RV-Archive.digest.vol-sf
August 26, 2006 - September 11, 2006
      Can anyone comment on this type of ring gear wear pattern as to whether it is normal
      or do I have a problem developing?  Also, it possible that my starter could
      have the wrong tooth size for the ring gear and have been operating reasonably
      well for this many hours?
      Appreciate any thoughts on this.
      Harry Crosby
      RV-6 N16CX, 254 hours
      the many List utilities such as the Subscriptions page,
      ronics.com/Navigator?RV-List" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)">
      http://forums.matronics.com
      http://wiki.matronics.com
      _blank" onclick="return top.js.OpenExtLink(window,event,this)">http://www.matronics.com/contribution
Thanks Bob, I appreciate the info.
Harry Crosby
This is a problem I've seen with Sky-Tec starters on at least three occasions, not enough ring gear engagement.  If you call them of course it won't be their fault.  Once you can't get the thing to crank over the first compression, then they'll blame the engine manufacturer, then your wiring, your battery, your solenoid, your mother, etc.  I used to poo-poo B&C's because of the cost until I did some horsetrading and got one on a trade.  Now without question I believe that it is the best starter, with the new Sky-Tec high-torque starter in close second.  They're both about the same price ($550). The B&C is geared slightly taller which helps it overcome the first compression stroke with ease, just a little bit better (but slower) than the high-torque inline start er fro m Sky-Tec, but not by much.  A friend and I did testing on his F1 of three different starters (Sky-Tec Flyweight, my B&C, and the Sky-Tec high torque model).  The Flyweight's planetary gearing (which is plastic!) can only be rebuilt by them; as far as cranking performance goes it was in dead-last place.  One big advantage of the B&C is that it is rebuildable by your local starter shop.  I rebuilt the used one I got to like new condition for $38.00.   BTW the better two of the three starters fully engaged the ring gear.
Bob Japundza
RV-6 flying F1 under const.
On 8/25/06, HCRV6(at)comcast.net < HCRV6(at)comcast.net> wrote:
Engine Gurus,
I have about 255 hours total time on my factory new O-360A1A and have noticed that the wear pattern on the flywheel ring gear looks as if the starter gear is engaging only about the top 1/16 inch or less of each ring gear tooth.  Also it looks as if the teeth on the ring gear are wearing slightly rounded, with slightly more wear on the aft part.  The engine was delivered from Van's with a Sky-Tec starter that otherwise seems to work great and really spins up the engine on startup.
Can anyone comment on this type of ring gear wear pattern as to whether it is normal or do I have a problem developing?  Also, it possible that my starter could have the wrong tooth size for the ring gear and have been operating reasonably well for this many hours?
Harry Crosby
      http://www.matronics.com/Navigator?RV-List>
      http://forums.matronics.com>
      http://wiki.matronics.com>
http://www.matronics.com/contribution> ===========
Date: Aug 26, 2006
Subject: Engine Kick-Back IO-360
All, yesterday as I attempted to start up the IO-360 in my RV-8A, the engine "kicked back" and broke something in the starter, which is a Sky Tec Flyweight 149-12LS. When I say "broke something" I mean it actually broke off the cast metal nose of the starter, exposing the pinion gear. Any thoughts on what could cause the kick-backs? This is the second time I've had a problem with this starter - sent it back for repairs about 200 hours ago - it was almost new then, and the factory covered the repair cost. Walt Shipley ________________________________________________________________________________
Date: Aug 26, 2006
If you have an electronic ignition, your voltage drop when you engage the starter may be causing timing problems. If you have a standard magneto ignition system then you should check your impulse coupling and mag timing. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rveighta Sent: Saturday, August 26, 2006 9:41 AM Subject: RV-List: Engine Kick-Back IO-360 All, yesterday as I attempted to start up the IO-360 in my RV-8A, the engine "kicked back" and broke something in the starter, which is a Sky Tec Flyweight 149-12LS. When I say "broke something" I mean it actually broke off the cast metal nose of the starter, exposing the pinion gear. Any thoughts on what could cause the kick-backs? This is the second time I've had a problem with this starter - sent it back for repairs about 200 hours ago - it was almost new then, and the factory covered the repair cost. Walt Shipley ________________________________________________________________________________
Subject: Re: Engine Kick-Back IO-360
Date: Aug 26, 2006
On 26 Aug 2006, at 09:41, rveighta wrote: > > All, yesterday as I attempted to start up the IO-360 in my RV-8A, the > engine "kicked back" and broke something in the starter, which is a > Sky Tec Flyweight 149-12LS. > > When I say "broke something" I mean it actually broke off the cast > metal nose of the starter, exposing the pinion gear. > > Any thoughts on what could cause the kick-backs? This is the second > time I've had a problem with this starter - sent it back for > repairs about > 200 hours ago - it was almost new then, and the factory covered the > repair cost. What type of ignition system? I've heard of some electronic ignition systems that misbehave when the voltage goes low during start. The permanent magnet SkyTec starters apparently pull more current than some other starters, and thus drag the system voltage lower. Possible solutions, if this is the problem: 1. Leave the EI off until after start, 2. Ensure the EI is wired so it gets its power close to the battery. There will be a large voltage drop between the battery and the starter, and it would be bad to pull the EI power from a location that is subject to some or all of that voltage drop. 3. Reduce the resistance of the starter power feed (larger diameter cable, clean up connections etc). 4. Battery with more capacity and/or lower internal resistance so it provides higher voltage during starting. 5. Different starter. I've seen one report where going to a B&C starter stopped the kickback problem. Kevin Horton RV-8 (finishing kit) Ottawa, Canada
http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Aug 26, 2006
Walt, You are not the first person to experience this. My Stytec flyweight did the same thing on me at about 70 hours. Skytec likes to blame electronic ignitions for this problem, but the electronic ignition manufacturers have a different take on it. What ignition, battery and prop are you using? If you have a smaller battery (Odyssey, Panasonic) and a light prop (wood, composite) than you are set up for failure. Permanent magnet motors (like the Skytec) have much higher current draw than a wound-field motor. Combine the high current draw with the low current capabilities of a small battery and the lack of flywheel effect from a light prop, and you've set the stage for starting problems. In my case, a switch to a B&C wound field starter solved my problems. It spins the engine so fact I can almost get the tail up on starter power alone, Ok, not quite. In fairness, Skytec does sell a wound field starter as well, but I'm a big fan of B&C. There's plenty about this in the archives. Search on my name and "Skytec" around August 2004. Jeff Point RV-6 flying RV-8 preview plans Milwaukee > > ________________________________________________________________________________
Date: Aug 26, 2006
>Klaus issued a service bulletin ( 1/05 ) regarding "kickbacks".It notes >that the PM starters draw very high current which drops the voltage >available to the LSE ignition system. If the voltage drops below 8.5 volts >the LSE is disabled and kickbacks can occur. The system needs at least 8.5 >volts during the starting phase. > I have a carbureted O-360, Aymar Demuth wood prop, LSE III ignition and Odyssey PC 680 battery. During one annual my A&P measured the voltage at several points during a short cranking cycle. There was a significant voltage drop (don't remember the number) so I went to a larger cable to the starter, changed to the correct starter solenoid and put in the PC 925 battery. I also think my starter is a Sky Tec LS something. Where before the prop would often stop on a compression stroke (assumption) it swings right through now. I had perhaps 700 hours on the previous deficient setup with no kickbacks. At least not one that caused any problem. I am not sure that I have even experienced a kickback. I may make the LSE voltage mod if I am down for something else in the future for additional protection. Ron Lee ________________________________________________________________________________
Date: Aug 26, 2006
This is directly from Lightspeed Engineering's website today. Terry KICKBACKS Date of Issue: 01/2005 There are many possible reasons the engine can misfire during start. Several AD's have been issued over the years regarding impulse coupling problems on magnetos. Additionally, cold oil can prevent proper functioning of the impulse coupling. Cross firing in the distributor section of the mag can also be the cause for uncontrolled spark timing of the magneto. So if you still have a magneto on one side, be sure the mag is in good shape and up to date to avoid misfiring. Some time ago we received reports of kickbacks during start on airplanes with dual Plasma CD Ignitions. Extensive investigation showed that they were all using permanent magnet type starters. This type of starter typically draws much higher current than field wound starters. The installation manual for one of the main PM starter manufacturers advises that a 45% larger battery output is required! This, of course, eliminates any advertised weight savings but the bigger problem occurs when the engine owner is not aware of these requirements. If the battery is too small, the electrical system voltage can collapse when the starter tries to turn the engine over compression. This can temporarily disable the ignition system if the voltage drops to less than 8.5 volts. Other ignition systems go off line when the supply voltage drops below 10.3 volts. The Plasma CDI will operate safely down to about 5 volts once the engine is running but it needs 8.5 volts to start. The best way to prevent any problems is to install an appropriate size battery and cables to carry the actual load. If the electrical system is robust, the voltage dips during cranking should not go below 10 volts. This also keeps the Plasma CDI happy. To help avoid any kick backs that might be caused by low voltage of a compromised electrical system, we have made further improvements to the design that now allows the Plasma CDI to operate reliably down to 6.5 volts! The Plasma CDI's new extreme low voltage capability provides a larger safety margin (more time) in case of an alternator failure. It also allows starting by hand when the battery is too low to turn the starter. This modification to lower the minimum voltage even further will be incorporated into all Plasma CDI systems beginning spring 2005 and can be incorporated into older systems if requested. Systems having this modification are labeled "Version PMS" (this stands for "Permanent Magnet Starter", of course), "U3+" or "A" after the serial number. There have been no reports of kickbacks with the B&C starters, which are all wound field types and draw substantially less current. ________________________________________________________________________________
Date: Aug 26, 2006
Subject: First flight N176LD
Listers--My airplane partner David White and I have been on this list since Fall 1999 when we started our RV-6 project. Today she flew for the first time. Total build time was 6,000+ man hours over almost seven years. She's a semi-quick-build (quick-build fuselage, slow-build everything else) with the tall fin and counterbalanced rudder. She has a new 0-360 A1A and Hartzell blended airfoil CS prop (both from Van's) and regular magnetos. Equipment includes S-Tec 30 two-axis autopilot, standby electric attitude indicator, Gretz heated pitot and alternate static, VM 1000 engine monitor, Garmin 430 with GPSS steering, dual brakes. All antennas are external. We intend to fly her IFR. Paint is Imron three colors (painted at home). Empty weight is 1149 lbs at station 71. Mods include oil cooler on firewall with homemade fiberglass intake shroud, servo- operated landing light tilt in right wing, Meske (Aircraft Extras.com) tip-up/slider mod, Meske (Aircraft Extras.com) optical low fuel warning lights, tailwheel fairing.. We would like to thank Rich Meske, engineer extraordinaire, and Daryl Green, RV craftsman extraordinaire, for all their help and advice, and our tech counselor Jim Baldwin, and our supportive spouses and sweethearts, without whom this project could not have been completed. Flew her today without gear fairings for engine break-in. No heavy wing, she flies straight with a little right rudder. Looks like we will need to add that rudder tab. A few weeks ago we did six hours of dual with Alex De Dominicis (RVtraining.com) and highly recommend this to those about to take their first flights. We have learned a lot from this list and want to thank all who have contributed their thoughts over the years. Her name is Esperanza. For those still building, keep pounding those rivets! It's worth it! LeRoy Johnston and David White in Ohio. ________________________________________________________________________________
Date: Aug 26, 2006
Subject: Tire Wear
Over time, do RV main tires wear more on the outside or the inside treads? Pete RV-6, 123 hours. ________________________________________________________________________________
Date: Aug 26, 2006
Subject: Rant, question, suggestion: errors in plans/drawings
Rant mode on; drinkers of the 'Van's can do no wrong' koolaid, please stop & delete now. Several weeks (months?) ago I built up all the fuselage bulkheads including the main spar carry-thru for my -7 kit. I carefully followed all the directions/drawing indications I could find, especially on the spar carrythru bulkhead. I noted & carefully followed the exploded views on dwg 11 (rev 10-16-00) & later, dwg 22 (rev 10-27-00) showing the bolts for the F633 L&R control brackets & all the F716 seat ribs with the heads to the rear, threads forward. I built up the tail cone. I completed the prep work for final assy of the midsection. I began the riveting of the midsection several days ago & today, neared completion of the riveting. While studying dwg 22 section views to determine the orientation of the bolts through the F715 seat ribs, I noticed that they show nuts on the rib flange of all the F716 seat ribs where they bolt to the F704 spar carry-thru. 'Curses; must have not been paying attention when I bolted this stuff together.' (Bad medium term memory of earlier careful study of plans.) Out came the wrenches, re-oriented all the F716 bolts, retorqued. Happened to glance at the exploded view on the same dwg. All rib bolts drawn with head on the rib flange. I checked dwg 11 exploded view for the F633 bolts; it's inconsistent with the section view on dwg 22 also. Errors/inconsistencies #742 & 743 (guesstimate :-) ) noted in the plans and/or instructions. By the way, this same section in the instructions tells you to cleco in & drill the seat & baggage floors without telling you to install the baggage ribs at all & before they mention installing the F715 seat ribs, which must be curved by the builder, have centerlines drawn on their bottom flanges (not prepunched), & be match drilled to the belly skin. My revision of dwg shows the control stick walking beam assy to the spar with bolts oriented in a fashion that cannot be achieved under the current laws of physics. When I called about that, the tech guy had different orientation for some of the bolts, on his dwg with the same revision date. Excuse: 'Well, sometimes minor changes are made without changing the rev date/number.' His 1st suggested change also could not be achieved under the current laws of physics. The final result was basically, 'assemble it however you can to get it to work.' I've lost count of the number of times I've called the tech guys at Van's to politely question or point out this kind of stuff & asked repeatedly why they don't offer a section of the website with corrections & updates. They are usually courteous, but I invariably get various lame excuses like 'you should read ahead', you should know how it's done', 'well, when we built the prototype, we didn't have the instructions', etc etc etc. Sometimes they say they will bring up the issue 'at a staff meeting' but rarely if ever do they act like the issues are any big deal. Never is there any feedback or encouragement to continue reporting this stuff & with a single exception (defective AL bar stock) never an admission that others have had the same issue. Ok, rant mode off. Question: should I care which way the F716 bolts are oriented (currently head forward, nut/washer on rib) or the F633 bolts (currently head on F633)? The belly skin rivets under the F716 bolts will be less convenient to drive, but still 'doable'. Suggestion: We all take advantage of Matt's wiki to add a section for each model & sub sections for each assy or part that we have problems understanding or that are obvious errors/inconsistencies. The entries should document the plan revision date and/or the instruction revision date. This should help us all by consolidating records of problem areas, something Van's is obviously unwilling to do. Is this a worthwhile suggestion? (Again, koolaid drinkers please don't reply.) Thanks, Charlie ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: Tire Wear
Date: Aug 26, 2006
I'm sure it varies from aircraft to aircraft. On my RV-6, I get more wear on the outside of the tires, because I typically fly at lighter weights, which doesn't flex the gear as much and causes.... wear on the outside of the tire. Someone who operates a heavy aircraft will flex the gear more, and will have more wear towards the inside of the tire. My biggest wear area is on the right tire, because I still have not learned how to keep from occasionally dragging the right brake on takeoff. KB ----- Original Message ----- From: PeterHunt1(at)aol.com To: rv-list-digest(at)matronics.com ; RV6-list(at)matronics.com Sent: Saturday, August 26, 2006 10:54 PM Subject: RV-List: Tire Wear Over time, do RV main tires wear more on the outside or the inside treads? Pete RV-6, 123 hours. ________________________________________________________________________________
Subject: Tire Wear
Date: Aug 27, 2006
Pete: Yes they wear more on the outside. Left tire wears the most on the outside. (P-factor and need for right rudder on full power takeoff) Rotate tires when 1/2 worn out to get the most landing out of your tires. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,936 + Flying Hours So. CA, USA http://SoCAL_WVAF.rvproject.com ----Original Message Follows---- From: PeterHunt1(at)aol.com Subject: RV-List: Tire Wear Date: Sat, 26 Aug 2006 22:54:28 EDT Over time, do RV main tires wear more on the outside or the inside treads? Pete RV-6, 123 hours. ________________________________________________________________________________
Date: Aug 27, 2006
Subject: Re: Rant, question, suggestion: errors in plans/drawings
In a message dated 8/26/2006 10:59:14 PM Eastern Standard Time, ceengland(at)bellsouth.net writes: Is this a worthwhile suggestion? (Again, koolaid drinkers please don't reply.) Thanks, Charlie ======================================== It sure is Charlie! As one person said: "PSS Van does not do to much wrong when it comes to the RV's. :-)" How little is wrong does not matter or count when you spend hours or days working on something only to find it cannot be built or fit together the way it was drawn or described. It is still wrong. I really like RV's and there are less problems with RV's than GA planes. But, get frustrated because of a 'wrong' and then tell me you want to kiss Van. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Subject: RE: Tire Wear
Date: Aug 27, 2006
Hi Pete- Re: Over time, do RV main tires wear more on the outside or the inside treads? Yes, they do. Crosswind landings made in a slip put wear on the outboard edges of tires. The same principle applies to all aircraft. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Aug 27, 2006
Subject: Kick Back - More Info
Guys, thanks all of you who answered my query about a kick back problem with my IO-360. I should have included info about the battery and ignition system. I don't have an electronic ignition system, just two mags, the left is equipped with the standard impulse coupler. I have a new Concord 25RG-XC battery that is fully charged. When starting, I always flip on both mags. I have recently been experiencing start problems where the engine will fire on a cylinder or two for a few seconds, then gradually on all four. Sound like a impulse coupler problem? Walt Shipley ________________________________________________________________________________
Date: Aug 27, 2006
Plasma III Ignitions have been modified to run down to 6.5V during start from the previous 8.5V. If you have a plasma Ign go to their website and see which serial number have the mod. You can also send your module back and get it changed to accept as low as 6.5V during start up for $100. Changing starters is not always possible as I found out. I originally wanted to use the B&C and do believe they are better than Skytek. But I also have Precision Airmotive fuel injection which would interfere with the mixture control on the FI. In addition my engine is horizontal induction and the fiberglass ducting from Van's needs a ton of modifications to clear the B&C. Its built to go around the Skytek 12LS. Steve RV7A Flying, IO-360, Plasma III, 1 Mag > From: rveighta <rveighta(at)earthlink.net> > Subject: RV-List: Engine Kick-Back IO-360 > > > All, yesterday as I attempted to start up the IO-360 in my RV-8A, the > engine "kicked back" and broke something in the starter, which is a > Sky Tec Flyweight 149-12LS. > > When I say "broke something" I mean it actually broke off the cast > metal nose of the starter, exposing the pinion gear. > > Any thoughts on what could cause the kick-backs? This is the second > time I've had a problem with this starter - sent it back for repairs about > 200 hours ago - it was almost new then, and the factory covered the > repair cost. > > Walt Shipley ________________________________________________________________________________
Date: Aug 27, 2006
In a message dated 8/26/2006 4:26:39 P.M. Eastern Daylight Time, mkejrj(at)comcast.net writes: I spoke with Klaus @ OSH regarding the "kickback" potential of my LSE Plasma III installed on my Superior I0 360. I also have the SkyTek starter. Klaus issued a service bulletin ( 1/05 ) regarding "kickbacks".It notes that the PM starters draw very high current which drops the voltage available to the LSE ignition system. If the voltage drops below 8.5 volts the LSE is disabled and kickbacks can occur. The system needs at least 8.5 volts during the starting phase. LSE can modify your system if you return same to him. I believe the cost is about $ 100.00. The mod allows the LSE to operate as low as 6.5 volts. Dick Jordan N888BZ RV 8A/flying Interesting! I worked in ignition system design for GM for 15 years. We always had to meet a 4.5 volt, 30 RPM cranking test. Yes, a low battery on a GM car can dip to 4.5 volts and the ignition system has to stay in sync and deliver a spark. It seems to me like a design defect, and LSE should do the fix for no charge. Dan Hopper RV-7A ________________________________________________________________________________
Date: Aug 27, 2006
Walt, Unless both your mags have impulse couplings then you should start your engine with the impulse mag on and the non impulse mag OFF. Once the engine is running, turn on the other mag. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rveighta Sent: Sunday, August 27, 2006 9:54 AM Subject: RV-List: Kick Back - More Info Guys, thanks all of you who answered my query about a kick back problem with my IO-360. I should have included info about the battery and ignition system. I don't have an electronic ignition system, just two mags, the left is equipped with the standard impulse coupler. I have a new Concord 25RG-XC battery that is fully charged. When starting, I always flip on both mags. I have recently been experiencing start problems where the engine will fire on a cylinder or two for a few seconds, then gradually on all four. Sound like a impulse coupler problem? Walt Shipley ________________________________________________________________________________
Date: Aug 27, 2006
FYI, I started a database of "errors" (or at least, shall we say, "clarifications" as people reported them over the years. Oddly, though, I really don't have that many. If folks have specifics, please e-mail them to me at bcollinsrv7a(at)comcast.net (or if you're subscribed, just add it yourself at http://groups.yahoo.com/group/RV7A/database) and perhaps we can make it easier on those who are to follow. Bob Collins St. Paul, Minn RV Builder's Hotline free weekly newsletter http://home.comcast.net/~rvnewsletter/ > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Sunday, August 27, 2006 10:11 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Rant, question, suggestion: errors in > plans/drawings > > > > I would suggest that the comments regarding laxity in > accuracy of the plans and laxity of notifications of > revisions, and items like those quoted are valid concerns. ________________________________________________________________________________
Date: Aug 27, 2006
Subject: Re: Kick Back - More Info
Walt, the impulse will disengage at a couple of hundred RPM if I recall. When it fires the first time or second time may be enough to get past that. At that speed though, you could turn on the right mag (because you're starting on the left only now aren't you???) and see if it helps. A good plug cleaning and leaning on the ground may help also. What you might have is not enough primer so I would experiment there. While the engine is cranking, give the primer a push and see if that doesn't speed things up a bit. Linn rveighta wrote: > >Guys, thanks all of you who answered my query about a kick back problem >with my IO-360. I should have included info about the battery and ignition >system. I don't have an electronic ignition system, just two mags, the left is >equipped with the standard impulse coupler. I have a new Concord 25RG-XC >battery that is fully charged. When starting, I always flip on both mags. > >I have recently been experiencing start problems where the engine will fire >on a cylinder or two for a few seconds, then gradually on all four. Sound like >a impulse coupler problem? > >Walt Shipley > > > > ________________________________________________________________________________
Date: Aug 27, 2006
rveighta wrote: >Sound like a impulse coupler problem? > > No, it sounds like the non-impulse coupled mag is firing before TDC (like it should) during starting. The purpose of the IC is to slow the mag down so it fires right at TDC during the starting process. When the engine is running, there is enough speed and inertia that firing at 28 BTDC is desireable. Duirng starting, when the engine is running so slowly, if the non-IC mag fires at 28 BDTC, it is likely to cause a kickback. Try leaving the non-IC mag off during starting. If you have a keyswitch, make sure it's wired properly to ground (turn off) the non-IC mag at the START position. Jeff Point > > > > ________________________________________________________________________________
Date: Aug 27, 2006
I'm very close to wiring my plane and would like to know how to wire the ignition key switch. I have an AeroSport IO360 with one "mag", and one Lightspeed Electronic Ignition. It seems that the forum is suggesting that I wire the key switch so that in the "start" position only the Mag is firing, but upon releasing the key switch from start to both, that then both the mag and the Lightspeed are firing. Is this correct? Garry Stout RV7A Odessa Fl ----- Original Message ----- From: "Jeff Point" <jpoint(at)mindspring.com> Sent: Sunday, August 27, 2006 1:29 PM Subject: Re: RV-List: Kick Back - More Info > > rveighta wrote: > >>Sound like a impulse coupler problem? >> > No, it sounds like the non-impulse coupled mag is firing before TDC (like > it should) during starting. The purpose of the IC is to slow the mag down > so it fires right at TDC during the starting process. When the engine is > running, there is enough speed and inertia that firing at 28 BTDC is > desireable. Duirng starting, when the engine is running so slowly, if the > non-IC mag fires at 28 BDTC, it is likely to cause a kickback. > > Try leaving the non-IC mag off during starting. If you have a keyswitch, > make sure it's wired properly to ground (turn off) the non-IC mag at the > START position. > > Jeff Point > >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 27, 2006
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Subject: Cylinders: ECI vs Superior or Others
I'm looking for decision support To all the Engine Gurus and Roll your own engine builders out there, which is the cylinder kit to by in todays market. So many things are changing. It seems like everyday products are being improved and or modified in some way. I will not be going with standard compression pistons and have not settled on the type of pistons or the ratio yet. I would like to discuss overall quality, casting, manufacturing methods etc... Which will require a port clean up? Who's cleaned up their fins from casing issues? Is anyone using a cryogenic process on wear parts? Etc... Any information or advice is appreciated. Thanks in advance! __________________ Darrell Reiley RV7A "Reiley Rocket" N622DR Reserved CenTex_RV_Aircraft-owner(at)yahoogroups.com __________________________________________________ ________________________________________________________________________________
Subject: Rant, question, etc
Date: Aug 27, 2006
I read with interest the comments in this thread. I built my RV6A starting in 1991 so your quick builders, pre-punched, matched-hole RV'ers don't have a clue as to problems with plans. Yet, it got built and I am happy, but I had a lot of bad days struggling with "instructions" and drawings. Keep punching away, you don't know how easy you have it! ________________________________________________________________________________
Date: Aug 27, 2006
No, you want to start the engine with the EI ON and the mag OFF. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Garry Sent: Sunday, August 27, 2006 2:05 PM Subject: Re: RV-List: Kick Back - More Info I'm very close to wiring my plane and would like to know how to wire the ignition key switch. I have an AeroSport IO360 with one "mag", and one Lightspeed Electronic Ignition. It seems that the forum is suggesting that I wire the key switch so that in the "start" position only the Mag is firing, but upon releasing the key switch from start to both, that then both the mag and the Lightspeed are firing. Is this correct? Garry Stout RV7A Odessa Fl ----- Original Message ----- From: "Jeff Point" <jpoint(at)mindspring.com> Sent: Sunday, August 27, 2006 1:29 PM Subject: Re: RV-List: Kick Back - More Info > > rveighta wrote: > >>Sound like a impulse coupler problem? >> > No, it sounds like the non-impulse coupled mag is firing before TDC (like > it should) during starting. The purpose of the IC is to slow the mag down > so it fires right at TDC during the starting process. When the engine is > running, there is enough speed and inertia that firing at 28 BTDC is > desireable. Duirng starting, when the engine is running so slowly, if the > non-IC mag fires at 28 BDTC, it is likely to cause a kickback. > > Try leaving the non-IC mag off during starting. If you have a keyswitch, > make sure it's wired properly to ground (turn off) the non-IC mag at the > START position. > > Jeff Point > >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 27, 2006
Subject: Weight & Balance
After removing the vacuum system, pump and instruments, and adding an autopilot, I want to re-weigh and do a weight & balance on my RV-4. Is it feasable to top off the fuel tanks, assume a 32 gallon load and then reverse the fuel arm and weight to arrive at the gross aircraft weight? Part of my brain says that won't work correctly. Any thoughts? Pat Long PGLong(at)aol.com N120PL RV4 Bay City, Michigan 3CM Do Not Archive ________________________________________________________________________________
Date: Aug 27, 2006
Subject: Re: Weight & Balance
At 03:41 PM 8/27/2006, you wrote: >After removing the vacuum system, pump and instruments, and adding an >autopilot, I want to re-weigh and do a weight & balance on my RV-4. Is it >feasable to top off the fuel tanks, assume a 32 gallon load and then >reverse the fuel arm and weight to arrive at the gross aircraft weight? >Part of my brain says that won't work correctly. Any thoughts? If you can weigh it empty then add the weight of 32 gallons at its arm, why not? Ron Lee ________________________________________________________________________________
Date: Aug 27, 2006
On 27 Aug 2006, at 17:41, PGLong(at)aol.com wrote: > After removing the vacuum system, pump and instruments, and adding > an autopilot, I want to re-weigh and do a weight & balance on my > RV-4. Is it feasable to top off the fuel tanks, assume a 32 gallon > load and then reverse the fuel arm and weight to arrive at the > gross aircraft weight? Part of my brain says that won't work > correctly. Any thoughts? > > Pat Long > PGLong(at)aol.com > N120PL > RV4 > Bay City, Michigan > 3CM > This will work, if you have already confirmed that you have 32 USG usable fuel load. The number from Van's is only the nominal value. Every aircraft is slightly different. But, if you subtract the fuel, you'll get an empty weight, not the gross weight, right? Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Aug 27, 2006
Right, empty weight. There is just enough grey area, guess I'll wait till I'm light enough on fuel to have storage for the balance. Didn't want to do that, but it is the correct and safer way. Pat -------- Pat Long RV-4, N120PL Bay City, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=57841#57841 ________________________________________________________________________________
Date: Aug 27, 2006
I was struck, when starting my -8 with the empennage, just how simple and straightforward the plans and instructions were. Nice little check boxes for each step. Then I got the wing kit. The wing is much more complex and the instructions are much less exacting. Like where it discusses how to rivet the bottom skins. Then, the next page talks about what to do before you put on the bottom skins and then the next page goes back to how to put on the bottom skins. I suppose the truth is that I learned enough from the empennage to sort out how to do most of the wing--with a lot of help from the online community and a few questions to Van's. My guess is that the online community would probably be happy to re-write the assembly manual given the opportunity. Anyway, most the kit and plans are pretty straightforward. I would be happier if I had a bunch more pages of little check boxes. I am clearly an assembler and not an engineer. I think the second RV would be a lot easier. I suppose Van's has other stuff to do, but I think they would sell even more kits if all the instructions were as well documented as the empennage instructions. Regards, Michael Wynn (Ginger ale drinker) RV-8, Wings San Ramon, California Do Not Archive ________________________________________________________________________________
Date: Aug 27, 2006
-----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Sunday, August 27, 2006 1:37 PM Subject: Re: RV-List: Rant, question, suggestion: errors in plans/drawings Why should I be forced to guess his intent when I paid good money for a kit & instructions instead of a truckload of ore? I've had quite a few conversations with Van's various tech guys offering what I consider constructive suggestions that could improve the kits at minimal expense & radically reduce phone time for them. Charlie et al: It might be helpful to think of the builders manual as an outline to direct your own thought processes. A manual sufficiently detailed to satisfy everyone would be impractical. One needs to think through the tasks and the builders manual will help you do that but it will not do it for you. Time spent trying to improve Van's perceived performance could be spent solving problems using any and all resources that can be found. The literature has many volumes describing standard practices, techniques methods and goals that have been a part of aircraft manufacture for decades. These projects are part of a learning process we can strive for. The ensueing self reliance can be gratifying. Gordon Comfort N363GC ________________________________________________________________________________
Date: Aug 28, 2006
LeRoy and David, CONGRATULATIONS and WELL DONE !!! Chuck & Dave Rowbotham RV-8A >From: JhnstnIII(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: First flight N176LD >Date: Sat, 26 Aug 2006 22:26:44 EDT > > >Listers--My airplane partner David White and I have been on this list >since >Fall 1999 when we started our RV-6 project. Today she flew for the first >time. >LeRoy Johnston and David White in Ohio. ________________________________________________________________________________
Date: Aug 27, 2006
gordon or marge wrote: > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie England >Sent: Sunday, August 27, 2006 1:37 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Rant, question, suggestion: errors in plans/drawings > > Why should I be forced >to guess his intent when I paid good money for a kit & instructions >instead of a truckload of ore? > >I've had quite a few conversations with Van's various tech guys offering >what I consider constructive suggestions that could improve the kits at >minimal expense & radically reduce phone time for them. > > >Charlie et al: > >It might be helpful to think of the builders manual as an outline to direct >your own thought processes. A manual sufficiently detailed to satisfy >everyone would be impractical. One needs to think through the tasks and the >builders manual will help you do that but it will not do it for you. Time >spent trying to improve Van's perceived performance could be spent solving >problems using any and all resources that can be found. The literature has >many volumes describing standard practices, techniques methods and goals >that have been a part of aircraft manufacture for decades. These projects >are part of a learning process we can strive for. The ensueing self >reliance can be gratifying. > >Gordon Comfort >N363GC > You're not fooling me, Gordon; I can smell the koolaid on your breath. :-) I think that you're missing the point. If I wanted the raw 'mine the ore' experience, I could buy a set of plans for a -6 (or a crashed plane to build around the serial #), a Mustang II or a Thorp T-18 & start pounding metal. (Yes, there are scratch built -4's & -6's out there.) Please explain what value, other than long suffering & patience, I can take from spending 20 hours inventorying parts when the job could be done in 2 hours with a pick list sorted by part #. I paid a premium for a prepunched kit, the instructions to assemble it, and the support of the kit seller. Van's A/C understands their market well enough to continue adding features (along with price) like prepunch, FWF kits, etc. In the past they have incorporated many features in the kits that were dreamed up by builders & flyers. It's unfortunate that they cannot or will not recognize that the kits could be significantly improved and the need for factory support minimized with a little attention to their documents. I really don't want to just rant; I'd like to try for a solution. That's why I'm proposing that we do this ourselves. Charlie ________________________________________________________________________________
Date: Aug 27, 2006
In general, I think that Van's has designed excellent aircraft and their kits are great. But in some respects the instructions could be a little better. Yes, we should be able to extrapolate from the drawings and instructions to figure out what we should be doing, but when there are specific instructions or drawings for an operation, we should be able to rely on them. It is not that the instructions need to be expanded, it is that those that are there should be correct. Any incorrect or contradictory instructions should be fixed. This is not hard, as I'm sure that Van's has been apprised of the errors by many people. Also, we should not have to worry about following the instructions and doing something only to find out later that something else should have been done first. Reading ahead in the instructions is a good idea, but they should be in the proper order anyway. I'm having a great time building my 8, but sometimes it is frustrating trying to figure out what to do when the instructions and drawing are unclear or contradict each other. The instructions that are provided, at whatever level of detail that Van's feels are necessary, should be accurate. It would take very little effort to create a section on their website with corrections to the instructions and drawings. For anything beyond that, I feel that these forums and email lists are a great resource. Paul Trotter RV-8 82080 Fuselage Kit > > Charlie et al: > > It might be helpful to think of the builders manual as an outline to > direct > your own thought processes. A manual sufficiently detailed to satisfy > everyone would be impractical. One needs to think through the tasks and > the > builders manual will help you do that but it will not do it for you. Time > spent trying to improve Van's perceived performance could be spent solving > problems using any and all resources that can be found. The literature > has > many volumes describing standard practices, techniques methods and goals > that have been a part of aircraft manufacture for decades. These projects > are part of a learning process we can strive for. The ensueing self > reliance can be gratifying. > > Gordon Comfort > N363GC > ________________________________________________________________________________
Date: Aug 27, 2006
It's unfortunate that they cannot or will not recognize that the kits could be significantly improved and the need for factory support minimized with a little attention to their documents. Charlie, I understand where you're coming from. It has been a few years since Van himself decided to make the company employee owned. Maybe now it's a Job/Owner Security issue. ;-) Darrell Reiley RV7A "Reiley Rocket" N622DR Reserved CenTex_RV_Aircraft-owner(at)yahoogroups.com __________________________________________________ ________________________________________________________________________________
Date: Aug 27, 2006
That's called "Job Security" Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Darrell Reiley Sent: Sunday, August 27, 2006 9:48 PM Subject: Re: RV-List: Rant, question, suggestion: errors in plans/drawings It's unfortunate that they cannot or will not recognize that the kits could be significantly improved and the need for factory support minimized with a little attention to their documents. Charlie, I understand where you're coming from. It has been a few years since Van himself decided to make the company employee owned. Maybe now it's a Job/Owner Security issue. ;-) Darrell Reiley RV7A "Reiley Rocket" N622DR Reserved CenTex_RV_Aircraft-owner(at)yahoogroups.com __________________________________________________ ________________________________________________________________________________
Subject: tire wear
Date: Aug 27, 2006
Well, the last time I made a suggestion on this topic it took about two weeks for the flaming to stop. But they wear primarily for three reasons. Camber, the tire isn't vertically straight Toe, the tire isn't pointed straight ahead and aft, parallel to the AC centerline. Big foot, the brakes are on during take offs, landings and taxi operations Sans a big foot, toe will wear the tires rapidly if more than one deg. Test is to rub across the grooves with a finger, if feathered and sharp on one side of groove and rounded on the other side of groove then side scrubbing is happening. Direction of scrubbing is from feather edge towards rounded edge. Fix is to rotate gear in socket for tapered rod type, the others can be shimmed at stub axel. Because of aft rake of tapered rod gear rotating in socket will change both camber and toe. But fixing toe is most important as it scrubs tire on one side usually, rather than wearing it at a camber angle. Since most wear comes from ground ops set toe with AC in that attitude and common weight. As well most landing are close to three point landings anyways. Project line of sight off wheel rim 100 inches out and measure to centerline close to wheel and at 100 inches. Both should be same. At 100 inches out one degree = 1.75 inches roughly so get fore and aft tire parallelism with centerline inside of that value. Camber - not much you can do about it on an RV as weight changes too much, too often. Get 'em both the same if you have the stub axel design (-8) I generally get about 350-400 hours out of a set of tires if I don't pop 'em on those damm goat head thorns and rotate 'em once. W And PS, leak stop tubes rock. ________________________________________________________________________________
Subject: Davd Clark X-11 headset review?
Date: Aug 28, 2006
Hello listers, The David Clark Co. Inc. website offers what apears to be a new headset called X 11. The promo on the website looks good I have not heard or found any other reports pro or can about this product. Would anyone care to offer opinions based on actual use? Jim in Kelowna - final inspection soon ________________________________________________________________________________
Date: Aug 28, 2006
Why would you want to do this if the mag has the impulse coupling? You might as well use an non IC mag for that. Does the electronic ign have an option for retard timing? ----- Original Message ----- From: "Bruce Gray" <Bruce(at)glasair.org> Sent: Sunday, August 27, 2006 5:35 PM Subject: RE: RV-List: Kick Back - More Info > > No, you want to start the engine with the EI ON and the mag OFF. > > Bruce > www.glasair.org > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Garry > Sent: Sunday, August 27, 2006 2:05 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Kick Back - More Info > > > I'm very close to wiring my plane and would like to know how to wire the > ignition key switch. I have an AeroSport IO360 with one "mag", and one > Lightspeed Electronic Ignition. It seems that the forum is suggesting > that > I wire the key switch so that in the "start" position only the Mag is > firing, but upon releasing the key switch from start to both, that then > both > > the mag and the Lightspeed are firing. Is this correct? > > Garry Stout > RV7A Odessa Fl > > ----- Original Message ----- > From: "Jeff Point" <jpoint(at)mindspring.com> > To: > Sent: Sunday, August 27, 2006 1:29 PM > Subject: Re: RV-List: Kick Back - More Info > > >> >> rveighta wrote: >> >>>Sound like a impulse coupler problem? >>> >> No, it sounds like the non-impulse coupled mag is firing before TDC (like >> it should) during starting. The purpose of the IC is to slow the mag >> down > >> so it fires right at TDC during the starting process. When the engine is >> running, there is enough speed and inertia that firing at 28 BTDC is >> desireable. Duirng starting, when the engine is running so slowly, if >> the > >> non-IC mag fires at 28 BDTC, it is likely to cause a kickback. >> >> Try leaving the non-IC mag off during starting. If you have a keyswitch, >> make sure it's wired properly to ground (turn off) the non-IC mag at the >> START position. >> >> Jeff Point >> >>> >>> >>> >>> >>> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 28, 2006
Well said, Paul. My sentiments exactly. Now for an anecdote... About a year and a half ago, my EAA chapter held a sheet metal assembly workshop using the old Van's flap project. Before the workshop, all of us "instructors" got together to put one of the projects together to familiarize ourselves with it so we wouldn't make fools of ourselves when we actually went to teach it. Good thing, too. During this familiarization, I found at least three problems with the one-page instruction/drawing sheet that came with the project! One was a nutplate part number callout where the drawing disagreed with the instructions, the other showed one of the end ribs facing the wrong way and finally, a couple of steps in the instructions were out of sequence. I could have sworn Van did this intentionally. It must be his way of preparing us for all the problems we would encounter with the real plans. Seeing this, I suggested to my fellow instructors that we begin the workshop by having the students take a half-hour to read ahead, just like Van's suggests in the real plans, to see who could spot the three problems and that we award a door prize to the winner(s). They didn't take my suggestion either. :-( Jack Fromm RV-8 81120 Flying > > In general, I think that Van's has designed excellent aircraft and their > kits are great. But in some respects the instructions could be a little > better. Yes, we should be able to extrapolate from the drawings and > instructions to figure out what we should be doing, but when there are > specific instructions or drawings for an operation, we should be able to > rely on them. It is not that the instructions need to be expanded, it is > that those that are there should be correct. Any incorrect or contradictory > instructions should be fixed. This is not hard, as I'm sure that Van's has > been apprised of the errors by many people. Also, we should not have to > worry about following the instructions and doing something only to find out > later that something else should have been done first. Reading ahead in the > instructions is a good idea, but they should be in the proper order anyway. > I'm having a great time building my 8, but sometimes it is frustrating > trying to figure out what to do when the instructions and drawing are > unclear or contradict each other. > > The instructions that are provided, at whatever level of detail that Van's > feels are necessary, should be accurate. It would take very little effort > to create a section on their website with corrections to the instructions > and drawings. For anything beyond that, I feel that these forums and email > lists are a great resource. > > Paul Trotter > RV-8 82080 Fuselage Kit ________________________________________________________________________________
Date: Aug 28, 2006
All EI systems I've seen have a retard mechanism for starting. One of the main benefits of an EI is it's supposed ease of starting. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Reiche Sent: Monday, August 28, 2006 4:43 AM Subject: Re: RV-List: Kick Back - More Info Why would you want to do this if the mag has the impulse coupling? You might as well use an non IC mag for that. Does the electronic ign have an option for retard timing? ----- Original Message ----- From: "Bruce Gray" <Bruce(at)glasair.org> Sent: Sunday, August 27, 2006 5:35 PM Subject: RE: RV-List: Kick Back - More Info > > No, you want to start the engine with the EI ON and the mag OFF. > > Bruce > www.glasair.org > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Garry > Sent: Sunday, August 27, 2006 2:05 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Kick Back - More Info > > > I'm very close to wiring my plane and would like to know how to wire the > ignition key switch. I have an AeroSport IO360 with one "mag", and one > Lightspeed Electronic Ignition. It seems that the forum is suggesting > that > I wire the key switch so that in the "start" position only the Mag is > firing, but upon releasing the key switch from start to both, that then > both > > the mag and the Lightspeed are firing. Is this correct? > > Garry Stout > RV7A Odessa Fl > > ----- Original Message ----- > From: "Jeff Point" <jpoint(at)mindspring.com> > To: > Sent: Sunday, August 27, 2006 1:29 PM > Subject: Re: RV-List: Kick Back - More Info > > >> >> rveighta wrote: >> >>>Sound like a impulse coupler problem? >>> >> No, it sounds like the non-impulse coupled mag is firing before TDC (like >> it should) during starting. The purpose of the IC is to slow the mag >> down > >> so it fires right at TDC during the starting process. When the engine is >> running, there is enough speed and inertia that firing at 28 BTDC is >> desireable. Duirng starting, when the engine is running so slowly, if >> the > >> non-IC mag fires at 28 BDTC, it is likely to cause a kickback. >> >> Try leaving the non-IC mag off during starting. If you have a keyswitch, >> make sure it's wired properly to ground (turn off) the non-IC mag at the >> START position. >> >> Jeff Point >> >>> >>> >>> >>> >>> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 28, 2006
When I reweighed my 8A, I drained the fuel tanks by pumping fuel into cans through a hose connected in place of the carb fuel inlet using the auxiliary electric fuel pump. This insured the correct amount of unusable fuel remained in the tanks and eliminated the uncertainty over exactly how much fuel was in the tanks. If I was off by 1 gallon, 6lb, that would translate into a moment of 480 for a CG position error of +/- 6 tenths of a percent in CG location given the empty moment of my airplane, 84575. Not a very big error as errors go. Still, it made me uncomfortable enough that I took the slightly harder route of emptying the tanks. There were two additional benefits to this approach: I could calibrate a dip stick for measuring usable fuel by refilling the empty tanks in two gallon increments, and, by raising the gas can above the fuel tank level, I could look at my see through fuel filter during the pump out operation to see if the fuel system was sucking any air. Dave Reel - RV8A ________________________________________________________________________________
Date: Aug 28, 2006
An excellent tip. Thank you. Such sharing of good building tips is becoming very rare on this list, so forgive me for further clogging it. No not archive. Denis Walsh On Aug 28, 2006, at 07:49 281700008, DAVID REEL wrote: > > When I reweighed my 8A, I drained the fuel tanks by pumping fuel > into cans > through a hose connected in place of the carb fuel inlet using the > auxiliary > electric fuel pump. This insured the correct amount of unusable fuel > remained in the tanks and eliminated the uncertainty over exactly > how much > fuel was in the tanks. If I was off by 1 gallon, 6lb, that would > translate > into a moment of 480 for a CG position error of +/- 6 tenths of a > percent in > CG location given the empty moment of my airplane, 84575. Not a > very big > error as errors go. Still, it made me uncomfortable enough that I > took the > slightly harder route of emptying the tanks. > > There were two additional benefits to this approach: I could > calibrate a > dip stick for measuring usable fuel by refilling the empty tanks in > two > gallon increments, and, by raising the gas can above the fuel tank > level, I > could look at my see through fuel filter during the pump out > operation to > see if the fuel system was sucking any air. > > Dave Reel - RV8A > > ________________________________________________________________________________
Subject: intersection fairings...
Date: Aug 28, 2006
Hey all... I bought a set of intersection fairings from Fairings, Etc., and am looking for ideas on how to attach them at the top... I think I am going to make the fairings part of the gear leg fairing at the top and attach it to the fuse, and make the lower fairings part of the wheel pants... Any suggestions and photos would be greatly appreciated... Thanks! -Bill ________________________________________________________________________________
Date: Aug 28, 2006
Subject: Re: intersection fairings...
Hi Bill! I also bought a set of upper and lower intersection fairings for my 8, but had to EXTENSIVELY modify them for proper fit. The lower fairings are attached (epoxy/micro bonded) to the pants. The upper fairings fit snugly over the gear leg fairing and are attached to my fuselage with two nut plates fwd and one rivnut on the aft. They are quite solid. I'm not sure if this will work for an 8A, but if you'd like I'll take some photos and send them to you. John D'Onofrio N585JD (_Tailgummer(at)aol.com_ (mailto:Tailgummer(at)aol.com) ) ________________________________________________________________________________
Date: Aug 28, 2006
Bill, Don't remember which aircraft you have. Do you have the two piece aluminum gear leg fairings or the one piece fiberglas? I have the one piece fiberglass main gear leg fairing on 6A. The main gear top intersection fairings are attached to the fuse at the top and not attached to the gear leg fairing. There is considerable movement between the gear leg fairing and the top intersection fairing when the main gear flexes. Same is true for the bottom. Need to keep some movement possible. Dale Ensing ----- Original Message ----- From: Bill VonDane To: rv-list(at)matronics.com Sent: Monday, August 28, 2006 10:24 AM Subject: RV-List: intersection fairings... Hey all... I bought a set of intersection fairings from Fairings, Etc., and am looking for ideas on how to attach them at the top... I think I am going to make the fairings part of the gear leg fairing at the top and attach it to the fuse, and make the lower fairings part of the wheel pants... Any suggestions and photos would be greatly appreciated... Thanks! -Bill ________________________________________________________________________________
Date: Aug 28, 2006
sorry, i have an rv-8a ----- Original Message ----- From: Bill VonDane Sent: Monday, August 28, 2006 8:24 AM Subject: RV-List: intersection fairings... Hey all... I bought a set of intersection fairings from Fairings, Etc., and am looking for ideas on how to attach them at the top... I think I am going to make the fairings part of the gear leg fairing at the top and attach it to the fuse, and make the lower fairings part of the wheel pants... Any suggestions and photos would be greatly appreciated... Thanks! -Bill ________________________________________________________________________________
Date: Aug 28, 2006
At the risk of bringing some maturity (g) to the discussion, I think it's important to recognize that everyone is different and one size doesn't necessarily fit all. We all learn differently. We all interpret differently. There is no "right" way or "wrong" way. There's only a different way and if we're smart enough to build airplanes, aren't we smart enough to stay clear of pointless debate about the people doing the learning? It's true that the folks who built off the plans were real good builders, but a plans-only model wouldn't have kept Van's in business because few people actually could do that. On the other side of the coin, this is a friggin' big airplane, not a Lego kit. Under the 51% rule, we're supposed to get educated. It's just that sometimes the process of education collides head-on with the recreation part. The other thing to remember is that the instructions/plans method was deployed before something like builders groups on the Internet came along and, frankly, sites like Dan Checkoway's are becoming the defacto instruction manual for a lot of people who like to SEE stuff put together. Then you have the Orndorff videos. And this list, and other lists, and newsletters. When you really think about it, building for many people is not "I built just off the plans," it's "I built off the plans, the manual, the Web sites, the videos, and the user groups." Debating whether people should just build off the plans is a moot point except for those who just want to have a good online feud. Even Van's recognizes they shouldn't or else they wouldn't have taken such a huge step forward with the RV-10 plans. How did they get to that improvement? Someone must've pointed out that there was a better way. Good for them. Good for us. I'm guessing they also did it without characterizing the company as inordinately inferior. So just one more plea before I have to start setting up another stinkin' Rules Wizard on Outlook: If we could just bend over backwards to consider other obvious improvements that could be made in this process without giving in to the temptation to use the thread for another worthless "I'm better than you are" stage, that'd go a long way toward making this week's building process even better at my house. -------- Bob Collins St. Paul, Minn. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=58009#58009 ________________________________________________________________________________
Date: Aug 28, 2006
At 08:24 AM 8/28/2006, you wrote: >Hey all... I bought a set of intersection fairings from Fairings, Etc., >and am looking for ideas on how to attach them at the top... > >I think I am going to make the fairings part of the gear leg fairing at >the top and attach it to the fuse, and make the lower fairings part of the >wheel pants... You have beaucoup resources at 00V Bill. I suspect that if you attach the upper fairings at two points then gear leg movement may cause something to crack (fiberglass part). The lower attachment method I believe was done by Wolfie next door to where you used to hanger your airplane. Ron Lee ________________________________________________________________________________
Date: Aug 28, 2006
> It sounds like there are errors that should and could be > corrected. I just found one. The bolt callout (3-10A) for connecting the pushrod between the two control yokes is too short. That strikes me as kind of an important connection, and there's not enough threads to get threadlocker on there, or even the torque seal goop. Change to 3-11A. Might also be the case for the bolt connecting the aileron pushrods to the stick. I've added it to the database. ________________________________________________________________________________
Date: Aug 28, 2006
OH, I should have mentioned that this applies for those using manual aileron trim. That steel tab that connects the spring and the yoke adds the thickness that makes the 10A too short. > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Collins > Sent: Monday, August 28, 2006 1:20 PM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Re: Rant, question, suggestion: errors in > > > > > > It sounds like there are errors that should and could be > > corrected. > > I just found one. The bolt callout (3-10A) for connecting the > pushrod between the two control yokes is too short. That > strikes me as kind of an important connection, and there's > not enough threads to get threadlocker on there, or even the > torque seal goop. Change to 3-11A. Might also be the case > for the bolt connecting the aileron pushrods to the stick. > I've added it to the database. > ________________________________________________________________________________
Subject: First Flight N95BF
Date: Aug 28, 2006
Hi, Well after almost 6 years of building another RV has flown and returned to earth safely. The first flight of my RV-9A occurred last Friday night about 6 pm lasted a hour. The flight was nearly perfect, except I landed slightly on the brakes, which seem to be working quite well. Anyway, for the record I wanted to say how valuable I found transition training to be. I did transition training with Dan Cunningham in Decatur Alabama in his RV-9A. First off Dan was great. I had to get 5 hours for insurance but only had one day to fly. Dan really worked hard to make sure I got all the time I needed, which involved taking several breaks and going for a nice lunch. I was pretty tired after that big day of flying, but what a difference it made in my ability to handle the airplane. When I took off on the first flight of my plane the training proved invaluable. At no point during the first flight did I have to question my ability to land b/c I had already landed Dan's plane a bunch of times. The pressure was completely off. I thought the first flight would be shear terror, but it wasn't. About 2 seconds after the plane lifted off the ground and was clearly controllable the rest of the flight was a pure joy. I really do contribute this to training, having experience in the type was everything for me. Before the first flight I reasoned that if the plane would perform flawlessly on the first flight I could probably take the flight w/o transition training. You know spend time feeling it out, slowly finding the stall buffet, estimating an approach speed and what not. As it turns out the first flight was flawless, and I did get to the stall buffet and found that the numbers were exactly the same as Dan's plane. So I knew all the information I needed before I even took off. That was very reassuring, but in the case of an emergency it would have been invaluable. If everything hadn't gone exactly perfect it occurs to me that I would not only had an idea of the emergency procedures but actually had done them. Again training with Dan was probably one of the best decisions I made during the whole project. I would highly recommend Dan Cunningham's training, especially if you have an RV-9A and want to get time in the model. Dectaur Alabama is a nice town, the airport is nice and clean (and long), the people are friendly (the airport dog even more friendly), and not that long of a drive or a flight from anyplace when you consider how close it is to Huntsville. Anyway thanks Dan! And good luck to all of you in RV land. Bryan Flood N95BF (0.6 hours) ________________________________________________________________________________
Subject: Anyone have anymore information about this?
Date: Aug 28, 2006
2 killed in Sonoma County plane crash http://www.sfgate.com/cgi-bin/article.cgi?f=/c/a/2006/08/28/ BAGR8KQNVS4.DTL tw ________________________________________________________________________________
Date: Aug 28, 2006
It seems that everyone on the list has replied, so why should I be any different? As a person who strives to swim downstream, and not upstream, I learned early from Van's when most of their advice to my questions was "to just make it work." Sort of like if the small hammer doesn't work, use a slightly bigger one. Somewhere during the wing construction, I began to use Van's instructions and plans as a general guidelines. You could say that my RV is not built to the plans. But as many of you are finding out, few if any RVs are or can be built to the exact specifications on the plans. I remember on one of the promotional videos for the RVs of some disgruntled builder running outside of the workshop with a part, throwing it on the ground and then jumping up and down on it. I think someone at Vans has a sense of humor, or at least understands that building an RV is not an exact science step by step and paint by the numbers process. I am one of the last people on earth to defend Vans Aircraft. I just offer my opinions to help others overcome the extreme frustration that we all get caught up in (some will not admit it). Take a week off, come back refreshed and relook the problem, and the answer will be forthcoming! You might not like the obvious answer, but that is part of homebuilding, you have to take the good with the bad, or you will be forced to abandon you project! BTW the kit with the most comprehensive instructions that I have heard of was the Christen Eagle. At the time I built my RV, the RV kit cost about $11,000 and the Eagle kit was $50,000. Would you rather pay Van the extra $39,000 or do it yourself? Bob ________________________________________________________________________________
Date: Aug 28, 2006
Subject: Re: Anyone have anymore information about this?
I just saw a second report on KRON-TV (Channel 4 out of SF), and they showed some video footage of the wreckage. The tail was visible - white with blue and red stripes across the top of the vertical stab. The first anchor called it a "homemade plane." The report also said the pilot was trying to land on Hwy 101. Not much else in the report - I'll post more if I hear it. My condolences... Terry Williams wrote: > 2 killed in Sonoma County plane crash > > http://www.sfgate.com/cgi-bin/article.cgi?f=/c/a/2006/08/28/BAGR8KQNVS4.DTL > > tw > > ________________________________________________________________________________
Date: Aug 28, 2006
I know nothing about the crash, but it would be nice if the person who wrote the article knew what they were talking about...! Darrell --- Terry Williams <7ecapilot(at)comcast.net> wrote: > 2 killed in Sonoma County plane crash > > http://www.sfgate.com/cgi-bin/article.cgi?f=/c/a/2006/08/28/ > > BAGR8KQNVS4.DTL > > tw __________________________________________________ ________________________________________________________________________________
Subject: RV6 down in Petaluma
Date: Aug 28, 2006
Sad news about a couple guys in a RV-6 up in Petaluma today. Anybody know anything? <http://www.sfgate.com/cgi-bin/article.cgi?f=/c/a/2006/08/28/BAGR8KQNVS4.DTL > http://www.sfgate.com/cgi-bin/article.cgi?f=/c/a/2006/08/28/BAGR8KQNVS4.DTL Parker Thomas RV-6A 421PT ________________________________________________________________________________
Date: Aug 28, 2006
FYI...I had an electroair ignition and had problems with Kickback, and the subsequent owner did as well...even chipped teeth on the ring gear...could have been the ignition, but not sure...I seem to remember that you started it on the EI, but didn't turn on the advance function until start, but that was 5 years ago, and am not 100% sure. Paul Besing Bruce Gray wrote: All EI systems I've seen have a retard mechanism for starting. One of the main benefits of an EI is it's supposed ease of starting. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Reiche Sent: Monday, August 28, 2006 4:43 AM Subject: Re: RV-List: Kick Back - More Info Why would you want to do this if the mag has the impulse coupling? You might as well use an non IC mag for that. Does the electronic ign have an option for retard timing? ----- Original Message ----- From: "Bruce Gray" Sent: Sunday, August 27, 2006 5:35 PM Subject: RE: RV-List: Kick Back - More Info > > No, you want to start the engine with the EI ON and the mag OFF. > > Bruce > www.glasair.org > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Garry > Sent: Sunday, August 27, 2006 2:05 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Kick Back - More Info > > > I'm very close to wiring my plane and would like to know how to wire the > ignition key switch. I have an AeroSport IO360 with one "mag", and one > Lightspeed Electronic Ignition. It seems that the forum is suggesting > that > I wire the key switch so that in the "start" position only the Mag is > firing, but upon releasing the key switch from start to both, that then > both > > the mag and the Lightspeed are firing. Is this correct? > > Garry Stout > RV7A Odessa Fl > > ----- Original Message ----- > From: "Jeff Point" > To: > Sent: Sunday, August 27, 2006 1:29 PM > Subject: Re: RV-List: Kick Back - More Info > > >> >> rveighta wrote: >> >>>Sound like a impulse coupler problem? >>> >> No, it sounds like the non-impulse coupled mag is firing before TDC (like >> it should) during starting. The purpose of the IC is to slow the mag >> down > >> so it fires right at TDC during the starting process. When the engine is >> running, there is enough speed and inertia that firing at 28 BTDC is >> desireable. Duirng starting, when the engine is running so slowly, if >> the > >> non-IC mag fires at 28 BDTC, it is likely to cause a kickback. >> >> Try leaving the non-IC mag off during starting. If you have a keyswitch, >> make sure it's wired properly to ground (turn off) the non-IC mag at the >> START position. >> >> Jeff Point >> >>> >>> >>> >>> >>> >> >> >> >> >> > > > --------------------------------- Everyone is raving about the all-new Yahoo! Mail. ________________________________________________________________________________
Date: Aug 28, 2006
Subject: Re: RV6 down in Petaluma
On 20:16:50 2006-08-28 Paul Besing wrote: > "Home-built planes, often referred to as "experimental aircraft," > are inspected by an FAA examiner who looks at the bolts, rivets and > mechanical parts of the craft before the metal skin is installed. If it > passes, the pilot is restricted to flying alone, and over unpopulated > areas, for a period of time, Gregor said, and must pass an annual > inspection." > > Last I checked, the FAA examiner (or DAR if it happens to be) > doesn't check the craft before the metal skin is installed. We all here know that, but to the general public it's a largely irrelevant detail. I commend the reporter in question for at least communicating that homebuilt aircraft are inspected by a regulatory body when they're built, and are inspected regularly when they're flying. That's a lot better than leaving it as "so and so died in a homemade plane". At least this time it doesn't sound like some yahoo who slapped together an engine and some planks of wood and went out trying to fly. -Rob ________________________________________________________________________________
Date: Aug 28, 2006
Here is a copy of a letter I wrote in 1999 while building my RV-8. Doesn't sound like things have changed much, Too bad. The plans are useable, but........... > > Take a look at the plans that Frank Christen had for the Christen Eagle II > twenty years ago. Outstanding!!! A manual for every kit, subdivided with a > general description of what the task is, description of new skills, an > accurate list of parts needed on the next section, tools needed and > preaddressed cards to report back any errors or questions. Isometric > pictures on every page. Change letters on every page, upgrades sent until > you are done with that area. Small parts packaged in plastic boxes with the > part number for each part depicted in the lid of the box when you flipped > the it open. > > Van's plans are useable but they could be much better. I think I learned > just as much building the Eagle without all the guess work and wandering > around the garage trying to figure out what Van meant. You still have to do > the work and use the tools, you just know that what you are doing is RIGHT. Rich Crosley RV-8, N948RC 175 hours ________________________________________________________________________________
Date: Aug 29, 2006
What does a Cristen Eagle kit cost? Are these Kits even made any more? But there where mistakes right? I would just have to say build what you like. It's a challenge to build, and if it was easy everyone would do it. Sad truth, rarely said is not everyone can build a plane no matter how much desire they have, for one reason or another. You make good observations and the Van's "system" could be better, but it's still a fairly easy to build kit even comparied to the C-Eagle, which was no walk in the park, even with the great instructions. Cheers George M. RV-4, RV-7 >From: "Richard Crosley" <rcrosley(at)adelphia.net> > >Here is a copy of a letter I wrote in 1999 while building my RV-8. >Doesn't sound like things have changed much, Too bad. > >The plans are usable, but........... > > Take a look at the plans that Frank Christen had for the Christen >Eagle II > twenty years ago. Outstanding!!! A manual for every kit, subdivided >with a general description of what the task is, description of new skills, >an accurate list of parts needed on the next section, tools needed and > preaddressed cards to report back any errors or questions. Isometric > pictures on every page. Change letters on every page, upgrades sent >until you are done with that area. Small parts packaged in plastic boxes >with the part number for each part depicted in the lid of the box when you >flipped the it open........................... >Rich Crosley >RV-8, N948RC --------------------------------- Get on board. You're invited to try the new Yahoo! Mail. ________________________________________________________________________________
Subject: Re: Day 2 Trio Avionics Autopilot Install
Date: Aug 29, 2006
Hiya Dana, One thing I would sugest is that you should have rivited the hanger and bolt or screwed the module, you will have to take it out. I have had mine out 3 times, this time to be exchanged. Charles heathco ________________________________________________________________________________
Date: Aug 29, 2006
n223rv(at)wolflakeairport wrote: > .........If you think Van's plans need improvement on their prints, build an RV-4.... The RV-10 has best in class instructions. If you have an issue with them, maybe another hobby would be better............ Some time ago, a seasoned airline pilot with a wry wit observed that the airline travel experience was being rapidly reduced to just two classes of flyers.......First Class and Third World. As Van's kits and plans increasingly improve, the process has been democratized to the point that a whole new class of builder has emerged. Because of the advanced nature of todays kits, it is now possible to attract the masses. For the first time in history, it is possible for the marginally skilled (and that includes builders who have assembled nothing more complicated than a propane barbeque grill from Lowes or Home Depot), the impatient citizen long accustomed to instant gratification and his cousin....the first time builder and vocal critic who cannot adapt generally well written plans and callouts to a particular building situation. Such are the realities of an efficient marketplace. A place at the table for everyone. I'll go even further than that. I say a prepunched Quickbuild kit is to homebuilt aircraft construction what a Betty Crocker Warm Delights Molten Chocolate cake mix is to the culinary arts. It is generally conceded the devils food treat can be loosely described as cake but demanding purists with a discerning palate would naturally chafe at the notion and the chef a natural impulse to suggest a Herculean effort and superior cooking skill to produce a confection demanding little more than cup water and 1 minute, 45 seconds in the microwave. [Rolling Eyes] Rick Galati RV-6A "Darla" (standard kit) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=58209#58209 ________________________________________________________________________________
Subject: Re: Rant, question, suggestion: errors in
Date: Aug 29, 2006
I just want to put in that I think Vans is excellent. It's the frickin builder, being myself in this case. I'm the one that forgets to do something, or I cut something wrong, I get ahead of myself. Personally, I don't know how the average person can do these kits, that's probably why so many people join these groups, because they are pretty complicated. Myself, I hardly use the manual, I just look at the blueprints and just throw it together so to speak. When I have a problem then I go to the manual, but that still leaves me a little baffled, so then I come here and read a little, then I go to the different web sites and then I go look for an RV at the airport, to look at it. Myself I've built many remote control airplanes in the past. I've always been able to use my hands and put things together, well I do have a transmission shop and build todays transmissions and do the computer systems and electronics. So this gives me a real big boost for building the RV. I love this stuff, I call it my big erector set. Which was my most favorite toy when I was a kid, you couldn't get me away from it. I just love the prepunched holes, but I think most people are putting to much work into these kits. I personally just go through and drill out all the holes to the proper size, then I put them together, forget about match hole drilling, I feel that when you do that, you stand a chance of changing the alignments, just drill them real quick seperately then put them together. Like I said, when I do this and put them together I then check the alignments and there right on. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=58210#58210 ________________________________________________________________________________
Date: Aug 29, 2006
Yes, that's definately a good point, and the fact that his facts were not straight is definately a plus in our column...we just got lucky that the error was in our favor...too often they make errors without checking facts, and unfortunately there is a negative spin on them. Yeah, couldn't you imagine that if he wrote "Ironically, the airplane was built in someone's garage from a mail order kit" or something like that. Paul Besing "Rob Prior (rv7)" wrote: On 20:16:50 2006-08-28 Paul Besing wrote: > "Home-built planes, often referred to as "experimental aircraft," > are inspected by an FAA examiner who looks at the bolts, rivets and > mechanical parts of the craft before the metal skin is installed. If it > passes, the pilot is restricted to flying alone, and over unpopulated > areas, for a period of time, Gregor said, and must pass an annual > inspection." > > Last I checked, the FAA examiner (or DAR if it happens to be) > doesn't check the craft before the metal skin is installed. We all here know that, but to the general public it's a largely irrelevant detail. I commend the reporter in question for at least communicating that homebuilt aircraft are inspected by a regulatory body when they're built, and are inspected regularly when they're flying. That's a lot better than leaving it as "so and so died in a homemade plane". At least this time it doesn't sound like some yahoo who slapped together an engine and some planks of wood and went out trying to fly. -Rob --------------------------------- ________________________________________________________________________________
Subject: Van's Wheel Fairings
Date: Aug 29, 2006
I am replacing (finally!) my original, old style wheel fairings, for Van's "new" Pressure Recovery fairings. Any ideas on what works best for a minimal tire-to-faring clearance around the lower opening? Thanks, Derrick L. Aubuchon RV-4: N184DA (450+ hrs) Jackson/Westover -Amador County (O70) n184da(at)volcano.net ________________________________________________________________________________
Date: Aug 29, 2006
Subject: Re: Engine Kick-Back IO-360
> >Interesting! I worked in ignition system design for GM for 15 years. We >always had to meet a 4.5 volt, 30 RPM cranking test. Yes, a low battery >on a GM car can dip to 4.5 volts and the ignition system has to stay in >sync and deliver a spark. It seems to me like a design defect, and LSE >should do the fix for no charge. This is not just a problem with LSE but with magnetos as well. I had the same problem with slick magnetos, my fix, was to go with a 25 year old prestolite starter. It works great and only cost me $150. It cost me more to fix the SkyTec starter the first time, the second time I did not fix it! It seems that this is more a problem with SkyTec and they should fix the problem, of course they told me my magnetos were not timed properly and that was the reason for the kickbacks! I do not like their product, but their management is very innovative on reasons why it is not their fault that their starter does not work. Bob ________________________________________________________________________________
Date: Aug 29, 2006
>I don't even know why you would > waste time looking up what length bolt was called out, just > find a bolt > that fits and use it. Well, I'm probably a little anal in this area but I like to make sure all of the parts that the designers want in a connection of any importance are installed on the plane. So I actually use the plans more than the instructions because I like to make sure the waashers are where they're supposed to be around rod end bearings etc (I actually, just an aside, am kind of surprised when I look at a number of builders who graciously put their work online, how many rod end bearings are not surrounded by washers. And as a further aside, let me point out the value of -- of at least to me -- of the online log that pointed out the value of surrounding the TruTrak installation with washeres). Anyway, as long as I'm using the plans, it's easier to look at the bolt callout, grab it out of the right bin and install it. Now, it's true, you could just grab a couple of bolts and put one in until one fits properly. But in my case, theat probably wouldn't work. Why? Because I installed those bolts in that control column the other night and put the nutstops on and never noticed it didn't fit until I was disassembling it the other day. Your point on the plans production difficulty is taken which is why I value these lists and databses so much because I CAN make the changes really quick when people find them. I just take a pen, scratch ut what's on the plans and write down the correct part, number, or process. Simple. I've REALLY enjoyed BUILDING the plane so far and if it's half as much fun to fly as it is to build ...well... Great. But I'm a different person than when I started. All my life, my family called me the "Scotch tape kid," because when something wasn't quite right, I'd just Scotch tape it until it was. My dad's fixes were legendary for their -- ummm -- quirkiness and inconsistency of results. That was me. However, since I started building 5 years ago, I answer to "me" now. I want to do things perfectly and though perfection is often not achievable, approaching tasks with that goal is what I like. I go slow and if *I'm* not satisfied, I redo it or do it until I *am* satisfied. I'm the quality control guy on my plane; not the guy at the other end of the phone or the person that laughs at my question or the people who might ridicule me on a bulletin board for not being just like him. Look, sure we'd like the plans to be as good as they can be. But Van's isn't building my plane. I'm building my plane and one of the things you learn in the constructin process is that sometimes the plans are inefficient, and the instructions are in ther ight order and you have to check and doublecheck if you're of that mind to do so. I think questioning and double-checking is a good thing and I think it leads to good habits in every other facet of flying. It's no different, it seems to me, than checking your fuel tank after the line guy has filled it up to be sure that it's full of 100LL and not JetA. So I think in the end we have to live with what we have. But I also think we should accept that everyone is -- as I said before -- different. Brains work differently. Rather than spend endless time characterizing people as being one way or the other -- a completely fruitless exercise in the grand scheme of things -- let's just redouble our efforts to provide information that can help our fellow builders. Let's offer constructive advice and support. Van's is one of the quirkiest companies I've ever dealt with. Heck of a plane, no doubt about it. They're not going to suddenly change their ways any more than I am going to go back to being the Scotch tape kid. We are what we are. Bob RV Builder's Hotline http://home.comcast.net/~rvnewsletter/ ________________________________________________________________________________
Date: Aug 29, 2006
Subject: Re: Engine mount out of spec
In a message dated 8/29/06 10:16:28 AM Eastern Daylight Time, Hopperdhh(at)aol.com writes: > I called Van's to see if perhaps I was sent the wrong mount. I was told > that this spec on the mounts was +/- 1/16 inch, and there must be something > else causing the problem. Since I am using the same everything else, I can't > see what else it could be. With the engine mounted and 2 weeks of connecting > up everything already done, I am stuck. ================================= Dan: Before you go through all that work, I would check one thing ... Check to see if you have the thrust washers on in the correct order and correct location. I have more info but first I need to know which engine and who's vibration mounts? They wouldn't happen to be Lord? Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Subject: Re: Attaching floors with nutplates.
Date: Aug 29, 2006
Jeff I agree with you on using only torx screws and also with Charley on using only 8-32 screws. I am installing the seat and baggage floors, the baggage bulkheads, and the baggage side covers almost totally with SS 100 degree flush 6 lobe 8-32 machine screws. In a small number of locations that will not accept flush screws/nutplates, I am using SS button head 6 lobe 8-32 screws. These screws are available from Micro Fasteners ( microfasteners.com ) ( 800-892-6917 ) Lebanon, NJ. They use a standard Torx T-15 driver. Dean Van Winkle RV-9A Fuselage/ Finish/ Engine ----- Original Message ----- From: Jeff Dowling To: rv-list(at)matronics.com Sent: Thursday, August 24, 2006 4:45 PM Subject: Re: RV-List: Attaching floors with nutplates. I would consider using torx screws . I hate removing those #8 phillip heads. Same with the seat panels and baggage panels. Shemp/Jeff Dowling RV-6A, N915JD 295 hours Chicago/Louisville ----- Original Message ----- From: Steve Sampson To: rv-list Sent: Thursday, August 24, 2006 12:35 PM Subject: RV-List: Attaching floors with nutplates. Is it OK to substitute nutplanes and #6 screws for LP4-3 rivets when installing the floors? Thanks, Steve. RV4 #4478 com/Navigator?RV-List ------------------------------------------------------------------------- ------- Try SPAMfighter for free now! ________________________________________________________________________________
Date: Aug 29, 2006
Bob Collins wrote: > >> I don't even know why you would >> waste time looking up what length bolt was called out, just >> find a bolt >> that fits and use it. > > Well, I'm probably a little anal in this area but I like to make sure all of > the parts that the designers want in a connection of any importance are > installed on the plane. So I actually use the plans more than the > instructions because I like to make sure the waashers are where they're > supposed to be around rod end bearings etc (I actually, just an aside, am > kind of surprised when I look at a number of builders who graciously put > their work online, how many rod end bearings are not surrounded by washers. > And as a further aside, let me point out the value of -- of at least to me > -- of the online log that pointed out the value of surrounding the TruTrak > installation with washeres). A HIGHLY recommended option for all builders, especially those with no previous aircraft experience, is to put the following publication in your shop and refer to it any time you are flummoxed about anything construction related: http://www.buildersbooks.com/4313.htm A quick look at AC 43.13, Acceptable Methods of Aircraft Repair, can tell you how to properly install bolts, utilize washers, torque fasteners, install safety wiring, etc, etc, etc and will prevent you from calling Vans and asking questions that make it sound like you are clueless concerning aircraft construction. It's true Vans is the manufacturer of the kit and has some responsibility therein, but that doesn't remove our obligations as builders to educate ourselves as much as possible about this endeavor we have undertaken. Sam Buchanan ________________________________________________________________________________
Date: Aug 29, 2006
Lordy, Lordy, Rick, I hope you know what a can of worms you have kicked over on the rug...Em, Em, Em. Charlie Ennis RV6-A Slow Build ----- Original Message ----- From: "Rick Galati" <rick6a(at)yahoo.com> Sent: Tuesday, August 29, 2006 9:18 AM Subject: RV-List: Re: Rant, question, suggestion: errors in > > > n223rv(at)wolflakeairport wrote: >> .........If you think Van's plans need improvement on their prints, build >> an RV-4.... The RV-10 has best in class instructions. If you have an >> issue with them, maybe another hobby would be better............ > > > Some time ago, a seasoned airline pilot with a wry wit observed that the > airline travel experience was being rapidly reduced to just two classes of > flyers.......First Class and Third World. > > As Van's kits and plans increasingly improve, the process has been > democratized to the point that a whole new class of builder has emerged. > Because of the advanced nature of todays kits, it is now possible to > attract the masses. For the first time in history, it is possible for the > marginally skilled (and that includes builders who have assembled nothing > more complicated than a propane barbeque grill from Lowes or Home Depot), > the impatient citizen long accustomed to instant gratification and his > cousin....the first time builder and vocal critic who cannot adapt > generally well written plans and callouts to a particular building > situation. Such are the realities of an efficient marketplace. A place at > the table for everyone. > > I'll go even further than that. I say a prepunched Quickbuild kit is to > homebuilt aircraft construction what a Betty Crocker Warm Delights Molten > Chocolate cake mix is to the culinary arts. It is generally conceded the > devil?Ts food treat can be loosely described as ?ocake? but demanding > purists with a discerning palate would naturally chafe at the notion and > the ?ochef? a natural impulse to suggest a Herculean effort and > superior cooking skill to produce a confection demanding little more than > cup water and 1 minute, 45 seconds in the microwave. [Rolling Eyes] > > Rick Galati RV-6A "Darla" (standard kit) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=58209#58209 > > > ________________________________________________________________________________
Subject: Re: Van's Wheel Fairings
Date: Aug 29, 2006
Derrick, If you expect to fly from only asphalt and never have a tire low on pressure..a 1/4 inch around is enough. If on the other hand you will be flying in the real world, 5/8 inch is the minimum side clearance I could stand. Front and rear of the tread I use 1 inch which allows most of the grass I pick up from my home field to exit without excessive buildup. Yes, I did start with 1/4 inch all around and increased the clearance from there. Your results may vary. ;-) Charlie Ennis N60CE ----- Original Message ----- From: Derrick Aubuchon To: RV List Sent: Tuesday, August 29, 2006 9:44 AM Subject: RV-List: Van's Wheel Fairings I am replacing (finally!) my original, old style wheel fairings, for Van's "new" Pressure Recovery fairings. Any ideas on what works best for a minimal tire-to-faring clearance around the lower opening? Thanks, Derrick L. Aubuchon RV-4: N184DA (450+ hrs) Jackson/Westover -Amador County (O70) n184da(at)volcano.net ________________________________________________________________________________
Date: Aug 29, 2006
Subject: Engine mount out of spec
Date: Aug 29, 2006
Jeff & Dean: I like the look of Torx head screws and they work very well. But, why add a part that is not, shall we say standard? If you are away from home and need to do a little maintenance or something works its way down into no-man's land ... Your girlfriends diamond from the engagement ring. It will be just a stumbling block to obtain a driver. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 29, 2006
>I like the look of Torx head screws and they work very well. But, why add a >part that is not, shall we say standard? If you are away from home and need >to do a little maintenance or something works its way down into no-man's land >... Your girlfriends diamond from the engagement ring. It will be just a >stumbling block to obtain a driver. You mean the torx driver is not in your travel kit? A fishing tackle box can contain many items that will help you with repairs away from home. Ron Lee ________________________________________________________________________________
Subject: Attaching floors with nutplates.
Date: Aug 29, 2006
You don't carry a tool kit? Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of FLYaDIVE(at)aol.com Sent: Tuesday, August 29, 2006 3:11 PM Subject: Re: RV-List: Attaching floors with nutplates. Jeff & Dean: I like the look of Torx head screws and they work very well. But, why add a part that is not, shall we say standard? If you are away from home and need to do a little maintenance or something works its way down into no-man's land ... Your girlfriends diamond from the engagement ring. It will be just a stumbling block to obtain a driver. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Subject: TRUTRACK ADI Pilot 1
Date: Aug 29, 2006
Hello Listers, I am new here so hope this works ok. I am seriously considering purchase of Trutrack's ADI Pilot 1 as it is autopilot and attitude instrument using one valuable panel hole in RV8 panel. The company seems to have a first class reputation. Has anyone out there had experience with this unit? Ian from Downunder. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=58334#58334 ________________________________________________________________________________
Date: Aug 29, 2006
Derrick, When I built my RV8 in 1999, I experimented with several wheelpant and tire variations. My objective was to obtain the most speed and the least drag possible. I found out that when I used any of the various cheap tires, I needed at least a 1/2 inch clearance around the tire casing, because when landing etc. the cheap tires would expand and rub the wheelpant. I solved the problem by installing Goodyear Custom III tires and tubes. The Custom III series has a much stiffer tred and side casing and holds its shape even with a hard landing. Note: the lower (closer to ground) you install the wheel pant, the faster you will go. I tried Vans pressure recovery pants first and then went to Sam James pressure recovery pants because they went faster and looked better. Good luck with your project. Dick Martin RV8 N233M the fast one 1350 hours - it gets better every day ----- Original Message ----- From: Derrick Aubuchon To: RV List Sent: Tuesday, August 29, 2006 9:44 AM Subject: RV-List: Van's Wheel Fairings I am replacing (finally!) my original, old style wheel fairings, for Van's "new" Pressure Recovery fairings. Any ideas on what works best for a minimal tire-to-faring clearance around the lower opening? Thanks, Derrick L. Aubuchon RV-4: N184DA (450+ hrs) Jackson/Westover -Amador County (O70) n184da(at)volcano.net ________________________________________________________________________________
Date: Aug 29, 2006
Ditto. I've swapped many of the torx or hex screws I used initially out for SS phillips for that very reason. Some places they make sense (forward baggage floor still has hex cap screws, very helpful.) Other places, there's no point (spinner). IMO. - Larry Bowen, RV-8, RV-7 VS Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: FLYaDIVE(at)aol.com [mailto:FLYaDIVE(at)aol.com] > Sent: Tuesday, August 29, 2006 6:11 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Attaching floors with nutplates. > > > Jeff & Dean: > > I like the look of Torx head screws and they work very well. > But, why add a part that is not, shall we say standard? If > you are away from home and need to do a little maintenance or > something works its way down into no-man's land ... Your > girlfriends diamond from the engagement ring. It will be > just a stumbling block to obtain a driver. > > Barry > "Chop'd Liver" > > "Show them the first time, correct them the second time, kick > them the third time." > Yamashiada > > Photoshare, and much much more: > > > ________________________________________________________________________________
Date: Aug 29, 2006
Subject: Re: Rant, question, suggestion: errors in plans/drawings
Now you guys have got me worried. I have the tail & wings done, the fuselage side and bottom skins drilled to the fuselage and have moved on to the gearleg boxes . . . and have found the instructions and plans to be fine with none of the errors confusing others. I have, however, spent many hours waving parts in the air until I figure out what I am trying to do though! Pete Cowper RV8 #81139 ________________________________________________________________________________
Date: Aug 29, 2006
Barry, Yes, they are Lord, I think. They are the from Vans. But, they are the exact same ones I had on the other mount and in the same positions. When I took the engine off the mount, I put each set in a separate zip-lock bag and labeled it. I referred to the plans again and put the high durometer mounts in the right locations -- just like I had them before. I kept them stacked just like I took them off and restarted the nuts. I'm very sure that there is no mistake here. There is one possibility. The engine case is not the same one, but a different IO-360-C1E6 off the shelf at Divco. I agreed to take a different case to speed up the turnaround. If I had it to do over again I wouldn't do this. I am using an IO-360-A1A sump and intake tubes on this engine, which I believe makes it an IO-360-A1D6. Do you know of any problem like this between cases? Dan Hopper RV-7A In a message dated 8/29/2006 5:27:19 P.M. Eastern Daylight Time, FLYaDIVE(at)aol.com writes: --> RV-List message posted by: FLYaDIVE(at)aol.com In a message dated 8/29/06 10:16:28 AM Eastern Daylight Time, Hopperdhh(at)aol.com writes: > I called Van's to see if perhaps I was sent the wrong mount. I was told > that this spec on the mounts was +/- 1/16 inch, and there must be something > else causing the problem. Since I am using the same everything else, I can't > see what else it could be. With the engine mounted and 2 weeks of connecting > up everything already done, I am stuck. ================================= Dan: Before you go through all that work, I would check one thing ... Check to see if you have the thrust washers on in the correct order and correct location. I have more info but first I need to know which engine and who's vibration mounts? They wouldn't happen to be Lord? Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 30, 2006
In a message dated 8/30/2006 4:40:08 AM Eastern Standard Time, Hopperdhh(at)aol.com writes: Do you know of any problem like this between cases? Dan Hopper RV-7A =============================== Hi Dan: Sorry, I don't know of any problems between cases. I mention the Lord mounts because I have heard of WASHER STACKING problems. When setting up the thrust line it does not take much of a change at the back to effect things at the front. Just for S&G's ... DO you think swapping or removing the washers will make a difference? Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 30, 2006
In a message dated 08/29/2006 9:11:33 PM Central Daylight Time, FLYaDIVE(at)aol.com writes: If you are away from home and need to do a little maintenance or something works its way down into no-man's land >>> I keep a small 1/4" ratchet and each of the bits/sockets for most routine items on my plane in my on-board toolkit, which is a single Shure microphone bag about the size of a small shaving kit that essentially vainishes on the floor between the seats on my -6A. There are also several spare Torx screws of each size I use in there too. (also tie-down rings, electrical tape, wingjack blocks and basic tools to remove all access covers, cowling, pants and do most away-from-home chores- no spare engine or kitchen sink tho...) >From The PossumWorks in TN Mark Phillips - N51PW "Mojo" with LOTS of Torx screws on board! ________________________________________________________________________________
Date: Aug 30, 2006
Dan, Vans does not sell Lord or Barry brand mounts. The mount kit they supply is made by VIP, Vibration Isolation Products. Charlie Kuss >Barry, > >Yes, they are Lord, I think. They are the from Vans. But, they are >the exact same ones I had on the other mount and in the same >positions. When I took the engine off the mount, I put each set in >a separate zip-lock bag and labeled it. I referred to the plans >again and put the high durometer mounts in the right locations -- >just like I had them before. I kept them stacked just like I took >them off and restarted the nuts. I'm very sure that there is no mistake here. > >There is one possibility. The engine case is not the same one, but >a different IO-360-C1E6 off the shelf at Divco. I agreed to take a >different case to speed up the turnaround. If I had it to do over >again I wouldn't do this. I am using an IO-360-A1A sump and intake >tubes on this engine, which I believe makes it an IO-360-A1D6. Do >you know of any problem like this between cases? > >Dan Hopper >RV-7A > > >In a message dated 8/29/2006 5:27:19 P.M. Eastern Daylight Time, >FLYaDIVE(at)aol.com writes: > >In a message dated 8/29/06 10:16:28 AM Eastern Daylight Time, >Hopperdhh(at)aol.com writes: > > > I called Van's to see if perhaps I was sent the wrong mount. I was told > > that this spec on the mounts was +/- 1/16 inch, and there must be >something > > else causing the problem. Since I am using the same everything else, I >can't > > see what else it could be. With the engine mounted and 2 weeks of >connecting > > up everything already done, I am stuck. >================================= >Dan: > >Before you go through all that work, I would check one thing ... Check to see >if you have the thrust washers on in the correct order and correct location. > >I have more info but first I need to know which engine and who's vibration >mounts? They wouldn't happen to be Lord? > >Barry >"Chop'd Liver" > >"Show them the first time, correct them the second time, kick them the third >time." es Day --> - NEW MATRONICS WEB FORUMS - >bsp; --> nbsp; - NEW MATRONICS LIST WIKI - >; ======================== > > ________________________________________________________________________________
Date: Aug 30, 2006
Dick Two questions. Can you recommend any other name brand tires besides Goodyear? What speed gain did you see by using the Sam James wheel pants? Charlie Kuss >Derrick, >When I built my RV8 in 1999, I experimented with several wheelpant >and tire variations. My objective was to obtain the most speed and >the least drag possible. I found out that when I used any of the >various cheap tires, I needed at least a 1/2 inch clearance around >the tire casing, because when landing etc. the cheap tires would >expand and rub the wheelpant. I solved the problem by installing >Goodyear Custom III tires and tubes. The Custom III series has a >much stiffer tred and side casing and holds its shape even with a >hard landing. Note: the lower (closer to ground) you install the >wheel pant, the faster you will go. >I tried Vans pressure recovery pants first and then went to Sam >James pressure recovery pants because they went faster and looked better. >Good luck with your project. >Dick Martin >RV8 N233M >the fast one >1350 hours - it gets better every day >----- Original Message ----- >From: <mailto:n184da(at)volcano.net>Derrick Aubuchon >To: RV List >Sent: Tuesday, August 29, 2006 9:44 AM >Subject: RV-List: Van's Wheel Fairings > >I am replacing (finally!) my original, old style wheel fairings, for >Van's "new" Pressure Recovery fairings. >Any ideas on what works best for a minimal tire-to-faring clearance >around the lower opening? > >Thanks, > > >Derrick L. Aubuchon > >RV-4: N184DA (450+ hrs) > >Jackson/Westover -Amador County (O70) > >n184da(at)volcano.net > > >com/Navigator?RV-List > > ________________________________________________________________________________
Date: Aug 30, 2006
Subject: Re: TRUTRACK ADI Pilot 1
Ian Just added a TruTrak ADI Pilot II, two axis pilot to my RV-4. Make sure you get the Pilot II, and not the Pilot I, or you will end up with a single axis pilot. I don't know why it took me so long to decide to do this. What a superb instrument. Pat Long PGLong(at)aol.com N120PL RV4 Bay City, Michigan 3CM Do Not Archive ________________________________________________________________________________
Date: Aug 30, 2006
Does anyone know the difference between Goodyear Custom III tires and the earlier Custom II tires? Many thanks .... Jerry Grimmonpre' ----- Original Message ----- From: Charlie Kuss To: rv-list(at)matronics.com Sent: Wednesday, August 30, 2006 7:04 AM Subject: Re: RV-List: Van's Wheel Fairings Dick Two questions. Can you recommend any other name brand tires besides Goodyear? What speed gain did you see by using the Sam James wheel pants? Charlie Kuss Derrick, When I built my RV8 in 1999, I experimented with several wheelpant and tire variations. My objective was to obtain the most speed and the least drag possible. I found out that when I used any of the various cheap tires, I needed at least a 1/2 inch clearance around the tire casing, because when landing etc. the cheap tires would expand and rub the wheelpant. I solved the problem by installing Goodyear Custom III tires and tubes. The Custom III series has a much stiffer tred and side casing and holds its shape even with a hard landing. Note: the lower (closer to ground) you install the wheel pant, the faster you will go. I tried Vans pressure recovery pants first and then went to Sam James pressure recovery pants because they went faster and looked better. Good luck with your project. Dick Martin RV8 N233M the fast one 1350 hours - it gets better every day ________________________________________________________________________________
Date: Aug 30, 2006
FORD found on road dead -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=58476#58476 ________________________________________________________________________________
Date: Aug 30, 2006
Barry, No, I have looked this thing over about a hundred times. There is no way to get 3/8 inch out from between the case and the mount. I understand that washers can make a big difference. Since the distance between the mounts is about half the length of the engine it should make about a 2 to 1 difference, maybe a little more due to the 30 degree angle of the dynafocal mount. What looks like my best alternative, all things considered, is to add about 3/8 inch at the rear of the cowl. This means removing the hinges and adding some glass around the cowl and refitting it. I say this because I don't have room enough in front for the way the baffle is made. There is the FAB induction box and air cleaner which limits me from trimming the baffle in front. Also, the alternator is getting very close to the cowl. Moving the whole cowling forward seems like the best bet. I had to redo this when building the plane and it is not too bad. The worst thing is messing up the paint job. I have a new nose wheel fairing and gear leg fairing that need to be painted anyway. I will probably be flying it with primer patches for a while. Dan Hopper RV-7A In a message dated 8/30/2006 5:00:00 A.M. Eastern Daylight Time, FLYaDIVE(at)aol.com writes: In a message dated 8/30/2006 4:40:08 AM Eastern Standard Time, Hopperdhh(at)aol.com writes: Do you know of any problem like this between cases? Dan Hopper RV-7A =============================== Hi Dan: Sorry, I don't know of any problems between cases. I mention the Lord mounts because I have heard of WASHER STACKING problems. When setting up the thrust line it does not take much of a change at the back to effect things at the front. Just for S&G's ... DO you think swapping or removing the washers will make a difference? Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada (http://www.matronics.com/Navigator?RV-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Aug 30, 2006
I would like to add some info here that might seem surprising. In the auto field the manuals, and I'm talking the factory manuals, have a 30% error. Now the aftermarket manuals just take from these manuals as well so they are also 30% in error. This was told to me by the factory reps. What do I do. Well if I look in a manual and it doesn't seem right, it probably isn't, so I'm careful. I guess we just need to be smart and research when things are not right on these planes. And yes I do believe vans should be posting on their web site the problems, I feel it would make their job a lot easier. But then again it just might give them a bad rep for a person looking into buying a kit and their just not willing to take the risk of admitting to not doing a very good job. I know, sounds a bit stuppid in thinking, but there are people that look at things that way. I know they should be worried about us, but we already took the plunge and started buying the kits, so, they don't care about us people, they care about future sales, or the first sale more. I'm thinking marketing here nothing more. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=58486#58486 ________________________________________________________________________________
Subject: RE: longer spinner, was Engine mount out of spec
Date: Aug 30, 2006
Hi Dan- My spinner ( a couple years old) had about an eighth inch of protrusion beyond the backplate, and it was a clean cut edge. Perhaps you could contact the manufacturer and get one that they haven't trimmed yet, or even one that is made a bit longer intentionally. FWIW, glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Aug 30, 2006
OK, Dan: One more trick ... This may not look the best but it does work and of course you can go fancy and improve the idea... Get a piece of 1/2" Pipe insulation foam. Cut it length wise in half so now you have something that look like a 'C' With the 'C' facing OUT (towards you), glue one part of the 'C' to the cowl and let the other part fit up against the spinner. The glue to use is 3M's Weather Stripping Adhesive (Red & White tube / box). This will seal the gap between the spinner and the cowl. Don't worry about it being bigger than the gap. The spinning of the spinner will ware it to exact fit in a few minutes. And if you want to paint the foam, yes it is paintable. The advantage are: 1 - Seals off an area of lost air. 2 - Increases the positive air pressure in the upper cowl. 3 - Adds to the cooling and 4 - Makes for a better look than a huge gap. Now, the pipe insulation can be replace with a thick neoprene cut into an 'O' ring. I have this configuration on a Grumman, used it for 9 years, it only needed replacing once in 9 years. And the scary thing is ... IT WORKS! Barry =============================================================== Barry, No, I have looked this thing over about a hundred times. There is no way to get 3/8 inch out from between the case and the mount. I understand that washers can make a big difference. Since the distance between the mounts is about half the length of the engine it should make about a 2 to 1 difference, maybe a little more due to the 30 degree angle of the dynafocal mount. What looks like my best alternative, all things considered, is to add about 3/8 inch at the rear of the cowl. This means removing the hinges and adding some glass around the cowl and refitting it. I say this because I don't have room enough in front for the way the baffle is made. There is the FAB induction box and air cleaner which limits me from trimming the baffle in front. Also, the alternator is getting very close to the cowl. Moving the whole cowling forward seems like the best bet. I had to redo this when building the plane and it is not too bad. The worst thing is messing up the paint job. I have a new nose wheel fairing and gear leg fairing that need to be painted anyway. I will probably be flying it with primer patches for a while. Dan Hopper RV-7A In a message dated 8/30/2006 5:00:00 A.M. Eastern Daylight Time, FLYaDIVE(at)aol.com writes: In a message dated 8/30/2006 4:40:08 AM Eastern Standard Time, Hopperdhh(at)aol.com writes: Do you know of any problem like this between cases? Dan Hopper RV-7A =============================== Hi Dan: Sorry, I don't know of any problems between cases. I mention the Lord mounts because I have heard of WASHER STACKING problems. When setting up the thrust line it does not take much of a change at the back to effect things at the front. Just for S&G's ... DO you think swapping or removing the washers will make a difference? Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 30, 2006
At 10:11 AM 8/30/2006, you wrote: > >I would like to add some info here that might seem surprising. In >the auto field the manuals, and I'm talking the factory manuals, >have a 30% error. Now the aftermarket manuals just take from these >manuals as well so they are also 30% in error. This was told to me >by the factory reps. >snipped >kitfoxmike >kitfox4 1200 912ul speedster >http://www.frappr.com/kitfoxmike >rv7 wingkit >reserved 287RV I'll second Mike's observation about errors in automotive tech info. I do this for a living and it can be maddening. I'd also like to mention that you don't get "step by step" instructions in these manuals either. The authors assume that the person doing the work has enough training to figure out HOW to remove or install a particular part or assembly which needs to be removed or installed, as part of a larger project. Like everyone else, I've spotted a number of small errors on my 8A plans. A local RV4 builder/owner coined a term for being bit in the butt by an error in the plans. He calls it being VANdalized. :-) After seeing my pre-punched 8A kit, he told me I had the "girls" kit. I got the lecture about earlier builders having to mine their own Bauxite, in the snow, trudging up hill, both ways, in June, etc, etc. I spent 4 months helping Jody build his RV4. He was correct, the older plans were nowhere near as good. He says that compared to today's plans, his RV4 instructions were "mere vague suggestions". Still, he finished it, and did a great job of it. I have a lot of respect for the builders of RV4s and early RV6s like Jody Edwards and Jerry Springer. For builders of RV3s, like Alex Sloan, all I can say is "We are not worthy"! :-) I was the winner in giving Jody 4 months of free help. He taught me a lot more than I helped him. Folks starting out without a good skill set, could do worse than to offer to help another builder. It will be time well spent. Vans does update errors in the plans. However, if he has 1000 sets of plans already printed out, the error won't be fixed till the next printing cycle. He has Dutch genes, after all. Charlie Kuss ________________________________________________________________________________
Date: Aug 30, 2006
He has Dutch genes. Oh my, that xplains everything. The first person I worked for in the auto industry was Dutch, boy was he frugal. Great guy. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=58531#58531 ________________________________________________________________________________
Date: Aug 30, 2006
Dan, Just a thought to consider. I know that Divco offers to modify Dynafocal type II cases to type I specification. I would think that this would require material to be machined from the rear of the case at this point. Perhaps if this was done to your cases, it could explain the gap. Perhaps a phone call to the shop who overhauled the crankcases is in order? Charlie Kuss >Barry, > >No, I have looked this thing over about a hundred times. There is >no way to get 3/8 inch out from between the case and the mount. I >understand that washers can make a big difference. Since the >distance between the mounts is about half the length of the engine >it should make about a 2 to 1 difference, maybe a little more due to >the 30 degree angle of the dynafocal mount. > >What looks like my best alternative, all things considered, is to >add about 3/8 inch at the rear of the cowl. This means removing the >hinges and adding some glass around the cowl and refitting it. I >say this because I don't have room enough in front for the way the >baffle is made. There is the FAB induction box and air cleaner >which limits me from trimming the baffle in front. Also, the >alternator is getting very close to the cowl. Moving the whole >cowling forward seems like the best bet. I had to redo this when >building the plane and it is not too bad. The worst thing is >messing up the paint job. I have a new nose wheel fairing and gear >leg fairing that need to be painted anyway. I will probably be >flying it with primer patches for a while. > >Dan Hopper >RV-7A > > >In a message dated 8/30/2006 5:00:00 A.M. Eastern Daylight Time, >FLYaDIVE(at)aol.com writes: >In a message dated 8/30/2006 4:40:08 AM Eastern Standard Time, >Hopperdhh(at)aol.com writes: >Do you know of any problem like this between cases? > >Dan Hopper >RV-7A > >=============================== >Hi Dan: > >Sorry, I don't know of any problems between cases. >I mention the Lord mounts because I have heard of WASHER STACKING problems. >When setting up the thrust line it does not take much of a change at >the back to effect things at the front. > >Just for S&G's ... DO you think swapping or removing the washers >will make a difference? > >Barry >"Chop'd Liver" > >"Show them the first time, correct them the second time, kick them the third >time." >Yamashiada > > >="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > >.matronics.com/">http://forums.matronics.com > >ronics.com/">http://wiki.matronics.com > >://www.matronics.com/contribution">http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Aug 30, 2006
Dan, I would explore sending the mount back to Vans for a refund and get a "custom" mount made by Snowline Mfg. in Oregon, who build the mounts for Van's. It may be possible to make a mount to your specs using the factory jigs, all they'd have to do is put some washers in under the firewall attach points when they bolt those pieces into the jig (and build up the mount from there). Assuming some of the other fixtures of the jig that hold the nosegear socket are bolted to the jig base and those could be raised perpendicular to the plane of the firewall as well. That would in effect shorten the length of the mount if a new one were constructed to your specs. I did a lot of work designing the jig and the 3rd generation of engine mounts for the F1, and have stayed at a Holiday In Express. :) My guess is that there are several jigs in use and it may be that there are some significant dimensional differences between the jigs. I'd call Snowline and see what they may come up with for you. IMO that would be a far better solution than cutting into the cowl, at the very minimum you wouldn't be making a CG problem worse. Regards, Bob Japundza RV-6 flying F1 under const. On 8/30/06, Hopperdhh(at)aol.com wrote: > > Barry, > > No, I have looked this thing over about a hundred times. There is no way > to get 3/8 inch out from between the case and the mount. I understand that > washers can make a big difference. Since the distance between the mounts is > about half the length of the engine it should make about a 2 to 1 > difference, maybe a little more due to the 30 degree angle of the dynafocal > mount. > > What looks like my best alternative, all things considered, is to add > about 3/8 inch at the rear of the cowl. This means removing the hinges and > adding some glass around the cowl and refitting it. I say this because I > don't have room enough in front for the way the baffle is made. There is > the FAB induction box and air cleaner which limits me from trimming the > baffle in front. Also, the alternator is getting very close to the cowl. > Moving the whole cowling forward seems like the best bet. I had to redo > this when building the plane and it is not too bad. The worst thing is > messing up the paint job. I have a new nose wheel fairing and gear leg > fairing that need to be painted anyway. I will probably be flying it with > primer patches for a while. > > Dan Hopper > RV-7A > > > In a message dated 8/30/2006 5:00:00 A.M. Eastern Daylight Time, > FLYaDIVE(at)aol.com writes: > > In a message dated 8/30/2006 4:40:08 AM Eastern Standard Time, > Hopperdhh(at)aol.com writes: > > Do you know of any problem like this between cases? > > Dan Hopper > RV-7A > > =============================== > Hi Dan: > > Sorry, I don't know of any problems between cases. > I mention the Lord mounts because I have heard of WASHER STACKING > problems. > When setting up the thrust line it does not take much of a change at the > back to effect things at the front. > > Just for S&G's ... DO you think swapping or removing the washers will > make a difference? > > Barry > "Chop'd Liver" > > "Show them the first time, correct them the second time, kick them the > third > time." > Yamashiada > > ** > > *="http://www.matronics.com/Navigator?RV-List"> > http://www.matronics.com/Navigator?RV-List .matronics.com/"> > http://forums.matronics.com ronics.com/">http://wiki.matronics.com* > ** *://www.matronics.com/contribution"> > > > * > > > * > > ________________________________________________________________________________
Date: Aug 30, 2006
Dana, Thanks very very much! That would make this a lot easier than how I was going to do it. I am going to take Bob's advice and see if the engine mount can be modified because he is right about the cg. That would also save me a lot of paint work. The plane is already nose heavy, and this should only move it about another 1/8 inch forward, but that is in the wrong direction. Thanks again, Dan Hopper RV-7A In a message dated 8/30/2006 2:24:22 P.M. Eastern Daylight Time, bo124rs(at)hotmail.com writes: --> RV-List message posted by: "Dana Overall" Dan, if you do choose to extend the aft portion of your firewall, let me give you some advice from my plastic airplane building days. Find a local custom gutter company, the ones with the forming machine on a trailer. Get a couple scrap pieces of the flat stocklong enough to go wrap completely around the aft of the cowl. Wax either surface very well and rivet this to the outside of the cowl, extend aft your desired distance. This material flexes and bends very, very easily. Now you have surface flush with the outside edge of your cowl that is used to blend the addition on quite nicely. Go to playing with glass, let dry, drill the rivets out and pop the form off the cowl. All you should have to do now is fill in the gap left between the cowl and your addition. After all this, you probably know of another method:-), but gutter scrap has been used in the plastic world extensively. Dana Overall Richmond, KY i39 RV-7 slider, Imron black, "Black Magic" O 360 A1A, C/S C2YK-1BF/F7666A4 http://rvflying.tripod.com/id30.html do not archive ________________________________________________________________________________
Date: Aug 30, 2006
Bob, I called Snowline Mfg. and they said that they don't make RV engine mounts. Does anyone know who does? Dan Hopper RV-7A In a message dated 8/30/2006 12:41:33 P.M. Eastern Daylight Time, rocketbob(at)gmail.com writes: Dan, I would explore sending the mount back to Vans for a refund and get a "custom" mount made by Snowline Mfg. in Oregon, who build the mounts for Van's. It may be possible to make a mount to your specs using the factory jigs, all they'd have to do is put some washers in under the firewall attach points when they bolt those pieces into the jig (and build up the mount from there). Assuming some of the other fixtures of the jig that hold the nosegear socket are bolted to the jig base and those could be raised perpendicular to the plane of the firewall as well. That would in effect shorten the length of the mount if a new one were constructed to your specs. I did a lot of work designing the jig and the 3rd generation of engine mounts for the F1, and have stayed at a Holiday In Express. :) My guess is that there are several jigs in use and it may be that there are some significant dimensional differences between the jigs. I'd call Snowline and see what they may come up with for you. IMO that would be a far better solution than cutting into the cowl, at the very minimum you wouldn't be making a CG problem worse. Regards, Bob Japundza RV-6 flying F1 under const. On 8/30/06, _Hopperdhh(at)aol.com_ (mailto:Hopperdhh(at)aol.com) <_ Hopperdhh(at)aol.com_ (mailto:Hopperdhh(at)aol.com) > wrote: Barry, No, I have looked this thing over about a hundred times. There is no way to get 3/8 inch out from between the case and the mount. I understand that washers can make a big difference. Since the distance between the mounts is about half the length of the engine it should make about a 2 to 1 difference, maybe a little more due to the 30 degree angle of the dynafocal mount. What looks like my best alternative, all things considered, is to add about 3/8 inch at the rear of the cowl. This means removing the hinges and adding some glass around the cowl and refitting it. I say this because I don't have room enough in front for the way the baffle is made. There is the FAB induction box and air cleaner which limits me from trimming the baffle in front. Also, the alternator is getting very close to the cowl. Moving the whole cowling forward seems like the best bet. I had to redo this when building the plane and it is not too bad. The worst thing is messing up the paint job. I have a new nose wheel fairing and gear leg fairing that need to be painted anyway. I will probably be flying it with primer patches for a while. Dan Hopper RV-7A In a message dated 8/30/2006 5:00:00 A.M. Eastern Daylight Time, _FLYaDIVE(at)aol.com_ (mailto:FLYaDIVE(at)aol.com) writes: In a message dated 8/30/2006 4:40:08 AM Eastern Standard Time, _Hopperdhh(at)aol.com_ (mailto:Hopperdhh(at)aol.com) writes: Do you know of any problem like this between cases? Dan Hopper RV-7A ====== Hi Dan: Sorry, I don't know of any problems between cases. I mention the Lord mounts because I have heard of WASHER STACKING problems. When setting up the thrust line it does not take much of a change at the back to effect things at the front. Just for S&G's ... DO you think swapping or removing the washers will make a difference? Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ="_ http://www.matronics.com/Navigator?RV-List_ (http://www.matronics.com/Navigator?RV-List) ">_http://www.matronics.com/Navigator?RV-List _ (http://www.matronics.com/Navigator?RV-List) _blank" onclick="return top.js.OpenExtLink(window,event,this)">http://forums.matronics.com _ronics.com/_ (http://ronics.com/) ">_ http://wiki.matronics.com_ (http://wiki.matronics.com/) ://www.matronics.com/contribution"> ="return top.js.OpenExtLink(window,event,this)">http://www.matronics.com/contribution the many List utilities such as the Subscriptions page, ronics.com/Navigator?RV-List" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)"> " onclick="return top.js.OpenExtLink(window,event,this)">http://www.matronics.com/Navigator?RV-List k" onclick="return top.js.OpenExtLink(window,event,this)"> turn top.js.OpenExtLink(window,event,this)">http://forums.matronics.com "return top.js.OpenExtLink(window,event,this)"> rn top.js.OpenExtLink(window,eve nt,this)">http://wiki.matronics.com -Matt Dralle, List Admin. _blank" onclick="return top.js.OpenExtLink(window,event,this)">_ http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) ========== (http://www.matronics.com/Navigator?RV-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Subject: FW: video input/taxi camera and other questions
Date: Aug 30, 2006
OK, one of you geeks out there knows where to find such a device.... a Windows CE driven camera. Go! Fetch! Good boy! ;-) Vince ________________________________ From: Greg Toman - Grand Rapids Technologies, Inc. Sent: Wednesday, August 30, 2006 3:46 PM Subject: Re: video input/taxi camera and other questions The ASI calibration is in the release Jeff and I are testing now. We thought we would release it tomorrow, but it might be another couple of days because I messed up the new function for defining missed approach altitudes, decision altitudes, and a pre-set altitude for the vertical nav function. I checked into the camera thing (which by the way, we have had others request). Our software engineer said that a web cam that plugs into our USB port would provide us with video, but that he was unaware of any webcams that include a driver for Windows CE (this is the embedded version of windows that we use...it is quite different from the version on your PC). So, all we need is the software driver. If you heard of someonw that found a webcam that includes a Windows CE driver, find out what camera that is, and let us know. This would be a free update. I don't want to get you too excited though. If we can't find a camera that includes the driver, we would need to write our own. This is not a trival task, and a very rough estimate of the cost to do so is in the range of $15,000-$30,000 worth of labor. We would only do this if we thought we could earn that much back, which is unclear at this time. In other words, don't count on it if we have to write the driver. Interestingly, when I tested the winds aloft calc, my RV-6A was off by less than 1 foot/sec at crusing speed. (I have Van's recommended static and pitot ports.) Thanks Greg ----- Original Message ----- From: Frazier, Vincent A <mailto:VFrazier(at)usi.edu> To: Greg Toman - Grand Rapids Technologies, Inc. Sent: Wednesday, August 30, 2006 9:30 AM Subject: video input/taxi camera and other questions Greg, After the TBM/RV-6 accident at Oshkosh, the email lists are on fire with guys wanting taxi cameras. Someone at your booth at Oshkosh mentioned that someone had a USB interface that would allow your EFIS screen to show video. PLEASE tell us where and how to get it. Right now, this would be a HUGE selling point. Also, is the ASI calibration to correct the winds aloft calculations ever going to be available? It's been almost 2 years since we discussed it. Vince ________________________________________________________________________________
Date: Aug 30, 2006
http://www.bluechillies.com/details/16749.html http://www.codecomments.com/archive425-2005-9-615836.html http://www.windowsfordevices.com/articles/AT4566767075.html http://www.gotdotnet.com/workspaces/workspace.aspx?id=0eb87e35-13e4-4fa3-9fd e-71e9136f47de http://web.tampabay.rr.com/vescovi/gumstix/gumstix%20RVTC/Rear%20View%20Todd ler%20Cam2.doc _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Frazier, Vincent A Sent: Wednesday, August 30, 2006 2:01 PM Subject: RV-List: FW: video input/taxi camera and other questions OK, one of you geeks out there knows where to find such a device.... a Windows CE driven camera. Go! Fetch! Good boy! ;-) Vince _____ From: Greg Toman - Grand Rapids Technologies, Inc. Sent: Wednesday, August 30, 2006 3:46 PM Subject: Re: video input/taxi camera and other questions The ASI calibration is in the release Jeff and I are testing now. We thought we would release it tomorrow, but it might be another couple of days because I messed up the new function for defining missed approach altitudes, decision altitudes, and a pre-set altitude for the vertical nav function. I checked into the camera thing (which by the way, we have had others request). Our software engineer said that a web cam that plugs into our USB port would provide us with video, but that he was unaware of any webcams that include a driver for Windows CE (this is the embedded version of windows that we use...it is quite different from the version on your PC). So, all we need is the software driver. If you heard of someonw that found a webcam that includes a Windows CE driver, find out what camera that is, and let us know. This would be a free update. I don't want to get you too excited though. If we can't find a camera that includes the driver, we would need to write our own. This is not a trival task, and a very rough estimate of the cost to do so is in the range of $15,000-$30,000 worth of labor. We would only do this if we thought we could earn that much back, which is unclear at this time. In other words, don't count on it if we have to write the driver. Interestingly, when I tested the winds aloft calc, my RV-6A was off by less than 1 foot/sec at crusing speed. (I have Van's recommended static and pitot ports.) Thanks Greg ----- Original Message ----- From: Frazier, Vincent A <mailto:VFrazier(at)usi.edu> Inc. Sent: Wednesday, August 30, 2006 9:30 AM Subject: video input/taxi camera and other questions Greg, After the TBM/RV-6 accident at Oshkosh, the email lists are on fire with guys wanting taxi cameras. Someone at your booth at Oshkosh mentioned that someone had a USB interface that would allow your EFIS screen to show video. PLEASE tell us where and how to get it. Right now, this would be a HUGE selling point. Also, is the ASI calibration to correct the winds aloft calculations ever going to be available? It's been almost 2 years since we discussed it. Vince ________________________________________________________________________________
Date: Aug 30, 2006
Subject: Re: FW: video input/taxi camera and other questions
Oh, I don't know. Maybe we could google "web cam + windows CE driver" and get something like: http://www.gotdotnet.com/workspaces/workspace.aspx?id=0eb87e35-13e4-4fa3-9fde-71e9136f47de http://msdn.microsoft.com/embedded/usewinemb/ce/sharedsrccode/USBDriver/default.aspx http://www.windowsfordevices.com/news/NS7191593413.html http://blogs.msdn.com/mikehall/archive/2006/03/08/546465.aspx This is a start, let me know how it progresses. THis could turn me from the Dynon Flightdek 180 to the Grand Rapids units. Steve EBerhart RV-7A razier, Vincent A wrote: > > OK, one of you geeks out there knows where to find such a device.... a > Windows CE driven camera. Go! Fetch! Good boy! ;-) > > Vince > > ------------------------------------------------------------------------ > *From:* Greg Toman - Grand Rapids Technologies, Inc. > *Sent:* Wednesday, August 30, 2006 3:46 PM > *To:* Frazier, Vincent A > *Subject:* Re: video input/taxi camera and other questions > > The ASI calibration is in the release Jeff and I are testing now. We > thought we would release it tomorrow, but it might be another couple > of days because I messed up the new function for defining missed > approach altitudes, decision altitudes, and a pre-set altitude for the > vertical nav function. > > I checked into the camera thing (which by the way, we have had others > request). Our software engineer said that a web cam that plugs into > our USB port would provide us with video, but that he was unaware of > any webcams that include a driver for Windows CE (this is the embedded > version of windows that we use...it is quite different from the > version on your PC). So, all we need is the software driver. If you > heard of someonw that found a webcam that includes a Windows CE > driver, find out what camera that is, and let us know. This would be > a free update. > > I don't want to get you too excited though. If we can't find a camera > that includes the driver, we would need to write our own. This is not > a trival task, and a very rough estimate of the cost to do so is in > the range of $15,000-$30,000 worth of labor. We would only do this if > we thought we could earn that much back, which is unclear at this > time. In other words, don't count on it if we have to write the driver. > > Interestingly, when I tested the winds aloft calc, my RV-6A was off by > less than 1 foot/sec at crusing speed. (I have Van's recommended > static and pitot ports.) > > Thanks > Greg > > ----- Original Message ----- > *From:* Frazier, Vincent A > *To:* Greg Toman - Grand Rapids Technologies, Inc. > > *Sent:* Wednesday, August 30, 2006 9:30 AM > *Subject:* video input/taxi camera and other questions > > Greg, > > After the TBM/RV-6 accident at Oshkosh, the email lists are on > fire with guys wanting taxi cameras. Someone at your booth at > Oshkosh mentioned that someone had a USB interface that would > allow your EFIS screen to show video. PLEASE tell us where and > how to get it. > > Right now, this would be a HUGE selling point. > > Also, is the ASI calibration to correct the winds aloft > calculations ever going to be available? It's been almost 2 years > since we discussed it. > > Vince > >* > > >* > ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Aug 30, 2006
I have Goodyear Custom II tires and they also maintain their shape.....stiff well made sidewalls. Tom in Ohio RV6-A ----- Original Message ----- From: Jerry Grimmonpre To: rv-list(at)matronics.com Sent: Wednesday, August 30, 2006 9:48 AM Subject: Re: RV-List: Van's Wheel Fairings Does anyone know the difference between Goodyear Custom III tires and the earlier Custom II tires? Many thanks .... Jerry Grimmonpre' ----- Original Message ----- From: Charlie Kuss To: rv-list(at)matronics.com Sent: Wednesday, August 30, 2006 7:04 AM Subject: Re: RV-List: Van's Wheel Fairings Dick Two questions. Can you recommend any other name brand tires besides Goodyear? What speed gain did you see by using the Sam James wheel pants? Charlie Kuss Derrick, When I built my RV8 in 1999, I experimented with several wheelpant and tire variations. My objective was to obtain the most speed and the least drag possible. I found out that when I used any of the various cheap tires, I needed at least a 1/2 inch clearance around the tire casing, because when landing etc. the cheap tires would expand and rub the wheelpant. I solved the problem by installing Goodyear Custom III tires and tubes. The Custom III series has a much stiffer tred and side casing and holds its shape even with a hard landing. Note: the lower (closer to ground) you install the wheel pant, the faster you will go. I tried Vans pressure recovery pants first and then went to Sam James pressure recovery pants because they went faster and looked better. Good luck with your project. Dick Martin RV8 N233M the fast one 1350 hours - it gets better every day ________________________________________________________________________________
Date: Aug 30, 2006
Subject: Re: rivets
In a message dated 8/30/06 6:48:13 PM Eastern Daylight Time, pitts_pilot(at)bellsouth.net writes: > OK rivet heads! Here's your chance to help educate me! I have acquired > a lot of rivets ....... bags of them .... without any ID on them at all. > How do you identify the rivets with their AN number???? They do appear > to be aviation grade. How can you tell what the hardness of the rivet > is??? Do you need to know???? > Linn > ====================== Hi Linn: I did not know you were o this group! Start with the angle of the flush rivets, they should be 100 Deg. Then there is a gage you can get for the diameter. It may even have length. There are also rivets with a dimple on the head. Separate them into a separate group also. Now, the rest of the information is located in the AC 43-13 4-57. Riveting 4-14 Figure 4-4. Rivet Identification and Part Number Breakdown 4-16 Table 4-8. Aircraft Rivet Identification 4-17 There is also information on Hardened, Oversized and Frozen Rivets. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 31, 2006
Subject: elevator balance weight
Date: Aug 30, 2006
Howdy list, I've rebuilt the elevators on our 6 due to pedestrian damage. I went with the .020 skins (previously .016) and am using the heavier lead counterbalance weights recommended for these skins. Pre-paint, the left elevator balances with only about an ounce or two on the trailing edge while the right elevator is considerably more nose heavy without the trim tab and associated structure. I'd like to remove some of the extra weight from the right elevator before I rivet on the tip and paint, but I'm concerned that the left elevator won't have enough c-balance weight and I'll need extra on the right side to do the final balance on the whole assembly rather than balancing each individually. I know that it all depends on how heavy the paint is and I'm not sure what that will be. How much did you have to remove from the weights on your airplane to get it to balance after paint? Did the left elevator have enough weight or did it need make up weight on the other elevator? Pax, Ed Holyoke ________________________________________________________________________________
Subject: Re: rivets
Date: Aug 31, 2006
Gee, I thought that dot in the center was for drilling them back out. -------- kitfoxmike kitfox4 1200 912ul speedster http://www.frappr.com/kitfoxmike rv7 wingkit reserved 287RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=58727#58727 ________________________________________________________________________________
Subject: Re: elevator balance weight
Date: Aug 31, 2006
Ed, Not sure where you are coming from on this. After paint I had to add about 2 ounces to the left elevator and about 1 ounce to the right if memory serves me correctly. The paint definitely increased weight aft of the pivot, not forward as you are suggesting. I balanced the elevators separately because once they are installed with the manual trim cable in place it would be impossible to get a meaningful balance indication. BTW, the way I did it worked well by installing the added weight behind the existing weight pocket using a couple of rivnuts thru the elevator tip rib. Worked good for me. -- Harry Crosby RV-6 N16CX, 254 hours -------------- Original message -------------- From: "Ed Holyoke" <bicyclop(at)pacbell.net> > > > > Howdy list, > > I've rebuilt the elevators on our 6 due to pedestrian damage. I went > with the .020 skins (previously .016) and am using the heavier lead > counterbalance weights recommended for these skins. Pre-paint, the left > elevator balances with only about an ounce or two on the trailing edge > while the right elevator is considerably more nose heavy without the > trim tab and associated structure. I'd like to remove some of the extra > weight from the right elevator before I rivet on the tip and paint, but > I'm concerned that the left elevator won't have enough c-balance weight > and I'll need extra on the right side to do the final balance on the > whole assembly rather than balancing each individually. I know that it > all depends on how heavy the paint is and I'm not sure what that will > be. > > How much did you have to remove from the weights on your airplane to get > it to balance after paint? Did the left elevator have enough weight or > did it need make up weight on the other elevator? > > Pax, > > Ed Holyoke > > > > >
Ed,
Harry Crosby
> --> RV-List message posted by: "Ed Holyoke"
> Howdy list,
> and I'll need extr a on t =====
Date: Aug 31, 2006
Van's phone person told me to do final balance of the elevators after they were joined (Without the manual trim control connected if that is your setup.) Dale Ensing ----- Original Message ----- From: HCRV6(at)comcast.net To: rv-list(at)matronics.com Sent: Thursday, August 31, 2006 1:30 PM Subject: Re: RV-List: elevator balance weight Ed, Not sure where you are coming from on this. After paint I had to add about 2 ounces to the left elevator and about 1 ounce to the right if memory serves me correctly. The paint definitely increased weight aft of the pivot, not forward as you are suggesting. I balanced the elevators separately because once they are installed with the manual trim cable in place it would be impossible to get a meaningful balance indication. BTW, the way I did it worked well by installing the added weight behind the existing weight pocket using a couple of rivnuts thru the elevator tip rib. Worked good for me. -- Harry Crosby RV-6 N16CX, 254 hours -------------- Original message -------------- From: "Ed Holyoke" <bicyclop(at)pacbell.net> > > > > Howdy list, > > I've rebuilt the elevators on our 6 due to pedestrian damage. I went > with the .020 skins (previously .016) and am using the heavier lead > counterbalance weights recommended for these skins. Pre-paint, the left > elevator balances with only about an ounce or two on the trailing edge > while the right elevator is considerably more nose heavy without the > trim tab and associated structure. I'd like to remove some of the extra > weight from the right elevator before I rivet on the tip and paint, but > I'm concerned that the left elevator won't have enough c-balance weight > and I'll need extr a on t ====== ________________________________________________________________________________
Date: Aug 31, 2006
Dale, Yeah, we've got the manual trim. If it were the electric setup with the servo in the elevator, there'd be no way that the supplied weights would be enough to balance the left elevator separately even before paint. That would mean that the bolted together assembly would indeed be the only way to balance, short of adding weight to the left side. Perhaps it is of little value to balance them individually, but it is how I'd like to do it if possible. If they do become separated in flight, flutter will likely be the least of my problems. ;-) Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Ensing Sent: Thursday, August 31, 2006 11:12 AM Subject: Re: RV-List: elevator balance weight Van's phone person told me to do final balance of the elevators after they were joined (Without the manual trim control connected if that is your setup.) Dale Ensing ----- Original Message ----- From: HCRV6(at)comcast.net Sent: Thursday, August 31, 2006 1:30 PM Subject: Re: RV-List: elevator balance weight Ed, Not sure where you are coming from on this. After paint I had to add about 2 ounces to the left elevator and about 1 ounce to the right if memory serves me correctly. The paint definitely increased weight aft of the pivot, not forward as you are suggesting. I balanced the elevators separately because once they are installed with the manual trim cable in place it would be impossible to get a meaningful balance indication. BTW, the way I did it worked well by installing the added weight behind the existing weight pocket using a couple of rivnuts thru the elevator tip rib. Worked good for me. -- Harry Crosby RV-6 N16CX, 254 hours -------------- Original message -------------- From: "Ed Holyoke" <bicyclop(at)pacbell.net> > > > > Howdy list, > > I've rebuilt the elevators on our 6 due to pedestrian damage. I went > with the .020 skins (previously .016) and am using the heavier lead > counterbalance weights recommended for these skins. Pre-paint, the left > elevator balances with only about an ounce or two on the trailing edge > while the right elevator is considerably more nose heavy without the > trim tab and associated structure. I'd like to remove some of the extra > weight from the right elevator before I rivet on the tip and paint, but > I'm concerned that the left elevator won't have enough c-balance weight > and I'll need extr a on t ====== com/Navigator?RV-List ________________________________________________________________________________
Date: Aug 31, 2006
Harry, You've got me wrong. I do understand that the paint is going to move the balance point aft. Van's directions say that weight will have to be removed from the counterbalances by drilling holes implying that the weights are too heavy. The balance point is much further forward on the right side and I'm wondering if I can remove some of the extra weight now. I'm wanting to get a little closer to the correct weight so that I don't have to swiss cheese it so much later. One thing I did after asking the question yesterday was too attach the outboard weights to the elevators with rivets holding nutplates so that I'll be able to remove the inboard weights and shave and/or drill the back sides where it won't be visible. Do you have the .020 skins and the .020 weights? Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)comcast.net Sent: Thursday, August 31, 2006 10:31 AM Subject: Re: RV-List: elevator balance weight Ed, Not sure where you are coming from on this. After paint I had to add about 2 ounces to the left elevator and about 1 ounce to the right if memory serves me correctly. The paint definitely increased weight aft of the pivot, not forward as you are suggesting. I balanced the elevators separately because once they are installed with the manual trim cable in place it would be impossible to get a meaningful balance indication. BTW, the way I did it worked well by installing the added weight behind the existing weight pocket using a couple of rivnuts thru the elevator tip rib. Worked good for me. -- Harry Crosby RV-6 N16CX, 254 hours -------------- Original message -------------- From: "Ed Holyoke" <bicyclop(at)pacbell.net> > > > > Howdy list, > > I've rebuilt the elevators on our 6 due to pedestrian damage. I went > with the .020 skins (previously .016) and am using the heavier lead > counterbalance weights recommended for these skins. Pre-paint, the left > elevator balances with only about an ounce or two on the trailing edge > while the right elevator is considerably more nose heavy without the > trim tab and associated structure. I'd like to remove some of the extra > weight from the right elevator before I rivet on the tip and paint, but > I'm concerned that the left elevator won't have enough c-balance weight > and I'll need extr a on t ====== ________________________________________________________________________________
Subject: Capacitance sender
Date: Aug 31, 2006
I am using Van's capacitance plates but need info on the capacitance to voltage converter. I will be using a Dynon EMS D10 for fuel level display. 1. Source for converter 2. Make and model number 3. How is the connection made between the converter and the BNC connection on the tanks. 4. How many and what gauge wires need to be run between the converter and the Dynon EMS. I expect the converters will be installed in the wing roots but would really like to get a handle on the wiring so I can proceed with it. PS: I have tried to contacting Princeton Electronics but get no reply to email or voice mail. I also understand that Dynon is working on a converter design but it has not yet reached the try out stage. Thanks Dennis Enns ________________________________________________________________________________
Subject: Re: rivets
Date: Aug 31, 2006
Chuckle Doc ----- Original Message ----- From: "kitfoxmike" <kitfoxmike(at)yahoo.com> Sent: Thursday, August 31, 2006 8:22 AM Subject: RV-List: Re: rivets > > Gee, I thought that dot in the center was for drilling them back out. > > -------- > kitfoxmike > kitfox4 1200 912ul speedster > http://www.frappr.com/kitfoxmike > rv7 wingkit > reserved 287RV > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=58727#58727 > > > > > > > > > > > ________________________________________________________________________________
Subject: yuk yuk
Date: Aug 31, 2006
Interesting rant on vans plans you guys ought to try working on certified AC with certified manuals/plans... often 43.13 is the best thing you have.... particularly on the old ones. The reason they call them aircraft is because you are supposed to be a craft's person to build 'em and to fly 'em. Vans plan's fasteners diameters are rarely wrong but lengths are always wrong, buy a ruler or inside bolt hole gauge and get over it. 2117 AD structural rivets should have a dimple in the top, one only. These come in flush an426 or universal an470 head design mostly these days. They tend to be good for about five to ten years then need to be reannealed as they do age harden slowly. Try crushing a few if they cracks chuck 'em or anneal 'em. No dimple means 1100 soft aluminum and the list goes on, check AC43.13 1A or 1B or AC65-15A for the list. W ________________________________________________________________________________
Date: Sep 01, 2006
Ed, OK, I understand. I planned to fly my -6 before painting so I balanced the elevators first without paint, then had to add weight after painting to rebalance. Your approach sounds good if you plan to paint before first flight, then shave the weights as required to balance. Hopefully they are oversize to start with. When I built my elevators we still had to cast the weights into the tips. Oh yes, I have the 0.016 skins. Harry Crosby RV-6 N16CX, 254 hours -------------- Original message -------------- From: "Ed Holyoke" <bicyclop(at)pacbell.net> Harry, Youve got me wrong. I do understand that the paint is going to move the balance point aft. Vans directions say that weight will have to be removed from the counterbalances by drilling holes implying that the weights are too heavy. The balance point is much further forward on the right side and Im wondering if I can remove some of the extra weight now. Im wanting to get a little closer to the correct weight so that I dont have to swiss cheese it so much later. One thing I did after asking the question yesterday was too attach the outboard weights to the elevators with rivets holding nutplates so that Ill be able to remove the inboard weights and shave and/or drill the back sides where it wont be visible. Do you have the .020 skins and the .020 weights? Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)comcast.net Sent: Thursday, August 31, 2006 10:31 AM Subject: Re: RV-List: elevator balance weight Ed, Not sure where you are coming from on this. After paint I had to add about 2 ounces to the left elevator and about 1 ounce to the right if memory serves me correctly. The paint definitely increased weight aft of the pivot, not forward as you are suggesting. I balanced the elevators separately because once they are installed with the manual trim cable in place it would be impossible to get a meaningful balance indication. BTW, the way I did it worked well by installing the added weight behind the existing weight pocket using a couple of rivnuts thru the elevator tip rib. Worked good for me. -- Harry Crosby RV-6 N16CX, 254 hours -------------- Original message -------------- From: "Ed Holyoke" <bicyclop(at)pacbell.net> > > > > Howdy list, > > I've rebuilt the elevators on our 6 due to pedestrian damage. I went > with the .020 skins (previously .016) and am using the heavier lead > counterbalance weights recommended for these skins. Pre-paint, the left > elevator balances with only about an ounce or two on the trailing edge > while the right elevator is considerably more nose heavy without the > trim tab and associated structure. I'd like to remove some of the extra > weight from the right elevator before I rivet on the tip and paint, but > I'm concerned that the left elevator won't have enough c-balance weight > and I'll need extr a on t ====== - The RV-List Email Forum - --> - NEW MATRONICS WEB FORUMS - --> - NEW MATRONICS LIST WIKI - --> - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. -->
Ed,
Harry Crosby
Harry,
Pax,
Ed Holyoke
Sent:
< B>To:
Ed,
Harry Crosby
-------------- Original message -------------- <BR>From: "Ed Holyoke" <bicyclop(at)pacbell.net> <BR><BR>> --> RV-List message posted by: "Ed Holyoke"
> Howdy list,
      - NEW MATRONICS
      WEB FORUMS -
   --&g
       t;
  Thank you for your
      generous support!
Subject: Re: Capacitance sender
From: "mchamberlain(at)runbox.com" <mchamberlain(at)runbox.com>
Date: Sep 01, 2006
Just went through this myself. I managed to get Todd from Princeton on the phone, you just have to keep trying until you catch him. I finally got hold of him and ordered 2 of the S1 model senders. I installed them a couple of days ago. Won't know if they work until fuel is put in the tanks which won't be for a couple of months yet. Here is a link:
http://websites.expercraft.com/markc/index.php?q=log_entry&log_id=11982 Keep trying, Mark - 234C (res) Last 20% Read this topic online here: http://forums.matronics.com/viewtopic.php?p=58849#58849 ________________________________________________________________________________
Subject: Tip Up Release
Date: Sep 01, 2006
Recently there was some discussion about the merits or lack of relating to the release handle on the tip up. As I recall some felt that the release was mainly for maintenance and not putting the handle through the panel. Could anyone point me in the right direction. Thanks John Furey 2 RV6A RV7 in process ________________________________________________________________________________
Date: Sep 01, 2006
Subject: CS Crankshaft end - what's it look like
Reposting since my original post failed to make it...... Fellow listers, I'm trying to determine what the prop end of the crankshaft is supposed to look like when it is set up for a constant speed prop. Folks have written about plugs - but that doesn't tell me what to look for. If it's plugged, should I only see the plug? If it's not plugged, what does the inside look like? FWIW, I'm not seeing 'just a plug' - I'm seeing stuff in there - looks like a bar going across with a notch cut in to it...maybe to allow a tool to get all the way in to the back. Anyone have any drawings or photographs? I know this is one that I don't want to have the wrong way... Thanks, Ralph Capen ________________________________________________________________________________
Date: Sep 01, 2006
Subject: Re: Tip Up Release
In a message dated 09/01/2006 8:18:08 AM Central Daylight Time, john(at)fureychrysler.com writes: Recently there was some discussion about the merits or lack of relating to the release handle on the tip up. As I recall some felt that the release was mainly for maintenance and not putting the handle through the panel. Could anyone point me in the right direction. >>> Hi John- no right direction here, just preferences. This topic has been beat to a bloody pulp on the list in the past- check archives for: "tip & up & canopy & release" and you'll need several cups of coffee before you're done. General consensus is that no one has ever jumped out of a tip-up RV, and even if you wanted to, it would be darn near impossible- oh yeah, then there's that parachute thing. 8-) My own take is that it is useful mostly for canopy removal for painting/maintenance, but I did set mine up so it could at least be released in flight by reaching under the panel, pulling a pin, and rotating a handle. Quite a number of other builders have taken this approach, or some version (perversion?) of it. See: http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=4969 Inadvertant release would be pretty difficult. Also note that I used .063 angle for the links to the pins from the bellcrank instead of those wimpy little chromoly tubes as I was concerned about how thin the tube wall is and that it "might" cut into the bolts after 50 years or so. The angles on the bottom plastic block with the holes through them were for a rudder trim system that I decided not to use- you can see it in the previous entry if interested... >From The PossumWorks in TN Mark Phillips RV-6A "Mojo" 350 hrs of grin time... ________________________________________________________________________________
Date: Sep 01, 2006
Subject: Re: CS Crankshaft end - what's it look like
Ralph, In my new Lyc. O-320 D1A from Van's, as received, the plug was an approximately 50mil thick steel disc within an inch or so of the open end of the crankshaft. It was slightly convex toward the open end. When the plug is removed, the shaft end is open for some distance in. I have not looked for or measured just how far in the shaft is hollow. To prepare for my C/S prop, I followed the Orndorf video which suggested using a sharp punch to penetrate the center of the disc and work it out of the crankshaft opening. It came out quite easily. Be prepared for oil to flow out of the crankshaft when the disc is removed. Hope this is helpful Richard Dudley -6A flying n Ralph E. Capen wrote: > >Reposting since my original post failed to make it...... > >Fellow listers, > >I'm trying to determine what the prop end of the crankshaft is supposed to look >like when it is set up for a constant speed prop. > >Folks have written about plugs - but that doesn't tell me what to look for. >If it's plugged, should I only see the plug? If it's not plugged, what >does the inside look like? > >FWIW, I'm not seeing 'just a plug' - I'm seeing stuff in there - >looks like a bar going across with a notch cut in to it...maybe to allow a tool >to get all the way in to the back. > >Anyone have any drawings or photographs? > >I know this is one that I don't want to have the wrong way... > >Thanks, >Ralph Capen > > > > ________________________________________________________________________________
Date: Sep 01, 2006
Ralph, As Dale Walter stated, the new plug must go behind the spray bar for the C/S prop setup. You can make a long handle hook from stiff SS wire that will pull out the old pierced plug that is probably still in there. To get the new plug into place, carefully slide the new plug into the crank cavity and up behind the spray bar. This can be done with the plug lying flat and the crank positioned so the spray bar is horizontal. To set the plug into the recessed area in the crank, I made a tool from a cheap socket that would just fit/slide inside the crank cavity. I ground relief slots in the socket sides180 degrees apart that would fit over the spray bar and yet allow the "tool" to press the new plug in place. Using a long extension on the socket I tapped the new plug into place. I am sure someone makes an expensive tool to do this but my homebuilders tool worked very well. Can send you a pict of the tool if you need. Also, somewhere in my notes, I have the dimension from the flange to the plug to help assure that the plug is all the way into the recess. Dale Ensing > Hi Ralph, > The bar you see is a spray bar. About 7 or 8 inches back. Farther in, about > an inch is a plug. For a CS prop the plug should be closed, no hole, to > maintain oil pressure to control the prop. If your engine had a fixed prop > before they were supposed to pierce the plug to avoid oil leaks against an > unsealed prop. I changed from fixed to CS and removed the rear plug (which > had been pierced)and replaced with a new one. Lycoming cautions to treat the > spray bar like glass, if it is damaged the crank must be sent to the factory > to replace. I can send you some pics. Your crank also has a place for an > outer seal to be used with a fixed prop. It is placed less than an inch from > the prop end of the crank and keeps the oil in. > Dale > > > I'm trying to determine what the prop end of the crankshaft is supposed to > look > like when it is set up for a constant speed prop. > > Folks have written about plugs - but that doesn't tell me what to look for. > If it's plugged, should I only see the plug? If it's not plugged, what > does the inside look like? > > FWIW, I'm not seeing 'just a plug' - I'm seeing stuff in there - > looks like a bar going across with a notch cut in to it...maybe to allow a > tool > to get all the way in to the back. > > Anyone have any drawings or photographs? > > I know this is one that I don't want to have the wrong way... > > Thanks, > Ralph Capen > > ________________________________________________________________________________
Date: Sep 01, 2006
Forget the 'stiff wire' to remove the old plug from behind the sludge tube....the wire will just keep bending back and pulling out of the hole. Best way to remove the plug is to borrow a dent puller from your local body shop...or make your own. You simply pierce a hole in the plug (if there isn't one or if the existing hole is inadequate), screw in the threaded end (screw) of the dent puller, and give it a little whack. The plug will come out in a New York minute. Rick in Ohio at the Buffalo Farm - Ohio Valley RVators http://rv6rick.tripod.com/ohiovalleyrvators/ for the archives > Ralph, > As Dale Walter stated, the new plug must go behind the spray bar for the C/S > prop setup. You can make a long handle hook from stiff SS wire that will > pull out the old pierced plug that is probably still in there. > To get the new plug into place, carefully slide the new plug into the crank > cavity and up behind the spray bar. This can be done with the plug lying > flat and the crank positioned so the spray bar is horizontal. To set the > plug into the recessed area in the crank, I made a tool from a cheap socket > that would just fit/slide inside the crank cavity. I ground relief slots in > the socket sides180 degrees apart that would fit over the spray bar and yet > allow the "tool" to press the new plug in place. Using a long extension on > the socket I tapped the new plug into place. > I am sure someone makes an expensive tool to do this but my homebuilders > tool worked very well. > Can send you a pict of the tool if you need. Also, somewhere in my notes, I > have the dimension from the flange to the plug to help assure that the plug > is all the way into the recess. > Dale Ensing > > > Hi Ralph, > > The bar you see is a spray bar. About 7 or 8 inches back. Farther in, > about > > an inch is a plug. For a CS prop the plug should be closed, no hole, to > > maintain oil pressure to control the prop. If your engine had a fixed prop > > before they were supposed to pierce the plug to avoid oil leaks against an > > unsealed prop. I changed from fixed to CS and removed the rear plug (which > > had been pierced)and replaced with a new one. Lycoming cautions to treat > the > > spray bar like glass, if it is damaged the crank must be sent to the > factory > > to replace. I can send you some pics. Your crank also has a place for an > > outer seal to be used with a fixed prop. It is placed less than an inch > from > > the prop end of the crank and keeps the oil in. > > Dale > > > > > I'm trying to determine what the prop end of the crankshaft is supposed > to > > look > > like when it is set up for a constant speed prop. > > > > Folks have written about plugs - but that doesn't tell me what to look > for. > > If it's plugged, should I only see the plug? If it's not plugged, what > > does the inside look like? > > > > FWIW, I'm not seeing 'just a plug' - I'm seeing stuff in there - > > looks like a bar going across with a notch cut in to it...maybe to allow a > > tool > > to get all the way in to the back. > > > > Anyone have any drawings or photographs? > > > > I know this is one that I don't want to have the wrong way... > > > > Thanks, > > Ralph Capen > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 01, 2006
Subject: Re: yuk yuk
> Only testosterone needed and there was no list when I built my RV-6 :-) :-) You had testosterone? Luxury! In my day we had to kill bull wi' bare hands, boil down oysters for testosterone, inject testosterone wi' dirty needle, AND we mined our own bauxite. You tell the young builders that today and they won't believe you. (Spit.) ________________________________________________________________________________
Date: Sep 02, 2006
Subject: AOPA Solicitation?
Has anyone else received a recent phone call supposedly from the AOPA asking for a donation? Often citing the AOPA's around the country seminars and on-line courses as expensive undertakings needing financial support, it all sounded so proper until "Brian" asked me to provide him with my credit card number so he could process my donation with a minimum of hassle. When I declined and instead suggested he send the donation request via snail mail, "Brian" expressed a sense of urgency and said my donation should be received by the AOPA no later than Sept. 5 and he would send out the donation letter immediately. That was several days ago. For being in such a rush, I wonder why I have yet to receive an official request from the AOPA. Being cynical by nature, I have to wonder if the phone call was a legitimate request or just another sophisticated attempt by bottom feeders to prey upon the unwary? With the Labor Day weekend upon us, my attempts at contacting the AOPA by telephone for confirmation have proved fruitless. Rick Galati RV-6A "Darla" ________________________________________________________________________________
Date: Sep 02, 2006
Subject: Re: AOPA Solicitation?
At 07:35 AM 9/2/2006, you wrote: >Has anyone else received a recent phone call supposedly from the AOPA >asking for a donation? Often citing the AOPA's around the country >seminars and on-line courses as expensive undertakings needing financial >support, it all sounded so proper until "Brian" asked me to provide him >with my credit card number so he could process my donation with a minimum >of hassle. When I declined and instead suggested he send the donation >request via snail mail, "Brian" expressed a sense of urgency and said my >donation should be received by the AOPA no later than Sept. 5 and he would >send out the donation letter immediately. That was several days ago. For >being in such a rush, I wonder why I have yet to receive an official >request from the AOPA. Being cynical by nature, I have to wonder if the >phone call was a legitimate request or just another sophisticated attempt >by bottom feeders to prey upon the unwary? With the Labor Day weekend >upon us, my attempts at contacting the AOPA by telephone for confirmation >have proved fruitless. Has to have your credit card number NOW. That is a scam. Ron Lee ________________________________________________________________________________
Subject: TIS?
Date: Sep 02, 2006
Do you have mode S traffic in the plane? Can you tell me how many times you fly in an area that is "supposed" to have TIS data available and does not? We are in the Seattle area, fly in the area of coverage and find that the data is not being broadcast more then a fraction of the time. Is this the norm, or is there something unique to our Center? It seems to be true for Portland as well. I have to say that TIS in the plane is beyond great when it's available. Thanks, Dave ________________________________________________________________________________
Subject: RE: [SoCAL-RVlist] VNY FSDO
Date: Sep 02, 2006
Folks, If you remember last year I had a problem with the VNY FSDO and a memo that prohibited flights at 4 airports for experimental aircraft. Apparently the FSDO is narrowing it's interpretation to experimental/exhibition and not (now) trying to apply it to experimental/amateur built. Here's the latest from the EAA: http://www.eaa.org/communications/eaanews/060830_overflights.html Keep your ears open. This could still end up affecting us all. Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ed Holyoke Sent: Thursday, December 22, 2005 11:42 AM Subject: RV-List: RE: [SoCAL-RVlist] VNY FSDO I'm hoping they're at work for all of us. Mark and I got our new oplims and theoretically we're out of the fight now. I pushed on the EAA and AOPA to go to work on this because I don't want anybody else to have to go to the mat with the FAA later. The EAA didn't really need pushing. They were eager to jump on it and just waiting for our oplims to clear so those couldn't be held hostage. They have their yearly summit with the FAA at Oshkosh in January. The memo and differing regional policies are definitely on the agenda. EAA rep Randy told me a FSDO horror story about a guy who bought a homebuilt in southern Florida with 14 hours on it and the phase 1 not complete. He moved it (disassembled) to northern Florida and applied for a new test flight area in August. He had been told to send his original airworthiness certificate and oplims in and they would turn them around in 2 weeks. They lost the paperwork and he had to send copies (do you have copies of all your paperwork in a safe place?). Every 2 weeks, they told him it would be 2 weeks more. As of last week, and the EAA's intervention on the guy's behalf, they had promised to issue the new oplims the next day. I haven't heard if they came through. Part of the problem is that the guy is based in extreme northern Florida and the Miami FSDO says they can't give him a test area overlapping the Atlanta FSDO's area. I guess they couldn't pick up the phone and coordinate something with the other FSDO - no, so the oplims they finally agreed to issue will force the guy to fly off his time to the south only so he can remain in Miami's region. This story of bureaucracy run amok is another example of why the FAA needs to be forced to set some rational national policy and limit the regional FSDOs' authority. The AOPA initially seems a little less interested. I got a call back from a guy there who told me that he had called the FSDO claiming to be an RV-6 pilot planning a trip into Santa Barbara and wanting to know if there was going to be a problem. He was assured that there's no problem and not to worry about the memo. I told the rep that I figure it's all well and good to say that they won't enforce it, but how about later when they change their mind about that. I also told him that the real issue is the local setting of standards which may conflict with those in other areas and a discriminatory restriction on one category of aircraft. He said that there probably wouldn't be much happening about it at AOPA until after the holidays, but that he'd get back to me. Well, it's out in the open now and the lines are drawn. After they issued our new oplims, the question in my mind was: did the current FSDO manager support the former manager's policy or was it just an unwillingness to deal with changing the policy? It's pretty obvious that Swanson is not a friend to homebuilders. He isn't going to make it easy for new homebuilt aircraft in his area. He can't do much about existing ones so he's not going to fight us on that, although they did try to hold up our oplims until I screamed. Doesn't it sound like he's threatening more ramp checks, though? If you are ramp checked, I bet the inspector can find a way to violate you if he wants to bad enough. Read your oplims again, folks. Ours, issued in '98, were definitely more restrictive than the new ones. Make sure that all your required paperwork is in the plane and correct, just in case. Pax, Ed Holyoke * -----Original Message----- From: SoCAL-RVlist(at)yahoogroups.com [mailto:SoCAL-RVlist(at)yahoogroups.com] * Sent: Thursday, December 22, 2005 6:21 AM Subject: [SoCAL-RVlist] VNY FSDO http://www.avweb.com/eletter/archives/avflash/537-full.html#191233 Looks like the EAA is at work for Ed. _____ * Visit your group "SoCAL-RVlist <http://groups.yahoo.com/group/SoCAL-RVlist> " on the web. * To unsubscribe from this group, send an email to: SoCAL-RVlist-unsubscribe(at)yahoogroups.com <http://docs.yahoo.com/info/terms/> Terms of Service. _____ ________________________________________________________________________________
Subject: Re: Connecting Blue Mountain EFIS lite to Pictorial Pilot
Date: Sep 02, 2006
Blue Mountain Avionics has discovered that the Serial B port on the G3 Lite is inoperative. Regardless of the settings placed in the Setup window there is no output from the unit on this pinout. There is no GPSS or NMEA-0183 information sent even if one selects "none" on the Serial A port. This means that, in spite of the fact that the Install Manual clearly states that you can drive a Trutrak autopilot with the G3 using the settings provided, the G3 Lite efis is incapable at this time of providing the needed information. BMA has told me that that have looked at the BIOS software and cannot find the cause of the problem and they are now looking at the hardware as the source of the malfunction. Jim Ellis RV9-A, Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=59088#59088 ________________________________________________________________________________
Subject: Re: Van's Wheel Fairings
Date: Sep 02, 2006
Charlie, I used Goodyear because at the time they were readily available to me. I have not kept up with the airplane tire market, so I cannot recommend any other brand. I will say, however, that the performance and service life on my RV8 with the Goodyear Custom III has been excellent. As near as I can tell, I gained about 5 knots with the Sam James wheel pants. I flight tested both pants and the James pants are faster. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: Charlie Kuss To: rv-list(at)matronics.com Sent: Wednesday, August 30, 2006 7:04 AM Subject: Re: RV-List: Van's Wheel Fairings Dick Two questions. Can you recommend any other name brand tires besides Goodyear? What speed gain did you see by using the Sam James wheel pants? Charlie Kuss Derrick, When I built my RV8 in 1999, I experimented with several wheelpant and tire variations. My objective was to obtain the most speed and the least drag possible. I found out that when I used any of the various cheap tires, I needed at least a 1/2 inch clearance around the tire casing, because when landing etc. the cheap tires would expand and rub the wheelpant. I solved the problem by installing Goodyear Custom III tires and tubes. The Custom III series has a much stiffer tred and side casing and holds its shape even with a hard landing. Note: the lower (closer to ground) you install the wheel pant, the faster you will go. I tried Vans pressure recovery pants first and then went to Sam James pressure recovery pants because they went faster and looked better. Good luck with your project. Dick Martin RV8 N233M the fast one 1350 hours - it gets better every day ----- Original Message ----- From: Derrick Aubuchon To: RV List Sent: Tuesday, August 29, 2006 9:44 AM Subject: RV-List: Van's Wheel Fairings I am replacing (finally!) my original, old style wheel fairings, for Van's "new" Pressure Recovery fairings. Any ideas on what works best for a minimal tire-to-faring clearance around the lower opening? Thanks, Derrick L. Aubuchon RV-4: N184DA (450+ hrs) Jackson/Westover -Amador County (O70) n184da(at)volcano.net com/Navigator?RV-List ________________________________________________________________________________
Date: Sep 03, 2006
Gained 5 knots against which wheel pants from Vans? PR or the earlier boxy ones. > Charlie, > I used Goodyear because at the time they were readily available to me. > I have not kept up with the airplane tire market, so I cannot > recommend any other brand. I will say, however, that the performance > and service life on my RV8 with the Goodyear Custom III has been > excellent. > As near as I can tell, I gained about 5 knots with the Sam James wheel > pants. I flight tested both pants and the James pants are faster. > Dick Martin > RV8 N233M > ________________________________________________________________________________
Subject: Iridite Wanted to Buy
Date: Sep 02, 2006
I'm looking to buy a couple pounds of iridite from somebody. I've used a gallon of Alodine and am just getting started. My research on iridite a few months ago came up with only a few sources. I'd have to buy 10# and pay a lot for shipping. I'm in Bellingham, WA If that's not possible, maybe you could let me know of some retail sources? Thanks, Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=59154#59154 ________________________________________________________________________________
Subject: XM Antenna through Fiberglass?
Date: Sep 03, 2006
I have had success mounting the GPS antenna under the fiberglass cowl, so I thought I'd try it with my XM antenna. It seems to work, but not as well. The weather seems to take longer to download and the music is spotty at times. I don't know if it is because I have it close to the baffles and it may be blocking reception during climbs in certain directions, or if it is because of the fiberglass. Has anyone had success mounting theirs under fiberglass?? Does anyone know if it should work? Thanks -Mike Kraus RV-4 flying RV-10 building ________________________________________________________________________________
Date: Sep 03, 2006
Subject: Re: Iridite Wanted to Buy
In a message dated 9/3/06 2:03:43 AM Eastern Daylight Time, messydeer(at)yahoo.com writes: > I'm looking to buy a couple pounds of iridite from somebody. I've used a > gallon of Alodine and am just getting started. My research on iridite a few > months ago came up with only a few sources. I'd have to buy 10# and pay a lot > for shipping. I'm in Bellingham, WA > > If that's not possible, maybe you could let me know of some retail sources? > > Thanks, > Dan ============================= Dan: POUNDS ! ! ! One (1) ounce makes 10 Gallons I'll check and see if I have any left in powder form. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Sep 03, 2006
Dan: A late PS: You probably know this already ... But check under Chemical Conversion Coating. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Sep 03, 2006
Subject: Relocating plane prior to phase one complete
Hi Listers, I am planning to move to Texas from Oregon in mid to late October. My pl ane will have been inspected and maybe 15 hours flown off by then. I asked m y DAR if I could get a ferry permit to move it to Texas. Since it crosses several teritorries, he was not certain. Has anybody ever done this? I definately want to have enough time on the plane to be comfortable and have any issues worked out. But will need to establish a new phase one a rea once it is relocated. Tim RV-6 N616TB ________________________________________________________________________________
Date: Sep 03, 2006
Thanks, Barry! MacDermid's documentation says to use 0.75 to 2.25 ounces per gallon. I look forward to hearing about what you have :-) And thanks fot the search tip. Hadn't tried that. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=59184#59184 ________________________________________________________________________________
Date: Sep 03, 2006
In a message dated 9/3/06 10:00:51 AM Eastern Daylight Time, messydeer(at)yahoo.com writes: > Thanks, Barry! > > MacDermid's documentation says to use 0.75 to 2.25 ounces per gallon. > > I look forward to hearing about what you have :-) > > And thanks fot the search tip. Hadn't tried that. > > Dan > ======================= Dan: There are different CLASSes of Chem Film. They are determined by color and time. You can either use a low concentration say 1 oz for 10 Gal and let tit sit for a long time or double it for a shorter time. One other very important factor is TEMPERATURE. The solution is mixed hot and used warm. See the instructions for temps. Also, DD (Distilled & De-Ionizied) water is best but not very practical. Filter the water if you can, Minerals (Iron, Salt and Chlorine) affect the quality of the film. And...for some crazy reason SUNLIGHT weakens the solution so keep it covered. A dark plastic tarp works. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Sep 03, 2006
Barry, Try again. One POUND of Alodine 1201 or Iridite 14-2 will make 10 to 13 gallons of liquid. I really like making it from the powder, as you can control the strength of the solution. The powder also costs less than $2 per gallon, versus $25 per gallon for the liquid version. Charlie Kuss ---- FLYaDIVE(at)aol.com wrote: > > In a message dated 9/3/06 2:03:43 AM Eastern Daylight Time, > messydeer(at)yahoo.com writes: > > > I'm looking to buy a couple pounds of iridite from somebody. I've used a > > gallon of Alodine and am just getting started. My research on iridite a few > > months ago came up with only a few sources. I'd have to buy 10# and pay a > lot > > for shipping. I'm in Bellingham, WA > > > > If that's not possible, maybe you could let me know of some retail sources? > > > > Thanks, > > Dan > ============================= > Dan: > > POUNDS ! ! ! > > One (1) ounce makes 10 Gallons > > I'll check and see if I have any left in powder form. > > > Barry > "Chop'd Liver" > > "Show them the first time, correct them the second time, kick them the third > time." > Yamashiada > > > > ________________________________________________________________________________
Date: Sep 03, 2006
---- messydeer wrote: > > Thanks, Barry! > > MacDermid's documentation says to use 0.75 to 2.25 ounces per gallon. > > I look forward to hearing about what you have :-) > > And thanks fot the search tip. Hadn't tried that. > > Dan Dan & Listers, Just an FYI about mixing Alodine or Iridite. Mixing it towards the weak end of the recommended scale, will reduce the solution's storage life, greatly slow the chemical reaction time, plus leave you with more solution to dispose of. 1.5 to 2.25 ounces per gallon works well and will give a storage life (once converted to liquid) of about 2 years. Remember that these chemicals are photo chemically reactive. Don't use them outside in the sun light, or store them exposed to light. That will ruin the chemicals. Use them in the shade or in the garage with all the doors and windows open. Charlie Kuss ________________________________________________________________________________
Date: Sep 03, 2006
Thanks for the tips, again, Barry. I had talked with Henkel before using alodine. They had mentioned it could be recycled. What I found was that as I reused the solution, it took a longer dwell time to get the same results. So I ended up adding straight alodine to the recycled solution. So I'd like to be prepared to use solutions on the stronger side to speed up the process, especially since the baths will be tap water cold. I supposed I could use hot water to start with, but it would cool quite a bit anyway before finishing my parts for the day. Charlie: Where do you get your powder? Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=59194#59194 ________________________________________________________________________________
Date: Sep 03, 2006
MessageI had one in my KR-2 under the fiberglass turtledeck and it worked fine. I would worry more about the heat than anything under the cowl. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Mike Kraus Sent: Sunday, September 03, 2006 8:15 AM To: rv-list(at)matronics.com Subject: RV-List: XM Antenna through Fiberglass? I have had success mounting the GPS antenna under the fiberglass cowl, so I thought I'd try it with my XM antenna. It seems to work, but not as well. The weather seems to take longer to download and the music is spotty at times. I don't know if it is because I have it close to the baffles and it may be blocking reception during climbs in certain directions, or if it is because of the fiberglass. Has anyone had success mounting theirs under fiberglass?? Does anyone know if it should work? Thanks -Mike Kraus RV-4 flying RV-10 building ________________________________________________________________________________
Date: Sep 03, 2006
---- FLYaDIVE(at)aol.com wrote: > > In a message dated 9/3/06 10:00:51 AM Eastern Daylight Time, > messydeer(at)yahoo.com writes: > > > Thanks, Barry! > > > > MacDermid's documentation says to use 0.75 to 2.25 ounces per gallon. > > > > I look forward to hearing about what you have :-) > > > > And thanks fot the search tip. Hadn't tried that. > > > > Dan > > > ======================= > Dan: > > There are different CLASSes of Chem Film. They are determined by color and > time. You can either use a low concentration say 1 oz for 10 Gal and let tit > sit for a long time or double it for a shorter time. One other very important > factor is TEMPERATURE. The solution is mixed hot and used warm. See the > instructions for temps. Also, DD (Distilled & De-Ionizied) water is best but not > very practical. Filter the water if you can, Minerals (Iron, Salt and > Chlorine) affect the quality of the film. > And...for some crazy reason SUNLIGHT weakens the solution so keep it covered. > A dark plastic tarp works. > > Barry > "Chop'd Liver" Barry, One of my friends mixed up a batch of Iridite 14-2 (1 pound to 10 gallons). He used it in his driveway, outside during a 90 degree summer day in S Florida. All his parts turned out great that day. However, the next day, the solution was worthless. Use this stuff in the shade only. Charlie Kuss ________________________________________________________________________________
Date: Sep 03, 2006
---- messydeer wrote: > > Thanks for the tips, again, Barry. > > I had talked with Henkel before using alodine. They had mentioned it could be recycled. What I found was that as I reused the solution, it took a longer dwell time to get the same results. So I ended up adding straight alodine to the recycled solution. So I'd like to be prepared to use solutions on the stronger side to speed up the process, especially since the baths will be tap water cold. I supposed I could use hot water to start with, but it would cool quite a bit anyway before finishing my parts for the day. > > Charlie: > > Where do you get your powder? > > Dan Dan, I live in SE Florida (corrosion capital of the world). I checked with Henkel Corp (makers of Alodine) My nearest distributer was in the Atlanta, Georgia area. I then checked with MacDirmid Corp. They have a distributer about 25 miles from me. Allied Plating Supply of Hialeah, (north of Miami). I'll send you more detailed info on them when I get home, later today. Charlie ________________________________________________________________________________
Date: Sep 03, 2006
Rick, I had received a similar call about 6 months ago, but I do not believe that it got to the part about requesting a credit card. Ed Godfrey Rick Galati wrote: > Has anyone else received a recent phone call supposedly from the AOPA > asking for a donation? Often citing the AOPA's around the country > seminars and on-line courses as expensive undertakings needing > financial support, it all sounded so proper until "Brian" asked me > to provide him with my credit card number so he could process my > donation with a minimum of hassle. When I declined and instead > suggested he send the donation request via snail mail, "Brian" > expressed a sense of urgency and said my donation should be received > by the AOPA no later than Sept. 5 and he would send out the donation > letter immediately. That was several days ago. For being in such a > rush, I wonder why I have yet to receive an official request from the > AOPA. Being cynical by nature, I have to wonder if the phone call was > a legitimate request or just another sophisticated attempt by bottom > feeders to prey upon the unwary? With the Labor Day weekend upon us, > my attempts at contacting the AOPA by telephone for confirmation have > proved fruitless. > > Rick Galati RV-6A "Darla" > > ________________________________________________________________________________
Date: Sep 03, 2006
Need to keep your alodine solution warm? Use an aquarium heater. All the wetted component are plastic or glass. Buy a 1000w unit and it should keep your solution warm and with no shock hazard. Chuck Jensen > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of messydeer > Sent: Sunday, September 03, 2006 10:34 AM > To: rv-list(at)matronics.com > Subject: RV-List: Re: Iridite Wanted to Buy > > > > Thanks for the tips, again, Barry. > > I had talked with Henkel before using alodine. They had > mentioned it could be recycled. What I found was that as I > reused the solution, it took a longer dwell time to get the > same results. So I ended up adding straight alodine to the > recycled solution. So I'd like to be prepared to use > solutions on the stronger side to speed up the process, > especially since the baths will be tap water cold. I supposed > I could use hot water to start with, but it would cool quite > a bit anyway before finishing my parts for the day. > > Charlie: > > Where do you get your powder? > > Dan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=59194#59194 > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 03, 2006
Dan This past April I discovered a Canadian company who sells Powdered Alodine in 4oz tubes. This will make 2 to 2.5 gallons of liquid Alodine. Here is a web link to their Canadian & American distributors. http://www.endura.ca/adobe/uslist.pdf http://www.endura.ca/adobe/canadalist.pdf Charlie Kuss PS You might ask on the RV List if anyone local to you has some of the powder they would sell. Or ask if a few guys would be willing to split a 10 pound batch. That's how we do it down here. > >I'm looking to buy a couple pounds of iridite from somebody. I've >used a gallon of Alodine and am just getting started. My research on >iridite a few months ago came up with only a few sources. I'd have >to buy 10# and pay a lot for shipping. I'm in Bellingham, WA > >If that's not possible, maybe you could let me know of some retail sources? > >Thanks, >Dan > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=59154#59154 > > ________________________________________________________________________________
Date: Sep 03, 2006
I got my iridite powder from Eldorado Chemical...the chemical cost itself for a can was reasonable but the hazmat shipping charge is what makes it expensive. If you call them they will have a rep in your area sell it to you. http://www.eldoradochem.com/conversion-coatings.htm#Dorado-Kote-1 Regards, Bob On 9/3/06, messydeer wrote: > > > Thanks for the tips, again, Barry. > > I had talked with Henkel before using alodine. They had mentioned it could > be recycled. What I found was that as I reused the solution, it took a > longer dwell time to get the same results. So I ended up adding straight > alodine to the recycled solution. So I'd like to be prepared to use > solutions on the stronger side to speed up the process, especially since the > baths will be tap water cold. I supposed I could use hot water to start > with, but it would cool quite a bit anyway before finishing my parts for the > day. > > Charlie: > > Where do you get your powder? > > Dan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=59194#59194 > > ________________________________________________________________________________
Date: Sep 03, 2006
quick question, if I am only going to spray this only on the outside of my rv9a before primer and paint , how much is needed ?.. and is it needed at all ? Danny.. ----- Original Message ----- From: <chaztuna(at)adelphia.net> Sent: Sunday, September 03, 2006 9:37 AM Subject: Re: RV-List: Re: Iridite Wanted to Buy > > > ---- FLYaDIVE(at)aol.com wrote: >> >> In a message dated 9/3/06 10:00:51 AM Eastern Daylight Time, >> messydeer(at)yahoo.com writes: >> >> > Thanks, Barry! >> > >> > MacDermid's documentation says to use 0.75 to 2.25 ounces per gallon. >> > >> > I look forward to hearing about what you have :-) >> > >> > And thanks fot the search tip. Hadn't tried that. >> > >> > Dan >> > >> ======================= >> Dan: >> >> There are different CLASSes of Chem Film. They are determined by color >> and >> time. You can either use a low concentration say 1 oz for 10 Gal and let >> tit >> sit for a long time or double it for a shorter time. One other very >> important >> factor is TEMPERATURE. The solution is mixed hot and used warm. See the >> instructions for temps. Also, DD (Distilled & De-Ionizied) water is best >> but not >> very practical. Filter the water if you can, Minerals (Iron, Salt and >> Chlorine) affect the quality of the film. >> And...for some crazy reason SUNLIGHT weakens the solution so keep it >> covered. >> A dark plastic tarp works. >> >> Barry >> "Chop'd Liver" > > Barry, > One of my friends mixed up a batch of Iridite 14-2 (1 pound to 10 > gallons). He used it in his driveway, outside during a 90 degree summer > day in S Florida. All his parts turned out great that day. However, the > next day, the solution was worthless. Use this stuff in the shade only. > Charlie Kuss > > > ________________________________________________________________________________
Date: Sep 03, 2006
I had Vans later style round profile "pressure recovery" wheel pants, not the old style Dick Martin RV8 N233M the fast one ----- Original Message ----- From: "Doug Gray" <dgra1233(at)bigpond.net.au> Sent: Sunday, September 03, 2006 12:03 AM Subject: Re: RV-List: Van's Wheel Fairings > > Gained 5 knots against which wheel pants from Vans? PR or the earlier > boxy ones. > >> Charlie, >> I used Goodyear because at the time they were readily available to me. >> I have not kept up with the airplane tire market, so I cannot >> recommend any other brand. I will say, however, that the performance >> and service life on my RV8 with the Goodyear Custom III has been >> excellent. >> As near as I can tell, I gained about 5 knots with the Sam James wheel >> pants. I flight tested both pants and the James pants are faster. >> Dick Martin >> RV8 N233M > >> > > > ________________________________________________________________________________
From: "Elie Curetti" <elie.curetti(at)tmgmedia.com>
Subject: For Sale: RV-7 Empennage in Paris / France, new never opened
+ Avery Toolkit with pneumatic rivet squeezer
Date: Sep 04, 2006
(sorry to US listers - this is a post for European readers) Hello, Unfortunately, I will not be able to start my RV as I planned to, because of work and family constraints. I am selling everything you need to get started. Everything is in its original box, and was never opened. Sale price: current USD price, converted in Euros at today's exchange rate (1USD = EUR 0.78). You save freight costs and VAT ! 1. Empennage: $ 1,755 = EUR 1,368 2. Avery Toolkit: $3,009 = EUR 2,347 3. Misc stuff for your workshop: $ 300 = EUR 234 Total: 3,949 Euros. Located in Versailles (10 miles from Paris) in France. 1. RV-7 Empennage with Electric Elevator Trim option New price: $1755 = EUR 1,368 (see here: <http://www.vansaircraft.com/pdf/rv77a_qb_order_form.pdf> http://www.vansaircraft.com/pdf/rv77a_qb_order_form.pdf) 2. Complete Avery RV Builders Toolkit 3x, with pneumatic rivet squeezer, 3 yokes and several additions recommended by expert builders: (see here: https://www.cart.averytools.com/pc-689-68-rv-builders-tool-kit-with-3x-rivet -gun.aspx) 1 RV builders toolkit with 3x gun (#kit-016) $2160 + I have added: 1 Pneumatic squeezer with 3'' yoke (#7530) - $625 1 Adjustable set holder (#274) - $65 1 Longeron yoke (#7755) - $140 1 Thin nose yoke (#7760) - $145 1 Quick change yoke pins (#7795) - $6 1 Cleco pliers (#200) - $7.50 (additional one, so someone can help) 1 Hex adapter for deburring, with cutter (#59010) - $24 1 scotch brite wheel (#3753) -$57 1 Mandrel for Scotch brite (#934) - $16.50 1 chip chaser (#5105) - $10 1 plate nut drill jig (#1180) - $36 1 Boelube dry (#7090) - $3.5 1 box of 20 Scotch Brite pads (#7447B) - $28 (as replacement of the 5 box) 1 3m Riveting Tape (#3507) - $7 (additional) 1 Noxon Punch (#3200-1) - $13 Following items have been removed from the standard kit: - Aircraft Sheet Metal book - Hand squeezer - 5 Scotchbrite pads (#7447) Total: $ 3343, less 10% discount: $3,009 = EUR 2,347 3. Workshop stuff I bought various compressor accessories, pneumatic connectors, lines, tools, etc. I don't have the exact list but roughly: 1 paint gun 2 long pneumatic lines (100ft) 1 little pneumatic line 1 compressor starter kit 2 wall mount for compressor lines Numerous connectors: T / Male Female / Quick connects / swiver, etc. Water Oil separator Die Grinder with 10 discs Torque Wrench And other stuff Total: ~USD 300 = EUR 234 (to be confirmed with the precise list). Contact Elie Curetti Phone: from France: 06 66 60 70 80 / outside France: +33 6 66 60 70 80 Email: elie.curetti(at)tmgmedia.com I am really sad to sell my kit :-( Elie ________________________________________________________________________________
Subject: Re: XM Antenna through Fiberglass?
Date: Sep 04, 2006
I had mine under the VS fairing and it didn't work well at all. XM should and does work under fiberglass but as you experienced the signal is degraded. Also try and not splice the antenna wire. Its hard since the connector is larger but I replaced my XM antenna with one that was not spliced and placed it on my windshield. The reception is perfect. Not only is the tiny wire hard to work into a connector, but the shielding must be kept in place. Steve RV7A Flying I have had success mounting the GPS antenna under the fiberglass cowl, so I thought I'd try it with my XM antenna. It seems to work, but not as well. The weather seems to take longer to download and the music is spotty at times. I don't know if it is because I have it close to the baffles and it may be blocking reception during climbs in certain directions, or if it is because of the fiberglass. Has anyone had success mounting theirs under fiberglass?? Does anyone know if it should work? Thanks -Mike Kraus RV-4 flying RV-10 building ________________________________________________________________________________
Subject: Forward Baggage Compartment Temperatures
Date: Sep 04, 2006
Yesterday I measured a 110 degree Fahrenheit temperature close to the firewall in the forward baggage compartment of my RV8A. The method was to tape the wire lead of the outdoor sensor of an indoor/outdoor digital thermometer to the firewall so that the sensor was held close but not actually in contact with the firewall. Upon return from a half hour flight, I just opened the baggage compartment door and read the temperature about 5 minutes after landing. I also know that plastic bubble wrap which was in contact with the firewall did not melt and that although you can touch the firewall, it feels pretty hot. Outside air temp was 75 degrees F. Does anyone else have any information on the temperatures likely to be experienced by baggage stowed in this area? Dave Reel - RV8A ________________________________________________________________________________
Date: Sep 04, 2006
Subject: Re: Alodine/Iridite accessories was Re: Iridite Wanted to Buy
Chuck That's a great tip, although keeping the solution warm is not a problem here in SE Florida. For the rest of the listers, I will suggest another item to buy while you are at the aquarium supply store. Buy an aquarium pump. This will aid in transferring the AlumiPrep and Alodine back to your storage buckets. I keep my chemicals in 5 gallon plastic buckets with sealing lids, like the ones that paint and dry wall spackle are sold in. You can buy the buckets at Home Depot or Lowes. I get mine for free from a friend. He has a home remodeling business and is happy to give them to me. If you have a friend in the business, bum his excess buckets from him. You might also try looking in the dumpster behind your local house painter's shop. Charlie Kuss > >Need to keep your alodine solution warm? Use an aquarium heater. All >the wetted component are plastic or glass. Buy a 1000w unit and it >should keep your solution warm and with no shock hazard. > >Chuck Jensen > > > > -----Original Message----- > > From: owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of messydeer > > Sent: Sunday, September 03, 2006 10:34 AM > > To: rv-list(at)matronics.com > > Subject: RV-List: Re: Iridite Wanted to Buy > > > > > > > > Thanks for the tips, again, Barry. > > > > I had talked with Henkel before using alodine. They had > > mentioned it could be recycled. What I found was that as I > > reused the solution, it took a longer dwell time to get the > > same results. So I ended up adding straight alodine to the > > recycled solution. So I'd like to be prepared to use > > solutions on the stronger side to speed up the process, > > especially since the baths will be tap water cold. I supposed > > I could use hot water to start with, but it would cool quite > > a bit anyway before finishing my parts for the day. > > > > Charlie: > > > > Where do you get your powder? > > > > Dan > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=59194#59194 > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 04, 2006
In a message dated 9/4/2006 8:01:12 A.M. Pacific Daylight Time, chaztuna(at)adelphia.net writes: That's a great tip, although keeping the solution warm is not a problem here in SE Florida. For the rest of the listers, I will suggest another item to buy while you are at the aquarium supply store. Buy an aquarium pump. This will aid in transferring the AlumiPrep and Alodine back to your storage buckets. I keep my chemicals in 5 gallon plastic buckets with sealing lids, like the ones that paint and dry wall spackle are sold in. =============================== Another thing to get at the aquarium store is an aerating stone. The solution needs oxygen to maintain its properties for performing the conversion of the surface. This is the property that gets lost first (dissolved oxygen) or so I'm told. GV (RV-6A N1GV O-360-A1A, C/S, Flying 807hrs, Silicon Valley, CA) ________________________________________________________________________________
Date: Sep 04, 2006
Subject: Prop Extension Trade?
I have a 3 inch spool type prop extension with a 4 1/2 in bolt pattern with 3/8 in bolts. I need a 4 inch spool type prop extension with a 4 3/4 in bolt pattern with 3/8 in bolts. I will pay all shipping plus a little extra if needed. Raymond Wallace RV-4 in Progress --------------------------------- ________________________________________________________________________________
Date: Sep 05, 2006
Subject: For Sale - RV-6 / 6a kit
RV-6 / 6a kit for sale. Empennage: Complete except for fiberglass tips. Includes electric elevator trim kit. All parts are alodined and primed with Marhyde primer. Wings & Phlogiston Spar: Main wings are complete, bottom skins ready for final riveting. Both tanks are complete and sealed. Flaps and ailerons complete, but not installed. Includes electric aileron trim kit. All parts are alodined and primed with Deft epoxy primer (Mil-P-23377G). Both kits are the pre-punched versions purchased in 1997 & 1998 by myself. Construction is excellent. Preview plans and Orndorff videos are included for both kits. Price: $3900 If all items were purchased separately the price would be more than $6500 for unassembled kits. Scott Kuebler Buffalo, NY 716-695-1987 home 716-510-0318 cell scottkuebler(at)yahoo.com --------------------------------- ________________________________________________________________________________
Date: Sep 05, 2006
Tim, Call me at (503) 615-3237 and I will give you a hand to get a Ferry permit to Texas. Mike Robertson Date: Sun, 3 Sep 2006 06:54:40 -0700From: flyrv6(at)bryantechnology.comTo: rv- list(at)matronics.comSubject: RV-List: Relocating plane prior to phase one com plete Hi Listers, I am planning to move to Texas from Oregon in mid to late October. My plan e will have been inspected and maybe 15 hours flown off by then. I asked m y DAR if I could get a ferry permit to move it to Texas. Since it crosses several teritorries, he was not certain. Has anybody ever done this? I definately want to have enough time on the plane to be comfortable and ha ve any issues worked out. But will need to establish a new phase one area once it is relocated. Tim RV-6 N616TB _________________________________________________________________ Use Messenger to talk to your IM friends, even those on Yahoo! http://ideas.live.com/programpage.aspx?versionId=7adb59de-a857-45ba-81cc- 685ee3e858fe ________________________________________________________________________________
Date: Sep 05, 2006
Subject: 10 Vane Oil Cooler
Hey Flight: Who is the manufacture and what is the part number for the 10 Vane Oil Cooler used on the RV-6 with an O-360? Thanks for the feedback, Barry ________________________________________________________________________________
Date: Sep 05, 2006
Subject: Re: EIS faceplate
Garry, Try "Steinair.com" in Minn. He has it on his web site Jim ________________________________________________________________________________
Subject: rudder trim
Date: Sep 05, 2006
Trying to install rudder trim with some kind of spring bias on an RV4. Any ideas(especially pictures) would be appreciated. Thanks John Furey ________________________________________________________________________________
Date: Sep 05, 2006
Subject: Re: rudder trim
John, I saw something in a paper write-up where someone installed a cable with springs from each of their right side pedals. It went forward to and then up the firewall with springs in the middle initially to keep tension. IIRC they later incorporated something electrical (MAC servo maybe) to bias the springs and provide electrical trim capability. I'll try to remember to find it.... Ralph -----Original Message----- >From: John Furey <john(at)fureychrysler.com> >Sent: Sep 5, 2006 12:47 PM >To: rv-list(at)matronics.com >Subject: RV-List: rudder trim > >Trying to install rudder trim with some kind of spring bias on an RV4. Any >ideas(especially pictures) would be appreciated. > >Thanks >John Furey ________________________________________________________________________________
Date: Sep 05, 2006
Subject: Re: Aircraft Spruce terrible Service?
I have nothing but GOOD experiences with Aircraft Spruce. Give 'em another chance... Kim Nicholas RV9A 120 hours. ________________________________________________________________________________
Subject: Visionmicro Systems Moved or sold?
Date: Sep 05, 2006
It appears VisionMicro has moved and may have been sold by JP Instruments. If you call VM, their is a recording that gives you a new number 830-750-6330 and states they have moved. The recording does say where. When you call the new number you get a recoring and so far no one has returned my calls. Does anyone know what is happeing with VM? Roger Crandell N125RV _________________________________________________________________ ________________________________________________________________________________
Subject: First Flight N95BF
Date: Sep 05, 2006
Bryan, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A >From: "Bryan Flood" <bryanflood(at)hotmail.com> >Subject: RV-List: First Flight N95BF >Date: Mon, 28 Aug 2006 15:59:33 -0500 > >Well after almost 6 years of building another RV has flown >and returned to earth safely. The first flight of my RV-9A occurred >last Friday night about 6 pm lasted a hour. >Bryan Flood >N95BF (0.6 hours) ________________________________________________________________________________
Date: Sep 05, 2006
VM has not been sold, they have just moved their service department to JPI. Bruce www.glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Roger Crandell Sent: Tuesday, September 05, 2006 2:48 PM Subject: RV-List: Visionmicro Systems Moved or sold? It appears VisionMicro has moved and may have been sold by JP Instruments. If you call VM, their is a recording that gives you a new number 830-750-6330 and states they have moved. The recording does say where. When you call the new number you get a recoring and so far no one has returned my calls. Does anyone know what is happeing with VM? Roger Crandell N125RV _________________________________________________________________ ________________________________________________________________________________
Date: Sep 05, 2006
The Vision Microsystems website says a JPI company. -----Original Message----- >From: Bruce Gray <Bruce(at)glasair.org> >Sent: Sep 5, 2006 4:12 PM >To: rv-list(at)matronics.com >Subject: RE: RV-List: Visionmicro Systems Moved or sold? > > >VM has not been sold, they have just moved their service department to JPI. > >Bruce >www.glasair.org > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Roger Crandell >Sent: Tuesday, September 05, 2006 2:48 PM >To: rv-list(at)matronics.com >Subject: RV-List: Visionmicro Systems Moved or sold? > > >It appears VisionMicro has moved and may have been sold by JP Instruments. >If you call VM, their is a recording that gives you a new number >830-750-6330 and states they have moved. The recording does say where. >When you call the new number you get a recoring and so far no one has >returned my calls. > >Does anyone know what is happeing with VM? > >Roger Crandell >N125RV > >_________________________________________________________________ > > ________________________________________________________________________________
Date: Sep 05, 2006
bertrv6(at)highstream.net wrote: > > > > Hi: > > I have tried for the past two weeks, to call Spruce, to place a small order. > > This is not exageration, I have made at least eight calls, Starting > at 12:00 my time, East Coast...to 4:30 PM.. > > No one ever answers, I have hold at one time for 3 minutes... What number are you trying to call? Sam Buchanan ________________________________________________________________________________
Date: Sep 05, 2006
Subject: KFZY RV Forum, RV10 & Mike Seager planning to attend
Hey Listers KFZY Oswego NY 12th annual RV FORUM.... YUP....it is comming this weekend....see you there... Factory RV10 and Mike Seager scheduled to be there... As well as the usual 30 to 50+ assorted RV's in and out... For more info check it out at: http://www.eaachapter486.com/RVInfo.htm 486's home website http://www.eaachapter486.com Regards David McManmon ________________________________________________________________________ ________________________________________________________________________________
Date: Sep 05, 2006
Subject: Re: Engine tune up
In a message dated 9/5/06 2:25:55 PM Eastern Daylight Time, bertrv6(at)highstream.net writes: > > Is there any thing else to be done?? ============================= WOW! This a a total open ended question.... What is the history of the engine? Is it as new as the 30 hours? Have you tried different fuel? Are yo sure of the octane of the fuel? Is there or has there been WATER in the fuel? How long has the engine sat? Is there in line filters coming from each tank BEFORE it gets to the Boos Pump (found this to be a problem in a friends plane - It needed better filtering than that LOUSY gascolator and Carb Filter)? How are the wires? How good is your friend or you with the timing box? Having one is not enough. So many questions so little time. Does this give you some ideas on how to begin your diagnostics? A two item check is only the beginning. Barry "Chop'd Liver" ________________________________________________________________________________
Date: Sep 05, 2006
Quoting Sam Buchanan : > > bertrv6(at)highstream.net wrote: > > > > > > > > Hi: > > > > I have tried for the past two weeks, to call Spruce, to place a small > order. > > > > This is not exageration, I have made at least eight calls, Starting > > at 12:00 my time, East Coast...to 4:30 PM.. > > > > No one ever answers, I have hold at one time for 3 minutes... > > > What number are you trying to call? > > Sam Buchanan > SAM; I TRIED BOTH, I DO NOT MIND TO PAY FOR THE CALL, IF I CAN GET SOME ONE TO ANSWER. ONE IS THE 1.877 477.7823 and regular one 951.372.9555 I know they are not the fastest to answer the telephone, but for pete's sake 2 weeks, waiting for up to 3 minutes, and no answer , just the commercial and the you know,...all agents are busy but your call is important to us etc.. I think, maybe the mgt, does not know about this...if we complaint, maybe the will change... Hope so.,, we need them.... ON THE OTHER SIDE WICKS IS EXCELLENT ON THIS.. FAST ON THE PHONE, AND TWICE AS FAST ON SHIPPING... BUT THEY DON"T ALWAYS HAVE THE SAME THINGS ACS HAS...THEY ARE SAMALLER IN SOMES RESPECT... WELL WE WILL SEE IF MY LETTER WOULD HELP.. BERT RV6A > > ________________________________________________________________________________
Date: Sep 05, 2006
I order on their website. No problems. Ron Lee ________________________________________________________________________________
Date: Sep 05, 2006
I spoke with VM only a week ago. Friday and today when I called I heard a recording stating VM has moved. The new number given in the recording is 830-755-6330. I called the new number and received another recording. I left a message at the new number on Friday and have heard nothing back. The new number is in Boerne, Texas near San Antonio. I have unfinished work to be done on my system and need to contact them. I guess I will wait and hope someome calls. Late this afternoon I called JP Instruments and asked what was happening with VM. I could tell the person knew, but was unwilling to tell me. They said the Company Controller, Scott, would call me. Scott has not called. Roger Crandell _________________________________________________________________ Call friends with PC-to-PC calling -- FREE http://imagine-msn.com/messenger/launch80/default.aspx?locale=en-us&source=wlmailtagline ________________________________________________________________________________
Date: Sep 05, 2006
sorry to be sarcastic, but, 3 whole minutes, jeez..... BERTRV6(at)highstream.net wrote: > > Quoting Sam Buchanan : > > >> >> bertrv6(at)highstream.net wrote: >> >>> >>> >>> >>> Hi: >>> >>> I have tried for the past two weeks, to call Spruce, to place a small >>> >> order. >> >>> This is not exageration, I have made at least eight calls, Starting >>> at 12:00 my time, East Coast...to 4:30 PM.. >>> >>> No one ever answers, I have hold at one time for 3 minutes... >>> >> What number are you trying to call? >> >> Sam Buchanan >> SAM; I TRIED BOTH, I DO NOT MIND TO PAY FOR THE CALL, IF I CAN >> > GET SOME ONE TO ANSWER. > > > ONE IS THE 1.877 477.7823 and regular one 951.372.9555 > > I know they are not the fastest to answer the telephone, but for pete's sake > 2 weeks, waiting for up to 3 minutes, and no answer , just the commercial > and the you know,...all agents are busy but your call is important to us etc.. > > I think, maybe the mgt, does not know about this...if we complaint, > maybe the will change... > > Hope so.,, we need them.... ON THE OTHER SIDE WICKS IS EXCELLENT ON THIS.. > > FAST ON THE PHONE, AND TWICE AS FAST ON SHIPPING... BUT THEY DON"T ALWAYS > HAVE THE SAME THINGS ACS HAS...THEY ARE SAMALLER IN SOMES RESPECT... > > WELL WE WILL SEE IF MY LETTER WOULD HELP.. > > BERT > > RV6A > > > >> >> >> > > > -- ------------------------------------------------------------------- Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227, any and all nonsolicited commercial E-mail sent to this address is subject to a download and archival fee in the amount of $500 US. E-mailing denotes acceptance of these terms. -------------------------------------------------------------------- ________________________________________________________________________________
Date: Sep 05, 2006
Hi John- I spent (wasted?) an inordinate amount of effort (just because...) to develop one of these- see: http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=4968 ...for my take on the whole thing. In the end I opted (mostly for safety reasons: what happens when one of the springs breaks or comes un-attached/bound/etc.?) to adhere to the KISS thing and left it unconnected for phase I and didn't need it anyway. Rudder bias on departure for p-factor? "You put yer right foot in and you..." FWIW as usual From The PossumWorks in TN Mark Phillips RV-6A "Mojo" 350 hours pure grin time... ________________________________________________________________________________
Subject: Re: Forward Baggage Compartment Temperatures
Date: Sep 05, 2006
Dave, Suggest you consider insulating the firewall with 3M Vibration Dampinng Tape or equivalent. This will provide a fire barrier and also reduce temps to normal cabin temps. This is a standard insulation for aircraft and is readily available. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: "DAVID REEL" <dreel(at)cox.net> Sent: Monday, September 04, 2006 8:50 AM Subject: RV-List: Forward Baggage Compartment Temperatures > > Yesterday I measured a 110 degree Fahrenheit temperature close to the > firewall in the forward baggage compartment of my RV8A. The method was to > tape the wire lead of the outdoor sensor of an indoor/outdoor digital > thermometer to the firewall so that the sensor was held close but not > actually in contact with the firewall. Upon return from a half hour > flight, > I just opened the baggage compartment door and read the temperature about > 5 > minutes after landing. I also know that plastic bubble wrap which was in > contact with the firewall did not melt and that although you can touch the > firewall, it feels pretty hot. Outside air temp was 75 degrees F. > > Does anyone else have any information on the temperatures likely to be > experienced by baggage stowed in this area? > > Dave Reel - RV8A > > > ________________________________________________________________________________
Subject: Re: Cylinders: ECI vs Superior or Others
Date: Sep 05, 2006
FWIW just installed an engine with 171 hrs on Superior cylinders, and had to take #4 in for OH after lapping both valves. Rings wore out and piston scraping cyl wall. Superior said SORRY/ Charlie Heathco ________________________________________________________________________________
Date: Sep 05, 2006
Subject: RV 7 Wing Kit For Sale
Would the person who called me sometime around August 20 about the RV 7 wing kit I have for sale please call me again or email me? I've misplaced your phone number. Jim Hasper 615-595-4334 ________________________________________________________________________________
From: "L Klingmuller" <l_klingmuller6(at)earthlink.net>
Subject: Fuel flow pulsation dampener
Date: Sep 05, 2006
I have a J P fuel flow/fuel totalizer but are somewhat disappointed in the fuel flow readings. These fluctuate constantly within a +/- up to 1 gl/hr rate. Now my installation is not accordingly to the manufactures recommendation which calls for 6 inches of straight line on the inlet and outlet sides. I attached the sensor right to the gascolator out side since this seems to be a much sounder installation scheme. Questions for those who have been there: Is it worthwhile (time, $) to install the Dralle dampener?? I do not recall seeing too many post on this subject on the list. Could not find anything in the achieves. Lothar, 6A, 650 hrs ________________________________________________________________________________
Date: Sep 06, 2006
I have Superior cylinders s/n 8, 9, 10 , and 11 running for the past almost 9 years and 1,950 hours. Compression is still good and using 1 qt of oil every 6 hours. About ready to retire them. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,950 + Flying Hours So. CA, USA ----Original Message Follows---- From: "Charles Heathco" <cheathco(at)cox.net> Subject: Re: RV-List: Cylinders: ECI vs Superior or Others Date: Tue, 5 Sep 2006 21:36:54 -0500 FWIW just installed an engine with 171 hrs on Superior cylinders, and had to take #4 in for OH after lapping both valves. Rings wore out and piston scraping cyl wall. Superior said SORRY/ Charlie Heathco ________________________________________________________________________________
Date: Sep 05, 2006
Subject: Re: Relocating plane prior to phase one complete
Why don't you just go spend a good hard weekend or two of flying and burn off the hours, then do the real flight testing after you get to Texas? I had a similar situation and got my 40 hrs. flown off in less than 3 weeks of weekend flying. Proof of durability before your cross country meets the letter and spitit of the law, expecially if you then continue the testing later. Dave Leonard On 9/3/06, Tim Bryan wrote: > > > Hi Listers, > > I am planning to move to Texas from Oregon in mid to late October. My > plane will have been inspected and maybe 15 hours flown off by then. I > asked my DAR if I could get a ferry permit to move it to Texas. Since it > crosses several teritorries, he was not certain. Has anybody ever done > this? > > I definately want to have enough time on the plane to be comfortable and > have any issues worked out. But will need to establish a new phase one area > once it is relocated. > > Tim > RV-6 > N616TB > > * > > * > > -- David Leonard Turbo Rotary RV-6 N4VY My websites at: http://members.aol.com/_ht_a/rotaryroster/index.html http://members.aol.com/_ht_a/vp4skydoc/index.html http://leonardiniraq.blogspot.com ________________________________________________________________________________
Date: Sep 06, 2006
Subject: Re: Fuel flow pulsation dampener
I had a similar, but not quite so high, oscilation on my flow readings. I installed the dampener and it smoothed things out considerably. It's not much $ or much work to install, and I recommend it. Jeff Point RV-6 flying RV-8 preview plans Milwaukee >* >* > ________________________________________________________________________________
Date: Sep 06, 2006
In a message dated 9/6/06 2:44:29 AM Eastern Daylight Time, l_klingmuller6(at)earthlink.net writes: > I have a J P fuel flow/fuel totalizer but are somewhat disappointed in the > fuel flow readings. These fluctuate constantly within a +/- up to 1 gl/hr > rate. Now my installation is not accordingly to the manufactures > recommendation which calls for 6 inches of straight line on the inlet and > outlet sides. I attached the sensor right to the gascolator out side since > this seems to be a much sounder installation scheme. > > Questions for those who have been there: Is it worthwhile (time, $) to > install the Dralle dampener?? > I do not recall seeing too many post on this subject on the list. Could not > find anything in the achieves. > > Lothar, 6A, 650 hrs ========================================= Lothar: I have installed 5 fuel flow totalizes, that extra length of straight run depends on how you hooked up the fittings. Especially if you did a 90 Deg turn in fuel flow before entering or leaving the transducer. I have never used the Dralle Dampener, ONLY a smooth flow of fuel is required. In one case where a 90 Deg turn was needed I had to fabricate a fitting with oversized bores and a cut away internal turn. This either reduced or eliminated internal restriction or caviation. Questions: The variance you are seeing, I guess you are seeing it during S&L flight? How is the accuracy of the instrument on Gallons Remaining? By playing with the 'k' factor you might take the gage from a borderline reading into a more stabilized reading without affecting the Gallons Remaining reading. Barry "Chop'd Liver" ________________________________________________________________________________
Date: Sep 06, 2006
Over the past 6 years I have dealt with both companies frequently, literally spending thousands of dollars to support my addiction. As far as I am concerned, both Wicks and Spruce are national treasures. Both companies offer excellent service......generally. In my experience, Spruce's Jim Irwin will personally contact you relative to customer satisfaction issues or catalog suggestions. If you would like to see Spruce carry a particular item, by all means.....ask him....not necessarily the person who answers the phone. The fact that Spruce's catalog grows ever thicker by the year with a growing inventory of choices does not happen by accident. Nothing however, is perfect. On occasion, I have found Spruce's on-line ordering process to be flawed. It can sometimes be difficult to locate items you know they carry and at times prices are at variance with those posted in the print catalog. Just yesterday I placed a rather eclectic order and the on-line check-out cart indicated all the items were in stock. When the routine order confirmation arrrived via e-mail, it noted one item on backorder. I consider these to be a very minor frustrations and part of the price we sometimes pay for the convenience of e-commerce. As a people, we can be inclined towards instant gratification, the fast food expectation by another name. Well, homebuilt aircraft construction will puts the halts to that inclination very quickly. Instant gratification has no place in our hobby. I have become "almost" comfortable dealing with the frustration and deferred satisfactions that are an inevitable part of this hobby. Is it all worth it? Oh Yea....and then some. Rick Galati RV-6A "Darla" 165 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=59900#59900 ________________________________________________________________________________
Subject: RV Area at COPPERSTATE Regional EAA Fly-In
Date: Sep 06, 2006
Hello RV Listers- My Name is Jim McChesney. In addition to working full time and building an RV-7A I am in charge of Aircraft Parking at Copperstate Regional EAA Fly-In. This year's fly-in will be held at the Casa Grande, Arizona municipal airport (CGZ) from October 26-29, 2006. http://www.copperstate.org/> The reason for this post is to see if there is any interest in having an RV-specific area on the main showplane ramp this year? And, if so, is there anyone available and willing to staff such an area? We always have a really good showing from the RV guys but unfortunately I just don't have the volunteer manpower to staff an RV parking area. One person would NOT be able to do this alone so we'd need to assemble a crew of 3-4 people (minimum) to man this area. If anyone is interested in taking charge of this area or working there, please contact me off list. The usual perks apply: free admission, free food, plenty of sun. Jim McChesney RV-7A ________________________________________________________________________________
Date: Sep 06, 2006
Hi Mike, Thank You. I am expecting to get my inspection for AW in about two weeks =2E I want to fly enough hours to be sure I am comfortable with the plane and eliminate any squaks. How long do I need to allow to obtain the ferry permit? Thanks Tim -------Original Message------- From: Mike Robertson Date: 09/05/06 08:15:35 Subject: RE: RV-List: Relocating plane prior to phase one complete Tim, Call me at (503) 615-3237 and I will give you a hand to get a Ferry permi t to Texas. Mike Robertson Date: Sun, 3 Sep 2006 06:54:40 -0700 From: flyrv6(at)bryantechnology.com Subject: RV-List: Relocating plane prior to phase one complete Hi Listers, I am planning to move to Texas from Oregon in mid to late October. My pl ane will have been inspected and maybe 15 hours flown off by then. I asked m y DAR if I could get a ferry permit to move it to Texas. Since it crosses several teritorries, he was not certain. Has anybody ever done this? I definately want to have enough time on the plane to be comfortable and have any issues worked out. But will need to establish a new phase one a rea once it is relocated. Tim RV-6 N616TB t=_blank>
http://www.matronics.com/Navigator?RV-List p://forums.matronics.com //wiki.matronics.com blank>http://www.matronics.com/contribution Use Messenger to talk to your IM friends, even those on Yahoo! Talk now! ========== ========== ========== ========== ========== ________________________________________________________________________________
Date: Sep 06, 2006
Subject: Bose versus Lightspeed headset comparison
>Yesterday I had the chance to compare my Lightspeed (LS) Twenty 3G headsets against a pair of Bose. This is a quick, non-scientific review. I could detect an improvement in noise reduction with the Bose but suspect that the difference would be minimal or non-existent with a pair of LS Thirty 3G headsets (6 db better active noise reduction than Twenty 3G). The ear clamping force on the Bose was less which I thought would make them less effective in reducing noise. I was wrong. The Bose weighs about 120 grams (4 ounces) less. The earcup assemblies are about an inch thinner on the Bose. I did not wear the Bose for the entire flight so I can't make any comments about it being more comfortable but it is nice. It looks sleeker because of the smaller earcup assemblies. Bottom line is that I don't know that it would be worth $400 more than a pair of LS 30-3Gs. Ron Lee ________________________________________________________________________________
Date: Sep 06, 2006
If you get 25 hours on your phase one test flight period then you will need a minimum of 10 hours and have no mechanical discrepancies. If you have a 40 hours test period then you will need at least 15 hours and have no outs tanding discrepancies. You will also have to plot a route including all fu el stops. Needless to say the route must be over sparsely populated areas. Going from Bend to anywhere in Texas, that shouldn't be a problem. Mike Date: Wed, 6 Sep 2006 06:31:06 -0700From: flyrv6(at)bryantechnology.comTo: rv- list(at)matronics.comSubject: RE: RV-List: Relocating plane prior to phase one complete Hi Mike, Thank You. I am expecting to get my inspection for AW in about two weeks. I want to fly enough hours to be sure I am comfortable with the plane and eliminate any squaks. How long do I need to allow to obtain the ferry perm it? Thanks Tim -------Original Message------- From: Mike Robertson Date: 09/05/06 08:15:35 Subject: RE: RV-List: Relocating plane prior to phase one complete Tim, Call me at (503) 615-3237 and I will give you a hand to get a Ferry p ermit to Texas. Mike Robertson Date: Sun, 3 Sep 2006 06:54:40 -0700From: flyrv6(at)bryantechnology.comTo: rv- list(at)matronics.comSubject: RV-List: Relocating plane prior to phase one com plete Hi Listers, I am planning to move to Texas from Oregon in mid to late October. My plan e will have been inspected and maybe 15 hours flown off by then. I asked m y DAR if I could get a ferry permit to move it to Texas. Since it crosses several teritorries, he was not certain. Has anybody ever done this? I definately want to have enough time on the plane to be comfortable and ha ve any issues worked out. But will need to establish a new phase one area once it is relocated. Tim RV-6 N616TB t=_blank>http://www.matronics.com/Navigator?RV-List p://forums.matronics.com //wiki.matronics.com blank>http://www.matronics.com/contribution Use Messenger to talk to your IM friends, even those on Yahoo! Talk now! p://www.matronics.com/Navigator?RV-List onics.com s.com ww.matronics.com/contribution _________________________________________________________________ Use Messenger to talk to your IM friends, even those on Yahoo! http://ideas.live.com/programpage.aspx?versionId=7adb59de-a857-45ba-81cc- 685ee3e858fe ________________________________________________________________________________
Date: Sep 06, 2006
Mike Do you have metal flake paint on the fiberglass? Dick Martin informed me it did affect his antennas in his wing tips. I assume it would do the same in receiving the XM signal Dane Sheahen N838RV RV8a Subject: RV-List: XM Antenna through Fiberglass? I have had success mounting the GPS antenna under the fiberglass cowl, so I thought I'd try it with my XM antenna. It seems to work, but not as well. The weather seems to take longer to download and the music is spotty at times. I don't know if it is because I have it close to the baffles and it may be blocking reception during climbs in certain directions, or if it is because of the fiberglass. Has anyone had success mounting theirs under fiberglass?? Does anyone know if it should work? Thanks -Mike Kraus RV-4 flying RV-10 building ________________________________________________________________________________
Date: Sep 06, 2006
Subject: Re: Bose versus Lightspeed headset comparison
I have two pairs of Lightspeed headsets that I'm happy with the performance of. But earlier this year I had a problem with one and called Lightspeed for help. I was told that my model is no longer supported and they don't stock parts for it, but they invited me to upgrade to a newer model. I really don't think it's too much to ask that a company support and stock parts for a headset that's less than ten years old, so I wasn't very impressed with that. Fortunately, the problem turned out to be only a broken wire. But when an actual Lightspeed part eventually fails the headset will be scrap. I doubt that would happen with a David Clark, at the same age. --- Tedd McHenry Surrey, BC, Canada ________________________________________________________________________________
Date: Sep 06, 2006
Subject: Baggage Compartment Temperatures
Hi Dick, What was that 3M tape you were talking about. I'd like to explore using it on my fire wall. Jim Nelson ________________________________________________________________________________
Subject: Aircraft Spruce terrible Service?
Date: Sep 06, 2006
I have been quite pleased with Aircraft Spruce over the last couple of years. A few months ago I screwed up an on-line order and within a few minutes had an email from them telling me that I had provided an invalid credit card number. A few minutes later I received a call from them to straighten it out. I also see that they now provide virtually instant email quotes on avionics that they don't show prices for in their catalog. I get the impression that they have worked hard and successfully to correct previous inadequacies in their service. Unlike a few years ago, I now like to buy from them. Terry ________________________________________________________________________________
Date: Sep 06, 2006
On 11:18:51 2006-09-06 "Tim Bryan" wrote: > At ten years this could very well be the case with your 50K car. > After ten years the parts start to dry up. Unless the aftermarket > picks up the molds or it is a component that is available through the > local auto zone. Tim Maybe if it's american-made... But i've never had problems obtaining parts for 15-20 year old japanese cars or motorcycles. Honda always seems to have parts. You'll just have to pay exorbitant amounts of money for them... -Rob ________________________________________________________________________________
Subject: RE: Aircraft Spruce terrible Service?
Date: Sep 06, 2006
I have ordered from ACS for about 6 years and must state they have always provided me with outstanding service and pricing. Because of my remote location, I order many items using the internet. ACS is one of, if not the best I have ever dealt with. How many internet businesses will ship instock items immediately and later ship the backordered items free of charge? Roger Crandell _________________________________________________________________ Got something to buy, sell or swap? Try Windows Live Expo ttp://clk.atdmt.com/MSN/go/msnnkwex0010000001msn/direct/01/?href=http://expo.live.com/ ________________________________________________________________________________
Date: Sep 06, 2006
Tedd McHenry wrote: > >I have two pairs of Lightspeed headsets that I'm happy with the performance of. >But earlier this year I had a problem with one and called Lightspeed for help. >I was told that my model is no longer supported and they don't stock parts for >it, but they invited me to upgrade to a newer model. > >I really don't think it's too much to ask that a company support and stock >parts for a headset that's less than ten years old, so I wasn't very impressed >with that. Fortunately, the problem turned out to be only a broken wire. But >when an actual Lightspeed part eventually fails the headset will be scrap. I >doubt that would happen with a David Clark, at the same age. > >--- > >Tedd McHenry >Surrey, BC, Canada > Hi Tedd, Since I'm the originator of the recent 'rant' controversy, I thought I might play 'devil's advocate' for a change. I feel your frustration, since I just went through the exact same issue with a pair of 20K's (which I bought used, from an individual) and a pair of 15XL's that I bought new. My experience was that the tech guy said that they *might* not be able to fix the 20K's; I could trade them up if I wanted; but send them anyway & they'd take a look. I just got both sets back today, repaired, no charge, including wear items like the pads (2nd time, free, on the 15XL's). I was planning to write the list tonight to praise LS for their excellent service when I read your post. Here's my 'devil's advocate' position: When I ran a consumer electronics repair company in a previous life (no sales; just repair) & we had to tell a customer that their stereo/tv/vcr/etc wasn't worth fixing, most got really frustrated with us, even though we didn't sell the product to them. My explanation usually ran something like, "I know it's only x years old, but you only paid y dollars for it. If you had paid 3 times y dollars for it, it would be worth fixing. I think you came out ahead, even though it's hard to adjust to 'disposable' products." Manufacturers of almost all products are pushing us into disposable products by jacking up the replacement parts prices so high they can stay legal (automotive, for example) by keeping just a couple of parts on a shelf somewhere priced at half the value of the product. The upside is that most mass produced products have gotten incredibly inexpensive relative to what they do. The LS headsets are (mostly) constructed of very inexpensive, often flimsy, parts. The purchase price, compared to the high end stuff, reflects it. One of the ways to keep costs down is not restocking custom parts after changing models (common practice; there's a particular relatively high dollar GPS brand that quit supplying even database updates after just 3 or 4 years, a while back). The impressive thing about LS is that I've never heard of anyone that paid for a repair on them, no matter what the age. Not so for some of the high end brands. The $1k brands can probably be fixed 'forever' but it's likely to cost almost as much as a new pair of LS for each repair. I can't stop without griping about something; they wouldn't let me trade in the 20K's on a pair of the new in-the-ear models. :-) Charlie ________________________________________________________________________________
Date: Sep 06, 2006
Barry, Our oil cooler came from Vans, 4/11/2001, part number 4215, per Vans invoice; "EA OIL COOLER 4215, OIL COOLER FOR IO-360". I had forgotten our cooler was for the IO and not the "O" model, but I would recommend it. We have the O-360, 180 hp. I will try to find the mfg info next time I take the bottom cowl off. Maybe Vans can tell you who makes the #4215. Pic attached. Dale -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of FLYaDIVE(at)aol.com Sent: Tuesday, September 05, 2006 11:09 AM Subject: RV-List: 10 Vane Oil Cooler Hey Flight: Who is the manufacture and what is the part number for the 10 Vane Oil Cooler used on the RV-6 with an O-360? Thanks for the feedback, Barry ________________________________________________________________________________
Subject: Re: Baggage Compartment Temperatures
Date: Sep 06, 2006
Jim, It is called 3M VIBRATION DAMPING TAPE. It is used by commercial medium and large twin engine type repair and refurbishing companys. It is also used by none aviation users. Suggest you try 3M website for vendors in your area. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: "James H Nelson" <rv9jim(at)juno.com> Sent: Wednesday, September 06, 2006 1:05 PM Subject: RV-List: Baggage Compartment Temperatures > > Hi Dick, > What was that 3M tape you were talking about. I'd like to > explore using it on my fire wall. > > Jim Nelson > > > ________________________________________________________________________________
Date: Sep 06, 2006
I still can't believe this continues to be a recurring thread. My opinion only, (not sure why it is not more common, though!) is that to ME it's worth the $1K for the quality, comfort, and most of all, piece of mind that I won't ever have to send them back....I don't care if LS sends me a new pair every time or repairs them...the bottom line is you have to send them back and be without headsets, pay shipping charges to LS, and frankly, is a pain in the rear. I'll reiterate from my previous posts...I've had the Bose X for 6 years now, and have about 1000 hours on a pair. The most of those hours were in and out of Cessnas while I was a flight instructor, in all kinds of heat, cold, rain, etc, and not one blip out of them in all that time. To ME, it's worth not every buying another pair, or having to send one back. Not to mention, I feel that they are far more comfortable, even if the ANR quality is close enough between the two. I now have two pairs of Bose X headsets for the above reasons and don't have the slightest regret for spending the money...especially when they have no interest over 12 months. We are airplane builders, flyers, etc..nobody said it was a cheap hobby! Again, my opinion only! Paul Besing Charlie England wrote: Tedd McHenry wrote: > >I have two pairs of Lightspeed headsets that I'm happy with the performance of. >But earlier this year I had a problem with one and called Lightspeed for help. >I was told that my model is no longer supported and they don't stock parts for >it, but they invited me to upgrade to a newer model. > >I really don't think it's too much to ask that a company support and stock >parts for a headset that's less than ten years old, so I wasn't very impressed >with that. Fortunately, the problem turned out to be only a broken wire. But >when an actual Lightspeed part eventually fails the headset will be scrap. I >doubt that would happen with a David Clark, at the same age. > >--- > >Tedd McHenry >Surrey, BC, Canada > Hi Tedd, Since I'm the originator of the recent 'rant' controversy, I thought I might play 'devil's advocate' for a change. I feel your frustration, since I just went through the exact same issue with a pair of 20K's (which I bought used, from an individual) and a pair of 15XL's that I bought new. My experience was that the tech guy said that they *might* not be able to fix the 20K's; I could trade them up if I wanted; but send them anyway & they'd take a look. I just got both sets back today, repaired, no charge, including wear items like the pads (2nd time, free, on the 15XL's). I was planning to write the list tonight to praise LS for their excellent service when I read your post. Here's my 'devil's advocate' position: When I ran a consumer electronics repair company in a previous life (no sales; just repair) & we had to tell a customer that their stereo/tv/vcr/etc wasn't worth fixing, most got really frustrated with us, even though we didn't sell the product to them. My explanation usually ran something like, "I know it's only x years old, but you only paid y dollars for it. If you had paid 3 times y dollars for it, it would be worth fixing. I think you came out ahead, even though it's hard to adjust to 'disposable' products." Manufacturers of almost all products are pushing us into disposable products by jacking up the replacement parts prices so high they can stay legal (automotive, for example) by keeping just a couple of parts on a shelf somewhere priced at half the value of the product. The upside is that most mass produced products have gotten incredibly inexpensive relative to what they do. The LS headsets are (mostly) constructed of very inexpensive, often flimsy, parts. The purchase price, compared to the high end stuff, reflects it. One of the ways to keep costs down is not restocking custom parts after changing models (common practice; there's a particular relatively high dollar GPS brand that quit supplying even database updates after just 3 or 4 years, a while back). The impressive thing about LS is that I've never heard of anyone that paid for a repair on them, no matter what the age. Not so for some of the high end brands. The $1k brands can probably be fixed 'forever' but it's likely to cost almost as much as a new pair of LS for each repair. I can't stop without griping about something; they wouldn't let me trade in the 20K's on a pair of the new in-the-ear models. :-) Charlie --------------------------------- Get your email and more, right on the new Yahoo.com ________________________________________________________________________________
Date: Sep 07, 2006
3M lists several metal foil vibration damping tapes. 2552 tape is for 40 to 140 degrees F which would be OK for the 110 degree F I measured on my firewall. 434, 435, and 436 tapes are for -76 to 68 degrees F. Too low to dampen vibration on the firewall at 110 degrees F. However, I'm more interested in temperature reduction than vibration damping & 3M is quiet concerning this property. Perhaps there is an insulating tape or ??? Dave Reel - RV8A ________________________________________________________________________________
Subject: decorative prop
Date: Sep 07, 2006
My apologies for the spam. Delete if not interested. Here's a nice Hartzell 2 blade unairworthy prop to put on your wall. Similar, but slightly smaller to the Hartzells found on many Rockets and RV's. http://cgi.ebay.com/ebaymotors/Hartzell-constant-speed-prop-propeller_W0 QQitemZ290026847977QQihZ019QQcategoryZ26439QQssPageNameZWDVWQQrdZ1QQcmdZ ViewItem Vince ________________________________________________________________________________
Subject: Re: Visionmicro Systems Moved or sold?
Date: Sep 07, 2006
I too talk to VM on Thursday of last week and they said they would have to research my question and that they would get back to me last Friday or Monday... Well, almost a week gone by now and they haven't contacted me or returned my phone calls or emails... I'm getting a little aggravated to say the least! There website now says: "Dear Valued VMS Customer: Due to circumstances beyond our control, Vision Microsystems is being moved to Texas. The new location for VMS will be: 28120 Boerne Stage Airport Hanger 302 Boerne, TX 78006 Phone 830-755-6330 We are trying to make this a seamless transition and will try to ship small items during the transition. VMS is expecting to be fully operational by the end of November. Thank you for your cooperation. " I hope we don't have to wait until the end of November to get our questions answered and products shipped.... John Loretz RV8 - Denver, Colorado On Sep 5, 2006, at 6:32 PM, Roger Crandell wrote: > > I spoke with VM only a week ago. Friday and today when I called I > heard a recording stating VM has moved. The new number given in > the recording is 830-755-6330. I called the new number and > received another recording. I left a message at the new number on > Friday and have heard nothing back. The new number is in Boerne, > Texas near San Antonio. I have unfinished work to be done on my > system and need to contact them. I guess I will wait and hope > someome calls. > > Late this afternoon I called JP Instruments and asked what was > happening with VM. I could tell the person knew, but was unwilling > to tell me. They said the Company Controller, Scott, would call > me. Scott has not called. > > > Roger Crandell > > _________________________________________________________________ > Call friends with PC-to-PC calling -- FREE http://imagine-msn.com/ > messenger/launch80/default.aspx?locale=en-us&source=wlmailtagline > > ________________________________________________________________________________
Date: Sep 07, 2006
All, I just spoke to Vision Micro... They freturned my call. They said they are alive and well, but they are having to relocate their facilities to Texas. He said that they are returning phone calls, just bear with them. Blue Skies, John On Sep 7, 2006, at 8:02 AM, John Loretz wrote: > > I too talk to VM on Thursday of last week and they said they would > have to research my question and that they would get back to me > last Friday or Monday... Well, almost a week gone by now and they > haven't contacted me or returned my phone calls or emails... > > I'm getting a little aggravated to say the least! There website > now says: > > > "Dear Valued VMS Customer: > Due to circumstances beyond our control, Vision Microsystems is > being moved to Texas. The new location for VMS will be: > > 28120 Boerne Stage Airport > Hanger 302 > Boerne, TX 78006 > > Phone 830-755-6330 > > We are trying to make this a seamless transition and will try to > ship small items during the transition. VMS is expecting to be > fully operational by the end of November. > > Thank you for your cooperation. " > > > I hope we don't have to wait until the end of November to get our > questions answered and products shipped.... > > John Loretz > RV8 - Denver, Colorado > > > On Sep 5, 2006, at 6:32 PM, Roger Crandell wrote: > >> >> I spoke with VM only a week ago. Friday and today when I called I >> heard a recording stating VM has moved. The new number given in >> the recording is 830-755-6330. I called the new number and >> received another recording. I left a message at the new number on >> Friday and have heard nothing back. The new number is in Boerne, >> Texas near San Antonio. I have unfinished work to be done on my >> system and need to contact them. I guess I will wait and hope >> someome calls. >> >> Late this afternoon I called JP Instruments and asked what was >> happening with VM. I could tell the person knew, but was >> unwilling to tell me. They said the Company Controller, Scott, >> would call me. Scott has not called. >> >> >> >> Roger Crandell >> >> _________________________________________________________________ >> Call friends with PC-to-PC calling -- FREE http://imagine- >> msn.com/messenger/launch80/default.aspx?locale=en- >> us&source=wlmailtagline >> >> >> >> > > ________________________________________________________________________________
Date: Sep 08, 2006
Subject: Man I hate to do this... (Marhyde update)
Howdy Listers- Just to add fuel to the Primer Wars, please take a look here if you are interested in using self-etching primers on your project: http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=4863 Please reply OFF-LIST if any ?s... >From The PossumWorks in TN Mark Phillips - RV-6A "Mojo" 350 hrs since January, '04 ________________________________________________________________________________
Date: Sep 08, 2006
Subject: Aircraft Spruce -- Great Service
Sorry for changing the subject line. I think that we should keep them separate! After calling customer service and getting nowhere, I posted what I thought was a legitimate complaint about ACS a couple of years ago on this list. Within a day I got a response from Jim Irwin saying that was not how ACS did business, and corrected the problem in a very professional manner. I am glad that Aircraft Spruce is in business, and I count myself among their many satisfied customers. Just placed another order a few minutes ago, in fact. Dan Hopper RV-7A ________________________________________________________________________________
Date: Sep 08, 2006
Subject: Re: Man I hate to do this... (Marhyde update)
Aww come on Mark... enquiring minds want to know; What's your opinion ? Fiveonepw(at)aol.com wrote: Howdy Listers- Just to add fuel to the Primer Wars, please take a look here if you are interested in using self-etching primers on your project: http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=4863 Please reply OFF-LIST if any ?s... From The PossumWorks in TN Mark Phillips - RV-6A "Mojo" 350 hrs since January, '04 --------------------------------- All-new Yahoo! Mail - Fire up a more powerful email and get things done faster. ________________________________________________________________________________
Date: Sep 08, 2006
Subject: Curious
Just curious.... I'm running an IO-320 (Ly-con) with Bendix injections, mechanical fuel pump and an electric "Dukes Inc." boost-pump. The Duke takes a dump (spins but won't pressure up). I find out the replacement Duke is $600 plus core, shipping and tax ($900 area). I went with the Duke because I got it in trade; I use to use Performance Air (?) but their price sucks too and I hated the added weight & complexity of their recommended fuel filter. Seeking thoughts & recommendations: 1. Cough-up the bucks and get the replacement Duke. 2. Crack-open the Duke's seals ans see if I can repair (might be just a spun nut/cotter-key/or sumpin' like the nylatron pump vane). 3. Skip the boost pump 'cuz I never use it anyway... 4. Forget this ever increasin' overly-expensive flyin' sh!t and spend the $$$ on girls & surfin' 5. Your suggestions........... Thanks. Chuck --------------------------------- ________________________________________________________________________________
Date: Sep 08, 2006
Subject: Re: Aircraft Spruce -- Great Service ... LOL
In a message dated 9/8/06 11:15:21 AM Eastern Daylight Time, Hopperdhh(at)aol.com writes: > Sorry for changing the subject line. I think that we should keep them > separate! > > After calling customer service and getting nowhere, I posted what I thought > > was a legitimate complaint about ACS a couple of years ago on this list. > Within a day I got a response from Jim Irwin saying that was not how ACS > did > business, and corrected the problem in a very professional manner. I am > glad > that Aircraft Spruce is in business, and I count myself among their many > satisfied customers. Just placed another order a few minutes ago, in fact. > > Dan Hopper > RV-7A ======================== Dan: I am in a $1066 dispute with ACS right now. So far I have been given all the rhetoric that can flow from Jim Irwin's underlings. Today alone I have been put on hold for 28 minutes waiting for a call back since 1800 Z ... The time now is 2200 Z. Dan, would you happen to have Jim Irwin's phone number or direct email? Truly great service is determined not when everything goes smooth but how well they smooth out the bumps. Barry PS I'm sick of hearing Jim talk about ACS as a FAMILY. I would not treat my FAMILY the way ACS treats their customers. ________________________________________________________________________________
Date: Sep 08, 2006
Subject: Re: RV6 down in Petaluma
NTSB Identification: LAX06LA275 14 CFR Part 91: General Aviation Accident occurred Sunday, August 27, 2006 in Novato, CA Aircraft: Terry Tevis RV-6A, registration: N312RV Injuries: 2 Fatal. This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. On August 27, 2006, about 2200 Pacific daylight time, an experimental amateur-built Tevis RV-6A airplane, N312RV, impacted terrain about 2 miles north of the Gnoss Field Airport near Novato, California. The private pilot and passenger sustained fatal injuries. The airplane was substantially damaged. The airplane was built and operated by the pilot under the provisions of 14 CFR Part 91 as a personal flight. The flight originated from the Lincoln Regional Airport, Lincoln, California, around 2100, and was destined for Petaluma, California. Dark night conditions prevailed and a flight plan was not filed for the flight. According to the pilot's family, he had flown the airplane from Petaluma to Lincoln earlier in the day. The family took the pilot and passenger to the Lincoln airport around 2030, and they believe they departed around 2100. The pilot's hangar and car were located at Petaluma. According to the Federal Aviation Administrator (FAA) inspector who responded to the accident site, the airplane impacted a hill leaving prop strikes in the ground. The wreckage was scattered along a debris path that stretched approximately 250 feet. -----Original Message----- From: me(at)parkerthomas.com Sent: Mon, 28 Aug 2006 9:20 PM Subject: RV-List: RV6 down in Petaluma Sad news about a couple guys in a RV-6 up in Petaluma today. Anybody know anything? http://www.sfgate.com/cgi-bin/article.cgi?f=/c/a/2006/08/28/BAGR8KQNVS4.DTL Parker Thomas RV-6A 421PT ________________________________________________________________________ ________________________________________________________________________________
Subject: Re: Curious
Date: Sep 08, 2006
My vote goes to the girls and surfing.. but they cost alot more than the new fuel pump.. the airplane does what you say... how many women do that ? plus if you have an airplane, maybe you can do all three :) on 2nd thought, get the new duke and getover it.. ----- Original Message ----- From: Chuck To: rv-list(at)matronics.com Sent: Friday, September 08, 2006 3:54 PM Subject: RV-List: Curious Just curious.... I'm running an IO-320 (Ly-con) with Bendix injections, mechanical fuel pump and an electric "Dukes Inc." boost-pump. The Duke takes a dump (spins but won't pressure up). I find out the replacement Duke is $600 plus core, shipping and tax ($900 area). I went with the Duke because I got it in trade; I use to use Performance Air (?) but their price sucks too and I hated the added weight & complexity of their recommended fuel filter. Seeking thoughts & recommendations: 1. Cough-up the bucks and get the replacement Duke. 2. Crack-open the Duke's seals ans see if I can repair (might be just a spun nut/cotter-key/or sumpin' like the nylatron pump vane). 3. Skip the boost pump 'cuz I never use it anyway... 4. Forget this ever increasin' overly-expensive flyin' sh!t and spend the $$$ on girls & surfin' 5. Your suggestions........... Thanks. Chuck ------------------------------------------------------------------------- ----- Get your own web address for just $1.99/1st yr. We'll help. --> http://forums.matronics.com http://wiki.matronics.com =========== ________________________________________________________________________________
Date: Sep 08, 2006
Subject: For Sale -- RV-7
Posting this message makes my stomach hurt ........................... Due to personal (any male will understand this means "divorce") reasons I a m forced to sell my RV7 kit. The specifics are listed below. I will gladly answer any questions anyone may have (even build questions). I bought this kit a few years ago and hav e almost completed it. While I am required to sell this kit, this is NOT a fire sale. Any real RV'er will quickly realize there is over $60K in part s alone listed with no compensation for build time. A month ago I placed t his kit on a trailer in a secured storage unit located in northern Indiana. I am currently working in Washington DC, but will gladly meet with a SERI OUS buyer to show the plane. Please, if you really want to buy an exceptio nal kit at a reasonable price then fine, contact me. If you just want to l ook at an RV then please go to your local airport. There are many exceptio nal RVs and the owners are all great people who will let you bend their ear . My point is .... please don't waste my time. Interested persons may con tact me directly at the following email: jrlewismail-rv(at)yahoo.com For now I will not set a price, but will rather solicit reasonable offers. I will know a lot about you by the questions you ask and the offer you sug gest. If your comments are ridiculous then it is unlikely you will succeed in convincing me to fly to Indiana to show you my plane. Sorry, just bein g honest. For the serious RV'ers, please feel free to pass this info to anyone you kn ow who is not on this board but who you think might be interested. Info on my plane: RV-7 w/ slider =93 QB complete with kit parts Build Status: Ready for engine / panel / canopy install Equipment / Accessories: - Fuel tank flop tubes for inverted flight - Strobes - 2 axis Auto-Pilot W/ Vertical Speed Hold & GPS Track (servos installed) - Blue Mountain Avionics EFIS - RMI Monitor - RMI Encoder w/independent compass system - Dynon EFIS - Dual Pitot static systems - Landing light - Taxi Light - Electric Aileron and Elevator Trim - Custom stick grips enable trim, auto-pilot, and nav control - Electric Flaps - EMI Fuel Monitor System - Wingtip comm./nav antennas - Sitting on a custom built 20 ft flatbed trailer - Top aviation grade wiring installed Over $60K invested (not including any build time) - If it looks like I have made a typo then ask.. I will clarify what I have written. ________________________________________________________________________________
Date: Sep 08, 2006
In a message dated 9/8/2006 5:09:01 P.M. Eastern Daylight Time, FLYaDIVE(at)aol.com writes: --> RV-List message posted by: FLYaDIVE(at)aol.com In a message dated 9/8/06 11:15:21 AM Eastern Daylight Time, Hopperdhh(at)aol.com writes: > Sorry for changing the subject line. I think that we should keep them > separate! > > After calling customer service and getting nowhere, I posted what I thought > > was a legitimate complaint about ACS a couple of years ago on this list. > Within a day I got a response from Jim Irwin saying that was not how ACS > did > business, and corrected the problem in a very professional manner. I am > glad > that Aircraft Spruce is in business, and I count myself among their many > satisfied customers. Just placed another order a few minutes ago, in fact. > > Dan Hopper > RV-7A ======================== Dan: I am in a $1066 dispute with ACS right now. So far I have been given all the rhetoric that can flow from Jim Irwin's underlings. Today alone I have been put on hold for 28 minutes waiting for a call back since 1800 Z ... The time now is 2200 Z. Dan, would you happen to have Jim Irwin's phone number or direct email? Truly great service is determined not when everything goes smooth but how well they smooth out the bumps. Barry PS I'm sick of hearing Jim talk about ACS as a FAMILY. I would not treat my FAMILY the way ACS treats their customers. ________________________________________________________________________________
Date: Sep 08, 2006
Barry, Go in to some detail here on the list and I'm sure Jim will get in touch with you and get it settled real soon! No, it has been about 2 years ago. I had the same experience with "customer service." Dan In a message dated 9/8/2006 5:09:01 P.M. Eastern Daylight Time, FLYaDIVE(at)aol.com writes: --> RV-List message posted by: FLYaDIVE(at)aol.com In a message dated 9/8/06 11:15:21 AM Eastern Daylight Time, Hopperdhh(at)aol.com writes: > Sorry for changing the subject line. I think that we should keep them > separate! > > After calling customer service and getting nowhere, I posted what I thought > > was a legitimate complaint about ACS a couple of years ago on this list. > Within a day I got a response from Jim Irwin saying that was not how ACS > did > business, and corrected the problem in a very professional manner. I am > glad > that Aircraft Spruce is in business, and I count myself among their many > satisfied customers. Just placed another order a few minutes ago, in fact. > > Dan Hopper > RV-7A ======================== Dan: I am in a $1066 dispute with ACS right now. So far I have been given all the rhetoric that can flow from Jim Irwin's underlings. Today alone I have been put on hold for 28 minutes waiting for a call back since 1800 Z ... The time now is 2200 Z. Dan, would you happen to have Jim Irwin's phone number or direct email? Truly great service is determined not when everything goes smooth but how well they smooth out the bumps. Barry PS I'm sick of hearing Jim talk about ACS as a FAMILY. I would not treat my FAMILY the way ACS treats their customers. ________________________________________________________________________________
Date: Sep 08, 2006
In a message dated 9/8/06 9:04:17 PM Eastern Daylight Time, Hopperdhh(at)aol.com writes: > Barry, > > Go in to some detail here on the list and I'm sure Jim will get in touch > with you and get it settled real soon! > > No, it has been about 2 years ago. I had the same experience with " > customer service." > > Dan ========================== Dan: I'm going to wait just a little bit longer and see if the person I talked to will follow through and offer a proper solution. Then if nothing happens I will peruse a different path. I'm only the mechanic on the plane with the problem. I don't want to air dirty laundry for no reason. Bad publicity is hard to correct. Barry ________________________________________________________________________________
Date: Sep 08, 2006
Subject: looking for Reno Tix
I'm looking for 2 admissions and 2 Reno Chairmans Club tickets for either Friday, Saturday, or Sunday. Russ ________________________________________________________________________________
Subject: Curious
Date: Sep 09, 2006
The Airflow Performance boost pump is around 500.00 bucks. Lighweight, simple in design and works. Everybody I know has problems with Duke pumps and end up chucking them in the trash. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sportypilot Sent: Friday, September 08, 2006 4:52 PM Subject: Re: RV-List: Curious My vote goes to the girls and surfing.. but they cost alot more than the new fuel pump.. the airplane does what you say... how many women do that ? plus if you have an airplane, maybe you can do all three :) on 2nd thought, get the new duke and getover it.. ----- Original Message ----- From: Chuck <mailto:chuck515tigger(at)yahoo.com> To: rv-list(at)matronics.com Sent: Friday, September 08, 2006 3:54 PM Subject: RV-List: Curious Just curious.... I'm running an IO-320 (Ly-con) with Bendix injections, mechanical fuel pump and an electric "Dukes Inc." boost-pump. The Duke takes a dump (spins but won't pressure up). I find out the replacement Duke is $600 plus core, shipping and tax ($900 area). I went with the Duke because I got it in trade; I use to use Performance Air (?) but their price sucks too and I hated the added weight & complexity of their recommended fuel filter. Seeking thoughts & recommendations: 1. Cough-up the bucks and get the replacement Duke. 2. Crack-open the Duke's seals ans see if I can repair (might be just a spun nut/cotter-key/or sumpin' like the nylatron pump vane). 3. Skip the boost pump 'cuz I never use it anyway... 4. Forget this ever increasin' overly-expensive flyin' sh!t and spend the $$$ on girls & surfin' 5. Your suggestions........... Thanks. Chuck ________________________________ Get your own web address for just $1.99/1st yr. We'll help. <http://us.rd.yahoo.com/evt=41244/*http:/smallbusiness.yahoo.com/> <http://us.rd.yahoo.com/evt=41244/*http:/smallbusiness.yahoo.com/> the Web <http://us.rd.yahoo.com/evt=41244/*http:/smallbusiness.yahoo.com/> --> <http://us.rd.yahoo.com/evt=41244/*http:/smallbusiness.yahoo.com/> =========== ________________________________________________________________________________
Date: Sep 09, 2006
A friend of mine rebuilt his Dukes pump, and I got to look at the innards when he had it apart. They're pretty simple inside, its just a vane pump with a check valve/bypass. The vanes were made of teflon IIRC. I think he paid $160 for the rebuild kit. Regards, Bob Japundza RV-6 flying F1 under const. On 9/8/06, Chuck wrote: > > Just curious.... > > I'm running an IO-320 (Ly-con) with Bendix injections, mechanical fuel > pump and an electric "Dukes Inc." boost-pump. The Duke takes a dump > (spins but won't pressure up). I find out the replacement Duke is $600 > plus core, shipping and tax ($900 area). I went with the Duke because I > got it in trade; I use to use Performance Air (?) but their price sucks too > and I hated the added weight & complexity of their recommended fuel filter. > > Seeking thoughts & recommendations: > > 1. Cough-up the bucks and get the replacement Duke. > 2. Crack-open the Duke's seals ans see if I can repair (might be just a > spun nut/cotter-key/or sumpin' like the nylatron pump vane). > 3. Skip the boost pump 'cuz I never use it anyway... > 4. Forget this ever increasin' overly-expensive flyin' sh!t and spend the > $$$ on girls & surfin' > 5. Your suggestions........... > > Thanks. > > Chuck > > ------------------------------ > * > > ________________________________________________________________________________
Date: Sep 09, 2006
Bob, Thanks for telling me that. Can you get the contact info for the rebuild kit. So far my research has yielded negative results. I was afraid Duke's parts were somehow proprietary and classified next to unobtainium on the Elements chart. I will crack her seals tomorrow morning and report back. Like what's his name said "... why not open her up, you've got nothing to lose." You know, ocassionally I do enjoy this list for actual RV related stuff (not just to laugh my a$$ off at ALL the pissin' & moanin' & flame wars :-) Chuck "Bob J." wrote: A friend of mine rebuilt his Dukes pump, and I got to look at the innards when he had it apart. They're pretty simple inside, its just a vane pump with a check valve/bypass. The vanes were made of teflon IIRC. I think he paid $160 for the rebuild kit. Regards, Bob Japundza RV-6 flying F1 under const. On 9/8/06, Chuck < chuck515tigger(at)yahoo.com > wrote: Just curious.... I'm running an IO-320 (Ly-con) with Bendix injections, mechanical fuel pump and an electric "Dukes Inc." boost-pump. The Duke takes a dump (spins but won't pressure up). I find out the replacement Duke is $600 plus core, shipping and tax ($900 area). I went with the Duke because I got it in trade; I use to use Performance Air (?) but their price sucks too and I hated the added weight & complexity of their recommended fuel filter. Seeking thoughts & recommendations: 1. Cough-up the bucks and get the replacement Duke. 2. Crack-open the Duke's seals ans see if I can repair (might be just a spun nut/cotter-key/or sumpin' like the nylatron pump vane). 3. Skip the boost pump 'cuz I never use it anyway... 4. Forget this ever increasin' overly-expensive flyin' sh!t and spend the $$$ on girls & surfin' 5. Your suggestions........... Thanks. Chuck --------------------------------- Get your own web address for just $1.99/1st yr. We'll help. --------------------------------- ________________________________________________________________________________
Date: Sep 09, 2006
If I had to guess it sounds like a check valve seal. They'll sell you the individual seals, according to my buddy. http://www.dukesinc.com/contact.html Regards, Bob Japundza RV-6 flying F1 under const On 9/9/06, Chuck wrote: > > Bob, > > Thanks for telling me that. Can you get the contact info for the rebuild > kit. So far my research has yielded negative results. I was afraid > Duke's parts were somehow proprietary and classified next to unobtainium on > the Elements chart. > > I will crack her seals tomorrow morning and report back. Like what's his > name said "... why not open her up, you've got nothing to lose." You > know, ocassionally I do enjoy this list for actual RV related stuff (not > just to laugh my a$$ off at ALL the pissin' & moanin' & flame wars :-) > > Chuck > > > *"Bob J." * wrote: > > A friend of mine rebuilt his Dukes pump, and I got to look at the innards > when he had it apart. They're pretty simple inside, its just a vane pump > with a check valve/bypass. The vanes were made of teflon IIRC. I think he > paid $160 for the rebuild kit. > > Regards, > Bob Japundza > RV-6 flying F1 under const. > > On 9/8/06, Chuck < chuck515tigger(at)yahoo.com > wrote: > > > > Just curious.... > > > > I'm running an IO-320 (Ly-con) with Bendix injections, mechanical fuel > > pump and an electric "Dukes Inc." boost-pump. The Duke takes a dump > > (spins but won't pressure up). I find out the replacement Duke is $600 > > plus core, shipping and tax ($900 area). I went with the Duke because I > > got it in trade; I use to use Performance Air (?) but their price sucks too > > and I hated the added weight & complexity of their recommended fuel filter. > > > > Seeking thoughts & recommendations: > > > > 1. Cough-up the bucks and get the replacement Duke. > > 2. Crack-open the Duke's seals ans see if I can repair (might be just a > > spun nut/cotter-key/or sumpin' like the nylatron pump vane). > > 3. Skip the boost pump 'cuz I never use it anyway... > > 4. Forget this ever increasin' overly-expensive flyin' sh!t and spend > > the $$$ on girls & surfin' > > 5. Your suggestions........... > > > > Thanks. > > > > Chuck > > ------------------------------ > > * > > > ________________________________________________________________________________
Date: Sep 10, 2006
Subject: RV-7 F-770 forward side skin 'pucker factor' question
Greetings -7 fuselage builders, I've got a glitch with my F-770 forward side skins. With the mid section belly skin clecoed to the tailcone @ F706, when I add the F770 side skins & cleco them to the F704, 705 & 706 bulkheads I get a 'pucker' in the bottom edge of the skin between the rear spar carry-through & the change in angle of the bottom skin where the F-770 curved portion starts. This is where the 770 would (I assume) get riveted to the flange of the F-623 rib that lies flat in the belly skin on each side. Both sides do this. I've removed one skin & rolled the bottom corner to fit the tailcone, & it still has the 'pucker'. With the 770 clecoed to F705 bulkhead there is about a 1/4" gap at midpoint between the rear spar & the point at which the curved transistion begins. Again, one side has been curved to transition around to the belly & the other is still unbent; both exhibit the same bulge. Related question: I see in my instructions one note that says 'don't install the F-623 ribs now' but I can't find any instruction to actually install them. Anyone seen that instruction? All I've seen is an instruction to install the forward doubler attach tab for the F-623's. Thanks, Charlie ________________________________________________________________________________
Date: Sep 10, 2006
Subject: Gretz Aero Pitot Wiring
I have a GA-1000 heated Pitot on back-order so I don't have the install info yet. Does anyone have the details of the wiring required and the panel indicator. I tried Stein Air and Warren Gretz, so far no answers. RV7A Wiring Ralph Hoover ________________________________________________________________________________
Subject: RV8 A - Quickbuild vs. Standard
Date: Sep 10, 2006
Hi everybody, this is my first post on this list. I'm planning to build an RV 8A and will place the order as soon as I have my workshop organized. This won't be my first adventure into airplane building - I have already built a Zodiac CH 601 HDS. Have a question: what other arguements (besides cost and time saving) speak for or against the quickbuild kit versus the standard kit? Thanks Thilo Kind ________________________________________________________________________________
Date: Sep 10, 2006
Subject: Re: RV8 A - Quickbuild vs. Standard
Bob Collins wrote: > > I must be building my RV wrong. I'm building slo-build and I'm having a > BLAST! (g) > > If I'd gone QB, I wouldn't have known what I was missing (wcept flying > really soon, of course) Bob, I don't know that you would be flying *that* much sooner. :-) What is often overlooked in QB vs standard discussions is that the QB only saves time during construction of the airframe. Once the airframe is looking sorta like an airplane, the project is only about half finished and at that point the QB and standard builder are faced with identical completion tasks. Keep in mind that a 50% savings of QB time over standard airframe build ends up only representing a 25% difference in total project build time. And the new, highly evolved kits are blurring these distinctions even more. There are valid reasons for going with a QB, but it seems the advantages in build time are often misunderstood and overstated. Sam Buchanan ________________________________________________________________________________
Date: Sep 11, 2006
How about the increased probability of completion! No so much a problem for a second time builder I should imagine. Doug Gray > > Hi everybody, > > this is my first post on this list. I'm planning to build an RV 8A and will > place the order as soon as I have my workshop organized. This won't be my > first adventure into airplane building - I have already built a Zodiac CH > 601 HDS. > > Have a question: what other arguements (besides cost and time saving) speak > for or against the quickbuild kit versus the standard kit? > > Thanks > > Thilo Kind > > ________________________________________________________________________________
Date: Sep 10, 2006
On 10 Sep 2006, at 16:03, Thilo Kind wrote: > > Have a question: what other arguements (besides cost and time > saving) speak for or against the quickbuild kit versus the standard > kit? Some builders like to make deviations from the plans to add custom features. Many of these types of mods are more difficult on a QB kit, as they would require significant disassembly and rework. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Sep 10, 2006
Thanks Bob, for the contct info. I did email them before and they sent me their rebuilt boost-pump price list. I will email they again and ask specifically for a re-build kit. By the way, I pulled her apart. The main shaft pin sheared-off. It is so small, I'm gonna have some trouble getting the old piece out and a new one to re-place it. I will also replace the vanes and seals while I've got her off/out and apart. I hope they do sell a rebuild kit; life would be so much easier if they do. Chuck "Bob J." wrote: If I had to guess it sounds like a check valve seal. They'll sell you the individual seals, according to my buddy. http://www.dukesinc.com/contact.html Regards, Bob Japundza RV-6 flying F1 under const On 9/9/06, Chuck wrote: Bob, Thanks for telling me that. Can you get the contact info for the rebuild kit. So far my research has yielded negative results. I was afraid Duke's parts were somehow proprietary and classified next to unobtainium on the Elements chart. I will crack her seals tomorrow morning and report back. Like what's his name said "... why not open her up, you've got nothing to lose." You know, ocassionally I do enjoy this list for actual RV related stuff (not just to laugh my a$$ off at ALL the pissin' & moanin' & flame wars :-) Chuck "Bob J." < rocketbob(at)gmail.com> wrote: A friend of mine rebuilt his Dukes pump, and I got to look at the innards when he had it apart. They're pretty simple inside, its just a vane pump with a check valve/bypass. The vanes were made of teflon IIRC. I think he paid $160 for the rebuild kit. Regards, Bob Japundza RV-6 flying F1 under const. On 9/8/06, Chuck < chuck515tigger(at)yahoo.com > wrote: Just curious.... I'm running an IO-320 (Ly-con) with Bendix injections, mechanical fuel pump and an electric "Dukes Inc." boost-pump. The Duke takes a dump (spins but won't pressure up). I find out the replacement Duke is $600 plus core, shipping and tax ($900 area). I went with the Duke because I got it in trade; I use to use Performance Air (?) but their price sucks too and I hated the added weight & complexity of their recommended fuel filter. Seeking thoughts & recommendations: 1. Cough-up the bucks and get the replacement Duke. 2. Crack-open the Duke's seals ans see if I can repair (might be just a spun nut/cotter-key/or sumpin' like the nylatron pump vane). 3. Skip the boost pump 'cuz I never use it anyway... 4. Forget this ever increasin' overly-expensive flyin' sh!t and spend the $$$ on girls & surfin' 5. Your suggestions........... Thanks. Chuck --------------------------------- Get your own web address for just $1.99/1st yr. We'll help. --------------------------------- Get on board. You're invited to try the new Yahoo! Mail. ________________________________________________________________________________
Date: Sep 10, 2006
I had a chance to hear both the LS 30G and the Bose at Oshkosh this year, in a sound booth where you could pipe in engine noise and vary the volume. I was impressed with the LS, especially considering the price. For the sound, immediate comfort and price, I would purchase the LS hands down. However, I can't comment on the long term wear of both. Seems to me this would be a very critical criteria. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=60849#60849 ________________________________________________________________________________
Date: Sep 10, 2006
The other thing I like about the slo-build. Every night when I close the garage door and just before turning out the light, I look back at this thing and I say, "*I* built that; every rivet. (OK, except the main wing spar). I can't tell you how cool that feels. (http://stirringsfromtheemptynest.blogspot.com/2006/07/right-here-provenzani .html). It's my $8,000 feeling. On the other hand, I know a guy who started his 7A just a little before I did and I think he went QB all the way. Five years later, he's about as far ahead of me -- not too much -- as we were five years ago. He had to do a QB, not because he wanted to get in the air fast -- although maybe he did -- but his lifestyle didn't allow for a slow build. Bottom line? Like so many things in RV building, there's no *right* answer. Bob St. Paul, Minn. ________________________________________________________________________________
Date: Sep 11, 2006
Subject: Re: Gretz Aero Pitot Wiring
Ralph, Will reply to you off list. Regards, Scott Lewis Ralph Hoover wrote: > > I have a GA-1000 heated Pitot on back-order so I don't have the install > info yet. Does anyone have the details of the wiring required and the > panel indicator. I tried Stein Air and Warren Gretz, so far no answers. > RV7A Wiring > Ralph Hoover > > > > > > ________________________________________________________________________________
Date: Sep 11, 2006
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Fuel Pumps
These pumps are not rocket science but they are obviously "aircraft" parts because the price is about 10 TIMES what it ought to be. I ended up with an AFP fuel pump when Mattituck sent me my finished engine. I can't help but speculate that there HAS to be a similar pump in the auto racing world that can be used for this purpose. That pump will likely cost between 50-100 dollars and be of equal or better quality than a PMA stamped part (who knows maybe even AFP adapts one of these pumps). Not to knock the AFP system, it's likely the best mechanical system to be had today and Don Rivera's service is top notch. But... these ridiculous prices for simple and proven pumping technology is idiotic (like many old low tech aircraft parts). Anyone researched using an automotive racing pump (ie. Holley, Edelbrock, etc) for this purpose. Dean Psiropoulos RV-6A N197DM Always blown away by the cost of "aircraft" parts. >Subject: RE: RV-List: Curious >From: "BPA" <BPA(at)bpaengines.com> > >The Airflow Performance boost pump is around 500.00 bucks. Lighweight, >simple in design and works. Everybody I know has problems with Duke >pumps and end up chucking them in the trash. ________________________________________________________________________________
Date: Sep 11, 2006
The Duplicolor primer is made by Sherwin-Williams. There are some differences in the MSDS fromt he other Sherwin-Williams primer. -------- AltonD Waiting on the slow build fuselage to deliver Read this topic online here: http://forums.matronics.com/viewtopic.php?p=60905#60905 ________________________________________________________________________________
Subject: Re: looking for Reno Tix
Date: Sep 11, 2006
Check Doug Reeves site, Mel Jordan in Tucson is selling some there. -------- Glenn Brasch RV-9A Finishing #90623 Tucson, Arizona Van's Aircraft Belt Buckles http://home.earthlink.net/~gbrasch/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=60906#60906 ________________________________________________________________________________
Date: Sep 11, 2006
August 26, 2006 - September 11, 2006
RV-Archive.digest.vol-sf
