RV-Archive.digest.vol-qt
April 11, 2005 - April 24, 2005
Subject: Re: Should I or shouldn't I
Date: Apr 11, 2005
> > If you were in my shoes, where I am just about to take my 6A to the > airport, would you replace the vertical stab and rudder with a 7/7A > version prior to getting everything completed? Oh, and aesthetically I prefer the shorter 6 tail. Kind of racy looking you know, and the stubby RV-6 can use some of that. Larry Pardue ________________________________________________________________________________
Date: Apr 11, 2005
Ron Lee wrote: > >Go fly it as is and change it later if you feel the need. I have 600 hours >in my 6A and have no desire to change the tail...even if approved. > >Ron Lee > > > > It's approved, been there and done that. I flew my -6 for about a thousand hours with the original stab and rudder. IMO the -6 never had quite enough rudder in cross wind landings. That is just my opinion and others may disagree. With the new -7 stab and rudder I feel much more comfortable doing x-wind landings. I also find that it has a more solid feel in turbulance and it dampens out the so called "fishtail." Would I do it again? Yes I would, I like the way it handles on the gorund and in the air. And Larry I like the way it looks:-) I just need to get it painted. Jerry ________________________________________________________________________________
Date: Apr 11, 2005
Hi Jeff, I'm in the unique position of having both at the moment. My "old" RV6 is the short tailed one, and my newer RV6 has the RF7/9 tail on it. That one had an O-320/FP prop, but is being retrofitted at the moment with a 360/CS. Here's the deal with the little tailed plane. The short tailed RV's do wag in bumpy air. You get used to it pretty quickly and don't even notice it after awhile, but those who don't fly the short tails notice it quite quickly when riding with me in bumpy air. My short tailed (Old REALLY short tail that is) RV6 runs out of rudder somewhere around 15-18KT of direct XWind. Now, my big tailed beauty handles much nicer in XWinds, I've never used much more than 1/2 rudder (the rv7/9 rudder is nearly twice the size in area of the old short rudder). That being said, I am swapping out the O-320 because the RV7/9 tail is quite a lot heavier than the -6 short tail, and being a taildragger (which are kind of tail heavy anyway), I ended up with very little baggage with the -320 on front. So, I'm hanging a -360 and C/S prop on front, which should bring my CG right back into the center and allow me to a haul to fat guys like me, full fuel and as much baggage as I can cram in there. Such is the case with my short tailed RV. Anyway, I can't say with certainty what the behavior on the nosedragger would be, but I like my big tailed RV more than the short tailed one in x winds and bumpy air. Just my 2 cents as usual! Cheers, Stein. ---------- Original Message ---------------------------------- From: "Jeff Orear" <jorear(at)new.rr.com> Date: Mon, 11 Apr 2005 21:49:59 -0500 > >List: > >This question is directed more toward my 6/6A brethren who are flying their creations. > >If you were in my shoes, where I am just about to take my 6A to the airport, would you replace the vertical stab and rudder with a 7/7A version prior to getting everything completed? Those of you that are flying the 6/6A, do you ever wish you had more rudder authority? Is the tendency to fishtail that apparent with the 6/6A vertical stab and rudder? > >One thing that I have to consider is that I have an 0320 E2D with a Catto three blade, which may bring CG into the picture. > >Just wondering what those that have gone before would do. > > >Regards, > > >Jeff Orear >RV6A N782P (reserved) >Just about to head to the airport >Peshtigo, WI > > ________________________________________________________________________________
Date: Apr 11, 2005
I think you'll find very few -6 drivers who wish they had the bigger V-stab. Of course if we were to try both ways like Jerry, perhaps we'd feel differently. But IMHO the original -6 tail is certainly sufficient. As someone else said on this list some years ago, "My RV wags its tail because its HAPPY!" Randall Henderson RV-6 ________________________________________________________________________________
Date: Apr 11, 2005
I remember when I first started flying my -8 that it would tail wag quite a bit... I ended up squeezing the rudder trailing edge to make it sharper... It made a HUGE difference... Night and day... if you don't have a sharp edge you can get separation of the air over the trialing edge of the rudder on one side and then the other... This can cause a wag, which is exaggerated in turbulence... Doesn't the -7 and -9 tail have the new sandwiched trailing edge? Maybe this is the cure for the tail wag and not necessarily the larger tail... Just a thought... -Bill ----- Original Message ----- From: "Stein Bruch" <stein(at)steinair.com> Subject: Re: RV-List: Should I or shouldn't I Hi Jeff, I'm in the unique position of having both at the moment. My "old" RV6 is the short tailed one, and my newer RV6 has the RF7/9 tail on it. That one had an O-320/FP prop, but is being retrofitted at the moment with a 360/CS. Here's the deal with the little tailed plane. The short tailed RV's do wag in bumpy air. You get used to it pretty quickly and don't even notice it after awhile, but those who don't fly the short tails notice it quite quickly when riding with me in bumpy air. My short tailed (Old REALLY short tail that is) RV6 runs out of rudder somewhere around 15-18KT of direct XWind. Now, my big tailed beauty handles much nicer in XWinds, I've never used much more than 1/2 rudder (the rv7/9 rudder is nearly twice the size in area of the old short rudder). That being said, I am swapping out the O-320 because the RV7/9 tail is quite a lot heavier than the -6 short tail, and being a taildragger (which are kind of tail heavy anyway), I ended up with very little baggage with the -320 on front. So, I'm hanging a -360 and C/S prop on front, which should bring my CG right back into the center and allow me to a haul to fat guys like me, full fuel and as much baggage as I can cram in there. Such is the case with my short tailed RV. Anyway, I can't say with certainty what the behavior on the nosedragger would be, but I like my big tailed RV more than the short tailed one in x winds and bumpy air. Just my 2 cents as usual! Cheers, Stein. ---------- Original Message ---------------------------------- From: "Jeff Orear" <jorear(at)new.rr.com> Date: Mon, 11 Apr 2005 21:49:59 -0500 > >List: > >This question is directed more toward my 6/6A brethren who are flying their >creations. > >If you were in my shoes, where I am just about to take my 6A to the >airport, would you replace the vertical stab and rudder with a 7/7A version >prior to getting everything completed? Those of you that are flying the >6/6A, do you ever wish you had more rudder authority? Is the tendency to >fishtail that apparent with the 6/6A vertical stab and rudder? > >One thing that I have to consider is that I have an 0320 E2D with a Catto >three blade, which may bring CG into the picture. > >Just wondering what those that have gone before would do. > > >Regards, > > >Jeff Orear >RV6A N782P (reserved) >Just about to head to the airport >Peshtigo, WI > > ________________________________________________________________________________
Date: Apr 11, 2005
Subject: Aviation News
AVIATION News Group to view & share your valuable comments and the latest trends and happenings in the aviation industry. Please click on the attached yahoo group link site to share & receive the updates on the latest happenings, business ventures, business opportunities, Air Shows and Exhibitions, New Aircraft releases, and certifications, Career news, Appointments etc. http://groups.yahoo.com/group/AVIATION-NEWS/ Please take few moments recommend us to your near & dears in the industry. We welcome your valuable comments and updates. With best regards AVIATION NEWS. http://groups.yahoo.com/group/AVIATION-NEWS/ --------------------------------- ________________________________________________________________________________
Subject: heavy rt wing problem
Date: Apr 12, 2005
I have been compensating for this with the manual aileron trim I installed on my 6a. Yesterday the light was shining on the Rt wing in such a way that i could see a slight upturn of the wing skin at the aileron joint for about 3' along the joint from the outer end. The lft side is fine. That would certainly cause the rt wing to pull down a bit. I didnt build the plane and not sure how this could be fixed, if at all. I wondered if anyone had experienced this, or have a posible fix for it. Charlie heathco ________________________________________________________________________________
Subject: Antenna doubler plates
Date: Apr 12, 2005
In general I use the rule of thumb to use a thickness equal to the skin thickness, but that can be changed to thicker material depending on the weight and drag of the item being mounted. In this case I think a double plate of .025-.032 is about right. Mike Robertson >From: "Ralph E. Capen" <recapen(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RE: RV-List: Antenna doubler plates >Date: Mon, 11 Apr 2005 13:42:28 -0500 (GMT-05:00) > > >Mike, > >Anything on thickness? > >Ralph > >-----Original Message----- >From: Mike Robertson <mrobert569(at)hotmail.com> >To: rv-list(at)matronics.com >Subject: RE: RV-List: Antenna doubler plates > > >Ralph, > >For a whip antenna AC 43.13-2A does not even show a doubler. The general >rule-of-thumb that I use for whip antenna installation is at least a 1 inch >edge past any/all screw holes or the outer edge of the antenna base, >whichever is wider. >Use this info at your own risk. > >Mike Robertson > > >From: "Ralph E. Capen" <recapen(at)earthlink.net> > >Reply-To: rv-list(at)matronics.com > >To: avionics-list(at)matronics.com, rv-list(at)matronics.com > >Subject: RV-List: Antenna doubler plates > >Date: Mon, 11 Apr 2005 13:07:12 -0500 (GMT-05:00) > > > > > >Fellow listers, > > > >I am starting the installation of my Comant CI122 com antenna on the > >underbelly of my RV6A. > > > >All I can find in the archives is Eric Newton's post on a 3" x 6" x .040 > >doubler along with a couple of others that indicate that one is > >required/has been used - check the 43.13. No mention of the basis for >the > >dimensions used. > > > >Obviously, the AC 43.13 should have info on the determination of the > >appropriate dimensions - but I have not learned to read that mumbo jumbo > >well enough to get any usable information from it. > > > >If someone could point out the correct paragraph or how they arrived at > >their specific numbers, I would greatly appreciate it. > > > >Ralph Capen > >RV6AQB N822AR > > > > > > ________________________________________________________________________________
Date: Apr 12, 2005
Thanks Mike...! -----Original Message----- From: Mike Robertson <mrobert569(at)hotmail.com> Subject: RE: RV-List: Antenna doubler plates In general I use the rule of thumb to use a thickness equal to the skin thickness, but that can be changed to thicker material depending on the weight and drag of the item being mounted. In this case I think a double plate of .025-.032 is about right. Mike Robertson >From: "Ralph E. Capen" <recapen(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RE: RV-List: Antenna doubler plates >Date: Mon, 11 Apr 2005 13:42:28 -0500 (GMT-05:00) > > >Mike, > >Anything on thickness? > >Ralph > >-----Original Message----- >From: Mike Robertson <mrobert569(at)hotmail.com> >To: rv-list(at)matronics.com >Subject: RE: RV-List: Antenna doubler plates > > >Ralph, > >For a whip antenna AC 43.13-2A does not even show a doubler. The general >rule-of-thumb that I use for whip antenna installation is at least a 1 inch >edge past any/all screw holes or the outer edge of the antenna base, >whichever is wider. >Use this info at your own risk. > >Mike Robertson > > >From: "Ralph E. Capen" <recapen(at)earthlink.net> > >Reply-To: rv-list(at)matronics.com > >To: avionics-list(at)matronics.com, rv-list(at)matronics.com > >Subject: RV-List: Antenna doubler plates > >Date: Mon, 11 Apr 2005 13:07:12 -0500 (GMT-05:00) > > > > > >Fellow listers, > > > >I am starting the installation of my Comant CI122 com antenna on the > >underbelly of my RV6A. > > > >All I can find in the archives is Eric Newton's post on a 3" x 6" x .040 > >doubler along with a couple of others that indicate that one is > >required/has been used - check the 43.13. No mention of the basis for >the > >dimensions used. > > > >Obviously, the AC 43.13 should have info on the determination of the > >appropriate dimensions - but I have not learned to read that mumbo jumbo > >well enough to get any usable information from it. > > > >If someone could point out the correct paragraph or how they arrived at > >their specific numbers, I would greatly appreciate it. > > > >Ralph Capen > >RV6AQB N822AR > > > > > > ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Date: Apr 12, 2005
I would not undo anything at this point. Just go fly it and see how you like it. I think you will be very happy with your 6 just the way it is. Shemp/Jeff Dowling RV-6A, N915JD 165 hours Chicago/Louisville ________________________________________________________________________________
Date: Apr 11, 2005
I had 1.3 hours dual in an RV-6 and it "hunted" directionally. This is a fairly common observation. - If I could increase the vertical stab area easily, I would. More rudder isn't the issue - it is vertical stab area. - Might consider a "dorsal fin" extending fwd from base of vertical stab (like a Cessna) - should be an easier way of increasing yaw stability vs an entirely new RV-7 vertical stab & rudder. David ----- Original Message ----- From: "Jeff Orear" <jorear(at)new.rr.com> Subject: RV-List: Should I or shouldn't I > > List: > > This question is directed more toward my 6/6A brethren who are flying their creations. > > If you were in my shoes, where I am just about to take my 6A to the airport, would you replace the vertical stab and rudder with a 7/7A version prior to getting everything completed? Those of you that are flying the 6/6A, do you ever wish you had more rudder authority? Is the tendency to fishtail that apparent with the 6/6A vertical stab and rudder? > > One thing that I have to consider is that I have an 0320 E2D with a Catto three blade, which may bring CG into the picture. > > Just wondering what those that have gone before would do. > > > Regards, > > > Jeff Orear > RV6A N782P (reserved) > Just about to head to the airport > Peshtigo, WI > > ________________________________________________________________________________
Date: Apr 12, 2005
Directional stability in turbulence was something I noticed in my RV6A but didn't worry about too much. After I installed vortex generators on the wings the wobble or fishtailing in rough air stopped. Nada. John David Carter wrote: > >I had 1.3 hours dual in an RV-6 and it "hunted" directionally. This is a >fairly common observation. > - If I could increase the vertical stab area easily, I would. More >rudder isn't the issue - it is vertical stab area. > - Might consider a "dorsal fin" extending fwd from base of vertical >stab (like a Cessna) - should be an easier way of increasing yaw stability >vs an entirely new RV-7 vertical stab & rudder. > >David > >----- Original Message ----- >From: "Jeff Orear" <jorear(at)new.rr.com> >To: >Subject: RV-List: Should I or shouldn't I > > > > >> >>List: >> >>This question is directed more toward my 6/6A brethren who are flying >> >> >their creations. > > >>If you were in my shoes, where I am just about to take my 6A to the >> >> >airport, would you replace the vertical stab and rudder with a 7/7A version >prior to getting everything completed? Those of you that are flying the >6/6A, do you ever wish you had more rudder authority? Is the tendency to >fishtail that apparent with the 6/6A vertical stab and rudder? > > >>One thing that I have to consider is that I have an 0320 E2D with a Catto >> >> >three blade, which may bring CG into the picture. > > >>Just wondering what those that have gone before would do. >> >> >>Regards, >> >> >>Jeff Orear >>RV6A N782P (reserved) >>Just about to head to the airport >>Peshtigo, WI >> >> >> >> > > > > ________________________________________________________________________________
Date: Apr 12, 2005
That is really interesting! I'm planning to add vgs after I fly the airplane a few hours and get baseline data for comparison. - It is easy to "assume" that fishtailing is due to inadequate vertical fin area, but . . . - One fellow just mentioned he squeezed his rudder trailing edge and that fixed the problem. A little asymmetrical shedding of air off left and right sides of rudder actually make the rudder move, thus the fishtailing. . . . - You added vg's - asymmetrical shedding of turbulent flow over wings by fuselage could do the same thing. - Lots of variables! David ----- Original Message ----- From: "John" <n1cxo320(at)salidaco.com> Subject: Re: RV-List: Should I or shouldn't I > > Directional stability in turbulence was something I noticed in my RV6A > but didn't worry about too much. After I installed vortex generators on > the wings the wobble or fishtailing in rough air stopped. Nada. > > John > > David Carter wrote: > > > > >I had 1.3 hours dual in an RV-6 and it "hunted" directionally. This is a > >fairly common observation. > > - If I could increase the vertical stab area easily, I would. More > >rudder isn't the issue - it is vertical stab area. > > - Might consider a "dorsal fin" extending fwd from base of vertical > >stab (like a Cessna) - should be an easier way of increasing yaw stability > >vs an entirely new RV-7 vertical stab & rudder. > > > >David > > > >----- Original Message ----- > >From: "Jeff Orear" <jorear(at)new.rr.com> > >To: > >Subject: RV-List: Should I or shouldn't I > > > > > > > > > >> > >>List: > >> > >>This question is directed more toward my 6/6A brethren who are flying > >> > >> > >their creations. > > > > > >>If you were in my shoes, where I am just about to take my 6A to the > >> > >> > >airport, would you replace the vertical stab and rudder with a 7/7A version > >prior to getting everything completed? Those of you that are flying the > >6/6A, do you ever wish you had more rudder authority? Is the tendency to > >fishtail that apparent with the 6/6A vertical stab and rudder? > > > > > >>One thing that I have to consider is that I have an 0320 E2D with a Catto > >> > >> > >three blade, which may bring CG into the picture. > > > > > >>Just wondering what those that have gone before would do. > >> > >> > >>Regards, > >> > >> > >>Jeff Orear > >>RV6A N782P (reserved) > >>Just about to head to the airport > >>Peshtigo, WI > >> > >> > >> > >> > > > > > > > > > > ________________________________________________________________________________
Date: Apr 12, 2005
Subject: Re: Your VG's?
Jerry and Konrad et al, I got the vg's from an outfit in Washington State...don't recall exactly where,..I believe that they are available from the fellow that makes exhaust systems for RV's also...same price as I recall...around $400 (vs $1,200-1600 or thereabouts if put on a certified plane.) As to installation, its dead-brain simple. You measure forward for the leading edge skin-main skin seam so many inches and mark it. A stickon sheet with the places to put the vg's is already cut out shows you the exact location to put them. You scuff up the paint, and use the supplied Lock Tite to install them. Its a two part liquid. You hold them in place for about one minute and they're there for good. Never had one come loose. Total installation time about 2 hours at max. Performance - somewhat subjective - I "feel" more advance warning about an impending stall. The stall is FAR, FAR more gentle...power off stalls are really just a good 'mush' with no wing drop....indicated stall speeds (accuracy at stall angle is really inexact) but my guess is that its about 5 MPH slower as I can tell from GPS - again, thats a crude measurement because its happening pretty fast....Rough air fishtailiing seems no longer to be present. Now if we could get something that would stop the up and down bouncing that now and then gives you a head bump, we'd be on to something! I fly in fairly rugged country near the continental divide with 14,000-ft hills nearby...if I had to go down there aren't many good spots for an emergency landing and a reduction of even 5MPH might save my rear. I see the vg's as a safety feature. John Konrad L. Werner wrote: > Dear John, > Could you please tell me more about these Vortex Generators on your RV? > What / Why / Where / Who, etc. > Thanks, > Konrad ________________________________________________________________________________
Date: Apr 12, 2005
Subject: [ Jeff Deuchar ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Jeff Deuchar Lists: RV-List,Rocket-List Subject: Photos of Eric Hansen's rocket with new paint scheme, and Ken Fowler's rocket. http://www.matronics.com/photoshare/F1Rocket@telus.net.04.12.2005/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Apr 12, 2005
Probably Larry Vetterman vetxaust(at)gwtc.net (605) 745-5932 http://www.ontariorvators.org/pitot/pitot.htm Ron Lee ________________________________________________________________________________
Date: Apr 12, 2005
Subject: [Fwd: [VAF Mailing List] RV-6A Down - not fatal]
-------- Original Message -------- Subject: [VAF Mailing List] RV-6A Down - not fatal Date: Tue, 12 Apr 2005 19:34:58 -0500 From: Jim Smith <jsmith(at)openairnet.com> http://www.sfgate.com/cgi-bin/article.cgi?file=/c/a/2005/04/12/HAYWARD12.TMP A pilot crash-landed a small airplane in a Hayward parking lot early today after having engine problems shortly after taking off at the city's airport, officials said. The 70-year-old pilot departed from Hayward Executive Airport at 8:50 a.m. and immediately radioed the airport tower with the message that he had a dead engine, a Federal Aviation Administration spokesman said. He got out of the experimental plane after landing it in an industrial area near Soto Road and Jackson Street, about four miles from the airport, officials said. The plane collided with two unoccupied city vehicles, officials sad. The unidentified pilot was taken to a local hospital. Police said the man's injuries did not appear to be life-threatening. An airport spokeswoman said the pilot of the home-built RV-6 plane, who was the only person on board the craft, was bleeding from the head and leg after the crash. No other people were reported injured. The plane crashed into a storage area called Hayward Corporation Yard where city equipment and recycling bins are kept. Serial Number 22305 Type Registration Individual Manufacturer Name NEWELL THOMAS J Certificate Issue Date 09/05/2003 Model RV6A Status Valid Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating Pending Number Change None Dealer No Date Change Authorized None Mode S Code 50170413 MFR Year 1998 Fractional Owner NO Give the gift of life to a sick child. Support St. Jude Children's Research Hospital's 'Thanks & Giving.' http://us.click.yahoo.com/5iY7fA/6WnJAA/Y3ZIAA/1yWplB/TM Online help on this group at: http://help.yahoo.com/help/groups/ <*> To visit your group on the web, go to: http://groups.yahoo.com/group/vansairforce/ <*> To unsubscribe from this group, send an email to: vansairforce-unsubscribe(at)yahoogroups.com http://docs.yahoo.com/info/terms/ -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Slowbuild wings-QB Fuse :-) ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Subject: vg's for windscreen clearing
Date: Apr 12, 2005
I have noticed patterns of "dead" air on the windscreen of my 6A. What I mean is that if flying in mist, there is minimal tendency for the airstream to blow beads of water from the center two feet or so of the windscreen. I have flown side by side with 8's which do not seem to have this problem. It doesn't matter if I use rain-ex (I've done tests with other products as well, covering the left half of the windscreen and looking for mist to fly in - no difference). The general problem seems to be a lack of high velocity air near the windscreen. I've even noticed when flying in light snow flurries that one can see individual snowflakes as they momentarily pause just ahead of the windscreen. The question is: Would placing a few vg's ahead of the windscreen help this? And, have others noticed this phenomenon? Thanks - Alex Peterson RV6-A 608 hours Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ <http://www.home.earthlink.net/> ________________________________________________________________________________
Subject: Re: vg's for windscreen clearing
Date: Apr 12, 2005
Hi Alex, If it seems to be worth a few test flights to you. You could try taping short lengths of wool yarn onto and around the the areas in question (tufting). Then use double sided tape to attach some number of vg's in various areas. After several test flights you might at least be able to improve on the condition you have at present. Has anyone else encountered this and tried some testing? Keep us informed. Jim in Kelowna ----- Original Message ----- From: "Alex Peterson" <alexpeterson(at)earthlink.net> > > I have noticed patterns of "dead" air on the windscreen of my 6A. What I > mean is that if flying in mist, there is minimal tendency for the > airstream > to blow beads of water from the center two feet or so of the windscreen. > I > have flown side by side with 8's which do not seem to have this problem. > It > doesn't matter if I use rain-ex (I've done tests with other products as > well, covering the left half of the windscreen and looking for mist to fly > in - no difference). The general problem seems to be a lack of high > velocity air near the windscreen. I've even noticed when flying in light > snow flurries that one can see individual snowflakes as they momentarily > pause just ahead of the windscreen. > > The question is: Would placing a few vg's ahead of the windscreen help > this? > And, have others noticed this phenomenon? > > Thanks - > > Alex Peterson ________________________________________________________________________________
Date: Apr 12, 2005
Subject: Engine trouble @ Valkaria
Howdy listers, Developed some engine trouble today coming back from Sun'n'Fun. #1 cylinder EGT began to run a couple hundred degrees lower than normal and a kinda slapping sound like an exhaust leak was audible. The EGT kept decreasing and finally stabilized at around 950 or so. It had been running over 1400 before. Engine is very rough. The good folks at the X59 EAA hangar have kindly offered me the use of the hangar and compression tester for tomorrow. I'm going to be there pretty early to uncowl and such. If there's any engine gurus in the neighborhood, I'd be much obliged if you'd offer some advice. We may be in the market for a cylinder shop that can do a fairly quick turnaround somewhere near here, too. My cell # is : 818 723-8272 As you can see by my San Fernando Valley, CA area code, I'm a long ways from home. Thanks, Ed Holyoke ________________________________________________________________________________
Date: Apr 12, 2005
Subject: Proposed MT prop AD
Proposed "AD" for MT propellers http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgADNPRM.nsf/0/9D764C3BEA27ADC786256FDB005CB285?OpenDocument --------------------------------- ________________________________________________________________________________
Date: Apr 13, 2005
Subject: Re: RV Down? - CNN Headline News
According to the local news here in the Bay Area he was taking off from Hayward and lost power. The pilot successfully put it down in a parking lot with, according to the news reporter, minor injuries. The airplane looks pretty badly bent. An N-number search indicates the airplane is registered to Richard Crowe from Oxnard, anyone know him. Apparently he was not the builder. Thats all I know. Harry Crosby RV-6 N16CX, 61 hours. ________________________________________________________________________________
Subject: Re: [Fwd: [VAF Mailing List] RV-6A Down - not fatal]
Date: Apr 12, 2005
> It also looks like he had newly installed fuel tanks, or they weren't > installed when the plane was painted. > Yeah and elevators and rudder. Curious. ________________________________________________________________________________
Date: Apr 13, 2005
Subject: Re: Engine trouble @ Valkaria
Update. Got the cowl off and found the exhaust pipe dangling. No nuts, no gasket. Gone looking for parts. Looks like easy fix. Ed Holyoke Ed Holyoke wrote: Howdy listers, Developed some engine trouble today coming back from Sun'n'Fun. #1 cylinder EGT began to run a couple hundred degrees lower than normal and a kinda slapping sound like an exhaust leak was audible. The EGT kept decreasing and finally stabilized at around 950 or so. It had been running over 1400 before. Engine is very rough. The good folks at the X59 EAA hangar have kindly offered me the use of the hangar and compression tester for tomorrow. I'm going to be there pretty early to uncowl and such. If there's any engine gurus in the neighborhood, I'd be much obliged if you'd offer some advice. We may be in the market for a cylinder shop that can do a fairly quick turnaround somewhere near here, too. My cell # is : 818 723-8272 As you can see by my San Fernando Valley, CA area code, I'm a long ways from home. Thanks, Ed Holyoke ________________________________________________________________________________
Date: Apr 13, 2005
this plane used to be here in Colorado...and was sold a couple years ago... I remember hearing that the buyer had to put it down in a field due to an engine failure, hence the new tanks and tail... sad to hear this, I did some flying in this plane before I flew mine for the first time... -Bill ----- Original Message ----- From: "randall" <rv6n6r(at)comcast.net> Subject: Re: RV-List: [Fwd: [VAF Mailing List] RV-6A Down - not fatal] > It also looks like he had newly installed fuel tanks, or they weren't > installed when the plane was painted. > Yeah and elevators and rudder. Curious. ________________________________________________________________________________
Date: Apr 13, 2005
Subject: RV-6A Down - not fatal
Interesting. This was the first 6A that I looked at possibly buying. I did create a simple website to help the owner sell it. http://home.pcisys.net/~ronlee/RV6A/N16TN/N16TN.htm Ron Lee ________________________________________________________________________________
Subject: 24 volt dry cell battery...
Date: Apr 13, 2005
Anyone have a source for a 24v dry cell battery? -Bill ________________________________________________________________________________
Date: Apr 13, 2005
Subject: Re: RV-6A Down - not fatal
If I remember correctly, I looked at this plane in Colorado Springs when it was for sale a couple years ago, built by Tom Newell. Ron Lee, am I right? Jerry Cochran Wilsonville, OR Subject: [VAF Mailing List] RV-6A Down - not fatal From: Jim Smith <jsmith(at)openairnet.com> http://www.sfgate.com/cgi-bin/article.cgi?file=/c/a/2005/04/12/HAYWARD12.TMP A pilot crash-landed a small airplane in a Hayward parking lot early today after having engine problems shortly after taking off at the city's airport, officials said. ________________________________________________________________________________
Date: Apr 13, 2005
Subject: alodine alternative
Hi All, For those of us in chromate unfriendly areas (california ;) are there good alternatives to alodine? Specfically, I was wondering if anyone had any experience with safegard CC 3400 from sanchem: http://www.sanchem.com their test specs look relatively impressive... Thanks, James (preparing to order the -10) ________________________________________________________________________________
Date: Apr 13, 2005
Subject: Re: RV6a for sale
In a message dated 4/10/2005 4:50:04 AM Mountain Daylight Time, pj115(at)journey.com writes: << pjlein(at)journey.com >> I cannot find the airplane on that net. Thanks Rollie ________________________________________________________________________________
Subject: Wing Jig for grabs
Date: Apr 13, 2005
Hi Everyone, If anyone is interested in a free standing floor jig for your horizontal/vertical stab's or wings it's ready to be picked up. Best part about it is, the wood is dry and it has produced 2 beautiful sets of wings. ITS FREE! to who ever wants it 1st. Contact me off list at "brucerv8(at)charter.net". Bruce Gray RV8 #81745 Fuselage Coming Soon! ________________________________________________________________________________
Subject: Engine problems.
Date: Apr 13, 2005
04/13/2005 16:28:36, Serialize complete at 04/13/2005 16:28:36 Folks, Any help would be appreciated. Having said that, Ed Holyoke's situation is much more dire than mine so help him first (he is traveling, I am at my home airport). Plane specifics: RV-6, 0-320-B2C, Fixed pitch Sensenich, Jeff Rose ignition on the right firing Autolite 386 Auto plugs in the bottom of each cylinder, Slick Mag on the left firing the top aircraft plugs, New carb at overhaul, 240hours SMOH. I was flying the other day for about 1/2 hour when out of the blue the engine started running extremely rough. Mag check and fuel switch yielded the same result. All cylinder temps were in the norm except for #4 which went very hot (512 degrees on the CHT). All other cylinders were a little warmer than normal but not much...I think the hottest was 320 degrees. I wish I had the presence of mind to also notice the EGT's but I didn't....focus was on #4 CHT and getting my butt on the ground. At full throttle the plane would only muster 120 MPH. As soon as I had the airport made and pulled power for landing, everything smoothed out. It was instantaneous with pulling power. After landing and taxi back to the ramp I did a run up and had full RPM with not even a hint of a miss. The next day I did a compression check. All cylinder OK except for #4... 80/65. At annual just about a month ago this cylinder was my lowest but was at 80/70. I was concerned then but my IA friend told me that I shouldn't worry too much about it but to keep an eye on it. Other three cylinders 80/78, 80/79, 80/78. I am totally baffled. I suspected an air leak but found none. I was worried about detonation but the top of the piston looks great...no pitting. The cylinder walls look good also. The compression test revealed that the leak seems to be mostly from the intake but the exhaust is leaking also. How do I troubleshoot? I am tempted to fly the plane again (close to the airport) but I am spooked. I would love to know what happened and have a fix before heading into the sky. Thanks in advance for any/all ideas.....don Don Nowakowski , Equipment Engineering Tech Telephone (802)288-3359, "More than anything else the sensation is one of perfect peace mingled with an excitement that strains every nerve to the utmost, if you can conceive of such a combination." -- Wilbur Wright ________________________________________________________________________________
Date: Apr 13, 2005
After dimpling my tank skins with a standard (Avery) dimple die set I learned of the tank die set sold by Cleaveland Aircraft. My question is this: will re-dimpling my tank skins with the tank die set reduce the strength of the rivetted joint? Switch to Netscape Internet Service. As low as $9.95 a month -- Sign up today at http://isp.netscape.com/emreg Netscape. Just the Net You Need. ________________________________________________________________________________
Date: Apr 13, 2005
All I can say is do not give into your temptation to "test fly" this airplane again until you are confident you have discovered the nature of th problem. Next time you may not be so lucky especially if you develop troubles on the climb out. Kevin Yellowknife, NT, Canada RV-8 Wanna Be Builder From: Donald Nowakowski <nowakod(at)us.ibm.com> Subject: RV-List: Engine problems. Date: Wed, 13 Apr 2005 15:11:00 -0400 04/13/2005 16:28:36, Serialize complete at 04/13/2005 16:28:36 Folks, Any help would be appreciated. Having said that, Ed Holyoke's situation is much more dire than mine so help him first (he is traveling, I am at my home airport). Plane specifics: RV-6, 0-320-B2C, Fixed pitch Sensenich, Jeff Rose ignition on the right firing Autolite 386 Auto plugs in the bottom of each cylinder, Slick Mag on the left firing the top aircraft plugs, New carb at overhaul, 240hours SMOH. I was flying the other day for about 1/2 hour when out of the blue the engine started running extremely rough. Mag check and fuel switch yielded the same result. All cylinder temps were in the norm except for #4 which went very hot (512 degrees on the CHT). All other cylinders were a little warmer than normal but not much...I think the hottest was 320 degrees. I wish I had the presence of mind to also notice the EGT's but I didn't....focus was on #4 CHT and getting my butt on the ground. At full throttle the plane would only muster 120 MPH. As soon as I had the airport made and pulled power for landing, everything smoothed out. It was instantaneous with pulling power. After landing and taxi back to the ramp I did a run up and had full RPM with not even a hint of a miss. The next day I did a compression check. All cylinder OK except for #4... 80/65. At annual just about a month ago this cylinder was my lowest but was at 80/70. I was concerned then but my IA friend told me that I shouldn't worry too much about it but to keep an eye on it. Other three cylinders 80/78, 80/79, 80/78. I am totally baffled. I suspected an air leak but found none. I was worried about detonation but the top of the piston looks great...no pitting. The cylinder walls look good also. The compression test revealed that the leak seems to be mostly from the intake but the exhaust is leaking also. How do I troubleshoot? I am tempted to fly the plane again (close to the airport) but I am spooked. I would love to know what happened and have a fix before heading into the sky. Thanks in advance for any/all ideas.....don Don Nowakowski , Equipment Engineering Tech Telephone (802)288-3359, "More than anything else the sensation is one of perfect peace mingled with an excitement that strains every nerve to the utmost, if you can conceive of such a combination." -- Wilbur Wright ________________________________________________________________________________
Date: Apr 13, 2005
Lcoming Engines have a known valve sticking problem that can be casued by any number of thinks. If the compression check shows that the leaking is past the valves, first try staking the vavles first and see what/if that does. If it doesn't do anything then you may need to get the valves re-done. Lycoming has several kep reprints that may help. Here is a short one about valve sticking. There are some service instrction and service letter numbers in there that may be of some assistance. http://www.lycoming.textron.com/main.jsp?bodyPage=support/publications/keyReprints/operation/stickingValves.html If it is valve sticking, a valve job usually does the trick........not always, but usually. Mike Robertson >From: Donald Nowakowski <nowakod(at)us.ibm.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Engine problems. >Date: Wed, 13 Apr 2005 15:11:00 -0400 04/13/2005 16:28:36, Serialize >complete at 04/13/2005 16:28:36 > > >Folks, Any help would be appreciated. Having said that, Ed Holyoke's >situation is much more dire than mine so help him first (he is traveling, >I am at my home airport). > >Plane specifics: RV-6, 0-320-B2C, Fixed pitch Sensenich, Jeff Rose >ignition on the right firing Autolite 386 Auto plugs in the bottom of each >cylinder, Slick Mag on the left firing the top aircraft plugs, New carb at >overhaul, 240hours SMOH. > >I was flying the other day for about 1/2 hour when out of the blue the >engine started running extremely rough. Mag check and fuel switch yielded >the same result. All cylinder temps were in the norm except for #4 which >went very hot (512 degrees on the CHT). All other cylinders were a little >warmer than normal but not much...I think the hottest was 320 degrees. I >wish I had the presence of mind to also notice the EGT's but I >didn't....focus was on #4 CHT and getting my butt on the ground. > >At full throttle the plane would only muster 120 MPH. As soon as I had the >airport made and pulled power for landing, everything smoothed out. It was >instantaneous with pulling power. After landing and taxi back to the ramp >I did a run up and had full RPM with not even a hint of a miss. > >The next day I did a compression check. All cylinder OK except for #4... >80/65. At annual just about a month ago this cylinder was my lowest but >was at 80/70. I was concerned then but my IA friend told me that I >shouldn't worry too much about it but to keep an eye on it. Other three >cylinders 80/78, 80/79, 80/78. > >I am totally baffled. I suspected an air leak but found none. I was >worried about detonation but the top of the piston looks great...no >pitting. The cylinder walls look good also. The compression test revealed >that the leak seems to be mostly from the intake but the exhaust is >leaking also. > >How do I troubleshoot? I am tempted to fly the plane again (close to the >airport) but I am spooked. I would love to know what happened and have a >fix before heading into the sky. Thanks in advance for any/all >ideas.....don > >Don Nowakowski , Equipment Engineering Tech >Telephone (802)288-3359, > >"More than anything else the sensation >is one of perfect peace mingled with >an excitement that strains every nerve >to the utmost, if you can conceive of such >a combination." > -- Wilbur >Wright > > ________________________________________________________________________________
Date: Apr 13, 2005
Hi All, For those of us in chromate unfriendly areas (i.e. california ;) are there good alternatives to alodine? Specfically, I was wondering if anyone had any experience with safegard CC 3400 from sanchem: http://www.sanchem.com their test specs look relatively impressive... Thanks, James (preparing to order the -10) ________________________________________________________________________________
Subject: Engine problems-stuck exhaust valve?
Date: Apr 13, 2005
Sounds very much like a stuck exhaust valve. Lycoming SB369 goes into great detail about how to troubleshoot, inspect, repair. Dave Saylor AirCrafters LLC 831-722-9141 ________________________________________________________________________________
Date: Apr 13, 2005
Subject: tank dimple dies
Sorry if this was already posted... After dimpling my tank skins with a standard (Avery) dimple die set I learned of the tank die set sold by Cleaveland Aircraft. My question is this: will re-dimpling my tank skins with the tank die set reduce the strength of the rivetted joint? Tom Switch to Netscape Internet Service. As low as $9.95 a month -- Sign up today at http://isp.netscape.com/emreg Netscape. Just the Net You Need. ________________________________________________________________________________
Mid-AtlRVwing(at)yahoogroups.com (MARV)
Subject: New EFIS model for under $3K
Date: Apr 13, 2005
1.25 RCVD_NUMERIC_HELO Received: contains an IP address used for HELO For those looking for a hell of deal for the $, here's GRT's new offering. I guess it's designed to go more head to head price wise with BMT, Dynon and if Dynon decides to do it their larger EFIS. Link to a .pdf brochure is at the bottom of the page. http://www.grtavionics.com/sport.htm For those looking for a hell of deal for the $, here's GRT's new offering. I guess it's designed to go more head to head price wisewith BMT, Dynon and if Dynon decides to do it their larger EFIS. Link to a .pdf brochure is at the bottom of the page. http://www.grtavionics.com/sport.htm ________________________________________________________________________________
Date: Apr 13, 2005
Subject: Snorkle for AirFlow Performance FM-200
I have an IO-360-M1 with Airflow Performance fuel injection (FM-200 controller). Using the smooth lower cowl and firewall forward kit from Vans which has a fiberglass filtered air inlet plenum made for a Bendix fuel injector - hence flat face mating surface with four bolt holes. Several questions: 1) Has anyone modified the Vans plenum to fit the FM-200 controller? I am aware of several builders who have placed a wye on the FM inlet and used one branch for the filtered air inlet and one branch as ram air inlet. This requires adding a hole in the lower cowl and I'm looking for other solutions. 2) What method was used to attach inlet plenum to the FM-200 controller? 3) What attachment piece was used to transition between the fiberglass plenum and the FM-200 inlet? Photos and/or drawings for the above would be greatly appreciated. Ron Jagels (RV-8A) ________________________________________________________________________________
Date: Apr 13, 2005
Tom, I'm sealing my tanks on my RV-8a now and had also heard of the tank dimple die set. I asked Van's support if they were necessary and they said heck no. There's been hundreds of tanks built (if not more) with the standard die set and they are more than adequate. I decided to pass on them. Regarding the redimpling. This was another question I asked Van's and their rule of thumb is you can redo the dimple (reverse/enlarge) one time with out weaking the metal. Your results may vary... Regards, Mark Sedlacek RV-8a Wings San Jose, CA ________________________________ From: owner-rv-list-server(at)matronics.com on behalf of tomatwork(at)netscape.com Subject: RV-List: tank dimple dies Sorry if this was already posted... After dimpling my tank skins with a standard (Avery) dimple die set I learned of the tank die set sold by Cleaveland Aircraft. My question is this: will re-dimpling my tank skins with the tank die set reduce the strength of the rivetted joint? Tom Switch to Netscape Internet Service. As low as $9.95 a month -- Sign up today at http://isp.netscape.com/emreg Netscape. Just the Net You Need. ________________________________________________________________________________
Date: Apr 13, 2005
Subject: Re: Engine problems.
A significant, sudden CHT excursion like that has to be a detonation event. You did the correct thing by getting the plane back onto the ground ASAP. Depending on the cause, going full rich, reducing power, and getting on the ground quickly, can control the detonation and temperature before serious dammage occurs. Try replacing BOTH plugs in the #4 cylinder with NEW ones. If the ceramic on one of the plugs has cracked or the bond has failed, then the plug won't dissipate the combustion heat to the cylinder head and become a hot spot. This is a fairly common problem. Also, verify your ignition timing! A leaky or sticking valve will not cause the CHT to shoot up. A sticking exhaust valve will cause a rise in EGT, and a drop in CHT. Skylor RV-8QB Under Construction --- Donald Nowakowski wrote: > > > Folks, Any help would be appreciated. Having said > that, Ed Holyoke's > situation is much more dire than mine so help him > first (he is traveling, > I am at my home airport). > > Plane specifics: RV-6, 0-320-B2C, Fixed pitch > Sensenich, Jeff Rose > ignition on the right firing Autolite 386 Auto plugs > in the bottom of each > cylinder, Slick Mag on the left firing the top > aircraft plugs, New carb at > overhaul, 240hours SMOH. > > I was flying the other day for about 1/2 hour when > out of the blue the > engine started running extremely rough. Mag check > and fuel switch yielded > the same result. All cylinder temps were in the norm > except for #4 which > went very hot (512 degrees on the CHT). All other > cylinders were a little > warmer than normal but not much...I think the > hottest was 320 degrees. I > wish I had the presence of mind to also notice the > EGT's but I > didn't....focus was on #4 CHT and getting my butt on > the ground. > > At full throttle the plane would only muster 120 > MPH. As soon as I had the > airport made and pulled power for landing, > everything smoothed out. It was > instantaneous with pulling power. After landing and > taxi back to the ramp > I did a run up and had full RPM with not even a hint > of a miss. > > The next day I did a compression check. All cylinder > OK except for #4... > 80/65. At annual just about a month ago this > cylinder was my lowest but > was at 80/70. I was concerned then but my IA friend > told me that I > shouldn't worry too much about it but to keep an eye > on it. Other three > cylinders 80/78, 80/79, 80/78. > > I am totally baffled. I suspected an air leak but > found none. I was > worried about detonation but the top of the piston > looks great...no > pitting. The cylinder walls look good also. The > compression test revealed > that the leak seems to be mostly from the intake but > the exhaust is > leaking also. > > How do I troubleshoot? I am tempted to fly the plane > again (close to the > airport) but I am spooked. I would love to know what > happened and have a > fix before heading into the sky. Thanks in advance > for any/all > ideas.....don > > Don Nowakowski , Equipment Engineering Tech > Telephone (802)288-3359, > > "More than anything else the sensation > is one of perfect peace mingled with > an excitement that strains every nerve > to the utmost, if you can conceive of such > a combination." > > -- Wilbur > Wright > > > > browse > Subscriptions page, > FAQ, > > > > > > __________________________________ ________________________________________________________________________________
Date: Apr 13, 2005
Someone posted a statement similar to yours. He was told by an "old" A&P that at about 300 hours or so the Lycoming will "stick a valve " then it will unstuck and everything will be OK after that. How many hours on your engine? Vic -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Robertson Subject: RE: RV-List: Engine problems. Lcoming Engines have a known valve sticking problem that can be casued by any number of thinks. If the compression check shows that the leaking is past the valves, first try staking the vavles first and see what/if that does. If it doesn't do anything then you may need to get the valves re-done. Lycoming has several kep reprints that may help. Here is a short one about valve sticking. There are some service instrction and service letter numbers in there that may be of some assistance. http://www.lycoming.textron.com/main.jsp?bodyPage=support/publications/k eyReprints/operation/stickingValves.html If it is valve sticking, a valve job usually does the trick........not always, but usually. Mike Robertson >From: Donald Nowakowski <nowakod(at)us.ibm.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Engine problems. >Date: Wed, 13 Apr 2005 15:11:00 -0400 04/13/2005 16:28:36, Serialize >complete at 04/13/2005 16:28:36 > > >Folks, Any help would be appreciated. Having said that, Ed Holyoke's >situation is much more dire than mine so help him first (he is traveling, >I am at my home airport). > >Plane specifics: RV-6, 0-320-B2C, Fixed pitch Sensenich, Jeff Rose >ignition on the right firing Autolite 386 Auto plugs in the bottom of each >cylinder, Slick Mag on the left firing the top aircraft plugs, New carb at >overhaul, 240hours SMOH. > >I was flying the other day for about 1/2 hour when out of the blue the >engine started running extremely rough. Mag check and fuel switch yielded >the same result. All cylinder temps were in the norm except for #4 which >went very hot (512 degrees on the CHT). All other cylinders were a little >warmer than normal but not much...I think the hottest was 320 degrees. I >wish I had the presence of mind to also notice the EGT's but I >didn't....focus was on #4 CHT and getting my butt on the ground. > >At full throttle the plane would only muster 120 MPH. As soon as I had the >airport made and pulled power for landing, everything smoothed out. It was >instantaneous with pulling power. After landing and taxi back to the ramp >I did a run up and had full RPM with not even a hint of a miss. > >The next day I did a compression check. All cylinder OK except for #4... >80/65. At annual just about a month ago this cylinder was my lowest but >was at 80/70. I was concerned then but my IA friend told me that I >shouldn't worry too much about it but to keep an eye on it. Other three >cylinders 80/78, 80/79, 80/78. > >I am totally baffled. I suspected an air leak but found none. I was >worried about detonation but the top of the piston looks great...no >pitting. The cylinder walls look good also. The compression test revealed >that the leak seems to be mostly from the intake but the exhaust is >leaking also. > >How do I troubleshoot? I am tempted to fly the plane again (close to the >airport) but I am spooked. I would love to know what happened and have a >fix before heading into the sky. Thanks in advance for any/all >ideas.....don > >Don Nowakowski , Equipment Engineering Tech >Telephone (802)288-3359, > >"More than anything else the sensation >is one of perfect peace mingled with >an excitement that strains every nerve >to the utmost, if you can conceive of such >a combination." > -- Wilbur >Wright > > ________________________________________________________________________________
Date: Apr 13, 2005
Subject: Re: tank dimple dies
You don't 'need' them, but I used the standard dies on the tanks & regret it. Of course, what I really regret is not building the tanks like Boeing: rivet ribs to skin dry then proseal the shop heads & seams. Charlie Mark A. Sedlacek wrote: > >Tom, I'm sealing my tanks on my RV-8a now and had also heard of the tank dimple die set. I asked Van's support if they were necessary and they said heck no. There's been hundreds of tanks built (if not more) with the standard die set and they are more than adequate. I decided to pass on them. Regarding the redimpling. This was another question I asked Van's and their rule of thumb is you can redo the dimple (reverse/enlarge) one time with out weaking the metal. Your results may vary... > >Regards, > >Mark Sedlacek >RV-8a >Wings >San Jose, CA > >________________________________ > >From: owner-rv-list-server(at)matronics.com on behalf of tomatwork(at)netscape.com >To: rv-list(at)matronics.com >Subject: RV-List: tank dimple dies > > >Sorry if this was already posted... > > >After dimpling my tank skins with a standard (Avery) dimple die set I >learned of the tank die set sold by Cleaveland Aircraft. My question >is this: will re-dimpling my tank skins with the tank die set reduce the >strength of the rivetted joint? > > >Tom > ________________________________________________________________________________
Date: Apr 13, 2005
Subject: Re:
No, it will not. However, why bother. It has been found that the tank dies are best used only on the under lying structure (ribs and rear baffle). Charlie Kuss > > > After dimpling my tank skins with a standard (Avery) dimple die set I > learned of the tank die set sold by Cleaveland Aircraft. My question >is this: will re-dimpling my tank skins with the tank die set reduce the >strength of the rivetted joint? > > >Switch to Netscape Internet Service. >As low as $9.95 a month -- Sign up today at http://isp.netscape.com/emreg > >Netscape. Just the Net You Need. > > ________________________________________________________________________________
Date: Apr 13, 2005
At 09:46 PM 4/12/2005, you wrote: > >I have noticed patterns of "dead" air on the windscreen of my 6A. What I >mean is that if flying in mist, there is minimal tendency for the airstream >to blow beads of water from the center two feet or so of the windscreen. I >have flown side by side with 8's which do not seem to have this problem. It >doesn't matter if I use rain-ex (I've done tests with other products as >well, covering the left half of the windscreen and looking for mist to fly >in - no difference). The general problem seems to be a lack of high >velocity air near the windscreen. I've even noticed when flying in light >snow flurries that one can see individual snowflakes as they momentarily >pause just ahead of the windscreen. > >The question is: Would placing a few vg's ahead of the windscreen help this? >And, have others noticed this phenomenon? The builder of my RV-4, Pete Fountain, placed the the cockpit cooling airscoop (NACA airscoop) on the lower half of the left side of the engine cowling. The result was terrible. This was in an area of dead airflow, and almost no airflow could be detected. I suggested to him that he place two VG's ahead of the scoop, as I had heard of all sorts of "miracle cures" from using VG's. Within two hours, Pete fashioned two small aluminum VG's, double face taped them on ( positioned purely by guesswork), and went flying. I got a call two hours and 10 minutes after I first suggested the VG's to Pete. He couldn't get over it, "They worked beautifully!" They were removed, painted, and replaced with a better quality of double face tape. They are still there after 470 hours. You can go wrong try the same thing. I would guess that you might want to try several positions. Good luck. - Louis I Willig 1640 Oakwood Dr. Penn Valley, PA 19072 610 668-4964 RV-4, N180PF 190HP IO-360, C/S prop ________________________________________________________________________________
Date: Apr 13, 2005
Donald Nowakowski wrote: Folks, Any help would be appreciated. Having said that, Ed Holyoke's situation is much more dire than mine so help him first (he is traveling, I am at my home airport). My problem's all solved, thank goodness. A new blow proof exhaust gasket did the trick and I'm back in business. I owe the local chapter big time for lending the hangar. I hope Donald can get his problem solved quickly, too. Pax, Ed Holyoke ________________________________________________________________________________
Date: Apr 14, 2005
Subject: Re: New EFIS model for under $3K
> Overall, for the price, it's a great alternative. Competition is a wonderful thing! Agreed. What would also be nice is a comparison table with this device and the two major competitors, the BMA EFIS/Lite and the Dynon D10A. -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re:
Date: Apr 13, 2005
I would be careful if you decide to do it. Here is the concern I have with this. Once you dimple, you have very slightly enlarged the original hole size. Now when redimpling, you are putting the already slightly larger hole again on the dimple die, you have a good chance of having a slight misalignment rather than the die being dead center as it was the first time. It will not be much off, but it will be there. I'd say the resulting dimple will not be perfect. I would do the other tank with the Cleveland dies leaving what was done done; and after you get the plane painted, see if you can tell a difference. My experience: I built my wings and used Avery dies. My friend has the Cleveland tank dies. His might look better than mine but it is not overwhelmingly different. Indiana Larry, RV7 Tip Up -- Ready for first flight just about any time it is right......... > > > After dimpling my tank skins with a standard (Avery) dimple die set I > learned of the tank die set sold by Cleaveland Aircraft. My question > is this: will re-dimpling my tank skins with the tank die set reduce the > strength of the rivetted joint? > > ________________________________________________________________________________
From: "Stucklen, Frederic W UTPWR" <Fred.Stucklen(at)UTCFuelCells.com>
Date: Apr 14, 2005
Don, I've had the same problems. GET RID OF THE 386 PLUGS..... If you look at the #4 cylinder plugs, you will see that the ceramic has been damaged, actually melted! And with them glowing you have pre-ignition problems, causing back-firing into the intake manifold, causing ALL cylinders to misfire. (BTW, immediately pulling the mixture, counting to three, pushing it back in, will "put out" the glow plug effect, and save your cylinder...). Put in aviation plugs, preferably REM 37BY (or is it REM 38 BY) in all cylinders. It means a new harness, or at least new terminations, but it will solve the problem. My carbureted O-320 with 9:1 pistons had the exact same problems. I initially thought that it was the ignitions systems. But close examination of the plugs (even new ones) revealed the pre-ignition problem. I tried everything - full mixture, aux pump ON, full throttle (even pumped the throttle), mag check - all the standard emergency procedures, nothing seemed to work. I finally started pulling the mixture to cut-off immediately when I started getting the rough engine. Wait 3 seconds, then pushed it in, and vola! the problem went away! Fred stucklen RV-6A N926RV 375 Hrs Time: Subject: Engine problems. From: Donald Nowakowski < nowakod(at)us.ibm.com <mailto:nowakod(at)us.ibm.com> > 04/13/2005 16:28:36, Serialize complete at 04/13/2005 16:28:36 > Folks, Any help would be appreciated. Having said that, Ed Holyoke's situation is much more dire than mine so help him first (he is traveling, I am at my home airport). Plane specifics: RV-6, 0-320-B2C, Fixed pitch Sensenich, Jeff Rose ignition on the right firing Autolite 386 Auto plugs in the bottom of each cylinder, Slick Mag on the left firing the top aircraft plugs, New carb at overhaul, 240hours SMOH. I was flying the other day for about 1/2 hour when out of the blue the engine started running extremely rough. Mag check and fuel switch yielded the same result. All cylinder temps were in the norm except for #4 which went very hot (512 degrees on the CHT). All other cylinders were a little warmer than normal but not much...I think the hottest was 320 degrees. I wish I had the presence of mind to also notice the EGT's but I didn't....focus was on #4 CHT and getting my butt on the ground. At full throttle the plane would only muster 120 MPH. As soon as I had the airport made and pulled power for landing, everything smoothed out. It was instantaneous with pulling power. After landing and taxi back to the ramp I did a run up and had full RPM with not even a hint of a miss. The next day I did a compression check. All cylinder OK except for #4... 80/65. At annual just about a month ago this cylinder was my lowest but was at 80/70. I was concerned then but my IA friend told me that I shouldn't worry too much about it but to keep an eye on it. Other three cylinders 80/78, 80/79, 80/78. I am totally baffled. I suspected an air leak but found none. I was worried about detonation but the top of the piston looks great...no pitting. The cylinder walls look good also. The compression test revealed that the leak seems to be mostly from the intake but the exhaust is leaking also. How do I troubleshoot? I am tempted to fly the plane again (close to the airport) but I am spooked. I would love to know what happened and have a fix before heading into the sky. Thanks in advance for any/all ideas.....don Don Nowakowski , Equipment Engineering Tech Telephone (802)288-3359, ________________________________________________________________________________
Date: Apr 14, 2005
> I've had the same problems. GET RID OF THE 386 PLUGS..... If you look at I agree 100%. Those plugs are no good in a Lycoming. Its too cold of a plug. I use the plugs Klaus recommends with my Electroair; they are the Denso W27ESR-U with adapters. There is an equivalent NGK that I now use (I forget the number) that are a cross-reference plug to the Denso's. I used to change them at every oil change, but found that was unnecessary. I change them now during annual. Regards, Bob Japundza RV-6 flying 600+ hours, F1 under const. ________________________________________________________________________________
Date: Apr 14, 2005
> I agree 100%. Those plugs are no good in a Lycoming. Its too cold of > a plug. I use the plugs Klaus recommends with my Electroair; they are > the Denso W27ESR-U with adapters. There is an equivalent NGK that I > now use (I forget the number) that are a cross-reference plug to the > Denso's. I used to change them at every oil change, but found that > was unnecessary. I change them now during annual. I believe BR9ES is the NGK equivalent to the Denso W27EMR-C, not sure about the W27ESR-U. Double check me on that. Klaus sells the W27EMR-C and W24EMR-C plugs last time I looked. I use NGK BR8ES (5422) plugs with my Lightspeed Plasma II on my RV-7, IO-360-A1B6, 8.7:1. I have had great performance and no problems with the BR8ES plugs. They're available at just about any auto parts store. I found the cheapest source to be Pep Boys at $1.79 each. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Apr 14, 2005
Subject: Re: Snorkle for AirFlow Performance FM-200
On 04/13 3:42, Ron Jagels wrote: > > I have an IO-360-M1 with Airflow Performance fuel injection (FM-200 controller). Using the smooth lower cowl and firewall forward kit from Vans which has a fiberglass filtered air inlet plenum made for a Bendix fuel injector - hence flat face mating surface with four bolt holes. Several questions: > > 1) Has anyone modified the Vans plenum to fit the FM-200 controller? I am aware of several builders who have placed a wye on the FM inlet and used one branch for the filtered air inlet and one branch as ram air inlet. This requires adding a hole in the lower cowl and I'm looking for other solutions. > > 2) What method was used to attach inlet plenum to the FM-200 controller? > > 3) What attachment piece was used to transition between the fiberglass plenum and the FM-200 inlet? > > Photos and/or drawings for the above would be greatly appreciated. I used some silicone tank baffle material and clamped it on. -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: Apr 14, 2005
Subject: CLEVELAND WHEELS/BRAKES -- 600X6 ON INCH AND 1/4 AXLES
CHECK OUT EBAY ITEM # 4543359529. NEW 600X6 LOW PROFILE TIRES WHEELS/BRAKES, SPACERS AND BUSHINGS FOR RV-8 -- TOM Tom Whelan Whelan Farms Airport President EAA Chapter 1097 wfact01(at)aol.com 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 Tel: 203-266-5300 Fax: 202-266-5140 EAA Technical/Flight Advisor RV-8 540 LYC (40 PLUS HOURS) S-51 Mustang Turbine (Under Construction) ________________________________________________________________________________
Date: Apr 14, 2005
On 4/14/05, Dan Checkoway wrote: > I use NGK BR8ES (5422) plugs with my Lightspeed Plasma II on my RV-7, > IO-360-A1B6, 8.7:1. I have had great performance and no problems with the > BR8ES plugs. They're available at just about any auto parts store. I found > the cheapest source to be Pep Boys at $1.79 each. Yes that sounds like the correct part number. Regards, Bob ________________________________________________________________________________
Date: Apr 14, 2005
Subject: Re: CLEVELAND WHEELS/BRAKES -- 600X6 ON INCH AND 1/4 AXLES
Hi, Is this a fairly common upgrade to the RV8? Where I fly we have a lot of grass strips, but I've never had any trouble with the Warrior I currently fly. Will the standard wheel pants fit with these bigger wheels and tires? Thanks, Mickey > CHECK OUT EBAY ITEM # 4543359529. NEW 600X6 LOW PROFILE TIRES WHEELS/BRAKES, > SPACERS AND BUSHINGS FOR RV-8 -- TOM > > Tom Whelan > Whelan Farms Airport > President EAA Chapter 1097 > wfact01(at)aol.com > 249 Hard Hill Road North > PO Box 426 > Bethlehem, CT 06751 > Tel: 203-266-5300 > Fax: 202-266-5140 > EAA Technical/Flight Advisor > RV-8 540 LYC (40 PLUS HOURS) > S-51 Mustang Turbine (Under Construction) -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
Date: Apr 14, 2005
MICKY-I HAD A MODED STOCK PAIR THAT WORKED-TOM Tom Whelan Whelan Farms Airport President EAA Chapter 1097 wfact01(at)aol.com 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 Tel: 203-266-5300 Fax: 202-266-5140 EAA Technical/Flight Advisor RV-8 540 LYC (40 PLUS HOURS) S-51 Mustang Turbine (Under Construction) ________________________________________________________________________________
Date: Apr 14, 2005
Subject: Re: Should I or shouldn't I
In a message dated 4/12/2005 1:43:46 A.M. Pacific Daylight Time, jorear(at)new.rr.com writes: This question is directed more toward my 6/6A brethren who are flying their creations. If you were in my shoes, where I am just about to take my 6A to the airport, would you replace the vertical stab and rudder with a 7/7A version prior to getting everything completed? Those of you that are flying the 6/6A, do you ever wish you had more rudder authority? Is the tendency to fishtail that apparent with the 6/6A vertical stab and rudder? =============================== No way! It's fine just the way it is. GV (RV-6A N1GV O-360-A1A, C/S, Flying 738hrs, Silicon Valley, CA) ________________________________________________________________________________
Subject: Kx 125 repair guy needed
Date: Apr 14, 2005
My radio nav side has had a problem for a while, when I turn up the vol on nav to listen for Vor ID I get white noise which overrides comm side as well. I spoke to a radio guy about another problem, think his name is George something.. believe he is in Seven Lakes airpark. would like to get ahold of him, but lost all contact info. Anybody know him & how to get ahold of him? Any other recomendations for raidio repair guy in Atl area? charlie heathco ________________________________________________________________________________
Date: Apr 15, 2005
During the past 7.5 years of flying my RV, there was only one time that I wish I had a larger rudder. The wind was 080 degrees to the runway and gusts were 38 knots. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,654 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com In a message dated 4/12/2005 1:43:46 A.M. Pacific Daylight Time, jorear(at)new.rr.com writes: This question is directed more toward my 6/6A brethren who are flying their creations. If you were in my shoes, where I am just about to take my 6A to the airport, would you replace the vertical stab and rudder with a 7/7A version prior to getting everything completed? Those of you that are flying the 6/6A, do you ever wish you had more rudder authority? Is the tendency to fishtail that apparent with the 6/6A vertical stab and rudder? ________________________________________________________________________________
Date: Apr 14, 2005
Call Honeywell @ 1-913-782-0400, ask receptionist for ext 1082 and tell the person that answers that you need to speak with someone for technical assistance on a KX125. Let us know about your experience with Honeywell. -Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Heathco Subject: RV-List: Kx 125 repair guy needed My radio nav side has had a problem for a while, when I turn up the vol on nav to listen for Vor ID I get white noise which overrides comm side as well. I spoke to a radio guy about another problem, think his name is George something.. believe he is in Seven Lakes airpark. would like to get ahold of him, but lost all contact info. Anybody know him & how to get ahold of him? Any other recomendations for raidio repair guy in Atl area? charlie heathco ________________________________________________________________________________
Date: Apr 15, 2005
My 6a has no fishtail tendencys, in fact I can kick the rudder, and it will return to stable flight in about 2 or 3 osilations. If you want to do acro, I think the taller tail would be a hinderance, charlie heathco ________________________________________________________________________________
Date: Apr 15, 2005
Man! I thought I was pushing it with 80d gusts to 30K. You a hell of a pilot Gary! charlie heathco ________________________________________________________________________________
Date: Apr 15, 2005
Charles Heathco wrote: > >My 6a has no fishtail tendencys, in fact I can kick the rudder, and it will return to stable flight in about 2 or 3 osilations. If you want to do acro, I think the taller tail would be a hinderance, charlie heathco > > Base on what? From experience it is not a hindrance at all. Also I don't believe your 6A has no fishtail tendencies because they all do it so why should yours be any different? It is a characteristic of the design in turbulence. Anyone that says it is not an improvement has not flown both stab. and rudders on a -6 as I have. Jerry . ________________________________________________________________________________
Subject: Should I or shouldn't I
Date: Apr 15, 2005
> In a message dated 4/12/2005 1:43:46 A.M. Pacific Daylight > Time, jorear(at)new.rr.com writes: > > This question is directed more toward my 6/6A brethren who > are flying their creations. > > If you were in my shoes, where I am just about to take my 6A to the > airport, > would you replace the vertical stab and rudder with a 7/7A > version prior to getting everything completed? Those of you > that are flying the 6/6A, do > you > ever wish you had more rudder authority? Is the tendency to > fishtail that apparent with the 6/6A vertical stab and rudder? I have consistently noticed with my 6A, when landing in crosswinds, that the amount of rudder needed diminishes significantly during the last couple feet of altitude prior to touchdown. Apparently, the low profile of these planes allows much of the plane, wings particularly, to be in much lower velocity air close to the ground. This was not the case with spam cans that I had previously flown. I've landed in direct crosswinds up to 22g28 winds as reported by AWOS. At 10 feet, I might have had 3/4 rudder applied, but at touchdown, maybe 1/2. The only complaint I have about the rudder in my 6A is that the pedal forces are quite high - maybe the "counterweighted" 7 rudder is better in this regard, I don't know. As to yaw in the air, that seems to be a stronger function of CG than VS. Additionally, I have noticed that when the autopilot is flying, it corrects a turbulence induced wing drop fast enough where adverse yaw is almost eliminated. When hand flying, this is not the case. It could also be that yaw stability is affected by taildragger/trike differences, as the wheel and gear fairings have significant areas. I have not flown much in a 7A, so I don't have direct comparison. However, if I were building another 6 kit, I would not bother with modifying the VS. Alex Peterson RV6-A 609 hours Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: Engine Problems
Date: Apr 15, 2005
11, 2005) at 04/15/2005 10:05:20, Serialize complete at 04/15/2005 10:05:20 Folks, I can't thank you enough for all of your ideas. The folks who have had the same problem as me with the same ignition system/spark plug combination have steered me in the right direction. I took out the Autolite 386 spark plug in #4 and the ceramic was in bad shape. I have ordered the REM37BY's and the new wiring harness from Electroair. I think I had a glowing plug as Fred S. described. Hopefully this is the fix. If not, I'll be back here asking for more ideas. Thanks again to all. This list is a great resource.....don Don Nowakowski , Equipment Engineering Tech Telephone (802)288-3359, "More than anything else the sensation is one of perfect peace mingled with an excitement that strains every nerve to the utmost, if you can conceive of such a combination." -- Wilbur Wright ________________________________________________________________________________
Date: Apr 15, 2005
I have a couple thousand landings on my 6A, and love to go out and practice crosswinds frequently. My experience is exactly as Alex, and would recommend the same. Walsh On Apr 15, 2005, at 7:00 AM, Alex Peterson wrote: > > > >> In a message dated 4/12/2005 1:43:46 A.M. Pacific Daylight >> Time, jorear(at)new.rr.com writes: >> >> This question is directed more toward my 6/6A brethren who >> are flying their creations. >> >> If you were in my shoes, where I am just about to take my 6A to the >> airport, >> would you replace the vertical stab and rudder with a 7/7A >> version prior to getting everything completed? Those of you >> that are flying the 6/6A, do >> you >> ever wish you had more rudder authority? Is the tendency to >> fishtail that apparent with the 6/6A vertical stab and rudder? > > I have consistently noticed with my 6A, when landing in crosswinds, > that the > amount of rudder needed diminishes significantly during the last > couple feet > of altitude prior to touchdown. Apparently, the low profile of these > planes > allows much of the plane, wings particularly, to be in much lower > velocity > air close to the ground. This was not the case with spam cans that I > had > previously flown. I've landed in direct crosswinds up to 22g28 winds > as > reported by AWOS. At 10 feet, I might have had 3/4 rudder applied, > but at > touchdown, maybe 1/2. The only complaint I have about the rudder in > my 6A > is that the pedal forces are quite high - maybe the "counterweighted" 7 > rudder is better in this regard, I don't know. > > As to yaw in the air, that seems to be a stronger function of CG than > VS. > Additionally, I have noticed that when the autopilot is flying, it > corrects > a turbulence induced wing drop fast enough where adverse yaw is almost > eliminated. When hand flying, this is not the case. It could also be > that > yaw stability is affected by taildragger/trike differences, as the > wheel and > gear fairings have significant areas. > > I have not flown much in a 7A, so I don't have direct comparison. > However, > if I were building another 6 kit, I would not bother with modifying > the VS. > > Alex Peterson > RV6-A 609 hours > Maple Grove, MN > > http://www.home.earthlink.net/~alexpeterson/ > > ________________________________________________________________________________
Date: Apr 15, 2005
Subject: Static System Connections
Is there an easy way to insert the recommended 3/16" plastic tube fittings into the 1/4" OD plastic static lines. Hot water helps but its still very difficult to get the tubing on all the way. Jack H. 6A - finishing kit ________________________________________________________________________________
Date: Apr 15, 2005
Subject: Pitot tube & mount
I have a heated pitot tube from aircraft spruce: http://www.aircraftspruce.com/catalog/inpages/homepitot.php I also have the mount the aircraft spruce sells: http://www.aircraftspruce.com/catalog/inpages/gretzbrackets.php I have found that the mount and the pitot tube are not compatible even though it describes it on webpage and in the catalog as being the correct mount to order. For guys using this heated pitot tube, which mount did you use? ACS solution is to return the items. Anybody have an actual solution? Steve RV7A ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Subject: GPS phone
Date: Apr 15, 2005
My 4 year old daughter just threw my cell phone in the fish pond so I'm shopping for a new one. My question is do any of you guys have a cell phone with built in GPS and if so is it useful in the airplane? I know that a lot of phones have GPS chips for locating you in emergency, but I want one that will give coordinates. A quick search on the web showed something similar on Nextel but I have a regular Verizon phone. Just curious... Thanks in advance Evan Johnson www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ________________________________________________________________________________
Date: Apr 15, 2005
Subject: Pitot Tube & Mount Part 2
Here is a website showing the fit of the pitot tube and mount: http://www.members.kingston.net/sjhdcl/Pitot%20Tube.htm Steve RV7A ________________________________________________________________________________
Subject: Ique 3600a ?
Date: Apr 15, 2005
A friend sent the following to Garmin Inquiry: > I am considering the iQue 3600a to put in my homebuilt and was wondering > if > the unit has the ability to drive my autopilot through some sort of > link?Or to > put it another way is there provisions for a signal out? Garmin's answer indicated that the iQue 3600a is the one portable GPS that does not output the NMEA 0183 sentences needed by some devices to drive an autopilot. The response also indicated that a work around has been found by "some people". If this is in fact true? can "some of you" describe the fixes and how you feel about the efficacy of the outcome? Jim in Kelowna ________________________________________________________________________________
Date: Apr 15, 2005
Subject: Tips for riveting LE ribs #13 and 14 to wing spar?
I am having the devil's own time trying to figure out how to pound the AN470-4 rivets that attach leading edge ribs #13 and 14 (the two outermost) to the wing main spar. There's little room to get the rivet gun into the leading edge space and it's awkward as hell trying to hold the rivet gun while also holding the bucking bar. I even tried installing the rivets with the manufactured head facing aft, instead of forward, and botched them. Any suggestions as to how I can do them on my own, or are these such that I really need another set of hands? And...I've drilled out and replaced (and botched again) at least two rivets to the point where the holes are probably too large for AN470-4 rivets...sigh. And it occurred to me...are there any pop rivets that would work as substitutes? This is what I get for having to lay off building for almost three years. Ugh. Semper Fi John (RV-6 - left wing - destroying the world's supply of AN470-4 rivets one at a time) __________________________________ http://travel.yahoo.com/p-travelguide ________________________________________________________________________________
Date: Apr 15, 2005
Subject: Re: GPS phone
Current location 97.467 degrees west, 34.05 degrees north. Now go to Meadow lake airport. probably can't. Get an aviation GPS unit or Etrex driving a PDA or similar of you want to use GPS for navigation. Ron Lee At 01:47 PM 4/15/2005, you wrote: > >My 4 year old daughter just threw my cell phone in the fish pond so I'm >shopping for a new one. My question is do any of you guys have a cell >phone with built in GPS and if so is it useful in the airplane? I know >that a lot of phones have GPS chips for locating you in emergency, but I >want one that will give coordinates. A quick search on the web showed >something similar on Nextel but I have a regular Verizon phone. Just curious... ________________________________________________________________________________
Subject: Re: Tips for riveting LE ribs #13 and 14 to wing spar?
Date: Apr 15, 2005
Hi John, You can you LP4-3 pop rivets. Best of luck Kirk RV-8 starting QB fuse > > From: John Lawson <rv6builder48138(at)yahoo.com> > Date: 2005/04/15 Fri PM 09:16:47 EDT > To: rv-list(at)matronics.com > Subject: RV-List: Tips for riveting LE ribs #13 and 14 to wing spar? > > > I am having the devil's own time trying to figure out > how to pound the AN470-4 rivets that attach leading > edge ribs #13 and 14 (the two outermost) to the wing > main spar. There's little room to get the rivet gun > into the leading edge space and it's awkward as hell > trying to hold the rivet gun while also holding the > bucking bar. I even tried installing the rivets with > the manufactured head facing aft, instead of forward, > and botched them. Any suggestions as to how I can do > them on my own, or are these such that I really need > another set of hands? And...I've drilled out and > replaced (and botched again) at least two rivets to > the point where the holes are probably too large for > AN470-4 rivets...sigh. And it occurred to me...are > there any pop rivets that would work as substitutes? > > This is what I get for having to lay off building for > almost three years. Ugh. > > Semper Fi > John (RV-6 - left wing - destroying the world's supply > of AN470-4 rivets one at a time) > > > > __________________________________ > http://travel.yahoo.com/p-travelguide > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2005
Engine Lyc O-320-A1A 150hp, Bendix mags. Symptoms: Started running rough on right mag, EGT's normal except #1 was elevated approx 200 degs. in cruise, CHT about 20 deg. lower than normal. Solution: Found #1L plug was shorted with small balls of material stuck-one in each gap. When tested, at first plug did not fire but soon started firing even though mater was still in gap. After cleaning, engine runs normally, both EGT and CHT as before. After reading all the posts recently about engine problems I don't understand why the EGT was elevated with plug fouled. I would have thought the unburned fuel would have cooled the exhaust and lowered EGT. Albert Gardner RV-9A 872RV Yuma, AZ ________________________________________________________________________________
Date: Apr 15, 2005
It is because the fuel burns as it goes into the exhaust pipe where the EGT probe is. Rob Hickman N401RH RV-4 ________________________________________________________________________________
Subject: Re: RVs in Kamloops / Kelowna??
Date: Apr 15, 2005
I'm down from Yellowknife for the weekend and will be in and around Kamloops and Kelowna area this weekend. As I haven't purchased my kit yet I'd love to get a glimps of one under construction or see a flying one. A ride would be great too and I'd be more than willing cover the cost of gas etc. If you have a RV in the construction phase and or flying stage and have sometime to spare this weekend post an note on when and where would be best to contact you. Kevin ________________________________________________________________________________
Subject: Re: Static System Connections
Date: Apr 15, 2005
This Van's "method" has to be the most ignorant thing about the entire kit - totally unacceptable to do it their way. I went to a local "fittings" shop (brass & plastic) and bought standard, cheap Ts with the screw on caps that you just stick the tubing into and then tighten the caps. Totally professional, totally secure, totally better than forcing the one size tubing onto the smaller (but not small enough) tubing and then having the ends split by a week later. They claim "they never heard of that one before". Yeah, sure, I'm the ONLY ONE who had the tubing split. David ----- Original Message ----- From: "Jack" <jgh2(at)charter.net> Subject: RV-List: Static System Connections > > Is there an easy way to insert the recommended 3/16" plastic tube > fittings into the 1/4" OD plastic static lines. Hot water helps but > its still very difficult to get the tubing on all the way. > > Jack H. > 6A - finishing kit > > ________________________________________________________________________________
Subject: RE: [AtlRVers] Kx 125 repair guy needed
Date: Apr 15, 2005
Charlie, You are looking for George Mock I believe his company name is Atlanta Avionics. 770-504-0011 Mike Crowe _____ From: AtlRVers(at)yahoogroups.com [mailto:AtlRVers(at)yahoogroups.com] On Behalf Of Charles Heathco Subject: [AtlRVers] Kx 125 repair guy needed My radio nav side has had a problem for a while, when I turn up the vol on nav to listen for Vor ID I get white noise which overrides comm side as well. I spoke to a radio guy about another problem, think his name is George something.. believe he is in Seven Lakes airpark. would like to get ahold of him, but lost all contact info. Anybody know him & how to get ahold of him? Any other recomendations for raidio repair guy in Atl area? charlie heathco ________________________________________________________________________________
Date: Apr 15, 2005
A while ago I asked if anyone had tried the Garmin NavTalk Pilot but there were no responses. I think it was discontinued but there might be a replacement model. Roger Embree C-GIRH Evan and Megan Johnson wrote: > >My 4 year old daughter just threw my cell phone in the fish pond so I'm shopping for a new one. My question is do any of you guys have a cell phone with built in GPS and if so is it useful in the airplane? I know that a lot of phones have GPS chips for locating you in emergency, but I want one that will give coordinates. A quick search on the web showed something similar on Nextel but I have a regular Verizon phone. Just curious... >Thanks in advance >Evan Johnson >www.evansaviationproducts.com >(530)247-0375 >(530)351-1776 cell > > > > ________________________________________________________________________________
Date: Apr 15, 2005
The key to bucking rivets by yourself is to clamp the piece down to a table or something to hold it steady. Better to have a helper but if doing it yourself, it must be held somehow. If you can get the bucking bar on it and somehow manage it so it does not vibrate off the rivet, you can do a very good job of buck riveting by yourself. You can use pop rivets but if you can do the job without damaging it up, better to use the solid ones. Friends are like angels who lift us to our feet when our wings have trouble remembering how to fly....unknown Indiana Larry, RV7 Tip Up ----- Original Message ----- From: <groves(at)epix.net> Subject: Re: RV-List: Tips for riveting LE ribs #13 and 14 to wing spar? > > Hi John, > You can you LP4-3 pop rivets. > Best of luck > Kirk RV-8 starting QB fuse >> >> From: John Lawson <rv6builder48138(at)yahoo.com> >> Date: 2005/04/15 Fri PM 09:16:47 EDT >> To: rv-list(at)matronics.com >> Subject: RV-List: Tips for riveting LE ribs #13 and 14 to wing spar? >> >> >> I am having the devil's own time trying to figure out >> how to pound the AN470-4 rivets that attach leading >> edge ribs #13 and 14 (the two outermost) to the wing >> main spar. There's little room to get the rivet gun >> into the leading edge space and it's awkward as hell >> trying to hold the rivet gun while also holding the >> bucking bar. I even tried installing the rivets with >> the manufactured head facing aft, instead of forward, >> and botched them. Any suggestions as to how I can do >> them on my own, or are these such that I really need >> another set of hands? And...I've drilled out and >> replaced (and botched again) at least two rivets to >> the point where the holes are probably too large for >> AN470-4 rivets...sigh. And it occurred to me...are >> there any pop rivets that would work as substitutes? >> >> This is what I get for having to lay off building for >> almost three years. Ugh. >> >> Semper Fi >> John (RV-6 - left wing - destroying the world's supply >> of AN470-4 rivets one at a time) >> >> >> >> __________________________________ >> http://travel.yahoo.com/p-travelguide >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Apr 15, 2005
The typical symptom for 1 out of 2 plugs fouled in a cylinder is that EGT goes up and CHT goes down. The reason for this is that the MAGS are timed so that the optimal timing and power occurs when both plugs are firing. When only one of the two plugs fires, the flame front starts out smaller, and travels a bit slower. The end result is that the combustion process doesn't quite complete itself before the exhaust valve opens, and so the combustion energy is transferred to the exhaust rather than the cylinder. This is why the CHT's drop and EGT's rise in this situation. Skylor RV-8 QB, Under Construction --- Albert Gardner wrote: > > > Engine Lyc O-320-A1A 150hp, Bendix mags. > Symptoms: Started running rough on right mag, EGT's > normal except #1 was > elevated approx 200 degs. in cruise, CHT about 20 > deg. lower than normal. > Solution: Found #1L plug was shorted with small > balls of material stuck-one > in each gap. When tested, at first plug did not fire > but soon started firing > even though mater was still in gap. After cleaning, > engine runs normally, > both EGT and CHT as before. > After reading all the posts recently about engine > problems I don't > understand why the EGT was elevated with plug > fouled. I would have thought > the unburned fuel would have cooled the exhaust and > lowered EGT. > Albert Gardner > RV-9A 872RV > Yuma, AZ > > > > browse > Subscriptions page, > FAQ, > > > > > > __________________________________ http://travel.yahoo.com/p-travelguide ________________________________________________________________________________
Date: Apr 16, 2005
Hi John I also laid off building for about 3 years after completing a RV-6A and then started on a RV-7A. Had a terrible time driving AN470-4 rivets and didn't remember having trouble with the first aircraft. After drilling out some rivets three times and using larger rivets I decided to buy a new rivet set (get two, 3" and 5" from Cleveland), suddenly no more problems with mashed rivet heads and humungous smiley's. Not sure if this is factual but I was later told that some of the cheaper RV builders kits had included used rivet sets and I guess they do wear out. George in Langley BC 7A fwd fuse -----Original Message----- I am having the devil's own time trying to figure out how to pound the AN470-4 rivets snip------------------- And...I've drilled out and replaced (and botched again) at least two rivets to the point where the holes are probably too large for AN470-4 rivets...sigh. snip---------- This is what I get for having to lay off building for almost three years. Ugh. Semper Fi John (RV-6 - left wing - destroying the world's supply of AN470-4 rivets one at a time) ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Subject: Aerosport Engines and Shipping/Tax issues
Date: Apr 16, 2005
> Subject: RV-List: Aerosport Engines and Shipping/Tax issues > Tim, you will have a hard time finding a better person to talk to about your questions than Bart LaLonde of Aerosport Power. He is almost always available on the phone, and will spend as much time with you as you need. He will build an engine with all new parts, partly used, everything used, whatever you want. I have yet to hear of any customer service problems that they did not take care of. I have over 600 hours on my Aerosport engine now, and it looks as clean as the day I installed it. The engines are works of art. Alex Peterson RV6-A 609 hours Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Apr 16, 2005
Subject: Re: Aerosport Engines and Shipping/Tax issues
Freight on my engine to Louisiana was $195?? It was less to ship from Canada than it would have been from Dallas. wp ________________________________________________________________________________
Date: Apr 16, 2005
Tim: I will second Alex's assessment of AeroSport. I now have 175+ hrs on my Aerosport engine and it has been flawless. When I was engine shopping, I had heard so many good reports about Bart, I decided to combine a ski trip to Kamloops with a visit to his shop (this was 6 years ago). Bart is an engine genius in my opinion. I spent the morning with him and most of the time he was talking way over my head. I was sold right there. Since then, more than a dozen Aerosport engines are powering RVs in the Twin Cities RV Builder's Club. Bart will go that extra mile and there have been many instances his outstanding customer service. My engine was 100% new except for the case which was an OH unit. Bart will build an engine in any many you choose with whatever parts you choose. As to taxes and shipping, I think I recall a small broker fee (seems like it was 50 or 60 dollars and that was it. Shipping was comparable to a similar parcel coming from Van's. If you would like more details, feel free to contact me off list. Doug Weiler, pres MN Wing Hudson, WI On 4/16/05 8:26 AM, "Tim Olson" wrote: > > Hi all, > > I have been trying to figure out where to buy my engine, and I want to > buy it soon. I've talked to a couple of domestic engine shops, and > AeroSport Power in Canada. I've heard they have a good reputation, > which is my main motivator for them. > > My questions are: I'm in Wisconsin and I had another engine company > tell me that if I order from AeroSport I might face some odd tax > consequences as customs or someone makes Aerosport report to your > state the cost of the engine or something like that. I'm not sure > this is really relevant though, because I'm thinking that in Wisconsin > I need to pay sales tax on the plane when I register it anyway...this > would just be paying tax early I'd assume. Can anyone who's purchased > one from them, or knows what the deal is enlighten me? > > Another question is, do pretty much all engine companies re-use the > cams and gears? I was thinking that Aerosport said they reuse the > crank and case, but most companies give me the impression that those > are the only parts re-used....but, when you push harder and dig > deeper, they seem to start to indicate that they regrind cams if > within limits, reuse gears, and some other things. I'd like to > go as new as possible. > > Regarding fuel injection systems: AeroSport lists their IO's with > "new fuel injection system". Then I talked to another place and > they rebuild the existing bendix system. What's the best route > here? Does Aerosport use precision fuel injection systems that > would be much better? > > My last question is, the last engine place I talked to looked at me > like I was crazy when I asked if they use roller lifters on their > engines or if they can. They said that in all 20+ years they haven't > done that. I was under the impression that there are new roller > lifters out recently, and that these things are great for reducing > wear. What's the deal? > > Thanks for any help you guys can offer. I'm hoping to start to rope > in my engine soon. > > Tim ________________________________________________________________________________
Date: Apr 16, 2005
Subject: Re: Ique 3600a ?
Jim Jewell wrote: >>I am considering the iQue 3600a to put in my homebuilt and was wondering >>if the unit has the ability to drive my autopilot through some sort of >>link? Or to put it another way is there provisions for a signal out? > > Garmin's answer indicated that the iQue 3600a is the one portable GPS that > does not output the NMEA 0183 sentences needed by some devices to drive an > autopilot. I just read in a magazine this week (i'll try and find the article if anyone wants it) that some of Garmin's eTrex units only have USB connectors, and *DO NOT* support the NMEA standard protocols. Garmin appears to be moving away from the NMEA standards, at least on their consumer-oriented units. I'm not sure if the 3600a falls in this category or not, but you should be able to find out from Garmin what protocols it will output and how it does it. If you know what protocols your autopilot takes in, it should be a simple matter to determine whether they're compatable. fwiw, I replaced my trusty GPS III with a GPSMAP 76CS this year. I still advocate avoiding the aviation units with their expensive, proprietary databases. A consumer GPS can have all the airports you want entered into it with your computer, and you can always carry a Flight Supplement to look up frequencies. And the FS is cheaper to keep up-to-date than a proprietary aviation database. Just my $0.02! Rob in Burnaby ________________________________________________________________________________
Date: Apr 16, 2005
3600a doesn't output ANYTHING. It's not designed to interact with any other device according to on of their folks I called. -------------- Original message -------------- > > Jim Jewell wrote: > >>I am considering the iQue 3600a to put in my homebuilt and was wondering > >>if the unit has the ability to drive my autopilot through some sort of > >>link? Or to put it another way is there provisions for a signal out? > > > > Garmin's answer indicated that the iQue 3600a is the one portable GPS that > > does not output the NMEA 0183 sentences needed by some devices to drive an > > autopilot. > > I just read in a magazine this week (i'll try and find the article if > anyone wants it) that some of Garmin's eTrex units only have USB > connectors, and *DO NOT* support the NMEA standard protocols. Garmin > appears to be moving away from the NMEA standards, at least on their > consumer-oriented units. I'm not sure if the 3600a falls in this > category or not, but you should be able to find out from Garmin what > protocols it will output and how it does it. If you know what protocols > your autopilot takes in, it should be a simple matter to determine > whether they're compatable. > > fwiw, I replaced my trusty GPS III with a GPSMAP 76CS this year. I > still advocate avoiding the aviation units with their expensive, > proprietary databases. A consumer GPS can have all the airports you > want entered into it with your computer, and you can always carry a > Flight Supplement to look up frequencies. And the FS is cheaper to keep > up-to-date than a proprietary aviation database. > > Just my $0.02! > > Rob in Burnaby > > > > > > 3600a doesn't output ANYTHING. It's not designed to interact with any other device according to on of their folks I called. -------------- Original message -------------- -- RV-List message posted by: "Rob Prior (rv7)" Jim Jewell wrote: -- RV-List message posted by: "Jim Jewell" I am considering the iQue 3600a to put in my homebuilt and was wondering if the unit has the ability to drive my autopilot through some sort of link? Or to put it another way is there provisions for a signal out? Garmin's answer indicated that the iQue 3600a is the one portable GPS that does not output the NMEA 0183 sentences needed by some devices to drive an autopilot. I just read in a magazine this week (i'll try and find the article if anyone wants it) that some of Garmin's eTrex units only have USB connectors, and *DO NOT* support the NMEA standard protocols. Garmin appears to be moving away from the NMEA standards, at least on their consumer-oriented units. I'm not sure if the 3600a falls in this category or not, but you should be able to find out from Garmin what protocols it will output and how it does it. If you know what protocols your autopilot takes in, it should be a simple matter to determine whether they're compatable. fwiw, I replaced my trusty GPS III with a GPSMAP 76CS this year. I still advocate avoiding the aviation units with their expensive, proprietary databases. A consumer GPS can have all the airports you want entered into it with your computer, and you can always carry a Flight Supplement to look up frequencies. And the FS is cheaper to keep up-to-date than a proprietary aviation database. Just my $0.02! Rob in Burnaby ________________________________________________________________________________
Date: Apr 16, 2005
Tim, Have an O-360 A1A from Aero Sport Power and have 45 hours of flight time on airplane. Engine is now running as expected. However, there were some detail issues: 1. Engine was shipped without desiccant plugs as promised. 2. Engine was shipped without oil dip stick and tube. 3. Starter needed to be exchanged because the gear did not match the ring gear on the engine. 4. Engine would not start because the LASAR mags were not timed correctly. Right mag was 360 deg off. (timed to fire on the exhaust stroke) Left mag was timed "out in left field". On the tax issue, check it out carefully. Another local RV builder sent an engine to ASP for repair after a prop. strike and had to pay taxes to get it back. Dale Ensing RV-6A in North Carolina ________________________________________________________________________________
Date: Apr 16, 2005
In a message dated 4/14/05 5:42:28 PM Pacific Daylight Time, Vanremog(at)aol.com writes: > < their > creations. > > If you were in my shoes, where I am just about to take my 6A to the > airport, > would you replace the vertical stab and rudder with a 7/7A version prior to > getting everything completed? Those of you that are flying the 6/6A, do > you > ever wish you had more rudder authority? Is the tendency to fishtail that > apparent with the 6/6A vertical stab and rudder? > >> I've only got 62+ hours on my -6 so far but I would also say "no way" (especially if you are planning on a lighter prop like a composite or wood.) Yeah, there is a little bit of fish tailing in moderate turbulence, but so what? I don't have any significant amount of time in a "V" tail Bonanza but I've always heard they do the same thing. The airplane flies just fine with the original tail, why screw with success and add tail weight in the process. Harry Crosby RV-6 N16CX, 62 hours R ________________________________________________________________________________
Subject: confused about taxes
Date: Apr 16, 2005
Hi all, I am getting ready to order the -10 kit and trying to make heads or tails of the California / Santa Clara County tax laws around aircraft, and specifically homebuilts ;) Does anyone have any resources that they can refer me to to get a plain English explanation of the rules? i.e. since I'll be buying from a seller in Oregon, for California, do I pay the sales tax for each component of the kit as I buy it? Do I just pay use tax when I register it instead? Am I liable for property tax / use tax every year on the thing? Santa Clara county is going to be fun too.. apparently they have a tax that was created in the 1800's to tax farmers allowing their animals to graze on county land. They have managed to apply this tax to aircraft owners hangaring their aircraft in the county by calling it a property tax on exclusive use of public lands - even though your rental fee for the hanger goes to the county / airport. Add this to what I have heard is a 1% annual property tax and who knows what else, and maybe I'll just need to look for a hangar / tie down (20 year waiting lists on hangars around here :P) somewhere else! Everything I can find on the tax agencies web site is written in such a way as to be so vague that it actually doesn't say anything useful and is geared toward the purchase of a built and flying aircraft. I can't imagine that it is really that complicated to state what the taxes due are. I would think an individual buying a kit out of state, building it, then registering it should be a very simple case on the state level. Man I hate tax law. It doesn't have to be this complicated! ;) Thanks, James ________________________________________________________________________________
Date: Apr 16, 2005
Subject: [Please Read] Matronics Email Server Upgrade...
Dear Listers, I will be upgrading the Matronics Email Server this weekend. This includes some hardware improvements - more memory, faster, more capable processors - as well as a complete operating system upgrade from scratch. I hope to have both the old system and the new system running at the same time to minimize the actual impact of the upgrade. Hopefully there will be little actual downtime during the transition, but a few posts may get lost in the shuffle. If you don't see your post show up on the List in the normal amount of time (plus a little bit), then please just try posting it again. Upgrading the Matronics Email Server operating system (from Redhat Linux 7.2 to Redhat Linux WS 4) is a sizeable undertaking and requires a great deal of work to port all of the utilities, programs, and scripts over to the new system. As I've already mentioned, both the old and new systems will be on line at the same time, so interruption should be held to an absolute minimal. You might see a couple of odd test messages during the cut-over or other odd messages; please just ignore them. I have setup a new System Status Web Page that I will use to update List Members on the current status of the email and web systems. Please refer to it as often as you like: http://www.matronics.com/SystemStatus/ Thank you for your continued support of the List Services at Matronics! Its your yearly Contributions that make these major upgrades possible! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: VM1000 Fuel flow transducer mounting
Date: Apr 16, 2005
Can anyone help with where they mounted their VM1000 Fuel Flow transducer? We are building an RV-6, with a Lycoming O-360-AIA engine. The instructions say to mount level, between the engine driven fuel pump and the carb, and allow at least 5" minimum straight length between. How does one do that? ________________________________________________________________________________
Date: Apr 16, 2005
Subject: Re: VM1000 Fuel flow transducer mounting
I mounted mine just downstream of the gasolator (RV8) . . . I would think flow would need to be down stream of the engine driven pump? I'm using ACS and EI furnished the flow sensor? Good Luck, Bob RV-8 - N678RC On 4/16/05, dwhite17(at)columbus.rr.com wrote: > > Can anyone help with where they mounted their VM1000 Fuel Flow transducer? We are building an RV-6, with a Lycoming O-360-AIA engine. The instructions say to mount level, between the engine driven fuel pump and the carb, and allow at least 5" minimum straight length between. How does one do that? > > > ________________________________________________________________________________
Date: Apr 16, 2005
On my flying rv6 the transducer is mounted on firewall with flex hose from pump -> transducer -> carb. Works fine. As long as you have straight in & out fittings on the transducer and no sharp bends in the hose that would create turbulence I think you are ok. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of dwhite17(at)columbus.rr.com Subject: RV-List: VM1000 Fuel flow transducer mounting Can anyone help with where they mounted their VM1000 Fuel Flow transducer? We are building an RV-6, with a Lycoming O-360-AIA engine. The instructions say to mount level, between the engine driven fuel pump and the carb, and allow at least 5" minimum straight length between. How does one do that? ________________________________________________________________________________
Date: Apr 16, 2005
Subject: Re: Rising EGT with one fouled plug
With only one plug firing, the flame front has to travel more than twice as far to burn the fuel air charge. This means some of the combustion energy is liberated at a lower availability to be converted into useful work on the piston. Energy not extracted by the piston remains in the exhaust. Ideally, all of the combustion should be complete very shortly after top dead center. A shorted plug defeats that and combustion after TDC raises EGT. Pure thermodynamics! Paul S. Petersen, RV6A with son Eric, 90% finished ________________________________________________________________________________
Date: Apr 16, 2005
Bob, To maintain the installation requirements as called out by VM, specifically the correct transducer orientation and at least 5" of unbended line into the transducer from the fuel pump, I fabricated a type of shelf out of .040 right angle stock onto which the transducer is bolted and the assembly attached to the left firewall area with nutplates. I had to make up custom fuel hoses as the lengths are not exactly the cookie cutter variety included in Van's firewall forward kits. I just uploaded a close up detail shot of the installation and it can be accessed in my photo gallery section at http://www.rvaero.com/ The engine is an O-320-D1A. Rick Galati RV-6A "Darla" ________________________________________________________________________________
Date: Apr 16, 2005
rv-list
Subject: IO-360 oilcooler
Hi gang I am about to order a bunch of FWF parts from Van's, amongst them an oil cooler. Van's has 2 oilcoolers the Steward Warner and the Positech for the IO-360. any pro/cons/indifferences to either?? I searched the archives but it seems the results are ambigiuos, any results for the updated Positech?? Thanks Gert -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Apr 16, 2005
In a message dated 4/16/2005 11:44:23 A.M. Pacific Daylight Time, HCRV6(at)aol.com writes: Yeah, there is a little bit of fish tailing in moderate turbulence, but so what? I don't have any significant amount of time in a "V" tail Bonanza but I've always heard they do the same thing. ===================================== The Bonanza wags way more IMO than the infinitesimal tail wag of the RV-6A. When I first got in one of those V-tailed monsters (one with the throw over yoke), I thought we were wandering all over the sky. Not pleasant. The RV is wonderful as is with the small booty. GV (RV-6A N1GV O-360-A1A, C/S, Flying 738hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Apr 16, 2005
Subject: Re: confused about taxes
In a message dated 4/16/2005 11:45:21 A.M. Pacific Daylight Time, jochs(at)froody.org writes: I am getting ready to order the -10 kit and trying to make heads or tails of the California / Santa Clara County tax laws around aircraft, and specifically homebuilts ;) Does anyone have any resources that they can refer me to to get a plain English explanation of the rules? ========================================= CA state board of equalization has a pamphlet you can probably request on their website. i.e. since I'll be buying from a seller in Oregon, for California, do I pay the sales tax for each component of the kit as I buy it? Do I just pay use tax when I register it instead? ========================================= Use tax when you register it. Am I liable for property tax / use tax every year on the thing? ========================================= You will pay property tax in the county you hangar it. GV (RV-6A N1GV O-360-A1A, C/S, Flying 738hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Apr 16, 2005
A small chunk of additional information. I was following a friend's RV6A in my VariEze one day and noticed his tail wagging. I asked him on the radio if he was doing that for my benefit and his answer was that it was a characteristic of the RV6 and that it is somewhat speed dependent. The small chunk is that it is plainly visible from another aircraft, so the wag at the tail must be at least a few inches. Garth Shearing VariEze and 90% RV6A Victoria BC Canada ________________________________________________________________________________
Date: Apr 17, 2005
Thanks to all who answered my question! A follow-up...one lister suggested blind rivets, and another suggested substituting bolts for the rivets. Has anyone else used them? Any suggestions on rivet and/or bolt diameters? John (RV-6) __________________________________ http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Apr 17, 2005
Aerosport, Burt and his staff are truly top shelf. They built up my XP 360 and did an excellent job in all regards. As to Tax issues: Because Aerosport is in Canada, your engine will have to clear US Customs on it's return across the boarder. Customs has an agreement with and notifies all states if shipments across the border bound to individual states. Customs and its agreement is the problem not Aerosport. If your state picks up on the fact that it may be a new engine, then you may be charged sales tax by your state if you have not already paid them. If you can prove previous ownership and or payment of sales tax there is no problem. I know I had to pay around $1,400 sales tax on my engine. If I had it to do over again I would have paid the sales tax on the engine when it was in pieces from Superior rather than after completion. Like me you may not like it, but if you read the Tax Code for your state they are really entitled to the tax. Steve Glasgow ________________________________________________________________________________
Subject: Re: Tips for riveting LE ribs #13 and 14 to wing spar? (GMC)
Date: Apr 17, 2005
// LE ribs and 470-4 When I've gotten into this pattern of being unable to make a decent rivet with 4's -- and I have -- I've always found the solution is to slow down...turn it down... Relax. I think driving rivets is like golf; it messes with your head and pretty soon you start anticipating a bad shot and...voila...you get a bad shot. It's as much confidence as it is technique and the goal right now is to set a good rivet and get some confidence back. If you're getting smileys, turn the gun pressure down so things are not bouncing around. Keep the bar and the gun on the work and use a couple of small "atta tats" to set your rivet, rather than just plowing ahead. Get yourself back in the mindeset of not moving stuff off the work. Once you let go of the trigger, count "one thouand one, one thousand two" and THEN remove your bucking bar and gun off the work. That'll help you get your timing back. For those leading edge rivets near the wing ribs...grind down an offset set so you can keep your gun straight. Now, using the offset set is a pain in the neck because it wants to flop around. You can try putting a little duct tape to keep it from doing so, but not much. On these rivets, it's not a terrible idea to get someone to work the gun, while you work the bucking bar. These rivets are difficult solo (by the way, you might want to consider pop rivets for these particular rivets. On the wing spar, with 4's, I can tell you (and you're under no obligation to accept this): live with the rivet you drive. I've rarely seen -- from personal experience -- where drilling out a rivet didn't cause a bigger problem. ________________________________________________________________________________
Subject: Mounting Fuel Flow Transducer
Date: Apr 17, 2005
For those looking at how to mount the flow transducer (mine is the std Flowscan 201) I recently had discussed with EI who along with JPI have instructions for mounting the transducer on the web. In fact, Gary (I believe was his name) from EI called me to respond to my direct Email to EI. I'm using a FI system and he said to mount the transducer in the line from the Servo to the Distribution Spider on the top of the engine. Just mount it in the line, support the line no more than 8" away, wrap the device as shown in their instructions with FireSleeve (-24 size) and it should be good to go. So that is what I'm about to do. One can also mount this in the line from the pump to the carb the same way without having to mount the transducer on the Firewall. The EI representative said there doesn't have to be much in the way of a straight length before or after the transducer to get accurate readings. There was a discussion on the Lycoming groups list about this in February with Don at AFP contributing who also basically stated the above. YMMV Marty in Brentwood TN ________________________________________________________________________________
Date: Apr 17, 2005
I have talked to Aerosport and they are great people with a great reputation. I only want to make you aware of a couple of potential issues. This comes after my very negative experience with Crossflow Aero out of Canada. So bad in fact that a law suit will be filed next week after their failure to accept a very generous settlement offer. 1) I got nailed for $1500 in Customs fees many months after the initial delivery. 2) Also got nailed for $1300 in sales tax from the State of Arizona. Again nothing against Aerosport but there are plenty of US companies that have excellent engines. My choice is now ECI. All certified parts but at very competitive prices. They have been great to work with and you avoid all other potential issues. Just my thoughts. Darwin N. Barrie Chandler AZ ________________________________________________________________________________
Date: Apr 17, 2005
Subject: Re: Should I or shouldn't I- vortex generators
Hi Jerry and the RV-List gang, I sell VGs at a very affordable price ($95). Plus I offer a 100% money back guarantee. Why don't you give them a try and see for yourself? Most of my RV customers are noticing a 4-6 mph reduction in stall and better low speed handling. You can find more information on my website at www.landshorter.com or by giving me a call at 877-272-1414. Thanks. Joa www.landshorter.com Jerry Grimmonpre wrote: John ... Would you mind telling ALL about your installed vortex generators. What improved, what changed, where you got them, what spacing, yada, yada. Thanx ... Jerry Grimmonpre Huntley, IL RV7A --------------------------------- ________________________________________________________________________________
Date: Apr 17, 2005
Subject: Re: confused about taxes (APPLIES TO MANY STATES)
>i.e. since I'll be buying from a seller in Oregon, for California, do I pay >the sales tax for each component of the kit as I buy it? Do I just pay use >tax when I register it instead? Am I liable for property tax / use tax >every year on the thing? WARNING LUXERY TAX OR PERSONAL PEOPERTY TAX APPLIES TO *MANY* STATES, INCLUDING RV AIRPLANES, EVEN IF YOU BUILT IT! MOST IMPORTANT, when you finish your airplane the state you live in may have their hand out and want you to pay several thousand in TAXES. This is like buying anything, new car or TV, you will have to pay sales tax on it. KNOW YOUR STATES LOCAL TAX LAWS ON PERSONAL PEOPERTY / AIRCRAFT. For those building an RV and who have never have owned a plane in the state they live, may be in for a BIG UNPLEASENT SURPRISE. Some states have personal property or Luxury tax, which applies to boats & planes. Basically it is a ONE TIME SALES tax on the value or cost of the vehicle. Since cars and boats are often registered by the state it is easy for them to tax you. Airplanes being federally registered make it harder for them to collect, but they have ways of tracking you down and making you pay. Like all current "mail order" sales, the seller does not have to charge sales tax for out of state orders (yet). Van's (mail order) Aircraft does not collect state sales tax for other states. You may be liable down the road but not at the kit level (but check your local laws). When the kits become a vehicle they (state revenue dept) may have their hand out. (Varies state to state). BTW, Oregon is one of 5 states without sales tax. As far as paying tax on a kit I son't know how the state would even know. I would not volunteer to pay taxes on individual kits as you go. I would wait until you have finished building and registered the aircraft. However any taxes you pay along the way (avionics, parts, prop, engine) can be deduct from the final tax. So keep good records. How they (state tax-man) values an airplane you built from a kit is a whole other story and gets a little complicated. SAVE ALL RECIEPTS AND ANY SALES TAX YOU PAY ALONG THE WAY. It may be in your best interest to keep good cost records. Q: You might say, "I did not buy the plane I made it, so why do they want sales tax?" A: Well they do. Even if you can mail order parts and kits from out of state, free of tax, when you put it together and make a boat, plane or car out of those parts, the local tax-man may want a piece of the action. (check state laws) What if you build it and hide it in a hanger and never pay the tax? You can do that and you might get a way with it. If you fly of a private airstrip you might avoid detection? I am not saying you should avoid taxes, just that some states are not as tight on tracking down aircraft owners. How do they catch plane owners who don't pay? Well first they drive around airports and take N numbers down on the ramp or runway. They check the aircraft's registered address and owners address (from auto or pilots license records). Some states issue yearly stickers and they look for those. You might say you can register it out of state. You might as well as change your pilots license out of state too. You can try that, but they have ways of catching you. A famous case in WA State caught a Billionaire trying to avoid tax on his fleet of Jets. (This someone had something to do with Microsoft, not Bill). He had a fake company to hold his corporate jets in Oregon (no sales tax), although he flew them out of Seattle. They figured out what he was doing and he had to pay millions in tax. (He had many jets and a turbine floatplane). Not only where his planes registered in Oregon, they noticed when they went to his house his expensive cars had Oregon plates. So the out-of-state-re gister game may work for a small guy, however if the tax guy keeps seeing your plane at the same airport, for a long period, they will come knocking. What they can do if they catch you, besides collect the tax, I do not know? I recommend you pay your taxes, so you don't have to look over your shoulder all the time. Otherwise move to a state that does not tax airplanes. After the first one time big "sales" tax some states charge a small annual registration fee. In WA State the annual renewal of the sticker, was something like $20-$30. Most of the yearly registration fee went to the state aeronautical coffers for search and rescue, or that is what they said. The state troopers would check for stickers on planes at airports. You are not taxed annually; only the first time you register it. After that is is just the "sticker fee". What do other states like CA charge yearly? I do not know. If they were taxing you yearly I would move. Many states have become savvy with the kit planes. It used to be you could go in and say your plane is worth $8,000 in parts. They will say "Nope, isnt going to fly". They know what stuff cost and want receipts. Otherwise they may go on trade-a-plane or other "blue-book" type index. You have some leeway in valuing it, so use what is to your advantage. In Washington state there is an exemption on the books that the "the manufacture" does not have to pay tax. So Boeing does not have to pay tax on a B747 they build, the buyer does. (However the buyers fly to Canada and to "get the keys", avoiding sales tax.) You might say, "Hey, I am the manufacture," so I can write off the tax. You would be right in that you made it, but the revenue service in WA State says it does not apply to you, an amateur builder (manufacturer). It has been tried. Don't ask me how I know ;-) . The future is internet "mail order" sales is in question. Some states that would like to tax you on ALL "mail order" out of states purchase, regardless of what it is. That has not happened yet to my knowledge, but they are trying. Make sure your state is not trying this. Write your state Gov or vote accordingly. Fact is, regardless of sales tax, states with personal property tax on items like boats and planes will eventually want their money, whether you built it or bought it. I think awareness and working the tax laws in your favor, with in the law, is a wise thing to do. As far as a business expense? Good luck. Cheers George --------------------------------- ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Wonky Altimeter
Date: Apr 17, 2005
I flew home from SnF this morning, and as I was entering the pattern at my home field, my eyeballs told me that I was lower than the altimeter was reading. Sure enough, I tapped on the instrument's glass face, and it more or less corrected itself. When I landed, the altimeter was off again (reading high again), so I rapped on the face, and it corrected to field level. Other than making sure there isn't a problem in the static system, is there anything else I can do other than pulling out the altimeter and sending it to a repair shop? Anyone got a recommendation for an altimeter repair shop in the Atlanta area? Thanks in advance, Kyle Boatright ________________________________________________________________________________
Date: Apr 17, 2005
For those who have owned many planes, this may be old news, but some builders may be first time aircraft owners and not aware of the tax liability. I wanted to add to my previous post this reference: http://www.sbw.org/tax/ I did not want to appear cavalier about taxation on your RV. What ever it is called: Luxury Tax, Use Tax, Personal Property Tax or Excise Tax, it is tax. I checked my state and a few others. All I can say is there are many variations. I am RV-less for now and way done on my RV-7 and have a 100% to go; You know what I mean. I am new to this state, and never owned an aircraft in this state before. Goggle: personal property tax+aircraft+(state) Try other names like: excise tax, use tax, luxury tax. BTW, Oregon which did not have tax on aircraft, is now considering Luxury tax on aircraft. Also failure to pay, if caught can be stiff and result in seizure of property. Again not to scare anyone, just wanted those new to aircraft ownership to know about aircraft taxation. I came across it by accident myself after buying my first aircraft. As far as exemption, historic and Airline (common carriage) get tax breaks. If you try the "I am the manufacture" and thus tax exempt, good luck, hope it works. The good news RVs are popular and have high resale. Unfortunately the bad news is due to their popularity and high resale value, tax will be much higher than other kit planes. Since many states will go on fair market value, regardless of what you have into it. $30,000 RVs of 15 years ago are now $80,000. At 1%-2.5% tax rate yearly, that can add up. Cheers George --------------------------------- ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: RV-7 N3XG Flys High
Date: Apr 17, 2005
Pie ChartsToday another new RV-7 left the earthly bound of gravity for the first time. SunSeeker was flown first by RV-8 latch man Mike Zeller. Mike looked with a careful eye when I told him I thought it was ready for flight and asked him if he would do the honors. So the RV-8 Latch man checked about everything again that Kentucky-based DAR Pat Patterson had checked weeks ago when he awarded the plane its airworthiness certificate. Mike took the active runway and announced he was beginning a high speed taxi test. After 150 feet or so, and everything feeling real straight and solid, he said the plane just wanted to fly. With tail up it left the earth for the first time for a trip that would not end for1 hour. Mike flew the flight for the most part by feel and keeping his eyes outside the plane. He had lots of info available inside however to tell how things were going on the perfectly clear, low wind day that had the breeze mostly right down the runway. Occasionally he checked a Dynon flight indicator and an Advanced Flight Systems ACS2002 engine monitor and heard no annuciating warning messages from the monitor and Garmin 340 intercom.. These insturments confirmed what he felt about the flight that the Mattituck TMX-O360 engine running on one impulse slick mag and one Jeff Rose EI connected to a FP Sensenich prop were performing as expected. Mike maintained a near constant circling climb around the airport so he could see over the top cowling comfortably and did watch the CHT for a new engine break in. He leveled off at 10,500 and noted that pressures and temps were ok. The left wing was a bit heavy but it flies straight otherwise. The Garmin 430 GPS reported speeds in the 170 kts without wheelpants and landing gear leg fairings in level flight. There are lots of people to thank in the completion of the plane. I hope I don't forget anyone there are so many. Thanks to the local EAA21 club and the many members who have helped with this slow build project that took just at 4 years. Special thanks go to my wife Karen, noted EAA21 members John Crabtree, Vince Frazier, Earl Schroeder, Keith Schlagater, Steve Eberhart, Bill Majors, Jim Hall, Don Taylor, and everyone else that know they helped and I am too short on words to properly acknowledge. One such person is Bill Brooks who helped just about every Friday for the last three years. Without his help, I would still be bucking rivets. Also I got encouragement and ideas from Dan Overall although he could not convert me away from the TMX-O360 engine. And also David Lowe for being my tailwheel CFI. David operates out of his private strip in Sacramento, Kentucky. And John Crabtree will provide me transition training in his RV6 as I step up to this hot rod from the Cessna 140. I am looking forward to commanding SunSeeker in the near future. This feeling is about a good as it gets without it being illegal or immoral. I can not imagine how it can be much better behind the stick, but I am sure it will be. So,,,,,for all you guys who are headed in the same direction, my advice just take it one day at a time. Keep in good with your family and never forget that I listed my wife first as one of my greatest helpers although she bucked only a few rivets just to see what it was like. For the knowledge of it all is why I did it -- not the thrill. What a project!! Friends are like angels who lift us to our feet when our wings have trouble remembering how to fly....unknown Indiana Larry, RV7 Tip Up, SunSeeker ________________________________________________________________________________
Date: Apr 17, 2005
Subject: Re:Landshorter Vortex generators
At 12:10 PM 4/17/2005, you wrote: > >Hi Jerry and the RV-List gang, > >I sell VGs at a very affordable price ($95). Plus I offer a 100% money >back guarantee. Why don't you give them a try and see for yourself? > >Most of my RV customers are noticing a 4-6 mph reduction in stall and >better low speed handling. > >You can find more information on my website at www.landshorter.com or by >giving me a call at 877-272-1414. > >Thanks. > >Joa Joa, Your web site has no remarks or testimonials on the use of VG's on the RV series of aircraft. I see no reason why they wouldn't improve the slow speed handling of the RV wing, BUT why don't you supply one of us (not me) with a set of VG's and instructions. You might find that you won't be able to keep up with production. The only resistance you will find is that they can't be removed without removing the paint. If you overcome this problem, everyone will be a potential customer. I would gladly try them out. If I was unhappy with them, I wouldn't ask for my money back. I'd just remove them. ________________________________________________________________________________
Date: Apr 17, 2005
Subject: Re: Wonky Altimeter
Kyle; Any chance of water accumulating at a low point in the static system? This could be rain in flight but more likely rain dripping down the side and entering the static ports when parked or perhaps a wash job with a pressure hose. Climbing and descending with a blob of water in the lines will cause some interesting surges in pressure with resulting jumps in altimeter readings. (Avoiding water entry is a good reason to run the line joining the two ports to a tee-fitting at the top of the fuselage, like Vans plans show. Guess who didn't and who found out the 'interesting' way on an RV-3.) OTOH, simply tapping the instrument is not likely to correct a water blockage, so it way well be off to the instrument shop with your sticky altimeter. A quick puff of air in the main static line from an air gun or similar might be worth a try - watch for any water emerging from the static ports - and won't cost much. Needless to say, make sure that all your other instruments using static pressure are disconnected first or a blast from an air hose could be quite costly ! Jim Oke RV-3, RV-6A Wpg., MB ----- Original Message ----- From: "Kyle Boatright" <kboatright1(at)comcast.net> Subject: RV-List: Wonky Altimeter > > I flew home from SnF this morning, and as I was entering the pattern at my > home field, my eyeballs told me that I was lower than the altimeter was > reading. Sure enough, I tapped on the instrument's glass face, and it > more or less corrected itself. When I landed, the altimeter was off again > (reading high again), so I rapped on the face, and it corrected to field > level. > > Other than making sure there isn't a problem in the static system, is > there anything else I can do other than pulling out the altimeter and > sending it to a repair shop? > > Anyone got a recommendation for an altimeter repair shop in the Atlanta > area? > > Thanks in advance, > > Kyle Boatright > > > ________________________________________________________________________________
Subject: RV6 chin scoop and Superior engine
Date: Apr 18, 2005
Hi guys , I originally ordered the 0320 size chin scoop for my RV6 (5 years ago ) but then have subsequently put an O360 engine in. It is a Superior 0360 engine with a carby (Precision Airmotive M-4-5). As you can imagine the O320 scoop doesn't fit. A reply from Vans states that they have not seen a Superior engine but believe if the dimensions are indeed the same as the Lycoming - that their O360 chin scoop should fit it OK. Anybody out there with the same problem or any advice? Thank you Shirley Harding RV6 QB Perth, Australia ________________________________________________________________________________
Date: Apr 17, 2005
Hi Louis, I need to update my testimonials, just need to find the time first :) Most folks are putting the VGs on with double-stick tape to try them out. If you're careful when taking them off (and follow my directions included with the VGs) you usually won't have any problems with any of the paint coming off. Joa www.landshorter.com +++++++++++++ The only resistance you will find is that they can't be removed without removing the paint. If you overcome this problem, everyone will be a potential customer. I would gladly try them out. If I was unhappy with them, I wouldn't ask for my money back. I'd just remove them. --------------------------------- ________________________________________________________________________________
Date: Apr 17, 2005
Subject: [Please Read] Matronics Email Server Upgrade Complete!
Dear Listers, The upgrade of the Matronics Email Server can be considered complete at this time. All known issues related to the upgrade process have been resolved and email services are running normal. The Nightly Digest processing has not yet been tested and will wait for tonight's update. If you encounter any odd behavior with respect to the Matronics Email Server over the next few days, please contact me via email at dralle(at)matronics.com or if that fails try dralle(at)speakeasy.net. Thanks to everyone for being patient through this arduous process of a major system upgrade! Matt Dralle Email List Administrator At 12:37 PM 4/16/2005 Saturday, Matt Dralle wrote: >Dear Listers, > >I will be upgrading the Matronics Email Server this weekend. This >includes some hardware improvements - more memory, faster, more capable >processors - as well as a complete operating system upgrade from >scratch. I hope to have both the old system and the new system running at >the same time to minimize the actual impact of the upgrade. > >Hopefully there will be little actual downtime during the transition, but >a few posts may get lost in the shuffle. If you don't see your post show >up on the List in the normal amount of time (plus a little bit), then >please just try posting it again. > >Upgrading the Matronics Email Server operating system (from Redhat Linux >7.2 to Redhat Linux WS 4) is a sizeable undertaking and requires a great >deal of work to port all of the utilities, programs, and scripts over to >the new system. As I've already mentioned, both the old and new systems >will be on line at the same time, so interruption should be held to an >absolute minimal. You might see a couple of odd test messages during the >cut-over or other odd messages; please just ignore them. > >I have setup a new System Status Web Page that I will use to update List >Members on the current status of the email and web systems. Please refer >to it as often as you like: > > http://www.matronics.com/SystemStatus/ > > >Thank you for your continued support of the List Services at >Matronics! Its your yearly Contributions that make these major upgrades >possible! > >Best regards, > >Matt Dralle >Matronics Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 18, 2005
I can offer only anecdotal data for one Positech oil cooler. I purchased the Positech cooler recommended by Van's for use with a 180 HP engine. It cools and doesn't leak - at least not yet in almost 5 years of flying. I have read numerous posts in the past about "older" Positech coolers not providing sufficient cooling. In my -4, and most -4's I believe, running too cool is more likely to be an issue than not cool enough. ----Original Message Follows---- From: gert <gert.v(at)sbcglobal.net> Subject: RV-List: IO-360 oilcooler Date: Sat, 16 Apr 2005 21:22:24 -0500 Hi gang I am about to order a bunch of FWF parts from Van's, amongst them an oil cooler. Van's has 2 oilcoolers the Steward Warner and the Positech for the IO-360. any pro/cons/indifferences to either?? I searched the archives but it seems the results are ambigiuos, any results for the updated Positech?? Thanks Gert -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Apr 18, 2005
Subject: Re: Flight Planning
_www.fltplan.com_ (http://www.fltplan.com) is the one I use for fun and corporate. Free and lots of info. Regards, Doug Preston RV7 N731RV C501 N577JT ________________________________________________________________________________
Date: Apr 18, 2005
As far as I know there is no Customs Fee. Steve Glasgow ________________________________________________________________________________
Date: Apr 18, 2005
I'm with David, I purchased the Vans static kit and installed it. By heating the 1/4" plastic tubing in boiling water, with effort, I was able to get the plastic tubing on the Tee fitting. Four days later, that cheap (import stuff, NOT real Imperial Eastman Nyloflow) tubing split. I ripped it all out. I replaced it with genuine Nyloflow tubing and fittings similar to what David describes. I purchased the tubing and fittings from ACS. I've also gotten the "you are the only one who has ever complained" routine from Vans. Each time, it was in reference to a problem which was widely reported on the RV List. I've found that Van's Dutch genes occasionally do us a dis-service. The static kit and capacitance fuel sender kit are two examples of this. I'm not a disgruntled customer. On the whole, the RV kits are still the best "bang for the buck", in my opinion. You just have to side step the occasional "pot hole" in the road. :-) Charlie Kuss > >This Van's "method" has to be the most ignorant thing about the entire kit - >totally unacceptable to do it their way. I went to a local "fittings" shop >(brass & plastic) and bought standard, cheap Ts with the screw on caps that >you just stick the tubing into and then tighten the caps. Totally >professional, totally secure, totally better than forcing the one size >tubing onto the smaller (but not small enough) tubing and then having the >ends split by a week later. They claim "they never heard of that one >before". Yeah, sure, I'm the ONLY ONE who had the tubing split. > >David > >----- Original Message ----- >From: "Jack" <jgh2(at)charter.net> >To: >Subject: RV-List: Static System Connections > > > > > > Is there an easy way to insert the recommended 3/16" plastic tube > > fittings into the 1/4" OD plastic static lines. Hot water helps but > > its still very difficult to get the tubing on all the way. > > > > Jack H. > > 6A - finishing kit > > > > > > ________________________________________________________________________________
Date: Apr 18, 2005
HI-PUT THEM ON TO TRY WITH DOUBLE SIDED TAPE-IT COMES OFF-TOM Tom Whelan Whelan Farms Airport President EAA Chapter 1097 wfact01(at)aol.com 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 Tel: 203-266-5300 Fax: 202-266-5140 EAA Technical/Flight Advisor RV-8 540 LYC (40 PLUS HOURS) S-51 Mustang Turbine (Under Construction) ________________________________________________________________________________
Date: Apr 18, 2005
Tim, I have bought two engines from Bart and paid no customs fees, just shipping to Florida. Pat Hatch RV-6 RV-7 Thanks everyone, so far, for the replies to my question about engines from AeroSport. It does sound like they have a good reputation. I am a bit confused though, especially after Darwin's post here. As far as taxes, I'm not worried about that. I know that either way I'll be paying the use tax on the plane when I go to register it, so the State of Wisconsin will get their tax one way or the other. I see that some said shipping was less to have it shipped from Aerosport than similar packages shipped from closer and within the US. I'll have to check this out. I see that some said they had small "brokerage fees". No big deal, since it sounds like they were small. The big confusion though is this $1500 "Customs Fee" that Darwin mentions....what's that all about? Was that actually a fee for going through customs? I didn't think there were any fees other than shipping and brokerage (other than tax). So now I'm happy that the engines would be pretty good, but these additional fees are still making me apprehensive. I've got a US supplier that can supply the same engine with ECI Titan cylinders, for probably $2000 less money. The 2 catches are that A) The original cores come from Africa and from turbocharged planes (ss-s-s-scary), and B) They talk of roller lifters like they are something voodoo. I thought that roller lifters were not only a good idea, but something that was now a good and recent product that could help my engine's longevity. Thanks again guys, I'm getting closer. Tim - RV-10 #170 ________________________________________________________________________________
Date: Apr 18, 2005
Subject: EAA Airventure Cup Race
For ANYONE who might be interested in racing in the EAA Airventure Cup Race this year... Please come race with us! We would love to have more planes in the field. If we get a good turnout then mabye EAA will notice, and will work to keep it going. The past two years I've done this race have resulted in some of the most fun experiences I've had flying. It's truly a good time! Come race! Join the fun! This is a really safe form of racing. Just like a fast cross-country flight with a lot of other planes. The planes are spaced on start and passing is at a minimum. Basically a race against the clock. Did I say it was fun? Best way I've found to get to OSH! Check out: http://www.airventure.org/2005/news/050225_avcup.html Following is a copy of correspondance between myself and the Race Director... -----Original Message----- From: SCOTT SPENCER [mailto:aerokinetic(at)sbcglobal.net] Subject: AvCup '05 Hi Eric! Don't know if you're still the man in charge of the race or not... but it had occurred to me that I hadn't recieved any email correspondance regarding the race this year... -then I thought 'Oh well, yeah, I have a new email address now... I guess that figures' (Doh!) So my email did change, but I'm planning on racing... and I may drag a few friends along for their first race too. My registration package will be headed to EAA in the near future. Hope all's well w/ you Scott Spencer Race 74 RV-4-150 Hi Scott, Yes I have been roped into doing the race again. Actually you have not missed any e-mails since the race is sort of a mess at this point. It was canceled and now it is back on. But we got such a late start from the indecision that went on that we have been scrambling to get caught up. Glad you are going to be back. Bring as many as you can get signed up. It should be about the same deal as last year. The USAF Museum is still up in the air, we are working on that but there are some complications due to the late timing. I will keep you posted. Other than that it should be about the same set up as in the past. I think we have a new Hotel this year. (The Holiday Inn is booked) The course will again be MGY SQI RFD FLD. The finish line will be at that little private strip where it was last year. The tower liked the mass arrival so that looks like the plan for this year as well. Talk to you later.. Eric ________________________________________________________________________________
Date: Apr 18, 2005
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net>
Subject: Re: IO-360 oilcooler
Dean Pichon wrote: > >I can offer only anecdotal data for one Positech oil cooler. I purchased >the Positech cooler recommended by Van's for use with a 180 HP engine. It >cools and doesn't leak - at least not yet in almost 5 years of flying. I >have read numerous posts in the past about "older" Positech coolers not >providing sufficient cooling. In my -4, and most -4's I believe, running >too cool is more likely to be an issue than not cool enough. > > > > I too, find my engine runs on the cool side. Yesterday on the way back from Sun and Fun. I was less than 180 deg. all the way home. On the ground taxiing in to the hangar, it rose to near 200. Ground temp was in the low 80's. I am using a Stewart Warner about the same size as the positech. I also have the new Positech that was exchanged for an earlier one. It is up in the cabinets. Workmanship on it looks as good or better than the SW...... I would not be too concerned about using the newer exchanged unit... Phil ________________________________________________________________________________
Date: Apr 18, 2005
He must have quit charging the brokerage fee. It wasn't much, maybe $100 or so. It was to pay the people who do that tariff paperwork, clearing customs, etc. FWIW, Arizona didn't ask me to pay tax on the engine. They never knew I bought it. Paul Besing RV-6A Sold Kitlog Builder's Software www.kitlog.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Pat Hatch Subject: RE: RV-List: Aerosport Engines and Shipping/Tax issues Tim, I have bought two engines from Bart and paid no customs fees, just shipping to Florida. Pat Hatch RV-6 RV-7 Thanks everyone, so far, for the replies to my question about engines from AeroSport. It does sound like they have a good reputation. I am a bit confused though, especially after Darwin's post here. As far as taxes, I'm not worried about that. I know that either way I'll be paying the use tax on the plane when I go to register it, so the State of Wisconsin will get their tax one way or the other. I see that some said shipping was less to have it shipped from Aerosport than similar packages shipped from closer and within the US. I'll have to check this out. I see that some said they had small "brokerage fees". No big deal, since it sounds like they were small. The big confusion though is this $1500 "Customs Fee" that Darwin mentions....what's that all about? Was that actually a fee for going through customs? I didn't think there were any fees other than shipping and brokerage (other than tax). So now I'm happy that the engines would be pretty good, but these additional fees are still making me apprehensive. I've got a US supplier that can supply the same engine with ECI Titan cylinders, for probably $2000 less money. The 2 catches are that A) The original cores come from Africa and from turbocharged planes (ss-s-s-scary), and B) They talk of roller lifters like they are something voodoo. I thought that roller lifters were not only a good idea, but something that was now a good and recent product that could help my engine's longevity. Thanks again guys, I'm getting closer. Tim - RV-10 #170 ________________________________________________________________________________
Date: Apr 18, 2005
Just wait until you register the airplane..... Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Paul Besing Subject: RE: RV-List: Aerosport Engines and Shipping/Tax issues He must have quit charging the brokerage fee. It wasn't much, maybe $100 or so. It was to pay the people who do that tariff paperwork, clearing customs, etc. FWIW, Arizona didn't ask me to pay tax on the engine. They never knew I bought it. Paul Besing RV-6A Sold Kitlog Builder's Software www.kitlog.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Pat Hatch Subject: RE: RV-List: Aerosport Engines and Shipping/Tax issues Tim, I have bought two engines from Bart and paid no customs fees, just shipping to Florida. Pat Hatch RV-6 RV-7 Thanks everyone, so far, for the replies to my question about engines from AeroSport. It does sound like they have a good reputation. I am a bit confused though, especially after Darwin's post here. As far as taxes, I'm not worried about that. I know that either way I'll be paying the use tax on the plane when I go to register it, so the State of Wisconsin will get their tax one way or the other. I see that some said shipping was less to have it shipped from Aerosport than similar packages shipped from closer and within the US. I'll have to check this out. I see that some said they had small "brokerage fees". No big deal, since it sounds like they were small. The big confusion though is this $1500 "Customs Fee" that Darwin mentions....what's that all about? Was that actually a fee for going through customs? I didn't think there were any fees other than shipping and brokerage (other than tax). So now I'm happy that the engines would be pretty good, but these additional fees are still making me apprehensive. I've got a US supplier that can supply the same engine with ECI Titan cylinders, for probably $2000 less money. The 2 catches are that A) The original cores come from Africa and from turbocharged planes (ss-s-s-scary), and B) They talk of roller lifters like they are something voodoo. I thought that roller lifters were not only a good idea, but something that was now a good and recent product that could help my engine's longevity. Thanks again guys, I'm getting closer. Tim - RV-10 #170 ________________________________________________________________________________
Subject: PARKER FAST&TITE tube connectors
Date: Apr 18, 2005
Builders, Anyone using, and have good 2 to 5 quantity cost source for PARKER FAST&TITE connectors for use with poly tubing and instruments. Parker brand comes with the AOA, looks good, simple, uses O-ring. Comments? Jack -8 wiring and plumbing ________________________________________________________________________________
Subject: Re: EAA Airventure Cup Race
Date: Apr 18, 2005
I'd love to enter that race but those insurance requirements look very stiff. The $1,000,000 liability coverage is fine but the requirement for specific air race coverage and the required clause for including race sponsors, EAA, etc on the coverage is not going to be in ANYBODY's policy unless they specifically request it. Have any of you past racers gotten this and if so, how hard & expensive was it? I would have assumed that the insurance company would answer me with a hearty chuckle if I asked. Tracy Crook (Totally pissed that Sun n Fun cancelled Sun 100 race) For ANYONE who might be interested in racing in the EAA Airventure Cup Race this year... Please come race with us! We would love to have more planes in the field. If we get a good turnout then mabye EAA will notice, and will work to keep it going. The past two years I've done this race have resulted in some of the most fun experiences I've had flying. It's truly a good time! Come race! Join the fun! This is a really safe form of racing. Just like a fast cross-country flight with a lot of other planes. The planes are spaced on start and passing is at a minimum. Basically a race against the clock. Did I say it was fun? Best way I've found to get to OSH! Check out: http://www.airventure.org/2005/news/050225_avcup.html> Following is a copy of correspondance between myself and the Race Director... -----Original Message----- From: SCOTT SPENCER [mailto:aerokinetic(at)sbcglobal.net] Subject: AvCup '05 Hi Eric! Don't know if you're still the man in charge of the race or not... but it had occurred to me that I hadn't recieved any email correspondance regarding the race this year... -then I thought 'Oh well, yeah, I have a new email address now... I guess that figures' (Doh!) So my email did change, but I'm planning on racing... and I may drag a few friends along for their first race too. My registration package will be headed to EAA in the near future. Hope all's well w/ you Scott Spencer Race 74 RV-4-150 Hi Scott, Yes I have been roped into doing the race again. Actually you have not missed any e-mails since the race is sort of a mess at this point. It was canceled and now it is back on. But we got such a late start from the indecision that went on that we have been scrambling to get caught up. Glad you are going to be back. Bring as many as you can get signed up. It should be about the same deal as last year. The USAF Museum is still up in the air, we are working on that but there are some complications due to the late timing. I will keep you posted. Other than that it should be about the same set up as in the past. I think we have a new Hotel this year. (The Holiday Inn is booked) The course will again be MGY SQI RFD FLD. The finish line will be at that little private strip where it was last year. The tower liked the mass arrival so that looks like the plan for this year as well. Talk to you later.. Eric ________________________________________________________________________________
From: "Moore, Warren" <Warren.Moore(at)tidelandsoil.com>
Date: Apr 18, 2005
James, I live in Huntington Beach and just finished up my RV-4. My understanding is that the Ca. State "use" tax is subsitute for sales tax....California tried to collect sales tax on out of state purchases and lost in Federal Court so they created the Use tax - a tax only on Californian residents. About the 4th time Califonria has been smacked down in Fed court for "over reaching".....What can you say, welcome to California! As a California resident you are supposed to remit the Use tax anytime you buy something out of state that does not have a sales tax collected. For small stuff almost no one pays it, but on boats and airplanes, etc as soon as you register them the State will be after you. The FAA and California share data bases, so when you are issued a N number, California will know you have an airplane, and they will want to know how and when you got it. Legally you should pay the Use tax as you buy each kit. Go to the their web site; www.boe.ca.gov/sutax/usetaxreturn.htm and it will explain proceedures, forms, and tax rate for your county. The BOE (Board of Equalization) administers the Use Tax, the State Franchise Tax Board will be after you for property taxes. I think you should pay as you go; first that is legally how you should do it, and secondly you will end up paying the tax anyway when you finish your airplane and get your N number. If you wait until the end you could be in for penalties and interest. You are not the first RV builder in the State!! Also if you get your N number now, and the state tries to collect property tax, like they do on all airplanes and boats each year, You can point out that is just a kit in progress, and refer them to your Use tax forms. Good luck........and you wonder why so many Californian's are moving to Nevada and Oregon?? -----Original Message----- From: James Ochs [mailto:jochs(at)froody.org] Subject: RV-List: confused about taxes Hi all, I am getting ready to order the -10 kit and trying to make heads or tails of the California / Santa Clara County tax laws around aircraft, and specifically homebuilts ;) Does anyone have any resources that they can refer me to to get a plain English explanation of the rules? i.e. since I'll be buying from a seller in Oregon, for California, do I pay the sales tax for each component of the kit as I buy it? Do I just pay use tax when I register it instead? Am I liable for property tax / use tax every year on the thing? Santa Clara county is going to be fun too.. apparently they have a tax that was created in the 1800's to tax farmers allowing their animals to graze on county land. They have managed to apply this tax to aircraft owners hangaring their aircraft in the county by calling it a property tax on exclusive use of public lands - even though your rental fee for the hanger goes to the county / airport. Add this to what I have heard is a 1% annual property tax and who knows what else, and maybe I'll just need to look for a hangar / tie down (20 year waiting lists on hangars around here :P) somewhere else! Everything I can find on the tax agencies web site is written in such a way as to be so vague that it actually doesn't say anything useful and is geared toward the purchase of a built and flying aircraft. I can't imagine that it is really that complicated to state what the taxes due are. I would think an individual buying a kit out of state, building it, then registering it should be a very simple case on the state level. Man I hate tax law. It doesn't have to be this complicated! ;) Thanks, James ________________________________________________________________________________
Subject: Re: PARKER FAST&TITE tube connectors
Date: Apr 18, 2005
Here is another company that provides fittings etc. of the type reffered to. That is if your local area supplier does not handle Parker.
http://www.smcusa.com/sections/products/fittings_tubings.asp ----- Original Message ----- From: "Jack Blomgren" <jackanet(at)hotmail.com> Subject: RV-List: PARKER FAST&TITE tube connectors > > Builders, > > Anyone using, and have good 2 to 5 quantity cost source for PARKER > FAST&TITE > connectors for use with poly tubing and instruments. Parker brand comes > with > the AOA, looks good, simple, uses O-ring. > Comments? > > Jack > -8 wiring and plumbing > > > ________________________________________________________________________________
Date: Apr 18, 2005
Amen about the sun 100 !!! Last year, I called my insurance agent, and then faxed them a copy of EAAs requirements (which certainly do sound onorus). It took two tries but they finally issued a statement covering all the conditions to EAAs satisfaction, for no extra charge. It sure would be worth a try. I will be trying it again this year myself. John Huft RV8 "Nuisance" Race 13 Tracy Crook wrote: > >I'd love to enter that race but those insurance requirements look very stiff. The $1,000,000 liability coverage is fine but the requirement for specific air race coverage and the required clause for including race sponsors, EAA, etc on the coverage is not going to be in ANYBODY's policy unless they specifically request it. > >Have any of you past racers gotten this and if so, how hard & expensive was it? I would have assumed that the insurance company would answer me with a hearty chuckle if I asked. > >Tracy Crook (Totally pissed that Sun n Fun cancelled Sun 100 race) > > >For ANYONE who might be interested in racing in the EAA Airventure Cup Race this year... > >Please come race with us! > >We would love to have more planes in the field. If we get a good turnout then mabye EAA will notice, and will work to keep it going. > >The past two years I've done this race have resulted in some of the most fun experiences I've had flying. It's truly a good time! Come race! Join the fun! > >This is a really safe form of racing. Just like a fast cross-country flight with a lot of other planes. The planes are spaced on start and passing is at a minimum. Basically a race against the clock. Did I say it was fun? Best way I've found to get to OSH! > >Check out: http://www.airventure.org/2005/news/050225_avcup.html> > >Following is a copy of correspondance between myself and the Race Director... > >-----Original Message----- >From: SCOTT SPENCER [mailto:aerokinetic(at)sbcglobal.net] >To: ewhyte(at)wi.rr.com >Subject: AvCup '05 > > >Hi Eric! > > >Don't know if you're still the man in charge of the race or not... but it had occurred to me that I hadn't recieved any email correspondance regarding the race this year... -then I thought 'Oh well, yeah, I have a new email address now... I guess that figures' (Doh!) > > >So my email did change, but I'm planning on racing... and I may drag a few friends along for their first race too. My registration package will be headed to EAA in the near future. > > >Hope all's well w/ you > > >Scott Spencer > > >Race 74 > > >RV-4-150 > > >Hi Scott, > > >Yes I have been roped into doing the race again. Actually you have not missed any e-mails since the race is sort of a mess at this point. It was canceled and now it is back on. But we got such a late start from the indecision that went on that we have been scrambling to get caught up. Glad you are going to be back. Bring as many as you can get signed up. It should be about the same deal as last year. The USAF Museum is still up in the air, we are working on that but there are some complications due to the late timing. I will keep you posted. > >Other than that it should be about the same set up as in the past. I think we have a new Hotel this year. (The Holiday Inn is booked) The course will again be MGY SQI RFD FLD. The finish line will be at that little private strip where it was last year. The tower liked the mass arrival so that looks like the plan for this year as well. > > >Talk to you later.. > > >Eric > > > > ________________________________________________________________________________
Date: Apr 18, 2005
Tracy, They have had this insurance requirment in the race rules for a number of years. When I did the race in '03 it was just a call to the insurance broker who had it add at no charge and faxed the letter to EAA. I would recomend that everyone does a race like this at least once, it was a lot of fun. Alan Kritzman RV-8 N8EM Tracy Crook wrote: I'd love to enter that race but those insurance requirements look very stiff. The $1,000,000 liability coverage is fine but the requirement for specific air race coverage and the required clause for including race sponsors, EAA, etc on the coverage is not going to be in ANYBODY's policy unless they specifically request it. Have any of you past racers gotten this and if so, how hard & expensive was it? I would have assumed that the insurance company would answer me with a hearty chuckle if I asked. Tracy Crook (Totally pissed that Sun n Fun cancelled Sun 100 race) --------------------------------- ________________________________________________________________________________
Date: Apr 18, 2005
Just want to know the experience with VG's in general on RV's and some research / options. I have no association with any company but do know a few RV'ers who have experimented with VG's. Landshort:
http://www.landshorter.com/index.html Is unique in that their VG's are triangular wedged shaped clear plastic, clear LEXAN (tm), cost $99. I don't know of any on RV's. They make VG's for experimental aircraft only. Pacific NW Aero http://www.pnwaero.com/ They use 6063 aluminum "T" extrusions, low profile about 1" long, cost is $349. Many are flying on RV's. They offer VG's for several certified single and multi engine aircraft. Micro Aerodynamics http://www.microaero.com/ They use 6063 aluminum extrusion of similar shape, cost is $395. Many are flying on RV's. They have a kit specifically made for the RV. They also have extensive list of kits for certified aircraft. Terry Jantzi http://www.ontariorvators.org/pitot/pitot.htm Sold by Larry Vetterman, I think they are the same aluminum style VG as PacificNW and MicroAero at similar cost. Visit Terry's link above and you can see flight test data. Leave it to RV builders to provide real no BS data. The VG's lowered Stall speed by 3.5-4.5 *MPH and lowered top speed about 3.5 *MPH on a RV-6. (* Numbers originally reported in knots) VG Facts: First VG's do work, all will reduced stall speed, but also expect some top end loss as well. The benefit is in the order of 3-6 MPH, Loss at top end, 0-4 MPH. My opinion is that RV's fly slow enough and I absolutely don't want any loss of top speed, since I spend my time more at cruise than approach, so I am going to pass on the VG's for now. However there are advantages of VG's besides shorter approaches. If you like to Dog-fight you know that you keep turning inside until someone runs out of speed, so the VG equip RV can turn tighter. Also, clean break at stall and better aileron authority at slow speeds has been reported. Like everything, no free lunch. Yes you gain lower stall speed, but at a cost of time, money and a little top speed. Cheers George --------------------------------- ________________________________________________________________________________
Date: Apr 18, 2005
You can also get fittings of this type (as well as a lot of other kinds) at McMaster Carr (www.mcmaster.com). Dick Tasker Jim Jewell wrote: > >Here is another company that provides fittings etc. of the type reffered to. >That is if your local area supplier does not handle Parker. > >http://www.smcusa.com/sections/products/fittings_tubings.asp > > >----- Original Message ----- >From: "Jack Blomgren" <jackanet(at)hotmail.com> >To: >Subject: RV-List: PARKER FAST&TITE tube connectors > > > > >> >> Builders, >> >> Anyone using, and have good 2 to 5 quantity cost source for PARKER >> FAST&TITE >> connectors for use with poly tubing and instruments. Parker brand comes >> with >> the AOA, looks good, simple, uses O-ring. >> Comments? >> >> Jack >> -8 wiring and plumbing > ________________________________________________________________________________
Date: Apr 18, 2005
Another disadvantage of VG's is that they will require maneuvering speed to be reduced, since they effectively increase the lift available at any given airspeed. Skylor RV-8QB Under Construction --- gmcjetpilot(at)yahoo.com wrote: > > VG Facts: > First VG's do work, all will reduced stall speed, > but also expect some top end loss as well. > The benefit is in the order of 3-6 MPH, Loss at top > end, 0-4 MPH. >If you like to Dog-fight you know that you keep > turning > inside until someone runs out of speed, so the VG > equip RV can turn tighter. Also, clean break at > stall and better aileron authority at slow speeds > has been reported. Like everything, no free lunch. > Yes you gain lower stall speed, but at a cost of > time, money and a little top speed. > > Cheers George > > > > --------------------------------- > > > > browse > Subscriptions page, > FAQ, > > > > > > __________________________________ http://travel.yahoo.com/p-travelguide ________________________________________________________________________________
Subject: Aerosport Engines and Shipping/Tax issues
Date: Apr 18, 2005
True...When I registered it, there were tax issues on the entire plane, but what I was referring to was my engine was not taxed individually. Paul Besing RV-6A Sold Kitlog Builder's Software www.kitlog.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bruce Gray Subject: RE: RV-List: Aerosport Engines and Shipping/Tax issues Just wait until you register the airplane..... Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Paul Besing Subject: RE: RV-List: Aerosport Engines and Shipping/Tax issues He must have quit charging the brokerage fee. It wasn't much, maybe $100 or so. It was to pay the people who do that tariff paperwork, clearing customs, etc. FWIW, Arizona didn't ask me to pay tax on the engine. They never knew I bought it. Paul Besing RV-6A Sold Kitlog Builder's Software www.kitlog.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Pat Hatch Subject: RE: RV-List: Aerosport Engines and Shipping/Tax issues Tim, I have bought two engines from Bart and paid no customs fees, just shipping to Florida. Pat Hatch RV-6 RV-7 Thanks everyone, so far, for the replies to my question about engines from AeroSport. It does sound like they have a good reputation. I am a bit confused though, especially after Darwin's post here. As far as taxes, I'm not worried about that. I know that either way I'll be paying the use tax on the plane when I go to register it, so the State of Wisconsin will get their tax one way or the other. I see that some said shipping was less to have it shipped from Aerosport than similar packages shipped from closer and within the US. I'll have to check this out. I see that some said they had small "brokerage fees". No big deal, since it sounds like they were small. The big confusion though is this $1500 "Customs Fee" that Darwin mentions....what's that all about? Was that actually a fee for going through customs? I didn't think there were any fees other than shipping and brokerage (other than tax). So now I'm happy that the engines would be pretty good, but these additional fees are still making me apprehensive. I've got a US supplier that can supply the same engine with ECI Titan cylinders, for probably $2000 less money. The 2 catches are that A) The original cores come from Africa and from turbocharged planes (ss-s-s-scary), and B) They talk of roller lifters like they are something voodoo. I thought that roller lifters were not only a good idea, but something that was now a good and recent product that could help my engine's longevity. Thanks again guys, I'm getting closer. Tim - RV-10 #170 ________________________________________________________________________________
Subject: touch screen pdas in rough air?
Date: Apr 18, 2005
A question for those that own and are using The iPAQ and other touch screen type PDA's; In a discussion recently I was told that the majority of touch screen PDA GPS system users felt that they where very difficult to use effectively in bumpy and or rough air flight conditions. The person making the claims was adamant that this reason among unmentioned others was the prime reason to avoid the PDA based GPS and flight systems. I think it has been a while since this kind of question on this subject has been asked. I have not as yet chosen a path on this subject and hope to get some input pro and con re- PDA based GPS and flight data versus the mainstream portable GPS and fight data systems. Jim in Kelowna ________________________________________________________________________________
Date: Apr 18, 2005
Subject: X-COM Radio and Microair Repair
My Microair VHF 760 radio has failed after only 27 hours of operation. I'm trying to decide if I should try to have it repaired or replace it with the new XCOM radio which has some nice additional features. Does anyone know of a U.S. repair station for Microair radios? I've contacted the factory, but haven't heard back from them. Phone calls to Australia are expensive so I'm relying on e-mails. Also, has anyone been able to get their hands on the XCOM radio? They seem to be back ordered everywhere. Looking at the wiring diagram I should be able to plug it in to my existing radio connector. Thanks, Ted Sweet, sweet flying (but communication challenged) RV-4 ________________________________________________________________________________
Date: Apr 18, 2005
I use Airplan, http://www.razorsedgesoft.com/. Good price and works great. Rene' 801-721-6080 ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Subject: Impressions after flying the RV10
Date: Apr 19, 2005
While at SnF, April 2005, I got a chance to fly the RV10. What follows are a few impressions. (I will try to be brief and to the point). Load = Me + Mike Seager + (RV6'er) Ken + small amount of baggage + almost full fuel. Space . significant as everyone has mentioned. I had sat in the mock-up and later in the real thing (at OSH) but this was better. Engine smooth . as expected for the 6 cylinder. Take-off roll MUCH SHORTER than I expected (with ~ 15 degrees of flaps {my guess}) Climb-out ~ 1500 FPM from sea level at much warmer than standard day (Florida around noon . don't remember the temp) Handling feels "like an RV" . appropriate for the obvious weight. Control forces seem to be between the RV6/RV7 and the outer edges of the RV9. ("9 Flyers" will relate to this) Control forces are expectedly much lighter than Beechcraft A36, Cessna 210 as well as the Piper Saratoga. (I know, these are 6-place . I was thinking speed range). Control forces are much lighter (to me) than the Cirrus SR22 and the Lancair Columbia 300. No excessive trim required. Some required as expected due to size, speed and our loading. Handles well at slow speeds (75 MPH) and high speeds (175 MPH). Yes, it can fly SLOWER and FASTER. Control forces seem well balanced . no major deviations in steep turns (other than those induced by the pilot :-) ) Nice plane. As one had come to expect from Vans. My only comment that was not praise was "I wish someone would donate Vans a set Bose X's . that would make the experience complete." James . now if I could just magically convert the Piper to a 10 overnight .. ________________________________________________________________________________
Subject: Re: touch screen pdas in rough air?
Date: Apr 19, 2005
AWM running on iPAQ works for me. Bit harder in rough air but not impossible. My Terra radio with the speed sensitive knobs is more of a problem than the PDA in turbulence. Having PDA mounted on the top right longeron helps since I can steady my fore arm on it while using wrist action to tap on the screen. This also places it close to eyeballs so I can see screen details easily. If it were mounted on panel it would be harder to manage. Tracy Crook RV-4, Rotary powered. A question for those that own and are using The iPAQ and other touch screen type PDA's; In a discussion recently I was told that the majority of touch screen PDA GPS system users felt that they where very difficult to use effectively in bumpy and or rough air flight conditions. The person making the claims was adamant that this reason among unmentioned others was the prime reason to avoid the PDA based GPS and flight systems. I think it has been a while since this kind of question on this subject has been asked. I have not as yet chosen a path on this subject and hope to get some input pro and con re- PDA based GPS and flight data versus the mainstream portable GPS and fight data systems. Jim in Kelowna ________________________________________________________________________________
Date: Apr 18, 2005
Hi Ted; I have an X-com radio & MicroAir x-ponder. The X-com is a nice little unit and so far I'm pleased with it. This winter I did have a couple of problems with the MicroAir, but they were resolved with excellent customer support. First I found that the backlight was intermittent as if a faulty switch, then a few days later the unit wouldn't turn on at all. I'd e-mailed them and didn't get an immediate response so I phoned them. Long distance is cheap these days, but you need to call during their business hours (go to www.timeanddate.com/worldclock/ to check for Brisbane). When I called, the secretary said the service guy was at lunch but she would have him call me (yeah right, I figured). Twenty minutes later he did and asked if I had any electronics experience and tools at hand. So he talked to me while I disassembled the unit and led me to de-solder a certain transistor that was used as part of the hibernation circuitry, but in some cases would make the unit too "sleepy" and wouldn't wake up. Reassembled the unit and it worked again. Unfortunately however, the backlight was still intermittent. As this wasn't a known problem, he had no self-repair fix for it and instead promised to send me a new front display plate. 30 minutes after I got off the phone with him he called me back with the courier shipping # and said it was on it's way. 4 days later I had it in my hands here in Canada and it only took minutes to install it. I then returned the faulty faceplate in their shipping box using parcel post (cheapest... they said they weren't in any hurry for the return) The whole issue was resolved in less than a week and cost me ~$2 for the phone call & $6 for return shipping. I've dealt with very few companies here in North America that gave me that kind of service. About a week later I received an e-mail from a different service guy in response to my original e-mail request. I really prefer to use e-mail myself for most things, but the sheer amount of spam and other abuse of the internet has severely impacted on the usefulness of e-mail as a communications tool. A company such as MicroAir that has their e-mail address plastered all over the web will receive untold amounts of spam making an aggressive spam filter a necessity. Unfortunately this results in some legitimate e-mails not getting through the filters resulting in unhappy customers and there will still be volumes of spam that will still get by even the best filters, so even if your e-mail got through it may be buried. A large company (such as Aircraft $pruce)has people whose job it is to sort through this stuff and answer e-mails. MicroAir is not that big and service techs likely have to go through e-mail between jobs in the shop. Sometimes it's better to just pickup the phone. Hope this helps Todd Bartrim (satisfied MicroAir customer) RV9Endurance 13B Turbo Rotary C-FSTB "The world will always have a place for those that bring hard work and determination to the things they do." My Microair VHF 760 radio has failed after only 27 hours of operation. I'm trying to decide if I should try to have it repaired or replace it with the new XCOM radio which has some nice additional features. Does anyone know of a U.S. repair station for Microair radios? I've contacted the factory, but haven't heard back from them. Phone calls to Australia are expensive so I'm relying on e-mails. Also, has anyone been able to get their hands on the XCOM radio? They seem to be back ordered everywhere. Looking at the wiring diagram I should be able to plug it in to my existing radio connector. Thanks, Ted Sweet, sweet flying (but communication challenged) RV-4 ________________________________________________________________________________
Date: Apr 19, 2005
Larry, CONGRATULATIONS and WELL DONE !!! Chuck & Dave Rowbotham RV-8A >From: "LarryRobertHelming" <lhelming(at)sigecom.net> >Reply-To: rv-list(at)matronics.com >To: , >Subject: RV-List: RV-7 N3XG Flys High >Date: Sun, 17 Apr 2005 20:20:46 -0500 > > >Pie ChartsToday another new RV-7 left the earthly bound of gravity for the >first time. ________________________________________________________________________________
Subject: Subaru Engine Package for sale
Date: Apr 19, 2005
I have a complete Subaru EJ 2.5 engine package for sale, details can be seen at www.angelfire.com/un/ch701/forsale.html. Larry, N1345L www.angelfire.com/un/ch701 ________________________________________________________________________________
Date: Apr 19, 2005
In a message dated 4/18/2005 7:06:35 P.M. Pacific Daylight Time, jjewell(at)telus.net writes: A question for those that own and are using The iPAQ and other touch screen type PDA's; In a discussion recently I was told that the majority of touch screen PDA GPS system users felt that they where very difficult to use effectively in bumpy and or rough air flight conditions. I have been flying with AWM and an "older" iPaq for several years. I really like the AWM for many reasons - but to answer your question, yes, it can be rough to tap the screen in rough air but I have not found it to be a big issue. Having said that, the other alternative is a bigger screen. The good folks at AWM now have a "jumbo" touch screen PDA called "Raven" with should make the find & tap easier. The back-order is pretty lengthy and mine is on order so I can't give 1st had experiences, but the preliminary reports are good. Kim ________________________________________________________________________________
Subject: .DWG and .DXF TurboCAD Instruments
Date: Apr 19, 2005
I've looked all over and can't find any instrument templates for TurboCAD. Does anyone have the instrument drawings in .dwg or .dxf? I've found the instrument panel, just need good instrument drawings. Jim -7 Fuse Mountain View, CA ________________________________________________________________________________
Date: Apr 19, 2005
Subject: Mag Drive Gear
Today's crayon-level question: I'm installing the drive gear on a Slick 4371 impulse coupled magneto. When trying to tighten the nut, the shaft and the inards of the coupling spin. Despite holding the gear still, everything else is rotating, making it impossible to get the required torque on the nut. What's the trick? Thanks, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Subject: Re: VM1000 Fuel flow transducer mounting
Date: Apr 19, 2005
The recommendation to mount the flow transducer after the engine driven fuel pump is a CYA type instruction. Flow is flow and the instrument will read the same anywhere between the fuel tank and the flow divider. It however is always better to mount any resistance (filter, gascolator,transducers) after the pump as they drop the pressure and could help to cause cavitation. I however only have the airflow performance fuel filter in line without a gascolator so I went ahead and mounted it in the long strait run along the floor between the boost pump and firewall. This kept the sensor out of harms way and reduced the number of hoses needed fwf. Works great. The totalizer is always right on at fillup. -Ross Ross Schlotthauer RV-7 Driver www.experimentalair.com >From: "Bob C. " <flyboy.bob(at)gmail.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: VM1000 Fuel flow transducer mounting >Date: Sat, 16 Apr 2005 17:57:46 -0500 > > >I mounted mine just downstream of the gasolator (RV8) . . . I would >think flow would need to be down stream of the engine driven pump? > >I'm using ACS and EI furnished the flow sensor? > >Good Luck, >Bob >RV-8 - N678RC > > >On 4/16/05, dwhite17(at)columbus.rr.com wrote: > > > > Can anyone help with where they mounted their VM1000 Fuel Flow >transducer? We are building an RV-6, with a Lycoming O-360-AIA engine. >The instructions say to mount level, between the engine driven fuel pump >and the carb, and allow at least 5" minimum straight length between. How >does one do that? > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2005
I use a Palm Zire 71 with Flybynav to figure distance and the AOPA directory for airport info and it works great. I use a Fujitsu ltp-600 for WXworx weather and it works good as well. I have tried the AWM with the weather function and it seem to overload the processor, plus most of the really cool features of XM were not available. Of all the in-cockpit weather solutions I have seen WXworx on wings is by far the best! Tailwinds, Doug Rozendaal ----- Original Message ----- From: <Knicholas2(at)aol.com> Subject: Re: RV-List: touch screen pdas in rough air? > > > In a message dated 4/18/2005 7:06:35 P.M. Pacific Daylight Time, > jjewell(at)telus.net writes: > > A question for those that own and are using The iPAQ and other touch > screen > type PDA's; > > In a discussion recently I was told that the majority of touch screen PDA > GPS system users felt that they where very difficult to use effectively > in > bumpy and or rough air flight conditions. > > > I have been flying with AWM and an "older" iPaq for several years. I > really > like the AWM for many reasons - but to answer your question, yes, it > can > be rough to tap the screen in rough air but I have not found it to be a > big > issue. > > Having said that, the other alternative is a bigger screen. The good > folks > at AWM now have a "jumbo" touch screen PDA called "Raven" with should > make > the find & tap easier. The back-order is pretty lengthy and mine is on > order so I can't give 1st had experiences, but the preliminary reports > are good. > > Kim > > > ________________________________________________________________________________
Date: Apr 19, 2005
Eric White More on the EAA Airventure Cup Race... First... in answer to Tracy Crook's questions about insurance -my experience has been the same as John Huft and Alan Kritzman -who commented already. Last year Avemco took three tries to get it right (they kept trying to change EAA's required wording just 'slightly' -in their favor and EAA wouldn't buy it) -but they finally got it done -and there was no extra charge as I recall. I only kept the 'race' coverage in effect 'till I got back from OSH -then I called and had them change it back to 'normal'. This year I'm with AIG -and I specifically asked about the race requirements when I went with them -they said 'no problem' -so we'll see... It would be so cool to have you show up for the race, Tracy -I'm not sure which class you be grouped into -but it would be so neat to have your blazingly fast Mazda RV-4 in the race with us (even if you did kick my butt and deny me a trophy...) More correspondance from race director Eric White follows... Best Regards, and come race with us! -Scott Spencer Race 74 N4ZW (a stock 150hp RV-4 w/ wood prop -first place in class 2003... so anyone can win theoretically...) Hi Scott, Thanks for the help. Hopefully we will get a few more entries. Although, to qualify for the Formula RV class, you need to have a "stock" RV, although sort of hard to define stock in a homebuilt airplane. Engines are limited to 360 cubic inches, so anyone running the new IO-390 will have to run in the Sport Class for this year. (We might modify the rules in the future) I am planning to split the RV class into the Red and Blue divisions this year. Last year it got left out. Red for the O-320 powered RVs and the Blue for the 360 powered airplanes. If anyone has an RV-9/9A with the O-235 in it, (Like Van's Prototype they can run in the Sprint class). One new addition this year, the race has been asked to hold "mini-forums" at the race tent to describe the mods, or overall race experience. I have heard from several of the RV drivers and they have indicated that they would like to do a group discussion "Cross Country Racing in your RV" If you would like to take part we need a RV-4 pilot. I would like to recruit Bobbie as well. I will keep you posted on changes as they happen. Eric ________________________________________________________________________________
Date: Apr 19, 2005
Subject: Re: .DWG and .DXF TurboCAD Instruments
Jim, I have some TurboCAD instrument templates, mostly for 2 1/2 and 3/1/4 gages (at least the ones in my panel). Also have a few rectangular things (hobbs, CO monitor, etc.), and switches. They are a combination of drawings from other builder's web sites, and ones I have created from manufacturers drawings. Contact me off the list and let me know what you are looking for. I can extract them from my panel print and send them directly to you. Steve Allison RV-6A - future N9806A San Jose, CA Piavis wrote: > >I've looked all over and can't find any instrument templates for TurboCAD. >Does anyone have the instrument drawings in .dwg or .dxf? I've found the >instrument panel, just need good instrument drawings. > >Jim >-7 Fuse >Mountain View, CA > > > > ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Subject: XM2GO
Date: Apr 19, 2005
Just a review on the relatively new xm2go, the portable xm receiver. I flew down to snf from Chicago with the antenna sticking to my rollover bar and the rcvr between the seats. It worked GREAT!! I plugged it directly into my stereo via a front panel mini plug. I talked to the xm guys and they told me the music is included if you purchase their weather package. That leads me to a question. Is anyone using xm weather by itself with a pda? The price of anywhere map is too high. Shemp/Jeff Dowling RV-6A, N915JD 165 hours Chicago/Louisville ________________________________________________________________________________
Date: Apr 19, 2005
>"In a discussion recently I was told that the majority of touch screen PDA GPS system users felt that they where very difficult to use effectively in bumpy and or rough air flight conditions." I have used both PDA and dedicated GPS units like the Garmin 195. I like a dedicated buttons on the Garmin GPS. The touch screen is a little bit of a hassle especially if you have to use a stylus. TOUCH SCREEN: In turbulence, ease of screen touch depends on how you mount you PDA GPS. Mount it close and place it so you can rest your hand or arm. If you have it bolted to the inst panel at arms length, yes, it can be hard to select functions in the bumps. Most PDA GPS software have a rough air mode the expands the menu keys, to make it easier to see and pick. Also you can use some of the buttons on the PDA to select functions. If the PDA is mounted on the side, off the panel, you can rest your arm or hand on the arm rest or side longeron, it is not a big issue. I would say the discreet buttons on the stand alone GPS units are easier to operate than the touch screen of a PDA IMHO, especially when you know the tricks of the buttons. My old Garmin 195 has a 4 position rocker that makes moving the screen cursor easy. Cheers George --------------------------------- ________________________________________________________________________________
Subject: Air Box
Date: Apr 19, 2005
Like many of you I had to replace my air box mounting plate at 370hrs. It looks like it was cracked for some time. I replaced it but think I will lay up one out of composite since it acts more like wood to dampen out vibration. Anyone have experience with this? John Furey RV6A O-320 C/S ________________________________________________________________________________
From: "Alex & Gerry Peterson" <alexpeterson(at)earthlink.net>
Subject: Air Box
Date: Apr 19, 2005
> > > > Like many of you I had to replace my air box mounting plate > at 370hrs. It looks like it was cracked for some time. I > replaced it but think I will lay up one out of composite > since it acts more like wood to dampen out vibration. Anyone > have experience with this? > > John Furey > RV6A O-320 C/S I doubt if it is vibration, probably engine movements. Round up all the edges, including where it fastens to its mounting plate or bracket. Alex Peterson RV6-A 609 hours Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: Caution: Quickbuild Wingtank Fuel Pickup
Date: Apr 19, 2005
Adding fuel gages this weekend before installing the wings on my 9A quickbuild I found that the fuel pickup tubes, as they came from the factory, were bent incorrectly and were about 3" above where called for in the plans if all the fuel in the tanks were to be available. Since this could be a safety of flight issue I thought I'd better mention it. No doubt if you are diligent in checking everything versus the plans this would be caught, but it isn't inconceivable that one could assume the parts were completed accurately and remain unaware of the situation until running out of gas thinking they still had fuel remaining. Also, what do people think about a slotted tube vs. a screen on the fuel pickup? Is one better than the other in the event of particulate matter somehow getting into the tanks? Mike Holland Dana Point, CA ________________________________________________________________________________
Date: Apr 19, 2005
Subject: Re: X-COM Radio and Microair Repair
Ted, What exactly is wrong with your radio? Ted Lumpkin wrote: > >My Microair VHF 760 radio has failed after only 27 hours of operation. I'm trying to decide if I should try to have it repaired or replace it with the new XCOM radio which has some nice additional features. >Does anyone know of a U.S. repair station for Microair radios? I've contacted the factory, but haven't heard back from them. Phone calls to Australia are expensive so I'm relying on e-mails. >Also, has anyone been able to get their hands on the XCOM radio? They seem to be back ordered everywhere. Looking at the wiring diagram I should be able to plug it in to my existing radio connector. > >Thanks, > >Ted >Sweet, sweet flying (but communication challenged) RV-4 > > > > ________________________________________________________________________________
Date: Apr 19, 2005
Scott, My radio just stopped working completely. No display, no static, no transmit/receive light. The back-light does still work. I just got off the phone with Microair and their tech rep, Ian, feels it is probably a fuse. He is sending me a service bulletin that will show me how to replace it. I will try that and let the list know if it worked. By the way, I have an avionics master switch and am pretty religious about turning it off during engine start and shut down. Ted Scott VanArtsdalen wrote: Ted, What exactly is wrong with your radio? Ted Lumpkin wrote: > >My Microair VHF 760 radio has failed after only 27 hours of operation. I'm trying to decide if I should try to have it repaired or replace it with the new XCOM radio which has some nice additional features. >Does anyone know of a U.S. repair station for Microair radios? I've contacted the factory, but haven't heard back from them. Phone calls to Australia are expensive so I'm relying on e-mails. >Also, has anyone been able to get their hands on the XCOM radio? They seem to be back ordered everywhere. Looking at the wiring diagram I should be able to plug it in to my existing radio connector. > >Thanks, > >Ted >Sweet, sweet flying (but communication challenged) RV-4 > > > > ________________________________________________________________________________
Date: Apr 20, 2005
Subject: Re: Caution: Quickbuild Wingtank Fuel Pickup
In a message dated 4/19/05 9:54:23 PM Central Daylight Time, hollandm(at)pacbell.net writes: > Also, what do people think about a slotted tube vs. a screen on the fuel > pickup? Is one better than the other in the event of particulate matter > somehow getting into the tanks? >>>> I'd fer sure go with a couple of finger strainers- not that a bunch of RVs aren't happily running with the slots, but keeping as much potential crud out of as much of the fuel system as possible couldn't be a bad idea. Disconnecting a fuel line at annual and blowing the pickup tube out to clear any stuff on it is easy to do... http://www.aircraftspruce.com/catalog/appages/fingstrainers.php from Spruce could likely be adapted, and Vans has a complete pickup tube with integral strainer for $12.50 (go to on-line catalog and search for "finger" or try this): http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1114000613-232-603& browse=airframe&product=fuel-pickup Being "cheap", I made my own strainers by plugging the end of the pickup tube, drilling four holes on each side of the bottom of it, then wrapping screen liberated from a frying pan splatter guard around the tube and securing with a couple of Oetiker clamps (foto sent off-list). Has worked well so far, but the commercial finger strainers would be much easier... Also- good thing ya checked the pickup tube position and thanks for the heads-up! From The Possumworks in TN Mark Phillips - N51PW 175 hrs. ________________________________________________________________________________
Date: Apr 20, 2005
Mike and Others I was less than pleased with the results obtained in fabricating my slotted fuel pickup tubes, so I ordered Van's standard units. Dean Van Winkle RV-9A Fuselage/Finish ----- Original Message ----- From: "Mike Holland" <hollandm(at)pacbell.net> Subject: RV-List: Caution: Quickbuild Wingtank Fuel Pickup > > Adding fuel gages this weekend before installing the wings on my 9A quickbuild I found that the fuel pickup tubes, as they came from the factory, were bent incorrectly and were about 3" above where called for in the plans if all the fuel in the tanks were to be available. Since this could be a safety of flight issue I thought I'd better mention it. > > No doubt if you are diligent in checking everything versus the plans this would be caught, but it isn't inconceivable that one could assume the parts were completed accurately and remain unaware of the situation until running out of gas thinking they still had fuel remaining. > > Also, what do people think about a slotted tube vs. a screen on the fuel pickup? Is one better than the other in the event of particulate matter somehow getting into the tanks? > > Mike Holland > Dana Point, CA > > ________________________________________________________________________________
Date: Apr 20, 2005
Subject: Installing prop governor/DC #7 for gasket
During our next building session this weekend we'll install the engine. We'd like to install the MaCaully governor before we hang the engine and they recommend using Dow Corning #7 on the gasket. I assume this for easy release in case, 100's of hours down the road, the gov. needs to be removed. We can't find any DC #7 locally. Is there a good substitute that would be easlily available in small town America? Bob Skinner -- ________________________________________________________________________________
Date: Apr 20, 2005
Subject: Re: Installing prop governor/DC #7 for gasket
Any silicone dielectric grease will do. You may want to check your local auto parts store for AGS Sil-Glyde Dielectric Spark Plug Protector. Regards, Bob Japundza RV-6 flying 600+ hours F1 under const. On 4/20/05, rv6fly wrote: > > During our next building session this weekend we'll install the > engine. We'd like to install the MaCaully governor before we hang the > engine and they recommend using Dow Corning #7 on the gasket. I assume > this for easy release in case, 100's of hours down the road, the gov. > needs to be removed. We can't find any DC #7 locally. Is there a good > substitute that would be easlily available in small town America? > > Bob Skinner > > -- > > > ________________________________________________________________________________
Date: Apr 20, 2005
Also, what do people think about a slotted tube vs. a screen on the fuel pickup? Is one better than the other in the event of particulate matter somehow getting into the tanks? Since the primary purpose of a fuel system is to deliver fuel, it is important that particles that might restrict flow be removed before reaching the choke point where they could cause the restriction. As the wing tank fuel pickup is the initial point of entry to the system, it's openings should be the coarsest in the system. I like the slotted tube because the openings are large, numerous, & it's simple. Unlikely to be blocked. Filters placed further downstream should be no finer than needed to remove particles too large to pass through the parts of the system further downstream. Doing so increases the likelihood that the filter may become blocked without gaining any material advantage. Surface areas should be as generous as possible. The area needed is a function not only of how large the particles encountered are but how long the filter has to operate between inspections. How often can fuel pickups be inspected? A finger screen with a mesh about as coarse as the slots in the pickup tube and a surface area to match would work just as well as the slotted tube but would introduce the additional complexity of a fastener. Just my insufferably didactic $200 worth. Dave Reel - RV8A ________________________________________________________________________________
Date: Apr 20, 2005
Subject: Re: Air Box
I'm curious whether you guys experiencing these cracks have an airbox that contacts the bottom of the air filter element directly, or the style I have with a deeper bowl and a separate aluminum plate that fits inside the bottom filter gasket to close off the bottom. I never realized there were two styles until my campground neighbor at SnF showed my the newer style (we were discussing air filter service difficulty and the trick of notching the back of the airbox to allow its removal without dropping the gear leg each time, an option I don't believe will work on my setup without interference with the filter itself.) My installation is crack-free after 500 hours. Just curious. -Stormy -----Original Message----- From: Alex & Gerry Peterson <alexpeterson(at)earthlink.net> Subject: RE: RV-List: Air Box > > > > Like many of you I had to replace my air box mounting plate > at 370hrs. It looks like it was cracked for some time. I > replaced it but think I will lay up one out of composite > since it acts more like wood to dampen out vibration. Anyone > have experience with this? > > John Furey > RV6A O-320 C/S I doubt if it is vibration, probably engine movements. Round up all the edges, including where it fastens to its mounting plate or bracket. Alex Peterson RV6-A 609 hours Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: Air Box
Date: Apr 20, 2005
Mine has the air filter held in place by a separate plate. It does not contact the fiberglass housing. On both my RV6A's, one with O-320 and one with O-360 I was able to remove the housing without removing the nose gear. John ________________________________________________________________________________
Date: Apr 20, 2005
Bob J wrote: > >Any silicone dielectric grease will do. You may want to check your >local auto parts store for AGS Sil-Glyde Dielectric Spark Plug >Protector. > >Regards, >Bob Japundza >RV-6 flying 600+ hours F1 under const. > Thanks Allen and Bob. Would Dow Corning 4 work? It sure worked well on the oil filter gasket on both my RV6 and truck. Hi, Bob. 600+ hours. Wow. It doesn't seem like that long ago that you were building your 6. Doesn't look like you're letting any grass grow under your tires. The F1 is a beautiful airplane. Bob Skinner -- ________________________________________________________________________________
Date: Apr 20, 2005
That's pretty weird. I have a Microair 760 too and I have no avionics switch. I leave the radio and T2000 transponder on so they power up when the master switch is on. I had a problem with the funny characters in the display problem. That was an easy fix. Hopefully your fix will be just as easy. Please do keep us updated. > From: Ted Lumpkin <tlump51(at)sbcglobal.net> > Reply-To: rv-list(at)matronics.com > Date: Tue, 19 Apr 2005 22:59:49 -0700 (PDT) > To: rv-list(at)matronics.com > Subject: Re: RV-List: X-COM Radio and Microair Repair > > > Scott, > > My radio just stopped working completely. No display, no static, no > transmit/receive light. The back-light does still work. > I just got off the phone with Microair and their tech rep, Ian, feels it is > probably a fuse. He is sending me a service bulletin that will show me how to > replace it. I will try that and let the list know if it worked. > By the way, I have an avionics master switch and am pretty religious about > turning it off during engine start and shut down. > > Ted > > > Scott VanArtsdalen wrote: > > Ted, > What exactly is wrong with your radio? > > Ted Lumpkin wrote: > >> >> My Microair VHF 760 radio has failed after only 27 hours of operation. I'm >> trying to decide if I should try to have it repaired or replace it with the >> new XCOM radio which has some nice additional features. >> Does anyone know of a U.S. repair station for Microair radios? I've contacted >> the factory, but haven't heard back from them. Phone calls to Australia are >> expensive so I'm relying on e-mails. >> Also, has anyone been able to get their hands on the XCOM radio? They seem to >> be back ordered everywhere. Looking at the wiring diagram I should be able to >> plug it in to my existing radio connector. >> >> Thanks, >> >> Ted >> Sweet, sweet flying (but communication challenged) RV-4 >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Apr 20, 2005
Subject: Fitting cowl without having engine and prop installed
The builder I'm helping has some printed material on installation of the cowl without installing the bulkheads, prop and spinner. I don't know where this info came from, off the list or Van's? I think I remember something along these lines when I built my six and helped with a 6A but elected to install the prop and bulkheads because I felt more certain off getting the cowl fit properly. As I've been away from building for several years, I'm not up to speed on the latest. Does this alternate method work OK or would you recommend mounting prop, bulkhead and spinner? Bob Skinner -- ________________________________________________________________________________
Date: Apr 20, 2005
Bob, DC4 will work just fine. Allen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rv6fly Subject: Re: RV-List: Installing prop governor/DC #7 for gasket Bob J wrote: > >Any silicone dielectric grease will do. You may want to check your >local auto parts store for AGS Sil-Glyde Dielectric Spark Plug >Protector. > >Regards, >Bob Japundza >RV-6 flying 600+ hours F1 under const. > Thanks Allen and Bob. Would Dow Corning 4 work? It sure worked well on the oil filter gasket on both my RV6 and truck. Hi, Bob. 600+ hours. Wow. It doesn't seem like that long ago that you were building your 6. Doesn't look like you're letting any grass grow under your tires. The F1 is a beautiful airplane. Bob Skinner -- ________________________________________________________________________________
Date: Apr 20, 2005
Bob, Go down to your local auto parts store. Ask for a tube of Permatex Dielectric Tune-Up Grease. Everyone carries it, and it's the equivilent of the Dow #7. Charlie Kuss ---- rv6fly wrote: > > During our next building session this weekend we'll install the > engine. We'd like to install the MaCaully governor before we hang the > engine and they recommend using Dow Corning #7 on the gasket. I assume > this for easy release in case, 100's of hours down the road, the gov. > needs to be removed. We can't find any DC #7 locally. Is there a good > substitute that would be easlily available in small town America? > > Bob Skinner > > > -- > > > > > > ________________________________________________________________________________
Date: Apr 20, 2005
Bob, The instructions most likely came from Van's website. I just fit my cowl that way. It seems to work fine, but then I don't have my prop yet. Terry RV-8A finishing Seattle The builder I'm helping has some printed material on installation of the cowl without installing the bulkheads, prop and spinner. I don't know where this info came from, off the list or Van's? I think I remember something along these lines when I built my six and helped with a 6A but elected to install the prop and bulkheads because I felt more certain off getting the cowl fit properly. As I've been away from building for several years, I'm not up to speed on the latest. Does this alternate method work OK or would you recommend mounting prop, bulkhead and spinner? Bob Skinner -- ________________________________________________________________________________
Subject: Announcing The Third Annual Rebel's Bluff FlyIn
Date: Apr 20, 2005
"RV-List Digest Server" Subject: Announcing The Third Annual Rebel's Bluff FlyIn "Flash"! THIRD ANNUAL REBEL'S BLUFF FLYIN Now that Sun n Fun is over, it's time to fly to the Third Annual Rebel's Bluff FlyIn for Rocket's and Van's RV Aircraft on May 7th, 2005. Come in about 10:00AM for an Ozarks Style Bar-B-Que lunch with all the fixin's (catered by the First Baptist Ladies Group), and some great comaradrie. Rebel's Bluff (N37 06.1 W93 52.2) is located two miles north of Mt Vernon Municipal Airport (2MO), and just west of Mt Vernon, Missouri. About 150 miles SSE of Kansas City, MO, and 140 east of Tulsa, OK. The runway 14/32 is 2,200' of very smooth sod by 60' wide. Use 122.9 (Mt Vernon's) UNICOM frequency and announce "landing at Rebel's Bluff." AV Gas 100LL will be available for approximately $2.50/gallon. Rain date is May 14th if it is a complete washout. RSVP would be greatly appreciated to your host Les Featherston at lwfeatherston(at)aol.com or call 417-466-4663 at home, or 417-425-3595 cell. Overnighters can stay at the Super 8 for $53, or camping by the creek (with flush toilet) is available. Looking forward to seeing all of you again. Les ************************************************************************ ************************************************************************ ****** Les has a gorgeous Harmon. Pics on my pireps page if you're interested. http://www.usi.edu/science/chemistry/vfrazier/Pilot%20reports.html I plan to go to the flyin. I've been to Les's flyin previously and it was very nice. If anyone wants more info and can't reach Les, feel free to call me... 812-464-1839 M-F Vince ________________________________________________________________________________
Date: Apr 20, 2005
clamav-milter version 0.80j on opie.wvnet.edu >Like many of you I had to replace my air box mounting plate at 370hrs. It >looks like it was cracked for some time. I replaced mine at 150 hours. I think the cracks have a lot to do with how tight the cowl is mounted to the airbox. A tight fitting gives the highest manifold pressure increase, but then is subject to the increase in vibration between the engine and the cowl (the cowl does not vibrate as much as the engine, nor at the same frequency). Also I suspect that high G maneuvers (4+) would cause more cracking. At 4 Gs you can see the spinner (meaning engine) drop in reference to the top of the cowl. My fix was to replace the plate with a much thicker plate and to insure extra space between the cowl inlet and the airbox. Time will tell if this works. Bob RV6 NightFighter ________________________________________________________________________________
Subject: Re: Static System Connections
Date: Apr 20, 2005
Hi, Charlie. Your experience was same as mine - hot water. . . split 4 days later. There must of have been a materials change somewhere along the line - those with good enuf mat'l (older kits) had no problem and are mystified by my post. But split tubing is split tubing - so it's "not optimum" to continue with the "procedure" that no longer works when real fittings are so readily available and cheap and work so well. David ----- Original Message ----- From: "Charlie Kuss" <chaztuna(at)adelphia.net> Subject: Re: RV-List: Static System Connections > > I'm with David, > I purchased the Vans static kit and installed it. By heating the 1/4" > plastic tubing in boiling water, with effort, I was able to get the plastic > tubing on the Tee fitting. Four days later, that cheap (import stuff, NOT > real Imperial Eastman Nyloflow) tubing split. I ripped it all out. I > replaced it with genuine Nyloflow tubing and fittings similar to what David > describes. I purchased the tubing and fittings from ACS. > I've also gotten the "you are the only one who has ever complained" > routine from Vans. Each time, it was in reference to a problem which was > widely reported on the RV List. I've found that Van's Dutch genes > occasionally do us a dis-service. The static kit and capacitance fuel > sender kit are two examples of this. I'm not a disgruntled customer. On the > whole, the RV kits are still the best "bang for the buck", in my opinion. > You just have to side step the occasional "pot hole" in the road. :-) > Charlie Kuss > > > > >This Van's "method" has to be the most ignorant thing about the entire kit - > >totally unacceptable to do it their way. I went to a local "fittings" shop > >(brass & plastic) and bought standard, cheap Ts with the screw on caps that > >you just stick the tubing into and then tighten the caps. Totally > >professional, totally secure, totally better than forcing the one size > >tubing onto the smaller (but not small enough) tubing and then having the > >ends split by a week later. They claim "they never heard of that one > >before". Yeah, sure, I'm the ONLY ONE who had the tubing split. > > > >David ________________________________________________________________________________
Date: Apr 20, 2005
Subject: Re: Fitting cowl without having engine and prop installed
I am about to embark on the same road, can anybody who employed Van's article without having the prop give some good/bad/indifferent remarks when they did finally hang the prop??? more gap/less gap?? etc. move up or down a bit?? Thanks Gert Terry Watson wrote: > >Bob, > >The instructions most likely came from Van's website. I just fit my cowl >that way. It seems to work fine, but then I don't have my prop yet. > >Terry >RV-8A finishing >Seattle > > > The builder I'm helping has some printed material on installation of >the cowl without installing the bulkheads, prop and spinner. I don't >know where this info came from, off the list or Van's? I think I >remember something along these lines when I built my six and helped with >a 6A but elected to install the prop and bulkheads because I felt more >certain off getting the cowl fit properly. As I've been away from >building for several years, I'm not up to speed on the latest. Does >this alternate method work OK or would you recommend mounting prop, >bulkhead and spinner? > >Bob Skinner > > >-- > > > > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Apr 20, 2005
I trust you mean removal by way of molding a recessed notch into the back of the airbox, for the gear leg to fit into as the box is lowered for removal... I've looked at the geometry of this on my plane, and for the life of me it doesn;t seem as if there's room for such a notch without interfering with the filter itself. Maybe I'm just 3-D visualization-challenged! -Stormy -----Original Message----- From: John Furey <john(at)fureychrysler.com> Subject: RE: RV-List: Air Box Mine has the air filter held in place by a separate plate. It does not contact the fiberglass housing. On both my RV6A's, one with O-320 and one with O-360 I was able to remove the housing without removing the nose gear. John ________________________________________________________________________________
Subject: wheel pants bracket
Date: Apr 20, 2005
Can anyone tell me where to get stainless steel wheel pant brackets for my RV6A main gears? Thanks John ________________________________________________________________________________
Subject: Air Box
Date: Apr 20, 2005
Yes, The O-360 needed an indentation in the air box. I just heated the fiberglass and pushed a round pipe into it until it cooled. The O-320 did not need this. John ________________________________________________________________________________
Date: Apr 20, 2005
Subject: Re: wheel pants bracket
Yo' Crossfire, Attaway Air has them. Scroll about half way down the page....90 buckaroos. http://www.attawayair.com/ Rick Gray in Ohio at the Buffalo Farm http://rv6rick.tripod.com/ohiovalleyrvators/index.html For the archives Can anyone tell me where to get stainless steel wheel pant brackets for my RV6A main gears? Thanks John ________________________________________________________________________________
Date: Apr 20, 2005
Terry Watson wrote: >Bob, > >The instructions most likely came from Van's website. I just fit my cowl >that way. It seems to work fine, but then I don't have my prop yet. > >Terry >RV-8A finishing >Seattle > Thanks, Terry. I'm kind of embarassed. I hadn't checked Van's website in 5 or 6 years. They have lots of building info there. Quite an improvement from the "old days". The instructions make sense. I'd still like to hear from builders who have got their props and spinners fitted and say that everything worked out OK. I know, if the prop & spinner is on that the cowl can be made to fit. I'm still a bit nervous about this other method. Thanks, Bob Skinner -- ________________________________________________________________________________
Date: Apr 20, 2005
Mike, I favor Vans prefabricated pick up tubes with screens. The total surface area of the screening, far exceeds the surface area of the bare tube. Therefore, it should take more debris to restrict the screened units. Charlie Kuss > >Adding fuel gages this weekend before installing the wings on my 9A >quickbuild I found that the fuel pickup tubes, as they came from the >factory, were bent incorrectly and were about 3" above where called for in >the plans if all the fuel in the tanks were to be available. Since this >could be a safety of flight issue I thought I'd better mention it. > >No doubt if you are diligent in checking everything versus the plans this >would be caught, but it isn't inconceivable that one could assume the >parts were completed accurately and remain unaware of the situation until >running out of gas thinking they still had fuel remaining. > >Also, what do people think about a slotted tube vs. a screen on the fuel >pickup? Is one better than the other in the event of particulate matter >somehow getting into the tanks? > >Mike Holland >Dana Point, CA > > ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Apr 21, 2005
John, Got them for mine from attawayair.com.....easy to install with no modifications. If you need a set while waiting for your order my never installed aluminum are available for FREE. Tom in Ohio (10G) ----- Original Message ----- From: "John Furey" <john(at)fureychrysler.com> Subject: RV-List: wheel pants bracket > > Can anyone tell me where to get stainless steel wheel pant brackets for my > RV6A main gears? > > Thanks > John > > > ________________________________________________________________________________
Date: Apr 21, 2005
Thanks for the generous offer Tom. I put a patch on the old one that should hold for quite a while. How is the plane coming? jf ________________________________________________________________________________
Date: Apr 21, 2005
Thanks Rick, My plane is falling apart. I thought helicopters were high maintance... while I had the cowl off I did a comp check, new plugs, fix the air box, patched fairing bracket, etc. should make the annual a snap in June. Hope to have it ready to fly tonight. jf ________________________________________________________________________________
Subject: RV vs Rocket
Date: Apr 21, 2005
SNIP People can say what they want about how great an RV flies, that is until they experience a rocket. Its not just about the horsepower. They fly as beautifully as they look. Regards, Bob Japundza RV-6 flying 600+ hours F1 under const. SNIP Bob is right. Man, I LOVED my RV-4. It ruined me from ever being happy in any production plane that I ever flew afterwards. But what about the Rocket? Well, I still like to fly RVs, but given a choice..... the Rocket wins. Let me explain: Flying RVs is like spending the night with Jennifer Aniston. Flying the Rocket is like spending the night with Jennifer Aniston, Cindy Crawford, Sandra Bullock, and 12 Victoria's Secret models... and they're fighting over who gets you next. Vince F-1H Rocket, N540VF http://www.usi.edu/science/chemistry/vfrazier/page1.html ________________________________________________________________________________
Date: Apr 21, 2005
I'll give that a try next time I'm uncowled. Using this modification, does the nose gear leg fairing have to be removed for clearance when removing the airbox? -Stormy -----Original Message----- From: John Furey <john(at)fureychrysler.com> Subject: RE: RV-List: Air Box Yes, The O-360 needed an indentation in the air box. I just heated the fiberglass and pushed a round pipe into it until it cooled. The O-320 did not need this. John ________________________________________________________________________________
Date: Apr 21, 2005
Subject: Re: RV vs Rocket
I gotta get me a F-1 rocket! Talk about girls............................. ________________________________________________________________________________
Subject: Experimental O360 for sale
Date: Apr 21, 2005
I have a new Penn Yan XE 360 with Slick Mags, forward cold air induction, and Precision fuel injection for sale. On pallet as delivered to me $20K. Please reply personally to me at abqmooney(at)excite.com if interested for more details. ________________________________________________________________________________
Date: Apr 21, 2005
Subject: oil cooling methods
My friend's (Larry), 6A has a firewall mounted oil cooler. I imagine the standard source of cool air for the cooler would be SCAT tubing from the baffle behind cylinder #4. Years ago while helping with another 6A I toyed with the idea of taking the cooling air from a NACA vent on the left side of the cowl with the idea of keeping all of the air coming in the cowl inlet for cylinder cooling instead of bleeding off air behind #4 for the oil cooler. The downside would be having to undo a clamp before being able to drop the bottom cowl. As a lot of my RV knowledge is not up to date, I thought I'd check current thingking on this. Also, what's the latest on mechanical fuel pump cooling and alternator cooling both of which I did when I built my 6. Bob Skinner -- ________________________________________________________________________________
Subject: Closing VS and HS tips
Date: Apr 21, 2005
Although the instructions say it's OK to leave the vertical stabilizer and horizontal stabilizer tips open, I'm wondering if anyone who stores their airplane outside on a tie-down as I plan to do has wished they closed the tips for any reason. Water entry and critter nests come to mind. Dave Reel - RV8A ________________________________________________________________________________
Date: Apr 21, 2005
Subject: Fw: I have a Sky-Tec starter for sale
If anyone needs a starter.......IIRC it's from an O360.... -----Forwarded Message----- From: James Redmon <james(at)berkut13.com> Subject: I have a Sky-Tec starter for sale I have a starter in need of a good home if you know someone that might need it. Fresh from the factory - 0-time. Ebay item number: 4544864662 Please post on the RV groups lists if you feel that they might benefit too. Thanks, James Redmon Berkut #013 N97TX http://www.berkut13.com ________________________________________________________________________________
Date: Apr 21, 2005
> ... My answer was an RV-8 with a 300 HP rotary with the > wings extended 1 foot on each side and RV-7/Rocket wingtips. ... Sounds very interesting. Did you do anything to beef up the spar, or are you planning on reducing the aerobatic limits? What's the difference between the RV7 wingtips and the RV8 wingtips? Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
From: "Aircraft Technical Book Company" <winterland(at)rkymtnhi.com>
Subject: Re: Fw: I have a Sky-Tec starter for sale
Date: Apr 21, 2005
Why aren't you using it? I remember reading once that Skytec starters and Lightspeed Electronic ignition systems had compatibility problems. I don't remember why this was the case or if the problem was or is easily resolved. Anybody have a Skytec and a Lightspeed who can attest to its performance? Andy Builder's Bookstore www.buildersbooks.com ----- Original Message ----- From: "Ralph E. Capen" <recapen(at)earthlink.net> Subject: RV-List: Fw: I have a Sky-Tec starter for sale > > If anyone needs a starter.......IIRC it's from an O360.... > > -----Forwarded Message----- > From: James Redmon <james(at)berkut13.com> > To: "Ralph E. Capen" > Subject: I have a Sky-Tec starter for sale > > I have a starter in need of a good home if you know someone that might > need > it. Fresh from the factory - 0-time. > > Ebay item number: 4544864662 > > Please post on the RV groups lists if you feel that they might benefit > too. > > Thanks, > > James Redmon > Berkut #013 N97TX > http://www.berkut13.com > > > ________________________________________________________________________________
Subject: Re: oil cooling methods
Date: Apr 21, 2005
O-320's seem to cool just fine with the any oil cooler/mounting location. Its the IO-360's that seem to cause the most problems. I should know, I've been working on mine a lot. I have a 10 row behind #4 and it still has a tough time keeping up. I had a 7 row on the firewall that didnt work. In hind sight, I would have done the naca duct right from the start but you never know if you're going to have trouble until your flying. Shemp/Jeff Dowling RV-6A, N915JD 165 hours Chicago/Louisville ----- Original Message ----- From: "rv6fly" <rv6fly(at)bresnan.net> Subject: RV-List: oil cooling methods > > My friend's (Larry), 6A has a firewall mounted oil cooler. I imagine > the standard source of cool air for the cooler would be SCAT tubing from > the baffle behind cylinder #4. Years ago while helping with another 6A > I toyed with the idea of taking the cooling air from a NACA vent on the > left side of the cowl with the idea of keeping all of the air coming in > the cowl inlet for cylinder cooling instead of bleeding off air behind > #4 for the oil cooler. The downside would be having to undo a clamp > before being able to drop the bottom cowl. > As a lot of my RV knowledge is not up to date, I thought I'd check > current thingking on this. > Also, what's the latest on mechanical fuel pump cooling and alternator > cooling both of which I did when I built my 6. > > Bob Skinner > > > -- > > > ________________________________________________________________________________
Date: Apr 21, 2005
Subject: Lightening Holes on the Vertical Stab Spar, HS rivet opinions?
Hi all, I am starting work on the vertical stab spar. They describe "optional" lightening holes in the spar reinforcing piece. It doesn't look to me like this would be a significant weight savings, although it is at the end of a very long moment arm. What are most people doing with this? I am awaiting an inspection by my friend EAA tech counselor this weekend to look at my horizontal stabilizer. It is almost perfect except for a couple of small issues. There are a few small scratches in the primer from bucking rivets. Do most of you go back and touch those up? I have one rivet that is just slightly proud. I am unsure if taking it out will improve things or make them worse. Will see what the tech counselor thinks. The one I am most worried about is a rivet that holds the front inner rib to the from spar reinforcement. My first rivet got bent going in. I drilled it out from the wrong side (shop head) and got a little way into the spar reinforcement bar. I re-riveted it with the same -4 rivet. You can see a small defect from my over drilling. I was considering the following options: 1. Leave it--put in some primer around it. 2. Drill it out and go with a larger size rivet 3. Drill it out and put in a small 3/16 bolt. Since the hole only goes about 1/3 of the thickness of the spar reinforcement, I thought it might be okay to leave. I will see what the tech counselor thinks. Opinions here? Regards, Michael Wynn RV8 Empennage San Ramon, CA ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Apr 21, 2005
Another issue seems to be engine time. The oil temperatures on my 0-320 were higher than I wanted for the first 150 hours, but there was a definite decrease over time. Some of the decrease is attributable to modifications I made, but I'd wager that a meaningful amount of the decrease was because the engine finally broke itself in completely. Just a theory, mind you... KB ----- Original Message ----- From: "Jeff Dowling" <shempdowling2(at)earthlink.net> Subject: Re: RV-List: oil cooling methods > > > O-320's seem to cool just fine with the any oil cooler/mounting location. > Its the IO-360's that seem to cause the most problems. I should know, > I've > been working on mine a lot. I have a 10 row behind #4 and it still has a > tough time keeping up. I had a 7 row on the firewall that didnt work. In > hind sight, I would have done the naca duct right from the start but you > never know if you're going to have trouble until your flying. > > Shemp/Jeff Dowling > RV-6A, N915JD > 165 hours > Chicago/Louisville > ________________________________________________________________________________
Date: Apr 21, 2005
> Why aren't you using it? I remember reading once that Skytec starters and > Lightspeed Electronic ignition systems had compatibility problems. I don't > remember why this was the case or if the problem was or is easily resolved. I believe Sky-Tec is/was worried about kickbacks being caused by electronic ignition systems at lower voltages. i.e. (and I'm pushing my knowledge envelope here, so correct me if I'm wrong) the possibility exists that while cranking, the voltage to the EI would drop, and the EI might go nuts and spark at an inopportune time, causing a kickback. > Anybody have a Skytec and a Lightspeed who can attest to its performance? I have both. Sky-Tec LS flyweight starter and a Lightspeed Plasma II. The only issue I had was with the Sky-Tec solenoid which died around 110 hours. Not related to the EI. I've been running the same starter since with no probs. I learned to carry a spare solenoid (thanks Birdstrike & Rosie) in my tool kit just in case. I'm not saying my experience counts for anything, but you asked. ;-) )_( Dan RV-7 N714D (457 hours) http://www.rvproject.com ________________________________________________________________________________
From: "Vincent Welch" <welchvincent(at)hotmail.com>
Subject: Archer Wingtip Antenna
Date: Apr 21, 2005
Gentlemen, I was looking over the instructions relating to the installation of Archer wingtip antenna. The instructions indicate that the ground plane is formed by placing the edge of the antenna between the wing and the wingtip. This would work fine if the wingtip fit over the wing skin BUT the RV tip fits inside of the skin. For those of you that have installed this type of antenna on the RV series of aircraft, how did you mount it and how did you form the ground plane? Vince RV-8A ________________________________________________________________________________
Date: Apr 21, 2005
Subject: Re: Lightening Holes on the Vertical Stab Spar, HS rivet
opinions? Michael, If you actually take the time to READ the Mil Spec on riveting (no one does) you'll find that you are allowed 1 non conforming rivet in 10. You'll also find that you don't have to have shop heads which are 150% of the rivet's diameter or a shop head which has a height of 50% of the rivet's diameter. Those are the "ideal". The shop head can be as little as 33% of the diameter high and as little as 133% of the rivet's diameter wide. See what your tech councilor says. I suggest you abide by what he/she says. Charlie Kuss ---- MLWynn(at)aol.com wrote: > > Hi all, > > I am starting work on the vertical stab spar. They describe "optional" > lightening holes in the spar reinforcing piece. It doesn't look to me like this > would be a significant weight savings, although it is at the end of a very > long moment arm. What are most people doing with this? > > I am awaiting an inspection by my friend EAA tech counselor this weekend to > look at my horizontal stabilizer. It is almost perfect except for a couple > of small issues. There are a few small scratches in the primer from bucking > rivets. Do most of you go back and touch those up? I have one rivet that is > just slightly proud. I am unsure if taking it out will improve things or > make them worse. Will see what the tech counselor thinks. > > The one I am most worried about is a rivet that holds the front inner rib to > the from spar reinforcement. My first rivet got bent going in. I drilled > it out from the wrong side (shop head) and got a little way into the spar > reinforcement bar. I re-riveted it with the same -4 rivet. You can see a small > defect from my over drilling. I was considering the following options: > 1. Leave it--put in some primer around it. > 2. Drill it out and go with a larger size rivet > 3. Drill it out and put in a small 3/16 bolt. > > Since the hole only goes about 1/3 of the thickness of the spar > reinforcement, I thought it might be okay to leave. I will see what the tech counselor > thinks. Opinions here? > > Regards, > > Michael Wynn > RV8 Empennage > San Ramon, CA > > > > > > ________________________________________________________________________________
Subject: Re: Lightening Holes on the Vertical Stab Spar, HS rivet opinions?
Date: Apr 21, 2005
> I am starting work on the vertical stab spar. They describe "optional" > lightening holes in the spar reinforcing piece. It doesn't look to me like this > would be a significant weight savings, although it is at the end of a very > long moment arm. What are most people doing with this? Do it...my 2 cents is: cut every single optional lightening hole that Van's approves...and cut lightening holes in everything non-structural that you add later. A year or two down the line, when you and a fat buddy are loaded up with full fuel and baggage, you'll wish you cut every hole you were allowed by the designer to cut. I own one RV-7 and two completely different airplanes. The way it feels when loaded is nothing like the way it feels when it's got just me and 15 gallons in it. Now that the plane is done, the only thing I can try to control is the weight of the pilot (I'm workin' on it). Food for thought -- Van's used to ship the steel elevator horns "solid." There wasn't even a callout for lightening holes. Now the standard issue elevator horn has 3 lightening holes pre-cut. When I built my -7 there wasn't even a callout for those VS spar doubler lightening holes. I would have cut 'em in an instant. If Van's says the material is dead weight, you can trust that it is. The only area where I would ADD material over the plans-prescribed specs would be on the engine baffles. Where you can lighten, do lighten! You'll be glad you did. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Apr 21, 2005
On 16:45:06 2005-04-21 wrote: > If you actually take the time to READ the Mil Spec on riveting (no > one does) you'll find that you are allowed 1 non conforming rivet in > 10. True, in a case where you have a row of rivets. However in this case the builder was referring to a rib attachment to a spar, where there are only two or three rivets (I forget which, and don't have my plans handy). In that case, it's one out of two or one out of three, and in either case I would be inclined to replace the bad rivet with the next size up, being very careful to drive the new rivet cleanly... :) -Rob ________________________________________________________________________________
Date: Apr 21, 2005
IVE GOT A 400HP-ITS FRONT&REAR ITS CALLED AN RV-8SP Tom Whelan Whelan Farms Airport President EAA Chapter 1097 wfact01(at)aol.com 249 Hard Hill Road North PO Box 426 Bethlehem, CT 06751 Tel: 203-266-5300 Fax: 202-266-5140 EAA Technical/Flight Advisor RV-8 540 LYC (40 PLUS HOURS) S-51 Mustang Turbine (Under Construction) ________________________________________________________________________________
Date: Apr 21, 2005
I am finishing up the engine baffles and then mount the oil cooler. There are a couple of pieces to paint, label the panel, and then mount the wings. The end is near!! I will be flying this summer "God willing and the creek don't rise." Tom ----- Original Message ----- From: "John Furey" <john(at)fureychrysler.com> Subject: RE: RV-List: wheel pants bracket > > Thanks for the generous offer Tom. I put a patch on the old one that > should > hold for quite a while. How is the plane coming? > > jf > > > ________________________________________________________________________________
Subject: Re: Archer Wingtip Antenna
Date: Apr 21, 2005
Vince, The antenna makes contact with the airframe structure by virtue of the nutplates and screws. The nutplates rivet to the wingtip right onto the antenna "base," whereby the antenna is sandwiched between the wingtip and the nutplates. When screws go through the skin and into the nutplates, the antenna is thus connected to the airframe. What I wondered about was what happens once the wing skin is painted...i.e. if the screws will still make enough contact with the wing skin for this to be functional. So what I did on mine was to use aluminum tape to provide a direct connection between the "inside" of the wing skin and the antenna. A picture or three can illustrate what I'm talking about much better than words: http://www.rvproject.com/20040322.html Remarkably, that cheap aluminum tape I bought from Harbor Freight indeed has enough metal in it to be an electrical conductor. Works great on the Archer NAV antenna, although the Archer COM antenna in the RV-7 sheared wing tip leaves a bit to be desired. There's a fair amount of shadowing by the airframe, and barely enough room to give it vertical polarization. YMMV )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Vincent Welch" <welchvincent(at)hotmail.com> Subject: RV-List: Archer Wingtip Antenna > > Gentlemen, > > I was looking over the instructions relating to the installation of Archer > wingtip antenna. The instructions indicate that the ground plane is formed > by placing the edge of the antenna between the wing and the wingtip. This > would work fine if the wingtip fit over the wing skin BUT the RV tip fits > inside of the skin. > > For those of you that have installed this type of antenna on the RV series > of aircraft, how did you mount it and how did you form the ground plane? > > Vince > RV-8A > > ________________________________________________________________________________
Subject: Air Box
Date: Apr 21, 2005
Not on mine. jf ________________________________________________________________________________
Date: Apr 21, 2005
Anybody have a Skytec and a Lightspeed who can attest to its performance? Used to have the Skytec lightweight and LSE II. The starter crapped out last year on the way to Oshkosh. The housing was cracked and looked like a kickback. The Skytec guy blamed the LSE and said they cause kickbacks during to low voltage conditions. Klaus (Mr. Lightspeed) had a different view, and explained to me in great detail (most of which is forgotten) why his units do not do this. The problem with the Skyweight, IMHO, is that it uses a permanent magnet motor (lighter weight and cheaper) which by their nature draw much higher current during starting than a starter with a wound field motor. Combine this with a small battery (ie. Odessy, Panasonic etc. which many of us use) which just can't keep up with the current demands, and you have a problem. In my case, I had the triple whammy of Flyweight starter, small battery, and wood prop (low inertia) so my plane was never an enthusiastic starter to begin with. The problem was solved by upgrading to a B & C starter, which is a couple pounds heavier (you make up for it by being a couple pounds lighter in the wallet) but uses a wound field motor. I can now get the tail up just on starter power (well, almost.) I was not impressed with Skytec as a company at all, expecially with the way they blame LSE for the problems with their starter. I was able to resolve the issue to my satisfaction, but it took a lot of arm twisting. In fairness to Skytec, they do make a starter with a field wound motor which I'm sure would work just fine, but these are heavier and more expensive. Also in fairness, there are a bunch of the Skytec lightweights out there working just fine. However, there is a difference between a production plane with a 35A huge battery and heavy prop, and a homebuilt with a light prop and small battery. Jeff Point RV-6 Milwaukee WI > > > > ________________________________________________________________________________
Date: Apr 21, 2005
Drill out a few of the wingtip attach nutplates and rivet the antenna in between them and the wingtip. Sam has a write up about this antenna and a picture of this: http://home.hiwaay.net/~sbuc/journal/sportcraft.htm Jeff Point RV-6 Milwaukee WI > > ________________________________________________________________________________
Date: Apr 21, 2005
Dan is basically right. I just ordered my RV-10 Aerosport IO-540 engine today and talked to Bart about it. He recommended getting the HT Sky-Tec starter with my Lightspeed III ignition. I didn't follow it perfectly, but it basically amounted to the voltage dropping when you crank the engine. I don't think he said it caused kickbacks, but maybe just poor starting. Anyway, I'm hoping to use a dual-bus system and run my lightspeed on the essential bus...separated...during starting anyway, along with an instrument or two. Tim Tim Olson -- RV-10 #170 Dan Checkoway wrote: > >>Why aren't you using it? I remember reading once that Skytec starters > > and > >>Lightspeed Electronic ignition systems had compatibility problems. I > > don't > >>remember why this was the case or if the problem was or is easily > > resolved. > > I believe Sky-Tec is/was worried about kickbacks being caused by electronic > ignition systems at lower voltages. i.e. (and I'm pushing my knowledge > envelope here, so correct me if I'm wrong) the possibility exists that while > cranking, the voltage to the EI would drop, and the EI might go nuts and > spark at an inopportune time, causing a kickback. > > >>Anybody have a Skytec and a Lightspeed who can attest to its performance? > > > I have both. Sky-Tec LS flyweight starter and a Lightspeed Plasma II. The > only issue I had was with the Sky-Tec solenoid which died around 110 hours. > Not related to the EI. I've been running the same starter since with no > probs. I learned to carry a spare solenoid (thanks Birdstrike & Rosie) in > my tool kit just in case. > > I'm not saying my experience counts for anything, but you asked. ;-) > > )_( Dan > RV-7 N714D (457 hours) > http://www.rvproject.com > > > > > > ________________________________________________________________________________
Date: Apr 21, 2005
I believe Bob A's intent in the instructions is to rivet the antennal ground element (the short leg) between the inside of the fiberglass tip and the nut plates used for the attach screws that secure the tip to the wing. Ground is provided by the screws through the metal structure to the nutplates and ground leg of the antenna. Dick Sipp ----- Original Message ----- From: "Vincent Welch" <welchvincent(at)hotmail.com> Subject: RV-List: Archer Wingtip Antenna > > Gentlemen, > > I was looking over the instructions relating to the installation of Archer > wingtip antenna. The instructions indicate that the ground plane is > formed > by placing the edge of the antenna between the wing and the wingtip. This > would work fine if the wingtip fit over the wing skin BUT the RV tip fits > inside of the skin. > > For those of you that have installed this type of antenna on the RV series > of aircraft, how did you mount it and how did you form the ground plane? > > Vince > RV-8A > > > ________________________________________________________________________________
Date: Apr 22, 2005
Mine have been working fantastic the way Dick say to mount them. Note that I have 1,655 flying hours. The installation picks up a signal before I can hear the ID. Had KX-125 for 3 years. Replaced with SL-30 past 4 years. As I said, both had nav signal before you could hear the ID. The second Archer Nav antenna runs the Pioneer FM CD/MP3 player installed in the panel. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,655 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: "Richard Sipp" <rsipp(at)earthlink.net> Subject: Re: RV-List: Archer Wingtip Antenna Date: Thu, 21 Apr 2005 21:46:49 -0400 I believe Bob A's intent in the instructions is to rivet the antennal ground element (the short leg) between the inside of the fiberglass tip and the nut plates used for the attach screws that secure the tip to the wing. Ground is provided by the screws through the metal structure to the nutplates and ground leg of the antenna. Dick Sipp ----- Original Message ----- From: "Vincent Welch" <welchvincent(at)hotmail.com> Subject: RV-List: Archer Wingtip Antenna > > Gentlemen, > > I was looking over the instructions relating to the installation of Archer > wingtip antenna. The instructions indicate that the ground plane is > formed > by placing the edge of the antenna between the wing and the wingtip. This > would work fine if the wingtip fit over the wing skin BUT the RV tip fits > inside of the skin. > > For those of you that have installed this type of antenna on the RV series > of aircraft, how did you mount it and how did you form the ground plane? > > Vince > RV-8A ________________________________________________________________________________
Date: Apr 21, 2005
Subject: Edmonton RVators
I am looking for any RV builders in the Edmonton area that could provide some assistance in the next couple of days. I am staying at the Royal Inn Express Hotel in Spruce Grove. 780 962-6050 or Ontario cell phone number 519 217-3111 Thanks Roger Embree My RV-4 is sitting in Villeneuve waiting for some TLC ________________________________________________________________________________
Date: Apr 22, 2005
Hi Dan What you say makes good sense, lighten as much as possible. So, how does one best cut these lightening holes? Circular hole saw on a drill press? Regards, Michael Wynn RV-8, Empennage San Ramon, California ________________________________________________________________________________
Date: Apr 22, 2005
I have a SkyTec and Lightspeed and I ended up changing to a wound field SkyTec and it all works fine. My opinion only but I would use a wound field and not permanent magnet starter with the electronic ignition. I guess in some cases the PM starter with its high inrush current pulls the voltage down below the compliance voltage for the electronic ignition. All works fine now. N89erDD -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Checkoway Subject: Re: RV-List: Fw: I have a Sky-Tec starter for sale > Why aren't you using it? I remember reading once that Skytec starters and > Lightspeed Electronic ignition systems had compatibility problems. I don't > remember why this was the case or if the problem was or is easily resolved. I believe Sky-Tec is/was worried about kickbacks being caused by electronic ignition systems at lower voltages. i.e. (and I'm pushing my knowledge envelope here, so correct me if I'm wrong) the possibility exists that while cranking, the voltage to the EI would drop, and the EI might go nuts and spark at an inopportune time, causing a kickback. > Anybody have a Skytec and a Lightspeed who can attest to its performance? I have both. Sky-Tec LS flyweight starter and a Lightspeed Plasma II. The only issue I had was with the Sky-Tec solenoid which died around 110 hours. Not related to the EI. I've been running the same starter since with no probs. I learned to carry a spare solenoid (thanks Birdstrike & Rosie) in my tool kit just in case. I'm not saying my experience counts for anything, but you asked. ;-) )_( Dan RV-7 N714D (457 hours) http://www.rvproject.com ________________________________________________________________________________
Date: Apr 22, 2005
Mike, Opinions are never in short supply and that goes triple for the good folks in our aviation community, so here's mine. If it were my airplane, I would not hesitate to drill the bad rivet out, clean up the hole to the next nominal diameter, in this case with a #20 drill bit, (better yet, a #22 drill then final reamed with a .160 or .161 reamer), then install an AD-5 rivet. The defect you seem to be describing ..... 1/3 the thickness of the spar reinforcment sounds to me like fertile ground for increasing the chances of a stress fracture to develop. Personally, I would not want to dwell on nagging doubts about a known defect I chose to ignore while bouncing around in turbulent air. One final word........there are tech counselors and there are tech counselors. My first tech counselor visit was with a wood and fabric guy who knew as much about sheet metal work as I do about flying wires. The glowing form he submitted to the EAA was all well and good but in the end, I know in my gut that the session was little more than a paperwork dog and pony show. Find someone who is really experienced in sheet metal work and not just anyone who simply qualifies as a tech counselor. Rick Galati RV-6A "Darla" The one I am most worried about is a rivet that holds the front inner rib to the from spar reinforcement. My first rivet got bent going in. I drilled it out from the wrong side (shop head) and got a little way into the spar reinforcement bar. I re-riveted it with the same -4 rivet. You can see a small defect from my over drilling. I was considering the following options: 1. Leave it--put in some primer around it. 2. Drill it out and go with a larger size rivet 3. Drill it out and put in a small 3/16 bolt. Since the hole only goes about 1/3 of the thickness of the spar reinforcement, I thought it might be okay to leave. I will see what the tech counselor thinks. Opinions here? Regards, Michael Wynn RV8 Empennage San Ramon, CA ________________________________________________________________________________
From: "Stucklen, Frederic W UTPWR" <Fred.Stucklen(at)UTCFuelCells.com>
Date: Apr 22, 2005
Bob, I have a 13 bay classic mounted on the firewall, with a 3" SCAT tube from #4 cylinder. on my RV-6A, O-320-D1A ... I'm finding that it's not getting enough air to sufficiently cool the oil on hot days (OAT > 95*F). Oil temps go up to 230*F under those conditions. When I called the Niagara people about changing coolers, I was told that I should have at least a 4" SCAT tube, preferably a 6". I'm thinking that taking that much air from the top of the engine would introduce engine cooling issues. I'm now considering a NACA vent off the left lower cowl..... Fred Stucklen RV-6A N926RV 375 Hrs Time: From: rv6fly < rv6fly(at)bresnan.net <mailto:rv6fly(at)bresnan.net> > Subject: oil cooling methods > My friend's (Larry), 6A has a firewall mounted oil cooler. I imagine the standard source of cool air for the cooler would be SCAT tubing from the baffle behind cylinder #4. Years ago while helping with another 6A I toyed with the idea of taking the cooling air from a NACA vent on the left side of the cowl with the idea of keeping all of the air coming in the cowl inlet for cylinder cooling instead of bleeding off air behind #4 for the oil cooler. The downside would be having to undo a clamp before being able to drop the bottom cowl. As a lot of my RV knowledge is not up to date, I thought I'd check current thingking on this. Also, what's the latest on mechanical fuel pump cooling and alternator cooling both of which I did when I built my 6. Bob Skinner ________________________________________________________________________________
