RV-Archive.digest.vol-rq
January 22, 2006 - February 02, 2006
      > let it dry over night.
      How accurate do you need to be when you mix the two parts of the
      Smooth Prime?  The directions make it seem like you need to be very
      precise, which doesn't seem easy if you do many batches.
      Kevin Horton         RV-8 (finishing kit)
      Ottawa, Canada
      http://www.kilohotel.com/rv8
Subject: Sensenich prop & not enough pitch?
Date: Jan 22, 2006
After 20 hrs. on my newly completed rv6, I am undecided as to what to do as far as changing the pitch of my Sensenich fixed pitch prop. At full throttle, I am seeing 2850 rpm. and nearly 2450 static. I have an 0-360 with 9.5 compression pistons and supposedly it puts out close to 195 h.p. The tach has been checked with an optical tachometer and is accurate. The climb rate right now is close to 2000 fpm and top speed is over 210 mph. I like the performance, just not sure I want to live with the higher rpms. I know I can throttle back to stay under red line, but am I then limiting my horsepower? Would my climb rate suffer much with more pitch? Anybody else had this situation and repitched? Just looking for some feedback. Dave Mader 2nd 6/20hrs. ________________________________________________________________________________
Date: Jan 22, 2006
Subject: Re: Sensenich prop & not enough pitch?
Dave: repitching, like FP props themselves, is a mixed bag. I was running over redline too easily with my Sensenich after upgrading the O-320 to the 160 hp pistons, (2600 rpm) so I took it to Sensenich Prop Service in Lancaster, PA and added 2". Much less overspeeding in gradual descents from cruise, but a lower ROC and static now 2150-2200 depending on the wind, baro, etc, which is also down a good 50-75 rpm. The tradeoffs were exactly what I was told to expect. I get about 1300 fpm solo; plenty for me, but not much by RV standards. The red warning light for rpm no longer comes on much in 75% cruise, which makes the wife happier somoehow. -Stormy -----Original Message----- From: DAVE MADER <davemader(at)bresnan.net> Subject: RV-List: Sensenich prop & not enough pitch? After 20 hrs. on my newly completed rv6, I am undecided as to what to do as far as changing the pitch of my Sensenich fixed pitch prop. At full throttle, I am seeing 2850 rpm. and nearly 2450 static. I have an 0-360 with 9.5 compression pistons and supposedly it puts out close to 195 h.p. The tach has been checked with an optical tachometer and is accurate. The climb rate right now is close to 2000 fpm and top speed is over 210 mph. I like the performance, just not sure I want to live with the higher rpms. I know I can throttle back to stay under red line, but am I then limiting my horsepower? Would my climb rate suffer much with more pitch? Anybody else had this situation and repitched? Just looking for some feedback. Dave Mader 2nd 6/20hrs. ________________________________________________________________________________
Date: Jan 22, 2006
Subject: Re: First Flight
Congratulations Tom!!! Richard Dudley -6A 72 hours Tom & Cathy Ervin wrote: > >Group, > At 12:10 today another RV6-A took it's first flight from 10G-Holmes Co. I made a couple of laps to make sure everything was within perimeters and went South for ZZV-Zanesville and shot my first landing on runway 4. Smooth....no problems. > After a snickers bar I flew back to 10G at 20 Squared and indicated airspeed of 160 Kts. No heavy wing, no rudder tab needed!! I want to thank Vince Welch for always having the right tool when I needed to borrow one and his advice. Thanks to Keith Embry for his transition training which made this first flight safe and uneventful. > Keep pounding those rivets!!!!!!!!!!!!!!!!!!!!!!!!!!! > Tom 362CT > > > > > > > > > ________________________________________________________________________________
Date: Jan 22, 2006
Subject: Re: Financing
Hi Paul, How are you? I came across your card from OSH the other day, btw. I haven't financed an RV, but I did an article on kit financing for Kitplanes magazine in the Oct 2004 issue. I'll save the you trouble of trying to find it, though . You're in luck - RVs are about the most widely accepted kit aircraft on the market by bankers. I spoke to officers from NAFCO (Jim Janssen - 800/999-3712 - www.airloans.com) and Mike Jacobs, who is the president of First Pryority Bank in Pryor, OK (800/462-7032 - www.1st-of-pryor.com). The only kit Mike will consider (as of our last interview) is the RV. There were some new comers to the kit financing market at the last OSH, and if you still have your vendor list, you'll probably find a few. I hope this helps, and if you need to contact me off-list, just let me know. best, Cory Emberson Contributing Editor Kitplanes Magazine Paul Besing wrote: > >Wonder if anyone has any input on who to contact for >RV financing (or who NOT to contact). > >Any experiences shared would be appreciated. > >Paul Besing > > > > > > > > > ________________________________________________________________________________
Subject: First Flight
Date: Jan 23, 2006
Tom, CONGRATULATIONS and WELL DONE !!! Chuck & Dave Rowbotham RV-8A >From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> >Reply-To: rv-list(at)matronics.com >To: >CC: >Subject: RV-List: First Flight Date: Sun, 22 Jan 2006 18:01:05 -0500 > > >Group, > At 12:10 today another RV6-A took it's first flight from >10G-Holmes Co. I made a couple of laps to make sure everything was within >perimeters and went South for ZZV-Zanesville and shot my first landing on >runway 4. Smooth....no problems. > ________________________________________________________________________________
Subject: Financing
Date: Jan 23, 2006
Hi Paul, We used NAFCO - They were great to deal with. Chuck >From: Paul Besing <pbesing(at)yahoo.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Financing >Date: Sun, 22 Jan 2006 16:38:58 -0800 (PST) > > >Wonder if anyone has any input on who to contact for >RV financing (or who NOT to contact). > >Any experiences shared would be appreciated. > >Paul Besing > > ________________________________________________________________________________
Subject: Re: Artificial Horizon Uncertified
Date: Jan 23, 2006
Mr. Bigelow, I can assure you that my view of things are just as wide as yours. My profession requires me often to think "outside the box". You may disagree with some of my statements or ideas, but don't even try to denigrate my intelligence. The new electronics coming on the market are great, I have 2 moving maps on my panel (G530/430), well 3 actually if you count the EHSI. I never said that certified was better, I said that certified implied that the product had gone through a known level of testing and would deliver its specified function. How long it would function (MTBF) was not addressed. Certification implies that it will do what its supposed to do, no more. In my narrow world view of things, I'll take the promise of certification over the words of a basement engineer any day. Yea, yea, I know, electro-wizzies last 10,000 hours MTBF. There's a elegant engineering principal that states, "The more complex solution is not as reliable as a simple, low parts count solution". Or to put it another way, reliability is inversely proportional to the parts count. One other thing, a properly maintained vacuum system is just as reliable as your electro-whizzy. Wet oil pumps last 2-3,000 hours. And those vacuum gyros just keep spinning when everything else goes dark. My Glasair III has vacuum and electric gyros, 2 compass systems, 2 alternators, 2 vacuum systems and one battery. I fly a lot of hard IFR. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of JetPilot Sent: Sunday, January 22, 2006 1:20 PM Subject: RV-List: Re: Artificial Horizon Uncertified The author of the origional thread has a very limited, narrow view of things. Just because something is "certified" does not make it better or safer. That kind of backwards thinking just hindres progress. And yes, having a moving map IS safer, as it increases situational awareness. There are many many dead people that have flown into terrain that would have lived had they had a moving map display. Failures of people are much more common than failures of moving map displays. For safety, I would take the best moving map display with terrain displayed over "certified" round dials and vacuum pumps any day. Vacuum pumps are famous for failing, their antique design is very limited and they fail more much more often than pizo-electric gyros. Only a complete moron with the inability to adapt to anything new would say something is safer just because it is "certified". Michael A. Bigelow -------- NO FEAR - If you have no fear you did not go as fast as you could have !!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=5912#5912 ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Subject: Re: I HATE PINHOLES
Date: Jan 23, 2006
Akzo Aerospace Finishes does a product called "static conditioner". It's a white milky thick liquid that is applied by brush in circular motions or by squeegee. Let it dry for about an hour and remove excess by scotchbrite. Do not use blown gun but use a tackrag. Then apply a coat of Laminar X500 surfacer which will seal in the static conditioner and provide a real hard surface to sand or paintprep on so that one doesn't sand into the fibers of the cloth. Maybe not cheap, but fast and effective. It's used among other on Boeing and Bombardier compositesamong other applications. The static conditioner is applied straight out of the tin, just stir before use. A litre of each should be sufficient for both cowlings and the roof (RV10) and wingtips If you use any other filler, make sure it's in near liquid state so that the product can be either forced into the pinhole or run into it. If not, the product will "bridge" the hole and when you ssand open up again, with the added bonus of eventually damaging the fibers by repeating the procedure a number of times. For effective filling, use a crosscoat system,similar to when you're spraying. ________________________________________________________________________________
Subject: Re: >Re: I HATE PINHOLES
Date: Jan 23, 2006
> Jim, glad you made the statement about smooth prime not being wet sandable. > It is not wet sandable. It MUST be dry sanded as the directions on the can > state. > Larry's right. At the time I used it, I had the can and the instruction manual. Maybe it was assumed I'd dry sand. The instructions said nothing about it. Since we do a lot of wet sanding on RV's, that's what I did with the Smooth Prime. What scared me about the stuff was that it would raise in tiny bubbles while being sanded. Those would leave pock marks about the size of pin heads. I then tried dry sanding the stuff; but, I was afraid the lifting would also happen while paint was being applied. It's wet, also. I got rid of it and went with a fast fill primer, instead. If I ever build a glass airplane, I may try Smooth Prime, again; but, there's a very slim chance I'll build a glass airplane. In the meantime, I'll use the fast fill primer that matches the paint I'll be using. I just thought I'd let our folks know that not all are happy with the stuff. It does have drawbacks. Jim Sears in KY ________________________________________________________________________________
From: =?iso-8859-1?Q?Mich=E8le_Delsol?= <michele.delsol(at)microsigma.fr>
Date: Jan 23, 2006
Good thing this thread was not started in France - As a builder of a tin can airplane (RV8), I frequently engage in friendly arguments with wood/cloth airplanes such as Ministrel, Emeraude (from which the CAP 10 was derived) and plenty of others. There never is a winner but we have lots of fun battling things out. Michele RV8 - Fuselage PS would never build a plastic airplane or a match-stick/rags one. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of JetPilot Sent: dimanche 22 janvier 2006 19:20 Subject: RV-List: Re: Artificial Horizon Uncertified The author of the origional thread has a very limited, narrow view of things. Just because something is "certified" does not make it better or safer. That kind of backwards thinking just hindres progress. And yes, having a moving map IS safer, as it increases situational awareness. There are many many dead people that have flown into terrain that would have lived had they had a moving map display. Failures of people are much more common than failures of moving map displays. For safety, I would take the best moving map display with terrain displayed over "certified" round dials and vacuum pumps any day. Vacuum pumps are famous for failing, their antique design is very limited and they fail more much more often than pizo-electric gyros. Only a complete moron with the inability to adapt to anything new would say something is safer just because it is "certified". Michael A. Bigelow -------- NO FEAR - If you have no fear you did not go as fast as you could have !!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=5912#5912 ________________________________________________________________________________
Date: Jan 23, 2006
On 22 Jan 2006, at 21:24, DAVE MADER wrote: > > After 20 hrs. on my newly completed rv6, I am undecided as to what > to do as > far as changing the pitch of my Sensenich fixed pitch prop. At > full throttle, > I am seeing 2850 rpm. and nearly 2450 static. I have an 0-360 with > 9.5 > compression pistons and supposedly it puts out close to 195 h.p. > The tach has > been checked with an optical tachometer and is accurate. The climb > rate right > now is close to 2000 fpm and top speed is over 210 mph. I like the > performance, just not sure I want to live with the higher rpms. I > know I can > throttle back to stay under red line, but am I then limiting my > horsepower? > Would my climb rate suffer much with more pitch? Anybody else had > this > situation and repitched? Just looking for some feedback. If you need to throttle back to keep the rpm where you want it, then you are sacrificing a lot of power. In this case, a bit more pitch should yield better cruise performance, as you would make more power in cruise with the higher throttle opening that you could use. The climb rate will decrease a bit, but it should still be quite acceptable. Given that you spend a lot more time in cruise than you do climbing, it may be worthwhile to sacrifice the climb to improve the cruise. Sensenich should be able to work with you to determine how much pitch change is needed. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jan 23, 2006
> I'll take the promise of certification > over the words of a basement engineer any day. Yea, yea, I know, > electro-wizzies...... Below is a short BIO of Greg Richter of Blue Mountain one of those "basemant engineers" :) Richter is a graduate of Georgia Tech holding a Bachelor of Electrical Engineering and is a Grumman Aerospace scholar and a member of the IEEE. Richter has been involved in software, systems engineering, RF, analog and digital electronic design for over 20 years. 8) I have 2 BMA EFIS, 2 external comnavs, 1 alternator 2 batteries and a flight Cheetah 210 with solid state harddrive in my F1. I fly a lot of IFR when there is no chance of icing and no TSTMs. As I have 2 separate electro whizzie systems I do so with confidence and, in my mind, the same degree of safety I would have with a certified system or 3. The word certified to me instills no confidence the certification standards put out by the FAA are just as likely to have been developed by a lifelong anministrative engineer as by a techno geek. If you have been around long enough you have encountered "Certified "Flight Instructors, "Certified" mechanics, "Certified" Doctor's, etc,etc................... Some of whom are idiots. The key to safety is to have backup and to understand the limitations of the systems you are using. These electro whizzies have been around long enough to have a track record that "implies" they are safe and reliable. Now I must go and install some rear view mirrors on my Rocket so I can enjoy the look of awe on the face of Velocity drivers as I whizzzzzz by them. :P My next plane is going to be a plastic Radial Rocket with Bluemountain whizzies. I reallly the Glasairs but can't fit in one. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=6085#6085 ________________________________________________________________________________
Date: Jan 23, 2006
Subject: Re: Wingtip has twist
Tim, this is probably a dumb question, but did you trim the inner edge to fit? Dick At 05:16 PM 1/22/2006, you wrote: > > > Hi Listers, looking for a bit of advice. My -6 wingtip appears to have a >bit of a twist in it preventing me from getting it installed as I would like > Here are the observed conditions. > - At the leading edge the wingtip is flat with the top of the wing. >- At the trailing edge the wingtip is flared up a bit. >- I have the wingtip nicely fit and clecoed into the top of the wing all >along it's edge. >- The wingtip fits snug into the leading edge of the wing >- As you travel back along the bottom of the join, the wingtip will not go >into the wing all the way. >- with considerable pressure you can twist it in about a 1/6th of an inch at >the most. > >The question: Can the wingtip be heated in enough of an area to allow me to >reshape it? What other suggestions might one have in this situation? > >Thanks for any help >Tim >N616TB Registerd, not flying - but soon > > ________________________________________________________________________________
From: "Stucklen, Frederic W UTPWR" <Fred.Stucklen(at)UTCFuelCells.com>
Cc: "'RV-List'"
Subject: Re: AeroElectric-List: MD200-306 VOR/ILS Indicator
Date: Jan 23, 2006
Dean, The MD200-306 has internal lighting. But one gottcha.... Be sure that you don't put a dimmer circuit on it as it also has it's own internal dimmer... Fred Stucklen RV-6A N926RV 525 Hrs in 2.5 Years... --> AeroElectric-List message posted by: "DEAN PSIROPOULOS" < dean.psiropoulos(at)verizon.net > I have a VOR/ILS indicator made by Mid Content Instruments (MD200-306) and I am trying to figure out if it is lighted internally or if I need to supply some sort of lighting. The (Spartan) instruction manual shows lighting connections but I'm not sure if they are for the annunciator lights or for full facial lighting. Those who've used this instrument in your panels, do you remember if it is internally lit or will I need to supply post lights or something similar? I emailed Mid Content Instruments several days ago about this but apparently their entire technical support department is on an extended vacation! Thanks for all the help. Dean Psiropoulos RV-6A N197DM Panel ________________________________________________________________________________
Date: Jan 23, 2006
Subject: I HATE PINHOLES
Kevin, I believe that Poly Fiber provides a measuring device to get the correct blend. I used a paint mixer on my drill to mix it completely. Then washed it off to keep it clean. If you don't, it hardens and you have to scrape it off. :-(( I did my applications in small batches to keep it from getting hard while applying. I used Home despot for trays and rollers to put the smooth prime on. Jim ________________________________________________________________________________
Date: Jan 23, 2006
Fred, My pinout diagram for the MD200-306 shows that pin #23 goes to the 14 volt dimmer, pin # 22 goes to either a 28 volt dimmer or to ground in the case of a 14 volt dimmer. Pin # 19 is for 14 v input and pin # 21 is the power ground. I wired mine this way and it dims very nicely with the dimmer circuit. I was not aware that it had an internal dimmer as well. Can you clarify? Documentation is sparse but I do have the pinout if anyone needs a copy. Pat Hatch RV-6 RV-7 Dean, The MD200-306 has internal lighting. But one gottcha.... Be sure that you don't put a dimmer circuit on it as it also has it's own internal dimmer... Fred Stucklen RV-6A N926RV 525 Hrs in 2.5 Years... ________________________________________________________________________________
Subject: RE: RV-List:Uncertified Artificial Horizon
Date: Jan 23, 2006
You're preaching to the choir, Rob. I have your AOA Pro in my airplane. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RobHickman(at)aol.com Sent: Sunday, January 22, 2006 2:19 PM Subject: Re: RV-List:Uncertified Artificial Horizon In a message dated 1/22/2006 6:12:13 AM Pacific Standard Time, Bruce(at)glasair.org writes: If all these manufacturers were so damn sure their products would pass, why didn't they test and certify them? It would give them a leg up on the competition. Bruce, The reason that manufacturers don't do it is that it costs a huge amount of money and once you do it limits your ability to make improvements to the product. We have been in the middle of certifying the AOA for over three years now. We have passed DO-160 testing and we should have our first STC in the spring. It has cost well over $75,000 to get it certified. We have made a number of improvements to the AOA since we started certification and we currently are selling the AOA Sport 3. The certified AOA Sport 1 unit that we could start selling this summer is 3 generations old and is not as good as the one that we make today, but it will be =E2=80=9CCertified=E2=80=9D. The paper work alone will add a major amount of cost to each unit that we sell and to be honest most people are not willing to pay for it. You forgot the really big benefit that you get once you start selling a certified product. You are assured that you will be sued for every airplane crash no madder what caused it. We currently have a customer that wants to install a large number of AOA=E2=80=99s in Cessna Caravans. They have three Caravans flying with the AOA and =E2=80=9Cmust have it=E2=80=9D. You would not even believe the conversations I have had with my insurance company over this one=E2=80=A6. Cessna, Cirrus, ect=E2=80=A6 would tell you exactly the same thing about airframes as you have said about avionics. There is no way that Lancair, Vans, or Glassair have done the paper work and testing that the certified manufactures have had to do. Does this automatically mean that a new RV-10 is not as safe as a Cirrus? I don=E2=80=99t think so, and I can=E2=80=99t wait to load my family in my RV-10 with my uncertified EFIS , Engine Monitor, and AOA. I would also argue that my RV-10 will be safer because of them. Every year I have someone stop by the booth and tell me that our uncertified product has saved their life. How many people would not be here today if they had waited to install a certified instrument? How much higher would the insurance that you pay be? I would bet that way more lives are saved because of affordable, uncertified avionics. Rob Hickman Advanced Flight Systems ________________________________________________________________________________
Date: Jan 23, 2006
Hi Dick, Yes, I had to trim the inner edge of the bottom because it was hitting the rib. I trimmed about 3/16". Now it doesn't hit but still won't go in. I can warp a little with my hands but not near enough to do any good. I had to trim quite a bit on the right wing tip but in the end it went in and together. Didn't notice any warping in it and it was pretty flat accross the top of wingtip / wing. -------Original Message------- From: Richard Seiders Date: 01/23/06 05:35:57 Subject: Re: RV-List: Wingtip has twist Tim, this is probably a dumb question, but did you trim the inner edge to fit? Dick At 05:16 PM 1/22/2006, you wrote: > > > Hi Listers, looking for a bit of advice. My -6 wingtip appears to have a >bit of a twist in it preventing me from getting it installed as I would like > Here are the observed conditions. > - At the leading edge the wingtip is flat with the top of the wing. >- At the trailing edge the wingtip is flared up a bit. >- I have the wingtip nicely fit and clecoed into the top of the wing all >along it's edge. >- The wingtip fits snug into the leading edge of the wing >- As you travel back along the bottom of the join, the wingtip will not go >into the wing all the way. >- with considerable pressure you can twist it in about a 1/6th of an inch at >the most. > >The question: Can the wingtip be heated in enough of an area to allow me to >reshape it? What other suggestions might one have in this situation? > >Thanks for any help >Tim >N616TB Registerd, not flying - but soon > > ________________________________________________________________________________
Date: Jan 23, 2006
> >I can see the reasons that the RV list has a reputation for driving out >those brave souls who don't blindly follow the group mindset. Good luck, you >guys. I hope all have a sound backup plan. I don't know that people leave this list because of disagreements. Personally I take grief for flying high whereas other RV pilots fly closer to the ground. A recent close encounter with a Cessna at 9500' (low in my book) just reinforces my belief that it is safer higher. I do have a question about the Dynon system. Some say that it is acceptable for use in IFR flight. Is there anything in writing that confirms that assertion? I also am of the impression that the issue of certified or not is not that important. Look at the NTSB accident reports and see the boneheaded, Darwin-tempting things that pilots do that kill themselves and others. If you want to reduce accidents, figure out how to keep pilots from making STUPID decisions that result in fatalities. Ron Lee ________________________________________________________________________________
Date: Jan 23, 2006
Thank you Ron. I thought that was what I was trying to do. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee Sent: Monday, January 23, 2006 11:39 AM Subject: RE: RV-List: Re: Artificial Horizon Uncertified > >I can see the reasons that the RV list has a reputation for driving out >those brave souls who don't blindly follow the group mindset. Good luck, you >guys. I hope all have a sound backup plan. I don't know that people leave this list because of disagreements. Personally I take grief for flying high whereas other RV pilots fly closer to the ground. A recent close encounter with a Cessna at 9500' (low in my book) just reinforces my belief that it is safer higher. I do have a question about the Dynon system. Some say that it is acceptable for use in IFR flight. Is there anything in writing that confirms that assertion? I also am of the impression that the issue of certified or not is not that important. Look at the NTSB accident reports and see the boneheaded, Darwin-tempting things that pilots do that kill themselves and others. If you want to reduce accidents, figure out how to keep pilots from making STUPID decisions that result in fatalities. Ron Lee ________________________________________________________________________________
Date: Jan 23, 2006
Subject: Re: Gluing canopies - a few more notes
Kevin, You mention doing the canopy upside down... I was under the impression that the canopy had to/should be glued on the aircraft with the frame and canopy in the closed position in order to insure that no twist or movement will screw up the final fit (and yes, I thought that might be a bit problematic). So if you glue the canopy to the frame off the aircraft, how do you make sure it stays aligned as it should? Vern On 1/22/06, Kevin Hester wrote: > > kevinh-unfiltered(at)sneakyfrog.com > > * The clear sika prep fluid will slightly roughen any plexi that it is > allowed to sit on for an extended time. Either use masking to protect > against this (particularly when doing the canopy frame with the plexy > upside down over the table) or when you screw up wipe up excess with a > paper towel. It is a very slight effect but noticeable if you look at > the right angle. Kevin > > ________________________________________________________________________________
Date: Jan 23, 2006
I used some of the scrap canopy track to make a mount on my workbench. You can see what I did in some of these pictures: http://www.rv8.ch/article.php?story 050617213651709 If I could do it again, I'd use some dabs of Sikaflex to "tack" the canopy to the frame, and then turn the whole thing upside down to finish it off. Mickey Vern W. wrote: > > Kevin, > You mention doing the canopy upside down... I was under the impression that > the canopy had to/should be glued on the aircraft with the frame and canopy > in the closed position in order to insure that no twist or movement will > screw up the final fit (and yes, I thought that might be a bit problematic). > > So if you glue the canopy to the frame off the aircraft, how do you make > sure it stays aligned as it should? > > Vern > > > On 1/22/06, Kevin Hester wrote: > >>kevinh-unfiltered(at)sneakyfrog.com >> >>* The clear sika prep fluid will slightly roughen any plexi that it is >>allowed to sit on for an extended time. Either use masking to protect >>against this (particularly when doing the canopy frame with the plexy >>upside down over the table) or when you screw up wipe up excess with a >>paper towel. It is a very slight effect but noticeable if you look at >>the right angle. > -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Jan 23, 2006
Subject: Re: Artifical Horizon
I know this isn't a solid-state instrument, but I ran into this electric, battery backed-up gyro in a blurb in AOPA Pilot: http://www.lifesavergyro.com/ They also have a mini electric gyro: http://www.mcico.com/master1.html?whatsnew.html&1 Thought it might interest someone.. -- Corey Crawford corey.crawford(at)gmail.com Building an RV-7A in Denver, CO ________________________________________________________________________________
Date: Jan 23, 2006
I don't mind the disagreements. What I don't like is when others, who are struggling to counter my statements, resort to personal attacks. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee Sent: Monday, January 23, 2006 11:39 AM Subject: RE: RV-List: Re: Artificial Horizon Uncertified > >I can see the reasons that the RV list has a reputation for driving out >those brave souls who don't blindly follow the group mindset. Good luck, you >guys. I hope all have a sound backup plan. I don't know that people leave this list because of disagreements. Personally I take grief for flying high whereas other RV pilots fly closer to the ground. A recent close encounter with a Cessna at 9500' (low in my book) just reinforces my belief that it is safer higher. I do have a question about the Dynon system. Some say that it is acceptable for use in IFR flight. Is there anything in writing that confirms that assertion? I also am of the impression that the issue of certified or not is not that important. Look at the NTSB accident reports and see the boneheaded, Darwin-tempting things that pilots do that kill themselves and others. If you want to reduce accidents, figure out how to keep pilots from making STUPID decisions that result in fatalities. Ron Lee ________________________________________________________________________________
Date: Jan 23, 2006
Subject: RV Wiki Featured Article
Rob Prior has written an excellent article for the RV Wiki in which he compiles information from many posts to the RV List on the subject of gluing canopies. http://www.rvwiki.org/index.php?title=Gluing_Your_Canopy As always, you are welcome to improve this article any way you can, such as by adding further information or pictures, or even just by correcting any typos you notice. You'll find quick instructions on editing an article here, http://www.rvwiki.org/index.php?title=Quick_Page_Editing_Instructions and more detailed instructions here, http://www.rvwiki.org/index.php?title=Help:Edit --- Tedd McHenry Surrey, BC, Canada ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Date: Jan 23, 2006
Look at Dan's website, he has a good photo of his "hi-tech" solution. http://www.rvproject.com/index.html Lot of good info there. I just noticed he's a contributing editor to Kitplanes. Who knew? Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ----- Original Message ----- From: "Tim Bryan" <flyrv6(at)bryantechnology.com> Sent: Sunday, January 22, 2006 4:16 PM Subject: RV-List: Wingtip has twist > > > Hi Listers, looking for a bit of advice. My -6 wingtip appears to have a > bit of a twist in it preventing me from getting it installed as I would > like > Here are the observed conditions. > - At the leading edge the wingtip is flat with the top of the wing. > - At the trailing edge the wingtip is flared up a bit. > - I have the wingtip nicely fit and clecoed into the top of the wing all > along it's edge. > - The wingtip fits snug into the leading edge of the wing > - As you travel back along the bottom of the join, the wingtip will not go > into the wing all the way. > - with considerable pressure you can twist it in about a 1/6th of an inch > at > the most. > > The question: Can the wingtip be heated in enough of an area to allow me > to > reshape it? What other suggestions might one have in this situation? > > Thanks for any help > Tim > N616TB Registerd, not flying - but soon > > > ________________________________________________________________________________
Date: Jan 23, 2006
tacking is the way to go, it lets u make a much nicer finish on the glue beads, is what the Sika guys recommended when i called them. Mickey Coggins wrote: > >I used some of the scrap canopy track to make a mount >on my workbench. You can see what I did in some of >these pictures: > > http://www.rv8.ch/article.php?story 050617213651709 > >If I could do it again, I'd use some dabs of Sikaflex >to "tack" the canopy to the frame, and then turn the >whole thing upside down to finish it off. > >Mickey > >Vern W. wrote: > > >> >>Kevin, >>You mention doing the canopy upside down... I was under the impression that >>the canopy had to/should be glued on the aircraft with the frame and canopy >>in the closed position in order to insure that no twist or movement will >>screw up the final fit (and yes, I thought that might be a bit problematic). >> >>So if you glue the canopy to the frame off the aircraft, how do you make >>sure it stays aligned as it should? >> >>Vern >> >> >>On 1/22/06, Kevin Hester wrote: >> >> >> >>>kevinh-unfiltered(at)sneakyfrog.com >>> >>>* The clear sika prep fluid will slightly roughen any plexi that it is >>>allowed to sit on for an extended time. Either use masking to protect >>>against this (particularly when doing the canopy frame with the plexy >>>upside down over the table) or when you screw up wipe up excess with a >>>paper towel. It is a very slight effect but noticeable if you look at >>>the right angle. >>> >>> > > > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Jan 23, 2006
Hey Kevin, timing is everything. Im planning on removing my poorly fit aluminum canopy fairing and replacing with fiberglass. Any tips? i.e. How many layups of what oz cloth, pitfalls... tia Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ----- Original Message ----- From: "Kevin Hester" <kevinh-unfiltered(at)sneakyfrog.com> Cc: "Gerry Filby" Sent: Sunday, January 22, 2006 1:45 PM Subject: RV-List: Re: Gluing canopies - a few more notes > > > Hi, > > Various other posters have already covered most points, but since I've > done the adhesive canopy thing I'd like to add a few notes: > > * Thanks to Chalkie for getting this great idea started with his Sport > Aviation article > * Sika is a bit of a pain to work with, but no where nearly as nasty as > proseal. If I had it to do over again, there's no way I'd even > consider using pop rivets. > * I really like that with Sika your canopy mates right up with your > windscreen - no need to make the fiberglass lip > * Before applying the black primer to the plexi, be very careful about > masking (duh) > * Rough up the rollbar powdercoat pretty good before applying the sika > prep clear fluid to it. > * Also apply masking tape to the rollbar where you don't want any sika > to stick. > * The clear sika prep fluid will slightly roughen any plexi that it is > allowed to sit on for an extended time. Either use masking to protect > against this (particularly when doing the canopy frame with the plexy > upside down over the table) or when you screw up wipe up excess with a > paper towel. It is a very slight effect but noticeable if you look at > the right angle. > * Although Sika says it is dry within a day(?), it really takes a few > weeks before it is as strong as it is ever going to be. When I did > some test pieces I was initially a bit concerned with the strength of > the bond but two weeks later it reached the point where I was breaking > plexy before sika would come off. (Not a very scientific test though). > * Use this 'slow dry' property to your advantage - if you need to > mechanically remove any sika that squeezes past masking tape, it is > much easier to do this the day after the lay-up than a week later. > * I had one helper for the actual bonding day of the windscreen to the > rollbar, I'd recommend two helpers. ;-) > * If you are doing sika, you probably want to make your aft skirt out > of fiberglass rather than aluminum. The fiberglass skirt only takes a > day to make and you can bond it with sika as well - no pop rivets > through the plexi and the frame. > * Like anything - doing it the first time takes _much_ longer. If you > can find someone local who's done it, buy em with beer to come help on > windscreen bonding day (canopy bonding is way easier). I'm happy to > help any SF Bay Area builder who decides to go this way... > > (I think the current GLO custom photos on the VAF homepage show my > crummy masking job - fortunately Sika is paintable (and Grady friggen > rocks), so I've now decided that my rollbar should be black to match > the top of my plane) > > Kevin > > > ________________________________________________________________________________
Date: Jan 23, 2006
Hey Milt, what do you think about the Flight Cheetah? Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ----- Original Message ----- From: "N395V" <N395V(at)direcway.com> Sent: Monday, January 23, 2006 7:10 AM Subject: RV-List: Re: Artificial Horizon Uncertified > > >> I'll take the promise of certification >> over the words of a basement engineer any day. Yea, yea, I know, >> electro-wizzies...... > > > Below is a short BIO of Greg Richter of Blue Mountain one of those > "basemant engineers" :) > > Richter is a graduate of Georgia Tech holding a Bachelor of Electrical > Engineering and is a Grumman Aerospace scholar and a member of the IEEE. > Richter has been involved in software, systems engineering, RF, analog and > digital electronic design for over 20 years. 8) > > I have 2 BMA EFIS, 2 external comnavs, 1 alternator 2 batteries and a > flight Cheetah 210 with solid state harddrive in my F1. I fly a lot of IFR > when there is no chance of icing and no TSTMs. > > As I have 2 separate electro whizzie systems I do so with confidence and, > in my mind, the same degree of safety I would have with a certified system > or 3. > > The word certified to me instills no confidence the certification > standards put out by the FAA are just as likely to have been developed by > a lifelong anministrative engineer as by a techno geek. > > If you have been around long enough you have encountered "Certified > "Flight Instructors, "Certified" mechanics, "Certified" Doctor's, > etc,etc................... > > Some of whom are idiots. > > The key to safety is to have backup and to understand the limitations of > the systems you are using. These electro whizzies have been around long > enough to have a track record that "implies" they are safe and reliable. > > Now I must go and install some rear view mirrors on my Rocket so I can > enjoy the look of awe on the face of Velocity drivers as I whizzzzzz by > them. :P > > > My next plane is going to be a plastic Radial Rocket with Bluemountain > whizzies. I reallly the Glasairs but can't fit in one. > > -------- > Milt > N395V > F1 Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=6085#6085 > > > ________________________________________________________________________________
Date: Jan 23, 2006
Bruce Gray wrote: > >I don't mind the disagreements. What I don't like is when others, who are >struggling to counter my statements, resort to personal attacks. > >Bruce >www.glasair.org > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee >Sent: Monday, January 23, 2006 11:39 AM >To: rv-list(at)matronics.com >Subject: RE: RV-List: Re: Artificial Horizon Uncertified > > > > >> >>I can see the reasons that the RV list has a reputation for driving out >>those brave souls who don't blindly follow the group mindset. Good luck, >> >> >you > > >>guys. I hope all have a sound backup plan. >> >> Bruce you have been a good contributor to this list for a long time, I enjoy reading your posts. I also agree with you. It is amazing to me how many people that have the "electronic gizmo's" also have some type of steam gauge. When asked why both it is always the same answer, "JUST IN CASE." :-) Jerry ________________________________________________________________________________
Date: Jan 23, 2006
shempdowling2(at)earthlin wrote: > Hey Milt, what do you think about the Flight Cheetah?- Just got it put in so havn't used it a lot. I have been running the same software (True Map) on a tablet and really love it. Provides great weather, moving map, and airway info and easy rapid access to approach plates. Now with a solid state HD I can go up into the low teen Flight Levels without crunching my harddrive. The actual flight Cheetah is quicker and easier to use as all it is is a flight instrument and not a multi purpose computer. It was a real struggle to pick between the 396 and Cheetah but I really needed an EFB type solution to charts and approach plates. The 396 just didn't provide that. The short answer to your question is I think it is terrific. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=6336#6336 ________________________________________________________________________________
Date: Jan 23, 2006
Subject: first real dimples
Ok I am just now setting my first real dimples in the HS spars and ribs, pneumatic squeezer, do I want to see the slight ring imprint also ,? or am I just a little deep ? How about when I get to the skin ?? Thanks all,., Dan Hatch -8 QB N728RV Reserved and gettin on a roll ! ________________________________________________________________________________
From: "Dan Beadle" <dan.beadle(at)inclinesoftworks.com>
Date: Jan 23, 2006
I overdid the dimpling on my first try. I used a lot of pressure. TOO MUCH. What you want is to have the dies just touch the surface. In my case, the excessive pressure caused the holes to expand, making a cleco not hold well. Another test is to insert an AN426 rivet. The top of the rivet should be flush with the skin. And the mating part, the spar or rib, should be dimpled enough to accept the skin without visible separation. Hope this helps. Dan -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Sent: Monday, January 23, 2006 7:11 PM Subject: RV-List: first real dimples Ok I am just now setting my first real dimples in the HS spars and ribs, pneumatic squeezer, do I want to see the slight ring imprint also ,? or am I just a little deep ? How about when I get to the skin ?? Thanks all,., Dan Hatch -8 QB N728RV Reserved and gettin on a roll ! ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jan 23, 2006
This is obviously uncertified but might make a backup unit? Does anyone have any experience with these Stratomaster Units? At $875 they aren't much more than a T&B? http://www.sportflyingshop.com/Instr/Stratomaster/SmartSingles/AttitudeIndic ators/attitudeindicators.html Bill S 7a Ark -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of N395V Sent: Monday, January 23, 2006 9:07 PM Subject: RV-List: Re: Artificial Horizon Uncertified shempdowling2(at)earthlin wrote: > Hey Milt, what do you think about the Flight Cheetah?- Just got it put in so havn't used it a lot. I have been running the same software (True Map) on a tablet and really love it. Provides great weather, moving map, and airway info and easy rapid access to approach plates. Now with a solid state HD I can go up into the low teen Flight Levels without crunching my harddrive. The actual flight Cheetah is quicker and easier to use as all it is is a flight instrument and not a multi purpose computer. It was a real struggle to pick between the 396 and Cheetah but I really needed an EFB type solution to charts and approach plates. The 396 just didn't provide that. The short answer to your question is I think it is terrific. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=6336#6336 ________________________________________________________________________________
Date: Jan 23, 2006
Subject: Re: first real dimples
The slight imprint is good and is not a problem. It means the die has fully depressed the dimple. If, outside that ring,you see bulging, it is too much pressure. Dave --- Dan wrote: > > Ok I am just now setting my first real dimples in > the HS spars and ribs, > pneumatic squeezer, do I want to see the slight > ring imprint also ,? or am I just a little deep ? > How about when I get to the skin ?? > Thanks all,., > > Dan Hatch > -8 QB > N728RV Reserved > > and gettin on a roll ! > > > > > > > > browse > Subscriptions page, > FAQ, > > Admin. > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 23, 2006
Subject: Shop Tool ?
Thanks all for the responses I've gotten , on a few "new builder " questions, I just wanted to share on one of my favorite and usefull tools which I got on the first day of building was my shop apron from Duluth Trading co. http://www.duluthtrading.com/search/searchresults/83490.aspx It's tough, has great pockets to hold cleco's, tools, pen and glasse's it does a great job of protecting my clothes and when I go to the garage I put it on ! AND I'm building an airplane !! The toughest apron you'll ever weld, grind, or grill in Dan Hatch Seattle -8 QB 728RV ________________________________________________________________________________
Date: Jan 24, 2006
Since you brought up the subject ... A long while back, I started using scrubs (www.scrubs.com) and found them to be very handy. They are cool to work in, have large pockets for clecos and parts, do not hamper movement, and can quickly be peeled off so you don't track aluminum dust everywhere. I wear an old pair of running shoes and athletic socks and usually a scrub cap to keep debris out of my hair. I might look a bit funny, but it was really handy recently when I was back-drilling the top skins of my -6A fuselage; aluminum was falling all around me and the inside of the plane was fairly hot with my and a worklight in there. My wife made me a shop apron which I found to be pretty hand when working externally but aprons just get in the way when you have to crawl around, IMHO. Scrubs can be had with cuffed legs (elastic, so the bottom is closed around the leg) and jackets with long sleeves for painting/prosealing. However, I just went with the "old-shirt" method for prosealing. One set of scrubs has stood up to the entire project to date (beware hospital scrubs - they're made of lighter material). If you think that they're too light for shop work, check out Dan Checkoway's wife doing "pin-up riveting". ;} Dan, that picture should be made into an inspirational poster... Patrick Kelley - RV-6A - installing cockpit floors and systems -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Sent: Monday, January 23, 2006 11:13 PM Subject: RV-List: Shop Tool ? Thanks all for the responses I've gotten , on a few "new builder " questions, I just wanted to share on one of my favorite and usefull tools which I got on the first day of building was my shop apron from Duluth Trading co. http://www.duluthtrading.com/search/searchresults/83490.aspx It's tough, has great pockets to hold cleco's, tools, pen and glasse's it does a great job of protecting my clothes and when I go to the garage I put it on ! AND I'm building an airplane !! The toughest apron you'll ever weld, grind, or grill in Dan Hatch Seattle -8 QB 728RV ________________________________________________________________________________
Subject: instructor needed in Ann Arbor Michigan area
Date: Jan 24, 2006
Does anyone know of an instructor in the Ann Arbor, MI area that can check someone out in their RV tri-gear aircraft? Reply offlist to vfrazier(at)usi.edu Thanks ________________________________________________________________________________
Subject: Sikaflex Tip-up
Date: Jan 24, 2006
Has anyone found a method to use sikaflex on the tip-up version canopy? RV9A C-FYOO Finishing ________________________________________________________________________________
From: "Stucklen, Frederic W UTPWR" <Fred.Stucklen(at)utcfuelcells.com>
Cc: "'RV-List'"
Date: Jan 24, 2006
Pat, I just looked up my wiring and found the following: Pin #21,22 to GND, Pin #23 to dimmer, and Pin #19 to +14VDC. I had originally wired Pin #23 (ann. PWR) to the dimmer, but found that the unit had an internal dimmer associated with the enunciator. Fred Stucklen RV-6A N926RV 525 Hrs in 2.5 Years... > Fred, My pinout diagram for the MD200-306 shows that pin #23 goes to the 14 volt dimmer, pin # 22 goes to either a 28 volt dimmer or to ground in the case of a 14 volt dimmer. Pin # 19 is for 14 v input and pin # 21 is the power ground. I wired mine this way and it dims very nicely with the dimmer circuit. I was not aware that it had an internal dimmer as well. Can you clarify? Documentation is sparse but I do have the pinout if anyone needs a copy. Pat Hatch RV-6 RV-7 < Fred.Stucklen(at)UTCFuelCells.com > Dean, The MD200-306 has internal lighting. But one gottcha.... Be sure that you don't put a dimmer circuit on it as it also has it's own internal dimmer... Fred Stucklen RV-6A N926RV 525 Hrs in 2.5 Years... ________________________________________________________________________________
Subject: Re: "Excess" Energy use!
Date: Jan 24, 2006
In my humble opinion, anyone who would criticise the unacceptable damage and polution from a (US) petrochem facility has no place flying GA/personal airplanes. The is the same contradiction as those who complain about "global warming" and driver their Land Rovers. These are all hypocritical contradictions. The tactic "liberal/enviro whackos" use when they accuse conservatives of not caring about the environment is baseless and ignorant. What sane person does not want clean air and water for themselves and their children! It's all about what's a reasonable, sustainable level of emission. Life is a made up of compromises... and the laws of thermodynamics. You want to fly in an airplane, there will be waste and byproduct produced from its use. I can only speak for the US petrochem industry - in which I worked for 17 years - where they have made incredible strides over the last 20 years. There still could be improvements in some areas, but much greater emission reduction requirements and we will be pricing ourselves right out of business due to diminishing returns *and* the fact that (third world) Mexico can produce the same products cheaper while spewing their waste right into the Southwestern US air flow. Anyone suggestion that the environmental compliance capital spending doesn't add to the cost of production and processing is really fooling themselves. Who pays for the $BILLIONS spent on NOx reduction, low sulfur diesel, etc, etc. projects? The EPA Fairies?? I have spent time near (US) petroleum production sites. In the US essentially no waste or byproduct leaves the local containment. The impact is essentially nill. Tar in the surf is both naturally occurring and, unfortunately, sometimes the result of spills. Which got on your feet? Remember the Valdez natural disaster? Would "kill-off all fish and wildlife for 20-30 years!!" While a stupid mistake and a terrible mess, nature reclaimed the area to a near pre-accident state in only a few years. And biologists have determined that those species not back to pre-spill conditions may have experienced *natural* fluctuations in their conditions. Last, proposing "fair" use of energy is only something right out of the Communist Manifesto. Let the markets decide. 2 cents Bryan Jones Read this topic online here: http://forums.matronics.com/viewtopic.php?p=6482#6482 ________________________________________________________________________________
Subject: Waterjet Cutting
Date: Jan 24, 2006
Anyone have a source (in the US) for small waterjet cutting services? I'm for a source that doesn't charge "industrial" rates to make some complex (1/2" thick) steel brackets. Thanks Bryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=6504#6504 ________________________________________________________________________________
Date: Jan 24, 2006
Those are my exact reasons for wanting the Cheetah. I also am looking at a 396 but I hate always worrying about approach charts. It seems to me the Cheetah has it all, just not in a pretty case :) Good software options as well. Please give us an update once you have used it a bit. Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ----- Original Message ----- From: "N395V" <N395V(at)direcway.com> Sent: Monday, January 23, 2006 9:07 PM Subject: RV-List: Re: Artificial Horizon Uncertified > > > shempdowling2(at)earthlin wrote: >> Hey Milt, what do you think about the Flight Cheetah?- > > > Just got it put in so havn't used it a lot. I have been running the same > software (True Map) on a tablet and really love it. Provides great > weather, moving map, and airway info and easy rapid access to approach > plates. Now with a solid state HD I can go up into the low teen Flight > Levels without crunching my harddrive. > > The actual flight Cheetah is quicker and easier to use as all it is is a > flight instrument and not a multi purpose computer. It was a real struggle > to pick between the 396 and Cheetah but I really needed an EFB type > solution to charts and approach plates. The 396 just didn't provide that. > > The short answer to your question is I think it is terrific. > > -------- > Milt > N395V > F1 Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=6336#6336 > > > ________________________________________________________________________________
Subject: B&C alternator clearance
Date: Jan 24, 2006
I currently have Vans 35amp alt. With a Gates 7355 belt (36-1/4") on an O-360 C/S. Somewhere between 3-3.5 g's the pulley makes contact with lower cowl. I tried the next size shorter belt 7350 (35-5/8") but it's too tight and holds the alternator against the Stainless oil line from the governor. I would buy a B&C L40 if I thought it would give more clearance, but would rather save the money if it wouldn't fit with the shorter belt. Does anyone have a B&C L40 on a O-360 with a constant speed prop, and using a 7350 (35-5/8") (890mm) belt? If I know this combination works I'll order the B&C. Chris Brooks RV6 ________________________________________________________________________________
Date: Jan 24, 2006
Subject: ECi cylinder AD
Well, I installed the spacer behind #3 cylinder and totally solved my hot #3 problem - fantastic, all the temps are now perfect! That's the good news. The bad news is that now that I have the temps under control I get nailed by the ECi mandatory service bulletin/ AD. I know, my RV6 is experimental and AD's don't legally apply, but they've had 30 failures so I think that it's prudent to take care of it. If nothing else, I'd take a big hit if I tried to sell it without taking care of the AD. ECi is not going to make me pay full price for 4 new cylinder assemblies. A prorated warranty applies, and since I've got just 100 hrs on them it's "only" going to cost me about $1350 to replace them with new "Titan"cylinders. Yes, I shouldn't have to pay anything but that's the nature of AD's - the owner gets screwed. ( As a mater of fact, anytime the government gets involved you get screwed) I brought this up because this is one AD that I think we should comply with and the sooner it's done the cheaper it's going to be. So if you have ECi Classic Cast cylinders, do yourself a favor and check out ECi service bulletin #05-8 at: http://www.eci2fly.com/pdf/05-8.pdf The AD# is 2005-26-10. Dave -6 SoCal EAA Technical Counselor ________________________________________________________________________________
Subject: Re: B&C alternator clearance
Date: Jan 24, 2006
Chris, I don't have an answer for you on the L40, but here is something else you may consider. Get yourself a "slightly" bigger diameter pulley for your current alternator, which will do two things for you: 1. Get the ALT closer to the engine while still using the 7355 belt you have on it right now, and 2. slow down your ALT.-RPM a little bit! Does that make sense to anyone else ??? Good Luck to you (without spending to much money) ----- Original Message ----- From: Chris Brooks To: rv-list(at)matronics.com Sent: Tuesday, January 24, 2006 3:13 PM Subject: RV-List: B&C alternator clearance I currently have Vans 35amp alt. With a Gates 7355 belt (36-1/4") on an O-360 C/S. Somewhere between 3-3.5 g's the pulley makes contact with lower cowl. I tried the next size shorter belt 7350 (35-5/8") but it's too tight and holds the alternator against the Stainless oil line from the governor. I would buy a B&C L40 if I thought it would give more clearance, but would rather save the money if it wouldn't fit with the shorter belt. Does anyone have a B&C L40 on a O-360 with a constant speed prop, and using a 7350 (35-5/8") (890mm) belt? If I know this combination works I'll order the B&C. Chris Brooks RV6 -- ________________________________________________________________________________
Subject: Re: Waterjet Cutting
Date: Jan 24, 2006
Try this. A huge list of shops. http://waterjets.org/waterjet_jobshops.html ----- Original Message ----- From: "bdjones1965" <rv_8pilot(at)hotmail.com> Sent: Tuesday, January 24, 2006 11:20 AM Subject: RV-List: Waterjet Cutting > > Anyone have a source (in the US) for small waterjet cutting services? I'm for a source that doesn't charge "industrial" rates to make some complex (1/2" thick) steel brackets. > > Thanks > > Bryan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=6504#6504 > > ________________________________________________________________________________
Date: Jan 24, 2006
Excellent responses. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=6648#6648 ________________________________________________________________________________
Date: Jan 24, 2006
In a message dated 1/24/2006 2:16:26 P.M. Pacific Standard Time, brooksrv6(at)hotmail.com writes: Does anyone have a B&C L40 on a O-360 with a constant speed prop, and using a 7350 (35-5/8") (890mm) belt? If I know this combination works I'll order the B&C. ===================================== I run the B&C L60 alternator with the Gates 7360 belt fine on mine since day one, if it helps you to decide. GV (RV-6A N1GV O-360-A1A, C/S, Flying 771hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jan 25, 2006
Emachineshop.com is the cats meow...if you can draw a part, it can be made most any material, most any process, all online, with pricing... give a look... Steven dinieri N221rv N231rv -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bdjones1965 Sent: Tuesday, January 24, 2006 10:48 PM Subject: RV-List: Re: Waterjet Cutting Excellent responses. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=6648#6648 ________________________________________________________________________________
Date: Jan 25, 2006
Konrad, that makes since to me. My algebra is probably flawed but I calculated that if I went with a 3-1/4" pulley instead of the 2-3/4" it would move the alt. .4" closer to the engine but only gain 1/8" of pulley clearance. That .4" puts me back into the prop governor line. Chris ________________________________________________________________________________
Subject: dan's wife!?
Date: Jan 25, 2006
Oh sure, tease us with the image of a "pin up wife" and not tell us the URL. Good thing that I have a pin up wife of my own to gawk at. I even put her on the back of my flight jacket. http://vincesrocket.com/jacket%20back%20web.JPG (Artwork done by R.T. Foster, www.rtfosterart.com) Go Dan! ;-) Vince Frazier http://vincesrocket.com/ ________________________________________________________________________________
Date: Jan 25, 2006
Chris, What is your thought in regards to a small clearance bump fiberglassed into the cowl, versus buying a new expensive alternator? After all it is not very much additional clearance that you are looking for? Or perhaps you could stay away from the 3+G Pulls :-) ----- Original Message ----- From: Chris Brooks To: rv-list(at)matronics.com Sent: Wednesday, January 25, 2006 7:52 AM Subject: Re: RV-List: B&C alternator clearance Konrad, that makes since to me. My algebra is probably flawed but I calculated that if I went with a 3-1/4" pulley instead of the 2-3/4" it would move the alt. .4" closer to the engine but only gain 1/8" of pulley clearance. That .4" puts me back into the prop governor line. Chris -- ________________________________________________________________________________
Date: Jan 25, 2006
I have a similar set-up to yours with the 40 amp B&C alternator, the same engine, and a constant speed prop. I found that my alterantor hit the cowl on the first flight. I used a slightly shorter (Gates) belt and modified the tensioning arm. Since the mod I have not had a problem in over 300 hours. 'Hope this helps, Dean Pichon RV-4 Bolton, MA ----Original Message Follows---- From: "Chris Brooks" <brooksrv6(at)hotmail.com> Subject: RV-List: B&C alternator clearance Date: Tue, 24 Jan 2006 16:13:28 -0600 I currently have Vans 35amp alt. With a Gates 7355 belt (36-1/4") on an O-360 C/S. Somewhere between 3-3.5 g's the pulley makes contact with lower cowl. I tried the next size shorter belt 7350 (35-5/8") but it's too tight and holds the alternator against the Stainless oil line from the governor. I would buy a B&C L40 if I thought it would give more clearance, but would rather save the money if it wouldn't fit with the shorter belt. Does anyone have a B&C L40 on a O-360 with a constant speed prop, and using a 7350 (35-5/8") (890mm) belt? If I know this combination works I'll order the B&C. Chris Brooks RV6 ________________________________________________________________________________
Date: Jan 25, 2006
Subject: Re: dan's wife!?
Jen is a very attractive woman. But I believe that ANY woman that will help her husband rivet an airplane is a goddess. Dave Nellis --- "Frazier, Vincent A" wrote: > > > Oh sure, tease us with the image of a "pin up wife" > and not tell us the > URL. > > Good thing that I have a pin up wife of my own to > gawk at. I even put > her on the back of my flight jacket. > http://vincesrocket.com/jacket%20back%20web.JPG > (Artwork done by R.T. > Foster, www.rtfosterart.com) > > Go Dan! ;-) > > Vince Frazier > http://vincesrocket.com/ > > > > > > > > browse > Subscriptions page, > FAQ, > > Admin. > > > > > > > > > > > ________________________________________________________________________________
Subject: oil rant response
Date: Jan 25, 2006
I didnt read em all, but Mickys reply was on the mark for me, As for cars, My VERY comfortable and quiet Buick Regal gets 32 mpg on the road. As for global warming, anyboddy seen all the disapearing glaciers and barren land that was once covered with ice? As for nEuropena gas, It was $1.00 a gal in germany in the late 50's already. I know because when my ultra cheep gas ration card ran out, I had to buy it at the pump. Now let me tell you, those Litters run so fast you can hardly see them :-) Charlie Heathco ________________________________________________________________________________
Date: Jan 25, 2006
We'd just wake up in the morning, scratch ourselves, and see what food we can find laying around. Dang, I been doing this for 48 years, was I supposed to be doing something different??? ;{) Re: RV-List: We'd just wake up in the morning, scratch ourselves, and see what food we can find laying around. Dang, I been doing this for 48 years, was I supposed to be doing something different??? ;{) ________________________________________________________________________________
Subject: Lycoming Mechanical Fuel Pump Available
Date: Jan 25, 2006
I have a new fuel pump model LW15473 date code 3905 avialable for $200. I'll pay shipping. ACS list $254.95 plus shipping. Good for engine models: IO-320, IO-360, AIO-360, HIO-360, IVO-360, IO-540, IGO-540, IO-720. Here's the scoop: I have an O360 which came from the factory with a low pressure fuel pump, an LW15472, which was recalled under a mandatory service bulletin. The Cessna dealer, Dulles Aviation, of Manassas VA, removed this pump & incorrectly recorded the model number as LW15473. The error was not caught by Cessna who shipped back a LW15473 which Dulles subsequently installed. The 25-30psi this pump produces overwhelmed my carburettor's ability to stop the fuel flow & it only took me four days to diagnose why my new from the factory engine wouldn't run more than 10 seconds before dying with fuel dripping out the filtered air box because I suspected everything I had done first. So, I bought a new low pressure pump from ACS and removed the one I have available. Total run time on it is about 30 seconds. What really bugged me though was that Dulles Aviation insisted they had done nothing wrong even though they agreed they had installed the wrong pump. So, if any of you have to have this warrantee type of service done by a dealer, beware, and make sure they get the numbers, which can be hard to read, right. Dave Reel - RV8A - Engine now running. ________________________________________________________________________________
Date: Jan 25, 2006
Subject: Re: Lycoming Mechanical Fuel Pump Available
DAVID REEL wrote: > > I have a new fuel pump model LW15473 date code 3905 avialable for > $200. I'll pay shipping. ACS list $254.95 plus shipping. Good for > engine models: IO-320, IO-360, AIO-360, HIO-360, IVO-360, IO-540, > IGO-540, IO-720. Here's the scoop: > > I have an O360 which came from the factory with a low pressure fuel > pump, an LW15472, which was recalled under a mandatory service > bulletin. The Cessna dealer, Dulles Aviation, of Manassas VA, > removed this pump & incorrectly recorded the model number as LW15473. > The error was not caught by Cessna who shipped back a LW15473 which > Dulles subsequently installed. The 25-30psi this pump produces > overwhelmed my carburettor's ability to stop the fuel flow & it only > took me four days to diagnose why my new from the factory engine > wouldn't run more than 10 seconds before dying with fuel dripping out > the filtered air box because I suspected everything I had done first. > So, I bought a new low pressure pump from ACS and removed the one I > have available. Total run time on it is about 30 seconds. I thought I was the only one who had been through this fiasco! :-) Wentworth sent a high pressure pump with my used O-320 engine. Like Dave's engine, mine would only run a few seconds before fuel would be pouring out the carb. After considerable time spent troubleshooting, I disgustedly had the carb in hand and was about to tear it apart when somebody mentioned "What are the odds you have a high pressure pump?". The two pumps look identical. I used a Sharpie and wrote the correct part number on my new low pressure pump. This was one of those deals that in hindsight I should have figured out in minutes.......but didn't.... I think I still have the several-years-old used high pressure pump in case anybody wants it for a spare; I have no knowledge of its history. Sam Buchanan ________________________________________________________________________________
Date: Jan 25, 2006
I helped a friend with his IO-360 replace his mechanical fuel pump. The mechanial fuel pump was not making enough pressure to keep the engine running. The new pump came out of a new box with the part number of a high pressure fuel pump. The engine would not run more than 5 or 10 seconds. When we checked the new fuel pump, it had the part number of a low pressure fuel pump but the number on the box it came out of was high pressure. The moral of this story is "In God we trust. Everything else we check." This works even if you are a atheists. Verify the part number on the part is what it should be. Verify everything and trust no one. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,833 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: Sam Buchanan <sbuc(at)hiwaay.net> Subject: Re: RV-List: Lycoming Mechanical Fuel Pump Available Date: Wed, 25 Jan 2006 15:47:50 -0600 DAVID REEL wrote: > > I have a new fuel pump model LW15473 date code 3905 avialable for > $200. I'll pay shipping. ACS list $254.95 plus shipping. Good for > engine models: IO-320, IO-360, AIO-360, HIO-360, IVO-360, IO-540, > IGO-540, IO-720. Here's the scoop: > > I have an O360 which came from the factory with a low pressure fuel > pump, an LW15472, which was recalled under a mandatory service > bulletin. The Cessna dealer, Dulles Aviation, of Manassas VA, > removed this pump & incorrectly recorded the model number as LW15473. > The error was not caught by Cessna who shipped back a LW15473 which > Dulles subsequently installed. The 25-30psi this pump produces > overwhelmed my carburettor's ability to stop the fuel flow & it only > took me four days to diagnose why my new from the factory engine > wouldn't run more than 10 seconds before dying with fuel dripping out > the filtered air box because I suspected everything I had done first. > So, I bought a new low pressure pump from ACS and removed the one I > have available. Total run time on it is about 30 seconds. I thought I was the only one who had been through this fiasco! :-) Wentworth sent a high pressure pump with my used O-320 engine. Like Dave's engine, mine would only run a few seconds before fuel would be pouring out the carb. After considerable time spent troubleshooting, I disgustedly had the carb in hand and was about to tear it apart when somebody mentioned "What are the odds you have a high pressure pump?". The two pumps look identical. I used a Sharpie and wrote the correct part number on my new low pressure pump. This was one of those deals that in hindsight I should have figured out in minutes.......but didn't.... I think I still have the several-years-old used high pressure pump in case anybody wants it for a spare; I have no knowledge of its history. Sam Buchanan ________________________________________________________________________________
Date: Jan 25, 2006
Subject: Seats
Hello: I am looking for the best, well not the best but the least expensive place to get my Seats for my rv6a. I only checked Aero Classic,, too much money for my wallett.. Any other, dependable places ? Appreciate suggestions \\ Bert rvf6a ________________________________________________________________________________
Subject: Need suggestion for book on fiberglass
Date: Jan 25, 2006
Does anyone know of a good book on how to do the fiberglass work that we typically do on RV's? Im tired of guessing at every step and bugging everybody on this list. Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ----- Original Message ----- From: "Wheeler North" <wnorth(at)sdccd.edu> Sent: Wednesday, January 25, 2006 2:59 PM Subject: Re: RV-List: > > We'd just wake up in the morning, scratch ourselves, and see what food we > can find laying around. > > > Dang, I been doing this for 48 years, was I supposed to be doing something > different??? > > > ;{) > > > > > 5.5.2658.2"> > Re: RV-List: > > > We'd just wake up in the morning, scratch ourselves, and see what food we > can find laying around. > > > Dang, I been doing this for 48 years, was I supposed to be doing something > different??? > > > ;{) > > > ________________________________________________________________________________
Subject: Re: Seats
Date: Jan 25, 2006
I bought my foam from Vans and had a local auto upholstery shop do the rest. Im satisfied with Vans product. Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ----- Original Message ----- From: "Bert Murillo" <bertrv6(at)gmail.com> Sent: Wednesday, January 25, 2006 4:10 PM Subject: RV-List: Seats > > Hello: > > I am looking for the best, well not the best but the least expensive > place > to get my Seats for my rv6a. > > I only checked Aero Classic,, too much money for my wallett.. > > Any other, dependable places ? > > Appreciate suggestions > > \\ > Bert > > > rvf6a > > > ________________________________________________________________________________
Subject: Seats
Date: Jan 25, 2006
Bert, try Flightline Interiors. Abby is very reasonable and product is great! Mike ________________________________________________________________________________
Date: Jan 25, 2006
Sam James has a VHS tape on basic fiberglassing, as used in RV's. Andy Gold at Builder's Books sells it. Terry Does anyone know of a good book on how to do the fiberglass work that we typically do on RV's? Im tired of guessing at every step and bugging everybody on this list. Shemp/Jeff Dowling ________________________________________________________________________________
Date: Jan 25, 2006
There's two types of fiber glassing, vinyl ester and epoxy. If you have vinyl ester parts, let me know and we'll hook you up with a friendly Glasair builder in your area, if it's epoxy work then you'll have to troll over to the Lancair list. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jeff Dowling Sent: Wednesday, January 25, 2006 6:37 PM Subject: RV-List: Need suggestion for book on fiberglass Does anyone know of a good book on how to do the fiberglass work that we typically do on RV's? Im tired of guessing at every step and bugging everybody on this list. Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ----- Original Message ----- From: "Wheeler North" <wnorth(at)sdccd.edu> Sent: Wednesday, January 25, 2006 2:59 PM Subject: Re: RV-List: > > We'd just wake up in the morning, scratch ourselves, and see what food we > can find laying around. > > > Dang, I been doing this for 48 years, was I supposed to be doing something > different??? > > > ;{) > > > > > 5.5.2658.2"> > Re: RV-List: > > > We'd just wake up in the morning, scratch ourselves, and see what food we > can find laying around. > > > Dang, I been doing this for 48 years, was I supposed to be doing something > different??? > > > ;{) > > > ________________________________________________________________________________
Date: Jan 25, 2006
Subject: Re: Need suggestion for book on fiberglass
You might try contacting Sam James, he has an excellent video for beginners. I think it is called Composites 101!!!!! If you have specific question, your welcome to call or email me. I work with composites every day. BRIAN ALLEY (N320WT) CARBON FIBER COMPOSITES 101 Caroline Circle Hurricane, WV 25526 304-562-6800 home 304-395-4932 cell How are you going to win by a nose if you don't stick out your neck? ________________________________________________________________________________
Date: Jan 25, 2006
Chris, go here and see if this helps, he's using a NAPA 7355 belt: http://our-rv7a.com/engine/engine110703.htm Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Slowbuild wings-QB Fuse-XPO360 engine :-) Chris Brooks wrote: > >Konrad, that makes since to me. My algebra is probably flawed but I >calculated that if I went with a 3-1/4" pulley instead of the 2-3/4" it >would move the alt. .4" closer to the engine but only gain 1/8" of pulley >clearance. That .4" puts me back into the prop governor line. > >Chris > > > > > > > > > ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Jan 25, 2006
If you have a belt length problem, take your current belt to the local auto parts store. They will have a gauge to measure the length of your belt. Once you know that, you can choose another one that is the appropriate amount shorter. I found a little pulley scrubbing on my -'6's cowl last summer, took the old belt in and got a replacement that was a centimeter or two shorter. Made all the difference in the world. KB ________________________________________________________________________________
Date: Jan 25, 2006
tried emailing you to give you the fiberglass 101 sam james video ----- Original Message ----- From: "Jeff Dowling" <shempdowling2(at)earthlink.net> Sent: Wednesday, January 25, 2006 5:37 PM Subject: RV-List: Need suggestion for book on fiberglass > > > Does anyone know of a good book on how to do the fiberglass work that we > typically do on RV's? Im tired of guessing at every step and bugging > everybody on this list. > > Shemp/Jeff Dowling > RV-6A, N915JD > 235 hours > Chicago/Louisville > > ----- Original Message ----- > From: "Wheeler North" <wnorth(at)sdccd.edu> > To: > Sent: Wednesday, January 25, 2006 2:59 PM > Subject: Re: RV-List: > > >> >> We'd just wake up in the morning, scratch ourselves, and see what food we >> can find laying around. >> >> >> Dang, I been doing this for 48 years, was I supposed to be doing >> something >> different??? >> >> >> ;{) >> >> >> >> >> >> > 5.5.2658.2"> >> Re: RV-List: >> >> >> >> >> >> We'd just wake up in the morning, scratch ourselves, and see what food we >> can find laying around. >> >> >> >> >> >> >> >> >> Dang, I been doing this for 48 years, was I supposed to be doing >> something >> different??? >> >> >> >> >> >> >> >> >> ;{) >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: A little adition from an old fart
Date: Jan 25, 2006
Well I couldnt help it I had to add this. If It hadnt have been for all the wars that took so many out, we would be standing on each other. Now we have to deal with the fact that oour wars dont make many inroads on overpop., keep in mind that its not fuel, but pop, that keeps the balance.. Burn me at the stake, I dont give a damn. Charlie Heathco ________________________________________________________________________________
Date: Jan 25, 2006
I couldn't get any fuel pressure from the mech pump on one of the 0360-a4m's I bought brand new. After checking the pump and finding it worked fine we tore off the accessory housing and found that lycoming installed the wrong gear. So there was no cam to operate the pump. Steve dinieri The moral of this story is "In God we trust. Everything else we check." This works even if you are a atheists. Verify the part number on the part is what it should be. Verify everything and trust no one. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,833 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ________________________________________________________________________________
Subject: Smooth Prime, Sam James Videos on Fiberglass & Painting
Date: Jan 26, 2006
Here's a good primer on fiberglass work: http://rv8a.tripod.com/fiberglass.html I also recommend the Smooth Prime pinhole filler and got a gallon from Sacramento Sky Ranch (best price). One gallon was enough for 2 RV's. Spray it on, the roller method is too uneven. I just finished painting my plane and would suggest both of the Sam James videos. They are now for sale. Fiberglass 101 $20 incl. shipping Painting 101 $20 incl. shipping Both for $35 Drop me an email off list. Kbob at cox.net Kelly Patterson N716K RV-6A PHX, AZ Final Assembly, ready to weigh From: "Jeff Dowling" <shempdowling2(at)earthlink.net> Subject: RV-List: Need suggestion for book on fiberglass Does anyone know of a good book on how to do the fiberglass work that we typically do on RV's? Im tired of guessing at every step and bugging everybody on this list. Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ________________________________________________________________________________
Subject: Re: Sikaflex Tip-up
Date: Jan 26, 2006
I used Sikaflex for attaching the plexi on my tip up as well as using it as a fairing at the front of the windshield. Pretty straight forward just go to their web site http://www.sikaindustry.ca/ind/ind-mar/ind-mar-window/ind-mar-window-instal.htm and follow the instructions. Basically its prep, prime, apply and clamp. Drop me a line if you have specific questions. Wayne RV7a in final assembly C-GOYA -------- RV 7 eh? C-GOYA Claresholm, AB (CEJ4) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=6955#6955 ________________________________________________________________________________
Subject: Re: Smooth Prime, Sam James Videos on Fiberglass & Painting
Date: Jan 26, 2006
On Thursday 26 January 2006 08:50 am, Kelly Patterson wrote: > > > Here's a good primer on fiberglass work: > > http://rv8a.tripod.com/fiberglass.html > > I also recommend the Smooth Prime pinhole filler and got a gallon from > Sacramento Sky Ranch (best price). > One gallon was enough for 2 RV's. Spray it on, the roller method is too > uneven. > > I just finished painting my plane and would suggest both of the Sam James > videos. They are now for sale. > Fiberglass 101 $20 incl. shipping > Painting 101 $20 incl. shipping > Both for $35 > Drop me an email off list. Kbob at cox.net > > Kelly Patterson Kelly, Still have the videos? I would be interested. Jim Paypal? check? Jim Carlton 7614 Chesterfield Ave Parma, OH 44129 ________________________________________________________________________________
Date: Jan 26, 2006
I just read the fiberglass section at http://rv8a.tripod.com/fiberglass.html. This is all very good information and should be very helpfull to those just beginning to dive into the composite parts that come with your kits. The one thing I didn't see is the prep work need on the part you are working on. When applying a reinforcement or patch to any composite part that is cured, it is necessary to prepare that surface for bonding. I sand usually with 80 grit until there is nothing shiny left, then remove the dust with compressed air. I don't recommend cleaning freshly prepared surfaces with acetone as this just contaminates the surface you are preparing. After wetting out the cloth as described, apply a small amount of resin to the prepared surface using a gloved finger or squeegee. There just isn't enough resin left in the laminate to wet the surface of the part. Use a squeegee or roller to force out any trapped air. I usuall remove any excess resin from the edges of the layup by tamping with a folded dry paper towel. The prep work on the part is just as important as how the layup is prepared to ensure a proper bond. BRIAN ALLEY (N320WT) CARBON FIBER COMPOSITES 101 Caroline Circle Hurricane, WV 25526 304-562-6800 home 304-395-4932 cell How are you going to win by a nose if you don't stick out your neck? ________________________________________________________________________________
Subject: Torque for Delrin Seals
Date: Jan 26, 2006
Does the use of these seals affect the torque used to tighten the fluid fitting where they are employed? I use 240 in-lb on my -8 aluminum fitting where I'm thinking of trying these. Dave Reel - RV8A - Leaking ________________________________________________________________________________
Subject: Canopy shade
Date: Jan 26, 2006
The best I have found are at walmart in the auto section. About $10 for a pair that fold up and can be stuck in front, the side, the top, wherever you need it. I would not use anything else. John Furey 2 RV6A's - F1 in process ________________________________________________________________________________
Date: Jan 26, 2006
IIRC there was something called a KOGER sunshade.......memory...... -----Original Message----- >From: John Furey <john(at)fureychrysler.com> >Sent: Jan 26, 2006 1:10 PM >To: rv-list(at)matronics.com >Subject: RE: RV-List: Canopy shade > > >The best I have found are at walmart in the auto section. About $10 for a >pair that fold up and can be stuck in front, the side, the top, wherever >you need it. I would not use anything else. > >John Furey >2 RV6A's - F1 in process > > > > > > > ________________________________________________________________________________
Date: Jan 26, 2006
Available from the Vans catalogue -------------- Original message ---------------------- From: "Ralph E. Capen" <recapen(at)earthlink.net> > > IIRC there was something called a KOGER sunshade.......memory...... > > -----Original Message----- > >From: John Furey <john(at)fureychrysler.com> > >Sent: Jan 26, 2006 1:10 PM > >To: rv-list(at)matronics.com > >Subject: RE: RV-List: Canopy shade > > > > > >The best I have found are at walmart in the auto section. About $10 for a > >pair that fold up and can be stuck in front, the side, the top, wherever > >you need it. I would not use anything else. > > > >John Furey > >2 RV6A's - F1 in process > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 26, 2006
Mickey, This subject was discussed at length on the Lancair List. The Lancair manuals recommend cleaning freshly prepped surfaces with acetone. Most builders especially professional composite workers and engineers have performend test that show improved bonding especially in peel strength when acetone or other solvents are not used. If you apply fresh epoxy to the sanded area and work it into the surface any minute particles of dust will mix with the epoxy just like cotton flox or micro ballons and become a part of the structure. If you use acetone, you are just making acetone soup and contaminating the freshly prepared surface. Some amount of acetone residue will always remain in the surface and weaken the bond. BRIAN ALLEY (N320WT) CARBON FIBER COMPOSITES 101 Caroline Circle Hurricane, WV 25526 304-562-6800 home 304-395-4932 cell How are you going to win by a nose if you don't stick out your neck? ________________________________________________________________________________
Date: Jan 26, 2006
I seem to remember from my Lancair build that the study I recall said it took something like 12 hours for acetone or MC to totally evaporate from the surface. That could be speeded up with the use of a hair dryer or other heat source. So if you have to remove contamination from a critical bond area, don't get in a hurry. Brian Alley wrote: > >Mickey, This subject was discussed at length on the Lancair List. The Lancair manuals recommend cleaning freshly prepped surfaces with acetone. Most builders especially professional composite workers and engineers have performend test that show improved bonding especially in peel strength when acetone or other solvents are not used. If you apply fresh epoxy to the sanded area and work it into the surface any minute particles of dust will mix with the epoxy just like cotton flox or micro ballons and become a part of the structure. If you use acetone, you are just making acetone soup and contaminating the freshly prepared surface. Some amount of acetone residue will always remain in the surface and weaken the bond. > >BRIAN ALLEY (N320WT) >CARBON FIBER COMPOSITES >101 Caroline Circle >Hurricane, WV 25526 >304-562-6800 home >304-395-4932 cell > >How are you going to win by a nose if you don't stick out your neck? > > > > > > > > > ________________________________________________________________________________
From: "czechsix(at)juno.com" <czechsix(at)juno.com>
Date: Jan 26, 2006
Subject: Transition training in a -6A or -7A near Iowa?
Guys, AIG wants me to get 1 hour of dual with a CFI in a -6A or -7A prior to covering my first flight in my -8A. Anybody know of a CFI in the midwest who could do this? The closest person I'm aware of is Ben Johnson in Mesquite, TX. That's quite a ways to travel for an hour of dual and I'd rather find someone closer to home if possible (I'm in Cedar Rapids, Iowa). Please let me know off-list at czechsix(at)juno.com Thanks! --Mark Navratil Cedar Rapids, Iowa RV-8A N2D ready to roll.... Guys, AIG wants me to get 1 hour of dual with a CFI in a -6A or -7A prior to covering my first flight in my -8A. Anybody know of a CFI in the midwest who could do this? The closest person I'm aware of is Ben Johnson in Mesquite, TX. That's quite a ways to travel for an hour of dual and I'd rather find someone closer to home if possible (I'm in Cedar Rapids, Iowa). Please let me know off-list at czechsix(at)juno.com Thanks! --Mark Navratil Cedar Rapids, Iowa RV-8A N2D ready to roll.... ________________________________________________________________________________
Subject: Re: Seats
Date: Jan 26, 2006
The least expensive way might be to buy from someone changing or upgrading. Maybe salvage also. Could take some patience waiting for a deal to show up. Next to that might be making your own. I flew on my home brew seats for several years before upgrading to Orndorf (sp?) products. Wasn't too tough of a job. Bought an old sewing machine and got after it. The Van's foam may be the way to go now days. I bought and cut my own foam. Bryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=7085#7085 ________________________________________________________________________________
Date: Jan 26, 2006
Subject: Re: Gluing Canopy RV9A Tip-up
You can go to: www.rvwiki.org/index.php?title=Main_Page There are some pictures and installation notes under the "canopy construction" subject that might answer your question about using Sikaflex adhesive for a tip-up canopy. Jim Ellis RV9-A Tip-up wheel pants ________________________________________________________________________________
Date: Jan 26, 2006
Try Tom Irlbeck http://www.mnwing.org/cgi-bin/WebObjects/mnwing.woa , look under Transition Training. I got quite a few hours from Tom. Great Guy. Former Top Gun Instructor. John L. Danielson -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of czechsix(at)juno.com Sent: Thursday, January 26, 2006 1:54 PM Subject: RV-List: Transition training in a -6A or -7A near Iowa? Guys, AIG wants me to get 1 hour of dual with a CFI in a -6A or -7A prior to covering my first flight in my -8A. Anybody know of a CFI in the midwest who could do this? The closest person I'm aware of is Ben Johnson in Mesquite, TX. That's quite a ways to travel for an hour of dual and I'd rather find someone closer to home if possible (I'm in Cedar Rapids, Iowa). Please let me know off-list at czechsix(at)juno.com Thanks! --Mark Navratil Cedar Rapids, Iowa RV-8A N2D ready to roll.... Guys, AIG wants me to get 1 hour of dual with a CFI in a -6A or -7A prior to covering my first flight in my -8A. Anybody know of a CFI in the midwest who could do this? The closest person I'm aware of is Ben Johnson in Mesquite, TX. That's quite a ways to travel for an hour of dual and I'd rather find someone closer to home if possible (I'm in Cedar Rapids, Iowa). Please let me know off-list at czechsix(at)juno.com Thanks! --Mark Navratil Cedar Rapids, Iowa RV-8A N2D ready to roll.... ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Jan 26, 2006
> > Try Tom Irlbeck > http://www.mnwing.org/cgi-bin/WebObjects/mnwing.woa , look > under Transition Training. > I got quite a few hours from Tom. Great Guy. Former Top Gun > Instructor. > > John L. Danielson Tom is in FL until about the beginning of May. FYI, he has done something around 30 first flights for RV guys around here. Alex Peterson RV6-A N66AP 708 hours Maple Grove, MN ________________________________________________________________________________
Date: Jan 26, 2006
Subject: Troubling Airworthiness Directive...
I just received an AD in the mail regarding cylinder heads on Lycoming 320 and 360 engines manufactured by ECI. It requires that the cylinders be replaced before 800 hours or if you are over 800 than within 60 hours.... This could cost a fortune, who pays for this? I am a recent aircraft owner for the first time and have not encountered this before. I cant imagine that the manufacture (ECI) doesnt have some kind of liability. My engine just had an overhaul 40 hours ago! - Matt ________________________________________________________________________________
Subject: Flight training
Date: Jan 26, 2006
Looking for someone in the Snta Ana arer that can give Duel in a RV-6 ________________________________________________________________________________
Date: Jan 26, 2006
> > I just received an AD in the mail regarding cylinder heads on > Lycoming 320 and 360 engines manufactured by ECI. It requires > that the cylinders be replaced before 800 hours or if you are > over 800 than within 60 hours.... This could cost a fortune, > who pays for this? I am a recent aircraft owner for the first > time and have not encountered this before. I cant imagine > that the manufacture (ECI) doesnt have some kind of > liability. My engine just had an overhaul 40 hours ago! > > - Matt If you have the cylinders on an RV, compliance is not required. However, most RVers will comply, and I understand that for four new cylinders the price from ECI will be $1300 total. They aren't paying for the labor. Welcome to an imperfect world. Alex Peterson RV6-A N66AP 708 hours (lucky, at least for now, to have Millennium cylinders) Maple Grove, MN ________________________________________________________________________________
Date: Jan 26, 2006
Subject: Re: Troubling Airworthiness Directive...
At 06:56 PM 1/26/2006, you wrote: > >I just received an AD in the mail regarding cylinder heads on Lycoming 320 >and 360 engines manufactured by ECI. It requires that the >cylinders be replaced before 800 hours or if you are over 800 than within >60 hours.... This could cost a fortune, who pays for this? I am a >recent aircraft owner for the first time and have not encountered this >before. I cant imagine that the manufacture (ECI) doesnt have some >kind of liability. My engine just had an overhaul 40 hours ago! > >- Matt Before you get upset read the AD. It is probably on their website and may not even apply to you. Ron Lee ________________________________________________________________________________
Date: Jan 26, 2006
It is for a certified plane (Grumman). I guess that I dont have to comply until it is at 800 hours, but it will still hurt the resell value if I dont do it. How often do people get AD's that cost them thousands of dollars on a whim? At least with cars they are recalls and the manufacturer picks up the cost of replacement... - Matt -----Original Message----- From: "Alex Peterson" <alexpeterson(at)earthlink.net> Date: Thu, 26 Jan 2006 20:06:31 -0600 Subject: RE: RV-List: Troubling Airworthiness Directive... > > > > > > > > I just received an AD in the mail regarding cylinder heads on > > Lycoming 320 and 360 engines manufactured by ECI. It requires > > that the cylinders be replaced before 800 hours or if you are > > over 800 than within 60 hours.... This could cost a fortune, > > who pays for this? I am a recent aircraft owner for the first > > time and have not encountered this before. I cant imagine > > that the manufacture (ECI) doesnt have some kind of > > liability. My engine just had an overhaul 40 hours ago! > > > > - Matt > > If you have the cylinders on an RV, compliance is not required. > However, > most RVers will comply, and I understand that for four new cylinders > the > price from ECI will be $1300 total. They aren't paying for the labor. > Welcome to an imperfect world. > > Alex Peterson > RV6-A N66AP 708 hours (lucky, at least for now, to have Millennium > cylinders) > Maple Grove, MN > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 26, 2006
Chris, I have the B&C alternator and have over 1200 hours with it. It works perfect, no problem with clearance. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: "Chris Brooks" <brooksrv6(at)hotmail.com> Sent: Tuesday, January 24, 2006 4:13 PM Subject: RV-List: B&C alternator clearance > > I currently have Vans 35amp alt. With a Gates 7355 belt (36-1/4") on an > O-360 C/S. Somewhere between 3-3.5 g's the pulley makes contact with lower > cowl. > I tried the next size shorter belt 7350 (35-5/8") but it's too tight and > holds the alternator against the Stainless oil line from the governor. I > would buy a B&C L40 if I thought it would give more clearance, but would > rather save the money if it wouldn't fit with the shorter belt. > Does anyone have a B&C L40 on a O-360 with a constant speed prop, and > using > a 7350 (35-5/8") (890mm) belt? If I know this combination works I'll order > the B&C. > > Chris Brooks > RV6 > > > ________________________________________________________________________________
Date: Jan 26, 2006
They're paying $475 for labor, it's included in the $1350 exchange price that they are charging me. The AD doesn't affect all ECi cylinders, just the "Classic Cast". The replacements are "Titan" which are a step up. They also pay shipping one way. Dave >If you have the cylinders on an RV, compliance is not required. However, >most RVers will comply, and I understand that for four new cylinders the >price from ECI will be $1300 total. They aren't paying for the labor. >Welcome to an imperfect world. > >Alex Peterson >RV6-A N66AP 708 hours (lucky, at least for now, to have Millennium >cylinders) >Maple Grove, MN > > > > > > > > > ________________________________________________________________________________
Date: Jan 26, 2006
FYI. This does not apply to the new ECI Titan cylinders that many kit builders including myself purchased. Of course you can double check that with ECI . Eddy Fernandez RV-9a Finishing ECI O-320 -----Original Message----- From: Matt Johnson <matt(at)n559rv.com> Subject: RV-List: Troubling Airworthiness Directive... I just received an AD in the mail regarding cylinder heads on Lycoming 320 and 360 engines manufactured by ECI. It requires that the cylinders be replaced before 800 hours or if you are over 800 than within 60 hours.... This could cost a fortune, who pays for this? I am a recent aircraft owner for the first time and have not encountered this before. I cant imagine that the manufacture (ECI) doesnt have some kind of liability. My engine just had an overhaul 40 hours ago! - Matt ________________________________________________________________________________
Date: Jan 26, 2006
ECI will pay for a pro-rated labor reimbursement for removal & installation. http://www.eci2fly.com/pdf/05-8.pdf last paragraph. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Alex Peterson [mailto:alexpeterson(at)earthlink.net] > Sent: Thursday, January 26, 2006 9:07 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Troubling Airworthiness Directive... > > --> > > > > > ...They aren't paying for the labor. > Welcome to an imperfect world. > > Alex Peterson > RV6-A N66AP 708 hours (lucky, at least for now, to have Millennium > cylinders) > Maple Grove, MN ________________________________________________________________________________
Date: Jan 26, 2006
First of all, determine whether the AD applies to the exact serial number cylinders you have. Given your overhaul is so recent, it is very unlikely, but get with your overhauler and be CERTAIN. It is the owner's responsibility. An engine still under warranty is likely to get much more consideration than the basic coverage mentioned in the AD. Matt Johnson wrote: > > It is for a certified plane (Grumman). I guess that I dont have to comply until it is at 800 hours, but it will still hurt the resell value if I > dont do it. > > How often do people get AD's that cost them thousands of dollars on a whim? At least with cars they are recalls and the manufacturer > picks up the cost of replacement... > > - Matt > > > -----Original Message----- > From: "Alex Peterson" <alexpeterson(at)earthlink.net> > To: > Date: Thu, 26 Jan 2006 20:06:31 -0600 > Subject: RE: RV-List: Troubling Airworthiness Directive... > >> >> >> >> >>> >>> I just received an AD in the mail regarding cylinder heads on >>> Lycoming 320 and 360 engines manufactured by ECI. It requires >>> that the cylinders be replaced before 800 hours or if you are >>> over 800 than within 60 hours.... This could cost a fortune, >>> who pays for this? I am a recent aircraft owner for the first >>> time and have not encountered this before. I cant imagine >>> that the manufacture (ECI) doesnt have some kind of >>> liability. My engine just had an overhaul 40 hours ago! >>> >>> - Matt >> If you have the cylinders on an RV, compliance is not required. >> However, >> most RVers will comply, and I understand that for four new cylinders >> the >> price from ECI will be $1300 total. They aren't paying for the labor. >> Welcome to an imperfect world. >> >> Alex Peterson >> RV6-A N66AP 708 hours (lucky, at least for now, to have Millennium >> cylinders) >> Maple Grove, MN >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: first real dimples
Date: Jan 27, 2006
Yes Dan, I used a pneumatic squeezer extensivly and had the same effect. Just set a rivit in the dimple and it will show you if the dept is correct. Use some scrap alum. sheet for practice when you go to a different thickness to set the dimple depth. I think they say, your not building a swiss watch here. Have fun. It will look great. Jim Bowen RV-8 QB >From: Dan <dan(at)rdan.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: first real dimples >Date: Mon, 23 Jan 2006 19:10:33 -0800 (PST) > > >Ok I am just now setting my first real dimples in the HS spars and ribs, > pneumatic squeezer, do I want to see the slight ring imprint also ,? or >am I just a little deep ? > How about when I get to the skin ?? > Thanks all,., > > Dan Hatch > -8 QB > N728RV Reserved > > and gettin on a roll ! > > ________________________________________________________________________________
Date: Jan 27, 2006
matt(at)n559rv.com wrote: > > How often do people get AD's that cost them thousands of dollars on a whim? At least with cars they are recalls and the manufacturer > picks up the cost of replacement. Do a search on the 400 series Cessna wing spar AD. $60,000 out of every owners pocket because Cessna did a theoretical study that contains "confidential data not available to the public" No reimbursement by Cessna, all out of the owners pocket. It affects so many planes it will take Cessna 5 years to mfg all the kits. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=7251#7251 ________________________________________________________________________________
Date: Jan 27, 2006
Perhaps it's time for a class action suit against Cessna. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of N395V Sent: Friday, January 27, 2006 8:07 AM Subject: RV-List: Re: Troubling Airworthiness Directive... matt(at)n559rv.com wrote: > > How often do people get AD's that cost them thousands of dollars on a whim? At least with cars they are recalls and the manufacturer > picks up the cost of replacement. Do a search on the 400 series Cessna wing spar AD. $60,000 out of every owners pocket because Cessna did a theoretical study that contains "confidential data not available to the public" No reimbursement by Cessna, all out of the owners pocket. It affects so many planes it will take Cessna 5 years to mfg all the kits. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=7251#7251 ________________________________________________________________________________
Date: Jan 27, 2006
Keep in mind that the longer you run the cylinders, the less ECI will "discount" the replacement Titan cylinders. Rhonda -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Alex Peterson Sent: Thursday, January 26, 2006 8:07 PM Subject: RE: RV-List: Troubling Airworthiness Directive... > > I just received an AD in the mail regarding cylinder heads on > Lycoming 320 and 360 engines manufactured by ECI. It requires > that the cylinders be replaced before 800 hours or if you are > over 800 than within 60 hours.... This could cost a fortune, > who pays for this? I am a recent aircraft owner for the first > time and have not encountered this before. I cant imagine > that the manufacture (ECI) doesnt have some kind of > liability. My engine just had an overhaul 40 hours ago! > > - Matt If you have the cylinders on an RV, compliance is not required. However, most RVers will comply, and I understand that for four new cylinders the price from ECI will be $1300 total. They aren't paying for the labor. Welcome to an imperfect world. Alex Peterson RV6-A N66AP 708 hours (lucky, at least for now, to have Millennium cylinders) Maple Grove, MN ________________________________________________________________________________
Date: Jan 27, 2006
First make sure you cylinders are the ones affected . . . I'm told that "Classic Cast" cylinders haven't been made since 2001?? "Titan" cylinders (post 2001) are not included in the AD. If you engine only has 40 hours on it maybe they are ECi "Titan" cylinders? Good Luck, Bob On 1/26/06, Matt Johnson wrote: > > > I just received an AD in the mail regarding cylinder heads on Lycoming 320 > and 360 engines manufactured by ECI. It requires that the > cylinders be replaced before 800 hours or if you are over 800 than within > 60 hours.... This could cost a fortune, who pays for this? I am a > recent aircraft owner for the first time and have not encountered this > before. I cant imagine that the manufacture (ECI) doesnt have some > kind of liability. My engine just had an overhaul 40 hours ago! > > - Matt > > ________________________________________________________________________________
Date: Jan 27, 2006
Another point . . . these cylinders were "certified" by the FAA to "perform equal to the original manufacturer's part" . . . shouldn't the FAA pick up their share of the blame and cost?? Perhaps ECi doesn't agree with the FAA's conclusion . . . it becomes a sticky situation?! Regards, Bob On 1/27/06, Bruce Gray wrote: > > > Perhaps it's time for a class action suit against Cessna. > > Bruce > www.glasair.org > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of N395V > Sent: Friday, January 27, 2006 8:07 AM > To: rv-list(at)matronics.com > Subject: RV-List: Re: Troubling Airworthiness Directive... > > > matt(at)n559rv.com wrote: > > > > How often do people get AD's that cost them thousands of dollars on a > whim? At least with cars they are recalls and the manufacturer > > picks up the cost of replacement. > > > Do a search on the 400 series Cessna wing spar AD. > > $60,000 out of every owners pocket because Cessna did a theoretical study > that contains "confidential data not available to the public" > > No reimbursement by Cessna, all out of the owners pocket. It affects so > many planes it will take Cessna 5 years to mfg all the kits. > > -------- > Milt > N395V > F1 Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=3D7251#7251 > > ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Date: Jan 27, 2006
> Perhaps it's time for a class action suit against Cessna. I believe that's exactly the reason Cessna stopped making single engined airplanes in the 80's.............. ________________________________________________________________________________
Date: Jan 27, 2006
On Jan 27, 2006, at 8:12 AM, Bruce Gray wrote: > > Perhaps it's time for a class action suit against Cessna. > > Bruce > www.glasair.org > > (snip) > > Do a search on the 400 series Cessna wing spar AD. > > (snip) C'mon Bruce. A lawsuit on planes that haven't been manufactured in over 30 years? Should t-34 owners sue Beech for the wing spar ADs on those airplanes? Small wonder that it's difficult to find honest support for older airplanes. ________________________________________________________________________________
Date: Jan 27, 2006
Here is an interesting article on Aviation Product Liability. http://www.avweb.com/news/avlaw/181885-1.html Bob C...There is a small section in the article that speaks to FAA certification. Regards, Skippy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=7309#7309 ________________________________________________________________________________
From: "Dan Beadle" <dan.beadle(at)inclinesoftworks.com>
Date: Jan 27, 2006
I am a C414A owner. I watched this AD progress through. The cost is probably closer to $90K with real labor rates. FORTUNATELY, like the eci AD, it only applies in certain situations - in my case with 18000 airframe hours. I have 4500 hours on the airframe and fly 250 hours a year. With a little math... That is another 52 years of service I can expect. And, if I were convinced that it were a safety issue now, I would apply the AD. $90K is only 15% of the value of the airplane. And it is far less than the value of my life. I am a little bit miffed that Cessna will not share the engineering data so we can understand it - but that is probably the result of lawyers afraid that the data will hang them. Dan -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James Freeman Sent: Friday, January 27, 2006 7:28 AM Subject: Re: RV-List: Re: Troubling Airworthiness Directive... On Jan 27, 2006, at 8:12 AM, Bruce Gray wrote: > > Perhaps it's time for a class action suit against Cessna. > > Bruce > www.glasair.org > > (snip) > > Do a search on the 400 series Cessna wing spar AD. > > (snip) C'mon Bruce. A lawsuit on planes that haven't been manufactured in over 30 years? Should t-34 owners sue Beech for the wing spar ADs on those airplanes? Small wonder that it's difficult to find honest support for older airplanes. ________________________________________________________________________________
Date: Jan 27, 2006
In my humble opinion, that is precisely the wrong answer. I watched the Cessna 400 series wing spar AD unfold very closely, and at the core of it, pretty much everyone agrees that Cessna's actions were the result of trying to limit its exposure to liability suits. The only spar failures recorded were in airframes that always flew fully loaded, low down in the summer thermals, and with a light fuel load- precisely the conditions which apply maximum stress to the wing spars. BUT, Cessna is still on the liability hook for airplanes sold many years ago, because they have supplied parts for them which resets the liability period for another 17 years. They are in an impossible situation with lawyers coming from all over the place to take a piece. Damned if they don't take action on the slightest indication of a problem, damned if they do because owners will sue them for making them spend the money. My opinion? Stop class action and liability suits on aircraft manufacturers, because that's the root of the problem (and promote an understanding among all of mankind that life has risks...the failure to accept this has created the litigious business climate we have today). The Cessna 400 series wing is built hell for stout, but that doesn't amount for shit in front of a jury. Dave Bruce Gray wrote: > >Perhaps it's time for a class action suit against Cessna. > >Bruce >www.glasair.org > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of N395V >Sent: Friday, January 27, 2006 8:07 AM >To: rv-list(at)matronics.com >Subject: RV-List: Re: Troubling Airworthiness Directive... > > >matt(at)n559rv.com wrote: > > >>How often do people get AD's that cost them thousands of dollars on a >> >> >whim? At least with cars they are recalls and the manufacturer > > >>picks up the cost of replacement. >> >> > > >Do a search on the 400 series Cessna wing spar AD. > >$60,000 out of every owners pocket because Cessna did a theoretical study >that contains "confidential data not available to the public" > >No reimbursement by Cessna, all out of the owners pocket. It affects so >many planes it will take Cessna 5 years to mfg all the kits. > >-------- >Milt >N395V >F1 Rocket > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=7251#7251 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 27, 2006
Dave, you are completely right IMHO but it shouldn't stop at aircraft manufactures. There should be very strict criteria applied to class action lawsuits as well. Tim -------Original Message------- From: Dave Johnson Date: 01/27/06 10:25:44 Subject: Re: RV-List: Re: Troubling Airworthiness Directive... In my humble opinion, that is precisely the wrong answer. I watched the Cessna 400 series wing spar AD unfold very closely, and at the core of it, pretty much everyone agrees that Cessna's actions were the result of trying to limit its exposure to liability suits. The only spar failures recorded were in airframes that always flew fully loaded, low down in the summer thermals, and with a light fuel load- precisely the conditions which apply maximum stress to the wing spars. BUT, Cessna is still on the liability hook for airplanes sold many years ago, because they have supplied parts for them which resets the liability period for another 17 years. They are in an impossible situation with lawyers coming from all over the place to take a piece. Damned if they don't take action on the slightest indication of a problem, damned if they do because owners will sue them for making them spend the money. My opinion? Stop class action and liability suits on aircraft manufacturers, because that's the root of the problem (and promote an understanding among all of mankind that life has risks...the failure to accept this has created the litigious business climate we have today). The Cessna 400 series wing is built hell for stout, but that doesn't amount for shit in front of a jury. Dave Bruce Gray wrote: > >Perhaps it's time for a class action suit against Cessna. > >Bruce >www.glasair.org > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of N395V >Sent: Friday, January 27, 2006 8:07 AM >To: rv-list(at)matronics.com >Subject: RV-List: Re: Troubling Airworthiness Directive... > > >matt(at)n559rv.com wrote: > > >>How often do people get AD's that cost them thousands of dollars on a >> >> >whim? At least with cars they are recalls and the manufacturer > > >>picks up the cost of replacement. >> >> > > >Do a search on the 400 series Cessna wing spar AD. > >$60,000 out of every owners pocket because Cessna did a theoretical study >that contains "confidential data not available to the public" > >No reimbursement by Cessna, all out of the owners pocket. It affects so >many planes it will take Cessna 5 years to mfg all the kits. > >-------- >Milt >N395V >F1 Rocket > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=3D7251#7251 > > ________________________________________________________________________________
Subject: VS skin attachment
Date: Jan 27, 2006
I'll research, but maybe a bit of help. Attaching the VS skin to the nose ribs I have a little dimple occurring where the rib flange pushes against the skin. I'm trying to match drill and it's leaving a pretty good dent. Any ideas? Has this happened to other RV10 vertical stab builders? Thanks ________________________________________________________________________________
Subject: dent in vertical stab skin
Date: Jan 27, 2006
thanks for the time guys but my research found the answer on Tim Olson's site...thanks Tim and I KNEW there was an answer out there...just wish I found it before I dented the skin...and I even read the rest of the plans but didn't see the reference in the horizontal stab section... Jim ________________________________________________________________________________
Subject: Advanced Flight Systems AF2500 Engine Monitor - Fuel Flow Sensor
Date: Jan 18, 2006
I just got my fuel flow sensor for my AF2500 Engine Monitor and I'm wondering on the best place/way to mount it. (The sensor is an Electronics International Inc (Bend, Orgeon) Model FT-60.) I'm building a 9 (same fuse more-or-less as the 7). I'm putting in an IO-320 from Aerosport. Plans have you run the fuel feed line from the AFP high pressure pump below the tank selector valve to the firewall between the center floor stiffeners. There's not a whole lot of room in there and the latest style sensor is rectangular block of red anodized aluminum measuring some 1.25 x 1.25 x 2". I believe the preferred method is to mount it with the wires exiting the top - which means the mounting bolts would be vertical. Anyone out there have experience with this sensor ? Did you locate it in the cabin floor tunnel forward of the pump ? Did you bolt it to the floor, or glue it ? __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Sensor
Date: Jan 27, 2006
Gerry, I used double sided tape. Along with the fuel lines I think it will stay put. I did have to build a "dog house" over the cut out in the tunnel cover. Hope this helps. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Gerry Filby Sent: Wednesday, January 18, 2006 1:22 PM Subject: RV-List: Advanced Flight Systems AF2500 Engine Monitor - Fuel Flow Sensor I just got my fuel flow sensor for my AF2500 Engine Monitor and I'm wondering on the best place/way to mount it. (The sensor is an Electronics International Inc (Bend, Orgeon) Model FT-60.) I'm building a 9 (same fuse more-or-less as the 7). I'm putting in an IO-320 from Aerosport. Plans have you run the fuel feed line from the AFP high pressure pump below the tank selector valve to the firewall between the center floor stiffeners. There's not a whole lot of room in there and the latest style sensor is rectangular block of red anodized aluminum measuring some 1.25 x 1.25 x 2". I believe the preferred method is to mount it with the wires exiting the top - which means the mounting bolts would be vertical. Anyone out there have experience with this sensor ? Did you locate it in the cabin floor tunnel forward of the pump ? Did you bolt it to the floor, or glue it ? __g__ ========================================================= Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: mogas
Date: Jan 27, 2006
What is easy way to determine which airports have autogas aka mogas for planning XC stops? Indiana Larry, RV7 ________________________________________________________________________________
Subject: Re: mogas
Date: Jan 27, 2006
Check out www.airnav.com Type in the airport identifier(s) that you need and it will list sevices at each in regards to what fuel is available, as well as fairly current prices. Regards, Jeff Orear RV6A N782P (reserved) Getting close Peshtigo, WI ----- Original Message ----- From: "LarryRobertHelming" <lhelming(at)sigecom.net> Sent: Friday, January 27, 2006 9:59 PM Subject: RV-List: mogas > > What is easy way to determine which airports have autogas aka mogas for > planning XC stops? > > Indiana Larry, RV7 > > > ________________________________________________________________________________
Date: Jan 27, 2006
Thank you everyone who has responded to my posts. These forums are very helpful and provide a lot of insite and guidance... Regarding these AD's it amazes me that the manufacturer is not liable. I have always heard of the huge amounts of liability that manufacturers take in the aviation field yet they are not held responsible for these blantantly defective parts in most of the issued AD's... very strange. - Matt -----Original Message----- From: "N395V" <N395V(at)direcway.com> Date: Fri, 27 Jan 2006 05:07:12 -0800 Subject: RV-List: Re: Troubling Airworthiness Directive... > > > matt(at)n559rv.com wrote: > > > > How often do people get AD's that cost them thousands of dollars on a > whim? At least with cars they are recalls and the manufacturer > > picks up the cost of replacement. > > > > Do a search on the 400 series Cessna wing spar AD. > > $60,000 out of every owners pocket because Cessna did a theoretical > study that contains "confidential data not available to the public" > > No reimbursement by Cessna, all out of the owners pocket. It affects > so many planes it will take Cessna 5 years to mfg all the kits. > > -------- > Milt > N395V > F1 Rocket > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=7251#7251 > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 27, 2006
Subject: Re: Advanced Flight Systems AF2500 Engine Monitor - Fuel Flow
Sensor Here is where I mounted mine: http://members.hopkinsville.net/bhester/Baffling.htm Click the picture to view it bigger. Can't tell you how well this we be yet. I got the idea from the RV6A that Superior has on display at Sun-n-fun and Oshkosh. Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Slowbuild wings-QB Fuse-XPO360 engine :-) Gerry Filby wrote: > > >I just got my fuel flow sensor for my AF2500 Engine Monitor and >I'm wondering on the best place/way to mount it. > >(The sensor is an Electronics International Inc (Bend, Orgeon) >Model FT-60.) > >I'm building a 9 (same fuse more-or-less as the 7). I'm >putting in an IO-320 from Aerosport. Plans have you run the >fuel feed line from the AFP high pressure pump below the tank >selector valve to the firewall between the center floor >stiffeners. > >There's not a whole lot of room in there and the latest style >sensor is rectangular block of red anodized aluminum measuring >some 1.25 x 1.25 x 2". I believe the preferred method is to >mount it with the wires exiting the top - which means the >mounting bolts would be vertical. > >Anyone out there have experience with this sensor ? Did you >locate it in the cabin floor tunnel forward of the pump ? Did >you bolt it to the floor, or glue it ? > >__g__ > >========================================================== >Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > > > > > > ________________________________________________________________________________
Date: Jan 28, 2006
Subject: Re: mogas
It will also let you say what type fuel you are looking for and show all airports within so many miles of a specific airport. You should also call ahead to insure the info is current. We use to have it but no longer do. I think the info still says we do. I know two airports not far from here that has it. Murray, KY and Springfeild, TN Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A Slowbuild wings-QB Fuse-XPO360 engine :-) Jeff Orear wrote: > >Check out www.airnav.com > >Type in the airport identifier(s) that you need and it will list sevices at >each in regards to what fuel is available, as well as fairly current prices. > >Regards, > >Jeff Orear >RV6A N782P (reserved) >Getting close >Peshtigo, WI >----- Original Message ----- >From: "LarryRobertHelming" <lhelming(at)sigecom.net> >To: >Sent: Friday, January 27, 2006 9:59 PM >Subject: RV-List: mogas > > > > >> >>What is easy way to determine which airports have autogas aka mogas for >>planning XC stops? >> >>Indiana Larry, RV7 >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > ________________________________________________________________________________
Subject: Re: mogas
Date: Jan 28, 2006
Larry, AirNav.Com has a Fuel Price program. You can use it several ways. But, it also includes a function that enables you to input your departure and arriving airport and specify either the fastest or cheapest route. You can also specify some parameters such as max leg distance, etc. It will then compute up to 10 routes and give you how much you would save (I presume over the average price along the route) each route as well as the distance of each route, etc. Worth using, but as others have said, sometimes the fuel prices and availability are not up todate so you should call ahead. Ed A Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ----- Original Message ----- From: "LarryRobertHelming" <lhelming(at)sigecom.net> Sent: Friday, January 27, 2006 10:59 PM Subject: RV-List: mogas > > What is easy way to determine which airports have autogas aka mogas for > planning XC stops? > > Indiana Larry, RV7 > > > ________________________________________________________________________________
Subject: FAA list of TIS (mode-s) broadcast sites as of 20 January 2006
Date: Jan 28, 2006
Got this off another list I'm on. If you were wondering if Mode S was a lost investment, this may help. -----Original Message----- From: pipercherokee(at)yahoogroups.com [mailto:pipercherokee(at)yahoogroups.com] On Behalf Of paul k. sanchez Sent: Friday, January 27, 2006 7:30 PM Subject: [pipercherokee] FAA list of TIS (mode-s) broadcast sites as of 20 January 2006 Got this list from Rebecca Trexler (rebecca.trexler(at)faa.gov) at the FAA public affairs office. It shows 115 broadcast sites (each 55 nm radius for TIS) as of 20 January 2006. And still 97 broadcast sites after year 2012. But without the Garmin GTX330 you can't get the TIS on your Garmin MX20/GNS430/GNS480/GNS530 or Avidyne display. Operational MODE-S Facilities Providing Traffic Information Service (mode-s) Data as of January 20, 2006 RADAR ST FAC PRIMARY TIS # FACILITY IDENT RDR TYPE REGION MEMO 1 ABILENE TX ABI ASR-8 ASW SEG 1 2 ALBANY NY ALB ASR-9 AEA 3 ALBUQUERQUE NM ABQ ASR-9 ASW 4 ANDREWS AFB MD ADW ASR-9 AEA 5 ATLANTA GA ATL ASR-9 ASO 6 ATLANTA 2 (LAWRENCEVILLE) GA LZU ASR-9 ASO 7 AUSTIN TX AUS ASR-9 ASW 8 BALTIMORE MD BWI ASR-9 AEA 9 BEALE (MARYSVILLE) CA BAB ASR-9 AWP 10 BILLINGS MT BIL ASR-7 ANM SEG 1 11 BIRMINGHAM AL BHM ASR-9 ASO 12 BISMARCK ND BIS ASR-8 AGL SEG 2 13 BOSTON MA BOS ASR-9 ANE 14 BRISTOL/JOHNSON/KINGSPORT TN TRI ASR-8 ASO SEG 2 15 BUFFALO NY BUF ASR-9 AEA 16 BURBANK CA BUR ASR-9 AWP 17 CAMP PENDLETON CA NFG ASR-9 AWP 18 CEDAR RAPIDS IA CID ASR-9 ACE 19 CHARLESTON SC CHS ASR-9 ASO 20 CHARLOTTE NC CLT ASR-9 ASO 21 CHESTER NH MHTT ASR-9 ANE 22 CHICAGO IL ORD ASR-9 AGL 23 CHICAGO (TINLEY PARK) IL QXM ASR-9 AGL 24 CLEVELAND OH CLE ASR-9 AGL 25 COLUMBUS OH CMH ASR-9 AGL 26 CORPUS CHRISTI TX CRP ASR-8 ASW SEG 1 27 COVINGTON/CINCINNATI KY CVG ASR-9 ASO 28 DAYTON OH DAY ASR-9 AGL 29 DAYTONA BEACH FL DAB ASR-9 ASO 30 DENVER CO DVX ASR-9 ANM 31 DENVER-2 (PLATTEVILLE) CO GXY ASR-9 ANM 32 DES MOINES IA DSM ASR-9 ACE 33 DETROIT "A" Site (Romulus) MI DTWA ASR-9 AGL 34 DETROIT "C" SITE (Northville/Pontiac) MI DTWC ASR-9 AGL 35 DFW - 1 TX DFW ASR-9 ASW 36 DFW - 2 (AIRFIELD WEST) TX QZB ASR-9 ASW 37 DFW - 3 (AZLE) TX PA2 ASR-9 ASW 38 DFW - 4 (SACHSE) TX MI2 ASR-9 ASW 39 DULUTH MN DLH ASR-8 AGL SEG 2 40 EL PASO TX ELP ASR-9 ASW 41 EVANSVILLE IN EVV ASR-8 AGL SEG 2 42 FARGO ND FAR ASR-7 AGL SEG 1 43 FAYETTEVILLE NC FAY ASR-8 ASO 44 FORT LAUDERDALE FL FLL ASR-9 ASO 45 FORT SMITH AR FSM ASR-8 ASW SEG 1 46 GAINESVILLE FL GNV ASR-9 ASO 47 GRAND RAPIDS MI GRR ASR-9 AGL 48 GREAT FALLS MT GTF ASR-8 ANM SEG 2 50 HONOLULU HI HNL ASR-9 AWP 51 HOUSTON INTERNATIONAL TX IAH ASR-9 ASW 52 HOUSTON/HOBBY TX HOU ASR-9 ASW 53 INDIANAPOLIS IN IND ASR-9 AGL 54 ISLIP NY ISP ASR-9 AEA 55 JACKSON MS JAN ASR-8 ASO SEG 2 56 JACKSONVILLE FL JAX ASR-9 ASO 57 JFK - NEW YORK NY JFK ASR-9 AEA 58 KANSAS CITY MO MCI ASR-9 ACE 59 LAKE CHARLES LA LCH ASR-8 ASW SEG 2 60 LAS VEGAS NV LAS ASR-9 AWP 61 LITTLE ROCK AR LIT ASR-8 ASW SEG 1 62 LONG BEACH CA LGB ASR-9 AWP 63 LOS ANGELES-1 CA LAX ASR-9 AWP 64 LOS ANGELES-2 CA LAXA ASR-9 AWP 65 LOUISVILLE KY SDF ASR-9 ASO 66 MADISON WI MSN ASR-9 AGL 67 MARTINSBURG WV MRB ASR-9 AEA 68 MEMPHIS TN MEM ASR-9 ASO 69 MIAMI FL MIA ASR-9 ASO 70 MILWAUKEE WI MKE ASR-9 AGL 71 MINNEAPOLIS MN MSP ASR-9 AGL 72 MOFFETT/SAN JOSE CA NUQ ASR-9 AWP 73 NASHVILLE TN BNA ASR-9 ASO 74 NEW ORLEANS LA MSY ASR-9 ASW 75 NEWARK NJ EWR ASR-9 AEA 76 NORFOLK VA ORF ASR-9 AEA 77 OAKLAND CA OAK ASR-9 AWP 78 OKLAHOMA CITY OK OKC ASR-9 ASW 79 OMAHA NE OFF ASR-9 ACE 80 ONTARIO CA ONT ASR-9 AWP 81 ORLANDO FL MCO ASR-9 ASO 82 PALM SPRINGS CA PSP ASR-9 AWP 83 PENSACOLA FL PNS ASR-8 ASO SEG 1 84 PHILADELPHIA PA PHL ASR-9 AEA 85 PHOENIX AZ PHX ASR-9 AWP 86 PITTSBURGH PA PIT ASR-9 AEA 87 PORTLAND OR PDX ASR-9 ANM 88 PORTLAND ME CUMB ASR-9 ANE 89 PROVIDENCE (COVENTRY) RI PVD ASR-9 ANE 90 RALEIGH/DURHAM NC RDU ASR-9 ASO 91 ROANOKE VA ROA ASR-8 AEA SEG 2 92 ROCHESTER NY ROC ASR-9 AEA 93 SACRAMENTO CA MCC ASR-9 AWP 94 SAINT LOUIS-2 MO STL2 ASR-9 ACE 95 SALT LAKE CITY UT SLC ASR-9 ANM 96 SAN ANTONIO TX SAT ASR-9 ASW 97 SAN DIEGO/MIRAMAR CA NKX ASR-9 AWP 98 SANTA BARBARA CA SBA ASR-8 AWP SEG 1 99 SARASOTA FL SRQ ASR-9 ASO 100 SCOTT AFB IL BLV ASR-9 AGL 101 SEATTLE WA SEAB ASR-9 ANM 102 SHREVEPORT (BOSSIER CITY) LA BAD ASR-9 ASW 103 SPOKANE WA GEG ASR-9 ANM 104 STEWART NY SWF ASR-9 AEA 105 SYRACUSE NY SYR ASR-9 AEA 106 TALLAHASSEE FL TLH ASR-8 ASO SEG 2 107 TAMPA FL TPA ASR-9 ASO 108 TUCSON AZ TUS ASR-9 AWP 109 TULSA OK TUL ASR-9 ASW 110 WASHINGTON DULLES VA IAD ASR-9 AEA 111 WASHINGTON REAGAN NATIONAL (DC) VA DCA ASR-9 AEA 112 WHITE PLAINS NY HPN ASR-9 AEA 113 WICHITA KS ICT ASR-9 ACE 114 WILMINGTON NC ILM ASR-8 ASO SEG 2 115 WINDSOR LOCKS CT BDL ASR-9 ANE SEGMENT 1 SITES NOT PROVIDING TIS SERVICE 1 BANGOR ME COMMISSIONED ASR-11 (11/1/2004) 2 SPRINGFIELD MO COMMISSIONED ASR-11 (4/13/2005) 3 MACON GA MODE-S LEAPFROGGED TO FAY (6/15/2003) 4 MIDLAND TX NOT PRESENTLY OPERATING IN MODE-S 115 TOTAL OPERATIONAL MODE-S FACILITIES PROVIDING TIS SERVICE AS OF 1/20/2006 8 SEGMENT 1 REMAINING 10 SEGMENT 2 97 FACILITIES PROVIDING TIS SERVICE AFTER COMPLETION OF SEGMENTS 1 & 2 ________________________________________________________________________________
Date: Jan 28, 2006
Thanks Skippy, An interesting article for all to read! I actually made the comment somewhat "tongue-in-cheek" . . . I have a 1940 Piper J4-A that I have to hand prop . . . if I get hurt . . . who do I sue . . . how long is long enough . . . there are financial and personal risks when you mess with airplanes . . . It does seem to me the we pay a lot for FAA Certification for less benefit than the cost . . . but there are few guarantees that cover you after you get down the road a ways! I'm lucky . . . my ECi cylinders (on my RV-8) are the more recent "Titan" version and are unaffected by the AD . . . but who knows what tomorrow may bring?? Thanks again, Bob On 1/27/06, hemico wrote: > > > Here is an interesting article on Aviation Product Liability. > > http://www.avweb.com/news/avlaw/181885-1.html > > Bob C...There is a small section in the article that speaks to FAA > certification. > > Regards, > Skippy > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=3D7309#7309 > > ________________________________________________________________________________
Sensor
Date: Jan 28, 2006
I have an afp fuel pump in my 6 and think you would not even know if your sending unit was mounted in front of it. You cant really get your foot in there anyway. Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ----- Original Message ----- From: "Gerry Filby" <gerf(at)gerf.com> Sent: Wednesday, January 18, 2006 3:22 PM Subject: RV-List: Advanced Flight Systems AF2500 Engine Monitor - Fuel Flow Sensor > > > I just got my fuel flow sensor for my AF2500 Engine Monitor and > I'm wondering on the best place/way to mount it. > > (The sensor is an Electronics International Inc (Bend, Orgeon) > Model FT-60.) > > I'm building a 9 (same fuse more-or-less as the 7). I'm > putting in an IO-320 from Aerosport. Plans have you run the > fuel feed line from the AFP high pressure pump below the tank > selector valve to the firewall between the center floor > stiffeners. > > There's not a whole lot of room in there and the latest style > sensor is rectangular block of red anodized aluminum measuring > some 1.25 x 1.25 x 2". I believe the preferred method is to > mount it with the wires exiting the top - which means the > mounting bolts would be vertical. > > Anyone out there have experience with this sensor ? Did you > locate it in the cabin floor tunnel forward of the pump ? Did > you bolt it to the floor, or glue it ? > > __g__ > > ========================================================= > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > ________________________________________________________________________________
Subject: Re: mogas
Date: Jan 28, 2006
I have not been able to find Mo-gas on trips, I just settle for 100LL Lean her out and try to burn off the lead before you park it, Charlie Heathco ________________________________________________________________________________
Subject: Service variations - Intercom
Date: Jan 28, 2006
Over the period of nearly two years I have generally been very impressed with the high level of service from Vans and other American suppliers. Best of all was Hooker, who when told that I was in a rush to get my RV8 flying for its test programme, initially quoted me 10 days to make my harness selection. However, they pulled out all the stops and made and despatched my choice of harnesses so that they arrived here in England just three days after the order was placed. Absolutely fantastic. At the other end of the scale, Aircraft Spruce. I recently ordered a new Sigtronics 200S intercom and face plate from ACS and asked for special delivery. I was told that the goods would be despatched by the end of the week in question. A week after that I was concerned that the intercom had been mislaid in transit so I rang to get a tracking number. After five international calls and several emails I was told that the goods would take up to another few weeks as Spruce would have to place a minimum order of 3,000 dollars with Sigtronics. They didn't have the courtesy to let me know the situation and left me completely in the lurch - the worst service in the last two years of building my RV. I don't think that I can place the order directly with Sigtronics - so I am at a loss as I urgently need a suitable 2 place intercom with a face plate that will fit a 21/4" hole in my existing panel - any suggestions please ? Thanks, Nic ________________________________________________________________________________
Date: Jan 28, 2006
Subject: Re: mogas
> I have not been able to find Mo-gas on trips, I just settle for 100LL > Lean her out and try to burn off the lead before you park it, Charlie > Heathco If you normally run mogas but you have to run 100LL when mogas is not available, you could put a little "lead scavenger" in with the 100LL. Here's a good one: http://www.aircraftspruce.com/catalog/appages/Decalin.php -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Subject: Re: Service variations - Intercom
Date: Jan 28, 2006
Nic Check out Chief Aircraft and the P S Enigineering PMA4000. I've always had good service from Chief here in the US http://www.chiefaircraft.com/ Mauri RV-8 fuse ---- Original Message ----- From: "Nic" <Nic(at)skyhi.flyer.co.uk> Sent: Saturday, January 28, 2006 10:43 AM Subject: RV-List: Service variations - Intercom > > Over the period of nearly two years I have generally been very impressed > with the high level of service from Vans and other American suppliers. > > Best of all was Hooker, who when told that I was in a rush to get my RV8 > flying for its test programme, initially quoted me 10 days to make my > harness selection. However, they pulled out all the stops and made and > despatched my choice of harnesses so that they arrived here in England > just > three days after the order was placed. Absolutely fantastic. > > At the other end of the scale, Aircraft Spruce. > > I recently ordered a new Sigtronics 200S intercom and face plate from ACS > and asked for special delivery. I was told that the goods would be > despatched by the end of the week in question. A week after that I was > concerned that the intercom had been mislaid in transit so I rang to get a > tracking number. After five international calls and several emails I was > told that the goods would take up to another few weeks as Spruce would > have > to place a minimum order of 3,000 dollars with Sigtronics. They didn't > have > the courtesy to let me know the situation and left me completely in the > lurch - the worst service in the last two years of building my RV. > > I don't think that I can place the order directly with Sigtronics - so I > am > at a loss as I urgently need a suitable 2 place intercom with a face plate > that will fit a 21/4" hole in my existing panel - any suggestions please ? > > Thanks, Nic > > > -- > > ________________________________________________________________________________
Date: Jan 28, 2006
Nic wrote: >At the other end of the scale, Aircraft Spruce. > >I recently ordered a new Sigtronics 200S intercom and face plate from ACS >and asked for special delivery. I was told that the goods would be >despatched by the end of the week in question. A week after that I was >concerned that the intercom had been mislaid in transit so I rang to get a >tracking number. After five international calls and several emails I was >told that the goods would take up to another few weeks as Spruce would have >to place a minimum order of 3,000 dollars with Sigtronics. They didn't have >the courtesy to let me know the situation and left me completely in the >lurch - the worst service in the last two years of building my RV. > >I don't think that I can place the order directly with Sigtronics - so I am >at a loss as I urgently need a suitable 2 place intercom with a face plate >that will fit a 21/4" hole in my existing panel - any suggestions please ? > >Thanks, Nic > > > Typical service from ACS "IMO" in my dealings with them. do not archve ________________________________________________________________________________
Date: Jan 28, 2006
Cc: Nic Nic, Check out Flightcom's 403d unit. Both of these units are stereo intercoms. See http://www.flightcom.net/pdf/English/prodsheet_403d%20Stereo%20Panel%20Mount.pdf http://www.flightcom.net/intercoms/403d-intercom.php or the less expensive 403 http://www.flightcom.net/intercoms/403-intercom.php http://www.flightcom.net/pdf/English/prodsheet_403%20Panel%20Mount.pdf There are many excellent vendors for these units here in the States. Two good ones on the East Coast I've had good luck with are: http://www.gulf-coast-avionics.com/detail.asp?id=4540 http://www.tropicaero.com/intercoms.asp Both the above vendors stock a complete line of both Sigtronics and Flightcom. Both stand behind their products. When I purchased my 403d, I got a great deal from http://www.affordablepanels.com/ Good luck Charlie Kuss ---- Nic wrote: > > Over the period of nearly two years I have generally been very impressed > with the high level of service from Vans and other American suppliers. > > Best of all was Hooker, who when told that I was in a rush to get my RV8 > flying for its test programme, initially quoted me 10 days to make my > harness selection. However, they pulled out all the stops and made and > despatched my choice of harnesses so that they arrived here in England just > three days after the order was placed. Absolutely fantastic. > > At the other end of the scale, Aircraft Spruce. > > I recently ordered a new Sigtronics 200S intercom and face plate from ACS > and asked for special delivery. I was told that the goods would be > despatched by the end of the week in question. A week after that I was > concerned that the intercom had been mislaid in transit so I rang to get a > tracking number. After five international calls and several emails I was > told that the goods would take up to another few weeks as Spruce would have > to place a minimum order of 3,000 dollars with Sigtronics. They didn't have > the courtesy to let me know the situation and left me completely in the > lurch - the worst service in the last two years of building my RV. > > I don't think that I can place the order directly with Sigtronics - so I am > at a loss as I urgently need a suitable 2 place intercom with a face plate > that will fit a 21/4" hole in my existing panel - any suggestions please ? > > Thanks, Nic > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 28, 2006
Subject: Drilled the wrong hole in my hs help
Somehow when I read "Drill all rib attach holes to #30" I drilled the holes on top of the flange of HS-702 (that connect HS-708) too. My skin (HS-601PP) is drilled to #40. The plan says use a "AN26AD3-4 to HS-601PP to HS-702 to HS708" This can't be right! Any suggestions on how I can fix this dilemma? Thanks in advance. David Karlsberg ________________________________________________________________________________
Subject: Re: Drilled the wrong hole in my hs help
Date: Jan 28, 2006
If I under stand your problem correctly, you can use "oops" rivets (AD4 size shank and AD3 size head). Lots of sources, including Avery and I think Van's has them in the catalog now. -- Harry Crosby RV-6 N16CX, 170 hours -------------- Original message ---------------------- From: David Karlsberg <claypride(at)hotmail.com> > > Somehow when I read "Drill all rib attach holes to #30" I drilled the holes > on top of the flange of HS-702 (that connect HS-708) too. My skin > (HS-601PP) is drilled to #40. The plan says use a "AN26AD3-4 to HS-601PP to > HS-702 to HS708" This can't be right! Any suggestions on how I can fix > this dilemma? > > Thanks in advance. > > > David Karlsberg > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 28, 2006
> Typical service from ACS "IMO" in my dealings with them. > Lest you forget, ACS monitors this list for folks who talk down ACS. I've gotten notes from Mr. Jim, himself, trying to win my business back. They don't want this kind of negative advertising; but, they don't seem to change enough to prevent it. I quit buying from ACS, some time ago, because of the poor service. Being the biggest does not mean the bestest. Now, I use Wicks for most of my hardware and other suppliers for other things. Amazingly, I've not found anything I need that I can't find somewhere else. Well, I do like their catalog. Jim Sears in KY do not archve ________________________________________________________________________________
Date: Jan 28, 2006
----- Original Message ----- From: David Karlsberg Sent: Saturday, January 28, 2006 1:14 PM Subject: RV-List: Drilled the wrong hole in my hs help I'm not familiar with these exact parts, but assuming it's just a flange, and edge distances are okay, they make the "cheater" rivets which fit in the #30 hole but have the smaller head size of the AN26AD3 rivets. You can buy a small kit, that contains various cheater rivet sizes. There is a structural limitation to these rivets due to the smaller head, so it's something to keep in mind, as I don't know how many holes you need to fix. Somehow when I read "Drill all rib attach holes to #30" I drilled the holes on top of the flange of HS-702 (that connect HS-708) too. My skin (HS-601PP) is drilled to #40. The plan says use a "AN26AD3-4 to HS-601PP to HS-702 to HS708" This can't be right! Any suggestions on how I can fix this dilemma? ________________________________________________________________________________
Date: Jan 28, 2006
Subject: [ Michael Kosta ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Michael Kosta Lists: RV-List,RV4-List,RV8-List Subject: RV-4 panel and radio console http://www.matronics.com/photoshare/mikel@dimensional.com.01.28.2006/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Cc: "RV-list"
Subject: helmet issues
Date: Jan 28, 2006
Someone else asked about scratching the canopy: . . . If visor is down in front of you, then a piece of soft leather or similar on top of helmet protects canopy. . . . If visor is up, then it will contact canopy - so, one might want to put a bit (1 foot square or diameter) of "cling plastic" on canopy above where your head will be. Lots of folks already have sun barriers above them, which would protect the plexi. Brian, my helmet simply has a snap on each side for attaching the elastic strap on the visor. I can unsnap the clear and snap on the colored visor when needed. I use the clear most of the time, for bird protection, with sunglasses underneath when needed, so don't really need the tinted visor. In combat in 1967 up "north" in Package 6, one day I told myself the visor was bulletproof - I no longer suffered anxiety rolling in on a heavily defended tgt. Prior to that I worried a bit about a 37 or 57mm in the face. Piece of cake after I put on my bullet proof visor. Now the biggest threat is buzzards, snow geese, and other large "mm" birds. Visor is real protection in event of a birdstrike, not just make believe. I just had 3M tinted window film (thin sheet of plastic) on my windows on the Gulf Coast last summer - makes the windows rather "hurricane proof". The website tells of a company putting these films on windows of a mobile home "office" at some petro-chemical plant construction site - 3 days or so later, there was a big explosion - trailer was blown over on its side but windows were intact. . . . I'm going to consider experimenting with that stuff on the front part of my RV-6 tip-up canopy for bird resistance. Hey, we are on the "Lectric list" - Sorry for being "off topic". Will Cc: the RV list. David Carter ----- Original Message ----- From: "Brian Lloyd" <brian-yak(at)lloyd.com> Sent: Saturday, January 28, 2006 12:51 PM Subject: Re: AeroElectric-List: helmet (was: Why use starter contactor (fire)) > --> AeroElectric-List message posted by: Brian Lloyd > > > Mickey Coggins wrote: >> --> AeroElectric-List message posted by: Mickey Coggins >> >> >> Brian Lloyd wrote: >>> 8. you can paint stuff on it to look really cool or really stupid >>> depending on who's looking. >> >> Now you're talkin'! :-) It sounds like you've got a nice >> helmet. Which brand/model do you use? I've seen a lot of >> nice ones on the web, but I never wanted to buy one without >> trying it on. I really can't recall any helmets on sale >> at the last few SNFs or OSH, but perhaps I overlooked them. > > I bought mine at Flight Suits, Ltd. (http://www.flightsuits.com/) They > usually have a booth at OSH. I don't know about SnF. > > I have an HGU-33 with a single visor. (I wish I had the dual visor.) > > The trick is to get Flight Suits to provide the helmet, earspeakers, and > mic wiring. Get the helmet fit-kit from Oregon Aero. Their approach to > the liner and earspeakers is quieter and more comfortable. I can wear my > helmet literally all day long and never feel uncomfortable. > > Get the super-duper noise-canceling mic from Sigtronics. > > > -- > Brian Lloyd 2243 Cattle Dr. > brian-yak at lloyd dot com Folsom, CA 95630 > +1.916.367.2131 (voice) +1.270.912.0788 (fax) ________________________________________________________________________________
Date: Jan 28, 2006
My helmet is made out of soft leather. I don't get it. Bud Silvers RV - 8 finishing -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of David Carter Sent: Saturday, January 28, 2006 3:24 PM Cc: RV-list Subject: RV-List: helmet issues Someone else asked about scratching the canopy: . . . If visor is down in front of you, then a piece of soft leather or similar on top of helmet protects canopy. . . . If visor is up, then it will contact canopy - so, one might want to put a bit (1 foot square or diameter) of "cling plastic" on canopy above where your head will be. Lots of folks already have sun barriers above them, which would protect the plexi. Brian, my helmet simply has a snap on each side for attaching the elastic strap on the visor. I can unsnap the clear and snap on the colored visor when needed. I use the clear most of the time, for bird protection, with sunglasses underneath when needed, so don't really need the tinted visor. In combat in 1967 up "north" in Package 6, one day I told myself the visor was bulletproof - I no longer suffered anxiety rolling in on a heavily defended tgt. Prior to that I worried a bit about a 37 or 57mm in the face. Piece of cake after I put on my bullet proof visor. Now the biggest threat is buzzards, snow geese, and other large "mm" birds. Visor is real protection in event of a birdstrike, not just make believe. I just had 3M tinted window film (thin sheet of plastic) on my windows on the Gulf Coast last summer - makes the windows rather "hurricane proof". The website tells of a company putting these films on windows of a mobile home "office" at some petro-chemical plant construction site - 3 days or so later, there was a big explosion - trailer was blown over on its side but windows were intact. . . . I'm going to consider experimenting with that stuff on the front part of my RV-6 tip-up canopy for bird resistance. Hey, we are on the "Lectric list" - Sorry for being "off topic". Will Cc: the RV list. David Carter ----- Original Message ----- From: "Brian Lloyd" <brian-yak(at)lloyd.com> Sent: Saturday, January 28, 2006 12:51 PM Subject: Re: AeroElectric-List: helmet (was: Why use starter contactor (fire)) > --> AeroElectric-List message posted by: Brian Lloyd > > > Mickey Coggins wrote: >> --> AeroElectric-List message posted by: Mickey Coggins >> >> >> Brian Lloyd wrote: >>> 8. you can paint stuff on it to look really cool or really stupid >>> depending on who's looking. >> >> Now you're talkin'! :-) It sounds like you've got a nice >> helmet. Which brand/model do you use? I've seen a lot of >> nice ones on the web, but I never wanted to buy one without >> trying it on. I really can't recall any helmets on sale >> at the last few SNFs or OSH, but perhaps I overlooked them. > > I bought mine at Flight Suits, Ltd. (http://www.flightsuits.com/) They > usually have a booth at OSH. I don't know about SnF. > > I have an HGU-33 with a single visor. (I wish I had the dual visor.) > > The trick is to get Flight Suits to provide the helmet, earspeakers, and > mic wiring. Get the helmet fit-kit from Oregon Aero. Their approach to > the liner and earspeakers is quieter and more comfortable. I can wear my > helmet literally all day long and never feel uncomfortable. > > Get the super-duper noise-canceling mic from Sigtronics. > > > -- > Brian Lloyd 2243 Cattle Dr. > brian-yak at lloyd dot com Folsom, CA 95630 > +1.916.367.2131 (voice) +1.270.912.0788 (fax) ________________________________________________________________________________
Date: Jan 28, 2006
David Karlsberg wrote: > >Somehow when I read "Drill all rib attach holes to #30" I drilled the holes >on top of the flange of HS-702 (that connect HS-708) too. My skin >(HS-601PP) is drilled to #40. The plan says use a "AN26AD3-4 to HS-601PP to >HS-702 to HS708" This can't be right! Any suggestions on how I can fix >this dilemma? > >Thanks in advance. > > >David Karlsberg > Aren't the HS-702 flanges dimpled? (I hate the numbers on the instructions with no name; I've got really short memory with part #'s.) Assuming adequate edge distance & dimples on everything, the simplest thing to do is drill the skin #30, dimple, & use an426ad4-4 rivets. Buck carefully on the thin skin, but it should work fine; some of the older designs use ad4's for skins. ________________________________________________________________________________
Date: Jan 28, 2006
Subject: 1st rivet's confussion
Just wanted to check, I ready to rivet the HS spar to the stiffners and brackets, do the Rivets go from foward to aft, spar to stiffner, thin to thick , shop head on the (thicker) stiffner, (aft) Thanks ________________________________________________________________________________
Date: Jan 28, 2006
Subject: Re: 1st rivet's confussion
Yuo are correct. The general rule for riveting is that the shop head goes on the thicker material, unless the plans indicate otherwise. Jeff Point RV-6 Milwaukee > > > > > > > > > ________________________________________________________________________________
Date: Jan 28, 2006
Hi Dan, Riveting the shop head on the (thicker) stiffer structure is the preferred way to go. Putting the shop head on the thicker material avoids or reduces local area distortion that might occur on the thinner material, You might occasionally find it won't work out that way due to assembly stages or access with the rivet gun or bucking bar. The forward, aft, top and bottom orientation consideration is used more in reference to nuts and bolts etc. Supposedly if the nut or lock pin, clip etc, falls away, the bolt will remain in place a while attempting to do it's job. {[;-? Are ya Havin fun yet? Jim in Kelowna - Putting the wings on the 6a ----- Original Message ----- From: "Dan" <dan(at)rdan.com> Sent: Saturday, January 28, 2006 6:29 PM Subject: RV-List: 1st rivet's confussion > > Just wanted to check, I ready to rivet the HS spar to the stiffners and > brackets, > do the Rivets go from foward to aft, spar to stiffner, thin to thick , > shop head on the (thicker) stiffner, (aft) > Thanks > > > ________________________________________________________________________________
Date: Jan 29, 2006
Yes I agree that Hooker is great. However I can see the problem ACS has, if it is not in stock then they have to order it, not good for us. On the other hand I have ordered stuff from Van's and had to wait over six months to get it (aerobatic motor mounts). Sunday night I ordered some parts from ACS and I received them Wedensday USPS. I don't know how they could get much quicker, unless I paid the overnight freight. Last order from Van's was 10 days, which is significantly faster than the 17 days when I was building. I ordered my intercom from Stark Avionics, and had him make the wiring harness for my radios. Of course custom building a wiring harness takes some time. I wired the rest of my aircraft, but I am sure glad I had the intercom harness built by someone else. Bob RV6 NightFighter At 11:43 AM 1/28/06, you wrote: > >Over the period of nearly two years I have generally been very impressed >with the high level of service from Vans and other American suppliers. > >Best of all was Hooker, who when told that I was in a rush to get my RV8 >flying for its test programme, initially quoted me 10 days to make my >harness selection. However, they pulled out all the stops and made and >despatched my choice of harnesses so that they arrived here in England just >three days after the order was placed. Absolutely fantastic. > >At the other end of the scale, Aircraft Spruce. > >I recently ordered a new Sigtronics 200S intercom and face plate from ACS >and asked for special delivery. I was told that the goods would be >despatched by the end of the week in question. A week after that I was >concerned that the intercom had been mislaid in transit so I rang to get a >tracking number. After five international calls and several emails I was >told that the goods would take up to another few weeks as Spruce would have >to place a minimum order of 3,000 dollars with Sigtronics. They didn't have >the courtesy to let me know the situation and left me completely in the >lurch - the worst service in the last two years of building my RV. > >I don't think that I can place the order directly with Sigtronics - so I am >at a loss as I urgently need a suitable 2 place intercom with a face plate >that will fit a 21/4" hole in my existing panel - any suggestions please ? > >Thanks, Nic ________________________________________________________________________________
Date: Jan 29, 2006
David, Just rivet it up with 4-4s. Work carefully and you will be fine. I have a second hand RV-7 empanage kit and the whole Vertical stab was drilled with #30. I took my time and only had to drill out a couple. MG David Karlsberg wrote: > > Somehow when I read "Drill all rib attach holes to #30" I drilled the holes > on top of the flange of HS-702 (that connect HS-708) too. My skin > (HS-601PP) is drilled to #40. The plan says use a "AN26AD3-4 to HS-601PP to > HS-702 to HS708" This can't be right! Any suggestions on how I can fix > this dilemma? > > Thanks in advance. > > > David Karlsberg ________________________________________________________________________________
Subject: SL-30 side tone problem
Date: Jan 29, 2006
Anybody have any ideas about what's going on? My avionics have worked like a charm until about two flight hours ago. The side tone on my SL-30 went from normal, to incredibly loud. It still transmits and receives well, but the side tone is so loud, it's uncomfortable. It's installed as the second Nav/Com, number one is a 300XL, it works great. Steve Struyk RV-8, N842S St. Charles, MO 18.8 Hrs (still grinnin') ________________________________________________________________________________
Date: Jan 29, 2006
A new builder myself, I have found it very useful to read through the steps several times before committing a drill to anything. Analyzing the drawings over and over as well. As a rule of thumb, skin attachments are USUALLY drilled to #40 (unless otherwise specified). If you are not 100% sure about something, re-read the step while looking closely at the plans over and over until you convince yourself that you ARE 100% sure what you are about to do is correct. If you still are not sure, ask for help BEFORE drilling. It will save you time and $ later on down the line. Dennis Roberts RV7 N35DR (reserved) Emp nearly complete / awaiting wing shipment Dennis(at)DRRV7.com http://www.DRRV7.com ________________________________________________________________________________
Date: Jan 29, 2006
On 18:55:04 2006-01-28 Jeff Point wrote: > Yuo are correct. The general rule for riveting is that the shop head > goes on the thicker material, unless the plans indicate otherwise. In this location, however, many people (myself included) opted to put the factory head on the stiffener side, since it's the side that will be visible (sort of) when the airplane is complete. The reason for putting the factory head on the thinner side is that when you form the shop head, you're more likely to stretch/deform the thinner material. In this case, it seems the thinner material doesn't stretch significantly when setting the rivet on that side. So the joint is equally strong either way. The builder's manual for my -7 says that while the norm is to put the factory head on the thinner material side, there have been no problems with putting the factory head on the thicker material side in this location. -Rob ________________________________________________________________________________
Subject: Re: RV Wiki FAQ
Date: Jan 29, 2006
There are already lots of opinions and answers for the questions you bring up in your post below. I suggest you check the archives and get the best thought of hundreds who have gone before you. If after doing that you still have questions, I am sure you will get lots of answers if any questions still remain. http://www.matronics.com/search/ Indiana Larry ----- Original Message ----- > > There are several blank articles on the RV Wiki frequently-asked-questions > page > that are crying out to have something added. If you have any knowledge or > interest in any of these areas, please feel free to start an article. > ________________________________________________________________________________
Date: Jan 29, 2006
My read is that he wants concise writeups on those subjects for all to use, not advice on random subjects for himself. The wiki will be much more useful than this list for 'how-to' questions, because a searcher won't have to wade through literally 10's of thousands of messages to find an answer. Even using the search engine on the list, you still must read through dozens or even hundreds of 'me too', 'I agree', posts written about totally different subjects but with the wrong subject line, etc to get an answer. Wiki's are great tools once they are populated with data. Go prowl around Wikipedia & pick just about any subject of interest to see how useful they can be. http://en.wikipedia.org/wiki/Main_Page For instance, here's the entry for Van's Aircraft: http://en.wikipedia.org/wiki/Van%27s_Aircraft See something that's incorrect? Register, then log in & correct it. Charlie LarryRobertHelming wrote: > >There are already lots of opinions and answers for the questions you bring >up in your post below. I suggest you check the archives and get the best >thought of hundreds who have gone before you. If after doing that you still >have questions, I am sure you will get lots of answers if any questions >still remain. http://www.matronics.com/search/ > >Indiana Larry > >----- Original Message ----- > > > > >> >>There are several blank articles on the RV Wiki frequently-asked-questions >>page >>that are crying out to have something added. If you have any knowledge or >>interest in any of these areas, please feel free to start an article. >> >> >> ________________________________________________________________________________
Date: Jan 29, 2006
Subject: Six New Email Lists / Forums At Matronics!
Dear Listers, Its my pleasure to announce the addition of six new Email List / Forums to the aviation line up at Matronics! These new lists support all the usual features you've come to know and love from the Matronics Email List including full integration with the All New Web BBS Forums Site!! The new Lists include: LycomingEngines-List Textron/Lycoming Engines RotaxEngines-List Rotax Engine for Aircraft M14PEngines-List Vendenyev M14P Radial Engine MurphyMoose-List Murphy Moose Aircraft Allegro-List Allegro 2000, a Czech-built, Rotax-powered Aircraft Falco-List Sequoia Aircraft's Falco Experimental To sign up for any or all of the new Lists, surf over to the Matronics Email List Subscription Form and follow the instructions: http://www.matronics.com/subscribe Don't forget to check out the All New Web BBS Forum now available along with all of the usual message and archive viewing tools at the Matronics Email Lists site. Surf over to the following URL for information on the BBS Forum: http://forums.matronics.com Enjoy the new Lists! Matt Dralle Matronics Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Subject: Re: SL-30 side tone problem
Date: Jan 29, 2006
Are both radios on the same freq? Sometimes this will cause all kinds of wacky results. Shemp/Jeff Dowling RV-6A, N915JD 235 hours Chicago/Louisville ----- Original Message ----- From: "Steve Struyk" <rv8striker(at)hotmail.com> Sent: Sunday, January 29, 2006 8:13 AM Subject: RV-List: SL-30 side tone problem > > Anybody have any ideas about what's going on? My avionics have worked like > a charm until about two flight hours ago. The side tone on my SL-30 went > from normal, to incredibly loud. It still transmits and receives well, but > the side tone is so loud, it's uncomfortable. It's installed as the second > Nav/Com, number one is a 300XL, it works great. > > Steve Struyk > RV-8, N842S > St. Charles, MO > 18.8 Hrs (still grinnin') > > > ________________________________________________________________________________
Date: Jan 30, 2006
Bob - I don't have an issue with items that are on backorder, I do however think that suppliers have a duty to stick to their promises. In this case ACS promised fast track delivery on the items I ordered, and only when they didn't arrive ten days later and I chased them did they finally admit that the goods would not be despatched for weeks to come. Had I known this from the outset it would have saved me numerous overseas calls and I would have ordered from an outlet that had the goods ready to ship. Many thanks for all the help to source an alternative intercom, Now I just need to know which is the best two place 2 1/4" intercom with music input that is available off the shelf at any reasonable price. Rgds, Nic > Sunday night I ordered some parts from ACS and I received them Wedensday > USPS. I don't know how they could get much quicker, unless I paid the > overnight freight. ________________________________________________________________________________
Date: Jan 30, 2006
Subject: Re: RV-List: Service variations - Intercom Hi Nic- I agree that ACS has the greatest catalog and also agree with all the negatives that have been offered up. To add one, I had occasion to require a special order part. I was unable to determine from the catalog if Spruce could help, so I called for guidance. The ACS employee on the other end assured me that they could have it special made. When the part arrived, it was the wrong thing. When I called again, the agent I got was rather short and condescending about my having ordered the wrong item. On the other hand, Wicks has sent me the wrong item twice, but they are always pleasant to deal with. Also, since I only live one state away, an order placed in the morning will generally arrive the following afternoon with their regular shipping rates. Not much to complain about there. WRT the intercom issue, I believe that PS Engineering's PMA 4000 can be had with a face plate for a std instrument hole. > >At the other end of the scale, Aircraft Spruce... ...I am >at a loss as I urgently need a suitable 2 place intercom with a face plate >that will fit a 21/4" hole in my existing panel - any suggestions please ? > >Thanks, Nic Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: Yahoo RV Lists are going bye-bye
Date: Jan 30, 2006
So long to a good friend. The Yahoo RV lists are going to be decommisioned on February 15, 2006. I have long been a member, looking forward to reading about the trials, tribulations and joys of the RV world. These messages from on high (altitude that is) brought joy and meaning to my life in a time when work was not much fun. They, and the Matronics list are the reason that I'm building my very own RV today. I find it sad that personal gain is the motive for their demise. Smitty's RV-9A http://SmittysRV.com ________________________________________________________________________________
Date: Jan 30, 2006
Nic, I would suggest that in future, when dealing with ACS, you do your ordering off of their web site. Their site will show you whether the item in question is in stock (and at which of their two warehouses) or on back order. I've also found that often the web site price is slightly lower (5%) than the listed paper catalog price. I really like using the web site to order from them. Charlie Kuss > >Bob - I don't have an issue with items that are on backorder, I do however >think that suppliers have a duty to stick to their promises. In this case >ACS promised fast track delivery on the items I ordered, and only when they >didn't arrive ten days later and I chased them did they finally admit that >the goods would not be despatched for weeks to come. > >Had I known this from the outset it would have saved me numerous overseas >calls and I would have ordered from an outlet that had the goods ready to >ship. > >Many thanks for all the help to source an alternative intercom, Now I just >need to know which is the best two place 2 1/4" intercom with music input >that is available off the shelf at any reasonable price. > >Rgds, Nic > > > Sunday night I ordered some parts from ACS and I received them Wedensday > > USPS. I don't know how they could get much quicker, unless I paid the > > overnight freight. > > ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jan 30, 2006
Why ? Bill S 7a -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Smitty Sent: Monday, January 30, 2006 6:36 AM Subject: RV-List: Yahoo RV Lists are going bye-bye So long to a good friend. The Yahoo RV lists are going to be decommisioned on February 15, 2006. I have long been a member, looking forward to reading about the trials, tribulations and joys of the RV world. These messages from on high (altitude that is) brought joy and meaning to my life in a time when work was not much fun. They, and the Matronics list are the reason that I'm building my very own RV today. I find it sad that personal gain is the motive for their demise. Smitty's RV-9A http://SmittysRV.com ________________________________________________________________________________
Subject: Re: Yahoo RV Lists are going bye-bye
Date: Jan 30, 2006
Hi Linn, I prefer the Yahoo email groups because of the fast and direct response I get to my office email box. I get to read everybodys submissions as they happen. I don't want to have to go a website to search read for submissions. The Yahoo email messages "come to you". I have learned a lot from reading submissions that sometimes don't necessarly apply to me in my current construction phase. For those of us who don't have DSL, the amount of time it takes to pull in all of advertisement images on the forum website takes forever. I have given up a long time ago trying to find anything on the forum website for this reason. I recently posted an email message to the Yahoo RV email and got over 15 responses, as compare the "1" I got from the forum website. When I post an email to the Yahoo RV email group, it goes directly to the other builders email boxes, a few minutes after it is posted. It is clear to me that I am being forced to go a forum website that is jammed full of advertisements. Smitty -------- Smittys RV-9A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=8101#8101 ________________________________________________________________________________
Date: Jan 30, 2006
I'm not talking about the Matronics email list. My concern is about the loss of the Yahoo email list and being incouraged to go the Van's Air Force Forum website. Smitty -------- Smittys RV-9A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=8116#8116 ________________________________________________________________________________
Date: Jan 30, 2006
More than a year ago when Doug Reeves threatened to shut down the Yahoo lists I initiated four RV related Yahoo lists of my own to take their place if and when he really shut down the originals. I, like many others, prefer an Email list that's moderated. The sorry thing is that the archives will die when Doug pulls the plug. A number of people found these lists on their own and subscribed but there hasn't been a lot of activity because of the small subscriber base. If you would like to move over to the new Yahoo lists, here are the Email addresses to subscribe : RV-7-subscribe(at)yahoogroups.com RV-10-subscribe(at)yahoogroups.com RV-9-subscribe(at)yahoogroups.com vans-airforce-subscribe(at)yahoogroups.com We can also create additional YAHOO groups if desired. -- Best regards, Steve Mottin Granbury, Texas mailto:rv9(at)charter.net P.S. I also subscribe to and like the Matronics lists, but sometimes their unmoderated nature can lead to some really off-topic posts. Monday, January 30, 2006, 7:55:00 AM, you wrote: s> Hi Linn, s> I prefer the Yahoo email groups because of the fast and direct response I get to my office email box. I get to read everybodys submissions as they happen. I don't want to have to go a website to s> search read for submissions. The Yahoo email messages "come to you". I have learned a lot from reading submissions that sometimes don't necessarly apply to me in my current construction phase. s> For those of us who don't have DSL, the amount of time it takes to pull in all of advertisement images on the forum website takes forever. I have given up a long time ago trying to find anything s> on the forum website for this reason. s> I recently posted an email message to the Yahoo RV email and got over 15 responses, as compare the "1" I got from the forum website. When I post an email to the Yahoo RV email group, it goes s> directly to the other builders email boxes, a few minutes after it is posted. s> It is clear to me that I am being forced to go a forum website that is jammed full of advertisements. s> Smitty s> -------- s> Smittys RV-9A ________________________________________________________________________________
Date: Jan 30, 2006
One thing to keep in mind is that if you ever needed to drill out and replace a rivet, it is way easier and more accurate (less likely to enlarge or mess up a hole) if you have access to the manufactured head. John D'Onofrio RV8 ________________________________________________________________________________
Subject: Engine problems
Date: Jan 30, 2006
Many thanks to all who provided feedback in helping me identify my engine problem. I finally had time of the past weekend to try some of the many suggestions. And as most of you who responded guessed, it was an induction leak. I connected the discharge side of a shop vac to the bottom of the carb intake, duct taped it up the best I could and turn the vac on. Then began spraying soapy water around the induction components. I immediately began to see bubbles forming at the right rear induction tube near the engine. Turns out that the steel tube that inserts into the aluminum cast oil pan was loose and leaking. Again, many thanks to everyone who helped point me to the problem. Jimmy Ayres RV6A - flying RV7A - building ________________________________________________________________________________
Date: Jan 30, 2006
Clearly the loss of the Yahoo RV Email Groups will be a great shot in the arm for the Matronics Email List. I can see that Matronics system will become (if not already) the number one source of immediate info for RV builders. The Vans Air Force website is still a great place to go for the latest stories and pictures, but their forum will never surpass Matronics. -------- Smittys RV-9A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=8133#8133 ________________________________________________________________________________
Date: Jan 30, 2006
Good point Michael! I hadn't thought of that. The loss of the Yahoo RV email archives will indeed be bad. I gone there many times when in dire need of information about certain building processes. Putting builders in a bind, in the name of advertising revenues. -------- Smittys RV-9A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=8142#8142 ________________________________________________________________________________
Subject: Glass as it comes or all at once at the end?
Date: Jan 30, 2006
From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
I am close to finishing up my HS and will be doing so this week. I have got to wondering about whether I should do the tips when it's done or just wait and do all of them at the end. I lean towards the latter because I'm afraid of fiberglass, and, seriously, it seems to make more sense to do it all at once (though I guess that is going to mean several weeks of hell all at once). Are there any good reasons I should do the tail tips earlier? Paul 9A QB #1176 ________________________________________________________________________________
Date: Jan 30, 2006
Subject: Re: Glass as it comes or all at once at the end?
In a message dated 1/30/06 9:29:35 AM Central Standard Time, PFolbrecht(at)starkinvestments.com writes: > Are there any good reasons I should do the tail tips earlier? >>> Hi Paul- I waited til the end and glad I did. It gave me a lot more time to look at other planes and decide how I wanted to attach them- actually changed my mind a couple of times before committing to final arrangement. Doing all at same time probably will save some time, and your materials/skills will be fresher. You WILL have to deal with that cowling & the gear legs eventually! Mark Phillips ________________________________________________________________________________
Date: Jan 30, 2006
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
It's really personal choice. No technical or building issues either way. I got my tail F/G started while waiting for my wings to arrive. Did the same with the wing tips, waiting for the fuselage. None of it is done because the new stuff arrived, but at least some of the work is done. Dennis Glaeser 7A Fuselage Subject: Low Time IO-360 A1A
Date: Jan 30, 2006
One of our customers is replacing his low-time (300 hours since new) IO-360-A1A with one of our IO-390s and asked me to send a message to let the list know that his engine is for sale. I don't know any other details about the engine He is located in France. His name is Christophe Jacquard with Corsair Warbird, Ltd.. He can be reached by fax at +33 03 80 35 69 19 for additional information if you are interested. Rhonda Barrett-Bewley Barrett Precision Engines, Inc. 2870-B N. Sheridan Rd. Tulsa, OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com ________________________________________________________________________________
Date: Jan 30, 2006
I think you missed the point Larry. He is asking for people to make contributions to the Wiki pages. I have used them, made contributions, and find them very helpful. Go to the site and see what is being developed there. When many people have contributed and this site is a wealth of information the archives on Matronics sites will have cobwebs from lack of use. As far as I am concerned the Wiki pages are the new wave of fingertip info. I avoid the list archives like the plague because it takes forever to browse your way through a hundred hits to find the right info. That is why there are so many redundant questions on the list. Don't misunderstand me - the list is a great place (it would be better without the usenet mentality I see here a lot) and I have been lurking here since it first started and it has helped me a lot. I just think the Wiki will be a good source of information without the encumbrances of email articles that a person has no interest in. Jim ________________________________________________________________________________
Subject: Gaps in HS rib-to-front-spar joint
Date: Jan 30, 2006
I hate to have to post this. As the title says, I have a slight gap in two ribs - one on each side. It is at least wide enough to get a piece of paper under. I have not yet installed the rear spar so I could drill these out and re-rivet. Something tells me that I really ought to. Is it something I would need to worry about? Is it a strength issue? Paul ________________________________________________________________________________
Date: Jan 30, 2006
On Mon Jan 30 13:18:56 2006, Mickey Coggins wrote : >One question - who "owns" the site, the contributions, >and what are the long term plans for it? You're not >going to trick us all into fleshing out the site, and >then you get to make millions on google ads? :-) This is an excellent question, and as one of the "owners" I'll jump in and give my answer. At the moment I, technically, "own" the RV Wiki in as much as I pay for the hosting, have registered the domain name, and try and keep the technical end of things working. Tedd is, in my opinion, the other "owner" as he has taken on the awesome task of being RV-Wiki content shepherd and prime evangelist. Long term plans (and it is my belief that Tedd and I are completely in sync on this) are to simply grow it as best we can. No Google ads. No "premium access" games where you pay a fee for the "good stuff". No tricks. The intent is to strive to create a value repository of information ... one complimentary to all the existing forums and mailing lists. It is *different*, and as such does not replace any of them, but simply adds new value to the options builders have for getting needed/useful information. Because of this we actually have some concern about our ability to support the site ... and may, eventually, have to solicit for some donations. We aren't there yet, and hope to not be for some time to come. Until there is enough value to make it *worth* people donating then it really isn't an issue. :) Don't get me wrong, there is some good stuff there already. I'm, personally, very impressed. But it is clearly in the early stages and has a long way to go. So you may well see a PayPal link show up on the RV Wiki one day, but it will be an optional and voluntary donation link, not a sign-up-to-access sort of link. Finally, I believe that the REAL answer to your question is that *every* *single* *contributor* "owns" the RV-Wiki. Yes this is a very idealistic viewpoint. Yes, it asks that you trust to our good intentions. I ask that you give us the benefit of the doubt, contribute, and give us the opportunity to show that your trust is well placed. -- Dwight PS: I think I will let this one be archived, as I think the question is very valid, and the answer important. I could be wrong, of course. :) ________________________________________________________________________________
Date: Jan 30, 2006
Hee hee, one of the assumptions of a "Wiki" is that you can reach a general consensus on a topic, that might prove difficult :D Its an admirable effort though - I had a conversation with another builder on just this topic - sometimes its really hard to search for answers to your question - what keywords would I use. I for one will make an effort to contribute - when I have time off from my build :) g > > > My read is that he wants concise writeups on those subjects for all to > use, not advice on random subjects for himself. The wiki will be much > more useful than this list for 'how-to' questions, because a searcher > won't have to wade through literally 10's of thousands of messages to > find an answer. Even using the search engine on the list, you > still must > read through dozens or even hundreds of 'me too', 'I agree', posts > written about totally different subjects but with the wrong subject > line, etc to get an answer. > > Wiki's are great tools once they are populated with data. Go prowl > around Wikipedia & pick just about any subject of interest to see how > useful they can be. > > http://en.wikipedia.org/wiki/Main_Page > > For instance, here's the entry for Van's Aircraft: > > http://en.wikipedia.org/wiki/Van%27s_Aircraft > > See something that's incorrect? Register, then log in & correct it. > > Charlie > > LarryRobertHelming wrote: > > > > >There are already lots of opinions and answers for the questions you bring > >up in your post below. I suggest you check the archives and get the best > >thought of hundreds who have gone before you. If after doing that you still > >have questions, I am sure you will get lots of answers if any questions > >still remain. http://www.matronics.com/search/ > > > >Indiana Larry > > > >----- Original Message ----- > > > > > > > > > >> > >>There are several blank articles on the RV Wiki frequently-asked-questions > >>page > >>that are crying out to have something added. If you have any knowledge or > >>interest in any of these areas, please feel free to start an article. > >> > >> > >> > > > > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Subject: O320 to O360 conversion
Date: Jan 30, 2006
I have an RV6A with on O320 which I am currently flying. I am rebuilding an O360 which I plan to use in an RV7A that I am building. I have heard that the break-in for a rebuilt engine is to run it full throttle for several hours initially. Unfortunately, that is not the way I want to break in my newly built RV7A on the first few flights. A friend suggested putting the O360 on my currently flying RV6A to break it in since it is already flying and I am familiar with it. Seems like a good idea to me. My question is: Can this be done without modifying my existing cowl on the RV6A? Does anyone out have any experience with changing over from an O320 to and O360? Jimmy Ayres RV6A - flying RV7A - building ________________________________________________________________________________
Subject: Re: O320 to O360 conversion
Date: Jan 30, 2006
Sounds like almost as much hassle as finding a test stand and breaking it in on the ground. Ever consider this option? Bryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=8234#8234 ________________________________________________________________________________
Date: Jan 30, 2006
To clarify, this is the front-flange of the main rib to front-spar joint on a 9A HS. ________________________________ From: Folbrecht, Paul Sent: Monday, January 30, 2006 1:06 PM Subject: Gaps in HS rib-to-front-spar joint I hate to have to post this. As the title says, I have a slight gap in two ribs - one on each side. It is at least wide enough to get a piece of paper under. I have not yet installed the rear spar so I could drill these out and re-rivet. Something tells me that I really ought to. Is it something I would need to worry about? Is it a strength issue? Paul ________________________________________________________________________________
Date: Jan 30, 2006
Jimmy, The cowling I wouldn't think would need modification, but the engine baffling would as the 0-360 is wider than the 0-320. Engine break-in does not have to be done at full throttle, but rather at high MP settings. 25-26 square is ideal as long as temps and pressures are normal. It does require a (few hours) but not several hours at a time. (unless your lucky) Hope this helps, Allen Barrett Barrett Precision Engines, Inc www.barrettprecisionengines.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of AYRES, JIMMY L Sent: Monday, January 30, 2006 1:59 PM Subject: RV-List: O320 to O360 conversion I have an RV6A with on O320 which I am currently flying. I am rebuilding an O360 which I plan to use in an RV7A that I am building. I have heard that the break-in for a rebuilt engine is to run it full throttle for several hours initially. Unfortunately, that is not the way I want to break in my newly built RV7A on the first few flights. A friend suggested putting the O360 on my currently flying RV6A to break it in since it is already flying and I am familiar with it. Seems like a good idea to me. My question is: Can this be done without modifying my existing cowl on the RV6A? Does anyone out have any experience with changing over from an O320 to and O360? Jimmy Ayres RV6A - flying RV7A - building ________________________________________________________________________________
Date: Jan 30, 2006
I have never read that the eng should be run wide open to break in. However they do want you to run at high power settings for the first few hours. Ollie ----- Original Message ----- From: "bdjones1965" <rv_8pilot(at)hotmail.com> Sent: Monday, January 30, 2006 3:14 PM Subject: RV-List: Re: O320 to O360 conversion > > Sounds like almost as much hassle as finding a test stand and breaking it > in on the ground. Ever consider this option? > > Bryan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=8234#8234 > > > ________________________________________________________________________________
Date: Jan 30, 2006
Subject: Re: Gaps in HS rib-to-front-spar joint
Paul, Only a sheet of paper? On my 8a HS and VS, the rib lengths were off so badly, that I couldn't maintain edge distance on the front spar flanges. (My kit was not matched hole remember) I had to cut the front flanges off the affected ribs and make "scab" flanges to get everything to line up correctly. It wasn't the only place this was necessary on my kit. It sounds like your mis-alignment is slight however. If interested, I can email you photos of how to modify a rib using the scab flange method. Charlie Kuss > > >I hate to have to post this. > > >As the title says, I have a slight gap in two ribs - one on each side. >It is at least wide enough to get a piece of paper under. I have not >yet installed the rear spar so I could drill these out and re-rivet. >Something tells me that I really ought to. Is it something I would need >to worry about? Is it a strength issue? > > >Paul > > ________________________________________________________________________________
Date: Jan 30, 2006
Jim, I agree and I couldn't have said it better. Flying an RV-6A in Kentucky Charlie Ennis ________________________________________________________________________________
Subject: Fiberglass canopy skirt from scratch
Date: Jan 30, 2006
Fiberglass gurus, After trying to get the metal skirt to fit on my RV-3 I'm giving up -- I'm convinced God just didn't intend aluminum to be used for compound curves, fiberglass on the other hand is perfectly suited for that. No worries with laying it up and such (West Systems and 9 oz crowfoot e-glass), but what I'd appreciate some ideas on are how to craft a molding surface. I will pop rivet my tipover plexi bubble to the frame in every other hole, which I will later drill out, so there won't need to be an clecos and thus I can layup onto the plexi. But what do I use to create a form from the plexi down to the fuselage, or to bridge the gap along the sides? This is way too much area for the traditional modeling clay we use for intersection fairings. If I use any sort of tape it will create an uneven layup and require lots of sanding and filling, something I'd rather avoid. I was thinking of using expandable foam around the front and rear sections (won't work on the sides) and then sculpting it. Seems like I heard that the cans of foam you can buy at Home Depot aren't good because they contain formaldehyde, not sure why that's bad though. Spruce has Poly-Cell 100 Polyurethane Foam http://www.aircraftspruce.com/catalog/cmpages/polycel.php and Liquid "X30" Foam http://www.aircraftspruce.com/catalog/cmpages/x30foam.php Anyone had an experience with either of these? When using foam, do you lay up directly on it, or coat it with something first? And lastly, what would be a good way to create a surface on the sides? Here's a pic of what I'm dealing with... http://www.romeolima.com/RV3works/Gallery/DSC_0899.jpg Thanks! Randy Lervold www.rv-3.com www.rv-8.com ________________________________________________________________________________
Subject: Re: PC Simulators
Date: Jan 30, 2006
I'm looking to purchase a flight simulator program for my PC to refresh my skills before spending big bucks on actual training. I have seen some information on MSFS 2004, Flight Factory RV-7/7A, X-Plane, & Elite. Any feedback on software and the best stick, throttle/prop/mixture, rudder controls would be appreciated. Scott Diffenbaugh diff(at)foothill.net RV-7A about ready to fly ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: Fiberglass canopy skirt from scratch
Date: Jan 30, 2006
You could try tapeing thin cardboard between the canopy and fuselage. My cardboard of preference (from making the empennage fairing years ago) comes from Diet Coke 12-pack cartons... Several pieces of cardboard, a little packing tape, and volia, female mold... Alternately, you could get yourself some Monokote or similar shrink film, cut it to rough shape, tape the ends to the plexi and fuselage, and shrink the stuff into the shape you want. Might even work. (Note- put a layer of packing tape between the monokote and your canopy, or risk color transfer)... KB ----- Original Message ----- From: "Randy Lervold" <randy(at)romeolima.com> Sent: Monday, January 30, 2006 6:21 PM Subject: RV-List: Fiberglass canopy skirt from scratch > > Fiberglass gurus, > > After trying to get the metal skirt to fit on my RV-3 I'm giving up -- I'm > convinced God just didn't intend aluminum to be used for compound curves, > fiberglass on the other hand is perfectly suited for that. No worries with > laying it up and such (West Systems and 9 oz crowfoot e-glass), but what > I'd > appreciate some ideas on are how to craft a molding surface. I will pop > rivet my tipover plexi bubble to the frame in every other hole, which I > will > later drill out, so there won't need to be an clecos and thus I can layup > onto the plexi. But what do I use to create a form from the plexi down to > the fuselage, or to bridge the gap along the sides? This is way too much > area for the traditional modeling clay we use for intersection fairings. > > If I use any sort of tape it will create an uneven layup and require lots > of > sanding and filling, something I'd rather avoid. I was thinking of using > expandable foam around the front and rear sections (won't work on the > sides) > and then sculpting it. Seems like I heard that the cans of foam you can > buy > at Home Depot aren't good because they contain formaldehyde, not sure why > that's bad though. > Spruce has Poly-Cell 100 Polyurethane Foam > http://www.aircraftspruce.com/catalog/cmpages/polycel.php > and Liquid "X30" Foam > http://www.aircraftspruce.com/catalog/cmpages/x30foam.php > > Anyone had an experience with either of these? When using foam, do you lay > up directly on it, or coat it with something first? > > And lastly, what would be a good way to create a surface on the sides? > Here's a pic of what I'm dealing with... > http://www.romeolima.com/RV3works/Gallery/DSC_0899.jpg > > Thanks! > Randy Lervold > www.rv-3.com > www.rv-8.com > > > ________________________________________________________________________________
Date: Jan 30, 2006
Paul, I did my "tail tips" while I was waiting on the wing kit. I'm glad I did. It's a bunch of work already done. The "doing it all at once" idea sounds logical but I don't think it has any real merit. It doesn't really take that long to get set up, and I didn't think it was all that messy either. Jump in! If you have more of the kit there to work on it really won't make any difference. It's all got to get done. Mark -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Folbrecht, Paul Sent: Monday, January 30, 2006 9:26 AM Subject: RV-List: Glass as it comes or all at once at the end? I am close to finishing up my HS and will be doing so this week. I have got to wondering about whether I should do the tips when it's done or just wait and do all of them at the end. I lean towards the latter because I'm afraid of fiberglass, and, seriously, it seems to make more sense to do it all at once (though I guess that is going to mean several weeks of hell all at once). Are there any good reasons I should do the tail tips earlier? Paul 9A QB #1176 ________________________________________________________________________________
Date: Jan 30, 2006
On Jan 30, 2006, at 5:21 PM, Randy Lervold wrote: > > Fiberglass gurus, > > (snip) Umm not really a fiberglass guru, but I think I can help here. > Spruce has Poly-Cell 100 Polyurethane Foam > http://www.aircraftspruce.com/catalog/cmpages/polycel.php > and Liquid "X30" Foam > http://www.aircraftspruce.com/catalog/cmpages/x30foam.php > > Anyone had an experience with either of these? When using foam, do > you lay > up directly on it, or coat it with something first? I recently helped someone do a _lot_ of fiberglass work on an RV-8, and the X30 foam completely rocks. We mixed it in small cups ( like you would have next to a drinking fountain) by filling each cup about 40%, and pouring back and forth until the foam started to kick off, then pouring it onto the work surface. In 10 minutes it's ready to file or sand, or even add more foam. It's not possible to make a mistake you can't fix in 15 minutes. The foam is kind of porous, so we covered it with strips of carefully laid duct tape as a release after getting the surface we wanted. This is the method I'm planning to use to redo my tail fairing, which has "bumps" between the fasteners. The local EZ guys seemed to approve of our method, although they did seem somewhat amused by our slow pace... James Freeman > > And lastly, what would be a good way to create a surface on the sides? > Here's a pic of what I'm dealing with... > http://www.romeolima.com/RV3works/Gallery/DSC_0899.jpg > > Thanks! > Randy Lervold > www.rv-3.com > www.rv-8.com > > ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Jan 30, 2006
> > Fiberglass gurus, Well, that I'm not. Is it possible to simply drape a single, lightweight strip across the gap? Let it cure and then build on that? One might have to go along every so often and give it a nip or tuck as it cures, but it might work. Pay attention to the bias of the weave, I'm not sure what would be best in this case. Alex Peterson RV6-A N66AP 712 hours Maple Grove, MN ________________________________________________________________________________
Date: Jan 30, 2006
If memory serves me the 2 inboard ribs are canted to the outside and require the fabrication of .040 shims (HS-909) to fill the gap Bob Perkinson Hendersonville, TN. RV9 N658RP Reserved If nothing changes Nothing changes -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Folbrecht, Paul Sent: Monday, January 30, 2006 2:16 PM Subject: RV-List: Gaps in HS rib-to-front-spar joint To clarify, this is the front-flange of the main rib to front-spar joint on a 9A HS. ________________________________ From: Folbrecht, Paul Sent: Monday, January 30, 2006 1:06 PM Subject: Gaps in HS rib-to-front-spar joint I hate to have to post this. As the title says, I have a slight gap in two ribs - one on each side. It is at least wide enough to get a piece of paper under. I have not yet installed the rear spar so I could drill these out and re-rivet. Something tells me that I really ought to. Is it something I would need to worry about? Is it a strength issue? Paul ________________________________________________________________________________
Date: Jan 30, 2006
Some builder made a form out of his wife's panty hose and stretched the material over the gear leg to create fairings. A release agent would have to be used where you don't want the stuff to grab. My 1 cent worth ... Jerry Grimmonpre' Is it possible to simply drape a single, lightweight > strip across the gap? Let it cure and then build on that? One might have > to go along every so often and give it a nip or tuck as it cures, but it > might work. Pay attention to the bias of the weave, I'm not sure what > would > be best in this case. ________________________________________________________________________________
Date: Jan 30, 2006
Usually a prolonged full power run is the last gasp before pulling the jugs on an engine that consumes to much oil after overhaul. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Oliver Washburn Sent: Monday, January 30, 2006 4:27 PM Subject: Re: RV-List: Re: O320 to O360 conversion I have never read that the eng should be run wide open to break in. However they do want you to run at high power settings for the first few hours. Ollie ----- Original Message ----- From: "bdjones1965" <rv_8pilot(at)hotmail.com> Sent: Monday, January 30, 2006 3:14 PM Subject: RV-List: Re: O320 to O360 conversion > > Sounds like almost as much hassle as finding a test stand and breaking it > in on the ground. Ever consider this option? > > Bryan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=8234#8234 > > > ________________________________________________________________________________
Date: Jan 30, 2006
Subject: Rudder questions
1. I saw a very well done RV 7 this weekend with a trim wedge mounted on the side of the rudder. Has anyone used an adjustable trim tab? It would be easy to slip in while building the rudder. 2. Has anyone had experience with 3M polyurethane adhesive? I am thinking about using it on the trailing edged assembly. Sherman Butler RV 7a Empennage Sherman Butler RV-7a Empennage --------------------------------- ________________________________________________________________________________
Date: Jan 30, 2006
Subject: nut plate revets
Is mounting nut plates with NAS-1097 rivets (oops) and acceptable practice? It seems as if it would be easier in some locations, such as the trim plate. Sherman Butler RV 7a Empennage Sherman Butler RV-7a Empennage --------------------------------- ________________________________________________________________________________
Date: Jan 30, 2006
Some of the other replies reference a fit problem but I read it that the parts fit and that you had a small gap after riveting. If that's the case, yes, you should drill them out and rivet again. Squeezing is the best method there; I found that driven rivets tended to gap where the parts were fairly flexible, unless I clamped near the hole, which made driving rivets more difficult. Where those rib flanges are, there aren't enough clecos or other structure to keep things from flexing and separating while you rivet. This will be true on all remaining structure - wing ribs and fuselage bulkheads. The preceding refers to a gap at the rivet. It the gap is between rivets, there is some fitment issue in the structure. I'd have a tech counselor look at it and advise you. Pat Kelley - RV-6A - Cabin floors in, working on passenger seat. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Folbrecht, Paul Sent: Monday, January 30, 2006 1:16 PM Subject: RV-List: Gaps in HS rib-to-front-spar joint To clarify, this is the front-flange of the main rib to front-spar joint on a 9A HS. ________________________________ From: Folbrecht, Paul Sent: Monday, January 30, 2006 1:06 PM Subject: Gaps in HS rib-to-front-spar joint I hate to have to post this. As the title says, I have a slight gap in two ribs - one on each side. It is at least wide enough to get a piece of paper under. I have not yet installed the rear spar so I could drill these out and re-rivet. Something tells me that I really ought to. Is it something I would need to worry about? Is it a strength issue? Paul ________________________________________________________________________________
Date: Jan 30, 2006
Subject: Re: nut plate revets
Sherman, The main purpose of a nutplate rivet is to hold the nut(plate) so you can get a screw in it . . . the rivet is not usually structural. So I would use what ever works in a given situation unless you perceive that the rivet is doing something more than just holding the nutplate. I generally try to use the rivet that is called out . . . but I would rather have a good "blind rivet" than a bad driven one! You talk about Oops rivets . . . which is just another form of driven rivet in my shop and are used mainly when you have missdrilled something and ended up to a over sized hole? Good Luck, Bob in SE Iowa On 1/30/06, Sherman Butler wrote: > > > Is mounting nut plates with NAS-1097 rivets (oops) and acceptable practice? It seems as if it would be easier in some locations, such as the trim plate. > > Sherman Butler > RV 7a Empennage > > > Sherman Butler > RV-7a Empennage > > --------------------------------- > > ________________________________________________________________________________
Subject: Request for Kitplanes Magazine: Avionics Shops for Hazard Avoidance
Installation
Date: Jan 30, 2006
Hello all, I'm working on an article for Kitplanes Magazine about the various products for hazard avoidance (traffic, terrain and weather), and would like to hear from anyone who's had this installed in their RV (or other homebuilt, if you have more than an RV). In particular, I'd like to hear your experiences in what you learned in the process, what you wish you had known at the outset, how your experiences with the gear has been and whether it's met your expectations. I would like to focus on the products that are not dug-in certified gear, but rather designed and engineered for experimental aircraft. In addition, I would like to talk to a few avionics shops who have some solid experience in these installations in experiementals, so if you have a shop that you felt did a good job, that would be great. For the sake of the list traffic, I may be contacted off-list at (de-spammed email to follow): Coryemberson (at) earthlink (dot) net Also, congratulations to Dan Checkoway, chosen by SportAir workshops to teach RV Assembly classes on the west coast. Attaboy, Dan! Your "Build Your Skills: Metal" series in Kitplanes has been excellent! (And yes, I lifted this from the latest issue's "Around the Patch"!) Thanks very much! Best, Cory Emberson Contributing Editor Kitplanes Magazine ________________________________________________________________________________
Date: Jan 31, 2006
In a message dated 1/30/2006 7:32:33 P.M. Pacific Standard Time, lsbrv7a(at)yahoo.com writes: Is mounting nut plates with NAS-1097 rivets (oops) and acceptable practice? It seems as if it would be easier in some locations, such as the trim plate. ========================================= Absolutely. These rivets were almost made for this application. GV (RV-6A N1GV O-360-A1A, C/S, Flying 771hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jan 31, 2006
Yes, 1097 rivets are acceptable and IMHO invaluable for installing nutplates. The rivets only hold the nutplate in place, thetorque of the screw in the nutplate provides the structural stuff. You could hold the nutplate in place with dried bubblegum if you wanted to. Jeff Point RV-6 Milwaukee > > ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Date: Jan 31, 2006
Hi, I've not seen the origin on this tread, Lycoming's break in procedure tells you to keep ground running to a minimum, use 75% power and for 5 min every hour full throttle, and of course avoid shock cooling. Run the engine on Straight 80 until such time oil consumption is established. Re: the subject line, it is possible since the cast for the crankcase is the same, however, everything else has to be changed, including the crank. The cam is the same though in a lot of cases. A good project if you have nothing better to do with your time and money :-) ----- Original Message ----- From: "Bruce Gray" <Bruce(at)glasair.org> Sent: Tuesday, January 31, 2006 2:48 AM Subject: RE: RV-List: Re: O320 to O360 conversion > > Usually a prolonged full power run is the last gasp before pulling the > jugs > on an engine that consumes to much oil after overhaul. > > Bruce > www.glasair.org > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Oliver Washburn > Sent: Monday, January 30, 2006 4:27 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Re: O320 to O360 conversion > > > I have never read that the eng should be run wide open to break in. > However > they do want you to run at high power settings for the first few hours. > Ollie > > > ----- Original Message ----- > From: "bdjones1965" <rv_8pilot(at)hotmail.com> > To: > Sent: Monday, January 30, 2006 3:14 PM > Subject: RV-List: Re: O320 to O360 conversion > > >> >> Sounds like almost as much hassle as finding a test stand and breaking it >> in on the ground. Ever consider this option? >> >> Bryan >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=8234#8234 >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: Rudder questions
Date: Jan 31, 2006
The proseal in the traling edge is only there to assist novice builders in the novice nuisance of double flush riveting. It can be build without proseal. There are 3M adhesives for aerospace use more commonly used in the composites structures. I'm not 100% about the numbers, but 3512 I think is the fast drying and 2266 the slow one. I is quite a few years that I used these adhesives. The slow one is in a Boeing material spec for the filler of the Rudder on the 737 Classic and 737X. ----- Original Message ----- From: "Sherman Butler" <lsbrv7a(at)yahoo.com> Sent: Tuesday, January 31, 2006 3:25 AM Subject: RV-List: Rudder questions > > 1. I saw a very well done RV 7 this weekend with a trim wedge mounted on > the side of the rudder. Has anyone used an adjustable trim tab? It > would be easy to slip in while building the rudder. > > > 2. Has anyone had experience with 3M polyurethane adhesive? I am > thinking about using it on the trailing edged assembly. > > Sherman Butler > RV 7a Empennage > > > Sherman Butler > RV-7a Empennage > > --------------------------------- > > > ________________________________________________________________________________
Date: Jan 31, 2006
> Is mounting nut plates with NAS-1097 rivets (oops) and acceptable practice? It seems as if it would be easier in some locations, such as the trim plate. > You've gotten some good answers on this; but, let me throw in something. Whatever you use to install nut plates, plate nuts, anchor nuts (official name), make sure it's somthing that has enough strength to hold up for a long time. You don't want your fasteners to give up at some point down the line when you accidentally put too much torque on the anchor nut; so, bubblegum may not work well enough. :-). Anchor nuts are used in places where one can't get to them easily. Changing one out, or replacing the rivets that hold them in place, can be a real task that you don't want. The oops rivet may work; but, remember that tiny head may cause you problems later if it decides to pull out. I'm not saying it will. I'm being conservative. I've seen anchor nuts come loose on at least one side. It became a task getting the anchor nut back in place well enough for the screw to thread in without cross threading. I don't want that to happen if it's buried deeply inside the structure where I'd have to disassemble a bunch of stuff to get to it to fix it. Jim Sears in KY RV-6A N198JS RV-7A #70317 EAA Tech Counselor ________________________________________________________________________________
Date: Jan 31, 2006
Jim, Sounds like a craftsman. Actually I was thinking about a ground adjustable trim tab. On my Grumman the exposed edge of 0.16 was about 6" X 1.25" on the rudder and ailerons. sears(at)searnet.com wrote: > 1. I saw a very well done RV 7 this weekend with a trim wedge mounted on the > side of the rudder. Has anyone used an adjustable trim tab? It would be easy to > slip in while building the rudder. A fellow I know has a trim tab mounted in the rudder of his RV-3 and will do it for his RV-7. May have already done it. If I remember, the horn for the tab is also hidden. He does very nice work. If you're close to Louisville, KY, he may show it to you. His name is Chuck Brietigam at brietigam(at)earthlink.net, if this address is still good. His workmanship is beautiful. . Jim Sears in KY RV-6A N198JS RV-7A #70317 (Putting lights in leading edges.) EAA Tech Counselor Sherman Butler Idaho Falls Sherman Butler RV-7a Empennage --------------------------------- ________________________________________________________________________________
Date: Jan 31, 2006
lsbrv7a(at)yahoo.com wrote: > Is mounting nut plates with NAS-1097 rivets (oops) and acceptable practice? It seems as if it would be easier in some locations, such as the trim plate. ------- Sherman, Absolutely. For nut plate application the NAS1097 is the fastener of choice. In fact, you will surely compromise hole quality by attempting to machine countersink thin material such as .025 to accept a kit supplied 426 rivet! The NAS 1097 is available in just about every length that the ubiquitious NAS426 is, but the longer lengths can be hard to find. The rivet has long been used in the production environment. No matter, the RV design only requires the smaller lengths. I don't know for sure, but my guess is Van's coined the quaint little term "oops" rivet to paint a word picture in the mind of a newbie in an attempt to better describe one of the NAS1097AD4's potential qualities to a new builder faced with a botched and oversized hole to fill. Actually the NAS1097 is a far more utilitarian fastener than just serving in that capacity. Curiously, Van's own people use the 1097 AD3 rivet to install nutplates/platenuts (the term is interchangeable) but its application is never explained in the builders manual. Van's stocks a few lengths of the NAS1097AD3. You will find the -3.5 to be by far the most commonly used length. Not found in the accessory catalog, you have to refer to "the list" to find them. I have used the 1097 in many places on the airframe, including a pattern on the canopy side skirts, rudder cable fairing attachment, etc....wherever material thickness and the job warrants their welcomed use. The oft misunderstood NAS1097....its not just an "oops" rivet. Order your stash today! Rick Galati RV-6A "Darla" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=8391#8391 ________________________________________________________________________________
Date: Jan 31, 2006
Hi Paul- Re: "I hate to have to post this. As the title says, I have a slight gap... ...It is at least wide enough to get a piece of paper under. I have not >yet installed the rear spar... ...Is it something I would need >to worry about? Is it a strength issue?" > >Paul If I understand your situation correctly, I would say that yes, those should be re-done. I believe that structural members such as the ones in question here should definitely be in full contact. I'd be concerned that the rivets in question would loosen pretty quickly in service. In any case, I'd also suggest that correcting the issue now will prevent sleepless nights in the future. I believe that the phenomena you have encountered here is generally caused by not holding the bucking bar sufficiently tight to the rivet during bucking. This allows the bucking bar to 'chatter' against the rivet, which can cause the gap between the parts. You may wonder how I know this.... Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
From: "Mark Chamberlain" <mchamberlain(at)runbox.com>
Subject: Van's Firewall Forward Kit
Date: Jan 31, 2006
Hi all, Just wondering how many of you ordered/intend to order the Van's firewall forward kit? I'm trying to decide if that is the best way to go, or if it is better to just purchase the parts as needed. For those of you who have used it; did you use everything in there? Or did some items go to waste? How much other stuff did you need to purchase on top of this for the firewall forward? Thanks in advance for any help, Mark Fuselage - Finish kit arriving this week. http://websites.expercraft.com/markc/ ________________________________________________________________________________
Subject: Re: Van's Firewall Forward Kit
Date: Jan 31, 2006
Mark, I didn't use the firewall forward for two reasons. I had purchased a "firewall forward" off a 2000 Decathlon and had a lot of duplication had I gone with the Vans stuff. That said, I have spent a lot of time just locating stuff so it doesn't conflict. I purchased some drawings to help with firewall penetrations. If I had it to do over again, and didn't have inverted systems, (ie standard Lycoming) I would have bought vans FWF and been flying already. It has been the slowest part for me, and I'm one slow builder, ha, ha. Have fun. John Porter #80002 (slowest -8 build of all time) > Hi all, > > Just wondering how many of you ordered/intend to order the Van's > firewall forward kit? > > > > ________________________________________________________________________________
Date: Jan 31, 2006
It seems that I overstated the case. I posted from the office, without the parts in sight, after having thought about this "gap" for several hours. It turns out that there is full contact where the rivets are and the gaps are only between rivets, for whatever reason. I probably should have clamped to prevent this (I had clecos in two of the three holes when riveting but no clamps) but I don't think it's a concern. Come to think of it, if the rib had been offset any significant amount, the skin-to-rib rivets would not likely have fit without redrilling, and they did. So, again, I'm afraid this was 90% my newbie-perfectionism and my overactive imagination at work. I apologize for not looking at things more carefully before posting. Thanks. Paul -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Glen Matejcek Sent: Tuesday, January 31, 2006 7:49 AM Subject: RV-List: Gaps in HS rib-to-front-spar joint Hi Paul- Re: "I hate to have to post this. As the title says, I have a slight gap... ...It is at least wide enough to get a piece of paper under. I have not >yet installed the rear spar... ...Is it something I would need >to worry about? Is it a strength issue?" > >Paul If I understand your situation correctly, I would say that yes, those should be re-done. I believe that structural members such as the ones in question here should definitely be in full contact. I'd be concerned that the rivets in question would loosen pretty quickly in service. In any case, I'd also suggest that correcting the issue now will prevent sleepless nights in the future. I believe that the phenomena you have encountered here is generally caused by not holding the bucking bar sufficiently tight to the rivet during bucking. This allows the bucking bar to 'chatter' against the rivet, which can cause the gap between the parts. You may wonder how I know this.... Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: land of enchantment
Date: Jan 31, 2006
Hi all, I am going to visit a friend in Las Cruces NM soon, can anyone recommend some interesting places to go in a rented Skyhawk? I live on the Olympic Peninsula, haven't seen the sun in months! Kevin Shannon HR-II under const ________________________________________________________________________________
Date: Jan 31, 2006
Kyle, I like the monokote idea. A couple of thoughts to expand on this. Monokote has a very glossy finish. The resin may still stick to the Monokote. Use mold release wax on the Monokote followed with PVA mold release. Spray multiple LIGHT coats of PVA onto the Monokote. PVA has a tendency to bead up when sprayed over the wax. Multiple light coats help eliminate the beading. When finished, the the piece will pop off the Monokote much easier. Acetone removes the pigment/adhesive used on Monokote. Unless the surface beneath the Monokote is reactive to acetone, put some acetone on a rag and wipe the surface clean. Obviously, use proper ventilation and protective safety gear. BTW, PVA is PolyVinyl Alcohol. Any good fiberglass supplier will stock this item. Dave --- Kyle Boatright wrote: > > > You could try tapeing thin cardboard between the > canopy and fuselage. My > cardboard of preference (from making the empennage > fairing years ago) comes > from Diet Coke 12-pack cartons... > > Several pieces of cardboard, a little packing tape, > and volia, female > mold... > > Alternately, you could get yourself some Monokote or > similar shrink film, > cut it to rough shape, tape the ends to the plexi > and fuselage, and shrink > the stuff into the shape you want. Might even work. > (Note- put a layer of > packing tape between the monokote and your canopy, > or risk color > transfer)... > > KB > > > ----- Original Message ----- > From: "Randy Lervold" <randy(at)romeolima.com> > To: > Sent: Monday, January 30, 2006 6:21 PM > Subject: RV-List: Fiberglass canopy skirt from > scratch > > > > > > > Fiberglass gurus, > > > > After trying to get the metal skirt to fit on my > RV-3 I'm giving up -- I'm > > convinced God just didn't intend aluminum to be > used for compound curves, > > fiberglass on the other hand is perfectly suited > for that. No worries with > > laying it up and such (West Systems and 9 oz > crowfoot e-glass), but what > > I'd > > appreciate some ideas on are how to craft a > molding surface. I will pop > > rivet my tipover plexi bubble to the frame in > every other hole, which I > > will > > later drill out, so there won't need to be an > clecos and thus I can layup > > onto the plexi. But what do I use to create a form > from the plexi down to > > the fuselage, or to bridge the gap along the > sides? This is way too much > > area for the traditional modeling clay we use for > intersection fairings. > > > > If I use any sort of tape it will create an uneven > layup and require lots > > of > > sanding and filling, something I'd rather avoid. I > was thinking of using > > expandable foam around the front and rear sections > (won't work on the > > sides) > > and then sculpting it. Seems like I heard that the > cans of foam you can > > buy > > at Home Depot aren't good because they contain > formaldehyde, not sure why > > that's bad though. > > Spruce has Poly-Cell 100 Polyurethane Foam > > > http://www.aircraftspruce.com/catalog/cmpages/polycel.php > > and Liquid "X30" Foam > > > http://www.aircraftspruce.com/catalog/cmpages/x30foam.php > > > > Anyone had an experience with either of these? > When using foam, do you lay > > up directly on it, or coat it with something > first? > > > > And lastly, what would be a good way to create a > surface on the sides? > > Here's a pic of what I'm dealing with... > > > http://www.romeolima.com/RV3works/Gallery/DSC_0899.jpg > > > > Thanks! > > Randy Lervold > > www.rv-3.com > > www.rv-8.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ, > > Admin. > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 31, 2006
Call Van's and have them fax you the inventory list for the FWF kit for your particular engine+intake. You can then pick and choose what you want omitted or included. Or just use it for a reference to do your own shopping. I had a handful of items that I didn't end up using -- particularly hoses that didn't quite work with my setup. The more *bone stock* your setup is, the more applicable the FWF kit is, and vice versa. )_( Dan RV-7 N714D (802 hours) http://www.rvproject.com ----- Original Message ----- From: "John Porter" <december29(at)bellsouth.net> Sent: Tuesday, January 31, 2006 7:07 AM Subject: Re: RV-List: Van's Firewall Forward Kit > > Mark, > I didn't use the firewall forward for two reasons. I had purchased a > "firewall forward" off a 2000 Decathlon and had a lot of duplication had I > gone with the Vans stuff. That said, I have spent a lot of time just > locating stuff so it doesn't conflict. I purchased some drawings to help > with firewall penetrations. If I had it to do over again, and didn't have > inverted systems, (ie standard Lycoming) I would have bought vans FWF and > been flying already. It has been the slowest part for me, and I'm one > slow > builder, ha, ha. Have fun. > > John Porter > #80002 (slowest -8 build of all time) > > >> Hi all, >> >> Just wondering how many of you ordered/intend to order the Van's >> firewall forward kit? > >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 31, 2006
Subject: Headset Hanger
What have others done to hang their headsets on to keep them out of the way? I keep mine plugged in and ready to go so would like to come up with something that won't hinder climbing into and out of my RV-4. Pat Long PGLong(at)aol.com N120PL RV4 Bay City, Michigan 3CM Do Not Archive ________________________________________________________________________________
Date: Jan 31, 2006
Mark, I would strongly recommend the firewall forward kit. Otherwise you are going to spend an inordinate amount of time figuring out what to order (hoses, clamps, special bolts, washers, etc, etc.) There will still be enough of that to do anyway. In some cases you could order the individual kits, such as the Filtered Air Box kit or the Baffle kit, but it is much easier to just get the Firewall Forward kit. Terry RV-8A #80729 Baffling Seattle Hi all, Just wondering how many of you ordered/intend to order the Van's firewall forward kit? I'm trying to decide if that is the best way to go, or if it is better to just purchase the parts as needed. For those of you who have used it; did you use everything in there? Or did some items go to waste? How much other stuff did you need to purchase on top of this for the firewall forward? Thanks in advance for any help, Mark Fuselage - Finish kit arriving this week. http://websites.expercraft.com/markc/ ________________________________________________________________________________
Date: Jan 31, 2006
I purchased it. Had some duplication, but made it up in lots of time saved. I'd definetly recommend purchasing it. Chuck Weyant RV9A Slowbuild 140 Hours now and loving it! > > Call Van's and have them fax you the inventory list for the FWF kit for > your > particular engine+intake. You can then pick and choose what you want > omitted or included. Or just use it for a reference to do your own > shopping. > > I had a handful of items that I didn't end up using -- particularly hoses > that didn't quite work with my setup. The more *bone stock* your setup > is, > the more applicable the FWF kit is, and vice versa. > > )_( Dan > RV-7 N714D (802 hours) > http://www.rvproject.com > ________________________________________________________________________________
Date: Jan 31, 2006
Subject: Re: Headset Hanger
I've got a photo of a stolen idea for a 6(A) slider. Don't know how it might apply to a 4 though. Zap me offline..... Ralph Capen -----Original Message----- >From: PGLong(at)aol.com >Sent: Jan 31, 2006 11:24 AM >To: Rv-list(at)matronics.com >Subject: RV-List: Headset Hanger > > >What have others done to hang their headsets on to keep them out of the way? >I keep mine plugged in and ready to go so would like to come up with >something that won't hinder climbing into and out of my RV-4. > >Pat Long >PGLong(at)aol.com >N120PL >RV4 >Bay City, Michigan >3CM > >Do Not Archive > > > > > > > ________________________________________________________________________________
Date: Jan 31, 2006
I've been using Van's firewall forward kit and wiring kit in a 6A under construction. We decided to use the RV7A configuration with the Odyssey battery installation and so far everything lines up the way it's supposed to. You have to put things where Van's tells you to so all the brackets, cables and hoses work but just make sure you're using the correct plan sheet and firewall penetration chart for your configuration. We are not using the vertical panel from the panel to the floor and that means the mixture cable and manual trim cable are in a different position and one is too short and one is too long. We just deleted the cables from the package and will order them later when their length is determined. I haven't found the need to order any extra parts yet but I'm sure when I get into the wiring there will be bit's and pieces necessary. All the big stuff is there, baffle kit, alternator and mounting kit, airbox, motor mounts with bolts, plumbing, things I had to make multiple orders from Van's and Spruce to get are all here so there is no excuse for not making progress on the project. Good luck. Larry Gagnon RV6 N6LG 90 hours RV6A finish kit ________________________________________________________________________________
Date: Jan 31, 2006
Subject: Hollister AWOS???
I was in Los Banos last night and a local pilot gave me a phone number for Hollister AWOS. Now that I am home I wanted to get that phone number again and cannot find anything on the web about Hollister having an AWOS, let alone a phone number to get to it. Does anyone know what the phone number is to call Hollister AWOS? - Matt ________________________________________________________________________________
Subject: Re: Hollister AWOS???
Date: Jan 31, 2006
I think the Hollister AWOS phone number is 1-831-724-8794. Don't know for sure, I just googled it. Bill King ----- Original Message ----- From: "Matt Johnson" <matt(at)n559rv.com> Sent: Tuesday, January 31, 2006 12:59 PM Subject: RV-List: Hollister AWOS??? > > I was in Los Banos last night and a local pilot gave me a phone number for > Hollister AWOS. Now that I am home I wanted to get that phone > number again and cannot find anything on the web about Hollister having an > AWOS, let alone a phone number to get to it. Does anyone > know what the phone number is to call Hollister AWOS? > > - Matt > > > ________________________________________________________________________________
Date: Jan 31, 2006
Subject: No safety wire hole for oil temp probe
The oil temp probe supplied with my engine monitor (Dynon EMS D10) has no hole drilled for attaching safety wire. This seems unusual to me. I'm wondering if I should attempt to drill a hole myself or perhaps just acquire a new temp probe. Any thoughts. Joel Haynes Bozeman, MT 7A Finishing ________________________________________________________________________________
Date: Jan 31, 2006
Subject: Fwd: PC Simulators
I have purchased several version of MS Flight Simulator through the years and I still do not like it. However, I have found OnTop version 8 from ASA to be a great IFR trainer. Don't expect great graphics out the window because it's an IFR trainer. But the panel graphics are great and you can configure the panel in many different ways for a variety of aircraft. It has all the VORs, NDBs, airports, etc. It flies like a real airplane. Joel Haynes Bozeman, MT 7A Finishing ________________________________________________________________________________
Subject: Flight sim for RV???
Date: Jan 31, 2006
Try the Flight Factory RV-7/7A. You can probably tweak it to match your aircraft's performance. Pat Kelley - RV-6A - working on seats -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com Sent: Tuesday, January 31, 2006 6:06 PM Subject: RV-List: Flight sim for RV??? This may have been asked before but I can't find anything in the archives.... Does anyone have an RV (I fly an RV9A) for the Microsoft Flight Sim? Thanks - Kim Nicholas ________________________________________________________________________________
Subject: Re: Hollister AWOS??? try anyAWOS.com
Date: Feb 01, 2006
Have you tried www.anyawos.com? Phone is 877-269 2967. According to the phone message, the service becomes subscription only on 6 Feb..... Marty RV-7 Still hoping to tip the canoe someday.... >From: "William King" <bill@kane-king.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: Hollister AWOS??? >Date: Tue, 31 Jan 2006 13:33:31 -0500 > > >I think the Hollister AWOS phone number is 1-831-724-8794. Don't know for >sure, I just googled it. > >Bill King >----- Original Message ----- >From: "Matt Johnson" <matt(at)n559rv.com> >To: ; ; > >Sent: Tuesday, January 31, 2006 12:59 PM >Subject: RV-List: Hollister AWOS??? > > > > > > I was in Los Banos last night and a local pilot gave me a phone number >for > > Hollister AWOS. Now that I am home I wanted to get that phone > > number again and cannot find anything on the web about Hollister having >an > > AWOS, let alone a phone number to get to it. Does anyone > > know what the phone number is to call Hollister AWOS? > > > > - Matt > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Flight sim for RV???
Date: Jan 31, 2006
Pat, Try this link. http://www.surclaro.com/downloads_c23_10_dateD.html You might have to join up but its free and there are a lot of files and information to download. There are some other files you might want to go with this that allow you to tweek it into a fair model. if you do let me know. There is also an RV-6 on this site. Do Not Arcive Have Fun John D. ----- Original Message ----- From: "Patrick Kelley" <webmaster(at)flion.com> Sent: Tuesday, January 31, 2006 7:20 PM Subject: RE: RV-List: Flight sim for RV??? > > Try the Flight Factory RV-7/7A. You can probably tweak it to match your > aircraft's performance. > > Pat Kelley - RV-6A - working on seats > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of > Knicholas2(at)aol.com > Sent: Tuesday, January 31, 2006 6:06 PM > To: rv-list(at)matronics.com > Subject: RV-List: Flight sim for RV??? > > > This may have been asked before but I can't find anything in the > archives.... > > Does anyone have an RV (I fly an RV9A) for the Microsoft Flight Sim? > > Thanks - > Kim Nicholas > > ________________________________________________________________________________
Subject: #3 CHT
Date: Feb 01, 2006
Listers, For years I have just lived with the fact that #3 CHT is always higher than the rest. I have flown my RV-8 for 950 hours with #3 CHT running 15* higher than the rest, after I put the temp riser in front of #1. Then, awhile back someone mentioned putting a washer between the #3 cylinder and the back baffle where the screw holds the baffle to #3. Well, I put a 1/8" washer there and sure enough, #3 CHT came down 15* and now all four CHTs are with 4* of one another. Thanks to whomever made the suggestion. So #3 CHT does not have to be higher than the rest!!! Another myth busted. Stu McCurdy RV-8 Flying ________________________________________________________________________________
Date: Jan 31, 2006
Subject: Re: #3 CHT
Just goes to show how important a engine monitor is. Otherwise you really dont know what your engine is doing. Is there anyone out there who thought their engine was running great, then put in a engine monitor and realized just how bad the temps were? Care to share with us? sturdy(at)att.net wrote: Listers, For years I have just lived with the fact that #3 CHT is always higher than the rest. I have flown my RV-8 for 950 hours with #3 CHT running 15* higher than the rest, after I put the temp riser in front of #1. Then, awhile back someone mentioned putting a washer between the #3 cylinder and the back baffle where the screw holds the baffle to #3. Well, I put a 1/8" washer there and sure enough, #3 CHT came down 15* and now all four CHTs are with 4* of one another. Thanks to whomever made the suggestion. So #3 CHT does not have to be higher than the rest!!! Another myth busted. Stu McCurdy RV-8 Flying Scott Bilinski RV-8a cell 858-395-5094 --------------------------------- ________________________________________________________________________________
Subject: Re: Fwd: PC Simulators
Date: Jan 31, 2006
----- Original Message ----- From: joelrhaynes(at)aol.com Sent: Tuesday, January 31, 2006 5:44 PM Subject: RV-List: Fwd: PC Simulators When it comes to MS Flight Simulator, there are many 3rd party add-on aircraft, both freeware and payware, that are designed and programmed by people with many years experience. And some of these designers range from private GA airplane owners to 767 Captains. The end result is also a simulated plane that fly's like a plane, as well as panels that look very real. Personally, I prefer MS to On Top, because of the realistic topography mesh that's available for the areas I fly in the Mt. West. I like simulated airports that are located within the surrounding topography, as they are in real life. It's like flying there, before you actually do. You can get a good idea of the airport layout including taxiways beforehand. I have purchased several version of MS Flight Simulator through the years and I still do not like it. However, I have found OnTop version 8 from ASA to be a great IFR trainer. Don't expect great graphics out the window because it's an IFR trainer. But the panel graphics are great and you can configure the panel in many different ways for a variety of aircraft. It has all the VORs, NDBs, airports, etc. It flies like a real airplane. ________________________________________________________________________________
Date: Jan 31, 2006
From: William Scaringe <bscaringe(at)sbcglobal.net>
Subject: Tools For Sale: 2X Rivet Gun, 5000 rpm 3/8 Air Drill, Rivet Cutter
Hi Builders, my divorce sale continues with these high quality tools on eBay: U.S. Air Tool 2X Rivet Gun http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7586776693 Rockwell 5000 rpm 3/8 Air Drill http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7586774967 Heavy Duty Rivet Cutter http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7586771504 ________________________________________________________________________________
Date: Jan 31, 2006
Yeah, I had tried anyAWOS, they did not have it. I just got it though from another pilot who called the airport. Thanks for the suggestion. I guess it is pretty new and not registered with anything yet but you can call it. - Matt -----Original Message----- From: "Marty Helller" <marty_away(at)hotmail.com> Date: Wed, 01 Feb 2006 01:43:33 +0000 Subject: Re: RV-List: Hollister AWOS??? try anyAWOS.com > > Have you tried www.anyawos.com? Phone is 877-269 2967. According to > the > phone message, the service becomes subscription only on 6 Feb..... > > Marty > RV-7 > Still hoping to tip the canoe someday.... > > > >From: "William King" <bill@kane-king.com> > >Reply-To: rv-list(at)matronics.com > >To: > >Subject: Re: RV-List: Hollister AWOS??? > >Date: Tue, 31 Jan 2006 13:33:31 -0500 > > > > > >I think the Hollister AWOS phone number is 1-831-724-8794. Don't know > for > >sure, I just googled it. > > > >Bill King > >----- Original Message ----- > >From: "Matt Johnson" <matt(at)n559rv.com> > >To: ; ; > > > >Sent: Tuesday, January 31, 2006 12:59 PM > >Subject: RV-List: Hollister AWOS??? > > > > > > > > > > I was in Los Banos last night and a local pilot gave me a phone > number > >for > > > Hollister AWOS. Now that I am home I wanted to get that phone > > > number again and cannot find anything on the web about Hollister > having > >an > > > AWOS, let alone a phone number to get to it. Does anyone > > > know what the phone number is to call Hollister AWOS? > > > > > > - Matt > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: EIS Settings / Pages
Date: Jan 31, 2006
Speaking of engine monitors... I have been doing some tweaking on my EIS and have created a spreadsheet I use for figuring out the settings and getting down on paper before transferring them to the EIS and have put a copy on my web site if anyone wants to download it: http://www.rv8a.com/downloads/ Anyway, I am interested in how people have their EIS configured, specifically; What are you displaying on your custom pages? What limits do you have set? Moreover, What limits do you have set for: MAX EGT SPAN MAX EGT INC MAX EGT DEC MAX C RATE Thanks! -Bill VonDane RV-8A - Colorado Springs www.rv8a.com www.creativair.com www.epanelbuilder.com ________________________________________________________________________________
Date: Feb 01, 2006
Thanks for all the great information on this folks! It sounds like this is the way to go, especially at the speed I'm building at, with this I will have most of what I need when I need it and won't be waiting for another shipment every five minutes. Van's is pretty good when it comes to returning stuff (usually) so I'm guessing they'll let me return anything I don't use anyway. Thanks again, Mark - 234C (res) http://websites.expercraft.com/markc/ ________________________________________________________________________________
Subject: EIS settings
Date: Feb 01, 2006
I've got them all in a handy spreadsheet. Email me OFFLINE if you want a copy sent to you. The spreadsheet is set up for an IO-540, but most, if not all, of the settings are applicable to RV engines. The only thing I can think of that doesn't apply is the %power chart and the fuel inj stuff if you're carbureted. Vince F-1H Rocket, N540VF http://vincesrocket.com/ ________________________________________________________________________________
Date: Feb 01, 2006
Pat, I saw a clever idea at S&F last year. Van's display model had a small bent pc 025 alum riveted to the mid level angle brace to left of pilot's knee. This creates a "hook" to hang the headsets on. Put one on each side of my RV6A last year. Works just fine. They are out of the way until you are ready for them. Don't know if this is adaptable to RV4, but worth a look. Dick At 11:24 AM 1/31/2006, you wrote: > >What have others done to hang their headsets on to keep them out of the way? >I keep mine plugged in and ready to go so would like to come up with >something that won't hinder climbing into and out of my RV-4. > >Pat Long >PGLong(at)aol.com >N120PL >RV4 >Bay City, Michigan >3CM > >Do Not Archive > > ________________________________________________________________________________
Date: Feb 01, 2006
I bought Van's RV8 wiring kit for $200 + - and used it on my HR II. It was perfect, saved time and headaches, and had to be less expensive than buying too much of everything. If his FWF kit is as good you can't miss. I have been dealing with Van since I started my RV6 in 1989, and the cadre he has now are nothing short of phenomenal in their engineering. Take this for what it's worth but if I were in your shoes I would buy it. jim HR II N144HR ________________________________________________________________________________
Date: Feb 01, 2006
The "Pilot's Guide to California Airports" lists the Hollister AWOS number as 831-636-4394. I tried it and it works. ----- Original Message ----- From: "Matt Johnson" <matt(at)n559rv.com> Sent: Tuesday, January 31, 2006 9:59 AM Subject: RV-List: Hollister AWOS??? > > I was in Los Banos last night and a local pilot gave me a phone number for > Hollister AWOS. Now that I am home I wanted to get that phone > number again and cannot find anything on the web about Hollister having an > AWOS, let alone a phone number to get to it. Does anyone > know what the phone number is to call Hollister AWOS? > > - Matt > > > -- > > ________________________________________________________________________________
Subject: Re: CYL high temp
Date: Feb 01, 2006
Those temps sound reasonable to me. Frankly, I would wait until the seasonal temps begin to heat up a bit and see how the airplane flies leaned back at altitude. Remember that temps will come down as your altitude increases. Your well below the recommended temp for maximum service life. I'm flying an RV6 with a new 0320 D1A and an 80 pitch Sensenich FP. I'm running about 374F at 65% cruise and 392F flat out. My climb temp is 428F full throttle. Oil temp 176-194F. This is at 3000' and below. At 8000' and above subract about 3-5 percent from those numbers. Here is the complete list of CHT problems in case you don't want to read all the way through this message before troubleshooting. 1. Spark plugs of improper heat rating 2. Cooling baffles, missing, broken or bent. Be sure you have the lycoming baffles between the cylinders. Not just the baffling kit that came from Van's. 3. Partially plugged fuel nozzle 4. Fuel lines of improper I.D. Should be .085 to .090 for lycoming engines. Primer lines must have restrictor fittings. 5. Engine improperly timed. 6. Engine running too lean. Look for carbon deposits in the combustion chamber, if there are none, the engine is being run continually too lean. 7. Improper rigging of mixture control. Ensure full travel capability. 8. Exhaust gas leak into the cylinder. Look for burned paint or white deposits. 9. Loose or bad CHT leads. Only use bayonette style. Spark plug ring style are junk. Temps to remember Oil Temp - 160F to 245F . At least 180 deg F to ensure vaporization of moisture out of the oil. CHT- Minimum in flight 150F. Cruise range 350-435F ( not to exceed 400F for maximum service life) EGT- 1200-1600F. (1400F for maximum service life) Probe calibration Forget about having to buy expensive thermometers to calibrate your probes. Just emerse the probes in boiling water and look for consistancy around 212 deg F. If you have all 4 monitored, try swapping around to look for a change in readings. Once you feel comfortable that your monitoring is accurate to within 10 deg F or so you can begin to look for ways to bring the temps down. The most common sources of problems lie in Mixture control and baffle efficiency. Lets attack them one at a time Mixture Questions Which is your hottest cylinder, should be #3 or #4. The leanest running cylinder is going to be the hottest. My experience is that #3 usually runs a little leaner than the rest and therefore hotter. If you have carb heat, try cracking it slightly to enrich the mixture and see if the temp comes down. If this works, you might go with it. If your still worried, we will move on. If your engine is running a bit lean at cruise rpm, the only way you can improve this would be to bore out the jets by a tiny amount. This would be the last option after you try all else. The mixture dial on the carb is only for idle mixuture adjustment and will have no effect on cruise mixture. Baffling Questions Have you tried to tape vortex generators on the baffling just forward of the entry to cyl 1 and 2. They will increase airflow past 1 and 2 and feed more air back to 3 and 4. The comments about keeping the cylinder fins clean and clear are good ones as well. You can also adjust the air exit velocity by playing with your safety wire length under the baffles. If you want to get real inventive, you can change the air exit velocity from the coweling by cutting away about 1/4" at a time from the trailing edge of the scoop. The biggest breakthrough I found was to put fiberglass boxes above the air entry ports into the coweling using those funny looking layups that Van's sends you with the finish kit. Pop rivet and glass those in and seal off the open ends with more layups so that air can't circulate unterneath them. Frankly, I would wait until the seasonal temps begin to heat up a bit and see how the airplane flies leaned back at altitude. Remember that temps will come down as your altitude increases. Happy Landings ----- Original Message ----- From: "lowell lemay" <llemay1(at)austin.rr.com> Sent: Tuesday, January 17, 2006 12:13 PM Subject: RV-List: CYL high temp > > Anyone have any new ideas on how to bring down the CYL temp on a new > Mattituck O-360 RV-7 with plenum chamber? Have plugged most > holes..placed horizontal flanges on top inside of plenum near the split in > the cyl heads, and cut off 1 inch across the middle bottom of the under > cowling. Started with over 425 on # 3 & 4 with 70% power and have them > down to about 380 with 55 F OAT. Will need more room when it gets > hot...........Now have 40 hours and consider it broken in...Lowell > > > ________________________________________________________________________________
From: "Dan Beadle" <dan.beadle(at)inclinesoftworks.com>
Subject: CYL high temp
Date: Feb 01, 2006
I am not flying the same engine, but the oil temps look great. The CHT seems a little high on climb out - I shoot for 400 degrees max, using cowl flaps. One engine runs 375 (gages have been calibrated recently). Generally, cooler is better for CHT. Oil Temp should get to 180 or so to boil off moisture in it. So your temps all sound pretty "Normal" -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of lancenewman Sent: Wednesday, February 01, 2006 12:07 PM Subject: Re: RV-List: CYL high temp Those temps sound reasonable to me. Frankly, I would wait until the seasonal temps begin to heat up a bit and see how the airplane flies leaned back at altitude. Remember that temps will come down as your altitude increases. Your well below the recommended temp for maximum service life. I'm flying an RV6 with a new 0320 D1A and an 80 pitch Sensenich FP. I'm running about 374F at 65% cruise and 392F flat out. My climb temp is 428F full throttle. Oil temp 176-194F. This is at 3000' and below. At 8000' and above subract about 3-5 percent from those numbers. Here is the complete list of CHT problems in case you don't want to read all the way through this message before troubleshooting. 1. Spark plugs of improper heat rating 2. Cooling baffles, missing, broken or bent. Be sure you have the lycoming baffles between the cylinders. Not just the baffling kit that came from Van's. 3. Partially plugged fuel nozzle 4. Fuel lines of improper I.D. Should be .085 to .090 for lycoming engines. Primer lines must have restrictor fittings. 5. Engine improperly timed. 6. Engine running too lean. Look for carbon deposits in the combustion chamber, if there are none, the engine is being run continually too lean. 7. Improper rigging of mixture control. Ensure full travel capability. 8. Exhaust gas leak into the cylinder. Look for burned paint or white deposits. 9. Loose or bad CHT leads. Only use bayonette style. Spark plug ring style are junk. Temps to remember Oil Temp - 160F to 245F . At least 180 deg F to ensure vaporization of moisture out of the oil. CHT- Minimum in flight 150F. Cruise range 350-435F ( not to exceed 400F for maximum service life) EGT- 1200-1600F. (1400F for maximum service life) Probe calibration Forget about having to buy expensive thermometers to calibrate your probes. Just emerse the probes in boiling water and look for consistancy around 212 deg F. If you have all 4 monitored, try swapping around to look for a change in readings. Once you feel comfortable that your monitoring is accurate to within 10 deg F or so you can begin to look for ways to bring the temps down. The most common sources of problems lie in Mixture control and baffle efficiency. Lets attack them one at a time Mixture Questions Which is your hottest cylinder, should be #3 or #4. The leanest running cylinder is going to be the hottest. My experience is that #3 usually runs a little leaner than the rest and therefore hotter. If you have carb heat, try cracking it slightly to enrich the mixture and see if the temp comes down. If this works, you might go with it. If your still worried, we will move on. If your engine is running a bit lean at cruise rpm, the only way you can improve this would be to bore out the jets by a tiny amount. This would be the last option after you try all else. The mixture dial on the carb is only for idle mixuture adjustment and will have no effect on cruise mixture. Baffling Questions Have you tried to tape vortex generators on the baffling just forward of the entry to cyl 1 and 2. They will increase airflow past 1 and 2 and feed more air back to 3 and 4. The comments about keeping the cylinder fins clean and clear are good ones as well. You can also adjust the air exit velocity by playing with your safety wire length under the baffles. If you want to get real inventive, you can change the air exit velocity from the coweling by cutting away about 1/4" at a time from the trailing edge of the scoop. The biggest breakthrough I found was to put fiberglass boxes above the air entry ports into the coweling using those funny looking layups that Van's sends you with the finish kit. Pop rivet and glass those in and seal off the open ends with more layups so that air can't circulate unterneath them. Frankly, I would wait until the seasonal temps begin to heat up a bit and see how the airplane flies leaned back at altitude. Remember that temps will come down as your altitude increases. Happy Landings ----- Original Message ----- From: "lowell lemay" <llemay1(at)austin.rr.com> Sent: Tuesday, January 17, 2006 12:13 PM Subject: RV-List: CYL high temp > > Anyone have any new ideas on how to bring down the CYL temp on a new > Mattituck O-360 RV-7 with plenum chamber? Have plugged most > holes..placed horizontal flanges on top inside of plenum near the split in > the cyl heads, and cut off 1 inch across the middle bottom of the under > cowling. Started with over 425 on # 3 & 4 with 70% power and have them > down to about 380 with 55 F OAT. Will need more room when it gets > hot...........Now have 40 hours and consider it broken in...Lowell > > > ________________________________________________________________________________
Subject: Re: Fiberglass canopy skirt from scratch
Date: Feb 01, 2006
Guys, the Monokote idea might just work well, and I have a couple of rolls laying around. What is Monokote actually made of, and is there a chance that epoxy resin won't stick to it? Also, how well can you control what/where it adheres? And lastly, how tough is it to get off, the plexi in particular? Anyone have more experience with it? Randy > > Kyle, > > I like the monokote idea. A couple of thoughts to > expand on this. > > Monokote has a very glossy finish. The resin may > still stick to the Monokote. Use mold release wax on > the Monokote followed with PVA mold release. Spray > multiple LIGHT coats of PVA onto the Monokote. PVA > has a tendency to bead up when sprayed over the wax. > Multiple light coats help eliminate the beading. When > finished, the the piece will pop off the Monokote much > easier. > > Acetone removes the pigment/adhesive used on Monokote. > Unless the surface beneath the Monokote is reactive > to acetone, put some acetone on a rag and wipe the > surface clean. Obviously, use proper ventilation and > protective safety gear. > > BTW, PVA is PolyVinyl Alcohol. Any good fiberglass > supplier will stock this item. > > Dave > > > --- Kyle Boatright wrote: > >> >> >> You could try tapeing thin cardboard between the >> canopy and fuselage. My >> cardboard of preference (from making the empennage >> fairing years ago) comes >> from Diet Coke 12-pack cartons... >> >> Several pieces of cardboard, a little packing tape, >> and volia, female >> mold... >> >> Alternately, you could get yourself some Monokote or >> similar shrink film, >> cut it to rough shape, tape the ends to the plexi >> and fuselage, and shrink >> the stuff into the shape you want. Might even work. >> (Note- put a layer of >> packing tape between the monokote and your canopy, >> or risk color >> transfer)... >> >> KB ________________________________________________________________________________
Date: Feb 01, 2006
Randy, Monokote is a plastic film used to cover model aircraft. It is heatshrinkable and has a heat activated adhesive which is also the pigment. First off, DO NOT adhere Monokote to plexi!!!!! I have just started my project and I am not totally familiar with the canopy area. After reading the posts regarding this, I was thinking that their was an area on the fuselage at the canopy that was used as a mold. I would only attach Monokote to bare metal or to a surface that is NOT reactive to acetone or dope thinner. Do not under any circumstances use acetone or dope thinner on plexi. If Monokote is the way you want to go, consider the following. Buy a Monokote iron from a hobby shop, about $20. Follow the directions therein. When attaching, only seal the edges down. When shrinking the rest, do not press down on the iron. Let the weight of the iron do the work. Shrink the Monokote till all wrinkles are gone. Make your layups with suitable mold release products. Upon removal, you will find some of the Monokote will have adhered to sealed edge areas and quite possibly the center as well. Use acetone or dope thinner in a clean rag with proper ventilation and safety equipment to remove the adhered Monokote. You will find the inside of your lamination to be glass smooth which I would lightly sand to break the glaze. Use your favorite adhesive to attach the skirt to the canopy. I have used Monokote to cover model aircraft for 30 years and for mold making because it makes a smooth surface without a great deal of work. One last thought, if you put Monokote on the plexi, only put it on the area that would be under the skirt. To remove it from the plexi, use a small orbital sander with a fine grit paper. I am guessing that you would need to rough this surface up anyways. I re-iterate, do not use solvents on the plexi. Dave --- Randy Lervold wrote: > > > Guys, the Monokote idea might just work well, and I > have a couple of rolls > laying around. What is Monokote actually made of, > and is there a chance that > epoxy resin won't stick to it? Also, how well can > you control what/where it > adheres? And lastly, how tough is it to get off, the > plexi in particular? > > Anyone have more experience with it? > > Randy > > > > > > > > Kyle, > > > > I like the monokote idea. A couple of thoughts to > > expand on this. > > > > Monokote has a very glossy finish. The resin may > > still stick to the Monokote. Use mold release wax > on > > the Monokote followed with PVA mold release. > Spray > > multiple LIGHT coats of PVA onto the Monokote. > PVA > > has a tendency to bead up when sprayed over the > wax. > > Multiple light coats help eliminate the beading. > When > > finished, the the piece will pop off the Monokote > much > > easier. > > > > Acetone removes the pigment/adhesive used on > Monokote. > > Unless the surface beneath the Monokote is > reactive > > to acetone, put some acetone on a rag and wipe the > > surface clean. Obviously, use proper ventilation > and > > protective safety gear. > > > > BTW, PVA is PolyVinyl Alcohol. Any good > fiberglass > > supplier will stock this item. > > > > Dave > > > > > > --- Kyle Boatright > wrote: > > > >> > >> > >> You could try tapeing thin cardboard between the > >> canopy and fuselage. My > >> cardboard of preference (from making the > empennage > >> fairing years ago) comes > >> from Diet Coke 12-pack cartons... > >> > >> Several pieces of cardboard, a little packing > tape, > >> and volia, female > >> mold... > >> > >> Alternately, you could get yourself some Monokote > or > >> similar shrink film, > >> cut it to rough shape, tape the ends to the plexi > >> and fuselage, and shrink > >> the stuff into the shape you want. Might even > work. > >> (Note- put a layer of > >> packing tape between the monokote and your > canopy, > >> or risk color > >> transfer)... > >> > >> KB > > > > > > browse > Subscriptions page, > FAQ, > > Admin. > > > > > > > > > > > ________________________________________________________________________________
Subject: Gaps again - HS rear-spar-to-skin
Date: Feb 01, 2006
From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
I clecoed on the rear spar of the HS and noticed a bit of gap between the skin and the spar, even at the clecos, with clecos in every other hole. I figured I had countersunk enough and so took it apart and went a bit deeper. (I tested the cage on a peice of scrap again and it seemed very good, with a dimple on another scrap peice the same thickness as the skin fitting nicely.) Clecod it back together and in most places there is really no gap, but not quite everywhere. I was careful to countersink the full depth on each hole - so that no more metal was coming off. I test drove a couple rivets at the places with the gaps and found that it remained. It's enough to insert a peice of paper about 1/8", but no more. The thing is, I'm afraid to really go any deeper with the cage because it was very near the point where the hole would be enlarged. I took a look at my QB wings and noticed that the TE skin has no gap - except near the edges, where I *can* get a piece of paper in there a bit. Again, the paper goes in about 1/8" - maybe halfway to where the rivet is. I think the irregularities (some areas tigher than others) are due more to small variations in alignment than differences in the countersinking. Is this normal, or Ok? If you've built a HS lately, did you notice this? Am I being a bit anal or am I right to wonder about this? Should I risk countersinking a bit deeper, on the areas with a bit of gap? Paul 9A QB #1176 P.S. I *did* end up completely drilling out and bending one of those problem ribs of earlier in the week. I'm much happier with the ________________________________________________________________________________
Date: Feb 01, 2006
You should not be using a counter-sink on the rear spar. These parts are thin enough to dimple. Don RV7 Wiring Instrument Panel -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Folbrecht, Paul Sent: Wednesday, February 01, 2006 5:33 PM Subject: RV-List: Gaps again - HS rear-spar-to-skin I clecoed on the rear spar of the HS and noticed a bit of gap between the skin and the spar, even at the clecos, with clecos in every other hole. I figured I had countersunk enough and so took it apart and went a bit deeper. (I tested the cage on a peice of scrap again and it seemed very good, with a dimple on another scrap peice the same thickness as the skin fitting nicely.) Clecod it back together and in most places there is really no gap, but not quite everywhere. I was careful to countersink the full depth on each hole - so that no more metal was coming off. I test drove a couple rivets at the places with the gaps and found that it remained. It's enough to insert a peice of paper about 1/8", but no more. The thing is, I'm afraid to really go any deeper with the cage because it was very near the point where the hole would be enlarged. I took a look at my QB wings and noticed that the TE skin has no gap - except near the edges, where I *can* get a piece of paper in there a bit. Again, the paper goes in about 1/8" - maybe halfway to where the rivet is. I think the irregularities (some areas tigher than others) are due more to small variations in alignment than differences in the countersinking. Is this normal, or Ok? If you've built a HS lately, did you notice this? Am I being a bit anal or am I right to wonder about this? Should I risk countersinking a bit deeper, on the areas with a bit of gap? Paul 9A QB #1176 P.S. I *did* end up completely drilling out and bending one of those problem ribs of earlier in the week. I'm much happier with the ________________________________________________________________________________
Date: Feb 01, 2006
Subject: cablecraft good customer service
I just received a shipment of 3 control cables from Cablecraft today. When I was handed the box - sort of a big pizza box- it was clear that there was a big crease across the middle of it. UPS had bent it, I guess. Anyway, one of the cables had the threaded rod at the end badly bent. I called Cablecraft and they immediately offered to rush me a replacement even though it wasn't their fault. The stuff is shipped F.O.B. Cablecraft, so I should be the one going after UPS. This is a $225 cable. They don't even want me to ship the damaged cable back to them! I'm impressed. -- Tom Sargent, RV-6A, engine ________________________________________________________________________________
Subject: IO390
Date: Feb 01, 2006
From: "Dan Beadle" <Dan.Beadle(at)hq.InclineSoftworks.com>
I am thinking about the IO390 for my RV8. Did you have any trouble adapting the IO390 to the RV8. Did the cowling fit as-is? What did you do for exhaust? What about ignition? I am thinking FADEC would be cool, but don't know the issues here. What real performance do you see in cruise with the ACI prop? (and conditions) Finally, what about insurance? Technically, the 390 is more HP than Vans recommends. Did your insurance carrier care? I live in Sierra Nevadas - so climb is always welcome. (We expect to have portable O2 in the plane most of the time). Thanks Dan Beadle ________________________________________________________________________________
Date: Feb 02, 2006
Subject: South Lakeland Home Owners Fly-in
X-49 South Lakeland Airport will have its annual Super Bowl Saturday Home Owners Flyin this Saturday. All are welcome to fly or drive in. The activity will be centered around the FBO building on the South end of the airport. B-fast and lunch will be avalible from the local shriners and all proceeds go to a great cause. Just a good time seeing old friends and making new ones..... Runway 14/32 aprox 4000 feet grass. X-49 Sponsored by EAA Chapter 149UL Sal Capra Lakeland, FL My Home Page ________________________________________________________________________________
Date: Feb 02, 2006
I don't know the thickness, but it's pretty thick, and the manual does specify countersinking... -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DonVS Sent: Wednesday, February 01, 2006 7:56 PM Subject: RE: RV-List: Gaps again - HS rear-spar-to-skin You should not be using a counter-sink on the rear spar. These parts are thin enough to dimple. Don RV7 Wiring Instrument Panel -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Folbrecht, Paul Sent: Wednesday, February 01, 2006 5:33 PM Subject: RV-List: Gaps again - HS rear-spar-to-skin I clecoed on the rear spar of the HS and noticed a bit of gap between the skin and the spar, even at the clecos, with clecos in every other hole. I figured I had countersunk enough and so took it apart and went a bit deeper. (I tested the cage on a peice of scrap again and it seemed very good, with a dimple on another scrap peice the same thickness as the skin fitting nicely.) Clecod it back together and in most places there is really no gap, but not quite everywhere. I was careful to countersink the full depth on each hole - so that no more metal was coming off. I test drove a couple rivets at the places with the gaps and found that it remained. It's enough to insert a peice of paper about 1/8", but no more. The thing is, I'm afraid to really go any deeper with the cage because it was very near the point where the hole would be enlarged. I took a look at my QB wings and noticed that the TE skin has no gap - except near the edges, where I *can* get a piece of paper in there a bit. Again, the paper goes in about 1/8" - maybe halfway to where the rivet is. I think the irregularities (some areas tigher than others) are due more to small variations in alignment than differences in the countersinking. Is this normal, or Ok? If you've built a HS lately, did you notice this? Am I being a bit anal or am I right to wonder about this? Should I risk countersinking a bit deeper, on the areas with a bit of gap? Paul 9A QB #1176 P.S. I *did* end up completely drilling out and bending one of those problem ribs of earlier in the week. I'm much happier with the ________________________________________________________________________________
Date: Feb 02, 2006
OK. Sorry about that . On thye 7 the manual says dimple. -------------- Original message ---------------------- From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com> > > > I don't know the thickness, but it's pretty thick, and the manual does > specify countersinking... > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DonVS > Sent: Wednesday, February 01, 2006 7:56 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Gaps again - HS rear-spar-to-skin > > > You should not be using a counter-sink on the rear spar. These parts > are > thin enough to dimple. > > Don > RV7 > Wiring Instrument Panel > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Folbrecht, Paul > Sent: Wednesday, February 01, 2006 5:33 PM > To: rv-list(at)matronics.com > Subject: RV-List: Gaps again - HS rear-spar-to-skin > > > > > I clecoed on the rear spar of the HS and noticed a bit of gap between > the > skin and the spar, even at the clecos, with clecos in every other hole. > I > figured I had countersunk enough and so took it apart and went a bit > deeper. > (I tested the cage on a peice of scrap again and it seemed very good, > with a > dimple on another scrap peice the same thickness as the skin fitting > nicely.) > > Clecod it back together and in most places there is really no gap, but > not > quite everywhere. I was careful to countersink the full depth on each > hole - so that no more metal was coming off. I test drove a couple > rivets > at the places with the gaps and found that it remained. It's enough to > insert a peice of paper about 1/8", but no more. > > The thing is, I'm afraid to really go any deeper with the cage because > it > was very near the point where the hole would be enlarged. > > I took a look at my QB wings and noticed that the TE skin has no gap - > except near the edges, where I *can* get a piece of paper in there a > bit. > > Again, the paper goes in about 1/8" - maybe halfway to where the rivet > is. > I think the irregularities (some areas tigher than others) are due more > to > small variations in alignment than differences in the countersinking. > > Is this normal, or Ok? If you've built a HS lately, did you notice > this? > Am I being a bit anal or am I right to wonder about this? Should I risk > countersinking a bit deeper, on the areas with a bit of gap? > > Paul > 9A QB #1176 > > P.S. I *did* end up completely drilling out and bending one of those > problem > ribs of earlier in the week. I'm much happier with the > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 02, 2006
One suggestion for Monokote: Top Flight makes clear Monokote that doesn't have any pigment in the adhesive (at least they did 20 years ago, when I was really into models). This way, if any adhesive gets onto the plexi, at least it's clear and won't be very visible... I know for a fact that Aerovironment uses Monokote or similar coverings to cover some of their molds that they shape from foam, so this concept should work just fine. Skylor RV-8QB Under Construction --- Dave Nellis wrote: > > > Randy, > > Monokote is a plastic film used to cover model > aircraft. It is heatshrinkable and has a heat > activated adhesive which is also the pigment. > > First off, DO NOT adhere Monokote to plexi!!!!! I > have just started my project and I am not totally > familiar with the canopy area. After reading the > posts regarding this, I was thinking that their was > an > area on the fuselage at the canopy that was used as > a > mold. I would only attach Monokote to bare metal or > to a surface that is NOT reactive to acetone or dope > thinner. Do not under any circumstances use acetone > or dope thinner on plexi. > > If Monokote is the way you want to go, consider the > following. Buy a Monokote iron from a hobby shop, > about $20. Follow the directions therein. When > attaching, only seal the edges down. When shrinking > the rest, do not press down on the iron. Let the > weight of the iron do the work. Shrink the Monokote > till all wrinkles are gone. Make your layups with > suitable mold release products. > > Upon removal, you will find some of the Monokote > will > have adhered to sealed edge areas and quite possibly > the center as well. Use acetone or dope thinner in > a > clean rag with proper ventilation and safety > equipment > to remove the adhered Monokote. > > You will find the inside of your lamination to be > glass smooth which I would lightly sand to break the > glaze. Use > > your favorite adhesive to attach the skirt to > the canopy. > > I have used Monokote to cover model aircraft for 30 > years and for mold making because it makes a smooth > surface without a great deal of work. > > One last thought, if you put Monokote on the plexi, > only put it on the area that would be under the > skirt. > To remove it from the plexi, use a small orbital > sander with a fine grit paper. I am guessing that > you > would need to rough this surface up anyways. I > re-iterate, do not use solvents on the plexi. > > Dave > > > --- Randy Lervold wrote: > > > > > > > Guys, the Monokote idea might just work well, and > I > > have a couple of rolls > > laying around. What is Monokote actually made of, > > and is there a chance that > > epoxy resin won't stick to it? Also, how well can > > you control what/where it > > adheres? And lastly, how tough is it to get off, > the > > plexi in particular? > > > > Anyone have more experience with it? > > > > Randy > > > > > > > > > > > > > > Kyle, > > > > > > I like the monokote idea. A couple of thoughts > to > > > expand on this. > > > > > > Monokote has a very glossy finish. The resin > may > > > still stick to the Monokote. Use mold release > wax > > on > > > the Monokote followed with PVA mold release. > > Spray > > > multiple LIGHT coats of PVA onto the Monokote. > > PVA > > > has a tendency to bead up when sprayed over the > > wax. > > > Multiple light coats help eliminate the beading. > > > When > > > finished, the the piece will pop off the > Monokote > > much > > > easier. > > > > > > Acetone removes the pigment/adhesive used on > > Monokote. > > > Unless the surface beneath the Monokote is > > reactive > > > to acetone, put some acetone on a rag and wipe > the > > > surface clean. Obviously, use proper > ventilation > > and > > > protective safety gear. > > > > > > BTW, PVA is PolyVinyl Alcohol. Any good > > fiberglass > > > supplier will stock this item. > > > > > > Dave > > > > > > > > > --- Kyle Boatright > > wrote: > > > > > >> > > >> > > >> You could try tapeing thin cardboard between > the > > >> canopy and fuselage. My > > >> cardboard of preference (from making the > > empennage > > >> fairing years ago) comes > > >> from Diet Coke 12-pack cartons... > > >> > > >> Several pieces of cardboard, a little packing > > tape, > > >> and volia, female > > >> mold... > > >> > > >> Alternately, you could get yourself some > Monokote > > or > > >> similar shrink film, > > >> cut it to rough shape, tape the ends to the > plexi > > >> and fuselage, and shrink > > >> the stuff into the shape you want. Might even > > work. > > >> (Note- put a layer of > > >> packing tape between the monokote and your > > canopy, > > >> or risk color > > >> transfer)... > > >> > > >> KB > > > > > > > > > > > > browse > > Subscriptions page, > > FAQ, > > > > Admin. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ,
January 22, 2006 - February 02, 2006
RV-Archive.digest.vol-rq
