-oil breather tube should exit close to the hot exhaust stack to minimize oil build up on the belly. The fuel pump breather should never exit anywhere near the hot exhaust for obvious reasons. The only forward bend I know of in the fuel tank vents to the outboard sides of the belly. Yes they do build a ram positive pressure of about 1/2 psi. This adds to the overall pressure on your fuel pressure guage. If you don't have the fuel vent line open end inside the tank high enough out of the fuel, it will dump overboard when the tanks are full especially on a hot sunny day when your tank is facing the sun. Happens more often on un-painted RV's. If this happens, reach inside the tank and try to bend the line up slightly more inside the tank. It is easy to do. LN RV6 Flying since last July ----- Original Message ----- From: "Brian Denk" <akroguy(at)hotmail.com> Subject: RE: RV-List: lycoming breather tube > > >>Van's FW drawing shows the bottom bend of their breather tube facing >>forwards (looking kind of like a ram air effect is going on). They don't >>show any exhaust stack in relation to the breather tube. How important is >>it to mount the bend in the tube forward and should I have mounted the >>breather tube so that the overflow would have landed on the hot exhaust or >>just let the crap fall on the inside of the cowl? >> >>Also, they hint two adel clamps should be used but I only used one because >>I didn't want to hard mount the tube so much since it's attached to the >>shaking engine. Is that going to generally be OK or should I go with what >>Van's sort of drew? >> >> >>thx, >>lucky >> > > I have my vent hose routed straight down and discharging directly over the > top of one of the pipes maybe a couple of inches forward of the firewall > plane. A short length of steel pipe is inserted into the hose (length of > rubber radiator hose) and a single adel clamp mounts it to the engine > mount. > The remaining free length of rubber hose allows it to move with the > wobbly > shaky Lycosaur. > > Brian Denk > RV8 N94BD > RV10 '51 > > > ________________________________________________________________________________
Date: Mar 12, 2005
Subject: Re: White Letters for Panel
Date: Mar 13, 2005
8 years ago, I had the the entire panel engraved for $135 US. I painted the panel then used a paint stick to make the letters white. I used the Brother Label Maker to make other permanent labels. (fuel selector, Remote PTT, Headset jack, mic jack, Do Not Step, etc. and they are still good after 7 years of flying) The Brother Labels are great and resist just about everything. I tried Jasco Paint Stripper on a set of labels. It removed the paint but not the labels. White on Clear is not available for all models. I purchased a replacement Brother label maker at Christmas for less than $20 US. My old one would work on AC but would not work on batteries any more. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,642 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ________________________________________________________________________________
Date: Mar 13, 2005
Subject: Cheap Navaid servo for sale?
I've been told that a number of people are changing from Navaid to TruTrak and thus have Navaid servos for sale. I'm interested in aquiring a servo (only) cheap ($200 or less). A $75 1/3 scale RC servo was suggested, but apparently does not have a clutch. Any other souces for a cheap servo? (For a home-brewed wing-leveller. I prefer not having springs hindering stick movement.) Finn ________________________________________________________________________________
Date: Mar 12, 2005
Subject: Re: Cheap Navaid servo for sale?
Finn Lassen wrote: > >I've been told that a number of people are changing from Navaid to >TruTrak and thus have Navaid servos for sale. > >I'm interested in aquiring a servo (only) cheap ($200 or less). > >A $75 1/3 scale RC servo was suggested, but apparently does not have a >clutch. > >Any other souces for a cheap servo? (For a home-brewed wing-leveller. I >prefer not having springs hindering stick movement.) > >Finn > > > Have you tried the spring setup? It does work very well. I believe that most people that are changing to TruTrak are keeping the servos and just replacing the gyros. Jerry ________________________________________________________________________________
Subject: Re: ACS MAP Hose
Date: Mar 13, 2005
Bob, FWIW, here's my setup...the ACS2002's MAP sensor is behind the firewall. I wasn't sure if it's designed to withstand high temperatures, and it was no sweat to install it behind the firewall. Figured I'd err on the conservative side. On cylinder #3 I used the 45-degree AN fitting that Van's called out. From there I used the hose provided in the FWF kit to run between #3 and the bulkhead restrictor fitting also provided with the FWF kit. Photo here: http://rvproject.com/images/2003/20030720_man_press_hose.jpg If I didn't have Lightspeed ignition, from the firewall fitting I would have just run tubing between the barbed end on the firewall and the barbed end on the MAP sensor. Since I do have Lightspeed ignition, I ran tubing from the firewall fitting, teed it out, one end to the Lightspeed, the other end to the ACS2002's MAP sensor. See the photos about 1/2 way down this page: http://www.rvproject.com/20030729.html Sounds convoluted, but it's pretty straightforward. Not sure if this is the info you were after or not. Hope it helps. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Bob C. " <flyboy.bob(at)gmail.com> Subject: RV-List: ACS MAP Hose > > I'm starting to install the ACS Engine Monitor on my TXM-360 (read > O-360) . . . the MAP Sensor they sent looks like you would just camp > a hose on it. I planned to come off the engine with a 37 degree > fitting, but maybe that's overkill? > > How did other hook up their MAP to the ACS unit? > > Thanks, > Bob Christensen > RV-8 to be N678RC - Engine / Panel / Finishing (Slowly!) > > ________________________________________________________________________________
Date: Mar 13, 2005
Jerry Springer wrote: > >Finn Lassen wrote: > > > >> >>I've been told that a number of people are changing from Navaid to >>TruTrak and thus have Navaid servos for sale. >> >>I'm interested in aquiring a servo (only) cheap ($200 or less). >> >>A $75 1/3 scale RC servo was suggested, but apparently does not have a >>clutch. >> >>Any other souces for a cheap servo? (For a home-brewed wing-leveller. I >>prefer not having springs hindering stick movement.) >> >>Finn >> >> >> >> >> >Have you tried the spring setup? It does work very well. I believe that >most people that are changing to TruTrak >are keeping the servos and just replacing the gyros. > >Jerry > Jerry, I'm having a hard time believeing that springs strong enough to keep wings leveled in turbulence will not be noticable when doing aileron rolls and such. Finn ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Mar 13, 2005
----- Original Message ----- From: "Finn Lassen" <finn.lassen(at)verizon.net> Subject: Re: RV-List: Cheap Navaid servo for sale? > > Jerry Springer wrote: > >> >>Finn Lassen wrote: <<<>>> >>> >>Have you tried the spring setup? It does work very well. I believe that >>most people that are changing to TruTrak >>are keeping the servos and just replacing the gyros. >> >>Jerry >> > Jerry, > I'm having a hard time believeing that springs strong enough to keep > wings leveled in turbulence will not be noticable when doing aileron > rolls and such. > > Finn Finn, The spring system is unnoticable in flight. That said, it is a trim system and not a wing leveler. KB ________________________________________________________________________________
Date: Mar 13, 2005
From: "Richard V. Reynolds" <rvreynolds(at)macs.net>
Subject: AFM Supplement for GPS IFR Operations / Limitation
Reference AIM 1-1-19, d. General Requirements For experimental aircraft operating with an IFR GPS, is a FAA Approved Aircraft Flight Manual Supplement for the GPS required for "legal" operation? The Aircraft Flight Manual (AFM) is the new name for the old Pilot Operating Handbook (POH). The AFM supplement for the GPS lists operational limitation of the IFR GPS. Inquiring minds want to know. Richard Reynolds Norfolk, VA, RV-6A, about to fly IFR ________________________________________________________________________________
Date: Mar 13, 2005
It may seem somewhat wierd considering you don't need to have an AFM but if you have an IFR GPS and are using it for IFR then the supplement must be carried on board the aircraft during IFR ops. that is because it is part of the STC and is approved. Mike Robertson >From: "Richard V. Reynolds" <rvreynolds(at)macs.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: AFM Supplement for GPS IFR Operations / Limitation >Date: Sun, 13 Mar 2005 10:12:54 -0500 > > >Reference AIM 1-1-19, d. General Requirements > >For experimental aircraft operating with an IFR GPS, is a FAA Approved >Aircraft Flight Manual Supplement for the GPS required for "legal" >operation? > >The Aircraft Flight Manual (AFM) is the new name for the old Pilot >Operating Handbook (POH). > >The AFM supplement for the GPS lists operational limitation of the IFR >GPS. > >Inquiring minds want to know. > >Richard Reynolds >Norfolk, VA, RV-6A, about to fly IFR > > ________________________________________________________________________________
From: "Karen and Robert Brown" <bkbrown(at)ashcreekwireless.com>
Date: Mar 13, 2005
I used a bulkhead AN-to-hose barb fitting. I mounted the ACS MAP sensor inside the cockpit. I'll run the hose coming off the engine to the bulkhead fitting placed in the firewall, then come off of hose barb side (cockpit side) with tubing which will connect to the ACS MAP sensor. Bob Brown RV7A - wiring ________________________________________________________________________________
Date: Mar 13, 2005
For what it's worth... I use the Rocky Mountain MAP sensor, which is used by several different auto manufacturors. I mounted my on my engine mount with a couple of adel clamps and it is holding up well in that environment. Karen and Robert Brown wrote: > >I used a bulkhead AN-to-hose barb fitting. I mounted the ACS MAP sensor inside the cockpit. I'll run the hose coming off the engine to the bulkhead fitting placed in the firewall, then come off of hose barb side (cockpit side) with tubing which will connect to the ACS MAP sensor. > >Bob Brown >RV7A - wiring > > > > ________________________________________________________________________________
Date: Mar 13, 2005
I don't notice my springs in flight. The aerodynamic loads on the control surfaces pretty much masks the spring tension. The springs just aren't that strong. Kyle Boatright wrote: > > >----- Original Message ----- >From: "Finn Lassen" <finn.lassen(at)verizon.net> >To: "ax; PROMO" >Subject: Re: RV-List: Cheap Navaid servo for sale? > > > > >> >>Jerry Springer wrote: >> >> >> >>> >>>Finn Lassen wrote: >>> >>> ><<<>>> > > >>>Have you tried the spring setup? It does work very well. I believe that >>>most people that are changing to TruTrak >>>are keeping the servos and just replacing the gyros. >>> >>>Jerry >>> >>> >>> >>Jerry, >>I'm having a hard time believeing that springs strong enough to keep >>wings leveled in turbulence will not be noticable when doing aileron >>rolls and such. >> >>Finn >> >> > >Finn, > >The spring system is unnoticable in flight. That said, it is a trim system >and not a wing leveler. > >KB > > > > ________________________________________________________________________________
Date: Mar 13, 2005
My install manual says it's OK to mount the MAP sensor on the firewall . . . it would seem simpler to run the wires along with all the others rather than a hose through the firewall? I'm I missing something? Thanks, Bob wrote: > > I used a bulkhead AN-to-hose barb fitting. I mounted the ACS MAP sensor inside the cockpit. I'll run the hose coming off the engine to the bulkhead fitting placed in the firewall, then come off of hose barb side (cockpit side) with tubing which will connect to the ACS MAP sensor. > > Bob Brown > RV7A - wiring > > > > ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Subject: Simulator Software for KLN90B ???
Date: Mar 13, 2005
Just checking collective knowledge for help. Is there a simulator for the KLN90B that can be downloaded and used at home to learn the system? It looks like Shorty's might have something for $5 but wonder if it's even worth the trouble? Thanks Bill S 7a Arkansas ________________________________________________________________________________
Date: Mar 13, 2005
Subject: Re: RV-8 Empennage - HS-405 edge distance
Alan I ran into this problem on my 8A as well. I asked my local RV guru what to do. He suggested I make what are called "scab flanges" for the HS-405s. I simply made new forward flanges out of some scrap 2024-T3 (same thickness as the rib). Cut the original forward flanges off, and locate and rivet the scab flanges on. Locate them to obtain proper edge distance as needed. I'll send you a few photos of this "off list". Charlie Kuss > > >All, > >I'm working on the RV-8 empennage. Reference drawing 3, you can see where >the HS-702, HS-405, and HS-801PP all overlap. > >After drilling the skin to the skeleton and then disassembling, I notice >that the hole that goes through those three items does not meet minimum >edge distance on the HS-405 towards the front edge of the flange (both top >and bottom). This hole is the one that is in the seamed area of the >HS-405. > >The holes in HS-702 are down the centerline of the flange, so I'm not sure >where the alignment problem is. > >If I were to rebend the front and rear flanges of HS-405 slightly to shift >the web of HS-405 forward, then I start getting into the edge distance on >the top and bottom flanges at the rear end instead of the front. > >Any thoughts on what's going on here? Has anyone else seen this, and if >so, how did you correct it? > >-- >Alan Reichert >RV-8 N927AR (reserved) >Building Horizontal/Vertical Stabilizers > > ________________________________________________________________________________
Date: Mar 13, 2005
Finn Lassen wrote: > >Jerry Springer wrote: > > > >> >>Finn Lassen wrote: >> >> >> >> >> >>> >>>I've been told that a number of people are changing from Navaid to >>>TruTrak and thus have Navaid servos for sale. >>> >>>I'm interested in aquiring a servo (only) cheap ($200 or less). >>> >>>A $75 1/3 scale RC servo was suggested, but apparently does not have a >>>clutch. >>> >>>Any other souces for a cheap servo? (For a home-brewed wing-leveller. I >>>prefer not having springs hindering stick movement.) >>> >>>Finn >>> >>> >>> >>> >>> >>> >>> >>Have you tried the spring setup? It does work very well. I believe that >>most people that are changing to TruTrak >>are keeping the servos and just replacing the gyros. >> >>Jerry >> >> >> >Jerry, >I'm having a hard time believeing that springs strong enough to keep >wings leveled in turbulence will not be noticable when doing aileron >rolls and such. > >Finn > Hi Finn, I flew my 1st -4 both with & without Van's spring kit. On the ground the springs will move the stick when you move the trim control. In the air, I could never tell the difference. My only complaint with Van's system was that the springs weren't strong enough to completely counter roll from fuel imbalance. But.. I doubt you could use springs in an autopilot because it would be chasing itself constantly in turbulence. Kind of 'auto-PIO'. I once owned a Thorp T-18 with roll trim/autopilot using a very small r/c servo driving a tab on the trailing edge of one aileron. There is obviously an added risk of flutter if you do this but it was never a problem on the Thorp. Charlie ________________________________________________________________________________
Subject: Aileron trim
Date: Mar 13, 2005
Actually, I was concerned about this as well, but the spring system is *not* noticeable in flight for a very simple (once you see it in action) reason. There are two opposing springs, under tension that hold the stick in place. So the tension in one spring cancels out the tension of the other. It really does work very well. Ed > > > >Have you tried the spring setup? It does work very well. I believe that > > >most people that are changing to TruTrak > > >are keeping the servos and just replacing the gyros. > > > > > >Jerry > > > > > Jerry, > > I'm having a hard time believeing that springs strong enough to keep > > wings leveled in turbulence will not be noticable when doing aileron > > rolls and such. > > > > Finn -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Subject: Lost power on takeoff again
Date: Mar 13, 2005
I replaced the carb with OH unit, and this morn had the same failure, lost power 4-5 sec into takeoff run. pulled the mixture control to about where it is at cruise and it started running again. I ran up and did mag checks couple times with mix at norm and it was ok. I had made two flights after carb change before this with no problem. One common thing between this and when it happened before I swapped carb, is it was much warmer than usual both times, and it was following a long taxie both times as well. Any Ideas? (cut short a very nice morn for flying) charlie heathco ________________________________________________________________________________
Subject: NavAid Auto pilot servo and head for sale
Date: Mar 13, 2005
Used 2 year old NavAid system includes servo, head and internal smart coupler to track your GPS signal. 120 hours since new, will demo in Jupiter, FL. New $1350, asking $900. Mint condition. Warmest Regards, Bob Gross For the latest F1 Rocket/Synthetic Vision progress, click here... www.F1-RocketBoy.com <http://www.f1-rocketboy.com/> -----Disclaimer--------- The contents of this E-mail (including contents of enclosure/(s) or attachment/(s) if any are privileged & confidential material of Innovative Aviation Systems Inc. or RocketBoy Aircraft Products Inc. and should not be disclosed to, used by, or copied in any manner by anyone other than intended addressee/(s).If this E-mail (including enclosure/(s) or attachment/(s) if any has been received in error, please advise sender immediately and delete it from your system. The views expressed in this E-mail message (including enclosure/(s) or attachment/(s) if any are those of the individual sender. ________________________________________________________________________________
Subject: Re: Lost power on takeoff again
Date: Mar 13, 2005
Received-SPF: none It sounds like it is running too rich, have you confirmed that you only a slight rpm increase before it shuts down when you pull your mixture? Jim Jim Cimino N7TL RV-8 S/N 80039 150+ Hours http://www.geocities.com/jcimino.geo/ ----- Original Message ----- From: "Charles Heathco" <cheathco(at)comcast.net> Subject: RV-List: Lost power on takeoff again > > I replaced the carb with OH unit, and this morn had the same failure, lost > power 4-5 sec into takeoff run. pulled the mixture control to about where > it is at cruise and it started running again. I ran up and did mag checks > couple times with mix at norm and it was ok. I had made two flights after > carb change before this with no problem. One common thing between this and > when it happened before I swapped carb, is it was much warmer than usual > both times, and it was following a long taxie both times as well. Any > Ideas? (cut short a very nice morn for flying) charlie heathco > > > ________________________________________________________________________________
Date: Mar 13, 2005
Charles Heathco wrote: > >I replaced the carb with OH unit, and this morn had the same failure, lost power 4-5 sec into takeoff run. pulled the mixture control to about where it is at cruise and it started running again. I ran up and did mag checks couple times with mix at norm and it was ok. I had made two flights after carb change before this with no problem. One common thing between this and when it happened before I swapped carb, is it was much warmer than usual both times, and it was following a long taxie both times as well. Any Ideas? (cut short a very nice morn for flying) charlie heathco > > > > Sounds like Vapor lock, check heat sources around your fuel lines and fuel pump. Jerry ________________________________________________________________________________
Date: Mar 13, 2005
STC = Supplemental Type Certificate. Experiments don't have a Type Certificate, so how can you get an STC, and why would you need one? Kevin Horton > >It may seem somewhat wierd considering you don't need to have an AFM but if >you have an IFR GPS and are using it for IFR then the supplement must be >carried on board the aircraft during IFR ops. that is because it is part of >the STC and is approved. > >Mike Robertson > >>From: "Richard V. Reynolds" <rvreynolds(at)macs.net> >>Reply-To: rv-list(at)matronics.com >>To: rv-list(at)matronics.com >>Subject: RV-List: AFM Supplement for GPS IFR Operations / Limitation >>Date: Sun, 13 Mar 2005 10:12:54 -0500 >> >> >>Reference AIM 1-1-19, d. General Requirements >> >>For experimental aircraft operating with an IFR GPS, is a FAA Approved >>Aircraft Flight Manual Supplement for the GPS required for "legal" >>operation? >> >>The Aircraft Flight Manual (AFM) is the new name for the old Pilot >>Operating Handbook (POH). >> >>The AFM supplement for the GPS lists operational limitation of the IFR >>GPS. >> >>Inquiring minds want to know. >> >>Richard Reynolds > >Norfolk, VA, RV-6A, about to fly IFR > > ________________________________________________________________________________
Subject: Re: Auto Pilots
Date: Mar 13, 2005
Hi Bill, Just got back from week end with Tracy and Laura Crook - great as always. Yes, I found some code for an "Inverted Pendulum" that looks like it will provide a basis for the PID code. They do some neat tricks with clock frequency and sampling rates to make the math (shifts) much quicker. Yes, the 1/3 scale model servos produce torque equal and greater than that shown in the autopilot specs on servos - so no problem there. However, I have not been able to find one with any type of clutch which as you indicate is desirable. My initial thoughts on that aspect of the problem is to have the servo push a rod that goes through a hole in a tab attached to aileron bell crank. The rod would have springs on both sides of the tab (conceptually similar to Van's elCheapo spring trim system which I use in my RV-6A). However, there are some problems with that concept, so don't know if that would work, but might be worth a try. On the otherhand adapting a magnetic clutch might be a more elegant way to go. Thanks for the suggestions Ed Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ----- Original Message ----- From: "Bill Dube" <bdube(at)al.noaa.gov> Subject: Re: Roll your own auto pilot? Re: RV-List: Auto Pilots > > > > >I am currently playing with a design for a heading hold -wing leveler. I > >have the electronic components mocked up in a electronic simulation (PSPICE) > >at this point. I am still debating whether to go with the analog approach > >or the digital using a PIC Microchip. The digital clearly offers more move > >for growth and change but the complexity of the algorithms are a bit much. > >The analog looks to be more straight forward - but with limited growth > >capability. > > You can easily find PID code for the PIC or nearly any other > embedded controller. Use that stock code as the core for your system and > you will save yourself a ton of programming and de-bugging work. > > > > I am looking to make a simply (inexpensive) system that will start out as > >an manual electric aileron trim and progress from there. I believe that a > >Cascading set of simple OpAmp PID controllers looks to be the best bet (and > >least expensive) for smooth operation. This is basically two control > >loops - the outside loop would be comparing a heading signal to your set > >heading the difference would generally a roll angle requirement this would > >feed to the inside loop where the current roll angle would be compared to > >the command roll and if a difference exists the inner list would generate a > >roll rate command which would end up driving the servo. > > That makes sense. Feed in the rate sensor information to the inner > loop to keep it stable and reduce the sensitivity to noise on the heading > input. Easier to do digitally, by the way. > > > A small difference > >in heading would generate a small roll rate and a larger difference a faster > >roll rate (with limits of course - probably 15 deg max). Obviously quite a > >bit more complex than this brief description - but that's the general idea. > >The Unit is intended for VFR ONLY and will probably use a 1/3 scale model > >aircraft servo. > > Would that have the torque needed? Also, how do you plan to clutch > the servo to allow manual over-ride? > > ________________________________________________________________________________
Date: Mar 13, 2005
Thanks Charlie! This sounds like a very sensible solution. Do you know if, in case of power loss to the servo, will an R/C servo exert enough hold (resistance) on the trim tab to prevent tab induced flutter. I know next to nothing about R/C servos but imagine that if it's geared it should resist movement. Could also be an incentive for me to rebuild my crooked left aileron. (Are you listening Ed Anderson?) Finn Charlie England wrote: >I once owned a Thorp T-18 with roll trim/autopilot using a very small >r/c servo driving a tab on the trailing edge of one aileron. There is >obviously an added risk of flutter if you do this but it was never a >problem on the Thorp. > >Charlie > > ________________________________________________________________________________
Date: Mar 13, 2005
Yes, Listening Finn. Since I do not intend to control roll with an aileron trim tab, flutter is not one of my concerns. I intend to use an 1/3 RC servo to push a rod which in turn pushes a tab on the aileron bell crank - so no additional mass out on the control surface. So perhaps other problems, but don't expect flutter to be one of them. Great seeing you again at the Flyin and Tracy's Finn. Hope you get back from your trip to make it to Sun & Fun. Made it back to Charlotte from Tracy's in 2 hours 45 minutes, so even had a small tail wind component to help this day. Ed Subject: Re: RV-List: Cheap Navaid servo for sale? > > Thanks Charlie! > > This sounds like a very sensible solution. Do you know if, in case of > power loss to the servo, will an R/C servo exert enough hold > (resistance) on the trim tab to prevent tab induced flutter. I know next > to nothing about R/C servos but imagine that if it's geared it should > resist movement. > > Could also be an incentive for me to rebuild my crooked left aileron. > > (Are you listening Ed Anderson?) > > Finn > > Charlie England wrote: > > >I once owned a Thorp T-18 with roll trim/autopilot using a very small > >r/c servo driving a tab on the trailing edge of one aileron. There is > >obviously an added risk of flutter if you do this but it was never a > >problem on the Thorp. > > > >Charlie > > > > > > ________________________________________________________________________________
Date: Mar 13, 2005
Charlie, Check your primer system. If you have not already ruled this out. Leaking primer pump or valve can cause the richer than normal condition. Mike Mckenna > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Heathco > To: rv-list(at)matronics.com > Subject: RV-List: Lost power on takeoff again > > > I replaced the carb with OH unit, and this morn had the same failure, > lost power 4-5 sec into takeoff run. pulled the mixture control to about > where it is at cruise and it started running again. I ran up and did mag > checks couple times with mix at norm and it was ok. I had made two > flights after carb change before this with no problem. One common thing > between this and when it happened before I swapped carb, is it was much > warmer than usual both times, and it was following a long taxie both > times as well. Any Ideas? (cut short a very nice morn for flying) > charlie heathco ________________________________________________________________________________
Date: Mar 13, 2005
what about vapor lock ________________________________________________________________________________
Date: Mar 13, 2005
Subject: Starter Switch Problem
Listers, Anybody have a diagram for the OFF-LEFT-RIGHT-BOTH-START key switch. I have power to the terminal marked "Bat" and no power at the terminal marked "S" when I turn it to the start position. I have only a hand drawn diagram that I used. Wondering if it is right. Shoot, I was gonna fire this thing, what a let down. Thanks Tim Bryan -6 N616TB ________________________________________________________________________________
Date: Mar 13, 2005
Hi Charlie, Are you running 100LL or mogas? Just a thought... Good luck with the troubleshooting! ________________________________________________________________________________
Date: Mar 13, 2005
Subject: Re: Starter Switch Problem
Tim, Sounds like you have it wired right. You probably have a bad switch or something else is miswired. Dave B Tim Bryan wrote: > > > Listers, >Anybody have a diagram for the OFF-LEFT-RIGHT-BOTH-START key switch. I have >power to the terminal marked "Bat" and no power at the terminal marked "S" >when I turn it to the start position. I have only a hand drawn diagram that >I used. Wondering if it is right. > >Shoot, I was gonna fire this thing, what a let down. > >Thanks >Tim Bryan >-6 N616TB > > > > ________________________________________________________________________________
Date: Mar 13, 2005
Kevin & Kevin, I was just browsing EBay. I came across an IO-360-B1E sump for sale. It is a horizontal, rear mount unit, so it definitely WON'T work on an RV. Charlie Kuss >snipped > >Is the M1B the only 180hp engine that will fit into the RV-8 without > >modifying the plane? Are people buying non M1B engines and making changes > >to the engines so they meet M1B specs? If so what engines can be bought > >and converted to the M1B configuration and what engines just cant be > >converted at all? > > > >Argh my head hurts!! Lol your input would be appreciated. > >The IO-360-M1A and M1B are the only 180 hp IO-360s that have the fuel >injection servo mounted on the front of the oil sump. That allows it >to be used with Van's "horizontal induction" air box, which means you >get the cowling with the smooth front (i.e. there is no protruding >inlet for engine induction air intake). > >Other 180 hp IO-360s will work, but they have the fuel injection >servo mounted on the bottom of the oil sump, similar to most >carbureted versions. You need the cowling with the air induction >inlet sticking out the bottom. Van really designed this setup around >a carbureted engine, so there might be a bit of air box rework to >make it fit - other builders should be able to give a better story >here. > >Looking at the FAA Type Certificate Data Sheet (TCDS) for the IO-360 >engines, it looks like the following 180 hp IO-360s might work: > >IO-360-B1B >IO-360-B1C >IO-360-B1D >IO-360-B1F >IO-360-B1F6 >IO-360-B2E (fixed pitch prop only) >IO-360-B2F (fixed pitch prop only) >IO-360-B2F6 (fixed pitch prop only) >IO-360-B4A >IO-360-E1A (type 2 Dynafocal mount) >IO-360-F1A (modifications to allow turbo-charging - find out what >the mods are before buying this one.). >IO-360-M1A (front mounted fuel injection and front mounted prop governor). >IO-360-M1B (front mounted fuel injection and rear mounted prop governor). > >Other than the IO-360-M1A and M1B, all the above engines would have >bottom mounted fuel injection servos. > >The following models look like they might cause grief: >IO-360-B1A - it has Simmonds fuel injection, which is uncommon. I >suspect you might have additional problems making it fit the airbox, >etc. But I'm guessing here. > >IO-360-B1E - has different oil sump and induction manifolding. This >might interfere with the engine mount. Further investigation needed. > >IO-360-B1G6 - has bed type engine mount. Not compatible with the >engine mounts that Van sells. > >The above info is completely speculative, and is offered without any >warrantee as to its accuracy. Use at your own risk. > >To view the TCDS, go to: http://www.airweb.faa.gov/tcds, then search >for IO-360. Scroll past the Continental IO-360s to find a link to a >Textron Lycoming IO-360 (there a gazillion links, one for each model >of Lycoming IO-360, but they all point to the same TCDS). You'll >have to click on one more link, then you'll end up viewing the TCDS. > >There is a section starting on page 15 that attempts to explain the >differences between the various models. The explanations can be a >misleading though, e.g. it says the IO-360-B1A is "Similar to >IO-360-A1A except has Simmonds Type 530 fuel injector. Does not have >tuned induction". That is very misleading, as the IO-360-A1A is a >200 hp, angle-valve engine, and the IO-360-B1A is a 180 hp >parallel-valve engine. But if you stick with the 180 hp variants, I >think the story on the differences between models is probably OK. > >You can also buy a carbureted O-360, and add Airflow Performance Fuel >injection. This would be approximately equivalent to an IO-360-B1B. >-- >Kevin Horton RV-8 (finishing kit) >Ottawa, Canada >http://www.kilohotel.com/rv8 > > ________________________________________________________________________________
Date: Mar 13, 2005
Did you try turning completely to the right and then push in? The wiring diagram is in the Aircraft Spruce Catalog. If you go to the starter solenoid. Does the starter engage if you apply power to the starter terminal. If it has two small terminals, sometimes the 2nd one has to grounded. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: "Tim Bryan" <flyrv6(at)bryantechnology.com> Subject: RV-List: Starter Switch Problem > > > Listers, > Anybody have a diagram for the OFF-LEFT-RIGHT-BOTH-START key switch. I > have > power to the terminal marked "Bat" and no power at the terminal marked "S" > when I turn it to the start position. I have only a hand drawn diagram > that > I used. Wondering if it is right. > > Shoot, I was gonna fire this thing, what a let down. > > Thanks > Tim Bryan > -6 N616TB > > > ________________________________________________________________________________
Subject: Got Wax?
Date: Mar 13, 2005
After 4 years, I think the paint on my airplane has finally cured well enough that it may be time for a wax job. Anyone got a recommendation for the perfect wax? Inexpensive, easy to apply, and leaves a nice finish? I'm hoping someone can recommend a good liquid wax. I simply don't have the time or energy right now to use one of the paste waxes... Thanks in advance, KB ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Mar 13, 2005
> > > I replaced the carb with OH unit, and this morn had the same > failure, lost power 4-5 sec into takeoff run. pulled the > mixture control to about where it is at cruise and it started > running again. I ran up and did mag checks couple times with > mix at norm and it was ok. I had made two flights after carb > change before this with no problem. One common thing between > this and when it happened before I swapped carb, is it was > much warmer than usual both times, and it was following a > long taxie both times as well. Any Ideas? (cut short a very > nice morn for flying) charlie heathco Charlie, a couple questions: Describe the details of what "4-5 sec into the takeoff run" means. Is that after full throttle? Or after beginning the throttle up? Normal advancement to full throttle should take about 3 to 4 seconds. Have you tested your boost pump for its flow output (how long to pump a quart, for example)? At full throttle, your engine will burn something like a quart of gas every minute, which is a pretty healthy flow. If you disconnect the fuel line into the carb and put it into a container, the boost pump should pump something above a quart per minute. If the boost pump can do this, it wouldn't seem to be vapor lock. Vapor lock should plague one only when the boost pump is off, unless the vapor lock is upstream of the boost pump. Alex Peterson RV6-A 584 hours Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Mar 14, 2005
I'm not concerned about any additional mass on the aileron - should be easy to rebalance the aileron to compensate for the slight weight of the servo, rod and piano hinge (pour a bit of lead into the water pipe). I'm concerned about the trim tab "flapping" in the wind producing flutter. I like the trim tab a lot because it eliminates need for servo clutch, and because I already have two fixed trim tabs compensating for my twisted wings, which I then could get rid of (the tabs, not the wings :). Any idea of how long and deep into the aileron I need to make the tab? I assume the the size of the elevator trim tab would be way too much. Van's electric aileron trim tab is just a lenght of piano hinge in extension to the trailing edge, but I imagine that may not be enough for a wing leveler? Finn Ed Anderson wrote: > > Yes, Listening Finn. > >Since I do not intend to control roll with an aileron trim tab, flutter is >not one of my concerns. I intend to use an 1/3 RC servo to push a rod which >in turn pushes a tab on the aileron bell crank - so no additional mass out >on the control surface. So perhaps other problems, but don't expect flutter >to be one of them. > >Great seeing you again at the Flyin and Tracy's Finn. > >Hope you get back from your trip to make it to Sun & Fun. > >Made it back to Charlotte from Tracy's in 2 hours 45 minutes, so even had a >small tail wind component to help this day. > >Ed > > ________________________________________________________________________________
Date: Mar 14, 2005
Guys, this is a great discussion. Please keep it online so we can all benefit. I have dreams of doing the same myself when I am finished my RV-6. The stepper motor servo seems to be the most practical solution, saves building a clutched servo. A stepper can be driven from buffered outputs from a microcontroller. I have done this myself for a job many years ago but it didnt have the torque I had expected. Didn't get to the bottom of that at the time. I would have anticipated quite a lot of drag for these. Also, the stepper motor could possibly be liberated from a dead printer. Approximatly how big is the tru-track(?) stepper? Can anyone glean a little more information. Doug Gray '6 Fuse, now off the jig. Ed Anderson wrote: > > Hi Bill, > > Just got back from week end with Tracy and Laura Crook - great as always. > > Yes, I found some code for an "Inverted Pendulum" that looks like it will > provide a basis for the PID code. They do some neat tricks with clock > frequency and sampling rates to make the math (shifts) much quicker. > > Yes, the 1/3 scale model servos produce torque equal and greater than that > shown in the autopilot specs on servos - so no problem there. However, I > have not been able to find one with any type of clutch which as you indicate > is desirable. > > My initial thoughts on that aspect of the problem is to have the servo push > a rod that goes through a hole in a tab attached to aileron bell crank. The > rod would have springs on both sides of the tab (conceptually similar to > Van's elCheapo spring trim system which I use in my RV-6A). However, there > are some problems with that concept, so don't know if that would work, but > might be worth a try. On the otherhand adapting a magnetic clutch might be > a more elegant way to go. > > Thanks for the suggestions > > Ed > > Ed Anderson > RV-6A N494BW Rotary Powered > Matthews, NC > eanderson(at)carolina.rr.com > > > ----- Original Message ----- > From: "Bill Dube" <bdube(at)al.noaa.gov> > To: > Subject: Re: Roll your own auto pilot? Re: RV-List: Auto Pilots > > > >> >> >>> >>>I am currently playing with a design for a heading hold -wing leveler. I >>>have the electronic components mocked up in a electronic simulation >> > (PSPICE) > >>>at this point. I am still debating whether to go with the analog >> > approach > >>>or the digital using a PIC Microchip. The digital clearly offers more >> > move > >>>for growth and change but the complexity of the algorithms are a bit >> > much. > >>>The analog looks to be more straight forward - but with limited growth >>>capability. >> >> You can easily find PID code for the PIC or nearly any other >>embedded controller. Use that stock code as the core for your system and >>you will save yourself a ton of programming and de-bugging work. >> >> >> >>> I am looking to make a simply (inexpensive) system that will start out >> > as > >>>an manual electric aileron trim and progress from there. I believe that >> > a > >>>Cascading set of simple OpAmp PID controllers looks to be the best bet >> > (and > >>>least expensive) for smooth operation. This is basically two control >>>loops - the outside loop would be comparing a heading signal to your set >>>heading the difference would generally a roll angle requirement this >> > would > >>>feed to the inside loop where the current roll angle would be compared to >>>the command roll and if a difference exists the inner list would generate >> > a > >>>roll rate command which would end up driving the servo. >> >> That makes sense. Feed in the rate sensor information to the > > inner > >>loop to keep it stable and reduce the sensitivity to noise on the heading >>input. Easier to do digitally, by the way. >> >> >>> A small difference >>>in heading would generate a small roll rate and a larger difference a >> > faster > >>>roll rate (with limits of course - probably 15 deg max). Obviously quite >> > a > >>>bit more complex than this brief description - but that's the general >> > idea. > >>>The Unit is intended for VFR ONLY and will probably use a 1/3 scale model >>>aircraft servo. >> >> Would that have the torque needed? Also, how do you plan to > > clutch > >>the servo to allow manual over-ride? >> >> > > > > > > > > ________________________________________________________________________________
Date: Mar 14, 2005
Subject: Re: Wheel pants
Hi Bob, Thanks for the hints. A couple of hours of filing and they fit together fine. There is a bit of a gap between the forward part and the aft, and I've put a couple of strips of fiberglass on the forward half to help it fit better. It will probably need a couple more hours of sanding. I also ordered the Sam James DVD on how to do this stuff. I found the Ordorff cassettes helpful as well. Best regards, Mickey Oldsfolks(at)aol.com wrote: > > Mickey; > I used a file to get a better fit between the two halves of the wheel > pants. A square or flat file will do. > I also used Poly-Fibre "Smooth Prime" to prime them . It goes on with a > small roller and you can push down to squish it into the pinholes in that #$% > &* > fibre glas. A/C S has it in the glas & resins section of their catalog. > Mix small amounts since it goes a long way. It washes up with water and sands > into lots of snow on the floor. A couple of coats usually takes care of > the pinholes. > > Bob Olds RV-4 , N1191X > A&P , EAA Tech. Counselor > Charleston,Arkansas > Real Aviators Fly Taildraggers > -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
Date: Mar 14, 2005
Hi Doug, I am not that familiar with the details of stepper motors, although I do understand the concept. My question is what aspect of the stepper motor makes it better suited for this application? Does a stepper motor not offer "resistance" as does a servo without a clutch may do? Does a stepper motor provide "position" feed back? or does it already "know" (based on the command sent) what position it will be activated to reach. Ed Anderson ----- Original Message ----- From: "Doug Gray" <dgra1233(at)bigpond.net.au> Subject: Re: Roll your own auto pilot? Re: RV-List: Auto Pilots > > Guys, this is a great discussion. Please keep it online so we can all benefit. > > I have dreams of doing the same myself when I am finished my RV-6. > > The stepper motor servo seems to be the most practical solution, saves building a clutched servo. A > stepper can be driven from buffered outputs from a microcontroller. I have done this myself for a > job many years ago but it didnt have the torque I had expected. Didn't get to the bottom of that at > the time. I would have anticipated quite a lot of drag for these. > > Also, the stepper motor could possibly be liberated from a dead printer. > > Approximatly how big is the tru-track(?) stepper? Can anyone glean a little more information. > > Doug Gray > '6 Fuse, now off the jig. > > > Ed Anderson wrote: > > > > Hi Bill, > > > > Just got back from week end with Tracy and Laura Crook - great as always. > > > > Yes, I found some code for an "Inverted Pendulum" that looks like it will > > provide a basis for the PID code. They do some neat tricks with clock > > frequency and sampling rates to make the math (shifts) much quicker. > > > > Yes, the 1/3 scale model servos produce torque equal and greater than that > > shown in the autopilot specs on servos - so no problem there. However, I > > have not been able to find one with any type of clutch which as you indicate > > is desirable. > > > > My initial thoughts on that aspect of the problem is to have the servo push > > a rod that goes through a hole in a tab attached to aileron bell crank. The > > rod would have springs on both sides of the tab (conceptually similar to > > Van's elCheapo spring trim system which I use in my RV-6A). However, there > > are some problems with that concept, so don't know if that would work, but > > might be worth a try. On the otherhand adapting a magnetic clutch might be > > a more elegant way to go. > > > > Thanks for the suggestions > > > > Ed > > > > Ed Anderson > > RV-6A N494BW Rotary Powered > > Matthews, NC > > eanderson(at)carolina.rr.com > > > > > > ----- Original Message ----- > > From: "Bill Dube" <bdube(at)al.noaa.gov> > > To: > > Subject: Re: Roll your own auto pilot? Re: RV-List: Auto Pilots > > > > > > > >> > >> > >>> > >>>I am currently playing with a design for a heading hold -wing leveler. I > >>>have the electronic components mocked up in a electronic simulation > >> > > (PSPICE) > > > >>>at this point. I am still debating whether to go with the analog > >> > > approach > > > >>>or the digital using a PIC Microchip. The digital clearly offers more > >> > > move > > > >>>for growth and change but the complexity of the algorithms are a bit > >> > > much. > > > >>>The analog looks to be more straight forward - but with limited growth > >>>capability. > >> > >> You can easily find PID code for the PIC or nearly any other > >>embedded controller. Use that stock code as the core for your system and > >>you will save yourself a ton of programming and de-bugging work. > >> > >> > >> > >>> I am looking to make a simply (inexpensive) system that will start out > >> > > as > > > >>>an manual electric aileron trim and progress from there. I believe that > >> > > a > > > >>>Cascading set of simple OpAmp PID controllers looks to be the best bet > >> > > (and > > > >>>least expensive) for smooth operation. This is basically two control > >>>loops - the outside loop would be comparing a heading signal to your set > >>>heading the difference would generally a roll angle requirement this > >> > > would > > > >>>feed to the inside loop where the current roll angle would be compared to > >>>the command roll and if a difference exists the inner list would generate > >> > > a > > > >>>roll rate command which would end up driving the servo. > >> > >> That makes sense. Feed in the rate sensor information to the > > > > inner > > > >>loop to keep it stable and reduce the sensitivity to noise on the heading > >>input. Easier to do digitally, by the way. > >> > >> > >>> A small difference > >>>in heading would generate a small roll rate and a larger difference a > >> > > faster > > > >>>roll rate (with limits of course - probably 15 deg max). Obviously quite > >> > > a > > > >>>bit more complex than this brief description - but that's the general > >> > > idea. > > > >>>The Unit is intended for VFR ONLY and will probably use a 1/3 scale model > >>>aircraft servo. > >> > >> Would that have the torque needed? Also, how do you plan to > > > > clutch > > > >>the servo to allow manual over-ride? > >> > >> > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 14, 2005
Finn, I believe that Van sells an electric aileron trim kit - undoubtedly the size tab it calls for would be a starting point. Someone on the list may have the diagram which shows the cut-out size. Ed ----- Original Message ----- From: "Finn Lassen" <finn.lassen(at)verizon.net> Subject: Re: RV-List: Cheap Navaid servo for sale? > > I'm not concerned about any additional mass on the aileron - should be > easy to rebalance the aileron to compensate for the slight weight of the > servo, rod and piano hinge (pour a bit of lead into the water pipe). I'm > concerned about the trim tab "flapping" in the wind producing flutter. > > I like the trim tab a lot because it eliminates need for servo clutch, > and because I already have two fixed trim tabs compensating for my > twisted wings, which I then could get rid of (the tabs, not the wings :). > > Any idea of how long and deep into the aileron I need to make the tab? I > assume the the size of the elevator trim tab would be way too much. > Van's electric aileron trim tab is just a lenght of piano hinge in > extension to the trailing edge, but I imagine that may not be enough for > a wing leveler? > > Finn > > Ed Anderson wrote: > > > > > Yes, Listening Finn. > > > >Since I do not intend to control roll with an aileron trim tab, flutter is
March 08, 2005 - March 14, 2005
RV-Archive.digest.vol-qp
