RV-Archive.digest.vol-sq
March 02, 2007 - March 26, 2007
      and Ill see what I can do to help you out.
        Im leaving early Sunday morning for New England (CT).
      Fred Stucklen
      RV-6A N925RV  2008 hrs (sold)
      RV-6A N926RV    720 hrs
      RV-7A N924RV (Reserved)
Date: Mar 02, 2007
Subject: Splitters for Sale
Listers, I have two different splitters that I do not need and would like to sell. They are: 1. DIM Antenna Technologies Type DM H22-1 Diplexer. From the Chief Aircraft catalog: "Single VOR and single GS. Will permit operation of one NAV and one glide slope receiver from one VOR antenna. VSWR 1.5:1. Weight 0.25 lbs." Has one BNC input and two BNC outputs. $45.00 2. Comant Industries CI 5120 Dual VOR/GS Splitter. Distributes input from one VOR/LOC/GS antenna to two VOR/LOC/GS receivers. BNC input and outputs. $30.00 I'll pay the shipping. Richard Dudley RV-6A flying ________________________________________________________________________________
Date: Mar 02, 2007
Subject: Re: Glass for IFR
On 3/2/07, linn Walters wrote: > > Bob J. wrote: > > The best approach is to use a wet vacuum pump and a separator. I know of > many wet vaccum pumps that outlived the engines they were installed in. > > They're heavier, and the separator isn't that efficient. That's why the > dry pump is standard on most 'newer' engines. > So what if they're heavier. They last forever! We're talking a pound or two difference. The reason why dry pumps became fashionable was because someone thought it would be a clever way to cut costs in certificated aircraft production. > I don't know of a single dry pump that I've ever seen that didn't fail > in the shear coupler. I've never seen on where the vanes wore out. > > Well, that's why the pump fails. The vanes are plasticized carbon, and > the centripetal force keeps the vanes in contact with the pumps outer wall, > which causes them to wear down slowly. The vanes are the sacrificial > parts. When the vanes get thin ..... about 1/4" wide or so, they jam in the > ports and the shear coupling fails. > I don't see how a vane can jam into a port. I've taken dry pumps apart and the ports are only a 1/4" or so in diameter. When they fail due to vane wear what will happen is that they will fall out of the stator in the open area ahead of the port, then will jam between the body of the pump and the next vane that comes along. I can show you a box of about a half dozen cores we have on our airport of dry pumps, all of them have vanes in excellent shape. The vanes will outlast the shear coupler. Ask any A&P that has replaced many of these and I will bet you a beer you will get the same answer. In every single one I've seen the drive coupling failed. Why? To use your analogy of the fuse, imagine a 5A fuse on a 10A circuit. Now lets analyze the design of a dry pump. Lets say the shear coupling is more rigid, perhaps 50% stronger. Now lets say a vane fails, what happens? The pump will grind itself internally to death, and if it causes a seizure of the pump, then a stronger shear coupler will fail. As long as the bits an pieces can't get into the engine, or the instruments, there's no problem. Which normally they can't unless the dry pump is used to inflate deice boots. In those installations however they have screens to prevent junk from getting in the boots (Piper Aerostar comes to mind.) Wet pumps such as the Garwins have a thinned down section of the drive shaft to act as a shear coupler if the pump seized. In dry pumps the shear couplers are plastic, it doesn't take much torque to make them fail. > If the dry pumps didn't have the silly shear coupler they would be far > more reliable. > > Can't agree with that! That's like replacing a fuse with a piece of > metal. If the shear coupling didn't fail when the pump jammed ..... some > other, weaker, link in the food chain would have to ...... maybe internal to > the engine. Who knows??? I sure wouldn't want to find out! > The weak link would then be the carbon stator and the vanes, and if they fail there should not be any cascading effect other than no vacuum pressure. I believe the shear couplers fail from being subject constant pounding of the engine power pulses. FYI ..... I had a dry pump last more than 2000 hours on an O-235 ...... and > yes, it failed as I was climbing out through the soup. Sigh. > Linn > Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Date: Mar 02, 2007
Subject: Re: ANR Headsets
On 9:26 2007-03-02 "Neal George" wrote: > Are there any audiologists among us who would care to comment on the > relative quality of protection offered by the traditional cup-style > vs. in-ear headsets? I'm not an audiologist, but I did stay in a holiday inn expresss... Just kidding. I have a pair of the in-ear silicone earplugs, that I had made to wear while riding my motorcycle. I tried them out in flight, and found that the combination of the silicone plugs, and my David Clark 10-13.4 headset, almost matched the comfort and audio level of my Lightspeed 20XL. I've also worn the earplugs on an airline flight between North America and China, and was happy with the performance there as well. The earplugs were made by Custom Protect Ear (http://www.protectear.com) and are the "Convertible Vented" model. They are vented to prevent ear damage with altitude changes. All that being said, I think my next headset purchase will be a pair of Bose Quiet Comfort headphones, plus the aviation mod kit (http://www.uflymike.com/) to add a boom microphone. The Quiet Comfort headset is reportedly as good as the X headset in noise cancellation, at 1/3 the price point. I wish I knew someone with this setup so I could give it a try first, though. -Rob ________________________________________________________________________________
Subject: Glass for IFR
Date: Mar 02, 2007
Many people are starting to realize the problems associated with the plastic couplings and are replacing it every two years. The guys who are doing this are getting a lot of trouble free time from the dry pumps. The problem seems to be the life of the coupling is getting pushed too far The vanes are designed to go a long time, and in industrial applications, they do, unless they ingest something like foam from an aged out filter. . Maybe a $11 coupling every couple of years or so, along with a new garter filter, may save a lot of grief and money.. Just an opinion, Phil ________________________________________________________________________________
Date: Mar 02, 2007
Subject: Comparing Bose X headset to the QCII, was ANR Headseats
I have both the Quiet Comfort II headphones and the X aviation headset. I have not used the aviation set in an airplane yet (RV7A soon to fly) but have tried the QCs once, while flying, to listen to MP3s. That was not very satisfying as the noise in my Grumman almost drowned out the music. After reading your post Rob, I turned on some thumpy dance music in my living room and ran a non scientific comparison between the two. In my subjective opinion, I would say that the X set noise reduction, approaches twice the effectiveness as the QC in both passive and active modes. Some other factors to consider: The X is more comfortable, although it will be hotter on warm days. The X is much more robust in construction and has much heavier cables and connectors. I initially had power switch problems with the QC. It's a cheap slide switch. The X is stereo/mono selectable. The X has individual L/R volume controls. The mic position on the X can be reversed. The X has auto shut off. The X has 2 AA batteries as opposed to 1 AAA for the QC. I don't remember the length of the warrantee on the QCs but that could be a factor. There's a 5 yr warrantee on the X set. I bought my X set used, but within the warrantee period. One of the metal headband yokes was broken. Bose rebuilt the head band with two new metal yokes and included new head and ear cushions, all at no charge including return shipping. With all that said, I still don't know why they are THAT expensive. Anyway, I reported, you decide. Bob Trumpfheller mesawood.com In a message dated 3/2/2007 11:39:57 A.M. Mountain Standard Time, rv7(at)b4.ca writes: All that being said, I think my next headset purchase will be a pair of Bose Quiet Comfort headphones, plus the aviation mod kit (http://www.uflymike.com/) to add a boom microphone. The Quiet Comfort headset is reportedly as good as the X headset in noise cancellation, at 1/3 the price point. I wish I knew someone with this setup so I could give it a try first, though. -Rob
AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. ________________________________________________________________________________
Subject: ANR Headsets
Date: Mar 02, 2007
Regarding quiet comfort (non aviation) Bose headsets. I recently had a problem with a QC1 set of headsets, called Bose to arrange repair. Bad news, they could not/ would not repair. Good news for $100 they sent me a pair of the QC2 headsets. I had to send the QC1's to their depot for evaluation and received the new set in less than 10 days. I travel a lot for business (as passenger) I will NEVER go on another trip with out the QC headsets. Most recent long trip, Denver - LA, Singapore, Kuala Lumpur, Bangkok, Tokyo, Seattle - (replaced battery) back to Denver. Nearly 40 hours on one AAA Arrive at your destination feeling better, and travel more comfortably. Bose did not ask for original receipts, so...... Get aviation ANR headsets too, you'll be glad you did. There are sources for upgrade kits to take passive to ANR. Use Google to find, very easy to do. Dave Cordner RV-7 N898DC (rsvd) Fuse -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Rob Prior Sent: Friday, March 02, 2007 11:38 AM Subject: Re: RV-List: ANR Headsets On 9:26 2007-03-02 "Neal George" wrote: > Are there any audiologists among us who would care to comment on the > relative quality of protection offered by the traditional cup-style > vs. in-ear headsets? I'm not an audiologist, but I did stay in a holiday inn expresss... Just kidding. I have a pair of the in-ear silicone earplugs, that I had made to wear while riding my motorcycle. I tried them out in flight, and found that the combination of the silicone plugs, and my David Clark 10-13.4 headset, almost matched the comfort and audio level of my Lightspeed 20XL. I've also worn the earplugs on an airline flight between North America and China, and was happy with the performance there as well. The earplugs were made by Custom Protect Ear (http://www.protectear.com) and are the "Convertible Vented" model. They are vented to prevent ear damage with altitude changes. All that being said, I think my next headset purchase will be a pair of Bose Quiet Comfort headphones, plus the aviation mod kit (http://www.uflymike.com/) to add a boom microphone. The Quiet Comfort headset is reportedly as good as the X headset in noise cancellation, at 1/3 the price point. I wish I knew someone with this setup so I could give it a try first, though. -Rob ________________________________________________________________________________
Date: Mar 02, 2007
Subject: Re: Comparing Bose X headset to the QCII, was ANR Headseats
Hi all, If it's any help, the Kitplanes website (www.kitplanes.com) has three of my four headset review articles as free content on their website. The in-the-ear feature isn't in the free content section just yet, but it appeared in the Feb 07 issue. There may be some info in there that may be helpful. Each article has a feature comparison chart, including prices at the time it went to press, and contact info. I loved the Bose X and bought a set for myself. I also use it when doing tricky audio transcription- the sophisticated audio electronics does wonders for so-so audio. Of the in-the-ear headsets, I liked the Clarity Aloft a lot, and found the Quiet Technologies Halo to work well, too. The LS Mach 1 was cool, but tookme some time to get used to it. This has been a great thread. best, CoryEmberson Contributing Editor Kitplanes Magazine ________________________________________________________________________________
Date: Mar 02, 2007
> Many people are starting to realize the problems associated with the plastic couplings and are replacing it every two years. Not a bad idea if it is really the coupling that fails. In my case I saw the innards broken. That likely led to the coupling shearing as opposed to the other way. I will have to examine the Rapco 215cc I get to see if it is easy to replace the coupling. Ron Lee --------------------------------------------- This message was sent using Endymion MailMan. http://www.endymion.com/products/mailman/ ________________________________________________________________________________
From: "Aircraft Spruce" <info(at)aircraftspruce.com>
Subject: Aircraft Spruce
Date: Mar 02, 2007
We noticed a posting recently regarding Aircraft Spruce and Tru Trak indicators, and wanted to reply to the readers. Tru Trak sends these turn and bank indicators to us bulk packaged 4 in a box, and we have to repackage them as individual units. This is why the packaging did not look like "Tru Tak" packaging. Our customer service department exchanged the first unit for another one, and of course the second one looked just the same; they should have checked first and would have found that we get them bulk packed from the manufacturer. Both units were of course new, not used, and our customer is satisfied with the unit. Please let us know if you ever have any questions or concerns. Aircraft Spruce Customer Service ________________________________________________________________________________
Subject: cowl plugs
Date: Mar 02, 2007
Does anyone know if the cowl plugs that vans sells will work for an -8 too? It doesn't say anything on the site about the -8... Does anyone have these and have any feedback? http://www.vansaircraft.com/cgi-bin/catalog.cgi?&browse=airframe&produc t=cowl_plugs -Bill www.rv8a.com ________________________________________________________________________________
Date: Mar 02, 2007
Subject: Re: cowl plugs
RV-7/8 - fits RV-6/7/8/9 airplane cowls without scoop Part Number = COWL PLUG HORIZ Price = $59.95 Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Bill VonDane wrote: > Does anyone know if the cowl plugs that vans sells will work for an -8 > too? It doesn't say anything on the site about the -8... Does anyone > have these and have any feedback? > > http://www.vansaircraft.com/cgi-bin/catalog.cgi?&browse=airframe&product=cowl_plugs > <http://www.vansaircraft.com/cgi-bin/catalog.cgi?&browse=airframe&product=cowl_plugs> > > -Bill > www.rv8a.com <http://www.rv8a.com> > > > > > ________________________________________________________________________________
Date: Mar 03, 2007
On 3/2/07, Bill VonDane wrote: > > Does anyone know if the cowl plugs that vans sells will work for an -8 > too? It doesn't say anything on the site about the -8... Does anyone > have these and have any feedback? > > > http://www.vansaircraft.com/cgi-bin/catalog.cgi?&browse=airframe&product=cowl_plugs > > -Bill > www.rv8a.com > > Bill, you are having a senior moment.. :-) It says 6/7/8/9 right in the item description... -- David Leonard Turbo Rotary RV-6 N4VY My websites at: http://members.aol.com/_ht_a/rotaryroster/index.html http://members.aol.com/_ht_a/vp4skydoc/index.html http://leonardiniraq.blogspot.com ________________________________________________________________________________
Date: Mar 03, 2007
Subject: FS: 2004 RV6A
Date: Mar 03, 2007
For sale: 2004 RV-6A w/Sliding Canopy SN: 23143 Location: KMJD TTAF/TSMO: 250 hrs. That will vary as I fly often. Engine: Conical mount 160hp O-320 A1A Narrow deck with carb, mags and chrome cyls All parts were new or yellow tagged. All ADs complied with. Have paperwork Spin on oil filter. 35 amp alt Compact starter Cabin heat 80 pitch Sensenich metal propeller. KLX-135A com /gps KT-76A transponder AmeriKing - AK-350 - Altitude Encoder and ELT, Standard 6-pack configuration, Vertical card compass Voice activated intercom, Flight Data Systems GT-50 G-meter, clock/timer and voltmeter Aerospace Logic four probe Egt & Cht, Other gauges are Vans, Volt, Oil P, Oil T, Fuel P, Fuel level. Single brakes Manual aileron and elevator trim Single leading edge landing light Painted interior Leather seats in fair condition New tires and tubes AeroFlash wingtip marker, position and double flash strobe combination units All airframe parts primed inside and out with Dupont vari-prime self etching primer. Exterior painted with Dupont Imron. Gross weight is set at1750lbs and empty weight is around1050lbs. Always hangered Fresh Condition inspection and Transponder check as of 2/3/07. Performance stats: Climbs 800 to 1800 fpm depending on load and temps. Cruise: 8500 WOT, 2530 rpms, 158mph indicated, 185mph TAS @8.5-9gph 9500 WOT, 2500rpms, 158mph indicated, 188mph TAS @8.5-9gph E-mail for pictures Price: $65k Thanks Scott Frierson Cell # 601-347-1114 _________________________________________________________________ The average US Credit Score is 675. The cost to see yours: $0 by Experian. http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE ________________________________________________________________________________
Subject: 1999 RV8 For Sale
Date: Mar 03, 2007
1999 RV8 For Sale 1050 TTAF O 360 180 HP Photos and specs at -------- Milt N395V F1 Rocket www.excaliburaviation.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=98571#98571 ________________________________________________________________________________
Subject: Re: Regarding Bose QC headsets
Date: Mar 03, 2007
Can anyone report on using the Bose QC2 headsets with the UflyMike conversion for aircraft use? Sounds like a good deal but I'd like to know what they actually work in the noisy RV environment. Randy Lervold RV-3B, almost done RV-8, sold ----- Original Message ----- From: "Dave Cordner" <davcor(at)comcast.net> Sent: Friday, March 02, 2007 12:33 PM Subject: Regarding Bose QC headsets Was: RE: RV-List: ANR Headsets > > Regarding quiet comfort (non aviation) Bose headsets. I recently had a > problem with a QC1 set of headsets, called Bose to arrange repair. > Bad news, they could not/ would not repair. > Good news for $100 they sent me a pair of the QC2 headsets. I had to send > the QC1's to their depot for evaluation and received the new set in less > than 10 days. > > I travel a lot for business (as passenger) I will NEVER go on another trip > with out the QC headsets. Most recent long trip, Denver - LA, Singapore, > Kuala Lumpur, Bangkok, Tokyo, Seattle - (replaced battery) back to Denver. > Nearly 40 hours on one AAA > > Arrive at your destination feeling better, and travel more comfortably. > > Bose did not ask for original receipts, so...... > > Get aviation ANR headsets too, you'll be glad you did. There are sources > for > upgrade kits to take passive to ANR. Use Google to find, very easy to do. > > Dave Cordner > RV-7 N898DC (rsvd) > Fuse ________________________________________________________________________________
Subject: RE:Comparing Bose X headset to the QCII, was ANR Headseats
Date: Mar 03, 2007
A quick data point- When the QC2 battery fails, you loose ALL audio, not just the ANR. Com is lost. I realize that batteries last a looong time in these units, and that the battery indicator LED starts flashing well in advance of unit failure, but there is no failsafe mode. A point to consider- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: upgrade- dont use qc2's in your plane! :Comparing Bose X headset
Date: Mar 03, 2007
Right, In my earlier post describing how pleased I am with the QC2 I guess I failed to say these are NOT aviation headsets. If you want to see what the benefit of the Bose or other vendors ANR sets are, either borrow a set, or toss about $250 (less than the cost of the QC2 headsets and designed for aviation needs) at your old David Clarks or others and put an ANR upgrade in. I bought someone else's upgraded set when he finished his RV10 and outfitted the new plane with new Bose (4 places - nice). Bottom line, final is no place to be debugging a kludged headset arrangement... If I can't afford two new Bose aviation headsets when I launch my '7, I'll buy another kit and upgrade one of my DC's use google, there are several sources.... around $169 here for David Clarks: http://anr-headsets.com do 2 headsets for a little more than list price of the QC2's Dave -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of glen matejcek Sent: Saturday, March 03, 2007 8:33 PM Subject: RV-List: RE:Comparing Bose X headset to the QCII, was ANR Headseats A quick data point- When the QC2 battery fails, you loose ALL audio, not just the ANR. Com is lost. I realize that batteries last a looong time in these units, and that the battery indicator LED starts flashing well in advance of unit failure, but there is no failsafe mode. A point to consider- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Mar 03, 2007
Don't have info on use in a airplane, but I did read a review that said when the battery quits so does the music, or in our case, the radio. Something to think about. Pax, Ed Holyoke -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Randy Lervold Sent: Saturday, March 03, 2007 6:44 PM Subject: RV-List: Re: Regarding Bose QC headsets Can anyone report on using the Bose QC2 headsets with the UflyMike conversion for aircraft use? Sounds like a good deal but I'd like to know what they actually work in the noisy RV environment. Randy Lervold RV-3B, almost done RV-8, sold ----- Original Message ----- From: "Dave Cordner" <davcor(at)comcast.net> Sent: Friday, March 02, 2007 12:33 PM Subject: Regarding Bose QC headsets Was: RE: RV-List: ANR Headsets > > Regarding quiet comfort (non aviation) Bose headsets. I recently had a > problem with a QC1 set of headsets, called Bose to arrange repair. > Bad news, they could not/ would not repair. > Good news for $100 they sent me a pair of the QC2 headsets. I had to send > the QC1's to their depot for evaluation and received the new set in less > than 10 days. > > I travel a lot for business (as passenger) I will NEVER go on another trip > with out the QC headsets. Most recent long trip, Denver - LA, Singapore, > Kuala Lumpur, Bangkok, Tokyo, Seattle - (replaced battery) back to Denver. > Nearly 40 hours on one AAA > > Arrive at your destination feeling better, and travel more comfortably. > > Bose did not ask for original receipts, so...... > > Get aviation ANR headsets too, you'll be glad you did. There are sources > for > upgrade kits to take passive to ANR. Use Google to find, very easy to do. > > Dave Cordner > RV-7 N898DC (rsvd) > Fuse ________________________________________________________________________________
Subject: "We Love RV's" Invitational Luncheon April 14th at Leeward Air
Ranch
Date: Mar 04, 2007
The Leeward Air Ranch RVators are having their Annual "We Love RV's" Invitational Luncheon April 14th at Leeward Air Ranch, (FD04), near Ocala, FL. We had about 100 RV's fly-in at the 2005 event. April 14th is the weekend before Sun n Fun. We expect a lot of out of state RV's since we are only 67NM North of Lakeland (LAL) We are tentatively setting the 15th as a rain date. This gathering is by invitation only. If you think you can make it, Please email Esten Spears, ewspears(at)comcast.net with names of people that will attend with you. (wife, kids, or friends) Also would like to know what RV or other plane you will be arriving in. If you plan to drive in let me know that. I will email you back with an Invitation including flying and driving instructions. Please inform any other RV Enthusiasts you know about our Gathering and have them email me with the info I've asked for. The many RVators at Leeward Air Ranch Hope you can make it! ________________________________________________________________________________
Date: Mar 04, 2007
Subject: Re: "We Love RV's" Invitational Luncheon April 14th at Leeward
Air Ranch Please include Richard and Ruth Dudley who will arrive in our yellow and white RV-6A, N331RD. Regards, Richard Dudley Esten Spears wrote: > The Leeward Air Ranch RVators are having their Annual "We Love RV's" > Invitational Luncheon April 14th at Leeward Air Ranch, (FD04), near > Ocala, FL. We had about 100 RV's fly-in at the 2005 event. April 14th > is the weekend before Sun n Fun. We expect a lot of out of state RV's > since we are only 67NM North of Lakeland (LAL) We are tentatively > setting the 15th as a rain date. > > This gathering is by invitation only. If you think you can make it, > Please email Esten Spears, ewspears(at)comcast.net with names of people > that will attend with you. (wife, kids, or friends) Also would like to > know what RV or other plane you will be arriving in. If you plan to > drive in let me know that. > I will email you back with an Invitation including flying and driving > instructions. > Please inform any other RV Enthusiasts you know about our Gathering > and have them email me with the info I've asked for. > > The many RVators at Leeward Air Ranch Hope you can make it! > > ________________________________________________________________________________
Date: Mar 04, 2007
Subject: Re: upgrade- dont use qc2's in your plane! :Comparing Bose X
headset to the QCII, was ANR Headseats I am building an RV-7 and will use my lightspeed ANR headset in them. However, my 'other' airplane is Canadair Regional Jet, which I fly for one of the regional airlines. I use the Bose QC2 with the Uflymike adapter, as do many of the other pilots who fly the RJ. If you use rechargable batteries in the QC2, there is no warning when the battery fails, however, if you use standard batteries, the light on the side of the headset will start to blink when you have about 5 hours of life left in them. The flight department in our airline has no problem with both pilots being on QC2s, as long as we are not using rechargeable batteries. For what it's worth... DD On 3/3/07, Dave Cordner wrote: > > > Right, In my earlier post describing how pleased I am with the QC2 I guess > I > failed to say these are NOT aviation headsets. > > If you want to see what the benefit of the Bose or other vendors ANR sets > are, either borrow a set, or toss about $250 (less than the cost of the > QC2 > headsets and designed for aviation needs) at your old David Clarks or > others > and put an ANR upgrade in. I bought someone else's upgraded set when he > finished his RV10 and outfitted the new plane with new Bose (4 places - > nice). > > Bottom line, final is no place to be debugging a kludged headset > arrangement... > > If I can't afford two new Bose aviation headsets when I launch my '7, I'll > buy another kit and upgrade one of my DC's > > use google, there are several sources.... around $169 here for David > Clarks: > http://anr-headsets.com > do 2 headsets for a little more than list price of the QC2's > > Dave > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of glen matejcek > Sent: Saturday, March 03, 2007 8:33 PM > To: RV-List Digest Server > Subject: RV-List: RE:Comparing Bose X headset to the QCII, was ANR > Headseats > > > A quick data point- When the QC2 battery fails, you loose ALL audio, not > just the ANR. Com is lost. I realize that batteries last a looong time > in > these units, and that the battery indicator LED starts flashing well in > advance of unit failure, but there is no failsafe mode. A point to > consider- > > glen matejcek > aerobubba(at)earthlink.net > > ________________________________________________________________________________
Subject: SL30 and Dynon
Date: Mar 04, 2007
I would like to get opinions and thoughts from anyone driving the HSI feature of the Dynon D10A or D100 from a Garmin SL30 Garmin. I'm thinking of doing this in lieu of having a DG and a CDI/LOC/GS/GPS indicator like a MD200-306 indicator and wondering about the pros and cons of this. I already have a Altitude Indicator. Marty ________________________________________________________________________________
Subject: RE: SL30 and Dynon
Date: Mar 04, 2007
Oops, I mean Attitude Indicator, it's electric not vacuum. Marty -----Original Message----- From: Emrath [mailto:emrath(at)comcast.net] Sent: Sunday, March 04, 2007 3:24 PM Subject: SL30 and Dynon I would like to get opinions and thoughts from anyone driving the HSI feature of the Dynon D10A or D100 from a Garmin SL30 Garmin. I'm thinking of doing this in lieu of having a DG and a CDI/LOC/GS/GPS indicator like a MD200-306 indicator and wondering about the pros and cons of this. I already have a Altitude Indicator. Marty ________________________________________________________________________________
Date: Mar 04, 2007
I recently wired my SL30 and Garmin 396 to my Dynon D10A. Everything works as advertised. I have a MD200 as well and it is the least used thing in my panel for the VFR flying I do. So I think the answer to your question might be sure, why not. But it really depends on your mission profile and personal preference. - Larry Bowen, RV-8 280 Hrs & RV-7 in progress... Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Emrath [mailto:emrath(at)comcast.net] > Sent: Sunday, March 04, 2007 10:26 PM > To: rv-list(at)matronics.com > Subject: RV-List: RE: SL30 and Dynon > > > Oops, I mean Attitude Indicator, it's electric not vacuum. > Marty > > -----Original Message----- > From: Emrath [mailto:emrath(at)comcast.net] > Sent: Sunday, March 04, 2007 3:24 PM > To: rv-list(at)matronics.com > Subject: SL30 and Dynon > > > I would like to get opinions and thoughts from anyone driving the HSI > feature of the Dynon D10A or D100 from a Garmin SL30 Garmin. > I'm thinking > of doing this in lieu of having a DG and a CDI/LOC/GS/GPS > indicator like a > MD200-306 indicator and wondering about the pros and cons of this. I > already have a Altitude Indicator. Marty > > > > > > ________________________________________________________________________________
Date: Mar 05, 2007
Subject: ANR Headsets - power plugs
A question along the lines of ANR: what are the connector options for ANR Headsets using ship's power ?? I want to get rid of battery packs flopping around in our Decathlon and avoid the issue from the beginning in our Rocket. >From what I seem to have found so far there are 4 different plug configurations: Bose - some sort of single plug handling mic, headset, and ANR power. Telex - another sort of single plug handling mic, headset, and ANR power. I have this and it is a Lemo brand connector. Lightspeed - standard plugs for mic and headset with a 3rd plug for ANR power. Sennheiser - standard plugs for mic and headset with another 3rd plug for ANR power. Are there any other plug configurations ?? Is there a standard emerging ?? So far it's looking like a 3-plug configuration will be the way to go so that worst-case I can use any headset in any aircraft although the ANR will only function in those aircraft equipped with whichever power receptacle I choose to interface with. Now how about power . does the ANR accept 12vdc ?? Larry E. James Bellevue, WA Super Decathlon Rocket (fuselage / systems) ________________________________________________________________________________
Date: Mar 05, 2007
Subject: Spare Parts List
Is there a list of spare nuts & bolts & cotter pins & misc stuff out there to maintain an RV? I'd like to order up a package of stuff to have around rather than searching. I bought this RV flying already. ________________________________________________________________________________
Date: Mar 05, 2007
Subject: Re: RV-List Re: Too much fun!!
0-523536320-1173141513=:27092-- ________________________________________________________________________________
Date: Mar 05, 2007
_http://video.yahoo.com/video/play?vid=61b3901ac51b5c12457145eea53b71bc.150423 2&cache=1_ (http://video.yahoo.com/video/play?vid=61b3901ac51b5c12457145eea53b71bc.1504232&cache=1)
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: Spare Parts List
Date: Mar 05, 2007
Before buying materials, I think you should consider first who has the authority to do maintenance on your plane. Usually the airplane builder will get the certificate to do that on that particular plane only. This privilege cannot be sold along with the plane unfortunately. The only other people who can legally do all types of maintenance work on an experimental are FAA authorized airplane mechanics. You can legally do things like add and change oil and filter, add air in tires, put grease in the tail wheel -- But the annual inspection work must be performed by a licensed A&P. You really should not need spare nuts and bolts. If you have insurance and want to rely on it, you need to maintain the plane per the FAA rules or else it is money wasted. Larry in Indiana ----- Original Message ----- From: Greg Williams To: rv-list(at)matronics.com Sent: Monday, March 05, 2007 1:33 PM Subject: RV-List: Spare Parts List Is there a list of spare nuts & bolts & cotter pins & misc stuff out there to maintain an RV? I'd like to order up a package of stuff to have around rather than searching. I bought this RV flying already. ________________________________________________________________________________
Date: Mar 05, 2007
LarryRobertHelming wrote: > Before buying materials, I think you should consider first who has > the authority to do maintenance on your plane. Usually the airplane > builder will get the certificate to do that on that particular plane > only. This privilege cannot be sold along with the plane > unfortunately. The only other people who can legally do all types of > maintenance work on an experimental are FAA authorized airplane > mechanics. > > You can legally do things like add and change oil and filter, add air > in tires, put grease in the tail wheel -- But the annual inspection > work must be performed by a licensed A&P. You really should not > need spare nuts and bolts. If you have insurance and want to rely on > it, you need to maintain the plane per the FAA rules or else it is > money wasted. Greg can legally do any work on the plane he chooses. He just needs to get an A&P to sign the condition inspect every twelve months. The restrictive requirements stated in the above post do not apply to aircraft with experimental certificates. Sam Buchanan ==================== > Is there a list of spare nuts & bolts & cotter pins & misc stuff out > there to maintain an RV? I'd like to order up a package of stuff to > have around rather than searching. I bought this RV flying already. > > ________________________________________________________________________________
Date: Mar 06, 2007
Larry: ANYONE can do ANY work on an EXPERIMENTAL aircraft. (may not be wise if you do not know what you are doing but it is LEGAL) The Repairman or an A & P is only necessary to do the ONCE a year CONDITION INSPECTION. A major change requires FAA FSDO approval of a flight test area. Gary A. Sobek FAA A&P / DAR "My Sanity" RV-6 N157GS O-320 Hartzell, 1,981 + Flying Hours So. CA, USA ----Original Message Follows---- From: "LarryRobertHelming" <lhelming(at)sigecom.net> Subject: Re: RV-List: Spare Parts List Date: Mon, 5 Mar 2007 19:14:23 -0600 Before buying materials, I think you should consider first who has the authority to do maintenance on your plane. Usually the airplane builder will get the certificate to do that on that particular plane only. This privilege cannot be sold along with the plane unfortunately. The only other people who can legally do all types of maintenance work on an experimental are FAA authorized airplane mechanics. You can legally do things like add and change oil and filter, add air in tires, put grease in the tail wheel -- But the annual inspection work must be performed by a licensed A&P. You really should not need spare nuts and bolts. If you have insurance and want to rely on it, you need to maintain the plane per the FAA rules or else it is money wasted. Larry in Indiana ----- Original Message ----- From: Greg Williams To: rv-list(at)matronics.com Sent: Monday, March 05, 2007 1:33 PM Subject: RV-List: Spare Parts List Is there a list of spare nuts & bolts & cotter pins & misc stuff out there to maintain an RV? I'd like to order up a package of stuff to have around rather than searching. I bought this RV flying already. _________________________________________________________________ Mortgage rates as low as 4.625% - Refinance $150,000 loan for $579 a month. Intro*Terms https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f6&disc=y&vers=743&s=4056&p=5117 ________________________________________________________________________________
Date: Mar 05, 2007
Not true, anyone can do the maintenance, only the builder or the others you mentioned can sign the condition inspection. LarryRobertHelming wrote: > Before buying materials, I think you should consider first who has the > authority to do maintenance on your plane. Usually the airplane > builder will get the certificate to do that on that particular plane > only. This privilege cannot be sold along with the plane > unfortunately. The only other people who can legally do all types > of maintenance work on an experimental are FAA authorized airplane > mechanics. > > You can legally do things like add and change oil and filter, add air > in tires, put grease in the tail wheel -- But the annual inspection > work must be performed by a licensed A&P. You really should not > need spare nuts and bolts. If you have insurance and want to rely on > it, you need to maintain the plane per the FAA rules or else it is > money wasted. > > Larry in Indiana > > ----- Original Message ----- > From: Greg Williams <mailto:mr.gsun(at)gmail.com> > To: rv-list(at)matronics.com > Sent: Monday, March 05, 2007 1:33 PM > Subject: RV-List: Spare Parts List > > Is there a list of spare nuts & bolts & cotter pins & misc stuff > out there to maintain an RV? I'd like to order up a package of > stuff to have around rather than searching. I bought this RV > flying already. > > >href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List >href="http://forums.matronics.com">http://forums.matronics.com > > >------------------------------------------------------------------------ > > > ________________________________________________________________________________
Date: Mar 05, 2007
Greg: You are asking a good question. Perhaps the answer is in the archive. Look for "traveling tool kit", "airplane tools", "emergency tools", or similar search string. I am close to starting this - but not yet. The list of things to include in your traveling toolkit would include a few cotter pins in the two popular sizes, a length of safety wire in the two sizes, a couple of fuses in every size that you would require to get you back home, small bolts plus washers and nuts in the small sizes, a tire gage perhaps, a small tool bag that you can strap down, etc. If you find something good let us all know. Others can submit as well. Ernie RV-9A O235 wood prop From: Greg Williams To: rv-list(at)matronics.com Is there a list of spare nuts & bolts & cotter pins & misc stuff out there to maintain an RV? I'd like to order up a package of stuff to have around rather than searching. I bought this RV flying already. ________________________________________________________________________________
Date: Mar 06, 2007
Without knowing what type of fasteners the original builder used to assemble his RV, it is difficult suggest specific hardware items to keep on hand. For instance, are the wingtips, cowling, and fairings installed with screws? If so, identify the type used and keep a small stash handy. Anytime a screw gets even slightly worn on my RV, I just throw it away and install a new one. An on-board emergency tool kit can be as spartan or as extensive as your imagination permits. You might want to consider keeping a spare fuel cap on board. You never know when a refueling event at some distant airport will result in a failed cap, and finding a local replacement can be problematic. Of course, duct tape is always handy to keep on board and can even be pressed into service as an instant fuel cap if need be. Enjoy your RV. Although you do not possess its unique Repairman's Certificate, you do enjoy a great deal of leeway in maintaining it. ________________________________________________________________________________
Date: Mar 06, 2007
Rick Galati wrote: > Without knowing what type of fasteners the original builder used to > assemble his RV, it is difficult suggest specific hardware items to > keep on hand. For instance, are the wingtips, cowling, and fairings > installed with screws? If so, identify the type used and keep a > small stash handy. Anytime a screw gets even slightly worn on my RV, > I just throw it away and install a new one. An on-board emergency > tool kit can be as spartan or as extensive as your imagination > permits. You might want to consider keeping a spare fuel cap on > board. You never know when a refueling event at some distant airport > will result in a failed cap, and finding a local replacement can be > problematic. Of course, duct tape is always handy to keep on board > and can even be pressed into service as an instant fuel cap if need > be. Enjoy your RV. Although you do not possess its unique > Repairman's Certificate, you do enjoy a great deal of leeway in > maintaining it. Another item I would add to the flight bag is either a spare fuel sump value or a 1/8" NPT plug. I've had a sump valve o-ring go bad a couple of times and needed to make a quick swap. You can easily change out the valve with either the spare or the plug and lose very little fuel in the process. Also found in my kit is a 6" length of 1/16" stainless welding rod from which a new pin can be quickly made for a fuel cap. And be sure you fly with a spare nose wheel tube or tailwheel chain link, whichever the case may be. Sam Buchanan ________________________________________________________________________________
Date: Mar 06, 2007
In assition to the hardware mentioned, I include main and nose tires/tubes, fuel cap, duct tape, tools needed to remove nose wheel fairing (hex wrench), valve stem removal tool and extra valve stems (the insert thingies), plus other stuff I would have to check. I have used the spare cap away from home. I have given a nose wheel tire and tube to my hangar mate away from home. Sam. thanks for the idea about the wing sump fitting. I will add that and an O-ring. Obviously you need basic tools. I will also be carrying an extra voltage regulator since I have converted to a plug and replace connector. Ron Lee --------------------------------------------- This message was sent using Endymion MailMan. http://www.endymion.com/products/mailman/ ________________________________________________________________________________
Date: Mar 06, 2007
Don't 4-get a spare spark plug and wrench. On Mar 6, 2007, at 5:36 AM, Sam Buchanan wrote: > > Rick Galati wrote: > >> Without knowing what type of fasteners the original builder used to >> assemble his RV, it is difficult suggest specific hardware items to >> keep on hand. For instance, are the wingtips, cowling, and fairings >> installed with screws? If so, identify the type used and keep a >> small stash handy. Anytime a screw gets even slightly worn on my RV, >> I just throw it away and install a new one. An on-board emergency >> tool kit can be as spartan or as extensive as your imagination >> permits. You might want to consider keeping a spare fuel cap on >> board. You never know when a refueling event at some distant airport >> will result in a failed cap, and finding a local replacement can be >> problematic. Of course, duct tape is always handy to keep on board >> and can even be pressed into service as an instant fuel cap if need >> be. Enjoy your RV. Although you do not possess its unique >> Repairman's Certificate, you do enjoy a great deal of leeway in >> maintaining it. >> > > Another item I would add to the flight bag is either a spare fuel > sump value or a 1/8" NPT plug. I've had a sump valve o-ring go bad > a couple of times and needed to make a quick swap. You can easily > change out the valve with either the spare or the plug and lose > very little fuel in the process. > > Also found in my kit is a 6" length of 1/16" stainless welding rod > from which a new pin can be quickly made for a fuel cap. And be > sure you fly with a spare nose wheel tube or tailwheel chain link, > whichever the case may be. > > Sam Buchanan > > ________________________________________________________________________________
Date: Mar 06, 2007
Subject: Re: Bose X, QC2, and Headset rant!
On 2:37 2007-03-06 Paul Besing wrote: > Now for my personal rant, it's amazing to me that people continue > to find a cheap way around headsets. Upgrading a pair of painful > clamping DC's from 1983, wiring your own, etc, etc. It is probably the > single most important piece of flying gear. It's comfort, it's > hearing, it's, communication. If one were spending 60-80K on building > an airplane, a $1,000 purchase for headsets seems cheap to me. I hear what you're saying Paul, but here's what it boils down to for me: My David Clarks are comfortable. I have a pair of 10-13.4's that have served me well for 7 years. They've never been uncomfortable, and I have a head that, to be nice to myself, "is of above average size." For that headset, I paid less than 1/3 the cost of a Bose X. Your comparison to spending 60-80K on building an airplane is extremely poor. By building an RV, i'm spending 60-80K on building an airplane that when finished will be worth more than that (how much more remains to be seen). By buying a Bose X, I would be spending $1K on a headset that might cost $200 to make in a Chinese factory. If we used the argument that "$X is cheap, when you're spending $60K to build your airplane", it wouldn't take long before it was costing $100K to build your airplane. -Rob ________________________________________________________________________________
Date: Mar 06, 2007
Well, I have a bag of crap on the tool kit, but I have no idea what I put in there???? Cotter pins for a few things like axles Zip ties, various sizes Safety wire, several sizes 300-kt tape, silver, red might be better though as it could be used for emergency lettering Various wire terminals Spare fuses and bulbs for the few things that have them 1 set of brake pads and rivets 2 spark plugs Possibly some misc AN hardware bolt, however if I break anything along these lines the odds are fairly low that having an extra will be all that is needed. Some various screws and stuff for missing cowl/fairing screws. Spare key for ign and fuel caps Brake M/C overhaul kit (spring and orings) Spare fuel cap pins and oring, although I don't have those kind of caps anymore??? I guess I should work on that. Tire valve stem valve and extra cap Extra anywheremap/compaq connector - they break easily Probably a few other things I can't think of right now. W ________________________________________________________________________________
Date: Mar 06, 2007
Subject: Bose X, QC2, and Headset rant!
On 13:02 2007-03-06 luckymacy(at)comcast.net (lucky) wrote: > have you taken any 3 + 3 hour trips in one day (ie, long cross > country for 6 hours or more)? > > How do you keep the plugs sanitary and how often do you change plugs > and can you find them cheaply locally? If they're anything like my custom silicone earplugs, they're easy to keep clean. Soap and water washes the plug portion and they're good as new. I've worn my silicone ones for a 12 hour trans-pacific flight, and they were comfortable and noise-attenuating all the way. -Rob ________________________________________________________________________________
Subject: RE: Bose X, QC2, and Headset rant!
Date: Mar 06, 2007
I've modified a Plantronics Star headset to use earplugs, similar to the Clarity Aloft, using a tubing 'Y' and poking holes in foam earplugs with a hot wire and sliding them over plastic tubing running to each ear. I've found a type of earplug that is both comfortable and reduce noise by a reported 33db - Max 200-1 (they are red and have sort of a bell shape). I can wear them for hours in total comfort - don't even notice that I have them in. You can make your own replacement earplugs for the Clarity Aloft the same way. I use a coat hanger wire heated with a propane torch to poke the holes. I've made some replacement plugs for my son's Clarity Aloft. I just stripped off the CA foam plug and slid on the new ones. I wear the same foam plugs when riveting. Far more effective than any earmuff type of protection. Dennis Glaeser RV7A - Finishing ________________________________________________________________________________
Subject: Superior XP O320 vs. 9A - Continuing Saga
Date: Mar 07, 2007
From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com>
I wrote several weeks ago about the interference between Superior's O320 carb and the 9A's lower cowl. The planned fix from Superior is to swap out the longer carb with a shorter one. Superior has been telling me that the testing of the new carb keeps getting bumped. They supposedly were finally able to test it last week, but the EGT's varied by as much as 300 degrees. According to the Superior rep, they have ordered another carb to test, but may have to test several before they get acceptable test results. This news is very disappointing to me, as I was hoping to fly to Sun-n-Fun in April. The good news is that I'll have a 9-hour drive to stew about having to drive and to wonder if Aerosport wouldn't have been a better choice. ________________________________________________________________________________
Subject: horiz. snorkel and cowling clearance
Date: Mar 07, 2007
Hey guys, I just fit my horiz. induction snorkel to the engin and baffling, but when I put the cowl bottom cowl on, it touches the lower front part of the snorkel. Any suggestions, or am I just going to have to cut out a piece out of the snorkel and make it smaller. Thanks in advance, Paul ________________________________________________________________________________
Date: Mar 07, 2007
Subject: Alternator field current?
Folks, I may be having a brain lockup, but trying to determine field current for the old 14184 type Van's alternator. I just began running my engine for the first time, and thought I had it wired per Z-11. I had inserted a 5a fuse onto the field circuit at the bus because I thought this would be equivalent to inserting one inline after the switch as Z-11 shows instead of the 22AWG fuselink. Z-11 looks like this circuit has double protection with the fuselink and 5a fuse on the same circuit . Well, upon first start, the 5a fuse on the buss blew, so I have two questions for Bob and/or other smart people on this list. 1) Why the "extra" protection on the field circuit? 2) What typically would the current draw be on the field circuit for this 35a alternator. I checked the archives and manuals, no joy... BTW, if it matters, this is the "Generic Ford" regulator as per Z-11 Any/all advice/input appreciated... If you have an immediate answer, please email me as well at jerry2dt(at)aol.com Jerry Cochran RV6a FAA inspection tomorrow!!!
Subject: Re: Superior XP O320 vs. 9A - Continuing Saga
Date: Mar 07, 2007
Daniel, So I take it Superior is using a non-standard O-320 carburetor? Have you thought about ordering an RV-7A O-360 lower cowl? I had a similar problem... discovered that my SilverHawk FI servo is taller than an O-320 carb necessitating a lower cowl with the O-360 scoop. Full story... http://www.romeolima.com/RV3works/Airframe/airframe.htm#Finish Randy Lervold ----- Original Message ----- From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com> Sent: Wednesday, March 07, 2007 5:22 AM Subject: RV-List: Superior XP O320 vs. 9A - Continuing Saga > > I wrote several weeks ago about the interference between Superior's O320 > carb and the 9A's lower cowl. The planned fix from Superior is to swap > out the longer carb with a shorter one. Superior has been telling me > that the testing of the new carb keeps getting bumped. They supposedly > were finally able to test it last week, but the EGT's varied by as much > as 300 degrees. According to the Superior rep, they have ordered > another carb to test, but may have to test several before they get > acceptable test results. > > This news is very disappointing to me, as I was hoping to fly to > Sun-n-Fun in April. The good news is that I'll have a 9-hour drive to > stew about having to drive and to wonder if Aerosport wouldn't have been > a better choice. > > > ________________________________________________________________________________
Subject: Re: Alternator field current?
Date: Mar 07, 2007
Jerry My B&C 60A draws about 4 amps. Richard Reynolds Norfolk, VA RV-6A, 350 hours On Mar 7, 2007, at 1:22 PM, Jerry2DT(at)aol.com wrote: > Folks, > > I may be having a brain lockup, but trying to determine field > current for the old 14184 type Van's alternator. I just began > running my engine for the first time, and thought I had it wired > per Z-11. I had inserted a 5a fuse onto the field circuit at the > bus because I thought this would be equivalent to inserting one > inline after the switch as Z-11 shows instead of the 22AWG > fuselink. Z-11 looks like this circuit has double protection with > the fuselink and 5a fuse on the same circuit > . > Well, upon first start, the 5a fuse on the buss blew, so I have two > questions for Bob and/or other smart people on this list. > > 1) Why the "extra" protection on the field circuit? > > 2) What typically would the current draw be on the field circuit > for this 35a alternator. I checked the archives and manuals, no joy... > > BTW, if it matters, this is the "Generic Ford" regulator as per Z-11 > > Any/all advice/input appreciated... > > If you have an immediate answer, please email me as well at > jerry2dt(at)aol.com > > Jerry Cochran > RV6a FAA inspection tomorrow!!! > > > AOL now offers free email to everyone. Find out more about > what1227241x4298082137/aol?redir=http://www.aol.com" href="http:// > pr.atwola.com/promoclk/1615326657x4311227241x4298082137/aol? > redir=http%3A%2F%2Fwww%2Eaol%2Ecom" target="_blank">AOL.com. > > ________________________________________________________________________________
Date: Mar 07, 2007
Jerry, The field current is not necessarily related to the output current rating of the alternator. It would normally be smaller for a small alternator, but not always in direct proportion. It should be less than 10 amps for sure. Try a temporary 10 amp fuse in place of your 5 amp fuse. If that blows, you have a problem. If it works, measure the current and use a fuse rated for about 1.5 to 2 times that current. I think the field fuse or switch/breaker is just a way to disable the alternator if it should become necessary for any reason -- like an overvoltage condition. Some automotive internal electronic regulators may not turn off if the "field" breaker is turned off. They must get power from some other source. There has been a lot of discussion about this on various lists. Dan Hopper Automotive engineer, ret. RV-7A N766DH Just flew yesterday, finally -- weather has been awful here in IN this winter. In a message dated 3/7/2007 1:26:21 PM Eastern Standard Time, Jerry2DT(at)aol.com writes: . Well, upon first start, the 5a fuse on the buss blew, so I have two questions for Bob and/or other smart people on this list. 1) Why the "extra" protection on the field circuit? 2) What typically would the current draw be on the field circuit for this 35a alternator. I checked the archives and manuals, no joy... BTW, if it matters, this is the "Generic Ford" regulator as per Z-11 Any/all advice/input appreciated... If you have an immediate answer, please email me as well at jerry2dt(at)aol.com Jerry Cochran RV6a FAA inspection tomorrow!!!
Subject: Re: horiz. snorkel and cowling clearance
Date: Mar 07, 2007
I did the same thing. You need to remove some of the snorkel to make it shorter. Larry in Indiana ----- Original Message ----- From: Paul Rice To: rv-list(at)matronics.com Sent: Wednesday, March 07, 2007 10:33 AM Subject: RV-List: horiz. snorkel and cowling clearance Hey guys, I just fit my horiz. induction snorkel to the engin and baffling, but when I put the cowl bottom cowl on, it touches the lower front part of the snorkel. Any suggestions, or am I just going to have to cut out a piece out of the snorkel and make it smaller. Thanks in advance, Paul ________________________________________________________________________________
Date: Mar 07, 2007
Thanks Larry, Just wanted to make sure I wasn't the only one that ever had this problem. Paul ----- Original Message ----- From: LarryRobertHelming<mailto:lhelming(at)sigecom.net> To: rv-list(at)matronics.com Sent: Wednesday, March 07, 2007 10:44 PM Subject: Re: RV-List: horiz. snorkel and cowling clearance I did the same thing. You need to remove some of the snorkel to make it shorter. Larry in Indiana ----- Original Message ----- From: Paul Rice<mailto:rice737(at)msn.com> To: rv-list(at)matronics.com Sent: Wednesday, March 07, 2007 10:33 AM Subject: RV-List: horiz. snorkel and cowling clearance Hey guys, I just fit my horiz. induction snorkel to the engin and baffling, but when I put the cowl bottom cowl on, it touches the lower front part of the snorkel. Any suggestions, or am I just going to have to cut out a piece out of the snorkel and make it smaller. Thanks in advance, Paul href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com http://www.matronics.com/Navigator?RV-List ator?RV-List> ________________________________________________________________________________
Subject: Headset rant
Date: Mar 07, 2007
I gotta go with the gentleman that mentioned the Clarity Aloft. I have those and could not imagine going back to conventional headset. I've worn the Bose and they are nice but they still are a headset. With the Clarity you have no issues with sunglasses, hats or the clamping force that gets old after a while. With the Bose you are paying $500 for the headset and $500 for the name!!! DArwin N. Barrie Chandler AZ RV7 N717EE ________________________________________________________________________________
Date: Mar 08, 2007
>Subject: RV-List: Alternator field current? > >I may be having a brain lockup, but trying to determine field current >for the old 14184 type Van's alternator. Z-11 looks like this circuit has >double protection with the fuselink and 5a fuse on the same circuit. 5 Amps is plenty. Remember you are protecting the wire NOT the regulator or alternator. To answer your question I would guess the draw at max output to be about 3 amps, 3.5 amps. The Z-11 dwg? In general you have two protections in the charge system. One from the battery or battery bus (via the starter contactor typical of Bobs scheme) to the output of the alternator (B-lead). This fuse, cuircuit breaker or fusible link must be at least 35 amps to handle the output but still protect the wire. I assume the field wire is at least 6 awg. The protection is near the battery or where the B-lead attaches to the pos circuit. The second protection is the HOT wire (+A terminal) to the voltage regulator (VR). This fuse or CB is about 5 amps, near the pos source. You should NOT see two protections in series on one wire. George --------------------------------- Sucker-punch spam with award-winning protection. Try the free Yahoo! Mail Beta. ________________________________________________________________________________
Date: Mar 08, 2007
> 5 Amps is plenty. Remember you are protecting > the wire NOT the regulator or alternator. I agree with George on this. The fuse or breaker is only to protect the wire. >> In general you have two protections in the charge system. One from the >> battery or battery bus (via the starter contactor typical of Bobs scheme) to the output of the alternator (B-lead). This fuse, cuircuit breaker or fusible link must be at least 35 amps to handle the output but still protect the wire. I assume the field wire is at least 6 awg. The protection is near the battery or where the B-lead attaches to the pos circuit.<< Again, I agree with George. > The second protection is the HOT wire (+A terminal) to the voltage > > regulator (VR). This fuse or CB is about 5 amps, near the pos source. And, this is what I'm using in my RV with no problems. I'm using a 35amp alternator, as well. > You should NOT see two protections in series on one wire. Let me add a small addition, here. In addition to the 5amp fuse or breaker, let me suggest an over voltage protection device, if you don't have one built into your system at the voltage regulator. This device checks the voltage to see if the alternator is putting out more voltage than it should. The limit is set at about 16V on the one I have. If the volatage surpasses the limit, the device triggers a direct short in the field wire that causes the fuse or breaker to fail. That protects the avionics, not the wire, against a runaway alternator if the voltage regulator fails. It's not needed when the regulator is functioning well; but, it can save you some money if the regulator fails. As for the fuse or breaker, let me suggest the breaker. I used a fuse in mine and ran into trouble with that idea when I was sorting out a problem in the charging system. I went through several fuses before all was said and done. The OV protection kept blowing the fuses, even when the new regulator was functioning well. I figured out it was the OV protection device that was failing in error. I sent it back for repairs. Shortly, I'll be putting the OV device back into the system and will do away with the fuse in favor of a new 5 amp breaker. Jim Sears in KY RV-6A N198JS (Scooter) RV-7A #70317 (On hold due to laziness) EAA Tech Counselor ________________________________________________________________________________
Date: Mar 08, 2007
Subject: Headset rant!
Dennis. What type of ear plug are you using? Brand ect-- I'm considering getting one of those types of head sets. My next purchase of head sets will be one like that. I don't want to be "ripped" off with replacement tips. Jim Nelson RV9-A (last electrical check before last skin on fuselage) ________________________________________________________________________________
Date: Mar 08, 2007
I have had this happen in my 170. The regulator went gunnysack and the OV protection kicked in. But apparently it was of a type the smoked itself inside to break the circuit and the alternator quit working. The problem was when the OV blew it made smoke in the cockpit. Since I didn't know what was going on at the time I shut down all electrical and made a steep spiral to a landing on an extreme high crosswind dirt landing strip just north of Lancaster, CA. I had to keep the plane running on the middle of the runway while my wife got out and held the tail. Then I could shut down and get off the runway. The good side was all my avionics were in good shape. Tim > > You should NOT see two protections in series on one wire. > > Let me add a small addition, here. In addition to the 5amp fuse or > breaker, > let me suggest an over voltage protection device, if you don't have one > built into your system at the voltage regulator. This device checks the > voltage to see if the alternator is putting out more voltage than it > should. > The limit is set at about 16V on the one I have. If the volatage > surpasses > the limit, the device triggers a direct short in the field wire that > causes > the fuse or breaker to fail. That protects the avionics, not the wire, > against a runaway alternator if the voltage regulator fails. It's not > needed when the regulator is functioning well; but, it can save you some > money if the regulator fails. > > As for the fuse or breaker, let me suggest the breaker. I used a fuse in > mine and ran into trouble with that idea when I was sorting out a problem > in > the charging system. I went through several fuses before all was said and > done. The OV protection kept blowing the fuses, even when the new > regulator > was functioning well. I figured out it was the OV protection device that > was failing in error. I sent it back for repairs. Shortly, I'll be > putting > the OV device back into the system and will do away with the fuse in favor > of a new 5 amp breaker. > > Jim Sears in KY > RV-6A N198JS (Scooter) > RV-7A #70317 (On hold due to laziness) > EAA Tech Counselor > > > > > > > ________________________________________________________________________________
Date: Mar 08, 2007
>> I have had this happen in my 170. The regulator went gunnysack and the >> OV protection kicked in. But apparently it was of a type the smoked >> itself inside to break the circuit and the alternator quit working. The >> problem was when the OV blew it made smoke in the cockpit.<< Yep, this is how I learned about the device in my Cheetah. It, too, failed and had to be replaced. Fortunately, I was able to replace the regulator with one that had OV protection built in. Since it was a commercially built aircraft, and one that required a more expensive FAA approved regulator, I opted to spend the few extra dollars to keep from having to by a regulator and OV protection seperately. I do have them seperate in the RV because I can use a $12 regulator in it. If I chose, I can even roll my own OV protection device for a few dollars. Jim in KY ________________________________________________________________________________
Subject: Re: Headset rant!
Date: Mar 08, 2007
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
I didn't have that info handy when I made my previous post (and knew I should have waited :-) Here are the ear plugs I'm using:
http://earplugstore.stores.yahoo.net/holemaxuffop.html I had originally gotten a pair of these at a local store, and loved them, but then I couldn't find them again. So I searched online and found them. I bought a box of 200, figuring that should last me a while... The headset I modified is a Plantronics MS50/T30-2 Aviation Headset. You can usually find them on Ebay for around $50 (do a search for Item number: 290090838388). I like the Clarity Aloft headsets a lot (my son and his wife have them), but for now my cheap alternative works fine. Dennis ------------------------------------------------------------------------ ------------------ Dennis. What type of ear plug are you using? Brand ect-- I'm considering getting one of those types of head sets. My next purchase of head sets will be one like that. I don't want to be "ripped" off with replacement tips. Jim Nelson RV9-A (last electrical check before last skin on fuselage) ________________________________________________________________________________
Subject: Flight Manual
Date: Mar 08, 2007
Wish to obtain a Flight Manual useful for 180 hp injected RV-8 w/ fixed pitch (85") Sensenich metal prop. Thanks in advance for your help and/or suggestions. Jack N8VZ taxiing tests, systems shakedown, corrections, etc, etc. _________________________________________________________________ Dont miss your chance to WIN 10 hours of private jet travel from Microsoft ________________________________________________________________________________
Subject: Check List RV9A
Date: Mar 08, 2007
I've looked high and low on the Matronics Index and can't find anyone with a downloadable checklist. Anyone got a downloadable copy? Chuck ________________________________________________________________________________
Date: Mar 08, 2007
I will mail you a copy in Word format. I also have GRT Horizon I electronic check list and CV Checklists (Control Vision) on PDA. Ted ------------------------------------------ T.C. Chang http://tc1234c.googlepages.com/ tc1234c(at)roadrunner.com RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, Dual Mag, Sensenich FP, all electric, GRT dual DU H1, TT DigiFlight II VSGV, 125 Hobbs 3/8/2007 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Chuck Weyant Sent: Thursday, March 08, 2007 3:02 PM Subject: RV-List: Check List RV9A I've looked high and low on the Matronics Index and can't find anyone with a downloadable checklist. Anyone got a downloadable copy? Chuck ________________________________________________________________________________
Subject: Looking for Charlie Kuss
Date: Mar 08, 2007
Charlie: I am going to be in Boca next Monday thru Friday. I lost your number. Shoot me an email, and maybe we can get together some time next week. Al Grajek ________________________________________________________________________________
From: "Brian Meyette" <brianpublic2(at)starband.net>
Date: Mar 09, 2007
I'd like to see a copy of this. I didn't see a link on your website to it, but if one was there, it'd save you a lot of "me too" emails, like this one Thanks, brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of T.C. Chang Sent: Thursday, March 08, 2007 3:45 PM Subject: RE: RV-List: Check List RV9A I will mail you a copy in Word format. I also have GRT Horizon I electronic check list and CV Checklists (Control Vision) on PDA. Ted ------------------------------------------ T.C. Chang http://tc1234c.googlepages.com/ tc1234c(at)roadrunner.com RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, Dual Mag, Sensenich FP, all electric, GRT dual DU H1, TT DigiFlight II VSGV, 125 Hobbs 3/8/2007 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Chuck Weyant Sent: Thursday, March 08, 2007 3:02 PM Subject: RV-List: Check List RV9A I've looked high and low on the Matronics Index and can't find anyone with a downloadable checklist. Anyone got a downloadable copy? Chuck -- 9:24 AM -- 10:58 AM ________________________________________________________________________________
Date: Mar 09, 2007
Brian, I am using googlepages server and I am not able upload non-photo files. I have created a new page called "checklist" that is linked from my homepage. Ted ------------------------------------------ T.C. Chang http://tc1234c.googlepages.com/ tc1234c(at)roadrunner.com RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, Dual Mag, Sensenich FP, all electric, GRT dual DU H1, TT DigiFlight II VSGV, 125 Hobbs 3/8/2007 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Meyette Sent: Friday, March 09, 2007 10:25 AM Subject: RE: RV-List: Check List RV9A --> I'd like to see a copy of this. I didn't see a link on your website to it, but if one was there, it'd save you a lot of "me too" emails, like this one Thanks, brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of T.C. Chang Sent: Thursday, March 08, 2007 3:45 PM Subject: RE: RV-List: Check List RV9A I will mail you a copy in Word format. I also have GRT Horizon I electronic check list and CV Checklists (Control Vision) on PDA. Ted ------------------------------------------ T.C. Chang http://tc1234c.googlepages.com/ tc1234c(at)roadrunner.com RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, Dual Mag, Sensenich FP, all electric, GRT dual DU H1, TT DigiFlight II VSGV, 125 Hobbs 3/8/2007 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Chuck Weyant Sent: Thursday, March 08, 2007 3:02 PM Subject: RV-List: Check List RV9A I've looked high and low on the Matronics Index and can't find anyone with a downloadable checklist. Anyone got a downloadable copy? Chuck -- 9:24 AM -- 10:58 AM ________________________________________________________________________________
Date: Mar 09, 2007
I figured out how to include text file download in googlepages server. I created two pages with useful data: A. http://tc1234c.googlepages.com/checklist2 : RV-9A checklist B. http://tc1234c.googlepages.com/technicalinformation : wiring diagrams, O320-D2A engine performance table, RV-9A POH, panel labels, and takeoff & landing procedures. Ted ________________________________________________________________________________
Date: Mar 10, 2007
Subject: Navaid AP Manual
Hey all, Does anyone out there have a Navaid Autopilot manual that can be sent to me via email? I recently bought an RV-6A with a Navaid and want to try to get the Navaid set up better. The autopilot cannot maintain a good wings level and continuously rocks the aircraft back and forth. Am hoping there is some pearl in the setup that will mean I can avoid having to replace it with a Trio. Many thanks, Scott Lewis RV-6A VH-AFG RV-10 40172 Quorn, South Australia ________________________________________________________________________________
Date: Mar 10, 2007
Its on navaids website, but the rocking you seeing is they need Something to slow down the noise a little, once done they are rock Solid.. call them and they will explain it very well to you.. 423-267-3311 is the number.. the manual is at www.navaid-devices.com have to look on the site to find the manual.. Sorry I couldn't be more help.. Danny.. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Lewis Sent: Friday, March 09, 2007 11:55 PM Subject: RV-List: Navaid AP Manual Hey all, Does anyone out there have a Navaid Autopilot manual that can be sent to me via email? I recently bought an RV-6A with a Navaid and want to try to get the Navaid set up better. The autopilot cannot maintain a good wings level and continuously rocks the aircraft back and forth. Am hoping there is some pearl in the setup that will mean I can avoid having to replace it with a Trio. Many thanks, Scott Lewis RV-6A VH-AFG RV-10 40172 Quorn, South Australia ________________________________________________________________________________
Date: Mar 10, 2007
Subject: Brake Lines along gear legs - front or back?
I just put my RV-7A on its gear,,,very exciting! I was reviewing my preview plans and the brake lines are shown going down the back of the main gear legs. When I went down to the hanger in my basement the real plans indicate the lines should go down the front. The revision dates on the two sets of plans are the same. I know I should build off the real plans but the preview plans seem to make more sense. The brake lines would be better protected going down the back side. What have others done and does it really matter? Thanks in advance! Dan Reeves RV-7A - starting to wonder how I'm going to get it out of the basement! --------------------------------- Expecting? Get great news right away with email Auto-Check. Try the Yahoo! Mail Beta. ________________________________________________________________________________
Date: Mar 10, 2007
I have it in front of the gear leg. The union comes out of the fuselage is in front of the gear leg. I just run the line straight down. The line is protected by the fairing. Ted ------------------------------------------ T.C. Chang <http://tc1234c.googlepages.com/> http://tc1234c.googlepages.com/ tc1234c(at)roadrunner.com RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, Dual Mag, Sensenich FP all electric, GRT dual DU H1, TT DigiFlight II VSGV, 125 Hobbs 3/8/2007 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Reeves Sent: Saturday, March 10, 2007 9:11 AM Subject: RV-List: Brake Lines along gear legs - front or back? I just put my RV-7A on its gear,,,very exciting! I was reviewing my preview plans and the brake lines are shown going down the back of the main gear legs. When I went down to the hanger in my basement the real plans indicate the lines should go down the front. The revision dates on the two sets of plans are the same. I know I should build off the real plans but the preview plans seem to make more sense. The brake lines would be better protected going down the back side. What have others done and does it really matter? Thanks in advance! Dan Reeves RV-7A - starting to wonder how I'm going to get it out of the basement! ________________________________________________________________________________
Date: Mar 11, 2007
Subject: Re: Navaid AP Manual
Hey Danny, Thanks for the response. The only form of manual on the website that I can find is the basic how to use bit. I am more interested in the setup and adjustment details, like how can I get the Navaid to realise that "wings level" is not a 5 degree bank to the right? Thanks, Scott Lewis Quorn, South Australia sportypilot wrote: > > Its on navaids website, but the rocking you seeing is they need > Something to slow down the noise a little, once done they are rock > Solid.. call them and they will explain it very well to you.. > 423-267-3311 is the number.. the manual is at www.navaid-devices.com > have to look on the site to find the manual.. > > Sorry I couldn't be more help.. > > Danny.. > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Lewis > Sent: Friday, March 09, 2007 11:55 PM > To: rv-list(at)matronics.com > Subject: RV-List: Navaid AP Manual > > > Hey all, > > Does anyone out there have a Navaid Autopilot manual that can be sent to > me via email? > > I recently bought an RV-6A with a Navaid and want to try to get the > Navaid set up better. The autopilot cannot maintain a good wings level > and continuously rocks the aircraft back and forth. Am hoping there is > some pearl in the setup that will mean I can avoid having to replace it > with a Trio. > > Many thanks, > Scott Lewis > RV-6A VH-AFG > RV-10 40172 > Quorn, South Australia > > > > > > > > ________________________________________________________________________________
Date: Mar 10, 2007
As far as centered , I would remove the wingtip and get it adjusted With the knobs centered using the wing alignment holes to get both Ailerons true centered, I am not sure if your using the smart coupler I don't have one, he said he would fax me a new procedure to adjust The pot as the one in the manual was hard to understand as I needed To move the crank arm 90 degree's.. I know you're a long way Away but calling him is your best bet.. he is very helpful.. I have all the manuals but I don't have a way to get them into A document to email you.. Danny.. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Lewis Sent: Saturday, March 10, 2007 9:09 AM Subject: Re: RV-List: Navaid AP Manual Hey Danny, Thanks for the response. The only form of manual on the website that I can find is the basic how to use bit. I am more interested in the setup and adjustment details, like how can I get the Navaid to realise that "wings level" is not a 5 degree bank to the right? Thanks, Scott Lewis Quorn, South Australia sportypilot wrote: > > Its on navaids website, but the rocking you seeing is they need > Something to slow down the noise a little, once done they are rock > Solid.. call them and they will explain it very well to you.. > 423-267-3311 is the number.. the manual is at www.navaid-devices.com > have to look on the site to find the manual.. > > Sorry I couldn't be more help.. > > Danny.. > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Lewis > Sent: Friday, March 09, 2007 11:55 PM > To: rv-list(at)matronics.com > Subject: RV-List: Navaid AP Manual > > > Hey all, > > Does anyone out there have a Navaid Autopilot manual that can be sent to > me via email? > > I recently bought an RV-6A with a Navaid and want to try to get the > Navaid set up better. The autopilot cannot maintain a good wings level > and continuously rocks the aircraft back and forth. Am hoping there is > some pearl in the setup that will mean I can avoid having to replace it > with a Trio. > > Many thanks, > Scott Lewis > RV-6A VH-AFG > RV-10 40172 > Quorn, South Australia > > > > > > > > ________________________________________________________________________________
Subject: Re: Brake Lines along gear legs - front or back?
Date: Mar 10, 2007
Either way will work, choose whichever one leads to a cleaner path to the firewall and into the cockpit. In my case that meant putting them on the back of the leg. Just make sure you leave an adequate loop at the bottom for removing/servicing the caliper, and that the line won't hit the tire or iside of the wheel pant (chafing damage). http://www.romeolima.com/RV3works/Airframe/DSC_1024.jpg Randy Lervold RV-3B ----- Original Message ----- From: Dan Reeves To: rv-list(at)matronics.com Sent: Saturday, March 10, 2007 6:10 AM Subject: RV-List: Brake Lines along gear legs - front or back? I just put my RV-7A on its gear,,,very exciting! I was reviewing my preview plans and the brake lines are shown going down the back of the main gear legs. When I went down to the hanger in my basement the real plans indicate the lines should go down the front. The revision dates on the two sets of plans are the same. I know I should build off the real plans but the preview plans seem to make more sense. The brake lines would be better protected going down the back side. What have others done and does it really matter? Thanks in advance! Dan Reeves RV-7A - starting to wonder how I'm going to get it out of the basement! ________________________________________________________________________________
Date: Mar 10, 2007
Hi Scott, I initially had some instability as you mentioned with my Navaid. Navaid people were aware of this condition with some airplane with very light aileron forces. They recommended a resistor installation at the servo. This solved my problem. The manual does have some information on setting the null position of the gyro. This requires using a digital VOM across some pins on the rear of the control unit and adjusting a pot. I will get the manual from the hangar and send you some info. Ken RV-6A N94KB RV-4 N63KB > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Scott Lewis > Sent: Friday, March 09, 2007 11:55 PM > To: rv-list(at)matronics.com > Subject: RV-List: Navaid AP Manual > > > Hey all, > > Does anyone out there have a Navaid Autopilot manual that can be sent to > me via email? > > I recently bought an RV-6A with a Navaid and want to try to get the > Navaid set up better. The autopilot cannot maintain a good wings level > and continuously rocks the aircraft back and forth. Am hoping there is > some pearl in the setup that will mean I can avoid having to replace it > with a Trio. > > Many thanks, > Scott Lewis > RV-6A VH-AFG > RV-10 40172 > Quorn, South Australia > > ________________________________________________________________________________
Date: Mar 10, 2007
On HRII N561FS we had this conversation about 8 years ago, Ran them down the back. In year two of flying we did have an airborne bird strike. Took the entire left gear flaring off, gone. Not the wheel cover the fairing only. Since the brake line was on the "back" side of the gear leg it was untouched. Landing was smooth & the brakes worked. Had it been on the front & exposed to "incoming", who knows.? ? ? KABONG Do Not Archive. Just a short story. The RV-12 will have them in the back. ----- Original Message ----- From: Dan Reeves To: rv-list(at)matronics.com Sent: Saturday, March 10, 2007 6:10 AM Subject: RV-List: Brake Lines along gear legs - front or back? I just put my RV-7A on its gear,,,very exciting! I was reviewing my preview plans and the brake lines are shown going down the back of the main gear legs. When I went down to the hanger in my basement the real plans indicate the lines should go down the front. The revision dates on the two sets of plans are the same. I know I should build off the real plans but the preview plans seem to make more sense. The brake lines would be better protected going down the back side. What have others done and does it really matter? Thanks in advance! Dan Reeves RV-7A - starting to wonder how I'm going to get it out of the basement! ________________________________________________________________________________
Date: Mar 10, 2007
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Subject: RV3B For Sale
Date: Mar 10, 2007
789RV is for sale. I have $52K and 6700 hours invested and have reduced the price to $43K. Details and pictures can be seen at www.barnstormers.com. Thanks for your time, Rick Fogerson. ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Subject: Re: RV3B For Sale
Date: Mar 11, 2007
Hi Rick, what is the empty weight of your Rv3? ----- Original Message ----- From: Rick Fogerson To: rv3-list(at)matronics.com ; RV List Sent: Sunday, March 11, 2007 3:10 AM Subject: RV-List: RV3B For Sale 789RV is for sale. I have $52K and 6700 hours invested and have reduced the price to $43K. Details and pictures can be seen at www.barnstormers.com. Thanks for your time, Rick Fogerson. ________________________________________________________________________________
Date: Mar 11, 2007
Subject: Autopilot wing rocking
I've had the wing rocking thing on my autopilot since I got it, but I found for me it is related to aileron trim. I have an external trim tab on the outboard end of my left aileron. If I turn on the autopilot and the wings start rocking, I can adjust the trim to one side (right, I think) and things calm down. I'm sure that is slightly more drag, but I can live with it. Rick Grenwis
AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. ________________________________________________________________________________
Date: Mar 11, 2007
Subject: Re: Autopilot wing rocking
This wing rocking problem is covered under "SETTING SYSTEM GAIN" in the Navaid manual. Quoting from my manual, page 14: "The autopilot should fly the airplane in a manner more or less similar to that of human pilots. If the stick action feels too jittery for the weather conditions, or if the airplane is continually hunting (oscillating) back and forth like a snake trying to follow a straight line, the system gain is probably set too high for your aircraft. "Remembering that the trimpots should not be forced beyond their 9 o'clock and 3 o'clock stops, you lower system gain by turning the SPAN trimpot counterclockwise. Decrease the gain (turn SPAN trimpot counterclockwise) until the stick calms down, then increase it to the point where the stick becomes jittery again. With your airplane operating at its usual cruise speed, set the gain as high as possible without oscillation or jittery stick movement. "If the SPAN trimpot ends up being set below 75% of maximum (full clockwise), the servo RANGE trimpot is set too high and tracking performance may be degraded. The following procedure increases servo resolution without changing system gain. Land the airplane and measure (better write it down) the full range of aileron movement obtainable using the TURN CONTROL with the autopilot in Wing Leveler mode. "Set the span to about 90% of full clockwise rotation. "Adjust the RANGE trimpot on the servo printed circuit board to restore that same range of aileron deflection." Dan Hopper RV-7A
Subject: RV6/6A Fuel Tank Attachment
Date: Mar 11, 2007
In preparation for replacing my loose slosh fuel tanks I want to mount the inboard forward bracket attachment the way Van now recommends it. My earlier plans just had you bolt the angle from the fuselage to the angle from the fuel tank tip. How is the 'new' arrangement? Which angle bracket gets the 1/4-inch slot? The tank one or the fuselage one? Also which goes forward - the tank bracket or the fuselage bracket.? Which bracket gets the platenut? My search said that Rvator #1 of 1998 shows what Van now recommends, but my old Rvators were given away long ago. If someone had one handy and could e-mail me what I believe is on page 11 of that issue I would appreciate it. Thanks for any help/insight. John n1cxo320(at)salidaco.com ________________________________________________________________________________
Date: Mar 11, 2007
Subject: Re: RV6/6A Fuel Tank Attachment
John Fasching wrote: > In preparation for replacing my loose slosh fuel tanks I want to mount > the inboard forward bracket attachment the way Van now recommends it. > My earlier plans just had you bolt the angle from the fuselage to the > angle from the fuel tank tip. > > How is the 'new' arrangement? Which angle bracket gets the 1/4-inch > slot? The tank one or the fuselage one? > Also which goes forward - the tank bracket or the fuselage bracket.? > Which bracket gets the platenut? John, 1st issue 1998, p 11 shows: * slot in the tank angle * plate nut in the fuselage angle * tank angle forward of the fuselage angle. If you'd like, I can scan the page and e-mail it directly to you. Steve RV-6A ________________________________________________________________________________
Date: Mar 11, 2007
No, thank you, Steve, the information you gave me is exactly what I needed to know. I can take it from here. Again, thank you !!! John ________________________________________________________________________________
Date: Mar 11, 2007
Tank one goes foreward. Tank one get s the slot. Fuse one gets the platenut. Just did my 6A. Don't have the appropriate RVator handy though - but I can take pictures next weekend of my install! Zap me direct......if you want 'em..... Ralph ----- Original Message ----- From: John Fasching To: rv-list(at)matronics.com Sent: Sunday, March 11, 2007 1:15 PM Subject: RV-List: RV6/6A Fuel Tank Attachment In preparation for replacing my loose slosh fuel tanks I want to mount the inboard forward bracket attachment the way Van now recommends it. My earlier plans just had you bolt the angle from the fuselage to the angle from the fuel tank tip. How is the 'new' arrangement? Which angle bracket gets the 1/4-inch slot? The tank one or the fuselage one? Also which goes forward - the tank bracket or the fuselage bracket.? Which bracket gets the platenut? My search said that Rvator #1 of 1998 shows what Van now recommends, but my old Rvators were given away long ago. If someone had one handy and could e-mail me what I believe is on page 11 of that issue I would appreciate it. Thanks for any help/insight. John n1cxo320(at)salidaco.com ________________________________________________________________________________
Date: Mar 11, 2007
John Fasching wrote: > No, thank you, Steve, the information you gave me is exactly what I > needed to know. I can take it from here. > > Again, thank you !!! John, Just for the record, in case you don't have this, there are some details on the bolt/washer installation. It is not a standard 1/4" bolt torque. From the RVator: "Do not over tighten the bolt. If there is too much clamping pressure the joint will note separate. The correct torque is achieved by tightening the bolt until the AN970 washer can barely be moved with your fingers. Then tighten the bolt 1/6 of a turn (one flat on the head). The bolt has a drilled head and should be safety wired." Good luck with the tank slosh clean out. Steve ________________________________________________________________________________
Date: Mar 11, 2007
Subject: Langley Fly-in June 23
The Langley, BC fly-in will be Saturday, June 23. This is the annual fly-in of the Western Canada Wing. Langley, BC, is about 20 nm north of Bellingham, WA. We generally have a good turnout of RVs from all over BC, and a good contingent from the U.S., too. Details are on our web page, http://www.vansairforce.org/CYNJ/ For U.S. visitors, the Home Wing web page has all the information you need on border crossing procedures. http://www.edt.com/homewing/international/ I hope lots of RV-Listers can make it. --- Tedd McHenry Van's Air Force Western Canada Wing tedd(at)vansairforce.org www.vansairforce.org ________________________________________________________________________________
Subject: Full face mask for painting
Date: Mar 11, 2007
I'm looking for a source of full face masks to be used for painting using supplied fresh air. I've located a 3m mask designed for this application which costs $120.00. I've also found one that I think will work from McMaster-Carr for $75.00 and they have disposable clear lens protectors for this mask. Any other suggestions for a lower cost alternative or one better suited for this application? Anybody have experience wearing eyeglasses under one of these? Thanks, Dave ________________________________________________________________________________
Subject: Re: Langley Fly-in June 23
Date: Mar 12, 2007
> For U.S. visitors, the Home Wing web page has all the information you need on border crossing procedures. > > http://www.edt.com/homewing/international/ One possible correction. I believe that you need a passport now to re-enter the USA. With processing times around 10 weeks now I would expedite the paperwork. http://travel.state.gov/passport/passport_1738.html Ron Lee --------------------------------------------- This message was sent using Endymion MailMan. http://www.endymion.com/products/mailman/ ________________________________________________________________________________
Date: Mar 11, 2007
Subject: Re: Full face mask for painting
In a message dated 3/11/2007 5:15:12 P.M. Pacific Daylight Time, d-burton(at)comcast.net writes: I'm looking for a source of full face masks to be used for painting using supplied fresh air. I've located a 3m mask designed for this application which costs $120.00. I've also found one that I think will work from McMaster-Carr for $75.00 and they have disposable clear lens protectors for this mask. Any other suggestions for a lower cost alternative or one better suited for this application? Anybody have experience wearing eyeglasses under one of these? =============================================== I might have an old one laying around that you may have for free. I'll look in the hangar next time I'm out there. There is enough room for eyeglasses but you'll have to find the peel-offs. GV (RV-6A N1GV O-360-A1A, C/S, Flying 840hrs, Silicon Valley, CA)
Date: Mar 11, 2007
Steve: Wh en you get the page scanned, I would greatly appreciate a copy of it also. Please email me at HYPERLINK "mailto:gerric(at)shaw.ca"gerric(at)shaw.ca Thank you for your time. Gerald Richardson RV-6A _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Steve Allison Sent: Sunday, March 11, 2007 12:42 Subject: Re: RV-List: RV6/6A Fuel Tank Attachment John Fasching wrote: In preparation for replacing my loose slosh fuel tanks I want to mount the inboard forward bracket attachment the way Van now recommends it. My earlier plans just had you bolt the angle from the fuselage to the angle from the fuel tank tip. How is the 'new' arrangement? Which angle bracket gets the 1/4-inch slot? The tank one or the fuselage one? Also which goes forward - the tank bracket or the fuselage bracket.? Which bracket gets the platenut? John, 1st issue 1998, p 11 shows: * slot in the tank angle * plate nut in the fuselage angle * tank angle forward of the fuselage angle. If you'd like, I can scan the page and e-mail it directly to you. Steve RV-6A "http://www.matronics.com/Navigator?RV-List"http://www.matronics.com/Navigat or?RV-List -- 09:27 -- 09:27 ________________________________________________________________________________
Subject: Re: Glass for IFR
Date: Mar 11, 2007
I was "just passing thru" and saw this post and could not resist a comment. I am now on my second Dynon IFR airplane. (RV-4 and F-1 EVO) I have flown over 500 hours behind Dynons with lots of actual including low approaches. Here are my thoughts. A steam gauge Altimeter, Airspeed Indicator & T/Coordinator are cheaper and a more independent source of backup info than standby glass unit. An autopilot is very important in an IFR RV. Both for Dynon failure and for keeping the airplane rightside up when you are looking at charts. If my Dynon ever fails, the autopilot will come on imeadiately. If I was unwilling to fly in the clouds without the autopilot engaged, then I wouldn't be flying in the clouds. I keep an old Lowrance 500 in my "little oh $hit" bag along with a vice grip, screwdriver, some Zip ties, a Mag light, some batteries, and some other goodies. (sorry no handheld VHF. I won't have a spare hand to use it anyway) A second EFIS might be a viable backup for the first, but I could fly to heck and back with a T&B Alt, Airspeed, and handheld GPS. My greatest fear in an all electric airplane is a lightning strike that fries everything that is turned on. That would be a bad day. I don't have a good answer for that. If the T&B and the Dynon both quit, I have a big problem. But I can name several other scenarios that are more likely to cause just as big a jamb. My $.02 Tailwinds, Doug Rozendaal Read this topic online here: http://forums.matronics.com/viewtopic.php?p=100030#100030 ________________________________________________________________________________
Date: Mar 11, 2007
From: "Greg Williams" <mr.gsun+rv-list(at)gmail.com>
Good two cents. I've got a Blue Mountain EFIS and a backup Dynon. No round gauges at all. Although I'm a long way from my IFR rating, I hope it will work well enough to get back home if it clouds up at the last minute. Greg On 3/11/07, B25Flyer wrote: > > > I was "just passing thru" and saw this post and could not resist a > comment. > > I am now on my second Dynon IFR airplane. (RV-4 and F-1 EVO) I have flown > over 500 hours behind Dynons with lots of actual including low approaches. > > Here are my thoughts. > A steam gauge Altimeter, Airspeed Indicator & T/Coordinator are cheaper > and a more independent source of backup info than standby glass unit. > > An autopilot is very important in an IFR RV. Both for Dynon failure and > for keeping the airplane rightside up when you are looking at charts. > > If my Dynon ever fails, the autopilot will come on imeadiately. > > If I was unwilling to fly in the clouds without the autopilot engaged, > then I wouldn't be flying in the clouds. > > I keep an old Lowrance 500 in my "little oh $hit" bag along with a vice > grip, screwdriver, some Zip ties, a Mag light, some batteries, and some > other goodies. (sorry no handheld VHF. I won't have a spare hand to use it > anyway) > > A second EFIS might be a viable backup for the first, but I could fly to > heck and back with a T&B Alt, Airspeed, and handheld GPS. > > My greatest fear in an all electric airplane is a lightning strike that > fries everything that is turned on. That would be a bad day. I don't > have a good answer for that. If the T&B and the Dynon both quit, I have a > big problem. But I can name several other scenarios that are more likely > to cause just as big a jamb. > > My $.02 > > Tailwinds, > Doug Rozendaal > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=100030#100030 > > ________________________________________________________________________________
Date: Mar 11, 2007
Tedd, You might remind us U.S. residents that we will need a passport to get back home if we are flying. Terry -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tedd McHenry Sent: Sunday, March 11, 2007 5:05 PM Subject: RV-List: Langley Fly-in June 23 The Langley, BC fly-in will be Saturday, June 23. This is the annual fly-in of the Western Canada Wing. Langley, BC, is about 20 nm north of Bellingham, WA. We generally have a good turnout of RVs from all over BC, and a good contingent from the U.S., too. Details are on our web page, http://www.vansairforce.org/CYNJ/ For U.S. visitors, the Home Wing web page has all the information you need on border crossing procedures. http://www.edt.com/homewing/international/ I hope lots of RV-Listers can make it. --- Tedd McHenry Van's Air Force Western Canada Wing tedd(at)vansairforce.org www.vansairforce.org ________________________________________________________________________________
Date: Mar 12, 2007
I agree with Doug on the autopilot. While I would not fly hard IFR without one, I do sometimes fly IFR with the autopilot on and ready to engage. As for fear of lighting, after having installed XM Weather on my GRT moving map overlays, I will no longer fly IFR without XM Weather to help keep me clear of nasty things that produce lighting and thunderstorms. Russ Daves N710RV - (RV-10) First Flight 7/28/06 N65RV - RV-6A Sold ________________________________________________________________________________
Date: Mar 12, 2007
Subject: Tank fix
At the risk of opening an old wound what, if anything ever happened to the tank pickup tube fix fuss that was hotly discussed a year or two ago? I have the wings off of my 6A for a repair to one of them (hit bush with leading edge) and recall the discussion. To gain access to tank interior I removed only the sending unit. After checking my pickup tube nuts and finding them tight after almost 500 hrs I am thinking about applying a small dab of pro seal to the joint and avoiding the really unpleasant task of removing the tank cover plates as well. I am reasonably satisfied with this as a fix. Would appreciate the thoughts of y'all out there. Those that did, and those that didn't, and reasoning. Thanks. Dick ________________________________________________________________________________
Date: Mar 12, 2007
I am in the same boat as John (my wings are off for painting), but I can't remember the purpose of the platenut. Dave Leonard On 3/11/07, Gerald Richardson wrote: > > Steve: > > > Wh en you get the page scanned, I would greatly appreciate a copy of it > also. > > Please email me at gerric(at)shaw.ca > > > Thank you for your time. > > > Gerald Richardson > > RV-6A > > > David Leonard > > Turbo Rotary RV-6 N4VY > My websites at: > http://members.aol.com/_ht_a/rotaryroster/index.html > http://members.aol.com/_ht_a/vp4skydoc/index.html > http://leonardiniraq.blogspot.com > ________________________________________________________________________________
Date: Mar 12, 2007
On 12 Mar 2007, at 09:08, David Leonard wrote: > I am in the same boat as John (my wings are off for painting), but > I can't remember the purpose of the platenut. > Pictue the angle on the nose of the inboard tank rib is bolted to the angle on the fuselage, with no slots in either angle. Now, imagine a crash scenario where the wing leading edge hits something, and this pushes the wing back. The nose of the tank rib is rigidly attached to the fuselage, so there is a risk of the rib being pulled out of the tank, releasing a large quantity of fuel, and leading to a fire. This apparently happened on more than one accident, and led to a design change. The design change puts a slot in one of those angles. If the bolt is not too tight, it will simply slide out the slot, and allow the wing to be pushed back without pulling the fuel tank apart. This should hopefully reduce the chance of a fuel tank breach, and reduce the risk of a post-crash fire, which should improve survivability. From a functionality point of view, it doesn't matter which angle has the slot. My recollection is that for retrofits to existing tanks, Van suggested to put the slot in the fuselage angle, as it can be unbolted to make the mod. For new build tanks, Van suggested to put the slot on the tank angle, as this was perceived to have some advantage. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Mar 12, 2007
I got one from a guy selling a bunch of them on ebay back around the end of November. I've emailed the seller and asked him if he has any more - will let you know You might also do a search on ebay and/or google -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of David Burton Sent: Sunday, March 11, 2007 7:12 PM Subject: RV-List: Full face mask for painting I'm looking for a source of full face masks to be used for painting using supplied fresh air. I've located a 3m mask designed for this application which costs $120.00. I've also found one that I think will work from McMaster-Carr for $75.00 and they have disposable clear lens protectors for this mask. Any other suggestions for a lower cost alternative or one better suited for this application? Anybody have experience wearing eyeglasses under one of these? Thanks, Dave -- 8:41 AM -- 8:41 AM ________________________________________________________________________________
Date: Mar 12, 2007
From: Gene Gottschalk <geneg(at)sled.gsfc.nasa.gov>
Subject: RV6A Project for Sale
I have a RV6A project for sale. The Empanage is complete. The Wings are complete except main skins on starboard wing. The bottom of the fuselage is complete and ready to fit the gear and remove from the jig. I have finishing kit and everything to finish and fly except engine, prop, and radios. I have every option you can get from Vans. I have many aftermarket goodies. I will consider selling the tools too. I'll sell the whole project for much less than of the cost of the parts alone. Contact me back channel for a complete list if you're interested. miranda(at)tartan30.org ________________________________________________________________________________
Subject: Lycoming's New Web Site
Date: Mar 12, 2007
Check out Lycoming's new web site! http://www.lycoming.com/ ERic-- RV-10, 40014 N104EP ________________________________________________________________________________
Date: Mar 12, 2007
Subject: Re: Tank fix
>At the risk of opening an old wound what, if anything ever happened to the >tank pickup tube fix fuss that was hotly discussed a year or two ago? > Would appreciate the thoughts of y'all out there. Those that did, and > those that didn't, and reasoning. I did it. Both tanks, one had the flop tube, which was the hardest to do. It took on average of 12 hours each tank. I know some reported that it is a 45 min job per tank. But it took that long for me to drain the tanks? When I figured the time, that includes getting the tools, supplies and parts necessary to actually start the operation. I took off the tanks to do it and it was still frustrating, I would not do it with the tanks still on the aircraft (but messing up the paint job was not a concern of mine). Also this is a good opportunity to induce a leak if you don't already have one, or maybe to have some loose proseal end up in the fuel filter (ask me how I know). The solution could be worse than the problem. Ten years ago when I built my tanks, both the list and Vans cautioned: follow the plans exactly as far as the fuel system is concerned. I did and then a few years later Vans state, if you followed the plans you did it wrong??!? As you can see Vans will change their advice based upon circumstances and not necessarily based upon good engineering data. I considered this fix a real waste of time, unless of course, it is your fuel pickup that falls off. This is a 15 minute fix while building the tanks and should be done at that time. This is a case much like the Lycoming oil pump. Some will argue that the AD replacement was as bad or worse than the original. But those who had a pump failure probably wished they had replaced them! I offer no advice, it is your butt in the aircraft. Do what is right for you. Bob ________________________________________________________________________________
Date: Mar 12, 2007
Basically, I had the same experience as Bob. Days to remove the tanks and to the fix the problem on an RV9. My fuel tank access covers were gasketted and Prosealed on. I carefully dried the tanks and used heat and prying to remove the covers. Vacuumed Proseal residue from tanks. Even so, I have continued to get a small amount of particulate when sampling the fuel drains, but only a very small amount on the Gascolator screen. My pickup tubes were secure, but the flares on the tubes were horribly scratched. My wings and tanks were Quickbuilds. I bought Van's pre-drilled and "screened" pickup replacement tubes. The level of scratching on the flares of the replacements was better but still unacceptable. Leland -------- Leland RV9A N137LC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=100081#100081 ________________________________________________________________________________
Subject: Tail wheel link
Date: Mar 12, 2007
Hey Guys, Are there any other tail wheel links out there to look at or is the Jantzi from Wayne Hadath the only one. Thanks, Paul ________________________________________________________________________________
Date: Mar 12, 2007
Subject: Re: Tail wheel link
Here's one: _http://www.rivethead-aero.com/default.htm_ (http://www.rivethead-aero.com/default.htm) John D'Onofrio (_Tailgummer(at)aol.com_ (mailto:Tailgummer(at)aol.com) )
Subject: Cessna Lycoming Alternator
Date: Mar 12, 2007
While helping some folks who were stranded with a dead alternator on a Saturday (when FAA certified folks didn't want to come out and help): A helpful Orielly automotive parts guy helped us ID an alternator that would replace the large 60 amp Cessna alternator. It is very similar to an alternator that fits a 1971 Ford Pickup with 302 V-8 engine. External regulator (try VR-600 or there is a new VR-301 low profile, solid state regulator which will also work). The Orielly part number for the alternator is 01-0147 - except this has a double pulley. The parts guy quickly changed out the pulley and it works. Looking at the NAPA listings, this alternator is used on a bunch of Fords. They had a single groove pulley, 60 amp alternator listed RAY2133014 which also should work. Ronnie Brown ________________________________________________________________________________
Subject: RV-4 First flight
Date: Mar 12, 2007
After 12 years of on and off construction, RV-4 N455J is officially a flyable airplane. After receiving the airworthiness certificate this morning, I performed a full power ground run on the engine just to make sure it would develop adequate power and to see that there were no issues with the fuel delivery system. A quick adjustment of the low speed idle and another 15 gallons of 100LL (for a total of 20 gallons, 10 in each side) I was ready to go. At 1715 this afternoon I pulled onto runway 18 at 17J (Donalsonville, GA) and applied full power. The take-off roll was brisk but the airplane tracked straight. It broke ground after a short ground run and climbed away at 1500 FPM. At 2000 feet I orbited the airport feeling out the controls and watching the oil pressure. The left wing is slightly heavy and I hope to correct that with a squeeze of the left aileron. Also, right rudder was required to keep the ball centered. I may try to correct the rudder first before squeezing the aileron, just to see how it affects the heavy wing. Stalls were non events at less than 50 knots indicated. Oil pressure was to high and I had to throttle back to keep it in limits. The oil pressure relief is adjustable so that should be a simple fix. The most annoying thing was a canopy buzz on the trailing end at high speed. How do you stop that? I would like to report that the first landing was a greaser but that would not be so. After the third bounce I remembered to plant the main gear on by raising the tail. Life was good after that. The 4 sure handles better than my Cessna C140A on the ground and in the air. I think I can get use to this airplane. Thanks to Pierre Smith, Louisville, GA., for my transition training. I was as prepared for this flight as any I have ever made. Jerry Isler Donalsonville, GA RV-4 N455J - Flying ________________________________________________________________________________
Date: Mar 12, 2007
Thanks Kevin, I understand the purpose of the slot, though to be honest I am still hesitant to cut the slot. What if it changes the flutter characteristics or allows some movement that wears over time etc... (I know, lots of planes flying with that mod but it is a tough one to accept). Anyway, my question is about the *platenut*. Even though Steve sent me the copy of the plans from the original RVator, I still don't understand the placement and/or purpose of the platenut. Is it a large platenut installed on the washer? (the plans say "miniature platenut"). If so, why not use a regular nut? Something about not letting the bolt get crooked when release is needed? Dave Leonard On 3/12/07, Kevin Horton wrote: > > > On 12 Mar 2007, at 09:08, David Leonard wrote: > > > I am in the same boat as John (my wings are off for painting), but > > I can't remember the purpose of the platenut. > > > > Pictue the angle on the nose of the inboard tank rib is bolted to the > angle on the fuselage, with no slots in either angle. Now, imagine a > crash scenario where the wing leading edge hits something, and this > pushes the wing back. The nose of the tank rib is rigidly attached > to the fuselage, so there is a risk of the rib being pulled out of > the tank, releasing a large quantity of fuel, and leading to a fire. > This apparently happened on more than one accident, and led to a > design change. > > The design change puts a slot in one of those angles. If the bolt is > not too tight, it will simply slide out the slot, and allow the wing > to be pushed back without pulling the fuel tank apart. This should > hopefully reduce the chance of a fuel tank breach, and reduce the > risk of a post-crash fire, which should improve survivability. > > From a functionality point of view, it doesn't matter which angle > has the slot. My recollection is that for retrofits to existing > tanks, Van suggested to put the slot in the fuselage angle, as it can > be unbolted to make the mod. For new build tanks, Van suggested to > put the slot on the tank angle, as this was perceived to have some > advantage. > > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > -- David Leonard Turbo Rotary RV-6 N4VY My websites at: http://members.aol.com/_ht_a/rotaryroster/index.html http://members.aol.com/_ht_a/vp4skydoc/index.html http://leonardiniraq.blogspot.com ________________________________________________________________________________
Date: Mar 12, 2007
Subject: Re: RV-4 First flight
Congrats on your milestone. According to an article in the latest issue of General Aviation News, the 5000th flying RV launched on Feb 14th in San Antonio. Another first flight was recorded that day as well. So, you must be number 5020 or something. Congrats again. Henry H. part time flyer of N72224 RV-6 KAWO Jerry Isler wrote: > After 12 years of on and off construction, RV-4 N455J is officially a > flyable airplane. After receiving the airworthiness certificate this > morning, I performed a full power ground run on the engine just to > make sure it would develop adequate power and to see that there were > no issues with the fuel delivery system. A quick adjustment of the low > speed idle and another 15 gallons of 100LL (for a total of 20 gallons, > 10 in each side) I was ready to go. At 1715 this afternoon I pulled > onto runway 18 at 17J (Donalsonville, GA) and applied full power. The > take-off roll was brisk but the airplane tracked straight. It broke > ground after a short ground run and climbed away at 1500 FPM. At 2000 > feet I orbited the airport feeling out the controls and watching the > oil pressure. The left wing is slightly heavy and I hope to correct > that with a squeeze of the left aileron. Also, right rudder was > required to keep the ball centered. I may try to correct the rudder > first before squeezing the aileron, just to see how it affects the > heavy wing. Stalls were non events at less than 50 knots indicated. > Oil pressure was to high and I had to throttle back to keep it in > limits. The oil pressure relief is adjustable so that should be a > simple fix. The most annoying thing was a canopy buzz on the trailing > end at high speed. How do you stop that? > > I would like to report that the first landing was a greaser but that > would not be so. After the third bounce I remembered to plant the main > gear on by raising the tail. Life was good after that. The 4 sure > handles better than my Cessna C140A on the ground and in the air. I > think I can get use to this airplane. > > Thanks to Pierre Smith, Louisville, GA., for my transition training. I > was as prepared for this flight as any I have ever made. > > Jerry Isler > Donalsonville, GA > RV-4 N455J - Flying > * > > > * ________________________________________________________________________________
Date: Mar 12, 2007
You don't see as many -4's leaving the ground for the first time anymore. Congrats on your new bird! May she serve you faithfully and deliver you safely to any destination you choose. Bill -4 wings Sucker-punch spam with award-winning protection. Try the free Yahoo! Mail Beta. ________________________________________________________________________________
Date: Mar 12, 2007
Jerry,=0A=0A Congratulations on your successful flight. Regarding your canopy buzz, I had the same problem. I solved it by installing rubber edgi ng along the rear of the canopy skirt. I used a more rounded shape that I found in the McMasterCarr catalog. This not only stopped the buzzing, but also made the cockpit less drafty and gave the canopy a more solid feel whe n closed.=0A=0ATed=0A=0A=0A=0A----- Original Message ----=0AFrom: Jerry Isl er =0ATo: rv-list(at)matronics.com=0ASent: Monday, March 1 2, 2007 8:12:48 PM=0ASubject: RV-List: RV-4 First flight=0A=0A=0AAfter 12 y ears of on and off construction, RV-4 N455J is officially a flyable airplan e. After receiving the airworthiness certificate this morning, I performed a full power ground run on the engine just to make sure it would develop ad equate power and to see that there were no issues with the fuel delivery sy stem. A quick adjustment of the low speed idle and another 15 gallons of 10 0LL (for a total of 20 gallons, 10 in each side) I was ready to go. At 1715 this afternoon I pulled onto runway 18 at 17J (Donalsonville, GA) and appl ied full power. The take-off roll was brisk but the airplane tracked straig ht. It broke ground after a short ground run and climbed away at 1500 FPM. At 2000 feet I orbited the airport feeling out the controls and watching th e oil pressure. The left wing is slightly heavy and I hope to correct that with a squeeze of the left aileron. Also, right rudder was required to keep the ball centered. I may try to correct the rudder first before squeezing the aileron, just to see how it affects the heavy wing. Stalls were non events at less than 50 knots indicated. Oil pressure was to high and I had to thr ottle back to keep it in limits. The oil pressure relief is adjustable so t hat should be a simple fix. The most annoying thing was a canopy buzz on th e trailing end at high speed. How do you stop that? =0A=0AI would like to r eport that the first landing was a greaser but that would not be so. After the third bounce I remembered to plant the main gear on by raising the tail . Life was good after that. The 4 sure handles better than my Cessna C140A on the ground and in the air. I think I can get use to this airplane.=0A=0A Thanks to Pierre Smith, Louisville, GA., for my transition training. I was as prepared for this flight as any I have ever made.=0A=0AJerry Isler=0ADon ============ ________________________________________________________________________________
Date: Mar 13, 2007
Congrats Jerry. 12 years is not bad for an old style kit. I have only build the tail of mine since '99, but have completed a -7 and finishing a -10 at present. Soon I'll purchase the rest of -4 and get started again. I'm sure it'll be a shock to the system after the pre-punch stuff! Happy Landings! ________________________________________________________________________________
Date: Mar 13, 2007
Ah, now I understand. Yeah, it could be to keep the bolt square to the angle if release is ever needed. If you just had a bolt, nut and two washers, I can imagine that the bolt could tip sideways a bit and bind, which would defeat the purpose of the mod. The purpose of these pieces of angle appear to be to support the weight of the front of the fuel, especially when pulling some g. Adding the slot does not compromise that function. I see no way this would affect flutter, nor would I expect much movement, and thus there should be very little, if any wear. I don't see a downside, other than the time required to do the mod. Kevin On 12 Mar 2007, at 23:34, David Leonard wrote: > Thanks Kevin, > I understand the purpose of the slot, though to be honest I am > still hesitant to cut the slot. What if it changes the flutter > characteristics or allows some movement that wears over time > etc... (I know, lots of planes flying with that mod but it is a > tough one to accept). > > Anyway, my question is about the platenut. Even though Steve sent > me the copy of the plans from the original RVator, I still don't > understand the placement and/or purpose of the platenut. Is it a > large platenut installed on the washer? (the plans say "miniature > platenut"). If so, why not use a regular nut? Something about not > letting the bolt get crooked when release is needed? > > Dave Leonard > > > On 3/12/07, Kevin Horton wrote: --> RV-List > message posted by: Kevin Horton > > On 12 Mar 2007, at 09:08, David Leonard wrote: > > > I am in the same boat as John (my wings are off for painting), but > > I can't remember the purpose of the platenut. > > > > Pictue the angle on the nose of the inboard tank rib is bolted to the > angle on the fuselage, with no slots in either angle. Now, imagine a > crash scenario where the wing leading edge hits something, and this > pushes the wing back. The nose of the tank rib is rigidly attached > to the fuselage, so there is a risk of the rib being pulled out of > the tank, releasing a large quantity of fuel, and leading to a fire. > This apparently happened on more than one accident, and led to a > design change. > > The design change puts a slot in one of those angles. If the bolt is > not too tight, it will simply slide out the slot, and allow the wing > to be pushed back without pulling the fuel tank apart. This should > hopefully reduce the chance of a fuel tank breach, and reduce the > risk of a post-crash fire, which should improve survivability. > > From a functionality point of view, it doesn't matter which angle > has the slot. My recollection is that for retrofits to existing > tanks, Van suggested to put the slot in the fuselage angle, as it can > be unbolted to make the mod. For new build tanks, Van suggested to > put the slot on the tank angle, as this was perceived to have some > advantage. > > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada ________________________________________________________________________________
Date: Mar 13, 2007
On 12 Mar 2007, at 23:12, Jerry Isler wrote: > After 12 years of on and off construction, RV-4 N455J is officially > a flyable airplane. After receiving the airworthiness certificate > this morning, I performed a full power ground run on the engine > just to make sure it would develop adequate power and to see that > there were no issues with the fuel delivery system. A quick > adjustment of the low speed idle and another 15 gallons of 100LL > (for a total of 20 gallons, 10 in each side) I was ready to go. At > 1715 this afternoon I pulled onto runway 18 at 17J (Donalsonville, > GA) and applied full power. The take-off roll was brisk but the > airplane tracked straight. It broke ground after a short ground run > and climbed away at 1500 FPM. At 2000 feet I orbited the airport > feeling out the controls and watching the oil pressure. The left > wing is slightly heavy and I hope to correct that with a squeeze of > the left aileron. Also, right rudder was required to keep the ball > centered. I may try to correct the rudder first before squeezing > the aileron, just to see how it affects the heavy wing. Yes, correct the rudder first. Then have a read of the info that Van has published on heavy wings: http://www.vansaircraft.com/pdf/Wing_Heavy.pdf Then, if all else fails, squeeze the aileron of the light wing - i.e. the right wing. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Mar 13, 2007
Leland and Bob, thanks for the input. I prosealed the flairnuts to the clip angles yesterday. I am satisfied with the fix. Dick At 01:38 PM 3/12/2007, you wrote: > >Basically, I had the same experience as Bob. Days to remove the >tanks and to the fix the problem on an RV9. My fuel tank access >covers were gasketted and Prosealed on. I carefully dried the tanks >and used heat and prying to remove the covers. Vacuumed Proseal >residue from tanks. Even so, I have continued to get a small amount >of particulate when sampling the fuel drains, but only a very small >amount on the Gascolator screen. My pickup tubes were secure, but >the flares on the tubes were horribly scratched. My wings and tanks >were Quickbuilds. I bought Van's pre-drilled and "screened" pickup >replacement tubes. The level of scratching on the flares of the >replacements was better but still unacceptable. >Leland > >-------- >Leland >RV9A >N137LC > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=100081#100081 > > ________________________________________________________________________________
Date: Mar 13, 2007
Congratulations, Jerry. Enjoy your new pride and joy!!!!! Richard Dudley RV-6A flying Jerry Isler wrote: > After 12 years of on and off construction, RV-4 N455J is officially a > flyable airplane. After receiving the airworthiness certificate this > morning, I performed a full power ground run on the engine just to > make sure it would develop adequate power and to see that there were > no issues with the fuel delivery system. A quick adjustment of the low > speed idle and another 15 gallons of 100LL (for a total of 20 gallons, > 10 in each side) I was ready to go. At 1715 this afternoon I pulled > onto runway 18 at 17J (Donalsonville, GA) and applied full power. The > take-off roll was brisk but the airplane tracked straight. It broke > ground after a short ground run and climbed away at 1500 FPM. At 2000 > feet I orbited the airport feeling out the controls and watching the > oil pressure. The left wing is slightly heavy and I hope to correct > that with a squeeze of the left aileron. Also, right rudder was > required to keep the ball centered. I may try to correct the rudder > first before squeezing the aileron, just to see how it affects the > heavy wing. Stalls were non events at less than 50 knots indicated. > Oil pressure was to high and I had to throttle back to keep it in > limits. The oil pressure relief is adjustable so that should be a > simple fix. The most annoying thing was a canopy buzz on the trailing > end at high speed. How do you stop that? > > I would like to report that the first landing was a greaser but that > would not be so. After the third bounce I remembered to plant the main > gear on by raising the tail. Life was good after that. The 4 sure > handles better than my Cessna C140A on the ground and in the air. I > think I can get use to this airplane. > > Thanks to Pierre Smith, Louisville, GA., for my transition training. I > was as prepared for this flight as any I have ever made. > > Jerry Isler > Donalsonville, GA > RV-4 N455J - Flying > > ________________________________________________________________________________
Date: Mar 13, 2007
VACUUMED? That thought crossed my mind, but then I thought of my shop vac loading up with gasoline vapors. There are sparks in that motor, and some air (fuel vapor!) is drawn up to cool it, at least that's how mine works. Dan Hopper RV-7A In a message dated 3/12/2007 12:45:51 PM Eastern Standard Time, federigo(at)pacbell.net writes: Basically, I had the same experience as Bob. Days to remove the tanks and to the fix the problem on an RV9. My fuel tank access covers were gasketted and Prosealed on. I carefully dried the tanks and used heat and prying to remove the covers. Vacuumed Proseal residue from tanks. Even so, I have continued to get a small amount of particulate when sampling the fuel drains, but only a very small amount on the Gascolator screen. My pickup tubes were secure, but the flares on the tubes were horribly scratched. My wings and tanks were Quickbuilds. I bought Van's pre-drilled and "screened" pickup replacement tubes. The level of scratching on the flares of the replacements was better but still unacceptable. Leland -------- Leland RV9A N137LC
From: "Jim Pleasants" <jpleasants(at)bellsouth.net>
Date: Mar 13, 2007
Dan, that's what makes homebuilding so exciting! Jim Pleasants Do not archieve ----- Original Message ----- From: <Hopperdhh(at)aol.com> Sent: Tuesday, March 13, 2007 9:59 AM Subject: Re: RV-List: Re: Tank fix > > > VACUUMED? That thought crossed my mind, but then I thought of my shop vac > loading up with gasoline vapors. There are sparks in that motor, and some air > (fuel vapor!) is drawn up to cool it, at least that's how mine works. > > Dan Hopper > RV-7A ________________________________________________________________________________
Date: Mar 13, 2007
Didn't I see that on Mythbusters.....? -----Original Message----- >From: Jim Pleasants <jpleasants(at)bellsouth.net> >Sent: Mar 13, 2007 10:23 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Re: Tank fix > > >Dan, that's what makes homebuilding so exciting! > >Jim Pleasants > >Do not archieve > > >----- Original Message ----- >From: <Hopperdhh(at)aol.com> >To: >Sent: Tuesday, March 13, 2007 9:59 AM >Subject: Re: RV-List: Re: Tank fix > > >> >> >> VACUUMED? That thought crossed my mind, but then I thought of my shop vac >> loading up with gasoline vapors. There are sparks in that motor, and some >air >> (fuel vapor!) is drawn up to cool it, at least that's how mine works. >> >> Dan Hopper >> RV-7A > > ________________________________________________________________________________
Subject: Re:insurance
Date: Mar 13, 2007
I just got a quote for my "other" airplane from Travers & Assoc. The quote was for considerably less than my current policy. Has anyone had experience with this company? Do they also offer coverage for Experimentals? dave@RAL 7A -- the panel now lights up and the coms. work >> > > ________________________________________________________________________________
Date: Mar 13, 2007
Dave- Travers & Associates is a Broker not an insurance carrier. Typically all brokers, get the same quotes form the underwriters if the same information is given to them. The "broker" does not set the price the underwriter does. To answer "Do they offer coverage for experimental?" Yes they can get quotes on your RV, but they are the same quotes as your current agent can get. Hope this helps clear some things up. Regards, David McCoy Branch Manager NationAir Aviation Insurance -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Cudney Sent: Tuesday, March 13, 2007 12:48 PM Subject: RV-List: Re:insurance I just got a quote for my "other" airplane from Travers & Assoc. The quote was for considerably less than my current policy. Has anyone had experience with this company? Do they also offer coverage for Experimentals? dave@RAL 7A -- the panel now lights up and the coms. work >> > > ________________________________________________________________________________
Date: Mar 13, 2007
yes. They're quotes were cheaper by far than the others I called and my renewel cost went down by a couple of hundred bucks this year on an experimental taildragger RV8. Definately give them a shot. -------------- Original message -------------- From: Dave Cudney <yenduc(at)sbcglobal.net> > > > I just got a quote for my "other" airplane from Travers & Assoc. The > quote was for considerably less than my current policy. Has anyone > had experience with this company? Do they also offer coverage for > Experimentals? > > dave@RAL > 7A -- the panel now lights up and the coms. work > >> > > > > > > > > > > > > > > > > >
ge,
Date: Mar 13, 2007
I just got a quote for my Navion that is $300 less than last year. My agent said a number of new underwriters have entered the field and all of them are getting competitive again. My quote was from a new one. The Navion is/was a hard aircraft to insure so maybe the competition will also carry over to experimentals. Regards, Greg Young - Houston (DWH) RV-6 N6GY ...project Phoenix Navion N5221K - just an XXL RV-6A > > > > I just got a quote for my "other" airplane from Travers & Assoc. The > quote was for considerably less than my current policy. Has anyone > had experience with this company? Do they also offer coverage for > Experimentals? > > dave@RAL > 7A -- the panel now lights up and the coms. work ________________________________________________________________________________
From: "Brian Meyette" <brianpublic2(at)starband.net>
Subject: URL for this list?
Date: Mar 14, 2007
I think I read somewhere that this list is also available in an online format, similar to Yahoo Groups (as opposed to getting it in my email). But I don't see any link to it on the matronics site. Is there a URL for the online discussion group? Thanks, brian -- 4:51 PM ________________________________________________________________________________
Date: Mar 14, 2007
Subject: Re: URL for this list?
Brian Meyette wrote: > > I think I read somewhere that this list is also available in an online > format, similar to Yahoo Groups (as opposed to getting it in my email). > But I don't see any link to it on the matronics site. Is there a URL for > the online discussion group? > Thanks, > brian Check the links at the bottom of this and all list messages. Sam Buchanan ==================== ________________________________________________________________________________
Date: Mar 14, 2007
http://forums.matronics.com/ http://www.matronics.com/Navigator?RV-List Tim Bolton Charlotte, NC www.TheRV7.com ----- Original Message ----- From: "Brian Meyette" <brianpublic2(at)starband.net> Sent: Wednesday, March 14, 2007 9:42 AM Subject: RV-List: URL for this list? I think I read somewhere that this list is also available in an online format, similar to Yahoo Groups (as opposed to getting it in my email). But I don't see any link to it on the matronics site. Is there a URL for the online discussion group? Thanks, brian -- 4:51 PM ________________________________________________________________________________
Subject: RV8 Rudder Cable
Date: Mar 14, 2007
Looking for 1 unused rudder cable(F-852A) for a RV8. Cable dimensions 161.375". Van's sells them in sets only. Will pay half of the going rate or whatever you feel its worth. New set from Van's is $77.45. I botched one up when it fell into my rotary file while opening a hole. Thanks, Bruce G. RV8 Fuse _________________________________________________________________ Mortgage rates as low as 4.625% - Refinance $150,000 loan for $579 a month. Intro*Terms https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f6&disc=y&vers=743&s=4056&p=5117 ________________________________________________________________________________
Subject: Painting Questions and Advice
Date: Mar 14, 2007
From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com>
First, a confession and apology; I haven't read any of the books or watched any of the videos on painting, so my questions and observations may be obvious to those that have. I'm using PPG's Concept and a Devilbiss FinishLine HVLP conversion gun. >From the start orange peel has been a problem. I kept increasing the pressure, increasing paint volume, and slowing my sweeping motion. Although orange peel was decreasing, I was using an enormous amount of paint. When I got to the wings, I decided to switch back to a conventional gun, NAPA's gravity feed. Results were much better. After talking with a painter friend, I have a couple suspicions; 1) The fast (low temperature) reducer is too fast 2) The amount of reducer is too little 3) The air pressure at the cap is too low I've been following PPG's recommended temperature range and recipe', but the friend suggested using a slower (medium temperature) reducer and doubling the amount of reducer. He also suggested increasing the pressure, but I've already maxed out the pressure both at the compressor and at the gun's regulator. Question #1: For anyone that's used Concept paint, what is your opinion about using more reducer and a slower reducer? Question #2: Do you spray rivet lines first to help fill around the rivet head? Now to share some of my experiences: Two 20" box fans force air into the booth, with "sticky" filters on the inlet side of the fans. These filters are available individually at paint stores. I started with pleated air filters at the booth exit, but they have too much resistance to airflow. I'm switching to the fiber type. The personnel entrance should be close to the inlet fans so that it's not a primary means of escape for paint fog. After a couple paint sessions, paint dust collects on the paint booth walls and floor. Lightly rinse the walls with a water hose and lay new paper drop cloth on the floor. The water will also raise the humidity and cause the paint to cure a little more slowly, which aids in it "flowing out". Wear a Tyvek paint suit with hood to minimize lint/dust contamination from your clothes. Handling all the solvents will dry out your hands very quickly (I know, I should be using gloves, but it hassssssssssnnnnnnnn'ttttttt affected me yet, hasn't affected me yet, hasn't affected me yet), and you'll be using hand lotion. That hand lotion has a sneaky way of finding its way onto parts to be painted. I suggest washing your hands with soap before working with parts to be painted. A friend also found that RTV is persistent. Alumiprep has a tendency to collect on the bottom of treated parts and drying there. You have to rinse the bottom of parts frequently until they're ready to dry. Even after Alumiprep, parts should be cleaned with a cleaning wipe, dried with a clean cloth, and wiped with a tack cloth. HVLP may be better suited to professionals. Most big parts can be suspended from wires or sawhorses in a manner that allows you to paint with each side in a horizontal position. This reduces the chances of runs and sags. For example, I placed 3' sections of 4" PVC pipe through each end of the wings and rested the pipes on sawhorses. This allows the wings to rotate around pipes. Another piece of 2" PVC placed in one end helps secure the wing in a horizontal position. Paint one side, flip the wing over, paint the other side. I've ready the recommendation to practice painting on paper. I don't know if this would work, but the slippery side of "coated" making paper might make a better test piece since it won't absorb the paint. The first "tack" coat of paint should be shot from about 12", and applied quickly to provide about 50% coverage. Wait 10 minutes, shoot the rivet lines and edges lightly, then shoot the final coat at 6"-8" and a little more slowly and more heavily. Make sure to overlap up to 50%. Pinholes - I know a lot has been written already, but I thought I could be successful with less work. WRONG! Sand the parts until there are no shiny spots left. Using a Bondo-type squeegee, work SuperFil back and forth quickly, like using a paint brush, then scrape the squeegee backwards to remove excess. The pinholes will have blue SuperFil in them and will be easy to see. Let cure overnight, then lightly sand entire piece, making sure not to remove the blue SuperFil from the pinholes. Prime several filled parts with the same primer you're using for your painting. After the primer cures, look closely for pinholes. If any pinholes remain, fill with "glazing/spot putty" available from auto parts stores. This putty is like a thinned Bondo and works into the pinholes with the same squeegee. In 15 minutes it's ready to sand, clean, and reprime. This method sounds like a lot of work, but it's effective and doesn't take a lot of elbow grease. Striping - Chances are that your paint will go on a little thicker than the manufacturer recommends. Wait a little longer to use fine line tape for stripes, or you may get tape tracks that have to be buffed out. Ask the paint store for paint spec sheets, or locate and print them off the internet, for the specific primer and paint that you'll be using. Depending on the answers to my questions above, you may want to increase the amount of reducer, and go with a reducer that is for a temperature range higher than what you'll be working in. Three good reasons to go with white; Red paint can cost twice as much as white paint, dark colors show mistakes more easily, and dark colors absorb a lot of energy from the sun. My investment: Paint booth - $250 (plastic, drop cloths, sawhorses, fans, filters, door, and duct tape) Supplies - $100 (masking tape, coated masking paper, fine line tape, coveralls, wipes, tack cloths, etc.) Paint - $1400 (1 gallon corrosion resistant primer, 2-3 gallons paint, reducer, hardener, cleaner) I'll be happy to provide more detailed information if anyone has questions. Again, this may all be covered in the books that I haven't read, and if so, I apologize. Questions can be posted on this site or to my direct email address. Happy painting! Daniel Snow RV-9A, Painting ________________________________________________________________________________
Date: Mar 14, 2007
Subject: RV tools For Sale
Due to two new mouths to feed, I am going to have to put my RV build on hold. I have for sale a RV tool kit from Avery's, with numerous upgrades, plus some shop tools. Please email for details. wlpmap(at)insightbb.com Thank you. Mark ________________________________________________________________________________
Subject: Re: Painting Questions and Advice
Date: Mar 14, 2007
I went to the PPG paint school a few years ago,and that paint and gun has flow rates and pressures for that exact paint and gun..Meaning that if you look at Devilbiss web site it will give you what tip and pressure AT THE GUN to use..Also your PPG dealer may have a tip pressure gauge to use for that gun that will nail the perfect pressure that you will need to do a great job..Just remember to use a large enough hose 3/8 because smaller will get you in trouble,don't ask me how because it hurts!!Always use the correct temp range reducer AT THAT TIME..Practice on something first like a old car hood etc first.... Good luck John McMahon (RV6 C/S ) ----- Original Message ----- From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com> Sent: Wednesday, March 14, 2007 11:33 AM Subject: RV-List: Painting Questions and Advice > > First, a confession and apology; I haven't read any of the books or > watched any of the videos on painting, so my questions and observations > may be obvious to those that have. > > I'm using PPG's Concept and a Devilbiss FinishLine HVLP conversion gun. >>From the start orange peel has been a problem. I kept increasing the > pressure, increasing paint volume, and slowing my sweeping motion. > Although orange peel was decreasing, I was using an enormous amount of > paint. When I got to the wings, I decided to switch back to a > conventional gun, NAPA's gravity feed. Results were much better. After > talking with a painter friend, I have a couple suspicions; > 1) The fast (low temperature) reducer is too fast > 2) The amount of reducer is too little > 3) The air pressure at the cap is too low > I've been following PPG's recommended temperature range and recipe', but > the friend suggested using a slower (medium temperature) reducer and > doubling the amount of reducer. He also suggested increasing the > pressure, but I've already maxed out the pressure both at the compressor > and at the gun's regulator. > > Question #1: For anyone that's used Concept paint, what is your opinion > about using more reducer and a slower reducer? > > Question #2: Do you spray rivet lines first to help fill around the > rivet head? > > > Now to share some of my experiences: > > Two 20" box fans force air into the booth, with "sticky" filters on the > inlet side of the fans. These filters are available individually at > paint stores. > > I started with pleated air filters at the booth exit, but they have too > much resistance to airflow. I'm switching to the fiber type. > > The personnel entrance should be close to the inlet fans so that it's > not a primary means of escape for paint fog. > > After a couple paint sessions, paint dust collects on the paint booth > walls and floor. Lightly rinse the walls with a water hose and lay new > paper drop cloth on the floor. The water will also raise the humidity > and cause the paint to cure a little more slowly, which aids in it > "flowing out". > > Wear a Tyvek paint suit with hood to minimize lint/dust contamination > from your clothes. > > Handling all the solvents will dry out your hands very quickly (I know, > I should be using gloves, but it hassssssssssnnnnnnnn'ttttttt affected > me yet, hasn't affected me yet, hasn't affected me yet), and you'll be > using hand lotion. That hand lotion has a sneaky way of finding its way > onto parts to be painted. I suggest washing your hands with soap before > working with parts to be painted. A friend also found that RTV is > persistent. > > Alumiprep has a tendency to collect on the bottom of treated parts and > drying there. You have to rinse the bottom of parts frequently until > they're ready to dry. > > Even after Alumiprep, parts should be cleaned with a cleaning wipe, > dried with a clean cloth, and wiped with a tack cloth. > > HVLP may be better suited to professionals. > > Most big parts can be suspended from wires or sawhorses in a manner that > allows you to paint with each side in a horizontal position. This > reduces the chances of runs and sags. For example, I placed 3' sections > of 4" PVC pipe through each end of the wings and rested the pipes on > sawhorses. This allows the wings to rotate around pipes. Another piece > of 2" PVC placed in one end helps secure the wing in a horizontal > position. Paint one side, flip the wing over, paint the other side. > > I've ready the recommendation to practice painting on paper. I don't > know if this would work, but the slippery side of "coated" making paper > might make a better test piece since it won't absorb the paint. > > The first "tack" coat of paint should be shot from about 12", and > applied quickly to provide about 50% coverage. Wait 10 minutes, shoot > the rivet lines and edges lightly, then shoot the final coat at 6"-8" > and a little more slowly and more heavily. Make sure to overlap up to > 50%. > > Pinholes - I know a lot has been written already, but I thought I could > be successful with less work. WRONG! Sand the parts until there are no > shiny spots left. Using a Bondo-type squeegee, work SuperFil back and > forth quickly, like using a paint brush, then scrape the squeegee > backwards to remove excess. The pinholes will have blue SuperFil in > them and will be easy to see. Let cure overnight, then lightly sand > entire piece, making sure not to remove the blue SuperFil from the > pinholes. Prime several filled parts with the same primer you're using > for your painting. After the primer cures, look closely for pinholes. > If any pinholes remain, fill with "glazing/spot putty" available from > auto parts stores. This putty is like a thinned Bondo and works into > the pinholes with the same squeegee. In 15 minutes it's ready to sand, > clean, and reprime. This method sounds like a lot of work, but it's > effective and doesn't take a lot of elbow grease. > > Striping - Chances are that your paint will go on a little thicker than > the manufacturer recommends. Wait a little longer to use fine line tape > for stripes, or you may get tape tracks that have to be buffed out. > > Ask the paint store for paint spec sheets, or locate and print them off > the internet, for the specific primer and paint that you'll be using. > Depending on the answers to my questions above, you may want to increase > the amount of reducer, and go with a reducer that is for a temperature > range higher than what you'll be working in. > > Three good reasons to go with white; Red paint can cost twice as much as > white paint, dark colors show mistakes more easily, and dark colors > absorb a lot of energy from the sun. > > > My investment: > Paint booth - $250 (plastic, drop cloths, sawhorses, fans, filters, > door, and duct tape) > Supplies - $100 (masking tape, coated masking paper, fine line tape, > coveralls, wipes, tack cloths, etc.) > Paint - $1400 (1 gallon corrosion resistant primer, 2-3 gallons paint, > reducer, hardener, cleaner) > > > I'll be happy to provide more detailed information if anyone has > questions. Again, this may all be covered in the books that I haven't > read, and if so, I apologize. Questions can be posted on this site or > to my direct email address. > > Happy painting! > > Daniel Snow > RV-9A, Painting > > > ________________________________________________________________________________
Date: Mar 14, 2007
Snow, Daniel A. wrote: > > First, a confession and apology; I haven't read any of the books or > watched any of the videos on painting, so my questions and observations > may be obvious to those that have. > > I'm using PPG's Concept and a Devilbiss FinishLine HVLP conversion gun. > >From the start orange peel has been a problem. I kept increasing the > pressure, increasing paint volume, and slowing my sweeping motion. > Although orange peel was decreasing, I was using an enormous amount of > paint. When I got to the wings, I decided to switch back to a > conventional gun, NAPA's gravity feed. Results were much better. After > talking with a painter friend, I have a couple suspicions; > 1) The fast (low temperature) reducer is too fast > 2) The amount of reducer is too little > 3) The air pressure at the cap is too low > I've been following PPG's recommended temperature range and recipe', but > the friend suggested using a slower (medium temperature) reducer and > doubling the amount of reducer. He also suggested increasing the > pressure, but I've already maxed out the pressure both at the compressor > and at the gun's regulator. > > Question #1: For anyone that's used Concept paint, what is your opinion > about using more reducer and a slower reducer? > > Question #2: Do you spray rivet lines first to help fill around the > rivet head? > > > Now to share some of my experiences: > > Two 20" box fans force air into the booth, with "sticky" filters on the > inlet side of the fans. These filters are available individually at > paint stores. > > I started with pleated air filters at the booth exit, but they have too > much resistance to airflow. I'm switching to the fiber type. > > The personnel entrance should be close to the inlet fans so that it's > not a primary means of escape for paint fog. > > After a couple paint sessions, paint dust collects on the paint booth > walls and floor. Lightly rinse the walls with a water hose and lay new > paper drop cloth on the floor. The water will also raise the humidity > and cause the paint to cure a little more slowly, which aids in it > "flowing out". > > Wear a Tyvek paint suit with hood to minimize lint/dust contamination > from your clothes. > > Handling all the solvents will dry out your hands very quickly (I know, > I should be using gloves, but it hassssssssssnnnnnnnn'ttttttt affected > me yet, hasn't affected me yet, hasn't affected me yet), and you'll be > using hand lotion. That hand lotion has a sneaky way of finding its way > onto parts to be painted. I suggest washing your hands with soap before > working with parts to be painted. A friend also found that RTV is > persistent. > > Alumiprep has a tendency to collect on the bottom of treated parts and > drying there. You have to rinse the bottom of parts frequently until > they're ready to dry. > > Even after Alumiprep, parts should be cleaned with a cleaning wipe, > dried with a clean cloth, and wiped with a tack cloth. > > HVLP may be better suited to professionals. > > Most big parts can be suspended from wires or sawhorses in a manner that > allows you to paint with each side in a horizontal position. This > reduces the chances of runs and sags. For example, I placed 3' sections > of 4" PVC pipe through each end of the wings and rested the pipes on > sawhorses. This allows the wings to rotate around pipes. Another piece > of 2" PVC placed in one end helps secure the wing in a horizontal > position. Paint one side, flip the wing over, paint the other side. > > I've ready the recommendation to practice painting on paper. I don't > know if this would work, but the slippery side of "coated" making paper > might make a better test piece since it won't absorb the paint. > > The first "tack" coat of paint should be shot from about 12", and > applied quickly to provide about 50% coverage. Wait 10 minutes, shoot > the rivet lines and edges lightly, then shoot the final coat at 6"-8" > and a little more slowly and more heavily. Make sure to overlap up to > 50%. > > Pinholes - I know a lot has been written already, but I thought I could > be successful with less work. WRONG! Sand the parts until there are no > shiny spots left. Using a Bondo-type squeegee, work SuperFil back and > forth quickly, like using a paint brush, then scrape the squeegee > backwards to remove excess. The pinholes will have blue SuperFil in > them and will be easy to see. Let cure overnight, then lightly sand > entire piece, making sure not to remove the blue SuperFil from the > pinholes. Prime several filled parts with the same primer you're using > for your painting. After the primer cures, look closely for pinholes. > If any pinholes remain, fill with "glazing/spot putty" available from > auto parts stores. This putty is like a thinned Bondo and works into > the pinholes with the same squeegee. In 15 minutes it's ready to sand, > clean, and reprime. This method sounds like a lot of work, but it's > effective and doesn't take a lot of elbow grease. > > Striping - Chances are that your paint will go on a little thicker than > the manufacturer recommends. Wait a little longer to use fine line tape > for stripes, or you may get tape tracks that have to be buffed out. > > Ask the paint store for paint spec sheets, or locate and print them off > the internet, for the specific primer and paint that you'll be using. > Depending on the answers to my questions above, you may want to increase > the amount of reducer, and go with a reducer that is for a temperature > range higher than what you'll be working in. > > Three good reasons to go with white; Red paint can cost twice as much as > white paint, dark colors show mistakes more easily, and dark colors > absorb a lot of energy from the sun. > > > My investment: > Paint booth - $250 (plastic, drop cloths, sawhorses, fans, filters, > door, and duct tape) > Supplies - $100 (masking tape, coated masking paper, fine line tape, > coveralls, wipes, tack cloths, etc.) > Paint - $1400 (1 gallon corrosion resistant primer, 2-3 gallons paint, > reducer, hardener, cleaner) > > > I'll be happy to provide more detailed information if anyone has > questions. Again, this may all be covered in the books that I haven't > read, and if so, I apologize. Questions can be posted on this site or > to my direct email address. > > Happy painting! > > Daniel Snow > I painted an RV-8 with the same paint and gun that you are using. With just a couple of changes in your procedures you will love the Concept/DeVilbiss FinishLine gun combination as much as I do. First you want to get a 1.3mm tip. My gun came with 1.5, 1.8 and 2.2mm tips. Don't screw around with this, get the 1.3mm tip. the next thing is you want to run with a little higher pressure at the gun. Mine usually runs around 38+ psi at the gun. Make sure you have a centrifugal filter at the gun. Now the secret to using Concept is how you thin it. I have had great success thinning it just like lacquer. This is a sight/feel thing not a measure thing. First measure your paint and thinner using your ratio paint cup. Add your paint and the amount of thinner recommended on the can. This is just the starting point. You are going to add probably about 20% to 30% more thinner. BUT, you are not going to measure it you are going to add small amounts of thiner and watch how the paint flows off of the end of the mixing stick. Mixed to the ratio printed on the can you will see the paint flow off of the stick in an unbroken stream. We want to keep adding thinner until the paint transitions into dropping in droplets rather than a smooth flow. If you are going to err, err on the side of more thinner rather than less. You are going to have to develop the technique of handling the gun during the spraying process. If you mix the paint like I described above and you are using the reducer recommended by the paint store for your local conditions you can easily get beautiful results. It sure sounds like you are getting way too much paint. I also really like the plastic baggies in the paint cup. This frees you up so you can spray with the gun upside down and not worry about paint dripping. I am sure you will get as many suggestions as there are painters. This is just what has worked for me. Steve Eberhart RV-7A, O-360-A1A, Catto 3 blade, working on finish kit ________________________________________________________________________________
From: "n801bh(at)netzero.com" <n801bh(at)netzero.com>
Date: Mar 14, 2007
I am not a professional painter and I didn't stay at a Holiday Inn Expre ss last night either. I have painted my street rods, boats and god o nly knows what other stuff I have spiffed up in the past. Your approach is sound and well thought out. Painting is like flying, driving a race c ar or any other highly demanding activity. There is not substitute for " seat time".. As alot of us that have painted our kit planes know by now, there is a VERY fine line between getting a slick finish with very li ttle orange peel and creating that dreaded ,,, RUN .. I am curious thoug h, with the product your are spraying,, How long do you wait for the pai nt to cure till you tape off for stripes??? Thanks in advance.. Ben Haas N801BH www.haaspowerair.com -- "Snow, Daniel A." wrote: > First, a confession and apology; I haven't read any of the books or watched any of the videos on painting, so my questions and observations may be obvious to those that have. I'm using PPG's Concept and a Devilbiss FinishLine HVLP conversion gun. >From the start orange peel has been a problem. I kept increasing the pressure, increasing paint volume, and slowing my sweeping motion. Although orange peel was decreasing, I was using an enormous amount of paint. When I got to the wings, I decided to switch back to a conventional gun, NAPA's gravity feed. Results were much better. After talking with a painter friend, I have a couple suspicions; 1) The fast (low temperature) reducer is too fast 2) The amount of reducer is too little 3) The air pressure at the cap is too low I've been following PPG's recommended temperature range and recipe', but the friend suggested using a slower (medium temperature) reducer and doubling the amount of reducer. He also suggested increasing the pressure, but I've already maxed out the pressure both at the compressor and at the gun's regulator. Question #1: For anyone that's used Concept paint, what is your opinion about using more reducer and a slower reducer? Question #2: Do you spray rivet lines first to help fill around the rivet head? Now to share some of my experiences: Two 20" box fans force air into the booth, with "sticky" filters on the inlet side of the fans. These filters are available individually at paint stores. I started with pleated air filters at the booth exit, but they have too much resistance to airflow. I'm switching to the fiber type. The personnel entrance should be close to the inlet fans so that it's not a primary means of escape for paint fog. After a couple paint sessions, paint dust collects on the paint booth walls and floor. Lightly rinse the walls with a water hose and lay new paper drop cloth on the floor. The water will also raise the humidity and cause the paint to cure a little more slowly, which aids in it "flowing out". Wear a Tyvek paint suit with hood to minimize lint/dust contamination from your clothes. Handling all the solvents will dry out your hands very quickly (I know, I should be using gloves, but it hassssssssssnnnnnnnn'ttttttt affected me yet, hasn't affected me yet, hasn't affected me yet), and you'll be using hand lotion. That hand lotion has a sneaky way of finding its way onto parts to be painted. I suggest washing your hands with soap before working with parts to be painted. A friend also found that RTV is persistent. Alumiprep has a tendency to collect on the bottom of treated parts and drying there. You have to rinse the bottom of parts frequently until they're ready to dry. Even after Alumiprep, parts should be cleaned with a cleaning wipe, dried with a clean cloth, and wiped with a tack cloth. HVLP may be better suited to professionals. Most big parts can be suspended from wires or sawhorses in a manner that allows you to paint with each side in a horizontal position. This reduces the chances of runs and sags. For example, I placed 3' sections of 4" PVC pipe through each end of the wings and rested the pipes on sawhorses. This allows the wings to rotate around pipes. Another piece of 2" PVC placed in one end helps secure the wing in a horizontal position. Paint one side, flip the wing over, paint the other side. I've ready the recommendation to practice painting on paper. I don't know if this would work, but the slippery side of "coated" making paper might make a better test piece since it won't absorb the paint. The first "tack" coat of paint should be shot from about 12", and applied quickly to provide about 50% coverage. Wait 10 minutes, shoot the rivet lines and edges lightly, then shoot the final coat at 6"-8" and a little more slowly and more heavily. Make sure to overlap up to 50%. Pinholes - I know a lot has been written already, but I thought I could be successful with less work. WRONG! Sand the parts until there are no shiny spots left. Using a Bondo-type squeegee, work SuperFil back and forth quickly, like using a paint brush, then scrape the squeegee backwards to remove excess. The pinholes will have blue SuperFil in them and will be easy to see. Let cure overnight, then lightly sand entire piece, making sure not to remove the blue SuperFil from the pinholes. Prime several filled parts with the same primer you're using for your painting. After the primer cures, look closely for pinholes. If any pinholes remain, fill with "glazing/spot putty" available from auto parts stores. This putty is like a thinned Bondo and works into the pinholes with the same squeegee. In 15 minutes it's ready to sand, clean, and reprime. This method sounds like a lot of work, but it's effective and doesn't take a lot of elbow grease. Striping - Chances are that your paint will go on a little thicker than the manufacturer recommends. Wait a little longer to use fine line tape for stripes, or you may get tape tracks that have to be buffed out. Ask the paint store for paint spec sheets, or locate and print them off the internet, for the specific primer and paint that you'll be using. Depending on the answers to my questions above, you may want to increase the amount of reducer, and go with a reducer that is for a temperature range higher than what you'll be working in. Three good reasons to go with white; Red paint can cost twice as much as white paint, dark colors show mistakes more easily, and dark colors absorb a lot of energy from the sun. My investment: Paint booth - $250 (plastic, drop cloths, sawhorses, fans, filters, door, and duct tape) Supplies - $100 (masking tape, coated masking paper, fine line tape, coveralls, wipes, tack cloths, etc.) Paint - $1400 (1 gallon corrosion resistant primer, 2-3 gallons paint, reducer, hardener, cleaner) I'll be happy to provide more detailed information if anyone has questions. Again, this may all be covered in the books that I haven't read, and if so, I apologize. Questions can be posted on this site or to my direct email address. Happy painting! Daniel Snow RV-9A, Painting ======================== =========== ======================== =========== ======================== ===========
I am not a professional painter and I didn't stay at a Holiday Inn Express last night either. <G> I have painted my street rods, boats and god only knows what other stuff I have spiffed up in the past. Your approach is sound and well thought out. Painting is like flying, d riving a race car or any other highly demanding activity. There is not s ubstitute for "seat time".. As alot of us that have painted our kit plan es know by now, there is a  VERY fine line between getting a slick finish  with very little orange peel and creating that dreaded ,,, RUN .. I am curious though, with the product your are spraying,, Ho w long do you wait for the paint to cure till you tape off for stri pes???
Thanks in advance..
Ben Haas
N801BH
www.haaspow erair.com
-- "Snow, Daniel A." <Daniel.Sno w(at)wancdf.com> wrote:
--> RV-List message po sted by: "Snow, Daniel A." <Daniel.Snow@wanc df.com>
First, a confession and apology;&n bsp; I haven't read any of the books& nbsp;or
watched any of the videos on pa inting, so my questions and observations
>From the  ;start orange peel has been a problem.&nbs p; I kept increasing the
pressure, increasin g paint volume, and slowing my sweeping&nb sp;motion.
Although orange peel was decreasing,&n bsp;I was using an enormous amount of
p aint.  When I got to the wings,  I decided to switch back to a
conventio nal gun, NAPA's gravity feed.  Results&nbs p;were much better.  After
talking with  ;a painter friend, I have a couple su spicions;
1)  The fast (low temperature)&nbs p;reducer is too fast
2)  The amount&nb sp;of reducer is too little
3)  The&nbs p;air pressure at the cap is too low< BR>I've been following PPG's recommended temper ature range and recipe', but
the friend  ;suggested using a slower (medium temperature)& nbsp;reducer and
doubling the amount of redu cer.  He also suggested increasing the
pressure, but I've already maxed out the&n bsp;pressure both at the compressor
and at&n bsp;the gun's regulator.
Question #1:  F or anyone that's used Concept paint, what& nbsp;is your opinion
about using more reduce r and a slower reducer?
Question #2:&nbs p; Do you spray rivet lines first to& nbsp;help fill around the
rivet head?
in let side of the fans.  These filters& nbsp;are available individually at
paint stores.< BR>
I started with pleated air filters  at the booth exit, but they have too< BR>much resistance to airflow.  I'm switch ing to the fiber type.
The personnel&nbs p;entrance should be close to the inlet&nb sp;fans so that it's
not a primary mean s of escape for paint fog.
After a& nbsp;couple paint sessions, paint dust collects  on the paint booth
walls and floor.&nb sp; Lightly rinse the walls with a wa ter hose and lay new
paper drop cloth&n bsp;on the floor.  The water will als o raise the humidity
and cause the pain t to cure a little more slowly, which  aids in it
"flowing out".
Wear a&nbs p;Tyvek paint suit with hood to minimize&n bsp;lint/dust contamination
from your clothes.
Handling all the solvents will dry out&nbs p;your hands very quickly (I know,
I sh ould be using gloves, but it hassssssssssn nnnnnnn'ttttttt affected
me yet, hasn't affected& nbsp;me yet, hasn't affected me yet), and& nbsp;you'll be
using hand lotion.  That  ;hand lotion has a sneaky way of find ing its way
onto parts to be painted.&n bsp; I suggest washing your hands with&nbs p;soap before
working with parts to be  painted.  A friend also found that RT V is
persistent.
Alumiprep has a tendency& nbsp;to collect on the bottom of treated&n bsp;parts and
drying there.  You have t o rinse the bottom of parts frequently&nbs p;until
Even after&n bsp;Alumiprep, parts should be cleaned with&nbs p;a cleaning wipe,
dried with a clean c loth, and wiped with a tack cloth.
HVLP may be better suited to professionals .
Most big parts can be suspended f rom wires or sawhorses in a manner th at
allows you to paint with each side&n bsp;in a horizontal position.  This
reduces& nbsp;the chances of runs and sags.  F or example, I placed 3' sections
of 4"& nbsp;PVC pipe through each end of the  ;wings and rested the pipes on
sawhorses.&nb sp; This allows the wings to rotate a round pipes.  Another piece
of 2" PVC&n bsp;placed in one end helps secure the&nbs p;wing in a horizontal
position.  Paint  ;one side, flip the wing over, paint  the other side.
I've ready the recommend ation to practice painting on paper.   ;I don't
know if this would work, but&n bsp;the slippery side of "coated" making p aper
might make a better test piece sin ce it won't absorb the paint.
The f irst "tack" coat of paint should be s hot from about 12", and
applied quickly  ;to provide about 50% coverage.  Wait  ;10 minutes, shoot
the rivet lines and  edges lightly, then shoot the final coat&n bsp;at 6"-8"
and a little more slowly a nd more heavily.  Make sure to overla p up to
50%.
Pinholes - I know a  lot has been written already, but I& nbsp;thought I could
be successful with less  work.  WRONG!  Sand the parts u ntil there are no
shiny spots left. &nb sp;Using a Bondo-type squeegee, work SuperFil&n bsp;back and
forth quickly, like using a&nbs p;paint brush, then scrape the squeegee
back wards to remove excess.  The pinholes  ;will have blue SuperFil in
them and wi ll be easy to see.  Let cure ove rnight, then lightly sand
entire piece, maki ng sure not to remove the blue SuperF il from the
pinholes.  Prime several fi lled parts with the same primer you're&nbs p;using
for your painting.  After the p rimer cures, look closely for pinholes.
If&n bsp;any pinholes remain, fill with "glazing/spo t putty" available from
auto parts stores.&n bsp; This putty is like a thinned Bon do and works into
the pinholes with the  same squeegee.  In 15 minutes it's&n bsp;ready to sand,
clean, and reprime.   ;This method sounds like a lot of wor k, but it's
Striping - C hances are that your paint will go on  a little thicker than
the manufacturer  ;recommends.  Wait a little longer to  ;use fine line tape
for stripes, or you  may get tape tracks that have to&nbs p;be buffed out.
Ask the paint store&nbs p;for paint spec sheets, or locate and&nbs p;print them off
the internet, for the  specific primer and paint that you'll be&n bsp;using.
Depending on the answers to my&nb sp;questions above, you may want to increa se
the amount of reducer, and go with&n bsp;a reducer that is for a temperature
range higher than what you'll be working& nbsp;in.
Three good reasons to go with&n bsp;white; Red paint can cost twice as&nbs p;much as
white paint, dark colors show  ;mistakes more easily, and dark colors
absor b a lot of energy from the sun.
My investment:
Paint booth - $250 (pla stic, drop cloths, sawhorses, fans, filters,
Supplies - $100 ( masking tape, coated masking paper, fine l ine tape,
coveralls, wipes, tack cloths, etc .)
Paint - $1400 (1 gallon corrosion re sistant primer, 2-3 gallons paint,
I'll be happy to  provide more detailed information if anyone&nbs p;has
questions.  Again, this may all b e covered in the books that I haven't
read, and if so, I apologize.  Qu estions can be posted on this site or
Happy pa ======================== ========================      - The RV-List Email Fo ;List utilities such as the Subscriptions  ======================== ========================      - NEW MATRONICS WEB FO ======================== ======================== ======
Date: Mar 15, 2007
The spec sheet says it can be taped in about 8 hours. I let mine cure overnight and still got tape trails. The next time I let it cure for about 24 hours and that worked much better. My problem is probably that I'm putting on too much paint. I'm about to paint now and will try using more reducer to reduce paint buildup and to get more flow out. > From: "n801bh(at)netzero.com" <n801bh(at)netzero.com> > Subject: Re: RV-List: Painting Questions and Advice > >As alot of us that have painted our kit planes know by now, > there is a VERY fine line between getting a slick finish with very li > ttle orange peel and creating that dreaded ,,, RUN .. I am curious thoug > h, with the product your are spraying,, How long do you wait for the pai > nt to cure till you tape off for stripes??? > > Thanks in advance.. > ________________________________________________________________________________
Subject: TRADE: RV 6/8 Emp Construction video for RV 9 Video
Date: Mar 15, 2007
I have the Orndorff RV-6/8 Empennage videos and I would like to make a straight trade with anyone who has the RV-9 video. Reply off list if you're interested. Thanks, Brandon. B_rigio(at)hotmail.com ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Date: Mar 15, 2007
Hi All, two things are of major influence when you paint: 1: temperature, most two pack paints require at least 15 centigrade preferable a bit higher around 18- 20 C mark. IF you CANNOT maintain this temperature for at least 6 hours, don't even attempt any paint spraying. 2: humidity,humidy between 40 - 70 % is fairly ideal. It can be elevated by wetting the floor, this is perfect when you're trying to accelerate the curing of polyurethane. Around 27C with a bucket of water over the floor does miracles on the cure time with Polyurethane. Excessive high temps won't hasten your case with poly. The 2 points above are required because of chemical reaction to be started and maintained between base and hardener. Yes, I know people too who claim to got away with far less, but it's like a poorly built aircraft, it flies and that's that. Technique and practise is what will make your paintjob look well. It can't be stressed enough 2 thin coats are better than one heavy one, regardless of what you spray. When I paint RV's I give it a single crosscoat where I just go a bit heavier than dusting the surface. When it's complete I go out of the booth and have a coffee and a snack, after half an hour I suit up again and give it a wet crosscoat. Look into the light and spray along with the mirror, in other words when you do your wet crosscoat which is about twice as haevy as your first coat, you'll notice that you get a good glossy finish which mirrors. When you make your passes keep spraying in a 50% overlap with the previous track and bring the mirror towards you without any hurry and without any interuptions. This will avoid any dry spots you 'll have to cut and polish afterwards. As you'll appreciate it's not that easy to teach someone to spray over the internet, so I only can give you some of the basic tips, if you practise a bit, even on a bit of masking paper, you'll swiftly get the hang of it. The most difficult thing in the begining will be the set up of your gun. Again use the masking paper and set up the ratio between paint and air. Too much paint at a given amount of air WILL produce orangepeel, no matter what type of paint you spray. Finally, the distance between the tip of your gun and your object is about the spread of your hand, spread hand as far as it goes, the distance between little finger and thumb is about 8" with most adults a faiurly good distance to start of with. As goes for runs and sags, I've been painting airliners for years both in the factory and out in the big maintenace facilities for years and light aircraft in the more recent years, they still occasionally happen. As long as you keep moving and don't keep hitting the same spot over and over you'll have a fair chance avoiding them. To aid your concentration switching of the cellphone is certainly a help! Good luck to all of you trying it for the first time and keep the paint to a minimum, it's an aircarft and not classic Rolls Royce motorcar needing 32 coats of paint. Marcel RV7 flying RV10 allmost ________________________________________________________________________________
Date: Mar 16, 2007
Good News! Someone had one in their hanger down in San Antinio TX.. Talked to him last night and its on its way. Thanks George. Bruce G. RV8 Fuse >From: "BRUCE GRAY" <brucerv84us(at)hotmail.com> >Reply-To: rv-list(at)matronics.com >To: RV-List(at)matronics.com >Subject: RV-List: RV8 Rudder Cable >Date: Wed, 14 Mar 2007 08:12:16 -0800 > > >Looking for 1 unused rudder cable(F-852A) for a RV8. Cable dimensions >161.375". Van's sells them in sets only. Will pay half of the going rate or >whatever you feel its worth. New set from Van's is $77.45. >I botched one up when it fell into my rotary file while opening a hole. >Thanks, > >Bruce G. >RV8 Fuse > >_________________________________________________________________ >Mortgage rates as low as 4.625% - Refinance $150,000 loan for $579 a month. >Intro*Terms >https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f6&disc=y&vers=743&s=4056&p=5117 > > _________________________________________________________________ 5.5%* 30 year fixed mortgage rate. Good credit refinance. Up to 5 free quotes - *Terms https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h2a5d&s=4056&p=5117&disc=y&vers=910 ________________________________________________________________________________
Date: Mar 16, 2007
". . . it's an aircarft and not classic Rolls Royce motorcar needing 32 coats of paint." Besides, if you stay away from airshows ATC will keep other pilots at least 500 feet away from your plane! Pete Cowper RV8 #81139 ________________________________________________________________________________
Date: Mar 16, 2007
Subject: RV8(A) Fuselage Jig Available
I'm helping a friend finish riveting the skins on his 8 and we'll have a fuselage jig available in the next couple days if anyone is interested. Come and get it if you can use it! This is the second 8 built on this jig. The jig is straight and true. It's located in Maumee, OH. not far from I-75 & I-80 (Northwest Ohio, suburb of Toledo). Tony Kirk 419.376.4536 ________________________________________________________________________________
Subject: Aircraft Registration
Date: Mar 16, 2007
Hey All, Just got my FAA registration in the mail. Less than 2 weeks from the time I sent it on its way to Oklahoma. Two more months till I'm in the air. Paul Rice RV8 ________________________________________________________________________________
Date: Mar 16, 2007
Subject: -7 tipup rollbar question
I'm fitting the F-631 rollover assy. to the fuselage. If I set the base at the station mentioned on the plans sheet (from memory, 56 13/16"?) it looks like I need to trim F732A about 1/4" to get that 2 7/8" setback at the top. Is there any consensus on this, or have y'all just used the F732A to set the tilt? Thanks, Charlie ________________________________________________________________________________
Subject: DeltaHawk Engine
Date: Mar 16, 2007
I'm still working on the empennage of my 8 quick-build kit and am spending way too much time daydreaming, panel planning and lurking on the web. I know I should be out in the shop squeezing rivets and mangling lovely pieces of .020 but I have an important question for group I hope you can help me with. Two days ago Dennis Webb from DeltsHawk Engines Inc (www.deltahawkengines.com) e-mailed me to offer a position in their projected delivery for 2008 and requesting a $5000 deposit. This will establish me in the line-up and I should receive my engine some time in 08,,,, hopefully I'll have completed the empennage by then and maybe even closed up the wings..hope hope...Actually the timing should work quite well for me given my pace I have read as much about Deltahawk and their DH180A4 as I can find on the web and Kitplanes author Tim Kern ran a very complimentary article in the December 2006 issue. The engine appeals to me for any number of reasons, direct drive purpose-built aviation engine, fuel availability, low fuel burn, durability, you can read all the hype on their web site. BUT......I need some advise and a devil's advocate or two (1) what about firewall forward installation...engine mounts..cooling rads..cowl design..exhaust and muffler..fuel pumps, filters and return lines, and all those things I haven't even thought of (2) company viability and the chance of me kissing my 5grand goodbye If anybody has any thoughts on this we can start a string or you can e-mail me directly with your comments good or bad.....the more input the better. My thoughts are I'll fly to Chicago and drive up to Racine to do the touchy-feely before I write the cheque ( check ), I retired from an airline job 1 Jan so do have some time available and the ticket won't cost much.. Thanks very much... Ralph Howey Delta B.C. ________________________________________________________________________________
Subject: Re: -7 tipup rollbar question
Date: Mar 16, 2007
Charlie: The angle of the "tilt" is easy if you cleco on the top skin. The the measurement you have to make is the distance from the top (I think it's the top, I don't have the plans here with me) of the rollbar to the 705. -------- Bob Collins St. Paul, Minn. RV Builder's Hotline (free!) http://rvhotline.expercraft.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=101135#101135 ________________________________________________________________________________
Subject: Re: DeltaHawk Engine
Date: Mar 16, 2007
Ralph, I have been in business for over 45 years and anytime I see a request for a large downpayment from a relitivly new company for a $5000 downpayment for something that I will not need for l or 2 years, I become very suspicious. If their terms demand a large downpayment for something that you will not need for at least one or two years, I would suggest that you keep your money in the bank earning interest and hold off untill you are within 6 months of requiring an engine for your airplane. Dick Martin RV8 N233M the fast one ----- Original Message ----- From: Ralph Howey To: rv-list(at)matronics.com Sent: Friday, March 16, 2007 7:56 PM Subject: RV-List: DeltaHawk Engine I'm still working on the empennage of my 8 quick-build kit and am spending way too much time daydreaming, panel planning and lurking on the web. I know I should be out in the shop squeezing rivets and mangling lovely pieces of .020 but I have an important question for group I hope you can help me with. Two days ago Dennis Webb from DeltsHawk Engines Inc (www.deltahawkengines.com) e-mailed me to offer a position in their projected delivery for 2008 and requesting a $5000 deposit. This will establish me in the line-up and I should receive my engine some time in 08,,,, hopefully I'll have completed the empennage by then and maybe even closed up the wings..hope hope...Actually the timing should work quite well for me given my pace I have read as much about Deltahawk and their DH180A4 as I can find on the web and Kitplanes author Tim Kern ran a very complimentary article in the December 2006 issue. The engine appeals to me for any number of reasons, direct drive purpose-built aviation engine, fuel availability, low fuel burn, durability, you can read all the hype on their web site. BUT......I need some advise and a devil's advocate or two (1) what about firewall forward installation...engine mounts..cooling rads..cowl design..exhaust and muffler..fuel pumps, filters and return lines, and all those things I haven't even thought of (2) company viability and the chance of me kissing my 5grand goodbye If anybody has any thoughts on this we can start a string or you can e-mail me directly with your comments good or bad.....the more input the better. My thoughts are I'll fly to Chicago and drive up to Racine to do the touchy-feely before I write the cheque ( check ), I retired from an airline job 1 Jan so do have some time available and the ticket won't cost much.. Thanks very much... Ralph Howey Delta B.C. ________________________________________________________________________________
Date: Mar 16, 2007
Bob Collins wrote: > > Charlie: The angle of the "tilt" is easy if you cleco on the top skin. The the measurement you have to make is the distance from the top (I think it's the top, I don't have the plans here with me) of the rollbar to the 705. > > -------- > Bob Collins > St. Paul, Minn. > RV Builder's Hotline (free!) > http://rvhotline.expercraft.com Everything's clecoed on; with the F732A (& the reinforcement/spacer) clecoed to the top skin & the base of the F637 positioned correctly on the fuselage sides, the tiltback measurement shown on the plans is 2 7/8" & I'm coming up at about 2 5/8". I think that this is on dwg#40. I'm sitting a framing square on the top of F705 to get the measurement; that might be the problem. Maybe I need to level the fuse & drop a plumb line. Charlie ________________________________________________________________________________
Date: Mar 16, 2007
On 16 Mar 2007, at 20:56, Ralph Howey wrote: > I'm still working on the empennage of my 8 quick-build kit and am > spending way too much time daydreaming, panel planning and lurking > on the web. I know I should be out in the shop squeezing rivets and > mangling lovely pieces of .020 but I have an important question for > group I hope you can help me with. > > Two days ago Dennis Webb from DeltsHawk Engines Inc > (www.deltahawkengines.com) e-mailed me to offer a position in their > projected delivery for 2008 and requesting a $5000 deposit. This > will establish me in the line-up and I should receive my engine > some time in 08,,,, hopefully I'll have completed the empennage by > then and maybe even closed up the wings..hope hope...Actually the > timing should work quite well for me given my pace > If you are still working on your empennage, you are a long way away from needing an engine. If your build goes at the pace of many builders, you may not need an engine for several years. The DeltaHawk engine has zero service history at the moment. There will almost certainly be changes made as a result of problems experienced in service. If you take delivery of your engine too early, you won't get the improvements that are made later. Will your money be held in escrow, or is there a risk that the company could go bankrupt and you lose it? If it later turns out that the engine isn't nearly as good as it is currently claimed to be, can you get your money back, or is this a non-refundable deposit? Having to sort out engine mount, cowling, radiator mount, etc, etc will add a lot of complication and cost to the project. This is OK as long was you enjoy this sort of thing, and are in no rush to get finished and have cash to burn. If you are hoping to get flying as early as possible, or as cheaply as possible, stick with a Lycoming. Personally, I would prefer to see a reasonable amount of good service history before I committed to something as important and expensive as an engine. Putting $5,000 down now only makes sense if you are comfortable with the possibility of having that money be lost. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Mar 17, 2007
Go hide your checkbook and credit card(s). Kevin was right on. Do you want to do all the mods needed to make this work in a proven design like RV plus Lycoming type engine? Fuel availability? How many airports have diesel? How will you refuel going cross-country? Get this thought out of your mind for now and ask again in a year. Even then I would not likely recommend this engine. Ron Lee --------------------------------------------- This message was sent using Endymion MailMan. http://www.endymion.com/products/mailman/ ________________________________________________________________________________
Subject: Oil Door Latch
Date: Mar 17, 2007
Can anybody tell me where to get the round push button oil door latch I see on a lot of RV's. I think it is made by camloc, but I can't find it anywhere. Thanks, Paul Rice RV8 almost ready to fly ________________________________________________________________________________
Subject: Re: Oil Door Latch
Date: Mar 17, 2007
I'm not sure if this is what you are looking for or not... KM610-64 Try this link to Skybolt. It's at the bottom of page 5... http://skybolt.com/SC180%20&%20185PL%20WEB.pdf Aircraft Spruce also offers it. You can also go to matronics search archives and type in "KM610-64" Bill Settle RV-8 Wings > > From: "Paul Rice" <rice737(at)msn.com> > Date: 2007/03/17 Sat AM 12:43:10 EST > To: > Subject: RV-List: Oil Door Latch > > Can anybody tell me where to get the round push button oil door latch I see on a lot of RV's. I think it is made by camloc, but I can't find it anywhere. > > Thanks, > > Paul Rice > RV8 almost ready to fly > > ________________________________________________________________________________
Date: Mar 17, 2007
ronlee(at)pcisys.net wrote: > > Go hide your checkbook and credit card(s). Kevin was right on. Do you > want to do all the mods needed to make this work in a proven design like > RV plus Lycoming type engine? Good advice. > Fuel availability? How many airports have diesel? How will you refuel > going cross-country? No problem here. The aviation diesels burn Jet-A which is one of the main appeals of a diesel. Sam Buchanan ________________________________________________________________________________
Date: Mar 17, 2007
I followed Deltahawk for a long time, with the thought that I wanted to put their 200HP inverted engine in my RV-10. After building for 4 years, during which Deltahawk continued to say there were "just about to start delivering engines", I ordered a lycoming to avoid bringing my project to a halt. I still watch their progress on their webpage. I think that eventually they'll deliver engines, and that they'll be good engines. They've made a lot of progress in the time I've been watching them. However, this is going to be the big challenge for you: Deltahawk is only interested in providing engines. If you buy an engine from them, either someone else has to build the firewall forward for you, or you've got to do it yourself. Don't underestimate the amount of engineering that will go into the engine mount, oil system, cooling system, etc. The fact that they want a deposit for something they'll deliver in 2008 means that they're either assembling the engines extremely slow, or they're going to use your money help to pay for the engines they promised in 2007. As we've seen with Direct-2-Avionics, that puts your deposit at serious risk if they run out of capital. My response would be different if they were delivering engines like hotcakes; I paid Barrett half the cost of my lycoming several months ago, but I'm comfortable that he's going to send me an engine when he says he is. PJ Seipel RV-10 #40032 Ralph Howey wrote: > I'm still working on the empennage of my 8 quick-build kit and > am spending way too much time daydreaming, panel planning and lurking > on the web. I know I should be out in the shop squeezing rivets and > mangling lovely pieces of .020 but I have an important question for > group I hope you can help me with. > > Two days ago Dennis Webb from DeltsHawk Engines Inc > (www.deltahawkengines.com <http://www.deltahawkengines.com>) e-mailed > me to offer a position in their projected delivery for 2008 and > requesting a $5000 deposit. This will establish me in the line-up and > I should receive my engine some time in 08,,,, hopefully I'll have > completed the empennage by then and maybe even closed up the > wings..hope hope...Actually the timing should work quite well for me > given my pace > > I have read as much about Deltahawk and their DH180A4 as I can find on > the web and Kitplanes author Tim Kern ran a very complimentary article > in the December 2006 issue. The engine appeals to me for any number of > reasons, direct drive purpose-built aviation engine, fuel > availability, low fuel burn, durability, you can read all the hype on > their web site. > > BUT......I need some advise and a devil's advocate or two > > (1) what about firewall forward installation...engine mounts..cooling > rads..cowl design..exhaust and muffler..fuel pumps, filters and return > lines, and all those things I haven't even thought of > > (2) company viability and the chance of me kissing my 5grand goodbye > > If anybody has any thoughts on this we can start a string or you can > e-mail me directly with your comments good or bad.....the more input > the better. > My thoughts are I'll fly to Chicago and drive up to Racine to do the > touchy-feely before I write the cheque ( check ), I retired from an > airline job 1 Jan so do have some time available and the ticket won't > cost much.. > > Thanks very much... > > Ralph Howey > Delta B.C. > * > > > * ________________________________________________________________________________
Date: Mar 17, 2007
Maybe what you are looking for is a Hartwell latch, do a search on this list and you should get some hit. Marty ________________________________________________________________________________
Date: Mar 17, 2007
-----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph Howey Sent: Friday, March 16, 2007 7:56 PM Subject: RV-List: DeltaHawk Engine Two days ago Dennis Webb from DeltsHawk Engines Inc (www.deltahawkengines.com) e-mailed me to offer a position in their projected delivery for 2008 and requesting a $5000 deposit. This will establish me in the line-up and I should receive my engine some time in 08,,,, hopefully I'll have completed the empennage by then and maybe even closed up the wings..hope hope...Actually the timing should work quite well for me given my pace BUT......I need some advise and a devil's advocate or two (1) what about firewall forward installation...engine mounts..cooling rads..cowl design..exhaust and muffler..fuel pumps, filters and return lines, and all those things I haven't even thought of (2) company viability and the chance of me kissing my 5grand goodbye Thanks very much... Ralph Howey Delta B.C. Ralph: This is at least the second time around on the request for funds. In Dec -03 I signed a delivery position agreement with the stipulation for a $5K deposit when requested. The request came some time later but they admitted to a problem with vibration that threatened the use of a Hartzell prop. They could not say when the matter would be resolved. I declined to send the deposit and have had no communication with them since. I think they are honest people. I do not know how they are financed, but they are still in there swinging when many others would have disappeared. Their original intent was to contract with others to do FWF development. I don't know if that has been done. I sketched up a layout for the RV-8 that I thought might be workable but the work involve to reduce the layout to working drawings and fabrication was beyond me, especially from the time standpoint. I have since taken delivery on a Lyc IO 390. Honest or not, if they get into financial trouble, that trouble will be visited upon you. Good luck. Gordon Comfort N363GC ________________________________________________________________________________
Date: Mar 17, 2007
Hi Ralph, You have read some good advise so far an I agree with most of it. A company that has been 1 year away from delivering engines for the last 5 years and is still not delivering engines does not deserve $5000 of your hard earned money. A good faith deposit is one thing, but you (as a builder) are not in the business of providing investment capitol. DH should take smaller deposits and use them to convince the bank that their engines will sell. That being said, I sure hope they make it. Being a fan of alternate engine choices I followed DH for a couple of years but wanted to get started long before they were ready. I looked at their site last night for the first time in years and am very impressed. The engineering and flight data is new and particularly impressive. If I had to guess, $5000 put down now would eventually see an engine at your door.... but maybe not in 2008. Anyway, I wanted to address your concerns about FF fabrication, having done it for my rotary RV-6. That stuff is not harder than the other systems you develop in building an RV. I spent about 2-3 months of my build time (couple half-day/week type thing) on the engine mount, and 2 more months on cooler placement and I keep changing the cowl. The nice thing for you with the DH is that the intake and exhaust manifolds are already done, same with the fuel, oil, injector, and electrical systems around the engine. Those were some of the hardest parts of my installation. Of course, I am still tinkering and making changes while the lyc guys are buzzing my house... but by 'next year' I should have it all worked out ;-) David Leonard Turbo Rotary RV-6 N4VY My websites at: http://members.aol.com/_ht_a/rotaryroster/index.html http://members.aol.com/_ht_a/vp4skydoc/index.html http://leonardiniraq.blogspot.com On 3/16/07, Ralph Howey wrote: > > I'm still working on the empennage of my 8 quick-build kit and > am spending way too much time daydreaming, panel planning and lurking on the > web. I know I should be out in the shop squeezing rivets and mangling lovely > pieces of .020 but I have an important question for group I hope you can > help me with. > > Two days ago Dennis Webb from DeltsHawk Engines Inc ( > www.deltahawkengines.com) e-mailed me to offer a position in their > projected delivery for 2008 and requesting a $5000 deposit. This will > establish me in the line-up and I should receive my engine some time in > 08,,,, hopefully I'll have completed the empennage by then and maybe even > closed up the wings..hope hope...Actually the timing should work quite well > for me given my pace > > I have read as much about Deltahawk and their DH180A4 as I can find on the > web and Kitplanes author Tim Kern ran a very complimentary article in the > December 2006 issue. The engine appeals to me for any number of reasons, > direct drive purpose-built aviation engine, fuel availability, low fuel > burn, durability, you can read all the hype on their web site. > > BUT......I need some advise and a devil's advocate or two > > (1) what about firewall forward installation...engine mounts..cooling > rads..cowl design..exhaust and muffler..fuel pumps, filters and return > lines, and all those things I haven't even thought of > > (2) company viability and the chance of me kissing my 5grand goodbye > > If anybody has any thoughts on this we can start a string or you can > e-mail me directly with your comments good or bad.....the more input the > better. > My thoughts are I'll fly to Chicago and drive up to Racine to do the > touchy-feely before I write the cheque ( check ), I retired from an airline > job 1 Jan so do have some time available and the ticket won't cost much.. > > Thanks very much... > > Ralph Howey > Delta B.C. > > * > > * > > -- ________________________________________________________________________________
Date: Mar 17, 2007
> > Fuel availability? How many airports have diesel? How will you refuel > > going cross-country? > > No problem here. The aviation diesels burn Jet-A which is one of the > main appeals of a diesel. > > Sam Buchanan > Thanks Sam. I did not know that. Of course there is no Jet A at my airport. Ron Lee Do not archive --------------------------------------------- This message was sent using Endymion MailMan. http://www.endymion.com/products/mailman/ ________________________________________________________________________________
Date: Mar 17, 2007
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Subject: Bleeding Brakes
Date: Mar 17, 2007
Where can I find step by step instructions on how to bleed the brakes. When I built the plane 10 years ago I had help with this from an A&P friend and most of what I remember was that it was a big mess. I found a leaky wheel cylinder today which means a new set of O-rings and an afternoon of fun. Having a little less fun than the first time would be a good thing. Then someone said I'll have to open up the master cylinders while I'm doing this, but I don't recall that. I think I remember bleeding straight up into the reservoir. Can anyone help me refresh my memory? Thanks, Andy ________________________________________________________________________________
Subject: Re: Bleeding Brakes
Date: Mar 17, 2007
Matco's website has two sets of instructions...pressure and suction....... ----- Original Message ----- From: "Andy Gold" <andygold(at)rkymtnhi.com> Sent: Saturday, March 17, 2007 6:59 PM Subject: RV-List: Bleeding Brakes > > Where can I find step by step instructions on how to bleed the brakes. > > When I built the plane 10 years ago I had help with this from an A&P > friend and most of what I remember was that it was a big mess. I found a > leaky wheel cylinder today which means a new set of O-rings and an > afternoon of fun. Having a little less fun than the first time would be a > good thing. > > Then someone said I'll have to open up the master cylinders while I'm > doing this, but I don't recall that. I think I remember bleeding straight > up into the reservoir. > > Can anyone help me refresh my memory? > > Thanks, > Andy > > > ________________________________________________________________________________
Date: Mar 17, 2007
Here is how I did it: http://webpages.charter.net/bobbyhester/FinishingUp.htm Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Andy Gold wrote: > > Where can I find step by step instructions on how to bleed the brakes. > > When I built the plane 10 years ago I had help with this from an A&P > friend and most of what I remember was that it was a big mess. I > found a leaky wheel cylinder today which means a new set of O-rings > and an afternoon of fun. Having a little less fun than the first time > would be a good thing. > > Then someone said I'll have to open up the master cylinders while I'm > doing this, but I don't recall that. I think I remember bleeding > straight up into the reservoir. > > Can anyone help me refresh my memory? > > Thanks, > Andy > > ________________________________________________________________________________
Date: Mar 17, 2007
Subject: non impulse coupling mag drive gear needed for elec ignition
You need to tell us brand and model number of the magneto. I have some parts in a drawer . Bob Olds _oldsfolks(at)aol.com_ (mailto:oldsfolks(at)aol.com) ************************************** AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. ________________________________________________________________________________
From: "Michael D. Cencula" <matronics(at)cencula.com>
Subject: RV7-List: Z-bracket height (again) - Help!
Date: Mar 17, 2007
Please forgive the cross-posting, but I sent this to the RV7 list first. Afterward, I thought some of the other RV builders might have some good ideas. Guys, I'm stumped! My when I set my leading edges on the spar, the leading edge skin butts right up to the main wing skins (both top and bottom) perfectly. With the tanks, it's a different story. I've been trying to figure out what's causing the gap and the only thing I can come up with is that the Z-brackets are a little too high. If y'all have a couple minutes and would be willing to look at what I've tried, I'd sure appreciate any feedback how to fix it. At this time, the only solution I can think of is to put a joggle in the web of the Z-brackets which will effectively shorten them by .040 inch. That seems like it'll be pretty difficult, though so I'm really hoping for a better solution. Here's some pics that document the problem: http://www.our7a.com/20070315.html http://www.our7a.com/20070317.html Thanks, Mike Cencula ________________________________________________________________________________
Date: Mar 18, 2007
Hi Andy, I used a pressure tank, it holds about a gallon of brake fluid, use the pump to bring the vessel under pressure, attach the hose to the bleednipple on the caliper, open the nipple about a turn and open the valve. it shoots the brakefluid straight into the system and out of the fluid resevoir if you're not careful. You'll find a -4 fitting will screw into your brake fluid resevoir, a bit of alu tubing and a jar at the bottom if you're not keen on cleaning spilt brake fluid. Takes about five minutes this way, and you can do it alone. Marcel ----- Original Message ----- From: "Andy Gold" <andygold(at)rkymtnhi.com> Sent: Saturday, March 17, 2007 10:59 PM Subject: RV-List: Bleeding Brakes > > Where can I find step by step instructions on how to bleed the brakes. > > When I built the plane 10 years ago I had help with this from an A&P > friend and most of what I remember was that it was a big mess. I found a > leaky wheel cylinder today which means a new set of O-rings and an > afternoon of fun. Having a little less fun than the first time would be a > good thing. > > Then someone said I'll have to open up the master cylinders while I'm > doing this, but I don't recall that. I think I remember bleeding straight > up into the reservoir. > > Can anyone help me refresh my memory? > > Thanks, > Andy > > > ________________________________________________________________________________
Date: Mar 18, 2007
Message Hi guys, Apologies to butt in on this topic. I must say I live across the Atlantic, we don't have as much freedom here to change what we want on our aeroplanes due to the need of some authoritive figures wanting to tell what you can or can't do. I have been on this list for quite a few years now and have seen many 'new' engines come and go or be a major disappoinment, either by the lack of permance or their integration with the RV airframe. Think the Thielert Diesels, conversion cost some $20K over new Lyco price and cut in performance to save a $$ on fuel. Maybe their new offering is better? Can some try to explain what is so attractive to an engine that has an unknown service history, unknown performance and to top all, is often more costlier when the full installation is completed? I personally don't see much sense in for example the Superior engines, the difference with genuine Lycoming is very small and a full service record has still to be established. I know their parts are authorized to be used on cert Lycomings, but that's still different in my book to an entire engine built of those parts. Part of this doubt may be caused by the way parts are sold and kept here in Europe, but seeing the RV is pretty much a travelling aeroplane, it make sense to me to stick to something 'standard' as Murphy says your aeroplane will only break away from base. What better than being able to walk straight to the nearest mechano and say: my Lyco has packed in , help please. The mechano will see something he familiar with, the engine gets fixed and you're on your way again. If you already have reservations about putting down a deposit, what is it going to be when you actually need parts for your engine? I mean I can understand the factory's position by trying to generate a cashflow, but it doesn't look good if some of their machines break down or something alike. If they only sell production slots now, how long before they have time to do a couple of runs of spares? I know this may not be the most optimistic approach to something like this, I have been running a repair shop specialising in repair of homebuilts, but the most frequent customers are those with alternative engines, composite designs etc. ________________________________________________________________________________
Date: Mar 18, 2007
RAS, Your well reasoned and considered argument for stasis is logical, but logic and common sense is only a small part of the decision equation. Progress, improvements and advancements occur only because individuals, against all good logic and common sense decide they want to try the newest, greatest, fastest, shiniest, coolest. In making that decision we already know there are going to be a few "Affordable Turbines" in the lot, but that's the price of progress. Some are willing to risk their time, effort and money on the oft chance that the newest, latest and greatest is just that. But for the willingness to try different things, we would all be driving American-built cars that were good for 50,000 mile (maybe) before they were a pile of junk (remember the '70s and '80s?). Now, American-built cars, after responding to foreign competition, are good for 100,000 before they need a tune-up. This came about simply because a large number of people said the status quo is not good enough. Progress comes in fits and start and is rarely a pretty process, but it never occurs unless people are willing to buck the system and take chances. In the end, its probably a cultural thing. It's why in the U.S. we have many breakthroughs, and many abject failures...but always a subset of people willing to try the new and unknown. Now, with that said, I would hesistate to put down a $5,000 deposit on an engine of an unknown level of development and uncertain future, unless I gave the money a proper going away party and with expectation that we are unlikely to meet up again in the future. Chuck Jensen Note: New Phone Extension -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RAS Sent: Sunday, March 18, 2007 4:51 AM Subject: Re: RV-List: DeltaHawk Engine Hi guys, Apologies to butt in on this topic. I must say I live across the Atlantic, we don't have as much freedom here to change what we want on our aeroplanes due to the need of some authoritive figures wanting to tell what you can or can't do. I have been on this list for quite a few years now and have seen many 'new' engines come and go or be a major disappoinment, either by the lack of permance or their integration with the RV airframe. Think the Thielert Diesels, conversion cost some $20K over new Lyco price and cut in performance to save a $$ on fuel. Maybe their new offering is better? Can some try to explain what is so attractive to an engine that has an unknown service history, unknown performance and to top all, is often more costlier when the full installation is completed? I personally don't see much sense in for example the Superior engines, the difference with genuine Lycoming is very small and a full service record has still to be established. I know their parts are authorized to be used on cert Lycomings, but that's still different in my book to an entire engine built of those parts. Part of this doubt may be caused by the way parts are sold and kept here in Europe, but seeing the RV is pretty much a travelling aeroplane, it make sense to me to stick to something 'standard' as Murphy says your aeroplane will only break away from base. What better than being able to walk straight to the nearest mechano and say: my Lyco has packed in , help please. The mechano will see something he familiar with, the engine gets fixed and you're on your way again. If you already have reservations about putting down a deposit, what is it going to be when you actually need parts for your engine? I mean I can understand the factory's position by trying to generate a cashflow, but it doesn't look good if some of their machines break down or something alike. If they only sell production slots now, how long before they have time to do a couple of runs of spares? I know this may not be the most optimistic approach to something like this, I have been running a repair shop specialising in repair of homebuilts, but the most frequent customers are those with alternative engines, composite designs etc. ________________________________________________________________________________
Date: Mar 18, 2007
Marcel's suggested method also worked very well for me. I ran the tubing from the reservoir back into the gallon container the brake fluid came in which allow me to push sufficient fluid thru the lines to carry some bubbles out of the high points in the lines between the left and right pedals. Note: I used a one gallon garden sprayer for my pressure tank. When I first tried this, I used the garden sprayer pump to pressurize it. Not a good idea! The bottom of the pump was below the fluid level in the tank and this put small bubbles into the fluid that showed up as large bubbles after a period of time. I then drilled a hole in the top of the garden sprayer tank for an air fitting. (a filler valve like on an inner tube but with pipe treads on the other end.) I sealed the air fitting to the plastic tank with Super Glue. The pressure tank was then pressurized with an external source. Put in about 10 pounds or so. Enough to get the fluid moving sufficiently fast to move the air bubbles to the reservoir and out to the catch can. Dale ----- Original Message ----- From: "RAS" <deruiteraircraftservices(at)btinternet.com> Sent: Sunday, March 18, 2007 4:32 AM Subject: Re: RV-List: Bleeding Brakes > > > Hi Andy, > > I used a pressure tank, it holds about a gallon of brake fluid, use the > pump to bring the vessel under pressure, attach the hose to the > bleednipple on the caliper, open the nipple about a turn and open the > valve. it shoots the brakefluid straight into the system and out of the > fluid resevoir if you're not careful. You'll find a -4 fitting will screw > into your brake fluid resevoir, a bit of alu tubing and a jar at the > bottom if you're not keen on cleaning spilt brake fluid. Takes about five > minutes this way, and you can do it alone. > > Marcel > ----- Original Message ----- > From: "Andy Gold" <andygold(at)rkymtnhi.com> > To: > Sent: Saturday, March 17, 2007 10:59 PM > Subject: RV-List: Bleeding Brakes > > >> >> Where can I find step by step instructions on how to bleed the brakes. >> >> When I built the plane 10 years ago I had help with this from an A&P >> friend and most of what I remember was that it was a big mess. I found a >> leaky wheel cylinder today which means a new set of O-rings and an >> afternoon of fun. Having a little less fun than the first time would be >> a good thing. >> >> Then someone said I'll have to open up the master cylinders while I'm >> doing this, but I don't recall that. I think I remember bleeding >> straight up into the reservoir. >> >> Can anyone help me refresh my memory? >> >> Thanks, >> Andy >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: still waiting on Bluemountain
Date: Mar 18, 2007
Message I'm still waiting on my 2 Blue Mountain G4's it will be almost 5 months since I ordered them if I get them in the next week or so. And I keep hearing the same thing from them. The problem with the temp sensors caused a back log blah blah blah. The give me an est. shipping week then when that time come they give another and so on. How long has anybody else been waiting? Maybe I should have gone with the Dynon. Any problems on their deliveries. Paul Rice RV8 almost ready to fly ________________________________________________________________________________
Subject: Fittings
Date: Mar 18, 2007
Looking for oil pressure line fitting that screws into the engine crankcase with restricted orifice. Does anyone know who carries them? Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Mar 18, 2007
Subject: Re: Fittings
Cappy, maybe someone makes them ready-to-go; I'm pretty sure I fabbed one from a fitting plugged with solder or JB-weld and drilled out #60. Maybe I squeezed a rivet in there and then drilled it out...? It's been 10 years. Re-doing stuff on your plane? I'm due for new hoses FWF myself. While I'm at it, I'll do the stainless steel towel bar firewall feed-through for all the cables and wires. It's going to be a busy spring, I can tell already :-) -Stormy > Looking for oil pressure line fitting that screws into the engine crankcase > with restricted orifice. Does anyone know who carries them? > > Steve Glasgow-Cappy > N123SG RV-8 > Cappy's Toy > > ________________________________________________________________________________
Date: Mar 18, 2007
Subject: Re: still waiting on Bluemountain
Paul Rice wrote: > Message I'm still waiting on my 2 Blue Mountain G4's it will be > almost 5 months since I ordered them if I get them in the next week > or so. And I keep hearing the same thing from them. The problem with > the temp sensors caused a back log blah blah blah. The give me an > est. shipping week then when that time come they give another and so > on. How long has anybody else been waiting? Maybe I should have > gone with the Dynon. Any problems on their deliveries. > > Paul Rice RV8 almost ready to fly Paul, as far as I know Dynon ships from stock, but your best bet is to call them to ask about delivery. My experience with Dynon has been reliable and truthful. Sam Buchanan ________________________________________________________________________________
Date: Mar 18, 2007
Van's has it, item number VA-128. Paul > Looking for oil pressure line fitting that screws into the engine crankcase > with restricted orifice. Does anyone know who carries them? > > Steve Glasgow-Cappy > N123SG RV-8 > Cappy's Toy > > > > > > http://www.matronics.com/Navigator?RV-List ator?RV-List> ________________________________________________________________________________
Date: Mar 18, 2007
Gee, I thought we alternative engine guys were the only one's who had to improvise stuff like that. :-) -- David Leonard Turbo Rotary RV-6 N4VY My websites at:
http://members.aol.com/_ht_a/rotaryroster/index.html http://members.aol.com/_ht_a/vp4skydoc/index.html http://leonardiniraq.blogspot.com On 3/18/07, Bill Boyd wrote: > > > Cappy, maybe someone makes them ready-to-go; I'm pretty sure I fabbed > one from a fitting plugged with solder or JB-weld and drilled out #60. > Maybe I squeezed a rivet in there and then drilled it out...? It's > been 10 years. > > Re-doing stuff on your plane? I'm due for new hoses FWF myself. > While I'm at it, I'll do the stainless steel towel bar firewall > feed-through for all the cables and wires. > > It's going to be a busy spring, I can tell already :-) > > -Stormy > > > > Looking for oil pressure line fitting that screws into the engine > crankcase > > with restricted orifice. Does anyone know who carries them? > > > > Steve Glasgow-Cappy > > N123SG RV-8 > > Cappy's Toy > > > > > > > > > > ________________________________________________________________________________
Date: Mar 18, 2007
From: Jeff Dowling <shempdowling2(at)earthlink.net>
Subject: Re: non impulse coupling mag drive gear needed for elec ignition
OK, found the receipt for the new one I purchased. Its a slick, model 4371. Not sure what the other one is yet but I assume the same model. Jeff Oldsfolks(at)aol.com wrote: > You need to tell us brand and model number of the magneto. > I have some parts in a drawer . > > Bob Olds > oldsfolks(at)aol.com > > > ------------------------------------------------------------------------ > AOL now offers free email to everyone. Find out more about what's free > from AOL at *AOL.com* <http://www.aol.com?ncid=AOLAOF00020000000339>. > * > > > * ________________________________________________________________________________
Subject: Re: RV7-List: Z-bracket height (again) - Help!
Date: Mar 18, 2007
Check the aft flange bend angle on the fuel tank ribs. If it's not 90 degrees, then it pushes the baffle "aft" and causes the problem you're seeing. Also make sure the fuel tank ribs are well seated inside the tank skin. That means all flanges on all tank ribs are square, and the "flats" around the nose aren't causing "high spots" that prevent the nose of the rib from seating all the way fwd. )_( Dan RV-7 N714D (1230 hours) www.rvproject.com / www.weathermeister.com / www.weighmyplane.com ----- Original Message ----- From: "Don Hall" <dhall(at)donka.net> Sent: Sunday, March 18, 2007 9:03 AM Subject: Re: RV7-List: Z-bracket height (again) - Help! > --> RV7-List message posted by: Don Hall > > Modifying the zbracket is crazy talk. :) Van's isn't perfect, but they > get it right more than we do. > > IMO, you should not be concerned about that small of a gap just yet. The > tank skin is extremely stiff, and by the time you rivet the structure > together, it should tighten up enough to close that gap. > > Even so, I offer the following suggestions for you at these stage. > - cleco every hole. > - maybe drill out the screw holes and try putting in screws. > > > On Mar 18, 2007, at 1:50 AM, Charlie England wrote: > >> --> RV7-List message posted by: Charlie England >> >> >> Michael D. Cencula wrote: >>> --> RV7-List message posted by: "Michael D. Cencula" >>> >>> >>>> Have you tried pulling the tank down (back) on the spar with >>>> ratcheting >>>> strap clamps? (You'll need a spacer at the rear spar to keep from >>>> bending the trailing edge skin.) Run the straps directly over ribs; I >>>> think I put them one bay in from each end of the tank. >>>> >>>> With the ribs, it's easy for slight flange irregularities to add up & >>>> push the back baffle back. >>>> >>>> Have you checked to see if the back baffle is totally flat (not bowed >>>> to >>>> the rear) when it's assembled to the ribs & skin? If it's not, that >>>> would be another indicator that the flanges are pushing the baffle >>>> back. >>>> >>>> Charlie >>> Charlie, >>> Thanks for the response. Indeed I have tried pulling it down with >>> ratcheting strap clamps. I can close the gap up by doing that, but >>> doing so flexes the baffle. Is it normal to need to pull the tank >>> towards the spar before driving the screws into the platenuts? >>> With no clamps on, the baffle is mostly straight, but the center is >>> bowed *up* a little. I believe that bowing is because the weight of >>> the tank is resting on the Z bracket. >>> Mike >> >> Are the tank holes/spar holes offset by the same amount as the skin gap? >> (I've 'over-prepped' an edge or two & that could leave a gap at the >> point in question.) >> >> Is the gap between the tank skin & wing skin perfectly consistent along >> the entire length & on both top & bottom of the wing? If not: >> >> Is the spar perfectly straight? (Jack under middle of trailing edge spar >> & tweak it up/down to see if the tank will fall into place with a little >> help from the straps.) >> >> Is there any twist in the spar? >> >> If you haven't riveted on the outboard leading edge, have you tried the >> tank without the outboard leading edge in place? >> >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 18, 2007
If you're thinking Dynon, also take a look at Rob's gear. http://www.advanced-flight-systems.com/ -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan Sent: Sunday, March 18, 2007 2:39 PM Subject: Re: RV-List: still waiting on Bluemountain Paul Rice wrote: > Message I'm still waiting on my 2 Blue Mountain G4's it will be > almost 5 months since I ordered them if I get them in the next week or > so. And I keep hearing the same thing from them. The problem with the > temp sensors caused a back log blah blah blah. The give me an est. > shipping week then when that time come they give another and so on. > How long has anybody else been waiting? Maybe I should have gone with > the Dynon. Any problems on their deliveries. > > Paul Rice RV8 almost ready to fly Paul, as far as I know Dynon ships from stock, but your best bet is to call them to ask about delivery. My experience with Dynon has been reliable and truthful. Sam Buchanan ________________________________________________________________________________
Date: Mar 19, 2007
Subject: Wailing brakes ...
Anyone got a cure or wailing brakes ? Particularly when I pull up to a st op for the run-up ... scares the Bejesus out of the passengers. The calip ers are moving free on the pins, there's plenty of time on the pads ... t hey should have seated by now ... Infusion of witchhazel ? Three Hail Mar ys and a splash of Holy water ? Replace the pads ? Get over it and tell t he passenger its the "super-turbo" winding up ? Seriously, any suggestions greatly appreciated ... g ________________________________________________________________________________
Date: Mar 19, 2007
Subject: Re: Wailing brakes ...
On 03/19 4:25, Gerry Filby wrote: > Anyone got a cure or wailing brakes ? Particularly when I pull up to a > stop for the run-up ... scares the Bejesus out of the passengers. The > calipers are moving free on the pins, there's plenty of time on the pads > ... they should have seated by now ... Infusion of witchhazel ? Three > Hail Marys and a splash of Holy water ? Replace the pads ? Get over it > and tell the passenger its the "super-turbo" winding up ? Good subject. I've just experienced this on the last couple of flights, only on the left brake. I'm thinking that some of my fiberglass powder got in there while I was sanding the wheelpants. I'll be pulling it all apart and giving it a thorough cleaning this week. Not sure if it will help... -- Walter Tondu http://www.rv7-a.com - Flying! http://www.evorocket.com - Building ________________________________________________________________________________
Date: Mar 19, 2007
See the archives. http://www.matronics.com/searching/getmsg_script.cgi?INDEX=161435118?KEYS=brake_noise_?LISTNAME=RV?HITNUMBER=2?SERIAL=22484826031?SHOWBUTTONS=YES I had the same problem. Removing all stress form the line fixed it. I remember one guy that used hose and had the problem till he replaced the hose with aluminum line. It was in the RVAtor 7 or 8 years ago. Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 1,986 + Flying Hours So. CA, USA ----Original Message Follows---- From: "Gerry Filby" <gerf(at)gerf.com> Subject: RV-List: Wailing brakes ... Date: Mon, 19 Mar 2007 04:25:56 +0000 Anyone got a cure or wailing brakes ? Particularly when I pull up to a stop for the run-up ... scares the Bejesus out of the passengers. The calipers are moving free on the pins, there's plenty of time on the pads ... they should have seated by now ... Infusion of witchhazel ? Three Hail Marys and a splash of Holy water ? Replace the pads ? Get over it and tell the passenger its the "super-turbo" winding up ? Seriously, any suggestions greatly appreciated ... g _________________________________________________________________ Mortgage refinance is hot 1) Rates near 30-yr lows 2) Good credit get intro-rate 4.625%* https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h2a5f&s=4056&p=5117&disc=y&vers=743 ________________________________________________________________________________
Subject: RE: List: Fittings
Date: Mar 19, 2007
Hi Steve- I think I might have gotten mine from Lyc themselves, but I don't recall for sure. I know Earl's doesn't carry them. IIRC, there should also be a restrictor in the vent line for the mechanical fuel pump. >Looking for oil pressure line fitting that screws into the engine crankcase >with restricted orifice. Does anyone know who carries them? glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: DeltaHawk engine decision
Date: Mar 19, 2007
Hello everyone; Just a short note thank you all for your wise and sober counsel and to advise you of my decision not to send Deltahawk a deposit. I will get on with my building and hopefully have them get on with the development and certification of their fine looking engines. Perhaps I am a bit naive thinking this is " THE " next best engine but as a purpose built a/c engine burning jet fuel and with all the other things going for it I'll maintain my enthusiasm until they prove me wrong. For those of you interested in the Deltahawk I finally discovered Doug Reeves www.VansAirForce.net alternative engine section this weekend and there is a lengthy discussion on Deltahawk and other diesels. I was quite surprised that no one else chimed in with the claim of having been approached about a deposit but then perhaps there just isn't the interest I thought there would be. As Mickey Coggins said " most pilots are conservative, sceptical and risk adverse ", maybe he's right and probably that's the way it should be. Thanks again and with spring just a day or two away we can start thinking summer flying. Now how am I going to make my 8 into a coupe? Ralph in Delta B.C. RV8 empennage ________________________________________________________________________________
Date: Mar 19, 2007
Andy, what I do is once the caliper is ready to go back on I "pre-bleed" the caliper by filling it with fluid so you are not pushing a bunch of air through the brake lines and master cylinders. I also don't drain the fluid out of of the lines; when removing the caliper I stop the line up with an AN plug. If you do it right, the brake will not need to be bled. If you're quick about disconnecting/reattaching the brake line to the caliper you will only get a few drops on the floor by doing it this way. Regards, Bob Japundza RV-6 flying F1 under const. On 3/17/07, Andy Gold wrote: > > > Where can I find step by step instructions on how to bleed the brakes. > > When I built the plane 10 years ago I had help with this from an A&P > friend > and most of what I remember was that it was a big mess. I found a leaky > wheel cylinder today which means a new set of O-rings and an afternoon of > fun. Having a little less fun than the first time would be a good thing. > > Then someone said I'll have to open up the master cylinders while I'm > doing > this, but I don't recall that. I think I remember bleeding straight up > into > the reservoir. > > Can anyone help me refresh my memory? > > Thanks, > Andy > > ________________________________________________________________________________
Subject: Gamut Services- Carbon Fiber Canopy
Date: Mar 19, 2007
Buyer Beware! I regretfully am posting this information to warn other builders of the fraud committed by Gamut Services and it's owner Charles Wilhite. Today I have contacted an Attorney and initiated legal action against Mr. Wilhite for failure to deliver a carbon fiber canopy that I paid for in full nine months ago. He has ignored all request for a full refund and has given me nothing but empty promises in return. He has gone into hiding, shutting down his web site, won't answer his telephone or emails. Myself and five others I know of, out of possibly 13 sales, have been ripped off to the tune of thousands of dollars and are starting a class action law suit against him, to recover our losses. If you to have been defrauded by Gamut Services and wish to join us, then contact me for details. This kind of business dishonesty cannot be tolerated in the aircraft building community and my warnings to other builders will hopefully prevent future victims to this fraud. Ron Oldgeezer01(at)msn.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=101753#101753 ________________________________________________________________________________
Date: Mar 19, 2007
I will admit up front I am an unabashed BMA fan and happy owner of 4 BMA EFis's and 2 autopilots. With one exception my experience with BMA has been pleasant and rewarding. I have over 600 hrs flying behind BMA, much of it IFR. The bottom line is the BMA units do what I want them to at a great price. The Launch of their Gen 4 products was bungled, egeregious, and inexcusable. Delivery was 8 months after I expected it. The units are now installed and doing everything I ask them to. There are some bugs and they do not do everything they are advertised to do but these bugs are trapidly dissappearing. I think rather than hearsay you should spend your EFIS dollars on a unit that fits your budget and does those things you think essential. If your only goals are fast delivery and out of the box plug and play then BMA is not for you. I know many happy Dynon, BMA, and Grand Rapids owners. The common theme is the units do what they expect them to. I also know some unhappy owners of most manufacturers. The common theme is the units do not do what they need to fulfill their flying requirements. Before you buy any unit talk to, and if possible fly with an owner of that unit. Before you listen to any advice about one company or another ask the giver of opinion if they own one or have flown behind one and if so how much time do they have using or installing them. If their answer starts with "well I know sombody, or I heard that, or I read" then you need to seriously discount their opinion. Bottom line is they are all good units, the question you need answered is will they do what I want done at a price I can afford. This is a big decision that you will have to live with the entire time you own your plane. If you are unhappy with your avionics you will be unhappy with your airplane. Decide based on fact and need, not rumor and innuendo. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Some people live an entire lifetime and wonder if they have made a difference to the world, but the Marines dont have that problem. - Ronald Reagan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=101768#101768 ________________________________________________________________________________
Date: Mar 20, 2007
> But I > *am* trying to figure out why, more than -- anecdotally speaking -- any > other company, the message that started this thread appears quite so often. > It appears so often because they absolutely and unequivocally blew the start up and launch of a new product line. Promised way too much too soon. This was aggravated by the fact that instead of backing up and taking a look at what it would take to fix the problem they kept wishing and hoping that tomorrow would bring the cure. Their entire problem could have been avoided if early on they would have fessed up to major problems, offered refunds to everyone who had made a deposit and made the statement "we are 8 months from delivery" But they didn't, and now suffer from the bad pR of those who were delayed by this, and those who were shopping at the time and watched the whole debacle unfold much of it on their own chatlist. A second reason is their early models were highly configurable by the builder and configuration was far too complex for many of the builders to deal with.They required a great deal of time to install, calibrate, and debug wheras the competition was out of the box, plug it in and go. This is what the generation 4 product was intended to do. Unfortunately as noted the launch of the product was a total disaster. I do however believe most of that is behind them. The retro look of steam guages isn't all bad for other reasons also. I think it was ironflight who had a great post on VAF today about backup to glass panels. I wouldn't let the unknown put you off on glass panels completely. At first I had trouble getting used to them and thought I had a huge mistake, but now when I fly a plane without one I really miss the glass. No matter whos system you install once you get used to it you arwe gonna love it. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Some people live an entire lifetime and wonder if they have made a difference to the world, but the Marines dont have that problem. - Ronald Reagan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=101860#101860 ________________________________________________________________________________
From: "Brian Meyette" <brianpublic2(at)starband.net>
Date: Mar 20, 2007
Do you use the BMA autopilot? What do you think of it? brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of N395V Sent: Monday, March 19, 2007 7:34 PM Subject: RV-List: Re: still waiting on Bluemountain I will admit up front I am an unabashed BMA fan and happy owner of 4 BMA EFis's and 2 autopilots. With one exception my experience with BMA has been pleasant and rewarding. I have over 600 hrs flying behind BMA, much of it IFR. The bottom line is the BMA units do what I want them to at a great price. The Launch of their Gen 4 products was bungled, egeregious, and inexcusable. Delivery was 8 months after I expected it. The units are now installed and doing everything I ask them to. There are some bugs and they do not do everything they are advertised to do but these bugs are trapidly dissappearing. I think rather than hearsay you should spend your EFIS dollars on a unit that fits your budget and does those things you think essential. If your only goals are fast delivery and out of the box plug and play then BMA is not for you. I know many happy Dynon, BMA, and Grand Rapids owners. The common theme is the units do what they expect them to. I also know some unhappy owners of most manufacturers. The common theme is the units do not do what they need to fulfill their flying requirements. Before you buy any unit talk to, and if possible fly with an owner of that unit. Before you listen to any advice about one company or another ask the giver of opinion if they own one or have flown behind one and if so how much time do they have using or installing them. If their answer starts with "well I know sombody, or I heard that, or I read" then you need to seriously discount their opinion. Bottom line is they are all good units, the question you need answered is will they do what I want done at a price I can afford. This is a big decision that you will have to live with the entire time you own your plane. If you are unhappy with your avionics you will be unhappy with your airplane. Decide based on fact and need, not rumor and innuendo. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Some people live an entire lifetime and wonder if they have made a difference to the world, but the Marines don(tm)t have that problem. - Ronald Reagan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=101768#101768 -- 11:49 AM -- 8:07 AM ________________________________________________________________________________
Date: Mar 20, 2007
N395V wrote: > > >> But I *am* trying to figure out why, more than -- anecdotally >> speaking -- any other company, the message that started this thread >> appears quite so often. >> > > > It appears so often because they absolutely and unequivocally blew > the start up and launch of a new product line. Promised way too much > too soon. This was aggravated by the fact that instead of backing up > and taking a look at what it would take to fix the problem they kept > wishing and hoping that tomorrow would bring the cure. This business ethic has been in place since January 2002. I ordered an EFIS/Lite after being told the units were on the shelf ready to ship (their website stated the same). Turns out the code for the device had not even been written yet. Seven months later I finally received product (was supposedly production unit but it turns out I was the alpha tester!? How would you feel if you were sold an EFIS that had never been flown in a plane!!) and after going through three units that were totally inop I cut all ties with BMA. I am really hesitant to post this type of info but this vendor has an established track record of promising far more than can be delivered in the promised time frame. It is unfortunate because the potential of the product deserves much better business standards. Sam Buchanan ________________________________________________________________________________
Date: Mar 20, 2007
bmeyette wrote: > Do you use the BMA autopilot? What do you think of it? > brian Yep, I like it for my purposes it holds altitude well and follows a course. I use it for when I am looking at charts or otherwise occupied with a task in the cockpit. It is low end and inexpensive (relatively) it does not interact with the trim system so you have to put the plane where you want it ,trim then engage. It is too aggressive when intercepting radials localizers etc and usually overshoots and then starts chasing the needle. I would not recommend it for IFR and coupled approaches. It responds well to the BMA output but there are mixed reports about getting it to accept external nav signals esp the Garmin 430/530. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Some people live an entire lifetime and wonder if they have made a difference to the world, but the Marines dont have that problem. - Ronald Reagan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=101890#101890 ________________________________________________________________________________
Subject: Looking for Engine Primer
Date: Mar 20, 2007
Looking for engine primer - Kohler, or Essex 'push-pull' type for use on carbureted O-360. Thanks! Don Duke swift(at)fuse.net Hm: 513.321.4745 ________________________________________________________________________________
Date: Mar 20, 2007
Why not use the electric setup that Van's sells? I love it. I put a push button on my panel; master on, boost on, push button for 1..2..3. start engine. Perfect. Just a thought Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Don Duke Sent: Tuesday, March 20, 2007 10:06 AM Subject: RV-List: Looking for Engine Primer Looking for engine primer - Kohler, or Essex 'push-pull' type for use on carbureted O-360. Thanks! Don Duke swift(at)fuse.net Hm: 513.321.4745 ________________________________________________________________________________
Date: Mar 20, 2007
Subject: Re: Looking for Engine Primer
I've started many times in the cold in my RV-6 and never have used the primer. Two shots of the throttle while the engine is cranking does the trick every time. If I were doing it over I wouldn't put a primer system in. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Date: Mar 20, 2007
>>Why not use the electric setup that Van's sells? I love it. I put a push >>button on my panel; master on, boost on, push button for 1..2..3. start >>engine. Perfect.<< I have that set up, except that I used a momentary toggle switch for triggering the primer valve. I installed a T fitting downline from the boost pump that's located on the firewall. Yeah, I chose to not install the pump inside the cabin. One exit from the T goes to the primer valve. The other goes to the mechanical pump. I' ve been using that setup since 1999, installed it on a friend's RV-9A, and plan on doing the same thing for my RV-7A, if I ever get that far. :-) Jim Sears in KY RV-6A N198JS (Scooter) ________________________________________________________________________________
Subject: RV-4 First flight
Date: Mar 20, 2007
Jerry, CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A >From: "Jerry Isler" <jlisler(at)alltel.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: RV-4 First flight >Date: Mon, 12 Mar 2007 23:12:48 -0400 > >After 12 years of on and off construction, RV-4 N455J is officially a >flyable airplane. > >Jerry Isler >Donalsonville, GA >RV-4 N455J - Flying _________________________________________________________________ i'm making a difference.Make every IM count for the cause of your choice. Join Now. ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Mar 20, 2007
Bob, I put an electric primer in that primes all 4 cylinders and agree with you. I have never needed it in sunny tropical Ohio!! Waste of time and money!!!!!! Tom in Ohio-RV6-A ----- Original Message ----- From: Bob J. To: rv-list(at)matronics.com Sent: Tuesday, March 20, 2007 2:57 PM Subject: Re: RV-List: Looking for Engine Primer I've started many times in the cold in my RV-6 and never have used the primer. Two shots of the throttle while the engine is cranking does the trick every time. If I were doing it over I wouldn't put a primer system in. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Subject: FS: RV 6/8 Emp Construction video - WANTED: RV-9 Emp Video
Date: Mar 20, 2007
I have the Orndorff RV-6/8 Empennage videos which I have transferred to a single DVD as well. It is a very nice job with menus, scene selection, a case and label. The videos and the DVD go together for $20. I am looking for the -9 Empennage construction video, if anyone is done with theirs and doesn't mind selling that would be great! Thanks, Brandon. B_rigio(at)hotmail.com ________________________________________________________________________________
Subject: Hartzell Blended Airfoil Prop
Date: Mar 20, 2007
I am interested in feedback from readers that have converted from the old style (C2YK-FB/F7666) to the Blended airfoil prop. I would like to know if it reduced vibrations. This will help me decide or upgrade or not. John Henley, RV7, IO-360, 500 hours _________________________________________________________________ i'm making a difference.Make every IM count for the cause of your choice. Join Now. ________________________________________________________________________________
Subject: Superior XP O-320 vs. 9A Cowl Interference - The End
Date: Mar 21, 2007
From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com>
I've written about my efforts to get Superior to provide a shorter carb to eliminate the interference with the 9A cowl. Here's the final outcome. Superior tested a shorter carb on two separate occasions and was unable to get the test results within their specifications. Rather than wait for another carb to be test, I elected to follow the advice of some on this forum and purchase a scoop for an O-360 engine. Superior has offered to pay for the scoop and is very apologetic. Apparently, they've always used the same carb on their engines and hadn't experienced a problem with fit until we tried putting them into the 9. I've suggested to them that they notify all purchasers of the O-320 to inform them that they will need the O-360 cowl. It is my understanding that Superior will continue testing carburetors in hopes of finding an acceptable substitute. I received the scoop yesterday and bonded it to the cowl. The fit and finish is very good, and the additional space should be more than adequate to accommodate the FAB. As a side note, Aerosport Power assembles the same engine with the shorter carb. I can only speculate what this means. ________________________________________________________________________________
Date: Mar 21, 2007
Subject: Any RV-9s near middle Tennessee?
Hello all. I'm very close to pulling the trigger on an RV-9A for my second build project (a Sonex being the first). Just curious if there are any -9 builders and/or flyers in either middle TN or south central KY? I know Bob by Hestor is right here in Hoptown with his -7. (Bobby - I want to come up with Robert and Doug sometime to check out your -7!)=0A=0AThanks,=0A=0ARick Spriggle=0AClarksville, TN ________________________________________________________________________________
Date: Mar 21, 2007
Subject: RV-9s near middle Tennessee?
Rick, There are several "9's" in the area. I know of one (Bob Perkins) in Gallatin TN, two around exit 24 on I 24 (Jerry Vanetta and a friend). I have visited Jerry at his house and he has his airplane in his hanger on his property. His home is with several other airplane people along side the grass strip. A nice place. I'm building a "9-A" and I will be retiring in the Springfield Tn area in about 2 years. I just riveted my front top skin on last night. I'm doing a QB version Great airplane. Are you coming to Sun-N-Fun this April? A great time to look over the many variations of the "9". There will be a "9" there that is trying to qualify as a LSA. It will have the O-235 and a basic VFR set-up. What a great idea! Jim ________________________________________________________________________________
Date: Mar 21, 2007
Subject: Re: Hartzell Blended Airfoil Prop
You will pick up 3-4 mph top speed. Is that not enough? Vibration comes for many things, old engine mounts, mass balance in engine (crank, rods, pistons, accessory section), power imbalance between cyl (one making more power), Prop or spinner imbalance. Also baffles or controls or any thing that can transfer the engine vibrations to the cowl, engine mount or fire wall will increase the vibration in the cockpit. Cables, hoses, wire bundles can all do that if too short or tight. If you have vibration because you prop is out of balance, than yes you will be smoother, but the real JOY of the new prop is the incredible efficiency. Hartzell MADE the BA prop for YOU, for the RV-7. I suggest you get Lord engine mounts (part J-9613-4). The cheap ones Van sells suck. Also the BA prop is a 2000 hr TBO and no AD's or SB prop. Vibration? May be, but that is not a reason to change to the BA. The BA is a way better prop for the RV. My suggestion is use your C2YK prop as long as you can, sell when due for overhaul/inspection than get the BA. If you plan on keeping the RV7 for say the next 20 years than get the new prop. It will pay for itself in lower maintenance and better speed. Too bad the price just took a jump I noticed in Vans' catalog. Hartzell REALLY wants you to convert becasue the new prop has no issues. You may get $1500-$2000 for your old prop, may be $2,500-$3,000 if low time late model? The new prop is about $6,000. If you have $4000 burning a hole in your pocket than it may be a good up-grade. Do you plan on flying into gravel and mountain strips this year. May be you should explore first than get the new prop? George >From: "JOHN HENLEY" <rv7plt(at)hotmail.com> >Subject: RV-List: Hartzell Blended Airfoil Prop >I am interested in feedback from readers that have converted >from the old style (C2YK-FB/F7666) to the Blended airfoil prop. >I would like to know if it reduced vibrations. This will help me >decide or upgrade or not. >John Henley, RV7, IO-360, 500 hours --------------------------------- Be a PS3 game guru. Get your game face on with the latest PS3 news and previews at Yahoo! Games. ________________________________________________________________________________
Date: Mar 21, 2007
Switching to the BA prop should make no difference in vibration if the original prop is properly balanced. As far as speed goes, I asked this very same question to one of the engineers at Hartzell about my Rocket prop and his response was "The differences are small and I would not swap props simply to get the additional performance, its not worth the cost in my opinion." The difference between the 8475D-4 prop and the 8068D BA blades suitable for a Rocket was four pounds difference in thrust. The non-blended airfoil props are already very efficient. If you wanted to reduce vibration I would consider a three-blade MT prop. Regards, Bob Japundza RV-6 Flying F1 under const. On 3/20/07, JOHN HENLEY wrote: > > > I am interested in feedback from readers that have converted from the old > style (C2YK-FB/F7666) to the Blended airfoil prop. I would like to know if > it reduced vibrations. This will help me decide or upgrade or not. > > John Henley, RV7, IO-360, 500 hours > > _________________________________________________________________ > i'm making a difference.Make every IM count for the cause of your choice. > Join Now. > > ________________________________________________________________________________
Date: Mar 21, 2007
From: "smitty(at)smittysrv.com" <smitty(at)smittysrv.com>
Date: Mar 21, 2007
Subject: Aircraft Painting 101 Video
I just finished watching the Sam Jones video on Aircraft Painting 101 and was making notes. There is a part where he talks about painting on graphics over the base coat using Fine Line tape, but he doesn't say how long to wait after putting on the base coat to starting on the graphics (ie stripes and stuff). How long should you wait before adding color graphics or stripes after putting on the base coat? Have a goodun! Smitty http://SmittysRV.com -------------------------------------------------------------------- mail2web LIVE Free email based on Microsoft Exchange technology - http://link.mail2web.com/LIVE ________________________________________________________________________________
Date: Mar 21, 2007
The answer is, it depends....... Since temperature and humidity varies, it will be different depending on your circumstances. I've heard horror stories from folks that finished up in the afternoon and came back the next morning to finish trim. The tape left visible marks because the paint wasn't totally cured. I personally would wait 24-48 hours depending on weather conditions. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of smitty(at)smittysrv.com Sent: Wednesday, March 21, 2007 5:02 PM Subject: RV-List: Aircraft Painting 101 Video I just finished watching the Sam Jones video on Aircraft Painting 101 and was making notes. There is a part where he talks about painting on graphics over the base coat using Fine Line tape, but he doesn't say how long to wait after putting on the base coat to starting on the graphics (ie stripes and stuff). How long should you wait before adding color graphics or stripes after putting on the base coat? Have a goodun! Smitty http://SmittysRV.com -------------------------------------------------------------------- mail2web LIVE - Free email based on MicrosoftR Exchange technology - http://link.mail2web.com/LIVE ________________________________________________________________________________
Date: Mar 21, 2007
Subject: NBVC Point Mugu Airshow...
As a reminder... The NBVC (Naval Base Ventura County) Point Mugu (formerly NAS Point Mugu, CA) airshow is scheduled Saturday, 31 March 2007 and Sunday, 01 April 2007. Admission is FREE! NBVC Ventura County (KNTD) is located near Oxnard and Camarillo, CA (45 miles NW of LAX). Show normally runs 1000-1600. This year the highlight act is the USAF Demonstration Team... Thunderbirds! Here is a link to the show: http://www.nbvc.navy.mil/airshow07/index.html Enjoy, Jack Lockamy Camarillo, CA USN/NBVC Point Mugu Federal Employee Former RV-7A builder/owner N174JL Current 2003 Cirrus SR20 owner/partner jack.lockamy(at)navy.mil ________________________________________________________________________________
Date: Mar 21, 2007
Subject: Re: Any RV-9s near middle Tennessee?
Sure come on up, I have about 13 hrs. on my 7A. I know someone in Mayfield, KY that has a RV9 tail that he is about ready to start riveting together. Rupert Holmes holmes(at)vci.net Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Rick Spriggle wrote: > Hello all. I'm very close to pulling the trigger on an RV-9A for my > second build project (a Sonex being the first). Just curious if there > are any -9 builders and/or flyers in either middle TN or south central > KY? I know Bobby Hestor is right here in Hoptown with his -7. (Bobby - > I want to come up with Robert and Doug sometime to check out your -7!) > > Thanks, > > Rick Spriggle > Clarksville, TN > > > ________________________________________________________________________________
Subject: Kitlog Pro
Date: Mar 22, 2007
I've been working with Matt Dralle over the last couple days on a problem that impacts all Kitlog Pro users. I am glad to report that he has fixed the problem in which paragraphs are run together. All you have to do is to save the offending pages again and re-upload them to mykitlog.com. Matt was unaware of the issue, but promptly fixed the problem once I gave him the specifics of the issue. It appears that we've already benefited from Matronics purchasing Kitlog Pro. The previous owner was aware of this issue for several months and chose to do nothing. Great support Matt! Bob N410BL - RV-10 N3493R - PA-28 ________________________________________________________________________________
Date: Mar 22, 2007
Subject: Re: Aircraft Painting 101 Video
This depends on the paint. I use Imron 6000 and always wait a day at 77F but your paint will say. Matt "smitty(at)smittysrv.com" wrote: I just finished watching the Sam Jones video on Aircraft Painting 101 and was making notes. There is a part where he talks about painting on graphics over the base coat using Fine Line tape, but he doesn't say how long to wait after putting on the base coat to starting on the graphics (ie stripes and stuff). How long should you wait before adding color graphics or stripes after putting on the base coat? Have a goodun! Smitty http://SmittysRV.com -------------------------------------------------------------------- mail2web LIVE Free email based on Microsoft Exchange technology - http://link.mail2web.com/LIVE --------------------------------- Never miss an email again! Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. ________________________________________________________________________________
From: "Steve Davis" <sdavisengraving(at)comcast.net>
Subject: Re: Kitlog Pro
Date: Mar 22, 2007
Let me be the first to congratulate Matt on his purchase of Kitlog Pro and I know he will do a fine job as he has with everything else he does. I would like to say in the defense of the previous owner that I'm real sure he was aware of the problems and I know for a fact that he would have taken care of them, but other things have been on his mind as of late, maybe leaving two little girls behind to go fight a war in Afghanistan for a year would justify for a real good reason. Paul, we love you brother, will pray everyday for your safe return, you stay safe and get home as quick as you can!! Steve Davis The Panel Pilot www.thepanelpilot.com ----- Original Message ----- From: Bob Leffler To: rv-list(at)matronics.com ; rv10-list(at)matronics.com Sent: Thursday, March 22, 2007 6:05 AM Subject: RV-List: Kitlog Pro I've been working with Matt Dralle over the last couple days on a problem that impacts all Kitlog Pro users. I am glad to report that he has fixed the problem in which paragraphs are run together. All you have to do is to save the offending pages again and re-upload them to mykitlog.com. Matt was unaware of the issue, but promptly fixed the problem once I gave him the specifics of the issue. It appears that we've already benefited from Matronics purchasing Kitlog Pro. The previous owner was aware of this issue for several months and chose to do nothing. Great support Matt! Bob N410BL - RV-10 N3493R - PA-28 ------------------------------------------------------------------------- ----- 3/16/2007 12:12 PM ________________________________________________________________________________
Date: Mar 22, 2007
From: "Robert E. Newhall II" <renewhall2(at)yahoo.com>
Subject: RE: Aircraft Painting 101 Video
BTW, I used the Sam James Aircraft Painting 101 Video and found it very helpful. You can see the results on my flight instruction site here (shameless plug, I know): http://renewhall2.googlepages.com/home I'm finished with the DVD. If anyone would like it, the first $15 takes it (shipping included). (It's $25.95 on Builder's Bookstore). Bob N829RV Boulder, CO Subject: RE: Aircraft Painting 101 Video From: Bob Leffler (rvmail(at)thelefflers.com) Date: Wed Mar 21 - 3:09 PM The answer is, it depends....... Since temperature and humidity varies, it will be different depending on your circumstances. I've heard horror stories from folks that finished up in the afternoon and came back the next morning to finish trim. The tape left visible marks because the paint wasn't totally cured. I personally would wait 24-48 hours depending on weather conditions. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of smitty(at)smittysrv.com Sent: Wednesday, March 21, 2007 5:02 PM Subject: Aircraft Painting 101 Video I just finished watching the Sam Jones video on Aircraft Painting 101 and was making notes. There is a part where he talks about painting on graphics over the base coat using Fine Line tape, but he doesn't say how long to wait after putting on the base coat to starting on the graphics (ie stripes and stuff). How long should you wait before adding color graphics or stripes after putting on the base coat? Have a goodun! Smitty http://SmittysRV.com -------------------------------------------------------------------- mail2web LIVE - Free email based on MicrosoftR Exchange technology - http://link.mail2web.com/LIVE ________________________________________________________________________________
Date: Mar 22, 2007
BTW, I used the Sam James Aircraft Painting 101 Video and found it very helpful. If anyone would like my DVD, the first $15 takes it (shipping included). (It's $25.95 on Builder's Bookstore). You can see the paint results on my flight instruction site here (shameless plug): http://renewhall2.googlepages.com/home Bob -------- Bob Newhall N829RV RV Transition Training Boulder, CO renewhall2.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102306#102306 ________________________________________________________________________________
Date: Mar 22, 2007
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Subject: Re: RE: Aircraft Painting 101 Video
I'll take it... Darrell --- "Robert E. Newhall II" wrote: > II" > > BTW, I used the Sam James Aircraft Painting 101 > Video > and found it very helpful. You can see the results > on > my flight instruction site here (shameless plug, I > know): http://renewhall2.googlepages.com/home > > I'm finished with the DVD. If anyone would like it, > the first $15 takes it (shipping included). (It's > $25.95 on Builder's Bookstore). > > Bob > N829RV > Boulder, CO > > > > > Subject: RE: Aircraft Painting 101 Video > From: Bob Leffler (rvmail(at)thelefflers.com) > Date: Wed Mar 21 - 3:09 PM > > The answer is, it depends....... > > Since temperature and humidity varies, it will be > different depending on > your circumstances. > > I've heard horror stories from folks that finished > up > in the afternoon and > came back the next morning to finish trim. The tape > left visible marks > because the paint wasn't totally cured. > > I personally would wait 24-48 hours depending on > weather conditions. > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On > Behalf > Of > smitty(at)smittysrv.com > Sent: Wednesday, March 21, 2007 5:02 PM > To: rv-list(at)matronics.com > Subject: Aircraft Painting 101 Video > > > I just finished watching the Sam Jones video on > Aircraft Painting 101 and > was making notes. There is a part where he talks > about > painting on graphics > over the base coat using Fine Line tape, but he > doesn't say how long to > wait after putting on the base coat to starting on > the > graphics (ie stripes > and stuff). > > How long should you wait before adding color > graphics > or stripes after > putting on the base coat? > > Have a goodun! > Smitty > http://SmittysRV.com > > > -------------------------------------------------------------------- > mail2web LIVE - Free email based on MicrosoftR > Exchange technology - > http://link.mail2web.com/LIVE > > > > > > browse > Subscriptions page, > FAQ, > > Web Forums! > > > > > Be a PS3 game guru. Get your game face on with the latest PS3 news and previews at Yahoo! Games. http://videogames.yahoo.com/platform?platform=120121 ________________________________________________________________________________
Date: Mar 22, 2007
Subject: Top this if you can.
Yesterday, 03/21/2007, N18XP, RV-6a QB kit #60534 took to the air from Newberg, OR. This was quite the red letter day in other respects also, one that I think other builders are going to have a tough time matching... Not only did my -6a "baby" become an airplane, but another baby was born, our first great-grandchild. Sophie arrived just 3 hours before first flight, and weighed 8 lbs with dark hair and blue eyes. We are so very blessed. N18XP flew flawlessly, with her Superior IO360 and Hartzell 74" blended airfoil prop. The six years spent building were rewarding in every way, and I truly believe I learned something new each one of those days. Thank you Van, for such a great design, and your outstanding crew at Van's, particularly Dale, Gus, and Rob, always very helpful, and Ken Scott who gave me that first "$30,000 Ride" where I was instantly hooked. I'd also like to thank Bob Haan, Dan Benua, Len Kauffman, Frank Sneed and many others from EAA105 along the way for all the help, without which this journey would have been much tougher. Oh, and I better mention the folks online at the "RV-list", "Aeroelectric List" and "Vans AF", LOTS of help there... Now to get those 40 hours flown off... Yah, someone's got to do it!! Jerry Cochran Sherwood, Oregon Find out more about what's free from AOL at http://www.aol.com. ________________________________________________________________________________
Date: Mar 22, 2007
Thanks Robert! I just mailed your check. Darrell --- renewhall2 wrote: > > > BTW, I used the Sam James Aircraft Painting 101 > Video and found it very helpful. If anyone would > like my DVD, the first $15 takes it (shipping > included). (It's $25.95 on Builder's Bookstore). > > You can see the paint results on my flight > instruction site here (shameless plug): > http://renewhall2.googlepages.com/home > > Bob > > -------- > Bob Newhall > N829RV > RV Transition Training > Boulder, CO > renewhall2.googlepages.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=102306#102306 > > > > > > > > > browse > Subscriptions page, > FAQ, > > Web Forums! > > > > > http://answers.yahoo.com/dir/?link=list&sid=396546091 ________________________________________________________________________________
Subject: Re: Top this if you can.
Date: Mar 22, 2007
Jerry, This is hilarious!! I'm back in ATL and looking at the list. Congratulations on a great flight! Can sure agree that you were off in about 4 seconds and she looked good! And now a great grandfather. You must have gotten married when you were 11, ha,ha. Well, I don't need anymore inspiration! Going to get her finished and we'll have two "real" airplanes at Sportsman! Great job! John Porter 80002 ----- Original Message ----- From: Jerry2DT(at)aol.com To: rv-list(at)matronics.com Sent: Thursday, March 22, 2007 12:44 PM Subject: RV-List: Top this if you can. Yesterday, 03/21/2007, N18XP, RV-6a QB kit #60534 took to the air from Newberg, OR. This was quite the red letter day in other respects also, one that I think other builders are going to have a tough time matching... Not only did my -6a "baby" become an airplane, but another baby was born, our first great-grandchild. Sophie arrived just 3 hours before first flight, and weighed 8 lbs with dark hair and blue eyes. We are so very blessed. N18XP flew flawlessly, with her Superior IO360 and Hartzell 74" blended airfoil prop. The six years spent building were rewarding in every way, and I truly believe I learned something new each one of those days. Thank you Van, for such a great design, and your outstanding crew at Van's, particularly Dale, Gus, and Rob, always very helpful, and Ken Scott who gave me that first "$30,000 Ride" where I was instantly hooked. I'd also like to thank Bob Haan, Dan Benua, Len Kauffman, Frank Sneed and many others from EAA105 along the way for all the help, without which this journey would have been much tougher. Oh, and I better mention the folks online at the "RV-list", "Aeroelectric List" and "Vans AF", LOTS of help there... Now to get those 40 hours flown off... Yah, someone's got to do it!! Jerry Cochran Sherwood, Oregon ------------------------------------------------------------------------- ----- AOL.com. ________________________________________________________________________________
Date: Mar 22, 2007
All you need to do is go down the road a little ways to Pleasant View. Jerry Vannatta and John VonDohlen have flying 9A's hangered at Weakleys field. A little further down the road in Joelton Joe Moore is about to launch his 9A. Mine is still a long ways from getting off the ground. Bob Perkinson Hendersonville, TN. RV9 N658RP Reserved If nothing changes Nothing changes Sure come on up, I have about 13 hrs. on my 7A. I know someone in Mayfield, KY that has a RV9 tail that he is about ready to start riveting together. Rupert Holmes holmes(at)vci.net Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Rick Spriggle wrote: Hello all. I'm very close to pulling the trigger on an RV-9A for my second build project (a Sonex being the first). Just curious if there are any -9 builders and/or flyers in either middle TN or south central KY? I know Bobby Hestor is right here in Hoptown with his -7. (Bobby - I want to come up with Robert and Doug sometime to check out your -7!) Thanks, Rick Spriggle Clarksville, TN ________________________________________________________________________________
From: "Richard Suffoletto" <rsuffoletto(at)starstream.net>
Subject: RV owners or EAA members in Asheville, NC
Date: Mar 22, 2007
> > I would like to communicate with any RV owners or EAA members in > Asheville, NC. I have tried through the local EAA chapter but they do not > have a email address listed on their site and any Pvt email addresses on > the site get bounced back. > > Thanks > Richard N623RS > > -- 3/22/2007 > 7:44 AM > > -- 3/22/2007 7:44 AM ________________________________________________________________________________
Date: Mar 22, 2007
Subject: Re: RV owners or EAA members in Asheville, NC
You might try the SERV list. I know there is at least one RV based there. http://bowenaero.com/serv/ -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Richard Suffoletto wrote: > > >> >> I would like to communicate with any RV owners or EAA members in >> Asheville, NC. I have tried through the local EAA chapter but they do >> not >> have a email address listed on their site and any Pvt email addresses on >> the site get bounced back. >> >> Thanks >> Richard N623RS >> >> -- > 3/22/2007 >> 7:44 AM >> >> > -- > 3/22/2007 > 7:44 AM > > ________________________________________________________________________________
Date: Mar 22, 2007
I will be very disappointed if you don't name your plane "Sophie". Congratulations on a great day. Pat Kelley - RV-6A - Panel structure almost ready to go to avionics installer. _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jerry2DT(at)aol.com Sent: Thursday, March 22, 2007 9:45 AM Subject: RV-List: Top this if you can. Yesterday, 03/21/2007, N18XP, RV-6a QB kit #60534 took to the air from Newberg, OR. This was quite the red letter day in other respects also, one that I think other builders are going to have a tough time matching... Not only did my -6a "baby" become an airplane, but another baby was born, our first great-grandchild. Sophie arrived just 3 hours before first flight, and weighed 8 lbs with dark hair and blue eyes. We are so very blessed. N18XP flew flawlessly, with her Superior IO360 and Hartzell 74" blended airfoil prop. The six years spent building were rewarding in every way, and I truly believe I learned something new each one of those days. Thank you Van, for such a great design, and your outstanding crew at Van's, particularly Dale, Gus, and Rob, always very helpful, and Ken Scott who gave me that first "$30,000 Ride" where I was instantly hooked. I'd also like to thank Bob Haan, Dan Benua, Len Kauffman, Frank Sneed and many others from EAA105 along the way for all the help, without which this journey would have been much tougher. Oh, and I better mention the folks online at the "RV-list", "Aeroelectric List" and "Vans AF", LOTS of help there... Now to get those 40 hours flown off... Yah, someone's got to do it!! Jerry Cochran Sherwood, Oregon _____ AOL.com. ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Date: Mar 22, 2007
Jerry Congrats.......for both accomplishments.... Frank @ SGU RV7A "NDY" >From: Jerry2DT(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Top this if you can. Date: Thu, 22 Mar 2007 12:44:39 EDT > > >Yesterday, 03/21/2007, N18XP, RV-6a QB kit #60534 took to the air from >Newberg, OR. This was quite the red letter day in other respects also, one >that I >think other builders are going to have a tough time matching... Not only >did >my -6a "baby" become an airplane, but another baby was born, our first >great-grandchild. Sophie arrived just 3 hours before first flight, and >weighed 8 >lbs with dark hair and blue eyes. >We are so very blessed. > >N18XP flew flawlessly, with her Superior IO360 and Hartzell 74" blended >airfoil prop. The six years spent building were rewarding in every way, and >I >truly believe I learned something new each one of those days. >Thank you Van, for such a great design, and your outstanding crew at >Van's, >particularly Dale, Gus, and Rob, always very helpful, and Ken Scott who >gave >me that first "$30,000 Ride" where I was instantly hooked. > >I'd also like to thank Bob Haan, Dan Benua, Len Kauffman, Frank Sneed and >many others from EAA105 along the way for all the help, without which this >journey would have been much tougher. Oh, and I better mention the folks >online >at the "RV-list", "Aeroelectric List" and "Vans AF", LOTS of help there... > >Now to get those 40 hours flown off... Yah, someone's got to do it!! > >Jerry Cochran >Sherwood, Oregon > > > Find out more about what's free from AOL at http://www.aol.com. _________________________________________________________________ Watch free concerts with Pink, Rod Stewart, Oasis and more. Visit MSN Presents today. http://music.msn.com/presents?icid=ncmsnpresentstagline&ocid=T002MSN03A07001 ________________________________________________________________________________
From: "RAS" <deruiteraircraftservices(at)btinternet.com>
Date: Mar 22, 2007
Hi Jerry, congrats on the first flight and the grand daughter. Can top you on the RV front OK with almost two inside four years, now for that grand daughter........ many happy landings. ----- Original Message ----- From: Jerry2DT(at)aol.com To: rv-list(at)matronics.com Sent: Thursday, March 22, 2007 4:44 PM Subject: RV-List: Top this if you can. Yesterday, 03/21/2007, N18XP, RV-6a QB kit #60534 took to the air from Newberg, OR. This was quite the red letter day in other respects also, one that I think other builders are going to have a tough time matching... Not only did my -6a "baby" become an airplane, but another baby was born, our first great-grandchild. Sophie arrived just 3 hours before first flight, and weighed 8 lbs with dark hair and blue eyes. We are so very blessed. N18XP flew flawlessly, with her Superior IO360 and Hartzell 74" blended airfoil prop. The six years spent building were rewarding in every way, and I truly believe I learned something new each one of those days. Thank you Van, for such a great design, and your outstanding crew at Van's, particularly Dale, Gus, and Rob, always very helpful, and Ken Scott who gave me that first "$30,000 Ride" where I was instantly hooked. I'd also like to thank Bob Haan, Dan Benua, Len Kauffman, Frank Sneed and many others from EAA105 along the way for all the help, without which this journey would have been much tougher. Oh, and I better mention the folks online at the "RV-list", "Aeroelectric List" and "Vans AF", LOTS of help there... Now to get those 40 hours flown off... Yah, someone's got to do it!! Jerry Cochran Sherwood, Oregon ------------------------------------------------------------------------- ----- AOL.com. ________________________________________________________________________________
Subject: Vne dependent on TAS?
Date: Mar 24, 2007
Listers, A recent article in Kitplane magazine describes the criticality of knowing TAS at relative high msl. For example, if one is flying at 8K to 10K, the indicated airspeed is significantly less than TAS. Therefore, an IAS of 90 could have TAS near Vne. I would be interested in offline comments from anyone experiencing "flutter" or some other situation at these altitudes and how you deal with the situations. Many thanks, Ken Arnold ________________________________________________________________________________
Date: Mar 24, 2007
Jerry, Those are the standard Van's wingtips that came in my wing kit in 2002. I'm not sure when Van's changed them but I noticed that on some -7's recently. Bob -------- Bob Newhall N829RV RV Transition Training Boulder, CO renewhall2.googlepages.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102628#102628 ________________________________________________________________________________
Subject: Re: Vne dependent on TAS?
Date: Mar 24, 2007
Ken, This is the very reason Van's doesn't support the use of engines higher than advertised and normally aspirated. A normaly aspirated Lycoming will usually reach full throttle height around 7500 feet AMSL/standard atmosphere. RV's can usually go a bit higher due to the RAM effect of the intake air if the cowling and baffling of intake has been carefully constructed, sometimnes as much as 1"MP can be gained. Save for a very light RV, little fuel, no lugagge, 1POB, I don't think it's an issue really. However should you have the urge to up the HP even a bit or use a TURBO where you can maintain your MP above the 7500 then you will quickly come very close to the VNE, in a similar way as you can quickly achieve VNE at low levels by high powersetting and just pushing the nose down. I recall it could be achieved within a 1000feet drop with only 1800RPM set during the testfase of my RV7.(180HP, FP, 1029LBS empty). ----- Original Message ----- From: Ken Arnold To: RV-List(at)matronics.com Sent: Saturday, March 24, 2007 2:27 PM Subject: RV-List: Vne dependent on TAS? Listers, A recent article in Kitplane magazine describes the criticality of knowing TAS at relative high msl. For example, if one is flying at 8K to 10K, the indicated airspeed is significantly less than TAS. Therefore, an IAS of 90 could have TAS near Vne. I would be interested in offline comments from anyone experiencing "flutter" or some other situation at these altitudes and how you deal with the situations. Many thanks, Ken Arnold ________________________________________________________________________________
Subject: Rebuilding Gyros
Date: Mar 24, 2007
Is there anyone on the "list" that has rebuilt a gyro themselves? I have a ADI of B.F.Goodrich origin that I would like to rebuild. Corollary question, who would be a good source to have the gyro overall, less yellow tag as this is for an experimental? Marty RV-6A finishing. ________________________________________________________________________________
Date: Mar 24, 2007
Go to the Vans Aircatft website and select RV 9/9A and then "Performance". There is an article about Why can't I use a bigger engine" that has some good info. Ron Lee --------------------------------------------- This message was sent using Endymion MailMan. http://www.endymion.com/products/mailman/ ________________________________________________________________________________
Date: Mar 24, 2007
Found it! http://www.vansaircraft.com/pdf/hp_limts.pdf as a discussion of the relationship between TAS and flutter on the RV List a year or so ago. You should find lots about it in the archives. The RV List discussion was inspired by an article in the RVator called "Flying High and Fast" (6th issue of 2004), in which Ken Krueger talks about the risk of encountering flutter at high altitude, due to TAS being much higher than IAS. Robin RV-10 still in pieces... ________________________________________________________________________________
Date: Mar 24, 2007
Subject: RE: RV10-List: Kitlog Pro
At 05:29 AM 3/22/2007 Thursday, RV Builder (Michael Sausen) wrote: >Matt bought KitLog?!? Wow, thats cool! Maybe he will fix the problem where clicking next on a project web page takes you backward in dates instead of forward. That has always drove me nuts along with the run on paragraphs. Spell check would be great too. I also mentioned to Paul way back when I was beta testing his 2.0 release that adding the ability to attach files to entries like scanned receipts to expenses would be useful. > >Michael Sausen Michael/Kitlog Users, I think you will be pleased. I've updated the "Next/Previous" functionality on the individual log entry pages so that the function is now more intuitive. Give it a try and let me know what you think... http://www.mykitlog.com/users/display_log.php?user=msausen&project=22&category=0&log=16675&row=5 How's that for customer service? Tell a friend! Best regards, Matt Dralle Matronics / Kitlog Pro Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Mar 24, 2007
Listers, Many thanks for all the good comments re: TAS effect on Vne. The Ken Kruger article is very good and very clear. ie be very careful when calculating your closeness to Vne at higher altitudes. My engine is Rotax 912 ULS. I have determined the rule of thumb is multiply thousands by 1.5 which gives a percentage number to find IAS to compare with TAS. For example, at 8K msl, multiply 8 x 1.5 = 12% reduction. If Vne at sealevel was 110 mph then 110 x 0.88 = 96.8 mph IAS. This is important news. Other docs have sort of ignored the situation by discussing how much more efficient it is to fly a little higher. Further, I think a placard pasted to the panel at some sample altitudes would be handy. Again, many thanks, Ken Arnold ----- Original Message ----- From: "Robin Marks" <robin1(at)mrmoisture.com> Sent: Saturday, March 24, 2007 3:01 PM Subject: RE: RV-List: Vne dependent on TAS? > > Found it! > > http://www.vansaircraft.com/pdf/hp_limts.pdf > > as a discussion of the relationship between TAS and flutter on the RV > List a year or so ago. You should find lots about it in the archives. > The RV List discussion was inspired by an article in the RVator called > "Flying High and Fast" (6th issue of 2004), in which Ken Krueger talks > about the risk of encountering flutter at high altitude, due to TAS > being much higher than IAS. > > Robin > RV-10 still in pieces... > > > ________________________________________________________________________________
Date: Mar 24, 2007
Subject: Re: RE: RV10-List: Kitlog Pro
Matt, Would this be something requiring an update? I've clicked on the check for updates and the reply is no updates available. Thanks, Darrell --- Matt Dralle wrote: > > > At 05:29 AM 3/22/2007 Thursday, RV Builder (Michael > Sausen) wrote: > >Matt bought KitLog?!? Wow, thats cool! Maybe he > will fix the problem where clicking next on a > project web page takes you backward in dates instead > of forward. That has always drove me nuts along > with the run on paragraphs. Spell check would be > great too. I also mentioned to Paul way back when I > was beta testing his 2.0 release that adding the > ability to attach files to entries like scanned > receipts to expenses would be useful. > > > >Michael Sausen > > Michael/Kitlog Users, > > I think you will be pleased. I've updated the > "Next/Previous" functionality on the individual log > entry pages so that the function is now more > intuitive. Give it a try and let me know what you > think... > > http://www.mykitlog.com/users/display_log.php?user=msausen&project=22&category=0&log=16675&row=5 > > How's that for customer service? Tell a friend! > > Best regards, > Matt Dralle > Matronics / Kitlog Pro > > > > Matt G Dralle | Matronics | PO Box 347 | Livermore | > CA | 94551 > 925-606-1001 V | 925-606-6281 F | > dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products > For Aircraft > > > > browse > Subscriptions page, > FAQ, > > Web Forums! > > > > > Don't get soaked. Take a quick peek at the forecast with the Yahoo! Search weather shortcut. http://tools.search.yahoo.com/shortcuts/#loc_weather ________________________________________________________________________________
Date: Mar 24, 2007
Darrell, No, all of these changes were made on the MyKitlog.com webserver side; no update to your Windows Application is required to take advantage of them. Matt Dralle At 04:15 PM 3/24/2007 Saturday, you wrote: > >Matt, > >Would this be something requiring an update? I've >clicked on the check for updates and the reply is no >updates available. > >Thanks, > >Darrell > >--- Matt Dralle wrote: > >> >> >> At 05:29 AM 3/22/2007 Thursday, RV Builder (Michael >> Sausen) wrote: >> >Matt bought KitLog?!? Wow, thats cool! Maybe he >> will fix the problem where clicking next on a >> project web page takes you backward in dates instead >> of forward. That has always drove me nuts along >> with the run on paragraphs. Spell check would be >> great too. I also mentioned to Paul way back when I >> was beta testing his 2.0 release that adding the >> ability to attach files to entries like scanned >> receipts to expenses would be useful. >> > >> >Michael Sausen >> >> Michael/Kitlog Users, >> >> I think you will be pleased. I've updated the >> "Next/Previous" functionality on the individual log >> entry pages so that the function is now more >> intuitive. Give it a try and let me know what you >> think... >> >> >http://www.mykitlog.com/users/display_log.php?user=msausen&project=22&category=0&log=16675&row=5 >> >> How's that for customer service? Tell a friend! >> >> Best regards, >> Matt Dralle >> Matronics / Kitlog Pro >> >> >> >> Matt G Dralle | Matronics | PO Box 347 | Livermore | >> CA | 94551 >> 925-606-1001 V | 925-606-6281 F | >> dralle(at)matronics.com Email >> http://www.matronics.com/ WWW | Featuring Products >> For Aircraft >> >> >> >> browse >> Subscriptions page, >> FAQ, >> >> Web Forums! >> >> >> >> >> > > > >Don't get soaked. Take a quick peek at the forecast >with the Yahoo! Search weather shortcut. >http://tools.search.yahoo.com/shortcuts/#loc_weather > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Mar 24, 2007
All of Matt's recent changes effect how the web pages are displayed and didn't require any changes to the PC application. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Darrell Reiley Sent: Saturday, March 24, 2007 7:15 PM Subject: Re: RV-List: RE: RV10-List: Kitlog Pro Matt, Would this be something requiring an update? I've clicked on the check for updates and the reply is no updates available. Thanks, Darrell --- Matt Dralle wrote: > > > At 05:29 AM 3/22/2007 Thursday, RV Builder (Michael > Sausen) wrote: > >Matt bought KitLog?!? Wow, that's cool! Maybe he > will fix the problem where clicking next on a > project web page takes you backward in dates instead > of forward. That' has always drove me nuts along > with the run on paragraphs. Spell check would be > great too. I also mentioned to Paul way back when I > was beta testing his 2.0 release that adding the > ability to attach files to entries like scanned > receipts to expenses would be useful. > > > >Michael Sausen > > Michael/Kitlog Users, > > I think you will be pleased. I've updated the > "Next/Previous" functionality on the individual log > entry pages so that the function is now more > intuitive. Give it a try and let me know what you > think... > > http://www.mykitlog.com/users/display_log.php?user=msausen&project=22&catego ry=0&log=16675&row=5 > > How's that for customer service? Tell a friend! > > Best regards, > Matt Dralle > Matronics / Kitlog Pro > > > > Matt G Dralle | Matronics | PO Box 347 | Livermore | > CA | 94551 > 925-606-1001 V | 925-606-6281 F | > dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products > For Aircraft > > > > browse > Subscriptions page, > FAQ, > > Web Forums! > > > > > Don't get soaked. Take a quick peek at the forecast with the Yahoo! Search weather shortcut. http://tools.search.yahoo.com/shortcuts/#loc_weather ________________________________________________________________________________
Date: Mar 25, 2007
Subject: Re:Vne dependent on TAS?
Hi Lynn- The example you cite is fine as long as all on does is fly straight and level. But consider the fellow that is on a long X/C, cruising along at 17,500. He's probably indicating 1/3 to 1/2 of Vne at the most. At top of descent he lowers the nose and keeps the power set. Before long he's indicating close to red line while still descending through the teens. His TAS is now well above Vne and bingo, flutter is a threat. > >I'm confused. Well, maybe not. If the discussion is based on 'bigger >engines', then I can see the basis for the discussion. However, VNE >probably can't be attained in level flight ...... even with a lot of >extra HP, so the VNE/TAS discussion should die right there. In the >absence of a turbo, flying at altitude will make that attempt even >farther from attainment. Also, the flutter design limit is higher than >VNE (or should be :-P ) so that shouldn't be a problem. >So, where's the fear?? >Linn Glen Matejcek ________________________________________________________________________________
Date: Mar 25, 2007
Subject: RV-7 tipup F768A,Bl,Br subpanel bends
I'm clecoing the structure between the instrument panel & firewall. It's obvious that there should be a bend in F768 (also the firewall) but I can't find any notes on the plans or the instructions on the bend line or angle. Does Van expect the natural curve to take care of things, or am I missing the bend info in the plans? Thanks, Charlie ________________________________________________________________________________
Subject: Re: RV-7 tipup F768A,Bl,Br subpanel bends
Date: Mar 25, 2007
Charlie, I never found a callout for a bend. Dwg 24A Section A-A shows the angle - but no callout. I just clecoed (and eventually riveted) everything and let that bend the parts. Same for the firewall. Dennis Glaeser RV-7A Tip-Up ---------------------------------------------------------------------------- -------------------- I'm clecoing the structure between the instrument panel & firewall. It's obvious that there should be a bend in F768 (also the firewall) but I can't find any notes on the plans or the instructions on the bend line or angle. Does Van expect the natural curve to take care of things, or am I missing the bend info in the plans? Thanks, Charlie ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Mar 25, 2007
In the RV-6 plans, the instructions were to clamp a board on both sides of the firewall along the top of the bend line and use the boards as a brake to make the bend. Properly done, you can get a nice crease along a straight line. KB ----- Original Message ----- From: "glaesers" <glaesers(at)wideopenwest.com> Sent: Sunday, March 25, 2007 8:33 PM Subject: RV-List: Re: RV-7 tipup F768A,Bl,Br subpanel bends > > Charlie, > > I never found a callout for a bend. Dwg 24A Section A-A shows the angle - > but no callout. I just clecoed (and eventually riveted) everything and > let > that bend the parts. Same for the firewall. > > Dennis Glaeser > RV-7A Tip-Up > > ---------------------------------------------------------------------------- > -------------------- > I'm clecoing the structure between the instrument panel & firewall. It's > obvious that there should be a bend in F768 (also the firewall) but I > can't find any notes on the plans or the instructions on the bend line > or angle. > > Does Van expect the natural curve to take care of things, or am I > missing the bend info in the plans? > > Thanks, > > Charlie > > > ________________________________________________________________________________
Subject: TAS and VNE
Date: Mar 25, 2007
I also don't entirely agree with the Kruger article. Flutter is not a function of velocity directly, it is a function of force acting upon the components which may flutter. While the air molecules are going by at a faster rate there are far less of them so the resultant force doesn't nearly increase at the rate TAS does with gains in altitude. Flutter is properly called negative dynamic stability and it requires positive static stability to occur. Positive static force pushes the control back to its neutral condition. When it's coupled to inertia and the resultant forces are able to move the control beyond that to a position greater then the original upset than that is negative dynamic stability AKA flutter. Mass aft of the pivot line adds to the inertia, mass at or just fwd of it takes away from the inertia. However it is force that causes the initial positive static desire to return to neutral and beyond. And it doesn't change too much with changes in altitude. If it did you would be able to notice it in the feel of the stick as altitude changed. This is one of the primary reasons we use VNE and all the other numbers in indicated units. W ________________________________________________________________________________
Date: Mar 26, 2007
http://www.vansaircraft.com/pdf/hp_limts.pdf Robin ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of David Maib Sent: Sunday, March 25, 2007 6:01 PM Subject: Re: RV-List: Re:Vne dependent on TAS? Somebody on this forum recently mentioned finding a good article about it in Vans Rvator publication. I am not sure how old it is or when it was published. David ________________________________________________________________________________
Date: Mar 26, 2007
>I'm confused. Well, maybe not. If the discussion is based on >'bigger engines', then I can see the basis for the >discussion. However, VNE probably can't be attained in level flight >...... even with a lot of extra HP, so the VNE/TAS discussion should >die right there. At 8000 feet max power available from an IO-360 180 HP, straight and level, I have exceeded TAS Vne on my RV6. However my IAS was well below Vne. Bob RV6 "The Wicked Witch of the West" ________________________________________________________________________________
Subject: 9A For Sale
Date: Mar 26, 2007
I'm posting this for a friend with medical issues. Everyone at the airport who watched him build this plane speaks highly of his meticulous work. 2006 Aerosport O-320, 55 hrs. Fixed pitch Sensenich Dynon D10A Garmin GPS/COM Garmin GTX-320A transponder I-K Technologies EIS $110,000 Bruce Roberts Pell City, AL 205-338-9618 Prism15(at)centurytel.net ________________________________________________________________________________
Subject: Re: TAS and VNE
Date: Mar 26, 2007
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
I must respectfully disagree. Flutter and dynamic stability are vastly different things. Flutter is NOT the trailing edge of a control surface flapping in the breeze like a flag in high wind. Flutter is the some portion of an airframe (wing, tail, fuselage) acting like a rubber band due to forces in resonance with one or more of it's natural frequencies. Since it is a frequency, not force, related phenomenon, that is why TAS is key instead of IAS. At the right frequency, it only takes a small force to start the process (think tuning fork). The force that reacts to bring the airframe back after a disturbance is the stiffness of the structure (again, like a tuning fork) not the control surface. The reason for balancing controls is to minimize their impact in increasing and/or maintaining the disturbing forces. Even a wing without ailerons or flaps (a helicopter rotor blade for example) can flutter. My first job was rotor blade design - I've seen wind tunnel videos of it happening. If you've never seen the bridge video mentioned in Ken's article - find it and take a look. The Kruger article is accurate. Dennis Glaeser BSAE - building an RV-7A ------------------------------------------------------------------------ From: Wheeler North I also don't entirely agree with the Kruger article. Flutter is not a function of velocity directly, it is a function of force acting upon the components which may flutter. While the air molecules are going by at a faster rate there are far less of them so the resultant force doesn't nearly increase at the rate TAS does with gains in altitude. Flutter is properly called negative dynamic stability and it requires positive static stability to occur. Positive static force pushes the control back to its neutral condition. When it's coupled to inertia and the resultant forces are able to move the control beyond that to a position greater then the original upset than that is negative dynamic stability AKA flutter. Mass aft of the pivot line adds to the inertia, mass at or just fwd of it takes away from the inertia. However it is force that causes the initial positive static desire to return to neutral and beyond. And it doesn't change too much with changes in altitude. If it did you would be able to notice it in the feel of the stick as altitude changed. This is one of the primary reasons we use VNE and all the other numbers in indicated units. W ________________________________________________________________________________
From: "Joe & Jan Connell" <jconnell(at)rconnect.com>
Subject: TAS and Vne
Date: Mar 26, 2007
Interesting comments on TAS, Vne, and flutter Years ago when I was flying rescue helicopters for the Air Force, a B-47 pilot and I had a discussion about TAS, Vne, and flutter. A B-47 could operate high enough that the stall speed would approach Vne. Too slow, the plane would stall -- too fast, the plane would exceed Vne. If the B-47 stalled, it would exceed Vne in recovery. The phenomena was called the "Coffin Corner..." ________________________________________________________________________________
Date: Mar 26, 2007
Hi All, IMHO, the purposed of the RVator (and the same article in Kitplanes) is to keep builder/pilots of RV's from killing themselves. Apparently there are a number of RV-10's being built with engine installations that caused this to be a very real concern to Van's Aircraft. My thoughts: There is no "design" flutter speed. I have heard that the RV airframe structure is the least likely to flutter first, because of its structural stiffness. It is expected that the flight control surfaces would flutter first. Inherent in this statement is the assumption that the airframe is built to the design documentation. The flutter speed of the flight controls is dependent on the control system stiffness and rigging. Where loose fitting flight control surfaces and control attachments will flutter at a lower airspeed. Inherent in this statement, the manufacturer of the aircraft builds in a unique flutter speed for that airframe. The RVator (and Kitplanes) article does seem like a better way to provide a warning about Vne and flutter speed, than to provide a fixed number for a flutter speed that could lead to someone's death. What I didn't like about the RVator article is the misleading statement Vne being a TAS. Part 23 defines Vne as an Equivalent Airspeed (EAS). This is a calibrated and corrected Indicated Airspeed. If an aircraft is NOT designed to Part 23, I suppose Vne could be defined anyway they want. :-) Actually, an awareness of TAS is a very good thing. Especially with the GPS readout of your ground speed. On a cruise climb in the direction of your destination, you can monitor the TAS and the GPS ground speed. The difference being your headwind, or tailwind. During your climb to your preferred cruise altitude, you can calculate the actual headwind, or tailwind, at the different altitudes. If you get to your preferred cruise altitude and find you have a greater headwind, or a lesser tailwind, than a lower altitude, you could decide to descend back down to a more favorable altitude. Jim Ayers RV-3 sn 50 33 years of learning about RV's :-) PS Van used to recommend that the RV-3 be flutter tested to 10% over Vne at 10,000' or higher. Vne being stated as an IAS! Some things do change. :-) In a message dated 03/26/2007 6:41:28 AM Pacific Standard Time, dennis.glaeser(at)eds.com writes: --> RV-List message posted by: "Glaeser, Dennis A" I must respectfully disagree. Flutter and dynamic stability are vastly different things. Flutter is NOT the trailing edge of a control surface flapping in the breeze like a flag in high wind. Flutter is the some portion of an airframe (wing, tail, fuselage) acting like a rubber band due to forces in resonance with one or more of it's natural frequencies. Since it is a frequency, not force, related phenomenon, that is why TAS is key instead of IAS. At the right frequency, it only takes a small force to start the process (think tuning fork). The force that reacts to bring the airframe back after a disturbance is the stiffness of the structure (again, like a tuning fork) not the control surface. The reason for balancing controls is to minimize their impact in increasing and/or maintaining the disturbing forces. Even a wing without ailerons or flaps (a helicopter rotor blade for example) can flutter. My first job was rotor blade design - I've seen wind tunnel videos of it happening. If you've never seen the bridge video mentioned in Ken's article - find it and take a look. The Kruger article is accurate. Dennis Glaeser BSAE - building an RV-7A ________________________________________________________________________________
Date: Mar 26, 2007
There is also an article on the subject in the current Kitplanes magazine, written by Ken Scott at Van's. Dick Sipp RV10 40065 ------------------------------------------------------------------------- ----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of David Maib Sent: Sunday, March 25, 2007 6:01 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Re:Vne dependent on TAS? Somebody on this forum recently mentioned finding a good article about it in Vans Rvator publication. I am not sure how old it is or when it was published. David ________________________________________________________________________________
Subject: A internet view of TAS and VNE
Date: Mar 26, 2007
Here is an explanation that appears to make it fairly clear as to why TAS rather than IAS is the critical factor in flutter. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html http://www.auf.asn.au/groundschool/flutter.html#flutter Indicated airspeed really reflects dynamic pressure rather than airflow velocity so if the structural limitations which define Vne for an aircraft type are particularly associated with the distribution of forces associated with velocity then the specified indicated Vne has to be decreased as altitude is increased - to adjust for the increase in true airspeed which latter is about 1.5% greater than IAS/CAS for every 1000 feet of altitude, see rule of thumb #2. 13.3 Aerodynamic reactions to flight at excessive speed Flutter Wing structures are akin to a 'tuning fork' extending from the fuselage. When a tuning fork is tapped the fork vibrates at a particular frequency, the stiffer the structure the higher its 'natural' frequency. The natural frequency of a wing or tailplane structure may apply another limiting airspeed to flight operations - related to structural instabilities: flutter and wing divergence. When the airflow around a wing or control surface is disturbed by aerodynamic reactions or pilot inputs, the structure's elastic reactions may combine as an oscillation or vibration of the structure (possibly evident as a buzz in the airframe) which will quickly damp itself out at normal cruise speeds. At some higher speed - the critical flutter speed - where the oscillations are in phase with the natural frequency of the structure the oscillations will not damp out but will resonate, rapidly increasing in amplitude. (Pushing a child on a swing is an example of phase relationships and amplification). This condition is flutter and, unless airspeed is very quickly reduced, the severe vibrations will cause control surface [or other] separation within a very few seconds. The following paragraph is an extract from an article by William P. Rodden appearing in the McGraw-Hill Dictionary of Science and Technology; it provides a succinct description of flutter: "Flutter (aeronautics) - An aeroelastic self-excited vibration with a sustained or divergent amplitude, which occurs when a structure is placed in a flow of sufficiently high velocity. Flutter is an instability that can be extremely violent. At low speeds, in the presence of an airstream, the vibration modes of an aircraft are stable; that is, if the aircraft is disturbed, the ensuing motion will be damped. At higher speeds, the effect of the airstream is to couple two or more vibration modes such that the vibrating structure will extract energy from the airstream. The coupled vibration modes will remain stable as long as the extracted energy is dissipated by the internal damping or friction of the structure. However a critical speed is reached when the extracted energy equals the amount of energy that the structure is capable of dissipating, and a neutrally stable vibration will persist. This is called the flutter speed. At a higher speed, the vibration amplitude will diverge, and a structural failure will result." Inertia has a role in flutter development requiring that control surfaces - ailerons, elevators, rudder - be mass balanced (i.e. the centre of gravity of the control surface coincides with the hinge line) to limit the mass moment of inertia. It may be acceptable for the control surface to be over-balanced, i.e. the cg is slightly forward of the hinge line. Mass balancing of the control surfaces will prevent them fluttering but the possibility for wing [for example] flexing/twisting flutter may still exist. The critical flutter airspeed [or something akin to it] may eventuate well below Vne if wear in control surface hinges, slop in actuating rods/cables/cranks/torque tubes, water or ice inside control surfaces or absorbed within a foam core, mud outside, faulty trim tabs, additional surface coatings applied after balancing or other system disturbances exist which alter the structure's reactions. ----- Original Message ----- From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com> Sent: Monday, March 26, 2007 10:34 AM Subject: RV-List: Re: TAS and VNE > > I must respectfully disagree. Flutter and dynamic stability are vastly > different things. Flutter is NOT the trailing edge of a control surface > flapping in the breeze like a flag in high wind. Flutter is the some > portion of an airframe (wing, tail, fuselage) acting like a rubber band > due to forces in resonance with one or more of it's natural frequencies. > Since it is a frequency, not force, related phenomenon, that is why TAS > is key instead of IAS. At the right frequency, it only takes a small > force to start the process (think tuning fork). > The force that reacts to bring the airframe back after a disturbance is > the stiffness of the structure (again, like a tuning fork) not the > control surface. The reason for balancing controls is to minimize their > impact in increasing and/or maintaining the disturbing forces. Even a > wing without ailerons or flaps (a helicopter rotor blade for example) > can flutter. My first job was rotor blade design - I've seen wind > tunnel videos of it happening. > If you've never seen the bridge video mentioned in Ken's article - find > it and take a look. The Kruger article is accurate. > > Dennis Glaeser > BSAE - building an RV-7A > > ------------------------------------------------------------------------ > From: Wheeler North > I also don't entirely agree with the Kruger article. > > Flutter is not a function of velocity directly, it is a function of > force acting upon the components which may flutter. While the air > molecules are going by at a faster rate there are far less of them so > the resultant force doesn't nearly increase at the rate TAS does with > gains in altitude. > > Flutter is properly called negative dynamic stability and it requires > positive static stability to occur. Positive static force pushes the > control back to its neutral condition. When it's coupled to inertia and > the resultant forces are able to move the control beyond that to a > position greater then the original upset than that is negative dynamic > stability AKA flutter. Mass aft of the pivot line adds to the inertia, > mass at or just fwd of it takes away from the inertia. However it is > force that causes the initial positive static desire to return to > neutral and beyond. And it doesn't change too much with changes in > altitude. If it did you would be able to notice it in the feel of the > stick as altitude changed. > > This is one of the primary reasons we use VNE and all the other numbers > in indicated units. > > W > > > > > > > > ________________________________________________________________________________
Date: Mar 26, 2007
><http://www.vansaircraft.com/pdf/hp_limts.pdf>http://www.vansaircraft.com/pdf/hp_limts.pdf > One of the articles talks about those who wish to put a 180 HP engine in an RV9 (a non aerobatic airplane that would probably fly reasonably well with a Rotax 912). This reminds me of the movie "Tin Cup" when Kevin Costner is bragging how he parred the back nine using a 7 iron? And Don Johnson replied, that he never considered doing such a thing and why would anyone do it? But, then again, I have been dreaming of hanging a 180 HP on my hang glider. I don't know, but I guess I could do at least 4X Vne if total catastrophic failure does not happen first! BTW, is there a term for exceeding Vne, sort of like the Mach number? If not, maybe we as a group can come up with one? Bob RV6 "The Wicked Witch of the West" ________________________________________________________________________________
Subject: Electroair/Rose Ignition
Date: Mar 26, 2007
One option with the Electroair Ignition, used to be a small rectangular display which showed the number of degrees of advance where the ignition was firing. Unfortunately, my display has a wiring problem inside the display and I don't think I have a very good chance of repairing it, although I will try. No problem, right? Just buy another one... Well, not so fast. They don't sell that unit anymore - apparently, the supplier dried up. So if I can't repair mine, I'm stuck with an oddball hole in my panel (about 1" x 2"). Due to the location of the hole, there really isn't much I can do with the space. This isn't an operational problem (the system works just fine without the digital readout), but it is an aesthetic problem and I *want* to know how the EI is operating... Anyway, this leads me to ask: 1) Does anyone have contact information for Jeff Rose? I know he isn't the front man for the business anymore, and may have sold it entirely, but he's been very helpful in the past and might have some insight. The folks currently running Electro didn't have any helpful suggestions when I spoke with them on the phone. 2) Does anyone have an "advance display" they would sell? I'm in the market if the price is reasonable. Thanks, KB ________________________________________________________________________________
Date: Mar 26, 2007
Subject: Re: Electroair/Rose Ignition
Kyle, any panel mounted voltmeter will do...this is the one I used: http://www.marteltesttools.com/products.php?cat=114&action=detail&id=73 This might be a bit smaller than the one you had, but if you look around there are many sizes these sorts of voltmeters come in. IIRC 10mV = 1 degree advance, you set up the scaling with a resistor network (two resistors which the instructions for the meter specify.) There are a series of jumpers on the back to set it up so there's no decimal point displayed. So, with a voltmeter if it reads .01V, that means 1 degree advance, 0.20V means 20 degrees advance, etc. With the divider network and the jumpers set up correctly, it the display would show 1 and 20 respectively. Regards, Bob Japundza RV-6 flying F1 under const. On 3/26/07, Kyle Boatright wrote: > > One option with the Electroair Ignition, used to be a small rectangular > display which showed the number of degrees of advance where the ignition was > firing. Unfortunately, my display has a wiring problem inside the display > and I don't think I have a very good chance of repairing it, although I will > try. > > No problem, right? Just buy another one... Well, not so fast. They don't > sell that unit anymore - apparently, the supplier dried up. So if I can't > repair mine, I'm stuck with an oddball hole in my panel (about 1" x 2"). Due > to the location of the hole, there really isn't much I can do with the > space. > > This isn't an operational problem (the system works just fine without the > digital readout), but it is an aesthetic problem and I *want* to know how > the EI is operating... > > Anyway, this leads me to ask: > > 1) Does anyone have contact information for Jeff Rose? I know he isn't > the front man for the business anymore, and may have sold it entirely, but > he's been very helpful in the past and might have some insight. The folks > currently running Electro didn't have any helpful suggestions when I spoke > with them on the phone. > > 2) Does anyone have an "advance display" they would sell? I'm in the > market if the price is reasonable. > > Thanks, > > KB > > * > > > http://www.matronics.com/Navigator?RV-List > > http://forums.matronics.com > > * > > ________________________________________________________________________________
Date: Mar 26, 2007
Would it be the same as what Lightspeed offers? The Simpson digital panel meter http://www.lsecorp.com/Products/Accessories.htm Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Kyle Boatright wrote: > One option with the Electroair Ignition, used to be a small > rectangular display which showed the number of degrees of advance > where the ignition was firing. Unfortunately, my display has a wiring > problem inside the display and I don't think I have a very good chance > of repairing it, although I will try. > > No problem, right? Just buy another one... Well, not so fast. They > don't sell that unit anymore - apparently, the supplier dried up. So > if I can't repair mine, I'm stuck with an oddball hole in my panel > (about 1" x 2"). Due to the location of the hole, there really isn't > much I can do with the space. > > This isn't an operational problem (the system works just fine without > the digital readout), but it is an aesthetic problem and I *want* to > know how the EI is operating... >
March 02, 2007 - March 26, 2007
RV-Archive.digest.vol-sq
