RV-Archive.digest.vol-rl
November 23, 2005 - December 09, 2005
Ralph Capen
Subject: | Re: Dimpled skin and clecos |
In a message dated 11/22/05 9:59:40 PM Central Standard Time,
gerns25(at)netscape.net writes:
> While building the Horiz. stabilizer I have found that after dimpling the
> skin and the ribs, the 3/32" clecos don't hold for anything...the spring in
> the skin pulls them out of 90% of the holes.
Hi Darin-
The problem might be the clecos- I had two different brands and one would
consistently not hold as well as the other- might want to check this. If you are
drilling #40 and using the right dimple dies (sounds like it) it "should" be
fine- check the dimples by dropping a -3 rivet in the hole and see if it is a
good fit (flush at the head to skin surface). Also possible you are deburring
too deeply and enlarging the holes- make darn sure you don't deburr a
countersink on both sides of the hole so the edges meet in the middle and make
the
hole larger! Some builders use #41 bits for match drilling (self included),
provided the dimple dies fit OK without cracking the edges of the hole when
dimpling. This might help some, but I'd check the clecos first...
Mark Phillips -6A slobuild- flying
Subject: | Horizantal vs Vertical Induction Engines |
From: | "Valovich, Paul" <pvalovich(at)dcscorp.com> |
I'm at the engine selection stage of my -8A QB project. Pretty much
decided on a new IO-360. I've been very impressed by Vans, Superior and
Aerosport regarding engine options and customer support, but still have
an unanswered question:
Are there any performance / reliability differences between horizontal
and vertical induction engines?
So far the only answers I've gotten have to do with aesthetics -
removing the scoop - which begs the question: Is the aesthetic value of
a horizontal induction engine worth the $1800 jump in price (Aerosport)?
Seems to me there has to be other factors, but so far I haven't been
smart enough to figure them out.
I'm leaning toward Aerosport - dealing with them just feels right.
Anyone have any goods or others comments on their Great White North
experiences?
Paul Valovich
"Booger"
Ridgecrest, CA
I had that problem with my 6 and found out that the money I saved buying cheap
clecoes cost me in the long run. Buy the good clecoes from Van's or Avery. Also,
after building the 6 I found that the dimple dies from Avery were the best.
My neighbor drills his holes with a 3/32 drill instead of #40 and doesn't
have this problem. I don't recommend it if you are short on patience because
getting the cleco in before the skin is dimpled is a PITA.
Subject: Re: RV-List: Dimpled skin and clecos
Darin, occasionally I had that problem but it would only be about 1% of the
holes. Dimpling definitely makes the hole larger though. Are you using tank
dimple dies from Cleveland, they will make a larger hole?
Greg
RV8
> I checked the archives for information on this subject but found none.
The problem I am having is this:
the skin pulls them out of 90% of the holes. I match drilled all the flush
rivets using the #40 bit and dimpled everything using the 3/32" dimple die
set. The holes are just a hair too large for the clecos. Has anyone else
had this problem? Another thing, it seems as though this only happens in
the ribs (thinner material), the rear and forward spar don't have the
problem. I dimpled this stuff with my pneumatic squeezer if that makes a
difference. I know there is not a whole lot I can to about it now but can
someone give me some advice for the future skins?
> Darin Hawkes
> RV7 Empennage
> N619PB reserved
> Try the New Netscape Mail Today!
> Virtually Spam-Free | More Storage | Import Your Contact List
> http://mail.netscape.com
Subject: | Dimpled skin and clecos |
From: | "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> |
I've run into this before. With tools like a pneumatic squeezer or,
in my case, the DRDT-2 dimpler it is possible to over dimple. When you
over dimple a hole it will enlarge it just enough so the cleco won't
hold. The dimple looks fine but the cleco tends to pop out. Back off
your dimple sets a little and the problem should go away.
Michael Sausen
-10 #352 waiting on fuselage
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of
Subject: RV-List: Dimpled skin and clecos
the skin and the ribs, the 3/32" clecos don't hold for anything...the
spring in the skin pulls them out of 90% of the holes. I match drilled
all the flush rivets using the #40 bit and dimpled everything using the
3/32" dimple die set. The holes are just a hair too large for the
clecos. Has anyone else had this problem? Another thing, it seems as
though this only happens in the ribs (thinner material), the rear and
forward spar don't have the problem. I dimpled this stuff with my
pneumatic squeezer if that makes a difference. I know there is not a
whole lot I can to about it now but can someone give me some advice for
the future skins?
Darin Hawkes
RV7 Empennage
N619PB reserved
Paul:
The Horizontal Induction can also be called "Cold Air Induction". All the
Lycoming manuals say that there is a 1% increase in horsepower for every 10
degree F drop below standard temperature.
The vertical induction goes right through the oil sump. There is in theory
some heat transfer from the oil to the induction air / fuel mixture. For
every 10 degrees F that you lower this temperature, there is a 1% increase
in horsepower.
With a carb, I prefer the vertical induction. With fuel injection, the
horizontal or cold air induction SHOULD give you a more tuned intake with
less resistance to the flow of air and a cooler air charge for each
cylinder. In theory the horizontal induction will provide more horsepower.
The design of the filter in front of the intake system also has some effect
on the induction system. The "Snorkel" sold by Van does not have the
manifold pressure gain that the FAB or RAM air intakes claim to have. In
actual flight, does this report 0.5 to 1.0" MP gain really make much
difference?
My O-320 is an updraft (vertical) carb. The replacement IO-360 I am looking
at is planned to have horizontal (cold air) induction.
Gary A. Sobek
1,814 + Flying Hours So. CA, USA
http://SoCAL_WVAF.rvproject.com
----Original Message Follows----
Subject: RV-List: Horizantal vs Vertical Induction Engines
Date: Wed, 23 Nov 2005 10:34:57 -0500
experiences?
Paul Valovich
"Booger"
Ridgecrest, CA
Please change my address:
old address: mimartin(at)sweetwaterhsa.com
New address: mimartin(at)wyoming.com
Thank you
Mickey Martin
Subject: | Re: Horizantal vs Vertical Induction Engines |
Hi Paul,
AeroSport Power is easily among the most highly regarded companies. Bart is
very customer conscious and he enjoys very high recommendations from his
customers around the world.
I have yet hear of or meet anyone that has regretted doing business with
him.
Jim in Kelowna, in the great white North - Prepping the fuse for paint
--- Original Message -----
> experiences?
> Paul Valovich
> "Booger"
> Ridgecrest, CA
Subject: | Re: Fw: Re: AeroElectric-List: GX60 internal battery |
-----Forwarded Message-----
Subject: Re: AeroElectric-List: GX60 internal battery
Just called Garmin-AT - got lucky.....
There is a difference between dead battery and needs service....the needs service
indicates that the unit is charging the battery and could vent into the system.
If the battery was dead I would have gotten a different error message.
According to the service technician......
Good news is that since my airplane has not flown - it is still covered by warranty...great
- allows me to test prior to first flight.
Ralph Capen
RV6A N822AR N06 90% 90%
Subject: AeroElectric-List: GX60 internal battery
--> AeroElectric-List message posted by: "Ralph E. Capen"
Fellow listers,
I am getting an error message stating that my internal battery needs service in
my GX60. The unit continues to function - I just have to press the msg button
every few minutes.
This only started since I upgraded the datacard - that may be coincidental though.
Anyone else seen this? Is it home-repairable...with the correct battery? I have
done some miniature soldering so I could probably do it......
The archives show some of the portable units needing a similar repair - being done
by the owner. Sure would save some RV gas money!
Ralph Capen
Subject: | Re: looking for potential exhaust systems |
Very happy with
http://www.aircraftexhaust.net/
Check out the 4 into 1
Tell them RV-7 George (custom 4 into 1) sent you.
They make custom exhaust and have off the shelf.
They have very efficent heat muff technology and I think
they not make a muffler (sound) heat muff (heat) combo.
George
George,
Is yours a 7A.....?
I looked on their site and have had numerous exchanges with them. They would need
to do a custom for me - I have a 6A and AFP injection.
Doing the research for now.
Ralph
Subject: RV-List: Re: looking for potential exhaust systems
Very happy with
George
Subject: | 912ULS Spark Plugs and Oil Filters |
Does anybody know of a cheap place to buy spark plugs and oil filters for the Rotax
912ULS engine?
Jim
Jim Pellien
Mid-Atlantic Sports Planes
www.MASPL.com
703-313-4818
jim(at)sportsplanes.com
---------- Original Message ----------------------------------
Date: Wed, 23 Nov 2005 11:06:53 -0800 (PST)
>Very happy with
> George
Sent via the WebMail system at Engage IT
Subject: | Re: 912ULS Spark Plugs and Oil Filters |
In a message dated 11/23/05 2:47:46 PM Eastern Standard Time, jim(at)pellien.com
writes:
> the Rotax 912ULS engine?
Oil Filter:
If my memory serves me....a Fram PH3614 is the one you need
or you can even cross it over to other brands. A 4 cyl Chrysler K-car
I think is the application .
Do a search on Google.com to be sure.
RV-4
RV-8 QB .... Fuselage
Sal Capra
Lakeland, FL
My Home Page
I don't know the exact plug you're looking for, but I'm pretty sure Spruce
sells 'em. http://www.aircraftspruce.com/catalog/eppages/ngk.php
The best deal I found on NGK spark plugs (if that's what you're after) was
at Rock Auto. http://www.rockauto.com/ That was as of a few months ago.
)_( Dan
RV-7 N714D (693 hours)
http://www.rvproject.com
Subject: RV-List: 912ULS Spark Plugs and Oil Filters
> Jim
> Jim Pellien
> www.MASPL.com
> 703-313-4818
> From: <gmcjetpilot(at)yahoo.com>
> >Very happy with
> > George
Subject: | Re: polished/painted airplane pics |
(not processed: message from valid local sender)
Those half paint/half polished RV's look pretty good, never seen one before. Probably
a lot of maintenance though...
- Matt
Date: Tue, 22 Nov 2005 11:59:55 -0500
Subject: Re: RV-List: polished/painted airplane pics
> On 11/22 7:56, Evan and Megan Johnson wrote:
> > I spent the weekend going though tons of RV websites looking for
> polished planes.....found very few. Just wondering if any of you guys
> can narrow the search for me. I just wanted to get some pictures to use
> as inspiration for paint schemes. There was an RV 8 I saw at Vans
> homecoming last year that was red on the front and had a polished
> tailcone...very pretty. Also for those who have not seen it check the
> link below to a picture of Jon Scholl's paint job.......its in the
> completions section on Vans site.
> http://www.vansaircraft.com/images/first_flight/Scholl_lg.jpg Too cool,
> but maybe bad Ju Ju :)
> I saved a bunch of images that I liked that were half paint half
> polished aluminum, they can be found here.
> http://www.rv7-a.com/paintschemes
> Walter Tondu
> Flying!
I recently picked up my TMX IO360 from Mattituck who were great to deal
with. With the Horiz. induction the air charge does not pass thru the hot
oil in the sump
therefore the air is colder resulting in greater performance. Give Mahlon a
call at Mattituck he sure knows his stuff.
Rob Enos
Westport, MA
> experiences?
> Paul Valovich
> "Booger"
> Ridgecrest, CA
From: | "Evan and Megan Johnson" <evmeg(at)snowcrest.net> |
Subject: | Re: polished/painted airplane pics (not processed: message |
Only half as much as you would expect :) I love the polished look but have
never been willing to put the effort into the maintenance. I just thought
that the mixed paint/polish scheme may be more manageable. There are some
beautiful planes out there! You guys rock......thanks for links...
Evan Johnson
www.evansaviationproducts.com
(530)247-0375
(530)351-1776 cell
Subject: Re: RV-List: polished/painted airplane pics (not processed: message
before. Probably a lot of maintenance though...
> - Matt
> From: Walter Tondu <walter(at)tondu.com>
> > Walter Tondu
> > Flying!
From: | "Mannan J. Thomason" <mannanj(at)alltel.net> |
Subject: | List Contributions |
List:
Matt's doing a fabulous job. I've made my pitifully small contribution to
the list. (I'm retarded----uhh---retired.) Please guys, if you think this
is worthwhile, give a little.
mannan
From: | "Steven DiNieri" <capsteve(at)adelphia.net> |
Darin, the first thought is that maybe your deburring too aggressively. I
cant remember any clecos pulling through dimples unless I've drilled out a
bad rivet. If your certain the bit is #40 take a mic and check for mislabel.
Steve dinieri
N221rv
N231rv
I checked the archives for information on this subject but found none. The
Darin Hawkes
RV7 Empennage
N619PB reserved
Subject: | Fuel cap engraving....Going cheap costs more |
I saw a nice fuel cap engraving on Dan's website and mentioned it to another
RV pilot who will remain nameless. This anomalous RV pilot suggested finding
a local engraver to do it so I looked around and found one.
This morning I took it in with a picture of the end result and got the cap back
several hours later. Not good. The engraving is nothing like what Bill
Esther
can do and is slightly offset. When discussing the fiasco (I seem to have
those)
with "what's his name" we both noted that the good job looks like a router type
cut as opposed to my cheap engraving pencil look.
I just looked at the website again and apparently it is CNC engraving:
http://www.rvproject.com/esther_engraving.html
So in trying to save a few bucks I effectively cosmetically ruined a fuel cap.
Of course it is not "you know who's" fault. In retrospect I did have subtle
indications that the job would not be what I wanted but it did not make it to
my "take the cap and run" brain synapses. I should have listened to Dan's
advise. Bad Ron bad.
Ron Lee
Subject: | Re: List Contributions |
On 23 Nov 2005, at 22:47, Mannan J. Thomason wrote:
> List:
> contribution to
> think this
The info I've gleaned from the list has saved me thousands of
dollars, and many hours. My RV-8 will be a much better aircraft
because of this list.
I've also made a bunch of new friends, and it is interesting to track
them down when I travel.
Ottawa, Canada
http://www.kilohotel.com/rv8
If the drill bit is a #40 check your dimple dies and make sure you are using
the right size.
Mike Harris
Subject: RE: RV-List: Dimpled skin and clecos
> mislabel.
> Steve dinieri
> N221rv
> N231rv
> The
> in
> flush
> Darin Hawkes
> RV7 Empennage
> N619PB reserved
Carbs are different if you are not using fuel injection.
Subject: Re: RV-List: Horizantal vs Vertical Induction Engines
> Hi Paul,
> is
> him.
> From: "Valovich, Paul" <pvalovich(at)dcscorp.com>
> To:
>> experiences?
>> Paul Valovich
>> "Booger"
>> Ridgecrest, CA
From: | Darrell Reiley <lifeofreiley2003(at)yahoo.com> |
I would say mislabel or wrong bit. I would even double check the cleco. I had that
problem before on a batch of used clecos I bought... odd sized.
Darrell
the right size.
Mike Harris
> mislabel.
> Steve dinieri
> N221rv
> N231rv
> The
> in
> flush
> Darin Hawkes
> RV7 Empennage
> N619PB reserved
From: | Charlie England <ceengland(at)bellsouth.net> |
Subject: | Re: Tip Light Indicators |
Fiveonepw(at)aol.com wrote:
>Howdy List-
>Occasionally one of my brain farts turns into something I think is pretty
>cool and I'd feel bad if I didn't share with y'all- if you don't like the little
>plexiglass blades (or other means) of telling if your tip lights are on,
>here's something that is embarrassingly cheap and easy to do- see:
>http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=7883
>Have fun!
>>From The PossumWorks in TN
>Mark -6A N51PW, 250 hours
This list is fun, but an occasional (too rare) nugget like this is what
homebuilding & this list are really about. You've shamed me into
whipping out my credit card for a donation.
Thanks, Mark
.Problem....." I match drilled all the flush rivets using the #40 bit and
had this problem?"
My experience building old, drill your own RV kits has made these points
obvious....
I bought my cleco's in about 1998 so things may have changed but most
builders had the same problems of insecure holding clecos and it is
normally the clecos. Cheap clecos from ATS and US Tool which were .02
cheaper than Avery and Cleaveland had tips that were not shaped as
consistently well. Brand name Clekoloc - USA were then sold by ATS/US Tool
and Wedgeloc was sold by Avery/Cleaveland. You can tell the difference as
the cheaper units have to be "tipped" into the hole since the tips do not,
when extended, close together to shape a "point" but rather just extend
leaving the builder to "tip" or force the prongs together to enter the
hole. There may be other brands but these are the only ones I know but I
do keep them segregated as the difference in performance is very noticeable.
Now for "popping" out of dimpled holes. The higher $$ clecos did better
but sometimes they did let go especially when doing high vibration jobs.
The cheaper clecos had a lower percentage of them that actually held
because the tips were not CONSISTENTLY well formed. Sometimes I could get
them to grip better by retracting the pin and turning them in the hole 90
degrees other times I place a scrap piece of aluminum just drilled, not
dimpled, behind the assembly to act as a washer to provide better gripping.
I have tried drilling the hole to # 41 (even #42) instead of #40 and found
problems with this. IF the dimple die enters this reduce hole with no
interference then okay but IF the dimple die is press fit or friction fit
then there is a problem. Examination with a strong magnifying glass will
show a slight cracking around your hole meaning stress risers have been
induced by forcing the pin of the dimple die into a tight undersize hole
meaning your deburring process was just ruined. The standard #40 hole
doesn't do this. Every builder should have a small cheap magnifying glass
handy to occasionally check work for stress risers which should be our goal
to eliminate. The rivet in a #40 hole which has been dimpled will have
extra play in the hole initially but after one blow with the rivet gun or,
if using a squeezer, the very first part of the squeeze, will cause the
entire rivet from head to shop end to expand filling the hole entirely.
Now continued driving of the rivet will produce the nice shaped shop head
we all strive for. So choosing the hole as #41 or #40 is more dependant on
the dimple die you have than the rivet but the whole process is designed
around #40 holes.
You can also have all the holes perfect and the when squeezing the dimple
die into the hole cause a crack or an oval hole if the squeezer side frame
runs against a rib or bulkhead. The leverage here is very great and the
thinner sheet will actually give rather than move the stationary rib
causing small cracks around one side of the hole. So be careful with the
squeezer when dimpling in tight fitting areas. The magnifying glass will
show the stress risers but the naked eye will miss them. I know of two low
time RV4's with cracks around screw holes at the fiberglass wingtip attach
points.
Blue Skies and happy riveting
Dick DeCramer
RV6 N500DD
100 Hours
Minnesota
Subject: | Printer labels with white ink |
I have a medium grey panel and need white letters on clear labels to note
functions. Who makes a white ink cartridge for what printer so I can
make some labels?
Jim Nelson
RV9-A (wiring done, on to the canopy)
I was just reading these series of emails on this subject. So if someone has
already mentioned my suggestion, please pardon my repetition.
I saw on the Orndorff videos where he mentions using 2 short blasts of the
air drill when going in out of the holes for final drilling skins to ribs
and spars. Anything longer than a short "in and out" drilling session could
make the holes larger than desired.
Have a good turkey day, ya'll!
Smitty's RV-9A
http://SmittysRV.com
Jim...
I labeled my panel with a cheap battery operated "Brother P-Touch" label
maker and they had a cartridge with clear mylar tape and black and white
lettering which I had to order through "Viking Office Supply" at
www.viking.com . I think the tapes cost more than the machine. Due to my
font size requirements it took 2 cartridges to get all my labels made for
the entire airplane. The only negative is you must have very clean hands
and tools as any dirty prints on the sticky side of the clear label will
show through the label after it is in place. I used an Exacto knife and
stuck the label just in the tip of the blade and transferred it to the
panel. It looks very professional considering the low cost.
Dick DeCramer
RV6 N500DD
100 Hrs.
Faribault, MN
> make some labels?
> Jim Nelson
It continues to amaze me that some of our brethren will not blink twice when
spending 60-70k or more to buy and finish an RV, Lancair, or Glasair and
then wimp out when it comes to finishing the panel. What every pilot looks
at most of the time he's in his pride and joy.
The cost to get your panel professionally engraved is less then most of you
think.
FMI: www.engravers.net
Bruce
www.glasair.org
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dick DeCramer
Subject: RE: RV-List: Printer labels with white ink
Jim...
Dick DeCramer
RV6 N500DD
100 Hrs.
Faribault, MN
> make some labels?
> Jim Nelson
INNOCENT GLOBAL 0.0000 1.0000 -4.4912
I have a lot of subscriptions. My Wall Street Journal costs about $175 a
year; the Seattle Times another $135 or so. Then there are the business and
professional magazines, and the science and technology and political
periodicals, and the flying related magazines such as AOPA Pilot, EAA's
Sport Aviation, Plane & Pilot, Flying, Private Pilot, GA News, Kit Planes,
Light Plane Maintenance, and a few others that I can't think of at the
moment.
The point is that I spend well over a thousand dollars a year on newspaper
and magazine subscriptions, and none of them come close to giving me the
immediately useful information and entertainment that I get from just the
few of Matt's lists that I subscribe to. AOPA Pilot doesn't tell me as much
about flying experimental airplanes as just a few of test pilot Kevin
Horton's posts to the RV list do. Kit Planes doesn't come close to telling
me as much about building an RV as Sam Buchanan's or Dan Checkoway's web
sites do, which of course I would never have known about had it not been for
Matt's RV list. But I think the most impressive service that Matt brings to
us is Bob Nuckolls on the Aeroelectric list. I am constantly amazed at the
solid knowledge and patient good will that Bob brings to us about wiring
little airplanes, and he does it for free. I have learned much more from Bob
than the aeroelectric list name would suggest.
I may not have had the fortitude to keep plugging along on the great project
had it not been for the help and inspiration I get from reading the posts
from you guys who have gone before or the many who have started after and
already passed me by.
So let Matt know that he makes your life better. Send him some money, and
sleep soundly with a clear conscience, knowing that you have done your part
to support truth, justice, and the airplane builder's way.
Terry
RV-8A #80829
Finishing?
I promise it will fly someday.
Subject: | Re: Horizontal vs Vertical Induction Engines |
Note- Subject line changed to correct spelling of "Horizantal" to horizontal
for the sake of future seekers of archive info.
Subject: RE: RV-List: Horizantal vs Vertical Induction Engines
Where do you buy engine bolts?
These are like AN bolts but with
course threads.
I need 1/4" bolts to attach the crank
sensor of my lightspeed ign. to front
of the lycoming O360
George Inman
Subject: | Re: Engine bolts |
George,
You can get these from Aircraft Spruce. The coarse thread bolts are
listed in the paper catalog with the engine parts (carb bolts I think).
They aren't shown with the rest of the standard fine thread AN hardware in
the catalog.
Charlie Kuss
> course threads.
>George Inman
Subject: | Re: Printer labels with white ink |
You can do it with Ptouch (White of Clear). I've played with it but havent
done it yet.
Good Luck,
Bob Christensen
RV-8 Bldr - SE Iowa
> make some labels?
> Jim Nelson
Most of the responses seem to focus on drilling or deburring as the culprit,
but for me it is only after dimpling that I've run into 'loose cleco'
syndrome, luckily only on a small percentage of holes so I just move the
cleco to the hole above or below.
Maybe overly aggressive deburring causes the problem, but doesn't manifest
into a fit issue until it's mashed in the dimple die? Sounds like an easy
experiment.
Now the next question. How are the shop heads on those rivets in the loose
holes?
Subject: | Folding Bikes, Go-ped Elect Scooter |
Considering what's the best way to get around after landing. From my research
between folding bikes, gas go-peds and elect scooters the winner seems to
be the folding Bike. The question is what brand, model and where to buy. I want
something that is light (20lbs or less) and compact (fit in a RV7 slider).
Any one flying a folding bike in their RV? Can you get two into the back compartment?
Here are some examples: (Price from $300-$1,000)
http://www.dahon.com/prestolite.htm
http://www.dahon.com/folding-bicycles-us-alpha.htm
Go-ped / gas scooters don't seem to be a good choices from what I heard. They are
very loud and attract a lot of unwanted attention and many places outlaw them.
Also the small wheels get caught in cracks, not to mention dealing with a
gas/oil tank in the cockpit. Semi-dangerous, but looking for input.
Electric scooters are too heavy (+40lbs) and have limited range. That leaves Bikes.
The big down side of the folding bikes is the cost. The quality light weight
ones are expensive. Unless the technology catches up this does not seem practical.
Any comments welcomed. Experiences good bad?
Thanks George
I'm thinking about the same engine with maybe the Fadec option and trying to
decide if its worth the extra cost!
Randy Utsey
D.J. Distributing Co.
1429 Bryant St.
Charlotte, NC 28208
800-585-4126
djdist(at)bellsouth.net
www.djdist.com
> oil in the sump
> a
> Rob Enos
> Westport, MA
> To:
>> experiences?
>> Paul Valovich
>> "Booger"
>> Ridgecrest, CA
From: | "Steve Struyk" <rv8striker(at)hotmail.com> |
Jim,
Go to your local Office Depot or similar store and look at the Brother Label
makers. They are available in several models and all have the ability to
change the size of the tape, fonts, color of the tape (including clear) and
color of the ink.
It's one of the things I wish I had purchased early in the project. It's
great for labeling your parts drawers, wires, and yes one's panel if you
wish. True, the clear tape is slightly visible around the edges of the print
but I found on my panel, also gray, it's not that big a deal. Just my two
cents worth.
Steve Struyk
RV-8, N842S
St. Charles, MO
Final inspection next Wednesday!
Subject: RV-List: Printer labels with white ink
> make some labels?
> Jim Nelson
Subject: | Re: Folding Bikes, Go-ped Elect Scooter |
research between >folding bikes, gas go-peds and elect scooters the winner
seems to be the folding Bike. The >question is what brand, model and where
to buy. I want something that is light (20lbs or less) >and compact (fit in
a RV7 slider).
compartment?
I have a pair of these:
http://www.dahon.com/marinerd7.htm which I purchased from:
http://brandscycle.com/site/itemdetails.cfm?ID=2735&Catalog=39&sort=Price
I fly with these in a larger airplane and have doubts that they will go into
the baggage compartment of your plane. They are a great choice for folding
bikes though and we fly with them often. I did a lot of looking and am
really happy with the quality of this bike. At the time Brands Cycle had
the best price. I gave you a link to the carrying case and would highly
recommend that you get one for each bike. It will protect both the bike and
interior. I have to stack one bike on top of the other in the back of my
plane, they are too tall to fit side by side. The smaller bikes that you
were looking at might fit the baggage compartment of a seven. The smaller
the wheel size though the poorer the bike will perform on the road. I like
to fly into small airports without services and find that I end up using
mine on rural two lane roads that have limited shoulders. Having larger
wheels can make a difference, and even the 16" wheels on the Mariner are
marginal. I'm hoping I can get at least one in the baggage compartment of
my six. Good luck with your choice. I sure enjoy these.
Recently someone posted that they carried folders in the back of their RV.
I hope they see your post and give us the details.
From: | "Larry Pardue" <n5lp(at)warpdriveonline.com> |
> compartment?
George,
I'm a big fan of the British Brompton, which I have been using for years
after trying a few other folders. It is about as compact as they come and I
am suspect it is the quickest and easiest of all folders to fold. It looks
to me like two would fit easily in the baggage compartment of a 6 but I have
not had the opportunity to try it. There could be a problem with "breakover
angle" getting it in.
The Brompton is very well built and rides well, but probably not nearly as
well as the, more difficult to fold, Bike Fridays. The Dahons used to be of
rather low quality and heavy, but it appears they have greatly improved. I
have not used any of them.
http://www.bromptonbicycle.co.uk/index.cfm?fuseaction=bikerange.bikerange
http://www.foldabikes.com/
http://www.landofenchantmentflyin.com/
One of the neat things about the Brompton is that it is so small that, with
the optional nylon cover, you can carry it into a restaurant as a large
valise and no one notices it or objects.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
http://n5lp.net
>>> compartment?
Oops, in my previous post I didn't notice how Doug Reeves' links work. This
should be better.
http://www.vansairforce.net/photography/loe3/loe3pictures.htm
There is a picture of me on my Brompton and a picture of Doug's Brompton in
his 6's baggage compartment.
Larry Pardue
I spotted these in London last week and hope to put one in the back of my
8...http:www.bromptonbicycle.co.uk , I'll get the cheapest and lightest, saw
lots of them and they seem to work quite well.
Ralph in Tsawwassen
RV8 QB just starting
Subject: RV-List: Folding Bikes, Go-ped Elect Scooter
> research between folding bikes, gas go-peds and elect scooters the winner
> seems to be the folding Bike. The question is what brand, model and where
> to buy. I want something that is light (20lbs or less) and compact (fit in
> a RV7 slider).
> compartment?
> They are very loud and attract a lot of unwanted attention and many places
> outlaw them. Also the small wheels get caught in cracks, not to mention
> dealing with a gas/oil tank in the cockpit. Semi-dangerous, but looking
> for input.
> leaves Bikes. The big down side of the folding bikes is the cost. The
> quality light weight ones are expensive. Unless the technology catches up
> Thanks George
George,
I flew a borrowed folding Dahon to a jobsite a few times this year in
our tip-up 6a. Unwilling to dismantle it, I was unable to get it over
the seatback brace and wound up strapping it into to copilot seat with
the stick and cushions removed.
My 6 project has the slider with tip-up mod which allows much better
access to the baggage compartment. You can get a bike in easily. I
haven't had two bikes to try it with, but it looks tight.
I'd like to try one of those full sized Montague folders, but I really
doubt two of those would go.
Pax,
Ed Holyoke
compartment?
Thanks George
From: | "Trevor Mills" <millstrj(at)ozemail.com.au> |
Subject: | Venturi and Drag ? |
After buying a vacuum A H, I have just ordered a Eggenfellner engine. I would like
to use what I have in the way of instruments.
Can anyone tell me about the amount of drag from a 4" Venturi, I have only ever
seen one RV with one, ( Australia) is this because the drag penalty is just too
great ?
Trevor Mills 80605
Quoting Larry Pardue :
> > compartment?
> George,
> Larry Pardue
> Carlsbad, NM
> RV-6 N441LP Flying
> http://n5lp.net
> But is the price for that? Can be as good as the one at Waltmart?
thanks
bert
From: | "Glen Matejcek" <aerobubba(at)earthlink.net> |
> Hi Paul,
> is
And, if memory serves, one of those happy customers is Jon Johanson, who
has flown one of Bart's engines around the world. Three times...
Glen Matejcek
Subject: | Re: Venturi and Drag ? |
Trevor:
It is not a terrible idea and I went thru the research I can share with you.
I did decide to go a different direction but it is an interesting idea. The drag
for a 4" unit is only going to be about 1.5 mph at 200 MPH and that is a
good guess. It could be less.
I thought the same thing and looked into it. There was actually some research
technical notes done by NASA in 1948. I have a PDF copy if you want. They
looked at 6 Venturi tubes 3 small, 3 large. To answer you question a quick
look makes it look like the small one is worth 0.5 mph drag at 200 mph. The
Large one was about 1.5 mph drag at 200 mph.
The small measures about Length x Dia of mouth = 6.375" x 1.75"
The large measures about Length x Dia of mouth = 10.5" x 3.1
The small is what I think today is a 2" unit, and the large a 4" unit. The paper
shows they produce more than the base rated value depending on speed and
altitude. I am guessing at 190 mph the out put will be much higher, since
these things where made and tested for only about 100-135 mph. Based on
there drag info at 100 I could extrapolate to 200 mph acuratly and that is
where I got the drag numbers above.
Besides looks and drag the large one will need a regulator and filter and
the smaller 2" may or may not be enough to drive a Attitude indicator. I
like the 2" because of less drag and you may not need a regulator if used
with a DG or AI. They where made originally for just one T&B. However at
RV speeds it should be above 2"-hg suction. However it may drive one DG
well. The AI needs more flow than the DG.
I wanted a back-up non-elect gyro. I was interested in the small Venturi
driving either a AI or a DG. The cost of a Elect mechanical AI back-ups
are too high, but I decided to go another direction. The cost of solid state
Gyros have come down and feel they are sufficient; since I already have
a Dynon EFIS and a Navaid Autopilot. A unit like the TruTrak AI is a
good back-up to those two gyros, and it goes for about $1000 usd.
The drag and looks plus the new solid state units made this a no go for
me. Also after the Venturi you may need to buy, regulator, filter. Than
you need to buy the Vac instrument, which can be expensive and prone
to failure. By the time you are done you may be better to just by solid
state gyro, which has zero drag. Also if you are going to do real IFR
using the Venturi for your prime attitude flight instruments you have to
think of icing. OF course you should never get into icing, intentionally at
least. If you did get into ice, it could be bad news.
If you want to keep looking into adding a small or large Venturi let me
know exact size (dimensions) of the Venturi you want to use, may be
I can calculate the exact suction it will produce and predict the drag.
There are all kinds of Venturi designs so it may be hard to know exactly
but the manufacture may provide info, or you could flight test it. Great
idea even though I abadonded it; it will work, and DRAG is not a real big
deal. A VAC pump is a terrible thing. Expensive and they break. Plus the
carbon dust gets into the gyros and kills them. A Venturi is a pure thing
that works like a charm, but it just may be a little out of place on a slick
homebuilt like a RV (anachronistic I thinkn is the word).
George
Subject: RV-List: Venturi and Drag ?
would like to use what I have in the way of instruments. Can anyone tell
me about the amount of drag from a 4" Venturi, I have only ever seen one
great ?
Trevor Mills 80605
> engine. I would like to use what I have in the way of instruments.
> have only ever seen one RV with one, ( Australia) is this because
> the drag penalty is just too great ?
Let's look at an RV that will cruise at 190 mph TAS at 8,000 ft at
75% power with a 160 hp engine (Van's specs for the RV-6). 75% power
is 120 hp. If we assume a prop efficiency of 85%, that gives us 120
* 0.85 = 102 hp available to overcome drag. 190 mph * 5280/3600 =
279 ft/sec. Power required = drag times speed, so drag = power / speed.
The total drag = (102 hp * 550 ft-lb/s per hp)/279 ft/sec = 201 lb.
I can't find a drag coefficient for a venturi, so the best I can do
is treat it as a flat plate. Hoerner, in Fluid-Dynamic Drag, gives
us a drag coefficient of 1.17 for a circular disk (page 3-17) with a
Reynolds number between 10
4 and 10
6.
The frontal area of a 4" venturi would be 12.5 in
2 or 0.0868 ft
2.
The air density at 8,000 ft on a standard day is 0.00186 slug/ft
(http://aero.stanford.edu/StdAtm.html)
The drag from the venturi = 0.5 * density * V
2 * CD * Area.
The predicted venturi drag = 0.5 * 0.00186 * 279
2 * 1.17 * 0.0868 =
7.4 lb drag.
7.4 lb of venturi drag / 201 airframe drag = 3.7% drag increase. The
speed is expected to vary with the cube root of the drag. So a 3.7%
drag increase should lead to about a 1.2% speed decrease, or a loss
of about 2-3 mph.
Keep in mind that I have no idea what the real drag coefficient of a
venturi is. It may very well be higher than I assumed, but looking
at the CDs Hoerner gives for some fairly ugly shapes, I wouldn't
expect the venturi's CD to be greater than 2.5, which would give
about a 5 mph speed loss.
Ottawa, Canada
Another consideration for any engine in my oppinion would be Barrett
Precision Engines in Tulsa Ok. They build a lot of engines for the big air
show peformers. I believe they also build the IO-390X, a 210 hp engine
that Dick Martin has in his "fastest RV-8 in the world."
Mannan
RV-8 slo-build
This is really bizarre. My message, as sent, had a bunch of "caret"
characters (the one on top of the 6 key on many keyboards) to
indicate a number raised to a power. But, the message from the list
had the "caret" characters replaced by new lines.
After reading George's post, where he mentioned data from a NACA
report, I remembered that a 4 inch venturi isn't 4 inches in
diameter, if I recall correctly. I think the 4 inch refers to the
amount of suction produced at some specific speed. So, the diameter
will be smaller than I assumed, which means less drag. George has
actual test data, so his numbers are a lot better than mine.
Kevin
> * 0.85 = 102 hp available to overcome drag. 190 mph * 5280/3600 > 279 ft/sec.
> speed.
> 4 and 10
> 6.
> 2 or 0.0868 ft
> 2.
> 3
> 2 * CD * Area.
> 2 * 1.17 * 0.0868 > 7.4 lb drag.
> of about 2-3 mph.
> Ottawa, Canada
Trevor,
This is not a very good idea at all. I spent 30 years flying my Stinson
with venturi's and regardless of the looks and drag, the performance
won't be acceptable.
Venturi's were used with the old AN type gyros which were pretty
efficient because they were designed to operate from the venturi. The
newer type of instruments require the same 4" of vacuum but a lot more
air flow. When I changed out the old gyros for new, I had to use 2 9"
venturi's (without a regulator) just to get the required 4" of vacuum.
Back in the 40's a 9" venturi would run everything, including the T&B.
So you would have to use at least a 9" venturi which is REALLY big and
ugly (IIRC about 4" in diameter by 12 to 14 " in length).
Now keeping all this in mind, remember that you will NOT have any gyros
on takeoff or initial climb and the venturi is subject to icing.
Bottom line, don't go there. If you can't use a vacuum pump, sell the
gyro and get something electric. It's not worth trying to resurrect 70
year old technology when there are so many modern options.
Dave -6 So Cal
EAA Technical Counselor
too great ?
>Thanks
>Trevor Mills 80605
>Kevin
Kevin,
I remember reading somewhere that venturis started on the belly & moved
to the side of the fuse when mfgrs realized they could save a few feet
of tubing & some labor by mounting them even with the instrument panel.
Would mounting the venturi on the belly with its inlet ~even with the
firewall, so it's fed by the cooling air exit, have any effect on total
drag? I assume that the exit air isn't accelerated back to the full
180-200mph relative to the airframe, so would drag be somewhat lower? A
potential side benefit is the warmer air from the cowl without as much
moisture if flying in freezing conditions.
What do you think?
Subject: | Backup AI was Venturi and Drag ? |
Trevor,
It sounds as if you're trying to find a way to use your vacuum
instruments even though your engine of choice doesn't have a spot for a
vacuum pump. Probably your best bet is to E-bay your instruments and get
some electric powered ones. As others have pointed out, vacuum
instruments are the wave of the past in terms of reliability and
utility. The real question, for many of us, becomes how to reliably
backup an all electric panel.
The electric turn and bank/coordinator was a response to the reliability
concerns of air powered gauges. You don't want everything going belly up
at the same time. When all gauges are on electric power, it seems
prudent to have two (or more) sources of power for them with sufficient
capacity to operate them for the remaining duration of fuel. Trevor,
you'll be needing something like this anyway as your engine of choice is
electrically dependant. Check out the AeroElectric Connection for ideas.
You can also subscribe to the AeroElectric list for good discussions.
On another note, for those with vac pads on their engines, I've been
seeing ads for piston powered vac pumps from Sigma Tek. These will
supposedly be more reliable than the old style wet or dry pumps.
Pax,
Ed Holyoke
only ever seen one RV with one, ( Australia) is this because the drag
>Thanks
>Trevor Mills 80605
On Sat, 26 Nov 2005, Dave Bristol wrote:
> The newer type of instruments require the same 4" of vacuum but a lot more
> air flow.
I think Dave makes a valid point here. I've been flying a Navion with a single
venturi and it's not really adequate to drive the AI and T&B. The owner is
planning to add a second venturi.
But the Navion only cruises at 120 kias. The extra speed of an RV would
presumably give better performance from the venturi.
Tedd McHenry
Surrey, BC
Listers,
I have an RV-8 with mag left side and ElectroAir electronic ignition right side.
My mag went out on left side. I am considering putting in a P-Mag left side
to give me dual electronic ignitions but still keep the reliablility fall back
of a self generated mag if electrical/battery system were to fail. Anybody
have practical experience with the P-Mag, good or bad? Replies here or directly
by email. Thanks.
Stu McCurdy
Listers,
to give me dual electronic ignitions but stillkeep the reliablility fall back
of a self generated mag if electrical/battery system were to fail. Anybody have
practical experience with the P-Mag, good or bad? Replies here or directly by
email. Thanks.
Stu McCurdy
And another point made is why bother with such devices on an RV. Consider a
Dynon like system.
Ron Lee
You didn't say, so I'll guess. A Lycoming 360 with a fixed pitch wood
propeller?
Jim Ayers
In a message dated 11/26/2005 2:39:02 PM Pacific Standard Time,
sturdy(at)att.net writes:
Listers,
side. My mag went out on left side. I am considering putting in a P-Mag left
side to give me dual electronic ignitions but stillkeep the reliablility fall
back of a self generated mag if electrical/battery system were to fail.
Anybody have practical experience with the P-Mag, good or bad? Replies here or
directly by email. Thanks.
Stu McCurdy
From: | "Jeff Dowling" <shempdowling2(at)earthlink.net> |
How about using clear with black ink? You can buy it in standard 8.5 x 11
sheets at any office supply store and print in your own printer. I copied
this from someone else and it works great. Once it gets a little old, just
pull it off and use a new one.
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
> make some labels?
> Jim Nelson
Hi Jeff,
The problem is the grey I used on my panel is fairly dark so
black letters would not show up very well. I could use bold in the
script but still in the world of "grey scale", those colors are toooo
close together. White would be the choice, even a very light blue. If
night flying, white would show up the best under dim lighting. When the
dodo hits the fan when its dark outside, you need to do it right with no
confusion. I know, I designed it and built it so there should be
minimal confusion, but some day I'll sell it and the next guy will need
all the help possible. As I get older and slow down, physically and
mentally, I will need all the help I can get. It's a bummer getting old
and slow (not me!).
Jim Nelson
RV9-A QB (N599RV reserved)
Subject: | Re: RV-List Navaid Coupler with Panel Mount GPS |
I got a question yesterday about my Navaid Auto Pilot with Porcine GPS
Coupler and Panel Mounted GPS's.
I got my Garmin 430 to work with my Navaid after getting Porcine's latest
coupler update. The problem is that most panel mounted GPS's do not
transmit the NEMA RS232 data streams that are common to hand held GPS's -
rather they transmit a data stream called "aviation". The Porcine couplers
have worked well with hand held GPS's but not "aviation", that is until the
update that was made in 2004. I got around to getting this update this
summer and IT WORKS! The aviation data stream will need to be set to
"aviation - no altitude".
Ronnie Brown
Velocity N703MR
Subject: | Oil Cooler Issues |
I see that Van's recently added an oil cooler vent to its fine stable of catalog accessories. http://tinyurl.com/cc2ay
This suggests to me that my Lyc. equipped 6A is not alone in experiencing cooler
than desired oil temps. During the summer, even with ground temps flirting with
100 degrees, my stock baffle mounted oil cooler installation stabilized the
engine temperature at 170 degrees.
I added a "partial plate" to the rear of the cooler and managed to increase the
temp to 180 degrees...the recommended temperature as published in the Lycoming
operating manual.
Now, with much colder weather upon us, I had to block the rear surface of the oil
cooler completely off with a "full plate," yet the engine temperature only
rose to 154 degrees during a 40 minute recent flight. I then blocked off nearly
1/5 or so of the total forward surface area of the oil cooler with steel tape
just to bring the temp up back up to 178 degrees.
I happily ordered the new catalog accessory item and hopefully, its installation
will finally resolve those vexing cooling issues.
I'm curious as to how prevalent the problem really is. Anybody else on this forum
experience similiar cooling issues? After all, I know the new vent wasn't designed
with just my particular RV in mind.
Rick Galati RV-6A "Darla"
Subject: Re: RV-List: Printer labels with white ink
And I spray my inkjet printer decals with a clear spray can sealer afterwards.
They look good, and are easy to copy extras for future use.
I've used black as well as other colors for a few, and some have borders. I have
a gray panel, and even used a gray fill-in color to hide a scratch under the
lettered decal.
Subject: | Re: Oil Cooler Issues |
>cooler than desired oil temps. During the summer, even with ground temps
>flirting with 100 degrees, my stock baffle mounted oil cooler installation
>stabilized the engine temperature at 170 degrees.
I had a problem with too hot oil temps this summer. That was corrected by
improving the air exit flow. Now my oil temps are running slightly low so I
am considering such an oil cooler airflow restriction device. Take good Before
and after data so we can decide if it is worth it.
Ron Lee
From: | "Alex Peterson" <alexpeterson(at)earthlink.net> |
> experiencing cooler than desired oil temps. During the
> summer, even with ground temps flirting with 100 degrees, my
SNIP
> Anybody else on this forum experience similiar cooling
> issues? After all, I know the new vent wasn't designed with
Rick,
I put a throttle in the 3" scat leading to my firewall mounted cooler in my
O360 RV6A. I can control this with a knob on the panel. The only time I
see oil temps above about 190F is during a long climb in hot weather. When
OAT's are in the -10 to 40F range, I throttle the cooling air. (I don't fly
colder than -10F!) Anyway, when I don't throttle the oil cooler, temps
don't get above about 140 or less. Yesterday, I made use of the throttle
several times, as the ground temps were about 20F, while at altitude the OAT
was around 45F.
I can't speak to the effectiveness of Van's new kit, but some throttling is
generally necessary for anyone flying in the winter. Most RVers here put
plates or tape on and off each season - yesterday was an example of how big
a pain that can be.
Alex Peterson
RV6-A N66AP 694 hours
Maple Grove, MN
> latest
> GPS's -
> couplers
> until the
> this
I had thought it was possible to get the Navaid to work with the CDI
output from the GNS430. At least that is what I hope to do, whenever
I get my RV-8 flying. Is this not possible?
Ottawa, Canada
Kevin I was able to couple our KMD 150 (MFD with internal GPS) CDI output to
the Navaid autopilot and have it work.
You need to be pretty much on course or it will take a while "hunting". Of
course there may be some more gain adjustments that I need to do but the
bottom line is it does work.
Let me know if you need me to look up any details on it as tplane was
finished at the end of 2002.
James
RV6
599 hours
> > latest
> > GPS's -
> > couplers
> > until the
> > this
> Ottawa, Canada
This is an alternate email. Please continue to email me at
james(at)nextupventures.com .
Kevin:
Been working for 3 years with by GX60 connected to the CDI output. I did
need to program the GX60 to be 0.3 mile full scale deflection to get
acceptable tracking results.
Gary A. Sobek
1,818 + Flying Hours So. CA, USA
Subject: Re: RV-List: Re: RV-List Navaid Coupler with Panel Mount GPS
Date: Sun, 27 Nov 2005 09:33:03 -0500
Ottawa, Canada
Kevin, I have an EZ-pilot and GNS 430. You need the output of pin 56 and
the output setup as follows:
SETUP PROCEDURES:
1. CONFIGURE THE OUTPUT AS FOLLOWS:
A. ENTER THE SETUP MODE BY PRESSING AND HOLDING THE "ENT" KEY
WHILE TURNING ON POWER
B. SELECT THE "MAIN RS-232 CONFIG" PAGE
C. SET THE CHANNEL 1 OUTPUT FIELD TO "AVIATION"
I will send a file to you that documents this. Navaid may be different so ask
the right person.
Ron Lee
From: | "Dave & Brenda Emond" <d_emond(at)mweb.co.za> |
Hi Ron
Would be interested to here what you did??
Dave
Subject: Re: RV-List: Oil Cooler Issues
> I
> Before
> Ron Lee
Subject: | Titanium Tie Downs |
Just wondered if anyone knows anything about Randy Simpson who sells the titanium
tie downs. We've been trying to get him for a month now via phone and email.
We've paid for our tie downs over a month ago through Pay Pal and no response
and no tie downs. Sure would like to get some tie downs! Thanks for any
help!
Becki Orndorff
Becki, check the archives. This problem has been ongoing for months if not
years.
Alex Peterson
Maple Grove, MN
> Simpson who sells the titanium tie downs. We've been trying
> to get him for a month now via phone and email. We've paid
> response and no tie downs. Sure would like to get some tie
> downs! Thanks for any help!
> Becki Orndorff
<002301c5f37b$e1bb1b70$a4d217c4@davexp>
>Hi Ron
>Would be interested to hear what you did??
First thing I did was to \remove the cabin heat tubes that went
down to one heat muff..across the air exit path to another heatmuff
than back across to the inlet. That created resistance to air
leaving the bottom cowl.
Improvement about 6-8 deg C
Then I cut open the outer portion of the middle area of the lower cowl
around the exhaust...about 3-4 inches. About the same cooling
improvement.
Finally I added louvers on the bottom...same improvement.
After all three oil temps are no longer an issue. Somewhere I documented
the improvement with each change so the numbers above are best recollection.
Fact is that the high oil temp problem is gone and now I may need to put a
cooling air restriction device for winter ops.
Louver info here:
http://www.attawayair.com/rv6a.htm
This picture shows my louver and the opened area around the exhaust
after my plane was painted a manly navy blue:
http://home.pcisys.net/~ronlee/RV6A/Cowl_Louver_Small.jpg
Ron Lee
>writes:
>Oil Filter:
I have been warned by Rotax mechanics that substituting an
automotive oil filter for a genuine Rotax filter is not recommended:
the Rotax engine develops significantly higher oil pressures than
automotive engines, so you could unknowingly be bypassing your
filter via the high pressure bypass.
Regards, J.
built: Zenith STOL CH701/912 C-IGGY, 250 hrs.
building: Sonex #325, Jabiru 3300/6, 50% completed
Brandywine Aviation: N42 47.33 W081 36.50 13/31, 2400', 760'elev.
| J. Davis, M.Sc. (comp_sci) | *NIX guru, consultant |
| Research Programmer, SysMgr | email: jd at lawsonimaging.ca |
| Lawson Health Research Inst | voice: 519 6466100 x64166 |
| London, Ontario | fax: 519 6466399 |
| Canada | http://www.cleco.ca |
Everywhere is walking distance if you have the time.
--- Steven Wright
Subject: | Re: RV-List Digest: 14 Msgs - 11/27/05 |
Ron,
I must be missing something on this thread. Most panel mount GPS's don't even
require a Porcine Coupler to work with a Navaid. The Porcine Coupler was developed
so people could use handheld GPS's to drive Navaids. Panel Mounts, like
my Garmin XL 250 use the "+LEFT" and "+RIGHT" Indicator Drive Output directly
into the Navaid.
I would be interested to know what "course deviation sensitivity" people have
found to work best with a RV/Panel Mount GPS/Navaid Setup since this can be
set in the GPS Setup Screens.
Thanks!
Esten Spears, Leeward Air Ranch, RV8A, 80922, N922ES, - FWF
> From: "Ron Brown" <romott(at)adelphia.net>
> Subject: RV-List: Re: RV-List Navaid Coupler with Panel Mount GPS
> Ronnie Brown
> Velocity N703MR
I called Navaid and set what they recommended. It was a pretty small scale
but I forgot what it was.
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
Subject: RV-List: Re: RV-List Digest: 14 Msgs - 11/27/05
> Ron,
> don't even require a Porcine Coupler to work with a Navaid. The Porcine
> Coupler was developed so people could use handheld GPS's to drive Navaids.
> Panel Mounts, like my Garmin XL 250 use the "+LEFT" and "+RIGHT"
> Indicator Drive Output directly into the Navaid.
> people have found to work best with a RV/Panel Mount GPS/Navaid Setup
> since this can be set in the GPS Setup Screens.
> Thanks!
>> couplers
>> the
>> Ronnie Brown
>> Velocity N703MR
Subject: | Used O-470 Engine Parts |
Listers,
Have a friend with an airboat sporting an inop Cont O-470. Anyone have a
source of used (uncertifiable, out of spec, etc.) parts? My thought is we
can probably get this thing running well enough for use on the local duck
pond with throw-away (for aviation use anyway) parts.
Thanks in advance,
Mark
You need to have your mechanics explain to you the technical reasons why you
wouldn't substitute filters...I'll bet you they can't. High operating oil
pressures have nothing to do with bypass valve operation. Bypass valves for
filters are spec'ed by the filter manufacturers as a low number. This low
number is the amount of pressure *differential* from the inlet side to the
outlet side of the filter; in other words, across the filter. Once pressure
comes up, there should be little pressure differential.
I avoid Fram filters, there is plenty of information on the web regarding
which filters perform the best. Fram is always at the bottom of those
lists.
I use a Wix 51068 on my O-360, not the standard Champion 48110. It bypasses
at 8-11 psi. It has a anti-drainback valve which the 48110 doesn't. After
an oil change I can leave the filter over a cup to drain out for a few days,
once I cut it open I can dump 1/2 qt. of oil out of it. The benefit of this
is that there is always oil inside the filter, so during cranking it takes
less time for the galleys and filter to pressurize and fill with oil, which
has obvious wear benefits. On one oil analysis, Blackstone stated that the
numbers looked like what they see for 35 hr. oil even though my change
interval is 50 hours. The other great thing about using this filter is it
only costs $5.79, and judging by my past oil analyses, filters better than
the 48110. No there's no safety nut on it, and I am comfortable with not
having the filter safety wired.
Bob Japundza
RV-6 flying, F1 under const.
Hi Jim
The labels are TZ-S135 ,available on the Brothers Web site. I use the
P-touch 1180 labeler.
Dave Cook RV-6 Finish Kit N815DC Res.
> make some labels?
> Jim Nelson
Subject: | AN fittings basic info |
Howdy
Excuse my ignorance, but AN fittings are new to me, and I still have a few questions
after searching the archives and perusing AC 43.13
(1)Sounds like lubricants are off limits except for the pipe thread portions of
fittings, correct?
(2)Im confused about the proper technique for tightening fittings on flared tubing. I have found torque specifications, but how does one use a torque wrench on a fitting when the tubing coming out of it would prevent any socket from gong over it? Can I safely tighten these without measuring the actual torque applied? One archive post referred to installation instructions at http://avstop.com/AC/apgeneral/INSTALLATIONOFRIGIDTUBING/html, which talked about how many turns to apply after the nut begins to bottom. This only confused me, because while it talks about how far to turn the nut after it bottoms and cites common problems like the flare being distorted/cracked/out of round etc, it was all under a heading of "Flareless Tube Installation". Huh?
(3) AC 43.13 indicates that a "double flare" should be used for tubing with a diamter
of 3/8 inch and less. Whats a double flare?
(4)I have seen photos of bulkhead fittings where spacer washers are used. I there
a rule of thumb on when to use these? Do they go on both sides or just one?
Ignorance is not bliss in this case. My head hurts.
Erich Weaver
Subject: | Re: AN fittings basic info |
From my experience, tighten until they no longer leak! Not trying to be a
smart ass here but it is amazing just how tight they need to be in order to
not leak. It varies a lot from fitting to fitting, even though they are
"the same fitting" just different location. Remember your not building a
Swiss watch.
>Howdy
>questions after searching the archives and perusing AC 43.13
>portions of fittings, correct?
>with a diamter of 3/8 inch and less. Whats a double flare?
>I there a rule of thumb on when to use these? Do they go on both sides or
>just one?
>Erich Weaver
Scott Bilinski
Eng dept 305
Phone (858) 657-2536
Pager (858) 502-5190
If you want to use a torque wrench on AN flare fittings - fit a
"crowsfoot" extension to the square socket drive. You have to
recalculate the torque setting required as a factor of the
change in length of the torque wrench caused by the extension.
This is the same method you use on rod end jam nuts. There's a
section on this in that Advisory Circular published by the FAA
- I think its called "Acceptable Aircraft Repair Techniques" or
something like that.
The collective wisdom I've gathered on lube and AN fittings is
to use a teflon based paste on pipe threads only. Don't use
ANYTHING on flared fittings - the compression caused between
the 37 degree flared faces is sufficient for a gas/fluid seal.
As to torque settings for the flare fitting - I hope someone
else can enlighten - I haven't found anything so far ...
g
> Howdy
> have a few questions after searching the archives and perusing
> AC 43.13
> thread portions of fittings, correct?
> instructions at
> Installation". Huh?
> tubing with a diamter of 3/8 inch and less. Whats a double
> flare?
> are used. I there a rule of thumb on when to use these? Do they
> Erich Weaver
__g__
Gerry Filby gerf(at)gerf.com
Tel: 415 203 9177
Erich,
Here's what I learned from our company A&P many months ago. I can't
recall the reference.
-4 fitting: 40 - 60 inch-pounds
-6 fitting: 110 - 130 inch-pounds
Also, Dan has a torque calculator on his site when an extension such as
a "crow's feet" is used.
erichweaver(at)cox.net
Subject: RV-List: AN fittings basic info
Howdy
few questions after searching the archives and perusing AC 43.13
used. I there a rule of thumb on when to use these? Do they go on both
sides or just one?
Erich Weaver
Subject: | Hive mind sought on IFR training courses - OT |
Ok, everyone, I'm ready to better myself through the pursuit of an IFR ticket.
First step seems obvious: take ground school at home on the laptop with a CDROM
or DVD course, and practice with a flight sim that will emulate (or come close)
my RV-6A.
I'd appreciate recommendations based on firsthand knowledge to help guide my shopping.
I'd hate to buy a lemon off eBay when the List could have steered me
in a better direction. Looking for course, textbook and sim software & hardware
recommendations.
Thanks in advance. Off-list responses okay if you feel this is not of general/archival
interest.
-Stormy
erichweaver(at)cox.net wrote:
>Howdy
fittings, correct?
>Erich Weaver
Excellent questions Erich! You won't learn if you don't ask questions.
Since most of the other questions have been answered, I'll tackle #3. A
double flare is formed using a really spiffy tool. The end of the tube
is folded back into the flare which gives the flare double thickness.
Read extra strength. The small diameter tubing just doesn't have much
material to work with if you are only doing a single flare. I found this
picture which should help explain.
http://www.phi-tulip.com/images/flaredr.gif
Happy building
Mark
Subject: | Off -Topic: Traffic Patterns @ Private Aiports |
The following is not RV specific. Delete now if this offends you.
The HOA at a residential airport where I have purchased property wants to keep
traffic on one side of the runway. So the pattern in one direction will be right-handed
(non-conventional). My question(s) to those knowledgeable on the subject
are:
1) Does an HOA as the owner of an airport have control over a traffic pattern?
2) Does any airport that is privately owned have such control? I see many open-to
the-public but privately owned airports with notations on Sectional charts
for right traffic on certain runways. I have yet to see this on a Sectional chart
for private runways.
3) If a runway is uncontrolled, can't you fly any pattern you deem appropriate
(albeit at the risk of safety and the risk of irate people on the ground when
you land!)
Curious minds want to know. I don't have a beef with anyone over anything. I am
just interested.
Ivan Haecker -4 1209 hrs. S. Cen. TX
BTW the FAA publication I mentioned is:
US Department of Transportation Advisory Circular AC 43.13-1B
"Acceptable Methods, Techniques, and Practices - Aircraft
Inspection And Repair".
Its typical government speak, but its stuffed with excellent
information ...
g
> g
> > Howdy
> > AC 43.13
> > instructions at
> > Installation". Huh?
> > flare?
> > Erich Weaver
__g__
Tel: 415 203 9177
Chapter 5, page 117 of AC65-9A has the torque table for the AN fittings.
Google AC65-9A and select the 8th or 9th item on the list to find this
in PDF format (select chapter 5, then go to page 117).
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Gerry Filby
Subject: Re: RV-List: AN fittings basic info
information ...
g
> g
> > Howdy
> > AC 43.13
> > instructions at
> > Installation". Huh?
> > flare?
> > Erich Weaver
__g__
Tel: 415 203 9177
Subject: | Re: Hive mind sought on IFR training courses - OT |
I used king schools for private, instrument,
commercial, multi, and CFI/CFII. I like their
materials alot, and found them to prepare you quite
well for the written exam.
Microsoft flight sim is great for procedural stuff.
Get a CFII to teach you the basics of approaches and
such, and you'd be amazed at what a good tool it is.
Paul Besing
> pursuit of an IFR ticket. First step seems obvious:
> CDROM or DVD course, and practice with a flight sim
> that will emulate (or come close) my RV-6A.
> knowledge to help guide my shopping. I'd hate to
> steered me in a better direction. Looking for
> recommendations.
> feel this is not of general/archival interest.
> -Stormy
> Click on
> about
> provided
> www.buildersbooks.com,
> Admin.
> _->
> browse
> Subscriptions page,
> FAQ,
Access over 1 million songs. Try it free.
http://music.yahoo.com/unlimited/
From: | Alan & Linda Daniels <aldaniels(at)fmtc.com> |
I did it on the King tapes, pre DVD, with no problems. For me it was
much better to go to a school out of town and away from my business for
a couple days a couple times. This let me concentrate on what I was
doing without constant interruptions which would have made it very
difficult. . The learning curve is pretty steep, but when the light
finally came on - a very dim light- it all made sense.
RV-9 wings
Bill Schlatterer wrote:
>Stormy, having just "been there, done it" I can really say that it's a
http://www.x-plane.com
http://www.x-plane.org
The first site is the developer of the program. Top
notch flying characteristics. You can change any
weather perameter you wish. I have flown a G5 in
terrible thunderstorms, in the clouds and learned how
to hold course while getting tossed like tonights
salad. You are in contact with ATC (vocal/text to
you, text to ATC)at all times while IFR. Shooting
approaches into an airport setting the cloud deck at
200 feet test your mettle. Navcomm freqs are used,
HSI, CDI and any other alphabet instruments are
available. You can design the instrument panel to be
exactly like the plane you would be using for IFR
training. This program is not a game. It can be used
used for logging sim time toward an ATP rating. The
ground graphics leave a lot to be desired, but if that
is what you want, get MS flight sim 200x.
The second site is an aircraft developer's site.
Download an aircraft, modify it if you want, and fly.
Other add ons are available as well.
I fly this sim through the winter when flying weather
is at a premium here in Michigan. I find it helps
keep procedures sharp and hands and feet coordinated.
BTW, I am not a computer gamer.
I do use a joystick and rudder pedals. My $.02.
Dave
> recommendations.
> -Stormy
> Click on
> about
> provided
> Admin.
> _->
> browse
> Subscriptions page,
> FAQ,
From: | Chris W <1qazxsw23edcvfr45tgbnhy67ujm(at)cox.net> |
The problem with using a torque value is they are written for a certain
metal with a certain finish, if you use a fitting with a different metal
or different finish or a tiny bit oil or other liquid gets on the
threads or other part of the fitting those torque values are worthless.
A better and much easier method is the called the FFFT or Flats From
Finger Tight method, this method works no mater what the surface
condition of the fitting is weather or not it is wet or dry. The quote
below is from pdf file published by Parker. Parker is one of the
biggest manufactures of fittings, so they should know what they are
talking about. I don't know where on the site the pdf file is but you
can probably find it a parker.com/ When I worked for a construction
equipment manufacture the 37 degree flare fittings were all that we used
on hoses and tubing for hydraulic lines at 3000+ PSI. When working on
hydraulics it is impossible to not get the hydraulic oil on the
fittings, and with the oil on them the torque numbers don't work so we
always used the FFFT method.
Well it looks like too much work to copy and past all the charts and
stuff from the PDF so I found the link
http://www.parker.com/tfd/cat/pdffiles/T-Assembly Installation.pdf
Note it looks like they now like to call it FFWR or Flats From Wrench
Resistance.
If you want to start at the beginning and see the whole fittings catalog
start here...
http://www.parker.com/tfd/cat/pdffiles/Open.pdf
Chris W
KE5GIX
From: | "Dave Saylor" <Dave(at)AirCraftersLLC.com> |
Erich,
Maybe relating some real world experience will be helpful.
(1) You are correct that lubes and sealants are not needed on B-nuts. The
threads on the B-nut play no part in making the physical seal. All the
sealing takes place at the flare; the B-nut provides pressure against the
ferrule to seal the female flare against the male cone. A correctly flared
tube and B-nut will not come loose by itself, even without sealant or
locking compound.
I have seen a very few instances of saftied B-nuts. These have been on
turbine helicopter engines and in other places were a failure would be
instantly catastrophic. I can't think of an application on an RV that would
need a saftied B-nut.
(2) In A&P school they showed us a set of special open-end torque wrenches
in a walnut case, years out of calibration, that were never ever used. In
the following 20 years as a GA A&P I haven't seen one since. You will get
the hang of torquing B-nuts by hand. If you want to check the quality of
flares and look for leaks you can pressurize most circuits with shop air
(NOT FUEL TANKS!!!) and check for leaks with soapy water.
As a general rule the B-nut should thread onto the fitting without any
interference and virtually no drag. Any drag usually indicates interference
or misalignment. The nut will come to a firm stop when it bottoms on the
ferrule edge. From there it needs only moderate pressure to stay tight,
much less than a whole turn, maybe 1/6 or 2/3. You could use the values you
found on some practice parts, with the tube cut short, to get the feel for
how tight to make them.
(3) A double flare needs an expensive tool to fabricate. It folds the
flare back in on itself making the flare two wall thicknesses deep. We have
fabricated many 1K+ psi hydraulic and oxygen systems using single flares.
The biggest problem I see in flaring is getting the flare size correct. We
use a Rigid flaring tool that makes nice flares if we leave the tube a
little shy of the clamp edge, which is not where one would naturally set it.
Like torquing, it just takes a few practice runs.
(4) I'm not quite sure what you mean by spacer washers. Large area washers
help spread out the load in soft materials, ie, composites/wood, etc. You
could space a bulkhead fitting back if it helped line up a tube or hose but
there is no general requirement to use them.
If you have questions, feel free to email or call our shop any time. I'd be
glad to get you more information.
Happy Flaring,
Dave Saylor
AirCrafters LLC
831-722-9141
Bolting my -10 empennage together
Subject: | Re: Off -Topic: Traffic Patterns @ Private Aiports |
Ivan,
This is just my understanding and is probably not entirely correct. I
believe that an owner can only request that operations at his airport be
done in a particular way, but there is no particular way to enforce these
requests other than not allowing violators access (the owner obviously has
the authority to do that). In general, traffic pattern policy at any
airport is just a recommendation and a statement general policy at that
airport. Done for reasons of safety and or noise abatement they allow for
everyone to be on the same page. However, the pilot has the ultimate
responsibility for safety and deviations from the standard are OK when the
conditions dictate.
I thought that noise abatement was voluntary, but one of our local airports
has found a way to send you a ticket if your plane is louder than certain
levels as measured by sensors in the departure path. So that shows you what
I know.
Dave Leonard
> keep traffic on one side of the runway. So the pattern in one direction will
> be right-handed (non-conventional). My question(s) to those knowledgeable on
> the subject are:
> pattern?
> open-to the-public but privately owned airports with notations on Sectional
> charts for right traffic on certain runways. I have yet to see this on a
> Sectional chart for private runways.
> appropriate (albeit at the risk of safety and the risk of irate people on
> the ground when you land!)
> I am just interested.
Dave Leonard
Turbo Rotary RV-6 N4VY
http://members.aol.com/_ht_a/rotaryroster/index.html
http://members.aol.com/_ht_a/vp4skydoc/index.html
> pattern?
Legally? Maybe not. But practically, he can raise a lot of trouble for
you if you don't follow the procedures. Do you need prior permission to
fly into a private strip? If so, then he can easily claim you don't have
it, and get you violated for that.
> on the ground when you land!)
In Canada, you can't just fly any pattern you want to. If it's
uncontrolled, and largely inactive, it's unlikely anyone will see you if
you choose to do something contrary to local policy. But be forewarned
that if you do, you risk aggravating whoever or whatever is located on the
upwind side of the airport. If it's a housing development, and the airport
owner has made a voluntary agreement to try and abate noise by keeping the
circuit to one side, and if you make it your mission to fly on the wrong
side, you can expect the owners to make it their mission to close the
strip. This will make you very unpopular with the airstrip owner and the
other users of the strip.
There is nothing unsafe about a right-hand pattern at an uncontrolled field
where this pattern is the standard procedure. My home airport also has all
circuits to one side, and it works very very well. All approaches are from
one side at circuit altitude. You do your wind check at midfield, and
choose the downwind (left or right) at that point. In some ways, it makes
it simpler because you don't need to overfly or circle around waiting for
someone to make a radio call in order to figure out what the wind is doing
first.
> anything. I am just interested.
Not to offend, but the way the questions were worded to gave me the
impression that someone you know is one of those "i'll do whatever I damn
well please" types, who won't listen to local rules (or to reason). I hope
someone answers with some more definitive answers with respect to the regs.
-Rob
Hey Stormy, I just did this in my 6A. With a GNS 430 I did VOR, ILS
and GPS approaches. No stinkin ADF!
I used the Gleim CD for the course work then borrowed a King CD. I
probably would have gotten about 90-92% with just the Gleim but the King
bumped me up to 97%. I got a lot from the King CD (or DVD now?)
that you don't get just reading questions.
I took the written test after I was almost done with the flying. Not a
problem. I have not taken the practical yet because of a vacuum
issue that needs to be fixed.
Just be sure to find a good instructor who doesn't yell. yelling is
counterproductive.
Ron Lee
Ron,
Just curious ...
What numbers/power settings do you use in the different phases of flight in
the 6A?
I am doing a numbers "work up" now with a 6 and was wondering what works for
others.
For example: (I *think* this is what I am settling on)
Enroute cruise 25" MP (with a fixed pitch prop)
"Terminal Area"/ Maneuvering 20"
Established on localizer 15" and trim for level
FAF 12.5"
Middle Marker: Full idle. Runway environ in sight hold alt + full flaps and
land
No runway, go missed
I am giving this as an example before having adequate coffee so it could ALL
be wrong.
Just curious.
James
p.s. STORMY ... There are flight models available for the RV as well with MS
Flight Sim
> counterproductive.
> Ron Lee
Subject: | Re: Double Flaring tubing was AN fittings basic info |
> >Howdy
> sides or just one?
> >Erich Weaver
>Happy building
>Mark
Eric,
I'm with Mark regarding the use of double flares. Flaring stretches the
aluminum tubing. It is stretched the most at the lip. This means that the
lip is where the material is now severely thinned. The aluminum is also
work hardened during this process. The combination of work hardening and
thinning the material invites cracks to form on the flare.
As shown in the link Mark provided, the double flare folds the edge of
the flare over. This effectively doubles the thickness of the end of the
flare. It also leaves the edge as a 180 degree bend, rather than an edge.
This is what makes the double flare superior. FYI The US Department of
Transportation mandates that auto makers use ONLY double flares on the
brake lines of all automobiles sold in the US. Your auto mechanic is also
forbidden to make any repairs that do not also use double flares.
The dilemma for most builders is the cost of aviation double flaring
tools. The price for the one I purchased recently jumped from $400 to
almost $700. See
http://www.usatco.com/tubing_tools_01.asp
I managed to find a brand new unit on EBay last year for $130, after a 2
month search. This is the type of tool that is best purchased by an EAA
Chapter or local RV builders group, for use by the membership. That makes
it cost effective for each user. This tool is a joy to use. It does not
mark or damage the tubing at the clamping point below the flare. If you
have any A&P friends, I suggest that you contact them to see if anyone owns
a unit you can borrow.
Regarding your first question, I apply Never Seize to the threaded area
of the male end of flare fittings. This is not required. AN fittings are
anodized to prevent galling of the 2 parts. However, my experience is that
if you live in a corrosive environment or if you tend to over tighten the
fittings, Never Seize (a trade name for generic anti-seize compound) makes
future disassembly easier. It also gives you a better chance to tighten up
a leaking fitting at a later date, as it reduces the "start up" torque
required to get the B nut to start moving again.
The fluid fitting tightening method described in the web link above is
an acceptable alternative to using a torque wrench on the fittings. As
mentioned earlier by another lister, use of a crows foot wrench with a
torque wrench allows you to torque the fittings. Another alternate method
is to simply torque a test fitting in a vice. Draw a line across the two
fittings once they are torqued. Now loosen the fittings and re-tighten the
fittings using a tubing or open end wrench till the lines you have
previously drawn, line up. Remember the amount of effort which was required
to re-tighten the B nut. Tighten your fittings to this same amount. You can
easily approximate the torque required from muscle memory. It is best to
stick to the recommended torque initially. You may need to go back later
and apply slightly more torque later, to correct a leaking fitting. If the
fitting still leaks, don't just keep tightening. The message you should get
from that situation is: There is something wrong with the flare. I need to
disassemble the joint and inspect it for cracks or foreign debris
contamination.
When spacer washers are required, I generally install the spacer under
the nut end of the fitting. This allows the spacer to protect the material
being penetrated from being scarred by the rotating nut. General rule of
thumb is to always hold the fitting and tighten by rotating the nut. This
applies to general hardware, as well as hydraulic fittings.
Charlie Kuss
PS Subject line changed to allow easier future archive searching.
Stormy,
I suggest you find someone that's currently training for their instrument
rating and ask to sit in the back seat and watch. Alternatively, find a
couple of intrument-rated friends and volunteer to provide safety pilot
services. In my opinion you can learn more about procedures from watching
someone else (especially another student getting instruction) than you can
while you're flying the plane.
Learning to control the aircraft is the easy part for most, learning all the
procedures (when to start the checklist, when to make the radio call, etc.)
while learning to control the aircraft is really hard, especially if you've
no prior exposure to the IFR environment.
Mark & Lisa Sletten
Legacy FG N828LM
http://www.legacyfgbuilder.com
Subject: | Traffic Patterns @ Private Aiports |
>From: "H.Ivan Haecker" <baremetl(at)gvtc.com>
>Subject: RV-List: Off -Topic: Traffic Patterns @ Private Aiports
keep
right-handed
>are:
pattern?
open-to
Sectional chart
appropriate
when
>you land!)
I am
>just interested.
Hi Ivan-
Those are good questions, and you got me to thinking about the fine print
of the situation. So much so, that I looked up the relevant (and some not
so relevant) references to see what guidance I could find.
First, FAR 1.1 says that "Traffic Pattern means the traffic flow that is
prescribed for aircraft landing at, taxiing on, or taking off from, an
airport." Note there is no mention of who writes the prescription, limits
on what kind of airport it applies to, and that it also includes ground
movement.
Next, WRT noise abatement, AIM 4-3-6 (b) states "Airport proprietors are
responsible for taking the lead in local aviation noise control.
Accordingly, they may propose specific noise abatement plans to the FAA.
If approved, these plans are applied in the form of Formal or Informal
Runway Use Programs for noise abatement purposes." Now, yes, I do realize
that the AIM is not regulatory. There is some fine print to add to that
concept, tho- First, the AIM is the considered opinion of the FAA. If you
operate contrary to this opinion, then the feds are liable to consider you
'careless and reckless', their generic violation of FAR 91.13. The next
caveat comes into play should you find yourself in a court room. It seems
that there is a concept (I forget it's proper name) in law wherein an
acknowledged expert in a given field can speak the gospel. In this
scenario, the courts accept that the FAA is an acknowledged expert, and if
they say you should operate in a certain manner, the court will go along
with that. The bottom line is that in the cockpit the AIM is not
regulatory, but once you get into a court room, it is.
FAR 91.103 states"Each pilot in command shall, before beginning a flight,
become familiar with all available information concerning that flight...",
so lack of familiarity with the local traffic pattern is not acceptable, as
long as that info is available.
Also, FAR 91.126(b)(1) [Operating on or in the vicinity of an airport in
class G airspace] states "Each pilot of an airplane must make all turns of
that airplane to the left unless the airport displays approved light
signals or visual markings indicating that turns should be made to the
right, in which case the pilot must make all turns to the right..." As I
read it, your airport proprietor in question can require right traffic, but
that needs to be visibly displayed to inbound traffic. Then again, a
private field doesn't need to comply with all the fed standards, hence the
'use at your own risk' notations.
FAR 91.127 Operating on or in the vicinity of an airport in class E
airspace says, in part, "....must comply with the requirements of para
91.126."
So, as I read it all, the airport proprietor can mandate non standard
patterns, but that information needs to be available to the pilot group.
Once those requirements are met, compliance isn't optional.
I hope that this was of some use to my fellow listers-
Glen Matejcek
>Howdy
questions
I there
>Erich Weaver
Howdy y'own self!
If you were to put a 3/8 (-6) bulkhead fitting through your firewall, you
wouldn't be able to tighten it down to the firewall due to the thinness of
the SS and the length of the threaded portion of the fitting. Putting a
spacer(s) on the fitting allows it to grip the firewall properly.
WRT the Parker web page and counting flats to set the B nut properly, all I
noticed were directions for steel, SS, and brass. Can anyone verify the
specs for aluminum fittings?
Glen Matejcek
Enter AC65-9A into Google...then select the 8th or 9th link down on the list...then
select chaper 5...then look at the table at the top of page 117 (page numbers
on the bottom of the PDF pages). There, you will find the torque values for
both aluminum and steel fittings.
> >Howdy
> questions
> I there
> >Erich Weaver
> Howdy y'own self!
> Glen Matejcek
-- RV-List message posted by: "Glen Matejcek"
Howdy
questions
I there
Erich Weaver
Howdy y'own self!
ess of
Glen Matejcek
m, and
I don't know why they never mention aluminum fittings. There are only 2
reasons that I can think of that would make it any different for
aluminum. One, is if the aluminum threads can't handle the stress of
being that tight. I haven't read any specs on the strength of brass but
I would think that a high quality aluminum alloy would be as strong as
brass, so if the brass are strong enough, I would think the aluminum
would be too. Two, would be if aluminum tend to gall, I understand the
anodizing on the AN fittings is to help prevent that, a little bit of
anti seize lube wouldn't hurt either, I know they recommend it on
stainless steel as well.
For those who don't know, galling is when two pieces of metal rub
together under very high pressure and the friction causes the surfaces
to tare out little chucks of metal. Not good!
I did find one site that mentions aluminum and just says to put some
anti seize on the fittings. It also says that the torque method is
preferred over FFFT but Parker contradicts that and I go with Parker on
that one, it just makes more sense to me.
http://www.interactmultimedia.com/airway/tightening.htm
Chris W
KE5GIX
From: | "czechsix(at)juno.com" <czechsix(at)juno.com> |
Subject: | Proper torque for Hartzell bolts through spinner backplate |
Guys,
I thought I'd pass this along for those of you with Hartzell props....
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D almost ready for final inspection (and subsequent first flight in
the dead of winter in Iowa....Ugh!)
"Ryan, Kevin" wrote on 11/29/2005 04:06:02 PM:
> Mark:
> I was intriqued by your question, so I asked our "nuts & bolts" engineer
> here at Hartzell. He informed me that the rolling torque or "drag"
between
> the nut and the bolt as the nut is tightened is accounted for when the
> torque specifications are calculated. It is not necessary, therefore, to
add
> the torque caused by the drag between the nut and the bolt to the
specified
> torque. 20-22 ft-lbs is sufficient for these nuts. You can simply back
the
> nuts off and apply to proper torque (20-22 ft-lbs).
> If you have any additional questions, or if I can be of further
assistance,
> please feel free to contact me at your convenience.
> Regards,
> Kevin M. Ryan
> Product Support Representative
> Hartzell Propeller Inc.
> Phone: 937.778.4379
> Fax: 937.778.4391
> Email: techsupport(at)hartzellprop.com
> From: menavrat(at)rockwellcollins.com [mailto:menavrat(at)rockwellcollins.com]
> Sent: Monday, November 28, 2005 4:03 PM
> To: Huelsman, Brad
> Subject: bolt torque question
> Hi Brad,
> Over the weekend I installed the aft spinner bulkhead on my Hartzell prop
> using the bolts that go through the hub at the root of each blade. The
> Hartzell manual calls out 20-22 ft lbs for the torque on these bolts. I
> believe it's standard practice to add the torque required to turn the
lock
> nut to this value. I measured approx 9 ft lbs of torque required to turn
> the locknut before it contacted the hub so I added this to the spec and
set
> the wrench for 30 ft lbs. Just wanted to confirm that this is correct so
> that I don't damage anything....?
> Thanks,
> --Mark Navratil
> Cedar Rapids, Iowa
> RV-8A N2D almost ready for final inspection...
Guys,
IthoughtI'dpassthisalongforthoseofyouwithHartzellprops....
--MarkNavratil
CedarRapids,Iowa
RV-8AN2Dalmostreadyforfinalinspection(andsubsequentfirstflightin
thedeadofwinterinIowa....Ugh!)
"Ryan,Kevin"kryan(at)HartzellProp.comwroteon11/29/200504:06:02PM:
Mark:
Iwasintriquedbyyourquestion,soIaskedour"nutsbolts"engineer
hereatHartzell.Heinformedmethattherollingtorqueor"drag"
between
thenutandtheboltasthenutistightenedisaccountedforwhenthe
torquespecificationsarecalculated.Itisnotnecessary,therefore,to
add
thetorquecausedbythedragbetweenthenutandthebolttothe
specified
torque.20-22ft-lbsissufficientforthesenuts.Youcansimplyback
the
nutsoffandapplytopropertorque(20-22ft-lbs).
Ifyouhaveanyadditionalquestions,orifIcanbeoffurther
assistance,
pleasefeelfreetocontactmeatyourconvenience.
KevinM.Ryan
ProductSupportRepresentative
HartzellPropellerInc.
Phone:937.778.4379
Fax:937.778.4391
Email:techsupport(at)hartzellprop.com
-----OriginalMessage-----
From:menavrat(at)rockwellcollins.com[mailto:menavrat(at)rockwellcollins.com]
Sent:Monday,November28,20054:03PM
To:Huelsman,Brad
Subject:bolttorquequestion
HiBrad,
OvertheweekendIinstalledtheaftspinnerbulkheadonmyHartzellprop
usingtheboltsthatgothroughthehubattherootofeachblade.The
Hartzellmanualcallsout20-22ftlbsforthetorqueonthesebolts.I
believeit'sstandardpracticetoaddthetorquerequiredtoturnthe
lock
nuttothisvalue.Imeasuredapprox9ftlbsoftorquerequiredtoturn
thelocknutbeforeitcontactedthehubsoIaddedthistothespecand
set
thewrenchfor30ftlbs.Justwantedtoconfirmthatthisiscorrectso
thatIdon'tdamageanything....?
--MarkNavratil
CedarRapids,Iowa
RV-8AN2Dalmostreadyforfinalinspection...
From: | "Tim Bryan" <flyrv6(at)bryantechnology.com> |
There has been several other posts with good info but to add to it. When a
private airport is reported to the FAA, the traffic pattern needs to be
identified. This is then either responded to by the FAA as an objection or
no objection. It goes on file in the FAA office as having a specific
traffic pattern. The identifier is issued if it is "no objection" This is
the airspace they consider to be protected.
Weather they have any enforcement of that or not, - I doubt it.
-------Original Message-------
Date: 11/28/05 19:23:25
the subject are:
pattern?
Curious minds want to know. I don't have a beef with anyone over anything I
am just interested.
Subject: | RV-6 kit for sale |
Fellow Listers:
I am posting this for a friend (Larry Groom). If you are interested, please
contact him directly.
Doug Weiler
pres, MN wing
...I have the tail kit (horizontal stab, vertical stab and right elevator
are complete) along with
the pre-punched wing kit and prebuilt anodized spars....
Larry Groom
952-492-3922
lgroom(at)frontiernet.net
Thanks to eveeryone who took the time to respond, on and off-list. I'm sifting
through the options and opinions now. Got my homework cut out for me, certainly.
This list is GREAT!
-Stormy
I am forwarding this message for Terry.
----- Original Message -----
Subject: tie downs
Becky....I have been trying to track this guy. He is getting a lot of peoples
money and not providing product. He even sent me an email that said he would
send it in a week...just long enough so that PAYPAL would not cover the loss.
I have posted on the VANS AIRFORCE forum that he is not providing the product
and ripping people off....I tried to get it on this site however for some reason
I cannot register. I have kept my email inquiries to Randy and no response...If
you could please post to this list and let people know that they will not
receive any product. There are many others who have been ripped off....sorry
Terry
Subject: | Telex TC200 Intercom Users Manual Needed |
Does anyone have a copy of the manual for this portable intercom? Telex doesn't
have it available any more and I can't find one on Google.
Charlie Kuss
From: | "Robert E. Lynch" <rv6lynch(at)earthlink.net> |
I have a new RV 8A that's ready to go to the paintshop. If interested, help me
select the color.
Contact:
From: | "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net> |
Subject: | RV-8 kit for sale |
I'll keep it short and sweet. I am only posting this on this list. Feel
free to copy and cross post it if you will.
Wick's aircraft is selling their partially completed RV8. I think the
workmanship was pretty good on it, at least the last time I looked at
it, it was.
take a look here.......
www.wicksaircraft.com/Wicks/Pages/Projects/RV8A_FOR_SALE.php
If you talk with Scott Wick, mention my name, he said he would give me
some credit in the store if it sold as a result of me...
Phil in Litchfield, IL
We are going to have an RV flyin here
http://www.litchfieldil.com/airport/ next Spring or Summer. Be
thinking about it. Suggestions appreciated on having a good 2 or 3 day
flyin. Volunteers would also be needed and appreciated... We will
probably get some financial help from the Airport Authority.
If you are passing through, check out our fuel price and stop in....
Subject: | Just ordered my Wings!! |
Hi Guys,
I just ordered my wings for my RV-9A. Here's a fun photo I made to
celebrate the occasion:
http://smittysrv.com/photos/OrderedTheWings.jpg
Smitty
http://SmittysRV.com
Subject: | Re: Fw: tie downs |
> From: Terry Allen
> To: becki@fly-gbi.com
> Subject: tie downs
> of peoples money and not providing product. He even sent me an
> email that said he would send it in a week...just long enough so
> that PAYPAL would not cover the loss. I have posted on the VANS
> AIRFORCE forum that he is not providing the product and ripping
> reason I cannot register. I have kept my email inquiries to Randy
> and no response...If you could please post to this list and let
> people know that they will not receive any product. There are many
If he has genuiely taken people's money and not delivered the product
when he said he would, then people should push PayPal harder. They
have a dispute resolution process. Failing that, if the payment was
made via a credit card, the credit card company may have a way to get
your money back.
If there are several people that have paid for the Ti-Downs, and not
received them, and they have used all reasonable means to contact
Randy Simpson, then I am prepared to put a notice on my web site
warning people about the problem. My site ranks fairly high on
Google, so I think it could be effective in warning some people to be
careful.
Ottawa, Canada
http://www.kilohotel.com/rv8
> careful.
Kevin, I have pulled the Product Review of the Ti-Downs from my site.
The review was formerly linked on Randy's site and he used the article
as a primary source of advertising.
But no more.......sad........
Sam Buchanan
http://thervjournal.com
I just don't get it. Randy is a nice guy. A little
excentric, but generally a nice guy. I shared a booth
with him at Oshkosh a few years back. I don't think
he is inentionally frauding people, I just don't think
he can keep up with demand. His tie downs are a work
of art, and they take several hours each to make.
Paul Besing
> > From: Terry Allen
> > Subject: tie downs
> is getting a lot
> even sent me an
> long enough so
> posted on the VANS
> product and ripping
> however for some
> inquiries to Randy
> list and let
> PayPal harder. They
> the payment was
> have a way to get
> your money back.
> Ti-Downs, and not
> means to contact
> my web site
> fairly high on
> some people to be
> careful.
> Ottawa, Canada
> Click on
> about
> provided
> Admin.
> _->
> browse
> Subscriptions page,
> FAQ,
Then he could easily make it known that the estimated
delivery time is X period. If I knew it would take a month
I could either not buy them or wait the required time.
BTW I do have a set.
Ron Lee
Subject: | Re: RV-8 kit for sale..... ooops RV8A |
>it, it was.
Actually it is an RV 8A.........
From: | "Mike Kraus" <n223rv(at)wolflakeairport.net> |
Tooks lots of repeated e-mails and phone calls with no luck until one
day I got a response from him and after 10 days I had them... They are
very nice and they were worth the wait, but I too was afraid I had been
taken.... Keep trying!!
-Mike
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Becki
Subject: RV-List: Titanium Tie Downs
the titanium tie downs. We've been trying to get him for a month now via
phone and email. We've paid for our tie downs over a month ago through
Pay Pal and no response and no tie downs. Sure would like to get some
tie downs! Thanks for any help!
Becki Orndorff
Hi All
Is it possible to get a image of what these tie downs look like? My shop can
weld or machine titanium.
Dayton
Mine took 3 monyhs to arrive. I left him a voice mail that said I was
turning him in to pay pal as non responsive. He called me a week after that
ans sent the tiedows about three week laterr. I think that he is just very
disorganized. If you wait long enough you will get the product, proviving
that Randy has not totally forgotten your order. Don
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ron Lee
Subject: Re: RV-List: Fw: tie downs
Ron Lee
Dayton Murdock wrote:
>Hi All
But can you bend it? That is how he makes them I believe.
Chris W
KE5GIX
If you are looking for a source for titanium tiedowns, headsets, GPS, etc I
recommend Rob Rollison.
http://www.airplanegear.com/
I have no financial ties to him or his co. I am just a satisfied customer.
He is a regular at osh and Lakeland. When something becomes avail that I
wanted, he calls me and asks if I still want it. He did that with terrain
awareness add-on for my Lowrance 2000. he refunded my $$ when I sent my
lightspeed headset back.
I think that he also sells LSA aircraft and has a co. for untralight stuff
too
Illinois Keith
Keith Hedrick 3LF
Subject: RV-List: Fw: tie downs
Subject: tie downs
peoples money and not providing product. He even sent me an email that said
he would send it in a week...just long enough so that PAYPAL would not cover
the loss. I have posted on the VANS AIRFORCE forum that he is not providing
the product and ripping people off....I tried to get it on this site however
for some reason I cannot register. I have kept my email inquiries to Randy
and no response...If you could please post to this list and let people know
that they will not receive any product. There are many others who have been
ripped off....sorry
Terry
Subject: | Traffic Patterns @ Private Airports |
For open-to-the-public (public) airports, the airport authority needs to
petition the FAA using form 7480-1. See A/C 70-2E (available on the AOPA
web site). The FAA determines if this is safe relative to other traffic
and will send a letter of "no objection" to the change if it is OK.
And, as previously commented, traffic direction at public airports is
in FAR 91.126 b (1) - left unless marked for right.
BTW, airport ownership does not matter, public or private owned public
use airports need to file. Also, a privately owned, private use airport
that is active and is in class E or higher surface based airspace OR
within 5 NM of a public use airport in any airspace should file with the
FAA for traffic changes.
Bill Gunn, Texas DOT Aviation Division
RV 4
Subject: Traffic Patterns @ Private Aiports
you.
wants to
keep
direction will be
right-handed
subject
>are:
traffic
pattern?
see many
open-to
Sectional charts
a
Sectional chart
deem
appropriate
the ground
when
>you land!)
anything.
I am
>just interested.
Hi Ivan-
fine print
some not
that is
from, an
ground
movement.
proprietors are
the FAA.
Informal
do realize
to that
FAA. If you
consider you
The next
It seems
wherein an
this
expert, and if
go along
not
flight,
flight...",
acceptable, as
airport in
turns of
light
to the
right..." As I
traffic, but
again, a
hence the
E
para
91.126."
standard
group.
Glen Matejcek
aerobubba(at)earthlink.net
He really fooled you!!
I ordered tie downs in March 2003, after numerous emails etc, I have not
recieved the tiedowns. At one point he said they would be in the mail next
day. Now 18 months later, no tiedowns.
He may be a nice guy, but he is a dishonest businessman, a Crook. He took
my money and never provided the product. Regardless of his intentions or
how nice he is at Oskkosh, he is an Internet Crook, Thief and not to be
trusted.
To anyone who would continue to defend him, please do so by getting him to
refund the money or provide the product.
For those with excess RV building funds, send it to the Randy Simpson get
out of jail fund (but do not expect any tie downs in return).
There are many RV related products that I can buy over the internet, but
this experience has convinced me that it is best not to buy from these type
of people. It is unfortunate that such a disreputable person as Randy
Simpson can tarnish the business of otherwise honest businessmen and women.
RV6 NightFighter
Subject: | Need Rivet Gun Set |
I'm looking for a serviceable 3X rivet gun set with regulator, .401" straight and
offset shanks with bucking bars. Please respond off-list with details.
Craig Payne
cpayne(at)joimail.com
Come on Bob, tell us how you really feel!
BTW, he sent me my tie downs.
Bruce
www.glasair.org
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob
trusted.
RV6 NightFighter
From: | Richard Tasker <retasker(at)optonline.net> |
As others have said, I don't believe he is a crook. He is just a "free
spirit" and totally disorganized. I ordered a set in Feb 04 and
received them several months later (with a little prodding on my part),
but I did receive them and they are a work of art!
So he was definitely delivering them long after you placed your order.
I can't understand why he operates the way he does, as he has an
excellent product. Nonetheless, I can't in good faith recommend anyone
order anything from him until (unless) he gets his act together.
Dick Tasker
>trusted.
>Bob
>RV6 NightFighter
From: | "lancenewman" <lancenewman(at)comcast.net> |
What ever a throttle is, he must mean a shut off flap controlled by a
cable. Anyway, Ive tried all those fancy do- dads in my rv6 and the only
thing that gets my temps up is preheating the engine on cold days to 70F and
flying with the feed air to the oil cooler blocked completely. Even then,
the highest temp I see is 190F on climb and 170F in cruise flight. You need
at least a sustained 190F to boil out the moisture in the engine completely.
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Subject: RE: RV-List: Oil Cooler Issues
> SNIP
> Rick,
> my
> When
> fly
> OAT
> was around 45F.
> is
> big
> a pain that can be.
> Alex Peterson
> Maple Grove, MN
From: | "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> |
As a different point of view and acknowledgement that Paul's instincts are
pretty good.... A few years ago when I lived in Portland (OR) and was
attending a Homewing RV builders group meeting, Randy showed up with a bunch
of tie downs peddling his wares. I looked at them, boy are they nice pieces
and the best part, light light and....did I mention LIGHT. I didn't want to
miss out but I didn't have the money on me at the time and mentioned it to
Randy. He said (to a complete stranger he'd never met before) "no problem,
here's my card send me a check". So....I went home, wrote a check and put
it in the mail. Randy works for a big manufacturer of titanium and other
aerospace metals in the Portland area and that's where he gets his raw
material. The tie downs are basically titanium bars one quarter inch
diameter bent into a helix with a triangle bent in the top to fasten the tie
down rope to. He sells them polished for a few bucks extra, mine are
unpolished and came in a nice canvas carry bag with some rope. No, I don't
get paid for saying this and I'm NOT a relative of Randy's...but, I am a
happy customer.
Dean Psiropoulos
RV-6A N197DM
Installing the last of Van's FWF parts.
________________________________ Original Message ________________________
Just guessing of course, but could it be that therein
lies the source of the problem? Titanium ain't
cheap, they don't give that stuff away.
........Randy works for a big manufacturer of titanium and
other aerospace metals in the Portland area and that's
where he gets his raw material.
I just found this bike manufacturer on the internet. The prices are really
low. Does anyone know whether that are any good or not?
http://zportusa.com/
Smitty's RV-9A
From: | "Don Kugler" <donkugler(at)earthlink.net> |
It's time to clean house!
The below items are for sale, leftovers from building my -8 which is now 400
hrs and 2 1/2 years flying. Contact me off list, make an offer, whatever.
-Don
RV8 - NJ
Don Kugler
908-303-6578 direct
1 Left RV 6/8 Elevator Skin .020, new, unused, still in box from Vans -
$35.00
Vans P/N - E-601-L-020 - ELEVATOR SKIN LEFT - New $51.26
1 Fiberglass Rudder bottom w/o light, new, unused leftover from RV8 Kit -
$30.00
Vans P/N - R-411W/O - FBRGLS RUD BOT W/O LT - New $45.45
2 Isspro 2" resistive-type fuel gauges, new, unused - $5.00 ea
1 Stewart Warner 8432 9-row Oil Cooler, used, pressure tested - $100
Removed from Beech Sierra IO-360 installation, New from ACS - $516
1 Ford 60A DOFF10300J (ACS PN 07-04616) Alternator - $100
35 hrs - Removed from Beech Sierra IO-360, New from ACS - $317
Subject: | More items for sale |
Found more stuff....
-Don
RV8 - NJ
Don Kugler
908-303-6578 direct
1 ELT Battery Pack - Artex ELT 110-4 Ordered in error amd forgot to return.
Good till June 2007. - $20
Cost $37.25 from ACS.
From: | Geoff Evans <hellothaimassage(at)yahoo.com> |
Subject: | RV8 Wheel Fairing / Brake Caliper Interference |
I mounted and aligned my wheel fairings with the brake calipers removed
because it was easier to access that way. I have the required 1" above the
tire, and the pants are aligned in all of the axes.
However, when I install the brake calipers, the lower edges of the calipers
and the bleed nipples interfere with the fairings. I triple checked the
installation of the axels and caliper mounting brackets -- they look correct
and they match photographs of other people's RV-8s.
I called Vans and they said they had never heard of this problem. A search of
the archives reveals one instance of this about five years ago, but no real
solutions or further information.
Anybody have any ideas? I have the new (epoxy, not gel coat) fairings.
Thanks.
-Geoff
RV-8
Just $16.99/mo. or less.
dsl.yahoo.com
Subject: | Re: RV8 Wheel Fairing / Brake Caliper Interference |
geoff- i had the same problem--tom
TOM WHELAN
249 HARDHILL RD NORTH BETHLEHEM CT. 06751 WFACT01(at)AOL.COM
TEL-203-2665300 FAX 203 266-5140
AIRPORT-CT01-----122.725
RV-8-SP-IO-540-350+HP---62HRS
S-51-MUSTANG-TURBINE
F-24 FAIRCHILD
Same here. Cut as needed:
http://bowenaero.com/mt3/archives/2005/05/wheel_pants.html
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
> From: Geoff Evans [mailto:hellothaimassage(at)yahoo.com]
> Sent: Friday, December 02, 2005 8:16 PM
> To: RV List
> Subject: RV-List: RV8 Wheel Fairing / Brake Caliper Interference
> calipers removed because it was easier to access that way. I
> have the required 1" above the tire, and the pants are
> of the calipers and the bleed nipples interfere with the
> fairings. I triple checked the installation of the axels and
> caliper mounting brackets -- they look correct and they match
> problem. A search of the archives reveals one instance of
> this about five years ago, but no real solutions or further
> information.
> Thanks.
> -Geoff
> RV-8
> dsl.yahoo.com
> Photoshare, and much much more:
Subject: | dzus fastener questions |
I am trying to puzzle out the Dzus fasteners from the information in the
Aircraft Spruce catalog. They don't seem to indicate how the springs
are fastened to the panel. The drawing shows some sort of rivet-like
fastener, but there's no other information about it. Can anyone tell me
what this is?
Also, does use of the full grommet make the stud captive or not? The
"half grommets" apparently capture the stud, which I don't want in my
application.
Are the full grommets suitable for installation in fiberglass?
Tom Sargent, RV-6A
From: | "Steve Glasgow" <willfly(at)carolina.rr.com> |
I had the same problem because I have the grove landing gear which is thicker than
Van's stock gear. I cut a hole where the problem area was and make blisters
or bumps on the pants out of fiberglass to allow clearance.
Steve Glasgow-Cappy
N123SG RV-8
Cappy's Toy
Subject: | heated pitot tube, and pnuematic squeezer for sale |
I have changed projects so I can fly sport pilot
catergory and have a heated 12v pitot tube, and a
pneumatic squeezer listed on ebay for sale. The item
numbers are below.
Best to all,
Rick
Pitot Tube, Heated Item #4593874350
Pneumatic rivet squeezer (#4593879112)
dsl.yahoo.com
Subject: | Re: Folding Bikes |
From the info I got this is the conclusion I came to. I first wanted a bike just
like these but talked myself out of them, even though I am a cheapskate.
Just for illustration and no offense meant, but have you ever seen a clown on
a little bike at the circus? That is what comes to mind. I like the price but
be ready to pay a lot more for a serious folding bike.
Also you get what you pay for comes to mind.
If you plan on doing some serious riding, touring it is totally unacceptable.
If you just want something to peddle down the tarmac to get to the FBO the zportusa
may be fine.
From a size standpoint the small wheel zportusa models it looks like it will
fit in the back of a RV-6/7/9, but a little heavy. The 20" are just a tad too
big and they are also heavy at 35lbs.
The mid/high priced Dahon's or a Bike Friday or Brompton are top on the list.
I think the Brompton may be a slight fit problem folded, but not sure. Also if
you want to do real riding shoot for 20". Many riders tell me the 16" wheel
is marginal for real touring/sight seeing.
George
Subject: RV-List: Folding Bikes
really
Smitty's RV-9A
Let fate take it's course directly to your email.
Has anybody on the list ever rode one of these cheap folding bikes from
www.zportusa.com
I'd like to hear a first person review of their experience. Some of these
folding bicycles from Brompton and Dahon and others are over $1000 each,
whereas this one from zport is $175 including shipping. A significant
difference. But I have not heard any first person accounts of the zport
equipment yet. I'm thinking about buying one just to look at it, but before
I do that, I'd like to hear from a person who has one.
Jim
Jim Pellien
Mid-Atlantic Sports Planes
The Mid-Atlantic Region of SportsPlanes.com
www.MASPL.com
703-313-4818
gmcjetpilot(at)yahoo.com
Subject: RV-List: Re: Folding Bikes
just like these but talked myself out of them, even though I am a
cheapskate.
on a little bike at the circus? That is what comes to mind. I like the price
but be ready to pay a lot more for a serious folding bike.
unacceptable. If you just want something to peddle down the tarmac to get to
the FBO the zportusa may be fine.
will fit in the back of a RV-6/7/9, but a little heavy. The 20" are just a
tad too big and they are also heavy at 35lbs.
list. I think the Brompton may be a slight fit problem folded, but not sure.
Also if you want to do real riding shoot for 20". Many riders tell me the
16" wheel is marginal for real touring/sight seeing.
George
really
Smitty's RV-9A
Subject: | [ John L. Danielson ] : New Email List Photo Share Available! |
From: | Email List Photo Shares <pictures(at)matronics.com> |
A new Email List Photo Share is available:
Poster: John L. Danielson
Lists: RV-List,RV6-List
Subject: Easy way to help cowl removal
http://www.matronics.com/photoshare/johnd@wlcwyo.com.12.03.2005/index.html
o Main Photo Share Index
o Submitting a Photo Share
If you wish to submit a Photo Share of your own, please include the
following information along with your email message and files:
2) Your Full Name:
3) Your Email Address:
Email the information above and your files and photos to:
Subject: | Magnetic Compass for sale |
-Don
RV8 - NJ
Don Kugler
908-303-6578 direct
1 Compass, 2 1/4" Panel Mount Northern Hemisphere. New - $50
Van's P/N IF CM-13L $75.00 in Van's Catalog
From: | "Steve Struyk" <rv8striker(at)hotmail.com> |
Well, the big day finally got here. This morning at 9:35 AM, N842S "slipped the
surly bonds" and soared into the crisp (34 F) morning air above Creve Coeur Airport,
1HO. (St. Louis Area) All went according to plan with no surprises. She
flies straight as an arrow and will require no aileron or rudder trimming or
re-rigging. What a Day!
For those to follow, just keep pressing on. You will get there, and it well be
so worth the effort.
Steve Struyk
RV-8, N842S
St. Charles, MO .8 Hours!
No not archive
Subject: | Re: First flight |
Congratulations Steve! Today was not exactly a warm CAVU day around the area but
that really didn't matter did it? YOU DID IT! What a feeling. I'm just a
few RV minutes away, based at Greensfield. Chalk up another RV joining the St.
Louis Mo. wing of the VAF. Congratulations again buddy. Fly safe.
Rick Galati RV-6A "Darla"
Steve Struyk
RV-8, N842S
I've put an article up on my web site describing the problems that
some people have had with Randy Simpson, to warn other potential
purchasers.
http://www.kilohotel.com/rv8/article.php?story=Beware_Randy_Simpson
I've quoted a few messages from this list, with the authors'
permission. If anyone else wants to put their oar in the water, you
can e-mail me your comments, or put a comment on the article on the
web page.
Ottawa, Canada
From: | "Tom Callender" <tcallender(at)alltel.net> |
Subject: | Re: RV9-List: status report 90616 |
>December 22 saw the successful completion of the
> airworthiness inspection of N927BJ (90616) RV9. I
> am told that there are only about dozen conventional
> gear 9's.
Way to go John, Congrats:-) I am building a 9 ( N793JT reserved ).
Tom C
Subject: | Re: First Flight |
Congrats Steve,
Still working on my fuselage, will attach wings next month. Maybe another
year to go, can't wait.
Good flying,
Paul
RV8QB
Subject: RV-List: First Flight
> "slipped the surly bonds" and soared into the crisp (34 F) morning air
> above Creve Coeur Airport, 1HO. (St. Louis Area) All went according to
> plan with no surprises. She flies straight as an arrow and will require no
> aileron or rudder trimming or re-rigging. What a Day!
> well be so worth the effort.
> Steve Struyk
> RV-8, N842S
> No not archive
From: | Charlie England <ceengland(at)bellsouth.net> |
RV list
Subject: | -7 aileron belcrank bushings |
INNOCENT GLOBAL 0.0000 1.0000 -4.4912
Just spent some time perusing old messages about bellcrank bushing
problems & got a few answers but still have some questions.
The bushings I got will slide into the bellcranks fairly easily until
they hit the point where the 2nd flange is welded, about 1/3 of the way
down from the top of the tube. Either bushing into either bellcrank,
same symptom. A 3/8 drill bit will slide through the bellcrank tube
without binding; actually, it's fairly loose.
In addition, neither bushing will accept an AN4 bolt shaft. The threads
will go in with slight binding, but any attempt to go further results in
the plating being scraped off the bolt at the thread-shaft transition
point. (I've used the deburring tool on the ends of the bushings; no help.)
Is everyone having to ream both the bellcrank tube & the bushing? I
suppose that I can turn the bushing OD down without too much trouble but
trying to drill it to 1/4"+ for the bolt, without a lathe, doesn't
strike me as fun.
(feeling like I paid for parts that should fit)
From: | "Frank Stringham" <fstringham(at)hotmail.com> |
Subject: | -7 aileron belcrank bushings INNOCENT GLOBAL 0.0000 1.0000 |
-4.4912
I used a 1/4 inch ream on my bushings and they came out great. I had no
problem with the bell crank bushing hole aliagnment.
Frank @ SGU and SLC
>From: Charlie England <ceengland(at)bellsouth.net>
>To: "rv7-list(at)matronics.com" , RV list
>Subject: RV-List: -7 aileron belcrank bushings INNOCENT GLOBAL
>Date: Sat, 03 Dec 2005 20:31:53 -0600
>strike me as fun.
>Charlie
From: | "Bob Perkinson" <bobperk(at)bellsouth.net> |
Subject: | -7 aileron belcrank bushings INNOCENT GLOBAL 0.0000 |
1.0000 -4.4912
Charlie,
As I recall I had to ream the Bellcrank. It appears that when the assembly
is welded the areas around the welds on the inside of the tube expands
somewhat. As for the bolts going through the bushing I don't recall having
any problem with that.
Bob Perkinson
Hendersonville, TN.
RV9 N658RP Reserved
If nothing changes
Nothing changes
strike me as fun.
Subject: | Re: -7 aileron belcrank bushings INNOCENT GLOBAL 0.0000 |
1.0000 -4.4912
Hi Charlie,
The welding process can and does cause some amount disstortion. It does seem
that the parts in question should have been reamed to final fit size....?
However, you might consider going to a machine shop and asking them to run
an adjustable reamer through The bellcranks enough to get the correct fit
for the bushing. Only remove enough material to allow a comfortable slide
fit.
Avoid removing material from the bushing as doing so will contribute
somewhat to loosness or play in the control system. Running the reamer
through the bellcranks will remove the tight spot without removing any
excess. Using the reamer will not take very long and the labour cost should
be minimal.
Hopefully you have a machine shop or better yet a friend nearby that can
provide the service for you.
Keep going,
Jim in Kelowna -- the fuse is in the paint shop
From: "Charlie England" <ceengland(at)bellsouth.net>
Subject: RV-List: -7 aileron belcrank bushings INNOCENT GLOBAL 0.0000
1.0000 -4.4912
> help.)
> strike me as fun.
> Charlie
:) Way cool ...
Congrats ...
g
> N842S "slipped the surly bonds" and soared into the crisp (34
> F) morning air above Creve Coeur Airport, 1HO. (St. Louis Area)
> All went according to plan with no surprises. She flies
> and it well be so worth the effort.
> Steve Struyk
> RV-8, N842S
> No not archive
__g__
Tel: 415 203 9177
>Got a question:
>Doesn't anyone on this list know Randy Simpson personally, and is willing to >talk
to him over a beer or so to find out what really happened here???
>Just a thought.
Seems to me we all know what happened, or should by now. Randy is disorganized
and can be slow getting his product out. People who know him know he's not a crook,
makes good product when he gets around to it, and is a lousy businessman.
How about we stop beating this horse?
Randall
Subject: | VANS ALTERNATOR WEIGHTS |
Does anybody know the weights of the alternators that vans sells?
I search the archives but didn't find anything.
Lee
RV-3
Subject: | Re: Magnetic Compass for sale |
Whoops, sorry, I had not seen all your message. You have already given all
the info. I will look at my panel again and see if I have room for it.
Thanks.
Jimmy
Subject: RV-List: Magnetic Compass for sale
> Regards,
> -Don
> RV8 - NJ
> Don Kugler
> 908-303-6578 direct
Steve,
CONGRATULATIONS and WELL DONE !!!
Chuck & Dave Rowbotham
RV-8A
>From: "Steve Struyk" <rv8striker(at)hotmail.com>
>Date: Sat, 3 Dec 2005 17:40:27 -0600
>the surly bonds" and soared into the crisp (34 F) morning air above Creve
>Coeur Airport, 1HO. (St. Louis Area) All went according to plan with no
>surprises. She flies straight as an arrow and will require no aileron or
>Steve Struyk
>RV-8, N842S
Subject: | Re: VANS ALTERNATOR WEIGHTS |
My 35 amp Van's alternator:
Weight with 3 mounting bolts 7lb 2oz
Mounting brackets weigh 14oz the way I built them with a link to the starter.
Dave Reel - RV8A
Quoting Gerry Filby :
> :) Way cool ...
> Congrats ...
> g
> > Steve Struyk
> > RV-8, N842S
> > No not archive
> > Steve CONGRATULATIONS'''' I KNOW THE FEELING
>BERT >
> __g__
> Tel: 415 203 9177
Subject: | Source for NAS6200 bolts ? |
1.66 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP)
1.28 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC)
1.36 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP
addr 1)
Anyone know where I can acquire NAS6200 close tolerance bolts
with the X and Y oversize designation ?
Yup, I bungled a hole :-|
__g__
Tel: 415 203 9177
Subject: | Star Washers Question |
Star type lock washers have either internal or external teeth. Aircraft
engine acessories use the internal teeth type lock washers while the
hardware store variety generally have external teeth. My question is
this, is there any technical difference in their locking capabilities?
George in Langley BC
Subject: | Re: Star Washers Question |
In a message dated 12/4/2005 12:27:28 P.M. Pacific Standard Time,
gmcnutt(at)shaw.ca writes:
engine accessories use the internal teeth type lock washers while the
George-
Actually, there are some that have both internal and external teeth on the
same washer. My experience with star washers would suggest the following.
Internal teeth seem to be better at providing mechanical locking and
maintaining the preload of the bolted joint, as these teeth are actually under
the
nut's bearing surface and benefit from the full locking torque applied to the
bolted joint. These teeth actually get somewhat flattened out in the
tightening of the fastener.
External teeth seem to be better at cutting thru surface treatments (paint
and such) to establish and maintain a good electrical connection. These teeth
are often outside of the area of compression and teeth remain in a higher
pitch state. This would do little to maintain the mechanical integrity of a
bolted joint.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 771hrs, Silicon Valley, CA)
From: | "Alex Peterson" <alexpeterson(at)earthlink.net> |
I am flying in my 5th winter with my 6A in Minnesota, and have had frozen
brakes frequently. If I taxi through any loose powder or even just a
dusting, I can expect a clunk when I touch down after that flight.
Obviously, the cause is from snow finding its way onto the brakes and
melting during taxi, and subsequently freezing after takeoff. I've tried
taxiing with NO brake usage, which is an interesting challenge in itself,
but no help. I believe that the tires have enough internal friction to heat
stuff up without any braking action. The brakes are not dragging, and the
wheels turn freely. I thought today about beginning the takeoff roll with
the brakes dragging to heat them just prior to take off, in an attempt to
dry them out. BTW, I got about 600 landings out of the first set of brake
pads, in case you might think I drag them unknowingly while taxiing (maybe
that is what I need to do?).
Landings can get interesting with one or both wheels locked, and today one
tire landed on pavement while the other was on hard pack snow. It is a
little unnerving to have to apply a bunch of rudder immediately at
touchdown! (I would think it would be even more fun in a taildragger.) In
one landing today, I dragged the left main for quite a while before it broke
free, owing partly to less than ideal runway conditions and partly to the
fact that it happened to be a greaser landing.
I wonder if there is some aerodynamic subtlety to my gear fairings which
causes snow to be drawn up inside the wheel fairings. I do notice that
black tire dust comes out of the top of the gear and gets on the belly. Do
others see this black dust up there?
What are other's snow and winter experience? (no cracks needed from the
SCAL group about moving away from the snow!)
Alex Peterson
RV6-A N66AP 696 hours
Maple Grove, MN
Subject: | Re: Van's Alternator Weight's (Reliability of alternators Van |
is selling)
About 7.3 lbs for the 60 amp. If you are worried about weight go with the smaller
industrial ND alternators like Niagara Air Parts sells. They weigh about 6.1
lbs and the brackets are going to more compact (lighter).
The Niagara kit has everything for $275. Also most important, Niagara supplies
only NEW genuine ND alternator, not a rebuilt alternator with aftermarket brand
replacement parts (like Van sells).
The Niagara / Nippondenso (ND) alternator is rated at 40 amps, but if you rated
it like Van, it would be a 45 amp alternator. Not sure why Van calls his alternator
is 60 amps, it's a 55 amp alternator at 5000 rpm. Alternators do tend
to make more power at higher RPM's, but the standard rating is at 5000 rpm.
The quality control of Van's supplier, where he buys rebuilt alternators is a
little questionable. ND alternators are VERY reliable, but there have been many
"events" with rebuilt alternators from Van, like: DOA, fails in hours of use,
voltage regulator starts to act odd (unstable voltage control) and a few other
things. In 15 years of using ND alternators (in both cars and planes), I have
never had a problem and have 1000's of combined hours on them. However these
are all genuine ND alternators, not rebuilds.
Reading and talking to other builders it seems there is a disproportionate number
of problems with the ND alternators Van sells. In fact of the 4-5 problems
I know of, every one came from Van. Where Niagara has never had a return or
complaint in 8 years.
If a rebuild is done well, with all serviceable parts replaced, with best quality
parts (even aftermarket just good aftermarket), inspected, assembled and
tested with care, they can be OK. However the quality of many rebuilds are suspect.
Go to automotive message boards and read about all the people who buy rebuilt
alternators for there car and complain about how long they last, not long.
A new ND alternator (brand new original ND) is much better than a rebuild in
my opinion, if you can get them. Unfortunately the Suzuki Samurai NipponDenso
alternator Van sells can not be bought new from ND. So you have to pick your supplier
carefully.
George
>From: Leesafur(at)aol.com
>Date: Dec 04, 2005
>Subject: VANS ALTERNATOR WEIGHTS
>Thanks Lee
>RV-3
Alex,
From up in not-quite-frozen-yet Vermont I have to offer that I have had the
same problem from time to time. I try to stay off the brakes while landing
so as to keep them cool. As a practical matter, it means rolling out to the
very end of the runway after landing and using the rudder (as you describe
below) to maintain directional control as much as possible. I don't recall
ever heating them up too much while just taxiing.
I do recall a thread about brake return springs on some of Van's older
brakes being too short. That might cause the brakes to drag even when your
feet are off them.
I don't see brake dust on the tops of my wheel pants. That's a new one.
Steve Soule
N227RV RV-6A
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Alex Peterson
Subject: RV-List: Freezing brakes
> a new one.
Steve,
It is not brake dust, it is tire dust. I noticed a big reduction in the
amount of it when I changed to a different tire brand. The black dust finds
its way up the gear leg and comes out through the gaps in the fuse/gear
fairing intersection fairing. I only bring it up here in case my setup is
somehow "pumping" snow dust up into the wheel fairings differently from
others.
Alex Peterson
Maple Grove, MN
Alex,
I do get that dust and just where you notice it. I believe you're right
about the mechanism.
Steve
Subject: RE: RV-List: Freezing brakes
> a new one.
Steve,
others.
Alex Peterson
Maple Grove, MN
Subject: | Avionics, ACU, etc |
I'm trying to decide what exactly I need in terms of an ACU (Annunciation
Control Unit) for my setup.
My avionics are:
GNS430
GNC300XL
GMA340
GI106A
GTX327
Right now I only only a single GI106A. When this is connected to the G430, I
understand the G430 can select between GPS input and NAV input. i.e. it has
a built in ACU.
What about the 300XL? I too can be connected to a GI106A and display GPS
track information. But for this to occur you need to have an external ACU
to select between GPS/NAV, as well as ARM and ACTV the approach for
non-precision approaches.
So what if I only have 1 GI106A? Do I still need this ACU? The G430 will
change it without the need for an ACU. Right now I;m considering getting a
second GI106A and the ACU to hook up to the G300XL. Would this be the best
solution? As well I presume since I'll be only be doing non-precision
appracohes with the 300XL then I only need the GI102A, not the 106A
(glideslope indication as well).
Can someone clarify this for me?
Thank you
BobR
From: | Darrell Reiley <lifeofreiley2003(at)yahoo.com> |
Subject: | Just ordered my Ti-Downs in Stock |
Hi Group,
I just ordered my Ti-Downs from Rob. Yes, Randy made them and they are the 5
loop with the bag, ropes and all.
Darrell
rv6n6r(at)comcast.net wrote:
>Got a question:
>Just a thought.
Randall
Single? There's someone we'd like you to meet.
Subject: | Re: Van's Alternator Weight's (Reliability of alternators |
Van is selling)
Airtech sells a new ND alternator kit for Lycomings with bolts, brackets and all
for $199.95. I bought one, very nice kit, excellent service!!!
Darrell
is 60 amps, it's a 55 amp alternator at 5000 rpm. Alternators do tend to
The quality control of Van's supplier, where he buys rebuilt alternators is a little
I know of, every one came from Van. Where Niagara has never had a return or complaint
in 8 years.
parts (even aftermarket just good aftermarket), inspected, assembled and tested
A new ND alternator (brand new original ND) is much better than a rebuild in my
opinion, if you can get them. Unfortunately the Suzuki Samurai NipponDenso alternator
carefully.
George
>Date: Dec 04, 2005
>Thanks Lee
>RV-3
Darrell
RV7A - 622DR Reserved
Van is selling)
How about a web site for Airtech? I get no joy on google
Denis Walsh
> brackets and all for $199.95. I bought one, very nice kit,
> Darrell
Subject: | Re: Just ordered my Ti-Downs in Stock |
<< I just ordered my Ti-Downs from Rob. Yes, Randy made them and they are the 5
Darrell >>
I must have missed something, who's Rob? I really want a set of Randy's tie downs
so if there is a way to get them, other than throwing some money in the ring
and hoping for the best, I'd sure like to know about it.
Harry Crosby
RV-6 N16CX, 161 hours and down for painting.
Subject: | Re: Cream colored bottom. |
Mike, try using TCP and see if it stops happening. My guess is that for
some strange reason lead is not being scavenged as well in one side of your
exhaust, but is in the other. Temperatures too low maybe to effectively
scavenge lead? I wouldn't be too concerned about it, unless you were
fouling plugs, or had too much lead in your oil.
I only see the lead deposits in the last 3-4" of my exhaust pipes...if I
look further up inside I see the normal sooty stuff. I imagine it has
something to do with the temperature of the pipes which causes the lead
deposits on the coolest part of the exhaust system.
Bob Japundza
RV-6 flying F1 under const. (perpetually)
On 12/5/05, Stewart, Michael (ISS Atlanta) wrote:
> mstewart(at)iss.net>
> What is the cream stuff exactly? Burnt lead?
> Do I need to be concerned?
> Do something? Do nothing?
Subject: | VNY FSDO weirdness |
Howdy folks,
We've applied at the VNY FSDO for a new set of operating limitations
based on the latest version being offered by the FAA so that we can
equip and operate our RV-6a as an IFR aircraft. I had an appointment to
pick up our amended oplims today, but the inspector just called to tell
me that experimental aircraft are not allowed at VNY, BUR and WHP (where
we're based) and some other airports as well. I objected to this
vehemently and requested that he show me chapter and verse in the
regulations where it says that they have any authority to prohibit
certain types of aircraft from specific airports. He said he'd do some
research and get back to me, but canceled our appointment for this
afternoon.
I had heard that VNY FSDO had tried this tack in the past, but thought
they had been shown the light. Has anybody else run into this kind of
bull? How did it shake out?
Pax,
Ed Holyoke
Subject: | Cream colored bottom. |
>And Bob J, what is TCP?
TCP is a fuel additive that is supposed to help minimize lead fouling.
Ron Lee
Subject: | Received Ti-Downs TODAY |
WOW... that was lightning fast. I ordered my Ti-Downs on Friday 12/02/2005. I received
them today Monday 12/05/2005, and there was a weekend in there too.
Everyone is correct in that they are beautiful!!
Darrell
Subject: | Re: VNY FSDO weirdness |
Ed ,
Did you say out to lunch?
Jim
Oh - I hope not. :-)
I did get a cal back from the EAA guy. He thinks that perhaps the FAA
guy is confusing first flight/flight test restrictions with normal
operations and will relent when this is straightened out. He was going
to call the inspector to try and resolve it. No call back from either
party yet.
Pax,
Ed Holyoke
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James H Nelson
Subject: Re: RV-List: VNY FSDO weirdness
Ed ,
Jim
OK - here's the latest.
The FAA airworthiness inspector called me back. It seems that we did not
communicate well this morning or at our previous meeting. The issue
appears to be the flight test area and corridor to get to it and back,
not where the aircraft is based. He said that he is ready to issue the
oplims as soon as a flight test area can be defined to his boss's
satisfaction. This is the area in which the aircraft will have to be
flown if and when it is returned to Phase I operations after a major
alteration. Following 5 hours in the test area and a logbook entry, the
aircraft can be returned to Phase II operations. He was reading the
boundaries of the flight test area as it was defined in our original
oplims in '98 and thinking that I was asking for the same area verbatim.
I had told him that I would accept any reasonable test area and that it
doesn't have to be the same as the original. Since '98 they have
redefined most of that area including WHP as densely populated. He says
we'll have this worked out within a few days. Hope so.
Pax,
Ed Holyoke
INNOCENT GLOBAL 0.0063 1.0000 -4.3997
NO!NO!NO
It is a big scam. Trust me. Look at the feedback. All from sellers, not
buyers. These guys are in Romania. Even the guy they give for reference
doesNOT work for Ebay. I checked it out. When I first looked there wer 8 or
10 of these. After Ebay investigated, there was one. Also notice, the email
address chandes a lot. AND there is NO way to get the money back. Thats why
they use Western Union. Like they say, "if its too good to be true......."
Al Grajek
Subject: | Priming/painting piano hinges? |
Hi everyone. Just a quick question.
For those who prime most everything before assembling, do you prime
piano hinges as well? And/or for those who paint their aircraft, do
the hinges get painted? Or should they be masked before painting the
plane, and skipped in priming?
I don't have my packing list handy at the moment, so I don't know if
the hinge is stainless steel or otherwise already fairly impervious
to corrosion. In any case, if everything else is being primed/
painted, I'd be tempted to be consistent, except for the concern that
primer and/or paint would get into the hinge itself, stiffening its
travel...
Any suggestions?
Thanks.. Dan
Syzygy Research & Technology
Box 83, Legal, AB T0G 1L0 Canada
Phone: 780-961-2213
From: | "Brian Kraut" <brian.kraut(at)engalt.com> |
I have painted several hinges without a problem. Keep the grease in the
hinge pin to a minimum and be sure to clean the outside surfaces good to
keep the paint from chipping off. You will get some paint chipping on the
hinge anyway, but not too much. I don't bother to prime the hinge before
riveting it on. You can just shoot primer on it and the surface it is
rivited to at the same time. Aluminum hinges are anodized fairly well so
you don't really need to worry about them corroding on the back sides.
Brian Kraut
Engineering Alternatives, Inc.
www.engalt.com
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dan Charrois
Subject: RV-List: Priming/painting piano hinges?
travel...
Any suggestions?
Thanks.. Dan
Phone: 780-961-2213
From: | Alan & Linda Daniels <aldaniels(at)fmtc.com> |
Subject: | Re: Priming/painting piano hinges? |
I think it is personal preference. I fit the hinge and even hold it in
place with a soft pop rivet if needed, but then remove it to paint the
other surfaces. For me the paint seems to chip on the hinge so I polish
or leave anodized and do final install after painting.
>travel...
>Any suggestions?
>Thanks.. Dan
>Phone: 780-961-2213
Nordo,
What does this refer to? I am always looking at Ebay.
I am always leary.
Dave Nellis
--- Al Grajek wrote:
> NO!NO!NO
> give for reference
> Al Grajek
> Click on
> about
> provided
> www.buildersbooks.com,
> Admin.
> _->
> browse
> Subscriptions page,
> FAQ,
dsl.yahoo.com
From: | "Kelly McMullen" <kellym(at)aviating.com> |
FAA-speak for NO RADIO. As in no comm or lost comm.
> Nordo,
> I am always leary.
> Dave Nellis
>> NO!NO!NO
Subject: | Proptach for sale |
Hi Listers,
I have satisfied myself of the calibration of my panel tachometer.
I no longer need my Proptach which, if you are not familiar, is a hand
held optical tachometer that allows you to check your prop rpm directly.
It cost me about $200 and I'll sell it for half price.
Please contact me off list.
Richard Dudley
-6A 70 hours
I need to order an engine soon and need to decide between a Mag/Lightspeed
system or an E Mag/P Mag. Any input would be appreciated.
John Furey
RV6A
F1 in process
Subject: | RV-7 Tip or slide? time to pick |
INNOCENT GLOBAL 0.0000 1.0000 -4.4912;INNOCENT GLOBAL 0.0000 1.0000 -4.4912
Ok, I need to order the fuselage before the price increase & the
operational ups & downs of tip vs slider seem to balance, at least for me.
The tipping point (pardon the pun) seems to be installation pains. I
know that in the past, slider frames have been really tough for a lot of
people.
Those of you who have been there recently building the -7/-9 slider,
what's it been like fitting the frame, start to finish? The guys at
Van's are hinting that the new frames fit with less of a struggle.
Subject: | Just orderd RV-8 |
!!!!!I just ordered my RV-8 QB !!!
My first kit I'm SO EXCITED
Dan,
Cleaning out the Garage !~ to make room !@@!
Subject: | Re: Received Ti-Downs TODAY |
Now you really got me curious Darrell, what did I miss.
apparently someone was selling Ti tiedowns. How about filling me in now
that you have yours. Thanks.
Harry Crosby
> 12/02/2005. I received them today Monday 12/05/2005, and there was a
> Darrell
Subject: | Deluxe Fuel Caps |
G'day all,
Several weeks ago I threw out a question asking for feedback on the
Deluxe Fuel Caps available from Van's. I got a couple of responses, but
the overall dearth of interest I took to mean that almost no-one has them.
So . . . . . . now that I have the caps in my hot little hands, I
thought I would throw out a PIREP for anyone searching for the answer to
the same question in future.
Straight out of the box the Deluxe Caps look nicer than the standards
with a more polished appearance. The dimensions of both are the same
with the exception of the diameter of the filler neck, which is less on
the deluxe caps due to the locking mechanism. The flange on the deluxe
caps has a curve machined into it, so there is no need for any flange
bending. That being said, the curve is a little too tight to fit the
RV-10 tank skins well, I would imagine it would fit the other model's
tanks much better. Nothing a bit of Proseal can't fill in any case.
The standard caps have no separate locking mechanism. They are held in
with the seal, which is formed by squeezing an O-Ring, forcing it
outwards against the filler neck. I have seen a number of people report
fuel leaks from around this seal.
The deluxe caps have a two stage mechanism. The lowering of the clip
presses the O-Ring at the top of the cap down against the angled wall of
the filler neck, forming a more positive seal. With the clip up (and
seal released) the cap is still held in, though it is loose. The cap is
released by turning the clip 45 degrees, at which point the caps easily
lifts out (as opposed to the force required to pull out the standard
cap). The deluxe caps also can come with a key lock which is hidden
below the clip.
Overall all I am very impressed with these caps and very glad I bought
them. Besides the fact they are just better, I think the ability to
lock them is valuable in this day and age (unfortunately). Yes, they
cost significantly more than the standard caps, but compared to the
amount of money we are sinking into these aircraft . . . . . . . .
I will be uploading some pictures into the Photoshare which hopefully
will clarify some of my babble from above!!
Have fun all,
Scott Lewis
RV-10 40172
Adelaide, South Australia
Subject: | RV-7 Tip or slide? time to pick INNOCENT GLOBAL 0.0000 |
Man, you've come this far and that's what's holding you up is a little (!)
difficulty fitting the frames. What about the ingress / egress, water on
the avionics, venting when taxiing, where the roll bar is placed, wind, etc.
Or coolness factor. You're a builder. No stinking frame fitting can stop
you now! Go for what you want. Until I switched over to the RV-10, it was
tip up all the way for me. My son wanted a slider. He also want a little
wheel in the back and an RV-8, but he didn't have the check book.
John Jessen
~40328 (Empennage)
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie England
Subject: RV-List: RV-7 Tip or slide? time to pick INNOCENT GLOBAL 0.0000
Ok, I need to order the fuselage before the price increase & the operational
The tipping point (pardon the pun) seems to be installation pains. I know
that in the past, slider frames have been really tough for a lot of people.
Those of you who have been there recently building the -7/-9 slider, what's
it been like fitting the frame, start to finish? The guys at Van's are
Great news, Dan! Now, remember, it's less of a marathon than it used to be,
but that's what it is. Take your time and enjoy!
John Jessen
~40328 (VS, Rudder, HS finished)
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan
Subject: RV-List: Just orderd RV-8
Dan,
Charlie,
I opted for the slider for the only reason that it gives a hand hold to get
in and out with. I hope that if I have any difficulty making it fit I can
call on some of the local builders in the area, have them over for a cold
drink and hope they will give me a hand in diagnosing the situation.
Bob Perkinson
Hendersonville, TN.
RV9 N658RP Reserved
If nothing changes
Nothing changes
people.
Subject: | Re: RV-7 Tip or slide? time to pick INNOCENT GLOBAL 0.0000 |
I believe the balance has changed! It is now harder for most
builders to do the tip up than the slider. As I see it, the reasons
are: Slider instructions are much better, frame is now made quite a
bit different and is more builder friendly. Tip up looks to me has
not changed much at all.
Let's hear from the guys at teh builders centers!
Denis Walsh
On Dec 7, 2005, at 7:51 AM, Bob Perkinson wrote:
> Charlie,
> hold to get
> fit I can
> a cold
> Bob Perkinson
> Hendersonville, TN.
> RV9 N658RP Reserved
> If nothing changes
> Nothing changes
> for me.
> lot of
> people.
> Thanks,
> Charlie
Subject: | Re: RV-7 Tip or slide? time to pick |
Paul Folbrecht wrote:
> Where do you fly? I have to think being able to pull the slider back on
> the ground in the summer is huge.. I roast in my 152 with the windows
> open even on those long taxis, waiting for release, etc...
> If I were in Seattle where it was never 90 and humid I think I'd want
> the tip-up.
I fly, just as Mike does, in the hot, humid, muggy, sticky, hazy
Southeast USA. In my opinion, the oft-repeated advantage of the slider
in hot climates is overstated. The tip-up latch allows the canopy to be
placed in a taxi position that creates a strong flow of air from
propwash through the cabin at face level that allows the occupants to
stay reasonable comfortable. Any RV is going to be warm during taxi in
the summer, but I have never found the tip-up to be uncomfortable enough
to tempt me to trade away the fantastic visibility the tip-up offers.
Now...as far as whether or not to prime the inside of the airframe..... ;-)
Sam Buchanan (~700 happy, comfortable hours in a tip-up RV-6)
Stick with the tip-up unless you enjoy laying on hard aluminum bedding and like
to look at roll bars in your vision while you fly. It will not take but once
or twice having an under the panel issue and a slider to really pis* you off.
Oh, then those cuts and bruises on the forehead from getting out from under the
panel...
And, both canopies will leak if care is not taken when they are built up and
installed. With a little TLC...and work both types will keep things pretty dry.
Darrell
people.
I like the slider for the summer months when it is hot. Its nice to be
able to slide the canopy back after landing.
I live in Wyoming where the wind blows A LOT!. That is the main reason I
went with the slider. I would hate to loss the canopy to a 30-35 mph
gust, and yes I have landed in those kind of winds and maybe more.
John L. Danielson
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan
Subject: Re: RV-List: RV-7 Tip or slide? time to pick
on
> the tip-up.
From: | "BRUCE GRAY" <brucerv84us(at)hotmail.com> |
Subject: | Flap Actuator Template for RV8 |
I guess I am slow but have missed the address or e-mail to get this drawing
of the template. I have seen a real nice cover made by Jim Daniels in New
Mexico on his RV8 and I'm curious if this is the one evryone is sharing?
If possible can someone re-post it to the list or send it direct to my
e-mail (brucerv8 at charter dot net)
TIA,
Bruce Gray
RV8 Fuse
IN PREP STAGES FOR RIVETING(In Jig)
John,
Are you familiar with the "Aeroelectric List" ? Lots of discussion about E/P
mags over there. Archive search will turn up tons of 'em...
_http://www.matronics.com/listbrowse/aeroelectric-list/date.html_
(http://www.matronics.com/listbrowse/aeroelectric-list/date.html)
Jerry Cochran
Wilsonville, OR
Subject: RV-List: E Mag
John Furey
RV6A
F1 in process
From: | "Chuck Weyant" <cweyant(at)chuckdirect.com> |
If you're going to travel the Country, I'd get a slider. I landed and
parked in Bullhead City, AZ a couple of months ago to spend a couple of
nights in Laughlin, NV (across the river) and the desert wind was blowing.
Their parking arrangment was such that you could not park into the wind. I
remember thinking I had made the right decision choosing the slider. Now my
question is, what's the best rudder lock for a Nine?
Chuck Weyant
RV9A
> John L. Danielson
> on
>> the tip-up.
Dan,
Congratulation - "Fun Begins"
but wait until you flight your 8 - Wow
Best Wishes,
Chuck Rowbotham
RV8A
>From: Dan <dan(at)rdan.com>
>Date: Tue, 6 Dec 2005 20:25:06 -0800 (PST)
>Dan,
From: | "Oliver Washburn" <ollie6a(at)earthlink.net> |
A good case for the slider in my opinion is take a look at which should
give you the most protection in case of a nose over. I lost a good friend in
a nose over in a tip-up this year.
Ollie
Subject: RE: RV-List: RV-7 Tip or slide? time to pick
> John L. Danielson
> on
>> the tip-up.
From: | "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net> |
Ollie,
Is it your opinion that your friend would have lived with the rollbar?
Was this an RV?
Very sorry about your friend
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Oliver Washburn
should
friend in
Ollie
I
> John L. Danielson
> on
>> the tip-up.
be
enough
airframe.....
What reference material are you using that states the tip-up caused the death?
Darrell
Ollie
> John L. Danielson
> on
>> the tip-up.
From: | "oliver h washburn" <ollie6a(at)earthlink.net> |
Mike,
Yes it was an RV and i suppose there is no way of knowing, but if you lay
a straight edge on a tip-up drawing it goes right through the tip-up and
just maybe a rollbar would have prevented his broken neck. I was the second
one there and I"m saying no more.
Ollie
> [Original Message]
> From: Stewart, Michael (ISS Atlanta) <mstewart(at)iss.net>
> To:
> Date: 12/7/2005 3:04:02 PM
> Ollie,
> Was this an RV?
> Mike
> should
> friend in
> Ollie
> From: "John Danielson" <johnd(at)wlcwyo.com>
> To:
> I
> > John L. Danielson
> > on
> >> the tip-up.
> be
> enough
> airframe.....
What would be the basis for believing that the slider would provide better
protection if you turn turtle in an RV? My inclination is to believe the
opposite, that a tip-up would be better, based on the roll bar being closer to
your head. While there might be specific examples where a slider would have
provided more protection, can anyone describe a general principle that would
suggest that they are safer?
Tedd McHenry
Surrey, BC, Canada
From: | "czechsix(at)juno.com" <czechsix(at)juno.com> |
John,
I think it depends on your objectives. If you want the simplest installation, go
with the E-Mag/P-Mag combo. If I had to do it over, that's what I'd do. I put
dual Lightspeeds in my airplane (before the E/P-mag products were announced).
Lightspeed does retain a couple advantages over the E/P-mags. One is that if
you use the crank-triggered timing pickup(s) on the Lightspeed system, it has
zero moving parts which in theory makes it more reliable in the long term. A
second perceived advantage from talking to both vendors is that Lightspeed's timing
curves are a bit more aggressive and have a proven track record of superior
efficiency (i.e. Klaus Savier's racing records and Jon Johanson's round the
world flights). I talked to the guys producing the E/P-Mags and they told me
their timing curves were more conservative (this could also be a good thing if
you question whether Lightspeed's timing curves may be getting too close to
the limit...but lots of Lightspeed systems have been running out there and I am
not aware of any documented engine damage occurring as a result of the ignition
timing).
That said, the downside to the Lightspeed system is that it's more of a pain to
install...you gotta mount the control box, mount the coils, run coax from the
box to the coils and then the ignition leads from the coils to the spark plugs.
Oh and by the way the box is supposed to be mounted outside of the engine compartment
meaning you have to run wiring & man. pressure hose through the firewall
and find someplace in the cabin to put the box. If you ignore this advice
like I did, you have to worry about heat and moisture getting into the control
box. And the ignition leads may not be the right length depending on where
you mount the coils, so you may have to send them back like I did and get new
ones made to fit your installation. And then if you have dual Lightspeeds you
have to worry about backup electrical source (a second battery in my case).
The E/P-mag system is so much easier to install as a system, and especially since
you don't have to worry about backup electrical source, that I would go that
route if I had to do it over. The only reason I would hesitate on the E/P-Mag
system at this time is because they have a relatively short track-record and
it's possible that you could experience unforeseen problems with the system and/or
company. But we already know that Lightspeed is not without its issues....not
the least of which is starter kick-back which has been well-documented by
a number of unfortunate souls on this List.
That's my advice, worth what ya paid for it...
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D almost ready for final inspection, in the middle of an Iowa ice age...
John Furey
RV6A
F1 in process
John,
timing).
meaning you have to run wiring man. pressure hose through the firewall
box. And the ignition leads may not be the right length depending on where you
mount the coils, so you may have to send them back like I did and get new ones
made to fit your installation. And then if you have dual Lightspeeds you have
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D almost ready for final inspection, in the middle ofan Iowa ice age...
-- RV-List message posted by: "John Furey" john(at)fureychrysler.com
John Furey
RV6A
F1 in process
The only down side to the lightspeed system as I'm told is the owner... many complaints
that his attitude if you have a problem, it's your problem as in if something
has gone wrong you had to of screwed something up on your own... he accepts
no responsibility. I've heard this from many builders trying to get support
out of him.
Darrell
"czechsix(at)juno.com" wrote:
John,
the limit...but lots of Lightspeed systems have been!
running out there and I am not aware of any documented engine damage occurring
as a result of the ignition timing).
--Mark Navratil
Cedar Rapids, Iowa
John Furey
RV6A
F1 in process
John,
--Mark Navratil
Cedar Rapids, Iowa
John Furey
RV6A
F1 in process
Darrell
Subject: | Cleaning out the hanger sale |
I have finally gotten around to gathering up some odds and ends that have
accumulated that I will sell to a good home for the right price. As always,
email me direct at brian(at)engalt.com, not to the entire list. You can also
call me at 904-536-1780. Here is what I have at the moment:
Midget Mustang, 109 hours TT, O-200 with about 1,100 hours SMOH, 174 MPH
cruise, new Imron paint job, custom stainless exhaust, VFR day/night -
$22,000 OBO
Sonerai II, 450 hours TT, 1835 VW with 55 hours SMOH, good flying
condition - $9,000 OBO
KR-2, 45 hours TT, Revmaster 2100 turbo with 45 hours TT, was flying, but
one wing water damaged, have new spars to build another. Whole plane -
$8,000, engine only with Hegy prop - $3,500, will sell cowl, engine mount,
and rest of firewall forward package for $500 with engine, brand new Grove
gear and mounting brackets $1,100. Will not sell gear separate unless
someone else buys the plane without it.
Vacuum pump, mounting bracket for VW, filter, regulator, vacuum gauge,
attitude indicator, and heading indicator - $1,000.
Brand spanking new Garmin GTX 320A transponder in original box with tray and
all connectors - $1,000.
Nice small IFR radio package including Terra TX720 com radio, Terra TN200
nav receiver with ILS and glideslope, Arnav 20 loran, Terra Trinav C display
with digital CDI for nav or loran, ILS indicator, and glideslope indicator,
ICS intercom with 3 light marker beacon - $3,000 for complete package with
all trays and wiring harnesses.
Bendix TR-641 A transponder with brand spanking new ACK encoder already
wired to it - $700.
RT-359A transponder with brand new ACK encoder already wired to it - $700.
Sportys SP-200 handheld with headset adaptor cables - $220.
Garmin GPS-90 aviation handheld GPS with yoke mount, external power cord,
external antenna suction cup mount, original manual, and cigarette lighter
plug $120.
1965 bomber emergency parachute with C9 canopy freshly certified and
repacked - $400.
All located in Jacksonville, FL.
And no, I am not getting out of flying, just need more room at the moment.
Once two of the planes go the other one comes off the market until I get my
KR-2S done.
Brian Kraut
www.engalt.com
From: | Richard Scott <rscott(at)cascadeaccess.com> |
As Ollie said, draw a line from the top of the tail to the nose on both
designs. On the slider, there is quite a rise in the line as it goes over
the rollbar, not so on the tip up. At 6'2", as I sit in a tip up, my head
is almost as high as the rollbar. Bodies & belts stretch quite a bit. If
I flipped in a tip up I expect the top of my head would get quite a whack
and could easily break my neck. In a slider, I might hit the canopy, but
that's a lot softer than the pavement. Which you rather hit, a plexiglass
canopy, or a canopy backed up by pavement?
Of course if the tail bends very much, all bets are off.
Richard Scott
RV-9A
Wings
Subject: | Re: RV-7 Tip or slide? (pleaseeee) |
>From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV-7 Tip or slide?
>The other day, we were doing formation practice. I heard something I never
>thought I would ever hear...a pilot (who shall remain nameless) admitted
>that the slider got in the way of his view. We were trying to polish
>echelon turns, and this guy commented, "When I turn right, I get a face
full
>of metal."
>Nuff said. ;-) There's nothing like the visibility in the tip-up.
Dan:
Tell him lean 1-inch forward, or move his head back or forward or left or to
the right.
Geeeeeee, lol.
Me thinks he exaggerate, but the tip-up does have an unobstructed view just like
my RV-4;
My RV-7 has a slider, but the way you did it Dan, is perfect for you.
Nuff said ;-) George
>many complaints that his attitude if you have a problem, it's your problem
>as in if something has gone wrong you had to of screwed something up on
>your own... he accepts no responsibility. I've heard this from many
>builders trying to get support out of him.
> Darrell
I have exactly the opposite experience. When I had a problem, which
ultimately may have
just been some contact "corrosion," Klaus sent me replacement parts to help
diagnose
the problem. In the process of replacing things the problem cleared and
he tested my
unit for functionality.
So I was happy with his support.
Ron Lee
Subject: | Re: RV-7 Tip or slide? |
Here is an article that may help. Bottom line is that both have advantages
http://www.vansairforce.net/articles/tipupvsslider.htm
Ron Lee
One thing I'd like to point out is that a roll-over stucture is not the only
thing required to protect the occupants in a roll-over accident. Having
crotch straps in your harnesses will help protect the occupants from sliding
up the seats and might make the difference in avoiding any injuries of the
vertebrae (ie broken neck.)
For me, having a slider in the -6, I will never have one again.
Bob Japundza
RV-6 flying, F1 under const (tip-over canopy and rollbar)
From: | "charles heathco" <cheathco(at)junct.com> |
Subject: | Tip up vs slider |
I see on digest there is lots of responses , didnt read em all but here is my 2
cents worth as an older fellow. Its very easy to grab the hand holds on the roll
bar on the slider and drop in or pull yourself out, I only got in and out
of a tip up once, and found it much harder to get in and out of. Charlie Heathco
Subject: | Lying on medical |
Anybody see the report of the guy making false statements on his med aplication
and is now facing federal charges that could get him 5 yrs in the pokey and or
$250000 fine? Charlie Heathco
Yep, and if he hadn't passed out while flying, he'd still be.
Bruce
www.glasair.org
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of charles heathco
Subject: RV-List: Lying on medical
aplication and is now facing federal charges that could get him 5 yrs in the
pokey and or $250000 fine? Charlie Heathco
A friend of mine did NOT lie on his medical about a very light dose of
anti-depressants he was taking (Hay, he flies a Beech Sundowner; you
would be depressed too!) and he had to fight with the examiner and the
FAA for 8 months to be reinstated from suspension. Right after
reinstatement his plane went into annual and so that was the better part
of a year W/O flying all the time paying for a tie down, insurance
etc... I am not suggesting one needs to lie but some of the systems and
procedures of the FAA as are antiquated as the steam gauges we are
flying behind.
Robin
RV-4 200 hours
Subject: | Re: Lying on medical |
Charles,
Could you give me the URL for that report. I'd like to include it on my website.
Jim
Jim Pellien
www.MASPL.com
703-313-4818
jim(at)sportsplanes.com
---------- Original Message ----------------------------------
Date: Thu, 8 Dec 2005 13:14:51 -0600
Sent via the WebMail system at mail.pellien.com
> Bob Japundza
Is that because the F1 will be the last one you will have?
Seriously, please give your reasons.
Most of the discussion seems to be from tip up builders defending their decision.
I'm building a slider because I like the look of it and on balance the practicalities
seem about the
same.
I simply do not like the appearance of a tip-up when it is open or part open.
I don't like the behind the panel & wiring exposed to the world. It's a bit like
exposing your
underwear in public, only rarely is it attractive. I'm sure a suitable cover can
be fabricated so it
is probably not a consideration.
I also do not like the jigglys when taxying.
The $ risk of damaged avionics due to water leakage behind the panel via the hinge
slots was the
final clincher.
A down side of the slider is the extra metalwork in the field of view. However,
when flying I have
never noticed my view to have been obscured by frames or bars and without exception
the few aircraft
I have flown have had much more metalwork to look at than in the RV slider.
I real plus for the tip up is the access behind the panel. For the slider you
can choose to add sub
panels for some instruments or a screwed access panel on the top skin.
Most practical issues can be addressed so IMO it comes back to general aesthetics.
Doug Gray
RV-6 Fuse - soon to commence the canopy
From: | bcollinsrv7a(at)comcast.net (Bob Collins) |
I wish the FAA would lighten up on the anti-depressants a bit, my son could fly.
However I realize why they don't. The side-effects can be devastating including
seizures. But rather than just a blanket ban on pilots, I'd like to see some
sort of medical evluation of the pilot, the med and the situation instead
of the FAA version of the "soup Nazi."
-------------- Original message ----------------------
From: | "Steve Sampson" <SSampson.SLN21(at)london.edu> |
Ollie - sorry to dwell on this, but did it tip over forwards with the
nosewheel collapsing or some other way. Steve.
From: "oliver h washburn" <ollie6a(at)earthlink.net>
> Mike,
> second
> Ollie
>> [Original Message]
>> To:
>> Ollie,
>> Was this an RV?
>> Mike
>> should
>> friend in
>> Ollie
>> To:
>> I
>> > John L. Danielson
>> > on
>> >> the tip-up.
>> be
>> enough
>> airframe.....
>> > http://thervjournal.com
> This email has been scanned by the MessageLabs Email Security System
> on behalf of the London Business School community.
> For more information please visit http://www.messagelabs.com/email
> 07/12/2005
Never gave it much thought, but my son just got his 3rd class medical in the
L.A. area a month ago and in the course of the conversation, the Dr. told him
he knew of examiners that would pass you for X amount of dollars regardless of
medical history. I realize it's totally devious and illegal, but .....would
be tempting if you had some issues.
>fly. However I realize why they don't. The side-effects can be devastating
>including seizures. But rather than just a blanket ban on pilots, I'd like
>to see some sort of medical evluation of the pilot, the med and the situation
>instead of the FAA version of the "soup Nazi."
>From: "Robin Marks" <robin(at)mrmoisture.com>
Subject: | Weight & Balance Arm |
Getting ready to weigh my RV8A QB, I'm coming up with main wheel to wing leading
edge distance of 22 9/16 inches. The sample RV8A W&B in my instruction book
shows 24 inches. The plane is sitting at a 3 degree nose up angle, but I thought
I'd be closer to the book number than this. Could those of you who remember
let me know what your number came out for your RV8A?
Dave Reel - RV8A
Subject: | Re: RV-List Digest: 38 Msgs - 12/07/05 |
I have a UPSAT CNX-80/GARMIN GNS-480 install kit/rack for sale. Was wired by
John Stark Avionics last year. Cost me $550, asking $400.
E-mail if interested: loflinj(at)comcast.net
-Jack
Subject: | CNX-80/GNS-480 Rack/Install kit |
-Jack
Received-SPF: none
I don't know about lying on the medical forms, but from what I know that
most drugs used to treat medical disorders will be disqualifying for a
medical. I have not found this out on my own...even though my wife is
trying her hardest to get me to need such drugs. Also, if you do lie on
your medical, you might as well save the insurance premium, since in most
cases when the truth comes out the insurance won't pay.
Jim
Jim Cimino
N7TL
RV-8 S/N 80039
150+ Hours
http://www.geocities.com/jcimino.geo/
> flying behind.
> Robin
> RV-4 200 hours
Subject: | Re: Weight & Balance Arm |
> wing leading edge distance of 22 9/16 inches. The sample RV8A W&B
> in my instruction book shows 24 inches. The plane is sitting at a
> 3 degree nose up angle, but I thought I'd be closer to the book
> number than this. Could those of you who remember let me know what
David,
If you drop a plumb line from the wing leading edge, and then slowly
tip the aircraft nose up, the distance from the plumb line to the
main wheel will decrease as you tip the aircraft up. Your
measurement of plumb line to main wheel is 1 7/16 inch less than you
expected, and your fuselage is tipped 3 degrees nose up. If your
main wheel was exactly where Van said it should be, and you tipped
the aircraft 3 degrees nose up, the error you measured implies the
leading edge is about 27.4 inches above the main wheel axle. This is
in the right ball park I think, so I suspect your main wheels are
roughly in the right place.
The aircraft really, really needs to be level when you do the weight
and balance. Otherwise it is a case of "garbage in, garbage out".
You would at first glance think you could simply measure the
distances from a plumb bob hung at the LE to the wheels, and use
those measurements, no matter if you aren't level. But, if we do
that, the empty CG we calculate is with respect to a line that is
sloped by 3 degrees from the vertical (because the aircraft was 3
degrees off level when you weighed it). This means we can't cross
reference to the recommended forward and aft CG limits that Van gives
us. Van's numbers are measured from a reference that is at 90
degrees to the fuselage reference line.
We could in theory correct your calculations to put them in the same
reference as Van uses, But, we can't make this correction unless we
know the vertical height of the aircraft's CG. We could
approximately figure that out if we took weighings at two very
different pitch attitudes and did some clever math (or plotting).
But, it is easier to simply level the aircraft, and do it once,
correctly.
Ottawa, Canada
AL 0.0000 1.0000 -4.4912;INNOCENT GLOBAL 0.0000 1.0000 -4.4912RV-7 Tip
or
Subject: | Re: RV-7 Tip or slide? time to pick INNOCENT GLOB |
or
I've opted for the slider on my '-7A. I think I can live with the slight
visual obstruction although I agree the tip-up would be better in this
regard. I like the slider for the western desert heat. I have mitigated
the instrument panel access issue by modifying the panel to hinge down based
on a design I saw in a recent RVator. I'm still in the process of building
the panel up but so far it's pretty slick - I can sit in the pilot seat and
basically drop the whole thing in my lap, or detach two bolts and some cable
connectors and pull the whole thing out to work on the bench. Easy mod.
http://www.w3.org/TR/REC-html40">
Ive opted for the slider on my -7A. I
think I can live with the slight visual obstruction although I agree the tip-up
would be better in this regard. I like the slider for the western desert
heat. I have mitigated the instrument panel access issue by modifying the
panel to hinge down based on a design I saw in a recent RVator. Im
still in the process of building the panel up but so far its pretty
slick I can sit in the pilot seat and basically drop the whole thing in
my lap, or detach two bolts and some cable connectors and pull the whole thing
"IMB Recipient 1"
AL 0.0000 1.0000 -4.4912;INNOCENT GLOBAL 0.0000 1.0000 -4.4912RV-7 Tip or
SNIP
> weight and balance. Otherwise it is a case of "garbage in,
> garbage out".
SNIP
> Ottawa, Canada
Maybe this has already been described, but a very easy way to get the plane
dead nuts level is to use about a 12 foot length of about 1/4" or larger PVC
tubing filled with water and taped to the fuselage. Put enough water in the
line to fill it from some forward part of the straight (level) longeron to
an aft location. Adjust the taped on tubing until the water levels are
close to the longeron. Now level the plane until the water levels are the
same distance above (or below) the longeron in both fore and aft positions.
One caution: make sure there are no bubbles in the water! Bubbles will
normally form in the tubing after a few hours, so if you come back to it
later make sure that you tap all the bubbles out.
Alex Peterson
Maple Grove, MN
Subject: | ND New Alternator kit |
This is a nice alternator kit available with a ND or Mitsu NEW alternator.
I bought one, Richard sells a nice kit. EBay 4596218435
Worth checking out and the price is right...
Darrell
Subject: | Re:Lying on Medical |
I wonder what the fine would be for flying with NO medical ??
Might be worth trying it out. Might accumulate a bunch of hours for free.
> > Bob Japundza
I put a flop-over canopy on my F1. The main reason being the panoramic
view, and not having to look around a roll bar when flying formation. Fly
several hundred hours in a RV-6 then go fly a RV-4 or Rocket, you won't know
what your missing until you remove the roll bar from your view. It was
easier, cheaper, lighter, and very easy to seal. I had a total of about $50
in building the frame and $300 for the canopy. I couldn't be happier with
how it came out. If I had to do the -6 canopy over, I't go with the tip-up.
Bob Japundza
RV-6 flying, F1 under const.
Just a guess but flying with no medical is better than flying with a
lyin' medical.
Chuck Jensen
> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-
> server(at)matronics.com] On Behalf Of Oldsfolks(at)aol.com
> Sent: Thursday, December 08, 2005 10:41 PM
> Subject: RV-List: Re:Lying on Medical
free.
Nose wheel bent, dug in and plane nosed over.
Ollie
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
> To:
>> Mike,
>> lay
>> second
>> Ollie
>>> [Original Message]
>>> To:
>>> Ollie,
>>> Was this an RV?
>>> Mike
>>> should
>>> friend in
>>> Ollie
>>> To:
>>> I
>>> > John L. Danielson
>>> > on
>>> >> the tip-up.
>>> be
>>> enough
>>> airframe.....
>> 07/12/2005
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
November 23, 2005 - December 09, 2005
RV-Archive.digest.vol-rl
