RV-Archive.digest.vol-sz
September 18, 2007 - October 10, 2007
Subject: IFR Approaches In An RV
Date: Sep 18, 2007
Also, what type of prop you have. Have been in both and the slow down was amazingly good with the constant speed over fixed. John J -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee Sent: Tuesday, September 18, 2007 7:01 AM Subject: Re: RV-List: IFR Approaches In An RV I question the assertion that it is difficult to slow an RV down. If you come in at full throttle and chop the power as you enter downwind then yes it is. So slow down earlier. Ron Lee ----- Original Message ----- From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com> Sent: Tuesday, September 18, 2007 6:36 AM Subject: RV-List: IFR Approaches In An RV > > I don't mean to turn this into an IFR forum, as there are other forums > for that discussion. However, due to the difficulty of slowing RV's > down, I'm curious how people approach IFR approaches. In other words, > when do you start slowing down, what speeds do you use for precision and > non-precision approaches, when do you start lowering flaps, when do you > finish lowering flaps, and when do you settle into your final approach > configuration. > > > Thanks, > > Daniel Snow > RV-9A, 72 hours > > > > > > ________________________________________________________________________________
Subject: Re: IFR Approaches In An RV
Date: Sep 18, 2007
I have a fixed pitch prop. No problems. Ron Lee ----- Original Message ----- From: "John Jessen" <n212pj(at)gmail.com> Sent: Tuesday, September 18, 2007 9:23 AM Subject: RE: RV-List: IFR Approaches In An RV > > Also, what type of prop you have. Have been in both and the slow down was > amazingly good with the constant speed over fixed. > > John J > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee > Sent: Tuesday, September 18, 2007 7:01 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: IFR Approaches In An RV > > > I question the assertion that it is difficult to slow an RV down. > > If you come in at full throttle and chop the power as you enter downwind > then yes it is. So slow down earlier. > > Ron Lee > > > ----- Original Message ----- > From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com> > To: > Sent: Tuesday, September 18, 2007 6:36 AM > Subject: RV-List: IFR Approaches In An RV > > >> >> I don't mean to turn this into an IFR forum, as there are other forums >> for that discussion. However, due to the difficulty of slowing RV's >> down, I'm curious how people approach IFR approaches. In other words, >> when do you start slowing down, what speeds do you use for precision and >> non-precision approaches, when do you start lowering flaps, when do you >> finish lowering flaps, and when do you settle into your final approach >> configuration. >> >> >> Thanks, >> >> Daniel Snow >> RV-9A, 72 hours >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: RE: IFR Approaches In An RV
Date: Sep 18, 2007
OK, let me rephrase . . . my RV-9A with fixed-pitch prop is noticeably different than my old PA-28-160 when approaching an airport. Can someone please describe the speeds and flap settings you use for the various phases of precision and non-precision approaches? Thanks in advance for help. Daniel ________________________________________________________________________________
Date: Sep 18, 2007
Subject: Re: RE: IFR Approaches In An RV
Snow, Daniel A. wrote: > OK, let me rephrase . . . my RV-9A with fixed-pitch prop is noticeably > different than my old PA-28-160 when approaching an airport. Yes it is, just start slowing a little sooner. :-) Can > someone please describe the speeds and flap settings you use for the > various phases of precision and non-precision approaches? 100kts, no flaps, unless in a hurry, then 120kts. At 100kts, there is plenty of time to slow to flap speed (87kts) after hitting minimums. Once power is pulled to idle, the flaps extended, and the flare initiated, the RV will slow very quickly with most of the runway still in front of you. Sam Buchanan ________________________________________________________________________________
From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: Sep 18, 2007
Daniel, Your speeds should not be any different IFR, VFR, Precision, or non precision. You will fly the same speeds you usually do. One thing you can do to help practice before hand is do some appraoches VFR and follow your needles, carrying your normal approach speeds. Take a mental snapshot or write down, your power setting to maintain your appr oach speed and flaps. This will more easily help you nail a speed on approac h rather than hunting for it like you might do now. Other than that, you will fly your plane the same way you do now in ter ms of landing speeds to make touch down. Best, Mike "Snow, Daniel A." <Daniel.Snow@wanc df.com> To Sent by: owner-rv-list-ser cc ver(at)matronics.com Subj ect RV-List: RE: IFR Approaches In A n 09/18/2007 12:23 RV PM Please respond to rv-list@matronics .com OK, let me rephrase . . . my RV-9A with fixed-pitch prop is noticeably different than my old PA-28-160 when approaching an airport. Can someo ne please describe the speeds and flap settings you use for the various ph ases of precision and non-precision approaches? Thanks in advance for help. Daniel ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Sep 18, 2007
On Sep 18, 2007, at 11:30 AM, Michael W Stewart wrote: > Daniel, > Your speeds should not be any different IFR, VFR, Precision, or non > precision. > You will fly the same speeds you usually do. > My normal VFR approach speed is 65 knots with a very short final. I don't think ATC is going to be happy with that at all with 6 737s following me down the ILS. I like to fly an ILS at around 100 to 120 knots minimum and it does take a long time to slow down with my fixed pitch prop. To be fair, if the 737s were following me VFR I would probably fly even faster, but that situation seems to rarely come up VFR. Larry Pardue ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Sep 18, 2007
Subject: Air Force Completes Transition of GPS Fleet to Upgraded Control
System This is good to see but it makes me a bit nervous to learn that the entire GPS nav data command and control system is in one location and LA none the less...... http://www.losangeles.af.mil/news/story.asp?id=123068412 ________________________________________________________________________________
Subject: high temp cable ties - now - engine mount stresses
Date: Sep 18, 2007
Wow, I've never heard of this before .. And it makes sense. >>Subject: Re: RV-List: high temp cable ties >>From: "Kelly McMullen" <kellym(at)aviating.com> >> >>Regardless of the temps, it is not acceptable to use cable ties on an >>engine mount tube. Oil and dirt get under it and start wearing the tube. >>You need a pair of Adel clamps. >>KM >>A&P/IA So this leads me to two more questions: 1) Given the Engine Mount is a highly stressed piece; is it acceptable to weld a tab so that something can be bolted to it ?? 2) How about Electroless Nickel Plating ??? Larry E. James Bellevue, WA Super Decathlon (flying) Rocket (under contruction - way too long) ________________________________________________________________________________
Subject: Re: Air Force Completes Transition of GPS Fleet to Upgraded Control
System
Date: Sep 18, 2007
no, it's still controlled by squadrons in colorado. the branch of the air force that developed the replacement ground control system is headquartered in LA. The development folks are patting themselves on the back and doing a press release from their HQ in LA.... "AEP was delivered by the Space and Missile Systems Center's GPS Wing to the 50th Space Wing to replace the legacy 1970s-era mainframe computer at Schriever AFB, Colo. " -------------- Original message -------------- From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> This is good to see but it makes me a bit nervous to learn that the entire GPS nav data command and control system is in one location and LA none the less http://www.losangeles.af.mil/news/story.asp?id=123068412
http://www.losangeles.af.mil/news/story.asp?id=123068412>
Subject: Re: high temp cable ties - now - engine mount stresses
Date: Sep 18, 2007
Here are two things that might work to protect the tubes: 1. First wrap the engine mount or structural tube with Aluminium heat duct tape two layers thick then install the cable ties. 2. Use self vulcanizing silicon tape two layers thick then apply the cable ties. I think the tapes would keep moisture away well enough. The silicon tape might help reduce wear due to vibration. Jim in Kelowna ----- Original Message ----- From: Larry James To: rv-list(at)matronics.com Sent: Tuesday, September 18, 2007 2:08 PM Subject: RV-List: high temp cable ties - now - engine mount stresses Wow, I've never heard of this before .. And it makes sense. >>Subject: Re: RV-List: high temp cable ties >>From: "Kelly McMullen" <kellym(at)aviating.com> >> >>Regardless of the temps, it is not acceptable to use cable ties on an >>engine mount tube. Oil and dirt get under it and start wearing the tube. >>You need a pair of Adel clamps. >>KM >>A&P/IA So this leads me to two more questions: 1) Given the Engine Mount is a highly stressed piece; is it acceptable to weld a tab so that something can be bolted to it ?? 2) How about Electroless Nickel Plating ??? Larry E. James Bellevue, WA Super Decathlon (flying) Rocket (under contruction - way too long) ________________________________________________________________________________
Date: Sep 18, 2007
On 15:23 2007-09-18 "Jim Jewell" wrote: > 2. Use self vulcanizing silicon tape two layers thick then apply the > cable ties. I like this solution because the silicone tape is pretty much heat-proof, and the self-vulcanizing aspect means it's not going to slowly unwrap on you like black electrical tape would. That being said, it looks like most of the planes near me have used black electrical tape. Either way, check it when you have the cowlings off, and you'll be fine. You're not going to get enough motion under either kind of tape to wear through the powdercoating on the mount. And you certainly don't need expensive and heavy Adel clamps. -Rob ________________________________________________________________________________
Date: Sep 18, 2007
Daniel, I also have a fixed pitch and you are right that it takes a little longer to slow down. But Mike was right. Fly the same speeds you would VFR. You dont fly VFR approaches at 65kt from 5 mi out from the airport, you gradually slow down to that speed. Do the same for your IFR flying. Gradually slow as you approach the airport. True, that is contrary to the way you may have learned to fly approaches in a c-172: 80kts, pitch for speed, power for altitude, trim up and drone along. You can do the same thing in your RV by slowing to 80 and putting out the flaps at the IAF just like in the cessna. I fly approaches a little different in my -6 (some would say sloppy?). Long about the outer marker I go to idle power. Use pitch to stay on the glide slope. Depending on how fast I was going at the outer marker I either have to eventually add a little power back in to maintain 70-80kts, or when I break out I hold altitude and cross control until I reach flap speed. Slows down pretty quick after that. Timed approach - Whats that? Unconventional yes, but so are these aircraft. Just go do some VMC and you will figure out what you like. JMHO -- David Leonard Turbo Rotary RV-6 N4VY
http://N4VY.RotaryRoster.net http://RotaryRoster.net On 9/18/07, Larry Pardue wrote: > > > On Sep 18, 2007, at 11:30 AM, Michael W Stewart wrote: > > > Daniel, > > Your speeds should not be any different IFR, VFR, Precision, or non > > precision. > > You will fly the same speeds you usually do. > > > My normal VFR approach speed is 65 knots with a very short final. I > don't think ATC is going to be happy with that at all with 6 737s > following me down the ILS. I like to fly an ILS at around 100 to 120 > knots minimum and it does take a long time to slow down with my fixed > pitch prop. > > To be fair, if the 737s were following me VFR I would probably fly > even faster, but that situation seems to rarely come up VFR. > > Larry Pardue > > <http://RotaryRoster.net> ________________________________________________________________________________
Subject: electric aileron trimp kit, part F-7126
Date: Sep 19, 2007
Installing the electric aileron trim kit for an RV-7, I seem to be missing the F-7126 trim links which connect the trim handle to the servo. Unfortun ately, the Optional drawing 19 doesn't have dimensions. Talking to Vans to order the part, they recommend to just make it out of .063 aluminum. Do es anyone have the kit and could trace the part shape? It will be easier t o fabricate if I don't have to do it several times as I guess at the size/s hape. Marty RV-7, Fitting interior systems N622HR> _________________________________________________________________ Connect to the next generation of MSN Messenger- http://imagine-msn.com/messenger/launch80/default.aspx?locale=en-us&sourc e=wlmailtagline ________________________________________________________________________________
Date: Sep 19, 2007
Subject: Re: My losing fight with a prop
Hi Stein, We never know how lucky we are till something goes wrong! I hope your recovery goes well. Ed H RV7A ************************************** See what's new at ________________________________________________________________________________
Date: Sep 19, 2007
=0A =0AIn my RV6A=C2-with fixed pitch prop I fly at 90kts once I am in the ap proach environment. I keep in 10 degrees of flaps, and turn the engine abou t 1800-1900 RPM.=C2- The 10 degrees of flaps tends to make the airplane m ore stable, though that probably isn't necessary in the -9 (a more stable p latform to begin with). Generally I limit climb power to about 2100-2200 RP M which provides 600fpm climb and allows an easier transition back to the 9 0kt speed once I level off. =0A=C2- =0AUsing these numbers the airplane is a much more stable platform.=C2- =0A=C2- =0AI usually give the approach Controller a heads up that I will be dramati cally reducing speed and at what point I intend to do so. =0A=C2- =0AJohn Allen =0A=C2- =0A=0A=C2- ________________________________________________________________________________
Date: Sep 19, 2007
Hi Stein, Did you hear about the girl who backed into a running prop? Disassther :) Get well. -- Walter Tondu http://www.rv7-a.com - Flying! http://www.evorocket.com - Building ________________________________________________________________________________
Date: Sep 19, 2007
Stein: Sorry to hear about your prop trouble-- those things have always scarred me -- I know with your attitude your will make it through this fine -- I always enjoy talking to you. My panel works great and looks good -- mostly due to your advice and hard work. dave P.S. Did you hear about the butcher who backed up into the meat grinder and got a little behind in his work??? ---- hope you don't get too far behind in yours. On Sep 19, 2007, at 8:28 AM, Walter Tondu wrote: > > Hi Stein, > > Did you hear about the girl who backed into a running prop? > > Disassther :) > > Get well. > > > -- > Walter Tondu > http://www.rv7-a.com - Flying! > http://www.evorocket.com - Building > > ________________________________________________________________________________
Date: Sep 19, 2007
Subject: My losing fight with a prop
On 12:10 2007-09-19 Dana Overall wrote: > You know Stein, they make flash tachs that will tell you the RPMs of > the prop so you don't have to stick your fingers in there:-) It sounds like he already has a digital model (or at least he did), but I think he wants a non-contacting model next. :) -Rob ________________________________________________________________________________
Subject: Brake Pedals
Date: Sep 19, 2007
I'm building my RV 7 brake pedals and I decided to buff one up and see how it looks, and it looks marvelous. Obviously, once installed it would be very difficult to keep it in Bristol condition, yet every RV I have seen has worn paint, yada, yada. So, do any of you super experienced builder out there have a way I could get chrome looking brake pedals that may actually last for a little while?? Is it possible to chrome plate the aluminum, or would that compromise the strength some way. I was thinking of buffing and putting on a few heavy coats of clear coat. Any thought here or am I just being too possessed to help myself. Thx Carl ________________________________________________________________________________
Date: Sep 19, 2007
John Cox put it very well. As the manufacturer, you can do what you want. A DAR not finding fault with something does NOT mean it is a good practice or even safe. I can tell you that as an IA, every Tywrap found attached around the engine mount on a TC aircraft will be written up as a discrepancy. Your plane, your experiment, you can do as you choose, at your own risk. > > Kelly McMullen wrote: >> >> Regardless of the temps, it is not acceptable to use cable ties on an >> engine mount tube. Oil and dirt get under it and start wearing the tube. >> You need a pair of Adel clamps. > > True. > > However, the regular ol' nylon zip ties in the engine compartment of my > RV-6, some of which are on mount tubes, were not only passed by the DAR, > but have stood up just fine for eight years and 825 hours and have > caused no damage. > > Maybe it is because oil and dirt are not allowed in the engine > compartment of my plane. :-) > > Sam Buchanan > > ________________________________________________________________________________
Date: Sep 19, 2007
WRONG! Tie wraps will cut steel engine mount tubing regardless of what you have under them. It is just a matter of time. If you don't have a cushion under the tiewrap to prevent it from chafing, it will chafe. But, if you want to have to occasionally replace or reweld your engine mount, be my guest. Just remember that the type certificated industry had about 40 years head start on the experimental category in figuring out how to screw up a perfectly good airplane. You just have the freedom to relearn others mistakes. > You can use tie wraps if you use them properly. You are suppose to use one > to go around both the structure and the cable and don't tighten it but > then use another tie wrap wraped around the first tie wrap in between the > cable and structure to tighten the first tie wrap. If installed properly, > it won't cut into anything. > > Mike ________________________________________________________________________________
Date: Sep 19, 2007
Subject: Flap actuator measurements
I have a question about the dimensions of the flap actuator from Vans. The web doesn't give much info about them. I'm building a 7A but currently have a PL-1 with manual flaps and I'd like to convert them. What I'm looking for is the info of the actuator itself. What is the retracted/extended length of the unit? Can you trim the length if necessary? How heavy is it? I'm thinking of using it in the PL for electrical flaps. I want to make sure it will fit before I actually buy one. I will also be comparing it to those linear actuators from cars/trucks for compatibility. Carlos in AZ -- Carlos Hernandez <carlosh@sec-engr.com> Structural Engineers, LLC 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Subject: Re: Brake Pedals
Date: Sep 19, 2007
Carl, there is a chemical method now used to plate aluminum which overcomes some of the problem way back when chrome plating of aluminum was first tired. While I did not have any aluminum chromed I had my aluminum gear box nickel plated using this technique (it turns it to a soft gold color) which stands up much better than anodizing/alodizing - its much tougher. I was told that it is now used as a prep for chrome plating aluminum - but, I have not tried it for that. You can read up on it if you wish starting here is good. or just goggle Electroless Nickel plating. http://en.wikipedia.org/wiki/Electroless_nickel_plating http://www.corrosion-doctors.org/MetalCoatings/Electroless.htm Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html ----- Original Message ----- From: Carl Bell To: rv-list(at)matronics.com Sent: Wednesday, September 19, 2007 6:21 PM Subject: RV-List: Brake Pedals I'm building my RV 7 brake pedals and I decided to buff one up and see how it looks, and it looks marvelous. Obviously, once installed it would be very difficult to keep it in Bristol condition, yet every RV I have seen has worn paint, yada, yada. So, do any of you super experienced builder out there have a way I could get chrome looking brake pedals that may actually last for a little while?? Is it possible to chrome plate the aluminum, or would that compromise the strength some way. I was thinking of buffing and putting on a few heavy coats of clear coat. Any thought here or am I just being too possessed to help myself. Thx Carl ________________________________________________________________________________
Date: Sep 19, 2007
Anyone ever heard of *Koroseal* (as sold by AC-Spruce and others) http://www.aircraftspruce.com/catalog/elpages/lacing.php That is the product I would use in the engine compartment instead of tie-wraps, based on input from much smarter people then myself. Just because we Experimenters can do whatever they want does not necessarily make it a necessarily great move... ----- Original Message ----- From: Kelly McMullen To: rv-list(at)matronics.com Sent: Wednesday, September 19, 2007 5:28 PM Subject: Re: RV-List: high temp cable ties John Cox put it very well. As the manufacturer, you can do what you want. A DAR not finding fault with something does NOT mean it is a good practice or even safe. I can tell you that as an IA, every Tywrap found attached around the engine mount on a TC aircraft will be written up as a discrepancy. Your plane, your experiment, you can do as you choose, at your own risk. > > Kelly McMullen wrote: >> >> Regardless of the temps, it is not acceptable to use cable ties on an >> engine mount tube. Oil and dirt get under it and start wearing the tube. >> You need a pair of Adel clamps. > > True. > > However, the regular ol' nylon zip ties in the engine compartment of my > RV-6, some of which are on mount tubes, were not only passed by the DAR, > but have stood up just fine for eight years and 825 hours and have > caused no damage. > > Maybe it is because oil and dirt are not allowed in the engine > compartment of my plane. :-) > > Sam Buchanan > > > > ________________________________________________________________________________
Date: Sep 19, 2007
Carl, I chose to powder coat my RV-10 pedals (they look more like chrome in person). I have zero idea how long my pedals will stay in this condition. My white painted RV-6A pedals don't look bad after 375 hours. Attached are my RV-10 pedals. Robin ndition10 pedals an from HumidTech ________________________________________________________________________________
Date: Sep 19, 2007
On 09/19 4:43, Kelly McMullen wrote: > WRONG! Tie wraps will cut steel engine mount tubing regardless of what > you have under them. It is just a matter of time. If you don't have a I wrap engine mount tubing with 3 to 4 wraps of self-sticking silicone tape and put the tie wrap on that. Some of the tape should also be wrapped around any part being held with the tie wrap as well. No way that will cut through in my lifetime. http://www.aircraftspruce.com/catalog/appages/uniwrap.php -- Walter Tondu http://www.rv7-a.com - Flying! http://www.evorocket.com - Building ________________________________________________________________________________
Date: Sep 19, 2007
Mark, What color did you use when you coated the brake pedals to look like chrome? Who does this kind of painting and what is the charge for something like this. BTW they look great. Thx Carl _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Wednesday, September 19, 2007 9:09 PM Subject: RE: RV-List: Brake Pedals Carl, I chose to powder coat my RV-10 pedals (they look more like chrome in person). I have zero idea how long my pedals will stay in this condition. My white painted RV-6A pedals don't look bad after 375 hours. Attached are my RV-10 pedals. Robin ndition10 pedals an from HumidTech ________________________________________________________________________________
From: "Michael A Taylor" <mktaylor(at)frontiernet.net>
Subject: RV-8A baggage door lock
Date: Sep 19, 2007
Has anybody found any other system to latch the forward baggage door other than Van's lock? I'm wondering if a Hartwell latch would be more secure? Thanks ________________________________________________________________________________
Date: Sep 20, 2007
Carl, check out some of the supplier sites for color options and info. i use caswell plating (caswellplating.com) out of Rochester NY. they have a wealth of information if your interested in doing it yourself or want to see what colors are available. There are a couple chrome like options. if you prep the pedals you really shouldn't pay more than 5-10 bucks apiece at a retail shop as they only take 10 mins or so in a 400 deg oven to cure. Steven dinieri 40205 iflyrv10.com _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Carl Bell Sent: Wednesday, September 19, 2007 10:02 PM Subject: RE: RV-List: Brake Pedals Mark, What color did you use when you coated the brake pedals to look like chrome? Who does this kind of painting and what is the charge for something like this. BTW they look great. Thx Carl _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Wednesday, September 19, 2007 9:09 PM Subject: RE: RV-List: Brake Pedals Carl, I chose to powder coat my RV-10 pedals (they look more like chrome in person). I have zero idea how long my pedals will stay in this condition. My white painted RV-6A pedals don't look bad after 375 hours. Attached are my RV-10 pedals. Robin ndition10 pedals an from HumidTech ________________________________________________________________________________
Date: Sep 20, 2007
Here's a link to AC 43-13-1B covering wiring bundles, etc. I do not imagine it is required to be followed on experimentals, but it certainly is a good guide... http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2011.pdf Hope this helps! Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Mike Divan wrote: > I have been watching the cable tie debate with interest. Lots of > things to think about on both sides. My little bird is extremely well > built (by someone other than me so I can say that) it has cable ties > and 590 + hours. Checking my little bird out I have noticed that the > cable ties hav e abraded some paint. I have looked at a 6 just a > couple hangers away with well over 2000 hours, adle clamps and no > abraded paint. I will be replacing the cable ties with adle (however > you spell it) clamps over time. It just seems better to not have > abraded paint. Anyone trying to decide is welcome to come over and > take a look if that will help you make a decision. Don't know what is > wright or wrong or acceptable in this case I just know what I have > observed and the clamps appear at least to me to be a better choice. > > Mike Divan > Adopted - N64GH (RV6) > RV7 Builder - SLOW > EAA - 577486 > FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS! > > ________________________________________________________________________________
Subject: Landing gear fairing cuff
Date: Sep 20, 2007
I didn't build my -6, so I hope one of you can help me. The fiberglass cuff that closes the gap between the landing gear leg fairing and the fuselage. are held in place by a spring and wire attachment. I assume it was part of the original build plan. One of these springs broke and I replaced with a similar looking hardware store spring. It did not last one flight. Can anyone Identify the spring and a source? Thanks ________________________________________________________________________________
Subject: Re: Landing gear fairing cuff
Date: Sep 20, 2007
It would not have been part of the original kit and is a design area le ft up to the builder. Ace hardware in the aviation section is probably a good choice for replacement springs. Best, Mike "George Tyler" To Sent by: owner-rv-list-ser cc ver(at)matronics.com Subj ect RV-List: Landing gear fairing cu ff 09/20/2007 08:10 AM Please respond to rv-list@matronics .com I didn't build my -6, so I hope one of you can help me. The fiberglass cuff that closes the gap between the landing gear leg fairing and the fusela ge. are held in place by a spring and wire attachment. I assume it was part of the original build plan. One of these springs broke and I replaced wit h a similar looking hardware store spring. It did not last one flight. Can anyone Identify the spring and a source? Thanks ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Sep 20, 2007
Subject: Possible Scam
All, I've had my RV-8A advertised in Trade-A-Plane now for a few weeks and recently had an email dialogue with someone I believe to be a scam artist. Here's what occurred: The first inquiry from this person indicated he was very interested and asked what type of payment would be acceptable - cashier's check, bank draft or bank wire. His sentence structure and wording indicated to me that english was probably not his native language. He also asked for some pictures via email which I sent and I advised him that I had a CD disk with lots of pix, etc., which I could send by snail mail if he would give me his address. That never happened. Supposedly this person was in europe at the time attending a conference which was to conclude in a few days, after which he could set up a date to come look at the plane. His last email said that he could not personally check out the plane because he had been reassigned to "western europe" - he then proposed that an "inspection/moving representative" come by and look at the plane. In the meantime, he would send me a "check/bankdraft" for $105K and I would deposit to my bank account. I would keep 20% as a deposit on the plane and write a check for the remainder to the representative to cover inspection and moving expenses. When I received this last email, I replied that his method of payment was not acceptable and that I would require a bank wire for 10% deposit and another bank wire for the remainder if his representative found the plane to his liking, and that any expenses by the representative would be a matter between that person and the buyer. Since my last response I have heard nothing. It's possible this guy was a bonafide buyer, but I seriously doubt it ........... In fact, I spoke with a person in sales at TAP and was told they have heard of numerious scams concerning the sale of aircraft. Soooo, just passing it on, if you have an airplane for sale be very careful! Walt Shipley RV-8, RV-8A ________________________________________________________________________________
Subject: Re: RV-8A baggage door lock
Date: Sep 20, 2007
Hey Mike, I used the Van's system and if it is adjusted correctly, it really does a good job of pulling the baggage door down tightly against the supports. I also used John Huft's design for the hidden hinge, it worked out very well and looks good. He has a link from the Vans web sight. Paul Rice RV8 N64PR 45 hours ----- Original Message ----- From: Michael A Taylor<mailto:mktaylor(at)frontiernet.net> To: rv-list(at)matronics.com Sent: Wednesday, September 19, 2007 10:36 PM Subject: RV-List: RV-8A baggage door lock Has anybody found any other system to latch the forward baggage door other than Van's lock? I'm wondering if a Hartwell latch would be more secure? Thanks http://www.matronics.com/Navigator?RV-List ator?RV-List> ________________________________________________________________________________
Date: Sep 20, 2007
I use two bolts with platenuts to hold mine on. One in front and one on the side. Seems to work well and are easy to take off. Bob RV6 "Wicked Witch of the West" At 07:49 AM 9/20/07, you wrote: >It would not have been part of the original kit and is a design area >left up to the builder. >Ace hardware in the aviation section is probably a good choice for >replacement springs. >Best, >Mike > >Inactive hide details for "George Tyler" "George Tyler" > >"George Tyler" Sent by: >owner-rv-list-server(at)matronics.com > >09/20/2007 08:10 AM >Please respond to rv-list(at)matronics.com >[] > >To > > >[] > >cc > >[] > >Subject > >RV-List: Landing gear fairing cuff > >I didn't build my -6, so I hope one of you can help me. The >fiberglass cuff that closes the gap between the landing gear leg >fairing and the fuselage. are held in place by a spring and wire >attachment. I assume it was part of the original build plan. One of >these springs broke and I replaced with a similar looking hardware >store spring. It did not last one flight. Can anyone Identify the >spring and a source? Thanks > > >==================================== >?RV-List">
http://www.matronics.com/Navigator?RV-List >==================================== >u>http://forums.matronics.com >==================================== > > ________________________________________________________________________________
Date: Sep 20, 2007
What some folks have been missing in this discussion is that your engine mount is rather important, and is designed for that single purpose. It is not designed to be the hangar or mount for a bunch of other stuff. Minimize what you attach to the mount by any means, and use the best techniques you can if you feel you have to attach something to the mount. Nuff said. > I have been watching the cable tie debate with interest. Lots of things to > think about on both sides. My little bird is extremely well built (by > someone other than me so I can say that) it has cable ties and 590 + > hours. Checking my little bird out I have noticed that the cable ties hav > e abraded some paint. I have looked at a 6 just a couple hangers away with > well over 2000 hours, adle clamps and no abraded paint. I will be > replacing the cable ties with adle (however you spell it) clamps over > time. It just seems better to not have abraded paint. Anyone trying to > decide is welcome to come over and take a look if that will help you make > a decision. Don't know what is wright or wrong or acceptable in this case > I just know what I have observed and the clamps appear at least to me to > be a better choice. > > Mike Divan > Adopted - N64GH (RV6) > RV7 Builder - SLOW > EAA - 577486 > FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS! > > ----- Original Message ---- > From: John W. Cox <johnwcox(at)pacificnw.com> > To: rv-list(at)matronics.com > Sent: Wednesday, September 19, 2007 6:41:46 PM > Subject: RE: RV-List: high temp cable ties > ________________________________________________________________________________
Date: Sep 20, 2007
Depending on how hands on you are or how much you are into collecting tools , you can easily do small parts yourself. Here is a popular system with a load of different powders.... http://www.eastwoodco.com/jump.jsp?itemID=412&itemType=PRODUCT&path=1 %2C2%2C458%2C459%2C460&KickerID=68&KICKER http://www.eastwoodco.com/jump.jsp?itemID=845&itemType=CATEGORY http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=18797&it emType=PRODUCT&iMainCat=844&iSubCat=847&iProductID=18797 Michael Sausen -10 Limbo From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Carl Bell Sent: Wednesday, September 19, 2007 9:02 PM Subject: RE: RV-List: Brake Pedals Mark, What color did you use when you coated the brake pedals to look like chrome ? Who does this kind of painting and what is the charge for something like this. BTW they look great. Thx Carl ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Robin Marks Sent: Wednesday, September 19, 2007 9:09 PM Subject: RE: RV-List: Brake Pedals Carl, I chose to powder coat my RV-10 pedals (they look more like chr ome in person). I have zero idea how long my pedals will stay in this condi tion. My white painted RV-6A pedals don't look bad after 375 hours. Attache d are my RV-10 pedals. Robin ndition10 pedals an from HumidTech ________________________________________________________________________________
Date: Sep 20, 2007
Subject: Re: Possible Scam
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Sep 20, 2007
Thanks Carl, The pedals are powder coated not painted. I selected the chrome color (and the blue) from a list of color choices making sure to select powder coatings that had a high durability rating and had a UV inhibitor component so they would not change color over time when exposed to the sun. Using the powder coating material rated for "exterior" is a good start. As far as cost is concerned that may depend on who you take your parts to however I have found that the biggest cost is the first piece, if you have a selection of 12 parts all the same color it probably will not cost much more than having one piece done since there is a bit of set up involved and spraying 12 parts on a rack is just about as easy as spraying one part. I know there are MANY people on the list more qualified to discuss this process on the list me but if cost is a concern or you are one of the "do everything yourself types" then you can powder coat (PC) your parts yourself relatively inexpensively. I own a manufacturing facility and we set up a PC booth out of half a refrigerator box and coat hangers. One can buy a PC gun on eBay new for $100.00 and the actual powder is inexpensive. The only problem is that a sprayed part needs to be baked in an oven for 10-20 minutes at 350-400 degrees (time & temp specified by powder manufacturer). It is not difficult to get good at this but I warn you that once you start it's hard to stop powder coating things. Also note that the oven should not be used for food once it has been used for powder coating. I have purchased PC powder from this company for some home furnishing projects. Ebay is also a good source for powder. https://www.pendrypowdercoatings.com/shop/index.php?osCsid=949392b82a9d 5 6a221209d308cdf6b23 Good luck, Robin Marks ________________________________________________________________________________
Date: Sep 20, 2007
All that will get you is a $25 charge from your bank when the check bounces. >> How about taking the larger then asking price (although fake) check and then simply >> disappear on the scammer..... Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Date: Sep 20, 2007
The good news is that this only represented a financial scam... A friend of a friend was selling his mint condition Arizona based Baron. He received a call from an interested party and took them up for a flight. They never returned. Long story/short. The "buyer" had been released from prison the day before; he got cleaned up and started placing calls to purchase an airplane. Apparently on the demo flight the convict either killed or disabled the seller then landed in the desert where he may have finished the job and dumped the body. The owner was missing for about 4 weeks (from my recollection). The authorities found the body around the same time the convict was caught in the process of committing another crime in another state. The authorities has no idea that this was a crime as it looked more like a missing plane in the desert. Because of the relatively short time between first call and the flight very few people were in the loop as to who the "buyer" was and what the plans were relative to the demo flight. Basically no one knew this was a "plane jacking" till his body was discovered. There are many lessons here but I don't know where to begin to discuss them. Let's be careful out there, Robin ________________________________________________________________________________
Date: Sep 20, 2007
Subject: Re: Cornonado Airport
When did they close Coronado and why? I used to fly in NM, my RV spent much of it's live in NM before it was completed.. Always hate to hear of airport closures. Bob RV6 "Wicked Witch of the West" At 12:07 PM 9/20/07, you wrote: >Dear Robin, >Unfortunately, your story it true... >The plane ended up at the (now closed) Coronado Airport here in >Albuquerque, NM, with the victims blood all over the interior... > ________________________________________________________________________________
Date: Sep 20, 2007
Thanks for the info. I was hoping someone would tell me what they did if not the spring. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Sent: Thursday, September 20, 2007 10:20 AM Subject: Re: RV-List: Landing gear fairing cuff I use two bolts with platenuts to hold mine on. One in front and one on the side. Seems to work well and are easy to take off. Bob RV6 "Wicked Witch of the West" At 07:49 AM 9/20/07, you wrote: >It would not have been part of the original kit and is a design area >left up to the builder. >Ace hardware in the aviation section is probably a good choice for >replacement springs. >Best, >Mike > >Inactive hide details for "George Tyler" "George Tyler" > >"George Tyler" Sent by: >owner-rv-list-server(at)matronics.com > >09/20/2007 08:10 AM >Please respond to rv-list(at)matronics.com >[] > >To > > >[] > >cc > >[] > >Subject > >RV-List: Landing gear fairing cuff > >I didn't build my -6, so I hope one of you can help me. The >fiberglass cuff that closes the gap between the landing gear leg >fairing and the fuselage. are held in place by a spring and wire >attachment. I assume it was part of the original build plan. One of >these springs broke and I replaced with a similar looking hardware >store spring. It did not last one flight. Can anyone Identify the >spring and a source? Thanks > > >==================================== >?RV-List">http://www.matronics.com/Navigator?RV-List >==================================== >u>http://forums.matronics.com >==================================== > > ________________________________________________________________________________
Date: Sep 20, 2007
If that is at the north edge of Albuquerque, it has been several years. Consider AEG Ron Lee ----- Original Message ----- From: "Bob" <panamared5(at)brier.net> Sent: Thursday, September 20, 2007 12:23 PM Subject: Re: RV-List: Cornonado Airport > > When did they close Coronado and why? I used to fly in NM, my RV > spent much of it's live in NM before it was completed.. Always hate > to hear of airport closures. > > Bob > RV6 "Wicked Witch of the West" > > > At 12:07 PM 9/20/07, you wrote: >>Dear Robin, >>Unfortunately, your story it true... >>The plane ended up at the (now closed) Coronado Airport here in >>Albuquerque, NM, with the victims blood all over the interior... >> > > > > > > > ________________________________________________________________________________
Subject: Canopy part way open latch
Date: Sep 20, 2007
Hi all, I don't have any locks on my canopy but would like to put a latch of some kind where it would stay open just about 4 inches. The problem is when I am taxing I like to leave it ajar so I can get the breeze in. It doesn't really stay there by itself as it tries to slide on back. It will stay if I push it almost closed but then it is too easy to forget to latch it. Does anybody have an idea or something they have done to put a small latch inside for keeping it just a few inches open? I am wondering about the stock locks that go in the canopy. They provide for a means to lock in partly open as well but wasn't sure if that was operable from inside without the key in the lock. Someday I may install the stock lock system but it seemed so un-secure that I didn't really see the point. I keep my plane in a hangar but when I travel it obviously is out on the ramp. Any ideas would be appreciated. RV-6 Tim ________________________________________________________________________________
Date: Sep 20, 2007
Bob wrote: > > When did they close Coronado and why? I used to fly in NM, my RV > spent much of it's live in NM before it was completed.. Always hate > to hear of airport closures. > > Bob > RV6 "Wicked Witch of the West" The airport was on the Sandia Indian Reservation (they bought it in 1994 under a corporation name not clearly associated at the time with the tribe) and they no longer wanted it. The reason given was closure for 'safety'. That sort of was true....they subsequently built a Casino just NE of the approach end of runway 17 that would have had aircraft overflying the facility. Go to http://www.airfields-freeman.com/NM/Airfields_NM_Albuquerque.html#coronado where you can see an aerial photo of the airport and casino, and a link to the 'official' explanation. ________________________________________________________________________________
Date: Sep 20, 2007
I cut cereal box cardboard in an L shape. The long part is .25" by 1.5". the other part is the handle. One or 2 layers is enough thickness to keep my slider from sliding when put under the roller and rolling it back. You can cut and fold in such a way to get 2 or 3 layers, and one layer can be shorter to keep the roller from going back. Like a mini wheel chock. Dale -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Thursday, September 20, 2007 2:37 PM Subject: RV-List: Canopy part way open latch Hi all, I don't have any locks on my canopy but would like to put a latch of some kind where it would stay open just about 4 inches. The problem is when I am taxing I like to leave it ajar so I can get the breeze in. It doesn't really stay there by itself as it tries to slide on back. It will stay if I push it almost closed but then it is too easy to forget to latch it. Does anybody have an idea or something they have done to put a small latch inside for keeping it just a few inches open? I am wondering about the stock locks that go in the canopy. They provide for a means to lock in partly open as well but wasn't sure if that was operable from inside without the key in the lock. Someday I may install the stock lock system but it seemed so un-secure that I didn't really see the point. I keep my plane in a hangar but when I travel it obviously is out on the ramp. Any ideas would be appreciated. RV-6 Tim ________________________________________________________________________________
Date: Sep 20, 2007
Subject: Re: Canopy part way open latch
Tim, I have a simple lock that has worked for years and is really simple,which I need. I took a piece of piano wire and put a small loop in one end for a screw to fit through,then about 4-6 inchs from that I bent it 90* . I fastened this to the front of canopy near the roller and drilled a hole through the rail at the distance I wanted the canopy open. The 90* bend goes in this hole and the canopy stays open.Simpler to do than try and explain. Ollie 6A Central Fl. On 9/20/07, Tim Bryan wrote: > > > Hi all, > > I don't have any locks on my canopy but would like to put a latch of some > kind where it would stay open just about 4 inches. The problem is when I > am > taxing I like to leave it ajar so I can get the breeze in. It doesn't > really stay there by itself as it tries to slide on back. It will stay if > I > push it almost closed but then it is too easy to forget to latch it. > > Does anybody have an idea or something they have done to put a small latch > inside for keeping it just a few inches open? > > > I am wondering about the stock locks that go in the canopy. They provide > for a means to lock in partly open as well but wasn't sure if that was > operable from inside without the key in the lock. Someday I may install > the > stock lock system but it seemed so un-secure that I didn't really see the > point. I keep my plane in a hangar but when I travel it obviously is out > on > the ramp. > > Any ideas would be appreciated. > RV-6 > Tim > > ________________________________________________________________________________
Date: Sep 20, 2007
Check with the RV8 guys....when they're flying solo they wouldn't want that thing sliding all the way back. I've got a note in to my local -8 driver - I know he did his that way. -----Original Message----- >From: Tim Bryan <n616tb(at)btsapps.com> >Sent: Sep 20, 2007 2:36 PM >To: rv-list(at)matronics.com >Subject: RV-List: Canopy part way open latch > > >Hi all, > >I don't have any locks on my canopy but would like to put a latch of some >kind where it would stay open just about 4 inches. The problem is when I am >taxing I like to leave it ajar so I can get the breeze in. It doesn't >really stay there by itself as it tries to slide on back. It will stay if I >push it almost closed but then it is too easy to forget to latch it. > >Does anybody have an idea or something they have done to put a small latch >inside for keeping it just a few inches open? > > >I am wondering about the stock locks that go in the canopy. They provide >for a means to lock in partly open as well but wasn't sure if that was >operable from inside without the key in the lock. Someday I may install the >stock lock system but it seemed so un-secure that I didn't really see the >point. I keep my plane in a hangar but when I travel it obviously is out on >the ramp. > >Any ideas would be appreciated. >RV-6 >Tim > > ________________________________________________________________________________
Date: Sep 21, 2007
Walt, Glad you weren't taken in by this. I used to work for an ISP and we got reports of this sort of thing left and right. Friends in banking and law enforcement and they report the same. First time I've heard of this being done for an airplane. Then again, maybe they just want the check and not the plane. The newest Internet scam I am aware of is "free" pure breed puppies if you pay $800 to have them shipped from Africa. They would be full grown by the time they got through quarantine. Well, that assumes the puppies exist at all. Mark rveighta wrote: > > All, I've had my RV-8A advertised in Trade-A-Plane now for a few weeks and recently had an email dialogue with someone I believe to be a scam artist. Here's what occurred: > > The first inquiry from this person indicated he was very interested and asked what type of payment would be acceptable - cashier's check, bank draft or bank wire. His sentence structure and wording indicated to me that english was probably not his native language. He also asked for some pictures via email which I sent and I advised him that I had a CD disk with lots of pix, etc., which I could send by snail mail if he would give me his address. That never happened. > > Supposedly this person was in europe at the time attending a conference which was to conclude in a few days, after which he could set up a date to come look at the plane. His last email said that he could not personally check out the plane because he had been reassigned to "western europe" - he then proposed that an "inspection/moving representative" come by and look at the plane. In the meantime, he would send me a "check/bankdraft" for $105K and I would deposit to my bank account. I would keep 20% as a deposit on the plane and write a check for the remainder to the representative to cover inspection and moving expenses. > > When I received this last email, I replied that his method of payment was not acceptable and that I would require a bank wire for 10% deposit and another bank wire for the remainder if his representative found the plane to his liking, and that any expenses by the representative would be a matter between that person and the buyer. Since my last response I have heard nothing. It's possible this guy was a bonafide buyer, but I seriously doubt it ........... In fact, I spoke with a person in sales at TAP and was told they have heard of numerious scams concerning the sale of aircraft. > > Soooo, just passing it on, if you have an airplane for sale be very careful! > > Walt Shipley RV-8, RV-8A > > > ________________________________________________________________________________
Date: Sep 20, 2007
Mike Divan wrote: > I have been watching the cable tie debate with interest. Lots of > things to think about on both sides. My little bird is extremely well > built (by someone other than me so I can say that) it has cable ties > and 590 + hours. Checking my little bird out I have noticed that the > cable ties hav e abraded some paint. I have looked at a 6 just a > couple hangers away with well over 2000 hours, adle clamps and no > abraded paint. I will be replacing the cable ties with adle (however > you spell it) clamps over time. It just seems better to not have > abraded paint. Anyone trying to decide is welcome to come over and > take a look if that will help you make a decision. Don't know what is > wright or wrong or acceptable in this case I just know what I have > observed and the clamps appear at least to me to be a better choice. Since my original post has been quoted on several of the replies in this thread, I want to clear up a couple of things: 1) I agreed with the the person to whom I replied that adel clamps are the preferred way to secure item to the engine mount tubes. I have several adel clamps in my engine installation. 2) I disagree with the assertion that the use of cable ties will always doom your engine mount to certain damage. Mine and the experience of many other builders would invalidate this position. Our engine compartments are monitored much more closely than many certificated planes and we have ample opportunity to catch problems before they become problems. If you have used cable ties to attach wiring to the mount, then replacing them with adel clamps would certainly be in keeping with certificated practice. But if the ties remain in place, just keep an eye on them and replace them if/when you see anything that bothers you. Common sense rules. :-) Sam Buchanan ________________________________________________________________________________
Subject: forsale Icom A200
Date: Sep 20, 2007
On www.vansairforce.net there is a group buy for the new Icom A210. I have joined in on this deal (They should cost around $1100 or so) . The A210 is a plug and play with the A200 so I will be selling my A200 with a new tray. I started using this new NON TSO A200 in Feb 2007. It has worked great but I would like the ability to monitor a standby freq. I think I paid around $700 for the A200 and will be looking to sell the A200 around $600 and I will pay ground shipping to the 48 states. The group buy ends Oct 12 so I would think the A200 will be shipped within 30 days of that time. I hate to let it sit on the shelf waiting for the next project. No money now......just someone that says they want it and I will contact you when the new radio is here. Any takers? Sal Capra N898SC? RV8 Lakeland FL ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 20, 2007
Sound like a scam to me. I don't understand why they would send more than a down payment and ask you to refund a portion of the check unless their $105K check was worthless and you sent off a check before that fact would have been discovered. Sounds like you were alert and it was good for you to insist on normal terms like they send you X% down and the rest at delivery... Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) rveighta wrote: > >All, I've had my RV-8A advertised in Trade-A-Plane now for a few weeks and recently had an email dialogue with someone I believe to be a scam artist. Here's what occurred: > >The first inquiry from this person indicated he was very interested and asked what type of payment would be acceptable - cashier's check, bank draft or bank wire. His sentence structure and wording indicated to me that english was probably not his native language. He also asked for some pictures via email which I sent and I advised him that I had a CD disk with lots of pix, etc., which I could send by snail mail if he would give me his address. That never happened. > >Supposedly this person was in europe at the time attending a conference which was to conclude in a few days, after which he could set up a date to come look at the plane. His last email said that he could not personally check out the plane because he had been reassigned to "western europe" - he then proposed that an "inspection/moving representative" come by and look at the plane. In the meantime, he would send me a "check/bankdraft" for $105K and I would deposit to my bank account. I would keep 20% as a deposit on the plane and write a check for the remainder to the representative to cover inspection and moving expenses. > >When I received this last email, I replied that his method of payment was not acceptable and that I would require a bank wire for 10% deposit and another bank wire for the remainder if his representative found the plane to his liking, and that any expenses by the representative would be a matter between that person and the buyer. Since my last response I have heard nothing. It's possible this guy was a bonafide buyer, but I seriously doubt it ........... In fact, I spoke with a person in sales at TAP and was told they have heard of numerious scams concerning the sale of aircraft. > >Soooo, just passing it on, if you have an airplane for sale be very careful! > >Walt Shipley RV-8, RV-8A > > > > ________________________________________________________________________________
Date: Sep 20, 2007
On the other hand, I have seen damage on our 6a caused by cable ties. Most places, it just wore through the paint. Other places, it did some some damage to the metal. We still have some cable ties, but now they have tape or rubber hose between them and the engine mount. I highly recommend protecting the engine mount from cable ties and any other possible cause of chafing. Even if the metal isn't damaged, it is unprotected from corrosion unless you chase it down, prime and paint it. Pax, Ed Holyoke Sam Buchanan wrote: > > Mike Divan wrote: > >> I have been watching the cable tie debate with interest. Lots of >> things to think about on both sides. My little bird is extremely well >> built (by someone other than me so I can say that) it has cable ties >> and 590 + hours. Checking my little bird out I have noticed that the >> cable ties hav e abraded some paint. I have looked at a 6 just a >> couple hangers away with well over 2000 hours, adle clamps and no >> abraded paint. I will be replacing the cable ties with adle (however >> you spell it) clamps over time. It just seems better to not have >> abraded paint. Anyone trying to decide is welcome to come over and >> take a look if that will help you make a decision. Don't know what is >> wright or wrong or acceptable in this case I just know what I have >> observed and the clamps appear at least to me to be a better choice. > > > Since my original post has been quoted on several of the replies in > this thread, I want to clear up a couple of things: > > 1) I agreed with the the person to whom I replied that adel clamps are > the preferred way to secure item to the engine mount tubes. I have > several adel clamps in my engine installation. > > 2) I disagree with the assertion that the use of cable ties will > always doom your engine mount to certain damage. Mine and the > experience of many other builders would invalidate this position. > > Our engine compartments are monitored much more closely than many > certificated planes and we have ample opportunity to catch problems > before they become problems. If you have used cable ties to attach > wiring to the mount, then replacing them with adel clamps would > certainly be in keeping with certificated practice. But if the ties > remain in place, just keep an eye on them and replace them if/when you > see anything that bothers you. > > Common sense rules. :-) > > Sam Buchanan > > ________________________________________________________________________________
Date: Sep 20, 2007
Good grief......now my post to clear up how I was originally misquoted has been misquoted......... Guess I will just have to go hang myself with some oil-soaked, abraded nylon cable ties..... ;-) Sam Buchanan ====================== Ed wrote: > > On the other hand, I have seen damage on our 6a caused by cable ties. > Most places, it just wore through the paint. Other places, it did some > some damage to the metal. We still have some cable ties, but now they > have tape or rubber hose between them and the engine mount. I highly > recommend protecting the engine mount from cable ties and any other > possible cause of chafing. Even if the metal isn't damaged, it is > unprotected from corrosion unless you chase it down, prime and paint it. > > Pax, > > Ed Holyoke > > Sam Buchanan wrote: > >> >> Mike Divan wrote: >> >>> I have been watching the cable tie debate with interest. Lots of >>> things to think about on both sides. My little bird is extremely well >>> built (by someone other than me so I can say that) it has cable ties >>> and 590 + hours. Checking my little bird out I have noticed that the >>> cable ties hav e abraded some paint. I have looked at a 6 just a >>> couple hangers away with well over 2000 hours, adle clamps and no >>> abraded paint. I will be replacing the cable ties with adle (however >>> you spell it) clamps over time. It just seems better to not have >>> abraded paint. Anyone trying to decide is welcome to come over and >>> take a look if that will help you make a decision. Don't know what is >>> wright or wrong or acceptable in this case I just know what I have >>> observed and the clamps appear at least to me to be a better choice. >> >> >> >> Since my original post has been quoted on several of the replies in >> this thread, I want to clear up a couple of things: >> >> 1) I agreed with the the person to whom I replied that adel clamps are >> the preferred way to secure item to the engine mount tubes. I have >> several adel clamps in my engine installation. >> >> 2) I disagree with the assertion that the use of cable ties will >> always doom your engine mount to certain damage. Mine and the >> experience of many other builders would invalidate this position. >> >> Our engine compartments are monitored much more closely than many >> certificated planes and we have ample opportunity to catch problems >> before they become problems. If you have used cable ties to attach >> wiring to the mount, then replacing them with adel clamps would >> certainly be in keeping with certificated practice. But if the ties >> remain in place, just keep an eye on them and replace them if/when you >> see anything that bothers you. >> >> Common sense rules. :-) >> >> Sam Buchanan ________________________________________________________________________________
Date: Sep 20, 2007
From: Michael Hilderbrand <m_hilderbrand(at)sbcglobal.net>
I had a similar situation trying to sell some of my RC stuff. This perosn actually sent me a cashiers check! I took it to the bank and they looked i nto the check, oh yeah, it was fraudulent! As long as they are out of the country, I guess there is nothing a person can really do about it... buyer beware! If it sounds fishy.. it probably is. =0A =0AMichael Hilderbrand =0ADerby, Kansas=0A =0A=0A=0A=0A----- Original Message ----=0AFrom: rveight a =0ATo: "rv-list(at)matronics.com" =0ASent: Thursday, September 20, 2007 8:15:18 AM=0ASubject: RV-List: P hlink.net>=0A=0AAll, I've had my RV-8A advertised in Trade-A-Plane now for a few weeks and recently had an email dialogue with someone I believe to be a scam artist. Here's what occurred:=0A=0AThe first inquiry from this pers on indicated he was very interested and asked what type of payment would be acceptable - cashier's check, bank draft or bank wire. His sentence struct ure and wording indicated to me that english was probably not his native la nguage. He also asked for some pictures via email which I sent and I advise d him that I had a CD disk with lots of pix, etc., which I could send by sn ail mail if he would give me his address. That never happened.=0A=0ASuppose dly this person was in europe at the time attending a conference which was to conclude in a few days, after which he could set up a date to come look at the plane. His last email said that he could not personally check out th e plane because he had been reassigned to "western europe" - he then propos ed that an "inspection/moving representative" come by and look at the plane . In the meantime, he would send me a "check/bankdraft" for $105K and I wo uld deposit to my bank account. I would keep 20% as a deposit on the plane and write a check for the remainder to the representative to cover inspecti on and moving expenses.=0A=0AWhen I received this last email, I replied tha t his method of payment was not acceptable and that I would require a bank wire for 10% deposit and another bank wire for the remainder if his represe ntative found the plane to his liking, and that any expenses by the represe ntative would be a matter between that person and the buyer. Since my last response I have heard nothing. It's possible this guy was a bonafide buyer, but I seriously doubt it ........... In fact, I spoke with a person in sal es at TAP and was told they have heard of numerious scams concerning the sa le of aircraft.=0A=0ASoooo, just passing it on, if you have an airplane for ================ ________________________________________________________________________________
Date: Sep 20, 2007
Subject: A123 Systems Batteries in new Cessna
Here is a link to the article: http://home.businesswire.com/portal/site/home/index.jsp?ndmViewId=news_view&ndmConfigId=1000001&newsId 070919005033&newsLang=en Cessna is going to use A123 Systems Nano-phosphate batteries in their jets. These are the same batteries I use in my electric drag bike. As I said over a year ago, these are prefect batteries for aircraft applications. Lightweight, enormous power, lots of energy, about 4 to 5 times the cycle life, and safer than other battery technologies. Basically, you forget everything you thought you knew about batteries. These are an enormous leap forward. I made a 3.5 lb 12 volt battery for my GMC van from A123 Systems cells to replace the original 35 lb battery. 720 cranking amps. No joke. Bill Dube' ________________________________________________________________________________
Date: Sep 20, 2007
From: "Greg Williams" <mr.gsun+rv-list(at)gmail.com>
Subject: Re: A123 Systems Batteries in new Cessna
How do I get one for my RV-7 ? On 9/20/07, Bill Dube wrote: > > > Here is a link to the article: > > http://home.businesswire.com/portal/site/home/index.jsp?ndmViewId=news_view&ndmConfigId=1000001&newsId 070919005033&newsLang=en > > Cessna is going to use A123 Systems Nano-phosphate batteries in their > jets. > > These are the same batteries I use in my electric drag bike. As I > said over a year ago, these are prefect batteries for aircraft > applications. Lightweight, enormous power, lots of energy, about 4 to > 5 times the cycle life, and safer than other battery technologies. > Basically, you forget everything you thought you knew about > batteries. These are an enormous leap forward. > > I made a 3.5 lb 12 volt battery for my GMC van from A123 Systems > cells to replace the original 35 lb battery. 720 cranking amps. No joke. > > Bill Dube' > > ________________________________________________________________________________
Date: Sep 21, 2007
---Gawd, don't these scammers have anything better to do than dream up crap like this?--- Well, not really. It's a full time job and can be quite lucrative if they are good at it...and we are bad at it. The Nigerian "we have money we want to send you, all we need is your bank account number to send it to" is a scam that was good for about $35,000,000 last year. P.T. Barnum had the situation covered in his famous saying. Make sure they skip your minute. Chuck ________________________________________________________________________________
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Subject: Re: high temp cable ties - now - engine mount stresses
Date: Sep 21, 2007
One easy trick is to buy a bunch of different diameter plastic tubing and cut small sections to wrap around your engine mount before using your tie wrap. Shemp/Jeff Dowling RV-6A, N915JD 325 hours Chicago ----- Original Message ----- From: Larry James To: rv-list(at)matronics.com Sent: Tuesday, September 18, 2007 4:08 PM Subject: RV-List: high temp cable ties - now - engine mount stresses Wow, I've never heard of this before .. And it makes sense. >>Subject: Re: RV-List: high temp cable ties >>From: "Kelly McMullen" <kellym(at)aviating.com> >> >>Regardless of the temps, it is not acceptable to use cable ties on an >>engine mount tube. Oil and dirt get under it and start wearing the tube. >>You need a pair of Adel clamps. >>KM >>A&P/IA So this leads me to two more questions: 1) Given the Engine Mount is a highly stressed piece; is it acceptable to weld a tab so that something can be bolted to it ?? 2) How about Electroless Nickel Plating ??? Larry E. James Bellevue, WA Super Decathlon (flying) Rocket (under contruction - way too long) ________________________________________________________________________________
Date: Sep 21, 2007
I see tie wraps on certified planes all the time. What gives? Shemp/Jeff Dowling RV-6A, N915JD 325 hours Chicago ----- Original Message ----- From: "Kelly McMullen" <kellym(at)aviating.com> Sent: Wednesday, September 19, 2007 6:28 PM Subject: Re: RV-List: high temp cable ties > > John Cox put it very well. As the manufacturer, you can do what you want. > A DAR not finding fault with something does NOT mean it is a good practice > or even safe. I can tell you that as an IA, every Tywrap found attached > around the engine mount on a TC aircraft will be written up as a > discrepancy. Your plane, your experiment, you can do as you choose, at > your own risk. > >> >> Kelly McMullen wrote: >>> >>> Regardless of the temps, it is not acceptable to use cable ties on an >>> engine mount tube. Oil and dirt get under it and start wearing the tube. >>> You need a pair of Adel clamps. >> >> True. >> >> However, the regular ol' nylon zip ties in the engine compartment of my >> RV-6, some of which are on mount tubes, were not only passed by the DAR, >> but have stood up just fine for eight years and 825 hours and have >> caused no damage. >> >> Maybe it is because oil and dirt are not allowed in the engine >> compartment of my plane. :-) >> >> Sam Buchanan >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 21, 2007
Bill, The link you posted did not work for me, but the A123 website is: http://www.a123systems.com/newsite/index.php#/products/cells32series/ There is no pricing or ordering info on the website (unless you are a high-volume OEM customer) - can you give me (us) an idea of what these cost and where to get them? Greg Arehart ________________________________________________________________________________
Date: Sep 21, 2007
The trouble is that no one wants to take on the liability of marketing to experimental aircraft. While these batteries, overall, are safer than other types of batteries, they still are batteries that store energy and have some hazards. These hazards are less, but different. This is all you need in a courtroom to get the traction you need with a jury for a successful lawsuit. Folks are coming out with 12 volt batteries that use these exact cells for other applications. They won't sell you them for an airplane, but they will sell them for your car stereo, race car, or computer back-up power supply, etc. Just like you go down to NAPA and buy an electric fuel pump for your tractor. Bill Dube' At 12:38 AM 9/21/2007, you wrote: >How do I get one for my RV-7 ? ________________________________________________________________________________
Date: Sep 21, 2007
Did they have tie wraps to the engine mount when they were delivered from the factory, or where they added later? Kevin Horton On 21 Sep 2007, at 10:27, Jeff Dowling wrote: > > > I see tie wraps on certified planes all the time. What gives? > > Shemp/Jeff Dowling > RV-6A, N915JD > 325 hours > Chicago > ----- Original Message ----- From: "Kelly McMullen" > > To: > Sent: Wednesday, September 19, 2007 6:28 PM > Subject: Re: RV-List: high temp cable ties > > >> >> John Cox put it very well. As the manufacturer, you can do what >> you want. >> A DAR not finding fault with something does NOT mean it is a good >> practice >> or even safe. I can tell you that as an IA, every Tywrap found >> attached >> around the engine mount on a TC aircraft will be written up as a >> discrepancy. Your plane, your experiment, you can do as you >> choose, at >> your own risk. >> >>> >>> Kelly McMullen wrote: >>>> >>>> >>>> Regardless of the temps, it is not acceptable to use cable ties >>>> on an >>>> engine mount tube. Oil and dirt get under it and start wearing >>>> the tube. >>>> You need a pair of Adel clamps. >>> >>> True. >>> >>> However, the regular ol' nylon zip ties in the engine compartment >>> of my >>> RV-6, some of which are on mount tubes, were not only passed by >>> the DAR, >>> but have stood up just fine for eight years and 825 hours and have >>> caused no damage. >>> >>> Maybe it is because oil and dirt are not allowed in the engine >>> compartment of my plane. :-) >>> >>> Sam Buchanan >>> >>> >>> >>> >> ________________________________________________________________________________
Date: Sep 21, 2007
Subject: CHT accuracy
My old old VM1000 which sat in a box for about 6 years is running now and showing 15 - 20 deg. F low readings on CHT3. (Using 160 - 190 deg. water to test the with.) I've swapped cables and thermocouples and even the socketted multiplexor chips that the thermocouples connect to. The low readings always stay with CHT3. The same cable connected to a different channel works OK. In talking to what's left of vision micro, the guy seemed to not be too disturbed by a 20 deg. error. A 5 deg. error would certainly not be a problem, but I think 20 deg. is getting too big for a parameter that you want to see stay below 400 deg. What kind of accuracy do people normally expect in CHT readings? Tom Sargent, RV-6A, electrical system. ________________________________________________________________________________
Subject: LogTen Pro
Date: Sep 22, 2007
I just downloaded a demo of this program on my MAC. Are there any instructions on how to get started, ie, set it up for my log book, airplane? Richard Reynolds ________________________________________________________________________________
Date: Sep 22, 2007
Subject: Filliform looks like?
I have just pulled out my wing root fairings (p/n F999 ) and pulled the blue skin from the underside of the fairing. It looks like there is some form of "corrosion" that looks like a fuzzy worm that snakes around from an edge. It is only on my wing root fairings and is covering the one edge of the fairing where the factory holes are located. Both fairings have this condition. If it is the "filliform" corrosion, can I eliminate it from the part? if so, how is the best way? If it is left as is, since this a nonstructural part, will it contaminate any other parts such as my wing skins? Its one of those "got to know about this" items. Jim Nelson RV9-A ________________________________________________________________________________
Date: Sep 22, 2007
Subject: Re: Filliform looks like?
Check out this link for examples. The second link shows a time lapse of filliform growing. Pretty neat! _http://www.asnt.org/publications/Materialseval/basics/oct03basics/oct03basicsfig1.htm#fig1a_ (http://www.asnt.org/publications/Materialseval/basics/oct03basics/oct03basicsfig1.htm#fig1a) _http://aluminium.matter.org.uk/content/html/eng/default.asp?catid=180&pageid 2144416691_ (http://aluminium.matter.org.uk/content/html/eng/default.asp?catid=180&pageid=2144416691) ________________________________________________________________________________
Date: Sep 22, 2007
Jim, Best bet would to apply some elbow grease to it with Scotch Brite pads , a little Alumaprep acid etch, Alodyne and followed by your favorite primer then the part will have the best chance to endure and to ensure no chance of contributing to more corrosion. As they say "airplanes are Bio-Degradable. Everything the plane comes into contact with will cause corrosion of one form or another if left unchecked. Protect it best you can. Ed Flow ________________________________________________________________________________
Date: Sep 23, 2007
Jim I had the same problem on one of the pats of my -10 tail cone. I just called Van's and they sent a replacement part. Their initial suggestion was to scotch brite the corrosion out. I found that I was taking too much material off (for my comfort) and decided to ask for a replacement part. They were very good about it. Cheers Les Kearney RV10 - # 40643 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of James H Nelson Sent: September-22-07 1:09 PM Subject: RV-List: Filliform looks like? I have just pulled out my wing root fairings (p/n F999 ) and pulled the blue skin from the underside of the fairing. It looks like there is some form of "corrosion" that looks like a fuzzy worm that snakes around from an edge. It is only on my wing root fairings and is covering the one edge of the fairing where the factory holes are located. Both fairings have this condition. If it is the "filliform" corrosion, can I eliminate it from the part? if so, how is the best way? If it is left as is, since this a nonstructural part, will it contaminate any other parts such as my wing skins? Its one of those "got to know about this" items. Jim Nelson RV9-A ________________________________________________________________________________
Subject: Fuel Sender Wire Length
Date: Sep 23, 2007
The answer to this may be staring me in the face, but I can't figure it out. -8A QB, so I haven't had the pleasure of a lot of fuel tank work. Also, since the tank is closed, access is restricted. I'm trying to install Van's float- type fuel senders, but can't figure out the wire dimensions. Plan 16A makes one reference to the nearly horizontal segment as "Approximately 3 inches". However, the scale view is drawn showing that segment over 4 inches. No reference at all to the "vertical" segment length. Can anyone help by both giving me the dimensions you used - and pointing out how you determined them? Is there a missing directions page that I may have filed away so securely 2+ years ago that it's missing? I checked the archives with more confusion than success - some folks were talking about different left and right tank dimensions. Where did that come form? Paul Valovich N192NM Reserved ________________________________________________________________________________
Date: Sep 23, 2007
I have to admit I am not sure how you would do this very accurately in a closed tank. I presume the quick built tanks come with no senders installed. Maybe another quick build kit builder will respond with something more sensible but is it possible to take your senders to another builder with an open set of tanks to get those cut, bent, and fitted for maximum effectiveness? There probably still is some minor differences between one tank and another, but you may be able to get pretty close. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Valovich, Paul > Sent: Sunday, September 23, 2007 10:50 AM > To: Valovich, Paul; rv-list(at)matronics.com > Subject: RV-List: Fuel Sender Wire Length > > > The answer to this may be staring me in the face, but I can't figure it > out. > > -8A QB, so I haven't had the pleasure of a lot of fuel tank work. Also, > since the tank is closed, access is restricted. I'm trying to install > Van's float- type fuel senders, but can't figure out the wire dimensions. > Plan 16A makes one reference to the nearly horizontal segment as > "Approximately 3 inches". However, the scale view is drawn showing that > segment over 4 inches. No reference at all to the "vertical" segment > length. > > Can anyone help by both giving me the dimensions you used - and pointing > out how you determined them? Is there a missing directions page that I may > have filed away so securely 2+ years ago that it's missing? > > I checked the archives with more confusion than success - some folks were > talking about different left and right tank dimensions. Where did that > come form? > Paul Valovich > N192NM Reserved > > > > > > ________________________________________________________________________________
Subject: Re: Fuel Sender Wire Length
Date: Sep 23, 2007
There's a separate drawing that you should have received with the senders (if you bought them from Vans) w/ these dimensions. It'd probably be best to contact Van's for a copy. -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135903#135903 ________________________________________________________________________________
Subject: FW: RV6 - Rear spar question
Date: Sep 23, 2007
Hi, I am just about to drill the final size holes for the rear spar (#30) at the root end. I want to use solid rivets in the skin at the wink walk section - So to enable me to remove the first 4 ribs. Rivet on the skin .. Then put each rib back in and rivet my way "back out" ... Should I use flush rivets on the leading edge of the rear spar in this region or will I be able to push the main ribs past the universal head ? I think if I set the shop head on the leading edge side of the rear spar - The rear end of the main rib will not go past the shop head.... but they may just push over a universal head... ?? Flush rivets will obviously not foul the main rib. But more work with countersinking the rear spar Any comments here greatly appreciated Jan RV6 ... building almost from scratch ... ________________________________________________________________________________
Date: Sep 23, 2007
Just don't rivet there until the ribs are in place. As you put in each rib, rivet the rear spar to the next rib. Shop head inside, universal outside - keeps it looking neat. I had no problem reaching the heads behind the flap brace with a long set; just don't rivet the brace to the bottom skin until the last so you can run the set between the skin and brace. Patrick Kelley - RV-6A - finishing the canopy frame -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of jan Sent: Sunday, September 23, 2007 10:27 AM Subject: RV-List: FW: RV6 - Rear spar question Hi, I am just about to drill the final size holes for the rear spar (#30) at the root end. I want to use solid rivets in the skin at the wink walk section - So to enable me to remove the first 4 ribs. Rivet on the skin .. Then put each rib back in and rivet my way "back out" ... Should I use flush rivets on the leading edge of the rear spar in this region or will I be able to push the main ribs past the universal head ? I think if I set the shop head on the leading edge side of the rear spar - The rear end of the main rib will not go past the shop head.... but they may just push over a universal head... ?? Flush rivets will obviously not foul the main rib. But more work with countersinking the rear spar Any comments here greatly appreciated Jan RV6 ... building almost from scratch ... ________________________________________________________________________________
Date: Sep 23, 2007
Subject: Re: FW: RV6 - Rear spar question
Jan, I put the shop heads on the aft side of the spar (factory head forward, inside the wing) for the rivets between the wing walk ribs. This made it relatively easy to slide the wing walk ribs into place. The rib can be tipped, twisted and flexed a bit in order to "slide" it into the end of the wing. Steve Allison RV-6A - no stinkin' pop rivets in the wing skins :-) jan wrote: > Hi, > > I am just about to drill the final size holes for the rear spar (#30) at the > root end. I want to use solid rivets in the skin at the wink walk section - > So to enable me to remove the first 4 ribs. Rivet on the skin .. Then put > each rib back in and rivet my way "back out" ... Should I use flush rivets > on the leading edge of the rear spar in this region or will I be able to > push the main ribs past the universal head ? I think if I set the shop head > on the leading edge side of the rear spar - The rear end of the main rib > will not go past the shop head.... but they may just push over a universal > head... ?? > > Flush rivets will obviously not foul the main rib. But more work with > countersinking the rear spar > > Any comments here greatly appreciated > > Jan > RV6 ... building almost from scratch ... ________________________________________________________________________________
Date: Sep 23, 2007
Thanks for that ! -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Patrick Kelley Sent: 23 September 2007 19:10 Subject: RE: RV-List: FW: RV6 - Rear spar question Just don't rivet there until the ribs are in place. As you put in each rib, rivet the rear spar to the next rib. Shop head inside, universal outside - keeps it looking neat. I had no problem reaching the heads behind the flap brace with a long set; just don't rivet the brace to the bottom skin until the last so you can run the set between the skin and brace. Patrick Kelley - RV-6A - finishing the canopy frame -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of jan Sent: Sunday, September 23, 2007 10:27 AM Subject: RV-List: FW: RV6 - Rear spar question Hi, I am just about to drill the final size holes for the rear spar (#30) at the root end. I want to use solid rivets in the skin at the wink walk section - So to enable me to remove the first 4 ribs. Rivet on the skin .. Then put each rib back in and rivet my way "back out" ... Should I use flush rivets on the leading edge of the rear spar in this region or will I be able to push the main ribs past the universal head ? I think if I set the shop head on the leading edge side of the rear spar - The rear end of the main rib will not go past the shop head.... but they may just push over a universal head... ?? Flush rivets will obviously not foul the main rib. But more work with countersinking the rear spar Any comments here greatly appreciated Jan RV6 ... building almost from scratch ... ________________________________________________________________________________
Date: Sep 23, 2007
Thanks .. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Steve Sent: 23 September 2007 21:03 Subject: Re: RV-List: FW: RV6 - Rear spar question Jan, I put the shop heads on the aft side of the spar (factory head forward, inside the wing) for the rivets between the wing walk ribs. This made it relatively easy to slide the wing walk ribs into place. The rib can be tipped, twisted and flexed a bit in order to "slide" it into the end of the wing. Steve Allison RV-6A - no stinkin' pop rivets in the wing skins :-) jan wrote: > Hi, > > I am just about to drill the final size holes for the rear spar (#30) at the > root end. I want to use solid rivets in the skin at the wink walk section - > So to enable me to remove the first 4 ribs. Rivet on the skin .. Then put > each rib back in and rivet my way "back out" ... Should I use flush rivets > on the leading edge of the rear spar in this region or will I be able to > push the main ribs past the universal head ? I think if I set the shop head > on the leading edge side of the rear spar - The rear end of the main rib > will not go past the shop head.... but they may just push over a universal > head... ?? > > Flush rivets will obviously not foul the main rib. But more work with > countersinking the rear spar > > Any comments here greatly appreciated > > Jan > RV6 ... building almost from scratch ... ________________________________________________________________________________
Date: Sep 23, 2007
Hi Paul, Take a look at the outside end of the fuel tank in profile. The fuel sender flange and gasket will eventually be installed mounted on the rear face of the rear baffle of the tank. For fine tuning; If you take great care as to the sender's correct vertical height and it's orientation as to left or right tank and clamp the sending unit onto the end flange outside the tank end. You should be able to adjust the float actuating wire length and shape to provide the correct movement of the sender arm. Be sure to check electrically with a meter or the gage itself. mark the gage as to left or right for later installation. I would use a piece of scrap material about the thickness of the gasket clamped to the tank rear flange with the sender temporarily mounted to it with a couple of screws or clecoes. Careful measuring with correct positioning and alignment of the sender mounting face with the rear tank baffle will be important. Jim in Kelowna ----- Original Message ----- From: "Tim Bryan" <n616tb(at)btsapps.com> Sent: Sunday, September 23, 2007 9:36 AM Subject: RE: RV-List: Fuel Sender Wire Length > > I have to admit I am not sure how you would do this very accurately in a > closed tank. I presume the quick built tanks come with no senders > installed. Maybe another quick build kit builder will respond with > something more sensible but is it possible to take your senders to another > builder with an open set of tanks to get those cut, bent, and fitted for > maximum effectiveness? There probably still is some minor differences > between one tank and another, but you may be able to get pretty close. > > Tim > >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- >> server(at)matronics.com] On Behalf Of Valovich, Paul >> Sent: Sunday, September 23, 2007 10:50 AM >> To: Valovich, Paul; rv-list(at)matronics.com >> Subject: RV-List: Fuel Sender Wire Length >> >> >> The answer to this may be staring me in the face, but I can't figure it >> out. >> >> -8A QB, so I haven't had the pleasure of a lot of fuel tank work. Also, >> since the tank is closed, access is restricted. I'm trying to install >> Van's float- type fuel senders, but can't figure out the wire dimensions. >> Plan 16A makes one reference to the nearly horizontal segment as >> "Approximately 3 inches". However, the scale view is drawn showing that >> segment over 4 inches. No reference at all to the "vertical" segment >> length. >> >> Can anyone help by both giving me the dimensions you used - and pointing >> out how you determined them? Is there a missing directions page that I >> may >> have filed away so securely 2+ years ago that it's missing? >> >> I checked the archives with more confusion than success - some folks >> were >> talking about different left and right tank dimensions. Where did that >> come form? >> Paul Valovich >> N192NM Reserved >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 23, 2007
Subject: Lightening holes in ribs
Bought an OLD wing kit for my RV-4 recently. The lightening holes need to be cut out on the ribs. Does anybody have a pet method for accurately finding the center of the cutout...I will be using a fly cutter to do the cutting job. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) ________________________________________________________________________________
Date: Sep 23, 2007
Subject: Re: Lightening holes in ribs
Scott wrote: > > Bought an OLD wing kit for my RV-4 recently. The lightening holes need > to be cut out on the ribs. Does anybody have a pet method for > accurately finding the center of the cutout...I will be using a fly > cutter to do the cutting job. > Scott, measure the diameters of the lightening holes and make a set of round templates (cut out of poster board?) with a hole in the middle. Center a template on the rib in a lightening hole recess, make a mark in the center hole with a Sharpie, and crank up the fly cutter. Be careful with the fly cutter, that thing can be deadly! Sam Buchanan ________________________________________________________________________________
Date: Sep 23, 2007
Hi Scott, You can copy the drawing for the ribs or order a new one from Vans. They are only $3 or so for a full sized sheet. Cut it out and lay it in the rib to mark the centers. Just a silly suggestion: DON'T get on a roll and cut lightening holes in ALL the ribs. The tank ribs and ends of the tanks don't get "lightened". It's a hassle to fix them after they have big holes in them, ask me how I know... And no, it wasn't me, it was Van's themselves. I got one of the first set of wing kits that came with the lightening holes done at the factory. Whoever they gave that task to did them all... tank ribs and all! Dave -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Sent: Sunday, September 23, 2007 3:33 PM Subject: RV-List: Lightening holes in ribs Bought an OLD wing kit for my RV-4 recently. The lightening holes need to be cut out on the ribs. Does anybody have a pet method for accurately finding the center of the cutout...I will be using a fly cutter to do the cutting job. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) ________________________________________________________________________________
Date: Sep 24, 2007
I understand! I have experience with them...I used one to cut out all the holes in my new instrument panel on my Corben. Good thing there were only about 8 holes I had to make! :) Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Sam Buchanan wrote: > > > Be careful with the fly cutter, that thing can be deadly! > > Sam Buchanan > > ________________________________________________________________________________
Date: Sep 24, 2007
Ooh, now there's some advice I can really use!! Yes, I probably would've done just that! I would have gotten the flycutter all set up and done every hole that was that size in one fell swoop. Thanks for saving me from having to send MORE money to Van... Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) David Burton wrote: > >Hi Scott, > >You can copy the drawing for the ribs or order a new one from Vans. They >are only $3 or so for a full sized sheet. Cut it out and lay it in the rib >to mark the centers. > >Just a silly suggestion: > >DON'T get on a roll and cut lightening holes in ALL the ribs. The tank ribs >and ends of the tanks don't get "lightened". It's a hassle to fix them >after they have big holes in them, ask me how I know... And no, it wasn't >me, it was Van's themselves. I got one of the first set of wing kits that >came with the lightening holes done at the factory. Whoever they gave that >task to did them all... tank ribs and all! > >Dave > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott >Sent: Sunday, September 23, 2007 3:33 PM >To: RV List; RV-4 List; RV-4(at)yahoogroups.com >Subject: RV-List: Lightening holes in ribs > > >Bought an OLD wing kit for my RV-4 recently. The lightening holes need >to be cut out on the ribs. Does anybody have a pet method for >accurately finding the center of the cutout...I will be using a fly >cutter to do the cutting job. > > > ________________________________________________________________________________
Date: Sep 23, 2007
That's a great idea; I wish I'd thought of it. I carefully did the first rib and then used the stock I'd just removed to mark all the rest of the ribs. Even then, I'd clamp the rib in place and rotate the fly cutter by hand to check where it was cutting. By the way, that removed stock is useful for making small bits. Even the small holes yielded clamping pads, bolt washers (for when I was bolting the longerons to the jig), and shims. Waste nothing! Patrick Kelley - RV-6A - working on canopy frame -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan Sent: Sunday, September 23, 2007 4:57 PM Subject: Re: RV-List: Lightening holes in ribs Scott wrote: > > Bought an OLD wing kit for my RV-4 recently. The lightening holes need > to be cut out on the ribs. Does anybody have a pet method for > accurately finding the center of the cutout...I will be using a fly > cutter to do the cutting job. > Scott, measure the diameters of the lightening holes and make a set of round templates (cut out of poster board?) with a hole in the middle. Center a template on the rib in a lightening hole recess, make a mark in the center hole with a Sharpie, and crank up the fly cutter. Be careful with the fly cutter, that thing can be deadly! Sam Buchanan ________________________________________________________________________________
Date: Sep 24, 2007
That's a good idea as well (big fender washers!!)! Guess I better buy a metal "trash" bin to throw all the various bits of leftovers into. Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Patrick Kelley wrote: > >That's a great idea; I wish I'd thought of it. I carefully did the first >rib and then used the stock I'd just removed to mark all the rest of the >ribs. Even then, I'd clamp the rib in place and rotate the fly cutter by >hand to check where it was cutting. By the way, that removed stock is >useful for making small bits. Even the small holes yielded clamping pads, >bolt washers (for when I was bolting the longerons to the jig), and shims. >Waste nothing! > >Patrick Kelley - RV-6A - working on canopy frame > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan >Sent: Sunday, September 23, 2007 4:57 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Lightening holes in ribs > > >Scott wrote: > > >> >>Bought an OLD wing kit for my RV-4 recently. The lightening holes need >>to be cut out on the ribs. Does anybody have a pet method for >>accurately finding the center of the cutout...I will be using a fly >>cutter to do the cutting job. >> >> >> > >Scott, measure the diameters of the lightening holes and make a set of >round templates (cut out of poster board?) with a hole in the middle. >Center a template on the rib in a lightening hole recess, make a mark in >the center hole with a Sharpie, and crank up the fly cutter. > >Be careful with the fly cutter, that thing can be deadly! > >Sam Buchanan > > > > ________________________________________________________________________________
Date: Sep 24, 2007
Scott wrote: > > That's a good idea as well (big fender washers!!)! Guess I better buy a > metal "trash" bin to throw all the various bits of leftovers into. By all means save all your cutoffs and scraps; you will be fabbing all sorts of brackets, spacers, etc. I still have ten-year-old bits and pieces of RV-6 in my scrap box and several of my subsequent projects have RV-6 metal "flying" in them. :-) Sam Buchanan ________________________________________________________________________________
Date: Sep 24, 2007
I found it easy to just draw a couple of lines at 90 deg on the disk to cut out - Got the centre with no problem that way... Did use a large compass to draw a circle, just to make sure before getting the fly cutter out ... I also made a small jig to clamp the rib in place during cutting ... and watch you hands !! -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of David Burton Sent: 24 September 2007 02:29 Subject: RE: RV-List: Lightening holes in ribs Hi Scott, You can copy the drawing for the ribs or order a new one from Vans. They are only $3 or so for a full sized sheet. Cut it out and lay it in the rib to mark the centers. Just a silly suggestion: DON'T get on a roll and cut lightening holes in ALL the ribs. The tank ribs and ends of the tanks don't get "lightened". It's a hassle to fix them after they have big holes in them, ask me how I know... And no, it wasn't me, it was Van's themselves. I got one of the first set of wing kits that came with the lightening holes done at the factory. Whoever they gave that task to did them all... tank ribs and all! Dave -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Sent: Sunday, September 23, 2007 3:33 PM Subject: RV-List: Lightening holes in ribs Bought an OLD wing kit for my RV-4 recently. The lightening holes need to be cut out on the ribs. Does anybody have a pet method for accurately finding the center of the cutout...I will be using a fly cutter to do the cutting job. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) ________________________________________________________________________________
Date: Sep 24, 2007
Subject: Completely off-topic, but you will love it anyway
I posted about A123 Systems batteries now being used in Cessna business jets. Here is what we are doing on the drag strip with those identical batteries. This was on the Speed Channel just yesterday: http://www.youtube.com/watch?v=3c8eLH8x_-Y You can see what has been distracting me from building my RV-7. :-) Bill Dube' ________________________________________________________________________________
Date: Sep 24, 2007
Subject: FS: Blue Mountain EFIS lite
For sale, used Blue mountain EFIS LITE, Generation 2, about 4 years old, flight time 200 hours, works fine wih latest firmware, USA database, moving map, HSI, PFD, G meter etc. Includes OAT sensor, GPS antenna. No marks or scratches on bezel, looks very nice. New was $3200, asking $1500. Thanks for reading! Bob -- Using Opera's revolutionary e-mail client: http://www.opera.com/mail/ ________________________________________________________________________________
Subject: Brake Pedals
Date: Sep 24, 2007
Robin, I found a place in Augusta that does powder coating and took them over today. Did you powder coat the tubing also, or paint over Vans grey powder coat? _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Wednesday, September 19, 2007 9:09 PM Subject: RE: RV-List: Brake Pedals Carl, I chose to powder coat my RV-10 pedals (they look more like chrome in person). I have zero idea how long my pedals will stay in this condition. My white painted RV-6A pedals don't look bad after 375 hours. Attached are my RV-10 pedals. Robin ndition10 pedals an from HumidTech ________________________________________________________________________________
Date: Sep 24, 2007
Carl, I would send this reply via email vs. the list but I don't have your email. Not sure what you are asking, nothing on my -10 has been painted to date. I powder coated all the items you see on the pedal assembly plus I powder coated my steps and the center windshield tube in chrome. While I was at it I PC'd my interior door handles and a custom "dish" in which my fuel valve resides. I expect to make 2-3 more trips to the powder coater for the balance of the build. Robin From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Carl Bell Sent: Monday, September 24, 2007 2:16 PM Subject: RE: RV-List: Brake Pedals Robin, I found a place in Augusta that does powder coating and took them over today. Did you powder coat the tubing also, or paint over Vans grey powder coat? ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Wednesday, September 19, 2007 9:09 PM Subject: RE: RV-List: Brake Pedals Carl, I chose to powder coat my RV-10 pedals (they look more like chrome in person). I have zero idea how long my pedals will stay in this condition. My white painted RV-6A pedals don't look bad after 375 hours. Attached are my RV-10 pedals. Robin ndition10 pedals an from HumidTech ________________________________________________________________________________
Date: Sep 24, 2007
Bill, The following is quoted from a special technology section in today's Wall Street Journal about their annual awards for innovation. Would this be a potential competitor to the batteries you are using? "ENERGY Co-winner Firefly Energy Inc., Peoria, Ill., developed a power supply that replaces the heavy lead plates in typical vehicle batteries with a carbon-graphite foam. The result is smaller and lighter -- yet can deliver as much power as more advanced and more costly technologies. Though its batteries aren't yet on the market, Firefly has signed a deal with Sweden's Husqvarna Group to provide batteries for the outdoor-equipment maker's planned line of electric lawn mowers and lawn tractors. And in March Firefly received $5 million from the U.S. Army to develop a prototype for possible use in combat vehicles." Terry -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill Dube Sent: Monday, September 24, 2007 11:30 AM Subject: RV-List: Completely off-topic, but you will love it anyway I posted about A123 Systems batteries now being used in Cessna business jets. Here is what we are doing on the drag strip with those identical batteries. This was on the Speed Channel just yesterday: http://www.youtube.com/watch?v=3c8eLH8x_-Y You can see what has been distracting me from building my RV-7. :-) Bill Dube' ________________________________________________________________________________
Date: Sep 25, 2007
From: Lapsley R & Sandra E Caldwell <lrsecaldwell(at)earthlink.net>
Subject: Throttle controle available
I have a 48 " long, 3 " throw vernier throttle control cable ( 1760). It's yours for $35.00. Roger Caldwell: lrsecaldwell(at)earthlink.net ________________________________________________________________________________
Subject: RE: Lightning holes in ribs
Date: Sep 25, 2007
Beg, borrow, rent or otherwise obtain some chassis punches or conduit punches to do the holes. Edge lipping the punched holes helps in the rigidity (over just a plain cut hole). The Fly cutter will hurt you, especially doing hundreds of holes. I did a wing set via the punch and a battery drill on slow to operate the punch. All done in one evening I recall, and the edge lipping of the hole worked out.... ....................................................................... ..... Patrick Kelley wrote: > >That's a great idea; I wish I'd thought of it. I carefully did the first >rib and then used the stock I'd just removed to mark all the rest of the >ribs. Even then, I'd clamp the rib in place and rotate the fly cutter by >hand to check where it was cutting. By the way, that removed stock is >useful for making small bits. Even the small holes yielded clamping pads, >bolt washers (for when I was bolting the longerons to the jig), and shims. >Waste nothing! > >Patrick Kelley - RV-6A - working on canopy frame > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Sam Buchanan >Sent: Sunday, September 23, 2007 4:57 PM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Lightening holes in ribs > > >Scott wrote: > > >> >>Bought an OLD wing kit for my RV-4 recently. The lightening holes need >>to be cut out on the ribs. Does anybody have a pet method for >>accurately finding the center of the cutout...I will be using a fly >>cutter to do the cutting job. >> >> >> > >Scott, measure the diameters of the lightening holes and make a set of >round templates (cut out of poster board?) with a hole in the middle. >Center a template on the rib in a lightening hole recess, make a mark in >the center hole with a Sharpie, and crank up the fly cutter. > >Be careful with the fly cutter, that thing can be deadly! > >Sam Buchanan > > > > ________________________________________________________________________________
Date: Sep 25, 2007
Subject: Re: RV-List Digest: 9 Msgs - 09/24/07 Fly cutters
Fly cutter hints: Yes, The fly cutter can be a loose cannon, but done right it can be tamed. First, mark all the centers carefully and drill (not with the fly cutter) 1/4". Drill the ribs undersize and ream to 1/4" if you have a reamer. Fit the fly cutter with a 1/4" SMOOTH pin NOT a drill bit. Grind the cutter blade to a narrow cut, about .050 at its outer edge. Use only about a 7 degree clearance angle. Set up a sturdy board clamped to your drill press table and drill about 15/64 and then "burn" to 1/4" with a smooth pin. A few drops of oil in the hole will help. This will give a firm outboard pilot for fly-cutting. Now mount up your fly cutter and float the SMOOTH pilot pin into the rib hole and into the board. Clamp the rib to the board and only now start the drill press. Use rather slow speed, but you may feed quite firmly until near breakthru. A touch of oil will help but is not always needed. This makes fly cuttin a piece of cake! Good luck,. Paul S. Petersen Minnetonka MN RV6A nearly complete with son Eric ________________________________________________________________________________
Date: Sep 25, 2007
You know, I never had a problem with my fly cutter, and I was a lot less cautious than this. I normally run it on the slowest setting on my drill press, but I even used it with a variable-speed hand drill. With the hand drill, I was still careful and I went slowly. When using a hand drill, you can feel when something isn't going right and can adjust accordingly. So, I'm not sure what the dangers are, as long as you respect the tool. Did I just get lucky? -Joe On Sep 25, 2007, at 2:08 PM, PSPRV6A(at)aol.com wrote: > Fly cutter hints: Yes, The fly cutter can be a loose cannon, > but done right it can be tamed. First, mark all the centers > carefully and drill (not with the fly cutter) 1/4". Drill the ribs > undersize and ream to 1/4" if you have a reamer. Fit the fly > cutter with a 1/4" SMOOTH pin NOT a drill bit. Grind the cutter > blade to a narrow cut, about .050 at its outer edge. Use only > about a 7 degree clearance angle. > Set up a sturdy board clamped to your drill press table and > drill about 15/64 and then "burn" to 1/4" with a smooth pin. A few > drops of oil in the hole will help. This will give a firm outboard > pilot for fly-cutting. Now mount up your fly cutter and float the > SMOOTH pilot pin into the rib hole and into the board. Clamp the > rib to the board and only now start the drill press. Use rather > slow speed, but you may feed quite firmly until near breakthru. A > touch of oil will help but is not always needed. This makes fly > cuttin a piece of > cake! > Good luck,. Paul S. Petersen > > Minnetonka MN RV6A nearly complete with son Eric > ________________________________________________________________________________
Date: Sep 25, 2007
You definitely got lucky ... A hand drill and a fly cutter does not go together .. Or maybe you are just shit hot with a fly cutter :-) ... I would go with the method described below ... Its very similar to what I did when I did my RV6 spar and all my ribs... (not the tank ribs) Photo show my cutter (the disk is removed) ...Slow speed and a back stop for the rib / spar -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Joseph Larson Sent: 25 September 2007 21:40 Subject: Re: RV-List: Re: RV-List Digest: 9 Msgs - 09/24/07 Fly cutters You know, I never had a problem with my fly cutter, and I was a lot less cautious than this. I normally run it on the slowest setting on my drill press, but I even used it with a variable-speed hand drill. With the hand drill, I was still careful and I went slowly. When using a hand drill, you can feel when something isn't going right and can adjust accordingly. So, I'm not sure what the dangers are, as long as you respect the tool. Did I just get lucky? -Joe On Sep 25, 2007, at 2:08 PM, PSPRV6A(at)aol.com wrote: > Fly cutter hints: Yes, The fly cutter can be a loose cannon, > but done right it can be tamed. First, mark all the centers > carefully and drill (not with the fly cutter) 1/4". Drill the ribs > undersize and ream to 1/4" if you have a reamer. Fit the fly > cutter with a 1/4" SMOOTH pin NOT a drill bit. Grind the cutter > blade to a narrow cut, about .050 at its outer edge. Use only > about a 7 degree clearance angle. > Set up a sturdy board clamped to your drill press table and > drill about 15/64 and then "burn" to 1/4" with a smooth pin. A few > drops of oil in the hole will help. This will give a firm outboard > pilot for fly-cutting. Now mount up your fly cutter and float the > SMOOTH pilot pin into the rib hole and into the board. Clamp the > rib to the board and only now start the drill press. Use rather > slow speed, but you may feed quite firmly until near breakthru. A > touch of oil will help but is not always needed. This makes fly > cuttin a piece of > cake! > Good luck,. Paul S. Petersen > > Minnetonka MN RV6A nearly complete with son Eric > ________________________________________________________________________________
Date: Sep 25, 2007
A fast way to clean up the holes after cutting out the disk ... Jan -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Joseph Larson Sent: 25 September 2007 21:40 Subject: Re: RV-List: Re: RV-List Digest: 9 Msgs - 09/24/07 Fly cutters You know, I never had a problem with my fly cutter, and I was a lot less cautious than this. I normally run it on the slowest setting on my drill press, but I even used it with a variable-speed hand drill. With the hand drill, I was still careful and I went slowly. When using a hand drill, you can feel when something isn't going right and can adjust accordingly. So, I'm not sure what the dangers are, as long as you respect the tool. Did I just get lucky? -Joe On Sep 25, 2007, at 2:08 PM, PSPRV6A(at)aol.com wrote: > Fly cutter hints: Yes, The fly cutter can be a loose cannon, > but done right it can be tamed. First, mark all the centers > carefully and drill (not with the fly cutter) 1/4". Drill the ribs > undersize and ream to 1/4" if you have a reamer. Fit the fly > cutter with a 1/4" SMOOTH pin NOT a drill bit. Grind the cutter > blade to a narrow cut, about .050 at its outer edge. Use only > about a 7 degree clearance angle. > Set up a sturdy board clamped to your drill press table and > drill about 15/64 and then "burn" to 1/4" with a smooth pin. A few > drops of oil in the hole will help. This will give a firm outboard > pilot for fly-cutting. Now mount up your fly cutter and float the > SMOOTH pilot pin into the rib hole and into the board. Clamp the > rib to the board and only now start the drill press. Use rather > slow speed, but you may feed quite firmly until near breakthru. A > touch of oil will help but is not always needed. This makes fly > cuttin a piece of > cake! > Good luck,. Paul S. Petersen > > Minnetonka MN RV6A nearly complete with son Eric > ________________________________________________________________________________
Date: Sep 25, 2007
I find that a fly cutter can be safely used in an electric drill motor, IF used carefully and IF you set the clutch to slip if it snags. I would be very hesitant to try it with a big drill motor (lots of power) and no clutch. Terry -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Joseph Larson Sent: Tuesday, September 25, 2007 1:40 PM Subject: Re: RV-List: Re: RV-List Digest: 9 Msgs - 09/24/07 Fly cutters You know, I never had a problem with my fly cutter, and I was a lot less cautious than this. I normally run it on the slowest setting on my drill press, but I even used it with a variable-speed hand drill. With the hand drill, I was still careful and I went slowly. When using a hand drill, you can feel when something isn't going right and can adjust accordingly. So, I'm not sure what the dangers are, as long as you respect the tool. Did I just get lucky? -Joe On Sep 25, 2007, at 2:08 PM, PSPRV6A(at)aol.com wrote: > Fly cutter hints: Yes, The fly cutter can be a loose cannon, > but done right it can be tamed. First, mark all the centers > carefully and drill (not with the fly cutter) 1/4". Drill the ribs > undersize and ream to 1/4" if you have a reamer. Fit the fly > cutter with a 1/4" SMOOTH pin NOT a drill bit. Grind the cutter > blade to a narrow cut, about .050 at its outer edge. Use only > about a 7 degree clearance angle. > Set up a sturdy board clamped to your drill press table and > drill about 15/64 and then "burn" to 1/4" with a smooth pin. A few > drops of oil in the hole will help. This will give a firm outboard > pilot for fly-cutting. Now mount up your fly cutter and float the > SMOOTH pilot pin into the rib hole and into the board. Clamp the > rib to the board and only now start the drill press. Use rather > slow speed, but you may feed quite firmly until near breakthru. A > touch of oil will help but is not always needed. This makes fly > cuttin a piece of > cake! > Good luck,. Paul S. Petersen > > Minnetonka MN RV6A nearly complete with son Eric > ________________________________________________________________________________
Date: Sep 25, 2007
Subject: Fly cutters
The following posted for the benefit of builders who have yet to use a fly cutter: Like all power tools, the fly cutter has the potential for being extremely dangerous. What makes it particularly hazardous to RV builders is that the project may be the first time a fly cutter has been encountered by the builder. True, common sense will dramatically reduce the odds of an accident, but when a fly cutter and the material being cut gets loose, the results can be catastrophic. Somewhere on the web a few years ago a photo circulated of a mangled hand that had a most unfortunate encounter with a fly cutter. The points presented in Paul's post below are certainly valid and detail a great way to tame the fly cutter. In my experience the two most common errors in using the fly cutter are failing to TIGHTLY clamp the piece to the drill press table with a wood backing and failure to use a SHARP fly cutter. If the cutter gets dull, it WILL snag in the cut, hopefully stalling the drill press, but if the work isn't tightly clamped, and the drill doesn't stall, the whole deal becomes a whirling guillotine. Another hazard is failing to stay clear of the cutter. Depending on the speed of the drill press, the cutter bar can be nearly impossible to see and dangling clothing or careless fingers can instantly be pulled into a really bad situation. Yep, a fly cutter can be used with a hand drill.....I've done it when needing to add a hole to a panel in an assembled plane (didn't enjoy the process, however), but this only increases the possibility of having an accident. It is easy to let the cutter get less than perpendicular to the work and then there are problems (see above). So, be careful, work slowly, keep the work securely clamped and the cutter sharp, and all should go well. Violate any of these guidelines, and your building progress may be uninterrupted while you learn to use fewer fingers. Let's be careful. :-) Sam Buchanan ======================= Joseph Larson wrote: > > You know, I never had a problem with my fly cutter, and I was a lot less > cautious than this. I normally run it on the slowest setting on my > drill press, but I even used it with a variable-speed hand drill. With > the hand drill, I was still careful and I went slowly. > > When using a hand drill, you can feel when something isn't going right > and can adjust accordingly. > > So, I'm not sure what the dangers are, as long as you respect the tool. > Did I just get lucky? > > -Joe > > On Sep 25, 2007, at 2:08 PM, PSPRV6A(at)aol.com wrote: > >> Fly cutter hints: Yes, The fly cutter can be a loose cannon, but >> done right it can be tamed. First, mark all the centers carefully and >> drill (not with the fly cutter) 1/4". Drill the ribs undersize and >> ream to 1/4" if you have a reamer. Fit the fly cutter with a 1/4" >> SMOOTH pin NOT a drill bit. Grind the cutter blade to a narrow cut, >> about .050 at its outer edge. Use only about a 7 degree clearance angle. >> Set up a sturdy board clamped to your drill press table and drill >> about 15/64 and then "burn" to 1/4" with a smooth pin. A few drops of >> oil in the hole will help. This will give a firm outboard pilot for >> fly-cutting. Now mount up your fly cutter and float the SMOOTH pilot >> pin into the rib hole and into the board. Clamp the rib to the board >> and only now start the drill press. Use rather slow speed, but you >> may feed quite firmly until near breakthru. A touch of oil will help >> but is not always needed. This makes fly cuttin a piece of >> cake! >> Good luck,. Paul S. Petersen >> >> Minnetonka MN RV6A nearly complete with son Eric ________________________________________________________________________________
Date: Sep 25, 2007
>Beg, borrow, rent or otherwise obtain some chassis punches or conduit >punches to do the holes. I did my smaller holes this way. I didn't have large enough punches to do them all. The rib material is thin enough that it goes pretty quickly with a fly cutter. On a Van's kit the ribs have pressed in raised rings that you leave in place when you cut the lightening holes out leaving you a nice reinforcing flange. I also used a punch to do my conduit holes. That made short work of those and it leaves a great hole without a burr. Dave ________________________________________________________________________________
Date: Sep 25, 2007
Subject: RV-List: Re: RV-List Digest: 9 Msgs - 09/24/07 Fly cutters Fly cutter hints: Yes, The fly cutter can be a loose cannon, but done right it can be tamed. First, mark all the centers carefully and drill (not with the fly cutter) 1/4". Drill the ribs undersize and ream to 1/4" if you have a reamer. Fit the fly cutter with a 1/4" SMOOTH pin NOT a drill bit. Grind the cutter blade to a narrow cut, about .050 at its outer edge. Use only about a 7 degree clearance angle. Minnetonka MN RV6A nearly complete with son Eric Better yet is a flycutter with a 3/8" integral pilot. Stanley makes (made) one. Works very well. Gordon Comfort N363GC ________________________________________________________________________________
Date: Sep 25, 2007
My pedals are the aluminum part supplied by Van. I drilled a number of holes (around one inch) to lighten the weight and then buffed the aluminum with Scotch Bright. The buffed aluminum looks beautiful, even after 250 hours. Not a mark on them. Paint, even powder coating, will scuff off. I also made foot rests (fastened to the two outside vertical bars of the rudder) in the same manner. You can see part of my brake pedals if you enlarge the panel picture of my airplane at _www.petesrvaviationproducts.com_ (http://www.petesrvaviationproducts.com) . Pete in Clearwater RV-6, SnF Reserve Grand Champion, Outstanding aircraft award All electric panel ________________________________________________________________________________
Date: Sep 25, 2007
Subject: Re: Brake Pedals
Pete, Do you have any pics of your aluminum trays that keep the water from your instruments? Greg RV-7 tipup all electric panel On 9/25/07, PeterHunt1(at)aol.com wrote: > > My pedals are the aluminum part supplied by Van. I drilled a number of > holes (around one inch) to lighten the weight and then buffed the > aluminum with Scotch Bright. The buffed aluminum looks beautiful, even > after 250 hours. Not a mark on them. Paint, even powder coating, > will scuff off. I also made foot rests (fastened to the two outside > vertical bars of the rudder) in the same manner. You can see part of my > brake pedals if you enlarge the panel picture of my airplane at > www.petesrvaviationproducts.com. > > Pete in Clearwater > RV-6, SnF Reserve Grand Champion, Outstanding aircraft award > All electric panel > > > ------------------------------ > Se69" target="_blank">Make AOL Your Homepage. > > * > > > * > > ________________________________________________________________________________
From: "Jim Fogarty at Lakes & Leisure Realty" <jfogarty(at)tds.net>
Subject: Re: Fly cutters
Date: Sep 26, 2007
General information, do not raise the fly cutter after you have cut through the aluminum with your drill or drill press still running. You will have a flying disc heading for a perfectly good fuselage, VS or other airplane parts, including the pilot. I had a disc hit the VS and fortunately I did not have damage, thank you lord. Jim RV9a ----- Original Message ----- From: "Sam Buchanan" <sbuc(at)hiwaay.net> Sent: Tuesday, September 25, 2007 4:32 PM Subject: RV-List: Fly cutters > > The following posted for the benefit of builders who have yet to use a fly > cutter: > > Like all power tools, the fly cutter has the potential for being extremely > dangerous. What makes it particularly hazardous to RV builders is that the > project may be the first time a fly cutter has been encountered by the > builder. True, common sense will dramatically reduce the odds of an > accident, but when a fly cutter and the material being cut gets loose, the > results can be catastrophic. > > Somewhere on the web a few years ago a photo circulated of a mangled hand > that had a most unfortunate encounter with a fly cutter. The points > presented in Paul's post below are certainly valid and detail a great way > to tame the fly cutter. > > In my experience the two most common errors in using the fly cutter are > failing to TIGHTLY clamp the piece to the drill press table with a wood > backing and failure to use a SHARP fly cutter. If the cutter gets dull, it > WILL snag in the cut, hopefully stalling the drill press, but if the work > isn't tightly clamped, and the drill doesn't stall, the whole deal becomes > a whirling guillotine. > > Another hazard is failing to stay clear of the cutter. Depending on the > speed of the drill press, the cutter bar can be nearly impossible to see > and dangling clothing or careless fingers can instantly be pulled into a > really bad situation. > > Yep, a fly cutter can be used with a hand drill.....I've done it when > needing to add a hole to a panel in an assembled plane (didn't enjoy the > process, however), but this only increases the possibility of having an > accident. It is easy to let the cutter get less than perpendicular to the > work and then there are problems (see above). > > So, be careful, work slowly, keep the work securely clamped and the cutter > sharp, and all should go well. Violate any of these guidelines, and your > building progress may be uninterrupted while you learn to use fewer > fingers. > > Let's be careful. :-) > > Sam Buchanan > > ======================= > > Joseph Larson wrote: >> >> You know, I never had a problem with my fly cutter, and I was a lot less >> cautious than this. I normally run it on the slowest setting on my drill >> press, but I even used it with a variable-speed hand drill. With the >> hand drill, I was still careful and I went slowly. >> >> When using a hand drill, you can feel when something isn't going right >> and can adjust accordingly. >> >> So, I'm not sure what the dangers are, as long as you respect the tool. >> Did I just get lucky? >> >> -Joe >> >> On Sep 25, 2007, at 2:08 PM, PSPRV6A(at)aol.com wrote: >> >>> Fly cutter hints: Yes, The fly cutter can be a loose cannon, but >>> done right it can be tamed. First, mark all the centers carefully and >>> drill (not with the fly cutter) 1/4". Drill the ribs undersize and ream >>> to 1/4" if you have a reamer. Fit the fly cutter with a 1/4" SMOOTH pin >>> NOT a drill bit. Grind the cutter blade to a narrow cut, about .050 at >>> its outer edge. Use only about a 7 degree clearance angle. >>> Set up a sturdy board clamped to your drill press table and drill >>> about 15/64 and then "burn" to 1/4" with a smooth pin. A few drops of >>> oil in the hole will help. This will give a firm outboard pilot for >>> fly-cutting. Now mount up your fly cutter and float the SMOOTH pilot >>> pin into the rib hole and into the board. Clamp the rib to the board >>> and only now start the drill press. Use rather slow speed, but you may >>> feed quite firmly until near breakthru. A touch of oil will help but is >>> not always needed. This makes fly cuttin a piece of cake! >>> Good luck,. Paul S. Petersen >>> >>> Minnetonka MN RV6A nearly complete with son Eric > > > -- > 269.13.30/1030 - Release Date: 9/25/2007 8:02 AM > > ________________________________________________________________________________
Date: Sep 26, 2007
From: George Inman 204 287 8334 <ghinman(at)mts.net>
Subject: Wing mounting bolt direction
I cannot find an instruction on the direction for the main wing attach bolts in the center section.Does the nut go to the front or back? Or does it matter? RV-8 QB -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Subject: Re: Wing mounting bolt direction
Date: Sep 26, 2007
Good practice puts the bolt front to back with nut on aft side. But, if ability to properly torque the nut is not possible, do what works best. Dale Ensing RV-6A ----- Original Message ----- From: "George Inman 204 287 8334" <ghinman(at)mts.net> Sent: Wednesday, September 26, 2007 4:07 PM Subject: RV-List: Wing mounting bolt direction > > > I cannot find an instruction on the direction for > the > main wing attach bolts in the center section.Does the nut go to the front > or back? Or does it matter? > RV-8 QB > > -- > > George H. Inman > ghinman(at)mts.net > > > ________________________________________________________________________________
Date: Sep 26, 2007
On my 8A, I don't believe it is even possible to put the bolts in from the front. Terry RV-8A Seattle Wiring -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of George Inman 204 287 8334 Sent: Wednesday, September 26, 2007 1:07 PM Subject: RV-List: Wing mounting bolt direction I cannot find an instruction on the direction for the main wing attach bolts in the center section.Does the nut go to the front or back? Or does it matter? RV-8 QB -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Date: Sep 27, 2007
Greg, No, I don't have any pictures of the trays over my instruments, but I'll take a few and post them. I have a special tip-up front gasket (see _www.petesrvaviationproducts.com_ (http://www.petesrvaviationproducts.com/) ) which stops the water from entering when the canopy is closed. The problem is keeping water off the instruments when I open a wet canopy and some water cascades down and then rearward (tail-dragger). That small amount of water I catch in three long, narrow (2.5") trays mounted against the rear side of the firewall and over the forward half of the gauges. I learned after losing my transponder to rain a year ago that Van's tip-up front gasket and design gives limited water protection. That got me thinking about a better solution to keeping water out of a tip-up canopy. Pete in Clearwater RV-6 250 hours, all electric panel Greg wrote: "Pete, Do you have any pics of your aluminum trays that keep the water from your instruments? Greg RV-7 tipup all electric panel" ________________________________________________________________________________
From: "Jeff Linebaugh" <jefflinebaugh(at)bellsouth.net>
Subject: The Memphis 100 Air Race
Date: Sep 27, 2007
The Memphis 100 is coming! Come join us for the fun! When: October 27th Where: DeWitt Spain Airport (M01), Memphis, TN What: The Memphis 100 is an Official Sport Air Racing League sanctioned eventIt is for ALL aircraft, from Cubs to Unlimiteds, run on a 100 mile triangular course, with staggered starts. No formation experience required! Racers are split into categories for fair, friendly competition. Come run hard, or enjoy the scenery and camaraderie! Who: You! Hosted by the Memphis CAF. Breakfast by the Memphis EAA. For more information or registration contact: Rick Pellicciotti: rick@rocket-boys.com 901 481-1934 Jeff Linebaugh: jeff@rocket-boys.com 901 606-6735 Hope to see you all there! Jeff Linebaugh jefflinebaugh(at)bellsouth.net ________________________________________________________________________________
Date: Sep 27, 2007
Subject: RV9 tail kit
For sale: RV9 tail kit with electric trim due to health reasons. I am located in a western suburb of Chicago. I can't pack it so someone will have to be in driving distance. I also bought the Cleaveland tool kit for RV's including a pneumatic squeezer. The tools are barely used. $1200 for the tail kit and $2000 for tools. More info: jharrison46atgmaildotcom ________________________________________________________________________________
Subject: Re: Firewall insulation for heat and sound
Date: Sep 27, 2007
I'm just about to the point of putting on the front deck of my 7A and thought it would be easier to put some insulation on the aft face of the firewall now. There are several types advertised -- I was looking for ease of application and good performance in reducing heat and sound from the engine. Does anyone out there have a favorite type??? Do you feel that it is worth the effort to insulate the firewall? I'd appreciate your comments dave > ________________________________________________________________________________
Date: Sep 27, 2007
Dave, I recently installed the aluminized heat barrier by Thermotec (Spruce p/n 08-00600 for the 12X24 in size) on the aft side of my 8 firewall and had a DRAMATIC drop in heat in the fwd baggage hold. Its 1/16 thick and is comprised of woven ceramic cloth similar to fiberglass with an adhesive back. Added weight is negligible. It does not reduce sound much, if at all. I have ANR headsets which reduces the sound level to manageable levels. John D RV8 N585JD ________________________________________________________________________________
Date: Sep 27, 2007
Dave, I used a foam from Wick's: http://www.wicksaircraft.com/catalog/product_detail.php/pid=7836~subid= 1925/index.html It's available in several thicknesses (I used 1/2 inch on the aft side of the firewall) and I found it easy to apply with a spray adhesive (3M as I recall) available from the "aviation aisle" at Home Depot. I have nothing to compare it to but have been pleased with it's insulating value for both for sound and heat. Steve Struyk St. Charles, MO RV8, N842S, 90 Hrs, ----- Original Message ----- From: Dave Cudney To: rv-list(at)matronics.com Sent: Thursday, September 27, 2007 7:03 PM Subject: RV-List: Re: Firewall insulation for heat and sound I'm just about to the point of putting on the front deck of my 7A and thought it would be easier to put some insulation on the aft face of the firewall now. There are several types advertised -- I was looking for ease of application and good performance in reducing heat and sound from the engine. Does anyone out there have a favorite type??? Do you feel that it is worth the effort to insulate the firewall? I'd appreciate your comments dave http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Sep 27, 2007
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
I used Super Soundproofing foam from spruce. I've had it in from day one it seems to be working pretty good but I don't know what it would sound like without it. Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Dave Cudney wrote: > I'm just about to the point of putting on the front deck of my 7A and > thought it would be easier to put some insulation on the aft face of > the firewall now. There are several types advertised -- I was looking > for ease of application and good performance in reducing heat and > sound from the engine. Does anyone out there have a favorite type??? > Do you feel that it is worth the effort to insulate the firewall? > > I'd appreciate your comments > > dave >> *http://www.matronics.com/Navigator?RV-List >> href="http://forums.matronics.com">http://forums.matronics.com >> >> * > > * > > > * ________________________________________________________________________________
Date: Sep 27, 2007
Dave, I'm not sure what others are using but I am planning to use the insulation from Abby at Flightline Interiors. http://www.flightlineinteriors.com/products/construction/default.asp Firewall Insulation Fabric - Blocks up to 97% of radiated heat - Effective conductive heat barrier - Effective moisture barrier - Superior sound deflector - Resistant to mold and mildew - Easily installs in minutes - Lightweight Firewall Insulation (per yard, 48" wide) $22.00 Bret Smith RV-9A (91314) Mineral Bluff, GA www.FlightInnovations.com _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Cudney Sent: Thursday, September 27, 2007 8:04 PM Subject: RV-List: Re: Firewall insulation for heat and sound I'm just about to the point of putting on the front deck of my 7A and thought it would be easier to put some insulation on the aft face of the firewall now. There are several types advertised -- I was looking for ease of application and good performance in reducing heat and sound from the engine. Does anyone out there have a favorite type??? Do you feel that it is worth the effort to insulate the firewall? I'd appreciate your comments dave http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Sep 27, 2007
I used some stuff from abby at flightline interiors , light and strong and now is the time to do it , acs has some black stuff that I hear works good, great article in kitplanes several months ago about heat & noise reduction. Danny -----Original Message----- From: "Dave Cudney" <yenduc(at)sbcglobal.net> Sent: 9/27/07 7:03 PM Subject: RV-List: Re: Firewall insulation for heat and sound I'm just about to the point of putting on the front deck of my 7A and thought it would be easier to put some insulation on the aft face of the firewall now. There are several types advertised -- I was looking for ease of application and good performance in reducing heat and sound from the engine. Does anyone out there have a favorite type??? Do you feel that it is worth the effort to insulate the firewall? I'd appreciate your comments dave > ________________________________________________________________________________
Date: Sep 27, 2007
Hi Dave, In my 6A, I used sound insulation only in the floor. I have no insulation on the backside of the firewall. With my sound cancelling headset, the sound level at my ears is very confortable. There is also no sign of excess heat in the cockpit. I've been flying for 2-1/2 years in Central Florida. It is hot on the ground in the summer in or out of the cockpit and it cools off when I climb above 1000 feet. Regards, Richard Dudley Dave Cudney wrote: > I'm just about to the point of putting on the front deck of my 7A and > thought it would be easier to put some insulation on the aft face of > the firewall now. There are several types advertised -- I was looking > for ease of application and good performance in reducing heat and > sound from the engine. Does anyone out there have a favorite type??? > Do you feel that it is worth the effort to insulate the firewall? > > I'd appreciate your comments > > dave > >>http://www.matronics.com/Navigator?RV-List >>href="http://forums.matronics.com">http://forums.matronics.com >> >> > > ________________________________________________________________________________
Date: Sep 27, 2007
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Same stuff as JC Whitney...=0A=0ADarrell=0A=0A=0A----- Original Message --- -=0AFrom: Bret Smith <smithhb(at)tds.net>=0ATo: rv-list(at)matronics.com=0ASent: Thursday, September 27, 2007 8:32:16 PM=0ASubject: RE: RV-List: Re: Firewal l insulation for heat and sound=0A=0A=0ADave,=0A =0AI'm not sure what other s are using but I am planning to use the insulation from Abby at Flightline Interiors. http://www.flightlineinteriors.com/products/construction/defau lt.asp=0A =0A=0AFirewall Insulation Fabric =0A- Blocks up to 97% of radiate d heat=0A- Effective conductive heat barrier=0A- Effective moisture barrier =0A- Superior sound deflector=0A- Resistant to mold and mildew=0A- Easily i nstalls in minutes=0A- Lightweight=0AFirewall Insulation (per yard, 48" wid e) $22.00=0ABret Smith=0ARV-9A (91314)=0AMineral Bluff, GA=0Awww.FlightInno vations.com=0A =0A=0A=0A=0A=0AFrom: owner-rv-list-server(at)matronics.com [mai lto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Cudney=0ASent: Th ursday, September 27, 2007 8:04 PM=0ATo: rv-list(at)matronics.com=0ASubject: R V-List: Re: Firewall insulation for heat and sound=0A=0A=0AI'm just about t o the point of putting on the front deck of my 7A and thought it would be e asier to put some insulation on the aft face of the firewall now. There are several types advertised -- I was looking for ease of application and good performance in reducing heat and sound from the engine. Does anyone out th ere have a favorite type??? Do you feel that it is worth the effort to insu late the firewall? =0A=0A=0AI'd appreciate your comments=0A=0A=0Adave=0A=0A http://www.matronics.com/Navigator?RV-List=0Ahref="http://forums.matronic s.com">http://forums.matronics.com=0A=0A=0A=0A=0A=0A=0Ahref="http://www.m atronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List =0Ahref="http://forums.matronics.com">http://forums.matronics.com=0A=0A =0A =0A______________________________________________________________ ______________________=0AMoody friends. Drama queens. Your life? Nope! - th o.com/ ________________________________________________________________________________
Date: Sep 27, 2007
In a message dated 9/27/2007 6:47:05 P.M. Pacific Daylight Time, rhdudley1(at)bellsouth.net writes: There is also no sign of excess heat in the cockpit. I've been flying for 2-1/2 years in Central Florida. ================================ How hot would it be if the engine caught on fire? N1GV (RV-6A, Flying 865hrs, O-360-A1A, C/S, Silicon Valley) ________________________________________________________________________________
Date: Sep 27, 2007
In a message dated 9/27/2007 5:07:58 P.M. Pacific Daylight Time, yenduc(at)sbcglobal.net writes: Does anyone out there have a favorite type??? Do you feel that it is worth the effort to insulate the firewall? ================================================ Definitely worth the effort IMO. I used Soundcoat brand Soundfoam HT P/N FF30AHT7 in a 1" thickness. It's a flame retardant polyimide foam (think Kapton but foamed) with a aluminized mylar backing. It weighs 1oz/sqft so only 3/4 of a lb or so for the whole firewall. I used aluminum tape to reconnect the various cutout shapes that fit the firewall topography into a contiguous whole. It is expensive but probably the best material for the job. I have an AutoCAD file of the 6/6A firewall available. N1GV (RV-6A, Flying 865hrs, O-360-A1A, C/S, Silicon Valley) ________________________________________________________________________________
Date: Sep 28, 2007
When selecting firewall insulation material, it might be assumed that the manufacturer (amateur builder) looked at flame propagation time or just dismissed the guideline published for certificated aircraft in the AC. (Which is often a great "jumping off" point in decision making). Firewall insulation, upholstery covers, carpeting and headliner are often grouped with other "thermal attenuation" and "sound attenuation" products. Some products can do both - they are not always the same. Fire Suppression and flame spread were not listed other than in the description. Often the adhesive used invalidates the purpose for the product in the first place. The ability to remove it and locate corrosion years later should not be dismissed without reasonable consideration. Too often in our quest for completion we totally dismiss "fire annunciation" and "fire suppression" objective of safe building. I had a friend who recently crashed in Virginia, only to extract himself after his canopy burned away adequately. He was in serious condition afterwards. Below is the NTSB report of Boriak's accident. I read in an aerobatics newsletter that he was inverted after the accident and couldn't get out until the canopy melted. NTSB Identification: NYC07LA201 John Cox RV-10 (40600) ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bret Smith Sent: Thursday, September 27, 2007 6:32 PM Subject: RE: RV-List: Re: Firewall insulation for heat and sound Dave, I'm not sure what others are using but I am planning to use the insulation from Abby at Flightline Interiors. http://www.flightlineinteriors.com/products/construction/default.asp Firewall Insulation Fabric - Blocks up to 97% of radiated heat - Effective conductive heat barrier - Effective moisture barrier - Superior sound deflector - Resistant to mold and mildew - Easily installs in minutes - Lightweight Firewall Insulation (per yard, 48" wide) $22.00 Bret Smith RV-9A (91314) Mineral Bluff, GA www.FlightInnovations.com ________________________________ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Cudney Sent: Thursday, September 27, 2007 8:04 PM Subject: RV-List: Re: Firewall insulation for heat and sound I'm just about to the point of putting on the front deck of my 7A and thought it would be easier to put some insulation on the aft face of the firewall now. There are several types advertised -- I was looking for ease of application and good performance in reducing heat and sound from the engine. Does anyone out there have a favorite type??? Do you feel that it is worth the effort to insulate the firewall? I'd appreciate your comments dave http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. c om/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Sep 28, 2007
Thanks for the comments I definitely will use some insulation, although I'm still unclear as to which product to use. Currently leaning towards the Flightline Interiors product. dave On Sep 27, 2007, at 5:03 PM, Dave Cudney wrote: > I'm just about to the point of putting on the front deck of my 7A > and thought it would be easier to put some insulation on the aft > face of the firewall now. There are several types advertised -- I > was looking for ease of application and good performance in > reducing heat and sound from the engine. Does anyone out there > have a favorite type??? Do you feel that it is worth the effort to > insulate the firewall? > > I'd appreciate your comments > > dave >> http://www.matronics.com/Navigator?RV-List >> href="http://forums.matronics.com">http://forums.matronics.com >> > > ________________________________________________________________________________
Date: Sep 28, 2007
Subject: Low Fuel Pressure
With the boost pump off, my fuel pressure in flight normally stays around the bottom of the green arc (Van's gauge). Yesterday I was flying 22 squared and saw that my fuel pressure had dropped to 1 psi which is just a fraction above the red line. The engine ran fine, but I got very concerned. I turned the boost pump on which slowly boosted the pressure up to the bottom of the green arc, but no higher. Normally with the boost pump on (such as on takeoff) I can get the pressure up to 5 psi (top of the green arc). During landing, with the power pulled back, the fuel pressure rose and behaved normally. I am concerned that for a period my fuel pressure dropped almost to the red line. Have any of you had a similar experience? (My mechanical fuel pump diaphragm is not leaking and my fuel lines are plumbed as per Vans.) Pete, in Clearwater RV-6, 250 hours ________________________________________________________________________________
Date: Sep 28, 2007
Subject: Re: Low Fuel Pressure
Hi Pete, I have had similar experiences with Van's fuel pressure gauge though never to 1 psi. I see variations from the bottom of the green arc to middle of the green arc. There has never been any indication from the engine of lack of fuel. The indications seem to be independent of power. The boost pump will sometimes bring the indication to mid green when it is at the bottom of the green arc on engine driven pump alone. The variations seem to occur randomly. I have an O-320-D1A with about 130 hours on it since new. Richard in Orlando RV-6A PeterHunt1(at)aol.com wrote: > With the boost pump off, my fuel pressure in flight normally stays > around the bottom of the green arc (Van's gauge). Yesterday I was > flying 22 squared and saw that my fuel pressure had dropped to 1 psi > which is just a fraction above the red line. The engine ran fine, but > I got very concerned. I turned the boost pump on which slowly > boosted the pressure up to the bottom of the green arc, but no > higher. Normally with the boost pump on (such as on takeoff) I can > get the pressure up to 5 psi (top of the green arc). During landing, > with the power pulled back, the fuel pressure rose and behaved > normally. I am concerned that for a period my fuel pressure dropped > almost to the red line. Have any of you had a similar experience? > (My mechanical fuel pump diaphragm is not leaking and my fuel lines > are plumbed as per Vans.) > > Pete, in Clearwater > RV-6, 250 hours > > > ------------------------------------------------------------------------ > See w target="_blank">Make AOL Your Homepage. > > ________________________________________________________________________________
Date: Sep 28, 2007
Tis normal in my RV. I biased my RMI engine monitor to add 1 psi so it would not constantly blink. Otherwise it was often ZERO in flight The engine has run fine for over 1200 hours this way. Ron Lee ----- Original Message ----- From: PeterHunt1(at)aol.com To: rv-list-digest(at)matronics.com Sent: Friday, September 28, 2007 12:46 PM Subject: RV-List: Low Fuel Pressure With the boost pump off, my fuel pressure in flight normally stays around the bottom of the green arc (Van's gauge). Yesterday I was flying 22 squared and saw that my fuel pressure had dropped to 1 psi which is just a fraction above the red line. The engine ran fine, but I got very concerned. I turned the boost pump on which slowly boosted the pressure up to the bottom of the green arc, but no higher. Normally with the boost pump on (such as on takeoff) I can get the pressure up to 5 psi (top of the green arc). During landing, with the power pulled back, the fuel pressure rose and behaved normally. I am concerned that for a period my fuel pressure dropped almost to the red line. Have any of you had a similar experience? (My mechanical fuel pump diaphragm is not leaking and my fuel lines are plumbed as per Vans.) Pete, in Clearwater RV-6, 250 hours ------------------------------------------------------------------------- ----- See w target="_blank">Make AOL Your Homepage. ________________________________________________________________________________
Subject: Thomasville, GA Fly-In Oct. 12, 13, 14
Date: Sep 28, 2007
This a great fly-in if you can make it. There are normally several hundred aircraft in attendance over the three days of the event. Obviously Saturday is the better attendance day. Of all the fly-ins I attend this one has been my favorite. The dates are 10/12, 10/13, and 10/14 See www.thomasvilleflyin.com Jerry Isler Donalsonville, GA RV4 N455J ________________________________________________________________________________
Date: Sep 28, 2007
On 28 Sep 2007, at 14:46, PeterHunt1(at)aol.com wrote: > With the boost pump off, my fuel pressure in flight normally stays > around the bottom of the green arc (Van's gauge). Yesterday I was > flying 22 squared and saw that my fuel pressure had dropped to 1 > psi which is just a fraction above the red line. The engine ran > fine, but I got very concerned. I turned the boost pump on which > slowly boosted the pressure up to the bottom of the green arc, but > no higher. Normally with the boost pump on (such as on takeoff) I > can get the pressure up to 5 psi (top of the green arc). During > landing, with the power pulled back, the fuel pressure rose and > behaved normally. I am concerned that for a period my fuel > pressure dropped almost to the red line. Have any of you had a > similar experience? (My mechanical fuel pump diaphragm is not > leaking and my fuel lines are plumbed as per Vans.) What was the altitude when you noticed the low fuel pressure, and how long had it been since you climbed to that altitude? I've seen some reports that suggest that some of the commonly used fuel pressure senders are not very well vented, and it can take some time after you climb for the pressure on the ambient side of its diaphragm to actually decrease to the local ambient pressure. This causes the pressure to read lower than the actual pressure. -- Kevin Horton RV-8 (Finishing Kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: Thomasville, GA Fly-In Oct. 12, 13, 14
Date: Sep 28, 2007
I agree wholeheartedly with Jerry. This is a great fly-in. KB ----- Original Message ----- From: Jerry Isler To: rvsoutheast-list(at)matronics.com ; rv-list(at)matronics.com Sent: Friday, September 28, 2007 4:44 PM Subject: RV-List: Thomasville, GA Fly-In Oct. 12, 13, 14 This a great fly-in if you can make it. There are normally several hundred aircraft in attendance over the three days of the event. Obviously Saturday is the better attendance day. Of all the fly-ins I attend this one has been my favorite. The dates are 10/12, 10/13, and 10/14 See www.thomasvilleflyin.com Jerry Isler Donalsonville, GA RV4 N455J ________________________________________________________________________________
Date: Sep 29, 2007
Subject: AF-2500 Calibration
Date: Sep 30, 2007
I'm trying to calibrate the AF-2500 and have questions regarding the Manifold Pressure and Amps process. It seems that two known data points must be entered for each and I'm unsure how to do this. I appreciate any suggestions from those experienced using the AF-2500. Thanks. Have a great weekend, Bill Gill RV-7 (preparing for inspection) Lee's Summit, MO ________________________________________________________________________________
Subject: Bell Tail Wheel
Date: Sep 30, 2007
Is the Bell Tail Wheel still being produced? If so how does one get in touch with Doug Bell Jr. to get one. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Sep 30, 2007
Subject: Re: AF-2500 Calibration
My came with those setting already set, your should be also. Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm William Gill wrote: > > I'm trying to calibrate the AF-2500 and have questions regarding the > Manifold Pressure and Amps process. It seems that two /known /data > points must be entered for each and I'm unsure how to do this. I > appreciate any suggestions from those experienced using the AF-2500. > Thanks. > > > > > > Have a great weekend, > > > > > > Bill Gill > > RV-7 (preparing for inspection) > > Lee's Summit, MO > > * > > > * ________________________________________________________________________________
Date: Sep 30, 2007
Hello Bobby, AFS said to set the first cal point for manifold pressure to the ambient condition. Then, pull a KNOWN vacuum with corresponding baro pressure for the second cal point. When I start the engine, my manifold pressure reads "9" at idle. What data appears in your cal menu for the second data point for manifold pressure? I believe a similar process is necessary for the Amp sensor. Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bobby Hester Sent: Sunday, September 30, 2007 7:44 AM Subject: Re: RV-List: AF-2500 Calibration My came with those setting already set, your should be also. Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm William Gill wrote: I'm trying to calibrate the AF-2500 and have questions regarding the Manifold Pressure and Amps process. It seems that two known data points must be entered for each and I'm unsure how to do this. I appreciate any suggestions from those experienced using the AF-2500. Thanks. Have a great weekend, Bill Gill RV-7 (preparing for inspection) Lee's Summit, MO href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.c om/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Sep 30, 2007
Subject: HVLP Questions
I went "shopping" at Sears yesterday to look at spray guns to use for priming parts (did not buy one, but bought their 24" digital level with laser -- on sale for $44!!). They had 2 regular guns and one HVLP gun. My question: does this HVLP gun get used with my regular air compressor or would I need to buy a special air supply system? I didn't see anything at Sears that looked like anything other than standard air compressors. If the HVLP cannot be used with my regular compressor, I will get a regular gun. Is there anything special I should look for? What other stuff will I need? I do have a small water separator on the output of my compressor and no inline oilers of any kind. Never painted with anything but a spray bomb from Wal Mart ;) -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) ________________________________________________________________________________
Subject: Nashville Airports
Date: Sep 30, 2007
I am posting this again because it never came through on the email list. My wife and I are planning to fly to Nashville for our anniversary in a couple of weeks. I see there are two airports besides the International airport (BNA). John C. Tune (JWN) and Cornelia (M88). Could someone from this area tell me which would be the most RV (RV related post) friendly airport between these two? We will be in town for 4 days. Any comments appreciated Tim ________________________________________________________________________________
Date: Sep 30, 2007
An HVLP gun can be used with a regular compressor. Here a couple of good links: http://www.hotrodders.com/kb/body-exterior/articles/spraygun.html http://toolsofthetrade.net/industry-news.asp?sectionID=1497&articleID=501284 Bob Collins St. Paul, Minn. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Sent: Sunday, September 30, 2007 4:04 PM Subject: RV-List: HVLP Questions I went "shopping" at Sears yesterday to look at spray guns to use for priming parts (did not buy one, but bought their 24" digital level with laser -- on sale for $44!!). They had 2 regular guns and one HVLP gun. My question: does this HVLP gun get used with my regular air compressor or would I need to buy a special air supply system? I didn't see anything at Sears that looked like anything other than standard air compressors. If the HVLP cannot be used with my regular compressor, I will get a regular gun. Is there anything special I should look for? What other stuff will I need? I do have a small water separator on the output of my compressor and no inline oilers of any kind. Never painted with anything but a spray bomb from Wal Mart ;) -- ________________________________________________________________________________
Date: Sep 30, 2007
Subject: Re: HVLP Questions
Thanks...I'll check out the links! Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Bob Collins wrote: > >An HVLP gun can be used with a regular compressor. > >Here a couple of good links: > >http://www.hotrodders.com/kb/body-exterior/articles/spraygun.html > >http://toolsofthetrade.net/industry-news.asp?sectionID=1497&articleID=501284 > >Bob Collins >St. Paul, Minn. > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott >Sent: Sunday, September 30, 2007 4:04 PM >To: RV List; RV-4(at)yahoogroups.com; RV-4 List >Subject: RV-List: HVLP Questions > > >I went "shopping" at Sears yesterday to look at spray guns to use for >priming parts (did not buy one, but bought their 24" digital level with >laser -- on sale for $44!!). They had 2 regular guns and one HVLP gun. >My question: does this HVLP gun get used with my regular air compressor or >would I need to buy a special air supply system? I didn't see anything at >Sears that looked like anything other than standard air compressors. If the >HVLP cannot be used with my regular compressor, I will get a regular gun. >Is there anything special I should look for? >What other stuff will I need? I do have a small water separator on the >output of my compressor and no inline oilers of any kind. Never painted >with anything but a spray bomb from Wal Mart ;) > >-- > > > > ________________________________________________________________________________
Date: Sep 30, 2007
One more thread on VAF which may be of interest http://www.vansairforce.com/community/showthread.php?t=7663 http://www.romeolima.com/RV8/Paint.htm http://www.minitruckinweb.com/tech/body/0706mt_spray_gun_basics/ -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Sent: Sunday, September 30, 2007 5:03 PM Subject: Re: RV-List: HVLP Questions Thanks...I'll check out the links! Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Bob Collins wrote: > >An HVLP gun can be used with a regular compressor. > >Here a couple of good links: > >http://www.hotrodders.com/kb/body-exterior/articles/spraygun.html > >http://toolsofthetrade.net/industry-news.asp?sectionID=1497&articleID=5 >01284 > >Bob Collins >St. Paul, Minn. > > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott >Sent: Sunday, September 30, 2007 4:04 PM >To: RV List; RV-4(at)yahoogroups.com; RV-4 List >Subject: RV-List: HVLP Questions > > >I went "shopping" at Sears yesterday to look at spray guns to use for >priming parts (did not buy one, but bought their 24" digital level with >laser -- on sale for $44!!). They had 2 regular guns and one HVLP gun. >My question: does this HVLP gun get used with my regular air >compressor or would I need to buy a special air supply system? I >didn't see anything at Sears that looked like anything other than >standard air compressors. If the HVLP cannot be used with my regular compressor, I will get a regular gun. >Is there anything special I should look for? >What other stuff will I need? I do have a small water separator on the >output of my compressor and no inline oilers of any kind. Never >painted with anything but a spray bomb from Wal Mart ;) > >-- > > > > ________________________________________________________________________________
Date: Sep 30, 2007
I've flown into M88 a couple times. The service always seemed prompt and accomodating. The provided a courtesy car and hunted down directions for where I needed to go, though M88's location is a little tricky to drive to/from....then again, its probably easier if a person follows directions. Don't know much about JWN and BNA is the usual big airport with prices to match. The FBOs at BNA are probably friendly---if you burn kerosene. Chuck [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Tim Bryan Sent: Sunday, September 30, 2007 5:13 PM Subject: RV-List: Nashville Airports I am posting this again because it never came through on the email list. My wife and I are planning to fly to Nashville for our anniversary in a couple of weeks. I see there are two airports besides the International airport (BNA). John C. Tune (JWN) and Cornelia (M88). Could someone from this area tell me which would be the most RV (RV related post) friendly airport between these two? We will be in town for 4 days. Any comments appreciated Tim ________________________________________________________________________________
Subject: Re: Nashville Airports
Date: Sep 30, 2007
I do burn JP4 and go into BNA on a regular basis, but I also go to MQY, Smyrna, quite a bit. They are very nice there and after checking the white pages on VAF, I found other Rvers there, contacted some of them when I was going to ROM and got a chance to visit with some, see their planes etc. Murfreesboro isn't too far away and they seem real nice as well. I usually just drop off and pick up there, but very friendly people. They kinda place I will fly into when my -7 is done. RVRC Robert RV7 - Fuselage in transit arrives this week. KCUB ----- Original Message ----- From: "Tim Bryan" <n616tb(at)btsapps.com> Sent: Sunday, September 30, 2007 5:12 PM Subject: RV-List: Nashville Airports > > > I am posting this again because it never came through on the email list. > > My wife and I are planning to fly to Nashville for our anniversary in a > couple of weeks. I see there are two airports besides the International > airport (BNA). John C. Tune (JWN) and Cornelia (M88). Could someone from > this area tell me which would be the most RV (RV related post) friendly > airport between these two? We will be in town for 4 days. > > Any comments appreciated > Tim > > > ________________________________________________________________________________
Date: Sep 30, 2007
Why don't I proof read or spell check? RON - remain over night and THE kinda place... RC ----- Original Message ----- From: "Robert Cutter" <rcutter(at)cupower.com> Sent: Sunday, September 30, 2007 9:02 PM Subject: Re: RV-List: Nashville Airports > > > I do burn JP4 and go into BNA on a regular basis, but I also go to MQY, > Smyrna, quite a bit. They are very nice there and after checking the > white pages on VAF, I found other Rvers there, contacted some of them when > I was going to ROM and got a chance to visit with some, see their planes > etc. > > Murfreesboro isn't too far away and they seem real nice as well. I > usually just drop off and pick up there, but very friendly people. They > kinda place I will fly into when my -7 is done. > > RVRC > > Robert > RV7 - Fuselage in transit arrives this week. > KCUB > ----- Original Message ----- > From: "Tim Bryan" <n616tb(at)btsapps.com> > To: > Sent: Sunday, September 30, 2007 5:12 PM > Subject: RV-List: Nashville Airports > > >> >> >> I am posting this again because it never came through on the email list. >> >> My wife and I are planning to fly to Nashville for our anniversary in a >> couple of weeks. I see there are two airports besides the International >> airport (BNA). John C. Tune (JWN) and Cornelia (M88). Could someone >> from >> this area tell me which would be the most RV (RV related post) friendly >> airport between these two? We will be in town for 4 days. >> >> Any comments appreciated >> Tim >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 30, 2007
I think John C. Tune would be the would be the better choice between the two. M88 is an old small airport, harder to get to by car. JWN is a newer bigger airport with easier access, both by plane and by car. Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Tim Bryan wrote: > > I am posting this again because it never came through on the email list. > > My wife and I are planning to fly to Nashville for our anniversary in a > couple of weeks. I see there are two airports besides the International > airport (BNA). John C. Tune (JWN) and Cornelia (M88). Could someone from > this area tell me which would be the most RV (RV related post) friendly > airport between these two? We will be in town for 4 days. > > Any comments appreciated > Tim > > > ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Date: Sep 30, 2007
Bob, All I use any more is HVLP. It's the BOMB! Less, way less, overspray, and using a lot less material-saves$$$$$. 1) any good single stage or 2 stage air compressor will work. Any brand. I would suggest that if you have space and $ invest in a good stand up compressor. Sears is ok but over priced. If you have a Tractor Supply Co. near look there. If not any good discount place, home depot, Lowe's will have 30-80 gallon size. CFM is the number that you are looking for on the compressor. Higher the better. My IR is 80 gallon single stage 18.1CFM 5HP - works like a mule. It will also keep up with ANY air tool that you have, die grinder, cut off tool, sanders, NOTHING can bog it down. 2) Invest in a good quality HVLP gun. It makes all the difference in the world. DeVilbiss is all that I use. AKZO epoxy primer, basecoat, clearcoat, will handle it all. Gravity fed(cup on top) or pot feed is the only way to go. Got mine on Ebay, new, half price what I could get it for locally. On Ebay search HVLP paint gun, Devilbiss, there are quite a few west coast reputable companies out there that have tons of stuff and great price. Like with anything - SHOP till you drop before laying out the $ . You'll get a better product for your bucks. 3). I picked up the digital level/laser also-mine was craftsman's club no brainer. check out there 3D laser level with stands for $40 when on sale. Very easy to stripe an a/c the entire length on both sides with two, or to do checkerboard on cowl/spinner/rudder. Hope that this all helped, PS - MUST have an inline water trap/filter with any compressor, big or small, compressed air makes water and will ruin your tools and paint. You are right-no inline oiler. Mike H 9A, 8A ----- Original Message ----- From: "Bob Collins" <bcollinsrv7a(at)comcast.net> Sent: Sunday, September 30, 2007 6:52 PM Subject: RE: RV-List: HVLP Questions > > One more thread on VAF which may be of interest > http://www.vansairforce.com/community/showthread.php?t=7663 > > http://www.romeolima.com/RV8/Paint.htm > > http://www.minitruckinweb.com/tech/body/0706mt_spray_gun_basics/ > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott > Sent: Sunday, September 30, 2007 5:03 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: HVLP Questions > > > Thanks...I'll check out the links! > > Scott > http://corbenflyer.tripod.com/ > Gotta Fly or Gonna Die > Building RV-4 (Super Slow Build Version) > > > Bob Collins wrote: > >> >>An HVLP gun can be used with a regular compressor. >> >>Here a couple of good links: >> >>http://www.hotrodders.com/kb/body-exterior/articles/spraygun.html >> >>http://toolsofthetrade.net/industry-news.asp?sectionID=1497&articleID=5 >>01284 >> >>Bob Collins >>St. Paul, Minn. >> >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott >>Sent: Sunday, September 30, 2007 4:04 PM >>To: RV List; RV-4(at)yahoogroups.com; RV-4 List >>Subject: RV-List: HVLP Questions >> >> >>I went "shopping" at Sears yesterday to look at spray guns to use for >>priming parts (did not buy one, but bought their 24" digital level with >>laser -- on sale for $44!!). They had 2 regular guns and one HVLP gun. >>My question: does this HVLP gun get used with my regular air >>compressor or would I need to buy a special air supply system? I >>didn't see anything at Sears that looked like anything other than >>standard air compressors. If the HVLP cannot be used with my regular > compressor, I will get a regular gun. >>Is there anything special I should look for? >>What other stuff will I need? I do have a small water separator on the >>output of my compressor and no inline oilers of any kind. Never >>painted with anything but a spray bomb from Wal Mart ;) >> >>-- >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 30, 2007
Subject: Re: Bell Tail Wheel
dbell(at)manisteenational.com Not sure if they are or not, but I love mine!! Paul Besing --- Steve Glasgow wrote: > > > Is the Bell Tail Wheel still being produced? If so > how does one get in > touch with Doug Bell Jr. to get one. > > Steve Glasgow-Cappy > N123SG RV-8 > Cappy's Toy > > > > browse > Subscriptions page, > FAQ, > > Web Forums! > > > > > Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase. http://farechase.yahoo.com/ ________________________________________________________________________________
Date: Oct 01, 2007
Best I can tell, they are still in business. Try this thread from VAF _http://www.vansairforce.com/community/showthread.php?t=5361_ (http://www.vansairforce.com/community/showthread.php?t=5361) Regards, Michael Wynn RV 8 Fuselage San Ramon, CA ________________________________________________________________________________
Date: Oct 01, 2007
Sounds like good advice. I'll shop around... Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) mike humphrey wrote: > > > Bob, > All I use any more is HVLP. It's the BOMB! Less, way less, > overspray, and using a lot less material-saves$$$$$. > 1) any good single stage or 2 stage air compressor will work. Any > brand. I would suggest that if you have space and $ invest in a good > stand up compressor. Sears is ok but over priced. If you have a > Tractor Supply Co. near look there. If not any good discount place, > home depot, Lowe's will have 30-80 gallon size. CFM is the number > that you are looking for on the compressor. Higher the better. My IR > is 80 gallon single stage 18.1CFM 5HP - works like a mule. It will > also keep up with ANY air tool that you have, die grinder, cut off > tool, sanders, NOTHING can bog it down. > 2) Invest in a good quality HVLP gun. It makes all the difference in > the world. DeVilbiss is all that I use. AKZO epoxy primer, basecoat, > clearcoat, will handle it all. Gravity fed(cup on top) or pot feed is > the only way to go. Got mine on Ebay, new, half price what I could > get it for locally. On Ebay search HVLP paint gun, Devilbiss, there > are quite a few west coast reputable companies out there that have > tons of stuff and great price. Like with anything - SHOP till you > drop before laying out the $ . You'll get a better product for your > bucks. > 3). I picked up the digital level/laser also-mine was craftsman's > club no brainer. check out there 3D laser level with stands for $40 > when on sale. Very easy to stripe an a/c the entire length on both > sides with two, or to do checkerboard on cowl/spinner/rudder. > Hope that this all helped, > PS - MUST have an inline water trap/filter with any compressor, big or > small, compressed air makes water and will ruin your tools and paint. > You are right-no inline oiler. > Mike H 9A, 8A > > ________________________________________________________________________________
Date: Oct 01, 2007
Yes, the Bell Tail Wheel is still being made. Got mine several months ago and love it. Here also is Doug's Dad's email address if Doug Jr. doesn't work for you. _bell1301(at)yahoo.com_ (mailto:bell1301(at)yahoo.com) Doug Bell Sr. _dbell(at)manisteenational.com_ (mailto:dbell(at)manisteenational.com) Doug Bell Jr. Pat Long PGLong(at)aol.com N120PL RV4 Bay City, Michigan 3CM Do Not Archive ________________________________________________________________________________
Subject: Re: RV-List Digest: Nashville Airports
Date: Oct 01, 2007
I'm based at John C. Tune JWN. Depending on what you are planning and where you'll be either John C. Tune or Cornelia Fort would serve for access to Nashville. JWN is in West Nashville and M88 is near downtown on the east side. Driving directions are a little tricky getting to M88. Full service fuel is over $5 at JWN but they are in the process of bringing online Self Serve fuel at Tune at approx $4.30 - not officially open waiting for permit but I heard someone fuel up Sat. Feel free to contact me directly for any other recommendations. Shelby Smith rvaitor(at)comcast.net On Oct 1, 2007, at 1:57 AM, RV-List Digest Server wrote: > From: "Tim Bryan" <n616tb(at)btsapps.com> > Subject: RV-List: Nashville Airports > > > I am posting this again because it never came through on the email > list. > > My wife and I are planning to fly to Nashville for our anniversary > in a > couple of weeks. I see there are two airports besides the > International > airport (BNA). John C. Tune (JWN) and Cornelia (M88). Could > someone from > this area tell me which would be the most RV (RV related post) > friendly > airport between these two? We will be in town for 4 days. > > Any comments appreciated > Tim ________________________________________________________________________________
Subject: Bell tailwheel and Screaming Eagle tailwheel
Date: Oct 01, 2007
Guys, Bell makes a fine tailwheel. No doubt about it. But so do I. IMHO, if you have a Van's or Rocket taildragger you should have either a Bell or a Screaming Eagle tailwheel installed. You will love the better handling and the extra clearance that either will provide. A Screaming Eagle tailwheel is a bit more streamlined and more closely resembles the stock Van's type. Screaming Eagle tailwheels will accept a wheel pant and still be able to full swivel if you're a total speed freak. A Screaming Eagle tailwheel fork is available to EASILY retrofit your existing Van's fork. Literally a 5 minute swap. I have tailwheels, tires, and replacement parts in stock all of the time. I usually ship the following day. Screaming Eagle tailwheels are guaranteed. If you don't like it, send it back. Please take a look at the website below as there is far too much info to list here. For instance, I offer a durable, lightweight tailwheel tire that is 6 oz lighter than the Van's tire. Also sealed bearing to eliminate the mess on the rudder. Thanks, Vince Frazier Screaming Eagle Graphics and Accessories, LLC 3965 Caborn Road Mount Vernon, IN 47620 812-464-1839 http://vincesrocket.com/products.htm ________________________________________________________________________________
Date: Oct 01, 2007
I tried to order a Bell Tailwheel a couple of months ago and recieved this reply from Doug Bell: Dean,Sorry for not replying sooner. I have actually been buried in painting myRV8 and between work, that and family obligations I have fallen behind i n afew areas. I was actully at a family reunion on Sat when you left me avo icemail.Have you ever felt summers were too busy?Weel here is the tailwheel fork status:At this time Dad is not accepting any new orders for his tail wheel fork.At 80 yrs old he is worried that the current order list will out live him.That sounds funny to type, but he is concerned and wants to make s ure allthe people who are currently on order get their fork. At that time h e willlook to take more orders.Dad was injured this winter and for several months we were unable to produceforks and are therefore behind.I will keep you email on file and contact you when Dad catches up, but thatis likely to be at least a year out.Sorry for the situation and thanks for the inquiry. We hope to catch up asfast as we can.He only sells the fork, not the seale d bearing tailwheel itself.His cost started at $185 and has gone up about $ 8 due to steel and shippingcosts....Let me know if saving your email will w ork for you and I understand if itdoes not.Sincerely, Doug Bell, jr.RV-8Man istee, MI I decided to order a Screaming Eagle tailwheel and have been very happy wit h the decision. Regards, Dean Pichon RV-4 _________________________________________________________________ Explore the seven wonders of the world BRE ________________________________________________________________________________
Date: Oct 01, 2007
Scott wrote: > > Everyone seems to like them and they say they are available, but WHERE > are they available from? Does Bell Tailwheels have a website? No website, this is a small, retirement shop project of Mr. Bell's (age 80) that has gotten kinda out of hand. :-) Messages posted earlier in this thread explain the Bell's situation and provide email contacts. If you want a tailwheel soon, you're out of luck. But if you can wait, you might still be able to get a Bell unit sometime in the distant future by using the email addresses provided in the earlier posts. Mr. Bell and his son are very nice folks who have been sort of forced into tailwheel production once people discovered the quality of the unit coming out of their shop. I have a Bell on my RV-6 and it is a nice piece. Sam Buchanan ________________________________________________________________________________
From: "Michael D. Cencula" <matronics(at)cencula.com>
Subject: Aileron leading edges
Date: Oct 01, 2007
Greetings listers. I'm working on the ailerons for my -7A and have a slight issue with the leading edge skins. As you probably know, the bottom portion of the leading edge skin is flat and the top is curved. The problem is that the top isn't curved enough. I have to pull the skin down about 1 1/2 or 2 inches to cleco it to the aileron spar. This makes the bottom skin bulge out. Did anyone else run into this? What did you do to fix it? I've thought about trying to curl the top of the aileron leading edge skin some more, but not sure how to do that. Thanks for any help you can offer. Mike Cencula RV-7A wings ________________________________________________________________________________
Date: Oct 02, 2007
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Brake caliper bleed fitting.
Probably a dumb question but...getting ready to install brake calipers on RV-6A. Cleveland installs the bleeder on the same side of both calipers but Van's drawing shows the bleeder at the bottom of the installation. So....I'm assuming that I need to reverse the bleeder and the fluid line fittings on one of the Calipers? Yes/No? Thanks. Dean RV-6A Hope to fly soon. ________________________________________________________________________________
Date: Oct 01, 2007
Yes, reverse the bleed fitting and the brake line fitting on one caliper so that both bleed fittings are on the bottom. Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of DEAN PSIROPOULOS Sent: Monday, October 01, 2007 11:20 PM Subject: RV-List: Brake caliper bleed fitting. Probably a dumb question but...getting ready to install brake calipers on RV-6A. Cleveland installs the bleeder on the same side of both calipers but Van's drawing shows the bleeder at the bottom of the installation. So....I'm assuming that I need to reverse the bleeder and the fluid line fittings on one of the Calipers? Yes/No? Thanks. Dean RV-6A Hope to fly soon. ________________________________________________________________________________
Date: Oct 02, 2007
Scott, Glad that I could help out. One thing that is Critical to the life of any HVLP gun is to clean it immediately after use. I buy 5 gal cans of lacquer thinner at a discount paint shop/auto body shop and run 3x 1/2 cups of lacquer thinner through it after each use. Thoroughly wipe out the cup with a clean paper towel soaked in lacquer thinner and the nozzle. Let it air dry before putting it away. If you maintain your equipment, it will last forever. I have one HVLP gun that is 3 years old and shoots as good as day one. The outside ain't so pretty but the guts are spotless. Most people don't take care of their guns properly and then cuss them when they fail. Also you can plumb your shop with HIGH pressure PVC pipe and not cast iron, same isle as the regular PVC water pipe, just look for High Pressure HOT/COLD on the PVC. Regular or High PVC cement. Good luck, Mike H 9A, 8A ----- Original Message ----- From: "Scott" <acepilot(at)bloomer.net> Sent: Monday, October 01, 2007 6:46 AM Subject: Re: RV-List: HVLP Questions > > Sounds like good advice. I'll shop around... > > Scott > http://corbenflyer.tripod.com/ > Gotta Fly or Gonna Die > Building RV-4 (Super Slow Build Version) > > > mike humphrey wrote: > >> >> >> Bob, >> All I use any more is HVLP. It's the BOMB! Less, way less, overspray, >> and using a lot less material-saves$$$$$. >> 1) any good single stage or 2 stage air compressor will work. Any brand. >> I would suggest that if you have space and $ invest in a good stand up >> compressor. Sears is ok but over priced. If you have a Tractor Supply >> Co. near look there. If not any good discount place, home depot, Lowe's >> will have 30-80 gallon size. CFM is the number that you are looking for >> on the compressor. Higher the better. My IR is 80 gallon single stage >> 18.1CFM 5HP - works like a mule. It will also keep up with ANY air tool >> that you have, die grinder, cut off tool, sanders, NOTHING can bog it >> down. >> 2) Invest in a good quality HVLP gun. It makes all the difference in the >> world. DeVilbiss is all that I use. AKZO epoxy primer, basecoat, >> clearcoat, will handle it all. Gravity fed(cup on top) or pot feed is >> the only way to go. Got mine on Ebay, new, half price what I could get >> it for locally. On Ebay search HVLP paint gun, Devilbiss, there are >> quite a few west coast reputable companies out there that have tons of >> stuff and great price. Like with anything - SHOP till you drop before >> laying out the $ . You'll get a better product for your bucks. >> 3). I picked up the digital level/laser also-mine was craftsman's club >> no brainer. check out there 3D laser level with stands for $40 when on >> sale. Very easy to stripe an a/c the entire length on both sides with >> two, or to do checkerboard on cowl/spinner/rudder. >> Hope that this all helped, >> PS - MUST have an inline water trap/filter with any compressor, big or >> small, compressed air makes water and will ruin your tools and paint. >> You are right-no inline oiler. >> Mike H 9A, 8A >> >> > > > ________________________________________________________________________________
Date: Oct 02, 2007
Tim - I flew into Nashville several years ago in my RV-8. Tune is a nice little airport (I got my pilots license there), but I ruled it out because I couldn't get a rental car there. If you can, it is great because it is right near an interstate that can whisk you downtown or to tourist attractions, etc. It is not very difficult to get to if you can read interstate signs. I landed at BNA and used one of the FBO's. It worked fine - no problems with tiedowns, fees weren't expensive, etc. They dropped me at the rental car counter with no trouble. Smyrna is fine too, but it is a little farther out than the other two. Hope that helps. If you need any suggestions about where to go, contact me off list. I grew up there. Parker ____________________________________ F. Parker Thomas me(at)parkerthomas.com www.parkerthomas.com Phone 510-393-9876 Fax 510-225-2358 > > I am posting this again because it never came through on the email list. > > My wife and I are planning to fly to Nashville for our anniversary in a > couple of weeks. I see there are two airports besides the International > airport (BNA). John C. Tune (JWN) and Cornelia (M88). Could someone from > this area tell me which would be the most RV (RV related post) friendly > airport between these two? We will be in town for 4 days. > > Any comments appreciated > Tim > > > ________________________________________________________________________________
Date: Oct 02, 2007
The system is sent out calibrated so you should not have to do anything. Yo can check it by setting your altimeter to zero feet and then seing if the setting matches the manifold pressure. We have our new forum up and running just for this type of question: _http://www.advanced-flight-systems.com/forum/_ (http://www.advanced-flight-systems.com/forum/) Sincerely, Rob Hickman ________________________________________________________________________________
Subject: alternate tailwheel - was Bell tailwheel
Date: Oct 02, 2007
I'm sure the Bell tailwheel and Vince's tailwheel (Screaming Eagle) are good. In the interest of maintaining the archives; another source for a very good tailwheel is the Aircraft Products product. The contact info is: Aviation Products, Inc. 114 Bryant Street Ojai, CA 93023 805-646-6042 I'm pretty sure they don't do computers but you can find pictures of them through the archives on builders' sites. I have one and like it as do a few of my friends flying RV's. Larry E. James Bellevue, WA Super Decathlon Rocket (under construction) ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Oct 02, 2007
If you use PVC, I would make sure your compressor is shut off after every use. Good practice either way. PVC will work but it will also become brittle over time and can shatter with a solid hit from something. If it's permanent, use type L copper pipe. It's more expensive but will last forever. It's also rated for compressed air. Michael Sausen Rv-10 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of mike humphrey Sent: Tuesday, October 02, 2007 12:00 AM Subject: Re: RV-List: HVLP Questions Scott, Glad that I could help out. One thing that is Critical to the life of any HVLP gun is to clean it immediately after use. I buy 5 gal cans of lacquer thinner at a discount paint shop/auto body shop and run 3x 1/2 cups of lacquer thinner through it after each use. Thoroughly wipe out the cup with a clean paper towel soaked in lacquer thinner and the nozzle. Let it air dry before putting it away. If you maintain your equipment, it will last forever. I have one HVLP gun that is 3 years old and shoots as good as day one. The outside ain't so pretty but the guts are spotless. Most people don't take care of their guns properly and then cuss them when they fail. Also you can plumb your shop with HIGH pressure PVC pipe and not cast iron, same isle as the regular PVC water pipe, just look for High Pressure HOT/COLD on the PVC. Regular or High PVC cement. Good luck, Mike H 9A, 8A ----- Original Message ----- From: "Scott" <acepilot(at)bloomer.net> Sent: Monday, October 01, 2007 6:46 AM Subject: Re: RV-List: HVLP Questions > > Sounds like good advice. I'll shop around... > > Scott > http://corbenflyer.tripod.com/ > Gotta Fly or Gonna Die > Building RV-4 (Super Slow Build Version) > > > mike humphrey wrote: > >> >> >> Bob, >> All I use any more is HVLP. It's the BOMB! Less, way less, overspray, >> and using a lot less material-saves$$$$$. >> 1) any good single stage or 2 stage air compressor will work. Any brand. >> I would suggest that if you have space and $ invest in a good stand up >> compressor. Sears is ok but over priced. If you have a Tractor Supply >> Co. near look there. If not any good discount place, home depot, Lowe's >> will have 30-80 gallon size. CFM is the number that you are looking for >> on the compressor. Higher the better. My IR is 80 gallon single stage >> 18.1CFM 5HP - works like a mule. It will also keep up with ANY air tool >> that you have, die grinder, cut off tool, sanders, NOTHING can bog it >> down. >> 2) Invest in a good quality HVLP gun. It makes all the difference in the >> world. DeVilbiss is all that I use. AKZO epoxy primer, basecoat, >> clearcoat, will handle it all. Gravity fed(cup on top) or pot feed is >> the only way to go. Got mine on Ebay, new, half price what I could get >> it for locally. On Ebay search HVLP paint gun, Devilbiss, there are >> quite a few west coast reputable companies out there that have tons of >> stuff and great price. Like with anything - SHOP till you drop before >> laying out the $ . You'll get a better product for your bucks. >> 3). I picked up the digital level/laser also-mine was craftsman's club >> no brainer. check out there 3D laser level with stands for $40 when on >> sale. Very easy to stripe an a/c the entire length on both sides with >> two, or to do checkerboard on cowl/spinner/rudder. >> Hope that this all helped, >> PS - MUST have an inline water trap/filter with any compressor, big or >> small, compressed air makes water and will ruin your tools and paint. >> You are right-no inline oiler. >> Mike H 9A, 8A >> >> > > ________________________________________________________________________________
Date: Oct 03, 2007
All good advice. I have no plans to plumb my shop with air though. I just drag the air hose around to where I need it... Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) RV Builder (Michael Sausen) wrote: > > If you use PVC, I would make sure your compressor is shut off after every use. Good practice either way. PVC will work but it will also become brittle over time and can shatter with a solid hit from something. If it's permanent, use type L copper pipe. It's more expensive but will last forever. It's also rated for compressed air. > >Michael Sausen >Rv-10 > > > > > ________________________________________________________________________________
Date: Oct 03, 2007
My last shop was plumbed with high pressure pvc pipe and I did have a blow out. I was in the shop when it happened and it took a few years off my life. Shrapnel was everywhere and damaged a couple of things but nothing major. If anyone wants to plumb the shop I would recommend this product: http://nibco.com/cms.do?id=2&pId=14 It is PVC and rated for compressed air. It isn't quite as cheap as regular o'l pvc but still not bad and glues together the same. It is green and they have great fittings for doing air. I used it and had T fittings pointing up for each drop. Then they have a 180 degree short bend that allows you to go from the T fitting down to your coupling. This is great because any water in your pipe is not dropped to your fittings but rather continues down the run to the end where you can place a separator. Good stuff and much safer. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) > Sent: Tuesday, October 02, 2007 7:40 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: HVLP Questions > > > > If you use PVC, I would make sure your compressor is shut off after > every use. Good practice either way. PVC will work but it will also > become brittle over time and can shatter with a solid hit from something. > If it's permanent, use type L copper pipe. It's more expensive but will > last forever. It's also rated for compressed air. > > Michael Sausen > Rv-10 > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of mike humphrey > Sent: Tuesday, October 02, 2007 12:00 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: HVLP Questions > > > > Scott, > Glad that I could help out. One thing that is Critical to the life of any > HVLP gun is to clean it immediately after use. I buy 5 gal cans of > lacquer > thinner at a discount paint shop/auto body shop and run 3x 1/2 cups of > lacquer thinner through it after each use. Thoroughly wipe out the cup > with > a clean paper towel soaked in lacquer thinner and the nozzle. Let it air > dry before putting it away. If you maintain your equipment, it will last > forever. I have one HVLP gun that is 3 years old and shoots as good as > day > one. The outside ain't so pretty but the guts are spotless. Most people > don't take care of their guns properly and then cuss them when they fail. > Also you can plumb your shop with HIGH pressure PVC pipe and not cast > iron, > same isle as the regular PVC water pipe, just look for High Pressure > HOT/COLD on the PVC. Regular or High PVC cement. > Good luck, > Mike H 9A, 8A > ----- Original Message ----- > From: "Scott" <acepilot(at)bloomer.net> > To: > Sent: Monday, October 01, 2007 6:46 AM > Subject: Re: RV-List: HVLP Questions > > > > > > Sounds like good advice. I'll shop around... > > > > Scott > > http://corbenflyer.tripod.com/ > > Gotta Fly or Gonna Die > > Building RV-4 (Super Slow Build Version) > > > > > > > > mike humphrey wrote: > > > >> > >> > >> Bob, > >> All I use any more is HVLP. It's the BOMB! Less, way less, overspray, > >> and using a lot less material-saves$$$$$. > >> 1) any good single stage or 2 stage air compressor will work. Any > brand. > >> I would suggest that if you have space and $ invest in a good stand up > >> compressor. Sears is ok but over priced. If you have a Tractor Supply > >> Co. near look there. If not any good discount place, home depot, > Lowe's > >> will have 30-80 gallon size. CFM is the number that you are looking > for > >> on the compressor. Higher the better. My IR is 80 gallon single stage > >> 18.1CFM 5HP - works like a mule. It will also keep up with ANY air > tool > >> that you have, die grinder, cut off tool, sanders, NOTHING can bog it > >> down. > >> 2) Invest in a good quality HVLP gun. It makes all the difference in > the > >> world. DeVilbiss is all that I use. AKZO epoxy primer, basecoat, > >> clearcoat, will handle it all. Gravity fed(cup on top) or pot feed is > >> the only way to go. Got mine on Ebay, new, half price what I could get > >> it for locally. On Ebay search HVLP paint gun, Devilbiss, there are > >> quite a few west coast reputable companies out there that have tons of > >> stuff and great price. Like with anything - SHOP till you drop before > >> laying out the $ . You'll get a better product for your bucks. > >> 3). I picked up the digital level/laser also-mine was craftsman's > club > >> no brainer. check out there 3D laser level with stands for $40 when on > >> sale. Very easy to stripe an a/c the entire length on both sides with > >> two, or to do checkerboard on cowl/spinner/rudder. > >> Hope that this all helped, > >> PS - MUST have an inline water trap/filter with any compressor, big or > >> small, compressed air makes water and will ruin your tools and paint. > >> You are right-no inline oiler. > >> Mike H 9A, 8A > >> > >> > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 03, 2007
Just for clarification, this stuff looks to be ABS and not PVC. Michael -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Wednesday, October 03, 2007 8:59 AM Subject: RE: RV-List: HVLP Questions My last shop was plumbed with high pressure pvc pipe and I did have a blow out. I was in the shop when it happened and it took a few years off my life. Shrapnel was everywhere and damaged a couple of things but nothing major. If anyone wants to plumb the shop I would recommend this product: http://nibco.com/cms.do?id=2&pId=14 It is PVC and rated for compressed air. It isn't quite as cheap as regular o'l pvc but still not bad and glues together the same. It is green and they have great fittings for doing air. I used it and had T fittings pointing up for each drop. Then they have a 180 degree short bend that allows you to go from the T fitting down to your coupling. This is great because any water in your pipe is not dropped to your fittings but rather continues down the run to the end where you can place a separator. Good stuff and much safer. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) > Sent: Tuesday, October 02, 2007 7:40 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: HVLP Questions > > > > If you use PVC, I would make sure your compressor is shut off after > every use. Good practice either way. PVC will work but it will also > become brittle over time and can shatter with a solid hit from something. > If it's permanent, use type L copper pipe. It's more expensive but will > last forever. It's also rated for compressed air. > > Michael Sausen > Rv-10 > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of mike humphrey > Sent: Tuesday, October 02, 2007 12:00 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: HVLP Questions > > > > Scott, > Glad that I could help out. One thing that is Critical to the life of any > HVLP gun is to clean it immediately after use. I buy 5 gal cans of > lacquer > thinner at a discount paint shop/auto body shop and run 3x 1/2 cups of > lacquer thinner through it after each use. Thoroughly wipe out the cup > with > a clean paper towel soaked in lacquer thinner and the nozzle. Let it air > dry before putting it away. If you maintain your equipment, it will last > forever. I have one HVLP gun that is 3 years old and shoots as good as > day > one. The outside ain't so pretty but the guts are spotless. Most people > don't take care of their guns properly and then cuss them when they fail. > Also you can plumb your shop with HIGH pressure PVC pipe and not cast > iron, > same isle as the regular PVC water pipe, just look for High Pressure > HOT/COLD on the PVC. Regular or High PVC cement. > Good luck, > Mike H 9A, 8A > ----- Original Message ----- > From: "Scott" <acepilot(at)bloomer.net> > To: > Sent: Monday, October 01, 2007 6:46 AM > Subject: Re: RV-List: HVLP Questions > > > > > > Sounds like good advice. I'll shop around... > > > > Scott > > http://corbenflyer.tripod.com/ > > Gotta Fly or Gonna Die > > Building RV-4 (Super Slow Build Version) > > > > > > > > mike humphrey wrote: > > > >> > >> > >> Bob, > >> All I use any more is HVLP. It's the BOMB! Less, way less, overspray, > >> and using a lot less material-saves$$$$$. > >> 1) any good single stage or 2 stage air compressor will work. Any > brand. > >> I would suggest that if you have space and $ invest in a good stand up > >> compressor. Sears is ok but over priced. If you have a Tractor Supply > >> Co. near look there. If not any good discount place, home depot, > Lowe's > >> will have 30-80 gallon size. CFM is the number that you are looking > for > >> on the compressor. Higher the better. My IR is 80 gallon single stage > >> 18.1CFM 5HP - works like a mule. It will also keep up with ANY air > tool > >> that you have, die grinder, cut off tool, sanders, NOTHING can bog it > >> down. > >> 2) Invest in a good quality HVLP gun. It makes all the difference in > the > >> world. DeVilbiss is all that I use. AKZO epoxy primer, basecoat, > >> clearcoat, will handle it all. Gravity fed(cup on top) or pot feed is > >> the only way to go. Got mine on Ebay, new, half price what I could get > >> it for locally. On Ebay search HVLP paint gun, Devilbiss, there are > >> quite a few west coast reputable companies out there that have tons of > >> stuff and great price. Like with anything - SHOP till you drop before > >> laying out the $ . You'll get a better product for your bucks. > >> 3). I picked up the digital level/laser also-mine was craftsman's > club > >> no brainer. check out there 3D laser level with stands for $40 when on > >> sale. Very easy to stripe an a/c the entire length on both sides with > >> two, or to do checkerboard on cowl/spinner/rudder. > >> Hope that this all helped, > >> PS - MUST have an inline water trap/filter with any compressor, big or > >> small, compressed air makes water and will ruin your tools and paint. > >> You are right-no inline oiler. > >> Mike H 9A, 8A > >> > >> > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 03, 2007
Subject: for sale: RV9 tail kit
For sale: RV9 tail kit with electric trim. I am located in a western suburb of Chicago. I can't pack it so someone will have to be in driving distance. I also bought the Cleaveland tool kit for RV's including a pneumatic squeezer. The tools are barely used. $1300 for the tail kit and $2100 for tools. More info: jharrison46atgmaildotcom ________________________________________________________________________________
Subject: Top forward skin help.
Date: Oct 03, 2007
Can some one give me some pointers on how to make the F-7106 (forward top skin) lay flat along the longeron rivet line. Should I pre-bend it around some pipe, use an edge roller or maybe hand bend it over the rounded edge of a table. It is just the last two inches that can't be realistically pulled down with clecos, and I don't want it lifting off the longeron between rivets. Thx Carl ________________________________________________________________________________
Date: Oct 03, 2007
Subject: Re: Top forward skin help.
Precurling the horizontal edge with an edge rolling tool helps quite a bit on the 6. Don't see why it shouldn't on the 7. Dick RV6A At 04:37 PM 10/3/2007, you wrote: >Can some one give me some pointers on how to make the F-7106 >(forward top skin) lay flat along the longeron rivet line. Should I >pre-bend it around some pipe, use an edge roller or maybe hand bend >it over the rounded edge of a table. It is just the last two inches >that can't be realistically pulled down with clecos, and I don't >want it lifting off the longeron between rivets. Thx Carl > ________________________________________________________________________________
Date: Oct 03, 2007
I've done both of those things, Carl -- rolled the skin and used the edge roller. But I also bought some wingnut clecos and those work great. -------- Bob Collins St. Paul, Minn. Letters from Flyover Country http://rvnewsletter.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137919#137919 ________________________________________________________________________________
Date: Oct 03, 2007
Carl, That is a tough edge to get to lay flat. I found standard clecos in every rivet hole would still not pull it completely flat along the longeron. There was still some puckering between the clecos. Wing nut clecos did pull it in. Here's what I did: Crease the edge with Avery's edge rolling tool (or whatever tool works for you): http://www.averytools.com/pc-45-70-edge-rolling-tool.aspx. Put a cleco in EVERY hole (unless it interferes with the rivet gun). Use wing nut clecos on the adjacent holes while riveting. Make sure to push the rivet gun onto the skin hard enough to push the top skin edge flat (may require someone pushing on the opposite side of the fuselage to keep it from sliding sideways). Mine came out without any puckering between rivets. good luck, Steve Allison RV-6A Carl Bell wrote: > > Can some one give me some pointers on how to make the F-7106 (forward > top skin) lay flat along the longeron rivet line. Should I pre-bend it > around some pipe, use an edge roller or maybe hand bend it over the > rounded edge of a table. It is just the last two inches that cant be > realistically pulled down with clecos, and I dont want it lifting off > the longeron between rivets. Thx Carl > ________________________________________________________________________________
Date: Oct 03, 2007
I had the same concerns but doing nothing worked for me. The top skin snugged right in there when we riveted it. My concern was not warranted as I am very pleased with the results. Steve Eberhart - RV-7A Slider, just riveted the forward top skin a week and a half ago. Working on canopy now. Carl Bell wrote: > > Can some one give me some pointers on how to make the F-7106 (forward > top skin) lay flat along the longeron rivet line. Should I pre-bend it > around some pipe, use an edge roller or maybe hand bend it over the > rounded edge of a table. It is just the last two inches that cant be > realistically pulled down with clecos, and I dont want it lifting off > the longeron between rivets. Thx Carl > ________________________________________________________________________________
Date: Oct 03, 2007
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
I did the same thing! Worked great! Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Bob Collins wrote: > > I've done both of those things, Carl -- rolled the skin and used the edge roller. > > But I also bought some wingnut clecos and those work great. > > -------- > Bob Collins > St. Paul, Minn. > Letters from Flyover Country > http://rvnewsletter.blogspot.com/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=137919#137919 > > > ________________________________________________________________________________
Date: Oct 03, 2007
Subject: Looking for RV-4 Rudder
Anyone have a spare RV-4 rudder, either complete or kit?=0A=0APaul Besing =0A=0A=0A=0A=0A=0A=0A =0A____________________________________________ ________________________________________=0AMoody friends. Drama queens. You ________________________________________________________________________________
Date: Oct 04, 2007
From: "George, Neal E Capt MIL USAF 605TES/TSI" <Neal.George(at)hurlburt.af.mil>
Carl - I took mine to the local sheet metal shop and asked them to roll it. Made a HUGE difference. Neal George =============== Can some one give me some pointers on how to make the F-7106 (forward top skin) lay flat along the longeron rivet line. Should I pre-bend it around some pipe, use an edge roller or maybe hand bend it over the rounded edge of a table. It is just the last two inches that can't be realistically pulled down with clecos, and I don't want it lifting off the longeron between rivets. Thx Carl ________________________________________________________________________________
Date: Oct 04, 2007
Thanks all for your help on that pesky forward skin, I'll do a little pre-bending and get some wing nut clecos. Carl -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bobby Hester Sent: Wednesday, October 03, 2007 10:44 PM Subject: Re: RV-List: Re: Top forward skin help. I did the same thing! Worked great! Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Bob Collins wrote: > > I've done both of those things, Carl -- rolled the skin and used the edge roller. > > But I also bought some wingnut clecos and those work great. > > -------- > Bob Collins > St. Paul, Minn. > Letters from Flyover Country > http://rvnewsletter.blogspot.com/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=137919#137919 > > > ________________________________________________________________________________
Date: Oct 04, 2007
George, that sound like a good idea, do you remember the radius they used? Thx Carl Carl W Bell New Venture Consulting Mobile: 803.640.2760 www.newventureconsulting.com carlbell(at)gforcecable.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of George, Neal E Capt MIL USAF 605TES/TSI Sent: Thursday, October 04, 2007 9:33 AM Subject: RE: RV-List: Top forward skin help. Carl - I took mine to the local sheet metal shop and asked them to roll it. Made a HUGE difference. Neal George =============== Can some one give me some pointers on how to make the F-7106 (forward top skin) lay flat along the longeron rivet line. Should I pre-bend it around some pipe, use an edge roller or maybe hand bend it over the rounded edge of a table. It is just the last two inches that can't be realistically pulled down with clecos, and I don't want it lifting off the longeron between rivets. Thx Carl ________________________________________________________________________________
Date: Oct 04, 2007
Subject: New Flight Bags...
Just added some great new bags for your RV, your production plane, or your travel needs. See whats new at: www.bisonmountainbags.com Happy Flying, Kurt --------------------------------- ________________________________________________________________________________
Date: Oct 04, 2007
Hi Carl, I hand curled or curved the skin. I did not treat the edges with an edging tool. I located two 2X4s long enough to slip the forward skin between them with enough left over to hold them in my bench mounted Vice,. I clamped the edge of the skin to be riveted between the 2x4s. with a large C clamps. This somewhat clumsy assemblage was then clamped into the vice. With care not to crease the skin at the 2x4 edges I pulled the skin over enough that the desired gentle curve was created. I repeated the set up for the other side. I did not try to make the skin curvature exactly match the supporting ribs. When done the skin rested not Clekoed onto the structure with the skins outer edges about two inches away from the fuse sides. Clekoes easily pulled the skin on as desired. When riveted the skin fit very nice , no puckering at all and no evidence of edging tool use. Keep building, Jim in Kelowna ----- Original Message ----- From: "Carl Bell" <carlbell(at)gforcecable.com> Sent: Thursday, October 04, 2007 10:10 AM Subject: RE: RV-List: Top forward skin help. > > George, that sound like a good idea, do you remember the radius they > used? > Thx Carl > > Carl W Bell > New Venture Consulting > Mobile: 803.640.2760 > www.newventureconsulting.com > carlbell(at)gforcecable.com > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of George, Neal E > Capt > MIL USAF 605TES/TSI > Sent: Thursday, October 04, 2007 9:33 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Top forward skin help. > > > > Carl - > > I took mine to the local sheet metal shop and asked them to roll it. > Made a HUGE difference. > > Neal George > > > =============== > Can some one give me some pointers on how to make the F-7106 (forward > top skin) lay flat along the longeron rivet line. Should I pre-bend it > around some pipe, use an edge roller or maybe hand bend it over the > rounded edge of a table. It is just the last two inches that can't be > realistically pulled down with clecos, and I don't want it lifting off > the longeron between rivets. Thx Carl > > > ________________________________________________________________________________
Date: Oct 04, 2007
Hi Bobby, I noticed you have an offset panel (I think it Affordable's) in your plane. Are you happy with it and would you do that one again or the XL? Also can you see your Garmin map in the dock ok in the position you have? I'm going with a G 496 and twin GRT's, an SL 30 and GTX 327. Any thoughts would be appreciated. Carl Carl W Bell New Venture Consulting Mobile: 803.640.2760 www.newventureconsulting.com carlbell(at)gforcecable.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bobby Hester Sent: Wednesday, October 03, 2007 10:44 PM Subject: Re: RV-List: Re: Top forward skin help. I did the same thing! Worked great! Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Bob Collins wrote: > > I've done both of those things, Carl -- rolled the skin and used the edge roller. > > But I also bought some wingnut clecos and those work great. > > -------- > Bob Collins > St. Paul, Minn. > Letters from Flyover Country > http://rvnewsletter.blogspot.com/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=137919#137919 > > > ________________________________________________________________________________
Subject: WTB: rv-3 or rv-4 project
From: "tailwheelbill" <1tnumqd02(at)sneakemail.com>
Date: Oct 04, 2007
Anybody know of any rv-3 or rv-4 projects for sale? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=138184#138184 ________________________________________________________________________________
Date: Oct 04, 2007
Subject: Re: Brake caliper bleed fitting.
Date: Oct 04, 2007
Yes ________________________________________________________________________________
Date: Oct 04, 2007
Yes Denis Walsh On Oct 1, 2007, at 07:20 8042400010, DEAN PSIROPOULOS wrote: > > > Probably a dumb question but...getting ready to install brake > calipers on > RV-6A. Cleveland installs the bleeder on the same side of both > calipers but > Van's drawing shows the bleeder at the bottom of the installation. > So....I'm assuming that I need to reverse the bleeder and the fluid > line > fittings on one of the Calipers? Yes/No? Thanks. > > Dean RV-6A > Hope to fly soon. > > ________________________________________________________________________________
Date: Oct 04, 2007
Yes. Put bleeder on bottom on both sides so that you can force any air bubbles up thru the system. Dale Enisng ----- Original Message ----- From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> Sent: Thursday, October 04, 2007 9:57 PM Subject: RV-List: Brake caliper bleed fitting. > > > > Probably a dumb question but...getting ready to install brake calipers on > RV-6A. Cleveland installs the bleeder on the same side of both calipers > but > Van's drawing shows the bleeder at the bottom of the installation. > So....I'm assuming that I need to reverse the bleeder and the fluid line > fittings on one of the Calipers? Yes/No? Thanks. > > Dean RV-6A > Hope to fly soon. > > > ________________________________________________________________________________
Subject: Power Charts
Date: Oct 05, 2007
I'm looking for a good all around power chart for a 180 HP, IO-360 with constant speed propeller. To be used for POH. Thanks in advance, please send to me direct. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Subject: Specific Power Chart
Date: Oct 05, 2007
I'm learning to be more specific. I need a power chart for an IO-360-MIB. Apparently it differs considerably from the O-360-A1A series. I have a graph and am looking for charted data or table format. Thanks, Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Oct 05, 2007
Subject: Re: Power Charts
Maybe here? http://www.edt.com/homewing/o360_power.html -- Larry Bowen Larry(at)BowenAero.com RV-8 for sale: http://BowenAero.com On 10/5/07, Steve Glasgow wrote: > > > I'm looking for a good all around power chart for a 180 HP, IO-360 with > constant speed propeller. > > To be used for POH. > > Thanks in advance, please send to me direct. > > Steve Glasgow-Cappy > N123SG RV-8 > Cappy's Toy > > ________________________________________________________________________________
Date: Oct 06, 2007
Subject: Power Chart for 180 hp IO-360
I need one too! I could also use the graph if someone would share that too! =0A=0AJohn Dalman=0AN247TD RV-8=0AElburn, IL ________________________________________________________________________________
Date: Oct 06, 2007
Here's another one: http://n5lp.net/Power.htm -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=138474#138474 ________________________________________________________________________________
Date: Oct 01, 2007
Yes, you do... ----- Original Message ----- From: DEAN PSIROPOULOS To: rv-list(at)matronics.com Sent: Monday, October 01, 2007 10:20 PM Subject: RV-List: Brake caliper bleed fitting. Probably a dumb question but...getting ready to install brake calipers on RV-6A. Cleveland installs the bleeder on the same side of both calipers but Van's drawing shows the bleeder at the bottom of the installation. So....I'm assuming that I need to reverse the bleeder and the fluid line fittings on one of the Calipers? Yes/No? Thanks. Dean RV-6A Hope to fly soon. ________________________________________________________________________________
Date: Oct 07, 2007
Also see Kevin Horton's site: http://www.kilohotel.com/rv8/phplinks/out.php?&ID=49 Doug Gray > Maybe here? > > http://www.edt.com/homewing/o360_power.html > > -- > Larry Bowen > Larry(at)BowenAero.com > RV-8 for sale: http://BowenAero.com > > On 10/5/07, Steve Glasgow wrote: > > > I'm looking for a good all around power chart for a 180 HP, > IO-360 with > > > > > > > > ________________________________________________________________________________
Subject: Fiberglass Panel
Date: Oct 07, 2007
Does anyone know how to get to Laird Owens, is he still making panels? Does he have a site? ________________________________________________________________________________
From: "Shirley Harding" <ShirleyH(at)oceanbroadband.net>
Subject: Altimeter error
Date: Oct 07, 2007
Today the altimeter in our RV6 developed a strange fault. When we set airfield elevation on the ground the pressure displayed was much lower than reported on the forecast. We set the forecast qnh and that gave an altimeter error of about 600 feet high. We reset to airfield elevation and took off. At altitude we set the area qnh reported on Jandakot ATIS which was 20 mb higher than our altimeter was indicating. We've checked the static lines - no blockages or leaks that we can find. Any thoughts? Cheers Shirley ________________________________________________________________________________
Subject: Re: Fiberglass Panel
Date: Oct 07, 2007
I contacted him by email a months ago and he was still making the panels. I don't think he has a website yet. His email is: owens(at)aerovironment.com Smitty http://SmittysRV.com ----- Original Message ----- From: Carl Bell To: rv-list(at)matronics.com Sent: Saturday, October 06, 2007 11:33 PM Subject: RV-List: Fiberglass Panel Does anyone know how to get to Laird Owens, is he still making panels? Does he have a site? ________________________________________________________________________________
Date: Oct 07, 2007
Hi Smitty, That is the address I tried and this is what I get back: SMTP module(domain [192.168.20.116]) reports: host 192.168.20.116 says: 550 Invalid recipient Carl W Bell New Venture Consulting Mobile: 803.640.2760 <http://www.newventureconsulting.com> www.newventureconsulting.com carlbell(at)gforcecable.com _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Smitty Sent: Sunday, October 07, 2007 8:13 AM Subject: Re: RV-List: Fiberglass Panel I contacted him by email a months ago and he was still making the panels. I don't think he has a website yet. His email is: owens(at)aerovironment.com Smitty http://SmittysRV.com ----- Original Message ----- From: Carl <mailto:carlbell(at)gforcecable.com> Bell Sent: Saturday, October 06, 2007 11:33 PM Subject: RV-List: Fiberglass Panel Does anyone know how to get to Laird Owens, is he still making panels? Does he have a site? href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Oct 07, 2007
Got this as a local SoCAL message. ------- insert ------- [Fwd: RV-List: Fiberglass Panel] Ed, I'm not subscribed to Matt's lists. Can you forward my email? laird "at" macelgin.com Thanks, I appreciate it. Laird --------- end insert -------- Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 2,055 + Flying Hours So. CA, USA From: carlbell(at)gforcecable.com Subject: RE: RV-List: Fiberglass Panel Date: Sun, 7 Oct 2007 09:58:36 -0400 Hi Smitty, That is the address I tried and this is what I get back: SMTP module(domain [192.168.20.116]) reports: host 192.168.20.116 says: 550 Invalid recipient Carl W Bell New Venture Consulting Mobile: 803.640.2760 www.newventureconsulting.com carlbell(at)gforcecable.com From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Smitty Sent: Sunday, October 07, 2007 8:13 AM Subject: Re: RV-List: Fiberglass Panel I contacted him by email a months ago and he was still making the panels. I don't think he has a website yet. His email is: owens(at)aerovironment.com Smitty http://SmittysRV.com ----- Original Message ----- From: Carl Bell Sent: Saturday, October 06, 2007 11:33 PM Subject: RV-List: Fiberglass Panel Does anyone know how to get to Laird Owens, is he still making panels? Does he have a site? href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.mat ronics.com _________________________________________________________________ Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop by today. http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_Oc tWLtagline ________________________________________________________________________________
Subject: Re: Altimeter error
Date: Oct 07, 2007
Shirley, Anything in an airplane that has preformed well for a long time and then suddenly has a change should be looked at by someone with experience in that field. That being said, and if you are sure that altimeter is otherwise functioning correctly, with reasonable care try this. Adjust the altimeter to airfield elevation. Near the adjustment knob there is a flat head screw. Carefully turn it out until the head just clears the face of the instrument but still is engaged in the threads. The screw is engaged in a small rod that locks the knob in position. Try not to let it come out or lose it. Slide the screw away from the adjustment knob to unlock it. With care, pull out on the knob. In this position the knob will only adjust the Kollsman's window. Set the QNH in the Kollsman's window. When manipulating the knob in and out, use a very slight and gentle twisting force to accommodate its movement. Move the knob to the in position, slide the screw/lock back to where the screw can be turned in to its original position. If its within 50 ft you got it, if not, do it again. Careful, John D. ----- Original Message ----- From: "Shirley Harding" <ShirleyH(at)oceanbroadband.net> Sent: Sunday, October 07, 2007 2:56 AM Subject: RV-List: Altimeter error > > > Today the altimeter in our RV6 developed a strange fault. When we set > airfield elevation on the ground the pressure displayed was much lower > than > reported on the forecast. We set the forecast qnh and that gave an > altimeter > error of about 600 feet high. We reset to airfield elevation and took off. > At altitude we set the area qnh reported on Jandakot ATIS which was 20 mb > higher than our altimeter was indicating. > > We've checked the static lines - no blockages or leaks that we can find. > Any > thoughts? > > Cheers > > Shirley > > ________________________________________________________________________________
Subject: Re: Aileron leading edges
Date: Oct 07, 2007
For the archives: Scott at Van's looked at the photos and is sending out new aileron leading edge skins. On Monday October 1 2007 09:18:08 pm Michael D. Cencula wrote: > > Greetings listers. > > I'm working on the ailerons for my -7A and have a slight issue with the > leading edge skins. As you probably know, the bottom portion of the > leading edge skin is flat and the top is curved. The problem is that the > top isn't curved enough. I have to pull the skin down about 1 1/2 or 2 > inches to cleco it to the aileron spar. This makes the bottom skin bulge > out. Did anyone else run into this? What did you do to fix it? I've > thought about trying to curl the top of the aileron leading edge skin some > more, but not sure how to do that. > > Thanks for any help you can offer. > > Mike Cencula > RV-7A wings > ________________________________________________________________________________
Date: Oct 07, 2007
DQpNaWtlLA0KR29vZCB0byBrbm93LiBUaGFua3MhIEknbSBqdXN0IGdldHRpbmcgaW50byBtaW5l IHNvIHlvdSB0aW1pbmcgaXMgcGVyZmVjdC4NCkJyZW50IE93ZW5zDQpBc3Npc3RhbnQgRGlyZWN0 b3Igb2YgT3BlcmF0aW9ucw0KTmV0SmV0cyBBdmlhdGlvbg0KeDI0ODYNCg0KLS0tLS1PcmlnaW5h bCBNZXNzYWdlLS0tLS0NCkZyb206IG93bmVyLXJ2LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20g PG93bmVyLXJ2LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+DQpUbzogcnYtbGlzdEBtYXRyb25p Y3MuY29tIDxydi1saXN0QG1hdHJvbmljcy5jb20+DQpTZW50OiBTdW4gT2N0IDA3IDE0OjA4OjA3 IDIwMDcNClN1YmplY3Q6IFJlOiBSVi1MaXN0OiBBaWxlcm9uIGxlYWRpbmcgZWRnZXMNCg0KLS0+ IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJNaWNoYWVsIEQuIENlbmN1bGEiIDxtYXRyb25p Y3NAY2VuY3VsYS5jb20+DQoNCkZvciB0aGUgYXJjaGl2ZXM6DQoNClNjb3R0IGF0IFZhbidzIGxv b2tlZCBhdCB0aGUgcGhvdG9zIGFuZCBpcyBzZW5kaW5nIG91dCBuZXcgYWlsZXJvbiANCmxlYWRp bmcgZWRnZSBza2lucy4NCg0KT24gTW9uZGF5IE9jdG9iZXIgMSAyMDA3IDA5OjE4OjA4IHBtIE1p Y2hhZWwgRC4gQ2VuY3VsYSB3cm90ZToNCj4gLS0+IFJWLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6 ICJNaWNoYWVsIEQuIENlbmN1bGEiIDxtYXRyb25pY3NAY2VuY3VsYS5jb20+DQo+DQo+IEdyZWV0 aW5ncyBsaXN0ZXJzLg0KPg0KPiBJJ20gd29ya2luZyBvbiB0aGUgYWlsZXJvbnMgZm9yIG15IC03 QSBhbmQgaGF2ZSBhIHNsaWdodCBpc3N1ZSB3aXRoIHRoZQ0KPiBsZWFkaW5nIGVkZ2Ugc2tpbnMu ICBBcyB5b3UgcHJvYmFibHkga25vdywgdGhlIGJvdHRvbSBwb3J0aW9uIG9mIHRoZQ0KPiBsZWFk aW5nIGVkZ2Ugc2tpbiBpcyBmbGF0IGFuZCB0aGUgdG9wIGlzIGN1cnZlZC4gIFRoZSBwcm9ibGVt IGlzIHRoYXQgdGhlDQo+IHRvcCBpc24ndCBjdXJ2ZWQgZW5vdWdoLiAgSSBoYXZlIHRvIHB1bGwg dGhlIHNraW4gZG93biBhYm91dCAxIDEvMiBvciAyDQo+IGluY2hlcyB0byBjbGVjbyBpdCB0byB0 aGUgYWlsZXJvbiBzcGFyLiAgVGhpcyBtYWtlcyB0aGUgYm90dG9tIHNraW4gYnVsZ2UNCj4gb3V0 LiAgRGlkIGFueW9uZSBlbHNlIHJ1biBpbnRvIHRoaXM/ICBXaGF0IGRpZCB5b3UgZG8gdG8gZml4 IGl0PyAgSSd2ZQ0KPiB0aG91Z2h0IGFib3V0IHRyeWluZyB0byBjdXJsIHRoZSB0b3Agb2YgdGhl IGFpbGVyb24gbGVhZGluZyBlZGdlIHNraW4gc29tZQ0KPiBtb3JlLCBidXQgbm90IHN1cmUgaG93 IHRvIGRvIHRoYXQuDQo+DQo+IFRoYW5rcyBmb3IgYW55IGhlbHAgeW91IGNhbiBvZmZlci4NCj4N Cj4gTWlrZSBDZW5jdWxhDQo+IFJWLTdBIHdpbmdzDQo+DQoNCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAg LSBUaGUgUlYtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBG ZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMg c3VjaCBhcyB0aGUgU3Vic2NyaXB0aW9ucyBwYWdlLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93 bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNo IG11Y2ggbW9yZToNCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9y P1JWLUxpc3QNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBXRUIgRk9S VU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgbm93IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUg V2ViIEZvcnVtcyENCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQoNCg0KDQoNClRoaXMgbWVzc2FnZSBjb250YWlucyBpbmZvcm1hdGlvbiB3aGljaCBtYXkgYmUg Y29uZmlkZW50aWFsIGFuZCBwcml2aWxlZ2VkLiBVbmxlc3MgeW91IGFyZSB0aGUgYWRkcmVzc2Vl IChvciBhdXRob3JpemVkIHRvIHJlY2VpdmUgZm9yIHRoZSBhZGRyZXNzZWUpLCB5b3UgbWF5IG5v dCB1c2UsIGNvcHkgb3IgZGlzY2xvc2UgdG8gYW55b25lIHRoZSBtZXNzYWdlIG9yIGFueSBpbmZv cm1hdGlvbiBjb250YWluZWQgaW4gdGhlIG1lc3NhZ2UuIElmIHlvdSBoYXZlIHJlY2VpdmVkIHRo ZSBtZXNzYWdlIGluIGVycm9yLCAgcGxlYXNlIGFkdmlzZSB0aGUgc2VuZGVyIGJ5IHJlcGx5IGUt bWFpbCBhbmQgZGVsZXRlIHRoZSBtZXNzYWdlLg0K ________________________________________________________________________________
Subject: Bell Tailwheel Fork
Date: Oct 08, 2007
Fellow flyers and builders... Yes my Dad is still making the tailwheel forks. He did hae a summer offf as he puts it due to Heat and helping me paint my 8. But he has made a deal with a local pilot owned machine shop to assist him in production. the forks will still go out only after he as approved their look, fit, finish and feel. We appreciate the patience of those who are waiting on the order list and many of you have contacted us after he put orders on hold. I think this help will catch us up quickly and we should be able to get to all of you. Dad takes great pride in helping you and with this fork...it just quickly became overwheming for him. Thanks and please diorect any emails to me at dbell(at)manisteenational.com Now that golf season is coming to an end here in Michigan, I will keep up with email reply's better. Thanks to all who are interested and those current customers that have posted kind comments... Doug Bell jr. RV8 266WB Manistee, MI ________________________________________________________________________________
Subject: ProSeal
Date: Oct 09, 2007
I posted this over the weekend on the VAF site, but got no response. -8A QB N192NM so I haven't had the fun assembling the tanks. However, it is time to install the float-type fuel senders. I've got a tube of "stuff" from Vans that's supposed to work - if I can really figure out the mixing instructions. Some really basic questions: 1. Urban legend sez to toss the cork gaskets. Is that correct? 2. Bead size - what's appropriate? While subscribing to the "More is better" idea, what happens if the excess oozes from the cover plate into the tank and possibly breaks loose sometime in the future? 3. Rubber gaskets - just in case the damn thing doesn't work and I have to remove the sender, I intend to use the provided rubber gaskets without sealer, but put plenty of sealer on the screws before assembly. Good idea? 4. Shelf life - or more accurately - "After mixing useful life". How long do I have after mixing for useful application capability? Paul Valovich N192NM Reserved (Again) ________________________________________________________________________________
Subject: cutting canopy
Date: Oct 09, 2007
Not very long ago there was an article in EAA-SPORTAVIATION that explained and suggested to make the cut using a cutting bit in a Dremel tool with a cutting guide. I think it was written by an RV builder. I cannot find the article anymore. Anyone know the details, or has experience with this method ? Should you recommend it? Jef Vervoort 91031; Belgium. ________________________________________________________________________________
Subject: Re: ProSeal
Date: Oct 09, 2007
//1. Urban legend sez to toss the cork gaskets. Is that correct? As with many things in RV building, there's no right or wrong answer. It's a matter of personal taste. Ken Scott says the cork gaskets will leak as they dry out and recommends just prosealing. Others have reported no problem with the cork gaskets. Still others have used cork gaskets AND proseal. Part of your decision may have to do with what happens if you have to remove the sender. It's a lot easier just unscrewing and pulling it off if all you've used is cork. When meetingthe Van's SB, I pulled both access plates off -- one with cork and proseal and one with just proseal -- and found both were quite an exercise. //2. Bead size - what's appropriate? While subscribing to the "More is better" idea, what happens if the excess oozes from the cover plate into the tank and possibly breaks loose sometime in the future? I subscribe to the more is better rule. I see little liklihood of something breaking off in the future. Keep the George Orndorff rule in mind. "If you look in there and say, "that can't leak," it probably won't. But if you look at i and say, "I don't THINK that'll leak, it probably will." // Rubber gaskets - just in case the damn thing doesn't work and I have to remove the sender, I intend to use the provided rubber gaskets without sealer, but put plenty of sealer on the screws before assembly. Good idea? I did not use the rubber gasket because I found it quite difficult with the screws on the call-out to get the sender attached. To me, it seemed the rubber gasket was too think. I just ProSealed. //4. Shelf life - or more accurately - "After mixing useful life". How long do I have after mixing for useful application capability? It depends on the temperature. I've used ProSeal in an unheated garage in December and it's REALLY thick but takes a long time to set up so you have more time. I've done it in the heat of summer and while it's easier to apply, It begins to skin over pretty quickly -- within 15, as I recall. To me THIS is the big problem I have with those tubes rather than the two cans. When I used the cans (and I used two quarts on my tanks, by the way, that's how MUCH I subscribed to the Orndorrf theory (g)), I would use just mix up about 35-40 grams... enough for a couple of ribs, and then work on those two ribs. Then I'd take a long break and mix more up. Lots of popsicle sticks, lots of mess, lots of gloves, but I liked being more slow and methodical and not be under pressure to get stuff done before the ProSeal bomb goes off. With the tubes...you don't get the mess, but you pay for it with less flexibility on time and if you are very organized and efficient, I think they're a great way to go. I did buy the tube once (we're talking about the one where you mix it in the tube, right?) for something like $16 and I ended up tossing half of it away because I didn't need that much. Some people freeze their ProSeal which they say adds life to it etc. I cannot speak to that because while my wife is quite forgiving of my airplane mistress, she draws the line when reaching for an ice cream sandwich and getting a baggie full of ProSeal instead. -------- Bob Collins St. Paul, Minn. Letters from Flyover Country http://rvnewsletter.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=138980#138980 ________________________________________________________________________________
From: Charles Rowbotham <crowbotham(at)hotmail.com>
Date: Oct 09, 2007
Jef, We used a cut off disc in Dremel tool but we did it free hand. One note of caution - allow some extra overhang (beyound the line on the canopy). The overhang will not interfere with fitting the canopy to the frame or drillin g your holes. After you have fitted the canopy canopy, drilled your holes a nd clecoed the canopy to the fame you can mark the excess for removal. BTW we tried the plexiglass drill bits and had much better results but dril ling the initial hole with anew #40 drill bit and then opening up the hole with the small Uni-Bit. We did have the garage at 60 degrees C (85 degress F) for 24 hours before we drilled the canopy holes. Best Wishes, Chuck & Dave Rowbotham RV-8A From: jef.vervoortw(at)telenet.beTo: rv-list(at)matronics.comSubject: RV-List: cu tting canopyDate: Tue, 9 Oct 2007 17:14:07 +0200 Not very long ago there was an article in EAA-SPORTAVIATION that explained and suggested to make the cut using a cutting bit in a Dremel tool with a c utting guide. I think it was written by an RV builder. I cannot find the article anymore. Anyone know the details, or has experience with this method ? Should you re commend it? Jef Vervoort 91031; Belgium. _________________________________________________________________ ! ilnews ________________________________________________________________________________
Date: Oct 09, 2007
Hi Chuck, I would question just one thing you mentioned here. The problem with a regular drill bit on plexi is the amount of twist in the bit will allow it to try to pull through the plexi causing a crack. You mentioned using a new # 40 bit, but in reality I think you are better off with a dull one. I used a regular "dull" bit to drill my initial holes in the canopy. Then I used the plexi bits to open them up to the size I needed. Anyway, I could be wrong but it seems this is how I remember how it goes. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Rowbotham Sent: Tuesday, October 09, 2007 12:27 PM Subject: RE: RV-List: cutting canopy Jef, We used a cut off disc in Dremel tool but we did it free hand. One note of caution - allow some extra overhang (beyound the line on the canopy). The overhang will not interfere with fitting the canopy to the frame or drilling your holes. After you have fitted the canopy canopy, drilled your holes and clecoed the canopy to the fame you can mark the excess for removal. BTW we tried the plexiglass drill bits and had much better results but drilling the initial hole with anew #40 drill bit and then opening up the hole with the small Uni-Bit. We did have the garage at 60 degrees C (85 degress F) for 24 hours before we drilled the canopy holes. Best Wishes, Chuck & Dave Rowbotham RV-8A _____ From: jef.vervoortw(at)telenet.be Subject: RV-List: cutting canopy Date: Tue, 9 Oct 2007 17:14:07 +0200 Not very long ago there was an article in EAA-SPORTAVIATION that explained and suggested to make the cut using a cutting bit in a Dremel tool with a cutting guide. I think it was written by an RV builder. I cannot find the article anymore. Anyone know the details, or has experience with this method ? Should you recommend it? Jef Vervoort 91031; Belgium. _____ Boo! Scare awnews' target='_new'>Try now! ________________________________________________________________________________
Date: Oct 09, 2007
I agree with you on sharp vs dull, Tim. For cutting mine, I did it freehand, using a 4=94 cutoff wheel in my battery drill. Using one in a die grinder should work just as well. IMHO, the Dremel cutters are too fine for what=92s needed here ' no need for such a fine cut, with larger diameter cutter, you can get wheel more perpendicular to the work, and the fine Dremel wheels break easily. Details here: HYPERLINK "http://brian76.mystarband.net/canopy.htm"http://brian76.mystarband.net/c ano py.htm - plexi work beginning end of September if it=92s cold out when you work on plexi, just put the canopy on sawhorses & put a little camping heater under the bubble for awhile ot get plexi nice & warm brian _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Tuesday, October 09, 2007 1:55 PM Subject: RE: RV-List: cutting canopy Hi Chuck, I would question just one thing you mentioned here. The problem with a regular drill bit on plexi is the amount of twist in the bit will allow it to try to pull through the plexi causing a crack. You mentioned using a new # 40 bit, but in reality I think you are better off with a dull one. I used a regular =93dull=94 bit to drill my initial holes in the canopy. Then I used the plexi bits to open them up to the size I needed. Anyway, I could be wrong but it seems this is how I remember how it goes. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Rowbotham Sent: Tuesday, October 09, 2007 12:27 PM Subject: RE: RV-List: cutting canopy Jef, We used a cut off disc in Dremel tool but we did it free hand. One note of caution - allow some extra overhang (beyound the line on the canopy). The overhang will not interfere with fitting the canopy to the frame or drilling your holes. After you have fitted the canopy canopy, drilled your holes and clecoed the canopy to the fame you can mark the excess for removal. BTW we tried the plexiglass drill bits and had much better results but drilling the initial hole with anew #40 drill bit and then opening up the hole with the small Uni-Bit. We did have the garage at 60 degrees C (85 degress F) for 24 hours before we drilled the canopy holes. Best Wishes, Chuck & Dave Rowbotham RV-8A _____ From: jef.vervoortw(at)telenet.be Subject: RV-List: cutting canopy Date: Tue, 9 Oct 2007 17:14:07 +0200 Not very long ago there was an article in EAA-SPORTAVIATION that explained and suggested to make the cut using a cutting bit in a Dremel tool with a cutting guide. I think it was written by an RV builder. I cannot find the article anymore. Anyone know the details, or has experience with this method ? Should you recommend it? Jef Vervoort 91031; Belgium. _____ Boo! Scare awnews' target='_new'>Try now! "http://www.matronics.com/Navigator?RV-List"http://www.matronics.com/Navi gat or?RV-List "http://forums.matronics.com"http://forums.matronics.com 10/8/2007 4:54 PM 10/8/2007 4:54 PM ________________________________________________________________________________
Date: Oct 09, 2007
Tim is correct. Plexiglass drill bits have been made with about half the cutting angle of regular metal cutting bits. This restrains them from getting too much bite and starting a crack. Use moderate drill speed (not slow) and low pressure. Test your dull bit on scrap first. Dale _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Tuesday, October 09, 2007 1:55 PM Subject: RE: RV-List: cutting canopy Hi Chuck, I would question just one thing you mentioned here. The problem with a regular drill bit on plexi is the amount of twist in the bit will allow it to try to pull through the plexi causing a crack. You mentioned using a new # 40 bit, but in reality I think you are better off with a dull one. I used a regular "dull" bit to drill my initial holes in the canopy. Then I used the plexi bits to open them up to the size I needed. Anyway, I could be wrong but it seems this is how I remember how it goes. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Rowbotham Sent: Tuesday, October 09, 2007 12:27 PM Subject: RE: RV-List: cutting canopy Jef, We used a cut off disc in Dremel tool but we did it free hand. One note of caution - allow some extra overhang (beyound the line on the canopy). The overhang will not interfere with fitting the canopy to the frame or drilling your holes. After you have fitted the canopy canopy, drilled your holes and clecoed the canopy to the fame you can mark the excess for removal. BTW we tried the plexiglass drill bits and had much better results but drilling the initial hole with anew #40 drill bit and then opening up the hole with the small Uni-Bit. We did have the garage at 60 degrees C (85 degress F) for 24 hours before we drilled the canopy holes. Best Wishes, Chuck & Dave Rowbotham RV-8A ________________________________________________________________________________
Subject: Sealing fuel tank inspection plate & sender
Date: Oct 09, 2007
You might consider using SS Allen head cap screws on the inspection plates and the sender mounts in lieu of the Phillips head screws. In my opinion; 1. They make it easier to more evenly torque the screws. 2. The bottom of the head of the cap screws have a slight undercut which makes a sealing edge out at the periphery of the screw head. 3. And, if you need to remove or re-torque the screws with the wing on, it is much easier to do with a short Allen wrench segment in one of the very small right angle ratchet screwdrivers handles. I had done my 6A tanks with the cap screws and when Van's came out with the SB, getting the screws out and reinstalling them was very simple. Dale Ensing > Part of your decision may have to do with what happens if you have to > remove the sender. It's a lot easier just unscrewing and pulling it off if > all you've used is cork. When meetingthe Van's SB, I pulled both access > plates off -- one with cork and proseal and one with just proseal -- and > found both were quite an exercise. > > > // Rubber gaskets - just in case they don't work and I have to remove the > sender, I intend to use the provided rubber gaskets without sealer, but > put plenty of sealer on the screws before assembly. Good idea? > > I did not use the rubber gasket because I found it quite difficult with > the screws on the call-out to get the sender attached. To me, it seemed > the rubber gasket was too think. I just ProSealed. ________________________________________________________________________________
Subject: Re: cutting canopy
Date: Oct 09, 2007
dale1rv6(at)comcast.net wrote: > Use moderate drill speed (not slow) and low pressure. Test your dull bit on scrap first. > Dale > Too late for me now but I'm curious if I've introduced a problem into my canopy project unwittingly. I turned my drill VERY slowly when drilling the canopy, exerting very little pressure. My goal was to scrape...not cut... when I drilled. What have I done by drilling too slowly? -------- Bob Collins St. Paul, Minn. Letters from Flyover Country http://rvnewsletter.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=138991#138991 ________________________________________________________________________________
From: "Jim Fogarty at Lakes & Leisure Realty" <jfogarty(at)tds.net>
Date: Oct 09, 2007
Here's my question, has anyone ever used EZ Turn Fuellube between the gasket and the plate, Vs proseal? Jim RV9a ----- Original Message ----- From: "Bob Collins" <bcollinsrv7a(at)comcast.net> Sent: Tuesday, October 09, 2007 11:58 AM Subject: RV-List: Re: ProSeal > > //1. Urban legend sez to toss the cork gaskets. Is that correct? > > As with many things in RV building, there's no right or wrong answer. It's > a matter of personal taste. Ken Scott says the cork gaskets will leak as > they dry out and recommends just prosealing. Others have reported no > problem with the cork gaskets. Still others have used cork gaskets AND > proseal. > > Part of your decision may have to do with what happens if you have to > remove the sender. It's a lot easier just unscrewing and pulling it off if > all you've used is cork. When meetingthe Van's SB, I pulled both access > plates off -- one with cork and proseal and one with just proseal -- and > found both were quite an exercise. > > //2. Bead size - what's appropriate? While subscribing to the "More is > better" idea, what happens if the excess oozes from the cover plate into > the tank and possibly breaks loose sometime in the future? > > I subscribe to the more is better rule. I see little liklihood of > something breaking off in the future. Keep the George Orndorff rule in > mind. "If you look in there and say, "that can't leak," it probably won't. > But if you look at i and say, "I don't THINK that'll leak, it probably > will." > > // Rubber gaskets - just in case the damn thing doesn't work and I have to > remove the sender, I intend to use the provided rubber gaskets without > sealer, but put plenty of sealer on the screws before assembly. Good idea? > > I did not use the rubber gasket because I found it quite difficult with > the screws on the call-out to get the sender attached. To me, it seemed > the rubber gasket was too think. I just ProSealed. > > //4. Shelf life - or more accurately - "After mixing useful life". How > long do I have after mixing for useful application capability? > > It depends on the temperature. I've used ProSeal in an unheated garage in > December and it's REALLY thick but takes a long time to set up so you have > more time. I've done it in the heat of summer and while it's easier to > apply, It begins to skin over pretty quickly -- within 15, as I recall. > > To me THIS is the big problem I have with those tubes rather than the two > cans. When I used the cans (and I used two quarts on my tanks, by the way, > that's how MUCH I subscribed to the Orndorrf theory (g)), I would use just > mix up about 35-40 grams... enough for a couple of ribs, and then work on > those two ribs. Then I'd take a long break and mix more up. Lots of > popsicle sticks, lots of mess, lots of gloves, but I liked being more slow > and methodical and not be under pressure to get stuff done before the > ProSeal bomb goes off. > > With the tubes...you don't get the mess, but you pay for it with less > flexibility on time and if you are very organized and efficient, I think > they're a great way to go. > > I did buy the tube once (we're talking about the one where you mix it in > the tube, right?) for something like $16 and I ended up tossing half of it > away because I didn't need that much. > > Some people freeze their ProSeal which they say adds life to it etc. I > cannot speak to that because while my wife is quite forgiving of my > airplane mistress, she draws the line when reaching for an ice cream > sandwich and getting a baggie full of ProSeal instead. > > -------- > Bob Collins > St. Paul, Minn. > Letters from Flyover Country > http://rvnewsletter.blogspot.com/ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=138980#138980 > > > -- > 8:44 AM > > ________________________________________________________________________________
Date: Oct 09, 2007
No problem, the light pressure is the most important. If you don't see any cracks you are a winner. Some who go slow push harder when they don't see the hole developing and that can start a crack. The ideal combination of speed and pressure will produce a thin rather steady chip. A machinist judges his progress based on the chip output. Dale -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Collins Sent: Tuesday, October 09, 2007 3:03 PM Subject: RV-List: Re: cutting canopy dale1rv6(at)comcast.net wrote: > Use moderate drill speed (not slow) and low pressure. Test your dull bit on scrap first. > Dale > Too late for me now but I'm curious if I've introduced a problem into my canopy project unwittingly. I turned my drill VERY slowly when drilling the canopy, exerting very little pressure. My goal was to scrape...not cut... when I drilled. What have I done by drilling too slowly? -------- Bob Collins St. Paul, Minn. Letters from Flyover Country http://rvnewsletter.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=138991#138991 ________________________________________________________________________________
Subject: Re: Altimeter error - ASI question
Date: Oct 10, 2007
John, Very interesting procedure for adjusting the Altimeter. I'm looking forward to the outcome from Shirley. Do you have a procedure for adjusting an airspeed indicator? I have a very nice second hand ASI (Unknown German brand, model is FM-440/4) but has an error at zero diff. pressure of ~25 kts. I have not tested the range yet so I don't know if this is across the scale. Can this be adjusted or do I have a dud? TIA Doug Gray > > Shirley, > > Anything in an airplane that has preformed well for a long time and then > suddenly has a change should be looked at by someone with experience in that > field. That being said, and if you are sure that altimeter is otherwise > functioning correctly, with reasonable care try this. Adjust the altimeter > to airfield elevation. Near the adjustment knob there is a flat head screw. > Carefully turn it out until the head just clears the face of the instrument > but still is engaged in the threads. The screw is engaged in a small rod > that locks the knob in position. Try not to let it come out or lose it. > Slide the screw away from the adjustment knob to unlock it. With care, pull > out on the knob. In this position the knob will only adjust the Kollsman's > window. Set the QNH in the Kollsman's window. When manipulating the knob in > and out, use a very slight and gentle twisting force to accommodate its > movement. Move the knob to the in position, slide the screw/lock back to > where the screw can be turned in to its original position. If its within 50 > ft you got it, if not, do it again. > > Careful, > John D. > ----- Original Message ----- > From: "Shirley Harding" <ShirleyH(at)oceanbroadband.net> > To: > Sent: Sunday, October 07, 2007 2:56 AM > Subject: RV-List: Altimeter error > > > > > > > > Today the altimeter in our RV6 developed a strange fault. When we set > > airfield elevation on the ground the pressure displayed was much lower > > than > > reported on the forecast. We set the forecast qnh and that gave an > > altimeter > > error of about 600 feet high. We reset to airfield elevation and took off. > > At altitude we set the area qnh reported on Jandakot ATIS which was 20 mb > > higher than our altimeter was indicating. > > > > We've checked the static lines - no blockages or leaks that we can find. > > Any > > thoughts? > > > > Cheers > > > > Shirley > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 09, 2007
I don't know any instances of Fuel Lube being used but a few of the folks in the Minnesota Wing of Van Air Force say a product called TiteSeal is a fine alternative. -------- Bob Collins St. Paul, Minn. Letters from Flyover Country http://rvnewsletter.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=138999#138999 ________________________________________________________________________________
Date: Oct 09, 2007
Doug, That one has to go to the shop. I can say though, airspeed indicator errors are generally in the Pitot/Static system. The main trouble spot seems to be the Static Port position and height above the surrounding surface. There are some very elegant solutions available for static ports, but in my opinion they are just a fancy way to terminate the static tubing at skin level. A cheap pop rivet with enough length to install the tubing on and a washer placed between it and the head of the gun when it is installed has worked for me many times. The washer is to make the rivet head flat and without the slight oval shape they normally have. John D. ----- Original Message ----- From: "Doug Gray" <dgra1233(at)bigpond.net.au> Sent: Tuesday, October 09, 2007 2:52 PM Subject: Re: RV-List: Altimeter error - ASI question > > John, > > Very interesting procedure for adjusting the Altimeter. I'm looking > forward to the outcome from Shirley. > > Do you have a procedure for adjusting an airspeed indicator? > > I have a very nice second hand ASI (Unknown German brand, model is > FM-440/4) but has an error at zero diff. pressure of ~25 kts. I have > not tested the range yet so I don't know if this is across the scale. > > Can this be adjusted or do I have a dud? > > TIA > Doug Gray ________________________________________________________________________________
Date: Oct 09, 2007
Right. Saw that. Followed it. But the question wasn't about the procedure, it was about the speed at which a drill bit should turn in plexi. -------- Bob Collins St. Paul, Minn. Letters from Flyover Country http://rvnewsletter.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=139008#139008 ________________________________________________________________________________
Date: Oct 09, 2007
Subject: VHB Tape vs Rivets
I have recently seen an episode of "Modern Marvels" on the history channel called "Sticky Stuff". One of the things they had on that show, is this tape called VHB tape made by 3M. In a test they repeatedly impacted a 16 lb bowling ball against 2 sheets of aluminum bonded with VHB tape till it failed, then they did the same test with the 2 sheets of aluminum riveted together. Since this was 3M doing the test, obviously there tape performed better. However based on the fact that bowling balls are between 8.5 and 8.6" in diameter, it appears as they only had a rivet every 4 inches. I would be really curious to see how the tape compared to doing it with the appropriate number of rivets. Anyone want to try the test? Below is a link to a youtube video of the demonstration. http://youtube.com/watch?v=ZhKreIqU_R4 -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" ________________________________________________________________________________
Date: Oct 09, 2007
Subject: Pro Seal
Hi Jim, I am of the same opinion as you. I have put EZ fuel lube on my cork gaskets (both sides) and installed them. I used moderate pressure on the screws so they should not leak. I need to get some av gas and run some test strips to see how it is affected. It seems at this point to reject the fuel quite nicely. So--- I am running with it that way. Worst case, I'll have to replace the gaskets and do it bare . I can not think about pro seal on the fittings. I did get some silicone O-Ringed screws from McMaster Carr so the fuel would not come back up the threads and leak that way. For the standard float level Stewart Warner senders, I added a ground wire to the sender to be sure they would work. I think I have it on my web site at www.websites.expercraft.com/jimn so take a peak. Jim N15JN (almost ready for paint) ________________________________________________________________________________
Date: Oct 09, 2007
I'd say if you didn't crack anything, you are good to go brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Collins Sent: Tuesday, October 09, 2007 3:03 PM Subject: RV-List: Re: cutting canopy dale1rv6(at)comcast.net wrote: > Use moderate drill speed (not slow) and low pressure. Test your dull bit on scrap first. > Dale > Too late for me now but I'm curious if I've introduced a problem into my canopy project unwittingly. I turned my drill VERY slowly when drilling the canopy, exerting very little pressure. My goal was to scrape...not cut... when I drilled. What have I done by drilling too slowly? -------- Bob Collins St. Paul, Minn. Letters from Flyover Country http://rvnewsletter.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=138991#138991 4:54 PM 4:54 PM ________________________________________________________________________________
Subject: Re: Pro Seal
Date: Oct 09, 2007
Jim, My A&P told me that he has uses EZ Turn to seal fuel tank senders on various aircraft over many years and that it has worked good. I'm hoping he is right because it sure is easier to work with. I used proseal on all the other parts on the fuel tank sender and fuel line but I used the EZ Turn on the screws and gasket. Thanks for your reply, it's great to know someone else is trying this product. I need to add fuel and then test it over the years for the final outcome. More to come later! Jim ----- Original Message ----- From: "James H Nelson" <rv9jim(at)juno.com> Sent: Tuesday, October 09, 2007 3:53 PM Subject: RV-List: Pro Seal > > Hi Jim, > I am of the same opinion as you. I have put EZ fuel lube on my > cork gaskets (both sides) and installed them. I used moderate pressure > on the screws so they should not leak. I need to get some av gas and run > some test strips to see how it is affected. It seems at this point to > reject the fuel quite nicely. So--- I am running with it that way. > Worst case, I'll have to replace the gaskets and do it bare . I can not > think about pro seal on the fittings. I did get some silicone O-Ringed > screws from McMaster Carr so the fuel would not come back up the threads > and leak that way. For the standard float level Stewart Warner senders, > I added a ground wire to the sender to be sure they would work. I think > I have it on my web site at www.websites.expercraft.com/jimn so take a > peak. > > Jim > N15JN > (almost ready for paint) > > > -- > 8:44 AM > > ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Re: Sealing fuel tank inspection plate & sender
Date: Oct 09, 2007
Just another data point... When I performed the work for the service bulletin, I had a nightmare of a time with the Stainless Steel fasteners I planned to use as replacements for the Phillips screws. I stripped out several of the heads (Allen Wrench type) before I went back to the Phillips screws. KB ----- Original Message ----- From: "Dale Ensing" <densing(at)carolina.rr.com> Sent: Tuesday, October 09, 2007 2:49 PM Subject: RV-List: Sealing fuel tank inspection plate & sender > > You might consider using SS Allen head cap screws on the inspection plates > and the sender mounts in lieu of the Phillips head screws. In my opinion; > 1. They make it easier to more evenly torque the screws. 2. The bottom of > the head of the cap screws have a slight undercut which makes a sealing > edge out at the periphery of the screw head. 3. And, if you need to remove > or re-torque the screws with the wing on, it is much easier to do with a > short Allen wrench segment in one of the very small right angle ratchet > screwdrivers handles. > > I had done my 6A tanks with the cap screws and when Van's came out with > the SB, getting the screws out and reinstalling them was very simple. > Dale Ensing > > >> Part of your decision may have to do with what happens if you have to >> remove the sender. It's a lot easier just unscrewing and pulling it off >> if all you've used is cork. When meetingthe Van's SB, I pulled both >> access plates off -- one with cork and proseal and one with just >> proseal -- and found both were quite an exercise. >> >> >> // Rubber gaskets - just in case they don't work and I have to remove the >> sender, I intend to use the provided rubber gaskets without sealer, but >> put plenty of sealer on the screws before assembly. Good idea? >> >> I did not use the rubber gasket because I found it quite difficult with >> the screws on the call-out to get the sender attached. To me, it seemed >> the rubber gasket was too think. I just ProSealed. > > > ________________________________________________________________________________
Date: Oct 09, 2007
Check the RV-list archives before you go with the fuel lube and gasket approach. I think you'll find a spotty success rate. History shows that using Proseal with no gasket gives you the best odds of a leak free tank. I'd go that route simply because it is a hassle to work in the wing root are once the wings are installed, and you'll be happier avoiding that chore down the road. KB ----- Original Message ----- From: "James H Nelson" <rv9jim(at)juno.com> Sent: Tuesday, October 09, 2007 4:53 PM Subject: RV-List: Pro Seal > > Hi Jim, > I am of the same opinion as you. I have put EZ fuel lube on my > cork gaskets (both sides) and installed them. I used moderate pressure > on the screws so they should not leak. I need to get some av gas and run > some test strips to see how it is affected. It seems at this point to > reject the fuel quite nicely. So--- I am running with it that way. > Worst case, I'll have to replace the gaskets and do it bare . I can not > think about pro seal on the fittings. I did get some silicone O-Ringed > screws from McMaster Carr so the fuel would not come back up the threads > and leak that way. For the standard float level Stewart Warner senders, > I added a ground wire to the sender to be sure they would work. I think > I have it on my web site at www.websites.expercraft.com/jimn so take a > peak. > > Jim > N15JN > (almost ready for paint) > > > ________________________________________________________________________________
Date: Oct 09, 2007
Silicone is not recommended for use with hydrocarbons (avgas or mogas) as it swells and gets very soft. Viton, fluorosilicone, Kalrez are all excellent when exposed to fuel. Buna-N is good and especially where it is not immersed in gasoline is an acceptable inexpensive choice. Dick Tasker. James H Nelson wrote: > > Hi Jim, > I am of the same opinion as you. I have put EZ fuel lube on my > cork gaskets (both sides) and installed them. I used moderate pressure > on the screws so they should not leak. I need to get some av gas and run > some test strips to see how it is affected. It seems at this point to > reject the fuel quite nicely. So--- I am running with it that way. > Worst case, I'll have to replace the gaskets and do it bare . I can not > think about pro seal on the fittings. I did get some silicone O-Ringed > screws from McMaster Carr so the fuel would not come back up the threads > and leak that way. For the standard float level Stewart Warner senders, > I added a ground wire to the sender to be sure they would work. I think > I have it on my web site at www.websites.expercraft.com/jimn so take a > peak. > > Jim > N15JN > (almost ready for paint) > > > ________________________________________________________________________________
Date: Oct 09, 2007
Hi guys: On 2 of my RV=B9s and several other local ones, we have simply used Aviation Form A Gasket (available at any NAPA store) and the cork gaskets to seal th e tank covers. This was worked flawlessly with no leaks fore many years. Give it a try!! Doug Weiler N722DW, 400+ hours On 10/9/07 9:23 AM, "Valovich, Paul" wrote: > I posted this over the weekend on the VAF site, but got no response. > > -8A QB N192NM so I haven't had the fun assembling the tanks. However, it is > time to install the float-type fuel senders. > > I've got a tube of "stuff" from Vans that's supposed to work - if I can r eally > figure out the mixing instructions. Some really basic questions: > > 1. Urban legend sez to toss the cork gaskets. Is that correct? > 2. Bead size - what's appropriate? While subscribing to the "More is bett er" > idea, what happens if the excess oozes from the cover plate into the tank and > possibly breaks loose sometime in the future? > 3. Rubber gaskets - just in case the damn thing doesn't work and I have t o > remove the sender, I intend to use the provided rubber gaskets without se aler, > but put plenty of sealer on the screws before assembly. Good idea? > 4. Shelf life - or more accurately - "After mixing useful life". How long do I > have after mixing for useful application capability? > Paul Valovich > N192NM Reserved (Again) > > > > > ________________________________________________________________________________
Date: Oct 09, 2007
Kyle Was wondering.....did the socket heads of the Allen head cap screws strip out because of the initial torque when first installed? Or, where there other factors? It is easy to over torque them because of the hex socket vs. the Phillips. Dale > > Just another data point... > > When I performed the work for the service bulletin, I had a nightmare of a > time with the Stainless Steel fasteners I planned to use as replacements > for the Phillips screws. I stripped out several of the heads (Allen > Wrench type) before I went back to the Phillips screws. > > KB >> >> You might consider using SS Allen head cap screws on the inspection >> plates and the sender mounts in lieu of the Phillips head screws. In my >> opinion; 1. They make it easier to more evenly torque the screws. 2. The >> bottom of the head of the cap screws have a slight undercut which makes a >> sealing edge out at the periphery of the screw head. 3. And, if you need >> to remove or re-torque the screws with the wing on, it is much easier to >> do with a short Allen wrench segment in one of the very small right angle >> ratchet screwdrivers handles. >> >> I had done my 6A tanks with the cap screws and when Van's came out with >> the SB, getting the screws out and reinstalling them was very simple. >> Dale Ensing ________________________________________________________________________________
Date: Oct 09, 2007
It has been a couple of years since my bad experience, but my recollection is that the heads stripped simply because of the torque required to run the screws down into the platenuts. They were not even snug when they stripped. I was very surprised that they stripped out in platenuts that had already been run-in. KB ----- Original Message ----- From: "Dale Ensing" <densing(at)carolina.rr.com> Sent: Tuesday, October 09, 2007 9:21 PM Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > Kyle > Was wondering.....did the socket heads of the Allen head cap screws strip > out because of the initial torque when first installed? Or, where there > other factors? It is easy to over torque them because of the hex socket > vs. the Phillips. > Dale > >> >> Just another data point... >> >> When I performed the work for the service bulletin, I had a nightmare of >> a time with the Stainless Steel fasteners I planned to use as >> replacements for the Phillips screws. I stripped out several of the >> heads (Allen Wrench type) before I went back to the Phillips screws. >> >> KB > >>> >>> You might consider using SS Allen head cap screws on the inspection >>> plates and the sender mounts in lieu of the Phillips head screws. In my >>> opinion; 1. They make it easier to more evenly torque the screws. 2. The >>> bottom of the head of the cap screws have a slight undercut which makes >>> a sealing edge out at the periphery of the screw head. 3. And, if you >>> need to remove or re-torque the screws with the wing on, it is much >>> easier to do with a short Allen wrench segment in one of the very small >>> right angle ratchet screwdrivers handles. >>> >>> I had done my 6A tanks with the cap screws and when Van's came out with >>> the SB, getting the screws out and reinstalling them was very simple. >>> Dale Ensing > > > ________________________________________________________________________________
Date: Oct 09, 2007
Subject: Property Tax Appeal
Listers: I'm in the process of appealing the property tax valuation on my RV-9A. I spent approximately 60k and it's being valued at 108k by San Bernardino Co., CA. So I'm looking for 3 or 4 people who have sold or bought an RV-9A who would be willing to share their hard data with me such as name, phone#, selling price, etc. All information would be kept confidential shared only with the County. For comparison my RV is VFR, O-320, fixed pitch prop, Dynon, 1 radio, handheld GPS, and Digitrak. Please reply off list to: jpaynter(at)cyberg8t.com Thanks in advance, Jim Paynter RV-9A, KCCB ________________________________________________________________________________
Subject: Epoxy not hardening
Date: Oct 09, 2007
Hey guys, I'm having a problem with the epoxy (aeropoxy) I used for coating the cowl surface. I thinned with acetone per Van's directions, but after 4 days now (or so) it's still tacky. It feels smooth if you run your finger over it, but if you just touch it - it's sticky. Batch was purchased 10 mo ago (no date on container) Stored in 60F+ Parts are curing in a humidity controlled environment, 70-75F Epoxy worked ok 3 months ago Mixed by weight on postal scale That said, I think I figured it out... but check me. A few of my colleagues mentioned that my hardener might be the problem and that it needs stirring. I opened the can and it had crystallized slightly. I suppose if I read the side of the can in CAPS where it says "MAY CRYSTALLIZE IN STORAGE" that I would have checked earlier. My questions are: 1. Since I mixed a few batches without homogeneous hardener, would the mixed remainder be of the wrong constituents and should I just throw it out? I'm not planning on using this stuff for anything flight critical or structural. Perhaps I need to heat the hardener to re-mix it correctly? 2. How can I remove the sticky crap off the cowling so I can start over, or is there something I can do to cure it? Sanding just gums up the sandpaper and acetone just made it stickier. I tried a small corner of MEK, but wonder if I'll hurt the prepreg substrate. Any suggestions? All comments will be appreciated. -Andy ________________________________________________________________________________
Date: Oct 09, 2007
Listers: I'm getting old and forget things. Please forgive me! On my previuos post I forgot to add that the data I need should be for an RV-9A bought or sold between the months of Oct., 2005 and Mar., 2006. Thanks again, Jim Paynter ________________________________________________________________________________
Date: Oct 10, 2007
Subject: Re: Epoxy not hardening
Order a new cowl? DOH! Just kidding. What about that deadly stuff called MEK??? Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Andrew Olech wrote: > > >Hey guys, > >I'm having a problem with the epoxy (aeropoxy) I used for coating the cowl >surface. I thinned with acetone per Van's directions, but after 4 days now >(or so) it's still tacky. It feels smooth if you run your finger over it, >but if you just touch it - it's sticky. > >Batch was purchased 10 mo ago (no date on container) >Stored in 60F+ >Parts are curing in a humidity controlled environment, 70-75F >Epoxy worked ok 3 months ago >Mixed by weight on postal scale > >That said, I think I figured it out... but check me. A few of my colleagues >mentioned that my hardener might be the problem and that it needs stirring. >I opened the can and it had crystallized slightly. I suppose if I read the >side of the can in CAPS where it says "MAY CRYSTALLIZE IN STORAGE" that I >would have checked earlier. My questions are: > >1. Since I mixed a few batches without homogeneous hardener, would the >mixed remainder be of the wrong constituents and should I just throw it out? >I'm not planning on using this stuff for anything flight critical or >structural. Perhaps I need to heat the hardener to re-mix it correctly? > >2. How can I remove the sticky crap off the cowling so I can start over, or >is there something I can do to cure it? Sanding just gums up the sandpaper >and acetone just made it stickier. I tried a small corner of MEK, but >wonder if I'll hurt the prepreg substrate. > >Any suggestions? All comments will be appreciated. > >-Andy > > > > ________________________________________________________________________________
Date: Oct 09, 2007
I would think that the receipts of what you paid for your kit would do the trick. The value is the sum of the cost. Unless the state of CA thinks they can tax you on the value of your labor. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Paynter Sent: Tuesday, October 09, 2007 10:40 PM Subject: RV-List: Property Tax Appeal Listers: I'm in the process of appealing the property tax valuation on my RV-9A. I spent approximately 60k and it's being valued at 108k by San Bernardino Co., CA. So I'm looking for 3 or 4 people who have sold or bought an RV-9A who would be willing to share their hard data with me such as name, phone#, selling price, etc. All information would be kept confidential shared only with the County. For comparison my RV is VFR, O-320, fixed pitch prop, Dynon, 1 radio, handheld GPS, and Digitrak. Please reply off list to: jpaynter(at)cyberg8t.com Thanks in advance, Jim Paynter RV-9A, KCCB ________________________________________________________________________________
Date: Oct 09, 2007
When ever you have a problem like this I beleive you should always call the manufacturer, they know better than anybody as to what is going on. I had the same problem on the cowl and after calling the manufacturer they told me that it is normal to get a film on the surface of the epoxy......I dont remember the reasoning (its been 5 years) to get it off I just sanded, yes it plugged the sand paper but I had a bunch so...... Scott Bilinski RV-8a ----- Original Message ---- From: Andrew Olech <olechap(at)comcast.net> Sent: Tuesday, October 9, 2007 7:29:28 PM Subject: RV-List: Epoxy not hardening Hey guys, I'm having a problem with the epoxy (aeropoxy) I used for coating the cowl surface. I thinned with acetone per Van's directions, but after 4 days now (or so) it's still tacky. It feels smooth if you run your finger over it, but if you just touch it - it's sticky. Batch was purchased 10 mo ago (no date on container) Stored in 60F+ Parts are curing in a humidity controlled environment, 70-75F Epoxy worked ok 3 months ago Mixed by weight on postal scale That said, I think I figured it out... but check me. A few of my colleagues mentioned that my hardener might be the problem and that it needs stirring. I opened the can and it had crystallized slightly. I suppose if I read the side of the can in CAPS where it says "MAY CRYSTALLIZE IN STORAGE" that I would have checked earlier. My questions are: 1. Since I mixed a few batches without homogeneous hardener, would the mixed remainder be of the wrong constituents and should I just throw it out? I'm not planning on using this stuff for anything flight critical or structural. Perhaps I need to heat the hardener to re-mix it correctly? 2. How can I remove the sticky crap off the cowling so I can start over, or is there something I can do to cure it? Sanding just gums up the sandpaper and acetone just made it stickier. I tried a small corner of MEK, but wonder if I'll hurt the prepreg substrate. Any suggestions? All comments will be appreciated. -Andy Pinpoint customers who are looking for what you sell. http://searchmarketing.yahoo.com/ ________________________________________________________________________________
Date: Oct 09, 2007
I beleive socket head cap screws are recommended here.......if memory serves, much harder to strip than phillips. Scott Bilinski RV-8a ----- Original Message ---- From: Kyle Boatright <kboatright1(at)comcast.net> Sent: Tuesday, October 9, 2007 6:42:04 PM Subject: Re: RV-List: Sealing fuel tank inspection plate & sender It has been a couple of years since my bad experience, but my recollection is that the heads stripped simply because of the torque required to run the screws down into the platenuts. They were not even snug when they stripped. I was very surprised that they stripped out in platenuts that had already been run-in. KB ----- Original Message ----- From: "Dale Ensing" <densing(at)carolina.rr.com> Sent: Tuesday, October 09, 2007 9:21 PM Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > Kyle > Was wondering.....did the socket heads of the Allen head cap screws strip > out because of the initial torque when first installed? Or, where there > other factors? It is easy to over torque them because of the hex socket > vs. the Phillips. > Dale > >> >> Just another data point... >> >> When I performed the work for the service bulletin, I had a nightmare of >> a time with the Stainless Steel fasteners I planned to use as >> replacements for the Phillips screws. I stripped out several of the >> heads (Allen Wrench type) before I went back to the Phillips screws. >> >> KB > >>> >>> You might consider using SS Allen head cap screws on the inspection >>> plates and the sender mounts in lieu of the Phillips head screws. In my >>> opinion; 1. They make it easier to more evenly torque the screws. 2. The >>> bottom of the head of the cap screws have a slight undercut which makes >>> a sealing edge out at the periphery of the screw head. 3. And, if you >>> need to remove or re-torque the screws with the wing on, it is much >>> easier to do with a short Allen wrench segment in one of the very small >>> right angle ratchet screwdrivers handles. >>> >>> I had done my 6A tanks with the cap screws and when Van's came out with >>> the SB, getting the screws out and reinstalling them was very simple. >>> Dale Ensing > > > Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more. http://mobile.yahoo.com/go?refer=1GNXIC ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Date: Oct 09, 2007
Andy, Try www.fibreglast.com for help. They a resin company only and have a whole on-line help section. I'm getting ready to do my epoxy work and have dealt with Fibreglast before when I was mold making. Great source for products and advice. Sounds like I should have posted it earlier. Mike H 9A/8A ----- Original Message ----- From: "Andrew Olech" <olechap(at)comcast.net> Sent: Tuesday, October 09, 2007 10:29 PM Subject: RV-List: Epoxy not hardening > > > Hey guys, > > I'm having a problem with the epoxy (aeropoxy) I used for coating the cowl > surface. I thinned with acetone per Van's directions, but after 4 days > now > (or so) it's still tacky. It feels smooth if you run your finger over it, > but if you just touch it - it's sticky. > > Batch was purchased 10 mo ago (no date on container) > Stored in 60F+ > Parts are curing in a humidity controlled environment, 70-75F > Epoxy worked ok 3 months ago > Mixed by weight on postal scale > > That said, I think I figured it out... but check me. A few of my > colleagues > mentioned that my hardener might be the problem and that it needs > stirring. > I opened the can and it had crystallized slightly. I suppose if I read > the > side of the can in CAPS where it says "MAY CRYSTALLIZE IN STORAGE" that I > would have checked earlier. My questions are: > > 1. Since I mixed a few batches without homogeneous hardener, would the > mixed remainder be of the wrong constituents and should I just throw it > out? > I'm not planning on using this stuff for anything flight critical or > structural. Perhaps I need to heat the hardener to re-mix it correctly? > > 2. How can I remove the sticky crap off the cowling so I can start over, > or > is there something I can do to cure it? Sanding just gums up the > sandpaper > and acetone just made it stickier. I tried a small corner of MEK, but > wonder if I'll hurt the prepreg substrate. > > Any suggestions? All comments will be appreciated. > > -Andy > > > ________________________________________________________________________________
Date: Oct 09, 2007
One other thing, if the state is trying to tax your labor, tell them that because of product liability issues, you will never sell it but scrap it instead. Therefore, it's resale value is zero and you owe nothing. It's been done, witness airplanes being donated to museums, turned into windsocks, or cut up into pieces. All to avoid product liability. So, argue that because it's an experimental aircraft its value is zero. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bruce Gray Sent: Tuesday, October 09, 2007 11:21 PM Subject: RE: RV-List: Property Tax Appeal I would think that the receipts of what you paid for your kit would do the trick. The value is the sum of the cost. Unless the state of CA thinks they can tax you on the value of your labor. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Paynter Sent: Tuesday, October 09, 2007 10:40 PM Subject: RV-List: Property Tax Appeal Listers: I'm in the process of appealing the property tax valuation on my RV-9A. I spent approximately 60k and it's being valued at 108k by San Bernardino Co., CA. So I'm looking for 3 or 4 people who have sold or bought an RV-9A who would be willing to share their hard data with me such as name, phone#, selling price, etc. All information would be kept confidential shared only with the County. For comparison my RV is VFR, O-320, fixed pitch prop, Dynon, 1 radio, handheld GPS, and Digitrak. Please reply off list to: jpaynter(at)cyberg8t.com Thanks in advance, Jim Paynter RV-9A, KCCB ________________________________________________________________________________
Date: Oct 09, 2007
Set it out in the sun to warm up and cure. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Sent: Tuesday, October 09, 2007 11:22 PM Subject: Re: RV-List: Epoxy not hardening Order a new cowl? DOH! Just kidding. What about that deadly stuff called MEK??? Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Andrew Olech wrote: > > >Hey guys, > >I'm having a problem with the epoxy (aeropoxy) I used for coating the cowl >surface. I thinned with acetone per Van's directions, but after 4 days now >(or so) it's still tacky. It feels smooth if you run your finger over it, >but if you just touch it - it's sticky. > >Batch was purchased 10 mo ago (no date on container) >Stored in 60F+ >Parts are curing in a humidity controlled environment, 70-75F >Epoxy worked ok 3 months ago >Mixed by weight on postal scale > >That said, I think I figured it out... but check me. A few of my colleagues >mentioned that my hardener might be the problem and that it needs stirring. >I opened the can and it had crystallized slightly. I suppose if I read the >side of the can in CAPS where it says "MAY CRYSTALLIZE IN STORAGE" that I >would have checked earlier. My questions are: > >1. Since I mixed a few batches without homogeneous hardener, would the >mixed remainder be of the wrong constituents and should I just throw it out? >I'm not planning on using this stuff for anything flight critical or >structural. Perhaps I need to heat the hardener to re-mix it correctly? > >2. How can I remove the sticky crap off the cowling so I can start over, or >is there something I can do to cure it? Sanding just gums up the sandpaper >and acetone just made it stickier. I tried a small corner of MEK, but >wonder if I'll hurt the prepreg substrate. > >Any suggestions? All comments will be appreciated. > >-Andy > > > > ________________________________________________________________________________
Date: Oct 09, 2007
I had the same stripped-screw issue and it really sucked. Plus, with the wings on you can't get any tools in there. I was getting leaks around the screw heads. I ended up putting some Marine epoxy(label said can be used to seal fuel tanks) around each of the leaky screws and it fixed the problem. It has only been a couple months so I can't guarantee how long it will last. -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net > > > It has been a couple of years since my bad experience, but my recollection > is that the heads stripped simply because of the torque required to run > the > screws down into the platenuts. They were not even snug when they > stripped. > > I was very surprised that they stripped out in platenuts that had already > been run-in. > > KB > > ----- Original Message ----- > From: "Dale Ensing" <densing(at)carolina.rr.com> > To: > Sent: Tuesday, October 09, 2007 9:21 PM > Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > > > > > Kyle > > Was wondering.....did the socket heads of the Allen head cap screws > strip > > out because of the initial torque when first installed? Or, where there > > other factors? It is easy to over torque them because of the hex socket > > vs. the Phillips. > > Dale > > > kboatright1(at)comcast.net> > >> > >> Just another data point... > >> > >> When I performed the work for the service bulletin, I had a nightmare > of > >> a time with the Stainless Steel fasteners I planned to use as > >> replacements for the Phillips screws. I stripped out several of the > >> heads (Allen Wrench type) before I went back to the Phillips screws. > >> > >> KB > > > >>> > >>> You might consider using SS Allen head cap screws on the inspection > >>> plates and the sender mounts in lieu of the Phillips head screws. In > my > >>> opinion; 1. They make it easier to more evenly torque the screws. 2. > The > >>> bottom of the head of the cap screws have a slight undercut which > makes > >>> a sealing edge out at the periphery of the screw head. 3. And, if you > >>> need to remove or re-torque the screws with the wing on, it is much > >>> easier to do with a short Allen wrench segment in one of the very > small > >>> right angle ratchet screwdrivers handles. > >>> > >>> I had done my 6A tanks with the cap screws and when Van's came out > with > >>> the SB, getting the screws out and reinstalling them was very simple. > >>> Dale Ensing > > > > > > > > > > > > > > > Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, > news, photos & more. > http://mobile.yahoo.com/go?refer=1GNXIC > > ________________________________________________________________________________
Date: Oct 09, 2007
Dale and others, I bought some SS 8X32 round or button head screws that had the annoying habit of stripping out during installation. The Allen wrench key socket size was 'about' 3/32" ..(Its been a while) ;-) Later I bought a box of SS 8X32 "Allen head' screws. These required an Allen head socket wrench size of 'about' 3/16" and are plenty strong enough to be used in places such as the fuel tanks etc. I have yet to strip out one of these Allen head screws even when being deliberately abusive during a test to see what they could take. They have been holding back fuel for a year so far and they offer far better access in tight quarters than their Philips head type cousins. Jim in Kelowna ----- Original Message ----- From: "Dale Ensing" <densing(at)carolina.rr.com> Sent: Tuesday, October 09, 2007 6:21 PM Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > Kyle > Was wondering.....did the socket heads of the Allen head cap screws strip > out because of the initial torque when first installed? Or, where there > other factors? It is easy to over torque them because of the hex socket > vs. the Phillips. > Dale > >> >> Just another data point... >> >> When I performed the work for the service bulletin, I had a nightmare of >> a time with the Stainless Steel fasteners I planned to use as >> replacements for the Phillips screws. I stripped out several of the >> heads (Allen Wrench type) before I went back to the Phillips screws. >> >> KB > >>> >>> You might consider using SS Allen head cap screws on the inspection >>> plates and the sender mounts in lieu of the Phillips head screws. In my >>> opinion; 1. They make it easier to more evenly torque the screws. 2. The >>> bottom of the head of the cap screws have a slight undercut which makes >>> a sealing edge out at the periphery of the screw head. 3. And, if you >>> need to remove or re-torque the screws with the wing on, it is much >>> easier to do with a short Allen wrench segment in one of the very small >>> right angle ratchet screwdrivers handles. >>> >>> I had done my 6A tanks with the cap screws and when Van's came out with >>> the SB, getting the screws out and reinstalling them was very simple. >>> Dale Ensing > > > ________________________________________________________________________________
Date: Oct 10, 2007
Dale, Try SS Torx screws, www.microfasteners.com they take a #20 6 point torx bit, at any hardware store. Same driver as premium deck screws. You cannot strip them. Mike H ----- Original Message ----- From: "Jim Jewell" <jjewell(at)telus.net> Sent: Wednesday, October 10, 2007 2:03 AM Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > Dale and others, > > I bought some SS 8X32 round or button head screws that had the annoying > habit of stripping out during installation. > The Allen wrench key socket size was 'about' 3/32" ..(Its been a while) > ;-) > > Later I bought a box of SS 8X32 "Allen head' screws. These required an > Allen head socket wrench size of 'about' 3/16" and are plenty strong > enough to be used in places such as the fuel tanks etc. > I have yet to strip out one of these Allen head screws even when being > deliberately abusive during a test to see what they could take. > They have been holding back fuel for a year so far and they offer far > better access in tight quarters than their Philips head type cousins. > > Jim in Kelowna > > ----- Original Message ----- > From: "Dale Ensing" <densing(at)carolina.rr.com> > To: > Sent: Tuesday, October 09, 2007 6:21 PM > Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > >> >> Kyle >> Was wondering.....did the socket heads of the Allen head cap screws strip >> out because of the initial torque when first installed? Or, where there >> other factors? It is easy to over torque them because of the hex socket >> vs. the Phillips. >> Dale >> >>> >>> >>> Just another data point... >>> >>> When I performed the work for the service bulletin, I had a nightmare of >>> a time with the Stainless Steel fasteners I planned to use as >>> replacements for the Phillips screws. I stripped out several of the >>> heads (Allen Wrench type) before I went back to the Phillips screws. >>> >>> KB >> >>>> >>>> You might consider using SS Allen head cap screws on the inspection >>>> plates and the sender mounts in lieu of the Phillips head screws. In my >>>> opinion; 1. They make it easier to more evenly torque the screws. 2. >>>> The bottom of the head of the cap screws have a slight undercut which >>>> makes a sealing edge out at the periphery of the screw head. 3. And, if >>>> you need to remove or re-torque the screws with the wing on, it is >>>> much easier to do with a short Allen wrench segment in one of the very >>>> small right angle ratchet screwdrivers handles. >>>> >>>> I had done my 6A tanks with the cap screws and when Van's came out with >>>> the SB, getting the screws out and reinstalling them was very simple. >>>> Dale Ensing >> >> >> >> >> > > > ________________________________________________________________________________
Subject: ASI question
Date: Oct 10, 2007
If the asi is off by the same arc segment over the entire range, the pointer shaft gear may have jumped a few cogs. You could try removing the pointer and replacing it in the correct position and then check the calibration. The pointer should pop off if you put a piece of cloth/cardboard at each
September 18, 2007 - October 10, 2007
RV-Archive.digest.vol-sz
