RV-Archive.digest.vol-qv
May 04, 2005 - May 12, 2005
      lubrication, it is just that, a myth as I am told. As a mater of fact, I followed
      the advice of a friend who put 2 oz of Marvel Mystry oil in the gas at
      fillup. He had 2400+ on his O-360, untouched when he sold the plane. Charlie
      heathco
Subject: Re: Manifold pressure to primer port
Date: May 04, 2005
They are 1/8" PIPE which has 27 threads per inch Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: "George Inman" <ghinman(at)mts.net> Subject: RV-List: Manifold pressure to primer port > > What did others use to connect > Manifold press. to primer port > Primer fittings are 5/16 32 > but some say to use AN816-4 > Whch is 1/4 inch > The primer port on my > #4 cyl. seems a bit larger than 1/4" > > > GEORGE H. INMAN > ghinman(at)mts.net > CELL 204 799 7062 > HOME 204 287 8334 > > > > > > > ________________________________________________________________________________
Subject: Wiring diagram
Date: May 04, 2005
May have been Bob Nuckoll's - AeroElectric. Many of us have used his and we are very pleased with the results. Check the yeller pages or search for AeroElectic Connection. Good Building, Chuck Rowbotham RV-8A >From: "D Paul Deits" <pdeits(at)comcast.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Wiring diagram >Date: Tue, 3 May 2005 15:11:35 -0700 > > >Earlier this year either as a result of a list entry or reviewing a >lister's site, I reviewed a well thought out wiring diagram. I have >misplaced my copy. Anyone remember the site etc.? > > ________________________________________________________________________________
Subject: Re: Long glide to landing
Date: May 04, 2005
George and all, I sense some misunderstanding. Just to be totally clear about what I advocated in my post. I did not take a pilot up in an airplane unfamiliar to me and pull the mixture to a deadstick landing. I would not do that to another pilot in an airplane that was not my own, and I do not recommend that on a BFR. This is what I said, and what I did. Read carefully... "We pulled the mixture and flew best glide speed and the airplane came down 1000 fpm measured on my watch, not the VSI. The VSI showed about 800 fpm. We found that 1/3 flaps and idle thrust simulated that descent, then we practiced deadstick overhead 360 and 180 approaches to a specific point on the runway, without going short. He did well and I would suspect his chances of successfully making a deadstick landing increased dramatically." Tailwinds, Doug ________________________________________________________________________________
Date: May 04, 2005
From: Chris W <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net>
cgalley wrote: > >They are 1/8" PIPE which has 27 threads per inch > > I thought it is worth noting that just because it is called an "1/8 inch" pipe thread doesn't mean anything is really 1/8 of an inch. Theoretically the ID of the pipe would be 1/8", but in reality, you are not likely to find a 1/8" pipe or fitting where the ID is exactly 1/8" or whatever the size it is called out as. Hear is a quote from page 2 of the www.mcmaster.com on line catalog. " Pipe size does not refer to the inside or outside diameters (ID or OD) of a pipe fitting or pipe. It's the accepted industry designation, not an actual size. When matching pipe OD for male threads and pipe ID for female threads, you need them to have the same pipe size." Their catalog has lots of good information on this and other things it's worth a look just for that kind of information. -- Chris W ________________________________________________________________________________
Subject: RV-7 fuel vent location (fuselage side penetration)
Date: May 04, 2005
1.25 RCVD_NUMERIC_HELO Received: contains an IP address used for HELO I am planning to install the fuel vent line prior to wing mating and cannot find a measurement for the location of the fuel vent bulkhead fitting where it penetrates the side of the fuselage. Can someone please measure if you are at this stage and provide details or would it be wise to delay until wing mating? Regards, Bill Gill RV-7 fuse & finish Lees Summit, MO I am planning to install the fuel vent line prior to wing mating and cannot find a measurement for the location of the fuel vent bulkhead fitting where it penetrates the side of the fuselage. Can someone please measure if you are at this stageand provide details or would it be wise to delay until wing mating? Regards, Bill Gill RV-7 fuse finish Lees Summit, MO ________________________________________________________________________________
Subject: Re: Tip up Canopy Vs. Slider
Date: May 04, 2005
On the RV-6, there is a low pressure area along the side canopy skirts. This is because the fuselage begins to narrow about 1/2 way back along the skirts, and because that area also coincides with the low pressure area above the wing. Flow through ventilation is the problem - air is sucked into the cockpit through every other orifice in the airplane and exhausts around the side skirts. You can cut a piece of foam pipe insulation in half and place it between the slider tracks and the slider skirt to seal the area in flight. I carry a couple of pieces of this stuff with me during cool weather, and it makes a huge difference in the amount of cold air blowing through the cockpit. Adding more "exit" air ventilation would only make the problem worse. KB ======================================== I used 3M mylar door/window "V" strip to seal skirt leaks. Works better than anything else I've tried. P.S. Unless one understand which way the air is flowing.... chances are the direction of the "V" will need to be reversed. Bob ________________________________________________________________________________
Date: May 04, 2005
Subject: Re: Hartzell service and trip report (long)
> God Bless American Aviation Infrastructure! I agree with this. I hope our politicians don't "fix" it out of existence. -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
Date: May 04, 2005
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Subject: Starters
Group, Does anyone have an experience with the Starters for Lycoming engines that are being sold New on ebay? The Starter with the tandem motor... Is there a possible fit issue with the RV cowling? Darrell --------------------------------- ________________________________________________________________________________
Date: May 04, 2005
Pipe size is noted as a "nominal" inside dimension. Example: 1/2" plastic pipe. There are several different wall thickness' but the OD is the same. Next time your at Lowes, Home Depot etc. pick up any schedule 1/2" slip (glue) coupling and try it on sprinkler pipe, schedule 40 & schedule 80 pipe. You'll find that they all fit inside the coupling BUT they all have different wall thickness & therefore different "nominal" inside diameters. (same holds true for 1/2" copper in types "M" , "L" & "K" copper pipe). Tube is sized by OD which is why tube & pipe do not fit together without an adaptor. Pipe threads are tapered, tube threads are not. They are straight cut, no taper. This is the short lesson. KABONG (GBA & GWB) 8*) ----- Original Message ----- From: "Chris W" <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net> Subject: Re: RV-List: Manifold pressure to primer port > <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net> > > cgalley wrote: > >> >>They are 1/8" PIPE which has 27 threads per inch ________________________________________________________________________________
Date: May 04, 2005
Been watching this "thread" with interest. For the last 3 years I've been shutting down over an isolated airport. I wait until the summer so my engine won't cool down quickly. The first time I had the prop completely stopped it was quite a feeling. I would have landed short the first time by a long shot. I had aimed for the middle of the runway and just barely got in down on the threshold. After the first couple of times,a stopped prop doesn't bother you and boy do you learn the glide ratio of an RV this way!! --- Doug Rozendaal wrote: > > > George, > > Thank you for your well thought out post. You make > several good points and > it is clear we disagree. I do not want to argue > your post point by point. > My thesis is this. I believe we have dumbed down > training to accommodate > the low experience level of the instructors doing > the training and the > result is dumber pilots. > > I take a FAR 61.58 checkride every year in > something, sometimes twice a > year, and the FAA requires (Per the ATP PTS) we do a > shutdown, feather, and > restart, every time. I guess the FAA assumes that > if you fly a large > (read over 12,500#) airplane you need more > "realistic" training. I can > assure you that I am much better for that > training/checking. > > The airplane I was flying for the BFR in my post was > a homebuilt and the > pilot had no idea of the sink rate and there was no > book to look in. > > I have done this with several pilots and based on my > experience, the > learning that occurs far outweighs the risk. And > you are absolutely > correct, the risk is mine! With regard to the > risk the mixture cable is > exactly the same type of cable that controls the > throttle and if it failing > is the concern it is exactly the same risk as the > throttle. If the carb is > the concern, the chances of a throttle butterfly > getting jammed are far > greater than the mixture needle valve getting > jammed. I fly 60 year old > airplanes every weekend. Pulling the mixture over a > 3000 feet over 6500 > foot runway is a risk I can live with. > > I see pilots who have learned to fly and > successfully passed FAA checkrides, > and yet have no concept of how fast an airplane > comes down and I continue to > see pilots who think they can turn back from an > engine failure at 500 feet > and land on the runway they departed from. > > I am also a FAR 135 check airmen for the local > Charter service. Recently we > had a Seneca that had runout engines. We lined up > all the Charter pilots, > some are long in the tooth, gray haired, or no > haired types. We went up > high over the airport and shut one down and flew > around on it. I do quite > a bit of training, and I can recognize when learning > occurs. Learning > occurred. These guys got to see for real what > single engine performance was > really like. Not simulated, not numbers on a page, > but numbers on a barely > climbing altimeter in a lightly loaded Seneca. They > got to see the > importance of raising the dead and splitting the > ball. Learning occurred. > The restarts were a real eye-opener. One of the > pilots had recently had a > precautionary shutdown for an oil pressure problem > and he considered a > restart for landing. After a real restart, he said, > "if I had tried to > restart when I planned, I would have never made the > airport." Learning > occurred. > > Is there risk associated with that type of training? > You bet. Is there > reward? Absolutely. Can the risk be mitigated? I > think so. Many ways. A > through briefing. Flying at altitudes that if the > other engines quits we > still would have landed on the airport. The risk > associated with a > shutdown, feather, and restart in a B-25 is probably > 100 fold greater than > pulling the mixture in a light single engine > airplane over a runway. > > I believe the current state of flight training is > terrible. I believe > flight instructors should be required to have 1000's > of hours not a few > hundred. I believe instructors should be paid > similar to other corporate or > airline pilots. (I am not, and do not want to be a > full time flight > instructor, even if the pay was better) In short I > believe there are lots > and lots of pilots out there who do not have a clue > about the airplanes they > are flying, on several subjects, engine failures are > one, but there is one > pilot in Iowa who has a better understanding, and I > believe it was worth the > risk. But then you could find several people who > would say I am one of the > clueless ones ;-) > > Tailwinds, > Doug Rozendaal > > > ----- Original Message ----- > From: <gmcjetpilot(at)yahoo.com> > To: > Subject: RV-List: Re: Long glide to landing > > > > > > > > > >Doug wrote: > > > > >I asked the pilot what the rate of decent was > power off in his airplane. > He said, "I don't >know, I suppose around 500 fpm." > I said we would go up > over the airport and pull the >mixture and find out. > He was concerned about > that. I asked him why? He said "What if >it > doesn't restart?" We land, I > replied. If anyone is concerned in the least about > an engine >failure at > 3000 AGL directly over a 6500 x 250 ft runway they > should not be flying > single >engine airplanes. > > > > > > >If you are not comfortable shutting down your > engine over an airport, > find a > > >flight instructor and go do it ASAP. > Unfortunately most flight > instructors are teaching to >gain experience rather > than share it. If your > flight instructor is unwilling to do it, find a > > >different flight instructor. > > > > > > Doug: > > > > > > The pilot in command is the pilot getting the BFR. > The instructor giving a > BFR to a current pilot is not the PIC. When he said > to you, "What if the > engine does not start?" that was a very valid > question. > > > > > > What if cut-off is used in training and the engine > does not come back in > time or at all? The FAA would rightly blame the CFI. > I think CFIs should > provide realistic training with out undue risk to > the student or yourself. > Doug if you feel it is safe, that is your judgment > call, but I respectively > disagree with your suggestion that a CFI who does > not use idle cutoff is > unworthy some how to teach. > > > > > > You don't have to simulate an emergency with a > real emergency. Regardless > what is under you at the time, loss of power, > intentional or not, in a > single engine airplane is always an emergency. > Pulling mixture in flight has > risks. Not sure what you are advocating, but if you > are suggesting dead > stick landing practice with the mixture in cut-off, > I would say that is > unnecessarily risky, and I know if an accident > resulted the FAA would agree. > I agree at 3000 feet over a long runway and engine > failure should be no > problem. However what if? Vehicle on runway, you > miss judge and the engine > wont fire up? It has happened. > === message truncated == Stay connected, organized, and protected. Take the tour: http://tour.mail.yahoo.com/mailtour.html ________________________________________________________________________________
Subject: Re: try-it-yourself fly-in - was Long glide to landing
Date: May 04, 2005
Best glide speed won't change much but glide ratio will. Best glide speed is a function of airframe performance, mainly the wings. Prop windmilling and prop stopped produce different drags and affect sink rate and gliding distance accordingly. Prop windmilling is higher drag than prop stopped. Another lister pointed out the drag difference to me by comparing a helicopter with rotor windmilling and one with rotor stopped. Which one do you think will come down faster? You have to translate the helicopter windmilling rotor producing lift instead of drag in this case but you get the idea. An autorotating (windmilling) helicopter can in fact land safely. I'll have to leave how much the drag difference is to the experts. Garth Shearing VariEze & 90% RV6A Victoria BC Canada ----- Original Message ----- From: "Doug Gray" <dgra1233(at)bigpond.net.au> Subject: Re: RV-List: try-it-yourself fly-in - was Long glide to landing > > So does best glide speed differ between 'prop windmilling' and 'prop > stopped' glide? > > And if so, by how much? > > Doug Gray ________________________________________________________________________________
Subject: How high have you flown an RV6?
Date: May 04, 2005
I have been wanting to see how high my 6a would go before it quit flying (sans oxy). I took a near new cherokee 180 to little over 14000' before it quit flying a long time ago. I have a stock O-320, and I would imagine the 180hp would go higher, but by how much?? Im sure a few of you at least have tested this. I would like to hear about it (I know, I know, should have oxy over 12500) Charlie heathco ________________________________________________________________________________
Date: May 04, 2005
Subject: Wing Wiring
When wiring wings, do builders tend to put some kind of disconnect for the wiring in the wing root, or do most people feel they will not have to remove the wings after final assemble and just wire directly to wherever the wire go in the fuselage? Thanks, Paul Trotter RV-8 82080 ________________________________________________________________________________
Date: May 04, 2005
Subject: Re: Wing Wiring
In a message dated 5/4/2005 4:53:16 P.M. Pacific Daylight Time, ptrotter(at)acm.org writes: When wiring wings, do builders tend to put some kind of disconnect for the wiring in the wing root, or do most people feel they will not have to remove the wings after final assemble and just wire directly to wherever the wire go in the fuselage? Most people (including ME) just wire directly out of the wing to the fuse. I figure, if I need to remove the wings for any reason, the few wires from the wings are the least of my worries!!! Kim Nicholas RV9A Seattle ________________________________________________________________________________
Date: May 04, 2005
I know Terry Jantzi of Kitchener, Ontario took his 180 hp RV-6 to over 26,000 feet. John L. Danielson EAA Chapter 420 Secretary and Newletter Editor -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Heathco Subject: RV-List: How high have you flown an RV6? I have been wanting to see how high my 6a would go before it quit flying (sans oxy). I took a near new cherokee 180 to little over 14000' before it quit flying a long time ago. I have a stock O-320, and I would imagine the 180hp would go higher, but by how much?? Im sure a few of you at least have tested this. I would like to hear about it (I know, I know, should have oxy over 12500) Charlie heathco ________________________________________________________________________________
Date: May 04, 2005
Paul, I initially planned to install a connector in the wing roots. However, Bob N made the point that every connection is an extra point of failure. Since this area is exposed to the elements, you would need a weather proof connection. It's easier to just wire it without the connector. If you ever have to remove the wings, you can cut the wires and add the connector then. Charlie Kuss > >When wiring wings, do builders tend to put some kind of disconnect for the >wiring in the wing root, or do most people feel they will not have to remove >the wings after final assemble and just wire directly to wherever the wire >go in the fuselage? > > >Thanks, > >Paul Trotter >RV-8 82080 > > ________________________________________________________________________________
Date: May 04, 2005
On 4-May-05, at 5:14 AM, Doug Gray wrote: > > So does best glide speed differ between 'prop windmilling' and 'prop > stopped' glide? > > And if so, by how much? > > Doug Gray > I would expect the drag at a constant windmilling rpm to vary with square of airspeed, like regular profile drag. But, the windmilling rpm should increase with airspeed, and the drag will increase with rpm. So, the windmilling drag should increase at something greater than airspeed squared. So, I would expect that the best glide speed with windmilling prop would be a bit slower than the best glide speed with prop stopped. But, the only way to know for sure is to do some flight testing. Once my RV-8 is flying, I plan to do a full series of glide performance vs speed with idle power, engine off and windmilling prop, and prop stopped. I'll publish the results once I have them. I am many months away from doing this. Kevin Horton Ottawa, Canada RV-8 - Finishing Kit http://www.kilohotel.com/rv8 ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: How high have you flown an RV6?
Date: May 04, 2005
I've had my 160 hp RV6 to 14,000' several times at or near "my" gross weight of 1675 lbs, and have done it on warmer than standard days. At that altitude and weight, it was still climbing reasonably well, but I have never noted the climb rate. My plane has a cruise prop, and that limits rpm for climb at that altitude. At lighter weight, I've had it to 15,000', and was still climbing at 500 fpm. Van's site lists 17,400 and 21,500 feet as the ceiling for a 160 hp RV-6 at light and gross weight, and I think my experience shows that these altitudes are possible. Van's lists 25,700' as the ceiling for a lightly loaded 180 hp RV-6, which is fairly close to the 26,000+ achieved by Terry Jantzi. I guess those folks at Van's know what they are doing after all... ;-) KB ----- Original Message ----- From: "Charles Heathco" <cheathco(at)comcast.net> Subject: RV-List: How high have you flown an RV6? > > I have been wanting to see how high my 6a would go before it quit flying > (sans oxy). I took a near new cherokee 180 to little over 14000' before it > quit flying a long time ago. > I have a stock O-320, and I would imagine the 180hp would go higher, but > by how much?? Im sure a few of you at least have tested this. I would > like to hear about it (I know, I know, should have oxy over 12500) Charlie > heathco > > > ________________________________________________________________________________
Date: May 04, 2005
Years ago, Terry Jantzi of Toronto climbed his 180 hp, C/S, RV-6 to 26,000'. The climb and decent took right at one hour (he said it was really cold up there). Doug Weiler Hudson WI On 5/4/05 6:39 PM, "Charles Heathco" wrote: > > I have been wanting to see how high my 6a would go before it quit flying (sans > oxy). I took a near new cherokee 180 to little over 14000' before it quit > flying a long time ago. > I have a stock O-320, and I would imagine the 180hp would go higher, but by > how much?? Im sure a few of you at least have tested this. I would like to > hear about it (I know, I know, should have oxy over 12500) Charlie heathco > > > > > > ________________________________________________________________________________
Date: May 04, 2005
How about Terry Jantzi's hop to 26,000! I think oxygen might be in order... http://home.hiwaay.net/~sbuc/journal/high.html ----- Original Message ----- From: "Charles Heathco" <cheathco(at)comcast.net> Subject: RV-List: How high have you flown an RV6? > > I have been wanting to see how high my 6a would go before it quit flying (sans oxy). I took a near new cherokee 180 to little over 14000' before it quit flying a long time ago. > I have a stock O-320, and I would imagine the 180hp would go higher, but by how much?? Im sure a few of you at least have tested this. I would like to hear about it (I know, I know, should have oxy over 12500) Charlie heathco > > ________________________________________________________________________________
Date: May 04, 2005
I've cruised my RV-8 at 16,500' a couple of times, and every time was two up. 180 hp c/s. It still climbed at 400-500 fpm getting up there even near gross weight. Randy Lervold > > I have been wanting to see how high my 6a would go before it quit flying (sans oxy). I took a near new cherokee 180 to little over 14000' before it quit flying a long time ago. > I have a stock O-320, and I would imagine the 180hp would go higher, but by how much?? Im sure a few of you at least have tested this. I would like to hear about it (I know, I know, should have oxy over 12500) Charlie heathco > > ________________________________________________________________________________
Date: May 04, 2005
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
At gross I have been to 22,000 in my 180/cs 6A. I was coming through 200ft/min max at the leveloff. The angle of attack was freakin me out so I quit there. Mike -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Heathco Subject: RV-List: How high have you flown an RV6? I have been wanting to see how high my 6a would go before it quit flying (sans oxy). I took a near new cherokee 180 to little over 14000' before it quit flying a long time ago. I have a stock O-320, and I would imagine the 180hp would go higher, but by how much?? Im sure a few of you at least have tested this. I would like to hear about it (I know, I know, should have oxy over 12500) Charlie heathco ________________________________________________________________________________
Date: May 04, 2005
My RV6A went up 17,600-ft in the Rockies and was willing to go higher, but I was too close to positive control so I stopped climbing. 160HP fixed wood prop. I descended at 300FPM to reduce chances of shock cooling, and it took me one-half hour to get down to airport altitude of about 7,500-ft. John at Salida, CO Charles Heathco wrote: > >I have been wanting to see how high my 6a would go before it quit flying (sans oxy). I took a near new cherokee 180 to little over 14000' before it quit flying a long time ago. >I have a stock O-320, and I would imagine the 180hp would go higher, but by how much?? Im sure a few of you at least have tested this. I would like to hear about it (I know, I know, should have oxy over 12500) Charlie heathco > > > > ________________________________________________________________________________
Date: May 04, 2005
Had my 200hp RV-7 cruising around IFR (in VMC) up at FL200 a month ago. Details here: http://www.rvproject.com/20050403.html 20,000' MSL was nothing. It had plenty more oomph to go. I plan on doing a service ceiling test or two once my new O2 system arrives (been on special order for a month). )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Charles Heathco" <cheathco(at)comcast.net> Subject: RV-List: How high have you flown an RV6? > > I have been wanting to see how high my 6a would go before it quit flying (sans oxy). I took a near new cherokee 180 to little over 14000' before it quit flying a long time ago. > I have a stock O-320, and I would imagine the 180hp would go higher, but by how much?? Im sure a few of you at least have tested this. I would like to hear about it (I know, I know, should have oxy over 12500) Charlie heathco > > ________________________________________________________________________________
Date: May 05, 2005
About 7 years ago, I had mine up to 17,800 MSL. Everything forward, 100 KIAS, 300 FPM when I turned around. Weight was around 1,500. Had just refueled at Bowling Green and heading west. I like my Oxygen any time more than one leg starting at 9,500 MSL. Been know to use O2 30 minutes before landing at lower altitudes when flying all day. (2nd leg with flying time 6+ hours for the day.) Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,665 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: "Charles Heathco" <cheathco(at)comcast.net> Subject: RV-List: How high have you flown an RV6? Date: Wed, 4 May 2005 19:39:19 -0400 I have been wanting to see how high my 6a would go before it quit flying (sans oxy). I took a near new cherokee 180 to little over 14000' before it quit flying a long time ago. I have a stock O-320, and I would imagine the 180hp would go higher, but by how much?? Im sure a few of you at least have tested this. I would like to hear about it (I know, I know, should have oxy over 12500) Charlie heathco ________________________________________________________________________________
Date: May 04, 2005
> Good point. However, you can get the rubber? tape that only sticks to > itself and make a connecter pretty near moistureproof! http://www.aircraftspruce.com/catalog/appages/uniwrap.php Cheaper at Spruce than the little spool B&C sells. I use Uni-wrap silicone tape everywhere. Good for much more than electrical stuff. It's my favorite anti-chafe material used all over the place in my plane. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: Response to how high can you fly
Date: May 05, 2005
Wow, I am impressed, had no Idea they would actually go that high and keep flying. I was thinking I would maybe get up to 14000, than drop back down (sans oxy), I think the cherokee 180 was rated at 14500 sevice ceiling, but it wouldnt do it. Thanks for the many responses. Charlie heathco ________________________________________________________________________________
Subject: Re: RV-List:silicone rubber tape
Date: May 05, 2005
Dan, Silicone rubber is usually not very abrasion resistent. How much time do you have on the anti-chafe appications? Dale Ensing ________________________________________________________________________________
From: "Aircraft Technical Book Company" <winterland(at)rkymtnhi.com>
Subject: Re: Response to how high can you fly
Date: May 05, 2005
I often fly up around 15-16,000 with no problems. An RV-6 owner in the hangar next to me says his standard mags starting cutting out in the 18-19,000 range, but when he switched to an electronic system the problem went away and he made it once to around 24,000. Andy ----- Original Message ----- From: "Charles Heathco" <cheathco(at)comcast.net> Subject: RV-List: Response to how high can you fly > > Wow, I am impressed, had no Idea they would actually go that high and keep > flying. I was thinking I would maybe get up to 14000, than drop back down > (sans oxy), I think the cherokee 180 was rated at 14500 sevice ceiling, > but it wouldnt do it. Thanks for the many responses. Charlie heathco > > > ________________________________________________________________________________
Date: May 05, 2005
It would likely do it with a brand new engine in standard atmospheric conditions. RVs tend to be quite overpowered which is the difference. --- Charles Heathco wrote: > > Wow, I am impressed, had no Idea they would actually go that high and keep > flying. I was thinking I would maybe get up to 14000, than drop back down > (sans oxy), I think the cherokee 180 was rated at 14500 sevice ceiling, but > it wouldnt do it. Thanks for the many responses. Charlie heathco ________________________________________________________________________________
Subject: Confusing Engine Claims
Date: May 05, 2005
The next big event in my RV-8A construction saga is choice of an engine. I'm not very knowledgeable about engines, but understand the performance requirements I'm looking for (mainly X/C with a bit of acro when I just can't stand being right side up any more) and have pretty much narrowed the general selection to new, 180 hp, fuel injected. (There are $ advantages to becoming an old fart builder who has saved up some RV bucks over the years). Now it gets a bit confusing. I'm impressed by the technology claims of the Superior XP-360, but also like the stability and reputation of Lycoming. And the Aero Sport folks seem like a delight to deal with. I called Vans and of course got the Lycoming side - even to the point of being told they had never seen a Superior-equipped RV come through there. So I am once again soliciting the usual unbiased opinions of forum participants - in this case, about motors. Are the Superior and Aero Sport products commonly used in RV's? Are the Superior technology claims a worthwhile improvement over Lycoming? I planned on using Vans Firewall Forward kit. Any real-world compatibility experience with the Superior and Aero Sport products? Even if the manufacturer says it's ok, do folks really use auto gas? What are opinions about ignition choices? What other questions would I be asking if I was "more smarter" about this stuff? OBTW - new subject - my QB wings and fuselage were delivered last week by Tony Partain's company - the driver was Paul. What a professional, no-hassle way of kit delivery! No crating; no damage; three of us unloaded the truck in single-digit minutes. I highly recommend it. $1120 to my workshop front door - Vans to Ridgecrest (in the boonies - 60 mi north of Mojave). No crating / no forklift rental charges. Thanks, Paul Valovich Ridgecrest, CA -8A QB ________________________________________________________________________________
Date: May 05, 2005
That was a great report Dan. Thanks for taking the time to add it to your web site. Dick Sipp do not archieve ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV-List: How high have you flown an RV6? > > Had my 200hp RV-7 cruising around IFR (in VMC) up at FL200 a month ago. > Details here: http://www.rvproject.com/20050403.html > > 20,000' MSL was nothing. It had plenty more oomph to go. I plan on doing > a > service ceiling test or two once my new O2 system arrives (been on special > order for a month). > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ----- Original Message ----- > From: "Charles Heathco" <cheathco(at)comcast.net> > To: > Subject: RV-List: How high have you flown an RV6? > > >> >> I have been wanting to see how high my 6a would go before it quit flying > (sans oxy). I took a near new cherokee 180 to little over 14000' before it > quit flying a long time ago. >> I have a stock O-320, and I would imagine the 180hp would go higher, but > by how much?? Im sure a few of you at least have tested this. I would > like > to hear about it (I know, I know, should have oxy over 12500) Charlie > heathco >> >> > > > ________________________________________________________________________________
Date: May 05, 2005
> Dan, > Silicone rubber is usually not very abrasion resistent. How much time do you > have on the anti-chafe appications? > Dale Ensing Just shy of 500 hours and ticking. You're correct, it does wear, but not much. We're not talking about things flailing around here, just very slight amplitude vibration-induced cycles. So if I have to replace 20 cents worth of tape every 1000 hours, so be it. ;-) )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: RE: Starters
Date: May 05, 2005
Hi Darrell, I have two of these black airboat starters from Ebay in both of my rv-4s to replace the heavy starters they had. The starters have worked great so far. They are a lot lighter and spin my props faster. Way cheaper than the Skytec or B&C starters and cant see any difference in performance or weight. When I bought mine from Ebay, he was selling them a lot cheaper but they still are a good price. Am thinking about buying another one to just have as a spare. Regards, Thomas Velvick ________________________________________________________________________________
Date: May 05, 2005
I ran the wires an extra twelve inches or so, so after wing installation the wires reached into the area under the seat inside the fuselage. Easy to get too and out of the weather. ________________________________________________________________________________
Date: May 05, 2005
Subject: Re: altitude
WHAT TAS ARE YA'LL GETTING AT HIGH ALTITUDE? THANKS, DOUG PRESTON RV7 N731RV ________________________________________________________________________________
Subject: To ram air or NOT to ram air -- that is the question
Date: May 05, 2005
I have done some testing recently on my ram air setup, and the results were interesting (at least to me). Here's a comprehensive run-down on ram air, how it has worked on my RV-7, and some recent flight tests and confirmations about the system's performance: http://www.rvproject.com/ramair.html )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: May 05, 2005
Subject: Re: Confusing Engine Claims
At least you are planning on no lower than 180 HP. Good choice. Ron ________________________________________________________________________________
Date: May 05, 2005
At 17,500 in well above standard temperature I can get 160 to 165 knots. RV-6, O-360, fixed pitch Sensenich. http://n5lp.net/day5.htm Have to go to a best power mixture setting to do that though, so not as much fuel saving as would be the case with normal leaning. On 5/5/05 2:01 PM, "DOUGPFLYRV(at)aol.com" wrote: > > WHAT TAS ARE YA'LL GETTING AT HIGH ALTITUDE? Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Date: May 05, 2005
I used a thin wall plastic tube to carry the wiring through the wing ribs and added an extra 2 ft. of this tubing extending inside the inboard root rib. Then (after suitable measurements) I cut matching holes in the fuselage side and fuselage seat ribs to extend the tubing in to the fuselage centerline. There is a junction block there that picks up the wiring from the L&R wings and the fuselage although a simple solder connection would work just as well. This has the best of several worlds: minimizes the wire connections, protects the wiring all the way from fuselage to wing tip, allows the wings to be removed as needed (undo the connections, slide tubing out from fuselage), or conversely will allow the wiring to be replaced with the wings left on. This was all on an RV-6A, BTW. Jim Oke Winnipeg, MB RV-6A C-GKGZ ----- Original Message ----- From: "Paul Trotter" <ptrotter(at)acm.org> Subject: RV-List: Wing Wiring > > When wiring wings, do builders tend to put some kind of disconnect for the > wiring in the wing root, or do most people feel they will not have to > remove > the wings after final assemble and just wire directly to wherever the wire > go in the fuselage? > > > Thanks, > > Paul Trotter > RV-8 82080 > > > ________________________________________________________________________________
Date: May 05, 2005
Subject: Re: RE: Starters
Thanks, I am going to order one up... Darrell tomvelvick(at)cox.net wrote: Hi Darrell, I have two of these black airboat starters from Ebay in both of my rv-4s to replace the heavy starters they had. The starters have worked great so far. They are a lot lighter and spin my props faster. Way cheaper than the Skytec or B&C starters and cant see any difference in performance or weight. When I bought mine from Ebay, he was selling them a lot cheaper but they still are a good price. Am thinking about buying another one to just have as a spare. Regards, Thomas Velvick ________________________________________________________________________________
Subject: Re: To ram air or NOT to ram air -- that is the question
Date: May 05, 2005
Dan, I am curious about your tests but first I appreciate your "hard work" to get the info. What impact does RPM have on the manifold pressures each of your buddies were getting? Example: Number one engine is turning 2700 RPM at WOT, number two engine turning 2600 RPM at WOT, number 3 engine turning 2500 at WOT and finally number 4 engine turning 2400 at WOT. This was probably not the case but illustrated for discussion. Will there be a difference in manifold pressures? This info was not in your web site discussion and may be important info. What difference between CSP and fixed pitch? Thanks again for your work on this project. Vic ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: To ram air or NOT to ram air -- that is the question > > I have done some testing recently on my ram air setup, and the results > were > interesting (at least to me). Here's a comprehensive run-down on ram air, > how it has worked on my RV-7, and some recent flight tests and > confirmations > about the system's performance: > > http://www.rvproject.com/ramair.html > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > > ________________________________________________________________________________
Date: May 05, 2005
Dan, nice write up. I thought I would offer another way to accomplish the same thing... http://www.lazy8.net/intakesystem.htm And, another way to test it, that may only work in mountainous areas... I start on the ground, at my home airport (2V1), at 7650 ft. msl. I note the manifold pressure reading before starting the engine (normally around 22.5"). Then I fly 15 miles south, where the ground level is about 6000 ft msl, and I can fly at 7650, wide open throttle, and read manifold pressure again. The difference is what I call the ram air gain. I also close the valve, and see what the difference is with it closed. I found it interesting that the air pressure in the bottom of the cowl is still higher than ambient. John Huft RV8 "Nuisance" I am working with a fellow in California to go into production on these valves, so we can supply them to builders. Dan Checkoway wrote: > >I have done some testing recently on my ram air setup, and the results were >interesting (at least to me). Here's a comprehensive run-down on ram air, >how it has worked on my RV-7, and some recent flight tests and confirmations >about the system's performance: > >http://www.rvproject.com/ramair.html > >)_( Dan >RV-7 N714D >http://www.rvproject.com > > > > ________________________________________________________________________________
Subject: Duct Tape
Date: May 05, 2005
Hi, We got our RV-8 Emp kit last night and I was wondering if anyone else's kit arrived with Duct Tape holding the metal pieces down in the box. We lost a bit of the plastic coating as we tried to get it all apart for inventory. Thanks, Steph ________________________________________________________________________________
Subject: Re: Duct Tape
Date: May 05, 2005
This is the normal Van's packaging. Don't worry about the plastic. Don > > Hi, > We got our RV-8 Emp kit last night and I was wondering if anyone else's kit > arrived with Duct Tape holding the metal pieces down in the box. > > We lost a bit of the plastic coating as we tried to get it all apart for > inventory. > > Thanks, > Steph > > > > > > ________________________________________________________________________________
Date: May 05, 2005
Yep that's the norm. Whenever possible start peeling the tape from inboard to out to avoid taking off the plastic -- Scott www.scottfarner.com RV-7A Wings On 5/5/05, Stephanie Marshall wrote: > > Hi, > We got our RV-8 Emp kit last night and I was wondering if anyone else's kit arrived with Duct Tape holding the metal pieces down in the box. > > We lost a bit of the plastic coating as we tried to get it all apart for inventory. > > Thanks, > Steph > > > ________________________________________________________________________________
Date: May 05, 2005
Good questions. First of all, when we did the head-to-head test, we were all turning 2700 RPM (or as close to it as possible...I was turning 2670). Regarding tests at lower RPMs, I don't have any hard data on that. I presume you're implying there's a possibility of the ram effect being *greater* when the prop blade angle is greater. i.e. the propeller is providing more compression effect? At some point I'll do some more testing in that regard. My assumption is that the difference won't be measurable in 10ths of inches...maybe even 100ths of inches. I only have a constant speed prop, so I can't speak to the question about fixed pitch stuff. I'm actually trying to think of a single person I know with fixed pitch and fuel injection (horiz. induction)...I can't think of anybody! )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Vic Jacko" <vicwj(at)earthlink.net> Subject: Re: RV-List: To ram air or NOT to ram air -- that is the question > > Dan, I am curious about your tests but first I appreciate your "hard work" > to get the info. > > What impact does RPM have on the manifold pressures each of your buddies > were getting? > > Example: Number one engine is turning 2700 RPM at WOT, number two engine > turning 2600 RPM at WOT, number 3 engine turning 2500 at WOT and finally > number 4 engine turning 2400 at WOT. This was probably not the case but > illustrated for discussion. > > Will there be a difference in manifold pressures? This info was > not in your web site discussion and may be important info. > > What difference between CSP and fixed pitch? > > Thanks again for your work on this project. > > Vic > > > ----- Original Message ----- > From: "Dan Checkoway" <dan(at)rvproject.com> > To: ; > Subject: RV-List: To ram air or NOT to ram air -- that is the question > > > > > > I have done some testing recently on my ram air setup, and the results > > were > > interesting (at least to me). Here's a comprehensive run-down on ram air, > > how it has worked on my RV-7, and some recent flight tests and > > confirmations > > about the system's performance: > > > > http://www.rvproject.com/ramair.html > > > > )_( Dan > > RV-7 N714D > > http://www.rvproject.com > > > > > > > > ________________________________________________________________________________
Date: May 05, 2005
Steph, When I received my RV-8 Empennage kit, S/N 81735 it had the masking tape also. Paul N9NM reserved ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: May 05, 2005
Yeah...all the boxes come that way. No big deal..you really should not leave the plastic coating on too long anyway. I have seen quite a lot of tank skins that have started to oxidize badly where the aluminum supplier prints their name. The ink seems to have some caustic properties when it is all covered up with plastic. You will have to weigh this risk with the potential of hanger rash after the plastic is pulled. I believe Vans also recommends you pull the plastic off. Cheers...Evan Johnson www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ----- Original Message ----- From: "Stephanie Marshall" <smarshall(at)enid.org> Subject: RV-List: Duct Tape > > Hi, > We got our RV-8 Emp kit last night and I was wondering if anyone else's kit arrived with Duct Tape holding the metal pieces down in the box. > > We lost a bit of the plastic coating as we tried to get it all apart for inventory. > > Thanks, > Steph > > ________________________________________________________________________________
Date: May 05, 2005
What is your reference? O-360's? They do not even at a stock configuration put out 180 HP? Darrell Ron Lee wrote: At least you are planning on no lower than 180 HP. Good choice. Ron ________________________________________________________________________________
Date: May 05, 2005
Dan, Excellent article. I'm curious if it is somehow possible to use only the ram air inlet and somehow place a filter in that inlet? Wouldn't this give you a continuous flow of filterd air with no bends, no Y's and still maintain the ram air effect? My appologies if this totally impossible I'm no where close to building my system? Kevin From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: To ram air or NOT to ram air -- that is the question Date: Thu, 5 May 2005 13:16:20 -0700 I have done some testing recently on my ram air setup, and the results were interesting (at least to me). Here's a comprehensive run-down on ram air, how it has worked on my RV-7, and some recent flight tests and confirmations about the system's performance: http://www.rvproject.com/ramair.html )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: May 05, 2005
> > The next big event in my RV-8A construction saga is choice of an engine. > I'm not very knowledgeable about engines, but understand the performance > requirements I'm looking for (mainly X/C with a bit of acro when I just > can't stand being right side up any more) and have pretty much narrowed > the general selection to new, 180 hp, fuel injected. (There are $ > advantages to becoming an old fart builder who has saved up some RV > bucks over the years). > > > Now it gets a bit confusing. I'm impressed by the technology claims of > the Superior XP-360, but also like the stability and reputation of > Lycoming. And the Aero Sport folks seem like a delight to deal with. I > called Vans and of course got the Lycoming side - even to the point of > being told they had never seen a Superior-equipped RV come through > there. > > > So I am once again soliciting the usual unbiased opinions of forum > participants - in this case, about motors. > I think you are a smart person to solict opinions. You will get many to consider I predict. > > Are the Superior and Aero Sport products commonly used in RV's? > I think they are from what is being shared on this list. I am surprised Vans has never seen one come through there. > > Are the Superior technology claims a worthwhile improvement over > Lycoming? > I think they are. Basically they start with a certified bunch of parts that normally go into a Lycoming engine and add a few more and change a few to make a better engine that is not certified, but Superior is working to have theirs certified and that will put Lycoming on defense. I expect Lyc. to come out of their certified shell of uncompetitiveness and offer an experimental engine soon. > > I planned on using Vans Firewall Forward kit. Any real-world > compatibility experience with the Superior and Aero Sport products? > I can say that my new Mattituck TMX-O360 engine fit with everything I got from Vans. I suspect the others will be the same. > > Even if the manufacturer says it's ok, do folks really use auto gas? Check the archives on this. Many do. You can more safely use auto gas if you get lower compression pistons put in your new engine. You probably could use autogas with standard pistons just so you don't go with higher compression pistons. > > > What are opinions about ignition choices? > I like the standard mag on one side for safety and an electronic with variable timing on the other side for performance. > > What other questions would I be asking if I was "more smarter" about > this stuff? > Whether you want fuel injection and/or constant speed prop. These add complexity and cost but have advantages. Consider the risk and benefit of each choice from the Lycoming norm. > > OBTW - new subject - my QB wings and fuselage were delivered last week > by Tony Partain's company - the driver was Paul. What a professional, > no-hassle way of kit delivery! No crating; no damage; three of us > unloaded the truck in single-digit minutes. I highly recommend it. $1120 > to my workshop front door - Vans to Ridgecrest (in the boonies - 60 mi > north of Mojave). No crating / no forklift rental charges. > > Thanks, > > Paul Valovich > > Ridgecrest, CA > > -8A QB ((((((((((())))))))))))))) Indiana Larry, RV7 Tipup, Phase 1 Test flying, TMX-O360 180 HP ________________________________________________________________________________
Subject: New Engine Technology - What would it take?
Date: May 05, 2005
Hello Everyone, I would like to get feedback from this group on a hypothetical. Let's say that a new combustion chamber technology surfaced that was developed by a really brainy person with lots of letters behind his name. Let's also say that the demonstrated efficiency of this combustion chamber technology is double what is currently available. This is to say that an engine that used this combustion chamber technology would operate with a BSFC in the order of .15 to .20 lb/hp/hr. on multiple different fuels. This engine would produce its full rated torque from (not at) 0 rpm and the torque curve would be linear and horizontal meaning that you may not need a constant speed propeller. This engine would operate in an RPM range from ~300 to 3000rpm. It wouldn't need an ignition system and it doesn't retain much heat so a small liquid cooling system would allow you to have heat in the cabin. It is NOT a rotary Wankle engine, an Otto cycle piston engine, a Sterling engine or an axial turbine. The engine would be compact and be available in the exact horsepower you require for your airframe. The engine would only be available as a part of a complete firewall forward package. So here is the question. In your humble opinion(s) what would a company have to demonstrate to you in regard to an aircraft engine based on the above information. What would you have to see in place. What would you have to see demonstrated. What level of comfort would you have to have with the company before you would place your order? Hypothetically! Dave Hertner ________________________________________________________________________________
Date: May 05, 2005
This is quibbling. O-360 is essentially 180 HP versus much bless for an O-320. The point is that starting with a less than large engine on an RV is asking for a later upgrade. Name one person who complained about too much power on an RV and changed the engine to one of less horsepower. Might be such a case but it would be overwhelmingly outnumbered by those who changed to a larger engine. Ron Lee >What is your reference? O-360's? They do not even at a stock configuration >put out 180 HP? > >Darrell > >Ron Lee wrote: > >At least you are planning on no lower than 180 HP. Good choice. > >Ron > > ________________________________________________________________________________
Date: May 05, 2005
No loss. You have to remove it sometime before you rivet it together or paint it. It is to prevent scratches in shipping. Some builders just remove in strips where the parts go together and then remove all before painting. I have heard some have found corrosion under the plastic from moisture getting trapped under the plastic. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: "Stephanie Marshall" <smarshall(at)enid.org> Subject: RV-List: Duct Tape > > Hi, > We got our RV-8 Emp kit last night and I was wondering if anyone else's > kit arrived with Duct Tape holding the metal pieces down in the box. > > We lost a bit of the plastic coating as we tried to get it all apart for > inventory. > > Thanks, > Steph > > > ________________________________________________________________________________
Date: May 05, 2005
Adding anything in-line with the ram air inlet would theoretically reduce manifold pressure. It's arguable whether or not the pressure at the filter in front of the baffle is lower or identical to the pressure available at the ram air inlet. One of these days, maybe I'll remove the filter but keep the ram air inlet closed -- which ought to tell me exactly what the pressure drop across the filter is. For example if it's 25.2" with the filter and 25.4" without the filter (these are out-of-butt numbers), then we can pretty much assume that adding a filter to the ram air inlet would drop manifold pressure roughly 0.2". Big assumptions here...I don't have the answers. Over time I will add data points. )_( Dan ----- Original Message ----- From: "Kevin Williams" <kevinsky18(at)hotmail.com> Subject: RE: RV-List: To ram air or NOT to ram air -- that is the question > > Dan, > > Excellent article. I'm curious if it is somehow possible to use only the > ram air inlet and somehow place a filter in that inlet? Wouldn't this give > you a continuous flow of filterd air with no bends, no Y's and still > maintain the ram air effect? My appologies if this totally impossible I'm > no where close to building my system? > > Kevin > > > From: "Dan Checkoway" <dan(at)rvproject.com> > To: , > Subject: RV-List: To ram air or NOT to ram air -- that is the question > Date: Thu, 5 May 2005 13:16:20 -0700 > > > I have done some testing recently on my ram air setup, and the results were > interesting (at least to me). Here's a comprehensive run-down on ram air, > how it has worked on my RV-7, and some recent flight tests and confirmations > about the system's performance: > > http://www.rvproject.com/ramair.html > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ________________________________________________________________________________
Date: May 05, 2005
Dan, I understand what your say regarding the filter dropping MP. However, I'm thinking there might be some marginal MP to be gained over the current filtered system by getting rid of all the extra ducting and Y connection and going total clean and straight into the intake via the ram air intake. I'm thinking the gain would be marginal but in your article you're really keen on scavanging every little bit that you can. Preformance gains / losses aside is it possible to put a filter inline with the Ram air intake and get rid of the Y connector and related ducting? Kevin From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV-List: To ram air or NOT to ram air -- that is the question Date: Thu, 5 May 2005 18:52:37 -0700 Adding anything in-line with the ram air inlet would theoretically reduce manifold pressure. It's arguable whether or not the pressure at the filter in front of the baffle is lower or identical to the pressure available at the ram air inlet. One of these days, maybe I'll remove the filter but keep the ram air inlet closed -- which ought to tell me exactly what the pressure drop across the filter is. For example if it's 25.2" with the filter and 25.4" without the filter (these are out-of-butt numbers), then we can pretty much assume that adding a filter to the ram air inlet would drop manifold pressure roughly 0.2". Big assumptions here...I don't have the answers. Over time I will add data points. )_( Dan ----- Original Message ----- From: "Kevin Williams" <kevinsky18(at)hotmail.com> Subject: RE: RV-List: To ram air or NOT to ram air -- that is the question > > Dan, > > Excellent article. I'm curious if it is somehow possible to use only the > ram air inlet and somehow place a filter in that inlet? Wouldn't this give > you a continuous flow of filterd air with no bends, no Y's and still > maintain the ram air effect? My appologies if this totally impossible I'm > no where close to building my system? > > Kevin > > > From: "Dan Checkoway" <dan(at)rvproject.com> > To: , > Subject: RV-List: To ram air or NOT to ram air -- that is the question > Date: Thu, 5 May 2005 13:16:20 -0700 > > > I have done some testing recently on my ram air setup, and the results were > interesting (at least to me). Here's a comprehensive run-down on ram air, > how it has worked on my RV-7, and some recent flight tests and confirmations > about the system's performance: > > http://www.rvproject.com/ramair.html > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ________________________________________________________________________________
Date: May 05, 2005
Subject: Re: New Engine Technology - What would it take?
>In your humble opinion(s) what would a company have to demonstrate to you >in regard to an aircraft engine based on the above information. It would have to be in use operationally and show an adequate history of reliability. Putting one unit in a Cessna 172 for 40 hours would not do it for me. Ron Lee ________________________________________________________________________________
Date: May 05, 2005
No "quibbling" here... I guess the same could be said for FP vs CS props? Look at he last aircraft data #'s in the second issue 2005 RVator... just for instance... 180 HP vs 200 HP... This would lead me to believe I wouldn't want a 200 HP period... Darrell Ron Lee wrote: This is quibbling. O-360 is essentially 180 HP versus much bless for an O-320. The point is that starting with a less than large engine on an RV is asking for a later upgrade. Name one person who complained about too much power on an RV and changed the engine to one of less horsepower. Might be such a case but it would be overwhelmingly outnumbered by those who changed to a larger engine. Ron Lee >What is your reference? O-360's? They do not even at a stock configuration >put out 180 HP? > >Darrell > >Ron Lee wrote: > >At least you are planning on no lower than 180 HP. Good choice. > >Ron > > --------------------------------- ________________________________________________________________________________
Date: May 05, 2005
> > The next big event in my RV-8A construction saga is choice of an > engine. > I'm not very knowledgeable about engines, but understand the > performance > requirements I'm looking for (mainly X/C with a bit of acro when I just > can't stand being right side up any more) and have pretty much narrowed > the general selection to new, 180 hp, fuel injected. (There are $ > advantages to becoming an old fart builder who has saved up some RV > bucks over the years). > > > Now it gets a bit confusing. I'm impressed by the technology claims of > the Superior XP-360, but also like the stability and reputation of > Lycoming. And the Aero Sport folks seem like a delight to deal with. I > called Vans and of course got the Lycoming side - even to the point of > being told they had never seen a Superior-equipped RV come through > there. > > > So I am once again soliciting the usual unbiased opinions of forum > participants - in this case, about motors. > > I've got nothing bad to say about any of the engine builders that you mentioned. But I'd offer two comments about Aero Sport Power. 1. When Jon Johanson was getting ready to fly his RV-4 over the North Pole, he wanted to get his engine rebuilt first. He sent it from Australia to Aerosport Power for the rebuild. That says quite a bit about the reputation that Bart Lalonde has for quality work. 2. A local RV builder bought an engine from Aerosport Power. Part way through his flight test program a sudden very large vibration started. He looked at everything he could find on the engine, airframe, prop, spinner, etc, but he couldn't find the problem. The vibration appeared to vary with rpm, so he believed that it was engine related, and that it may be a precursor of an engine failure. Bart Lalonde offered to tear the engine apart to see what was going on. Bart found nothing wrong with the engine, but the builder said he was nervous to put that engine back on his aircraft. Bart built him up a different engine, no charge. It's hard to beat service like that. Kevin Horton Ottawa, Canada RV-8 - Finishing Kit http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: May 05, 2005
> Preformance gains / losses aside is it possible to put a filter inline with > the Ram air intake and get rid of the Y connector and related ducting? Yes, absolutely possible. )_( Dan ________________________________________________________________________________
Date: May 05, 2005
Ram air intakes are a big part of the muscle car scene. I wonder if they've come to the same conclussion that ram air doesn't give them any more power than a normal air intake. If they have come to the same conclusion then it would certainly go a long way to providing further support to debunking the myth of ram air. If however, they are getting better preformance with ram air it would be interesting to study what it is that they are doing to make their ram air systems more efficient. This is a very interesting topic. Thanks for bring it to light Dan. kev From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV-List: To ram air or NOT to ram air -- that is the question Date: Thu, 5 May 2005 19:34:55 -0700 > Preformance gains / losses aside is it possible to put a filter inline with > the Ram air intake and get rid of the Y connector and related ducting? Yes, absolutely possible. )_( Dan ________________________________________________________________________________
Date: May 06, 2005
Part 33 compliance, certification, AND a recommendation from Van's Aircraft. Other wise, NOT INTERESTED even if you PAY me. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,665 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: "Dave Hertner" <effectus(at)rogers.com> Subject: RV-List: New Engine Technology - What would it take? Date: Thu, 5 May 2005 21:40:22 -0700 Hello Everyone, I would like to get feedback from this group on a hypothetical. Let's say that a new combustion chamber technology surfaced that was developed by a really brainy person with lots of letters behind his name. Let's also say that the demonstrated efficiency of this combustion chamber technology is double what is currently available. This is to say that an engine that used this combustion chamber technology would operate with a BSFC in the order of .15 to .20 lb/hp/hr. on multiple different fuels. This engine would produce its full rated torque from (not at) 0 rpm and the torque curve would be linear and horizontal meaning that you may not need a constant speed propeller. This engine would operate in an RPM range from ~300 to 3000rpm. It wouldn't need an ignition system and it doesn't retain much heat so a small liquid cooling system would allow you to have heat in the cabin. It is NOT a rotary Wankle engine, an Otto cycle piston engine, a Sterling engine or an axial turbine. The engine would be compact and be available in the exact horsepower you require for your airframe. The engine would only be available as a part of a complete firewall forward package. So here is the question. In your humble opinion(s) what would a company have to demonstrate to you in regard to an aircraft engine based on the above information. What would you have to see in place. What would you have to see demonstrated. What level of comfort would you have to have with the company before you would place your order? Hypothetically! Dave Hertner ________________________________________________________________________________
Date: May 05, 2005
Hey Paul, I was at Sun and Fun and ordered an engine from Matituk. They will build you an engine with superior parts and ECI cylinders. Plus the will put oil injectors in to lube the cam and lifter bodies. You get the best of both the XP from Superior and the TMX engine from Matituk. You can get it with the light weight plastic (I forget the material name) forward facing cool air induction sump from Superior. Matituk has been around forever and has a great rep. If you want more info, give them a call or email me at rice737(at)msn.com. My friend who is an A&P and building a slow build RV-6 also ordered one at the same time. Take care, Paul RV8QB ----- Original Message ----- From: Valovich, Paul Subject: RV-List: Confusing Engine Claims The next big event in my RV-8A construction saga is choice of an engine. I'm not very knowledgeable about engines, but understand the performance requirements I'm looking for (mainly X/C with a bit of acro when I just can't stand being right side up any more) and have pretty much narrowed the general selection to new, 180 hp, fuel injected. (There are $ advantages to becoming an old fart builder who has saved up some RV bucks over the years). Now it gets a bit confusing. I'm impressed by the technology claims of the Superior XP-360, but also like the stability and reputation of Lycoming. And the Aero Sport folks seem like a delight to deal with. I called Vans and of course got the Lycoming side - even to the point of being told they had never seen a Superior-equipped RV come through there. So I am once again soliciting the usual unbiased opinions of forum participants - in this case, about motors. Are the Superior and Aero Sport products commonly used in RV's? Are the Superior technology claims a worthwhile improvement over Lycoming? I planned on using Vans Firewall Forward kit. Any real-world compatibility experience with the Superior and Aero Sport products? Even if the manufacturer says it's ok, do folks really use auto gas? What are opinions about ignition choices? What other questions would I be asking if I was "more smarter" about this stuff? OBTW - new subject - my QB wings and fuselage were delivered last week by Tony Partain's company - the driver was Paul. What a professional, no-hassle way of kit delivery! No crating; no damage; three of us unloaded the truck in single-digit minutes. I highly recommend it. $1120 to my workshop front door - Vans to Ridgecrest (in the boonies - 60 mi north of Mojave). No crating / no forklift rental charges. Thanks, Paul Valovich Ridgecrest, CA -8A QB ________________________________________________________________________________
Date: May 05, 2005
> >In your humble opinion(s) what would a company have to demonstrate to you > >in regard to an aircraft engine based on the above information. Put it in an RV-4 and fly it around the world a time or two. Show your complete confidence in it's ability to span an ocean and I would look in your direction. Bill ________________________________________________________________________________
Date: May 05, 2005
YEP, a plan "B" and/or an intake with a "Y" in it. N561FS has ram air AND a "Y" that can be opened to draw air from inside the cowl. KABONG Do Not Archive 8*) My assumption is that no matter what system you > build you will have some sort of fresh air by pass. > > > Kevin > ________________________________________________________________________________
Date: May 05, 2005
One more thought to this Ram Air discussion. If you have a direct path to the inside of your engine "A Ram Air Intake", you have several things to think about. The Rocket has a 90 degree adapter to allow ram air to be picked up from a air scoop under the prop. During construction, John Harmon came to visit and I proudly showed him the "Tight" fit between the cowl and the adapter. He then pointed out that what if a kid walked by and dropped a small rock into the air scoop. It would clearly roll down inside the adapter and unseen be ingested on start up. My scoop now has a gap to allow small items to fall through the gap and not go into the engine. Of course, this defeats some of the Ram Air Effect. Of course, that is one of the reasons why, I have the slowest Harmon Rocket flying. Tom Gummo Apple Valley, CA Harmon Rocket-II http://mysite.verizon.net/t.gummo/index.html ----- Original Message ----- From: "JOHN STARN" <jhstarn(at)verizon.net> Subject: Re: RV-List: To ram air or NOT to ram air -- that is the question > > YEP, a plan "B" and/or an intake with a "Y" in it. N561FS has ram air AND > a > "Y" that can be opened to draw air from inside the cowl. KABONG Do Not > Archive 8*) > > My assumption is that no matter what system you >> build you will have some sort of fresh air by pass. >> >> >> Kevin >> > > > ________________________________________________________________________________
Date: May 05, 2005
Affordable and available. Not just empty promises of delivery "real soon", while accepting deposits. Todd Bartrim C-FSTB RV-9endurance 13B Turbo ________________________________________________________________________________
Date: May 06, 2005
> From: "Dave Hertner" <effectus(at)rogers.com> > Subject: RV-List: New Engine Technology - What would it take? > <...> > In your humble opinion(s) what would a company have to demonstrate to you > in regard > to an aircraft engine based on the above information. What would you have > to see in place. What would you have to see demonstrated. What level of > comfort > would you have to have with the company before you would place your order? > Hypothetically! > > Dave Hertner 1. Get off the "hypothetical" bandwagon and show us the plan. "Hypothetical" can translate to "snake oil salesman". 2. Prove the design with extensive testing and use... meaning more than just 50-100 hours of ground running and a handful of flights. How about going for certification? (I'm not against non-certified engines, but this would be a good way to show that the company is serious about what they are doing.) 3. Prove a viable/affordable/sustainable support plan that supports more than just the manufacturers whims and protection of the manufacturer's legal backside. Anything else is just vaporware/dreams/empty promises, and we've already seen enough of that in the aviation industry. -- Alan RV-8 N927AR (reserved) Prepping Horizontal/Vertical Stabilizers for Assembly ________________________________________________________________________________
From: "Alex & Gerry Peterson" <alexpeterson(at)earthlink.net>
Date: May 06, 2005
> Let's say that a new combustion chamber technology surfaced > that was developed by a really brainy person with lots of > letters behind his name. Let's also say that the demonstrated > efficiency of this combustion chamber technology is double > what is currently available. This is to say that an engine > that used this combustion chamber technology would operate > with a BSFC in the order of .15 to .20 lb/hp/hr. on multiple > different fuels. > If someone had this, they would be thinking more about their Gulfstream V's next destination rather than watching this list. Alex Peterson RV6-A 612 hours Maple Grove, MN http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: May 06, 2005
Dan, interesting read on the induction system. I do want to point out one thing, that manifold pressure is a function of ram air pressure at the inlet and how well it is being "exhausted" through the induction system. By that I mean how well the engine is breathing all that air that's presented to it and converting it along with fuel into horsepower. That's why if you run WOT, and back off the RPM without touching the throttle your MP increases. My point here is that the efficiency of the engine will have an effect on indicated MP, so to more accurately describe your tests you should note fuel flow, and do some flying with your buddies at the same fuel flow and rpm, running at a comparable mixture setting. At that point you could compare MP readings. It would be interesting to see if your fuel flow changes between ram air and filtered. One problem with the bendix system IMO is that the servo meters fuel by measuring the pressure drop from the front to the rear of the 'bullet'. That is one of the reasons why I'm going with the RSA10 and cold air induction on the rocket. The larger servo will flow more air around the bullet. Regards, Bob Japundza RV-6 flying 600+ hours F1 under const. ________________________________________________________________________________
Date: May 06, 2005
> One problem with the bendix system IMO is that the servo meters fuel > by measuring the pressure drop from the front to the rear of the > 'bullet'. That is one of the reasons why I'm going with the RSA10 and > cold air induction on the rocket. The larger servo will flow more air > around the bullet. Yep. That's one reason why I went with Airflow Performance instead of Bendix. The servo's throat is huge compared to the stock Bendix servo usually found on my engine. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: Duct Tape
Date: May 06, 2005
Thanks, I think that getting your first emp. is like getting a new baby...you don't know yet what's normal and what isn't. :) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Evan and Megan Johnson Subject: Re: RV-List: Duct Tape Yeah...all the boxes come that way. No big deal..you really should not leave the plastic coating on too long anyway. I have seen quite a lot of tank skins that have started to oxidize badly where the aluminum supplier prints their name. The ink seems to have some caustic properties when it is all covered up with plastic. You will have to weigh this risk with the potential of hanger rash after the plastic is pulled. I believe Vans also recommends you pull the plastic off. Cheers...Evan Johnson www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ----- Original Message ----- From: "Stephanie Marshall" <smarshall(at)enid.org> Subject: RV-List: Duct Tape > > Hi, > We got our RV-8 Emp kit last night and I was wondering if anyone else's kit arrived with Duct Tape holding the metal pieces down in the box. > > We lost a bit of the plastic coating as we tried to get it all apart for inventory. > > Thanks, > Steph > > ________________________________________________________________________________
Subject: LOP and ROP - Lycoming mixture settings
Date: May 06, 2005
Can someone explain how to accurately acheive running a Lycoming at LOP (lean of peak) or ROP (rich of peak)? Suppose I takeoff and climb to 8000 ft. I set the cruise (fixed pitch) to 2300 RPM. Pull out the mixture until observe highest EGT then lean a little more? Is this all this is done? Can someone quantify "a little more". Thanks BobR http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Subject: Hoosier RVers?
Date: May 06, 2005
Got more time on my hands this weekend than I know what to do with (was hoping to go to the Rebel's Bluff Fly-in this weekend, but so far I've been unable to secure a ride) so if anyone is building or flying in or around Indy this weekend, contact me off list. I'd really like to get close and personal with an RV for the first time. It's nice to look at pictures and the DVD from Van's Info kit, but you can only do that for so long before you start getting stir crazy! 765-537-2342 Marty, RV-8a dreamer. ________________________________________________________________________________
Date: May 06, 2005
Well, for starters, how about pointing to a published piece of work - i.e, an SAE paper, a patent description, or an article in any other scientific or engineering journal describing in detail this breakthrough new technology by this person with all the letters behind their name. Phil Stay connected, organized, and protected. Take the tour: http://tour.mail.yahoo.com/mailtour.html ________________________________________________________________________________
Subject: Re: LOP and ROP - Lycoming mixture settings
Date: May 06, 2005
Its not something to try if you don't have balanced injectors and EGT probes for all cylinders. This is because without a balanced induction system there will be a wide spread in mixture between the first cylinder peaking and the last cylinder peaking. If you lean to the point that a single probe egt gauge is telling you that you are LOP, then you may have a different cylinder that is running at peak. Deakins has a great bunch of articles (Pelican's Peak I believe) on this at www.avweb.com. Its great reading. He's also an interesting guy to talk to. There is way more info there than you will probably find here. -- John www.rivetbangers.com - Now with listserv !! www.spikesplace.org/cgi-php/serendipity - Builder's log ________________________________________________________________________________
Date: May 06, 2005
From: Chris W <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net>
bob rundle wrote: > >Can someone explain how to accurately acheive running a Lycoming at LOP >(lean of peak) or ROP (rich of peak)? > >Suppose I takeoff and climb to 8000 ft. I set the cruise (fixed pitch) to >2300 RPM. Pull out the mixture until observe highest EGT then lean a little >more? Is this all this is done? Can someone quantify "a little more". > > My understanding is that, after you get to peak, you lean it till it is 50 degrees below peak for best economy or you richen it till it is 50 degrees below peak for best power. I'm not sure how hard and fast the 50 degree rule is though, it probably varies from engine to engine. -- Chris W ________________________________________________________________________________
Date: May 06, 2005
Hi Rob, If you really want to know, here is an excellent article: http://www.avweb.com/news/columns/182084-1.html Mickey > Can someone explain how to accurately acheive running a Lycoming at LOP > (lean of peak) or ROP (rich of peak)? > > Suppose I takeoff and climb to 8000 ft. I set the cruise (fixed pitch) to > 2300 RPM. Pull out the mixture until observe highest EGT then lean a little > more? Is this all this is done? Can someone quantify "a little more". > -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
Date: May 06, 2005
>Can someone explain how to accurately acheive running a Lycoming at LOP >(lean of peak) or ROP (rich of peak)? This (LOP) may not be possible unless you have fuel injection and something like GAMI injectors. When I lean my carbureted engine, I lean until some roughness develops then back in just enough to be smooth. I believe that it is still ROP. Ron Lee ________________________________________________________________________________
Date: May 06, 2005
Ron, I think you have the one or two of the leanest cylinders running at LOP when you enrichen to smooth things out.. I don't know what the other cylinders are doing other than not running at LOP! IMHO, Vic ----- Original Message ----- From: "Ron Lee" <ronlee(at)pcisys.net> Subject: Re: RV-List: LOP and ROP - Lycoming mixture settings > > >>Can someone explain how to accurately acheive running a Lycoming at LOP >>(lean of peak) or ROP (rich of peak)? > > > This (LOP) may not be possible unless you have fuel injection and > something > like > GAMI injectors. When I lean my carbureted engine, I lean until some > roughness > develops then back in just enough to be smooth. I believe that it is still > ROP. > > Ron Lee > > > ________________________________________________________________________________
Subject: Pneumatic Squeezer Prices as of May '05
Date: May 06, 2005
I am in the market for a Pneumatic Squeezer (C 214 type). I have compiled a list of the prices I have been able to find... anyone else have other sources I can look into (add to the list)? When given the option, I have always priced the squeezer with a 3" yoke. Aircraft Spruce - $487 - 2.5" yoke ATS - $472 - No yoke Avery - $689 - 3" yoke Cleveland - $599 - 3" yoke Brown Tools - $750 - 3" yoke - new Ishams - $549 - 3" yoke - new Pro Rivet Tools - $429 - no yoke US Tool - $330 - yoke? - US114CR (assume rebuilt) US Tool - $625 - yoke? - US114C US Tool - $950 - yoke? - US114CC Yard Store - $349 - 3" yoke - Rebuilt Yard Store - $574 - 3" yoke - US114CC new Then there is always eBay. Cheers, Brad ________________________________________________________________________________
Date: May 06, 2005
I have one to add to this list Clear Air Tools (http://clearairtools.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=CA&Category_Code=PRS) $465.00 Remanufactured with a New 3" yoke and a one year parts and labor warrenty. We are looking at getting one next month from them. Cheers, Stephanie www.rv-8a.4t.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Brad Oliver Subject: RV-List: Pneumatic Squeezer Prices as of May '05 I am in the market for a Pneumatic Squeezer (C 214 type). I have compiled a list of the prices I have been able to find... anyone else have other sources I can look into (add to the list)? When given the option, I have always priced the squeezer with a 3" yoke. Aircraft Spruce - $487 - 2.5" yoke ATS - $472 - No yoke Avery - $689 - 3" yoke Cleveland - $599 - 3" yoke Brown Tools - $750 - 3" yoke - new Ishams - $549 - 3" yoke - new Pro Rivet Tools - $429 - no yoke US Tool - $330 - yoke? - US114CR (assume rebuilt) US Tool - $625 - yoke? - US114C US Tool - $950 - yoke? - US114CC Yard Store - $349 - 3" yoke - Rebuilt Yard Store - $574 - 3" yoke - US114CC new Then there is always eBay. Cheers, Brad ________________________________________________________________________________
Date: May 06, 2005
Vic, you may be right. Without an all cylinder monitoring system it is just quesswork. However I believe that this process is well accepted. Ron Lee >Ron, I think you have the one or two of the leanest cylinders running at >LOP when you enrichen to smooth things out.. > > I don't know what the other cylinders are doing other than not running at >LOP! > >Vic > > When I lean my carbureted engine, I lean until some roughness > > develops then back in just enough to be smooth. I believe that it is still > > ROP. > > > > Ron Lee > > > > ________________________________________________________________________________
Subject: Van's Calendar 2005
Date: May 06, 2005
For those of us that use Van's Calendar, it lists Mother's Day as 15 May. Be advised that Mother's Day is this Sunday May 8th. If you are like me and using the Calendar, you forgot about Mother's Day so you are now scurrying around trying to fix the oversight. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,665 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ________________________________________________________________________________
Subject: Alternator belt size
Date: May 06, 2005
I have one of Van's 60 amp alternators (kit) on an O-360 and need a 30-1/2" v-belt. Can't seem to find any auto parts store that has one! Any suggestions from you guys who have BTDT? Tommy Walker 6A, Finishing the finishing! Ridgetop, TN ________________________________________________________________________________
Date: May 06, 2005
Subject: Training Edge Bending Brake
Hi all I was getting ready to make a bending brake for the trailing edges. Couple of things are unclear, and not addressed in the achives. 1. Length I think the longest trailing edge is something around four feet. Is four feet long enough? 2. Spacer: some folks have described putting a spacer between the boards, I guess so it can't clamp all the way closed. How thick? 3. I understand that I will want to place a 1/8 hardwood dowel at the bend point to provide for the correct 1/16 radius. Any other tips? Regards, Michael Wynn RV-8, Empennage San Ramon, California ________________________________________________________________________________
Date: May 06, 2005
Ebay, Ebay, Ebay I recently bought a genuine Chicago Pneumatic 214 for........., ...........get ready............. . ....................., just $60. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=22664&item=4363032989 This tool has an SRP of $1169 and typically retails for $850 new. Typically, you can get a CP-214 clone on Ebay for about $200, give or take. (There don't seem to be many for sale at this moment, however.) The key to good deals like this is a well thought out search string. For this squeezer, I used the following search string: (squeezer,squeazer,squeezers,squeazers,squeeze,squeaze) (rivet, rivit) Notice I include all the common misspellings. Bad listings are where you will get the best deals because fewer people can find the item to bid on it. I search both the title and the description. PayPal is the safest way to do business on Ebay. My favorite aircraft tool dealer on Ebay is ToolsEZ. You can look at their Ebay store at: http://stores.ebay.com/TOOLSEZ_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm In all honestly, I probably spent the same about of money on tools as I would have had I bought new, but I have about three times as many tools. I'm like Tim Allen when it comes to tools, but Ebay makes it cheap to do. $57. The price included four guns, about 50 tubes, about 40 tips and a variety of nifty smoothing tools. Enough to fill a box 2 ft on a side. I have both a 90 deg 1/4-28 air drill AND a 45 deg 1/4-28 air drill. I have 8 or 9 countersink cages so I can set each one up for a different countersink. I have a big collection of bucking bars. I have an alligator squeezer that has 9 inch deep jaws. Great for dimpling skins. At 04:12 PM 5/6/2005, you wrote: > >I have one to add to this list Clear Air Tools >(http://clearairtools.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=CA&Category_Code=PRS) > >$465.00 Remanufactured with a New 3" yoke and a one year parts and labor >warrenty. > >We are looking at getting one next month from them. > >Cheers, >Stephanie >www.rv-8a.4t.com > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Brad Oliver >To: Rv-List >Subject: RV-List: Pneumatic Squeezer Prices as of May '05 > > >I am in the market for a Pneumatic Squeezer (C 214 type). I have compiled a >list of the prices I have been able to find... anyone else have other >sources I can look into (add to the list)? When given the option, I have >always priced the squeezer with a 3" yoke. > >Aircraft Spruce - $487 - 2.5" yoke >ATS - $472 - No yoke >Avery - $689 - 3" yoke >Cleveland - $599 - 3" yoke >Brown Tools - $750 - 3" yoke - new >Ishams - $549 - 3" yoke - new >Pro Rivet Tools - $429 - no yoke >US Tool - $330 - yoke? - US114CR (assume rebuilt) >US Tool - $625 - yoke? - US114C >US Tool - $950 - yoke? - US114CC >Yard Store - $349 - 3" yoke - Rebuilt >Yard Store - $574 - 3" yoke - US114CC new > >Then there is always eBay. > >Cheers, >Brad > > ________________________________________________________________________________
Date: May 06, 2005
Subject: Re: Training Edge Bending Brake
Michael, You'll need to make it at least 5 feet long for the wing flaps. -- Scott www.scottfarner.com RV-7A Wings On 5/6/05, MLWynn(at)aol.com wrote: > > Hi all > > I was getting ready to make a bending brake for the trailing edges. Couple > of things are unclear, and not addressed in the achives. > 1. Length I think the longest trailing edge is something around four feet. > Is four feet long enough? > 2. Spacer: some folks have described putting a spacer between the boards, I > guess so it can't clamp all the way closed. How thick? > 3. I understand that I will want to place a 1/8 hardwood dowel at the bend > point to provide for the correct 1/16 radius. > > Any other tips? > > Regards, > > Michael Wynn > RV-8, Empennage > San Ramon, California > > > ________________________________________________________________________________
Subject: Re: Alternator belt size
Date: May 06, 2005
----- Original Message ----- From: Tommy Walker Subject: RV-List: Alternator belt size I used a NAPA Premium XL 25-09153/7360 with my 0-360-A1A & Van's 60 amp alternator. It also allows my hand to slip between the alternator and RV6A cowl. >I have one of Van's 60 amp alternators (kit) on an O-360 and need a 30-1/2" v-belt. Can't seem to find any auto parts store that has one! Any suggestions >from you guys who have BTDT? ________________________________________________________________________________
Date: May 06, 2005
> > >In a message dated 5/6/2005 1:34:39 A.M. Central Daylight Time, >khorton01(at)rogers.com writes: > >Bart found nothing >wrong with the engine, but the builder said he was nervous to put that >engine back on his aircraft. Bart built him up a different engine, no >charge. It's hard to beat service like that. > >Kevin Horton >Ottawa, Canada >RV-8 - Finishing Kit >http://www.kilohotel.com/rv8 > >SO, DID THE NEW ENGINE FIX THE PROBLEM?? Well, I am told that there is no more vibration, but it is hard to know whether it was an engine problem, or loose spinner, or prop, as all those were taken off and reinstalled. And maybe he found something else that he is too embarrassed to mention, after all the fuss with the engine. All I know is that he is very satisfied with the service from Bart Lalonde. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: May 06, 2005
Subject: Re: How high have you flown an RV6?
Check Terry Jantzi site: http://home.hiwaay.net/~sbuc/journal/high.html "Final readings from the data logger indicate an absolute altitude reached at 26,137' and level flight was maintained at 25,900'." He states he was at 55kts indicated and 9" MP @2700, on an O-360 (180hp). From his description is below max endurance/range speed and near stall. Est. HP was around 52 HP at 25,900 feet. To note Van's specs the RV-6 with 180 hp with service ceiling of 25,700'. RV-7/RV-8; 180HP Van's spec says 23,000' but does not say this is absolute ceiling or service ceiling. My guess is it is absolute (ie ZERO rate of climb), increase in angle of attack results in decent and no additional hp available. Not sure but also assume Van's numbers are calculated? Service ceiling is a more practical number. For a SE airplane by definition is 100 fpm climb, so this is as high as you can go but not practical. Note of interest alt champ according to Van's specs is a 180HP RV-4 at 28,600 feet. Obviously, max ceiling is a function of available HP and aircraft weight. I never tried for an ultimate ceiling, but did fly my RV-4 150hp solo to 17,500' once. At 17,500' the angle of attack is high and controls gets a little mushy. I don't have fuel flow numbers but recall TAS was about 24 mph slower than 8,500, where I could do 193 mph at 7.8 gal.hr. The max cruise alt I would use on a routine long x-country, if I had O2 and winds were favorable was 14,500'. If I did not hve O2, winds not favorable, hot outside temps or at higher weight (passenger) 8,500-11,500 feet was ideal for long cross-country. I usually flew below 12,500 just because of the lack of O2 on board. One trip I flew solo all day, above 10,000 feet, 3 legs, over 9 hours in cold weather. With out O2 I ended up with a mild headache at the end of the day. I am a non-smoker and in good health. I did not care for the after effect of no O2 all day near the 12,500' legal limit. Even with O2, breathing it all day has a down side, besides cost and weight, there is the drying out of the n asal membrane. Practical cruise altitudes between 8,500-11,500 work best for me, unless terrain is an issue. If you never sniffed O2 in flight it is kind of fun at first but looses its luster real fast. It is not my idea of fun so I plan on flying at or below 12,500 (up to incl 14,000 for less than 30 minutes). What is the purpose of flying high, if not to just set a personal record, than what is the best altitude to fly at? In theory the higher you fly the less drag and better range. However you have to have enough HP to maintain the optimum long range/max range cruise speed. If you want to go as fast as you can, with no regard to fuel burn, 100% power at SL would give max speed and min range. If you want fuel economy and max endurance, fly at reduced power by throttling back, to maintain best glide (L/Dmax), which is max endurance speed. In RVs this is about 93-109 mph at SL. Assume a nominal 100 mph IAS. Max endurance (L/D max) is good if you are just trying to stay aloft longer but not real practical for going somewhere. If you want max range cruise, best mileage, you need to fly faster than max L/D. Optimum cruise is best range , approx best glide speed (L/Dmax) x 1.316 at sea level. Using the average best glide speed (L/Dmax) at SL of 100 mph for a RV, Best range (SL) = 100 mph x 1.316= 132 mph. Factors affecting best range (L/Dmax) speed: -L/Dmax TAS speed goes up with altitude and weight -Indicated AS goes down for the same TAS with altitude. -HP goes down with altitude (normal aspirated) -HP required goes down w/ Alt, for a given speed (not on the back-side of the pwr curve) -Max range speed is affected by L/Dmax and wind To make it easy, the max altitude for efficient (optimal or max range) cruise with a 180 hp Lycoming RV is between power settings of 75% to 51% BHP or 8,500 - 18,000 feet (density alt). Flying higher allows trading speed for fuel economy with in limits. Fly lower or faster at higher weights, short legs and with head-winds. With a tail-wind fly slower (or lower %BHP) and/or higher altitudes. The lower HP model engines will need to operate at slightly lower altitudes (or higher % power) since required total HP is the same to achieve the required speed for a given altitude. Obviously you can fly slow at sea level by pulling the throttle back and saving fuel and extending endurance or range, but by flying at altitude with the equivalent airspeed you can take advantage of lower drag, due to thinner air at the higher altitudes. The RV has "excess HP" and can fly much faster than optimal speed at sea level. RVs have "extra HP" due to a low-drag low-weight airframe, airfoil and relatively high HP engines to start with. Also by flying higher, less dense air will "throttle back" the engine naturally. This has has a side advantage of reduced power while still at WOT, where the throttle plate is in the wide-open position. This allows the engine to breathe easier than when the throttle plate is partially closed, as you would have at low altitudes and partial power settings. The loss from pulling air past the restricted intake from a partially closed throttle butterfly is called pumping loss. It's worth a few HP. Note: Advantage of turbo/turbine engines is the higher HP available at altitude, however the airframe Vne or Vmo, max operating speed, is a function of TAS. So indicated Vne goes down with altitude. This should not be a problem with a non-turbo Lycoming since it can't make enough HP to exceed Vne in climb or cruise. However, if you start a descent from high altitude, you could easily exceed Vne by accident due to a much lower indicated speed than at sea level. With more available HP at altitude using a turbo engine, you could easily exceed Vne in cruise. At very high altitude, Vne and Vstall meet theoretically. This altitude is possible to reach in Jets and is known as the coffin corner, where flying slower will cause a stall, flying faster will exceed Vmo (max Mach) and cause a high speed buffet. The only fix is to descend. At 18,000 you would need to fly at IAS of 122 to 142 MPH for best range. This is about as high as you can fly, and still have enough available HP from a 180HP Lycoming (about 51-53% power) to achieve best range speed in still air. Of course above FL180 you need an IFR clearance, rating and equipment. If you want shorter flight time (higher speed) you would want to fly at 65-75% power, which would be closer to 13,500-9000 feet. A light (solo) RV with 180 HP c/s prop can easily cruise at 17,500' while maintaining long range cruise. There is no advantage in flight range or economy by flying at higher altitudes than FL180 (53% power on a 180HP engine). Lower HP engines and heavy RVs may have a lower optimum altitude. The best cruise altitudes without O2 is closer to 8,500-11,500. Your mileage may vary. Cheers George --------------------------------- Stay connected, organized, and protected. Take the tour ________________________________________________________________________________
Date: May 07, 2005
I suggest you find a store that sells Gates. Buy several, like a 30", 31", 32" or what ever is available around what you measured. Then return the ones that don't fit. Indiana Larry, RV7 Tip Up FLYING - Phase 1 Testing ----- Original Message ----- From: "Tommy Walker" <twsurveyor(at)msn.com> Subject: RV-List: Alternator belt size > > I have one of Van's 60 amp alternators (kit) on an O-360 and need a > 30-1/2" v-belt. Can't seem to find any auto parts store that has one! Any > suggestions from you guys who have BTDT? ________________________________________________________________________________
Date: May 07, 2005
> >Check Terry Jantzi site: http://home.hiwaay.net/~sbuc/journal/high.html > >"Final readings from the data logger indicate an absolute altitude >reached at 26,137' and level flight was maintained at 25,900'." > >He states he was at 55kts indicated and 9" MP @2700, on an O-360 >(180hp). From his description is below max endurance/range speed and >near stall. Est. HP was around 52 HP at 25,900 feet. Actually, the best condition to be at would have been the speed that required the least amount of power, because power was the limiting factor here. The speed that requires the least amount of power is lower than the speed for best L/D, and is theoretically equal to best glide speed divided by 1.316. So Terry was probably not too far off the optimum speed at the light weight he was at. >If you want fuel economy and max endurance, fly at reduced power by >throttling back, to maintain best glide (L/Dmax), which is max >endurance speed. In RVs this is about 93-109 mph at SL. Assume a >nominal 100 mph IAS. Max endurance (L/D max) is good if you are just >trying to stay aloft longer but not real practical for going >somewhere. There seems to be some confusion between jet aircraft and piston aircraft performance. The two types of aircraft have different relationships between speeds for best endurance, best range, and L/D max. See: http://www.professionalpilot.ca/aerodynamics/performance/range_jet.htm http://www.professionalpilot.ca/aerodynamics/performance/range_prop.htm Max endurance is achieved at the speed that produces the lowest fuel flow, which means the speed that requires the least amount of power for a piston engine aircraft. The power required is equal to the drag times the speed (with a few conversion factors thrown in), assuming that the prop efficiency doesn't do something strange. So, the speed for best endurance on a piston engined aircraft is actually slower than the speed for L/D max. >If you want max range cruise, best mileage, you need to fly faster >than max L/D. This is true on a jet aircraft, but not on a piston engined one. With a piston engined aircraft, the speed for max range is the speed for max L/D, assuming that the engine produces the same specific fuel consumption at all power settings, and that the prop efficiency remains constant. In the real world, the engine probably is not quite as efficient at very low power, and the prop may be off its design point, so it efficiency may suffer a bit. These factors would lead to a max range speed a bit higher than speed for max L/D. In practice, the range vs speed curve has quite a flat top, so the range penalty to go a bit faster is quite small. People looking for max range will often target the speed that gives 99% of max range, as giving up on 1% of absolute max range allows the cruise speed to be bumped up quite a bit. >Optimum cruise is best range , approx best glide speed (L/Dmax) x >1.316 at sea level. Using the average best glide speed (L/Dmax) at >SL of 100 mph for a RV, Best range (SL) = 100 mph x 1.316= 132 mph. This is Carson's speed - the speed that gives the lowest fuel flow per unit speed. I.e. a good compromise. Lots more info at: http://www.eaa1000.av.org/technicl/perfspds/perfspds.htm -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: cleco pliers
Date: May 07, 2005
Anybody make cloche style pliers that don't have to be opened so wide to grasp a cloche? I have several misc. manufacturer's pliers and they all have the same grip length. I almost cannot open my hand wide enough to grab a side grip cloche, and would like it to be easier to grab a regular cloche. I thought I'd ask the list before I took the torch to one of mine... They have a useless range of travel at the closed position and have to be opened too wide at the large. Thanks, Dave RV6 near Seattle ----- Original Message ----- From: "LarryRobertHelming" <lhelming(at)sigecom.net> Subject: Re: RV-List: Alternator belt size > > I suggest you find a store that sells Gates. Buy several, like a 30", 31", > 32" or what ever is available around what you measured. Then return the > ones that don't fit. > > Indiana Larry, RV7 Tip Up FLYING - Phase 1 Testing > ----- Original Message ----- > From: "Tommy Walker" <twsurveyor(at)msn.com> > To: "rv-list" > Subject: RV-List: Alternator belt size > > > > > > I have one of Van's 60 amp alternators (kit) on an O-360 and need a > > 30-1/2" v-belt. Can't seem to find any auto parts store that has one! Any > > suggestions from you guys who have BTDT? > > ________________________________________________________________________________
Date: May 07, 2005
Subject: Would appreciate references for pro panel-builders
Cutting & wiring my panel is probably the only thing on the project (other than painting) that I won't care to do myself. I am, at this planning stage, looking to get quotes from shops on a plug-and-play panel with component supplied by me. I would appreciate any references anybody here can give me, as well as maybe some general information on what it might cost me (I'm hoping somewhat less than the standard certified avionics shop rates). For reference, this is the panel I'm planning at this point: 2-screen GRT EFIS (with their EIS 4000) Garmin 300XL IFR GPS Garmin SL-30 Nav/com Garmin 327 transponder PSE 6000 audio panel Analog ASI, Alt, electric TC for IFR backup TruTrak DigiTrak AP (1-axis) Probably an AOA indicator I'm especially interested in custom fiberglass panels for the RV. I think they look better. But that's not a must. I like affordable panels stuff as well. Feel free to contact me off-list if that would be more appropriate. TIA. ________________________________________________________________________________
Subject: Re: cleco pliers
Date: May 07, 2005
Dave: If you are having that much trouble with your cleco pliers, I suggest that you consider buying a pneumatic one from Avery's. It is engaged via a trigger and may be more comfortable for you. Regards, Jeff Orear RV6A N782P Heading to the airport 5/11 Peshtigo, WI ----- Original Message ----- From: "David Burton" <dburton(at)nwlink.com> Subject: RV-List: cleco pliers > > Anybody make cloche style pliers that don't have to be opened so wide to > grasp a cloche? I have several misc. manufacturer's pliers and they all > have the same grip length. I almost cannot open my hand wide enough to > grab > a side grip cloche, and would like it to be easier to grab a regular > cloche. > I thought I'd ask the list before I took the torch to one of mine... They > have a useless range of travel at the closed position and have to be > opened > too wide at the large. > > Thanks, > Dave > RV6 near Seattle > ----- Original Message ----- > From: "LarryRobertHelming" <lhelming(at)sigecom.net> > To: > Subject: Re: RV-List: Alternator belt size > > >> >> >> I suggest you find a store that sells Gates. Buy several, like a 30", > 31", >> 32" or what ever is available around what you measured. Then return the >> ones that don't fit. >> >> Indiana Larry, RV7 Tip Up FLYING - Phase 1 Testing >> ----- Original Message ----- >> From: "Tommy Walker" <twsurveyor(at)msn.com> >> To: "rv-list" >> Subject: RV-List: Alternator belt size >> >> >> > >> > I have one of Van's 60 amp alternators (kit) on an O-360 and need a >> > 30-1/2" v-belt. Can't seem to find any auto parts store that has one! > Any >> > suggestions from you guys who have BTDT? >> >> > > > ________________________________________________________________________________
Subject: Channel caps?
Date: May 07, 2005
What are the rivet callout for the 804 Channel Caps on the RV8? I can't find it on the plans, but I've missed them before too. Thanks Mark finishing all the little stuff. ________________________________________________________________________________
Subject: RV-7 upper spar opening rivets
Date: May 07, 2005
Reference drawing 28 The two corner upper rivets around the spar opening in the fuse for F-704H and side skin call for AN470AD5 rivets. Anyone have experience with these interfering with the wing root fairing/seal? If so, how did you remedy this? Bill RV-7 fuse & finish Lee's Summit, MO ________________________________________________________________________________
Date: May 07, 2005
Subject: Re: Pneumatic Squeezer Prices as of May '05
Please allow me to reinforce the usefulness of Ebay for buying tools - and a friendly raspberry to Bill Dube for giving away the secret to profitable searches. My best score is the 9" alligator squeezer on pedestal stand for pennies on the dollar. Just hold up a skin and dimple away.... Lots of surplus aerospace stuff out there. I would be careful about Toolsez though, while I've probably gotten most of my stuff from them they have stiffed me twice on minor items. Like the pneumatic wire crimper for $9.99 (score) which they shipped without the heads as advertised (loss) and then proceeded to ignore my emails about it. Mike 7a Fuselage planning Snake Oil engine =========== Ebay, Ebay, Ebay I recently bought a genuine Chicago Pneumatic 214 for........., ...........get ready............. . ....................., just $60. ________________________________________________________________________________
Date: May 07, 2005
If you want a closer fit go get a metric belt as they are sized by the CM so they are plus or minus a cm instead of an inch on the circumference. That's less than a 1/3 of a cm as opposed to 1/3 of an inch when you are talking center to center distances. Matched pairs are very easy with metric sized belts. Very expensive with inch sizes. Your 30 1/2 " could be as short as 30 and as long as 31. a 77cm is 30.31 inches while a 78 cm belt is 30.71 inches. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: "LarryRobertHelming" <lhelming(at)sigecom.net> Subject: Re: RV-List: Alternator belt size > > I suggest you find a store that sells Gates. Buy several, like a 30", > 31", > 32" or what ever is available around what you measured. Then return the > ones that don't fit. > > Indiana Larry, RV7 Tip Up FLYING - Phase 1 Testing > ----- Original Message ----- > From: "Tommy Walker" <twsurveyor(at)msn.com> > To: "rv-list" > Subject: RV-List: Alternator belt size > > >> >> I have one of Van's 60 amp alternators (kit) on an O-360 and need a >> 30-1/2" v-belt. Can't seem to find any auto parts store that has one! Any >> suggestions from you guys who have BTDT? > > > ________________________________________________________________________________
Date: May 07, 2005
Thanks for the tips. I've thought about a pneumatic cleco tool, and since I live close to Boeing Surplus I might look for one there. I didn't mention Boeing as a source for air tools to the list since it doesn't help much if you don't live around here... There may be something similar in your area though worth checking out. Boeing has bins of Rockwell right angle pneumatic drills for $75 and rivet guns by the hundreds. I can see that the cleco pliers have lots of wasted travel when closed. I'm going to either find some different ones or modify one of mine... Boeing sometimes has boxes of them for a buck. Easy to experiment with. Sorry about my spell checker changing cleco to chloe. At least the header stayed correct... Dave ________________________________________________________________________________
Date: May 07, 2005
Subject: camera in the tail
Hi Folks to you who have installed a camera in the tail.....the wired version.... What wires did you run for the camera, I guess a 12 volt, maybe a ground, and a coax?? if so, what kind of coax does it require?? try to install the ifra structure without actually buying the camera yet. Thanks Gert -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Subject: Re: RV-7 upper spar opening rivets
Date: May 07, 2005
The rubber of the wing root fairing seal just "gives" in that area and sort of forms to the rivet. You'll never notice it. Press on, you'll be flying soon. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "William Gill" <wgill10(at)comcast.net> Subject: RV-List: RV-7 upper spar opening rivets > > Reference drawing 28 > The two corner upper rivets around the spar opening in the fuse for > F-704H and side skin call for AN470AD5 rivets. Anyone have experience > with these interfering with the wing root fairing/seal? If so, how did > you remedy this? > > Bill > RV-7 fuse & finish > Lee's Summit, MO > > ________________________________________________________________________________
Date: May 07, 2005
Subject: Conversion Coating and Priming with Sanchem
Hi all, Thought I would report back on a different conversion coating. I ordered the 3 part Sanchem 6100 system. Part C is a cleaner/activator. A&B get mixed 1:1. Basically, you scrub the parts with scotchbrite and part C, rinse and immediately brush on or immerse in the A&B stuff. I minute or two later, you have a pretty golden brown conversion coating. It looks exactly like my alondined conversion. I then applied AZKO two part epoxy over the whole thing. Mostly an all day project, but the results are beautiful. The really nice thing about the Sanchem is that it is not toxic or environmentally harmful. Judging from the color of the stuff, I would guess this is a permanganate that reacts with the prepared aluminum to make an AlMn04 coating over the surface. The folks at Sanchem, particularly Jonathon Filcher their technical guy, were very helpful. Will let you know in ten years if the primer remains intact. Anyway, took about the same amount of time as the alodine process, just a lot less toxic. Regards, Michael Wynn RV-8, Empennage San Ramon, California ________________________________________________________________________________
Date: May 07, 2005
Subject: Rude RVers?
Apparently the following RVers visited Clearwater Airpark (CLW) today: N699JB, N99PZ, N515L, N695LS and N628PV. If any of you are on the list, I'd like to hear your side of the story. Apparently managed to piss off a number of people including the flight school owner at the FBO, not following published pattern at airpark, violate St Pete controlled airspace and buzz the neigborhood below minimum altitude, just as a meeting to appease complaining neigbors was about to end. The message I got from the FBO was "they are not welcome back". This does not reflect well on the RV community. Finn Lassen RV-3 Mazda rotary powered ________________________________________________________________________________
Date: May 07, 2005
I did shielded 20 awg for the video, unshielded 20 for the power, and local ground. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: gert [mailto:gert.v(at)sbcglobal.net] > Sent: Saturday, May 07, 2005 8:48 PM > To: RV-8(at)yahoogroups.com > Subject: RV-List: camera in the tail > > > Hi Folks > > to you who have installed a camera in the tail.....the wired > version.... > > What wires did you run for the camera, I guess a 12 volt, > maybe a ground, and a coax?? if so, what kind of coax does > it require?? > > try to install the ifra structure without actually buying the > camera yet. > > Thanks > > Gert > > > -- > > > is subject to a download and archival fee in the amount of $500 > > > Photoshare, and much much more: > > > > > > ________________________________________________________________________________
Date: May 07, 2005
I'm also using the Sanchem products. It's pretty easy to apply and clean up. And I am really happy with it so far. I'm using their seal #2 instead of primer on the internal bits. It puts a coating over the parts that is almost like lacquer or plastic and seems to be very durable. Again, you just rinse and dry after the part a+b solution, brush or spray it on, hit it with a heat gun and it's done in about 30 seconds. For anyone who is interested I have a write up at http://www.froody.org/html/index.php?module=ContentExpress&file=index&func=d isplay&ceid=1&meid=3 and docs and MSDS posted at http://www.froody.org/html/modules.php?op=modload&name=DownloadsPlus&file=in dex&req=viewdownload&cid=3 The MSDS is quite boring as far as MSDS go, which is nice ;) James #40400 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of MLWynn(at)aol.com Subject: RV-List: Conversion Coating and Priming with Sanchem Hi all, Thought I would report back on a different conversion coating. I ordered the 3 part Sanchem 6100 system. Part C is a cleaner/activator. A&B get mixed 1:1. Basically, you scrub the parts with scotchbrite and part C, rinse and immediately brush on or immerse in the A&B stuff. I minute or two later, you have a pretty golden brown conversion coating. It looks exactly like my alondined conversion. I then applied AZKO two part epoxy over the whole thing. Mostly an all day project, but the results are beautiful. The really nice thing about the Sanchem is that it is not toxic or environmentally harmful. Judging from the color of the stuff, I would guess this is a permanganate that reacts with the prepared aluminum to make an AlMn04 coating over the surface. The folks at Sanchem, particularly Jonathon Filcher their technical guy, were very helpful. Will let you know in ten years if the primer remains intact. Anyway, took about the same amount of time as the alodine process, just a lot less toxic. Regards, Michael Wynn RV-8, Empennage San Ramon, California ________________________________________________________________________________
Subject: overtightened pipe fittings?
Date: May 07, 2005
Hi list, I've seen several people warn not to overtighten NPT fittings, but how do you know if you've overtightened one? I was just struggling with my gascolator 45-degree elbow -- it started to snug up just past the proper clocking, so by the time it was back to the right position the torque was quite high. Toward the end I was wondering if I was bending the fitting rather than threading it in, though there is no evidence of this besides some scraped-off anodizing from the wrench. (yes, I used fuellube) I'm also willing to take the steel-fitting plunge (especially since I suspect I screwed up this fitting), but is there a dissimilar-metal problem if I use a steel fitting on the aluminum gascolator? Thanks, Paul RV-9A finishing ________________________________________________________________________________
Date: May 07, 2005
Subject: Re: Rude RVers?
Finn Lassen wrote: > >Apparently the following RVers visited Clearwater Airpark (CLW) today: >N699JB, N99PZ, N515L, N695LS and N628PV. > >If any of you are on the list, I'd like to hear your side of the story. > >Apparently managed to piss off a number of people including the flight >school owner at the FBO, not following published pattern at airpark, >violate St Pete controlled airspace and buzz the neigborhood below >minimum altitude, just as a meeting to appease complaining neigbors was >about to end. The message I got from the FBO was "they are not welcome >back". > >This does not reflect well on the RV community. > >Finn Lassen >RV-3 Mazda rotary powered > > > I know 4 of the 5 on your list and I don't believe they did what you said. I also know that most of them are or were on the RV-List. To characterize any on that list as RUDE is way off the mark. Finn I have to believe that you have the capability to look up who belongs to these airplanes and would have to agree with me. You have been on this list long enough to see most of them post here at one time or another. Jerry ________________________________________________________________________________
Subject: Re: Alternator belt sizeAlternator belt size
Date: May 08, 2005
I somehow missed the orig post, but for what its worth the stock belt is a gates 9335XL, get em at NAPA auto. charlie heathco ________________________________________________________________________________
Date: May 08, 2005
Maybe the ones who made the error should give the FBO, etc. a call and apologize. They may have thought the locals would enjoy what they did, as do most of us who hang out at airports. Sometimes, what we do that's outside the norm isn't appreciated as well as we think. If the person who initiated this thread had the "N" numbers, somebody who told him about it had to have had access to them, somehow. Maybe they were guilty of the crime, even if we think they weren't? We gotta be careful out there! More and more homes are encroaching on airports. Those homes are filled with folks who don't like us. They think most of us are rich guys having our fun at their expense. Jim Sears in KY EAA Tech Counselor EAA Flight Advisor ________________________________________________________________________________
Date: May 08, 2005
Yes, I wish I had been there to see what actually happened... But if St Pete Tower called the FBO to get their N-numbers, something must have happened that would have been out of character with the general RV community. Finn Jerry Springer wrote: > >Finn Lassen wrote: > > > >> >>Apparently the following RVers visited Clearwater Airpark (CLW) today: >>N699JB, N99PZ, N515L, N695LS and N628PV. >> >>If any of you are on the list, I'd like to hear your side of the story. >> >>Apparently managed to piss off a number of people including the flight >>school owner at the FBO, not following published pattern at airpark, >>violate St Pete controlled airspace and buzz the neigborhood below >>minimum altitude, just as a meeting to appease complaining neigbors was >>about to end. The message I got from the FBO was "they are not welcome >>back". >> >>This does not reflect well on the RV community. >> >>Finn Lassen >>RV-3 Mazda rotary powered >> >> >> >> >> >I know 4 of the 5 on your list and I don't believe they did what you >said. I also know that >most of them are or were on the RV-List. To characterize any on that >list as RUDE is way >off the mark. Finn I have to believe that you have the capability to >look up who belongs to >these airplanes and would have to agree with me. You have been on this >list long enough >to see most of them post here at one time or another. > >Jerry > > > > ________________________________________________________________________________
Date: May 08, 2005
Flinn: I know all of them and do not believe it. One of them have been to Clearwater before including last years Open House. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,666 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: Finn Lassen <finn.lassen(at)verizon.net> Subject: RV-List: Rude RVers? Date: Sat, 07 May 2005 23:56:47 -0400 Apparently the following RVers visited Clearwater Airpark (CLW) today: N699JB, N99PZ, N515L, N695LS and N628PV. If any of you are on the list, I'd like to hear your side of the story. Apparently managed to piss off a number of people including the flight school owner at the FBO, not following published pattern at airpark, violate St Pete controlled airspace and buzz the neigborhood below minimum altitude, just as a meeting to appease complaining neigbors was about to end. The message I got from the FBO was "they are not welcome back". This does not reflect well on the RV community. Finn Lassen RV-3 Mazda rotary powered ________________________________________________________________________________
Date: May 08, 2005
Flinn: Just got off the cell phone with the people flying the below N numbers. They talked to the FBO and they tell me they made right traffic like they were suppose to both coming and going. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,666 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: Finn Lassen <finn.lassen(at)verizon.net> Subject: RV-List: Rude RVers? Date: Sat, 07 May 2005 23:56:47 -0400 Apparently the following RVers visited Clearwater Airpark (CLW) today: N699JB, N99PZ, N515L, N695LS and N628PV. If any of you are on the list, I'd like to hear your side of the story. Apparently managed to piss off a number of people including the flight school owner at the FBO, not following published pattern at airpark, violate St Pete controlled airspace and buzz the neigborhood below minimum altitude, just as a meeting to appease complaining neigbors was about to end. The message I got from the FBO was "they are not welcome back". This does not reflect well on the RV community. Finn Lassen RV-3 Mazda rotary powered ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Date: May 08, 2005
Although we might not like the message here, we must all deal with **PERCEPTIONS**, especially at "sensitive" airports. It is good that there was a request for "the other side of the story". I take it that this is done in the spirit of healing. Let's assume our RV friends were 100% in the "right" in everything they did. But if the perception of one or a few "concerned neighbors" in a sensitive neighborhood is that something was not right and they were concerned enough to NOTE THE N-NUMBERS, then there is some "healing" that probably needs to be done by someone. I operate out of an airport that is "in town" and surrounded on two sides by a neighborhood. I serve on a committee that tries to deal with the "Safety Issues" that are perceived by the neighborhood. And I would say that immediate attention would be good. It is not the pilots involved in this matter that will stand to lose so much (unless they are locals) as those that are at the airport in question. I have witnessed incorrect pattern entry (we use Right 13) at our airport that took the planes right over the sensitive neighbors at our airport. I have been there when the FBO got the calls from a certain neighbor and the FBO feels obliged to log the time, action and N-numbers in case there is a further issue. And I have nicely talked to pilots who were not aware of the sensitivities about corrective actions. So far, so good. Maybe one of the pilots (a local??) can fly over and have a sit down with the FBO owner. And be prepared to get an earful, but for the greater good hear the FBO owner out and check to see if anything can be done to help (and I don't mean staying away). Such action would probably benefit us all. James ________________________________________________________________________________
Date: May 08, 2005
I'm sorry, this is a pet peeve of mine. You buy a house near an airport and then complain about the noise? It makes me sick. In orlando a golf community built up south of the airport and THEN the money people got the airport to change its pattern to suite them. I would want to go down there and smack the he!! out of all of them. If you don't like the sound of aircraft, buy a house that isn't next to an airport. If you don't like the sounds of baseball, don't buy next to coors field. If you don't like traffic noise, don't buy next to a major highway. If you have your head so far up your butt that you have to complain about something every day of your life...seek counseling. Ok, maybe I'm venting because of that neighbor behind me whose dog barked ALL night long but still... :-) Good morning RV people. See? I'm trying to be nice. Bill --- sears(at)searnet.com wrote: > > Maybe the ones who made the error should give the FBO, etc. a call and > apologize. They may have thought the locals would enjoy what they did, as > do most of us who hang out at airports. Sometimes, what we do that's > outside the norm isn't appreciated as well as we think. If the person who > initiated this thread had the "N" numbers, somebody who told him about it > had to have had access to them, somehow. Maybe they were guilty of the > crime, even if we think they weren't? We gotta be careful out there! More > and more homes are encroaching on airports. Those homes are filled with > folks who don't like us. They think most of us are rich guys having our fun > at their expense. > > Jim Sears in KY > EAA Tech Counselor > EAA Flight Advisor > > > > > > > __________________________________ http://mobile.yahoo.com/learn/mail ________________________________________________________________________________
Date: May 08, 2005
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Sounds like you might have the same type group at this meeting a lot of airport communities somehow end up with... Whiners. Build an airport and they will come... Darrell Finn Lassen wrote: Apparently the following RVers visited Clearwater Airpark (CLW) today: N699JB, N99PZ, N515L, N695LS and N628PV. If any of you are on the list, I'd like to hear your side of the story. Apparently managed to piss off a number of people including the flight school owner at the FBO, not following published pattern at airpark, violate St Pete controlled airspace and buzz the neigborhood below minimum altitude, just as a meeting to appease complaining neigbors was about to end. The message I got from the FBO was "they are not welcome back". This does not reflect well on the RV community. Finn Lassen RV-3 Mazda rotary powered --------------------------------- Stay connected, organized, and protected. Take the tour ________________________________________________________________________________
Date: May 08, 2005
Subject: Is there interest in an Oct fly-in to Albuquerque, NM?
Another Oct RV fly-in is well attended (I have been three times) but the move to Santa Teresa raises doubts in my mind about parking. The Albuquerque Balloon Fiesta is 30 Sep to 9 Oct and Double Eagle (AEG) is not far from the balloon launch area (at least by air). http://www.balloonfiesta.com/ In addition to more things to do in Albuquerque, Sante Fe NM is close by as well. Is there interest among RV folks to attend a fly-in to coincide with the balloon fiesta? It is probably best to email me directly at ronlee(at)pcisys.net Ron Lee ________________________________________________________________________________
Subject: Rude RVers? (2nd cell phone call)
Date: May 08, 2005
Just got off the cell phone for the second time. The 5 airplanes did the same noise abatment departure that is done at my home airport (CCB) except it was right turns. They departed one right after the other in sequence using full power and best rate of climb. All 5 airplanes are 180 HP and constant speed prop powered. Yes they were heavy with bagagage and two people per airplane and are not going to have the best rate of climb published by Van for solo. They departed runway 34 and made a climbing right 270 degree turn. They passed over the airport at 2,000 feet. The flew west away from the area at 2,500 feet. All 5 airplanes were in the article on page 62 of the April 2005 issue of "Sport Aviation". This time they are on their way to Cayman Islands. How can one fly an RV more quietly that the departure that I was just told by one of the pilots described above? Thanks for letting me know NEVER to fly to Clearwater Airpark. I will go spend my money where it is welcome. Zephyrhills Municipal Airport is $0.97 per gallon cheaper for 100 LL according to AirNav.com and only 35 miles away. I do not see any published noise abatement procedures at http://www.airnav.com/airport/KCLW other than "- NOISE ABATEMENT PROCEDURES IN EFFECT CTC FBO 727-443-3433.". Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,666 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: Finn Lassen <finn.lassen(at)verizon.net> Subject: RV-List: Rude RVers? Date: Sat, 07 May 2005 23:56:47 -0400 Apparently the following RVers visited Clearwater Airpark (CLW) today: N699JB, N99PZ, N515L, N695LS and N628PV. If any of you are on the list, I'd like to hear your side of the story. Apparently managed to piss off a number of people including the flight school owner at the FBO, not following published pattern at airpark, violate St Pete controlled airspace and buzz the neigborhood below minimum altitude, just as a meeting to appease complaining neigbors was about to end. The message I got from the FBO was "they are not welcome back". This does not reflect well on the RV community. Finn Lassen RV-3 Mazda rotary powered ________________________________________________________________________________
Date: May 08, 2005
Finn, Are you saying that St. Pete tower did call the FBO? It would be interesting to hear more of the facts. It would be nice to hear exactly what they are accused of having done. I went to bed thinking that maybe they had screwed up and flew the wrong pattern. Gary says that he spoke to them and they say they flew right traffic. I believe it as these guys are very professional. They may have made a formation arrival and a low pass (I'm supposing now). It is easy to piss off locals around airports, especially during a meeting about noise complaints, even while flying within the letter of the law. Perhaps on a different day, it wouldn't have made such a stink. Knowing these guys, you can bet that they did not set out to be deliberately rude. Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Finn Lassen Subject: Re: RV-List: Rude RVers? Yes, I wish I had been there to see what actually happened... But if St Pete Tower called the FBO to get their N-numbers, something must have happened that would have been out of character with the general RV community. Finn Jerry Springer wrote: > >Finn Lassen wrote: > > > >> >>Apparently the following RVers visited Clearwater Airpark (CLW) today: >>N699JB, N99PZ, N515L, N695LS and N628PV. >> >>If any of you are on the list, I'd like to hear your side of the story. >> >>Apparently managed to piss off a number of people including the flight >>school owner at the FBO, not following published pattern at airpark, >>violate St Pete controlled airspace and buzz the neigborhood below >>minimum altitude, just as a meeting to appease complaining neigbors was >>about to end. The message I got from the FBO was "they are not welcome >>back". >> >>This does not reflect well on the RV community. >> >>Finn Lassen >>RV-3 Mazda rotary powered >> >> >> >> >> >I know 4 of the 5 on your list and I don't believe they did what you >said. I also know that >most of them are or were on the RV-List. To characterize any on that >list as RUDE is way >off the mark. Finn I have to believe that you have the capability to >look up who belongs to >these airplanes and would have to agree with me. You have been on this >list long enough >to see most of them post here at one time or another. > >Jerry > > > > ________________________________________________________________________________
Date: May 08, 2005
> Ok, maybe I'm venting because of that neighbor behind me whose dog barked >ALL night long but still... If you don't like people buy acreage. Every neighborhood has at least one inconsiderate louse. Ron Lee ________________________________________________________________________________
Subject: Re: Rude RVers? (2nd cell phone call)
Date: May 08, 2005
DITTO FOR ME. I gassed up at Zephyr hills during sun n fun. There were several RVs tied down there when I was gassing up. Great place. Self serve. Clearwater can be a private airport if that's what they want as far as I am concerned. Denis Walsh On May 8, 2005, at 11:54 AM, RV6 Flyer wrote: > > Just got off the cell phone for the second time. The 5 airplanes > did the > same noise abatment departure that is done at my home airport > (CCB) except > it was right turns. They departed one right after the other in > sequence > using full power and best rate of climb. All 5 airplanes are 180 > HP and > constant speed prop powered. Yes they were heavy with bagagage and > two > people per airplane and are not going to have the best rate of climb > published by Van for solo. They departed runway 34 and made a > climbing > right 270 degree turn. They passed over the airport at 2,000 > feet. The > flew west away from the area at 2,500 feet. All 5 airplanes were > in the > article on page 62 of the April 2005 issue of "Sport Aviation". > This time > they are on their way to Cayman Islands. > > How can one fly an RV more quietly that the departure that I was > just told > by one of the pilots described above? > > Thanks for letting me know NEVER to fly to Clearwater Airpark. I > will go > spend my money where it is welcome. Zephyrhills Municipal Airport > is $0.97 > per gallon cheaper for 100 LL according to AirNav.com and only 35 > miles > away. > > I do not see any published noise abatement procedures at > http://www.airnav.com/airport/KCLW other than "- NOISE > ABATEMENT PROCEDURES > IN EFFECT CTC FBO 727-443-3433.". > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 1,666 + Flying Hours So. CA, USA > http://SoCAL_WVAF.rvproject.com > > > ----Original Message Follows---- > From: Finn Lassen <finn.lassen(at)verizon.net> > To: rv-list(at)matronics.com.Gecko/20030624.Netscape/7.1 (ax; PROMO) > Subject: RV-List: Rude RVers? > Date: Sat, 07 May 2005 23:56:47 -0400 > > > Apparently the following RVers visited Clearwater Airpark (CLW) today: > N699JB, N99PZ, N515L, N695LS and N628PV. > > If any of you are on the list, I'd like to hear your side of the > story. > > Apparently managed to piss off a number of people including the flight > school owner at the FBO, not following published pattern at airpark, > violate St Pete controlled airspace and buzz the neigborhood below > minimum altitude, just as a meeting to appease complaining neigbors > was > about to end. The message I got from the FBO was "they are not welcome > back". > > This does not reflect well on the RV community. > > Finn Lassen > RV-3 Mazda rotary powered > > ________________________________________________________________________________
Date: May 08, 2005
>Jerry, If there were enough 'issues' to cause the angst, then there must >have been something. Maybe 'rude' wasn't a good word .... but symantics >aside ..... they caused enough grief so that "they are not welcome back". Even this is debatable. There are people who could have seen five planes take off quickly and get upset. So the five may have done nada wrong and are just the recipients of the ire of someone in need of a life. Or maybe there was an honest mistake which was blown out of proportion. And just because one FBO says they are not welcome is not proof that they were wrong. I am not standing up for them. I just don't see any factual information that warrants questioning their actions. In due time we may have facts and can discuss this rationally. Until then, I am complaining that the restaurant that I went to this morning for breakfast was closed. I have a gas receipt worth $2.99 off a breakfast burning a hole in my wallet and I wanted breakfast. This is not right :) Ron Lee ________________________________________________________________________________
Date: May 08, 2005
LIFE CAN BE A BITCH, CAN'T IT RON. DELAYING MY WEST COAST TRIP SO HOPE TO BE AT LOE....SEE YA THERE. DOUG ________________________________________________________________________________
Date: May 08, 2005
if every pilot has your attitude then GA is really in trouble I hope that other pilots show more sensitivity than you do ----- Original Message ----- From: "bill shook" <billshook2000(at)yahoo.com> Subject: Re: RV-List: Rude RVers? > > I'm sorry, this is a pet peeve of mine. You buy a house near an airport and then > complain about the noise? It makes me sick. In orlando a golf community built up south > of the airport and THEN the money people got the airport to change its pattern to suite > them. I would want to go down there and smack the he!! out of all of them. If you > don't like the sound of aircraft, buy a house that isn't next to an airport. If you > don't like the sounds of baseball, don't buy next to coors field. If you don't like > traffic noise, don't buy next to a major highway. If you have your head so far up your > butt that you have to complain about something every day of your life...seek > counseling. Ok, maybe I'm venting because of that neighbor behind me whose dog barked > ALL night long but still... > > :-) Good morning RV people. See? I'm trying to be nice. > > Bill > > > --- sears(at)searnet.com wrote: > > > > Maybe the ones who made the error should give the FBO, etc. a call and > > apologize. They may have thought the locals would enjoy what they did, as > > do most of us who hang out at airports. Sometimes, what we do that's > > outside the norm isn't appreciated as well as we think. If the person who > > initiated this thread had the "N" numbers, somebody who told him about it > > had to have had access to them, somehow. Maybe they were guilty of the > > crime, even if we think they weren't? We gotta be careful out there! More > > and more homes are encroaching on airports. Those homes are filled with > > folks who don't like us. They think most of us are rich guys having our fun > > at their expense. > > > > Jim Sears in KY > > EAA Tech Counselor > > EAA Flight Advisor > > > > > > > > > > > > > > > > > __________________________________ > http://mobile.yahoo.com/learn/mail > > ________________________________________________________________________________
Date: May 08, 2005
Without arguing the particulars of this event at CLW, I have to agree with Bill on this one. There is a huge difference between performing a normal operation during business hours and bringing in a turbojet or large noisy aircraft at 4 am. Complain about the loud flight at 4 am and I am right there with you. Complain about the same flight at noon at an airport that typically has those types of operations and I'll tell you that you really need to go find something else to do, and probably somewhere else to live. It's an airport. It's been there a lot longer than 99% of the surrounding community. There are airplanes, and they make noise. I am all for working with the surrounding communities to reach acceptable noise abatement procedures to both parties. What I don't agree with is people who complain about normal operations and try to get the airport to reduce its hours unreasonably or close or create noise abatement procedures or encroachment that cause safety concerns. James -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of son hoang Subject: Re: RV-List: Rude RVers? if every pilot has your attitude then GA is really in trouble I hope that other pilots show more sensitivity than you do ----- Original Message ----- From: "bill shook" <billshook2000(at)yahoo.com> Subject: Re: RV-List: Rude RVers? > > I'm sorry, this is a pet peeve of mine. You buy a house near an airport and then > complain about the noise? It makes me sick. In orlando a golf community built up south > of the airport and THEN the money people got the airport to change its pattern to suite > them. I would want to go down there and smack the he!! out of all of them. If you > don't like the sound of aircraft, buy a house that isn't next to an airport. If you > don't like the sounds of baseball, don't buy next to coors field. If you don't like > traffic noise, don't buy next to a major highway. If you have your head so far up your > butt that you have to complain about something every day of your life...seek > counseling. Ok, maybe I'm venting because of that neighbor behind me whose dog barked > ALL night long but still... > > :-) Good morning RV people. See? I'm trying to be nice. > > Bill > > > --- sears(at)searnet.com wrote: > > > > Maybe the ones who made the error should give the FBO, etc. a call and > > apologize. They may have thought the locals would enjoy what they did, as > > do most of us who hang out at airports. Sometimes, what we do that's > > outside the norm isn't appreciated as well as we think. If the person who > > initiated this thread had the "N" numbers, somebody who told him about it > > had to have had access to them, somehow. Maybe they were guilty of the > > crime, even if we think they weren't? We gotta be careful out there! More > > and more homes are encroaching on airports. Those homes are filled with > > folks who don't like us. They think most of us are rich guys having our fun > > at their expense. > > > > Jim Sears in KY > > EAA Tech Counselor > > EAA Flight Advisor > > > > > > > > > > > > > > > > > __________________________________ > http://mobile.yahoo.com/learn/mail > > ________________________________________________________________________________
Date: May 08, 2005
In a message dated 5/8/2005 10:32:44 AM Central Standard Time, billshook2000(at)yahoo.com writes: I'm sorry, this is a pet peeve of mine. You buy a house near an airport and then complain about the noise? It makes me sick. In orlando a golf community built up south of the airport and THEN the money people got the airport to change its pattern to suite them RIGHT ON !!!!!!! ________________________________________________________________________________
Date: May 08, 2005
I appreciate all the replies. Unfortunately I was only relaying what I was told - probably never a good idea. Yes, it was my understanding that they did encroach on St Pete's airspace and that Tower called the FBO for the N-numbers. I probably chose a bad subject line. Maybe "inconsiderate?" would have been better? But do note the question mark:) There was a remark from the flight school owner that they had been rude to "Brian". No idea who Brian is - the line boy? It's beginning to sound like they just were at the wrong place at the wrong (worst) time, doing a formation break for landing over the exact neigborhood where a plane (not a home built) crashed into a house a month or so ago, were a meeting between the airport manager and a neighborhood group was taking place. Yes, KCLW is (now) in the middle of Clearwater. The fact that it was there first is generally lost on people. The reason I wrote the original posting was that as I entered the FBO late yesterday afternoon I was greeted by the flight school owner who commenced telling me what I relayed in my first posting. I can see both sides of the argument but sure would like to tell complaining neighbors to go take a f... My concern is that I'd like to continue to be based there, at least for a few more years. What is OK at an airport open house may not be considered OK during normal operation. I guess a good rule of thumb would be to be extra careful when entering any small airport in the middle of any city or town, if not familiar with any sensitive issues. From what Gary wrote, they did indeed take care during departure. Finn Ed Holyoke wrote: > >Finn, > >Are you saying that St. Pete tower did call the FBO? It would be >interesting to hear more of the facts. It would be nice to hear exactly >what they are accused of having done. > >I went to bed thinking that maybe they had screwed up and flew the wrong >pattern. Gary says that he spoke to them and they say they flew right >traffic. I believe it as these guys are very professional. They may have >made a formation arrival and a low pass (I'm supposing now). It is easy >to piss off locals around airports, especially during a meeting about >noise complaints, even while flying within the letter of the law. >Perhaps on a different day, it wouldn't have made such a stink. Knowing >these guys, you can bet that they did not set out to be deliberately >rude. > >Pax, > >Ed Holyoke > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Finn Lassen >To: ax; PROMO >Subject: Re: RV-List: Rude RVers? > > >Yes, I wish I had been there to see what actually happened... >But if St Pete Tower called the FBO to get their N-numbers, something >must have happened that would have been out of character with the >general RV community. > >Finn > >Jerry Springer wrote: > > > >> >>Finn Lassen wrote: >> >> >> >> >> >>> >>>Apparently the following RVers visited Clearwater Airpark (CLW) today: >>>N699JB, N99PZ, N515L, N695LS and N628PV. >>> >>>If any of you are on the list, I'd like to hear your side of the >>> >>> >story. > > >>>Apparently managed to piss off a number of people including the flight >>> >>> > > > >>>school owner at the FBO, not following published pattern at airpark, >>>violate St Pete controlled airspace and buzz the neigborhood below >>>minimum altitude, just as a meeting to appease complaining neigbors >>> >>> >was > > >>>about to end. The message I got from the FBO was "they are not welcome >>> >>> > > > >>>back". >>> >>>This does not reflect well on the RV community. >>> >>>Finn Lassen >>>RV-3 Mazda rotary powered >>> >>> >>> >>> >>> >>> >>> >>I know 4 of the 5 on your list and I don't believe they did what you >>said. I also know that >>most of them are or were on the RV-List. To characterize any on that >> >> > > > >>list as RUDE is way >>off the mark. Finn I have to believe that you have the capability to >>look up who belongs to >>these airplanes and would have to agree with me. You have been on this >>list long enough >>to see most of them post here at one time or another. >> >>Jerry >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: May 08, 2005
Yes Gary, I would much rather be based at ZPH. However CLW is only 3 miles from my home. Can't wait to build my new home at "my own" strip - Shady Bend (9FL5). But would probably still have to fly to CLW to go to work :( Finn RV6 Flyer wrote: >Thanks for letting me know NEVER to fly to Clearwater Airpark. I will go >spend my money where it is welcome. Zephyrhills Municipal Airport is $0.97 >per gallon cheaper for 100 LL according to AirNav.com and only 35 miles >away. >... > > ________________________________________________________________________________
Date: May 08, 2005
The Safety data sheet that James posted below states "SafeGard CC-6100 leaves a highly corrosion resistant and adherent surface". My question is, why prime over this at all, if it is "highly corrosion resistant"? Where does one purchase some of this stuff? Marty in Brentwood TN From: "James Ochs" <jochs(at)froody.org> Subject: RE: RV-List: Conversion Coating and Priming with Sanchem I'm also using the Sanchem products. It's pretty easy to apply and clean up. And I am really happy with it so far. I'm using their seal #2 instead of primer on the internal bits. It puts a coating over the parts that is almost like lacquer or plastic and seems to be very durable. Again, you just rinse and dry after the part a+b solution, brush or spray it on, hit it with a heat gun and it's done in about 30 seconds. For anyone who is interested I have a write up at http://www.froody.org/html/index.php?module=ContentExpress&file=index&func=d isplay&ceid=1&meid=3 and docs and MSDS posted at http://www.froody.org/html/modules.php?op=modload&name=DownloadsPlus&file=in dex&req=viewdownload&cid=3 The MSDS is quite boring as far as MSDS go, which is nice ;) James #40400 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of MLWynn(at)aol.com Subject: RV-List: Conversion Coating and Priming with Sanchem Hi all, Thought I would report back on a different conversion coating. I ordered the 3 part Sanchem 6100 system. Part C is a cleaner/activator. A&B get mixed 1:1. Basically, you scrub the parts with scotchbrite and part C, rinse and immediately brush on or immerse in the A&B stuff. I minute or two later, you have a pretty golden brown conversion coating. It looks exactly like my alondined conversion. I then applied AZKO two part epoxy over the whole thing. Mostly an all day project, but the results are beautiful. The really nice thing about the Sanchem is that it is not toxic or environmentally harmful. Judging from the color of the stuff, I would guess this is a permanganate that reacts with the prepared aluminum to make an AlMn04 coating over the surface. The folks at Sanchem, particularly Jonathon Filcher their technical guy, were very helpful. Will let you know in ten years if the primer remains intact. Anyway, took about the same amount of time as the alodine process, just a lot less toxic. Regards, Michael Wynn RV-8, Empennage San Ramon, California ________________________________________________________________________________
Subject: All these virus messages....
Date: May 08, 2005
I don't know about everyone else, but I'm now getting around 20-50 of these fake messages everyday along with the RV mail. The latest is from serviceVansAircraft, which means their computer is infected also. Subject line is usually : mailing error, Re, FWD Re, Your password, or Email was blocked. This virus was caught by my computers McAfee Anti Virus, but then I've never opened the attachments either. It's more of an annoying virus than anything else. Once in your computer, it sends out these messages to everyone on your address book. Spreads like wildfire, from what I'm seeing. L.Adamson ________________________________________________________________________________
Subject: Re: All these virus messages....
Date: May 08, 2005
I sorry but even though it says it is from Van's...It probably isn't. It is called spoofing when the virus takes one address out of someone's address book and uses another as the source. But probably it is someone that has accessed van's and your computer and the is no way to know where is came from as it is done randomly. If you keep your computer virus free, that is about the best you can do. Cy Galley - Webmaster www.qcbc.org ----- Original Message ----- From: "LARRY ADAMSON" <rvhi03(at)msn.com> Subject: RV-List: All these virus messages.... > > > I don't know about everyone else, but I'm now getting around 20-50 of > these fake messages everyday along with the RV mail. The latest is from > serviceVansAircraft, which means their computer is infected also. Subject > line is usually : mailing error, Re, FWD Re, Your password, or Email was > blocked. > > This virus was caught by my computers McAfee Anti Virus, but then I've > never opened the attachments either. It's more of an annoying virus than > anything else. Once in your computer, it sends out these messages to > everyone on your address book. Spreads like wildfire, from what I'm > seeing. > > L.Adamson > > > ________________________________________________________________________________
Date: May 08, 2005
----- Original Message ----- From: Mark Grieve Subject: Re: RV-List: All these virus messages.... Larry, Do you know the name of the virus? I tried to figure it out from the subject lines you mentioned but didn't come up with anything definite. Sounds like a virus that Norton is calling Sober. I'm not sure what McAfee named it. It has a new variant and is causing a lot of headaches lately. It's listed as W32/Sober, first detected on 5/2/2005 And just to make it clear, it doesn't generate from the RV list, but several addresses from this list as well as Van's, parts suppliers, etc. have appeared as the E-mail originator, even though it's all bogus. Off course, IMO, a bit of "jail" time would serve well for these people who write viruses that disrupt every day commerce. This one could tend to jam mail boxes everywhere, let alone spending company time to discover what's legit and what isn't. L.Adamson ________________________________________________________________________________
Date: May 08, 2005
>Simply turn the pliers around... Thanks John, I gave that a try and it helps a lot. Just to clarify my "problem". I don't really have small hands, a medium glove is the right size for me. I've been running cleco pliers since about 1999 and I don't even think about using them to grab a cleco, they just do it... My hands are not getting tired for the most part. What I find frustrating is when I've got a handfull of parts that I'm trying to hold in alignment to put in a cleco. Especially with the side grip clecos I find it difficult to open the pliers up wide enough to pick up the cleco one handed, in fact I can't do it at all with my left hand. When I can use both hands it's not a problem. I see that there is almost half an inch of unused travel when first opening the pliers. If I could gain that much usable travel I think that would solve the issue. I looked at all my pliers, all bought at different times and places and coincidentally they all are USATCO brand. I'm wondering if another brand might have different handles or a different pivit point... Thanks for all the suggestions.. Dave ________________________________________________________________________________
Date: May 08, 2005
Subject: Solenoid installation/wire routing
Hi All, I have recently had the opportunity to disassembly the firewall forward electrical wiring on a RV-6A and a RV-6. In both installations, the starter solenoid was mounted on the front side of the firewall. In both cases, the large wire from the master solenoid going to the starter solenoid was chaffing against the corner of an aluminum bracket. The wire insulation was worn more than half way through to the copper wire. (48 hours TT on one installation, and the copper was visible through the insulation.) Please, take a little extra care with this large wire. With the master switch on, it's hot all the way to the starter solenoid. Regards, Jim Ayers PS I relocated the master and starter solenoids directly over the battery box in my RV-6A. The starter wire going through the firewall is only hot when the starter is engaged. ________________________________________________________________________________
Date: May 09, 2005
Subject: Re: Conversion Coating and Priming with Sanchem
Hey Marty, The answer is that this is a conversion coating, so it is about two or three molecules thick and needs to be protected with either their clear sealer or a traditional primer. Here is the link: http://www.sanchem.com/ Regards, Michael Wynn RV-8, Empennage San Ramon, California ________________________________________________________________________________
Date: May 08, 2005
Here is another suggestion that worked well for me; Get some heat shrink from the electonics supplier. The kind that has the sealant inside. Cut lengths suitable to cover the handles. Shrink it over the handles The slightly larger handle will provide a better sized grip and not be as slippery. In my case the carpel tunnel syndrome 'type' of pain that plagued me literally went right away. Jim in Kelowna > Try this. You may not, but most people place any pliers in their hand with > their little finger toward the end of the handles. This puts you at a > great > mechanical disadvantage. Simply turn the pliers around So that your index > finger and thumb are toward the ends of the handles. > > John D. Heath ________________________________________________________________________________
Subject: RAM air calculations
Date: May 09, 2005
From: "Wiethe, Philip (P.J.)" <pwiethe(at)ford.com>
1.25 RCVD_NUMERIC_HELO Received": rv-list(at)matronics.com After reading Dan's well detailed experiments, I became interested in the theoretical calculations of the "RAM air effect". Disclaimer - I'm a EE, so this ME/Fluid Dynamics stuff is not my forte, but here goes... Total Pressure in a fluid is the sum of the static pressure and dynamic pressure. The "ram" air effect is due to the dynamic pressure. Bernoulli's equation shows this as: Pd 0.5 * p * V 2 Where: Pd Dynamic Pressure p density (greek letter rho) V Velocity Using the STP density of air in SI units - 1.2250 kg/m 3, and an air speed of 220Mph, I solved Bernoulli's equation to yield 1.75 Inches of Mercury. Thus it looks like the maximum theoretical gain in STP air at 220MPH would be 1.75" Hg from an intake that had no RAM air benefit to one with full RAM air benefit. Obviously, air density is a complex function of Barometric Pressure, Altitude, Temperature, Dew Point, and Humidity. Here is a web site which offers a density calculator and some other useful flying/engine performance calculators: http://wahiduddin.net/calc/density_altitude.htm Phil RV8A - Fuse ________________________________________________________________________________
Subject: Dimple Dies - regular vs. springback
Date: May 09, 2005
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
Has anyone done a comparison between 'regular' and 'springback' dimple dies? I figured all dimple dies have some springback designed in, but maybe not? The springback dies cost a couple bucks more (I'm using Aircraft Tool Supply as my reference here), so I'm looking for input on whether they are worth it or not. I'm getting ready to start an RV7A in July. I will be borrowing most tools from my son (also building an RV7A), but obviously need to get a number of things for myself. Thanks, Dennis Glaeser ________________________________________________________________________________
Date: May 09, 2005
Subject: Re: Dimple Dies - regular vs. springback
On 05/09 11:32, Glaeser, Dennis A wrote: > > Has anyone done a comparison between 'regular' and 'springback' dimple > dies? I figured all dimple dies have some springback designed in, but > maybe not? The springback dies cost a couple bucks more (I'm using > Aircraft Tool Supply as my reference here), so I'm looking for input on > whether they are worth it or not. > I'm getting ready to start an RV7A in July. I will be borrowing most > tools from my son (also building an RV7A), but obviously need to get a > number of things for myself. The best dimple dies I know of come from P.A.R.T.S. http://www.rivettools.com Not cheap but well worth it. You might get a deal on them if buying tools from them, like a pneumatic squeezer. -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: May 09, 2005
Subject: RE: Conversion Coating and Priming with Sanchem
I am heading up to Van's on Thursday for the tour and demo ride... I plan on ordering my RV-7 tail kit while there. Anywhoo... the recent discussions about Sanchem's products have made me very interested in it as a form of Conversion Coating, specifically as a way to avoid storing/using toxic chemical and dealing with the waste. I called Sanchem for pricing info, but my question is, how much of this stuff are you guys ordering? Gallon of each (A, B & C)? Regards, Brad Oliver Livermore, CA ________________________________________________________________________________
Date: May 09, 2005
Subject: Oil on Plug
Here one for engine experts...I began my annual condition inspection today and pulled the plugs to replace them and do a compression check. All looked normal except the bottom plug on #1 cylinder...it had FRESH oil that filled the depression where the electrodes are...upper plug normal. Rest of plugs normal. I did a compression check and that #1 cylinder was 78/80, just the same as last year's compression on that cylinder. An A&P/IA looked at it and thought perhaps my ring gaps had rotated to line up, allowing oil to pass. I had just flown and everything was normal, including run up. Operation on either set of plugs was smooth and I didn't see anything odd. Lycoming 0-320, 160 HP, 400 hrs on major overhaul. Any ideas/thoughts? John at Salida, CO ________________________________________________________________________________
Date: May 09, 2005
Subject: Re: RE: Conversion Coating and Priming with Sanchem
I ordered a gallon of each a, b and c and a gallon of seal #2. Judging by what I have used so far I think that amount will probably run out somewhere in the middle to the end of the wings (I'm working on the emp kit of a 10 now). They (sanchem) said that the products have an indefinite shelf life as long as a+b aren't mixed. If a+b are mixed then its good for about a day, so I usually just mix up what I think I am going to use. James. brad(at)rv7factory.com wrote: > >I am heading up to Van's on Thursday for the tour and demo ride... I >plan on ordering my RV-7 tail kit while there. Anywhoo... the recent >discussions about Sanchem's products have made me very interested in it >as a form of Conversion Coating, specifically as a way to avoid >storing/using toxic chemical and dealing with the waste. > >I called Sanchem for pricing info, but my question is, how much of this >stuff are you guys ordering? Gallon of each (A, B & C)? > >Regards, >Brad Oliver >Livermore, CA > > > > ________________________________________________________________________________
Date: May 09, 2005
Don't be surprised if you glance up from the lounge chair at your local FBO and see some guys wearing Groucho Marx masks piling out of RV's with the N-numbers covered with NASCAR decals...... It'll just be part of the north Alabama gang making an attempt to confuse anybody trying to smear our already questionable reputations via the RAR-VEE list. Sam Buchanan (that's not my real name, though) P.S. In all seriousness, I appreciate the clarification. I am still struggling with the intent of the original message, however. ================================= Finn Lassen wrote: > > I'm going to owe you on this one. Brian wasn't there today and I'd be a > while before I can get back there. > > I was able to ask the flight instructor (Stefanie) that was talking to > St Pete Tower. Yes, they did violate St Pete airspace and no, Tower did > not call the FBO. The FBO took the N-numbers because a neigbor called. > Stefanie guessed that because it was relatively quiet that day the Tower > "let it go". > > Gary, I appreciate you getting the other side of the story for me. At > least I now know who to watch for at the airpark regarding reliability > of data. > > Another line boy today told me "not true, we welcome RV's here", when I > mentioned that the flight school owner has said that they were not > welcome back. ________________________________________________________________________________
Date: May 09, 2005
Having known Finn for a while, I'd bet that the original intent was as written, not as mis-read & over-reacted to by several folks. The subject line ended with a question mark, not a period. The body of the message stated that allegations had been made by non-pilot neighbors, employees at the airport, and the FAA. It stated that there were ongoing problems between neighbors & users of that airport. It seemed clear to me that the posting was an attempt to get the 'other side' of the story from the pilots involved. It also seemed clear to me that he recognized the reality that pilots are in the extreme minority in this country & due to current government propaganda to hide its incompetence, we could easily be driven out of flying by overwhelming negative public opinion leading to more government restrictions. (ok, maybe that was overstating it a bit.) It's worth noting that at least one of the allegations might be literally true (airspace violation) which could lead to others being given more consideration by the FAA and grumpy neighbors. The obvious net result of all this is the potential for more hassle for those using the airpark. It's worth remembering that there are very few real 'rights' left in this country. The use of land as an airport is at the whim of various governments involved in controlling land use. If I had been in Finn's position, I'd have probably asked the same questions. Charlie Sam Buchanan wrote: > >Don't be surprised if you glance up from the lounge chair at your local >FBO and see some guys wearing Groucho Marx masks piling out of RV's with >the N-numbers covered with NASCAR decals...... > >It'll just be part of the north Alabama gang making an attempt to >confuse anybody trying to smear our already questionable reputations via >the RAR-VEE list. > >Sam Buchanan (that's not my real name, though) > >P.S. In all seriousness, I appreciate the clarification. I am still >struggling with the intent of the original message, however. > >================================= > > >Finn Lassen wrote: > > >> >>I'm going to owe you on this one. Brian wasn't there today and I'd be a >>while before I can get back there. >> >>I was able to ask the flight instructor (Stefanie) that was talking to >>St Pete Tower. Yes, they did violate St Pete airspace and no, Tower did >>not call the FBO. The FBO took the N-numbers because a neigbor called. >>Stefanie guessed that because it was relatively quiet that day the Tower >>"let it go". >> >>Gary, I appreciate you getting the other side of the story for me. At >>least I now know who to watch for at the airpark regarding reliability >>of data. >> >>Another line boy today told me "not true, we welcome RV's here", when I >>mentioned that the flight school owner has said that they were not >>welcome back. >> ________________________________________________________________________________
Date: May 09, 2005
John, I think it's more likely that the oil ran out around a valve stem after the engine stopped. It just stopped in the right place to allow it to happen. The idea of the ring gaps lining up is possible, but I think the oil would have to run slightly uphill to get on the plug. Or have so much oil in there that it came up to that level. As long as the mags continue to check good and your oil consumption is normal I wouldn't worry about it. I'd bet the next time you pull the plug the oil won't be there. Just my thoughts. Mark Burns -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Subject: RV-List: Oil on Plug Here one for engine experts...I began my annual condition inspection today and pulled the plugs to replace them and do a compression check. All looked normal except the bottom plug on #1 cylinder...it had FRESH oil that filled the depression where the electrodes are...upper plug normal. Rest of plugs normal. I did a compression check and that #1 cylinder was 78/80, just the same as last year's compression on that cylinder. An A&P/IA looked at it and thought perhaps my ring gaps had rotated to line up, allowing oil to pass. I had just flown and everything was normal, including run up. Operation on either set of plugs was smooth and I didn't see anything odd. Lycoming 0-320, 160 HP, 400 hrs on major overhaul. Any ideas/thoughts? John at Salida, CO ________________________________________________________________________________
Date: May 09, 2005
Subject: Re: A Bigger Better ePanel Builder??
YOU HAVE A GREAT PROGRAM AND I APPRECIATE YOUR TIME AND EFFORTS TO SHARE IT. ONE THING THAT WOULD BE A BIG HELP TO ME, SINCE I AM NOT A COMPUTER PERSON........WOULD BE IF IT COULD BE FIXED SO THAT WE DON'T GET THE LOCK UP AND HAVE TO GO IN TO THE BOWELS OF THE PUTER TO FIX IT. I CAN'T DO IT SO HAVE TO FIND SOMEONE TO COME FIX IT FOR ME. I DO ENJOY IT AND HOPE TO USE IT SOON TO WORK ON OUR 10 PANEL. THANKS REGARDS, DOUG PRESTON RV7A N731RV RV10 - TAILCONE ________________________________________________________________________________
Date: May 09, 2005
On 05/09 2:24, Paul Folbrecht wrote: > > To tell you the truth, I just spent a half-hour with your site building Panel > Candidate #1 and found it really great. > > But, two niceties that would make it better: > > 1) Some sort of "snap-to-grid" feature that auto-aligns components. > > 2) A Save button that will save the panel locally as a .jpg, instead of having > to copy/paste to Paint or whatever. Hi Bill, I found your site very useful when designing/destroying my panel. The one item that was challenging was to 'precisely' place items on the panel, especially if there was any close interferance issues. Snap to grid and a larger on-screen panel area might help. Now how about having the panel *rotate* in the 'Z' axis so we can see the depth of the instruments, and any interferance issues with the subpanel. Ok, now for the real "wannahave". How about providing a nice CAD drawing of the cutouts once the design is complete :) It's a great site and it will be hard to make better, but I'm sure you will. -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Subject: RE Sanchem
Date: May 09, 2005
Thanks Michael for the link. Under the page for SAFEGUARD CC it states " SafeGard CC aluminum pretreatment provides excellent corrosion resistance without paint. Simple cleaning, or all other chrome-free pretreatment systems, leaves the metal open to corrosion." They also state "Are there time restraints on painting after pretreatment? NO, you may paint right after pretreatment and drying or a year or more later." So, I think I may give this a try. I'd like to use this on the metal under the cowling and for the inside (an outside) of the push tubes, both ailerons and elevator, with out further painting. Hey Marty, The answer is that this is a conversion coating, so it is about two or three molecules thick and needs to be protected with either their clear sealer or a traditional primer. Here is the link: http://www.sanchem.com/ Regards, Michael Wynn RV-8, Empennage San Ramon, California ________________________________________________________________________________
Subject: Re:Oil on Plug
Date: May 10, 2005
Hi John, My factory-new O-320 had exactly the same happen at its first 100 hourly inspection, except it was on the bottom plug of cylinder #4. We pulled the top plug on the same cylinder and it was perfect, so it obviously was not a problem with the cylinder, and the engine hardly uses any oil between changes. It was suggested that the valve guide may be dropping a small amount of oil directly onto the lower plug at shutdown, but I am open to any other suggestions..... Martin in Oz RV6 _____ <http://promos.hotbar.com/promos/promodll.dll?RunPromo&El&SG&RAND8424&par tnerfastutility> Block Spam Emails - Click here! ________________________________________________________________________________
Date: May 09, 2005
> Each of us....consider how we would feel (and how will the pilots > involved feel after they return from their island vacation?) if the tail > number of our plane had been broadcast on the list as was done to the > "rude?" pilots before we had a chance to explain/defend/refute/accept > our actions. I would quite simply slice my wrists. What could there possibly be to live for if people I never met thought I might be rude for possibly doing something that might have offended someone who bought a house right next to an airport and then complained about the noise? Oh thank you Jesus that this has never happened to me, or I would be living out my life as a monk in Tibet, praying for the forgiveness of whiners the world over and striving to save every earthworm I could find. Well either that or I would laugh and get out the map to plan my next trip. :-) Hehehe. Is it Monday already? Ok, who took off with my weekend? I got robbed. Charlie Kuss is probably still sipping fruity drinks on his balcony with that marine corps hippie guy and here I am working like a slave. It's criminal I tell ya. Bill Find restaurants, movies, travel and more fun for the weekend. Check it out! http://discover.yahoo.com/weekend.html ________________________________________________________________________________
Date: May 09, 2005
Hi Brad Welcome to RV land. I ordered a gallon each. I can see that the cleaner (part C) will run out first. I suspect I will get through the wings with the two gallons of A+B that I have. so, I would say to start with a gallon and each and see how it goes. Regards, Michael Wynn RV-8, Empennage San Ramon, California ________________________________________________________________________________
Date: May 09, 2005
Subject: Re: Noisy Airplanes (was Rude RV'ers)
You know, that is a question I have asked myself numerous times. Why don't we put an effective muffler on our planes? Is it a weight issue? Would the muffler degrade the engine performance that much? Any aeronautical engineers out there know the answer? Regards, Michael Wynn RV-8, Empennage San Ramon, California ________________________________________________________________________________
Date: May 09, 2005
MLWynn(at)aol.com wrote: > >You know, that is a question I have asked myself numerous times. Why don't >we put an effective muffler on our planes? Is it a weight issue? Would the >muffler degrade the engine performance that much? Any aeronautical engineers >out there know the answer? > >Regards, > >Michael Wynn >RV-8, Empennage >San Ramon, California > > > > Most of the noise you hear from an aircraft flying overheard is prop noise. Jerry ________________________________________________________________________________
Subject: More O-360 Questions
Date: May 09, 2005
All, I am trying to finalize the options for my planned O-360, and I had a few questions I was needing help to understand: 1) I have a FP prop, but I understand it is possible to set the engine up for a CS (then plug it for FP)? I want the ability to easily upgrade to CS prop in the future if possible. What does the $500 adder that Mattituck charges for CS engine consist of? 2) I noticed the option for horizontal (cold-air induction) on the IO models. Is it not possible to do horizontal induction with the O-360? How much does that generally add to the basic cost of the engine (Aerosport or Mattituck)? 3) Will all of the "regular" O-360s (Aersport, Mattituck, Superior, etc.) use the Dynafocal #1 mount? Are there percieved advantages of one mount vs the other? I would also be intersted in talking off-line with anyone who has done the Sam James cowl. I am curious about the deletions required for the finish kit order. Thanks,Scott7A Waiting for Fuse ________________________________________________________________________________
Subject: RE: To ram air or NOT to ram air -- that is the question
Date: May 09, 2005
7.50 BARRACUDA_HEADER_FP56 RBL: Blacklist bl.spamcop [Blocked - see <http://www.spamcop.net/bl.shtml?68.217.221.11>] Dan, Great effort and research, pretty slick how your filtered setup worked so well. One other thought is based on an experience with my first airplane, a Q-2/200. A friend of mine experimented with the ram air aspects as all the engines were set up that way with some very creative filters (a t-shirt for example). One thing guys tried was varying lengths of the inlet with the focus being on how close to the prop you should get. The closer you got, the better the performance and the impression was you got a bit of a turbo-type boost as the prop went buy. The next step was to align the prop so you would get the most benefit of the pressure and that was based on trying to get a blade past the inlet about the time an intake valve was about to open. Far from an exact science, but some guys seemed to have pretty good success with it. Marcus RV-10, tailcone well on it's way, QB on the ocean ________________________________________________________________________________
Date: May 09, 2005
On 05/09 7:57, Walter Tondu wrote: > > On 05/09 2:24, Paul Folbrecht wrote: > > > > > To tell you the truth, I just spent a half-hour with your site building Panel > > Candidate #1 and found it really great. > > > > But, two niceties that would make it better: > > > > 1) Some sort of "snap-to-grid" feature that auto-aligns components. > > > > 2) A Save button that will save the panel locally as a .jpg, instead of having > > to copy/paste to Paint or whatever. > > Hi Bill, > > I found your site very useful when designing/destroying my panel. The one > item that was challenging was to 'precisely' place items on the panel, especially > if there was any close interferance issues. Snap to grid and a larger on-screen panel > area might help. > > Now how about having the panel *rotate* in the 'Z' axis so we can see > the depth of the instruments, and any interferance issues with the subpanel. 'X' axis. I guess this depends upon which planet you come from... > Ok, now for the real "wannahave". How about providing a nice CAD drawing > of the cutouts once the design is complete :) > > It's a great site and it will be hard to make better, but I'm sure you will. > -- > Walter Tondu > http://www.rv7-a.com > > > > > -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: May 09, 2005
Subject: Re:Dimple Dies-regular vs. springback
I think the extra cost of springback dies is miney well spent. I used them on our RV-4 and my neighbor used regular. We both riveted together on both planes and ours is very much smoother than his. We back-riveted on both fuselages and it really shows up there. I think I got mine from Bob Avery. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: May 09, 2005
Our European colleagues have been dealing with aircraft noise issues for many years and have considerable experience with improved (quieter) muffler systems. Perhaps some of our European readers can provide some www links to local muffler suppliers. Here is one link, ironically to an item from Tony Bingelis's "Firewall Forward". http://www.piteraq.dk/flight/muffler.html Jim Oke Wpg, MB RV-6A, RV-3 ----- Original Message ----- From: <MLWynn(at)aol.com> Subject: Re: RV-List: Noisy Airplanes (was Rude RV'ers) > > You know, that is a question I have asked myself numerous times. Why > don't > we put an effective muffler on our planes? Is it a weight issue? Would > the > muffler degrade the engine performance that much? Any aeronautical > engineers > out there know the answer? > > Regards, > > Michael Wynn > RV-8, Empennage > San Ramon, California > > > ________________________________________________________________________________
Date: May 10, 2005
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: RE: Rude RVers
The owner of N628PV gave myself and fellow RV-7 builder Dave Hollingsworth rides out of Clearwater Airpark this past Friday afternoon (day before all the excitement). I had never met Paul before but he is one of the most gracious persons I have had the pleasure to know and most professional in all his actions when flying the RV. He was very considerate of the noise issue, very careful about NOT busting Tampa's class B airspace and very careful about flying the proper pattern when landing at Clearwater. We went out over the gulf to have our fun and were never below 2500 feet MSL during that time. I suspect that it was the noise of 5 un-muffled RVs taking off that made the neighbors upset. So they probably called St. Pete tower to complain and St. Pete called CLW to find out what was going on. I don't believe for a minute that any of those RV folks did anything to create this uproar (if one of them did mess up I'm sure it was accidental, there's just too much experience there). Thanks for the E-ticket Paul and I hope you and Victoria have a great vacation in spite of all this. Dean Psiropoulos RV-6A N197DM Tarpon Sprgs, FL ----Original Message Follows---- From: Finn Lassen <finn.lassen(at)verizon.net> Subject: RV-List: Rude RVers? Apparently the following RVers visited Clearwater Airpark (CLW) today: N699JB, N99PZ, N515L, N695LS and N628PV. ________________________________________________________________________________
Date: May 10, 2005
> ... Community outreach is one solution, quieter airplanes is > another. There was an interesting question from a potential student > pilot in a British aviation magazine I read, "Why do I have to wear > the aircraft muffler on my head instead of it being on the airplane?" Good mufflers will go a long way towards making airplanes quieter, but there does not seem to be much research into this area. If anyone knows of some, I'm very interested in finding it. Here in Switzerland, many airports charge landing fees based on the MTOW and the "noise classification" of the airplane. They are doing this in a probably vain attempt at keeping the airports open. Having a quiet airplane can save you a lot of money per landing, and usually will pay for itself in a couple of days of doing touch and gos. The fees can get quite expensive. The normal way people here quiet down their airplane is with a big honkin' glasspack, a.k.a. the "Swiss muffler". They do work, but they are heavy, not too easy to install, and they sit out in the air stream. I was chatting with a couple of guys trying to find a way to put one on their Ercoupe just this Sunday. It can be difficult to mount these rascals. The other issue is, of course, prop noise. Everyone knows that long blades spinning fast can approach or exceed supersonic velocities, which makes a lot of racket. Recently at SNF some of the airshow guys thought that it would be great to make a lot of noise, and were constantly overspeeding their props. Everyone around was really annoyed by the excess noise, and you know this crowd is pretty partial to airplanes. The solution to prop noise is pretty well known, and that's simply reduce the tip speed of the prop. This can be done with some of those levers in the cockpit, and of course having a shorter prop (3-blade, for example) makes it easier. Many of the glider towing airplanes here have huge mufflers, and tiny 4-blade props to keep the noise down, and it really works. Yes, they are sacrificing some performance, but from the testing I've seen on the modern 3-blade props, you don't seem to lose much at all, if any. I have communicated with AOPA on this issue to see why they don't put any emphasis on the quieter airplane when they are discussing airport complaints and closures. All the answers I have received are basically saying that they don't want to open up that can of worms. If they start promoting mufflers and quieter props, then the people trying to get the airports closed will use that as a club to beat us. It makes sense, but does not really solve the problem. -- Mickey Coggins http://www.rv8.ch/ #82007 Wiring ________________________________________________________________________________
Subject: Mufflers on Rv's
Date: May 10, 2005
It never ceases to amase me how one can ask a question about a problem and get maybe one response at best, but something like the rude RV'rs bings dozens of replys, reposts, posturing, and turmoil. :-) As to noise, we are right up there with the older jets. First time I heard a 6a with 180 fire up, my first thought was, man that guy needs a new muffler!, suprise, suprise, NO muffler. ( I got arrested for not haveing one on my 42 ford when I was a kid). I guess it would cause loss of performance to have one, as would require bigger cowl, and reduce poweroutput some. I can and do fly without headphones comfortably, when not needed, in my cherokee, but try it in my 150hp 6a, Nyet! Nein! Uhuh! Charlie heathco ________________________________________________________________________________
Date: May 10, 2005
In one of the Tony Bingelis' books he describes a "European" muffler that is purported to allow experimental aircraft to meet some claimed some tough European country noise standards. As I recall it is a coaxial tube arrangement that runs almost the length of the fuselage and was shown being mounted along the centerline under the fuselage of some sort of homebuilt design. I think the reason you don't see any such muffler is the weight and performance penalty. You can't build one without robbing some performance and adding weight. The newer RVs (6,7,8,9,10) have more room under the cowling than the orignal designs (3,4) that are very tight with their cowlings and would make it vey hard to fabicate any sort of convential muffler under the cowling. In any event, any sort of muffler design is goning to add weight and cut power to some extent but, again with the newer designs such as the 7 and 10 the goal seems to be shifting from absolute performance and efficiency to a more complete corss-country and in many cases fully IFR capable platform so such creature comforts as muffled engine sound might make more sense, not to mention the airport friendly advantages. Maybe some inventive person will start making one and offering it for sale to this ever-growing community. I forget which Bingelis book it was - 'Firewall Forward' perhaps - but I was always intrigued by the nature of the muffler design. I remember seeing some sort of reconisaise aircarft taht was Lycoming ppowered and looked sorta like a mini U2 type thing in some museum tha thad a long muffler running external to the fuselage so the key to getting reallly quiet is probably something similar. In order to perserve the looks of the plane the fuselage would have to be modified to "hide the thing somewhat which, addes weight, complexity, and would likely not be considered worht the trouble unless some severe noise restrictions are enacted here. Perhaps some reader will know more about the so-called European muffler and the noise restrictions it is supposed to tame and can add some enlightenment. ----- Original Message ----- From: <MLWynn(at)aol.com> Subject: Re: RV-List: Noisy Airplanes (was Rude RV'ers) > > You know, that is a question I have asked myself numerous times. Why don't > we put an effective muffler on our planes? Is it a weight issue? Would the > muffler degrade the engine performance that much? Any aeronautical engineers > out there know the answer? > > Regards, > > Michael Wynn > RV-8, Empennage > San Ramon, California > > ________________________________________________________________________________
Date: May 10, 2005
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
http://www.customaircraft.com/systems.html Try this site for mufflers and exhaust systems fir experimentals... Darrell MLWynn(at)aol.com wrote: You know, that is a question I have asked myself numerous times. Why don't we put an effective muffler on our planes? Is it a weight issue? Would the muffler degrade the engine performance that much? Any aeronautical engineers out there know the answer? Regards, Michael Wynn RV-8, Empennage San Ramon, California Darrell Reiley Round Rock, Texas RV 7A #70125 N622DR (reserved) --------------------------------- ________________________________________________________________________________
Subject: OFF THE TOPIC: Young Eagle Credits
Date: May 10, 2005
From: "Nightingale Michael" <NightingaleMichaelV(at)JohnDeere.com>
"RV-9 LIST (RV-9 LIST)" FILETIME=[8811EFC0:01C55562] Our EAA chapter is sending three young men (we sent two young ladies last year) to the Advanced Aviation Air Academy during Airventure. If anyone has any YOUNG EAGLE CREDITS that are not spoken for PLEASE contact me OFF the list. In the last six year EAA Chapter 75 and the QCAA (Quad City Airmen's Association) has sent 12 young to the Air Academy. PLEASE help us continue introducing young people to General Aviation. This is the only thing the YOUNG EAGLE CREDITS can be used for; to help pay up to half the tuition for each attendee. Thank You Michael V. Nightingale @ DEERE & Co. Computer Center 400 19th ST MOLINE, IL. 61265 309-314-6806 cell NightingaleMichaelV(at)JohnDeere.com I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: May 10, 2005
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Here is a simple way to keep an engine quiet. EI causes all the combustion to take place in the combustion chamber where it belongs. An aircraft engine with one EI at idle is very quiet compared to mags. Although I have not heard a EI equipped plane take off that I know of, I can only imagine it is quieter. With the prop, a smaller dia helps. I went with a 3 blade WW151 prop, it is very quiet, and many people have commented about the sound of my plane on take off, much quieter than all others with no mufflers!! Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: May 10, 2005
Subject: Re: RE: Rude RVers
The following is a copy of an email that I was asked to forward to the RV-List. I have already shot my wad on this subject and have nothing further to add so please direct any responses about this post directly to Mr. Coggin, not me. Sam Buchanan ====================================== Sam, I am not a member of the Matronics RV list but monitor it. Would you please forward this email to the list? I have sent the same to one Finn Lassen. Thanks. Tom Coggin motniggo(at)localnet.com ---------- Dear Finn Lassen, I know all of the owners and pilots of the named aircraft in your post to the Matronics RV list as I flew with them to the Turks and Caicos a year or so ago. None of them were rude or inconsiderate on that trip. On that trip I saw all of them experience delays and excessive paperwork with patience and courtesy. One of the group was once very plainspoken but when he expressed his forthright opinion about the price of a taxi ride in the Bahamas, I was in complete agreement with him. Even then he was not rude to the taxi driver. All of them are careful and safe pilots. I would fly in formation or with anyone of them. None of them are "HOTDOGS". If this trip was handled as the one I was on, it was extremely well planned and researched. They would certainly have known of and complied with the proper traffic patterns at planned refueling stops. I am sure it will come as a shock to them when they return from their trip to learn that they had insulted or inconviencied anyone. I am a little disturbed by your post on the RV list which is widely read in the RV community. Your posting of tail numbers after hearing only one side of the controversy is (in my opinion) at least inconsiderate of the owners of those airplanes. RV's having become more numerous and often flown in groups seem to invite the ire of others more so than regular certified aircraft which do not as often travel in groups. Flying as a group is perfectly legal and proper and honored by the FAA but is unusual in the eyes of the non flying public but is widely practiced in my part of the country by RVers. Tom Coggin, RV6 N112WA (256) 775-0383 motniggo(at)localnet.com ________________________________________________________________________________
Date: May 10, 2005
Has anyone looked at or installed a ram air induction system from Jon Johanason? http://www.flymore.com.au/ He has some great products and I'm tempted to believe that his ram air induction might work a touch better then the standard open inlet. here is a quote from his product site. "Extensive flight-testing has shown increases in excess of 2 of Manifold Pressure Recovery at 1,500 and 1" of Manifold Pressure Recovery at 10,000. These increases are improvements compared to Vans snorkel type induction (not the rhino horn induction)." There is actually a full page write up on it on his web site. kev From: "Marcus Cooper" <coop85(at)bellsouth.net> Subject: RV-List: RE: To ram air or NOT to ram air -- that is the question Date: Mon, 9 May 2005 18:21:14 -0400 7.50 BARRACUDA_HEADER_FP56 RBL: Blacklist bl.spamcop [Blocked - see <http://www.spamcop.net/bl.shtml?68.217.221.11>] Dan, Great effort and research, pretty slick how your filtered setup worked so well. One other thought is based on an experience with my first airplane, a Q-2/200. A friend of mine experimented with the ram air aspects as all the engines were set up that way with some very creative filters (a t-shirt for example). One thing guys tried was varying lengths of the inlet with the focus being on how close to the prop you should get. The closer you got, the better the performance and the impression was you got a bit of a turbo-type boost as the prop went buy. The next step was to align the prop so you would get the most benefit of the pressure and that was based on trying to get a blade past the inlet about the time an intake valve was about to open. Far from an exact science, but some guys seemed to have pretty good success with it. Marcus RV-10, tailcone well on it's way, QB on the ocean ________________________________________________________________________________
Date: May 10, 2005
Subject: Sources for electrical system design
Now that I've decided on priming, manual vs. electrical trim (agonizing), engine/prop (Mattituck or Aerosports O-320 with 3-blade Catto), and a working version of my panel (subject to change), I want to tackle designing the electrical system for my aircraft in the remaining 6 weeks or so I have before I can start construction. I'm not asking any specific questions, just looking for good references to study. I'm nearly certain I want a single-alt dual-batt system but I need to decide on things like alternator output, battery brand/size, and come up with an actual wiring diagram. Am also looking for general tips on electrical work.. I'm no electrician. I can solder and crimp, but that's about it. (When I was a kid I once connected the ends of a bare cord to a nail and then plugged it in a wall socket. I would recommend against this.) So, if there are some great references out there (websites, books) talking 'bout electrical systems for experimentals in general, and especially RVs, with emphasis on dual-bus systems for all-electric IFR setups, please shoot them my way. TIA. ~Paul ~RV-9A QB ordered ________________________________________________________________________________
Date: May 10, 2005
Is it really true that many RVs have NO muffler?? Surely a muffler is part of Van's FWF kits. I realize they are not very effective mufflers, but they're mufflers.. just like the stacks on most certified AC. The RVs I have heard are no louder than the average 172. Am I missing something?? --- Darrell Reiley wrote: > > http://www.customaircraft.com/systems.html > > > Try this site for mufflers and exhaust systems fir experimentals... > > Darrell ________________________________________________________________________________
Date: May 10, 2005
Scott ... what is a WW151 prop and do you have a link to their site? Regards ... Jerry Grimmonpre 7a shop building Subject: Re: RV-List: Noisy Airplanes (was Rude RV'ers) > <bilinski@kyocera-wireless.com> > I went with a 3 blade > WW151 prop, it is very quiet, and many people have commented about the > sound of my plane on take off, much quieter than all others with no > mufflers!! > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > > ________________________________________________________________________________
Date: May 10, 2005
Subject: Re: Sources for electrical system design
Quoting Paul Folbrecht : > So, if there are some great references out there (websites, books) talking > 'bout electrical systems for experimentals in general, and especially http://www.aeroelectric.com/ -- Dan Brown, KE6MKS, dan(at)familybrown.org "Since all the world is but a story, it were well for thee to buy the more enduring story rather than the story that is less enduring." -- The Judgment of St. Colum Cille ________________________________________________________________________________
Date: May 10, 2005
From: Scott Bilinski <bilinski@kyocera-wireless.com> question
question Be careful with those numbers, I belive Jon's new plane is turbo normalized and am not sure it that is taken into account. > >Has anyone looked at or installed a ram air induction system from Jon >Johanason? http://www.flymore.com.au/ > >He has some great products and I'm tempted to believe that his ram air >induction might work a touch better then the standard open inlet. > >here is a quote from his product site. > >"Extensive flight-testing has shown increases in excess of 2 of Manifold >Pressure Recovery at 1,500 and 1" of Manifold Pressure Recovery at 10,000. >These increases are improvements compared to Vans snorkel type induction >(not the rhino horn induction)." > >There is actually a full page write up on it on his web site. > >kev > > >From: "Marcus Cooper" <coop85(at)bellsouth.net> >To: >Subject: RV-List: RE: To ram air or NOT to ram air -- that is the question >Date: Mon, 9 May 2005 18:21:14 -0400 7.50 BARRACUDA_HEADER_FP56 RBL: >Blacklist bl.spamcop [Blocked - see ><http://www.spamcop.net/bl.shtml?68.217.221.11>] > > >Dan, > > Great effort and research, pretty slick how your filtered setup worked >so well. One other thought is based on an experience with my first >airplane, a Q-2/200. A friend of mine experimented with the ram air aspects >as all the engines were set up that way with some very creative filters (a >t-shirt for example). One thing guys tried was varying lengths of the inlet >with the focus being on how close to the prop you should get. The closer >you got, the better the performance and the impression was you got a bit of >a turbo-type boost as the prop went buy. The next step was to align the >prop so you would get the most benefit of the pressure and that was based on >trying to get a blade past the inlet about the time an intake valve was >about to open. Far from an exact science, but some guys seemed to have >pretty good success with it. > > >Marcus > >RV-10, tailcone well on it's way, QB on the ocean > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: May 10, 2005
http://www.aeroelectric.com Buy the book, read it cover to cover, and make up your own mind about architecture. FWIW, I used Z-11 and Bob's techniques on my RV-7, and it has been rock solid in the electrons dept. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Paul Folbrecht" <paulfolbrecht(at)yahoo.com> Subject: RV-List: Sources for electrical system design > > Now that I've decided on priming, manual vs. electrical trim (agonizing), > engine/prop (Mattituck or Aerosports O-320 with 3-blade Catto), and a working > version of my panel (subject to change), I want to tackle designing the > electrical system for my aircraft in the remaining 6 weeks or so I have before > I can start construction. > > I'm not asking any specific questions, just looking for good references to > study. I'm nearly certain I want a single-alt dual-batt system but I need to > decide on things like alternator output, battery brand/size, and come up with > an actual wiring diagram. Am also looking for general tips on electrical > work.. I'm no electrician. I can solder and crimp, but that's about it. (When > I was a kid I once connected the ends of a bare cord to a nail and then plugged > it in a wall socket. I would recommend against this.) > > So, if there are some great references out there (websites, books) talking > 'bout electrical systems for experimentals in general, and especially RVs, with > emphasis on dual-bus systems for all-electric IFR setups, please shoot them my > way. TIA. > > ~Paul > ~RV-9A QB ordered > > ________________________________________________________________________________
Date: May 10, 2005
The AeroElectric thread on this list server - along with AeroElectric.com. Here's a link to a date sorted view: http://www.matronics.com/browse/aeroelectric-list/date.html Get Bob Nuckolls book - he's just updated it (Version 11). Some tips: (worth what you paid for it :-) A 40A alternator will handle an all electric IFR airplane - even with electronic ignition (is that why you want 2 batteries?). I'm planning on a couple of Odyssey PC625 batteries (I'm using an electrically dependent Subaru engine). I'm also going with electric trim (not too much agonizing). Your panel will constantly change because new stuff is always coming out!! Dennis Glaeser Starting an RV-7A in July ----------------------------------------- Subject: Sources for electrical system design From: Paul Folbrecht Now that I've decided on priming, manual vs. electrical trim (agonizing), engine/prop (Mattituck or Aerosports O-320 with 3-blade Catto), and a working version of my panel (subject to change), I want to tackle designing the electrical system for my aircraft in the remaining 6 weeks or so I have before I can start construction. I'm not asking any specific questions, just looking for good references to study. I'm nearly certain I want a single-alt dual-batt system but I need to decide on things like alternator output, battery brand/size, and come up with an actual wiring diagram. Am also looking for general tips on electrical work.. I'm no electrician. I can solder and crimp, but that's about it. (When I was a kid I once connected the ends of a bare cord to a nail and then plugged it in a wall socket. I would recommend against this.) So, if there are some great references out there (websites, books) talking 'bout electrical systems for experimentals in general, and especially RVs, with emphasis on dual-bus systems for all-electric IFR setups, please shoot them my way. TIA. ~Paul ~RV-9A QB ordered ________________________________________________________________________________
Date: May 10, 2005
http://www.whirlwindaviation.com/ The WW 151 is a very smooth and quiet prop. > >Scott ... >what is a WW151 prop and do you have a link to their site? >Regards ... >Jerry Grimmonpre >7a shop building > >Subject: Re: RV-List: Noisy Airplanes (was Rude RV'ers) > > > > <bilinski@kyocera-wireless.com> > > I went with a 3 blade > > WW151 prop, it is very quiet, and many people have commented about the > > sound of my plane on take off, much quieter than all others with no > > mufflers!! > > > > > > Scott Bilinski > > Eng dept 305 > > Phone (858) 657-2536 > > Pager (858) 502-5190 > > > > > > > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: May 10, 2005
At the risk of asking a really stupid question, what is the difference? Michael Wynn RV 8 Empennage ________________________________________________________________________________
Date: May 10, 2005
Most RV's have no mufflers at all... not a Van's norm... Folbrecht Is it really true that many RVs have NO muffler?? Surely a muffler is part of Van's FWF kits. I realize they are not very effective mufflers, but they're mufflers.. just like the stacks on most certified AC. The RVs I have heard are no louder than the average 172. Am I missing something?? --- Darrell Reiley wrote: > > http://www.customaircraft.com/systems.html > > > Try this site for mufflers and exhaust systems fir experimentals... > > Darrell Darrell Reiley Round Rock, Texas RV 7A #70125 N622DR (reserved) --------------------------------- ________________________________________________________________________________
Date: May 10, 2005
Subject: Re: Duct Tape
On 05/10 11:17, Stephanie Marshall wrote: > > I am not an Oklahoma gal, I am an Oregonian born and bred :-) BTW where is Brown't Tools, do they have a web site? http://www.browntool.com -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: May 10, 2005
Subject: Noisy Airplanes (was Rude RV'ers)
A couple of quick points: Noise: RVs (and other straight no muffler airplanes) are louder. That is OK since we climb so fast and move so fast the effect to Mr & Mrs. Joe Public is not real bad. Just be aware we are louder than you think. Our European brothers and sisters have to add 4-5 feet long "swiss mufflers". to reduce noise. Any builder can reduce noise but it will cost you a little added weight, a loss of a few MPH, a few less HP and a less than attractive tube extending under the belly. I have a 4 into 1 exhaust with a 2.25" collector. I am thinking of a removable 21" stainless 4" diameter stainless steel racing muffler extending back past the firewall on the centerline of the belly. I could extend the cowl exit aft to cover it and maybe get a little "augment-or" action, which improves cooling and will hide the muffler. Since the "tuned" length of a Lycoming is in 18.5"-21" interval lengths, the racing muffler should produce min back-pressure and could actually improve exhaust scavenging. Mistakes Happen If you say you never have flown into airspace that you should not have, you have not been flying very long or you have never figured out you already have, probably many times. (Thank you GPS with airspace warning.) "Formation Flight" and "180 Overhead Break approach": A group of RV's fly formation and like to land in formation. They are friends of mine and I flew with them on occasion. They were all retired and flew often. When their activities came under attack from the general pilot community at the airport, they were dumbfounded that anyone should complain. Their usual activity, formation landings are: in trail formation, idle power (with back-fires), "180 Break" approach abeam the numbers, steep continuous bank descending 180 turn to landing. Each RV lands within say 10-15 seconds. The "short approach", back-fire, from abruptly going to Idle power and 4 plus planes at once was not popular with all. They were pissing off the airport general population, but were oblivious, and because of their previous airline or military experience they justified it is the safest way to land a group of airplanes in minimum time. That is true, but I tried to explain they (we) needed to fit into the pattern. The Airman's Info Manual (AIM) shows 45, downwi nd, base, final to landing patterns. The 180 overhead landing is not standard. I do formation flying, takeoff, approach and landing, including 180 overheads, however you have to be aware that you will startle other pilots and folks on the ground with mass arrivals and military patterns. Some bystanders love it, and my RV buddies think everyone should love the show. They don't all love it. May be it is jealousy, but just be sensitive to that. Also this could be actionable by the FAA. Patterns are not specified by the FARs except "all turns must be made to the left unless noted otherwise." However US Government Vs. Joe Pilot, in appeals court, has shown the AIM, which is not regulations, does show a standard pattern and has been upheld as de-facto law. Meaning pilots not flying the pattern per the AIM can get the FAA shaft. If the pattern is clear, no one around and you are over flying rural unpopulated areas, make formation 180 break overhead landings all day, but if the pattern is full, I would kindly suggest you knock it off. Cheers George --------------------------------- ________________________________________________________________________________
Subject: Uneven RV6 bottom cowl
Date: May 10, 2005
Hi Listers.... A friend who mounted the cowling on his almost completed RV6... noticed the bottom cowl contour curves not matching exactly. The bottom right (passenger side) contour seems to bow down a bit further towards the ground than on the left side. However it does match up even at the firewall area and close to the spinner. Darn thing just looks ' swollen' in between those two area's. I'm building an RV6 too ... I checked and my lower cowl does the same thing.... same side. It's a notice-able when looking head on and I'll probably be cutting into it to even things up best I can. These cowlings are known for needing reshaping but I hadn't heard of this one nor found anything in the archives about it. Any RV6,7 or 9 builders with the same problem on the O360 RV bottom cowl? Wondering if someone had addressed this problem already with a workable solution? Thanks everybody, Clay - RV6 finish kit (almost) ________________________________________________________________________________
Date: May 10, 2005
Subject: Mogas warning
Just came across this a few minutes ago, Just an FYI: http://planenews.com/modules.php?name=News&file=article&sid=528 *Marathon Oil Warns Pilots Using Auto Gas in West Virginia.* Safety and Warnings <http://planenews.com/modules.php?name=News&new_topic=52>Marathon Ashland Petroleum officials are warning pilots in West Virginia, and parts of Ohio and Kentucky, who use 87 or 89 octane auto fuel in their aircraft that the company has detected the presence of foreign materials in some of that fuel. Pilots using auto fuel in airplanes in those areas are asked to call 800-892-3418. ________________________________________________________________________________
Date: May 10, 2005
www.whirlwindpropellers You will find information here... Darrell Reiley Jerry Grimmonpre wrote: Scott ... what is a WW151 prop and do you have a link to their site? Regards ... Jerry Grimmonpre 7a shop building Subject: Re: RV-List: Noisy Airplanes (was Rude RV'ers) > > I went with a 3 blade > WW151 prop, it is very quiet, and many people have commented about the > sound of my plane on take off, much quieter than all others with no > mufflers!! > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > > --------------------------------- ________________________________________________________________________________
Date: May 10, 2005
Jim, Vetterman has a muffler system for the RV. I think I will order one for my RV9. He states it will make very little difference inside but much better on the outside. Jim Nelson ________________________________________________________________________________
Date: May 10, 2005
Wow, that's quite a bit. Is this the max draw configuration, ie. pitot heat, landing lights, microwave oven all on at once? If so how much do you draw under normal flying conditions? Jeff Point Stewart, Michael (ISS Atlanta) wrote: >I draw 48 amps, IFR all electric rv. > > > > ________________________________________________________________________________
Subject: Re: Re:Dimple Dies-regular vs. springback
Date: May 10, 2005
Whenever you form sheet metal, you can't just bend it exactly to the desired angle because it 'springs back' a bit. The amount depends on material, thickness, bend radius, bend angle, (there are tables for this) ... Tooling designers take this into account and add a springback angle to the tooling surfaces where flanges are formed - you overbend the flange by the springback angle and the result is a flange bent to the angle you intended to get. I figured that all dimple dies already had this built-in, but then I saw that suppliers had 'spring-back' dimple dies, in addition to the 'regular' ones. I guess in general, dimples are small enough, and typically done with enough force (hammer, squeezer) that the metal doesn't spring back enough to matter. But apparently someone decided to make a better mousetrap. I was wondering if the difference is noticeable, and a couple of people have said yes. (BTW - the only dumb questions are the ones you DON'T ask :-) Dennis Glaeser ---- Subject: Re: Re:Dimple Dies-regular vs. springback From: MLWynn(at)aol.com At the risk of asking a really stupid question, what is the difference? Michael Wynn RV 8 Empennage ________________________________________________________________________________
Date: May 10, 2005
> Some tips: (worth what you paid for it :-) > A 40A alternator will handle an all electric IFR airplane - even with > electronic ignition (is that why you want 2 batteries?). I'm planning I'm planning LASAR ignition. Maybe it's silly, but a battery-dependent engine just makes me a tad nervous. I like the LASAR solution of having old-fashioned mags underneath. Two batts is because I will have an all-electric IFR aircraft. I want two separate busses with my IFR backup instruments and avionics on the 2nd bus with its own battery. > on a couple of Odyssey PC625 batteries (I'm using an electrically > dependent Subaru engine). > I'm also going with electric trim (not too much agonizing). Your panel > will constantly change because new stuff is always coming out!! I don't know about that. I'm going with the GRT EFIS in part because it's *not* brand-new and it's proven. Same goes for the TT AP. If a new company comes along, I'm not going with their product, no matter how good it sounds/looks, until plenty of others have been flying with it for a year+. That's not going to unfold in the next 1-2 years. As for avionics, really doesn't change that fast. I may well go with a GNS 430 instead of the 300XL if prices drop or refurbished units become available, but that's about it. Don't see my SL-30 nav/com, Garmin 327 xponder, or PSE audio panel being superseded in the next year either. If they are, though, with a better unit at the same price range, that doesn't really change the panel much. I don't see many major innovations coming in the way of my backup analog ASI, alt, or electric TC, either. ;-> ________________________________________________________________________________
Date: May 10, 2005
Subject: Re: Joy Riding in the Pattern
> The 180 overhead landing is not standard. I do formation flying, > takeoff, approach and landing, including 180 overheads, however you have > to be aware that you will startle other pilots and folks on the ground > with mass arrivals and military patterns. Some bystanders love it, and my > RV buddies think everyone should love the show. They don't all love it. > May be it is jealousy, but just be sensitive to that. Also this could be > actionable by the FAA. Patterns are not specified by the FARs except "all > turns must be made to the left unless noted otherwise." However US > Government Vs. Joe Pilot, in appeals court, has shown the AIM, which is > not regulations, does show a standard pattern and has been upheld as > de-facto law. Meaning pilots not flying the pattern per the AIM can get > the FAA shaft. Now for the other side of the story. Flying a standard pattern behind a Piper Cub flying at 35 knots and doing a Bomber Pattern, (that is 5 miles downwind, 2 miles crosswind and another 5 miles on final with a 5 minute taxi on the runway before turn off on a taxiway) is sheer frustration for even a Citabria Pilot. My philosophy is if you are going to land, then land. Do not joy ride in the pattern. Bob RV6 NightFighter ________________________________________________________________________________
Date: May 10, 2005
I'm still a tad confused on this. Van's FWF kits include what they call a "muffler". What I think you're saying is that this "muffler" is so ineffective that it barely qualifies as one. Correct? If not, you're saying that most RVers do not use Van's FWF kits with their Lycs or do not use the Van's exhaust stack. > Most RV's have no mufflers at all... not a Van's norm... > ________________________________________________________________________________
Date: May 11, 2005
Does anyone know if Larry Vetterman has a web site? Thanks Wayne ----- Original Message ----- From: "James H Nelson" <rv9jim(at)juno.com> Subject: Re: RV-List: Noisy Airplanes (was Rude RV'ers) > > Jim, > Vetterman has a muffler system for the RV. I think I will order > one for my RV9. He states it will make very little difference inside but > much better on the outside. > > Jim Nelson > > > > > > ________________________________________________________________________________
Date: May 10, 2005
On 14:12:39 2005-05-10 Bob wrote: > My philosophy is if you are going to land, then land. Do not joy > ride in the pattern. Another option is, if you're going to fly formation, learn to take off and land *in formation*. That way you get your entire wing in or out in one shot, without confusing the itinerant traffic with interval takeoffs or breaks to downwind on landing. -Rob ________________________________________________________________________________
Date: May 10, 2005
>Now for the other side of the story. Flying a standard pattern behind a >Piper Cub flying at 35 knots and doing a Bomber Pattern, (that is 5 miles >downwind, 2 miles crosswind and another 5 miles on final with a 5 minute >taxi on the runway before turn off on a taxiway) is sheer frustration for >even a Citabria Pilot. So turn base while they still have three miles to go on downwind. Just announce that you are turning base inside of the Cub doing a B-52 pattern and everything is fine. Ron Lee ________________________________________________________________________________
Date: May 10, 2005
Paul, Suggest you purchase Bob Nuckolls - AeroElectric book. We used his designs and our elecrtical systems have been rock solid and allows for future growth. In addition, Bob has answered our few questions. IMHO the small cost of his book was some of the best $$ spent on our 8A. Chuck Rowbotham RV-8A 300+ hours >From: Paul Folbrecht <paulfolbrecht(at)yahoo.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Sources for electrical system design >Date: Tue, 10 May 2005 07:57:57 -0700 (PDT) > > >Now that I've decided on priming, manual vs. electrical trim (agonizing), >engine/prop (Mattituck or Aerosports O-320 with 3-blade Catto), and a >working >version of my panel (subject to change), I want to tackle designing the >electrical system for my aircraft in the remaining 6 weeks or so I have >before >I can start construction. > >I'm not asking any specific questions, just looking for good references to >study. ________________________________________________________________________________
Date: May 10, 2005
> Wow, that's quite a bit. Is this the max draw configuration, ie. pitot > heat, landing lights, microwave oven all on at once? If so how much do > you draw under normal flying conditions? > > >I draw 48 amps, IFR all electric rv. FWIW, I'm in the same boat. With all toys running, including dual 100W landing lights, high pressure boost pump, strobes, position lights, and pitot heat, my system draws around 48A as well. Nevertheless, I use a single 40A B&C alternator on my RV-7, all-electric, IFR, single 17AH PC-680 battery. Typical current flowing from the alternator to battery with no "high power" toys running is just shy of 11A. This is with all of the avionics, engine monitor, and instruments running, without shedding any load. On my plane strobes add around 7A, position lights another 7A, each landing light (or wig-wag) another 7A, boost pump another 5A or so. Imho, every builder should do a current draw analysis on all of your toys to size your alternator needs. Or just be lazy and go with a 60A setup. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: May 10, 2005
From the people I have discussed FWF kits with, it a deletion. You can add and subtract from the FWF kit. You really do not need a muffler and in the end will not want a muffler. The prop makes most of the noise. I do not believe I have ever seen an RV with a muffler... I have heard of people using them. If your going with the Catto, you will be just fine. Darrell Paul Folbrecht wrote: I'm still a tad confused on this. Van's FWF kits include what they call a "muffler". What I think you're saying is that this "muffler" is so ineffective that it barely qualifies as one. Correct? If not, you're saying that most RVers do not use Van's FWF kits with their Lycs or do not use the Van's exhaust stack. > Most RV's have no mufflers at all... not a Van's norm... > --------------------------------- ________________________________________________________________________________
Date: May 10, 2005
Actually, after looking they are deleting the aluminum heat muff and going with the stainless one. There is no muffler in the FWF kit. Darrell Paul Folbrecht wrote: I'm still a tad confused on this. Van's FWF kits include what they call a "muffler". What I think you're saying is that this "muffler" is so ineffective that it barely qualifies as one. Correct? If not, you're saying that most RVers do not use Van's FWF kits with their Lycs or do not use the Van's exhaust stack. > Most RV's have no mufflers at all... not a Van's norm... > Darrell Reiley Round Rock, Texas RV 7A #70125 N622DR (reserved) ________________________________________________________________________________
Date: May 10, 2005
Mattituck's standard alternator option is 55A. Seems like a prudent choice given that I'll all the same "toys" as well as the LASAR ignit which I believe draws about 4A. > Imho, every builder should do a current draw analysis on all of your toys to > size your alternator needs. Or just be lazy and go with a 60A setup. > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > > > > > > > ________________________________________________________________________________
Date: May 10, 2005
----- Original Message ----- From: "Darrell Reiley" <lifeofreiley2003(at)yahoo.com> Subject: Re: RV-List: Noisy Airplanes (was Rude RV'ers) > > Actually, after looking they are deleting the aluminum heat muff and going > with the stainless one. There is no muffler in the FWF kit. > > Darrell > Yep what the listing says is at: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1115764777-100-615&browse=engines&product=FF_Kit It is "1 EA EXH W/MUFF 320/ RV-6/6A/7/7A/8/8A/9A " Now MUFF may be carburator heat muff or may be cabin heat muff but it pretty sure isn't a muffler. Haven't seen a muffler yet on a Lycoming powered RV. Yes I know there are a few, mostly in Europe though. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Subject: Joy Riding in the Pattern
Date: May 10, 2005
At my home field, the flight schools teach huge patterns to their students - wide downwinds and long finals. I guess they want them to have time to think what the next step is. They also don't do touch and goes so every landing has a taxi back. Maybe what they're really teaching is how to run up the Hobbs. That's where they make their money. The bad news is that they are also teaching them to spend a lot of time in the pattern out of gliding range to the runway. One can't turn inside them as it's a towered airport. Most arriving traffic is given a straight in and call 3 mile final. Any traffic on downwind is forced to extend. This is all well and good except that you have to slow down a fair distance from the airport at low altitude and, if your engine quits, you're landing on the road. I usually ask for the overhead approach on first call up. This lets me drive on in to the airport at good speed which I can trade for altitude if the engine quits. I start to slow down when I've got the runway made and dissipate the rest of my speed in the break. My plan is to stay close enough to make the runway if the engine quits and I think it's more realistic than the big pattern. Arriving at untowered airports is only different in that you've got to provide your own traffic avoidance and spacing. If the pattern is occupied, one must fit in with the traffic. A modified overhead approach is safer than a straight in and much the same as crossing midfield to enter downwind. I start a little higher than the pattern and turn downwind with good spacing. If the guy I'm following is slow, I practice slow flight and try to stay reasonably close to the airport. If you're arriving from the direction of the pattern side of the airport, by all means enter on the 45 to downwind. By the way, you're right. A 180 degree approach is non-standard - a 360 degree overhead approach would be much more standard. ;-) Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Subject: Re: RV-List: Joy Riding in the Pattern > The 180 overhead landing is not standard. I do formation flying, > takeoff, approach and landing, including 180 overheads, however you have > to be aware that you will startle other pilots and folks on the ground > with mass arrivals and military patterns. Some bystanders love it, and my > RV buddies think everyone should love the show. They don't all love it. > May be it is jealousy, but just be sensitive to that. Also this could be > actionable by the FAA. Patterns are not specified by the FARs except "all > turns must be made to the left unless noted otherwise." However US > Government Vs. Joe Pilot, in appeals court, has shown the AIM, which is > not regulations, does show a standard pattern and has been upheld as > de-facto law. Meaning pilots not flying the pattern per the AIM can get > the FAA shaft. Now for the other side of the story. Flying a standard pattern behind a Piper Cub flying at 35 knots and doing a Bomber Pattern, (that is 5 miles downwind, 2 miles crosswind and another 5 miles on final with a 5 minute taxi on the runway before turn off on a taxiway) is sheer frustration for even a Citabria Pilot. My philosophy is if you are going to land, then land. Do not joy ride in the pattern. Bob RV6 NightFighter ________________________________________________________________________________
Date: May 10, 2005
----- Original Message ----- From: Paul Folbrecht Subject: Re: RV-List: Re: Sources for electrical system design This alternator debate has been a tough one. I have a 60 internally regulated alt. from Van's. A few years ago, I installed the O.V, protection that opened the main cable from the alt. to battery. Turns out, that removing the alt field voltage won't shut down an internally regulated alternator, and disconnecting from the battery can cause a load dump. Haven't yet flown the plane, but it looks like I'm taking out the O.V. (over voltage) setup. There is a good discussion of this on the Matronics Aeroelectric list during the last month. Seriously? I thought all the hard decisions had been made. Damn! Is it that big a deal? I admit I'm not expert, but I've never had an alternator failure (Ok, in my measly 300 hours) or heard of one firsthand even on airplanes with very old alternators. Which I think are all externally regulated.. I guess it's another point to research.. and I guess there is probably a reason why a B&C alternator costs 2x what the one Mattituck supplies does. ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: May 11, 2005
----- Original Message ----- > Turns out, that removing the alt field voltage won't shut down an > internally regulated alternator, and disconnecting >from the battery can > cause a load dump. Haven't yet flown the plane, but it looks like I'm > taking out the O.V. (over voltage) setup. ((((((((())))))))) Good point. IR (internally regulated) alternators are so plentiful and reasonably priced. Everyone can easily accept the thought of having a problem in podunk, podunk where there is an Autozone close that has a freshly overhauled alternator replacement. No hold over, reasonable prices. BUT there is a problem, we might also like the idea of OV protection, LV warning, and perhaps the ability to adjust the voltage up or down a tenth or two. That is where the IR alt does not work. SO,,,,,,decide whether you can live with IR and its risks --or-- NR (non regulated) with OV/LV regulator. Vans sells a NR alternator but you can't be running your electric copier while flying =:-) Bob of Aeroelectric advocates the NR alternator. Whichever way you go with, you have some risks, which you should understand, and their costs. Yearly out of pocket cost appears to be lower by not using a fresh battery every year as Bob advocates. However the risk is lowered with Bob's admonition. Risk vs. cost. You understand them and make and fly your decision within the design and needs of your flying. I found that I revised some of my flying goals to make the components in my electrical system more acceptable risk-cost wise. I recommend, if you haven't already done so, to get a copy of Aeroelectric Bob's manual and read it at least twice. A few nights well spent. No, I am not on Bob's payroll, I am just happen my RV7 is flying using one of his wiring designs and appears to not have any electrical problems. And I more fully understand what Indiana Larry, RV7 Tip Up FLYING - Phase 1 Flight Testing ________________________________________________________________________________
Date: May 11, 2005
Subject: Re: Just trashing my first flap!!
In a message dated 5/11/05 6:37:28 AM Central Daylight Time, afulmer(at)charter.net writes: > I still don't know how I will get my fat hand on a bucking bar over those > bottom rib/top skin rivets? And I think I will get my wife to help hold the > flap steady in the v-blocks. >>> I had good luck using a modified splitting wedge for a bucking bar- seems it came in real handy on the flap ribs and also for all the rear control surface rivets. There's enough mass in it to help control it when banging on the skinny end. Mark Phillips ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Date: May 11, 2005
Are you sure that what you are referencing is not the "cabin heat muff" or "carb heat muff"? The widely used Vetterman cross-over exhausts that I suspect most of us use is non-mufflered as far as I know. James | -----Original Message----- | From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- | server(at)matronics.com] On Behalf Of Paul Folbrecht | Sent: Tuesday, May 10, 2005 4:17 PM | To: rv-list(at)matronics.com | Subject: Re: RV-List: Noisy Airplanes (was Rude RV'ers) | | | I'm still a tad confused on this. Van's FWF kits include what they call | a | "muffler". What I think you're saying is that this "muffler" is so | ineffective | that it barely qualifies as one. Correct? If not, you're saying that | most | RVers do not use Van's FWF kits with their Lycs or do not use the Van's | exhaust | stack. | | > Most RV's have no mufflers at all... not a Van's norm... | > | | | | | ________________________________________________________________________________
Date: May 11, 2005
Thanks Mike for posting this. I was about to look up the pages and diagrams to post with my notes below. For those who might not have experienced this from inside a plane, it is not only legal but is understood at the "big airports with picky controllers that will remind you if you are doing anything wrong :-) ". If you ask properly they will not only oblige, they will vector you into position (mindful of other traffic) and sometimes call the point for lead to make the first turn. Of course at some (non-towered) airports when it is first introduced, there may be people in the pattern that are wondering what is going on (they might not be familiar with the AIM reference below), but a courteous (and quick) explanation works wonders. This I have experienced. Finally, upon returning to the home base airport in IFR conditions (riding with the FBO owner, Aeronautics Commission member, bazillion hour pilot) this maneuver was performed after we broken out in the clear on the localizer approach. He pointed out to me how it was a MUCH safer approach as even though the ceilings were a bit low, it was still LEGAL for VFR traffic to be in the pattern. James | -----Original Message----- | From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- | server(at)matronics.com] On Behalf Of Stewart, Michael (ISS Atlanta) | Sent: Tuesday, May 10, 2005 5:18 PM | To: rv-list(at)matronics.com | Subject: RE: RV-List: Joy Riding in the Pattern | | | | OK here we go again on the overheads. | They are very standard and are defined in the AIM chapter 5. Quote | below. Searchable here: | http://www.faa.gov/ATpubs/AIM/Chap5/aim0504.html | {SNIP} ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Subject: New pitot/ static offerings
Date: May 11, 2005
A few months ago there was a thread about the poor choices available for pitot tubes and static port kits. We have just received our first batch of CNC machined pitot tubes and they look beautiful! Please have a look http://www.evansaviationproducts.com/Other%20Products.htm The pitot kit comes complete with the mast and all of the hardware you need for a super clean installation. I believe this is the only kit available right now as a complete package....most others require you to go searching for the components from different sources. You will find a significant cost savings with the kit as well as really nice hardware. We are currently prototyping a heated version, but it is still a bit down the road. Cheers, Evan Johnson www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ________________________________________________________________________________
Subject: Mason City 3rd annual RV Formation Clinic
Date: May 11, 2005
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Its that time of year for the Mason City Iowa 3 day formation clinic. Its held the weekend before Oshkosh so you can gear up and head in for the show. This is one of several clinics held around the country. The training program is provided by Team RV with support from other talented folks to include the SoCal group, Falcon Flight, Buckeye flight and others. These RV'ers have lots of formation experience and freely give of their time and money to provide this training free of charge. Obviously they are not in it for the money, but the love of the game. You will not receive a better training in your RV than what these teams provide. The training is intense and carefully checked by experienced pilots and instructors. Im sure participants from past years will chime in and provide you some feedback on the value and activities. Its more fun than should be allowed. Great planes, great flying, and as always..... great people. Details can be found at the website below. Doug Rozendaal is our host. You all should know him from his excellent posts on the RV-list. Last year our training culminated in a 13 ship on a P-51D Mustang, Mustang flown by Doug. Fun had by all. http://www.mstewart.net/teamrv/formationclinic/masoncity05 Hope to see you there. Kahuna Aka Mike Stewart ________________________________________________________________________________
Date: May 11, 2005
From: "David E. Nelson" <david.nelson(at)pobox.com>
15, 2004) at 05/11/2005 09:39:05 AM, Serialize by Router on MailServ59-US/AUS/H/NIC(Release 6.5.3FP1|December 15, 2004) at 05/11/2005 09:39:07 AM, Serialize complete at 05/11/2005 09:39:07 AM Hi Mark, As I'm getting to do this... Are you talking about a wedge for splitting wood? And what type of modifications? Got a picture? Thanks, /\/elson RV-7A - Feveristly finishing the wings before the fus shows up Austin, TX On Wed, 11 May 2005 Fiveonepw(at)aol.com wrote: > I had good luck using a modified splitting wedge for a bucking bar- seems it > came in real handy on the flap ribs and also for all the rear control surface > rivets. There's enough mass in it to help control it when banging on the > skinny end. > > Mark Phillips ________________________________________________________________________________
Date: May 11, 2005
Subject: Re: Just trashing my first flap!! 15, 2004) at 05/11/2005 09:39:05
A... In a message dated 5/11/05 9:43:42 AM Central Daylight Time, david.nelson(at)pobox.com writes: > Are you talking about a wedge for splitting wood? And what type of > modifications? Got a picture? >>> Yep- maybe $10-12 down at the local hardware store, WallyWorld or Lowes Depot. These come kind of rough- you'll need one good surface on both sides down near the pointy end. As purchased, mine had too much radius along the side near the point, so I ground it flatter (on the side) until I could get a fairly square edge, then polished both sides and dulled the original cutting edge to avoid scratching any metal it might contact. What you're shooting for is a good bucking surface close to the very end of the wedge on both sides so you can flip it over to get 'em from both directions. Sorry, but don't think I ever took a foto of it... And if it don't work, it still makes a nice doorstop, or you can even split farwood with it! Mark ________________________________________________________________________________
Date: May 11, 2005
----- Original Message ----- From: "James E. Clark" <james(at)nextupventures.com> Subject: RE: RV-List: Joy Riding in the Pattern > > Thanks Mike for posting this. I was about to look up the pages and > diagrams > to post with my notes below. > > For those who might not have experienced this from inside a plane, it is > not > only legal but is understood at the "big airports with picky controllers > that will remind you if you are doing anything wrong :-) ". If you ask > properly they will not only oblige, they will vector you into position > (mindful of other traffic) and sometimes call the point for lead to make > the > first turn. > > Of course at some (non-towered) airports when it is first introduced, > there > may be people in the pattern that are wondering what is going on (they > might not be familiar with the AIM reference below), but a courteous (and > quick) explanation works wonders. This I have experienced. > > Finally, upon returning to the home base airport in IFR conditions (riding > with the FBO owner, Aeronautics Commission member, bazillion hour pilot) > this maneuver was performed after we broken out in the clear on the > localizer approach. He pointed out to me how it was a MUCH safer approach > as > even though the ceilings were a bit low, it was still LEGAL for VFR > traffic > to be in the pattern. > > James > > > | -----Original Message----- > | From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > | server(at)matronics.com] On Behalf Of Stewart, Michael (ISS Atlanta) > | Sent: Tuesday, May 10, 2005 5:18 PM > | To: rv-list(at)matronics.com > | Subject: RE: RV-List: Joy Riding in the Pattern > | > | > | > | OK here we go again on the overheads. > | They are very standard and are defined in the AIM chapter 5. Quote > | below. Searchable here: > | http://www.faa.gov/ATpubs/AIM/Chap5/aim0504.html > | > {SNIP} > > > ________________________________________________________________________________
Date: May 11, 2005
Subject: Just trashing my first flap!!
Allen What weight bar are you using? I've found that my riveting has been transformed since I got an aerospace surplus 3lb bar off ebay. Previously I was having problems when using some of the recommended lighter bars. This new one will buck 3/32" rivets without any pressure other than its own weight. I've only got a cheap manual squeezer so am bucking nearly everything (including all 1/8" rivets). As long as I can get the heavy bar in it is no problem. Also, I don't subscribe to the swivel flush set argument. I use a 1.5" solid flush set with a neoprene ring round the edge. I've had no problems with smilies as the set is big enough to guarantee its aligned. Best regards Peter ----- Original Message ----- From: "Allen Fulmer" <afulmer(at)charter.net> Subject: RE: RV-List: Just trashing my first flap!! Date: Wed, 11 May 2005 06:34:41 -0500 > > > Swivel flush set was in use. I DID try a little boost in air pressure as it > "seemed" I was having to rat-a-tat-tat too long on the bottom side. And I > WAS getting some "bounce" on the bottom side, but reasoned it was acceptable > since it was the bottom. I don't have a pressure gage on the gun but one of > those little regulators with a numbered knob you can adjust. Setting has > stayed the same for wings and ailerons. By the time I reduced the > "regulator" on the gun back to where it had been the damage had been done > and I was too frustrated to be able to think straight anyway. > > I still don't know how I will get my fat hand on a bucking bar over those > bottom rib/top skin rivets? And I think I will get my wife to help hold the > flap steady in the v-blocks. > > I know others have probably had to work through similar disappointments and > I will too. > > Thanks for the help. > > Allen > ________________________________________________________________________________
Date: May 11, 2005
From: Chris W <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net>
Subject: Noisy Airplanes and Altitude
I was just curious how high you would have to be for the sound level on the ground to be low enough that it probably wouldn't be hard in someones house. Maybe there is a formula of x DB drop per 1000 feet of altitude. Does anyone know? -- Chris W ________________________________________________________________________________
Subject: PC680hd (Battery hold down)
Date: May 11, 2005
I was going to use the PC680 hold down to mount a PC680 battery in my RV-8. I decided against it,because the battery cannot be removed without removing the hold down. There is a lip on the hold down,and then the engine mount is in the way Has anyone else used the hold down on the firewall? GEORGE H. INMAN ghinman(at)mts.net CELL 204 799 7062 HOME 204 287 8334 ________________________________________________________________________________
Date: May 11, 2005
I did some reading. I think I will go with the B&C alternator. I think I will need the 60A too which is $600 - ouch!! --- LARRY ADAMSON wrote: > > > ----- Original Message ----- > From: Paul Folbrecht > To: rv-list(at)matronics.com > Subject: Re: RV-List: Re: Sources for electrical system design > > > > This alternator debate has been a tough one. I have a 60 internally regulated > alt. from Van's. A few years ago, I installed the O.V, protection that opened > the main cable from the alt. to battery. Turns out, that removing the alt > field voltage won't shut down an internally regulated alternator, and > disconnecting from the battery can cause a load dump. Haven't yet flown the > plane, but it looks like I'm taking out the O.V. (over voltage) setup. There > is a good discussion of this on the Matronics Aeroelectric list during the > last month. > > > Seriously? I thought all the hard decisions had been made. Damn! > > Is it that big a deal? I admit I'm not expert, but I've never had an > alternator failure (Ok, in my measly 300 hours) or heard of one firsthand > even > on airplanes with very old alternators. Which I think are all externally > regulated.. I guess it's another point to research.. and I guess there is > probably a reason why a B&C alternator costs 2x what the one Mattituck > supplies > does. > > > > > > > > ________________________________________________________________________________
Subject: Lycoming O-360 A1A for Sale
Date: May 11, 2005
I have a Lycoming 0-360 A1A for sale. $8500 1700 TTSN 1000 since TOH. Has carburator and starter, no other accessories. Set up for constant speed with a govenor pad and line from govenor to prop. Wide Deck. This engine came out of a piper navajo that had the O-360 conversion done. I bought both engines. One for my rv-6a project and one for my wifes rv-4. She had decided that she wants a new XP-360 instead so I am selling her engine. Buyer has to pay shipping and crating costs or come and pick it up. Contact Tom Velvick in Peoria, AZ at 623-261-2906 cell, 623-979-2519 home phone. My email is tomvelvick(at)cox.net ________________________________________________________________________________
From: "Bob Hodgson" <bob(at)hodgson252.freeserve.co.uk>
Subject: Re: Mufflers on Rv's
Date: May 11, 2005
"Prop noise is loudest" - not necessarily, and it's very 'peaky' in line with the plane of the prop. Keep helical tip speed below around 800 fps and you avoid the annoying T6 blare. Not a problem on fixed pitch props unless they're very fine, and on a CS prop that allows 2700 rpm on take-off, just get back to 25/25 as soon as safely possible after take-off. Exhaust noise remains the dominant factor for most of the time an aeroplane is overflying, and as for mufflers, the Swiss type in Tony Bingelis' books works well for damping out the high frequencies. However the Lycoming sound spectrum shows highest powers under 800Hz. An expansion chamber muffler of adequate volume (say over 270 cu in) should work better for these low frequencies. Even treating the ends of the exhaust pipes as per the Wicks 'piccolo' takes some of the 'bite' out of the sound. Some German companies have done successful work on certificated mufflers and will be happy to sell you a couple (for enormous piles of euros!) They are much smaller / lighter than the Swiss muffler in Tony's book. Have a Google for Gomolzig and Liese for starters. Our Popular Flying Association takes noise reduction seriously, and some info can be found on their website: http://www.pfa.org.uk/engineering_services/silencing_papers.asp Performance loss may be less than feared using these new free-breathing mufflers. If the length of pipe is tuned to say 2500rpm, it may not even happen, according to some reports. My RV is not yet flying, so I can't quote actual figures yet. I do however intend to take before and after readings when playing around with mufflers. You can still legally fly an 'experimental' without any muffler over here in the UK, but for how long?? We've lost a lot of airfields to noise complaints, so have to disarm the critics before they shut us down completely. Just my 2c /pence worth, YMMV etc Bob (RV3B - still starting 'finishing') ________________________________________________________________________________
Date: May 11, 2005
> > Mike, so you are telling us that everytime you do an overhead break to a > landing you have been on an IFR flight plan? I seriously doubt it, > especially when you are in formation flight. According to the source you > quote, that is the only time it is allowed. > Don Don: How do you get that interpretation? The source says, "Pilots operating in accordance with an IFR flight plan in Visual Meteorological Conditions (VMC) may request ATC authorization for an overhead maneuver." It says nothing whatsoever about when an overhead may not be used. Tedd McHenry Surrey, BC, Canada ________________________________________________________________________________
Date: May 11, 2005
09":39:05.A...@roxy.matronics.com
09:39:05 A... 15, 2004) at 05/11/2005 03:08:39 PM, Serialize by Router on MailServ58-US/AUS/H/NIC(Release 6.5.3FP1|December 15, 2004) at 05/11/2005 03:08:41 PM, Serialize complete at 05/11/2005 03:08:41 PM Thanks Mark, I've got an better idea/vision of what you are talking about. Thanks, /\/elson On Wed, 11 May 2005 Fiveonepw(at)aol.com wrote: > Yep- maybe $10-12 down at the local hardware store, WallyWorld or Lowes > Depot. These come kind of rough- you'll need one good surface on both sides down > near the pointy end. As purchased, mine had too much radius along the side > near the point, so I ground it flatter (on the side) until I could get a fairly > square edge, then polished both sides and dulled the original cutting edge to > avoid scratching any metal it might contact. What you're shooting for is a > good bucking surface close to the very end of the wedge on both sides so you can > flip it over to get 'em from both directions. Sorry, but don't think I ever > took a foto of it... > > And if it don't work, it still makes a nice doorstop, or you can even split > farwood with it! > > Mark ________________________________________________________________________________
Subject: plane flew into restricted airspace
Date: May 11, 2005
C 152 w/ 2 men on board violated no fly zone White House and Congress evacuated red level alert stock market dived because of the security scare this incident made me angry, frustrated and very sad I just shook my head in disbelief there was much over reaction to the real threat but if we GA pilots keep doing this we will lose any freedom we have to fly who do we have to blame but ourselves ( or a few rotten ones among us) ----- Original Message ----- From: "Bob Hodgson" <bob(at)hodgson252.freeserve.co.uk> Subject: Re: RV-List: Mufflers on Rv's > > "Prop noise is loudest" - not necessarily, and it's very 'peaky' in line > with the plane of the prop. Keep helical tip speed below around 800 fps and > you avoid the annoying T6 blare. Not a problem on fixed pitch props unless > they're very fine, and on a CS prop that allows 2700 rpm on take-off, just > get back to 25/25 as soon as safely possible after take-off. > > Exhaust noise remains the dominant factor for most of the time an aeroplane > is overflying, and as for mufflers, the Swiss type in Tony Bingelis' books > works well for damping out the high frequencies. However the Lycoming sound > spectrum shows highest powers under 800Hz. An expansion chamber muffler of > adequate volume (say over 270 cu in) should work better for these low > frequencies. Even treating the ends of the exhaust pipes as per the Wicks > 'piccolo' takes some of the 'bite' out of the sound. Some German companies > have done successful work on certificated mufflers and will be happy to sell > you a couple (for enormous piles of euros!) They are much smaller / lighter > than the Swiss muffler in Tony's book. Have a Google for Gomolzig and Liese > for starters. > > Our Popular Flying Association takes noise reduction seriously, and some > info can be found on their website: > http://www.pfa.org.uk/engineering_services/silencing_papers.asp > > Performance loss may be less than feared using these new free-breathing > mufflers. If the length of pipe is tuned to say 2500rpm, it may not even > happen, according to some reports. > > My RV is not yet flying, so I can't quote actual figures yet. I do however > intend to take before and after readings when playing around with mufflers. > You can still legally fly an 'experimental' without any muffler over here in > the UK, but for how long?? We've lost a lot of airfields to noise > complaints, so have to disarm the critics before they shut us down > completely. > > Just my 2c /pence worth, YMMV etc > > Bob > > (RV3B - still starting 'finishing') > > ________________________________________________________________________________
Date: May 11, 2005
I believe that the original post used an IFR scenario to justify all uses of this approach. Ron Lee > > Mike, so you are telling us that everytime you do an overhead break to a > > landing you have been on an IFR flight plan? I seriously doubt it, > > especially when you are in formation flight. According to the source you > > quote, that is the only time it is allowed. > > Don > >Don: > >How do you get that interpretation? The source says, "Pilots operating in >accordance with an IFR flight plan in Visual Meteorological Conditions (VMC) >may request ATC authorization for an overhead maneuver." It says nothing >whatsoever about when an overhead may not be used. > >Tedd McHenry >Surrey, BC, Canada > > ________________________________________________________________________________
Date: May 11, 2005
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Subject: Heavy Wing
Read this for starters www.vansaircraft.com/pdf/Wing_Heavy.pdf Darrell Reiley Round Rock, Texas RV 7A #70125 N622DR (reserved) ________________________________________________________________________________
Date: May 11, 2005
Subject: Re: Is there interest in an Oct fly-in to Albuquerque, NM?
Hi Ron. How is the EASTER EGG doing? Wish we had kept it. Flying a 7 right now and hope to come to LOE 5. Are u suggesting a change of dates for LOE to coincide with the balloon activities? Regards, Doug ________________________________________________________________________________
Date: May 11, 2005
> > I believe that the original post used an IFR scenario to justify all uses > of this approach. If I'm reading the posts in the right order, that's true. But, unless I missed the post, there so far hasn't been any reference presented that suggests overhead breaks are for IFR flights only. Can someone provide such a reference? Tedd McHenry Surrey, BC, Canada ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Subject: Flightline Interiors - Comments FYI
Date: May 11, 2005
Decided to cheat and ordered a custom interior from Abby at Flightline Interiors for my 7a. Having a golf club compartment and lower baggage access panels complicated that area immensely. Also wanted something a little different on the seats. All the stuff came today, some 30 separate pieces and I am totally amazed at the workman(woman)ship and detail. Won't have it installed for a while but simply had to put in a plug for Abby after having the finished product in my hand! Now that she is not working on mine, I would highly recommend her operation! You will not be disappointed. Thanks Bill S 7a Ark fuse/panel ________________________________________________________________________________
Date: May 11, 2005
From: Ron Lee <ronlee(at)pcisys.net> Albuquerque, NM?(at)roxy.matronics.com
Albuquerque, NM? > Are u suggesting a change of dates for LOE to coincide with the > balloon activities? >Regards, >Doug Absolutely not. This has nada to do with LOE. This is a possible new fly-in opportunity that offers different things to see and do than LOE Ron ________________________________________________________________________________
Date: May 11, 2005
Subject: Re: Flightline Interiors - Comments FYI
I have to second this. Abby did my interior and I am verrrrrry happy with it. Tim RV6 - N616TB DNA -------Original Message------- From: Bill Schlatterer Date: 05/11/05 18:19:03 Subject: RV-List: Flightline Interiors - Comments FYI net> Decided to cheat and ordered a custom interior from Abby at Flightline Interiors for my 7a. Having a golf club compartment and lower baggage access panels complicated that area immensely. Also wanted something a little different on the seats. All the stuff came today, some 30 separate pieces and I am totally amazed at the workman(woman)ship and detail. Won't have it installed for a while but simply had to put in a plug for Abby after having the finished product in my hand! Now that she is not working on mine, I would highly recommend her operation! You will not be disappointed. Thanks Bill S 7a Ark fuse/panel ________________________________________________________________________________
Date: May 11, 2005
OK. I wish the timing was such that I could make both in one trip. dp ________________________________________________________________________________
Date: May 11, 2005
I'm lucky enough to live just a few miles from Abby and lucky enough to have flown in one of the 7s she did (and also flew in herself I undertand) and it is indeed impeccable. Interior's a no-brainer for me when I get to that stage! --- Tim Bryan wrote: > > I have to second this. Abby did my interior and I am verrrrrry happy with > it. > Tim > RV6 - N616TB > DNA > > -------Original Message------- > > From: Bill Schlatterer > Date: 05/11/05 18:19:03 > To: rv-list(at)matronics.com; RV7and7A(at)yahoogroups.com > Subject: RV-List: Flightline Interiors - Comments FYI > > net> > > Decided to cheat and ordered a custom interior from Abby at Flightline > Interiors for my 7a. Having a golf club compartment and lower baggage > access panels complicated that area immensely. Also wanted something a > little different on the seats. All the stuff came today, some 30 separate > pieces and I am totally amazed at the workman(woman)ship and detail. Won't > have it installed for a while but simply had to put in a plug for Abby after > having the finished product in my hand! > > Now that she is not working on mine, I would highly recommend her operation! > You will not be disappointed. > > > Thanks Bill S > 7a Ark fuse/panel > > > > > > > > ________________________________________________________________________________
Subject: Re: [RV7Yahoo] Flightline Interiors - Comments FYI
Date: May 11, 2005
I echo your sentiments. I had already chosen a material and wanted someone familiar with RV seats to use my stuff. She gladly accepted. I received my seats and everything fits great. FYI, I asked her how she liked the material. (White leather like material and blue microfiber for the center pieces.) She said it was refreshing from the usual tans and grays most people pick:) Darwin N. Barrie P19 ----- Original Message ----- From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net> Subject: [RV7Yahoo] Flightline Interiors - Comments FYI > Decided to cheat and ordered a custom interior from Abby at Flightline > Interiors for my 7a. Having a golf club compartment and lower baggage > access panels complicated that area immensely. Also wanted something a > little different on the seats. All the stuff came today, some 30 separate > pieces and I am totally amazed at the workman(woman)ship and detail. Won't > have it installed for a while but simply had to put in a plug for Abby after > having the finished product in my hand! > > Now that she is not working on mine, I would highly recommend her operation! > You will not be disappointed. > > > Thanks Bill S > 7a Ark fuse/panel > > > Help save the life of a child. Support St. Jude Children's Research Hospital's > 'Thanks & Giving.' > http://us.click.yahoo.com/6iY7fA/5WnJAA/Y3ZIAA/1yWplB/TM > > > Van's Air Force - World Wide Wing > www.vansaircraft.net > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/RV7and7A/ > > <*> To unsubscribe from this group, send an email to: > RV7and7A-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > ________________________________________________________________________________
Date: May 11, 2005
Since those devices restrict flow but don't drop the pressure, my theory is that the first hit from the rivet gun is at whatever the line pressure is and then the restricted flow keeps the pressure from building up on subsequent hits. As soon as you stop riveting, the line pressure will build up again ready for the next smile. I'd say throw those devices away and get a pressure regulator or better yet a combination regulator/oiler/water trap. You need to oil your tool from time to time. Albert Gardner RV-9A 872RV Yuma, AZ I don't have a pressure gage on the gun but one of > those little regulators with a numbered knob you can adjust. Setting has > stayed the same for wings and ailerons. By the time I reduced the > "regulator" on the gun back to where it had been the damage had been done > and I was too frustrated to be able to think straight anyway. ________________________________________________________________________________
Date: May 12, 2005
From: "Richard E. Tasker" <retasker(at)optonline.net>
I will second this endorsement. I recently received my RV9A interior and was amazed by the number of pieces included. She provides precut pieces for just about every exposed surface in the cockpit area - including under the panel and the sidewalls under the instrument area. She covered Oregon Aero seats for my installation and they look great! The quality is top notch! She also provides pictorial directions for where each and every piece goes and in what order to install them. As Bill says, now that she is finished with mine I would highly recommend her work. Dick Tasker Bill Schlatterer wrote: > >Decided to cheat and ordered a custom interior from Abby at Flightline >Interiors for my 7a. Having a golf club compartment and lower baggage >access panels complicated that area immensely. Also wanted something a >little different on the seats. All the stuff came today, some 30 separate >pieces and I am totally amazed at the workman(woman)ship and detail. Won't >have it installed for a while but simply had to put in a plug for Abby after >having the finished product in my hand! > >Now that she is not working on mine, I would highly recommend her operation! >You will not be disappointed. > > >Thanks Bill S >7a Ark fuse/panel > > > > -- ---- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. ---- ________________________________________________________________________________
Date: May 12, 2005
I agree. I started with one and almost immediately removed it and used a real regulator. Much better control. Dick Tasker Albert Gardner wrote: > >Since those devices restrict flow but don't drop the pressure, my theory is >that the first hit from the rivet gun is at whatever the line pressure is >and then the restricted flow keeps the pressure from building up on >subsequent hits. As soon as you stop riveting, the line pressure will build >up again ready for the next smile. I'd say throw those devices away and get >a pressure regulator or better yet a combination regulator/oiler/water >trap. You need to oil your tool from time to time. >Albert Gardner >RV-9A 872RV >Yuma, AZ > > > > >> >> >I don't have a pressure gage on the gun but one of > > >>those little regulators with a numbered knob you can adjust. Setting has >>stayed the same for wings and ailerons. By the time I reduced the >>"regulator" on the gun back to where it had been the damage had been done >>and I was too frustrated to be able to think straight anyway. >> >> > > > > -- ---- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. ---- ________________________________________________________________________________
Date: May 12, 2005
Subject: Re: Noisy Airplanes and Altitude
Something about diminishing by the square of the distance... Finn Chris W wrote: > >I was just curious how high you would have to be for the sound level on >the ground to be low enough that it probably wouldn't be hard in >someones house. Maybe there is a formula of x DB drop per 1000 feet of >altitude. Does anyone know? > > > ________________________________________________________________________________
Date: May 11, 2005
Subject: Re: Mufflers for RVs (Was Re: Noisy Airplanes)
Has anybody used the exhaust system from Aircraft Exhaust Technologies http://www.aircraftexhaust.net? According to their web site, they have a stainless steel crossover system that includes two mufflers that are small enough to fit inside the cowl of an RV-6, RV-6A, RV-7, RV-7A, RV-8, RV-8A, RV-9, or RV-9A. Besides reducing sound, they are supposed to increase cabin heat, too. Mark ________________________________________________________________________________
Subject: Re: New pitot/ static offerings
Date: May 12, 2005
On 11-May-05, at 10:56 AM, Evan and Megan Johnson wrote: > > > A few months ago there was a thread about the poor choices available > for pitot tubes and static port kits. We have just received our first > batch of CNC machined pitot tubes and they look beautiful! Please have > a look http://www.evansaviationproducts.com/Other%20Products.htm > The pitot kit comes complete with the mast and all of the hardware you > need for a super clean installation. I believe this is the only kit > available right now as a complete package....most others require you > to go searching for the components from different sources. You will > find a significant cost savings with the kit as well as really nice > hardware. We are currently prototyping a heated version, but it is > still a bit down the road. > Cheers, > Evan Johnson > www.evansaviationproducts.com > (530)247-0375 > (530)351-1776 cell > > The pitot tubes look great. The static ports look great too, but people need to understand that a flush port may not provide an accurate static source on RVs. It seems that the static pressure in the area of the recommended aft fuselage location is not the same as the free-stream ambient pressure. The protruding pop rivet head is needed, as it forces the air flow to accelerate around it, causing the pressure at the static port to be decreased. Several builders have found that flush static ports resulted in indicated airspeeds and altitudes that were too low. One report showed a difference of about 10 kt in indicated airspeed, and 100 - 200 ft of altimeter error at cruise speed. Many other builders probably haven't done the testing to know the difference, and they might just wonder why their RV's indicated airspeeds are a bit lower than everyone else's RV. If looks are more important to you than accurate airspeed and altitude indications, then by all means go for flush static ports. There is lots of info in the archives on this, including reports from people who found flush static ports gave them errors in IAS and/or altitude. Info on how to test your static system accuracy is on my web site: http://www.kilohotel.com/rv8/rvlinks/ssec.html Kevin Horton Ottawa, Canada RV-8 - Finishing Kit http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: May 12, 2005
Subject: RE: Joy Riding in the Pattern
> > > Points addressed below: > > > -----Original Message----- > From: gmcjetpilot(at)yahoo.com [mailto:gmcjetpilot(at)yahoo.com] > Subject: Joy Riding in the Pattern <...> > > > Also, to avoid doing aerobatics in the pattern by definition (far > 91.307), bank angles must be limited to 60 degree bank. Many RV 180 > breaks are done at high initial speeds and large (up to 90 degree) > initial bank angles. There is nothing making this cool to the FAA. > Again some think it looks great but it tends to get people excited > in a bad way when they see a 90 degree bank in the pattern. > > I did not recommend any aerobatic maneuvers or even suggest how > to execute the maneuver. <...> CFR 91.307 does not address or "define" aerobatics. It addresses parachutes and parachuting. It explains that occupants *other* *than* *crew* *members* must wear a parachute if the aircraft exceeds 60 degrees bank or 30 degrees pitch. It does not *limit* the angles of bank or pitch. CFR 91.307 is included below. Look through it all, but in particular, read through 91.307(c). Note that many high-performance aerobatic aircraft can reach high nose-up angles easily, but that may also be the angle needed for their Vx/Vy. If you want to argue the aerobatic flight angle, at least reference the correct CFR: 91.303. Note, though, that that CFR does not limit angles either. It simply states this: "For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight." That, of course, opens up interpretation as to "normal flight". I have not reproduced the entire CFR 91.303 here. I'll leave that as an exercise for those who want to argue it to do the research first. ##### 91.307 Parachutes and parachuting. (a) No pilot of a civil aircraft may allow a parachute that is available for emergency use to be carried in that aircraft unless it is an approved type and (1) If a chair type (canopy in back), it has been packed by a certificated and appropriately rated parachute rigger within the preceding 120 days; or (2) If any other type, it has been packed by a certificated and appropriately rated parachute rigger (i) Within the preceding 120 days, if its canopy, shrouds, and harness are composed exclusively of nylon, rayon, or other similar synthetic fiber or materials that are substantially resistant to damage from mold, mildew, or other fungi and other rotting agents propagated in a moist environment; or (ii) Within the preceding 60 days, if any part of the parachute is composed of silk, pongee, or other natural fiber, or materials not specified in paragraph (a)(2)(i) of this section. (b) Except in an emergency, no pilot in command may allow, and no person may conduct, a parachute operation from an aircraft within the United States except in accordance with part 105 of this chapter. (c) Unless each occupant of the aircraft is wearing an approved parachute, no pilot of a civil aircraft carrying any person (other than a crewmember) may execute any intentional maneuver that exceeds (1) A bank of 60 degrees relative to the horizon; or (2) A nose-up or nose-down attitude of 30 degrees relative to the horizon. (d) Paragraph (c) of this section does not apply to (1) Flight tests for pilot certification or rating; or (2) Spins and other flight maneuvers required by the regulations for any certificate or rating when given by (i) A certificated flight instructor; or (ii) An airline transport pilot instructing in accordance with 61.67 of this chapter. (e) For the purposes of this section, approved parachute means (1) A parachute manufactured under a type certificate or a technical standard order (C23 series); or (2) A personnel-carrying military parachute identified by an NAF, AAF, or AN drawing number, an AAF order number, or any other military designation or specification number. [Doc. No. 18334, 54 FR 34308, Aug. 18, 1989, as amended by Amdt. 91255, 62 FR 68137, Dec. 30, 1997; Amdt. 91268, 66 FR 23553, May 9, 2001] ##### -- Alan Reichert Priv, Inst, SEL RV-8 N927AR (reserved) Prepping Horizontal/Vertical Stabilizers for Assembly ________________________________________________________________________________
Subject: Re: Mufflers for RVs (Was Noisy Airplanes)
Date: May 12, 2005
I have read with interest the "swiss muffler" blog, and also the info on RV mufflers on Aircraft Exaust site, I will call them when they open and post my findings. I for one highly dislike the noise our planes produce and so do a lot of other people. Like it or not, airports everywhere are under attack for just the noise factor. I am sure many would defend their right to make as much noise as they want and would point to the fact that we in the USA are not under any noise restrictions YET. I woulnt mind giving up a small amount of performance for a quieter plane. Charlie heathco ________________________________________________________________________________
Date: May 12, 2005
In a message dated 5/11/05 9:59:11 PM Central Daylight Time, ibspud(at)adelphia.net writes: > I'd say throw those devices away and get > a pressure regulator or better yet a combination regulator/oiler/water > trap. You need to oil your tool from time to time. >>>> Agree on use of regulator- a good regulator at the compressor is the way to go, but best avoid any automatic oiler- If an oiler is placed upstream of the hoses, these same hoses can not be used for any priming or painting as they will be contaminated with oil- it's easy to just add a few drops of oil to the gun inlet occasionally, or before each extended riveting or drilling session to keep your tool well-lubed! Also consider that using larger hoses will reduce the pressure drop once the tool is activated- the plastic coiled hose is particularly notorious for this- all that going round & round adds centrifugal force to the air, slowing it down as Gs build in the airstream! 8-) (well, not really on the G stuff, but don't use 'em for riveting, anyway!) Also be sure to drain your compressor tank regularly- amazing how much water is in the air, particularly in humid locations. From The PossumWorks in TN Mark Phillips -6A, flying ________________________________________________________________________________
Subject: "new" regulation re taking pasengers in hombuilts?
Date: May 12, 2005
The FAA is underscoring regulatory requirements for pilots who fly passengers in homebuilt aircraft. A new notice would restrict them to flying passengers only in planes in which they are qualified and experienced. Currency and proficiency rules apply to those who take people for rides in their experimental aircraft and EAA says current pilots have until Aug. 31, 2005, to prove they have the necessary category and class ratings for the aircraft they fly. This is the first Ive heard of this, am I the only one in the dark about it? charlie heathco (this is from Avweb) ________________________________________________________________________________
Date: May 12, 2005
Having watched this noise thread....I guess I love the noise of airplanes.....one of the many things I enjoy about them. I understand that many dont feel this way. For this reason we probably should be moving in the direction of quieter engines and better controlled props. Dont be deceived into believing that the airport/airplane dissidents will go away though....the only way many will be happy is if your engine simply doesn't run. We can then all sit out on the ramp, in formation, making engine noises as far as many of them are concerned. But....be sure, someone will protest that, too. While some airplane/airport detractors have legitimate concerns, the 'rush' of many, if not most, comes simply from being 'involved'....not really having a dog in the fight. I wish they knew how much they were messing with the wholesome enjoyment of a lot of good people. Tony Marshall RV6 Polson, MT ----- Original Message ----- From: "Charles Heathco" <cheathco(at)comcast.net> Subject: Re: RV-List: Mufflers for RVs (Was Noisy Airplanes) > > I have read with interest the "swiss muffler" blog, and also the info on > RV mufflers on Aircraft Exaust site, I will call them when they open and > post my findings. I for one highly dislike the noise our planes produce > and so do a lot of other people. Like it or not, airports everywhere are > under attack for just the noise factor. I am sure many would defend their > right to make as much noise as they want and would point to the fact that > we in the USA are not under any noise restrictions YET. I woulnt mind > giving up a small amount of performance for a quieter plane. Charlie > heathco > > > ________________________________________________________________________________
Date: May 12, 2005
It is a new requirement that came out just recently with the light sport changes. It is in FAR 61.31(k)(2). This is the FAR that previously made it possible for multi-engine Experimental aircraft to be flown without having a multi-engine pilot's certificate. The wording in 61.31(k)(1) has not changed and still excludes non-type certificate aircraft from needing a categroy and class rating. But 61.31(k)(2) changed clarifying that a categroy and class rating is needed if a passenger is being carried. For the vast majority of people this will mean nothing new as the FAA has been including wording in the aircraft Operating Limitations requiring a categroy and class rating since the mid 90's. Only if you have an aircraft that was completed prior to that time and do not have a paragraph about categroy and class rating in your operating limitations do you need to worry about this. A new order, 8700.42 gives all the details and is available at: http://www.faa.gov/avr/afs/notices/8700/n8700-42.doc If you do happen to be in the categroy needing new operating limitations and/or ratings added to your pilot's certificate the procedures are also in this order. The good news is that you will be able to use the flight time you already have in your aircraft to get these newly required ratings. Mike Robertson Das Fed >From: "Charles Heathco" <cheathco(at)comcast.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: "new" regulation re taking pasengers in hombuilts? >Date: Thu, 12 May 2005 08:28:11 -0400 > > >The FAA is underscoring regulatory requirements for pilots who fly >passengers in homebuilt aircraft. A new notice would restrict them to >flying passengers only in planes in which they are qualified and >experienced. Currency and proficiency rules apply to those who take people >for rides in their experimental aircraft and EAA says current pilots have >until Aug. 31, 2005, to prove they have the necessary category and class >ratings for the aircraft they fly. > >This is the first Ive heard of this, am I the only one in the dark about >it? charlie heathco (this is from Avweb) > > ________________________________________________________________________________
Date: May 12, 2005
Subject: Re: "new" regulation re taking pasengers in hombuilts?
Like you, Charlie, I somehow missed out on the public comment period on this new rule ;-) I couldn't believe my eyes when I read & re-read the AvWeb's report on it: the paperwork required and the revised license which sounds like it will only permit the pilot to fly in the experimental make & model for which pax-carrying permission is sought, and no other aircraft, even when solo. That is so bizarre, it can't be right. Even the D. C. Swamp mentality isn't that screwed up. Great example of fixing a non-existent problem by heavy-handed regulation. I'm beginning to think we need an unauthorized small aircraft overflight of the DC airspace about twice a day, to keep the gummint hunkered in their bunkers, and the citizens safe and free. -----Original Message----- From: Charles Heathco <cheathco(at)comcast.net> Subject: RV-List: "new" regulation re taking pasengers in hombuilts? The FAA is underscoring regulatory requirements for pilots who fly passengers in homebuilt aircraft. A new notice would restrict them to flying passengers only in planes in which they are qualified and experienced. Currency and proficiency rules apply to those who take people for rides in their experimental aircraft and EAA says current pilots have until Aug. 31, 2005, to prove they have the necessary category and class ratings for the aircraft they fly. This is the first Ive heard of this, am I the only one in the dark about it? charlie heathco (this is from Avweb) ________________________________________________________________________________
Date: May 12, 2005
From: Hal Kempthorne <hal_kempthorne(at)sbcglobal.net>
Subject: Re: Sources for electrical system design
60 amps! Wow! So you can run your compressor and drill press? hal Paul Folbrecht wrote: I did some reading. I think I will go with the B&C alternator. I think I will need the 60A too which is $600 - ouch!! --- LARRY ADAMSON wrote: > > > ----- Original Message ----- > From: Paul Folbrecht > To: rv-list(at)matronics.com > Subject: Re: RV-List: Re: Sources for electrical system design > > > > This alternator debate has been a tough one. I have a 60 internally regulated > alt. from Van's. A few years ago, I installed the O.V, protection that opened > the main cable from the alt. to battery. Turns out, that removing the alt > field voltage won't shut down an internally regulated alternator, and > disconnecting from the battery can cause a load dump. Haven't yet flown the > plane, but it looks like I'm taking out the O.V. (over voltage) setup. There > is a good discussion of this on the Matronics Aeroelectric list during the > last month. > > > Seriously? I thought all the hard decisions had been made. Damn! > > Is it that big a deal? I admit I'm not expert, but I've never had an > alternator failure (Ok, in my measly 300 hours) or heard of one firsthand > even > on airplanes with very old alternators. Which I think are all externally > regulated.. I guess it's another point to research.. and I guess there is > probably a reason why a B&C alternator costs 2x what the one Mattituck > supplies > does. > > > > > > > > ________________________________________________________________________________
Date: May 12, 2005
Subject: Re: Bomber pattern WAS: Joy Riding in the Pattern
The bomber pattern yesterday was not at all frustrating but then I was in no hurry. The B-17 arrived in Paso Robles yesterday afternoon as I was approaching the airport. He did fly very large pattern. To follow him in one would have to be very patient. He was so far away that someone got in the way and he had to go around once. I followed around on his right about a thousand feet above and a bit behind. I later wondered if that is about where crews would first spot an enemy fighter. He did not seem to have prepared himself for the landing at this uncontrolled airport. After landing he asked for the ground control frequency. hal ________________________________________________________________________________
Subject: Mufflers for RVs (Was Noisy Airplanes)
Date: May 12, 2005
Hello; Cant resist, forgive me. It would seem to me in that case that we would all need to install windshield wipers on the inside of our canopies. You know, all those lips flapping making airplane sounds and the spit flying....... Sorry but I just couldn't resist. Bud Silvers RV-8 wings done starting on fuselage. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Tony Marshall Subject: Re: RV-List: Mufflers for RVs (Was Noisy Airplanes) Having watched this noise thread....I guess I love the noise of airplanes.....one of the many things I enjoy about them. I understand that many dont feel this way. For this reason we probably should be moving in the direction of quieter engines and better controlled props. Dont be deceived into believing that the airport/airplane dissidents will go away though....the only way many will be happy is if your engine simply doesn't run. We can then all sit out on the ramp, in formation, making engine noises as far as many of them are concerned. But....be sure, someone will protest that, too. While some airplane/airport detractors have legitimate concerns, the 'rush' of many, if not most, comes simply from being 'involved'....not really having a dog in the fight. I wish they knew how much they were messing with the wholesome enjoyment of a lot of good people. Tony Marshall RV6 Polson, MT ----- Original Message ----- From: "Charles Heathco" <cheathco(at)comcast.net> Subject: Re: RV-List: Mufflers for RVs (Was Noisy Airplanes) > > I have read with interest the "swiss muffler" blog, and also the info on > RV mufflers on Aircraft Exaust site, I will call them when they open and > post my findings. I for one highly dislike the noise our planes produce > and so do a lot of other people. Like it or not, airports everywhere are > under attack for just the noise factor. I am sure many would defend their > right to make as much noise as they want and would point to the fact that > we in the USA are not under any noise restrictions YET. I woulnt mind > giving up a small amount of performance for a quieter plane. Charlie > heathco > > ________________________________________________________________________________
Date: May 12, 2005
Subject: 'New' proficiency/currency rules for experimentals
From AvWeb... I'm sure many of you have already been aware of this, but I don't remember seeing any list traffic or discussion of it. Anyway, after calling the EAA to confirm this I was told that this only really applies to those who are flying experimental aircraft for which category and class they are not rated as a pilot, i.e... a private pilot with a single-engine-land rating who is operating an experimental helicopter. There is and has been for decades, a loophole in the rules which allows pilots of experimentals to do this sort of thing mainly for the purpose of developing new types of aircraft like say powered lift a few years back -there was no recognized category for it (although there is now) and so it was impossible to be rated properly in category and class. So... AvWeb has really not worded it as it should have been worded. The statement "make and model" will really not apply to us since we are properly rated as to category and class (assuming we all have airplane single-engine-land ratings), and no, we're not all going to have to go out and have logbooks entries made and get new licenses to ca rry passengers in our RV's. This will affect mainly the gyroplane, powered-lift and rotorcraft guys as I see it. It didn't help that AvWeb included a picture of an RV-4 in their article. -Scott Spencer N4ZW (CFII, ATP) The article follows: The FAA is underscoring regulatory requirements for pilots who fly passengers in homebuilt aircraft. A new notice would restrict them to flying passengers only in planes in which they are qualified and experienced. Currency and proficiency rules apply to those who take people for rides in their experimental aircraft and EAA says current pilots have until Aug. 31, 2005, to prove they have the necessary category and class ratings for the aircraft they fly. Those who always fly solo will not need to fly through the bureaucratic hoops. Under the new notice, which was issued April 21, affected pilots will have fill out a form and make sure their recreational or higher certificate is in order. Flying passengers requires that the pilot have at least five hours as PIC in the category, class, make and model of the experimental aircraft in question between Sept. 1, 2004, and Aug. 31, 2005. An authorized flight instructor must make a logbook entry attesting to the pilot's proficiency w ith the aircraft and then the pilot must show the log to a designated pilot examiner or FAA Operations Inspector. A new pilot certificate will then be issued restricting the pilot to flying that particular experimental aircraft (or any others for which he or she has done the paperwork). ________________________________________________________________________________
Subject: Mooney spinner
Date: May 12, 2005
Hello group; I have an IO 360 A1A 200 hp angle valve engine with a Hartzel Constant Speed Propeller. Engine, prop and spinner came from a Mooney M20. Question is can I use my spinner or do I have to use the one from Vans? My spinner bulkhead attaches to ring gear and it looks like we will have to modify the cowling to make it work. Has anyone done this before? If so how has it worked? Please advise. Thanking you all in advance. Bud Silvers RV-8 under construction in Colorado ________________________________________________________________________________
Date: May 12, 2005
Subject: DC incursion (Was: Joy Riding in the Pattern)
> Folks, I don't mean to sound arrogant >but my experience has been the airways are full of pilots that don't >have a clue, and frequently use their ears instead of their eyes, or >don't think while they're flying, or in the case of the latest DC ADIZ >incursion, don't do any preflight planning. Where I live 100 mile visibility is typical and visibility around 30 miles seems like "IFR" conditions. Can someone explain how a person could fly over DC even not using GPS? Where conditions hazy and five miles visibility? Ron Lee ________________________________________________________________________________
Date: May 12, 2005
Subject: Aluminum 2 blade MT Propeller Advertisement
NEW! JAA/FAA certified 2 blade aluminum constant speed MT-Propeller MT-Propeller has developed a new high performance 2 blade aluminum propeller for eliminating certain disadvantages of regular 2 blade aluminum constant speed propellers. The 2 blade aluminum MT-Propeller has the following: - No RPM restrictions for undampened crankshaft Lycoming ( )O-360- series engines. - Latest available high efficiency airfoils - Scimitar blade shape for noise reduction and high performance. - Smooth running due to close tolerance manufacturing (CNC machined) The new aluminum MT-Propeller is available for Lycoming and Continental engines developing up to 300 hp. The maximum diameter is 203 cm (80 inches). The Lycoming ( )O-360-series MT-Propeller is typically a 72 inch diameter and includes a spinner assembly installed at the factory to match your cowl. This allows delivery to be a bolt on propeller assembly. Minimum blade diameter is 68 inches. Price is $6,399 plus shipping and any applicable taxes. 13" diameter spinner assembly set for 1 1/2" cowl spacing installed on propeller. No cost option: Spinner color - White, Red, Black, Grey, Yellow or left in primer only. "Hi-Glo" option - $450 (The "Hi-Glo" option gives the Kevlar/Epoxy spinner the appearance of a polished aluminum (or chrome) spinner dome.) Regards, Jim Ayers Custom Aircraft Propeller - A division of Less Drag Products, Inc. _www.lessdrag.com_ (http://www.lessdrag.com/) (805) 795-5377 ________________________________________________________________________________
Date: May 12, 2005
Mike- I went to the link and read the regs; my legalese-challenged eyes glazed over rather quickly... I had always thought "category and class" meant that "ASEL" would cover it for a fixed-wing experimental that was not "high-performance" without any further endorsements. Have I been operating my RV illegally (with pax) all these years? What really caught my eye was the verbiage defending the reason for the regs: an increasing trend in experimental accidents with pax aboard. The FAA's response to this data appears not to involve investigating the EFFECT OF PASSENGERS on the aircraft involved in these accidents, but on granting almost "shall-issue" rubber-stamp license endorsements to the pilots of those aircraft. If the trend is rising for pax-carrying experimental fatalities, let's dig into why the CARRIAGE OF PASSENGERS causes increased numbers of crashes: are the aircraft overloaded? Are pax grabbing the controls and pulling wings off? Are pilots acting stupid with a captive audience aboard? If it's an uptrend for experimental crashes in general, and fatality absolute numbers are climbing only because a crash with pax aboard _by definition_ kills more people than an aircraft crashed solo, then let's be logical and scrutinize experimental accidents in general, admitting that pax are not a contributing variable to the crashes themselves. At any rate, I am without a clue how the proposed issuance of new license endorsements based on prior expereince might do anything to reduce the fatality statistics; it's all symbolism trumping substance. How many pax fatalities occur in the first five hours that a pilot flies a new make and model? If it's significant, then forbid that behavior for the first 5 hours. Why the license endorsement? Prediction: I foresee the FAA certifying night proficiency using the same "logic" - issuing every airman a license with a night flight endorsement - valid only for 90 days, of course, in keeping with the night flight currency regs we already have on the books. Or maybe issuing every airline pilot an endorsed license after he passes a blood alcohol test, such license only good for flight on the day of issue, to cut down on the number of flight crews flying under the influence... I fail to see why every reg needs to appear reincarnated as a license endorsement; it's already illega l to bust these regs! (Reminds me of gun control - lets' reduce murder by making it illegal; oh, wait, it already is - ya think making it double-illegal will help?) I would sincerely appreciate your assistance with understand this. The rule announcement comes on the heels of a vey bad day for GA in the Washington ADIZ, a day that made one pilot look foolish, and the federal security apparatus look like a cross between Chicken Little and a two-ton, rabid gorilla. -Stormy -----Original Message----- From: Mike Robertson <mrobert569(at)hotmail.com> Subject: RE: RV-List: "new" regulation re taking pasengers in hombuilts? It is a new requirement that came out just recently with the light sport changes. It is in FAR 61.31(k)(2). This is the FAR that previously made it possible for multi-engine Experimental aircraft to be flown without having a multi-engine pilot's certificate. The wording in 61.31(k)(1) has not changed and still excludes non-type certificate aircraft from needing a categroy and class rating. But 61.31(k)(2) changed clarifying that a categroy and class rating is needed if a passenger is being carried. For the vast majority of people this will mean nothing new as the FAA has been including wording in the aircraft Operating Limitations requiring a categroy and class rating since the mid 90's. Only if you have an aircraft that was completed prior to that time and do not have a paragraph about categroy and class rating in your operating limitations do you need to worry about this. A new order, 8700.42 gives all the details and is available at: http://www.faa.gov/avr/afs/notices/8700/n8700-42.doc If you do happen to be in the categroy needing new operating limitations and/or ratings added to your pilot's certificate the procedures are also in this order. The good news is that you will be able to use the flight time you already have in your aircraft to get these newly required ratings. Mike Robertson Das Fed >From: "Charles Heathco" <cheathco(at)comcast.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: "new" regulation re taking pasengers in hombuilts? >Date: Thu, 12 May 2005 08:28:11 -0400 > > >The FAA is underscoring regulatory requirements for pilots who fly >passengers in homebuilt aircraft. A new notice would restrict them to >flying passengers only in planes in which they are qualified and >experienced. Currency and proficiency rules apply to those who take people >for rides in their experimental aircraft and EAA says current pilots have >until Aug. 31, 2005, to prove they have the necessary category and class >ratings for the aircraft they fly. > >This is the first Ive heard of this, am I the only one in the dark about >it? charlie heathco (this is from Avweb) > > ________________________________________________________________________________
Date: May 12, 2005
Seems that 40A may not cover max current draw. More research needs to be done. If it turns out 40A will cover the draw then I'll go with 40. --- Hal Kempthorne wrote: > > 60 amps! Wow! So you can run your compressor and drill press? > > hal ________________________________________________________________________________
Date: May 12, 2005
For others that may be sorting through on this, yet another angle. The 60 amp is what I decided to do as well. Some of my logic ... My Piper consistently uses in the high 30's to low 40's amps. I monitor it and based on the way I prefer to fly (lights on etc. and with admittedly older radios) that is what it takes. Our RV6 in theory should have been just fine with the 35 amp alternator from Van's, **BUT** I noticed that based on the way I prefer to fly (lights on in somewhat busy area), once I slowed down to enter the pattern, that alternator definitely was NOT delivering 35 amps. Nowhere near it. By the time I turn final, I had a bright red low voltage light staring me in the face. I was not happy with that. My **estimates**, as far as I can recall (data not currently handy), that 35 amp'er may have looked more like a 20 amp'er under certain conditions. So I switched it out for Van's 55(?) amp'er. Even with it, on a long taxi at very low idle (not a problem condition) I can get to low voltage on the PC680. So when it came to RV under construction that is electrically dependent, and with a lot more electrical "stuff" (toys), I took the "lazy way out" and went ahead and ordered the 60 amp'er from B&C to complement the 20 amp'er (Z-14). Of course, I do believe that based on data received either from Bob or B&C the B&C 40 amp unit delivers closer to rated current at low RPM that the one 35 amp unit from Van's. And maybe that is part of what one pays for. But for me the extra $$ was worth the peace of mind. James | -----Original Message----- | From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- | server(at)matronics.com] On Behalf Of Hal Kempthorne | Sent: Thursday, May 12, 2005 11:23 AM | To: rv-list(at)matronics.com | Subject: Re: RV-List: Re: Sources for electrical system design | | | | 60 amps! Wow! So you can run your compressor and drill press? | | hal | | Paul Folbrecht wrote: | | | I did some reading. I think I will go with the B&C alternator. I think I | will | need the 60A too which is $600 - ouch!! | ________________________________________________________________________________
Date: May 12, 2005
Subject: New Rule N 8700.42
What looks disturbing to me is that in sect. 5. GUIDANCE it specifically states: "The pilot certificate will be issued with the limitiation "Authorized Experimental Aircraft: [Category] and [Class] rating [Make] and [Model]" for the aircraft authorized to be operated. This reference to Make and Model appears several more times, and is shown on Figure 5 "Baxter built- Mini 500" and Figure 6 "Weaver built Mini 500". Is this to be interpreted to mean my re-issued certificate limits me to pax transport in "Phillips built RV-6A" only and would preclude me from carrying pax in a "Rosales built RV-6A", a "Hotchkiss built RV-7A" or even a "Buchannan built RV-6"? (supposing one of these guys would even let me NEAR their airplanes!) Mark Phillips ________________________________________________________________________________
Date: May 12, 2005
Mark: It sure looks like a new product they are offering, MUFFLER and heat Muff. I can recommend aircraft exhaust in general, as I have a custom exhaust system from them. Good quality. As far as cabin heat muff and muffler (noise suppressor) in one I can't say. Looks like they combined the two. How much quieter? I can't speak to the muffler, as my 4 into 1 are straight pipes with no muffler. However one thing I did have them do on my pipes is weld the optional porcupine studs on the pipe where the heat muff goes, as they show on their web site. They improve heat transfer and you get much more heat. Good find Mark, George Mark Schrimmer Subject: Re: Mufflers for RVs (Was Re: Noisy Airplanes) Has anybody used the exhaust system from Aircraft Exhaust Technologies http://www.aircraftexhaust.net? According to their web site, they have a stainless steel crossover system that includes two mufflers that are small enough to fit inside the cowl of an RV-6, RV-6A, RV-7, RV-7A, RV-8, RV-8A, RV-9, or RV-9A. Besides reducing sound, they are supposed to increase cabin heat, too. Mark --------------------------------- Find restaurants, movies, travel & more fun for the weekend. Check it out! ________________________________________________________________________________
Subject: Microfastener website
Date: May 12, 2005
Has Microfastener.com changed their web address? I can't seem to get on their web site. John L. Danielson ________________________________________________________________________________
Date: May 12, 2005
Subject: Re: Microfastener website
Don't forget the "S" http://www.microfasteners.com/ Jeff Point Has Microfastener.com changed their web address? I can't seem to get on their web site. > > > ________________________________________________________________________________
Subject: New rule N8700.42 does not apply to RVers
Date: May 12, 2005
According the EAA, new requirements would not apply to RVers.... See example A. ATTENTION, EXPERIMENTAL/HOMEBUILT PILOTS Category and Class Rating Required to Carry Passengers May 9, 2005 - On April 21, 2005, FAA Flight Standards reinforced a regulatory requirement for passenger-carrying experimental/amateur-built aircraft pilots to have category and class ratings for the aircraft they intend to fly. The new Notice, N 8700.42, also provides a "grandfather" clause allowing current pilots without the required ratings a limited window of opportunity (through August 31, 2005) to obtain them. This new policy does not apply to pilots flying experimental aircraft who do not carry passengers. Here's the procedure: 1. The airman must complete an FAA Form 8710-1. 2. The airman must currently hold a Recreational Pilot certificate or higher. 3. The airman must have at least five hours as pilot in command flight time in the category, class, make, and model of experimental aircraft between September 1, 2004 and August 31, 2005. 4. An authorized flight instructor must provide a logbook endorsement that the applicant is proficient to act as PIC of that category, class, make, and model of experimental aircraft. 5. The airman must make an appointment with a DPE or an FAA Operations Inspector (ASI), who will verify that 1-4 are completed correctly, then issue the new certificate. No DPE or ASI flight evaluation is required. 6. The new pilot certificate will be issued with the following restriction placed on it: "Authorized Experimental Aircraft: (category) and (class), (make) and (model)." Examples: a. Pilots who hold a private pilot SEL airplane category and class rating certificate, and fly a SEL experimental aircraft, no action is required. b. Pilots who hold a private pilot SEL airplane category and class rating certificate, and fly a multi-engine experimental aircraft (MEL), will need to comply with the new requirements. c. Pilots who hold a private pilot SEL airplane category and class rating certificate, and who fly an experimental single-engine sea plane, will need to comply with the new requirements. d. Pilots who hold a private pilot Glider category and class rating certificate, and who fly an experimental single-engine helicopter, will need to comply with the new requirements. Designated Airworthiness Representatives (DARs) or FAA Inspectors (ASIs) will continue issuing operating limitations without this new requirement, until the FAA issues the revision based on notice N 8700.42. However, at the time the operating limitations are issued, DARs/ASIs will brief the builder/owner of the new requirement. This new requirement does not do away with requirement for the pilot to meet FAR 61.31(e), (f), (g), (h), (i), or (j). Mike Draper RV-8 (fuse) N468RV ________________________________________________________________________________
Date: May 12, 2005
It came up okay for me at http://www.microfasteners.com/> Perhaps the "s" will make the difference. Rick McBride ----- Original Message ----- From: John Danielson<mailto:johnd(at)wlcwyo.com> To: rv-list(at)matronics.com Sent: Thursday, May 12, 2005 3:01 PM Subject: RV-List: Microfastener website Has Microfastener.com changed their web address? I can't seem to get on their web site. John L. Danielson ________________________________________________________________________________
Subject: Re: DC incursion (Was: Joy Riding in the Pattern)
Date: May 12, 2005
In the video, the plane was clearly visible from the ground, I would imagine similar visibility from where he was sitting On May 12, 2005 12:52 pm, Ron Lee wrote: > > > > Folks, I don't mean to sound arrogant > >but my experience has been the airways are full of pilots that don't > >have a clue, and frequently use their ears instead of their eyes, or > >don't think while they're flying, or in the case of the latest DC ADIZ > >incursion, don't do any preflight planning. > > Where I live 100 mile visibility is typical and visibility around 30 miles > seems like "IFR" conditions. Can someone explain how a person > could fly over DC even not using GPS? Where conditions hazy and > five miles visibility? > > Ron Lee > > > > > > > ________________________________________________________________________________
Date: May 12, 2005
Subject: Re: Aluminum 2 blade MT Propeller Advertisement
Jim, How much does it weigh? Ted LeastDrag93066(at)aol.com wrote: NEW! JAA/FAA certified 2 blade aluminum constant speed MT-Propeller MT-Propeller has developed a new high performance 2 blade aluminum propeller for eliminating certain disadvantages of regular 2 blade aluminum constant speed propellers. The 2 blade aluminum MT-Propeller has the following: - No RPM restrictions for undampened crankshaft Lycoming ( )O-360- series engines. - Latest available high efficiency airfoils - Scimitar blade shape for noise reduction and high performance. - Smooth running due to close tolerance manufacturing (CNC machined) The new aluminum MT-Propeller is available for Lycoming and Continental engines developing up to 300 hp. The maximum diameter is 203 cm (80 inches). The Lycoming ( )O-360-series MT-Propeller is typically a 72 inch diameter
May 04, 2005 - May 12, 2005
RV-Archive.digest.vol-qv
