RV-Archive.digest.vol-ri
October 05, 2005 - October 23, 2005
      RV8 Fuselage
      -----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ed OConnor
Subject: Fuel Caps
I installed them on my RV-8 and they were simple to install (used Proseal) and they sealed with no problem. Very high quality. Only down side is they do restrict the size of the opening slightly but no problem for normal nozzle or gas can spout. They look great and with the price of 100LL it is good you can lock them up. G'day all, Does anyone have experience with the Deluxe Fuel Caps available from Vans. I am interested in knowing how they look and how well they seal in comparison to the standard caps. I wouldn't mind the ability to lock my tanks. Have fun, Scott Lewis RV-10 40172 VH-DRS Adelaide, South Australia ________________________________________________________________________________
Date: Oct 05, 2005
Subject: Re: Zero Thrust
Hi All, I believe it takes about 1300 RPM for the governor to have control of the propeller. I believe you will see the propeller windmilling at around 1000 RPM in low pitch. So it isn't going to work to try to reduce the RPM with coarse pitch on a standard CS propeller. The counterweighted blade CS propeller operates from coarse pitch (low RPM), instead of fine pitch (high RPM). With the same best glide engine off situation, the counterweighted blades automatically go towards coarse pitch (low RPM) providing a 67% decrease in propeller drag (on MT propellers). Regards, Jim Ayers In a message dated 10/05/2005 7:43:59 AM Pacific Daylight Time, mstewart(at)iss.net writes: --> RV-List message posted by: "Stewart, Michael (ISS Atlanta)" Ok I get what Zero thrust is. But again: Whats the point of caring what it is? What does knowing it do for me? What change in decisioning would I make if I knew it? And as a note: On my c/s prop at best glide engine off, I can not make my prop change pitch. Moving blue knob does nothing while prop is windmilling. Mike S8 ________________________________________________________________________________
Date: Oct 05, 2005
On 8:10:46 2005-10-05 Ron Lee wrote: > I am a bit slow with some concepts so bear with me. > It seems like this zero thrust issue may be relevant to > determining engine out glide path. I am still unclear > on the real world implication. Assume you lose power > and lower the nose to near best glide speed. Won't the > prop continue to turn? If so, how is that tied to zero thrust? > I have a fixed pitch prop. Unless you have a wooden prop or some kind of catastrophic failure within your engine case, your prop is likely to keep turning unless you actively try to stop it. A wooden prop has a lot less momentum in it, if you apply almost *any* back pressure on the stick with the engine stopped, the prop will stop turning very quickly. A metal prop will take more of a nose-up attitude to get the blades to stop turning. If you are reasonably high when you have an engine failure, you will be better off stopping the prop first before starting your glide. You may increase your range considerably. The trade-off is that you will first lose some airspeed while you're stopping the prop, then some altitude when you regain your glide speed. I haven't run the numbers on an RV, but I did do it for a Cessna 150 (with a metal prop) a while ago, and my recollection was that the "break even" point was very near 2000'. Over 2000', I could stretch my glide by stopping the prop. Under 2000', I get a longer glide by riding it down. And it's a lot safer to try these things than people think. Take your plane up to 5000' sometime, and pull the mixture. Engine stops. Push it in again. Engine starts. Prop keeps turning either way. Do it again, and this time pull the nose up until the prop stops. Then you can either push the nose down to get the prop to start spinning, or flick your starter, and push the mixture back in. The engine will start right up. -Rob ________________________________________________________________________________
Date: Oct 05, 2005
On 10/5/05 8:27 AM, "Richard Dudley" wrote: > > Listers, > Thanks for the many responses. > This was not intended as a trick question. > My apologies for not expanding on the reasons for the question. > The CAFE report on the -6A described the use of microswitches to detect > when the force on the crankshaft shifted from "tractoring" to > "windmilling". They considered that transition to be "zero thrust" and > that the plane simulated a pure glider without securing the engine. > Years ago in Navy flight training in the SNJ (T6) there was a power > setting that was considered neither drag or thrust from the propeller. > This was used for engine out practice (assuming that the propeller could > be stopped from windmilling in the real case). > In the recent past on this list there was a thread about engine out > glide performance with and without a windmilling prop where some had > actually done the experiment with the engine secured. (Kevin's comment: I did a very rough experiment at one speed where I compared engine at idle, engine shut off but propeller windmilling and propeller stopped. There were the expected differences, but they were not of a large magnitude. Should be in the archives somewhere. Larry Pardue Carlsbad, NM RV-6 N441LP Flying, Fixed Pitch Sensenich http://n5lp.net ________________________________________________________________________________
Subject: Zero Thrust
Date: Oct 05, 2005
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
The difference between stopped and the slow windmill at my best glide was negligible on my fat blade hartzell c/s prop. I agree with the previous post about stopping the prop. I decided if I have over 3k'agl, I would pitch up to stop the prop then resume best glide. Requires stick nearly in my lap on the 8 do it and not something I would be comfortable doing below 3k'. Mike -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Pardue Subject: Re: RV-List: Zero Thrust On 10/5/05 8:27 AM, "Richard Dudley" wrote: > > Listers, > Thanks for the many responses. > This was not intended as a trick question. > My apologies for not expanding on the reasons for the question. > The CAFE report on the -6A described the use of microswitches to detect > when the force on the crankshaft shifted from "tractoring" to > "windmilling". They considered that transition to be "zero thrust" and > that the plane simulated a pure glider without securing the engine. > Years ago in Navy flight training in the SNJ (T6) there was a power > setting that was considered neither drag or thrust from the propeller. > This was used for engine out practice (assuming that the propeller could > be stopped from windmilling in the real case). > In the recent past on this list there was a thread about engine out > glide performance with and without a windmilling prop where some had > actually done the experiment with the engine secured. (Kevin's comment: I did a very rough experiment at one speed where I compared engine at idle, engine shut off but propeller windmilling and propeller stopped. There were the expected differences, but they were not of a large magnitude. Should be in the archives somewhere. Larry Pardue Carlsbad, NM RV-6 N441LP Flying, Fixed Pitch Sensenich http://n5lp.net ________________________________________________________________________________
Date: Oct 05, 2005
On 5 Oct 2005, at 10:41, Stewart, Michael (ISS Atlanta) wrote: > > > Ok I get what Zero thrust is. But again: > Whats the point of caring what it is? What does knowing it do for me? > What change in decisioning would I make if I knew it? > > > And as a note: > On my c/s prop at best glide engine off, I can not make my prop change > pitch. Moving blue knob does nothing while prop is windmilling. > > Mike > S8 It is useful to know how to simulate a zero thrust condition if you have a multi-engined aircraft where you would feather the prop after an engine failure. For training, you would put the simulated failed engine in a zero thrust condition, rather than shut it down and feather the prop. For single-engined aircraft, people generally do the training with the engine at idle. If the prop stops in a real engine failure, the glide performance will be a bit different than it was during training with engine at idle. But, the real problem is what happens if the engine fails and the prop keeps windmilling. A windmilling constant- speed prop will create a lot more drag than was seen during training with engine at idle. I can see the value in finding a condition that will simulate a windmilling prop (e.g. with partial flaps and power, to simulate flaps up with failed engine and windmilling prop). I don't immediately see the value in simulating a zero thrust condition. But maybe I am missing something. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Oct 05, 2005
Another thought. I was taught during primary training in a fixed pitch prop airplane to set the throttle to zero thrust when abreast of the runway for landing. The theory, I guess, was that if the airplane was in landing configuration with zero thrust then if the engine quit you wouldn't have much change in your approach for landing. Like I said, I guess, because I certainlyh didn't understand much at that stage of the game. I been flying mostly constant speed since then so it isn't as relavant. Tim -------Original Message------- From: Kevin Horton Date: 10/05/05 14:36:12 Subject: Re: RV-List: Zero Thrust On 5 Oct 2005, at 10:41, Stewart, Michael (ISS Atlanta) wrote: > > > Ok I get what Zero thrust is. But again: > Whats the point of caring what it is? What does knowing it do for me? > What change in decisioning would I make if I knew it? > > > And as a note: > On my c/s prop at best glide engine off, I can not make my prop change > pitch. Moving blue knob does nothing while prop is windmilling. > > Mike > S8 It is useful to know how to simulate a zero thrust condition if you have a multi-engined aircraft where you would feather the prop after an engine failure. For training, you would put the simulated failed engine in a zero thrust condition, rather than shut it down and feather the prop. For single-engined aircraft, people generally do the training with the engine at idle. If the prop stops in a real engine failure, the glide performance will be a bit different than it was during training with engine at idle. But, the real problem is what happens if the engine fails and the prop keeps windmilling. A windmilling constant- speed prop will create a lot more drag than was seen during training with engine at idle. I can see the value in finding a condition that will simulate a windmilling prop (e.g. with partial flaps and power, to simulate flaps up with failed engine and windmilling prop). I don't immediately see the value in simulating a zero thrust condition. But maybe I am missing something. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Oct 05, 2005
Subject: Re: anodizing engine baffles
Anodized can cause cracking if not done properly. It is called hydrogen embittlment. If done properly the change in fatigue life is small, but it is not the ideal finish. It all depends on the surface and material. If you bead shot blast a surface you can improve fatigue and crack resistance, but that does not make sense for a clad aluminum material. Bare aluminum yes you can peen the surface. However we are talking about sheet metal and there is not a lot you can do because shot blasting can warp it. In a message dated 9/27/2005 5:04:08 P.M. Pacific Daylight Time, sarg314(at)comcast.net writes: I am just starting on my engine baffles. I saw another builder's plane which had the baffles blue anodized and it looks good. However, anodizing hardens the surface and might make it more prone to crack. I'm just guessing here. Does any one have any experience with this? Are there planes with hundreds of hours on them with anodized baffled that haven't cracked? --------------------------------- Click here to donate to the Hurricane Katrina relief effort. ________________________________________________________________________________
Subject: Tip-up canopy aft end fiberglass strip
Date: Oct 05, 2005
Searched the archives with no luck so I thought I'd toss this out to everyone - The roll bar on my 7A tip-up is not terrible, but it's not a work of art either. So, I am considering putting a strip of fiberglass over the aft end of the tip-up canopy to 'hide' it. It would be about 2-3 inches wide, overhang the aft window by about a half and inch, and would only be attached to the tip up portion. I was thinking that this might also prevent leaks between the aft window and the tip up, as well as eliminate or reduce wind noise since there is a small gap between the two halves. A friend did this, and it blew off in-flight fairly quickly. As a result, he suggests using screws to ensure a permanent attachment. Anyone have any recommendations regarding this, or reasons not to use the glass at all? Since the strip would not be attached to the aft window, would air pressure or wind try to get underneath it from the back and try to rip it off or crack of chunks and pieces? Thanks in advance. Bryan Hooks RV-7A tip-up, finish kit, slow-build Knoxville, TN ________________________________________________________________________________
Subject: Re: Wing tip com antenna
Date: Oct 05, 2005
Hey Jim ,My has worked great for the last 7yrs Dwain Harris RV-6 N164DH Tehachapi, Ca ----- Original Message ----- From: AYRES, JIMMY L<mailto:JAYRES(at)entergy.com> To: 'rv-list(at)matronics.com' Sent: Monday, October 03, 2005 11:06 AM Subject: RV-List: Wing tip com antenna Hey Guys, I am conducting a survey. Does anyone out there flying have a wing tip installed com antenna? If so does it work? Well? Thanks for your feedback. Jimmy Ayres RV7AQB Hey Guys, I am conducting a survey. Does anyone out there flying have a wing tip installed com antenna? If so does it work? Well? Thanks for your feedback. Jimmy Ayres RV7AQB ________________________________________________________________________________
Subject: Re: Tip-up canopy aft end fiberglass strip
Date: Oct 05, 2005
For what its worth, Bryan. I installed an aluminum strip 3" wide of 0.032 2024T3 on the aft end of my tip-up. It overhangs the back part by approx 1 1/2", hides my not so even canopy cut and keeps the wind/rain out. I installed mine before pop riveting the canopy to the frame, so could use the same pop rivets as held the canopy. Have 300 hours on it with no problem. Ed ----- Original Message ----- From: "Bryan Hooks" <bryanhooks(at)comcast.net> Subject: RV-List: Tip-up canopy aft end fiberglass strip > > Searched the archives with no luck so I thought I'd toss this out to > everyone - > > The roll bar on my 7A tip-up is not terrible, but it's not a work of art > either. So, I am considering putting a strip of fiberglass over the aft > end of the tip-up canopy to 'hide' it. It would be about 2-3 inches > wide, overhang the aft window by about a half and inch, and would only > be attached to the tip up portion. I was thinking that this might also > prevent leaks between the aft window and the tip up, as well as > eliminate or reduce wind noise since there is a small gap between the > two halves. > > A friend did this, and it blew off in-flight fairly quickly. As a > result, he suggests using screws to ensure a permanent attachment. > Anyone have any recommendations regarding this, or reasons not to use > the glass at all? > > Since the strip would not be attached to the aft window, would air > pressure or wind try to get underneath it from the back and try to rip > it off or crack of chunks and pieces? > > Thanks in advance. > > Bryan Hooks > RV-7A tip-up, finish kit, slow-build > Knoxville, TN > > > ________________________________________________________________________________
Subject: Sealer on Whelen strobe lights
Date: Oct 05, 2005
I thought the sealer on the strobes was just silicon but I really don't know. However, I have the good fortune of being based at an airport that has a Cirrus approved warranty maintenance center and get to see how Cirrus Aircraft are constructed. All wires and push/pull controls which pass through the firewall have a stainless steel cover over a rubber grommet covered with a healthy dab of red high temperature silicone. They also have conduits to run wires through and they place a dab at the end of the conduit enclosing the wires as well. I did that on my RV6 and found it relieves strain on the wires, keeps chaffing down and it can be easily cut away if need be to rewire if you wish. Dick DeCramer RV6 N500DD 90 hours Northfield, MN > > Subject: RV-List: Sealer on Whelen strobe lights > > > Listers, > > I just received my Whelen strobe lights. They are sealed with some white > ProSeal like, Sikaflex like substance which is quite rubbery and which seems > perfect for preserving wires from chaffing against each other as they come > out of connectors or pass through grommets. Any of you guys have an idea as > to what Whelen might have used ? Or could you recommend a similar product ? > > Thanks, > Michele > RV8 - Fuselage > > ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Oct 05, 2005
There is discussion in the archives on this. Search for targa strip. It should be built as you describe. Attach with adhesive and use the screws that hold the canopy glass on the roll over bar. You may need screws that are about 1/8" longer than supplied with kit. Lots of tip ups have this strip. Carefully done and finished it will enhance the looks of your plane and be functional for keeping water and wind out. It will also hide any unsightly damage or work. I for instance have both corners at the bottom with cracks where the canopy glass edge has touched the metal skin while closing. The targa strip will hide that. Indiana Larry in Evansville, RV7 Tip Up SunSeeker 65 hours and still grinning......... ----- Original Message ----- > > Searched the archives with no luck so I thought I'd toss this out to > everyone - > > The roll bar on my 7A tip-up is not terrible, but it's not a work of art > either. So, I am considering putting a strip of fiberglass over the aft > end of the tip-up canopy to 'hide' it. It would be about 2-3 inches > wide, overhang the aft window by about a half and inch, and would only > be attached to the tip up portion. I was thinking that this might also > prevent leaks between the aft window and the tip up, as well as > eliminate or reduce wind noise since there is a small gap between the > two halves. > > A friend did this, and it blew off in-flight fairly quickly. As a > result, he suggests using screws to ensure a permanent attachment. > Anyone have any recommendations regarding this, or reasons not to use > the glass at all? > > Since the strip would not be attached to the aft window, would air > pressure or wind try to get underneath it from the back and try to rip > it off or crack of chunks and pieces? > > Thanks in advance. > > Bryan Hooks > RV-7A tip-up, finish kit, slow-build > Knoxville, TN ________________________________________________________________________________
Date: Oct 05, 2005
There should be some discussions in the archive on this. But a quick answer based on my research before I installed a bent antenna on the bottom of my plane was that the wing tip concealed antenna works nicely except sometimes when the antenna is on the opposite side away from where you need to communicate. This situation could be plane to plane communications ( hearing another plane near you making an announcement) or ATC that you are required to communicate with when in controlled airspace. I liked the idea of a concealed antenna, but I did not like the idea of the consequences of what might happen if I missed a call or could not be heard when making a broadcast. Indiana Larry in Evansville, RV7 Tip Up SunSeeker ----- Original Message ----- From: "DWAIN HARRIS" <DJaerosports(at)msn.com> Subject: Re: RV-List: Wing tip com antenna > > Hey Jim ,My has worked great for the last 7yrs > Dwain Harris > RV-6 N164DH > Tehachapi, Ca > > > ----- Original Message ----- > From: AYRES, JIMMY L<mailto:JAYRES(at)entergy.com> > To: 'rv-list(at)matronics.com' > Sent: Monday, October 03, 2005 11:06 AM > Subject: RV-List: Wing tip com antenna > > > > > > Hey Guys, > > > I am conducting a survey. Does anyone out there flying have a wing tip > installed com antenna? If so does it work? Well? > > > Thanks for your feedback. > > > Jimmy Ayres > > RV7AQB > > > > > > font-family:Arial'>Hey Guys, > > > font-family:Arial'> > > > font-family:Arial'>I am conducting a survey. Does anyone out there flying > have a wing tip installed com antenna? If so does it work? Well? > > > font-family:Arial'> > > > font-family:Arial'> > > > font-family:Arial'>Thanks for your feedback. > > > font-family:Arial'> > > > font-family:Arial'>Jimmy Ayres > > > font-family:Arial'>RV7AQB > > > ________________________________________________________________________________
Date: Oct 05, 2005
If I recall, Van's construction manual for the -7 covers this pretty well -- maybe it's just the slider windshield joint thing that they cover, but the principal is the same, right? What they DO NOT say, which I believe would be helpful, is that you should NOT countersink the plexi along the rear bow if you're going to use a targa strip on a tip-up. (Keep in mind that on the -7 they went to screws/nuts instead of pop rivets.) Instead, I personally think it would be better to countersink through the fiberglass strip -- and a bit of the plexi in the process, but not as much. In my case, I built the canopy to the plans. If I want to install a targa strip now, which I do plan on doing someday, then it will most likely cover the screw heads. Not a huge deal really, but I think it would be better if the strip were sandwiched in there with the screws. Yeah, I could install new screws in between existing holes, and you'd never know the difference from the outside, but that's a little funky imho. I'll probably just lay the strip up over the bow and the screws will be in there for good (like most of the rest of the canopy fasteners are anyway). Next time I'd probably include the strip integrally from the get-go, countersink the strip, and have the screws hold the strip on. Yes, I would use epoxy to hold the strip on just like the construction manual describes, but I think having the screws sandwich it in there would be a little added assurance. In any case, I'm just thinking out loud here. In your case, just rough that plexi up really well before doing the layup. I suspect your friend's "adhesion issue" was due to not roughing things up enough, or perhaps not cleaning it well enough before doing the layup. Just food for thought. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "LarryRobertHelming" <lhelming(at)sigecom.net> Subject: Re: RV-List: Tip-up canopy aft end fiberglass strip > > There is discussion in the archives on this. Search for targa strip. > > It should be built as you describe. Attach with adhesive and use the > screws > that hold the canopy glass on the roll over bar. You may need screws that > are about 1/8" longer than supplied with kit. Lots of tip ups have this > strip. Carefully done and finished it will enhance the looks of your > plane > and be functional for keeping water and wind out. It will also hide any > unsightly damage or work. I for instance have both corners at the bottom > with cracks where the canopy glass edge has touched the metal skin while > closing. The targa strip will hide that. > > Indiana Larry in Evansville, RV7 Tip Up SunSeeker 65 hours and still > grinning......... > > > ----- Original Message ----- > >> >> Searched the archives with no luck so I thought I'd toss this out to >> everyone - >> >> The roll bar on my 7A tip-up is not terrible, but it's not a work of art >> either. So, I am considering putting a strip of fiberglass over the aft >> end of the tip-up canopy to 'hide' it. It would be about 2-3 inches >> wide, overhang the aft window by about a half and inch, and would only >> be attached to the tip up portion. I was thinking that this might also >> prevent leaks between the aft window and the tip up, as well as >> eliminate or reduce wind noise since there is a small gap between the >> two halves. >> >> A friend did this, and it blew off in-flight fairly quickly. As a >> result, he suggests using screws to ensure a permanent attachment. >> Anyone have any recommendations regarding this, or reasons not to use >> the glass at all? >> >> Since the strip would not be attached to the aft window, would air >> pressure or wind try to get underneath it from the back and try to rip >> it off or crack of chunks and pieces? >> >> Thanks in advance. >> >> Bryan Hooks >> RV-7A tip-up, finish kit, slow-build >> Knoxville, TN > > > ________________________________________________________________________________
Subject: Re: Sealer on Whelen strobe lights
Date: Oct 05, 2005
> I just received my Whelen strobe lights. They are sealed with some white > ProSeal like, Sikaflex like substance which is quite rubbery and which seems > perfect for preserving wires from chaffing against each other as they come > out of connectors or pass through grommets. Any of you guys have an idea as > to what Whelen might have used ? Or could you recommend a similar product ? Hi Michele, It's called potting compound and you can find it at any electronics shop. Here is a link to a bunch of different ones: http://www.mgchemicals.com/products/832tc.html We buy it in disposable syringes that fit in a plier like tool that dispenses the compound. As others have said already, silicone or E6000 might be just as good or better. I guess I vote for silicon since the other two might be difficult to remove... Good luck! Dave, RV6 ________________________________________________________________________________
Date: Oct 05, 2005
Jim, I tried this is my 6/Hartzel just 2 days ago and found that at 75-80 mph indicated and idle power, there was a big change when I pulled the prop to coarse pitch, it was actually quite dramatic. Also, if I leave the prop at cruise setting while landing, the airplane will float, where if it's all the way in, it just kerplunks on. Empirical evidence for sure, but there is enough difference to be quite noticeable well below 1300 rpm. Considering that with an engine out, I'll probably be gliding at about 100 mph, pulling the prop should be quite effective. Dave B. LessDragProd(at)aol.com wrote: > > >Hi All, > >I believe it takes about 1300 RPM for the governor to have control of the >propeller. >I believe you will see the propeller windmilling at around 1000 RPM in low >pitch. >So it isn't going to work to try to reduce the RPM with coarse pitch on a >standard CS propeller. > > > > ________________________________________________________________________________
Date: Oct 06, 2005
Subject: Zero thrust
The zero thrust measurement that Richard Dudley asked about is for drag measurement. Once you've eliminated the thrust (or drag) of a prop, whatever is left is the drag of the airplane. By timing the rate of descent and knowing the weight, you can calculate the power required to fly at that airspeed. Dividing by the airspeed (TAS) gives you the drag at that airspeed. Cheers, Martin -- Martin Gomez MLG28 at cornell.edu http://www.bashingaluminum.com ________________________________________________________________________________
Subject: Fuel Caps Mini-Medco Cylindrical locks for fuel caps
Date: Oct 06, 2005
Subject: RV-List: Fuel Caps The Mooney Miser sells mini circular tumbler lock sets for fuel tank caps. Norm is his real name. He is the elderly gentleman normally snoozing on a stool at the Mooney Owners tent or table(depending on what airplane related show your are at). He also sells wing and tail trim kits that are STC'ed for everything from Cessna 150's to large turboprops. He sells these trim kits at a discount to experimental guys. I am running both of these products on my RV-4 and I am quite happy with the items........Google for norm or the MAPA (Mooney owners group) to find Norm....... ________________________________________________________________________________
Subject: Rear view mirrors on the 8
Date: Oct 06, 2005
OK I took some real crappy pictures last night and posted em. http://www2.mstewart.net:8080/super8/mirrors/index.htm Enjoy Mike ________________________________________________________________________________
Subject: Flow matching injector nozzles
Date: Oct 06, 2005
I recently went through the process of flow matching my injector nozzles. Thought some of you might find the process interesting. I know I did. http://www.mstewart.net/super8 Best Mike ________________________________________________________________________________
Date: Oct 06, 2005
My method differs from Dan's if you want another idea. I have not built my targa strip to date -- but my plan is to build it by laying up 4 to 6 layers of the fiberglass-epoxy strips over UPS tape (release agent) that is in place covering the plexiglass gap on a closed and locked down canopy. Remove the epoxy (targa) strip after it cures and finish it to uniform size by sanding and filling, sanding and filling as needed. After you get it where you like it, remove 6-8 of the screws that hold the plexiglass on the rollover bar, then reposition the strip in place and drill using roll over bar as drill guide. Tape the outline of where the strip goes on the plexiglass. Remove strip and rough up the plexiglass where the targa strip will cover. Counter sink the targa strip for your screws and use epoxy, or proseal and nut&bolt the finished and painted targa strip on the roll over bar. With the adhesive, only 6-8 bolts should be needed. Make it 8 for good measure. I like the ability to finish the strip off the plexiglass to protect the plexi during the sanding process. Also, painting is easier by painting it off the plane. Indiana Larry in Evansville, RV7 Tip Up SunSeeker ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV-List: Tip-up canopy aft end fiberglass strip > > If I recall, Van's construction manual for the -7 covers this pretty > well -- > maybe it's just the slider windshield joint thing that they cover, but the > principal is the same, right? > > What they DO NOT say, which I believe would be helpful, is that you should > NOT countersink the plexi along the rear bow if you're going to use a > targa > strip on a tip-up. (Keep in mind that on the -7 they went to screws/nuts > instead of pop rivets.) > > Instead, I personally think it would be better to countersink through the > fiberglass strip -- and a bit of the plexi in the process, but not as > much. > > In my case, I built the canopy to the plans. If I want to install a targa > strip now, which I do plan on doing someday, then it will most likely > cover > the screw heads. Not a huge deal really, but I think it would be better > if > the strip were sandwiched in there with the screws. Yeah, I could install > new screws in between existing holes, and you'd never know the difference > from the outside, but that's a little funky imho. I'll probably just lay > the strip up over the bow and the screws will be in there for good (like > most of the rest of the canopy fasteners are anyway). > > Next time I'd probably include the strip integrally from the get-go, > countersink the strip, and have the screws hold the strip on. Yes, I > would > use epoxy to hold the strip on just like the construction manual > describes, > but I think having the screws sandwich it in there would be a little added > assurance. > > In any case, I'm just thinking out loud here. In your case, just rough > that > plexi up really well before doing the layup. I suspect your friend's > "adhesion issue" was due to not roughing things up enough, or perhaps not > cleaning it well enough before doing the layup. Just food for thought. > > )_( Dan > RV-7 N714D > http://www.rvproject.com >> ----- Original Message ----- >> >>> >>> Searched the archives with no luck so I thought I'd toss this out to >>> everyone - >>> >>> The roll bar on my 7A tip-up is not terrible, but it's not a work of art >>> either. So, I am considering putting a strip of fiberglass over the aft >>> end of the tip-up canopy to 'hide' it. It would be about 2-3 inches >>> wide, overhang the aft window by about a half and inch, and would only >>> be attached to the tip up portion. I was thinking that this might also >>> prevent leaks between the aft window and the tip up, as well as >>> eliminate or reduce wind noise since there is a small gap between the >>> two halves. >>> >>> A friend did this, and it blew off in-flight fairly quickly. As a >>> result, he suggests using screws to ensure a permanent attachment. >>> Anyone have any recommendations regarding this, or reasons not to use >>> the glass at all? >>> >>> Since the strip would not be attached to the aft window, would air >>> pressure or wind try to get underneath it from the back and try to rip >>> it off or crack of chunks and pieces? >>> >>> Thanks in advance. >>> >>> Bryan Hooks >>> RV-7A tip-up, finish kit, slow-build >>> Knoxville, TN >> >> >> > > > ________________________________________________________________________________
Date: Oct 06, 2005
I have a -6 tipup flying since 94. 3 years ago, I got a crack on one side up thru the first to pop rivets, as Larry described. As Bryan described, I also wanted the 'cosmetic improvement'. I layed it up as described, in place on the canopy/airplane. However, as Dan mentioned, I didn't 'rough it up enough', and at Van's Homecoming my son inadvertantly popped one side loose. On the next takeoff, it exited the airframe onto the runway at Aurora (unbeknownst to me). Someone saw it's exit and turned it in at Van's (yes, they all got a good laugh when I claimed it ;-). It was undamaged except for a little paint loss. So, I roughed the mating surfaces very well and bonded it back on, this time adding 2 screws at each end (very small, countersunk head, with threads tapped into the frame), and a 3rd screw a few inches up. I did NOT put screws all the way over, just at each end as described. It has not come off or loose in 3 years now. So, rough it very well and maybe use screws at the ends (this is where it will accidently get grabbed, it may hit the roll bar during closing, etc.), and you're good to go. It is a very good addition, cosmetically and otherwise. Dw 94 RV-6 910hrs ________________________________________________________________________________
Date: Oct 06, 2005
From: "Lapsley R & Sandra E. Caldwell" <caldwel(at)ictransnet.com>
Subject: CORTEC VPCI-326
Does anyone have a source for a small quanty of CORTEC VPCI-326? Enough for one engine. caldwel(at)ictransnet.com Roger ________________________________________________________________________________
Date: Oct 06, 2005
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Re: Flow matching injector nozzles
Hey you were moaning about the cost ($25 each)....Have you priced GAMI injectors that do exactly the same thing ($100 each or is it $200?) > > >I recently went through the process of flow matching my injector >nozzles. Thought some of you might find the process interesting. I know >I did. > >http://www.mstewart.net/super8 > > >Best > >Mike > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Subject: Properly setting rivets with dimpled surfaces
Date: Oct 06, 2005
Hi everyone. I'm just getting started on an RV-10 project and practiced riveting a bit on scrap material first last night. And I've run into a couple of problems/questions that I'm sure at least some of you have had, but I couldn't find anything in a search of the archives. First question - riveting two dimpled surfaces together: I've seen all kinds of resources saying that a rivet is set properly if the shop head is at least 1.5 times the diameter of the rivet and has a height of 0.5 times the diameter. That's fine and straightforward when riveting two flat (non-dimpled) pieces. But when measuring the shop head height formed against the back side of a dimpled piece, is the shop height measured as the amount the back of the rivet extends from the maximum height of the dimple, or from the amount the rivet extends from the non-dimpled surface? (not sure if I'm explaining this clearly, but hopefully you can get what I mean) If the shop head height is measured from the surrounding non-dimpled surface, I suspect that it may not be thick enough since some of the rivet that would normally be formed in a shop head on flat surfaces would be within the dimple itself and wouldn't contribute to the head. If it's measured from the "crown" of the dimple, it would seem as though the rivet would need to be a bit longer (by an amount equal to the depth of the dimple) to form the same size of shop head as if it were on undimpled material. But I haven't seen any references in the reading I've done indicating that the rivets made to join two dimpled surfaces should be longer than if the shop head is to form on an undimpled surface. Second question - countersinking to receive a dimpled surface: I read that when countersinking to receive a dimpled surface, it should be drilled about 0.005" deeper than if the countersink was to just receive the head of a flush rivet, so that the dimple will fit properly into the countersink. But in the test pieces I was trying to join, I had to drill substantially deeper than this so that the dimple would fit within the countersink to allow the pieces to lay flush against each other. And I don't want to have "loose" holes by drilling the countersink deeper than necessary. It seemed to be due to the underside of the dimple (the part formed by the female die) starting out with a larger diameter than the starting diameter of the countersunk hole when the hole was drilled to 0.005" deeper than required to receive the head of the flush rivet. And I'm pretty sure that I used the same size countersink bit as dimple die - of course, I could have made a mistake, but the pilot/guide of both the countersink bit and dimple die fit perfectly into the hole that I had drilled. Does anyone have an idea what I'm doing wrong? Am I dimpling too deep or something? I was under the impression that I had to press the dimple die so that the flat surface of the die was flush with the flat surface of the surrounding metal, but I presume that if I dimple less it may fit within the countersink better. In either case, a flush rivet seems to fit very nicely on the surface of the dimple as it is, and if I dimple less, it may protrude a bit out. I've also found that even when riveting flat sheets together, the range of the shop head being hit or squeezed enough to have a large enough diameter while not too much that it ends up too thin is very small - smaller than I anticipated. I'm sure I'll get used to exactly the right amount with practice, but does anyone else find it to be this way? In any case, I'm glad that I decided to try practicing a bit first before getting into the real construction. And lastly, I've read in the archives that some people prefer to drill a hole slightly smaller than required when dimpling a skin (using a #41 instead of #40, for example), since the hole will expand slightly while dimpling. Is this just being overzealous, or is there a good case to be made for this? I'm thinking that if the hole were slightly smaller, the rivet would expand a bit less while filling the hole, leaving a bit more material for the shop head, making the tolerances for setting it just the right amount a bit less fine. Any advice that anyone can provide to a beginner like myself? Thanks! Dan -- Syzygy Research & Technology Box 83, Legal, AB T0G 1L0 Canada Phone: 780-961-2213 ________________________________________________________________________________
Subject: Re: Properly setting rivets with dimpled surfaces
Date: Oct 06, 2005
> when measuring the shop head height formed against the back side of a > dimpled piece, is the shop height measured as the amount the back of > the rivet extends from the maximum height of the dimple, or from the > amount the rivet extends from the non-dimpled surface? (not sure if Measure the shop head height *not including* the height of the dimple. Pick up a copy of "Aircraft Sheet Metal." Great book! Also keep in mind that there is a *range* of acceptable dimensions for rivet heads. http://images.rvproject.com/MIL-R-47196A_MI.pdf Take a peek at that Mil-Spec for reference. > drilled. Does anyone have an idea what I'm doing wrong? Am I > dimpling too deep or something? I was under the impression that I You're not doing anything wrong. Just countersink deep enough to get a good FIT, without "bottoming out" through the material. Kitplanes magazine is running a series called "Build Your Skills," and in the 4th and 5th installments it goes into gory detail about dimpling and countersinking. > had to press the dimple die so that the flat surface of the die was > flush with the flat surface of the surrounding metal, but I presume > that if I dimple less it may fit within the countersink better. In Don't dimple "less." Whack the crap out of it and get yourself a nice crisp dimple. Also consider taking a SportAir "RV Assembly" workshop or a weekend workshop from somebody like Tom Emery, or at least get some help from your EAA Chapter and/or other RV builders nearby. It sounds like you have basic technique questions and haven't had much hands-on help. Please don't take that the wrong way, I'm just suggesting that a little help up front will save you lots of headaches down the road. > I've also found that even when riveting flat sheets together, the > range of the shop head being hit or squeezed enough to have a large > enough diameter while not too much that it ends up too thin is very > small - smaller than I anticipated. I'm sure I'll get used to > exactly the right amount with practice, but does anyone else find it > to be this way? In any case, I'm glad that I decided to try > practicing a bit first before getting into the real construction. Again, reference that Mil-Spec link above. Sometimes you just have to "average" it out. There is a range of acceptable dimensions, and if I recall, the height dimension varies based on tension or shear (I could be mistaken about that). > And lastly, I've read in the archives that some people prefer to > drill a hole slightly smaller than required when dimpling a skin > (using a #41 instead of #40, for example), since the hole will expand > slightly while dimpling. Is this just being overzealous, or is there > a good case to be made for this? I'm thinking that if the hole were I'm sure people will argue one way or the other, but why not do what the kit manufacturer recommends, which is to use a #40 drill? Keep it simple. Don't overthink this stuff. You're building a light airplane, not the space shuttle or a Swiss watch. ;-) )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Oct 06, 2005
Dan, 1) Measure from the top of the dimple. The rivet doesn't need to be longer. On the RV-10 Vans does a pretty decent job of calling out the right size rivets. 2) Countersink deep enough that the dimple sits flush in the countersink after you rivet it. It's probably going to be more than .005". 3) With practice you'll be able to look at them and tell if they're good. I've been told that it's better to have them a bit flat than under-driven. 4) I don't have experience with drilling a smaller hole, but there are thousands of RV's flying who's builders didn't drill undersize holes, so I doubt it's necessary. Take Dan Checkoway's advice and get with someone who's currently building for a few hours or take a class. You'll learn a lot. PJ 40032 Dan Charrois wrote: > >Hi everyone. I'm just getting started on an RV-10 project and >practiced riveting a bit on scrap material first last night. And >I've run into a couple of problems/questions that I'm sure at least >some of you have had, but I couldn't find anything in a search of the >archives. > >First question - riveting two dimpled surfaces together: >I've seen all kinds of resources saying that a rivet is set properly >if the shop head is at least 1.5 times the diameter of the rivet and >has a height of 0.5 times the diameter. That's fine and >straightforward when riveting two flat (non-dimpled) pieces. But >when measuring the shop head height formed against the back side of a >dimpled piece, is the shop height measured as the amount the back of >the rivet extends from the maximum height of the dimple, or from the >amount the rivet extends from the non-dimpled surface? (not sure if >I'm explaining this clearly, but hopefully you can get what I mean) >If the shop head height is measured from the surrounding non-dimpled >surface, I suspect that it may not be thick enough since some of the >rivet that would normally be formed in a shop head on flat surfaces >would be within the dimple itself and wouldn't contribute to the >head. If it's measured from the "crown" of the dimple, it would seem >as though the rivet would need to be a bit longer (by an amount equal >to the depth of the dimple) to form the same size of shop head as if >it were on undimpled material. But I haven't seen any references in >the reading I've done indicating that the rivets made to join two >dimpled surfaces should be longer than if the shop head is to form on >an undimpled surface. > >Second question - countersinking to receive a dimpled surface: >I read that when countersinking to receive a dimpled surface, it >should be drilled about 0.005" deeper than if the countersink was to >just receive the head of a flush rivet, so that the dimple will fit >properly into the countersink. But in the test pieces I was trying >to join, I had to drill substantially deeper than this so that the >dimple would fit within the countersink to allow the pieces to lay >flush against each other. And I don't want to have "loose" holes by >drilling the countersink deeper than necessary. It seemed to be due >to the underside of the dimple (the part formed by the female die) >starting out with a larger diameter than the starting diameter of the >countersunk hole when the hole was drilled to 0.005" deeper than >required to receive the head of the flush rivet. And I'm pretty sure >that I used the same size countersink bit as dimple die - of course, >I could have made a mistake, but the pilot/guide of both the >countersink bit and dimple die fit perfectly into the hole that I had >drilled. Does anyone have an idea what I'm doing wrong? Am I >dimpling too deep or something? I was under the impression that I >had to press the dimple die so that the flat surface of the die was >flush with the flat surface of the surrounding metal, but I presume >that if I dimple less it may fit within the countersink better. In >either case, a flush rivet seems to fit very nicely on the surface of >the dimple as it is, and if I dimple less, it may protrude a bit out. > >I've also found that even when riveting flat sheets together, the >range of the shop head being hit or squeezed enough to have a large >enough diameter while not too much that it ends up too thin is very >small - smaller than I anticipated. I'm sure I'll get used to >exactly the right amount with practice, but does anyone else find it >to be this way? In any case, I'm glad that I decided to try >practicing a bit first before getting into the real construction. > >And lastly, I've read in the archives that some people prefer to >drill a hole slightly smaller than required when dimpling a skin >(using a #41 instead of #40, for example), since the hole will expand >slightly while dimpling. Is this just being overzealous, or is there >a good case to be made for this? I'm thinking that if the hole were >slightly smaller, the rivet would expand a bit less while filling the >hole, leaving a bit more material for the shop head, making the >tolerances for setting it just the right amount a bit less fine. > >Any advice that anyone can provide to a beginner like myself? > >Thanks! Dan >-- >Syzygy Research & Technology >Box 83, Legal, AB T0G 1L0 Canada >Phone: 780-961-2213 > > > > ________________________________________________________________________________
Date: Oct 06, 2005
Be careful here. With a quality dimpling die, the under side of a dimpled hole is the same size as the top. You can see this when you put 2 dimpled sheets together - they fit just fine. However, when fitting the dimpled sheet into a countersunk piece you can have a problem with fit because the edge of the countersunk hole is sharp and the corresponding point on the bottom of the dimple is not, (quality "spring back" dies may give a sharper transition than cheap dies) especially if you didn't use enough force when forming the dimple. Also, dimpling can distort the sheet of aluminum making it look like the dimple/countersink is a poor fit. It's very easy to make the countersunk hole too big, trying to compensate for this miss fit and then you've got a mess. In theory at least, the countersunk hole should fit the rivet. Don't arbitrarily make it bigger, figure out why it doesn't fit and fix it Dave Bristol, -6 So Cal EAA Technical Counselor Dan Charrois wrote: > > >Second question - countersinking to receive a dimpled surface: >I read that when countersinking to receive a dimpled surface, it >should be drilled about 0.005" deeper than if the countersink was to >just receive the head of a flush rivet, so that the dimple will fit >properly into the countersink. But in the test pieces I was trying >to join, I had to drill substantially deeper than this so that the >dimple would fit within the countersink to allow the pieces to lay >flush against each other. > > ________________________________________________________________________________
Date: Oct 06, 2005
On 18:57:18 2005-10-06 "D.Bristol" wrote: > Be careful here. With a quality dimpling die, the under side of a > dimpled hole is the same size as the top. You can see this when you > put 2 dimpled sheets together - they fit just fine. However, when > fitting the dimpled sheet into a countersunk piece you can have a > problem with fit because the edge of the countersunk hole is sharp > and the corresponding point on the bottom of the dimple is not, > (quality "spring back" dies may give a sharper transition than cheap > dies) especially if you didn't use enough force when forming the > dimple. The engineer in me must speak up: A countersunk hole will always have a sharp transition at the top corner, unless you remove it. A dimpled piece of aluminum will always have a rounded (or filleted) corner in the corresponding location. This means you will end up with one of two situations: One, you can countersink until the skin sits flat, in which case there will be an air gap under the dimpled skin in the "cone" of the countersink. You don't want this. It's not as strong a joint, and can lead to corrosion in the cavities, well beyond where you can see it happening. Two, you can countersink to fit the rivet, in which case the skin will *not* sit flat in the countersink. This is not a problem, if your dimple is good. When you drive the rivet it will drive that rounded corner into a sharp one and it will all become flush. This is what you want. So: Countersink only far enough to fit the head of the rivet. There's no reason to go further As for drilling a smaller hole so everything is "tighter", the engineer in me says you will end up with a smaller diameter of "meat" in the hole once the rivet is driven. This means that every rivet joint will be slightly less strong than it was designed to be. Which means your airplane is slightly less strong than it was designed to be. Why would you want that? Stop second-guessing the designer. -Rob ________________________________________________________________________________
Date: Oct 07, 2005
Hi everyone. I'm just getting started on an RV-10 project and practiced riveting a bit on scrap material first last night. And I've run into a couple of problems/questions that I'm sure at least some of you have had, but I couldn't find anything in a search of the archives. And lastly, I've read in the archives that some people prefer to drill a hole slightly smaller than required when dimpling a skin (using a #41 instead of #40, for example), since the hole will expand slightly while dimpling. Is this just being overzealous, or is there a good case to be made for this? I'm thinking that if the hole were slightly smaller, the rivet would expand a bit less while filling the hole, leaving a bit more material for the shop head, making the tolerances for setting it just the right amount a bit less fine. Any advice that anyone can provide to a beginner like myself? Thanks! Dan -- Syzygy Research & Technology Box 83, Legal, AB T0G 1L0 Canada Phone: 780-961-2213 Dan, I have been researching this subject myself. I would suggest you look at this link. http://www.tech.purdue.edu/at/courses/at308/Technical_Links/MMPDS/OptionsMen u.pdf Look at the introduction to see the approval for use. Chapter 8 covers solid rivets. Look at Table 8.1.2(a) page 8-12 It shows a 41 bit as the standard rivet-drill size for a 3/32 rivet. Mike Crowe ________________________________________________________________________________
Date: Oct 07, 2005
From another E-mail list.... Two days ago I got around to doing something that I had planned last year -- actual pull tests on riveted aluminum coupons to see how critical it is to drive rivets to the correct height. All of us building or with completed RVs (as will those those planning on it in the future) have had to wonder which imperfect rivets to drill out and which are OK. The answer is obvious when there is a severe cosmetic problem, but when strength is at issue, how much does a slightly under or overdriven rivet affect strength? How much does a grossly under or overdriven rivet affect it? Frankly, I had made the decision that the risk of damage from drilling out a flush rivet is greater than the benefit of doing so, unless an obvious cosmetic defect or really bad rivet is at issue. Now I have some hard data to go by. What I did was to make up 10 test coupons. Each of these consisted of two pieces of .032 2024-T3 sheet 1.5 inches wide and 4 inches long. These two pieces were overlapped by 1.5 inches and riveted together with two parallel rows of 3 rivets each. Of the 10 total coupons, five involved the use of universal head AN 470 AD3 rivets and the other 5 used AN 426 AD3 flush rivets. In the latter case, both pieces of aluminum were dimpled at each rivet location, as is routinely done in Van's airplanes. In fact, the coupon construction is similar to the double rivet line where the lower outboard wing skin overlaps the lower inboard wing skin. This joint is loaded in tension normally for positive G flight and gave me the idea to mimic it for the pull tests. Before getting into the results, let me ask you a question. Please think about the answer before proceeding. Just how many pounds of force do you think it would take to destroy one of the sheets used in making up the coupons? Remember this is .032, 2024-T3 sheet 4 inches long and 1.5 inches wide with no holes or rivets in it. Think about grabbing and suspending it at one end with some sort of clamp across the entire 1.5 inch width and then hanging weights on the other end from another clamp. How much weight would it take to break this .032 inch thick sheet? Would a 100 pound set of barbells do it? A 500 pound set? A 1200 pound small car? A gross weight RV8 at 1800 pounds? A gross weight Grumman Tiger at 2400 pounds? More than that? Come up with some sort of gut feel before proceeding. I was surprised by the answer. You may or may not be, depending on your knowledge in this area. Since some of you will cheat and read on, I'll hold the answer for a moment! Each of the 5 test coupons, both with the universal head rivets and the flush head rivets, was riveted to a different degree. One was grossly under driven, one was slightly under driven, one was correct per the rivet gauge, one was slightly over driven and the last was grossly over driven. The slightly under driven and slightly over driven rivets were such that you would probably need a rivet gauge to detect them -- I did this because I suspect that most of the rivets in our planes fall into this category. The grossly over and under driven rivets were really gross. The over driven were squashed nearly flat and the under driven were barely set at all. I did this to see just how poorly a joint make of this sort of gross error would hold up. You would easily see these and know there was a problem immediately. You'll find the results interesting......... The idea was to put each coupon in a pull test machine and expose the riveted joint to a slowly increasing force until it yielded. This was done at a structural test lab in Paramount (Southern CA city) that works mostly with civil engineering construction materials. A stress/strain graph was running and we monitored it to see the first indication of joint failure as indicated by a decrease in force required as the coupon stretched, cracked, broke in two, sheared or tipped rivets, etc. I was interested in the force required to cause the initial failure, as well as the nature and appearance of that initial failure; ie, what actually happened first. We agreed to stop the machine at the incipient indication of failure, thus preserving the coupon in its early failure state without destroying the joint completely. I was very curious as to how things would fail and really had no idea other than the thought that the dimpled, flush riveted joint would probably be stronger than the undimpled one with the 470 universal head rivets. In contrast, one of the owners of the lab came in to watch and thought the opposite would be true. In his 50 years in the business, he had never seen this test done. What do you think would hold best? That said, here is the answer to my prior question. A force of 2300 pounds was required to break the test material with no rivets or holes in it. It failed catastrophically shortly after some initial stretching was noted. I had no idea that a cross section of this 2024 T3 sheet, .032 inches thick and 1.5 inches wide, would sustain anywhere near that load. Frankly, I was surprised when it passed 1000 pounds and still going strong. Before showing you the numbers, I will give a brief summary of them: 1. The dimpled, flush riveted construction was stronger, but not by as much as I had thought. However, and this is really important, initial failure of the dimpled construction was generally not catastrophic and occurred as rivet tipping and rivet head distortion. In contrast, initial failure of the AN 470 undimpled construction was generally catastrophic by rivet shear. I am really happy Van uses the flush riveted, double dimpled joints throughout most of the airplane! 2. Slightly under driving or slightly over driving a rivet makes an observable and thus measurable difference in the joint strength. 3. Slightly over driving is stronger than slightly under driving and results (in my opinion) in an insignificant difference in strength as compared to properly driven rivets. 4. In the one test of slightly over driven AN 470 rivets, the joint was actually stronger than with properly driven rivets. This may have just been the luck of the draw for this single sample, so I wouldn't put any real faith in it. 5. A joint made of grossly over driven rivets is stronger joint than a joint make of grossly under driven ones. 6. A grossly under driven AN 470 joint is much weaker than a grossly under driven AN 426 joint. 7. No joint was as strong as the parent material itself. To summarize the summary, try for properly driven rivets but realize that minor over driving is preferable to minor under driving and results in nearly the same strength as does the condition of properly driven rivets. AN 426 AD 3 Table Condition Force at failure Nature of failure Gross under 1650 Rivet tipping, head distortion Slight under 1775 Same Correct 2025 Same Slight over 1975 Same Gross over 1825 Sheet tear at rivet line AN 470 AD 3 Table Gross under 1100 Rivet tip plus one sheared rivet Slight under 1600 5 sheared rivets! Correct 1625 6 sheared rivets! Slight over 1750 6 sheared rivets! Gross over 1500 Rivet tip plus sheet tear at rivet line Anyway, those are some real numbers for an area we have undoubtedly thought about at one time or another. My opinions, FWIW: I think an occasional rivet that is slightly under driven or slightly over driven is utterly no big deal and can safely be ignored. We all have some of these flying in formation in our airplanes. A line of them would be another matter. Even an occasional grossly over driven rivet is probably OK, especially if getting rid of it could cause damage. And if underdriven too much, just whack it again. Hope you learned something from this. I certainly did. Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Oct 07, 2005
For those who have not had good experiences with the wingtip comm antennas, please describe how you had the antenna mounted in the wingtip. I have had people who have had these antennas tell me they work great, of those that did they had the radiating element attached to the top surface of the wingtip to maximize the vertical component of the antenna. In other words the ground portion was attached to the bottom of the wingtip and the antenna was bent so that the radiating element was glassed to the top surface of the wingtip along its edge. With that said... I have a belly mounted antenna that works well on my -6, and I have borrowed a MFJ antenna analyzer to check it. VSWR of the belly mounted antenna was typically 1.2-1.8 best as I can remember across the frequency range. The problem with a good antenna is that you pick up everybody and their mother transmitting within a three state radius so sometimes the chatter can get overwhelming especially if you only care about the aircraft that are within a few miles of you. So to have a 50 mile radius of communications is acceptable to me, the only time you really ever use that sort of range or beyond is to chit-chat with your buddies on the other side of the state. There is one RV-8 that I occasionnally fly with that whenever I get up close, we can't talk to each other. If I back out 20 ft then everything is fine. I suspect it has to do with the geometry in which the signals radiate between our two airplanes. My point being is there is no perfect location for an antenna on an RV for all circumstances. Regards, Bob Japundza RV-6 flying, F1 under const. ________________________________________________________________________________
Date: Oct 07, 2005
Very good report Scott! This answers some good questions that I never had answers for before. Thanks! Dave Scott Bilinski wrote: > > From another E-mail list.... > > >Two days ago I got around to doing something that I had planned last >year -- actual pull tests on riveted aluminum coupons to see how >critical it is to drive rivets to the correct height. All of us >building or with completed RVs (as will those those planning on it in >the future) have had to wonder which imperfect rivets to drill out and >which are OK. The answer is obvious when there is a severe cosmetic >problem, but when strength is at issue, how much does a slightly under >or overdriven rivet affect strength? How much does a grossly under or >overdriven rivet affect it? Frankly, I had made the decision that the >risk of damage from drilling out a flush rivet is greater than the >benefit of doing so, unless an obvious cosmetic defect or really bad >rivet is at issue. Now I have some hard data to go by. > > >What I did was to make up 10 test coupons. Each of these consisted of >two pieces of .032 2024-T3 sheet 1.5 inches wide and 4 inches long. >These two pieces were overlapped by 1.5 inches and riveted together with >two parallel rows of 3 rivets each. Of the 10 total coupons, five >involved the use of universal head AN 470 AD3 rivets and the other 5 >used AN 426 AD3 flush rivets. In the latter case, both pieces of >aluminum were dimpled at each rivet location, as is routinely done in >Van's airplanes. In fact, the coupon construction is similar to the >double rivet line where the lower outboard wing skin overlaps the lower >inboard wing skin. This joint is loaded in tension normally for >positive G flight and gave me the idea to mimic it for the pull tests. > > >Before getting into the results, let me ask you a question. Please >think about the answer before proceeding. Just how many pounds of force >do you think it would take to destroy one of the sheets used in making >up the coupons? Remember this is .032, 2024-T3 sheet 4 inches long and >1.5 inches wide with no holes or rivets in it. Think about grabbing and >suspending it at one end with some sort of clamp across the entire 1.5 >inch width and then hanging weights on the other end from another clamp. >How much weight would it take to break this .032 inch thick sheet? >Would a 100 pound set of barbells do it? A 500 pound set? A 1200 pound >small car? A gross weight RV8 at 1800 pounds? A gross weight Grumman >Tiger at 2400 pounds? More than that? Come up with some sort of gut >feel before proceeding. I was surprised by the answer. You may or may >not be, depending on your knowledge in this area. > > >Since some of you will cheat and read on, I'll hold the answer for a >moment! Each of the 5 test coupons, both with the universal head rivets >and the flush head rivets, was riveted to a different degree. One was >grossly under driven, one was slightly under driven, one was correct per >the rivet gauge, one was slightly over driven and the last was grossly >over driven. The slightly under driven and slightly over driven rivets >were such that you would probably need a rivet gauge to detect them -- I >did this because I suspect that most of the rivets in our planes fall >into this category. The grossly over and under driven rivets were >really gross. The over driven were squashed nearly flat and the under >driven were barely set at all. I did this to see just how poorly a >joint make of this sort of gross error would hold up. You would easily >see these and know there was a problem immediately. You'll find the >results interesting......... > > >The idea was to put each coupon in a pull test machine and expose the >riveted joint to a slowly increasing force until it yielded. This was >done at a structural test lab in Paramount (Southern CA city) that works >mostly with civil engineering construction materials. A stress/strain >graph was running and we monitored it to see the first indication of >joint failure as indicated by a decrease in force required as the coupon >stretched, cracked, broke in two, sheared or tipped rivets, etc. I was >interested in the force required to cause the initial failure, as well >as the nature and appearance of that initial failure; ie, what actually >happened first. We agreed to stop the machine at the incipient >indication of failure, thus preserving the coupon in its early failure >state without destroying the joint completely. I was very curious as to >how things would fail and really had no idea other than the thought that >the dimpled, flush riveted joint would probably be stronger than the >undimpled one with the 470 universal head rivets. In contrast, one of >the owners of the lab came in to watch and thought the opposite would be >true. In his 50 years in the business, he had never seen this test >done. What do you think would hold best? > > >That said, here is the answer to my prior question. A force of 2300 >pounds was required to break the test material with no rivets or holes >in it. It failed catastrophically shortly after some initial stretching >was noted. I had no idea that a cross section of this 2024 T3 sheet, >.032 inches thick and 1.5 inches wide, would sustain anywhere near that >load. Frankly, I was surprised when it passed 1000 pounds and still >going strong. > > >Before showing you the numbers, I will give a brief summary of them: > > >1. The dimpled, flush riveted construction was stronger, but not by as >much as I had thought. However, and this is really important, initial >failure of the dimpled construction was generally not catastrophic and >occurred as rivet tipping and rivet head distortion. In contrast, >initial failure of the AN 470 undimpled construction was generally >catastrophic by rivet shear. I am really happy Van uses the flush >riveted, double dimpled joints throughout most of the airplane! > > >2. Slightly under driving or slightly over driving a rivet makes an >observable and thus measurable difference in the joint strength. > > >3. Slightly over driving is stronger than slightly under driving and >results (in my opinion) in an insignificant difference in strength as >compared to properly driven rivets. > > >4. In the one test of slightly over driven AN 470 rivets, the joint was >actually stronger than with properly driven rivets. This may have just >been the luck of the draw for this single sample, so I wouldn't put any >real faith in it. > > >5. A joint made of grossly over driven rivets is stronger joint than a >joint make of grossly under driven ones. > > >6. A grossly under driven AN 470 joint is much weaker than a grossly >under driven AN 426 joint. > > >7. No joint was as strong as the parent material itself. > > >To summarize the summary, try for properly driven rivets but realize >that minor over driving is preferable to minor under driving and results >in nearly the same strength as does the condition of properly driven >rivets. > > >AN 426 AD 3 Table > > >Condition Force at failure Nature of failure > > >Gross under 1650 Rivet tipping, head distortion > >Slight under 1775 Same > >Correct 2025 Same > >Slight over 1975 Same > >Gross over 1825 Sheet tear at rivet line > > >AN 470 AD 3 Table > > >Gross under 1100 Rivet tip plus one sheared rivet > >Slight under 1600 5 sheared rivets! > >Correct 1625 6 sheared rivets! > >Slight over 1750 6 sheared rivets! > >Gross over 1500 Rivet tip plus sheet tear at > >rivet line > > >Anyway, those are some real numbers for an area we have undoubtedly >thought about at one time or another. My opinions, FWIW: I think an >occasional rivet that is slightly under driven or slightly over driven >is utterly no big deal and can safely be ignored. We all have some of >these flying in formation in our airplanes. A line of them would be >another matter. Even an occasional grossly over driven rivet is >probably OK, especially if getting rid of it could cause damage. And if >underdriven too much, just whack it again. Hope you learned something >from this. I certainly did. > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 > > > > ________________________________________________________________________________
Date: Oct 07, 2005
Great INFO Scott !! Now I won't feel so bad about the few rivets I left in place that weren't just right. Sometimes one has to weigh the potential for making things worse against leaving the non-perfect rivet there. This info just confirms my building decisions. Thanks Again Bill ________________________________________________________________________________
Date: Oct 07, 2005
> Remind me tomorrow to put an AN426AD3-x rivet in my female dimple die. I > honestly haven't even tried that yet...but I intend to! I wonder if the > rivet will sit flush or sit low. My $.02 bet is that it will sit low. The rivet sets low in a regular die. Now the question is how to get the rivet back out of the die... :-) ________________________________________________________________________________
Date: Oct 07, 2005
Ha! At least you didn't make my mistake: I used a female die and a rivet in order to dimple an area I couldn't fit the male die into (can't remember where it was right now). The rivet was too long for the hole in the female die and when I hit it, the rivet expanded in the die and got stuck. Getting it out was not much fun. PJ 40032 David Burton wrote: > > > >>Remind me tomorrow to put an AN426AD3-x rivet in my female dimple die. I >>honestly haven't even tried that yet...but I intend to! I wonder if the >>rivet will sit flush or sit low. My $.02 bet is that it will sit low. >> >> > > >The rivet sets low in a regular die. Now the question is how to get the >rivet back out of the die... :-) > > > > ________________________________________________________________________________
Date: Oct 07, 2005
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
This will be the somewhat the same for countersinking. You want a very slight... ever so slight recess of the rivet head on the 426 rivet. You should just see a faint shiny hair thin part of the countersink and the rivet should be basically flush. Darrell David Burton wrote: > Remind me tomorrow to put an AN426AD3-x rivet in my female dimple die. I > honestly haven't even tried that yet...but I intend to! I wonder if the > rivet will sit flush or sit low. My $.02 bet is that it will sit low. The rivet sets low in a regular die. Now the question is how to get the rivet back out of the die... :-) --------------------------------- Click here to donate to the Hurricane Katrina relief effort. ________________________________________________________________________________
Date: Oct 07, 2005
Subject: Re: Wing tip com antenna
You'll want more than 50 miles of range if you ever call flight service for wx at your destination. In close formation, you are experiencing receiver front-end overload, which has everything to do with near-field signal strength and little to do with exact antenna location, save for its distance from the other ship's antenna. If you want just 50 miles' range, try lopping the antenna off at 6 or 8 inches. The high swr will fold back your radio's power output, and you'll reduce aerodynamic drag to boot. Kidding, of course. -Stormy -----Original Message----- From: Bob J <rocketbob(at)gmail.com> Subject: Re: RV-List: Wing tip com antenna For those who have not had good experiences with the wingtip comm antennas, please describe how you had the antenna mounted in the wingtip. I have had people who have had these antennas tell me they work great, of those that did they had the radiating element attached to the top surface of the wingtip to maximize the vertical component of the antenna. In other words the ground portion was attached to the bottom of the wingtip and the antenna was bent so that the radiating element was glassed to the top surface of the wingtip along its edge. With that said... I have a belly mounted antenna that works well on my -6, and I have borrowed a MFJ antenna analyzer to check it. VSWR of the belly mounted antenna was typically 1.2-1.8 best as I can remember across the frequency range. The problem with a good antenna is that you pick up everybody and their mother transmitting within a three state radius so sometimes the chatter can get overwhelming especially if you only care about the aircraft that are within a few miles of you. So to have a 50 mile radius of communications is acceptable to me, the only time you really ever use that sort of range or beyond is to chit-chat with your buddies on the other side of the state. There is one RV-8 that I occasionnally fly with that whenever I get up close, we can't talk to each other. If I back out 20 ft then everything is fine. I suspect it has to do with the geometry in which the signals radiate between our two airplanes. My point being is there is no perfect location for an antenna on an RV for all circumstances. Regards, Bob Japundza RV-6 flying, F1 under const. ________________________________________________________________________________
Date: Oct 07, 2005
On 10/7/05, sportav8r(at)aol.com wrote: > > > You'll want more than 50 miles of range if you ever call flight service > for wx at your destination. I've had mixed luck getting FSS or flightwatch even with a good antenna. If you want just 50 miles' range, try lopping the antenna off at 6 or 8 > inches. The high swr will fold back your radio's power output, and you'll > reduce aerodynamic drag to boot. Kidding, of course. > I just turn the dang radio off! :) So...how was your antenna installed; was it on the bottom surface only? Regards, Bob ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Subject: Re: Firewall ??????????
Date: Oct 07, 2005
Hi to all I am at that stage in the project where I need to start formulating plans for fire wall info. Things to contemplate, gotches to watch out for, and the equipment needs. I will be hanging an IO 360 fuel injected, Pmags, CS prop......................I am also considering (99% for sure) dual oil coolers, horizontal sump........it is real out in SW Utah Desert Country. Also the need for a gascolater considering I will have fuel injection???????? Your help and info will be greatly appreciated. TIA Frank @ SGU and SLC 7A Fuse about to be rolled.....Finish kit will arrive next week ________________________________________________________________________________
Date: Oct 07, 2005
Scott Thanks for the valuable info. I would be interested in the clinched rivet senerio. Also I would think that a head that was round and to spec but slightly tiped would pretty much mimic your results. At any rate thanks.....I can now breath a little more easy about some of my more interesting buck / shot / driven RIVETS. Plus I belive that this airplane is way over enginneered and probably has 25% more rivets than really needed . JUST a GUESS Frank @ SGU and SLC >From: Dave Bristol <dbris200(at)sbcglobal.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Properly setting rivets with dimpled surfaces >Date: Fri, 07 Oct 2005 08:56:04 -0700 > > >Very good report Scott! This answers some good questions that I never >had answers for before. Thanks! > >Dave > >Scott Bilinski wrote: > ><bilinski@kyocera-wireless.com> > > > > From another E-mail list.... > > > > > >Two days ago I got around to doing something that I had planned last > >year -- actual pull tests on riveted aluminum coupons to see how > >critical it is to drive rivets to the correct height. All of us > >building or with completed RVs (as will those those planning on it in > >the future) have had to wonder which imperfect rivets to drill out and > >which are OK. The answer is obvious when there is a severe cosmetic > >problem, but when strength is at issue, how much does a slightly under > >or overdriven rivet affect strength? How much does a grossly under or > >overdriven rivet affect it? Frankly, I had made the decision that the > >risk of damage from drilling out a flush rivet is greater than the > >benefit of doing so, unless an obvious cosmetic defect or really bad > >rivet is at issue. Now I have some hard data to go by. > > > > > >What I did was to make up 10 test coupons. Each of these consisted of > >two pieces of .032 2024-T3 sheet 1.5 inches wide and 4 inches long. > >These two pieces were overlapped by 1.5 inches and riveted together with > >two parallel rows of 3 rivets each. Of the 10 total coupons, five > >involved the use of universal head AN 470 AD3 rivets and the other 5 > >used AN 426 AD3 flush rivets. In the latter case, both pieces of > >aluminum were dimpled at each rivet location, as is routinely done in > >Van's airplanes. In fact, the coupon construction is similar to the > >double rivet line where the lower outboard wing skin overlaps the lower > >inboard wing skin. This joint is loaded in tension normally for > >positive G flight and gave me the idea to mimic it for the pull tests. > > > > > >Before getting into the results, let me ask you a question. Please > >think about the answer before proceeding. Just how many pounds of force > >do you think it would take to destroy one of the sheets used in making > >up the coupons? Remember this is .032, 2024-T3 sheet 4 inches long and > >1.5 inches wide with no holes or rivets in it. Think about grabbing and > >suspending it at one end with some sort of clamp across the entire 1.5 > >inch width and then hanging weights on the other end from another clamp. > >How much weight would it take to break this .032 inch thick sheet? > >Would a 100 pound set of barbells do it? A 500 pound set? A 1200 pound > >small car? A gross weight RV8 at 1800 pounds? A gross weight Grumman > >Tiger at 2400 pounds? More than that? Come up with some sort of gut > >feel before proceeding. I was surprised by the answer. You may or may > >not be, depending on your knowledge in this area. > > > > > >Since some of you will cheat and read on, I'll hold the answer for a > >moment! Each of the 5 test coupons, both with the universal head rivets > >and the flush head rivets, was riveted to a different degree. One was > >grossly under driven, one was slightly under driven, one was correct per > >the rivet gauge, one was slightly over driven and the last was grossly > >over driven. The slightly under driven and slightly over driven rivets > >were such that you would probably need a rivet gauge to detect them -- I > >did this because I suspect that most of the rivets in our planes fall > >into this category. The grossly over and under driven rivets were > >really gross. The over driven were squashed nearly flat and the under > >driven were barely set at all. I did this to see just how poorly a > >joint make of this sort of gross error would hold up. You would easily > >see these and know there was a problem immediately. You'll find the > >results interesting......... > > > > > >The idea was to put each coupon in a pull test machine and expose the > >riveted joint to a slowly increasing force until it yielded. This was > >done at a structural test lab in Paramount (Southern CA city) that works > >mostly with civil engineering construction materials. A stress/strain > >graph was running and we monitored it to see the first indication of > >joint failure as indicated by a decrease in force required as the coupon > >stretched, cracked, broke in two, sheared or tipped rivets, etc. I was > >interested in the force required to cause the initial failure, as well > >as the nature and appearance of that initial failure; ie, what actually > >happened first. We agreed to stop the machine at the incipient > >indication of failure, thus preserving the coupon in its early failure > >state without destroying the joint completely. I was very curious as to > >how things would fail and really had no idea other than the thought that > >the dimpled, flush riveted joint would probably be stronger than the > >undimpled one with the 470 universal head rivets. In contrast, one of > >the owners of the lab came in to watch and thought the opposite would be > >true. In his 50 years in the business, he had never seen this test > >done. What do you think would hold best? > > > > > >That said, here is the answer to my prior question. A force of 2300 > >pounds was required to break the test material with no rivets or holes > >in it. It failed catastrophically shortly after some initial stretching > >was noted. I had no idea that a cross section of this 2024 T3 sheet, > >.032 inches thick and 1.5 inches wide, would sustain anywhere near that > >load. Frankly, I was surprised when it passed 1000 pounds and still > >going strong. > > > > > >Before showing you the numbers, I will give a brief summary of them: > > > > > >1. The dimpled, flush riveted construction was stronger, but not by as > >much as I had thought. However, and this is really important, initial > >failure of the dimpled construction was generally not catastrophic and > >occurred as rivet tipping and rivet head distortion. In contrast, > >initial failure of the AN 470 undimpled construction was generally > >catastrophic by rivet shear. I am really happy Van uses the flush > >riveted, double dimpled joints throughout most of the airplane! > > > > > >2. Slightly under driving or slightly over driving a rivet makes an > >observable and thus measurable difference in the joint strength. > > > > > >3. Slightly over driving is stronger than slightly under driving and > >results (in my opinion) in an insignificant difference in strength as > >compared to properly driven rivets. > > > > > >4. In the one test of slightly over driven AN 470 rivets, the joint was > >actually stronger than with properly driven rivets. This may have just > >been the luck of the draw for this single sample, so I wouldn't put any > >real faith in it. > > > > > >5. A joint made of grossly over driven rivets is stronger joint than a > >joint make of grossly under driven ones. > > > > > >6. A grossly under driven AN 470 joint is much weaker than a grossly > >under driven AN 426 joint. > > > > > >7. No joint was as strong as the parent material itself. > > > > > >To summarize the summary, try for properly driven rivets but realize > >that minor over driving is preferable to minor under driving and results > >in nearly the same strength as does the condition of properly driven > >rivets. > > > > > >AN 426 AD 3 Table > > > > > >Condition Force at failure Nature of failure > > > > > >Gross under 1650 Rivet tipping, head distortion > > > >Slight under 1775 Same > > > >Correct 2025 Same > > > >Slight over 1975 Same > > > >Gross over 1825 Sheet tear at rivet line > > > > > >AN 470 AD 3 Table > > > > > >Gross under 1100 Rivet tip plus one sheared rivet > > > >Slight under 1600 5 sheared rivets! > > > >Correct 1625 6 sheared rivets! > > > >Slight over 1750 6 sheared rivets! > > > >Gross over 1500 Rivet tip plus sheet tear at > > > >rivet line > > > > > >Anyway, those are some real numbers for an area we have undoubtedly > >thought about at one time or another. My opinions, FWIW: I think an > >occasional rivet that is slightly under driven or slightly over driven > >is utterly no big deal and can safely be ignored. We all have some of > >these flying in formation in our airplanes. A line of them would be > >another matter. Even an occasional grossly over driven rivet is > >probably OK, especially if getting rid of it could cause damage. And if > >underdriven too much, just whack it again. Hope you learned something > >from this. I certainly did. > > > > > >Scott Bilinski > >Eng dept 305 > >Phone (858) 657-2536 > >Pager (858) 502-5190 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 07, 2005
Yes, bottom surface only, curving most of the way up to the outermost edge -----Original Message----- From: Bob J <rocketbob(at)gmail.com> Subject: Re: RV-List: Wing tip com antenna On 10/7/05, sportav8r(at)aol.com wrote: > > > You'll want more than 50 miles of range if you ever call flight service > for wx at your destination. I've had mixed luck getting FSS or flightwatch even with a good antenna. If you want just 50 miles' range, try lopping the antenna off at 6 or 8 > inches. The high swr will fold back your radio's power output, and you'll > reduce aerodynamic drag to boot. Kidding, of course. > I just turn the dang radio off! :) So...how was your antenna installed; was it on the bottom surface only? Regards, Bob ________________________________________________________________________________
Date: Oct 07, 2005
From: "Richard E. Tasker" <retasker(at)optonline.net>
Shouldn't be installed on the bottom surface (or the top surface for that matter). It should be installed to get the maximum vertical orientation. This means that it does not touch the internal surface of the wingtip (at least on the 9 tips) except at the bottom of the antenna and at the top of the antenna. Support it with fiberglass. Dick Tasker sportav8r(at)aol.com wrote: > >Yes, bottom surface only, curving most of the way up to the outermost edge > >-----Original Message----- >From: Bob J <rocketbob(at)gmail.com> >To: rv-list(at)matronics.com >Subject: Re: RV-List: Wing tip com antenna > > >On 10/7/05, sportav8r(at)aol.com wrote: > > >> >>You'll want more than 50 miles of range if you ever call flight service >>for wx at your destination. >> >> > > >I've had mixed luck getting FSS or flightwatch even with a good antenna. > >If you want just 50 miles' range, try lopping the antenna off at 6 or 8 > > >>inches. The high swr will fold back your radio's power output, and you'll >>reduce aerodynamic drag to boot. Kidding, of course. >> >> >> > >I just turn the dang radio off! :) > >So...how was your antenna installed; was it on the bottom surface only? > >Regards, >Bob > > > > -- ---- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. ---- ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Oct 08, 2005
I installed a gascolator on my carburated engine, and wouldn't do it again. In fact, I've thought about removing the one I've got. I'm very disciplined about sumping the wing tanks, and have never found any water in the gascolator. On the other hand, I think the gascolator is just another big heat-sink under the cowl and contributes in some way to vapor lock. If you're worried about heat related issues, vapor lock needs to be on your list. With our tight cowls, heat gets trapped in there and everything gets warm, particularly if you land, shut down, and try to re-start in 20-30 minutes on a hot summer day, which is probably the worst case. If I was you, I'd consider firesleeving the fuel lines and aiming a blast tube at your fuel pump. Some folks even valve things so they can circulate hot firewall forward fuel back to one of the tanks, but I don't like adding complexity to a fuel system. It adds another point of failure in a critical system. On the oil cooler issue, 2 coolers? You'll see more pressure drop, there isn't a whole lot of extra room under the cowl, and you're doubling the number of failure points. Before you go that route, you might talk to Pacific Oil Cooler Service (1-800 866 7335). IMO, they are the most knowledgable people around on oil coolers. They may be able to recommend a single cooler that will serve your needs. I fought the oil temperature war when my airplane was new. In the end, the single biggest factor in fixing my temperature problem was cutting a big enough hole in the baffles to provide air to the baffle mounted cooler. KB ----- Original Message ----- From: "Frank Stringham" <fstringham(at)hotmail.com> Subject: RV-List: Re: Firewall ?????????? > > > Hi to all > > I am at that stage in the project where I need to start formulating plans > for fire wall info. Things to contemplate, gotches to watch out for, and > the > equipment needs. I will be hanging an IO 360 fuel injected, Pmags, CS > prop......................I am also considering (99% for sure) dual oil > coolers, horizontal sump........it is real out in SW Utah Desert Country. > Also the need for a gascolater considering I will have fuel > injection???????? Your help and info will be greatly appreciated. > > TIA > > Frank @ SGU and SLC 7A Fuse about to be rolled.....Finish kit will arrive > next week > > > ________________________________________________________________________________
Subject: Re: Full Swivel Tail wheel
Date: Oct 08, 2005
Andair sold a pneumatic TW for a while but it seems to have fizzled -- too insubstantial and prone to flats. I tried two alternatives with plastic hubs (still solid tires) and they saved a little weight but were also harder rubber and vibrated a lot more, so I went back to the std. Vans wheel. I'm still looking for a source for some better quality bearings for the std. wheel. Randall Henderson RV-6 ~700 hrs ________________________________________________________________________________
Date: Oct 08, 2005
Randall, What's the problem with the bearings on the standard wheel? Mine has 350 hours and a bunch of landings, and it is holding up very well despite the abuse I occasionally put it through. KB ----- Original Message ----- From: "randall" <rv6n6r(at)comcast.net> Subject: Re: RV-List: Full Swivel Tail wheel > > Andair sold a pneumatic TW for a while but it seems to have fizzled -- too > insubstantial and prone to flats. I tried two alternatives with plastic > hubs > (still solid tires) and they saved a little weight but were also harder > rubber and vibrated a lot more, so I went back to the std. Vans wheel. I'm > still looking for a source for some better quality bearings for the std. > wheel. > > Randall Henderson > RV-6 ~700 hrs > > > ________________________________________________________________________________
Date: Oct 08, 2005
The only problem that I found with Van's tailwheel is that it needs a spacer between the two bearings so that the axle nut can be tightened enough to keep the race from spinning on the axle, without preloading the bearings too much. Very easy to do. The bearings seem to be good enough but probably won't last very long if they have too much preload. Dave B. -6 So Cal randall wrote: > >Andair sold a pneumatic TW for a while but it seems to have fizzled -- too >insubstantial and prone to flats. I tried two alternatives with plastic hubs >(still solid tires) and they saved a little weight but were also harder >rubber and vibrated a lot more, so I went back to the std. Vans wheel. I'm >still looking for a source for some better quality bearings for the std. >wheel. > >Randall Henderson >RV-6 ~700 hrs > > > > ________________________________________________________________________________
Date: Oct 08, 2005
I don't remember how long my first TW lasted -- maybe 300-400 hrs -- but the bearings were shot before the tire was. They are pretty cheezy affairs as others have found (check the archives.) It's not a big deal, would nice to find something a little better is all. Randall Henderson RV-6 > > Randall, > > What's the problem with the bearings on the standard wheel? Mine has 350 > hours and a bunch of landings, and it is holding up very well despite the > abuse I occasionally put it through. > > KB ________________________________________________________________________________
Subject: Full Swivel Tail wheel
Date: Oct 08, 2005
My experience was similar to Randall's. I got a light wheel with sealed bearings from Terry Jantzi, it's working well. Dw RV-6 910hrs -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of randall Subject: Re: RV-List: Full Swivel Tail wheel I don't remember how long my first TW lasted -- maybe 300-400 hrs -- but the bearings were shot before the tire was. They are pretty cheezy affairs as others have found (check the archives.) It's not a big deal, would nice to find something a little better is all. Randall Henderson RV-6 > --> > > Randall, > > What's the problem with the bearings on the standard wheel? Mine has > 350 hours and a bunch of landings, and it is holding up very well > despite the abuse I occasionally put it through. > > KB ________________________________________________________________________________
Date: Oct 08, 2005
Frank, I agree with Kyle. A properly installed oil cooler will cool your engine, and adding lines/failure points is NOT good. Minimize all lines/connections/lengths, firesleeve, blast tube major components. Do a GOOD job on your baffling to insure air flow where you WANT it. I have FI and don't use a gascolator, no problems in 900 hrs. One thing I do that helps is when I stop somwhere, I open the oil door to allow cool air to come in the bottom of the cowl and circulate up thru everything and out the top of the cowl. I check my oil before EVERY flight, so it is not an inconvenience, and helps reduce heat soak. dw RV-6 910hrs -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kyle Boatright Subject: Re: RV-List: Re: Firewall ?????????? --> I installed a gascolator on my carburated engine, and wouldn't do it again. In fact, I've thought about removing the one I've got. I'm very disciplined about sumping the wing tanks, and have never found any water in the gascolator. On the other hand, I think the gascolator is just another big heat-sink under the cowl and contributes in some way to vapor lock. If you're worried about heat related issues, vapor lock needs to be on your list. With our tight cowls, heat gets trapped in there and everything gets warm, particularly if you land, shut down, and try to re-start in 20-30 minutes on a hot summer day, which is probably the worst case. If I was you, I'd consider firesleeving the fuel lines and aiming a blast tube at your fuel pump. Some folks even valve things so they can circulate hot firewall forward fuel back to one of the tanks, but I don't like adding complexity to a fuel system. It adds another point of failure in a critical system. On the oil cooler issue, 2 coolers? You'll see more pressure drop, there isn't a whole lot of extra room under the cowl, and you're doubling the number of failure points. Before you go that route, you might talk to Pacific Oil Cooler Service (1-800 866 7335). IMO, they are the most knowledgable people around on oil coolers. They may be able to recommend a single cooler that will serve your needs. I fought the oil temperature war when my airplane was new. In the end, the single biggest factor in fixing my temperature problem was cutting a big enough hole in the baffles to provide air to the baffle mounted cooler. KB ________________________________________________________________________________
Date: Oct 08, 2005
> I don't remember how long my first TW lasted -- maybe 300-400 hrs -- but the > bearings were shot before the tire was. Have you guys checked the price of Van's TW bearings? $2.60 and an entire TW is $27 at currant 2005 prices! Chief Aircraft wants $114.50 for a solid tire for the Scott 2000 TW and the 3200 TW is $349.95 for the wheel assembly!!! Now, again, what is the issue with Van's Tailwheel ??? I don't find much of a problem here as I can carry spares in my parts inventory and still save much $$$$ even if they have to be replaced every 300 hrs! Dick DeCramer RV6 90hrs Minnesota ________________________________________________________________________________
Subject: stereo or not?
Date: Oct 10, 2005
Hi all, just wondering about the advantage if any of having a stereo input to the audio system. Considering the ambient noise level in an RV, is stereo noticeable and worth the added cost? Thanks Greg RV8 ________________________________________________________________________________
Subject: Re: stereo or not?
Date: Oct 09, 2005
Oh, it is MOST definitely worth having stereo. If you are any sort of audiophile -- that is, you can actually tell the difference between mono and stereo -- then I highly recommend installing a stereo input. I've used an ipod & now an XM Roady 2 in my RV and it really kicks butt. Using the GMA-340 with its 20dB boost enabled and listening through Lightspeed headsets that I have (25XL and 20XL), the sound quality is excellent considering its in an airplane with tiny headset speakers. I personally wouldn't be happy with monaural sound. Something else to consider... I originally wired up a single 1/8" stereo jack under the panel (wired into the entertainment input in my audio panel). That worked, but I'm not a fan of wires in the cockpit -- and it's not very conducive to "expansion" of the system. When it came time to install my XM radio "permanently," I went ahead and installed a 4-circuit terminal strip. Shield, left, right, ground, wired to the audio panel. The 1/8" stereo jack hooks up at the terminal strip, as does the permanent XM installation. If I ever want to add some other audio device in the future, I just wire it to the terminal strip. No need to do surgery on my audio panel harness. I'm sure there are more elegant ways of doing this, but this works for me. Hope this helps, )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Greg@itmack" <greg(at)itmack.com> Subject: RV-List: stereo or not? > > Hi all, just wondering about the advantage if any of having a stereo input to the audio system. Considering the ambient noise level in an RV, is stereo noticeable and worth the added cost? > > Thanks > Greg RV8 > > ________________________________________________________________________________
Subject: Sealer on Whelen strobe lights
Date: Oct 10, 2005
Thanks all for the input. Michele RV8 - Fuselage -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] Subject: RV-List: Sealer on Whelen strobe lights Listers, I just received my Whelen strobe lights. They are sealed with some white ProSeal like, Sikaflex like substance which is quite rubbery and which seems perfect for preserving wires from chaffing against each other as they come out of connectors or pass through grommets. Any of you guys have an idea as to what Whelen might have used ? Or could you recommend a similar product ? Thanks, Michele RV8 - Fuselage ________________________________________________________________________________
Date: Oct 10, 2005
Are you someone who listens to music at home, in the office, in the car? If you love music and especially want to take long trips with your RV it is a must. However a cheap stereo intercom and headset and poor music source (low power low fidelity) is almost worse than having no music. If you want music be ready to pay extra for the best components. There is more to it than having a STEREO input. Good quality input (ipod, xm radio), good quality stereo headset (lightspeed) and most important good quality intercom. I recommend the 244e from DRE. They make a top of the line stereo intercom. I know PS engineering also makes good intercoms. Some problems with some portable music/CD player/MP3 players is they don't have enough output to drive the intercom properly, so I made a little stereo preamp, hidden under the panel. It uses a few milli amps when not used. The preamp is in-line with my aux jack, if I need to boost the source. Many low powered devices have to be turned way up to supply the proper source and the music become more distorted. As far as noise, Yes, you will never get the fidelity you would sitting in your media room or den with your doba-deca-super-phonic 10 thousand watt surround sound, but it is still a nice feature. If you are a talk-radio guy and the last CD you bought was in the mid 80's or all your music is on somthing that starts with 8, forget it. :-) One thing you can consider instead of a full stereo intercom, for occasional cross country flights, is stuffing ear-buds into you ears, than put the head-set over them. The music is direct from the music source to the ear buds, separate from the intercom. If the head-set has good ear seals the wires will not leak much noise. Turning your com radio up a little will override the music if needed and assure no missed radio calls, but you will have to manually turn the music down to talk. Stereo intercoms MUTE the music automatically and fade it back when done, however if flying VFR in basic G airspace, outside the airport traffic pattern, there's not much ATC to listen to. I do suggest 121.5 is a good freq to listen to on a X-C for those distress calls or when the F-16 intercepts you because you just flew thru restricted airspace due to being distracted from listening to your music mix tape, Best of the Polka. :-) George >Subject: RV-List: stereo or not? >Hi all, just wondering about the advantage if any of having a stereo input to the >audio system. Considering the ambient noise level in an RV, is stereo noticeable >and worth the added cost? > >Thanks >Greg RV8 --------------------------------- ________________________________________________________________________________
Date: Oct 10, 2005
>Hi all, just wondering about the advantage if any of having a stereo input >to the audio system. Considering the ambient noise level in an RV, is >stereo noticeable and worth the added cost? Absolutely. As Dan and George mentioned, go for quality. I use the XM Roady 2 which can be had for free to $5 at times on www.ecost.com. Definitely wire your system so that the unit can be mounted in a good place to minimize wires. Mine is not that way now and the spaghetti nest of wires is tacky. But I do have nice music. Lightspeed 20 3G headsets but I would go for the 30s next time (more db attenuation). Make sure that your intercom mutes on VHF radio operation. I would also look for an intercom that has the option to NOT mute in that case for the passenger. Ron Lee ________________________________________________________________________________
Date: Oct 10, 2005
Dan (and others), Did you have to use a separate antenna to be able to get reception or is the raw/base unit adequate? Last thing we need is more antennas and wires. Chuck Dan Checkoway wrote Oh, it is MOST definitely worth having stereo. If you are any sort of audiophile -- that is, you can actually tell the difference between mono and stereo -- then I highly recommend installing a stereo input. I've used an ipod & now an XM Roady 2 in my RV and it really kicks butt. Using the GMA-340 with its 20dB boost enabled and listening through Lightspeed headsets that I have (25XL and 20XL), the sound quality is excellent considering its in an airplane with tiny headset speakers. I personally wouldn't be happy with monaural sound. Something else to consider... I originally wired up a single 1/8" stereo jack under the panel (wired into the entertainment input in my audio panel). That worked, but I'm not a fan of wires in the cockpit -- and it's not very conducive to "expansion" of the system. When it came time to install my XM radio "permanently," I went ahead and installed a 4-circuit terminal strip. Shield, left, right, ground, wired to the audio panel. The 1/8" stereo jack hooks up at the terminal strip, as does the permanent XM installation. If I ever want to add some other audio device in the future, I just wire it to the terminal strip. No need to do surgery on my audio panel harness. I'm sure there are more elegant ways of doing this, but this works for me. Hope this helps, )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Oct 10, 2005
>Did you have to use a separate antenna to be able to get reception or is >the raw/base unit adequate? Last thing we need is more antennas and >wires. XM requires a small antenna (max 1 inch square). Then there is the power cord and the radio output cord (to intercom stereo input). That is why you need to plan for it to minimize cord issues. I have heard that the XM cigarette lighter assembly has DC-DC converter electronics so you may not be able to cut the cord and hardwire it in. I am considering a cigarette lighter stack behind the panel for the various items that need it. Most likely would be inserted down and tiewrapped for security. Ron Lee ________________________________________________________________________________
Date: Oct 10, 2005
From: "Jeffery J. Morgan" <jmorgan(at)compnetconcepts.com>
If you check online or go to a Best Buy or such store, they sell an in dash car hookup kit that has a cigarette plug connector with a wire split off for junction into the line so that you can put the adapter in the dash without having it hanging out in the open. That is what I did in my vehicle. Of course that being said, you could make such a connector very easily and probably much less then that $30 for the kit. ------- XM requires a small antenna (max 1 inch square). Then there is the power cord and the radio output cord (to intercom stereo input). That is why you need to plan for it to minimize cord issues. I have heard that the XM cigarette lighter assembly has DC-DC converter electronics so you may not be able to cut the cord and hardwire it in. I am considering a cigarette lighter stack behind the panel for the various items that need it. Most likely would be inserted down and tiewrapped for security. ________________________________________________________________________________
Date: Oct 10, 2005
> Did you have to use a separate antenna to be able to get reception or is > the raw/base unit adequate? Last thing we need is more antennas and > wires. I've been playing around with my XM antenna installation. I use the stock antenna that came with the Roady2. It works fine if you place it out in the open, but I'm still fidgeting around with antenna locations. I'm such a snob about "seeing" stuff out in the open, and I want nothing on my glareshield and I refuse to mount antennas externally. So obviously that presents a challenge... ;-) My current project is to replacing my front deck access panels, currently aluminum, with fiberglass, and mounting my XM antenna (and a few other satellite antennas for new projects) under there as well. I'm currently envying composite aircraft builders...nah, nevermind that. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Oct 10, 2005
Subject: Off Topic: Wild Blue Internet service, anyone?
I'm struggling with bad dialup & can't get dsl or cable. Has anyone had any experience with 'Wild Blue Internet' satellite service? http://www.wildblue.com/ Any other fast/affordable alternatives? (DirectPC is a bit too painful an entry fee at this point) Thanks, Charlie ________________________________________________________________________________
Subject: Solder-it-yourself Magneto Buzz Box
Date: Oct 10, 2005
RVators, If you're like me and have at least one magneto, you gotta check timing from time to time. My hangarmate has a dual mag buzz box, and I've been bumming it off him. But recently he loaned out his engine tool kit, and I've wanted to have my own buzz box. To buy one of these suckers off the shelf, the price isn't too bad, around $45-50 or so at the cheapest. But I always figured it couldn't be too complicated a circuit if you wanted to build your own. I'm no electrical engineer, but I can solder! I was turned on to this KIT to solder up your own buzz box: http://www.magnetotimer.com It's basically half the cost ($28, including shipping) of an off-the-shelf product, and you get to build it yourself. I bought one, and last night I soldered it up and gave it a try. Here are some photos: http://images.rvproject.com/images/magtimer/kit.jpg It comes 100% complete, including the molded case and everything you need. All you need is a soldering iron and solder (and a 9V battery). All of the components come taped to the diagram, pointing at exactly where they go on the board. Just solder 'em on, one by one, and then fire it up! It works great!!! http://images.rvproject.com/images/magtimer/completed.jpg It has a buzzer and two LEDs, one for each mag (assuming you have two). It has an auto-off function. It detects a short or improper hookups. The test leads stow in the case. The thing rocks! (I am not affiliated...just a happy customer.) )_( Dan RV-7 N714D (643 hours) http://www.rvproject.com ________________________________________________________________________________
Date: Oct 10, 2005
Subject: RV-6A for Sale
7.50 BARRACUDA_HEADER_FP56 RBL": "Blacklist bl.spamcop [Blocked - see" <http://www.spamcop.net/bl.shtml?206.46.252.53@roxy.matronics.com>] Our new RV-7A flew September 30! George says it flies great. When it is out of the paint shop, we'll post pictures on our website. It is with much regret, but we cannot justify two planes, that we are offering our RV-6A for sale. Details can be found at: www.fly-gbi.com/N229RV.htm Please email or call (940) 648-0841 if you are interested. Becki Orndorff GeoBeck, Inc. ________________________________________________________________________________
Date: Oct 10, 2005
Subject: RV10 Kit for sale
From: "McIntosh, Todd" <McIntoshT(at)health.missouri.edu>
1.53 RCVD_NUMERIC_HELO Received": rv-list(at)matronics.com Two RVs is one to many. I am selling my RV10 kit. Tail is finished. Haven't started on wings yet but everything has been inventoried. Contact me at mcintoshtw(at)direcway.com if interested. ________________________________________________________________________________
Date: Oct 10, 2005
Subject: Garmin 396 on EBay
Check out his link on Ebay http://cgi.ebay.com/Garmin-GPSMap-396-Garmin-GPSMap-296-brand-new_W0QQit emZ6005145584QQcategoryZ18992QQssPageNameZWDVWQQrdZ1QQcmdZViewItem I was wondering if anyone has bought these Garmin 296 and 396 GPS's on Ebay. Is this a scam? It appears that they ship direct from Europe to America for $500.00 USD for the Garmin 396 and $400.00 USD for the 296, and they both contain all the optional equipment. They want the funds transferred via Western Union only. Makes me wonder here... It appears there is more than 1 individual doing this. Here is a response I received from 2 different individuals ""HI First I want to tell you that my Garmin are brand new, unopened box all accessories included and also an international warranty. The invoice will come at the same time with the package. My price is the best you could get: 500 $, including the shipping and insurance taxes. We will pay them because the package will be delivered from Europe.I have 5 units avalaible. As delivery service we use UPS 2 days air service or overnight (with insurance and 15 days return policy), because it's the faster also free. And if you will have a quick payment, we must also have a quick delivery. So that's why we use as a payment method Western Union money transfer, the fastest and also very secure way of sending money. So, if you agree with my terms I'm sure that we can close the deal as soon as possible. Waiting your quick answer right now, THANK YOU "" Sounds a little too good to be true. Any comments... Thanks Gerald RV6A ________________________________________________________________________________
Date: Oct 10, 2005
If you go for this, I have a bridge in Brooklyn that I'd be willing to sell.... Jerry -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Gerald Richardson Subject: RV-List: Garmin 396 on EBay Check out his link on Ebay http://cgi.ebay.com/Garmin-GPSMap-396-Garmin-GPSMap-296-brand-new_W0QQit emZ6005145584QQcategoryZ18992QQssPageNameZWDVWQQrdZ1QQcmdZViewItem I was wondering if anyone has bought these Garmin 296 and 396 GPS's on Ebay. Is this a scam? It appears that they ship direct from Europe to America for $500.00 USD for the Garmin 396 and $400.00 USD for the 296, and they both contain all the optional equipment. They want the funds transferred via Western Union only. Makes me wonder here... It appears there is more than 1 individual doing this. Here is a response I received from 2 different individuals ""HI First I want to tell you that my Garmin are brand new, unopened box all accessories included and also an international warranty. The invoice will come at the same time with the package. My price is the best you could get: 500 $, including the shipping and insurance taxes. We will pay them because the package will be delivered from Europe.I have 5 units avalaible. As delivery service we use UPS 2 days air service or overnight (with insurance and 15 days return policy), because it's the faster also free. And if you will have a quick payment, we must also have a quick delivery. So that's why we use as a payment method Western Union money transfer, the fastest and also very secure way of sending money. So, if you agree with my terms I'm sure that we can close the deal as soon as possible. Waiting your quick answer right now, THANK YOU "" Sounds a little too good to be true. Any comments... Thanks Gerald RV6A ________________________________________________________________________________
Date: Oct 10, 2005
Subject: Re: Garmin 396 on EBay
It's a scam. Usually those auctions get pulled within 30 minutes or so... but they try to pull that with all of the new electronics. james #40400 Gerald Richardson wrote: > >Check out his link on Ebay >http://cgi.ebay.com/Garmin-GPSMap-396-Garmin-GPSMap-296-brand-new_W0QQit >emZ6005145584QQcategoryZ18992QQssPageNameZWDVWQQrdZ1QQcmdZViewItem > >I was wondering if anyone has bought these Garmin 296 and 396 GPS's on >Ebay. Is this a scam? >It appears that they ship direct from Europe to America for $500.00 USD >for the Garmin 396 and $400.00 USD for the 296, and they both contain >all the optional equipment. They want the funds transferred via Western >Union only. Makes me wonder here... > >It appears there is more than 1 individual doing this. > >Here is a response I received from 2 different individuals > >""HI >First I want to tell you that my Garmin are brand new, unopened box >all accessories included and also an international warranty. >The invoice will come at the same time with the package. >My price is the best you could get: 500 $, including the >shipping and insurance taxes. We will pay them because the package >will be delivered from Europe.I have 5 units avalaible. >As delivery service we use UPS 2 days air service or overnight (with >insurance and >15 days return policy), because it's the faster also free. And if you >will have >a quick payment, we must also have a quick delivery. So that's why we >use as a payment method Western Union money transfer, the fastest and >also very secure way of sending money. >So, if you agree with my terms I'm sure that we can close the deal as >soon as possible. >Waiting your quick answer right now, >THANK YOU "" > >Sounds a little too good to be true. > >Any comments... > >Thanks > >Gerald >RV6A > > > > ________________________________________________________________________________
Subject: RV flooring & adhesive
Date: Oct 10, 2005
I am just getting around to putting in some 3/4 foam padding on the floor of my 6 between the floor angles and wondered what is being used as adhesive? 3M spray? 2 sided tape? Pro seal? Dave Ford RV6 ________________________________________________________________________________
Subject: Re: RV flooring & adhesive
Date: Oct 10, 2005
> > I am just getting around to putting in some 3/4 foam padding on the > floor of my 6 between the floor angles and wondered what is being used > as adhesive? I have found that adhesive is not necessary to hold the foam in place, Keeping the carpet in place over the foam is another matter - any suggestions on how to hold the carpet and still easily remove it for inspections - greatly appreciated. Dan Krueger RV6A Flying ________________________________________________________________________________
Date: Oct 10, 2005
> I have found that adhesive is not necessary to hold the foam in place, > Keeping the carpet in place over the foam is another matter - any > suggestions on how to hold the carpet and still easily remove it for > inspections - greatly appreciated. I used 3M Super 77 spray on foam-to-floor. I used double-sided carpet tape (from the aviation aisle at Lowe's) to keep the carpet in place. The first year, the passenger side kept scooting forward, because regardless of how clearly briefed passengers were on how to get in, it seemed like they ALWAYS dug their heels in. At the first annual, I pulled up the old tape and replaced it, and I used almost 2x as much tape, particularly in the area where a bonehead would dig his heels in. The carpet hasn't budged since. )_( Dan RV-7 N714D (643 hours) http://www.rvproject.com ________________________________________________________________________________
Date: Oct 11, 2005
No need to glue the foam to the floor. Cut it to fit snug and it will stay in place. You want it easily removable for when you drop hardware while working under the panel and it rolls back and under the spar... 3M77 or even better 3M90 to glue the carpet to the floor. I used one piece of carpet over each of the two outer sections, and one narrow piece for the middle foam section, and this makes the whole thing pretty easy to remove and install. Jeff Point RV-6 Milwaukee > > ________________________________________________________________________________
Subject: BETA: Winds Aloft Interpolator
Date: Oct 11, 2005
I just finished a beta version of my new "great circle winds aloft interpolator." This will you the winds aloft at various altitudes and locations along a specified route. The goal is to help you pick an optimal altitude for a cross-country flight. I emphasize the word BETA. But please give it a shot...go to: http://www.rvproject.com/wx/ ...and click on "Winds" at the top. Enter your departure and destination airports, and click Go. Let me know if you see any funky behavior. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Oct 11, 2005
Subject: Re: BETA: Winds Aloft Interpolator
Very Cool! Thanks Dan! Smitty http://SmittysRV.com > > I just finished a beta version of my new "great circle winds aloft > interpolator." This will you the winds aloft at various altitudes and > locations along a specified route. The goal is to help you pick an > optimal > altitude for a cross-country flight. > > I emphasize the word BETA. But please give it a shot...go to: > > http://www.rvproject.com/wx/ > > ...and click on "Winds" at the top. Enter your departure and destination > airports, and click Go. > > Let me know if you see any funky behavior. > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ________________________________________________________________________________
Date: Oct 11, 2005
Excellent planning tool, Dan. Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: BETA: Winds Aloft Interpolator > > I just finished a beta version of my new "great circle winds aloft > interpolator." This will you the winds aloft at various altitudes and > locations along a specified route. The goal is to help you pick an > optimal > altitude for a cross-country flight. > > I emphasize the word BETA. But please give it a shot...go to: > > http://www.rvproject.com/wx/ > > ...and click on "Winds" at the top. Enter your departure and destination > airports, and click Go. > > Let me know if you see any funky behavior. > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > > ________________________________________________________________________________
Date: Oct 11, 2005
>I am just getting around to putting in some 3/4 foam padding on the floor >of my 6 between the floor angles and wondered what is being used as >adhesive? 3M spray? 2 sided tape? Pro seal? Like others I used normal two sided tape (2-3 strips). I also placed approximately 14" x 10 " sections of about 1/8" thick clear plastic under where peoples heels go when on the pedals. That keeps from digging in. That goes under the carpet although on top might offer some advantages. The plastic also came from Home Depot or Lowes. This is one plastic piece on each side. Ron Lee ________________________________________________________________________________
Date: Oct 11, 2005
Oh, Dan, I'm so embarrassed. I really appreciated the ride, so I didn't want to say anything about how the carpet bunched up. I thought it was just substandard construction. Oh, I'm so embarrassed, words fail me. I never knew. I just thought your long winded haranguing before the flight about getting into the plane carefully was just because you were afraid some parts might fall off or something. Oh, I'm just so embarrassed. Yours regretfully, Bone Head (Just kidding) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Checkoway Subject: Re: RV-List: RV flooring & adhesive > I have found that adhesive is not necessary to hold the foam in place, > Keeping the carpet in place over the foam is another matter - any > suggestions on how to hold the carpet and still easily remove it for > inspections - greatly appreciated. I used 3M Super 77 spray on foam-to-floor. I used double-sided carpet tape (from the aviation aisle at Lowe's) to keep the carpet in place. The first year, the passenger side kept scooting forward, because regardless of how clearly briefed passengers were on how to get in, it seemed like they ALWAYS dug their heels in. At the first annual, I pulled up the old tape and replaced it, and I used almost 2x as much tape, particularly in the area where a bonehead would dig his heels in. The carpet hasn't budged since. )_( Dan RV-7 N714D (643 hours) http://www.rvproject.com ________________________________________________________________________________
Date: Oct 11, 2005
Nice job, Dan! Does it calculate a "headwind component" even if it's actually a crosswind (which still adds length to the trip by forcing a correction angle, as we know...)? Just curious. I've bookmarked it on my favorites list. Thanks! -Stormy -----Original Message----- From: Ed Anderson <eanderson(at)carolina.rr.com> Subject: Re: RV-List: BETA: Winds Aloft Interpolator Excellent planning tool, Dan. Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: BETA: Winds Aloft Interpolator > > I just finished a beta version of my new "great circle winds aloft > interpolator." This will you the winds aloft at various altitudes and > locations along a specified route. The goal is to help you pick an > optimal > altitude for a cross-country flight. > > I emphasize the word BETA. But please give it a shot...go to: > > http://www.rvproject.com/wx/ > > ...and click on "Winds" at the top. Enter your departure and destination > airports, and click Go. > > Let me know if you see any funky behavior. > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > > ________________________________________________________________________________
From: "LML Klingmuller" <l_klingmuller(at)earthlink.net>
Date: Oct 11, 2005
Thanks Dan for the post. I just ordered one as I always borrowed a timer also.! Many, many more thanks that your translated weather site is up again!!! For all the available weather sites, YOURS IS THE VERY BEST!! For those on the RV list who are not familiar with Dan's great weather site visit : http//rvproject/com/wx Lothar, RV-6A in Denver ________________________________________________________________________________
Date: Oct 11, 2005
Subject: Re: Solder-it-yourself Magneto Buzz Box
Actually http://www.rvproject.com/wx/ works a lot better. :-) Dick Tasker LML Klingmuller wrote: > >For those on the RV list who are not familiar with Dan's great weather site visit : http//rvproject/com/wx > >Lothar, RV-6A in Denver > > > ________________________________________________________________________________
Date: Oct 11, 2005
----- Original Message ----- From: "Ron Lee" <ronlee(at)pcisys.net> Subject: RV-List: RV flooring & adhesive I haven't gotten that far yet in my project, but, how about using snaps. They work well in my boat. You can get a snap kit at any boat shop or hardware store. Paul RV 8QB > > Ron Lee > > > ________________________________________________________________________________
Date: Oct 11, 2005
Dave; My solution in a RV-6A: fitted the foam between the floor angles and then fitted a sheet of 1/8 " hardboard (aka "Masonite") between the lower longerons and on top of the foam; glued the foam to the underside of the hardboard with 3M spay adhesive; next fitted and glued some lightweight indoor/outdoor carpet to the top of the hardboard. The hardboard was cut to fits in two pieces (L&R of the stock battery box) and the carpet overlaps the hardboard joint and is secured by Velcro strips. The carpet extends a few inches up the fuselage sides and is secured by more Velcro. (Velcro purchased from the aviation department at Weal-Mart). Result is a nice firm floor and the carpet doesn't wiggle around or bunch up, the floor system is removable and the bit of carpet going up the sides means that dropped pencils, etc. don't fall down in a crack and get lost. The hardboard didn't seem to ad much weight but I suppose some lightening holes could have been cut in non-critical areas. Lightweight plywood or similar would do the same job. Jim Oke Wpg., MB RV-6A C-GKGZ > >I am just getting around to putting in some 3/4 foam padding on the floor of my 6 between the floor angles and wondered what is being used as adhesive? 3M spray? 2 sided tape? Pro seal? > >Dave Ford >RV6 > > > > ________________________________________________________________________________
Date: Oct 12, 2005
On 11 Oct 2005, at 23:14, sportav8r(at)aol.com wrote: > > This brings up an interesting question which I am too simple to > reason out for myself: at what angle does a quartering tailwind > actually begin to be more help than hindrance to a pilot? A direct > crosswind is not neutral from a groundspeed standpoint, since it > requires a crab angle to compensate for, and reduces forward speed > in the desired direction. A direct tailwind is obviously good. > Variations between cross- and tail-winds produce a vector sum of > good and bad effects, but at what angle does the net gain really > begin? My hunch is that the "magic angle" will be 45 or 60 degrees > off of a direct tailwind bearing, for reasons that have something > to do with half-forgotten trig from the 11th grade. Somehow I > don't think the answer varies with wind speed and true airspeed, > but maybe it does. What's the answer, Dan? Inquiring minds want > to know... > At typical RV and wind speeds, the wind only has to be a few degrees off of a direct crosswind before it will help your ground speed. For example, if your TAS is 160 kt, your track is 90 degrees, a wind of 20 kt from 360 degrees knocks your groundspeed down a whole knot to 159. If the wind direction changes 4 degrees to the west, to 356 degrees, your groundspeed is back up to 160. No wind forecast is good enough to discern a 4 degree change in wind direction. If the wind speed is higher, it must be more to the west before it will help our east bound flyer. A 50 kt wind from 360 degrees gives a ground speed of 152 kt. A wind from 351 degrees neither helps nor hurts the ground speed, and winds further west obviously help. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: RTV and Manual trim
Date: Oct 12, 2005
Van's instructions say to use RTV to protect the manual trim cable where it penetrates the horizontal stabilizer rib at an acute angle and the horizontal stabilizer spar where the spar reinforcements don't allow the hole to be large enough to accomodate a snap bushing. I didn't do this because I forgot during assembly and now that the system is operating, I feel the increase in stick forces needed to bend the trim cable as I operate the elevator. During operation, the trim cable moves back and forth a little bit & using RTV at those joints near the trim tab can only make the operation stiffer. So, I'm asking if anyone has experience with manual trim that was not RTV'd and what kind of cable wear occured at the spar and rib penetrations. Dave Reel - RV8A ________________________________________________________________________________
Date: Oct 12, 2005
Brilliant, Dan. The FAA should pay you for this, far superior to what they have. I use your site every time for cross country, a real benefit, and fast. Thanks so much for it. I will use the "winds" today for a short flight KUAO to KPSC, about an hour and 10... It occurred to me it might be possible for the program to take your cruise speed and calculate optimum altitude for shortest time... with adjustment for climb/descent??? Jerry Cochran Wilsonville, OR In a message dated 10/12/2005 12:02:59 A.M. Pacific Daylight Time, rv-list-digest(at)matronics.com writes: From: "Dan Checkoway" <dan(at)rvproject.com> Subject: RV-List: BETA: Winds Aloft Interpolator I just finished a beta version of my new "great circle winds aloft interpolator." This will you the winds aloft at various altitudes and locations along a specified route. The goal is to help you pick an optimal altitude for a cross-country flight. I emphasize the word BETA. But please give it a shot...go to: http://www.rvproject.com/wx/ ...and click on "Winds" at the top. Enter your departure and destination airports, and click Go. Let me know if you see any funky behavior. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Oct 12, 2005
Subject: Re:RV flooring & adhesive
VELCRO is the ticket here folks. Been using it for two years pilot side, no problema!!! Jerry Cochran Wilsonville, OR Subject: Re: RV-List: RV flooring & adhesive --> RV-List message posted by: "Paul Rice" ----- Original Message ----- From: "Ron Lee" <ronlee(at)pcisys.net> Subject: RV-List: RV flooring & adhesive I haven't gotten that far yet in my project, but, how about using snaps. They work well in my boat. You can get a snap kit at any boat shop or hardware store. ________________________________________________________________________________
Subject: Resale Values
Date: Oct 12, 2005
From: "Dan Beadle" <Dan.Beadle(at)hq.InclineSoftworks.com>
INNOCENT GLOBAL 0.0007 1.0000 -4.4816 I would like to hear from those of you who have actually sold an RV as to the resale value, headaches, etc. I am seriously looking at an RV-8. I am budgeting $75K for the project (new engine). I would like to think that I can get out after a few years of flying for close to my investment, less engine reserves, with zero for my time. My questions: - How hard is it to sell an RV or other experimental vs. a production aircraft? - How long does it typically take to sell - How well do the values hold up, neglecting the time investment? - How hard is it to sell a tail dragger vs. a tricycle gear configuration? - Should there be any concern over ongoing liability after a sale? If so, would parting out the airplane make more sense? Thanks Dan ________________________________________________________________________________
Date: Oct 12, 2005
> Thank you very much Dan!!!!! Your time and effort is really appreciated. Kirk > From: Jerry2DT(at)aol.com > Date: 2005/10/12 Wed PM 01:42:21 EDT > To: rv-list(at)matronics.com > Subject: RV-List: Re: BETA: Winds Aloft Interpolator > > > > Brilliant, Dan. The FAA should pay you for this, far superior to what they > have. I use your site every time for cross country, a real benefit, and fast. > Thanks so much for it. I will use the "winds" today for a short flight KUAO > to KPSC, about an hour and 10... It occurred to me it might be possible for > the program to take your cruise speed and calculate optimum altitude for > shortest time... with adjustment for climb/descent??? > > Jerry Cochran > Wilsonville, OR > > > In a message dated 10/12/2005 12:02:59 A.M. Pacific Daylight Time, > rv-list-digest(at)matronics.com writes: > > From: "Dan Checkoway" <dan(at)rvproject.com> > Subject: RV-List: BETA: Winds Aloft Interpolator > > > I just finished a beta version of my new "great circle winds aloft > interpolator." This will you the winds aloft at various altitudes and > locations along a specified route. The goal is to help you pick an optimal > altitude for a cross-country flight. > > I emphasize the word BETA. But please give it a shot...go to: > > http://www.rvproject.com/wx/ > > ...and click on "Winds" at the top. Enter your departure and destination > airports, and click Go. > > Let me know if you see any funky behavior. > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > > > > > > ________________________________________________________________________________
Subject: Rain (archived)
Date: Oct 12, 2005
Hi RVers, Today is a day, in my country, when, if you are a pilot, you would not normally push open the hangar door, nor for that matter, drive out to the airfield. For today we have wind and rain which beats so hard that my wipers barely keep up. But then, this was such a day when, at 17, and invincible, I completed my cross country when everyone else turned back and, upon my return, was both congratulated and vilified. What the hell did I know ? it was all new to me to see rain run uphill on the windsreen, and since I only had one day off a week and had spent whole days waiting for the white light to go off on the tower, was up to the task. No radio in those days, and no need to even crane your neck to see under the wing as to what the ident for this particular ship was. All I know was that I took off on 08 and assumed to come back the same way, especially when I saw a Hurc sitting on the button of same, but NO, I found out later, they wanted me to land on 26 after skimming at 600 over the shoreline and black overcast, but the Hurc was a better indicator to me than the windsock, which I could not find anyway. And a steady green light I took to mean..OK, land !.....I mean, it was getting blacker and windier and it wouldn't get better any time soon. Pleased to get their aircraft back, the office staff told me that one Owen Lloyd in the tower would like me to call. Call, I did, and got a reaming I shall treasure always....but I was 17....a virgin still, but a warrior of the sky just the same. Which brings me back to today. For some reason, I relish a hellish day when I can sit in an airplane with wings rocking and see if I can do more than just a circuit to see if I am still at one with the elements. Besides, I now have a metal prop and that makes a difference. Well, takeoff is a non event other than the normal thrill an RV imparts, but climbing out keeps me in practice of my dance steps as I head out East and follow my beloved river. Rain is so neat to watch steaming back in rivulets as it does with the speed that an RV pulls it. Low cloud base, but the visibilty is still surprisingly good and the rivers course and sand bars with rainy day fishermen are still where they always are. What a hoot, bending this way and that with the hills still far enough away, but the tops of them and the giant Firs in mist. Before long however, things close in somewhat and after the last bend the hills rise steeply and one enters a canyon from which decisions are best wisely and quickly made, however fun and thrilling this may be, for to fly another 5 minutes this way means very bad things be lurking and even so, to get through and land at the little grass strip where gliders live may mean that one would not get home today or tomorrow, for the sake of 5 minutes more this way. This river wends its way from countless galcial streams with clear ice water to a torrent of brown, silt laden, rushing to the sea and creating the delta upon which I live. This silt can be seen for miles out into the gulf and as I turn to follow it, I now have the outflow winds from the mountains at my back and I am racing at 209 mph on the GPS back toward the barn. An RV is a very fast pony to race with, but also makes for a short entry time in the log unless you decide to run a while longer while vis is good and traffic is nowhere. I can see a white line where waves break on the shore, and freighters from Asia leave wakes a mile long behind them, and what great fun to drop down to about 300 along the shore and marvel at how now, I can actually see the speed which altitude cannot give you....no head in the cockpit now, just a very gentle suggestion to the right with two fingers and thumb, and we drop the wing and round the corner of the point, level off, climb back where we belong, race over the green pastures and call in for landing. Straight ins are a bore, and no test of skill, so a short carrier approach with speed bled off sits me down with satisfaction once again. Sliding back the canopy and I get rain in the face and when the prop stops, the only sound is banging hangar doors where some other RV builder has decided that a rainy day at the airport is better than TV at home anytime, and therefore a visit makes for a nice way to top off the day. Even if it was way too poor to fly, I would still get a boot just to sit in the cabin and watch the rain beat and listen to the wind sing her song..... Rain was meant to flow uphill sometimes. Anonymous ________________________________________________________________________________
Subject: Re: Properly setting rivets with dimpled surfaces
Date: Oct 12, 2005
Hi everyone. A few days ago, I asked about the proper technique for setting rivets in dimpled surfaces. My original intent was to write back individually to everyone who replied, but the response and variety of suggestions I got to my questions was so overwhelming, so I thought I'd write a brief note summarizing what I've learned from others and/or discovered on my own, in case anyone else out there is just starting as I was, and has the same questions. Many of you probably already know this, but for those who don't... 1. When judging the height of the shop head on a rivet set in two dimpled surfaces, the height should be measured from the top of the dimple (where the head starts to form), not the surface of the surrounding material. This makes it a bit more tricky to use a rivet height gauge, but absolutely critical to ensure that there is enough actual head thickness. It's what I figured, but it's nice to have it confirmed. 2. If a dimple is properly formed, it should fit well into a countersink that is just slightly recessed more than enough for a rivet to sit flush inside it. Just slightly is really only about 0.005" or so, as recommended by Van's. When I was doing my first test pieces, there was no way that I could get a dimple to sit into the appropriate countersink, until I realized that I wasn't being as aggressive as I should have been on my dimples. The resulting dimples had a somewhat rounded edge where they started, and this was conflicting with a good fit against the sharp edge of the countersink. Setting the dimple much more aggressively sharpened the edges, and now they fit rather quite well. I presume that as long as the thickness of the surrounding metal isn't being deformed by the dies, it's tough to set a dimple too aggressively. If anyone knows otherwise, please let me know. 3. If two dimples don't fit perfectly into one another, there's a little trick to setting a flush rivet to let everything line up perfectly. I tried it and it works great. Into a bucking bar or something similar, machine a hole and appropriate countersink for the rivet (basically, machine a simple female dimple die into a bucking bar). Use riveting tape to tape the rivet in place. Use this machined hole over the rivet as a bucking bar and give the rivet a relatively light burst from the rivet gun. It will cause the rivet to set itself and the surrounding dimple into place. Then, rivet as normal. Some say they do this for all of their flush rivets and they all turn out great. 4. Though some advocate using a #41 drill instead of #40 when using dimpled holes to compensate for the hole stretching when dimpling, it's kind of a diminishing returns kind of thing. It doesn't make a huge difference, and can even be detrimental if the width of the "neck" of the rivet passing through the sheets is actually supposed to be enlarged to the size of a stretched #40 - for all we know, it could have been engineered that way specifically, and a smaller hole would mean a smaller neck, which would mean a weaker rivet. When in doubt, stick to Van's plans... 5. I was having trouble setting rivets with the appropriate minimum diameter and minimum shop head thickness. In a few cases, the rivets would end up smaller than required for both the diameter and thickness (so there was no way I could drive it any differently), implying that the rivet wasn't long enough to form a good head. I obtained a practice starter kit from GeoBeck, Inc (www.fly-gbi.com) that included an Orndorff video (which was very informative) and some practice materials apparently provided by Van's. In any case, my less than perfect dimples made a less than perfect fit, making the rivet a little short. And it looks like that practice kit routinely called for rivets to be at least 1/32 shorter than the RV-10 kit calls for when joining the same thicknesses of aluminum. So hopefully on the plane, I'll have a bit more material in the rivet to work with. I've started the real thing now on the vertical stabilizer and so far everything's going okay, but I haven't reached the point where I've had to actually rivet anything together yet, so I don't know for sure how much easier it will be. It does appear as though a rivet dropped in a hole has a substantially longer tail poking out that I can bash. 6. I'll also see if I can find someone local who I can hit up for advice and/or a bit of practical riveting experience with someone who's been there before. Again, thanks for everyone's help in getting me going. The advice given by the members of this list is really invaluable in helping reducing the likelihood of my making expensive (if not time consuming) mistakes. Thanks! Dan -- Syzygy Research & Technology Box 83, Legal, AB T0G 1L0 Canada Phone: 780-961-2213 ________________________________________________________________________________
Date: Oct 12, 2005
Subject: Re: Resale Values
> > >> I am seriously looking at an RV-8. I am budgeting $75K for the project >> (new engine). I would like to think that I can get out after a few >> years of flying for close to my investment, less engine reserves, with >> zero for my time. I bought an RV-4 in 2000 for $63K and sold it two years later for $65K. I think RV maintain or appreciate in value certainly better than any other experimental aircraft. I have also been involved in pricing and helping to sell several RVs in the Minneapolis area and all sold for much more than the builder had into them. Obviously RV-6s and RV-4s may have been stagnant in light of new and better models to compete against them. But I would feel my $75K investment in an RV-8 would be sound.; Doug Weiler Pres, MN Wing ________________________________________________________________________________
Date: Oct 13, 2005
Subject: Seats - Classic Aero Designs
Guys, I just received the seats for my RV-8 from Luke at Classic Aero Designs; they're top notch in appearance and workmanship. My seats were made from "Allante AL Grey" vinyl and everyone who see them swear they look just like leather. Just wanted to pass this on for your consideration. It's nice when a product exceeds your expectations Walt Shipley ________________________________________________________________________________
Subject: Re: RTV and Manual trim
Date: Oct 13, 2005
Dave, I know just what you're talking about. I did RTV mine at final assembly, but I left it alone to allow the RTV time to cure and didn't really notice that at full elevator deflection the cable moves fore and aft inside the rear spar. When I did my first condition inspection a couple of months ago, I did notice it and also noticed that because of that motion, the cable had pulled free of the RTV. That disturbed me and I carefully checked the sheath for wear but thankfully didn't detect any. This is after 100 hours. I'm sure it will eventually wear through, but how many hours that will take, I have no way of knowing. I figured that when I put the plane in the paint shop and had the elevator off I would try to come up with some way of better protecting the cable but I honestly don't know how it can be done. Even if you could manage to fit something around the sheath it's only going to restrict its movement and further add to the stick forces. A check of the archives didn't yield any better ideas. Jack Fromm RV-8 QB 81120 Flying - 110 hours <> Dave Reel - RV8A ________________________________________________________________________________
Date: Oct 13, 2005
Subject: Re: Seats - Classic Aero Designs
Cool! Got some pics? Smitty http://SmittysRV.com > > Guys, I just received the seats for my RV-8 from Luke at Classic Aero > Designs; they're > top notch in appearance and workmanship. My seats were made from "Allante > AL > Grey" vinyl and everyone who see them swear they look just like leather. > > Just wanted to pass this on for your consideration. It's nice when a > product exceeds > your expectations > > Walt Shipley > > ________________________________________________________________________________
From: "Aircraft Technical Book Company" <winterland(at)rkymtnhi.com>
Subject: Free Books
Date: Oct 13, 2005
2005 FAR/AIMs by Jeppesen Private Pilot Test Guides - 2005 Instrument Pilot Test Guides - 2005 Commercial Pilot Test Guides - 2005 A&P Airframe Test Guides - 2005 Every year when these items revise to the next edition, we have a certain number still on the shelf that we send back the covers for credit and then discard the otherwise complete book. I'm never happy doing this since the books are still perfectly good regarding its content and purpose. So, this year, while they last, we'll give them away Free to anyone who wants them along with any other regular order from Builders Bookstore or PilotsBooks. the rules: 1] Get a maximum of one of each title (five books) free with any order of any size. Don't feel guilty about getting all five books free when your order is nothing more than a sectional chart. I really just want to not have to throw them away. 2] If you place your order by phone, just tell us you which ones you want. If you place your order on the web site, write what you want in the special instructions box on the on-line order form. Don't hit "add to cart" for these or you'll get the 2006 editions and get charged for them. 3] On the 2005 FAR/AIMs, you have a choice of without covers for free, or an intact one with covers for $11. Specify which you want. The $11 intact book still qualifies you for the Test Guides for free. 4] We'll run this special till October 21st or untill they run out. Thanks, Andy 800 780-4115 Builder's Bookstore www.buildersbooks.com PilotsBooks www.PilotsBooks.com ________________________________________________________________________________
Date: Oct 13, 2005
Something you might consider. While there is not room for cable grommets, you might consider a section of tubing of some of the abrasive resistant plastics. They are much thinner than a grommet, are flexible and certainly less messy than RTV. If you have not installed the cable, you might consider getting a length of (5/8" dia or whatever dia the cable is plus 1/8" larger) plastic tubing and cut a 6 -8" long section out and slip it over the end of your cable. A plastic electric tie or even safety wire around each end should hold it to the trim cable in the area you want. Put the ties where this is no likelihood of it hanging up on a flange, etc. McMaster.com has a large selection of tubing that might be suitable with a description http://www.mcmaster.com/ Something like the PTFE & PFA Tubing looks like it might work. Ed A Rv-6A N494BW Rotary Powered Matthews, NC ----- Original Message ----- From: "Jack Fromm" <jfromm1(at)hotmail.com> Subject: RV-List: Re: RTV and Manual trim > > Dave, > > I know just what you're talking about. I did RTV mine at final assembly, > but I left it alone to allow the RTV time to cure and didn't really notice > that at full elevator deflection the cable moves fore and aft inside the > rear spar. When I did my first condition inspection a couple of months > ago, > I did notice it and also noticed that because of that motion, the cable > had > pulled free of the RTV. That disturbed me and I carefully checked the > sheath for wear but thankfully didn't detect any. This is after 100 > hours. > I'm sure it will eventually wear through, but how many hours that will > take, > I have no way of knowing. I figured that when I put the plane in the > paint > shop and had the elevator off I would try to come up with some way of > better > protecting the cable but I honestly don't know how it can be done. Even > if > you could manage to fit something around the sheath it's only going to > restrict its movement and further add to the stick forces. A check of the > archives didn't yield any better ideas. > > Jack Fromm > RV-8 QB 81120 > Flying - 110 hours > > < RTV'd and > what kind of cable wear occured at the spar and rib penetrations.>> > > Dave Reel - RV8A > > > ________________________________________________________________________________
Date: Oct 13, 2005
Well, Ron, I am at 7489-ft (0V2) and routinely fly into and out of Leadville at a few short of 10,000 with my 160-HP Lycoming in my RV6A and have no problems, and see 175TAS at 2,300 rpm and 6.1 gph...you can use whatever HP you wish, but unless its just a macho thing, I can't see that it is needed. FWIW John at Salida, CO > > One suggestion. Do not install an engine with less than 180 HP. > IMO, I would not even look at it so it has ZERO value to me. Applies > to RV-6, -7 as well > > Careful on paint job. > > Ron Lee > 00V at 6840' MSL > > > ________________________________________________________________________________
Subject: RV10A
Date: Oct 13, 2005
Just heard N256H an RV10A on the scanner in Chicago climbing to 9,500 on way to Grand Rapids. Registered to INDIGENOUS PEOPLES TECHNOLOGY & EDUCATION CTR INC built by Steve Saint Dunnellon, Florida. Dennis in Chicago ________________________________________________________________________________
Subject: Re: Poor Handling RV
Date: Oct 13, 2005
Howdy, I reported, a while back, on an RV I had the privilege of flying that I thought had unpleasant handling. It took longer than expected to install a new, longer, stick along with new grip and new wiring for elevator and aileron trim along with new relay decks. Today, I was able to fly the RV-6 with it's new configuration. To me, the airplane is pretty much transformed. Instead of needing great concentration to fly well or land acceptably it feels natural and easy to fly. This airplane is more nose heavy than mine, because of a constant speed propeller, and is heavier on the elevator, but that is an esthetic consideration, more than a safety one. I prefer the handling of my, nose lighter, RV, but enjoy flying this one thoroughly. A lister wanted to know about stick lengths, but during this conversion I found that stick lengths are pretty much irrelevant because of the variations in grips and where they put your hand in relation to the top of the stick. The grip we bought from Van's puts your hand much higher than the grip that was installed on the airplane. If one was to compare, I think distance to the top of the index finger, would be what one is interested in. On this airplane, a lot of stick trimming was necessary to clear obstructions in the cockpit; I think it would be nicer with more stick length. My advice would be to make the stick as long as possible, but that is just my opinion. See yall at LOE. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Subject: One antenna or two?
Date: Oct 14, 2005
INNOCENT GLOBAL 0.0000 1.0000 -4.4912 I have a dual comm set-up. Trying to decide whether to have 2 antennas or a splitter (and single antenna). Opinions? Bob R http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Oct 14, 2005
Subject: Re: One antenna or two?
I'm considering the same thing and already purchased the splitter..... Here's what I'm looking forward to: One antenna - less parasitic drag Here's what I'm worried about: Single antenna - single point of failure...... Not being able to have both pilot and copilot transmitting on diff radios/diff freqs at the same time. Wiring it all up - good instructions - just time consuming....... My .02 Ralph Capen RV6A N822AR N06 90% / 90% -----Original Message----- From: bob rundle <bobrundle2(at)hotmail.com> Subject: RV-List: One antenna or two? I have a dual comm set-up. Trying to decide whether to have 2 antennas or a splitter (and single antenna). Opinions? Bob R http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Oct 14, 2005
I'm planning on putting a belly whip for com1 and then an archer wingtip antenna for com2. This gives you two antennas, but with the same drag as a single whip ;) From what I hear the wingtip ones will work pretty well in most conditions, so as the second comm it should suffice pretty well. James #40400 Ralph E. Capen wrote: > >I'm considering the same thing and already purchased the splitter..... > >Here's what I'm looking forward to: > >One antenna - less parasitic drag > >Here's what I'm worried about: > >Single antenna - single point of failure...... >Not being able to have both pilot and copilot transmitting on diff radios/diff freqs at the same time. >Wiring it all up - good instructions - just time consuming....... > >My .02 >Ralph Capen >RV6A N822AR N06 90% / 90% > >-----Original Message----- >From: bob rundle <bobrundle2(at)hotmail.com> >To: aeroelectric-list(at)matronics.com, rv-list(at)matronics.com >Subject: RV-List: One antenna or two? > > >I have a dual comm set-up. Trying to decide whether to have 2 antennas or a >splitter (and single antenna). > >Opinions? > >Bob R > >http://search.msn.click-url.com/go/onm00200636ave/direct/01/ > > > > ________________________________________________________________________________
Date: Oct 14, 2005
Whatever you do, be certain you are isolating the com receive of each radio from the transmitter of the other, via switch or other physical disconnect mechanism, or you will fry the receiver of one of them. linn walters said: > > Ralph E. Capen wrote: > >> >>I'm considering the same thing and already purchased the splitter..... >> >>Here's what I'm looking forward to: >> >>One antenna - less parasitic drag ________________________________________________________________________________
Subject: free books all gone
Date: Oct 14, 2005
The free FAR/AIMs and test guide books mentioned yesterday are all gone. Thanks, Andy Builder's Bookstore www.buildersbooks.com ________________________________________________________________________________
Date: Oct 14, 2005
You're correct - I should have said switch......not splitter -----Original Message----- From: Kelly McMullen <kellym(at)aviating.com> Subject: Re: RV-List: One antenna or two? Whatever you do, be certain you are isolating the com receive of each radio from the transmitter of the other, via switch or other physical disconnect mechanism, or you will fry the receiver of one of them. linn walters said: > > Ralph E. Capen wrote: > >> >>I'm considering the same thing and already purchased the splitter..... >> >>Here's what I'm looking forward to: >> >>One antenna - less parasitic drag ________________________________________________________________________________
Date: Oct 14, 2005
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
---------------------- I have a dual comm set-up. Trying to decide whether to have 2 antennas or a splitter (and single antenna). Opinions? Bob R --------------------- I suggest asking this question on the AeroElectric List. As Kelly pointed out, there are real dangers trying to use one antenna for 2 Comm radios, which is why I don't think I've ever seen it done in more years than I want to admit of flying. The drag on an antenna isn't much, but James' approach (use one Archer Comm antenna) is better than a splitter IMHO if you really only want one stick in the breeze. Dennis Glaeser ________________________________________________________________________________
Subject: Re: AeroElectric-List: One antenna or two?
Date: Oct 14, 2005
It is my understanding that for comm radios, each one must have it's own antenna. For NAV's, splitters are very common. Wayne ----- Original Message ----- From: "bob rundle" <bobrundle2(at)hotmail.com> Subject: AeroElectric-List: One antenna or two? > --> AeroElectric-List message posted by: "bob rundle" > > > I have a dual comm set-up. Trying to decide whether to have 2 antennas or > a > splitter (and single antenna). > > Opinions? > > Bob R > > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ > > > ________________________________________________________________________________
Date: Oct 14, 2005
> Allow me to jump in here and say that as a 160 hp upgrade owner, I'd go back in a heartbeat if >I had the engine apart for anything else. And we have found that we have a hard time getting 2000 hours out of a 160 horse engine, and no problem getting 2500 and beyond from a stock 150. Although at the rate that most but Rosie put hours on the plane it's probably not much of a factor... ________________________________________________________________________________
Subject: Finished my HS!!
Date: Oct 14, 2005
Just finished my Horizontal Stabilizer on my RV-9A. (Jes' had to tell somebody) Here's a pic: http://smittysrv.com/big_photo.asp?id=10142005_03.jpg Smitty's RV-9A http://SmittysRV.com ________________________________________________________________________________
Date: Oct 14, 2005
Bob Archer (Sportcraft Antenna's) has an active COM switch that allows a single COM antenna for a dual COM's. pn SA-010 Regards, Jim Ayers In a message dated 10/14/2005 11:51:32 AM Pacific Daylight Time, recapen(at)earthlink.net writes: --> RV-List message posted by: "Ralph E. Capen" You're correct - I should have said switch......not splitter ________________________________________________________________________________
Date: Oct 15, 2005
Where can I buy one at? Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,795 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: LessDragProd(at)aol.com Subject: Re: RV-List: One antenna or two? Date: Fri, 14 Oct 2005 19:51:36 EDT Bob Archer (Sportcraft Antenna's) has an active COM switch that allows a single COM antenna for a dual COM's. pn SA-010 Regards, Jim Ayers In a message dated 10/14/2005 11:51:32 AM Pacific Daylight Time, recapen(at)earthlink.net writes: --> RV-List message posted by: "Ralph E. Capen" You're correct - I should have said switch......not splitter ________________________________________________________________________________
Date: Oct 14, 2005
Subject: Parallel Fuel Line for IO-540 (that bypasses the engine driven
fuel pump) Listers, There are some intersting fuel system design suggestions in <http://www.rv8.ch/staticpages/index.php?page 030914230507849> (or <http://www.ellison-fluid- systems.com/article/fuelsystemsforhomebuilts/fuelsystems.htm>) In particular, to minimize the chance of vapor lock, "Fuel Routing should be direct from boost pump through filter to carburetor or fuel injector servo. Have engine driven pump plumbed in parallel, not series, so that possible vapor lock in engine driven pump will be bypassed. A check valve may be necessary, depending on pump type." I'm considering using this approach on my RV-10 (IO-540). In the approach I'm considering the fuel line will "T" after the high pressure boost pump output (aft of firewall). One branch will go thru the engine driven pump. The other branch will go thru an Andair check valve then "T" with the output of the engine driven fuel pump, at which point a single line will go forward to the injection system servo/throttle. With this setup the boost pump will be able to supply fuel to the injection system even if the engine drive boost pump is blocked. Does anybody know of any significant downside to this approach? Thanks, Tim Lewis RV-6A N47TD - 790 hrs RV-10 N31TD (reserved) - under construction ________________________________________________________________________________
Date: Oct 14, 2005
Call Bob Archer. (310) 316-8796 Or email Bob at _bobsantennas(at)earthlink.com_ (mailto:bobsantennas(at)earthlink.com) Regards, Jim In a message dated 10/14/2005 5:40:53 PM Pacific Daylight Time, rv6_flyer(at)hotmail.com writes: --> RV-List message posted by: "RV6 Flyer" Where can I buy one at? Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,795 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: LessDragProd(at)aol.com Subject: Re: RV-List: One antenna or two? Date: Fri, 14 Oct 2005 19:51:36 EDT Bob Archer (Sportcraft Antenna's) has an active COM switch that allows a single COM antenna for a dual COM's. pn SA-010 Regards, Jim Ayers ________________________________________________________________________________
Date: Oct 15, 2005
Subject: Re: Finished my HS!!
Smitty, Congratulations! You're on your way. How do I know? My RV 6A just flew last week!! I have fond memories of doing the EMP. Hang in there, you're gonna love that plane. Greg in Honolulu. --- Smitty wrote: > > > Just finished my Horizontal Stabilizer on my RV-9A. > (Jes' had to tell > somebody) > > Here's a pic: > > http://smittysrv.com/big_photo.asp?id=10142005_03.jpg > > Smitty's RV-9A > http://SmittysRV.com > > > > browse > Subscriptions page, > FAQ, > > > > > > __________________________________ Access over 1 million songs. Try it free. http://music.yahoo.com/unlimited/ ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Date: Oct 15, 2005
Smitty >From: "Smitty" <smitty(at)smittysrv.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Finished my HS!! >Date: Fri, 14 Oct 2005 17:54:02 -0500 > > >Just finished my Horizontal Stabilizer on my RV-9A. (Jes' had to tell >somebody) > >Here's a pic: > >http://smittysrv.com/big_photo.asp?id=10142005_03.jpg > >Smitty's RV-9A >http://SmittysRV.com > > ________________________________________________________________________________
Date: Oct 15, 2005
Smitty Looks like A1 Quality work Frank @ SGU and SLC >From: "Smitty" <smitty(at)smittysrv.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Finished my HS!! >Date: Fri, 14 Oct 2005 17:54:02 -0500 > > >Just finished my Horizontal Stabilizer on my RV-9A. (Jes' had to tell >somebody) > >Here's a pic: > >http://smittysrv.com/big_photo.asp?id=10142005_03.jpg > >Smitty's RV-9A >http://SmittysRV.com > > ________________________________________________________________________________
Date: Oct 15, 2005
Subject: Garmin GPS 396
Has anyone actually hooked up a 396 to GTX330 transponder and gotten the traffic display to work? I have been trying without success, and receiving no useful help from Garmin. Tried two different 396's and two different 330's. All seem to give the "waiting for data" message which indicates, according to the manual, that a valid data stream has not been received. It should show "data unavailable" which means connection to the transponder established, but no TIS is available. Twice it has announced "TIS unavailable" when descending below the radar coverage altitude. No other audio messages or alerts. These tests have been done in a Mode-S TIS area. Information from anyone who has done it would be greatly appreciated. Thanks. Stan N67SL (reserved) RV7-A KCCB ________________________________________________________________________________
Date: Oct 16, 2005
Subject: Question on Lycoming crankcase spec
Folks, I am curious to know what the spec is for concentricity of the main bearing journals within a Lycoming case. Can anybody tell me what this is and if it is a requirement to confirm this when 'tagging' a 'case? My question is prompted by a broken crank story in an alternate engine. I cannot believe combustion pressures alone can induce sufficient bending to cause a crank failure after ~20 hours nitrided or not. See http://home.hiwaay.net/~langford/ for the story, sorry it is unrelated to RVs. Doug Gray ________________________________________________________________________________
Subject: Canopy Jettison
Date: Oct 16, 2005
I have just installed the C627 spring on the WD620 canopy jettison handle. Spring won't compress enough to allow release pins to clear WD716 canopy frame for jettison. Checked for proper clocking of WD619 canopy release shaft, and ears point outboard as directed. Without the spring everything works perfectly. It appears that the spring is too heavy a guage to permit the almost 3 to 1 compression required by the full stroke. Any experiences on this? RV9A finishing C-FYOO (reserve) Randy ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Subject: Re: Canopy Jettison
Date: Oct 16, 2005
Hi distance to the back of the instrument panel and the rollpin/splitpin is quite critical for smooth operation. ----- Original Message ----- From: "Randy Russell" <rer51(at)netscape.ca> Subject: RV-List: Canopy Jettison > > I have just installed the C627 spring on the WD620 canopy jettison handle. > Spring won't compress enough to allow release pins to clear WD716 canopy > frame for jettison. Checked for proper clocking of WD619 canopy release > shaft, and ears point outboard as directed. Without the spring everything > works perfectly. It appears that the spring is too heavy a guage to permit > the almost 3 to 1 compression required by the full stroke. Any > experiences on this? RV9A finishing C-FYOO (reserve) Randy > > > ________________________________________________________________________________
Date: Oct 16, 2005
Subject: Re: Resale values-horsepower
The Superior engine runs on premium UL and puts out 180+ HP out of the box. Jeff Point RV-6 Milwaukee DEAN PSIROPOULOS wrote: >If you look at the Lycoming specs you'll see that they also offered a >version of their 0-360 parallel valve engine with low compression pistons >(7.5-1). This engine runs on 80/87 octane and puts out 168 horsepower. > > > ________________________________________________________________________________
Subject: Re: Resale values-horsepower / fuel
Date: Oct 16, 2005
If you look at the Lycoming O-360 A1A that Van's sells, it runs on 91 / 96 fuel. Look on the Data Plate or Lycoming SI-1070. Since the lower octane avgas that the engine was certified on is no longer available, we use the 100LL. When a LEAD free fuel is FORCED on the aviation community, the Turbo guys are the ones that will be hurting. Check out the Type Certificate Data Sheet E00001SC for the Superior O-360. Same bore, same stroke, same compression as the Lycoming. Why was one engine able to use Motor Gasoline (R+M/2) (See Note 7) ASTM D4814, Min Octane 91 (no alcohol) and the other did not? For the best resale value on an RV, it MUST have a constant speed prop. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,798 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- >If you look at the Lycoming specs you'll see that they also offered a >version of their 0-360 parallel valve engine with low compression pistons >(7.5-1). This engine runs on 80/87 octane and puts out 168 horsepower. > ________________________________________________________________________________
Date: Oct 16, 2005
Subject: Updated pic of the old Easter Egg RV-6A
This was taken this morning at Leadville CO. Smooth flight both ways. 14,500' over and 15,500' back. RVs are great. http://www.pcisys.net/~ronlee/RV6A/Leadville16Oct05.jpg Ron Lee ________________________________________________________________________________
Date: Oct 16, 2005
Subject: Left over switches
Hi Listers, I have toggle and momentary switches left over from building my RV-6A. The toggle switches are in two sizes: miniature (1/4") and standard (7/16"). They are all new, never used, with original nuts and washers. Many are in their original packages. They were purchased from B&C and Digi-Key. I'll let the whole batch go for $35. They are: 1 - DPDT, miniature toggle, (ON)-OFF-ON, solder 4 - SPDT, miniature toggle, ON-NONE-ON, solder 1 - SPDT, miniature toggle, locking in either position, ON-NONE-ON, solder 2 - SPDT toggle (Aeroelectric 1-3), ON-NONE-ON, faston 1 - SPDT toggle(Aeroelectric 1-1), ON-OFF-ON, faston 1 - DPDT toggle,(ON)-OFF-ON, screw terminals, 1 - DPDT toggle, ON-NONE-ON , faston, 4 - SPST, momentary push, miniature, OFF (ON), solder Richard Dudley -6A flying ________________________________________________________________________________
Date: Oct 16, 2005
I don't use the spring. The handle is secured in place with a breakable wire. This also makes gettng the on an off much easier as you don't need the third hand for the handle. -- Dave Leonard Turbo Rotary RV-6 N4VY http://members.aol.com/_ht_a/rotaryroster/index.html http://members.aol.com/_ht_a/vp4skydoc/index.html ________________________________________________________________________________
Date: Oct 16, 2005
Subject: I get VOR and GS, no localizer
I am receiving a good VOR reading and glideslope, but NO localizer on my VOR head and KX-155. The radio has been bench-tested ok and I get the ILS morse code identifier, it just does not read on the VOR head. Does anyone have any idea where I start to troubleshoot??? Thanks, Kim Nicholas RV9A Auburn, Washington ________________________________________________________________________________
Date: Oct 16, 2005
Wiring from the radio to the nav head. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com Subject: RV-List: I get VOR and GS, no localizer I am receiving a good VOR reading and glideslope, but NO localizer on my VOR head and KX-155. The radio has been bench-tested ok and I get the ILS morse code identifier, it just does not read on the VOR head. Does anyone have any idea where I start to troubleshoot??? Thanks, Kim Nicholas RV9A Auburn, Washington ________________________________________________________________________________
Date: Oct 16, 2005
Subject: Re: I get VOR and GS, no localizer
It sounds like the trouble is probably in the head. If the VOR works then the VOR/LOC signal is getting to the head and the localizer should also work. The only other wire that could cause it would be the ILS energize wire which is pin 8 on the KX155, and pin K on a KI203/204 or pin 4 on a KI208/209. The best way to test it is to borrow another head or have yours bench checked. Dave B -6 So Cal Knicholas2(at)aol.com wrote: > >I am receiving a good VOR reading and glideslope, but NO localizer on my VOR >head and KX-155. The radio has been bench-tested ok and I get the ILS morse >code identifier, it just does not read on the VOR head. Does anyone have >any idea where I start to troubleshoot??? > >Thanks, > >Kim Nicholas >RV9A Auburn, Washington > > > > ________________________________________________________________________________
Subject: Propeller Decisions
Date: Oct 17, 2005
I have made the decision to use a constant speed prop on my airplane for several reasons including desired increased take-off performance at gross weight from my 'short' runway. Now which one? I want mild aerobatic capability. I would like to reduce weight because I have some extra weight items up front already. For this reason I'm leaning towards MT or Whirlwind. Questions: 1. I often see 3 bladed MT props. Why not 2 blades? Anyone have a 2 blade? Is it as smooth? 2. Does anyone remember the test Van's did with different props? Where can I find this article? 3. Hydraulic or electrically controlled. Right now I'm leaning towards hydraulic for facter pitch changes plus the fact that my dash is full. Any experiences out there would be great!!! Bob R RV7A IO-360 180 hp ________________________________________________________________________________
From: "Richard Suffoletto" <rsuffoletto(at)hotmail.com>
Subject: Rivet Squeezer and Longeron yoke for sale
Date: Oct 17, 2005
I have a US tools pneumatic squeezer and yoke for sale. Squeezer has quick change pins and adjustable ram. New price today for these items is $535.00. my price $400. Includes shipping anywhere in continental US. Pic's and details in classified page at www.sacrvators.com ________________________________________________________________________________
Subject: Any using silicone Cyinder Head Gaskets?
Date: Oct 17, 2005
I just replaced the cork cylinder head gaskets (that have always leaked a little) with a set of silicone gaskets purchased from Van's. After a brief test run-up, I found two gaskets leaking a little, so I re-tightened everything and am anxious to see how they perform. Has anyone had good or bad experiences with these silicone gaskets? When installing them, is a liquid sealant ever used in conjunction with the gasket? Any insight is much appreciated. Dean Pichon RV-4, 300 hours Bolton, MA http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Re: Any using silicone Cyinder Head Gaskets?
Dean Pichon wrote: > >I just replaced the cork cylinder head gaskets (that have always leaked a >little) with a set of silicone gaskets purchased from Van's. After a brief test run-up, I found two gaskets leaking a little, so I re-tightened everything and am anxious to see how they perform. > You will be pleased. >Has anyone had good or bad experiences with these silicone gaskets? > All good. They'll last longer than cork gaskets and are reuseable. You might take the covers without gaskets, fit them to the head and lightly hammer the 'face' of the cover flat. Over the years folks that have been trying to stop cork gaskets from leaking have deformed the covers by tightening the screws far beyond their recommended torque. I don't have my manual handy, but that figure is surprisingly low. > When installing them, is a liquid sealant ever used in conjunction with the gasket? > No. >Any insight is much appreciated. > Best I can do. Linn > >Dean Pichon >RV-4, 300 hours >Bolton, MA > >http://search.msn.click-url.com/go/onm00200636ave/direct/01/ > > > > -- ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Re: Any using silicone Valve Cover Gaskets?
What you are talking about is valve cover gaskets. Aircraft cylinders don't have head gaskets like cars, the head is screwed onto the cylinder barrel in an interference fit by heating the head and cooling the barrel. Silcone valve cover gaskets are the way to go, IMHO. Commonally available from all aviation parts places. They require MUCH less torque than cork gaskets. You want the screws just snugged enough they won't back out, not as tight as you can get them. Usually they come with instructions that give a very low in/lb torque value. If the gasket is squeezing out with any deformation it is too tight, and just as prone to leaking. Loosen all the screws and then re-tighten. It doesn't take much after you feel the screw starting to compress the gasket. > Dean Pichon wrote: > >> >>I just replaced the cork cylinder head gaskets (that have always leaked a >>little) with a set of silicone gaskets purchased from Van's. >> >>Dean Pichon >>RV-4, 300 hours >>Bolton, MA ________________________________________________________________________________
Date: Oct 17, 2005
Bob, See: http://www.romeolima.com/RV8/Prop.htm Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bob rundle Subject: RV-List: Propeller Decisions I have made the decision to use a constant speed prop on my airplane for several reasons including desired increased take-off performance at gross weight from my 'short' runway. Now which one? I want mild aerobatic capability. I would like to reduce weight because I have some extra weight items up front already. For this reason I'm leaning towards MT or Whirlwind. Questions: 1. I often see 3 bladed MT props. Why not 2 blades? Anyone have a 2 blade? Is it as smooth? 2. Does anyone remember the test Van's did with different props? Where can I find this article? 3. Hydraulic or electrically controlled. Right now I'm leaning towards hydraulic for facter pitch changes plus the fact that my dash is full. Any experiences out there would be great!!! Bob R RV7A IO-360 180 hp ________________________________________________________________________________
Date: Oct 17, 2005
On 10/17 12:38, Dean Pichon wrote: > > I just replaced the cork cylinder head gaskets (that have always leaked a > little) with a set of silicone gaskets purchased from Van's. After a brief > test run-up, I found two gaskets leaking a little, so I re-tightened > everything and am anxious to see how they perform. Be careful about over torqueing them, you can make the situation worse. Just the slightest amount of torque is needed on the screws. I don't remember the exact torque spec, but it's very light. > Has anyone had good or bad experiences with these silicone gaskets? When > installing them, is a liquid sealant ever used in conjunction with the > gasket? No sealant is supposed to be used. Carefully clean the mating surface of the cylinder with a good oil/grease remover. Clean the silicone gasket with soap and water and dry well. Both surfaces should be clean and dry. Install with no sealant. -- Walter Tondu http://www.rv7-a.com Flying! ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Fuel tank return line placement?, RV-7
I'm up to my elbows in Pro-seal (ugh.) Building the right fuel tank on my RV-7. Where is the best place to put the return line? Thanks in advance, Bill Dube' ________________________________________________________________________________
Date: Oct 17, 2005
In a message dated 10/17/05 11:41:39 AM Central Daylight Time, deanpichon(at)msn.com writes: > Has anyone had good or bad experiences with these silicone gaskets? When > installing them, is a liquid sealant ever used in conjunction with the > gasket? >>> Did the same on mine after initial fire-up and they didn't leak a bit with no sealant- I just cleaned the head and covers thoroughly and tightened the screws until they started squishing out a bit. Check for any interferences between the covers and the edges of the baffling that might be keeping the covers from pulling down and that the covers are not warped by laying them on a flat surface... Mark ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Re: Fuel tank return line placement?, RV-7
What engine/fuel injection combo are you going with? Lycoming IO-360 with standard Bendix RSA injection doesn't require/use a return line. Bill Dube said: > > I'm up to my elbows in Pro-seal (ugh.) Building the right fuel tank > on my RV-7. > > Where is the best place to put the return line? > > Thanks in advance, > > Bill Dube' > ________________________________________________________________________________
Subject: Re: [RV7Yahoo] Propeller Decisions
Date: Oct 17, 2005
Why not look at the Whirlwind RV200? This is composite prop, US made and is showing great performance. I have not flown mine yet but have talked to several who have considerable time on theirs. They are happy with the performance and customer service. This is a hydraulic prop. I am using the Jihostro governor from Van's. Darwin N. Barrie Chandler AZ ----- Original Message ----- From: "bob rundle" <bobrundle2(at)hotmail.com> Subject: [RV7Yahoo] Propeller Decisions >I have made the decision to use a constant speed prop on my airplane for > several reasons including desired increased take-off performance at gross > weight from my 'short' runway. > > Now which one? I want mild aerobatic capability. > > I would like to reduce weight because I have some extra weight items up > front already. For this reason I'm leaning towards MT or Whirlwind. > > Questions: > 1. I often see 3 bladed MT props. Why not 2 blades? Anyone have a 2 > blade? > Is it as smooth? > > 2. Does anyone remember the test Van's did with different props? Where can > I > find this article? > > 3. Hydraulic or electrically controlled. Right now I'm leaning towards > hydraulic for facter pitch changes plus the fact that my dash is full. > > Any experiences out there would be great!!! > > Bob R > RV7A > IO-360 180 hp > > _________________________________________________________________ > > > http://us.click.yahoo.com/dpRU5A/wUILAA/yQLSAA/1yWplB/TM > > > Van's Air Force - World Wide Wing > www.vansaircraft.net > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/RV7and7A/ > > <*> To unsubscribe from this group, send an email to: > RV7and7A-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > > ________________________________________________________________________________
Date: Oct 17, 2005
Bill, I put my return line near the bottom directly under the vent line, I did this on both tanks. This will leave my options open as to which tank I will return to. I guess you could put it anywhere on the rib that you want. If you want a picture, I can send you one direct. Bob Perkinson Hendersonville, TN. RV9 N658RP Reserved If nothing changes Nothing changes -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bill Dube Subject: RV-List: Fuel tank return line placement?, RV-7 I'm up to my elbows in Pro-seal (ugh.) Building the right fuel tank on my RV-7. Where is the best place to put the return line? Thanks in advance, Bill Dube' ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Subject: honda engine
Date: Oct 17, 2005
Did any of you who managed to go to OSH this year pump the Honda/Continental people for information? Honda is notorious for keeping product information close to the vest prior to release. A quick google search only produced the press release from 2 years ago with no real numbers and a small picture of the mocked up motor. I have spoken to 2 local pilots who are claiming that the engine is supposed to be in the 300 HP range at half the price of the equivalent Lycoming. The Honda people at OSH when pressed for pricing supposedly responded only that they were going to "own" the market. All of this is second or third hand airport chatter and worth only what you are paying for it, soooooo......How bout some more solid information? Anybody?.......Anybody? Evan Johnson www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ________________________________________________________________________________
Date: Oct 17, 2005
Put it in down low and plumb it through the first bay into the second bay before you dump it. If you run it along one of the tank stiffeners you can proseal it right to the stiffener with a big gob...that will hold forever. You want to dump it in the second bay so you avoid potentially putting a bunch of bubbles or froth into the bay with your pick up. Is this a Subaru conversion? Cheers... Evan Johnson www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ----- Original Message ----- From: "Bill Dube" <William.P.Dube(at)noaa.gov> Subject: RV-List: Fuel tank return line placement?, RV-7 > > I'm up to my elbows in Pro-seal (ugh.) Building the right fuel tank > on my RV-7. > > Where is the best place to put the return line? > > Thanks in advance, > > Bill Dube' > > ________________________________________________________________________________
Date: Oct 17, 2005
Originally the poster mentioned he wanted to do some aerobatics: The below is a email off of the IAC aerobatic exploder (email list) reference the whirlwind propeller. ........."I am the airshow pilot with the S1-T and you are incorrect. I had a pitch pin fail on my 200C propeller twice. First time was about 2.5 years ago, in case they didn't tell you. And the most recent was in May of this year forcing me into a cow pasture. That incident came within inches of my life. This time the pitch pin had been disintegrating for some time and did not just shear off as the first time. And yes, a service bulletin did go out the first time mine failed, but the service bulletin didn't help me much after the fact. It might only have prolonged the next failure. "....... It seems to me that if you fly aerobatics, your constant speed prop takes a real beating. I have heard from others of their prop overhauls and blade failures with less than 200 hours (this includes various manufactures, not just whirlwind). I would recommend that anyone doing aerobatics with a constant speed prop spend time reviewing the props safety record before purchasing and then doing a lot of prop inspections after buying. I personally only fly aerobatics in my RV6 and I use a fixed pitch wooden prop. I find that my prop and RV6 will beat all performance specs put out by Van's for a 180 HP engine. The down side of wood, you must retorque every 25 hours and I do not get prop braking that I would get in a constant speed, but the price difference allows me to buy 2100 gallons of gas at $4.91/gal. Also fixed pitch wood prop puts less stress on the engine during aerobatics than a heavier constant speed or metal prop. Based upon the data that I have reviewed, my RV would probably go slower if I had a constant speed prop (just my best guess). No endorsement or criticism. Bob RV6 NightFighter ________________________________________________________________________________
Subject: hot cylinder cure
Date: Oct 17, 2005
INNOCENT GLOBAL 0.0000 1.0000 -4.4912 Some cylinders run hot simply because the baffles are too tight in the wrong areas. Specifically the front face of the #2 and the rear face of the #5 cylinder (540 Lycs) or #3 (4 cylinder Lycs) don't get enough airflow past the baffles. It's easy to fix with a few washers. This has been discussed before... but now there's a photo and some text to make it easier to understand. http://vincesrocket.com/Engine%20and%20Prop.htm Vince ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Re: honda engine
Maybe I missed it but I didn't see any sign of the Honda piston engine this year? And I looked for it! Good Luck, Bob Christensen RV-8 Builder - SE Iowa On 10/17/05, Evan and Megan Johnson wrote: > > evmeg(at)snowcrest.net> > > Did any of you who managed to go to OSH this year pump the > Honda/Continental people for information? Honda is notorious for keeping > product information close to the vest prior to release. A quick google > search only produced the press release from 2 years ago with no real numbers > and a small picture of the mocked up motor. I have spoken to 2 local pilots > who are claiming that the engine is supposed to be in the 300 HP range at > half the price of the equivalent Lycoming. The Honda people at OSH when > pressed for pricing supposedly responded only that they were going to "own" > the market. All of this is second or third hand airport chatter and worth > only what you are paying for it, soooooo......How bout some more solid > information? Anybody?.......Anybody? > > Evan Johnson > www.evansaviationproducts.com <http://www.evansaviationproducts.com> > (530)247-0375 > (530)351-1776 cell > > ________________________________________________________________________________
Date: Oct 17, 2005
I put mine right in the center of the forward "lightening hole" that isn't cut out. I ran it in for 3 ribs. I'm in the middle of my second (left) tank. Dennis Glaeser 7A I'm up to my elbows in Pro-seal (ugh.) Building the right fuel tank on my RV-7. Where is the best place to put the return line? Thanks in advance, Bill Dube' ________________________________________________________________________________
Date: Oct 17, 2005
Bill, I put mine high on the 1st rib so that if there is a leak (or fracture) in the line it cannot drain the tank. I used an AN-6 bulkhead fitting. Once inside the tank a small piece of AN-6 alum tube bends down to just above the lower skin, this helps minimize frothing. There is a small hole drilled near the top of the tube to prevent siphoning. Running to the second rib is a reasonable option as well, but is extra work and weight, and of little value IMHO. -- Dave Leonard Turbo Rotary RV-6 N4VY http://members.aol.com/_ht_a/rotaryroster/index.html http://members.aol.com/_ht_a/vp4skydoc/index.html > > > I'm up to my elbows in Pro-seal (ugh.) Building the right fuel tank > on my RV-7. > > Where is the best place to put the return line? > > Thanks in advance, > > Bill Dube' > > ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Re: Mazda RX-8 engine (was: Fuel tank return line placement?,
RV-7) Evan and Megan Johnson wrote: > >Put it in down low and plumb it through the first bay into the second bay >before you dump it. If you run it along one of the tank stiffeners you can >proseal it right to the stiffener with a big gob...that will hold forever. >You want to dump it in the second bay so you avoid potentially putting a >bunch of bubbles or froth into the bay with your pick up. > Sounds like the perfect way to do it. Is there any structure on the fuse at the wing root that I should avoid hitting? > Is this a Subaru >conversion? > > Actually an 2005 RX-8 Mazda Rotary. Puts out 248 HP stock, normally aspirated. Firewall forward weighs less than a Lyc 360 (including the cooling system.) Costs about a third as much. Quite a bit of custom work, however. Lots of components available, but no turn-key package. You have to build your own intake manifold and exhaust manifold, for example. Fortunately, all the hard stuff like the injection electronics, PSRU, and engine mount are off-the-shelf products. The engine itself is probably more robust than a Lyc. Very few moving parts. You can swallow a chunk of metal and they continue to run. You can also run them out of water and they continue to run (for awhile.) No problem running lean of peak. No one that I know of has had a dead stick from internal engine problems. Tracy Crook has over 1450 hours on his rotary-powered RV-4. <http://www.rotaryaviation.com/> The main reliability issues are the custom stuff you can't buy and have to do yourself. Bad design on the fuel system has caused a few silent flights. Bad wiring layout has also caused some problems. Getting the cooling right can be tricky too. I suppose these same sort of things have caused grief in certified engine aircraft as well. Bill Dube' ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Switches
Hi Listers, Thanks to everyone who responded with interest in my extra switches. They are sold to the person who was first to respond. Regards and good luck building, Richard Dudley ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Headsets
Hi Listers, I have two vintage aviation headsets in good and working condition and a Push-To-Talk Switch that someone might have a use for. They are: - Telex Model A610, TSO C57, Cat B headset. - Pacific Plantronics Model MS50/T30-3, TSO C57 & C58 earset - Telex PT-200 Push-To-Talk Switch You can find the Plantronics set on page 103 in the one of the latest Sportys catalogs. If you call for price Sporty's quotes $169. This is used but in good condition. Neither headset has ANR. Both have been tested in my aircraft. The PTT switch is for aircraft without internal PTT and the connectors are compatible with standard microphone plugs and jacks. It is like the one on page 107 of Sportys. you could take all for $60. Regards, Richard Dudley RV-6A flying ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: Teak Stick Grip switch dust covers
Date: Oct 17, 2005
List, I bought a set of teak stick grips and need to find a source for the rubber dust covers that go over the switch. Called Aircraft Spruce to try and buy a couple spares but no luck. Anyone know the manufacture? Any leads on a source would be greatly appreciated. Tom in Ohio ________________________________________________________________________________
Date: Oct 17, 2005
Any sealant under the gasket acts to lubricate the new gasket and allow it to slide out from under the valve cover. I have had good luck with the spray gasket adhesive, its sorta like contact cement. If used on the valve cover side of the gasket to glue it in place it makes disassembly easier later, and holds the gasket from sliding around. .02 Steve d n221rv I just replaced the cork cylinder head gaskets (that have always leaked a little) with a set of silicone gaskets purchased from Van's. After a brief test run-up, I found two gaskets leaking a little, so I re-tightened everything and am anxious to see how they perform. Has anyone had good or bad experiences with these silicone gaskets? When installing them, is a liquid sealant ever used in conjunction with the gasket? Any insight is much appreciated. Dean Pichon RV-4, 300 hours Bolton, MA http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Oct 17, 2005
Subject: Re: Teak Stick Grip switch dust covers
In a message dated 10/17/2005 6:24:29 P.M. Pacific Daylight Time, dan(at)rvproject.com writes: Very early on, my pant leg caught on my PTT switch and tore the dust cover off. I just left it like that. I actually like the more affirmative feel of the switch better without the dust cover. ==================================== I agree that the switch action is better without those bogus dust covers. I would just cut the damn things off and use just the dress nut. GV (RV-6A N1GV O-360-A1A, C/S, Flying 767hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Oct 17, 2005
From: Dave Lammers <lammers.david(at)mcleodusa.net>
Dean, You need to bring the torque up gradually and uniformly as you tighten any head gasket. Start by "hand tightening" all so that the surface is planar and parallel with the gasket but just touching. Now establish a tightening pattern. Start with one screw and torque to about 25%, then torque the opposite one the same, then pick another as far removed from the line between the first two and torque it 25% then the one across from it and so on. Then start all over torqueing to 50%, then 75% etc. The reason they leak is that the mounting surface on the head cover gets warped from mis-torqueing and can never seal uniformly around the seal. You can check for this by laying them on an absolutely flat plate and see if the gasket surface is uniformly on the surface or is there a bow. If they are bowed, go get some new ones and always carefully torque them as described. Never never overtorque. That's how the covers get warped. I've used silicone on my -6 and Pitts before that and they work great. Regards, Dave Lammers RV-6 N6X 650 hrs RV-10 under construction Dean Pichon wrote: > > >I just replaced the cork cylinder head gaskets (that have always leaked a >little) with a set of silicone gaskets purchased from Van's. After a brief >test run-up, I found two gaskets leaking a little, so I re-tightened >everything and am anxious to see how they perform. > >Has anyone had good or bad experiences with these silicone gaskets? When >installing them, is a liquid sealant ever used in conjunction with the >gasket? > >Any insight is much appreciated. > >Dean Pichon >RV-4, 300 hours >Bolton, MA > >http://search.msn.click-url.com/go/onm00200636ave/direct/01/ > > > > ________________________________________________________________________________
From: "czechsix(at)juno.com" <czechsix(at)juno.com>
Date: Oct 18, 2005
Subject: Usable fuel RV-7/8
Guys, Can anybody tell me what their measured usable fuel quantity is in an RV-7/8 series? I know Vans numbers say 42 gal total and I imagine most of that is usable. I want to placard my panel now if there's a reasonable consensus and will risk having to change it later if my own measurements are different. I can't imagine it varies much on these prepunched kits.... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D getting close....(definition of "close" is that I may be flying "soon", which is anytime between a couple months from now and a couple years from now...depending on what else life conspires to bring my way in an effort to prolong 1st flight indefinitely...) Guys, Can anybody tell me what their measured usable fuel quantity is in an RV-7/8 series? I know Vans numbers say 42 gal total and I imagine most of that is usable. I want to placard my panel now if there's a reasonable consensus and will risk having to change it later if my own measurements are different. I can't imagine it varies much on these prepunched kits.... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D getting close....(definition of "close" is that I may be flying "soon", which is anytime between a couple months from now and a couple years from now...depending on what else life conspires to bring my way in an effort to prolong 1st flight indefinitely...) ________________________________________________________________________________
Subject: Re: Usable fuel RV-7/8
Date: Oct 18, 2005
On my RV-7 with flop tubes in both tanks, I ran a couple of different tests... Test 1: On the GROUND, I pumped both tanks dry using the boost pump... LEFT: 175ml (0.05 gal) unusable RIGHT: 160ml (0.04 gal) unusable http://rvproject.com/images/2004/20040307_unusable_fuel_right.jpg Test 2: Later, in FLIGHT, I ran both tanks dry in flight (on separate occasions, thank you). I found there was less than 0.3 gallons unusable in each tank. Note: when doing this test, as soon as fuel pressure dumped and the engine sputtered, I switched tanks. I may have been able to burn slightly more fuel if I had allowed the engine to sputter longer. But for all intents and purposes, there were 0.3 gallons left in the tank at the point where any sane pilot would switch tanks. My tanks are dead nuts on 42.0 gallons total capacity. So in flight, I have 41.4 gallons usable and 0.6 gallons unusable. From what I've heard, you can potentially have more usable fuel with standard pickups instead of flop tubes. YMMV. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: <czechsix(at)juno.com> Subject: RV-List: Usable fuel RV-7/8 > > Guys, > Can anybody tell me what their measured usable fuel quantity is in an > RV-7/8 series? I know Vans numbers say 42 gal total and I imagine most of > that is usable. I want to placard my panel now if there's a reasonable > consensus and will risk having to change it later if my own measurements > are different. I can't imagine it varies much on these prepunched > kits.... > Thanks, > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D getting close....(definition of "close" is that I may be flying > "soon", which is anytime between a couple months from now and a couple > years from now...depending on what else life conspires to bring my way in > an effort to prolong 1st flight indefinitely...) > > > Guys, > > > Can anybody tell me what their measured usable fuel quantity is in an > RV-7/8 series? I know Vans numbers say 42 gal total and I imagine most of > that is usable. I want to placard my panel now if there's a reasonable > consensus and will risk having to change it later if my own measurements > are different. I can't imagine it varies much on these prepunched kits.... > > > Thanks, > > > --Mark Navratil > > > Cedar Rapids, Iowa > > > RV-8A N2D getting close....(definition of "close" is that I may be flying > "soon", which is anytime between a couple months from now and a couple > years from now...depending on what else life conspires to bring my way in > an effort to prolong 1st flight indefinitely...) > > > ________________________________________________________________________________
Date: Oct 18, 2005
Subject: camera in the tail
Hi Lucky What about a camera on the wing? I am currently testing a wing-mount for my Videocamera. I made it from fiberglass and ACRYL-FOAM. It just gets taped to the wing and you can take it off in a minute. http://www.rv-4.de/gallerie/Detail1_img/KHF.jpg A Testvideo ist here: http://www.rv-4.de/videos.htm Happy Landings Thomas, RV-4 -- Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko! Satte Provisionen fr GMX Partner: http://www.gmx.net/de/go/partner ________________________________________________________________________________
Date: Oct 18, 2005
Wasn't the Honda aircraft engine sitting on a shelf over there in a corner next to the TCM-GAP engine? You know, where they keep the invisible aircraft engines that people make once in a while and talk about excitedly before putting them on that shelf in the corner ... :-) Vern On 10/17/05, Bob C. wrote: > > > Maybe I missed it but I didn't see any sign of the Honda piston engine > this > year? And I looked for it! > Good Luck, > Bob Christensen > RV-8 Builder - SE Iowa > > On 10/17/05, Evan and Megan Johnson wrote: > > > > evmeg(at)snowcrest.net> > > > > Did any of you who managed to go to OSH this year pump the > > Honda/Continental people for information? Honda is notorious for keeping > > product information close to the vest prior to release. A quick google > > search only produced the press release from 2 years ago with no real > numbers > > and a small picture of the mocked up motor. I have spoken to 2 local > pilots > > who are claiming that the engine is supposed to be in the 300 HP range > at > > half the price of the equivalent Lycoming. The Honda people at OSH when > > pressed for pricing supposedly responded only that they were going to > "own" > > the market. All of this is second or third hand airport chatter and > worth > > only what you are paying for it, soooooo......How bout some more solid > > information? Anybody?.......Anybody? > > > > Evan Johnson > > www.evansaviationproducts.com <http://www.evansaviationproducts.com> < > http://www.evansaviationproducts.com> > > (530)247-0375 > > (530)351-1776 cell > > > > > > ________________________________________________________________________________
Date: Oct 18, 2005
Mark, I recenlty did this exercise to re-verify the usealbe fuel in my -8. You're right. It's almost all useable. So much so, if you're concerned about it, you're cutting it way too close!. First of all my tanks hold what Van's says they do. 21 gallons side a +/- few ounces when filled to the brim. Unusable fuel is: Left tank - 6oz, right tank 2oz. My left tank has a flop tube. Your actual results may vary depending on the installation of the pickup tubes. Just make sure they go all the way to the bottom inside corner of the tank.. Verifed all this by leveling the aircraft in flight attitude and then pumpming each tank dry with the electric pump. Start with just a few gallons in each side so it doesn't take forever. I disconnected the fuel line at the fuel servo and let go into a bucket. Then I drained and measured what was left out of each tank fuel drain into a cup. Followed by filling each tank to re-verify total capacity. -Don Don Kugler don(at)earthlink.net RV8 - NJ ________________________________________________________________________________
Date: Oct 18, 2005
Outstanding videos Thomas!! I used Google to translate the descriptions: http://tinyurl.com/c9nlx - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Thomas Lukasczyk [mailto:Lukasczyk(at)gmx.net] > Sent: Tuesday, October 18, 2005 6:01 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: camera in the tail > > > Hi Lucky > > What about a camera on the wing? I am currently testing a > wing-mount for my Videocamera. I made it from fiberglass and > ACRYL-FOAM. It just gets taped to the wing and you can take > it off in a minute. > > http://www.rv-4.de/gallerie/Detail1_img/KHF.jpg > > A Testvideo ist here: > > http://www.rv-4.de/videos.htm > > Happy Landings > > Thomas, RV-4 > > > -- > Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko! > Satte Provisionen fr GMX Partner: http://www.gmx.net/de/go/partner > > > > > > > > ________________________________________________________________________________
Date: Oct 18, 2005
version=3.0.3 Lately, (actually, after the AirVenture Cup race) I have been wondering if it would be the same at 100 mph as at 200. When I tested mine, at cruise speed, I got the same results as Dan and Don, but I wonder about the attitude change in the pattern. Haven't tested it yet. John Don Kugler wrote: > >Mark, > >I recenlty did this exercise to re-verify the usealbe fuel in my -8. >You're right. It's almost all useable. So much so, if you're concerned >about it, you're cutting it way too close!. > >First of all my tanks hold what Van's says they do. 21 gallons side a >+/- few ounces when filled to the brim. Unusable fuel is: Left tank - >6oz, right tank 2oz. My left tank has a flop tube. Your actual results >may vary depending on the installation of the pickup tubes. Just make >sure they go all the way to the bottom inside corner of the tank.. > >Verifed all this by leveling the aircraft in flight attitude and then >pumpming each tank dry with the electric pump. Start with just a few >gallons in each side so it doesn't take forever. I disconnected the >fuel line at the fuel servo and let go into a bucket. Then I drained >and measured what was left out of each tank fuel drain into a cup. >Followed by filling each tank to re-verify total capacity. > > -Don > >Don Kugler >don(at)earthlink.net >RV8 - NJ > > > > ________________________________________________________________________________
Date: Oct 18, 2005
In all the talk about unusable fuel, people seem to be measuring unusable fuel as what will not be used in level flight. Unless my memory is failing me unusable fuel would be what is unusable in normal flight attitudes. More is likely to be unusable in nose up or nose down attitudes. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Date: Oct 18, 2005
Subject: Re: Usable fuel RV-7/8 version=3.0.3
>When I tested mine, at >cruise speed, I got the same results as Dan and Don, but I wonder about >the attitude change in the pattern. Haven't tested it yet. I have tested in the pattern and I find that a prolonged steep decent with less than five gallons will cause fuel starvation on the tank without the flop tube. The tank with the flop tube is not as bad. Also it gets worse if you do a forward slip. While in the traffic pattern, I always select the high wing tank (right tank in left hand traffic), when I am below a half tank of fuel. Or the high wing tank in a forward slip. Note: I have been able to get fuel starvation with up to 8 gallons in a tank. Bob RV6 NightFighter ________________________________________________________________________________
Subject: Match-drill/dimple thru the blue film?
Date: Oct 18, 2005
I'm dimpling my first skin (VS), and I'm getting small scratches from the male die as I move the piece from hole to hole. Additionally, the dies are leaving a ring around the hole the diameter of the die. Since I'm planning on a bare metal airplane, I'm very concerned about the surface finish. I've experimented with drilling and dimpling thru the blue vinyl film on a scrap piece. This solved the scratching problem, and my untrained eye can see no difference in the dimple. Does anyone know of any cons to this method? Thanks for any help! Jim L. Cox RV-8A emp ________________________________________________________________________________
Subject: FAA renewal of Medical
Date: Oct 18, 2005
My guess is that because of your age and the fact that you take Lipitor for high lipid levels, the FAA is looking for underlying heart disease. Look at the AOPA website and you'll see that for heart trouble you have to take a stress test and pass the Bruce level 3 (9 minutes) without showing signs of ischemia. What are your lipid level numbers? Another reason to have your physician take you off all meds 90 days before your medical. Now you've got some smart-ass on Oklahoma City sniffing around trying to prove you're to old to fly. Damn Feds! Bruce www.glasair.org ________________________________________________________________________________
Date: Oct 18, 2005
Mark, On my RV-8A in Hawaii with standard pickup tubes we had a grand total of 1 pint unusable which works out to a total of 41.75 gallons total usable fuel. For safety sake we declared .5 gallons unusable on each side although the point is mute now. (I'm sure the fish like it though) Mike Robertson >From: "czechsix(at)juno.com" <czechsix(at)juno.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Usable fuel RV-7/8 >Date: Tue, 18 Oct 2005 05:46:54 GMT > > >Guys, >Can anybody tell me what their measured usable fuel quantity is in an >RV-7/8 series? I know Vans numbers say 42 gal total and I imagine most of >that is usable. I want to placard my panel now if there's a reasonable >consensus and will risk having to change it later if my own measurements >are different. I can't imagine it varies much on these prepunched kits.... >Thanks, >--Mark Navratil >Cedar Rapids, Iowa >RV-8A N2D getting close....(definition of "close" is that I may be flying >"soon", which is anytime between a couple months from now and a couple >years from now...depending on what else life conspires to bring my way in >an effort to prolong 1st flight indefinitely...) > > >Guys, > > >Can anybody tell me what their measured usable fuel quantity is in an >RV-7/8 series? I know Vans numbers say 42 gal total and I imagine most of >that is usable. I want to placard my panel now if there's a reasonable >consensus and will risk having to change it later if my own measurements >are different. I can't imagine it varies much on these prepunched kits.... > > >Thanks, > > >--Mark Navratil > > >Cedar Rapids, Iowa > > >RV-8A N2D getting close....(definition of "close" is that I may be flying >"soon", which is anytime between a couple months from now and a couple >years from now...depending on what else life conspires to bring my way in >an effort to prolong 1st flight indefinitely...) > > ________________________________________________________________________________
Date: Oct 18, 2005
I think I found a website that lets you figure out from the spec sheet what the FOV is and it also let's you see the effect of different FOV from the same spot. Go to the web site below and click on the link to "Compare FOV" http://viosport.com/store/customer/ourgear.php?page=ac3_overview It looks like the 88 degree or 2.9mm lense is the one I'm probably wanting. lucky -------------- Original message -------------- > > Hi Lucky > > What about a camera on the wing? I am currently testing a wing-mount for my > Videocamera. I made it from fiberglass and ACRYL-FOAM. It just gets taped to > the wing and you can take it off in a minute. > > http://www.rv-4.de/gallerie/Detail1_img/KHF.jpg > > A Testvideo ist here: > > http://www.rv-4.de/videos.htm > > Happy Landings > > Thomas, RV-4 > > > -- > Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko! > Satte Provisionen fr GMX Partner: http://www.gmx.net/de/go/partner > > > > > > I think I found a website that lets you figure out from the spec sheet what the FOV is and it also let's you see the effect of different FOV from the same spot. Go to the web site below and click on the link to "Compare FOV" http://viosport.com/store/customer/ourgear.php?page=ac3_overview It looks like the 88 degree or 2.9mm lense is the one I'm probably wanting. lucky -------------- Original message -------------- -- RV-List message posted by: "Thomas Lukasczyk" Hi Lucky What about a camera on the wing? I am currently testing a wing-mount for my Videocamera. I made it from fiberglass and ACRYL-FOAM. It just gets taped to the wing and you can take it off in a minute. http://www.rv-4.de/gallerie/Detail1_img/KHF.jpg A Testvideo ist here: http://www.rv-4.de/videos.htm Happy Landings Thomas, RV-4 -- Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko! Satte Provisionen fr GMX Partner: http://www.gmx.net/de/go/partner he RV-List Email Forum - ________________________________________________________________________________
Date: Oct 18, 2005
To all that care As my dear old dad used to say, It's time for a revolution and we will take no prisoners. The FAA like most gov. agencies is wayyyyyyyyyyyyyyy out of control. The 3RD class med should be the same as the LSA .....Drivers Lic and you are good to go. If the whole general aviation community rose up in arms I know we could correct this situation. When I get my 7A done I am going to take up the cause. I know, fight the GOV. GOOD LUCK you say. If we don't do something we will all be in the same boat as Bert Frank @ SGU and SLC >From: "Bruce Gray" <Bruce(at)glasair.org> >Reply-To: rv-list(at)matronics.com >To: >Subject: RE: RV-List: FAA renewal of Medical >Date: Tue, 18 Oct 2005 18:21:44 -0400 > > >My guess is that because of your age and the fact that you take Lipitor for >high lipid levels, the FAA is looking for underlying heart disease. > >Look at the AOPA website and you'll see that for heart trouble you have to >take a stress test and pass the Bruce level 3 (9 minutes) without showing >signs of ischemia. > >What are your lipid level numbers? > >Another reason to have your physician take you off all meds 90 days before >your medical. Now you've got some smart-ass on Oklahoma City sniffing >around >trying to prove you're to old to fly. Damn Feds! > >Bruce >www.glasair.org > > ________________________________________________________________________________
Date: Oct 18, 2005
On 18 Oct 2005, at 13:35, Bob wrote: > > >> When I tested mine, at >> cruise speed, I got the same results as Dan and Don, but I wonder >> about >> the attitude change in the pattern. Haven't tested it yet. >> > > I have tested in the pattern and I find that a prolonged steep > decent with > less than five gallons will cause fuel starvation on the tank > without the > flop tube. The tank with the flop tube is not as bad. Also it > gets worse > if you do a forward slip. > > While in the traffic pattern, I always select the high wing tank > (right > tank in left hand traffic), when I am below a half tank of fuel. > Or the > high wing tank in a forward slip. > > Note: I have been able to get fuel starvation with up to 8 gallons > in a tank. > Very interesting. In the FAR 23, type certificated world, this would lead to a declared unusable fuel of 8 gallons per tank. I'm assuming that there is nothing strange about your fuel pickups, so other RVs may have the same "issue". The critical parameter isn't pitch attitude - it is longitudinal acceleration. In this case it is deceleration, or negative acceleration that pushes the fuel toward the leading edge. Picture a tricycle-geared RV doing hard braking on the ground - the pitch attitude isn't very nose down, but the deceleration will push the fuel towards the leading edge. The worst case in flight will be with full flap, idle power and the max allowable speed for full flap. It would be very wise for every RVer to do such a test with his aircraft. This is the sort of thing you want to discover when you are ready for it (i.e. within easy gliding distance of a long runway), rather than have it catch you by surprise at a bad moment. If you know your RV is potentially at risk from fuel starvation in some conditions, you could adjust your approach and landing procedures to avoid high longitudinal decelation when your fuel is less than X gallons. You would do this by avoiding full flap and powers less YYYY rpm until you were within easy gliding distance of the runway. The value of YYYY would be determined via flight test, and would be specific to the aircraft, as it is prop and fuel tank dependent. I'm adding this to my list of tests to perform after I get flying. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Oct 18, 2005
Subject: Re:FAA renewal of Medical
Frank is absolutely right !! I had a little problem , walked right through the stress test and was denied. DAMN !! I sent in my paperwork 3 weeks before the new LSA rule was approved,and they had sneaked in that "Medical Denied" clause. Now I have an RV-4 sitting in the hangar with 61 hours on it . I sent letters from my cardiologist and internal medicine specialist - both said I was not likely to be incapicated any more than anyone else. Try an email to a doctor who is good with such cases,in Tulsa,OK. _GBaldwindo(at)cs.com_ (mailto:GBaldwindo(at)cs.com) Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Subject: Interesting article on increasing oil pressures
Date: Oct 19, 2005
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Sent to me By Jimmy Baker. Chief planner of flights & co-instigator of the infamous flight of 15 to the Turks & Caicos. Thanks Jimmy. Im cranking up my oil pressure. http://egaa.home.mindspring.com/new.htm Key word archive search: oil pressure increase higher use of oil to augment exhaust valve and guide cooling Cessna red line 115 125 Robinson Bill Marvel and Bill Scott Mike ________________________________________________________________________________
Date: Oct 19, 2005
Subject: Wilma
We've got house/hanger space if anyone needs to get out of Florida. Our # is 601 879 9596. Charlie England ________________________________________________________________________________
Subject: Another RV-8 Empennage for sale, Complete!
Date: Oct 19, 2005
RV-8 Empennage for sale. Built complete. Bought another partially finished wing kit with finished Empennage. No need for two tails! $1000 + shipping. Eric Parlow Asheville, NC (828) 777-7976 ________________________________________________________________________________
Date: Oct 19, 2005
Be sure to check out Virtual Flight Surgeon (www.aviationmedicine.com ?) as well as EAA's Aeromedical Advocacy service. Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: Texas Formation Clinic
Date: Oct 19, 2005
1.53 RCVD_NUMERIC_HELO Received: contains an IP address used for HELO Gainesville TX Formation Clinic You may remember we had a formation clinic scheduled at Abilene in late September, but we canceled it with Hurricane Rita moving in. We are now considering scheduling another formation clinic the weekend before Thanksgiving, 18-20 Nov, in Texas, if there is enough interest. We have chosen Gainesville TX (GLE), 45 Northwest of Dallas as the host site. It has everything we need for a successful clinic. We find about 1/3 low, 1/3 medium, 1/3 high experienced formation pilots is a good mix for a good formation clinic. If you would plan on attending the clinic, given good weather, please email me at sturdy-at-att-dot-net by 25 Oct. Include Name, City/State, Aircraft, Tail#, Formation experience level, email address, telephone#. If there is enough interest, we will schedule it and further advertise the clinic. Stu McCurdy (Falcon) Gainesville TX Formation Clinic You may remember we had a formation clinic scheduled at Abilene in late September, but we canceled it with Hurricane Rita moving in. We are now considering scheduling another formation clinic the weekend before Thanksgiving, 18-20 Nov, in Texas, if there is enough interest. We have chosen Gainesville TX (GLE), 45 Northwest of Dallas as the host site. It has everything we need for a successful clinic. We find about 1/3 low, 1/3 medium, 1/3 high experienced formation pilots is a good mix for a good formation clinic. If you would plan on attending the clinic, given good weather, please email me at sturdy-at-att-dot-net by 25 Oct. Include Name, City/State, Aircraft, Tail#, Formation experience level, email address, telephone#. If there is enough interest, we will schedule it and further advertise the clinic. Stu McCurdy (Falcon) ________________________________________________________________________________
Subject: IO-360 B1B firewall forward kit
Date: Oct 19, 2005
Greeetings. I am working on my 7A, and recently ordered a IO-360 B1B from AeroSport Power. I now want to order the firewall forward kit from Vans, but discovered there is nothing specifically tailored for that engine. The tech guy at Vans recommended ordering the O-360 FWF kit, with a few changes, which were just off the top of his head: (1) Substitute the VA-182 for the VA-149 bracket (for carrying the throttle and mixture cables I think) (2) Delete the gascolator (3) Add the FIA(?) pump and filter (fuel injector pump I presume); and (4) Get a 47-inch mixture cable instead of the 45-inch. I know there are plenty of IO-360s ou there. Does this list sound accurate and complete? thanks for any input. Erich Weaver ________________________________________________________________________________
Date: Oct 19, 2005
Some of it depends on the fuel injection system you are getting with the engine from Bart. If you are getting the Airflow Performance system, mine came with the flat aluminum plate that connects the bottom of the fuel control box with the filtered air box, so you won't need that from Van's. On the other hand, neither that one or the one from Van's would work on my 8A because the Airflow Performance fuel control box is not centered on the engine and the filtered air box would not fit down into the air scoop, so that flat plate had to be custom built anyway. I ended up moving the hole 3/8" to one side to make it fit. Hopefully Van's has resolved that problem, but I would be surprised if they have. It's another of those "No one else has any problem with it" problems. The bracket that holds the engine-end of the throttle and mixture cables will probably have to be severely modified to fit around the nose gear too, but again, you will probably have to do that yourself. It's not too difficult, but it really helps to see someone else's 7A installation. I also had to move the prop control cable hole in the firewall to make it fit, but the longer cable probably solves that problem. You will be very pleased with how complete Bart is with the engine and the accessories. Mine came with the Airflow Performance purge valve and the prop control line (tubing) and the oil pressure restrictor fitting all installed, along with the Light Speed Engineering Plasma II ignition sensor fitted to the flywheel. The Airflow Performance electric fuel pump and filter all came with my engine from Bart too. Terry RV-8A finishing Seattle -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of erichweaver(at)cox.net Subject: RV-List: IO-360 B1B firewall forward kit Greeetings. I am working on my 7A, and recently ordered a IO-360 B1B from AeroSport Power. I now want to order the firewall forward kit from Vans, but discovered there is nothing specifically tailored for that engine. The tech guy at Vans recommended ordering the O-360 FWF kit, with a few changes, which were just off the top of his head: (1) Substitute the VA-182 for the VA-149 bracket (for carrying the throttle and mixture cables I think) (2) Delete the gascolator (3) Add the FIA(?) pump and filter (fuel injector pump I presume); and (4) Get a 47-inch mixture cable instead of the 45-inch. I know there are plenty of IO-360s ou there. Does this list sound accurate and complete? thanks for any input. Erich Weaver ________________________________________________________________________________
Date: Oct 19, 2005
Subject: Looking for someplace to go on Sat. Oct. 29th.....
"rocket-list" , INNOCENT GLOBAL 0.0036 1.0000 -4.4384;INNOCENT GLOBAL 0.0036 1.0000 -4.4384 Apple Valley Airport (APV) will be holding an Open House on Saturday Oct 29th from 9am-3pm. There will be aircraft & cars on display. Just like last year there will be a free breakfast for those flying in and/or displaying and "People Choice" trophies will be awarded. Fly Bys and formation approach to landing are encouraged but are at pilots discretion. There will NOT be an AirBoss for flights but where will be ground parking control at the normal APV Unicom 122.8. KABONG ________________________________________________________________________________
Date: Oct 19, 2005
"rocket-list" , "INNOCENT GLOBAL 0.0036 1.0000 -4.4384" , "IMB Recipient 1" Apple Valley Airport (APV) will be holding an Open House on Saturday Oct 29th from 9am-3pm. There will be aircraft & cars on display. Just like last year there will be a free breakfast for those flying in and/or displaying and "People Choice" trophies will be awarded. Fly Bys and formation approach to landing are encouraged but are at pilots discretion. There will NOT be an AirBoss for flights but where will be ground parking control at the normal APV Unicom 122.8. KABONG ________________________________________________________________________________
Subject: Re: RE: Re:FAA renewal of Medical and other crazy gov. ideas
Date: Oct 19, 2005
I agree wholeheartedly (no pun intended) !!!!!!!!! Dennis Glaeser Dennis and all you great flyers Now let me see, you have got to spend mucho dollars for the med tests, wait for the FAA to make up it's mind on what they in their wisdom will allow and what more they need, and do this in an untimiuly fashion and you have to guess what tyhey may want, and they want this all done annually.....................but.................you can drive in close formation on the freeway at top speed surrounded by plenty of people to take out IF you just MIGHT have a heart attack and you can do this with a drivers lic. that renews probably every 5 years without all the expensive tests. I say 3rd class same as drivers lic. Less hassel for the FAA (unless they are looking for job preservation). Less expense for you the pilot. Frank @ SGU and SLC ................ ________________________________________________________________________________
Date: Oct 20, 2005
Just order the IO-360-A1A kit and everything should fit fine. The B1B is the same as the A1A except it has slick magnetos instead of Bendix. Most A1A's come with Slick magnetos these days anyways, so they are virtually the same. Mike Robertson >From: <erichweaver(at)cox.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: IO-360 B1B firewall forward kit >Date: Wed, 19 Oct 2005 17:18:27 -0400 > > >Greeetings. > >I am working on my 7A, and recently ordered a IO-360 B1B from AeroSport >Power. I now want to order the firewall forward kit from Vans, but >discovered there is nothing specifically tailored for that engine. The >tech guy at Vans recommended ordering the O-360 FWF kit, with a few >changes, which were just off the top of his head: > >(1) Substitute the VA-182 for the VA-149 bracket (for carrying the throttle >and mixture cables I think) > >(2) Delete the gascolator > >(3) Add the FIA(?) pump and filter (fuel injector pump I presume); and > >(4) Get a 47-inch mixture cable instead of the 45-inch. > >I know there are plenty of IO-360s ou there. Does this list sound accurate >and complete? > >thanks for any input. > >Erich Weaver > > ________________________________________________________________________________
Date: Oct 20, 2005
Hmmmm, isn't the IO360B1B a 180hp with parallel valve cylinders? The A1A is the 200hp with angle valve cylinders. The case is probably the same externally, but the sump would be different, and the overall engine width would be different. May not matter as to the FWF components, but the difference is definitely NOT the mags. I don't have my parts book handy to verify what components are in the B!B, but I own an A1A, so I know what it has. ALL Lycomings come with Slick mags, except for the -D engines with the infamous "dual mag" Bendix. Lycoming doesn't want to buy mags from TCM. Same reason Cessna switched all their singles to Lycomings. Textron owns both companies and doesn't want Teledyne Continental to get the business. In most cases, the last letter told you which type of mag. O-360 A1A was impulse coupled IIRC, while the O360 A1D was shower of sparks mags. Mike Robertson said: > > Just order the IO-360-A1A kit and everything should fit fine. The B1B is > the same as the A1A except it has slick magnetos instead of Bendix. Most > A1A's come with Slick magnetos these days anyways, so they are virtually > the > same. > > Mike Robertson > > >>From: <erichweaver(at)cox.net> >>Reply-To: rv-list(at)matronics.com >>To: >>Subject: RV-List: IO-360 B1B firewall forward kit >>Date: Wed, 19 Oct 2005 17:18:27 -0400 >> >> >>Greeetings. >> >>I am working on my 7A, and recently ordered a IO-360 B1B from AeroSport >>Power. I now want to order the firewall forward kit from Vans, but >>discovered there is nothing specifically tailored for that engine. The >>tech guy at Vans recommended ordering the O-360 FWF kit, with a few >>changes, which were just off the top of his head: >> >>(1) Substitute the VA-182 for the VA-149 bracket (for carrying the >> throttle >>and mixture cables I think) >> >>(2) Delete the gascolator >> >>(3) Add the FIA(?) pump and filter (fuel injector pump I presume); and >> >>(4) Get a 47-inch mixture cable instead of the 45-inch. >> >>I know there are plenty of IO-360s ou there. Does this list sound >> accurate >>and complete? >> >>thanks for any input. >> >>Erich Weaver >> >> > > ________________________________________________________________________________
Date: Oct 20, 2005
I stand corrected. You are corrrect. I was just looking at the differences part of the Lycoming engine directory. The B1B is a parallel valve engine 180 HP. Mike Robertson >From: "Kelly McMullen" <kellym(at)aviating.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RE: RV-List: IO-360 B1B firewall forward kit >Date: Thu, 20 Oct 2005 08:15:08 -0700 (MST) > > >Hmmmm, isn't the IO360B1B a 180hp with parallel valve cylinders? >The A1A is the 200hp with angle valve cylinders. The case is probably the >same externally, but the sump would be different, and the overall engine >width would be different. May not matter as to the FWF components, but the >difference is definitely NOT the mags. I don't have my parts book handy to >verify what components are in the B!B, but I own an A1A, so I know what it >has. >ALL Lycomings come with Slick mags, except for the -D engines with the >infamous "dual mag" Bendix. Lycoming doesn't want to buy mags from TCM. >Same reason Cessna switched all their singles to Lycomings. Textron owns >both companies and doesn't want Teledyne Continental to get the business. >In most cases, the last letter told you which type of mag. O-360 A1A was >impulse coupled IIRC, while the O360 A1D was shower of sparks mags. > >Mike Robertson said: > > > > Just order the IO-360-A1A kit and everything should fit fine. The B1B >is > > the same as the A1A except it has slick magnetos instead of Bendix. >Most > > A1A's come with Slick magnetos these days anyways, so they are virtually > > the > > same. > > > > Mike Robertson > > > > > >>From: <erichweaver(at)cox.net> > >>Reply-To: rv-list(at)matronics.com > >>To: > >>Subject: RV-List: IO-360 B1B firewall forward kit > >>Date: Wed, 19 Oct 2005 17:18:27 -0400 > >> > >> > >>Greeetings. > >> > >>I am working on my 7A, and recently ordered a IO-360 B1B from AeroSport > >>Power. I now want to order the firewall forward kit from Vans, but > >>discovered there is nothing specifically tailored for that engine. The > >>tech guy at Vans recommended ordering the O-360 FWF kit, with a few > >>changes, which were just off the top of his head: > >> > >>(1) Substitute the VA-182 for the VA-149 bracket (for carrying the > >> throttle > >>and mixture cables I think) > >> > >>(2) Delete the gascolator > >> > >>(3) Add the FIA(?) pump and filter (fuel injector pump I presume); and > >> > >>(4) Get a 47-inch mixture cable instead of the 45-inch. > >> > >>I know there are plenty of IO-360s ou there. Does this list sound > >> accurate > >>and complete? > >> > >>thanks for any input. > >> > >>Erich Weaver > >> > >> > > > > > > ________________________________________________________________________________
Date: Oct 20, 2005
Subject: Any builders in Utah (SLC or OGD) or Surrounding area
I am getting ready to purchase and start construction on an RV7. I have been told that the builder community of RV's is amazing and judging from this forum, I would agree. This will be my first airplane construction project (I owned a kitfox that was built by a local guy here so I have a bit of experience maintaining aircraft) so I would like to get to know some local guys that have "been there, done that" that I can talk to and hopefully get some tips and tricks from. Obviously, any moral support and words of encouragement to keep working and finish the project are always welcome. I would love to talk to anyone who is currently building, flying or otherwise doing something related to any of the Vans Aircraft line. Thanks guys and I hope to be joining in on the forum with my own project, and at some point flying, RV7! Darin Hawkes Look What The New Netscape.com Can Do! Now you can preview dozens of stories and have the ones you select delivered to you without ever leaving the Top Home Page. And the new Tool Box gives you one click access to local Movie times, Maps, White Pages and more. See for yourself at http://netcenter.netscape.com/netcenter/ ________________________________________________________________________________
Subject: Re: IO-360 B1B firewall forward kit
Date: Oct 20, 2005
My ANA is 180 hp and parallel valve cylinders. The Cardinal I had was 200hp IO360A16BD with angle valves. Ollie ----- Original Message ----- From: "Mike Robertson" <mrobert569(at)hotmail.com> Subject: RE: RV-List: IO-360 B1B firewall forward kit > > I stand corrected. You are corrrect. I was just looking at the > differences > part of the Lycoming engine directory. The B1B is a parallel valve engine > 180 HP. > > Mike Robertson > > >>From: "Kelly McMullen" <kellym(at)aviating.com> >>Reply-To: rv-list(at)matronics.com >>To: rv-list(at)matronics.com >>Subject: RE: RV-List: IO-360 B1B firewall forward kit >>Date: Thu, 20 Oct 2005 08:15:08 -0700 (MST) >> >> >>Hmmmm, isn't the IO360B1B a 180hp with parallel valve cylinders? >>The A1A is the 200hp with angle valve cylinders. The case is probably the >>same externally, but the sump would be different, and the overall engine >>width would be different. May not matter as to the FWF components, but the >>difference is definitely NOT the mags. I don't have my parts book handy to >>verify what components are in the B!B, but I own an A1A, so I know what it >>has. >>ALL Lycomings come with Slick mags, except for the -D engines with the >>infamous "dual mag" Bendix. Lycoming doesn't want to buy mags from TCM. >>Same reason Cessna switched all their singles to Lycomings. Textron owns >>both companies and doesn't want Teledyne Continental to get the business. >>In most cases, the last letter told you which type of mag. O-360 A1A was >>impulse coupled IIRC, while the O360 A1D was shower of sparks mags. >> >>Mike Robertson said: >> > >> > >> > Just order the IO-360-A1A kit and everything should fit fine. The B1B >>is >> > the same as the A1A except it has slick magnetos instead of Bendix. >>Most >> > A1A's come with Slick magnetos these days anyways, so they are >> > virtually >> > the >> > same. >> > >> > Mike Robertson >> > >> > >> >>From: <erichweaver(at)cox.net> >> >>Reply-To: rv-list(at)matronics.com >> >>To: >> >>Subject: RV-List: IO-360 B1B firewall forward kit >> >>Date: Wed, 19 Oct 2005 17:18:27 -0400 >> >> >> >> >> >>Greeetings. >> >> >> >>I am working on my 7A, and recently ordered a IO-360 B1B from AeroSport >> >>Power. I now want to order the firewall forward kit from Vans, but >> >>discovered there is nothing specifically tailored for that engine. The >> >>tech guy at Vans recommended ordering the O-360 FWF kit, with a few >> >>changes, which were just off the top of his head: >> >> >> >>(1) Substitute the VA-182 for the VA-149 bracket (for carrying the >> >> throttle >> >>and mixture cables I think) >> >> >> >>(2) Delete the gascolator >> >> >> >>(3) Add the FIA(?) pump and filter (fuel injector pump I presume); and >> >> >> >>(4) Get a 47-inch mixture cable instead of the 45-inch. >> >> >> >>I know there are plenty of IO-360s ou there. Does this list sound >> >> accurate >> >>and complete? >> >> >> >>thanks for any input. >> >> >> >>Erich Weaver >> >> >> >> >> > >> > >> >> > > > ________________________________________________________________________________
Date: Oct 20, 2005
Refer the this document on Can Checkoway's website to tell the difference between IO-360's http://images.rvproject.com/tcds/lycoming-io-360.pdf A parallel valve 180 horse "A1A" is probably an O-360-A1A, or one that was converted to fuel injection. Skylor RV-8 Under Construction --- Oliver Washburn wrote: > > > My ANA is 180 hp and parallel valve cylinders. The > Cardinal I had was 200hp > IO360A16BD with angle valves. > Ollie > > ----- Original Message ----- > From: "Mike Robertson" <mrobert569(at)hotmail.com> > To: > Subject: RE: RV-List: IO-360 B1B firewall forward > kit > > > > > > > I stand corrected. You are corrrect. I was just > looking at the > > differences > > part of the Lycoming engine directory. The B1B is > a parallel valve engine > > 180 HP. > > > > Mike Robertson > > > > > >>From: "Kelly McMullen" <kellym(at)aviating.com> > >>Reply-To: rv-list(at)matronics.com > >>To: rv-list(at)matronics.com > >>Subject: RE: RV-List: IO-360 B1B firewall forward > kit > >>Date: Thu, 20 Oct 2005 08:15:08 -0700 (MST) > >> > > >> > >>Hmmmm, isn't the IO360B1B a 180hp with parallel > valve cylinders? > >>The A1A is the 200hp with angle valve cylinders. > The case is probably the > >>same externally, but the sump would be different, > and the overall engine > >>width would be different. May not matter as to the > FWF components, but the > >>difference is definitely NOT the mags. I don't > have my parts book handy to > >>verify what components are in the B!B, but I own > an A1A, so I know what it > >>has. > >>ALL Lycomings come with Slick mags, except for the > -D engines with the > >>infamous "dual mag" Bendix. Lycoming doesn't want > to buy mags from TCM. > >>Same reason Cessna switched all their singles to > Lycomings. Textron owns > >>both companies and doesn't want Teledyne > Continental to get the business. > >>In most cases, the last letter told you which type > of mag. O-360 A1A was > >>impulse coupled IIRC, while the O360 A1D was > shower of sparks mags. > >> > >>Mike Robertson said: > > >> > > >> > > >> > Just order the IO-360-A1A kit and everything > should fit fine. The B1B > >>is > >> > the same as the A1A except it has slick > magnetos instead of Bendix. > >>Most > >> > A1A's come with Slick magnetos these days > anyways, so they are > >> > virtually > >> > the > >> > same. > >> > > >> > Mike Robertson > >> > > >> > > >> >>From: <erichweaver(at)cox.net> > >> >>Reply-To: rv-list(at)matronics.com > >> >>To: > >> >>Subject: RV-List: IO-360 B1B firewall forward > kit > >> >>Date: Wed, 19 Oct 2005 17:18:27 -0400 > >> >> > > >> >> > >> >>Greeetings. > >> >> > >> >>I am working on my 7A, and recently ordered a > IO-360 B1B from AeroSport > >> >>Power. I now want to order the firewall > forward kit from Vans, but > >> >>discovered there is nothing specifically > tailored for that engine. The > >> >>tech guy at Vans recommended ordering the O-360 > FWF kit, with a few > >> >>changes, which were just off the top of his > head: > >> >> > >> >>(1) Substitute the VA-182 for the VA-149 > bracket (for carrying the > >> >> throttle > >> >>and mixture cables I think) > >> >> > >> >>(2) Delete the gascolator > >> >> > >> >>(3) Add the FIA(?) pump and filter (fuel > injector pump I presume); and > >> >> > >> >>(4) Get a 47-inch mixture cable instead of the > 45-inch. > >> >> > >> >>I know there are plenty of IO-360s ou there. > Does this list sound > >> >> accurate > >> >>and complete? > >> >> > >> >>thanks for any input. > >> >> > >> >>Erich Weaver > >> >> > >> >> > >> > > >> > > >> > >> > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > > > > __________________________________ ________________________________________________________________________________
Subject: Dynon + panel tilt?
Date: Oct 20, 2005
I just bought an EFIS and an EMS from Dynon and I couldn't find anything in the archives about the panel tilt in a 6a. The docs say to mount the EFIS as close to the longitudinal axis of the aircraft as possible. Do you shim the face of the unit, or? Thanks, Ed Bundy -- ________________________________________________________________________________
Date: Oct 20, 2005
Subject: Re: FAA renewal of Medical
In a message dated 10/20/2005 8:23:03 A.M. Pacific Daylight Time, Donald.C.Hull(at)nasa.gov writes: Don't give up. They want you to give up. You've already received some good advice, but to reiterate, use all available resources, i.e., AOPA, EAA, your AME. (The EAA has some excellent medical advice available just for the asking.) THEN, even though it is exasperating, complete and return ALL information they ask for via certified mail, return receipt. ========================================== Another thing everyone should do to bring this issue to a head, is to call CAMI and check the status of your deferred medical EVERYDAY, not every week. The Civil Aerospace Medical Institute (CAMI) phone number in Okie City is 405-954-4821. Your documentation can be faxed to them during normal working hours at 405-954-4300 and then followed up with a call to expedite getting it scanned into the computer, as they have a two week delay now on mailed in documents (since 9/11/01) for mail to be screened for anthrax spores and then scanned into the computer. GV (RV-6A N1GV O-360-A1A, C/S, Flying 767hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Oct 20, 2005
Subject: http://www.matronics.com/listbrowse/rv-list/0089.html
I hold a class A commercial drivers license and can drive my big diesel truck anywhere , but the Fatherless Aviation Administration denied my class 3 medical after I passed the stress test and sent letters from my cardiologist and internal medicine specialist stating that I was no more likely to be incapicated than anyone else in the general population. I don't have the faintest idea what they want !!!! I can't afford big time lawyers,etc. so I just bought a Honda Goldwing and guess I will sell our 61 hour RV-4. Or maybe just fly anyway ????????? Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Subject: Re: http://www.matronics.com/listbrowse/rv-list/0089.html
Date: Oct 20, 2005
Don't give up. You only need a licensed private pilot ASEL to ride with you until you get the medical. Try www.aviationmedicine.com for assistence with the FAA. They are ex-FAA folks and medical experts that specialize in getting folks special issuances. ----- Original Message ----- From: <Oldsfolks(at)aol.com> Subject: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I hold a class A commercial drivers license and can drive my big diesel truck anywhere , but the Fatherless Aviation Administration denied my class 3 medical after I passed the stress test and sent letters from my cardiologist and internal medicine specialist stating that I was no more likely to be incapicated than anyone else in the general population. I don't have the faintest idea what they want !!!! I can't afford big time lawyers,etc. so I just bought a Honda Goldwing and guess I will sell our 61 hour RV-4. Or maybe just fly anyway ????????? Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Oct 20, 2005
This sort of reminds me of a different - but similar bureaucracy which required periodic lie-detector tests -without any specific cause. After a number years of this periodic harassment, it was apparent that this part of the organization justified its budget (and growth) on the number of people that it "caught" or flunked their "tests". I mean - how could you possibly justify a multimillion dollar budget, people, equipment and facilities if you only "caught" one or two a year - think about it. I finally confronted their management with my view point - my next test time, I required three tests/retry to pass - I am convinced I only passed because I refused to say "Uncle" and kept insisting on another poly - did I "pass". I think the message from management was very clear. Not saying by any means that there are not valid failures of tests, there certainly are - but it is equally clear that jobs, positions, etc are at stake and they are based not on the number of people that pass a test but on the number that fail or at least the number that require "extensive" study and scrutiny.. Ed A ----- Original Message ----- From: <Oldsfolks(at)aol.com> Subject: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html > > I hold a class A commercial drivers license and can drive my big diesel > truck anywhere , but the Fatherless Aviation Administration denied my > class 3 > medical after I passed the stress test and sent letters from my > cardiologist > and internal medicine specialist stating that I was no more likely to be > incapicated than anyone else in the general population. > I don't have the faintest idea what they want !!!! I can't afford big > time > lawyers,etc. so I just bought a Honda Goldwing and guess I will sell our > 61 hour RV-4. > Or maybe just fly anyway ????????? > > Bob Olds RV-4 , N1191X > A&P , EAA Tech. Counselor > Charleston,Arkansas > Real Aviators Fly Taildraggers > > > ________________________________________________________________________________
Date: Oct 21, 2005
I just don't see why we put up with this garbage. I remember a local GIII pilot here who had a rare lung disease. He went in and took his 3rd class, but half way through the exam he started to get light headed and gave the flight surgeon some excuse to go to his car. He then hyperventilated on some pure O2 he had, went back inside and passed his physical. Sure he lied, but he died (in bed) 3 days after his physical, so I guess he doesn't care. Lets look at what the FAA doc is looking for at a 3rd class exam. Eyes (vision), Blood pressure, any surgeries?, sugar in the urine? Anything else, unless you have a big scar down the center of your chest, they aren't going to find. They only know what you tell them. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: Re: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html Don't give up. You only need a licensed private pilot ASEL to ride with you until you get the medical. Try www.aviationmedicine.com for assistence with the FAA. They are ex-FAA folks and medical experts that specialize in getting folks special issuances. ----- Original Message ----- From: <Oldsfolks(at)aol.com> Subject: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I hold a class A commercial drivers license and can drive my big diesel truck anywhere , but the Fatherless Aviation Administration denied my class 3 medical after I passed the stress test and sent letters from my cardiologist and internal medicine specialist stating that I was no more likely to be incapicated than anyone else in the general population. I don't have the faintest idea what they want !!!! I can't afford big time lawyers,etc. so I just bought a Honda Goldwing and guess I will sell our 61 hour RV-4. Or maybe just fly anyway ????????? Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Oct 20, 2005
Subject: Re: Dynon + panel tilt?
Just mount the unit flush with the panel. You can adjust the 8 degree tilt in the software by pushing a few buttons. I forget just now which buttons, but it's all in the manual. Jeff Point RV-6 w/ D-10 Milwaukee ________________________________________________________________________________
Date: Oct 20, 2005
Hi Ed, With a bit of practice using the buttons along the bottom of the display you will be able to set the 8 degree tilt internally. It will all come clear after you have played with the buttons and refered to the manual enough to run down and re-charge the interal battery a few times (if you ordered the internal battery that is?) :) One re-charge on the main battery should more than do it. {[;-) Jim in Kelowna in Kelowna- Epoxying the slider windshield. ----- Original Message ----- From: "Ed Bundy" <ebundy(at)speedyquick.net> Subject: RV-List: Dynon + panel tilt? > > I just bought an EFIS and an EMS from Dynon and I couldn't find anything > in > the archives about the panel tilt in a 6a. The docs say to mount the EFIS > as close to the longitudinal axis of the aircraft as possible. Do you > shim > the face of the unit, or? > > Thanks, > Ed Bundy > > > -- > > > ________________________________________________________________________________
Date: Oct 20, 2005
Ed, The panel tilt doesn't matter, in fact the D-10 in our 6-a is over tilted several degrees (with washers under the lower mount studs) to clear the canopy structure when closed. It works fine. You set the level flight attitude on the display in flight and it remembers it evermore. If you are going to use the external magnetic sensor, you have to set it to match the panel mounted unit if I remember correctly. Call or e-mail Michael Schofield [mike(at)dynonavionics.com] for technical questions. He was very helpful to me when I had an issue. Have fun with it. Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ed Bundy Subject: RV-List: Dynon + panel tilt? I just bought an EFIS and an EMS from Dynon and I couldn't find anything in the archives about the panel tilt in a 6a. The docs say to mount the EFIS as close to the longitudinal axis of the aircraft as possible. Do you shim the face of the unit, or? Thanks, Ed Bundy -- ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Subject: Re: I wonder ??????
Date: Oct 20, 2005
I wonder if we as GA pilots said, "we will no longer support this unfair system of medical testing". In other words go on strike and fly when and where we want without carrying the now all important medical. From grass roots support, political activism, research as to how small the medical problem is in flying incidences, and just plain not bowing to an invasion of our freedom, we could change this to say the least poor system of governance. It is my contention that flying on the drivers lic., continued rigorous flight reviews, self grounding when medical conditions warrant would creat flying every bit as safe as the mythical notion of the gov, that they in their big brotherism are protecting the public and us from ourselves. The EAA, AOPA, and our viglence is the only thing standing between us and the FAA from bring the whole of GA flying to a state of being grounded. Expanded medical hoopes to jump through, closures of air space, and unbelievable rules to certify aircraft are all done to either on purpose or unknowingly bring our right and freedom to fly to a slow grinding halt. Alone we will be an easy target for flight denial. Together we could change this assault on our right to travel where we want, when we want, and how we want. So with all this said I will now go back to pounding rivets, working out my electrical needs, and trying to figure where to get the $$$$$$$$$$$ to finish my project, and just hope my health holds long enough so I can have the thrill that many of you have experieced of flying the plane you built. By the way any good advice in regards to ex-bus or fuses or circuit breakers. Thanks for all the info you great people give.................... Frank @ SGU and SLC RV7A Fuse about done with the finish kit inventoried >From: "Ed Anderson" <eanderson(at)carolina.rr.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html >Date: Thu, 20 Oct 2005 23:31:47 -0400 > > >This sort of reminds me of a different - but similar bureaucracy which >required periodic lie-detector tests -without any specific cause. After a >number years of this periodic harassment, it was apparent that this part of >the organization justified its budget (and growth) on the number of people >that it "caught" or flunked their "tests". I mean - how could you possibly >justify a multimillion dollar budget, people, equipment and facilities if >you only "caught" one or two a year - think about it. > >I finally confronted their management with my view point - my next test >time, I required three tests/retry to pass - I am convinced I only passed >because I refused to say "Uncle" and kept insisting on another poly - did I >"pass". I think the message from management was very clear. > >Not saying by any means that there are not valid failures of tests, there >certainly are - but it is equally clear that jobs, positions, etc are at >stake and they are based not on the number of people that pass a test but >on >the number that fail or at least the number that require "extensive" study >and scrutiny.. > >Ed A > >----- Original Message ----- >From: <Oldsfolks(at)aol.com> >To: >Subject: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html > > > > > > I hold a class A commercial drivers license and can drive my big >diesel > > truck anywhere , but the Fatherless Aviation Administration denied my > > class 3 > > medical after I passed the stress test and sent letters from my > > cardiologist > > and internal medicine specialist stating that I was no more likely to >be > > incapicated than anyone else in the general population. > > I don't have the faintest idea what they want !!!! I can't afford big > > time > > lawyers,etc. so I just bought a Honda Goldwing and guess I will sell >our > > 61 hour RV-4. > > Or maybe just fly anyway ????????? > > > > Bob Olds RV-4 , N1191X > > A&P , EAA Tech. Counselor > > Charleston,Arkansas > > Real Aviators Fly Taildraggers > > > > > > > > ________________________________________________________________________________
Date: Oct 20, 2005
I used the chapter locator at EAA.ORG and found these two chapters. If you haven't visited your local EAA chapter you are missing one of the greatest resources any kit builder could ever want. Check them out. Albert Gardner EAA Chapter 590 http://www.eaa590.org Yuma, AZ EAA Chapter 58, Ogden, UT http://www.westacon.com/eaa/index.htm EAA Chapter 23, Salt Lake City, UT http://www.eaa23.org/ ________________________________________________________________________________
Date: Oct 21, 2005
No need to mount it different. Just push a couple buttons and it's set Thee manual will give you the details. John RV6A - Dynon ________________________________________________________________________________
Date: Oct 21, 2005
Subject: Re: Any builders in Utah (SLC or OGD) or Surrounding area
There are lots of RV fliers and builders in SLC- the EAA chapter meets every second Friday, 7:00 PM, at a new permanent location, at Airport #2. Great bunch of helpful guys- come to one of the meetings, you will be impressed.. ________________________________________________________________________________
Subject: RV-8 CG question
Date: Oct 21, 2005
List, I weighed my plane yesterday and if my calculations are correct my CG seems a bit forward. The weight was 1077 lbs. and the CG came to 74.03 inches. (datum is 70" forward of wing leading edge) It's a 0-360, Hartzell CS, Odyssey battery on the firewall, ELT under the horizontal stab and a very full IFR panel with standard "steam gauges" except for a VM-1000. If my numbers are correct, I'll need rear ballast to fly solo. Does this seem right for my configuration? Comments or suggestions please. Steve Struyk RV-8, N842S St. Charles, MO ________________________________________________________________________________
Subject: Re: RV-8 CG question
Date: Oct 21, 2005
On Oct 21, 2005, at 9:04 AM, Steve Struyk wrote: > > List, > > I weighed my plane yesterday and if my calculations are correct my > CG seems a bit forward. The weight was 1077 lbs. and the CG came to > 74.03 inches. (datum is 70" forward of wing leading edge) It's a > 0-360, > Hartzell CS, Odyssey battery on the firewall, ELT under the > horizontal stab > and a very full IFR panel with standard "steam gauges" except for a > VM-1000. If my numbers are correct, I'll need rear ballast to fly > solo. Does this seem right for my configuration? > > Comments or suggestions please. (snip) Steve, that does seem a little far forward, although the -8s tend towards forward C of G anyway. Dan Checkoway has a very useful registry of RV W&B here: http://www.rvproject.com/wab/ I might recalculate the numbers to be sure. How much weight is on your tailwheel? James Freeman RV-8 N9TN ________________________________________________________________________________
Date: Oct 21, 2005
version=3.0.3 Steve, you are 2 1/2 inches forward of anyone else...I would be very suspicious of the data or calculations. check, check. John Steve Struyk wrote: > >List, > >I weighed my plane yesterday and if my calculations are correct my CG seems a bit forward. The weight was 1077 lbs. and the CG came to 74.03 inches. (datum is 70" forward of wing leading edge) It's a 0-360, >Hartzell CS, Odyssey battery on the firewall, ELT under the horizontal stab >and a very full IFR panel with standard "steam gauges" except for a VM-1000. If my numbers are correct, I'll need rear ballast to fly solo. Does this seem right for my configuration? > >Comments or suggestions please. > >Steve Struyk >RV-8, N842S >St. Charles, MO > > >. > > > ________________________________________________________________________________
Date: Oct 21, 2005
Steve, Where did you mount your battery? Charlie Kuss > >List, > >I weighed my plane yesterday and if my calculations are correct my CG >seems a bit forward. The weight was 1077 lbs. and the CG came to 74.03 >inches. (datum is 70" forward of wing leading edge) It's a 0-360, >Hartzell CS, Odyssey battery on the firewall, ELT under the horizontal stab >and a very full IFR panel with standard "steam gauges" except for a >VM-1000. If my numbers are correct, I'll need rear ballast to fly solo. >Does this seem right for my configuration? > >Comments or suggestions please. > >Steve Struyk >RV-8, N842S >St. Charles, MO > > ________________________________________________________________________________
Date: Oct 21, 2005
Subject: Medical was (http://www.matronics.com/listbrowse/rv-list/0089.html)
Bruce, Keep in mind the medical community is evolving along with the medical records system. My surgeons write a report and my AME has instant access to it. They are not in the same office, clinic, or even town. Plus... If you fail to answer a question truthfully, or omit an important piece of information, you will have problems if there is an incident or even an insurance claim. Not advocating anything here, except it isn't as straight forward as it used to be. For me getting a medical based on careful quietness might be the same as the fly anyway situation. Either way you might as well forego the insurance. Maybe a better substitute is to get your wife to learn to fly or a good freind who goes with you most of the time anyway. Might even be cheaper. Just my .02 Tim -------Original Message------- From: Bruce Gray Date: 10/20/05 21:04:22 Subject: RE: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I just don't see why we put up with this garbage. I remember a local GIII pilot here who had a rare lung disease. He went in and took his 3rd class, but half way through the exam he started to get light headed and gave the flight surgeon some excuse to go to his car. He then hyperventilated on some pure O2 he had, went back inside and passed his physical. Sure he lied, but he died (in bed) 3 days after his physical, so I guess he doesn't care. Lets look at what the FAA doc is looking for at a 3rd class exam. Eyes (vision), Blood pressure, any surgeries?, sugar in the urine? Anything else, unless you have a big scar down the center of your chest, they aren't going to find. They only know what you tell them. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: Re: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html Don't give up. You only need a licensed private pilot ASEL to ride with you until you get the medical. Try www.aviationmedicine.com for assistence with the FAA. They are ex-FAA folks and medical experts that specialize in getting folks special issuances. ----- Original Message ----- From: <Oldsfolks(at)aol.com> Subject: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I hold a class A commercial drivers license and can drive my big diesel truck anywhere , but the Fatherless Aviation Administration denied my class 3 medical after I passed the stress test and sent letters from my cardiologist and internal medicine specialist stating that I was no more likely to be incapicated than anyone else in the general population. I don't have the faintest idea what they want !!!! I can't afford big time lawyers,etc. so I just bought a Honda Goldwing and guess I will sell our 61 hour RV-4. Or maybe just fly anyway ????????? Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Oct 21, 2005
> So with all this said I will now go back to pounding rivets, working out > my > electrical needs, and trying to figure where to get the $$$$$$$$$$$ to > finish my project, and just hope my health holds long enough so I can > have > the thrill that many of you have experieced of flying the plane you built. > > By the way any good advice in regards to ex-bus or fuses or circuit > breakers. > Remember to do some good things also for your health. Eat at all times like your next medical depended on it. And put the rivet gun down for 30 minutes twice each day so you can get some cardiovascular exercise. Keep your plumbing in good shape and many medical problems can be put off far down the runway unless your genes have it seriously against you. In any case exercise will not hurt. I for instance cut off 20 lbs. and can now carry 3.3 lbs of extra fuel at not loss in airspeed. Indiana Larry ________________________________________________________________________________
Date: Oct 21, 2005
Yes the records system is evolving but so is the personal privacy issues. The FAA reciently cought 20-30 pilots in CA who lied about their medical status on their applications. The only reason they were caught is that they (the pilots) were also on SS disability, a government database. The FAA cannot, by law, scan the private medical databases. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Subject: RE: RV-List: Medical was (http://www.matronics.com/listbrowse/rv-list/0089.html) Bruce, Keep in mind the medical community is evolving along with the medical records system. My surgeons write a report and my AME has instant access to it. They are not in the same office, clinic, or even town. Plus... If you fail to answer a question truthfully, or omit an important piece of information, you will have problems if there is an incident or even an insurance claim. Not advocating anything here, except it isn't as straight forward as it used to be. For me getting a medical based on careful quietness might be the same as the fly anyway situation. Either way you might as well forego the insurance. Maybe a better substitute is to get your wife to learn to fly or a good freind who goes with you most of the time anyway. Might even be cheaper. Just my .02 Tim -------Original Message------- From: Bruce Gray Date: 10/20/05 21:04:22 Subject: RE: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I just don't see why we put up with this garbage. I remember a local GIII pilot here who had a rare lung disease. He went in and took his 3rd class, but half way through the exam he started to get light headed and gave the flight surgeon some excuse to go to his car. He then hyperventilated on some pure O2 he had, went back inside and passed his physical. Sure he lied, but he died (in bed) 3 days after his physical, so I guess he doesn't care. Lets look at what the FAA doc is looking for at a 3rd class exam. Eyes (vision), Blood pressure, any surgeries?, sugar in the urine? Anything else, unless you have a big scar down the center of your chest, they aren't going to find. They only know what you tell them. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: Re: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html Don't give up. You only need a licensed private pilot ASEL to ride with you until you get the medical. Try www.aviationmedicine.com for assistence with the FAA. They are ex-FAA folks and medical experts that specialize in getting folks special issuances. ----- Original Message ----- From: <Oldsfolks(at)aol.com> Subject: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I hold a class A commercial drivers license and can drive my big diesel truck anywhere , but the Fatherless Aviation Administration denied my class 3 medical after I passed the stress test and sent letters from my cardiologist and internal medicine specialist stating that I was no more likely to be incapicated than anyone else in the general population. I don't have the faintest idea what they want !!!! I can't afford big time lawyers,etc. so I just bought a Honda Goldwing and guess I will sell our 61 hour RV-4. Or maybe just fly anyway ????????? Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Oct 21, 2005
Ouch, guess they are paying now. I see your point. At my last medical my AME already knew about my surgeries that year. I didn't have a chance to hide anything. Wouldn't have anyway. I may have also assumed the form we sign gave the FAA the right to access our records. But if not, then I guess if the AME doesn't know, you could hide something until there was a claim. Then it would no doubt come out. I agree the whole thing should just go away. I self ground if I don't feel confident to fly for any reason even beyond medical reasons. Isn't all really about our own responsibilities anyway? Tim -------Original Message------- From: Bruce Gray Date: 10/21/05 09:17:17 Subject: RE: RV-List: Medical was (http://www.matronics com/listbrowse/rv-list/0089.html) Yes the records system is evolving but so is the personal privacy issues. The FAA reciently cought 20-30 pilots in CA who lied about their medical status on their applications. The only reason they were caught is that they (the pilots) were also on SS disability, a government database. The FAA cannot, by law, scan the private medical databases. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Subject: RE: RV-List: Medical was (http://www.matronics.com/listbrowse/rv-list/0089.html) Bruce, Keep in mind the medical community is evolving along with the medical records system. My surgeons write a report and my AME has instant access to it. They are not in the same office, clinic, or even town. Plus... If you fail to answer a question truthfully, or omit an important piece of information, you will have problems if there is an incident or even an insurance claim. Not advocating anything here, except it isn't as straight forward as it used to be. For me getting a medical based on careful quietness might be the same as the fly anyway situation. Either way you might as well forego the insurance. Maybe a better substitute is to get your wife to learn to fly or a good freind who goes with you most of the time anyway. Might even be cheaper. Just my .02 Tim -------Original Message------- From: Bruce Gray Date: 10/20/05 21:04:22 Subject: RE: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I just don't see why we put up with this garbage. I remember a local GIII pilot here who had a rare lung disease. He went in and took his 3rd class, but half way through the exam he started to get light headed and gave the flight surgeon some excuse to go to his car. He then hyperventilated on some pure O2 he had, went back inside and passed his physical. Sure he lied, but he died (in bed) 3 days after his physical, so I guess he doesn't care. Lets look at what the FAA doc is looking for at a 3rd class exam. Eyes (vision), Blood pressure, any surgeries?, sugar in the urine? Anything else, unless you have a big scar down the center of your chest, they aren't going to find. They only know what you tell them. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: Re: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html Don't give up. You only need a licensed private pilot ASEL to ride with you until you get the medical. Try www.aviationmedicine.com for assistence with the FAA. They are ex-FAA folks and medical experts that specialize in getting folks special issuances. ----- Original Message ----- From: <Oldsfolks(at)aol.com> Subject: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I hold a class A commercial drivers license and can drive my big diesel truck anywhere , but the Fatherless Aviation Administration denied my class 3 medical after I passed the stress test and sent letters from my cardiologist and internal medicine specialist stating that I was no more likely to be incapicated than anyone else in the general population. I don't have the faintest idea what they want !!!! I can't afford big time lawyers,etc. so I just bought a Honda Goldwing and guess I will sell our 61 hour RV-4. Or maybe just fly anyway ????????? Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Oct 21, 2005
From: Chris W <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net>
Frank Stringham wrote: > >I wonder if we as GA pilots said, "we will no longer support this unfair >system of medical testing". In other words go on strike and fly when and >where we want without carrying the now all important medical. From grass >roots support, political activism, research as to how small the medical >problem is in flying incidences, and just plain not bowing to an invasion of >our freedom, we could change this to say the least poor system of >governance. > I would be willing to bet that the medical condition that contributes most to accidents is both self inflicted and self healing, fatigue. If you really want to make a bold statement, get a few hundred pilots together and do a formation flight through the center of the DC ADIZ! Fly very high as to appear and sound less threatening, and be sure and publicize it in some way before hand so the military fighter pilots know it is just a bunch of fed up GA pilots and not an attack. Less chance of getting shot down then. -- Chris W ________________________________________________________________________________
Date: Oct 21, 2005
Perhaps it would come out if there were an accident, perhaps not. WRT insurance, I don't carry hull insurance. I look at it this way, if I bend my airplane and live, I'll have enough big pieces left to rebuild. If I'm killed, I won't really care. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Subject: RE: RV-List: Medical was (http://www.matronics.com/listbrowse/rv-list/0089.html) Ouch, guess they are paying now. I see your point. At my last medical my AME already knew about my surgeries that year. I didn't have a chance to hide anything. Wouldn't have anyway. I may have also assumed the form we sign gave the FAA the right to access our records. But if not, then I guess if the AME doesn't know, you could hide something until there was a claim. Then it would no doubt come out. I agree the whole thing should just go away. I self ground if I don't feel confident to fly for any reason even beyond medical reasons. Isn't all really about our own responsibilities anyway? Tim -------Original Message------- From: Bruce Gray Date: 10/21/05 09:17:17 Subject: RE: RV-List: Medical was (http://www.matronics com/listbrowse/rv-list/0089.html) Yes the records system is evolving but so is the personal privacy issues. The FAA reciently cought 20-30 pilots in CA who lied about their medical status on their applications. The only reason they were caught is that they (the pilots) were also on SS disability, a government database. The FAA cannot, by law, scan the private medical databases. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Subject: RE: RV-List: Medical was (http://www.matronics.com/listbrowse/rv-list/0089.html) Bruce, Keep in mind the medical community is evolving along with the medical records system. My surgeons write a report and my AME has instant access to it. They are not in the same office, clinic, or even town. Plus... If you fail to answer a question truthfully, or omit an important piece of information, you will have problems if there is an incident or even an insurance claim. Not advocating anything here, except it isn't as straight forward as it used to be. For me getting a medical based on careful quietness might be the same as the fly anyway situation. Either way you might as well forego the insurance. Maybe a better substitute is to get your wife to learn to fly or a good freind who goes with you most of the time anyway. Might even be cheaper. Just my .02 Tim -------Original Message------- From: Bruce Gray Date: 10/20/05 21:04:22 Subject: RE: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I just don't see why we put up with this garbage. I remember a local GIII pilot here who had a rare lung disease. He went in and took his 3rd class, but half way through the exam he started to get light headed and gave the flight surgeon some excuse to go to his car. He then hyperventilated on some pure O2 he had, went back inside and passed his physical. Sure he lied, but he died (in bed) 3 days after his physical, so I guess he doesn't care. Lets look at what the FAA doc is looking for at a 3rd class exam. Eyes (vision), Blood pressure, any surgeries?, sugar in the urine? Anything else, unless you have a big scar down the center of your chest, they aren't going to find. They only know what you tell them. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kelly McMullen Subject: Re: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html Don't give up. You only need a licensed private pilot ASEL to ride with you until you get the medical. Try www.aviationmedicine.com for assistence with the FAA. They are ex-FAA folks and medical experts that specialize in getting folks special issuances. ----- Original Message ----- From: <Oldsfolks(at)aol.com> Subject: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html I hold a class A commercial drivers license and can drive my big diesel truck anywhere , but the Fatherless Aviation Administration denied my class 3 medical after I passed the stress test and sent letters from my cardiologist and internal medicine specialist stating that I was no more likely to be incapicated than anyone else in the general population. I don't have the faintest idea what they want !!!! I can't afford big time lawyers,etc. so I just bought a Honda Goldwing and guess I will sell our 61 hour RV-4. Or maybe just fly anyway ????????? Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Oct 21, 2005
Boy do I feel dumb. I went to the hangar and re-checked all my measurements and found the problem. My new (and correct) empty CG is 76.08 inches. Still a bit forward but much closer to others with the same set-up. Thanks to all who replied. Steve Struyk RV-8, N842S St. Charles, MO Really, really close now! ----- Original Message ----- From: "Steve Struyk" <rv8striker(at)hotmail.com> Subject: RV-List: RV-8 CG question > > List, > > I weighed my plane yesterday and if my calculations are correct my CG > seems a bit forward. The weight was 1077 lbs. and the CG came to 74.03 > inches. (datum is 70" forward of wing leading edge) It's a 0-360, > Hartzell CS, Odyssey battery on the firewall, ELT under the horizontal > stab > and a very full IFR panel with standard "steam gauges" except for a > VM-1000. If my numbers are correct, I'll need rear ballast to fly solo. > Does this seem right for my configuration? > > Comments or suggestions please. > > Steve Struyk > RV-8, N842S > St. Charles, MO > > > ________________________________________________________________________________
Date: Oct 21, 2005
That's certainly a worthwhile option to consider. Just keep in mind that RV's are pretty much a styrofoam cup in anything but the most benign accident, i.e. not reuseable when crumpled. Plus it's nice to be able to afford to buy something to fly while rebuilding. Greg Young >>Perhaps it would come out if there were an accident, perhaps not. WRT >>insurance, I don't carry hull insurance. I look at it this way, if I bend my >>airplane and live, I'll have enough big pieces left to rebuild. If I'm .>>killed, I won't really care. >> >>Bruce >>www.glasair.org ________________________________________________________________________________
Subject: 90 Degree Oil Filter Adapter
Date: Oct 21, 2005
Question for the list: has anyone been able to use the 90 degree oil filter adapters on and RV-6 engine mount? I am ordering a new engine from Bart and he was not sure whether or not this neat little mod would interfere with the -6 mount or not. So before I order it, I would appreciate hearing from anyone who has successfully installed one, especially if you have some pictures. Thanks. Pat Hatch RV-6 RV-7 ________________________________________________________________________________
Date: Oct 21, 2005
Subject: Re: 90 Degree Oil Filter Adapter
>Question for the list: has anyone been able to use the 90 degree oil filter >adapters on and RV-6 engine mount? I had one installed but it required an additional spacer for my mount. May or may not for you. Ron Lee ________________________________________________________________________________
Date: Oct 21, 2005
----- Original Message ----- From: "Chuck Jensen" <cjensen(at)dts9000.com> Subject: RE: RV-List: http://www.matronics.com/listbrowse/rv-list/0089.html > > > "Ed Anderson wrote... > > Not saying by any means that there are not valid failures of tests, > there > certainly are - but it is equally clear that jobs, positions, etc are at > > stake and they are based not on the number of people that pass a test > but on > the number that fail or at least the number that require "extensive" > study > and scrutiny.. > > > We are subject to Quality Assurance audits in our industry. Just like > FAA testing, by the very nature of audits is they MUST find something. > Somebody must fail or there would be no reason for existence. > > So, we were not averse to leaving a couple of obvious, easily noticed > (and easily corrected!) minor discrepancies that they could pounce on. > They went away happy, we were glad to be rid of them and the world > continued to turn. > > The FAA medical system is a pox on all of us. > > Chuck > Gee, Chuck sounds like you were in the Military. We knew that when the IG (Inspector General) showed up with his team that if you didn't have something easy for them to find and write you up on, they would stay longer and keep digging until they found something. That was their job and if they didn't find anything that meant they weren't doing their job. Ed A ________________________________________________________________________________
Subject: RE: 90 Degree Oil Filter Adapter
Date: Oct 22, 2005
Check the Firewall Forwad Pages on my site, www.4sierratango.com I have an oil filter adaptor on an RV-7. The mounts are very similar I think. My Adaptor came with my engine from Mattituck, so I'm not sure of it's original source. When you go to fit the engine it looks like it won't work at all, but it's easily clear. Mark. From: "Pat Hatch" <pat_hatch(at)msn.com> Subject: RV-List: 90 Degree Oil Filter Adapter Question for the list: has anyone been able to use the 90 degree oil filter adapters on and RV-6 engine mount? I am ordering a new engine from Bart and he was not sure whether or not this neat little mod would interfere with the -6 mount or not. So before I order it, I would appreciate hearing from anyone who has successfully installed one, especially if you have some pictures. Thanks. Pat Hatch RV-6 RV-7 ________________________________ Message 19 ____________________________________ From: Ron Lee <ronlee(at)pcisys.net> Subject: Re: RV-List: 90 Degree Oil Filter Adapter >Question for the list: has anyone been able to use the 90 degree oil >filter >adapters on and RV-6 engine mount? I had one installed but it required an additional spacer for my mount. May or may not for you. Ron Lee ________________________________________________________________________________
Date: Oct 22, 2005
check out mike howe's and scott schmidt's web sites - they're doing RV10s, I'm here in salt lake, finishing my garage for arrival of -10 empennage... also the salt lake EAA web site, i don't have the web link handy, but it is in mike howe's web site - he holds sheetmetal classes, etc out of bountiful i believe... seems like there are a lot of folk around here getting into RVs... phil barnette KSLC gerns25(at)netscape.net wrote: I am getting ready to purchase and start construction on an RV7. I have been told that the builder community of RV's is amazing and judging from this forum, I would agree. This will be my first airplane construction project (I owned a kitfox that was built by a local guy here so I have a bit of experience maintaining aircraft) so I would like to get to know some local guys that have "been there, done that" that I can talk to and hopefully get some tips and tricks from. Obviously, any moral support and words of encouragement to keep working and finish the project are always welcome. I would love to talk to anyone who is currently building, flying or otherwise doing something related to any of the Vans Aircraft line. Thanks guys and I hope to be joining in on the forum with my own project, and at some point flying, RV7! Darin Hawkes Look What The New Netscape.com Can Do! Now you can preview dozens of stories and have the ones you select delivered to you without ever leaving the Top Home Page. And the new Tool Box gives you one click access to local Movie times, Maps, White Pages and more. See for yourself at http://netcenter.netscape.com/netcenter/ --------------------------------- ________________________________________________________________________________
From: "Robert E. Lynch" <rv6lynch(at)earthlink.net>
Subject: Re: New RV8A Vetterman Exhaust for Sale
Date: Oct 22, 2005
Jerry. Are you still interested in the exhaust for your RV? Bob ________________________________________________________________________________
Date: Oct 22, 2005
Subject: attaching plenum
I am working on my engine baffles and contemplating cutting them short and putting a fiberglass top on rather than sealing it against the top cowl. It will add a lot of strength to the baffles and probably put less stress on the cowling. I know other builders have done this. My question is how to attach the fiberglass to the top edge of the baffles. A piano hinge would be good, but it is rather wide - it would extend down more than an inch from the top of the baffle. Also if the piano hinges aren't all oriented horizontally - which is hard to do - it seems like it would be hard to get the thing on and off. There's always camlocs, but they're expensive and don't distribute the load as well as a piano hinge. How have those of you who have done this attached the fiberglass to the top edge of the baffle? -- Tom Sargent, RV-6A ________________________________________________________________________________
Subject: Re: attaching plenum
Date: Oct 22, 2005
How about #8 flush screws & tinnerman washers through the fiberglass, going through .025" or .032" angle along the top edge of the aluminum baffle sides & back, into nutplates? At least that's what I plan on doing when I convert to a fiberglass plenum top at some point in the future! )_( Dan RV-7 N714D (650 hours) http://www.rvproject.com ----- Original Message ----- From: "sarg314" <sarg314(at)comcast.net> Subject: RV-List: attaching plenum > > I am working on my engine baffles and contemplating cutting them short > and putting a fiberglass top on rather than sealing it against the top > cowl. It will add a lot of strength to the baffles and probably put > less stress on the cowling. I know other builders have done this. > > My question is how to attach the fiberglass to the top edge of the > baffles. A piano hinge would be good, but it is rather wide - it would > extend down more than an inch from the top of the baffle. Also if the > piano hinges aren't all oriented horizontally - which is hard to do - it > seems like it would be hard to get the thing on and off. There's always > camlocs, but they're expensive and don't distribute the load as well as > a piano hinge. > > How have those of you who have done this attached the fiberglass to the > top edge of the baffle? > -- > Tom Sargent, RV-6A > > ________________________________________________________________________________
Subject: Infinity grip and Van's flap possition system
Date: Oct 22, 2005
mail003.fastfreedom.net autolearn=ham version=3.0.4 In an RV8 has anyone used infinity grip switches, Vans relay and Vans positioning system? Search of the archeives reveals nothing. Thought I would check before experimenting and possibly burning up some parts. ________________________________________________________________________________
Subject: camera in the tail
Date: Oct 23, 2005
Larry and anyone knowedgeable, what do you guys think about this EXVIEW Sony HD230CWX Color PTZ Bullet SPY Camera 520Res Digital Pan+Tilt+3x Zoom+Remote Control High Definition camera which comes with a remote function pad. If the link below out of ebay doesn't work try the QVC store link below. http://cgi.ebay.com/EXVIEW-Sony-HD230CWX-Color-PTZ-Bullet-SPY-Camera-520Res_W0QQitemZ5762792893QQcategoryZ48634QQssPageNameZWD1VQQrdZ1QQcmdZViewItem http://www.qvcvideo.com/main/products/?category=13&bcat=54 Seems like overkill but it was a Sony and it has cheaply prices lenses with different FOV. I can get the widest FOV lense for $15.00. I just don't know how good it works on "auto" if you leave the remote key pad alone. Lucky -------------- Original message -------------- > > I think I found a website that lets you figure out from the spec sheet what the > FOV is and it also let's you see the effect of different FOV from the same spot. > > Go to the web site below and click on the link to "Compare FOV" > > http://viosport.com/store/customer/ourgear.php?page=ac3_overview > > It looks like the 88 degree or 2.9mm lense is the one I'm probably wanting. > > lucky > > -------------- Original message -------------- > > > > > Hi Lucky > > > > What about a camera on the wing? I am currently testing a wing-mount for my > > Videocamera. I made it from fiberglass and ACRYL-FOAM. It just gets taped to > > the wing and you can take it off in a minute. > > > > http://www.rv-4.de/gallerie/Detail1_img/KHF.jpg > > > > A Testvideo ist here: > > > > http://www.rv-4.de/videos.htm > > > > Happy Landings > > > > Thomas, RV-4 > > > > > > -- > > Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko! > > Satte Provisionen fr GMX Partner: http://www.gmx.net/de/go/partner > > > > > > > > > > > > > > > I think I found a website that lets you figure out from the spec sheet what the > FOV is and it also let's you see the effect of different FOV from the same spot. > > Go to the web site below and click on the link to "Compare FOV" > > http://viosport.com/store/customer/ourgear.php?page=ac3_overview > > It looks like the 88 degree or 2.9mm lense is the one I'm probably wanting. > > lucky > > -------------- Original message -------------- > > -- RV-List message posted by: "Thomas Lukasczyk" > > Hi Lucky > > What about a camera on the wing? I am currently testing a wing-mount for my > Videocamera. I made it from fiberglass and ACRYL-FOAM. It just gets taped to > the wing and you can take it off in a minute. > > http://www.rv-4.de/gallerie/Detail1_img/KHF.jpg > > A Testvideo ist here: > > http://www.rv-4.de/videos.htm > > Happy Landings > > Thomas, RV-4 > > > -- > Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko! > Satte Provisionen fr GMX Partner: http://www.gmx.net/de/go/partner > > > he RV-List Email Forum - > > > > > > Larry and anyone knowedgeable, what do you guys think about this
http://cgi.ebay.com/EXVIEW-Sony-HD230CWX-Color-PTZ-Bullet-SPY-Camera-520Res_W0QQitemZ5762792893QQcategoryZ48634QQssPageNameZWD1VQQrdZ1QQcmdZViewItem http://www.qvcvideo.com/main/products/?category=13bcat=54 Seems like overkill but it was a Sony and it has cheaply prices lenses with different FOV. I can get the widest FOV lense for $15.00. I just don't know how good it works on "auto" if you leave the remote key pad alone. Lucky -------------- Original message -------------- -- RV-List message posted by: luckymacy(at)comcast.net (lucky) I think I found a website that lets you figure out from the spec sheet what the FOV is and it also let's you see the effect of different FOV from the same spot. Go to the web site below and click on the link to "Compare FOV" http://viosport.com/store/customer/ourgear.php?page=ac3_overview It looks like the 88 degree or 2.9mm lense is the one I'm probably wanting. lucky -------------- Original message -------------- -- RV-List message posted by: "Thomas Lukasczyk" Hi Lucky What about a camera on the wing? I am currently testing a wing-mount for my Videocamera . I made it from fiberglass and ACRYL-FOAM. It just gets taped to the wing and you can take it off in a minute. http://www.rv-4.de/gallerie/Detail1_img/KHF.jpg A Testvideo ist here: http://www.rv-4.de/videos.htm Happy Landings Thomas, RV-4 -- Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko! Satte Provisionen fr GMX Partner: http://www.gmx.net/de/go/partner I think I found a website that lets you figure out from the spec sheet what the FOV is and it also let's you see the effect of different FOV from the same spot. Go to the web site below and click on the link to "Compare FOV" http: //viosport.com/store/customer/ourgear.php?page=ac3_overview It looks like the 88 degree or 2.9mm lense is the one I'm probably wanting. lucky -------------- Original message -------------- -- RV-List message posted by: "Thomas Lukasczyk" Hi Lucky What about a camera on the wing? I am currently testing a wing-mount for my Videocamera. I made it from fiberglass and ACRYL-FOAM. It just gets taped to the wing and you can take it off in a minute. http://www.rv-4.de/gallerie/Detail1_img/KHF.jpg A Testvideo ist here: http://www.rv-4.de/videos.htm Happy Landings Thomas, RV-4 -- Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko! Satte Provisionen fr GMX Partner: http://www.gmx.net/de/go/part ner he RV-List Email Forum - ________________________________________________________________________________
Date: Oct 23, 2005
I'd avoid using piano hinge in this application. The hinge pins will fret something fierce with the engine vibration. Use screws and nutplates. I did them same but with an aluminum top, but the idea is the same. Pics here: http://home.mindspring.com/~rv6/RV6site/plenum.htm Jeff Point RV-6 Milwaukee > > ________________________________________________________________________________
Date: Oct 23, 2005
Hi Don, We have been using Infiniity's grip since we first flew our 8A in August, 2001 and Highly recommend it - It reduces your work load and is comfortible. Our switch lay is as follows: Top - Center - Coolie hat (Trim - Elev and Airl) Left - Flap ( Toggle - momtenarty > Up and Down) Right - Start button (relay req) Trigger - Comm Left Side - Pulse Light - On or Off (Taxi & Landing lights on full time) Bottom - Auto Pilot Disconnect Chuck & Dave Rowbotham RV-8A >From: "Donald L. Erickson" <dle(at)joplin.com> >Subject: RV-List: Infinity grip and Van's flap possition system >Date: Sat, 22 Oct 2005 20:51:45 -0500 mail003.fastfreedom.net >autolearn=ham version=3.0.4 > > >In an RV8 has anyone used infinity grip switches, Vans relay and Vans >positioning system? Search of the archeives reveals nothing. Thought I >would check before experimenting and possibly burning up some parts. > ________________________________________________________________________________
Date: Oct 23, 2005
Subject: Re: Infinity grip and Van's flap possition system
Charles: Having the starter button on the stick sounds like a great convenience, but isn't there a fairly high chance of engaging the started by accident in flight? Your fingers are a fraction of an inch from it all the time and the switch doesn't take much pressure to activate. Charles Rowbotham wrote: > > It reduces your work load and is comfortible. > >Our switch lay is as follows: > > Top - Center - Coolie hat (Trim - Elev and Airl) > Left - Flap ( Toggle - momtenarty > Up and Down) > Right - Start button (relay req) > > -- Tom Sargent, RV-6A, engine ________________________________________________________________________________
Date: Oct 23, 2005
Subject: RE: Infinity grip and Van's flap position system
My under construction 8A will sport the same arrangement on an Infinity joystick grip as my flying 6A. I use the trigger for PTT, the coolie hat for 2 axis trim, and the toggle as a momentary flap switch. This simple arrangement allows one touch operation for all these functions and greatly eases pattern chores with the left hand firmly on the grip at all times. I highly recommend it. The necessary relays were all purchased from Van's. I have a UMA flap position indicator installed but in reality, rarely refer to it. Flap deployment is easily felt through the seat of the pants and working in concert with the AOA and airspeed indicator, the FPI is an option I will not likely install on the next project. Rick Galati RV-6A "Darla" 89 hours RV-8A empennage complete In an RV8 has anyone used infinity grip switches, Vans relay and Vans positioning system? Search of the archeives reveals nothing. Thought I would check before experimenting and possibly burning up some parts. ________________________________________________________________________________
Date: Oct 23, 2005
Subject: Re: Infinity grip and Van's flap position system
>Charles: > Having the starter button on the stick sounds like a great >convenience, but isn't there a fairly high chance of engaging the >started by accident in flight? My opinion is that any minimal perceived convenience is vastly overruled by the potential of damage if you hit it once the engine is running. Bad idea IMO. Ron Lee ________________________________________________________________________________
From: "Karen and Robert Brown" <bkbrown(at)ashcreekwireless.com>
Date: Oct 23, 2005
I friend of mine attached a fiberglass plenum on an -8A. He did it just as Dan described. Shortened the baffles a little, fit .032 angle around the perimeter of the baffles, laid up the plenum over the engine, drilled downward through the .032 angle, then installed nutplates on the bottom of the angle. Used screws and tinnermans on the plenum. Works great. (and looks great). I have the Airflow Performance Purge valve assembly on my 7A, and I too plan on installing a glass plenum, but I've had to do some re-thinking of the geometry of the purge valve arm and linkage to make it fit under a plenum...it will work! Bob Brown 7A - fitting lower cowl @$#%@# Darn that Ryton sump! My advice, think twice... ________________________________________________________________________________
Date: Oct 23, 2005
I also wanted a start button on the stick, to make it easier to start a fuel-injected engine when hot, without running out of hands. I was worried about the risk of hitting the button in flight, so I put another switch on the panel to enable or disable the switch on the stick. The panel switch is mounted right above the throttle, is guarded, and has three positions: Bottom - Starter switch on the switch disabled, Middle - Starter swtich on the switch enabled, Up (momentary position) - crank the starter. Wiring diagram: http://www.kilohotel.com/rv8/elec_sys_pdfs/ 2.1_Ignition,_Mag,_Starter.pdf Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 On 23 Oct 2005, at 11:57, sarg314 wrote: > > Charles: > Having the starter button on the stick sounds like a great > convenience, but isn't there a fairly high chance of engaging the > started by accident in flight? Your fingers are a fraction of an inch > from it all the time and the switch doesn't take much pressure to > activate. > > Charles Rowbotham wrote: > > >> >> >> It reduces your work load and is comfortible. >> >> Our switch lay is as follows: >> >> Top - Center - Coolie hat (Trim - Elev and Airl) >> Left - Flap ( Toggle - momtenarty > Up and Down) >> Right - Start button (relay req) >> >> >> ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Oct 23, 2005
> Our switch lay is as follows: > > Top - Center - Coolie hat (Trim - Elev and Airl) > Left - Flap ( Toggle - momtenarty > Up and Down) > Right - Start button (relay req) > > Trigger - Comm > > Left Side - Pulse Light - On or Off (Taxi & Landing > lights on full time) > > Bottom - Auto Pilot Disconnect What is the throttle hand doing while the stick hand is so occupied? I simply cannot see the risk/benefit of having the flaps on the stick (not to mention the complexity of a relay). The max flap speed on these planes is about half of what they can fly at. Why not put the (no relay required) flap switch where the throttle hand can actuate it? Another consideration is that one will want to be actuating the trim during flap movement in most landing cases, which could get interesting if that one hand is asked to do both while also flying the plane. About then the tower will ask you for something, requiring also transmitting... Regarding the starter, sooner or later, it will be actuated in flight if the button is on the stick. I know many will reply to this saying "it hasn't ever happened to me", but odds are that it will happen given enough flying hours on the plane. Please give this some thought, particularly go through complete "flights" while sitting at the mocked up panel/cockpit. Alex Peterson RV6-A N66AP 684 hours Maple Grove, MN ________________________________________________________________________________
Subject: Beaded end on aluminum tube
Date: Oct 23, 2005
I have to make new oil return lines on two cylinders,because they interfere with the wire holding bottom of the baffles. These aluminum tubes have a bead where it enters the hose to the crankcase. SEE http://www.mts.net/~ghinman/Bead.html What tool do I need to make these? George Inman Home 204 287 8334 Cell 204 799 7062 ________________________________________________________________________________
Date: Oct 23, 2005
The scres are certainly up to the task, but doesn't that make it a lot of work to take the plenum off? There must be 30 of them. If I was going to use fasteners like that, I think I would have to go with camlocs or dzus, or something that only takes a 90 deg. rotation. Karen and Robert Brown wrote: > >I friend of mine attached a fiberglass plenum on an -8A. He did it just as Dan described. Shortened the baffles a little, fit .032 angle around the perimeter of the baffles, laid up the plenum over the engine, drilled downward through the .032 angle, then installed nutplates on the bottom of the angle. Used screws and tinnermans on the plenum. Works great. (and looks great). > >Bob Brown >7A - fitting lower cowl @$#%@# >Darn that Ryton sump! My advice, think twice... > -- Tom Sargent ________________________________________________________________________________
Date: Oct 23, 2005
I failed proof reading 101. The list of positions on the panel mounted switch should be: Bottom - Starter switch on the stick disabled, Middle - Starter swtich on the stick enabled, Up (momentary position) - crank the starter. Kevin On 23 Oct 2005, at 12:59, Kevin Horton wrote: > > I also wanted a start button on the stick, to make it easier to start > a fuel-injected engine when hot, without running out of hands. I was > worried about the risk of hitting the button in flight, so I put > another switch on the panel to enable or disable the switch on the > stick. The panel switch is mounted right above the throttle, is > guarded, and has three positions: > > Bottom - Starter switch on the switch disabled, > Middle - Starter swtich on the switch enabled, > Up (momentary position) - crank the starter. > > Wiring diagram: > > http://www.kilohotel.com/rv8/elec_sys_pdfs/ > 2.1_Ignition,_Mag,_Starter.pdf > > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > On 23 Oct 2005, at 11:57, sarg314 wrote: > > >> >> Charles: >> Having the starter button on the stick sounds like a great >> convenience, but isn't there a fairly high chance of engaging the >> started by accident in flight? Your fingers are a fraction of an inch >> from it all the time and the switch doesn't take much pressure to >> activate. >> >> Charles Rowbotham wrote: >> >> >> >>> >>> >>> It reduces your work load and is comfortible.
October 05, 2005 - October 23, 2005
RV-Archive.digest.vol-ri
