RV-Archive.digest.vol-sd
July 29, 2006 - August 10, 2006
      > the web site:       http://www.dixiechopper.com/
Date: Jul 29, 2006
Subject: Re: N710RV First Flight
Quoting Russell Daves : > First flight went off without a hitch today. Felt great. Plans are to fly > every day for the next two weeks, either before or after work on the real > job. > > Russ Daves > > > Russ: CONGRATULATIONS,, I WISH I COULD HAVE A 10 ALSO BERT RV6A... ________________________________________________________________________________
Date: Jul 29, 2006
Subject: Cooling Blast tubes - Lycoming
RV7A - IO360 I'm planning to install 5/8" blast tubes from baffling to fuel pump, 1 mag, and alternator. Routing and securing to baffling is easy but any tricks on securing the end where the component is so the cooling blast actually hits the fuel pump? Adel clamps stategically placed? Pics? Thanks Steve RV7A flying soon! ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Jul 29, 2006
Subject: Re: Cooling Blast tubes - Lycoming
----- Original Message ----- Sent: Saturday, July 29, 2006 10:05 AM > > RV7A - IO360 > I'm planning to install 5/8" blast tubes from baffling to fuel pump, 1 > mag, > and alternator. > > Routing and securing to baffling is easy but any tricks on securing the > end > where the component is so the cooling > blast actually hits the fuel pump? Adel clamps stategically placed? > Pics? > > Thanks > Steve > RV7A flying soon! > ((((((((())))))))) I found a good bit of use for safety wire when securing the blast tubes to keep them aimed where wanted. Simple to use. Indiana Larry with one trip to OSH completed. > ________________________________________________________________________________
Date: Jul 29, 2006
Subject: PPG Paint Code
Hi List, I am trying to match colors in cockpit. Does anyone have the PPG Paint Code to match the powder coat finished steel parts? Thanks in advance. Randy Hooper RV-8 ________________________________________________________________________________
Date: Jul 29, 2006
Subject: Re: PPG Paint Code
Van's has the Cardnial paint code on their site, maybe you can have PPG cross referance it. My new email address: bobbyhester(at)charter.net Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ RV7A N857BH SB wings-QB Fuse-XPO360 engine :-) Randy Hooper wrote: > Hi List, I am trying to match colors in cockpit. Does anyone have > the PPG Paint Code to match the powder coat finished steel parts? > Thanks in advance. > > Randy Hooper > RV-8 > ________________________________________________________________________________
Date: Jul 29, 2006
Subject: Re: exhaust bolt torque
The torque values you are looking up are for airframe bolts. The Lycoming Direct Drive Overhaul Manual has it's own set of default torque values.. and they are only for the coarse thread bolts (no fine thread bolts on the engine) #10 49 in. lb. 1/4 96 in. lb. 5/16 204 in. lb. 3/8 360 in. lb. 7/16 600 in. lb. 1/2 900 in. lb. They also call for lubricated threads except when otherwise specified. Lycoming also has another set of instructions for crush type copper/asbestos gaskets - which I believe the exhaust gaskets would fall under. In this case, for a 18 threads to the inch bolt/stud, tighten until surfaces are in contact and then tighten another 135 degrees. This is only if the exhaust gaskets fall under the description of a "crush type" gasket Perhaps a A&P can help out here... I'm only an airframe mechanic... [Wink] ... but I got the Lycoming book... gil in Tucson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=50666#50666 ________________________________________________________________________________
Date: Jul 30, 2006
The bottle of touch up paint,I got from Van's, has on the label that it is a PPG Concept paint. Will get the name and number when I am at the hangar tomorrow. Steve Eberhart RV-7A, almost ready to flip the canoe. Bobby Hester wrote: > > Van's has the Cardnial paint code on their site, maybe you can have > PPG cross referance it. > > My new email address: bobbyhester(at)charter.net > Surfing the Web from Hopkinsville, KY > Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/ > RV7A N857BH SB wings-QB Fuse-XPO360 engine :-) > > > Randy Hooper wrote: > >> Hi List, I am trying to match colors in cockpit. Does anyone have >> the PPG Paint Code to match the powder coat finished steel parts? >> Thanks in advance. >> >> Randy Hooper >> RV-8 > ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Date: Jul 30, 2006
Subject: Lightspeed Ignition
Quick question on LSE: I've got the version with the sensor board that mounts behind the flywheel. Bad part of this setup is routing the sensor cable back to the controller box. I've tentatively routed this wire under the crankcase with and an adel clamp under one of the baffle bracket screws secures the wire up front. The wire runs under the engine at the base of the cylinders to the firewall. Problem is I don't really have any way to secure it down there. Those who have this setup, could you email me with some description or better yet, photos of what you did here? I need to resolve this somehow. Thanks. Dean Psiropoulos RV-6A N197DM Wiring, wiring and....wiring! ________________________________________________________________________________
Date: Jul 30, 2006
Subject: Recommendations for Iridium plugs?
I'd like to replace my Champion plugs with something that is less suseptable to fouling. I don't know whether I should go with just a new set Champions, or perhaps Iridiium plugs or another type. Any recommendation from Listers would be most appreciated. I'm flying a -4 with an IO-360 with Lasar ingnition. Thanks, Dean Bolton, MA _________________________________________________________________ ________________________________________________________________________________
Date: Jul 30, 2006
Subject: Re: Lightspeed Ignition
Dean, I have lots of detailed photos of my LSE installation. I have to run at the moment but I'll get you some photos later today. Doug Weiler N722DW, RV-4 ----- Original Message ----- Sent: Sunday, July 30, 2006 2:33 AM > > > Quick question on LSE: > > I've got the version with the sensor board that mounts behind the > flywheel. > Bad part of this setup is routing the sensor cable back to the controller > box. I've tentatively routed this wire under the crankcase with and an > adel > clamp under one of the baffle bracket screws secures the wire up front. > The > wire runs under the engine at the base of the cylinders to the firewall. > Problem is I don't really have any way to secure it down there. Those who > have this setup, could you email me with some description or better yet, > photos of what you did here? I need to resolve this somehow. Thanks. > > Dean Psiropoulos > RV-6A N197DM > Wiring, wiring and....wiring! > > > ________________________________________________________________________________
Date: Jul 30, 2006
Randy, I had the powder coat color matched - number is DCC92783RQ for the PPG Concept paint according to my receipt. The color was an exact match for Van's parts.. Hope this helps. Tom Gesele RV-10 #40473 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Randy Hooper Sent: Saturday, July 29, 2006 10:49 PM To: rv-list(at)matronics.com Subject: RV-List: PPG Paint Code Hi List, I am trying to match colors in cockpit. Does anyone have the PPG Paint Code to match the powder coat finished steel parts? Thanks in advance. Randy Hooper RV-8 ________________________________________________________________________________
Date: Jul 30, 2006
I did just like you, with an adel clamp on the baffle screw. I also put another adel clamp on the case/sump bolts in one or two spots as the wire runs aft. Presumably you have a fat starter wire running in that vicinity as well. You could also run the LSE wire along that wire. Whatever works! )_( Dan RV-7 N714D (1021 hours) http://www.rvproject.com ----- Original Message ----- Sent: Sunday, July 30, 2006 12:33 AM > > > Quick question on LSE: > > I've got the version with the sensor board that mounts behind the > flywheel. > Bad part of this setup is routing the sensor cable back to the controller > box. I've tentatively routed this wire under the crankcase with and an > adel > clamp under one of the baffle bracket screws secures the wire up front. > The > wire runs under the engine at the base of the cylinders to the firewall. > Problem is I don't really have any way to secure it down there. Those who > have this setup, could you email me with some description or better yet, > photos of what you did here? I need to resolve this somehow. Thanks. > > Dean Psiropoulos > RV-6A N197DM > Wiring, wiring and....wiring! > > > ________________________________________________________________________________
Date: Jul 30, 2006
Subject: Re: Recommendations for Iridium plugs?
> The other cure is to lean the crap out of the engine at all times ..... > from startup to shutdown. At any altitude. I know, that's not what > Lycoming recommends, so don't waste the bandwidth busting my chops. > Leaning agressively, like mogas, has worked for me and has for years. Excellent suggestions assuming the cause is lead fouling. Another one that has worked for a lot of people is to use a lead scavenger like Decalin TCP Plus. http://www.decalinchemicals.com/ -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Jul 30, 2006
In a message dated 7/30/2006 5:58:51 A.M. Pacific Daylight Time, pitts_pilot(at)bellsouth.net writes: The cure on lesser engines is the REM 37BY, but I don't know if they'll fit in the O-360. ================================ I can tell you they work fine in my O-360. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 30, 2006
In a message dated 7/30/2006 5:41:37 A.M. Pacific Daylight Time, deanpichon(at)msn.com writes: I'd like to replace my Champion plugs with something that is less susceptible to fouling. I don't know whether I should go with just a new set Champions, or perhaps Iridium plugs or another type. Just switch to the REM37BY. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 30, 2006
Gil, I don't have the overhaul manual but I need the size of the bolts that go into the machined boss that was origionally used for the generator on the lycoming o-360. This is an area that has three tapped holes just on the generator side of the case. It is bigger than a 1/4" but not 5/16". I want to support the starter cable as it leaves the starter and heads back to the start solenoid. With an adel clamp in that position, it will releive strain where the start cable attaches to the starter. Jim Nelson ________________________________________________________________________________
Date: Jul 30, 2006
Jim... I don't have my parts manual here - a different book from the overhaul manual - but Lycoming only uses US coarse thread screws. If it's not 1/4, then I bet it's a 5/16-18 Buy a cheap 5/16 bolt from the hw store and see if it threads in. It should not be an odd size. gil in Tucson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=50740#50740 ________________________________________________________________________________
Date: Jul 30, 2006
The REM37BY are approved. If you want more plug details, Lycoming has their approved spark plug list on the web at http://www.lycoming.textron.com/support/publications/maintenancePublications/serviceInstructions/SI1042X.pdf gil in Tucson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=50741#50741 ________________________________________________________________________________
Date: Jul 30, 2006
Gary, any idea how these would work with a magneto ignition? My IO-360 on my -4 fouls the bottom plugs really easily, and have to be cleaned every oil change in order keep them running well. Paul Besing Vanremog(at)aol.com wrote: In a message dated 7/30/2006 5:41:37 A.M. Pacific Daylight Time, deanpichon(at)msn.com writes: I'd like to replace my Champion plugs with something that is less susceptible to fouling. I don't know whether I should go with just a new set Champions, or perhaps Iridium plugs or another type. Just switch to the REM37BY. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) --------------------------------- See the all-new, redesigned Yahoo.com. Check it out. ________________________________________________________________________________
Date: Jul 30, 2006
They ought to work just fine with mags. I run UREM37BY plugs with my Slick mag on my IO-360-A1B6. Bottom plugs. I have yet to experience a fouled plug in more than 1000 hours. Granted, I have a Lightspeed Plasma II firing the top plugs, which must help...but at least the UREM37BY plugs on the bottom haven't had any issues. )_( Dan RV-7 N714D (1021 hours) http://www.rvproject.com ----- Original Message ----- From: Paul Besing To: rv-list(at)matronics.com Sent: Sunday, July 30, 2006 10:18 AM Subject: Re: RV-List: Recommendations for Iridium plugs? Gary, any idea how these would work with a magneto ignition? My IO-360 on my -4 fouls the bottom plugs really easily, and have to be cleaned every oil change in order keep them running well. Paul Besing Vanremog(at)aol.com wrote: In a message dated 7/30/2006 5:41:37 A.M. Pacific Daylight Time, deanpichon(at)msn.com writes: I'd like to replace my Champion plugs with something that is less susceptible to fouling. I don't know whether I should go with just a new set Champions, or perhaps Iridium plugs or another type. Just switch to the REM37BY. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ------------------------------------------------------------------------- ----- See the all-new, redesigned Yahoo.com. Check it out. ________________________________________________________________________________
Date: Jul 30, 2006
Watch out for those crush type exhaust gaskets. I had one of those burn through allowing the nuts to loosen and fall off. The pipe was found hanging (barely) on the end of the stud. I replaced it with a solid "blow proof" gasket. I checked the other 3 gaskets when we got home and they all showed signs of damage and some leakage. Replaced all. 700 hours on engine at the time. Ed Holyoke >Lycoming also has another set of instructions for crush type copper/asbestos gaskets - which I believe the exhaust gaskets would fall under. >In this case, for a 18 threads to the inch bolt/stud, tighten until surfaces are in contact and then tighten another 135 degrees. >This is only if the exhaust gaskets fall under the description of a "crush type" gasket Perhaps a A&P can help out here... I'm only an airframe mechanic... [Wink] ... but I got the Lycoming book... >gil in Tucson ________________________________________________________________________________
Date: Jul 30, 2006
Subject: Re: Cooling Blast tubes - Lycoming (do it right)
Suggest you get a REAL fuel pump cooling shroud. select products and sroll down to bottom. http://showplanes.com/index_800.htm here is a picture. http://showplanes.com/images/prod_thumbnail(shroud).jpg You want to shield from radiant heat as well as shroud in cool air. Cheers George >posted by: "LarryRobertHelming" > > > RV7A - IO360 > I'm planning to install 5/8" blast tubes from baffling to fuel pump, 1 > mag, > and alternator. > > Routing and securing to baffling is easy but any tricks on securing the > end > where the component is so the cooling > blast actually hits the fuel pump? Adel clamps stategically placed? > Pics? > > Thanks > Steve > RV7A flying soon! > ((((((((())))))))) I found a good bit of use for safety wire when securing the blast tubes to keep them aimed where wanted. Simple to use. Indiana Larry with one trip to OSH completed. > --------------------------------- ________________________________________________________________________________
Date: Jul 30, 2006
Best place to get them? Anything special that needs to be done for the gap? Paul Besing Dan Checkoway wrote: They ought to work just fine with mags. I run UREM37BY plugs with my Slick mag on my IO-360-A1B6. Bottom plugs. I have yet to experience a fouled plug in more than 1000 hours. Granted, I have a Lightspeed Plasma II firing the top plugs, which must help...but at least the UREM37BY plugs on the bottom haven't had any issues. )_( Dan RV-7 N714D (1021 hours) http://www.rvproject.com ----- Original Message ----- From: Paul Besing To: rv-list(at)matronics.com Sent: Sunday, July 30, 2006 10:18 AM Subject: Re: RV-List: Recommendations for Iridium plugs? Gary, any idea how these would work with a magneto ignition? My IO-360 on my -4 fouls the bottom plugs really easily, and have to be cleaned every oil change in order keep them running well. Paul Besing Vanremog(at)aol.com wrote: In a message dated 7/30/2006 5:41:37 A.M. Pacific Daylight Time, deanpichon(at)msn.com writes: I'd like to replace my Champion plugs with something that is less susceptible to fouling. I don't know whether I should go with just a new set Champions, or perhaps Iridium plugs or another type. Just switch to the REM37BY. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) --------------------------------- See the all-new, redesigned Yahoo.com. Check it out. --------------------------------- ________________________________________________________________________________
Date: Jul 30, 2006
[quote="pbesing(at)yahoo.com"]Best place to get them?? Anything special that needs to be done for the gap? ? Paul Besing Vans sells them.... keep him in business.... :D His prices are good too.. gil in Tucson PS the Unison ones are shorter than the Champions, and allow a shorter socket... making easier removal on #3 and #4 were the side baffles are close. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=50786#50786 ________________________________________________________________________________
Date: Jul 30, 2006
I added some more photos to my Flickr page showing my LSE installation. Take a look: http://www.flickr.com/photos/n722dw/sets/72157594147109903/ Doug N722DW, 200 hours ----- Original Message ----- Sent: Sunday, July 30, 2006 8:08 AM > Dean, > > I have lots of detailed photos of my LSE installation. I have to run at > the moment but I'll get you some photos later today. > > Doug Weiler > N722DW, RV-4 > > > ----- Original Message ----- > From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> > To: > Sent: Sunday, July 30, 2006 2:33 AM > Subject: RV-List: Lightspeed Ignition > > >> >> >> Quick question on LSE: >> >> I've got the version with the sensor board that mounts behind the >> flywheel. >> Bad part of this setup is routing the sensor cable back to the controller >> box. I've tentatively routed this wire under the crankcase with and an >> adel >> clamp under one of the baffle bracket screws secures the wire up front. >> The >> wire runs under the engine at the base of the cylinders to the firewall. >> Problem is I don't really have any way to secure it down there. Those >> who >> have this setup, could you email me with some description or better yet, >> photos of what you did here? I need to resolve this somehow. Thanks. >> >> Dean Psiropoulos >> RV-6A N197DM >> Wiring, wiring and....wiring! >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > ________________________________________________________________________________
Date: Jul 30, 2006
Yeah... Dan... but..... Sky Geek is only 5 cents less than Vans.... I'd rather keep Vans in long term business than Sky Geek.... :D gil in Tucson ... trying to keep my $$$ where they do good.... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=50820#50820 ________________________________________________________________________________
From: "Michael D. Cencula" <matronics(at)cencula.com>
Date: Jul 30, 2006
Subject: Elevator trailing edge bend radius (RV-7A)
Greetings, I'm building the jig to bend the trailing edges of the elevators on my RV-7A. Does anyone know the correct bend radius for these trailing edges? Thanks, Mike ________________________________________________________________________________
Date: Jul 30, 2006
Randy, The gray that Vans uses is a standard PPG color. It's called Pearl Gray. Paint code is 92783. This color code can be used for any PPG product. Most folks use their Concept or Delta products. I'm using the Delta (next step up from Concept) and I love it. The stuff is easy to spray, has great coverage and is tough as nails. Charlie Kuss > Hi List, I am trying to match colors in cockpit. Does anyone have > the PPG Paint Code to match the powder coat finished steel parts? > Thanks in advance. > >Randy Hooper >RV-8 > ________________________________________________________________________________
Date: Jul 30, 2006
In a message dated 7/30/2006 10:20:50 A.M. Pacific Daylight Time, pbesing(at)yahoo.com writes: Gary, any idea how these would work with a magneto ignition? My IO-360 on my -4 fouls the bottom plugs really easily, and have to be cleaned every oil change in order keep them running well. ======================================== Paul- I am running the REM37BY plugs with standard Slick Mags. Just gap them for .019" and they still won't foul like the old REM38E or REM40E massives. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 30, 2006
Subject: Re: Air Oil Separators
In a message dated 7/30/2006 10:14:53 A.M. Pacific Daylight Time, luckymacy(at)comcast.net writes: Any make/model preference on these things? I was surprised to see such a wide range of options in the ACS catalogue. I don't know anyone who is actually using one so this one goes out to the list. =========================== Get the 3/4" dia port one from Wicks (P/N OIL-BS3/4) for around $50 and do the pot scrubber mod defined in the archives. It's a no brainer. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Jul 30, 2006
Thanks, it's more like $87.50 now and looks suspiciously like the $50 one in ACS! lucky -------------- Original message -------------- In a message dated 7/30/2006 10:14:53 A.M. Pacific Daylight Time, luckymacy(at)comcast.net writes: Any make/model preference on these things? I was surprised to see such a wide range of options in the ACS catalogue. I don't know anyone who is actually using one so this one goes out to the list. =========================== Get the 3/4" dia port one from Wicks (P/N OIL-BS3/4) for around $50 and do the pot scrubber mod defined in the archives. It's a no brainer. GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA)
lucky
Date: Jul 30, 2006
In a message dated 7/30/2006 4:47:28 P.M. Pacific Daylight Time, luckymacy(at)comcast.net writes: Thanks, it's more like $87.50 now and looks suspiciously like the $50 one in ACS! lucky -------------- Original message -------------- In a message dated 7/30/2006 10:14:53 A.M. Pacific Daylight Time, luckymacy(at)comcast.net writes: Any make/model preference on these things? I was surprised to see such a wide range of options in the ACS catalogue. I don't know anyone who is actually using one so this one goes out to the list. =========================== Get the 3/4" dia port one from Wicks (P/N OIL-BS3/4) for around $50 and do the pot scrubber mod defined in the archives. It's a no brainer. Ask ACS why they don't sell the 3/4" port version. They are made by the same company. ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Date: Jul 30, 2006
Mike I used an 1/8 inch wood dowel. I did tape the dowel in so it wood remain in position. and I also taped the bottom edge of the elevator to the bending break. I also couldn't believe how much force)it took to get the edge to be straight/true/and the correct radius. Frank @ SGU and SLC finish................ >From: "Michael D. Cencula" <matr onics(at)cencula.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Elevator trailing edge bend radius (RV-7A) >Date: Sun, 30 Jul 2006 18:58:48 -0400 > > >Greetings, > >I'm building the jig to bend the trailing edges of the elevators on my >RV-7A. >Does anyone know the correct bend radius for these trailing edges? > >Thanks, > >Mike > > ________________________________________________________________________________
Date: Jul 30, 2006
Subject: Re: Elevator trailing edge bend radius (RV-7A)
Mike, if you want a nice flying airplane in pitch feel use a 1/4" dowel. The tighter the radius, the heavier the airplane will be in pitch. Regards, Bob Japundza RV-6 flying F1 under const. On 7/30/06, Michael D. Cencula wrote: > > > > > Greetings, > > I'm building the jig to bend the trailing edges of the elevators on my > RV-7A. > Does anyone know the correct bend radius for these trailing edges? > > Thanks, > > Mike > > ________________________________________________________________________________
Date: Jul 30, 2006
Mike, On Drawing 4pp it shows 3/32 as the minimum bend radius. This was for .020 skins when I built mine about 5 years ago. Actually, I didn't put anything in to maintain that radius. But I did have a little trouble with the stiffeners limiting the travel. As a result the skins are not as smooth as they could be. I made my "brake" out of some old door jambs and hinges. It seems like it would be hard to keep a dowel in position. Let us know how it works out, please. Dan Hopper RV-7A In a message dated 7/30/2006 7:03:38 P.M. Eastern Daylight Time, matronics(at)cencula.com writes: I'm building the jig to bend the trailing edges of the elevators on my RV-7A. Does anyone know the correct bend radius for these trailing edges? Thanks, Mike ________________________________________________________________________________
Date: Jul 31, 2006
Subject: TBM Avenger / RV-6 accident at OSH
Hey guys, I'm reluctant to post this but feel like I need to share it in hopes it never happens again. I was at OSH this morning (Sunday) and due to the rain showers my 5-year old son Skyler and I decided to hang out at the flightline for a while until the wx improved for our flight home. There was a whole line of aircraft coming down the taxiway right in front of us to depart OSH. I noticed a white RV-6 with blue striped trim waiting in line a couple hundred feet from us, coming towards us, and right behind him was a huge TBM Avenger. The thought passed through my mind that somebody out working the flightline should be standing off to the side of the TBM to give him signals for taxiing, since it was virtually impossible for him to see the RV over his nose even with S-turns. My thoughts were interrupted by the roar of jet engines as a couple L-39's took off in formation followed by a couple Pitts Model 12's and other interesting aircraft. I looked back down the taxiway just in time to see the RV-6, now less than a hundred feet from us, coming to a stop with the TBM still right behind it. We watched in shock as the TBM continued right into the tail of the RV. At that moment I was only thinking about how bad it would be to have your tail chewed up by somebody's propeller, but that thought turned to horror as the TBM continued to move, wacking through the fuselage and sending strips of metal flying. When it got to the baggage compartment, clothing and other gear was being strewn into the air and across the grass. I should have closed my eyes before it got to the cockpit. I'll spare you the details but suffice it to say it was horrific. The prop on the TBM finally stopped somewhere in the vicinity of the rollbar / panel but of course by that time it was too late....the fire truck and other rescue personnel were there in moments by I knew there was nothing they could do but pull out the white sheet and drape it over the mess. I don't know who the unfortunate RV pilot was (and by the way, I'm not sure he was solo, but I think he was). Regardless, I've been feeling physically ill all day and the scene just keeps replaying in my mind. It seems like such a preventable accident....I know the poor guy in the Avenger will get the blame (and I sure feel sorry for him too!) but it was really a failure of the system when a spotter along side the TBM would have prevented this tragic loss of life. Even though there's probably nothing I could have done, I still feel sick about it, because I noticed the situation and regret that I didn't at least try to point it out to one of the busy flightline volunteers... I hope the folks at EAA make it standard policy from now on to have spotters available to help out any taildragger pilot who needs a second set of eyes for taxiing. And it's a good reminder to be extra vigilant not only at Oshkosh but at any airport to pay attention to who's behind you. We're used to looking right/left/forward when moving about the airport but if you're like me you don't worry too much about what's behind you. Well, when we left OSH this afternoon in the -8A, there was a T-6 behind us and I can guarantee you we were nervously checking our six about every 10 seconds to make sure he wasn't getting too close. My heartfelt condolences and deepest sympathies go out to the family of the unfortunate RV-6 pilot we lost today. --Mark Navratil Cedar Rapids, Iowa RV-8A N2D with 70+ hours of cheating death so far... ________________________________________________________________________________
Date: Jul 30, 2006
Subject: Re: TBM Avenger / RV-6 accident at OSH
Mark E Navratil wrote: > >Hey guys, > >I'm reluctant to post this but feel like I need to share it in hopes it >never happens again. > http://seattlepi.nwsource.com/national/1110AP_Airshow_Fatality.html?source=mypi ________________________________________________________________________________
From: "czechsix(at)juno.com" <czechsix(at)juno.com>
Date: Jul 31, 2006
Subject: RE: TBM Avenger / RV-6 accident at OSH
Ok, I see the news story that the pax was killed and the pilot survived. I hate spreading misinformation so I apologize for not getting the fact s straight....I'm also amazed that anyone in that cockpit could have sur vived the accident! We were watching from the passenger's side of the R V at a slight angle when it happened, after the loud noises stopped the prop was in the cockpit area and the canopy was gone....and I couldn't s ee anybody at all in the cockpit. We watched for a few minutes and I did n't see anybody get out. When the rescue crew arrived, they took a look inside and then backed everybody away and appeared to be covering it up with white sheets when we left the scene (remember I had a 5 year old wi th me so we didn't stick around for a long time...). So what I saw seeme d to confirm that there was no possibility of survivors. Anyway, very glad the pilot miraculously escaped and next time I'll chec k the news before posting something of serious nature like this... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D
Ok, I see the news story that the pax was killed and the pilot surviv ed. I hate spreading misinformation so I apologize for not getting the f acts straight....I'm also amazed that anyone in that cockpit could have survived the accident!  We were watching from the passenger's side of the RV at a slight angle when it happened, after the loud noises stop ped the prop was in the cockpit area and the canopy was gone....and I co uldn't see anybody at all in the cockpit. We watched for a few minutes a nd I didn't see anybody get out. When the rescue crew arrived, they took a look inside and then backed everybody away and appeared to be&nb sp;covering it up with white sheets when we left the scene (remember I h ad a 5 year old with me so we didn't stick around for a long time...). S o what I saw seemed to confirm that there was no possibility of survivor s.
Anyway, very glad the pilot miraculously escaped and next time I'll c heck the news before posting something of serious nature like this...
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D
Date: Jul 31, 2006
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Oil temp limits
I have noticed my newer engine is running hotter oil temp than the older one. Used to be 190-200 max. now its going up to 220-230. Anyone can say for sure what max norm opr and also max safe temp should be? Charlie Heathco ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Further thread on airborne weather services!
Has anyone tried a CELL PHONE weather system with success or failure? Primarily due to limited cockpit space, I am considering buying a new cell phone with a larger than average screen and using Velcro to attach it to the panel. Do you like/dislike your weather on the cell phone? Whose service do you have/have tried in the past? What problems does anyone see with it? i.e. Is it illegal to use cell phone in an airplane? What were the costs involved? Connection fee? Monthly service? Additional minutes, etc? Thanks listers, you are a walking encyclopedia of knowledge, Les Featherston ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Re: Further thread on airborne weather services!
Les, first try using your cell phone for voice or text from the plane. It can be a frustrating excercise unless you're down low. You'll want to experiment before spending the bucks, unless getting wx only before departure is what you're after. That said, I was able to make several phone calls from the air this weekend, checking out the aux feature of my new LightSpeed Mach one headset (worked beautifully) but I was only at about 1500' AGL at the time. As to cellular or in-cockpit wx services, never used them yet so cannot comment intelligently. Hope this helps. -----Original Message----- Sent: Mon, 31 Jul 2006 12:32 PM Has anyone tried a CELL PHONE weather system with success or failure? Primarily due to limited cockpit space, I am considering buying a new cell phone with a larger than average screen and using Velcro to attach it to the panel. Do you like/dislike your weather on the cell phone? Whose service do you have/have tried in the past? What problems does anyone see with it? i.e. Is it illegal to use cell phone in an airplane? What were the costs involved? Connection fee? Monthly service? Additional minutes, etc? Thanks listers, you are a walking encyclopedia of knowledge, Les Featherston ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Who from MT was at OSH
Just lookig to find out who from MT was there. I'm expecting my prop back from MT in FL - getting the correct length hub/spinner to fit my SamJames cowl. Ralph Capen ________________________________________________________________________________
Date: Jul 31, 2006
I have used Ram-Page Cell phone weather service http://avwx.net/home.php. It only cost around $7.00/month at the time, I think for the price it was a great service. Having said that, it could be frustratingly slow in downloading radar/satellite photos. I tried to use it once airborne, but was at 7500 ft over west central Texas where cell towers are not plentiful. I did use it to check weather when landing at air patches with no computer connections. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW ----- Original Message ----- From: Morocketman(at)aol.com To: rv-list(at)matronics.com Sent: Monday, July 31, 2006 12:32 PM Subject: RV-List: Further thread on airborne weather services! Has anyone tried a CELL PHONE weather system with success or failure? Primarily due to limited cockpit space, I am considering buying a new cell phone with a larger than average screen and using Velcro to attach it to the panel. Do you like/dislike your weather on the cell phone? Whose service do you have/have tried in the past? What problems does anyone see with it? i.e. Is it illegal to use cell phone in an airplane? What were the costs involved? Connection fee? Monthly service? Additional minutes, etc? Thanks listers, you are a walking encyclopedia of knowledge, Les Featherston ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Rear Prop Gov. Questions
I posted this last week, but didn't get answers. Maybe someone on the list could point me to a picture of a rear mounted prop governor so I could get a feel for how much room there is. Probably an O-360 would be the same. Thanks, Dan I searched the archives, but couldn't find answers to these questions. I am thinking of putting an IO-360-A1A engine in my RV-7A. It has been flying with an IO-360-A1D6 which has a front mounted governor. Could someone on the list please tell me approximately what the thickness of the rear mounted prop governor adapter pad is on an IO-360-A1A? I have an old one that measures about 2 1/16 inches. Is there a thinner one available? The dimension I need is from the accessory case to the prop governor itself. Also, will the McCauley governor off the left front of my IO-360-A1D6 work on the rear of the -A1A? There is about 3 percent difference in the drive ratio -- 0.866 vs 0.895. I would assume that the governor could be adjusted for this difference. Is there some other reason why it won't work? Thanks, Dan Hopper RV-7A ________________________________________________________________________________
Date: Jul 31, 2006
Subject: RV 10 Mike Seager training at (1m5)
Mike Saeger will be in Portland,Tn (1M5) 50 miles north of Nashville,Tn Sept 13,14,15..He will be giving flight training in the factory RV-10..The cost is $155.00 per Hr.If you are interested in flying with Mike, please E-Mail me at (rv6(at)earthlink.net) or call me at 615-452-8742..When I get a feel for who is interested I will set up a schedule to accommodate you..First come first serve!! There is a Motel in Franklin,Ky $98.00 nite,270-598-8001 Hampton Inn.. John McMahon (RV6 180/CS) Flying Gallatin,Tn ________________________________________________________________________________
Date: Jul 31, 2006
Subject: oil cooler and vernatherm
I am considering purchasing the oil cooler shutter that Vans offers, but dont exactly understand the need for this product. Shouldnt a correctly operating vernatherm, which most of our engines come with, do the same job, or am I missing something? Erich Weaver ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Re: Oil temp limits
In a message dated 7/31/06 12:26:00 PM Eastern Daylight Time, cheathco(at)cox.net writes: > I have noticed my newer engine is running hotter oil temp than the older one. > Used to be 190-200 max. now its going up to 220-230. > Anyone can say for sure what max norm opr and also max safe temp should be? > Charlie Heathco ================================= Charlie: You did not mention which engine you have? Most engine manufactures recommend 245 - 250 Deg F as the Max point. This is also the accepted point by oil manufactures as well. You are correct you will be seeing higher oil and CHT's with a new engine, it is breaking in. Keep your climbs shallow, air speed high and the RPMs high also. Don't baby the engine, oil consumption should stabilize in 50 hours or a little less. Change your oil after the first 10 hours and then at 20 hour intervals until oil consumption is stabilized Your 220 - 230 Deg F is quite normal especially for this time of year. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Jul 31, 2006
In a message dated 7/31/06 12:26:00 PM Eastern Daylight Time, cheathco(at)cox.net writes: > I have noticed my newer engine is running hotter oil temp than the older one. > Used to be 190-200 max. now its going up to 220-230. > Anyone can say for sure what max norm opr and also max safe temp should be? > Charlie Heathco ============================= Charlie: A PS to my previous post... You did not mention what the CHT were. If yo have a gage keep them LOW ... Lycoming use to say 500 Deg F, they recently went down to 450 Deg F, I have my limit of No Higher than 435 Deg F. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Jul 31, 2006
On 31 Jul 2006, at 12:21, Charles Heathco wrote: > I have noticed my newer engine is running hotter oil temp than the > older one. Used to be 190-200 max. now its going up to 220-230. > Anyone can say for sure what max norm opr and also max safe temp > should be? Charlie Heathco > Is this with the same oil temp sender and indicator as the old engine? Has the oil temp indication system been calibrated so you are sure it is telling you the truth? Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jul 31, 2006
Thank you Ed! The website you mentioned avwx.net/home.php was just the answer I wanted. They stated that airborne reception was "spotty, at best", and that the FAA doesn't consider them an approved preflight source. The other little hidden cost was also a surprise............your cell phone has to be web-enabled by your provider at an additional cost. O.K. We have got cell phones covered. What are the best devices to receive airborne weather services? Good work Ed, Les Featherston ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Re: TBM Avenger/RV-6 accident at OSH and other OSH stuff
Having seen almost the same scenario played out at Reno a number of years ago, with a Sea Fury taxiing up the back end of a Lancair, I can see how it happens. It's a large plane, with (I would guess) a high workload during taxi and run-up. Losing track of just how many small planes are in front of you would be very easy. In the incident I witnessed, the Lancair was pushed ahead enough by the impact that by the time the Sea Fury shut down he was still a foot from the cockpit. But the Lancair was still running, and as I recall it taxiied itself further ahead before shutting down to get out and inspect the damage. Still, my condolences to all involved, if anyone here knows any of them. As someone pointed out, it was a relatively incident-free year at Oshkosh this year, it's unfortunate that this had to be one of the incidents. -Rob ________________________________________________________________________________
Date: Jul 31, 2006
May have all info you need. I have Irridiums I put in year ago, I burn mostly mogas, so cant say much about lead exept that when I do burn some out of my left "takeoff" tank I have no fouling. They stay clean as a whislte all the time. They are expensive. Charlie Heathco ________________________________________________________________________________
Date: Jul 31, 2006
Contrary to what I have read on some of the posts, the vernitherm always lets a bit of oil through to the oil cooler. I know because I tested it. By blocking the airflow to the oil cooler, you will be able to raise the oil temp. My concern with Van's set-up is that when their shutter is open, it is also blocking 1/2 of the air to the oil cooler..... So when your engine is running hot and you need to cool the oil real bad, you are losing airflow. I know you could remove it in the summer, but that would defeat the purpose. -Mike Kraus -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Erich_Weaver(at)URSCorp.com Sent: Monday, July 31, 2006 3:18 PM I am considering purchasing the oil cooler shutter that Vans offers, but dont exactly understand the need for this product. Shouldnt a correctly operating vernatherm, which most of our engines come with, do the same job, or am I missing something? Erich Weaver ________________________________________________________________________________
Date: Jul 31, 2006
The biggest obstacle would be getting the phone to work at anything over 2,000' agl. Mine works close to the ground, but it never works at the altitudes I fly. -Mike -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Morocketman(at)aol.com Sent: Monday, July 31, 2006 12:32 PM Has anyone tried a CELL PHONE weather system with success or failure? Primarily due to limited cockpit space, I am considering buying a new cell phone with a larger than average screen and using Velcro to attach it to the panel. Do you like/dislike your weather on the cell phone? Whose service do you have/have tried in the past? What problems does anyone see with it? i.e. Is it illegal to use cell phone in an airplane? What were the costs involved? Connection fee? Monthly service? Additional minutes, etc? Thanks listers, you are a walking encyclopedia of knowledge, Les Featherston ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Re: Rear Prop Gov. Questions
Dan, I'll try to get a decent picture tomorrow of my rear mounted govenor. However, my set up is a Woodward govenor on a O-360 in a 6A. But, if you think it well help I'll send the picture. Dale Ensing Maybe someone on the list could point me to a picture of a rear mounted prop governor so I could get a feel for how much room there is. Probably an O-360 would be the same. Thanks, Dan ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Matronics Email List Web Server Upgrade Tonight...
Dear Listers, This evening I will be upgrading the Matronics Web Server hardware to a new Quad-processor 2.8Ghz Xeon system (yes, 4-physical CPUs!) with an Ultra 320 SCSI Raid 5 disk system and 5GB of DDR2 RAM. As with the older system, the new system will be running the latest version of Redhat Linux. Most of the software configuration work is already done for the migration, but I still have to sync all of the archive and forum data from the old system to the new system. I am anticipating about 2 to 3 hours of downtime for me to fully make the transition, although it could be considerable less if everything goes according to plan. The Matronics Webserver will be *UNavailable* from the Internet during the work, and you will receive a time-out if you try to connect during the upgrade. Email List Distribution will be *available* during the upgrade of the Web Server, and List message distribution will function as normal. This represents a significant performance upgrade for the Matronics Web Server and you should notice nicely improved searching and surfing performance following the upgrade! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Re: oil cooler and vernatherm
The vernatherm only bypasses the oil cooler, it does not restrict the flow to it, so you will always have some oil going to the cooler. Dave Mike Kraus wrote: > >Contrary to what I have read on some of the posts, the vernitherm always >lets a bit of oil through to the oil cooler. I know because I tested >it. > >By blocking the airflow to the oil cooler, you will be able to raise the >oil temp. My concern with Van's set-up is that when their shutter is >open, it is also blocking 1/2 of the air to the oil cooler..... So when >your engine is running hot and you need to cool the oil real bad, you >are losing airflow. I know you could remove it in the summer, but that >would defeat the purpose. > >-Mike Kraus > >-----Original Message----- >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of >Erich_Weaver(at)URSCorp.com >Sent: Monday, July 31, 2006 3:18 PM > > >I am considering purchasing the oil cooler shutter that Vans offers, >but dont exactly understand the need for this product. Shouldnt a >correctly operating vernatherm, which most of our engines come with, do >the same job, or am I missing something? > >Erich Weaver > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Looking for Reports on new David Clark X-11 Headset
Are there any RV pilots out there that can provide an objective report on this new headset released at Oshkosh? I am particularly interested in an evaluation in the noise environment of a typical RV and how well the active noise cancellation works. The rest looked pretty good at Oshkosh. Thanks Tom Olson ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Small mirrow
Does any one have on their roll bar a small mirror,like about 1" wide and about 3 or 4 inches long?? I have looked, and no luck!! Where did you get it??? Thanks John M (RV6 180/CS) ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Re: Small mirrow
Try "baby mirrors" from a store that sells baby/infant supplies. They are designed so parents can see their offspring in the back seat. This is what's working for me in the RV-8 On Jul 31, 2006, at 7:57 PM, John McMahon wrote: > Does any one have on their roll bar a small mirror,like about 1" wide > and about 3 or 4 inches long?? I have looked, and no luck!! > Where did you get it??? > Thanks > John M (RV6 180/CS) > ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Re: Landing Gear
This is really interesting stuff for a newbie like myself. Could not really comment without some study but would really like to know what others think. Regards, Michael Wynn RV 8 Wings ________________________________________________________________________________
Date: Aug 01, 2006
John: Mine came from Pep Boys. I needed to add a small film of RTV over the clamp so that it would stay in positon on the roll bar brace. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,917 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- Does any one have on their roll bar a small mirror,like about 1" wide and about 3 or 4 inches long?? I have looked, and no luck!! Where did you get it??? Thanks John M (RV6 180/CS) ________________________________________________________________________________
Date: Jul 31, 2006
Subject: Stuff For Sale
Do you still have the AOA for sale? Please advise, thanks! -Mike -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rveighta Sent: Wednesday, July 26, 2006 6:17 PM I have the following items for sale: ITEM CONDITION PRICE Angle of Attack (vans p/n IF AOA PRO) new $1,000 Microair 760 VHF Transciever slightly used $575 Rose Electroair electronic ignition used $400 RV-8(A) fiberglass wingtip light fairings new $10 Westach CHT gauge (p/n 2C1) new $15 Westach EGT gauge (p/n 2C2) new $15 If you need additional info, email me direct or give me a call at (423) 257-6566. Walt Shipley ________________________________________________________________________________
Date: Jul 31, 2006
http://mobile.wunderground.com provides decent info for free if you can surf the web via your phone. That was my plan before I invested in the 396. I mostly used it on the ground, not in flight. I have a Treo 650 and verizon service. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com _____ Sent: Monday, July 31, 2006 7:38 PM The biggest obstacle would be getting the phone to work at anything over 2,000' agl. Mine works close to the ground, but it never works at the altitudes I fly. -Mike -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Morocketman(at)aol.com Sent: Monday, July 31, 2006 12:32 PM Has anyone tried a CELL PHONE weather system with success or failure? Primarily due to limited cockpit space, I am considering buying a new cell phone with a larger than average screen and using Velcro to attach it to the panel. Do you like/dislike your weather on the cell phone? Whose service do you have/have tried in the past? What problems does anyone see with it? i.e. Is it illegal to use cell phone in an airplane? What were the costs involved? Connection fee? Monthly service? Additional minutes, etc? Thanks listers, you are a walking encyclopedia of knowledge, Les Featherston ________________________________________________________________________________
Date: Aug 01, 2006
Hi Dan- >I posted this last week, but didn't get answers. Funny how that goes sometimes, with all the talent on this list! >Maybe someone on the list could point me to a picture of a rear mounted prop >governor so I could get a feel for how much room there is. Probably an >O-360 would be the same. It appears on page 2-4 of parts catalog PC-406-1. I've an RV-8 with an IO-360-A1B6D with a Czech gov on the back so there is no direct correlation to your installation. My pad is about 7/8 thick and I have about 4 1/8 between the rearmost part of the gov (the end of the cable attach bolt) and the firewall. I do believe that all the gov's except Woodward have the same (AN) footprint. According to what I get out of the parts catalog, the correct adaptor for your installation would be #75545 if the case has studs and #78594 if your installation uses cap screws. Perhaps there is a part number on the adaptor you have? I wouldn't be at all surprised if you've got all you need already! Sorry I couldn't be of more direct assistance- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Aug 01, 2006
Hi Mark- >I hate spreading misinformation so I apologize for not getting the fact >s straight... It seems to me that the things you reported as fact were correct, and your interpretation of the events as entirely reasonable. Thank you for sharing your observations as clearly and factually as you did. You have done the rest of us a service while reporting on what must have been a gut wrenching experience. I hope the unfortunate events of the day don't have a lasting negative impact upon either you, your son, or the passion that we all share. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Date: Aug 01, 2006
You wont be able to get a signal at any kind of speed and altitude. Shemp/Jeff Dowling RV-6A, N915JD 295 hours Chicago/Louisville ----- Original Message ----- From: Morocketman(at)aol.com To: rv-list(at)matronics.com Sent: Monday, July 31, 2006 11:32 AM Subject: RV-List: Further thread on airborne weather services! Has anyone tried a CELL PHONE weather system with success or failure? Primarily due to limited cockpit space, I am considering buying a new cell phone with a larger than average screen and using Velcro to attach it to the panel. Do you like/dislike your weather on the cell phone? Whose service do you have/have tried in the past? What problems does anyone see with it? i.e. Is it illegal to use cell phone in an airplane? What were the costs involved? Connection fee? Monthly service? Additional minutes, etc? Thanks listers, you are a walking encyclopedia of knowledge, Les Featherston ________________________________________________________________________________
Date: Aug 01, 2006
I'm a bit confused.... was the accident RV and RV-6 (side-by-side) or was it an RV-8 (tandem)? I can understand the passenger being killed in an RV-8 while the pilot up-front survives, but I for life of me don't understand how the pilot would have been able to survive in an RV-6! I've read lots about this accident. Some report it as an RV-8... others and RV-6. Which is it? Jack ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Re: TBM Avenger/RV-6 accident at OSH (what to do)
Rob I agree with you but no one has said it so I will, the responsibility lies with the TBM pilot 100%. I am not being accusatory, it was a tragic accident, an accident but an accident that was preventable. This is not the first time as you point out so instead of blaming, since the TBM pilot no doubt has to deal with this mentally, financially and legally; what can we learn? What can we learn? Well 20/20 hind sight, Monday Morning QB, I would say if you are NOT 100% about where your plane is going STOP (or get out of the way). He could have called for wing walkers. Either pilots for that matter could have called. This happens at the airlines where pilots taxi into other planes or jet ways. I suppose the RV could have pulled off the taxiway or called for wing walkers for the TBM himself. The lesson learned, if faced with this scenario I know I will do something to keep from being run over. If following a plane I can't see, again I'll do something to get the safety margin back. I relize it's easy to say that now, I am not that smart but do have the luxury of learning, and if I'm uncomfortable, I'll do something about it. I can tell you from this accident I will not ALLOW a big Taildragger follow me in Stop-N-Go Congo line. I have worried about this for years when a blind taildragger was following me post air-show line up. I was constantly turning 45 on the taxiway and looking over the shoulder. Paranoid and not very comfortable. It does not have to be a TBM, a Cessna 190 will ruin your day. My procedure now is to wait for the line to go down. At any show there is a rush to leave right after the field opens. 30 minutes is usually plenty to get most out of the way. 30, 45, 60 minutes is well worth the wait to make your departure more efficient and safe. DON'T BE IN A HURRY. Wait and watch the show after the show, the departures. Hopefully there will only be safe departures to watch, no tragedies. My thoughts and Priers to all and their families. Sincerely George M RV-7/ATP/CFII_MEI >posted by: "Rob Prior (rv7)" > >Having seen almost the same scenario played out at >Reno a number of years ago, with a Sea Fury taxiing up >the back end of a Lancair, I can see how it happens. It's >a large plane, with (I would guess) a high workload during >taxi and run-up. Losing track of just how many small planes >are in front of you would be very easy. In the incident I >witnessed, the Lancair was pushed ahead enough by the >impact that by the time the Sea Fury shut down he was >still a foot from the cockpit. But the Lancair was still >running, and as I recall it taxied itself further ahead before >shutting down to get out and inspect the damage. > >Still, my condolences to all involved, if anyone here knows >any of them. As someone pointed out, it was a relatively >incident-free year at Oshkosh this year, it's unfortunate >that this had to be one of the incidents. >-Rob --------------------------------- See the all-new, redesigned Yahoo.com. Check it out. ________________________________________________________________________________
Date: Aug 01, 2006
Jack, I think the initial (logical) speculation was that if it was an RV it would have had to have been a tandem model. I think the more "official" word is RV6. I was not there but imagine that the first strike spins the tail a bit left for somewhat of a right turn of the plane. That would put the person on the left a bit more forward of the plane of the prop. This is pure speculation of the geometry of things on my part. I have NO data to back this view up. James p.s. How is "beautiful paint scheme" holding up?? :-) :-) On 8/1/06, Lockamy, Jack L wrote: > > I'm a bit confused.... was the accident RV and RV-6 (side-by-side) or was > it an RV-8 (tandem)? I can understand the passenger being killed in an RV-8 > while the pilot up-front survives, but I for life of me don't understand how > the pilot would have been able to survive in an RV-6! > > I've read lots about this accident. Some report it as an RV-8... others > and RV-6. Which is it? > > Jack > -- This is an alternate email. Please continue to email me at james(at)nextupventures.com . ________________________________________________________________________________
From: "Vincent Welch" <welchvincent(at)hotmail.com>
Date: Aug 01, 2006
Subject: Cooling Blast tubes - Lycoming
Run a hanger or other stiff piece of wire through the inside of the blast tube, bend it in any shape you like, then secure the hanger to the blast tube with RTV. Clamp the tube to structure as required along the outside. Vince Welch RV-8A >From: "Steve & Denise" <sjhdcl(at)kingston.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Cooling Blast tubes - Lycoming >Date: Sat, 29 Jul 2006 11:05:37 -0400 > > >RV7A - IO360 >I'm planning to install 5/8" blast tubes from baffling to fuel pump, 1 mag, >and alternator. > >Routing and securing to baffling is easy but any tricks on securing the end >where the component is so the cooling >blast actually hits the fuel pump? Adel clamps stategically placed? Pics? > >Thanks >Steve >RV7A flying soon! > > ________________________________________________________________________________
Date: Aug 01, 2006
On 8:55:42 2006-08-01 "Lockamy, Jack L" wrote: > I'm a bit confused.... was the accident RV and RV-6 (side-by-side) or > was it an RV-8 (tandem)? I can understand the passenger being killed > in an RV-8 while the pilot up-front survives, but I for life of me > don't understand how the pilot would have been able to survive in an > RV-6! Assuming the propellor rotates clockwise (from the pilot's perspective) on a TBM, I would expect multiple hits on the rear fuselage of an RV-6 would cause the RV to rotate clockwise (viewed from above), regardless of what the pilot was doing with the brakes. There's a lot of momentum in that big a propellor. Or, maybe the TBM was rolling on a path slightly to the right of the path of the RV, and only cut into the right-hand side of the fuselage. In any case, the plane has been officially confirmed to be an RV-6. C-FNQP, Registered to Bill Reed of Carp, Ontario. -Rob ________________________________________________________________________________
Date: Aug 01, 2006
This accident hit me hard because I thought of it being me and the copilot being my wife. I remember just a few weeks ago at arlington. seems that there were a group of planes that thought they were the cats meow when I was already cleared to land that had to just cut right in front of me, I of course turned right and did a go around. then on departure on sunday I had an incident(or potential incident) where 34 was the active runway all weekend, and I was departing at 6:30 in the morning before the tower opened and about 5 planes had already departed in about 5 minute seperations on 34. I got to the runway and announced my departure and lined up on the runway ready to push the throttle when I heard two planes giving intentions to depart on 16. I radiod that I was powering up on 34, no response, I aborted takeoff and while turning off the runway made another radio call, still no response, just as I got off the runway, two low wing small aircraft, one red, departed and flew right over us. I know my radio worked because the cessna after me said some things and I did also to these jerks on the radio to them, and of course no response. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51547#51547 ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Copper in Oil, XP-360
Recent Oil Analyses seem to be showing increased levels of copper coming from my XP-360. The engine has a total of 265 hours and I use Aeroshell 15/50. My last three oil analyses were flagged at 15.3, 19.5 and 36.3 P/M, average interval 30 hours between oil changes. I'm hoping it is about to peak and will start to go down soon. An oil analysis article by Lycoming says the following: "Differences in manufacturing process may cause a variation in analysis results for different engine models. The amount of tin plating, copper plating, etc, performed during manufacture has a definite relationship to the oil analysis reports. It is not uncommon, to see what seems to be high copper content early in the life of an engine, only to have this content continually decrease as the engine accumulates time, and then disappear altogether. Has anyone else experienced high copper? Did it go away? If so when? What specifically does "early in the life" and "as the engine accumulates time" mean? Comments and suggestions welcome. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Re: Copper in Oil, XP-360
What does your engine builder say about it? FWIW, my copper did go down a bit over time but has had some variation: http://rvimg.com/images/2006/20060703_oil_analysis.jpg (NOTE: I switched from hobbs to tach hours on the 3rd analysis) )_( Dan RV-7 N714D (1021 hours) http://www.rvproject.com ----- Original Message ----- Sent: Tuesday, August 01, 2006 10:36 AM > > Recent Oil Analyses seem to be showing increased levels of copper coming > from my XP-360. The engine has a total of 265 hours and I use Aeroshell > 15/50. > > My last three oil analyses were flagged at 15.3, 19.5 and 36.3 P/M, > average interval 30 hours between oil changes. > > I'm hoping it is about to peak and will start to go down soon. > > An oil analysis article by Lycoming says the following: "Differences in > manufacturing process may cause a variation in analysis results for > different engine models. The amount of tin plating, copper plating, etc, > performed during manufacture has a definite relationship to the oil > analysis reports. It is not uncommon, to see what seems to be high copper > content early in the life of an engine, only to have this content > continually decrease as the engine accumulates time, and then disappear > altogether. > > Has anyone else experienced high copper? Did it go away? If so when? > > What specifically does "early in the life" and "as the engine accumulates > time" mean? > > Comments and suggestions welcome. > > Steve Glasgow-Cappy > N123SG RV-8 > Cappy's Toy > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Aug 01, 2006
Thanks Dan, I'm still waithing to hear back from Superior and Bart. Cappy -------- Steve Glasgow-Cappy Cappy's Toy RV-8 N123SG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51564#51564 ________________________________________________________________________________
Date: Aug 01, 2006
My goof... it's not copper _in_ the oil as manufactured, it's apparently a leaching phenomenon from TCP: http://www.prime-mover.org/Engines/GArticles/Copper.html Google "copper aeroshell oil 15w-50" to learn more than you ever wanted to know about this, and some urban myths besides ;-) -Stormy you do realize you've given me something new to worry about, don't you, Cappy ?! -----Original Message----- Sent: Tue, 1 Aug 2006 2:45 PM Thanks Dan, I'm still waithing to hear back from Superior and Bart. Cappy -------- Steve Glasgow-Cappy Cappy's Toy RV-8 N123SG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51564#51564 ________________________________________________________________________ ________________________________________________________________________________
Date: Aug 01, 2006
Thanks Stormy, That was a great article on Aeroshell 15/50. To bad they changed the formula. OH well! Cappy -------- Steve Glasgow-Cappy Cappy's Toy RV-8 N123SG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51579#51579 ________________________________________________________________________________
Date: Aug 01, 2006
Steve, For the Mag I attached a clamp to engine and just aimed the tube at the mag. For the Alternator, there isn't any convenient place to attach a clamp. I took a piece of wire, bent loops at each end the size of the outside diameter of the tube. Bent them 90 degrees, slipped them over the tube and then bent the wire so that it was "aimed correctly" I used RTV to keep wire in place. I don'thave one to the fuel pump Seems to work so far Dave Burnham On 7/29/06, Steve & Denise wrote: > > > RV7A - IO360 > I'm planning to install 5/8" blast tubes from baffling to fuel pump, 1 > mag, > and alternator. > > Routing and securing to baffling is easy but any tricks on securing the > end > where the component is so the cooling > blast actually hits the fuel pump? Adel clamps stategically > placed? Pics? > > Thanks > Steve > RV7A flying soon! > > ________________________________________________________________________________
Date: Aug 01, 2006
Subject: Re: RE: TBM Avenger / RV-6 accident at OSH
Amen! Well said. I for one agree with glen that your reporting was excellent and reasonable. And that you did the list a real service. I pray that you and your son have no lasting ill effects from witnessing this tragedy and that the short term effects will indeed be short term. Doc Custer ----- Original Message ----- Sent: Tuesday, August 01, 2006 6:06 AM > > Hi Mark- > >>I hate spreading misinformation so I apologize for not getting the fact >>s straight... > > It seems to me that the things you reported as fact were correct, and your > interpretation of the events as entirely reasonable. Thank you for > sharing > your observations as clearly and factually as you did. You have done the > rest of us a service while reporting on what must have been a gut > wrenching > experience. > > I hope the unfortunate events of the day don't have a lasting negative > impact upon either you, your son, or the passion that we all share. > > glen matejcek > aerobubba(at)earthlink.net > > > ________________________________________________________________________________
Date: Aug 01, 2006
On 31 Jul 2006, at 10:19, rveighta wrote: > I'm sure I'm far from being the most knowledgeble builder on the list, > but it seems to me that automotive mfgrs recycle oil back through > their > engines without detriment and without puddles of oil on the garage > floor. Autos are burning fuel without lead, in liquid-cooled engines with smaller bores that can have much tighter clearances. I'm betting there is less blow by in an auto engine, and the blow by will contain different stuff. Plus automotive and aviation oil have different additive packages. Current automotive engines were designed to accept the blow by gasses, but I believe it goes into the induction air, rather than back into the oil as some have proposed for our aircraft engines. The auto engine experience may not be relevant. Given the cost of engine overhauls, I'm not too keen to put something different inside my engine (crud from the air-oil separator), unless there is a huge wealth of service experience behind it. Kevin Horton Ottawa, Canada ________________________________________________________________________________
Date: Aug 02, 2006
In a message dated 8/1/2006 10:41:39 A.M. Pacific Daylight Time, willfly(at)carolina.rr.com writes: Recent Oil Analyses seem to be showing increased levels of copper coming from my XP-360. The engine has a total of 265 hours and I use Aeroshell 15/50. =========================== It may be that the Triphenyl Phosphate (TPP) in that particular brand multi-vis oil is leaching the copper from your bearings as it is suspected of doing. Try changing to the better straight weight oils without the TPP. If you insist on using a multi-vis oil there are other brands without it. GV (RV-6A N1GV O-360-A1A, C/S, Flying 802hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Aug 02, 2006
Cappy, my first oil analysis showed copper at 39, then a slow steady drop into the 5-12 range where it has remained for the past 550 hours since break-in. I always use 15W-50 and a 50hr change interval, usually add 1-2 qts in the 50 hr interval. HTH -Stormy -----Original Message----- Sent: Wed, 2 Aug 2006 12:12 AM In a message dated 8/1/2006 10:41:39 A.M. Pacific Daylight Time, willfly(at)carolina.rr.com writes: Recent Oil Analyses seem to be showing increased levels of copper coming from my XP-360. The engine has a total of 265 hours and I use Aeroshell 15/50. =========================== It may be that the Triphenyl Phosphate (TPP) in that particular brand multi-vis oil is leaching the copper from your bearings as it is suspected of doing. Try changing to the better straight weight oils without the TPP. If you insist on using a multi-vis oil there are other brands without it. GV (RV-6A N1GV O-360-A1A, C/S, Flying 802hrs, Silicon Valley, CA) ________________________________________________________________________ ________________________________________________________________________________
Date: Aug 02, 2006
Enough may have been said about this, but my 320 will throw out anything over 7 qt, and I let it go down to 6 1/2 qt where I keep it and I get very little oil on the belly at that reading. As for the separators, from what I have heard from a few who had them, they are a waste of money. Charlie Heathco ________________________________________________________________________________
Date: Aug 02, 2006
Subject: slight mishap at Oshkosh
List.. After 20 some years of attending Oshkosh and flying into there 6 times I finally had a minor incident while landing. On Thurs. morning they were landing aircraft on runway 18. After touchdown in my RV6, the tower instructed me to exit the runway onto the grass immediately. This is common practice and as I turned off the runway to the right I heard a disheartening crunch. As there were 4 airplanes on final right behind me, and the airplane seemed to taxi o.k., I kept going. After a long taxi to the tie-down area I got out and looked and sure enough, my right wheel pant was pretty much destroyed. As I suspected, I had hit a runway light. No ones fault but my own, but it is very difficult to see anything directly off to the right in a taildragger 6. We ended up taking the pants off and made it home no problem. Just a heads up out there for anyone to keep in mind if they happen to be in that situation. It is just not an ordinary circumstance to "depart runway and taxi onto the grass". It is a situation you hardly ever duplicate at your home airport. As an aside, I flew into Osh. 3 years ago with a Vari-Eze that had never attended before. He was given the same instructions and completely destroyed his nose gear. Didn't hit anything, but the ground was just too rough. Finally got home after 2 days of repair. Keep in mind there are objects along the side of the runway and the ground there can be very hard on your gear. Dave Mader RV-6 ________________________________________________________________________________
Date: Aug 02, 2006
> >I searched the archives, but couldn't find answers to these questions. > >I am thinking of putting an IO-360-A1A engine in my RV-7A. It has >been flying with an IO-360-A1D6 which has a front mounted governor. > >Could someone on the list please tell me approximately what the >thickness of the rear mounted prop governor adapter pad is on an >IO-360-A1A? I have an old one that measures about 2 1/16 >inches. Is there a thinner one available? The dimension I need is >from the accessory case to the prop governor itself. > >Also, will the McCauley governor off the left front of my >IO-360-A1D6 work on the rear of the -A1A? As far as I can tell >there is about 3 percent difference in the drive ratio -- 0.866 vs >0.895. I would assume that the governor could be adjusted for this >difference. Is there some other reason why it won't work? > >Thanks, >Dan Hopper >RV-7A Dan, My adapter & Woodward governor assembly is 8.75" total length from the gasket surface of the accessory cover. I hope this helps. I suspect that your governor will work "as is". If an issue surfaces after the conversion, the unit can be modified by any competent prop shop. Charlie Kuss ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Installing Fuel Lines in RV-7A, 9A
Fuselage builders, I thought that I'd pass this along since I have never seen it in print before, and it was not in the manual, at least when I built my airplane. In the plans it says to install the main landing gear brackets, and two pages later to install the fuel lines. What we are talking about here are the two lines that come from the tank fittings through the fuselage sides to the selector valve. The bottom line is that if you install the fuel line at the same time you install the landing gear bracket, you can do it a lot easier and better. Bend the joggle in the line on your workbench. Slide the line through the bracket and the removed F-782B cover support rib. Then slide the line through the hole in the fuselage and slide the gear bracket into position. It is a little bit of a struggle, but much easier to do than if the gear bracket is bolted in. Dan Hopper RV-7A ________________________________________________________________________________
Date: Aug 02, 2006
Subject: TBM Avenger/RV-6 accident at OSH (what to do)
Regarding the accident, I'd like to toss out a few comments just to offer some info and some related experiences. I've been flying my Rocket for 2 years and 130 hours now. It's great fun but does have its share of weaknesses. One of which is the lack of visibility over the nose when on the ground. Yes, I know all about S-turns, so save your breath on those comments please. In my Rocket I found that I could not see an RV-6 until it was much less than 100' away if the big nose was in the way. Since we had a couple of RV-8s collide on a taxiway near here a few years ago, it really bothered me that the blind spot was, well... huge and inconvenient. My RV buddies would zoom down the taxiway because they had reasonable visibility and I would follow along doing S-turns at a much slower speed. So, being a bit of a gadget freak, I decided to add a camera and LCD screen to my plane. The Sony bullet color camera (VC-806B, standard lens)and LCD screen were relatively cheap, only a few hundred bucks... next to nothing in airplane dollars. The camera is mounted in the left cowl inlet and the heat and vibration don't seem to bother it at all. The LCD screen (sorry, no p/n available) is mounted under the panel and works well even in bright sun, although it isn't quite 100% immune to sunlight glare. Now when I follow my RV buddies I still S-turn as needed, but often can simply glance at the LCD screen for confirmation. IT DOESN'T REPLACE S-TURNS, but it gives a wonderful SUPPLEMENT. (I'm trying to choose my words carefully because I know that I'll be flamed for being DIFFERENT.) I use the camera/LCD combo during virtually all of my ground ops and find it very useful!!! With a quick glance I can see pop cans, runway lights, debris, small animals, cracks in the pavement, etc, etc.... all sorts of things that I don't want to run over!!! Now to share some reactions... last year at Oshkosh a warbird pilot asked me what the LCD screen was for. When I told him that it was my "taxi assist camera" he spun on his heel and walked away shaking his head. I thought "Hmmm, whatever". I guess that he didn't think too much of my system or my skills. Now, after 2 recent accidents (that I know of) and a fatality, I wonder which mindset is correct, mine or his? http://vincesrocket.com/Additions%20after%2010-27-04.htm for more info Vince FWIW, I also wanted a cheap way to display my GRT EFIS info to the back seat passenger in my plane. GRT wants $2500 for a slave display. Another camera and LCD screen easily displays the GRT info to the rear seater and it cost 10% of what GRT wanted. Not as elegant, but 100% useful. ________________________________________________________________________________
Date: Aug 02, 2006
> I guess that he didn't think too > much of my system or my skills. Since seeing your install have purchased the components for my plane. Recent episode at OSH has added new impetus to get off my lazy butt and install it. Vince's install below -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=51823#51823 ________________________________________________________________________________
Date: Aug 02, 2006
Subject: avionics ordering tip
Here is a small tip for those of you considering ordering a GRT EFIS along with Garmin avionics from Stark Avionics. For a small fee, Stark provided the wiring harnesses for my SL-40 comm, GTX-327 transponder, and PS Engineering intercom with lead lengths I specified. They did a nice neat job and I was glad I did it. However, what I didnt realize at the time was that the EFIS and SL-40 can talk to each other using serial input and output so that multiple airport frequencies can be automatically loaded into the comm for easy access. To do this, you will need to specifically request from Stark that the harness for the comm include the serial input and output pins. Otherwise, if you want to make use of this feature, you will have to undo Starks nice neat job and add the wire leads in yourself. Similarly, as desired, the EFIS can automatically switch the transponder from standby to on when it determines your flight has begun, but this requires an additional serial input lead to the transponder, which also must be specifically requested to be included in the harness. You can obviously do this all yourself after the fact, but if you are having Stark do the harnesses anyway, why mess up his nice neat job and re-do it? The above probably also applies to other EFIS brands, and possibly other avionics vendors, but I have no experience with those. regards, Erich Weaver ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: Air Oil Separators
Roger on the info regarding Air/Oil Separators! I had too much oil on the belly of my IO-540 powered Harmon Rocket II. Tried everything I could think of regarding the vent line size, loop up and over, aimed at the exhaust, etc. The Separator did no good at all. I let the oil quanity go down to 9 1/2 (per someone's suggestion) and vola! I have never seen below 8 1/2. And yes, I do find myself adding one pint sometimes. But easier than Washing the Belly. My Lycoming manual says 12 qt system, with minimum (bet you cannot believe this) of 2 qts. Yes! Two quarts minimum. I can't remember my IO-360 minimum, but recall that it was equally scary. Give it a try-------you'll like it. Les Featherston HRII "Airgasm" has 277 hours. ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: Vacuum pump fitting
In a message dated 8/2/06 4:37:02 PM Eastern Daylight Time, jrdial@hal-pc.org writes: > I have an RV-6 without a vacuum system but a friend that > rents hanger space from me is installing a new 0-360 in his RV6A and the > fitting for the inlet side (suction) of the vacuum pump appears that it > is going to be very close to the motor mount. Question is this normal or > is there a different fitting people that have vacuum system and 0-360 in > RV6s use? > > You can answer direct to my email. > Thanks, > Dick Dial > N89DD ============================= Dick: You have to be a bit more specific. Can you answer the following questions: 1 - Which engine mount are you referring to? 2 - Which fittings are you referring to? Check out ACS Catalog, and give me a part number. They are interchangeable and different fittings are available. My general response is: As long as you are using a standard store bought engine mount (dynalfocal) the vacuum Pump will fit. You are talking about a DRY Vacuum Pump? The intake and exhaust fittings can be varied in shape and location to have things fit. DO NOT OVER TIGHTEN! The ONLY problem I can foresee is the left lower NUT! You must have the special wrench to tighten that one. The RV-6A and RV-6 I fly both have dry vacuum pumps and fit is NOT a problem. Both have 360's an O-360 and an IO-360 respectively. Super Cautionary Note: I know the installation instructions say do not use Teflon Tape. I am a bit scared to recommend it, because, quite honestly most people do not know how to use it properly. There is a trick in its safe use. But Teflon tape may be required if when alignment is accomplished the fitting is still loose. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 02, 2006
Thanks Charlie and others for the info. Here are a few more questions I have: As far as I can tell from my measurements with the engine not assembled yet, it looks like the end of the governor will come back about even with the firewall. Does anyone else with a -7A know if this is OK? In other words, it is OK for the governor to extend into the recess a little? Will it clear the sides of the recess enough to allow for engine movement? Also, would someone please explain the metal plate that sometimes gets thrown away with the gasket. I need to come up with one of these, I guess. Exactly where does it go, and what purpose does it serve? Dan Hopper RV-7A In a message dated 8/2/2006 10:53:21 A.M. Eastern Daylight Time, chaztuna(at)adelphia.net writes: Dan I'm building an 8A. I'm using a parallel valve 360. The governor is out of an old Apache, but has been converted for use with my current setup. Charlie Charlie, What plane and engine do you have? do not archive Dan ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Re: exhaust bolt torque
In a message dated 7/30/06 2:38:01 PM Eastern Daylight Time, bicyclop(at)pacbell.net writes: > Watch out for those crush type exhaust gaskets. I had one of those burn > through allowing the nuts to loosen and fall off. The pipe was found > hanging (barely) on the end of the stud. I replaced it with a solid > "blow proof" gasket. I checked the other 3 gaskets when we got home and > they all showed signs of damage and some leakage. Replaced all. 700 > hours on engine at the time. > > Ed Holyoke ====================== Ed: You are 100% right on! A cheep friend, purchased a set of those soft -- gaskets (guaranteed to blowout) and not one, but two of them were totally burnt out and missing. The exhaust pipes were just barely hanging there. There was so much noise but he was more interested in flying than looking under the cowl. In the process he also ruined two exhaust mounting studs. So did he save any money? I don't think so! ! ! Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 02, 2006
I had a bunch of oil on the belly, the fix, cheap ACS round air oil seperator with 2 stainless pot scrubbers stuffed inside. Now, no oil on the belly, just a slight mist about 1~2 feet back from the tube which is not on the exhaust. I have made a few for others but dont know if they monitor the list here to comment. Morocketman(at)aol.com wrote: Roger on the info regarding Air/Oil Separators! I had too much oil on the belly of my IO-540 powered Harmon Rocket II. Tried everything I could think of regarding the vent line size, loop up and over, aimed at the exhaust, etc. The Separator did no good at all. I let the oil quanity go down to 9 1/2 (per someone's suggestion) and vola! I have never seen below 8 1/2. And yes, I do find myself adding one pint sometimes. But easier than Washing the Belly. My Lycoming manual says 12 qt system, with minimum (bet you cannot believe this) of 2 qts. Yes! Two quarts minimum. I can't remember my IO-360 minimum, but recall that it was equally scary. Give it a try-------you'll like it. Les Featherston HRII "Airgasm" has 277 hours. --------------------------------- ________________________________________________________________________________
Date: Aug 02, 2006
Subject: AN4-73 bolts
Hi there, Looking for a source of an AN4-73 bolt. Yeah, long one. Want to use it in the rudder pedal with alum tubing over it to act as a bar to place my foot on to avoid dragging the brakes inadvertently. I have a note into Aircraft Spruce, but if someone has a source, I'd be glad to hear it. Thanks, John Porter #80002 ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Copper in oil XP-360
FWIW, I've been running oil samples for a friend (I have access to a spectrometer used for O/A for other than for Gen. Aviation) & here are the copper readings in his Aerosport O-320: 13, 28.3, 30.6, 32.6, 29.9, 16.8, 15.9, 11.3, & 8.3 All readings are parts per million. Twice, we ran samples on new oil and found zero copper in the oil. I don't have engine time info, but the first sample was in April of '02 and the latest was last December. He has flown his RV-6A about 500 hours, so it appears the highest reading occurred at around 200 hrs. Also, I don't know what oil he is using, but I think it is Aeroshell. ________________________________________________________________________________
Date: Aug 03, 2006
Have tried with and without oil separator and with modified oil separator. There is less blow by with the oil separator and even less with the Scott Billinski modified oil separator. After the number of hour on the airplane, there is still oil on the belly but some of it is from the SMOKE system. The smoke system makes the belly easier to clean as it softens the exhaust gas deposits. The drain from the oil separator goes back into the engine and has always done so. Note the numbers of hours in the past almost 9 years of flying. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,921+ Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ________________________________________________________________________________
Date: Aug 02, 2006
John, How about some rubber tubing? Jim ________________________________________________________________________________
Date: Aug 02, 2006
Subject: Accident photos
Not sure if these have been posted here or not, sorry if this link has already been posted. http://www.vansairforce.com/community/showpost.php?p=63452&postcount=12 ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Re: Accident photos
I feel sorry for the Avenger crew too. What the hell do you do once you've made that big of a mistake? How does that person pick up the pieces an move on? -------------- Original message -------------- > > Not sure if these have been posted here or not, sorry if this link has > already been posted. > > http://www.vansairforce.com/community/showpost.php?p=63452&postcount=12 > > > > > > > > > > > > >
===== ________________________________________________________________________________
Date: Aug 02, 2006
On 19:13:24 2006-08-02 luckymacy(at)comcast.net (lucky) wrote: > I feel sorry for the Avenger crew too. What the hell do you do once > you've made that big of a mistake? How does that person pick up the > pieces an move on? Well, a Sony lipstick camera and a small LCD monitor may be a good start. -Rob ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Re: AN4-73 bolts
> John, How about some rubber tubing? > I second Jim's suggestion. I glued short pieces of scrap hose on the bottoms of my stirrups. That helped a bunch. My biggest problem was keeping my toes off the brakes during touch down and roll out at landing. Then, I discovered that if I'd just lay my feet on the sides of the stirrups, instead of the bottoms, I could keep my feet off the brakes, entirely. After that, I just move my feet over to the bottoms of the stirrups. The hose gives my feet enough clearance from the brake pedals to allow the slight touches I need to tap the brakes for taxi purposes. Jim Sears in KY ________________________________________________________________________________
Date: Aug 03, 2006
Hi Dan- >Also, would someone please explain the metal plate that sometimes gets >thrown away with the gasket. I need to come up with one of these, I guess. >Exactly where does it go, and what purpose does it serve? The metal plate goes between two gaskets, and the trio is then placed between the gov and the case. It seems that there is an oil passage that is too close to the edge of the mating surfaces, and without the plate the gasket material can blow out and port all you oil overboard. IIRC, there is at least one such scenario in the archives. And, yes, it's quite easy to chuck the plate with the gaskets. You may wonder how I know that... glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Aug 03, 2006
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Aug 03, 2006
I don't recall getting a 'plate' with my Jihostroj governor. Details please! How thick, what shape, what material, specific to governor brand, where in what manual is it referred to, anyone got pictures.....? Ralph Capen -----Original Message----- >From: glen matejcek <aerobubba(at)earthlink.net> >Sent: Aug 3, 2006 7:31 AM >To: RV-List Digest Server >Subject: Re: RV-List: Rear Prop Gov. Questions > > > Hi Dan- > >>Also, would someone please explain the metal plate that sometimes gets >>thrown away with the gasket. I need to come up with one of these, I guess. >>Exactly where does it go, and what purpose does it serve? > > The metal plate goes between two gaskets, and the trio is then placed >between the gov and the case. It seems that there is an oil passage that >is too close to the edge of the mating surfaces, and without the plate the >gasket material can blow out and port all you oil overboard. IIRC, there >is at least one such scenario in the archives. And, yes, it's quite easy >to chuck the plate with the gaskets. You may wonder how I know that... > >glen matejcek >aerobubba(at)earthlink.net > > > > > > > ________________________________________________________________________________
Date: Aug 03, 2006
> > Hi Dan- > > >Also, would someone please explain the metal plate that sometimes gets > >thrown away with the gasket. I need to come up with one of these, I guess. > >Exactly where does it go, and what purpose does it serve? > > The metal plate goes between two gaskets, and the trio is then placed >between the gov and the case. Glen, You have me confused by the use of the word "case" above. I was under the impression that these items were located between the governor and the adapter. Am I wrong? Do they go between the adapter and the accessory case? Charlie Kuss > It seems that there is an oil passage that >is too close to the edge of the mating surfaces, and without the plate the >gasket material can blow out and port all you oil overboard. IIRC, there >is at least one such scenario in the archives. And, yes, it's quite easy >to chuck the plate with the gaskets. You may wonder how I know that... > >glen matejcek >aerobubba(at)earthlink.net > > ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Re: doors off?
Evan, I may be wrong, but I think you have to have FSDO approval to remove the door for flight. Someone that carries skydivers or does aerial photography may be of help. Good luck. Doug P. ________________________________________________________________________________
Date: Aug 03, 2006
Glen, I too need some clarification. I have a governor, an adaptor, and an accessory case. At which joint does the metal plate go? Apparently the metal plate must have a rough surface or serrations, etc., that hold the gaskets better. Is this true? I'll look over the parts and see if I can tell where the oil passageway is that is close to the edge. Something that I had never thought about is that the prop pressure must run well above engine oil pressure -- perhaps 150 PSI? That means that the front main bearing is being lubricated by this pressure too, since there are no seals between the prop feed and the 2 bearing surfaces on the front main bearing. Dan Hopper RV-7A In a message dated 8/3/2006 7:43:36 A.M. Eastern Daylight Time, aerobubba(at)earthlink.net writes: --> RV-List message posted by: "glen matejcek" Hi Dan- >Also, would someone please explain the metal plate that sometimes gets >thrown away with the gasket. I need to come up with one of these, I guess. >Exactly where does it go, and what purpose does it serve? The metal plate goes between two gaskets, and the trio is then placed between the gov and the case. It seems that there is an oil passage that is too close to the edge of the mating surfaces, and without the plate the gasket material can blow out and port all you oil overboard. IIRC, there is at least one such scenario in the archives. And, yes, it's quite easy to chuck the plate with the gaskets. You may wonder how I know that... glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
From: "Folbrecht, Paul" <PFolbrecht(at)starkinvestments.com>
Date: Aug 03, 2006
Subject: Modified squeezer die set for trailing edges
After not the best results using the traditional method on my rudder TE, I'd like to try this: http://www.matronics.com/photoshare/jimnbev@olypen.com.07.29.2003/index.h tml on the elevators. Does anybody happen to have a set of grinded dies for this purpose? If there was a set available for sale or lending I would prefer that to making my own. I can be reached off-list at paul.folbrecht(at)veribox.net. Thanks, Paul 9A QB #1176 ________________________________________________________________________________
Date: Aug 03, 2006
On 3 Aug 2006, at 12:12, DOUGPFLYRV(at)aol.com wrote: > Evan, I may be wrong, but I think you have to have FSDO approval to > remove the door for flight. Someone that carries skydivers or does > aerial photography may be of help. Removing the door(s) will almost certainly affect the performance and handling, so even if you manage to get approval, apply all the normal precautions that you would for a flight in an aircraft with unknown performance and handling. I.e. the initial flights are test flights, which should have a planned list of tests, no passengers, and the test points should gradually build up to the end points of the desired weight/CG/manoeuvre envelope. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Aug 03, 2006
On 3 Aug 2006, at 12:12, DOUGPFLYRV(at)aol.com wrote: > Evan, I may be wrong, but I think you have to have FSDO approval > to remove the door for flight. Someone that carries skydivers or > does aerial photography may be of help. FAA AC 105-2C Covers requirements for operating an aircraft with one door removed for the purposes of dropping Skydivers. In Appendix 2 it lists the "Cessna 150 Series" as one of the types with blanket approval for operation in this manner. I would *expect* that this approval would mean that it's safe (as far as the FAA is concerned) to fly the airplane around in this configuration, but you never know when it comes to the FAA... There's a PDF of AC105-2C on the FAA website, but it appears to be corrupted (at least, Acrobat 7 wouldn't open it on my computer). I did find an html version here: http://www.brookfieldstore.com/aviationlinks/AC105-2c.htm Hope this helps! -Rob ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Thunder over Michigan this weekend
Anyone going to see this weekend show? Looks great since I love WWII planes and tanks. http://yankeeairmuseum.org/airshow/ I'm looking for some been there, done that feedback. I have relatives all over the place but have never flown my RV there. Is there a experimental friendly field around there? How's Oakland Troy KVLL or Willow Run KYIP itself during the show weekend? TIA, Lucky
TIA,
Lucky
Date: Aug 03, 2006
Subject: Re: Thunder over Michigan this weekend
I've been a Yankee Air Force/Museum member for years and will be at this year's Thunder over Michigan. It's always a great show and never too crowded. One year I stayed after the show to meet Chuck Yeager and Bud Anderson. While they were talking I walked out to the tarmac and was standing there alone at sunset surrounded by 60 or so WW2 warbirds. Amazing sight. Anyway, our web site says we have GA parking avialable, and since the museum's warbirds are classified experimental and fly almost daily I'd have to say Willow Run is experimental friendly, although it is mainly a cargo terminal. Some fly-in info here or call the museum: http://www.yankeeairmuseum.org/airshow/directions.htm Brett Morawski 419-887-3186 Desk 419-376-8071 Cell
This e-mail, and any attachments, is intended solely for use by the addressee(s) named above. It may contain the confidential or proprietary information of Dana Corporation, its subsidiaries, affiliates or business partners. If you are not the intended recipient of this e-mail or are an unauthorized recipient of the information, you are hereby notified that any dissemination, distribution or copying of this e-mail or any attachments, is strictly prohibited. If you have received this e-mail in error, please immediately notify the sender by reply e-mail and permanently delete the original and any copies or printouts.
Computer viruses can be transmitted via email. The recipient should check this e-mail and any attachments for the presence of viruses. Dana Corporation accepts no liability for any damage caused by any virus transmitted by this e-mail.
English, Francais, Espanol, Deutsch, Italiano, Portugues:
http://www.dana.com/overview/EmailDisclaimer.shtm
Date: Aug 03, 2006
Subject: purge line recommendation?
Howdy I need to install a fuel purge line for my fuel injection system. What kind of hose do folks recommend for the portion that will be in front of the firewall? Since its only a purge line, does it really need any special protection (i.e, steel braid and/or firesleeve)? thanks Erich Weaver ________________________________________________________________________________
Date: Aug 03, 2006
I bought a fire-sleeved line 41 or 42" long directly from Airflow Performance for mine. It was quite expensive -- I think about $60, maybe more. It was what they recommended. Terry -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Erich_Weaver(at)URSCorp.com Sent: Thursday, August 03, 2006 2:12 PM Howdy I need to install a fuel purge line for my fuel injection system. What kind of hose do folks recommend for the portion that will be in front of the firewall? Since its only a purge line, does it really need any special protection (i.e, steel braid and/or firesleeve)? thanks Erich Weaver ________________________________________________________________________________
Date: Aug 03, 2006
Lucky, KVLL is my home field. Traffic there usually does not get heavy there for special events. Paved parking, no formal grass parking. Some transients will tie down on the grass at the end of the hangar rows. Bring your own tie down materials. KPTK can handle corporate traffic better. Lots of traffic for the Super Bowl at KPTK last January. I am planning to go to Thunder Over Michigan on Sunday. If you need a lift from KVLL, leave a reply here. I have a Ford Escape and can carry three pax. Dave Nellis --- lucky wrote: > Anyone going to see this weekend show? Looks great > since I love WWII planes and tanks. > http://yankeeairmuseum.org/airshow/ > I'm looking for some been there, done that feedback. > I have relatives all over the place but have never > flown my RV there. Is there a experimental friendly > field around there? How's Oakland Troy KVLL or > Willow Run KYIP itself during the show weekend? > > TIA, > Lucky __________________________________________________ ________________________________________________________________________________
Date: Aug 03, 2006
Subject: Re: purge line recommendation?
Erich, What's a "fuel purge line"? I'll be receiving my Aero Sport IO360 engine next week and no one ever mentioned anything about a "purge line". Garry Stout Odessa, FL ----- Original Message ----- Sent: Thursday, August 03, 2006 5:12 PM > > > Howdy > > I need to install a fuel purge line for my fuel injection system. What > kind of hose do folks recommend for the portion that will be in front of > the firewall? Since its only a purge line, does it really need any special > protection (i.e, steel braid and/or firesleeve)? > > thanks > > Erich Weaver > > > ________________________________________________________________________________
Date: Aug 03, 2006
On 16:05:31 2006-08-03 Fiveonepw(at)aol.com wrote: > Most interesting- note the plural form "Skydivers" cited- Behold the > Mighty 150!!!! Sure... The 150 did have a child seat as an option. If you want to throw your spouse and child out of your 150, it's perfectly legal. But you have to give them parachutes. :) -Rob ________________________________________________________________________________
Date: Aug 04, 2006
Subject: RE: purge line recommendation?
Date: Aug 04, 2006
Subject: Re: RE: purge line recommendation?
On 4 Aug 2006, at 24:22, Erich_Weaver(at)URSCorp.com wrote: > Garry: > > Made me smile when I read your question, as thats exactly what I > said when I got my engine from Aerosport Power (IO-360B1B). > > Check the archives for further info, but the purge line is in > common use for fuel injected engines to make starting easier when > the engine is already hot. The thought is that the fuel sitting > stagnant in the hose within the hot engine compartment can > vaporize, making subsequent starting difficult. How big of a > problem this really is depends on who you talk to. I know plenty > of pilots with fuel injection on their certified planes that have > never heard of a purge valve either. Regardless, the "solution" to > the problem is a purge valve at the fuel divider, where the fuel is > distributed to the individual cylinders. The purge valve is > manually opened the using a bowden cable, and returns the hot fuel > into one of the lines leading to your tanks. > > You should also know that the purge valve is also used to kill the > engine. Apparently, mixture control cannot completely stop all > fuel from reaching the engine and it may be able to keep running- > not the case when using the purge valve. > > Somebody else chime in if Ive missed anything. We need to distinguish between two different fuel injection systems: Airflow Performance (AFP) - AFP fuel injection systems are commonly used to modify carbuereted engines to fuel injection. They are also commonly used on new built or overhauled engines for experimental use. AFP recommends a purge line for their system, to facilitate hot starts, and because in many installations the engine cannot be stopped with the mixture control. Precision (originally made by Bendix) - this is the fuel injection system that comes on fuel-injected engines as delivered by Lycoming. This system, as installed on type certificated aircraft, does not have, or need a purge valve. The vast majority of installations on experimental aircraft are without a purge valve. Find out what type of fuel injection your engine will have, then you can figure out whether a fuel return line will be needed. Kevin Horton Ottawa, Canada ________________________________________________________________________________
Date: Aug 04, 2006
Subject: RE: Rear Prop Gov. Questions / plate
Hi All- First off, I forget who originally brought the topic of the governor pad plate up, but the majority of you are safe as it only applies to the dual mag engines. To address your specific questions: >I don't recall getting a 'plate' with my Jihostroj governor. It's a Lyc part. >Details please! How thick, what shape, what material, specific to governor brand, >where in what manual is it referred to, anyone got pictures.....? It's a piece of sheet metal, steel I believe, that is configured just like the gov gaskets, except that it is missing the smaller of the two holes that lie on it's long axis. It is required because of the dual mag accessory case, not a specific governor. It is part # LW-12347 and appears as item #31 in figure 8, pages 2-3 and 2-4 of the Lyc IO 360 wide cylinder flange engine parts catalog. >You have me confused by the use of the word "case" above. I was >under the impression that these items were located between the >governor and the adapter. Am I wrong? Do they go between the adapter >and the accessory case? Sorry for the confusion- the dual mag engines don't use an adaptor, and as such the plate goes between the accessory case pad and the governor itself. >I too need some clarification. I have a governor, an adaptor, and an >accessory case. At which joint does the metal plate go? Apparently the metal >plate must have a rough surface or serrations, etc., that hold the gaskets >better. Is this true? If you need an adaptor, you do not use the plate, and vice versa. The plate is smooth, as I recall it. >Something that I had never thought about is that the prop pressure must run >well above engine oil pressure -- perhaps 150 PSI? That means that the front >main bearing is being lubricated by this pressure too, since there are no >seals between the prop feed and the 2 bearing surfaces on the front main >bearing. I can't comment on the oil pathways for the lubrication of the fwd bearings (anyone from BPA listening in?), but if my interpretation of the docs that came with my gov (in Czech and SI) is correct, it was tested to an output of 330 psi. I also checked with a Hartzell techie, and all he could contribute at the moment was that they bench test their props at between 110 and 120 psi (air) and advise prop shops to not exceed 175 psi. This is, of course, in a static condition and higher pressures could be encountered in flight. I'll let you guys know if / when they call back with more info. Sorry if this exchange put a scare into any of the single mag folks out there! glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Re: Will an RV Fly without the slider canopy
I guess with that, is it a slider or tip up. with a slider you have somewhat of a shield up front. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52364#52364 ________________________________________________________________________________
Date: Aug 04, 2006
Garry, Its a Air Flow Performance thing. Its necessary to be sure that the fuel stops going to the spider and on to the injectors. The purge valve lets off any pressure that may be there after the engine trys to stop. (not quite). It also lets you run cooler fuel up to the distribution spider when doing a "hot start". This stops any unwanted burps when starting after a hot start. I don't want to be on take off and have a air bubble in the line suddenly cause the engine to quit. The vaporization is caused by hot fuel vaporizing in the system. I'm told some systems do fine with out the purge system. Me? I'll use it. Jim ________________________________________________________________________________
Date: Aug 04, 2006
Subject: New F.A.B. alternate air intake
A couple of weeks or so ago I asked about other builder's experiences with Van's new alternate air intake that mounts on the bottom of the Filtered Air Box (FAB) I think I now have a solution that works, at least to my satisfaction. No testing yet, I'm still ground-bound for awhile longer. I bought another of Van's new shuttered oil cooler air controls ($85.00!) and mounted it under the FAB, leaving the round metal flange of the 2nd generation alternate air intake in place but removing the swinging door. I spaced the shuttered door down 1/4", more or less, to create a small plenum and adapt the larger rectangular shuttered door to the smaller round opening. I also incorporated a larger mounting plate for the shutter so my nutplates could all be outside the footprint of the filter. It all seems to work. It opens and closes with a short (maybe 1-1/2") pull on the knob in the cockpit. Disadvantages: a) A little more weight, b) It isn't completely air tight, and c) I have some nutplates now inside the FAB but outside the filter creating some turbulence in the incoming air, and d) $85.00 plus the control cable and other mounting hardware. Terry RV-8A finishing (?) Seattle ________________________________________________________________________________
Date: Aug 04, 2006
Unless you take off within about a minute I do not forsee this happening. Many pilots claim to suffer from vapor hot starts but it just turns out that they do not know how to start their own airplane. When you pull the mixture to idle cut off it should fully make the stop and thus close off the mixture valve or slide in varying carbs, throttle bodies, etc. Fuel flow dividers have a spring loaded poppet valve to stop fuel flow to the cylinders below 3psi. FYI Charlie ----- Original Message ----- Sent: Friday, August 04, 2006 4:39 PM > > Garry, > Its a Air Flow Performance thing. Its necessary to be sure that > the fuel stops going to the spider and on to the injectors. The purge > valve lets off any pressure that may be there after the engine trys to > stop. (not quite). It also lets you run cooler fuel up to the > distribution spider when doing a "hot start". This stops any unwanted > burps when starting after a hot start. I don't want to be on take off > and have a air bubble in the line suddenly cause the engine to quit. > The vaporization is caused by hot fuel vaporizing in the system. I'm > told some systems do fine with out the purge system. Me? I'll use it. > > > Jim > > > ________________________________________________________________________________
Date: Aug 04, 2006
We have been through all this before, more than once. Check the archives. Airflow Performance's owner's manual states that idle cut-off with the mixture will NOT reliably shut off the engine. Some fuel still leaks by. So they recommend installing the purge valve to be used to recirculate the fuel to cool it down when it the engine gets head soak, AND to shut down the engine. Terry RV-8A, Aerosport Power/Superior IO-360B1B (180hp) with Airflow Performance fuel injection -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Reiche Sent: Friday, August 04, 2006 3:24 PM Unless you take off within about a minute I do not forsee this happening. Many pilots claim to suffer from vapor hot starts but it just turns out that they do not know how to start their own airplane. When you pull the mixture to idle cut off it should fully make the stop and thus close off the mixture valve or slide in varying carbs, throttle bodies, etc. Fuel flow dividers have a spring loaded poppet valve to stop fuel flow to the cylinders below 3psi. FYI Charlie ----- Original Message ----- Sent: Friday, August 04, 2006 4:39 PM > > Garry, > Its a Air Flow Performance thing. Its necessary to be sure that > the fuel stops going to the spider and on to the injectors. The purge > valve lets off any pressure that may be there after the engine trys to > stop. (not quite). It also lets you run cooler fuel up to the > distribution spider when doing a "hot start". This stops any unwanted > burps when starting after a hot start. I don't want to be on take off > and have a air bubble in the line suddenly cause the engine to quit. > The vaporization is caused by hot fuel vaporizing in the system. I'm > told some systems do fine with out the purge system. Me? I'll use it. > > > Jim > > > ________________________________________________________________________________
Date: Aug 04, 2006
Terry Watson wrote: > >We have been through all this before, more than once. Check the archives. > >Airflow Performance's owner's manual states that idle cut-off with the >mixture will NOT reliably shut off the engine. Some fuel still leaks by. So >they recommend installing the purge valve to be used to recirculate the fuel >to cool it down when it the engine gets head soak, AND to shut down the >engine. > >Terry >RV-8A, Aerosport Power/Superior IO-360B1B (180hp) with Airflow Performance >fuel injection > You know, every time that I've just about convinced myself to forget about auto conversions because they are just too much trouble to adapt & install, I get a little reminder about 'aircraft quality'. (And this thing is supposed to be an *improvement* over the Bendix !) :-) ________________________________________________________________________________
Date: Aug 04, 2006
I lost a tip-over canopy (no windshield) on a full scale plastic replica of a P-51 with a T-53 Lycoming Turbine. I was at about 185 kias when it came off. I flew about 5 miles back to the airport and landed. I had to add some power on downwind/ base and the helmet nearly tore my head off. It was the most physically demanding thing I have ever done in my life!!!! The visor was ripped off my helmet, but the helmet kept my glasses on my face and protected my eyes. Without them I doubt I could have done it. We found the canopy on the roof of a building, buffed out the scratches, glued the hinges on again and 24 hours later, we were flying again. With a safety latch. There was a harmonic in the latch lever. The lever vibrated and came unlatched again while I was being photographed on the East side of Lake Winnebago at OSH and it was a long scary trip back to OSH, but the safety latch held. I would not recommend it. Latch your canopy and check it twice! I like the fixed windscreen on the Rocket! Tailwinds, Doug Rozendaal F1 EVO Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52476#52476 ________________________________________________________________________________
Date: Aug 04, 2006
Subject: Re: Modified squeezer die set for trailing edges
Sure. I have one. I thought it worked great. "Folbrecht, Paul" wrote: After not the best results using the traditional method on my rudder TE, I'd like to try this: http://www.matronics.com/photoshare/jimnbev@olypen.com.07.29.2003/index.html on the elevators. Does anybody happen to have a set of grinded dies for this purpose? If there was a set available for sale or lending I would prefer that to making my own. I can be reached off-list at paul.folbrecht(at)veribox.net. Thanks, Paul 9A QB #1176 Sherman Butler RV-7a Wings Idaho Falls --------------------------------- See the all-new, redesigned Yahoo.com. Check it out. ________________________________________________________________________________
Date: Aug 05, 2006
Subject: Re: nav-aid question
In a message dated 8/5/2006 10:22:57 A.M. Eastern Daylight Time, bertrv6(at)highstream.net writes: Hi: I am ready to connect my Nav aid. For those with this unit. Is there another way to setting the servo to neutral, without having to open unit? Bert, I don't think so. You need to do that mechanical adjustment with the unit open. Dan Hopper RV-7A ________________________________________________________________________________
Date: Aug 05, 2006
-----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of B25Flyer Sent: Friday, August 04, 2006 10:11 PM I lost a tip-over canopy (no windshield) on a full scale plastic replica of a P-51 with a T-53 Lycoming Turbine. I was at about 185 kias when it came off. I flew about 5 miles back to the airport and landed. I had to add some power on downwind/ base and the helmet nearly tore my head off. It was the most physically demanding thing I have ever done in my life!!!! Doug: Some years ago the late A.J.Smith took off from a local airport in his AJ2 and the canopy came unlatched. The unit, hinged on the right side, remained slightly open and he could not pull it back down by hand. When he started a turn the canopy flopped over and remained with the aircraft like an bathtub on the side of the fuselage. He then was faced, literally, with unprotected eyes, a well over 100kt slipstream at below freezing temperatures. Realizing he would lose his vision quickly he managed to fly an abbreviated pattern and land on the departure runway. Makes one think. Gordon Comfort N3363GC ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Date: Aug 05, 2006
Do you even need a purge line? I have a bendix system without a purge line and mine works fine. Shemp/Jeff Dowling RV-6A, N915JD 295 hours Chicago/Louisville ----- Original Message ----- Sent: Thursday, August 03, 2006 4:12 PM > > > Howdy > > I need to install a fuel purge line for my fuel injection system. What > kind of hose do folks recommend for the portion that will be in front of > the firewall? Since its only a purge line, does it really need any special > protection (i.e, steel braid and/or firesleeve)? > > thanks > > Erich Weaver > > > ________________________________________________________________________________
Date: Aug 05, 2006
Subject: Leaning on ground?
So whats a good technique for leaning on the ground. Shemp/Jeff Dowling RV-6A, N915JD 295 hours Chicago/Louisville ----- Original Message ----- Sent: Thursday, August 03, 2006 4:12 PM > > > Howdy > > I need to install a fuel purge line for my fuel injection system. What > kind of hose do folks recommend for the portion that will be in front of > the firewall? Since its only a purge line, does it really need any special > protection (i.e, steel braid and/or firesleeve)? > > thanks > > Erich Weaver > > > ________________________________________________________________________________
Date: Aug 05, 2006
It took me about 4 try's. Fly, remove all the stinking screws, adjust, repeat. Its just another test in patience. Enjoy Shemp/Jeff Dowling RV-6A, N915JD 295 hours Chicago/Louisville ----- Original Message ----- From: Hopperdhh(at)aol.com To: rv-list(at)matronics.com Sent: Saturday, August 05, 2006 9:27 AM Subject: Re: RV-List: nav-aid question In a message dated 8/5/2006 10:22:57 A.M. Eastern Daylight Time, bertrv6(at)highstream.net writes: Hi: I am ready to connect my Nav aid. For those with this unit. Is there another way to setting the servo to neutral, without having to open unit? Bert, I don't think so. You need to do that mechanical adjustment with the unit open. Dan Hopper RV-7A ________________________________________________________________________________
Date: Aug 05, 2006
Subject: radio stack mounting - standard widths?
I was about to mount two 1/16 plates of Al between the sub-panel and panel in my RV-6A to hold the radio trays, when I noticed that the mounting tray for my Garmin radio is about 1/32" smaller in width than the mounting tray for my Garmin transponder. If I proceed with this, the tray for the radio will have to be shimmed a bit. Is this type of width variation normal for mounting trays? If I add something else to the stack in the future, what is the chance that its tray will be still larger than the transponder's? Should I provide a little extra width now between the plates to accommodate wide trays in the future? Of course then, everything will have to be shimmed. -- Tom Sargent RV-6A ________________________________________________________________________________
Date: Aug 05, 2006
If you plan a cross-country cruise in even a moderately powered RV-8 without a canopy, I suggest a very good GPS and electronic Jepp plates . . . 'cause you'll never be able to unfold a sectional map. I asked Danny King from Texas this same question some time back when our California Central Valley summer temperatures were hovering over 100 degrees. He wisely told me to quit day dreaming and get back to building. Pete Cowper RV-8 #81139 (working on fuselage) Visalia Municipal Airport, Hanger B-5 Vice-President, EAA Tex Rankin Chapter #262 ________________________________________________________________________________
Date: Aug 05, 2006
Subject: SL-30 and GTX-327 mounting trays
More radio tray problems: My Garmin SL-30 was supplied with an aluminum tray that has 3/16" mounting holes punched in the side, but it only has about 1/32" of space for the screw head - any larger than that and the radio will hit it when it slides in the tray. Perhaps a #4 pan head screw would fit. Or, I could just rivet the thing to the support frame. What have other people done to mount this tray? The Garmin GTX-327 transponder tray comes with 3/16" screw holes also, and they are countersunk. The countersinks are no where near deep enough to accommodate a #10 screw or a #8 either. Does any one have any advice on how to secure this to the mounting frame? Thanks, -- Tom S., RV-6A ________________________________________________________________________________
Date: Aug 05, 2006
Tom, Same problem here. I have the Garmin's GTX 320, SL40, GMA 347 and King KX155 in the same rack. The SL40 is wider than all of the others and the mounting angles were bowed slightly the get the SL40 rack between the angles -- angles clecoed top and bottom and center holes drilled after the SL40 rack was inserted between the angles. I used screws and nutplates to secure the angles to the panel vs. rivets. I also used a file to slightly enlarge the hole in the panel to allow the SL40 to be inserted in the rack. It is not visually noticeable and the radio faceplate hides the edges of the hole anyway. Bill RV-7 wiring -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of sarg314 Sent: Saturday, August 05, 2006 1:02 PM I was about to mount two 1/16 plates of Al between the sub-panel and panel in my RV-6A to hold the radio trays, when I noticed that the mounting tray for my Garmin radio is about 1/32" smaller in width than the mounting tray for my Garmin transponder. If I proceed with this, the tray for the radio will have to be shimmed a bit. Is this type of width variation normal for mounting trays? If I add something else to the stack in the future, what is the chance that its tray will be still larger than the transponder's? Should I provide a little extra width now between the plates to accommodate wide trays in the future? Of course then, everything will have to be shimmed. -- Tom Sargent RV-6A ________________________________________________________________________________
Date: Aug 05, 2006
Tom, I may have some pictures if you're interested -- may have to send off line. Bill -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of sarg314 Sent: Saturday, August 05, 2006 1:11 PM More radio tray problems: My Garmin SL-30 was supplied with an aluminum tray that has 3/16" mounting holes punched in the side, but it only has about 1/32" of space for the screw head - any larger than that and the radio will hit it when it slides in the tray. Perhaps a #4 pan head screw would fit. Or, I could just rivet the thing to the support frame. What have other people done to mount this tray? The Garmin GTX-327 transponder tray comes with 3/16" screw holes also, and they are countersunk. The countersinks are no where near deep enough to accommodate a #10 screw or a #8 either. Does any one have any advice on how to secure this to the mounting frame? Thanks, -- Tom S., RV-6A ________________________________________________________________________________
Date: Aug 05, 2006
Erich: I treated it like any other fuel line. I used steel braided teflon throughout. >> >> >> Howdy >> >> I need to install a fuel purge line for my fuel injection system. What >> kind of hose do folks recommend for the portion that will be in front of >> the firewall? Since its only a purge line, does it really need any >> special >> protection (i.e, steel braid and/or firesleeve)? >> >> thanks >> >> Erich Weaver >> > ________________________________________________________________________________
Date: Aug 05, 2006
Subject: Re: SL-30 and GTX-327 mounting trays
---- sarg314 wrote: > > More radio tray problems: > > My Garmin SL-30 was supplied with an aluminum tray that has 3/16" > mounting holes punched in the side, but it only has about 1/32" of space > for the screw head - any larger than that and the radio will hit it when > it slides in the tray. Perhaps a #4 pan head screw would fit. Or, I > could just rivet the thing to the support frame. > > What have other people done to mount this tray? > > The Garmin GTX-327 transponder tray comes with 3/16" screw holes also, > and they are countersunk. The countersinks are no where near deep > enough to accommodate a #10 screw or a #8 either. > Does any one have any advice on how to secure this to the mounting frame? > > Thanks, > -- > Tom S., RV-6A Tom, I can't address the problem with the SL-30. However, my GTX 320A uses the exact same tray as your GTX 327. I used AN509-10 flush screws to mount my GTX 320A, Icom A200 and RMI uMonitor. You are correct that the dimple in the tray of the Garmin transponder does not allow the head of the screw to fit flush. However, there is room to install the radio with the screw head protruding. The protruding screw head actually acts as an internal shim, to steady the radio in the tray. The Garmin tray was wider (thicker material) than my other 2 trays. I simply made shims to compensate on the Icom and the uMonitor. I am very pleased with the fit and cosmetics of my installation. I suspect that you will find your SL-30 fits between the installed screw heads. If it doesn't, you could always dimple the tray mounting holes. Charlie Kuss ________________________________________________________________________________
Date: Aug 05, 2006
Subject: Rear Prop Gov. Questions
I can attest to the dumping oil overboard scenario having just experienced it on my trip to Oshkosh. The Lyc in my Navion has a similar adapter for the prop governor with a thin plate sandwiched by two paper-thin gaskets. One of the gaskets let go (at the high pressure port) and it was pumping a quart out every 2 hours. It turned out to be one of the cheapest to fix problems I've had but it was unnerving and could have been worse. Be careful if you have that setup. Use the manuals to be sure you get it right. Greg Young > > The metal plate goes between two gaskets, and the trio is > then placed between the gov and the case. It seems that > there is an oil passage that is too close to the edge of the > mating surfaces, and without the plate the gasket material > can blow out and port all you oil overboard. IIRC, there is > at least one such scenario in the archives. And, yes, it's > quite easy to chuck the plate with the gaskets. You may > wonder how I know that... > ________________________________________________________________________________
Date: Aug 05, 2006
Subject: is this spray gun ok?
want to know if my spray gun is usable. i set up a clean air line for spray priming, and then bought an el cheapo spray gun from hft. the gun has some oil on the internal parts apparently for lube or preservation from the manufacturer. is this normal? can i clean the gun maybe by spraying some mek or alcohol through it? thanks for any newbie education... jeff -------- -Clam ------------------ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52626#52626 ________________________________________________________________________________
Date: Aug 05, 2006
Unfortunately, those photos were too offensive for some and have been removed from the site. jsflyrv(at)verizon.net wrote: > Not sure if these have been posted here or not, sorry if this link has > already been posted. > > http://www.vansairforce.com/community/showpost.php?p=63452&postcount=12 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52694#52694 ________________________________________________________________________________
Date: Aug 06, 2006
Not pictures but info: http://www.ntsb.gov/ntsb/brief.asp?ev_id 060804X01093&key=1 http://www.ntsb.gov/ntsb/brief.asp?ev_id 060804X01093&key=2 Typically users of the forum upload images to: http://www.imageshack.us but I have not found a way to seach for what others have stored there. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,932 + Flying Hours So. CA, USA ----Original Message Follows---- I agree.. The photos were priceless lesson material. I'm annoyed now that I did not save copies in my 'Pilotage' directory. They should be mandatory viewing for every tail-dragger pilot. If someone has copies I would be grateful to receive them. Perhaps they could be posted as attachments to the 'list. Doug Gray > > They were up when I posted the link. I am truly sorry for the families > involved but if it were me in that > situation I would want those photos posted everywhere, so other pilots > would never be lax about what is > going on around them at all times. Those photos were worth more than any > words could ever be plus there was nothing > offensive about them, just a horrible accident site. I have seen much > worse on TV and newspapers when it > comes to aircraft accidents and auto accidents. > > Jerry > > > > Dave Johnson wrote: > > > > >Unfortunately, those photos were too offensive for some and have been removed from the site. > > > > > >jsflyrv(at)verizon.net wrote: > > > > > >>Not sure if these have been posted here or not, sorry if this link has > >>already been posted. > >> > >>http://www.vansairforce.com/community/showpost.php?p=63452&postcount=12 > >> > >> > > > > > > > > > > > >Read this topic online here: > > > >http://forums.matronics.com/viewtopic.php?p=52694#52694 > > ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Re: Leaning on ground?
Shemp, Leaning your engine on the ground will greatly reduce the lead deposits on your spark plugs. The anti-lead agent incorporated in AvGas doesn't activate until things get hot - generally around 1800 RPM. Anytime you operate the engine rich below that heat threshold you will be depositing lead on the plugs. Here's a good way to ground lean (Lycoming recommended): Most people taxi with the RPM near idle; there's plenty of thrust to keep rolling. You do, however, need a little more than that to get things rolling, so you need to find the lowest RPM at which the aircraft starts to move. 1. Taxi to a level area and close the throttle to idle. 2. Slowly advance the throttle with your feet off the brakes until the aircraft starts to roll; note the RPM. 3. Stop. 4. Set the throttle to the RPM noted before (usually around 1200). 5. Lean the mixture until the RPM starts to drop off. That's it! Set aside your fears of taking off with the mixture too lean - your engine with falter and die if you advance the throttle beyond 1200 RPM (or wherever you set the mixture). Similarly, have no fear of "burning up" your engine due to an over-lean condition - you cannot over-lean the engine at power settings below 75%. If you don't want to go through the whole level ground thing (or if your airplane starts rolling with the RPM at idle), just use 1200 RPM - it's usually enough to get you started rolling unless you're pointed up a steep hill. If you find you need a little more RPM to get started (grass, steep hill, nose gear sharply turned, all of the above!) just push in the mixture until you get started, then go back to your lean setting at 1200 RPM. The first couple of times through the procedure will take some time; after that it becomes second nature. You'll find yourself ground leading after landing (as soon as you turn off the runway, of course) while taxiing to parking. A final note, do a 20 second run-up (at least 1800 RPM) prior to every engine shut down. This will activate the anti-leading agent in the fuel further reducing lead deposits. I run up to 1800 RPM, time for 20 seconds, quickly back to 1200 RPM, then immediately pull the mixture to kill the engine. If you don't touch the throttle, the next time you start the engine it will already be at 1200 RPM - ready for setting the mixture to ground lean. Mark Sletten Legacy FG N828LM http://www.legacyfgbuilder.com ________________________________________________________________________________
Date: Aug 06, 2006
Spot on, Jerry. I got "moderated" on the VAF site for suggesting that it was poor judgement to remove the photos, and requesting a considerably broader censoring policy to allow such things in the future. The personal attacks toward me that followed from a handful of other posters were something to behold. If anyone has the photos, I will be glad to host them on my web server and link them back here. I'm going to start appending "if it pleases the king and his loyal subjects" to my posts over there [Laughing] I'm sure Doug is a great guy, but that experience was not a positive one for me. Dave jsflyrv(at)verizon.net wrote: > They were up when I posted the link. I am truly sorry for the families > involved but if it were me in that > situation I would want those photos posted everywhere, so other pilots > would never be lax about what is > going on around them at all times. Those photos were worth more than any > words could ever be plus there was nothing > offensive about them, just a horrible accident site. I have seen much > worse on TV and newspapers when it > comes to aircraft accidents and auto accidents. > > Jerry > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52731#52731 ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Aug 06, 2006
About a year and a half ago the Matronics RV-10 list was essentially dead and all of the -10 builders were on one of Doug's Yahoo list. Several of us started to experience his idea of what was socially acceptable through his moderation and so we worked with Matt to make a couple of small modifications to his RV-10 list. Once completed we all promptly mutinied and left the Yahoo list which promptly shriveled and died. What really PO'd me was when he started to edit my posts with absolutely no comment that he did so. That was the last straw for me. I feel a little sense of satisfaction that his RV-10 forum on his website never took off either. I do not know Doug personally nor have I ever met him. I also think his website adds value to the RV community. But understand that he now runs it as a business to make money. He may have started it with other ideas but he has long since realized the profit potential and does not tolerate any criticism of his actions. I just wish he would drop the pretense that anything the site makes are for his kids college fund. As a business it is his right to edit any content on his site whereas these Matronics lists are a true community that is allowed to work through its issues and determine what is acceptable. Michael Sausen -10 #352 on hiatus -----Original Message----- [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Johnson Sent: Sunday, August 06, 2006 8:19 AM Spot on, Jerry. I got "moderated" on the VAF site for suggesting that it was poor judgement to remove the photos, and requesting a considerably broader censoring policy to allow such things in the future. The personal attacks toward me that followed from a handful of other posters were something to behold. If anyone has the photos, I will be glad to host them on my web server and link them back here. I'm going to start appending "if it pleases the king and his loyal subjects" to my posts over there [Laughing] I'm sure Doug is a great guy, but that experience was not a positive one for me. Dave jsflyrv(at)verizon.net wrote: > They were up when I posted the link. I am truly sorry for the families > involved but if it were me in that situation I would want those photos > posted everywhere, so other pilots would never be lax about what is > going on around them at all times. Those photos were worth more than > any words could ever be plus there was nothing offensive about them, > just a horrible accident site. I have seen much worse on TV and > newspapers when it comes to aircraft accidents and auto accidents. > > Jerry > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=52731#52731 ________________________________________________________________________________
Date: Aug 06, 2006
http://flickr.com/photos/bowen/tags/oshkosh2006accident/ - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: RV6 Flyer [mailto:rv6_flyer(at)hotmail.com] > Sent: Sunday, August 06, 2006 8:07 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Re: Accident photos > > > > Not pictures but info: > > http://www.ntsb.gov/ntsb/brief.asp?ev_id 060804X01093&key=1 > > http://www.ntsb.gov/ntsb/brief.asp?ev_id 060804X01093&key=2 > > Typically users of the forum upload images to: > http://www.imageshack.us but I have not found a way to seach > for what others have stored there. > > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 1,932 + Flying Hours So. CA, USA > > > > > ----Original Message Follows---- > Reply-To: rv-list(at)matronics.com > > > I agree.. > The photos were priceless lesson material. I'm annoyed now that I did > not save copies in my 'Pilotage' directory. They should be mandatory > viewing for every tail-dragger pilot. > If someone has copies I would be grateful to receive them. > Perhaps they > could be posted as attachments to the 'list. > Doug Gray > > > > > > They were up when I posted the link. I am truly sorry for > the families > > involved but if it were me in that > > situation I would want those photos posted everywhere, so > other pilots > > would never be lax about what is > > going on around them at all times. Those photos were worth > more than any > > words could ever be plus there was nothing > > offensive about them, just a horrible accident site. I > have seen much > > worse on TV and newspapers when it > > comes to aircraft accidents and auto accidents. > > > > Jerry > > > > > > > > Dave Johnson wrote: > > > > > > > >Unfortunately, those photos were too offensive for some > and have been > removed from the site. > > > > > > > > >jsflyrv(at)verizon.net wrote: > > > > > > > > >>Not sure if these have been posted here or not, sorry if > this link has > > >>already been posted. > > >> ________________________________________________________________________________
Date: Aug 06, 2006
Subject: More on fuel breather problems ...
Many thanks for the suggestions on the fuel breather problems on my RH tank. here are the latest observations : If I blow through the breather from the inlet under the fuselage, then air reaches the far end of the breather in the upper corner of the tank. If I fill the tank (below the tank breather level ) in hot weather fuel will start to vent underneath the aircraft and come out in a constant stream that appears as though it is siphoning, this will continue until a lot of fuel has been lost and the tank has lost a considerable amount of fuel. My concussion is that there maybe a leak in the breather on the inside of the tank. Fuel leaks into the breather, and as the air in the tank expands it forces the fuel out along the breather. Once pressurised the fuel starts to flow, and then siphons until equilibrium is reached. Problem - how do I fix the leak without removing the tank and messing up an expensive paint job ? or am I barking up the wrong tree ? At nearly $10/gal I would really like to fix this problem. Any suggestions appreciated. Rgds, Nic PS - THIS IS A QB READY-BUILT VANS TANK ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Aug 06, 2006
Subject: Re: More on fuel breather problems ...
A guess is that something has come loose where the vent line attaches to an AN fitting inside the tank rib at the wing root. In an RV-6 tank, you can access that fitting by removing the fuel tank access/sender plate at the root end of the fuel tank. Once you have access to the fitting, you can tighten it and maybe apply a little proseal where it goes through the tank rib. KB ----- Original Message ----- Sent: Sunday, August 06, 2006 12:40 PM > > Many thanks for the suggestions on the fuel breather problems on my RH > tank. > here are the latest observations : > > If I blow through the breather from the inlet under the fuselage, then air > reaches the far end of the breather in the upper corner of the tank. > > If I fill the tank (below the tank breather level ) in hot weather fuel > will > start to vent underneath the aircraft and come out in a constant stream > that > appears as though it is siphoning, this will continue until a lot of fuel > has been lost and the tank has lost a considerable amount of fuel. > > My concussion is that there maybe a leak in the breather on the inside of > the tank. Fuel leaks into the breather, and as the air in the tank expands > it forces the fuel out along the breather. Once pressurised the fuel > starts > to flow, and then siphons until equilibrium is reached. > > Problem - how do I fix the leak without removing the tank and messing up > an > expensive paint job ? or am I barking up the wrong tree ? At nearly > $10/gal I would really like to fix this problem. Any suggestions > appreciated. > > Rgds, Nic > > PS - THIS IS A QB READY-BUILT VANS TANK > > > ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Accident pictures
Interesting reading http://www.ntsb.gov/ntsb/brief.asp?ev_id 060804X01093&key=2 ________________________________________________________________________________
Date: Aug 06, 2006
Quoting "RV Builder (Michael Sausen)" : > > > About a year and a half ago the Matronics RV-10 list was essentially > dead and all of the -10 builders were on one of Doug's Yahoo list. > Several of us started to experience his idea of what was socially > acceptable through his moderation and so we worked with Matt to make a > couple of small modifications to his RV-10 list. Once completed we all > promptly mutinied and left the Yahoo list which promptly shriveled and > died. What really PO'd me was when he started to edit my posts with > absolutely no comment that he did so. That was the last straw for me. > I feel a little sense of satisfaction that his RV-10 forum on his > website never took off either. > > I do not know Doug personally nor have I ever met him. I also think > his website adds value to the RV community. But understand that he now > runs it as a business to make money. He may have started it with other > ideas but he has long since realized the profit potential and does not > tolerate any criticism of his actions. I just wish he would drop the > pretense that anything the site makes are for his kids college fund. As > a business it is his right to edit any content on his site whereas these > Matronics lists are a true community that is allowed to work through its > issues and determine what is acceptable. > > Michael Sausen > -10 #352 on hiatus > > -----Original Message----- > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Johnson > Sent: Sunday, August 06, 2006 8:19 AM > > > Spot on, Jerry. I got "moderated" on the VAF site for suggesting that it > was poor judgement to remove the photos, and requesting a considerably > broader censoring policy to allow such things in the future. The > personal attacks toward me that followed from a handful of other posters > were something to behold. If anyone has the photos, I will be glad to > host them on my web server and link them back here. I'm going to start > appending "if it pleases the king and his loyal subjects" to my posts > over there [Laughing] > > I'm sure Doug is a great guy, but that experience was not a positive one > for me. > > Dave > > > jsflyrv(at)verizon.net wrote: > > They were up when I posted the link. I am truly sorry for the families > > > involved but if it were me in that situation I would want those photos > > > posted everywhere, so other pilots would never be lax about what is > > going on around them at all times. Those photos were worth more than > > any words could ever be plus there was nothing offensive about them, > > just a horrible accident site. I have seen much worse on TV and > > newspapers when it comes to aircraft accidents and auto accidents. > > > > Jerry > > > > I for one, do not want to see, the tragic results of this or any accident. Is bad enough, that one of our brothers in what we love most, flying, has met such fate. I do not belong to this generation for sure....this nonsense of" freedom" to profanity, vulgarity, pronography, show anything, do anything you want any time you want... The total degeneration os Society, no morals no right or wrong... Bert rv6a dop not archive > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=52731#52731 > > ________________________________________________________________________________
Date: Aug 06, 2006
Subject: Re: Cooling Blast tubes - Lycoming
Quoting LarryRobertHelming : > > > ----- Original Message ----- > Sent: Saturday, July 29, 2006 10:05 AM > > > > > > RV7A - IO360 > > I'm planning to install 5/8" blast tubes from baffling to fuel pump, 1 > > mag, > > and alternator. > > > > Routing and securing to baffling is easy but any tricks on securing the > > end > > where the component is so the cooling > > blast actually hits the fuel pump? Adel clamps stategically placed? > > Pics? > > > > Thanks > > Steve > > RV7A flying soon! > > > ((((((((())))))))) > I found a good bit of use for safety wire when securing the blast tubes to > keep them aimed where wanted. Simple to use. > > Indiana Larry with one trip to OSH completed. > > > > Larry: I use tie wraps, to secure end of plastic corrugated, tubes, to hold them where they suppose to stay for cooling. A better way, is to use a piece of,soft wire, I think is about 1/8 or so thick, the length of the cooling tube, inserted inside it, and attached end in loop,with a screw, to convenient place, screw and nut.. or perhaps nut-plate.. I do not know name of wire or where to get it...it feels like lead, is easily bend and twist...yet strong enough to hold, seen in some planes..works well. ' bert rv6a donot archive > > ________________________________________________________________________________
Date: Aug 06, 2006
Subject: New Incoming Message Size Limit Implemented...
Dear Listers, Due to a number of requests to limit the size of incoming posts to the Lists because of the recently added enclosure feature, I have add a new filter that will limit the total size of any given message posted to the List. I have initially set the limit to 2MB and we'll see how everyone likes that. If a member attempts to post a message that is greater than the set limit, they will receive an email back indicating that their message wasn't posted to the List and why. Also included in the message will be the current size limit and how large their message was. Some might say that 2MB is still too large, but its a place to start... Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Electronics International 6 cyl Deluxe Pkg for sale
Date: Aug 06, 2006
I have an EI 6cyl (all probes + 4 extras, manuals, warranty cards) Deluxe Instrument Package (http://www.buy-ei.com/Panel%20Package.htm) for sale. It has never been in a plane and all the warranty cards are waiting to be activated. The instruments have a total of 30 minutes time that was incurred during a dyno run. They were new then and worked flawlessly. I've decided to go with an EFIS/EIS combo glass panel. EI gets $4600 for this panel of gauges. I'm asking $3200/ best offer. Please email me off list jonlaury(at)impulse.net ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Aug 06, 2006
Threaded brass rods will also work in place of the heavy wire. I have used the bent rods with safety nuts or nuts with lock washers and the safety wire with success for holding blast tubes in place. Larry in Indiana ----- Original Message ----- From: <bertrv6(at)highstream.net> > >> ----- Original Message ----- >> Sent: Saturday, July 29, 2006 10:05 AM >> >> >> > >> > RV7A - IO360 >> > I'm planning to install 5/8" blast tubes from baffling to fuel pump, 1 >> > mag, >> > and alternator. >> > >> > Routing and securing to baffling is easy but any tricks on securing the >> > end >> > where the component is so the cooling >> > blast actually hits the fuel pump? Adel clamps stategically placed? >> > Pics? >> > >> > Thanks >> > Steve >> > RV7A flying soon! >> > > > I use tie wraps, to secure end of plastic corrugated, tubes, to hold > them where they suppose to stay for cooling. > > A better way, is to use a piece of,soft wire, I think is about 1/8 or so > thick, the length of the cooling tube, inserted inside it, and attached > end > in loop,with a screw, to convenient place, screw and nut.. or perhaps > nut-plate.. > > I do not know name of wire or where to get it...it feels like lead, is > easily > bend and twist...yet strong enough to hold, seen in some planes..works > well. > ' > bert > > rv6a > > donot archive > ________________________________________________________________________________
Subject: Misl bolts
Date: Aug 06, 2006
I am looking for an 10-24 1/2 bolts with holes on the heads for the lycoming 0320 seal retainer so I can mount my prop and spacer.. anyone have a good location to get these, I have looked everywhere locally.. #10 24threads per inch 1/2 long.. any ideas ? I need 4 of them.. Danny.. ________________________________________________________________________________
Subject: Re: Accident photos
Date: Aug 06, 2006
This is bit of a rant and you may have heard it from me before, so of course delete if you want. Strong disagreement would be appropriate if you think I'm off base.: ........... I'm with Jerry on this one. We have censored each other to the point that we can't talk about and learn anything from the loss of those who share our interest in flying little airplanes. We can't talk about Scott Crossfield's accident because that might not show the respect he deserves. We shouldn't look at pictures of a beautiful RV-6 chopped up by a prop because it might offend someone's sensibilities? None of us get out of this life alive and it stands to reason and past experience that some of us are going to take our RV's with us. So again and again, we are going to face the choice of trying to learn from a tragic event, or to avert our eyes and avoid question or comment lest we offend the dead, injured, their survivors, family, friends, or those who would have been friends had they had a chance to know them. If you have been on this list for very long you have likely lost good friends and friends you hadn't actually met face to face yet. So here's MY request: If I screw up, or am the victim of someone else's screw-up, or if my tail falls off because I forgot to bolt it on properly or if I land long on a short runway or short of a long runway or if I scud run myself into a mountain, or run out of gas crossing Puget Sound, please feel free to postulate, speculate, blame, ridicule or whatever it takes to learn enough from my misfortune, bad judgment or stupidity to prevent some other soul from doing what lead to my demise. If I survive my misadventure I will most likely want to set the record straight or paint myself in a more heroic light, but if I don't, you will be on your own to sort it out. Make the best of it. What do you think the military's accident rate would be like if the S.O.P. after an accident was for everyone to stick their head in the sand and pretend it didn't happen? My apologies in advance if anyone feels flamed by this. I do not want to offend, just convince you that the more we know the safer we are. They put a sheet over dead bodies out of respect of the dead and the sensibilities of the living. That, in my mind, is the appropriate amount of censorship. Terry RV-8A finishing Seattle ________________________________________________________________________________
Date: Aug 07, 2006
Nic - I agree with Kyle. From what you describe my bet is the AN fitting where the vent line joins to the tank plate is not tight. I have heard of people getting the plate off without removing the tank or wing. That would give you an inch or so of access ....but it sounds like a bitch of a job. If it is any help you can see how it *should* be arranged inside if you go here <http://gikonwings.blogspot.com/>. The final of 3 pictures. Good luck, Steve. On 06/08/06, Kyle Boatright wrote: > > > A guess is that something has come loose where the vent line attaches to > an > AN fitting inside the tank rib at the wing root. In an RV-6 tank, you can > access that fitting by removing the fuel tank access/sender plate at the > root end of the fuel tank. > > Once you have access to the fitting, you can tighten it and maybe apply a > little proseal where it goes through the tank rib. > > KB > > ----- Original Message ----- > Sent: Sunday, August 06, 2006 12:40 PM > > > > > > Many thanks for the suggestions on the fuel breather problems on my RH > > tank. > > here are the latest observations : > > > > If I blow through the breather from the inlet under the fuselage, then > air > > reaches the far end of the breather in the upper corner of the tank. > > > > If I fill the tank (below the tank breather level ) in hot weather fuel > > will > > start to vent underneath the aircraft and come out in a constant stream > > that > > appears as though it is siphoning, this will continue until a lot of > fuel > > has been lost and the tank has lost a considerable amount of fuel. > > > > My concussion is that there maybe a leak in the breather on the inside > of > > the tank. Fuel leaks into the breather, and as the air in the tank > expands > > it forces the fuel out along the breather. Once pressurised the fuel > > starts > > to flow, and then siphons until equilibrium is reached. > > > > Problem - how do I fix the leak without removing the tank and messing up > > an > > expensive paint job ? or am I barking up the wrong tree ? At nearly > > $10/gal I would really like to fix this problem. Any suggestions > > appreciated. > > > > Rgds, Nic > > > > PS - THIS IS A QB READY-BUILT VANS TANK > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: N710RV First Flight
Date: Aug 07, 2006
Russ, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A >From: "Russell Daves" <dav1111(at)cox.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: N710RV First Flight >Date: Fri, 28 Jul 2006 18:42:25 -0500 > >First flight went off without a hitch today. Felt great. Plans are to fly >every day for the next two weeks, either before or after work on the real >job. > >Russ Daves ________________________________________________________________________________
Subject: RE:Accident photos
Date: Aug 07, 2006
>...I'm with Jerry on this one. We have censored each other to the point that we >can't talk about and learn anything from the loss of those who share our >interest in flying little airplanes.... Very well put, Terry. I couldn't agree more. To paraphrase George Santayana, "Those who don't learn from the past are doomed to repeat it." glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Aug 07, 2006
I see nothing offensive on these pics, I now understand how difficult it was for the taxi of this big avenger, I personally have learned that if I get in a situation and am told to taxi in front of such an aircraft I will use my pilot in command option and stay put until the big worly plan passes me. My simpathy to both the pilot in the avenger and those in the RV6 and families. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53045#53045 ________________________________________________________________________________
Date: Aug 07, 2006
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Subject: Re: Misl bolts
Hi Danny, Very odd size indeed... you may need to get longer bolts and cut them off. Easy enough to do. Darrell --- Sportypilot wrote: > I am looking for an 10-24 1/2 bolts with holes on > the heads for the lycoming 0320 seal retainer so I > can > mount my prop and spacer.. anyone have a good > location to get these, I have looked everywhere > locally.. > #10 24threads per inch 1/2 long.. any ideas ? I need > 4 of them.. > > > Danny.. __________________________________________________ ________________________________________________________________________________
Subject: Re: Oshkosh accident - Caution, on my Soapboxt
Date: Aug 07, 2006
Beware, this is an op ed post, There is no question that this was a tragedy almost beyond comprehension. I feel badly for the victim, the victim's family, anyone who witnessed it personally and, lastly, the TBM's PIC. That being said, I think it's important that we, as pilots, don't let this tragedy lead us somewhere - emotionally, intellectually or literally - someplace we don't want to go; we must keep our eyes on the ball. There is no question that wing walkers and/or ground spotters could have (most likely would have) prevented this accident. The bottom line in this case is there were none. I know I'm going to hear from those of you accusing me of armchair quarterbacking. That's as may be, but I felt compelled to comment in light of Linn's (maybe unintentional - see below) hints that someone other than the PIC might be responsible for the safe movement of his or her aircraft on the ground. Even *WITH* ground spotters, taxiing safely is still the responsibility of the PIC. To even hint, however faintly, otherwise is to open Pandora's Box. Intimating that someone other than the PIC is responsible is the 1st step to in the process wherein someone other then the PIC decides how to safely operate our aircraft. Taxiing an aircraft that dwarfs most others at the show, with limited visibility outside the aircraft, and knowing he was going to mix with many different kinds of aircraft on a crowded, busy taxiway *WITH NO SPOTTERS* should have spurred the Avenger pilot to take appropriate precautions - he was the PIC. >From the victim's point of view, and in light of the number of pilots who've made who-woulda-thunk-it comments, it's a safe bet that neither he, nor many others of us have considered this kind of accident before now. I'd say the majority of us will definitely think about it, and take appropriate precautions (a mirror, stopping on a slant to allow aft visibility, etc., let's keep those comments coming), should we find ourselves in a similar situation. Additionally, I believe adamantly it is in no way the responsibility of the EAA, or any other AirVenture organizer, to provide ground crews to prevent taxi accidents. Volunteers help direct the flow of traffic and, as a side benefit, might be in a position to *HELP* prevent ground accidents. Both of these aircraft were on an established taxiway and knew where they were going, therefore, no ground crews were provided. And that's as it should be unless the PIC decides otherwise. Further, *ANYONE* can volunteer to work at OSH during AirVenture - there is no way to determine qualifications or expertise. If you *MUST* have a ground crew to taxi safely, then the only way to be sure the crew is competent is to bring your own. IMHO, by providing safety observers specifically to "help" pilots safely taxi their aircraft, the EAA and AirVenture would become just as responsible as the PIC. That kind of liability coupled with a tragic event such as this can effectively kill large events like AirVenture. I wouldn't accept it - nor, do I think, will they. If we pilots demand that the EAA and AirVenture organizers take steps to *HELP* us avoid future accidents of this type, we shouldn't be surprised at what we get - like scheduled departure times by type. Mark Sletten Legacy FG N828LM http://www.legacyfgbuilder.com Linn Walters said: I read the NTSB report and understood exactly how it happened. The addition of volunteers with paddles to regulate the flow on the taxiway could have prevented this accident. It may be as simple as a golf cart on the grass to aid those pilots with forward visibility problems .... and as I said, it doesn't reside only with the warbirds ..... would go a long way to prevent a reoccurrence. The only other solution would be to set up departure times by type and I'm sure nobody wants that. What saddens me me about this accident is that it truly was preventable ..... like most accidents are. ________________________________________________________________________________
Date: Aug 07, 2006
>I'm with Jerry on this one. We have censored each other to the point that we >can't talk about and learn anything from the loss of those who share our >interest in flying little airplanes. We can't talk about Scott Crossfield's >accident because that might not show the respect he deserves. We shouldn't >look at pictures of a beautiful RV-6 chopped up by a prop because it might >offend someone's sensibilities? I had never heard of Crossfield but my initial thought was that he screwed up royally. That opinion has only been reinforced by obtaining additional info about the pilot error leading to death event. I learned nothing from that pilot error event since I already know that flying into severe thunderstorms is stupid. The Oshkosh Avenger/RV6 incident is not one that I had ever considered so I did learn from it. The pictures were not gruesome but were very informative. I have not been in a similar taxiing situation but if I ever am I will make appropriate actions to NOT be in front of such a plane. I often hear after aviation fatalities that we can all learn from it. Personally in recent years I don't recall any that I learned from except for this taxiing death. There may have been others that I don't recall. Fact is that pilots have always done stupid things that result in fatalities. I suspect that they always will and I see no way to dramatically reduce those pilot error fatalities. It would be great if the RV community could do something to reduce fatal pilot errors. Perhaps some sort of web-based training that discusses the major causes of deaths from pilot errors. If that training resulted in a reduction in insurance rates I would do it every year. Ideally it would mean fewer RV pilot deaths. And it would include photos. Ron Lee ________________________________________________________________________________
Subject: lower cowl heat shield picture?
Date: Aug 07, 2006
From: "Puckett, Gregory [DENTK]" <Greg.Puckett(at)united.com>
g'day all, I'm getting ready to install some of the Van's stick-on heat shield material to my lower cowl and would love to see a picture of where other have placed this stuff and found it successful at preventing burning/blistering. My install is an angle valve I0360-A3B6D with Van's smooth bottom s-type cowl and Vetterman exhaust. Thanks, Greg Puckett RV-8 N881GP (first engine start and taxi yesterday) ________________________________________________________________________________
Date: Aug 07, 2006
Well said, Terry. I would make the same request should I end up an aviation accident statistic. The taxi accident situation applies to all of us and we should learn from it. Regards, Richard Dudley Terry Watson wrote: > >This is bit of a rant and you may have heard it from me before, so of course >delete if you want. Strong disagreement would be appropriate if you think >I'm off base.: > >........... > >I'm with Jerry on this one. We have censored each other to the point that we >can't talk about and learn anything from the loss of those who share our >interest in flying little airplanes. We can't talk about Scott Crossfield's >accident because that might not show the respect he deserves. We shouldn't >look at pictures of a beautiful RV-6 chopped up by a prop because it might >offend someone's sensibilities? > >None of us get out of this life alive and it stands to reason and past >experience that some of us are going to take our RV's with us. So again and >again, we are going to face the choice of trying to learn from a tragic >event, or to avert our eyes and avoid question or comment lest we offend the >dead, injured, their survivors, family, friends, or those who would have >been friends had they had a chance to know them. If you have been on this >list for very long you have likely lost good friends and friends you hadn't >actually met face to face yet. > >So here's MY request: If I screw up, or am the victim of someone else's >screw-up, or if my tail falls off because I forgot to bolt it on properly or >if I land long on a short runway or short of a long runway or if I scud run >myself into a mountain, or run out of gas crossing Puget Sound, please feel >free to postulate, speculate, blame, ridicule or whatever it takes to learn >enough from my misfortune, bad judgment or stupidity to prevent some other >soul from doing what lead to my demise. If I survive my misadventure I will >most likely want to set the record straight or paint myself in a more heroic >light, but if I don't, you will be on your own to sort it out. > >Make the best of it. > >What do you think the military's accident rate would be like if the S.O.P. >after an accident was for everyone to stick their head in the sand and >pretend it didn't happen? > >My apologies in advance if anyone feels flamed by this. I do not want to >offend, just convince you that the more we know the safer we are. They put a >sheet over dead bodies out of respect of the dead and the sensibilities of >the living. That, in my mind, is the appropriate amount of censorship. > >Terry >RV-8A finishing >Seattle > > > > > > > > > ________________________________________________________________________________
Date: Aug 07, 2006
Subject: Re: lower cowl heat shield picture?
In a message dated 8/7/2006 11:14:27 A.M. Eastern Daylight Time, Greg.Puckett(at)united.com writes: g'day all, I'm getting ready to install some of the Van's stick-on heat shield material to my lower cowl and would love to see a picture of where other have placed this stuff and found it successful at preventing burning/blistering. My install is an angle valve I0360-A3B6D with Van's smooth bottom s-type cowl and Vetterman exhaust. Thanks, Greg Puckett RV-8 N881GP (first engine start and taxi yesterday) Greg, I don't have pictures, but here's what I did. First be sure you have painted the inside of the cowl with thinned epoxy. Then just put the foil down in large areas if the area is pretty flat and in smaller areas where it has curvature. In other words, it takes several separate pieces. I would say if you cover all areas that are within 6 inches of the exhaust system, you will have no problem. It isn't very hard to do, actually. Dan Hopper RV-7A 200HP ________________________________________________________________________________
Date: Aug 07, 2006
I agree whole heartedly, There is a reason that the Military preaches lessons learned, and any family that has lost someone, would certainly want others to avoid the tragedy by learning the lesson from another's mistake. Keep reviewing the lessons learned from each and every incident and we will break the chain, and prevent it from happening again. Dan 40269 (N289DT) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Terry Watson Sent: Monday, August 07, 2006 2:19 AM Subject: RE: RV-List: Re: Accident photos This is bit of a rant and you may have heard it from me before, so of course delete if you want. Strong disagreement would be appropriate if you think I'm off base.: ........... I'm with Jerry on this one. We have censored each other to the point that we can't talk about and learn anything from the loss of those who share our interest in flying little airplanes. We can't talk about Scott Crossfield's accident because that might not show the respect he deserves. We shouldn't look at pictures of a beautiful RV-6 chopped up by a prop because it might offend someone's sensibilities? None of us get out of this life alive and it stands to reason and past experience that some of us are going to take our RV's with us. So again and again, we are going to face the choice of trying to learn from a tragic event, or to avert our eyes and avoid question or comment lest we offend the dead, injured, their survivors, family, friends, or those who would have been friends had they had a chance to know them. If you have been on this list for very long you have likely lost good friends and friends you hadn't actually met face to face yet. So here's MY request: If I screw up, or am the victim of someone else's screw-up, or if my tail falls off because I forgot to bolt it on properly or if I land long on a short runway or short of a long runway or if I scud run myself into a mountain, or run out of gas crossing Puget Sound, please feel free to postulate, speculate, blame, ridicule or whatever it takes to learn enough from my misfortune, bad judgment or stupidity to prevent some other soul from doing what lead to my demise. If I survive my misadventure I will most likely want to set the record straight or paint myself in a more heroic light, but if I don't, you will be on your own to sort it out. Make the best of it. What do you think the military's accident rate would be like if the S.O.P. after an accident was for everyone to stick their head in the sand and pretend it didn't happen? My apologies in advance if anyone feels flamed by this. I do not want to offend, just convince you that the more we know the safer we are. They put a sheet over dead bodies out of respect of the dead and the sensibilities of the living. That, in my mind, is the appropriate amount of censorship. Terry RV-8A finishing Seattle ________________________________________________________________________________
Date: Aug 07, 2006
> > The Oshkosh Avenger/RV6 incident is not one that I had ever > considered so > I did learn from it. The pictures were not gruesome but were very > informative. I > have not been in a similar taxiing situation but if I ever am I > will make appropriate > actions to NOT be in front of such a plane. I think there is another, more general, lesson that we should take from this accident. It is quite likely that the Avenger pilot knew that taxing on a narrow taxi way with many other aircraft was risky. But he probably justified it with something like: "I've done this before, and it went OK, so it'll be OK this time too", or "Other war bird pilots do it, so it must be safe enough", or "If I stop and shut down until I get a wing walker, it will really mess up the other aircraft." Just because you've done something risky before, and got away with it, doesn't mean you'll get away with it again. Just because other people do it, and get away with it, doesn't mean you'll get away with it. Just because stopping isn't convenient, doesn't mean that continuing is a safe thing to do. Don't cut corners on safety. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Aug 07, 2006
I agree, Mark. The reponsibility must be ours as pilots for the complete operation of our aircraft, including taxiing at an aviation event. Neither the EAA nor the FAA can or should take on that responsibility. Perhaps that should also be made clear in the NOTAM for next year, so there is no question in anyone's mind. No doubt the TBM pilot is profoundly sorry right now as well. I can't imagine dealing with that sort of thing on my conscience. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53096#53096 ________________________________________________________________________________
Date: Aug 07, 2006
Here's how I did mine... http://www.romeolima.com/RV8/Cowl.htm#Heat%20damage Basically just look inside the lower cowl and put the heat shield anywhere the exhaust is closer than about 6". Randy Lervold www.rv-8.com www.rv-3.com ----- Original Message ----- From: Puckett, Gregory [DENTK] To: rv-list(at)matronics.com Sent: Monday, August 07, 2006 8:09 AM Subject: RV-List: lower cowl heat shield picture? g'day all, I'm getting ready to install some of the Van's stick-on heat shield material to my lower cowl and would love to see a picture of where other have placed this stuff and found it successful at preventing burning/blistering. My install is an angle valve I0360-A3B6D with Van's smooth bottom s-type cowl and Vetterman exhaust. Thanks, Greg Puckett RV-8 N881GP (first engine start and taxi yesterday) ________________________________________________________________________________
Date: Aug 07, 2006
From: "Don/Marcia Piermattei" <dlpier(at)lamar.colostate.edu>
Subject: Microfiber cloth and plexiglass
These new microfiber towels are advertised as bing safe for plexiglass. Does anyone have experience with them? Don P RV-9A 192DP ________________________________________________________________________________
Date: Aug 07, 2006
personally I think all these big aircraft should have their own runway and park in their own parking area at OSH from now on, just my opinion. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53105#53105 ________________________________________________________________________________
Date: Aug 07, 2006
Subject: Re: Microfiber cloth and plexiglass
Yes, and they're terrific. No paper towels or tee-shirts, ever! (just like wire hangars!) Be careful to launder them separately from your other stuff, so the scratchy fibers from your jeans don't get stuck in your m'fiber towels. They basically take the dirt and stuff from your plex and pull it deeper into the towel, enabling you to clean the soft plex with a clean cloth surface. Every plexi cleaner professional or aircraft detailer I've spoken to has been strongly emphatic on the need to use microfiber only on plex (water and your non-ringed hand is a good initial cleaner, too). best, Cory Emberson Contributing Editor Kitplanes Magazine Don/Marcia Piermattei wrote: > >These new microfiber towels are advertised as bing safe for plexiglass. Does >anyone have experience with them? >Don P >RV-9A 192DP > > > > > > > > > ________________________________________________________________________________
Date: Aug 07, 2006
Subject: Landin' Gear
The person that wrote the piece about the adjustments on the RV8 landing gear. The 'how to' article, Could you contact me at: cecilth(at)juno.com Sure would appreciate it. Thanks, Cecil ________________________________________________________________________________
Date: Aug 07, 2006
Don, Have used microfiber cloth on plexiglas with no problems but be careful for the sewing on the bound edges. Sometimes the sewing is a rather hard thread and can scratch. Probably a polyester. Also, I use them only once, then wash a load to remove trapped dirt particles. Dale Ensing > These new microfiber towels are advertised as bing safe for plexiglass. Does > anyone have experience with them? > Don P > RV-9A 192DP ________________________________________________________________________________
Date: Aug 07, 2006
I found some allen head bolts today.. some washers and loctight & drilled for safety wire maybe they will work Thanks.. Danny.. ----- Original Message ----- From: "Darrell Reiley" <lifeofreiley2003(at)yahoo.com> Sent: Monday, August 07, 2006 9:21 AM Subject: Re: RV-List: Misl bolts > > Hi Danny, > > Very odd size indeed... you may need to get longer > bolts and cut them off. Easy enough to do. > > Darrell > > --- Sportypilot wrote: > >> I am looking for an 10-24 1/2 bolts with holes on >> the heads for the lycoming 0320 seal retainer so I >> can >> mount my prop and spacer.. anyone have a good >> location to get these, I have looked everywhere >> locally.. >> #10 24threads per inch 1/2 long.. any ideas ? I need >> 4 of them.. >> >> >> Danny.. > > > __________________________________________________ > > > ________________________________________________________________________________
Date: Aug 07, 2006
Good point about the bound edges, Dale. I also clip the tags off the cloths as well. Dale Ensing wrote: > >Don, >Have used microfiber cloth on plexiglas with no problems but be careful for >the sewing on the bound edges. Sometimes the sewing is a rather hard thread >and can scratch. Probably a polyester. Also, I use them only once, then wash >a load to remove trapped dirt particles. > >Dale Ensing > > > >>These new microfiber towels are advertised as bing safe for plexiglass. >> >> >Does > > >>anyone have experience with them? >>Don P >>RV-9A 192DP >> >> > > > > > > > > > ________________________________________________________________________________
Date: Aug 07, 2006
I been using them for the past 3 years with no problems. (I use them on the whole airplane including the plexi.) Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,932 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: "Don/Marcia Piermattei" <dlpier(at)lamar.colostate.edu> Subject: RV-List: Microfiber cloth and plexiglass Date: Mon, 7 Aug 2006 10:54:55 -0600 These new microfiber towels are advertised as bing safe for plexiglass. Does anyone have experience with them? Don P RV-9A 192DP ________________________________________________________________________________
Date: Aug 07, 2006
I'm sorry, but I disagree with some of these sentiments. No, I don't want a shift in overall responsibility. However, Oshkosh has deaths every year, it seems. If there are steps that can be taken to reduce those deaths that aren't terribly onerous, I think it makes sense to take those steps. Ground handling accidents are easy to avoid. Adding a requirement for an extra ground crew to assist any aircraft with over-the-nose visibility issues wouldn't be onerous. The ground control frequency could also warn people to maintain a larger distance when following smaller aircraft. They could erect signs to this effect or simply include it in a briefing to all large tail draggers. Or they could have a 10-minute window every hour for certain types of aircraft to queue up. So all the big aircraft would be clustered together. There are dozens of different steps that could alleviate the likelihood of repeated ground handling accidents. A failure to take any of them is an acknowledgment of spinelessness on the part of the folks shirking the opportunity to increase safety. I don't blame the EAA guys for this accident. The fault rests solely with the pilot of the TBM. If you can't taxi your aircraft without running over some poor guy in front of you, you have no business at the controls of the aircraft. But the EAA could take fairly simple steps to prevent it happening again. I don't know about anyone else, but I'd happily pay a $2 safety fee to help provide for the types of ground crew that might prevent a repeat. I sure as hell don't want to be run over by someone driving his oversized toy up my back side. -Joe On Aug 7, 2006, at 11:50 AM, Dave Johnson wrote: > > I agree, Mark. The reponsibility must be ours as pilots for the > complete operation of our aircraft, including taxiing at an > aviation event. Neither the EAA nor the FAA can or should take on > that responsibility. Perhaps that should also be made clear in the > NOTAM for next year, so there is no question in anyone's mind. > > No doubt the TBM pilot is profoundly sorry right now as well. I > can't imagine dealing with that sort of thing on my conscience. > > Dave > > ________________________________________________________________________________
Date: Aug 07, 2006
>>The Avenger pilot reported that the airplane in front of the Avenger was a green and white, high wing airplane with TUNDRA written on top of the wing. >>The Avenger pilot reported that he observed the Tundra pilot taxi off the right side of the taxiway for some unknown reason. >>The Avenger pilot reported that he spotted the airplane that was in front of the Tundra airplane, and he stated that he had "100 yards of free pavement" in front of the Avenger. >>The Avenger pilot reported that when he heard the impact and saw debris flying, he shut down the engine. He reported that he never saw the airplane that he hit while he was taxiing. >>The RV6 pilot reported that he was taxiing behind a green and white, high wing airplane that had TUNDRA painted on the top of the wing. >>The RV6 pilot reported that a gray airplane was in front of the Tundra aircraft. >>The RV6 pilot reported that he "didn't know the TBM was behind" his airplane. >>The RV6 pilot reported that he was not sure if he was taxiing forward or if he was stopped when the Avenger struck the RV-6 from behind. Based on their respective statements, it looks like neither the TBM-Avenger Pilot, -nor the RV-6 Pilot knew about the presence of each other! How could that be possible, as clearly at least one of the two pilots should have known of the proximity of the other at one point in time while on the same taxiway? I have met the Pilot of the TBM & his wife (who was with him in the backseat). He is well known for repairing-, restoring- & flying all kinds of Warbirds, and has done so for all his adult life. He is a very careful operator of the expensive machines entrusted into his care. He is not a risktaker. Needless to say, he and his wife are just devastated about this freak accident that cost someone his life. My heartfelt condolences go out to the accident victim and his family. This accident should not have happened. I was not present in either one cockpit-, nor did I see the actual accident happen. Everything else is just speculation based on incomplete information given ... ----- Original Message ----- From: Kevin Horton I think there is another, more general, lesson that we should take from this accident. It is quite likely that the Avenger pilot knew that taxing on a narrow taxi way with many other aircraft was risky. But he probably justified it with something like: "I've done this before, and it went OK, so it'll be OK this time too", or "Other war bird pilots do it, so it must be safe enough", or "If I stop and shut down until I get a wing walker, it will really mess up the other aircraft." Just because you've done something risky before, and got away with it, doesn't mean you'll get away with it again. Just because other people do it, and get away with it, doesn't mean you'll get away with it. Just because stopping isn't convenient, doesn't mean that continuing is a safe thing to do. Don't cut corners on safety. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Aug 07, 2006
----- Original Message ----- From: "Dale Ensing" <densing(at)carolina.rr.com> Sent: Monday, August 07, 2006 12:20 PM Subject: Re: RV-List: Microfiber cloth and plexiglass > > Don, > Have used microfiber cloth on plexiglas with no problems but be careful > for > the sewing on the bound edges. Sometimes the sewing is a rather hard > thread > and can scratch. Probably a polyester. Also, I use them only once, then > wash > a load to remove trapped dirt particles. > > Dale Ensing > >> These new microfiber towels are advertised as bing safe for plexiglass. > Does >> anyone have experience with them? >> Don P >> RV-9A 192DP > > > ________________________________________________________________________________
Date: Aug 07, 2006
Hi Dale ... What's a good source for microfiber cloth? Thanks ... Jerry Grimmonpre' > > Don, > Have used microfiber cloth on plexiglas with no problems but be careful > for > the sewing on the bound edges. Sometimes the sewing is a rather hard > thread > and can scratch. Probably a polyester. Also, I use them only once, then > wash > a load to remove trapped dirt particles. > > Dale Ensing ________________________________________________________________________________
Date: Aug 07, 2006
Ron, You say we don't ever learn or can't be taught to avoid stupid accidents. That's not true. Just yesterday I almost read about 4 accidents that didn't happen because the pilots were awares from lessons learned from others less fortunate. We can check the NTSB to see read about the stupid-pilot-tricks that are still being pulled. What we don't get to read about are the tens, hundreds or even thousands of accidents that don't happen because of training, education, lessons-learned and peer pressure to do better. Chuck > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee > Sent: Monday, August 07, 2006 11:04 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Re: Accident photos > > > > > >I'm with Jerry on this one. We have censored each other to the point > >that we can't talk about and learn anything from the loss of > those who > >share our interest in flying little airplanes. We can't talk about > >Scott Crossfield's accident because that might not show the > respect he > >deserves. We shouldn't look at pictures of a beautiful RV-6 > chopped up > >by a prop because it might offend someone's sensibilities? > > I had never heard of Crossfield but my initial thought was > that he screwed up royally. That opinion has only been > reinforced by obtaining additional info about the pilot error > leading to death event. I learned nothing from that > pilot > error event since I already know that flying into severe > thunderstorms is stupid. > > The Oshkosh Avenger/RV6 incident is not one that I had ever > considered so I did learn from it. The pictures were not > gruesome but were very > informative. I > have not been in a similar taxiing situation but if I ever am > I will make > appropriate > actions to NOT be in front of such a plane. > > I often hear after aviation fatalities that we can all learn from > it. Personally in recent > years I don't recall any that I learned from except for this taxiing > death. There may > have been others that I don't recall. Fact is that pilots > have always done > stupid > things that result in fatalities. I suspect that they always > will and I > see no way to > dramatically reduce those pilot error fatalities. > > It would be great if the RV community could do something to > reduce fatal > pilot errors. > Perhaps some sort of web-based training that discusses the > major causes of > deaths > from pilot errors. If that training resulted in a reduction > in insurance > rates I would do > it every year. Ideally it would mean fewer RV pilot deaths. > > And it would include photos. > > Ron Lee > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 07, 2006
>.. >What's a good source for microfiber cloth? >Thanks ... >Jerry Grimmonpre' Walmart auto section. Ron Lee ________________________________________________________________________________
Date: Aug 07, 2006
In a message dated 8/7/06 12:53:31 PM Eastern Daylight Time, rv(at)discursion.com writes: > Neither the EAA nor the FAA can or should take on that responsibility. =========================== Dave: Playing lawyer ... Check you local listings for the 2PM slot. The EAA automatically takes on responsibility by sponsoring the event and even more responsibility by providing Ground Crew. Either way they are responsible and what is the definition of Class D Tower operations? Control of aircraft departing and arriving while on the ground and advisories when in the air within the air space. It is akin to parking your car via a Valet or checking your coat. If the service is provided the risk is assumed. ASSUMED not as in making an ass out of you and me ... But, as in taking on the responsibility! YET, by FAA definition the accident would not have happened IF the pilot did not get in the plane. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 07, 2006
Chuck, you either misunderstood me or I was not clear in my message. I said (I think) that I rarely learn from these accidents because they are things that I already know (previously learned). The Avenger/RV6 death was a new one for me and was a learning experience. I don't have statistics on accidents but I would guess that running out of fuel and flying into bad weather are major causal factors. If people really learned then those should soon be minor causal factors. Yet year after year they still cause problems. Why is that? My guess is that there will always be pilots who are destined to die or have a non-fatal accident for things that are preventable. It is human nature. I would hope that you do not need to hear every few months about a person dying because he flew into a thunderstorm to know that you should not. So my view is that saying that we can all learn from such an event is as useful as saying that at least the pilot died doing something he loved. Your assertion about 10s,100s or 1000s of people not having accidents because of something they learned (NTSB report?) frankly is not verifiable. I would believe that the pilot community as a whole DID LEARN if some sort of educational process were implemented and within a year or so you saw dramatic reduction in a given accident cause (such as flying into weather). My final comment about RV community training was aimed at that so if you or anyone else has ideas on how RV pilots could truly learn and drastically reduce current accident causal factors then we should try it. I am more than eager to learn of ways to reduce my genetic disposition to doing stupid things. Until then, I will just continue my normal conservative flying. Ron Lee At 01:23 PM 8/7/2006, you wrote: > >Ron, > >You say we don't ever learn or can't be taught to avoid stupid >accidents. That's not true. Just yesterday I almost read about 4 >accidents that didn't happen because the pilots were awares from lessons >learned from others less fortunate. We can check the NTSB to see read >about the stupid-pilot-tricks that are still being pulled. What we >don't get to read about are the tens, hundreds or even thousands of >accidents that don't happen because of training, education, >lessons-learned and peer pressure to do better. > >Chuck > > > -----Original Message----- > > From: owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee > > Sent: Monday, August 07, 2006 11:04 AM > > To: rv-list(at)matronics.com > > Subject: RE: RV-List: Re: Accident photos > > > > > > > > > > >I'm with Jerry on this one. We have censored each other to the point > > >that we can't talk about and learn anything from the loss of > > those who > > >share our interest in flying little airplanes. We can't talk about > > >Scott Crossfield's accident because that might not show the > > respect he > > >deserves. We shouldn't look at pictures of a beautiful RV-6 > > chopped up > > >by a prop because it might offend someone's sensibilities? > > > > I had never heard of Crossfield but my initial thought was > > that he screwed up royally. That opinion has only been > > reinforced by obtaining additional info about the pilot error > > leading to death event. I learned nothing from that > > pilot > > error event since I already know that flying into severe > > thunderstorms is stupid. > > > > The Oshkosh Avenger/RV6 incident is not one that I had ever > > considered so I did learn from it. The pictures were not > > gruesome but were very > > informative. I > > have not been in a similar taxiing situation but if I ever am > > I will make > > appropriate > > actions to NOT be in front of such a plane. > > > > I often hear after aviation fatalities that we can all learn from > > it. Personally in recent > > years I don't recall any that I learned from except for this taxiing > > death. There may > > have been others that I don't recall. Fact is that pilots > > have always done > > stupid > > things that result in fatalities. I suspect that they always > > will and I > > see no way to > > dramatically reduce those pilot error fatalities. > > > > It would be great if the RV community could do something to > > reduce fatal > > pilot errors. > > Perhaps some sort of web-based training that discusses the > > major causes of > > deaths > > from pilot errors. If that training resulted in a reduction > > in insurance > > rates I would do > > it every year. Ideally it would mean fewer RV pilot deaths. > > > > And it would include photos. > > > > Ron Lee > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 07, 2006
If you have the option to buy the microfiber that looks closer in texture to chamois rather than a loosely woven cloth, chose the tighter knit chamois weave. I got that tip from one of the Oshkosh seminars last week on Plexiglas. Larry in Indiana ----- Original Message ----- From: "Ron Lee" <ronlee(at)pcisys.net> Sent: Monday, August 07, 2006 2:35 PM Subject: Re: RV-List: Microfiber cloth and plexiglass > > >>.. >>What's a good source for microfiber cloth? >>Thanks ... >>Jerry Grimmonpre' > > Walmart auto section. > > Ron Lee > > > http://www.matronics.com/Navigator?RV-List > http://wiki.matronics.com > > > ________________________________________________________________________________
Date: Aug 07, 2006
Hello Jerry, Here is a website for microfiber cloths from Griots Garage. But, as someone else indicated, you can also purchase at auto parts stores/departments. Not all are created equal. As I indicated, check the bound edges for finish. Microfiber dish cloths can also be puchased from kitchen deparments. They are usually smaller but I like the size for a single time use of cleaning the w/screen. Then wash them and use again. http://www.griotsgarage.com/catalog.jsp?L1=L1_1000&L2=L2_1001&SKU=11096 Are you enjoying the RV-4? How is the 8 coming along? Dale > Hi Dale ... > What's a good source for microfiber cloth? > Thanks ... > Jerry Grimmonpre' > > > > > Don, > > Have used microfiber cloth on plexiglas with no problems but be careful > > for > > the sewing on the bound edges. Sometimes the sewing is a rather hard > > thread > > and can scratch. Probably a polyester. Also, I use them only once, then > > wash > > a load to remove trapped dirt particles. > > > > Dale Ensing > > ________________________________________________________________________________
Date: Aug 07, 2006
Subject: Reno tickets for sale
I have Reno air race tickets for sale for two people for the 15th 16th and 17th. Reversed seat uppper seats in G and pit passes. Face value $348. Unexpected prop overhaul blew my budget. Sherman Butler RV-7a Wings Idaho Falls --------------------------------- See the all-new, redesigned Yahoo.com. Check it out. ________________________________________________________________________________
Date: Aug 07, 2006
Subject: Re: Leaning on ground?
In a message dated 8/6/06 9:19:38 AM Eastern Daylight Time, marknlisa(at)hometel.com writes: > A final note, do a 20 second run-up (at least 1800 RPM) prior to every > engine shut down. This will activate the anti-leading agent in the fuel > further reducing lead deposits. I run up to 1800 RPM, time for 20 seconds, > quickly back to 1200 RPM, then immediately pull the mixture to kill the > engine. If you don't touch the throttle, the next time you start the engine > it will already be at 1200 RPM - ready for setting the mixture to ground > lean. > > Mark Sletten > Legacy FG N828LM > http://www.legacyfgbuilder.com =================================== Mark: I have seen this lean at shut down procedure written up by Lycoming. I have great reservations about this procedure. 1 - Consider you just did an hour flight or maybe even a half hour flight. Weren't you leaning during that flight? So why should you have to do it again? 2 - You just did this this leaning procedure before you took off to remove the lead deposits. I would then ask two questions here: a> Why not just do this procedure BEFORE you take off. Why would you have to do it AGAIN after you land? Or; b> If you did it after you land why would you have to do it again BEFORE you take off? Confusing ain't it? 3 - You just did your flight, at least durring the flight even with leaning you had a large volume of air moving through your cowling, helping things to cool off. So, why would you sit on the ground heat the engine, then shut down just to saturate the engine and the area under the cowl with heat? Sounds like Lycoming has an ulterior motive for doing this procedure. 4 - What does heat saturation do? Well, it dries out hoses, wires, ty-wraps, anti-chafe material ... add to the list as you see fit. But, here is one area I noticed heat failure ... The plastic coupling on the Vacuum Pump. Mine failed after 1935 Hours. Close inspection under magnification revealed heat cracks. I also opened up the pump only to find PERFECTLY GOOD insides. Probably would have gone for an additional 1935 Hours. Guess where I'm putting a small blast tube? First guess doesn't count. So, personally, I do not see any advantage in this procedure. YMMV, yet there just seems to be holes in the procedure. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 07, 2006
On 7 Aug 2006, at 21:51, Jeff Point wrote: > > -----Original Message----- > >> From: Kevin Horton <khorton01(at)rogers.com> >> I'm not familiar with the taxi way widths of the various taxi routes >> at OSH. The crux of the problem appears to be that some taxi ways >> are too narrow to allow large tail draggers to S turn. Given that >> most of the large tail draggers are in one area, is there any hope of >> giving them taxi routes during peak traffic periods that keep them on >> wider taxi ways, maybe at the expense of funneling them all to 09/27? > > True, most warbirds park in one area, but they move back and forth > around the airport, landing and departing from one of six different > runways. And, how do you define peak traffic periods? This > accident could have occured whether there were 10 airplanes in the > que, or 100. Traffic levels ebb and flow throughout the day. If > we are to have a policy of escorting warbirds back and forth, then > it has to be an all or nothing idea. And, of course, do you stop > at warbirds? How about Cessna 195s? Stearmans? Harmon Rockets? > Where do you draw the line? These are the things we are trying to > work out. The way I see it, any tail dragger should be able to taxi safely, if there is enough room to S-turn. The problem comes when you put large tail draggers on narrow taxi ways. So the C195s, Stearmans, Rockets, etc should be able to taxi safely, and it is the pilot's responsibility to do just that. Obviously, the large tail dragger pilot also has full responsibility to taxi safely, but the "system" should make every effort to put him in a situation where that is possible. If the taxi way is too narrow to allow S-turns, then the only way a large tail dragger can taxi safely is with some outside assistance. The Avenger pilot was put in a very difficult situation. Once he was marshalled onto a narrow taxi way with no wing walkers, he had two choices: press on and hope for the best, or shut down and become a road block. He gambled with option 1, and he lost. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: doors off?
Date: Aug 07, 2006
I do know that if you open both doors at the same time on a 150 with the flaps down you go down a whole lot faster than normal. You can fall out of the sky almost straight down, no forward air speed flat as a pancake. I know. Bob Perkinson Hendersonville, TN. RV9 N658RP Reserved If nothing changes Nothing changes Thanks for the advise guys, I knew I could count on you for the facts. I am just looking to get the windy ultralight experience without spending a bunch of cash on a new toy. I figured I could try doors off a couple of times and get it out of my system....then get back to the real challenge of building an RV 10. Cheers.. Evan Johnson ________________________________________________________________________________
Date: Aug 07, 2006
Subject: Re: SL-30 and GTX-327 mounting trays
Charlie: You are correct. I'm surprised, but that looks like it will work. I also checked the SL-30 tray and found that it has about 1/16" of space for the screw head, not 1/32". Stark Avionics informs me that they use 6-32 countersunk screws on the SL-30 mounting tray. The heads stick up, since the you can't countersink the tray, but once again, they don't stick up enough to interfere with the radio sliding in and out. Not pretty, but they say it works well. (Why doesn't Garmin supply the right screws?) I called Garmin and they couldn't tell me what screw to use. Thanks, chaztuna(at)adelphia.net wrote: > > >Tom, > I can't address the problem with the SL-30. However, my GTX 320A uses the exact same tray as your GTX 327. I used AN509-10 flush screws to mount my GTX 320A, Icom A200 and RMI uMonitor. You are correct that the dimple in the tray of the Garmin transponder does not allow the head of the screw to fit flush. However, there is room to install the radio with the screw head protruding. The protruding screw head actually acts as an internal shim, to steady the radio in the tray. > The Garmin tray was wider (thicker material) than my other 2 trays. I simply made shims to compensate on the Icom and the uMonitor. I am very pleased with the fit and cosmetics of my installation. > I suspect that you will find your SL-30 fits between the installed screw heads. If it doesn't, you could always dimple the tray mounting holes. >Charlie Kuss > > > > ________________________________________________________________________________
Date: Aug 08, 2006
In a message dated 8/7/06 11:11:12 PM Eastern Daylight Time, pitts_pilot(at)bellsouth.net writes: > Hi Barry! The Lycoming 'leaning/lead removing process' is done just > before takeoff and just before shutdown because it supposes that you > were taxiing around with the engine just above idle power. Low power > operations do not get the cylinder temps up so the natural lead > scavenging process can occur. Of course, if you leaned on the ground > that violates Lycomings "8500' 75% power" rule so they can't support > that. Mark could lessen the low power lead fouling problem by > aggressive leaning on the ground or switch to an unleaded fuel. > Linn ==================================== Hi Linn: As you said, Lycoming can't support that. And I'd bet dollars to doughnuts that there is no data on how long at low RPM it takes to develop lead. Morristown AP (KMMU) here in NJ has a LONG taxi to and from the runway, over a mile each way and many times you are waiting for a Jet to get its IFR clearance. Now, during the taxi it would be recommended to lean aggressively. After all you are only about 1000 to 1300 RPM not really at the 75% power point :-) Better to do the lead scavenging procedure prior to takeoff than at shutdown (see previous post for reasoning). There are just too many holes in Lycoming's procedure, it does not make sense. But, then again, what does Lie-Comming do that ever does make mechanical sense? Ya gots to ask the lawyers! YES! By all means, use unleaded fuel. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 08, 2006
Subject: Re: oshkosh accident
This list certainly tosses enough ideas around for the lawyers seize. I like Gordon Comforts ideas. In addition to looking over my shoulder etc I wouldn't mind taxiing along with a flag on the top of a long pole. My kids already think I am goofy so I don't mind being uncool. Surely there is enough collective creativity here to design something telescopic that would mount to the back side of the seat or neatly fits into the baggage compartment. It could be named after our fallen brother. Just one idea. RE JT Helms wrote: > >Although I generally agree that the PIC of the Avenger was at fault, I'd bet >my last dollar that EAA gets sued as part of that loss, though. It's their >party after all, but the main reason is that they likely have more $ and >insurance coverage available than the Avenger pilot (who will certainly also >be named in any lawsuit). > >JT > > > ________________________________________________________________________________
Subject: Flap actuator to rod end - locking
Date: Aug 08, 2006
I have converted my manual flap kit to electric. What are the best options to lock the rod end bearing to prevent it spinning out of the actuator when the jam nut works loose. Doug Gray RV-6 finishing kit ________________________________________________________________________________
Subject: RE: Oshkosh accident - Caution, on my Soapbox
Date: Aug 08, 2006
Hi Jeff- Thanks for your thoughtful and measured input. Personally, I like the suggestion that warbird operations be responsible for warbird operations. It seems to me that would be appropriate from both an experiential and resource basis. My other observation regards the comment "However, it was a freak accident..." Perhaps this was a first for OSH, but it's not really an isolated event. I can't recall the exact date, but within the last couple of years here locally we had a couple of RV's taxiing to the fuel pumps when one stopped and the other didn't. Fortunately, their relative sizes precluded the kind of tragedy that occurred at the convention. If you and your crew can come up with a plan to facilitate our success as aviators, as well as help preserve our convention, then thank you very much. However, it still falls to us as PIC's to protect ourselves and each other. Please, people, be aware of your surroundings. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
From: =?iso-8859-1?Q?Mich=E8le_Delsol?= <michele.delsol(at)microsigma.fr>
Date: Aug 08, 2006
Here is another tragedy which I relate to emphasize the need to be very attentive as to what we do when flying. I personally know all the protagonists, including the dead pilot, but not the controller at the control tower. This happened this spring at my airport in France. Cri-Cri (for those who are unfamiliar with this airplane - Cri-Cri is the worlds smallest twin - empty weigh 190 lbs. - two one cylinder engines) was on runway threshold - Cessna 150 was on short final. Airport is controlled - this is all within two hundred yards of the control tower - grass runway which passes 50 yards in front of the control tower. For some reason which has not been determined, Cri-cri takes off, Cessna aborts landing, presumably (nothing certain here as accident is still under investigation) Cri-Cri got clearance to take off and Cessna was instructed to go around. To make a long story short, Cri-Cri flew up into the Cessna's propeller - Cessna chewed up the T-tail rudder and horizontal stabilizer of the Cri-Cri. The collision occurred at approximately 150 ft above the ground. Without an empennage, the Cri-cri tumbled forward head over heels and hit the ground flat on its back on the runway from which it was taking off - the pilot was killed instantly on impact. The crew of two in the Cessna safely managed to make it back the other runway. I relate this to emphasize that the PIC should not take anything for granted. This concerns both the Cessna's and the Cri-Cri's PICs. At the airport, no one is debating as to who is at fault - it is a tragic loss for us and sobering as to the inherent risk of flying. One should be on guard at all times and not take anything for granted. This accident, as the one at Oshkosh, should never have happened. Please do not ask questions on this accident - I just wanted to relate it so that it should help us be more careful as we fly. Michele RV8 - Fuselage -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee Sent: lundi 7 aot 2006 17:04 Subject: RE: RV-List: Re: Accident photos >I'm with Jerry on this one. We have censored each other to the point that we >can't talk about and learn anything from the loss of those who share our >interest in flying little airplanes. We can't talk about Scott Crossfield's >accident because that might not show the respect he deserves. We shouldn't >look at pictures of a beautiful RV-6 chopped up by a prop because it might >offend someone's sensibilities? I had never heard of Crossfield but my initial thought was that he screwed up royally. That opinion has only been reinforced by obtaining additional info about the pilot error leading to death event. I learned nothing from that pilot error event since I already know that flying into severe thunderstorms is stupid. The Oshkosh Avenger/RV6 incident is not one that I had ever considered so I did learn from it. The pictures were not gruesome but were very informative. I have not been in a similar taxiing situation but if I ever am I will make appropriate actions to NOT be in front of such a plane. I often hear after aviation fatalities that we can all learn from it. Personally in recent years I don't recall any that I learned from except for this taxiing death. There may have been others that I don't recall. Fact is that pilots have always done stupid things that result in fatalities. I suspect that they always will and I see no way to dramatically reduce those pilot error fatalities. It would be great if the RV community could do something to reduce fatal pilot errors. Perhaps some sort of web-based training that discusses the major causes of deaths from pilot errors. If that training resulted in a reduction in insurance rates I would do it every year. Ideally it would mean fewer RV pilot deaths. And it would include photos. Ron Lee ________________________________________________________________________________
Subject: GPS & Autopilot Setup
Date: Aug 08, 2006
I am using a ControlVision GPS (HP ipaq 4700) connected to my Trio EZ Pilot Autopilot and it is not working properly. Is anyone else using this same setup? I'm trying to resolve the problem and I'm wondering if it's working for someone else. Albert Gardner Yuma, AZ ________________________________________________________________________________
Subject: Re: microfiber cloth?
Date: Aug 08, 2006
Bert, Go here for explanation of microfiber cloth and the type you should use. http://www.autogeek.net/leabmi.html Dale Ensing > I have been reading, the postings about micro fiber cloth, to clean > windshield.. > Can some one explain what is a micro fiber cloth, and where can I buy them? > I have use a regular small wash cloth, from Walt-mart...also the red type > you buy at auto store... > Am I using wrong kind...? > > Bert ________________________________________________________________________________
Date: Aug 08, 2006
Van's suggest you drill a small hole at the lip of the actuator tube and safety wire the tube so that it can't spin relative to the rod end bearing. It's a little hard to get a hole there but a small drill started perpendicular to the tube and then angled seems to work. Albert Gardner Yuma, AZ -----Original Message----- Sent: Tuesday, August 08, 2006 4:30 AM Subject: RV-List: Flap actuator to rod end - locking I have converted my manual flap kit to electric. What are the best options to lock the rod end bearing to prevent it spinning out of the actuator when the jam nut works loose. Doug Gray RV-6 finishing kit ________________________________________________________________________________
Date: Aug 08, 2006
> > In addition to looking over my shoulder etc I wouldn't mind taxiing > along > with a flag on the top of a long pole. My kids already think I am > goofy so I > don't mind being uncool. Surely there is enough collective > creativity here > to design something telescopic that would mount to the back side of > the seat > or neatly fits into the baggage compartment. It could be named > after our > fallen brother. I don't think we need to carry around flagpoles for our airplanes. But I wonder if a very very small change would make us more visible. What if the policy was for small aircraft to sort of hug the left side of the taxiway instead of doing what we all do -- plant the front wheel on the centerline and be proud of our ability to taxi precisely. If the small aircraft hugged the left side, and the big aircraft did what they could do S-turn or hug right, everyone should be able to see everyone. But I've never been in an aircraft where the pilot couldn't see an RV parked in front of it, so I'm not sure if this would be sufficient for the situation. -Joe ________________________________________________________________________________
Date: Aug 08, 2006
On 4:07:20 2006-08-08 Roger Embree wrote: > Surely there is enough > collective creativity here to design something telescopic that would > mount to the back side of the seat or neatly fits into the baggage > compartment. It could be named after our fallen brother. > Just one idea. That's a great idea, but i'll add one feature to the device you describe... It shouldn't stick straight up. In order to be seen over the nose of a TBM, it would need to be nearly 20' high. I suggest that it be angled to one side, so the "flag" appears about ten feet above the left wing. That puts it on the pilot's side of most aircraft, and possibly far enough "off-axis" that the rear plane would be able to see it. Of course, S-turning would help too. -Rob ________________________________________________________________________________
Date: Aug 08, 2006
Subject: Re: GPS & Autopilot Setup
Albert Gardner wrote: > I am using a ControlVision GPS (HP ipaq 4700) connected to my Trio EZ > Pilot Autopilot and it is not working properly. Is anyone else using > this same setup? Im trying to resolve the problem and Im wondering if > its working for someone else. > > Albert Gardner > Albert, the versions of AWM that I tried with the Trio did not provide the standard NMEA protocol that the EZ-Pilot requires. I understand there was considerable effort on the part of Trio to convince Control Vision to standardize the NMEA output of AWM but it seems that may not have happened. Sam Buchanan http://thervjournal.com ________________________________________________________________________________
Subject: First Flight of N23BB
Date: Aug 08, 2006
Hi All, After eleven years of fun N23BB flew for the first time this morning, 4 days after my 76th birthday. Using N9X flight test program. Thanks to my wife of 49 years Anita Bell for her help and understanding. Stan Blanton was always ready to drop everything and come over to help. Stan also planned a very smooth move to the airport. Rick Liles EAA Chapter 19 Tech thanks for all the tech help and move to the airport. Engine ran fine and no leaks on postflight inspection. Able to walk away after the landing and 23BB can fly again without any major repair! Thanks to Ann and Russ Daves for their friendly first flight support. Regards , Bruce Bell Lubbock, Texas ________________________________________________________________________________
Date: Aug 08, 2006
They show how to drill and safety wire the lock nut in the drawings. I did not do it and mine came loose so I would sure recommend doing it. I did not pay attention to how it worked but when the motor runs it puts a small amount of torque on the shaft that can eventually cause the nut to loosen up. It took mine 225 hours to come loose. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Doug Gray Sent: Tuesday, August 08, 2006 6:30 AM Subject: RV-List: Flap actuator to rod end - locking I have converted my manual flap kit to electric. What are the best options to lock the rod end bearing to prevent it spinning out of the actuator when the jam nut works loose. Doug Gray RV-6 finishing kit ________________________________________________________________________________
Date: Aug 08, 2006
>I don't think we need to carry around flagpoles for our airplanes. I sure will not. I understand how people may want to relive the Rat Patrol concept but it makes more sense for the big warbirds to install a forward facing video system. Ron Lee ________________________________________________________________________________
Date: Aug 08, 2006
Tom, This is something to consider. You want to keep the radio's side to side "slop" movement in the tray to a minimum. Excessive movement can damage the radio internals and does nothing good for the connector pins. Use of screws below size #8 is problematic, as they tend to break off easily if installed in nutplates. Best to use the largest diameter screws which space will allow for your SL-30. The larger diameter screw heads will act to reduce excess slop space. Is the SL-30 tray made of aluminum or steel? If steel, is it heavy gauge steel, like the GTX 327 tray? My 8A radio rack is a variation of Mark Richardson's excellent design. I can email photos off list if you like. Charlie > >Charlie: > You are correct. I'm surprised, but that looks like it will > work. I also checked the SL-30 tray and found that it has about > 1/16" of space for the screw head, not 1/32". Stark Avionics > informs me that they use 6-32 countersunk screws on the SL-30 > mounting tray. The heads stick up, since the you can't countersink > the tray, but once again, they don't stick up enough to interfere > with the radio sliding in and out. Not pretty, but they say it > works well. (Why doesn't Garmin supply the right screws?) I called > Garmin and they couldn't tell me what screw to use. >Thanks, > >chaztuna(at)adelphia.net wrote: > >> >> >>Tom, >>I can't address the problem with the SL-30. However, my GTX 320A >>uses the exact same tray as your GTX 327. I used AN509-10 flush >>screws to mount my GTX 320A, Icom A200 and RMI uMonitor. You are >>correct that the dimple in the tray of the Garmin transponder does >>not allow the head of the screw to fit flush. However, there is >>room to install the radio with the screw head protruding. The >>protruding screw head actually acts as an internal shim, to steady >>the radio in the tray. >>The Garmin tray was wider (thicker material) than my other 2 trays. >>I simply made shims to compensate on the Icom and the uMonitor. I >>am very pleased with the fit and cosmetics of my installation. >>I suspect that you will find your SL-30 fits between the installed >>screw heads. If it doesn't, you could always dimple the tray mounting holes. >>Charlie Kuss >> >> >> >> > > ________________________________________________________________________________
Date: Aug 08, 2006
Subject: Re: Oshkosh accident - Caution, on my Soapboxt
>snipped >Obviously, the large tail dragger pilot also has full responsibility >to taxi safely, but the "system" should make every effort to put him >in a situation where that is possible. If the taxi way is too narrow >to allow S-turns, then the only way a large tail dragger can taxi >safely is with some outside assistance. The Avenger pilot was put in >a very difficult situation. Once he was marshalled onto a narrow >taxi way with no wing walkers, he had two choices: press on and hope >for the best, or shut down and become a road block. He gambled with >option 1, and he lost. > >Kevin Horton RV-8 (finishing kit) >Ottawa, Canada >http://www.kilohotel.com/rv8 Kevin, He could have asked his wife to get out and act as a spotter. He had a choice. Just playing devils advocate Charlie Kuss ________________________________________________________________________________
Date: Aug 08, 2006
Wow! 76 and flying and a loving wife ta boot! How lucky can you be! Congratulations on the flight and your persistence and your family. Hope to see some pictures one day. Enjoy! John Jessen RV-10 Tailcone -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bruce Bell Sent: Tuesday, August 08, 2006 8:50 AM Subject: RV-List: First Flight of N23BB Hi All, After eleven years of fun N23BB flew for the first time this morning, 4 days after my 76th birthday. Using N9X flight test program. Thanks to my wife of 49 years Anita Bell for her help and understanding. Stan Blanton was always ready to drop everything and come over to help. Stan also planned a very smooth move to the airport. Rick Liles EAA Chapter 19 Tech thanks for all the tech help and move to the airport. Engine ran fine and no leaks on postflight inspection. Able to walk away after the landing and 23BB can fly again without any major repair! Thanks to Ann and Russ Daves for their friendly first flight support. Regards , Bruce Bell Lubbock, Texas ________________________________________________________________________________
Date: Aug 08, 2006
Just because the controllers at the airfield tell you to do something doesn't mean you have to do it. In my one trip to Oshkosh, I was told that I'd be directed to a run up area. Instead, the ground controllers basically "pushed" me onto the runway with no run up. I didn't know what else to do, so I just ran off the other side of the runway and told the tower I'd like a run up before takeoff. Optimal? Certainly not. And to this day, I don't know what I was supposed to do. I don't think doing a run up in the parking area is the right choice. Maybe I was supposed to do it during the taxi. But I really expected a chance to pull over and do a proper run up. It wasn't until they gestured me onto the runway that I realized I was about to take off on an IFR flight plan without finishing my pre- takeoff checklist. But my point -- you CAN interrupt procedures if you don't think they're safe, regardless of how annoying doing so might be to the controllers. And difficulty in seeing the guy in front of you definitely counts. -J On Aug 8, 2006, at 11:08 AM, Charlie Kuss wrote: >> snipped >> Obviously, the large tail dragger pilot also has full responsibility >> to taxi safely, but the "system" should make every effort to put him >> in a situation where that is possible. If the taxi way is too narrow >> to allow S-turns, then the only way a large tail dragger can taxi >> safely is with some outside assistance. The Avenger pilot was put in >> a very difficult situation. Once he was marshalled onto a narrow >> taxi way with no wing walkers, he had two choices: press on and hope >> for the best, or shut down and become a road block. He gambled with >> option 1, and he lost. >> >> Kevin Horton RV-8 (finishing kit) >> Ottawa, Canada >> http://www.kilohotel.com/rv8 > > Kevin, > He could have asked his wife to get out and act as a spotter. He > had a choice. > Just playing devils advocate > Charlie Kuss ________________________________________________________________________________
Date: Aug 08, 2006
Subject: Re: Flap actuator to rod end - locking
I spun a nylock nut on backwards, and torqued it against the rod end as a stop nut. Hasn't budged a bit, but I check it every annual. Jeff Point RV-6 Milwaukee > > ________________________________________________________________________________
Date: Aug 08, 2006
Sam Buchanan wrote: > > Albert Gardner wrote: >> I am using a ControlVision GPS (HP ipaq 4700) connected to my Trio EZ >> Pilot Autopilot and it is not working properly. Is anyone else using >> this same setup? Im trying to resolve the problem and Im wondering >> if its working for someone else. >> >> Albert Gardner >> > > > Albert, the versions of AWM that I tried with the Trio did not provide > the standard NMEA protocol that the EZ-Pilot requires. I understand > there was considerable effort on the part of Trio to convince Control > Vision to standardize the NMEA output of AWM but it seems that may not > have happened. > > Sam Buchanan > http://thervjournal.com I just received word from Trio (they monitor this list!) that apparently the latest version of Anywhere Map does indeed send out a standardized NMEA data stream. Sam Buchanan ________________________________________________________________________________
Subject: TBM Accident
Date: Aug 08, 2006
Well, I would personally like to thank Jeff for his comments. As one who works under Mike, aka Susie Q, this accident was one of those rare things that was just that, an accident. Go ahead write a boat load of rules and changes and policies and you will still have a few accidents. Which by the way this year was the first time in a few that we've had fatalities on field, which I think is a good record given what we do. I hate to be callous but get over it, the war birds are here to stay and we want them. They cause the public gate to at least triple from what it would be were they not here. That income is needed for this event to happen. Make bigger taxi ways, it won't do squat. In a 1000' it's entirely possible (as in I've seen it many times) for both planes to be in wiggle phase and not be able to see each other if they are close. And who is going to make bigger taxiways at every airport the TBM lands at? Go ahead put wing walkers out there, that way the TBM will have more targets to run over and kill. RE control towers, guess what the only legal obligation of a control tower for vfr traffic is to provide sequencing. Get over it, that's been tested in court many times. They are not obligated nor able to provide separation services in any vfr environment, particualrly on the gorund at Oshkosh. And the TBM is taking a risk when it taxi's but that risk is no different then the same risk you take when you taxi. I've seen little kids run out in front of various aircraft, fortunately none I've seen were hurt. But by some of this logic put forth we should outlaw kids and any airplane that might run them over. Yes we have rules to help reduce those risks, but that said all they do is reduce the risk, they never prevent entirely. The two airplanes did not, and apparently could not see each other, that is the cause of most aircraft collisions and to date no rule has ever fixed that. I'm pretty certain no new rules will help things any. If you are little and worried get a rearview mirror. Or better yet give up flying, stop driving, avoid earthquake and volcano country and don't eat at McDonald's any more. The bottom line is that our emotional response to tragic events in aviation is to cast a cause out there in the hopes of future prevention. This is one of those cases where the accident chain wasn't broken and so it occured. But any of the proposed fixes just make room for alternative chains without really reducing the overall risk much. You want to talk about safety, let's talk about the fact that an hour before this happended the controllers were launching aircraft into 35 kt tailwind takeoffs with rain in an effort to oblige the many who wanted to depart pre-hurricane. They finally got it and closed the airport. But that closure put even more pressure on the limited time slot for departures pre-airshow after the WX system passed. So guess what, it's partly God's fault, therefore I would suggest we write a rule forbidding God from having short term hurricanes at Oshkosh. And while we're at it the simplest fix would be to not allow RV's to come to Oshkosh as that will eliminate about 2/3 of the overall traffic which will greatly reduce the number of accidents. In fact there's some good data to support this fix as RV's (and Bonanzas) tend to be involved in many of the incidents that happen at Oshkosh. So, yes I feel horrible about this, as I do about the Europa, and the Cub, and the few others who perished coming to or from Oshkosh. And I feel bad about those who perished just flying that week as I do about the estimated 98000 people who die each year from boo boos that happen in US hospitals. That's almost twice the number of people who die in auto accidents and I'll bet most of you didn't even know that statistic. Get a life, be happy that you are alive, go fly your airplane and celebrate those who can longer join us for that ride. W ________________________________________________________________________________
Date: Aug 08, 2006
Bruce, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A >From: "Bruce Bell" <brucebell74(at)sbcglobal.net> >Reply-To: rv-list(at)matronics.com >To: "RV List" >Subject: RV-List: First Flight of N23BB >Date: Tue, 8 Aug 2006 10:50:22 -0500 > > >Hi All, >After eleven years of fun N23BB flew for the first time this morning, 4 >days after my 76th birthday. Using N9X flight test program. Thanks to my >wife of 49 years Anita Bell for her help and understanding. >Regards , >Bruce Bell >Lubbock, Texas ________________________________________________________________________________
Subject: Flying to OXR
Date: Aug 08, 2006
Hey all... In the next couple weeks I will be making a trip from Colorado Springs to Oxnard Airport (OXR), by way of either Page, AZ or Sedona, AZ, and am looking for a place to stay for a few days while I am in CA... I don't need much, just a bed will do me just fine.....if anyone has any spare room in the area please drop me a line... Thanks in advance!! -Bill VonDane RV-8A ~ www.rv8a.com bill(at)vondane.com ________________________________________________________________________________
Date: Aug 08, 2006
Subject: Re: TBM Accident
>The bottom line is that our emotional response to tragic events in aviation >is to cast a cause out there in the hopes of future prevention. This is one >of those cases where the accident chain wasn't broken and so it occured. But >any of the proposed fixes just make room for alternative chains without >really reducing the overall risk much. The fact that a warbird ran over an RV and killed someone sounds like a broken accident chain to me. As far as "getting over it" I can think of two families who probably won't be able to easily. Ron Lee > ________________________________________________________________________________
Date: Aug 08, 2006
>From another lister: > Obviously, the large tail dragger pilot also has full responsibility > to taxi safely, but the "system" should make every effort to put him > in a situation where that is possible. If the taxi way is too narrow > to allow S-turns, then the only way a large tail dragger can taxi > safely is with some outside assistance. This argument, on its face, makes perfect sense - especially in light of the possibility of "saving lives." Again I urge caution, I believe this to be the first step down a slippery slope, at the bottom of which you'll find Pandora's Box. I, for one, do not wish the system to do my job for me, because the system rarely makes an effort to do anything, other than to tell me what I cant do. Do you see the "system' making the taxiways wider in response to this accident? Making a mandatory rule (for that can be the system's only response) to deal specifically with this situation may very well prevent its reoccurrence, but at what cost? We are all (those certificated at least) qualified pilots, qualified to operate an aircraft from chocks out to chocks in. We already have a plethora of rules whose boundaries we are obliged to remain within - do we really want more? The counter-argument is, "It's only one rule, and it just might save someone's life." Those making this counter-argument seek to trump all future arguments by making potential opponents seem callous and uncaring about human life. One of flyings biggest draws is a marvelous sense of freedom. Part of that sense of freedom comes from feeling the pride of accomplishment. It's knowing we are engaging in a risky endeavor, risks we overcome through the effective application of skills learned in training. Our training allows us to bend an unruly aero-machine to our will. How long until "...just one rule..." becomes too many rules? In Mexico one can't fly his or her aircraft VFR at night. The Government thinks it's too risky... We could save a tremendous number of lives in this country by making a national 55 mph speed limit, and enforcing it with a speed governor on every automobile. I don't know the specific ratios (I'm sure the hobby physicists among us will correct me), but reducing the speed of an impact by a factor of 1 reduces the force of that impact by a factor of 4 (Energy = Mass times Velocity squared, I hate math...) The point is we don't have a national speed limit; a deadly impact is a risk we are all willing to accept - along with the freedom to drive faster. As has been pointed out by another poster, this is the one and only time an accident such as this has occurred at OSH in its long and storied history. After this one, assuming *NO RULES* are added, how long do you think it will be before another? How many of us will blithely sit on a busy taxiway without knowing who or what is taxiing behind us? How about a simple radio call, "Avenger taxiing south on Bravo, do you see the RV in front of you?" > You seem to be saying that one fatality in 36 years is an acceptable > loss rate, so no changes are needed. What loss rate would it take > before you would conclude that changes were warranted? Another question designed to intimidate the opponent by making him or her appear to be unconcerned about the loss of life - and is also very close to a personal attack. Let me be clear, NO FATALITIES ARE ACCEPTABLE! The question isnt whether fatalities are acceptable; the question is what reaction to this accident is appropriate. Its not unusual to feel the need to do something in the face of a tragic accident, but we must approach the situation carefully so that whatever we do (or dont do) is appropriate! > The Avenger pilot was put in a very difficult situation. Once he > was marshalled onto a narrow taxi way with no wing walkers, he had > two choices: press on and hope for the best, or shut down and > become a road block. This argument is a little specious. Assuming the Avenger pilot even considered the dangers of taxiing on a narrow taxiway in a row of mixed traffic, he had an infinite number of options. If he was feeling uncomfortable with the situation he may very well have chosen to continue due to percieved pressure to do so - this, of course, is mere speculation. We could also speculate that the perceived pressure to taxi and avoid becoming a "road block" would surely have paled in comparison to the eventual outcome, if only he had the gift of clairvoyance. So what is the final outcome? What if there are no wing walkers available, do we prohibit taxiing without them? Can we make enough rules so as to rule out the possibility of one of making mistakes? I submit that the umbrella of rules under which we currently operate is quite broad, but not so broad as to prevent any number of tragic accidents from happening on a daily basis. How many more would do the trick? No, the reality is the Avenger's pilot operated within the rules, and still made mistakes - mistakes that proved fatal for the victim in this case. We can argue what he, the RV pilot, the EAA and/or the FAA should or shouldn't have done until the cows come home, and it won't change the fact that this accident was a freakish tragedy exactly *BECAUSE* it was so unexpected, unlikely, unusual and uncommon. Everyone involved in our avocation knows (or should know) the risks. Every time we "slip the surly bonds" we are risking our life, the lives of our passengers and assorted potential victims on the ground. We've all heard the clich, "The only way to conduct a flight in complete safety is to not conduct it at all," or something close to it. It may be clich, but there is a small seed of truth there if one cares to look for it. You have to look beyond the irony, beyond the sarcasm and think! You'll find one of the immutable truths upon which our system of liberty and freedom is founded - the very system that allows us the freedom of personal flight. That truth, simply stated, tells us that we are responsible and accountable for our actions. To abdicate that responsibility is to abdicate our freedom. My fear is that the little seed of truth found in the clich, a truth which can grow to understanding and enlightenment, will wither and die if shielded from the sunlight of freedom by the umbrella of rules. IMHO, the *BEST* way to prevent this tragedy's reenactment is through education, not legislation. In that regard, lets keep the ideas coming for what we as pilots, not as regulators, can do. Mark Sletten Legacy FG N828LM www.legacyfgbuilder.com ________________________________________________________________________________
Date: Aug 08, 2006
Subject: Re: doors off?
I would think you can't take the doors doors off your 172 without an STC to do so.... at least that's the way it is for the Cessna 140. There is an STC (a friend of mine has it) that allows ONE door to be off of a 140. It's a paperwork-only sort of STC -but the fact that only one door is allowed off at a time kinda' leads one to believe that the plane won't fly very well with both off. My buddy says that his 140 is very windy and doggy on the performance with a door off -and the interior trim tries very hard to leave the plane... Scott N4ZW CFII A&P ATP ________________________________________________________________________________
Date: Aug 08, 2006
The safety wire is new since my 6A.. Rod end loosened one time about 300 hrs ago. I put some loctite on it and no problem since. DICK At 11:53 AM 8/8/2006, you wrote: > > > They show how to drill and safety wire the lock nut in the >drawings. I did not do it and mine came loose so I would sure recommend >doing it. I did not pay attention to how it worked but when the motor >runs it puts a small amount of torque on the shaft that can eventually >cause the nut to loosen up. It took mine 225 hours to come loose. > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Doug Gray >Sent: Tuesday, August 08, 2006 6:30 AM >To: rv-list >Subject: RV-List: Flap actuator to rod end - locking > > >I have converted my manual flap kit to electric. >What are the best options to lock the rod end bearing to prevent it >spinning out of the actuator when the jam nut works loose. >Doug Gray >RV-6 finishing kit > > ________________________________________________________________________________
Date: Aug 08, 2006
Wheeler, I'm with you about new rules and policies in general. However, if a procedural change can be made to address the cause, it might not be an entirely bad thing. The real problem was that the TBM pilot didn't know what airplane he was following. He thought he was following the Tundra and hung back far enough to see it, but was not even aware that there was an RV behind the Tundra. When the Tundra pulled off, he thought he was clear ahead and tried to move up and take station on whatever airplane was ahead of the Tundra. He stated that he had 100 yards of clear pavement ahead. He never once saw the RV. The RV pilot said he didn't know the guy was behind him. He said that he was directed to enter the taxiway by aircraft marshallers. That means that either he pulled into the gap in front of the TBM while he was already following the Tundra or the TBM pulled out behind him after he taxied past. Either way, the Avenger driver never saw the RV. The Lancair pilot behind the TBM (who chose not to pull out in front of the big airplane even though aircraft marshallers were gesturing to him to do so) said that he didn't see the TBM S-turning before he hit the RV. I'm supposing here that he didn't feel that S-turns were necessary because he could see the airplane he thought he was following - the Tundra. Maybe the accident chain would have been broken if the marshaller who (possibly) directed the RV onto the taxiway ahead of the TBM had made a point to inform the larger plane of who was in front of him as he passed. Yeah, I know, he would have to run in behind the guy's wing and it wouldn't be easy to make himself heard. Or maybe a handheld radio could have been used to inform the taildragger pilot. If the TBM was sequenced onto the taxi way after the RV, maybe that marshaller should have informed him of who he was going to be following. It may be that marshallers shouldn't be directing small airplanes into the queue ahead of aircraft with bad forward visibility. If you can't see ahead and you leave space so you can see who you're following, having that space fill up like the freeway at rush hour makes it more likely that something like this will happen again. When we approach these large airshows for landing, we are identified by type and color and told to follow an aircraft by type and color. Maybe something like this should be done on the taxiway at least for aircraft with limited visibility. We are already told to monitor a ground frequency so theoretically everybody should be listening. It could go something like this: "Avenger on taxiway P1 wiggle your ailerons, Roger you are following a white RV who is behind a green and white Tundra". Once he was thus sequenced, care would have to be taken not to run in anybody else in front of him and it would still be incumbent on him to occasionally verify that no new airplanes had snuck in on him. A radio call might need to be made at several points along the taxiway. Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Wheeler North Sent: Tuesday, August 08, 2006 11:14 AM Subject: RV-List: TBM Accident Well, I would personally like to thank Jeff for his comments. As one who works under Mike, aka Susie Q, this accident was one of those rare things that was just that, an accident. Go ahead write a boat load of rules and changes and policies and you will still have a few accidents. Which by the way this year was the first time in a few that we've had fatalities on field, which I think is a good record given what we do. I hate to be callous but get over it, the war birds are here to stay and we want them. They cause the public gate to at least triple from what it would be were they not here. That income is needed for this event to happen. Make bigger taxi ways, it won't do squat. In a 1000' it's entirely possible (as in I've seen it many times) for both planes to be in wiggle phase and not be able to see each other if they are close. And who is going to make bigger taxiways at every airport the TBM lands at? Go ahead put wing walkers out there, that way the TBM will have more targets to run over and kill. RE control towers, guess what the only legal obligation of a control tower for vfr traffic is to provide sequencing. Get over it, that's been tested in court many times. They are not obligated nor able to provide separation services in any vfr environment, particualrly on the gorund at Oshkosh. And the TBM is taking a risk when it taxi's but that risk is no different then the same risk you take when you taxi. I've seen little kids run out in front of various aircraft, fortunately none I've seen were hurt. But by some of this logic put forth we should outlaw kids and any airplane that might run them over. Yes we have rules to help reduce those risks, but that said all they do is reduce the risk, they never prevent entirely. The two airplanes did not, and apparently could not see each other, that is the cause of most aircraft collisions and to date no rule has ever fixed that. I'm pretty certain no new rules will help things any. If you are little and worried get a rearview mirror. Or better yet give up flying, stop driving, avoid earthquake and volcano country and don't eat at McDonald's any more. The bottom line is that our emotional response to tragic events in aviation is to cast a cause out there in the hopes of future prevention. This is one of those cases where the accident chain wasn't broken and so it occured. But any of the proposed fixes just make room for alternative chains without really reducing the overall risk much. You want to talk about safety, let's talk about the fact that an hour before this happended the controllers were launching aircraft into 35 kt tailwind takeoffs with rain in an effort to oblige the many who wanted to depart pre-hurricane. They finally got it and closed the airport. But that closure put even more pressure on the limited time slot for departures pre-airshow after the WX system passed. So guess what, it's partly God's fault, therefore I would suggest we write a rule forbidding God from having short term hurricanes at Oshkosh. And while we're at it the simplest fix would be to not allow RV's to come to Oshkosh as that will eliminate about 2/3 of the overall traffic which will greatly reduce the number of accidents. In fact there's some good data to support this fix as RV's (and Bonanzas) tend to be involved in many of the incidents that happen at Oshkosh. So, yes I feel horrible about this, as I do about the Europa, and the Cub, and the few others who perished coming to or from Oshkosh. And I feel bad about those who perished just flying that week as I do about the estimated 98000 people who die each year from boo boos that happen in US hospitals. That's almost twice the number of people who die in auto accidents and I'll bet most of you didn't even know that statistic. Get a life, be happy that you are alive, go fly your airplane and celebrate those who can longer join us for that ride. W ________________________________________________________________________________
Date: Aug 08, 2006
The taxiway is wide enough for a flight of 15 RVs to taxi staggard (side by side). How wide are we to make it? Everything we do in VFR flying is SEE and AVOID. Take all the space you need behind other aircraft so that you can taxi without hitting someone. DO NOT let others tell you to get closer than you want. I purchased my REAR VIEW Mirror from Pep Boys over 4 years ago. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,932 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- >From another lister: > Obviously, the large tail dragger pilot also has full responsibility > to taxi safely, but the "system" should make every effort to put him > in a situation where that is possible. If the taxi way is too narrow > to allow S-turns, then the only way a large tail dragger can taxi > safely is with some outside assistance. This argument, on its face, makes perfect sense - especially in light of the possibility of "saving lives." Again I urge caution, I believe this to be the first step down a slippery slope, at the bottom of which you'll find Pandora's Box. I, for one, do not wish the system to do my job for me, because the system rarely makes an effort to do anything, other than to tell me what I cant do. Do you see the "system' making the taxiways wider in response to this accident? ________________________________________________________________________________
Date: Aug 08, 2006
The safety wire solution is not the only way to solve this problem but it is fairly simple to do. When my rod end came loose, I was on final. Going from half to full flaps, there was a bang, and all at once I had no flaps. Bit of a surprise. Albert Gardner RV-9A N872RV Yuma, AZ ________________________________________________________________________________
Date: Aug 08, 2006
In a message dated 8/8/06 11:49:31 AM Eastern Daylight Time, sbuc(at)hiwaay.net writes: > the versions of AWM that I tried with the Trio did not provide > the standard NMEA protocol that the EZ-Pilot requires. I understand > there was considerable effort on the part of Trio to convince Control > Vision to standardize the NMEA output of AWM but it seems that may not > have happened. > > Sam Buchanan > http://thervjournal.com ========================= Sam: What type of output does AWM use? The three I a familiar with are: RS-232 IEEE and the NEMA versions. There are a few versions of NEMA. The next question is what input does the Trio require? Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 08, 2006
Well, the plot thickens. Talking to AWM leads me to believe that they think they are putting out the "right stuff." Trio thinks they will work if the "right stuff" comes in. I'm taking the whole shebang over to El Cajon (Trio Avionics) tomorrow to see if they can find a problem. Trio is great to work with so I am very optimistic. Albert Gardner Yuma, AZ -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of FLYaDIVE(at)aol.com Sent: Tuesday, August 08, 2006 5:57 PM Subject: Re: RV-List: GPS & Autopilot Setup In a message dated 8/8/06 11:49:31 AM Eastern Daylight Time, sbuc(at)hiwaay.net writes: > the versions of AWM that I tried with the Trio did not provide > the standard NMEA protocol that the EZ-Pilot requires. I understand > there was considerable effort on the part of Trio to convince Control > Vision to standardize the NMEA output of AWM but it seems that may not > have happened. > Sam Buchanan > http://thervjournal.com ________________________________________________________________________________
Date: Aug 08, 2006
FLYaDIVE(at)aol.com wrote: > > In a message dated 8/8/06 11:49:31 AM Eastern Daylight Time, sbuc(at)hiwaay.net > writes: > >> the versions of AWM that I tried with the Trio did not provide >> the standard NMEA protocol that the EZ-Pilot requires. I understand >> there was considerable effort on the part of Trio to convince Control >> Vision to standardize the NMEA output of AWM but it seems that may not >> have happened. >> >> Sam Buchanan >> http://thervjournal.com > ========================= > Sam: > > What type of output does AWM use? The three I a familiar with are: > RS-232 > IEEE > and the > NEMA versions. There are a few versions of NEMA. > The next question is what input does the Trio require? > > Barry > "Chop'd Liver" Barry, you must have missed the update I sent out shortly after posting the above message. Trio informed me that they have had success getting the latest version of AWM to drive the EZ-Pilot. I suggest you contact Trio if you need more specific info on their system. Both AWM and the EZ-Pilot use NMEA data. I have had success driving the EZ-Pilot with a Lowrance Airmap 100 and Airmap 1000. Fellow RVers in the area also get excellent results with Garmin units. Apparently earlier versions of AWM did not send all the sentences of the NMEA data or the sentences were in non-standard form. Since the guys at Trio are very particular about assuring their unit is flying only on good data, the EZ-Pilot filters would reject non-standard data protocol. Sam Buchanan ________________________________________________________________________________
Date: Aug 08, 2006
But let's not forget we (the volunteers) WERE there. anytime the avenger pilot felt unsafe, he could have stopped and waved any of the volunteers along Papa and stated his problem and his request. it would not be the first pilot and will not be the last pilot asking for help. I myself have helped warbird pilots, as well as others, along Papa who needed space, direction, urge to do a run-up then and there, etc. All u have to do is ask and we will do our best to secure the area for u. And papa seems to get smaller and smaller as this thread moves along, the main gear of a super conny fits on it, so did the B24 and the B17 as well as the lancaster gear without running off in the grass on either side, just to put width in perspective. The avenger is not that wide compared to the above planes. Yes i know, they don't have to S-turn, just pointing out other warbird tail draggers can and do on papa taxiway. RV6 Flyer wrote: > > > The taxiway is wide enough for a flight of 15 RVs to taxi staggard > (side by side). How wide are we to make it? > > Everything we do in VFR flying is SEE and AVOID. Take all the space > you need behind other aircraft so that you can taxi without hitting > someone. DO NOT let others tell you to get closer than you want. > > I purchased my REAR VIEW Mirror from Pep Boys over 4 years ago. > > > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 1,932 + Flying Hours So. CA, USA > http://SoCAL_WVAF.rvproject.com > > > ----Original Message Follows---- > > >From another lister: > > > Obviously, the large tail dragger pilot also has full responsibility > > to taxi safely, but the "system" should make every effort to put him > > in a situation where that is possible. If the taxi way is too narrow > > to allow S-turns, then the only way a large tail dragger can taxi > > safely is with some outside assistance. > > This argument, on its face, makes perfect sense - especially in light of > the possibility of "saving lives." Again I urge caution, I believe > this to > be the first step down a slippery slope, at the bottom of which you'll > find Pandora's Box. I, for one, do not wish the system to do my job for > me, because the system rarely makes an effort to do anything, other > than to tell me what I cant do. Do you see the "system' making the > taxiways wider in response to this accident? > > -- ------------------------------------------------------------------- Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227, any and all nonsolicited commercial E-mail sent to this address is subject to a download and archival fee in the amount of $500 US. E-mailing denotes acceptance of these terms. -------------------------------------------------------------------- ________________________________________________________________________________
Subject: WTB: RV7A Wing kit & Fuse or QB
Date: Aug 09, 2006
I'm ready to get rolling on the wings for my 7A. If anyone is thinking about shifting gears and getting out, let's talk. I will consider a QB kit too, but am trying to keep costs low for the airframe and I love the build process anyway. E-mail me if you want to give your kit a good home. Looking for tip-up, if possible. rv(at)discursion.com Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53579#53579 ________________________________________________________________________________
Date: Aug 09, 2006
I suggest the responsibility lies with the Avenger's PIC, the fault is shared by many parties. Chuck Jensen ________________________________________________________________________________
Date: Aug 09, 2006
cjensen(at)dts9000.com wrote: > I suggest the responsibility lies with the Avenger's PIC, the fault is > shared by many parties. > > Chuck Jensen Respectfully, IMO, you're half right. The responsibility lies with the PIC (of the TBM) - period. The fault is not a consideration. All PIC's operating aircraft chose to come to Oshkosh and accepted the finite amount of risk. True, no death is acceptable, but there is in fact a certain number of accidents/incidents/collisions, etc. that are either acceptable or unacceptable. Apparently, one or two each year are acceptable. The show continues - for now. Doesn't make the losses good or something we should not try very hard to prevent (e.g., this discussion). But to say no accidents will occur or none should be expected in the plan is just not realistic. The goal should be to *minimize* risks. Last comment with my turn, PLEASE don't advocate any more rules. After 20 yrs of flying, I actually gain more respect for those rules (OSH and system wide) the more I use them. If pilots would just do their #1 job of SEE AND AVOID, these human error risks would be pushed to near zero. I'll step away from the horse. Flame away. Bryan -------- Bryan -8 Houston Read this topic online here: http://forums.matronics.com/viewtopic.php?p=53619#53619 ________________________________________________________________________________
Date: Aug 09, 2006
Hi Rob- >On 5:44:47 2006-08-08 "glen matejcek" wrote: >> My other observation regards the comment "However, it was a freak >> accident..." Perhaps this was a first for OSH, but it's not really an >> isolated event. > >Not at all. The event I related from Reno a few years back is another (Sea >Fury meeting Lancair), but didn't a warbird overrun another warbird on >takeoff a few years back at Oshkosh? I seem to recall one radial-engined >warbird overrunning another after a miscommunication of takeoff procedure >during a formation flight. > >But that being said, why are we discussing this on the RV-List? > >-Rob Well, for a couple of reasons. We lost a brother. That is of concern and interest to us. We don't want this to happen again. As to my post in particular, I was trying to not put too fine a point on it and was perhaps a bit too successful. A lot of the previous commentary on this list seemed to imply that, just as in the case you cited, the problem is one of a large aircraft following a smaller one, and as such is perhaps not a problem we need to concern ourselves with too much in our daily ops. That is not the case. Size differential exacerbates the situation, but it is not the cause. A lack of situational awareness (SA) is the cause. Had the TBM known the RV was there, he would have stopped short. Had the RV known the TBM was about to run him over, he'd have goosed it and run off into the grass or some such. The biggest killer of GA pilots is continued VFR into IMC. Same problem, lack of SA. This leads directly to the next issue: rules. You can't regulate SA. All you can do is pre-assess blame. Case in point: Barring other input from ATC, after landing at a tower controlled airport, you are to clear the runway ASAP but remain clear of the parallel taxiway. Unfortunately, the taxiway is generally too close to the runway for an air carrier aircraft to turn off and be clear of both the taxiway and the runway. The end result is that if there is a conflict, the bureaucracy is protected and the PIC is to blame. Do we really need more of that? The better we are at policing ourselves, the less the feds will be inclined to do so. And that is precisely what comes of these exchanges on our list. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Aug 09, 2006
Subject: Re: Leaning on ground?
In a message dated 8/5/06 1:31:57 PM Eastern Daylight Time, shempdowling2(at)earthlink.net writes: > So whats a good technique for leaning on the ground. > > Shemp/Jeff Dowling > RV-6A, N915JD > 295 hours > Chicago/Louisville ============================== Shemp: That depends on what instrumentation is in the plane. Simple answer, lean to stumble and then RICH'N three clicks, or three turns or three-sixteenths of an inch. All you are looking for is a leaner mixture to prevent the lead from forming. Hell, we're EAA ... EXPERIMENT! Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Subject: Vertical Card Compass in RV Panel
Date: Aug 09, 2006
I'm curious to hear from anyone who has installed a vertical card compass in an RV panel. My understanding is that they need to be mounted in a vertical panel +/- 4 degress of tilt. I got a response from a vendor who said "people are doing it" but that doesn't meet it works or works right. Anyone out there have a VC Compass mounted in the panel and noticed any issues?? Matthew N523RV :: RV-9A :: 109.3 hours http://www.n523rv.com ________________________________________________________________________________
Subject: Re: Vertical Card Compass in RV Panel
Date: Aug 09, 2006
Mine is mounted on the windshield brace tube (slider) and works fine. If you have a tip up this won't be applicable to your situation. -- Harry Crosby RV-6 N16CX, 250hours -------------- Original message ---------------------- From: "Matthew Brandes" <matthew(at)n523rv.com> > I'm curious to hear from anyone who has installed a vertical card compass in > an RV panel. My understanding is that they need to be mounted in a vertical > panel +/- 4 degress of tilt. I got a response from a vendor who said > "people are doing it" but that doesn't meet it works or works right. Anyone > out there have a VC Compass mounted in the panel and noticed any issues?? > > Matthew > N523RV :: RV-9A :: 109.3 hours > http://www.n523rv.com > > > From: "Matthew Brandes" <matthew(at)n523rv.com> Subject: RV-List: Vertical Card Compass in RV Panel Date: Wed, 9 Aug 2006 17:39:44 +0000 Content-Type: Multipart/alternative; boundary="NextPart_Webmail_9m3u9jl4l_10402_1155146709_1" --NextPart_Webmail_9m3u9jl4l_10402_1155146709_1 Content-Type: text/html; charset="us-ascii" Content-Transfer-Encoding: quoted-printable
Matthew
--NextPart_Webmail_9m3u9jl4l_10402_1155146709_1-- ________________________________________________________________________________
Date: Aug 09, 2006
I've been leaning on the ground to where if I advance the throttle past about 1200 RPM the engine quits. Seems to work since I have no problem with lead fouling. It's also pretty hard to take off if I forget to richen for T.O. (only once, I swear). -- Harry Crosby RV-6 N16CX, 250hours -------------- Original message ---------------------- From: FLYaDIVE(at)aol.com > > In a message dated 8/5/06 1:31:57 PM Eastern Daylight Time, > shempdowling2(at)earthlink.net writes: > > > So whats a good technique for leaning on the ground. > > > > Shemp/Jeff Dowling > > RV-6A, N915JD > > 295 hours > > Chicago/Louisville > ============================== > Shemp: > > That depends on what instrumentation is in the plane. Simple answer, lean to > stumble and then RICH'N three clicks, or three turns or three-sixteenths of > an inch. All you are looking for is a leaner mixture to prevent the lead from > forming. Hell, we're EAA ... EXPERIMENT! > > Barry > "Chop'd Liver" > > "Show them the first time, correct them the second time, kick them the third > time." > Yamashiada > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 09, 2006
I tried mounting one in the panel in the lower center of a "6 pack" where a DG is typically placed. In this location it was badly affected by the other instruments or maybe it was the avionics. I now have a electronic compass there with a remote sensor and that works great. Dale Ensing ----- > -------------- Original message ---------------------- > From: "Matthew Brandes" <matthew(at)n523rv.com> > > I'm curious to hear from anyone who has installed a vertical card compass in > > an RV panel. My understanding is that they need to be mounted in a vertical > > panel +/- 4 degress of tilt. I got a response from a vendor who said > > "people are doing it" but that doesn't meet it works or works right. Anyone > > out there have a VC Compass mounted in the panel and noticed any issues?? > > > > Matthew > > N523RV :: RV-9A :: 109.3 hours > > http://www.n523rv.com > > > > > > > > ________________________________________________________________________________
Date: Aug 09, 2006
I mounted a vertical card compass on a bracket on the bottom edge of the panel and it works adequately there. When I had it in the panel it was very poor. Bill RV6 > ----- Original Message ----- > From: "Dale Ensing" <densing(at)carolina.rr.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: Vertical Card Compass in RV Panel > Date: Wed, 9 Aug 2006 15:11:01 -0400 > > > > I tried mounting one in the panel in the lower center of a "6 pack" where a > DG is typically placed. In this location it was badly affected by the other > instruments or maybe it was the avionics. I now have a electronic compass > there with a remote sensor and that works great. > Dale Ensing > > ----- > -------------- Original message ---------------------- > > From: "Matthew Brandes" <matthew(at)n523rv.com> > > > I'm curious to hear from anyone who has installed a vertical card > compass in > > > an RV panel. My understanding is that they need to be mounted in a > vertical > > > panel +/- 4 degress of tilt. I got a response from a vendor who said > > > "people are doing it" but that doesn't meet it works or works right. > Anyone > > > out there have a VC Compass mounted in the panel and noticed any > issues?? > > > > > > Matthew > > > N523RV :: RV-9A :: 109.3 hours > > > http://www.n523rv.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 09, 2006
-----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Mac Donald Sent: Wednesday, August 09, 2006 7:54 AM Subject: Re: RV-List: RE: Oshkosh accident - Caution, on my Soapbox Rob, That accident was Frank Pardue either not hearing or not listening to the controllers and starting his take off roll with two warbirds on the runway in front of him. He hit one of them with enough energy to do a flaming cartwheel over the one he hit. As to your second question. We are trying to protect our RV's, and our butts, by looking at the small system, our RV's taxiing, and the big system, heavy taxi traffic at OSH, and trying to make some sense of it all. Larry Mac Donald Larry: I believe it was Howard Pardue who was in the Bearcat that was hit. He was one of a pair of F-8's that had taxied down the runway, pulled to the sides (one on each side), turned toward the runway centerline and stopped, awaiting further directions from the warbird airboss. Due to some mixup in the signals, the two Corsairs started takeoff runs from the runway threshold and did not see the motionless Bearcats until their tails were up. The Corsair on the right(West side) was able to deviate the the right into the grass and managed to avoid the Bearcat on the right albeit with considerable crow hopping and grass flying. The Corsair on the left was unable to avoid a collision with Pardue and was grievously injured in the horrific, firey crash that followed. This was likely a communication error with all parties doing as they believed they had been directed to do. The results were devastating. Gordon Comfort N363GC ________________________________________________________________________________
Date: Aug 09, 2006
I put one on the glare shield in a tip-up and it's very good. Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)comcast.net Sent: Wednesday, August 09, 2006 11:05 AM Subject: Re: RV-List: Vertical Card Compass in RV Panel Mine is mounted on the windshield brace tube (slider) and works fine. If you have a tip up this won't be applicable to your situation. -- Harry Crosby RV-6 N16CX, 250hours -------------- Original message ---------------------- From: "Matthew Brandes" <matthew(at)n523rv.com> > I'm curious to hear from anyone who has installed a vertical card compass in > an RV panel. My understanding is that they need to be mounted in a vertical > panel +/- 4 degress of tilt. I got a response from a vendor who said > "people are doing it" but that doesn't meet it works or works right. Anyone > out there have a VC Compass mounted in the panel and noticed any issues?? > > Matthew > N523RV :: RV-9A :: 109.3 hours > http://www.n523rv.com > > > ________________________________________________________________________________
Subject: LSE Plugs...
Date: Aug 09, 2006
What are you all using for plug with your LSE systems? They came with Denso W24EMR-C plugs, but was wondering if anyone is using anything different... Thanks... -Bill VonDane RV-8A ~ www.rv8a.com ________________________________________________________________________________
Subject: TBM
Date: Aug 09, 2006
Ed, not a bad idea, ie. using what is called a "ramp" frequency. This is done at some airshows like NWEAA in Arlington. We have used this for many years up there, but then we only digest about 2000-2500 airplanes. But Papa taxiway, as well as a few others is not completely visable from the tower at the south end, and there is so much going on that it would be next to impossible to radio control on one frequency with one controller. So then you would have the pilots changing frequencies as they move to each area? Me thinks that would be a riskier distraction. Given where the two planes were and where they most likely came from, the RV probably taxied out in front of the TBM while it was already well established on Papa. This could have happened while the TBM pilot was looking out his left side and he never saw the RV come out. The fact that the RV pilot didn't see the TBM when he pulled out is the only mistake I can see that was made in this event. What I have not yet been clearly led to understand is did the RV pilot pull onto Papa on his own or was he really marshalled. If he was marshalled then, at least when I run intersections, the aircraft on the taxiway gets stopped or slowed by hand and eye contact and the new aircraft is entered into the flow. It's very obvious to all, "if I have the time to make it so," that a new plane has been put on the taxiway. One problem arises because our parking rows come out close to the taxiway, where someone on the end could just start up and pull out (AKA it happens a lot). If that happens than the accident is ripe to happen.(They are not supposed to do this without an escort) The other problem is when an intesection gets over congested. If any landings are happening you have to keep part of it clear so the runway remains free of stopped aircraft. As well you may be putting airplanes into line from several different taxiways, of which most won't be going to the same locations once they pass you. So, were I to investigate this I would be asking how the RV got onto Papa without the TBM being aware of it. Jeff, did anyone ever find out where the RV came from, or if he just pulled onto the taxiway without a marshaller either at an intesection or from the grass? This isn't to single out a marshaller but rather to identify if there even was one and if so what led to them escorting the RV on in a way that didn't leave the TBM aware of it. In those details there might be some tweeks that would promote more safety. But even then, there's a manpower issue in that when I am working Papa 3 intersection I have airplanes coming at me from any one of 6 different directions all at the same time. Plus, the runway must stay clear because not only are planes landing and not pulling into the grass but rather lagging down to the taxiway and they are being shot across from the east runway 36/18 by the FAA pink shirts. So if I push three of those landers/crossers then spin in one coming north in the ditch taxiway and then a few from either direction of Papa I'm generally not going to be able to ensure who is aware of what. And I'm not sure a radio would help that any, particularly given the fact that the landing or crossing aircraft would not be on "ramp" frequency yet. And I'm already on a non-acft band radio talking to the other intersections letting them know if something odd coming their way needs their attention. As well both Papa two and Papa one are even more confusing to work. As I remember the accident occured between the two just north of Papa two. I stand my ground that this accident was just that, an accident, freaky and somewhat unavoidable when placed upon the scales against Lady Luck's evil sister. Finally I would like to comment about one comment made in regards to a collsion between an airliner and a cherokee. Not sure if that was referencing the PSA accident in San Diego which is why the TCAs(now class B) were formed. It was actually a 727 that took a hard right turn to a short approrach while being handed off from NAS Miramar Approach to San Diego Lindbergh approach/tower. It ran into a Cessna(182 if I remember right) on an IFR missed approach that, in the 727's turn had gone completely across the 27's windows and none of the four pilots in that cockpit ever saw it. (Two were hopping a ride home and were standing in the back gangway when it impacted) In the end they never knew what really went wrong. The rapid hand off from one agency to another is why the two airplanes were being controlled by differing controllers while in the same airspace until the last second which is what led to joining all complex airspaces into common units called TCAs. In this case the only real change was a big one, but that change probably did significantly reduce risks for those airports, so it was a good thing. The bottom line is we come to Oshkosh because of all the airplanes but because of all the airplanes the potential for a trajedy increases. These are juxtopposed forces that in this case won't be fixed by anything other than more awareness and diligence. And if you think that's bizarre, try explaining to me why during one airshow we had a yellow cub going down our Papa ditch taxiway being chased by a guy in a green toga carrying a bucket full of gravel. Weird stuff happens at Oshkosh... fortunately most of it isn't quite so tragic. W PS, I doubt EAA will be sued, they carry very good insurance for this event and in most cases establishing fault is avoided because it just raises an overall cost dramatically that will be borne by the insurance industry one way or another anyways. JT may correct me if I'm wrong but lawsuits don't do much for anybody's bottom line these days. ________________________________________________________________________________
Subject: Re: LSE Plugs...
Date: Aug 09, 2006
NGK BR8ES (#5422). As far as I can tell, they're identical to the Denso W24EMR-C. The NGKs are cheap and readily available just about anywhere. They're about $1.70 each from Rock Auto (http://www.rvproject.com/pricewatch.html). There may be a cheaper source on ebay if you buy in quantity. Note that EMagAir recommends the same BR8ES plugs for use with P-Mags. Fwiw, my IO-360-A1B6 / Lightspeed Plasma II has over 1000 hours on it with this setup. These NGKs are workin' great, and I ain't changin' a thing... I think they're actually snowmobile or personal watercraft plugs, but they run great on an RV. ;-) )_( Dan RV-7 N714D (1028 hours) http://www.rvproject.com ----- Original Message ----- From: "Bill VonDane" <bill(at)vondane.com> Sent: Wednesday, August 09, 2006 6:44 PM Subject: RV-List: LSE Plugs... > > What are you all using for plug with your LSE systems? They came with > Denso > W24EMR-C plugs, but was wondering if anyone is using anything different... > > Thanks... > -Bill VonDane > RV-8A ~ www.rv8a.com > > > ________________________________________________________________________________
Date: Aug 09, 2006
Subject: Re: TBM
The RV came out of RV land down Papa-1, taxiing east, then took a right turn at the Northpoint intersection, (north end of 18-36 at the warbird-trimotor crossroads), onto Papa, taxiing south to a center point departure to the south, center point is the Tower road intersection with Papa, the displaced 18 threshold. When the RV took the right turn at Northpoint, the TBM was still in warbird land. not a factor. That's why the rv pilot never knew the TBM was behind him, The TBM simply was not there when he taxied by. So no error on anybody's side here. The RV was escorted down Papa-1 as Papa-1 is narrow, fenced and partially open to public. At Northpoint, turning onto Papa, the RV was flagged south. Papa is considerable wider and not open to public, so the escort was terminated at Northpoint as is customary. For those who were in RV land and/or homebuild camping and seen Papa-1, we employ quite a few folks just to escort planes in and out on just that short stretch of Papa-1. likewise, when the TBM taxied past northpoint, the RV was far enough ahead not to be an immediate taxi issue for the TBM. This was NOT a case were the RV was on the side of Papa and was flagged or pulled right in front of the TBM. So now u know how the RV and the TBM came on Papa, without seeing each other. Wheeler North wrote: > > Ed, > > not a bad idea, ie. using what is called a "ramp" frequency. This is done at > some airshows like NWEAA in Arlington. We have used this for many years up > there, but then we only digest about 2000-2500 airplanes. > > But Papa taxiway, as well as a few others is not completely visable from the > tower at the south end, and there is so much going on that it would be next > to impossible to radio control on one frequency with one controller. So then > you would have the pilots changing frequencies as they move to each area? > > Me thinks that would be a riskier distraction. > > Given where the two planes were and where they most likely came from, the RV > probably taxied out in front of the TBM while it was already well > established on Papa. This could have happened while the TBM pilot was > looking out his left side and he never saw the RV come out. > > The fact that the RV pilot didn't see the TBM when he pulled out is the only > mistake I can see that was made in this event. What I have not yet been > clearly led to understand is did the RV pilot pull onto Papa on his own or > was he really marshalled. > > If he was marshalled then, at least when I run intersections, the aircraft > on the taxiway gets stopped or slowed by hand and eye contact and the new > aircraft is entered into the flow. It's very obvious to all, "if I have the > time to make it so," that a new plane has been put on the taxiway. > > One problem arises because our parking rows come out close to the taxiway, > where someone on the end could just start up and pull out (AKA it happens a > lot). If that happens than the accident is ripe to happen.(They are not > supposed to do this without an escort) > > The other problem is when an intesection gets over congested. If any > landings are happening you have to keep part of it clear so the runway > remains free of stopped aircraft. As well you may be putting airplanes into > line from several different taxiways, of which most won't be going to the > same locations once they pass you. > > So, were I to investigate this I would be asking how the RV got onto Papa > without the TBM being aware of it. > > Jeff, did anyone ever find out where the RV came from, or if he just pulled > onto the taxiway without a marshaller either at an intesection or from the > grass? This isn't to single out a marshaller but rather to identify if there > even was one and if so what led to them escorting the RV on in a way that > didn't leave the TBM aware of it. In those details there might be some > tweeks that would promote more safety. > > But even then, there's a manpower issue in that when I am working Papa 3 > intersection I have airplanes coming at me from any one of 6 different > directions all at the same time. Plus, the runway must stay clear because > not only are planes landing and not pulling into the grass but rather > lagging down to the taxiway and they are being shot across from the east > runway 36/18 by the FAA pink shirts. > > So if I push three of those landers/crossers then spin in one coming north > in the ditch taxiway and then a few from either direction of Papa I'm > generally not going to be able to ensure who is aware of what. And I'm not > sure a radio would help that any, particularly given the fact that the > landing or crossing aircraft would not be on "ramp" frequency yet. And I'm > already on a non-acft band radio talking to the other intersections letting > them know if something odd coming their way needs their attention. > > As well both Papa two and Papa one are even more confusing to work. As I > remember the accident occured between the two just north of Papa two. > > I stand my ground that this accident was just that, an accident, freaky and > somewhat unavoidable when placed upon the scales against Lady Luck's evil > sister. > > Finally I would like to comment about one comment made in regards to a > collsion between an airliner and a cherokee. Not sure if that was > referencing the PSA accident in San Diego which is why the TCAs(now class B) > were formed. It was actually a 727 that took a hard right turn to a short > approrach while being handed off from NAS Miramar Approach to San Diego > Lindbergh approach/tower. It ran into a Cessna(182 if I remember right) on > an IFR missed approach that, in the 727's turn had gone completely across > the 27's windows and none of the four pilots in that cockpit ever saw it. > (Two were hopping a ride home and were standing in the back gangway when it > impacted) In the end they never knew what really went wrong. > > The rapid hand off from one agency to another is why the two airplanes were > being controlled by differing controllers while in the same airspace until > the last second which is what led to joining all complex airspaces into > common units called TCAs. > > In this case the only real change was a big one, but that change probably > did significantly reduce risks for those airports, so it was a good thing. > > The bottom line is we come to Oshkosh because of all the airplanes but > because of all the airplanes the potential for a trajedy increases. These > are juxtopposed forces that in this case won't be fixed by anything other > than more awareness and diligence. > > And if you think that's bizarre, try explaining to me why during one airshow > we had a yellow cub going down our Papa ditch taxiway being chased by a guy > in a green toga carrying a bucket full of gravel. > > Weird stuff happens at Oshkosh... fortunately most of it isn't quite so > tragic. > > W > > PS, I doubt EAA will be sued, they carry very good insurance for this event > and in most cases establishing fault is avoided because it just raises an > overall cost dramatically that will be borne by the insurance industry one > way or another anyways. JT may correct me if I'm wrong but lawsuits don't do > much for anybody's bottom line these days. > > > > > > > > -- ------------------------------------------------------------------- Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227, any and all nonsolicited commercial E-mail sent to this address is subject to a download and archival fee in the amount of $500 US. E-mailing denotes acceptance of these terms. -------------------------------------------------------------------- ________________________________________________________________________________
Date: Aug 09, 2006
:-))) BR8ES plugs were the plugs of choice for the Yamaha TY50 .. all 49 CCs of it ... http://www.gerf.com/images/ty50.jpg Can't believe you're suggesting put them in a 360 cubic inch Lycoming, whatever next ... ;-) (Yes 1973 ... a slightly younger design than a Lycoming ...) g > > > NGK BR8ES (#5422). As far as I can tell, they're identical to > the Denso > W24EMR-C. The NGKs are cheap and readily available just about > anywhere. > They're about $1.70 each from Rock Auto > (http://www.rvproject.com/pricewatch.html). There may be a > cheaper source > on ebay if you buy in quantity. > > Note that EMagAir recommends the same BR8ES plugs for use with P-Mags. > > Fwiw, my IO-360-A1B6 / Lightspeed Plasma II has over 1000 hours > on it with > this setup. These NGKs are workin' great, and I ain't changin' > a thing... > I think they're actually snowmobile or personal watercraft > plugs, but they > run great on an RV. ;-) > > )_( Dan > RV-7 N714D (1028 hours) > http://www.rvproject.com > > ----- Original Message ----- > From: "Bill VonDane" <bill(at)vondane.com> > To: > Sent: Wednesday, August 09, 2006 6:44 PM > Subject: RV-List: LSE Plugs... > > > > > > What are you all using for plug with your LSE systems? They came with > > Denso > > W24EMR-C plugs, but was wondering if anyone is using anything different... > > > > Thanks... > > -Bill VonDane > > RV-8A ~ www.rv8a.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ---------------------------------------------------------- ________________________________________________________________________________
Date: Aug 09, 2006
>:-))) BR8ES plugs were the plugs of choice for the Yamaha TY50 >.. all 49 CCs of it ... > >http://www.gerf.com/images/ty50.jpg > >Can't believe you're suggesting put them in a 360 cubic inch >Lycoming, whatever next ... ;-) > I believe that is what I have been using for hundreds of hours in my O-360 with LSE. Ron Lee ________________________________________________________________________________
Date: Aug 10, 2006
In a message dated 08/09/2006 12:36:36 PM Central Daylight Time, matthew(at)n523rv.com writes: I'm curious to hear from anyone who has installed a vertical card compass in an RV panel. >>>> Mine is TDC between A/S & Alt- PAI-700 and works great except I never look at the stupid thing- GPS pretty much obsoletes it, but I DO do a cross-check occasionally. Here's my location: http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5256 >From The PossumWorks in TN, Mark Phillips http://websites.expercraft.com/n51pw/ ________________________________________________________________________________
From: "L Klingmuller" <l_klingmuller6(at)earthlink.net>
Subject: Vertical Card Compass in RV Panel Vertical Card Compass
in RV Panel
Date: Aug 10, 2006
In my tip up 6A I had it in the panel next the six pack. Did not work at all. So I moved it to the glareschield. Still debating if I should replace it with a regular whisky compass as it still not what it should be. Oh yes, GPS have made compass obsolete but then again it is required and you may find out the GPS does not work. Lothar ________________________________________________________________________________
Subject: Capella
Date: Aug 10, 2006
I have a friend that needs to go to LSA. He has come across a Capella with a Rotax912 that fits his price, anyone have information or opinions about this plane? Thanks John 2 RV6A completed RV7 in process ________________________________________________________________________________
Date: Aug 10, 2006
The issue with vertical card compasses when mounted in a panel is two-fold. First, they are more sensitive to local magnetic fields. Second, and much worse is that they use a BIG magnet on a needle bearing and no damping fluid. They will just spin around in circles under certain resonant vibrations. They are horribly affected by vibration. It also wears out the pivot bearings very fast. This is why the manufacturers of these devices provide very soft and cushioned mounts for them -for out of the panel applications only. I tried on in a panel myself a few years back -even talked to the manufacturer about it... It just plain didn't work for the above reasons. Scott N4ZW ________________________________________________________________________________
Date: Aug 10, 2006
Useful link for deciphering NGK spark plug numbers... http://www.kaila.net/tl125/tl125ngkcode.html Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Subject: TBM
Date: Aug 10, 2006
Thanks Gert, It sounds like the TBM just missed seeing the smaller plane in the horizon of stuff. I might be painting my rudder day glo orange just because... It also sounds like there was initially a large gap between the TBM and the rest of the traffic when it first approached the north end of Papa which may have also led to him not identifying which was the next in line. The bottom line there is that if he was following the wrong plane and didn't know about the RV than nothing outside like walkers or radios could have fixed that as they would not know that he didn't know until he ran into it. Which is pretty much what happens in most mid air collisions ie neither pilot has identified the other's presence and relative location until it's too late. As has already been said, a lot of S/A and a little prayer... AKA head on a swivel at all times on any airport. ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Subject: Flying to Canada from US (and back)
Date: Aug 10, 2006
Im planning on making my first international leg with my rv this wknd. I checked out aopa's site and was surprised to find I needed a stinkin' radio operators permit for me and the plane. 155 bucks down the drain. Then another 25 for a customs decal. Add the fee for air traffic control, which I dont know how it will be charged, and its costing a lot more than I thought. Oh well, Ive heard the fishing is ok. Any suggestions from anyone familiar with this type of flying? Im planning on landing in Ontario at Dryden and plan to call customs 24 hours in advance. No idea where to clear in MN yet. Shemp/Jeff Dowling RV-6A, N915JD 295 hours Chicago/Louisville ----- Original Message ----- From: "Wheeler North" <wnorth(at)sdccd.edu> Sent: Thursday, August 10, 2006 12:46 PM Subject: RV-List: TBM > > Thanks Gert, > > It sounds like the TBM just missed seeing the smaller plane in the horizon > of stuff. > > I might be painting my rudder day glo orange just because... > > It also sounds like there was initially a large gap between the TBM and > the > rest of the traffic when it first approached the north end of Papa which > may > have also led to him not identifying which was the next in line. > > The bottom line there is that if he was following the wrong plane and > didn't > know about the RV than nothing outside like walkers or radios could have > fixed that as they would not know that he didn't know until he ran into > it. > > Which is pretty much what happens in most mid air collisions ie neither > pilot has identified the other's presence and relative location until it's > too late. > > As has already been said, a lot of S/A and a little prayer... AKA head on > a > swivel at all times on any airport. > > > ________________________________________________________________________________
Date: Aug 10, 2006
Since you are near us in Chicago, you should join the Ohio Valley Rvators. We have more than 50 RV's flying, weekend get togethers, have a great formation team, and yearly clinic. We now have over 400 members and growing. Rick Gray runs the group and a bunch of them have made this trip several times and should be able to help you with what exactly you do and do not need. Takes just a few minutes to join, great group of guys and great resources for international travel. Hope this helps. Dan 40269 (N289DT) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jeff Dowling Sent: Thursday, August 10, 2006 2:34 PM Subject: RV-List: Flying to Canada from US (and back) Im planning on making my first international leg with my rv this wknd. I checked out aopa's site and was surprised to find I needed a stinkin' radio operators permit for me and the plane. 155 bucks down the drain. Then another 25 for a customs decal. Add the fee for air traffic control, which I dont know how it will be charged, and its costing a lot more than I thought. Oh well, Ive heard the fishing is ok. Any suggestions from anyone familiar with this type of flying? Im planning on landing in Ontario at Dryden and plan to call customs 24 hours in advance. No idea where to clear in MN yet. Shemp/Jeff Dowling RV-6A, N915JD 295 hours Chicago/Louisville ----- Original Message ----- From: "Wheeler North" <wnorth(at)sdccd.edu> Sent: Thursday, August 10, 2006 12:46 PM Subject: RV-List: TBM > > Thanks Gert, > > It sounds like the TBM just missed seeing the smaller plane in the horizon > of stuff. > > I might be painting my rudder day glo orange just because... > > It also sounds like there was initially a large gap between the TBM and > the > rest of the traffic when it first approached the north end of Papa which > may > have also led to him not identifying which was the next in line. > > The bottom line there is that if he was following the wrong plane and > didn't > know about the RV than nothing outside like walkers or radios could have > fixed that as they would not know that he didn't know until he ran into > it. > > Which is pretty much what happens in most mid air collisions ie neither > pilot has identified the other's presence and relative location until it's > too late. > > As has already been said, a lot of S/A and a little prayer... AKA head on > a > swivel at all times on any airport. > > > ________________________________________________________________________________
Subject: Re: Flying to Canada from US (and back)
Date: Aug 10, 2006
I have flown across the border hundreds of times, and no one has ever asked to see my radio operators permit, nor the one for the aircraft. They are much more worried about what type of food you might have along, drugs, alcohol, guns, etc. Don't waste your time or money on the radio permits. Kevin Horton Ottawa, Canada On 10 Aug 2006, at 14:34, Jeff Dowling wrote: > > > Im planning on making my first international leg with my rv this > wknd. I checked out aopa's site and was surprised to find I needed > a stinkin' radio operators permit for me and the plane. 155 bucks > down the drain. Then another 25 for a customs decal. Add the fee > for air traffic control, which I dont know how it will be charged, > and its costing a lot more than I thought. Oh well, Ive heard the > fishing is ok. > > Any suggestions from anyone familiar with this type of flying? Im > planning on landing in Ontario at Dryden and plan to call customs > 24 hours in advance. No idea where to clear in MN yet. > > Shemp/Jeff Dowling > RV-6A, N915JD > 295 hours > Chicago/Louisville > > ----- Original Message ----- From: "Wheeler North" <wnorth(at)sdccd.edu> > To: > Sent: Thursday, August 10, 2006 12:46 PM > Subject: RV-List: TBM > > >> >> Thanks Gert, >> >> It sounds like the TBM just missed seeing the smaller plane in the >> horizon >> of stuff. >> >> I might be painting my rudder day glo orange just because... >> >> It also sounds like there was initially a large gap between the >> TBM and the >> rest of the traffic when it first approached the north end of Papa >> which may >> have also led to him not identifying which was the next in line. >> >> The bottom line there is that if he was following the wrong plane >> and didn't >> know about the RV than nothing outside like walkers or radios >> could have >> fixed that as they would not know that he didn't know until he ran >> into it. >> >> Which is pretty much what happens in most mid air collisions ie >> neither >> pilot has identified the other's presence and relative location >> until it's >> too late. >> >> As has already been said, a lot of S/A and a little prayer... AKA >> head on a >> swivel at all times on any airport. >> >> >> ________________________________________________________________________________
Subject: Re: Capella
Date: Aug 10, 2006
I built and flew one, It was a fun plane, great in the summer with the doors off. Flew about 90-105 mph. I got rid of it when I got my RV-6, but lots of times I wish I still had it for those low and slow days. Although I had no trouble with the manufacturer or the kit, I think he did have problems with timely deliveries that caused more than a few customer complaints. I am not even sure if they are still in business. George ----- Original Message ----- From: John Furey To: rv-list(at)matronics.com Sent: Thursday, August 10, 2006 9:07 AM Subject: RV-List: Capella I have a friend that needs to go to LSA. He has come across a Capella with a Rotax912 that fits his price, anyone have information or opinions about this plane? Thanks John 2 RV6A completed RV7 in process ________________________________________________________________________________
Date: Aug 10, 2006
I've been across the border a few times and like Kevin, was never asked for it. Our chapter has a good guide to flying to Canada although some of the data applies to us out west... http://www.edt.com/homewing/international/index.html Randy Lervold www.rv-3.com ----- Original Message ----- From: "Kevin Horton" <khorton01(at)rogers.com> Sent: Thursday, August 10, 2006 12:33 PM Subject: Re: RV-List: Flying to Canada from US (and back) > > I have flown across the border hundreds of times, and no one has ever > asked to see my radio operators permit, nor the one for the aircraft. > They are much more worried about what type of food you might have along, > drugs, alcohol, guns, etc. Don't waste your time or money on the radio > permits. > > Kevin Horton > Ottawa, Canada > > > On 10 Aug 2006, at 14:34, Jeff Dowling wrote: > >> >> >> Im planning on making my first international leg with my rv this wknd. >> I checked out aopa's site and was surprised to find I needed a stinkin' >> radio operators permit for me and the plane. 155 bucks down the drain. >> Then another 25 for a customs decal. Add the fee for air traffic >> control, which I dont know how it will be charged, and its costing a lot >> more than I thought. Oh well, Ive heard the fishing is ok. >> >> Any suggestions from anyone familiar with this type of flying? Im >> planning on landing in Ontario at Dryden and plan to call customs 24 >> hours in advance. No idea where to clear in MN yet. >> >> Shemp/Jeff Dowling >> RV-6A, N915JD >> 295 hours >> Chicago/Louisville >> >> ----- Original Message ----- From: "Wheeler North" <wnorth(at)sdccd.edu> >> To: >> Sent: Thursday, August 10, 2006 12:46 PM >> Subject: RV-List: TBM >> >> >>> >>> Thanks Gert, >>> >>> It sounds like the TBM just missed seeing the smaller plane in the >>> horizon >>> of stuff. >>> >>> I might be painting my rudder day glo orange just because... >>> >>> It also sounds like there was initially a large gap between the TBM and >>> the >>> rest of the traffic when it first approached the north end of Papa
July 29, 2006 - August 10, 2006
RV-Archive.digest.vol-sd
