RV-Archive.digest.vol-sb
July 02, 2006 - July 13, 2006
      > Always a major thrill on first flight.
      > Sounds like a governor setting needs work.
      > Good luck on the flight testing.
      > You only need 39.9 hours to get to Oshkosh :)
      > Kelly Patterson
      > N716K RV-6A PHX, AZ
      > 68 hrs & going to OSH
Date: Jul 02, 2006
Subject: mounting strobe power supply in RV-6/6A
I have the Whelen strobe power supply to run 3 strobes ( HDACF). It's got a mounting plate that is about 6" square. It weighs 2 Lbs. I want to mount it just behind the baggage bulkhead some where. First idea, to simply mount it to the belly skin was rejected. The skin's not braced enough. Putting a shelf of some sort from the central rib to the side skin seems like too large a run and gets in the way of accessing the elevator bell crank unless youplace it rather far aft. I'd like to keep it as far forward as possible. I could make a mounting "shelf" attached vertically to the aft side of the skin that screws to the baggage bulkhead, down low the lower corner. Problem there is you'd have to remove or diconnect the thing everytime you removed the skin. It's an easy installation, though, since you can work on the bench instead of int he plane. Another idea is to mount it oriented vertically on the side of the fuse, up high. One bracket attached to the bulkhead itself, the other to the skin. The skin's flat there. A piece of 1/16 angle 7" long rivetted vertically between the 2 J strips would be plenty solid and I think the skin is strong enough there. The baggage floor is rivetted down so that closes off some possibilities. If any one has some ideas or photos on a web site, I would be very appreciative. -- Tom Sargent, RV-6A ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Jul 02, 2006
Subject: Re: mounting strobe power supply in RV-6/6A
Obviously not a direct answer to your question, but why not mount it between the battery box and the fuel selector? Make a little shelf between two of the floor stringers and put it on the shelf. This is also a good location for your ELT, oxygen bottle, or fire extinguisher. KB ----- Original Message ----- Sent: Sunday, July 02, 2006 10:25 AM > > I have the Whelen strobe power supply to run 3 strobes ( HDACF). It's got > a mounting plate that is about 6" square. It weighs 2 Lbs. I want to > mount it just behind the baggage bulkhead some where. First idea, to > simply mount it to the belly skin was rejected. The skin's not braced > enough. > > Putting a shelf of some sort from the central rib to the side skin seems > like too large a run and gets in the way of accessing the elevator bell > crank unless youplace it rather far aft. I'd like to keep it as far > forward as possible. > > I could make a mounting "shelf" attached vertically to the aft side of the > skin that screws to the baggage bulkhead, down low the lower corner. > Problem there is you'd have to remove or diconnect the thing everytime you > removed the skin. It's an easy installation, though, since you can work > on the bench instead of int he plane. > > Another idea is to mount it oriented vertically on the side of the fuse, > up high. One bracket attached to the bulkhead itself, the other to the > skin. The skin's flat there. A piece of 1/16 angle 7" long rivetted > vertically between the 2 J strips would be plenty solid and I think the > skin is strong enough there. > > The baggage floor is rivetted down so that closes off some possibilities. > If any one has some ideas or photos on a web site, I would be very > appreciative. > -- > Tom Sargent, RV-6A > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 02, 2006
Here's what I did, I had it on my web site at one time but have since removed some of the older stuff: Strobe mount I ran conduits under my baggage floors to run wires. My new email address: bobbyhester(at)charter.net Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A N857BH SB wings-QB Fuse-XPO360 engine :-) sarg314 wrote: > > I have the Whelen strobe power supply to run 3 strobes ( HDACF). It's > got a mounting plate that is about 6" square. It weighs 2 Lbs. I want > to mount it just behind the baggage bulkhead some where. First idea, > to simply mount it to the belly skin was rejected. The skin's not > braced enough. > > Putting a shelf of some sort from the central rib to the side skin > seems like too large a run and gets in the way of accessing the > elevator bell crank unless youplace it rather far aft. I'd like to > keep it as far forward as possible. > > I could make a mounting "shelf" attached vertically to the aft side of > the skin that screws to the baggage bulkhead, down low the lower > corner. Problem there is you'd have to remove or diconnect the thing > everytime you removed the skin. It's an easy installation, though, > since you can work on the bench instead of int he plane. > > Another idea is to mount it oriented vertically on the side of the > fuse, up high. One bracket attached to the bulkhead itself, the > other to the skin. The skin's flat there. A piece of 1/16 angle 7" > long rivetted vertically between the 2 J strips would be plenty solid > and I think the skin is strong enough there. > > The baggage floor is rivetted down so that closes off some possibilities. > If any one has some ideas or photos on a web site, I would be very > appreciative. > -- > Tom Sargent, RV-6A > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Jul 02, 2006
Tom, I used screws instead of rivets to fasten down my right side baggage floor. I added two stiffeners to the floor panel between the ribs and mounted the power supply upside below the baggage floor. Whelen said it can be mounted any direction and cooling was not a factor. Also, I have no strobe noise in the headsets, even with the comm antenna on the belly under the seats. Mike Hilger RV-6 N207AM 760 hrs ________________________________________________________________________________
Date: Jul 02, 2006
Kyle: Yes, that's a good location, functionally, but likely to get kicked. I'd want to make some sort of cover for it (there's 5000v in one of those wires). Besides, I plan on putting the fire extinguisher there. Also, the wires from the strobe supply have to end up on the aft side of the wing spar, so it's convenient if they start out on the aft side of the wing spar to begin with. That ay only the power & ground wires cross the spar. Kyle Boatright wrote: > > Obviously not a direct answer to your question, but why not mount it > between the battery box and the fuel selector? Make a little shelf > between two of the floor stringers and put it on the shelf. This is > also a good location for your ELT, oxygen bottle, or fire extinguisher. > > KB > ----- Original Message ----- Sent: Sunday, July 02, 2006 10:25 AM > > >> >> I have the Whelen strobe power supply to run 3 strobes ( HDACF). >> It's got a mounting plate that is about 6" square. It weighs 2 Lbs. >> I want to mount it just behind the baggage bulkhead some where. > ________________________________________________________________________________
Date: Jul 02, 2006
I would caution you on putting your strobe power supply in a location near to anything that may leak fuel... Strobe power supplies send very high voltage to the strobe heads and it would make for a very bad day if for some reason your fuel selector should happen to leak on the connections to the strobe heads... Just an FYI... -Bill VonDane RV-8A ~ N8WV Colorado Springs, CO www.rv8a.com ----- Original Message ----- Sent: Sunday, July 02, 2006 8:54 AM Obviously not a direct answer to your question, but why not mount it between the battery box and the fuel selector? Make a little shelf between two of the floor stringers and put it on the shelf. This is also a good location for your ELT, oxygen bottle, or fire extinguisher. KB ----- Original Message ----- Sent: Sunday, July 02, 2006 10:25 AM > > I have the Whelen strobe power supply to run 3 strobes ( HDACF). It's got > a mounting plate that is about 6" square. It weighs 2 Lbs. I want to > mount it just behind the baggage bulkhead some where. First idea, to > simply mount it to the belly skin was rejected. The skin's not braced > enough. > > Putting a shelf of some sort from the central rib to the side skin seems > like too large a run and gets in the way of accessing the elevator bell > crank unless youplace it rather far aft. I'd like to keep it as far > forward as possible. > > I could make a mounting "shelf" attached vertically to the aft side of the > skin that screws to the baggage bulkhead, down low the lower corner. > Problem there is you'd have to remove or diconnect the thing everytime you > removed the skin. It's an easy installation, though, since you can work > on the bench instead of int he plane. > > Another idea is to mount it oriented vertically on the side of the fuse, > up high. One bracket attached to the bulkhead itself, the other to the > skin. The skin's flat there. A piece of 1/16 angle 7" long rivetted > vertically between the 2 J strips would be plenty solid and I think the > skin is strong enough there. > > The baggage floor is rivetted down so that closes off some possibilities. > If any one has some ideas or photos on a web site, I would be very > appreciative. > -- > Tom Sargent, RV-6A > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Jul 02, 2006
Tom, My RV sports two Whelen power supplies, and I mounted a unit to each outboard wing rib. In your case, perhaps it is advantageous to mount your single unit to the right wing given that side is usually built a bit lighter than the left wing if your landing light and pitot installation is located on the left wing. The photo illustrates my installation technique on the right wing. As shown, the wing tip rests atop the wing showing the internally mounted VOR antenna bolted inside the tip. http://img373.imageshack.us/img373/2518/img0004457xa.jpg Rick Galati RV-6A "Darla" 145 hours sarg314(at)comcast.net wrote: > I have the Whelen strobe power supply to run 3 strobes ( HDACF). It's > got a mounting plate that is about 6" square. It weighs 2 Lbs. I want > to mount it just behind the baggage bulkhead some where. First idea, to > simply mount it to the belly skin was rejected. The skin's not braced > enough. > > Putting a shelf of some sort from the central rib to the side skin > seems like too large a run and gets in the way of accessing the elevator > bell crank unless youplace it rather far aft. I'd like to keep it as > far forward as possible. > > I could make a mounting "shelf" attached vertically to the aft side of > the skin that screws to the baggage bulkhead, down low the lower > corner. Problem there is you'd have to remove or diconnect the thing > everytime you removed the skin. It's an easy installation, though, > since you can work on the bench instead of int he plane. > > Another idea is to mount it oriented vertically on the side of the > fuse, up high. One bracket attached to the bulkhead itself, the other > to the skin. The skin's flat there. A piece of 1/16 angle 7" long > rivetted vertically between the 2 J strips would be plenty solid and I > think the skin is strong enough there. > > The baggage floor is rivetted down so that closes off some possibilities. > > If any one has some ideas or photos on a web site, I would be very > appreciative. > -- > Tom Sargent, RV-6A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=44386#44386 ________________________________________________________________________________
Date: Jul 02, 2006
Subject: CHT mounting sockets
I'm getting around to wiring up the CHT's and there is a male socket that screws into the head to hold the probe. Does this fitting require Teflon on the threads that screw into the head? Jim Nelson RV9-A FWF ________________________________________________________________________________
Date: Jul 02, 2006
No, but some spark plug anti-seize compound might be a good idea. Bruce www.glasair.org -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James H Nelson Sent: Sunday, July 02, 2006 3:19 PM I'm getting around to wiring up the CHT's and there is a male socket that screws into the head to hold the probe. Does this fitting require Teflon on the threads that screw into the head? Jim Nelson RV9-A FWF ________________________________________________________________________________
Date: Jul 02, 2006
Subject: Fwd: MOGAS Use With FI Engines
-----Original Message----- There was some discussion several weeks back re use of MOGAS with fuel injected engines. I expect to be finished with the fuselage by the end of the year and am considering various engine options. I called Superior on Monday and was told that their XP360 fuel injected engines with 7.2/1 or 8.5/1 pistons will run very happily on MOGAS, 87 octane (non-ethanol) and 91 octane(non-ethanol) respectively. However, the 200 HP version (FI of course) of that engine does require 100LL avgas. The 7.2/1 version is not terribly popular and it does cost an extra $100. I'm leaning toward the 8.5/1 version with the fuel injection. Dan Bergeron Chicopee, MA RV-7A N307TB (reserved) (Turned the canoe over on 6/25 and am moving out smartly.) ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 02, 2006
Tom, I mounted mine to the bottom rear of the baggage bulkhead and it's never been a problem. Removing it is as simple as disconnecting a few plugs. It was the simplest and lightest way to mount it and I'd do it the same way again. Dave sarg314 wrote: > > I have the Whelen strobe power supply to run 3 strobes ( HDACF). It's > got a mounting plate that is about 6" square. It weighs 2 Lbs. I want > to mount it just behind the baggage bulkhead some where. First idea, > to simply mount it to the belly skin was rejected. The skin's not > braced enough. > > Putting a shelf of some sort from the central rib to the side skin > seems like too large a run and gets in the way of accessing the > elevator bell crank unless youplace it rather far aft. I'd like to > keep it as far forward as possible. > > I could make a mounting "shelf" attached vertically to the aft side of > the skin that screws to the baggage bulkhead, down low the lower > corner. Problem there is you'd have to remove or diconnect the thing > everytime you removed the skin. It's an easy installation, though, > since you can work on the bench instead of int he plane. > > Another idea is to mount it oriented vertically on the side of the > fuse, up high. One bracket attached to the bulkhead itself, the > other to the skin. The skin's flat there. A piece of 1/16 angle 7" > long rivetted vertically between the 2 J strips would be plenty solid > and I think the skin is strong enough there. > > The baggage floor is rivetted down so that closes off some possibilities. > If any one has some ideas or photos on a web site, I would be very > appreciative. > -- > Tom Sargent, RV-6A > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > ________________________________________________________________________________
Date: Jul 02, 2006
Mine went on the aft side of the baggage bulkhead, slightly left of center and just below the seam between the two halves of the bulkhead . It has worked well. Now that I have done many inspections, mods and maintenance I would recommend putting it on the top half bulkhead. Reason being that I have not had the need to remove that one in the last several years. There fore I would not have to unplug the power wires each time I take off the bulkhead for inspections etc. I also like Bobby Hester picture, since that belly skin is an oil canner and those rails should stiffen them up a bit! Denis Walsh On Jul 2, 2006, at 07:25 303180007, sarg314 wrote: > > I have the Whelen strobe power supply to run 3 strobes ( HDACF). > It's got a mounting plate that is about 6" square. It weighs 2 > Lbs. I want to mount it just behind the baggage bulkhead some > where. First idea, to simply mount it to the belly skin was > rejected. The skin's not braced enough. > > Putting a shelf of some sort from the central rib to the side skin > seems like too large a run and gets in the way of accessing the > elevator bell crank unless youplace it rather far aft. I'd like to > keep it as far forward as possible. > > I could make a mounting "shelf" attached vertically to the aft side > of the skin that screws to the baggage bulkhead, down low the lower > corner. Problem there is you'd have to remove or diconnect the > thing everytime you removed the skin. It's an easy installation, > though, since you can work on the bench instead of int he plane. > > Another idea is to mount it oriented vertically on the side of the > fuse, up high. One bracket attached to the bulkhead itself, the > other to the skin. The skin's flat there. A piece of 1/16 angle > 7" long rivetted vertically between the 2 J strips would be plenty > solid and I think the skin is strong enough there. > > The baggage floor is rivetted down so that closes off some > possibilities. > If any one has some ideas or photos on a web site, I would be very > appreciative. > -- > Tom Sargent, RV-6A > > > www.matronics.com/Navigator?RV-List > wiki.matronics.com > > ________________________________________________________________________________
Date: Jul 02, 2006
Subject: Re: Fwd: MOGAS Use With FI Engines
>There was some discussion several weeks back re use of MOGAS with fuel >injected engines. I expect to be finished with the fuselage by the end of >the year and am considering various engine options. I called Superior on >Monday and was told that their XP360 fuel injected engines with 7.2/1 or >8.5/1 pistons will run very happily on MOGAS, 87 octane (non-ethanol) >and 91 octane(non-ethanol) respectively. However, the 200 HP version (FI >of course) of that engine does require 100LL avgas. The 7.2/1 version is >not terribly popular and it does cost an extra $100. >I'm leaning toward the 8.5/1 version with the fuel injection. Note the important "non-ethanol" caveat. What will you do if most auto fuels are ethanol enhanced? In the great Tim Allen tradition, I would give consideration to 200 HP and not worry about auto fuel. Tis your ultimate choice. For those who fly a lot, how many people bother with auto fuel? I for one do not and have no desire to. Ron Lee ________________________________________________________________________________
Date: Jul 02, 2006
Hmmm, I don't think that will help with oil canning. It looks as if the rails are suspended on each end at the bulkheads and not in contact with the skin. I bought another rib from Van's - the one that the elevator bellcrank is mounted to (sorry I don't have the part # at my fingertips) and fit it parallel to the existing one and made a sort of avionics deck. Things wound up crowded and I mounted on the side of it. That black thing at the aft end is a remote compass sensor which I'll probably end up not using. Pax, Ed Holyoke >I also like Bobby Hester picture, since that belly skin is an oil canner and those rails should stiffen them up a bit! Denis Walsh On Jul 2, 2006, at 07:25 303180007, sarg314 wrote: > > I have the Whelen strobe power supply to run 3 strobes ( HDACF). > It's got a mounting plate that is about 6" square. It weighs 2 > Lbs. I want to mount it just behind the baggage bulkhead some > where. First idea, to simply mount it to the belly skin was > rejected. The skin's not braced enough. ________________________________________________________________________________
Date: Jul 02, 2006
Subject: Re: N161RL Flies
Congratulations, Mannan - what a magnificant achievement! I sympathise about the minor setback - it feels like a big thing at the time, but I've learned that each snag is just another step in the process. You can fix it and fly on. Remember a few weeks back you thought the project was finished? :) Shirley Harding RV6 - failed alternator, damaged ring gear (twice), heavy left wing, radio probs - all in the first 10 hours! The ammeter seems to be working backwards too - but the aircraft is thrilling to fly! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=44464#44464 ________________________________________________________________________________
Date: Jul 02, 2006
At 17:00 2006-07-02, you wrote: > > >>There was some discussion several weeks back re use of MOGAS with >>fuel injected engines. I expect to be finished with the fuselage >>by the end of the year and am considering various engine >>options. I called Superior on Monday and was told that their XP360 >>fuel injected engines with 7.2/1 or 8.5/1 pistons will run very >>happily on MOGAS, 87 octane (non-ethanol) and 91 >>octane(non-ethanol) respectively. However, the 200 HP version (FI >>of course) of that engine does require 100LL avgas. The 7.2/1 >>version is not terribly popular and it does cost an extra $100. >>I'm leaning toward the 8.5/1 version with the fuel injection. > > >Note the important "non-ethanol" caveat. What will you do if most auto fuels >are ethanol enhanced? In the great Tim Allen tradition, I would >give consideration >to 200 HP and not worry about auto fuel. Tis your ultimate choice. > >For those who fly a lot, how many people bother with auto fuel? I for one >do not and have no desire to. > >Ron Lee MOGAS is all I use unless I fill up somewhere away from home and it's not available. I have no reason to pay $4 /gal when I can fly on $3 / gal. Mike McGee, RV-4 N996RV, O320-E2G, Hillsboro, OR ________________________________________________________________________________
From: "sheldon barrett" <sheldonb(at)frontiernet.net>
Date: Jul 03, 2006
Ed, Just some information for you... I have the AK-450 ELT as you do... The mount for the mounting strap broke (at around 300 hours)... Not sure why, but might be from unhooking it and re hooking at battery change times or from viberation... you might think of beefing this up... for if it came loose back there... not good...! Sheldon RV6A 400 hrs ----- Original Message ----- From: Ed Holyoke To: rv-list(at)matronics.com Sent: Sunday, July 02, 2006 5:55 PM Subject: RE: RV-List: mounting strobe power supply in RV-6/6A Hmmm, I don't think that will help with oil canning. It looks as if the rails are suspended on each end at the bulkheads and not in contact with the skin. I bought another rib from Van's - the one that the elevator bellcrank is mounted to (sorry I don't have the part # at my fingertips) and fit it parallel to the existing one and made a sort of avionics deck. Things wound up crowded and I mounted on the side of it. That black thing at the aft end is a remote compass sensor which I'll probably end up not using. Pax, Ed Holyoke >I also like Bobby Hester picture, since that belly skin is an oil canner and those rails should stiffen them up a bit! Denis Walsh On Jul 2, 2006, at 07:25 303180007, sarg314 wrote: > > I have the Whelen strobe power supply to run 3 strobes ( HDACF). > It's got a mounting plate that is about 6" square. It weighs 2 > Lbs. I want to mount it just behind the baggage bulkhead some > where. First idea, to simply mount it to the belly skin was > rejected. The skin's not braced enough. ________________________________________________________________________________
Date: Jul 03, 2006
Subject: N161RL Flies
Mannan, Congratulations on getting in the air. Good Luck with the phase 1! Doug Bell N266WB RV8 Manistee, MI ________________________________________________________________________________
Date: Jul 03, 2006
Subject: Tools for Sale
Unless it says 'Spruce' the prices were compared with Avery. All tools are 'used' but in excellent condition. Tools for Sale 1-Avery =98C=99 Frame =93$165 2=93US Rivet gun #TP82 Spruce price $252 3=93US Rivet gun #TP83 Spruce price $205 4=93Back rivet set $22 5=937 misc rivet sets for pneumatic gun $6 to $9 ea (approx $40) 6=93Mushroom Swivel Set - $39 7=93Flush Set with Guard $18 8=936 misc Mushroom Flush Sets $7 to $14 ea (approx $40) 9=93Rivet length gauge $7 10=93Shop Head Gauge set of 4 $7 11=93Edge Rolling tool (I have 2) Spruce price $15ea = $30 total 12-3 size Tubing Bender Spruce price $31 13=932 pair of Fluting Pliers Spruce price $16.50ea = $33 total 14=93Die Grinder =93 Spruce Price $42 15=93Snips =93 Left hand Spruce Price $17.50 16-Snips =93 Right hand Spruce Price $17.50 17-Snips =93 Straight Cut Spruce Price $17.50 (2ea) = $35 total 18=93Cleco Pliers - $4.95 19=933 Drill Stops various sizes $.95 ea = $2.85 total 20=93Clecos =93 3/32 Silver (300ea) $.38ea = $114 total 21=93Clecos =93 1/8 Copper (100ea) $.38ea = $38 total 22=93Clecos =93 5/32 Black (14ea) $.38ea = $5.32 total 23=93Clecos =93 3/16 Brass (55ea) $.38ea = $20.90 total 24=9324 Wing Nut Clecos 1/4" $3ea = $72 total 25=9318 Side Grip Cleco type clamps (long style) $2.50ea =$45 total 26=93Rivet Cutter Spruce price $12.95 27-Instrument Cutout Template Spruce price =93 $9.95 28-Bolt Gauge - Free 29-Drill Gauge =93 Free 30-High Speed Debur Tool w/extension =93 Spruce price $22.95 31-2 Plate Nut jigs 3/32 & 1/18 =93 $5ea (not sure of price) = $10 total 32-Safety Wire Twister Pliers - Spruce price $22.95 33-NEW in box 2ea ISSPRO R8790 2=9D Fuel Gauges (unknown price so $50 for the pair) 34-NEW in box Mitchell Volt Meter 2=9D Spruce price $43.95 35- Micromesh plexi kit (box opened and may have been used???) Spruce price $17.95 make offer Total comes to about $1,488.87 for =98new=99 stuff. I=99m not 100% positive on all the above prices and I=99d like to sell everything together if po ssible. That said..I'll take $850 for EVERYTHING on the list..I =99ll box it up and you pay the shipping. Obviously you may not need/want everything but I figure y ou can always pass on to someone else what you don't want/need and make out OK with the price I'm offering. If you're interested give me a buzz and we'll work it out....these tools ar e just taking up space in my garage :^). If you aren=99t happy when you get the stuff then send EVERYTHING back at your cost and I=99ll refund you in full. Rick Gray in Ohio at the Buffalo Farm - _rgray67968(at)aol.com_ (mailto:rgray67968(at)aol.com) or H740.678.8031 ________________________________________________________________________________
Date: Jul 03, 2006
Subject: Re strobe PS mounting
Probably already got info, but I mounted mine on the lowere inside back of the psgr seat, Charlie Heathco ________________________________________________________________________________
Date: Jul 03, 2006
Subject: Mogas and corn liquir
Well, yes, lots more of us use Mogas than one would think. I knew several cherokee drivers using it for years, and i saw a guy fill up his 152 with it at Drake the other dqay. Drake FYV is the only place I have run across selling on the firld. I plan to fill my pickup there today as it has been $2.85 for some time and local gas at cheapest place has gone up to $2.93 in last fe days. The big argument re mogs has been that it ruins gaskets and such, but I have seen no evidence of this and the argument that 100ll is a lubricant is just plane false. One thing for sure, it fouwls the plugs. The engine I just installed in my 6a had one plug full of LL to the point that I dont see how it could have been firing. Charlei Heathco ________________________________________________________________________________
Date: Jul 03, 2006
Subject: Drilling exhaust for EGT
Fellow listers, I'm getting ready to drill into my Vetterman exhaust to install the EGT transducers for my VM1000 engine monitor. I've already got some of the CHT transducers wired and working so I think I have my transducer wiring technique working. Other than drilling them the same distance down from the head mounting flange and staying away from the spark plugs, I haven't been able to find any info on the best place to drill the holes. Even though straight outboard looks like a great place to put them - I'm wondering about the cowl (I have a Sam James Cowl). Anyone out there have any photos of what worked well for them? Kinda scary - drilling holes in an exhaust system...don't they leak? Thanks, Ralph Capen RV6A N822AR @ N06 Wiring firewall foreward ________________________________________________________________________________
Date: Jul 03, 2006
Date: Jul 03, 2006
Subject: Inspirational First Flight Video
For those still 'pounding those rivets' or for those who are getting close and need an 'inspirational boost', my first flight video, professional videographed and edited by Jay Hagwell, Van Nuys, CA at www.yudavision.com on 3/17/2005 (St. Patrick's Day) has surpassed the 100,000 mark as times being viewed.) Pretty spectacular number of viewings considering this is an experimental, homebuilt, RV, First Flight Video. The 'infamous' Dan Checkoway (Kitplanes writer/contributor and friend) was the chase pilot and flew the videographer during the event. (Thanks again Dan!.....). It really is a wonderful, inspiring video with incredible editing that has been viewed from people from all over the world (India, New Zealand, Australia, Figi, South America, the great USA and others). If you need a 'boost' or would like to view a first flight video done professionally, check it out: (Click on the link below) http://www.jacklockamy.com/N174JL_First_Flight_Video.wmv Contact Jay Hagwell at www.yudavision.com if you would like to document your first flight.... Of all the comments I receive, it is the upholstery from Abby at Flightline Interiors that most stands out. She did a MARVELOUS job and I sincerely thank her! She is an 'angel' to work with and produces the nicest interior for RV's out there (my humble opinion of course...). You can check out her upholstery package for an RV-7/7A here: (Click on the link below to view some of her work: http://www.jacklockamy.com/RV-7A.html Thank you to the RV community for all your help and support during the construction and subsequent flight testing/flights. Who knows, there may just be an RV-10 in my future... :-). I LOVE Building these kits from Van's Aircraft. This is my third homebuilt and I think a fourth may be in order. Jack Lockamy Camarillo, CA www,jacklockamy.com N174JL RV-7A 190 HRS ________________________________________________________________________________
Date: Jul 03, 2006
Subject: Re: Inspirational First Flight Video
ooops... link to professional videographer should have been: www.Yudavision.net ( not www.yudavision.com). Jack ----- Original Message ----- From: JACK LOCKAMY To: RV List Sent: Monday, July 03, 2006 2:08 PM Subject: Inspirational First Flight Video For those still 'pounding those rivets' or for those who are getting close and need an 'inspirational boost', my first flight video, professional videographed and edited by Jay Hagwell, Van Nuys, CA at www.yudavision.com on 3/17/2005 (St. Patrick's Day) has surpassed the 100,000 mark as times being viewed.) Pretty spectacular number of viewings considering this is an experimental, homebuilt, RV, First Flight Video. The 'infamous' Dan Checkoway (Kitplanes writer/contributor and friend) was the chase pilot and flew the videographer during the event. (Thanks again Dan!.....). It really is a wonderful, inspiring video with incredible editing that has been viewed from people from all over the world (India, New Zealand, Australia, Figi, South America, the great USA and others). If you need a 'boost' or would like to view a first flight video done professionally, check it out: (Click on the link below) http://www.jacklockamy.com/N174JL_First_Flight_Video.wmv Contact Jay Hagwell at www.yudavision.com if you would like to document your first flight.... Of all the comments I receive, it is the upholstery from Abby at Flightline Interiors that most stands out. She did a MARVELOUS job and I sincerely thank her! She is an 'angel' to work with and produces the nicest interior for RV's out there (my humble opinion of course...). You can check out her upholstery package for an RV-7/7A here: (Click on the link below to view some of her work: http://www.jacklockamy.com/RV-7A.html Thank you to the RV community for all your help and support during the construction and subsequent flight testing/flights. Who knows, there may just be an RV-10 in my future... :-). I LOVE Building these kits from Van's Aircraft. This is my third homebuilt and I think a fourth may be in order. Jack Lockamy Camarillo, CA www,jacklockamy.com N174JL RV-7A 190 HRS ________________________________________________________________________________
Date: Jul 03, 2006
Ralph, I think straight out would interfere with your cowl. Remember too that the wires won't want to make a sharp 90 degree bend at the end of the transducer. I feel like I lucked out with mine, not realizing how the lower plugs were going to protrude. Mine sweep back on the outside, maybe 45 degrees instead of 90 degrees. I think I have seen some turned in somewhat towards the engine which kept the wires from the transducers more out of the way. Hopefully someone else will give you a better answer. Terry RV-8A finishing? Seattle -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Monday, July 03, 2006 1:50 PM Fellow listers, I'm getting ready to drill into my Vetterman exhaust to install the EGT transducers for my VM1000 engine monitor. I've already got some of the CHT transducers wired and working so I think I have my transducer wiring technique working. Other than drilling them the same distance down from the head mounting flange and staying away from the spark plugs, I haven't been able to find any info on the best place to drill the holes. Even though straight outboard looks like a great place to put them - I'm wondering about the cowl (I have a Sam James Cowl). Anyone out there have any photos of what worked well for them? Kinda scary - drilling holes in an exhaust system...don't they leak? Thanks, Ralph Capen RV6A N822AR @ N06 Wiring firewall foreward ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Jul 03, 2006
Subject: Re: Drilling exhaust for EGT
You will not want to drill them at a 90 degree bearing to your longitudinal plane. Rather, you want to drill them more on a 45 degree angling back toward the rear of the engine. You can angle them toward the outside/cowling or the inside. I did mine toward the outside because I could drill it with the exhaust system installed on the engine. It works fine. It would however probably be a cleaner install to drill the angle toward the center of the rear of the engine on about a 45 degree angle but that would require careful marking and exhaust removal and reinstall unless you have a nice tight fit angle drill. That inside route would remove any chance of interference with the cowling. The exhaust system will be tight with a properly installed sensor and will not leak. Larry in Indiana ----- Original Message ----- > > Fellow listers, > > I'm getting ready to drill into my Vetterman exhaust to install the EGT > transducers > for my VM1000 engine monitor. > > I've already got some of the CHT transducers wired and working so I think > I have > my transducer wiring technique working. > > Other than drilling them the same distance down from the head mounting > flange and > staying away from the spark plugs, I haven't been able to find any info on > the best > place to drill the holes. Even though straight outboard looks like a > great place > to put them - I'm wondering about the cowl (I have a Sam James Cowl). > > Anyone out there have any photos of what worked well for them? > > Kinda scary - drilling holes in an exhaust system...don't they leak? > > Thanks, > Ralph Capen > RV6A N822AR @ N06 Wiring firewall foreward > > > ________________________________________________________________________________
Date: Jul 03, 2006
Subject: How to turn an RV-9A fuse over?
I am at the point of having the lower half of the 9A fuse riveted and/or clecoed together. It is currently upside down and I need to turn it 90 degrees so I can rivet the floor stiffeners on. It now weighs enough that it takes two men and a boy to lift and turn it. And I will be needing to install all kinds of plumbing, wiring etc. and I would like to be able to turn it by myself. I am thinking that there must be a better way than to simply man handle it with three men. Does anybody out there have an solution? Thanks in advance, David (Doc) Custer ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Date: Jul 03, 2006
Doc Check out www.jeffsrv-7a.com Jeff has a great stand tro rotate the fuse Frank @ SGU and SLC >From: "Doc Custer" <ddcuster@wmv-co.us> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: How to turn an RV-9A fuse over? >Date: Mon, 3 Jul 2006 17:51:59 -0600 > >I am at the point of having the lower half of the 9A fuse riveted and/or >clecoed together. It is currently upside down and I need to turn it 90 >degrees so I can rivet the floor stiffeners on. It now weighs enough that >it takes two men and a boy to lift and turn it. And I will be needing to >install all kinds of plumbing, wiring etc. and I would like to be able to >turn it by myself. > >I am thinking that there must be a better way than to simply man handle it >with three men. > >Does anybody out there have an solution? > >Thanks in advance, > >David (Doc) Custer ________________________________________________________________________________
Date: Jul 03, 2006
Subject: Re: How to turn an RV-9A fuse over?
FWIW, when I was at that point, I just left the fuselage the way it was. I had my wife stand up on a step stool and shoot the floor stiffener rivets pointing the gun down. I was underneath in the fuse bucking the rivets. The clecos held the stiffeners up onto the floor just fine. I'd say don't move the thing if you don't have to! )_( Dan RV-7 N714D (966 hours) http://www.rvproject.com ----- Original Message ----- From: Doc Custer To: rv-list(at)matronics.com Sent: Monday, July 03, 2006 4:51 PM Subject: RV-List: How to turn an RV-9A fuse over? I am at the point of having the lower half of the 9A fuse riveted and/or clecoed together. It is currently upside down and I need to turn it 90 degrees so I can rivet the floor stiffeners on. It now weighs enough that it takes two men and a boy to lift and turn it. And I will be needing to install all kinds of plumbing, wiring etc. and I would like to be able to turn it by myself. I am thinking that there must be a better way than to simply man handle it with three men. Does anybody out there have an solution? Thanks in advance, David (Doc) Custer ________________________________________________________________________________
Date: Jul 03, 2006
In a message dated 7/3/2006 4:47:54 P.M. Pacific Daylight Time, lhelming(at)sigecom.net writes: Would someone please point us to a reputable reference that authenticates it requires more fossil energy fuel to produce ethanol energy than we get back? How can that make sense if oil is in short supply? Why waste .3 gallons of it? =============================== Here's a good factual article not written by ADM. _http://www.businessweek.com/technology/content/may2006/tc20060519_225336.htm_ (http://www.businessweek.com/technology/content/may2006/tc20060519_225336.htm) GV (RV-6A N1GV O-360-A1A, C/S, Flying 799hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 03, 2006
Hi David, If your workplace ceiling is low enough and you don't mind screwing some fairly robust hooks into it; I turned my 6-A over alone. I used two hooks in the ceiling and four nylon ratchet type cargo straps. link two straps together making a big loop repeat with the remaining straps. loop both sets of straps around the fuse then up to the hooks in the ceiling. tighten the straps till the fuse clears the jig, table or stand. It will rotate quite easily suspended this way. I used the same straps when putting the gear on etc. Later on in the build I used an engine stand adapted to the firewall and an hight adjustable rear pivot stand to support the fuse while installing the floors etc. I made the stands tall enough to allow full rotation with the slider windshield roll over bar temporarily place. This allowed me to work sitting on a low stool while finishing the floors etc. For me this was much better than bending over and reaching down to get the various jobs done. Keep on building, Jim in Kelowna - Weight and balance and brake bleeding. ----- Original Message ----- From: Doc Custer To: rv-list(at)matronics.com Sent: Monday, July 03, 2006 4:51 PM Subject: RV-List: How to turn an RV-9A fuse over? I am at the point of having the lower half of the 9A fuse riveted and/or clecoed together. It is currently upside down and I need to turn it 90 degrees so I can rivet the floor stiffeners on. It now weighs enough that it takes two men and a boy to lift and turn it. And I will be needing to install all kinds of plumbing, wiring etc. and I would like to be able to turn it by myself. I am thinking that there must be a better way than to simply man handle it with three men. Does anybody out there have an solution? Thanks in advance, David (Doc) Custer ________________________________________________________________________________
Date: Jul 03, 2006
In a message dated 7/3/06 4:44:39 PM Eastern Daylight Time, recapen(at)earthlink.net writes: > I haven't been able to find any info on the best place to drill the holes. > Even though straight outboard looks like a great place to put them - I'm > wondering about the cowl (I have a Sam James Cowl). > > Anyone out there have any photos of what worked well for them? > > Kinda scary - drilling holes in an exhaust system...don't they leak? > > Thanks, > Ralph Capen > RV6A N822AR @ N06 Wiring firewall foreward =============================== Ralph: You have to look at EVERYTHING! What will be blocked - Manifold Nuts & Bolts Cowling - Well you know that Where the strap will be when it is fully tightened. Service loop on the probe wires NO strain on any of the wires Distance down from the face of the exhaust flange. [Remember EGT & CHT are only reference values. Of course CHT is a bit more accurate as long as you don use Ring or Bayonet Thermocouples. EGT is way too variable. The numbers you get are YOUR numbers and no one else's. As the disclaimer goes YMMV.] I believe all mine are on a 45 Deg angle. Barry "Chop'd Liver" ________________________________________________________________________________
Date: Jul 03, 2006
Subject: Re: Fwd: MOGAS Use With FI Engines was Fuel Injected
>Subject: MOGAS Use With FI Engines > >There was some discussion several weeks back re use of MOGAS with >fuel injected engines. I expect to be finished with the fuselage by >the end of the year and am considering various engine options. I >called Superior on Monday and was told that their XP360 fuel >injected engines with 7.2/1 or 8.5/1 pistons will run very happily >on MOGAS, 87 octane (non-ethanol) and 91 octane(non-ethanol) >respectively. However, the 200 HP version (FI of course) of that >engine does require 100LL avgas. The 7.2/1 version is not terribly >popular and it does cost an extra $100. >I'm leaning toward the 8.5/1 version with the fuel injection. > > >Dan Bergeron >Chicopee, MA >RV-7A N307TB (reserved) >(Turned the canoe over on 6/25 and am moving out smartly.) Dan, I was one of the listers in on that discussion. I called the EAA and spoke to a woman regarding their STCs. They only attempted to obtain STCs for low compression (7.2 to 1) engines. They made no effort to obtain auto fuel STCs for 8.5 to 1 or higher compression engines. I reported this to the list on June 13th. I called Peterson Aviation that same day, but their technical expert was out of town. I called back and spoke to him on June 29th at length. He was quite helpful. He stated that Peterson had attempted to obtain STCs for 91 octane (minimum) auto fuel for various fuel injected engines. They had success with a number of aircraft with Continental engines/fuel injection. Every Lycoming based aircraft failed. These tests were done over 20 years ago, and they have never revisited this issue since. He told me that the testing was done to "worst case scenario". At that time, the Reid Vapor Pressure of aircraft fuel was no higher than 6.5 (lower is better). Common auto fuel could range from 7 to 15. The highest Reid Vapor Pressure numbers were "winter blend" fuels designed to aid in vaporization of fuel in the northern US and Canada, where temperatures can drop to -20 F and below. The engine/airframe combination had to pass all the tests using "worst case" fuel (ie 14-15 Reid Vapor pressure) Due to various "clean air" enactments, auto fuel Reid Vapor Pressures have dropped considerably in the intervening 20 years. This requirement is related to keeping the fuel in the tank of your car from evaporating out into the atmosphere. That is why you have sealed gas tank caps and a charcoal recovery cannister on cars since about 1981. He stated that in California, any premium auto fuel without ethanol in it, is practically aviation grade, as California specifies a Reid Vapor Pressure of 7. Please note that once ethanol gets introduced into auto fuel, all bets are off. He stated that the biggest problem would be incurred by aircraft owners in States which see cold winter temperatures. During these months, they may be restricted to 100LL, as the local auto fuel's Reid Vapor Pressure may be to high to allow safe operation with a winter fuel blend. All the hype about problems with fuel system gaskets and seals relates to parts produced over 20 years ago. Most fuel injection servos now in use have been overhauled with materials which are compatible with auto fuel. A simple way to tell is to look at the color of the diaphragms on your Bendix (now Precision Airmotive) servo. If the diaphragms are orange, you've got the late model, compatible materials. If you see black, stick with 100LL or get the servo and fuel distributor overhauled. He stated that in my home state of Florida, I could expect the Reid Vapor Pressure of local fuels to be 8.5 or below. His opinion was that for "optimum" operation & safety of Lycoming fuel injected engines, a vapor return system should be installed. This should not be confused with the vapor system marketed by Airflow Performance. API's system consists of a manually controlled valve, which the pilot opens prior to a hot restart of his engine. Once this valve is opened, the electric boost pump in engaged. This clears out the overheated fuel sitting in the system, firewall forward. This fuel is returned to a single tank and replaced with cool fuel from that tank. API's system was only intended to aid in hot restarts. What he suggests, is to use a pair of vapor/fuel return lines with a duplex fuel valve. See Andair's model FS20-20 here http://www.andair.co.uk/system/index.html This system is very similar to the system used in modern American pick up trucks with dual fuel tanks or the above mentioned Continental system. The system has a feed line running from each tank to the duplex fuel selector. Each tank also has a fuel return line running to the duplex fuel selector. A single feed line and a single return line run from the duplex selector up to the engine's fuel injection system. Each fuel tank also has a vent line, as is now normally installed. This means that a 3rd line must be run to each fuel tank. This type of system keeps fuel constantly moving from the wing fuel tanks, through the duplex selector, up to the engine. A portion of this fuel is constantly being returned via the fuel selector, to the tank it is being drawn from. In essence, the fuel tank is being used as a fuel cooler, much the oil cooler for your engine. It is this feature which keeps the fuel cool enough to operate with auto fuels with high Reid Vapor Pressure numbers. You can learn more about this type of system by looking at the way fuel is managed on any fuel injected Mazda or Subaru engined RV. These engines must use this type of fuel system because that is how the system was designed in the original vehicles the engines came out of. There are a fair number of folks flying fuel injected Lycomings with auto fuel who are using stock or API modified fuel systems with success. This may be due to their geographic location, or because they use a Reid Vapor Pressure tester, available from Peterson Aviation for $65. See http://www.webworksltd.com/autofuelstc/pa/HodgesTester.html I asked him to give me an airframe / engine combination utilizing a Continental engine which had passed the STC tests. He suggested looking at Beech Debonairs up to 1970 or 1972 (he was unsure of the cut off year). The engines suggested were the IO-470-J and IO-470-K models. He stated that these airframe/engine combinations are a good example of the vapor return line system he recommends. There were others which passed, but I simply wanted one good example. Charlie Kuss ________________________________________________________________________________
Date: Jul 03, 2006
Consider orienting the hole so that the wire coming from sensor is pointed in a friendly direction -- like parrallel to the wire bundle. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Ralph E. Capen wrote: > > Fellow listers, > > I'm getting ready to drill into my Vetterman exhaust to install the EGT > transducers > for my VM1000 engine monitor. > > I've already got some of the CHT transducers wired and working so I think > I have > my transducer wiring technique working. > > Other than drilling them the same distance down from the head mounting > flange and > staying away from the spark plugs, I haven't been able to find any info on > the best > place to drill the holes. Even though straight outboard looks like a > great place > to put them - I'm wondering about the cowl (I have a Sam James Cowl). > > Anyone out there have any photos of what worked well for them? > > Kinda scary - drilling holes in an exhaust system...don't they leak? > > Thanks, > Ralph Capen > RV6A N822AR @ N06 Wiring firewall foreward > > ________________________________________________________________________________
Date: Jul 03, 2006
Subject: Fwd: MOGAS Use With FI Engines was Fuel Injected
For your consideration: http://www.eci2fly.com/pdf/FIS11x17.pdf ECI has a new fuel injection system which incorporates constant fuel circulation back to the tanks as described below. It is more similar to the Continental type than to the Bendix. Pax, Ed Holyoke Dan, I was one of the listers in on that discussion. I called the EAA and spoke to a woman regarding their STCs. They only attempted to obtain STCs for low compression (7.2 to 1) engines. They made no effort to obtain auto fuel STCs for 8.5 to 1 or higher compression engines. I reported this to the list on June 13th. I called Peterson Aviation that same day, but their technical expert was out of town. I called back and spoke to him on June 29th at length. He was quite helpful. He stated that Peterson had attempted to obtain STCs for 91 octane (minimum) auto fuel for various fuel injected engines. They had success with a number of aircraft with Continental engines/fuel injection. Every Lycoming based aircraft failed. These tests were done over 20 years ago, and they have never revisited this issue since. He told me that the testing was done to "worst case scenario". At that time, the Reid Vapor Pressure of aircraft fuel was no higher than 6.5 (lower is better). Common auto fuel could range from 7 to 15. The highest Reid Vapor Pressure numbers were "winter blend" fuels designed to aid in vaporization of fuel in the northern US and Canada, where temperatures can drop to -20 F and below. The engine/airframe combination had to pass all the tests using "worst case" fuel (ie 14-15 Reid Vapor pressure) Due to various "clean air" enactments, auto fuel Reid Vapor Pressures have dropped considerably in the intervening 20 years. This requirement is related to keeping the fuel in the tank of your car from evaporating out into the atmosphere. That is why you have sealed gas tank caps and a charcoal recovery cannister on cars since about 1981. He stated that in California, any premium auto fuel without ethanol in it, is practically aviation grade, as California specifies a Reid Vapor Pressure of 7. Please note that once ethanol gets introduced into auto fuel, all bets are off. He stated that the biggest problem would be incurred by aircraft owners in States which see cold winter temperatures. During these months, they may be restricted to 100LL, as the local auto fuel's Reid Vapor Pressure may be to high to allow safe operation with a winter fuel blend. All the hype about problems with fuel system gaskets and seals relates to parts produced over 20 years ago. Most fuel injection servos now in use have been overhauled with materials which are compatible with auto fuel. A simple way to tell is to look at the color of the diaphragms on your Bendix (now Precision Airmotive) servo. If the diaphragms are orange, you've got the late model, compatible materials. If you see black, stick with 100LL or get the servo and fuel distributor overhauled. He stated that in my home state of Florida, I could expect the Reid Vapor Pressure of local fuels to be 8.5 or below. His opinion was that for "optimum" operation & safety of Lycoming fuel injected engines, a vapor return system should be installed. This should not be confused with the vapor system marketed by Airflow Performance. API's system consists of a manually controlled valve, which the pilot opens prior to a hot restart of his engine. Once this valve is opened, the electric boost pump in engaged. This clears out the overheated fuel sitting in the system, firewall forward. This fuel is returned to a single tank and replaced with cool fuel from that tank. API's system was only intended to aid in hot restarts. What he suggests, is to use a pair of vapor/fuel return lines with a duplex fuel valve. See Andair's model FS20-20 here http://www.andair.co.uk/system/index.html This system is very similar to the system used in modern American pick up trucks with dual fuel tanks or the above mentioned Continental system. The system has a feed line running from each tank to the duplex fuel selector. Each tank also has a fuel return line running to the duplex fuel selector. A single feed line and a single return line run from the duplex selector up to the engine's fuel injection system. Each fuel tank also has a vent line, as is now normally installed. This means that a 3rd line must be run to each fuel tank. This type of system keeps fuel constantly moving from the wing fuel tanks, through the duplex selector, up to the engine. A portion of this fuel is constantly being returned via the fuel selector, to the tank it is being drawn from. In essence, the fuel tank is being used as a fuel cooler, much the oil cooler for your engine. It is this feature which keeps the fuel cool enough to operate with auto fuels with high Reid Vapor Pressure numbers. You can learn more about this type of system by looking at the way fuel is managed on any fuel injected Mazda or Subaru engined RV. These engines must use this type of fuel system because that is how the system was designed in the original vehicles the engines came out of. There are a fair number of folks flying fuel injected Lycomings with auto fuel who are using stock or API modified fuel systems with success. This may be due to their geographic location, or because they use a Reid Vapor Pressure tester, available from Peterson Aviation for $65. See http://www.webworksltd.com/autofuelstc/pa/HodgesTester.html I asked him to give me an airframe / engine combination utilizing a Continental engine which had passed the STC tests. He suggested looking at Beech Debonairs up to 1970 or 1972 (he was unsure of the cut off year). The engines suggested were the IO-470-J and IO-470-K models. He stated that these airframe/engine combinations are a good example of the vapor return line system he recommends. There were others which passed, but I simply wanted one good example. Charlie Kuss ________________________________________________________________________________
Date: Jul 03, 2006
Not too sure if it matters or not, but I angled mine 45 deg. aft on the right and 45 deg. fwd on the left. My theory is this places the probes in the same relative position on each cylinder (#1 being the exception since the probe is just below the bend on my Vetterman x-over). FWIW From The PossumWorks in TN Mark ________________________________________________________________________________
Date: Jul 03, 2006
...or just put it on a rotisserie- MUCH easier to do all kinds of stuff! 8-) http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5373 Mark ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Re: MOGAS Use With FI Engines
ANY CAR GAS OR MO GAS HAS LOWER VAPOR PRESSURE AND IS SUBJECT TO VAPOR LOCK. JUST A NOTE: MO gas is what you can buy out of a pump at the airport, MO gas for Motor Gas. Auto Fuel, is what you get at the corner gas station. MO Gas is like 86 octane. If you need 91 octane you need to get premium from the corner gas station. The problem is your plane is at the airport. (not much price difference from premium to 100LL) So to use Auto fuel in your plane you are faced with the hassle of hauling fuel to the plane. This can be a huge hassle, dangerous and illegal. At most airports and with state highway laws (hazardous material transport) a NO NO. You are just not going to be hauling eight 5 Gal jerry cans around or 55 gal barrels with gas easily. I can see all the cheapskates thinking of the cost savings they will get. In fact the saving is small if impractical for 91 octane engines. If you have a low compression engine that can run on MO gas than sure there is some advantage. HOWEVER A RV tight cowl is NOT ideal for MO gas operations. Also price of MO Gas is not that much less than 100LL or can you even get MO gas widely. Some times MO gas cost more than 100LL. So you might be taking abut $4.00/hr savings for all the hassle. Fuel Injection has nothing to do with it, it is compression ratio. All the original STC's where for low compression engines that where made for like 80 octane. There are premium gas STC's for Lyc 320/360's with the 8.5:1 CR, which needs 91 octane, but not all planes can pass the test and get a STC, even after much effort. A 150HP O320 is a low octane engine, a O235 is NOT. The INSTALLATION is critical. When a STC for auto fuel is given it is for the installation as well as the engine. YES I know we are experimental but you can't ignore physics. I recall airplane like the older Mooney's with the O360 can't get a STC for premium auto fuel because of vapor lock. Like RV's the Mooney have very tight cowls. Don't compare the Piper with a huge cowl and a RV with a very tight cowl and exhaust pipes snaking all around near fuel lines. The overall issue is you will not get AUTO GAS with out all the hamburger helper and modified fuel like alcohol and ethanol. I remember in Washington state, in the winter they went to an alcohol blend fuel. My gas milage went in the crapper. That is the other issue. Car gas is NOT CONSISTANT. It varies widely by region, session and testing is a hassle. If you do go auto fuel insulate and heat shield EVER part of the fuel system and add a vapor return line even for Carb engines. >From: "Tracy Crook" <lors01(at)msn.com> > >My RX-8 rotary (10 : 1 CR) powered RV-4 runs best and >gets best fuel economy on 87 octane. I burn 100LL in a >pinch but plug life is greatly reduced. Automotive and aircraft engines are two differnt things. RX8 cars strictly call for premium and use 2 qts of oil between oil changes, and also get terriable gas millage. I know you are a rotary expert Tracy but a water cooled car engine piston or rotary is not an aircooled aircraft engine. My Lyc plug life is 1000 hour plus on 100LL. I am not picking on you Tracy but you have to take the good with the bad. Good, you can use auto fuel; Bad, your engine is noisier, heavier and burns way more fuel than a Lycoming for equivalent performance. >Best experts I've read say that almost all aircraft engines >would work fine on 91 octane mogas. Most aircraft engines where certified for 91, like 320 (160HP) and 360 (180 hp) Lycoming. So that is a no brainer, The problem is the MO gas you can buy at the airport is way less than 91 octane, like 80/86. If you want premium AUTO fuel you have to haul. And the idea of having your own tank, even on your own property is likely to be illegal in most states. We may get a 91UL or 95UL in the near future. Basically I believe 100LL without the lead. >equipped with knock sensors to adjust timing appropriately. >This would be a simple and inexpensive thing to do if the >FAA were not involved. The FAA has nothing to do with it. Aircraft engines can not use automotive knock sensor, which are basically little microphones. An air cooled engine with out water jackets can not use them due to mechanical noise. When I say noise I DON'T mean what you hear, like thru the exhaust pipe but mechanical valve noise. Now combustion chamber pressure probes would work in maximizing timing and improving economy of a Lyc, but that is very expensive and not needed. Lyc's work at such a narrow RPM/Power band you don't need fancy electronics to make it work. You do need a trained pilot who knows what the red knob is for. Most (not all) aircraft engines will work with premium AUTO FUEL or the new 91UL that MAY BE coming down the road. I say may be because it might not happen. There are some high end piston aircraft engines that will not work with less than 100LL. BTW Rotaries are of course the loudest engine you can put on a plane. Of course there are no valves. We are again talking water cooled verse aircooled. You would think that would give a fuel edge to the rotary but in fact the rotary burn more fuel than a Lyc. You can talk all the ECU tweaking the basic design of the rotary will never allow the same spacific fuel consumption. The RX8 gets 5 mpg less than equivalent 220hp sport cars, BOTH City and Highway. Even the Nissan Z car with almost 100 hp more gets the same milage as the RX8 Mazda. (about 20% less fuel econ) Do you think Mazda tuned their ECU for best EPA milage for the gas milage sticker test? Sure. So when talking about the advantage of burning auto fuel, talk about the higher fuel burn and oil usage. Also mixing oil into the fuel tank is a pain, or if you use an oil injector instead, it's more weight. >We will still be saddled with the expensive idiocy of a >separate distribution system for our fuel due to the growing >mandates to use ethanol which requires 1.3 gallons of fossil >fuel to produce 1 gallon of the moonshine. >Are we stupid or what? Well we are not to be political, but where is the presidential primaries held? (Iowa?) Where do they grow the most corn and what is ethanol made of? (corn?) That is the problem alternative fuel availability Auto GAs and Mo gas, with out alcohol or ethanol is getting hard to get. We can expect that 91UL aviation gas will come down the road. IT already has in Europe. For now all we have 100LL. --------------------------------- ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Marhyde reformulation?
Howdy folks- Have any of you other Marhyde #5111 (spray) or #5112 (quart) users out there seen a change in this stuff's quality over the last year or so? A buddy building a Mustang II has been using it and it does not seem to stick to properly-prepped aluminum anywhere near as well as when I used it to build my plane. You can scratch it off the surface with a thumbnail pretty easily. It was tough stuff on my project and about the only way I could get it off was to sand it off! See: http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=4863 I sent an inquiry to Bondo Corp's Tech assistance several weeks ago and the respondent asked for batch #s which were forwarded. I haven't heard back yet. He claimed there has been no change in formulation. If so, their QC has some serious problems, but I really think they've changed it (even smells a little different). Although my own experience with it was excellent, I need a substitue immediately. Discussion over the years on the RV-list points to other self-etch primers, namely SW GPB988, SEM 39683 and Dupont A-4115S, which I believe is also the same as NAPA 7020. If you are presently using one of these and are satisfied they bond well to aluminum, please let me know! I most respectfully ask that you PLEASE do not respond to this message with your concerns & opinions about using self-etch primers (unless you have specific FACTS about new EPA regulations or some other factor that has castrated ALL of these products!) If you want to do that, contact me OFF LIST and spare thousands of listers the annoyance of wearing out their DEL key. I have been on this list for many years and have heard it ALL about etch/alodine/epoxy/wash primer/whatever and am looking for hard information regarding the current crop of self-etch primers specifically. The last thing we have time for is an argument over primers- it's already archived, again&again&again&again.......... Thanks! Mark Phillips ________________________________________________________________________________
Date: Jul 04, 2006
Having drilled my O360 A1A's vetterman exhaust both ways, I consider a hole that helps the wire line up with the lower spark plug leads the best orientation. The ones I drilled to join the wire bundle that runs along the crankcase/sump joint are more difficult to work with plus they run through the hot area just under the cooling fins. Both methods are working OK but I think bundling with the spark plug leads is a cleaner installation. In my case, it also let me get all sensors closer to the same distance from the exhaust port. At the same distance as all the other leads, the number 1 cylinder lead would have angled up to hit the cooling fins. Also, if you make a mistake, grinding a stainless screw down and securing it in the hole with a hose clamp is a decent alternative to junking that part of the exhaust. Dave Reel - RV8A ________________________________________________________________________________
Date: Jul 04, 2006
Subject: RE: MOGAS Use With FI Engines
Hi All- It's been a bunch of years since I followed this aspect of the industry, so please pardon my ignorance. I'd like some clarification from those of you (Charlie?) who've done the research on this issue. The Lyc manual for my 8.7:1 IO-360-A1B6D specifies 100/130 fuel. It also refers to S.I. 1070, which says the engine was certificated for 100/130 but that 100LL or 100 are the commercial designations to be used. The SI further states "The chart showing specified and alternate fuels that can be safely used in no instance permits use of fuels of lower grade than that which is specified. Also, it is not permissible in any instance to use automotive fuel in aircraft engines, regardless of octane or advertised features because of the corrosive effect of its chlorine content and because of vapor lock that could result due to its high vapor pressure. Any fuel used in Lycoming engines must conform with Specifications ASTM-D910 or MIL-G-5572F." Last things first- if one were to test / verify the vapor pressure of the locally available mogas, and only use fuel with a Ried vapor pressure less than 7, wouldn't that essentially preclude vapor lock problems? Does the chlorine mentioned only corrode / swell fuel system seals, or are there other effects? If one tank held avgas for non-cruise ops, and the other held mogas for sub 75% cruise ops, wouldn't knock be a non-issue? Or would some sort of knock sensor still be appropriate? Is there any news on the status of the efforts to keep 91 octane alcohol free? Thanks in advance, guys! glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jul 04, 2006
Subject: MOGAS (Detonation)
This MOGAS thread is has some great information. It looks like the greatest threat is vapor lock which can be dealt with but what about Detonation? With a 160hp O-320 my biggest concern was Detonation. But as long as I use 91-93 octane MOGAS, that does not seem to be the case. Is that a fair conclusion? Scott ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Re: RE: MOGAS Use With FI Engines
At 10:52 AM 7/4/2006, you wrote: > >Hi All- > >It's been a bunch of years since I followed this aspect of the industry, so >please pardon my ignorance. I'd like some clarification from those of you >(Charlie?) who've done the research on this issue. The Lyc manual for my >8.7:1 IO-360-A1B6D specifies 100/130 fuel. It also refers to S.I. 1070, >which says the engine was certificated for 100/130 but that 100LL or 100 >are the commercial designations to be used. The SI further states "The >chart showing specified and alternate fuels that can be safely used in no >instance permits use of fuels of lower grade than that which is specified. >Also, it is not permissible in any instance to use automotive fuel in >aircraft engines, regardless of octane or advertised features because of >the corrosive effect of its chlorine content and because of vapor lock that >could result due to its high vapor pressure. Any fuel used in Lycoming >engines must conform with Specifications ASTM-D910 or MIL-G-5572F." > >Last things first- if one were to test / verify the vapor pressure of the >locally available mogas, and only use fuel with a Ried vapor pressure less >than 7, wouldn't that essentially preclude vapor lock problems? > >Does the chlorine mentioned only corrode / swell fuel system seals, or are >there other effects? > >If one tank held avgas for non-cruise ops, and the other held mogas for sub >75% cruise ops, wouldn't knock be a non-issue? Or would some sort of knock >sensor still be appropriate? > >Is there any news on the status of the efforts to keep 91 octane alcohol >free? > >Thanks in advance, guys! > >glen matejcek >aerobubba(at)earthlink.net Glen, No one related to obtaining STCs for use of auto fuel in aircraft recommends it's use in engines with greater than 8.5 to 1 compression ratios. Even though the Lycoming angle valve engines are only 0.2 points higher, they have a totally different combustion chamber design. That said, I do know of RV owners using auto fuel in these engines with no modification. I would expect that their detonation margins are reduced to less than what Lycoming would like. Another option would be to operate on a mixture of 100LL and premium auto fuel. On refueling away from home base, this will occur anyway. Testing the Reid Vapor Pressure of all auto fuel you use, (as well as testing for alcohol) would be extremely wise. Modification of your fuel system to include a Continental style vapor return system would also be wise with this engine. As mentioned by another lister, knock sensors are not practical for air cooled engines. The addition of ethanol to auto fuel is a regional issue at present. The issue of chemicals used in auto fuels that are not used in aviation fuels has been dealt with in recent years. Re-read my last post regarding this. Charlie Kuss ________________________________________________________________________________
Date: Jul 04, 2006
Jack, Man what a fantastic first flight and video. Yes, it was Yani for the background but well let that go. I'm still doing FWF but I can see the end even if its down the road a bit. This video just makes it all worth while an keeps me pounding rivets. Jim Nelson RV9-A http://websites.expercraft.com/jimn ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Re: MOGAS (Detonation)
In a message dated 7/4/06 3:36:33 PM Eastern Daylight Time, tn3639(at)hotmail.com writes: > This MOGAS thread is has some great information. It looks like the greatest > threat is vapor lock which can be dealt with but what about Detonation? With > > a 160hp O-320 my biggest concern was Detonation. But as long as I use 91-93 > octane MOGAS, that does not seem to be the case. Is that a fair conclusion? > > Scott ============================= Scott: Under the right conditions I can create Vapor Lock even with AvGas. The right conditions seem to exist more in Texas than anywhere else. The only reason why I say that is I have had more opponents of MoGas from their than anywhere else. I have even had ALL the symptoms of vapor lock in a Piper Arrow with fuel injection. I support MoGas and have seen better engine runs with MoGas than AvGas. BUT! There will always be those in favor and those apposed. With the addition of ethanol to our MoGas that should stop vapor lock, since the vapor point and flash point are higher. As for the O-320 with high compression pistons, YES stick with the 93 or better octane. Ya know ... I have never seen 91 octane offered anywhere. As for detonation, you can feel free to mix 100 LL AvGas with 93 MoGas ... BUT! Never mix 93 MoGas with anything less than 93 or better. Barry "Chop'd Liver" ________________________________________________________________________________
Date: Jul 04, 2006
Wow!!! Are you some sort of lobbist for the 100LL fuel industry. You have convinced me, I won't even use mogas in my tractor after this warning. 100LL for everything!! Bob ----- Original Message ----- From: gmcjetpilot(at)yahoo.com To: rv-list(at)matronics.com Sent: Tuesday, July 04, 2006 5:32 AM Subject: RV-List: Re: MOGAS Use With FI Engines ANY CAR GAS OR MO GAS HAS LOWER VAPOR PRESSURE AND IS SUBJECT TO VAPOR LOCK. JUST A NOTE: MO gas is what you can buy out of a pump at the airport, MO gas for Motor Gas. Auto Fuel, is what you get at the corner gas station. MO Gas is like 86 octane. If you need 91 octane you need to get premium from the corner gas station. The problem is your plane is at the airport. (not much price difference from premium to 100LL) So to use Auto fuel in your plane you are faced with the hassle of hauling fuel to the plane. This can be a huge hassle, dangerous and illegal. At most airports and with state highway laws (hazardous material transport) a NO NO. You are just not going to be hauling eight 5 Gal jerry cans around or 55 gal barrels with gas easily. I can see all the cheapskates thinking of the cost savings they will get. In fact the saving is small if impractical for 91 octane engines. If you have a low compression engine that can run on MO gas than sure there is some advantage. HOWEVER A RV tight cowl is NOT ideal for MO gas operations. Also price of MO Gas is not that much less than 100LL or can you even get MO gas widely. Some times MO gas cost more than 100LL. So you might be taking abut $4.00/hr savings for all the hassle. Fuel Injection has nothing to do with it, it is compression ratio. All the original STC's where for low compression engines that where made for like 80 octane. There are premium gas STC's for Lyc 320/360's with the 8.5:1 CR, which needs 91 octane, but not all planes can pass the test and get a STC, even after much effort. A 150HP O320 is a low octane engine, a O235 is NOT. The INSTALLATION is critical. When a STC for auto fuel is given it is for the installation as well as the engine. YES I know we are experimental but you can't ignore physics. I recall airplane like the older Mooney's with the O360 can't get a STC for premium auto fuel because of vapor lock. Like RV's the Mooney have very tight cowls. Don't compare the Piper with a huge cowl and a RV with a very tight cowl and exhaust pipes snaking all around near fuel lines. The overall issue is you will not get AUTO GAS with out all the hamburger helper and modified fuel like alcohol and ethanol. I remember in Washington state, in the winter they went to an alcohol blend fuel. My gas milage went in the crapper. That is the other issue. Car gas is NOT CONSISTANT. It varies widely by region, session and testing is a hassle. If you do go auto fuel insulate and heat shield EVER part of the fuel system and add a vapor return line even for Carb engines. >From: "Tracy Crook" <lors01(at)msn.com> > >My RX-8 rotary (10 : 1 CR) powered RV-4 runs best and >gets best fuel economy on 87 octane. I burn 100LL in a >pinch but plug life is greatly reduced. Automotive and aircraft engines are two differnt things. RX8 cars strictly call for premium and use 2 qts of oil between oil changes, and also get terriable gas millage. I know you are a rotary expert Tracy but a water cooled car engine piston or rotary is not an aircooled aircraft engine. My Lyc plug life is 1000 hour plus on 100LL. I am not picking on you Tracy but you have to take the good with the bad. Good, you can use auto fuel; Bad, your engine is noisier, heavier and burns way more fuel than a Lycoming for equivalent performance. >Best experts I've read say that almost all aircraft engines >would work fine on 91 octane mogas. Most aircraft engines where certified for 91, like 320 (160HP) and 360 (180 hp) Lycoming. So that is a no brainer, The problem is the MO gas you can buy at the airport is way less than 91 octane, like 80/86. If you want premium AUTO fuel you have to haul. And the idea of having your own tank, even on your own property is likely to be illegal in most states. We may get a 91UL or 95UL in the near future. Basically I believe 100LL without the lead. >equipped with knock sensors to adjust timing appropriately. >This would be a simple and inexpensive thing to do if the >FAA were not involved. The FAA has nothing to do with it. Aircraft engines can not use automotive knock sensor, which are basically little microphones. An air cooled engine with out water jackets can not use them due to mechanical noise. When I say noise I DON'T mean what you hear, like thru the exhaust pipe but mechanical valve noise. Now combustion chamber pressure probes would work in maximizing timing and improving economy of a Lyc, but that is very expensive and not needed. Lyc's work at such a narrow RPM/Power band you don't need fancy electronics to make it work. You do need a trained pilot who knows what the red knob is for. Most (not all) aircraft engines will work with premium AUTO FUEL or the new 91UL that MAY BE coming down the road. I say may be because it might not happen. There are some high end piston aircraft engines that will not work with less than 100LL. BTW Rotaries are of course the loudest engine you can put on a plane. Of course there are no valves. We are again talking water cooled verse aircooled. You would think that would give a fuel edge to the rotary but in fact the rotary burn more fuel than a Lyc. You can talk all the ECU tweaking the basic design of the rotary will never allow the same spacific fuel consumption. The RX8 gets 5 mpg less than equivalent 220hp sport cars, BOTH City and Highway. Even the Nissan Z car with almost 100 hp more gets the same milage as the RX8 Mazda. (about 20% less fuel econ) Do you think Mazda tuned their ECU for best EPA milage for the gas milage sticker test? Sure. So when talking about the advantage of burning auto fuel, talk about the higher fuel burn and oil usage. Also mixing oil into the fuel tank is a pain, or if you use an oil injector instead, it's more weight. >We will still be saddled with the expensive idiocy of a >separate distribution system for our fuel due to the growing >mandates to use ethanol which requires 1.3 gallons of fossil >fuel to produce 1 gallon of the moonshine. >Are we stupid or what? Well we are not to be political, but where is the presidential primaries held? (Iowa?) Where do they grow the most corn and what is ethanol made of? (corn?) That is the problem alternative fuel availability Auto GAs and Mo gas, with out alcohol or ethanol is getting hard to get. We can expect that 91UL aviation gas will come down the road. IT already has in Europe. For now all we have 100LL. ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Jul 04, 2006
Guys I have been running over four years and 500+ hours on a mix of 25% 100LL, 75% 87 octane no-alcohol unleaded which I purchase from the local farm bureau. Never had any trouble, other than the stains it makes on the paint. No signs of detonation or elevated temperatures. Typically as a flatlander I rarely go above 7500ft and have flown many times where the OAT was 95 deg. F. At the moment my fuel costs are $31.98/hr, and if I go 100% 100LL its $40.00/hr, for a savings of $8.02/hour. (based on 10gph, 87 octane at $2.93/gal and 100LL at $4.00/gal.). I typically fly 10 hours a month, for a net savings of $80.20 a month, $962.40/year. It's worth the hassle! Regards, Bob Japundza RV-6 O-360 C/S flying 700+ hours, F1 under const. ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Re: Engine alignment
Dana, you want to space it evenly at the front. You do whatever you need to do to the back to achieve the perfect front. You probably sand/cut stuff off back there and if you take too much off, you get to add it back later. You want about 3/8" to 1/4" gap that pic 3 shows to be uniform all around. Put a spacer in there and clamp it down or it will move when you go to drilling the cowling to the firewall. You want the cowling to be a bit low from being perfect to the spinner position so when the engine drops/sags a bit after a few hours of use, you will be closer to perfect. Indiana Larry ----- Original Message ----- > > > Started working on the cowling this morning and ran into a little question > mark. > > On my case, there is a little ridge where the bottom two engine mounts > contact the case. I put a large washer between the Barry mount and the > case on the bottom, otherwise the engine mounts would not be flush on the > case. > http://rvflying.tripod.com/alignment1.jpg > > I did not put any washers on the top. My thinking was Lyc had taken this > into consideration with the ridge in the bottom two. > > http://rvflying.tripod.com/alignment2.jpg > > So, when I placed the upper cowling in place, there is an increasing gap > from top to bottom. Me thinks this does not look right!! > > http://rvflying.tripod.com/alignment3.jpg > > > Anyone run into this? What are my options, put a large washer between the > top to mounts and the case? ________________________________________________________________________________
Date: Jul 04, 2006
Subject: MOGAS Use
At 03:44 PM 7/4/2006, you wrote: >Guys I have been running over four years and 500+ hours on a mix of 25% >100LL, 75% 87 octane no-alcohol unleaded which I purchase from the local >farm bureau. Never had any trouble, other than the stains it makes on the >paint. No signs of detonation or elevated temperatures. Typically as a >flatlander I rarely go above 7500ft and have flown many times where the >OAT was 95 deg. F. At the moment my fuel costs are $31.98/hr, and if I go >100% 100LL its $40.00/hr, for a savings of $8.02/hour. (based on 10gph, 87 >octane at $2.93/gal and 100LL at $4.00/gal.). I typically fly 10 hours a >month, for a net savings of $80.20 a month, $962.40/year. It's worth the >hassle! So what happens at up to 17,500' ? Ron Lee ________________________________________________________________________________
Date: Jul 04, 2006
Dana, you want the engine alignment to be perfect before fitting the cowling. If it is up or down or anything but straight away, (it is offset however a bit to the left on mine to alleviate the P-factor I was told) you will have loss of TAS. Make sure you have the proper engine mount for your particular engine. Recheck the correct washers were used (top was different than bottom on mine) on the engine mount. I suspect you will find the problem is somewhere with the engine mount or attachment. Hope this helps. Larry with little SunSeeker -- the Indiana RV7 ----- Original Message ----- > > Larry and any other listers, what my problem appears to be is a > misalignment of the engine, ie., tilted up with the introduction of the > washer between the engine mount and case on the bottom to clear the lip on > the case bottom attach points. If you notice on the third picture, the > gap gets progressively larger on the bottom of the upper cowl. My > thinking is the washers have canted the engine up, thereby giving me this > non standard gap. Any thoughts? > > Dana Overall ________________________________________________________________________________
Date: Jul 04, 2006
Subject: MOGAS Use
Ron, What's 17,500?? Isn't that a nose bleed altitude? :-))) I intend to use MOGAS in a 50/50 blend in at least one tank until I am satisfied that with my FI I'll have no problems. Then I may go to 25/75 MOGAS / 100LL in the other tank. If nothing else, it will keep the lead accumulations down to a low level. Jim Nelson ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Engine alignment
Larry, I also had a problem with the lower engine mounts flanges where the rubber engine mounts meet the case. The steel washer of the engine mount did not meet up flush with the relief cut on the engine case. It was about 1/8 protrusion at the bottom. I examined the juncture of the lower oil / intake case with the upper engine case and found out that if I ground a small amount of the case at the seam between the two parts I could get the engine mount to lie flush with the upper case mount. The cut away portion of the flange was between two bolts that held the lower part of the engine case to the upper part. My die grinder with an aluminum burr made short work of both sides. My Tech counselor had not seen this before so it was a new on him. The cut away portion would not have any effect on the integrity of the case or sealing surface. I could take a pix if it would be of any help to you. Jim Nelson ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Jul 04, 2006
Subject: Re: How NOT to turn a fuselage over
Just a quick warning for you guys. My neighbors at the airport have been building a T-18 and the other day they came in the morning to do some riveting to find that the sawhorses had collapsed under the fuselage. It caused substantial damage and will set the project back many hours. Scary thing for me is that I have a much heavier/larger RV-10 fuselage on the same crappy Home Depot plastic sawhorses......I have even been getting in it to do hours of work! They think that the heat in our area for the last few weeks made them fail. It has been over 100F consistently, even up to 117 F. My focus now is to get the landing gear trunions in so I can mount my temporary landing gear (more on those in a sec.) I just got the sound proofing in under the forward floors, sealed the firewall with proseal and popped down the floors. Now all that is left is to bolt in those trunions. The temporary landing gear is some pipe I had cut with a couple of bolts welded on to act as axels...throw in a couple of wheelbarrow tires and you got the idea. It will set the fuselage about 2 feet off the floor and I will be able to set the whole works down on the wheels and the side steps. Also by simply lifting up the tailcone I will be able to move it about the hanger, wheel barrow style. These guys cost about $100 dollars and when I am done I will send them on to some other deserving RV 10 builder for their use. Now I need to get over to the hanger and stick my small refrigerator under the fuse to act as a back-up to those saw horses. Cheers.. Evan Johnson www.evansaviationproducts.com (530)247-0375 (530)351-1776 cell ----- Original Message ----- Sent: Monday, July 03, 2006 5:13 PM > > Doc > > Check out www.jeffsrv-7a.com > > Jeff has a great stand tro rotate the fuse > > Frank @ SGU and SLC > > > >From: "Doc Custer" <ddcuster@wmv-co.us> > >Reply-To: rv-list(at)matronics.com > >To: > >Subject: RV-List: How to turn an RV-9A fuse over? > >Date: Mon, 3 Jul 2006 17:51:59 -0600 > > > >I am at the point of having the lower half of the 9A fuse riveted and/or > >clecoed together. It is currently upside down and I need to turn it 90 > >degrees so I can rivet the floor stiffeners on. It now weighs enough that > >it takes two men and a boy to lift and turn it. And I will be needing to > >install all kinds of plumbing, wiring etc. and I would like to be able to > >turn it by myself. > > > >I am thinking that there must be a better way than to simply man handle it > >with three men. > > > >Does anybody out there have an solution? > > > >Thanks in advance, > > > >David (Doc) Custer > > ________________________________________________________________________________
Date: Jul 04, 2006
17,500 FEET MSL, Or pick 16,500 Feet, or 14,423 feet. That is where I fly. Ron Lee >Ron, > What's 17,500?? Isn't that a nose bleed altitude? :-))) I >intend to use MOGAS in a 50/50 blend in at least one tank until I am >satisfied that with my FI I'll have no problems. Then I may go to 25/75 >MOGAS / 100LL in the other tank. If nothing else, it will keep the lead >accumulations down to a low level. > >Jim Nelson ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Heat muff overheat?
Are there any problems closing off the air flow to the heat muff during the summer months? It's air supply is a 2" hole off the baffling behind cylinder #3. My concern is that without the flow through the heat muff, it may get too hot and melt or burst into flames or worse! What do you think? - Larry Bowen, RV-8 196 Hrs. Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Jul 04, 2006
Subject: D10A magnetic sensor alignment
I ordered my D10A with the external magnetic (compass) sensor. I was thinking of installing it in a wingtip or behind the baggage bulkhead, perhaps. I just read the installation manual which says the magnetic sensor should be installed oriented to match the orientation of the D10A (in the panel) in pitch, roll, and yaw to an accuracy of better than 1 degree. This sounds impractical. Positioning it relative to a longeron or rib or any component of the airplane could easily have 1 deg. of error in it.You'd have to be able to measure the orientation of both units in an absolute sense somehow to get this kind of accuracy. Perhaps with a surveyors transit and an electronic level I could work it out, but I have neither. What have other people done? Does it really need this kind of accuracy? Or am I the only one foolish enough to order it this way? -- Tom Sargent, RV-6A ________________________________________________________________________________
Date: Jul 04, 2006
At 17:07 2006-07-04, you wrote: > >At 03:44 PM 7/4/2006, you wrote: >>Guys I have been running over four years and 500+ hours on a mix of >>25% 100LL, 75% 87 octane no-alcohol unleaded which I purchase from >>the local farm bureau. Never had any trouble, other than the >>stains it makes on the paint. No signs of detonation or elevated >>temperatures. Typically as a flatlander I rarely go above 7500ft >>and have flown many times where the OAT was 95 deg. F. At the >>moment my fuel costs are $31.98/hr, and if I go 100% 100LL its >>$40.00/hr, for a savings of $8.02/hour. (based on 10gph, 87 octane >>at $2.93/gal and 100LL at $4.00/gal.). I typically fly 10 hours a >>month, for a net savings of $80.20 a month, $962.40/year. It's >>worth the hassle! > > >So what happens at up to 17,500' ? > >Ron Lee The highest I've been is 15,500 and that was on a horse. I don't have an O2 bottle for the RV-4 so it's only been to 12k (for a very short period of time). We ran tens of thousands of gallons of auto gas through the C-182's we used for jumping years ago and they regularly went to 12,500 and sometimes to 14,500. Never a fuel problem and saved thousands of $. Engines went to TBO and beyond as well. If I were running at 17,500 I'd have to treat it like a special case and use a special mix. Sorta like scuba divers going deep with a special air mix. P-) Mike ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Granby CO Fly-in breakfast
Saturday, 1 July 2006 was the annual fly in breakfast at Granby CO (KGNB). Whereas last year about six RVs from MeadowLake flew up I apparently was the only one this year. Weather was great. Air was calm and cool at 14,500' The following picture was taken a few years ago http://www.pcisys.net/~ronlee/RV6A/Granby2003/GrandLakeSmall.jpg As soon as I got out of the plane I noticed a really nice smell to the air. It was probably a combination of crisp air, trees and some moisture. There was a good variety of planes including the normal multiple RVs I hung around for about an hour (perhaps a record for me) then departed. As I crossed the mountains to the plains I listened to the MeadowLake unicom and a pilot was complaining about the runway in use. The norm here is to land/take-off on Rwy 15 when the winds are about 5 knots and less. Some people want to use Rwy 33 with the slightest amount of breeze out of the north. So instead of listening to the whining I called Denver approach to make sure that I was not in their preferred arrival/departure path. By the time that they cut me loose (got rid of me) there were no pattern problems at MeadowLake. The MeadowLake runway was recently slurried and looks really great compared to recent years: http://home.pcisys.net/~ronlee/00V.jpg Ron Lee ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Re: Heat muff overheat?
Hello Larry, If you have used a correctly designed cabin heat door or valve on the firewall there should not be any need to cut off the flow at the supply end. A correctly designed heat door will spill the muff heated air out to the hot side of the firewall area in the closed position. If you wish to cut of the flow of heated air to the lower reaches of the hot side for cooling and or drag reasons then I would suggest that the heat muff and hoses for same should be removed for the reasons that you have already suggested. This of course will disable the cabin heat feature but would most likely reduce drag by some very hard to measure amount. Jim in Kelowna - The 6-A slider weighed in at 1134 LB.today O360-A1A with CS. Have not done W&B as yet ----- Original Message ----- Sent: Tuesday, July 04, 2006 8:15 PM > > Are there any problems closing off the air flow to the heat muff during > the > summer months? It's air supply is a 2" hole off the baffling behind > cylinder #3. My concern is that without the flow through the heat muff, > it > may get too hot and melt or burst into flames or worse! What do you > think? > > - > Larry Bowen, RV-8 196 Hrs. > Larry(at)BowenAero.com > http://BowenAero.com > > > ________________________________________________________________________________
Date: Jul 04, 2006
Subject: Re: D10A magnetic sensor alignment
You CAN measure the orientation pretty easily. Get out the digital protractor...or it's time to beg/borrow/steal one if you don't have one already. They're nifty little tools, worth blowing the bucks on imho. See the photos on the bottom of this page: http://www.rvproject.com/20030806.html and one at the top of this page: http://www.rvproject.com/20030809.html )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- Sent: Tuesday, July 04, 2006 8:20 PM > > I ordered my D10A with the external magnetic (compass) sensor. I was > thinking of installing it in a wingtip or behind the baggage bulkhead, > perhaps. > > I just read the installation manual which says the magnetic sensor should > be installed oriented to match the orientation of the D10A (in the panel) > in pitch, roll, and yaw to an accuracy of better than 1 degree. This > sounds impractical. Positioning it relative to a longeron or rib or any > component of the airplane could easily have 1 deg. of error in it.You'd > have to be able to measure the orientation of both units in an absolute > sense somehow to get this kind of accuracy. Perhaps with a surveyors > transit and an electronic level I could work it out, but I have neither. > > What have other people done? Does it really need this kind of accuracy? > Or am I the only one foolish enough to order it this way? > -- > Tom Sargent, RV-6A > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Date: Jul 05, 2006
Subject: Fossil energy fuel to produce ethanol
No reputable source is needed Larry. The fact of the matter is, you can not get 100% ethanol directly from ANY source, it always comes along with some water mixed in (ever make, wine beer or hooch). So.......it takes some OTHER source of heat (fossil fuel, nuclear energy, wind power, etc) to distill the water out and get the pure alcohol. As you surmised, it does not make sense, it's just enviro-wackos stabbing at anything to get rid of fossil fuels. When we've succeeded in replacing oil, they will find something wrong with alcohol to bitch about. Since alcohol is a hydrocarbon, like oil it produces carbon dioxide. But the enviro-wackos have ignored that fine little detail right now, they just want to get rid of those EVIL fossil fuels. Trust me, if we had the "perfect" energy source that's fully renewable and generates no toxic waste products or CO2 (I don't consider CO2 a hazard to our planets health) they would still find something "evil" about it! Dean Psiropoulos RV-6A N197DM _________________________Original Message_________________________________ Would someone please point us to a reputable reference that authenticates it requires more fossil energy fuel to produce ethanol energy than we get back? How can that make sense if oil is in short supply? Why waste .3 gallons of it? ________________________________________________________________________________
Date: Jul 04, 2006
Dan: Thanks for the pictures (and whole website, for that matter), but measure it relative to what? I think I can position it within a degree relative to some bulkhead, but can't the bulkhead be slighly misaligned with the whole plane or at least the instrument panel? A degree isn't much. Dan Checkoway wrote: > > You CAN measure the orientation pretty easily. -- Tom Sargent ________________________________________________________________________________
Date: Jul 04, 2006
Relative to the instrument head itself. Basically measure the angle of the panel, and add 90 degrees. That gives you your longitudinal offset. Since the panel itself should be level laterally, level the EDC-D10 laterally. "Yaw" is removed from the equation by using a bulkhead as the reference perpendicular to the aircraft's centerline. )_( Dan ----- Original Message ----- Sent: Tuesday, July 04, 2006 10:37 PM > > Dan: > Thanks for the pictures (and whole website, for that matter), but > measure it relative to what? I think I can position it within a degree > relative to some bulkhead, but can't the bulkhead be slighly misaligned > with the whole plane or at least the instrument panel? A degree isn't > much. > Dan Checkoway wrote: > >> >> You CAN measure the orientation pretty easily. > > -- > Tom Sargent > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 05, 2006
Ditto what Dan said. Getting the thing level and plumb is not as hard is they make it sound. Get yourself a digital level. Lay it across the top of the Dynon face and compare it to a level laid across the longerons, and you've got the roll axis figured out. Make a board about 6 inches long and 4 inches tall, so that you can lay the board on the top of the Dynon body (lengthwise) and lay the level on that. Obviously make sure the wood shim has exactly parallel sides. Bingo, you've got the pitch axis figured. As for the yaw axis, you can get it close by measuring against other bulkheads, including the instrument panel, but I think this is the least critical of the three, since changes to the yaw axis are what you are measureing with the unit, and a degree or 2 of install error will be cancelled out in the calibration process. As for mounting, I think my solution is about the easiest. Make an aluminum mount to get it close, then use the brass screws and washers as shims to get it dead nuts on. http://home.mindspring.com/~rv6/RV6site/Dynon.htm Jeff Point RV-6 Milwaukee 13 days and counting till Osh...... > ________________________________________________________________________________
Date: Jul 05, 2006
> > Are there any problems closing off the air flow to the heat muff during the > summer months? It's air supply is a 2" hole off the baffling behind > cylinder #3. My concern is that without the flow through the heat muff, it > may get too hot and melt or burst into flames or worse! What do you think? > > Larry Bowen, RV-8 196 Hrs. > Larry, I have a hot/cold air mixer valve that dumps a small portion of the heated air when set for full cold air to the cabin. It does this thru a hole in the valve that is about 5/8" diameter as I remember. I also have two heat muffs in series so the heated air passing thru the valve is quite warm. Have 120 hours on the system and no indication of deterioration of the system. This would seems to indicate that you could perhaps substantially block the 2" opening but allow some air to continually pass to moderate the muff temperature. Dale Ensing ________________________________________________________________________________
Date: Jul 05, 2006
Subject: RE MOGAS Use With FI Engines
Thanks, Charlie- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jul 05, 2006
>posted by: "Jim Sears" > Oh? I'm sure glad you told me. I've been flying on > auto gas for 20 years and don't have every part of > my fuel system insulated. I do insulate the lines with > firesleeve and do put blast tubes to the pump.That's > it. My Cheetah didn't even have the blast tubes.Jim > Sears in KY Jim: Thanks for the very detailed response, I learned a lot. You clearly have way more experience with Auto Gas in planes than I. However you miss quote or miss read a few things. No need to repeat everything, but let me address a few things. I think you gloss over and paint a very rosy picture that may be less than typical. I think your fuel savings is at the extreme MAX of what is possible. In the real world it's much less, but first....... First let be say the most important thing is Auto gas in planes CAN cause loss of power, engine failure. That is the main reason for NOT using it. The important thing to remember 160, 180 and 200 HP Lycomings need premium Auto gas and that is NOT available for purchase right out of an airport pump. One better consider the facts of hauling fuel around to fill your plane from the corner gas station: Hassle, legality, safety and lack of availability away from home. The price savings if you HAUL YOUR own gas can be good, especially IF you can use 80/87 octane. However if you buy from the airport if avail, the price diff between AVgas and MOgas is often measured in dimes not dollars. Any one can do a search for gas prices nation wide. Avgas avg $4.28 min $2.90 max $7.05 Mogas (auto) avg $3.17 min $1.75 max $5.10 Premium (auto) avg $3.35 min $x.xx max $x.xx As you can see price varies; 100LL can be CHEAPER than AUTO GAS! Yes you can play games and that the Low of one and the high of another and go WOW, look at that. The real world and Murphy's law says the savings will be much smaller. IF you just look at average you can see you will may be save $1.00 on average. That is about $8.00/hr on my plane. OK, that is great, about 100 hrs a year that is $800. However 1/2 of my flying is X-C and I likely could not get premium auto gas, so that savings is $400, but than again I might find some $3.00 AVgas. That $400 will cost me the hassle of hauling and storing fuel. Add the worry of Vapor Lock.... no thanks. If you need premium, again check the price of premium auto gas (from the corner station) & AVgas. Premium Autogas can be over $3.00/gal. AVgas in the low-mid $3-$4 range. Not the $1.50 you say. I believe you but not everyone lives in Kentucky, which has the lowest car gas price nation wide. Good for you Mr. Smug. You have a very provincial and narrow focus, other (most) states, savings not so great. If you are going to go around the patch in KY than haul your own gas might work. Travel cross country and buy MOgas at the airport, the price difference is not that great. ANY ONE can verify that for themselves. If your engine was certified for 91/96 octane you need to get Premium and you will not fine that in a X-C flight. If you price premium Vs. AVgas the price is again in dimes not dollars. Again this is easy to look up on the web. Assume 50 cent savings per gal and 8 gal an hr burn, $ 4.00. Say it is double that, $8.00. Is it worth it to flame out your engine on a hot day takeoff? Will that gas savings rebuild your airplane you just Ball'ed up in the corn field (if you are lucky). Good for you that you live in a state that does not require Alcohol or Ethanol. It is widely known that your days are numbered. The good old Fed Gov will force that down our / your throat sooner than later. I am glad your RV-6A is working well. However a Grumman Cheetah is a BIG cowl compared, and the exhaust pipes do not snake and wrap around the Carb like they do on a RV. I do know that. To quote Lycoming why not to use Auto fuel: ENGINE FAILURE. Yea I know Lycoming does not know anything. Yea I know you have done it and live a charmed life and nothing ever will go bad because of your experience in Kentucky. Vapor Lock is a REAL issue. Please don't gloss that over, that is disingenuous and not forthright. Pouring your OWN gas into your plane is NOT allowed at most Muni Airports. Even large gas tanks on personal property are regulated and restricted by law. Also there is a big difference in one 5 gal gas can and a 55 gal barrel or ten (5) gal jugs. Check out Haz material laws for your state, I know. Just because you can get away with it, may not be a good reason to do it. I am sure gas station attendants will question you filling your 10 jugs that are more than a car fill-up by a factor of 3 or 4. Handling Gas is not without danger. No thanks, and your reward for all the effort is worry if you will lose power on takeoff or climb on a hot day. Yes there are hotter places than Kentucky. Thanks for the info but I think you have been somewhat lucky. I know experimentals don't need STC btw and said that. However you gloss over the fact some planes can not get a STC. Than you correctly state we can learn from STC's. Well Take the HINT. RV's are very tight cowls and have little in common with a Grumman. I am not saying don't do Auto gas but at least know what you are getting into and the real RISK! That is all. Cheers George M --------------------------------- at 1/min. ________________________________________________________________________________
Date: Jul 05, 2006
Thanks Dale and others for the input. Yes, I have the standard heat muff/heat box/etc setup. The objective is to patch the 2" "hole" in the baffling to maximize cyl head cooling during the hottest summer months. Taking the whole system out is an option, but patching the baffling hole is a simpler option. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Dale Ensing wrote: > >> >> Are there any problems closing off the air flow to the heat muff during > the >> summer months? It's air supply is a 2" hole off the baffling behind >> cylinder #3. My concern is that without the flow through the heat muff, > it >> may get too hot and melt or burst into flames or worse! What do you > think? >> > Larry Bowen, RV-8 196 Hrs. >> > > Larry, > I have a hot/cold air mixer valve that dumps a small portion of the heated > air when set for full cold air to the cabin. It does this thru a hole in > the > valve that is about 5/8" diameter as I remember. I also have two heat > muffs > in series so the heated air passing thru the valve is quite warm. Have 120 > hours on the system and no indication of deterioration of the system. > This would seems to indicate that you could perhaps substantially block > the > 2" opening but allow some air to continually pass to moderate the muff > temperature. > Dale Ensing ________________________________________________________________________________
Date: Jul 05, 2006
I've tried to stay out of this food fight, but want to make a few comments. I've been using Auto fuel in my Pitts (modified O-360-A4A with high lift cam) and PS-5 (modified too for increased fuel flow) pressure carburetor for 26 years now. In Florida. With no electrical system. It really likes hi-test (92 or 93) but will run on 87 if the engine doesn't get hot like when doing heavy akro. George appears to be in the anti auto fuel camp and I'm on the other side. I'm not going to convince George (or anyone else) that they should switch to auto fuel. If they want to, great, and if they want to use a strictly 100LL diet, that's great too. My only complaint is that George makes statements without any FACTS to back them up. Like Jim, I've used auto fuel in my Grumman too. For years. The only gripe I have with Auto fuel is that it coats the inside of the sight gauges with a red film over time, and I have to disassemble them to clean them. Like Jim, I find that the benefits outweigh the hassle of carting fuel to the airport. The benefits have all been discussed here already so I won't repeat them. For me, the purchase cost is lower, and then I can remove the federal excise tax when I file for my federal taxes. Legally. Just my two pennies worth. YMMV and the best you can do with this disagreement is to agree to disagree and move on. If you're interested in using auto fuel, do your own research. I know, it'll take some time, but best to get the facts separated from urban legend. Learn what typically creates vapor lock and how to ameliorate the contributing factors. All I ask is that you approach the fuel dilemma with an open mind and do your fueling safely. And do your own research. There are experts out there, and they may, or may not, be listening on these lists. Linn gmcjetpilot(at)yahoo.com wrote: > >posted by: "Jim Sears" > > > Oh? I'm sure glad you told me. I've been flying on > > auto gas for 20 years and don't have every part of > > my fuel system insulated. I do insulate the lines with > > firesleeve and do put blast tubes to the pump.That's > > it. My Cheetah didn't even have the blast tubes.Jim > > Sears in KY > > Jim: > > Thanks for the very detailed response, I learned a > lot. You clearly have way more experience with Auto > Gas in planes than I. However you miss quote or > miss read a few things. No need to repeat > everything, but let me address a few things. > > > I think you gloss over and paint a very rosy picture > that may be less than typical. I think your fuel > savings is at the extreme MAX of what is possible. > In the real world it's much less, but first....... > > > First let be say the most important thing is Auto gas > in planes CAN cause loss of power, engine failure. > That is the main reason for NOT using it. > > > The important thing to remember 160, 180 and 200 > HP Lycomings need premium Auto gas and that is > NOT available for purchase right out of an airport pump. > > > One better consider the facts of hauling fuel around > to fill your plane from the corner gas station: Hassle, > legality, safety and lack of availability away from > home. > > > The price savings if you HAUL YOUR own gas can > be good, especially IF you can use 80/87 octane. > However if you buy from the airport if avail, the price > diff between AVgas and MOgas is often measured in > dimes not dollars. Any one can do a search for gas > prices nation wide. > > > Avgas avg $4.28 min $2.90 max $7.05 > > Mogas (auto) avg $3.17 min $1.75 max $5.10 > > Premium (auto) avg $3.35 min $x.xx max $x.xx > > > As you can see price varies; 100LL can > be CHEAPER than AUTO GAS! > > Yes you can play games and that the Low of > one and the high of another and go WOW, look > at that. The real world and Murphy's law says > the savings will be much smaller. IF you just > look at average you can see you will may be > save $1.00 on average. That is about $8.00/hr on > my plane. > > OK, that is great, about 100 hrs a year that is $800. > > However 1/2 of my flying is X-C and I likely could not > get premium auto gas, so that savings is $400, but > than again I might find some $3.00 AVgas. > > That $400 will cost me the hassle of hauling and > storing fuel. Add the worry of Vapor Lock.... no thanks. > If you need premium, again check the price of > premium auto gas (from the corner station) & AVgas. > Premium Autogas can be over $3.00/gal. AVgas > in the low-mid $3-$4 range. Not the $1.50 you say. I > believe you but not everyone lives in Kentucky, which > has the lowest car gas price nation wide. Good > for you Mr. Smug. You have a very provincial and > narrow focus, other (most) states, savings not so great. > > If you are going to go around the patch in KY than > haul your own gas might work. Travel cross country > and buy MOgas at the airport, the price difference is > not that great. ANY ONE can verify that for themselves. > > If your engine was certified for 91/96 octane you need to > get Premium and you will not fine that in a X-C flight. If > you price premium Vs. AVgas the price is again in > dimes not dollars. > > Again this is easy to look up on the web. Assume 50 > cent savings per gal and 8 gal an hr burn, $ 4.00. > Say it is double that, $8.00. Is it worth it to flame out > your engine on a hot day takeoff? Will that gas > savings rebuild your airplane you just Ball'ed up in > the corn field (if you are lucky). > > Good for you that you live in a state that does not > require Alcohol or Ethanol. It is widely known that > your days are numbered. The good old Fed Gov will > force that down our / your throat sooner than later. > > I am glad your RV-6A is working well. However a > Grumman Cheetah is a BIG cowl compared, and the > exhaust pipes do not snake and wrap around the > Carb like they do on a RV. I do know that. > > To quote Lycoming why not to use Auto fuel: > ENGINE FAILURE. > > Yea I know Lycoming does not know anything. > > Yea I know you have done it and live a charmed life > and nothing ever will go bad because of your > experience in Kentucky. Vapor Lock is a REAL > issue. Please don't gloss that over, that is > disingenuous and not forthright. > > Pouring your OWN gas into your plane is NOT > allowed at most Muni Airports. Even large gas > tanks on personal property are regulated and > restricted by law. > > Also there is a big difference in one 5 gal gas can > and a 55 gal barrel or ten (5) gal jugs. Check out Haz > material laws for your state, I know. Just because you > can get away with it, may not be a good reason to do it. > > I am sure gas station attendants will question you filling > your 10 jugs that are more than a car fill-up by a factor > of 3 or 4. Handling Gas is not without danger. > > No thanks, and your reward for all the effort is worry if > you will lose power on takeoff or climb on a hot day. > > Yes there are hotter places than Kentucky. > > Thanks for the info but I think you have been somewhat > lucky. I know experimentals don't need STC btw and > said that. However you gloss over the fact some planes > can not get a STC. Than you correctly state we can > learn from STC's. Well Take the HINT. RV's are very > tight cowls and have little in common with a Grumman. > > I am not saying don't do Auto gas but at least know what > you are getting into and the real RISK! That is all. > > Cheers George M > > ------------------------------------------------------------------------ > rates starting at 1/min. > <http://us.rd.yahoo.com/mail_us/taglines/postman7/*http://us.rd.yahoo.com/evt=39666/*http://messenger.yahoo.com> ________________________________________________________________________________
Date: Jul 05, 2006
In a message dated 07/04/2006 7:07:09 PM Central Daylight Time, bo124rs(at)hotmail.com writes: So, when I placed the upper cowling in place, there is an increasing gap from top to bottom. Me thinks this does not look right!! >>>>> Hi Dana- Can't really say about the mounts, but looking at the picture of the cowl/spinner fit, from what I've seen (my own and quite a few others) this is a standard fit from Vans. Not hard to fix- if interested holler at me... Mark ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Re: Fossil energy fuel to produce ethanol
I'm one of those enviro-wackos mentioned in Dean's letter. Yep, I believe we should get off the oil-based economy so that we can stop caring how much the people in the mideast hate each other, so we can stop shelling out billions to foreign countries to fuel our cars, and so that we can reduce the harmful effects petroleum has on our environment. Oh, and it's running out, anyway. That makes me a wacko, I guess. Dean, this is a public list with people from all walks of life. Check your facts before you go about intentionally insulting a bunch of people whom you clearly haven't bothered to try to understand. Don't continue to post like an ignorant bigot. Environmentalists are generally smart people who care about the world around them. They usually have pretty good reasons for the positions they take. Instead of assuming they are wackos, maybe you should actually try to understand their reasoning. You may continue to feel the other side is more important, but at least you'll have made an informed decision. They are some wackos (I don't agree with the people who spike trees, for instance, but I understand their position), but the bulk of environmentalists have solid science at their backs. Some of them even have financial data in mind, too (as I do). In any case, as another poster has said, it's not the environmentalists who are pushing for ethanol. It's the farm industry. Ethanol is a big political button in all the corn states. Despite the scientific evidence. Environmentalists, however, tend to listen to the scientists. When there's scientific evidence against something, we tend to say, "Let's not go that way." So us enviro-wackos aren't telling you to use ethanol. However, you don't need to use petroleum to produce ethanol. You can use the energy in ethanol to produce more ethanol. Okay, you have a chicken and egg thing, but once you have a barrel of ethanol, you can use that barrel to make more ethanol. If you want to sell a barrel of ethanol, first you have to make 5 barrels. Sell one barrel. Use the remaining 4 to make 5 more. Sell 1. That's the ratio. (Or I might be off by one, it might be 6 to sell 1, I'm going from memory). Oh, and the poster who linked to the Sierra Club (yes, I'm a member) -- the poster child for us enviro-wackos is Greenpeace. I'm not a member, but I periodically give them money. They state an anti- ethanol policy the same as the Sierra Club. -Joe On Jul 5, 2006, at 12:09 AM, DEAN PSIROPOULOS wrote: > > > No reputable source is needed Larry. The fact of the matter is, > you can not > get 100% ethanol directly from ANY source, it always comes along > with some > water mixed in (ever make, wine beer or hooch). So.......it takes > some > OTHER source of heat (fossil fuel, nuclear energy, wind power, etc) to > distill the water out and get the pure alcohol. As you surmised, > it does > not make sense, it's just enviro-wackos stabbing at anything to get > rid of > fossil fuels. When we've succeeded in replacing oil, they will find > something wrong with alcohol to bitch about. Since alcohol is a > hydrocarbon, > like oil it produces carbon dioxide. But the enviro-wackos have > ignored > that fine little detail right now, they just want to get rid of > those EVIL > fossil fuels. Trust me, if we had the "perfect" energy source > that's fully > renewable and generates no toxic waste products or CO2 (I don't > consider CO2 > a hazard to our planets health) they would still find something > "evil" about > it! > > Dean Psiropoulos > RV-6A N197DM > > ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Re: MOGAS Use With FI Engines
Linn- I'm a bigtime mogas user and one of the guys who hauls premium mogas home to the hangar by the hundred-gallon tankload. I have been filing for a rebate on the ~15 cents/gallon state road tax for years, but was unaware you could get back the federal tax as well, which should be quite substantial. How do I go about doing that? Thanks. -Stormy -----Original Message----- I've tried to stay out of this food fight, but want to make a few comments. I've been using Auto fuel in my Pitts (modified O-360-A4A with high lift cam) and PS-5 (modified too for increased fuel flow) pressure carburetor for 26 years now. In Florida. With no electrical system. It really likes hi-test (92 or 93) but will run on 87 if the engine doesn't get hot like when doing heavy akro. George appears to be in the anti auto fuel camp and I'm on the other side. I'm not going to convince George (or anyone else) that they should switch to auto fuel. If they want to, great, and if they want to use a strictly 100LL diet, that's great too. My only complaint is that George makes statements without any FACTS to back them up. Like Jim, I've used auto fuel in my Grumman too. For years. The only gripe I have with Auto fuel is that it coats the inside of the sight gauges with a red film over time, and I have to disassemble them to clean them. Like Jim, I find that the benefits outweigh the hassle of carting fuel to the airport. The benefits have all been discussed here already so I won't repeat them. For me, the purchase cost is lower, and then I can remove the federal excise tax when I file for my federal taxes. Legally. << snipped ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Re: RE MOGAS Use With FI Engines
Glen, You can try anything you want. If it damages the engine you're the only one who has to pay. I fully intend to use auto fuel in my RV8A. I'm currently trying to find someone to make a tuned 4 into 1 exhaust system for the A model RVs. With the capability to reduce your fuel consumption by .75 to 1 gallon per hour, a 4 into 1 tuned exhaust is one of the best investments you can make in your RV. Check out the CAFE Foundation's web site for more info. Charlie > >Thanks, Charlie- > >glen matejcek >aerobubba(at)earthlink.net > > ________________________________________________________________________________
Date: Jul 05, 2006
Keep me posted on that exhaust, Charlie. Interest level would be very high for me... -Stormy -----Original Message----- Glen, You can try anything you want. If it damages the engine you're the only one who has to pay. I fully intend to use auto fuel in my RV8A. I'm currently trying to find someone to make a tuned 4 into 1 exhaust system for the A model RVs. With the capability to reduce your fuel consumption by .75 to 1 gallon per hour, a 4 into 1 tuned exhaust is one of the best investments you can make in your RV. Check out the CAFE Foundation's web site for more info. Charlie Thanks, Charlie- glen matejcek aerobubba(at)earthlink.net Email Forum - http://www.matronics.com/Navigator?RV-List - NEW MATRONICS LIST WIKI - http://wiki.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Lightspeed with Keyswitch and 1 Mag Wiring
This is a repost of previous info. I had a builder ask me about it and I couldn't find it in the archives well, so I thought I'd resend it with a good subject line. ----- Wiring a Keyswitch Ignition - Lightspeed Plasma III/II+ ignition and a Mag Another non-RV10 builder, Dave Sundberg passed this on to me previously, and I wired mine this way and it indeed works fine. It does seem a bit like black magic, but seeing as it works fine I won't be complaining. Test it out before and after you run the engine, but it should work fine. The configuration is a Mag on the Left side, feeding the lower plugs, and a Lightspeed Plasma III (or II+) feeding the top plugs as the Right system. Note that allthough Lightspeed calls it a keyswitch "Option", it's always on the system, just optional to connect. * The P-Lead from the Mag goes to the L-Terminal on the Switch with the shield connected to the GRN terminal on the mag and not connected to anything on the switch end. * The P-Lead from the LS (Pin 1) goes to the R-Terminal on the switch and the shield (Pin 9) goes to the GRN-Terminal in the center of the switch. * Do not connect the jumper from the R-Term to the GRN-Terminal next to it. * Do not connect the center GRN-Terminal on the switch to aircraft ground. Both ignitions are grounded out with the switch in the OFF position. Dave had been flying and it was working for him. I am flying too and it's working great for me. I had previously spent time hooking mine up and ohming things out and was confused as heck. I also was confused in that the P-Lead on the mag is seemingly shorted to ground even with the wire disconnected, so I couldn't easily tell that it would be grounded by the switch. (Turns out this is normal) If you hook it all up, except for the mag P-Lead, you can indeed see that they ground the way their supposed to by using your ohmmeter. I also have this posted on my Electrical Tips section on my site. Tim -- Tim Olson - RV-10 N104CD - Flying ________________________________________________________________________________
Date: Jul 05, 2006
Subject: 4 into 1 exhaust
Charlie, Have you talked to these people? http://www.aircraftexhaust.net/ I see that the have one that doesn't list the A models, but maybe they'll make one up for you. Pax, Ed Holyoke -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie Kuss Sent: Wednesday, July 05, 2006 7:47 AM Glen, You can try anything you want. If it damages the engine you're the only one who has to pay. I fully intend to use auto fuel in my RV8A. I'm currently trying to find someone to make a tuned 4 into 1 exhaust system for the A model RVs. With the capability to reduce your fuel consumption by .75 to 1 gallon per hour, a 4 into 1 tuned exhaust is one of the best investments you can make in your RV. Check out the CAFE Foundation's web site for more info. Charlie Thanks, Charlie- glen matejcek aerobubba(at)earthlink.net Email Forum - http://www.matronics.com/Navigator?RV-List - NEW MATRONICS LIST WIKI - http://wiki.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 05, 2006
sportav8r(at)aol.com wrote: > Linn- > > I'm a bigtime mogas user and one of the guys who hauls premium mogas > home to the hangar by the hundred-gallon tankload. I have been filing > for a rebate on the ~15 cents/gallon state road tax for years, but was > unaware you could get back the federal tax as well, which should be > quite substantial. How do I go about doing that? > > Thanks. > > -Stormy > There's a federal form you file with your taxes. Try 4136 .... go to http://www.irs.gov/ and search for 4136 Linn ________________________________________________________________________________
Date: Jul 05, 2006
Date: Jul 05, 2006
On 9:32:12 2006-07-05 linn Walters wrote: > There's a federal form you file with your taxes. Try 4136 .... go to > http://www.irs.gov/ and search for 4136 Direct link: http://www.irs.gov/pub/irs-pdf/f4136.pdf -Rob ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Re:MOGAS Use With FI Engines
George (aka gmcjetpilot), Cheapskates? Puhleeze!!! With due respect, not all of us are highly paid Boeing drivers such as yourself :-) ... As soon as my XP-IO360 flies (soon, very soon...), I fully intend to save myself 4.05-2.93=1.12/gal x 8.5=9.52x150hrs/yr= $1428. That is enough to entirely offset the cost of insurance each year. I think that is significant. Hauling it to the airport? No problem for anyone with a pickup. Aux transfer tanks of any config like the farmers use to fuel their tractors, combines, etc. are available all over the country complete with hoses/pumps. Totally legal, BTW... Or, in my case the 1994 F-150 with dual tanks, and 50 gal capacity, a bit of creative plumbing will get the job done nicely. According to my engine manual, Superior not only allows the use of 91 oct, but encourages it, FWIW... Methanol? Easy as pie to test for. Alcohol-free mogas has been available year round outside our metro area. (KPDX). However, if the politicians have their way, may not continue... Illegal to have a tank on your own property? Tell it to my local fire marshall who issues the permits to anyone with an acre of ground for "farm use" of course... Obviously George, you are not a country boy... hoho... Cheers, Jerry Cochran Wilsonville, OR ANY CAR GAS OR MO GAS HAS LOWER VAPOR PRESSURE AND IS SUBJECT TO VAPOR LOCK. JUST A NOTE: MO gas is what you can buy out of a pump at the airport, MO gas for Motor Gas. Auto Fuel, is what you get at the corner gas station. MO Gas is like 86 octane. If you need 91 octane you need to get premium from the corner gas station. The problem is your plane is at the airport. (not much price difference from premium to 100LL) So to use Auto fuel in your plane you are faced with the hassle of hauling fuel to the plane. This can be a huge hassle, dangerous and illegal. At most airports and with state highway laws (hazardous material transport) a NO NO. You are just not going to be hauling eight 5 Gal jerry cans around or 55 gal barrels with gas easily. I can see all the cheapskates thinking of the cost savings they will get. In fact the saving is small if impractical for 91 octane engines. If you have a low compression engine that can run on MO gas than sure there is some advantage. HOWEVER A RV tight cowl is NOT ideal for MO gas operations. Also price of MO Gas is not that much less than 100LL or can you even get MO gas widely. Some times MO gas cost more than 100LL. So you might be taking abut $4.00/hr savings for all the hassle. Fuel Injection has nothing to do with it, it is compression ratio. All the original STC's where for low compression engines that where made for like 80 octane. There are premium gas STC's for Lyc 320/360's with the 8.5:1 CR, which needs 91 octane, but not all planes can pass the test and get a STC, even after much effort. A 150HP O320 is a low octane engine, a O235 is NOT. The INSTALLATION is critical. When a STC for auto fuel is given it is for the installation as well as the engine. YES I know we are experimental but you can't ignore physics. I recall airplane like the older Mooney's with the O360 can't get a STC for premium auto fuel because of vapor lock. Like RV's the Mooney have very tight cowls. Don't compare the Piper with a huge cowl and a RV with a very tight cowl and exhaust pipes snaking all around near fuel lines. The overall issue is you will not get AUTO GAS with out all the hamburger helper and modified fuel like alcohol and ethanol. I remember in Washington state, in the winter they went to an alcohol blend fuel. My gas milage went in the crapper. That is the other issue. Car gas is NOT CONSISTANT. It varies widely by region, session and testing is a hassle. If you do go auto fuel insulate and heat shield EVER part of the fuel system and add a vapor return line even for Carb engines. >From: "Tracy Crook" <lors01(at)msn.com> > >My RX-8 rotary (10 : 1 CR) powered RV-4 runs best and >gets best fuel economy on 87 octane. I burn 100LL in a >pinch but plug life is greatly reduced. Automotive and aircraft engines are two differnt things. RX8 cars strictly call for premium and use 2 qts of oil between oil changes, and also get terriable gas millage. I know you are a rotary expert Tracy but a water cooled car engine piston or rotary is not an aircooled aircraft engine. My Lyc plug life is 1000 hour plus on 100LL. I am not picking on you Tracy but you have to take the good with the bad. Good, you can use auto fuel; Bad, your engine is noisier, heavier and burns way more fuel than a Lycoming for equivalent performance. >Best experts I've read say that almost all aircraft engines >would work fine on 91 octane mogas. Most aircraft engines where certified for 91, like 320 (160HP) and 360 (180 hp) Lycoming. So that is a no brainer, The problem is the MO gas you can buy at the airport is way less than 91 octane, like 80/86. If you want premium AUTO fuel you have to haul. And the idea of having your own tank, even on your own property is likely to be illegal in most states. ________________________________________________________________________________
Date: Jul 05, 2006
If I were to say "I don't agree with suicide bombers, but I understand their position," I would expect most of you to be offended and question my intelligence or sincerity or ethics, or all three. If I were to say, "I don't agree with fire-bombing expensive new homes, but I understand the fire-bomber's position," or "I don't agree with people who sabotage small airplanes, (presumably because I don't like their noise flying over wilderness areas) but I understand their position", I would expect all hell to break loose, and it should. Giving sympathy to terrorists of any stripe supports not only their cause but their tactics. So when Joe Larson says "They are some wackos (I don't agree with the people who spike trees, for instance, but I understand their position).", I would expect someone to object to acceptance or sympathy for this form of terrorism. Maybe you don't understand was it means to spike a tree. It means to drive a spike into a tree in a location and in a manner so that it will not be seen by the logger, and so that when a logger with a chainsaw tries to fall (fell) the tree, he will hit the spike, causing the saw's chain to explode off the saw and cause mayhem to the logger, or if the logger is lucky, to destroy the huge high-speed band saw blade in the mill and cause mayhem to the mill workers. It is a form of terrorism used to prevent the owners of timber from harvesting timber on their own property, or timber legally purchased from other private or public timberland owners. Unlike tree sitters or people who chain themselves to equipment in order to prevent something from happening, tree spikers are sabotaging the tree so that anyone attempting to use it runs a high risk of injury or death. So, if by "understand their position," Joe, you mean that there is any possible justification for what they are doing; I really hope you don't know what you are talking about. If anyone cares, I consider myself a free-market environmentalist. I have a university degree in forest management (now called natural resource management) and am old enough and lucky enough to have spent time in the timber country of the northwest when the sound of a saw cutting down a tree was the quiet swish-swish of a long cross-cut saw being pulled back and forth by muscle power. With parents who survived the Depression, I grew up knowing that waste was bad - very bad - and that re-cycle and re-use were the norm, not the exception. Maybe this is why the modern-day save-the-world trendy authoritarian brand of environmentalism frosts me so much. Clean up your own act before you try to tell me what I can and cannot do with what I worked hard to have. Why do your 'solutions' to preserve an eco-system invariably involve top-down command and control, in complete contradiction of the natural give and take that characterizes the ecosystem itself? My apologies to Michael and others who thought this list was about building little airplanes. Terry RV-8A finishing Seattle ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Jul 05, 2006
These are them same Scientists who said "We are moving into an Ice Age in the mid 1970's!" They have always claimed to be the "Only intelligent opinion" around. "Liberal arguments always are emotion based while claiming intellectual superiority." The Scientific Community was wrong in the 70's and many of the same scientists are on the Global Warming Band Wagon today. Let's get back to building RV's! DO NO ARCHIVE Tom in Ohio ----- Original Message ----- Sent: Wednesday, July 05, 2006 10:06 AM > > >. . Environmentalists are generally smart people who care about the >world around them. They usually have pretty good reasons for the >positions they take. Instead of assuming they are wackos, maybe you >should actually try to understand their reasoning. You may continue to >feel the other side is more important, but at least you'll have made an >informed decision. > >>> > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 05, 2006
Does anyone know what the Research Octane + Motor Octane divided by 2 would equal for 100LL Aviation Gasoline? (R+M / 2) The highest the R+M / 2 current pump sticker would have ever been for the 103 octane premium (Union 76 Super & Chevron white pump) would be about 96. Pete Cowper Union Oil Company of California 1972-84 ________________________________________________________________________________
Date: Jul 05, 2006
Subject: Re: How to turn an RV-9A fuse over?
I did something similar, but this is great. Mark is too modest to tell you, but he is a two time winner of EAA awards, first the Lindy and now a Best Metal. Thanks for sharing Mark. ....or just put it on a rotisserie- MUCH easier to do all kinds of stuff! 8-) http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5373 Mark ________________________________________________________________________________
Date: Jul 05, 2006
The whole pop-culture enviro movement is based upon an mostly JUNK science. Global warming, my eye! What caused the previous warming cycles of the last million years? Dinosaur flatulence? So we need to reduce dependence upon foreign oil? How about opening up coastal exploration?! It's too destructive for the US to drill off the Florida coast, but not for Cuba and China to drill there. I'm an engineer. A real one with a degree, a license and experience in petroleum refining. If you enviros really want to get off petroleum, then you'll have to wait about 10-20 years while we BUILD about 200 NUCLEAR POWER PLANTS!!! But we can't do that because it's such an evil danger!! You know - like the world ending with all the "Three Mile Islands" that were destined to end the world. So now our existing gasoline production is further bastardized with this foolish ethanol fantasy. You want to know why gasoline costs $3.15 a gallon? In part due to ethanol, part due to the illogical and inane efforts of the EPA and their 50+ formulations of gasoline mandated across the US. I'm also a naturalist. I like trees, clean water, air, birds and fish. But there's a big difference between a naturalist and an enviro whacko. It's called logic and science, and a lot less Algore hype-fiction. So why do the enviros want to prohibit use of petroleum through restricted drilling, restricted refining, displacement with ethanol? Read plank 6 of the Communist Manifesto. Bryan Jones Houston Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45095#45095 ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Idle Mixture in Fuel Injected Engine
My experience with carburated engines was that a proper idle mixture usually results in a momentary RPM increase when using the mixture to shut the engine down. I've noted that when I shut down my fuel injected engine using the mixture control, I get NO increase in RPM before the engine quits. Is the no increase in RPM typical of FI engines, or am I running too lean? Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Re: Idle Mixture in Fuel Injected Engine
Probably, consult the maintenace manual, you will likely need some hoses and a guage to setup your fuel injection system to spec. its also good just to check this out every 2 years or so just to make sure everything is working the way its supposed to. ----- Original Message ----- Sent: Thursday, July 06, 2006 4:47 AM > > My experience with carburated engines was that a proper idle mixture > usually results in a momentary RPM increase when using the mixture to > shut the engine down. I've noted that when I shut down my fuel injected > engine using the mixture control, I get NO increase in RPM before the > engine quits. > > Is the no increase in RPM typical of FI engines, or am I running too > lean? > > Charlie Brame > RV-6A N11CB > San Antonio > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 06, 2006
Subject: RE: 4 into 1 exhaust
Hi Charlie- There was a company somewhere in the Virginias that was making 4 into 1 systems a few years back. Sorry, I don't recall the name- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Re: sun shades
Bill, come see the great one and I will show you what I use. It is a suction cup sunshade that I got at Pep Boys. It comes in a small folded up size (with pouch). The advantage over the Koger is that you can move it to different locations based upon sun direction and your flight path. Ron Lee ________________________________________________________________________________
Date: Jul 06, 2006
Automotive tint film (the static cling kind) as sold by Wal-Mart has worked well for me. From one roll of the stuff you can cut out numerous small shades which let you and your pax slap them up wherever needed and reposition as the flight progresses. A nice under-$10 solution. -Stormy -----Original Message----- Bill, come see the great one and I will show you what I use. It is a suction cup sunshade that I got at Pep Boys. It comes in a small folded up size (with pouch). The advantage over the Koger is that you can move it to different locations based upon sun direction and your flight path. Ron Lee ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Re: 4 into 1 exhaust
Listers, AET was recently sold by the original owner. He sold the assets to two different companies. One of the new owners has no interest in low volume production. The other new owner is not yet settled into this new business and reports that they won't even consider new items for at least 6 months, maybe longer. We tried to arrange a group buy of 4 into 1 exhausts on the Yahoo RV8 group, but it fell through due to this sale. Charlie Kuss >Charlie, > >Have you talked to these people? > ><http://www.aircraftexhaust.net/>http://www.aircraftexhaust.net/ > >I see that the have one that doesn't list the A models, but maybe >they'll make one up for you. > >Pax, > >Ed Holyoke > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie Kuss >Sent: Wednesday, July 05, 2006 7:47 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: RE MOGAS Use With FI Engines > >Glen, > You can try anything you want. If it damages the engine you're the > only one who has to pay. I fully intend to use auto fuel in my > RV8A. I'm currently trying to find someone to make a tuned 4 into 1 > exhaust system for the A model RVs. With the capability to reduce > your fuel consumption by .75 to 1 gallon per hour, a 4 into 1 tuned > exhaust is one of the best investments you can make in your RV. > Check out the CAFE Foundation's web site for more info. >Charlie > > >Thanks, Charlie- > >glen matejcek >aerobubba(at)earthlink.net > > >Email Forum - > >http://www.matronics.com/Navigator?RV-List >- NEW MATRONICS LIST WIKI - > >http://wiki.matronics.com >- List Contribution Web Site - >-Matt Dralle, List Admin. >http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Jul 06, 2006
They seem to be called Suncutters now: http://www.auto-expressions.net/SunGlareReduction.pdf Ron Lee ________________________________________________________________________________
Date: Jul 06, 2006
http://www.autobarn.net/ac40712.html $5.99 for 2. I have 4 in the plane. 2 stay in my rear window (tip-up RV-7) all the time during summer. )_( Dan RV-7 N714D (966 hours) http://www.rvproject.com ----- Original Message ----- Sent: Thursday, July 06, 2006 6:30 AM > > Bill, come see the great one and I will show you what I use. > It is a suction cup sunshade that I got at Pep Boys. It comes > in a small folded up size (with pouch). > > The advantage over the Koger is that you can move it to different > locations based upon sun direction and your flight path. > > Ron Lee > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Heater vent inlet up vs down
Fellow listers, I'm getting ready to install my heater vents on the firewall. The way I read it, the instructions say 'inlet down'. This means that when you're not using the heater, the hot air is being blown up behind the engine instead of down towards the cowl exit area. Did I miss something? Does it matter? I would think inlet up.......Did they instruct it the other way for a reason? Pictures of how folks have already done it would be appreciated. Also, If you did it one way and didn't like it......why? Ralph Capen ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Re: Cowl Louvers
Would anyone care to post a picture and the overall dimensions of the F10109 louver Van's carries? I purchased a pair of the side louvers from Race Ace http://www.raceace.com/productsside.html?x=33&y=7 and upon inspection, am having second thoughts about installing 'em before I become a little more familiar with Van's version. Thanks, Rick Galati RV-6A "Darla" 149 hours alexpeterson(at)earthlink wrote: > Van's has them. See LOUVER F-10109, I believe. > > Alex Peterson > RV6-A N66AP 761 hours > Maple Grove, MN > > > > > > > > > Greetings Listers,, > > > > Anyone know of a good source for stamped, aluminum cowl louvers? > > I am looking to increase the airflow though the cowl and was > > thinking of two louvers, placed on the bottom of the cowl, on > > either side of the inlet air scoop. > > > > Thanks,, > > > > > > > > > > Derrick L. Aubuchon > > RV-4: N184DA > > Jackson/Westover -Amador County (O70) > > n184da(at)volcano.net > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45213#45213 ________________________________________________________________________________
Date: Jul 06, 2006
Subject: N161RL Flies
Mannan, CONGRATULATIONS and WELL DONE !!!! Chuck & Dave Rowbotham RV-8 >From: "Mannan J. Thomason" <mannanj(at)alltel.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: N161RL Flies >Date: Sat, 1 Jul 2006 10:13:29 -0400 > >After 4 1/2 years and after being asked "when is it going to fly?" and my >saying Thursday, about half a million times, N161RL flew Thurs.29 June. >She's an RV-8 slow build, IO-360-A3B6D, McCauley (ugh.) Prop, Sam James >Cowl. > >Mannan Thomason >RV-8 > ________________________________________________________________________________
Date: Jul 06, 2006
Aircraft Exhaust does not do RV exhausts anymore but Tom Heid at Aerospace Welding may. I sent him my engine type and sump info for him to give me an answer. I have a RV-7A with TMX IOF-360 with Forward facing ECI cold air sump but if enough people express an interest in 4 into 1 exhausts he may decide to do it. Tom Heid Aerospace Welding 952-890-1511 Hope this helps, Danny Smith -------- Danny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45219#45219 ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Gluing Canopy Skirt - RV-8
I'm leaning towards gluing my canopy to the frame using Sikaflex as detailed in numerous posts on this list, but I'm not quite sure how to approach the issue of gluing the skirt on. It appears that Sikaflex would be ruled out due to the reqirement to have a 3/16" bead between the skirt and canopy/ frame. Someone in the archives mentioned using Scotch SemWeld. Any other suggestions, and what were the results of the SemWeld? Walt Shipley ________________________________________________________________________________
Date: Jul 06, 2006
Subject:
There is a guy in Colorado that builds quality exhausts as well. Contact info below. He has built several systems for some of our customers and will have a couple on display at OSH in our booth. We'll be in building C booth#3025. Come by and visit. Exhaust system contact: Forsling Exhausts John Forsling (303) 841-6054 forslingaviation(at)aol.com See you at OSH, Allen Barrett Barrett Precision Engines, Inc. www.barrettprecisionengines.com <http://www.barrettprecisionengines.com/> ________________________________ I've stopped 50,492 spam messages. You can too! One month FREE spam protection at www.cloudmark.com <http://www.cloudmark.com/spamnet?v1&rc=gjw23> <http://www.cloudmark.com/spamnet?v1&rc=gjw23> ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Oil fitting position
I'm installing the oil fittings for the oil cooler. The upper fitting is a 45 degree fitting and I need to know where it should point when installed. Down along side the mag (toward the center of the engine) or up and over the mag pointing toward the #4 cylinder. Jim Nelson ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Looking for Bob Hargraves
Bob Hargraves: If you monitor this list, please reply to this message. Thanks Dick Sipp RV10 40065 do not archieve ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Date: Jul 06, 2006
Walt Like you I contemplated and just about went with the Sika canopy option. The more I read, the more I realized that there isn't alot of long term historical info on this product used in this application. Decide i didn't want to be trail blazer. I finally went with the tried and true Van's method. It was alot easier than I thought and came out great. Frank @ sgu and slc.......wiring...plus.......... >From: rveighta <rveighta(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: "rv-list(at)matronics.com" >Subject: RV-List: Gluing Canopy Skirt - RV-8 >Date: Thu, 6 Jul 2006 11:46:36 -0400 (EDT) > > >I'm leaning towards gluing my canopy to the frame using Sikaflex as >detailed in numerous posts on this list, but I'm not quite sure how to >approach the issue of gluing the skirt on. > >It appears that Sikaflex would be ruled out due to the reqirement to >have a 3/16" bead between the skirt and canopy/ frame. Someone >in the archives mentioned using Scotch SemWeld. Any other suggestions, >and what were the results of the SemWeld? > >Walt Shipley > > ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Need Help with Cowling Ducts
John Goodman just finished and flew his beautiful RV-9/Suburu. His oil cooler is supplied by a 2 1/2" S.C.A.T. tube that begans in the left intake of the cowling. With the intake horizontal at the bottom of the intake, oil temps were at the very upper limit near 250F. After installing a 2 inch "temporary" 90 degree elbow (thanks to the Aviation Department at Lowe's), temps are acceptable at about 205F on 90F days here in Missouri. Does anyone have expertise in ducts in the left side of RV cowlings? Would a N.A.C.A. duct work installed at 45 degrees to the airstream on the forward underside of the cowl? Would a plain round duct work just as well? There is a guy in Dallas (?) whose RV-8 (?) has several ducts to cool his turbo chargers. The airplane has a nickname like "Greased Lightning"? Anyone know him or his experience with ducting? Please respond off list, or send me his phone number. Anyone know of a source of fiberglass ducts which would adapt well to the inside of an RV-9 cowling into a S.C.A.T. tube? Thanks everyone, Les Featherston 417-425-3595 ________________________________________________________________________________
Date: Jul 06, 2006
Subject: RE: RV-List:Fuel economy / was Fossil energy fuel.....
I've always been an efficiency nut as well. I fly all cross countries at what I consider the "sweet spot" altitudes of 11,500/12,500'. At 8000' I get 183mphtas on 8.25gph or 22mpg. 11,500' gives 178tas on 7gph for 25+mpg, and 13,500' rewards me with 171tas on 6gph for 28.5mpg. Above 15000' the efficiency starts to drop off as my 160hp Lycoming can't keep the airplane "on the step" and the reduction in TAS is greater than the reduction in fuel burn. Most people scoff at giving up 5mph, but saving 1.25gph has always been worth it to me, even back when 100LL was <$2 a gallon. Ed Bundy I typically fly higher than 8000 feet, and since I've always been an efficiency freak, my engine monitor has a readout directly in MPG (based on TAS and fuel flow). I spend a lot of time tweaking & tuning to eke out that last possible .1 mpg on those long cross countries. At 15,500 I can do a little better than 30 MPG at 175 mph TAS. Anyone else into fuel efficiency? I'd love to hear your numbers. I honestly don't know how the rotary engine compares to a Lyc when flown for max efficiency. But I suspect it isn't much different. Tracy Crook (Wacko of many types) ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Oil fittings on the case
I am doing this again as I think I failed to get the message through before. I am installing the oil fittings in the case for the oil cooler. The straight fitting goes in around the center of the accessory case. The return fitting goes in just above the right mag and just behind the oil filter. This fitting is a 45 degree unit and I need to know where to point the fitting. Does it point downward toward the center of the engine between the oil filter and right mag or out over the mag toward the #4 cylinder ? Inquiring minds want to know! Jim Nelson ________________________________________________________________________________
Date: Jul 06, 2006
Jim, On my Superior XP-I0-360 B1B (180 hp) the 45 degree fitting is rotated so it points down maybe 20 degrees from horizontal so the hose clears the oil filter. Terry RV-8A Seattle -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James H Nelson Sent: Thursday, July 06, 2006 5:54 PM I am doing this again as I think I failed to get the message through before. I am installing the oil fittings in the case for the oil cooler. The straight fitting goes in around the center of the accessory case. The return fitting goes in just above the right mag and just behind the oil filter. This fitting is a 45 degree unit and I need to know where to point the fitting. Does it point downward toward the center of the engine between the oil filter and right mag or out over the mag toward the #4 cylinder ? Inquiring minds want to know! Jim Nelson ________________________________________________________________________________
Date: Jul 06, 2006
Subject: Re: Oil fittings on the case
Mine points toward the #4 cylinder but it kind of depends on just where your oil cooler is going to be hung. I think I'd wait until you install the cooler and hoses before picking a final orientation for the fitting. Dave James H Nelson wrote: > >I am doing this again as I think I failed to get the message through >before. I am installing the oil fittings in the case for the oil cooler. > The straight fitting goes in around the center of the accessory case. >The return fitting goes in just above the right mag and just behind the >oil filter. This fitting is a 45 degree unit and I need to know where to >point the fitting. Does it point downward toward the center of the >engine between the oil filter and right mag or out over the mag toward >the #4 cylinder ? Inquiring minds want to know! > >Jim Nelson > > > > > > > > > ________________________________________________________________________________
Date: Jul 07, 2006
Subject: Re: sun sahdes
> > I was wanting to get some feedback on the kroger sunshade. I just got one > for my -8, but after looking at it, and my canopy, and reading the > instructions I am worried about it scratching the canopy over time... > Anyone have any experience with this? > Bill, have had a Koger sun shade in my 6A for year and a half with no noticeable scratches on the canopy. When I put it in, I suspected there may eventually be some rub marks (not really scratches) on the canopy but not so bad that they can't be rub out. I had some pretty bad scratches from the building process that I was able to eliminate so I am not worried about the Koger sun shade. I like it and not sorry I put it in. Dale Ensing in sunny NC ________________________________________________________________________________
From: David Fenstermacher <davidfenster(at)comcast.net>
Date: Jul 07, 2006
Subject: remove
remove ________________________________________________________________________________
Date: Jul 07, 2006
Hi Walt- As I understand it, the thick bead specified in the sikaflex instructions is to account for differential thermal expansion of the plastic window and metal window frame. The difference between the coefficient of thermal expansion for plex and steel is huge. With fiberglass and plex the difference is very much smaller, and should require a much thinner layer of adhesive. I can't give you any hard numbers at the moment, as I've not found real consistent numbers for the different coefficients yet, but I do believe a fairly thin layer is in order. Perhaps this topis is right up the alley of someone on this list?. snip-It appears that Sikaflex would be ruled out due to the reqirement to have a 3/16" bead between the skirt and canopy/ frame. Walt Shipley glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jul 07, 2006
Subject: Re: Gluing Canopy Skirt - RV-8
Hi, Just for your information, I did a RV-3 canopy with Sikaflex and after about 3 weeks the canopy got unglued! Antoine Moulin ----- Original Message ----- Sent: Friday, July 07, 2006 9:20 AM > > Hi Walt- > > As I understand it, the thick bead specified in the sikaflex instructions > is to account for differential thermal expansion of the plastic window and > metal window frame. The difference between the coefficient of thermal > expansion for plex and steel is huge. With fiberglass and plex the > difference is very much smaller, and should require a much thinner layer > of > adhesive. I can't give you any hard numbers at the moment, as I've not > found real consistent numbers for the different coefficients yet, but I do > believe a fairly thin layer is in order. Perhaps this topis is right up > the alley of someone on this list?. > > > snip-It appears that Sikaflex would be ruled out due to the reqirement to > have a 3/16" bead between the skirt and canopy/ frame. > > Walt Shipley > > > glen matejcek > aerobubba(at)earthlink.net > > > -- > > ________________________________________________________________________________
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
Date: Jul 07, 2006
This is the first I have heard of any canopy glue failures using Sikaflex. Can you provide any info as to the installation? Were all the manufacturers installation instructions followed? Scuffing, cleaner, primer, bead? Was the separation in flight or noticed on the ground? Details would be very helpful for others. Thanks Mike -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Antoine Moulin Sent: Friday, July 07, 2006 10:58 AM Hi, Just for your information, I did a RV-3 canopy with Sikaflex and after about 3 weeks the canopy got unglued! Antoine Moulin ----- Original Message ----- Sent: Friday, July 07, 2006 9:20 AM > > Hi Walt- > > As I understand it, the thick bead specified in the sikaflex instructions > is to account for differential thermal expansion of the plastic window and > metal window frame. The difference between the coefficient of thermal > expansion for plex and steel is huge. With fiberglass and plex the > difference is very much smaller, and should require a much thinner layer > of > adhesive. I can't give you any hard numbers at the moment, as I've not > found real consistent numbers for the different coefficients yet, but I do > believe a fairly thin layer is in order. Perhaps this topis is right up > the alley of someone on this list?. > > > snip-It appears that Sikaflex would be ruled out due to the reqirement to > have a 3/16" bead between the skirt and canopy/ frame. > > Walt Shipley > > > glen matejcek > aerobubba(at)earthlink.net > > > -- > > ________________________________________________________________________________
Date: Jul 07, 2006
Antoine Moulin wrote: > > Hi, > Just for your information, I did a RV-3 canopy with Sikaflex and after > about 3 weeks the canopy got unglued! > Antoine Moulin Salut Antoine, Which sikaflex product did you use? Why do you think it didn't work for you? How did you end up attaching the canopy? Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Jul 07, 2006
Bonjour Mickey, I used Sikaflex 295, primer 209,cleaner 205, the plexiglass and the frame was well sanded and thickness controled with popsicle wood sticks. I think the trouble is the paint that I used on the frame.The fix was holes and pop rivets. I am making the skirt rigth now so in few days I may have some pictures available. Antoine ----- Original Message ----- Sent: Friday, July 07, 2006 11:58 AM > > Antoine Moulin wrote: >> Just for your information, I did a RV-3 canopy with Sikaflex and after >> about 3 weeks the canopy got unglued! >> Antoine Moulin > > Salut Antoine, > > Which sikaflex product did you use? > Why do you think it didn't work for you? > How did you end up attaching the canopy? > > Thanks, > Mickey > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 finishing > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > -- > > ________________________________________________________________________________
Date: Jul 07, 2006
So it separated at the paint and not the glue? That would make sense to me. I have no doubt the glue is tougher than the paint its glued to. Mike -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Antoine Moulin Sent: Friday, July 07, 2006 1:47 PM Bonjour Mickey, I used Sikaflex 295, primer 209,cleaner 205, the plexiglass and the frame was well sanded and thickness controled with popsicle wood sticks. I think the trouble is the paint that I used on the frame.The fix was holes and pop rivets. I am making the skirt rigth now so in few days I may have some pictures available. Antoine ----- Original Message ----- Sent: Friday, July 07, 2006 11:58 AM > > Antoine Moulin wrote: >> Just for your information, I did a RV-3 canopy with Sikaflex and after >> about 3 weeks the canopy got unglued! >> Antoine Moulin > > Salut Antoine, > > Which sikaflex product did you use? > Why do you think it didn't work for you? > How did you end up attaching the canopy? > > Thanks, > Mickey > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 finishing > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > -- > > ________________________________________________________________________________
Date: Jul 07, 2006
Hi Mickey, I've been reading with interest about the glued canopy on the "8". I have a 9-A and did the Sikaflex 295/209/205 route. I used PVC tubing that had an inner diameter that matched the canopy tubing. I don't remember the wall thickness but it was around 1/8 to 3/16" thick. I cleaned the powder coated frame from Van's and lightly sanded the areas where the glue would go. Basically got rid of the shinny surface. Then went about fitting the canopy and getting final trimming as it raised the canopy off the frame the 3/16" all around. I had to watch out because the canopy had been trimmed in length on the sides for the regular installation. (not good). But I went merrily along the way. Fortunately there was enough plexi on the sides to let the screws capture it and still get to the support on the frame. I did have to make new side skirts that were taller than the originals but that was a no brainer. I glued the for and aft hoop and the backbone tubes with Sikaflex. It took me a bit of learning to limit the glue on the plexi and the tape (electrical) to try to keep a nice edge. I found out that I needed to remove the tape right after I did the glue. If I let it stay until the glue skinned over, I found out that the tape removal also took the skinned glue with it in many places. It doesn't look as nice. I used pop sickle sticks to form the exposed edges of the glue to smooth it out. It was done during April and it seems to be strong and doesn't look as it will come loose. Of course, I'm not flying yet as I'm doing FWF but the canopy has no screws any place except along the side. I think it looks good. Jim Nelson ________________________________________________________________________________
Date: Jul 08, 2006
Subject: Videos for sale - From The Ground Up - RV8
For sale: Full set of EAA's "From the Ground Up" series covering the building of an RV-8. 13 episodes. http://www.buildersbooks.com/from_the_ground_up.htm http://www.eaa.org/communications/eaanews/ftgu.html Original tapes. Just like new. $68 shipping included. Please reply by email. brewtoo(at)yyhmail.com Thanks, Michael -- _______________________________________________ Get your free email from http://www.yyhmail.com ________________________________________________________________________________
Date: Jul 07, 2006
Subject: sun shades
I've been flying with the Koger sunshade on my slider 9A the past 2-1/2 years here in 'sunny' Arizona and it is a lifesaver. Flew the first year without it and I now wonder why it took me so long to put one in. Broke one of the plastic clamps and they sent a new bow gratis. The small sunspots are nice to cover up the direct sun in the windscreen but I think I'd be well done with out the sunshade. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Jul 07, 2006
Subject: The TRUTH about MOGAS
I am not ANTI Mogas or anyone who uses it, but I would like present some of the FACTS, negatives or CON's, in addition to all the PRO drinking the cool-aid comments for MOGAS. :-) I appreciate the passion and support some have for MOgas. Hey 5,10 and 15 years of successfully operation is not bad. I appreciate the sense of humor as well. Now for facts. besides the OCTANE molecule (distilled petroleum). Gas has 200 of chemicals in it, some are good for aviation some not, Auto gas has lower vapor pressure, which means it is more susceptible to vapor lock. Auto gas, even premium does NOT have the same octane as 100LL Avgas by quite a bit. Low octane can cause detonation, and uncontrolled burning of fuel which can lead to severe engine damage. In the past Av gas came in grades of 80-87; 91-98, 100-130 and 115-145. That has given way to the ubiquitous 100/100LL Why two numbers? The low number is the lean octane rating and the higher number is rich octane rating. There are four ways to measure fuel for octane: Automotive Research, Automotive Motor, Aviation Lean and Aviation Rich. Auto gas has one rating and is average of lean and rich rating and there are two methods as listed above. Aviation gas lean is about equal to automotive motor octane.100LL avgas if sold at the car pump would be 105. Premium 91 octane MOgas sold as Avgas would be about equiv to 86UL. STC for Mogas was when 80/86 went a way and the low compression engines ran terrible on the default gas grade 100/100LL. Despite the LL (Low Lead) designation, there's a lot of lead in 100LL. Therefor low compression engines designed to run on low octane fuel did not need or work well on leaded fuel. Lead boost octane. That was the beginning of STC's for automotive unleaded (UL) fuels for aircraft as a substitute for low lead/UL 80 octane. Just because the FAA approves STC's is not mean much in a high compression homebuilt. Lycomings come in to flavors, which are certified for 80 octane and have a compression ratio about 7.2:1CR or have about 8:50:1CR and are certified for 100/100LL gas, or the old 91/96 Avgas grade. If you buy the Super gas at the mini-mart and it said 92 octane it is only worth about 87 octane. We assume you test it for ethanol and alcohol every time of course. Can you run your 91/96 octane Lyc on it? Well that is subject to debate, but it does not fly in my plane. I guess you can reduce the timing advance a little as a precaution? Lycoming strongly recommends NOT using MOGAS. Lycoming does know about auto gas and in fact makes a very low compression O360 for flying in third world countries to run on low grade fuel. Unfortunately most 320's and 360's have 8:50:1CR and need the 91/96 (100LL) gas. If you are willing to test, haul and store your own auto gas and run your engine on less than the recommended octane, than OK, do that. If you have a low compression engine than auto gas makes more sense. You may want to look into reducing your timing and all the other things I mentioned about keeping the fuel cool, that where somewhat ridiculed by the MOgas experts. I would do everything I could to assure no loss of power due to vapor lock. If you have a 7:1CR engine than it is safer from an octane stand point, as long as it does not have the alcohol and ethanol. (However ethanol does increase the octane rating, see below). If you get a load of ethanol gas you run the risk of water contamination since it absorbs water. Once airborne it cools the water comes out of the fuel and water contamination result in loss of power. Carb ice is more likely with ethanol (alcohol). That is why it is important to test your auto gas. Also ethanol is not compatible with the rubber and gaskets used in aircraft and they will swell, which has caused aircraft engines to stop in the past. These are facts. If you do go auto fuel please please ask lots of questions of those who are experts in the topic. I think we have a few on this list (seriously :-) I am not an expert but than I don't have to jump of a bridge to know it might hurt when I hit the water. I know if your engine stops while flying in a plane it can be a bad thing. MOgas is NOT as good as AVgas. The debate is it good enough. May be. What I know about auto gas is enough to discourage me. Ethanol does help octane so if you can get some "sub grade" fuel before the distribution puts in the additives, like ethanol you can expect a 5% hit on octane. So basic fuel planned for 91 octane with ethanol is really 89 octane without the ethanol. This is like 84 aviation. To get "sub grade" you need to get it at the distribution terminal before they add the ethanol. 84 octane is not enough for higher compression 91/96 engines. If you have a 80 octane O320 140/150HP Lyc, than by all means go for it. Some debate about reducing timing for the high compression engines. Lycoming is testing UL blends and the gas companies are working on the 95UL as a 100/100LL replacement. Remember there are more high compression than low compression engines. Also the real fire breathing high end piston engines, turbo charged and so on NEED the high end gas, only make up 30% of the fleet but use 70% of the gas. So all you C65 & C85 engine Piper Cubs are stuck using the 95 octane but with the UL it should be OK. IF I HAD an 80 octane engine AND the gas prices kept going up I would consider auto gas it. (THERE I SAID IT, ARE YOU HAPPY....) As I said for the real world guy $400-$800 is about what you can expect to save per year. Some of the guys who live where fuel is cheap and ethanol is not forced down their throat, good for them. If you have a High compression engine and ethanol free fuel is hard to find at the pump than not so good. For the convenience of pulling up to the airport pump, filling with very high octane fuel, with very high vapor pressure and knowing there's no bad chemicals in it with out having to test it, is worth it to me. To each his own, I'll never say never but at some point I just will not fly as much or at all, sadly. --------------------------------- ________________________________________________________________________________
Date: Jul 07, 2006
Subject: Re: The TRUTH about MOGAS
I haven't researched enough to know which has the higher vapor pressure...auto or aviation fuel...but the higher the vapor pressure, the more likely to vapor lock, not the other way around. If indeed the auto gas has lower vapor pressure as you say, it would be less likely to vapor lock than avgas. ----- Original Message ----- From: gmcjetpilot(at)yahoo.com To: rv-list(at)matronics.com Sent: Friday, July 07, 2006 6:25 PM Subject: RV-List: The TRUTH about MOGAS I am not ANTI Mogas or anyone who uses it, but I would like present some of the FACTS, negatives or CON's, in addition to all the PRO drinking the cool-aid comments for MOGAS. :-) I appreciate the passion and support some have for MOgas. Hey 5,10 and 15 years of successfully operation is not bad. I appreciate the sense of humor as well. Now for facts. besides the OCTANE molecule (distilled petroleum). Gas has 200 of chemicals in it, some are good for aviation some not, Auto gas has lower vapor pressure, which means it is more susceptible to vapor lock. Auto gas, even premium does NOT have the same octane as 100LL Avgas by quite a bit. Low octane can cause detonation, and uncontrolled burning of fuel which can lead to severe engine damage. In the past Av gas came in grades of 80-87; 91-98, 100-130 and 115-145. That has given way to the ubiquitous 100/100LL Why two numbers? The low number is the lean octane rating and the higher number is rich octane rating. There are four ways to measure fuel for octane: Automotive Research, Automotive Motor, Aviation Lean and Aviation Rich. Auto gas has one rating and is average of lean and rich rating and there are two methods as listed above. Aviation gas lean is about equal to automotive motor octane.100LL avgas if sold at the car pump would be 105. Premium 91 octane MOgas sold as Avgas would be about equiv to 86UL. STC for Mogas was when 80/86 went a way and the low compression engines ran terrible on the default gas grade 100/100LL. Despite the LL (Low Lead) designation, there's a lot of lead in 100LL. Therefor low compression engines designed to run on low octane fuel did not need or work well on leaded fuel. Lead boost octane. That was the beginning of STC's for automotive unleaded (UL) fuels for aircraft as a substitute for low lead/UL 80 octane. Just because the FAA approves STC's is not mean much in a high compression homebuilt. Lycomings come in to flavors, which are certified for 80 octane and have a compression ratio about 7.2:1CR or have about 8:50:1CR and are certified for 100/100LL gas, or the old 91/96 Avgas grade. If you buy the Super gas at the mini-mart and it said 92 octane it is only worth about 87 octane. We assume you test it for ethanol and alcohol every time of course. Can you run your 91/96 octane Lyc on it? Well that is subject to debate, but it does not fly in my plane. I guess you can reduce the timing advance a little as a precaution? Lycoming strongly recommends NOT using MOGAS. Lycoming does know about auto gas and in fact makes a very low compression O360 for flying in third world countries to run on low grade fuel. Unfortunately most 320's and 360's have 8:50:1CR and need the 91/96 (100LL) gas. If you are willing to test, haul and store your own auto gas and run your engine on less than the recommended octane, than OK, do that. If you have a low compression engine than auto gas makes more sense. You may want to look into reducing your timing and all the other things I mentioned about keeping the fuel cool, that where somewhat ridiculed by the MOgas experts. I would do everything I could to assure no loss of power due to vapor lock. If you have a 7:1CR engine than it is safer from an octane stand point, as long as it does not have the alcohol and ethanol. (However ethanol does increase the octane rating, see below). If you get a load of ethanol gas you run the risk of water contamination since it absorbs water. Once airborne it cools the water comes out of the fuel and water contamination result in loss of power. Carb ice is more likely with ethanol (alcohol). That is why it is important to test your auto gas. Also ethanol is not compatible with the rubber and gaskets used in aircraft and they will swell, which has caused aircraft engines to stop in the past. These are facts. If you do go auto fuel please please ask lots of questions of those who are experts in the topic. I think we have a few on this list (seriously :-) I am not an expert but than I don't have to jump of a bridge to know it might hurt when I hit the water. I know if your engine stops while flying in a plane it can be a bad thing. MOgas is NOT as good as AVgas. The debate is it good enough. May be. What I know about auto gas is enough to discourage me. Ethanol does help octane so if you can get some "sub grade" fuel before the distribution puts in the additives, like ethanol you can expect a 5% hit on octane. So basic fuel planned for 91 octane with ethanol is really 89 octane without the ethanol. This is like 84 aviation. To get "sub grade" you need to get it at the distribution terminal before they add the ethanol. 84 octane is not enough for higher compression 91/96 engines. If you have a 80 octane O320 140/150HP Lyc, than by all means go for it. Some debate about reducing timing for the high compression engines. Lycoming is testing UL blends and the gas companies are working on the 95UL as a 100/100LL replacement. Remember there are more high compression than low compression engines. Also the real fire breathing high end piston engines, turbo charged and so on NEED the high end gas, only make up 30% of the fleet but use 70% of the gas. So all you C65 & C85 engine Piper Cubs are stuck using the 95 octane but with the UL it should be OK. IF I HAD an 80 octane engine AND the gas prices kept going up I would consider auto gas it. (THERE I SAID IT, ARE YOU HAPPY....) As I said for the real world guy $400-$800 is about what you can expect to save per year. Some of the guys who live where fuel is cheap and ethanol is not forced down their throat, good for them. If you have a High compression engine and ethanol free fuel is hard to find at the pump than not so good. For the convenience of pulling up to the airport pump, filling with very high octane fuel, with very high vapor pressure and knowing there's no bad chemicals in it with out having to test it, is worth it to me. To each his own, I'll never say never but at some point I just will not fly as much or at all, sadly. ------------------------------------------------------------------------- ----- Sneak preview the all-new Yahoo.com. It's not radically different. Just radically better. ________________________________________________________________________________
Date: Jul 08, 2006
, snip > > Auto gas has lower vapor pressure, which means it > is more susceptible to vapor lock. > >> Get it straight George. The higher the vapor pressure the more chance of vapor lock. And BTW av gas does have lower vapor pressure for that exact reason. Don Content-Type: Multipart/alternative; boundary="NextPart_Webmail_9m3u9jl4l_4597_1152320450_1" --NextPart_Webmail_9m3u9jl4l_4597_1152320450_1 Content-Type: text/html; charset=iso-8859-1 Content-Transfer-Encoding: 8bit
humor as well.
Now for facts.
damage.
above.
as a precaution?
sense.
past.
me.
the ethanol.
Sneak preview the all-new Yahoo.com. It's not radically different. Just radically better. --NextPart_Webmail_9m3u9jl4l_4597_1152320450_1-- ________________________________________________________________________________
Date: Jul 08, 2006
Subject: I need replacement parts for my Koger Sun Shield
One of the end retainer slider pieces for my Koger Sun Shield broke and I need a replacement. I talked to Van's (where I bought it) and they had no idea what I was talking about. I have tried 2 different email addresses (via the archives) for Mr. Koger and each has bounced back. Does anyone know how to reach Mr. Koger or at least get a replacement slider piece? Thanks! Kim Nicholas RV9A Auburn, WA ________________________________________________________________________________
Date: Jul 08, 2006
Subject: The TRUTH about MOGAS (very long)
As someone who long ago made up my mind not to use Mogas (for a variety of reasons) I still found this discussion interesting. I personally don't think the *potential* risks outweigh the monetary savings. I don't know if I fit into the "nice sum of cash" camp, but I know that I DO give up other things that I would like (such as an automobile built after 1988) in order to fly an RV. One thing I haven't seen mentioned (although I confess I have skipped a lot of this topic) is that a few years ago Avgas was twice as expensive as Mogas ($2 vs. $1). Now the same $1 differential exists, but at $4 vs. $3 Mogas is "only" 25% cheaper. Sorry, but with all the expenses of airplane ownership, a 25% savings on fuel is not worth ANY possibility of Mogas problems. Not to mention the hassle factor of lugging your own airplane fuel around. Yuck. Ed Bundy >> I am not ANTI Mogas or anyone who uses it, but > I would like present some of the FACTS, negatives > or CON's, in addition to all the PRO drinking the > cool-aid comments for MOGAS. :-)<< > George is like many on this list who have a nice sum of > cash to work with. With that, he doesn't have the > need, or desire, to try alternative things to help keep > his aviation expenses down. George also has an > engineering background; so, he's not dumber than a > box of rocks, like some of us out here. :-) -- ________________________________________________________________________________
Date: Jul 08, 2006
Subject: Garmin Service
I remember someone stating a problem with Garmin service a while back, and thought I would add to the discussion. I have a Garmin 396 that I had mounted in an Airgizmos panel dock. When working on my new panel, the antenna wire touched a breaker and somehow damaged the ground portion of the 396. It wouldn't recognize any external power anymore! So I sent it back, to see if it would be fixed under warranty. It was shipped out from them 3 days later via second day air, no charge. It had a couple of scratches on it, and one small scratch on the screen I wasn't happy about before hand. They replaced the entire front and back covers of the unit as well, all no charge. That's pretty darn good service I'd say for a large corporation like Garmin. Paul Besing __________________________________________________ ________________________________________________________________________________
Date: Jul 08, 2006
Subject: Re: I need replacement parts for my Koger Sun Shield
The paper work that came with my Koger Sun Shade shows: Ralph Koger 1947 W. 1st ext. Boone, IA 50036 515 432 5714 Bayne Just RV9A SEE Gillespie field San Diego, CA On Jul 8, 2006, at 7:18 AM, Knicholas2(at)aol.com wrote: > One of the end retainer slider pieces for my Koger Sun Shield broke > and I need a replacement. I talked to Van's (where I bought it) > and they had no idea what I was talking about. I have tried 2 > different email addresses (via the archives) for Mr. Koger and each > has bounced back. > > Does anyone know how to reach Mr. Koger or at least get a > replacement slider piece? > > Thanks! > > Kim Nicholas > RV9A > Auburn, WA ________________________________________________________________________________
Date: Jul 08, 2006
Subject: Re: The TRUTH about MOGAS (very long)
I don't think anyone can claim to be an expert on whether or not mogas is suitable for their airplanes unless they try it and see if it works in their airplane. Forget the numbers (compression ratio, octane, vapor pressure, etc.) For me 25% 100LL and 75% 87 octane sans alcohol mix works for me and I can't tell a bit of difference when I'm fueled up with 100% 100LL. My lines are firesleeved, no problem in the summer temperatures. It works for me and as far as I care those are the facts, everything else is conjecture. I've borescoped the cylinders to look for any signs of detonation, and there are none. My oil analysis reports always come back good. I have 9:1 pistons in the rocket, will likely go 50/50 on the fuel mixture, but have to see what works best thru some trial and error. Regards, Bob Japundza RV-6 flying 700+hours, F1 under const. ________________________________________________________________________________
Date: Jul 08, 2006
>Actually, I think mogas is better than avgas. I have >less problems with mogas than I do with avgas. I've >had cylinders off my engines for problems not relating >to mogas usage and have yet to find symptoms of detonation,etc. On the >contrary, I've found the engine >to be clean on the inside. No lead. Every time I fill >my plane up with 100LL, I get the fouled plugs and >lead related bad run ups. Don't take this the wrong way but that may be operating technique. I use 100LL and fly more than most folks and I don't have fouled plug issues on every fillup. I think that I have had three cases in 900 hours and most were probably because I failed to lean the engine after startup. I would prefer a fuel with little or no lead because it does require periodic maintenance to clean the plugs. Ron Lee ________________________________________________________________________________
Date: Jul 08, 2006
Subject: Fuel Efficiency
I'm also into fuel efficiency, and would like to suggest that you folks calculating NM/gal plug travel destinations into maps.google and then compare the efficiency of your airplane travel with that of driving a stupid utility vehicle going the same distance. If you haven't already. The curvier the roads, the better to fly. If Deltahawk ever gets their stuff together I'll finish this 7A and start doing some "extreme" efficiency/mileage experiments :-). Anyone else waiting on this pixie-dust engine? Mike Duran M20C 7A - airframe finished, treading water ________________________________________________________________________________
Date: Jul 08, 2006
Subject: 4 into 1 Exhaust
For those of you looking for a 4 into 1 exhaust may I suggest Kevin Murray of Sky Dynamics. I just received my 4 into 1 for my RV-8 / IO-390 and it is a thing of beauty. Kevin supplies exhausts for the likes of Patty Wagstaff, Sean Tucker, Jim Leroy, and Dave Anders. at www.skydynamics.com Bob Gibbons RV-8 Waiting 6 months for an MT prop. ________________________________________________________________________________
Date: Jul 08, 2006
Subject: fuselage center, f-623 rib question
Greetings, those who have gone before, I'm clecoing the mid section bottom skin to the seat & baggage ribs, trying to interpret the drawings on dwg22 (view C-C). My F623L & R ribs have a joggle on the outside vertical flange where it meets the F705 bulkhead. The joggle seems intended to allow a rivet to tie the side skin, f705 bulkhead & the outside flange of the F623 together. However, view C-C (side view of this point) seems to show the F623 rib being cut off just short of the F705 bulkhead flange. If I cut nothing, I'll have a joggle in the bottom skin (obviously wrong). If I cut as shown in view C-C, I'm cutting off a joggle in the flange that Van's went to the trouble of adding to the rib. My 1st thought is to cut the inside flange & horizontal surface of the F623 & leave the joggled tab for riveting to F705. Should I do something different? Bonus question1: The instructions say to cut a 1 1/2" hole in one of the baggage ribs if you intend to add a step. Is there any harm in cutting this hole if no step is planned? (grams add up to ounces add up to pounds....) Bonus question2: Any harm in enlarging the back tooling holes in the seat ribs to 5/8", like the front ones? (possible future wiring path, if needed) Thanks, Charlie ________________________________________________________________________________
Date: Jul 08, 2006
The seasonal blending and geographical blending by automotive gasoline refiners does have a significant effect on the operation of the engines. When I was Terminal Superintendent of the Union 76 tank farms at San Diego and Imperial (El Centro) Terminals back in the early 1980's, we used to back haul the Imperial "desert gasoline" for the coastal San Diego's California Highway Patrol during certain seasons of the year for fuelling the 24/7 patrolcars that ran severe duty periods of idling and high speed pursuits. As engines used in aircraft adopt modern automotive computers utilizing such monitors as temperature probes and O2 sensors, the engines will be able to finely tune themselves as they encounter differing weather and altitudes. With the 1930's technology of many of our Lycoming & Continental aircraft engines, this thread has been informative with its cautions and could prevent damage from unexpected power off landings or even save some lives. If a plane is based on a private strip at a rural home, farm or ranch where automotive gasoline for vehicles and equipment can be delivered by commercial tankwagon, the savings can be measurable if the automotive fuel is found to be adequate for the aircraft engine. Our local fairly busy airport, with commercial airline service on its 6,559 foot runway with ILS, only pumps 150,000 gallons of Aviation gasoline a year. If this were a corner filling station pumping only 150,000 gallons in just a month - it would be facing closure for being uneconomical. Refiners are making aviation gasoline more as a service than a profit center. We need to continue to educate ourselves about alternate fuels as aviation gasoline will no doubt have to change from the currently available 100LL to a fuel that has other shared applications to make it at least marginally profitable to produce and distribute. As to the flamers and naysayers . . . "Don't confuse me with the facts, I've already made up my mind." Pete Cowper RV-8 #81139 (working on fuselage) ________________________________________________________________________________
Date: Jul 08, 2006
He used to live near the Lauritsens. If all else fails, call Cleaveland Tool and I am sure they can get you fixed up. Denis Walsh On Jul 8, 2006, at 07:18 299370007, Knicholas2(at)aol.com wrote: > One of the end retainer slider pieces for my Koger Sun Shield broke > and I need a replacement. I talked to Van's (where I bought it) > and they had no idea what I was talking about. I have tried 2 > different email addresses (via the archives) for Mr. Koger and each > has bounced back. > > Does anyone know how to reach Mr. Koger or at least get a > replacement slider piece? > > Thanks! > > Kim Nicholas > RV9A > Auburn, WA ________________________________________________________________________________
Date: Jul 08, 2006
In a message dated 7/8/2006 9:41:33 A.M. Pacific Daylight Time, bjust(at)cox.net writes: The paper work that came with my Koger Sun Shade shows: Ralph Koger 1947 W. 1st ext. Boone, IA 50036 515 432 5714 =========================================== Also this kind of stuff is always just a mouse click away in the Yeller Pages at _http://www.matronics.com/YellerPages/_ (http://www.matronics.com/YellerPages/) GV (RV-6A N1GV O-360-A1A, C/S, Flying 792hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 08, 2006
RV list, I have changed to a cable server and my old e-mail address is not correct. My web site will be updated as soon as Mike Lauritson get home from the Washington show. www.Cleavelandtool.com/kogercompany/ Web site. If anyone needs parts send me the model of shade and your address and I will send them to you. Over the past 10+ years I have had very little breakage and replacements. I want to keep your Koger SunShade in good condition. ralphkoger(at)gmail.com or r.koger(at)mchsi.com Phone 515-432-5714 Thank You for buying my sunshade and the RV list. Ralph Koger On 7/8/06, Knicholas2(at)aol.com wrote: > > One of the end retainer slider pieces for my Koger Sun Shield broke and I > need a replacement. I talked to Van's (where I bought it) and they had no > idea what I was talking about. I have tried 2 different email addresses > (via the archives) for Mr. Koger and each has bounced back. > > Does anyone know how to reach Mr. Koger or at least get a replacement > slider piece? > > Thanks! > > Kim Nicholas > RV9A > Auburn, WA > ________________________________________________________________________________
From: " Karen and Bob Brown" <bkbrown(at)ashcreekwireless.com>
Date: Jul 08, 2006
FWIW, before gluing the canopy and windscreen (and skirts) on my 7A frame and fuselage with Sikaflex, I bought some black Sikaflex295UV and did a few Dr. Destructo pull tests using scrap pieces of plexi and pieces of both powder coated steel and aluminum. Thickness of the adhesive beads was controlled with rubber hose washers at 3/16ths inch per the product data sheet manuals. On one pull test, I tore the aluminum sheet (.032) and the Sika joint never failed. In all my other tests, the plexi failed. The Sika joints never failed. I can only presume the product that failed was out of date (either the primer, the wash or the adhesive or all) or there was some other contaminant present at the point of adhesion. This product has been sold as an adhesive for polycarbonate and plexiglass for years. It is recognized as an industry standard for the application we are using it for. I suppose time will tell, but there are installations in RV's out there now with over 5 years on them. If anyone knows of any other failures, I'd sure like to hear the details about them. I can only speak about my installation, which shows no sign of being anything but solid. I did return some tubes of Sikaflex which were out of date when I received them. I'd suggest looking at those dates closely. One thing I've learned from using Sikaflex 295 is that it will absolutely not stick to a surface that has not been properly prepped (both surfaces sanded w/60 grit, washed, primed). Also note there are time limits.wait 20 minutes after the wash coat before priming. Adhesive must be applied within 2 hrs of priming. I used to freak out if I got some Sikaflex on the canopy outside my masked bead area.later I just left it on until it cured, because it would peel off as easy as rivet tape if it was not applied over a properly prepped area. Bob _______________________________________________ Bob and Karen Brown RV7A - flying ________________________________________________________________________________
Date: Jul 08, 2006
Subject: Connecting Blue Mountain EFIS lite to Pictorial Pilot
Hi All, Is there anyone out there who has tried to connect a Blue Mountain EFIS G3 Lite to a Trutrak Pictorial Pilot? I have the Serial Port B connected to the Pictorial Pilot but the autopilot doesn't recognize the GPS input. I suspect that I don't have the correct settings in the EFIS (choices include GPSS and NMEA 0183 among others). BMA Tech Support says they haven't tested this autopilot so that can't give me the correct settings. Anybody out there have any ideas? Thanks Jim Ellis RV9-A, Flying ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 08, 2006
Subject: Re: Connecting Blue Mountain EFIS lite to Pictorial
Page 5 has this info. Looks like NMEA-0183 on Pin 3. Have you tried that format? P101 Pin Function Notes 1 Autopilot Master (+12 to +14 V DC). The autopilot itself draws less than 0.3 ampere. Most of the current required by the system is used by the servo (up to 1Amp depending on torque setting) and a smaller amount (up to 180 mA) for the illuminated pushbuttons. 2 Control Wheel Switch. Connect as shown in wiring diagram to a SPST momentary switch located remotely to the autopilot for convenient engage/disengage function. 3 Primary Serial Input. Baud rate selectable 1200,2400,4800 or 9600 baud. Automatically decodes NMEA-0183, Garmin Aviation Format, or Apollo/UPSAT Moving-Map format. Provides directional reference to the autopilot. 4,5,6 ________________________________________________________________________________
Date: Jul 09, 2006
Subject: MOGAS related Crashes, ouch
>> wrote: >> Auto gas has lower vapor pressure, which means it >> is more susceptible to vapor lock. >> >From: "Jim Sears" <jmsears(at)adelphia.net> > > >George and I have had some discussion on this subject >off line; and, I thought the topic was over with. > >Sorry, Goerge; but, you still have that one backwards, >which helps to debunk the rest of what you say. Don't >worry, I have had a hard time keeping this one straight, >myself. :-) > >(para-phrase) I only know of one accident from using >auto gas. What did you say, you only heard of one accident? One accident attributed to autogas? ha ha That is not correct. A quick NTSB search with the words *automotive fuel* found about 250 hits. I cut it down to experimental and *automotive fuel* and got about 50 hits. I guess you have your facts wrong, so does that debunks the rest of what you say. That's OK, I was wrong once years ago. > >I thought the topic was over with > Well you thought wrong. I am sorry, too dumb to be straightened out. When you are an expert, you expect people to believe you. Sorry, to disappoint you. Here you go Mr. Expert :-) -More carb ice -More water in the carb -More unexplained power loss Just a few select AUTOMOTIVE FUEL mishaps: Power Loss in-flight hot day? hummmm http://www.ntsb.gov/ntsb/GenPDF.asp?id=MIA91LA108&rpt=fi RV's with fuel pressure problem hot day, more hummm http://www.ntsb.gov/ntsb/GenPDF.asp?id=CHI04CA141&rpt=fi http://www.ntsb.gov/ntsb/GenPDF.asp?id=FTW95LA122&rpt=fi Gee handling your own fuel can contaminate it? You think http://www.ntsb.gov/ntsb/GenPDF.asp?id=LAX06CA033&rpt=fi http://www.ntsb.gov/ntsb/GenPDF.asp?id=DEN05CA144&rpt=fi Carb ice more likely with auto fuel? http://www.ntsb.gov/ntsb/GenPDF.asp?id=IAD05LA035&rpt=fi Mystery or auto fuel? Many unexplained loss of power http://www.ntsb.gov/ntsb/GenPDF.asp?id=FTW95LA122&rpt=fi http://www.ntsb.gov/ntsb/GenPDF.asp?id=IAD05LA103&rpt=fi http://www.ntsb.gov/ntsb/GenPDF.asp?id=LAX98LA038&rpt=fi http://www.ntsb.gov/ntsb/GenPDF.asp?id=MIA99LA134&rpt=fi Oops MTBE (Methyl tert-butyl ether) and other additives http://www.ntsb.gov/ntsb/GenPDF.asp?id=LAX91DUJ01&rpt=fi http://www.ntsb.gov/ntsb/brief.asp?ev_id 060706X00876&key=1 http://www.ntsb.gov/ntsb/GenPDF.asp?id=FTW85LA127&rpt=fi http://www.ntsb.gov/ntsb/GenPDF.asp?id=LAX83FA246&rpt=fi Water and corrosion in the carb again and again? http://www.ntsb.gov/ntsb/GenPDF.asp?id=DEN84FTG01&rpt=fi http://www.ntsb.gov/ntsb/GenPDF.asp?id=CHI95LA051&rpt=fi http://www.ntsb.gov/ntsb/GenPDF.asp?id=ATL03FA142&rpt=fi http://www.ntsb.gov/ntsb/brief.asp?ev_id 050211X00183&key=1 http://www.ntsb.gov/ntsb/GenPDF.asp?id=ATL97LA003&rpt=fi http://www.ntsb.gov/ntsb/GenPDF.asp?id=ATL86LA168&rpt=fi (this was only a few of many) I see anecdotal evidence that auto fuel may have directly or indirectly contributed to the grief of some of the above pilot's and their plane? I know by using your expert advice and procedures you can avoid ALL the above? Well may be not all. The ones that concern me the most are unexplained power loss on hot days. (hint hint, over, do you copy, vapor lock, Roger?) Note: Jim's mission in life is to promote auto fuel. He is doing a great job. When anyone talks about risk it means nothing, because it's not their fleshy buttock in the seat. I don't CARE. Just be informed. IF YOU USE AUTO FUEL AND SELF FUEL, aka HANDLE FUEL, PLEASE BE CAREFUL. THERE ARE RISK AND IT IS NOT ALL SUNSHINE AND BUTTERFLY'S. It may not be as bad as I make it sound, but it is not as great and carefree ( in my not so expert opinion) as Jim makes it sound. To use 1/2 auto and 1/2 avgas in each tank sounds weird to me. Don't you trust your fuel? What do you all think. If you don't trust you fuel to fly on, for all operations, do you want it in your plane? ME? not so much. YOU? decide for yourself. I don't care; I just suggest you know what you're getting. If you do use AUTO FUEL contact Jim. He knows way more than I do. However I know enough in 12,000 hours of flying to know how to stay out of trouble. I want to be an expert in power off emergency landings, but I never want to have to prove I am an expert for real. I want to always have a choice when and where I land. Using Avgas is just that little bit better in my humble but ever so right opinion. :-) It is NOT all about money as Jim makes it sounds. What does and off field landing cost? I hope only bent metal. Safety first, economy second. Boy I hope you have learned I have spoken and there is nothing left to be said. ha ha ha ha. Just kidding. Good debate, learned a lot, but lets keep it to facts and opinion and not personal comments. Have a NICE DAY. George M :-) --------------------------------- ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jul 09, 2006
Pete, just curious and you sound like someone who would really know so I have a question. I understand adding the "local content" for season and geography in the auto fuel side but I am under the impression that 100LL is the same everywhere. Is 100LL blended at the tank farms and then delivered locally, in which case the transportation/distribution costs would be slightly higher or does it come from one main refinery and then get trucked across the country in which case the difference in price might be very recognizable? Also wondered if 100LL and Jet goes through the normal pipeline distribution system or is it land-hauled because of the extremely low volumes compared to auto fuel? We appear to have a pretty amazing system for auto fuel distribution but I am wondering if there is a drastically different distribution cost to av fuel? Thanks Bill S 7a Ark -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Pete Cowper Sent: Saturday, July 08, 2006 2:36 PM The seasonal blending and geographical blending by automotive gasoline refiners does have a significant effect on the operation of the engines. When I was Terminal Superintendent of the Union 76 tank farms at San Diego and Imperial (El Centro) Terminals back in the early 1980's, we used to back haul the Imperial "desert gasoline" for the coastal San Diego's California Highway Patrol during certain seasons of the year for fuelling the 24/7 patrolcars that ran severe duty periods of idling and high speed pursuits. As engines used in aircraft adopt modern automotive computers utilizing such monitors as temperature probes and O2 sensors, the engines will be able to finely tune themselves as they encounter differing weather and altitudes. With the 1930's technology of many of our Lycoming & Continental aircraft engines, this thread has been informative with its cautions and could prevent damage from unexpected power off landings or even save some lives. If a plane is based on a private strip at a rural home, farm or ranch where automotive gasoline for vehicles and equipment can be delivered by commercial tankwagon, the savings can be measurable if the automotive fuel is found to be adequate for the aircraft engine. Our local fairly busy airport, with commercial airline service on its 6,559 foot runway with ILS, only pumps 150,000 gallons of Aviation gasoline a year. If this were a corner filling station pumping only 150,000 gallons in just a month - it would be facing closure for being uneconomical. Refiners are making aviation gasoline more as a service than a profit center. We need to continue to educate ourselves about alternate fuels as aviation gasoline will no doubt have to change from the currently available 100LL to a fuel that has other shared applications to make it at least marginally profitable to produce and distribute. As to the flamers and naysayers . . . "Don't confuse me with the facts, I've already made up my mind." Pete Cowper RV-8 #81139 (working on fuselage) ________________________________________________________________________________
Date: Jul 09, 2006
Subject: Re: Fossil energy fuel to produce ethanol
Dean, The United states produces about 60% of the world's Co2. This comes from cars, trucks and furnaces and it is a big deal. Co@ reflects the suns long wave radiations back into space and contributes greatly to global warming. It also mixes well with sulfur dioxide to form smog. Think Los Angelas. I agree with everything else you wrote. It would seem the environmentalists are quick to complain about things and want quick answers but are not willing to do the required studies to come up with responsible alternatives. Larry Mac Donald lm4(at)juno.com Rochester N.Y. Do not achcive writes: > > , if we had the "perfect" energy source that's fully > renewable and generates no toxic waste products or CO2 (I don't consider CO2 a hazard to our planets health) they would still find something "evil" about it! > > Dean Psiropoulos > RV-6A N197DM ________________________________________________________________________________
Date: Jul 09, 2006
Subject: Re:Fuel economy / was Fossil energy fuel.....
Tracy, With due respect, Van's tested two more or less identical rotary conversions in the "RV-Ator, 2nd issue of 2005. These were both RV-8's built as "twins" by two friends and retired pilots, Jim Clark and Gerry Gustafson. These were Powersport Rotaries and turned out beautifully. I had the pleasure of viewing them and talking to both men at Van's Homecoming 2004. The article is quite extensive, as was the testing, but I'll just mention that at cruise with identical speeds, the article states "But, in all cases, even at equal speeds, they burned more fuel than the reciprocation engines." Also... "The rotaries were definitely noiser inside and out." For instance, at cruise Van's RV8 burned 5.05 gals and the two rotaries 7.65 and 7.1 respectively. This was a round trip of 140nm. So it appears from their data that rotaries, at least these two, burn substantially more fuel. What do you think? I don't have a scanner, but would be happy to fax or mail copies. Jerry Cochran Wilsonville, OR That was seriously Cool data Dan. Thanks also to Ed Bundy who supplied his numbers. It is surprisingly hard to find RV drivers who keep track of this stuff (too busy having fun in these things which I also understand : ) be a significant advantage. If you ever get the chance Dan, I'd like to see you do the same test but instead of dropping manifold pressure only, try dropping the prop rpm to get the same fuel flow numbers you used. This should reduce pumping losses and result in even better numbers. "Do not operate" zones on the prop rpm is the only possible problem I can think of. I don't have that problem with my fixed pitch wood prop but I have to put up with very high pumping losses, especially at low altitude (which is another reason I cruise high). Bottom line is that based on this info, I don't see a nickel's worth of difference between the Lyc (when run LOP) and my Mazda rotary when it comes to fuel economy. Cleanliness of the airframe makes more difference than the engine. I always burn less fuel than the guys who run Lycs ROP. The horror stories about the fuel consumption of the rotary are based on automotive experience. Ironically, the rotary is at it's worst in auto use. The lower the engine load, the worse the rotary is. Car's typically run at 10% or less power settings. At low power settings the flame goes out in the large quench areas of the rotary combustion chamber resulting in more unburned mixture. The higher the power load is, the longer the flame stays lit and more complete combustion results. The crumby results on the rotary RV-8 comparisons they did at Van's home drome were the results of two factors. 1. The fixed prop RPM rule put the rotaries at a disadvantage. They should have allowed the pilots to set it at best economy for the two engine types (it is not the same). 2. The EFI controllers used with the Powersport engines do not allow the pilot to optimize the mixture. They were essentially running at full rich the whole time. The designers of it did not consider the users capable of deciding this and programmed what they thought was the safest mixture setting (rich). Tracy Crook ________________________________________________________________________________
Date: Jul 09, 2006
Subject: Fossil energy or What!
Right on Gummy, Lets get back to building!! Jim ________________________________________________________________________________
Date: Jul 09, 2006
Hi Jerry, I've read the articles (those were the planes I was referring to) and do not dispute the results at all, as I said, the rotaries had 'crumby' results. I only offered the reasons why I believe these two rotary powered planes did so poorly on the tests. My RV-4 is not nearly as clean (aerodynamically due to fit and finish) as those beautiful RV-8s but I get significantly better fuel economy when I try to duplicate those test conditions. I don't have a CS prop so can't do it perfectly. The main difference is, I have full control of mixture and they do not. As far as the noise issue, both of the RV-8s now have an improved muffler system since that test was done and are much quieter. Ask Jim & Gerry about that for details. Tracy Crook ----- Original Message ----- From: Jerry2DT(at)aol.com<mailto:Jerry2DT(at)aol.com> To: rv-list(at)matronics.com Sent: Sunday, July 09, 2006 1:06 PM Subject: RV-List: Re:Fuel economy / was Fossil energy fuel..... Tracy, With due respect, Van's tested two more or less identical rotary conversions in the "RV-Ator, 2nd issue of 2005. These were both RV-8's built as "twins" by two friends and retired pilots, Jim Clark and Gerry Gustafson. These were Powersport Rotaries and turned out beautifully. I had the pleasure of viewing them and talking to both men at Van's Homecoming 2004. The article is quite extensive, as was the testing, but I'll just mention that at cruise with identical speeds, the article states "But, in all cases, even at equal speeds, they burned more fuel than the reciprocation engines." Also... "The rotaries were definitely noiser inside and out." For instance, at cruise Van's RV8 burned 5.05 gals and the two rotaries 7.65 and 7.1 respectively. This was a round trip of 140nm. So it appears from their data that rotaries, at least these two, burn substantially more fuel. What do you think? I don't have a scanner, but would be happy to fax or mail copies. Jerry Cochran Wilsonville, OR From: "Tracy Crook" <lors01(at)msn.com> Subject: Re: RV-List:Fuel economy / was Fossil energy fuel..... That was seriously Cool data Dan. Thanks also to Ed Bundy who supplied his numbers. It is surprisingly hard to find RV drivers who keep track of this stuff (too busy having fun in these things which I also understand : ) be a significant advantage. If you ever get the chance Dan, I'd like to see you do the same test but instead of dropping manifold pressure only, try dropping the prop rpm to get the same fuel flow numbers you used. This should reduce pumping losses and result in even better numbers. "Do not operate" zones on the prop rpm is the only possible problem I can think of. I don't have that problem with my fixed pitch wood prop but I have to put up with very high pumping losses, especially at low altitude (which is another reason I cruise high). Bottom line is that based on this info, I don't see a nickel's worth of difference between the Lyc (when run LOP) and my Mazda rotary when it comes to fuel economy. Cleanliness of the airframe makes more difference than the engine. I always burn less fuel than the guys who run Lycs ROP. The horror stories about the fuel consumption of the rotary are based on automotive experience. Ironically, the rotary is at it's worst in auto use. The lower the engine load, the worse the rotary is. Car's typically run at 10% or less power settings. At low power settings the flame goes out in the large quench areas of the rotary combustion chamber resulting in more unburned mixture. The higher the power load is, the longer the flame stays lit and more complete combustion results. The crumby results on the rotary RV-8 comparisons they did at Van's home drome were the results of two factors. 1. The fixed prop RPM rule put the rotaries at a disadvantage. They should have allowed the pilots to set it at best economy for the two engine types (it is not the same). 2. The EFI controllers used with the Powersport engines do not allow the pilot to optimize the mixture. They were essentially running at full rich the whole time. The designers of it did not consider the users capable of deciding this and programmed what they thought was the safest mixture setting (rich). Tracy Crook ________________________________________________________________________________
Date: Jul 09, 2006
Subject: Re: Need Help with Cowling Ducts
Les, Is he sure his transducer is working correctly? I run air thru my oil cooler after it has been over the cylinders and have 30% of the oil cooler covered and can't get my oil temps above 160 on a hot day. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=45993#45993 ________________________________________________________________________________
Date: Jul 09, 2006
Subject: RV Fuel Efficiency, Page AZ and Antelope Canyon
Here is a real-life example comparing flying and driving to the same place. The plane is an RV-6A, O-360 carbureted, one Lightspeed ignition some drag from old wheelpants and one crooked main gear fairing. Car is a 2001 Jeep Grand Cherokee Laredo, cruise control, 8 Cylinder and automatic with full time 4WD. Flight to Page took three hours (headwind) at 16,500 feet. Distance about 400 statute miles using 19.5 gallons of 100LL. The comes to 20.5 miles/gallon (6.5 GPH). Add one hour for additional time before and after the flight and the trip took four hours. As an aside, the trip back took 2.5 hours and burned 14.9 gallons for 26.8 MPG (6 gallons/hr). The trip back was at 17,500 feet and I had about a 30 knot tailwind. The car trip took 12 hours each way. 600 miles at 21 MPG burned about 28.6 gallons each way. The plane trip was done in one day whereas the car trip took over two days and required two nights in a hotel. Pictures for perusal included. Ron Lee <http://www.pcisys.net/~ronlee/Lower16Apr06_14Small.jpg>http://www.pcisys.net/~ronlee/Lower16Apr06_14Small.jpg http://www.pcisys.net/~ronlee/Lower16Apr06_79Small.jpg http://www.pcisys.net/~ronlee/Lower16Apr06_91Small.jpg http://www.pcisys.net/~ronlee/Upper16Apr06_19Small.jpg http://www.pcisys.net/~ronlee/Upper16Apr06_28Small.jpg http://www.pcisys.net/~ronlee/Lower2Jun06_006Small.jpg http://www.pcisys.net/~ronlee/Lower2Jun06_042Small.jpg http://www.pcisys.net/~ronlee/Lower2Jun06_108Small.jpg http://www.pcisys.net/~ronlee/Lower2Jun06_112Small.jpg http://www.pcisys.net/~ronlee/Upper2Jun06_032Small.jpg http://www.pcisys.net/~ronlee/Upper2Jun06_072Small.jpg http://www.pcisys.net/~ronlee/Upper2Jun06_167Small.jpg ________________________________________________________________________________
Date: Jul 09, 2006
Subject: Bleeding the brakes
I tried to bleed the brakes with a little pump can like others have talked about doing. Well it made a big mess and did not work well. I asked a fellow RV builder (thanks Larry) about how he did it and found out from him that I could make a small pump sprayer into a pressurized brake bleeder. Here is how I made mine and it works great. It does take two people to do the job. I bought a 1-1/2 quart pump sprayer from Lowes allow with three different size pieces of tubing I put the tubing together and zip tied them to help hold them together. I used a small plug that came out of an instrument to attach another short piece of tubing to use as an overflow line to hold on the reservoir so the extra brake fluid could be caught in a bottle. Now this is the to do this job! When the job is all done the tubing can be stored in the tank to keep from losing it. -- My new email address: bobbyhester(at)charter.net Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A N857BH SB wings-QB Fuse-XPO360 engine :-) ________________________________________________________________________________
Date: Jul 10, 2006
Subject: AKZO primer question
Listers, No, I don't want to start a war. I have 2 one gallon cans (base and curing solution) of Dexter (AKZO) 2 part epoxy primer that are now 5 years old. The label says the maximum shelf life is 2 years -- mil spec, etc. They have been kept at room temperature the whole time (air conditioned in summer, greater than 60 degrees in winter). The contents look good after stirring the base for about 5 minutes. I mixed some up and waited 1/2 hour and sprayed it on a piece of scotch-bright scuffed aluminum. After curing it seems to be very hard and works like new as far as I can tell. Here is the question: what would be the failure mode of using this old primer? I hate to throw away $130 plus shipping if it is actually OK to use. Dan Hopper RV-7A ________________________________________________________________________________
Date: Jul 10, 2006
Why not just buy a "Mity-Vac" ,which is made for this kind of job ??? Harbor freight tools has one model for about 15 bucks and it has the things needed to do the job. More expensive models have more equipment and are re-buildable. Bob Olds RV-4 Charleston,Arkansas ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Re: MOGAS related Crashes, ouch
>From: Fiveonepw(at)aol.com > >C'mon, is this the best you can do? Very informative, >informative, but wearily long and all of these reports that YOU >CITED I made no claim of detailed analysis, I hear you, but.... I'll give you some better examples that spell it out, but... just because the final determination for the power loss is unexplained, it does not make me feel good. Fact is several planes, all using auto fuel, had loss of power along with low or erratic fuel pressure. Just happens it was also a hot day. Unexplained loss of power, surging and erratic fuel pressure on hot days, while using high vapor pressure auto fuel might mean vapor lock is the cause (I really do think). VL certainly is a very reasonable explanation since it matches the symptoms. Just because OJ was not found guilty does not mean he didn't do it. All the FAA can say is they can't prove it after the fact, but they out and out say it below or imply vapor lock often.. I got clever, I searched on Vapor Lock and Automotive fuel. (69 hits) Here they say it, out right, RV-9A auto gas and vapor lock http://www.ntsb.gov/ntsb/GenPDF.asp?id=CHI06LA069&rpt=fa some factory planes (hey if it can happen to them...) NAVION, any more questions http://www.ntsb.gov/ntsb/brief.asp?ev_id 001213X30993&key=1 Rockwell Ag plane, FAA says.... http://www.ntsb.gov/ntsb/GenPDF.asp?id=MKC88LA141&rpt=fi Piper PA-20, if that does not do it for Ya http://www.ntsb.gov/ntsb/GenPDF.asp?id=ANC89LA118&rpt=fi (auto fuel has three times the vapor pressure) Some more experimentals Pitts Special, auto fuel and vapor lock in narrative text http://www.ntsb.gov/ntsb/GenPDF.asp?id=CHI83LA312&rpt=fi Thorp T-18, Mazda powered, page 1, par 2 and par 4. http://www.ntsb.gov/ntsb/GenPDF.asp?id=LAX94LA273&rpt=fa D-51S vapor lock, no mention of auto gas, but could be. The vapor lock symptoms are interesting and common. http://www.ntsb.gov/ntsb/GenPDF.asp?id=MIA99FA159&rpt=fi Velocity - very interesting. engine failure due to auto fuel? Look at 1st-par on page 1a and 1 st-par on page 1b. Although an engine failure, the low octane auto gas contributed to the high compression engines demise. Also before the fatal flight the builder/pilot had vapor lock problems and installed additional return line and solenoid. Auto fuel was used. http://www.ntsb.gov/ntsb/GenPDF.asp?id=FTW98FA165&rpt=fa C'mon! You can deny deny deny but it's common knowledge. So when I say keep the fuel cool any way you can you see what I mean. I guess I am not that dumb after all. Sometime the NTSB probable cause for vapor lock is coded as: -Improper grade of fuel -fuel, system line blocked -fuel, system pump blocked -fluid, fuel starvation -fuel system overtemperature Unexplained does not mean it's not a possibility. I am just suggesting it's possible, suspect, that auto fuel contributed to the loss of power. You have to know what the vapor lock signals are. Heat and low atmospheric pressure is a recipe for VL. Here is a link that explains vapor lock. http://en.wikipedia.org/wiki/Vapour_lock >From: linn Walters <pitts_pilot(at)bellsouth.net> >Subject: Re: RV-List: MOGAS related Crashes, ouch > >I only read a few of the accident reports, and none that I >read said that Auto fuel CAUSED the accident. Great point, absolutly true. However when you read so many unexplained loss of power, high ambient temps and auto fuel, than you have to say, hummm. Obviously dirty rusty cans and not filtering the fuel is a dumb pilot trick. However when you handle fuel and buy car gas, the risk of getting bad gas increases, logically. I did not list several NTSB reports of in-flight engine failures due to valve damage. Now that could be due to detonation. We know a prime cause of detonation is low octane. Auto gas has lower octane. What scares me the most (and I found a few more since yesterday) are the takeoff or cruise unexplained loss of power, typically on hot days. That's scary and suggests vapor lock. May be I am not as big an idiot for suggesting that if you plan on using auto gas in your tightly cowled RV, you do everything you can to keep the fuel cool: hose insulation, heat shields, blast tubes and vapor return line. The mechanical pump is the biggest offender of heat into the fuel. They make shields and blast tubes for them. Also ceramic coated (in and out) exhaust is helpful. It might be a good idea even if you use AVfuel. If you plan on AVgas than less worries, it's without dispute AVgas is far more resistant to vapor lock and engine detonation with higher octane. That has been my main point. AVgas give you more margin to detonation and vapor lock. Also quality control of getting the fuel into the plane direct from an airfield pump or fuel truck is more higher or more secure. Clearly from 250 accidents, many involving poor fuel handing getting fuel into your plane, with gas cans, can cause contamination. Last, I don't think you can look at 250 accidents, almost all involving inflight loss of power, all w/ auto fuel on board, and not draw a conclusion? hummmmm, there is some increased risk. What can I learn from these NTSB reports, STC's, FAA, EAA and AOPA. Just like the TV public service Ads, You Ought-A Know. > "Jim Sears" > Since George has taken offense to our discussion, >I think it best to stop this discussion, now. I have been researching auto fuel for 20 years, since the late 80's. I just don't favor it for high compression engines and tightly cowled RV's. it's just my opinion. Sue me. :-) Besides reading a lot on the topic, as a CFI, I taught a group of pilots who owned a C-182 with a STC for auto fuel years ago. They stopped using it for several reasons. This is not like I just thought of this yesterday. I have followed this from the start. You present one side of the story, and just think another opinon was needed to this discourse. Jim has been 20 years flying with auto fuel. That is a good data point. I respect that. I recall Jim flys a low compression 150 HP Grumman Cheetah. I am going to submit the temps in the cowl of the AA-5 are less than a RV. Also with the lower temps and lower octane requirement of the 150 HP, O320, the Grumman makes a good candidate for auto fuel and better than a high compression RV. I do not believe Jim is flying his RV yet, so not sure he can claim auto gas RV experience, but I could be wrong. Forgive me if I am wrong. There are planes like the Mooney that suffer vapor lock with auto fuel and thus can not get a STC. It is not a stretch of logic to assume that the same issues might face the RV. I am NOT anti-Autogas. However I do think it is better suited for low compression engines (80/86 octane) and planes with big cowls and exhaust pipes that don't run inches from the carburetor, fuel lines and gascolator. THAT IS ALL FOLKS. Captain AVgas over and out, ha ha ha Cheers, George --------------------------------- at 1/min. ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Re: Heater vent inlet up vs down
Ralph, I have seen it done both ways. My outlet faces down, but others in my ar ea face up. Heat rises is one way to do it with outlet up, but then with th e exit air is a reason to do it the other. Maybe someone else has a good reason for one or the other. Have fun Tim -------Original Message------- Fellow listers, I'm getting ready to install my heater vents on the firewall. The way I read it, the instructions say 'inlet down'. This means that wh en you're not using the heater, the hot air is being blown up behind the eng ine instead of down towards the cowl exit area. Did I miss something? Does it matter? I would think inlet up.......Did they instruct it the other way for a reason? Pictures of how folks have already done it would be appreciated. Also, I f you did it one way and didn't like it......why? Ralph Capen ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
Date: Jul 10, 2006
Yep, there's a lot of emotional rant happening here. And no, it's not a building issue. But it is guaranteed to affect every one of us who enjoy burning hydrocarbons in their internal combustion engine in order to fly our little planes. Algore (making money) is using his misguided supporters to halt the use of CO2 emitting processes (i.e., powered flight). This will happen either through direct legislation or by indirectly jacking up the price to a point where 95% of us cannot afford to fly. This thread isn't just a silly little political or emotional rant. It's about seeing the end of recreational flying. You support Algore and his type, you have no place flying powered GA. Well, not without contradicting yourself. Sorry to be so harsh, but I take real offense at these misguided actions destroying my freedom to fly. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=46109#46109 ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Dan's Wx Site Address?
Hi Listers ... Can someone please post Dan Checkoway's weather site address ... I've misplaced it. Many thanks, Jerry Grimmonpre' jerry(at)mc.net ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Re: AKZO primer question
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Jul 10, 2006
The NMEA 0183 should work. Just make sure that the autopilot and EFIS are both at the same baud rate. The standard baud rate for the NMEA 0183 is 4800, but some systems will output at 9600 as well. Either is fine with the autopilot. Andrew Barker General Manager TruTrak Flight Systems "You build it...We fly it!" PH:479-751-0250 Ext. 222 www.trutrakap.com _____ [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of jellis9847(at)aol.com Sent: Saturday, July 08, 2006 9:09 PM Hi All, Is there anyone out there who has tried to connect a Blue Mountain EFIS G3 Lite to a Trutrak Pictorial Pilot? I have the Serial Port B connected to the Pictorial Pilot but the autopilot doesn't recognize the GPS input. I suspect that I don't have the correct settings in the EFIS (choices include GPSS and NMEA 0183 among others). BMA Tech Support says they haven't tested this autopilot so that can't give me the correct settings. Anybody out there have any ideas? Thanks Jim Ellis RV9-A, Flying _____ __________ NOD32 1.1651 (20060708) Information __________ This message was checked by NOD32 antivirus system. http://www.eset.com ________________________________________________________________________________
Date: Jul 10, 2006
> Let's move on. There'll be no converts and just wasted bandwidth. Bob: With respect, I couldn't disagree more. I haven't participated in the discussion at all, but I've found the ideas presented helpful. Sure, sometimes people express themselves badly. But there's still value in the discussion, and we shouldn't forget that a lot more people are reading what is said than are contributing themselves. As someone pointed out, this is something that will affect all of us who fly, so it needs to be discussed. Tedd McHenry Surrey, BC ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Re: RV-List Digest: 34 Msgs - 07/09/06, Gobal Warming?
We should be thankful at this time for global warming. Precisely where I am sitting (Minnesota) was buried under two miles of solid ice only a few thousand years ago, like 7-10 thousand years. The 10,000 lakes we enjoy are the direct result of those glaciers. Without global warming, nobody could live here, in northern Europe, or northern Asia. It is wise to be watchful but no need to be an alarmist. Paul S. Petersen, finishing RV6A with son Eric ________________________________________________________________________________
Date: Jul 10, 2006
Hi Ron, Thanks for the information. It was very useful. I spoke with Ross at Blue Mountain Avionics today and he told me that their NMEA-0183 output "should" work with a Trutrak autopilot but he said that neither he nor anyone else there had ever heard of anyone that had actually done so. My question is a simple one. Has anyone, anywhere ever been able to make a working connection between any Blue Mountain efis and any Trutrak autopilot? Strangely neither BMA or Trutrak technical support knows the answer to this question. I am truly baffled by the manufactures lack of knowledge about their very own product's usage in the real world! Jim Ellis ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Re: Connecting Blue Mountain EFIS lite to Pictorial Pilot
Hi Andrew, First of all let me say how surprised and delighted that you folks at TruTrak monitor the List and would take the time to respond. It is much appreciated! I spoke with John in your Tech Support Group today and he said much the same thing...that it "should" work. But he had never talked to anyone that had actually been able to make a working serial connection to a Blue Mountain EFIS. I don't know why but that seems so odd to me. There must be someone out there that has actually tried, successfully or otherwise, to connect a Blue Mountain EFIS to a TruTrak autopilot. Thanks again for your response, Jim Ellis RV9-A, Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=46212#46212 ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Cowling
Listers - I'm considering using the Sam James Holy Cowl on my RV-7. Anybody need a Van's (I)O-360 no-scoop cowl? Neal E. George 2023 Everglades Drive Navarre, FL 32566 Home - 850-515-0640 Cell - 850-218-4838 ________________________________________________________________________________
Date: Jul 10, 2006
Thanks everyone for the replies. Richard, it is slightly amber colored -- kind of like the color of auto gas. Does anyone know if it had any color to start with. I don't remember. The primer sprays and cures OK. It is as hard as nails just like it was 4 or 5 years ago. Its amazing stuff for those of you who haven't used it. How would I replace the hardener? Is it cheaper than the base? I bought them both from Aircraft Spruce together. Dan Hopper RV-7A In a message dated 7/10/2006 1:12:44 P.M. Eastern Daylight Time, seiders(at)bellsouth.net writes: --> RV-List message posted by: Richard Seiders Dan, I spoke with a friend who operates an auto body and paint shop (he painted my RV6A doing a beautiful job) and he says primer should be ok but check hardener and if yellowed replace it. Dick At 09:12 AM 7/10/2006, you wrote: Listers, No, I don't want to start a war. I have 2 one gallon cans (base and curing solution) of Dexter (AKZO) 2 part epoxy primer that are now 5 years old. The label says the maximum shelf life is 2 years -- mil spec, etc. They have been kept at room temperature the whole time (air conditioned in summer, greater than 60 degrees in winter). The contents look good after stirring the base for about 5 minutes. I mixed some up and waited 1/2 hour and sprayed it on a piece of scotch-bright scuffed aluminum. After curing it seems to be very hard and works like new as far as I can tell. Here is the question: what would be the failure mode of using this old primer? I hate to throw away $130 plus shipping if it is actually OK to use. Dan Hopper RV-7A ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Jacking up an RV
There has been a lot of information shared over the years on tires and changing of tires. I'm about to finish installing my gear and would like to know if the Avery RV Jack Stand is the way to go or not. I would like to hear from some who can extol the benefits of this method of changing tires or from anyone that was not satisfied with this type of jacking up the RV and what they did instead. Marty in Brentwood RV-6A ________________________________________________________________________________
Date: Jul 10, 2006
Subject: Re: Jacking up an RV
I have the Avery RV Jack Stand and have used it exclusively on my RV-7. I've changed tires 3 or 4 times, rotating the tires halfway through their wear. All said and done, I've probably jacked the thing up a dozen times or more using the jack stand. Works great from my perspective. It's stable and quick. I'm hard-pressed to think of a down-side other than having to hollow out the axle nut, which isn't a big deal. Some have said that you can simply put a hose clamp around the base of the gear leg at the bend, and then jack up against that. That would sure be the simplest way to go. But in my case the brake tubing loop would interfere with doing that. )_( Dan RV-7 N714D (972 hours) http://www.rvproject.com ----- Original Message ----- Sent: Monday, July 10, 2006 7:04 PM > > There has been a lot of information shared over the years on tires and > changing of tires. I'm about to finish installing my gear and would like > to > know if the Avery RV Jack Stand is the way to go or not. I would like to > hear from some who can extol the benefits of this method of changing tires > or from anyone that was not satisfied with this type of jacking up the RV > and what they did instead. > > Marty in Brentwood > RV-6A > > > ________________________________________________________________________________
Date: Jul 10, 2006
In a message dated 7/10/2006 7:10:17 P.M. Pacific Daylight Time, emrath(at)comcast.net writes: or from anyone that was not satisfied with this type of jacking up the RV and what they did instead. =========================================== I just use my old hydraulic floor jack sitting on top of a plastic step-stool/tool case. It has a cupped end that lifts against my wing tie down rings. I use the McMaster-Carr electro-polished stainless steel lifting eyes (P/N 8891T48) for my tie down rings, so they are hell-for-stout pulling or pushing. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 10, 2006
In a message dated 7/10/2006 8:10:08 A.M. Pacific Daylight Time, rv_8pilot(at)hotmail.com writes: You support Algore and his type, you have no place flying powered GA. Well, not without contradicting yourself. ============================== This must be true, since I personally have never heard or seen any flip-flopping come at me from the right (he said facetiously). GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 10, 2006
I also have the Avery RV Jack stand and think it is great. I first purchased the little angle iron gizmo with the U-bolt that bolts around t he gear leg. It really is terrible. First it is not a flat spot to jack up on and slid off my jack once. Fortunately I still had the wheel on. Second you would have to remove the gear fairing in order to bolt this around yo ur gear leg. The Avery tool is a good one for my money. Angle iron with U-bolt purchased from Van's for sale cheap. Tim -------Original Message------- I have the Avery RV Jack Stand and have used it exclusively on my RV-7. I've changed tires 3 or 4 times, rotating the tires halfway through their wear. All said and done, I've probably jacked the thing up a dozen times or more using the jack stand. Works great from my perspective. It's stable and quick. I'm hard-pressed to think of a down-side other than having to hollow out the axle nut, which isn't a big deal. Some have said that you can simply put a hose clamp around the base of th e gear leg at the bend, and then jack up against that. That would sure be the simplest way to go. But in my case the brake tubing loop would interfere with doing that. )_( Dan RV-7 N714D (972 hours) http://www.rvproject.com ----- Original Message ----- Sent: Monday, July 10, 2006 7:04 PM > > There has been a lot of information shared over the years on tires and > changing of tires. I'm about to finish installing my gear and would lik e > to > know if the Avery RV Jack Stand is the way to go or not. I would like to > hear from some who can extol the benefits of this method of changing ti res > or from anyone that was not satisfied with this type of jacking up the RV > and what they did instead. > > Marty in Brentwood > RV-6A > > ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
Date: Jul 10, 2006
Subject: exhaust bolt torque
I was going to torque down the nuts on the exhaust studs on my O-360 when I noticed a contradiction between my torque tables and Larry Vetterman's instructions. Larry says to torque the nuts to 100- 140 in-lb. That's the torque value for a 5/16-24 bolt, according to my table. But the exhaust studs in my engine are 5/16-18. The torque table says to use 80-90 in-lb for the coarse thread 5/16 bolts. What's the right torque value here? Is this another situation like the engine case bolts (1/4-20) which are torqued at 90 - 100 in-lb (about double the value listed in the table)? -- Tom Sargent, RV-6A ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re: exhaust bolt torque
In a message dated 7/10/2006 9:02:38 P.M. Pacific Daylight Time, sarg314(at)comcast.net writes: I noticed a contradiction between my torque tables and Larry Vetterman's instructions. Larry says to torque the nuts to 100- 140 in-lb. That's the torque value for a 5/16-24 bolt, according to my table. ======================================== I torqued them to 100-140 in-lb just as Larry indicates. He's the exhaust expert as far as I'm concerned! GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 10, 2006
I saw another method advertised somewhere recently. It was a bent pipe with a T on one end. The T steadied the pipe on the floor. The bent pipe went over the wheel, and had a loop of cable that would go under the axle. You jacked up the free end of the bent pipe, lifting the wheel with the cable. It seemed to me that you could do the same thing with a 2x4 and a husky box to support one end of the 2x4. Loop a cable under the axle. Jack the free end of the 2x4. But I have never tried it so maybe it's a bad idea. Terry RV-8A finishing Seattle _____ [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Monday, July 10, 2006 8:57 PM I also have the Avery RV Jack stand and think it is great. I first purchased the little angle iron gizmo with the U-bolt that bolts around the gear leg. It really is terrible. First it is not a flat spot to jack up on and slid off my jack once. Fortunately I still had the wheel on. Second you would have to remove the gear fairing in order to bolt this around your gear leg. The Avery tool is a good one for my money. Angle iron with U-bolt purchased from Van's for sale cheap. Tim -------Original Message------- I have the Avery RV Jack Stand and have used it exclusively on my RV-7. I've changed tires 3 or 4 times, rotating the tires halfway through their wear. All said and done, I've probably jacked the thing up a dozen times or more using the jack stand. Works great from my perspective. It's stable and quick. I'm hard-pressed to think of a down-side other than having to hollow out the axle nut, which isn't a big deal. Some have said that you can simply put a hose clamp around the base of the gear leg at the bend, and then jack up against that. That would sure be the simplest way to go. But in my case the brake tubing loop would interfere with doing that. )_( Dan RV-7 N714D (972 hours) http://www.rvproject.com ----- Original Message ----- Sent: Monday, July 10, 2006 7:04 PM > > There has been a lot of information shared over the years on tires and > changing of tires. I'm about to finish installing my gear and would like > to > know if the Avery RV Jack Stand is the way to go or not. I would like to > hear from some who can extol the benefits of this method of changing tires > or from anyone that was not satisfied with this type of jacking up the RV > and what they did instead. > > Marty in Brentwood > RV-6A > > > > > > > > > > > > > ===================================== he RV-List Email Forum - http://www.matronics.com/Navigator?RV-List ===================================== sp; - NEW MATRONICS LIST WIKI - nics.com ===================================== sp; - List Contribution Web Site - sp; -Matt Dralle, List Admin. //www.matronics.com/contribution ===================================== ________________________________________________________________________________
Date: Jul 10, 2006
Subject: New TruTrack Pictorial Pilot Autopilot for Sale
New in box 2 1/4" Pictorial Pilot combination turn coordinator/wing leveler AP. See http://www.trutrakflightsystems.com for specs and pictures. The Autopilot has the installation hardware for an RV-4 with it. $1700 includes shipping. Tom Velvick email tomvelvick(at)cox.net cell 623-261-2096 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=46285#46285 ________________________________________________________________________________
Date: Jul 11, 2006
Subject: How to fly Constant Speed?
Can someone explain how to fly a constant speed prop? I can't seem to find much info in the wealth of flying books I have here. Any recommended books? So far I've read: To reduce power: Set throttle to desired RPM. See prop to MP, RPM will remain constant. To increase power: Set prop to fine. Increase throttle/RPM. Correct? Else? BobR _________________________________________________________________ http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Jul 10, 2006
I used the hose clamp at the bend method and it worked, more or less, but one time it fell off the jack and bent the brake caliper bracket for a $90 replacement part. Ouch. The Avery set up does require the cotter key to be removed before jacking so it's not a handy way to level the airplane for getting gyros straight in the panel or getting a remote compass module level. If you're changing/rotating tires or packing wheel bearings, the cotter's got to come out anyway so that's not a big deal. Pax, Ed Holyoke -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Checkoway Sent: Monday, July 10, 2006 7:33 PM I have the Avery RV Jack Stand and have used it exclusively on my RV-7. I've changed tires 3 or 4 times, rotating the tires halfway through their wear. All said and done, I've probably jacked the thing up a dozen times or more using the jack stand. Works great from my perspective. It's stable and quick. I'm hard-pressed to think of a down-side other than having to hollow out the axle nut, which isn't a big deal. Some have said that you can simply put a hose clamp around the base of the gear leg at the bend, and then jack up against that. That would sure be the simplest way to go. But in my case the brake tubing loop would interfere with doing that. )_( Dan RV-7 N714D (972 hours) http://www.rvproject.com ----- Original Message ----- Sent: Monday, July 10, 2006 7:04 PM > > There has been a lot of information shared over the years on tires and > changing of tires. I'm about to finish installing my gear and would like > to > know if the Avery RV Jack Stand is the way to go or not. I would like to > hear from some who can extol the benefits of this method of changing tires > or from anyone that was not satisfied with this type of jacking up the RV > and what they did instead. > > Marty in Brentwood > RV-6A > > > ________________________________________________________________________________
Date: Jul 11, 2006
Here is one that got away: The Navion corrected http://www.ntsb.gov/ntsb/brief.asp?ev_id 001213X30993&key=1 Cheers George RV-4, RV-7 --------------------------------- ________________________________________________________________________________
Date: Jul 11, 2006
Here is what Lycoming has to say: http://www.lycoming.textron.com/main.jsp?bodyPage=/support/publications/keyReprints/operation/basicPowerSequence.html http://www.lycoming.textron.com/main.jsp?bodyPage=/support/publications/keyReprints/operation/powerSettings.html http://www.lycoming.textron.com/main.jsp?bodyPage=/support/publications/keyReprints/operation/lowPowerLowRPM.html http://www.lycoming.textron.com/main.jsp?bodyPage=/support/publications/keyReprints/operation/oldWivesTales.html Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,892 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- Can someone explain how to fly a constant speed prop? I can't seem to find much info in the wealth of flying books I have here. Any recommended books? So far I've read: To reduce power: Set throttle to desired RPM. See prop to MP, RPM will remain constant. To increase power: Set prop to fine. Increase throttle/RPM. Correct? Else? BobR _________________________________________________________________ http://search.msn.click-url.com/go/onm00200636ave/direct/01/ http://www.matronics.com/Navigator?RV-List http://wiki.matronics.com ________________________________________________________________________________
Date: Jul 11, 2006
emrath(at)comcast.net wrote: > There has been a lot of information shared over the years on tires and changing of tires. I'm about to finish installing my gear..........or from anyone that was not satisfied with this type of jacking up the RV and what they did instead. Marty in Brentwood > RV-6A Marty, I use the (admittedly pricey) Axle Jack offered by Van's, Spruce and probably others. It is a very easy, almost bulletproof method to quickly jack up a wheel. Little more than 48 hours ago I used it to rotate the tires and tubes to even out the wear pattern and while I was at it, changed the brake pads. Using this tool made jacking the airplane up a very quick and simple proposition. The whole thing breaks down into smaller component pieces and is stowed in a heavy cloth sack to carry along (if desired) on cross country trips. With this jack no modifications are necessary and emergency field repairs can be made without augmenting the tool with an appropriately sized bottle jack. http://img225.imageshack.us/img225/1750/tirejack407go.jpg Here is the link to Van's that better describes the included accessories package. http://tinyurl.com/o9bcy Rick Galati RV-6A "Darla" 151 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=46313#46313 ________________________________________________________________________________
Date: Jul 11, 2006
Marty, I took a 3/8 inch bolt, cut it off, and rounded the end for a safe fit into the top of my hydraulic bottle jack. This is a little more secure than jacking on the tiedown ring. I set the jack up on a piece of 2x6 lumber on top of 2 cement blocks on the concrete hangar floor. It would be safer to bolt a plate about 7 inches square to the bottom of the jack and I plan to do this. Be sure to chock the other main wheel as well as the nose wheel (if you have one). Dropping the airplane and punching a hole in the wing skin would of course be a disaster. I'm not saying this is the best way. I just used what I had available. Dan Hopper RV-7A ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Jul 11, 2006
I torqued my O360 at 90 in-lbs. They have not come off or loosened in over 100 hours. I checked them at last annual and they were all still tight. AND No leaks. Maybe it should be considered to torque at the low end of Vetterman's or the high end of the published torque table in the manual. I am sure Vetterman knows his stuff. That is quite a spread between 100 and 140 however. Usually you find this type spread when a cotter pin needs to be used which is not the case here. Indiana Larry ----- Original Message ----- > > I was going to torque down the nuts on the exhaust studs on my O-360 when > I noticed a contradiction between my torque tables and Larry Vetterman's > instructions. Larry says to torque the nuts to 100- 140 in-lb. That's > the torque value for a 5/16-24 bolt, according to my table. But the > exhaust studs in my engine are 5/16-18. The torque table says to use > 80-90 in-lb for the coarse thread 5/16 bolts. > What's the right torque value here? > > -- > Tom Sargent, RV-6A > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 11, 2006
The Avery jack works fine on my RV7. I played around with other jacking methods and they just did not seem safe after trying them. The Avery jack has been used twice and I like it. Money well spent. Indiana Larry ----- Original Message ----- > > There has been a lot of information shared over the years on tires and > changing of tires. I'm about to finish installing my gear and would like > to > know if the Avery RV Jack Stand is the way to go or not. I would like to > hear from some who can extol the benefits of this method of changing tires > or from anyone that was not satisfied with this type of jacking up the RV > and what they did instead. > > Marty in Brentwood ________________________________________________________________________________
Date: Jul 11, 2006
I made some weldments that screw into the wing tiedown and standard aircraft jacks for jacking... I will take some photos today and pass them on... -Bill ----- Original Message ----- Sent: Monday, July 10, 2006 8:04 PM There has been a lot of information shared over the years on tires and changing of tires. I'm about to finish installing my gear and would like to know if the Avery RV Jack Stand is the way to go or not. I would like to hear from some who can extol the benefits of this method of changing tires or from anyone that was not satisfied with this type of jacking up the RV and what they did instead. Marty in Brentwood RV-6A ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re: How to fly Constant Speed?
Yes definately get some instruction. You'll learn procedures and techniques with landing, etc that you'll want to experience before you fly with a CS prop. Not a big science, but as mentioned already, a flight with a CFI on using a CS prop would be very beneficial. Paul Besing --- bob rundle wrote: > > > Can someone explain how to fly a constant speed > prop? I can't seem to find > much info in the wealth of flying books I have here. > Any recommended books? > > So far I've read: > To reduce power: Set throttle to desired RPM. See > prop to MP, RPM will > remain constant. > To increase power: Set prop to fine. Increase > throttle/RPM. > > Correct? Else? > > BobR > > _________________________________________________________________ > Dont just search. Find. Check out the new MSN > Search! > http://search.msn.click-url.com/go/onm00200636ave/direct/01/ > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re:Wanted Garmin 296 GPS
Jerry, I got my 296 on eBay from a guy who was doing just that... I see they've sold 13 in the last 2 weeks, range about $1100-1300. Also might check Pac Coast Avionics, they might get you one used... Jerry Cochran In a message dated 7/11/2006 12:04:41 A.M. Pacific Daylight Time, rv-list(at)matronics.com writes: Anyone on the list have a Garmin 296 they want to sell because they are upgrading to a 396 etc? do not archive Jerry ________________________________________________________________________________
Date: Jul 11, 2006
> Here is one that got away: > > The Navion corrected > http://www.ntsb.gov/ntsb/brief.asp?ev_id 001213X30993&key=1 That aircraft, built in 1947, would be a Navion A. They are particularly susceptible to vapour lock, and no mogas STC has been issued for them. Tedd McHenry Surrey, BC ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re: "you're gonna die because you use autogas"
One thing I should point out is the source for my autogas. I have an account at the local farm bureau here out in the sticks where I live in central Indiana, and swipe my card to get biodiesel or unleaded and get a bill every month. They get their fuel from a small refinery in southern Indiana that only serves farm bureau distributors. I've talked to people at the refinery and they assured me that alcohol is not used at all in their refining processes. On many occasions (especially in the winter months) I have run 100% 87 octane with no problem but as a precaution I mix 25/75 100LL. Since there is no requirement for their rural customers to use oxygenates required by the EPA in and around major cities I suspect that is why I have been successful in using the fuel I do. As a side note, the source of oil for this particular refinery are small mom-and-pop oil wells scattered throughout southern Indiana and Illinois. So when people talk about lessening the dependence on foreign oil, I can honestly say that most of the fuel we buy is sourced from a domestic supplier of crude oil. I also drive a 50-mpg diesel car. Needless to say my motivation for running autogas in my airplane goes beyond just saving a considerable chunk of $$ annually. On another related note, I have a couple of friends with Rockets who I have flown cross-country with many times. Every time we go somewhere we all fill up and at our fuel stops we have a friendly contest to see who burned the least amount of fuel. And every time, without fail, the Rockets beat the RV's in least fuel used by a gallon or two. Every time the aircraft which use the most fuel are the carbureted RV's with O-320's and fixed pitch props. Its funny how counter intuitive that is. Regards, Bob Japundza RV-6 flying, F1 under const. ________________________________________________________________________________
Date: Jul 11, 2006
I bought a 2 ft piece of 5/8" (I think that's right) steel rod. This slips inside the axle. I then use my floor jack used for the car, it will fit under the steel rod, and jack the plane up. Works a lot like Avery's jack stand, but you really don't need any more than the steel rod. John L. Danielson RV-6 sold -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Emrath Sent: Monday, July 10, 2006 8:04 PM There has been a lot of information shared over the years on tires and changing of tires. I'm about to finish installing my gear and would like to know if the Avery RV Jack Stand is the way to go or not. I would like to hear from some who can extol the benefits of this method of changing tires or from anyone that was not satisfied with this type of jacking up the RV and what they did instead. Marty in Brentwood RV-6A ________________________________________________________________________________
Date: Jul 11, 2006
I read Flying High Performance Singles and Twins and Flying the Beech Bonanzas. They provide examples of power settings and the resulting performance of the aircraft. As an example, from study level flight reducing the MP by 5 inches will cause the Bonanza to descend at 500 fpm. So will extending the landing gear. My Basic rules 1 More MP (Manifold Pressure) means more power 2 Closing throttle and climbing will decrease MP 3 MP will not exceed density altitude pressure without assistance, will equal it with engine off, and can be a predictor of takeoff performance. 4 More RPM means more power, and use maximum for takeoff. 5 High power and low RPM is bad. Causes unnecessary engine stress. 6 High RPM means high noise and engine wear. 7 Low power and high RPM can act as an aerodynamic brake on descent or approach. Can someone explain how to fly a constant speed prop? I can't seem to find much info in the wealth of flying books I have here. Any recommended books? Sherman Butler RV-7a Wings Idaho Falls --------------------------------- Everyone is raving about the all-new Yahoo! Mail Beta. ________________________________________________________________________________
Date: Jul 11, 2006
This technique sounds intriguing. Can you please describe the process? Thanks, Jimmy Ayres RV-7A - building RV-6A - flying -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Oldsfolks(at)aol.com Sent: Monday, July 10, 2006 8:42 AM Why not just buy a "Mity-Vac" ,which is made for this kind of job ??? Harbor freight tools has one model for about 15 bucks and it has the things needed to do the job. More expensive models have more equipment and are re-buildable. Bob Olds RV-4 Charleston,Arkansas ________________________________________________________________________________
Date: Jul 11, 2006
Oversquare operation has been pretty much de-bunked as an old wives tale. Most POH's show available operations well into oversquare territory. My fixed-pitch prop RV operates oversquare on pretty much every takeoff. I have MAP in mine and at sea level I show 31" at 2200 rpm on takeoff. I usually pull back to 25" on climb (RPM approx 2300) and keep bumping the power back up to 75% as I climb. If you don't have MAP, then you don't know you're oversquare and it won't harm the engine. :-) Ed Bundy On a sidenote on running oversquare: How does one with a fixed pitch propeller operating from low altitude or even sea level deal with said oversquare scenario's? Isn't that pretty much an oversquare situation right from the get-go when one applies full take off power? As a Manifold Pressure Gauge is not required in a fixed pitch airplane, how would one even know how much oversquare they are during the takeoff roll? ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Instruments for Sale
I am re-doing my RV-4 instrument panel and I am selling my old instruments. Below is what I have for sale, first come first serve..... The rest will go to eBay. Also, if you feel the price is too high, feel free to make an offer, I'll take the highest offer or I'll eBay them. All instruments were new 168 hours ago, except the Dynon has less than 100 hours and the KX155, KI209, and the KT76A were used when I purchased them. Please respond off list to n223rv (at) wolflakeairport.net. Pictures available upon request, but I will most likely only be able to respond in the evenings. All prices include FedEx ground shipping. Item Current Price Asking Price UMA 1.25" CHT gauge $117.95 $82.00 UMA 1.25" Oil Pressure gauge $118.95 $83.00 UMA 1.25" Ammeter gauge $154.95 $108.00 UMA 1.25" EGT gauge $117.95 $82.00 UMA 1.25" Fuel Pressure gauge $118.95 $83.00 UMA 1.25" Volt Meter gauge $118.95 $83.00 UMA 1.25" Oil Temp gauge $118.95 $83.00 Price for all 7 gauges $866.65 $570.00 King KX155 14V w/ G/S $2,000.00 King KI209 Indicator (VOR/Glideslope Indicator) $750.00 King KT76A 14V Transponder $750.00 Garmin 295, color GPS, all original accy's, extra power cords, manuals, and original box $625.00 Comant Diplexer CI 1125 (Dual VOR and Dual G/S to one antenna) $125.95 $75.00 Van's Fuel Gauges (2) $70.00 $45.00 NavAid Autopilot $1,300.00 $650.00 Smart Coupler II LE $249.00 $200.00 UMA Tachometer PN TU 3041 and 19-806-11G (odometer showing 196 hours) $198.75 $110.00 UMA Airspeed PN 16-310-241D $160.00 $125.00 Van's Manifold Pressure Gauge (gauge only, no sender) $73.40 $25.00 Falcon Altimeter PN ALT20INF-3N 0-20K' $196.95 $130.00 Dynon D10 w/ magnetometer,OAT sensor, and flush mount $2,285.00 $1,500.00 Westach Carb Mix and OAT Temp gauge PN 2DA3-8 $83.25 $50.00 EI Fuel Flow Gauge (gauge only, no sender) $518.00 $310.00 P.S. - I'm no scammer, feel free to read my feedback on eBay (user ID mkraus01) Also, anyone is welcome to fly into my house and pick up the instruments, I live at 26W near Jackson, Michigan. Look us up on AirNav.com or just come visit sometime. I love guests and I have a flying RV-4 and building an RV-10. Thanks, Mike Kraus ________________________________________________________________________________
From: "Garrett, Randy L Dr HQ INSCOM" <randy.garrett1(at)us.army.mil>
Date: Jul 11, 2006
Subject: Aerobatics and gyro's
I am planning to begin aerobatics in my RV-6A (and will go through the proper paperwork process to add aerobatic manuevers to my flight limitations). I have a vacuum artificial horizon and directional gyro and an electrical turn coordinator. Unfortunately, there is no simple way to quickly remove any of these instruments. A potentially clever alternative ... I could easily adjust the vacuum so that the AH and DG do not run at all (that is, there's zero air flowing though the instruments) and pull the circuit breaker so that the turn coordinator is also off. But, I don't know if this would be better or worse for the gyros to not be spinning when they have G and centrifical forces applied to them. Also, would there be a problem for the vacuum pump to be running, but presumably not having any air flowing through it? Thanks! Randy Garrett RV-6A 675 hours ________________________________________________________________________________
From: "Dan Beadle" <dan.beadle(at)inclinesoftworks.com>
Date: Jul 11, 2006
I believe that this is a good solution. As long as they are not spinning, there is little stress on the bearings. _____ [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Garrett, Randy L Dr HQ INSCOM Sent: Tuesday, July 11, 2006 8:01 PM I am planning to begin aerobatics in my RV-6A (and will go through the proper paperwork process to add aerobatic manuevers to my flight limitations). I have a vacuum artificial horizon and directional gyro and an electrical turn coordinator. Unfortunately, there is no simple way to quickly remove any of these instruments. A potentially clever alternative ... I could easily adjust the vacuum so that the AH and DG do not run at all (that is, there's zero air flowing though the instruments) and pull the circuit breaker so that the turn coordinator is also off. But, I don't know if this would be better or worse for the gyros to not be spinning when they have G and centrifical forces applied to them. Also, would there be a problem for the vacuum pump to be running, but presumably not having any air flowing through it? Thanks! Randy Garrett RV-6A 675 hours ________________________________________________________________________________
Date: Jul 11, 2006
Subject: Re: Aerobatics and gyro's
Incorrect. Our EAA chapter just had a presentation from an avionics and major gyro rebuilding shop. I asked specifically about aerobatics and gyros, they said "No problem whatsoever, UNLESS you do something silly like remove the vacuum". They know the internals of gyros intimately, and said there are stops for the gimbals and it does them no harm at all to go to the stops for loops, rolls, etc. I know there are many wives tales and hunches out there, but these guys have serious experience with gyros. Mitch Faatz RV-6A Finish Kit (no, really) Auburn, CA Dan Beadle wrote: > > I believe that this is a good solution. As long as they are not > spinning, there is little stress on the bearings. > > > > ------------------------------------------------------------------------ > > *From:* owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Garrett, > Randy L Dr HQ INSCOM > *Sent:* Tuesday, July 11, 2006 8:01 PM > *To:* rv-list-digest(at)matronics.com > *Subject:* RV-List: Aerobatics and gyro's > > > > > > I am planning to begin aerobatics in my RV-6A (and will go through the > proper paperwork process to add aerobatic manuevers to my flight > limitations). > > I have a vacuum artificial horizon and directional gyro and an > electrical turn coordinator. > > Unfortunately, there is no simple way to quickly remove any of these > instruments. > > A potentially clever alternative ... > > I could easily adjust the vacuum so that the AH and DG do not run at > all (that is, there's zero air flowing though the instruments) and > pull the circuit breaker so that the turn coordinator is also off. > > But, I don't know if this would be better or worse for the gyros to > not be spinning when they have G and centrifical forces applied to > them. Also, would there be a problem for the vacuum pump to be > running, but presumably not having any air flowing through it? > > Thanks! > > Randy Garrett > RV-6A > 675 hours > ________________________________________________________________________________
Date: Jul 12, 2006
Subject: FW: powder coating panel - how big holes?
Hi - I'm getting ready to put a new panel in my 6a and plan to powder coat the panel after it has been cut. Does anyone have any suggestions about how much bigger we should cut holes to accommodate powder coating? How thick is it? Thanks, Parker ____________________________________ F. Parker Thomas ShredFirst phone 510-433-0200 fax 510-217-5976 parker(at)shredfirst.biz www.shredfirst.biz ________________________________________________________________________________
Date: Jul 12, 2006
Subject: Re: FW: powder coating panel - how big holes?
In a message dated 7/12/06 8:31:03 AM Eastern Daylight Time, me(at)parkerthomas.com writes: > I'm getting ready to put a new panel in my 6a and plan to powder coat the > panel after it has been cut. Does anyone have any suggestions about how > much bigger we should cut holes to accommodate powder coating? How thick is > it? > > Thanks, > > Parker ============================================ Parker: All according to what material they use for powder coating the thickness can vary from .005 to .015" So, if you are looking for a depth to work with, I would use .015" deeper. The worse condition would be the flat head screws would sit below the panel face by .010" If you coat thinner you might as well paint and save the cost and time. The other option is to get a 100 Deg countersink and just do a slight hand ream with the countersink. Just make sure it is 100 Deg ... As you probably know aircraft screws are 100 Deg. The other option is to use Pan Head or Philister Head Screws and just have the screw holes a straight hole. Use the above heads and a thin washer for looks. You can have the mounting hardware painted in a flat color to match or to contrast. I happen to like Dark colors for the panel - Black or Blue, it helps to cut down on glare. I fly an RV-6 & RV-6A they have light color panels and glare at night is a problem. The canopy just reflects the light like a parabola. Barry "Chop'd Liver" ________________________________________________________________________________
Date: Jul 12, 2006
Have ad on Barnstormers for following : Navaid head $400 good operating Terra 760D com $400 good operating Terra 200d nav $750 (needs some work as LOC ok, GS not indicating) Terra Tri Nav C digital vor/loc/gs good operating $400 Will sell as combinations and discount p[rices. e mail seiders(at)bellsouth.net or call 770 377 8342 if int. Dick ________________________________________________________________________________
Date: Jul 12, 2006
Subject: Re: The TRUTH about MOGAS (very long)
Here is something I didn't know until recently. When the engine's bore is increased from 4" to 5", the octane required increases by 10 units. That's from "The Internal Combustion Engine in Theory and Practice -- Volume II." by Charles Taylor. (Thanks Jim Baker for recommending this book.) Most car engine's bores are well under 4" and the Lyc 360 is 5 1/8". From the same reference, our 8.7:1 compression ratio looks like more than 10:1 if the bore were the size of a car engine's. Those using auto gas should keep this in mind when thinking that the low compression ratios of aircraft engines should allow us to use low octane gas. Your engine may be closer to detonation than you realize. Dan Hopper RV-7A ________________________________________________________________________________
Date: Jul 12, 2006
Dan Thanks for the info. I'm curious however. What is the date of publication of this tome? Also, where might one find a copy? Charlie Kuss > > >Here is something I didn't know until recently. When the engine's >bore is increased from 4" to 5", the octane required increases by 10 >units. That's from "The Internal Combustion Engine in Theory and >Practice -- Volume II." by Charles Taylor. (Thanks Jim Baker for >recommending this book.) Most car engine's bores are well under 4" >and the Lyc 360 is 5 1/8". From the same reference, our 8.7:1 >compression ratio looks like more than 10:1 if the bore were the >size of a car engine's. > >Those using auto gas should keep this in mind when thinking that the >low compression ratios of aircraft engines should allow us to use >low octane gas. Your engine may be closer to detonation than you realize. > >Dan Hopper >RV-7A > > ________________________________________________________________________________
Date: Jul 12, 2006
>From: SCOTT SPENCER <aerokinetic(at)sbcglobal.net> >There seems to be an attitude especially decidedly >anti-mogas. It would appear to be an elitist sort of thing. >I've flown with plenty of "holier than thou types" who >disdain mogas (but have absolutely no experience with it). There has been an abundance of sarcastic condescending attitude, as apparent from you post's title. It's a waste of time in a constructive dialog or discourse. You have your story wrong. I even said I'd consider MOgas with a LOW compression engine and proper protection against vapor lock. Provided I could readily get good MOgas. MOgas has been at the scene of the accident, some fatal a few times. Sorry if that upsets you. Even Glasair in their hey day recognized it and switched to selling Lycs for their kits with fuel pump cooling shrouds. WHY? Even AVgas can vapor lock. The first of their tight cowl hi-perf kits suffered vapor lock. BTW If any one wants a mechanical fuel pump cooling shroud, here is a source. (see products, last item) http://www.showplanes.com/index_1024.htm Scott apparently the way you deal with important safety info is name calling. So if you don't like what you hear you want to shut them up by insulting them. Nice move. My way is to educate people and give them the information to make good decisions and mitigate or minimize the risk. I suggest people get the full scoop and know the negatives as well as the positive, cost savings. There was and still is decidedly one side dialog going on. I made my point for the good presenting the other side. Too bad if you don't like it. For some reason if someone has a different view the procedure is to attack the person and make personal comments. Sad. There is no room for emotion and denial in aviation safety. Deal with it. You quote Bob as an example and say SEE! Bob is some one who is very careful and a model for others planning auto fuel. Never once did I say MOgas operations can not or never be done safely, BUT it does take great and extra care. I don't care what you do, but I sure would hate another RV'er to crash and say, hey I did not understand vapor lock or octane. No else mentioned it, so I did. Scott it's not disdain for your beloved MOgas, just a cautious approach, that's all. Excuse me for having an opinion that's different than yours. Have a nice day. Cheers Captain AVgas, give me 100/100LL or give me death. (sarcasm) --------------------------------- ________________________________________________________________________________
Date: Jul 12, 2006
In a message dated 7/12/2006 4:24:14 A.M. Pacific Daylight Time, dale1rv6(at)comcast.net writes: Then why did they make gyros that were cageable? =============================== I thought it was so that you could re-erect the gyro once you got straight and level after completing your aerobatic maneuvers. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 12, 2006
Subject: New F.A.B. alternate air intake
I installed Van's first version of the alternate air intake, the one with the magnet holding the door closed. It didn't look like it was going to work well so when the reports started coming in about them not closing or staying open, I junked that Filtered Air Box and ordered another one. Then Van's came out with version 2.0 of the alternate air intake, a round opening in the bottom of the F.A.B. with a door that pivots on one screw. I installed that in my new F.A.B. I don't like this one either. My best efforts still mean it's a one-shot deal. If I open it I will have to remove the lower cowl to get it completely closed again. Considering that it is an emergency air source and would only be opened when I thought the front opening was obstructed, that isn't completely unreasonable. But I hate the idea of needing to remove the lower cowl anytime anyone pulls on the control, intentionally or otherwise. Maybe I am missing something important here. Any thoughts? Terry RV-8A finishing Seattle ________________________________________________________________________________
Date: Jul 12, 2006
Charlie, "The Internal Combustion Engine in Theory and Practice -- Volume II." by Charles Taylor was published in 1968 by the Massachusetts Institute of Technology. I found a copy on Ebay. Dan In a message dated 7/12/2006 10:41:24 A.M. Eastern Daylight Time, chaztuna(at)adelphia.net writes: Dan Thanks for the info. I'm curious however. What is the date of publication of this tome? Also, where might one find a copy? Charlie Kuss Here is something I didn't know until recently. When the engine's bore is increased from 4" to 5", the octane required increases by 10 units. That's from "The Internal Combustion Engine in Theory and Practice -- Volume II." by Charles Taylor. (Thanks Jim Baker for recommending this book.) Most car engine's bores are well under 4" and the Lyc 360 is 5 1/8". From the same reference, our 8.7:1 compression ratio looks like more than 10:1 if the bore were the size of a car engine's. Those using auto gas should keep this in mind when thinking that the low compression ratios of aircraft engines should allow us to use low octane gas. Your engine may be closer to detonation than you realize. Dan Hopper RV-7A ________________________________________________________________________________
Date: Jul 12, 2006
> Here is something I didn't know until recently. When the engine's bore is > increased from 4" to 5", the octane required increases by 10 units. Dan: This is a rule of thumb that is meant to compare similarly designed engines of different displacements, such as the O-320 and O-360. It would be a mistake to apply it to significantly different engine designs without taking into consideration other factors. For example, combustion chamber shape is equally significant, so that a smaller-bore combustion chamber can require higher octane than a larger-bore chamber, at the same CR, if its shape is more conducive to detonation. One can't simply conclude that one engine requires higher octane than another simply because its bore is larger. Tedd McHenry Surrey, BC ________________________________________________________________________________
Date: Jul 12, 2006
Also available from amazon.com -------------- Original message ---------------------- > > > Charlie, > > "The Internal Combustion Engine in Theory and Practice -- Volume II." by > Charles Taylor was published in 1968 by the Massachusetts Institute of > Technology. I found a copy on Ebay. > > Dan > > > In a message dated 7/12/2006 10:41:24 A.M. Eastern Daylight Time, > chaztuna(at)adelphia.net writes: > > Dan > Thanks for the info. I'm curious however. What is the date of publication of > this tome? Also, where might one find a copy? > Charlie Kuss > > > > > > Here is something I didn't know until recently. When the engine's bore is > increased from 4" to 5", the octane required increases by 10 units. That's > from "The Internal Combustion Engine in Theory and Practice -- Volume II." by > Charles Taylor. (Thanks Jim Baker for recommending this book.) Most car > engine's bores are well under 4" and the Lyc 360 is 5 1/8". From the same > reference, our 8.7:1 compression ratio looks like more than 10:1 if the bore > were > the size of a car engine's. > > Those using auto gas should keep this in mind when thinking that the low > compression ratios of aircraft engines should allow us to use low octane gas. > Your engine may be closer to detonation than you realize. > > Dan Hopper > RV-7A > > > > > > > Content-Type: Multipart/alternative; boundary="NextPart_Webmail_9m3u9jl4l_19207_1152723451_1" --NextPart_Webmail_9m3u9jl4l_19207_1152723451_1 Content-Type: text/html; charset="US-ASCII" Content-Transfer-Encoding: quoted-printable
Charlie,
"The Internal Combustion Engine in Theory and Practice -- Volume II." b y Charles Taylor was published in 1968 by the Massachusetts Institute of Technology.  I found a copy on Ebay.
Dan
< FONT style="BACKGROUND-COLOR: transparent" face=Arial color=#000000 size =2>Dan
 Thanks for the info. I'm curious however. What is th e date of publication of this tome? Also, where might one find a copy?
Charlie Kuss
Here is something I didn't know until recently.  When the engine's bore is increased from 4" to 5", the octane required increases by 10 units.  ; That's from "The Internal Combustion Engine in Theory and Practice -- Vo lume II." by Charles Taylor.  (Thanks Jim Baker for recommending this book.)  Most car engine's bores are well under 4" and the Lyc 360 i s 5 1/8".  From the same reference, our 8.7:1 compression ratio looks l ike more than 10:1 if the bore were the size of a car engine's.
Those using auto gas should keep this in mind whe n thinking that the low compression ratios of aircraft engines should allo w us to use low octane gas.  Your engine may be closer to detonation tha n you realize.
Dan Hopper
RV-7A
--NextPart_Webmail_9m3u9jl4l_19207_1152723451_1-- ________________________________________________________________________________
Date: Jul 12, 2006
Subject: Re: New F.A.B. alternate air intake
Terry, I did not like version 2.0 either so I scrapped the magnet and the magnet holder of version 1.0, and potted three smaller magnets on the outside of the FAB with 3M DP-190 epoxy. It takes a bit more force to get it open now. I put some dychem machinists ink on the throat of the carburetor as an indicator to show if the door was opening in flight and contacting the carb and so far it hasn't. I absolutely will not put anything mechanical in the path of non-filtered air that could come loose and get sucked into the engine. The airbox really takes a beating from vibration. Regards, Bob Japundza RV-6 flying, F1 under const. On 7/12/06, Terry Watson wrote: > > > I installed Van's first version of the alternate air intake, the one with > the magnet holding the door closed. It didn't look like it was going to > work > well so when the reports started coming in about them not closing or > staying > open, I junked that Filtered Air Box and ordered another one. Then Van's > came out with version 2.0 of the alternate air intake, a round opening in > the bottom of the F.A.B. with a door that pivots on one screw. I installed > that in my new F.A.B. I don't like this one either. My best efforts still > mean it's a one-shot deal. If I open it I will have to remove the lower > cowl > to get it completely closed again. Considering that it is an emergency air > source and would only be opened when I thought the front opening was > obstructed, that isn't completely unreasonable. > > But I hate the idea of needing to remove the lower cowl anytime anyone > pulls > on the control, intentionally or otherwise. > > Maybe I am missing something important here. Any thoughts? > > Terry > RV-8A finishing > Seattle > > ________________________________________________________________________________
Date: Jul 12, 2006
You can't reach in through the exhaust opening in the lower cowl? I glassed my version 1.0 door shut; and close the carb heat door/alt air door at first indication of precip/birds/meteors. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Terry Watson wrote: > > > I installed Van's first version of the alternate air intake, the one with > the magnet holding the door closed. It didn't look like it was going to > work > well so when the reports started coming in about them not closing or > staying > open, I junked that Filtered Air Box and ordered another one. Then Van's > came out with version 2.0 of the alternate air intake, a round opening in > the bottom of the F.A.B. with a door that pivots on one screw. I installed > that in my new F.A.B. I don't like this one either. My best efforts still > mean it's a one-shot deal. If I open it I will have to remove the lower > cowl > to get it completely closed again. Considering that it is an emergency air > source and would only be opened when I thought the front opening was > obstructed, that isn't completely unreasonable. > > But I hate the idea of needing to remove the lower cowl anytime anyone > pulls > on the control, intentionally or otherwise. > > Maybe I am missing something important here. Any thoughts? > > Terry > RV-8A finishing > Seattle > > ________________________________________________________________________________
Date: Jul 12, 2006
An interesting discussion. Strong statements related to the engine. And the propeller seems to be ignored. Certified aircraft have POH power settings directly related to the engine /propeller combination installed on that aircraft. Unfortunately, the POH power settings for an RV would be much more difficult to establish, because of all of the different engine/propeller combinations used. Just an aside. The engine may provide more horsepower with an increase in RPM, but the propeller requires more horsepower to turn at a given airspeed with an increase in RPM. Empirically, in cruise at full throttle at 7,500', the 72" diameter CS propeller on a Lycoming O-360 engine requires more horsepower than the engine produces when the RPM is increased from 2600 to 2700. This results in a slight decrease in airspeed. Regards, Jim Ayers ________________________________________________________________________________
Date: Jul 12, 2006
Subject: MAC servo supplier
Hi, Can anyone help with the contact details for Menzimer Aircraft Components Inc... I have a old address for Vista CA....but no reply from the phone number I got... Have they gone out of business or has the business been sold..changed owner... ?? Regards Jan http://www.w3.org/TR/REC-html40">
Hi,
Can anyone help with the contact details for Menzimer Aircraft Components Inc… I have a old address for Vista CA….but no reply from the phone number I got… Have they gone out of business or has the business been sold..changed owner… ??
Jan
Date: Jul 12, 2006
Here is my take on the FAB alternate air intake. The FAB was first introduced without any regard to alternate air intake. Someone, or perhaps several had a problem with ice on the carb filter as I understand it due to flying into icing conditions, ie, freezing rain, or snow and the carb heat activated after the fact did not melt the ice because the warmed air could not flow to melt the ice. The pop up door remedied this problem but on some large engines like the 360 it could open due to the amount of vacuum created during high power settings such as during take off in perhaps dusty conditions. That could affect engine longevity because unfiltered air was getting into the engine. So the pop up door was replaced with a manual door that the pilot had to activate with a pull lever. The carb heat feature can close off all freezing moisture if activated before the air filter completely freezes, thereby cutting off all air movement through the filter. The new manually activated door allows unfiltered air into the carb when done can get through the filter. I don't think there is any problem with the FAB without an alternate air solution IF the carb heat is utilized before the air filter freezes over solid. So if the pilot recognizes the possibility of snow or freezing rain situation and pulls carb heat before air flow is totally cut off, there should not be a reason to activate the new manual alternate air solution as the heated air from carb heat will melt the ice on the filter. Based on this understanding, I removed the pop up door to save my engine from possible harm and glassed over it and did not install the sliding door solution. Aside from not activating carb heat in time, the one situation that the manual alternate air system will help on is if a plastic bag, or bird, or something is ingested in the air input that cuts off air to the carb. I don't know but the vacuum pressure could be strong enough to burst a bag and it might not be a problem without the alternate air. I liked the pop up door before I learned of its weakness. I am surprised Vans did not just strengthen the door so it could not accidentally deploy. Someone suggested adding stronger magnets. I think that is a better solution. Indiana Larry ----- Original Message ----- > > > I installed Van's first version of the alternate air intake, the one with > the magnet holding the door closed. It didn't look like it was going to > work > well so when the reports started coming in about them not closing or > staying > open, I junked that Filtered Air Box and ordered another one. Then Van's > came out with version 2.0 of the alternate air intake, a round opening in > the bottom of the F.A.B. with a door that pivots on one screw. I installed > that in my new F.A.B. I don't like this one either. My best efforts still > mean it's a one-shot deal. If I open it I will have to remove the lower > cowl > to get it completely closed again. Considering that it is an emergency air > source and would only be opened when I thought the front opening was > obstructed, that isn't completely unreasonable. > > But I hate the idea of needing to remove the lower cowl anytime anyone > pulls > on the control, intentionally or otherwise. > > Maybe I am missing something important here. Any thoughts? > > Terry > RV-8A finishing > Seattle ________________________________________________________________________________
Date: Jul 12, 2006
Lots of detail above. Two VERY GENERAL sequences of operation used to operate a CS prop/engine combo: Enrich the mixture, increase prop rpm, increase power (throttle). Decrease power (throttle), decrease rpm, lean the mixture. The specific numbers will vary with engine, prop, AC, etc. There are also lots of variations to these general sequences. Search for contollable pitch propeller (FAA lingo). Try the FAA document, Airplane Flying Handbook. http://www.faa.gov/library/manuals/aircraft/airplane_handbook/media/faa-h-8083-3a-5of7.pdf Read this topic online here: http://forums.matronics.com/viewtopic.php?p=46751#46751 ________________________________________________________________________________
Date: Jul 12, 2006
Thanks Indiana Larry. That all makes good sense, but I have fuel injection and therefore no carb heat door. A carb heat door would solve part of the problem -- if a bird or big snowball got stuck in the intake ahead of the carb heat inlet -- but the alternate air door is intended to also let air into the engine if the filter gets covered with ice, as I understand it. So a carb heat door, even with a fuel injection system, would solve half of the problem, or handle some but not all of the anticipated possible air inlet blockages. And thanks North Carolina Larry. Because I have a nosewheel, I don't think I could reach up in there to close the door properly, but I would sure give it a try before I removed the lower cowl. I think I can live with what I have, but I am still hoping someone has come up with an idea that makes this door work as intended. I have been thinking about getting a control cable with a T-handle and push-button to discourage me from pulling the wrong knob, but my history warns me that might not stop me. Thanks, Terry Here is my take on the FAB alternate air intake. The FAB was first introduced without any regard to alternate air intake. Someone, or perhaps several had a problem with ice on the carb filter as I understand it due to flying into icing conditions, ie, freezing rain, or snow and the carb heat activated after the fact did not melt the ice because the warmed air could not flow to melt the ice. The pop up door remedied this problem but on some large engines like the 360 it could open due to the amount of vacuum created during high power settings such as during take off in perhaps dusty conditions. That could affect engine longevity because unfiltered air was getting into the engine. So the pop up door was replaced with a manual door that the pilot had to activate with a pull lever. The carb heat feature can close off all freezing moisture if activated before the air filter completely freezes, thereby cutting off all air movement through the filter. The new manually activated door allows unfiltered air into the carb when done can get through the filter. I don't think there is any problem with the FAB without an alternate air solution IF the carb heat is utilized before the air filter freezes over solid. So if the pilot recognizes the possibility of snow or freezing rain situation and pulls carb heat before air flow is totally cut off, there should not be a reason to activate the new manual alternate air solution as the heated air from carb heat will melt the ice on the filter. Based on this understanding, I removed the pop up door to save my engine from possible harm and glassed over it and did not install the sliding door solution. Aside from not activating carb heat in time, the one situation that the manual alternate air system will help on is if a plastic bag, or bird, or something is ingested in the air input that cuts off air to the carb. I don't know but the vacuum pressure could be strong enough to burst a bag and it might not be a problem without the alternate air. I liked the pop up door before I learned of its weakness. I am surprised Vans did not just strengthen the door so it could not accidentally deploy. Someone suggested adding stronger magnets. I think that is a better solution. Indiana Larry ________________________________________________________________________________
Date: Jul 12, 2006
Ted, Yes, lots of things determine the octane required. Combustion chamber shape is certainly one which is very significant. In fact the open chamber like our Lycomings, in general, are the least resistant to detonation according to this book. All other things being equal, it IS fair to say that a larger bore engine requires higher octane fuel. This is not a rule of thumb, but was determined by a lot of testing. There are many graphs in this book which show the data from these tests. The book admits that there was (is?) still much to learn about the causes and cures of detonation. I'm not sure how much we've learned since then, but I think anything written in 1968 still applies to Lycomings! Dan Hopper RV-7A In a message dated 7/12/2006 12:58:46 P.M. Eastern Daylight Time, tedd(at)vansairforce.org writes: --> RV-List message posted by: Tedd McHenry > Here is something I didn't know until recently. When the engine's bore is > increased from 4" to 5", the octane required increases by 10 units. Dan: This is a rule of thumb that is meant to compare similarly designed engines of different displacements, such as the O-320 and O-360. It would be a mistake to apply it to significantly different engine designs without taking into consideration other factors. For example, combustion chamber shape is equally significant, so that a smaller-bore combustion chamber can require higher octane than a larger-bore chamber, at the same CR, if its shape is more conducive to detonation. One can't simply conclude that one engine requires higher octane than another simply because its bore is larger. Tedd McHenry Surrey, BC ________________________________________________________________________________
Date: Jul 12, 2006
Subject: Re: MAC servo supplier
Jan, Ray Allan purchased the company. MAC is now RAC. Go to: http://www.rayallencompany.com/index.html Charlie Kuss >Hi, > >Can anyone help with the contact details for >Menzimer Aircraft Components Inc=85 I have a old >address for Vista CA=85.but no reply from the >phone number I got=85 Have they gone out of >business or has the business been sold..changed owner=85 ?? > >Regards > >Jan ________________________________________________________________________________
Date: Jul 12, 2006
Try this: http://www.rayallencompany.com/ Jan wrote: > Hi, > > > > Can anyone help with the contact details for Menzimer Aircraft > Components Inc... I have a old address for Vista CA....but no reply > from the phone number I got... Have they gone out of business or has > the business been sold..changed owner... ?? > > > > Regards > > > > Jan > ________________________________________________________________________________
Date: Jul 12, 2006
One thing to think about. Many RV's don't have enough temperature rise with carb heat to do much good. That little tube with the bite out of it that Van's sells is about useless. Deploying carb heat in a timely manner in snow might not do enough and you might still wind up with filter blockage. Even if you have to manually reset it after use, alternate air might save the day sometime. Pax, Ed Holyoke -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of LarryRobertHelming Sent: Wednesday, July 12, 2006 2:18 PM I don't think there is any problem with the FAB without an alternate air solution IF the carb heat is utilized before the air filter freezes over solid. So if the pilot recognizes the possibility of snow or freezing rain situation and pulls carb heat before air flow is totally cut off, there should not be a reason to activate the new manual alternate air solution as the heated air from carb heat will melt the ice on the filter. Based on this understanding, I removed the pop up door to save my engine from possible harm and glassed over it and did not install the sliding door solution. Aside from not activating carb heat in time, the one situation that the manual alternate air system will help on is if a plastic bag, or bird, or something is ingested in the air input that cuts off air to the carb. I don't know but the vacuum pressure could be strong enough to burst a bag and it might not be a problem without the alternate air. I liked the pop up door before I learned of its weakness. I am surprised Vans did not just strengthen the door so it could not accidentally deploy. Someone suggested adding stronger magnets. I think that is a better solution. Indiana Larry ----- Original Message ----- > > > I installed Van's first version of the alternate air intake, the one with > the magnet holding the door closed. It didn't look like it was going to > work > well so when the reports started coming in about them not closing or > staying > open, I junked that Filtered Air Box and ordered another one. Then Van's > came out with version 2.0 of the alternate air intake, a round opening in > the bottom of the F.A.B. with a door that pivots on one screw. I installed > that in my new F.A.B. I don't like this one either. My best efforts still > mean it's a one-shot deal. If I open it I will have to remove the lower > cowl > to get it completely closed again. Considering that it is an emergency air > source and would only be opened when I thought the front opening was > obstructed, that isn't completely unreasonable. > > But I hate the idea of needing to remove the lower cowl anytime anyone > pulls > on the control, intentionally or otherwise. > > Maybe I am missing something important here. Any thoughts? > > Terry > RV-8A finishing > Seattle ________________________________________________________________________________
Date: Jul 12, 2006
Terry, I agree -- its a one shot deal. I couldn't get mine to seal all that well either, so I put a very small bead of RTV around it. Its there only for a rare emergency. One correction though. You can easily close it with only the upper cowl off. Dan Hopped RV-7A 200 HP IO-360 In a message dated 7/12/2006 12:21:02 P.M. Eastern Daylight Time, terry(at)tcwatson.com writes: But I hate the idea of needing to remove the lower cowl anytime anyone pulls on the control, intentionally or otherwise. Maybe I am missing something important here. Any thoughts? Terry RV-8A finishing Seattle ________________________________________________________________________________
Date: Jul 12, 2006
On my RV-6A (following involuntary glider training precipitated by snow in the FAB) I built a somewhat complicated filter bypass that takes the carb heat air (not hot enough to melt snow) and dumps it in the FAB AFTER the air filter. See <http://home.earthlink.net/~timrv6a/RV6_FAB.jpg> I like Van's alternate air solutions better than what I built for my -6A, but Van's wasn't available at the time. For my RV-10 (IO-540) I'm using a hinged alternate air door on the bottom of the FAB that opens and closes using the push/pull cable, rather than the "one way" sliding door arrangement. Photo is at <http://home.earthlink.net/~timrv6a/Alt_air.jpg>. I've not flown the -10 yet. Tim Lewis N47TD Ed Holyoke wrote: > > One thing to think about. Many RV's don't have enough temperature rise > with carb heat to do much good. That little tube with the bite out of it > that Van's sells is about useless. Deploying carb heat in a timely > manner in snow might not do enough and you might still wind up with > filter blockage. Even if you have to manually reset it after use, > alternate air might save the day sometime. > > Pax, > > Ed Holyoke ________________________________________________________________________________
Date: Jul 12, 2006
Subject: Re: MOGAS related Crashes, ouch
I have a '40 Ford coupe with a flathead V8 and 3 wodden clothespins on the fuel line to the carb. IT WORKS. ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Re: Jacking up an RV
I have a local RV friend that has developed a simple but effective jack for RV 6s and 7s. that works inboard of the gear, thus is out of your way! If there is an interest I'll get a picture . . . I don't know if he's selling or simply sharing the plans but it looks like a better solution to me? (But I'm a RV-8 guy) Send me an email directly and I'll put you in touch. Good luck! Bob in SE Iowa On 7/10/06, Emrath wrote: > > There has been a lot of information shared over the years on tires and > changing of tires. I'm about to finish installing my gear and would like to > know if the Avery RV Jack Stand is the way to go or not. I would like to > hear from some who can extol the benefits of this method of changing tires > or from anyone that was not satisfied with this type of jacking up the RV > and what they did instead. > > Marty in Brentwood > RV-6A > > ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Re: re:Clothes pins
In a message dated 7/13/06 8:30:17 AM Eastern Daylight Time, mark(at)macomb.com writes: > At > one point we were told about this great new idea of vaporizing the fuel > before it reached the cylinders. Gee, I believe that a couple of bicycle > mechanics from Ohio used this method on an engine back in 1903. ====================== Mark: I did not see the "This is humor" note, I guess I missed it. The Internet is a super tool, unfortunately it also spreads BS faster than The Man of Steel can fly. Have you ever heard the story of skunk essence being used to prolong the smell of perfume? And that is also the reason why perfume cost more than cologne (hard to find people to mile a skunk). I started that story way back when I was about 11 years old. As for the idea about atomizing the fuel before it reaches the cylinders, I did not know my breven thought of that ... I thought I did way back in 1966. I made a plate that fit between the Carb and the intake manifold. It had an impeller mounted on it. It spun from the suction of the cylinders and being that it was below the carburetor the idea was droplets of fuel would hit the impeller and be broken up still further. I never patented the idea, but a few years later I saw my idea being sold in J.C. Whitney. Barry "Chop'd Liver" ________________________________________________________________________________
Date: Jul 13, 2006
Subject: re:Clothes pins
I had a serious response to the original clothespin post, with my scientific testing nose in the air, when I finally saw the "humor" comment. Almost made quite a fool of myself, which wouldn't have been hard. After that I just had get out of the house and to go to the hanger to build some more, clapping my hands as I left and kissing my clove of garlic I hang round my neck (just that morning got a fresh batch). Those damned elephants haven't been around since I started clapping, and I'm not the only one who's making sure they stay away. Lot of the neighbors clap as well. Clearly it's working. Not sure about the vampires. Hard to tell. John Jessen -10 Tailcone -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of FLYaDIVE(at)aol.com Sent: Thursday, July 13, 2006 8:17 AM In a message dated 7/13/06 8:30:17 AM Eastern Daylight Time, mark(at)macomb.com writes: > At > one point we were told about this great new idea of vaporizing the > fuel before it reached the cylinders. Gee, I believe that a couple of > bicycle mechanics from Ohio used this method on an engine back in 1903. ====================== Mark: I did not see the "This is humor" note, I guess I missed it. The Internet is a super tool, unfortunately it also spreads BS faster than The Man of Steel can fly. Have you ever heard the story of skunk essence being used to prolong the smell of perfume? And that is also the reason why perfume cost more than cologne (hard to find people to mile a skunk). I started that story way back when I was about 11 years old. As for the idea about atomizing the fuel before it reaches the cylinders, I did not know my breven thought of that ... I thought I did way back in 1966. I made a plate that fit between the Carb and the intake manifold. It had an impeller mounted on it. It spun from the suction of the cylinders and being that it was below the carburetor the idea was droplets of fuel would hit the impeller and be broken up still further. I never patented the idea, but a few years later I saw my idea being sold in J.C. Whitney. Barry "Chop'd Liver" ________________________________________________________________________________
Date: Jul 13, 2006
"This is a rule of thumb that is meant to compare similarly designed engi nes of different displacements," Ted, you hit the nail more on the head with the term "displacements". Da n actually said bore size and I am thinking either he meant different or th e book was a little skewed based on it's age. Of course bore size, chamber shape, stroke, piston composition, piston shape, and squish all play an active role in this. I don't know much about the lycomings, but even wit h a relatively high compression ratio, you can achieve pretty good dynamics b y optimizing the squish and picking the right piston for the application. Lycomings may not apply since the availability of products is more limite d than typical auto engines. Tim ex Auto Machine Shop Owner but did not stay in a Holiday Inn Express last night RV-6 -------Original Message------- > Here is something I didn't know until recently. When the engine's bor e is > increased from 4" to 5", the octane required increases by 10 units. Dan: This is a rule of thumb that is meant to compare similarly designed engin es of different displacements, such as the O-320 and O-360. It would be a mist ake to apply it to significantly different engine designs without taking into consideration other factors. For example, combustion chamber shape is equally significant, so that a smaller-bore combustion chamber can require higher octane than a larger-bore chamber, at the same CR, if its shape is more conducive to detonation. One can't simply conclude that one engine requi res higher octane than another simply because its bore is larger. Tedd McHenry Surrey, BC ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
From: "Stucklen, Frederic W UTPWR" <Fred.Stucklen(at)UTCPower.com>
Date: Jul 13, 2006
I've done something a little different on my RV-6A. I've tested Van's original magnet scheme and found that my O-320-D1A engine doesn't open it under normal take off conditions. A plugged filter does open it OK. (Don't ask how I know.) The actual implementation of the trap door does not open into the lower cowl, but rather, into the FAB box it self. There's enough space between the bottom of the filter assembly and the FAB box shell to allow for the intake air flow. This way, the carb heat is always available to either filtered or unfiltered air. I periodically check the position/operation of the trap door by inserting a stiff wire through a small hole in the FAB box. And, yes, I epoxied the magnet into position so it can't get detached..... Fred Stucklen RV-6A N926RV 720 Hrs 3'd offender Building an RV-7A Tim_Lewis(at)msm.umr.edu> On my RV-6A (following involuntary glider training precipitated by snow in the FAB) I built a somewhat complicated filter bypass that takes the carb heat air (not hot enough to melt snow) and dumps it in the FAB AFTER the air filter. See < " target=otherpages> <http://home.earthlink.net/~timrv6a/RV6_FAB.jpg> http://home.earthlink.net/~timrv6a/RV6_FAB.jpg> I like Van's alternate air solutions better than what I built for my -6A, but Van's wasn't available at the time. For my RV-10 (IO-540) I'm using a hinged alternate air door on the bottom of the FAB that opens and closes using the push/pull cable, rather than the "one way" sliding door arrangement. Photo is at < ." target=otherpages> <http://home.earthlink.net/~timrv6a/Alt_air.jpg> http://home.earthlink.net/~timrv6a/Alt_air.jpg>. I've not flown the -10 yet. Tim Lewis N47TD ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Haze
The FAA aviation weather book describes haze as a yellowish or bluish tinged uniformly distributed contaminant formed from salt or dust particles. A temperature inversion keeps them from being diluted. Flying in haze yesterday, I started wondering why it seemed to thicken as I ascended. And why do ground stations report 6 miles when you can't see 6 miles from one mile agl? The book also says visibility is reduced toward the sun but I thought having the sun behind you would lessen visibility because of reflection from the particles back toward your eye. Any thoughts/info? Dave Reel - RV8A ________________________________________________________________________________
July 02, 2006 - July 13, 2006
RV-Archive.digest.vol-sb
