RV-Archive.digest.vol-rz
May 30, 2006 - June 13, 2006
Date: May 30, 2006
Couple of points on this topic: 1. A friend said they used to (probably still do) add steel weights to the tail of AT-6's that race in Reno for speed improvements. Can't recall, but I believe they have minimum weights and are probably working with that number but just shifting the CG aft. 2. A few years back I started trying to quantify this situation with adding weight aft. I never got a conclusive answer, but wondered if the benefit of adding ballast to move the CG aft offset the penalty of added overall weight. Example: I am flying (racing) with a near empty airplane. Would the plane be faster with 50-lbs of ballast in the rear baggage compartment than without the 50-lbs? Or faster with 50-lbs of ballast and if I lost 20-lbs?? ;) Seriously, it sounds like there may be some conditions where the added overall weight to move the CG aft may help. Bryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=37502#37502 ________________________________________________________________________________
Subject: Re: How to add 15kt to cruise speed by adding weight
Date: May 30, 2006
Passed on for what it's worth ... I've seen it demonstrated, in the big iron, when the airlines loaded the a/c tail heavy, the elevator would raise the tail and thereby, create an airfoil shape. The hs/elevator would sort of act like an airfoil and create lift. The up movement of the tail would reduce the wing incidence and shed some induced drag. Jerry Grimmonpre' RV8A Electrical > I discovered the same effect in my RV-6A which is a bit nose heavy. Best > top speed was when I had the baggage compartment load to the max with > camping gear and full wing tanks. I suspect you are correct in that the > aft > CG results in less down component from the horizonal stabilizer resulting > in > less drag. The wing incident may also be a bit more optimum (less) also > resulting in less drag. As best I could determine my speed increase was > between 8-10 MPH. > > Ed > Ed Anderson > Rv-6A N494BW Rotary Powered > Matthews, NC > eanderson(at)carolina.rr.com ________________________________________________________________________________
Date: May 30, 2006
You could do some very careful calculations, then try adding a much smaller weight in the far aft tailcone area somewhere. You wouldn't need remotely as much ballast as something in the baggage compartment - a few pounds would be pretty significant. Not something you would want to do casually. If remotely in doubt, you'd want to reweigh the plane afterwards and reverify the CG information. As you say, 50 pounds of ballast could easily offset the advantages of pushing the CG back. This would at least require far less than 50 pounds. -Joe On May 30, 2006, at 4:35 PM, bdjones1965 wrote: > > Couple of points on this topic: > > 1. A friend said they used to (probably still do) add steel > weights to the tail of AT-6's that race in Reno for speed > improvements. Can't recall, but I believe they have minimum > weights and are probably working with that number but just shifting > the CG aft. > > 2. A few years back I started trying to quantify this situation > with adding weight aft. I never got a conclusive answer, but > wondered if the benefit of adding ballast to move the CG aft offset > the penalty of added overall weight. > > Example: I am flying (racing) with a near empty airplane. Would > the plane be faster with 50-lbs of ballast in the rear baggage > compartment than without the 50-lbs? Or faster with 50-lbs of > ballast and if I lost 20-lbs?? ;) > > Seriously, it sounds like there may be some conditions where the > added overall weight to move the CG aft may help. > > Bryan ________________________________________________________________________________
Date: May 30, 2006
Subject: Re: mixture cable flexing
Erich: I am not flying yet, but I was also uncomfortable with that short run. All connections between the firewall and the engine should have plenty of slack in them. Another local builder whose 6A has been flying for a long time now advised me to penetrate the firewall well above - about 12" above - the fuel controller and have the cable do a graceful "S" down to the attach bracket. That is what I did for both throttle and mixture. You can have too little slack, but too much is not a problem, so err on the side of too much. BTW, mine is a vert. induction, so this may not be an issue for you, but I found the AFP-supplied cable mounting brackets to be unusable on a 6A and made my own which were essentially the mirror image of the AFP brackets. There just isn't room to get the standard brackets to fit around the engine mount tubes on a 6A without hacking away more of the bracket than I was comfortable with. This allowed me to maintain a good separation (about 1/2" as I recall) between the brackets and the engine mount tubes. Also, I had very good experience dealing with Cablecraft. They're expensive, but their cables have a shorter bend radius spec than the cheaper ones from Spruce. They also claim to have a gradual failure mode. I had some shipping damage on my first shipment and they made good on it, no questions asked, no fooling around with UPS claims, so their customer service was excellent. Erich_Weaver(at)URSCorp.com wrote: >However, with the >mixture cable in particular, the distance between the firewall pass-through >point and the point where the cable attaches to the bracket is very short >- maybe 4 inches. This short distance doesnt allow any room for curving >the cable and allowing it to flex during engine shaking etc, especially >since the eyeball socket at the firewall cable does not allow the cable to >slip in and out at all. > > ________________________________________________________________________________
Date: May 30, 2006
--- DAVID REEL wrote: > > > I've been exploring the CG range in flight testing > of my RV8A and have found > an unanticipated cruise speed effect. At 85.9 > inches, I was getting 155kias > with 2300rpm, 23 in mp, 5,500 ft, and 42 degrees F > outside. At 79.6 inches, > I got 142kias with 2300rpm, 23 in mp, 4,500 ft, and > 64 degrees F outside. > My whiz wheel gives true airspeeds of roughly 169kt > and 154kt. Quite an > improvement just by adding some weight in back. > Yes, the fast flight was > with a little bit higher weight! > > There's lots of discussion of speed improvements in > the archives, but > nothing related to CG location that I could find and > certainly nothing so > easy to get and of this magnitude. So, my question > to everyone is have you > had similar experience? Do you know anywhere this > has been quantified or > further detailed? After all, I'm just comparing two > test flights here, but > theoretically, I'd guess the decrease in drag due to > decreased pitch > stability requirements as the CG moves aft would > explain the speed increase. > > Excited! A few comments: 1. If you keep the rpm and MP the same, the power produced increases as you increase altitude (due, I think, to the lower exhaust back pressure helping improve the engine's breathing). So, the test at 5,500 ft was with higher power than the test at 4,500 ft. The air temperature was also quite a bit lower for the 5,500 ft test point. I don't know what engine you have, but if you have an IO-360-A series engine, the power at 5,500 ft was about 67.2%, and the power at 4,500 ft was about 65.1%. If you had an O-360-A series engine, the power at 5,500 ft was about 75%, and at 4,500 ft it was about 72.6%. As Alex Peterson mentioned, the mixture setting could also play a role, as you can change the power by changing the mixture, at the same rpm and MP. 2. ASIs have instrument error, and the error will be different at different indicated airspeeds. Static system position error is also different at different indicated airspeeds. Given items 1 and 2, it would be very interesting to repeat these tests at the same altitude. It will also be interesting to record the fuel flow, to be sure it is the same for each test. 3. At a given weight, there is less drag as you move the CG aft (with the CG in approved limits). The tail has to produce a down force to balance out the nose down pitching moment from the wing, and the fact that the CG is ahead of the wing's centre of pressure. The total lift that the wing has to produce is equal to the aircraft's weight, plus the amount of down force that the tail is producing. If you keep the aircraft weight the same, and move the CG aft, the amount of down force that the tail needs to produce decreases. This reduces the drag from the tail, but more importantly, it also reduces the amount of lift that the wing has to generate. So, if you move some item of weight aft (baggage, a body, etc), that will help reduce drag. 4. If you can't move an item of weight aft, some people are interested to know if you can improve performance by adding weight aft. Ideally, the weight you add would be in the area of the horizontal stab, or further aft. In this case, the amount of down force that the tail needs to produce is decreased. This reduces drag, as there is less induced drag from the tail. But, the amount of lift that the wing has to generate has not changed, for as far as it is concerned, we have simply replaced some down force from the tail by down force from gravity on our added weight. So the wing's induced drag does not change. 5. If you can't put the added weight at the HS, what about putting it in the baggage compartment? In this case, some of the additional weight is supported by the wing, and some by the tail. So the amount of tail down force decreases a bit, but the amount of lift that the wing has to generate increases. Depending on how far aft the baggage compartment is, the total drag may be increased or decreased. My gut feel is that in most cases the total drag would be increased. 6. it is very difficult to obtain repeatable speed vs power data. Any one test point may be in error due to poor air quality, not waiting long enough for the speed to stabilize, errors in setting the power or mixture, or errors in recording the data, etc. I wouldn't draw any conclusions from one set of tests. If you can do the same test on three or four different days and get the same speed vs power, then you know you have something. Keep us posted as you do more tests. Kevin Horton RV-8 (Finishing Kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: How to add 15kt to cruise speed by adding weight
Date: May 30, 2006
I see the same thing in my -4. Put about 100-120 lbs in the back seat and gain about 10 kts. It is very noticeable. Next time you fly solo, trim out the plane and look at the level the elevator sits relative to the HS. Add a passenger and look again. In my plane with a 120lb passenger, the elevators will be almost level with the HS, but flying solo they are quite a bit different. -Mike -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DAVID REEL Sent: Tuesday, May 30, 2006 10:48 AM Subject: RV-List: How to add 15kt to cruise speed by adding weight I've been exploring the CG range in flight testing of my RV8A and have found an unanticipated cruise speed effect. At 85.9 inches, I was getting 155kias with 2300rpm, 23 in mp, 5,500 ft, and 42 degrees F outside. At 79.6 inches, I got 142kias with 2300rpm, 23 in mp, 4,500 ft, and 64 degrees F outside. My whiz wheel gives true airspeeds of roughly 169kt and 154kt. Quite an improvement just by adding some weight in back. Yes, the fast flight was with a little bit higher weight! There's lots of discussion of speed improvements in the archives, but nothing related to CG location that I could find and certainly nothing so easy to get and of this magnitude. So, my question to everyone is have you had similar experience? Do you know anywhere this has been quantified or further detailed? After all, I'm just comparing two test flights here, but theoretically, I'd guess the decrease in drag due to decreased pitch stability requirements as the CG moves aft would explain the speed increase. Excited! Dave Reel - RV8A ________________________________________________________________________________
Date: May 30, 2006
Joe and others, 5 years ago when I first began racing the Air Venture race and others, I added a lead pig (approx 10 lbs) to the tail area of my RV8 to improve the CG. I mounted it just aft of the tail wheel in the tail cone. It fit very nicely and did improve the airspeed. However after a couple hundred hours , I noticed that my tailwheel spring rod was bending (taking a set) . I removed the tail weight and replaced the tailwheel attach rod. I now use a lead shot bag, 25 lbs strapped to the baggage floor and installed or removed as needed with a heavy passenger. The speed improvement is about the same with either of the about the same. On a separate note: I am getting ready for the Air Venture race this summer and would encourage all of you who have flying airplanes to particiipate. Don't worry about not having the fastest airplane. You will learn a lot by participating and competing with the other guys. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: "Joseph Larson" <jpl(at)showpage.org> Sent: Tuesday, May 30, 2006 5:22 PM Subject: Re: RV-List: Re: How to add 15kt to cruise speed by adding weight > > You could do some very careful calculations, then try adding a much > smaller weight in the far aft tailcone area somewhere. You wouldn't > need remotely as much ballast as something in the baggage compartment > - a few pounds would be pretty significant. > > Not something you would want to do casually. If remotely in doubt, > you'd want to reweigh the plane afterwards and reverify the CG > information. > > As you say, 50 pounds of ballast could easily offset the advantages > of pushing the CG back. This would at least require far less than 50 > pounds. > > -Joe > > On May 30, 2006, at 4:35 PM, bdjones1965 wrote: > >> >> Couple of points on this topic: >> >> 1. A friend said they used to (probably still do) add steel >> weights to the tail of AT-6's that race in Reno for speed >> improvements. Can't recall, but I believe they have minimum >> weights and are probably working with that number but just shifting >> the CG aft. >> >> 2. A few years back I started trying to quantify this situation >> with adding weight aft. I never got a conclusive answer, but >> wondered if the benefit of adding ballast to move the CG aft offset >> the penalty of added overall weight. >> >> Example: I am flying (racing) with a near empty airplane. Would >> the plane be faster with 50-lbs of ballast in the rear baggage >> compartment than without the 50-lbs? Or faster with 50-lbs of >> ballast and if I lost 20-lbs?? ;) >> >> Seriously, it sounds like there may be some conditions where the >> added overall weight to move the CG aft may help. >> >> Bryan > > > ________________________________________________________________________________
Date: May 30, 2006
I fly my -4 with a 40lb bag of salt in the baggage compartment (sans passenger of course)...haven't noticed the speed difference, but it does fly better...I'll have to check that out. Paul B esing --- Mike Kraus wrote: > > > I see the same thing in my -4. Put about 100-120 > lbs in the back seat > and gain about 10 kts. It is very noticeable. Next > time you fly solo, > trim out the plane and look at the level the > elevator sits relative to > the HS. Add a passenger and look again. In my > plane with a 120lb > passenger, the elevators will be almost level with > the HS, but flying > solo they are quite a bit different. > > -Mike > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On > Behalf Of DAVID REEL > Sent: Tuesday, May 30, 2006 10:48 AM > To: rvlist > Subject: RV-List: How to add 15kt to cruise speed by > adding weight > > > > > I've been exploring the CG range in flight testing > of my RV8A and have > found an unanticipated cruise speed effect. At 85.9 > inches, I was > getting 155kias with 2300rpm, 23 in mp, 5,500 ft, > and 42 degrees F > outside. At 79.6 inches, I got 142kias with > 2300rpm, 23 in mp, 4,500 > ft, and 64 degrees F outside. My whiz wheel gives > true airspeeds of > roughly 169kt and 154kt. Quite an improvement just > by adding some > weight in back. Yes, the fast flight was with a > little bit higher > weight! > > There's lots of discussion of speed improvements in > the archives, but > nothing related to CG location that I could find and > certainly nothing > so easy to get and of this magnitude. So, my > question to everyone is > have you had similar experience? Do you know > anywhere this has been > quantified or further detailed? After all, I'm just > comparing two test > flights here, but theoretically, I'd guess the > decrease in drag due to > decreased pitch stability requirements as the CG > moves aft would explain > the speed increase. > > Excited! > > Dave Reel - RV8A > > > > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Subject: Burnt out MAC indicator?
Date: May 30, 2006
One of the rectangluar LED's on my MAC pitch trim indicator seems to be burnt out. Am I the first to have this happen? Guess the only fix is to replace the whole thing? ($86!) - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: May 30, 2006
What are we to make of the speeds that Van gives for solo and gross weights? About one mph slower at gross, tandem or side-by side. jb ________________________________________________________________________________
Date: May 31, 2006
Van's cruise performance testing is usually done at a 8,000' density altitude using full throttle and 2500 RPM. (It helps to remove as many variables as possible when doing performance testing.) I have used a 7,500' density altitude for my RV-3 performance testing. This has been a station altitude of 5,500', at times. I have an RMI MicroEncoder in my RV-3, so I can get a direct readout on density altitude (I believe the outside air temperature is even corrected for compressibility effects). Jim Ayers In a message dated 05/30/2006 9:11:04 PM Pacific Daylight Time, jebrick(at)comcast.net writes: --> RV-List message posted by: "John Brick" What are we to make of the speeds that Van gives for solo and gross weights? About one mph slower at gross, tandem or side-by side. jb ________________________________________________________________________________
Date: May 31, 2006
I like both Dan and Rick's explanations and throw in a specific example of a very unstable airplane to illustrate the aft CG phenomnon. I used to fly an airplane that had the CG well aft of the center of lift (CL). In this configuration the tail plane needed to produce lift in order to keep the aircraft level. The advantage of this configuration was that both the wing and tail plane created lift in most every flight regime rather than the wing producing lift and the tail plane producing down force as for a conventionally balance aircraft. This made for some extremely tight turns and rapid response to control inputs but also made the aircraft impossible to control by the most experienced pilots. Solution: Put a computer in charge of stability and let the pilot input his desires through an electronic input to the computer. Thus you have fly-by-wire technology and the only way to control an F-16. Ron Schreck RV-8 "Miss Izzy" Gold Hill Airpark, NC I like Dan's explanation, but will add a bit more. Specifically, we require the CG to be forward of the center of lift (CL) in order to have a stable aircraft (and one whose nose drops when the wing is stalled). The closer the CG gets to the CL, the less induced drag, but the less stable the plane will be. If the CG should go aft of the CL, all bets are off in terms of controllability. Another e-mail commented on Bonanzas and how their CG moves with fuel burn. Whether the CG moves aft with fuel burn should depend on the CG of the tank and its fuel relative to the CG of the plane. I fly an A-36 Bonanza, and when weight is up (hence, realistically, with a CG farther aft than when lightly loaded), I have indeed noticed greater pitch sensitivity after a long flight. When I plan flights at higher weights, I check my loading by calculating CG for zero fuel, just to be on the safe side. For extra margin), I try to land with fuller tanks, too. Rick A-36, RV-7 in process -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Beadle Sent: Tuesday, May 30, 2006 12:38 PM Subject: RE: RV-List: How to add 15kt to cruise speed by adding weight This is basic aerodynamics. To get stability (AKA, hard to flare), you move the CG forward. Think Lawn Dart. In this mode, the tail actually pulls down, not up. This results in the wing needing to produce more lift (weight + the tails negative lift so that total lift = weight). If you move the CG back, you have less and less down-lift on the tail, letting the wing work less, thus getting less induced drag. Faster. A heavier airplane, with the same CG, should fly slower than the same plane, same CG, when it is lighter. The reason is the heavier airplane must have a higher angle of attack to produce the needed additional lift. That means more induced drag. The CG limits are set to give reasonable handling. The forward CG is limited by the ability to flare. The Aft CG is limited by the need for positive stability. If we moved the CG back to where the tail was lifting, we would have no stability. In the normal range, as the plane slows from the trimmed AS, the wing and the tail both lose some lift. But the tail is now lifting less in the downward direction, letting the nose fall down a bit and resume the trimmed AS. If we move too far back, we lose the stability feature making the airplane difficult or impossible to fly. Rule of thumb: smooth air, load for aft CG (within limits). Rough air, keep a more forward CG. So your data does make sense. (But the faster/heavier combination is probably just due to aft CG.) Dan ________________________________________________________________________________
Date: May 31, 2006
Subject: Re: Burnt out MAC indicator?
I had this happen to me too. I sent an e-mail to RayAllenCo and they took care of it! YMMV - but they were good to me! -----Original Message----- >From: Larry Bowen <Larry(at)bowenaero.com> >Sent: May 30, 2006 10:52 PM >To: rv-list(at)matronics.com >Subject: RV-List: Burnt out MAC indicator? > > >One of the rectangluar LED's on my MAC pitch trim indicator seems to be >burnt out. Am I the first to have this happen? Guess the only fix is to >replace the whole thing? ($86!) > >- >Larry Bowen >Larry(at)BowenAero.com >http://BowenAero.com > > > > > > > ________________________________________________________________________________
Date: May 31, 2006
Anyone who is thinking about moving the CG aft by adding some weight needs to keep two things in mind: 1. The weight should be properly secured. You don't want it coming loose during turbulence or an off-field landing and hitting you in the back of the head. 2. Adding weight aft will increase the moment of inertia on the yaw axis, and this will probably degrade the spin characteristics. I.e the results from any spin testing you did without that weight are now invalid. Kevin Horton RV-8 (Finishing Kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: May 31, 2006
To say nothing of having unsecured weight in the tail that, during a steep climb-out, slips even further back. You have now just been promoted to test pilot; one that may have his hands...and shorts full. Chuck Jensen > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Kevin Horton > Sent: Wednesday, May 31, 2006 8:11 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Re: How to add 15kt to cruise speed by adding weight > > > Anyone who is thinking about moving the CG aft by > adding some weight needs to keep two things in mind: > > 1. The weight should be properly secured. You don't > want it coming loose during turbulence or an off-field > landing and hitting you in the back of the head. > > 2. Adding weight aft will increase the moment of > inertia on the yaw axis, and this will probably > degrade the spin characteristics. I.e the results > from any spin testing you did without that weight are > now invalid. > > Kevin Horton > RV-8 (Finishing Kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > > > > > > > > > > ________________________________________________________________________________
Date: May 31, 2006
Larry you are right about that. I recently replaced mine after losing several leds over a span of about 1 year. Call Ray Allen. He may cut you a little slack on the replacement. Dick At 10:52 PM 5/30/2006, you wrote: > >One of the rectangluar LED's on my MAC pitch trim indicator seems to be >burnt out. Am I the first to have this happen? Guess the only fix is to >replace the whole thing? ($86!) > >- >Larry Bowen >Larry(at)BowenAero.com >http://BowenAero.com > > ________________________________________________________________________________
Subject: Re Aft CG speed gains
Date: May 31, 2006
Lots of posts on this, I remeber when I was on Cherokee chat, I read about Art Matsen, who usually won Cherokee races, and he had to have a second person, not co-pilot, and would always have him in back seat. Charlie H ________________________________________________________________________________
From: "Jim Pleasants" <jpleasants(at)bellsouth.net>
Subject: Re: GPS Tracking...
Date: May 31, 2006
FWIW, my Pilot III handheld shows a "trail of breadcrumbs" on the map display, and the maps are suprisingly accurate (for me), and will scale way down. Jim Pleasants -- ________________________________________________________________________________
Date: May 31, 2006
Thanks for all the input. I'll give Ray a call and if that doesn't pan out I'll get the parts book and soldering iron or check for someone selling one. Mickey - I reference it almost anytime I'm adjusting it. I know what the normal positions are for my plane during different phases of flight, so I can confirm everything is normal in regards to trim. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Richard Seiders wrote: > > Larry you are right about that. I recently replaced mine after losing > several leds over a span of about 1 year. Call Ray Allen. He may cut you a > little slack on the replacement. > Dick > > > At 10:52 PM 5/30/2006, you wrote: >> >>One of the rectangluar LED's on my MAC pitch trim indicator seems to be >>burnt out. Am I the first to have this happen? Guess the only fix is to >>replace the whole thing? ($86!) >> >>- >>Larry Bowen >>Larry(at)BowenAero.com >>http://BowenAero.com >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: May 31, 2006
I lost a couple of elements in several of mine after my voltage regulator failed and they saw high voltage. Just something you might want to check. Bryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=37647#37647 ________________________________________________________________________________
Date: May 31, 2006
To answer a few questions that came up, I was leaned out during both tests but I lean by ear and have no fuel flow meter. At 5,500 ft, I have measured 9.2 to 9.4 gph using the 'fly it half an hour on one tank then see how much it takes to refill the tank' method. To get the aft CG, I added weight to a fixture I built for the aft baggage shelf and added a 50 lb sand bag to the aft seat. Total 142 lb. I can refly the forward CG test at the higher altitude & will report the result. But it will probably be a while because I'm flying the RV to Brady TX for paint. I'll have to leave it there about a month. Of course, I'll put everything in the aft baggage compartment for the flight! Dave ----- Original Message ----- From: "DAVID REEL" <dreel(at)cox.net> Sent: Tuesday, May 30, 2006 10:47 AM Subject: How to add 15kt to cruise speed by adding weight > I've been exploring the CG range in flight testing of my RV8A and have found > an unanticipated cruise speed effect. At 85.9 inches, I was getting 155kias > with 2300rpm, 23 in mp, 5,500 ft, and 42 degrees F outside. At 79.6 inches, > I got 142kias with 2300rpm, 23 in mp, 4,500 ft, and 64 degrees F outside. > My whiz wheel gives true airspeeds of roughly 169kt and 154kt. Quite an > improvement just by adding some weight in back. Yes, the fast flight was > with a little bit higher weight! > > There's lots of discussion of speed improvements in the archives, but > nothing related to CG location that I could find and certainly nothing so > easy to get and of this magnitude. So, my question to everyone is have you > had similar experience? Do you know anywhere this has been quantified or > further detailed? After all, I'm just comparing two test flights here, but > theoretically, I'd guess the decrease in drag due to decreased pitch > stability requirements as the CG moves aft would explain the speed increase. > > Excited! > > Dave Reel - RV8A > ________________________________________________________________________________
Subject: Intercom PS Engineering / Sigtronics...Try NAT
Date: May 31, 2006
I agree that the PS is a far superior intercom. Even better is NAT. NAT is used by the Hello crowd. Got mine from a salvage yard and the wiring schematic from their web site. I can't believe the sound quality and range of the NAT. BTW, paid 75 dollars for the NAT and all the jacks....... PS Engineering all the way...can't beat the quality or customer service...not too much more expensive, but the audio quality is far superior, IMHO...I've had both sigtronics and PS Engineering...there's a reason that sigtronics sells "budget quality" headsets and avionics. Spend the extra money on PS Engineering in my opinion. Paul Besing --- Charles Heathco wrote: > > > I have a mono flightcom 403 that has alwqys had a > slight echo, and it > has a static discharge sound every so often. I want > to upgrad and am > thinking Sigtronics steri might be a good choice. > Would like coments, > and also will I have to change headst jacks? Charlie > H > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Subject: Re: Cheap Thrills
Date: May 31, 2006
I thought the topic was low level river flying, not air shows or aerobatics performed by a seasoned professional. In any event, I didn't mean to ruffle anyones feathers. My opinion was just that, my opinion. Have fun and be safe. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=37665#37665 ________________________________________________________________________________
Date: May 31, 2006
martin(at)gbonline.com wrote: > Joe and others, > 5 years ago when I first began racing the Air Venture race and others, I > added a lead pig (approx 10 lbs) to the tail area of my RV8 to improve the CG. I sure don't need any corrective ballast, but am thinking I might see what the effect of moving my battery aft (with an O-320 up front) would have on the CG envelope... Gotta carry it anyway. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=37667#37667 ________________________________________________________________________________
Subject: Bagage compartment balast
Date: May 31, 2006
________________________________ Message 53 ____________________________________ >I fly my -4 with a 40lb bag of salt in the baggage >compartment (sans passenger of course)...haven't >noticed the speed difference, but it does fly >better...I'll have to check that out. Paul: is this for better traction, like in my truck? RV-4's tend to be a little tail heavy anyway. Did yours come out light? My tool box (bag) and tie downs are always back there but secured as far forward as able. My elevator solo cruise is lined up with the horizontal, slightly elevator down (counterweight slightly above leading edge of horizontal) with a full load. Haven't noticed much change in speed. Michael RV-4 232 Suzie Q ________________________________________________________________________________
Date: May 31, 2006
Subject: Engine mounting bolt question
Listers, Can anyone tell me the length of the AN6 bolts which hold the engine to the motor mount? I'm using a Dynafocal 1 IO-360 Lycoming. Charlie Kuss ________________________________________________________________________________
Date: May 31, 2006
Subject: Re: Bagage compartment balast
Not real sure...just the stick forces seem smoother in pitch, not as squirly. I have a wood prop up front, and had to add a 10 lb prop weight just to bring the CG forward...I'm getting ready to have a new weight and balance done, and will see where we are at..since I've changed the panel, new stack on the floor, etc, I need to update it anyway. I'm going to check the weight and balance after it's done with just me, and then with my bag of salt in the back and see where she sits in the envelope. Then I'm gonna fly her both configurations and see if I can see a speed difference. I just prefer the feel when I have the bag of salt back there...never was intended to be a performance enhancer, but if I get more speed, great! Paul Besing --- Michael wrote: > > > > > > > > ________________________________ Message 53 > ____________________________________ > >I fly my -4 with a 40lb bag of salt in the baggage > >compartment (sans passenger of course)...haven't > >noticed the speed difference, but it does fly > >better...I'll have to check that out. > > Paul: is this for better traction, like in my truck? > RV-4's tend to be a > little tail heavy anyway. Did yours come out light? > My tool box (bag) and > tie downs are always back there but secured as far > forward as able. My > elevator solo cruise is lined up with the > horizontal, slightly elevator down > (counterweight slightly above leading edge of > horizontal) with a full load. > Haven't noticed much change in speed. > > Michael > > RV-4 232 Suzie Q > > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Date: May 31, 2006
>>I fly my -4 with a 40lb bag of salt in the baggage >>compartment (sans passenger of course)...haven't >>noticed the speed difference, but it does fly >>better...I'll have to check that out. For what it's worth ... Please be careful and watch the bag of salt for tiny holes. These holes develop because of the bag being mishandled at the vendor's store. You may find corrosion starting from the very fine granules sifting through the tiny holes and working their way into aluminum joints. The fine granules are generated from the same mishandling that causes tiny holes. Jerry Grimmonpre' RV8A Electrical ________________________________________________________________________________
Subject: Re: The brake thing some more
Date: May 31, 2006
----- Original Message ----- From: "Michael" <cubflyr(at)comcast.net> Sent: Wednesday, May 31, 2006 11:15 AM Subject: RV-List: The brake thing some more > >>I saw nothing in Wheeler's post that should cause this kind of nasty >>reply. > Here, Here, to that Now is your chance to delete this nonsense or forever hold your peace. Michael I was once teaching a new aviator (3 to 5 hours) Helicopter primary flight, demonstrating setteling with power. When the Big Scielence (engine failure) over came us. It being a demonstration only manuver with considerable altitude, I was already on the controls, entered autorotation, made all the radio calls, and setteled back to enjoy the quiet. The scielense was almost immediatly broken when the student pilot screamed in quit an aggitated tone," What do I do, What do I do." My reply," Grab that switch and recycle the rotating beacon at three second intervals." After we were back at the breafing room, I could still see the dismay covering the student's face. I ask," What's the matter kid?" He said," Sir' I just can't understand what recycle the rotation beacon.........." Interupting him, I explaned that it occupied his mind and kept his hands clear of the controls while I was taking care of bussiness. A big smile errased the look of pusselment from his face,I winked, and he resumed telling his fellow student aviators about his hair raising event. Now from all this you can conclude that almost any action you take that doesn't make a bad situation worse has a good chance of improving it. On this list you pick out the salutions you like and file the rest away for later referance but,you never dismiss any or alienate anyone that offered them with good intention, because this is an inviorment where you never want to run out of salutions. John D. ________________________________________________________________________________
Subject: Re: Engine mounting bolt question
Date: May 31, 2006
Mine were 7-43 and 7-44 for my AFP injected O360 - I'll have to look upwhich mount I have..... ----- Original Message ----- From: "Charlie Kuss" <chaztuna(at)adelphia.net> Sent: Wednesday, May 31, 2006 1:38 PM Subject: RV-List: Engine mounting bolt question > > Listers, > Can anyone tell me the length of the AN6 bolts which hold the engine > to the motor mount? I'm using a Dynafocal 1 IO-360 Lycoming. > Charlie Kuss > > > ________________________________________________________________________________
Date: May 31, 2006
pbesing(at)yahoo.com wrote: > > I just prefer the feel when I have the bag of salt back there...never was intended to be a performance enhancer, but if I get more speed, great! > > Paul Besing Please reconsider the salt. That, when in the presence of miosture, would be a very corrosive. Try sand, dirt, rocks or anything but salt. Bryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=37735#37735 ________________________________________________________________________________
Date: May 31, 2006
My IO-320 has Dynafocal I and as below they are AN7-43 for the top and AN7-44 for the bottom. g > > > Mine were 7-43 and 7-44 for my AFP injected O360 - I'll have to > look upwhich > mount I have..... > ----- Original Message ----- > From: "Charlie Kuss" <chaztuna(at)adelphia.net> > To: > Sent: Wednesday, May 31, 2006 1:38 PM > Subject: RV-List: Engine mounting bolt question > > > > > > Listers, > > Can anyone tell me the length of the AN6 bolts which hold the engine > > to the motor mount? I'm using a Dynafocal 1 IO-360 Lycoming. > > Charlie Kuss > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ---------------------------------------------------------- ________________________________________________________________________________
Date: May 31, 2006
Bird seed works for rear ballast for me. Dale ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: May 31, 2006
Add me to the list! I had 26 hours on my 6-A when parts of my trim indicator wouldn't light. Called Ray Allen and they said to send it in for a look see but that will have to wait for the annual in October as I am having to much fun right now. Tom in Ohio ----- Original Message ----- From: "Ralph E. Capen" <recapen(at)earthlink.net> Sent: Wednesday, May 31, 2006 7:48 AM Subject: Re: RV-List: Burnt out MAC indicator? > > I had this happen to me too. I sent an e-mail to RayAllenCo and they took > care of it! > > YMMV - but they were good to me! > > -----Original Message----- >>From: Larry Bowen <Larry(at)bowenaero.com> >>Sent: May 30, 2006 10:52 PM >>To: rv-list(at)matronics.com >>Subject: RV-List: Burnt out MAC indicator? >> >> >>One of the rectangluar LED's on my MAC pitch trim indicator seems to be >>burnt out. Am I the first to have this happen? Guess the only fix is to >>replace the whole thing? ($86!) >> >>- >>Larry Bowen >>Larry(at)BowenAero.com >>http://BowenAero.com >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: May 31, 2006
Good point, Jerry. I'll keep an eye on it! Paul Besing --- Jerry Grimmonpre wrote: > > > > >>I fly my -4 with a 40lb bag of salt in the baggage > >>compartment (sans passenger of course)...haven't > >>noticed the speed difference, but it does fly > >>better...I'll have to check that out. > > For what it's worth ... > Please be careful and watch the bag of salt for tiny > holes. These holes > develop because of the bag being mishandled at the > vendor's store. You may > find corrosion starting from the very fine granules > sifting through the tiny > holes and working their way into aluminum joints. > The fine granules are > generated from the same mishandling that causes tiny > holes. > Jerry Grimmonpre' > RV8A Electrical > > > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Date: May 31, 2006
I'll bet there are a lot of replies, but that is exactly what you should expect. With more weight in back, the tail has to produce less lift (downward) with it's associated lift drag. Just don't move the CG too far back, there be dragons there. Scott DAVID REEL wrote: > >I've been exploring the CG range in flight testing of my RV8A and have found >an unanticipated cruise speed effect. At 85.9 inches, I was getting 155kias >with 2300rpm, 23 in mp, 5,500 ft, and 42 degrees F outside. At 79.6 inches, >I got 142kias with 2300rpm, 23 in mp, 4,500 ft, and 64 degrees F outside. >My whiz wheel gives true airspeeds of roughly 169kt and 154kt. Quite an >improvement just by adding some weight in back. Yes, the fast flight was >with a little bit higher weight! > >There's lots of discussion of speed improvements in the archives, but >nothing related to CG location that I could find and certainly nothing so >easy to get and of this magnitude. So, my question to everyone is have you >had similar experience? Do you know anywhere this has been quantified or >further detailed? After all, I'm just comparing two test flights here, but >theoretically, I'd guess the decrease in drag due to decreased pitch >stability requirements as the CG moves aft would explain the speed increase. > >Excited! > >Dave Reel - RV8A > > > > > > > > > ________________________________________________________________________________
Subject: More on brakes
Date: Jun 01, 2006
DAMNNN..............Really appreciate the comments on Brake Drag Fix, but really sorry I started such a hassle of hurt feelings. Guess I'll go back to "Van's Air Force"..........llemay1(at)austin.rr.com WABOAH Please......no archive ________________________________________________________________________________
Date: Jun 01, 2006
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Subject: Re: More on brakes
Lowell, You did nothing to be sorry about! You have a few that want to shoot down others options everytime they post. They just seem to know it all. It gets old really quick and my opinion (hope they don't shoot this one down) is that my posts should be read in full and respected as an opinion just the same way the know it all wants their post read and respected. People on the list get upset with me about some of my post but in the end I find they really didn't read in full and understand my post. The information on the brakes was good information and it DID fix an RV7A's dragging and stiff brake issue. Live and let live... Sorry if I've offended anyone. Darrell lowell lemay wrote: DAMNNN..............Really appreciate the comments on Brake Drag Fix, but really sorry I started such a hassle of hurt feelings. Guess I'll go back to "Van's Air Force"..........llemay1(at)austin.rr.com WABOAH Please......no archive --------------------------------- ________________________________________________________________________________
Date: Jun 01, 2006
Lowell ... I too appreciate all contributions of information, tips, hints and everything that makes these little RV's a better airplane to fly. We are very lucky to have an affordable airplane to get our flight fix satisfied while having the freedom to call the airplane our creation. All builders/flyers place value on any tip that makes life easier, safer and affordable. The term "I built it in my garage" really translates to ... "Me and my 100's of RV'er friends built it in my garage by solving assembly problems". Continue offering up your good ideas. Those able to use them, as their own solutions, will see the value of what you express. None of us has the trump card on any builder's idea. Keep on smashing those rivets and squeezing terminals ... Jerry Grimmonpre' RV8A Electrical Sent: Thursday, June 01, 2006 8:54 AM Subject: Re: RV-List: More on brakes > > > Lowell, > > You did nothing to be sorry about! You have a few that want to shoot down > others options everytime they post. They just seem to know it all. It gets > old really quick and my opinion (hope they don't shoot this one down) is > that my posts should be read in full and respected as an opinion just the > same way the know it all wants their post read and respected. People on > the list get upset with me about some of my post but in the end I find > they really didn't read in full and understand my post. The information on > the brakes was good information and it DID fix an RV7A's dragging and > stiff brake issue. > > Live and let live... Sorry if I've offended anyone. > > Darrell > > > lowell lemay wrote: > > DAMNNN..............Really appreciate the comments on Brake Drag Fix, > but really sorry I started such a hassle of hurt feelings. Guess I'll > go back to "Van's Air Force"..........llemay1(at)austin.rr.com WABOAH > Please......no archive > > > --------------------------------- > > > ________________________________________________________________________________
Subject: Seat belt anchor hardware
Date: Jun 01, 2006
Ok, I seem to be suffering from a slight vision problem (don't tell my AME). I can't find a callout for the hardware to attach the seat belt anchor cable to the seat belt anchors in the rear of the fuselage. No bolts were in the bag with the cables and I don't have any AN-4 bolts left that would work there. Oops, forgot to say it's for an RV-6A. Anyone know where the callout is in the plans? And what bag the hardware was supplied in? Many thanks. Patrick Kelley - RV-6A - cabin interior progressing ________________________________________________________________________________
Date: Jun 01, 2006
Subject: wing to fuse fairing
Ok, I have a question about drilling holes in my wing tanks. I am mounting my -6 wings to my fuse and it seems I am to drill holes in the tank flange then mount some plate nuts there. The existing rivets are close enough together that fitting a platenut between them will be tight. Plus there is some squished out pro seal to make a non flat surface for mounting. Drilling holes in my tanks even in the flange makes me cringe. Should I be concerned? I hear the pre drilled airplanes had them already there. Guess I should have thought about that when I built the tanks. Tim RV-6 (ancient kit) N616TB Plan to fly in about 4-6 weeks ________________________________________________________________________________
Date: Jun 01, 2006
Subject: Motor mount question
Listers, Has anyone tried the motor mounts sold by Wicks Aircraft (page 74 of the current catalog)? Part number is EM100-005. I'm wondering if you are happy with them? Charlie Kuss ________________________________________________________________________________
Subject: Re: wing to fuse fairing
Date: Jun 01, 2006
Even the3 predrilled kits come without these holes . As long as you stay away from the rib you will be fine. Make sure that you push the fairing tight to the fuse before drilling. don -------------- Original message ---------------------- From: "Tim Bryan" <flyrv6(at)bryantechnology.com> > > > Ok, I have a question about drilling holes in my wing tanks. I am mount > ing > my -6 wings to my fuse and it seems I am to drill holes in the tank flang > e > then mount some plate nuts there. The existing rivets are close enough > together that fitting a platenut between them will be tight. Plus there > is > some squished out pro seal to make a non flat surface for mounting. > > Drilling holes in my tanks even in the flange makes me cringe. Should I > be > concerned? I hear the pre drilled airplanes had them already there. Gue > ss > I should have thought about that when I built the tanks. > Tim > RV-6 (ancient kit) N616TB > Plan to fly in about 4-6 weeks > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 01, 2006
Tim Bryan wrote: > Ok, I have a question about drilling holes in my wing tanks. I am mounting > my -6 wings to my fuse and it seems I am to drill holes in the tank flange > then mount some plate nuts there. The existing rivets are close enough > together that fitting a platenut between them will be tight. Plus there is > some squished out pro seal to make a non flat surface for mounting. > > Drilling holes in my tanks even in the flange makes me cringe. Should I be > concerned? I hear the pre drilled airplanes had them already there. Guess > I should have thought about that when I built the tanks. Tim, The nut plates used to mount the wing fairing to the tank go through the tank skin overhang, not the tank skin/rib flange joint. (The overhang extends 1/2" inboard of the tank skin/rib flange joint.) Trim the extruded proseal off the skin overhang with a razor blade and scotchbrite wherever a nut plate will be installed. Yea, this is one of those places where holes are at or slightly below minimum edge distance...........but, they only hold the wing fairing in place. Measure carefully before drilling. My early pre-punched wing skins came without these holes. Turned out to be OK, since my wing fairings were not pre-punched. (Ended up making my own fairings anyway.) The usual match drill process worked fine: 1) drill pilot holes in the fairing. 2) mark a line on the tank skin overhang and the wing root rib (aft of the spar). 3) line parts up, tape in place, match drill. Steve RV-6A extreme slow build........ ________________________________________________________________________________
Subject: choices
Date: Jun 01, 2006
Listers: I'm to the point where I need to make some choices as regards autopilots. The advertisements for TruTrak and Trio each "speak highly of themselves". I can't get a clue as to which of these would be, for me, the best choice. I respectfully request that anyone who has a reason to recommend either of these, or any other, please share with me their thoughts -- good, bad, or indifferent. I have the same quandry regarding glass cockpits -- do I choose Dynon, AFS, GRT, BMT, Chelton, or some other? All inputs will be appreciated. Jim Pleasants RV-7A QB N1QZ(reserved) -- ________________________________________________________________________________
Date: Jun 01, 2006
Subject: Re: choices
Jim Pleasants wrote: > > Listers: > > I'm to the point where I need to make some choices as regards > autopilots. > > The advertisements for TruTrak and Trio each "speak highly of > themselves". I can't get a clue as to which of these would be, for me, the > best choice. > > I respectfully request that anyone who has a reason to recommend either > of these, or any other, please share with me their thoughts -- good, bad, or > indifferent. > > I have the same quandry regarding glass cockpits -- do I choose Dynon, > AFS, GRT, BMT, Chelton, or some other? > > All inputs will be appreciated. > > Jim Pleasants > RV-7A QB N1QZ(reserved) Jim, you are opening a can of worms about as messy as asking "which primer do I use?"!!! It would be most helpful if you would reply with the mission profile of your plane. Whether or not you intend IFR ops, plan to install multiple electrical systems, budget, etc, etc will have a huge bearing on how you want to equip your plane. Also, your choice of EFIS will have a big impact on which autopilot will best suit your needs. You might also do some digging in the archives of this list. These matters have been hashed to death during the past few years and you might find a head start to your research. I have experience with various autopilots and EFII but will withhold my observations until we know more about how you intend to use your plane. Fortunately, the new digital equipment as a general rule works very well so it comes down mostly to what you like more than what will work. Sam Buchanan http://thervjournal.com ________________________________________________________________________________
Date: Jun 01, 2006
On 06/01 1:51, Jim Pleasants wrote: > I'm to the point where I need to make some choices as regards > autopilots. > > The advertisements for TruTrak and Trio each "speak highly of > themselves". I can't get a clue as to which of these would be, for me, the > best choice. > > I respectfully request that anyone who has a reason to recommend either > of these, or any other, please share with me their thoughts -- good, bad, or > indifferent. > > I have the same quandry regarding glass cockpits -- do I choose Dynon, > AFS, GRT, BMT, Chelton, or some other? > > All inputs will be appreciated. I have had zero regrets going with the GRT/TT combination. I have no experience with the other options you mention. I would make the same decision again. -- Walter Tondu http://www.rv7-a.com Flying! ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Date: Jun 01, 2006
I bought 2 bags of 25 lb lead shot that works well. shemp ----- Original Message ----- From: "Jerry Grimmonpre" <jerry(at)mc.net> Sent: Wednesday, May 31, 2006 3:32 PM Subject: Re: RV-List: Bagage compartment balast > > >>>I fly my -4 with a 40lb bag of salt in the baggage >>>compartment (sans passenger of course)...haven't >>>noticed the speed difference, but it does fly >>>better...I'll have to check that out. > > For what it's worth ... > Please be careful and watch the bag of salt for tiny holes. These holes > develop because of the bag being mishandled at the vendor's store. You > may > find corrosion starting from the very fine granules sifting through the > tiny > holes and working their way into aluminum joints. The fine granules are > generated from the same mishandling that causes tiny holes. > Jerry Grimmonpre' > RV8A Electrical > > > ________________________________________________________________________________
Date: Jun 01, 2006
Subject: Re: Hanging my IO-320 - lower mount spacer
Quoting Gerry Filby : > > > Has anyone else had this experience ? > > I hung my engine this weekend - but I think it needs to come > off again. Vans supplies 2 large diameter AN7 washers in the > engine mount bolt kit that are to shim the forward faces of the > lower engine mounts off the engine so that the mount clears a > "step" in the engine casing. The "step" is the mounting flange > for the oil sump. > > All's well on the right lower mount, but on the lower left its > as if the shim isn't thick enough, or more to the point, the > flange on the engine protrudes too much. Consequence is that > mount doesn't sit flush on the engine - its slightly at an > angle with the top part of the mount making contact and the > lower part interfering with the oil sump flange. > > Is this a common problem or am I breaking new ground here :) I > guess the obvious solution is to pull the engine and grind off > the flange on the oil sump mount. I'm more than a little > hesitant about doing surgery on my engine. > > __g__ > ========================================================= > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > ---------------------------------------------------------- > Gerry: I am speaking for my own which was a Dynafocal, engine mount for a Lycoming 0320ED2 Engine...for an rv6a... Now if you have same engine mount, you should not have to file anything down. I would not do that. The LOrd Mounts? should fit perfectly with the correct washers. If I recall they were the same for all four sides...I might be wrong... I mounteds the engine, all by myself, with no human help...Did not wanted to wait... I was able to do it, and it was done correctly..it was a question or patience, and engine was move to match the Eng. mount...It can be done. Any questions, you can call me . Hope I gave you some food for thought.... Bert rv6a Flying\ do not archive > > ________________________________________________________________________________
Subject: 0-320 H2AD For Sale
Date: Jun 01, 2006
This engine is on a flying RV-6A and is flying. The owner has ordered an XP-360 with a Sensenich to do a firewall forward replacement so all the firewall forward parts go with the 0-320. The prop is a Hendrickson wood prop and in perfect condition. All baffles, oil cooler, exhaust, hoses etc. are included with the engine. You can see the engine run and fly and check it out yourself or have your mechanic check it. The new engine will be here in about a week so at that time we will be removing this one from the plane. Asking $12,000 for the package. Jimmy Bennett 830-598-4221 ________________________________________________________________________________
Subject: AffOrdable medicine directly from manufacturer
Date: Jun 02, 2006
GOOd day dear Customer,
Please open your mind for a simple thing
Internet provided products always cheaper than others.
You may agree or not, but this is a fact
Just compare the numbers and get the same goods for a half value
You may agree or not, but this is a fact.
Subject: Front seat, back seat....
Date: Jun 02, 2006
>I assume you have heel cups or have never flown anyone who has flown >with them & then gotten into your back seat. OH, yes. I wouldn't curse anyone with a ride back there with their feet flat on the original floor. I have flown in the back of several -4s and, of course, found the heel cups a must-do. Mine are more heel PANS with lots of room for a whole foot, water bottle, whatever happens to be there at the time. ALSO: -4 builders: trim the FRONT seat "pleats" Down a little so they don't rub on legs and put an extra triangle of aluminum in the area just under the roll-over structure so knees don't get hung up in there. I have spent a good deal of time in the back seat of Suzie Q to make sure it is comfortable so my PIB (that's PRINCESS in back) is comfortable. She loves it back there. >WAY to much room in the front seat of an -8 ?. >You will then absolutely hate any Rocket 'cause it has lots more of the >same. No way I could hate a Rocket. Except my cheeks hurting from smiling so much. I'd figure out something. >Where do you put your arms in turbulence ?? I have an extended "shelf" that my left arm can rest on when on the throttle making for a very steady, sensitive hand there, much needed in formation flying and bouncing around flying. (Photo Share available on request.) I'm just wide enough to have to lean one way or another to be nestled against the sides of the -4 but find it secure rather than snug or tight. >But then again as one ages things can get difficult, like getting in & out of my LT-1 C-4. Age can do that!! >KABONG HRII N561FS aka RV-4 on steroids. BOTH exceptional airplanes!!! Michael RV-4 N232 Suzie Q ________________________________________________________________________________
Date: Jun 02, 2006
Tim, I see you've already got your answer but just thought I'd throw this in. I know the 6's and 7's are different and this may have nothing to do with a 6. On my 7, the screws for the wing root fairing replaced existing rivets rather than fitting between rivets. Drilled out rivets, enlarged hole, drilled for plate nut rivets, ctsk. everything and rivet plate nut. Worked well. Larry Bowles 7A starting canopy work ________________________________________________________________________________
From: "Shirley Harding" <ShirleyH(at)oceanbroadband.net>
Subject: Skytech starter problem
Date: Jun 03, 2006
Listers, I'm running a Superior XP O 360 with a Skytech lightweight starter (supplied as a package by Superior). After only 7 hours, I noticed the ring gear was damaged. Replaced the ring gear, but after two subsequent starts, observed chips on the new gear. I borrowed another Skytech starter and installed that - it meshed a little better than mine but didn't engage smoothly - they appear to be under-engaging. I've installed an old heavyweight Bendix temporarily - that seems to work fine - but has any one else had problems with the Skytech/Superior combination? Shirley Harding Perth, Western Australia RV6 7 hours - grinding teeth! ________________________________________________________________________________
Date: Jun 02, 2006
Subject: Re: Skytech starter problem
Shirley, a friend of mine recently had the same problem with his F1 Rocket (skytec starter). I loaned him the B&C starter off my F1. It meshed better with the ring gear it only went 1/8" or so deep into the ring gear when the bendix was engaged with the Skytec. The skytec starter wouldn't spin the motor over compression very well (stock compression), but the B&C spun it over no problem. When he called Skytec about his starter woes they initially tried to blame it on the battery, the cable, solenoid etc. but the conversation quickly changed direction once he told them he borrowed a B&C to replace the skytec and had no problems. They then offered a trade-in/upgrade+$$ on the new inline high-torque starter. The new starter works much better, and works as well as the B&C, if not maybe a little better. It also meshes with the ring gear fully, which the original skytec starter didn't. Regards, Bob Japundza RV-6 flying F1 under const. On 6/2/06, Shirley Harding wrote: > > ShirleyH(at)oceanbroadband.net> > > Listers, I'm running a Superior XP O 360 with a Skytech lightweight > starter > (supplied as a package by Superior). After only 7 hours, I noticed the > ring > gear was damaged. Replaced the ring gear, but after two subsequent starts, > observed chips on the new gear. I borrowed another Skytech starter and > installed that - it meshed a little better than mine but didn't engage > smoothly - they appear to be under-engaging. I've installed an old > heavyweight Bendix temporarily - that seems to work fine - but has any one > else had problems with the Skytech/Superior combination? > > > Shirley Harding > > Perth, Western Australia > > RV6 7 hours - grinding teeth! > > ________________________________________________________________________________
Date: Jun 03, 2006
Shirley, Is the damage to the back side of the ring gear teeth? If so this is typical of the starter remaining engaged after a start. Most likely cause is the back EMF from the PM motor itself continuing to hold the solenoid in. You will also hear a ringing sound from the ring gear (some irony here!) immediately after the key is released. If this is the case the fix is to electrically isolate the starter solenoid from the motor (a short link on the starter needs to be removed). Run a separate wire back to the key switch for the solenoid. As soon as the start switch is released then the start contactor (relay) and the starter solenoid will release allowing the gear to immediately disengage. There was an article in Rvator at some time. Doug Gray Sydney, Eastern Australia... RV-6 fuse nutplates!!! > > Listers, I'm running a Superior XP O 360 with a Skytech lightweight starter > (supplied as a package by Superior). After only 7 hours, I noticed the ring > gear was damaged. Replaced the ring gear, but after two subsequent starts, > observed chips on the new gear. I borrowed another Skytech starter and > installed that - it meshed a little better than mine but didn't engage > smoothly - they appear to be under-engaging. I've installed an old > heavyweight Bendix temporarily - that seems to work fine - but has any one > else had problems with the Skytech/Superior combination? > > > > Shirley Harding > > Perth, Western Australia > > RV6 7 hours - grinding teeth! > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 02, 2006
Subject: Langley Fly-in June 24
The annual Western Canada Wing fly-in is Saturday, June 24, at Langley Township Regional Airport (CYNJ). (Langley is 20 nm northeast of Bellingham, WA.) Gus Funnell, from Van's Aircraft, will be there, giving a seminar on RV building along with experienced local builders. For more information, including border crossing instructions, see our web page at http://www.vansairforce.org/CYNJ/. Hope to see you all there! --- Tedd McHenry Van's Air Force Western Canada Wing tedd(at)vansairforce.org www.vansairforce.org ________________________________________________________________________________
Date: Jun 03, 2006
Subject: Wing bolt detail for -6
Hi Listers, I am bolting my wings on today for my -6 and find (or not find) the detail for the wing bolts to be somewhat lacking. I am wondering if there is to be a washer on both sides, and what the torque values are. I am looking at Dwg 15 and 46 but no joy. The manual pretty much says "bolt the wings on". Any help appreciated. Thanks Tim -6 N616TB ________________________________________________________________________________
Date: Jun 03, 2006
Cc: Larry Bowles Larry, If you look at the flutes and rivets on the 6 where the fairings will go it would work out best to drill out every other rivet and use that hole for the center of the nutplate. I wish I'd done that and am still mad at Van's wording of "Think and measure carefully before drilling" . I squeezed nutplates in, but am sure glad they'll be covered with the fairing as they sure ain't pretty. Ron Burnett Slowly building RV-6A QB ---- Larry Bowles wrote: ============ Tim, I see you've already got your answer but just thought I'd throw this in. I know the 6's and 7's are different and this may have nothing to do with a 6. On my 7, the screws for the wing root fairing replaced existing rivets rather than fitting between rivets. Drilled out rivets, enlarged hole, drilled for plate nut rivets, ctsk. everything and rivet plate nut. Worked well. Larry Bowles 7A starting canopy work ________________________________________________________________________________
Date: Jun 03, 2006
Subject: princeton capactive fuel probe
I'm looking for a capacitive fuel probe/gauge to use in my old (circa 1999) RV-6A kit (tanks already built). The princeton probes look interesting because they could probably be used in this tank. You can specify a bendable section which I think would make it useable with the standard RV-6A tank configuration. Has any one used these probes successfully? -- Tom Sargent, RV-6A ________________________________________________________________________________
Date: Jun 03, 2006
Subject: List Enclosure Support
Dear Listers, Over the years, I have resisted the urge to enable enclosure support on the Matronics Lists for a number of reasons relating to performance, capacity, capability, and security. However, its now 2006 and most everyone using email these days is on an email client that, at some level, supports the viewing and handling of enclosures. I get a fair amount of email each month from people on the various Lists asking why their posts of this or that picture didn't go through. Back quite a while ago by popular request, I enabled enclosure support for a few Lists such as the RV10-List, Kolb-List, and the Tailwind-List. Contrary to my fears, there really hasn't been any significant issues on these Lists relating to the advent of enclosure support and for the most part, members have policed themselves well with respect to the size of things they have posted. Having enclosures enabled on some Lists and not others has given me a fair amount of headaches with respect to filtering messages and content since the formats are often quite different between a typical MIME encoded message and a generic plain-text message. The spammers are getting more cleaver all the time and are constantly trying to thwart my best efforts at keeping them from posting to the Lists. So, for these reasons, I've have decided to go ahead and enable limited enclosure posting on all of the email Lists at Matronics. This will not only increase the utility of the Lists, but will afford me a better opportunity to filter out the chaff. Here are some of the features and limits of enclosures on the Matronics Lists: 1) Enclosures will only be posted to the Real Time version of the Lists. 2) Enclosures will NOT be included in the Daily Digest version of the Lists. 3) Enclosures WILL BE forwarded on to the BBS Forum Web site. 4) Enclosures will NOT be appended to the Archives. 5) Enclosures will NOT be available in the List Browse feature. 6) Only the following file types and extensions will be allowed: jpg, bmp, gif, txt, xls, pdf, and doc All other enclosures types will be rejected and email returned to sender. The enclosure types listed above are relatively safe from a virus standpoint and don't pose a particularly large security risk. 7) !! All incoming enclosures will be scanned for viruses prior to posting to the List. This is done in real time and will not slow down the process of posting the message !! Here are some rules for posting enclosures. Failure to abide by these rules could result in the removal of a subscriber's email address from the Lists. 1) Pay attention to what you are posting!! Make sure that the files you are enclosing aren't HUGE (greater that 1MB). Remember that there are still people checking they're email via dial up modem. If you post 30MB worth of pictures, you are placing an unnecessary burden on these folks and the rest of us, for that matter. 2) SCALE YOUR PICTURES DOWN!!! I don't want to see huge 3000 x 2000 pictures getting posted that are 3 or 4MB each. This is just unacceptable. Use a program such as Photoshop to scale the picture down to something on the order of 800 x 600 and try to keep the file size to less-than 200KB, preferably much less. Microsoft has a really awesome utility available for free that allows you to Right-Click on a picture in Explorer and automatically scale it down and resave it. This is a great utility - get it, use it! http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx Look for the link "Image Resizer" 3) !! This would seem to go without saying, but I'll say it anyway. Do not post anything that would be considered offensive by your grandmother. And you know what I'm saying; I don't want to see anything even questionable. !! 4) REMEMBER THIS: If you post a 1MB enclosure to a List with 1000 members subscribed, your 1MB enclosure must be resent 1000 times amounting to 1MB X 1000 = 1 Gigabyte of network traffic!! BE CAREFUL and BE COURTEOUS! I hope everyone will enjoy the added functionality of enclosures. Please police yourself and use good judgement when posting messages with enclosures using the guidelines I've outlined above. Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: My last Brake-drag post
Date: Jun 04, 2006
Thanks for all the suggestions, guys. I tried all of them in reverse order of difficulty. Of course the last one worked. FYI where the brake pedals are bolted on at the bottom of the rudder pedals there is room for a bolt, a thin washer and nut to hold each on. 'Someone' had installed a thick washer, thereby making the pedals quite tight to rotate. Spent 3 hours on my belly in 88 degree temp correcting a five minute error. Following test flight succeeded in changing a frown to a grin by inverting the ADI. For those who have never benifited from 'Brain Storming Sessions', remember to keep your suggestions POSITIVE and keep the "DUMB" questions coming...Even I can learn........... ________________________________________________________________________________
Subject: Formation fun in the Fraser Valley
Date: Jun 04, 2006
We've always had the ability to enclose pics on the RV-10 list but please consider the problems associated with the increase in message size when you enclose pics. I reposted the formation pic (very impressive) after using the powertoy suggested by Matt and with one click it reduced the formation pic from 200K to 50K. I think it would be a good idea for us to reduce pic size whenever possible. Albert Gardner 40422 Yuma, AZ http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx -----Original Message----- On Behalf Of Rob Prior (rv7) Subject: RV-List: Formation fun in the Fraser Valley Since we now have this fancy attachment system, it seems a waste not to at least try it. This was taken yesterday while flying between Langley, BC and Chilliwack, BC. -Rob ________________________________________________________________________________
Date: Jun 04, 2006
Date: Jun 04, 2006
Subject: Re: Formation fun in the Fraser Valley
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Subject: RV Fuel Selector Handle
Date: Jun 04, 2006
> > > Got the Cleaveland Aircraft Tool RV Fuel Selector Handle for > Van's fuel valve but looks to me the set screw should come in > from the other direction for my RV-4 set up. Wouldn't the set > screw be on the shaft flat? Anyone got theirs yet? > Regards, > Bruce Bell > RV-4 N23BB Bruce, I recall that the standard handle had a flat in the bore which corresponded with the flat on the shaft. Don't remember where the set screw was. BTW, I'd recommend giving the Van's selector valve the heave-ho. I flew with mine for about 700 hours, never quite sure if it would actually stick or not when changing tanks. It was painful to buy the Andair, but worth every penny. Alex Peterson RV6-A N66AP 758 hours Maple Grove, MN ________________________________________________________________________________
Subject: Re: RV Fuel Selector Handle
Date: Jun 04, 2006
The new handle has the set screw. B. Bell ________________________________________________________________________________
Date: Jun 04, 2006
Date: Jun 04, 2006
Subject: Landoll Balancer
Just picked up a used Landoll Balancer. Has anyone got any installation information available? I have the copy of a sheet that shows pictures of the components and tell what it does, but I'm looking for torque requirements of the bolts and general installation information. This is the silicone fluid balancer with aerobatic plate. Thanks as always....... Pat Long PGLong(at)aol.com N120PL RV4 Bay City, Michigan 3CM Do Not Archive ________________________________________________________________________________
Date: Jun 05, 2006
Fuel lube gets extremely stiff at temperatures like we get in Minnesota in the winter. I could hardly turn my Van's valve at temps around 10F or colder. Perhaps there is another lube which will make the valve not creak and groan, and would work in cold temperatures, but I don't know what it would be. Alex Peterson RV6-A N66AP 758 hours Maple Grove, MN Alex, Suggest you try Dow Corning 3452 flourosilicone valve lube available from AS. Low temp property is -20F http://www.aircraftspruce.com/catalog/appages/dc3452valvelub.php Dale Ensing ________________________________________________________________________________
Date: Jun 05, 2006
Subject: RV-10 Flight Training at Columbia, SC (CUB) in Sept
Mike Seager will be in Columbia, SC (CUB) on Sept 5 & 6. He will be giving flight training in the factory RV-10. The cost is 60 per hour for Mike and the plane rents for 75 per hour for a total of $ 135 per hour. If you are interested in flying with Mike, please email me at Hamilton(at)sc.e du Once I get a feel for who and how many would like to fly with Mike I will set up a schedule to hopefully accommodate everyone's agenda. Thanks, Patty Hamilton ________________________________________________________________________________
Subject: Vans Heat Muff ... alternatives ?
Date: Jun 05, 2006
I'm not impressed with Vans heat muff as supplied in the firewall forward kit - has anyone used an alternative ? How about the "Homebuilders Heat Muff 9" in Spruce's catalog ? __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ---------------------------------------------------------- ________________________________________________________________________________
Subject: Dimpling Boo-boo
Date: Jun 05, 2006
From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
A couple days ago I was dimpling elevator skins with the C-frame. My helper's hand, pulling back the skin, slipped and it popped out of the male die as the mallet was coming down, creating a new dimple/hole about .20" from the existing hole. I pounded it out with a hammer on a steel backrivet plate, but the hole from the dimple die is still there. I would consider this to be not too big a deal (I hope). Perhaps a dab of tank sealant on the underside of the skin would be a good idea to prevent a vibration-crack from forming? There must be SOP for this sort of thing? Paul 9A QB #1176 ________________________________________________________________________________
Date: Jun 05, 2006
Subject: Re: Vans Heat Muff ... alternatives ?
Another one to look at is Larry Vetterman - I got his crossover exhaust with mufflers - the heater boxes are part of the mufflers - you can see the mufflers at Aircraft Exhaust technologies (built for the vetterman kits). Rumour has it that they really pump out the heat - but I haven't flown yet. -----Original Message----- >From: Gerry Filby <gerf(at)gerf.com> >Sent: Jun 5, 2006 12:56 PM >To: rv-list(at)matronics.com >Subject: RV-List: Vans Heat Muff ... alternatives ? > > >I'm not impressed with Vans heat muff as supplied in the >firewall forward kit - has anyone used an alternative ? How >about the "Homebuilders Heat Muff 9" in Spruce's catalog ? > >__g__ > >========================================================== >Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 >---------------------------------------------------------- > > > > > > > ________________________________________________________________________________
Date: Jun 05, 2006
I'm guessing that you had a 912S/914 as you have those parts for sale.... What are you putting in now? More oooomph? Trying to get to the VNE? Curious as someone else mentioned a Jabiru 6.... -----Original Message----- >From: Gerry Filby <gerf(at)gerf.com> >Sent: Jun 5, 2006 12:56 PM >To: rv-list(at)matronics.com >Subject: RV-List: Vans Heat Muff ... alternatives ? > > >I'm not impressed with Vans heat muff as supplied in the >firewall forward kit - has anyone used an alternative ? How >about the "Homebuilders Heat Muff 9" in Spruce's catalog ? > >__g__ > >========================================================== >Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 >---------------------------------------------------------- > > > > > > > ________________________________________________________________________________
Date: Jun 05, 2006
Sorrry - Ogre Fingers......wrong list! -----Original Message----- >From: "Ralph E. Capen" <recapen(at)earthlink.net> >Sent: Jun 5, 2006 1:44 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Vans Heat Muff ... alternatives ? > >I'm guessing that you had a 912S/914 as you have those parts for sale.... > >What are you putting in now? More oooomph? Trying to get to the VNE? > >Curious as someone else mentioned a Jabiru 6.... > > >-----Original Message----- >>From: Gerry Filby <gerf(at)gerf.com> >>Sent: Jun 5, 2006 12:56 PM >>To: rv-list(at)matronics.com >>Subject: RV-List: Vans Heat Muff ... alternatives ? >> >> >> >>I'm not impressed with Vans heat muff as supplied in the >>firewall forward kit - has anyone used an alternative ? How >>about the "Homebuilders Heat Muff 9" in Spruce's catalog ? >> >>__g__ >> >>========================================================== >>Gerry Filby gerf(at)gerf.com >> Tel: 415 203 9177 >>---------------------------------------------------------- >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: Dimpling Boo-boo
Date: Jun 05, 2006
He he ... I'll give you a cent to a dollar it won't be the last :-) I think I've got about 3 of those so far. The general wisdom I've heard is to flatten it out and move on, its more of a cosmetic issue than a structural one ... g > A couple days ago I was dimpling elevator skins with the C-frame. My > helper's hand, pulling back the skin, slipped and it popped out of the > male die as the mallet was coming down, creating a new dimple/hole about > ..20" from the existing hole. I pounded it out with a hammer on a steel > backrivet plate, but the hole from the dimple die is still there. > > > > I would consider this to be not too big a deal (I hope). Perhaps a dab > of tank sealant on the underside of the skin would be a good idea to > prevent a vibration-crack from forming? There must be SOP for this sort > of thing? > > > > Paul > > 9A QB #1176 > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ---------------------------------------------------------- ________________________________________________________________________________
Subject: Oxygen Bottle Pressure Test
Date: Jun 05, 2006
Can anyone point me to the applicable regulation for the "requirement" for a pressure test for oxygen bottles? This has the "smell" of an OSHA requirement and I am trying to determine its applicability (if any) to small portable ones used in private aircraft. Thanks. ________________________________________________________________________________
Date: Jun 05, 2006
I believe it's a DOT reg. http://www.c-f-c.com/gaslink/docs/dot_cylinder.htm Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Fasching Sent: Monday, June 05, 2006 4:00 PM Subject: RV-List: Oxygen Bottle Pressure Test Can anyone point me to the applicable regulation for the "requirement" for a pressure test for oxygen bottles? This has the "smell" of an OSHA requirement and I am trying to determine its applicability (if any) to small portable ones used in private aircraft. Thanks. ________________________________________________________________________________
Date: Jun 05, 2006
Subject: Re: Oxygen Bottle Pressure Test
At 02:00 PM 6/5/2006, you wrote: >Can anyone point me to the applicable regulation for the "requirement" for >a pressure test for oxygen bottles? > >This has the "smell" of an OSHA requirement and I am trying to determine >its applicability (if any) to small portable ones used in private >aircraft. Thanks. http://www.bouldermountainfire.org/training/hydro.html http://tinyurl.com/kbc4v http://tinyurl.com/z82a8 There is a way around this rule. Fill your own cylinder. But I would never skimp on this safety regulation just to save a few bucks every five years. There are places to save and places not to save. This is one where you follow the rules. Ron Lee ________________________________________________________________________________
Date: Jun 05, 2006
3AA bottles are due every 5 years. Most over looked item in an aircraft Stewart ________________________________________________________________________________
Date: Jun 05, 2006
Make your own, simple, cheap, better. Look in RV-list photo archives George McNutt Gerry Filby wrote: > > > I'm not impressed with Vans heat muff as supplied in the > firewall forward kit - has anyone used an alternative ? How > about the "Homebuilders Heat Muff 9" in Spruce's catalog ? > > > ________________________________________________________________________________
Date: Jun 05, 2006
It is a DOT requirement to have the bottles checked at regular inatervals. If I recall the steel bottles are good for 5 years betweeen checks and no life limit. Them light weight ones are I think 3 years and some thing like a 20 Year service life. If you have an out of date bottle you most likely will not find anyone to fill it. tiger 10 ----- Original Message ----- From: John Fasching To: rv-list(at)matronics.com Sent: Monday, June 05, 2006 2:00 PM Subject: RV-List: Oxygen Bottle Pressure Test Can anyone point me to the applicable regulation for the "requirement" for a pressure test for oxygen bottles? This has the "smell" of an OSHA requirement and I am trying to determine its applicability (if any) to small portable ones used in private aircraft. Thanks. ________________________________________________________________________________ Cc: sarg314(at)comcast.net
Date: Jun 05, 2006
Subject: Re: princeton capactive fuel probe
Hi Tom, I bought the capacitive Princeton probes through Grand Rapids to use with my EIS-4000 and the probes came already bent and ready to install in the RV tanks. I have an -8A but as far as I know the same bend profile will work in the -6 series too. Might not hurt to double-check before ordering. As far as using them "successfully" goes, I've had decent results with mine. You go through a calibration setup procedure where you turn power on, push a button on the probe with the tank empty for the empty set point, then fill the tank and push the button again for the full set point. The first time I did this it worked fine on one tank but the other tank was reading 0.0 and the LED on the probe was flashing an error code. Instructions said to try the calibration procedure again before calling Princeton. This is a bit of a pain because you have to empty the tank completely....it worked out ok for me because I was flight testing and figured what the heck, I should run the tank dry in the air anyway just to make sure I can really use all the fuel in flight. After resetting it the probe has worked fine. My only complaint--and it's a minor one--is that with the tanks full, the reading from the senders varies by about a gallon. You can program the EIS to show whatever quantity you want when the sender is at the full level...I measured about 11 gals in my tank when the fuel is at the top of the sender so that's what I programmed into the EIS. But the actual reading after refueling is anywhere from 10.0 to 10.9, and it varies from day to day. I didn't expect capacitive probes to wander in their readings like this. Anyway, the important part is that they do seem to read accurately when near empty. I have an alarm on my EIS set up to warn me when fuel level is reading 1.0 gals in either tank. It will start to flash at me a few minutes before the engine quits. So I'm satisfied with that aspect of it. One other note of interest, I originally installed Vans float sensors in my tanks but decided to change to capacitive in hopes that I'd never have to yank them out and change them (time will tell...). I made the swap before mounting my wings so it was easy. The curious thing is that in order to install the Princeton probes, I had to install both the probe and the tank access plate at the same time, with a series of twists and turns. If you install the probe in the access plate first, or install the plate and then try to put in the probe, it won't work. I just mention this because it may be a lot harder to retrofit a flying airplane than it was with the wings off.... Hope this helps, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D getting ready for 50 hr oil change.. ------------------------------------------------------------ From: sarg314 <sarg314(at)comcast.net> Subject: RV-List: princeton capactive fuel probe I'm looking for a capacitive fuel probe/gauge to use in my old (circa 1999) RV-6A kit (tanks already built). The princeton probes look interesting because they could probably be used in this tank. You can specify a bendable section which I think would make it useable with the standard RV-6A tank configuration. Has any one used these probes successfully? -- Tom Sargent, RV-6A ________________________________________________________________________________
Subject: Purchasing oxygen
Date: Jun 06, 2006
Speaking of oxygen, is there a good place to buy it when your traveling other than airports to save a buck or two or is in not worth it. Shemp/Jeff Dowling RV-6A, N915JD 265 hours Chicago/Louisville ----- Original Message ----- From: John Fasching To: rv-list(at)matronics.com Sent: Monday, June 05, 2006 3:00 PM Subject: RV-List: Oxygen Bottle Pressure Test Can anyone point me to the applicable regulation for the "requirement" for a pressure test for oxygen bottles? This has the "smell" of an OSHA requirement and I am trying to determine its applicability (if any) to small portable ones used in private aircraft. Thanks. ________________________________________________________________________________
Subject: Re: Purchasing oxygen
Date: Jun 06, 2006
I get my O2 filled locally at a surgical supply store. Saves me about $20 on each fill. If I was on the road and had a car and access to Yahoo yellow pages, I might try searching for "medical oxygen" or "surgical supply". )_( Dan RV-7 N714D (928 hours) http://www.rvproject.com ----- Original Message ----- From: Jeff Dowling To: rv-list(at)matronics.com Sent: Tuesday, June 06, 2006 7:33 AM Subject: RV-List: Purchasing oxygen Speaking of oxygen, is there a good place to buy it when your traveling other than airports to save a buck or two or is in not worth it. Shemp/Jeff Dowling RV-6A, N915JD 265 hours Chicago/Louisville ----- Original Message ----- From: John Fasching To: rv-list(at)matronics.com Sent: Monday, June 05, 2006 3:00 PM Subject: RV-List: Oxygen Bottle Pressure Test Can anyone point me to the applicable regulation for the "requirement" for a pressure test for oxygen bottles? This has the "smell" of an OSHA requirement and I am trying to determine its applicability (if any) to small portable ones used in private aircraft. Thanks. ________________________________________________________________________________
Subject: Engine OH
Date: Jun 06, 2006
Well Im still mulling over the choices. I was ready to take my engine down to Ft Smith for a $10k Oh prioviding crank ok. I was set up to go donw and wathc a 360 put back today or wed, but no one returned 2 calls yesterday so now having 2nd thoughts. I am looking at upgrade to 160 hp even tho I will loose Mogas ability. I took Tweetybird into a grass strip Sat and when coming out I was looking at a very high hill covered with trees a lot closser than I had intended. (Im 150 hp). Wamnted to get some thoughts on upgrading. Charlie Heathco ________________________________________________________________________________
Date: Jun 06, 2006
Subject: Re: Engine OH
Cc: Charles Heathco ---- Charles Heathco wrote: > snipped I am looking at upgrade to 160 hp even tho I will loose Mogas ability.snipped Charlie Heathco Charlie Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel. It simply means that you will have to use 91 -93 octane super, rather than 87 octane regular. Charlie Kuss ________________________________________________________________________________
Date: Jun 06, 2006
True. I've been paying the 20 cent premium per gallon ever since I upgraded, and often find myself wishing I could undo it easily. Peformance gain was vanishingly small, cost increase over 87 octane very real. If I were you, I'd stand pat at 150 hp and enjoy the economy. Next logical step up: 180 hp O-360... and still on mogas ;-) Saving 20 cents a gallon over time will buy a constant speed, perhaps? -Stormy -----Original Message---- From: chaztuna(at)adelphia.net Cc: Charles Heathco Subject: Re: RV-List: Engine OH ---- Charles Heathco wrote: > snipped I am looking at upgrade to 160 hp even tho I will loose Mogas ability.snipped Charlie Heathco Charlie Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel. It simply means that you will have to use 91 -93 octane super, rather than 87 octane regular. Charlie Kuss ________________________________________________________________________ on demand. Always Free. ________________________________________________________________________________
Date: Jun 06, 2006
Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel. It simply means that you will have to use 91 -93 octane super, rather than 87 octane regular. Charlie Kuss What about the ethanol content in the mogas? Isn't there some long term potential problems with seals etc.? DWE do not archieve ________________________________________________________________________________
Date: Jun 06, 2006
Yes, I believe there is... Be careful what state you reside in ;-) Some mandate ethanol, some don't. -Stormy -----Original Message----- From: Dale Ensing <densing(at)carolina.rr.com> Subject: Re: RV-List: Engine OH Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel. It simply means that you will have to use 91 -93 octane super, rather than 87 octane regular. Charlie Kuss What about the ethanol content in the mogas? Isn't there some long term potential problems with seals etc.? DWE do not archieve ________________________________________________________________________ on demand. Always Free. ________________________________________________________________________________
Date: Jun 06, 2006
I have a skyox system. Will I need any special fittings to fill it at a surgical supply store? I dont have my manual with me. Shemp/Jeff Dowling RV-6A, N915JD 265 hours Chicago/Louisville ----- Original Message ----- From: Dan Checkoway To: rv-list(at)matronics.com Sent: Tuesday, June 06, 2006 10:21 AM Subject: Re: RV-List: Purchasing oxygen I get my O2 filled locally at a surgical supply store. Saves me about $20 on each fill. If I was on the road and had a car and access to Yahoo yellow pages, I might try searching for "medical oxygen" or "surgical supply". )_( Dan RV-7 N714D (928 hours) http://www.rvproject.com ----- Original Message ----- From: Jeff Dowling To: rv-list(at)matronics.com Sent: Tuesday, June 06, 2006 7:33 AM Subject: RV-List: Purchasing oxygen Speaking of oxygen, is there a good place to buy it when your traveling other than airports to save a buck or two or is in not worth it. Shemp/Jeff Dowling RV-6A, N915JD 265 hours Chicago/Louisville ----- Original Message ----- From: John Fasching To: rv-list(at)matronics.com Sent: Monday, June 05, 2006 3:00 PM Subject: RV-List: Oxygen Bottle Pressure Test Can anyone point me to the applicable regulation for the "requirement" for a pressure test for oxygen bottles? This has the "smell" of an OSHA requirement and I am trying to determine its applicability (if any) to small portable ones used in private aircraft. Thanks. ________________________________________________________________________________
Subject: Super unleaded in 160hp O-320
Date: Jun 06, 2006
Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel. It simply means that you will have to use 91 -93 octane super, rather than 87 octane regular. Is this true? This is the first I have heard of it.... if so, I sure could save some $$$$$ if so Scott RV6-A !60hp O-320 ________________________________________________________________________________
Subject: Re: Super unleaded in 160hp O-320
Date: Jun 06, 2006
>> Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel. >> It simply means that you will have to use 91 -93 octane super, rather >> than 87 octane regular.<< > Is this true? This is the first I have heard of it.... if so, I sure could > save some $$$$$ if so > According to some old documentation I got from Petersen Aviation, owner of one of the auto gas STCs, the 150hp/160hp O320 and the 180hp O360 engines were approved by the FAA for auto gas. Oh, yeah. Let's not forget the normally aspirated O540s, either. I think those are the 235 hp versions for you -10 builders? H2ADs and fuel injected O360s were not approved. I think it applies to any fuel injected engine, actually. Of course, he noted that fuel line sizes, routing, and other variables, could impact the use of auto gas due to vapor lock. He also mentioned that some materials in our tanks may not hold up to the rigors of auto gas. The engines were OK, though. To run the higher compression engines on auto gas, just bump up to 91-93 antiknock gas. I invested in my first auto gas STC in 1986 and have saved money on gas for my airplanes, since. My RV-6A has a 150hp O320 that runs well on 87 antiknock. The tanks and fuel system have shown no adverse effects of having auto fuel in them, other than the minor vapor locking that can happen during fast turnarounds. The plugs are clean, except for some carbon build up. Oil, not fuel. No lead to foul plugs. Per Petersen's STC, I do put in some 100LL a couple of times a year. I can always tell the difference. Within an hour, or so, the lead deposits start building up and fouling plugs. Vapor locking is a minor problem, as was the case in my other two airplanes. If in doubt, I add some 100LL to the mix to change the vapor pressure so that the fuel is less apt to vapor lock. About the only time I chose to do this is if I'm going to take up a lot of kids during a Young Eagles day. If it's cold outside, I don't bother. If I ever get around to finishing my -7A, it will have an O320 160hp engine or an O360 180hp engine. Since I already have some pieces and parts for the O320, that will probably be my choice. I plan on using premium unleaded in it. I can't afford to own an airplane and keep it filled with 100LL. I'm just getting used to putting premium in my new Miata! (It does get good gas milage, though. :-) ) Jim Sears in KY RV-6A N198JS (Scooter) RV-7A #70317 (Started on fuse) EAA Tech Counselor ________________________________________________________________________________
Date: Jun 06, 2006
My understanding is that the engine will work on the mogas but the STC doesn't cover it. So, it would seem the decision is if you want to keep your engine certificated. ----- Original Message ----- From: "james frierson" <tn3639(at)hotmail.com> Sent: Tuesday, June 06, 2006 5:50 PM Subject: RV-List: Super unleaded in 160hp O-320 > > Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel. It > simply means that you will have to use 91 -93 octane super, rather than 87 > octane regular. > > Is this true? This is the first I have heard of it.... if so, I sure could > save some $$$$$ if so > > Scott > RV6-A > !60hp O-320 > > ________________________________________________________________________________
Date: Jun 06, 2006
Once an engine is installed on an experimental aircraft, it looses its certified status and cannot thereafter be reinstalled on a certified airframe without a complete disassembly/OH to determine it's status. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of George P. Tyler Sent: Tuesday, June 06, 2006 8:22 PM Subject: Re: RV-List: Super unleaded in 160hp O-320 My understanding is that the engine will work on the mogas but the STC doesn't cover it. So, it would seem the decision is if you want to keep your engine certificated. ----- Original Message ----- From: "james frierson" <tn3639(at)hotmail.com> Sent: Tuesday, June 06, 2006 5:50 PM Subject: RV-List: Super unleaded in 160hp O-320 > > Converting to 160 hp (8.5 to 1) does not preclude your use of Auto fuel. It > simply means that you will have to use 91 -93 octane super, rather than 87 > octane regular. > > Is this true? This is the first I have heard of it.... if so, I sure could > save some $$$$$ if so > > Scott > RV6-A > !60hp O-320 > > ________________________________________________________________________________
Subject: Charlotte NC routing to Chicago area
Date: Jun 06, 2006
Hi RV- Listers .. I just purchased Ron Awad's RV-4 and will soon fly it from the East side of Charlotte NC to just West of Chicago O'hare area. I'm wanting to know which direction most of you would fly heading out of Charlotte. Would you go South of Charlotte and make an end run around the mountains or would you go over the pass at Ashville and head straight out for a direct course to Chicago area? The airplane is VFR only so it's a given that the ground has to be visible. I'll make two stops for fuel not more than 300 miles at a time. Any suggested places to stop or avoid. The first stop will be an over night so it'd be nice to have it close to a hotel (town area). Crosswind landings ... what should a newbie pilot (in the 4) avoid in the way of wind velocity for cross? Any other suggestions that would help? Many thanks ... Jerry Grimmonpre' ________________________________________________________________________________
Subject: Re: Charlotte NC routing to Chicago area
Date: Jun 06, 2006
You're in an RV now. I just ran my flight planner for my 6a and found it would be a 3:20 flight, easily reachable without a stop in an rv. I would go direct at 8500 ft. Plenty of fuel stops along the way if you want to play it safe. If you havent used airnav, http://www.airnav.com/, you'll find it to be very helpful for fuel/flight planning. If you're not used to an rv, you will be pleasantly surprised. Shemp/Jeff Dowling RV-6A, N915JD 265 hours Chicago/Louisville ----- Original Message ----- From: "Jerry Grimmonpre" <jerry(at)mc.net> Sent: Tuesday, June 06, 2006 7:49 PM Subject: RV-List: Charlotte NC routing to Chicago area > > Hi RV- Listers .. > I just purchased Ron Awad's RV-4 and will soon fly it from the East side > of > Charlotte NC to just West of Chicago O'hare area. I'm wanting to know > which > direction most of you would fly heading out of Charlotte. Would you go > South of Charlotte and make an end run around the mountains or would you > go > over the pass at Ashville and head straight out for a direct course to > Chicago area? The airplane is VFR only so it's a given that the ground > has > to be visible. > > I'll make two stops for fuel not more than 300 miles at a time. Any > suggested places to stop or avoid. The first stop will be an over night > so > it'd be nice to have it close to a hotel (town area). > > Crosswind landings ... what should a newbie pilot (in the 4) avoid in the > way of wind velocity for cross? Any other suggestions that would > help? > Many thanks ... > Jerry Grimmonpre' > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jun 06, 2006
From: "Jeff Linebaugh" <jefflinebaugh(at)earthlink.net>
Subject: Stuff for Sale
Guys and Gals, I have a bunch of stuff for sale, flight instruments, engine instruments , and a radio stack... Don't want to spam the list, but this may be just w hat somebody is needing.... New Radio Stack For Sale Bendix King KY97 VHF Com Radios (2) Bendix King KT-76A Transponder with Encoder Bendix King 134 Audio Panel Radio Package Prewired PS Engineering PS 1000II Intercom List Price $5500 Asking $4500/OBO Flight Instruments Sigma Tek Artificial Horizon (vac) w/ 8 degree tilt for you TD guys $750 United DG (vac) $680 United Airspeed Indicator 3 1/8" $380.00 United Electric Turn Coordinator 3 1/8" $400.00 United Sensatrue Altimeter 3 1/8" $480 Sensatrue VSI 3 1/8" $275 Airpath Liquid Compass (Panel Mount 2 1/4") $90 Engine Instruments Electonics International UGB-16 with probes $1200 Electonics International Fuel Flow Gauge $400 UMA Tach 2 1/4" $100 UMA MP 2 1/4" $85 UMA Metered Fuel Pressure $100.00 UMA Unmetered Fuel Pressure $200.00 Westech Dual Oil Temp/PSI $225 Westech Dual Volts/Amps $90 Thanks, Jeff jefflinebaugh(at)earthlink.net 901 606-6735 ________________________________________________________________________________
Date: Jun 06, 2006
Bruce Gray wrote: > > Once an engine is installed on an experimental aircraft, it looses its > certified status and cannot thereafter be reinstalled on a certified > airframe without a complete disassembly/OH to determine it's status. As I understand the situation (and I am certainly willing to be corrected!) the mere act of bolting a certificated engine to an experimental airframe does not cause the engine to lose its certificated status. However, if the engine was to be returned to service on a certificated airframe, the installation would have to be signed off by an AI. And.....how many AI's are going to put their career on the line by signing off on an engine that they are not *absolutely certain* meets all certification requirements. The AI covering his backside is why the engine will most likely be torn down to insure compliance, not just the fact that it was bolted to an experimental airframe. If you can find an AI that is willing to sign off the engine installation without a teardown, it will be legal. This *might* actually happen if the AI owned or had detailed knowledge of the experimental aircraft the engine was on. Sam Buchanan ________________________________________________________________________________
Date: Jun 06, 2006
Hi Jerry, I have done it both ways from Charlotte to Chicago. Just depends on the day/weather. Last year, on trip to Oshkosh, the flight over the mountains was good but had to divert west at the Ohio River to get around the weather. Return flight was direct from 3CK to Charlotte with one stop for the bladder and some fuel.. It usually gets a bit bumpy over the mountains so altitude helps. Do you know when you will be coming down to get the RV-4. If we are home you are welcome to overnight with us if you need a place. How is the construction of the RV-8 coming along? My memory says you were doing the wiring so can't be too long to finish. Dale Ensing ________________________________________________________________________________
Date: Jun 06, 2006
I agree with Jeff's remarks. You can easily go direct over the mtns, respecting wx and winds of course. During my OSH run last year from N of CLT, I used Putnam county for a pit stop. It has good facilities and decent fuel prices: http://www.airnav.com/airport/4I7 - Larry Bowen, RV-8 @ 8A7 Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Jeff Dowling [mailto:shempdowling2(at)earthlink.net] > Sent: Tuesday, June 06, 2006 10:08 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Charlotte NC routing to Chicago area > > --> > > You're in an RV now. I just ran my flight planner for my 6a > and found it would be a 3:20 flight, easily reachable without > a stop in an rv. I would go direct at 8500 ft. Plenty of > fuel stops along the way if you want to play it safe. If you > havent used airnav, http://www.airnav.com/, you'll find it > to be very helpful for fuel/flight planning. If you're not > used to an rv, you will be pleasantly surprised. > > Shemp/Jeff Dowling > RV-6A, N915JD > 265 hours > Chicago/Louisville > > > > > ----- Original Message ----- > From: "Jerry Grimmonpre" <jerry(at)mc.net> > To: > Sent: Tuesday, June 06, 2006 7:49 PM > Subject: RV-List: Charlotte NC routing to Chicago area > > > > > > Hi RV- Listers .. > > I just purchased Ron Awad's RV-4 and will soon fly it from > the East side > > of > > Charlotte NC to just West of Chicago O'hare area. I'm > wanting to know > > which > > direction most of you would fly heading out of Charlotte. > Would you go > > South of Charlotte and make an end run around the mountains > or would you > > go > > over the pass at Ashville and head straight out for a > direct course to > > Chicago area? The airplane is VFR only so it's a given > that the ground > > has > > to be visible. > > > > I'll make two stops for fuel not more than 300 miles at a time. Any > > suggested places to stop or avoid. The first stop will be > an over night > > so > > it'd be nice to have it close to a hotel (town area). > > > > Crosswind landings ... what should a newbie pilot (in the > 4) avoid in the > > way of wind velocity for cross? Any other suggestions that would > > help? > > Many thanks ... > > Jerry Grimmonpre' > > > > > > > > > > > > http://www.matronics.com/Navigator?RV-List > > http://wiki.matronics.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 06, 2006
That's my understanding of the situation also. The engine would have to be examined to be sure all parts were in compliance and all AD's were up to snuff. In essence an overhaul. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan Sent: Tuesday, June 06, 2006 10:28 PM Subject: Re: RV-List: Super unleaded in 160hp O-320 Bruce Gray wrote: > > Once an engine is installed on an experimental aircraft, it looses its > certified status and cannot thereafter be reinstalled on a certified > airframe without a complete disassembly/OH to determine it's status. As I understand the situation (and I am certainly willing to be corrected!) the mere act of bolting a certificated engine to an experimental airframe does not cause the engine to lose its certificated status. However, if the engine was to be returned to service on a certificated airframe, the installation would have to be signed off by an AI. And.....how many AI's are going to put their career on the line by signing off on an engine that they are not *absolutely certain* meets all certification requirements. The AI covering his backside is why the engine will most likely be torn down to insure compliance, not just the fact that it was bolted to an experimental airframe. If you can find an AI that is willing to sign off the engine installation without a teardown, it will be legal. This *might* actually happen if the AI owned or had detailed knowledge of the experimental aircraft the engine was on. Sam Buchanan ________________________________________________________________________________
Date: Jun 06, 2006
Bruce Gray wrote: > > That's my understanding of the situation also. The engine would have to be > examined to be sure all parts were in compliance and all AD's were up to > snuff. In essence an overhaul. Only if the AI insisted on the inspection/overhaul, but not because the FARs require it. If the AI has extensive knowledge of the engine and its compliance with AD's, he *might* forgo the inspection. The A&P/AI that helped me with the yellow-tagged and updated logbook overhaul of the O-320 in my RV-6 might have returned that engine to certificated service without further inspection since he was familiar with the overhaul and all major service following the overhaul. But a different AI who didn't know the engine most likely would have required an internal look at the engine and logs before he signed off the new installation. Sam Buchanan ________________________________________________________________________________
Date: Jun 07, 2006
Sam, I believe the FAR's exempt our engines from AD's even if we don't remove the data plate. I recall emails from our friendly FAA guy that stated that the FAA considered all appliances when attached to an experimental airframe to be experimental. If your engine logs state that your engine was installed on an RV, Glasair, or any other experimental airframe followed by your signature, I don't know of any AP/IA that would sign if off for a reinstall on a certified aircraft. The local FSDO would be sure to frown on it. It's a real grey area. This might be a good question to kick up to the EAA experts. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan Sent: Tuesday, June 06, 2006 11:44 PM Subject: Re: RV-List: Super unleaded in 160hp O-320 Bruce Gray wrote: > > That's my understanding of the situation also. The engine would have to be > examined to be sure all parts were in compliance and all AD's were up to > snuff. In essence an overhaul. Only if the AI insisted on the inspection/overhaul, but not because the FARs require it. If the AI has extensive knowledge of the engine and its compliance with AD's, he *might* forgo the inspection. The A&P/AI that helped me with the yellow-tagged and updated logbook overhaul of the O-320 in my RV-6 might have returned that engine to certificated service without further inspection since he was familiar with the overhaul and all major service following the overhaul. But a different AI who didn't know the engine most likely would have required an internal look at the engine and logs before he signed off the new installation. Sam Buchanan ________________________________________________________________________________
Subject: Purchasing O2
Date: Jun 06, 2006
Guys: This is not hard. O2 be O2 and usually in a small to medium size town there is usually only one shop in town that has the LOX facility, larger cities may have more depending upon demand. Everyone gets their gaseous from them, yes the medicos, the welders and the airport! Ever notice the little trailers with 5 green O2 bottles strapped to it? The, the bottles look surprisingly identical to the local welders' bottles don't they? And before anyone starts with the moisture wives tale, all O2 containers are required to be absolutely dry or be purged to insure dryness. Moisture, medical O2, is added to the supply line downstream from the O2 containers. The five year requirement for testing is done, guess where, the local welding shop who sends them to a regional hydro testing facility. I have been using "welder's O2 for 13 years in my bottle and the welding shop has hydro tested it twice, price about $13 per refill and the same for the testing. If you are in the McKinney TX airport area there is a welding shop just of the airport entrance who will do it for free. However, for those who truly believe that aviation O2 is different, oh well, someone has to pay those high prices, it may as well be you. Dan. 90% done and 90% to go on my -9A QB. Test fitted and clecoed the instrument panel today. ________________________________________________________________________________
Date: Jun 07, 2006
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Instrument Panel Cutting
Just a quick thanks to all of you folks you responded to my quest for the optimum methods for cutting holes in the instrument panel (that are not of the round variety). After experimenting with several different things, I found that a (baby size) router used for laminate trimming worked the best for me. I made a wooden jig for the two rectangular holes needed for the EFIS and AOA mounting and the results turned out very nice, almost as good a as a CNC milling machine. Round instrument holes were cut with the common fly cutter and came out nice as well, I just had to adjust the damn thing for each my 2.5 inch instruments as they didn't seem to be a common size! I solved my problem of the funny VM1000 engine monitor display cutout by sending my blank to Mr Steve Davis of Memphis Tennessee (phone number 901-240-3068). Steve has autocad AND machining facilities and has done some very nice work on RV panels. He did a very nice job on my cutout and the price was VERY reasonable, it saved me a lot of work and disappointment. I highly recommend letting Steve do your panel if you have the resources. I've spent the better part of the last month (spare time) doing the flight instrument side of the panel and it was a lot more work than I expected (I have lots of stuff in there though). I enjoyed doing it but could be further along towards clearing the prop if I'd let someone else do that part of it. Oh well, I'll be able to say I built EVERYTHING on the airplane except the metal stampings. Oh the joys and frustrations of building your own aircraft!! Dean Psiropoulos RV-6A N197DM Not long to- Clear-the-prop ________________________________________________________________________________
Subject: Re: Instrument Panel Cutting
Date: Jun 07, 2006
Thanks Dean!!! Steve ----- Original Message ----- From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> Sent: Wednesday, June 07, 2006 12:54 AM Subject: RV-List: Instrument Panel Cutting > > > Just a quick thanks to all of you folks you responded to my quest for the > optimum methods for cutting holes in the instrument panel (that are not of > the round variety). After experimenting with several different things, I > found that a (baby size) router used for laminate trimming worked the best > for me. I made a wooden jig for the two rectangular holes needed for the > EFIS and AOA mounting and the results turned out very nice, almost as good > a > as a CNC milling machine. Round instrument holes were cut with the common > fly cutter and came out nice as well, I just had to adjust the damn thing > for each my 2.5 inch instruments as they didn't seem to be a common size! > > I solved my problem of the funny VM1000 engine monitor display cutout by > sending my blank to Mr Steve Davis of Memphis Tennessee (phone number > 901-240-3068). Steve has autocad AND machining facilities and has done > some > very nice work on RV panels. He did a very nice job on my cutout and the > price was VERY reasonable, it saved me a lot of work and disappointment. I > highly recommend letting Steve do your panel if you have the resources. > I've spent the better part of the last month (spare time) doing the flight > instrument side of the panel and it was a lot more work than I expected (I > have lots of stuff in there though). I enjoyed doing it but could be > further along towards clearing the prop if I'd let someone else do that > part > of it. Oh well, I'll be able to say I built EVERYTHING on the airplane > except the metal stampings. Oh the joys and frustrations of building your > own aircraft!! > > Dean Psiropoulos > RV-6A N197DM > Not long to- Clear-the-prop > > > -- > > ________________________________________________________________________________
Date: Jun 07, 2006
> My understanding is that the engine will work on the mogas but the > STC > doesn't cover it. So, it would seem the decision is if you want > to keep > your engine certificated. One has to look at the STCs. The EAA STC may not cover high compression engines; but, the Petersen seems to cover them. Do keep in mind that STCs, ADs, etc. do not apply to experimentals; but, one is foolish to not comply, in many cases. If the testing was done for the Petersen STC for high compression approval, I'd think it would be OK to use 91-93 antiknock fuels in them. If not, I wouldn't. Fortunately, his STC does seem to cover them; so, I'm going to use autogas in my next RV, as well. :-) As for the certification, Pat Patterson learned in AB-DAR school that a certifiied engine is indeed decertified when it is attached to an experimental. It is true, even if one does not remove the data plate, which I refuse to do. Just as Sam said, all one has to do is have an IA approve the engine's use on a certified airplane for it to be put back to use as such. I'm sure mine could be put back to service with a couple of changes like removing the starter and alternator. I kept mine in certified condition, I thought, by having an A&P sign off the engine at inspection time. I quit that when Pat told me what he'd learned. I still have Pat, the A&P, help me with the inspection; but, I do the sign off, now. Actually, I don't know why we worry so much about keeping our engines certified, anyway. How often do you think an engine from an experimental is going to be put back into a certified airplane? Most likely, it will be snapped up by another experimental builder before the certified status comes into play. Jim Sears in KY RV-6A N198JS (Scooter) RV-7A #70317 EAA Tech Counselor ________________________________________________________________________________
Date: Jun 07, 2006
In a message dated 6/7/06 12:58:42 AM Central Daylight Time, dean.psiropoulos(at)verizon.net writes: > He did a very nice job on my cutout and the > price was VERY reasonable, it saved me a lot of work and disappointment. I > highly recommend letting Steve do your panel if you have the resources. >>> I'll second Deans nomination! Mark Phillips ________________________________________________________________________________
Date: Jun 07, 2006
Is there any reason that a small medical oxygen cylinder and canulas not be used in an aircraft. My father, who passed away, had medical oxygen equipment that I now have. I can not see any reason I couldn't use this in my plane. Am I wrong? John L. Danielson ________________________________________________________________________________
Date: Jun 07, 2006
Steve did my new panel on my RV-4 as well...check out www.mykitlog.com/pbesing Nice work, Steve. Paul Besing > ----- Original Message ----- > From: "DEAN PSIROPOULOS" > > To: > Sent: Wednesday, June 07, 2006 12:54 AM > Subject: RV-List: Instrument Panel Cutting > > > > > > > > Just a quick thanks to all of you folks you > responded to my quest for the > > optimum methods for cutting holes in the > instrument panel (that are not of > > the round variety). After experimenting with > several different things, I > > found that a (baby size) router used for laminate > trimming worked the best > > for me. I made a wooden jig for the two > rectangular holes needed for the > > EFIS and AOA mounting and the results turned out > very nice, almost as good > > a > > as a CNC milling machine. Round instrument holes > were cut with the common > > fly cutter and came out nice as well, I just had > to adjust the damn thing > > for each my 2.5 inch instruments as they didn't > seem to be a common size! > > > > I solved my problem of the funny VM1000 engine > monitor display cutout by > > sending my blank to Mr Steve Davis of Memphis > Tennessee (phone number > > 901-240-3068). Steve has autocad AND machining > facilities and has done > > some > > very nice work on RV panels. He did a very nice > job on my cutout and the > > price was VERY reasonable, it saved me a lot of > work and disappointment. I > > highly recommend letting Steve do your panel if > you have the resources. > > I've spent the better part of the last month > (spare time) doing the flight > > instrument side of the panel and it was a lot more > work than I expected (I > > have lots of stuff in there though). I enjoyed > doing it but could be > > further along towards clearing the prop if I'd let > someone else do that > > part > > of it. Oh well, I'll be able to say I built > EVERYTHING on the airplane > > except the metal stampings. Oh the joys and > frustrations of building your > > own aircraft!! > > > > Dean Psiropoulos > > RV-6A N197DM > > Not long to- Clear-the-prop > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Date: Jun 07, 2006
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Will work great in your plane! But he probably has regular cannulas. Practically speaking, you would want the ones with the little flapper in them like the one on this page. http://www.airportshoppe.com/aviation_oxygen/compared.html or this one http://aerox.com/Pages/masks.html Really saves the oxygen. I could pull a tank dry in 3 hours on a std cannula at 18k'. I can go twice that with the flapper valve one. Mike _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Danielson Sent: Wednesday, June 07, 2006 11:27 AM Subject: RE: RV-List: Purchasing oxygen Is there any reason that a small medical oxygen cylinder and canulas not be used in an aircraft. My father, who passed away, had medical oxygen equipment that I now have. I can not see any reason I couldn't use this in my plane. Am I wrong? John L. Danielson ________________________________________________________________________________
Date: Jun 07, 2006
Subject: Looking for RVator article on Johanssen tiptanks
Does anyone out there have a copy of this article that they would be willing to scan in for me? IIRC it came out in '03. I have a set - just want to complete my documentation. Thanks, Ralph ________________________________________________________________________________
Date: Jun 07, 2006
Jerry, I'd like to suggest you stop in at RNC McMinnville, Tn. Their price for avgas is $3.53 per gal. tax included. Not far from your originally planned stop. Or. email me offlist for a delivery quote . RV's handle crosswinds better than any other taildragger I've flown. (2500+ TW) Anyone else traveling through Tennessee might check your flightplan to save a few bucks. Tell'em Mike Kellems from Lewisburg sent you for the local price. Mike K. RV3 29AT ----- Original Message ----- From: "Jerry Grimmonpre" <jerry(at)mc.net> Sent: Tuesday, June 06, 2006 7:49 PM Subject: RV-List: Charlotte NC routing to Chicago area > > Hi RV- Listers .. > I just purchased Ron Awad's RV-4 > I'll make two stops for fuel not more > than 300 miles at a time. Any > suggested places to stop or avoid. The first stop will be an over night > so > it'd be nice to have it close to a hotel (town area). > > Crosswind landings ... what should a newbie pilot (in the 4) avoid in the > way of wind velocity for cross? Any other suggestions that would > help? > Many thanks ... > Jerry Grimmonpre' > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > -- > > -- ________________________________________________________________________________
Subject: Leaking brakes
Date: Jun 07, 2006
Anyone got any good ideas on how to stop leaking brake cylinders? All four are leaking a tiny bit at the lower fitting. I first installed them without any pipe dope. then I drained the brake lines, cleaned the fittings and reinstalled with prematex sealant and they still leak a tiny bit. Ideas please! ________________________________________________________________________________
Subject: Re: Leaking brakes
Date: Jun 07, 2006
If you're talking about the brake line, are the double flared? If they aren't, double flair them. If they are, they make soft copper washers that are meant to take care of the same kind of problem in air conditioner systems. Auto parts stores have them. If you're sure its the fittings, good but it might not hurt to look at the calipers and make sure the pistons are not inverted, exposing the "O" rings. Some came from the manufacturer that way. Good Luck John D. ----- Original Message ----- From: dwhite17(at)columbus.rr.com To: rv-list(at)matronics.com Sent: Wednesday, June 07, 2006 9:05 PM Subject: RV-List: Leaking brakes Anyone got any good ideas on how to stop leaking brake cylinders? All four are leaking a tiny bit at the lower fitting. I first installed them without any pipe dope. then I drained the brake lines, cleaned the fittings and reinstalled with prematex sealant and they still leak a tiny bit. Ideas please! ________________________________________________________________________________
Subject: RV7
Date: Jun 08, 2006
I have an RV7 QB kit on the way. I now have to decide on engine. I'm leaning towards TMX IO-360 with Roller tappets and Cold Air forward facing intake. I would appreciate any thoughts on carb-vs-injection, roller tappets, etc. TMX-vs-Superior-vs-Lycomming-vs-??? Have any of you exchanged the Vans cowl, wing tips, wheel pants for the Same James? If so what results did you get. Any input would be appreciated. John Furey ________________________________________________________________________________
Date: Jun 08, 2006
Subject: Re: RV7
John, I have been working with Will James getting the newer "short cowl" (same dimensions as Van's cowl but with the circular inlets) working on a "carbureted O-360". I wnated a different look (customization you know) and hoped there might be a little performance thrown in as a bonus. I think I have the basics sorted out (there are a few little nuances to work out with the transition from the circular inlet to the Van's airbox) so contact me off-list if you decide to go that route. I do not have any performance data as the plane is nowhere near flying (yet) but what I am hoping for is enough to offset the drag from the **nosegear** and **steps** that this plane will have. :-) BTW, Will and Liz have been very nice to work with on this effort. If I were not dragging my feet so much (fingers in too many pies) this plane would have flown a few YEARS ago!! James On 6/8/06, John Furey wrote: > > I have an RV7 QB kit on the way. I now have to decide on engine. I'm > leaning towards TMX IO-360 with Roller tappets and Cold Air forward facing > intake. I would appreciate any thoughts on carb-vs-injection, roller > tappets, etc. TMX-vs-Superior-vs-Lycomming-vs-??? Have any of you exchanged > the Vans cowl, wing tips, wheel pants for the Same James? If so what results > did you get. Any input would be appreciated. > > John Furey > -- This is an alternate email. Please continue to email me at james(at)nextupventures.com . ________________________________________________________________________________
Date: Jun 08, 2006
I would be happy to do it for you, just let me know the year and issue # and I will forward it to you in a PDF. Dan 40269 RV10 (N289DT) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Wednesday, June 07, 2006 3:42 PM Subject: RV-List: Looking for RVator article on Johanssen tiptanks Does anyone out there have a copy of this article that they would be willing to scan in for me? IIRC it came out in '03. I have a set - just want to complete my documentation. Thanks, Ralph ________________________________________________________________________________
Subject: Super unleaded in 160hp O-320 Auto Fuel STC's ( fine point missed
Date: Jun 08, 2006
If you read carefully in the EAA and Perterson STC's for auto fuel STC's, one notices that all of the STC's are always combined with a airframe and engine pair, Just to say that the Lycoming-ABCD engine is STCed is incorrect when this particular example should be Lycoming-ABCD as installed in a Cessn-1234. Meaning that if the same engine is installed on a Piper=XYZ may NOT be Stc-able for auto fuel. Everyone seems to automatically assume that it's the engine only that determines the STC-ability to use auto fuel, when indeed it's the airframe and engine PAIR that determines the ability to consume autofeuk From: "Jim Sears" <jmsears(at)adelphia.net> Subject: Re: RV-List: Super unleaded in 160hp O-320 > My understanding is that the engine will work on the mogas but the > STC > doesn't cover it. So, it would seem the decision is if you want > to keep > your engine certificated. One has to look at the STCs. The EAA STC may not cover high compression engines; but, the Petersen seems to cover them. Do keep in mind that STCs, ADs, etc. do not apply to experimentals; but, one is foolish to not comply, in many cases. If the testing was done for the Petersen STC for high compression approval, I'd think it would be OK to use 91-93 antiknock fuels in them. If not, I wouldn't. Fortunately, his STC does seem to cover them; so, I'm going to use autogas in my next RV, as well. :-) As for the certification, Pat Patterson learned in AB-DAR school that a certifiied engine is indeed decertified when it is attached to an experimental. It is true, even if one does not remove the data plate, which I refuse to do. Just as Sam said, all one has to do is have an IA approve the engine's use on a certified airplane for it to be put back to use as such. I'm sure mine could be put back to service with a couple of changes like removing the starter and alternator. I kept mine in certified condition, I thought, by having an A&P sign off the engine at inspection time. I quit that when Pat told me what he'd learned. I still have Pat, the A&P, help me with the inspection; but, I do the sign off, now. Actually, I don't know why we worry so much about keeping our engines certified, anyway. How often do you think an engine from an experimental is going to be put back into a certified airplane? Most likely, it will be snapped up by another experimental builder before the certified status comes into play. Jim Sears in KY RV-6A N198JS (Scooter) ________________________________________________________________________________
Subject: LSI mag covers
Date: Jun 08, 2006
Greetings all: I have recently installed dual LSI electronic ignition in my RV-4. I installed the mag opening covers just as Klaus recommended with no gasket. I used my usual Aviation Form-A-Gasket as a sealant but the covers are leaking oil. Any suggestions on sealing these better? Did anyone use a gasket? Doug N722DW, 290 hours ________________________________________________________________________________
Date: Jun 08, 2006
No, its the fitting at the brake pedal cylinder, and just the bottom fittings! ----- Original Message ----- From: John D.Heath To: rv-list(at)matronics.com Sent: Wednesday, June 07, 2006 10:55 PM Subject: Re: RV-List: Leaking brakes If you're talking about the brake line, are the double flared? If they aren't, double flair them. If they are, they make soft copper washers that are meant to take care of the same kind of problem in air conditioner systems. Auto parts stores have them. If you're sure its the fittings, good but it might not hurt to look at the calipers and make sure the pistons are not inverted, exposing the "O" rings. Some came from the manufacturer that way. Good Luck John D. ----- Original Message ----- From: dwhite17(at)columbus.rr.com To: rv-list(at)matronics.com Sent: Wednesday, June 07, 2006 9:05 PM Subject: RV-List: Leaking brakes Anyone got any good ideas on how to stop leaking brake cylinders? All four are leaking a tiny bit at the lower fitting. I first installed them without any pipe dope. then I drained the brake lines, cleaned the fittings and reinstalled with prematex sealant and they still leak a tiny bit. Ideas please! ________________________________________________________________________________
Subject: Re: Super unleaded in 160hp O-320 Auto Fuel STC's ( fine point
missed )
Date: Jun 08, 2006
>> If you read carefully in the EAA and Perterson STC's for auto fuel >> STC's, one notices that all of the STC's are always combined with a >> airframe and engine pair, Just to say that the Lycoming-ABCD engine is >> STCed is incorrect when this particular example should be Lycoming-ABCD >> as installed in a Cessn-1234. Meaning that if the same engine is >> installed on a Piper=XYZ may NOT be Stc-able for auto fuel. Everyone >> seems to automatically assume that it's the engine only that determines >> the STC-ability to use auto fuel, when indeed it's the airframe and >> engine PAIR that determines the ability to consume autofeuk << This is true if one owns a commercially built aircraft that must adhere to the STC. However, experimentals do not require an STC for auto gas. Therefore, we aren't bound by the restrictions that owners of commercially built airplanes are. My friend owns a 150hp powered Mooney. His engine would run quite nicely on 87 antiknock fuel. His airframe/engine is not included in the STCs; so, he can't use auto gas. The AA-5A Cheetah that I owned before I started flying my RV-6A was listed in Petersen's STC; so, I bought the STC for it and took advantage of the savings. As owners of experimental aircraft, our biggest concerns are having fuel systems, ignition systems, and compression ratios that allow us to use the fuel. With that, the fine point as indicated was not missed because experimentals don't abide by the same rules as commercially built airplanes. The point of our discussion was what engines might be able to use auto gas safely in our RV airframes. Based on tests in other airframes, some higher compression ratio engines are good candidates for auto gas in our RVs, as well. We just need to use gas with a higher antiknock value. One of the advantages of building and flying experimentals is that we're supposed to experiment. I did test flights with auto fuel to be sure it works in my RV. It did; so, I use it. Knowing that I can up the compression and still possibly use premium auto gas gives me more options for my next RV. Think of it this way. As we fly more and more hours on auto fuels, the FAA may open the doors more for those who fly commerically built aircraft. Not a bad idea, huh? Our experiences will be quite helpful as 100LL becomes a thing of the past. :-) By the way, the only difference I've encountered between having the STCs for my two previous airplanes and my RV is the paperwork. Or, should I say the lack of it on the RV. I have a placard at the fuel cap that indicates 100LL or 87 antiknock fuels. I had to fill out paperwork, put placards at the tanks, and put tags on the engines for the STCs. I also had to pay for the STCs, which were well worth it. I played it somewhat smart when I did the fuel system on my RV. I made it almost identical to the one that was on my AA-5A Cheetah that was allowed the STC. So far, no complaints and much savings. Jim Sears in KY RV-6A N198JS (Scooter) RV-7A #70317 (One of these days) EAA Tech Counselor ________________________________________________________________________________
Date: Jun 08, 2006
Subject: Tru Trak ADI Pilot II
I'm interested in purchasing a Tru Trak ADI Pilot II. Does anyone sell at a better price than what is advertised? Willing to pay by check so no credit card charges to the lucky seller. Who has had the best service on Tru Trak items?...Maybe I should wait for Oshkosh. Any comments? Pat Long PGLong(at)aol.com N120PL RV4 Bay City, Michigan 3CM Do Not Archive ________________________________________________________________________________
Date: Jun 08, 2006
missed ) Jim, I am not aquainted with STC s and how they apply to use of auto fuel. You mention purchasing Peterson's STC that you bought. What do you purchase? Is it the right or license to use the process described in the STC, like a software license? In the case of the experimental aircraft is that necessary or did you apply it to your Cheeta? Does that STC apply to an O-320 160 hp Lycoming? One more question. You mention that you applied the fuel system design to your RV. Are there unique details of the fuel system design that differ from the standard Vans design? Regards, Richard Dudley -6A O-320-D1A flying Jim Sears wrote: > >>> If you read carefully in the EAA and Perterson STC's for auto fuel >>> STC's, one notices that all of the STC's are always combined with a >>> airframe and engine pair, Just to say that the Lycoming-ABCD engine >>> is STCed is incorrect when this particular example should be >>> Lycoming-ABCD as installed in a Cessn-1234. Meaning that if the same >>> engine is installed on a Piper=XYZ may NOT be Stc-able for auto >>> fuel. Everyone seems to automatically assume that it's the engine >>> only that determines the STC-ability to use auto fuel, when indeed >>> it's the airframe and engine PAIR that determines the ability to >>> consume autofeuk << >> > > This is true if one owns a commercially built aircraft that must > adhere to the STC. However, experimentals do not require an STC for > auto gas. Therefore, we aren't bound by the restrictions that owners > of commercially built airplanes are. My friend owns a 150hp powered > Mooney. His engine would run quite nicely on 87 antiknock fuel. His > airframe/engine is not included in the STCs; so, he can't use auto > gas. The AA-5A Cheetah that I owned before I started flying my RV-6A > was listed in Petersen's STC; so, I bought the STC for it and took > advantage of the savings. > > As owners of experimental aircraft, our biggest concerns are having > fuel systems, ignition systems, and compression ratios that allow us > to use the fuel. With that, the fine point as indicated was not > missed because experimentals don't abide by the same rules as > commercially built airplanes. The point of our discussion was what > engines might be able to use auto gas safely in our RV airframes. > Based on tests in other airframes, some higher compression ratio > engines are good candidates for auto gas in our RVs, as well. We just > need to use gas with a higher antiknock value. > > One of the advantages of building and flying experimentals is that > we're supposed to experiment. I did test flights with auto fuel to be > sure it works in my RV. It did; so, I use it. Knowing that I can up > the compression and still possibly use premium auto gas gives me more > options for my next RV. Think of it this way. As we fly more and > more hours on auto fuels, the FAA may open the doors more for those > who fly commerically built aircraft. Not a bad idea, huh? Our > experiences will be quite helpful as 100LL becomes a thing of the > past. :-) > > By the way, the only difference I've encountered between having the > STCs for my two previous airplanes and my RV is the paperwork. Or, > should I say the lack of it on the RV. I have a placard at the fuel > cap that indicates 100LL or 87 antiknock fuels. I had to fill out > paperwork, put placards at the tanks, and put tags on the engines for > the STCs. I also had to pay for the STCs, which were well worth it. > I played it somewhat smart when I did the fuel system on my RV. I > made it almost identical to the one that was on my AA-5A Cheetah that > was allowed the STC. So far, no complaints and much savings. > > Jim Sears in KY > RV-6A N198JS (Scooter) > RV-7A #70317 (One of these days) > EAA Tech Counselor > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Jun 09, 2006
Can someone explain "double flared" as opposed to the single flare? Perhaps a link to a picture or 2 would help. Thanks Greg ----- Original Message ----- From: John D.Heath To: rv-list(at)matronics.com Sent: Thursday, June 08, 2006 12:55 PM Subject: Re: RV-List: Leaking brakes If you're talking about the brake line, are the double flared? If they aren't, double flair them. If they are, they make soft copper washers that are meant to take care of the same kind of problem in air conditioner systems. Auto parts stores have them. If you're sure its the fittings, good but it might not hurt to look at the calipers and make sure the pistons are not inverted, exposing the "O" rings. Some came from the manufacturer that way. Good Luck John D. ----- Original Message ----- From: dwhite17(at)columbus.rr.com To: rv-list(at)matronics.com Sent: Wednesday, June 07, 2006 9:05 PM Subject: RV-List: Leaking brakes Anyone got any good ideas on how to stop leaking brake cylinders? All four are leaking a tiny bit at the lower fitting. I first installed them without any pipe dope. then I drained the brake lines, cleaned the fittings and reinstalled with prematex sealant and they still leak a tiny bit. Ideas please! ________________________________________________________________________________
Date: Jun 08, 2006
Subject: Re: LSI mag covers
Yes, I first installed mine without the gasket as spec'd. They leaked. Then I used the gasket...no more leaks. John Doug Weiler wrote: > > Greetings all: > > I have recently installed dual LSI electronic ignition in my RV-4. I > installed the mag opening covers just as Klaus recommended with no > gasket. I used my usual Aviation Form-A-Gasket as a sealant but the > covers are leaking oil. > > Any suggestions on sealing these better? Did anyone use a gasket? > > Doug > N722DW, 290 hours > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > ________________________________________________________________________________
Subject: FF Kit
Date: Jun 08, 2006
I'm building an RV7. Anyone have experience with the Firewall Forward kit from Van's, or is it better to piece meal? Thanks John ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Jun 08, 2006
I don't believe it has been made clear exactly where they are leaking. However, since you mentioned pipe dope, it would seem to be the pipe threads. Try some EZ Turn and tighten them as much as you dare. Double flaring is not generally necessary, and in this case it is not relevant, as there are not metal lines coming from the bottoms of the brake master cylinders anyway. Alex Peterson RV6-A N66AP 758 hours Maple Grove, MN _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Greg@itmack Sent: Thursday, June 08, 2006 6:57 PM Subject: Re: RV-List: Leaking brakes Can someone explain "double flared" as opposed to the single flare? Perhaps a link to a picture or 2 would help. Thanks Greg ----- Original Message ----- From: John <mailto:altoq(at)cebridge.net> D.Heath Sent: Thursday, June 08, 2006 12:55 PM Subject: Re: RV-List: Leaking brakes If you're talking about the brake line, are the double flared? If they aren't, double flair them. If they are, they make soft copper washers that are meant to take care of the same kind of problem in air conditioner systems. Auto parts stores have them. If you're sure its the fittings, good but it might not hurt to look at the calipers and make sure the pistons are not inverted, exposing the "O" rings. Some came from the manufacturer that way. Good Luck John D. ----- Original Message ----- From: dwhite17(at)columbus.rr.com Sent: Wednesday, June 07, 2006 9:05 PM Subject: RV-List: Leaking brakes Anyone got any good ideas on how to stop leaking brake cylinders? All four are leaking a tiny bit at the lower fitting. I first installed them without any pipe dope. then I drained the brake lines, cleaned the fittings and reinstalled with prematex sealant and they still leak a tiny bit. Ideas please! ________________________________________________________________________________
Date: Jun 08, 2006
/ \ _ _ \ / \ / \\ // ! ! ! ! ! ! A special flairing tool is used in two steps. The first step might be said to make a bubble like form at the end of the line. The second step folds the end most portion back inside the tube, making the flair its self double thickness. Hope this comes through. John D. ----- Original Message ----- From: Greg@itmack To: rv-list(at)matronics.com Sent: Thursday, June 08, 2006 6:57 PM Subject: Re: RV-List: Leaking brakes Can someone explain "double flared" as opposed to the single flare? Perhaps a link to a picture or 2 would help. Thanks Greg ----- Original Message ----- From: John D.Heath To: rv-list(at)matronics.com Sent: Thursday, June 08, 2006 12:55 PM Subject: Re: RV-List: Leaking brakes If you're talking about the brake line, are the double flared? If they aren't, double flair them. If they are, they make soft copper washers that are meant to take care of the same kind of problem in air conditioner systems. Auto parts stores have them. If you're sure its the fittings, good but it might not hurt to look at the calipers and make sure the pistons are not inverted, exposing the "O" rings. Some came from the manufacturer that way. Good Luck John D. ----- Original Message ----- From: dwhite17(at)columbus.rr.com To: rv-list(at)matronics.com Sent: Wednesday, June 07, 2006 9:05 PM Subject: RV-List: Leaking brakes Anyone got any good ideas on how to stop leaking brake cylinders? All four are leaking a tiny bit at the lower fitting. I first installed them without any pipe dope. then I drained the brake lines, cleaned the fittings and reinstalled with prematex sealant and they still leak a tiny bit. Ideas please! ________________________________________________________________________________
Subject: N-Number font
Date: Jun 08, 2006
From: "Puckett, Gregory [DENTK]" <Greg.Puckett(at)united.com>
This is starting to seem a little ridiculous but, Does anyone know of a commonly available computer font that meets all of the requirements of FAR 45.29 for registration marks? Specifically, the way I read it, they want the width of all characters to be two thirds of the height except for 1's W's and M's. I neglected to get somebody to make me a stencil and I need to finish spraying the trim and clear tomorrow. I would like to paint the reg. marking rather than have the stick on. I would like to just cut my own stencil from a product called "frisket film" and paint the number on but I'm worried that if I don't meet the letter of the regs I could be screwed. Has anyone ever run in to a problem with a DAR over this? Thanks, Greg Puckett Elizabeth, CO RV-8 (finally getting close) ________________________________________________________________________________
Subject: Re: N-Number font
Date: Jun 08, 2006
Has anyone ever run in to a problem with a DAR over this? Greg, you may want to check with your DAR. Recently a DAR in our area required an RV to put on the 12 in. letters because the builder said the plane was capable of more than 200 mph. Dale ________________________________________________________________________________
Subject: Re: FF Kit
Date: Jun 08, 2006
If you're a first-time builder and you're going mostly "stock" in terms of your engine/carb/FI/induction/baffles/oil & fuel systems, the FWF kit will be of high value (convenience in terms of $time$ saved). What type of engine are you hanging? The more you stray from Van's stock setups, the less useful the FWF kit will be imho. For example, if you were going with a Sam James cowl & plenum, the FWF kit wouldn't be a 100% perfect match for you. Next time around, I will still probably order the FWF kit but I will most likely omit several items that I would customize. I know this is kinda vague, but it really depends on your setup. )_( Dan RV-7 N714D (933 hours) http://www.rvproject.com ----- Original Message ----- From: John Furey To: rv-list(at)matronics.com Sent: Thursday, June 08, 2006 5:58 PM Subject: RV-List: FF Kit I'm building an RV7. Anyone have experience with the Firewall Forward kit from Van's, or is it better to piece meal? Thanks John ________________________________________________________________________________
Date: Jun 08, 2006
No offense to the DARs on this list, but don't let the DAR push you around. Here's the reg...from Part 45.29: (iii) Marks at least 3 inches high may be displayed on an aircraft for which the FAA has issued an experimental certificate under 21.191 (d), 21.191 (g), or 21.191 (i) of this chapter to operate as an exhibition aircraft, an amateur-built aircraft, or a light-sport aircraft when the maximum cruising speed of the aircraft does not exceed 180 knots CAS; Then the question is...who determines the aircraft's maximum cruising speed? Is it YOU the builder, or is it Van's, the kit manufacturer? How can you possibly know your aircraft's max cruising speed prior to actually flying it? I guess they have to take Van's specs then... And if so... http://www.vansaircraft.com/public/rv-7per.htm 75% Cruise for an RV-7 with the biggest powerplant Van's "endorses" for the design...200hp solo weight 75% cruise is 207 mph = 180 knots. But guess what?! It ain't gonna be INDICATING (calibrating) anywhere near that. CAS will be waaaay less than 180 knots. So even for the RV-8 which Van's specs out at 212 mph (184 knots) at solo weight 75% cruise, CAS won't be anywhere near 180 at 8000'. The key is "CAS" here. That's what the reg says. If the DAR is gonna push you on it, follow the reg to the letter!!! )_( Dan RV-7 N714D (933 hours) http://www.rvproject.com ----- Original Message ----- From: "Dale Ensing" <densing(at)carolina.rr.com> Sent: Thursday, June 08, 2006 8:30 PM Subject: Re: RV-List: N-Number font > > Has anyone ever run in to a problem with a DAR over this? > > > Greg, you may want to check with your DAR. Recently a DAR in our area > required an RV to put on the 12 in. letters because the builder said the > plane was capable of more than 200 mph. > Dale > > > ________________________________________________________________________________
Date: Jun 08, 2006
On 19:09:59 2006-06-08 "Puckett, Gregory [DENTK]" wrote: > Specifically, the way I read it, they want the width of all > characters to be two thirds of the height except for 1's W's and M's. I > neglected to get somebody to make me a stencil and I need to finish > spraying the trim and clear tomorrow. I would like to paint the reg. > marking rather than have the stick on. If nothing else, having a set of vinyl letters made first, in the same font that you would have used for painting, would let you see how it looks before committing to the final layout. And it may not be first in your mind right now, but having removable letters may make your plane a little more attractive down the road to a potential purchaser (if someone wants to re-reg it with different numbers, or move it to Canada, etc.) -Rob ________________________________________________________________________________
Date: Jun 08, 2006
There goes some of those leave it up to the DAR things...I've seen plenty of RV's with the small numbers on them...I'm sure they are over 200 MPH quite often! My -6A had 4" temporary hardware store numbers on it before it was painted...I'm pretty sure it went over 200 MPH on many occasions. Paul Besing --- Dale Ensing wrote: > > > Has anyone ever run in to a problem with a DAR over > this? > > > Greg, you may want to check with your DAR. Recently > a DAR in our area > required an RV to put on the 12 in. letters because > the builder said the > plane was capable of more than 200 mph. > Dale > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: FF Kit
Date: Jun 09, 2006
I am pretty much standard engine, cowling, and the FWF kit saved lots of time. There were some parts supplied I did not use but the convenience of having almost everything was nice. I am not an A&P with lots of spare parts laying around. I wanted parts that was the right part and the right size. The FWF kit worked very well with my TMX-O-360 engine installation. I am sure it would work well with a lycoming as well. Larry in Indiana ----- Original Message ----- From: John Furey To: rv-list(at)matronics.com Sent: Thursday, June 08, 2006 7:58 PM Subject: RV-List: FF Kit I'm building an RV7. Anyone have experience with the Firewall Forward kit from Van's, or is it better to piece meal? Thanks John ________________________________________________________________________________
Subject: Re: FF Kit
Date: Jun 09, 2006
I did the FWF kit and I'd do it again. If you already have some of the parts that are included in the kit, Van's will custom tailor the kit to your needs. Just let them know what you do not need. They will send the rest and bill you accordingly. Just my two cents worth. Steve Struyk RV-8, 50 hours. ----- Original Message ----- From: John Furey To: rv-list(at)matronics.com Sent: Thursday, June 08, 2006 7:58 PM Subject: RV-List: FF Kit I'm building an RV7. Anyone have experience with the Firewall Forward kit from Van's, or is it better to piece meal? Thanks John ________________________________________________________________________________
Subject: FF Kit
Date: Jun 09, 2006
Thanks Dan, I am going with the Sam James cowl and probably a TMX IO-360 (still looking for advice here) I have built 2 RV6A in the past. I am learning a lot from your web site. Thanks John ________________________________________________________________________________
Subject: FF Kit
Date: Jun 09, 2006
Larry, I am leaning towards the TMX O or IO-360 and would appreciate any input. Thanks John ________________________________________________________________________________
Date: Jun 09, 2006
Hi All- A person could have a lot of fun with this one! I asked a pertinent source about this subject and got the perfect answer. The cruise speed of a plane has an FAA definition. Unfortunately I don't have either the citation at my fingertips or the time to look it up right now, but you can go to the main fed site and do a search for the info and get it right from the horses mouth. The short version is that V sub D (design diving speed), V sub NE (never exceed speed), V sub H (max sea level speed), and V sub C (cruise speed) are all mathematically defined and interrelated, as well as linked to wing loading at max gross take off weight. V sub C has a range, the maximum end of which is defined as 0.9 x V sub H. According to Van's, V sub H is 192 kts for the RV-8. 192 x .9 = 173. Therefore, the max cruise speed for an RV-8 is 173 kts as defined by the FAA. Voila! Crossing an ADIZ is another matter, of course. We plan on 12" markings for that reason alone. > > Greg, you may want to check with your DAR. Recently a DAR in our area > required an RV to put on the 12 in. letters because the builder said the > plane was capable of more than 200 mph. > Dale > > > Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jun 09, 2006
Thanks for the info everyone. I know everyone wants to hash out the height issue again and I'm sure I can find some DAR to disagree but, I think that issue is pretty clear as written in the regulation. Dan is right, its CAS and at 75% power the RV-8 will see nothing close to 180kts CAS. Glen's analysis should also be some good ammo. The question I really needed an answer to is: With respect to FAR 45.29 (c), has anyone ever had an issue if the width does not exactly match? It's not like I'm using some crazy font, just a plain Swis821 LtCn BT in bold and slightly slanted but, it does not have characters that are exactly 2/3 wide as they are high and the "1" is not exactly 1/6th wide. The number "8"is exactly 2/3rd but the "N" the "G" and "P" are about as wide as they are high. After looking a Mike Stewarts font, I can't imagine anyone having a problem with mine but before I shoot and clear coat, I wanted to know if anyone had ever heard of an issue with the width and font of the character from their DAR? Thanks everyone. Greg N881GP (c) Width. Characters must be two-thirds as wide as they are high, except the number "1", which must be one-sixth as wide as it is high, and the letters "M" and "W" which may be as wide as they are high. (d) Thickness. Characters must be formed by solid lines one-sixth as thick as the character is high. (e) Spacing. The space between each character may not be less than one-fourth of the character width. ________________________________________________________________________________
Date: Jun 09, 2006
Call your AB-DAR and ask him. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Puckett, Gregory [DENTK] Sent: Friday, June 09, 2006 10:13 AM Subject: RV-List: Re: N-Number font Thanks for the info everyone. I know everyone wants to hash out the height issue again and I'm sure I can find some DAR to disagree but, I think that issue is pretty clear as written in the regulation. Dan is right, its CAS and at 75% power the RV-8 will see nothing close to 180kts CAS. Glen's analysis should also be some good ammo. The question I really needed an answer to is: With respect to FAR 45.29 (c), has anyone ever had an issue if the width does not exactly match? It's not like I'm using some crazy font, just a plain Swis821 LtCn BT in bold and slightly slanted but, it does not have characters that are exactly 2/3 wide as they are high and the "1" is not exactly 1/6th wide. The number "8"is exactly 2/3rd but the "N" the "G" and "P" are about as wide as they are high. After looking a Mike Stewarts font, I can't imagine anyone having a problem with mine but before I shoot and clear coat, I wanted to know if anyone had ever heard of an issue with the width and font of the character from their DAR? Thanks everyone. Greg N881GP (c) Width. Characters must be two-thirds as wide as they are high, except the number "1", which must be one-sixth as wide as it is high, and the letters "M" and "W" which may be as wide as they are high. (d) Thickness. Characters must be formed by solid lines one-sixth as thick as the character is high. (e) Spacing. The space between each character may not be less than one-fourth of the character width. ________________________________________________________________________________
Subject: map box kit
Date: Jun 09, 2006
I have a map box kit for the RV7-9 panel. Has been assembled & primed and includes cut stiffener angles and all hardware. Ready to install. $25.00 plus shipping. (lancej(at)charter.net). ________________________________________________________________________________
Subject: Squeaking brakes
Date: Jun 09, 2006
With all you guys in rocket ships, I'll probably get laughed of the list, but here goes. I have a Zenith CH801, it's maximum speed is around 100mph. I monitor this list because I'm interested in adding an RV-3 to my "stable", either by building from a kit, partially built kit, or possibly a flying plane. Since there are so many RV builders, I thought I might ask here: What can be done to quiet squealing brakes. My CH801 brakes squeal like the dickens with anything more than light application. I have heard a suggestion to put grease on the back side of the pads, between the pads and the pucks, I plan to try that, but I'd like to hear suggestions from anyone who has had to deal with this. When I first taxied the plane, I made sure to season the brakes the same way I used to season my cleveland brakes on production planes, but they have squealed since they were new. Thanks Jim Frisby Zenith CH801 N801ZA Palmer, Alaska ________________________________________________________________________________
Subject: Re: FF Kit
Date: Jun 09, 2006
I have been happy at every step taken with Mattituck. I would buy another engine from them again but would consider others also. Things to change and at the time I bought mine, I felt it was the best value available. Mattituck has exceeded my expectations at every opportunity. Larry in Indiana ----- Original Message ----- From: John Furey To: rv-list(at)matronics.com Sent: Friday, June 09, 2006 7:27 AM Subject: RE: RV-List: FF Kit Larry, I am leaning towards the TMX O or IO-360 and would appreciate any input. Thanks John ________________________________________________________________________________
Date: Jun 09, 2006
Doug, Use a gasket with "TITESEAL LIGHT OR MEDIUM". with a gasket. I have never had good luck with any of the permatex products on airplanes. Good luck. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: "Doug Weiler" <dcw(at)mnwing.org> Sent: Thursday, June 08, 2006 4:13 PM Subject: RV-List: LSI mag covers > > Greetings all: > > I have recently installed dual LSI electronic ignition in my RV-4. I > installed the mag opening covers just as Klaus recommended with no gasket. > I used my usual Aviation Form-A-Gasket as a sealant but the covers are > leaking oil. > > Any suggestions on sealing these better? Did anyone use a gasket? > > Doug > N722DW, 290 hours > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jun 09, 2006
John, I saw your post on the covers which reminded me to tell you that I am signing up for the Airventure race. I hope you are also. I just ordered a 10 gal aux tank for my RV8 from Summit racing. Last year was to close. I almost ran outof fuel. 10 extra gallons should give me a good cushion. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: "John Huft" <rv8(at)lazy8.net> Sent: Thursday, June 08, 2006 7:44 PM Subject: Re: RV-List: LSI mag covers > > Yes, I first installed mine without the gasket as spec'd. They leaked. > Then I used the gasket...no more leaks. > > John > > > Doug Weiler wrote: >> >> Greetings all: >> >> I have recently installed dual LSI electronic ignition in my RV-4. I >> installed the mag opening covers just as Klaus recommended with no >> gasket. I used my usual Aviation Form-A-Gasket as a sealant but the >> covers are leaking oil. >> >> Any suggestions on sealing these better? Did anyone use a gasket? >> >> Doug >> N722DW, 290 hours >> >> >> >> >> >> http://www.matronics.com/Navigator?RV-List >> http://wiki.matronics.com >> >> >> >> >> >> >> >> >> >> >> >> > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Subject: Re: RV7
Date: Jun 09, 2006
John, I was one of the first users of the Sam James cowl and Plenum. It is designed around a fuel injection system with a forward facing air intake direct to the fuel injector. It is very efficient. You can expect at least a 10 knot increase over Vans standard setup. Also, it will cool much more efficiently. Consider installing your oil cooler behind cyl number 4 as high as possible and tilt back approx. 25 degrees for better performance. Good Luck. I will look for you at one of the future Air Venture Cup races. I welcome the competition. Dick Martin N233M RV8 the fast one ----- Original Message ----- From: John Furey To: rv-list(at)matronics.com Sent: Thursday, June 08, 2006 8:14 AM Subject: RV-List: RV7 I have an RV7 QB kit on the way. I now have to decide on engine. I'm leaning towards TMX IO-360 with Roller tappets and Cold Air forward facing intake. I would appreciate any thoughts on carb-vs-injection, roller tappets, etc. TMX-vs-Superior-vs-Lycomming-vs-??? Have any of you exchanged the Vans cowl, wing tips, wheel pants for the Same James? If so what results did you get. Any input would be appreciated. John Furey ________________________________________________________________________________
Date: Jun 09, 2006
Subject: Re: Squeaking brakes
Hi Jim Do a search of the RV-list archives, there is probably a lot of relevant info there. The way aluminum brake lines are formed and attached to the wheel cylinder can create a vibration or chattering squeal. I had to reduce the size of the flexible loop on my aluminum brake lines, somehow a vibration would develop causing a fluttering or whipping in the large brake line loop and causing a lot of high pitched brake noise and also causing one brake line to fail at the wheel cylinder in about 12 hrs. George in Langley B.C. 6A flying 7A finishing Jim Frisby wrote: > > With all you guys in rocket ships, I'll probably get laughed of the list, > but here goes. > > I have a Zenith CH801, it's maximum speed is around 100mph. I monitor this > list because I'm interested in adding an RV-3 to my "stable", either by > building from a kit, partially built kit, or possibly a flying plane. > > Since there are so many RV builders, I thought I might ask here: > > What can be done to quiet squealing brakes. My CH801 brakes squeal like the > dickens with anything more than light application. I have heard a > suggestion to put grease on the back side of the pads, between the pads and > the pucks, I plan to try that, but I'd like to hear suggestions from anyone > who has had to deal with this. > > When I first taxied the plane, I made sure to season the brakes the same way > I used to season my cleveland brakes on production planes, but they have > squealed since they were new. > > Thanks > > Jim Frisby > Zenith CH801 > N801ZA > Palmer, Alaska > > > ________________________________________________________________________________
Date: Jun 09, 2006
Try cleaning and lubing the shafts that the caliper slides on, and make sure the caliper slides on the axis of those shafts...that there isn't a twisting load on it. Just a WAG, hope it helps. )_( Dan RV-7 N714D (934 hours) http://www.rvproject.com ----- Original Message ----- From: "Jim Frisby" <flyingj(at)mtaonline.net> Sent: Friday, June 09, 2006 5:49 PM Subject: RV-List: Squeaking brakes > > With all you guys in rocket ships, I'll probably get laughed of the list, > but here goes. > > I have a Zenith CH801, it's maximum speed is around 100mph. I monitor > this > list because I'm interested in adding an RV-3 to my "stable", either by > building from a kit, partially built kit, or possibly a flying plane. > > Since there are so many RV builders, I thought I might ask here: > > What can be done to quiet squealing brakes. My CH801 brakes squeal like > the > dickens with anything more than light application. I have heard a > suggestion to put grease on the back side of the pads, between the pads > and > the pucks, I plan to try that, but I'd like to hear suggestions from > anyone > who has had to deal with this. > > When I first taxied the plane, I made sure to season the brakes the same > way > I used to season my cleveland brakes on production planes, but they have > squealed since they were new. > > Thanks > > Jim Frisby > Zenith CH801 > N801ZA > Palmer, Alaska > > > ________________________________________________________________________________
Date: Jun 09, 2006
-----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of G McNutt Sent: Friday, June 09, 2006 9:41 PM Subject: Re: RV-List: Squeaking brakes Hi Jim Do a search of the RV-list archives, there is probably a lot of relevant info there. The way aluminum brake lines are formed and attached to the wheel cylinder can create a vibration or chattering squeal. I had to reduce the size of the flexible loop on my aluminum brake lines, somehow a vibration would develop causing a fluttering or whipping in the large brake line loop and causing a lot of high pitched brake noise and also causing one brake line to fail at the wheel cylinder in about 12 hrs. George in Langley B.C. 6A flying 7A finishing Jim Frisby wrote: > > With all you guys in rocket ships, I'll probably get laughed of the list, > but here goes. > > I have a Zenith CH801, it's maximum speed is around 100mph. I monitor this > list because I'm interested in adding an RV-3 to my "stable", either by > building from a kit, partially built kit, or possibly a flying plane. > > Since there are so many RV builders, I thought I might ask here: > > What can be done to quiet squealing brakes. My CH801 brakes squeal like the > dickens with anything more than light application. I have heard a > suggestion to put grease on the back side of the pads, between the pads and > the pucks, I plan to try that, but I'd like to hear suggestions from anyone > who has had to deal with this. > > When I first taxied the plane, I made sure to season the brakes the same way > I used to season my cleveland brakes on production planes, but they have > squealed since they were new. > > Thanks > > Jim Frisby > Zenith CH801 > N801ZA > Palmer, Alaska > > > ________________________________________________________________________________
Subject: DOUBLE FLARING
Date: Jun 10, 2006
Greetings Listers, I have been told that the safest way to treat flares brake and fuel fittings is with a double flaring tool. I can get my hands on a double flaring tool, but it is a 45degree fitting not 37 degree. I was thinking that I could use the double flaring tool to make the initial folded over flare, then my single 37degree flaring tool to finish it off. Does anyone see a problem with this approach?? Thanks, Mick ________________________________________________________________________________
Subject: Re: DOUBLE FLARING
Date: Jun 10, 2006
On 9 Jun 2006, at 23:53, Mick Muller wrote: > > Greetings Listers, I have been told that the safest way to treat > flares brake and fuel fittings is with a double flaring tool. I > can get my hands on a double flaring tool, but it is a 45degree > fitting not 37 degree. I was thinking that I could use the double > flaring tool to make the initial folded over flare, then my single > 37degree flaring tool to finish it off. Does anyone see a problem > with this approach?? The only problem is that there is no service history for this technique, so there is no way to know how likely a failure is. It might be acceptable, or they might have a high failure rate. I wouldn't use this technique on any flare where the failure could cause a safety problem. Fuel and brake lines are not a great place to be using an unproven technique. Yes, double flares are probably a bit more reliable than single flares. But, there are many thousands of aircraft flying with single flared tubes, and they aren't falling out of the sky because of them. Either buy the right double flaring tool, or stick with single flares. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jun 10, 2006
Dick, you bet I am signed up for the race. You will beat me again, but I will still have fun. Teresa is going to ride along this year. John dick martin wrote: > > John, > I saw your post on the covers which reminded me to tell you that I am > signing up for the Airventure race. I hope you are also. > I just ordered a 10 gal aux tank for my RV8 from Summit racing. Last > year was to close. I almost ran outof fuel. 10 extra gallons should > give me a good cushion. > Dick Martin > RV8 N233M > the fast one > ----- Original Message ----- From: "John Huft" <rv8(at)lazy8.net> > To: > Sent: Thursday, June 08, 2006 7:44 PM > Subject: Re: RV-List: LSI mag covers > > >> >> Yes, I first installed mine without the gasket as spec'd. They >> leaked. Then I used the gasket...no more leaks. >> >> John >> >> >> Doug Weiler wrote: >>> >>> Greetings all: >>> >>> I have recently installed dual LSI electronic ignition in my RV-4. >>> I installed the mag opening covers just as Klaus recommended with no >>> gasket. I used my usual Aviation Form-A-Gasket as a sealant but the >>> covers are leaking oil. >>> >>> Any suggestions on sealing these better? Did anyone use a gasket? >>> >>> Doug >>> N722DW, 290 hours >>> >>> >>> >>> >>> >>> http://www.matronics.com/Navigator?RV-List >>> http://wiki.matronics.com >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> http://www.matronics.com/Navigator?RV-List >> http://wiki.matronics.com >> >> >> >> >> >> >> >> >> >> > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Jun 10, 2006
Quoting Paul Besing : > > There goes some of those leave it up to the DAR > things...I've seen plenty of RV's with the small > numbers on them...I'm sure they are over 200 MPH quite > often! My -6A had 4" temporary hardware store numbers > on it before it was painted...I'm pretty sure it went > over 200 MPH on many occasions. > > Paul Besing > Paul: I thought, that the requirement, for 12" was only if you fly outside of the U.S.? Bert > --- Dale Ensing wrote: > > > > > > > Has anyone ever run in to a problem with a DAR over > > this? > > > > > > Greg, you may want to check with your DAR. Recently > > a DAR in our area > > required an RV to put on the 12 in. letters because > > the builder said the > > plane was capable of more than 200 mph. > > Dale > > > > > > > > > > > > browse > > Subscriptions page, > > FAQ, > > > > > > Admin. > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > > ________________________________________________________________________________
Date: Jun 10, 2006
I don't think aluminum line will take well to double fares. You would also have to remove it from your tool and put it in the 37 degree tool which would not work well. Single fares are the standard for aviation and works well, I don't think there is any need to go to double fares. The pressures we are running are just not that high. Jim Jim Cimino N7TL RV-8 S/N 80039 150+ Hours http://www.geocities.com/jcimino.geo/ ----- Original Message ----- From: "Mick Muller" <mmul6471(at)bigpond.net.au> Sent: Friday, June 09, 2006 11:53 PM Subject: RV-List: DOUBLE FLARING > > Greetings Listers, I have been told that the safest way to treat flares > brake and fuel fittings is with a double flaring tool. I can get my hands > on a double flaring tool, but it is a 45degree fitting not 37 degree. I > was thinking that I could use the double flaring tool to make the initial > folded over flare, then my single 37degree flaring tool to finish it off. > Does anyone see a problem with this approach?? > Thanks, Mick > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jun 10, 2006
bertrv6(at)highstream.net wrote: > > Quoting Paul Besing : > > >> >>There goes some of those leave it up to the DAR >>things...I've seen plenty of RV's with the small >>numbers on them...I'm sure they are over 200 MPH quite >>often! My -6A had 4" temporary hardware store numbers >>on it before it was painted...I'm pretty sure it went >>over 200 MPH on many occasions. >> >>Paul Besing >> > > > > > Paul: I thought, that the requirement, for 12" was only if you fly > outside of the U.S.? > > > Bert > Nope, based on speed and the ADIZ. Jerry ________________________________________________________________________________
Subject: IO 550 N
Date: Jun 10, 2006
I have a IO 550 N out of a Cirrus SR22 605 TT NDH 3 Blade Scimitar propeller and single lever engine management system. Interest for RV 10's ? Price with or without core. JN ________________________________________________________________________________
Date: Jun 10, 2006
On 10 Jun 2006, at 17:07, linn Walters wrote: > > > Jerry Springer wrote > >>> >>> Paul: I thought, that the requirement, for 12" was only if >>> you fly >>> outside of the U.S.? >>> Bert >> >> Nope, based on speed and the ADIZ. >> Jerry > > And where is MOST of the ADIZ??? Out of the country. You don't fly through an ADIZ to come up to Canada. Come visit us sometime. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jun 10, 2006
Subject: Re: FF Kit
John, I bought the Mattituck TMX IO-360 w/AFP fuel injection plus two P-mags. My engine was built with the hollow crank in case I might later want to change to a CS prop, but I am going to install and fly with a Catto 3-blade FP. Like you, I also had to do some head scratching about the FWF kit and what I came up with was that the best match for my engine was to get the FWF item #FF-7A O-360 FP. However, I still made some changes of either straight deletions or exchanges as follows: I deleted the gascolator (don't need it with the AFP-FI). I deleted ALL the electrical harnesses and master relay and starter solenoid. (I'll get what I need elsewhere). I deleted the throttle and mixture cables and bracket (I'm using a throttle quadrant from DJM). I changed out the standard FWF 60a alternator for the new 60a alternator w/internal OV protection. I deleted the standard oil cooler and instead bought the Stewart Warner replacement from Pacific. I deleted the standard Vetterman exhaust and instead bought the same exhaust directly from Vetterman except with the mufflers. You can obviously see that most of those changes were as per my personal preference as opposed to changes mandated by my engine installation. For the most part, I think if you just delete the gascolator, you might be able to use all the rest. I am also using the Sam James Cowl and Plenum, so be aware that you need to ask Mattituck to get the special bracket from AFP that's made to fit with the Sam James Plenum. I hope that gets you in the right direction. Vern Wanzong RV7-A Houston, TX On 6/9/06, John Furey wrote: > > Larry, I am leaning towards the TMX O or IO-360 and would appreciate any > input. > > Thanks > John > ________________________________________________________________________________
Subject: Quality
Date: Jun 10, 2006
I just read an article in the RV builders hotline about some very poor quality on quick build wings. Is this a prevalent issue or a rare occurrence? I have a 7 QB that is to be shipped in the next few weeks but don't want it if the workmanship is bad. What has been your experience? John Furey 2 RV6A slow builds 1 RV7 QB (maybe) ________________________________________________________________________________
Date: Jun 10, 2006
Subject: Re: Rv-List: For Sale
Return-Path: Received: from rly-yg04.mx.aol.com (rly-yg04.mail.aol.com [172.18.180.82]) by air-yg04.mail.aol.com (v109.13) with ESMTP id MAILINYG42-288448b46fd2f; Sat, 10 Received: from mr200.mail.mud.yahoo.com (mr200.mail.mud.yahoo.com [209.191.88.233]) by rly-yg04.mx.aol.com (v109.13) with ESMTP id MAILRELAYINYG48-288448b46fd2f; Received: from web55311.mail.re4.yahoo.com (206.190.58.190) DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:Received:Date:From:Subject:To:MIME-Version:Content-Type:Content-Transfer-Encoding; b=RWYr4S3HlxOlcysh6YgW/YQpQH8ScP4s6LQKejJ2i2u9CMtmKAvLUFvZ1VXqFpKLlY3fZyoUpftpbpvM/XcVK7OdobFhWUeIU8Yn5SRL02M0B4FLU1uIfPXC2WBfaGZ8yEnvK+CbZcnH6ejQZzqxs5aRxaiXiIStaMT1t/lE6+s= ; Received: from [70.191.179.28] by web55311.mail.re4.yahoo.com via HTTP; Sat, 10 Date: Sat, 10 Jun 2006 15:26:04 -0700 (PDT) From: Dave Fleckenstein <texasmtprops(at)yahoo.com> Subject: Yeller Pages Listing MIME-Version: 1.0 Content-Type: multipart/alternative; boundary="0-727895693-1149978364=:63360" Content-Transfer-Encoding: 8bit X-AOL-IP: 209.191.88.233 X-Mailer: Unknown (No Version) --0-727895693-1149978364=:63360 Content-Type: text/plain; charset=iso-8859-1 Content-Transfer-Encoding: 8bit Dear Gary VanRemortel, I have two very low time used Hartzell Propellers, Model HC-C2YK-1BF that would be perfect for RV aircraft. Would it be possible to advertise these on the Yeller Pages? Respectfully, Dave Fleckenstein Texas MT Props texasmtprops(at)yahoo.com 936-560-9296 __________________________________________________ --0-727895693-1149978364=:63360 Content-Type: text/html; charset=iso-8859-1 Content-Transfer-Encoding: 8bit --0-727895693-1149978364=:63360-- ________________________________________________________________________________
Date: Jun 10, 2006
Subject: Props for Sale
Please contact the gentleman below. I'm only forwarding to the list and have no connection to the seller. I have two very low time used Hartzell Propellers, Model HC-C2YK-1BF that would be perfect for RV aircraft. Would it be possible to advertise these on the Yeller Pages? Respectfully, Dave Fleckenstein Texas MT Props 936-560-9296 ________________________________________________________________________________
Date: Jun 11, 2006
Subject: Re: Quality
On 06/10 10:18, John Furey wrote: > I just read an article in the RV builders hotline about some very poor > quality on quick build wings. Is this a prevalent issue or a rare > occurrence? I have a 7 QB that is to be shipped in the next few weeks but > don't want it if the workmanship is bad. What has been your experience? Hi John, Mine are fantastic quality. Zero complaints. Well except for the fact that they pre-drill for vans pitot tube, but you can fill that with a steel snap fitting. Now the shipping was a different story. The crate was destroyed on one end and there was some scuffing of the wing skins since the wings were a bit loose. But overall the structure was fine, just buff it out. I've watched and helped another builder build his wings. I'm glad I didn't have to do it, twice, booooorrrriiinnngggggg. :) -- Walter Tondu http://www.rv7-a.com Flying! ________________________________________________________________________________
Date: Jun 11, 2006
For what its worth, my wings were delivered damaged. After a call to Vans and an e-mail with a picture to Scott I returned them and they were fixed. No charge. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Jun 11, 2006
John, My QB wings and fuse arrived together a couple of years ago and I confess I had some misgivings about what to expect concerning the quality of the build. I have to tell you that I was pleasantly amazed at what I saw, and I have yet to see a SB kit that was assembled and riveted as straight and with any more attention to detail than my parts were. What I found with my QB kit has been what I have read from others to find the same, so if there's a bad one out there, it's the exception rather than the rule. Vern On 6/10/06, John Furey wrote: > > I just read an article in the RV builders hotline about some very poor > quality on quick build wings. Is this a prevalent issue or a rare > occurrence? I have a 7 QB that is to be shipped in the next few weeks but > don't want it if the workmanship is bad. What has been your experience? > > John Furey > 2 RV6A slow builds > 1 RV7 QB (maybe) > ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Jun 11, 2006
I received my RV6-A QB in Jan. 2000 and the quality of assembly was "Top Shelf!" The RV flies hands off with absolutely no adjustment including not needing rudder trim. I am building an F1-Rocket now so my RV6-A will have a hanger mate. The F1 will also be a quick build. Tom in Ohio ----- Original Message ----- From: "Walter Tondu" <walter(at)tondu.com> Sent: Sunday, June 11, 2006 1:50 AM Subject: Re: RV-List: Quality > > On 06/10 10:18, John Furey wrote: > > > I just read an article in the RV builders hotline about some very > > poor > > quality on quick build wings. Is this a prevalent issue or a rare > > occurrence? I have a 7 QB that is to be shipped in the next few weeks > > but > > don't want it if the workmanship is bad. What has been your > > experience? > > Hi John, > > Mine are fantastic quality. Zero complaints. Well except for the fact > that > they pre-drill for vans pitot tube, but you can fill that with a steel > snap > fitting. > > Now the shipping was a different story. The crate was destroyed on one > end > and there was some scuffing of the wing skins since the wings were a bit > loose. > But overall the structure was fine, just buff it out. > > I've watched and helped another builder build his wings. I'm glad I > didn't > have to do it, twice, booooorrrriiinnngggggg. :) > > -- > Walter Tondu > http://www.rv7-a.com > Flying! > > > ________________________________________________________________________________
Date: Jun 11, 2006
Now you've done it. From now on, I will refer to nose wheel RVs as Canadian RVs. john gmcjetpilot(at)yahoo.com wrote: > Yea the US sucks, lets complain about the US again. Please there > are jerk Customs on both side. I have crossed the US/Can border > 100's of times when I was a commuter pilot. Trust me it goes both > ways. May be the Canada customs does not harass the C regestered > planes and visa a verse, but this has NOTHING to do with N-numbers. > > How did they name Canada? > > Three of the founding fathers of the frozen hinter lands of the North, > now > known as C-A-N-A-D-A where sitting around the table. One said, What > are we going to name this new country? Another said well lets each pick > one letter. Than each of the founding Fathers sitting around the table > picked a letter. > > The first person said, C, eh' > The next said: N, eh' > and the last person said: D, eh' > > > Cheers George, eh' > > P.S. ________________________________________________________________________________
Date: Jun 11, 2006
I got my QB -8 wings and fuse in April this year, I picked them up at the factory they are Bonanza, Philippines made, They appear to be excellent quality, I haven't started working on them yet,., Dan -8 Lake Stevens WA John Furey wrote: I just read an article in the RV builders hotline about some very poor quality on quick build wings. Is this a prevalent issue or a rare occurrence? I have a 7 QB that is to be shipped in the next few weeks but don't want it if the workmanship is bad. What has been your experience? John Furey 2 RV6A slow builds 1 RV7 QB (maybe) ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Date: Jun 11, 2006
John I was just at the Van's factory and got a close look at the in coming QBs. They were all excellent. I am building a 7A SB and a friend has a QB. Both the wings and the fuse were done to very high standards. Frank @ SGU and SLC.........Finishing up the Tip Up Canopy!!!!!!!!!!! >From: Dan <dan(at)rdan.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Quality >Date: Sun, 11 Jun 2006 09:47:52 -0700 (PDT) > >I got my QB -8 wings and fuse in April this year, I picked them up at the >factory they are Bonanza, Philippines made, They appear to be excellent >quality, I haven't started working on them yet,., > Dan > -8 > Lake Stevens WA > >John Furey wrote: > I just read an article in the RV builders hotline about some very >poor quality on quick build wings. Is this a prevalent issue or a rare >occurrence? I have a 7 QB that is to be shipped in the next few weeks but >don't want it if the workmanship is bad. What has been your experience? > > John Furey > 2 RV6A slow builds > 1 RV7 QB (maybe) > ________________________________________________________________________________
Date: Jun 11, 2006
Subject: VSI reads backwards
Why would a VSI read backwards? There is only 1 port in the back of the VSI for connecting to the static source. When the plane goes 'up' the VSI says it's descending and visa-versa. Can this be repaired or reversed to read properly? Thanks in advance, Rick in Ohio at the Buffalo Farm for the archives ________________________________________________________________________________
Date: Jun 11, 2006
I think you need to fly below sea level. Or maybe inverted? I know, you need to fly in the southern hemisphere. Seriously, it would seem to be mechanically mis-assembled, as it is hard to imagine what else would do it. If it were connected to the pitot, it would misbehave wildly, but not as you describe. Alex Peterson RV6-A N66AP 759 hours Maple Grove, MN _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RGray67968(at)aol.com Sent: Sunday, June 11, 2006 6:16 PM Subject: RV-List: VSI reads backwards Why would a VSI read backwards? There is only 1 port in the back of the VSI for connecting to the static source. When the plane goes 'up' the VSI says it's descending and visa-versa. Can this be repaired or reversed to read properly? Thanks in advance, Rick in Ohio at the Buffalo Farm for the archives ________________________________________________________________________________
Date: Jun 11, 2006
In a message dated 6/10/2006 4:10:21 P.M. Pacific Daylight Time, khorton01(at)rogers.com writes: You don't fly through an ADIZ to come up to Canada. Come visit us sometime. ============================== But aren't you guys, like....communists? ;o) GV (RV-6A N1GV O-360-A1A, C/S, Flying 795hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jun 11, 2006
Subject: Re: VSI reads backwards
If the port is blocked, and the air pressure is changing within the body of the instrument...leak in the body or glass face. jh RGray67968(at)aol.com wrote: > Why would a VSI read backwards? There is only 1 port in the back of > the VSI for connecting to the static source. > > When the plane goes 'up' the VSI says it's descending and visa-versa. > > Can this be repaired or reversed to read properly? > > Thanks in advance, > Rick in Ohio at the Buffalo Farm > for the archives ________________________________________________________________________________
Subject: Quality
Date: Jun 12, 2006
John: Just got home from Golden West Fly-In. The same question was asked to Miles who was giving the talk for Van's Aircraft. Miles is in charge of QUALITY on the QB kits. He says he fixes everything that is not perfect. If you have a problem with quick build quality, give him a call on Monday when he is back in the office. As an EAA TC and an AB DAR, I have not seen ANY QB product from Van's that was not better than what the average first time builder can do. (The QB products from Van's that I have seen are better quality than what I have seen done by first time builders.) Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,868 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: "John Furey" <john(at)fureychrysler.com> Subject: RV-List: Quality Date: Sat, 10 Jun 2006 22:18:42 -0400 I just read an article in the RV builders hotline about some very poor quality on quick build wings. Is this a prevalent issue or a rare occurrence? I have a 7 QB that is to be shipped in the next few weeks but don't want it if the workmanship is bad. What has been your experience? John Furey 2 RV6A slow builds 1 RV7 QB (maybe) ________________________________________________________________________________
Date: Jun 11, 2006
Rick, I once had a VSI which about drove me crazy. Turns out I cracked the case when I installed it in the instrument panel which caused strange indications. Ed ----- Original Message ----- From: RGray67968(at)aol.com To: rv-list(at)matronics.com Sent: Sunday, June 11, 2006 7:16 PM Subject: RV-List: VSI reads backwards Why would a VSI read backwards? There is only 1 port in the back of the VSI for connecting to the static source. When the plane goes 'up' the VSI says it's descending and visa-versa. Can this be repaired or reversed to read properly? Thanks in advance, Rick in Ohio at the Buffalo Farm for the archives ________________________________________________________________________________
Date: Jun 11, 2006
Subject: Quality
My RV-6A QB was 10 years ago almost now, but the workmanship was perfect. Not sure if the same outfit is doing it, but my understanding is you can't really beat the quality today. Paul Besing --- RV6 Flyer wrote: > > > John: > > Just got home from Golden West Fly-In. The same > question was asked to Miles > who was giving the talk for Van's Aircraft. Miles > is in charge of QUALITY > on the QB kits. He says he fixes everything that is > not perfect. If you > have a problem with quick build quality, give him a > call on Monday when he > is back in the office. > > As an EAA TC and an AB DAR, I have not seen ANY QB > product from Van's that > was not better than what the average first time > builder can do. (The QB > products from Van's that I have seen are better > quality than what I have > seen done by first time builders.) > > > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 1,868 + Flying Hours So. CA, USA > http://SoCAL_WVAF.rvproject.com > > > > > ----Original Message Follows---- > From: "John Furey" <john(at)fureychrysler.com> > Reply-To: rv-list(at)matronics.com > To: > Subject: RV-List: Quality > Date: Sat, 10 Jun 2006 22:18:42 -0400 > > I just read an article in the RV builders hotline > about some very poor > quality on quick build wings. Is this a prevalent > issue or a rare > occurrence? I have a 7 QB that is to be shipped in > the next few weeks but > don't want it if the workmanship is bad. What has > been your experience? > > John Furey > 2 RV6A slow builds > 1 RV7 QB (maybe) > > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Date: Jun 11, 2006
Subject: Oshkosh Traffic
Plan to head to Oshkosh and have their NOTAM booklet. Hope to arrive around 9 AM Saturday July 22. What can I expect for incoming traffic the day before Air Venture starts? If I ask for Home Built Parking or HBP, will they send me to the RV parking area? I'm just a little intimidated reading their information. Would like to hear from other who have made the trip. Thanks as usual, Pat Pat Long PGLong(at)aol.com N120PL RV4 Bay City, Michigan 3CM Do Not Archive ________________________________________________________________________________
Date: Jun 11, 2006
Again, this VSI doesn't behave erratically or give 'strange' indications......it's works as advertised....only it reads sdrawkcab (backwards). Rick in Ohio at the Buffalo Farm Rick, I once had a VSI which about drove me crazy. Turns out I cracked the case when I installed it in the instrument panel which caused strange indications. Ed ----- Original Message ----- From: _RGray67968(at)aol.com_ (mailto:RGray67968(at)aol.com) Sent: Sunday, June 11, 2006 7:16 PM Subject: RV-List: VSI reads backwards Why would a VSI read backwards? There is only 1 port in the back of the VSI for connecting to the static source. When the plane goes 'up' the VSI says it's descending and visa-versa. Can this be repaired or reversed to read properly? Thanks in advance, Rick in Ohio at the Buffalo Farm for the archives ________________________________________________________________________________
Date: Jun 11, 2006
Subject: Vent from battery requested
Hello Listers, As I am nearing completion and eventual inspection of my -6 I had the DAR out to have a look under the panel and front area before I install the sticks and other injury items for laying in there. He suggested I instal l a vent from the battery box down out of the plane. He apparently had a bad experience with an overcharged battery when a charge system ran away. I have not heard of this before. Does anyone have any experience in this ? If this is a very rare situation, than it hardly seems necessary. What d o you think? Outside of this, he was happy with all my work and gave me lot s of pointers of little things to tidy up in the engine area. Tim RV-6 N616TB ________________________________________________________________________________
Date: Jun 11, 2006
Turn it 180 degrees in your panel! Dale ________________________________________________________________________________
Date: Jun 11, 2006
Subject: Re: Oshkosh Traffic
The inbound traffic will not be too bad at 9am on Saturday. It doesn't get really busy until later that afternoon, and more so on Sunday. Just follow the Ripon arrival and you'll be fine. And, the show doesn't start until Monday, so you're two days ahead. As for signs- yes, have an HBP sign and hold it up to each and every orange vest you see. When you get in close to the homebuilt parking area you'll be sorted out by type and parked with the other RVs. It is not neccessary to have an "RV" sign. Jeff Point RV-6 Milwaukee ________________________________________________________________________________
Date: Jun 11, 2006
You have to fly with the wheels side down and the canopy side up for it to work properly. Dave Had the shot and took it:D --- RGray67968(at)aol.com wrote: > Why would a VSI read backwards? There is only 1 port > in the back of the VSI > for connecting to the static source. > > When the plane goes 'up' the VSI says it's > descending and visa-versa. > > Can this be repaired or reversed to read properly? > > Thanks in advance, > Rick in Ohio at the Buffalo Farm > for the archives > __________________________________________________ ________________________________________________________________________________
Date: Jun 12, 2006
Subject: That wasted Spark
It would only be if the sensor for the electronic ignition was mounted at the front of the crankshaft, and was triggered each engine rotation would you get that wasted spark. My E I is triggered by a Hall Effect sensor mounted on the accessory case , that is geared two to one with the crankshaft. I will not get that Ryton sump destroying Wasted Spark will I. Am I correct ? Comments please. Stan ________________________________________________________________________________
Date: Jun 11, 2006
What kind of battery are you going to use? If a flooded lead acid battery, then a sealed box with drain is a real good idea. If a recombinant gas battery, like the concord RG series or the Odyssey, you could hold it down with a strap and it would be fine. RG batteries don't outgas and don't need vents. They also crank the engine over like a SOB. Read up here: http://www.aeroelectric.com/articles/rg_bat.html Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Sunday, June 11, 2006 7:34 PM Subject: RV-List: Vent from battery requested Hello Listers, As I am nearing completion and eventual inspection of my -6 I had the DAR out to have a look under the panel and front area before I install the sticks and other injury items for laying in there. He suggested I install a vent from the battery box down out of the plane. He apparently had a bad experience with an overcharged battery when a charge system ran away. I have not heard of this before. Does anyone have any experience in this? If this is a very rare situation, than it hardly seems necessary. What do you think? Outside of this, he was happy with all my work and gave me lots of pointers of little things to tidy up in the engine area. Tim RV-6 N616TB ________________________________________________________________________________
Date: Jun 12, 2006
Subject: Re: That wasted Spark
Sorry Stan, you have two coils and each coil has two spark plug leads. When a coil is triggered a spark goes out each lead and one spark plug lights a fire and the other spark is wasted. Stan Jones wrote: > It would only be if the sensor for the electronic ignition was mounted > at the front of the crankshaft, > and was triggered each engine rotation would you get that wasted spark. > My E I is triggered by a Hall Effect sensor mounted on the accessory > case, that is geared > two to one with the crankshaft. > I will not get that Ryton sump destroying Wasted Spark will I. > Am I correct ? > Comments please. > Stan > > > > > > <http://www.incredimail.com/index.asp?id=409&lang=9> ________________________________________________________________________________
From: =?iso-8859-1?Q?Mich=E8le_Delsol?= <michele.delsol(at)microsigma.fr>
Subject: FF Kit
Date: Jun 12, 2006
Thanks for the info as I myself also ordered a TMX-IO360 ' AL sump, PMags and Vans standard cow. As you did, I am going personal on all the electrical stuff; Mufflers ' also via Vetterman direct. As for gascolators, I am putting a couple of Andairs at the wing roots. Not sure about the cables and brackets ' what would you recommend? Oil cooler ' same here ' going SW from Pacific ' great people to work with ' good advice. It seems that after removing the above, all that is left is all of the little items which a first time builder is sure not to have on hand, each of which will take tons of time to get. Thanks, Michele ' RV8 Fuselage (France) _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vern W. Sent: dimanche 11 juin 2006 02:25 Subject: Re: RV-List: FF Kit Importance: High John, I bought the Mattituck TMX IO-360 w/AFP fuel injection plus two P-mags. My engine was built with the hollow crank in case I might later want to change to a CS prop, but I am going to install and fly with a Catto 3-blade FP. Like you, I also had to do some head scratching about the FWF kit and what I came up with was that the best match for my engine was to get the FWF item #FF-7A O-360 FP. However, I still made some changes of either straight deletions or exchanges as follows: I deleted the gascolator (don't need it with the AFP-FI). I deleted ALL the electrical harnesses and master relay and starter solenoid. (I'll get what I need elsewhere). I deleted the throttle and mixture cables and bracket (I'm using a throttle quadrant from DJM). I changed out the standard FWF 60a alternator for the new 60a alternator w/internal OV protection. I deleted the standard oil cooler and instead bought the Stewart Warner replacement from Pacific. I deleted the standard Vetterman exhaust and instead bought the same exhaust directly from Vetterman except with the mufflers. You can obviously see that most of those changes were as per my personal preference as opposed to changes mandated by my engine installation. For the most part, I think if you just delete the gascolator, you might be able to use all the rest. I am also using the Sam James Cowl and Plenum, so be aware that you need to ask Mattituck to get the special bracket from AFP that's made to fit with the Sam James Plenum. I hope that gets you in the right direction. Vern Wanzong RV7-A Houston, TX On 6/9/06, John Furey wrote: Larry, I am leaning towards the TMX O or IO-360 and would appreciate any input. Thanks John ________________________________________________________________________________
Date: Jun 12, 2006
Mick, I had considered doing EXACTLY what you propose. However, I found that the vise block on the automotive double flaring tool had serrations designed to prevent slippage of the steel automotive tubing. These serrations imprinted themselves onto the soft aluminum tubing. These creates stress risers, which I found unacceptable. I created a "favorite search" for the correct tool on EBay. After several months, I was able to purchase the tool for $137. Check with your A&P friends or your local EAA Chapter. They may be willing to loan or rent you the tool. Charlie Kuss > >Greetings Listers, I have been told that the safest way to treat >flares brake and fuel fittings is with a double flaring tool. I can >get my hands on a double flaring tool, but it is a 45degree fitting >not 37 degree. I was thinking that I could use the double flaring >tool to make the initial folded over flare, then my single 37degree >flaring tool to finish it off. Does anyone see a problem with this approach?? >Thanks, Mick > > ________________________________________________________________________________
Subject: IO 550 N
Date: Jun 12, 2006
John: Is the engine damaged? How much are you asking for the engine core? Thank you. Rhonda ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Neel Sent: Saturday, June 10, 2006 6:02 PM Subject: RV-List: IO 550 N I have a IO 550 N out of a Cirrus SR22 605 TT NDH 3 Blade Scimitar propeller and single lever engine management system. Interest for RV 10's ? Price with or without core. JN ________________________________________________________________________________
Date: Jun 12, 2006
Hi Ed, I didn't see any recomendation in that article for venting, but interesti ng reading. My battery is the standard concord RG series battery. Van's do esn t show or suggest a vent in the pland or manual. Hopefully the issue won 't be pushed such that I need to install one. Thanks Tim -------Original Message------- From: Ed Holyoke Date: 06/11/06 22:59:47 Subject: RE: RV-List: Vent from battery requested What kind of battery are you going to use? If a flooded lead acid battery , then a sealed box with drain is a real good idea. If a recombinant gas battery, like the concord RG series or the Odyssey, you could hold it dow n with a strap and it would be fine. RG batteries don=92t outgas and don=92 t need vents. They also crank the engine over like a SOB. Read up here: http://www.aeroelectric.com/articles/rg_bat.html Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Sunday, June 11, 2006 7:34 PM Subject: RV-List: Vent from battery requested Hello Listers, As I am nearing completion and eventual inspection of my -6 I had the DAR out to have a look under the panel and front area before I install the sticks and other injury items for laying in there. He suggested I instal l a vent from the battery box down out of the plane. He apparently had a bad experience with an overcharged battery when a charge system ran away. I have not heard of this before. Does anyone have any experience in this ? If this is a very rare situation, than it hardly seems necessary. What d o you think? Outside of this, he was happy with all my work and gave me lot s of pointers of little things to tidy up in the engine area. Tim RV-6 N616TB ________________________________________________________________________________
Date: Jun 12, 2006
Subject: GPS antenna firewall quick connect
Does anyone know how to properly make up a disconnect at the firewall for my GPS antenna? I have mounted the antenna for my Garmin 396 under the engine cowling. What I don't know is how to splice into the antenna wire and make up a proper firewall quick connect/disconnect that will enable me to take off the cowl without fishing the antenna wire through the firewall every time. Is it OK to splice the antenna wire? how? which connectors do I use? Appreciate your ideas. Ron N8ZD - just weeks now! ________________________________________________________________________________
Subject: Re: GPS antenna firewall quick connect
Date: Jun 12, 2006
Make a shelf on the firewall for the antenna? That way removing the cowl is independent of the antenna. )_( Dan ----- Original Message ----- From: Ron Patterson To: rv-list-digest(at)matronics.com Sent: Monday, June 12, 2006 7:56 AM Subject: RV-List: GPS antenna firewall quick connect Does anyone know how to properly make up a disconnect at the firewall for my GPS antenna? I have mounted the antenna for my Garmin 396 under the engine cowling. What I don't know is how to splice into the antenna wire and make up a proper firewall quick connect/disconnect that will enable me to take off the cowl without fishing the antenna wire through the firewall every time. Is it OK to splice the antenna wire? how? which connectors do I use? Appreciate your ideas. Ron N8ZD - just weeks now! ________________________________________________________________________________
Date: Jun 12, 2006
When I turn the light switch off in my office, the electricity isn't bein g wasted because there is no load on it. Could this be true for this situation? No load, no spark -------Original Message------- From: G McNutt Date: 06/12/06 01:15:35 Subject: Re: RV-List: That wasted Spark Sorry Stan, you have two coils and each coil has two spark plug leads. When a coil is triggered a spark goes out each lead and one spark plug lights a fire and the other spark is wasted. Stan Jones wrote: > It would only be if the sensor for the electronic ignition was mounted > at the front of the crankshaft, > and was triggered each engine rotation would you get that wasted spark. > My E I is triggered by a Hall Effect sensor mounted on the accessory > case, that is geared > two to one with the crankshaft. > I will not get that Ryton sump destroying Wasted Spark will I. > Am I correct ? > Comments please. > Stan > > > <http://www.incredimail.com/index.asp?id=409&lang=9> ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
Date: Jun 12, 2006
In a message dated 6/12/2006 8:02:35 A.M. Pacific Daylight Time, scc_ron(at)yahoo.com writes: Does anyone know how to properly make up a disconnect at the firewall for my GPS antenna? I have mounted the antenna for my Garmin 396 under the engine cowling. What I don't know is how to splice into the antenna wire and make up a proper firewall quick connect/disconnect that will enable me to take off the cowl without fishing the antenna wire through the firewall every time. Is it OK to splice the antenna wire? how? which connectors do I use? ========================================= IIRC mine's a TNC type. GV (RV-6A N1GV O-360-A1A, C/S, Flying 792hrs, Silicon Valley, CA) ________________________________________________________________________________
Subject: Re: Tru Trak ADI Pilot II
Date: Jun 12, 2006
Fabian Lefler at Affordable Panels has good prices on TruTrak products, in fact, he has great prices on all products year round. (I have no connection to the company other than being a VERY satisfied customer) http://www.affordablepanels.com Jekyll Read this topic online here: http://forums.matronics.com/viewtopic.php?p=40133#40133 ________________________________________________________________________________
Date: Jun 12, 2006
I am not familiar with the waste spark system you are talking about, but am familiar with the automotive system. If you have two plugs being fired by a single coil, then the system fires one plug positive and one negative creating a complete circuit. The coil fires the first plug positive the voltage goes to ground continues though the engine block, jumps from the negative electrode to the positive electrode on the second plug and continues back to the coil. This means that one plug is firing on the top of the compression stroke and the other on the exhaust stroke...the wasted spark. I have a simulator in my classroom that when slowed way down you can actually see the positive and negative firing. Jim Jim Cimino N7TL RV-8 S/N 80039 150+ Hours http://www.geocities.com/jcimino.geo/ ----- Original Message ----- From: Tim Bryan To: rv-list(at)matronics.com Sent: Monday, June 12, 2006 11:30 AM Subject: Re: RV-List: That wasted Spark When I turn the light switch off in my office, the electricity isn't being wasted because there is no load on it. Could this be true for this situation? No load, no spark -------Original Message------- From: G McNutt Date: 06/12/06 01:15:35 To: rv-list(at)matronics.com Subject: Re: RV-List: That wasted Spark Sorry Stan, you have two coils and each coil has two spark plug leads. When a coil is triggered a spark goes out each lead and one spark plug lights a fire and the other spark is wasted. Stan Jones wrote: > It would only be if the sensor for the electronic ignition was mounted > at the front of the crankshaft, > and was triggered each engine rotation would you get that wasted spark. > My E I is triggered by a Hall Effect sensor mounted on the accessory > case, that is geared > two to one with the crankshaft. > I will not get that Ryton sump destroying Wasted Spark will I. > Am I correct ? > Comments please. > Stan > > > > > > <http://www.incredimail.com/index.asp?id=409&lang=9> ========================= ============ he RV-List Email Forum - http://www.matronics.com/Navigator?RV-List ========================= ============ sp; - NEW MATRONICS LIST WIKI - nics.com ========================= ============ sp; - List Contribution Web Site - sp; -Matt Dralle, List Admin. //www.matronics.com/contribution ========================= ============ ________________________________________________________________________________
Subject: Stainless steel brackets
Date: Jun 12, 2006
Greetings: Does anyone know who makes the stainless steel wheel pant brackets for RVs?? Thanks Doug Weiler N722DW ________________________________________________________________________________
Subject: Re: IO 550 N
Date: Jun 12, 2006
Rhonda, There is no damage to the engine or propeller. The total time is 605hours and they are complete. I would like a IO 360 core or approximate value. Call with any questions. Regards John Neel Cell 435-632-2917 ----- Original Message ----- From: Rhonda Bewley To: rv-list(at)matronics.com Sent: Monday, June 12, 2006 7:51 AM Subject: RE: RV-List: IO 550 N John: Is the engine damaged? How much are you asking for the engine core? Thank you. Rhonda ------------------------------------------------------------------------- ----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Neel Sent: Saturday, June 10, 2006 6:02 PM To: rv-list(at)matronics.com Subject: RV-List: IO 550 N I have a IO 550 N out of a Cirrus SR22 605 TT NDH 3 Blade Scimitar propeller and single lever engine management system. Interest for RV 10's ? Price with or without core. JN ------------------------------------------------------------------------- ----- 6/9/2006 ________________________________________________________________________________
Subject: Re: Stainless steel brackets
Date: Jun 12, 2006
Fairings Etc at www.fairings-etc.com Regards, Jeff Orear RV6A N782P Peshtigo, WI ----- Original Message ----- From: Doug Weiler To: rv-list(at)matronics.com Sent: Monday, June 12, 2006 11:59 AM Subject: RV-List: Stainless steel brackets Greetings: Does anyone know who makes the stainless steel wheel pant brackets for RVs?? Thanks Doug Weiler N722DW ________________________________________________________________________________
Date: Jun 12, 2006
Note these fairing are designed for Van's "Pressure Recovery" wheel pants. They are not suited for the older "slimmer" wheel pants of the RV-6A. I ordered a pair and tried to adapt them to my older wheel pants. They are well made and sturdy but I finally ended up making my own out of Stainless steel. It was just easier than trying to adapt these - but, perhaps I gave up to easy. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com ----- Original Message ----- From: Jeff Orear To: rv-list(at)matronics.com Sent: Monday, June 12, 2006 1:27 PM Subject: Re: RV-List: Stainless steel brackets Fairings Etc at www.fairings-etc.com Regards, Jeff Orear RV6A N782P Peshtigo, WI ----- Original Message ----- From: Doug Weiler To: rv-list(at)matronics.com Sent: Monday, June 12, 2006 11:59 AM Subject: RV-List: Stainless steel brackets Greetings: Does anyone know who makes the stainless steel wheel pant brackets for RVs?? Thanks Doug Weiler N722DW ________________________________________________________________________________
Subject: FF Kit
Date: Jun 12, 2006
Aerosport Power installed the Airflow Performance fuel injection on a Superior IO-360-B1B (180 hp) engine for my RV-8A. I ordered the firewall forward kit from Vans. There were some duplications. I remember that the plate that attaches the filtered air box (F.A.B.) to the fuel meter box came from both AFP and Van=92s, but I had to make a custom one anyway to move the F.A.B. about 3/8=94 to one side to center it in the bottom cowl scoop. This is the part that several have experienced cracks with, so I built it out of heavier aluminum than the original. It=92s a simple flat oval, so it wasn=92t difficult to make. I have a couple of hoses left over that I didn=92t need, and had to order two more that I didn=92t get from either source. One is the 42=94 long =BC=94 firesleeved line that runs from the purge valve on the top of the engine back to the firewall. The other is the 3/8=94 firesleeved line with a 90 degree pipe bend on one end that runs from the firewall to the mechanical fuel pump. Mine will be 15=94 long. I ordered both from Airflow Performance last week and expect to get them today or tomorrow. I think the two hoses will cost just a little under $200. I did install an Andair gascolator in the left wing root, although I now don=92t think that was any improvement over the AFP fuel filter that I did not install. But all that bent tubing looks impressive. Terry RV-8A firewall forward almost done Seattle _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mich=E8le Delsol Sent: Monday, June 12, 2006 5:42 AM Subject: RE: RV-List: FF Kit Thanks for the info as I myself also ordered a TMX-IO360 ' AL sump, PMags and Vans standard cow. As you did, I am going personal on all the electrical stuff; Mufflers ' also via Vetterman direct. As for gascolators, I am putting a couple of Andairs at the wing roots. Not sure about the cables and brackets ' what would you recommend? Oil cooler ' same here ' going SW from Pacific ' great people to work with ' good advice. It seems that after removing the above, all that is left is all of the little items which a first time builder is sure not to have on hand, each of which will take tons of time to get. Thanks, Michele ' RV8 Fuselage (France) ________________________________________________________________________________
Subject: copper antenna tape
Date: Jun 12, 2006
Any of you guys need some copper tape to make your hidden antenna?? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=8292565445&rd=1&ss pag ename=STRK%3AMESE%3AIT&rd=1 Vince ________________________________________________________________________________
Subject: Fuel Injected - or Not
Date: Jun 12, 2006
Indecision is the key to flexibility. One of the great things about building an airplane: it's ok to change one's mind. I'm about at the engine ordering stage for my RV-8A QB. I have done a lot of research and thought I had made a rationale, educated decision - a new 180 hp horizontal induction fuel injected engine from Aerosport. However, a buddy casually posed the question: "Why fuel injection?" and I realized that other than the fact it seemed newer and sexier, I had no compelling answer as to why fuel injection might be worth the additional cost and pump installation complexity. I live in the Mojave (Ridgecrest, CA); carb icing isn't a compelling driver. So a question for all you old hands out there - Is fuel injection really worth the extra several thousand bucks? Why or why not? Also, does anyone know of any document that shows an in depth analysis of why or why not? Paul Valovich Booger -8A QB ________________________________________________________________________________
Subject: Re: Fuel Injected - or Not
Date: Jun 12, 2006
Run LOP and fuel injection can "pay for itself" in less time than TBO. Beyond that, the savings are pure gravy. Gas isn't getting any cheaper, and the cost savings by burning 1-2 fewer gph is increasing on a daily basis. That is, the savings increase as gas prices increase. To those who think the 200hp IO-360-A1B6 angle valve engine "should" burn more fuel than smaller, less powered engines...I burn about 7.5 gph at wide open throttle doing 170 KTAS. Injected...wouldn't have it any other way. You asked for opinions. 8^) )_( Dan RV-7 N714D (935 hours) http://www.rvproject.com ----- Original Message ----- From: Valovich, Paul To: rv-list(at)matronics.com Sent: Monday, June 12, 2006 11:32 AM Subject: RV-List: Fuel Injected - or Not Indecision is the key to flexibility. One of the great things about building an airplane: it's ok to change one's mind. I'm about at the engine ordering stage for my RV-8A QB. I have done a lot of research and thought I had made a rationale, educated decision - a new 180 hp horizontal induction fuel injected engine from Aerosport. However, a buddy casually posed the question: "Why fuel injection?" and I realized that other than the fact it seemed newer and sexier, I had no compelling answer as to why fuel injection might be worth the additional cost and pump installation complexity. I live in the Mojave (Ridgecrest, CA); carb icing isn't a compelling driver. So a question for all you old hands out there - Is fuel injection really worth the extra several thousand bucks? Why or why not? Also, does anyone know of any document that shows an in depth analysis of why or why not? Paul Valovich Booger -8A QB ________________________________________________________________________________
Date: Jun 12, 2006
>So a question for all you old hands out there ' Is fuel injection really >worth the extra several thousand bucks? Why or why not? > >Also, does anyone know of any document that shows an in depth analysis of >why or why not? One benefit of Fuel Injection (FI) is the ability to run lean of peak. That should save fuel but I cannot show that it is worth the additional cost. A reported drawback of FI is hard starting under hot conditions (supposedly after landing then starting a short time later). You did go with 180 HP which is good. Whether it makes sense to go for more horsepower is another factor I cannot quantify. However, given that I could get more horsepower for the same cost of FI personally I would go for the horsepower. Ron Lee ________________________________________________________________________________
Date: Jun 12, 2006
Paul, The main reason is fuel economy. You can run lean of peak with fuel injection and the best you can run is about 50 deg rick of peak with a carburetor. Fuel distribution with fuel injection can be almost dead on where as carburetors can not do that. With fuel costs the way they are and not going to get any better, FI was the way I chose. Plus if you travel to places where carb heat is necessary - so comes the problems associated with it. Just my humble opinion. Jim Nelson IO-360 ________________________________________________________________________________
Date: Jun 12, 2006
For me: A smoother running engine and balanced fuel flow saving an immediate .5 GPH for the life of the engine. Now, all EGT's peak at the same time. This is a little work but easy to do. You can also able to run LOP. I have flown side by side with a carbureated RV-7 (I have an 8a injected) and used 2.0 GPH less than they did on a 3.5 hr flight one way. Oh, I also have dual EI so that helped. So I used 14 gallons less!!!!!! Also read ALL of John Deakins articles on running LOP. Might have to read them 3 times before it all sinks in but worth while in order to REALLY understand what goes on in a engine. So go here and sort through and read all articles "Pelicans Pearch" http://www.avweb.com/news/columns/list.html "Valovich, Paul" wrote: st1\:*{behavior:url(#default#ieooui) } Indecision is the key to flexibility. One of the great things about building an airplane: its ok to change ones mind. Im about at the engine ordering stage for my RV-8A QB. I have done a lot of research and thought I had made a rationale, educated decision a new 180 hp horizontal induction fuel injected engine from Aerosport. However, a buddy casually posed the question: Why fuel injection? and I realized that other than the fact it seemed newer and sexier, I had no compelling answer as to why fuel injection might be worth the additional cost and pump installation complexity. I live in the Mojave (Ridgecrest, CA); carb icing isnt a compelling driver. So a question for all you old hands out there Is fuel injection really worth the extra several thousand bucks? Why or why not? Also, does anyone know of any document that shows an in depth analysis of why or why not? Paul Valovich Booger -8A QB __________________________________________________ ________________________________________________________________________________
Date: Jun 12, 2006
This is a better link to Deakins articles. Cut and paste? http://www.avweb.com/cgi-bin/texis/scripts/avweb-search/search.html?publication=avflash&publication=bizav&publication=avweb&query=john+deakin&Go.x=11&Go.y=6 Scott in San Diego "Valovich, Paul" wrote: st1\:*{behavior:url(#default#ieooui) } Indecision is the key to flexibility. One of the great things about building an airplane: its ok to change ones mind. Im about at the engine ordering stage for my RV-8A QB. I have done a lot of research and thought I had made a rationale, educated decision a new 180 hp horizontal induction fuel injected engine from Aerosport. However, a buddy casually posed the question: Why fuel injection? and I realized that other than the fact it seemed newer and sexier, I had no compelling answer as to why fuel injection might be worth the additional cost and pump installation complexity. I live in the Mojave (Ridgecrest, CA); carb icing isnt a compelling driver. So a question for all you old hands out there Is fuel injection really worth the extra several thousand bucks? Why or why not? Also, does anyone know of any document that shows an in depth analysis of why or why not? Paul Valovich Booger -8A QB __________________________________________________ ________________________________________________________________________________
Date: Jun 12, 2006
Valovich, Paul wrote: > Indecision is the key to flexibility. One of the great things about > building an airplane: its ok to change ones mind. > > > > Im about at the engine ordering stage for my RV-8A QB. I have done a > lot of research and thought I had made a rationale, educated decision > a new 180 hp horizontal induction fuel injected engine from Aerosport. > However, a buddy casually posed the question: Why fuel injection? and > I realized that other than the fact it seemed newer and sexier, I had no > compelling answer as to why fuel injection might be worth the additional > cost and pump installation complexity. Your friend is a very perceptive fellow! After nine years of watching, building, maintaining, inspecting, and flying RV's, it has been my observation that those pilots with fuel injection spend more time and money getting their planes to operate the way they want them to than the carbed pilots. I have yet to hear one of them volunteer how much money they are saving on fuel. The carburator guys just bolt on the engine and go flying. :-) I'm not implying one system is better than the other, just offering my observations. Sam Buchanan (RV-6, 748 hrs) ________________________________________________________________________________
Date: Jun 12, 2006
Saturday is actually 2 days before Oshkosh starts (starts on Monday). I live only 1.5 hours flight from Oshkosh and fly in at this time every year. Traffic is light, but picks up late morning/early afternoon. As long as you read the NOTAM, and make a cheat sheet for you to follow (frequencies, patterns, etc.), you should be OK. Also, ATC has posted pictures on the AirVenture web site that shows you just what you will see from the air and what landmarks to look for. I've flown in alone without any problem, but a right seater with you surely lessens the load. Can't comment on your choice or parking, since I don't (yet) have a completed homebuilt and always park in the North 40. However, I DO walk around on Saturday and there seems to be PLENTY of space in every parking sector. Maybe somebody else can comment on the parking situation from personal experience. Good luck! I LOVE flying into Oshkosh. You get a real sense of accomplishment, and a real appreciation for the controllers and all the rest of the Oshkosh ground crews. The only thing missing is the red carpet to step on when you exit your aircraft! But, there ARE red-carpet people that will greet you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=40215#40215 ________________________________________________________________________________
Date: Jun 12, 2006
The "big puck" of the 396 antenna is like a usb cable and would be tricky to mount out there, personally I wouldnt mount any gps antennas inside the engine cowling. ----- Original Message ----- From: Ron Patterson To: rv-list-digest(at)matronics.com Sent: Monday, June 12, 2006 10:56 AM Subject: RV-List: GPS antenna firewall quick connect Does anyone know how to properly make up a disconnect at the firewall for my GPS antenna? I have mounted the antenna for my Garmin 396 under the engine cowling. What I don't know is how to splice into the antenna wire and make up a proper firewall quick connect/disconnect that will enable me to take off the cowl without fishing the antenna wire through the firewall every time. Is it OK to splice the antenna wire? how? which connectors do I use? Appreciate your ideas. Ron N8ZD - just weeks now! ________________________________________________________________________________
Date: Jun 12, 2006
> Your friend is a very perceptive fellow! > > After nine years of watching, building, maintaining, inspecting, and > flying RV's, it has been my observation that those pilots with fuel > injection spend more time and money getting their planes to operate > the > way they want them to than the carbed pilots. I have yet to hear > one of > them volunteer how much money they are saving on fuel. > > The carburator guys just bolt on the engine and go flying. :-) > > I'm not implying one system is better than the other, just offering my > > observations. > I tend to echo Sam's observations. If a reason for justifying the cost of fuel injection is the fuel savings one will have, one is missing a good deal. If one really wants to save money on fuel costs, auto gas has a much higher savings rate than maybe a .5 gallon savings per hour of 100LL. At 8gph of fuel, that equates to about $2 per hour savings on 100LL. Local mogas prices allow me about $10.50 savings with the same 8 gallons. In 2000 hours of flying, that could equate to $21K in savings. Whoah! That would go a long way toward the price on another engine, if one invests the savings. Of course, one who doesn't favor using mogas might see the fuel injection system as the better approach; but, taking the savings on the carby and fuel to the bank works well for my wallet. I just wonder which system has more problems. It seems I see more folks having fuel injection systems worked on than I do with carbys. That's not to say that they have more problems. It's just that I've observed more fuel injection systems being worked on as I've visited the local FBO's shop. If I'm right, maybe the predicted savings using a fuel injected engine would be eaten up by the costs of maintaining it? Just a thought. I guess I like the simplicity of the carb and will stick with that for myself. Each of us has his own ways to justify the system used. Pick the one that works best for you. Jim Sears in KY EAA Tech Counselor ________________________________________________________________________________
Date: Jun 12, 2006
An even better URL for Pelican's Perch: http://tinyurl.com/lej9v --- Tedd McHenry Surrey, BC, Canada ________________________________________________________________________________
Date: Jun 12, 2006
My RV-4 has an Aerosport Power IO-360B1B and it has worked perfectly for the last 400+ hours. The plane starts very easy when it is cold and has not been a problem when it is hot. I have never run a battery down trying to get it to start. A good friend has an O-320 from Powersport with a carb and no primer in his RV-6a. It is a total pain to start when it is cold. He has run the battery down a number of times trying to get it to start. Sam Buchanan wrote: The carburator guys just bolt on the engine and go flying. :-) you forgot... After they install and connect a heat muff for carb heat, carb heat control cable, primer hoses, primer pump, carb temp sensor, carb temp sensor wiring, ..... The reason I chose fuel injection: 1. No carb heat 2. I had been in an RV and it would sputter when we were down side up. 3. I had been told that Fuel Injection would tolerate water in the fuel better. Rob Hickman N401RH RV-4 ________________________________________________________________________________
Date: Jun 12, 2006
Seems like with the higher fuel pressure one could run Mogas without the vapor lock problem thus saving more $$$$. I have heard of hot start problems with FI but I have a carb and have no problems starting hot or cold. I would like to use Mogas but am afraid of vapor lock so I stick with 100LL. Scott >So a question for all you old hands out there - Is fuel injection really >worth the extra several thousand bucks? Why or why not? > > >Also, does anyone know of any document that shows an in depth analysis >of why or why not? > >Paul Valovich > >Booger > >-8A QB > > ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Jun 12, 2006
> Your friend is a very perceptive fellow! > > After nine years of watching, building, maintaining, inspecting, and > flying RV's, it has been my observation that those pilots with fuel > injection spend more time and money getting their planes to > operate the > way they want them to than the carbed pilots. I have yet to > hear one of > them volunteer how much money they are saving on fuel. > > The carburator guys just bolt on the engine and go flying. :-) > > I'm not implying one system is better than the other, just > offering my > observations. > > Sam Buchanan (RV-6, 748 hrs) Well, clearly there will be disagreements on this thread. I have no clue about the actual percentage of users which have trouble with carbs vs FI, but I do know that I burn less fuel with my Airflow Performance FI than most carb equipped planes do. A noticable amount less. I have flown many, many hours side by side with other RV's, on long cross country flights, and at cruises in the 155 - 160 knot TAS range, where I burn between 1 and 2 gallons per hour less (this is at MAP's of about 22", 2300 rpm, relatively low percent power, maybe 58 to 60%). How many of you cruise with fuel flows of 7.1 to 7.3 gph, at 155 to 160 ktas? Most carbs cannot be run, even with electronic ignition (a big factor), in the LOP region. I do not have much experience with my plane in the 75% power regime, but the differences would be expected to be even greater there, since keeping the engine out of the "red zone" (higher cht's, among other nasty combustion effects) is more important there, and tends to spread the LOP/ROP fuel flows even more. Even at 1 gph savings, it equates to something like $3000 worth of fuel at today's prices that I've saved up to now in 759 hours of flying my RV. I would welcome flying side by side with anyone wanting hard data, particularly where so many variables are involved. For those building and trying to decide, I simply have offered another viewpoint. Alex Peterson RV6-A N66AP 759 hours Maple Grove, MN ________________________________________________________________________________
Date: Jun 12, 2006
Maybe somebody else can comment on the parking situation from personal experience. You'll have no trouble getting a parking spot in RV land on Saturday morning. Parking doesn't really get tight until about late Monday into Tuesday. By Wednesday people begin leaving and spots open up. Monday through Wednesday are the best days for RV-looking. With that said, we are getting the same amount of space as last year, to park what will undoubtably be more RVs than last year. We'll likely end up having to tail planes into rows in order to fit them in, so nose-gear guys, bring your tow bars. Jeff ________________________________________________________________________________
Date: Jun 12, 2006
Howdy Tim, Our plane has been running the Concord RG 25 that fits the standard battery box for 700 plus hours. There's no vent for the box and no need for one. You can mount the battery on it's side if you want and it won't leak. Your DAR is thinking about the old style battery with vent/filler caps that you had to open up every so often to check the level of the electrolyte. Our Cessna had one of those and a vented box with a tube exiting the bottom of the cowl. It was corroded inside from the battery venting itself. Had to clean it up with baking soda and repaint pretty much every year. Not going back to that noise! Educate your DAR as to the newer technology. Concord still makes the old style flooded battery and the newer RG one. Go to Concord battery's website or Hawker's (the manufacturer of the Odyssey) for more info. Panasonic and others also make suitable RG batteries. Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Monday, June 12, 2006 7:37 AM Subject: RE: RV-List: Vent from battery requested Hi Ed, I didn't see any recomendation in that article for venting, but interesting reading. My battery is the standard concord RG series battery. Van's doesn't show or suggest a vent in the pland or manual. Hopefully the issue won't be pushed such that I need to install one. Thanks Tim -------Original Message------- From: Ed Holyoke <mailto:bicyclop(at)pacbell.net> Date: 06/11/06 22:59:47 Subject: RE: RV-List: Vent from battery requested What kind of battery are you going to use? If a flooded lead acid battery, then a sealed box with drain is a real good idea. If a recombinant gas battery, like the concord RG series or the Odyssey, you could hold it down with a strap and it would be fine. RG batteries don't outgas and don't need vents. They also crank the engine over like a SOB. Read up here: http://www.aeroelectric.com/articles/rg_bat.html Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Sunday, June 11, 2006 7:34 PM Subject: RV-List: Vent from battery requested Hello Listers, As I am nearing completion and eventual inspection of my -6 I had the DAR out to have a look under the panel and front area before I install the sticks and other injury items for laying in there. He suggested I install a vent from the battery box down out of the plane. He apparently had a bad experience with an overcharged battery when a charge system ran away. I have not heard of this before. Does anyone have any experience in this? If this is a very rare situation, than it hardly seems necessary. What do you think? Outside of this, he was happy with all my work and gave me lots of pointers of little things to tidy up in the engine area. Tim RV-6 N616TB ________________________________________________________________________________
Date: Jun 13, 2006
I can second that. He really goes out of his way to ensure things are OK. I am another satisfied customer. Stan -------Original Message------- From: Jekyll Date: 06/13/06 04:39:11 Subject: RV-List: Re: Tru Trak ADI Pilot II Fabian Lefler at Affordable Panels has good prices on TruTrak products, i n fact, he has great prices on all products year round. (I have no connecti on to the company other than being a VERY satisfied customer) http://www.affordablepanels.com Jekyll Read this topic online here: http://forums.matronics.com/viewtopic.php?p=40133#40133 ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
Date: Jun 13, 2006
You can get BNC connecters that go through a bulkhead. I have some. Stan -------Original Message------- From: Ron Patterson Date: 06/13/06 03:30:58 Subject: RV-List: GPS antenna firewall quick connect Does anyone know how to properly make up a disconnect at the firewall for my GPS antenna? I have mounted the antenna for my Garmin 396 under the engine cowling. Wh at I don't know is how to splice into the antenna wire and make up a proper firewall quick connect/disconnect that will enable me to take off the cow l without fishing the antenna wire through the firewall every time. Is it OK to splice the antenna wire? how? which connectors do I use? Appreciate your ideas. Ron N8ZD - just weeks now! ________________________________________________________________________________
Date: Jun 13, 2006
Another reason for FI would be if you do any negative G aerobatics ' I believe that float style carburetted engines cannot cope with negative Gs. Please someone correct me if I am wrong. Michele RV8 ' Fuselage PS ' negative Gs does not have to be the wrenching loops and turns one sees at air shows, it can be as simple as just flying straight upside down, or not doing +G figures quite as well as one should. _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Valovich, Paul Sent: lundi 12 juin 2006 20:33 Subject: RV-List: Fuel Injected - or Not Indecision is the key to flexibility. One of the great things about building an airplane: it=92s ok to change one=92s mind. I=92m about at the engine ordering stage for my RV-8A QB. I have done a lot of research and thought I had made a rationale, educated decision ' a new 180 hp horizontal induction fuel injected engine from Aerosport. However, a buddy casually posed the question: =93Why fuel injection?=94 and I realized that other than the fact it seemed newer and sexier, I had no compelling answer as to why fuel injection might be worth the additional cost and pump installation complexity. I live in the Mojave (Ridgecrest, CA); carb icing isn=92t a compelling driver. So a question for all you old hands out there ' Is fuel injection really worth the extra several thousand bucks? Why or why not? Also, does anyone know of any document that shows an in depth analysis of why or why not? Paul Valovich Booger -8A QB ________________________________________________________________________________
Date: Jun 13, 2006
>> A good friend has an O-320 from Powersport with a carb and no primer in >> his RV-6a. It is a total pain to start when it is cold. He has run the >> battery down a number of times trying to get it to start.<< I've never understood not having a primer. The engine can be harder to start and could cause one to have an engine fire. I have a primer system and have never run a battery down, even when it's really cold. >>you forgot... After they install and connect a heat muff for carb heat, carb heat control cable, primer hoses, primer pump, carb temp sensor, carb temp sensor wiring, .....<< Excuse me; but, I don't have a carb temp sensor and wiring. I do have the primer and carb heat. Both were easy to install. Since I've never had to use the carb heat on either of my Lycoming powered airplanes, I don't consider carb ice a major problem for the engines. The Continental I had on my C172 was another matter. :-( >> The reason I chose fuel injection: 1. No carb heat 2. I had been in an RV and it would sputter when we were down side up. 3. I had been told that Fuel Injection would tolerate water in the fuel better.<< I guess these are good reasons for this contributor; but, none make me jump up and take notice. As I said, carb ice hasn't been a problem for my Lycomings. Since I try to keep the top side up, during flights, I don't have the sputter problems. One who prefers to fly upside down (and have everything in the cabin trying to go through the canopy) may want fuel injection, though. I try to keep water out of my fuel systems and have never had problems with water in my fuel. Sure, I do get some out of the sumps, from time to time; but, I've never had an engine fail because of water in the gas. That's with my using mogas, as well. :-) Jim Sears in KY EAA Tech Counselor ________________________________________________________________________________
Date: Jun 13, 2006
The original poster is deciding on whether to order his new engine with or without FI, not convert an existing engine. I don't know about Aerosport, but I bought a brand new TMX-IO360 w/Airflow Performance FI from Mattituck (it arrived just last week) and the differenc e in price BETWEEN the standard carb engine and going to the AFP FI was only $700. For me, that was a no brainer going with the FI at that price difference because of the already mentioned advantages. In fact, I went one step further and paid the additional $1000 for the "Flow Matching" option that gives you the ability to lean very exactingly by the engines ability to kee p all four cylinders running at the same fuel flow. So even at the additional $1700 for the way I went, it was still a no brainer. I admit that if were actually flying with a carbed engine, I would probably seriously wonder if I wanted to spend more than $3000 to change it over, bu t that's not an issue with a brand new engine order. Vern RV7-A Houston, TX On 6/12/06, Valovich, Paul wrote: > > Indecision is the key to flexibility. One of the great things about > building an airplane: it's ok to change one's mind. > > > I'm about at the engine ordering stage for my RV-8A QB. I have done a lot > of research and thought I had made a rationale, educated decision ' a n ew > 180 hp horizontal induction fuel injected engine from Aerosport. However, a > buddy casually posed the question: "Why fuel injection?" and I realized t hat > other than the fact it seemed newer and sexier, I had no compelling answe r > as to why fuel injection might be worth the additional cost and pump > installation complexity. > > > I live in the Mojave (Ridgecrest, CA); carb icing isn't a compelling > driver. > > > So a question for all you old hands out there ' Is fuel injection reall y > worth the extra several thousand bucks? Why or why not? > > > Also, does anyone know of any document that shows an in depth analysis of > why or why not? > > Paul Valovich > > Booger > > -8A QB > > ________________________________________________________________________________
Date: Jun 13, 2006
>> Well, clearly there will be disagreements on this thread. I have no clue >> about the actual percentage of users which have trouble with carbs vs FI, >> but I do know that I burn less fuel with my Airflow Performance FI than >> most carb equipped planes do. A noticable amount less. I have flown >> many, many hours side by side with other RV's, on long cross country >> flights, and at cruises in the 155 - 160 knot TAS range, where I burn >> between 1 and 2 gallons per hour less (this is at MAP's of about 22", >> 2300 rpm, relatively low percent power, maybe 58 to 60%). How many of you >> cruise with fuel flows of 7.1 to 7.3 gph, at 155 to 160 ktas? Most carbs cannot be run, even with electronic ignition (a big factor), in the LOP region. I do not have much experience with my plane in the 75% power regime, but the differences would be expected to be even greater there, since keeping the engine out of the "red zone" (higher cht's, among other nasty combustion effects) is more important there, and tends to spread the LOP/ROP fuel flows even more.<< Alas, my little 150hp engine will not pull my -6A at those speeds at the altitudes I fly at. With that, I do fly at 75% power, most of the time. At that setting, it gets about 8gph on a cross country flight. If I pull mine back to a lesser setting, of say 2300 rpms, mine will also get better fuel usage per hour. I've gotten as low as 6gph while taking up Young Eagles. I use 2200 rpms for that. Granted, I can't use the LOP method for leaning; but, my use of mogas doesn't require major changes in my flying habits to save money. >> Even at 1 gph savings, it equates to something like $3000 worth of fuel >> at today's prices that I've saved up to now in 759 hours of flying my >> RV.<< That's fairly substantial and something most of us could have if we throttle back from 75% power. My savings during that same period would be at least $6K on mogas while flying at 75% power. That's knowing I'd be saving at least a dollar per gallon over the cost of 100LL, on average. Today, it's $1.31 per gallon difference. Alex obviously has it worked out so that he saves a little money on his flying. He may also have a very clean airplane. Mine isn't; so, I do have drag that make mine a little slower. I don't care because I get to build more time in my airplane, that way. I kinda like that. Mogas allows me to afford it. That's an option not available to FI engines. Jim Sears in KY EAA Tech Counselor ________________________________________________________________________________
Subject: RE: LOP with carb
Date: Jun 13, 2006
I have to throw in my 2 cents on this one. My initial thought was to run a FI system, but the simplicity & budget of the carb won out. The bonus was the economy is better than expected. The engine is an O-320 w/ 9.2:1 CR and a single Emag. The EGT's are only equal during WOT operation, otherwise they are 100 degrees off (some rich & some lean). I can get to about 30 LOP before the engine runs rougher and is unhappy. Fuel burns are 7.0-7.2 depending on altitude. This is at 155 kts in a 6A dragging steps, fixed pitch Sensenich and a nose gear around. So the answer to the question below is that carbs can run economically. How does this compare to others - I don't know - but I'm happy with the results. You make choices and move forward. I'll spend the thousands I saved on fuel and go places. Have fun everyone! Kelly Patterson PHX, AZ RV-6A 64 hours ----------______________________ Well, clearly there will be disagreements on this thread. I have no clue about the actual percentage of users which have trouble with carbs vs FI, but I do know that I burn less fuel with my Airflow Performance FI than most carb equipped planes do. A noticeable amount less. I have flown many, many hours side by side with other RV's, on long cross country flights, and at cruises in the 155 - 160 knot TAS range, where I burn between 1 and 2 gallons per hour less (this is at MAP's of about 22", 2300 rpm, relatively low percent power, maybe 58 to 60%). How many of you cruise with fuel flows of 7.1 to 7.3 gph, at 155 to 160 ktas? Most carbs cannot be run, even with electronic ignition (a big factor), in the LOP region. I do not have much experience with my plane in the 75% power regime, but the differences would be expected to be even greater there, since keeping the engine out of the "red zone" (higher cht's, among other nasty combustion effects) is more important there, and tends to spread the LOP/ROP fuel flows even more. Even at 1 gph savings, it equates to something like $3000 worth of fuel at today's prices that I've saved up to now in 759 hours of flying my RV. I would welcome flying side by side with anyone wanting hard data, particularly where so many variables are involved. For those building and trying to decide, I simply have offered another viewpoint. Alex Peterson RV6-A N66AP 759 hours Maple Grove, MN ________________________________________________________________________________
Date: Jun 13, 2006
> > I have to throw in my 2 cents on this one. My initial thought > was to run a FI system, but the simplicity & budget of the > carb won out. > > The bonus was the economy is better than expected. The engine > is an O-320 w/ > 9.2:1 CR and a single Emag. The EGT's are only equal during > WOT operation, otherwise they are 100 degrees off (some rich > & some lean). I can get to about 30 LOP before the engine > runs rougher and is unhappy. Fuel burns are > 7.0-7.2 depending on altitude. This is at 155 kts in a 6A > dragging steps, fixed pitch Sensenich and a nose gear around. > So the answer to the question below is that carbs can run > economically. > > How does this compare to others - I don't know - but I'm > happy with the results. You make choices and move forward. > I'll spend the thousands I saved on fuel and go places. Have > fun everyone! > > Kelly Patterson > PHX, AZ > RV-6A 64 hours Kelly, You have a nice setup, which seems to be well balanced. We have a 7A here which has a carb and is also well balanced (with respect to fuel/air charge to each cylinder). However, it seems to be more the exception than the rule, and seems to be luck of the draw. Again, side by side flight, equalizing ground speeds, is the only real way to know one's true fuel efficiency compared to others. Alex Peterson RV6-A N66AP 759 hours Maple Grove, MN ________________________________________________________________________________
Date: Jun 13, 2006
For those who don't know, Jeff is one of the volunteers who park us every year, so you are getting this from the horse's mouth (just an expression, Jeff ). One other option is to arrive about Thursday morning. By then many are leaving, having had all the aviation they can drink from a fire hose. Lots of parking opening up, and still half the show to see. If need be, our loyal parkers will steal space from the glass-backward crowd. John RV8 Nuisance Jeff Point wrote: > > Maybe somebody else can comment on the parking situation from personal experience. > > You'll have no trouble getting a parking spot in RV land on Saturday morning. Parking doesn't really get tight until about late Monday into Tuesday. By Wednesday people begin leaving and spots open up. Monday through Wednesday are the best days for RV-looking. > > With that said, we are getting the same amount of space as last year, to park what will undoubtably be more RVs than last year. We'll likely end up having to tail planes into rows in order to fit them in, so nose-gear guys, bring your tow bars. > > Jeff > > > > > > > > ________________________________________________________________________________
Date: Jun 13, 2006
At 06:59 AM 6/13/2006, you wrote: > >snipped > >Alex obviously has it worked out so that he saves a little money on >his flying. He may also have a very clean airplane. Mine isn't; >so, I do have drag that make mine a little slower. I don't care >because I get to build more time in my airplane, that way. I kinda >like that. Mogas allows me to afford it. That's an option not >available to FI engines. > >Jim Sears in KY >EAA Tech Counselor Jim What makes you think that FI engines can not use Mogas? If you are referring to the angle valve 200 hp models, you are correct. However, any parallel valve engine (320, 360 or 540) using 7.2 to 1 or 8.5 to 1 pistons CAN use Mogas. Those engines using 8.5 to 1 pistons (160 hp 320s, 180 hp 360s and 230 hp 540s) will require using premium (91 octane or better) Mogas. The 200 hp crowd is out of luck with Mogas. However, I suspect anyone willing to spend the extra money and sacrifice 20+ pounds of payload (due to the added weight of the angle valve engine) don't really care about economy, like you and I. Fuel injection, electronic ignition, 4 into 1 tuned exhaust with mogas will yield the best economy. Charlie Kuss ________________________________________________________________________________
Date: Jun 13, 2006
PLEASE TELL YOUR WEBMASTER TO TAKE ME OF THEIR LIST I DON"T KNOW HOW THEY GOT MY ADDRESS PLEASE I AM TRIED OF YOUR JUNK MAILS TO MY BOX PLEASE I DON"T WANT YOUR SPAM HERE. __________________________________________________ ________________________________________________________________________________
Subject: DC Load Centers
Date: Jun 13, 2006
On the Control Vision / Anywhere Map website, as well as in Van's catalog are several prewired 'synthetic' fuse circuit boards. What experience has anyone had good or bad. If you wish you may contact me directly at pdeits(at)comcast.net. Same question re: the Lamar MC-10 ________________________________________________________________________________
Date: Jun 13, 2006
GPS antenna pucks are different than most antennas. They are active and contain high gain amplifiers to boost the satellite signal from its fempto-watt apparent level to the level need by the receiver. That circuitry is not likely to enjoy living in a 400 degree world. It is also not going to like the corona traveling down each of the spark plug wires making a high noise samba line. >From a radio designer and RV9A builder take the recommendation to not locate that poor antenna in such a hostile place. On 6/12/06, Stan Jones wrote: > > You can get BNC connecters that go through a bulkhead. > I have some. > Stan > > *-------Original Message-------* > > *From:* Ron Patterson > *Date:* 06/13/06 03:30:58 > *To:* rv-list-digest(at)matronics.com > *Subject:* RV-List: GPS antenna firewall quick connect > > *Does anyone know how to properly make up a disconnect at the firewall for > my GPS antenna?* > ** > *I have mounted the antenna for my Garmin 396 under the engine cowling. > What I don't know is how to splice into the antenna wire and make up a > proper firewall quick connect/disconnect that will enable me to take off the > cowl without fishing the antenna wire through the firewall every time.* > ** > *Is it OK to splice the antenna wire? how? which connectors do I use?* > ** > *Appreciate your ideas.* > * > Ron > N8ZD - just weeks now! > * > > > <http://www.incredimail.com/index.asp?id=409&lang=9> > ________________________________________________________________________________
Date: Jun 13, 2006
From: "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net>
> > Jim > What makes you think that FI engines can not use Mogas? If you are > referring to the angle valve 200 hp models, you are correct. However, > any parallel valve engine (320, 360 or 540) using 7.2 to 1 or 8.5 to 1 > pistons CAN use Mogas. Those engines using 8.5 to 1 pistons (160 hp > 320s, 180 hp 360s and 230 hp 540s) will require using premium (91 > octane or better) Mogas. > The 200 hp crowd is out of luck with Mogas. However, I suspect anyone > willing to spend the extra money and sacrifice 20+ pounds of payload > (due to the added weight of the angle valve engine) don't really care > about economy, like you and I. > Fuel injection, electronic ignition, 4 into 1 tuned exhaust with > mogas will yield the best economy. > Charlie Kuss > Charlie, I was hoping someone would bring that up. When I had my engine on the S1S Pitt's, it had a diet of 93 octane (or whatever octane it was back then) Shell or Amoco. They finally went to an alcohol additive in this part of the Midwest and I quit using it. I have a bendix RSA and I couldn't tell any difference in 100 LL or Shell or Amoco, absolutely none. I never had any adjustments or babying with it to keep it going. It goes like a Duracell rabbit Phil, in Illinois RV6 181RV ________________________________________________________________________________
Date: Jun 13, 2006
> What makes you think that FI engines can not use Mogas? If you > are > referring to the angle valve 200 hp models, you are correct. > However, any parallel valve engine (320, 360 or 540) using 7.2 to > 1 or > 8.5 to 1 pistons CAN use Mogas. Those engines using 8.5 to >1 pistons (160 > hp 320s, 180 hp 360s and 230 hp 540s) will require > using premium (91 > octane or better) Mogas. If one sticks with the spirit of the STCs, I found no fuel injected engines listed as approved for auto gas. It could be that the fuel injection system is more prone to vapor locking. I don't know. I do know that I just looked at EAA's STC and found no engines starting with IO- in the list. (I've always assumed IO means fuel injected; so, correct me if I'm wrong. ) My list of engines from Petersen is pretty old; but, it shows none, either. That doesn't mean that the higher compression engines weren't shown, though. They just need more octane, as I've said before. If one wants to experiment, which we all can do, one can use auto gas in a fuel injected engine. However, I'm thinking there must have been a good reason for FI engines not being in the STCs. I'm betting it's the fact that auto gas tends to vapor lock faster than 100LL. If one runs auto gas over the top of a hot engine, would it not be more prone to vapor locking? Could be. I'm not willing to spend the money on a FI engine only to find out I can't use auto gas, after all. It would be most embarrasing to be flying along and have the engine quit due to vapor lock. Hmmmm. What would I tell my passenger, if I can find one brave enough to ride with me? :-) > The 200 hp crowd is out of luck with Mogas. However, I suspect anyone > willing to spend the extra money and sacrifice 20+ pounds > of payload > (due to the added weight of the angle valve engine) don't really care > about economy, like you and I. > Fuel injection, electronic ignition, 4 into 1 tuned exhaust with mogas > will yield the best economy. I hope Charlie is right. If enough of you guys are willing to take the risk and run auto gas in FI engines, let us know how it's working out. I may have to change my mind and buy a FI engine for my current project. Otherwise, I guess I'll be a big chicken and go with a carby. I figure I can suffer a little bit on fuel economy and still be smiling every time I fill up my tanks with auto gas. :-) Jim Sears in KY EAA Tech Counselor (20 years of flying with auto gas) ________________________________________________________________________________
Date: Jun 13, 2006
I have read on this list and others many reports of success installing the GPS antenna under the cowl; none that I recall reported problems. There was some concern about using metallic paint on the cowl, but I don't think anyone reported an actual problem. As for the "400 degree world", that does seem a bit high. There are often other electronics under the cowl too. My Lightspeed Ignition control box is there. If you think it might get too hot, maybe pointing a blast tube at it would help. And as for them all being active, my understanding is that some are and some are not. I don't know about that except that my Bluemountain EFIS instructions say to make sure I use the right one with their system. But then I design buildings, not antennas, so maybe I'm wrong. Terry RV-8A firewall forward Seattle _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael Hudson Sent: Tuesday, June 13, 2006 9:46 AM Subject: Re: RV-List: GPS antenna firewall quick connect GPS antenna pucks are different than most antennas. They are active and contain high gain amplifiers to boost the satellite signal from its fempto-watt apparent level to the level need by the receiver. That circuitry is not likely to enjoy living in a 400 degree world. It is also not going to like the corona traveling down each of the spark plug wires making a high noise samba line. >From a radio designer and RV9A builder take the recommendation to not locate that poor antenna in such a hostile place. ________________________________________________________________________________
Date: Jun 13, 2006
OR, take if from people who have been actually flying with this setup for YEARS with absolutely no problems. I know many people personally who have their GPS antenna on top of the engine compartment under the cowl. The position offers an amazing unobstructed view of the sky. My first reaction was the same as most: "doesn't that fry the antenna?". Their reply: "hasn't in the last 6 years!". Mitch Faatz RV-6A Finish Kit Auburn, CA GPS antenna under the cowl. Michael Hudson wrote: > GPS antenna pucks are different than most antennas. They are active > and contain high gain amplifiers to boost the satellite signal from > its fempto-watt apparent level to the level need by the receiver. > That circuitry is not likely to enjoy living in a 400 degree world. > It is also not going to like the corona traveling down each of the > spark plug wires making a high noise samba line. > > From a radio designer and RV9A builder take the recommendation to not > locate that poor antenna in such a hostile place. ________________________________________________________________________________
Date: Jun 13, 2006
My 430 antenna is also under the cowl with no problem. However, what 396 antenna are you referring to; the GPS or the XM weather antenna/receiver? What may not be a problem for the GPS antenna could possibly be for the XM antenna/receiver. Rick McBride ----- Original Message ----- From: Mitchell Faatz<mailto:mitch(at)skybound.com> To: rv-list(at)matronics.com Sent: Tuesday, June 13, 2006 2:30 PM Subject: Re: RV-List: GPS antenna firewall quick connect > OR, take if from people who have been actually flying with this setup for YEARS with absolutely no problems. I know many people personally who have their GPS antenna on top of the engine compartment under the cowl. The position offers an amazing unobstructed view of the sky. My first reaction was the same as most: "doesn't that fry the antenna?". Their reply: "hasn't in the last 6 years!". Mitch Faatz RV-6A Finish Kit Auburn, CA GPS antenna under the cowl. Michael Hudson wrote: > GPS antenna pucks are different than most antennas. They are active > and contain high gain amplifiers to boost the satellite signal from > its fempto-watt apparent level to the level need by the receiver. > That circuitry is not likely to enjoy living in a 400 degree world. > It is also not going to like the corona traveling down each of the > spark plug wires making a high noise samba line. > > From a radio designer and RV9A builder take the recommendation to not > locate that poor antenna in such a hostile place. ========================= ========== http://www.matronics.com/Navigator?RV-List ator?RV-List> ========================= ========== ========================= ========== http://www.matronics.com/contribution on> ========================= ========== ________________________________________________________________________________
Subject: OSH Parking Comments
Date: Jun 13, 2006
Just a few reminders for all of you going to OSH this year. As someone who has spent a reasonable amount of time in an orange vest at OSH and many other fly-ins remember the flight ain't over until the plane is tied down. For the most part almost all airplane fatalities and injuries occur either on, or very close to the ground. Oshkosh is no exception in spite of the higher potential for mid air collisions. While I don't work in the homebuilt section I do park a lot of aircraft during that two weeks in July. It is true that you are the pilot and it's your job to not run into anything, but it's my job to keep things from running into you. So if you don't like what you see, or you can see that I don't like what I see then it's time to shut it down and have a chat about it all. Fortunately airplanes aren't too hard to push and there's always a bunch of volunteers that would love to help. For many the trip in seems kinda fast and hairy, but then it's over and you are on the ground. Well, this is when the stress really begins. OSH is big and usually hot, we are moving up 11000 airplanes on and off the field. Typically there are pre-established routes that aren't very obvious to those sitting in a cockpit, but the idea is to keep everyone on any taxiway going the same direction. As such you may toodle around a bit for no apparent reason kinda like an IFR flight. We realize that you are hot, that you need to get out and clean your shorts, that a quart of ice cold rum would be just the thing, but please bear with us. Have the signs as per the NOTAM, and print them out with a printer, bold, landscape, 300pt Arial. Big letters with a ball point pen on a sectional chart will get a nice laugh from many, but you will taxi around for a while... I think it's the last page of the NOTAM has a great cheat sheet for frequencies but once you are off the runway that will do nothing for you. Depending on which runway you land on and where you are going you might see up to 20 or so volunteers directing you over the course. The sooner each one of them is able to recognize that three letter sign of yours, the sooner they will get you on your way to the right location. As well, there are defined areas for parking various types of airplanes. Just because it's empty and it is show center doesn't mean you get to park there. And if you know Paul or Tom Poberezny, that's fine, we'll still park you where we want and then you can have them come help you move your plane to where they want it. Speaking of that, while we are willing to relocate aircraft, we usually try to do it during the lulls. This often doesn't work out though because lulls come and go. Be patient, we'll do our best to get you there. Also, when departing, don't start your engine without an orange vested soul nearby. As one who has seen airplanes collide into things at OSH it doesn't matter whose fault it is, everyone is bummed and there are no winners. These orange vested souls can be hard to find, particularly down in the homebuilt area. If you are looking for something to do I suggest you volunteer and wear a vest for a few tours. It will greatly expand your knowledge of the ground operations there as well as get you a free glass of ice water and a baloney and butter sandwich. Make sure you get a briefing before you depart and keep the brief sheet or you will be stopped and briefed when you get to the runway. This is very disconcerting to have happen just before takeoff and I have seen many pilots have to abort because they got rattled and forgot something like a canopy latch. This of course means they get back in line and do it all over again. And always remember, no matter how bad it gets, if they are wearing an orange vest they aren't getting paid. Just like you, they are out there trying to have a good time. They may not know everything so help them learn, and help them help you. W ________________________________________________________________________________
Date: Jun 13, 2006
Hi Jim, I just checked EAA's web site. I note that they state: "Please note that our STC's are only for engines that are certified for the use of 80 octane fuel. Engines requiring 100 octane fuel must still use 100 octane avgas." I found the following link regarding Peterson Aviation's STCs for auto fuels. They do show that some models (8.5 to 1 CR) require the use of 91 octane auto fuel. As Jim stated, all these models are carbureted. Jim is correct here. The STC'd use of auto fuel in certified fuel injected aircraft may be a vapor lock concern as Jim states. It may also simply be that the STCs were not pursued due to poor return on investment. The IO-320-Bxx series of engines were not used on many aircraft. (Twin Comanches if memory serves me) Why waste the money to get the STC if the number of fleet aircraft using the engine won't recoup your investment and a reasonable return? The following is just my opinion, but I think that the physics back me up. Vapor lock occurs when the fuel boils in the lines. Carbureted engine fuel pumps generate 1 to 5 psi. Bendix (aka Precision) and Airflow Performance fuel injected units use 19 to 34 psi ( 25 psi is nominal on 4 cylinder models) fuel pumps. Pressurizing a liquid will increase it's boiling point. Therefore, from the electric boost pump to the fuel servo, you should have about 25 psi. The servo modifies (reduces) this pressure, but it stays well above the 5 psi maximum of carbureted systems. Once running, the FI system should be less likely to encounter vapor lock. Hot restarts are another issue. Jim may be correct that the issue is related to hot restarts on FI systems. With no pressure at start up, and the small steel lines going from the fuel distributor to the individual fuel injectors on top of the engine, this is a prime area for the fuel to boil. It may also boil at or near the mechanical pump. However, since we are in the experimental category we are free to use/try this approach. If your system, be it Bendix or Airflow Performance exhibits hot restart problems, these can be solved with the addition of Airflow Performance's fuel purge valve. This valve allows the pilot to recirculate the heated fuel by means of the boost pump with the purge valve open. We are free to stick with the simple, cheaper carburetor system, or use the fuel injection system of our choice, with or without a purge valve. Jim wants to err on the side of caution. I can't fault him for that. Another option is to simply build a fuel injected engine which uses the low compression 7.2 to 1 CR pistons. That means a 150 hp 320 cubic inch engine or a 168 hp 360 cubic inch engine. You may be able to run with 87 octane fuel OR you may need to stick with the higher octane 91/93 octane high test to avoid vapor lock. Some or all of this lost power can be reclaimed by the use of electronic ignition and tuned 4 into 1 exhaust systems. I think that a low compression, parallel valve 360 cubic inch engine utilizing fuel injection (with or without purge valve as operational experience dictates), single electronic ignition, tuned 4 into 1 exhaust using 87 octane fuel would be the miser's delight! :-) I "guesstimate" that such an engine would still produce 176 to 180 hp. Charlie Kuss > > >> What makes you think that FI engines can not use Mogas? If you > >> are referring to the angle valve 200 hp models, you are correct. >>However, any parallel valve engine (320, 360 or 540) using 7.2 to > >>1 or 8.5 to 1 pistons CAN use Mogas. Those engines using 8.5 to >1 >>pistons (160 hp 320s, 180 hp 360s and 230 hp 540s) will require > >>using premium (91 octane or better) Mogas. > >If one sticks with the spirit of the STCs, I found no fuel injected >engines listed as approved for auto gas. It could be that the fuel >injection system is more prone to vapor locking. I don't know. I >do know that I just looked at EAA's STC and found no engines >starting with IO- in the list. (I've always assumed IO means fuel >injected; so, correct me if I'm wrong. ) My list of engines from >Petersen is pretty old; but, it shows none, either. That doesn't >mean that the higher compression engines weren't shown, though. They >just need more octane, as I've said before. > >If one wants to experiment, which we all can do, one can use auto >gas in a fuel injected engine. However, I'm thinking there must >have been a good reason for FI engines not being in the STCs. I'm >betting it's the fact that auto gas tends to vapor lock faster than >100LL. If one runs auto gas over the top of a hot engine, would it >not be more prone to vapor locking? Could be. I'm not willing to >spend the money on a FI engine only to find out I can't use auto >gas, after all. It would be most embarrasing to be flying along and >have the engine quit due to vapor lock. Hmmmm. What would I tell >my passenger, if I can find one brave enough to ride with me? :-) > >> The 200 hp crowd is out of luck with Mogas. However, I suspect >> anyone willing to spend the extra money and sacrifice 20+ pounds > >> of payload (due to the added weight of the angle valve engine) >> don't really care about economy, like you and I. >> Fuel injection, electronic ignition, 4 into 1 tuned exhaust with >> mogas will yield the best economy. > >I hope Charlie is right. If enough of you guys are willing to take >the risk and run auto gas in FI engines, let us know how it's >working out. I may have to change my mind and buy a FI engine for >my current project. Otherwise, I guess I'll be a big chicken and go >with a carby. I figure I can suffer a little bit on fuel economy >and still be smiling every time I fill up my tanks with auto gas. :-) > >Jim Sears in KY >EAA Tech Counselor >(20 years of flying with auto gas) > > ________________________________________________________________________________
Date: Jun 13, 2006
Subject: Fuel Injection or Not
Sorry, I forgot to include the link regarding Peterson Aviation's auto fuel STCs in my earlier post. Here it is
http://www.webworksltd.com/autofuelstc/pa/ApprovedEngines.html Charlie red faced Kuss ________________________________________________________________________________
Date: Jun 13, 2006
I live in the Pacific NW. I'm going with fuel injection to get away from carb ice, better engine performance and because I can. I just like it better. Jim Bowen RV-8 QB >From: Ron Lee <ronlee(at)pcisys.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Fuel Injected - or Not >Date: Mon, 12 Jun 2006 13:21:15 -0600 > > >>So a question for all you old hands out there Is fuel injection really >>worth the extra several thousand bucks? Why or why not? >> >>Also, does anyone know of any document that shows an in depth analysis of >>why or why not? > >One benefit of Fuel Injection (FI) is the ability to run lean of peak. >That should >save fuel but I cannot show that it is worth the additional cost. > >A reported drawback of FI is hard starting under hot conditions (supposedly >after landing then starting a short time later). > >You did go with 180 HP which is good. Whether it makes sense to go for >more horsepower is another factor I cannot quantify. However, given that I >could get more horsepower for the same cost of FI personally I would go >for the horsepower. > >Ron Lee ________________________________________________________________________________
Date: Jun 13, 2006
Subject: Re: OSH Parking Comments
I'd like to add some to this excellent list as in the years before, the road to RV land and homebuild camping is a one-way street. We have to stop all traffic coming out when a plane goes in and vice versa. We have used the entry to the warbirds as a staging area to wait for planes to come out. If we point u towards the warbird area, please pull in the area and make a u turn (follow our signals), chances are there will be more planes waiting. We will get u going as soon as possible where u need to go. There is a defined pecking order of who goes first, Ford trimotor heads the parade, then warbirds, mostly P51s, finally all other, sorry that's the way it is. I second Wheeler's comment regarding signs, use the published signs and colors. it is very frustrating dealing with pilots who 'know' where they go because da's where they went for the past 20 years now. It is no fun getting close to propellors, shouting over the blast to find out what the pilot wants to do, only to get an earful because he/she is being stopped at each intersection. I am told every year that they don't need the notam........... Also, if the parking area fills up, becomes full, please don't argue with us that u want to park with the birds of a feather, we understand u want to. We will bend over backwards to get u in. However, take the space we point out to you, wander over to the area you want to park and talk to the orange vests in that area. we have had to sent planes to Fond Du Lac in the past, who argued and lost the last spot. Please don't plan your departure till the last moment before the airshow starts, any small hick-up in schedule will cause u to be shut down where u are that very moment till after the airshow. Fly save and have fun Gert Wheeler North wrote: > > Just a few reminders for all of you going to OSH this year. > > As someone who has spent a reasonable amount of time in an orange vest at > OSH and many other fly-ins remember the flight ain't over until the plane is > tied down. > > For the most part almost all airplane fatalities and injuries occur either > on, or very close to the ground. Oshkosh is no exception in spite of the > higher potential for mid air collisions. > > While I don't work in the homebuilt section I do park a lot of aircraft > during that two weeks in July. It is true that you are the pilot and it's > your job to not run into anything, but it's my job to keep things from > running into you. So if you don't like what you see, or you can see that I > don't like what I see then it's time to shut it down and have a chat about > it all. > > Fortunately airplanes aren't too hard to push and there's always a bunch of > volunteers that would love to help. > > For many the trip in seems kinda fast and hairy, but then it's over and you > are on the ground. Well, this is when the stress really begins. OSH is big > and usually hot, we are moving up 11000 airplanes on and off the field. > Typically there are pre-established routes that aren't very obvious to those > sitting in a cockpit, but the idea is to keep everyone on any taxiway going > the same direction. As such you may toodle around a bit for no apparent > reason kinda like an IFR flight. We realize that you are hot, that you need > to get out and clean your shorts, that a quart of ice cold rum would be just > the thing, but please bear with us. > > Have the signs as per the NOTAM, and print them out with a printer, bold, > landscape, 300pt Arial. Big letters with a ball point pen on a sectional > chart will get a nice laugh from many, but you will taxi around for a > while... I think it's the last page of the NOTAM has a great cheat sheet for > frequencies but once you are off the runway that will do nothing for you. > Depending on which runway you land on and where you are going you might see > up to 20 or so volunteers directing you over the course. The sooner each one > of them is able to recognize that three letter sign of yours, the sooner > they will get you on your way to the right location. > > As well, there are defined areas for parking various types of airplanes. > Just because it's empty and it is show center doesn't mean you get to park > there. And if you know Paul or Tom Poberezny, that's fine, we'll still park > you where we want and then you can have them come help you move your plane > to where they want it. Speaking of that, while we are willing to relocate > aircraft, we usually try to do it during the lulls. This often doesn't work > out though because lulls come and go. Be patient, we'll do our best to get > you there. > > Also, when departing, don't start your engine without an orange vested soul > nearby. As one who has seen airplanes collide into things at OSH it doesn't > matter whose fault it is, everyone is bummed and there are no winners. These > orange vested souls can be hard to find, particularly down in the homebuilt > area. If you are looking for something to do I suggest you volunteer and > wear a vest for a few tours. It will greatly expand your knowledge of the > ground operations there as well as get you a free glass of ice water and a > baloney and butter sandwich. > > Make sure you get a briefing before you depart and keep the brief sheet or > you will be stopped and briefed when you get to the runway. This is very > disconcerting to have happen just before takeoff and I have seen many pilots > have to abort because they got rattled and forgot something like a canopy > latch. This of course means they get back in line and do it all over again. > > And always remember, no matter how bad it gets, if they are wearing an > orange vest they aren't getting paid. Just like you, they are out there > trying to have a good time. They may not know everything so help them learn, > and help them help you. > > W > > > > > > > > -- ------------------------------------------------------------------- Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227, any and all nonsolicited commercial E-mail sent to this address is subject to a download and archival fee in the amount of $500 US. E-mailing denotes acceptance of these terms. -------------------------------------------------------------------- ________________________________________________________________________________
Subject: Re: Fuel Injected - or Not
Date: Jun 13, 2006
I have a carb and fly with a lot of different RV. The guys with Fuel Injection always burn less fuel than I do. It ranges from 0.5 GPH to 2.0 GPH less than I do to go the same speed. I have seen a 200 HP FI RV-7 fly on my wing doing Formation Check Ride maneuvers (Steep pitch and bank lazy 8 type maneuvers) and burn LESS fuel than I did flying lead with constant power (2,100 RPM / 22 IN-Hg). We both full at the begining of the day and then filled up at the end of the day only to see him buy 2 gallons less gas than I did. Yes the FI can sometimes be hard to start. There are more carb out there and I have seen as many problems with carbs as I have FI. Most of the FI problems that I have seen were because the owner / operator did NOT read the instruction manual and did not have it set up correctly. One carb problem went on for a year and end up being a bad float that had fuel in in it. One fuel injection problem was from a BAD fuel pump being replaced with the WRONG fuel pump. The difference in the up front cost when compared to the cost of entire airplane is small. Put in what YOU really want. I would like FI but do not want to stop flying long enough to install it. I would like to re-engine to a 180 and if / when I do, it will be FI. As for Auto Fuel, I do not want to spend the time transporting it. In the past 8.75 years of flying my RV, I have only been to ONE airport that had auto fuel. There was a video clip a few years back where someone fueling their RV with auto fuel had static electricity ignite the fuel and you could see the flames on the wing. They put the fire out before the airplane was damaged. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,869 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com >>So a question for all you old hands out there Is fuel injection really >>worth the extra several thousand bucks? Why or why not? >> ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Subject: Re: Fiberglass tips for tip up
Date: Jun 13, 2006
Hi to all Hate to change the subject (IFR or NOT)...........but I need some advice on the type of fiberglass / carbon cloth (Bi or Uni), and resin / hardner ( West Systems, Aero epoxy) types to start the fiberglass portion of the tip up canopy build. Best vendors would also be appreciated. I have searched the archives and google for info but need some more info to make the final choice. TIA Frank @ SGU and SLC Canopy and looking for $$$$$$$$$$$$$ to finish the project ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Jun 13, 2006
I used West Systems. I'd do it again. Larry in Indiana ----- Original Message ----- From: "Frank Stringham" <fstringham(at)hotmail.com> Sent: Tuesday, June 13, 2006 6:31 PM Subject: Re: RV-List: Fiberglass tips for tip up > > Hi to all > > Hate to change the subject (IFR or NOT)...........but I need some advice > on the type of fiberglass / carbon cloth (Bi or Uni), and resin / hardner > ( West Systems, Aero epoxy) types to start the fiberglass portion of the > tip up canopy build. Best vendors would also be appreciated. I have > searched the archives and google for info but need some more info to make > the final choice. > > TIA > > Frank @ SGU and SLC Canopy and looking for $$$$$$$$$$$$$ to finish the > project > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Subject: Tiedowns?
Date: Jun 13, 2006
Anybody remember who makes the titanium tiedowns? Albert Gardner Yuma, AZ ________________________________________________________________________________
Subject: RE: Kitfox for partial trade
Date: Jun 13, 2006
Jeff: I have a Kitfox 3 and thought I had a deal to trade it with money for a RV-4 but it fell thru. I'm still trying to get an RV. I have photos if interested. Randy 678-859-1861 >From: flamini2 <flamini2(at)comcast.net> >Reply-To: rv-list(at)matronics.com >To: "rv-list(at)matronics.com" >Subject: RV-List: Re: RV-6 Chicago area for sale >Date: Mon, 10 Apr 2006 07:15:20 -0500 > > >*RV-List message posted by: "Jeff Dowling" > > >What airport? > >Jeff, It's at C56 the old Sanger Airport about 25nm South of MDW (Midway >Chicago). >The airport was sold to Bult Corp. and will be closed 7/1/06 for new runway >and hangers >and the land is also being fought over by the third Chicago Airport people. >The registration is N405PP. >The owner, Paul Pressler is the builder and a true metal craftsman, you >should see his tools! >Dennis > > >----- Original Message ----- >From: "Dennis Flamini" <flamini2(at)comcast.net >> >To: > >Sent: Wednesday, April 05, 2006 9:03 PM >Subject: RV-6 Chicago area for sale > > >> > > > > For sale RV-6 tilt-up in Chicago area; > > Approx 300hrs TT > > 150hp not H2AD major OH at 0hrs > > Warnake wood prop > > Com, Transponder, GPS, Gyros, Intercom > > Perfect rivits, no bondo > > $50,000 firm > > You guys know the parts cost this much, you get 5 years labor for free! > > Call Paul at 708-534-3042 after 6pm > > see the photo section of;
May 30, 2006 - June 13, 2006
RV-Archive.digest.vol-rz
