RV-Archive.digest.vol-rr
February 02, 2006 - February 22, 2006
      === message truncated ==
Date: Feb 02, 2006
Subject: Re: CYL high temp
Kelly, Actually, John Deakin suggests that 420F should be the upper limit of CHT's, with the engine monitor alarm set to 400F. 380F should be the cruise target maximium. See the text that I attached below... Skylor Piper RV-8QB Under Construction --- Kelly McMullen wrote: > > > I'm not sure the basis of your temp recommendations. > The best > recommendations I know come from Advanced Pilot > Seminars, where they > have more data to back their recommendations than > anyone. Oil okay. > CHT, there is no minimum temp for max life, that is > an OWT. > Maximum for any flight phase, including climb should > be 400F.\ > EGT, for normally aspirated, there is no maximum, > especially none for > maximum life, but much over 1500 is unlikely. > Turbos, totally different, > they do have TIT maximums. What matters is all > cylinders peaking as > close to each other, in terms of fuel flow, not > temp. You are only > looking for the peak on each cylinder, not an > absolute temperature. > You are totally incorrect about why #3 on an O-360 > or IO-360 runs > hottest. Has very little to do with mixture, and if > it were leanest, it > would only be hottest on the rich side of peak, > where you don't want to > be anyway. #3 runs hottest because of the way > Lycoming designed the head > casting to have NO cooling fins on the back side of > #3 (and front #2). > If the baffling is tight against the cylinder head, > it will run 30-50 > degrees hotter than if you leave a 1/8" to 1/4" gap > for air to get through. > KM > A&P > Grads, Some of you may be getting a little too concerned over CHT "limits," and while that won't harm your engine, it may not allow you to get all the power you want. A very well-informed person wrote recently: Oversimplified, TCM set a redline around 460 degrees and knowledgeable folks at Ada Oklahoma, using highly instrumented engines have determined that 380 is a safer maximum. Not quite true. We're running into this a lot, which means we may have been "too successful." 460F is a common TCM redline for CHT, and 500F is common for Lycomings. We have LOTS of data that suggest engines that go to those temperatures for a very short period of time suffer little or no harm from that specific event in the short term, IF PROMPTLY CONTROLLED and brought right back down. We also have data that suggests that any engine that goes beyond those CHTs for even a short period of time WILL suffer damage, often catastrophic damage. George Braly has put hundreds of hours of detonation on the test-stand engines without hurting them, some of it very, very ugly, without damage. The secret to that is inducing the detonation, recording the data, then getting OUT of the detonation before the CHTs exceed the factory limits. Maybe this is what the factories had in mind?? Engines operated often and/or for long periods just barely within those factory limits probably suffer long-term damage that greatly reduces TBO and reliability. We think those limits are much too high for those reasons. TCM and Lycoming obviously agree, for they have verbiage in many of the manuals about "Maximum recommended CHT," and similar, but the numbers vary, sometimes even within the same manual! Where to set "reasonable" limits? Where to run? I have personally seen two engines that will do what we call a "thermal runaway" when the CHT is deliberately run up to the high 420s. My old IO-520 was like this, and I demonstrated it many, many times. Set the power and mixture to run 425F, no problem. Change the mixture slightly (lean it more if LOP, enrich it if ROP), and the CHT comes right down. 427, the same. Just above that, 428, 429, 430 or so, and the CHT would not stabilize there, it would keep on ticking up, degree by degree, very slowly increasing in rate of increase. Tweak the mixture as for the slightly lower CHTs, and there is no effect, it just keeps on rising, very slowly at first, then faster. All the data we have suggests that will continue right on past the factory redline, and well into the 500+ range, with damage. It takes a LARGE change in mixture or MP to stop this "runaway." We think that's from the usual uneven cooling around the cylinders. The hottest parts of the cylinder weaken a bit somewhere north of 420F, and it goes very slightly out of round. The piston remains round, and that starts a "scuffing" on the narrow part of the cylinder, increasing the friction, and the heat, becoming a self-feeding event. We've not seen that happen when the CHT is controlled below 420, except when there is a clear cut case of preignition. This is the basis of the GAMI/TAT/APS "limit" of 420F on all these engines. Some may run happily at higher CHTs, and heck, some engines we don't know about may not even do the runaway anywhere near 420F! But 420F makes a pretty decent upper limit, above which we strongly suggest the pilots DO SOMETHING RIGHT NOW TO GET IT BACK DOWN. We take that a step further, and say that if you never want to run above 420F, then it's probably a good idea to set the engine monitor to alarm at 400F, giving lots of time to spot it, figure it out, then take action. Now, if you try and run 399 or a bit less, you'll have constant nuisance warnings from the 400F alarm, and you'll be come so accustomed to it, you'll sooner or later stop paying attention to it, and you may not even hear it when it blows for real. So finally, the crux of the matter, we say that when you're controlling the mixture for cruise, use 380F as a TARGET (370 is fine, 399 is fine). It also happens to be a CHT where we're comfortable with the ICP (Internal Combustion Pressure) and thetaPP (the angle at which peak pressure occurs) in most of these engines. The big TIO-540, and the TSIO engines are on the hairy edge there, but it's still a decent set of numbers. Trouble is, folks take that 380, figure it's "The Limit," and start adding a buffer to it. Not our intention, we've ALREADY put the "buffers" in place! Never allow the CHT to exceed 420F. Set your monitor to alarm at 400F Use 380F as a "target" for "Go Fast Mode." Oh, and while I'm at it, feel comfortable running 1650F on your TIT (if you have a turbo) all day long, that one is very conservative already! Best... John Deakin Fly-Bye-Knight Press http://www.flybyeknightpress.com Advanced Pilot Seminars http://www.advancedpilot.com Index to all columns: http://www.avweb.com/news/columns/182146-1.html ________________________________________________________________________________
Subject: IO390
Date: Feb 02, 2006
Dan, I put one in a 7 and I used the vans 200 HP Angle valve firewall forward kit. The exhause fit great. As far as climb goes, I had mine to 22,000 feet and it was still going strong. -Ross >From: "Dan Beadle" <Dan.Beadle(at)hq.InclineSoftworks.com> >Reply-To: rv-list(at)matronics.com >To: "dick martin" , >Subject: RV-List: IO390 >Date: Wed, 1 Feb 2006 21:29:51 -0800 > > > >I am thinking about the IO390 for my RV8. > > >Did you have any trouble adapting the IO390 to the RV8. Did the cowling >fit as-is? What did you do for exhaust? What about ignition? I am >thinking FADEC would be cool, but don't know the issues here. What >real performance do you see in cruise with the ACI prop? (and >conditions) > > >Finally, what about insurance? Technically, the 390 is more HP than >Vans recommends. Did your insurance carrier care? I live in Sierra >Nevadas - so climb is always welcome. (We expect to have portable O2 in >the plane most of the time). > > >Thanks > > >Dan Beadle > > ________________________________________________________________________________
Subject: IO390
Date: Feb 02, 2006
Tell him where you got the engine Ross :) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ross S Sent: Thursday, February 02, 2006 2:06 PM Subject: RE: RV-List: IO390 Dan, I put one in a 7 and I used the vans 200 HP Angle valve firewall forward kit. The exhause fit great. As far as climb goes, I had mine to 22,000 feet and it was still going strong. -Ross >From: "Dan Beadle" <Dan.Beadle(at)hq.InclineSoftworks.com> >Reply-To: rv-list(at)matronics.com >To: "dick martin" , >Subject: RV-List: IO390 >Date: Wed, 1 Feb 2006 21:29:51 -0800 > > > >I am thinking about the IO390 for my RV8. > > >Did you have any trouble adapting the IO390 to the RV8. Did the cowling >fit as-is? What did you do for exhaust? What about ignition? I am >thinking FADEC would be cool, but don't know the issues here. What >real performance do you see in cruise with the ACI prop? (and >conditions) > > >Finally, what about insurance? Technically, the 390 is more HP than >Vans recommends. Did your insurance carrier care? I live in Sierra >Nevadas - so climb is always welcome. (We expect to have portable O2 in >the plane most of the time). > > >Thanks > > >Dan Beadle > > On the road to retirement? Check out MSN Life Events for advice on how to ________________________________________________________________________________
Date: Feb 02, 2006
Subject: Re: IO390
How does the 390 compare to the 360 regarding RPM restrictions? Jim Ayers In a message dated 02/02/2006 12:22:33 PM Pacific Standard Time, BPA(at)bpaengines.com writes: --> RV-List message posted by: "BPA" Tell him where you got the engine Ross :) ________________________________________________________________________________
Subject: IO390
Date: Feb 02, 2006
Limiting RPM restriction is the same at 2700 RPM full throttle. Check out Marc Cooks AvWeb article he wrote about the engine. Pretty good reading... -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com Sent: Thursday, February 02, 2006 3:13 PM Subject: Re: RV-List: IO390 How does the 390 compare to the 360 regarding RPM restrictions? Jim Ayers In a message dated 02/02/2006 12:22:33 PM Pacific Standard Time, BPA(at)bpaengines.com writes: --> RV-List message posted by: "BPA" Tell him where you got the engine Ross :) ________________________________________________________________________________
Subject: Re: Fiberglass canopy skirt from scratch
Date: Feb 02, 2006
Randy, My memory from RC days tells me that Monokote is made from Mylar. Another thing.........As you probably know, when you shrink it the profile will be that of a straight lines between two points. In other words, unless all points on the perimeter of the Monokote are in the same flat plane the surface will be a compound curve. The canopy skirts on an RV-3 do not appear to be a flat. Think of what Monokote looks like on an unsheeted RC wing with the recessed areas between the ribs. Dale Ensing ________________________________________________________________________________
Date: Feb 02, 2006
Subject: Re: IO390
Asked a different way. Is the 390 a counterweighted crankshaft engine? Or, as a non-counterweighted crankshaft engine, are there mid range RPM restrictions similar to the non-counterweighted crankshaft 360 engine? Jim In a message dated 02/02/2006 1:32:35 PM Pacific Standard Time, BPA(at)bpaengines.com writes: --> RV-List message posted by: "BPA" Limiting RPM restriction is the same at 2700 RPM full throttle. Check out Marc Cooks AvWeb article he wrote about the engine. Pretty good reading... ________________________________________________________________________________
Date: Feb 02, 2006
Subject: Build time, include helpers ?
When I get assistant, bucking rivets ect, on the plane . Do I include their time also in the build time ? Thanks, Dan -8 ________________________________________________________________________________
Subject: ADIZ, one more time with feeling
Date: Feb 03, 2006
One more time. As tired as we are of the issue, we still need to make our voice heard. Please consider one final submittal of you warmest thoughts on the Washington ADIZ, which, after extension of the comment period, is about to close. http://www.aopa.org/adizalert/ Politicians respond to only two things; money and voters. Please don't send them any more money but let them know we vote. Chuck Jensen ________________________________________________________________________________
Subject: IO390
Date: Feb 03, 2006
Yes, the IO-390 is counterweighted. Sorry I missed real question. Allen BPE, Inc. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com Sent: Thursday, February 02, 2006 10:28 PM Subject: Re: RV-List: IO390 Asked a different way. Is the 390 a counterweighted crankshaft engine? Or, as a non-counterweighted crankshaft engine, are there mid range RPM restrictions similar to the non-counterweighted crankshaft 360 engine? Jim In a message dated 02/02/2006 1:32:35 PM Pacific Standard Time, BPA(at)bpaengines.com writes: --> RV-List message posted by: "BPA" Limiting RPM restriction is the same at 2700 RPM full throttle. Check out Marc Cooks AvWeb article he wrote about the engine. Pretty good reading... ________________________________________________________________________________
Subject: Re: Build time, include helpers ?
Date: Feb 03, 2006
Dan, I don't know of any official requirement to record build time at all. A "builder's log" is usually used as proof that an individual is the actual builder and could take just about any form you like. As to recording assistant time I would think it's your choice. Dick Sipp ----- Original Message ----- From: "Dan" <dan(at)rdan.com> Sent: Friday, February 03, 2006 12:39 AM Subject: RV-List: Build time, include helpers ? > > When I get assistant, bucking rivets ect, on the plane . > Do I include their time also in the build time ? > > Thanks, > Dan > -8 > > > ________________________________________________________________________________
Date: Feb 03, 2006
From: Christopher Stone <rv8iator(at)earthlink.net>
Randy... Monokote and all the other model coverings are polyester film or woven polyester fiber. Polyester resin will stick to the film but will not bond to it. Definitely use mold release. There are also clear films available that are used as commercial masking film. Some of these I believe are Mylar. Hope this helps... Chris Stone Newberg, OR 2x RV8 -----Original Message----- >From: Randy Lervold <randy(at)romeolima.com> >Sent: Feb 1, 2006 6:37 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Fiberglass canopy skirt from scratch > > >Guys, the Monokote idea might just work well, and I have a couple of rolls >laying around. What is Monokote actually made of, and is there a chance that >epoxy resin won't stick to it? Also, how well can you control what/where it >adheres? And lastly, how tough is it to get off, the plexi in particular? > >Anyone have more experience with it? > >Randy > > >> >> Kyle, >> >> I like the monokote idea. A couple of thoughts to >> expand on this. >> >> Monokote has a very glossy finish. The resin may >> still stick to the Monokote. Use mold release wax on >> the Monokote followed with PVA mold release. Spray >> multiple LIGHT coats of PVA onto the Monokote. PVA >> has a tendency to bead up when sprayed over the wax. >> Multiple light coats help eliminate the beading. When >> finished, the the piece will pop off the Monokote much >> easier. >> >> Acetone removes the pigment/adhesive used on Monokote. >> Unless the surface beneath the Monokote is reactive >> to acetone, put some acetone on a rag and wipe the >> surface clean. Obviously, use proper ventilation and >> protective safety gear. >> >> BTW, PVA is PolyVinyl Alcohol. Any good fiberglass >> supplier will stock this item. >> >> Dave >> >> >> --- Kyle Boatright wrote: >> >>> >>> >>> You could try tapeing thin cardboard between the >>> canopy and fuselage. My >>> cardboard of preference (from making the empennage >>> fairing years ago) comes >>> from Diet Coke 12-pack cartons... >>> >>> Several pieces of cardboard, a little packing tape, >>> and volia, female >>> mold... >>> >>> Alternately, you could get yourself some Monokote or >>> similar shrink film, >>> cut it to rough shape, tape the ends to the plexi >>> and fuselage, and shrink >>> the stuff into the shape you want. Might even work. >>> (Note- put a layer of >>> packing tape between the monokote and your canopy, >>> or risk color >>> transfer)... >>> >>> KB > > > > > > > ________________________________________________________________________________
Date: Feb 03, 2006
From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
FWIW, I haven't been. So far, everything I've had help with I *could* do myself, though it'd be considerably more ackward in some cases (bucking the HS middle nose ribs, for example). Paul -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Sent: Thursday, February 02, 2006 11:40 PM Subject: RV-List: Build time, include helpers ? When I get assistant, bucking rivets ect, on the plane . Do I include their time also in the build time ? Thanks, Dan -8 ________________________________________________________________________________
From: "Dan Beadle" <dan.beadle(at)inclinesoftworks.com>
Date: Feb 03, 2006
SO far, I have been able to buck everything myself. There are only a couple places where I really needed an assistant - the biggest being supporting the skins during dimpling (and, I know: I could have rearranged my bench to support them for single person operation). As for me, when I do have the help of an assistant, I include the time. I figure we go 50% faster with two people but make 80% fewer mistakes. Bottom line, I am about done with the empennage at 160 hours (including helpers). Help accounted for about 30-40 hours of that time. Dan -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Folbrecht, Paul Sent: Friday, February 03, 2006 7:11 AM Subject: RE: RV-List: Build time, include helpers ? FWIW, I haven't been. So far, everything I've had help with I *could* do myself, though it'd be considerably more ackward in some cases (bucking the HS middle nose ribs, for example). Paul -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Sent: Thursday, February 02, 2006 11:40 PM Subject: RV-List: Build time, include helpers ? When I get assistant, bucking rivets ect, on the plane . Do I include their time also in the build time ? Thanks, Dan -8 ________________________________________________________________________________
Subject: Re: Build time-photographic
Date: Feb 03, 2006
My build history is simply photographic. Many key photos have date attached via Post-It note or chalk board with build number included. Some may show myself or rivet-bucking daughter holding or using appropriate tool. All unique or special features and building solutions are likewise so documented. Jack ________________________________________________________________________________
Subject: Wings on their way!
Date: Feb 03, 2006
Boy, am I excited! The wings will shipped the first part of next week. How many warm bodies do I need to help lug the boxes into the garage (hangar)? -------- Smittys RV-9A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=9361#9361 ________________________________________________________________________________
Date: Feb 03, 2006
> Monokote and all the other model coverings are polyester film or woven > polyester fiber. Polyester resin will stick to the film but will not bond > to it. Definitely use mold release. There are also clear films available > that are used as commercial masking film. Some of these I believe are > Mylar. > > Hope this helps... > > Chris Stone > Newberg, OR > 2x RV8 Chris (or anyone), will epoxy stick to it? I'll be laying up with West Systems. Thanks, Randy ________________________________________________________________________________
Date: Feb 03, 2006
Chris, Just a note for people who might be contemplating using polyester resin for their windshield and canopy fairings... there are many entries in the archives warning of damage to the canopy plastic when in contact with even tiny amounts of the polyester resin components, or even the fumes. It would seem to be much safer to use epoxy based systems in these areas. Hawkeye Hughes Polson MT Skyote, RV-3 ----- Original Message ----- From: "Christopher Stone" <rv8iator(at)earthlink.net> Sent: Friday, February 03, 2006 8:05 AM Subject: Re: RV-List: Fiberglass canopy skirt from scratch > > Randy... > > Monokote and all the other model coverings are polyester film or woven > polyester fiber. Polyester resin will stick to the film but will not bond > to it. Definitely use mold release. There are also clear films available > that are used as commercial masking film. Some of these I believe are > Mylar. > > Hope this helps... > > Chris Stone > Newberg, OR > 2x RV8 > > > -----Original Message----- >>From: Randy Lervold <randy(at)romeolima.com> >>Sent: Feb 1, 2006 6:37 AM >>To: rv-list(at)matronics.com >>Subject: Re: RV-List: Fiberglass canopy skirt from scratch >> >> >>Guys, the Monokote idea might just work well, and I have a couple of rolls >>laying around. What is Monokote actually made of, and is there a chance >>that >>epoxy resin won't stick to it? Also, how well can you control what/where >>it >>adheres? And lastly, how tough is it to get off, the plexi in particular? >> >>Anyone have more experience with it? >> >>Randy >> >> >> >>> >>> Kyle, >>> >>> I like the monokote idea. A couple of thoughts to >>> expand on this. >>> >>> Monokote has a very glossy finish. The resin may >>> still stick to the Monokote. Use mold release wax on >>> the Monokote followed with PVA mold release. Spray >>> multiple LIGHT coats of PVA onto the Monokote. PVA >>> has a tendency to bead up when sprayed over the wax. >>> Multiple light coats help eliminate the beading. When >>> finished, the the piece will pop off the Monokote much >>> easier. >>> >>> Acetone removes the pigment/adhesive used on Monokote. >>> Unless the surface beneath the Monokote is reactive >>> to acetone, put some acetone on a rag and wipe the >>> surface clean. Obviously, use proper ventilation and >>> protective safety gear. >>> >>> BTW, PVA is PolyVinyl Alcohol. Any good fiberglass >>> supplier will stock this item. >>> >>> Dave >>> >>> >>> --- Kyle Boatright wrote: >>> >>>> >>>> >>>> You could try tapeing thin cardboard between the >>>> canopy and fuselage. My >>>> cardboard of preference (from making the empennage >>>> fairing years ago) comes >>>> from Diet Coke 12-pack cartons... >>>> >>>> Several pieces of cardboard, a little packing tape, >>>> and volia, female >>>> mold... >>>> >>>> Alternately, you could get yourself some Monokote or >>>> similar shrink film, >>>> cut it to rough shape, tape the ends to the plexi >>>> and fuselage, and shrink >>>> the stuff into the shape you want. Might even work. >>>> (Note- put a layer of >>>> packing tape between the monokote and your canopy, >>>> or risk color >>>> transfer)... >>>> >>>> KB >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Fiberglass canopy skirt from scratch
Date: Feb 03, 2006
Polyester resins typical have styrene as a solvent carrier. Styrene will melt plexiglass. Epoxies do not have styrene content. Chuck Jensen -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of REHughes Sent: Friday, February 03, 2006 1:49 PM Subject: Re: RV-List: Fiberglass canopy skirt from scratch Chris, Just a note for people who might be contemplating using polyester resin for their windshield and canopy fairings... there are many entries in the archives warning of damage to the canopy plastic when in contact with even tiny amounts of the polyester resin components, or even the fumes. It would seem to be much safer to use epoxy based systems in these areas. Hawkeye Hughes Polson MT Skyote, RV-3 ----- Original Message ----- From: "Christopher Stone" <rv8iator(at)earthlink.net> Sent: Friday, February 03, 2006 8:05 AM Subject: Re: RV-List: Fiberglass canopy skirt from scratch > > Randy... > > Monokote and all the other model coverings are polyester film or woven > polyester fiber. Polyester resin will stick to the film but will not bond > to it. Definitely use mold release. There are also clear films available > that are used as commercial masking film. Some of these I believe are > Mylar. > > Hope this helps... > > Chris Stone > Newberg, OR > 2x RV8 > > > -----Original Message----- >>From: Randy Lervold <randy(at)romeolima.com> >>Sent: Feb 1, 2006 6:37 AM >>To: rv-list(at)matronics.com >>Subject: Re: RV-List: Fiberglass canopy skirt from scratch >> >> >>Guys, the Monokote idea might just work well, and I have a couple of rolls >>laying around. What is Monokote actually made of, and is there a chance >>that >>epoxy resin won't stick to it? Also, how well can you control what/where >>it >>adheres? And lastly, how tough is it to get off, the plexi in particular? >> >>Anyone have more experience with it? >> >>Randy >> >> >> >>> >>> Kyle, >>> >>> I like the monokote idea. A couple of thoughts to >>> expand on this. >>> >>> Monokote has a very glossy finish. The resin may >>> still stick to the Monokote. Use mold release wax on >>> the Monokote followed with PVA mold release. Spray >>> multiple LIGHT coats of PVA onto the Monokote. PVA >>> has a tendency to bead up when sprayed over the wax. >>> Multiple light coats help eliminate the beading. When >>> finished, the the piece will pop off the Monokote much >>> easier. >>> >>> Acetone removes the pigment/adhesive used on Monokote. >>> Unless the surface beneath the Monokote is reactive >>> to acetone, put some acetone on a rag and wipe the >>> surface clean. Obviously, use proper ventilation and >>> protective safety gear. >>> >>> BTW, PVA is PolyVinyl Alcohol. Any good fiberglass >>> supplier will stock this item. >>> >>> Dave >>> >>> >>> --- Kyle Boatright wrote: >>> >>>> >>>> >>>> You could try tapeing thin cardboard between the >>>> canopy and fuselage. My >>>> cardboard of preference (from making the empennage >>>> fairing years ago) comes >>>> from Diet Coke 12-pack cartons... >>>> >>>> Several pieces of cardboard, a little packing tape, >>>> and volia, female >>>> mold... >>>> >>>> Alternately, you could get yourself some Monokote or >>>> similar shrink film, >>>> cut it to rough shape, tape the ends to the plexi >>>> and fuselage, and shrink >>>> the stuff into the shape you want. Might even work. >>>> (Note- put a layer of >>>> packing tape between the monokote and your canopy, >>>> or risk color >>>> transfer)... >>>> >>>> KB >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Feb 03, 2006
Subject: Survival Kit
Can anyone refer me to the guys who make the aviation friendly survival kits I've seen at Oshkosh? I seem to remember a great website that has many light weight options. Thanks. Paul Besing ________________________________________________________________________________
Date: Feb 03, 2006
Subject: Carb heat
Hello: Would like to know, how to improve or what is necessary to do, so that the Carb Heat in my rv6a, will work? It does not show any drop on RPM, nor even after flying for 30 minutes... I know when landing, is very hot inside. I have not cover the gaps, that exist, on each side of the Hose tube's base, that is the small, square base, that one rivet to the top of the Air box.. this small base is not sealed all around. Is hard to explain, but is the unit that comes from Van's. I want to see at least 30 rpms drop... when applied heat.... Same as in my old Cherokee 140, same engine I have now 0320 150HP Thanks, Bert do not archive ________________________________________________________________________________
Subject: Re: Survival Kit
Date: Feb 04, 2006
www.aeromedix.com has some nice survival kits. I'm not sure that these are the kits you have seem at OSH, but they are intended for use in AC > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Carb heat
Date: Feb 03, 2006
Hi Bert: Try installing a new carbheat muff. I have one that I got from Wicks, part number EC100-020, installed on my 6A. I am close to my first test flights, but those who have installed this muff report improved carbheat perfomance. It is very easy to install. Fits very well on the forward crossover pipe. Hope this helps Regards, Jeff Orear RV6A N782P (reserved) Getting very close Peshtigo, WI ----- Original Message ----- From: "Bert Murillo" <bertrv6(at)gmail.com> Sent: Friday, February 03, 2006 5:21 PM Subject: RV-List: Carb heat > > Hello: > > Would like to know, how to improve or what is necessary to do, so that > the Carb Heat in my rv6a, will work? > > It does not show any drop on RPM, nor even after flying for 30 minutes... > I know when landing, is very hot inside. > > I have not cover the gaps, that exist, on each side of the Hose tube's > base, > that is the small, square base, that one rivet to the top of the Air > box.. > this small > base is not sealed all around. Is hard to explain, but is the unit that > comes from > Van's. > > I want to see at least 30 rpms drop... when applied heat.... Same as in > my > old > Cherokee 140, same engine I have now 0320 150HP > > > Thanks, > > Bert > > do not archive > > > ________________________________________________________________________________
Date: Feb 03, 2006
Here is something else. Polyester hardens and appears to cure, but it never fully cures. It is always chemically active. With age, polyester will change shape as it cures. Heat will accelerate this curing and shape changing. I have used polyester in model aircraft cowls and have noticed flared edges and once flat surfaces are now wavy. I now only use epoxy for any layup. Dave Nellis --- REHughes wrote: > > > Chris, > Just a note for people who might be contemplating > using polyester resin for > their windshield and canopy fairings... there are > many entries in the > archives warning of damage to the canopy plastic > when in contact with even > tiny amounts of the polyester resin components, or > even the fumes. It would > seem to be much safer to use epoxy based systems in > these areas. > > Hawkeye Hughes > Polson MT Skyote, RV-3 > > > ----- Original Message ----- > From: "Christopher Stone" <rv8iator(at)earthlink.net> > To: > Sent: Friday, February 03, 2006 8:05 AM > Subject: Re: RV-List: Fiberglass canopy skirt from > scratch > > > > > > > Randy... > > > > Monokote and all the other model coverings are > polyester film or woven > > polyester fiber. Polyester resin will stick to > the film but will not bond > > to it. Definitely use mold release. There are > also clear films available > > that are used as commercial masking film. Some of > these I believe are > > Mylar. > > > > Hope this helps... > > > > Chris Stone > > Newberg, OR > > 2x RV8 > > > > > > -----Original Message----- > >>From: Randy Lervold <randy(at)romeolima.com> > >>Sent: Feb 1, 2006 6:37 AM > >>To: rv-list(at)matronics.com > >>Subject: Re: RV-List: Fiberglass canopy skirt from > scratch > >> > > >> > >>Guys, the Monokote idea might just work well, and > I have a couple of rolls > >>laying around. What is Monokote actually made of, > and is there a chance > >>that > >>epoxy resin won't stick to it? Also, how well can > you control what/where > >>it > >>adheres? And lastly, how tough is it to get off, > the plexi in particular? > >> > >>Anyone have more experience with it? > >> > >>Randy > >> > >> > >> > > >>> > >>> Kyle, > >>> > >>> I like the monokote idea. A couple of thoughts > to > >>> expand on this. > >>> > >>> Monokote has a very glossy finish. The resin > may > >>> still stick to the Monokote. Use mold release > wax on > >>> the Monokote followed with PVA mold release. > Spray > >>> multiple LIGHT coats of PVA onto the Monokote. > PVA > >>> has a tendency to bead up when sprayed over the > wax. > >>> Multiple light coats help eliminate the beading. > When > >>> finished, the the piece will pop off the > Monokote much > >>> easier. > >>> > >>> Acetone removes the pigment/adhesive used on > Monokote. > >>> Unless the surface beneath the Monokote is > reactive > >>> to acetone, put some acetone on a rag and wipe > the > >>> surface clean. Obviously, use proper > ventilation and > >>> protective safety gear. > >>> > >>> BTW, PVA is PolyVinyl Alcohol. Any good > fiberglass > >>> supplier will stock this item. > >>> > >>> Dave > >>> > >>> > >>> --- Kyle Boatright > wrote: > >>> > >>>> > >>>> > >>>> You could try tapeing thin cardboard between > the > >>>> canopy and fuselage. My > >>>> cardboard of preference (from making the > empennage > >>>> fairing years ago) comes > >>>> from Diet Coke 12-pack cartons... > >>>> > >>>> Several pieces of cardboard, a little packing > tape, > >>>> and volia, female > >>>> mold... > >>>> > >>>> Alternately, you could get yourself some > Monokote or > >>>> similar shrink film, > >>>> cut it to rough shape, tape the ends to the > plexi > >>>> and fuselage, and shrink > >>>> the stuff into the shape you want. Might even > work. > >>>> (Note- put a layer of > >>>> packing tape between the monokote and your > canopy, > >>>> or risk color > >>>> transfer)... > >>>> > >>>> KB > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ, > > Admin. > === message truncated == ________________________________________________________________________________
Date: Feb 04, 2006
Phoey!!! Polyester will continue to shrink, vynalester will not, epoxy fumes can kill you. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Nellis Sent: Friday, February 03, 2006 11:52 PM Subject: Re: RV-List: Fiberglass canopy skirt from scratch Here is something else. Polyester hardens and appears to cure, but it never fully cures. It is always chemically active. With age, polyester will change shape as it cures. Heat will accelerate this curing and shape changing. I have used polyester in model aircraft cowls and have noticed flared edges and once flat surfaces are now wavy. I now only use epoxy for any layup. Dave Nellis --- REHughes wrote: > > > Chris, > Just a note for people who might be contemplating > using polyester resin for > their windshield and canopy fairings... there are > many entries in the > archives warning of damage to the canopy plastic > when in contact with even > tiny amounts of the polyester resin components, or > even the fumes. It would > seem to be much safer to use epoxy based systems in > these areas. > > Hawkeye Hughes > Polson MT Skyote, RV-3 > > > ----- Original Message ----- > From: "Christopher Stone" <rv8iator(at)earthlink.net> > To: > Sent: Friday, February 03, 2006 8:05 AM > Subject: Re: RV-List: Fiberglass canopy skirt from > scratch > > > > > > > Randy... > > > > Monokote and all the other model coverings are > polyester film or woven > > polyester fiber. Polyester resin will stick to > the film but will not bond > > to it. Definitely use mold release. There are > also clear films available > > that are used as commercial masking film. Some of > these I believe are > > Mylar. > > > > Hope this helps... > > > > Chris Stone > > Newberg, OR > > 2x RV8 > > > > > > -----Original Message----- > >>From: Randy Lervold <randy(at)romeolima.com> > >>Sent: Feb 1, 2006 6:37 AM > >>To: rv-list(at)matronics.com > >>Subject: Re: RV-List: Fiberglass canopy skirt from > scratch > >> > > >> > >>Guys, the Monokote idea might just work well, and > I have a couple of rolls > >>laying around. What is Monokote actually made of, > and is there a chance > >>that > >>epoxy resin won't stick to it? Also, how well can > you control what/where > >>it > >>adheres? And lastly, how tough is it to get off, > the plexi in particular? > >> > >>Anyone have more experience with it? > >> > >>Randy > >> > >> > >> > > >>> > >>> Kyle, > >>> > >>> I like the monokote idea. A couple of thoughts > to > >>> expand on this. > >>> > >>> Monokote has a very glossy finish. The resin > may > >>> still stick to the Monokote. Use mold release > wax on > >>> the Monokote followed with PVA mold release. > Spray > >>> multiple LIGHT coats of PVA onto the Monokote. > PVA > >>> has a tendency to bead up when sprayed over the > wax. > >>> Multiple light coats help eliminate the beading. > When > >>> finished, the the piece will pop off the > Monokote much > >>> easier. > >>> > >>> Acetone removes the pigment/adhesive used on > Monokote. > >>> Unless the surface beneath the Monokote is > reactive > >>> to acetone, put some acetone on a rag and wipe > the > >>> surface clean. Obviously, use proper > ventilation and > >>> protective safety gear. > >>> > >>> BTW, PVA is PolyVinyl Alcohol. Any good > fiberglass > >>> supplier will stock this item. > >>> > >>> Dave > >>> > >>> > >>> --- Kyle Boatright > wrote: > >>> > >>>> > >>>> > >>>> You could try tapeing thin cardboard between > the > >>>> canopy and fuselage. My > >>>> cardboard of preference (from making the > empennage > >>>> fairing years ago) comes > >>>> from Diet Coke 12-pack cartons... > >>>> > >>>> Several pieces of cardboard, a little packing > tape, > >>>> and volia, female > >>>> mold... > >>>> > >>>> Alternately, you could get yourself some > Monokote or > >>>> similar shrink film, > >>>> cut it to rough shape, tape the ends to the > plexi > >>>> and fuselage, and shrink > >>>> the stuff into the shape you want. Might even > work. > >>>> (Note- put a layer of > >>>> packing tape between the monokote and your > canopy, > >>>> or risk color > >>>> transfer)... > >>>> > >>>> KB > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ, > > Admin. > === message truncated == ________________________________________________________________________________
Date: Feb 04, 2006
It only took one warm body to unload and get mine into the garage. No big deal, just don't drop it. Bob Perkinson Hendersonville, TN. RV9 N658RP Reserved If nothing changes Nothing changes -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of smittysrv Sent: Friday, February 03, 2006 10:09 AM Subject: RV-List: Wings on their way! Boy, am I excited! The wings will shipped the first part of next week. How many warm bodies do I need to help lug the boxes into the garage (hangar)? -------- Smittys RV-9A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=9361#9361 ________________________________________________________________________________
Date: Feb 04, 2006
When a kit airplane is reviewed by the FAA for compliance to the 51 percent rule, it is not building time that qualifies it. It is the task to complete the airplane. That is why credit is given for building the ribs (for example) when only one rib is fabricated by the "builder" of the airplane. Dale Ensing RV-6A N118DE ________________________________________________________________________________
Date: Feb 04, 2006
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: Ameri-King AK-450 ELT - Remote Battery Included?
It is included, but must be changed periodically (I believe mine says every five years). If you have it in an inaccessible or hard to reach place you might want to rethink the location. Dick Tasker Tim Olson wrote: > >Can anyone tell me if the Lithium battery is included already in the >remote on the AK-450 ELT? > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Feb 04, 2006
Subject: Re. AK 450 Remote Battery
Tim: I didn't have to get a battery for the remote with my AK-450. Just the D cells. Bob Olds RV-4 , N1191X A&P , EAA Tech. Counselor Charleston,Arkansas Real Aviators Fly Taildraggers ________________________________________________________________________________
Date: Feb 04, 2006
Subject: firesleeved hoses and chafing
I am making oil and fuel hoses for my RV-6A using steel braided teflon hose. Is it OK for a firesleeved hose to touch another firesleeved hose? How about a firesleeved hose touching the engine mount or the firewall? In other words is the firesleeve by itself good enough chafing protection or should I anchor clamp the hoses down in such a way that they can' touch anything? -- Tom Sargent, RV-6A. ________________________________________________________________________________
Date: Feb 04, 2006
Subject: Sherwin williams GBP-988 question.
Okay so I have decided to prime the inside of my plane with GBP-988. I started priming the inner parts of the HS and I noticed that sometimes the GBP-988 goes on really smooth and on other surfaces goes on real rough and comes out feeling like sand paper. I am using the aerosol cans, if that matters. I am also cleaning every part with MEK but not scouring the parts with a scotch bright pad. I figure it is best to keep the alcad. 1. Does it matter that some faces of the part is smooth and some is rough? 2. How much of this stuff do I use? I usually have to spray every part twice to get all the pieces covered. I have already gone through a can just on the HS. 3. Sometimes the the primer goes on lighter grey and sometimes it goes on darker. What's up with that? 4. Am I supposed to shake the can before I spray? Thanks, David PS. I know some of you guys are sensitive about priming questions. I checked the archives couldn't find anything. Here is my white flag. No war! ________________________________________________________________________________
Subject: Seat heaters
Date: Feb 04, 2006
I just recently got some seat heating elements for my RV8 and thought others may be interested in this info. These are called Step warmfloor and are a self regulating plastic element that run on 12 volts. They make many different elements. The ones i got are 3" wide and draw 12 watts per foot. I plan to put them under a thin layer of foam at the top of my cushions. Their website is www.warmfloor.com. No fine wires to break or short out and no failure modes that i know of. I used this material to heat an entire house a few years ago and these people are great to deal with. Have not installed this in seats yet, but do not anticipate any problems. Tony RV8qb Wings ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: Sherwin williams GBP-988 question.
Date: Feb 04, 2006
----- Original Message ----- Subject: RV-List: Sherwin williams GBP-988 question. > > Okay so I have decided to prime the inside of my plane with GBP-988. I > started priming the inner parts of the HS and I noticed that sometimes the > GBP-988 goes on really smooth and on other surfaces goes on real rough and > comes out feeling like sand paper. I am using the aerosol cans, if that > matters. I am also cleaning every part with MEK but not scouring the > parts > with a scotch bright pad. I figure it is best to keep the alcad. > > 1. Does it matter that some faces of the part is smooth and some is > rough? You should apply and get a uniform smooth surface. Maybe you need practice. Do not apply heavy coats. Several light coats would be better than a heavy one. > > 2. How much of this stuff do I use? I usually have to spray every part > twice to get all the pieces covered. I have already gone through a can > just > on the HS. With proper preparation, clean by using soap and water with a scotch brite pad will not remove the alclad although it will look to be scuffed up. This primer is self etching so scotch briting is not really needed but it will not harm the alclad if you do not over scrub. Rinse and allow to dry completely. Follow with a solvent like MEK or lacquer thinner applied with clean rag and wear gloves to keep your skin oils off the metal and allow it to dry completely. PLEASE be aware that this primer requires a top coat of something to give corrosion protection. Using only the primer without a top coat is not preventing corrosion. Please see the directions on the can. If you prime your whole plane with this product, you will go through several 12 can cases. This stuff is easy to work with and can be safely used to temporarily protect parts that you remove the alclad from due to grinding or dent removal. Such a surface would normally be on the exterior and be refinished by priming and final painting at completion of the plane or assembled part. > > 3. Sometimes the the primer goes on lighter grey and sometimes it goes on > darker. What's up with that? > Be sure to see next question and answer. > 4. Am I supposed to shake the can before I spray? > You got to be kidding right? Yes, shake it. Respect recommended temperatures. I think you are pulling a fast one with this question but I answered it just in case... > > Thanks, > David > Indiana Larry, "Please use the information and opinions I express with responsibility, and at your own risk." ________________________________________________________________________________
Date: Feb 05, 2006
Subject: aileron trimming by squeezing question
Listers, Need to fix a slightly heavy right wing on a new rocket. Please correct me if I am wrong here. Seems one should squeeze the trailing edge of the light wing. Correct??? Thank you, Stewart Bergner ________________________________________________________________________________
Subject: Re: aileron trimming by squeezing question
Date: Feb 05, 2006
That's correct, Stewart. Gently squeeze the trailing edge aileron of the light wing. I simply used the pliers with the wide lips with some cloth to prevent scratching the paint. I would squeeze a small amount and then move it down the full length of the aileron doing the same. Then I repeated the process. Did it three times. I didn't want to distort the metal by trying to squeeze it down all the way in one location the first time. Did just a little bit each location before moving the plyers. I did it on my right wing (Left wing heavy) and it complete corrected the problem. I suggest to do it in stages so that it's not over done. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ----- Original Message ----- From: <RVer273sb(at)aol.com> Sent: Sunday, February 05, 2006 7:59 AM Subject: RV-List: aileron trimming by squeezing question > > Listers, > Need to fix a slightly heavy right wing on a new > rocket. Please correct me if I am wrong here. > Seems one should squeeze the trailing edge > of the light wing. Correct??? > Thank you, Stewart Bergner > > > ________________________________________________________________________________
Date: Feb 05, 2006
On 5 Feb 2006, at 07:59, RVer273sb(at)aol.com wrote: > > Listers, > Need to fix a slightly heavy right wing on a new > rocket. Please correct me if I am wrong here. > Seems one should squeeze the trailing edge > of the light wing. Correct??? > Thank you, Stewart Bergner Van's has a useful document on this subject. It should be read before you do anything, as there may be other causes for the heavy wing, and you ideally would attack the root cause, rather than just treat the symptoms: http://www.vansaircraft.com/pdf/Wing_Heavy.pdf Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Feb 05, 2006
On 17:59:14 2006-02-04 David Karlsberg wrote: > 2. How much of this stuff do I use? I usually have to spray every > part twice to get all the pieces covered. I have already gone > through a can just on the HS. I'm on my second rattle can, and i'm not finished the empennage yet. And i'm not priming the skins (other than the lines where the ribs contact them). Full coverage on ribs and non-alclad parts, though. A Sherwin-Williams rep that used to be a member of our flying club told me that the best way to apply it is to put on two or three very light coats to obtain the best coverage and adhesion. Almost a "dusting" of paint each time. It's worked fine so far, and I haven't had the problem that some others seem to with the paint sometimes flaking off. Prepping with Sher-Wil-Clean, which is the recommended prep for this paint. > 4. Am I supposed to shake the can before I spray? You're supposed to read the directions on the can, which say to shake it for something like two minutes after the ball comes free from the bottom of the can. Before spraying. I shake the can between sprays too, just to be sure. If you haven't been shaking it at all, that's why you're getting uneven colour and texture in your results. For what it's worth, i'll be switching to Marhyde when I finish the SW can i'm using now. The people who have used both seem to agree that Marhyde provides a tougher, more durable finish. Not so important on the inside of your airplane once it's finished, perhaps, but it might be while you're handling the parts during assembly. -Rob ________________________________________________________________________________
Date: Feb 05, 2006
> For what it's worth, i'll be switching to Marhyde when I finish the SW can > i'm using now. The people who have used both seem to agree that Marhyde > provides a tougher, more durable finish. Not so important on the inside > of > your airplane once it's finished, perhaps, but it might be while you're > handling the parts during assembly. > > -Rob FWIW, I started with a can of Marhyde (I like their products BTW) to use when I needed to spritz a part and didn't want to mix up some primer to spray. I bought a can of GBP when I needed another can on advice from others on the list and like it better. That said, I'd buy a can of Marhyde if there was some reason I couldn't get the GBP... Dave B RV6 B ________________________________________________________________________________
Date: Feb 05, 2006
Stewart, Here's a link to Van's instructions: http://vansaircraft.com/pdf/Wing_Heavy.pdf Terry Listers, Need to fix a slightly heavy right wing on a new rocket. Please correct me if I am wrong here. Seems one should squeeze the trailing edge of the light wing. Correct??? Thank you, Stewart Bergner ________________________________________________________________________________
Subject: Rudder Trim
Date: Feb 05, 2006
Richard, Thanks, that helps a lot. Did you place the trim high on the rudder, low on the rudder? (seems like I have see them on the lower section below the horz. stab) Did you place it perpendicular to the horizon or running along the trailing edge? Thanks, Robin ________________________________________________________________________________
Date: Feb 05, 2006
Subject: Garmin GMA 346 audio panel
Does anyone have a copy of the Garmin GMA 347 audio panel installation and operational manual. Also what experiences have you had with it. Any comments on the duplex telephone interface Thanks Gerald Richardson Medicine Hat, Alberta Canada -- 02/04/2006 ________________________________________________________________________________
Date: Feb 05, 2006
> For what it's worth, i'll be switching to Marhyde when I finish the SW can > i'm using now. The people who have used both seem to agree that Marhyde > provides a tougher, more durable finish. Having used both products I'd agree with this assessment. But I prefer SEM to them both in terms of both the finish it leaves and its durability. To those that apply the primer without first Scothbriting the surface, no question it does NOT adhere as well. Dip your Scotchbrite pad in your solvent of choice when scuffing and you degrease at the same time. Here's my two cents worth... http://www.romeolima.com/RV3works/Airframe/airframe.htm#Primer Randy Lervold www.rv-3.com ________________________________________________________________________________
Date: Feb 05, 2006
Subject: Re: Garmin GMA 346 audio panel
See if this link works: http://www2.mstewart.net:8080/Downloads/howtogetagarminmanual.htm >Does anyone have a copy of the Garmin GMA 347 audio panel >installation and operational manual. ________________________________________________________________________________
Date: Feb 05, 2006
Subject: Re: Rudder Trim
Robin, I can't look at it right now but, I believe that I put the wedge about midway on the rudder. The trailing edge of the wedge is flush with the trailing edge of the rudder. I think that the actual position along the trailing edge of the rudder is not important. I placed it where it looked ok to me. Regards, Richard Robin Marks wrote: > >Richard, > Thanks, that helps a lot. Did you place the trim high on the >rudder, low on the rudder? (seems like I have see them on the lower >section below the horz. stab) Did you place it perpendicular to the >horizon or running along the trailing edge? > >Thanks, >Robin > > > > > > > > > ________________________________________________________________________________
Subject: M T Props
Date: Feb 06, 2006
Can anyone tell me anything about the electric 3 blade MT props as sold by Eggenfellner ? I would like to find the Model # and any comments would be great. Thanks. Trevor Mills 80605 ________________________________________________________________________________
Date: Feb 06, 2006
Subject: Re: M T Props
> Can anyone tell me anything about the electric 3 blade MT props as sold by Eggenfellner ? > > I would like to find the Model # and any comments would be great. > > Thanks. > > Trevor Mills 80605 Hi Trevor, I've got one. Not flying yet. It's a MTV-7. I have an article with links and photos here: http://www.rv8.ch/article.php?story 050604180346524 If you search for MT Propeller on my website, you'll find a couple of other articles discussing the installation. Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Feb 06, 2006
Randy et al... The short answer is yes... But again it will not form a molecular bond only superficial adhesive bond. I would still recommend a mold release agent. cs -----Original Message----- >From: Randy Lervold <randy(at)romeolima.com> >Sent: Feb 3, 2006 8:33 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Fiberglass canopy skirt from scratch > > >> Monokote and all the other model coverings are polyester film or woven >> polyester fiber. Polyester resin will stick to the film but will not bond >> to it. Definitely use mold release. There are also clear films available >> that are used as commercial masking film. Some of these I believe are >> Mylar. >> >> Hope this helps... >> >> Chris Stone >> Newberg, OR >> 2x RV8 > >Chris (or anyone), will epoxy stick to it? I'll be laying up with West >Systems. > >Thanks, >Randy > > > > > > > ________________________________________________________________________________
Subject: RV-8 flap motor
Date: Feb 06, 2006
Hi List I am looking for the stop-to-stop travel distance of the RV-8 flap motor, does anyone have this info at their fingertips? Many thanks Kevin Shannon HR II under const ________________________________________________________________________________
Subject: Re: Wings on their way!
Date: Feb 06, 2006
These are quick-build wings? A couple of reasonably healthy individuals should suffice. If you're not unpacking the wings right away, you might do what I did and attach some casters to the long, skinny side of the box so you can easily move it around the shop till you're ready to unpack it. Re: RV-List: Wings on their way! These are quick-build wings? A couple of reasonably healthy individuals should suffice. If you're not unpacking the wings right away, you might do what I did and attach some casters to the long, skinny side of the box so you can easily move it around the shop till you're ready to unpack it. ________________________________________________________________________________
Date: Feb 06, 2006
Subject: Need some scrap plexiglass
I am finally getting around to repairing a portion of my canopy that broke when the wind blew it down. Unfortunately, I have long since gotten rid of all my scrap Plexiglas. Does anyone have any extra you could send me? I will of course pay for shipping. I need a that is mostly flat as it is going in the rear corner of a tip up RV-6. 10"x4" should do it. one piece would be best but I may have to make do with a couple of smaller pieces. Thanks, -- Dave Leonard Turbo Rotary RV-6 N4VY http://members.aol.com/_ht_a/rotaryroster/index.html http://members.aol.com/_ht_a/vp4skydoc/index.html ________________________________________________________________________________
Date: Feb 06, 2006
The MTV-7-C/183-51 72" dia. MT propeller is used, as well as the MTV-7-C/187-129 74" dia. MT propeller. MT propellers are normally specifically matched to the engine/airframe/aircraft performance specified as a complete assembly that bolts onto the engine/cowl being used. The RV standard spinner diameter is 13" with a cowl space (distance from hub mounting surface to the front of the cowl) of 1 1/2". (Van specifies 2 1/4" less the spinner flange distance and spinner to cowl distance, which is 1 1/2".) For the RV-8 Sam James Cowl, there is a 3 7/8" cowl spacing with the standard 13" dia. spinner. MT propeller provides a bolt on propeller assembly to fit this cowl without a propeller extension. There is NO aerobatic restriction on this engine/propeller combination. Please contact me off the list for specific MT propeller information. _jim(at)lessdrag.com_ (mailto:jim(at)lessdrag.com) Regards, Jim Ayers In a message dated 02/05/2006 11:44:53 PM Pacific Standard Time, millstrj(at)ozemail.com.au writes: --> RV-List message posted by: "Trevor Mills" Can anyone tell me anything about the electric 3 blade MT props as sold by Eggenfellner ? I would like to find the Model # and any comments would be great. Thanks. Trevor Mills 80605 ________________________________________________________________________________
Date: Feb 06, 2006
Subject: Re: Seat heaters
Shopko is unloading seat heated car seat cushions for around $15.00. Been testing them in my car for past month and they work fine. Put one on the Front seat of My RV8 and it fits ok. My opinion is that it is that rarity in aviation...good and cheap. For @ $10.00 more you can get one that massages. I passed on that one. They're cheap enough you can tear one apart and see what makes it tick, use it as is (recommended), or whatever. Also when it breaks, you just toss it without having to tear apart your seats. Another reason one may want to shy away from permanently embedded seat heaters is that I find it pretty hard to get in and out of the RV-8 without stepping on the seat. Over time, even if careful, this could shorten, maybe literally, the life of the embedded heater. Regards, Vince H. rv8432 VSB Finish - Get'r done mode ________________________________________________________________________________
Date: Feb 06, 2006
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Have you considered rear heat? It works! http://www2.mstewart.net:8080/super8/index.htm There is a link in there for how I installed rear heat in the RV-8 using a muff and duct tube. My wife loves me for this. Yours will too. Enjoy, Mike -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of vhimsl(at)adelphia.net Sent: Monday, February 06, 2006 1:22 PM Subject: Re: RV-List: Seat heaters Shopko is unloading seat heated car seat cushions for around $15.00. Been testing them in my car for past month and they work fine. Put one on the Front seat of My RV8 and it fits ok. My opinion is that it is that rarity in aviation...good and cheap. For @ $10.00 more you can get one that massages. I passed on that one. They're cheap enough you can tear one apart and see what makes it tick, use it as is (recommended), or whatever. Also when it breaks, you just toss it without having to tear apart your seats. Another reason one may want to shy away from permanently embedded seat heaters is that I find it pretty hard to get in and out of the RV-8 without stepping on the seat. Over time, even if careful, this could shorten, maybe literally, the life of the embedded heater. Regards, Vince H. rv8432 VSB Finish - Get'r done mode ________________________________________________________________________________
Date: Feb 06, 2006
Kevin, My -8 flap motor stop-to-stop (flap full up to fully extended) is five inches (5.000" plus/minus 0.010") Build Well Jack N8VZ should issue this month From: "Kevin Shannon" <kshannon(at)seanet.com> Subject: RV-List: RV-8 flap motor Date: Mon, 6 Feb 2006 08:37:33 -0800 RV-List message posted by: "Kevin Shannon" Hi List I am looking for the stop-to-stop travel distance of the RV-8 flap motor, does anyone have this info at their fingertips? Many thanks Kevin Shannon HR II under const ________________________________________________________________________________
Date: Feb 06, 2006
>> >> Listers, >> Need to fix a slightly heavy right wing on a new >> rocket. Please correct me if I am wrong here. >> Seems one should squeeze the trailing edge >> of the light wing. Correct??? >> Thank you, Stewart Bergner > You are correct the fix is to squeeze the light wing's aileron. I have done this successfully. AND I did this very carefully. What others have said here on the list is very true. First, check all other things per the Van's document/instructions to see if anything major is at fault. Then if that does not give you resolution, very very very gently squeeze the light wing's aileron all across the length of it. I mean squeeze it so you do not even think you are doing anything. Go out and fly. If the wing is still heavy, tighten the adjusting tool about 1/128th of an inch. Resqueeze. Test fly. Keep doing this until you find the right amount of squeeze. After I corrected the problem, I cannot even see that I changed the aileron one tiny bit. It is very very suttle. Indiana Larry, RV7 SunSeeker 80+ hours flying ----- Original Message ----- From: "Don Diehl" <diehldon(at)comcast.net> Sent: Sunday, February 05, 2006 11:46 AM Subject: Re: RV-List: aileron trimming by squeezing question > > My fix for a slightly heavy right wing was an aileron trim tab. > The "tab" is a wooden wedge from the hardware store, intended to > secure the head to a sledge hammer. > I bonded it on using double back tape, test flew it, trimmed it for > neutral roll, painted it then bonded it with a dab or epoxy. > It's on the underside of the left aileron, unobtrusive and completely > effective. > Later I installed Van's aileron trim kit and think I should have done > that first. > > BTW, my fix for a half-ball yaw caused by my imperfect installation > of gear leg fairings was to align the fairings using washers stacked > to 1/8 inch between the trailing edge of the fairings and the bracket > on the fuselage. > > Don Diehl > RV-4, N28EW > Bremerton WA > ________________________________________________________________________________
Date: Feb 06, 2006
Subject: Re: RE: Aileron Squeezing and bracket re-locating
Basically you move the hinge when squeezing the TE is not enough. For me I had a very heavy right wing. I did the squeeze thing and it helped but not enough. I then saw Dan's web site and notice what he did and it imediately made sense. I measured the aileron gap to top wing skin, with the aileron in a neutral position. The right wing, from the cockpit, was good. the left wing, the inner hinge was lower by about .050. I moved the hinge .030 and it helped greatly, need to change ity to the full .050. Scott how would you know that the aileron brackets are not installed exactly the same or in the proper position? Good question. I am not sure. I went through the "use the wing rib shape cutout made of plywood to hold the aileron and flap in position" exercise on my RV-6A and I submit that one simply cannot be precise using such a method. You are correct. Do you have some method of precisely locating both the bracket to the aileron and then the aileron to the wing? I finished building 2 years ago and dont remember the details exactly. There was no rocket sicence involved when I did it.....I think I just put them in place thinking it would be right.......if had to do it over again I would just be more careful. Do you also have a method of doing this on a finished airplane? On a finished airplane just like Dan's web site shows. And how do you know how much performance you lose by squeezing versus relocating the hinge hole? I know of no performance loss or gain. Is it significant enough to be worth doing one over the other? I had not heard of the "move the aileron hinge up or down" method of doing this until recently, has Van's changed their mind about using the squeeze method and now recommends using the "move the bracket method" or is there a way of deciding which method to use? The only time you move the bracket is when the squeeze method wont work. Van's for legal reason will never approve of people doing this. Scott --------------------------------- Brings words and photos together (easily) with ________________________________________________________________________________
Date: Feb 07, 2006
Subject: WW 200RV Prop RPM Restriction?
I am considering purchasing a Whirlwind 200RV prop to replace my Hartzell on an IO360. I am looking for a weight reduction and elimination of the 2000 - 2250 RPM restriction. I talked to Whirlwind today and the rep mentioned that the prop designer "recommends" avoiding 2250 - 2300 RPM and this is identified in the owner's manual. Those of you using this prop, how are you handling this recommendation? Thanks Ted Flying RV4 ________________________________________________________________________________
Date: Feb 08, 2006
Subject: Re: WW 200RV Prop RPM Restriction?
It is a non issue. Here is how to fly with restriction. Since I have been flying HC-C2YK/F7666-4's with the same restriction I can tell you it is no big deal. Going thru it or momentarily dwelling in it is not a problem, even for metal props. It is continuous operation that's a problem. So for operation you just avoid that RPM range. Take off, climb and cruise should be well above 2300 rpm. If you want to cruise at 2300 RPM fine. In the pattern when you get it slowed down and go to high RPM, your RPM in the pattern should be around 1900 rpm to 2100 rpm. I don't think 2250 RPM is going to get in the way. First to explain there is a little history that needs to be explained. This should make you feel better. I hear good things about the RV 200RV, but you have to remember its a small company. When Hartzell did there extensive testing of their props on RV's using modified engines, electronic ignition and Hi Comp pistons a few years ago, they found stronger modes or more vibration modes to avoid. RPM restrictions are nothing new. The HC-C2YK/F7444 has a restriction on 180hp engines for many years going back to the 70's (like on the Piper Arrow with this engine/prop combo). When Hartzell said, wait there are differnt vibration modes, that are more severe with the stronger power pulse when EI, HC pistons are used, WW jumped on the bandwagon and copied or echoed Hartzells restrictions for electronic ignition and Hi Comp pistons. The posted on their web site that Hartzell gound XYZ so they where imposing the same restriction. I am sure at that point (about 2 years ago) they only where copying and had no actual data of their own. The kind of testing Hartzell does is very sophisticated, expensive and time consuming. (Note: There is a good reason for going with a big prop company.) No offense to WW but I suspect they still have not independently flight tested their props with strain gages. I could be wrong, but the restriction on Hratzells is due to theoretical metal fatigue life. Since the WW is composite it should not be fatigue critical. Flying in the restricted RPM region will not cause catastrophic problems, even for metal props, but from a theoretical total fatigue life calculation you are reducing the life, which originally was assumed for practical purpose to be almost infinite. Infinite is a very large finite number that is essentially for practical purposes forever. Remember we are talking low stress but lots and lots of cycles. You know the paper clip trick bend it enough it breaks. Well if you don't bend the clip at all or very little, it never breaks. Same with the prop. You keep the stress below a threshold the life goes up to 10 to the 99th power. Over a critical stress you do "fatigue damage". Fatigue damage is cumulative and adds up (miners rule). Therefore Hartzell limits blade life on highly modified engines (experimental aircraft) to some where around 8,000-10,000 flight hours even with RPM restrictions. They make some very conservative assumptions to get this number. Since that is a lot of flying, chances are the blades will need to be retired due wear before time. Also you have to remember there are huge factors of safety or margins of safety and conservatism on these numbers. In other words even at 8,000 hour Hartzell on a radical engine is still safe, may be for another 8,000 hours. If you don't have HC pistons and EI than the prop life is not an issue at all. It is essentially infinite. WW is conservative, however its a mystery why a composite prop would have restricted RPM, at least from fatigue life standpoint, since composites are not subject to fatigue like metal. (I have a aerospace structural background). I got the feeling the WW was being conservative and coping what Hartzell was restricting. I think that is still the case. The WW200RV should be better than a metal prop in vibration and fatigue, so I also suspect the 2250-2300 RPM restriction is conservative. Their thinking is, hey it does not effect normal operation and since Hartzell suggest it, lets do the same. No doubt the power pulses are critical there for any prop and I guess they don't want to abuse their prop either. However when it comes to Props conservative is GOOD. The restriction is there for fatigue life on metal props. WHY WW has a restriction I don't know for sure. You would have to ask them. May be they did test it. Otherwise I think they are coping the Big Boy (Hartzell). So don't worry about it. Give use a report on your new prop. George From: Ted Lumpkin Subject: RV-List: WW 200RV Prop RPM Restriction? I am considering purchasing a Whirlwind 200RV prop to replace my Hartzell on an IO360. I am looking for a weight reduction and elimination of the 2000 - 2250 RPM restriction. I talked to Whirlwind today and the rep mentioned that the prop designer "recommends" avoiding 2250 - 2300 RPM and this is identified in the owner's manual. Those of you using this prop, how are you handling this recommendation? Thanks Ted Flying RV4 --------------------------------- ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Feb 08, 2006
George, Good post regarding the prop restrictions. A couple additional thoughts: Regarding fatigue life, what you said is true for alloys of steel, but not for aluminum. Even at low stresses, the fatigue life is not practically infinite. Aluminum and its alloys are somewhat unique in this regard. I haven't a clue what it would be for a prop, I suspect that there would be a huge variation based upon usage and knick history. Regarding the question of why an rpm limitation would be imposed on a composite prop, I was under the impression that the Hartzell limitation was somewhat based upon the crankshaft's interaction with the prop. Others more knowledgable can comment. Alex Peterson RV6-A N66AP 712 hours Maple Grove, MN ________________________________________________________________________________
Date: Feb 08, 2006
Subject: Re: RV fuel per hour and heat
I have been following van's rvaitor article on economy flying. 1950 rpm's, airspeed 120 mpr, and leaning. getting great fuel / hour. always under 5 g/h with the best 4.42 g/h. now i hear little jabs about i will burn up my O-320 which has a fixed pitch 79" prop. what should i think about this? Also My oil temp has always run cold. i have a door over the oil cooler. is there away of telling if the veratherm is working properly, without buying a new one? jerry wilken albany oregon rv6a n699wp 390 hours ________________________________________________________________________________
Date: Feb 08, 2006
Subject: Anyone live at Stellar Airpark??
I am looking for someone who currently lives at Stellar Airpark, if you do please email me off list I have a few questions. Thanks. - Matt ________________________________________________________________________________
Subject: Re: [RV7A] Anyone live at Stellar Airpark??
Date: Feb 08, 2006
Hi Matt, I live at Stellar. Feel free to call me. Darwin N. Barrie Chandler AZ (p19) RV-7 N717EE 480-204-0662 ----- Original Message ----- From: Matt Johnson To: rv-list(at)matronics.com ; rv7a(at)yahoogroups.com Sent: Wednesday, February 08, 2006 11:55 AM Subject: [RV7A] Anyone live at Stellar Airpark?? I am looking for someone who currently lives at Stellar Airpark, if you do please email me off list I have a few questions. Thanks. - Matt The RV Aircraft Builders Group SPONSORED LINKS Plane tickets Charter plane Aviation school Aviation headset a.. Visit your group "RV7A" on the web. b.. To unsubscribe from this group, send an email to: RV7A-unsubscribe(at)yahoogroups.com ________________________________________________________________________________
Date: Feb 09, 2006
Hi Jerry, I usually run my O-320 powered RV6 at 2250 rpm with a Sensenich 79" prop and get great economy as well as good speed - like around 6 US gals per hour at 135 kts.. I too have been told to be aware of burning up the engine, most notably the exhaust valves, as well as glazing the bores. I don't really see how, as my CHT's are all around 310-315 deg F, and the engine is producing approx 55% power. I know we didn't build our RVs to go slow, but it is relative, and the fuel savings are nice. Cheers Martin in Oz ________________________________________________________________________________
Date: Feb 08, 2006
Subject: Re: Typo - WW 200RV Prop RPM Restriction?
Thanks for all your input on this issue. I made a typo in my original post. The WW 200RV recommended restriction is 2050 - 2300, not 2250 - 2300. I'm flying with a Hartzell now so I can fly around the restriction, I just would feel more comfortable not having to. In the specs section on the WW website it clearly states, "restrictions: none". It's a little disappointing to read that then have the rep tell you the owners manual states otherwise. Ted Ted Lumpkin wrote: I am considering purchasing a Whirlwind 200RV prop to replace my Hartzell on an IO360. I am looking for a weight reduction and elimination of the 2000 - 2250 RPM restriction. I talked to Whirlwind today and the rep mentioned that the prop designer "recommends" avoiding 2250 - 2300 RPM and this is identified in the owner's manual. Those of you using this prop, how are you handling this recommendation? Thanks Ted Flying RV4 ________________________________________________________________________________
Date: Feb 08, 2006
Mike Kraus wrote: > >Or you can do what I did. Remove it, put it in some real hot water >(like boiling or slightly less than boiling) and see if it moves. You >can measure the end of it. Put it in cold water and it will shrink... >Worked great for me. > >By the way, O-320's run real cold most of the time. My RV-4 runs real >cold all the time, in the summer I have a 3/4" hole going to the oil >cooler and I just get to 190F. In the winter I block it off completely >and it still won't get to 180F >-Mike > I'm always interested in how those low numbers are achieved. What fuel flow, rpm & mp are you running to get those temps, & what's your cht? Is yours rated at 150 or 160 hp? Oil cooler on firewall, back cyl baffle, or ?? Speed? Inquiring minds (having owned several O-320's that ran hotter than that) want to know. Thanks, Charlie ________________________________________________________________________________
Subject: glueing canopy
Date: Feb 08, 2006
Hey Mickey, Charlie, Barefoot Billy et al- After a bunch of setbacks, interruptions, sidetrack, and minor crises, I'm finally back at it with my -8. Today I cut my (new Todd's) canopy to fit the fuselage. I've read about all I can find on the glued canopy subject. Standing back and admiring how much the project looks like a plane when the canopy is in place, I had an idea. Suppose I were to put a few dabs of SikaFlex on the roll bar and canopy bow, carefully set the canopy in place with adequate and competent help, and then add dabs of glue around the periphery of the canopy once it was clamped to the spacers. Once it was cured, I could cut the canopy from the windscreen and go to work on the full-up glue job and filleting. What do you guys think? Am I missing something here, or wouldn't this approach simplify the whole rigging aspect of independently gluing separate pieces of plastic to separate structures and hoping that they line up well? Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: Looking for Lycoming parts on-line
Date: Feb 09, 2006
Where can one buy Lycoming Parts on line? Did a Google search and not much luck finding an outfit that can cross-reference old part numbers to new and has a web site that you can order from. It looks like I have to do it the old fashioned way, pick up the phone, and call. I did find what I was looking for. (Studs to mount a mag.) Want spares in case I break one when I install my new P-Mags. It appears that there is a lack of new Lycoming part vendors on the internet. Wonder is it has anything to do with UnApproved Parts getting into the system. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,839 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ________________________________________________________________________________
Date: Feb 08, 2006
Gary, I don't know about "online" but when I needed a bunch of new engine parts a few years ago these guys seemed to be very knowledgeable and had the best prices I could find at the time. I experienced all around good service as well. Sorry I can't remember the name of the fellow I usually talked to. They seemed to be willing to negotiate on some stuff like cylinders at least. Premium Aircraft Parts 800-932-2129 > [Original Message] > From: RV6 Flyer <rv6_flyer(at)hotmail.com> > To: > Date: 2/8/2006 8:29:04 PM > Subject: RV-List: Looking for Lycoming parts on-line > > > Where can one buy Lycoming Parts on line? Did a Google search and not much > luck finding an outfit that can cross-reference old part numbers to new and > has a web site that you can order from. > > It looks like I have to do it the old fashioned way, pick up the phone, and > call. > > I did find what I was looking for. (Studs to mount a mag.) Want spares in > case I break one when I install my new P-Mags. > > It appears that there is a lack of new Lycoming part vendors on the > internet. Wonder is it has anything to do with UnApproved Parts getting > into the system. > > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 1,839 + Flying Hours So. CA, USA > http://SoCAL_WVAF.rvproject.com > > > > > > > ________________________________________________________________________________
Date: Feb 08, 2006
Subject: Re: Looking for Lycoming parts on-line
Gary, Have you tried Sacramento Sky Ranch? http://www.sacskyranch.com/ <http://www.sacskyranch.com/> Click on Lycoming on the left side and then search for "stud". It gives part # description and price for a lot of studs. I've never bought from them, but it looks like they have almost any part you'll need. Dave RV6 Flyer wrote: > > >Where can one buy Lycoming Parts on line? Did a Google search and not much >luck finding an outfit that can cross-reference old part numbers to new and >has a web site that you can order from. > >It looks like I have to do it the old fashioned way, pick up the phone, and >call. > >I did find what I was looking for. (Studs to mount a mag.) Want spares in >case I break one when I install my new P-Mags. > >It appears that there is a lack of new Lycoming part vendors on the >internet. Wonder is it has anything to do with UnApproved Parts getting >into the system. > > >Gary A. Sobek >"My Sanity" RV-6 N157GS O-320 Hartzell, >1,839 + Flying Hours So. CA, USA >http://SoCAL_WVAF.rvproject.com > > > > > > > > > ________________________________________________________________________________
Date: Feb 09, 2006
In a message dated 2/8/2006 8:25:30 P.M. Pacific Standard Time, rv6_flyer(at)hotmail.com writes: Where can one buy Lycoming Parts on line? Did a Google search and not much luck finding an outfit that can cross-reference old part numbers to new and has a web site that you can order from. It looks like I have to do it the old fashioned way, pick up the phone, and call. I did find what I was looking for. (Studs to mount a mag.) Want spares in case I break one when I install my new P-Mags. It appears that there is a lack of new Lycoming part vendors on the internet. Wonder is it has anything to do with UnApproved Parts getting into the system. ============================= Gary- When I needed the short stud when I had my flirtation with the P-Mags last year, I got them from Sacramento Skyranch. You can have the ones I got. The only issue here is that you don't always know which P/N stud you actually need. You may need to get an oversized (pitch diameter) stud if you can't develop the required torque at the required engagement in the accessory case. GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Feb 09, 2006
Subject: Re: glueing canopy
> ... Suppose I were to put a few dabs of > SikaFlex on the roll bar and canopy bow, carefully set the canopy in place > with adequate and competent help, and then add dabs of glue around the > periphery of the canopy once it was clamped to the spacers. Once it was > cured, I could cut the canopy from the windscreen and go to work on the > full-up glue job and filleting. What do you guys think? ... When I was gluing on my canopy, I didn't have the F-821PP skin riveted on, so your idea didn't occur to me. I did try to put some glue on the canopy frame and set the canopy down on it, and it was a mess. I didn't properly anticipate the exact locations on the frame where the canopy would touch. Along the side, the location changes about 90 degrees from front to back. I ended up with a lot of glue in places I didn't want it, so I had to have much larger fillets of Sikaflex that I really needed. I have done some test fitting of the windscreen to see how it will line up, and I don't anticipate any real troubles, if that is your major concern. On my next canopy, here's how I'll do it: Clamp the canopy to the frame, and use a bit of Sikaflex to glue it on - don't try to do too much until the canopy is glued to the frame. Once glued, then you can take your time and run some pretty beads along the edges. I'd try to put the glue on the bottom, not the top. You might need a very small fillet on the top just for cosmetics. The initial gluing step would require about 30 dabs of glue around the frame. Good luck! -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Feb 09, 2006
In addition to Sac Sky Ranch www.aircraft-specialties.com www.premiumaircraftparts.com Vanremog(at)aol.com wrote: > > > In a message dated 2/8/2006 8:25:30 P.M. Pacific Standard Time, > rv6_flyer(at)hotmail.com writes: > > Where can one buy Lycoming Parts on line? Did a Google search and not much > luck finding an outfit that can cross-reference old part numbers to new and > has a web site that you can order from. > > I ________________________________________________________________________________
Date: Feb 09, 2006
Are you talking about installing the canopy in one piece then cutting the wind screen loose from the sliding section? If I understand the process you are describing it sound reasonable. But this is coming from someone that has not gotten to this point in the building process. Bob Perkinson Hendersonville, TN. RV9 N658RP Reserved If nothing changes Nothing changes Hey Mickey, Charlie, Barefoot Billy et al- After a bunch of setbacks, interruptions, sidetrack, and minor crises, I'm finally back at it with my -8. Today I cut my (new Todd's) canopy to fit the fuselage. I've read about all I can find on the glued canopy subject. Standing back and admiring how much the project looks like a plane when the canopy is in place, I had an idea. Suppose I were to put a few dabs of SikaFlex on the roll bar and canopy bow, carefully set the canopy in place with adequate and competent help, and then add dabs of glue around the periphery of the canopy once it was clamped to the spacers. Once it was cured, I could cut the canopy from the windscreen and go to work on the full-up glue job and filleting. What do you guys think? Am I missing something here, or wouldn't this approach simplify the whole rigging aspect of independently gluing separate pieces of plastic to separate structures and hoping that they line up well? Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
From: "czechsix(at)juno.com" <czechsix(at)juno.com>
Date: Feb 09, 2006
Subject: O-360/CS full power fuel flow
Guys, For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power, but the engine break-in documentation that came from Aerosport Power shows something like 22 gph at max power. That's a pretty big discrepancy. Curious if anybody can verify one number or the other... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D, FAA inspection tomorrow with first flight as soon as the wx cooperates.... Guys, For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power, but the engine break-in documentation that came from Aerosport Power shows something like 22 gph at max power. That's a pretty big discrepancy. Curious if anybody can verify one number or the other... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D, FAA inspection tomorrow with first flight as soon as the wx cooperates.... ________________________________________________________________________________
Subject: Re: O-360/CS full power fuel flow
Date: Feb 09, 2006
I like to keep records on these numbers myself. EAA published an extensive test (including fuel flow numbers) on different exhaust systems and the test horse was the IO - 360. The max power fuel flow was always in the neighborhood of 20 - 21 GPH. The 180 HP O - 360 would burn proportionally less (about 18 - 19 GPH at max power) but 15 GPH at 180 HP is somewhat optimistic I think. Running the engine rich during break-in would easily put it in the 22 GPH area. My Mazda rotary makes about 200 HP at 7000 rpm and burns about 20 GPH. What a coincidence! The BSFC of most any piston (or rotary) engine improves when tested at less than max power. It takes less than half the fuel to make half the HP, especially when leaning the mixture aggressively. Tracy Crook ----- Original Message ----- From: czechsix(at)juno.com<mailto:czechsix(at)juno.com> To: rv-list(at)matronics.com Sent: Thursday, February 09, 2006 9:06 AM Subject: RV-List: O-360/CS full power fuel flow Guys, For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power, but the engine break-in documentation that came from Aerosport Power shows something like 22 gph at max power. That's a pretty big discrepancy. Curious if anybody can verify one number or the other... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D, FAA inspection tomorrow with first flight as soon as the wx cooperates.... Guys, For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power, but the engine break-in documentation that came from Aerosport Power shows something like 22 gph at max power. That's a pretty big discrepancy. Curious if anybody can verify one number or the other... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D, FAA inspection tomorrow with first flight as soon as the wx cooperates.... ________________________________________________________________________________
Date: Feb 09, 2006
In a message dated 2/9/2006 6:11:28 A.M. Pacific Standard Time, czechsix(at)juno.com writes: For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power ====================================================== 15-16 gph is what I see routinely at take off at my field on my 0-360 c/s WFO at 400 ft MSL. 8.2-8.4 gph is what I see leaned out at 65%. GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Feb 09, 2006
On 9 Feb 2006, at 14:06, czechsix(at)juno.com wrote: > > Guys, > For those of you with a 180 HP O-360, CS prop, and fuel > flowmeter.....can anybody tell me what fuel flow they see at full > takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows > about 15 gph at full power, but the engine break-in documentation > that came from Aerosport Power shows something like 22 gph at max > power. That's a pretty big discrepancy. Curious if anybody can > verify one number or the other... Mark, If you are looking at Figure 3-34 in the Lycoming Operator's Manual, it is labelled "Minimum Allowable Fuel Flow". There is nothing wrong with having a higher fuel flow than that, as long as the engine runs smoothly. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Feb 09, 2006
The numbers I gave are from memory from about a year ago, they were posted by Mahlon from Mattituc. Maybe I am off a gallon on the low side but I think close. Again you want real answers from someone who has run hundreds of engines on the dyno, then post this question on the Lycoming list and Mahlon will answer it with real numbers. I like to keep records on these numbers myself. EAA published an extensive test (including fuel flow numbers) on different exhaust systems and the test horse was the IO - 360. The max power fuel flow was always in the neighborhood of 20 - 21 GPH. The 180 HP O - 360 would burn proportionally less (about 18 - 19 GPH at max power) but 15 GPH at 180 HP is somewhat optimistic I think. Running the engine rich during break-in would easily put it in the 22 GPH area. My Mazda rotary makes about 200 HP at 7000 rpm and burns about 20 GPH. What a coincidence! The BSFC of most any piston (or rotary) engine improves when tested at less than max power. It takes less than half the fuel to make half the HP, especially when leaning the mixture aggressively. Tracy Crook ----- Original Message ----- From: czechsix(at)juno.com Sent: Thursday, February 09, 2006 9:06 AM Subject: RV-List: O-360/CS full power fuel flow Guys, For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power, but the engine break-in documentation that came from Aerosport Power shows something like 22 gph at max power. That's a pretty big discrepancy. Curious if anybody can verify one number or the other... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D, FAA inspection tomorrow with first flight as soon as the wx cooperates.... Guys, For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power, but the engine break-in documentation that came from Aerosport Power shows something like 22 gph at max power. That's a pretty big discrepancy. Curious if anybody can verify one number or the other... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D, FAA inspection tomorrow with first flight as soon as the wx cooperates.... Scott Bilinski RV-8a cell 858-395-5094 --------------------------------- ________________________________________________________________________________
Date: Feb 09, 2006
> For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can > anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / > mixture rich? The Lycoming manual shows about 15 gph at full power, but > the engine break-in documentation that came from Aerosport Power shows > something like 22 gph at max power. 16-17 gph for mine. Almost always read 16.5 when taking off from near sea level. I would imagine jetting could change this figure when running at full rich mixture. If someone is burning 19-20 gph their main jets may be too large. Randy Lervold ________________________________________________________________________________
Date: Feb 09, 2006
Subject: Re: WW 200RV Prop RPM Restriction? Hartzell WW MT
First I'll say I the Hartzell Blended Airfoil is the best value and the fastest constant speed prop you can put on. I think WW and MT make good products and will be lighter than the Hartzell. MT claims no restriction but they are VERY vague about it. I have seen nothing in writing or that they have tested it on modified engines. However with a wood core blade I suspect that they are OK at least with a stock engine since wood is such a good dampener. Alex you are right the stress level for Al fatigue damage can be lower than steel, but steel can be horrible, depending on type of steel and heat treat. Yes fatigue life is not really infinite for an aluminum prop, but I meant it's so long that for practical service it represents such a long calendar period it is considered infinite. Large jets are good for 20 years of economical service with 24/7 severe service with a factor of 2, or 40 years. Boeing's stand is with proper maintenance and inspection an airframe can go forever. However the FAA and aging fleet initiative makes inspections so expensive and intrusive (x-ray, eddy current, ultra sound and mass dis assembly) that it becomes too expensive to continue to fly it commercial. However a used B707 is built like a tank, and if only operated with low use private purposes makes an awesome large business Jet (John Travolta). These B707 are over 40 year old and built for stout. The freight companies are thrashing 40 year old DCV-8's nightly. They just keep replacing parts. On the other hand an old fire bomber (C130A) lost a wing and recently in the news the Chalks Airlines Grumman lost a wing, which is a dramatic and tragic reminder of what metal fatigue is. In the past people modified metal props off of slow factory planes for their fast homebuilt. They would cut them down, re-pitch them. The vibratory stresses where so great that they broke in a few 100 hours (I think at the 2/3 span). Alex, yes I do think the interaction of crank and prop vibration is the issue, but it's a prop restriction not a crank restriction. If Lycoming wanted a life limited crank they could save some lbs, but they have such an overbuilt piece of steel that stresses are below that critical level, where damage is nil. As it's now you can rebuild a Lycoming almost infinitely. They mandatory replacement parts are the highly loaded rod nuts and studs, for example. However you can weld up a 7000 hr cracked cylinder or use a 10,000 crank and go fly. They have S-N charts, stress-cycle charts. Higher the stress the less the cycles. Makes sense. Than there is stress concentration (sharp corners) and how the stress cycles, such as is it from zero to positive or tension-compression and back, which does far grater damage. If you keep a part in compression you can improve the fatigue life. I made a living doing fatigue life analysis on large aluminum transport jet airframes. I can tell you a sharp nick on a prop is critical. The prop mid to tip area is critical, where the cross section is thinner. The root has details that are critical, where the fillet radiuses are in the mount flange area in the hub. To counter act stress they add material (lower stress), use good details (smooth surfaces, big radius lower stress concentration) and treat the material to shoot penning in some cases to add residual compression to the material. My point is props are designed for a very very long fatigue life time. Although not really infinite, it's so long, for all practical purposes the prop will be dimensionally and physically worn down or is scrap for other reasons, like corrosion, before the fatigue life is reached. When you bring your Hartzell in and the P-shop says you are .001 under the min thickness at the second station from the tip, you are cooked. I have one of those "scraped" props on my RV. I called and the reason they specify a min dimension is not fatigue or stress but just a somewhat arbitrary dimension as a cutoff based more on loss of performance than fatigue. Some big props that start life at 6 inch chord can be trimmed down to say 5 inches they just say that is enough for performance reasons. Some times they do find cracks; micro cracks that if left could cause a failure. That is why there is limited time between overhauls recommend. Crack growth rate is another part of fatigue analysis. You assume a crack and calculate if it will grow to be critical before the next inspection cycle. The time limited aspect is for corrosion, which is the killer of most old props left out in the weather. Hartzell has recognized after a period of time some parts of old designs where not unlimited life and need to be restricted, thus the dreaded AD. In the past they made hubs and clamps with steel. We are talking 1940's, 50's design that have not been made in a 1/2 century. They have limited life, repeated inspections and some stress relieving process that must be done every overhaul (which period is now shorter), such a shot penning. Shot penning puts a residual compressive stress in the outer surface which can help fatigue life. The compact hub like the HC-C2YK and the later BA airfoil are derivatives of a design that has millions of hours and been improved since the 60's. Even a HC-C2YK has been improved and a new Hartzell with the same part number is nothing like the one make in 1969. They continually improve them so it's a mature design and well tested. That is why you find the NEW BA airfoil has NO RPM restrictions! "SUPERIOR XP-360 RESTRICTIONS: Hartzell Propeller Model HC-C2YR-1BFP/F7496 (BA prop) is vibrationally approved when mounted on Superior Air Parts model O- 360-B1A2 and IO-360-B1A2 engines rated at 180HP at 2700 RPM with magneto ignition and installed in Van's Model RV-6A and similar single engine tractor aircraft. There are no operating restrictions." http://www.hartzellprop.com/kitplane/index_kitplane.htm With HC pistons, EI and FADEC there are restrictions but they single power point restriction (one MP/RPM) for the new Hartzell BA prop, but they are not a range of RPM's as with the classic HC- C2YK/F7666. George From: "Alex Peterson" <alexpeterson(at)earthlink.net> George, Good post regarding the prop restrictions. A couple additional thoughts: Regarding fatigue life, what you said is true for alloys of steel, but not for aluminum. Even at low stresses, the fatigue life is not practically infinite. Alex Peterson RV6-A N66AP 712 hours Maple Grove, MN From: Ron Lee <ronlee(at)pcisys.net> Supposedly MT makes a prop without an RPM restriction. Ron Lee --------------------------------- ________________________________________________________________________________
From: "Dan Beadle" <dan.beadle(at)inclinesoftworks.com>
Date: Feb 09, 2006
These numbers seem about right. Rule of thumb is about 10HP / Gallon when at best power (100 degrees rich). Varies by engine type, but generally within 10% -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of scott bilinski Sent: Thursday, February 09, 2006 8:03 AM Subject: Re: RV-List: O-360/CS full power fuel flow The numbers I gave are from memory from about a year ago, they were posted by Mahlon from Mattituc. Maybe I am off a gallon on the low side but I think close. Again you want real answers from someone who has run hundreds of engines on the dyno, then post this question on the Lycoming list and Mahlon will answer it with real numbers. Crook" I like to keep records on these numbers myself. EAA published an extensive test (including fuel flow numbers) on different exhaust systems and the test horse was the IO - 360. The max power fuel flow was always in the neighborhood of 20 - 21 GPH. The 180 HP O - 360 would burn proportionally less (about 18 - 19 GPH at max power) but 15 GPH at 180 HP is somewhat optimistic I think. Running the engine rich during break-in would easily put it in the 22 GPH area. My Mazda rotary makes about 200 HP at 7000 rpm and burns about 20 GPH. What a coincidence! The BSFC of most any piston (or rotary) engine improves when tested at less than max power. It takes less than half the fuel to make half the HP, especially when leaning the mixture aggressively. Tracy Crook ----- Original Message ----- From: czechsix(at)juno.com Sent: Thursday, February 09, 2006 9:06 AM Subject: RV-List: O-360/CS full power fuel flow Guys, For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power, but the engine break-in documentation that came from Aerosport Power shows something like 22 gph at max power. That's a pretty big discrepancy. Curious if anybody can verify one number or the other... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D, FAA inspection tomorrow with first flight as soon as the wx cooperates.... Guys, For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power, but the engine break-in documentation that came from Aerosport Power shows something like 22 gph at max power. That's a pretty big discrepancy. Curious if anybody can verify one number or the other... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D, FAA inspection tomorrow with first flight as soon as the wx cooperates.... Scott Bilinski RV-8a cell 858-395-5094 --------------------------------- ________________________________________________________________________________
Date: Feb 09, 2006
Subject: Re: RV fuel per hour and heat (Low power cruise)
As long as the engine is in normal limits as Lycoming recommends. Off the top of my head 280 CHT, Oil Temp 190/180 min. There is not truth to doing damage as long as you get it hot enough. Sure you need to check it makes full power, but that happens every takeoff. I am not a fan of babying it on take-off but that would be the next step in fuel saving. Do you need 2000 fpm climb? Check Lycomings key reprints. They address this. http://www.lycoming.textron.com/main.jsp?bodyPage=support/publications/keyReprints/operation/lowPowerLowRPM.html Here is the other operational articles that has good info on power settings. http://www.lycoming.textron.com/main.jsp?bodyPage=/support/publications/keyReprints/operation.html So what do you all think about de-rated takeoffs? I guess if the runway is long and there are no obstacles, but I tend to want to get as high as fast as possible. ON the other hand a Cessna C150 is crawling up at 500 fpm all the time. George From: "Martin Hone" <mctrader(at)bigpond.net.au> Hi Jerry, I usually run my O-320 powered RV6 at 2250 rpm with a Sensenich 79" prop and get great economy as well as good speed - like around 6 US gals per hour at 135 kts.. I too have been told to be aware of burning up the engine, most notably the exhaust valves, as well as glazing the bores. I don't really see how, as my CHT's are all around 310-315 deg F, and the engine is producing approx 55% power. I know we didn't build our RVs to go slow, but it is relative, and the fuel savings are nice. Cheers Martin in Oz --------------------------------- Brings words and photos together (easily) with ________________________________________________________________________________
Subject: Re: Varnatherm
Date: Feb 09, 2006
The posting by linn Walters regarding operation of the Varatherm reminded me of a recent experience with an initial run of a engine that I think is worth passing along to the those who have not yet run their engines . When we did the first start of the engine on a rather cold day we saw no oil leaks in the engine area. In a subsequent engine start, within a half hour, suddenly there was oil leaking on the back side of the engine. After shutting it down we discovered the leak was from the oil line returning the oil from the oil cooler to the engine. It appears the oil leak only appeared after the Varatherm opened and there was oil pressure in the return line. A oil pressure check was made as soon as the engine was first started the first time so I don't think it was the oil pressure finally coming up, The point here is to be sure the engine gets sufficiently warm to open the Varatherm when doing the leak testing on a new engine. Other wise there maybe a leak you are not aware of when making that first flight. Dale Ensing RV-6A EAA TC & FA PS I would be interested in hearing from engine experts if my analysis is wrong. ________________________________________________________________________________
Date: Feb 09, 2006
Subject: Governor for Whirlwind Prop
For you users of Whirlwind props, what governor are you using? WW recommends the Jihostroj P920 which sells for approx $1,250. Van sells the MT P860-4 governor (also made by Jihostroj) for $1050. Will Van's MT governor work on a WW 150-151 prop which requires a pressure of 450-475 PSI? Do MT props require the same high pressure to operate? Any fit problems with either governor? Thanks, Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Subject: Varnatherm
Date: Feb 09, 2006
You are correct Dale in that an oil line leak from the cooler would not be found until the Vernatherm opens. The vernatherm is supposed to open (53E22144)which is the current Lycoming vernatherm when oil temp reaches 187-189 F. Not to be alarmed but when the vernatherm opens there will be a slight drop in pressure, usually 3-5 lbs. Allen Barrett BPE, Inc. www.barrettprecisionengines.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Ensing Sent: Thursday, February 09, 2006 11:15 AM Subject: Re: RV-List: Varnatherm The posting by linn Walters regarding operation of the Varatherm reminded me of a recent experience with an initial run of a engine that I think is worth passing along to the those who have not yet run their engines . When we did the first start of the engine on a rather cold day we saw no oil leaks in the engine area. In a subsequent engine start, within a half hour, suddenly there was oil leaking on the back side of the engine. After shutting it down we discovered the leak was from the oil line returning the oil from the oil cooler to the engine. It appears the oil leak only appeared after the Varatherm opened and there was oil pressure in the return line. A oil pressure check was made as soon as the engine was first started the first time so I don't think it was the oil pressure finally coming up, The point here is to be sure the engine gets sufficiently warm to open the Varatherm when doing the leak testing on a new engine. Other wise there maybe a leak you are not aware of when making that first flight. Dale Ensing RV-6A EAA TC & FA PS I would be interested in hearing from engine experts if my analysis is wrong. ________________________________________________________________________________
Date: Feb 09, 2006
Subject: Hartzell WW MT - my MT comments
For my engine combination (their actual statement was O360 - 180 hp or greater), MT recommended that I install the F6 counterweighted crankshaft (now going back for AD) and they told me there were no limitations with this recommended combination. I am using AFP injection, Lasar ignition, and 9.2 pistons in an Aerosport built engine. Ralph Capen ________________________________________________________________________________
Date: Feb 09, 2006
> Do you need 2000 fpm climb? Why not? Your first article discussed ways to save fuel. One way is to cut flying. I don't intend to fly 300 hours this year. But I will cruise at normal speeds when I do. And I buy gas where it is cheaper. > So what do you all think about de-rated takeoffs? I guess if the runway is long and there are no obstacles, but I tend to want to get as high as fast as possible. I agree. Get up to cruising altitude. Full Throttle for a few minutes is not going to cost that much gas. Personally, if you are worried about that amount either sell the plane or cut back a few hours. It is like buying a Yugo to save gas. Not me. I prefer large pieces of metal around me when I drive and if I have to pay more for gas, so be it. Safety is the higher priority. Ron Lee ________________________________________________________________________________
Date: Feb 09, 2006
> So what do you all think about de-rated takeoffs? I guess if the runway is long and there are no obstacles, but I tend to want to get as high as fast as possible. ON the other hand a Cessna C150 is crawling up at 500 fpm all the time. George George, De-rated takeoffs at low elevations are probably a bad idea because the carburetor (and I think fuel injection systems also) run richer at full throttle than when slightly retarded to increase the detonation margin. You run the risk of operating too lean and closer to the detonation margin when at higher than 75% power and low fuel flow. If you were to use a power setting below 75%, perhaps that would be a non issue. At higher altitude airports, your takeoff power is automatically de-rated by lower air pressure and you may have to lean to achieve maximum available power. Because you're operating below 75% at anything above around 7500' density altitude (and normally aspirated), it's harder to make it detonate by leaning. I like the idea of maximum terrain clearance as soon as possible for purposes of having more time in case of power failure. This calls for full available power for takeoff and initial climb. Power can be reduced when you feel you're high enough to have viable engine out options. YMMV Pax, Ed Holyoke ________________________________________________________________________________
Subject: Re: Governor for Whirlwind Prop
Date: Feb 09, 2006
> WW recommends the Jihostroj P920 which sells for approx $1,250. Van > sells the MT P860-4 governor (also made by Jihostroj) for $1050. > > Will Van's MT governor work on a WW 150-151 prop which requires a > pressure of 450-475 PSI? Do MT props require the same high pressure to > operate? Due to a smaller piston in the hub the WW 150-151 require the governor pressure to be in the 425 psi range rather than the 325-350 range. WW buys the Jihostroj governors specially modified for the higher pressure, therefore the MT version won't work for the WW 150-151. Randy Lervold ________________________________________________________________________________
Date: Feb 09, 2006
Subject: Re: Looking for Lycoming parts on-line (RV6 Flyer)
ECI http://www.eci2fly.com/ I think some one mentioned sacramento sky ranch already. G --------------------------------- ________________________________________________________________________________
Subject: Re: gluing canopy
Date: Feb 09, 2006
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
One thing to be sure to do if you glue in multiple steps is to re-do the prep steps each time, and be sure to apply the primer and glue within the timeframes specified. I spoke to a builder who did a bunch of testing on the glue joints. He tested parts where they waited much longer than specified between priming and gluing, and the joint strength definitely suffers. Done properly, he verified that the glue joint is stronger than the Plexiglas, but he said following the instructions is paramount. Dennis Glaeser 7A Fuselage (lots of riveting to do before I get to glue :-) ________________________________________________________________________________
Date: Feb 09, 2006
Are you saying that the modified Jihostroj P920 governor is the only governor that operates the Whirlwind 150-151 propeller? BTW, Jihostroj made the P-4xx series governor for MT Propeller. The P-8xx series governor number became necessary to differentiate a newly certified manufacturer for an identical performing governor. Jim Ayers In a message dated 02/09/2006 12:15:51 PM Pacific Standard Time, randy(at)romeolima.com writes: --> RV-List message posted by: "Randy Lervold" > WW recommends the Jihostroj P920 which sells for approx $1,250. Van > sells the MT P860-4 governor (also made by Jihostroj) for $1050. > > Will Van's MT governor work on a WW 150-151 prop which requires a > pressure of 450-475 PSI? Do MT props require the same high pressure to > operate? Due to a smaller piston in the hub the WW 150-151 require the governor pressure to be in the 425 psi range rather than the 325-350 range. WW buys the Jihostroj governors specially modified for the higher pressure, therefore the MT version won't work for the WW 150-151. Randy Lervold ________________________________________________________________________________
Date: Feb 09, 2006
> Are you saying that the modified Jihostroj P920 governor is the only > governor that operates the Whirlwind 150-151 propeller? Yes, as far as I know. Check with WW to be sure... www.whirlwindaviation.com Randy Lervold ________________________________________________________________________________
Date: Feb 09, 2006
I'm glad this came up, because I've never quite understood how this little gizmo worked. Now that I think I understand it, I'm left with another puzzle. Why do people go to the trouble to block off part of their oil cooler in the winter? If this thermostat only opens when the temp is too high, then it will barely be putting any oil through the cooler anyway. Color me confused... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=11138#11138 ________________________________________________________________________________
Subject: Re: VErnatherm
Date: Feb 09, 2006
Well....some of us that live up in the great north not only have to close off our oil coolers, but I also put Duct Tape over about 30% of my cowl inlets. I flew last weekend when it was only 12 degrees outside and to get the oil temp above 120 I have to have the cooler not only blocked off, but taped on the front and the cowl inlets also partially closed. Even then I barely got it above 180. Also, some of us have lyc's with no VERNATHERM (not only has this entire thread been archived, but it's been archived with the incorrect spelling....just wondering why nobody changed the subject line already)?!?! Cheers, Stein. >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of 13brv3 >Sent: Thursday, February 09, 2006 5:43 PM >To: rv-list(at)matronics.com >Subject: RV-List: Re: Varnatherm > > >I'm glad this came up, because I've never quite understood how >this little gizmo worked. Now that I think I understand it, I'm >left with another puzzle. > >Why do people go to the trouble to block off part of their oil >cooler in the winter? If this thermostat only opens when the temp >is too high, then it will barely be putting any oil through the >cooler anyway. > >Color me confused... > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=11138#11138 > > ________________________________________________________________________________
Date: Feb 09, 2006
> > Guys, > For those of you with a 180 HP O-360, CS prop, and fuel > flowmeter.....can anybody tell me what fuel flow they see at > full takeoff power / 2700 rpm / mixture rich? The Lycoming > manual shows about 15 gph at full power, but the engine > break-in documentation that came from Aerosport Power shows > something like 22 gph at max power. That's a pretty big > discrepancy. Curious if anybody can verify one number or the other... > Thanks, > --Mark Navratil Mark, the 22 sounds quite high. Mine runs at about 16 or so at 1000msl, and many others have reported similar results in past threads on this subject. Don Rivera (designer of the Airflow Performance system) has indicated to me that 17 or so is correct for a 180hp at sea level (I'll have to note the flow next time I'm at sea level, which will be Sun-n-Fun in April). There are some extremely good articles about engine management written by John Deakin on www.avweb.com. They are not necessarily easy reading, so plan on spending some serious time studying them. The one number I've not been able to directly find yet is the specific fuel consumption desired for a full throttle sea level condition. Clearly, at this full rich setting, excess fuel is desired to modify the combustion to eliminate detonation and to run cooler. My 16 gph at 1000msl would work out to be about .57 lb/hp/hr (sfc, specific fuel consumption). Best power is around .51, while best economy is around .4. 22gph would be .73 lb/hp/hr. Does anyone know the desired sfc for full throttle, sea level power? Alex Peterson RV6-A N66AP 712 hours Maple Grove, MN ________________________________________________________________________________
Subject: Aileron bearings
Date: Feb 10, 2006
Has anybody change the bearings in there aileron brackets? The ones on my -6A are in need of replacement. Seem like I have seen a tool similar to a c-clamp in an old RVator but can't put my hands on it. I searched the archive to no avail. i will be doing my annual in the near future and would like to take care of this. Scott Frierson N162RV Flying ________________________________________________________________________________
Date: Feb 10, 2006
> Why do people go to the trouble to block off part of their oil cooler in the winter? If this thermostat only opens when the temp is too high, then it will barely be putting any oil through the cooler anyway.olor me confused... Some production airplanes including Warriors and Cherokees use a bolt-on winterization plate to completely block off the frontal area of the oil cooler for winter operations. In fact the 0-320 equipped 1974 Piper Warrior's oil cooler is mounted exactly the same way my plans mounted cooler is and it has a permanently mounted back plate installed! The baffle mounted oil cooler supporting my 0-320 would barely attain degrees in the hottest of summer weather. Through trial and error experimentation, I eventually blocked off the entire back side of the oil cooler with a plate. This finally brought the temp up to 180-185 degrees. Even so, when winter arrived, the oil temp barely rose to 130 degrees so I blocked off the frontal area of the cooler like the aforementioned production planes. Then when a brief winter temperature inversion occurred around here, I had to remove it to keep from generating too hot oil temperatures. This is precisely why I brought the oil cooler vent/shutter from Van's. http://tinyurl.com/9xh9k Adjustable from the cockpit, this device should put an end to constant tweaking of the oil cooler to compensate for seasonal (or daily) weather changes. Rick Galati RV-6A "Darla" 108 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=11201#11201 ________________________________________________________________________________
Subject: EIS
Date: Feb 10, 2006
I am looking at graghical read out EIS systems. Does anyone have thoughts about the Auracle by Xerion. It looked nice at Oshgosh last year. ________________________________________________________________________________
Date: Feb 10, 2006
From: "Bob Perkinson" <bobperk(at)bellsouth.net> Subject: RE: RV-List: gluing canopy >Are you talking about installing the canopy in one piece then cutting the >wind screen loose from the sliding section? Yup- I'm currently pausing to contemplate all the ways I can screw this up, and will hopefully come up with an idea or two that will simplify the process. Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: Re: VernathermRe: Varnatherm
Date: Feb 10, 2006
"There should be no reason to cover your oil cooler if you have a vernatherm." Jeff, It was explained to me that there is a small flow of oil thru the cooler even when the vernatherm is closed. This is to prevent the oil in the cooler from congealing which would not allow the oil to flow thru the cooler when the vernatherm does open. Partially closing off the cooler helps the non-congealing flow to do its job and subsequently helps keep the oil temp up when there is a flow thru the cooler. Dale Ensing ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Subject: Re: Aileron bearings
Date: Feb 10, 2006
I had to change mine. I used a C clamp and a couple of sockets. Worked fine. I'll bet a bunch of old RVs have locked ail bearings. I talked to Vans and they told me that after having numerous seizures, they changed their bearing supplier. Shemp/Jeff Dowling RV-6A, N915JD 265 hours Chicago/Louisville . ----- Original Message ----- From: "james frierson" <tn3639(at)hotmail.com> Sent: Friday, February 10, 2006 6:27 AM Subject: RV-List: Aileron bearings > > Has anybody change the bearings in there aileron brackets? The ones on my > -6A are in need of replacement. Seem like I have seen a tool similar to a > c-clamp in an old RVator but can't put my hands on it. I searched the > archive to no avail. i will be doing my annual in the near future and > would > like to take care of this. > > Scott Frierson > N162RV > Flying > > > ________________________________________________________________________________
Subject: Vernatherm mystery unveiled
Date: Feb 10, 2006
Alright, someone explained how this works and why. He replied off list so I'll remove his identity. Here goes: There is always oil pressure in both the return line from the cooler and inlet to the cooler line weather the oil is cold or hot. There is only full flow through the cooler when the oil is hot. When the oil is cold the oil is ported is such a way that there is the same oil pressure going down the return line as what is going down the in line to the cooler. Thus no flow. When the vernatherm expands it changes the routing so that all the oil goes through the cooler and then back to the engine instead of down both lines. When the oil is cold there is actually a very small flow through the cooler even though the vernatherm is open. This is done by design, they do that so that when it is very cold the oil won't congeal in the cooler because if there was no flow, the stagnant oil would "freeze" in the cooler effectively blocking the cooler and preventing its use once the vernatherm called for cooling. This is why when it is cold out and we can't get any real oil temp, blocking the airflow over the cooler will help run the oil a bit warmer then without the block installed because we blocked the cooling air attacking the non congealing flow through the cooler. Not trying to start an argument just trying to set you straight. No argument here. Thanks for the reply. Shemp/Jeff Dowling RV-6A, N915JD 265 hours Chicago/Louisville ________________________________________________________________________________
From: "Mitchell Goodrich" <mgoodrich(at)tampabay.rr.com>
Subject: EIS
Date: Feb 10, 2006
HI Donald, I am very impressed with Xerion Auracele also. I've been to the factory and spent quite a bit of time with the unit out in the direct sun. Its the brightest and clearest screen ever seen. Perfect for a full canopy like my EZE. If you want a direct phone number to the technical gura, let me know. I call him quite often. Xerion will be at Sun n Fun this year with a large booth just outside the Aircraft Spruce Hall. Hear they will have many demo units and a plane in the booth with the unit installed. Mitchell Goodrich VEZE 60P 813-356-9758 hiflier68(at)yahoo.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Donald L. Erickson Sent: Friday, February 10, 2006 9:27 AM Subject: RV-List: EIS I am looking at graghical read out EIS systems. Does anyone have thoughts about the Auracle by Xerion. It looked nice at Oshgosh last year. ________________________________________________________________________________
Date: Feb 10, 2006
The Vernatherm does not block flow to the cooler, it's an oil cooler BYPASS valve. It's in parallel with the cooler, so when it's open the oil goes whichever direction is easiest. When it's closed (hot oil) it forces the oil through the cooler. So, oil is always able to go to the cooler and some always does, hence the reason for blocking the air to the cooler. Dave -6, So Cal EAA Technical Counselor 13brv3 wrote: > >I'm glad this came up, because I've never quite understood how this little gizmo worked. Now that I think I understand it, I'm left with another puzzle. > >Why do people go to the trouble to block off part of their oil cooler in the winter? If this thermostat only opens when the temp is too high, then it will barely be putting any oil through the cooler anyway. > >Color me confused... > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=11138#11138 > > > > > > > > > ________________________________________________________________________________
Date: Feb 10, 2006
Subject: To/From Avionics Question
Can someone tell me what the "+To" and "+From" wires from a nav radio actually do? What data do they send? I have them on my SL30 and it would seem like it sends data that states you are TO or FROM a VOR, but I have the same outputs on my GX60 which is a IFR certified GPS/Comm and I would not expect it on that unit if they were relating to a VOR. Any help would be greatly appreciated. -Mike Kraus ________________________________________________________________________________
Subject: Video's For Sale
Date: Feb 10, 2006
EAA From the Ground Up Vol 2 and 4. Orndorff RV- 8 Finishing Kit. Ornforff RV 6/8 Empennage Part 1 and Part 2. All 5 for $40 plus shipping. Steve Glasgow N123SG RV-8 Cappy's Toy 704-362-0005 ________________________________________________________________________________
Subject: Re: To/From Avionics Question
Date: Feb 10, 2006
The wires just drive the the to/from flag on the indicator. The gps will provide virtual vor so the info is used in the same way . The actual info is derived from which side of the vor you are compared with the selected radial. Hope that helps -------------- Original message ---------------------- From: n223rv(at)wolflakeairport.net > > > Can someone tell me what the "+To" and "+From" wires from a nav radio > actually do? What data do they send? > > I have them on my SL30 and it would seem like it sends data that states > you are TO or FROM a VOR, but I have the same outputs on my GX60 which is > a IFR certified GPS/Comm and I would not expect it on that unit if they > were relating to a VOR. > > Any help would be greatly appreciated. > -Mike Kraus > > > > > > > > > > > > > T ________________________________________________________________________________
Date: Feb 10, 2006
Subject: Lowrance GPS Tecnical Help
I recently purchased an older used Lowrance GPS, it's the 5 channel "Airmap" predecessor to the Airmap 300. It is 8 years old but in like new condition with little obvious signs of use. The computer and database functions work fine but (and its a big but) the GPS will not lock on to give a position. Lowrance sort of understandably declines to support stuff that is this old. So does anyone know of a source for Lowrance repairs or upgrades or of a web site with advice of keeping older Lowrance equipment going? I am thinking of opening the case to reseat the connectors, etc. Thanks to anyone who can assist. It's a nice unit and would be a shame to just toss it in the trash. (I realize this is not hard RV stuff but I did buy the GPS to use in my -6A so it is relevant to RV flight ops.) Jim Oke RV-6A C-GKGZ Wpg., MB ________________________________________________________________________________
Subject: Re: Lowrance GPS Tecnical Help
Date: Feb 10, 2006
Jim, I have one of those Lowarnce models and it works just fine....have it connected to the Nav Aid wing leveler to fly a flight plan, tho' I now use an AnywhereMap with a modern PDA, but keep the Lowarnce as back up...I found that the antenna placement is fairly fussy on the Lowrance...if everything else is OK, try moving the antenna to various locations...if you still have the "flip up" cover- antenna connected, you might try removing it and using the remote feature to let the antenna get a better view of the sky. John ----- Original Message ----- From: "Jim Oke" <wjoke(at)shaw.ca> ________________________________________________________________________________
Date: Feb 10, 2006
Subject: Re: Lowrance GPS Technical Help
First off it probably does not know where it is or the correct time. If you can verify that the date/time is correct then see if there is a way to set your approximate position. There should be a screen that shows the positions of the GPS satellites. If you can compare yours with a GPS receiver that is working properly you can see how bad the almanac is. Have it on in an area with a good view of the sky and leave it on It could take 20 minutes or more initially. Exactly what model is it. Ron Lee At 04:17 PM 2/10/2006, you wrote: > >I recently purchased an older used Lowrance GPS, it's the 5 channel >"Airmap" predecessor to the Airmap 300. It is 8 years old but in like >new condition with little obvious signs of use. The computer and >database functions work fine but (and its a big but) the GPS will not >lock on to give a position. > >Lowrance sort of understandably declines to support stuff that is this >old. So does anyone know of a source for Lowrance repairs or upgrades or >of a web site with advice of keeping older Lowrance equipment going? I >am thinking of opening the case to reseat the connectors, etc. > >Thanks to anyone who can assist. It's a nice unit and would be a shame >to just toss it in the trash. > >(I realize this is not hard RV stuff but I did buy the GPS to use in my >-6A so it is relevant to RV flight ops.) > >Jim Oke >RV-6A C-GKGZ >Wpg., MB > > ________________________________________________________________________________
Date: Feb 10, 2006
Hi gang, The current explanations of the vernatherm have been the best in several years. This subject always comes up in cold weather, and several of our listers really do know how it works. Todays posts from Jeff Dowling and Dave Bristol seem to explain the operation of the v/t properly and concisely. I would like to add a bit of information if I may. I don't remember the RV type of the original posters question, but if it was an RV-4 ...... What else can I say. Every RV-4 wants to run at ~ 120 -130 deg. in the winter. On a miserable, hot summer day, we are lucky to see 195-200 deg. The very tight cowling on the -4 is overkill to the cooler, and the explanation about the bypassing of the oil seems to explain and confirm why the --4's oil temp is so low. I have had several RV-4's and have seen and performed several experiments. My current -4 has its cooler mounted to the rear baffle, and has a controllable flap on the rear(exhaust side) of the cooler. This has never, never worked well. In fact, it doesn't work at all. Because at normal flying speed, the air pressure entering the intake side of the cooler is so strong, it pushes the flap open a millimeter or two. This is enough to over-cool the oil. HOWEVER, on both my -4's the solution that always works is to partially or completely cover over the intake side of the cooler. PS Thanks Jeff and Dave. - Louis I Willig 1640 Oakwood Dr. Penn Valley, PA 19072 610 668-4964 RV-4, N180PF 190HP IO-360, C/S prop ________________________________________________________________________________
Date: Feb 10, 2006
I just finished an IO-540 rebuild a few weeks ago. I used http://www.aircraft-specialties.com/ to do my crank balancing/certification and inspection of steel parts. I found that their on-line catalog is about the best available, but A.E.R.O. had very slightly better overall prices for new and used engine parts, and noticably better in-stock status for the parts I needed. A.E.R.O. is at http://www.a-e-r-o.com. I worked with Jesse at the Granite City office. Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 830 hrs RV-10 #40059 under construction RV6 Flyer wrote: > > > Where can one buy Lycoming Parts on line? Did a Google search and not much > luck finding an outfit that can cross-reference old part numbers to new and > has a web site that you can order from. > > It looks like I have to do it the old fashioned way, pick up the phone, and > call. > > I did find what I was looking for. (Studs to mount a mag.) Want spares in > case I break one when I install my new P-Mags. > > It appears that there is a lack of new Lycoming part vendors on the > internet. Wonder is it has anything to do with UnApproved Parts getting > into the system. > > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 1,839 + Flying Hours So. CA, USA > http://SoCAL_WVAF.rvproject.com > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 10, 2006
Subject: Re: Anyone know of a good place
Any chance you were a F-4G jock or EWO? I worked ECM on the Wild Weasels at George AFB, CA 1978-82. I built and now fly a W-10 Wittman Tailwind, Ona Airpark WV (12V). Not sure where you are flying from, but KPMH at Portsmouth OH is a favorite spot for our locals. BRIAN ALLEY (N320WT) CARBON FIBER COMPOSITES 101 Caroline Circle Hurricane, WV 25526 304-562-6800 home 304-395-4932 cell How are you going to win by a nose if you don't stick out your neck? ________________________________________________________________________________
Subject: Aircraft/avionics wiring schematic software
Date: Feb 11, 2006
Listers, I am beginning work on the electrical system and avionics for an RV-7. As a result, I'm looking for information regarding what software packages are available to develop schematics and any feedback pertaining to use would also be helpful. Best regards, Bill Gill Lee's Summit, MO ________________________________________________________________________________
Date: Feb 11, 2006
Subject: Re: Aircraft/avionics wiring schematic software
In a message dated 2/11/2006 7:39:35 A.M. Pacific Standard Time, wgill10(at)comcast.net writes: I am beginning work on the electrical system and avionics for an RV-7. As a result, I'm looking for information regarding what software packages are available to develop schematics and any feedback pertaining to use would also be helpful. =========================================== The Nuckolls stuff was done in AutoCAD and so is mine. If you choose this way, I will be happy to give you a file of mine. GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Feb 11, 2006
Lowrance will giv you up to $225 towards a new unit that you can buy from a discounter such as Flight Essentials.com Ollie ----- Original Message ----- From: "John Fasching" <n1cxo320(at)salidaco.com> Sent: Friday, February 10, 2006 6:59 PM Subject: Re: RV-List: Lowrance GPS Tecnical Help > > Jim, > > I have one of those Lowarnce models and it works just fine....have it > connected to the Nav Aid wing leveler to fly a flight plan, tho' I now use > an AnywhereMap with a modern PDA, but keep the Lowarnce as back up...I > found > that the antenna placement is fairly fussy on the Lowrance...if everything > else is OK, try moving the antenna to various locations...if you still > have > the "flip up" cover- antenna connected, you might try removing it and > using > the remote feature to let the antenna get a better view of the sky. > > John > ----- Original Message ----- > From: "Jim Oke" <wjoke(at)shaw.ca> > To: > > > ________________________________________________________________________________
Date: Feb 11, 2006
www.flightessentials.net ----- Original Message ----- From: "Oliver Washburn" <ollie6a(at)earthlink.net> Sent: Saturday, February 11, 2006 11:59 AM Subject: Re: RV-List: Lowrance GPS Tecnical Help > > Lowrance will giv you up to $225 towards a new unit that you can buy from > a > discounter such as Flight Essentials.com > Ollie > ----- Original Message ----- > From: "John Fasching" <n1cxo320(at)salidaco.com> > To: > Sent: Friday, February 10, 2006 6:59 PM > Subject: Re: RV-List: Lowrance GPS Tecnical Help > > >> >> Jim, >> >> I have one of those Lowarnce models and it works just fine....have it >> connected to the Nav Aid wing leveler to fly a flight plan, tho' I now >> use >> an AnywhereMap with a modern PDA, but keep the Lowarnce as back up...I >> found >> that the antenna placement is fairly fussy on the Lowrance...if >> everything >> else is OK, try moving the antenna to various locations...if you still >> have >> the "flip up" cover- antenna connected, you might try removing it and >> using >> the remote feature to let the antenna get a better view of the sky. >> >> John >> ----- Original Message ----- >> From: "Jim Oke" <wjoke(at)shaw.ca> >> To: >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Feb 11, 2006
Yes, I'm interested in the CAD file. Thanks. Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com Sent: Saturday, February 11, 2006 11:35 AM Subject: Re: RV-List: Aircraft/avionics wiring schematic software In a message dated 2/11/2006 7:39:35 A.M. Pacific Standard Time, wgill10(at)comcast.net writes: I am beginning work on the electrical system and avionics for an RV-7. As a result, I'm looking for information regarding what software packages are available to develop schematics and any feedback pertaining to use would also be helpful. =========================================== The Nuckolls stuff was done in AutoCAD and so is mine. If you choose this way, I will be happy to give you a file of mine. GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Feb 11, 2006
Subject: How cheep can we get? (engine pre-heat)
Howdy all- every now & again I have a brain fart that I'd just like to share- pretty darn attractrive, eh? go: http://websites.expercraft.com/n51pw/?q=tips/tricks Whut the heck from The PossumWorks in TN Mark ________________________________________________________________________________
Subject: Re: How cheep can we get? (engine pre-heat)
Date: Feb 12, 2006
Interesting set up indeed! I have been using a simular process, only I use a Heat gun which puts out about 3 times the heat, and poke it in same place, takes just a few min and can feel the warm air comming out the front. Charlie H ________________________________________________________________________________
Subject: Hooker Harness Group Buy
Date: Feb 12, 2006
I may have missed some pertinent messages, but I wanted to be sure that the RV-List members knew about a group buy from Hooker Harnesses. This was put together by Wade Lively (an RV-8 builder) over on Doug Reeves VAF site. http://www.vansairforce.net/ On the left side of the VAF Home Page, go down to 'Today's Posts' under the FORUMS section, and pull up the thread titled "Group Discount on 5-Point Hooker Harnesses' to get all the information. The pricing is very attractive. The offer is strictly limited to RV/Rocket owners and builders. The deadline for responding to Wade is Noon Feb 18. Be sure and read the whole thread to make sure you are receiving the latest information. Hawkeye Hughes Skyote, RV-3 ________________________________________________________________________________
Subject: Parking Brake Valve
Date: Feb 12, 2006
Gentlemen - I have a Matco PV-1 Parking Brake Valve from Van's that I have decided not to use. New, in the box, never been mounted. $110 delivered. Neal (at) appaero (dot) com 244 Andrews Street Maxwell AFB, AL 36113 Home - 334-262-8993 Cell - 334-546-2033 ________________________________________________________________________________
Date: Feb 12, 2006
Mark, I thought I was cheap, but you got me there. We used to use 2 100W trouble lites stuffed inside the cowling on all the time winters in OR, and they keep temp right at 60+. Don't use the ones with the plastic guard, however, they DO melt... This winter I had an extra oil-filled radiator not using, so planted that baby on a shop creeper, and the height works out perfectly, easy to roll in and out of just behind the ex pipes. At the lowest setting it's using about 300W and keeps inside cowling toasty with a blanket on top. No waiting for warmup when flying time arrives, either... I do feel bad about the the $300/mo hangar having to absorb the power bill... Jerry ... in sunny Oregon Subject: RV-List: How cheep can we get? (engine pre-heat) --> RV-List message posted by: Fiveonepw(at)aol.com Howdy all- every now & again I have a brain fart that I'd just like to share- pretty darn attractrive, eh? go: http://websites.expercraft.com/n51pw/?q=tips/tricks Whut the heck from The PossumWorks in TN Mark ________________________________________________________________________________
Subject: Operating angle - RV6 Electric Trim
Date: Feb 12, 2006
Hi, If I understand all the different things I have read about the Electric Trim kit for the RV6 ... The operating angles are less due to the limited travel by the MAC 8A servo ... I am currently busy laying it all out... So before I commit myself to the installation ... I would like to hear first hand from anyone who does fly with the electric trim kit (with the servo in the elevator) ... What angles are needed to operate safely ?? When you did cut the hole in the spar for the rod at the back of the servo ...You must have got quite close to one of the rivets used to secure the elevator horn to the spar ... How close ?? Appreciate any feedback on this. Jan ________________________________________________________________________________
Date: Feb 12, 2006
Fiveonepw(at)aol.com wrote: >I liked the AC idea also- all I'm missing is the >compressor/evaporator/condensor & environmentally responsible freon > I thought the RV's already had AC, just open the vents, open the throttle, and pull back on the stick for 10 min or so and it should start to cool off just fine :) -- Chris W KE5GIX ________________________________________________________________________________
Subject: weather site
Date: Feb 12, 2006
In changing computers I have lost the excellent weather site that one of you RV'ers developed. (the one which shows current weather along any selected route) Could someone please give me the site again? Thanks. Jimmy RV8A ________________________________________________________________________________
Subject: Re: weather site
Date: Feb 12, 2006
www.rvproject,com/wx/ ----- Original Message ----- From: "Jimmy Hill" <hillstw(at)jhill.biz> Sent: Sunday, February 12, 2006 6:04 PM Subject: RV-List: weather site > > In changing computers I have lost the excellent weather site that one of > you RV'ers developed. (the one which shows current weather along any > selected route) > > Could someone please give me the site again? > > Thanks. > > Jimmy RV8A > > > ________________________________________________________________________________
Date: Feb 12, 2006
Oops, typed a comma "stead' of a dot www.rvproject.com/wx/ ----- Original Message ----- From: "Mannan J. Thomason" <mannanj(at)alltel.net> Sent: Sunday, February 12, 2006 6:24 PM Subject: Re: RV-List: weather site > > www.rvproject,com/wx/ > > > ----- Original Message ----- > From: "Jimmy Hill" <hillstw(at)jhill.biz> > To: "rv-list" > Sent: Sunday, February 12, 2006 6:04 PM > Subject: RV-List: weather site > > >> >> In changing computers I have lost the excellent weather site that one of >> you RV'ers developed. (the one which shows current weather along any >> selected route) >> >> Could someone please give me the site again? >> >> Thanks. >> >> Jimmy RV8A >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Feb 12, 2006
Subject: Re: Operating angle - RV6 Electric Trim
Jan, I have the MAC 8A servo in the elevator and don't remember having any problems with the installation. It works as advertised. I have not had any troubles with it at all and have never run out of trim authority. It's an RV6 with O-360 and Hartzell CS, which moves the CG forward and will affect the trim. Dave -6 So Cal (85 deg today, no preheaters here!) Jan wrote: > >Hi, > >If I understand all the different things I have read about the Electric Trim >kit for the RV6 ... The operating angles are less due to the limited travel >by the MAC 8A servo ... I am currently busy laying it all out... So before I >commit myself to the installation ... > >I would like to hear first hand from anyone who does fly with the electric >trim kit (with the servo in the elevator) ... What angles are needed to >operate safely ?? > >When you did cut the hole in the spar for the rod at the back of the servo >...You must have got quite close to one of the rivets used to secure the >elevator horn to the spar ... How close ?? > >Appreciate any feedback on this. > >Jan > > > > > > > > > ________________________________________________________________________________
Subject: FOR SALE: Blue Mountain EFIS/One
Date: Feb 12, 2006
I'm posting this for a friend... New ***Blue Mountain EFIS/One*** for sale. Save over $1000!!! Details here: http://www.vansairforce.com/community/showthread.php?p=34256 )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Feb 12, 2006
Keep in mind that heat guns and hair driers can make sparks... Dave charles heathco wrote: > >Interesting set up indeed! I have been using a simular process, only I use a Heat gun which puts out about 3 times the heat, and poke it in same place, takes just a few min and can feel the warm air comming out the front. Charlie H > > > > > > > > > ________________________________________________________________________________
Date: Feb 13, 2006
Jan, I agree with Dave - the Matronics' servo has worked well since our 1st flight in 2001. Chuck Rowbotham RV-8A >From: "D.Bristol" <dbris200(at)sbcglobal.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Operating angle - RV6 Electric Trim >Date: Sun, 12 Feb 2006 17:46:02 -0800 > > >Jan, > >I have the MAC 8A servo in the elevator and don't remember having any >problems with the installation. It works as advertised. I have not had >any troubles with it at all and have never run out of trim authority. >It's an RV6 with O-360 and Hartzell CS, which moves the CG forward and >will affect the trim. > >Dave -6 So Cal (85 deg today, no preheaters here!) > > >Jan wrote: > > > > >Hi, > > > >If I understand all the different things I have read about the Electric >Trim > >kit for the RV6 ... The operating angles are less due to the limited >travel > >by the MAC 8A servo ... I am currently busy laying it all out... So >before I > >commit myself to the installation ... > > > >I would like to hear first hand from anyone who does fly with the >electric > >trim kit (with the servo in the elevator) ... What angles are needed to > >operate safely ?? > > > >When you did cut the hole in the spar for the rod at the back of the >servo > >...You must have got quite close to one of the rivets used to secure the > >elevator horn to the spar ... How close ?? > > > >Appreciate any feedback on this. > > > >Jan > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 13, 2006
I used the Express SCH software for circuit documentation. It is free, easy to learn and works well. Here is the URL:. http://www.expresspcb.com/ExpressPCBHtm/Free_schematic_software.htm Leland In a message dated 2/11/2006 7:39:35 A.M. Pacific Standard Time, wgill10(at)comcast.net writes: I am beginning work on the electrical system and avionics for an RV-7. As a result, I'm looking for information regarding what software packages are available to develop schematics and any feedback pertaining to use would also be helpful. ________________________________________________________________________________
Date: Feb 13, 2006
Thanks Randy, Finally got hold of the WW folks who said the same thing as you did. Ordered a new Jihostroj from them. Interestingly, the folks at Van's insisted their MT governor should work. Thanks for the reply. Charlie Brame RV-6A N11CB San Antonio ----------------------------------------------------- > From: "Randy Lervold" > Subject: Re: RV-List: Governor for Whirlwind Prop > > > > WW recommends the Jihostroj P920 which sells for approx $1,250. Van > > sells the MT P860-4 governor (also made by Jihostroj) for $1050. > > > > Will Van's MT governor work on a WW 150-151 prop which requires a > > pressure of 450-475 PSI? Do MT props require the same high pressure to > > operate? > > Due to a smaller piston in the hub the WW 150-151 require the governor > pressure to be in the 425 psi range rather than the 325-350 range. WW buys > the Jihostroj governors specially modified for the higher pressure, > therefore the MT version won't work for the WW 150-151. > > Randy Lervold > > ________________________________________________________________________________
Date: Feb 13, 2006
Subject: Another Source For AHRS for RVs?
Those still looking for a solid state AHRS unit might want to pay a visit to <http://www.stratomaster.uk.com/>. Click on "products" then the "maxi-singles" item. Quite a wide line of instruments from AHRS with or without heading, digital altimeters, airspeeds, engine instruments, engine monitors and the like. Can any PFA members comment on the quality, utility, etc. of this company's offerings? Jim Oke RV-3 & -6A Wpg., MB ________________________________________________________________________________
Subject: Sanding canopy plexy edges
Date: Feb 13, 2006
Got my feet wet with the canopy cutting this weekend. I'm sure my hand will get steadier with the cutoff wheel as I get experience, but my edges are quite rough. Sanding them smooth by hand is beyond tedious - it will take me the rest of the year. Is it OK to use an electrical orbital sander ? I'm a bit worried that the orbital motion might crack or chip the plexy. Would it be better to use a belt sander ? What have others used ? __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Feb 13, 2006
I did mine with a belt sander. Worked fine. Terry Got my feet wet with the canopy cutting this weekend. I'm sure my hand will get steadier with the cutoff wheel as I get experience, but my edges are quite rough. Sanding them smooth by hand is beyond tedious - it will take me the rest of the year. Is it OK to use an electrical orbital sander ? I'm a bit worried that the orbital motion might crack or chip the plexy. Would it be better to use a belt sander ? What have others used ? ________________________________________________________________________________
Date: Feb 13, 2006
> > I did mine with a belt sander. Worked fine. > > Terry There needs to be a caution here. If the edge is heated a bit too much, it will attempt to expand, and since it is now softer, it will relieve itself to a low stress condition. As the edge cools, it will be put into tension as it "hardens" and tries to shrink. This tension will remain permanently in the edge, potentially a bad thing. However you finish the edge, make sure it is not getting warm to the touch. Plexi has a very large coefficient of thermal expansion. Alex Peterson RV6-A N66AP 714 hours Maple Grove, MN ________________________________________________________________________________
Date: Feb 13, 2006
Subject: Re: Sanding canopy plexy edges
I used a hand block. Start with 60 grit and work finer. Dosent take that long if your inital was pretty straight. Dave Leonard On 2/13/06, Gerry Filby wrote: > > > Got my feet wet with the canopy cutting this weekend. I'm sure > my hand will get steadier with the cutoff wheel as I get > experience, but my edges are quite rough. Sanding them smooth > by hand is beyond tedious - it will take me the rest of the year. > > Is it OK to use an electrical orbital sander ? I'm a bit > worried that the orbital motion might crack or chip the plexy. > Would it be better to use a belt sander ? What have others used ? > > __g__ > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > -- Dave Leonard Turbo Rotary RV-6 N4VY http://members.aol.com/_ht_a/rotaryroster/index.html http://members.aol.com/_ht_a/vp4skydoc/index.html ________________________________________________________________________________
Subject: e-books
Date: Feb 13, 2006
e-book downloads are now available on Builder's Bookstore. Builder's Bookstore gives you a choice of receiving books either as traditional paper books shipped by UPS or mail, or as an instant internet download into your computer. This new feature will be a great benefit to international customers who no longer have to pay huge shipping costs or wait weeks for their orders. Our e-Book formats are full size, full color .pdf documents. Download times average 5 minutes for a 200 page book over a medium speed non-dialup connection. Successful downloads and image quality is guaranteed. A Free sample download of Aircraft Propeller Maintenance is available on this page. http://www.buildersbooks.com/all_about_ebooks.htm Try it and see if you like receiving books in this way. Items currently available as e-books are: 24 Years of the RVator Aeroelectric Connection Construction of Steel Tube Fuselages How to Paint Your Own Airplane Composite Basics & How To Cover an Aircraft will be available in 2-3 days, with many more coming in the next few weeks. Andy Gold Builder's Bookstore www.buildersbooks.com 800 780-4115 970 887-2207 --always on the edge of customer service and today's technology ________________________________________________________________________________
Subject: i39 Flyin Feb. 25th. Let's push 100 again
Date: Feb 14, 2006
OK, the final plans are underway for this years flyin. As attendees from the last two flyin's can attest, this is just a down home hangout kinda flyin. No vendors, no forum, no tickets to buy, no stucture at all, just a ton of RV's (we've pushed 100 the last two years) along with the biggest hits (plural) two Hooters girls with 1000 wings. Again, the lunch is free, donations accepted and please tip (money only) the Hooters Girls. We will have free coffee and donuts to start the day off, again free but donations accepted. Start time is light thirty, close is dark thirty. For those who fly in, watch the army depot on the east side of i39. If you drive in (yes, people actually drive in from as far away an Michigan), get off on exit 77, make a right then a right between the BP and Shelll, then follow the signs. We are once again looking forward to a wonderful formation flight demonstation from FFI cardholding members of TeamRV and OVRVators. Look for another Oshkosh quality demonstation. AnywhereMap is again the lead sponsor. We will once again be giving away the entire system, no hardware, at the end of the flyin. Van's also is donating along with Cleaveland Tool, Avery Tool. I will post additional door prize donations as they hit the door. Put is on your calander, I'm looking forward to another great flyin. My cell is 859 625-2844, home is 859 369-7582. Comfort Suites 859 624-0770 Next to Cracker Barrel Hampton Inn 859 626-1002 Next to Bob Evans Holiday Inn Express & Suites 859 624-4088 Walking distance Bob Evans Best Western 859 623-9220 Same as above Jameson Inn 859 623-0063 Bob Evans shares parking lot La Quinta 859 623-9121 Near Cracker Barrel Ramada Limited 859 626-8676 Same as above Dana Overall Richmond, KY i39 RV-7 slider, Imron black, "Black Magic" ________________________________________________________________________________
Date: Feb 14, 2006
gerf(at)gerf.com wrote: > Sanding them smooth by hand is beyond tedious - it will take me the rest of the year......What have others used ? > Gerry, I used this specially designed hand tool to "scrape" the edges of the plexiglass smooth and renders an almost polished like quality with not too much effort in a relatively short amount of time. Any remaining scratches on the edge surface can then (if required) be easily blended out with 600 (or finer) grit paper. I think you just may find this tool to be a real timesaver. http://tinyurl.com/7aozs Rick Galati RV-6A "Darla" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=12047#12047 ________________________________________________________________________________
Date: Feb 14, 2006
For what it's worth I used a Vixen file to smooth away the cutting marks and then used a sanding block and progressively finer grit sandpaper to finish the job. Steve Soule N227RV RV-6A 390 hours -----Original Message----- Gerry, I used this specially designed hand tool to "scrape" the edges of the plexiglass smooth and renders an almost polished like quality with not too much effort in a relatively short amount of time. ________________________________________________________________________________
Subject: NEW BLUE MOUNTAIN EFIS LITE G4
Date: Feb 14, 2006
From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com>
I just received my March issue of Kitplanes and saw the Blue Mountain Avionics ad. It appears that the Lite and Lite Plus will have 3-D terrain at the same price as the G3. I immediately went to their website but didn't find any information on the new models. Does anyone know of any online information on the G4? ________________________________________________________________________________
Date: Feb 14, 2006
I used a standard 1" paint scraper, but with the edge ground flat so the barb formed by the grinding process does a nice job of shaving off the rough edges. Use a scrap piece of plexi to test it. The result I got was that looking straight into the shaved edge, it is nice and translucent. Worked great! Henry Hore, -6A, C-GELS (Tip-up, Sold) ________________________________________________________________________________
Date: Feb 14, 2006
Subject: Re: Spamblocker problem - Matt please read
On 5:51:34 2006-02-14 "Alex Peterson" wrote: > Very recently, my earthlink spamblocker began blocking messages sent > to me from the matronics lists, but only those that I post to the > lists. Everyone else's gets through no problem. > ... > Is anyone else having this problem? Any ideas Matt? How about setting a rule in your email program that saves a copy into your "RV-List" folder when you send it? That way you get a copy stored locally, and you can let your spam filter do whatever it wants to with the other copy. -Rob ________________________________________________________________________________
Date: Feb 14, 2006
I used a standard 1" paint scraper, but with the scraping edge ground flat so that a barb is formed that will do the scraping function. Use a piece of scrap plexi to test it. On my Tip-up, all the finished edges were translucent when looking straight into them.-Worked great! Henry Hore, -6A, C-GELS (Sold, for med. reasons). ________________________________________________________________________________
Date: Feb 14, 2006
Subject: Garmin 296/396 plug
The cigarette lighter adapter plug for my Garmin 296 pulled apart. This is the connector that plugs into the Garmin. Has anyone else had this problem and solved it shy of buying a new $30 adapter from Garmin? The plug fits pretty tightly and I fear that a new plug would just pull apart again. Leland RV9A 73 hours ________________________________________________________________________________
Date: Feb 14, 2006
Yes, mine came apart too. Garmin gave me another one, gratis. Dave Saylor AirCrafters LLC 831-722-9141 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Leland Sent: Tuesday, February 14, 2006 9:39 AM Subject: SPAM: RV-List: Garmin 296/396 plug The cigarette lighter adapter plug for my Garmin 296 pulled apart. This is the connector that plugs into the Garmin. Has anyone else had this problem and solved it shy of buying a new $30 adapter from Garmin? The plug fits pretty tightly and I fear that a new plug would just pull apart again. Leland RV9A 73 hours ________________________________________________________________________________
Date: Feb 14, 2006
Gerry, A process that worked will for me, with out the danger of getting the plexi too warm, was to use a scraper. I made a scraper with a curved working edge from a piece of .040 aluminum. The metal edges in the working area are left rather sharp and the scraper is pulled along the edge of the plexi. Found this to remove material faster than block sanding. Takes a little practice to get the right technique.The curved edge vs. a flat edge was used to give the plexi a more finished edge. Final finish was with sanding. Dale Ensing ________________________________________________________________________________
Date: Feb 14, 2006
It has only happened to me TWICE! I contacted Garmin re: the very poor design and they have had problems with many customers. I think they sent me a free replacement and I think I also purchased one on ebay at a discount. The solution to this is to grab very close to the body with enough pressure and be focused on what you are doing with a light wiggle and direct pull. This will extend the life of the plug but will not solve the problem. It is just a poor design. Robin RV-6A 250 hours, 2 Garmin cords (so far) ________________________________________________________________________________
Date: Feb 14, 2006
My low tech solution is never take the plug out, or at least as rarely as possible :) g > > > It has only happened to me TWICE! > I contacted Garmin re: the very poor design and they have had problems > with many customers. I think they sent me a free replacement and I think > I also purchased one on ebay at a discount. > The solution to this is to grab very close to the body with enough > pressure and be focused on what you are doing with a light wiggle and > direct pull. This will extend the life of the plug but will not solve > the problem. It is just a poor design. > > Robin > RV-6A 250 hours, 2 Garmin cords (so far) > ________________________________________________________________________________
Subject: Re: NEW BLUE MOUNTAIN EFIS LITE G4
Date: Feb 14, 2006
Look Here -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=12179#12179 ________________________________________________________________________________
Subject: Re: i39 Flyin Feb. 25th. Let's push 100 again
Date: Feb 14, 2006
Dana, Where is the fly in? Dick Marti RV8 N233M the fast one ----- Original Message ----- From: "Dana Overall" <bo124rs(at)hotmail.com> Sent: Tuesday, February 14, 2006 6:05 AM Subject: RV-List: i39 Flyin Feb. 25th. Let's push 100 again > > OK, the final plans are underway for this years flyin. As attendees from > the last two flyin's can attest, this is just a down home hangout kinda > flyin. No vendors, no forum, no tickets to buy, no stucture at all, just > a > ton of RV's (we've pushed 100 the last two years) along with the biggest > hits (plural) two Hooters girls with 1000 wings. Again, the lunch is > free, > donations accepted and please tip (money only) the Hooters Girls. We will > have free coffee and donuts to start the day off, again free but donations > accepted. Start time is light thirty, close is dark thirty. > > For those who fly in, watch the army depot on the east side of i39. If > you > drive in (yes, people actually drive in from as far away an Michigan), get > off on exit 77, make a right then a right between the BP and Shelll, then > follow the signs. > > We are once again looking forward to a wonderful formation flight > demonstation from FFI cardholding members of TeamRV and OVRVators. Look > for > another Oshkosh quality demonstation. > > AnywhereMap is again the lead sponsor. We will once again be giving away > the entire system, no hardware, at the end of the flyin. Van's also is > donating along with Cleaveland Tool, Avery Tool. I will post additional > door prize donations as they hit the door. > > Put is on your calander, I'm looking forward to another great flyin. > > My cell is 859 625-2844, home is 859 369-7582. > > > Comfort Suites > 859 624-0770 > Next to Cracker Barrel > > Hampton Inn > 859 626-1002 > Next to Bob Evans > > Holiday Inn Express & Suites > 859 624-4088 > Walking distance Bob Evans > > > Best Western > 859 623-9220 > Same as above > > Jameson Inn > 859 623-0063 > Bob Evans shares parking lot > > La Quinta > 859 623-9121 > Near Cracker Barrel > > Ramada Limited > 859 626-8676 > Same as above > > > Dana Overall > Richmond, KY i39 > RV-7 slider, Imron black, "Black Magic" > > > ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Cc: "Steve Eberhart"
Date: Feb 14, 2006
Steve Eberhart and I plan to be there if weather permits safe travel. Will arrive early. Wheelpants are set low and need a smooth parking spot. Get the hooter girls warmed up. Tell Elaine we are coming. Get the whole airport ready. We might bring some others from our EAA 21 group along too. Dana, if you can just get the things right with the man controlling the weather -- and -- and the hooter girls. AND We want some krispy kreme donuts too. Sure, we will chip in something to help you keep from loosing your shirt. Lets just pray for good weather. Indiana Larry, RV7 SunSeeker 85+ hours flying ----- Original Message ----- From: "Dana Overall" <bo124rs(at)hotmail.com> Sent: Tuesday, February 14, 2006 6:05 AM Subject: RV-List: i39 Flyin Feb. 25th. Let's push 100 again > > OK, the final plans are underway for this years flyin. As attendees from > the last two flyin's can attest, this is just a down home hangout kinda > flyin. No vendors, no forum, no tickets to buy, no stucture at all, just > a > ton of RV's (we've pushed 100 the last two years) along with the biggest > hits (plural) two Hooters girls with 1000 wings. Again, the lunch is > free, > donations accepted and please tip (money only) the Hooters Girls. We will > have free coffee and donuts to start the day off, again free but donations > accepted. Start time is light thirty, close is dark thirty. snip ________________________________________________________________________________
Date: Feb 14, 2006
Dick, look on the subject line:-) i39 Richmond/Madison Co. Hope to see all here. Dana Overall Richmond, KY i39 RV-7 slider, Imron black, "Black Magic" >From: "dick martin" <martin(at)gbonline.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: i39 Flyin Feb. 25th. Let's push 100 again >Date: Tue, 14 Feb 2006 20:58:21 -0600 > > >Dana, > >Where is the fly in? > >Dick Marti >RV8 N233M >the fast one >----- Original Message ----- >From: "Dana Overall" <bo124rs(at)hotmail.com> >To: >Sent: Tuesday, February 14, 2006 6:05 AM >Subject: RV-List: i39 Flyin Feb. 25th. Let's push 100 again > > > > > > OK, the final plans are underway for this years flyin. As attendees >from > > the last two flyin's can attest, this is just a down home hangout kinda > > flyin. No vendors, no forum, no tickets to buy, no stucture at all, >just > > a > > ton of RV's (we've pushed 100 the last two years) along with the biggest > > hits (plural) two Hooters girls with 1000 wings. Again, the lunch is > > free, > > donations accepted and please tip (money only) the Hooters Girls. We >will > > have free coffee and donuts to start the day off, again free but >donations > > accepted. Start time is light thirty, close is dark thirty. > > > > For those who fly in, watch the army depot on the east side of i39. If > > you > > drive in (yes, people actually drive in from as far away an Michigan), >get > > off on exit 77, make a right then a right between the BP and Shelll, >then > > follow the signs. > > > > We are once again looking forward to a wonderful formation flight > > demonstation from FFI cardholding members of TeamRV and OVRVators. Look > > for > > another Oshkosh quality demonstation. > > > > AnywhereMap is again the lead sponsor. We will once again be giving >away > > the entire system, no hardware, at the end of the flyin. Van's also is > > donating along with Cleaveland Tool, Avery Tool. I will post additional > > door prize donations as they hit the door. > > > > Put is on your calander, I'm looking forward to another great flyin. > > > > My cell is 859 625-2844, home is 859 369-7582. > > > > > > > > > > > > > > > > Comfort Suites > > 859 624-0770 > > Next to Cracker Barrel > > > > Hampton Inn > > 859 626-1002 > > Next to Bob Evans > > > > Holiday Inn Express & Suites > > 859 624-4088 > > Walking distance Bob Evans > > > > > > Best Western > > 859 623-9220 > > Same as above > > > > Jameson Inn > > 859 623-0063 > > Bob Evans shares parking lot > > > > La Quinta > > 859 623-9121 > > Near Cracker Barrel > > > > Ramada Limited > > 859 626-8676 > > Same as above > > > > > > Dana Overall > > Richmond, KY i39 > > RV-7 slider, Imron black, "Black Magic" > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Tip Tanks
Date: Feb 15, 2006
I have started to build my own tip tanks and would like to know how/what/where of tank vents. or maybe what the Van's ones have got ? Thanks Trevor Mills 80605 ________________________________________________________________________________
Date: Feb 15, 2006
>From: "Terry Watson" <terry(at)tcwatson.com> > > >OK, now we are getting close. What state? > >Terry OK Terry, this is turning into something like "Where's Waldo":-) Let's go here i39......... http://www.airnav.com/airport/I39 tranlates into Richmond, Kentucky, 20 miles south of Lexington, KY pretty much smack dab in the middle of a two hour flight from something like 27-28 states. Sorry, couldn't resist:-) Comon' down, over, up or whatever. Dana Overall Richmond, KY i39 RV-7 slider, Imron black, "Black Magic" > ________________________________________________________________________________
Date: Feb 15, 2006
Subject: Re: Tip Tanks
IIRC, the tiptank vents for the tanks that Vans sells (Johannsen made them for Vans) were integrated in to the inboard wall of the tanks just forward of the fuel cap and stuck out the bottom about 1/2" with a forward facing angle cut to pressurize the vents...made of 1/4" alum tube. I have a set and have plumbed them into the existing wing tanks. Contact me directly, and I can get you some photos...... -----Original Message----- >From: Trevor Mills <millstrj(at)ozemail.com.au> >Sent: Feb 15, 2006 6:18 AM >To: rv-list(at)matronics.com >Subject: RV-List: Tip Tanks > > >I have started to build my own tip tanks and would like to know how/what/where of tank vents. or maybe what the Van's ones have got ? > >Thanks > >Trevor Mills 80605 > > > > > > > ________________________________________________________________________________
Subject: For Sale: Electric Attitude Gyro
Date: Feb 15, 2006
For Sale: Electric Attitude Gyro One Ray Allen RCA26AK-4 rebuilt by Kelly Manufacturing Company 1/10/2006. I have all documentation and it is under warrantee till 1/10/2007. $1,200 or best offer. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy 704-362-0005 willfly(at)carolina.rr.com ________________________________________________________________________________
Date: Feb 15, 2006
Date: Feb 15, 2006
Subject: Re: For Sale: Electric Attitude Gyro
guess I should have read Electric! -----Original Message----- >From: Steve Glasgow <willfly(at)carolina.rr.com> >Sent: Feb 15, 2006 8:53 AM >To: RV-List Digest Server >Subject: RV-List: For Sale: Electric Attitude Gyro > > >For Sale: Electric Attitude Gyro > > >One Ray Allen RCA26AK-4 rebuilt by Kelly Manufacturing Company 1/10/2006. I >have all documentation and it is under warrantee till 1/10/2007. > > >$1,200 or best offer. > > >Steve Glasgow-Cappy >N123SG RV-8 >Cappy's Toy >704-362-0005 >willfly(at)carolina.rr.com > > > > > > > ________________________________________________________________________________
Date: Feb 15, 2006
Is it Electric? Is it lighted? Is it set up for 8 degree panel tilt? -----Original Message----- >From: Steve Glasgow <willfly(at)carolina.rr.com> >Sent: Feb 15, 2006 8:53 AM >To: RV-List Digest Server >Subject: RV-List: For Sale: Electric Attitude Gyro > > >For Sale: Electric Attitude Gyro > > >One Ray Allen RCA26AK-4 rebuilt by Kelly Manufacturing Company 1/10/2006. I >have all documentation and it is under warrantee till 1/10/2007. > > >$1,200 or best offer. > > >Steve Glasgow-Cappy >N123SG RV-8 >Cappy's Toy >704-362-0005 >willfly(at)carolina.rr.com > > > > > > > ________________________________________________________________________________
Date: Feb 15, 2006
Subject: vernatherm success
I have a friend who has been fighting high oil temps since day one. He has relocated the oil cooler, and checked the operation of the vernatherm by heating it in boiling water and checking the seat. Nothing has seemed to helped the situation. I am wondering if there is anyone out there who cured their oil temp woes by replacing the vernatherm. The one he has seems to operate correctly, but who knows if it may be getting stuck. I'm just trying to get an idea of the success rate of lowering oil temps by simply replacing the vernatherm. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Subject: vernatherm or vernitherm success
Date: Feb 15, 2006
Bob: Not sure of the spelling. Found both when I did an internet search so I am adding both ways of spelling to the subject. I know of one airplane that replacing the vernatherm fixed the problem. Try this link for story and photos of good vrs bad vernitherm : http://www.rvproject.com/20050409.html Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,839 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: Bob J <rocketbob(at)gmail.com> Subject: RV-List: vernatherm success Date: Wed, 15 Feb 2006 09:30:17 -0500 I have a friend who has been fighting high oil temps since day one. He has relocated the oil cooler, and checked the operation of the vernatherm by heating it in boiling water and checking the seat. Nothing has seemed to helped the situation. I am wondering if there is anyone out there who cured their oil temp woes by replacing the vernatherm. The one he has seems to operate correctly, but who knows if it may be getting stuck. I'm just trying to get an idea of the success rate of lowering oil temps by simply replacing the vernatherm. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Date: Feb 15, 2006
Subject: Spamblocker problem - Matt please read
On 19:08:54 2006-02-14 "Alex Peterson" wrote: > > How about setting a rule in your email program that saves a > > copy into your "RV-List" folder when you send it? That way > > you get a copy stored locally, and you can let your spam > > filter do whatever it wants to with the other copy. > > Rob, these are getting snagged at the Earthlink server, not my > outlook. Yes, I know... The thought was to have Outlook just save a copy of what you've sent to the list, *before* it leaves your computer. We're all getting the posts to the 'list, it's just earthlink that's being silly and preventing them getting back to you. My solution was to keep a copy before earthlink sees it, and then let earthlink do whatever it wants to when it comes back from the 'list. I know, it shouldn't have to work that way, but it might be easier than getting Earthlink to change how they block email... :) -Rob ________________________________________________________________________________
Date: Feb 15, 2006
Subject: Re: vernatherm or vernitherm success
Thanks Gary, that was exactly what I was looking for. Regards, Bob On 2/15/06, RV6 Flyer wrote: > > > Bob: > > Not sure of the spelling. Found both when I did an internet search so I > am > adding both ways of spelling to the subject. > > I know of one airplane that replacing the vernatherm fixed the problem. > > Try this link for story and photos of good vrs bad vernitherm : > http://www.rvproject.com/20050409.html > > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 1,839 + Flying Hours So. CA, USA > http://SoCAL_WVAF.rvproject.com > > ________________________________________________________________________________
Date: Feb 15, 2006
Subject: Re: vernatherm success
At 07:30 AM 2/15/2006, you wrote: > >I have a friend who has been fighting high oil temps since day one. He has >relocated the oil cooler, and checked the operation of the vernatherm by >heating it in boiling water and checking the seat. Nothing has seemed to >helped the situation. I am wondering if there is anyone out there who cured >their oil temp woes by replacing the vernatherm. I have no vernatherm but fought high oil temps. I solved it by reducing cabin heat hose clutter, opening the bottom cowl to let air out better and adding cowl louvers. Best recollection is that it dropped the oil temp 40 deg F or so. http://home.pcisys.net/~ronlee/RV6A/Cowl_Louver_Small.jpg Ron Lee ________________________________________________________________________________
Date: Feb 15, 2006
Subject: Re: Re: Garmin 296/396 plug
Great input. I just called Garmin and they are sending me a warranty replacement Cigarette Lighter Adapter. They even offered to send it 2-day air. Garmin is working on the problem and I may possibly receive one with an improved plug. Leland Yes, mine came apart too. Garmin gave me another one, gratis. Dave Saylor AirCrafters LLC 831-722-9141 ________________________________________________________________________________
Date: Feb 15, 2006
Subject: Vernatherm
A Google search turned up this website for the company that makes the Vernatherm, there's some good info there. http://www.rostravernatherm.com/index.htm Also, some good high temp troubleshooting information at Sacramento Sky Ranch: http://www.sacskyranch.com/eng18.htm Dave B. ________________________________________________________________________________
Date: Feb 15, 2006
Subject: ELT MOUNTING ARROW
Lister's I received my ACK E-01 ELT today to be installed in my RV6-A. The installation manual said the ELT need to be mounted with the arrow on the case pointed in the direction of flight. I know I have seen many of them mounted vertical (the arrow pointed up). Can it be mounted vertical??? Thanks Jerry Davis Glen Carbon.Ill (almost done) ________________________________________________________________________________
Date: Feb 15, 2006
Not unless you plan on crashing upside down. Arrow forward is necessary to orientate the G- switch in the proper way. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jared davis Sent: Wednesday, February 15, 2006 7:12 PM Subject: RV-List: ELT MOUNTING ARROW Lister's I received my ACK E-01 ELT today to be installed in my RV6-A. The installation manual said the ELT need to be mounted with the arrow on the case pointed in the direction of flight. I know I have seen many of them mounted vertical (the arrow pointed up). Can it be mounted vertical??? Thanks Jerry Davis Glen Carbon.Ill (almost done) ________________________________________________________________________________
Subject: Re: ELT MOUNTING ARROW
Date: Feb 16, 2006
The arrow on the ELT indicates the direction in which the ELT will respond to a rapid deceleration, i.e., a crash. If you plan to have all crashes belly first than point the arrow up, otherwise it might be better to follow the manufacturers directions. Just a suggestion. -- Harry Crosby RV-6 N16CX, 181 hours -------------- Original message ---------------------- From: Jared davis <jsd41(at)sbcglobal.net> > > Lister's > I received my ACK E-01 ELT today to be installed in my RV6-A. The > installation manual said the ELT need to be mounted with the arrow on the case > pointed in the direction of flight. > I know I have seen many of them mounted vertical (the arrow pointed up). Can > it be mounted vertical??? > Thanks > Jerry Davis Glen Carbon.Ill (almost done) > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 15, 2006
It can be mounted any way you like, but it will only WORK if the arrow is forward. :-) Dave Jared davis wrote: > >Lister's > I received my ACK E-01 ELT today to be installed in my RV6-A. The installation manual said the ELT need to be mounted with the arrow on the case pointed in the direction of flight. > I know I have seen many of them mounted vertical (the arrow pointed up). Can it be mounted vertical??? > Thanks > Jerry Davis Glen Carbon.Ill (almost done) > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 15, 2006
HI Jarard Just mounted mine, my understanding is that ELT longitudnal axis must be aligned with direction of flight to ensure that the "G" switch operates properly, note that on a helicopter the ELT is tilted down 45 degrees. If you mount your ELT vertically it probably would not activate. Cirrus aircraft have similiar problem when they descend vertically under their parachute with a horizontally mounted ELT, they require manual ELT activation on descent (wonder if I would remember that). George in Langley BC Jared davis wrote: > >Lister's > I received my ACK E-01 ELT today to be installed in my RV6-A. The installation manual said the ELT need to be mounted with the arrow on the case pointed in the direction of flight. > I know I have seen many of them mounted vertical (the arrow pointed up). Can it be mounted vertical??? > Thanks > Jerry Davis Glen Carbon.Ill (almost done) > > > > > ________________________________________________________________________________
Date: Feb 16, 2006
It MUST be mounted with the ARROW pointing in the direction of FLIGHT. You are required to do an ELT inspection once a year. Read FAR 91.207(d). The inspection of the installation is part of the REQUIRED once a year check. You MUST also do the inspection and test the "G" switch per FAR 91.207(d). All inspections must be recorded. If you get RAMP CHECKED and the FAA ASI from the FSDO asks to see the record, you will be required to produce it. If you have a LOG entry that the inspection has been done and it is not MOUNTED CORRECTLY, there will be a VIOLATION for falsifying records. Gary A. Sobek FAA DAR Function Code 46 EAA TC FAA A&P "My Sanity" RV-6 N157GS O-320 Hartzell, 1,839 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: Jared davis <jsd41(at)sbcglobal.net> Subject: RV-List: ELT MOUNTING ARROW Date: Wed, 15 Feb 2006 16:11:56 -0800 (PST) Lister's I received my ACK E-01 ELT today to be installed in my RV6-A. The installation manual said the ELT need to be mounted with the arrow on the case pointed in the direction of flight. I know I have seen many of them mounted vertical (the arrow pointed up). Can it be mounted vertical??? Thanks Jerry Davis Glen Carbon.Ill (almost done) ________________________________________________________________________________
Date: Feb 15, 2006
In a message dated 2/15/2006 4:36:39 P.M. Pacific Standard Time, HCRV6(at)comcast.net writes: The arrow on the ELT indicates the direction in which the ELT will respond to a rapid deceleration, i.e., a crash ====================================== It probably bears mentioning here that it is quite common for ELTs to NOT activate during crashes even when mounted properly and the aircraft crashed properly. One might be wise to include in their checklist a manual activation of the ELT the instant you declare an emergency. GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Feb 16, 2006
If trying [WHOOP] to talk to [WHOOP] ATC on the same freq, [WHOOP] it would be a little distracting, no [WHOOP]? -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Vanremog(at)aol.com said: > > > In a message dated 2/15/2006 4:36:39 P.M. Pacific Standard Time, > HCRV6(at)comcast.net writes: > > The arrow on the ELT indicates the direction in which the ELT will > respond > to a rapid deceleration, i.e., a crash > > > ====================================== > > It probably bears mentioning here that it is quite common for ELTs to NOT > activate during crashes even when mounted properly and the aircraft > crashed > properly. One might be wise to include in their checklist a manual > activation > of the ELT the instant you declare an emergency. > > GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) > > ________________________________________________________________________________
Subject: Re: RV-7 Defog fans
Date: Feb 16, 2006
I installed two small (2-1/4") computer fans on the glare shield of my slider equipped 6a. I mounted the fans on approximately 3-1/2" x 3" rectangles of .032 aluminium sheet material. The squares have small tabs bent on the front edge that slip into and under the slightly smaller dimensioned glare shield fan openings. A 6-32 plate nut at the rear edge of the opening allows the fans to be held in place with one screw each. Remove screw, tilt up the fan and lift it out. A short wire with an insulated spade connection allows for disconnection. Some screen material over the fan opening makes them look good and should keep junk out of the fans. A small switch on the panel handles the small current required As described below no ducting etc. needed. This aircraft has yet to fly so actual defog performance is as yet an unknown. Pictures available on request. I think this would be somewhat harder to do with the tip up canopy. Jim in Kelowna > > Someone requested photos of defog fans. Not much to see. Attached to glare > shield...no ducts, just cabin air sucked under panel. > ________________________________________________________________________________
Date: Feb 16, 2006
Subject: RV-7 Defog fans
-----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Jewell Sent: Thursday, February 16, 2006 22:31 Subject: Re: RV-List: RV-7 Defog fans I installed two small (2-1/4") computer fans on the glare shield of my slider equipped 6a. I mounted the fans on approximately 3-1/2" x 3" rectangles of .032 aluminium sheet material. The squares have small tabs bent on the front edge that slip into and under the slightly smaller dimensioned glare shield fan openings. A 6-32 plate nut at the rear edge of the opening allows the fans to be held in place with one screw each. Remove screw, tilt up the fan and lift it out. A short wire with an insulated spade connection allows for disconnection. Some screen material over the fan opening makes them look good and should keep junk out of the fans. A small switch on the panel handles the small current required As described below no ducting etc. needed. This aircraft has yet to fly so actual defog performance is as yet an unknown. Pictures available on request. I think this would be somewhat harder to do with the tip up canopy. Jim in Kelowna > > Someone requested photos of defog fans. Not much to see. Attached to > glare shield...no ducts, just cabin air sucked under panel. > -- 02/16/2006 -- 02/16/2006 ________________________________________________________________________________
Date: Feb 17, 2006
Using a defogger is something I've given thought to, but am not sure how necessary it really is. I'd like to hear from frequent flyers who have NO defogging installed and get some reports about them ever wishing they had them. Vern W. ________________________________________________________________________________
Cc:
Subject: Virus protection
Date: Feb 17, 2006
Hope everyone has good virus prot updating. I have had a new update downloaded from Norton last 6 morn in a row, ( 2 on wed) Usual is 2 per wk on average. Be alert. Chas. ________________________________________________________________________________
Cc:
Date: Feb 17, 2006
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Feb 17, 2006
> > Using a defogger is something I've given thought to, but am > not sure how necessary it really is. > > I'd like to hear from frequent flyers who have NO defogging > installed and get some reports about them ever wishing they had them. > > Vern W. Vern, I am not sure why you only wanted those without fans to answer...mine doesn't have fans until I turn them on: ) The need depends upon the temperature and whether or not there are two people on board. If the OAT is at or below about 10F, and the ground ops time is more than 5 minutes, you will have a frosted up windscreen. Noticably faster with two on board. It will clear up after several minutes in flight. There have been takeoffs that I would not have been able to make without the fans. Both fans are directed at the pilot's side, and the copilot's side has been completely obscured. So, the necessity is totally dependent upon the OAT that you plan to taxi in. Another option is to keep the canopy cracked open while taxiing, something I've not found comfortable at all. Most GA pilots do not fly when the temps are in the 10F and below range, based upon my observations. Alex Peterson RV6-A N66AP 714 hours Maple Grove, MN ________________________________________________________________________________
Date: Feb 17, 2006
I put 2 computer cooling fans in my RV9A. Here in the damp Seattle area it does help to defrost the windshield. Another great benefit is that it draws warm air off the radio stack to keep the radios cool. I run the fans all the time for the radio cooling. Kim Nicholas Auburn, WA RV9A 77 hours! ________________________________________________________________________________
Subject: Re: Garmin handheld
Date: Feb 17, 2006
lyleedda(at)telus.net wrote: > .... opinions on choosing a Garmin 196 or a color 296, for any of you who may own or use either of these..... I want to know is how many users feel the cost and color diffference would affect your choice?.....I imagine the functions are about the same, are they not ? > Austin. I am pleased with the upgrade I made to the 296 from the quite capable 196 which I happily owned for 3 years or so, but it took significant Garmin discounting (prior to its 396 debut) for me to opt for the change. The surface display area and the intuitive user operations are pretty much the same between the units. The redraw rate is a bit faster in the 296 but as a practical matter, that doesn't mean a whole lot. However, the clear and sharp color display is much more sexy and appealing. But more important than the pretty colors is the nifty terrain avoidance feature. This is where the color display is essential and really comes into its potentially lifesaving own. I have intentionally aimed my airplane directly towards an obstruction, usually a communications tower straight ahead and watch the 296 unerrringly warn of its presence. Climbing or decending towards the conflict object (or elevated terrain) produces a yellow background on the display which indicates marginal clearance and turns to red to indicate a sure collision if a course (or altitude) correction is not made. One page shows this avoidance feature exclusively. However, Garmin convieniently thought to include its terrain warning feature as a "pop up' window on the main moving map page if a potential conflict suddenly arises. For my purposes, battery life is a non-issue since I keep it plugged into my RV's 12V power receptacle. In practice, I find myself referring to the 296 much more often than the permanently installed 430's display. The only thing I actually preferred in the 196 to the 296 is its vertical navigation function. The 296 will guide you down well enough but is programmed to shut down the guidance several miles from the destination target. My guess is Garmin rethought the function and altered it to better discourage a pilot from being tempted to shoot a casual and highly illegal approach! As a bonus and as the photo illustrates, I have a handy place to hang my headsets too. All in all, I am well pleased with the 296! but unl ike my less than satisfying experience in the past, I will not be sucked into purchasing the optional automotive kit like I did with the 196. But that is as they say, another story. http://img367.imageshack.us/img367/4584/pairofgarmins412au.jpg Rick Galati RV-6A "Darla" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=12934#12934 ________________________________________________________________________________
Date: Feb 17, 2006
I've placed a similar fan to circulate air around my avionics stacks to try to provide a little cooling. I've yet to wire up and test the avionics, and I'm concerned about electrical noise from the fan motor. Does anyone have any experience with a similar setup? Al Herron ________________________________________________________________________________
Subject: Inspection plates
Date: Feb 17, 2006
Anyone installing clear (plexi?) inspection covers / plates instead of aluminum? John Jessen ~328 ________________________________________________________________________________
Subject: Speed fairings
Date: Feb 17, 2006
Just wanted to let you know that Vic has been shipping the carbon fiber fairings for the fuel drains, fuel vents and aileron hinges for Rv's & Rockets and they are beautiful. For full details and pictures contact him at vjs406(at)yahoo.com John Furey RV6A gone F1 in process ________________________________________________________________________________
Date: Feb 17, 2006
Subject: Re: Inspection plates
John Jessen wrote: > >Anyone installing clear (plexi?) inspection covers / plates instead of >aluminum? > >John Jessen > ~328 > I believe that Van says the AL covers are structural (note the number of screws). You might want to give them a call before you do it. ________________________________________________________________________________
Date: Feb 17, 2006
> > I'd like to hear from frequent flyers who have NO defogging > > installed and get some reports about them ever wishing they had them. Okay that's me. I built a "defroster vent" into the glareshield with a duct routed to it. The tube goes down and just kind of hangs there next to where the heat inlet is thru the firewall. Seemed like a good idea at the time but in fact it doesn't do a damn thing. In the winter I get fogged plexi fairly often and sometimes it stays fogged once I get flying unless I open the cold air vents. I keep meaning to either 1) plumb the SCAT tube so the heat inlet blows more directly into the glareshield duct or 2) put a fan in there. But 5 years and 750 hrs after first flight I can't seem to get around to it... too many other fun things to do (like go flying!) Randall Henderson RV-6 ________________________________________________________________________________
Date: Feb 18, 2006
The 196 had a software update last year which gives it the same terrain functions, ie. depicts the towers and their heights and warns you when you're about to smack one. Jeff Point RV-6 w/ 196 Milwaukee Tony Marshall wrote: >The 296 has a 'terrain' feature that would be nice, and the screen is very >nice. > > > ________________________________________________________________________________
Date: Feb 18, 2006
Thanks Randall, that kind of says it all. If you've been "meaning" to install a defog system, but haven't in over 750 hours of flying, then I think when it comes right down to it, a defogger simply that much of an importance. A soft rag tucked into a side pocket seems to be plenty good for the purpose for those times when called for. Vern W. On 2/18/06, randall wrote: > > > Okay that's me. > > > I keep meaning to either 1) plumb the SCAT tube so the heat inlet blows > more > directly into the glareshield duct or 2) put a fan in there. But 5 years > and > 750 hrs after first flight I can't seem to get around to it... too many > other fun things to do (like go flying!) > > Randall Henderson > RV-6 > > ________________________________________________________________________________
Subject: Garmin handheld
Date: Feb 18, 2006
IMHO I would only get the color unit. I find the 296 to be the most useful device in my cockpit (other than the urine bottle) and being that I am so dependant on it I prefer the better image definition you get with the color display. Also keep in mind that if you ever choose to upgrade by selling your color unit you will get more for the 296 than the 196 to the actual cost is less than the purchase price difference between the two units. I have found (personally) that when I go with the cheaper "value" purchase I always wish I had purchased the upgraded version. A friend of mine has a saying that "the most expensive thing he ever did was try and save money." Note the above is only my opinion and part of the reason I am known as the great justifier! I can justify just about anything to myself. Robin RV-6A 250 hours (Pivot Panel Mounted 296) RV-4 Sold (Air Gizmo Mounted 296) http://www.painttheweb.com/rv-4/ ________________________________________________________________________________
Subject: XM and the 386
Date: Feb 18, 2006
Right off, I freely submit I barely understand the complexities involved but just the same, I'll throw this thought out there and maybe glean some useful insights from those more knowledgable. I would love to own a Garmin 396. I could buy one sure...but....I am loathe to commit to an ongoing monthly subscription for the primary reason for buying one......XM weather services. To me, a on-going $50 per month service fee is not an insignificant commitment. Beside, I just don't like elective monthly payments period. I keep reading reports that XM radio is in serious financial trouble and is generally falling short of its goals. Is XM satellite weather subject to the same financial pressures as XM satellite radio? Cutting to the chase: Within the framework of our capitalistic system, it is reasonable to suppose that XM technology is here to stay BUT at some point a structural reorganization will likely occur within the XM industry. If so, is there any likelyhood that monthly subscription services for XM weather services relevant to the 386 (and its eventual successor) will trend downward like so many other hi-tech consumer products? Rick Galati RV-6A "Darla" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=13105#13105 ________________________________________________________________________________
Date: Feb 18, 2006
Hi Austin, You can buy a used 296 on ebay because lots of folk are going to the 396, which run around $1000, and sell your 196 for about $500, that's what I did. Got a nice clean unit and like it much better. Redraws faster, easier to read because of the color, and I like the terrain feature a lot, for those pesky radio towers when the ceiling is down. A feature I like is the 8 hour ( tested it) battery life. We haven't bothered to wire it to the ship yet, just take it home keep it charged up. For ease of use, I think these beat the certified panel mounts. HTH... Jerry Cochran Wilsonville, OR From: "lyle" <lyleedda(at)telus.net> Subject: RV-List: Garmin handheld Hi Listers, I would like to ask for your opinions on choosing a Garmin 196 or a color 296, for any of you who may own or use either of these. I do realize the difference in cost and color, but what I want to know is how many users feel the cost and color diffference would affect your choice ? I sense that the display of the 196 appears larger, but is that just how the promo photos appear ? I imagine the functions are about the same, are they not ? Anyway, I guess it mostly comes down to whether the extra cost of color is worth it ? Many thanks for any who care to add to this. Austin. do not archive ________________________________________________________________________________
Date: Feb 18, 2006
> > Thanks Randall, that kind of says it all. If you've been > "meaning" to install a defog system, but haven't in over 750 > hours of flying, then I think when it comes right down to it, > a defogger simply that much of an importance. > > A soft rag tucked into a side pocket seems to be plenty good > for the purpose for those times when called for. > > > Vern W. Vern, there are people who don't ever use the heaters in their cars either, as they live in warm climates. To repeat my previous post, if you taxi in OAT's at or below about 10F, you will either need to leave the canopy cracked open or have some sort of defrost system. A rag will not clear frost. Everything depends on the temperatures where you live or plan to fly. Alex Peterson RV6-A N66AP 712 hours Maple Grove, MN ________________________________________________________________________________
Date: Feb 18, 2006
Ditto what alex said. Up here in the frozen north (where it's currently a whopping FOUR degrees outside) a defroster is a MUST. You'll quickly find that in temperatures like this that the light "film" that people think of on their windshields up here becomes literally a layer of frost and ice that really sucks to try and scrape off (not wipe, but scrape). I hate having the canopy craked with it's 10 degrees out (but sometimes just have to) so my little muffin fans at least keep an open circle in front of the pilot and co-pilot...although some days my little "portholes of defrosted window" aren't very large until the plane gets moving! Just my 2 cents...but then again everyone laughs at my "winterization kit" which consits of varying widths (currently 2 strips) of duct tape across my air inlets :) Cheers, Stein. >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Alex Peterson >Sent: Saturday, February 18, 2006 12:19 PM >To: rv-list(at)matronics.com >Subject: RE: RV-List: RV-7 Defog fans > >Vern, there are people who don't ever use the heaters in their cars either, >as they live in warm climates. To repeat my previous post, if you taxi in >OAT's at or below about 10F, you will either need to leave the canopy >cracked open or have some sort of defrost system. A rag will not clear >frost. Everything depends on the temperatures where you live or plan to >fly. > >Alex Peterson >RV6-A N66AP 712 hours >Maple Grove, MN > > ________________________________________________________________________________
Subject: F-904H Center Section Side Plate
Date: Feb 18, 2006
I think my right 904H might have been drilled backward. It appears on dwg 23 coordinates 3.5, and C, that the top of the spar flange has a bevel on the front flange. The 904H has this same bevel. My left side matches the dwg, but the right has the bevel on the aft flange of the spar. I matched up the bevels not paying attention to the orientation and matched drilled. Now I notice the spacer will not come out of the slot between the two spars. If I flip the 904H over, the slot works fine, and all is well. The issue now is the hole spacing. the front is supposed to have 24 holes and the rear flange 25 according to dwg 16. I can't simply drill new holes as they will elongate the current ones, any ideas, thoughts? The left side is correct.. spar flange serial numbers and orientation marks from vans is correct.. ________________________________________________________________________________
Subject: Finishing Van's intersection fairings (RV-6)
Date: Feb 18, 2006
Listers, I have Van's top and bottom intersection fairings and f/g legs and I have them cleco'd in place. They went on with very little distortion. I plan to attach them with screws and nutplates rather than bonding permanently to the wheel covers. The plans call for laying up two layers of glass over the intersection fairings. It seems to me that it would be okay to lay up the extra layers on the bench rather than on the airplane where I would have to deal with clecos. The only consideration I can think of - lies in the amount of distortion. QUESTION: Is this how others are doing it (on the bench)? Thanks for any input. Tom Barnes -6 190+ hrs Buffalo Grove, IL ________________________________________________________________________________
Date: Feb 18, 2006
newbie looking to hitch a ride from So. Il [Belleville IL/St Louis area]. I'd like to drive to your place and help with gas if you have an empty seat. my phone no. is 314.807.0027 thanks John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=13157#13157 ________________________________________________________________________________
Date: Feb 18, 2006
newbie from Belleville IL looking to hitch a ride for gas to the fly in. my phone # is 314.807.0027 if you have an empty seat and are within striking distance to the St Louis area so I could drive and meet up with you at your location. Thanks John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=13156#13156 ________________________________________________________________________________
From: "Dan Beadle" <dan.beadle(at)inclinesoftworks.com>
Date: Feb 18, 2006
XM did report a higher than expected loss this week. BUT They have the most subscribers. Their true fixed costs - the costs of satellites - are not going up while subscribers have doubled. They seem to be in the early, easy spending stages. They will likely start to watch pennies as they mature, but in this kind of play, it is all about subscribers. They have plenty of content to keep attracting subscribers. Right now, there are only 5 million. But the target population is 300 million. And some people will have multiple subscriptions - for Garmins, boom boxes, etc., as well as cars. I just committed to $6K upgrade to my MX-20 to put the weather on the panel in my C414. The RV8 will get a G396 ---- and another subscription. Dan -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Rick Galati Sent: Saturday, February 18, 2006 9:37 AM Subject: RV-List: XM and the 386 Right off, I freely submit I barely understand the complexities involved but just the same, I'll throw this thought out there and maybe glean some useful insights from those more knowledgable. I would love to own a Garmin 396. I could buy one sure...but....I am loathe to commit to an ongoing monthly subscription for the primary reason for buying one......XM weather services. To me, a on-going $50 per month service fee is not an insignificant commitment. Beside, I just don't like elective monthly payments period. I keep reading reports that XM radio is in serious financial trouble and is generally falling short of its goals. Is XM satellite weather subject to the same financial pressures as XM satellite radio? Cutting to the chase: Within the framework of our capitalistic system, it is reasonable to suppose that XM technology is here to stay BUT at some point a structural reorganization will likely occur within the XM industry. If so, is there any likelyhood that monthly subscription services for XM weather services relevant to the 386 (and its eventual successor) will trend downward like so many other hi-tech consumer products? Rick Galati RV-6A "Darla" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=13105#13105 ________________________________________________________________________________
Date: Feb 18, 2006
Subject: OAT Sensor problem
I recently installed an OAT sensor in the outboard inspection panel under the left wing of my 8A and hooked it up to my EIS engine monitor. I was surprised to see the indicated temp was twice what the ambient temp in my hangar was. Any ideas for the reason for this and a fix? Walt Shipley RV-8A flying, RV-8 still under construction ________________________________________________________________________________
Date: Feb 18, 2006
Subject: Re: OAT Sensor problem
I don't have the manual handy, but I'd guess the settings for that input are off. You might want to look them up and double check. Jeff Point RV-6 Milwaukee > > ________________________________________________________________________________
Date: Feb 18, 2006
On 2/18/06 5:52 PM, "rveighta" wrote: > > I recently installed an OAT sensor in the outboard inspection panel under the > left wing of my 8A and hooked it up to my EIS engine monitor. I was surprised > to see the indicated temp was twice what the ambient temp in my hangar was. > > Any ideas for the reason for this and a fix? > > Walt Shipley RV-8A flying, RV-8 still under construction > I hope you wired this with the proper thermocouple type wire. That will make a big, big difference. Doug Weiler RV-4, N722DW > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 18, 2006
----- Original Message ----- > > I recently installed an OAT sensor in the outboard inspection panel under > the > left wing of my 8A and hooked it up to my EIS engine monitor. I was > surprised > to see the indicated temp was twice what the ambient temp in my hangar > was. > > Any ideas for the reason for this and a fix? > > Walt Shipley RV-8A flying, RV-8 still under construction ((((((((()))))))))))) I installed mine by the inboard inspection plate of right wing. Be sure you have oriented your sensor/guage by setting it in freezing water and setting that temp. display to either 32 F or 0 C and have set it in boiling water and set that resulting measurement to 212 F or 100 C? I did that with my ACS2002 and it gives excellent indications of temperatures; If otherwise, I suggest you contact your sensor supplier. Indiana Larry, RV7 SunSeeker 85+ hours flying, AFS ACS2002 > > ________________________________________________________________________________
From: "Vincent Welch" <welchvincent(at)hotmail.com>
Date: Feb 18, 2006
Ron, I too have been fighting high oil temps with an IO-360 in an RV-8A. Can you put me in contact with your source for louvers? Vince Welch >From: Ron Lee <ronlee(at)pcisys.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: vernatherm success >Date: Wed, 15 Feb 2006 10:03:20 -0700 > > >At 07:30 AM 2/15/2006, you wrote: > > > >I have a friend who has been fighting high oil temps since day one. He >has > >relocated the oil cooler, and checked the operation of the vernatherm by > >heating it in boiling water and checking the seat. Nothing has seemed to > >helped the situation. I am wondering if there is anyone out there who >cured > >their oil temp woes by replacing the vernatherm. > > >I have no vernatherm but fought high oil temps. I solved it by reducing >cabin heat hose clutter, opening the bottom cowl to let air out better >and adding cowl louvers. Best recollection is that it dropped the oil temp >40 deg F or so. > >http://home.pcisys.net/~ronlee/RV6A/Cowl_Louver_Small.jpg > >Ron Lee > > ________________________________________________________________________________
Date: Feb 18, 2006
Subject: Re: P/N KM610-64 Camloc Flush Button Latch
Quite some time back someone on the RV-List asked about these push button latches. I recently did some research and realized that I had listed an incorrect P/N in my reply and that error is forever ensconced in the archives. My bad. These latches are much nicer than the commonly available Hartwell latches IMO, as they won't pop you on the thumb some cold morning when checking the oil. For those of you looking to use this really cool latch, they are apparently still available from a number of Cessna parts outlets and may be found on the web by simply Googling P/N KM610-64. GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Feb 19, 2006
how many of these are needed for the oil door ? Danny.. ----- Original Message ----- From: <Vanremog(at)aol.com> Sent: Saturday, February 18, 2006 10:45 PM Subject: RV-List: Re: P/N KM610-64 Camloc Flush Button Latch > > Quite some time back someone on the RV-List asked about these push button > latches. I recently did some research and realized that I had listed an > incorrect P/N in my reply and that error is forever ensconced in the > archives. My > bad. > > These latches are much nicer than the commonly available Hartwell latches > IMO, as they won't pop you on the thumb some cold morning when checking > the oil. > > For those of you looking to use this really cool latch, they are > apparently > still available from a number of Cessna parts outlets and may be found on > the > web by simply Googling P/N KM610-64. > > > GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) > > > ________________________________________________________________________________
Subject: fuselage stand
Date: Feb 18, 2006
Does anyone have a 7a fuselage stand they want to get ride of? Jim ________________________________________________________________________________
Date: Feb 19, 2006
In a message dated 2/18/2006 10:52:27 P.M. Pacific Standard Time, sportypilot(at)stx.rr.com writes: how many of these are needed for the oil door ? =============================== One would be sufficient, but in the spirit of redundancy, I have two of these latches on the oil access door. I use only one latch on the gascolator drain access door on the lower cowling. GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Feb 19, 2006
I found them for 20.00 each is that about right ? , I was planning on adding to the tube and have the gasolator drain stick out just a little without a door for it.. whats others doing on that ? Danny.. ----- Original Message ----- From: <Vanremog(at)aol.com> Sent: Sunday, February 19, 2006 1:14 AM Subject: Re: RV-List: Re: P/N KM610-64 Camloc Flush Button Latch > > > In a message dated 2/18/2006 10:52:27 P.M. Pacific Standard Time, > sportypilot(at)stx.rr.com writes: > > how many of these are needed for the oil door ? > > > =============================== > > One would be sufficient, but in the spirit of redundancy, I have two of > these latches on the oil access door. I use only one latch on the > gascolator > drain access door on the lower cowling. > > GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) > > > ________________________________________________________________________________
Date: Feb 19, 2006
sportypilot(at)stx.rr.com wrote: > how many of these are needed for the oil door ?Danny..--- I never did care for the dominant look produced by Hartwell latches contained in such a small area like the cowl oil door and I surely was not going to install those kit supplied wingy things on it either! Looking for ideas, I would cruise the RV line at Oshkosh endlessly and never did see an RV with the KM610-64's installed. It was only when I spotted a student checking the oil on a rental 172 that I finally had my inspiration. I'd like to think I was the first person to install these nifty latches on the RV oil door but apparently not. Oh well. I installed these KM610-64's a few years back, ordered and purchased from my (then) FBO out of a C-172 parts catalog for a mind bending $30.00 each. A few weeks later, I came across the same new latchs from a vendor in the Flymart at Airventure for $7.50 each. I think it was B&B Aviation Parts. Anyway, when I loudly complained to my FBO about the ripoff, he cut the price in half...to $15 each. As the photo's illustrate, I installed two of the camlocks on the oil door. I also bonded the cutout cowl waste material onto the back of the oil door the stiffen it considerably. They work great. http://img79.imageshack.us/img79/2166/oildoor01403wn.jpg http://img367.imageshack.us/img367/9172/oildoor04409tb.jpg http://img367.imageshack.us/img367/6949/oildoor05400wd.jpg Rick Galati RV-6A "Darla" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=13284#13284 ________________________________________________________________________________
Date: Feb 19, 2006
The only trouble with these latches is the contact area to the cowling is very small and the latch will wear at the point of contact, so will the aluminum piece they ride up against.. I've replaced these a couple of times on our club C-172's, and have tig welded them back into shape also. Regards, Bob Japundza RV-6 flying, F1 under const. On 2/19/06, Sportypilot wrote: > > > I found them for 20.00 each is that about right ? , I was planning on > adding > to the tube and have the gasolator drain stick out just a little without > a door for it.. whats others doing on that ? > > > Danny.. > ----- Original Message ----- > From: <Vanremog(at)aol.com> > To: > Sent: Sunday, February 19, 2006 1:14 AM > Subject: Re: RV-List: Re: P/N KM610-64 Camloc Flush Button Latch > > > > > > > > In a message dated 2/18/2006 10:52:27 P.M. Pacific Standard Time, > > sportypilot(at)stx.rr.com writes: > > > > how many of these are needed for the oil door ? > > > > > > > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > > One would be sufficient, but in the spirit of redundancy, I have two of > > these latches on the oil access door. I use only one latch on the > > gascolator > > drain access door on the lower cowling. > > > > GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 19, 2006
Subject: Cowl Louvers (was vernatherm success)
>I too have been fighting high oil temps with an IO-360 in an RV-8A. Can you >put me in contact with your source for louvers? > >Vince Welch I had them made locally using Home Depot aluminum by a guy who does it for race cars. Another source is at this link: http://www.attawayair.com/rv6a.htm Ron Lee ________________________________________________________________________________
Date: Feb 19, 2006
Subject: Re: fuselage stand
JIM ETCHEVERRY wrote: > >Does anyone have a 7a fuselage stand they want to get ride of? Jim > Are you asking about a dolly to plug into the gear sockets, or a construction jig? If you're looking for a 'jig', Van recommends 2 sawhorses to build the fuse on. Likely to be cheaper to go to a local building supply than pay shipping on them. ________________________________________________________________________________
Subject: Alternative Nav. Lights
Date: Feb 19, 2006
I viewed some LED nav. lights with strobe system a new company has been working on and for the life of me can't find it anywhere. Some one point me in the right direction. TIA, Bruce G. RV8 Fuse ________________________________________________________________________________
From: "Howard Walrath" <der_Jagdflieger(at)prodigy.net>
Subject: Re: XM and the 386
Date: Feb 19, 2006
Charlie, I presume you are aware that your "friend" is violating both FCC and FAA regulations as well as the restrictions of his service provider when he operates his cellular phone in an aircraft that is not on the ground. ----- Original Message ----- From: Charlie England Sent: Sunday, February 19, 2006 8:46 AM Subject: Re: RV-List: XM and the 386 The most likely solution (since the FAA won't 'do the right thing' & simply lease a transponder channel to supply us an avgas-tax supported feed) is coming in the next few years with broadband wireless, like 3G & WiMax. As those technologies spread, we will be able to use the same service for home broadband internet & to get info via a cellphone-like interface to a data screen (PDA or PDA/phone combo, computer, etc) in the plane. A friend is already getting in-flight weather with his PDA/phone. If you're flying anywhere near an interstate highway (most of the time you are), you can do this stuff now. Charlie ________________________________________________________________________________
Date: Feb 19, 2006
Subject: Re: Alternative Nav. Lights
At 09:54 AM 2/19/2006, you wrote: > >I viewed some LED nav. lights with strobe system a new company has been >working on and for the life of me can't find it anywhere. Some one point me >in the right direction. Is this it? http://www.creativair.com/cva/ Ron Lee ________________________________________________________________________________
Date: Feb 19, 2006
These aren't, technically, cell phones. You might be able to make a case for violating some archaic FAA rule, but those much more authority to speak than me say that the new technology is not restricted to ground use under FCC rules. My point is that new technology will soon render the XM issue mute. Charlie Howard Walrath wrote: > >Charlie, I presume you are aware that your "friend" >is violating both FCC and FAA regulations as well >as the restrictions of his service provider when he >operates his cellular phone in an aircraft that is >not on the ground. > >----- Original Message ----- >From: Charlie England >To: rv-list(at)matronics.com >Sent: Sunday, February 19, 2006 8:46 AM >Subject: Re: RV-List: XM and the 386 > > >The most likely solution (since the FAA won't 'do the right thing' & >simply lease a transponder channel to supply us an avgas-tax supported >feed) is coming in the next few years with broadband wireless, like 3G & >WiMax. As those technologies spread, we will be able to use the same >service for home broadband internet & to get info via a cellphone-like >interface to a data screen (PDA or PDA/phone combo, computer, etc) in >the plane. > >A friend is already getting in-flight weather with his PDA/phone. If you're >flying anywhere near an interstate highway (most of the time you are), you >can do this stuff now. > >Charlie > ________________________________________________________________________________
Date: Feb 19, 2006
Subject: N2D First Flight
Guys, most if not all of you have already seen my first flight report on Doug Reeves' or Van's websites, just in case anybody hasn't I thought I'd copy it to the various Lists I've followed over the past 6 years. Wish I could remember the names of everybody who has answered questions I have had, or posted information I have found invaluable during the contruction of N2D. I often find myself wondering how people built airplanes before the internet! Thanks for all your help and hope to see many of you in the air and at fly-ins around the country in the months/years ahead. --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finally flying... ---- Well folks, N2D is now officially an AIR-plane. The FAA signed me off Friday Feb 10th and on Wed morning (Feb 15) I woke up to calm winds and I said to myself, it's time to go flying. I get out to the airport, push it out of the hangar, do a careful preflight, and can't think of any excuse not to go. Don my nomex flight suit and helmet and strap myself in. "Clear Prop!" Engine lights off and the plane comes alive with a brief shudder and rumble as the vibration ripples through the aluminum airframe. Taxi out to the end of the East Tees and dial up ground control: "Cedar Rapids Ground, RV November Two Delta, Experimental...." Feels good to say that. Tell them I'm ready to do first flight and want to depart Three-One and circle the airport to 4000'. No problemo. After the run-up I call Tower and they give me "Position and Hold Three-One, regional jet landing Niner." I move out onto the runway, line up with the centerline and wait. I haven't really been apprehensive about flying this bird but as I sit there for a few moments, it sorta hits me that I am about to take off in an airplane that has never flown before....that arrived as boxes of parts and I assembled in my garage. I think to myself, ya know, this is a little bit crazy... My thoughts are interrupted by the Tower calling out "RV Two Delta, cleared for takeoff." I take a deep breath and push the throttle forward very slowly. I don't bother looking much at the airspeed, since I don't know if it will be accurate. I just wait until it has that 'ready to fly' feeling and pull back gently on the stick. And up we go. I realize I still don't have full power in so I open it up all the way and feel the constant-speed prop bite in and lunge skyward. Now I am just hanging on for dear life and hoping nothing bad happens until I can get a little altitude and catch my breath. Well, nothing bad happens and eventually my brain catches up with the airplane. Before I know it I am pushing the nose over at 4K.' My CHT's are getting a bit high from the climb but nothing out of limits. I wiggle the stick side-to-side a bit. The wings rock back and forth briskly in perfect synch with the stick. Gotta love that fighter-like control response. Flies like an RV.... I circle lazily above the airport for a while, adjusting my oil temp control and keeping a close eye on all the engine vital signs. Everything looking good. I peer down on the poor schmucks in the regional jets landing below me and try not to feel smug. Ok, back to the task at hand....need to do a few stalls just to see if my airspeed is working right at low speeds. I head northwest out over the open farmland. After some more maneuvers I pull the power back slowly to idle....nose coming up....watching the ASI. Slight buffet and clean break at 50 kts with flaps up. Try another one with full flaps...breaks right at 45 kts. Beautiful. Power back in to 24-squared....gotta run it hard for proper break-in. I glance at the flight timer and am surprised to see that an hour has gone by already. Time to head back to the aerodrome. I check my six for enemy fighters and, seeing none, key the mic and tell Cedar Rapids I am ready to return. They come back with "Wind 040 at 9, left base for runway niner, cleared to land." I run through my landing checklist. Grip the stick a bit tighter. Realize that I'm getting close to the field and am still way too high. Pull the power back to idle and feel the deceleration as the constant-speed prop and short stubby wings do their thing....get 'er slowed down enough to throw out the flaps, turn final, add a touch of power back in to maintain 70 kts and arrest the high sink rate. A bit of turbulence tossing me around. Nearing the ground now...power all the way off....flare....and touchdown. Whew! Not a greaser but not bad either. Big relief as I roll down the runway, all in one piece... Taxi up to my hangar, shut her down and just sit there for a while letting it all soak in. Quiet satisfaction. Engine making that tick, tick, tick sound as it cools. Lovely airplane aroma of heat, oil and avgas. Nobody's around for picture taking, back-slapping or champagne but that is fine. Some guy changing a light bulb outside the hangar comes by and says "nice airplane!". I don't tell him I have just completed its first flight....just smile and say "thanks." Speaking of thanks, I owe a huge debt of gratitude to the following: God, for blessing me with the freedom and resources to make this dream come true. My patient and supportive wife Kathleen--and my kids--who have sacrificed a lot to allow me to do this project. Alan Kritzman for all his help, encouragement (prodding?) and camaraderie. Jerry Esquenazi (T-6A IP at Moody AFB) and Karl Heidrich (Wright-Patt AFB) for going out of their way to help me duplicate the beautiful paint scheme on the T-6A. Everett Coleman for kindly donating his way-cool short N-number to me. Everybody at Vans Aircraft for the great design and support. Countless others--too many to name--from EAA Chapter 33 and the sport aviation community who have shared their time, hardware, advice and lessons-learned, resulting in a much better airplane than I could have built without them! Hope I can get lots of good flying wx in the weeks/months ahead....I have 38.7 hours to go before I can get out of my test area... --Mark Navratil Cedar Rapids, Iowa RV-8A (s/n 80583) N2D, 1.3 hours flying!! ________________________________________________________________________________
Date: Feb 19, 2006
This might also be what you're looking for: http://www.thorllc.net/LEDSTROBE.htm I already have the Creative Air Nav LED's, but I need a tail nav/strobe light to finish the system. Unfortunately, Thor won't sell just the tail nav/strobe light by itself and will only sell as a complete light set. Vern W. ________________________________________________________________________________
Date: Feb 19, 2006
CreativeAir has been out for awhile. This company just hit the market with-in the year. They have a triangular Tail/Stobe and showed a couple photo's of the nav instulation. Thanks for your help. Bruce G. >From: Ron Lee <ronlee(at)pcisys.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Alternative Nav. Lights >Date: Sun, 19 Feb 2006 10:36:01 -0700 > > >At 09:54 AM 2/19/2006, you wrote: > > > >I viewed some LED nav. lights with strobe system a new company has been > >working on and for the life of me can't find it anywhere. Some one point >me > >in the right direction. > >Is this it? > >http://www.creativair.com/cva/ > >Ron Lee > > ________________________________________________________________________________
Date: Feb 19, 2006
That the ticket! These are the guys I saw a while back. I'm liking these LED low maintenance approach with minimal voltage draw on the elec. system. Thanks for your help guys, Bruce Gray RV8 Fuse >From: "Vern W." <highflight1(at)gmail.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Alternative Nav. Lights >Date: Sun, 19 Feb 2006 15:33:33 -0600 > > >This might also be what you're looking for: >http://www.thorllc.net/LEDSTROBE.htm > >I already have the Creative Air Nav LED's, but I need a tail nav/strobe >light to finish the system. Unfortunately, Thor won't sell just the tail >nav/strobe light by itself and will only sell as a complete light set. > >Vern W. > > ________________________________________________________________________________
From: "Michael D. Cencula" <matronics(at)cencula.com>
Date: Feb 19, 2006
AFAICT, it's only the 900MHz phones that are against FAA regulations. Most current phones don't use the 900MHz bands. On Sunday February 19 2006 11:57, Howard Walrath wrote: > > > Charlie, I presume you are aware that your "friend" > is violating both FCC and FAA regulations as well > as the restrictions of his service provider when he > operates his cellular phone in an aircraft that is > not on the ground. ________________________________________________________________________________
Date: Feb 19, 2006
Subject: Re: N2D First Flight
Congradulations !!! Dan -8 Rudder Mark E Navratil wrote: Guys, most if not all of you have already seen my first flight report on Doug Reeves' or Van's websites, just in case anybody hasn't I thought I'd copy it to the various Lists I've followed over the past 6 years. Wish I could remember the names of everybody who has answered questions I have had, or posted information I have found invaluable during the contruction of N2D. I often find myself wondering how people built airplanes before the internet! Thanks for all your help and hope to see many of you in the air and at fly-ins around the country in the months/years ahead. --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finally flying... ---- Well folks, N2D is now officially an AIR-plane. The FAA signed me off Friday Feb 10th and on Wed morning (Feb 15) I woke up to calm winds and I said to myself, it's time to go flying. I get out to the airport, push it out of the hangar, do a careful preflight, and can't think of any excuse not to go. Don my nomex flight suit and helmet and strap myself in. "Clear Prop!" Engine lights off and the plane comes alive with a brief shudder and rumble as the vibration ripples through the aluminum airframe. Taxi out to the end of the East Tees and dial up ground control: "Cedar Rapids Ground, RV November Two Delta, Experimental...." Feels good to say that. Tell them I'm ready to do first flight and want to depart Three-One and circle the airport to 4000'. No problemo. After the run-up I call Tower and they give me "Position and Hold Three-One, regional jet landing Niner." I move out onto the runway, line up with the centerline and wait. I haven't really been apprehensive about flying this bird but as I sit there for a few moments, it sorta hits me that I am about to take off in an airplane that has never flown before....that arrived as boxes of parts and I assembled in my garage. I think to myself, ya know, this is a little bit crazy... My thoughts are interrupted by the Tower calling out "RV Two Delta, cleared for takeoff." I take a deep breath and push the throttle forward very slowly. I don't bother looking much at the airspeed, since I don't know if it will be accurate. I just wait until it has that 'ready to fly' feeling and pull back gently on the stick. And up we go. I realize I still don't have full power in so I open it up all the way and feel the constant-speed prop bite in and lunge skyward. Now I am just hanging on for dear life and hoping nothing bad happens until I can get a little altitude and catch my breath. Well, nothing bad happens and eventually my brain catches up with the airplane. Before I know it I am pushing the nose over at 4K.' My CHT's are getting a bit high from the climb but nothing out of limits. I wiggle the stick side-to-side a bit. The wings rock back and forth briskly in perfect synch with the stick. Gotta love that fighter-like control response. Flies like an RV.... I circle lazily above the airport for a while, adjusting my oil temp control and keeping a close eye on all the engine vital signs. Everything looking good. I peer down on the poor schmucks in the regional jets landing below me and try not to feel smug. Ok, back to the task at hand....need to do a few stalls just to see if my airspeed is working right at low speeds. I head northwest out over the open farmland. After some more maneuvers I pull the power back slowly to idle....nose coming up....watching the ASI. Slight buffet and clean break at 50 kts with flaps up. Try another one with full flaps...breaks right at 45 kts. Beautiful. Power back in to 24-squared....gotta run it hard for proper break-in. I glance at the flight timer and am surprised to see that an hour has gone by already. Time to head back to the aerodrome. I check my six for enemy fighters and, seeing none, key the mic and tell Cedar Rapids I am ready to return. They come back with "Wind 040 at 9, left base for runway niner, cleared to land." I run through my landing checklist. Grip the stick a bit tighter. Realize that I'm getting close to the field and am still way too high. Pull the power back to idle and feel the deceleration as the constant-speed prop and short stubby wings do their thing....get 'er slowed down enough to throw out the flaps, turn final, add a touch of power back in to maintain 70 kts and arrest the high sink rate. A bit of turbulence tossing me around. Nearing the ground now...power all the way off....flare....and touchdown. Whew! Not a greaser but not bad either. Big relief as I roll down the runway, all in one piece... Taxi up to my hangar, shut her down and just sit there for a while letting it all soak in. Quiet satisfaction. Engine making that tick, tick, tick sound as it cools. Lovely airplane aroma of heat, oil and avgas. Nobody's around for picture taking, back-slapping or champagne but that is fine. Some guy changing a light bulb outside the hangar comes by and says "nice airplane!". I don't tell him I have just completed its first flight....just smile and say "thanks." Speaking of thanks, I owe a huge debt of gratitude to the following: God, for blessing me with the freedom and resources to make this dream come true. My patient and supportive wife Kathleen--and my kids--who have sacrificed a lot to allow me to do this project. Alan Kritzman for all his help, encouragement (prodding?) and camaraderie. Jerry Esquenazi (T-6A IP at Moody AFB) and Karl Heidrich (Wright-Patt AFB) for going out of their way to help me duplicate the beautiful paint scheme on the T-6A. Everett Coleman for kindly donating his way-cool short N-number to me. Everybody at Vans Aircraft for the great design and support. Countless others--too many to name--from EAA Chapter 33 and the sport aviation community who have shared their time, hardware, advice and lessons-learned, resulting in a much better airplane than I could have built without them! Hope I can get lots of good flying wx in the weeks/months ahead....I have 38.7 hours to go before I can get out of my test area... --Mark Navratil Cedar Rapids, Iowa RV-8A (s/n 80583) N2D, 1.3 hours flying!! ________________________________________________________________________________
Date: Feb 19, 2006
In a message dated 2/19/2006 10:31:38 A.M. Pacific Standard Time, ceengland(at)bellsouth.net writes: My point is that new technology will soon render the XM issue mute. And also moot. GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Feb 20, 2006
Mark, CONGRATULATIONS and WELL DONE !!!! Chuck & Dave Rowbotham RV-8A >From: Mark E Navratil <czechsix(at)juno.com> >Reply-To: rv-list(at)matronics.com >To: RV-8(at)yahoogroups.com, aeroelectric-list(at)matronics.com, >rv-list(at)matronics.com >Subject: RV-List: N2D First Flight >Date: Sun, 19 Feb 2006 15:20:47 -0600 > > >Well folks, N2D is now officially an AIR-plane. >--Mark Navratil >Cedar Rapids, Iowa >RV-8A (s/n 80583) N2D, 1.3 hours flying!! > > ________________________________________________________________________________
Date: Feb 20, 2006
Mark, you have a way with words, enjoyed your first flight report, Congrats! Charlie Heathco ________________________________________________________________________________
Date: Feb 20, 2006
From: "jacklockamy" <jacklockamy(at)verizon.net> Camloc Flush Button Latch
Subject: Re: P/N KM610-64 Camloc Flush Button LatchP/N KM610-64 Camloc
Flush Button Latch I installed the Camlock Flush Button Latch on my now flying RV-7A. Works great with just one button as long as you stiffen the door. Scroll down near the bottom of this page and you will see four (4) close-up photos of how I installed mine: http://www.jacklockamy.com/RV-7A.html I purchased three or four of these camlocks at a fly-mart one year while at Sun-N-Fun for about $5 each. (I have sold the remaining flush locks to other friends building RVs.... sorry.) Jack Lockamy Camarillo, CA N174JL RV-7A 140 hrs. ________________________________________________________________________________
Date: Feb 20, 2006
To solve the problem of 'wear' where the camlock contacts the fiberglass cowling, I installed a small strip of stainless steel (1" x 1/2" x .030) under the cowling lip and attached with a couple of flush rivets. Jack Lockamy Camarillo, CA ________________________________________________________________________________
Date: Feb 20, 2006
-----Original Message----- From: Charles Rowbotham <crowbotham(at)hotmail.com> Subject: RE: RV-List: N2D First Flight Mark, CONGRATULATIONS and WELL DONE !!!! Chuck & Dave Rowbotham RV-8A >From: Mark E Navratil <czechsix(at)juno.com> >Reply-To: rv-list(at)matronics.com >To: RV-8(at)yahoogroups.com, aeroelectric-list(at)matronics.com, >rv-list(at)matronics.com >Subject: RV-List: N2D First Flight >Date: Sun, 19 Feb 2006 15:20:47 -0600 > > >Well folks, N2D is now officially an AIR-plane. >--Mark Navratil >Cedar Rapids, Iowa >RV-8A (s/n 80583) N2D, 1.3 hours flying!! > > Try the New Netscape Mail Today! Virtually Spam-Free | More Storage | Import Your Contact List http://mail.netscape.com ________________________________________________________________________________
Subject: Cockpit Light Bulb
Date: Feb 20, 2006
I just wanted to find out if anyone knows a source for a 12 volt # 313 bulb. I have a cockpit map light from a F-100 I acquired many years ago and I thought I would check to see if I can rig it up in my RV. Aircraft Spruce has the 313 but it only lists it in a 28 volt version. Maybe there is a substitute that will work in 12 volt. Ed O'Connor/ RV-8 N-366RV/ awaiting first flight. ________________________________________________________________________________
Subject: Re: FAR Safety question.
Date: Feb 20, 2006
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
The safety pilot can log the time as 'second-in-command', for the time that the 'pilot-in-command' is under the hood in VFR conditions. This is because during that time you are a required crewmember. Now keep in mind that 'second-in-command' time doesn't count toward most things for which you log your time, like additional ratings, insurance, ..., because those require PIC time. There is value in logging that time to prove that there was a safety pilot on-board. Just be careful that both pilot's logbooks are in synch (PIC vs. SIC). Dennis Glaeser CFII Maybe someone here can answer this question. A buddy and I fly as IFR safety pilot for each other for training. As safety pilot, can I log the flight time? If so, in what capacity? Pilot in command?? Even the local FAA gurus cannot agree on this one. Thanks. Kim Nicholas RV9A Auburn, WA ________________________________________________________________________________
Subject: Re: Cockpit Light Bulb
Date: Feb 20, 2006
> I just wanted to find out if anyone knows a source for a 12 volt # 313 > bulb. I have a cockpit map light from a F-100 I acquired many years > ago and I thought I would check to see if I can rig it up in my RV. > Aircraft Spruce has the 313 but it only lists it in a 28 volt version. > Maybe there is a substitute that will work in 12 volt. > Ed O'Connor/ RV-8 N-366RV/ awaiting first flight. Hi Ed, Start here for bulb information: http://www.donsbulbs.com/cgi-bin/r/b.pl/313~ac%7cdelco.html A 313 is 28 volts by definition. You should be able to find a 12 volt bulb that will work. It will have a different part number of course. If you don't want to try and figure out the bulb for yourself, call Bulbman and ask them for help... Good luck, Dave ________________________________________________________________________________
Date: Feb 20, 2006
Ed, A #313 is a 28V lamp, there is no 14V version. However a #1893 should be pretty close to the same output and they are both size T-1 3/4. The 1893 won't be quite as bright. Any decent electronics store should have them (probably not R.S.) or Mouser Electronics has them http://www.mouser.com/ Dave Ed OConnor wrote: > >I just wanted to find out if anyone knows a source for a 12 volt # 313 >bulb. I have a cockpit map light from a F-100 I acquired many years >ago and I thought I would check to see if I can rig it up in my RV. >Aircraft Spruce has the 313 but it only lists it in a 28 volt version. >Maybe there is a substitute that will work in 12 volt. >Ed O'Connor/ RV-8 N-366RV/ awaiting first flight. > > > > ________________________________________________________________________________
Date: Feb 20, 2006
Please note that both pilots can NOT log PIC for the same time! (legally anyway :-) As noted in the link that Dan provided, the pilots can agree on who is PIC during what times, regardless of who is 'manipulating the controls'. The safety pilot MUST be appropriately rated for the aircraft being flown. For instance, you can not have a student pilot act as a safety pilot, or a pilot rated only for single-engine can't be a safety pilot on a multi-engine aircraft. Dennis Glaeser --------------------------------------------------- It's my understanding that *both* pilots can log PIC time when one is under the hood (simulated instrument conditions, not actual), as long as the safety pilot is rated for the given category & class, and type if a type rating is required. Any private pilot can act as safety pilot in any airplane regardless of type, but he can only log it as PIC if appropriately rated and endorsed. ---snip-------------------- ________________________________________________________________________________
Date: Feb 20, 2006
Dennis, It was a little qirky the way it was written, but it did say you could both log the time if the safety pilot was PIC and properly rated. The legality of PIC was the issue. If the safety pilot is PIC then he is responsible if there was a violation, or accident, etc. I read it twice, and thought as you did at first. Tim -------Original Message------- From: Glaeser, Dennis A Date: 02/20/06 09:41:14 Subject: RV-List: Re: FAR Safety question. Please note that both pilots can NOT log PIC for the same time! (legally anyway :-) As noted in the link that Dan provided, the pilots can agree on who is PIC during what times, regardless of who is 'manipulating the controls'. The safety pilot MUST be appropriately rated for the aircraft being flown. For instance, you can not have a student pilot act as a safety pilot, or a pilot rated only for single-engine can't be a safety pilot on a multi-engine aircraft. Dennis Glaeser --------------------------------------------------- It's my understanding that *both* pilots can log PIC time when one is under the hood (simulated instrument conditions, not actual), as long as the safety pilot is rated for the given category & class, and type if a type rating is required. Any private pilot can act as safety pilot in any airplane regardless of type, but he can only log it as PIC if appropriately rated and endorsed. ---snip-------------------- ________________________________________________________________________________
Subject: Another good experience with GRT
Date: Feb 20, 2006
At the risk of repeating myself, the folks at Grand Rapids Technology, the EIS and now MFD people, are definitely among the greatest to work with. My EIS 4000 has worked flawlessly for the first 180 hours, but the carb air temp probe suddenly went bonkers last week. After checking the wiring I called and explained the problem to Sandy and gave her my CC number to send me a new probe. The upshot is a new probe is in the mail and there is NO charge. -- Harry Crosby RV-6 N16CX, 181 hours ________________________________________________________________________________
Date: Feb 20, 2006
Nope. Go to AOPA website members section under FAQ. Logging time as PIC and being PIC are two unrelated items. linn Walters wrote: > > Hmmm. I'm no expert by any stretch of the imagination (nor do I play > one on TV :-P ) but I believe that in order to log PIC time, you must be > the sole manipulator of the controls and have a valid pilot's license. > As for logging the flight time, if you're not a licensed instructor I > guess you're just like a passenger keeping an eye out for bandits. I > don't know why an FAA 'guru' can't answer that question though. Kinda > perpetuates the general opinion of the FAA, doesn't it??? Do not > archive in case the FAA's reading this!!! :-) > > Just my thoughts. YMMV. ________________________________________________________________________________
Date: Feb 20, 2006
Nope, not true. If safety pilot IS PIC, and pilot under the hood is sole manipulator of the controls, both can log PIC time. Glaeser, Dennis A wrote: > > Please note that both pilots can NOT log PIC for the same time! (legally > anyway :-) As noted in the link that Dan provided, the pilots can agree > on who is PIC during what times, regardless of who is 'manipulating the > controls'. > > The safety pilot MUST be appropriately rated for the aircraft being > flown. For instance, you can not have a student pilot act as a safety > pilot, or a pilot rated only for single-engine can't be a safety pilot > on a multi-engine aircraft. > > Dennis Glaeser > ________________________________________________________________________________
Subject: Opinions on antenae in VS
Date: Feb 20, 2006
From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
I'm about to close up my VS and need to decide if there's anything I want to put in there. I know I don't want a strobe there but have been thinking about antenae. However, since it looks like my 9A will be light up front (320 with Catto prop and RG batt), and I didn't do the "optional" lightening holes in the VS spar, I think I want to avoid any unneccessary weight in the VS at all. Many people seem to do the nav & com in the wingtips which seems to work well. So, those are my thoughts now, but if someone would like to tell me differently I would like to hear it. Thank you. Paul 9A QB #1176 ________________________________________________________________________________
Subject: Re: Re: FAR Safety question.
Date: Feb 20, 2006
Regarding Safety Pilots, I've always taught that only one pilot can log PIC at a time. The other one can log SIC when the PIC is under the hood. The article indicates that 'if the pilots agree' that the safety pilot is PIC, then that pilot can log PIC, and that the other pilot, who is manipulating the controls, can also log PIC (since that is the definition in the FARs). I think that is stretching the rule to justify double logging PIC time. In case of a violation or accident, that 'agreement' would be meaningless IMHO (I'm not a lawyer or with the FAA). My first question when someone asks me about this is: why is it so important to log PIC time when you are a safety pilot? Are you trying to qualify for a rating, meet some insurance requirement, get a flying job, or what? Back when you had to have 200 hrs to get an instrument rating, that was a motivation to get as much PIC time quickly as possible. Now it that not really an issue. Dennis --------------------- Dennis, It was a little qirky the way it was written, but it did say you could both log the time if the safety pilot was PIC and properly rated. The legality of PIC was the issue. If the safety pilot is PIC then he is responsible if there was a violation, or accident, etc. I read it twice, and thought as you did at first. Tim --------------------- ________________________________________________________________________________
Subject: Re: Opinions on antenae in VS
Date: Feb 20, 2006
a bullet (aka lipstick or spy) camera in the vertical stab fiberglass tip is a cool option. You'll want to make the fiberglass tip removable and as an option you might want to run some wire or string down between the two forward tooling holes you will have to open up to pass the stab cam cables through. No big deal. Just makes life a teensy bit easier later on. -------------- Original message -------------- From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com> > > > I'm about to close up my VS and need to decide if there's anything I want to put > in there. > > I know I don't want a strobe there but have been thinking about antenae. > However, since it looks like my 9A will be light up front (320 with Catto prop > and RG batt), and I didn't do the "optional" lightening holes in the VS spar, I > think I want to avoid any unneccessary weight in the VS at all. Many people > seem to do the nav & com in the wingtips which seems to work well. > > So, those are my thoughts now, but if someone would like to tell me differently > I would like to hear it. Thank you. > > Paul > 9A QB #1176 > > > > > > > > > > > > > a bullet (aka lipstick or spy)camera in the vertical stab fiberglass tip is a cool option. You'll want to make the fiberglass tip removable and as an option you might want to run some wire or string down between the two forward tooling holes you will have to open up to pass the stab cam cables through. No big deal. Just makes life a teensy bit easier later on. -------------- Original message -------------- From: "Folbrecht, Paul" PFolbrecht(at)starkinvestments.com -- RV-List message posted by: "Folbrecht, Paul" I'm about to close up my VS and need to decide if there's anything I want to put in there. I know I don't want a strobe there but have been thinking about antenae. However, since it looks like my 9A will be light up front (320 with Catto prop and RG batt), and I didn't do the "optional" lightening holes in the VS spar, I think I want to avoid any unneccessary weight in the VS at all. Many people seem to do the nav com in the wingtips which seems to work well. So, those are my thoughts now, but if someone would like to tell me differently I would like to hear i t. Thank you. Paul 9A QB #1176 ________________________________________________________________________________
Date: Feb 20, 2006
The AOPA FAQ reads very similar to the article Dan noted. Looks like I'm out-voted, as long as the safety pilot agrees to be responsible for the flight (one of the ways to be PIC). If you want/need the PIC time - go for it. The reality is that there is no way to dispute it anyway. It's important to know the correct way to explain things - with references like the AOPA - if a situation ever comes up that requires it. Good discussion! Dennis Nope. Go to AOPA website members section under FAQ. Logging time as PIC and being PIC are two unrelated items. ________________________________________________________________________________
Date: Feb 20, 2006
The fuselage stand I am talking about attaches to the firewall and tailend. It hold the fuselage before the gear is put on and you can rotate the fuselage 360 if you want. Anybody have one they are done with and want to sell it? Jim ________________________________________________________________________________
Date: Feb 20, 2006
> Many people seem to do the nav & com in the wingtips which seems to work > well. I am not sure I have heard of people happy with wingtip comm antenna. VOR yes. Ron Lee ________________________________________________________________________________
Subject: RV Of The Week
Date: Feb 20, 2006
Hey Guys, N327W made it on Doug Reeve's site (www.vansairforce.net) as RV Of The Week this week!!!! Vince ________________________________________________________________________________
Date: Feb 20, 2006
Ed, find out what the wattage is for the 313, Go to the aviation section of your local auto parts store and see if you can find a 12V bulb with the same base, wattage, and physical size (if the present bulb is a tight fit). You might be able to find a table on the I'net that will list all the bulbs and their specs. There is no #313 bulb in 12V because the number is for a 28V bulb. Ed OConnor wrote: > >I just wanted to find out if anyone knows a source for a 12 volt # 313 >bulb. I have a cockpit map light from a F-100 I acquired many years >ago and I thought I would check to see if I can rig it up in my RV. >Aircraft Spruce has the 313 but it only lists it in a 28 volt version. >Maybe there is a substitute that will work in 12 volt. >Ed O'Connor/ RV-8 N-366RV/ awaiting first flight. > > > > > > > > > ________________________________________________________________________________
Date: Feb 20, 2006
Subject: Help on Holes in Fuse for Brake Lines...
I was drilling the holes for the landing gear and the brake lines as per the template on DWG 34A for the RV-7A. It says to enlarge the pilot hole for the brake line as per DWG 28. DWG 28 says to drill it to 5/8" for the brake line. The problem is that 5/8" seems waay to big for the hardware called out on DWG 36A (AN837-4D 45 deg. Elbow). I already drilled the hole to 5/8" per the plans and there is a lot of wiggle room. Are the plans wrong on this or am I missing something??? P.S. I noticed that on another fitting (the fuel vent) it calls out 7/16" hole in the fuse skin which seems correct... - Matt ________________________________________________________________________________
From: "Bill and Tami Britton" <william(at)gbta.net>
Date: Feb 20, 2006
My VS on my -10 will have a cats whisker VOR/ILS/GS antenna on the top of it. Bill Britton RV-10 Tailcone #40137 ----- Original Message ----- From: "Ron Lee" <ronlee(at)pcisys.net> Sent: Monday, February 20, 2006 3:52 PM Subject: Re: RV-List: Opinions on antenae in VS > > >> Many people seem to do the nav & com in the wingtips which seems to work >> well. > > I am not sure I have heard of people happy with wingtip comm antenna. > VOR yes. > > > Ron Lee > > > ________________________________________________________________________________
Date: Feb 20, 2006
Subject: Brand new Red Dragon Pre Heater for sale
FYI...on Ebay.... Preheater, RED DRAGON LT2-12 MH-200 Brand New Item number: 4614781236 Thanks Dave Mc. Do Not Archive ________________________________________________________________________________
Subject: Re: Cowl Louvers (was vernatherm success)
Date: Feb 20, 2006
Vince, I had the same problem 5 years ago when I finished my RV8 with 200 hp lycoming. Before you cut your cowl, try the following: Install a Niagara/Harrison 10 row oil cooler on the rear baffle behind cylinder 4 as high as cowl clearance will permit. Tilt it back approximately 25 degrees or more if clearance from engine mount will allow. When making pie shaped supports, use 040 or 050 4130 steel instead of aluminum. The brackets if made from aluminum will crack in a few hours of operation. I have enjoyed normal oil temps in all weather conditions since installing this mod. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: "Ron Lee" <ronlee(at)pcisys.net> Sent: Sunday, February 19, 2006 7:16 AM Subject: RV-List: Cowl Louvers (was vernatherm success) > > >>I too have been fighting high oil temps with an IO-360 in an RV-8A. Can >>you >>put me in contact with your source for louvers? >> >>Vince Welch > > > I had them made locally using Home Depot aluminum by a guy who > does it for race cars. Another source is at this link: > > http://www.attawayair.com/rv6a.htm > > Ron Lee > > > ________________________________________________________________________________
Date: Feb 20, 2006
Subject: Re: Help on Holes in Fuse for Brake Lines...
Matt, I believe that the elbow is not attached to the skin, but rather the landing gear mount, where the elbow fitting is inserted up the hole on the mount with the nut on top. The fuel vent fitting you mentioned is directly attached to the skin. Scott www.scottfarner.com RV-7A Finish On 2/20/06, Matt Johnson wrote: > > > I was drilling the holes for the landing gear and the brake lines as per > the template on DWG 34A for the RV-7A. It says to enlarge the pilot > hole for the brake line as per DWG 28. DWG 28 says to drill it to 5/8" for > the brake line. The problem is that 5/8" seems waay to big for the > hardware called out on DWG 36A (AN837-4D 45 deg. Elbow). I already drilled > the hole to 5/8" per the plans and there is a lot of wiggle > room. Are the plans wrong on this or am I missing something??? > > P.S. I noticed that on another fitting (the fuel vent) it calls out 7/16" > hole in the fuse skin which seems correct... > > - Matt > > ________________________________________________________________________________
Subject: FS: uEncoder, g-meter
Date: Feb 20, 2006
I'm re-doing my panel yet again before even flying the plane, so... FOR SALE: installed in panel but never used, repacked in original packaging... Rocky Mountain Instruments microEncoder -More info at http://www.rkymtn.com/ -Fully assembled and tested, all current updates & software -GREAT support from RMI is transferrable, just give them the serial num. -Kit is $879, sell for $600 including shipping (continental US) Wultrad G-Meter CA 5 -2.25" Panel mount, unlit -$210 new, sell for $150 including shipping (continental US) Picture of both installed in panel... http://www.romeolima.com/RV3works/Panel/DSC_0627.jpg Contact: Randy Lervold, 360-882-8728 or randy(at)romeolima.com ________________________________________________________________________________
Date: Feb 20, 2006
Folbrecht, Paul wrote: >I'm about to close up my VS and need to decide if there's anything I want to put in there. > >Paul > >You'll want to make the H/S fiberglass tip removable and open up the two forward tooling holes and put snap bushings in them, then you can add anything you want at a later date. > > George in Langley BC ________________________________________________________________________________
Date: Feb 20, 2006
Thanks Scott. I would have never guessed that on my own and I looked at the plans many times. Thank God for these forums. - Matt -----Original Message----- From: "Scott Farner" <sfarner(at)gmail.com> Date: Mon, 20 Feb 2006 19:37:35 -0800 Subject: Re: RV-List: Help on Holes in Fuse for Brake Lines... > > Matt, > > I believe that the elbow is not attached to the skin, but rather the > landing > gear mount, where the elbow fitting is inserted up the hole on the > mount > with the nut on top. > > The fuel vent fitting you mentioned is directly attached to the skin. > > Scott > www.scottfarner.com > RV-7A Finish > > > On 2/20/06, Matt Johnson wrote: > > > > > > I was drilling the holes for the landing gear and the brake lines as > per > > the template on DWG 34A for the RV-7A. It says to enlarge the pilot > > hole for the brake line as per DWG 28. DWG 28 says to drill it to > 5/8" for > > the brake line. The problem is that 5/8" seems waay to big for the > > hardware called out on DWG 36A (AN837-4D 45 deg. Elbow). I already > drilled > > the hole to 5/8" per the plans and there is a lot of wiggle > > room. Are the plans wrong on this or am I missing something??? > > > > P.S. I noticed that on another fitting (the fuel vent) it calls out > 7/16" > > hole in the fuse skin which seems correct... > > > > - Matt > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 21, 2006
I have acquired an active helical GPS antenna I plan to put under the VS radome. See: http://www.sarantel.com/products/#s Doug Gray Folbrecht, Paul wrote: > > I'm about to close up my VS and need to decide if there's anything I want to put in there. > > I know I don't want a strobe there but have been thinking about antenae. However, since it looks like my 9A will be light up front (320 with Catto prop and RG batt), and I didn't do the "optional" lightening holes in the VS spar, I think I want to avoid any unneccessary weight in the VS at all. Many people seem to do the nav & com in the wingtips which seems to work well. > > So, those are my thoughts now, but if someone would like to tell me differently I would like to hear it. Thank you. > > Paul > 9A QB #1176 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 21, 2006
Hi, In the Newark catalog they list the followin numbers as 14 VDC lamps with the same base, T3 1/4: 756 1813 1815 1893 Hope this helps, might find some in auto parts. Paul QB RV-8 ________________________________________________________________________________
Date: Feb 21, 2006
Both pilots can indeed log the time PIC (only when under the hood) if the safety pilot agrees to be the acting pilot in command. Done it many, many times building those multi PIC hours back when I was pursuing the flying career dream. Some may scoff at the concept, but it's very legal and no different than taking advantage of an allowable tax deduction. Bryan Jones - MEI, CFII Houston, Texas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=13755#13755 ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Subject: pitot tube group buy
Date: Feb 21, 2006
Ok fellow builders, I have had several inquiries about whether or not I would discount my pitot tube kits for a group buy. Since I am currently participating in the Hooker harness group buy I can hardly say no. So heres the deal...I will discount the kit by 25% for a group buy of 10 or more, limited to the stock on hand. Anybody interested should just call or email me directly and add your name to the list. As soon as I hit the 10 mark I will ship them out. Those interested can have a look at the kits at the following link: http://www.evansaviationproducts.com/Other%20Products.htm Cheers... Evan Johnson www.evansaviationproducts.com (530) 351-1776 cell ________________________________________________________________________________
Date: Feb 21, 2006
Have to ask - why not hide it? -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton Sent: Monday, February 20, 2006 9:01 PM Subject: Re: RV-List: Opinions on antenae in VS My VS on my -10 will have a cats whisker VOR/ILS/GS antenna on the top of it. Bill Britton RV-10 Tailcone #40137 ----- Original Message ----- From: "Ron Lee" <ronlee(at)pcisys.net> Sent: Monday, February 20, 2006 3:52 PM Subject: Re: RV-List: Opinions on antenae in VS > > >> Many people seem to do the nav & com in the wingtips which seems to work >> well. > > I am not sure I have heard of people happy with wingtip comm antenna. > VOR yes. > > > Ron Lee > > > ________________________________________________________________________________
Date: Feb 21, 2006
Subject: Remember Von Alexander?
Hey guys, I was just wondering if you guys remember Von Alexander. He died in the Rv-8 that me (his son) and him built. It crashed in July of 1999 on its way home from the Arlington Airshow. I know he really LOVED this list and the help that everybody gave him. If you remember him, I would love to hear your thoughts about him and our RV-8 if you had a chance to see it. Also I had another idea that I wanted your guy's feedback on. I thought about having a "Fly in Lunch" at the Independence Oregon Airport in memory of my dad. Maybe around the 10th of July (when the accident occured). Would anybody be up to flying their rv's and join in on it? Just a thought. THANKS! Kelby L Alexander Fight the power! BlazeMail.com ________________________________________________________________________________
Date: Feb 21, 2006
Subject: Re: Remember Von Alexander?
kelby alexander wrote: > > > > Hey guys, I was just wondering if you guys remember Von Alexander. He > died in the Rv-8 that me (his son) and him built. It crashed in July > of 1999 on its way home from the Arlington Airshow. I know he really > LOVED this list and the help that everybody gave him. If you remember > him, I would love to hear your thoughts about him and our RV-8 if you > had a chance to see it. Hi Kelby, I remember with fondness your Dad's enthusiasm for his RV-8 and his eagerness to associate with this list. I was building my RV-6 while your -8 was coming together and recall many of the construction issues we all worked through at that time. I never had an opportunity to see your plane since we live on opposite sides of the country, but the RV-8 photo was on my website for several years. I hope the years since the accident have enhanced the great memories you have of your father and the project you shared. I wish you and your family the very best. Sam Buchanan ________________________________________________________________________________
Date: Feb 21, 2006
Kelby: I remember Von. I offered to pick him up in Green Bay and get him to Oshkosh one year....obviously before he had the 8 done. He was always very helpful on the RV list, which was much appreciated. A flyin in his memory sure sounds like a great idea. I am sure the guys out on the left coast will be interested. Regards, Jeff Orear RV6A N782P Peshtigo, WI ----- Original Message ----- From: "kelby alexander" <n41va(at)blazemail.com> Sent: Tuesday, February 21, 2006 9:51 PM Subject: RV-List: Remember Von Alexander? > > > Hey guys, I was just wondering if you guys remember Von Alexander. He died > in the Rv-8 that me (his son) and him built. It crashed in July of 1999 on > its way home from the Arlington Airshow. I know he really LOVED this list > and the help that everybody gave him. If you remember him, I would love to > hear your thoughts about him and our RV-8 if you had a chance to see it. > > > Also I had another idea that I wanted your guy's feedback on. I thought > about having a "Fly in Lunch" at the Independence Oregon Airport in memory > of my dad. Maybe around the 10th of July (when the accident occured). > Would anybody be up to flying their rv's and join in on it? Just a > thought. > > > THANKS! > > > Kelby L Alexander > > > Fight the power! BlazeMail.com > > > ________________________________________________________________________________
Date: Feb 21, 2006
In a message dated 2/21/2006 7:55:18 P.M. Pacific Standard Time, n41va(at)blazemail.com writes: Hey guys, I was just wondering if you guys remember Von Alexander. He died in the Rv-8 that me (his son) and him built. It crashed in July of 1999 on its way home from the Arlington Airshow. I know he really LOVED this list and the help that everybody gave him. If you remember him, I would love to hear your thoughts about him and our RV-8 if you had a chance to see it. ====================================== Kelby- I didn't know your dad personally, but knew of him and also his tragic misfortune. I think of him when I run over the few RV mishaps in my mind from time to time. The loss of every RV pilot hits very close to home. Flying RV's is so much fun that we often forget that it can also be dangerous when something goes wrong. I won't be in you area in July, but send all of my good wishes to you and your family. Gary VanRemortel (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Feb 21, 2006
Hello Kelby, Of course I remember your Dad, although I had just met him at the Scappoose fly-in a month or so before his accident. I also remember him well from this RV list. If you haven't already, to the Matronics website (see the bottom of any RV list message, including this one) and search with your Dad's name. It will bring back memories of the questions and thoughts he had while you and he were building. And it reminds me, at least, of the fine man that he was. Of course you know that, but you should know that many of us who knew him or only or primarily through the list know that too. Your idea of a fly-in lunch sounds like a good one, but I STILL won't be flying by then. Thanks for checking back in on the RV list. Terry RV-8A #80729 baffles Seattle -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of kelby alexander Sent: Tuesday, February 21, 2006 7:51 PM Subject: RV-List: Remember Von Alexander? Hey guys, I was just wondering if you guys remember Von Alexander. He died in the Rv-8 that me (his son) and him built. It crashed in July of 1999 on its way home from the Arlington Airshow. I know he really LOVED this list and the help that everybody gave him. If you remember him, I would love to hear your thoughts about him and our RV-8 if you had a chance to see it. Also I had another idea that I wanted your guy's feedback on. I thought about having a "Fly in Lunch" at the Independence Oregon Airport in memory of my dad. Maybe around the 10th of July (when the accident occured). Would anybody be up to flying their rv's and join in on it? Just a thought. THANKS! Kelby L Alexander Fight the power! BlazeMail.com ________________________________________________________________________________
Date: Feb 21, 2006
kelby alexander wrote: > > >Hey guys, I was just wondering if you guys remember Von Alexander. He died in the Rv-8 that me (his son) and him built. It crashed in July of 1999 on its way home from the Arlington Airshow. I know he really LOVED this list and the help that everybody gave him. If you remember him, I would love to hear your thoughts about him and our RV-8 if you had a chance to see it. > > > Hi Kelby, I met your dad at the Twin Oaks flyin breakfast and had some good conversations with him. He was a fine person and I think of him often and the great loss we all experienced. The day he left Arlington he came over to where my wife and I were camped with our RV-6 to say good bye, little did we realize it would be the last good bye. It is hard to believe that happened in 1999 it still seems like yesterday. If a fly in event in your dads memory becomes a reality I would love to attend. I see that July 10th is a Monday so would probably be difficult for working people to attend and the week before that is the Arlington fly in. Maybe you could contact the local EAA 105 and builders group and do something at the Arlington flyin. I know the local builders group always has some type of get together there. Jerry Springer ________________________________________________________________________________
Subject: Replacment Canopy
Date: Feb 22, 2006
Listers I need to source a replacement canopy for an RV7. I've just taken over a quick build project and the original builder has made such a bodge job that I need to start again. I'll be ordering the metal parts from Vans but I seem to recall a thread about a year back on a less expensive source for the plexey. I've tried looking in the archives without success. Can anyone point me in the right direction? Neil Henderson RV9 Flying ________________________________________________________________________________
Date: Feb 21, 2006
Wow thats hard to think about isnt it? You know that was pretty much the only time in 16 years I didnt fly with my dad. I woke up that morning with an invitation to go surfing or go with my dad to Arlignton. I decided without a doubt to go to the airshow but my dad wouldnt let me, he told me I would be too hot in the back of the -8. So he made me go surfing but he promised on his way home he would do a couple fly by's at the beach we were at. When he never came over, I knew something was wrong. Having something for him at Arlington is a great idea, or even a "fly in" in June would be great. I just want to make sure that we can have a good turn out. Im am going to be starting an RV-8 of my own (as soon as I save up the money, hopefully this summer) in his memory. So if anybody has any old tools they would like to donate or sell me or a portion of a hanger to work in ( I will be in the Salem Oregon area) Please drop me an email. I hope to be able to start on the tail kit in a few months. I am 23 so money isnt easy to come by, but I think I can do it over time. So be prepared for a TON of questions. I am going to dedicate it to my Father and every other RV pilot that we have lost over the years. I will keep in touch with you guys about a fly in, if you all would be up to it!? Thanks for your time and kind words, its so nice to know my Dad had a good reputation with you guys and I hope I can follow in his footsteps and be friends with you guys as well. He ALWAYS had only good things to say about this list. And when it was midnight and we were totally stuck on something, he would always say, forget it tonight, Ill just ask the guys on the RV list, they will know the answer. I look forward to meeting as many of you guys as possible over the years. --- Jerry Springer jsflyrv(at)comcast.net wrote: From: Jerry Springer jsflyrv(at)comcast.net Date: Tue, 21 Feb 2006 21:33:44 -0800 Subject: Re: RV-List: Remember Von Alexander? -- RV-List message posted by: Jerry Springer jsflyrv(at)comcast.net kelby alexander wrote: -- RV-List message posted by: kelby alexander n41va(at)blazemail.com Hey guys, I was just wondering if you guys remember Von Alexander. He died in the Rv-8 that me (his son) and him built. It crashed in July of 1999 on its way home from the Arlington Airshow. I know he really LOVED this list and the help that everybody gave him. If you remember him, I would love to hear your thoughts about him and our RV-8 if you had a chance to see it. Hi Kelby, I met your dad at the Twin Oaks flyin breakfast and had some good conversations with him. He was a fine person and I think of him often and the great loss we all experienced. The day he left Arlington he came over to where my wife and I were camped with our RV-6 to say good bye, little did we realize it would be the last good bye. It is hard to believe that happened in 1999 it still seems like yesterday. If a fly in event in your dads memory becomes a reality I would love to attend. I see that July 10th is a Monday so would probably be difficult for working people to attend and the week before that is the Arlington fly in. Maybe you could contact the local EAA 105 and builders group and do something at the Arlington flyin. I know the local builders group always has some type of get together there.
February 02, 2006 - February 22, 2006
RV-Archive.digest.vol-rr
