RV-Archive.digest.vol-st
April 24, 2007 - May 16, 2007
somewhat. I was set on having the GAMI injectors based upon reports I
had received. When talking to my engine builder (Allen Barrett @ BPA) he
educated me about the differences between Continental and Lycoming.
Basically the Continental induction system is not as efficient and
benefits MORE from the GAMI's than the Lyc's do. Additionally, if you
want to get that last measure of performance out of your engine, Don
River @ AFP has a wealth of information and a service to swap/tune
injectors for his fuel injection system. So If you've got a Lycoming
the benefits of the GAMI's will not be as large. If you've got a
Lycoming AND AFP injection you're in good luck.
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
linn Walters wrote:
> OK, go ahead and embarrass me!!! The reason I left that info out ....
> I've forgotten the particulars. Search the archives. The post was
> from a fellow that bought GAMIs and had problems ..... they sent out
> injectors over and over again .... and they never worked right. If I
> remember correctly, the whole GAMI injector needs to be removed and
> replaced .... not easy on a hot engine. He finally gave up on GAMIs
> and got his money back. The 'experimental' injector has a replaceable
> insert with different size orifices and was easily swapped out.
> Problem was .... they didn't work perfectly either. The problem was
> already either a lean or rich condition and they were trying to go in
> the same direction with the replacement injectors. maybe someone else
> will come up with the specifics. Sorry I can't remember more than
> that ..... or which list it was on!!!
> Linn
Subject: | Re: RV-7 engine/prop options |
From: | "Lloyd, Daniel R." <LloydDR(at)wernerco.com> |
Might that be because they sell Lycoming? And have a vested interest in
the consumer to keep buying the cool aid?
Dan
"GRIN"
-----Original Message-----
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jeff Dowling
Sent: Tuesday, April 24, 2007 9:13 AM
Subject: Re: RV-List: Re: RV-7 engine/prop options
This came directly from Van's during Sun n Fun
What engines to put in your rv
1. Lycoming
2. Lycoming clones
second to last. Auto conversions
last. Rubber bands.
Shemp
----- Original Message -----
Sent: Tuesday, April 24, 2007 7:35 AM
Subject: RV-List: Re: RV-7 engine/prop options
> gmcjetpilot(at)yahoo.com said:
> Stay way from Alternative Engines, a Lycoming will end up being
> lighter, faster, cheaper, quicker/easier to build, less
maintenance
> and fiddling in the long run.
> Is that authoritative, expert advice... or just one man's opinion?
> One person may satisfy himself the above statement is true, while
another
> may find just the opposite.
> Blanket declarations like this are almost always found to be lacking
when
> a
> few intelligent questions are asked...
> Mark
Well I would also want to see a Lycoming FWF weighing that, and creating
that much HP?
Dan
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob
Sent: Tuesday, April 24, 2007 10:29 AM
maintenance
OK, I'll bite. For you alternative engine experts on the list, why
is an alternative engine lighter, faster, cheaper, quicker/easier to
build and less maintenance?
I personally fly a Lycoming, but would be interested in a 220 HP, 250
lb fully aerobatic (+10,-10 G) alternative engine with a constant
speed prop and inverted oil system (inverted cooling system?).
RV6 "Wicked Witch of the West"
Subject: | Oil Temperature High |
The squat plenum may well be causing some turbulence and reducing
airflow. The sides of the plenum shouldn't diverge more than 19 degrees,
if I remember the figure correctly, to keep the airflow attached. Pay
attention to the exit side also. If there are obstructions, it can
reduce airflow.
We've got a firewall mounted Niagara with 3 inch scat (one 90 degree
bend) on our 6-a, O-320. It has a long plenum and is fine for winter and
spring (185-195), but doesn't do well enough in summer (220+). We're
thinking seriously about moving it to the baffle. In the meantime, 750
hrs worth of it, we change the oil at 25 hrs, tach.
Pax,
Ed Holyoke
[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Francis
Malczynski
Sent: Tuesday, April 24, 2007 3:13 AM
Subject: RV-List: Oil Temperature High
My friend is test flying an RV6 fuel injected 0320. At 75% power runs
ie: engine break-in, he is seeing oil temperatures in the 210 - 220-
range. This is with an OAT of 34 degrees. He has a firewall mounted oil
cooler and used the van's kit for installation, which utilizes a 3" scat
duct. His feeling is that this is not enough airflow through the cooler
and because the cooler plenum (shroud) is so squat that not enough air
is being distributed across the entire face off the oil cooler. Any
thoughts on this.Thanks
Fran Malczynski
RV6 - N594EF
Olcott, NY
At 09:14 AM 4/24/07, n801bh(at)netzero.com wrote:
>A 220 hp engine that's dependable and weighs 250 lbs total. I am
>also looking to by the Brooklyn Bridge too. :-)..........
Last week I saw a IO 360 Mattituck Superior clone with 10:1 pistons
(not an angle valved engine), cold air induction, front facing sump
(ram air), 4 tuned exhaust pipes, polished intake ports, inverted oil
system. Empty weight around 285-290, rated HP 215-220. Super
looking engine.
Now I don't know if you call a Lycoming clone dependable, but the HP
to weight of this engine is pretty good for aviation or alternative
engines. It doesn't meet the 250 pound goal, but it is not that far
off. This will give the automotive guys something to work for.
NOTE: This debate started with Lycoming is the best, no it isn't,
yes it is. Then we talked about the automotive engines are better if
you consider................., yes it is, no it isn't, yes it is. So
I decided to determine what is best for me: 220 HP, 250 pounds and +
or - 10G and a reasonable TBO. The engine that comes the closest,
goes in my next plane!
From: | "McFarland, Randy" <Randy.McFarland(at)novellus.com> |
Subject: | Orndorff videos for sale |
Invaluable to me during my 7A construction!!
Empenage 6/8 2 tape set
Wings 8 2 tape set
Finish Kit 8
Aircraft Systems 2 tape set
Aircraft Tools
Original cost was $175
All for $120 plus shipping
Contact me off list for interest / questions.
Randy
408 427 5254 / randy.mcfarland(at)novellus.com
Wings 8 2 tape set
Finish Kit 8
Aircraft Tools
Randy
Subject: | Re: User Fees and Patriotism |
> If you're not talking about how young I look
Your photo lookslike late 30s or early 40s certainly not 53.
Milt
2003 F1 Rocket
2006 Radial Rocket
Some people live an entire lifetime and wonder if they have made a difference to
the world, but the Marines dont have that problem. - Ronald Reagan
http://forums.matronics.com/viewtopic.php?p=109025#109025
From: | "Kyle Boatright" <kboatright1(at)comcast.net> |
Subject: | Re: Oil Temperature High |
I had high temperatures on my O-320 RV6 initially and eventually solved
the problem, primarily through more airflow. I agree that 210-220 is
high with a 34F OAT (presumably at the surface level), even for a new
engine.
In the past, Vans has indicated that a 3" scat tube is very marginal for
feeding a firewall mounted cooler on an RV-6. That's only a cross
section of 6 or 7 square inches. A 4" SCAT tube would have almost double
the cross section and have less flow loss from surface friction.
My recommendation is to increase the size of the SCAT tube...
KB
To: RV-List
Sent: Tuesday, April 24, 2007 6:13 AM
runs ie: engine break-in, he is seeing oil temperatures in the 210 '
220- range. This is with an OAT of 34 degrees. He has a firewall mounted
oil cooler and used the van=92s kit for installation, which utilizes a
3=94 scat duct. His feeling is that this is not enough airflow through
the cooler and because the cooler plenum (shroud) is so squat that not
enough air is being distributed across the entire face off the oil
cooler. Any thoughts on this=85Thanks
Fran Malczynski
RV6 - N594EF
Olcott, NY
From: | "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> |
Kyle.....Good idea!!! I have a 4" Tube running to the firewall mounted
cooler on my RV6-A. I have never seen an Oil Temp. above 185 and my RV
is running the 0-360-A1A.
Tom in Ohio
To: rv-list(at)matronics.com
Sent: Tuesday, April 24, 2007 6:38 PM
Subject: Re: RV-List: Oil Temperature High
solved the problem, primarily through more airflow. I agree that 210-220
is high with a 34F OAT (presumably at the surface level), even for a new
engine.
for feeding a firewall mounted cooler on an RV-6. That's only a cross
KB
To: RV-List
Fran Malczynski
RV6 - N594EF
Olcott, NY
From: | "Carl Bell" <carlbell(at)gforcecable.com> |
Subject: | RE: RV Advice, one leg flyer |
I want to thank everyone for there help on this topic, it has been
invaluable. The list ("you all" is how we say it in the south) has provided
me with some great information including:
1) Picture of how two amputees accomplish flying with one leg,
including a castor on a shoe to dual hand brakes and a push-pull rudder, and
an article about a double amputee doing it with some special hardware flying
an RV4.
2) It gave me the sense that I can pick the plane I want and find a
way to modify it to make it work safely.
3) A belief in a great community of builders that will readily share
there experiences
As an outcome I will go fly with a CFI in a tail dragger and a nose dragger
and see which one works for my handicap and order a kit. I know it will be
a 7, with a Lycoming type engine, so I'm almost there and can order some
more tools and the tail kit.
Thanks again, Carl
Subject: | Sun N Fun pictures |
Just got back from Sun N Fun and wanted to share some pics.
http://sportplanes.tv/
http://forums.matronics.com/viewtopic.php?p=109106#109106
Subject: | Re: Can't remember who or find in archives |
In a message dated 4/24/2007 8:45:20 PM Central Daylight Time,
dcr(at)fdltownhomes.com writes:
Question to whoever posted this: Did it work and if it did, how long were
the bolts.
_http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=4964_
(http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=4964)
This was more for preventing the small bolts from twisting cockeyed and
wearing the holes & hardware, although there are many many RVs flying with them.
If using either configuration, make sure the nuts are NOT tight- the pedals
should be able to freely pivot without sticking.
Dragging brakes are usually from weak return springs inside the cylinders,
and many have added external coil springs around the cylinder rods to add more
extension force (I did) and it stopped my dragging brake problem. It is a good
idea to add a flanged bushing on the bottom of the spring, with the OD of the
bushing inside the spring and the flange nested on top of the cylinder to
prevent the spring from scoring the rod- I used small plastic flanged bushings,
probably from McMaster.com, but it's been a while...
>From The PossumWorks in TN
Mark Phillips RV-6A "Mojo" 400+ hrs
_http://websites.expercraft.com/n51pw/_
(http://websites.expercraft.com/n51pw/) (http://websites.expercraft.com/n51pw/)
************************************** See what's free at http://www.aol.com.
In a message dated 4/24/2007 6:16:14 AM Central Daylight Time,
ebbfmm(at)verizon.net writes:
His feeling is that this is not enough airflow through the cooler and becaus
e
the cooler plenum (shroud) is so squat that not enough air is being
distributed across the entire face off the oil cooler. Any thoughts on this
_http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5000_
(http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5000)
This arrangement has worked well on my 150hp E3D for over 400 hours. Click
>>Next Entry>> at top of page for more entries, and click on foto for bigger
look...
>From The PossumWorks in TN,
Mark RV-6A "Mojo"
From: | Richard Seiders <seiders(at)bellsouth.net> |
--- MIME Errors - No Plain-Text Section Found ---
A message with no text/plain MIME section was received.
The entire body of the message was removed. Please
resend the email using Plain Text formatting.
HOTMAIL is notorious for only including an HTML section
in their client's default configuration. If you're using
HOTMAIL, please see your email application's settings
and switch to a default mail option that uses "Plain Text".
--- MIME Errors No Plain-Text Section Found ---
From: | "Jeff Dowling" <shempdowling2(at)earthlink.net> |
Subject: | Lightspeed electronic ignition |
I was reading the instructions in the timing manual and they mentioned
the timing at idle should be at 40 btdc with manifold pressure input and
20 without. I used an automotive timing light, however I think mine has
a potentiometer, which your not supposed to use. Anyway, I found my
timing to be about 30btdc at idle using the gun but my lightspeed
provided display showed the correct 40 degrees. Now Im wondering, do I
even have to use the timing light since I purchased the optional display
which shows me the timing?
I also thought it would fire closer to 25 btdc at idle and advance with
rpm. I was surprised to see it firing so early.
I did a typical mag check at 1700 and got about 150 drop in my mag and
almost no drop in the electronic. Its running very smoothly. However,
at low power settings and just one mag, it backfired and ran a bit
rough. Does that sound normal? I checked the mag timing and its right
on. New plugs.
Shemp/Jeff Dowling
RV-6A, N915JD
300+ hours
Chicago
From: | "Joe & Jan Connell" <jconnell(at)rconnect.com> |
Subject: | Engine wiring anchor points |
Guys,
I'm in the process of routing wires to the starter, alternator, CHT, and
EGT probes.
Is anyone using the induction tubes from the sump for a clamp and
standoff for the
wires? Also, how about using the sump-to-crankcase attach bolts for
cable clamp
attachments?
Thanks...
Joe Connell
RV-9A and O-320
From: | "Dale Ensing" <densing(at)carolina.rr.com> |
Subject: | Re: Engine wiring anchor points |
I fabricated a clamp arrangement on the induction tube for the
alternator wire.
I found a large rubber sleeve about 2 in long; about a 1/4 in wall
thickness and with stainless steel clamps at Home Depot. The rubber
sleeve was slit open from end to end and then trimmed so that the new ID
fit the OD of the induction tube. A hole was drilled in a SS screw clamp
to allow for a pan head screw that would become the mounting screw for a
cushioned clamp which holds the alt. wire. The SS screw clamp is around
the rubber sleeve on the induction tube. Now have 150 hours and it has
worked well.
Note: The CHT and EGT wires need to be at least 2 inches from any high
current wires. The voltage in these wire is so small that the magnetic
field around the high current wire, such as the alternator wire, will
produce very erratic readings.
Dale Ensing
To: RV-List
Sent: Thursday, April 26, 2007 2:51 PM
Subject: RV-List: Engine wiring anchor points
Guys,
and EGT probes.
standoff for the
cable clamp
attachments?
Thanks...
Joe Connell
RV-9A and O-320
In a message dated 4/26/2007 1:54:25 PM Central Daylight Time,
jconnell(at)rconnect.com writes:
Is anyone using the induction tubes from the sump for a clamp and standoff
for the
wires? Also, how about using the sump-to-crankcase attach bolts for cable
clamp
attachments?
I used the induction tubes on my plane for attaching CHT/EGT cables- large
black ty-rap around the rubber tube-to-sump hose with a small ty-rap between it
and the cables with no signs of degradation or loosening- I "believe" the
black ones are preferable in the engine environment to the natural nylon. They
are touted as "weatherable" and "weather" this means UV resistant or what, I'm
not sure, but they have worked well for me. It is standard practice to use
sump bolts as attach points for adel (cushion) clamps...
Mark RV-6A "Mojo" 400+ hrs...
Subject: | Pitot tube cover |
Folks,
I have a 10" L-shaped Gretz heated pitot/static tube and am looking for a cover
for it.
The ones that I have found to be commercially available are all too short.
Any ideas?
Ralph Capen
From: | "John Porter" <december29(at)bellsouth.net> |
Subject: | Re: Pitot tube cover |
Ralph,
I used one from Spruce that is specified for Falcon jets as I remember.
It looks like a black rubber cap that fits over the tip of the tube with a
remove before flight banner attached. The other collection of are all too
short as you've found out ( I have two "extras", ha, ha)
Good hunting,
80002
Sent: Friday, April 27, 2007 10:20 AM
Subject: RV-List: Pitot tube cover
> Folks,
> cover for it.
> Any ideas?
> Ralph Capen
Subject: | [Fwd: 12v supply to stabilize avionics] |
I am purchasing a 12V power supply that takes
6-24V input and gives 12V out at up to 14 A continuous.
It's a 95% efficient switcher with a quiescent current
around 10mA. We need to buy ten of them to get a
better price (about $55).
Why do I want one? Why might you want one?
I have a 1-battery airplane and don't want to rewire the
whole thing. The GPS and radios reboot if they are on when
I start the engine. During cranking, the bus voltage drops
to around 10 V, and the avionics brown out. I want that
problem to go away, and also want to keep the radio working
for a while if the alternator shuts down and the battery drains
below 10V.
So, the solution I am trying is a switching power supply that
converts anything between 6 and 24 V in to a stabilized 12V out.
with 95% efficiency, the lost power is minimal. We would like to
buy 10 units for about $55 each (+ s/h). We've accounted for
four units, so there will be six more available. Who wants one?
-bob mackey
n103md -at- yahoo.com
Subject: | Re: [Fwd: 12v supply to stabilize avionics] |
Leave avionics off while starting the plane. Cost...ZERO.
Ron Lee
Subject: | Advertisement: 6A or 9A cowling for sale |
Sorry about ad, but I recently purchased a cowl for 0-320 updraft carb f
or my conversion rotary to lyc for the 9A. It will fit 6A or 9A. Fixed p
itch (with 2.25 inch spacer) or constant speed props. Decided to do Jame
s cowl again like I had on my 6A.
Van's price is $1100 and I will sell for $1000. Will deliver free SE USA
. You pay freight anywhere else. I have Van's shipping box to ship it in
9A rotary converting to Lyc to sell. Waiting 12, no medical
Bernie Kerr 772 708 0093 jbker(at)juno.com
ft carb for my conversion rotary to lyc for the 9A. It will fit 6A or 9A
. Fixed pitch (with 2.25 inch spacer) or constant speed props. Decided t
o do James cowl again like I had on my 6A.
USA. You pay freight anywhere else. I have Van's shipping box to ship it
in.
Bernie
Kerr 772 708 0093 j
bker(at)juno.com
