RV-Archive.digest.vol-sc
July 13, 2006 - July 29, 2006
Date: Jul 13, 2006
Subject: Haze
Only thing I know is that I had a white out due to the sun and inversion and I was not IFR rated. Thank the good CFI who made me work under the hood all that time. John Jessen -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DAVID REEL Sent: Thursday, July 13, 2006 12:21 PM The FAA aviation weather book describes haze as a yellowish or bluish tinged uniformly distributed contaminant formed from salt or dust particles. A temperature inversion keeps them from being diluted. Flying in haze yesterday, I started wondering why it seemed to thicken as I ascended. And why do ground stations report 6 miles when you can't see 6 miles from one mile agl? The book also says visibility is reduced toward the sun but I thought having the sun behind you would lessen visibility because of reflection from the particles back toward your eye. Any thoughts/info? Dave Reel - RV8A ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Haze
Here in SoCal haze tends to be a little on the brown side of white. The visibility that ground stations are supplying is just that - ground visibility. It may be different in the air. Maybe it's seeming thicker to you because you're looking down through more of it as you climb. When you were looking up through it, there was nothing much on which to focus on the other side of it. It is definitely worse flying into the sun when it is low in the sky. There's been times near sunset when the visibility was OK to the sides and rear but just about nil ahead. A good time to turn on your landing lights and look for another way to go. Pax, Ed Holyoke -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DAVID REEL Sent: Thursday, July 13, 2006 12:21 PM The FAA aviation weather book describes haze as a yellowish or bluish tinged uniformly distributed contaminant formed from salt or dust particles. A temperature inversion keeps them from being diluted. Flying in haze yesterday, I started wondering why it seemed to thicken as I ascended. And why do ground stations report 6 miles when you can't see 6 miles from one mile agl? The book also says visibility is reduced toward the sun but I thought having the sun behind you would lessen visibility because of reflection from the particles back toward your eye. Any thoughts/info? Dave Reel - RV8A ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Oil cooler
Where is the best place for the oil cooler on a RV 9A, baffle or firewall and why. Dave 9a Finishing ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Oil cooler
The RV-9A baffle and firewall is very similar to the RV-6. On my RV-6, I had redline oil temps during and after flight testing with the oil cooler mounted on the firewall. I ran about 15 degrees hotter than the other RVs in cruise with it on the firewall. I move the oil cooler to the engine mount right behind the #4 cylinder with a 3" X 5" opening with baffle seal between it and the rear baffle. I now run the same oil temp to 15 degrees cooler than the other RV. I had 3 bad experiences with high oil temp and vapor lock with the oil cooler on the firewall. I do not recommend mounting it there. I had 3" SCAT tubing going to it from #3 cylinder. Others have had it work but I could not get it to work on my airplane. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,892 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- Where is the best place for the oil cooler on a RV 9A, baffle or firewall and why. Dave 9a Finishing ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Oil cooler
I mounted mine on the baffle behind #4. No aircraft temp problems. Forecast is for something like 116 in the next day or so. Short hops are usually at 1-3000 AGL with cruising temps at 80-90+ with no overheating problems. I have a 7 row cooler. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Re: Oil cooler
Did mine on the baffle. Did it exactly the way Van's baffle kit said to do it except I put an extra piece of sheet aluminum as a doubler to stiffen it up to keep it from flexing and cracking. Cut the air access hole just as indicated in the plans. Some guys thought I should enlarge the hole because about 1/3 of the oil cooler fins are covered by the plans mounting. Turns out Vans is right. Build it by the plans and you'll be happy. I've had no hight temps at all. In fact, the temps have never been higher than 200 (in climb) and 180 (cruise). Chuck Weyant RV9A 185 hours O320E3D 150HP I mounted mine on the baffle behind #4. No aircraft temp problems. Forecast is for something like 116 in the next day or so. Short hops are usually at 1-3000 AGL with cruising temps at 80-90+ with no overheating problems. I have a 7 row cooler. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Jul 13, 2006
In a message dated 7/13/06 5:17:03 PM Eastern Daylight Time, davwol(at)svtv.com writes: > Where is the best place for the oil cooler on a RV 9A, baffle or firewall and > why. > > Dave > 9a > Finishing =========================== Dave: I fly both an RV-6 and a RV-6A. The RV-6 has the cooler mounted right at the intake scoop. Things I have noticed with this mounting are: ~ VERY COOL oil, in the winter I have to cover over half of the cooler to get the temps up to normal (170- 190 Deg F) ~ In the summer even on hot 85 - and 95 Deg F days the oil temp runs 190- 200 Deg F MAX. ~ In the summer sitting on the taxi way in a line of planes and facing away from the wind the oil still runs cool. ~ The one negative thing I must report about the intake mounting of the cooler is the long hose runs and making sure they are secure. I check them about twice a year just to make sure nothing has moved. NOTHING HAS EVER MOVED. - - - - - - - - - - - - - - - The RV-6A has the cooler mounted on the back of the baffling. Things I have noticed about this mounting are: ~ In the winter I have to cover over half of the cooler to get the temps up to normal (170- 190 Deg F) - Same as the RV-6. ~ In the summer even on hot 85 - and 95 Deg F days the oil temp runs a bit hot usually hovering around 195 - 210 Deg F MAX. Now this is on climb-out. It drops to about 195 - 200 Deg F in cruse ... REMEMBER we are still talking HIGH OAT (5000 Ft or less). ~ In the summer sitting on the taxi way in a line of planes and facing away from the wind the oil DOES get warmer than I like and if the plane has a horn I would be beeping it ... Instead I have the luxury of politely remarking on how are YOUR oil and CHTs temps doing ... Sure would like to cool the engine down by flying ;-) ~ The one other negative thing I must report about the baffle mounting of the cooler is the extra heat stuffed in the rear of the engine ... Right where the Mag & electronic ignition are and right where the vacuum pump is. I put a probe there and on the RV-6 I see 135 Deg F. On the RV-6A I see 170 Deg F. Barry "Chop'd Liver" ________________________________________________________________________________
Date: Jul 13, 2006
Subject: Re: non-swiveling tail wheel
I think anyone upgrading to a Van's swivel tailwheel, or indeed anyone who hasn't flown one, should be aware of it's foibles: 1) It requires regular greasing, and the only way to grease it properly is to dissassemble it. This isn't hard but I have to do mine every 10 hours or so. 2) The little internal key that locks/unlocks the tailwheel eventually develops burrs and then sticks, allowing the tailwheel to stay unlocked. The solution is to file down the burrs and then slightly chamfer the edges of the key to prevent new burrs. You may as well do this right away instead of waiting for it to stick unexpectedly at some distant airport. Since I fixed mine the first time, it has been fine. 3) The design feature that allows the tailwheel to free swivel after depressing the rudder pedal about 3/4 down works really well most of the time. It has a spooky side though. On a couple of occasions I have been taxiig on a slippery surface with a stiff crosswind, and order to counteract a gust, I kicked full or nearly full rudder. This caused the tailwheel to unlock, and without the tailwheel helping to hold it straight anymore, the airplane immediately weathervaned into the wind and I was suddenly 90 degrees to the runway going 10 mph. Because the runway was snowy and slippery the brakes were not effective either, so off the runway I went, completely out of control. Luckily both times I only got stuck. Perhaps the Bell tailwheel alleviates some or all of these problems. I'm planning to get one myself, if only for the new/coolness factor. Curt RV-6 C-GACR ________________________________________________________________________________
Date: Jul 13, 2006
Yikes Curt, This doesn't paint a very pretty picture. Every 10 hours? That could be after every trip. My new one is supposed to be delivered tomorrow for a weekend install. Question for all the other tail wheelers. Are any of you using something other than Van's swivel tailwheel? Why? Are you happy with it? Thanks Tim -------Original Message------- I think anyone upgrading to a Van's swivel tailwheel, or indeed anyone wh o hasn't flown one, should be aware of it's foibles: 1) It requires regular greasing, and the only way to grease it properly i s to dissassemble it. This isn't hard but I have to do mine every 10 hours or so. 2) The little internal key that locks/unlocks the tailwheel eventually develops burrs and then sticks, allowing the tailwheel to stay unlocked. The solution is to file down the burrs and then slightly chamfer the edges of the key to prevent new burrs. You may as well do this right away instead of waiting for it to stick unexpectedly at some distant airport. Since I fix ed mine the first time, it has been fine. 3) The design feature that allows the tailwheel to free swivel after depressing the rudder pedal about 3/4 down works really well most of the time. It has a spooky side though. On a couple of occasions I have been taxiig on a slippery surface with a stiff crosswind, and order to counter act a gust, I kicked full or nearly full rudder. This caused the tailwheel to unlock, and without the tailwheel helping to hold it straight anymore, th e airplane immediately weathervaned into the wind and I was suddenly 90 degrees to the runway going 10 mph. Because the runway was snowy and slippery the brakes were not effective either, so off the runway I went, completely out of control. Luckily both times I only got stuck. Perhaps the Bell tailwheel alleviates some or all of these problems. I'm planning to get one myself, if only for the new/coolness factor. Curt RV-6 C-GACR ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
Date: Jul 13, 2006
Gee, folks.. I have 300 hours on my Van=B9s tailwheel and have had no significant problem. I grease it about every 6 months or so and have replaced the bearings once and the actual tire once. Other than that, it works perfect. Doug Weiler N722DW, RV-4, 300 hours On 7/13/06 8:04 PM, "Tim Bryan" wrote: > Yikes Curt, > > This doesn't paint a very pretty picture. Every 10 hours? That could be > after every trip. My new one is supposed to be delivered tomorrow for a > weekend install. > > Question for all the other tail wheelers. Are any of you using something > other than Van's swivel tailwheel? Why? Are you happy with it? > > Thanks > Tim > > -------Original Message------- > > From: Curt Reimer <mailto:cgreimer(at)mts.net> > Date: 07/13/06 17:09:00 > To: rv-list(at)matronics.com > Subject: Re: RV-List: non-swiveling tail wheel > > > I think anyone upgrading to a Van's swivel tailwheel, or indeed anyone wh o > hasn't flown one, should be aware of it's foibles: > > 1) It requires regular greasing, and the only way to grease it properly i s > to dissassemble it. This isn't hard but I have to do mine every 10 hours or > so. > > 2) The little internal key that locks/unlocks the tailwheel eventually > develops burrs and then sticks, allowing the tailwheel to stay unlocked. The > solution is to file down the burrs and then slightly chamfer the edges of > the key to prevent new burrs. You may as well do this right away instead of > waiting for it to stick unexpectedly at some distant airport. Since I fix ed > mine the first time, it has been fine. > > 3) The design feature that allows the tailwheel to free swivel after > depressing the rudder pedal about 3/4 down works really well most of the > time. It has a spooky side though. On a couple of occasions I have been > taxiig on a slippery surface with a stiff crosswind, and order to counter act > a gust, I kicked full or nearly full rudder. This caused the tailwheel to > unlock, and without the tailwheel helping to hold it straight anymore, th e > airplane immediately weathervaned into the wind and I was suddenly 90 > degrees to the runway going 10 mph. Because the runway was snowy and > slippery the brakes were not effective either, so off the runway I went, > completely out of control. Luckily both times I only got stuck. > > Perhaps the Bell tailwheel alleviates some or all of these problems. I'm > planning to get one myself, if only for the new/coolness factor. > > Curt > RV-6 C-GACR > > > > > ===================================== > he RV-List Email Forum - > http://www.matronics.com/Navigator?RV-List > ===================================== > sp; - NEW MATRONICS LIST WIKI - > nics.com > ===================================== > sp; - List Contribution Web Site - > sp; -Matt Dralle, List Admin. > //www.matronics.com/contribution > ===================================== > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 13, 2006
On Jul 13, 2006, at 7:04 PM, Tim Bryan wrote: > Yikes Curt, > > This doesn't paint a very pretty picture. Every 10 hours? That > could be after every trip. My new one is supposed to be delivered > tomorrow for a weekend install. > > Question for all the other tail wheelers. Are any of you using > something other than Van's swivel tailwheel? Why? Are you happy > with it? > > Thanks > Tim I have the standard Van's full swivel tailwheel. Once or maybe twice, in 800 hours, it has failed to lock into the steering detent. I think it was a bit of grit fouling it up, in my case. Every 75 or 100 hours the steering gets a bit stiff and I have to regrease it. I admire the simplicity and economy of the device compared to what Scotts puts out. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Date: Jul 14, 2006
Subject: The TRUTH about MOGAS
HI Tim- This is getting interesting and closer to answering my curiosity. What is the "squish" you referred to? glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jul 14, 2006
I has a couple issues with the tail wheel not locking in the first 50 hours on my plane. When I called and talked to Van's about it they said don't use grease use oil. So I took it apart, cleaned and polished the burrs and drilled a small hole in the top washer. I now shoot a little LPS 2 into the hole every 10 hours or so and disassemble it at annual to clean and inspect for burrs. For the last 300 hours it has been trouble free. Alan Kritzman RV-8 N8EM Larry Pardue wrote: On Jul 13, 2006, at 7:04 PM, Tim Bryan wrote: > Yikes Curt, > > This doesn't paint a very pretty picture. Every 10 hours? That > could be after every trip. My new one is supposed to be delivered > tomorrow for a weekend install. > > Question for all the other tail wheelers. Are any of you using > something other than Van's swivel tailwheel? Why? Are you happy > with it? > > Thanks > Tim I have the standard Van's full swivel tailwheel. Once or maybe twice, in 800 hours, it has failed to lock into the steering detent. I think it was a bit of grit fouling it up, in my case. Every 75 or 100 hours the steering gets a bit stiff and I have to regrease it. I admire the simplicity and economy of the device compared to what Scotts puts out. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net --------------------------------- Yahoo! Music Unlimited - Access over 1 million songs.Try it free. ________________________________________________________________________________
Date: Jul 14, 2006
I agree Curt. I grease mine with every oil change. I have the Bell tailwheel and love it, but in regards to swivel, it works the same way as the Van's. Don't know if you are using the one arm device or not, but I believe the one I was using was exacerbating the problem and have removed it for the new stainless Van's two arm device. I feel the one arm seems to bur the pin more than the two arm type. No suppresses in the last 50 hours. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Jul 14, 2006
Alan, This sounds like a reasonable solution. Grease can tend to collect dust and become sticky. Oil would do the same thing but doesn't last as long. Gr eat idea. Tim -------Original Message------- I has a couple issues with the tail wheel not locking in the first 50 hou rs on my plane. When I called and talked to Van's about it they said don't use grease use oil. So I took it apart, cleaned and polished the burrs and drilled a small hole in the top washer. I now shoot a little LPS 2 into the hole every 10 hours or so and disassemble it at annual to clean and inspe ct for burrs. For the last 300 hours it has been trouble free. Alan Kritzman RV-8 N8EM Larry Pardue wrote: On Jul 13, 2006, at 7:04 PM, Tim Bryan wrote: > Yikes Curt, > > This doesn't paint a very pretty picture. Every 10 hours? That > could be after every trip. My Yahoo! Music Unlimited - Access over 1 million songs. Try it free. ________________________________________________________________________________
From: "czechsix(at)juno.com" <czechsix(at)juno.com>
Date: Jul 14, 2006
Subject: Major new product announcement from Vans
Guys, I just got the most recent copy of the RVator and it says that Vans will be announcing a major new product at Oshkosh, one which they have expen ded considerable effort on over the past year and it is NOT the RV-12. Any guesses or rumors as to what it might be? I doubt it's the RV-11, and it's hard to imagine that it would be a tota lly new design. Possibilities thrown out around the water cooler so far : Tail dragger RV-10 (unlikely) Matched-hole RV-8 fuselage (would be more of a product improvement than "new" product) Super RV-8 to complete with Rockets (would depart from Vans traditional conservatism) New wing design for existing RV-7/8 series, either a new airfoil or tape red planform or both The new wing is our best guess, or maybe we're getting all antsy over no thing and it will just be a new FAB airbox alternate air design... : | Anybody else wanna toss out a speculative guess? Maybe Jerry Springer h as the inside scoop and will spill the beans (don't worry, I'm sure Van doesn't read the RV List and we'll never tell who we heard it from!) --Mark Navratil Cedar Rapids, Iowa RV-8A N2D with 65 hours of thrills so far...
Guys,
I just got the most recent copy of the RVator and it says that Vans w ill be announcing a major new product at Oshkosh, one which they have ex pended considerable effort on over the past year and it is NOT the RV-12 .  Any guesses or rumors as to what it might be?
I doubt it's the RV-11, and it's hard to imagine that it would be a t otally new design.  Possibilities thrown out around the water coole r so far:
Super RV-8 to comp lete with Rockets (would depart from Vans traditional conservatism)
N ew wing design for existing RV-7/8 series, either a new airfoil or taper ed planform or both
The new wing is our best guess, or maybe we're getting all antsy over nothing and it will just be a new FAB airbox alternate air design...&nb sp;  : |
Anybody else wanna toss out a speculative guess?  Maybe Jerry Sp ringer has the inside scoop and will spill the beans (don't worry, I'm s ure Van doesn't read the RV List and we'll never tell who we heard it fr om!)
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D with 65 hours of t hrills so far...
Date: Jul 14, 2006
Subject: Re: Major new product announcement from Vans
Must be a VLJ ... sign me up !! g > Guys, > I just got the most recent copy of the RVator and it says that > Vans will be announcing a major new product at Oshkosh, one > which they have expended considerable effort on over the past > year and it is NOT the RV-12. Any guesses or rumors as to what > it might be? > I doubt it's the RV-11, and it's hard to imagine that it would > be a totally new design. Possibilities thrown out around the > water cooler so far: > Tail dragger RV-10 (unlikely) > Matched-hole RV-8 fuselage (would be more of a product > improvement than "new" product) > Super RV-8 to complete with Rockets (would depart from Vans > traditional conservatism) > New wing design for existing RV-7/8 series, either a new > airfoil or tapered planform or both > The new wing is our best guess, or maybe we're getting all > antsy over nothing and it will just be a new FAB airbox > alternate air design... : | > Anybody else wanna toss out a speculative guess? Maybe Jerry > Springer has the inside scoop and will spill the beans (don't > worry, I'm sure Van doesn't read the RV List and we'll never > tell who we heard it from!) > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D with 65 hours of thrills so far... > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ---------------------------------------------------------- ________________________________________________________________________________
Date: Jul 14, 2006
A wider cockpit for the 6/7 design for us fat boys. Ron Lee Do nor archive ________________________________________________________________________________
Date: Jul 14, 2006
Mark, I was going to say Van's big announcement is that they are switching to all composite construction and then run hide under my desk for a month or two. But here's my serious guess (no inside information - just a guess.) Van's is going to open a builder help facility to compete with what Glassair and maybe a few other kit manufacturer's are doing, so guys like me can finish their project in 5 years instead of 10 and normal people can finish in a few months rather than a few years. Guess #2: They are going to certify and manufacture something, probably the RV-12 light sport aircraft. Terry RV-8A #80729 p.s. Mark, I still want to copy you paint job. _____ [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of czechsix(at)juno.com Sent: Friday, July 14, 2006 10:35 AM Guys, I just got the most recent copy of the RVator and it says that Vans will be announcing a major new product at Oshkosh, one which they have expended considerable effort on over the past year and it is NOT the RV-12. Any guesses or rumors as to what it might be? I doubt it's the RV-11, and it's hard to imagine that it would be a totally new design. Possibilities thrown out around the water cooler so far: Tail dragger RV-10 (unlikely) Matched-hole RV-8 fuselage (would be more of a product improvement than "new" product) Super RV-8 to complete with Rockets (would depart from Vans traditional conservatism) New wing design for existing RV-7/8 series, either a new airfoil or tapered planform or both The new wing is our best guess, or maybe we're getting all antsy over nothing and it will just be a new FAB airbox alternate air design... : | Anybody else wanna toss out a speculative guess? Maybe Jerry Springer has the inside scoop and will spill the beans (don't worry, I'm sure Van doesn't read the RV List and we'll never tell who we heard it from!) --Mark Navratil Cedar Rapids, Iowa RV-8A N2D with 65 hours of thrills so far... ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Re: IFR Panel Considerations
I will violate your reply rules by posting it here. I see little use in ADF. A panel mounted GPS with approaches is probably a must. WAAS functionality should be considered. Units that fit this are the Garmin GNS 430/530 or equivalent from other makers (if that exists). Then it is a matter of whether a Dynon like system is LEGAL from a artificial horizon point of view. The rest seems simple. Of course you can add redundant avionics but then you get pricey. Ron Lee ________________________________________________________________________________
From: =?iso-8859-1?Q?Mich=E8le_MS?= <michele.delsol(at)microsigma.fr>
Date: Jul 14, 2006
I suggested it could be a parachute attachment to the fuelage. Michele RV8 - Fuselage _____ [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of czechsix(at)juno.com Sent: vendredi 14 juillet 2006 19:35 Guys, I just got the most recent copy of the RVator and it says that Vans will be announcing a major new product at Oshkosh, one which they have expended considerable effort on over the past year and it is NOT the RV-12. Any guesses or rumors as to what it might be? I doubt it's the RV-11, and it's hard to imagine that it would be a totally new design. Possibilities thrown out around the water cooler so far: Tail dragger RV-10 (unlikely) Matched-hole RV-8 fuselage (would be more of a product improvement than "new" product) Super RV-8 to complete with Rockets (would depart from Vans traditional conservatism) New wing design for existing RV-7/8 series, either a new airfoil or tapered planform or both The new wing is our best guess, or maybe we're getting all antsy over nothing and it will just be a new FAB airbox alternate air design... : | Anybody else wanna toss out a speculative guess? Maybe Jerry Springer has the inside scoop and will spill the beans (don't worry, I'm sure Van doesn't read the RV List and we'll never tell who we heard it from!) --Mark Navratil Cedar Rapids, Iowa RV-8A N2D with 65 hours of thrills so far... ________________________________________________________________________________
Date: Jul 14, 2006
another personal opinion.........While I would agree that the nose gear on the A models may be a weak link, I do not think making it steerable would be an improvement. I would not want to give up the ability to do a tight 180 degree turn while parking which is possible with the current design. Dale Ensing > > My guess/hope is that it is a steerable nose gear for the RV-7 like the > one they are putting on the RV-12. How better to develop the new gear > than to put it on an RV-7 first. I think we all can agree that the -7A > nose gear is probably the weakest link in the Van's chain. > > Steve Eberhart do not archieve ________________________________________________________________________________
Date: Jul 14, 2006
My guess - a certifed plane..... The kits/designs are nicer than most aluminum certified planes out there..... Although Van said he'd never do it.... > Guys, > I just got the most recent copy of the RVator and it says that Vans will > be announcing a major new product at Oshkosh, one which they have expended > considerable effort on over the past year and it is NOT the RV-12. Any > guesses or rumors as to what it might be? > I doubt it's the RV-11, and it's hard to imagine that it would be a > totally new design. Possibilities thrown out around the water cooler so > far: > Tail dragger RV-10 (unlikely) > Matched-hole RV-8 fuselage (would be more of a product improvement than > "new" product) > Super RV-8 to complete with Rockets (would depart from Vans traditional > conservatism) > New wing design for existing RV-7/8 series, either a new airfoil or > tapered planform or both > The new wing is our best guess, or maybe we're getting all antsy over > nothing and it will just be a new FAB airbox alternate air design... : | > Anybody else wanna toss out a speculative guess? Maybe Jerry Springer has > the inside scoop and will spill the beans (don't worry, I'm sure Van > doesn't read the RV List and we'll never tell who we heard it from!) > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D with 65 hours of thrills so far... > ________________________________________________________________________________
Date: Jul 14, 2006
> My guess/hope is that it is a steerable nose gear for the > RV-7 like the one they are putting on the RV-12. How > better to develop the new gear than to put it on an RV-7 > first. I think we all can agree that the -7A nose gear is > probably the weakest link in the Van's chain. > Steve, I'm hoping your speculation is incorrect, as well. I've found that the weakest link in Van's -7A is not the gear. It's the pilot. I've been flying aircraft with castoring nose gears since 1990 and have had good luck with them. Since I'm just an average pilot, I assure you it's no big deal. The proper training will fill in the gaps. By the way, I've seen as many Cessnas with bent nose gears as I've seen RV's. In each case, it wasn't the design of the nose gear. It was the pilot's pilotage that took it out. Well, one of the RV incidents was actually a forced landing with a dead engine. Loose nut on a fuel line. Anyway, I never replaced the nose gear on my RV-6A when Van offered to replace the weaker nose gears. I figured if his prototype's nose gear held up as well as it did, I'd hold off replacing mine. I didn't see any need to fix what wasn't broken. It's still just fine. So are my original rudder stirrups. And, I do land on grass strips. As long as you take care to land properly, it's a pretty good set up. It's good enough that I'd prefer that they don't mess with it; or, worst case, give us a choice. Like, maybe making the steerable version an option. To be honest, I'd be surprised if they change what already works. That won't help you, though. Hey, once you get to making those tight turns at the tie down, and such, you'll forget all about wanting that steerable nose gear. :-) Jim Sears in KY ________________________________________________________________________________
Date: Jul 14, 2006
Guess one and I would be willing to bet money on it would be a smaller LSA RV, possibly O-200 powered. Guess two would be the glider which I would love to see, but I don't know that they would consider that major. ---------- Original Message ---------------------------------- >Guys, >I just got the most recent copy of the RVator and it says that Vans will be announcing a major new product at Oshkosh, one which they have expended considerable effort on over the past year and it is NOT the RV-12. Any guesses or rumors as to what it might be? >I doubt it's the RV-11, and it's hard to imagine that it would be a totally new design. Possibilities thrown out around the water cooler so far: >Tail dragger RV-10 (unlikely) >Matched-hole RV-8 fuselage (would be more of a product improvement than "new" product) >Super RV-8 to complete with Rockets (would depart from Vans traditional conservatism) >New wing design for existing RV-7/8 series, either a new airfoil or tapered planform or both >The new wing is our best guess, or maybe we're getting all antsy over nothing and it will just be a new FAB airbox alternate air design... : | >Anybody else wanna toss out a speculative guess? Maybe Jerry Springer has the inside scoop and will spill the beans (don't worry, I'm sure Van doesn't read the RV List and we'll never tell who we heard it from!) >--Mark Navratil >Cedar Rapids, Iowa >RV-8A N2D with 65 hours of thrills so far... > > ________________________________________________________________ Sent via the WebMail system at mail.engalt.com ________________________________________________________________________________
Date: Jul 14, 2006
I'll second a vote for a tapered wing. The F1 EVO Rocket looks pretty damn sweet with that tapered wing to match the tapered tail surfaces. -Rob ________________________________________________________________________________
Date: Jul 14, 2006
Primer. Self-cleaning, self-etching, auto-ding-filling primer. Made by Vans. In a can. Makes pop rivets look like driven rivets. Wonderful stuff. ;<) > Guys, > > I just got the most recent copy of the RVator and it says that Vans will > be announcing a major new product at Oshkosh, one which they have > expended considerable effort on over the past year and it is NOT the > RV-12. Any guesses or rumors as to what it might be? ________________________________________________________________________________
Date: Jul 14, 2006
>I think they will start delivering the RVator in PDF format, saving >enough in postage to fund the development a VLJ. I like this guess the best! Maybe it's that they are planning to print enough calendars to actually be able to fill MY order. I haven't gotten one for years, not from lack of trying... I listened to Ken Scott talk at Arlington and he denied anything new in the works. He said the 12 would not make Osh, but might be flying by the Homecoming. The glider is Van's personal project and is far from complete. I intended to kid him about a VLJ but didn't. He said they were working hard on the 12 and that in addition to shipping parts was more then enough to keep them busy. I suppose they could "announce" the 12, but since the specs are not known yet and they haven't built a conforming ship yet it would be unlike Van to do more then mention it. I guess we'll see at Osh. ________________________________________________________________________________
Date: Jul 14, 2006
LSA is my bet. -- Walter Tondu http://www.rv7-a.com Flying! ________________________________________________________________________________
Date: Jul 14, 2006
Date: Jul 14, 2006
At 03:29 PM 7/14/2006, you wrote: > >Dynon or bluemountain (bluemountain gives you the GPS, >so I'd go that way, personally) $3-$4K I just reviewed the Blue Mountain FAQ and EFIS/ONE brochure and did not see where it offers approached certified GPS capability. If it does not then add one for that functionality. Ron Lee ________________________________________________________________________________
Date: Jul 14, 2006
>Dynon or bluemountain (bluemountain gives you the GPS, >so I'd go that way, personally) $3-$4K I just scrolled further down the FAQ and found that the Blue Mountain EFIS does NOT provide certified GPS approach capability. Thus you would have add that (unknown cost). Actually VOR and ILS will get you most places but depending upon Possible phase-down of those systems in favor of GPS/WAAS you may find your approach options limited sometime in the future. Q: Is EFIS/One certified for GPS approaches? On the advice of our most trusted avionics dealer and partner, we have decided not to pursue it. For what it will cost to do TSO C129A testing and certification, we'd have to raise the price of the EFIS by more than the cost of a high-volume certified unit. We think it's a better deal to have a reasonably priced glass cockpit, and the interconnect available for those who want to fly GPS approaches. If you have a certified GPS, you can plug it in to drive the flight director and autopilot in approach mode. Ron Lee ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Partnership Agreement
Does anyone have draft of a partnership agreement that might work for an RV? Jim Jim Cimino N7TL RV-8 S/N 80039 200+ Hours http://www.geocities.com/jcimino.geo/ ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Re: Partnership Agreement
Check with the EAA office. I used info from them about 15 years ago for a partnership agreement. Dale ----- Original Message ----- From: Jim Cimino To: RV-LIST Sent: Friday, July 14, 2006 7:52 PM Subject: RV-List: Partnership Agreement Does anyone have draft of a partnership agreement that might work for an RV? Jim Jim Cimino N7TL RV-8 S/N 80039 200+ Hours http://www.geocities.com/jcimino.geo/ ________________________________________________________________________________
Date: Jul 14, 2006
Subject: tailwheel
Sounds like your tail wheel isn't set correctly. It should not be able to disconnect from the rudder with any amount of pedal movement. One must go another 5 degrees by adding brake and flexing the springs for it to disengage when it is set up correctly. My first Van's tail wheel went for 1000 hours with one bearing replacement, the next one now has about 6 hours on it. I've also installed a spacer between the bearings so that the bolt can be properly tightened with some slight preload on the bearings and place a solid pinch on the bearing inner races. If I remember correctly the rudder should go 30 deg each way and the tailwheel unlocks at 35 deg, but it's been a long time since I rigged that. W ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Tail wheel
Aviation Products Inc. 114 Bryant St. Ojai, CA 93023 ph/fax 805-646-6042 I think they have a web site if you google the name. I have one of their full-swivel wheels and have never had to do anything to it except routine maintenance at conditional inspection. I have had it apart once and finally may have to replace the body of the thing; after 1000 hours it is getting a little loose, but only a little. It has never failed to do what it was designed to do. The tire shows little to no wear at all and the bearings are still quiet. They have two angles to choose from. I have the taller one (?45 degrees?). Wouldn't have anything else on the tail of Suzie Q. Tear it apart every 10 hours??? Yikes. Sounds like something from Wichita. Michael N232 Suzie Q OSH-bound in about a week or so!!! ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Re: Jacking up an RV
John, How do you remove a wheel when it's jacked up like that? Bob On 7/11/06, John Danielson wrote: > > I bought a 2 ft piece of 5/8" (I think that's right) steel rod. This > slips inside the axle. I then use my floor jack used for the car, it > will fit under the steel rod, and jack the plane up. Works a lot like > Avery's jack stand, but you really don't need any more than the steel > rod. > > John L. Danielson > RV-6 sold > > -----Original Message----- > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Emrath > Sent: Monday, July 10, 2006 8:04 PM > > > There has been a lot of information shared over the years on tires and > changing of tires. I'm about to finish installing my gear and would like > to > know if the Avery RV Jack Stand is the way to go or not. I would like > to > hear from some who can extol the benefits of this method of changing > tires > or from anyone that was not satisfied with this type of jacking up the > RV > and what they did instead. > > Marty in Brentwood > RV-6A > > ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Date: Jul 14, 2006
Subject: Slide canopy compass mounting
Quick question on compass mounting: I have an RV-6 with sliding canopy. Have a bracket to mount the compass on the roll bar support. Question is: where is the best place on the support to mount the compass? Toward the top near the roll bar? Halfway down the support or down at the bottom just above the top skin? Thanks. Dean Psiropoulos RV-6A N197DM Plodding toward the blissful end. ________________________________________________________________________________
Date: Jul 14, 2006
Hi Dean, I have mine mounted quite low on the bar and am glad I did. It sits about 1.5" above the glareshield and doesn't get in the way of anything else. You'll find yourself using that bar for ingress/egress (and something to hold onto during rolls) so it's nice to leave the upper are of the bar clear. You can see a pic of my installation (barely, but it's all I have online at the moment) at: http://www.steinair.com/images/store/panels/4SB2.jpg Just my 2 cents! Cheers, Stein. >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of DEAN PSIROPOULOS >Sent: Friday, July 14, 2006 8:11 PM >To: rv-list(at)matronics.com >Subject: RV-List: Slide canopy compass mounting > > > > >Quick question on compass mounting: > >I have an RV-6 with sliding canopy. Have a bracket to mount the compass on >the roll bar support. Question is: where is the best place on the support >to mount the compass? Toward the top near the roll bar? Halfway down the >support or down at the bottom just above the top skin? Thanks. > >Dean Psiropoulos >RV-6A N197DM >Plodding toward the blissful end. > > ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Jacking up an RV
You slide the wheel out onto the rod and put a block under the axle so the rod and wheel can be moved away from the plane. Pax, Ed Holyoke -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob C. Sent: Friday, July 14, 2006 5:30 PM John, How do you remove a wheel when it's jacked up like that? Bob On 7/11/06, John Danielson wrote: > > I bought a 2 ft piece of 5/8" (I think that's right) steel rod. This > slips inside the axle. I then use my floor jack used for the car, it > will fit under the steel rod, and jack the plane up. Works a lot like > Avery's jack stand, but you really don't need any more than the steel > rod. > > John L. Danielson > RV-6 sold > > -----Original Message----- > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Emrath > Sent: Monday, July 10, 2006 8:04 PM > > > There has been a lot of information shared over the years on tires and > changing of tires. I'm about to finish installing my gear and would like > to > know if the Avery RV Jack Stand is the way to go or not. I would like > to > hear from some who can extol the benefits of this method of changing > tires > or from anyone that was not satisfied with this type of jacking up the > RV > and what they did instead. > > Marty in Brentwood > RV-6A > > ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Re: Slide canopy compass mounting
In a message dated 7/14/2006 6:14:53 P.M. Pacific Daylight Time, dean.psiropoulos(at)verizon.net writes: I have an RV-6 with sliding canopy. Have a bracket to mount the compass on the roll bar support. Question is: where is the best place on the support to mount the compass? Toward the top near the roll bar? Halfway down the support or down at the bottom just above the top skin? ======================================= Just an inch or so up and out from the glare shield. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 14, 2006
Subject: Tail wheel
More info here: http://bowenaero.com/mt3/archives/2006/04/tailwheel_upgra.html - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Michael [mailto:cubflyr(at)comcast.net] > Sent: Friday, July 14, 2006 8:21 PM > To: rv-list(at)matronics.com > Subject: RV-List: Tail wheel > > > Aviation Products Inc. > 114 Bryant St. > Ojai, CA 93023 > ph/fax 805-646-6042 > > I think they have a web site if you google the name. I have > one of their full-swivel wheels and have never had to do > anything to it except routine maintenance at conditional > inspection. I have had it apart once and finally may have to > replace the body of the thing; after 1000 hours it is getting > a little loose, but only a little. It has never failed to do > what it was designed to do. The tire shows little to no wear > at all and the bearings are still quiet. They have two angles > to choose from. I have the taller one (?45 degrees?). > Wouldn't have anything else on the tail of Suzie Q. > > Tear it apart every 10 hours??? Yikes. Sounds like something > from Wichita. > > Michael > N232 Suzie Q > > OSH-bound in about a week or so!!! > > > > > > Photoshare, and much much more: > > > > > > > > > ________________________________________________________________________________
Date: Jul 14, 2006
Thanks for answering for me Pax. John Danielson RV-6 sold Harmon Rocket -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ed Holyoke Sent: Friday, July 14, 2006 7:57 PM You slide the wheel out onto the rod and put a block under the axle so the rod and wheel can be moved away from the plane. Pax, Ed Holyoke -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob C. Sent: Friday, July 14, 2006 5:30 PM John, How do you remove a wheel when it's jacked up like that? Bob On 7/11/06, John Danielson wrote: > > I bought a 2 ft piece of 5/8" (I think that's right) steel rod. This > slips inside the axle. I then use my floor jack used for the car, it > will fit under the steel rod, and jack the plane up. Works a lot like > Avery's jack stand, but you really don't need any more than the steel > rod. > > John L. Danielson > RV-6 sold > > -----Original Message----- > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Emrath > Sent: Monday, July 10, 2006 8:04 PM > > > There has been a lot of information shared over the years on tires and > changing of tires. I'm about to finish installing my gear and would like > to > know if the Avery RV Jack Stand is the way to go or not. I would like > to > hear from some who can extol the benefits of this method of changing > tires > or from anyone that was not satisfied with this type of jacking up the > RV > and what they did instead. > > Marty in Brentwood > RV-6A > > ________________________________________________________________________________
Date: Jul 15, 2006
Subject: MAC servo supplier
Thanks !! _____ Sent: 13 July 2006 00:05 Jan, Ray Allan purchased the company. MAC is now RAC. Go to: http://www.rayallencompany.com/index.html <http://www.rayallencompany.com/index.html> Charlie Kuss Hi, Can anyone help with the contact details for Menzimer Aircraft Components Inc... I have a old address for Vista CA....but no reply from the phone number I got... Have they gone out of business or has the business been sold..changed owner... ?? Regards Jan http://www.w3.org/TR/REC-html40">
Thanks !!
From: Charlie Kuss [mailto:chaztuna(at)adelphia.net]
Subject: Re: RV-List: MAC servo supplier
Jan,
Charlie Kuss
Hi,
Can anyone help with the contact details for Menzimer Aircraft Components Inc… I have a old address for Vista CA….but no reply from the phone number I got… Have they gone out of business or has the business been sold..changed owner… ??
Jan
Date: Jul 15, 2006
I've got some pictures of mine - its a SIRS compass - I used SSplatenuts poprivets and screws on the SS roll bar brace. I did mine just above the skin so as not to make my scan large......right or wrong...... Contact me direct...... ----- Original Message ----- Sent: Friday, July 14, 2006 9:10 PM > > > Quick question on compass mounting: > > I have an RV-6 with sliding canopy. Have a bracket to mount the compass > on > the roll bar support. Question is: where is the best place on the support > to mount the compass? Toward the top near the roll bar? Halfway down the > support or down at the bottom just above the top skin? Thanks. > > Dean Psiropoulos > RV-6A N197DM > Plodding toward the blissful end. > > > ________________________________________________________________________________
Date: Jul 15, 2006
I'll guess its air bags to deploy in a crash -- like automobiles have. Ken Kruger mentioned last year at OSH that he thought it would be a good idea. I disagreed at the time, but have been thinking about it since then. Maybe it is a good idea. Dan Hopper RV-7A In a message dated 7/14/2006 2:35:53 P.M. Eastern Daylight Time, michele.delsol(at)microsigma.fr writes: I suggested it could be a parachute attachment to the fuelage. Michele RV8 - Fuselage ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Re: Nose gear failures (was new product announcement)
Its pretty normal to always think it happens to the other guy. In this case I'm the other guy! I tore up my -7A pretty good when the nose gear got into soft dirt and failed. I slid on wet grass as I was making a turn and went off the side of my grass strip into some soft mud. I tried to add power to pull it back onto the runway. As the nose wheel came to a clump of dirt it dug in and stopped the plane. It almost went clear over. As it was, I needed to replace the prop, engine mount and gear leg, the firewall and lower skin, and rebuild the engine. Definitely an expensive mistake. It was pilot error, but the design of the nose gear does not allow for much of a mistake. I have always taken good care of the nose gear as I was trained to do. These things happen quicker than you can think. Or, in this case, quicker than I could think. The replacement gear is of the new design, but I imagine that it would have done the same thing. It was the fairing that caught the mud in this case. Once it starts plowing it is not coming back up. If it were pavement, the new design would probably help. Please don't tell me what I should have done! I have had several weeks to reflect on all of that. I have the airplane nearly back together now, and am waiting on engine parts to get it going again. Should be back in the air in a month or so. Oh yeah, for you tail dragger pilots: You would probably have just gotten back on the runway and been out of there. Something to think about. Dan Hopper RV-7A In a message dated 7/15/2006 12:12:24 A.M. Eastern Daylight Time, steve(at)newtech.com writes: --> RV-List message posted by: Steve Eberhart Jim Sears wrote: > > >> I fully understand where pilotage comes into the equation but I have >> two nephews and a wife who will be taking their primary flight >> training in my RV-7A flying off of a moderate length grass strip. I >> think the oleo strut gear would be a slightly more robust nose gear. >> > > Steve, all I can say is you're one brave fella. :-) As for > the gear and primary training, having an instructor who > is good with RVs will lessen the need for concern. I've > bounced my nose gear over some humps in the runway > that made me wonder if I'd bent the gear. It's still fine, even > though it's the weaker one. It's a pretty springy > unit. I've seen a C150 nose gear pushed way back into the firewall. > Hey, one could let the students train in a C150/152 for a bit to get > past that initial learning > curve of reaching for the ground. Less risk on the -7A, that way. :-) > Jim in KY Hi Jim, That is the plan. Get them solo'd in a 152 and transition to the -7A during the next ten hours or so. I am not that concerned about the current castering nose wheel as that is what I am building. I just haven't heard of that many oleo equipped nose gears going over on their back while I have heard of RV's going over. One of the 152's I took my primary training in had its nose gear jammed up into the mount by one of the students. Tore it up pretty good but didn't go over on its back. I agree with you, if you are trained from the start to keep the weight off of the nose you shouldn't have any problems. Steve Eberhart RV-7A, Just moved the project to its new hangar and should be mounting the wings in a month or so. do not archive ________________________________________________________________________________
Date: Jul 15, 2006
Subject: New DVD on Glass Panels
This is an announcement of interest to the RV community that www.HomebuiltHELP.com has just released a new DVD video presentation entitled: " Building a Glass Panel for your Homebuilt Aircraft ". It is a unique presentation in that it allows first time panel builders see what is involved with designing and fabricating a modern electronic display panel for their homebuilt by watching someone do it from start to finish. I will leave it at that and those that are interested in this topic can visit the webpage outline at http://homebuilthelp.com/Glass_Panel.htm Thanks! Jon ________________________________________________________________________________
Date: Jul 15, 2006
Hopperdhh(at)aol.com wrote: > Its pretty normal to always think it happens to the other guy. In > this case I'm the other guy! snip > Oh yeah, for you tail dragger pilots: You would probably have just > gotten back on the runway and been out of there. Something to think > about. > > Dan Hopper > RV-7A I'm one of those taildragger pilots (Pitts) ..... and it doesn't take much for them to end up with the tail in the air. I know of a Pitts S-2 that was doing it's run-up on hard pavement. The airplane started to move and the pilot applied more pressure to the brakes to stop eth movement. Even with the stick full back to nail the tail on the ground ..... yup, you guessed right ..... over on it's nose. Prop and teardown too. As you know, trying to power out of a predicament usually makes things worse. No, not always, but usually. Sorry to hear about your unfortunate misfortune ..... it was a learning experience, I'm sure ..... and if it had ben a certificated airplane, the costs of repairs would be a lot more. Linn ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Electric trim switch replacement
Hi Gang, I have recently been having trouble with my electric trim switch. It is the older rocker with the red/green trim position light mounted above. The switch occasionally does not work, or it sticks in the "forward trim" setting. Can one purchase the switch from Van's, or do I need another source? Also can a toggle switch be used as a replacement? What designation would that be? Thanks in advance. Louis - Louis I Willig 1640 Oakwood Dr. Penn Valley, PA 19072 610 668-4964 RV-4, N180PF 190HP IO-360, C/S prop, 500.1 hrs !! ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Tire marking material
Has anyone found a material that will make a permanent mark on a tire sidewall? I've sprayed white auto body paint on mine a month ago and it has pretty completely disappeared by now. My purpose is to easily move the airplane to a point where the tire can be inflated without removing the wheel pants. Dave Reel - RV8A ________________________________________________________________________________
Date: Jul 15, 2006
I hope the air bag would mount up high enough so there was no chance of it pushing the stick forward if it fired off in the air. Otherwise a spurious firing could cause structural failure. I'm not a big fan of electrically commanded systems with single point failures that cause a catastrophic event. Kevin Horton On 15 Jul 2006, at 16:36, Terry Watson wrote: > > I read somewhere about airbags that are a part of the shoulder > harness. The > one I read about was for a single strap shoulder harness, such as in a > Cessna. I think they were to be an option on some certified aircraft. > > Terry > > >> I'll guess its air bags to deploy in a crash -- like automobiles >> have. >> Ken Kruger mentioned last year at OSH that he thought it would be >> a good >> idea. I disagreed at the time, but have been thinking about it since >> then. Maybe it is a good idea. > > That would be a great announcement, and I would probably install them. > > -- > Mickey Coggins > ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Re: Tire marking material
At 02:53 PM 7/15/2006, you wrote: > >Has anyone found a material that will make a permanent mark on a tire >sidewall? Yellow or white tire marking crayons are good enough. Ron Lee ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Lightspeed Ignition Problem
I have been using two Lightspeed Engineering Hall-effect electronic ignition systems on my O-320 160HP engine in my RV6A for some time now, all trouble free. BUT, today upon returning from a nearby flyin breakfast the plane was really "making knots" and was making about 180 TAS and 171 GPS ground speed at 2,350-RPM, with a fuel burn of 6.7 GPH. So I was happy. On shutdown, I always "kill" one ignition at a time to insure they are both working (you can turn one off in flight and only see a 10-RPM engine drop.) Today with the right side on alone it dropped engine rpm by 400 to 500 and it ran REALLY rough. I put in new plugs, re-timed the Hall-effect pickup units and got no improvement. Connections/connectors all securely attached. While its easy to suspect the electronic unit I do have to recognize that the plugs are firing, albiet in strange ways, so the electronics can't be "dead" - also in flight the roughness was not present, or at least not noticeable. I asked Klaus for an opinion but probably won't hear from him due to upcoming OSH, etc. Any Lightspeed users out there have any suggestions? John ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Re: The TRUTH about MOGAS
Hi Glen The squish band (aka quench area) is a tapered area on the periphery of a cylinder head's combustion chamber. It's purpose is to move the fuel/air mixture near the edges of this area, closer to the center of the cylinder. It also creates turbulence. This aids in more complete combustion of the fuel/air mixture. See links below for more info & photos. http://www.rbracing-rsr.com/squishcalc1.html http://www.lambretta.net/cylinder-head.htm http://www.motorcycle.com/mo/mcrob/rt-fuel2.html Charlie Kuss > > >HI Tim- > >This is getting interesting and closer to answering my curiosity. What is >the "squish" you referred to? > >glen matejcek >aerobubba(at)earthlink.net > > ________________________________________________________________________________
Date: Jul 15, 2006
Subject: Re: Lightspeed Ignition Problem
Check your coil connections. That is, the fast-on connectors that push onto the coil terminals. Check the wires & crimps at those connectors. Make sure there isn't any strain on 'em that has accumulated in form of poor connection or break in those wires (been there done that). Phase your coils as per the instructions on www.lsecorp.com. Make sure both coils are firing properly. That's about as much as I can tell ya. Let us know what works or doesn't. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: John Fasching To: rv-list(at)matronics.com Sent: Saturday, July 15, 2006 5:18 PM Subject: RV-List: Lightspeed Ignition Problem I have been using two Lightspeed Engineering Hall-effect electronic ignition systems on my O-320 160HP engine in my RV6A for some time now, all trouble free. BUT, today upon returning from a nearby flyin breakfast the plane was really "making knots" and was making about 180 TAS and 171 GPS ground speed at 2,350-RPM, with a fuel burn of 6.7 GPH. So I was happy. On shutdown, I always "kill" one ignition at a time to insure they are both working (you can turn one off in flight and only see a 10-RPM engine drop.) Today with the right side on alone it dropped engine rpm by 400 to 500 and it ran REALLY rough. I put in new plugs, re-timed the Hall-effect pickup units and got no improvement. Connections/connectors all securely attached. While its easy to suspect the electronic unit I do have to recognize that the plugs are firing, albiet in strange ways, so the electronics can't be "dead" - also in flight the roughness was not present, or at least not noticeable. I asked Klaus for an opinion but probably won't hear from him due to upcoming OSH, etc. Any Lightspeed users out there have any suggestions? John ________________________________________________________________________________
Date: Jul 15, 2006
John, I experienced similar problems several years ago. I determined that it was failure from heat soaking of the lightweight coils supplied by Klaus. He suggested I replace them with General Motors coils which I did. I have had no problems since, 1000 hours ago. Good Luck. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: John Fasching To: rv-list(at)matronics.com Sent: Saturday, July 15, 2006 7:18 PM Subject: RV-List: Lightspeed Ignition Problem I have been using two Lightspeed Engineering Hall-effect electronic ignition systems on my O-320 160HP engine in my RV6A for some time now, all trouble free. BUT, today upon returning from a nearby flyin breakfast the plane was really "making knots" and was making about 180 TAS and 171 GPS ground speed at 2,350-RPM, with a fuel burn of 6.7 GPH. So I was happy. On shutdown, I always "kill" one ignition at a time to insure they are both working (you can turn one off in flight and only see a 10-RPM engine drop.) Today with the right side on alone it dropped engine rpm by 400 to 500 and it ran REALLY rough. I put in new plugs, re-timed the Hall-effect pickup units and got no improvement. Connections/connectors all securely attached. While its easy to suspect the electronic unit I do have to recognize that the plugs are firing, albiet in strange ways, so the electronics can't be "dead" - also in flight the roughness was not present, or at least not noticeable. I asked Klaus for an opinion but probably won't hear from him due to upcoming OSH, etc. Any Lightspeed users out there have any suggestions? John ________________________________________________________________________________
Date: Jul 15, 2006
Just remove and reseat all the connections. I had a loss of one side once that nothing fixed. It finally went away and my opinion is that some corrosion impacted the connection of one of the wires to the coils. The multiple reconnecting may have "cleaned" the corrosion. Ron Lee ________________________________________________________________________________
Date: Jul 16, 2006
Subject: Re: Steerable nose gear (or MMTB)
In a message dated 7/14/06 7:49:05 PM Eastern Daylight Time, jmsears(at)adelphia.net writes: > > I fully understand where pilotage comes into the > > equation but I have two nephews and a wife who > > will be taking their primary flight training in my RV-7A > > flying off of a moderate length grass strip. I think the > > oleo strut gear would be a slightly more robust nose gear. > > > > Steve, all I can say is you're one brave fella. :-) ==================================== WOW Steve ... You are TOO kind. If this fella was a friend I would read him the riot act! I would not even consider ANY instructor an instructor if he accepted this challenge. And what insurance company would insure the plane or instructor under these conditions. Hello J. F. Kennedy, Jr., your family plot is waiting. Barry "Chop'd Liver" ________________________________________________________________________________
Date: Jul 16, 2006
We had the same problem. Pulled off the contacts to the coils, cleaned them all up, and put them back together. Fixed the problem. -Mike -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee Sent: Saturday, July 15, 2006 11:35 PM Just remove and reseat all the connections. I had a loss of one side once that nothing fixed. It finally went away and my opinion is that some corrosion impacted the connection of one of the wires to the coils. The multiple reconnecting may have "cleaned" the corrosion. Ron Lee ________________________________________________________________________________
Date: Jul 16, 2006
Subject: homebuilt blimps, was Major new product announcement from Vans
Hi Stormy- Re: why are there no homebuilt blimps flying? IIRC, there was a pedal powered, one seat blimp at OSH some years back. I think it ws the brain child and gimmick of some comedian. Really! glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jul 16, 2006
Subject: OAT probe position
I am about to hook up the outside air temp probe. After consulting the web (thank goodness) I am thinking about placing the sensor in the FAB prior to the air filter in the snorkel area. My logic says it would give me OAT with out the heating of the engine temps affecting it. It should give me air temps for my EFIS to compute DA. My second choice is the inboard inspection panel in the wing. The FAB position would require no disconnecting. Am I not seeing something? Jim Nelson RV9-A FWF ________________________________________________________________________________
Date: Jul 16, 2006
Hi Charlie- Thanks for the links. They gave me just what I needed- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jul 16, 2006
Subject: best construction web sites
I have great respect for those who can build an RV. I am even more impressed by those who build RVs and also build web sites to document their work. There are so many great sites! What are your favorites? Which have helped you most? Thanks -- _______________________________________________ Get your free email from http://www.yyhmail.com ________________________________________________________________________________
Date: Jul 16, 2006
Dick What GM coils are you referring to? Late model Corvette items? V-6/V-8 DIS (distributorless Ignition System) coils? Could you supply a part number or vehicle/engine application? Charlie Kuss >John, >I experienced similar problems several years ago. I determined >that it was failure from heat soaking of the lightweight coils >supplied by Klaus. He suggested I replace them with General Motors >coils which I did. I have had no problems since, 1000 hours ago. Good Luck. >Dick Martin >RV8 N233M >the fast one >----- Original Message ----- >From: <mailto:n1cxo320(at)salidaco.com>John Fasching >To: rv-list(at)matronics.com >Sent: Saturday, July 15, 2006 7:18 PM >Subject: RV-List: Lightspeed Ignition Problem > >I have been using two Lightspeed Engineering Hall-effect electronic >ignition systems on my O-320 160HP engine in my RV6A for some time >now, all trouble free. > >BUT, today upon returning from a nearby flyin breakfast the plane >was really "making knots" and was making about 180 TAS and 171 GPS >ground speed at 2,350-RPM, with a fuel burn of 6.7 GPH. So I was happy. > >On shutdown, I always "kill" one ignition at a time to insure they >are both working (you can turn one off in flight and only see a >10-RPM engine drop.) Today with the right side on alone it dropped >engine rpm by 400 to 500 and it ran REALLY rough. I put in new >plugs, re-timed the Hall-effect pickup units and got no improvement. >Connections/connectors all securely attached. > >While its easy to suspect the electronic unit I do have to recognize >that the plugs are firing, albiet in strange ways, so the >electronics can't be "dead" - also in flight the roughness was not >present, or at least not noticeable. > >I asked Klaus for an opinion but probably won't hear from him due to >upcoming OSH, etc. Any Lightspeed users out there have any suggestions? > >John ________________________________________________________________________________
Date: Jul 16, 2006
Subject: VM1000 light system failure
Fellow listers, Anyone out there experience a failure mode with their VM1000 internal lighting system? The lights worked up until a few days ago...I'm trying to remember if I have done anything to the lighting system that might cause the failure mode sooooo........ Here's the troubleshooting that I have already done: Pin 20 has 13.3 VDC Pin 21 has between 4.1 VDC and 10.8 VDC depending on the dimmer setting Pin 22 has continuity to ground These three are 'as designed' in my opinion - so the proper stuff is at least getting to the DPU. Is there something that I can check on the cable between the DPU and the display? I've sent a note to Vision Microsystems - I'll post their response......... Ralph Capen ________________________________________________________________________________
Date: Jul 16, 2006
Don't know what GM coils Klaus uses but, I have had similar symptoms with my system (rotary engine, but they all need spark) and it was due to heat soaking of coils. I use GM coils for the LS1 engine and the failures occurred with the truck version of the LS1. The Corvette version has always worked flawlessly. Point being that all GM coils are not created equal. The Corvette coils are made by Nippon Denso (I love their stuff). The truck version was made by Hitachi I think. Tracy Crook ----- Original Message ----- From: dick martin<mailto:martin(at)gbonline.com> To: rv-list(at)matronics.com Sent: Saturday, July 15, 2006 10:47 PM Subject: Re: RV-List: Lightspeed Ignition Problem John, I experienced similar problems several years ago. I determined that it was failure from heat soaking of the lightweight coils supplied by Klaus. He suggested I replace them with General Motors coils which I did. I have had no problems since, 1000 hours ago. Good Luck. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: John Fasching<mailto:n1cxo320(at)salidaco.com> To: rv-list(at)matronics.com Sent: Saturday, July 15, 2006 7:18 PM Subject: RV-List: Lightspeed Ignition Problem I have been using two Lightspeed Engineering Hall-effect electronic ignition systems on my O-320 160HP engine in my RV6A for some time now, all trouble free. BUT, today upon returning from a nearby flyin breakfast the plane was really "making knots" and was making about 180 TAS and 171 GPS ground speed at 2,350-RPM, with a fuel burn of 6.7 GPH. So I was happy. On shutdown, I always "kill" one ignition at a time to insure they are both working (you can turn one off in flight and only see a 10-RPM engine drop.) Today with the right side on alone it dropped engine rpm by 400 to 500 and it ran REALLY rough. I put in new plugs, re-timed the Hall-effect pickup units and got no improvement. Connections/connectors all securely attached. While its easy to suspect the electronic unit I do have to recognize that the plugs are firing, albiet in strange ways, so the electronics can't be "dead" - also in flight the roughness was not present, or at least not noticeable. I asked Klaus for an opinion but probably won't hear from him due to upcoming OSH, etc. Any Lightspeed users out there have any suggestions? John ________________________________________________________________________________
Date: Jul 16, 2006
Another problem I had with rough running was not obvious with a casual inspection. One wire had broken inside the connector (lead to a coil). I just found it by accidentally hitting the wire instead of the connector and saw that it was broken. It is well secured now! Since the cowl is off to fix something else I will take a picture of the repaired wire connection. Ron Lee ________________________________________________________________________________
Date: Jul 16, 2006
In a message dated 7/15/2006 1:54:27 P.M. Pacific Daylight Time, dreel(at)cox.net writes: Has anyone found a material that will make a permanent mark on a tire sidewall? ====================== I used the white-out correction fluid for making ink corrections to documents. It worked well enough and was free from work. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Jul 16, 2006
Subject: Re: OAT probe position
You should put it near the wing inspection plate to have better, consistent readings. Indiana Larry ----- Original Message ----- > > I am about to hook up the outside air temp probe. After consulting the > web (thank goodness) I am thinking about placing the sensor in the FAB > prior to the air filter in the snorkel area. My logic says it would give > me OAT with out the heating of the engine temps affecting it. It should > give me air temps for my EFIS to compute DA. My second choice is the > inboard inspection panel in the wing. The FAB position would require no > disconnecting. Am I not seeing something? ________________________________________________________________________________
Date: Jul 16, 2006
I put a Davtron OAT instrument (ACS: page 374) beside the map box and the OAT probe beside the inner inspection plate on the right wing. It comes prewired - it's long enough to install without cutting or adding wire. Very accessible and very maintainable. Seems remote enough from the prop/engine heat. > > You should put it near the wing inspection plate to have better, > consistent readings. Indiana Larry > >> >> I am about to hook up the outside air temp probe. After consulting the >> web (thank goodness) I am thinking about placing the sensor in the FAB >> prior to the air filter in the snorkel area. My logic says it would give >> me OAT with out the heating of the engine temps affecting it. It should >> give me air temps for my EFIS to compute DA. My second choice is the >> inboard inspection panel in the wing. The FAB position would require no >> disconnecting. Am I not seeing something? ________________________________________________________________________________
Date: Jul 16, 2006
Here is a link to the pic. One of the wires to the closest coil broke just inside the insulated portion of the connector. When I rewired it I added about three layers of heat shrink. The original method is somewhat visible in the out of focus right side coil. http://home.pcisys.net/~ronlee/CoilWireRepair.jpg Ron Lee >Another problem I had with rough running was not obvious with a casual >inspection. One wire had broken inside the connector (lead to a coil). I >just found it by accidentally hitting the wire instead of the connector and >saw that it was broken. It is well secured now! > >Since the cowl is off to fix something else I will take a picture of the >repaired >wire connection. > >Ron Lee ________________________________________________________________________________
Date: Jul 16, 2006
Subject: Re: homebuilt blimps, was Major new product announcement
glen matejcek wrote: > > > Hi Stormy- > >Re: why are there no homebuilt blimps flying? > >IIRC, there was a pedal powered, one seat blimp at OSH some years back. I >think it ws the brain child and gimmick of some comedian. Really! > Correcto! The comedian is Galagher .... one of my favorites. He also had a smaller version that was electrical powered and radio controlled. The guy that built the stuff is an EAA member ..... don't know if Galagher is though. Linn > >glen matejcek >aerobubba(at)earthlink.net > > > > > > > > > ________________________________________________________________________________
Date: Jul 16, 2006
Subject: Lightspeed Electronic Igntion Probelm - SOLVED
Thanks for all your suggestions - most of them were about on the mark. After replacing all plugs and re-timing (2nd time) I began ohm meter work and something "funny" was found at one transformer....after unwrapping some electrical tape I found the inside insulating material on the coaxial cable from the electronics box to the input side of one transformer has shrunk back far enough that the inside conductor was shorted to the braid. (probably from engine heat) So, naturally, the input to the transformer was 'gone.' A temporary repair confired all is well. I will just replace the entire coax cable upon my return from OSH (am driving to test out my new "Cubby" teardrop camper this year.) Again, thanks folks for your help. You don't relaize how close to the actural problem many of you were. Thanks again. John at Salida, CO ________________________________________________________________________________
Date: Jul 16, 2006
I have tried several positions and returned to my original choice. It is on the aft fuselage, right side, under the horizontal stabilizer. It has virtually no errors, reads ok even at zero airspeed. It is especially good for the Dynon since I have the magnetometer mounted on the deck in front of the stabilizer. The wiring on the Dynon OAT probe goes to the magnetometer. Only down side (pun) is that it is in the sun while inverted. Since I only use that position momentarily it works well for me. Denis Walsh On Jul 16, 2006, at 07:22 265390007, James H Nelson wrote: > > I am about to hook up the outside air temp probe. After consulting > the > web (thank goodness) I am thinking about placing the sensor in the FAB > prior to the air filter in the snorkel area. My logic says it would > give > me OAT with out the heating of the engine temps affecting it. It > should > give me air temps for my EFIS to compute DA. My second choice is the > inboard inspection panel in the wing. The FAB position would > require no > disconnecting. Am I not seeing something? > > > Jim Nelson > RV9-A FWF > > ________________________________________________________________________________
Date: Jul 16, 2006
>"I'll guess its air bags to deploy in a crash" So how will it tell the difference between a crash and one of my normal crappy landings?!! Pete Cowper RV-8 #81139 ________________________________________________________________________________
Date: Jul 16, 2006
Michael, I'm no geek on computers and with my first build I did it with a camera and made a scrapbook. Now I have a digital camera and it makes it soooo much easier. I am using Expercraft.com. It is free and you can upload your pix with each days work. I really appreciate the ease and of course, no expense for the web site. Your welcome to visit my site at http://websites,expercraft.com/jimn to see how my build is going. Jim Nelson RV9-A FWF ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Jul 16, 2006
My instructor told me if I walk away its a good landing...if I can fly the plane again, that's a great landing. ----- Original Message ----- Sent: Sunday, July 16, 2006 4:12 PM > > >"I'll guess its air bags to deploy in a crash" > > So how will it tell the difference between a crash and one of my normal > crappy landings?!! > > Pete Cowper > RV-8 #81139 > > ________________________________________________________________________________
Date: Jul 16, 2006
Dave, Before putting my wheel pants on I marked each tire with a dot using yellow torque seal. I just smeared it around a bit to work it into the rubber....if you were to put a three-dimensional glob of it on the tire sidewall (the way you normally use the stuff for its intended application) I'm sure it would break right off, but so far after 67 hours the marks still show clearly. Easy to do and doesn't require a seperate purchase if you've already got some laying around the hangar.... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D flying and grinning like an idiot.... ------------------------------------------------------------------------- ---------------------------------------------------------- Has anyone found a material that will make a permanent mark on a tire sidewall? I've sprayed white auto body paint on mine a month ago and it has pretty completely disappeared by now. My purpose is to easily move the airplane to a point where the tire can be inflated without removing the wheel pants. Dave Reel - RV8A ________________________________________________________________________________
Date: Jul 17, 2006
Jim: The recommendation to your idea is no. Anything in the engine compartment is HOT, even the inside of the FAB. Also you want to be as far away from the engine and prop air blast as practical like on the tail or outb'd wing. The entire engine area is a heated zone. I understand you think it is ahead of the heat. I guess if you had it on the tip of the spinner, but Anything in the engine compartment, inside the airbox included is hotter than the ambient air temp of the air mass you are flying through. Common locations are lwr surface of wing tip or mid wing inspection cover or under horz tail in inspection elevator bell crank access cover. The further away from the engine in any direction the better. George M RV-4, RV-7 >posted by: James H Nelson > >I am thinking about placing the sensor in the FAB >prior to the air filter in the snorkel area. My logic says >it would give me OAT with out the heating of the engine >temps affecting it. It should give me air temps for my >EFIS to compute DA. My second choice is the inboard >inspection panel in the wing. The FAB position would >require no disconnecting. Am I not seeing something? >The inboard inspection wing location is fine. Besides >how often are your wings going on and off after you >start flying? Do you want to route more wires thru >the fire wall --------------------------------- ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Have a Grand Rapids EIS 4000 manual as computer file?
I'd like to make up a small pilot's manual for the EIS 4000. Does anyone have the full manual in electronic form they could email to me at dreel(at)cox.net? Then I wouldn't have to type in all those tables. I've also asked Grand Rapids but no response to my email yet. Dave Reel - RV8A ________________________________________________________________________________
Date: Jul 17, 2006
Naca duct works At 09:22 AM 7/16/2006, you wrote: > >I am about to hook up the outside air temp probe. After consulting the >web (thank goodness) I am thinking about placing the sensor in the FAB >prior to the air filter in the snorkel area. My logic says it would give >me OAT with out the heating of the engine temps affecting it. It should >give me air temps for my EFIS to compute DA. My second choice is the >inboard inspection panel in the wing. The FAB position would require no >disconnecting. Am I not seeing something? > > >Jim Nelson >RV9-A FWF > > ________________________________________________________________________________
Date: Jul 17, 2006
Charlie, I went to an auto parts store and asked for a standard GM coil. Apparantly, this is a very common item. You will have to mount them on the firewall over a piece of non conductive material, because the contact point is on the bottom of the coil. I used brass strips to exit the coil and provide a spade connector for the input to the coil. The output of course is a sparkplug wire. Dick Martin Getting ready for the Air Venture race ----- Original Message ----- From: Charlie Kuss To: rv-list(at)matronics.com Sent: Sunday, July 16, 2006 8:38 AM Subject: Re: RV-List: Lightspeed Ignition Problem Dick What GM coils are you referring to? Late model Corvette items? V-6/V-8 DIS (distributorless Ignition System) coils? Could you supply a part number or vehicle/engine application? Charlie Kuss John, I experienced similar problems several years ago. I determined that it was failure from heat soaking of the lightweight coils supplied by Klaus. He suggested I replace them with General Motors coils which I did. I have had no problems since, 1000 hours ago. Good Luck. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: John Fasching To: rv-list(at)matronics.com Sent: Saturday, July 15, 2006 7:18 PM Subject: RV-List: Lightspeed Ignition Problem I have been using two Lightspeed Engineering Hall-effect electronic ignition systems on my O-320 160HP engine in my RV6A for some time now, all trouble free. BUT, today upon returning from a nearby flyin breakfast the plane was really "making knots" and was making about 180 TAS and 171 GPS ground speed at 2,350-RPM, with a fuel burn of 6.7 GPH. So I was happy. On shutdown, I always "kill" one ignition at a time to insure they are both working (you can turn one off in flight and only see a 10-RPM engine drop.) Today with the right side on alone it dropped engine rpm by 400 to 500 and it ran REALLY rough. I put in new plugs, re-timed the Hall-effect pickup units and got no improvement. Connections/connectors all securely attached. While its easy to suspect the electronic unit I do have to recognize that the plugs are firing, albiet in strange ways, so the electronics can't be "dead" - also in flight the roughness was not present, or at least not noticeable. I asked Klaus for an opinion but probably won't hear from him due to upcoming OSH, etc. Any Lightspeed users out there have any suggestions? John ________________________________________________________________________________
Date: Jul 17, 2006
>Naca duct works Negative on an RV-6A. You get too much heat from the engine area. Ron Lee ________________________________________________________________________________
Date: Jul 17, 2006
Nope, not if you want an accurate reading. I was doing some glide performance testing on an RV-6 in the winter, and the OAT indication varied depending on how much cabin heat we had selected. The back side of the probe was being warmed from the cockpit, and that was affecting the indication. This would likely be an issue even if cabin heat was not selected, as the greenhouse effect from the canopy means the cockpit temperature is usually warmer than ambient. Kevin Horton On 17 Jul 2006, at 08:42, Richard Seiders wrote: > > Naca duct works > > > At 09:22 AM 7/16/2006, you wrote: >> >> I am about to hook up the outside air temp probe. After >> consulting the >> web (thank goodness) I am thinking about placing the sensor in the >> FAB >> prior to the air filter in the snorkel area. My logic says it >> would give >> me OAT with out the heating of the engine temps affecting it. It >> should >> give me air temps for my EFIS to compute DA. My second choice is the >> inboard inspection panel in the wing. The FAB position would >> require no >> disconnecting. Am I not seeing something? >> ________________________________________________________________________________
Date: Jul 17, 2006
Very true. The only time my NACA duct mounted OAT probe is accurate is when the airplane has finally cooled down to the ambient temperature, such as occurs after being parked in the hangar overnight. One of these days I will get around to relocating that probe and the farther away from the engine compartment, the better. Rick Galati RV-6A "Darla" 153 hours ronlee(at)pcisys.net wrote: > > > Naca duct works > > > > > > > Negative on an RV-6A. You get too much heat from the engine area. > > Ron Lee Read this topic online here: http://forums.matronics.com/viewtopic.php?p=47841#47841 ________________________________________________________________________________
Date: Jul 17, 2006
I had asked Dynon about the OAT position a few months ago. They indicated that, while they could not tell me where to put it, that RV aircraft had had excellent results in the rear fuselage under the horizontal stabilizer. Covering their legal positions while still trying to answer my question. So, I'm going to go with the that soltion, the same one Denis Walsh has stated in another reply here. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=47856#47856 ________________________________________________________________________________
Date: Jul 17, 2006
In a message dated 7/17/2006 9:13:45 A.M. Eastern Daylight Time, martin(at)gbonline.com writes: Charlie, I went to an auto parts store and asked for a standard GM coil. Apparantly, this is a very common item. You will have to mount them on the firewall over a piece of non conductive material, because the contact point is on the bottom of the coil. I used brass strips to exit the coil and provide a spade connector for the input to the coil. The output of course is a sparkplug wire. Dick Martin Getting ready for the Air Venture race Having worked on the design of GM's distributorless ignition systems, I can pass along a small piece of advice. Ground the laminations of the coils. I think the GM coils will have a metal strip evident under one of the mounting bolts. Be sure this gets grounded. Otherwise the laminations float to a high voltage and finally arc causing radio noise or interference to the electronics of the ignition system. Along the same lines, if the secondary connections have even a very small gap you get what we called micro-arcing. A 1 thousandth of an inch arc, believe it or not, causes interference that can wreak havoc with the electronics of the ignition system -- that is the computer or logic driving the coils. This micro-arcing is much harder to deal with than the arc at the spark plug gap. Dan Hopper RV-7A ________________________________________________________________________________
Date: Jul 17, 2006
Maybe on your 6A, not mine. My oat is consistent with in air temp reports. Guess it depends where you put it. Dick At 09:23 AM 7/17/2006, you wrote: > > >>Naca duct works > > >Negative on an RV-6A. You get too much heat from the engine area. > >Ron Lee > > ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Re: best construction web sites
After looking at the products offered, free or otherwise I decided I wanted more control on the daily pages. No restriction on how many pictures and the ability to embed the photos in the text so I used MediaWiki. Its the software used by Wikipedia and is open-source so it is free. Didn't take but about an hour to come up to speed and most hosting companies have the script to get you started easily. I agree about the digital camera. I also recomend using Picasa2 from the Google site. Handles downloading the photos from your camera and all the corrections and sizing you might want to do; all for free. My site is www.N669RV.com and I welcome any constructive criticism. Michael Hudson Hillsboro, Oregon On 7/16/06, James H Nelson wrote: > > > Michael, > I'm no geek on computers and with my first build I did it with a > camera and made a scrapbook. Now I have a digital camera and it makes it > soooo much easier. I am using Expercraft.com. It is free and you can > upload your pix with each days work. I really appreciate the ease and > of course, no expense for the web site. Your welcome to visit my site at > http://websites,expercraft.com/jimn to see how my build is going. > > Jim Nelson > RV9-A FWF > > ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Marker Beacon Antennas
Does anyone have any meaningful info on the drag due to the different marker beacon antenna types (boat vs. sled)? - Alan RV-8 Perpetual Tail Kit ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Re: Marker Beacon Antennas
Bob Archer says a stripped coax in the wingtip will do the trick.....no antenna needed. I think it is 40" long. Did that in my 10 but not flying yet. Doug #40372 ________________________________________________________________________________
Date: Jul 17, 2006
People can do anything even if wrong but with the prevailing comments that away from the engine area is best why anyone would still go against good advise is beyond me. Ron Lee >Maybe on your 6A, not mine. My oat is consistent with in air temp reports. >Guess it depends where you put it. >Dick > > >At 09:23 AM 7/17/2006, you wrote: >> >> >>>Naca duct works >> >> >>Negative on an RV-6A. You get too much heat from the engine area. >> >>Ron Lee >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 17, 2006
What Doug describes worked great for me. As per the recommendation of several "experts," I took a 40" length of RG400 and stripped away the outer jacket and double shielding, leaving just the insulated center conductor. Glassed that into my right wingtip, bottom surface. There is a BNC connector on it so I can remove the wingtip easily. I do fly IFR with my RV-7, fwiw, got about 1000 hours on it. This marker beacon approach WORKS. whatsoever. Strip of aluminum or copper for example. Whatever floats your boat. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: DOUGPFLYRV(at)aol.com To: rv-list(at)matronics.com Sent: Monday, July 17, 2006 10:47 AM Subject: Re: RV-List: Marker Beacon Antennas Bob Archer says a stripped coax in the wingtip will do the trick.....no antenna needed. I think it is 40" long. Did that in my 10 but not flying yet. Doug #40372 ________________________________________________________________________________
Date: Jul 17, 2006
Bob suggests mounting the 40" wire starting at the trailing edge of the wingtip. The wire should run 3" outboard (and parallel to) the metal wing skin. Regards, Jim Ayers In a message dated 07/17/2006 11:28:41 AM Pacific Daylight Time, dan(at)rvproject.com writes: What Doug describes worked great for me. As per the recommendation of several "experts," I took a 40" length of RG400 and stripped away the outer jacket and double shielding, leaving just the insulated center conductor. Glassed that into my right wingtip, bottom surface. There is a BNC connector on it so I can remove the wingtip easily. I do fly IFR with my RV-7, fwiw, got about 1000 hours on it. This marker beacon approach WORKS. Strip of aluminum or copper for example. Whatever floats your boat. )_( Dan RV-7 N714D _http://www.rvproject.com_ (http://www.rvproject.com/) ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jul 17, 2006
I also did this, although I'm not flying yet either. You can see some less than spectacular pics here: http://www.mykitlog.com/users/display_log.php?user=msausen&project=22 &ca tegory=624&log=6520&row=4 You may need to paste the link back together. Sorry, I'm too lazy to use a URL shortener. ;-) Michael Sausen RV-10 #352 Working on Fuselage Recent RV-10 Build Activity <http://www.mykitlog.com/display_project.php?project_id=22> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Checkoway Sent: Monday, July 17, 2006 1:24 PM What Doug describes worked great for me. As per the recommendation of several "experts," I took a 40" length of RG400 and stripped away the outer jacket and double shielding, leaving just the insulated center conductor. Glassed that into my right wingtip, bottom surface. There is a BNC connector on it so I can remove the wingtip easily. I do fly IFR with my RV-7, fwiw, got about 1000 hours on it. This marker beacon approach WORKS. whatsoever. Strip of aluminum or copper for example. Whatever floats your boat. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: DOUGPFLYRV(at)aol.com To: rv-list(at)matronics.com Sent: Monday, July 17, 2006 10:47 AM Subject: Re: RV-List: Marker Beacon Antennas Bob Archer says a stripped coax in the wingtip will do the trick.....no antenna needed. I think it is 40" long. Did that in my 10 but not flying yet. Doug #40372 ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Fuel tank vent
Fuel is expensive and unfortunately my RH tank decides to empty itself via the air vent / drain whenever it is either full or it gets hot. Our guess is that the air vent tube doesn't reach the top of the tank, hence the pressure builds up and vents the fuel (If you open the filler there is a gush of released air pressure). The LH tank behaves itself. I don't want to remove the tank as I am flying - If I drill a 16" vent in the filler cap of this problematic QB tank, will the tank empty due to venturi in-flight - or is this the best solution ? Any remedies to save my fuel bill - much appreciated. Rgds, Nic ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Re: Fuel tank vent
One cause could be a loose connection (internal) of the vent line-to- inboard rib. This will allow the expanding air to force fuel overboard until the tank is more than half empty! check the vent line for integrity. If needed, It can be tightened by removing the inspection plate and use a mirror to guide your wrench to tighten it up. You would be surprised how many of those forget to get themselves tightened back up after loosening for riveting the tanks. Denis Walsh On Jul 17, 2006, at 07:13 548330007, Nic wrote: > > Fuel is expensive and unfortunately my RH tank decides to empty > itself via > the air vent / drain whenever it is either full or it gets hot. > > Our guess is that the air vent tube doesn't reach the top of the > tank, hence > the pressure builds up and vents the fuel (If you open the filler > there is a > gush of released air pressure). The LH tank behaves itself. > > I don't want to remove the tank as I am flying - If I drill a 16" > vent in > the filler cap of this problematic QB tank, will the tank empty due to > venturi in-flight - or is this the best solution ? > > Any remedies to save my fuel bill - much appreciated. > > Rgds, Nic > > ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Re: Van's announcement leaked
I heard they have come up with a 5 part epoxy primer that we will all be required to use. This is good because it solves the primer war, but the down side is it only comes in the color mauve so our cockpits will not be so pretty... ________________________________________________________________________________
Date: Jul 17, 2006
My guess is that this was leaked simply because Van's generally dislikes the RV list. They knew they could jam it up with this crap for at least a few weeks. Sigh. What a great way to spam up the RV list. Do not archive. Denis Walsh ________________________________________________________________________________
Date: Jul 17, 2006
On 17 Jul 2006, at 17:13, Nic wrote: > > Fuel is expensive and unfortunately my RH tank decides to empty > itself via > the air vent / drain whenever it is either full or it gets hot. > > Our guess is that the air vent tube doesn't reach the top of the > tank, hence > the pressure builds up and vents the fuel (If you open the filler > there is a > gush of released air pressure). The LH tank behaves itself. > > I don't want to remove the tank as I am flying - If I drill a 16" > vent in > the filler cap of this problematic QB tank, will the tank empty due to > venturi in-flight - or is this the best solution ? > > Any remedies to save my fuel bill - much appreciated. I would expect that you should be able to see the outboard end of the vent through the filler cap with a mirror and a flashlight. Compare the ones on the left and the right to see if there is a difference. If the right one isn't up against the top of the tank, it could explain the problem. I don't see an easy way to fix that. I think the tank would have to come off, and you would cut a hole in the rear baffle to provide access, then proseal a cover on. If the outboard end of the vent line looks normal, another possibility would be if the vent line inside the tank wasn't connected to the fitting on the inboard rib. If this is the problem, you could get at it via the access cover on the inboard rib. Good luck, Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jul 17, 2006
Subject: Re: Parking Brake Location
I am at the point now where I need to install the parking brake on my RV7A. There are no directions or instructions that I could find as to how or where to install it. What have some of you experienced builders done? Or......should I just forget about installing it altogether since I'm now doubting whether I really need it. Comments? Garry Stout RV7A, Odessa Florida ________________________________________________________________________________
Date: Jul 18, 2006
Nic: Everyone else have told possible causes and potental fixes. Just a warning. DO NOT dirll a hole in your filler cap. You will lose more fuel when you are flying from the low pressure suction over the wing. About all I can add to what others have said, only fill the tank part way to see if it vents fuel on the ground. How low does it need to be before it stops venting? If I fill my tanks, I will vent out some fuel in the hot sun but it stops when the fuel quits expanding. Have you measured the amout of fuel that comes out of the vent? If you get one or two liters and it stops, it may only be expansion of fuel in a full tank. If you get more than 6 or 8 liters, then more than likely the vent line is lose at the bulkhead fitting. After the inspection of the vent line at the fuel cap as others suggested, if it looks good, find a helper and a hose. Connect the hose to the vent and blow into the tank. Have your friend look in the tank through the filler to see where the air is coming out. Should narrow down where the leak is. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,894 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- Fuel is expensive and unfortunately my RH tank decides to empty itself via the air vent / drain whenever it is either full or it gets hot. Our guess is that the air vent tube doesn't reach the top of the tank, hence the pressure builds up and vents the fuel (If you open the filler there is a gush of released air pressure). The LH tank behaves itself. I don't want to remove the tank as I am flying - If I drill a 16" vent in the filler cap of this problematic QB tank, will the tank empty due to venturi in-flight - or is this the best solution ? Any remedies to save my fuel bill - much appreciated. Rgds, Nic ________________________________________________________________________________
Date: Jul 17, 2006
The marker beacon antenna works very well in the fiberglass wingtip of my RV8. Dick Martin RV8 N233M the fast one ----- Original Message ----- Sent: Monday, July 17, 2006 12:38 PM > > > Does anyone have any meaningful info on the drag due to the different > marker beacon antenna types (boat vs. sled)? > > - Alan > RV-8 Perpetual Tail Kit > > > ________________________________________________________________________________
Date: Jul 17, 2006
I vote for a loose connection at the bulkhead fitting, That would explain the =BD tank effect. Note that Vans SB to safety wire and tighten internal fittings on 7 and 9 tanks includes the very fitting mentioned. Mike ________________________________________________________________________________
Date: Jul 17, 2006
Denis: Way back when, some of Van's employees most knowledgeable employees participated actively on the list (on their own time) and provided invaluable assistance to the early builders. I'm sure they were discouraged by the signal to noise ratio and gave up. Dick Sipp ----- Original Message ----- Sent: Monday, July 17, 2006 5:43 PM > > My guess is that this was leaked simply because Van's generally dislikes > the RV list. They knew they could jam it up with this crap for at least > a few weeks. > > Sigh. What a great way to spam up the RV list. > > Do not archive. > > > Denis Walsh > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 18, 2006
OOPS, one too many "employees" in the last message. Sorry. ----- Original Message ----- Sent: Monday, July 17, 2006 11:48 PM > > Denis: > > Way back when, some of Van's employees most knowledgeable employees > participated actively on the list (on their own time) and provided > invaluable assistance to the early builders. I'm sure they were > discouraged by the signal to noise ratio and gave up. > > Dick Sipp > > > ----- Original Message ----- > Sent: Monday, July 17, 2006 5:43 PM > > >> >> My guess is that this was leaked simply because Van's generally dislikes >> the RV list. They knew they could jam it up with this crap for at least >> a few weeks. >> >> Sigh. What a great way to spam up the RV list. >> >> Do not archive. >> >> >> Denis Walsh >> >> >> >> >> >> http://www.matronics.com/Navigator?RV-List >> http://wiki.matronics.com >> >> >> >> >> >> >> >> >> >> > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 18, 2006
In a message dated 7/17/2006 4:56:21 P.M. Pacific Daylight Time, garrys(at)tampabay.rr.com writes: I am at the point now where I need to install the parking brake on my RV7A. There are no directions or instructions that I could find as to how or where to install it. What have some of you experienced builders done? =============================== I find mine very useful, but make sure you do the change over to the Viton O-rings and MIL-PRF-83282 fluid while you're at it. My cable is a detent (semi-locking) bowden type and is mounted to the left gear tower. I have the Cleveland Brand Parking Brake Valve and use it all the time. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 17, 2006
On my new panel conversion, I added a bent whip for a second comm, a boat type marker beacon antenna in my RV-4. No change in cruise performance. Nothing measurable, anyway. Go to www.mykitlog.com/pbesing and you can see the antenna placements. Paul Besing --- dick martin wrote: > > > The marker beacon antenna works very well in the > fiberglass wingtip of my > RV8. > Dick Martin > RV8 N233M > the fast one > ----- Original Message ----- > Sent: Monday, July 17, 2006 12:38 PM > > > alan(at)reichertech.com > > > > > > Does anyone have any meaningful info on the drag > due to the different > > marker beacon antenna types (boat vs. sled)? > > > > - Alan > > RV-8 Perpetual Tail Kit > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Date: Jul 17, 2006
Gary, I mounted mine about 4" to 5" directly above the standard location for the flex lines to the brake pedals. Because it was a retro fit I made up two short extensions with aluminums tubing and AN fittings. the mount for the park brake took some thinking but worked out fine. There is an issue with the positioning of the actuating arm on the unit. Mine came from Van's without paper work of any kind and it took a bit research to find out the precise brake on and brake off positioning of it for the best functioning hook-up. There where quite a few emails on the list about it during that time so the archives do have the info. I no longer have the info on hand However I'm sure someone will be happy to come forward with the right info. I like the idea of having the feature and I have had the occasion to use it twice now while moving the as yet un-flown aircraft. Lots of luck, Jim in Kelowna - it'll fly soon ----- Original Message ----- Sent: Monday, July 17, 2006 4:52 PM > > I am at the point now where I need to install the parking brake on my > RV7A. There are no directions or instructions that I could find as to how > or where to install it. What have some of you experienced builders done? > Or......should I just forget about installing it altogether since I'm now > doubting whether I really need it. Comments? > > Garry Stout > RV7A, Odessa Florida > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 18, 2006
Is that true or indicated? MPH or Knots? Degrees F or C? >From: LessDragProd(at)aol.com >Of course, there is always the temperature rise due to >compressibility. > >I'm surprised some of the technocrats haven't jumped >in on this. At 200 mph, it should be about 3 degrees >at the stagnation point. Or 90% of that in the boundary >layer. --------------------------------- ________________________________________________________________________________
Date: Jul 18, 2006
Subject: Parking Brake Location
Hi Gary, How's the build going? I bought a parking brake unit but decided to not use it. There seems to be no consensus on where. I think Dan Checkoways RV7 project on his web site shows how he did it. It required a small bracket that is riveted to the fire wall. It provided space to bolt it and provide room for the actuator to function.. I'm doing the FWF on my "9". I bought Vettermans mufflers instead of straight pipes. Take a look at my web site on my progress. http://websites.expercraft.com/jimn . I made a rig to move my airplane to the airport using the Chinese trailer. The trailer is 4' x 8' and rated at 1000#. Since I'll not have the wings or tail feathers on, it should take it OK. I'll also use it to get out of Dodge if a hurricane comes our way and its not flying yet, I'm not going to let it get scrunched. I got a place in Tenn. that I can put it if I have to. Just trying to be prepared. It would be a slow trip but at least my labor would be covered. Jim Nelson RV9-A FWF ________________________________________________________________________________
Date: Jul 18, 2006
Put it right where the current brake bracket is mounted. In this way, your brake lines will be the same as the drawings show and won't require any new, or more lines. Remove the bracket, and install one of your own design. It won't take you long to make a new bracket. Jekyll Read this topic online here: http://forums.matronics.com/viewtopic.php?p=48218#48218 ________________________________________________________________________________
Date: Jul 18, 2006
Subject: Re: Anti-Aviation bill in Florida
I wrote this on the rv7 list, but it's not an airplane until the FAA says it is. Until then it's just a pile of metal. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=48237#48237 ________________________________________________________________________________
Date: Jul 18, 2006
I was thinking the same thing about upsetting the neighbor thing. Got to get a hoot of this though. If the the guy wants to push it they really can't do anything. Like I said it's not an airplane until the FAA says so. Then if they change it to read that you can't build or modify anything on your premise, than you can't build any car ports or anything of the likeing, even fix your dish washer. It is amazing how someone that is called a mayor can think he can be a hitler. Just my thoughts. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=48260#48260 ________________________________________________________________________________
Date: Jul 18, 2006
Subject: X-C Tool Kit
I am preparing an emergency tool kit to be carried on trips and seeking ideas on the most efficient tools (and spares) to stow on board. Naturally, I want the kit to be light yet as comprehensive as possible. While no emergency tool kit can cover every possible contingency, what do seasoned overnight X-country RV'ers among us find to be especially useful for common field repairs? For instance, rather than carrying a common pair of pliers as is supplied with my Axle Jack, I prefer to tote a small pair of vice grips as this tool seems to offer more utility for roughly the same amount of weight penalty. Ideas? Rick Galati RV-6A "Darla" 153 hours ________________________________________________________________________________
Date: Jul 18, 2006
Before anybody gets riled up, I would like to hear how the guy fired everybody up first. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=48282#48282 ________________________________________________________________________________
Date: Jul 18, 2006
Subject: Re: X-C Tool Kit
Note that XC can be the airport 45 minutes away. So consider if a flat there is worth carrying things or will you want someone to drive there to get you. Main tire and tube Nose tire and tube Appropriate tools to get to main and nose tires to replace tube Extra valve stem cores and long removal tool (from NAPA) Extra gas cap Assortment of screws, washers, etc Appropriate tools to remove cowl and typical nuts/bolts Duct tape Tube repair kit Tube inflation device (electric or manual) There is more but this is a start. Some have laughed at my carriage of these items on even local flights yet I have helped others on two or three occasions. Ron Lee ________________________________________________________________________________
Date: Jul 18, 2006
We should hear both sides of the story - but we should NOT allow our governments to treat us like this! ________________________________________________________________________________
Date: Jul 18, 2006
Subject: Landing Gear Bolts
Hi there, Going through and finishing up stuff on my -8. Since I borrow a torque wrench, tightening the gear bolts had to wait. Now the problem! I have the wiring in my gear towers as well as the fuel vent line directly over the aft bolt (NAS 6206-27/ NAS679A6 nut). Yeah, excellent planning- I know. Any ideas on getting those aft nuts- anything at all, strange combinations that involve forging my own tools.........I'm stuck. Thanks, John #80002 PS If the answer involves MOGAS, AOA, or "my things bigger than yours", I'm not listening. Ha, ha ________________________________________________________________________________
Date: Jul 18, 2006
Kitfoxmike, It doesn't matter since they are not restricting him, they are wanting to restrict everybody. I would suggest someone has more history than a sing le incident. This can't be allowed to happen. Tim -------Original Message------- Before anybody gets riled up, I would like to hear how the guy fired everybody up first. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=48282#48282 ========================= ========== ========================= ========== ========================= ========== ========================= ========== ________________________________________________________________________________
From: =?iso-8859-1?Q?Mich=E8le_MS?= <michele.delsol(at)microsigma.fr>
Date: Jul 18, 2006
Might be overkill but I've been considering adding a spare starter and starter relay (I'll have a Skytech). As for the main contactor, I am planning on having a contactor override just in case the main contactor fails. Engine is a TMX-IO360 - I don't fancy hand proping it. Michele RV8 - Fuselage -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee Sent: mardi 18 juillet 2006 19:27 Note that XC can be the airport 45 minutes away. So consider if a flat there is worth carrying things or will you want someone to drive there to get you. Main tire and tube Nose tire and tube Appropriate tools to get to main and nose tires to replace tube Extra valve stem cores and long removal tool (from NAPA) Extra gas cap Assortment of screws, washers, etc Appropriate tools to remove cowl and typical nuts/bolts Duct tape Tube repair kit Tube inflation device (electric or manual) There is more but this is a start. Some have laughed at my carriage of these items on even local flights yet I have helped others on two or three occasions. Ron Lee ________________________________________________________________________________
Date: Jul 18, 2006
It would be reasonable for a city to limit what is done in semi- public (visible from the street) places. My city, for instance, requires people to do things like cut their grass and keep their garbage cans out of sight (except as required for pickup). It would be reasonable for the city to prevent folks from running a car repair business (or any business that generates traffic) in a residential area. It would also be reasonable to limit any construction-like activities in a residential area when those activities can produce an eyesore or violate some sort of noise restrictions. Consider how you would like to live next door to a guy who does auto body work until a couple hours past your bedtime, for instance. Even if it's not for a living -- he builds hot rods or something, and he's always running a sand blaster late. Or whatever hot rod guys do. Or if the guy keeps a couple of crappy junkers parked in his front yard. But... if it's in your basement or a contained garage with suitable noise insulation if required, you don't care. And the city shouldn't care. I think there's more going on here than we know about. I suspect the city has been having a variety of problems. City council may be receiving all sorts of complaints all over the city. Maybe this builder's carport is just outside the complaining woman's bedroom window, and he's using caustic materials, which the wind happily wafts right into her house. I wouldn't want to be living next to that -- an activity that the guy wears a respirator for, but his noxious gases are floating into my house. That would annoy me to no end, actually, and I'd find a way to stop it. Or maybe it's not this guy doing it, but some of the other guys in town. We just don't know. If we don't want to see this kind of rule making all over, it's to our benefit to make sure that our hobby doesn't negatively impact anyone else. -Joe On Jul 18, 2006, at 2:06 PM, Tim Bryan wrote: > Kitfoxmike, > > It doesn't matter since they are not restricting him, they are > wanting to restrict everybody. I would suggest someone has more > history than a single incident. This can't be allowed to happen. > > Tim > > -------Original Message------- > > From: kitfoxmike > Date: 07/18/06 10:31:26 > To: rv-list(at)matronics.com > Subject: RV-List: Re: Anti-Aviation bill in Florida > > > Before anybody gets riled up, I would like to hear how the guy > fired everybody up first. > > -------- > kitfoxmike > kitfox4 1200 912ul speedster > http://www.frappr.com/kitfoxmike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=48282#48282 > > > ====================================== he RV-List Email Forum - > http://www.matronics.com/Navigator?RV-List > ====================================== sp; - NEW MATRONICS LIST > WIKI - nics.com ====================================== sp; - List > Contribution Web Site - sp; -Matt Dralle, List > Admin. //www.matronics.com/contribution > ===================================== > > ________________________________________________________________________________
Date: Jul 18, 2006
Dan Checkoway posted a real reasonable tool kit to carry on his website. It might be a good place to start. I've had good luck getting help from pilots on the field when I've had problems, but you can't count on it... ________________________________________________________________________________
Date: Jul 18, 2006
I maintain the tool kit for a formation group I fly with. Our kit is pretty comprehensive (and heavy), but here are the items I've used most often this year, roughly in order. 1. safety wire 2. #2 phillips screwdriver (a good multi-bit driver would be fine) 3. wrench sizes common for our airplanes (Navions) -- 3/8, 7/16, 1/2, & 9/6 4. needle-nose pliers; I also use safety wire pliers a lot (see item 1) 5. telescoping magnet (for retrieving dropped parts) 6. inspection mirror 7. right-angle ratcheting screwdriver (MAC tools -- incredibly useful) 8. bits for item 7 (can be combined with item 2) 9. multi-meter and cables Tedd McHenry Surrey, BC, Canada ________________________________________________________________________________
Date: Jul 18, 2006
Subject: .020 tail feathers from .016
Howdy, Our 6-a (O-320, Sensenich) suffered tail feather damage at the hands of a drunk (we assume) who wasn't watching where he was going Saturday night at Shelter Cove, CA. Beautiful place, no security. I'm fixing to build new elevators and rudder and am looking at using .020 skins in place of the, rather easily damaged, .016 skins. Has anybody out there switched skin thickness and how did it affect your CG? Van's tells me that it's 6 pounds heavier which seems like a lot that far aft. This is the non-counter balanced rudder. I'm wondering if the 6 pound figure includes the counterbalance on the later model rudder. It seems like a lot for .004 worth of sheet metal on the 3 surfaces. Pax, Ed Holyoke ________________________________________________________________________________
Date: Jul 18, 2006
If I can't get a wrench/socket on the nut, I've wedged a chisel or wrench or whatever in-between a flat on the nut and the weldment to prevent the nut from turning. Then the bolt is torqued from below. Not ideal, but... - Larry Bowen. RV-8, 201 Hrs. Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: John Porter [mailto:december29(at)bellsouth.net] > Sent: Tuesday, July 18, 2006 2:17 PM > To: rv-list(at)matronics.com > Subject: RV-List: Landing Gear Bolts > > > > Hi there, > Going through and finishing up stuff on my -8. Since I > borrow a torque wrench, tightening the gear bolts had to > wait. Now the problem! I have the wiring in my gear towers > as well as the fuel vent line directly over the aft bolt (NAS > 6206-27/ NAS679A6 nut). Yeah, excellent planning- I know. > Any ideas on getting those aft nuts- anything at all, strange > combinations that involve forging my own tools.........I'm stuck. > > Thanks, > > John > #80002 > > PS If the answer involves MOGAS, AOA, or "my things bigger > than yours", I'm not listening. Ha, ha > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 19, 2006
I changed from 0.016 to 0.025 on the elevators 8 years ago after pushing my airplane into a pole. I found NO weight difference. Yes the airplane weighted 8 pounds more after painting (weighed on calibrated scales) and the elevators but I do not know how much of the 8 pounds was just to the elevators. I assumed it was all paint. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,894 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- Howdy, Our 6-a (O-320, Sensenich) suffered tail feather damage at the hands of a drunk (we assume) who wasn't watching where he was going Saturday night at Shelter Cove, CA. Beautiful place, no security. I'm fixing to build new elevators and rudder and am looking at using .020 skins in place of the, rather easily damaged, .016 skins. Has anybody out there switched skin thickness and how did it affect your CG? Van's tells me that it's 6 pounds heavier which seems like a lot that far aft. This is the non-counter balanced rudder. I'm wondering if the 6 pound figure includes the counterbalance on the later model rudder. It seems like a lot for .004 worth of sheet metal on the 3 surfaces. Pax, Ed Holyoke ________________________________________________________________________________
Date: Jul 18, 2006
Subject: Re: Landing Gear Bolts
Larry, You know that will work! Didn't even think about it. I will let you know how it worked. Thanks, John ----- Original Message ----- Sent: Tuesday, July 18, 2006 10:16 PM > > If I can't get a wrench/socket on the nut, I've wedged a chisel or wrench > or > whatever in-between a flat on the nut and the weldment to prevent the nut > from turning. Then the bolt is torqued from below. Not ideal, but... > > - > Larry Bowen. RV-8, 201 Hrs. > Larry(at)BowenAero.com > http://BowenAero.com > > >> -----Original Message----- >> From: John Porter [mailto:december29(at)bellsouth.net] >> Sent: Tuesday, July 18, 2006 2:17 PM >> To: rv-list(at)matronics.com >> Subject: RV-List: Landing Gear Bolts >> >> >> >> Hi there, >> Going through and finishing up stuff on my -8. Since I >> borrow a torque wrench, tightening the gear bolts had to >> wait. Now the problem! I have the wiring in my gear towers >> as well as the fuel vent line directly over the aft bolt (NAS >> 6206-27/ NAS679A6 nut). Yeah, excellent planning- I know. >> Any ideas on getting those aft nuts- anything at all, strange >> combinations that involve forging my own tools.........I'm stuck. >> >> Thanks, >> >> John >> #80002 >> >> PS If the answer involves MOGAS, AOA, or "my things bigger >> than yours", I'm not listening. Ha, ha >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
From: "Richard E. Tasker" <retasker(at)optonline.net>
Date: Jul 19, 2006
Subject: Re: .020 tail feathers from .016
Six pounds seems reasonably likely for the change in thickness. Since aluminum weighs approximately 0.0955 lbs/cu. in. and you are adding 0.004" all over the elevator and rudder it follows that the tail surface area would calculate to be 15,700 sq. in. or 109 sq. ft. (6 lbs / 0.0955 lbs/cu / 0.004" = 15707 sq. in.) which certainly seems to be in the ball park. Dick Tasker Ed Holyoke wrote: > > >Howdy, > >Our 6-a (O-320, Sensenich) suffered tail feather damage at the hands of >a drunk (we assume) who wasn't watching where he was going Saturday >night at Shelter Cove, CA. Beautiful place, no security. I'm fixing to >build new elevators and rudder and am looking at using .020 skins in >place of the, rather easily damaged, .016 skins. Has anybody out there >switched skin thickness and how did it affect your CG? Van's tells me >that it's 6 pounds heavier which seems like a lot that far aft. This is >the non-counter balanced rudder. I'm wondering if the 6 pound figure >includes the counterbalance on the later model rudder. It seems like a >lot for .004 worth of sheet metal on the 3 surfaces. > >Pax, > >Ed Holyoke > > > > > > > > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Jul 19, 2006
Doing a quick square measurement of my -9 rudder and elevators ( not taking in consideration the Rudder taper or counter weight arms) I come up with 6678 sq inches. (Rudder 53" X 27" X 2 surfaces = 2862 sq. in., Elevators 17" X 56" X 4 surfaces = 3808 sq. in. total 6678 sq. in. If you throw in another 322 sq. in. for good measure and rounding off the total to 7000 sq. in., and using .0955 lbs/cu. in. you would come up with 2.674 lb. ( 2.674 / 0.0955 lbs/cu. in./0.004" = 7000 sq. in. or 48.61 sq. ft. ) Of course the increase in rivet length might bring the weight up slightly. YMMV Bob Perkinson Hendersonville, TN. RV9 N658RP Reserved If nothing changes Nothing changes Six pounds seems reasonably likely for the change in thickness. Since aluminum weighs approximately 0.0955 lbs/cu. in. and you are adding 0.004" all over the elevator and rudder it follows that the tail surface area would calculate to be 15,700 sq. in. or 109 sq. ft. (6 lbs / 0.0955 lbs/cu / 0.004" = 15707 sq. in.) which certainly seems to be in the ball park. Dick Tasker Ed Holyoke wrote: > > >Howdy, > >Our 6-a (O-320, Sensenich) suffered tail feather damage at the hands of >a drunk (we assume) who wasn't watching where he was going Saturday >night at Shelter Cove, CA. Beautiful place, no security. I'm fixing to >build new elevators and rudder and am looking at using .020 skins in >place of the, rather easily damaged, .016 skins. Has anybody out there >switched skin thickness and how did it affect your CG? Van's tells me >that it's 6 pounds heavier which seems like a lot that far aft. This is >the non-counter balanced rudder. I'm wondering if the 6 pound figure >includes the counterbalance on the later model rudder. It seems like a >lot for .004 worth of sheet metal on the 3 surfaces. > >Pax, > >Ed Holyoke > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Jul 18, 2006
On 21:36:56 2006-07-18 "Richard E. Tasker" wrote: > Six pounds seems reasonably likely for the change in thickness. > Since aluminum weighs approximately 0.0955 lbs/cu. in. and you are > adding 0.004" all over the elevator and rudder it follows that the > tail surface area would calculate to be 15,700 sq. in. or 109 sq. ft. > (6 lbs / 0.0955 lbs/cu / 0.004" = 15707 sq. in.) which certainly > seems to be in the ball park. 109 square feet for the elevator and rudder sounds quite high to me. You've got about 10' of span, times about 1' of chord (average) times two surfaces = 20 square feet of area for both sides of the elevator. Half again for the rudder would be about 30 square feet total. So using your numbers above, you should be looking at something under 2 lb. -Rob ________________________________________________________________________________
Date: Jul 18, 2006
On 22:37:04 2006-07-18 "Bob Perkinson" wrote: > Of course the increase in rivet > length might bring the weight up slightly. YMMV I just about said that too... But you included the increase as a uniform increase across all the surfaces, so the increase in rivet length is already included (if you assume the density of the rivets is comparable to the density of the skins, which is reasonable in this case). -Rob ________________________________________________________________________________
Date: Jul 19, 2006
Subject: What have you had to fix on the road? Was XC toolkit.
Given the space constraints in the planes we fly a comprehensive set of tools/parts is prohibitive. I havve seen many "lists of tools and parts but never a comprehensive list of problems encountered while travelling which seems to me would be a good guide for building a tool/parts kit. In the last 10 years I have had to replace a boost pump and solenoid along with a few screws. Most of the time I obtained unsolicited help from local airport guys and the balance of my tools came from a local auto supply and hardware store. The newly purchased tools I left with the airport. An F1 has absolutely no baggage space to spare. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=48504#48504 ________________________________________________________________________________
Date: Jul 19, 2006
Subject: Re: What have you had to fix on the road? Was XC
Flat tire (needed tube replacement) Lost fuel cap (failure to verify line boy latching of cap) Note: these are other pilot cases. Ron Lee ________________________________________________________________________________
Date: Jul 19, 2006
I think if this guy is truely in need the aircaft community should ban together and get both EAA and AOPA involved. Spreading the problem throughout the country with the news media sounds appropriate as well. Letters to our representatives might be in order as well. sounds to me like this is total BS. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=48522#48522 ________________________________________________________________________________
Date: Jul 19, 2006
I had the same problem on my 8. I ended up grinding off one side of a cheap socket so it will fit over the forward nuts in the tower. For the aft nuts I fabricated a spacer form .250 stock that will just fit between the weldment and the flat of the nut keeping it from turning. Then It's torqued form below. I tried various screwdrivers and tools to jam the nut against the weldment but the gap was too big for any tools I tried, and not big enough for a socket to fit. I know, not ideal to torque from the bottom, but the only option I had. The "trick" with the spacer is getting it into position (and out) by brail. My two cents worth. Steve Struyk RV-8 50 hrs. ----- Original Message ----- Sent: Tuesday, July 18, 2006 9:16 PM > > If I can't get a wrench/socket on the nut, I've wedged a chisel or wrench > or > whatever in-between a flat on the nut and the weldment to prevent the nut > from turning. Then the bolt is torqued from below. Not ideal, but... > > - > Larry Bowen. RV-8, 201 Hrs. > Larry(at)BowenAero.com > http://BowenAero.com > > >> -----Original Message----- >> From: John Porter [mailto:december29(at)bellsouth.net] >> Sent: Tuesday, July 18, 2006 2:17 PM >> To: rv-list(at)matronics.com >> Subject: RV-List: Landing Gear Bolts >> >> >> >> Hi there, >> Going through and finishing up stuff on my -8. Since I >> borrow a torque wrench, tightening the gear bolts had to >> wait. Now the problem! I have the wiring in my gear towers >> as well as the fuel vent line directly over the aft bolt (NAS >> 6206-27/ NAS679A6 nut). Yeah, excellent planning- I know. >> Any ideas on getting those aft nuts- anything at all, strange >> combinations that involve forging my own tools.........I'm stuck. >> >> Thanks, >> >> John >> #80002 >> >> PS If the answer involves MOGAS, AOA, or "my things bigger >> than yours", I'm not listening. Ha, ha >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
From: "Delamarter, Jon" <JDelamarter(at)lycoming.textron.com>
Date: Jul 19, 2006
I thought you guys might be interested in the email I sent this morning to the President and Vice President of the Jacksonville City Council. I know it's long, but I hope it will be effective. Gentlemen: Due to the diligence of my fellow aviators, it has come to my attention that the City of Jacksonville, FL has recently enacted Sec. 656.420 amending Chapter 656 of the zoning code. It is my belief that this amendment will limit or eliminate the rights of citizens within the constraints of this code from pursuing activities which are neither commercial in nature nor threatening in anyway to the citizens of Jacksonville. I would encourage the members of your counsel to contact the Experimental Aircraft Association (www.eaa.org <http://www.eaa.org> ) for an eye-opening overview of the scope and importance of our sport. We have approximately 900 chapters nation-wide, approximately 1000 chapters worldwide, and represent the largest organization of our type in existence. Through our programs, we fund and administer programs which enrich the lives of America and the world. Through our Young Eagles program alone, we have introduced the wonder of flight to well over a million young Americans. These flights were provided at absolutely no cost to the community. Time, equipment, and expenses are paid for by our membership. Oh by the way, you may have heard of the president of our Young Eagles organization. His name is Harrison Ford. When several hundred thousand of us aviation-minded citizens get together next week for our annual gathering in Oshkosh, Wisconsin, our presence will turn this normally average airport into the busiest airport in the world for an entire week. Chuck Yeager, Bud Anderson, and many other veteran heroes are regular attendees. Last year, Spaceship One stopped at our Oshkosh gathering for it's only public appearance on it's way to the Smithsonian. By the way, the folks who designed, built, and flew the Voyager (first non-stop flight around the world), Spaceship One (first civilian space flight), and the Global Flyer (first solo non-stop flight around the world) are all EAA members and active participants in aircraft homebuilding activities. Our ranks include Hollywood movie stars, congressmen, and normal folks from all walks of life. Incidentally, the very first homebuilders were a couple of bicycle mechanics from Dayton, Ohio named Orville and Wilbur Wright. I shudder to think what the outcome would have been if these American heroes had been residents of Jacksonville, FL. The next time you or your counsel members board an aircraft of any type on official business or otherwise, I hope you will remember that you are able to do so only because of the type of entrepreneurial American spirit you are currently trying to regulate out of existence. Aviators in general and homebuilders specifically represent the absolute peak of American ingenuity and citizenship. I believe it would be worth your while to break away from your duties in Jacksonville for a day or two and join us in our annual celebration next week in Oshkosh. Lodging is impossible to get in Oshkosh at this late date, however, if you would like to attend, I will personally assure your accommodation and admission. As a Florida native, it is my sincere hope that you will do the right thing and rethink the county's position in this important matter. Florida is one of the most active homebuilding states in the Union; the majority of these folks are retirees. A large percentage are war veterans. I believe with all my heart that if you and your council members will truly understand the nature of aircraft homebuilding and the integrity of it's participants, you will welcome and encourage it's activity in your city. Sincerely, Jon A. Delamarter Thunderbolt Manager Lycoming Engines I also thought some of you might care to join me in voicing your protest. Here is their contact info. Michael L. Corrigan, Jr., President Jacksonville City Council 117 West Duval St., Suite 425 Jacksonville, FL 32202 (904) 630-1390 Corrigan(at)coj.net Daniel J. Davis, Vice President Jacksonville City Council 117 West Duval St., Suite 425 Jacksonville, FL 32202 (904) 630-1380 DDavis(at)coj.net NOTICE: This E-mail (including attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. 2510-2521, is confidential and may be legally privileged. If you are not the intended recipient, you are hereby notified that any retention, dissemination, distribution, or copying of this communication is strictly prohibited. Please reply to the sender that you have received the message in error, then delete it. Thank you. ________________________________________________________________________________
Date: Jul 19, 2006
EXCELLENT! Well put, non-abrasive and thus most effective in getting the message across. I think we could all benefit from copying with your permission, this letter and use it as the basis for such letters in the future if needed in our localities. Is such permitted? James ... from Florida On 7/19/06, Delamarter, Jon wrote: > > JDelamarter(at)lycoming.textron.com> > > I thought you guys might be interested in the email I sent this morning t o > the President and Vice President of the Jacksonville City Council. I kno w > it's long, but I hope it will be effective. > Gentlemen: > Due to the diligence of my fellow aviators, it has come to my attention > that > the City of Jacksonville, FL has recently enacted Sec. 656.420 amending > Chapter 656 of the zoning code. It is my belief that this amendment will > limit or eliminate the rights of citizens within the constraints of this > code from pursuing activities which are neither commercial in nature nor > threatening in anyway to the citizens of Jacksonville. I would encourage > the members of your counsel to contact the Experimental Aircraft > Association > (www.eaa.org <http://www.eaa.org> ) for an eye-opening overview of the > scope > and importance of our sport. We have approximately 900 chapters > nation-wide, approximately 1000 chapters worldwide, and represent the > largest organization of our type in existence. Through our programs, we > fund and administer programs which enrich the lives of America and the > world. Through our Young Eagles program alone, we have introduced the > wonder of flight to well over a million young Americans. These flights > were > provided at absolutely no cost to the community. Time, equipment, and > expenses are paid for by our membership. Oh by the way, you may have > heard > of the president of our Young Eagles organization. His name is Harrison > Ford. When several hundred thousand of us aviation-minded citizens get > together next week for our annual gathering in Oshkosh, Wisconsin, our > presence will turn this normally average airport into the busiest airport > in > the world for an entire week. Chuck Yeager, Bud Anderson, and many other > veteran heroes are regular attendees. Last year, Spaceship One stopped a t > our Oshkosh gathering for it's only public appearance on it's way to the > Smithsonian. By the way, the folks who designed, built, and flew the > Voyager (first non-stop flight around the world), Spaceship One (first > civilian space flight), and the Global Flyer (first solo non-stop flight > around the world) are all EAA members and active participants in aircraft > homebuilding activities. Our ranks include Hollywood movie stars, > congressmen, and normal folks from all walks of life. Incidentally, the > very first homebuilders were a couple of bicycle mechanics from Dayton, > Ohio > named Orville and Wilbur Wright. I shudder to think what the outcome > would > have been if these American heroes had been residents of Jacksonville, FL . > The next time you or your counsel members board an aircraft of any type o n > official business or otherwise, I hope you will remember that you are abl e > to do so only because of the type of entrepreneurial American spirit you > are > currently trying to regulate out of existence. > Aviators in general and homebuilders specifically represent the absolute > peak of American ingenuity and citizenship. I believe it would be worth > your while to break away from your duties in Jacksonville for a day or tw o > and join us in our annual celebration next week in Oshkosh. Lodging is > impossible to get in Oshkosh at this late date, however, if you would lik e > to attend, I will personally assure your accommodation and admission. As > a > Florida native, it is my sincere hope that you will do the right thing an d > rethink the county's position in this important matter. Florida is one o f > the most active homebuilding states in the Union; the majority of these > folks are retirees. A large percentage are war veterans. I believe with > all my heart that if you and your council members will truly understand > the > nature of aircraft homebuilding and the integrity of it's participants, > you > will welcome and encourage it's activity in your city. > Sincerely, > Jon A. Delamarter > Thunderbolt Manager > Lycoming Engines > > > I also thought some of you might care to join me in voicing your protest. > Here is their contact info. > > Michael L. Corrigan, Jr., > President > Jacksonville City Council > 117 West Duval St., Suite 425 > Jacksonville, FL 32202 > (904) 630-1390 > Corrigan(at)coj.net > Daniel J. Davis, > Vice President > Jacksonville City Council > 117 West Duval St., Suite 425 > Jacksonville, FL 32202 > (904) 630-1380 > DDavis(at)coj.net > > NOTICE: This E-mail (including attachments) is covered by the Electronic > Communications Privacy Act, 18 U.S.C. =A7=A7 2510-2521, is confidential and > may > be legally privileged. If you are not the intended recipient, you are > hereby notified that any retention, dissemination, distribution, or > copying > of this communication is strictly prohibited. Please reply to the sender > that you have received the message in error, then delete it. Thank you. > > ========================= =========== ========================= =========== ========================= =========== ========================= =========== > > -- This is an alternate email. Please continue to email me at james(at)nextupventures.com . ________________________________________________________________________________
Date: Jul 19, 2006
I think the AOPA should be doing something too! Aircraft Owners is the 1st part of their Name doesn't say production aircraft owners.. > > BTW, AOPA says there is nothing they can do. Yet to hear from the EAA > ________________________________________________________________________________
Date: Jul 19, 2006
I'm not sure where I got the idea, probably here. You can buy metal locking nuts at ACS that go on the RV8 gear legs and have much smaller heads, which allow you to easily get a socket on. I thought I had some pics on my website, but I can't find them. -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Jul 19, 2006
Here is part of an email from Dan Horton. This information was emailed out to the Pitts Model 12 group. "First call received was from Councilman Ray's executive assistant. We had a nice conversation. As suspected, the ordinance is the result of a protracted problem with a single individual, a Mr. Kraut of Mayapple Rd in Jacksonville. I did not debate the wisdom of a sweeping ordinance to address a single idiot. My goal was to gather information and get a handle on the feelings behind the actions. My impression is that Mr. Kraut has handed aircraft builders an uphill battle. Second call was mine, to Randy Hansen at EAA HQ. I've passed along all I know about the problem. Randy was already aware of the issue. A member of EAA's Legal Advisory Council has volunteered to take up the matter with the City Attorney, and will report, in person, at Oshkosh next week. Any action taken will be after the Convention." I agree with Dan that we should, at this point, rely on our member organizations to act on our behalf. Quick wit and tongue might do nothing but exacerbate the situation. Rhonda Barrett-Bewley Barrett Precision Engines, Inc. 2870-B N. Sheridan Rd. Tulsa,OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sportypilot Sent: Wednesday, July 19, 2006 12:55 PM I think the AOPA should be doing something too! Aircraft Owners is the 1st part of their Name doesn't say production aircraft owners.. > > BTW, AOPA says there is nothing they can do. Yet to hear from the EAA > ________________________________________________________________________________
Date: Jul 19, 2006
I wouldn't rely entirely on our member organizations to do the job for us, although I hope they help in whatever way they can. Respectful individual comments can certainly do no harm, and just might do a whole lot of good. I would encourage every homebuilder to submit a comment to Corrigan(at)coj.net. The next town could be yours. Following is a copy of my email submitted to Mr. Corrigan, President of the Jacksonville City Council... Dear Sir, The recent amendment 656.420 to the Jacksonville zoning code infringes upon and severely restricts the rights of your citizens, many of whom are aircraft homebuilders. This is the equivalent of forbidding the restoration of a vintage automobile or any other object or conveyance on personal property. Many activities of this nature can be done without impinging on anyone else's rights or causing any nuisance to others. It is apparent that this amendment was poorly thought out with regard to the consequences it has on the rights of your citizens (and future citizens). I would appeal to you to strike this ill-conceived amendment from your zoning code and replace it with one that does not deny fundamental AMERICAN LIBERTY. Respectfully, Kenneth Howell Glenwood Maryland -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Rhonda Bewley Sent: Wednesday, July 19, 2006 3:00 PM Here is part of an email from Dan Horton. This information was emailed out to the Pitts Model 12 group. "First call received was from Councilman Ray's executive assistant. We had a nice conversation. As suspected, the ordinance is the result of a protracted problem with a single individual, a Mr. Kraut of Mayapple Rd in Jacksonville. I did not debate the wisdom of a sweeping ordinance to address a single idiot. My goal was to gather information and get a handle on the feelings behind the actions. My impression is that Mr. Kraut has handed aircraft builders an uphill battle. Second call was mine, to Randy Hansen at EAA HQ. I've passed along all I know about the problem. Randy was already aware of the issue. A member of EAA's Legal Advisory Council has volunteered to take up the matter with the City Attorney, and will report, in person, at Oshkosh next week. Any action taken will be after the Convention." I agree with Dan that we should, at this point, rely on our member organizations to act on our behalf. Quick wit and tongue might do nothing but exacerbate the situation. Rhonda Barrett-Bewley Barrett Precision Engines, Inc. 2870-B N. Sheridan Rd. Tulsa,OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sportypilot Sent: Wednesday, July 19, 2006 12:55 PM I think the AOPA should be doing something too! Aircraft Owners is the 1st part of their Name doesn't say production aircraft owners.. > > BTW, AOPA says there is nothing they can do. Yet to hear from the EAA > ________________________________________________________________________________
Date: Jul 19, 2006
Subject: Re: Connecting Blue Mountain EFIS lite to Pictorial Pilot
For those of you who may be following this thread (maybe three people in the Western Hemisphere) let me update what I have learned. In a phone conversation today with Larry, BMA Technican, he confirmed that the Serial Port B sends out no data when it is selected/activated. He tried several different units with the same result. He thinks it might be a software problem. This confirms my own observation. When I connected my laptop PC to the G3 Lite serial output cable there was no data stream coming from the G3, therefore there was nothing for the TruTrak autopilot to lock on to. Because all the BMA folks are off to Oshkosh they said they will work on a fix when they return. I feel good that we may be making some progress. Jim Ellis RV9-A, Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=48633#48633 ________________________________________________________________________________
From: "Jim Pleasants" <jpleasants(at)bellsouth.net>
Date: Jul 19, 2006
FWIW, Unison has a major facility in Jacksonville, and I have seen articles published that indicate that the City government is proud to have them there. Prehaps, if their customers (and potential customers) would encourage Unison, they might be willing to reason with the Mayor and Councilmen. Jim Pleasants ________________________________________________________________________________
Date: Jul 19, 2006
Subject: RV-10 for sale
Fellow Listers: I am posting this note for a friend who has just completed a most beautiful RV-10. I have flown this aircraft about 20 hours and is REALLY nice. Here is the link for more information: http://www.mnwing.org/EldonRV10/index.html Thanks Doug Weiler ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Jul 19, 2006
Subject: Fw: Government Advocacy Homebuilt Ban Jacksonville, Fl.
List, This is the EAA response on the Jacksonville Homebuilt Ban. Tom in Ohio ----- Original Message ----- Sent: Wednesday, July 19, 2006 4:31 PM Tom, EAA is aware of this issue and will be briefed on it during AirVenture, but nothing will be done until all the facts are in and AirVenture is completed. Randy Randy Hansen EAA Government Relations Director 888-322-4636, extension 6522 Mark your 2006 calendar for the World's Greatest Aviation Celebration ... EAA AirVenture Oshkosh ... Monday, July 24th through Sunday, July 30th. http://www.airventure.org/ -----Original Message----- From: Tom & Cathy Ervin [mailto:tcervin(at)valkyrie.net] Sent: Wednesday, July 19, 2006 11:47 AM To: EAA Government Programs Subject: Government Advocacy Homebuilt Ban Jacksonville, Fl. The Jacksonville, Fl. City & County Council has banned Home Building any place including inside your home! The EEA needs to get very aggressive on stopping this intrusion into our hobby. If this ban on Home Building is allowed to stand Ohio will be next! Thomas Ervin # 0602653 ________________________________________________________________________________
Date: Jul 19, 2006
>In a phone conversation today with Larry, BMA Technican, he confirmed >that the Serial Port B sends out no data when it is selected/activated. He >tried several different units with the same result. He thinks it might be >a software problem. > >This confirms my own observation. When I connected my laptop PC to the G3 >Lite serial output cable there was no data stream coming from the G3, >therefore there was nothing for the TruTrak autopilot to lock on to. You probably could have verified this by hooking a voltmeter to the line that should have transmitted the data (ground as appropriate). This was how I verified that I had the right wire out of my Garmin GNS 430 before hooking it to my autopilot. Some of us do not have laptops (or cell phones, or DSL). :) Ron Lee ________________________________________________________________________________
Date: Jul 19, 2006
Subject: Garmin 496
I just received this ad from JA Air Center: JA Air Center, your Garmin source, is pleased to announce the new Garmin GPSmap 496 with XM Weather, Terrain, AOPA Airport Guide, Taxiway Database, and built in StreetPilot Automotive GPS. Limited quantities are in stock and available for immediate delivery. Terry ________________________________________________________________________________
Date: Jul 19, 2006
Subject: Garmin 496
I suspected that we would see something like this last month wen the price came down on the 396. Of course I just bought a 396 about 3 months ago. Arrrgh! Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Terry Watson Sent: Wednesday, July 19, 2006 6:37 PM To: rv-list(at)matronics.com Subject: RV-List: Garmin 496 I just received this ad from JA Air Center: JA Air Center, your Garmin source, is pleased to announce the new Garmin GPSmap 496 with XM Weather, Terrain, AOPA Airport Guide, Taxiway Database, and built in StreetPilot Automotive GPS. Limited quantities are in stock and available for immediate delivery. Terry ________________________________________________________________________________
Date: Jul 19, 2006
Subject: Re: non-swiveling tail wheel
To clarify my post, I find the main pivot itself sticks unless I grease it every 10 hours. I can still move it, but it's very stiff, and when I remove it to grease it, it's dry as a bone. The locking key on the other hand has been fine since the first de-burring repair hundreds of hours ago. Perhaps my problems come from flying off grass almost exclusively. It's been pretty wet here the past couple of summers and I thought the water was washing the grease away. I went though a set of front wheel bearings (rusted) after only 140 hours my first year. But this summer has been dry and I still have to grease the tailwheel. I should give the design it's due: it is an elegant, simple and lightweight mechanism for what it does and seems to give trouble-free use for a lot of people. Curt ________________________________________________________________________________
Date: Jul 19, 2006
Don't forget to retorque after about 50 hours flying time. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=48731#48731 ________________________________________________________________________________
Date: Jul 19, 2006
Subject: Anti-Aviation bill in Florida
Thanks. Very well written. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Delamarter, Jon Sent: Wednesday, July 19, 2006 10:30 AM I thought you guys might be interested in the email I sent this morning to the President and Vice President of the Jacksonville City Council. I know it's long, but I hope it will be effective. Gentlemen: Due to the diligence of my fellow aviators, it has come to my attention that the City of Jacksonville, FL has recently enacted Sec. 656.420 amending Chapter 656 of the zoning code. It is my belief that this amendment will limit or eliminate the rights of citizens within the constraints of this code from pursuing activities which are neither commercial in nature nor threatening in anyway to the citizens of Jacksonville. I would encourage the members of your counsel to contact the Experimental Aircraft Association (www.eaa.org <http://www.eaa.org> ) for an eye-opening overview of the scope and importance of our sport. We have approximately 900 chapters nation-wide, approximately 1000 chapters worldwide, and represent the largest organization of our type in existence. Through our programs, we fund and administer programs which enrich the lives of America and the world. Through our Young Eagles program alone, we have introduced the wonder of flight to well over a million young Americans. These flights were provided at absolutely no cost to the community. Time, equipment, and expenses are paid for by our membership. Oh by the way, you may have heard of the president of our Young Eagles organization. His name is Harrison Ford. When several hundred thousand of us aviation-minded citizens get together next week for our annual gathering in Oshkosh, Wisconsin, our presence will turn this normally average airport into the busiest airport in the world for an entire week. Chuck Yeager, Bud Anderson, and many other veteran heroes are regular attendees. Last year, Spaceship One stopped at our Oshkosh gathering for it's only public appearance on it's way to the Smithsonian. By the way, the folks who designed, built, and flew the Voyager (first non-stop flight around the world), Spaceship One (first civilian space flight), and the Global Flyer (first solo non-stop flight around the world) are all EAA members and active participants in aircraft homebuilding activities. Our ranks include Hollywood movie stars, congressmen, and normal folks from all walks of life. Incidentally, the very first homebuilders were a couple of bicycle mechanics from Dayton, Ohio named Orville and Wilbur Wright. I shudder to think what the outcome would have been if these American heroes had been residents of Jacksonville, FL. The next time you or your counsel members board an aircraft of any type on official business or otherwise, I hope you will remember that you are able to do so only because of the type of entrepreneurial American spirit you are currently trying to regulate out of existence. Aviators in general and homebuilders specifically represent the absolute peak of American ingenuity and citizenship. I believe it would be worth your while to break away from your duties in Jacksonville for a day or two and join us in our annual celebration next week in Oshkosh. Lodging is impossible to get in Oshkosh at this late date, however, if you would like to attend, I will personally assure your accommodation and admission. As a Florida native, it is my sincere hope that you will do the right thing and rethink the county's position in this important matter. Florida is one of the most active homebuilding states in the Union; the majority of these folks are retirees. A large percentage are war veterans. I believe with all my heart that if you and your council members will truly understand the nature of aircraft homebuilding and the integrity of it's participants, you will welcome and encourage it's activity in your city. Sincerely, Jon A. Delamarter Thunderbolt Manager Lycoming Engines I also thought some of you might care to join me in voicing your protest. Here is their contact info. Michael L. Corrigan, Jr., President Jacksonville City Council 117 West Duval St., Suite 425 Jacksonville, FL 32202 (904) 630-1390 Corrigan(at)coj.net Daniel J. Davis, Vice President Jacksonville City Council 117 West Duval St., Suite 425 Jacksonville, FL 32202 (904) 630-1380 DDavis(at)coj.net NOTICE: This E-mail (including attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. 2510-2521, is confidential and may be legally privileged. If you are not the intended recipient, you are hereby notified that any retention, dissemination, distribution, or copying of this communication is strictly prohibited. Please reply to the sender that you have received the message in error, then delete it. Thank you. ________________________________________________________________________________
Date: Jul 19, 2006
Subject: Garmin 496
http://www.garmin.com/products/gpsmap496/ _____ Sent: Wednesday, July 19, 2006 6:37 PM I just received this ad from JA Air Center: JA Air Center, your Garmin source, is pleased to announce the new Garmin GPSmap 496 with XM Weather, Terrain, AOPA Airport Guide, Taxiway Database, and built in StreetPilot Automotive GPS. Limited quantities are in stock and available for immediate delivery. Terry ________________________________________________________________________________
Date: Jul 19, 2006
>"We should hear both sides of the story..." Much as I detest governmental inferference with private property rights, I can just picture it: Carport made from pvc sprinkler pipe and blue plastic Harbor Freight tarps, plywood work table alongside the driveway set up on two rusty 55 gallon oil drums, cheap noisy oil-less air compressor running all day and night, rivet gun ringing, stench of paint fumes sucked into the whole neighborhood's swamp coolers . . . and now over 8 years into the project. It takes a real nuisance to get a city council involved let alone a county board of supervisors. Pete Cowper RV8 #81139 (working on fuselage) Hanger B-5 Visalia Municipal Airport ________________________________________________________________________________
Date: Jul 20, 2006
Hey Brian- In my limited experience with neighborhood busybodies it seems that as much as they try to exert their influence on others, they themselves are not in compliance with the body of rules they are trying to enforce. Also, it sure seems like you have grounds for a harassment suit. I'll zip JAX a short comment in a moment, as well as stop by the Unison booth (and flag down T.P.) if we cross paths at OSH. I would respectfully an sincerely request that you all do the same. If 30, 100, or 1,000 folks grab Tom by the ear next week it might rearrange his priorities a little. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jul 20, 2006
Subject: O-320 E2D For Sale
$10,000 outright recently removed from my 68 Cessna Cardinal for HP upgrade. 3,000 TTSN, 1056 SMOH, 560 STOH, new Cam and bearings and oil pump gears 150 hrs ago for oil pump AD. includes Mags (Slick), vacuume pump, starter and alternator. Compressions were all 80/80 when removed. This is a dry strong running engine. Used 1qt in 13-18 hrs. Price is outright NO core. Have all logs. Contact cowboy286(at)sbcglobal.net ________________________________________________________________________________
Date: Jul 21, 2006
Subject: Gear Socket Gusset for an RV-6 engine mount
Folks, I have purchased the gussets from Vans to re-enforce the landing gear socket of my old style RV-6 mount to prevent the cracking some have experienced. Parts are WD-672A-R and WD-672-L. My plan is to have these welded to the mount but I do not have a clear direction how they are positioned. Can someone point me to a clear photograph of the lower end of a gear leg socket. I believe these are fitted to all RV-6 and -7 mounts currently being shipped. Vans sent me two photos but they are not clear enough to pass to the welder. Thanks, Doug Gray Sydney, Australia ________________________________________________________________________________
Date: Jul 20, 2006
Subject: black screws for instruments
I need a few 8-32 and 4-40 black, round head screws for mounting instruments. Does any one know where I can get these? I can't find any in the Spruce catalog. -- Tom Sargent RV-6A ________________________________________________________________________________
Date: Jul 20, 2006
Subject: Re: black screws for instruments
Tom: Try Wicks. I had no problems finding them there. Regards, Jeff Orear RV6A N782P Peshtigo, WI ----- Original Message ----- Sent: Thursday, July 20, 2006 12:30 PM > > I need a few 8-32 and 4-40 black, round head screws for mounting > instruments. Does any one know where I can get these? I can't find any > in the Spruce catalog. > -- > Tom Sargent > RV-6A > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 20, 2006
You can't get to the part number online at Spruce (went through this just recently). Someone helped me out on this list - try searching the archive. If that doesn't work - let me know I have the part number on an invoice at home which I can get for you tomorrow. g > > > I need a few 8-32 and 4-40 black, round head screws for mounting > instruments. Does any one know where I can get these? I can't > find any > in the Spruce catalog. > -- > Tom Sargent > RV-6A > > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ---------------------------------------------------------- ________________________________________________________________________________
Date: Jul 20, 2006
Subject: Re: RV-10 for sale
Just out of curiousity, how realistic is that asking price? We're getting up into new SR20 range there. Henry H.
Henry H.
Date: Jul 20, 2006
Subject: Re: Garmin 496
So what is your plan??? Or did you purchase a 396 already? James On 7/19/06, Larry Bowen wrote: > > http://www.garmin.com/products/gpsmap496/ > > > ------------------------------ > *From:* Terry Watson [mailto:terry(at)tcwatson.com] > > *Sent:* Wednesday, July 19, 2006 6:37 PM > *To:* rv-list(at)matronics.com > *Subject:* RV-List: Garmin 496 > > I just received this ad from JA Air Center: > > > JA Air Center, your Garmin source, is pleased to announce the new Garmin > GPSmap 496 with XM Weather, Terrain, AOPA Airport Guide, Taxiway Database, > and built in StreetPilot Automotive GPS. > > Limited quantities are in stock and available for immediate delivery. > > > Terry > > -- This is an alternate email. Please continue to email me at james(at)nextupventures.com . ________________________________________________________________________________
Date: Jul 20, 2006
Subject: Garmin 496
I think you were asking Larry -not me- but my plan is to wait awhile. I have a 196 which I like a lot, but I always want the latest and greatest. Aviation Consumer says they are going to do a complete review of the 496 in their September issue. I also see that there are two levels of XM weather subscriptions now, one at $30 a month and another at $50. The $50 one seems to be for higher altitudes than we would typically be interested in. See: http://www.xmradio.com/weather/aviation.html Someone at one of the avionics booths at the Arlington fly-in told me that my wiring for the 196 won't work for the 396 or likely the 496. He said it was a different plug entirely. Terry _____ [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James Clark Sent: Thursday, July 20, 2006 2:25 PM So what is your plan??? Or did you purchase a 396 already? James On 7/19/06, Larry Bowen > wrote: http://www.garmin.com/products/gpsmap496/ _____ Sent: Wednesday, July 19, 2006 6:37 PM I just received this ad from JA Air Center: JA Air Center, your Garmin source, is pleased to announce the new Garmin GPSmap 496 with XM Weather, Terrain, AOPA Airport Guide, Taxiway Database, and built in StreetPilot Automotive GPS. Limited quantities are in stock and available for immediate delivery. Terry -- This is an alternate email. Please continue to email me at james(at)nextupventures.com . ________________________________________________________________________________
Date: Jul 20, 2006
Home Depot, ACE, etc. Unless you have to worry about ferrous metals, of course. I used SS ones and had no issues with magnetic interference. The brass ones are very soft too, and the paint comes off easily.. Paul Besing --- sarg314 wrote: > > > I need a few 8-32 and 4-40 black, round head screws > for mounting > instruments. Does any one know where I can get > these? I can't find any > in the Spruce catalog. > -- > Tom Sargent > RV-6A > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Date: Jul 20, 2006
Subject: XM WX
I have the $30 subscription for XM weather right now. It's fine, but the $50 one would be nice mainly for the winds aloft information. It is available on the 396, it's not just a 496 new item. Paul Besing --- Terry Watson wrote: > I think you were asking Larry -not me- but my plan > is to wait awhile. I have > a 196 which I like a lot, but I always want the > latest and greatest. > Aviation Consumer says they are going to do a > complete review of the 496 in > their September issue. I also see that there are two > levels of XM weather > subscriptions now, one at $30 a month and another at > $50. The $50 one seems > to be for higher altitudes than we would typically > be interested in. > > > > See: http://www.xmradio.com/weather/aviation.html > > > > Someone at one of the avionics booths at the > Arlington fly-in told me that > my wiring for the 196 won't work for the 396 or > likely the 496. He said it > was a different plug entirely. > > > > Terry > > > > > > _____ > > [mailto:owner-rv-list-server(at)matronics.com] On > Behalf Of James Clark > Sent: Thursday, July 20, 2006 2:25 PM > > > > So what is your plan??? Or did you purchase a 396 > already? > > James > > > > On 7/19/06, Larry Bowen > > wrote: > > http://www.garmin.com/products/gpsmap496/ > > > > > > > _____ > > > > > > Sent: Wednesday, July 19, 2006 6:37 PM > > > > I just received this ad from JA Air Center: > > > > JA Air Center, your Garmin source, is pleased to > announce the new Garmin > GPSmap 496 with XM Weather, Terrain, AOPA Airport > Guide, Taxiway Database, > and built in StreetPilot Automotive GPS. > > Limited quantities are in stock and available for > immediate delivery. > > > > > > Terry > > > > > > > > > -- > This is an alternate email. Please continue to email > me at > james(at)nextupventures.com . > > __________________________________________________ ________________________________________________________________________________
Date: Jul 20, 2006
Subject: Garmin 496
I recently upgraded from the 196 to 396. The wiring is different, but not a big deal. I'm real happy with the change -- even with the recent news of the 496. We sorta knew something was on the horizon when the price dropped. The 196 is now used in the back seat. http://bowenaero.com/mt3/archives/2006/06/gps_update.html -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Terry Watson wrote: > I think you were asking Larry -not me- but my plan is to wait awhile. I > have > a 196 which I like a lot, but I always want the latest and greatest. > Aviation Consumer says they are going to do a complete review of the 496 > in > their September issue. I also see that there are two levels of XM weather > subscriptions now, one at $30 a month and another at $50. The $50 one > seems > to be for higher altitudes than we would typically be interested in. > > > See: http://www.xmradio.com/weather/aviation.html > > > Someone at one of the avionics booths at the Arlington fly-in told me that > my wiring for the 196 won't work for the 396 or likely the 496. He said it > was a different plug entirely. > > > Terry > > > _____ > > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James Clark > Sent: Thursday, July 20, 2006 2:25 PM > > > So what is your plan??? Or did you purchase a 396 already? > > James > > > On 7/19/06, Larry Bowen > > > wrote: > > http://www.garmin.com/products/gpsmap496/ > > > _____ > > > Sent: Wednesday, July 19, 2006 6:37 PM > > > I just received this ad from JA Air Center: > > > JA Air Center, your Garmin source, is pleased to announce the new Garmin > GPSmap 496 with XM Weather, Terrain, AOPA Airport Guide, Taxiway Database, > and built in StreetPilot Automotive GPS. > > Limited quantities are in stock and available for immediate delivery. > > > Terry > > > -- > This is an alternate email. Please continue to email me at > james(at)nextupventures.com . > > ________________________________________________________________________________
Date: Jul 20, 2006
Subject: Garmin 496
The 196 and 296 have slightly different plugs. The 296 has 2 serial ports and the 196 only 1. I haven't looked at a 3 or 496. Pax, Ed Holyoke -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Terry Watson Sent: Thursday, July 20, 2006 3:10 PM I think you were asking Larry -not me- but my plan is to wait awhile. I have a 196 which I like a lot, but I always want the latest and greatest. Aviation Consumer says they are going to do a complete review of the 496 in their September issue. I also see that there are two levels of XM weather subscriptions now, one at $30 a month and another at $50. The $50 one seems to be for higher altitudes than we would typically be interested in. See: http://www.xmradio.com/weather/aviation.html Someone at one of the avionics booths at the Arlington fly-in told me that my wiring for the 196 won't work for the 396 or likely the 496. He said it was a different plug entirely. Terry _____ [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James Clark Sent: Thursday, July 20, 2006 2:25 PM So what is your plan??? Or did you purchase a 396 already? James On 7/19/06, Larry Bowen > wrote: http://www.garmin.com/products/gpsmap496/ _____ ] Sent: Wednesday, July 19, 2006 6:37 PM I just received this ad from JA Air Center: JA Air Center, your Garmin source, is pleased to announce the new Garmin GPSmap 496 with XM Weather, Terrain, AOPA Airport Guide, Taxiway Database, and built in StreetPilot Automotive GPS. Limited quantities are in stock and available for immediate delivery. Terry -- This is an alternate email. Please continue to email me at james(at)nextupventures.com . ________________________________________________________________________________
Date: Jul 20, 2006
Subject: Re: XM WX
On Jul 20, 2006, at 4:58 PM, Paul Besing wrote: > > I have the $30 subscription for XM weather right now. > It's fine, but the $50 one would be nice mainly for > the winds aloft information. It is available on the > 396, it's not just a 496 new item. > I think the $50 subscription is also real nice for the lightning data. I have seen times, like over the Guadalupe Mountains, that no echos at all showed up on my 396, but I could see a thunderstorm visually and by the lightning data. Makes me wonder about the source of the radar data because I know precip shows up here on NOAA sites. It is a difficult area for radar coverage though. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Jul 20, 2006
Its a lot better airplane than the SR20....compare the stats. It is much closer to the SR22 which is a lot more cash than that. I doubt very much I would sell mine for any less, there just aren't any better options for the money. Evan ----- Original Message ----- From: aeroncadoc(at)comcast.net To: rv-list(at)matronics.com Sent: Thursday, July 20, 2006 1:50 PM Subject: Re: RV-List: RV-10 for sale Just out of curiousity, how realistic is that asking price? We're getting up into new SR20 range there. Henry H. ________________________________________________________________________________
Date: Jul 20, 2006
Subject: Re: XM WX winds aloft not accurate
I just flew from Florida to Denver, Ohio, back to Florida. Liked everything on XM weather except the winds aloft info was far from correct. Estimate it was significantly wrong 75 % of time (so far off it was of no value). Used altitudes from 3,000 to 11,500 msl. Dale Walter ----- Original Message ----- Sent: Thursday, July 20, 2006 7:38 PM > > > On Jul 20, 2006, at 4:58 PM, Paul Besing wrote: > >> >> I have the $30 subscription for XM weather right now. >> It's fine, but the $50 one would be nice mainly for >> the winds aloft information. It is available on the >> 396, it's not just a 496 new item. >> > I think the $50 subscription is also real nice for the lightning data. I > have seen times, like over the Guadalupe Mountains, that no echos at all > showed up on my 396, but I could see a thunderstorm visually and by the > lightning data. Makes me wonder about the source of the radar data > because I know precip shows up here on NOAA sites. It is a difficult > area for radar coverage though. > > Larry Pardue > Carlsbad, NM > > RV-6 N441LP Flying > http://n5lp.net > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Jul 20, 2006
I'll bet there's $80-$90,000 worth of work just in the panel. And if the builder was Paul Irlbeck, and I think it was, you couldn't have a better builder. That man knows what he's doing. _____ [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Evan and Megan Johnson Sent: Thursday, July 20, 2006 8:15 PM Its a lot better airplane than the SR20....compare the stats. It is much closer to the SR22 which is a lot more cash than that. I doubt very much I would sell mine for any less, there just aren't any better options for the money. Evan ----- Original Message ----- Sent: Thursday, July 20, 2006 1:50 PM Just out of curiousity, how realistic is that asking price? We're getting up into new SR20 range there. Henry H. ________________________________________________________________________________
Date: Jul 20, 2006
For what it is worth, I've been flying the 396 for a year now (I was one of the first to get one) and I've been on the "$50" subscription ever since. I have found the winds aloft data to be as accurate, and in most cases more accurate than what Flight Service and Enroute Advisory Service will give you, from all altitudes from surface to 16,000 feet (most of my flying tends to be long cross country in excess of 500 miles one way between 4500-9500 feet). The only problem I had (as had most all of the early purchasers) was that the unit would not update as fast as it should sometimes...a downloaded (free) patch from Garmin fixed that problem. I heartedly endorse this unit...in my opinion it is the greatest single piece of equipment ever developed...a great GPS, and a weather display that is the next best thing to a weather radar, without the drag penalty or cost (and if you have weather radar, it gives you the ultimate weather picture). Bud Williams ----- Original Message ----- Sent: Thursday, July 20, 2006 8:16 PM > > I just flew from Florida to Denver, Ohio, back to Florida. Liked everything > on XM weather except the winds aloft info was far from correct. Estimate it > was significantly wrong 75 % of time (so far off it was of no value). Used > altitudes from 3,000 to 11,500 msl. > Dale Walter > > ----- Original Message ----- > Sent: Thursday, July 20, 2006 7:38 PM > > > > > > > > On Jul 20, 2006, at 4:58 PM, Paul Besing wrote: > > > >> > >> I have the $30 subscription for XM weather right now. > >> It's fine, but the $50 one would be nice mainly for > >> the winds aloft information. It is available on the > >> 396, it's not just a 496 new item. > >> > > I think the $50 subscription is also real nice for the lightning data. I > > have seen times, like over the Guadalupe Mountains, that no echos at all > > showed up on my 396, but I could see a thunderstorm visually and by the > > lightning data. Makes me wonder about the source of the radar data > > because I know precip shows up here on NOAA sites. It is a difficult > > area for radar coverage though. > > > > Larry Pardue > > Carlsbad, NM > > > > RV-6 N441LP Flying > > http://n5lp.net > > > > > > > > > > http://www.matronics.com/Navigator?RV-List > > http://wiki.matronics.com > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 20, 2006
On Jul 20, 2006, at 7:16 PM, Dale Walter wrote: > > I just flew from Florida to Denver, Ohio, back to Florida. Liked > everything on XM weather except the winds aloft info was far from > correct. Estimate it was significantly wrong 75 % of time (so far > off it was of no value). Used altitudes from 3,000 to 11,500 msl. > Dale Walter > Forecasts have never been reliable and never will be, and that is what those winds are, they are forecasts. I think the strength of the XM weather is the observed stuff, just like in the rest of aviation. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
From: "Jeffery J. Morgan" <jmorgan(at)compnetconcepts.com>
Date: Jul 20, 2006
Subject: XM WX winds aloft not accurate
And you filed a pirep so that they could get better at it, right? -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Pardue Sent: Thursday, July 20, 2006 10:07 PM On Jul 20, 2006, at 7:16 PM, Dale Walter wrote: > > I just flew from Florida to Denver, Ohio, back to Florida. Liked > everything on XM weather except the winds aloft info was far from > correct. Estimate it was significantly wrong 75 % of time (so far off > it was of no value). Used altitudes from 3,000 to 11,500 msl. > Dale Walter > Forecasts have never been reliable and never will be, and that is what those winds are, they are forecasts. I think the strength of the XM weather is the observed stuff, just like in the rest of aviation. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://n5lp.net ________________________________________________________________________________
Date: Jul 20, 2006
Subject: Re: Anti-Aviation bill in Florida
No. What it took was one neighbor with nothing better to do than complain. See more of the story at www.jaxairplane.com. -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Pete Cowper Sent: Wednesday, July 19, 2006 11:43 PM >"We should hear both sides of the story..." Much as I detest governmental inferference with private property rights, I can just picture it: Carport made from pvc sprinkler pipe and blue plastic Harbor Freight tarps, plywood work table alongside the driveway set up on two rusty 55 gallon oil drums, cheap noisy oil-less air compressor running all day and night, rivet gun ringing, stench of paint fumes sucked into the whole neighborhood's swamp coolers . . . and now over 8 years into the project. It takes a real nuisance to get a city council involved let alone a county board of supervisors. Pete Cowper RV8 #81139 (working on fuselage) Hanger B-5 Visalia Municipal Airport ________________________________________________________________________________
Date: Jul 20, 2006
The brass instrument screws at http://www.aircraftspruce.com/catalog/hapages/brassinstrscrew.php are black. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Gerry Filby Sent: Thursday, July 20, 2006 3:22 PM You can't get to the part number online at Spruce (went through this just recently). Someone helped me out on this list - try searching the archive. If that doesn't work - let me know I have the part number on an invoice at home which I can get for you tomorrow. g > > > I need a few 8-32 and 4-40 black, round head screws for mounting > instruments. Does any one know where I can get these? I can't > find any > in the Spruce catalog. > -- > Tom Sargent > RV-6A > > -- __g__ ========================================================= Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ---------------------------------------------------------- ________________________________________________________________________________
From: "BillDube(at)killacycle.com" <billdube(at)killacycle.com>
Date: Jul 20, 2006
Subject: Nifty scale engines on display at DIA
If you have the time at DIA (Denver International Airport) take a stroll along the bridge between the main terminal and concourse A. (Most folks take the train, and don't even realize the bridge exists.) There is a display of about 50 (maybe 100) fully-operational scale engines, mostly aircraft engines, some exact scale replicas, even one Wankel! The scale Continental 85 was particularly interesting. If you are just there for a connection, keep in mind that you will have to pass though security to get back to the concourses. (Ugh) Be sure you have enough time to marvel over these engines AND go back through security. They will be on display until September 10th. Bill Dube' ________________________________________________________________________________
Date: Jul 21, 2006
I know this is going to be like the "primer war". Winds aloft forecast based on observations taken on the 20th at use from negative above 24,000 feet. In the last issue of IFR magazine they discussed this. Note the forecast is only valid at 1200Z. The rest is a WAG. I do not think WX Weather makes its own independent forecast. Richard Reynolds Norfolk VA RV-6A, N841RV On Jul 20, 2006, at 9:16 PM, Dale Walter wrote: > > I just flew from Florida to Denver, Ohio, back to Florida. Liked > everything on XM weather except the winds aloft info was far from > correct. Estimate it was significantly wrong 75 % of time (so far > off it was of no value). Used altitudes from 3,000 to 11,500 msl. > Dale Walter > > ----- Original Message ----- Sent: Thursday, July 20, 2006 7:38 PM > ________________________________________________________________________________
Date: Jul 21, 2006
Sorry, Brian, you are not an unbiased reporter. Much as we are pre-disposed to agree with your side of things, to get the other side of the story we'd have to hear from the city council. By the way, your link to the ordinance is colored so that it is somewhat difficult to see; personally, I'd make it as contrasting as possible. Red, perhaps, or black on a red background. Pat Kelley -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Kraut Sent: Thursday, July 20, 2006 8:33 PM No. What it took was one neighbor with nothing better to do than complain. See more of the story at www.jaxairplane.com. -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Pete Cowper Sent: Wednesday, July 19, 2006 11:43 PM >"We should hear both sides of the story..." Much as I detest governmental inferference with private property rights, I can just picture it: Carport made from pvc sprinkler pipe and blue plastic Harbor Freight tarps, plywood work table alongside the driveway set up on two rusty 55 gallon oil drums, cheap noisy oil-less air compressor running all day and night, rivet gun ringing, stench of paint fumes sucked into the whole neighborhood's swamp coolers . . . and now over 8 years into the project. It takes a real nuisance to get a city council involved let alone a county board of supervisors. Pete Cowper RV8 #81139 (working on fuselage) Hanger B-5 Visalia Municipal Airport ________________________________________________________________________________
Date: Jul 21, 2006
The whole thing seems fishy. We're not getting all the details. Think about it. You're a member of the city council, and you've got someone whining to you constantly, about absolutely everything. Are you going to bend over backwards to help that person? I know I'm not! If she had a history of whining about things that were really problems, I'd take her seriously. But if she whines about everything under the sun, then there's no way I'll take her seriously. Nor would I ever abuse my power and oppress everyone else in the city just to get her off my back. The most I'd do is look into the issue. There's something else going on here that we don't know about. But if I were the guy in question, I'd be soliciting ideas from folks on how to legally make this woman's life miserable -- stuff like parking clunkers in the street in front of her house or painting my house some horrible color. -Joe On Jul 21, 2006, at 7:43 AM, Patrick Kelley wrote: > > Sorry, Brian, you are not an unbiased reporter. Much as we are pre- > disposed > to agree with your side of things, to get the other side of the > story we'd > have to hear from the city council. By the way, your link to the > ordinance > is colored so that it is somewhat difficult to see; personally, I'd > make it > as contrasting as possible. Red, perhaps, or black on a red > background. > > Pat Kelley > > -----Original Message----- > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Kraut > Sent: Thursday, July 20, 2006 8:33 PM > > > No. What it took was one neighbor with nothing better to do than > complain. > See more of the story at www.jaxairplane.com. > > -----Original Message----- > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Pete Cowper > Sent: Wednesday, July 19, 2006 11:43 PM > > >> "We should hear both sides of the story..." > > Much as I detest governmental inferference with private property > rights, > I can just picture it: Carport made from pvc sprinkler pipe and blue > plastic Harbor Freight tarps, plywood work table alongside the > driveway > set up on two rusty 55 gallon oil drums, cheap noisy oil-less air > compressor running all day and night, rivet gun ringing, stench of > paint > fumes sucked into the whole neighborhood's swamp coolers . . . and now > over 8 years into the project. > > It takes a real nuisance to get a city council involved let alone a > county board of supervisors. > > Pete Cowper > RV8 #81139 (working on fuselage) > Hanger B-5 > Visalia Municipal Airport > ________________________________________________________________________________
Date: Jul 21, 2006
You are correct. I am not an unbiased reporter, never claimed to be. I believe 100% that this is a bogus law that was passed to quiet one squeeky wheel. I also believe that two judges orders confirm that I was not doing anything wrong, but these are my biased opinion also. ---------- Original Message ---------------------------------- > >Sorry, Brian, you are not an unbiased reporter. Much as we are pre-disposed >to agree with your side of things, to get the other side of the story we'd >have to hear from the city council. By the way, your link to the ordinance >is colored so that it is somewhat difficult to see; personally, I'd make it >as contrasting as possible. Red, perhaps, or black on a red background. > >Pat Kelley > >-----Original Message----- >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Kraut >Sent: Thursday, July 20, 2006 8:33 PM > > >No. What it took was one neighbor with nothing better to do than complain. >See more of the story at www.jaxairplane.com. > >-----Original Message----- >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Pete Cowper >Sent: Wednesday, July 19, 2006 11:43 PM > > >>"We should hear both sides of the story..." > >Much as I detest governmental inferference with private property rights, >I can just picture it: Carport made from pvc sprinkler pipe and blue >plastic Harbor Freight tarps, plywood work table alongside the driveway >set up on two rusty 55 gallon oil drums, cheap noisy oil-less air >compressor running all day and night, rivet gun ringing, stench of paint >fumes sucked into the whole neighborhood's swamp coolers . . . and now >over 8 years into the project. > >It takes a real nuisance to get a city council involved let alone a >county board of supervisors. > >Pete Cowper >RV8 #81139 (working on fuselage) >Hanger B-5 >Visalia Municipal Airport > > > > > > > ________________________________________________________________ Sent via the WebMail system at mail.engalt.com ________________________________________________________________________________
Date: Jul 21, 2006
Cool Brian, Your on the list. Tell us more. Give us some pics of your place and your projects. Any and all info will help. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=49040#49040 ________________________________________________________________________________
Date: Jul 21, 2006
Brian, I bet everyone on this list agrees with you that this is a bogus regulation. But I think there were probably complaints from other people about things like airboats, or they wouldn't have been included in all this. You should be able to petition the city council and demand to be heard and to receive an explanation. You can also ask all your neighbors to come and publicly state they have no problems with your airplanes. I bet you could also get a lot of builders within driving distance of your home to stand in solidarity. With Unison in your area, you might be able to get a factory representative to also come. You could also run for city government yourself in order to make a difference. You could run on a campaign that starts out, "The current council has made it illegal to build model airplanes and kites in your garage. Is that the sort of city council you want?" You could get a petition campaign at Oshkosh. I bet you could get thousands of signatures on whatever petition you wanted. -Joe On Jul 21, 2006, at 10:31 AM, Brian Kraut wrote: > > You are correct. I am not an unbiased reporter, never claimed to > be. I believe 100% that this is a bogus law that was passed to > quiet one squeeky wheel. I also believe that two judges orders > confirm that I was not doing anything wrong, but these are my > biased opinion also. > > > ---------- Original Message ---------------------------------- > Reply-To: rv-list(at)matronics.com > >> >> Sorry, Brian, you are not an unbiased reporter. Much as we are >> pre-disposed >> to agree with your side of things, to get the other side of the >> story we'd >> have to hear from the city council. By the way, your link to the >> ordinance >> is colored so that it is somewhat difficult to see; personally, >> I'd make it >> as contrasting as possible. Red, perhaps, or black on a red >> background. >> >> Pat Kelley >> >> -----Original Message----- >> [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Kraut >> Sent: Thursday, July 20, 2006 8:33 PM >> >> >> No. What it took was one neighbor with nothing better to do than >> complain. >> See more of the story at www.jaxairplane.com. >> >> -----Original Message----- >> [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Pete Cowper >> Sent: Wednesday, July 19, 2006 11:43 PM >> >> >> >>> "We should hear both sides of the story..." >> >> Much as I detest governmental inferference with private property >> rights, >> I can just picture it: Carport made from pvc sprinkler pipe and blue >> plastic Harbor Freight tarps, plywood work table alongside the >> driveway >> set up on two rusty 55 gallon oil drums, cheap noisy oil-less air >> compressor running all day and night, rivet gun ringing, stench of >> paint >> fumes sucked into the whole neighborhood's swamp coolers . . . and >> now >> over 8 years into the project. >> >> It takes a real nuisance to get a city council involved let alone a >> county board of supervisors. >> >> Pete Cowper >> RV8 #81139 (working on fuselage) >> Hanger B-5 >> Visalia Municipal Airport >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________ > Sent via the WebMail system at mail.engalt.com > > ________________________________________________________________________________
Date: Jul 21, 2006
-------------- Original message -------------- > >. Those looking for a > 182 might just give a testicle or two for a 10. > ESPECIALLY THE WOMEN!
> --> RV-List message posted by: Tim Olson
Date: Jul 21, 2006
Subject: Re: tiny circlip pliers needed via mail order
Mickey Don has good advice here. I used my Blue Point (Snap On's budget or vendor made brand) Model PR-327 reversible snap ring pliers to remove and install that snap ring on the Matco parking brake valve. This is a set of straight nosed pliers. The corresponding 90 degree angle pliers are Model PR-129 These pliers can be used for both internal AND external snap rings. Similar units are sold by Mac Tools, Matco Tools and Cornwell Tools. Odds are, you can borrow a pair from a friend who is a professional auto mechanic. I can't imagine anyone doing this professionally without these tools. Charlie Kuss C&E Automotive owner Pompano Beach, Florida ---- dsvs(at)comcast.net wrote: > > Mickey, > Snapon Tools has an online store and sells snap ring pliers down to 0.039 in diameter. I'm not sure that that is small enough for what you need, but, if it is give them a try. Their stuff is the best quality in tools available. Don > -------------- Original message ---------------------- > > > > Hi, > > > > Anyone know where I can get some really small tip > > circlip pliers for the matco parking brake and > > the master cylinders? I can't seem to source > > them locally, so I need a mail order source. > > > > Thanks, > > Mickey > > -- > > Mickey Coggins > > http://www.rv8.ch/ > > #82007 finishing ________________________________________________________________________________
Date: Jul 21, 2006
McMaster Carr has a selection of pliers. I think I offered before, but if they cannot ship to you easily, I would be willing to get them and ship to you. We order from McMaster frequently and they are just a few miles down the road. Dick Tasker Mickey Coggins wrote: > > Hi, > > Anyone know where I can get some really small tip > circlip pliers for the matco parking brake and > the master cylinders? I can't seem to source > them locally, so I need a mail order source. > > Thanks, > Mickey ________________________________________________________________________________
Date: Jul 21, 2006
Subject: Re: What have you had to fix on the road? Was XC toolkit.
My trip stopping events. ElectroAir Ignition Sense Wire broke, fixed in Fort Pierce, FL. Alternator failed and had it rebuilt in Dothan, Al. Slick Ignition lead failed, replace in Souix City, IA Flat nose tire, replace tube in Greely, CO. Failures that I have help fix on other peoples planes. Flat Tires, Greely, CO Brake caliper seal replacement, Boise, ID. Slick Lasar Mags, Replaced in Stella Maris, Long Island, Bahamas Gary Zilik Read this topic online here: http://forums.matronics.com/viewtopic.php?p=49100#49100 ________________________________________________________________________________
Date: Jul 21, 2006
Subject: Re: Fuel tank vent
We had a local builder that forgot to tighten the B nut on the vent line inside the tank. The full tank caught the afternoon sun while sitting in the hanger and started to drip just like they all do when the tanks are full. This one did not stop, just a steady stream started coming out and flooding the hangar floor. I pulled the cap and stuck my finger over the vent but that did not stop it. Since the owner was not there we put a five gallon bucket under the drain and closed the hangar door. About 2 gallons of fuel drained out before it stopped. Removing the tank and tightening the B nut fixed the problem. Gary Read this topic online here: http://forums.matronics.com/viewtopic.php?p=49107#49107 ________________________________________________________________________________
Date: Jul 21, 2006
My Plane: Impulse coupler - Slick Mag Dead Battery Detonation - BAD FUEL - Lousy AvGas! - New Engine - Thank you! Other people's planes: Flaps - Failure to retract Flaps - out of rig Dead Battery Battery - Broken cap (sealed battery) Battery - Corrosion Position lights - NAV Alternator Field CB - Burnt - By passed with inline fuse Alternator Housing - Loose Alternator Belt - Broke Alternator B+ - Broke wire MAG Switch - Internal Ground - Grounded both Mags (P leads) Boost Pump - Clogged with debris - added auto filter Nose Strut - Low Vacuum Pump - Failure - replaced Strobe Noise - Shielded wire and Radio Shack filter Master Switch - High internal resistance - replaced Radio Problems (many) - CLEANED CONTACTS and GROUNDS I carry a 45 pound tool box --- 'Have tools - Will Travel' Barry "Chop'd Liver" ________________________________________________________________________________
Date: Jul 21, 2006
I've had two alternator failures and a total electrical failure caused by a broken wire to the ignition switch. Flaps failed full down caused by a broken fuse holder. That came close to an off field landing since I was practicing slow flight and was away from the airport. I've had a couple of failed spark plugs. I don't carry one, but I have the tools to clean and change them. I was unable to repair (and did not need to do anything) about two different cracked cylinders, one on a 540, one on an 0-320. Both diagnosed and repaired back home. The symptom both times was power loss and change in EGT. When I notice a change in engine performance I try and get on the ground and diagnose the problem. I'm OK flying with a known issue once I'm sure of the reason. I don't want a minor problem turning into a big one just because I was too lazy to land. ________________________________________________________________________________
Date: Jul 21, 2006
Subject: Re: Major new product announcement from Vans
Lawyer: the best possible landing is one you can walk away from, but your neck hurts. -Stormy /not a lawyer/ -----Original Message----- Sent: Sun, 16 Jul 2006 10:51 PM My instructor told me if I walk away its a good landing...if I can fly the plane again, that's a great landing. ----- Original Message ----- Sent: Sunday, July 16, 2006 4:12 PM > > >"I'll guess its air bags to deploy in a crash" > > So how will it tell the difference between a crash and one of my normal > crappy landings?!! > > Pete Cowper > RV-8 #81139 > > ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 21, 2006
Subject: Hey Stormy, take a look (was: Major new product announcement
from sportav8r(at)aol.com wrote: > Sorry, it's a light twin. But if you want a second opinion, I'll say > a rigid airship with prepunched aluminum inner skeleton. > > BTW, why are there no homebuilt blimps flying? Can't be that hard > with modern envelope materials, and a single seater would be way cool :-) > > -Stormy http://www.personalblimp.com/ See rec.aviation.homebuilt for some posts from the builder. Charlie @ Slobovia Outernational ________________________________________________________________________________
Date: Jul 21, 2006
Thanks for the tip. I would love to see them, but I don't get to Denver. I looked them up and found some information here http://www.flydenver.com/guide/art/exhibits.asp They come from a museum in Tempe, AZ who has a site here http://www.engine-museum.com/ I have been wanting to build some model radial engines for years, but don't have the time. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of BillDube(at)killacycle.com Sent: Friday, July 21, 2006 12:26 AM If you have the time at DIA (Denver International Airport) take a stroll along the bridge between the main terminal and concourse A. (Most folks take the train, and don't even realize the bridge exists.) There is a display of about 50 (maybe 100) fully-operational scale engines, mostly aircraft engines, some exact scale replicas, even one Wankel! The scale Continental 85 was particularly interesting. If you are just there for a connection, keep in mind that you will have to pass though security to get back to the concourses. (Ugh) Be sure you have enough time to marvel over these engines AND go back through security. They will be on display until September 10th. Bill Dube' ________________________________________________________________________________
Date: Jul 21, 2006
Had an exhaust gasket fail and pipe fall off 1500 miles from the house. Now I've got an extra gasket and exhaust nuts in the tool kit. In addition to a combination wrench set, 1/4" drive socket set, screwdrivers and pliers and such, I carry cardboard mixing cups for removed hardware control, a garbage bag, electrical and duct tape, zip ties and a selection of screws, nuts and washers and a couple of spark plugs. I also have hand cleaner and shop towels. When the airplane is heavy with baggage, I secure the kit just aft of the battery box on the floor (RV-6a) to help with CG. Pax, Ed Holyoke ________________________________________________________________________________
Date: Jul 22, 2006
Subject: Re: Gear Socket Gusset for an RV-6 engine mount
Would someone be kind enough to send me a photo of the re-enforcement around the lower end of the gear leg socket on a recent engine mount. I'm beginning to wonder if this list has been abandoned by actual RV builders. Doug > > Folks, > I have purchased the gussets from Vans to re-enforce the landing gear > socket of my old style RV-6 mount to prevent the cracking some have > experienced. Parts are WD-672A-R and WD-672-L. > > My plan is to have these welded to the mount but I do not have a clear > direction how they are positioned. Can someone point me to a clear > photograph of the lower end of a gear leg socket. I believe these are > fitted to all RV-6 and -7 mounts currently being shipped. > > Vans sent me two photos but they are not clear enough to pass to the > welder. > > Thanks, > Doug Gray > Sydney, Australia > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 22, 2006
During 12 years and 1600 hours of rotary powered flight time: Ruptured front cover oil transfer O-ring - Un-fun Oshkosh trip flying on low oil pressure. Broken tension bolt at RV fly-in @ Crawford TX - Wife Fed Ex'ed spare bolt and fixed it there. No Mag failures to report :-)))) Tracy Crook ________________________________________________________________________________
Date: Jul 22, 2006
Rich is right these are just FORECAST. Why do you need a forcast when you are flying, you have actually winds, use those. Cheers George M, RV-4/RV-7 >From: Richard Reynolds <rvreynolds(at)macs.net> > >I know this is going to be like the "primer war". > >Winds aloft forecast based on observations taken on the 20th at >EDT (1800Z). Temperatures are negative above 24,000 feet. > >In the last issue of IFR magazine they discussed this. Note the >forecast is only valid at 1200Z. The rest is a WAG. > >I do not think WX Weather makes its own independent forecast. --------------------------------- Everyone is raving about the all-new Yahoo! Mail Beta. ________________________________________________________________________________
Date: Jul 22, 2006
Opps, forgot the temporary exhaust system that fell apart in McKenny TX. Fixed with borrowed safety wire. I carry a roll of it when traveling now. Tracy ----- Original Message ----- From: Tracy Crook<mailto:lors01(at)msn.com> To: rv-list(at)matronics.com Sent: Saturday, July 22, 2006 8:28 AM Subject: Re: RV-List: Re: What have you had to fix on the road? During 12 years and 1600 hours of rotary powered flight time: Ruptured front cover oil transfer O-ring - Un-fun Oshkosh trip flying on low oil pressure. Broken tension bolt at RV fly-in @ Crawford TX - Wife Fed Ex'ed spare bolt and fixed it there. No Mag failures to report :-)))) Tracy Crook ________________________________________________________________________________
Date: Jul 22, 2006
Subject: For Sale Video
Hi: Have the famous "Been there Done That: Video Tapes, by Rich Hansen, builder of the award winning Rv6a. There are four vhs tapes. With excellent information and tips, when installing the engine to the Rv6a. Oil cooler. Baffles etc... Each tape has its own typed,list of topics, for easy, review.. Contact me off list for discounted price. Bert rv6a Flying ________________________________________________________________________________
Date: Jul 22, 2006
Subject: Re: Anti-Aviation bill in Florida - Local Solution?
>"I also believe that two judges orders confirm that I was not doing anything wrong," Brian's posts show that he appears to be a rather calm and level-headed person, and some third parties who have met him confirm this. For the city council to legislate in favor of the sole whining neighbor seems suspect, the whole story may show that Brian has been caught up in a citywide problem. I trust the list understands that my comment about the pole tent workshop was tongue-in-cheek and intended to illustrate the need to listen to both sides of the issue before jumping to conclusions. Having been a lawyer in California for almost 20 years in both criminal prosecution and defense as well as a civil litigation practice the past 15 years . . . I am always hesitant to determine the merits of a case based on hearing only one side of the story. Whether it is from the police department when I was a Deputy District Attorney or a client sitting across my desk attempting to sell me on the strength of their case as I am setting the retainer for the potential lengthy litigation that I am being assured will be put to rest with only one letter on my letterhead. Based on Brian's comment about two prior successful defenses in a true courtroom against this lady, she may have pulled a fast one by going to the city council instead of the courts. In California, a person who files multiple lawsuits without prevailing can be ruled a "vexatious litigant" by the court, on the court's own motion, after a hearing. This vexatious litigant must then present any further complaints (lawsuits) to the presiding judge who reviews the claim to determine whether it can be filed. There are a few California litigants in wheelchairs suing multiple small businesses under the ADA handicapped access rules who have been so labelled over the past year. Perhaps this possibly shrewd lady was aware of this potential and sought another jurisdiction with the city council. If she brings the identical claim in court it can be dismissed under "res judicata" as the same litigated claim cannot be relitigated after a determination has been issued by judge or jury. She has now secured a new law from the city. Seems to be a clever lady on a quest, unfortunately for her poor neighbor Brain. The suggestion that Brian get other local homebuilders and his neighbors to support his low neighborhood impact hobby is a good way to present his individual situation to to city council in hopes of getting a modification to the ordinance exempting his situation from who knows what other home hobbies the city is really intending to control (garage meth labs are popular here near Fresno, California). Seeking a determination from the city council in a positive manner about what parts of his aircraft homebuilding were objectionable, to which he can agree to control or eliminate, may allow him to continue his hobby with those restrictions. In dealing with government forums or any committee, present them with an answer rather than just a question and they will often readily agree with the solution so they can get on to other business. The city council might welcome being able to pare Brian out of the city ordinance just to whiz off the whining neighbor lady who is no doubt a gadfly thorn-in-their-side. To their possible irritation, she is no doubt trumpeting her "victory" with the new law that she may only have been a minor part in creating. Get the whole story and you are then prepared to work towards a solution. Usual caveats - not a Florida lawyer, seek own counsel . . . etc. Pete Cowper RV-8 #81139 ________________________________________________________________________________
Date: Jul 22, 2006
Worse was wood prop came loose and had to land at a ranch about 50 miles from home. Borrowed another prop and 4" extension and flew it back a couple of days later. Bendix starter stripped gears twice so would spin but not turn over prop. Slick Magneto failed on way to Oshkosh. Flat tire Loose ignition lead tail wheel Strobe light failure Broken air box Help on other planes on the road. Two alternators failed. Radio failure Regards, Tom Velvick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=49321#49321 ________________________________________________________________________________
Date: Jul 22, 2006
Subject: Prop governor mounting studs
I received my new TMX IO-360 engine a few days ago, and the mounting studs for the prop governor have not been installed. It came with a bag containing the studs, washers, star washers, and nuts, but I have absolutely no idea how to install the hardware and I can't find any references online. Can someone tell me how the studs go in (they are asymmetrical -- more threads on one end) and where the nuts/washers/star washers go? Also, what type of sealant is used on the gasket for the governor? Thanks. -Geoff RV-8 --------------------------------- ________________________________________________________________________________
Date: Jul 22, 2006
Subject: Re: Prop governor mounting studs
Geoff: Before installing, I would determine which prop govenor you will be using.. Different govenors require different length studs. They did you a favor by not installing something you might have to change anyway. If you determine that the ones your have are correct; I would double nut the long thread end. The studs are usually an "interference fit" into the case. That is that they are about .001 in larger than the threaded holes in the case. I would use " Lock-Tite" compound on them anyway to prevent any chance of oil seepage. Use a wrench on the outer nut to screw them into the case. I would not bottom them out in the case. After they're installed, remove the nuts. It is not necessary to use any kind of sealant on the gasket, in fact I would recommend that you don't. This has been my experience with the ones I have worked on. The usual caveat----YMMV. Mannan Thomason RV-8 N1 61RL ----- Original Message ----- From: Geoff Evans To: rv-list(at)matronics.com Sent: Saturday, July 22, 2006 7:20 PM Subject: RV-List: Prop governor mounting studs I received my new TMX IO-360 engine a few days ago, and the mounting studs for the prop governor have not been installed. It came with a bag containing the studs, washers, star washers, and nuts, but I have absolutely no idea how to install the hardware and I can't find any references online. Can someone tell me how the studs go in (they are asymmetrical -- more threads on one end) and where the nuts/washers/star washers go? Also, what type of sealant is used on the gasket for the governor? Thanks. -Geoff RV-8 ________________________________________________________________________________
Date: Jul 22, 2006
OR one where you get a Medivac helicopter flight, two days in the hospital, 30 hours strapped to a back board, a real nasty 6" cut complete with "flap" on your head that has still not healed after a month, a sore neck, 20 staples BUT no broken bones. It was the end of day two but I did walk about, sorta. KABONG 8*) Lawyer: the best possible landing is one you can walk away from, but your neck hurts. -Stormy /not a lawyer/ ________________________________________________________________________________
Date: Jul 22, 2006
Pete Cowper wrote: > > > >>"I also believe that two judges orders confirm that I was not doing >> >> >anything wrong," > >Brian's posts show that he appears to be a rather calm and level-headed >person, and some third parties who have met him confirm this. > >For the city council to legislate in favor of the sole whining neighbor >seems suspect, the whole story may show that Brian has been caught up in >a citywide problem. > >I trust the list understands that my comment about the pole tent >workshop was tongue-in-cheek and intended to illustrate the need to >listen to both sides of the issue before jumping to conclusions. Having >been a lawyer in California for almost 20 years in both criminal >prosecution and defense as well as a civil litigation practice the past >15 years . . . I am always hesitant to determine the merits of a case >based on hearing only one side of the story. Whether it is from the > >snipped > > >Pete Cowper >RV-8 #81139 > It seems to me that discussing this as a 'case' misses the point entirely. If this was a 'case', it would have been dealt with as a 'case' (Brian has apparently already dealt with the 'case'). This city (which happens to be an entire county) has legislated that *all* its citizens cannot exercise their constitutional rights in two areas. No restrictions were placed on hobbies like antique tractor restoration, which in every way could be just as dangerous and/or irritating to neighbors. Strategy & tactics used to respond can be debated, but there is no doubt in my mind that this blatantly unconstitutional, like most of the laws restricting conduct in the last 30-40 years. (Why do we allow the FAA to call our right to fly a 'privilege'? Is my right to vote a 'privilege' just because I can lose it if I'm convicted of a felony?) Charlie ________________________________________________________________________________
Date: Jul 22, 2006
It is very much a "case" and will have its day in court. I could move the plane to the airport or a mini storage and not go to court, but this needs to be fought. I will not run with my tail between my legs. I really appreciate everyone's support and suggestions. I wish I could respond to the hundreds of emails I get, but that would be a full time job. I have been keeping a little quiet on all the little details, the information I have been gathering on the ordinance and how it passed, and the legal strategy for getting this ordinance changed. This will go to court and I can't spill all the beans now. Brian Kraut www.jaxairplane.com -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Charlie England Sent: Saturday, July 22, 2006 11:31 PM Solution? Pete Cowper wrote: > > >>"I also believe that two judges orders confirm that I was not doing >> >> >anything wrong," > >Brian's posts show that he appears to be a rather calm and level-headed >person, and some third parties who have met him confirm this. > >For the city council to legislate in favor of the sole whining neighbor >seems suspect, the whole story may show that Brian has been caught up in >a citywide problem. > >I trust the list understands that my comment about the pole tent >workshop was tongue-in-cheek and intended to illustrate the need to >listen to both sides of the issue before jumping to conclusions. Having >been a lawyer in California for almost 20 years in both criminal >prosecution and defense as well as a civil litigation practice the past >15 years . . . I am always hesitant to determine the merits of a case >based on hearing only one side of the story. Whether it is from the > >snipped > > >Pete Cowper >RV-8 #81139 > It seems to me that discussing this as a 'case' misses the point entirely. If this was a 'case', it would have been dealt with as a 'case' (Brian has apparently already dealt with the 'case'). This city (which happens to be an entire county) has legislated that *all* its citizens cannot exercise their constitutional rights in two areas. No restrictions were placed on hobbies like antique tractor restoration, which in every way could be just as dangerous and/or irritating to neighbors. Strategy & tactics used to respond can be debated, but there is no doubt in my mind that this blatantly unconstitutional, like most of the laws restricting conduct in the last 30-40 years. (Why do we allow the FAA to call our right to fly a 'privilege'? Is my right to vote a 'privilege' just because I can lose it if I'm convicted of a felony?) Charlie ________________________________________________________________________________
Date: Jul 23, 2006
Doug, just to assure you that you are not going crazy - I know exactly what you are referring to. I have the old mount and will be checking regularly for cracks. I know of another RV6 that did crack the mount and had to weld on the gussets. Unfortunately I don't have a photo to help you. If I can contact that owner in the near future I'll ask him for more detail. Cheers Shirley Harding RV6 VH ASF - 23 hrs Perth Western Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=49393#49393 ________________________________________________________________________________
Date: Jul 23, 2006
Hi Shirley, Thanks. I have spoken to a number of RV-6 owners around our patch who are keeping watch on cracks developing in this area. I thought I'd head off the problem before mounting the engine. The positioning of the patches is obvious once the mount was off the fuselage. Planning to get them welded tomorrow. Doug Sydney > > Doug, just to assure you that you are not going crazy - I know exactly what you are referring to. I have the old mount and will be checking regularly for cracks. I know of another RV6 that did crack the mount and had to weld on the gussets. Unfortunately I don't have a photo to help you. If I can contact that owner in the near future I'll ask him for more detail. > > Cheers > > Shirley Harding > RV6 VH ASF - 23 hrs > Perth Western Australia > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=49393#49393 > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 23, 2006
I'm on your side; my point is that when the city decided to pass a discriminatory ordinance, it became much more than a 'case'. We are all affected. Even if you were the world's worst jerk, riveting at 3:00 AM & spraying dangerous chemicals into your neighbor's windows, it still would not justify passing the law they passed. Charlie Brian Kraut wrote: > >It is very much a "case" and will have its day in court. I could move the >plane to the airport or a mini storage and not go to court, but this needs >to be fought. I will not run with my tail between my legs. > >I really appreciate everyone's support and suggestions. I wish I could >respond to the hundreds of emails I get, but that would be a full time job. > >I have been keeping a little quiet on all the little details, the >information I have been gathering on the ordinance and how it passed, and >the legal strategy for getting this ordinance changed. This will go to >court and I can't spill all the beans now. > >Brian Kraut >www.jaxairplane.com > >-----Original Message----- >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Charlie England >Sent: Saturday, July 22, 2006 11:31 PM >Solution? > > >Pete Cowper wrote: > > > >> >> >> >> >> >>>"I also believe that two judges orders confirm that I was not doing >>> >>> >>> >>> >>anything wrong," >> >>Brian's posts show that he appears to be a rather calm and level-headed >>person, and some third parties who have met him confirm this. >> >>For the city council to legislate in favor of the sole whining neighbor >>seems suspect, the whole story may show that Brian has been caught up in >>a citywide problem. >> >>I trust the list understands that my comment about the pole tent >>workshop was tongue-in-cheek and intended to illustrate the need to >>listen to both sides of the issue before jumping to conclusions. Having >>been a lawyer in California for almost 20 years in both criminal >>prosecution and defense as well as a civil litigation practice the past >>15 years . . . I am always hesitant to determine the merits of a case >>based on hearing only one side of the story. Whether it is from the >> >> >> > >snipped > > > >>Pete Cowper >>RV-8 #81139 >> >> >> >It seems to me that discussing this as a 'case' misses the point entirely. > >If this was a 'case', it would have been dealt with as a 'case' (Brian >has apparently already dealt with the 'case'). > >This city (which happens to be an entire county) has legislated that >*all* its citizens cannot exercise their constitutional rights in two >areas. No restrictions were placed on hobbies like antique tractor >restoration, which in every way could be just as dangerous and/or >irritating to neighbors. > >Strategy & tactics used to respond can be debated, but there is no doubt >in my mind that this blatantly unconstitutional, like most of the laws >restricting conduct in the last 30-40 years. (Why do we allow the FAA >to call our right to fly a 'privilege'? Is my right to vote a >'privilege' just because I can lose it if I'm convicted of a felony?) > >Charlie > ________________________________________________________________________________
Date: Jul 23, 2006
Good observations. That is the part some people don't understand. If I was causing a tremendous nuisance with noise, dangerous conditions, trash and parts everywhere (which I am not) they would be giving me fines for those things. Those laws already exist here and it would be very easy for them to fine me on those things and make them stick. I have not gotten a single citation or warning for any of those things because they are not happening. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Charlie England Sent: Sunday, July 23, 2006 9:22 AM Solution? I'm on your side; my point is that when the city decided to pass a discriminatory ordinance, it became much more than a 'case'. We are all affected. Even if you were the world's worst jerk, riveting at 3:00 AM & spraying dangerous chemicals into your neighbor's windows, it still would not justify passing the law they passed. Charlie Brian Kraut wrote: > >It is very much a "case" and will have its day in court. I could move the >plane to the airport or a mini storage and not go to court, but this needs >to be fought. I will not run with my tail between my legs. > >I really appreciate everyone's support and suggestions. I wish I could >respond to the hundreds of emails I get, but that would be a full time job. > >I have been keeping a little quiet on all the little details, the >information I have been gathering on the ordinance and how it passed, and >the legal strategy for getting this ordinance changed. This will go to >court and I can't spill all the beans now. > >Brian Kraut >www.jaxairplane.com > >-----Original Message----- >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Charlie England >Sent: Saturday, July 22, 2006 11:31 PM >Solution? > > >Pete Cowper wrote: > > >> >> >> >> >> >>>"I also believe that two judges orders confirm that I was not doing >>> >>> >>> >>> >>anything wrong," >> >>Brian's posts show that he appears to be a rather calm and level-headed >>person, and some third parties who have met him confirm this. >> >>For the city council to legislate in favor of the sole whining neighbor >>seems suspect, the whole story may show that Brian has been caught up in >>a citywide problem. >> >>I trust the list understands that my comment about the pole tent >>workshop was tongue-in-cheek and intended to illustrate the need to >>listen to both sides of the issue before jumping to conclusions. Having >>been a lawyer in California for almost 20 years in both criminal >>prosecution and defense as well as a civil litigation practice the past >>15 years . . . I am always hesitant to determine the merits of a case >>based on hearing only one side of the story. Whether it is from the >> >> >> > >snipped > > >>Pete Cowper >>RV-8 #81139 >> >> >> >It seems to me that discussing this as a 'case' misses the point entirely. > >If this was a 'case', it would have been dealt with as a 'case' (Brian >has apparently already dealt with the 'case'). > >This city (which happens to be an entire county) has legislated that >*all* its citizens cannot exercise their constitutional rights in two >areas. No restrictions were placed on hobbies like antique tractor >restoration, which in every way could be just as dangerous and/or >irritating to neighbors. > >Strategy & tactics used to respond can be debated, but there is no doubt >in my mind that this blatantly unconstitutional, like most of the laws >restricting conduct in the last 30-40 years. (Why do we allow the FAA >to call our right to fly a 'privilege'? Is my right to vote a >'privilege' just because I can lose it if I'm convicted of a felony?) > >Charlie > ________________________________________________________________________________
Date: Jul 23, 2006
Subject: RE: black screws for instruments
Tom, The easiest solution is to get some stainless ones at the local hardware store and paint them. Very easy. Punch a bunch of holes in a piece of cardboard using a suitably size tool and stick the screws partway in. Paint whatever color you like. (I used satin black Krylon) Paint more than you need so you have some spares. I used SS socket head cap screws from www.microfasteners.com (there is a lot of screws in a panel and their prices are fair, plus they ran the 100 deg stainless Torx fasteners specially for the RV'ers.) Mike __________________________________________________ ________________________________________________________________________________
Date: Jul 24, 2006
Subject: N161RL Flies
Mannan, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A >From: "Mannan J. Thomason" <mannanj(at)alltel.net> >Subject: RV-List: N161RL Flies >Date: Sat, 1 Jul 2006 10:13:29 -0400 > > >After 4 1/2 years and after being asked "when is it going to fly?" and my >saying Thursday, about half a million times, N161RL flew Thurs.29 June. >She's an RV-8 slow build, IO-360-A3B6D, McCauley (ugh.) Prop, Sam James >Cowl. > ________________________________________________________________________________
Date: Jul 24, 2006
Subject: Re: XM WX
I just flew in Texas yesterday and noticed that the wx info is a little slow to update. It was nice to see the cell on the screen about 50 miles before I could even see it, though. Made the diversion much more gradual. I would caution not to completely rely on it in IMC to determine where the cells are, but it is great for the VFR pilot to make some turn around decisions, or diversions for alternate routes. Sometimes the information can be a little old, like 10-20 mins it might seem sometimes. Paul Besing --- Larry Pardue wrote: > > > > On Jul 20, 2006, at 4:58 PM, Paul Besing wrote: > > > > > > I have the $30 subscription for XM weather right > now. > > It's fine, but the $50 one would be nice mainly > for > > the winds aloft information. It is available on > the > > 396, it's not just a 496 new item. > > > I think the $50 subscription is also real nice for > the lightning > data. I have seen times, like over the Guadalupe > Mountains, that no > echos at all showed up on my 396, but I could see a > thunderstorm > visually and by the lightning data. Makes me wonder > about the source > of the radar data because I know precip shows up > here on NOAA sites. > It is a difficult area for radar coverage though. > > Larry Pardue > Carlsbad, NM > > RV-6 N441LP Flying > http://n5lp.net > > > > > > browse > Subscriptions page, > FAQ, > > > Admin. > > > > > > > > > > > __________________________________________________ ________________________________________________________________________________
Date: Jul 24, 2006
Subject: Anti-Aviation bill in Florida - Long
To say that our rights are actually privileges is to say that someone, presumably some level of government, has the power and the right to grant or deny those privileges. That premise is completely backwards. In the U.S. at least, government exists expressly by the consent of the governed, and our federal and individual state constitutions are expressly written to limit the power of the government, not the citizens. It is the nature of government to constantly try to push the limits of its power, as sure as it is the nature of fish to swim or dogs to bark, which is exactly why it is in all of our interests to push back. Regulations are written by people who for whatever reason believe they have the power and the right to tell other people how they should live their lives. Often this is to force inconsiderate people to respect the rights and autonomy of their neighbors, but it would seem to me that just as often it is by inconsiderate and dominating people to try to force others to live their lives according to the regulator's ideas of what is good for them. A third reason, often behind onerous zoning laws, is blatant self-interest at the expense of those without the political power to resist. I would encourage those who value their freedom to make their own decisions about their life to push back, never accepting the false premise that they live by the permission of any other individual or group or government. Terry RV-8A finishing Seattle -----Original Message-----From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ken Howell Sent: Monday, July 24, 2006 8:46 AM We are not 8th graders. Most of us realize that our so-called rights are really privileges. I think we all agree that the JAX ordinance is onerous to homebuilders and should be rescinded. Regardless of the degree of EAA or AOPA advocacy in this matter, I believe that it is a time where our voices should be heard as individuals, in an assertive and respectful manner. Just like the 20,000 comments that poured in opposing the permanent DC ADIZ, this ill-conceived ordinance should invoke a similar response, because if left unchallenged, it will set a precedent that will eventually affect all of us. It may be overkill, but my fervent hope would be that thousands of homebuilders would respond in opposition. Ken Howell ________________________________________________________________________________
Date: Jul 24, 2006
Subject: WTB - RV-6A or RV-7A
This is for another individual. We have looked at Trade-A-Plane. If there are other good web sources please email the link. Preferences as best known at this time 1) IO-360 preferred [O-360 may be ok]. Engine must be low time new 2) CS prop preferred 3) Blue Mountain type avionics preferred 4) Slider preferred Ron Lee ronlee(at)pcisys.net ________________________________________________________________________________
Date: Jul 24, 2006
Very well written. You have nailed a big part of the reason why I have not just given into the 10 day warnings and avoided the citations. Some people think I am crazy for that. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Terry Watson Sent: Monday, July 24, 2006 1:39 PM To say that our rights are actually privileges is to say that someone, presumably some level of government, has the power and the right to grant or deny those privileges. That premise is completely backwards. In the U.S. at least, government exists expressly by the consent of the governed, and our federal and individual state constitutions are expressly written to limit the power of the government, not the citizens. It is the nature of government to constantly try to push the limits of its power, as sure as it is the nature of fish to swim or dogs to bark, which is exactly why it is in all of our interests to push back. Regulations are written by people who for whatever reason believe they have the power and the right to tell other people how they should live their lives. Often this is to force inconsiderate people to respect the rights and autonomy of their neighbors, but it would seem to me that just as often it is by inconsiderate and dominating people to try to force others to live their lives according to the regulator's ideas of what is good for them. A third reason, often behind onerous zoning laws, is blatant self-interest at the expense of those without the political power to resist. I would encourage those who value their freedom to make their own decisions about their life to push back, never accepting the false premise that they live by the permission of any other individual or group or government. Terry RV-8A finishing Seattle -----Original Message-----From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ken Howell Sent: Monday, July 24, 2006 8:46 AM We are not 8th graders. Most of us realize that our so-called rights are really privileges. I think we all agree that the JAX ordinance is onerous to homebuilders and should be rescinded. Regardless of the degree of EAA or AOPA advocacy in this matter, I believe that it is a time where our voices should be heard as individuals, in an assertive and respectful manner. Just like the 20,000 comments that poured in opposing the permanent DC ADIZ, this ill-conceived ordinance should invoke a similar response, because if left unchallenged, it will set a precedent that will eventually affect all of us. It may be overkill, but my fervent hope would be that thousands of homebuilders would respond in opposition. Ken Howell ________________________________________________________________________________
Date: Jul 24, 2006
[alone and crickets chirping] Eh, er, well, I don't think I'd want a neighbor like Brian. As far as the legal aspect, I sympathize with him. I generally don't like more and more laws for all aspects of life. Aside from that, Brian seems to perpetually have two planes under construction somewhere on his property. That's doesn't seem like a typical homebuilder unless he's trying to build his own personal invasion fleet for a war against Amelia Island. I'd hate it if the guy next to me always had two cars under restoration in his yard and garage. Whether legal or not, it's not neighborhood friendly, and it sounds like Brian met his Bizarro with that neighbor. Brian, I have some suggestions for you. Remove the planes to offsite storage and invest your money in becoming the ultimate bad neighbor: 1) Erect a 50 foot ham radio tower in the back yard. 2) Start to build a new front porch and quit part way through the project. 3) Plant weeds in your yard. 4) Christmas lights all year long. 5) Use some old tires somewhere in your landscaping plans. 6) Make a weathervane out of a vert stab! 7) Find out the political persuasion of your neighbor and post support signs for the other party politicians. The guy sounds smart and crabby, so probably a republican (like me 'cept for the smart part). 8) A flock of rusty pink flamingos sounds about right for a true Floridian. Good luck! ****************************************** Don Hall N517DG (registered) rv7 fuselage http://rv7.donka.net ****************************************** > Brian Kraut wrote: > > > > >It is very much a "case" and will have its day in court. I > could move > >the plane to the airport or a mini storage and not go to court, but > >this needs to be fought. I will not run with my tail > between my legs. > > > >I really appreciate everyone's support and suggestions. I > wish I could > >respond to the hundreds of emails I get, but that would be a > full time > >job. > > > >I have been keeping a little quiet on all the little details, the > >information I have been gathering on the ordinance and how > it passed, > >and the legal strategy for getting this ordinance changed. > This will > >go to court and I can't spill all the beans now. > > > >Brian Kraut > >www.jaxairplane.com > > > >-----Original Message----- > >[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of > Charlie England > >Sent: Saturday, July 22, 2006 11:31 PM Solution? > > > > > >--> > > > >Pete Cowper wrote: > > > > > > > >> > >> > >> > >> > >> > >>>"I also believe that two judges orders confirm that I was not doing > >>> > >>> > >>> > >>> > >>anything wrong," > >> > >>Brian's posts show that he appears to be a rather calm and > >>level-headed person, and some third parties who have met > him confirm > >>this. > >> > >>For the city council to legislate in favor of the sole whining > >>neighbor seems suspect, the whole story may show that Brian > has been > >>caught up in a citywide problem. > >> > >>I trust the list understands that my comment about the pole tent > >>workshop was tongue-in-cheek and intended to illustrate the need to > >>listen to both sides of the issue before jumping to conclusions. > >>Having been a lawyer in California for almost 20 years in both > >>criminal prosecution and defense as well as a civil litigation > >>practice the past 15 years . . . I am always hesitant to > determine the > >>merits of a case based on hearing only one side of the > story. Whether > >>it is from the > >> > >> > >> > > >snipped > > > > > > > >>Pete Cowper > >>RV-8 #81139 > >> > >> > >> > >It seems to me that discussing this as a 'case' misses the point > >entirely. > > > >If this was a 'case', it would have been dealt with as a > 'case' (Brian > >has apparently already dealt with the 'case'). > > > >This city (which happens to be an entire county) has legislated that > >*all* its citizens cannot exercise their constitutional > rights in two > >areas. No restrictions were placed on hobbies like antique tractor > >restoration, which in every way could be just as dangerous and/or > >irritating to neighbors. > > > >Strategy & tactics used to respond can be debated, but there is no > >doubt in my mind that this blatantly unconstitutional, like > most of the > >laws restricting conduct in the last 30-40 years. (Why do > we allow the > >FAA to call our right to fly a 'privilege'? Is my right to vote a > >'privilege' just because I can lose it if I'm convicted of a felony?) > > > >Charlie > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 25, 2006
Subject: Re: New Target - Ham Radio WAS: Anti-Aviation bill in Florida
- L... What! Only a 50 foot tower? Mine is 91 feet. And I need some pink flamingos ... send them up to NJ Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Jul 25, 2006
Subject: garmin GMA 340 installation manual
Anyone have a lead on finding the GMA 340 audio panel installation manual online? I found the Pilot's Guide but can't locate a URL for the install manual pdf file. Not sure it even exits in that form. I can order one for 20 bucks but thought I'd ask here first. Thanks. -Stormy ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 25, 2006
Subject: Re: garmin GMA 340 installation manual
Stormy, I have it on PDF. I'll send you a copy tonight when I get home from work. Send me an off line message to remind me. Don VS -------------- Original message ---------------------- > Anyone have a lead on finding the GMA 340 audio panel installation manual > online? I found the Pilot's Guide but can't locate a URL for the install manual > pdf file. Not sure it even exits in that form. I can order one for 20 bucks > but thought I'd ask here first. > > Thanks. > > -Stormy > ________________________________________________________________________ Content-Type: Multipart/alternative; boundary="NextPart_Webmail_9m3u9jl4l_4511_1153839123_1" --NextPart_Webmail_9m3u9jl4l_4511_1153839123_1 Content-Type: text/html; charset="us-ascii" Content-Transfer-Encoding: 7bit
Thanks.
-Stormy
--NextPart_Webmail_9m3u9jl4l_4511_1153839123_1-- ________________________________________________________________________________
Date: Jul 25, 2006
Check out Barnstormers.com John L. Danielson -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee Sent: Monday, July 24, 2006 3:58 PM This is for another individual. We have looked at Trade-A-Plane. If there are other good web sources please email the link. Preferences as best known at this time 1) IO-360 preferred [O-360 may be ok]. Engine must be low time new 2) CS prop preferred 3) Blue Mountain type avionics preferred 4) Slider preferred Ron Lee ronlee(at)pcisys.net ________________________________________________________________________________
Date: Jul 25, 2006
Frank G. came to my rescue already. Thanks for the offer. This is why I love the RV list. Even when all of us should be at Oshkosh, I can still get help 24/7 ;-) -Stormy -----Original Message----- Sent: Tue, 25 Jul 2006 10:52 AM Stormy, I have it on PDF. I'll send you a copy tonight when I get home from work. Send me an off line message to remind me. Don VS -------------- Original message ---------------------- > Anyone have a lead on finding the GMA 340 audio panel installation manual > online? I found the Pilot's Guide but can't locate a URL for the install manual > pdf file. Not sure it even exits in that form. I can order one for 20 bucks > but thought I'd ask here first. > > Thanks. > > -Stormy > ________________________________________________________________________ Attached Message Subject: Date: Anyone have a lead on finding the GMA 340 audio panel installation manual online? I found the Pilot's Guide but can't locate a URL for the install manual pdf file. Not sure it even exits in that form. I can order one for 20 bucks but thought I'd ask here first. Thanks. -Stormy ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 25, 2006
Subject: Re: RV10-List: OSH Update 7/23/06
> Announcement is that the RV-8 fuselage is now completely prepunched along > with an update to the plans. > Bob YGBSM, as my Wild Weasel partner would say. Below is a direct reprint copy from the Van's site. Wonder how many people at OSH are looking, asking question about the "new" -8 prepunched format compared to those drooling over the prototype RV-12. Prepunched RV-4...maybe...but that would screw up all the HRII builder sales Van's does. Where are photos of the RV-12 ? ? Somebody has to have taken some. Are they taking "escrow" orders for the RV-12 yet ? ? Can you get/fax/e-mail me an RV-12 order form ? ? Now that would be a BIG ANNOUNCEMENT. KABONG HRII waiting for the RV-12. "In RV-7/8/9/10 kits, rivet and bolt holes are pre-punched into all the parts. It is hard to overstate just how much labor and difficulty matched-hole pre-punching saves. All part alignments, fastener spacings and measurements are set at the factory. When the builder aligns the holes, the parts must be in the correct position. An RV builder is assembling an airplane, not building one from scratch." ________________________________________________________________________________
Date: Jul 25, 2006
Doug Reeves has lots of -12 pix on his site today. -Stormy -----Original Message----- Sent: Tue, 25 Jul 2006 3:39 PM > Announcement is that the RV-8 fuselage is now completely prepunched along > with an update to the plans. > Bob YGBSM, as my Wild Weasel partner would say. Below is a direct reprint copy from the Van's site. Wonder how many people at OSH are looking, asking question about the "new" -8 prepunched format compared to those drooling over the prototype RV-12. Prepunched RV-4...maybe...but that would screw up all the HRII builder sales Van's does. Where are photos of the RV-12 ? ? Somebody has to have taken some. Are they taking "escrow" orders for the RV-12 yet ? ? Can you get/fax/e-mail me an RV-12 order form ? ? Now that would be a BIG ANNOUNCEMENT. KABONG HRII waiting for the RV-12. "In RV-7/8/9/10 kits, rivet and bolt holes are pre-punched into all the parts. It is hard to overstate just how much labor and difficulty matched-hole pre-punching saves. All part alignments, fastener spacings and measurements are set at the factory. When the builder aligns the holes, the parts must be in the correct position. An RV builder is assembling an airplane, not building one from scratch." ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 25, 2006
Subject: Fw: Van's RV-12
MessageA nice picture of the 12 before the crowd arrived. ________________________________________________________________________________
Date: Jul 25, 2006
Subject: Re: Fw: Van's RV-12
MessageCROWD ? ? , what crowd ? ?...., There was a crowd ? ? Oh, yes the overflow from the one gathered around the RV-8 with the all "new" pre-punched holes. YAWN.......... Thank You...Very nice picture of a very nice airplane. KABONG Do Not Archive 8*) (I just love to banter) ----- Original Message ----- From: Dale Ensing To: rvlist Sent: Tuesday, July 25, 2006 2:56 PM Subject: RV-List: Fw: Van's RV-12 A nice picture of the 12 before the crowd arrived. ________________________________________________________________________________
Date: Jul 25, 2006
Subject: Lycoming pre-oiling
For those of you who have installed a new lycoming engine, drained the preservative oil, and filled the oil sump; how did you go about filling the oil cooler? ________________________________________________________________________________
Date: Jul 25, 2006
Subject: Anti Aviation Bill in Jacksonville
Lots of people have asked me to put up some pictures on my web site so they could get an idea on what my house looks like compared to the other houses in my neighbohood. Some people are assuming that I live in a beautiful neighborhood and I have an airplane junkyard on my front lawn. Looking at the pictres should give everyone a sense of what the truth really is. I have also added to the questions section. Look at www.jaxairplane.com. I really want to thank all of the people that have sent emails of support on this. I wish tat I could reply to each one individually, but I have literally hundreds and hundreds of emails and I can't reply to all of them. I also want to thank a lot of the people that have voiced their opinion and sided against me. With few exceptions, those giving an opinion different than mine have been courteous and not started an email flame war. It takes courage to express your opinion even when it goes against the general flow. In my fight against the city I am the one swimming upstream and I know how important it is to not just sit back and listen and to express your own opinion. We all share a love of aviation and homebuilding, but we all do not necessarily need to agree all the time. Brian Kraut brian(at)jaxairplane.com ________________________________________________________________________________
Date: Jul 25, 2006
I can understand Van's wanting to save the announcements for Oshkosh. I'm not impressed by Ken Scott telling us at the Arlington Fly-in that Van would never offer a prepunched RV-8, and that the RV-12 would not be at Oshkosh. If he wanted to make "no comments" on the speculation of what the announcments were going to be that's fine with me, but to lie about it was not. I've attended my last Van's seminar. ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Jul 25, 2006
Subject: Re: Lycoming pre-oiling
Not a big worry, because gravity and syphon action cause the oil cooler to drain every time you shut down the engine. If you did want to fill it (hypothetically just before first start), you could pull the top oil cooler hose loose and fill the cooler through the hose. Most folks simply pull the plugs and spin the engine for a few seconds with the starter to bring the oil pressure up. KB ----- Original Message ----- From: dwhite17(at)columbus.rr.com To: rv-list(at)matronics.com Sent: Tuesday, July 25, 2006 9:53 PM Subject: RV-List: Lycoming pre-oiling For those of you who have installed a new lycoming engine, drained the preservative oil, and filled the oil sump; how did you go about filling the oil cooler? ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Jul 26, 2006
True story about a real estate appraiser who was called to court as a expert witness. It seems that a lady bought a lot and built a home next door to a home with 6 dogs. The dogs had been there for years, didn't bark abnormally, but did tear up the yard but hey, it's their yard. For some reason the folks decided they needed another dog and the neighbor took it as the final straw. She took them to court claiming "diminuation of value". Etc. After conferring with the appraiser, the judge noted that the dogs were there before she was and that after 6 dogs, one more just doesn't matter. After looking at the pictures, it seems to me that you have a lot of dogs in your neighborhood and one more just shouldn't matter. Keep after 'em. Bill S -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Kraut Sent: Tuesday, July 25, 2006 8:54 PM Lots of people have asked me to put up some pictures on my web site so they could get an idea on what my house looks like compared to the other houses in my neighbohood. Some people are assuming that I live in a beautiful neighborhood and I have an airplane junkyard on my front lawn. Looking at the pictres should give everyone a sense of what the truth really is. I have also added to the questions section. Look at www.jaxairplane.com. I really want to thank all of the people that have sent emails of support on this. I wish tat I could reply to each one individually, but I have literally hundreds and hundreds of emails and I can't reply to all of them. I also want to thank a lot of the people that have voiced their opinion and sided against me. With few exceptions, those giving an opinion different than mine have been courteous and not started an email flame war. It takes courage to express your opinion even when it goes against the general flow. In my fight against the city I am the one swimming upstream and I know how important it is to not just sit back and listen and to express your own opinion. We all share a love of aviation and homebuilding, but we all do not necessarily need to agree all the time. Brian Kraut brian(at)jaxairplane.com ________________________________________________________________________________
Date: Jul 26, 2006
Subject: Re: off-topic lawn tractor question
Check out the John Deere 2305. It's a SERIOUS "lawn mower" with either a mid or rear mower deck (I use the mid), and you can also get some pretty handy attachments including a front loader and a box blade, both great for runway maintenance. In reality, it's really a compact tractor rather than a lawn mower. With a 24hp diesel engine, this one will probably last long enough to dig my own grave when the time comes, and then they can bury me with it :-) Vern RV-7A QB Houston, TX ________________________________________________________________________________
Date: Jul 26, 2006
Subject: lawn tractor question
Stormy, I own a Gravley tractor w/ 52" deck Had it for 16 to 17 years and its good for more. Its expensive but its the last mower you will have to own. I've worn out one deck and on my second. (doesn't seem to be as good a quality as there are no grease fittings on the blade housings. It will out last me as long as I take care of it. Jim Nelson ________________________________________________________________________________
Date: Jul 26, 2006
Subject: Stuff For Sale
I have the following items for sale: ITEM CONDITION PRICE Angle of Attack (vans p/n IF AOA PRO) new $1,000 Microair 760 VHF Transciever slightly used $575 Rose Electroair electronic ignition used $400 RV-8(A) fiberglass wingtip light fairings new $10 Westach CHT gauge (p/n 2C1) new $15 Westach EGT gauge (p/n 2C2) new $15 If you need additional info, email me direct or give me a call at (423) 257-6566. Walt Shipley ________________________________________________________________________________
Date: Jul 26, 2006
Subject: Re: Anti Aviation Bill in Jacksonville
Hi Brian. You can move into my street any time you like, don't know about a couple of your neighbours though!!!!!! Which house is the nosy one???(just kidding) Our Neighbourhood Watch would love you, and if you are ill or needed a hand to clean up your yard, a few beers and a Bar-B-Que will fix it!!!!!!!! Kind Regards Noel ----- Original Message ----- Sent: Wednesday, July 26, 2006 1:53 PM > > Lots of people have asked me to put up some pictures on my web site so > they > could get an idea on what my house looks like compared to the other houses > in my neighbohood. Some people are assuming that I live in a beautiful > neighborhood and I have an airplane junkyard on my front lawn. Looking at > the pictres should give everyone a sense of what the truth really is. I > have also added to the questions section. Look at www.jaxairplane.com. > > I really want to thank all of the people that have sent emails of support > on > this. I wish tat I could reply to each one individually, but I have > literally hundreds and hundreds of emails and I can't reply to all of > them. > > I also want to thank a lot of the people that have voiced their opinion > and > sided against me. With few exceptions, those giving an opinion different > than mine have been courteous and not started an email flame war. It > takes > courage to express your opinion even when it goes against the general > flow. > In my fight against the city I am the one swimming upstream and I know how > important it is to not just sit back and listen and to express your own > opinion. We all share a love of aviation and homebuilding, but we all do > not necessarily need to agree all the time. > > Brian Kraut > brian(at)jaxairplane.com > > > -- > > ________________________________________________________________________________
Date: Jul 27, 2006
Subject: RV Builders Family Reunion BBQ at Oshkosh -- (long!)
Wednesday July 26, 2006 Got up early, met Darwin and we headed for the first Van's forum of the two he's giving at Oshkosh. And, of course, it was held in the #7 tent, the largest one, usually reserved for the likes of Rod Machado and Bert Rutan.Van brought Ken Krueger along. Van was Van and quickly gave way to Ken, who is an outstanding presenter and he ripped through a presentation on the RV-7, 9, and -- for the most part 10. He took a hand count before he started his presentation about who was interested in the 7, 9 and, 10 and it was clear within a very short timeframe that the RV-10 is now the king of the hill at Van's. He then concentrated on the RV-12, which is here. Darwin and I both were surprised that the RV-12 doesn't look at all like an RV. I happen to feel it's butt ugly with the pulled rivets but there's certainly a good reason for it since it's going to fly under Light Sport Aircraft rules and there's a speed limitation making flush rivets unnecessary, especially since ease of construction is supposed to be a key selling point. I suppose it's only a matter of time, though, until someone tries to put a 180 horsepower engine in the thing, and that idea opened the door for Van's to throw some darts consistent with his scathing article in the RVator a few months ago referring to "people who know more than the designers." Maybe he should just name the person he keeps quoting who, allegedly just "raised his gross weight by 300 pounds" to address weight and balance concerns of performance modifications. The other subject that came up was the nosegear allegations in the RV-7A. Ken was pretty direct in fielding it saying that as they've checked these nosegear rollovers that "there's more to the story" than what's on the various bulletin boards. Van quickly jumped in that they're not disregarding the complaints and they are taking a look at things. Ken's presentation was the first time I really paid a lot of attention to the RV-10 and it certainly is an impressive design. At the conclusion of the forum, Van said he'd be available to talk to builders at the tent, and then set a speed record of his own for darting out, leaving Ken behind to field a few questions. That was it for the forums for me, Darwin formed up and headed to Appleton for BBQ shopping. Now keep in mind I called Darwin a few weeks ago and said, "man, 150 people are coming!" and he said, "ahh, don' worry about it, I cook for that many people at family reunions." So we arrived at Sam's Club in Appleton and started the shopping. We got to the meat department and he said, "how many brats do we need?" "138," I said. "Whaaaaat?" he said. "I told you," I said. We bought about $600 worth of meat and potato salad and cole slaw and hoped the thunderstorms wouldn't return, leaving us to foot a very substantial bill. I dropped Darwin off at his campsite and headed back to the "Collins compound" to start setting up. I did the "preicing" on the beer and soft drinks and continued setting up. The clouds began to darken. Our plan was to start the grills at 5, get some stuff made so when people started showing up, we'd have some food for them. I dropped some parking credentials off to Jim Whitaker and Debbie Pennington of Lee's Summit , Missouri, who had just arrived at the Circle R campground, and headed back to the compound to get things going. As I arrived, the clouds opened up. All I could think of was what I was going to do with 60 pounds of cole slaw and about $2,000 worth of food. We huddled under our canopy when Frank Swart of Portage Michigan and his new bride, Joyce, pulled up in their RV. Frank and his brothers camped next to us last year and were a big help getting our BBQ pulled off last year. He saw what was happening and, like a pro trucker, brought his RV around to the back of the compound and unfolded a big awning. The 50 or so who had already shown up, including the folks at Trio Avionics, had a place to stay dry. Sort of. We moved the coolers around to keep people happy with beer and suddenly I was in a wet t-shirt contest as the rains came down and I got drenched. Anything's better than eating 50 pounds of cole slaw. Terry Frazier came by and quickly volunteered to help cook so we now had three cooks -- Howard Kaney, Darwin Barrie, and Terry Frazier. And the people kept coming. Larry Frey, who is a saint, pulled up with two big roaster pots full of baked beans. I finally got the tables configured, stacked high with buns, next to a table of beans, salads, cole slaw, potato salad etc. And the people kept coming. Bill Near started organizing the canopy operation and Rick Belsaas manned the sign-in area where people could pick up their name tag and, hopefully, make donation. And they kept coming. Then came tragedy. We were running out of beer...and maybe food too. So I grabbed $100 from the donations and Dave Domeier, UPS pilot and RV builder, headed to WalMart, stocked up with two shopping carts full of beer and got back within a half hour. "Who wants beer?" I said as came back in the compound which was now filled with more than 200 thirsty -- and hungry folks. "Forget the beer," Terry said, "we're running out of food." I hopped back in the car and headed back to WalMart. When I got there, my phone rang. It was Darwin. "We've got at least 100 people still in line to check in. WE need food and get all the beer you can and get back here FAST." We started out providing Corona and Leiningkugel, but we were now in Miller Lite and Budweiser mode. I picked up 3 additional watermelons, more buns, beer, 40 pounds of chicken and another 150 hamburger patties. The checkout women at WalMart asked if they could come to the party and then helped me take everything out to the car and load it. I got back in time to run into Dan Checkoway and it was a distinct pleasure to have him, and all of the RVers. It was cool to see the plane certainly to meet Dan. Dan sent a check before the barbecue, which is going uncashed, of course, because that man's money should be no good whenever he's in the company of other RVers. I can't imagine anyone who's done more for the rest of us except maybe Van himself and I'm not even sure if that's the case. I was sorry I didn't have more time to chat with everyone and I was just hoping everyone was having a good time. Since someone else had made another beer run, it appears they were as there were smiles all around. I think some people in line finally gave up on signing in and just came in the compound to chat becuase suddenly our food line disappeared and there we were with 4 cases of hamburgers and 12 cases of unused beer. Oh, and I'd also forgotten to get the rest of the potato chips out of the tent, along with two other cases of beer. Watermelon had already been cut so the the three I brought weren't needed. Things had slowed considerably and Darwin, Terry, and Howard could now relax a bit, I hoped, and get a chance to talk. There was applause all around, smiles everywhere and I was asked to say something. And here's what I said. "Someone had just reminded me that a few years ago, as I struggled with some parental issues, I'd lost enthusiasm for plane building and put my tail and wings up for sale. They talked me out of it and I'm glad they did becuase the fatherhood issues that demanded my time were resolved -- as they usually are -- and I can thank my fellow RVers for that. And while I'm here at Oshkosh by myself, I feel I'm also here with my family and I hoped everyone else felt the same way. But the folks who LITERALLY pulled the barbecue out of the fire were Darwin, Terry, and Howard for cooking, Larry Frey for doing just about everything a guy could do, Rich Emery for constantly showing up and bringing stuff, Bill Near and Rick Belsaas for pitching in. I can't possibly thank them enough. I then thanked Stein Bruch at SteinAir, who gave us a donation a few weeks ago "becuase that's what RVers should do." He didn't want any advertising. He didn't want anyone to even know what he was doing. But I put the STeinAir logo on all the nametags and it was the least we could do. I very much enjoyed meeting Stein and the gang he brought over from Direct To Avionics and TruTrak and Chelton. IN talking with him afterwards, we agreed that the barbecue should stay in Scholler because it's essentially for the "family reunion" vibe. This is really just a grassroots operation that just took off this year and clearly we're going to need bigger digs and a big tent and more grills -- and more beer. Oh, and we're going to need a better count on who is coming. I was taking Brad Oliver back to the blue lot late in the evening. He's heading home today and he was telling me everything he saw on his first trip to Oshkosh and he was very excited and then he said, "but tonight was the BEST part of being here." And that is why we do it and we thank everyone who came or wanted to come. You really ARE all family. Postscript. The campsite is almost all cleaned up. I got most of it done last night and Larry and Rich and Terry were all back this morning to finish the job. We ended up giving the left-over 10-12 cases of beer to Larry for a family reunion he has. We dropped the watermelons off over at the Civil Air Patrol kids' tent. As it turned out they lost their breakfast so they were hungry. We gave 'em the potato chips too. We had leftover single beers and stacks of buns and condiments that I put out on a table at the compound with a "free" sign and they're slowly going away. I haven't done all the financial stuff yet but with the expenses of about $2,000, the cost of the campsites and donations of about $2300, it looks like we're going to break out about even or slightly in the hole, but by a negligible amount. The one thing I regret is not having time to talk to many people but that's the price of hosting the BBQ. The point is to create a place where RVers can talk to each other. If you were in line and gave up, I'm very sorry. If you paid in advance and you didn't get food or beer, please let me know so we can return your money. We really want everyone to be happy and to have had a good time. I also didn't get an opportunity to take many pictures so if you took some, could you please send me copies. I've got nothing for the RV Builder's Hotline, especially since I lost the digital camera earlier this week. Aero News Network also sent a fine gentleman named Mark over to document our grassroots homecoming and hopefully that will be online soon. Please look for that. And who knows? Maybe next year will be the year that even Van's sends someone over. -------- Bob Collins St. Paul, Minn. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=50179#50179 ________________________________________________________________________________
Date: Jul 27, 2006
What an incredible write-up of an incredible get together. I'm planning to be there next year! Hope someone took pictures. John Jessen RV-10 Tailcone -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Collins Sent: Thursday, July 27, 2006 11:43 AM Wednesday July 26, 2006 Got up early, met Darwin and we headed for the first Van's forum of the two he's giving at Oshkosh. And, of course, it was held in the #7 tent, the largest one, usually reserved for the likes of Rod Machado and Bert Rutan.Van brought Ken Krueger along. Van was Van and quickly gave way to Ken, who is an outstanding presenter and he ripped through a presentation on the RV-7, 9, and -- for the most part 10. He took a hand count before he started his presentation about who was interested in the 7, 9 and, 10 and it was clear within a very short timeframe that the RV-10 is now the king of the hill at Van's. He then concentrated on the RV-12, which is here. Darwin and I both were surprised that the RV-12 doesn't look at all like an RV. I happen to feel it's butt ugly with the pulled rivets but there's certainly a good reason for it since it's going to fly under Light Sport Aircraft rules and there's a speed limitation making flush rivets unnecessary, especially since ease of construction is supposed to be a key selling point. I suppose it's only a matter of time, though, until someone tries to put a 180 horsepower engine in the thing, and that idea opened the door for Van's to throw some darts consistent with his scathing article in the RVator a few months ago referring to "people who know more than the designers." Maybe he should just name the person he keeps quoting who, allegedly just "raised his gross weight by 300 pounds" to address weight and balance concerns of performance modifications. The other subject that came up was the nosegear allegations in the RV-7A. Ken was pretty direct in fielding it saying that as they've checked these nosegear rollovers that "there's more to the story" than what's on the various bulletin boards. Van quickly jumped in that they're not disregarding the complaints and they are taking a look at things. Ken's presentation was the first time I really paid a lot of attention to the RV-10 and it certainly is an impressive design. At the conclusion of the forum, Van said he'd be available to talk to builders at the tent, and then set a speed record of his own for darting out, leaving Ken behind to field a few questions. That was it for the forums for me, Darwin formed up and headed to Appleton for BBQ shopping. Now keep in mind I called Darwin a few weeks ago and said, "man, 150 people are coming!" and he said, "ahh, don' worry about it, I cook for that many people at family reunions." So we arrived at Sam's Club in Appleton and started the shopping. We got to the meat department and he said, "how many brats do we need?" "138," I said. "Whaaaaat?" he said. "I told you," I said. We bought about $600 worth of meat and potato salad and cole slaw and hoped the thunderstorms wouldn't return, leaving us to foot a very substantial bill. I dropped Darwin off at his campsite and headed back to the "Collins compound" to start setting up. I did the "preicing" on the beer and soft drinks and continued setting up. The clouds began to darken. Our plan was to start the grills at 5, get some stuff made so when people started showing up, we'd have some food for them. I dropped some parking credentials off to Jim Whitaker and Debbie Pennington of Lee's Summit , Missouri, who had just arrived at the Circle R campground, and headed back to the compound to get things going. As I arrived, the clouds opened up. All I could think of was what I was going to do with 60 pounds of cole slaw and about $2,000 worth of food. We huddled under our canopy when Frank Swart of Portage Michigan and his new bride, Joyce, pulled up in their RV. Frank and his brothers camped next to us last year and were a big help getting our BBQ pulled off last year. He saw what was happening and, like a pro trucker, brought his RV around to the back of the compound and unfolded a big awning. The 50 or so who had already shown up, including the folks at Trio Avionics, had a place to stay dry. Sort of. We moved the coolers around to keep people happy with beer and suddenly I was in a wet t-shirt contest as the rains came down and I got drenched. Anything's better than eating 50 pounds of cole slaw. Terry Frazier came by and quickly volunteered to help cook so we now had three cooks -- Howard Kaney, Darwin Barrie, and Terry Frazier. And the people kept coming. Larry Frey, who is a saint, pulled up with two big roaster pots full of baked beans. I finally got the tables configured, stacked high with buns, next to a table of beans, salads, cole slaw, potato salad etc. And the people kept coming. Bill Near started organizing the canopy operation and Rick Belsaas manned the sign-in area where people could pick up their name tag and, hopefully, make donation. And they kept coming. Then came tragedy. We were running out of beer...and maybe food too. So I grabbed $100 from the donations and Dave Domeier, UPS pilot and RV builder, headed to WalMart, stocked up with two shopping carts full of beer and got back within a half hour. "Who wants beer?" I said as came back in the compound which was now filled with more than 200 thirsty -- and hungry folks. "Forget the beer," Terry said, "we're running out of food." I hopped back in the car and headed back to WalMart. When I got there, my phone rang. It was Darwin. "We've got at least 100 people still in line to check in. WE need food and get all the beer you can and get back here FAST." We started out providing Corona and Leiningkugel, but we were now in Miller Lite and Budweiser mode. I picked up 3 additional watermelons, more buns, beer, 40 pounds of chicken and another 150 hamburger patties. The checkout women at WalMart asked if they could come to the party and then helped me take everything out to the car and load it. I got back in time to run into Dan Checkoway and it was a distinct pleasure to have him, and all of the RVers. It was cool to see the plane certainly to meet Dan. Dan sent a check before the barbecue, which is going uncashed, of course, because that man's money should be no good whenever he's in the company of other RVers. I can't imagine anyone who's done more for the rest of us except maybe Van himself and I'm not even sure if that's the case. I was sorry I didn't have more time to chat with everyone and I was just hoping everyone was having a good time. Since someone else had made another beer run, it appears they were as there were smiles all around. I think some people in line finally gave up on signing in and just came in the compound to chat becuase suddenly our food line disappeared and there we were with 4 cases of hamburgers and 12 cases of unused beer. Oh, and I'd also forgotten to get the rest of the potato chips out of the tent, along with two other cases of be! er. Watermelon had already been cut so the the three I brought weren't needed. Things had slowed considerably and Darwin, Terry, and Howard could now relax a bit, I hoped, and get a chance to talk. There was applause all around, smiles everywhere and I was asked to say something. And here's what I said. "Someone had just reminded me that a few years ago, as I struggled with some parental issues, I'd lost enthusiasm for plane building and put my tail and wings up for sale. They talked me out of it and I'm glad they did becuase the fatherhood issues that demanded my time were resolved -- as they usually are -- and I can thank my fellow RVers for that. And while I'm here at Oshkosh by myself, I feel I'm also here with my family and I hoped everyone else felt the same way. But the folks who LITERALLY pulled the barbecue out of the fire were Darwin, Terry, and Howard for cooking, Larry Frey for doing just about everything a guy could do, Rich Emery for constantly showing up and bringing stuff, Bill Near and Rick Belsaas for pitching in. I can't possibly thank them enough. I then thanked Stein Bruch at SteinAir, who gave us a donation a few weeks ago "becuase that's what RVers should do." He didn't want any advertising. He didn't want anyone to even know what he was doing. But I put the STeinAir logo on all the nametags and it was the least we could do. I very much enjoyed meeting Stein and the gang he brought over from Direct To Avionics and TruTrak and Chelton. IN talking with him afterwards, we agreed that the barbecue should stay in Scholler because it's essentially for the "family reunion" vibe. This is really just a grassroots operation that just took off this year and clearly we're going to need bigger digs and a big tent and more grills -- and more beer. Oh, and we're going to need a better count on who is coming. I was taking Brad Oliver back to the blue lot late in the evening. He's heading home today and he was telling me everything he saw on his first trip to Oshkosh and he was very excited and then he said, "but tonight was the BEST part of being here." And that is why we do it and we thank everyone who came or wanted to come. You really ARE all family. Postscript. The campsite is almost all cleaned up. I got most of it done last night and Larry and Rich and Terry were all back this morning to finish the job. We ended up giving the left-over 10-12 cases of beer to Larry for a family reunion he has. We dropped the watermelons off over at the Civil Air Patrol kids' tent. As it turned out they lost their breakfast so they were hungry. We gave 'em the potato chips too. We had leftover single beers and stacks of buns and condiments that I put out on a table at the compound with a "free" sign and they're slowly going away. I haven't done all the financial stuff yet but with the expenses of about $2,000, the cost of the campsites and donations of about $2300, it looks like we're going to break out about even or slightly in the hole, but by a negligible amount. The one thing I regret is not having time to talk to many people but that's the price of hosting the BBQ. The point is to create a place where RVers can talk to each other. If you were in line and gave up, I'm very sorry. If you paid in advance and you didn't get food or beer, please let me know so we can return your money. We really want everyone to be happy and to have had a good time. I also didn't get an opportunity to take many pictures so if you took some, could you please send me copies. I've got nothing for the RV Builder's Hotline, especially since I lost the digital camera earlier this week. Aero News Network also sent a fine gentleman named Mark over to document our grassroots homecoming and hopefully that will be online soon. Please look for that. And who knows? Maybe next year will be the year that even Van's sends someone over. -------- Bob Collins St. Paul, Minn. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=50179#50179 ________________________________________________________________________________
Date: Jul 27, 2006
Sorry for the last post. Too excited. Forgot to trim and add the Do Not Archive. John Jessen RV-10 Tailcone -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Collins Sent: Thursday, July 27, 2006 11:43 AM Wednesday July 26, 2006 Got up early, met Darwin and we headed for the first Van's forum of the two he's giving at Oshkosh. ......... ________________________________________________________________________________
Date: Jul 27, 2006
Subject: High speed internet
Not exactly RV related but.....of interest if you are using dial-up to get the list. Recently there was some discussion by lister who do not have a high speed internet connection. If you are part of the group, are you aware of a satellite internet service called WildBlue similar to satillite TV? You can get info at: www.wildblue.net I have no connection/interest in this busines. Just thought I would pass info along. Dale Ensing ________________________________________________________________________________
Date: Jul 28, 2006
Subject: Re: High speed internet
The term High speed relative to Sattelite is a partial misnomer. I live on the wrong side of the interstate and cannot get cable. Dial up is unnacceptably slow and my only real option is sattelite. I have hughes.net (formerly direcway) and while it is significantly faster in the download(most of the time) it is no faster in the upload (no matter what the redhead on TV says) it ain't lightning fast. After 5 years I still am not used to the lag after clicking the mouse. During busy periods it slows to the speed of dialup and if there is rain to the South go take a coffee break cause you ain't gonna surf. On balance it is far better than dialup but when you converse with others it isn't in what I would call the high speed category. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=50280#50280 ________________________________________________________________________________
Date: Jul 28, 2006
As a fellow Hughes customer out in the boonies, I can say "amen" to all your observations and laments. After growing accustomed to the slow speed of DirecWay at home, the office DSL connection seems really nice, and my daughter's college library connection is almost mystical, as in "I haven't even hit "enter" yet and the page is already loaded!" Well, not really, but it's blink-of-an-eye fast. -Stormy -----Original Message----- Sent: Fri, 28 Jul 2006 9:03 AM The term High speed relative to Sattelite is a partial misnomer. I live on the wrong side of the interstate and cannot get cable. Dial up is unnacceptably slow and my only real option is sattelite. I have hughes.net (formerly direcway) and while it is significantly faster in the download(most of the time) it is no faster in the upload (no matter what the redhead on TV says) it ain't lightning fast. After 5 years I still am not used to the lag after clicking the mouse. During busy periods it slows to the speed of dialup and if there is rain to the South go take a coffee break cause you ain't gonna surf. On balance it is far better than dialup but when you converse with others it isn't in what I would call the high speed category. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=50280#50280 ________________________________________________________________________ ________________________________________________________________________________
From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
Date: Jul 28, 2006
Subject: Elevator TE Problem
I sent this to Van's yesterday and then realized that they, along with everyone else in the world and everyone else's brother, is up at OSH this week. Hello, 9A builder #1176 here. Starting TE on right elevator. The stiffeners prevent the TE from going in all the way - it sticks out about 1/16" past the skins. Options: 1) Trim the stiffeners. Since they're (obviously) installed, I can't see how I can realistically do this without damaging the skin. 2) Install the TE wedge sticking out 1/16" and leave it like that. There would be enough room from the rivets to the LE of the wedge for structural soundness. 3) Install the TE wedge as-is and file/trim it afterwards. None of these options is terribly inviting. Which is the best? ________________________________________________________________________________
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
Date: Jul 28, 2006
Subject: Re: Elevator TE Problem
I had a similar problem on my 7A rudder, only at the other end (stiffeners interfered with the spar). I slipped a thin piece of aluminum between the skin and the stiffener and used my dremel tool with a cutoff wheel - very carefully!! A fourth option is to trim the TE wedge locally to clear the stiffeners - mark the locations and 'deburr' away the TE wedge with your scotchbright wheel to clear the stiffeners. Dennis Glaeser 7A - Finishing Kit ------------------------------------------------------------------- 9A builder #1176 here. Starting TE on right elevator. The stiffeners prevent the TE from going in all the way - it sticks out about 1/16" past the skins. Options: 1) Trim the stiffeners. Since they're (obviously) installed, I can't see how I can realistically do this without damaging the skin. 2) Install the TE wedge sticking out 1/16" and leave it like that. There would be enough room from the rivets to the LE of the wedge for structural soundness. 3) Install the TE wedge as-is and file/trim it afterwards. ________________________________________________________________________________
From: "Evan and Megan Johnson" <evmeg(at)snowcrest.net>
Date: Jul 28, 2006
its been a while since I did mine but I am pretty sure they all stick out a bit.... Evan ----- Original Message ----- From: Folbrecht, Paul To: rv-list(at)matronics.com Sent: Friday, July 28, 2006 6:51 AM Subject: RV-List: Elevator TE Problem I sent this to Van's yesterday and then realized that they, along with everyone else in the world and everyone else's brother, is up at OSH this week. Hello, 9A builder #1176 here. Starting TE on right elevator. The stiffeners prevent the TE from going in all the way - it sticks out about 1/16" past the skins. Options: 1) Trim the stiffeners. Since they're (obviously) installed, I can't see how I can realistically do this without damaging the skin. 2) Install the TE wedge sticking out 1/16" and leave it like that. There would be enough room from the rivets to the LE of the wedge for structural soundness. 3) Install the TE wedge as-is and file/trim it afterwards. None of these options is terribly inviting. Which is the best? ________________________________________________________________________________
Date: Jul 28, 2006
Subject: Rear Prop Gov. Questions
I searched the archives, but couldn't find answers to these questions. I am thinking of putting an IO-360-A1A engine in my RV-7A. It has been flying with an IO-360-A1D6 which has a front mounted governor. Could someone on the list please tell me approximately what the thickness of the rear mounted prop governor adapter pad is on an IO-360-A1A? I have an old one that measures about 2 1/16 inches. Is there a thinner one available? The dimension I need is from the accessory case to the prop governor itself. Also, will the McCauley governor off the left front of my IO-360-A1D6 work on the rear of the -A1A? As far as I can tell there is about 3 percent difference in the drive ratio -- 0.866 vs 0.895. I would assume that the governor could be adjusted for this difference. Is there some other reason why it won't work? Thanks, Dan Hopper RV-7A ________________________________________________________________________________
Date: Jul 28, 2006
Subject: N710RV First Flight
First flight went off without a hitch today. Felt great. Plans are to fly every day for the next two weeks, either before or after work on the real job. Russ Daves ________________________________________________________________________________
Date: Jul 28, 2006
Subject: Re: re: off-topic lawn tractor question
Art Evans (owner of Dixie Chopper) is a bona-fide airplane nut and mad scientist. He has powered parachutes, ultralights, a RV-6A, a Citation, a Diamond aircraft dealership, hotel on the airport, FBO, on and on... At one point a few years ago he was developing an aircraft engine. He's a very unique individual, and is a down-to-earth good guy. Its rare to fly in to Putnam Co. airport and not find him there hanging out on the evenings and weekends. The restaurant has the best breakfast buffet around. In the non-summer months its not uncommon to find 15+ RV's there for breakfast on a Saturday morning. If I didn't already have a Woods zero-turn mower that doesn't seem to want to wear out I'd definitely go for a Dixie Chopper. Regards, Bob Japundza RV-6 flying F1 under const. > Funny you should ask! On the way to Oshkosh we stopped at a nice little > airport near Indianappolis. The "Dixie Chopper" lawn mowers are made there > and they were all over the place. One chasis was serving as the FBO's start > cart! They claim is is the fastest mower in the world and they look > positively tank-like. One has a 72-inch cut and twin engines with 54 > horsepower! That would probably mow the hump clean out of Hop-Along > airport! I didn't even ask how much, but I'm not in the market. Check out
July 13, 2006 - July 29, 2006
RV-Archive.digest.vol-sc
