RV-Archive.digest.vol-ta
October 10, 2007 - October 29, 2007
      side to protect the dial and use two (padded if possible) screwdrivers, one
      on each side to lever it up without putting any side load on the shaft.
      Press it back in the correct position (repeat as necessary! - I have just
      replaced a dial and pointer for an 'authentic' Cub asi so guess why I say
      that!).
       J.Kent RV-4 EI-DIY.
Date: Oct 10, 2007
Subject: Re: Epoxy not hardening
It's called blush. Easily removed with water and a scotchbrite pad. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com On 10/9/07, scott bilinski wrote: > > > When ever you have a problem like this I beleive you should always call > the manufacturer, they know better than anybody as to what is going on. I > had the same problem on the cowl and after calling the manufacturer they > told me that it is normal to get a film on the surface of the epoxy......I > dont remember the reasoning (its been 5 years) to get it off I just sanded, > yes it plugged the sand paper but I had a bunch so...... > > > Scott Bilinski > RV-8a > > > ----- Original Message ---- > From: Andrew Olech <olechap(at)comcast.net> > To: rv-list(at)matronics.com > Sent: Tuesday, October 9, 2007 7:29:28 PM > Subject: RV-List: Epoxy not hardening > > > Hey guys, > > I'm having a problem with the epoxy (aeropoxy) I used for coating the cowl > surface. I thinned with acetone per Van's directions, but after 4 days > now > (or so) it's still tacky. It feels smooth if you run your finger over it, > but if you just touch it - it's sticky. > > Batch was purchased 10 mo ago (no date on container) > Stored in 60F+ > Parts are curing in a humidity controlled environment, 70-75F > Epoxy worked ok 3 months ago > Mixed by weight on postal scale > > That said, I think I figured it out... but check me. A few of my > colleagues > mentioned that my hardener might be the problem and that it needs > stirring. > I opened the can and it had crystallized slightly. I suppose if I read > the > side of the can in CAPS where it says "MAY CRYSTALLIZE IN STORAGE" that I > would have checked earlier. My questions are: > > 1. Since I mixed a few batches without homogeneous hardener, would the > mixed remainder be of the wrong constituents and should I just throw it > out? > I'm not planning on using this stuff for anything flight critical or > structural. Perhaps I need to heat the hardener to re-mix it correctly? > > 2. How can I remove the sticky crap off the cowling so I can start over, > or > is there something I can do to cure it? Sanding just gums up the > sandpaper > and acetone just made it stickier. I tried a small corner of MEK, but > wonder if I'll hurt the prepreg substrate. > > Any suggestions? All comments will be appreciated. > > -Andy > > > Pinpoint customers who are looking for what you sell. > http://searchmarketing.yahoo.com/ > > ________________________________________________________________________________
Subject: higher gas burn
Date: Oct 10, 2007
I flew from Fayetteville ar to Columbus Oh and back fior the mustang thing, and calculated my gas burn, first since I put in the newer O-320. it was burning 9+ at 2400 and 10 at 2500. old engine burning a gal less. I lean aressivly, the old way I learned, no gauges. I put the orig carb on the new engine. so I am baffled as to why gs burn has increased. Both engines are 150hp. Any Ideas? Charlie Heathco ________________________________________________________________________________
Subject: Re: static port & altimeter error
Date: Oct 10, 2007
My static ports were so far off I have had ATC ask me to turn off the altitude reporting on my transponder. Investigation showed the convex 'dome' of the Vans pop rivet was causing a vacuum as the air passed over. I ground the rivet head flat (on a painted plane!) and the error went away. Use a GPS to see what your 'true' elevation is vs. the altimeter. If the altimeter reads high, consider this fix. Kelly Patterson RV-6A N716K PHX, AZ 185 hrs From: "John D. Heath" <altoq(at)cebridge.net> Subject: Re: RV-List: Altimeter error - ASI question Doug, That one has to go to the shop. I can say though, airspeed indicator errors are generally in the Pitot/Static system. The main trouble spot seems to be the Static Port position and height above the surrounding surface. There are some very elegant solutions available for static ports, but in my opinion they are just a fancy way to terminate the static tubing at skin level. A cheap pop rivet with enough length to install the tubing on and a washer placed between it and the head of the gun when it is installed has worked for me many times. The washer is to make the rivet head flat and without the slight oval shape they normally have. John D. ________________________________________________________________________________
Subject: Re: Sealing fuel tank inspection plate & sender
Date: Oct 10, 2007
Good point Jim. The round and button head screws have a much smaller hex socket relative to the screw size than do the Allen heads (which is what I was suggesting and used on my tanks). Dale > Dale and others, > > I bought some SS 8X32 round or button head screws that had the annoying > habit of stripping out during installation. > The Allen wrench key socket size was 'about' 3/32" ..(Its been a while) > ;-) > > Later I bought a box of SS 8X32 "Allen head' screws. These required an > Allen head socket wrench size of 'about' 3/16" and are plenty strong > enough to be used in places such as the fuel tanks etc. > I have yet to strip out one of these Allen head screws even when being > deliberately abusive during a test to see what they could take. > They have been holding back fuel for a year so far and they offer far > better access in tight quarters than their Philips head type cousins. > > Jim in Kelowna > > >> >> Kyle >> Was wondering.....did the socket heads of the Allen head cap screws strip >> out because of the initial torque when first installed? Or, where there >> other factors? It is easy to over torque them because of the hex socket >> vs. the Phillips. >> Dale >> >>> >>> >>> Just another data point... >>> >>> When I performed the work for the service bulletin, I had a nightmare of >>> a time with the Stainless Steel fasteners I planned to use as >>> replacements for the Phillips screws. I stripped out several of the >>> heads (Allen Wrench type) before I went back to the Phillips screws. >>> >>> KB >> >>>> >>>> You might consider using SS Allen head cap screws on the inspection >>>> plates and the sender mounts in lieu of the Phillips head screws. In my >>>> opinion; 1. They make it easier to more evenly torque the screws. 2. >>>> The bottom of the head of the cap screws have a slight undercut which >>>> makes a sealing edge out at the periphery of the screw head. 3. And, if >>>> you need to remove or re-torque the screws with the wing on, it is >>>> much easier to do with a short Allen wrench segment in one of the very >>>> small right angle ratchet screwdrivers handles. >>>> >>>> I had done my 6A tanks with the cap screws and when Van's came out with >>>> the SB, getting the screws out and reinstalling them was very simple. >>>> Dale Ensing ________________________________________________________________________________
Date: Oct 10, 2007
Subject: Re: higher gas burn
Just a WAG Charlie, but differences in the intake path (new Vs old) may change the 'lean point' so you're not able to lean as much on the new installation. Linn Charles Heathco wrote: > I flew from Fayetteville ar to Columbus Oh and back fior the mustang > thing, and calculated my gas burn, first since I put in the newer > O-320. it was burning 9+ at 2400 and 10 at 2500. old engine burning a > gal less. I lean aressivly, the old way I learned, no gauges. I put > the orig carb on the new engine. so I am baffled as to why gs burn has > increased. Both engines are 150hp. Any Ideas? Charlie Heathco > > ________________________________________________________________________________
Date: Oct 10, 2007
I have never had any problems stripping the sockets on Allen head cap screws. Matter of fact- I run a Allen head cap screw into new plate nuts to establish a "thread" before inserting Phillips head screws to reduce the wear on the Phillips head. Dale ----- Original Message ----- From: "mike humphrey" <mike109g6(at)insideconnect.net> Sent: Wednesday, October 10, 2007 2:30 AM Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > > Dale, > Try SS Torx screws, www.microfasteners.com they take a #20 6 point torx > bit, at any hardware store. Same driver as premium deck screws. You > cannot strip them. > Mike H > ----- Original Message ----- > From: "Jim Jewell" <jjewell(at)telus.net> > To: > Sent: Wednesday, October 10, 2007 2:03 AM > Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > >> >> Dale and others, >> >> I bought some SS 8X32 round or button head screws that had the annoying >> habit of stripping out during installation. >> The Allen wrench key socket size was 'about' 3/32" ..(Its been a while) >> ;-) >> >> Later I bought a box of SS 8X32 "Allen head' screws. These required an >> Allen head socket wrench size of 'about' 3/16" and are plenty strong >> enough to be used in places such as the fuel tanks etc. >> I have yet to strip out one of these Allen head screws even when being >> deliberately abusive during a test to see what they could take. >> They have been holding back fuel for a year so far and they offer far >> better access in tight quarters than their Philips head type cousins. >> >> Jim in Kelowna >> >> ----- Original Message ----- >> From: "Dale Ensing" <densing(at)carolina.rr.com> >> To: >> Sent: Tuesday, October 09, 2007 6:21 PM >> Subject: Re: RV-List: Sealing fuel tank inspection plate & sender >> >> >>> >>> Kyle >>> Was wondering.....did the socket heads of the Allen head cap screws >>> strip out because of the initial torque when first installed? Or, where >>> there other factors? It is easy to over torque them because of the hex >>> socket vs. the Phillips. >>> Dale >>> >>>> >>>> >>>> Just another data point... >>>> >>>> When I performed the work for the service bulletin, I had a nightmare >>>> of a time with the Stainless Steel fasteners I planned to use as >>>> replacements for the Phillips screws. I stripped out several of the >>>> heads (Allen Wrench type) before I went back to the Phillips screws. >>>> >>>> KB >>> >>>>> >>>>> You might consider using SS Allen head cap screws on the inspection >>>>> plates and the sender mounts in lieu of the Phillips head screws. In >>>>> my opinion; 1. They make it easier to more evenly torque the screws. >>>>> 2. The bottom of the head of the cap screws have a slight undercut >>>>> which makes a sealing edge out at the periphery of the screw head. 3. >>>>> And, if you need to remove or re-torque the screws with the wing on, >>>>> it is much easier to do with a short Allen wrench segment in one of >>>>> the very small right angle ratchet screwdrivers handles. >>>>> >>>>> I had done my 6A tanks with the cap screws and when Van's came out >>>>> with the SB, getting the screws out and reinstalling them was very >>>>> simple. >>>>> Dale Ensing >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 10, 2007
Subject: Property Tax Appeal
On 4:47 2007-10-10 Dana Overall wrote: > That's what I did. My airplane is a DO-7. Nothing for the tax > people to compare. > > Dana Overall > Richmond, KY i39 > RV-7 slider, Imron black, "Black Magic" If you're calling it an RV-7 in your signature, posting many, many messages with that same signature over the years to a public list, and discussing all of the things you did on "your -7", it's pretty clear that the plane is fundamentally an RV-7. If you're only calling it a DO-7 for the purposes of tax evasion, i'd think the tax man would have a pretty easy time of raking you over the coals for it. I know the probability is vanishingly low, but occasionally Tax people do check on these things... If they get it in their mind that you're trying to evade taxes, they'll look everywhere to prove it. -Rob ________________________________________________________________________________
Date: Oct 10, 2007
How many hours are on the new engine so far? ----- Original Message ----- From: Charles Heathco To: rv-list Sent: Wednesday, October 10, 2007 6:49 AM Subject: RV-List: higher gas burn I flew from Fayetteville ar to Columbus Oh and back fior the mustang thing, and calculated my gas burn, first since I put in the newer O-320. it was burning 9+ at 2400 and 10 at 2500. old engine burning a gal less. I lean aressivly, the old way I learned, no gauges. I put the orig carb on the new engine. so I am baffled as to why gs burn has increased. Both engines are 150hp. Any Ideas? Charlie Heathco ________________________________________________________________________________
Date: Oct 10, 2007
How would ATC know your static system is not accurate? All they see is the altitude reported from your transponder, which should be that which is sensed at the static ports. They have no way to compare it against anything else. GPS altitude is not the same thing as barometric altitude. There are many valid reasons why GPS altitude might differ by several hundred feet from barometric altitude, yet both could be correct (just as TAS may differ greatly from ground speed, yet both are correct, as they are measuring different things). GPS altitude is only the same as barometric altitude on the extremely rare day where the atmosphere perfectly matches a standard atmosphere. Kevin Horton "Kelly Patterson" wrote: > > My static ports were so far off I have had ATC ask me to turn off the > altitude reporting on my transponder. Investigation showed the convex > 'dome' of the Vans pop rivet was causing a vacuum as the air passed over. I > ground the rivet head flat (on a painted plane!) and the error went away. > > Use a GPS to see what your 'true' elevation is vs. the altimeter. If the > altimeter reads high, consider this fix. > > Kelly Patterson > RV-6A N716K > PHX, AZ 185 hrs > > > From: "John D. Heath" <altoq(at)cebridge.net> > Subject: Re: RV-List: Altimeter error - ASI question > > > Doug, > > That one has to go to the shop. I can say though, airspeed indicator errors > are generally in the Pitot/Static system. The main trouble spot seems to be > the Static Port position and height above the surrounding surface. There are > some very elegant solutions available for static ports, but in my opinion > they are just a fancy way to terminate the static tubing at skin level. A > cheap pop rivet with enough length to install the tubing on and a washer > placed between it and the head of the gun when it is installed has worked > for me many times. The washer is to make the rivet head flat and without the > slight oval shape they normally have. > > John D. > ________________________________________________________________________________
Date: Oct 10, 2007
Hi Dale, I to have often used the Allen head cap screws breaking in new plate nut threads. Way back when ordering tools etc. I bought a small container of Beolube from Avery tools. I have used this product on every screw in my 6-A. It conditions the plate-nut threads increasing their overall utility without unduly reducing the plate-nut's grip . I have used this product as suggested as a cutting agent when drilling holes with the drill press and the lathe. I have loaned out the small plastic tube of soft waxy soapstone like Beolube to others and still have about two thirds of the original container left. A must have product for me. Jim in Kelowna ----- Original Message ----- From: "Dale Ensing" <densing(at)carolina.rr.com> Sent: Wednesday, October 10, 2007 6:53 AM Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > I have never had any problems stripping the sockets on Allen head cap > screws. Matter of fact- I run a Allen head cap screw into new plate nuts > to establish a "thread" before inserting Phillips head screws to reduce > the wear on the Phillips head. > Dale > ----- Original Message ----- > From: "mike humphrey" <mike109g6(at)insideconnect.net> > To: > Sent: Wednesday, October 10, 2007 2:30 AM > Subject: Re: RV-List: Sealing fuel tank inspection plate & sender > > >> >> >> Dale, >> Try SS Torx screws, www.microfasteners.com they take a #20 6 point torx >> bit, at any hardware store. Same driver as premium deck screws. You >> cannot strip them. >> Mike H >> ----- Original Message ----- >> From: "Jim Jewell" <jjewell(at)telus.net> >> To: >> Sent: Wednesday, October 10, 2007 2:03 AM >> Subject: Re: RV-List: Sealing fuel tank inspection plate & sender >> >> >>> >>> Dale and others, >>> >>> I bought some SS 8X32 round or button head screws that had the annoying >>> habit of stripping out during installation. >>> The Allen wrench key socket size was 'about' 3/32" ..(Its been a while) >>> ;-) >>> >>> Later I bought a box of SS 8X32 "Allen head' screws. These required an >>> Allen head socket wrench size of 'about' 3/16" and are plenty strong >>> enough to be used in places such as the fuel tanks etc. >>> I have yet to strip out one of these Allen head screws even when being >>> deliberately abusive during a test to see what they could take. >>> They have been holding back fuel for a year so far and they offer far >>> better access in tight quarters than their Philips head type cousins. >>> >>> Jim in Kelowna >>> >>> ----- Original Message ----- >>> From: "Dale Ensing" <densing(at)carolina.rr.com> >>> To: >>> Sent: Tuesday, October 09, 2007 6:21 PM >>> Subject: Re: RV-List: Sealing fuel tank inspection plate & sender >>> >>> >>>> >>>> Kyle >>>> Was wondering.....did the socket heads of the Allen head cap screws >>>> strip out because of the initial torque when first installed? Or, where >>>> there other factors? It is easy to over torque them because of the hex >>>> socket vs. the Phillips. >>>> Dale >>>> >>>>> >>>>> >>>>> Just another data point... >>>>> >>>>> When I performed the work for the service bulletin, I had a nightmare >>>>> of a time with the Stainless Steel fasteners I planned to use as >>>>> replacements for the Phillips screws. I stripped out several of the >>>>> heads (Allen Wrench type) before I went back to the Phillips screws. >>>>> >>>>> KB >>>> >>>>>> >>>>>> >>>>>> You might consider using SS Allen head cap screws on the inspection >>>>>> plates and the sender mounts in lieu of the Phillips head screws. In >>>>>> my opinion; 1. They make it easier to more evenly torque the screws. >>>>>> 2. The bottom of the head of the cap screws have a slight undercut >>>>>> which makes a sealing edge out at the periphery of the screw head. 3. >>>>>> And, if you need to remove or re-torque the screws with the wing on, >>>>>> it is much easier to do with a short Allen wrench segment in one of >>>>>> the very small right angle ratchet screwdrivers handles. >>>>>> >>>>>> I had done my 6A tanks with the cap screws and when Van's came out >>>>>> with the SB, getting the screws out and reinstalling them was very >>>>>> simple. >>>>>> Dale Ensing >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 10, 2007
Wouldn't ATC know if they assigned an altitude such as 6,500 feet and the pilot of his RV flew at 6,500 feet according to his altimeter, but his encoder was reporting 6,000 or 7,000 feet? Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Kevin Horton wrote: > >How would ATC know your static system is not accurate? All they see is the altitude reported from your transponder, which should be that which is sensed at the static ports. They have no way to compare it against anything else. > >GPS altitude is not the same thing as barometric altitude. There are many valid reasons why GPS altitude might differ by several hundred feet from barometric altitude, yet both could be correct (just as TAS may differ greatly from ground speed, yet both are correct, as they are measuring different things). GPS altitude is only the same as barometric altitude on the extremely rare day where the atmosphere perfectly matches a standard atmosphere. > >Kevin Horton > >"Kelly Patterson" wrote: > > > >> >>My static ports were so far off I have had ATC ask me to turn off the >>altitude reporting on my transponder. Investigation showed the convex >>'dome' of the Vans pop rivet was causing a vacuum as the air passed over. I >>ground the rivet head flat (on a painted plane!) and the error went away. >> >>Use a GPS to see what your 'true' elevation is vs. the altimeter. If the >>altimeter reads high, consider this fix. >> >>Kelly Patterson >>RV-6A N716K >>PHX, AZ 185 hrs >> >> >>From: "John D. Heath" <altoq(at)cebridge.net> >>Subject: Re: RV-List: Altimeter error - ASI question >> >> >>Doug, >> >> That one has to go to the shop. I can say though, airspeed indicator errors >>are generally in the Pitot/Static system. The main trouble spot seems to be >>the Static Port position and height above the surrounding surface. There are >>some very elegant solutions available for static ports, but in my opinion >>they are just a fancy way to terminate the static tubing at skin level. A >>cheap pop rivet with enough length to install the tubing on and a washer >>placed between it and the head of the gun when it is installed has worked >>for me many times. The washer is to make the rivet head flat and without the >>slight oval shape they normally have. >> >>John D. >> >> >> > > > > ________________________________________________________________________________
Date: Oct 10, 2007
"Charles Heathco" wrote: > I flew from Fayetteville ar to Columbus Oh and back fior the mustang thing, and calculated my gas burn, first since I put in the newer O-320. it was burning 9+ at 2400 and 10 at 2500. old engine burning a gal less. I lean aressivly, the old way I learned, no gauges. I put the orig carb on the new engine. so I am baffled as to why gs burn has increased. Both engines are 150hp. Any Ideas? Charlie Heathco Is it possible that the new engine is making more power than the old one? Has your cruise speed changed at all? Do you have the same prop as before? Kevin Horton ________________________________________________________________________________
Date: Oct 10, 2007
But, if his altimeter was connected to the same static source as the encoder (as it should), a servicable altimeter should read the same as the encoder is reporting (ignoring the effect of altimeter setting, which is accounted for by ATC). It wouldn't matter if a bad static port gave a 1000 ft error - both the altimeter and the encoder would have the same error. If the altimeter and encoder are connected to the same source, and they say different things, then one of them is unserviceable, or there is a large static leak between the two. The problem cannot be the static source. Kevin Scott wrote: > > Wouldn't ATC know if they assigned an altitude such as 6,500 feet and > the pilot of his RV flew at 6,500 feet according to his altimeter, but > his encoder was reporting 6,000 or 7,000 feet? > > Scott > http://corbenflyer.tripod.com/ > Gotta Fly or Gonna Die > Building RV-4 (Super Slow Build Version) > > > > Kevin Horton wrote: > > > > >How would ATC know your static system is not accurate? All they see is the altitude reported from your transponder, which should be that which is sensed at the static ports. They have no way to compare it against anything else. > > > >GPS altitude is not the same thing as barometric altitude. There are many valid reasons why GPS altitude might differ by several hundred feet from barometric altitude, yet both could be correct (just as TAS may differ greatly from ground speed, yet both are correct, as they are measuring different things). GPS altitude is only the same as barometric altitude on the extremely rare day where the atmosphere perfectly matches a standard atmosphere. > > > >Kevin Horton > > > >"Kelly Patterson" wrote: > > > > > > > >> > >>My static ports were so far off I have had ATC ask me to turn off the > >>altitude reporting on my transponder. Investigation showed the convex > >>'dome' of the Vans pop rivet was causing a vacuum as the air passed over. I > >>ground the rivet head flat (on a painted plane!) and the error went away. > >> > >>Use a GPS to see what your 'true' elevation is vs. the altimeter. If the > >>altimeter reads high, consider this fix. > >> > >>Kelly Patterson > >>RV-6A N716K > >>PHX, AZ 185 hrs > >> > >> > >>From: "John D. Heath" <altoq(at)cebridge.net> > >>Subject: Re: RV-List: Altimeter error - ASI question > >> > >> > >>Doug, > >> > >> That one has to go to the shop. I can say though, airspeed indicator errors > >>are generally in the Pitot/Static system. The main trouble spot seems to be > >>the Static Port position and height above the surrounding surface. There are > >>some very elegant solutions available for static ports, but in my opinion > >>they are just a fancy way to terminate the static tubing at skin level. A > >>cheap pop rivet with enough length to install the tubing on and a washer > >>placed between it and the head of the gun when it is installed has worked > >>for me many times. The washer is to make the rivet head flat and without the > >>slight oval shape they normally have. > >> > >>John D. > >> > >> > >> > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: ASI question
Date: Oct 11, 2007
This just doesn't seem right. I find it difficult to believe an instrument like this has no better way for adjusting cal. Looking into the pitot port I see a slotted collar (nut?) and in the static port what might be a small lever. I am thinking these may be part of an adjustment mechanism. Any instrument fitters/mechanics out there? Doug Gray > If the asi is off by the same arc segment over the entire range, the > pointer > shaft gear may have jumped a few cogs. You could try removing the > pointer > and replacing it in the correct position and then check the > calibration. > The pointer should pop off if you put a piece of cloth/cardboard at > each > side to protect the dial and use two (padded if possible) > screwdrivers, one > on each side to lever it up without putting any side load on the > shaft. ________________________________________________________________________________
Date: Oct 10, 2007
I agree with that...I was making an assumption that the encoder OR the altimeter was bad. The encoder could have one of the output pins open or shorted to ground permanently giving a false number to the transponder or the altimeter needs to be serviced... Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Kevin Horton wrote: > >But, if his altimeter was connected to the same static source as the encoder (as it should), a servicable altimeter should read the same as the encoder is reporting (ignoring the effect of altimeter setting, which is accounted for by ATC). It wouldn't matter if a bad static port gave a 1000 ft error - both the altimeter and the encoder would have the same error. If the altimeter and encoder are connected to the same source, and they say different things, then one of them is unserviceable, or there is a large static leak between the two. The problem cannot be the static source. > >Kevin > >Scott wrote: > > > >> >>Wouldn't ATC know if they assigned an altitude such as 6,500 feet and >>the pilot of his RV flew at 6,500 feet according to his altimeter, but >>his encoder was reporting 6,000 or 7,000 feet? >> >>Scott >>http://corbenflyer.tripod.com/ >>Gotta Fly or Gonna Die >>Building RV-4 (Super Slow Build Version) >> >> >> >>Kevin Horton wrote: >> >> >> >>> >>>How would ATC know your static system is not accurate? All they see is the altitude reported from your transponder, which should be that which is sensed at the static ports. They have no way to compare it against anything else. >>> >>>GPS altitude is not the same thing as barometric altitude. There are many valid reasons why GPS altitude might differ by several hundred feet from barometric altitude, yet both could be correct (just as TAS may differ greatly from ground speed, yet both are correct, as they are measuring different things). GPS altitude is only the same as barometric altitude on the extremely rare day where the atmosphere perfectly matches a standard atmosphere. >>> >>>Kevin Horton >>> >>>"Kelly Patterson" wrote: >>> >>> >>> >>> >>> >>>> >>>>My static ports were so far off I have had ATC ask me to turn off the >>>>altitude reporting on my transponder. Investigation showed the convex >>>>'dome' of the Vans pop rivet was causing a vacuum as the air passed over. I >>>>ground the rivet head flat (on a painted plane!) and the error went away. >>>> >>>>Use a GPS to see what your 'true' elevation is vs. the altimeter. If the >>>>altimeter reads high, consider this fix. >>>> >>>>Kelly Patterson >>>>RV-6A N716K >>>>PHX, AZ 185 hrs >>>> >>>> >>>>From: "John D. Heath" <altoq(at)cebridge.net> >>>>Subject: Re: RV-List: Altimeter error - ASI question >>>> >>>> >>>>Doug, >>>> >>>>That one has to go to the shop. I can say though, airspeed indicator errors >>>>are generally in the Pitot/Static system. The main trouble spot seems to be >>>>the Static Port position and height above the surrounding surface. There are >>>>some very elegant solutions available for static ports, but in my opinion >>>>they are just a fancy way to terminate the static tubing at skin level. A >>>>cheap pop rivet with enough length to install the tubing on and a washer >>>>placed between it and the head of the gun when it is installed has worked >>>>for me many times. The washer is to make the rivet head flat and without the >>>>slight oval shape they normally have. >>>> >>>>John D. >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> > > > > ________________________________________________________________________________
Subject: Fw: New trim servo controller
From: "=?utf-8?B?Qm9iIE5ld21hbg==?=" <rcnewman(at)mycingular.blackberry.net>
Date: Oct 10, 2007
Sent via BlackBerry by AT&T -----Original Message----- From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> Date: Tue, 9 Oct 2007 13:19:05 To:"Matronics list" Subject: New trim servo controller Fellow RV builders, I would like to make you all aware of a new product I am introducing to the homebuilt community. We have developed a trim servo controller that eliminates the problems of run-away trim and inoperative trim conditions. Our new servo controller is called Safety-Trim and it provides speed control, direction control, emergency reversing and time limited motion of standard trim servos, such as the Ray Allen series. We've been flying Safety-Trim in our Glastar and recently introduced it at a local EAA fly-in in Toms River, NJ. 1 and 2 axis units are now available. Please visit. www.tcwtech.com for all the details. Please contact me off list at: rnewman(at)tcwtech.com Best regards, Bob Newman RV-10. #40176 Glastar N99RN Sent via BlackBerry by AT&T ________________________________________________________________________________
Subject: VHB Tape vs Rivets
Date: Oct 10, 2007
I've been told first hand by an experienced RV4 builder in California that he used VHB tape to stick the stiffeners to the inside of his elevators. He had prior experience with it and has flown it many hours since. No problems. We use it here and there for non-structural items and it works great, but I have not done long-term testing. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Chris W Sent: Tuesday, October 09, 2007 1:51 PM Subject: RV-List: VHB Tape vs Rivets I have recently seen an episode of "Modern Marvels" on the history channel called "Sticky Stuff". One of the things they had on that show, is this tape called VHB tape made by 3M. In a test they repeatedly impacted a 16 lb bowling ball against 2 sheets of aluminum bonded with VHB tape till it failed, then they did the same test with the 2 sheets of aluminum riveted together. Since this was 3M doing the test, obviously there tape performed better. However based on the fact that bowling balls are between 8.5 and 8.6" in diameter, it appears as they only had a rivet every 4 inches. I would be really curious to see how the tape compared to doing it with the appropriate number of rivets. Anyone want to try the test? Below is a link to a youtube video of the demonstration. http://youtube.com/watch?v=ZhKreIqU_R4 -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" ________________________________________________________________________________
Date: Oct 11, 2007
My alt encoder has a tag that reads: "Replacement or re-calibration of the altimeter used for flight requires re-calibration of the Altitude Encoder" Doug Gray > > I agree with that...I was making an assumption that the encoder OR the > altimeter was bad. The encoder could have one of the output pins open > or shorted to ground permanently giving a false number to the > transponder or the altimeter needs to be serviced... > > Scott > http://corbenflyer.tripod.com/ > Gotta Fly or Gonna Die > Building RV-4 (Super Slow Build Version) > > > > Kevin Horton wrote: > > > > >But, if his altimeter was connected to the same static source as the encoder (as it should), a servicable altimeter should read the same as the encoder is reporting (ignoring the effect of altimeter setting, which is accounted for by ATC). It wouldn't matter if a bad static port gave a 1000 ft error - both the altimeter and the encoder would have the same error. If the altimeter and encoder are connected to the same source, and they say different things, then one of them is unserviceable, or there is a large static leak between the two. The problem cannot be the static source. > > > >Kevin > > > >Scott wrote: > > > > > > > >> > >>Wouldn't ATC know if they assigned an altitude such as 6,500 feet and > >>the pilot of his RV flew at 6,500 feet according to his altimeter, but > >>his encoder was reporting 6,000 or 7,000 feet? > >> > >>Scott > >>http://corbenflyer.tripod.com/ > >>Gotta Fly or Gonna Die > >>Building RV-4 (Super Slow Build Version) > >> > >> > >> > >>Kevin Horton wrote: > >> > >> > >> > >>> > >>>How would ATC know your static system is not accurate? All they see is the altitude reported from your transponder, which should be that which is sensed at the static ports. They have no way to compare it against anything else. > >>> > >>>GPS altitude is not the same thing as barometric altitude. There are many valid reasons why GPS altitude might differ by several hundred feet from barometric altitude, yet both could be correct (just as TAS may differ greatly from ground speed, yet both are correct, as they are measuring different things). GPS altitude is only the same as barometric altitude on the extremely rare day where the atmosphere perfectly matches a standard atmosphere. > >>> > >>>Kevin Horton > >>> > >>>"Kelly Patterson" wrote: > >>> > >>> > >>> > >>> > >>> > >>>> > >>>>My static ports were so far off I have had ATC ask me to turn off the > >>>>altitude reporting on my transponder. Investigation showed the convex > >>>>'dome' of the Vans pop rivet was causing a vacuum as the air passed over. I > >>>>ground the rivet head flat (on a painted plane!) and the error went away. > >>>> > >>>>Use a GPS to see what your 'true' elevation is vs. the altimeter. If the > >>>>altimeter reads high, consider this fix. > >>>> > >>>>Kelly Patterson > >>>>RV-6A N716K > >>>>PHX, AZ 185 hrs > >>>> > >>>> > >>>>From: "John D. Heath" <altoq(at)cebridge.net> > >>>>Subject: Re: RV-List: Altimeter error - ASI question > >>>> > >>>> > >>>>Doug, > >>>> > >>>>That one has to go to the shop. I can say though, airspeed indicator errors > >>>>are generally in the Pitot/Static system. The main trouble spot seems to be > >>>>the Static Port position and height above the surrounding surface. There are > >>>>some very elegant solutions available for static ports, but in my opinion > >>>>they are just a fancy way to terminate the static tubing at skin level. A > >>>>cheap pop rivet with enough length to install the tubing on and a washer > >>>>placed between it and the head of the gun when it is installed has worked > >>>>for me many times. The washer is to make the rivet head flat and without the > >>>>slight oval shape they normally have. > >>>> > >>>>John D. > >>>> > >>>> > >>>> > >>>> > >>>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >> > >> > >> > >> > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Replys about my gas burn
Date: Oct 11, 2007
Tnx for replys, Im on digest so get it onc3 a day. engine is an E2C and old engine E2A, Melinium jugs on newer one, I had to have #4 OH with oly 171 hrs on it. So I know they are not high comp jugs. I now have 200 hrs on this engine. The carb on this engine is off the old engine, and it was OH about 80 hrs ago while on old engine. All hockups, intakes etc are the same, Charlie Heathco ________________________________________________________________________________
From: Charles Rowbotham <crowbotham(at)hotmail.com>
Subject: cutting canopy
Date: Oct 11, 2007
Jef, I also suggest that you take a small piece of scrap plexi (from the excess cut off thecanopy) and try the differnt methods first. Regards, Chuck Rowbotham From: n616tb(at)btsapps.comTo: rv-list(at)matronics.comSubject: RE: RV-List: cutt ing canopyDate: Tue, 9 Oct 2007 12:54:44 -0500 Hi Chuck, I would question just one thing you mentioned here. The problem with a reg ular drill bit on plexi is the amount of twist in the bit will allow it to try to pull through the plexi causing a crack. You mentioned using a new # 40 bit, but in reality I think you are better off with a dull one. I used a regular =93dull=94 bit to drill my initial holes in the canopy. Then I used the plexi bits to open them up to the size I needed. Anyway, I could be wrong but it seems this is how I remember how it goes. Tim From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Charles RowbothamSent: Tuesday, October 09, 2007 12: 27 PMTo: rv-list(at)matronics.comSubject: RE: RV-List: cutting canopy Jef, We used a cut off disc in Dremel tool but we did it free hand. One no te of caution - allow some extra overhang (beyound the line on the canopy). The overhang will not interfere with fitting the canopy to the frame or dr illing your holes. After you have fitted the canopy canopy, drilled your ho les and clecoed the canopy to the fame you can mark the excess for removal. BTW we tried the plexiglass drill bits and had much better results but dri lling the initial hole with anew #40 drill bit and then opening up the hole with the small Uni-Bit. We did have the garage at 60 degrees C (85 degress F) for 24 hours before we drilled the canopy holes. Best Wishes, Chuck & D ave RowbothamRV-8A From: jef.vervoortw(at)telenet.beTo: rv-list(at)matronics.comSubject: RV-List: cu tting canopyDate: Tue, 9 Oct 2007 17:14:07 +0200 Not very long ago there was an article in EAA-SPORTAVIATION that explained and suggested to make the cut using a cutting bit in a Dremel tool with a c utting guide. I think it was written by an RV builder. I cannot find the article anymore. Anyone know the details, or has experience with this method ? Should you re commend it? Jef Vervoort 91031; Belgium. Boo! Scare awnews' target='_new'>Try now! _________________________________________________________________ ! ilnews ________________________________________________________________________________
Date: Oct 11, 2007
Subject: Re: was static port & altimeter error, now radar services
Dale- RE: >In the US many or most approach control areas have radar altitude from their >ground system, independent of your on board encoder. Enroute seems to be a >different story. I've not heard of such capability before so I called our friendly local, and brand-new high tech, approach facility here in Indy to ask them about radar derived altitude. The answer was no, all they have is mode C capability. As someone else commented, military facilities used to have PAR that could esentially derive altitude along a specific range, but I'm not sure those facilities are up and running any more. Regardz- gm Glen Matejcek ________________________________________________________________________________
Subject: RV8 Axle P/N's
Date: Oct 12, 2007
Good Morning, I was surpose to check on a p/n to have it omitted from the finishing kit l ast night but didn't. Family Stuff. Anyway can someone check their prints a nd fwd me the p/n's for these as well as the bolt size that attach them to the steel gear. I already have them on hand when I drilled in the gear legs. TIA, Bruce Gray RV8 Fuse Wiring and stuff/Finishing on its way _________________________________________________________________ Climb to the top of the charts!- Play Star Shuffle:- the word scramble challenge with star power. http://club.live.com/star_shuffle.aspx?icid=starshuffle_wlmailtextlink_oc t ________________________________________________________________________________
Subject: TDY to Boston
Date: Oct 12, 2007
From: "George, Neal E Capt MIL USAF 605TES/TSI" <Neal.George(at)hurlburt.af.mil>
Gentlemen - I'm planning a trip to Hanscom AFB (Boston area) early next week. Any recommendations on a place to tie down and buy fuel? Any place to stay away from? Neal George CherokeeJet N9586J 850-218-4838 ________________________________________________________________________________
Subject: Re: RV8 Axle P/N's
Date: Oct 12, 2007
axel part numbers are U-801L and U-801R Tim ----- Original Message ----- From: BRUCE GRAY To: Matronics Sent: Friday, October 12, 2007 6:09 AM Subject: RV-List: RV8 Axle P/N's Good Morning, I was surpose to check on a p/n to have it omitted from the finishing kit last night but didn't. Family Stuff. Anyway can someone check their prints and fwd me the p/n's for these as well as the bolt size that attach them to the steel gear. I already have them on hand when I drilled in the gear legs. TIA, Bruce Gray RV8 Fuse Wiring and stuff/Finishing on its way ------------------------------------------------------------------------- ----- Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! ________________________________________________________________________________
Subject: Re: TDY to Boston
Date: Oct 12, 2007
Norwood seems to be the most GA friendly spot in the Boston area, at least the few times I've been into there. Can't you get permission to fly into the base? It's only a ton of forms filled out a year in advance. Henry h. KPAE N252MK -------------- Original message -------------- From: "George, Neal E Capt MIL USAF 605TES/TSI" <Neal.George(at)hurlburt.af.mil> Gentlemen - I'm planning a trip to Hanscom AFB (Boston area) early next week. Any recommendations on a place to tie down and buy fuel? Any place to stay away from? Neal George CherokeeJet N9586J 850-218-4838
Henry h.
KPAE N252MK
Gentlemen -
Neal George
CherokeeJet N9586J
850-218-4838
Date: Oct 12, 2007
Thanks Tim! Bruce G. From: tcone1(at)comcast.netTo: rv-list(at)matronics.comSubject: Re: RV-List: RV8 Axle P/N'sDate: Fri, 12 Oct 2007 07:54:08 -0700 axel part numbers are U-801L and U-801R Tim ----- Original Message ----- From: BRUCE GRAY Sent: Friday, October 12, 2007 6:09 AM Subject: RV-List: RV8 Axle P/N's Good Morning,I was surpose to check on a p/n to have it omitted from the fi nishing kit last night but didn't. Family Stuff. Anyway can someone check t heir prints and fwd me the p/n's for these as well as the bolt size that at tach them to the steel gear.I already have them on hand when I drilled in t he gear legs. TIA,Bruce GrayRV8 FuseWiring and stuff/Finishing on its way Climb to the top of the charts! Play Star Shuffle: the word scramble chal lenge with star power. Play Now! href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.co m/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________________________ ! ilnews ________________________________________________________________________________
Date: Oct 12, 2007
Norwood is nice, but on the south side of the city....read... traffic issue s on 128.... Consider airports on south edge of New Hampshire.... Marty RV-7 (fitting interior systems) From: aeroncadoc(at)comcast.netTo: rv-list(at)matronics.comSubject: Re: RV-List: TDY to BostonDate: Fri, 12 Oct 2007 15:37:53 +0000 Norwood seems to be the most GA friendly spot in the Boston area, at least the few times I've been into there. Can't you get permission to fly into t he base? It's only a ton of forms filled out a year in advance. Henry h. KPAE N252MK -------------- Original message -------------- From: "George, Neal E Capt M IL USAF 605TES/TSI" Gentlemen - I'm planning a trip to Hanscom AFB (Boston area) early next week. Any reco mmendations on a place to tie down and buy fuel? Any place to stay away fro m? Neal George CherokeeJet N9586J 850-218-4838 _________________________________________________________________ Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop by today. http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_Oc tWLtagline ________________________________________________________________________________
Date: Oct 12, 2007
Subject: Re: RV-List - Drilling plexiglas
The same abrasive disc you use for cutting the plex can be used to modify standard drill bits for safe drilling of the holes. Spin the disc full speed with it's axis perpendicular to the drill axis (SIDE OF DISC PARALLEL TO DRILL AXIS). Use the side of the abrasive disc to reduce the rake angle of the drill bit to zero for about 1/16 back of the cutting edge. this you can do in less than a minute. This will give a rake angle of approx. zero and will cut plex with no breakouts. You will find this to be much easier to do than reading this! Paul S. Petersen, RV6A nearly done with son Eric ________________________________________________________________________________
Date: Oct 12, 2007
Subject: Re: Replys about my gas burn
>Subject: RV-List: Replys about my gas burn > But is it fixed or CS? Glen Matejcek ________________________________________________________________________________
Date: Oct 12, 2007
> >As someone else commented, military facilities used to have PAR that could esentially >derive altitude along a specific range, but I'm not sure those facilities >are up and running any more. I got in touch w/ some friends and learned that GCA is increasingly rare in the US,but is still used elsewhere in the world,and that civil A/C do use these approaches. FWIW- Glen Matejcek ________________________________________________________________________________
Date: Oct 12, 2007
[quote="Neal.George(at)hurlburt.a"]Gentlemen - I'm planning a trip to Hanscom AFB (Boston area) early next week. Any recommendations on a place to tie down and buy fuel? Any place to stay away from? Neal George CherokeeJet N9586J 850-218-4838 > [b] Hi Neal. I assume that if your business is at Hanscom, you can just land at Hanscom, can't you? It's not exclusively an AFB; it's a regional airport, too. (I think Goulian flies out of there, doesn't he?) Besides, you're in the military so I doubt it'd be an issue anyway. I assume that some RV builder there would be more than happy to have you stay at their house. Anyone? -------- Bob Collins St. Paul, Minn. Letters from Flyover Country http://rvnewsletter.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=139620#139620 ________________________________________________________________________________
Subject: 2"1/4 Altimeter
Date: Oct 12, 2007
Hello, As I'm installing a D100, I need to put a backup ASI and altimeter. Van's sells a 2"1/4 airspeed indicator, but no altimeter of that size. Spruce doesn't sell that either, but a single pointer one. Does someone know a vendor providing a 2"1/4 dual-pointer altimeter ? As always, thanks to the community :-) Philippe Starting fuselage and instrument panel RV9A - Brussels - Belgium ________________________________________________________________________________
From: "Lamar Lawson" <lamar(at)takeflighttexas.com>
Subject: Re: 2"1/4 Altimeter
Date: Oct 12, 2007
Hate to tell you this but if you do not want the use the 2 1/4 UMA spruce sells, the next step is $700-$800 US. i opted for the $200 UMA. this comes up from time to time so you should be able to find lots of info in the achives. good luck! Lamar - RV7A ----- Original Message ----- From: Merlin To: 'RV-List Digest Server' Sent: Friday, October 12, 2007 2:38 PM Subject: RV-List: 2"1/4 Altimeter Hello, As I'm installing a D100, I need to put a backup ASI and altimeter. Van's sells a 2"1/4 airspeed indicator, but no altimeter of that size. Spruce doesn't sell that either, but a single pointer one. Does someone know a vendor providing a 2"1/4 dual-pointer altimeter ? As always, thanks to the community :-) Philippe Starting fuselage and instrument panel RV9A - Brussels - Belgium ________________________________________________________________________________
Date: Oct 12, 2007
I got one for my F1 from Stein at Steinair. Danny Melnik F1 #25 Melbourne (FL) Rocket Factory -----Original Message----- From: Merlin <phil.merlin(at)skynet.be> Sent: Fri, 12 Oct 2007 3:38 pm Subject: RV-List: 2"1/4 Altimeter Hello, ? As I'm installing a D100, I need to put a backup ?ASI and altimeter. Van's sells a 2"1/4 airspeed indicator, but no altimeter of that size. Spruce doesn't sell that either, but a single pointer one. ? Does someone know a vendor providing a 2"1/4 dual-pointer altimeter ?? ? As always, thanks to the community ?:-) ? ? Philippe Starting fuselage and instrument panel RV9A - Brussels - Belgium ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 12, 2007
There is a 2-1/4" altimeter made by Winter that is often installed in gliders. Check with the suppliers for gliders. If you can't find it, let me know and I will dig an ad out of Soaring magazine. It's pretty expensive - I think I remember about $600 or so. I have the 2-1/4" single-needle one (not flying yet) and I don't like it. Terry RV-8A wiring Seattle _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Merlin Sent: Friday, October 12, 2007 12:39 PM Subject: RV-List: 2"1/4 Altimeter Hello, As I'm installing a D100, I need to put a backup ASI and altimeter. Van's sells a 2"1/4 airspeed indicator, but no altimeter of that size. Spruce doesn't sell that either, but a single pointer one. Does someone know a vendor providing a 2"1/4 dual-pointer altimeter ? As always, thanks to the community :-) Philippe Starting fuselage and instrument panel RV9A - Brussels - Belgium ________________________________________________________________________________
Date: Oct 12, 2007
Hi Neal, You can land at Hanscom AFB (BED) and tie down there. The base shares the field with commerical and civil aviation. I used to keep my Citabria there and made the first flights in my -4 from there. I've since heard there is a landing fee and gas is definitely expensive there, but one or both of th ese may not apply to you. The next closest is probably Minuteman Airfield in Stow (9B9?), but no rental cars, nearby hotels, etc. I now keep my -4 a t Worcester which is about an hour's drive west. Feel free to contact me d irectly if you would like more help. Regards, Subject: RV-List: TDY to BostonDate: Fri, 12 Oct 2007 09:41:27 -0500From: N eal.George(at)hurlburt.af.milTo: rv-list(at)matronics.com Gentlemen - I'm planning a trip to Hanscom AFB (Boston area) early next week. Any reco mmendations on a place to tie down and buy fuel? Any place to stay away fro m? Neal George CherokeeJet N9586J 850-218-4838 _________________________________________________________________ Windows Live Hotmail and Microsoft Office Outlook ' together at last. - Get it now. http://office.microsoft.com/en-us/outlook/HA102225181033.aspx?pid=CL10062 6971033 ________________________________________________________________________________
Date: Oct 12, 2007
Subject: Re: ProSeal - small amt.for sale
I bought one of the tubes of ProSeal from Van's when I needed some to do the trailing edge on my rudder. Instead of mixing it up in the tube as directed, I dismantled the mixing apparatus and just took some out of the tube and mixed it up manually. I was able to save over half of it by doing it this way and not waste it. Now that I'm working on my fuel tanks, I still have it but it's out of date. It's not out of date by much and it's been in the refrigerator for the last 7 months since I built my rudder, but I don't want to take any chances with my fuel tanks. The amount I have left would be ideal for anyone building their rudder and at the point of doing the trailing edge. Since it's not critical that it be in-date, it would work fine for you. I'll be willing to give it to any builder who wants it, if you'll pay a nominal amount for my shipping costs. I hate to throw it away. Maybe I can save somebody a few bucks. Bruce Swayze RV-7A Wings - working on fuel tanks >With the tubes...you don't get the mess, but you pay for it with >less flexibility on time and if you are very organized and >efficient, I think they're a great way to go. > >I did buy the tube once (we're talking about the one where you mix >it in the tube, right?) for something like $16 and I ended up >tossing half of it away because I didn't need that much. > >Some people freeze their ProSeal which they say adds life to it etc. >I cannot speak to that because while my wife is quite forgiving of >my airplane mistress, she draws the line when reaching for an ice >cream sandwich and getting a baggie full of ProSeal instead. > >-------- >Bob Collins >St. Paul, Minn. >Letters from Flyover Country >http://rvnewsletter.blogspot.com/ -- ________________________________________________________________________________
Date: Oct 12, 2007
I just used some proseal I've had in the freezer that is four years old. It set up fine and I cannot tell any difference between it and fresh stuff. Seems to me shelf life is a good way of insuring future sales if you're in the glue business. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Date: Oct 12, 2007
Last I knew Luke AFB had one at their Aux 1 field along with an ILS for F-16 training. Eielson AFB in AK had one when I left their in '92 and they would allow civil planes to fly it for practice with something like 100 ft AGL restriction flying over their runway. Glen Matejcek wrote: > > >> As someone else commented, military facilities used to have PAR that could esentially >> derive altitude along a specific range, but I'm not sure those facilities >> are up and running any more. >> > > I got in touch w/ some friends and learned that GCA is increasingly rare in the US,but is still used elsewhere in the world,and that civil A/C do use these approaches. > > FWIW- > > Glen Matejcek > > > ________________________________________________________________________________
Date: Oct 13, 2007
Neal, Even though Hanscom is a civil airfield, the Air Force still has hangars, ramp space and an Aero Club there. If you're TDY or even on leave, you can buy avgas, tie down and/or get some hangar space cheaper than anywhere else on the field. I'm one of the club's CFIs, feel free to call (781 789 2768) or get in touch via private email and I'll be glad to help. Dave Setser RV-7 wings Arlington MA ________________________________________________________________________________
Subject: Transition training in Colorado
Date: Oct 13, 2007
I'm looking for a CFI with a full dual control RV-6, 7, or 8A in or around Colorado who can give a couple hours of dual to a friend for both proficiency and insurance requirements. He's a high time pilot, but with no RV time. Please call Andy Gold at 970 887-2194 or Mark Burg at 970 887-9776 or write back and we can schedule at your convenience. Thanks, Andy ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: PC-680 Performance
Date: Oct 13, 2007
Over the years, the Odyssey PC-680 has gotten very good reviews for its small size and high cranking amps. So, about 3 years ago, I selected one to replace a 4 year old Concorde battery. My first Odyssey battery became weak after just under 2 years. The vendor replaced it under warranty. Today, my ~14 month old replacement battery barely turned the engine over on a 80 degree day. Sure, the aircraft sat outside in 45 degree weather last night (Thomasville GA Fly-in - a really fun one), but the airplane had 8 hours of South Georgia sunshine to warm up, so is isn't like the battery was chilled or anything. To get to the point, what is the RV-list's collective experience with this battery? I know it is light and has good cranking power when new, but I'm interested in what sort of longevity people are seeing. Is it lasting 1 year, 2 years, more, or less? I'd hate to go back to the Concorde, but I'd prefer that to a battery that goes soft after less than two years. KB ________________________________________________________________________________
Date: Oct 13, 2007
Subject: Re: PC-680 Performance
On 10/13 10:07, Kyle Boatright wrote: > To get to the point, what is the RV-list's collective experience with this > battery? I know it is light and has good cranking power when new, but I'm > interested in what sort of longevity people are seeing. Is it lasting 1 > year, 2 years, more, or less? I'd hate to go back to the Concorde, but > I'd prefer that to a battery that goes soft after less than two years. Since the battery is relatively cheap, just above $100, I replace it at every annual. This gives me peace of mind knowing I have a fresh battery and I now have a decent backup or something to play pass the electrons with in the shop. I always connect to a trickle charger after each flight just to keep it tip-top. I've never had a battery issue now in two years. ymmv. -- Walter Tondu http://www.rv7-a.com - Painting http://www.evorocket.com - Empennage ________________________________________________________________________________
Date: Oct 14, 2007
in 2000 i purchased a pc680 for install in my 6a before it was completed. i used it to test and power up systems during final assembly. first flight in 2001- fast foreword to 2007, still going strong. I've left the master on twice in its life killing it completely. it seemed to recharge without incident. now i haven't done any discharge calculations to find out its true capacity, but it has no problem starting the o-360 after 10 days of inactivity. i have never used any trickle charger and don't remember having to jump start it when it wasn't my fault. I'd say it's probably hands down the best battery I've ever owned.( i even have one in my kids battery powered ride on truck) I'm using a B&C alternator and lr3 regulator using standard wet cell voltages. Steven dinieri iflyrv10.com capsteve(at)adelphia.net _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kyle Boatright Sent: Saturday, October 13, 2007 10:08 PM Subject: RV-List: PC-680 Performance Over the years, the Odyssey PC-680 has gotten very good reviews for its small size and high cranking amps. So, about 3 years ago, I selected one to replace a 4 year old Concorde battery. My first Odyssey battery became weak after just under 2 years. The vendor replaced it under warranty. Today, my ~14 month old replacement battery barely turned the engine over on a 80 degree day. Sure, the aircraft sat outside in 45 degree weather last night (Thomasville GA Fly-in - a really fun one), but the airplane had 8 hours of South Georgia sunshine to warm up, so is isn't like the battery was chilled or anything. To get to the point, what is the RV-list's collective experience with this battery? I know it is light and has good cranking power when new, but I'm interested in what sort of longevity people are seeing. Is it lasting 1 year, 2 years, more, or less? I'd hate to go back to the Concorde, but I'd prefer that to a battery that goes soft after less than two years. KB ________________________________________________________________________________
Date: Oct 14, 2007
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: ProSeal
I just used some 3 year old pro seal that spent most of its life in a south Florida hangar where temps are 110 in the daytime with the doors closed (metal Tee hangar). Believe it or not, both parts were still mixable although I did have to punch through a rubbery film on the top of the white stuff to get to the good stuff. So....is does have its limits but I think a year is little on the conservative side. No, I didn't use it on fuel tanks. ____________________________Original Message ______________________________ From: "Bob J." <rocketbob(at)gmail.com> Subject: Re: RV-List: Re: ProSeal - small amt.for sale I just used some proseal I've had in the freezer that is four years old..... Regards, Bob Japundza ________________________________________________________________________________
Date: Oct 14, 2007
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Hey Walter, I could use one of the rejects for testing. ;-) Darrell ----- Original Message ---- From: Walter Tondu <walter(at)tondu.com> Sent: Saturday, October 13, 2007 10:37:40 PM Subject: Re: RV-List: PC-680 Performance On 10/13 10:07, Kyle Boatright wrote: > To get to the point, what is the RV-list's collective experience with this > battery? I know it is light and has good cranking power when new, but I'm > interested in what sort of longevity people are seeing. Is it lasting 1 > year, 2 years, more, or less? I'd hate to go back to the Concorde, but > I'd prefer that to a battery that goes soft after less than two years. Since the battery is relatively cheap, just above $100, I replace it at every annual. This gives me peace of mind knowing I have a fresh battery and I now have a decent backup or something to play pass the electrons with in the shop. I always connect to a trickle charger after each flight just to keep it tip-top. I've never had a battery issue now in two years. ymmv. -- Walter Tondu http://www.rv7-a.com - Painting http://www.evorocket.com - Empennage Need a vacation? Get great deals to amazing places on Yahoo! Travel. http://travel.yahoo.com/ ________________________________________________________________________________
Date: Oct 14, 2007
I've had my PC-680 going on 5 years. Did run it flat once with the master left on. Didn't seem to affect it as it would had it been a lead acid battery. I never need to trickle charge it. Left last winter in the hangar without flying for five months. Put the charger on to see how it was in the spring and the charger indicated it was at full charge after 5 seconds of charge time. I personally can't say enough good about Odyssey's products. Pat Long PGLong(at)aol.com N120PL RV 4 Bay City, Michigan 3CM Do Not Archive ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Oct 14, 2007
The Odyssey battery in my RV6-A is 4 years old and still cranks the 0-360A1A over just like day one! I have the B&C alternator & regulator which I feel is the key reason the battery is always ready to go. After shutting down and attaching the BatteryMinder the green light starts flashing within a minute.......probably not needed. I live in Ohio and run a Reiff preheater with cylinder bands in the winter. Tom in Ohio (10G) ----- Original Message ----- From: Kyle Boatright To: rv-list(at)matronics.com Sent: Saturday, October 13, 2007 10:07 PM Subject: RV-List: PC-680 Performance Over the years, the Odyssey PC-680 has gotten very good reviews for its small size and high cranking amps. So, about 3 years ago, I selected one to replace a 4 year old Concorde battery. My first Odyssey battery became weak after just under 2 years. The vendor replaced it under warranty. Today, my ~14 month old replacement battery barely turned the engine over on a 80 degree day. Sure, the aircraft sat outside in 45 degree weather last night (Thomasville GA Fly-in - a really fun one), but the airplane had 8 hours of South Georgia sunshine to warm up, so is isn't like the battery was chilled or anything. To get to the point, what is the RV-list's collective experience with this battery? I know it is light and has good cranking power when new, but I'm interested in what sort of longevity people are seeing. Is it lasting 1 year, 2 years, more, or less? I'd hate to go back to the Concorde, but I'd prefer that to a battery that goes soft after less than two years. KB ________________________________________________________________________________
Date: Oct 14, 2007
In a message dated 10/13/2007 10:31:27 P.M. Pacific Daylight Time, capsteve(at)adelphia.net writes: in 2000 i purchased a pc680 for install in my 6a before it was completed. i used it to test and power up systems during final assembly. first flight in 2001- fast foreword to 2007, still going strong. I've left the master on twice in its life killing it completely. it seemed to recharge without incident. ========================================================== I always put the Power Sonic two stage charger on mine when not flying because I have a "keep alive" circuit in my am/fm radio that uses just a little power to retain the memory. Mine last for several years each with this treatment. N1GV (RV-6A, Flying 869hrs, O-360-A1A, C/S, Silicon Valley) ________________________________________________________________________________
Date: Oct 14, 2007
On 10/14 5:53, Darrell Reiley wrote: > I could use one of the rejects for testing. ;-) I've donated all of the older ones but have one left that I use as my tester/backup battery. If you want to wait till next July (scheduled annual) you can have the next off the firewall. Have only had two annuals so far and gave both to local builders. -- Walter Tondu http://www.rv7-a.com - Painting http://www.evorocket.com - Empennage ________________________________________________________________________________
Date: Oct 14, 2007
Hi Kyle, I have an Odyssey battery in my RV-6A.? I was told that it needed to be charged at 14.2 volts.? If it was charged at a lower voltage, it would gradually loose capacity from being undercharged. I don't have a source for the 14.2 volts.? I didn't find it on the Odyssey battery website.? Anyone know where the correct charging voltage is documented? Regards, Jim Ayers -----Original Message----- From: Kyle Boatright <kboatright1(at)comcast.net> Sent: Sat, 13 Oct 2007 7:07 pm Subject: RV-List: PC-680 Performance Over the years, the Odyssey PC-680 has gotten very good reviews for its small size and high cranking amps.? So, about 3 years ago, I selected one to replace a 4 year old Concorde battery. ? My first Odyssey battery became weak after just under 2 years.? The vendor replaced it under warranty. ? Today, my ~14 month old replacement battery barely turned the engine over on a 80 degree day. Sure, the aircraft sat outside in 45 degree weather last night (Thomasville GA Fly-in - a really fun one), but the airplane had 8 hours of South Georgia sunshine to warm up, so is isn't like the battery was chilled or anything. ? To get to the point, what is the RV-list's collective experience with this battery?? I know it is light and has good cranking power when new, but I'm interested in what sort of longevity people are seeing. Is it lasting 1 year, 2 years, more, or less?? I'd hate to go back to the Concorde, but I'd prefer that to a battery that goes soft after less than two years. ? KB ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 14, 2007
I found some excellent information on charging of AGM seal lead acid batteries on the panasonic web site. If I remeber it takes a little digging on their site, but its there. I believe the charging voltage depends primarily on chemistry type. (Ie sla-agm) and temperature. -bob newman Sent via BlackBerry by AT&T -----Original Message----- From: lessdragprod(at)aol.com Date: Sun, 14 Oct 2007 14:43:22 To:rv-list(at)matronics.com Subject: Re: RV-List: PC-680 Performance Hi Kyle, I have an Odyssey battery in my RV-6A. I was told that it needed to be charged at 14.2 volts. If it was charged at a lower voltage, it would gradually loose capacity from being undercharged. I don't have a source for the 14.2 volts. I didn't find it on the Odyssey battery website. Anyone know where the correct charging voltage is documented? Regards, Jim Ayers -----Original Message----- From: Kyle Boatright <kboatright1(at)comcast.net> To: rv-list(at)matronics.com Sent: Sat, 13 Oct 2007 7:07 pm Subject: RV-List: PC-680 Performance Over the years, the Odyssey PC-680 has gotten very good reviews for its small size and high cranking amps. So, about 3 years ago, I selected one to replace a 4 year old Concorde battery. My first Odyssey battery became weak after just under 2 years. The vendor replaced it under warranty. Today, my ~14 month old replacement battery barely turned the engine over on a 80 degree day. Sure, the aircraft sat outside in 45 degree weather last night (Thomasville GA Fly-in - a really fun one), but the airplane had 8 hours of South Georgia sunshine to warm up, so is isn't like the battery was chilled or anything. To get to the point, what is the RV-list's collective experience with this battery? I know it is light and has good cranking power when new, but I'm interested in what sort of longevity people are seeing. Is it lasting 1 year, 2 years, more, or less? I'd hate to go back to the Concorde, but I'd prefer that to a battery that goes soft after less than two years. KB ---------------- ________________________________________________________________________________
Date: Oct 14, 2007
Subject: RV7A near Dayton, OH?
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 List, After a number of years of thinking and hoping, I've just taken the plunge and bought an empennage kit for an RV-7A. Is there anybody on the list with a flying 7/7A near Dayton? I19 or MGY would be ideal, but other locations could work as well. It'd be great to see how they fly; I'd be happy to cover expenses, of course. Also, if there are any builders in the area who could use a hand, let me know--the more I can learn on somebody else's airplane, the better! (-: - -- Dan Brown, KE6MKS, dan(at)familybrown.org "Since all the world is but a story, it were well for thee to buy the more enduring story rather than the story that is less enduring." -- The Judgment of St. Colum Cille -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.2.1 (MingW32) Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org iD8DBQFHEnZ0yQGUivXxtkERAotlAJoDaH+MsvSUHS3vWBfSOcxpAdd/RQCfQJgg IkQ9Agtd2MsLpTpT8/v1mg8 =TJyw -----END PGP SIGNATURE----- ________________________________________________________________________________
Date: Oct 14, 2007
Thanks Walter! I will stick a note on the calendar. They do come in handy on the work bench for sure. I guess we'll figure out the details then. Regards, Darrell ----- Original Message ---- From: Walter Tondu <walter(at)tondu.com> Sent: Sunday, October 14, 2007 1:04:43 PM Subject: Re: RV-List: PC-680 Performance On 10/14 5:53, Darrell Reiley wrote: > I could use one of the rejects for testing. ;-) I've donated all of the older ones but have one left that I use as my tester/backup battery. If you want to wait till next July (scheduled annual) you can have the next off the firewall. Have only had two annuals so far and gave both to local builders. -- Walter Tondu http://www.rv7-a.com - Painting http://www.evorocket.com - Empennage Pinpoint customers who are looking for what you sell. http://searchmarketing.yahoo.com/ ________________________________________________________________________________
Date: Oct 14, 2007
Ditto what others have said about charging voltage. AGMs like a higher voltage. I don't have the paperwork handy, but I believe it was 14.2 or 14.4. If you regulator is set below 14 (likely scenario) than that would explain the short life. Jeff Point RV-6 flying RV-8 building Milwaukee > * > > * ________________________________________________________________________________
Date: Oct 14, 2007
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
Subject: Re: RV7A near Dayton, OH?
You need to join this group. There are alot of RV's around you. http://groups.yahoo.com/group/OhioValleyRVators/ Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Dan Brown wrote: > > -----BEGIN PGP SIGNED MESSAGE----- > Hash: SHA1 > > List, > > After a number of years of thinking and hoping, I've just taken the > plunge and bought an empennage kit for an RV-7A. Is there anybody on > the list with a flying 7/7A near Dayton? I19 or MGY would be ideal, but > other locations could work as well. It'd be great to see how they fly; > I'd be happy to cover expenses, of course. > > Also, if there are any builders in the area who could use a hand, let me > know--the more I can learn on somebody else's airplane, the better! (-: > > - -- > Dan Brown, KE6MKS, dan(at)familybrown.org > "Since all the world is but a story, it were well for thee to buy the > more enduring story rather than the story that is less enduring." > -- The Judgment of St. Colum Cille > -----BEGIN PGP SIGNATURE----- > Version: GnuPG v1.2.1 (MingW32) > Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org > > iD8DBQFHEnZ0yQGUivXxtkERAotlAJoDaH+MsvSUHS3vWBfSOcxpAdd/RQCfQJgg > IkQ9Agtd2MsLpTpT8/v1mg8 > =TJyw > -----END PGP SIGNATURE----- > > > ________________________________________________________________________________
Date: Oct 14, 2007
The next issue is how does one go about adjusting the Ford voltage regulator I installed per Electric Bob's suggestion? KB ----- Original Message ----- From: "Jeff Point" <jpoint(at)mindspring.com> Sent: Sunday, October 14, 2007 5:34 PM Subject: Re: RV-List: PC-680 Performance > > Ditto what others have said about charging voltage. AGMs like a higher > voltage. I don't have the paperwork handy, but I believe it was 14.2 or > 14.4. If you regulator is set below 14 (likely scenario) than that would > explain the short life. > > Jeff Point > RV-6 flying > RV-8 building > Milwaukee > > >> * >> >> * > > > ________________________________________________________________________________
Date: Oct 14, 2007
Kyle Boatright wrote: > > The next issue is how does one go about adjusting the Ford voltage > regulator I installed per Electric Bob's suggestion? Kyle, the Ford regulator is keeping my PC680 charged just fine, voltage to the battery is ~14.3. Don't know why your 680 died an early death, but that doesn't seem to be the norm. As inexpensive as the regulators are, you might just replace it if the output is too low. Sam Buchanan ________________________________________________________________________________
Date: Oct 14, 2007
Look it over for an adjusting screw. Then monitor the charging voltage when the engine is running ----- Original Message ----- From: "Kyle Boatright" <kboatright1(at)comcast.net> Sent: Sunday, October 14, 2007 6:33 PM Subject: Re: RV-List: PC-680 Performance > > The next issue is how does one go about adjusting the Ford voltage > regulator I installed per Electric Bob's suggestion? > > KB > > ----- Original Message ----- > From: "Jeff Point" <jpoint(at)mindspring.com> > To: > Sent: Sunday, October 14, 2007 5:34 PM > Subject: Re: RV-List: PC-680 Performance > > >> >> Ditto what others have said about charging voltage. AGMs like a higher >> voltage. I don't have the paperwork handy, but I believe it was 14.2 or >> 14.4. If you regulator is set below 14 (likely scenario) than that would >> explain the short life. >> >> Jeff Point >> RV-6 flying >> RV-8 building >> Milwaukee >> >> >>> * >>> >>> * >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 14, 2007
That depends on which Ford regulator you installed. The older tall units have an adjustment screw under the cap. Most of the short cap units are pre-set, not to be adjusted. If it's adjustable, a run up and volt meter will give you the charge output. You adjust the screw in for more output. Darrell ----- Original Message ---- From: Kyle Boatright <kboatright1(at)comcast.net> Sent: Sunday, October 14, 2007 7:33:11 PM Subject: Re: RV-List: PC-680 Performance The next issue is how does one go about adjusting the Ford voltage regulator I installed per Electric Bob's suggestion? KB ----- Original Message ----- From: "Jeff Point" <jpoint(at)mindspring.com> Sent: Sunday, October 14, 2007 5:34 PM Subject: Re: RV-List: PC-680 Performance > > Ditto what others have said about charging voltage. AGMs like a higher > voltage. I don't have the paperwork handy, but I believe it was 14.2 or > 14.4. If you regulator is set below 14 (likely scenario) than that would > explain the short life. > > Jeff Point > RV-6 flying > RV-8 building > Milwaukee > > >> * >> >> * > > > ________________________________________________________________________________
Date: Oct 15, 2007
> Over the years, the Odyssey PC-680 has gotten very good reviews... I had a PC-625 in my 180 hp IO-360 RV-8 for five years and it was still going strong when I replaced it last month.- I never used a trickle charger.- Maybe they have a QC issue. Mike Robbins ________________________________________________________________________________
Date: Oct 15, 2007
Darrell Reiley wrote: > > > That depends on which Ford regulator you installed. The older tall > units have an adjustment screw under the cap. Most of the short cap > units are pre-set, not to be adjusted. If it's adjustable, a run up > and volt meter will give you the charge output. You adjust the screw > in for more output. The VR166 type Ford regulator (mid-70's LTD) that 'Lectric Bob shows in some of his schematics and many of us use is solid-state and doesn't have any adjustments. Since it only costs about $10 it is easy to replace if it has drifted out of spec. But they seem to be very reliable units and mine has been fine for eight years. Sam Buchanan ________________________________________________________________________________
Subject: Thomasville, GA Fly-In
Date: Oct 15, 2007
This past week-end was the Thomasville, Georgia annual fly-in. This event has been happening close to 40 years and is one of my favorite fly-in's to attend. It is a well run event that does not have a real structured program. It is an aviation social event and the main rule is for you to have a good time. If you are tired of poorly run events with bad facilities, give this one a try next year. It happens the second week-end in October every year and is open to all types of aircraft. There is also a great private collection aviation engines on the field. It is always open for viewing during the fly-in and contains rare engines you might not have ever heard of. Go to http://picasaweb.google.com/RV455J/Thomasville2007 for a few pictures from this year. ________________________________________________________________________________
Date: Oct 15, 2007
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Oct 15, 2007
http://www.odysseyfactory.com/ is their website and they have their own charger, I took the part number and did a search on Google and saved a bit of money over the factory site. I use two of the batteries and always keep them charged full up, as I have an electrically dependant engine. Dan N289DT RV10E Flying _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of lessdragprod(at)aol.com Sent: Sunday, October 14, 2007 2:43 PM Subject: Re: RV-List: PC-680 Performance Hi Kyle, I have an Odyssey battery in my RV-6A. I was told that it needed to be charged at 14.2 volts. If it was charged at a lower voltage, it would gradually loose capacity from being undercharged. I don't have a source for the 14.2 volts. I didn't find it on the Odyssey battery website. Anyone know where the correct charging voltage is documented? Regards, Jim Ayers -----Original Message----- From: Kyle Boatright <kboatright1(at)comcast.net> Sent: Sat, 13 Oct 2007 7:07 pm Subject: RV-List: PC-680 Performance Over the years, the Odyssey PC-680 has gotten very good reviews for its small size and high cranking amps. So, about 3 years ago, I selected one to replace a 4 year old Concorde battery. My first Odyssey battery became weak after just under 2 years. The vendor replaced it under warranty. Today, my ~14 month old replacement battery barely turned the engine over on a 80 degree day. Sure, the aircraft sat outside in 45 degree weather last night (Thomasville GA Fly-in - a really fun one), but the airplane had 8 hours of South Georgia sunshine to warm up, so is isn't like the battery was chilled or anything. To get to the point, what is the RV-list's collective experience with this battery? I know it is light and has good cranking power when new, but I'm interested in what sort of longevity people are seeing. Is it lasting 1 year, 2 years, more, or less? I'd hate to go back to the Concorde, but I'd prefer that to a battery that goes soft after less than two years. KB _____ Email and AIM finally together. You've gotta check out free AOL Mail <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?nc id=AOLAOF00020000000970> ! ________________________________________________________________________________
Date: Oct 15, 2007
Kyle, I think there are a coule of brand new regulators in my shop. I should have both types. Darrell ----- Original Message ---- From: Kyle Boatright <kboatright1(at)comcast.net> Sent: Sunday, October 14, 2007 7:33:11 PM Subject: Re: RV-List: PC-680 Performance The next issue is how does one go about adjusting the Ford voltage regulator I installed per Electric Bob's suggestion? KB ----- Original Message ----- From: "Jeff Point" <jpoint(at)mindspring.com> Sent: Sunday, October 14, 2007 5:34 PM Subject: Re: RV-List: PC-680 Performance > > Ditto what others have said about charging voltage. AGMs like a higher > voltage. I don't have the paperwork handy, but I believe it was 14.2 or > 14.4. If you regulator is set below 14 (likely scenario) than that would > explain the short life. > > Jeff Point > RV-6 flying > RV-8 building > Milwaukee > > >> * >> >> * > > > Pinpoint customers who are looking for what you sell. http://searchmarketing.yahoo.com/ ________________________________________________________________________________
Date: Oct 15, 2007
Specialized chargers for AGM batteries available here... http://www.vdcelectronics.com/ Randy Lervold www.rv-3.com ----- Original Message ----- From: lessdragprod(at)aol.com To: rv-list(at)matronics.com Sent: Sunday, October 14, 2007 11:43 AM Subject: Re: RV-List: PC-680 Performance Hi Kyle, I have an Odyssey battery in my RV-6A. I was told that it needed to be charged at 14.2 volts. If it was charged at a lower voltage, it would gradually loose capacity from being undercharged. I don't have a source for the 14.2 volts. I didn't find it on the Odyssey battery website. Anyone know where the correct charging voltage is documented? Regards, Jim Ayers ________________________________________________________________________________
Date: Oct 15, 2007
Randy, I think you will find that most of the quality 12 volt battery chargers on the market today chage at the rate of 14.3 or there abouts so Why don't you go to a place where 12 volt battries are sold and ask what the charging rate is. Bob Stone Harker Heights, Tx ZodiacXL ----- Original Message ----- From: Randy Lervold To: rv-list(at)matronics.com Sent: Monday, October 15, 2007 1:15 PM Subject: Re: RV-List: PC-680 Performance Specialized chargers for AGM batteries available here... http://www.vdcelectronics.com/ Randy Lervold www.rv-3.com ----- Original Message ----- From: lessdragprod(at)aol.com To: rv-list(at)matronics.com Sent: Sunday, October 14, 2007 11:43 AM Subject: Re: RV-List: PC-680 Performance Hi Kyle, I have an Odyssey battery in my RV-6A. I was told that it needed to be charged at 14.2 volts. If it was charged at a lower voltage, it would gradually loose capacity from being undercharged. I don't have a source for the 14.2 volts. I didn't find it on the Odyssey battery website. Anyone know where the correct charging voltage is documented? Regards, Jim Ayers ________________________________________________________________________________
Date: Oct 15, 2007
AGM batteries prefer a little higher voltage. Yes, standard battery chargers will work but are not optimum. Info from their site... http://www.odysseyfactory.com/odycharg_b.htm ----- Original Message ----- From: robert stone To: rv-list(at)matronics.com Sent: Monday, October 15, 2007 12:32 PM Subject: Re: RV-List: PC-680 Performance Randy, I think you will find that most of the quality 12 volt battery chargers on the market today chage at the rate of 14.3 or there abouts so Why don't you go to a place where 12 volt battries are sold and ask what the charging rate is. Bob Stone Harker Heights, Tx ZodiacXL ----- Original Message ----- From: Randy Lervold To: rv-list(at)matronics.com Sent: Monday, October 15, 2007 1:15 PM Subject: Re: RV-List: PC-680 Performance Specialized chargers for AGM batteries available here... http://www.vdcelectronics.com/ Randy Lervold www.rv-3.com ----- Original Message ----- From: lessdragprod(at)aol.com To: rv-list(at)matronics.com Sent: Sunday, October 14, 2007 11:43 AM Subject: Re: RV-List: PC-680 Performance Hi Kyle, I have an Odyssey battery in my RV-6A. I was told that it needed to be charged at 14.2 volts. If it was charged at a lower voltage, it would gradually loose capacity from being undercharged. I don't have a source for the 14.2 volts. I didn't find it on the Odyssey battery website. Anyone know where the correct charging voltage is documented? Regards, Jim Ayers href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Fuel Flow Sensor
Date: Oct 15, 2007
Hello, I am trying to find a suitable location for my fuel flow sensor between the fuel pump and the Bendix injector (between the injector and flow divider is out of the question) on my Lycoming AEIO-540, At the moment the simplest location has the sensor longitudinally angled downward at about 40 deg angle (the outlet being lower than the inlet). This location also ensures a straight line prior to the inlet. I've read on previous post that it is better to have the sensor level, how critical is this? Thanks Vic Read this topic online here: http://forums.matronics.com/viewtopic.php?p=140177#140177 ________________________________________________________________________________
Subject: PC-680 Follow-up
Date: Oct 15, 2007
After Saturday's marginal starting performance, I thought it was worth getting quantifiable measurements on the battery and charging system, so today I checked the battery and it showed 12.6v. The aircraft had sat for 2 days since its last flight. Then, I went flying. The engine's starting performance was *much* better than on Saturday. I checked the charging system's performance several times on the ground and in the air, and the system voltage was always 14.2 - 14.5 v. After I landed, I let the aircraft sit for long enough to roll it back in the hangar, and checked it with the meter again. The reading was 12.8v. So, the question is: Was Saturday's reluctant start a freak event caused by unknown reasons? Or should I expect to see more than 12.6 - 12.8v on a "charged" battery? I know that 14.3-14.5v output from the alternator is within the appropriate range. Thanks in advance. KB ________________________________________________________________________________
Date: Oct 16, 2007
Subject: Re: PC-680 Follow-up
13.2 Volts is considered a full charge on a standard lead-acid battery. Also, on standard lead-acid batteries, heat can affect their performance. Most people think a battery is most likely to "act up" when it's very cold outside. They also "act up" when they are hot (like in places like Georgia)....No idea what makeup the PC-680s are... http://www.engineersedge.com/battery/discharge_rate_temperature_effects_battery.htm Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Kyle Boatright wrote: > After Saturday's marginal starting performance, I thought it was worth > getting quantifiable measurements on the battery and charging system, > so today I checked the battery and it showed 12.6v. The aircraft had > sat for 2 days since its last flight. > > Then, I went flying. The engine's starting performance was *much* > better than on Saturday. > > I checked the charging system's performance several times on the > ground and in the air, and the system voltage was always 14.2 - 14.5 v. > > After I landed, I let the aircraft sit for long enough to roll it back > in the hangar, and checked it with the meter again. The reading was 12.8v. > > So, the question is: > > Was Saturday's reluctant start a freak event caused by unknown > reasons? Or should I expect to see more than 12.6 - 12.8v on a > "charged" battery? I know that 14.3-14.5v output from the alternator > is within the appropriate range. > > Thanks in advance. > > KB > > ________________________________________________________________________________
Date: Oct 16, 2007
Date: Oct 15, 2007
On 18:02 2007-10-15 Scott wrote: > 13.2 Volts is considered a full charge on a standard lead-acid > battery. This is true, but keep in mind that 13.2 is at zero load. If you are reading the voltage by turning on your electrical system and reading the number off your volt meter, I wouldn't be surprised if there is enough in your system to draw the voltage down somewhat. 12.6 seems pretty much in the ballpark. -Rob ________________________________________________________________________________
Date: Oct 16, 2007
Oh, absolutely...I forgot to mention that was at no load. 12.6V with some load on it seems reasonable to me (that's what I usually see on my battery I use when I take my ham radio gear portable "in the field")...We have a handheld load tester at work...looks like something that would be bought at an auto parts store. I assume it is a high wattage resistor that puts a load on the battery and you keep it on for a certain period of time and watch the meter on it. If it stays in the green area, the battery is "good"... Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Rob Prior wrote: > >On 18:02 2007-10-15 Scott wrote: > > >>13.2 Volts is considered a full charge on a standard lead-acid >>battery. >> >> > >This is true, but keep in mind that 13.2 is at zero load. If you are >reading the voltage by turning on your electrical system and reading the >number off your volt meter, I wouldn't be surprised if there is enough in >your system to draw the voltage down somewhat. 12.6 seems pretty much in >the ballpark. > >-Rob > > > > ________________________________________________________________________________
Date: Oct 16, 2007
----- Original Message ----- From: "Rob Prior" <rv7(at)b4.ca> Sent: Tuesday, October 16, 2007 1:36 AM Subject: Re: RV-List: PC-680 Follow-up > > On 18:02 2007-10-15 Scott wrote: >> 13.2 Volts is considered a full charge on a standard lead-acid >> battery. > > This is true, but keep in mind that 13.2 is at zero load. If you are > reading the voltage by turning on your electrical system and reading the > number off your volt meter, I wouldn't be surprised if there is enough in > your system to draw the voltage down somewhat. 12.6 seems pretty much in > the ballpark. > > -Rob I saw between 12.6 and 12.8 at zero load. (Measured at the "always hot" aux power plug). With the system charging at 14.2+ volts, what does this tell me? KB ________________________________________________________________________________
Date: Oct 16, 2007
Subject: Re: Fuel Flow Sensor
Don Rivera at Air Flow Performance recommends placing the sensor between the fuel servo and the flow divider. In most cases this would mount the sensor vertically. I questioned him about this and he said, he tested it and it really makes no difference. I like the idea, because it seems to be the easiest solution. But, at this time, I do not have a need for a fuel flow data so I have not installed one. Bob RV6 "Wicked Witch of the West" At 07:15 PM 10/15/07, you wrote: > >Hello, > >I am trying to find a suitable location for my fuel flow sensor >between the fuel pump and the Bendix injector (between the injector >and flow divider is out of the question) on my Lycoming AEIO-540, At >the moment the simplest location has the sensor longitudinally >angled downward at about 40 deg angle (the outlet being lower than >the inlet). This location also ensures a straight line prior to the >inlet. I've read on previous post that it is better to have the >sensor level, how critical is this? > >Thanks >Vic > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=140177#140177 > > ________________________________________________________________________________
Date: Oct 16, 2007
Quoting Bobby Hester : > You need to join this group. There are alot of RV's around you. > http://groups.yahoo.com/group/OhioValleyRVators/ Thanks to you and Dana for the pointer; I'll check them out! -- Dan Brown, KE6MKS, dan(at)familybrown.org "Since all the world is but a story, it were well for thee to buy the more enduring story rather than the story that is less enduring." -- The Judgment of St. Colum Cille ________________________________________________________________________________
Date: Oct 16, 2007
My flow sensor is mounted vertically as described below and is functioning perfectly. YMMV, Randy Lervold www.rv-3.com ----- Original Message ----- From: "Bob" <panamared5(at)brier.net> Sent: Tuesday, October 16, 2007 8:45 AM Subject: Re: RV-List: Fuel Flow Sensor > > Don Rivera at Air Flow Performance recommends placing the sensor between > the fuel servo and the flow divider. In most cases this would mount the > sensor vertically. I questioned him about this and he said, he tested it > and it really makes no difference. > > I like the idea, because it seems to be the easiest solution. But, at > this time, I do not have a need for a fuel flow data so I have not > installed one. > > Bob > RV6 > "Wicked Witch of the West" > > > At 07:15 PM 10/15/07, you wrote: >> >>Hello, >> >>I am trying to find a suitable location for my fuel flow sensor between >>the fuel pump and the Bendix injector (between the injector and flow >>divider is out of the question) on my Lycoming AEIO-540, At the moment the >>simplest location has the sensor longitudinally angled downward at about >>40 deg angle (the outlet being lower than the inlet). This location also >>ensures a straight line prior to the inlet. I've read on previous post >>that it is better to have the sensor level, how critical is this? >> >>Thanks >>Vic >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=140177#140177 >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 16, 2007
Hey Vic, I put mine inside the firewall downstream of the electric fuel pump. Works fine, I think the directions were written by a lawyer, say that it need to be between the mech fuel pump and the divider. As I have to of the same se nsors on my boat installed prior to the mech fuel pump drawing more gph for the last ten years without a problem, I think this location will be suitab le on our planes as well. Paul Rice N64PR RV8 > Subject: RV-List: Fuel Flow Sensor > From: vicster(at)netvigator.com > Date: Mon, 15 Oct 2007 17:15:45 -0700 > To: rv-list(at)matronics.com > > > Hello, > > I am trying to find a suitable location for my fuel flow sensor between t he fuel pump and the Bendix injector (between the injector and flow divider is out of the question) on my Lycoming AEIO-540, At the moment the simples t location has the sensor longitudinally angled downward at about 40 deg an gle (the outlet being lower than the inlet). This location also ensures a s traight line prior to the inlet. I've read on previous post that it is bett er to have the sensor level, how critical is this? > > Thanks > Vic > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=140177#140177 > > > > > > > =========== =========== =========== > > > ________________________________________________________________________________
Date: Oct 16, 2007
Subject: Intersection Fairings
I'm doing the intersection fairings and those who have "9-A" airframes, how did you attach the upper intxn fairing to the fuselage? The lower is glassed to the speed pants but the top one? Jim Nelson N15JN 95% done 30% to go-- ________________________________________________________________________________
Subject: Re: Intersection Fairings
Date: Oct 16, 2007
Three choices, nutplates cabin floor and intersection failing, rivet- nuts or sheetmetal screws Danny Sent from cell On Oct 16, 2007, at 1:08 PM, James H Nelson wrote: > > I'm doing the intersection fairings and those who have "9-A" > airframes, > how did you attach the upper intxn fairing to the fuselage? The > lower is > glassed to the speed pants but the top one? > > Jim Nelson > N15JN 95% done 30% to go-- > > ________________________________________________________________________________
Date: Oct 17, 2007
Subject: Unfourtunately it's time to sell my RV6 and this time I mean
it. Health issues have restricted use of my "6" and finally have made it almost impossible to continue flying. It was completed in 2001 has 260 hr. TT with 190 SMOH on the 0360A3M with Electroair Ignition,new slick mag and a just overhauled Whirlwind 151 3 blade prop, Wolf air/oil separator Chrome Valve covers and intake tubes, Annual with sale, and will assit with annuals as needed. CUSTOM FEATURES includes:--Center fuel tank(12.5 gal). All carbon fiber tilt canopy structure with special locking access door and Kruger sun shade. Removable extended engine air intake. Carbon fiber extended vertical fin. Bonded on composite gear leg and intersection Fairing. Special ventilation and heater system with dual muffs, boots on all push rods including flaps and a custom air extractor, means you will be warm or cool, you decide. 3 density Temperfoam seats with lambs wool covering, Single Link tailwheel steering,Carbon fiber elevator intersection fairing, Vortex Generators, Baggage cover, heavy duty canopy cover, Special floor and cockpit insulation, and more. ELECTRICAL:--B&C 40 amp alt and adjustable reg, 2 new B&C 12 Amp/Hr 400 CCA sealed bats with either or both switching. Over voltage protection, Port on panel for alternator diagnostics, battery charging port. Electric flaps, electric elevator and aileron trim, stabs, dual landing lights with wig wag setting and more. PANEL:--MicroAir transponder and dual MicroAir radios, intercom with built in noise canceling headsets(2) Rocky Mnt Uencoder & Umonitor for engine, ECI CHT/EGT analiser, ECI dual Fuel gauge, Bendix King color GPS, True Track auto pilot, AOA with voice warning, Dynon D10A Efis just factory upgraded, left side throttle/mixtue/prop, controls, G meter, Parking brake, Electonic ignition advance gauge, Sony FM/CD player, Glove box, Wood grain accents, and more. It has always been hangered in dry climate area(last four years Paso Robles). The only thing she needs is a paint job, It has been primered since I first started flying. This is my baby and I'm going to miss her, hoping to find her a good home. I'm asking $69,900 or best offer 805-438-3451 garry(at)versadek.com Garry "Casper" LeGare ________________________________________________________________________________
Subject: Upgrade for Garmin 296 Color GPS
Date: Oct 18, 2007
Members, This message is to advise all of you who are using the Garmin Color 296 GPS and having trouble reading the screen because it is not light enough to compete with the sun. I have one of these units and trying to read it in bright sun light under a bubble or tear drop canopy is almost impossible. I just got off the phone with Garmin Electronics and there is a modification available for the 296 for a fee of $50.00. They will modify the unit to match the newer GPS units in light intensity so that they are more easily read. For those of you who are interested, here is the address to send your unit to for this modification. Garmin International 1200 East 151 Street Door 1, Olathe, Kansas, 66062 Bob Stone Harker Heights, Tx ZodiacXL w/Jabiru 3300 ________________________________________________________________________________
Date: Oct 18, 2007
Subject: Re: Upgrade for Garmin 296 Color GPS
Bob this sound very interesting. Please give us a report back as soon as you get yours back and let us know if it really is better. My Dynon and AF 2500 engine monitor are both alot easier to read. Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm robert stone wrote: > Members, > This message is to advise all of you who are using the Garmin > Color 296 GPS and having trouble reading the screen because it is not > light enough to compete with the sun. I have one of these units and > trying to read it in bright sun light under a bubble or tear drop > canopy is almost impossible. I just got off the phone with Garmin > Electronics and there is a modification available for the 296 for a > fee of $50.00. They will modify the unit to match the newer GPS units > in light intensity so that they are more easily read. For those of > you who are interested, here is the address to send your unit to for > this modification. > Garmin International > 1200 East 151 Street > Door 1, > Olathe, Kansas, 66062 > > Bob Stone > Harker Heights, Tx > ZodiacXL w/Jabiru 3300 > * > > > * ________________________________________________________________________________
Subject: Re: Altimeter error
Date: Oct 19, 2007
Thanks to all who offered advice regarding my faulty altimeter. I took it to a professional and he found that the subscale mechanism was loose. He was able to reset the subscale and reassemble the altimeter and it then checked out fine up to 40000ft. We will see how long it holds up - if it fails again then it gets consigned to the bin Shirley Read this topic online here: http://forums.matronics.com/viewtopic.php?p=140729#140729 ________________________________________________________________________________
Date: Oct 19, 2007
Bob, I assume you are sending your unit in and would you pls post re how much better the unit is when you get it back? As for mine, if I turn it so sun shibnes direcly on it, it is more easily seen, seems when adj to easily read angle, reflections from inside make it dificult to read. BTW, wonder if anyone has tried the magnifyer that is advertized for these units?? Charlie Heathco ________________________________________________________________________________
Subject: Re: TDY to Boston
Date: Oct 19, 2007
From: "George, Neal E Capt MIL USAF 605TES/TSI" <Neal.George(at)hurlburt.af.mil>
Folks - Thanks for all the suggestions, and my apologies for not responding sooner. I have jumped thru all the necessary hoops to get a HAF number, so I can land at any AF installation. But that's not always the best answer. Most don't have AvGas (Hanscom does, because they have an AeroClub), and it's still a fair amount of hassle to land and even more aggravation to launch from an Air Force Base, even with the clearance. I was hoping for a quiet little field with a few RVers to meet. But the Fates conspired against us and we wound up on the commercial cattle car. Probably a good thing, as we'd still be stuck looking for a hole in the storms that have soaked the PanHandle for the last few days. We'll try again in a few weeks :-) Neal ============= Hi Neal. I assume that if your business is at Hanscom, you can just land at Hanscom, can't you? It's not exclusively an AFB; it's a regional airport, too. (I think Goulian flies out of there, doesn't he?) Besides, you're in the military so I doubt it'd be an issue anyway. I assume that some RV builder there would be more than happy to have you stay at their house. Anyone? -------- Bob Collins St. Paul, Minn. Letters from Flyover Country http://rvnewsletter.blogspot.com/ ________________________________________________________________________________
Date: Oct 19, 2007
Sir, Your direct email bounced..... Can you provide me with the hoops..... I have a RV6A that I will be finishing this fall and would like to fly in to Hanscom (one of the controllers there is my sister's 'SigOther') along with a few other military installations that I have been stationed. I'm also a retired Marine Master Gunnery Sergeant (E9). Thanks, Ralph E. Capen MGySgt USMC retired RV6AQB Slider N822AR @ N06 - forever finishing -----Original Message----- >From: "George, Neal E Capt MIL USAF 605TES/TSI" <Neal.George(at)hurlburt.af.mil> >Sent: Oct 19, 2007 12:21 PM >To: rv-list(at)matronics.com >Subject: RE: RV-List: Re: TDY to Boston > > >Folks - > >Thanks for all the suggestions, and my apologies for not responding >sooner. I have jumped thru all the necessary hoops to get a HAF number, >so I can land at any AF installation. But that's not always the best >answer. Most don't have AvGas (Hanscom does, because they have an >AeroClub), and it's still a fair amount of hassle to land and even more >aggravation to launch from an Air Force Base, even with the clearance. > >I was hoping for a quiet little field with a few RVers to meet. > >But the Fates conspired against us and we wound up on the commercial >cattle car. Probably a good thing, as we'd still be stuck looking for a >hole in the storms that have soaked the PanHandle for the last few days. > > >We'll try again in a few weeks :-) > >Neal > >============= > >Hi Neal. I assume that if your business is at Hanscom, you can just land >at Hanscom, can't you? It's not exclusively an AFB; it's a regional >airport, too. (I think Goulian flies out of there, doesn't he?) Besides, >you're in the military so I doubt it'd be an issue anyway. > >I assume that some RV builder there would be more than happy to have you >stay at their house. > >Anyone? > >-------- >Bob Collins >St. Paul, Minn. >Letters from Flyover Country >http://rvnewsletter.blogspot.com/ > > ________________________________________________________________________________
Date: Oct 19, 2007
Date: Oct 19, 2007
Hey Ralph - The requirements are remarkably simple - DD Forms 2400, 2401 & 2402 sent to that funny-shaped building in DC. DD 2400 must travel directly from your insurer to HQ AF. The other two you fill out and send. Use blue ink. Retired status helps justify the request, but won't guarantee acceptance. Partnerships and non-owners are considerably more difficult. When I asked for my first HAF number, I enjoyed the use of an airplane that I didn't own - I carried a non-owner's insurance policy in addition to be listed as a named-pilot on the owner's policy. It complicated the insurance forms, but the folks at HQ AF were patient and helpful. More recently, I've partnered on an airplane, and had other (but similar) difficulties. These are the hoops that have given me headaches. Feel free to call if you want to talk it over - 850-218-4838 neal ================ Sir, Your direct email bounced..... Can you provide me with the hoops..... I have a RV6A that I will be finishing this fall and would like to fly in to Hanscom (one of the controllers there is my sister's 'SigOther') along with a few other military installations that I have been stationed. I'm also a retired Marine Master Gunnery Sergeant (E9). Thanks, Ralph E. Capen MGySgt USMC retired RV6AQB Slider N822AR @ N06 - forever finishing ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Oct 20, 2007
It may be OK for some, but the screen was not as bright as the 295 and is not as bright as the 396/496. Look at them side by side one day and it will be apparent. -Mike -----Original Message----- From: "Ed Bundy" <ebundy(at)speedyquick.net> Sent: 10/19/07 10:49 PM Subject: RE: RV-List: Upgrade for Garmin 296 Color GPS I for one was puzzled by the original post, as I've been flying behind a 296 for several years and have never had a problem reading the screen. In fact, I'm always impressed by how bright it is. I would think if anything the older units might not be as bright, but mine was a very early model. Maybe some are different, or maybe some people just perceive them differently. I'd spend some time with the unit first and see if you have a problem before sending it in. Ed Bundy -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of John Jessen Sent: Friday, October 19, 2007 11:42 AM To: rv-list(at)matronics.com Subject: RE: RV-List: Upgrade for Garmin 296 Color GPS ________________________________________________________________________________
Subject: countersink, dimple and nutplates
Date: Oct 21, 2007
Hello, all Pardon the interruption: I am and CH601 (Zenair's Zodiac) builder, and am looking for some information and advice. I want to build an access panel like the ones in the attached picture. countersinking, dimpling and nutplates being rare things in a CH601, I thought I would turn to the community of builders that does this the most. I have done a good deal of research, but I don't feel confident enough to proceed. So, here are my questions & concerns: 1) The CH601 skin is 0.020" thick. I suppose this is too thin for countersinking? Do I dimple instead? 2) If I dimple the skin, I presume I should also dimple the material underneath...? In the case of the nutplate, I presume I should get one with the dimpled lugs? (I saw it in Wicks' on-line catalog: MS21049) 3) I have been unable to relate screw size to dimple set size. How does this work? Any advice and suggestion welcome. Part numbers would be great !!! Thanks much for your time - now back to your regular broadcast. Carlos Sa -------- CH601-HD, plans Montreal, Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=140989#140989 Attachments: http://forums.matronics.com//files/access_panel_412.jpg ________________________________________________________________________________
Date: Oct 21, 2007
Subject: Re: countersink, dimple and nutplates
Carlos, .020 is indeed too thin for countersinking a standard rivet, but you can get away with "oops" rivets (sold by Avery and others) which have much smaller heads and require a much shallower countersink. You wouldn't need to have dimpled nutplates if you use them. They are also known as shear head rivets. I use them a lot for holding nutplates. An alternative to dimpled nutplates is to dimple them yourself. I ground one side of the female die flat so that it clears the central portion of the nutplate to facilitate the process. Are you using flush screws? If so, you will need the countersunk nutplates. You don't have to get the ones with dimpled lugs if you dimple them yourself. Avery and Cleaveland tools have dimple dies for screw holes. Another thing you can do, if you're too cheap to buy the dimple dies, is to make a jig with a C-sunk nutplate riveted to a scrap of aluminum. You would hold this behind the screw hole and run a flush screw into it, using the nutplate as a female die. Be sure to lube the threads of the screw and the metal around the hole and work slowly. As always, practice on scrap first. Have fun with it. Pax, Ed Holyoke Carlos Sa wrote: > >Hello, all > >Pardon the interruption: I am and CH601 (Zenair's Zodiac) builder, and am looking for some information and advice. > >I want to build an access panel like the ones in the attached picture. countersinking, dimpling and nutplates being rare things in a CH601, I thought I would turn to the community of builders that does this the most. > >I have done a good deal of research, but I don't feel confident enough to proceed. So, here are my questions & concerns: > >1) The CH601 skin is 0.020" thick. I suppose this is too thin for countersinking? Do I dimple instead? >2) If I dimple the skin, I presume I should also dimple the material underneath...? In the case of the nutplate, I presume I should get one with the dimpled lugs? (I saw it in Wicks' on-line catalog: MS21049) >3) I have been unable to relate screw size to dimple set size. How does this work? > >Any advice and suggestion welcome. Part numbers would be great !!! > >Thanks much for your time - now back to your regular broadcast. > > >Carlos Sa > >-------- >CH601-HD, plans >Montreal, Canada > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=140989#140989 > > >Attachments: > >http://forums.matronics.com//files/access_panel_412.jpg > > > > ________________________________________________________________________________
Subject: FOR SALE; RV6 WING KIT
Date: Oct 21, 2007
I have an older wing kit, sn 20808, that i would like to sell. It has Phlogiston spars, and is partially built. control surfaces have not been built. This is NOT pre-punched. I live in Kalamazoo, MI. Asking $3,700 Contact; John Veld 269 267-2509 jcveld(at)mac.com ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Date: Oct 22, 2007
Carlos, For #6, #8 flush head screws you need the corresponding dimple die, ie screw heads are different from rivet heads. Avery, Cleveland, ATS, Plane Tools, all carry Screw dimple die sets. So you will need #40 rivet dimple die set for the platenut rivets and the appropriate screw dimple die set. Dimpling the platenuts is easy as Ed pointed out. Use the large size dimpled plate nuts for the screw that you will be using if you can. They are much easier to rivet. Platenut jigs are available at those mentioned companies as well. Pricey but worth it if you are doing a bunch of platenuts. Mike H 9A/8A ----- Original Message ----- From: "Ed" <bicyclop(at)pacbell.net> Sent: Sunday, October 21, 2007 2:03 PM Subject: Re: RV-List: countersink, dimple and nutplates > > Carlos, > > .020 is indeed too thin for countersinking a standard rivet, but you can > get away with "oops" rivets (sold by Avery and others) which have much > smaller heads and require a much shallower countersink. You wouldn't need > to have dimpled nutplates if you use them. They are also known as shear > head rivets. I use them a lot for holding nutplates. > > An alternative to dimpled nutplates is to dimple them yourself. I ground > one side of the female die flat so that it clears the central portion of > the nutplate to facilitate the process. > > Are you using flush screws? If so, you will need the countersunk > nutplates. You don't have to get the ones with dimpled lugs if you dimple > them yourself. Avery and Cleaveland tools have dimple dies for screw > holes. Another thing you can do, if you're too cheap to buy the dimple > dies, is to make a jig with a C-sunk nutplate riveted to a scrap of > aluminum. You would hold this behind the screw hole and run a flush screw > into it, using the nutplate as a female die. Be sure to lube the threads > of the screw and the metal around the hole and work slowly. As always, > practice on scrap first. > > Have fun with it. > > Pax, > > Ed Holyoke > > > Carlos Sa wrote: > >> >>Hello, all >> >>Pardon the interruption: I am and CH601 (Zenair's Zodiac) builder, and am >>looking for some information and advice. >> >>I want to build an access panel like the ones in the attached picture. >>countersinking, dimpling and nutplates being rare things in a CH601, I >>thought I would turn to the community of builders that does this the most. >> >>I have done a good deal of research, but I don't feel confident enough to >>proceed. So, here are my questions & concerns: >> >>1) The CH601 skin is 0.020" thick. I suppose this is too thin for >>countersinking? Do I dimple instead? >>2) If I dimple the skin, I presume I should also dimple the material >>underneath...? In the case of the nutplate, I presume I should get one >>with the dimpled lugs? (I saw it in Wicks' on-line catalog: MS21049) >>3) I have been unable to relate screw size to dimple set size. How does >>this work? >> >>Any advice and suggestion welcome. Part numbers would be great !!! >> >>Thanks much for your time - now back to your regular broadcast. >> >> >>Carlos Sa >> >>-------- >>CH601-HD, plans >>Montreal, Canada >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=140989#140989 >> >> >> >> >>Attachments: >>http://forums.matronics.com//files/access_panel_412.jpg >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 22, 2007
Another idea Carlos would be to see if there is an RV builder in your area. Since your plane doesn't use much of this buying the tools seems rather un-necessary. You might be able to find an RV builder near by who would be willing to help with this small piece and has the tools needed. I see you are in Montreal, Canada. Anyone near there? Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of mike humphrey > Sent: Monday, October 22, 2007 12:40 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: countersink, dimple and nutplates > > > > Carlos, > For #6, #8 flush head screws you need the corresponding dimple die, ie > screw > heads are different from rivet heads. Avery, Cleveland, ATS, Plane Tools, > all carry Screw dimple die sets. So you will need #40 rivet dimple die > set > for the platenut rivets and the appropriate screw dimple die set. > Dimpling > the platenuts is easy as Ed pointed out. Use the large size dimpled plate > nuts for the screw that you will be using if you can. They are much > easier > to rivet. Platenut jigs are available at those mentioned companies as > well. > Pricey but worth it if you are doing a bunch of platenuts. > Mike H 9A/8A > ----- Original Message ----- > From: "Ed" <bicyclop(at)pacbell.net> > To: > Sent: Sunday, October 21, 2007 2:03 PM > Subject: Re: RV-List: countersink, dimple and nutplates > > > > > > Carlos, > > > > .020 is indeed too thin for countersinking a standard rivet, but you can > > get away with "oops" rivets (sold by Avery and others) which have much > > smaller heads and require a much shallower countersink. You wouldn't > need > > to have dimpled nutplates if you use them. They are also known as shear > > head rivets. I use them a lot for holding nutplates. > > > > An alternative to dimpled nutplates is to dimple them yourself. I ground > > one side of the female die flat so that it clears the central portion of > > the nutplate to facilitate the process. > > > > Are you using flush screws? If so, you will need the countersunk > > nutplates. You don't have to get the ones with dimpled lugs if you > dimple > > them yourself. Avery and Cleaveland tools have dimple dies for screw > > holes. Another thing you can do, if you're too cheap to buy the dimple > > dies, is to make a jig with a C-sunk nutplate riveted to a scrap of > > aluminum. You would hold this behind the screw hole and run a flush > screw > > into it, using the nutplate as a female die. Be sure to lube the threads > > of the screw and the metal around the hole and work slowly. As always, > > practice on scrap first. > > > > Have fun with it. > > > > Pax, > > > > Ed Holyoke > > > > > > > > Carlos Sa wrote: > > > >> > >>Hello, all > >> > >>Pardon the interruption: I am and CH601 (Zenair's Zodiac) builder, and > am > >>looking for some information and advice. > >> > >>I want to build an access panel like the ones in the attached picture. > >>countersinking, dimpling and nutplates being rare things in a CH601, I > >>thought I would turn to the community of builders that does this the > most. > >> > >>I have done a good deal of research, but I don't feel confident enough > to > >>proceed. So, here are my questions & concerns: > >> > >>1) The CH601 skin is 0.020" thick. I suppose this is too thin for > >>countersinking? Do I dimple instead? > >>2) If I dimple the skin, I presume I should also dimple the material > >>underneath...? In the case of the nutplate, I presume I should get one > >>with the dimpled lugs? (I saw it in Wicks' on-line catalog: MS21049) > >>3) I have been unable to relate screw size to dimple set size. How does > >>this work? > >> > >>Any advice and suggestion welcome. Part numbers would be great !!! > >> > >>Thanks much for your time - now back to your regular broadcast. > >> > >> > >>Carlos Sa > >> > >>-------- > >>CH601-HD, plans > >>Montreal, Canada > >> > >> > >> > >> > >>Read this topic online here: > >> > >>http://forums.matronics.com/viewtopic.php?p=140989#140989 > >> > >> > >> > >> > >>Attachments: > >>http://forums.matronics.com//files/access_panel_412.jpg > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 22, 2007
Subject: Gear Legs
Hi folks, I'm getting stuff ready to do my first annual condition inspection on my recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago. I was told to put a piece of pipe inside the landing gear strut before removing the nut and jack it up. Does anyone have their gear leg out in the open and could give me a measurement? Mine is all wrapped up in wheel pants and tough to get to right now. I think a 1" pipe is about right but need to know the inside diameter of the gear leg tube. Thanks in advance. Greg ________________________________________________________________________________
Subject: Gear Legs
Date: Oct 22, 2007
Greg, There is an excellent tool from Avery just for this purpose. I use it and love it. You end up drilling a hole in the center of the wheel nut and installing a bracket over it to replace the rivenut for the wheel pants. It is an easy conversion, an inexpensive jack jig, and makes lifting a wheel and removing it quite safe and easy. Check it out here. http://www.averytools.com/p-181-rv-jack-stand.aspx I see they have the already modified axle nuts as well. http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx Here are the brackets for wheel pant connection http://www.averytools.com/p-180-rv-jack-stand-kit-bracket-kit.aspx You can purchase all this as a kit. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Greg Williams Sent: Monday, October 22, 2007 11:57 AM Subject: RV-List: Gear Legs Hi folks, I'm getting stuff ready to do my first annual condition inspection on my recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago. I was told to put a piece of pipe inside the landing gear strut before removing the nut and jack it up. Does anyone have their gear leg out in the open and could give me a measurement? Mine is all wrapped up in wheel pants and tough to get to right now. I think a 1" pipe is about right but need to know the inside diameter of the gear leg tube. Thanks in advance. Greg ________________________________________________________________________________
Subject: Re: Gear Legs
Date: Oct 22, 2007
Tim: I'm having a hard time visualizing how you get the wheel off with the jack attached to the axle??? How does that work? dave On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote: > Greg, > > > There is an excellent tool from Avery just for this purpose. I use > it and love it. You end up drilling a hole in the center of the > wheel nut and installing a bracket over it to replace the rivenut > for the wheel pants. It is an easy conversion, an inexpensive jack > jig, and makes lifting a wheel and removing it quite safe and > easy. Check it out here. > > http://www.averytools.com/p-181-rv-jack-stand.aspx > > > I see they have the already modified axle nuts as well. > > > http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack- > stand.aspx > > > Here are the brackets for wheel pant connection > > http://www.averytools.com/p-180-rv-jack-stand-kit-bracket-kit.aspx > > > You can purchase all this as a kit. > > > Tim > > > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Greg Williams > Sent: Monday, October 22, 2007 11:57 AM > To: rv-list(at)matronics.com > Subject: RV-List: Gear Legs > > > Hi folks, > > I'm getting stuff ready to do my first annual condition inspection > on my recently purchased, completed RV7. (I'm having a GREAT time > flying!!) I want to change tires and was really nervous about > the wing jack when I swapped tires 9 months ago. I was told to put > a piece of pipe inside the landing gear strut before removing the > nut and jack it up. Does anyone have their gear leg out in the > open and could give me a measurement? Mine is all wrapped up in > wheel pants and tough to get to right now. I think a 1" pipe is > about right but need to know the inside diameter of the gear leg tube. > > Thanks in advance. > > Greg > > > http://www.matronics.com/Navigator?RV-List > http://forums.matronics.com > > http://www.matronics.com/Navigator?RV-List_- > ============================================================ _- > forums.matronics.com_- > =========================================================== > ________________________________________________________________________________
Subject: Gear Legs
Date: Oct 22, 2007
Yea, I understand that. What you do is remove the little wheel pant bracket, place the jack inside the axle through the axle nut. After jacking it up you remove the axle nut and slide it onto the jack bracket pipe. You slide the wheel onto the jack bracket pipe as well then you can place a block or jackstand or something under the axle and let it down. This allows you to remove the wheel from the jack bracket to do whatever you need. Reverse to re-install. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Cudney Sent: Monday, October 22, 2007 1:32 PM Subject: Re: RV-List: Gear Legs Tim: I'm having a hard time visualizing how you get the wheel off with the jack attached to the axle??? How does that work? dave On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote: <http://www.averytools.com/p-181-rv-jack-stand.aspx> http://www.averytools.com/p-181-rv-jack-stand.aspx I see they have the already modified axle nuts as well. <http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.asp x> http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx Here are the brackets for wheel pant connection _____ size=2 width="100%" align=center> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Greg Williams Sent: Monday, October 22, 2007 11:57 AM Subject: RV-List: Gear Legs Hi folks, I'm getting stuff ready to do my first annual condition inspection on my recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago. I was told to put a piece of pipe inside the landing gear strut before removing the nut and jack it up. Does anyone have their gear leg out in the open and could give me a measurement? Mine is all wrapped up in wheel pants and tough to get to right now. I think a 1" pipe is about right but need to know the inside diameter of the gear leg tube. Thanks in advance. Greg <http://www.matronics.com/Navigator?RV-List> http://www.matronics.com/Navigator?RV-List <http://forums.matronics.com> http://forums.matronics.com - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> <http://forums.matronics.com> http://forums.matronics.com ________________________________________________________________________________
Date: Oct 22, 2007
Subject: Gear Legs wheel replacement
Dave, What you do is to remove the pant. next, you remove the nut plate adapter from the nut leaving a (I believe a 11/16") hole. You put a pipe, about 12 to 15" long into the hole and put a jack on the end of the pipe. Jack the wheel up and then remove the nut (hopefully you pulled the key and loosened it a bit before you jacked it up) and slide the wheel outward on to the pipe. Once the wheel is removed far enough, you put a stand under the axle and let the jack down. Remove the wheel and pipe and do what ever. I modified my axle nuts to do this in the future. There is not a good way to do tire repair or what ever with the fairings in place. I did not relish lifting the a/c at the wing. Its a cheep mod. A piece of pipe and a small jack with a jack stand is all you need. Jim ________________________________________________________________________________
Subject: Gear Legs tire changing
From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: Oct 22, 2007
Dont all RV's have a platenet on the axel nut to hold the wheel pant bracket? I dont see how a hollow axel nut to take the pipe will work if you have to mount the wheel pant bracket to the axel nut. Mike "Tim Bryan" To Sent by: owner-rv-list-ser cc ver(at)matronics.com Subj ect RE: RV-List: Gear Legs 10/22/2007 01:29 PM Please respond to rv-list@matronics .com Greg, There is an excellent tool from Avery just for this purpose. I use it and love it. You end up drilling a hole in the center of the wheel nut and installing a bracket over it to replace the rivenut for the wheel pants . It is an easy conversion, an inexpensive jack jig, and makes lifting a wheel and removing it quite safe and easy. Check it out here. http://www.averytools.com/p-181-rv-jack-stand.aspx I see they have the already modified axle nuts as well. http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand .aspx Here are the brackets for wheel pant connection http://www.averytools.com/p-180-rv-jack-stand-kit-bracket-kit.aspx You can purchase all this as a kit. Tim From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Greg Williams Sent: Monday, October 22, 2007 11:57 AM Subject: RV-List: Gear Legs Hi folks, I'm getting stuff ready to do my first annual condition inspection on m y recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago. I was told to put a piece of pipe inside t he landing gear strut before removing the nut and jack it up. Does anyone have their gear leg out in the open and could give me a measurement? M ine is all wrapped up in wheel pants and tough to get to right now. I thin k a 1" pipe is about right but need to know the inside diameter of the gear leg tube. Thanks in advance. Greg ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Oct 22, 2007
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Subject: Gear Legs
Hey Greg, I've got a spare Avery jack and modified axle nut set I'll sell to you. They are nice and work very well. Total Price New $75.00, I'll take $50.00 Darrell --- Tim Bryan wrote: > Greg, > > > > There is an excellent tool from Avery just for this > purpose. I use it and > love it. You end up drilling a hole in the center > of the wheel nut and > installing a bracket over it to replace the rivenut > for the wheel pants. It > is an easy conversion, an inexpensive jack jig, and > makes lifting a wheel > and removing it quite safe and easy. Check it out > here. > > http://www.averytools.com/p-181-rv-jack-stand.aspx > > > > I see they have the already modified axle nuts as > well. > > > > http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx > > > > Here are the brackets for wheel pant connection > > http://www.averytools.com/p-180-rv-jack-stand-kit-bracket-kit.aspx > > > > You can purchase all this as a kit. > > > > Tim > > > > _____ > > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On > Behalf Of Greg Williams > Sent: Monday, October 22, 2007 11:57 AM > To: rv-list(at)matronics.com > Subject: RV-List: Gear Legs > > > > Hi folks, > > I'm getting stuff ready to do my first annual > condition inspection on my > recently purchased, completed RV7. (I'm having a > GREAT time flying!!) I > want to change tires and was really nervous about > the wing jack when I > swapped tires 9 months ago. I was told to put a > piece of pipe inside the > landing gear strut before removing the nut and jack > it up. Does anyone have > their gear leg out in the open and could give me a > measurement? Mine is all > wrapped up in wheel pants and tough to get to right > now. I think a 1" pipe > is about right but need to know the inside diameter > of the gear leg tube. > > Thanks in advance. > > Greg > > > > > __________________________________________________ ________________________________________________________________________________
Date: Oct 22, 2007
Mike, Check out the last link in my message below. It has a picture of the little bracket that goes over the hole in the axle nut. This little bracket has the platenut on it for the wheel pant. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael W Stewart Sent: Monday, October 22, 2007 2:22 PM Subject: RE: RV-List: Gear Legs tire changing Dont all RV's have a platenet on the axel nut to hold the wheel pant bracket? I dont see how a hollow axel nut to take the pipe will work if you have to mount the wheel pant bracket to the axel nut. Mike Inactive hide details for "Tim Bryan" "Tim Bryan" "Tim Bryan" Sent by: owner-rv-list-server(at)matronics.com 10/22/2007 01:29 PM Please respond to rv-list(at)matronics.com To cc Subject RE: RV-List: Gear Legs Greg, There is an excellent tool from Avery just for this purpose. I use it and love it. You end up drilling a hole in the center of the wheel nut and installing a bracket over it to replace the rivenut for the wheel pants. It is an easy conversion, an inexpensive jack jig, and makes lifting a wheel and removing it quite safe and easy. Check it out here. <http://www.averytools.com/p-181-rv-jack-stand.aspx> http://www.averytools.com/p-181-rv-jack-stand.aspx I see they have the already modified axle nuts as well. <http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.asp x> http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx Here are the brackets for wheel pant connection <http://www.averytools.com/p-180-rv-jack-stand-kit-bracket-kit.aspx> http://www.averytools.com/p-180-rv-jack-stand-kit-bracket-kit.aspx You can purchase all this as a kit. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Greg Williams Sent: Monday, October 22, 2007 11:57 AM Subject: RV-List: Gear Legs Hi folks, I'm getting stuff ready to do my first annual condition inspection on my recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago. I was told to put a piece of pipe inside the landing gear strut before removing the nut and jack it up. Does anyone have their gear leg out in the open and could give me a measurement? Mine is all wrapped up in wheel pants and tough to get to right now. I think a 1" pipe is about right but need to know the inside diameter of the gear leg tube. Thanks in advance. Greg ==================================== ?RV-List">http://www.matronics.com/Navigator?RV-List ==================================== u>http://forums.matronics.com ==================================== ________________________________________________________________________________
Date: Oct 22, 2007
The problem I had with this method was the height of the pipe to the floor. I didn't have a jack that would get under it. Even my floor jack was too low so I went with the avery system. Both use the same principle however and it works great. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of James H Nelson > Sent: Monday, October 22, 2007 2:11 PM > To: rv-list(at)matronics.com > Subject: RV-List: Gear Legs wheel replacement > > > Dave, > What you do is to remove the pant. next, you remove the nut plate > adapter from the nut leaving a (I believe a 11/16") hole. You put a > pipe, about 12 to 15" long into the hole and put a jack on the end of the > pipe. Jack the wheel up and then remove the nut (hopefully you pulled > the key and loosened it a bit before you jacked it up) and slide the > wheel outward on to the pipe. Once the wheel is removed far enough, you > put a stand under the axle and let the jack down. Remove the wheel and > pipe and do what ever. > I modified my axle nuts to do this in the future. There is not a > good way to do tire repair or what ever with the fairings in place. I > did not relish lifting the a/c at the wing. Its a cheep mod. A piece of > pipe and a small jack with a jack stand is all you need. > > Jim > > > ________________________________________________________________________________
Subject: Re: Gear Legs wheel replacement
Date: Oct 22, 2007
Dave, I got this somewhere. Whoever came up with it should realy get the credit but I don't know who that is. It seemed simple enough to duplicate that's what I planed to do. John D. ________________________________________________________________________________
Date: Oct 22, 2007
Brown tools or Avery sells it. I just saw it. Mike H ----- Original Message ----- From: "John D. Heath" <altoq(at)cebridge.net> Sent: Monday, October 22, 2007 4:22 PM Subject: Re: RV-List: Gear Legs wheel replacement > Dave, > > I got this somewhere. Whoever came up with it should realy get the credit > but I don't know who that is. It seemed simple enough to duplicate that's > what I planed to do. > > John D. > ________________________________________________________________________________
Date: Oct 22, 2007
On Oct 22, 2007, at 11:45 AM, Tim Bryan wrote: > Yea, I understand that. What you do is remove the little wheel > pant bracket, place the jack inside the axle through the axle > nut. After jacking it up you remove the axle nut and slide it > onto the jack bracket pipe. You slide the wheel onto the jack > bracket pipe as well then you can place a block or jackstand or > something under the axle and let it down. This allows you to > remove the wheel from the jack bracket to do whatever you need. > > > Reverse to re-install. > > > Tim Thanks that makes sense. dave > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Dave Cudney > Sent: Monday, October 22, 2007 1:32 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Gear Legs > > > Tim: > > > I'm having a hard time visualizing how you get the wheel off with > the jack attached to the axle??? How does that work? > > > dave > > > On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote: > > > http://www.averytools.com/p-181-rv-jack-stand.aspx > > I see they have the already modified axle nuts as well. > > http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack- > stand.aspx > > Here are the brackets for wheel pant connection > > size=2 width="100%" align=center> > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Greg Williams > Sent: Monday, October 22, 2007 11:57 AM > To: rv-list(at)matronics.com > Subject: RV-List: Gear Legs > > Hi folks, > > I'm getting stuff ready to do my first annual condition inspection > on my recently purchased, completed RV7. (I'm having a GREAT time > flying!!) I want to change tires and was really nervous about the > wing jack when I swapped tires 9 months ago. I was told to put a > piece of pipe inside the landing gear strut before removing the nut > and jack it up. Does anyone have their gear leg out in the open and > could give me a measurement? Mine is all wrapped up in wheel pants > and tough to get to right now. I think a 1" pipe is about right but > need to know the inside diameter of the gear leg tube. > > Thanks in advance. > > Greg > > > http://www.matronics.com/Navigator?RV-List > http://forums.matronics.com > > - NEW MATRONICS WEB FORUMS - class="Apple-converted- > space"> --> http://forums.matronics.com > > http://www.matronics.com/Navigator?RV-List > http://forums.matronics.com > > http://www.matronics.com/Navigator?RV-List_- > ============================================================ _- > forums.matronics.com_- > =========================================================== > ________________________________________________________________________________
Date: Oct 22, 2007
From: "Greg Williams" <mr.gsun+rv-list(at)gmail.com>
Hey Folks, Thanks for all the replies. I'm looking for the right size pipe to use. My thought is to weld a 16" piece of pipe to this old scissor jack that I already have. It came out of some import car and is in good shape. It will go low enough to slide the pipe in after the wheel pant and little bracket are removed. That way it is always in my hangar ready for use. I wouldn't ever worry about the pipe falling off the jack either. If a piece of 3/4" sch 40 water pipe (7/8" OD) will work, I'll grind off the galvanizing, weld it to the jack & slap some paint on it. If I can get something bigger in there, that's better. Anyone know or can easily measure the ID of that gear leg axle for me? Greg On 10/22/07, Dave Cudney wrote: > > > On Oct 22, 2007, at 11:45 AM, Tim Bryan wrote: > > Yea, I understand that. What you do is remove the little wheel pant > bracket, place the jack inside the axle through the axle nut. After > jacking it up you remove the axle nut and slide it onto the jack bracket > pipe. You slide the wheel onto the jack bracket pipe as well then you can > place a block or jackstand or something under the axle and let it down. > This allows you to remove the wheel from the jack bracket to do whatever you > need. > > > Reverse to re-install. > > > Tim > > > Thanks that makes sense. > > dave > > ------------------------------ > > *From:* owner-rv-list-server(at)matronics.com [ > mailto:owner-rv-list-server(at)matronics.com] > *On Behalf Of *Dave Cudney > *Sent:* Monday, October 22, 2007 1:32 PM > *To:* rv-list(at)matronics.com > *Subject:* Re: RV-List: Gear Legs > > > Tim: > > > I'm having a hard time visualizing how you get the wheel off with the jack > attached to the axle??? How does that work? > > > dave > > > On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote: > > > http://www.averytools.com/p-181-rv-jack-stand.aspx > > I see they have the already modified axle nuts as well. > > > http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx > > Here are the brackets for wheel pant connection > size=2 width="100%" align=center> > > *From:* owner-rv-list-server(at)matronics.com [ > mailto:owner-rv-list-server(at)matronics.com] > *On Behalf Of *Greg Williams > *Sent:* Monday, October 22, 2007 11:57 AM > *To:* rv-list(at)matronics.com > *Subject:* RV-List: Gear Legs > > Hi folks, > > I'm getting stuff ready to do my first annual condition inspection on my > recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want > to change tires and was really nervous about the wing jack when I swapped > tires 9 months ago. I was told to put a piece of pipe inside the landing > gear strut before removing the nut and jack it up. Does anyone have their > gear leg out in the open and could give me a measurement? Mine is all > wrapped up in wheel pants and tough to get to right now. I think a 1" pipe > is about right but need to know the inside diameter of the gear leg tube. > > Thanks in advance. > > Greg > > * * > > * * > > *http://www.matronics.com/Navigator?RV-List* > > *http://forums.matronics.com* > > * * > > * ** - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> http://forums.matronics.com* > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV-List* > > ** > > ** > > ** > > *http://forums.matronics.com* > > ** > > * * > > * - The RV-List Email Forum - class="Apple-converted-space"> * > > --> http://www.matronics.com/Navigator?RV-List - NEW > MATRONICS WEB FORUMS - class="Apple-converted-space"> --> > http://forums.matronics.com > > > * > > > * > > ________________________________________________________________________________
Subject: Gear Legs
Date: Oct 22, 2007
Hi Greg, The hole in my axle nut based on the modification is 1=94 diameter. The shaft from the avery tool is =BE=94 diameter. I don=92t have an axle nut off right now so not sure of the size hole into it. Hope that helps. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Greg Williams Sent: Monday, October 22, 2007 4:59 PM Subject: Re: RV-List: Gear Legs Hey Folks, Thanks for all the replies. I'm looking for the right size pipe to use. My thought is to weld a 16" piece of pipe to this old scissor jack that I already have. It came out of some import car and is in good shape. It will go low enough to slide the pipe in after the wheel pant and little bracket are removed. That way it is always in my hangar ready for use. I wouldn't ever worry about the pipe falling off the jack either. If a piece of 3/4" sch 40 water pipe (7/8" OD) will work, I'll grind off the galvanizing, weld it to the jack & slap some paint on it. If I can get something bigger in there, that's better. Anyone know or can easily measure the ID of that gear leg axle for me? Greg On 10/22/07, Dave Cudney < yenduc(at)sbcglobal.net> wrote: On Oct 22, 2007, at 11:45 AM, Tim Bryan wrote: Yea, I understand that. What you do is remove the little wheel pant bracket, place the jack inside the axle through the axle nut. After jacking it up you remove the axle nut and slide it onto the jack bracket pipe. You slide the wheel onto the jack bracket pipe as well then you can place a block or jackstand or something under the axle and let it down. This allows you to remove the wheel from the jack bracket to do whatever you need. Reverse to re-install. Tim Thanks that makes sense. dave _____ From: owner-rv-list-server(at)matronics.com [ mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Cudney Sent: Monday, October 22, 2007 1:32 PM Subject: Re: RV-List: Gear Legs Tim: I'm having a hard time visualizing how you get the wheel off with the jack attached to the axle??? How does that work? dave On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote: <http://www.averytools.com/p-181-rv-jack-stand.aspx> http://www.averytools.com/p-181-rv-jack-stand.aspx I see they have the already modified axle nuts as well. <http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand. asp x> http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.a spx Here are the brackets for wheel pant connection size=2 width="100%" align=center> From: owner-rv-list-server(at)matronics.com [ mailto:owner-rv-list-server(at)matronics.com ] On Behalf Of Greg Williams Sent: Monday, October 22, 2007 11:57 AM Subject: RV-List: Gear Legs Hi folks, I'm getting stuff ready to do my first annual condition inspection on my recently purchased, completed RV7. (I'm having a GREAT time flying!!) I want to change tires and was really nervous about the wing jack when I swapped tires 9 months ago. I was told to put a piece of pipe inside the landing gear strut before removing the nut and jack it up. Does anyone have their gear leg out in the open and could give me a measurement? Mine is all wrapped up in wheel pants and tough to get to right now. I think a 1" pipe is about right but need to know the inside diameter of the gear leg tube. Thanks in advance. Greg <http://www.matronics.com/Navigator?RV-List> <http://www.matronics.com/Navigator?RV-List> http://www.matronics.com/Navigator?RV-List <http://forums.matronics.com> <http://forums.matronics.com> http://forums.matronics.com - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> <http://forums.matronics.com> http://forums.matronics.com <http://www.matronics.com/Navigator?RV-List> http://www.matronics.com/Navigator?RV-List <http://forums.matronics.com> http://forums.matronics.com - The RV-List Email Forum - class="Apple-converted-space"> --> <http://www.matronics.com/Navigator?RV-List> http://www.matronics.com/Navigator?RV-List - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> --> <http://forums.matronics.com> http://forums.matronics.com http://www.matronics.com/Navigator?RV-List http://forums.matronics.com ________________________________________________________________________________
Date: Oct 23, 2007
Axle ID on my -6 gear legs is 7/8". Doug Gray > Anyone know or can easily measure the ID of that gear leg axle for me? > ________________________________________________________________________________
Subject: RV8 Wheel Axles
Date: Oct 22, 2007
If anyone can help. I need someone that has the invoice of a finishing kit to look up the proper nomenclature of the wheel axles and their price. I ne ed this item omitted from the finishing kit and they have deducted $27.19. I can't find the invoice that was sent with them for the life of me and nee d to make this correction before the kit can be shipped. TIA to anyone that can help, Bruce Gray RV8 Fuse Wiring and panel work _________________________________________________________________ Peek-a-boo FREE Tricks & Treats for You! http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us ________________________________________________________________________________
Subject: Water/Moisture in Static System
Date: Oct 22, 2007
RV List, The glass on my airspeed indicator is fogged up with moisture. I have removed the static line from the back of the instrument and found droplets of water in the line. I'm looking for suggestions on how to dry out the airspeed indicator and removal of water from the system. I have used compressed air to purge out the water droplets through the static lines and put a small wattage heat lamp under the airspeed instrument with no success. I am also concerned this moisture will migrate to my Dynon D10A. I first noticed the moisture two days after flying through a small rain shower. I have 630 hours on my RV-6 and have flown it through rain showers before, this is the first time I have ever had an issue with moisture/water in the system. I do not have the Cessna style static water sump collection bottle sold by ACS installed in the static system and am considering installing one. Thanks in advance for your help and suggestions. Larry Mersek N336RV ________________________________________________________________________________
Date: Oct 23, 2007
Hi Larry, I installed that bottle and it solved my problem, which was similar to yours. I put it at the low point in the back, behind the baggage compartment, extended the static line all the way to the bottom of fuselage. The line going from the bottle to the instruments is punched in to protrude an inch inside making it easy to keep any drops from moving forward. Putting that end of the bottle upward would do the same thing, but my connecter broke on that end of the bottle so I turned it into an opportunity. Bottle nipples are fragile. Since I live in South Florida with lots of humidity I also installed two 60 watt light bulbs (wired in series to reduce effective voltage per bulb) under the radio stack and plug them in to wall outlet in the hanger. This keeps the moisture out of my radios, the series wiring reduces the excessive heat a bulb would normally have in this confined area. Prior to this I was getting problems with my transponder after a humid week. No problems since. Dale RV6a 935 hrs, Lyc 0-360 A1A, Hartzell Youtube videos channel name: "lionheart33026" _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Mersek Sent: Monday, October 22, 2007 11:45 PM Subject: RV-List: Water/Moisture in Static System RV List, The glass on my airspeed indicator is fogged up with moisture. I have removed the static line from the back of the instrument and found droplets of water in the line. I'm looking for suggestions on how to dry out the airspeed indicator and removal of water from the system. I have used compressed air to purge out the water droplets through the static lines and put a small wattage heat lamp under the airspeed instrument with no success. I am also concerned this moisture will migrate to my Dynon D10A. I first noticed the moisture two days after flying through a small rain shower. I have 630 hours on my RV-6 and have flown it through rain showers before, this is the first time I have ever had an issue with moisture/water in the system. I do not have the Cessna style static water sump collection bottle sold by ACS installed in the static system and am considering installing one. Thanks in advance for your help and suggestions. Larry Mersek N336RV ________________________________________________________________________________
Date: Oct 23, 2007
Yes, Works as advertised. I got one of these a week ago and was able to easi ly change a tire with no swapping of jacks, blocks and so forth. While its an expensive little bugger, im hoping between my use and loan ing out to buddies, it will pay for itself. No reason why it would not work on all kinds of planes too. The pipe in the axle method requires a hollow axle. This gismo does not. Link to site here that sells the "handy Jack". Site d/l time is ridicul es for some reason. http://aviationtechproducts.com/html/products_pics.html#RVJACK Best, Mike "John D. Heath" To Sent by: owner-rv-list-ser cc ver(at)matronics.com Subj ect Re: RV-List: Gear Legs wheel 10/22/2007 04:22 replacement PM Please respond to rv-list@matronics .com Dave, I got this somewhere. Whoever came up with it should realy get the cr edit but I don't know who that is. It seemed simple enough to duplicate that 's what I planed to do. John D. [attachment "jack00215go6.jpg" deleted by Michael W Stewart/Atlanta/IBM ] [attachment "img_1270.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1271.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1272.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1273.jpg" deleted by Michael W Stewart/Atlanta/IBM] ________________________________________________________________________________
Date: Oct 23, 2007
Subject: Re: Water/Moisture in Static System
Larry Mersek wrote: > RV List, > > The glass on my airspeed indicator is fogged up with moisture. I have > removed the static line from the back of the instrument and found > droplets of water in the line. I'm looking for suggestions on how to > dry out the airspeed indicator and removal of water from the system. I > have used compressed air to purge out the water droplets through the > static lines and put a small wattage heat lamp under the airspeed > instrument with no success. I am also concerned this moisture will > migrate to my Dynon D10A. Remove the AS and place it in a box with a 100 watt bulb ..... so that nothing is touching the bulb that will burn. The last is very important. > I first noticed the moisture two days after flying through a small > rain shower. I have 630 hours on my RV-6 and have flown it through > rain showers before, this is the first time I have ever had an issue > with moisture/water in the system. > > I do not have the Cessna style static water sump collection bottle > sold by ACS installed in the static system and am considering > installing one. Probably the best option ..... or make your own. Get a plastic "T" that fits your tubing, and glue it into the top of a pill bottle. They seal pretty well. Be sure to label the pill bottle "EXPERIMENTAL" and mount it where it's easily accessible with a 'low spot' at the pill bottle. ;-) Linn > > > Thanks in advance for your help and suggestions. > > Larry Mersek > N336RV > > ________________________________________________________________________________
Date: Oct 23, 2007
I sense a reluctance by some to use a wing jack. I have been using a wing jack on my 6A since day one. Is there a problem with wing jacks on RVs that I may not be aware of. Dale Ensing ----- Original Message ----- From: Michael W Stewart To: rv-list(at)matronics.com Sent: Tuesday, October 23, 2007 9:06 AM Subject: Re: RV-List: Gear Legs wheel replacement Yes, Works as advertised. I got one of these a week ago and was able to easily change a tire with no swapping of jacks, blocks and so forth. While its an expensive little bugger, im hoping between my use and loaning out to buddies, it will pay for itself. No reason why it would not work on all kinds of planes too. The pipe in the axle method requires a hollow axle. This gismo does not. Link to site here that sells the "handy Jack". Site d/l time is ridicules for some reason. http://aviationtechproducts.com/html/products_pics.html#RVJACK Best, Mike "John D. Heath" "John D. Heath" Sent by: owner-rv-list-server(at)matronics.com 10/22/2007 04:22 PM Please respond to rv-list(at)matronics.com To cc Subject Re: RV-List: Gear Legs wheel replacement Dave, I got this somewhere. Whoever came up with it should realy get the credit but I don't know who that is. It seemed simple enough to duplicate that's what I planed to do. John D. [attachment "jack00215go6.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1270.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1271.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1272.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1273.jpg" deleted by Michael W Stewart/Atlanta/IBM] ________________________________________________________________________________
Subject: Tail Kit for RV6-7
Date: Oct 23, 2007
Folks. If anyone is interested there is a tail kit listed on E-bay. It says RV-6 or 7. Take a look if interested. It's not mine, I just saw it and am passing it on....don http://cgi.ebay.com/ebaymotors/Vans-Aircraft-RV-6-RV-7-RV6-RV7-Airplane-Plane-Tail-Kit_W0QQitemZ230182355463QQihZ013QQcategoryZ26438QQrdZ1QQssPageNameZWD6VQQcmdZViewItem Don Nowakowski , Equipment Engineering Tech Telephone (802)288-3359, "More than anything else the sensation is one of perfect peace mingled with an excitement that strains every nerve to the utmost, if you can conceive of such a combination." -- Wilbur Wright ________________________________________________________________________________
Date: Oct 23, 2007
I have been using a wing jack, but am going to change to the cable/lever type on axel. If sh__ happens it will be less to repair. Accidents are never planned, right? Happy landings, Dale _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dale Ensing Sent: Tuesday, October 23, 2007 9:57 AM Subject: Re: RV-List: Gear Legs wheel replacement I sense a reluctance by some to use a wing jack. I have been using a wing jack on my 6A since day one. Is there a problem with wing jacks on RVs that I may not be aware of. Dale Ensing ----- Original Message ----- From: Michael W <mailto:mike.stewart(at)us.ibm.com> Stewart Sent: Tuesday, October 23, 2007 9:06 AM Subject: Re: RV-List: Gear Legs wheel replacement Yes, Works as advertised. I got one of these a week ago and was able to easily change a tire with no swapping of jacks, blocks and so forth. While its an expensive little bugger, im hoping between my use and loaning out to buddies, it will pay for itself. No reason why it would not work on all kinds of planes too. The pipe in the axle method requires a hollow axle. This gismo does not. Link to site here that sells the "handy Jack". Site d/l time is ridicules for some reason. http://aviationtechproducts.com/html/products_pics.html#RVJACK Best, Mike Inactive hide details for "John D. Heath" "John D. Heath" "John D. Heath" Sent by: owner-rv-list-server(at)matronics.com 10/22/2007 04:22 PM Please respond to rv-list(at)matronics.com To cc Subject Re: RV-List: Gear Legs wheel replacement Dave, I got this somewhere. Whoever came up with it should realy get the credit but I don't know who that is. It seemed simple enough to duplicate that's what I planed to do. John D. [attachment "jack00215go6.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1270.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1271.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1272.jpg" deleted by Michael W Stewart/Atlanta/IBM] [attachment "img_1273.jpg" deleted by Michael W Stewart/Atlanta/IBM] ________________________________________________________________________________
Date: Oct 23, 2007
Harbor Freight sells a 1500lb ATV/Motorcycle lift that will pick up the whole airplane. I am using this on a Grumman Yankee (a.k.a. RV Trainer) and it works great! I built a box to fit on the rails and topped it with a piece of plywood and the pink hard foam from Home Depot. Just center the lift under the CG and service all three wheels at once. John Morgensen RV-9A Fuselage plumbing Grumman AA1B-150 (RV Trainer) Greg Williams wrote: > Hey Folks, > > Thanks for all the replies. I'm looking for the right size pipe to > use. My thought is to weld a 16" piece of pipe to this old scissor jack > that I already have. It came out of some import car and is in good > shape. It will go low enough to slide the pipe in after the wheel pant > and little bracket are removed. That way it is always in my hangar > ready for use. I wouldn't ever worry about the pipe falling off the > jack either. If a piece of 3/4" sch 40 water pipe (7/8" OD) will work, > I'll grind off the galvanizing, weld it to the jack & slap some paint on > it. If I can get something bigger in there, that's better. > > Anyone know or can easily measure the ID of that gear leg axle for me? > > Greg > > On 10/22/07, *Dave Cudney* < yenduc(at)sbcglobal.net > > wrote: > > > On Oct 22, 2007, at 11:45 AM, Tim Bryan wrote: > >> Yea, I understand that. What you do is remove the little wheel >> pant bracket, place the jack inside the axle through the axle >> nut. After jacking it up you remove the axle nut and slide it >> onto the jack bracket pipe. You slide the wheel onto the jack >> bracket pipe as well then you can place a block or jackstand or >> something under the axle and let it down. This allows you to >> remove the wheel from the jack bracket to do whatever you need. >> >> >> >> Reverse to re-install. >> >> >> >> Tim >> > > Thanks that makes sense. > > dave >> >> ------------------------------------------------------------------------ >> >> * From:* owner-rv-list-server(at)matronics.com >> [ >> mailto:owner-rv-list-server(at)matronics.com] * On Behalf Of *Dave Cudney >> * Sent:* Monday, October 22, 2007 1:32 PM >> * To:* rv-list(at)matronics.com >> * Subject:* Re: RV-List: Gear Legs >> >> >> >> Tim: >> >> >> >> I'm having a hard time visualizing how you get the wheel off with >> the jack attached to the axle??? How does that work? >> >> >> >> dave >> >> >> >> >> >> On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote: >> >> >> >> http://www.averytools.com/p-181-rv-jack-stand.aspx >> >> I see they have the already modified axle nuts as well. >> >> http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx >> >> >> Here are the brackets for wheel pant connection >> >> size=2 width="100%" align=center> >> >> * From:* owner-rv-list-server(at)matronics.com >> [ >> mailto:owner-rv-list-server(at)matronics.com >> ] * On Behalf Of *Greg >> Williams >> * Sent:* Monday, October 22, 2007 11:57 AM >> * To:* rv-list(at)matronics.com >> * Subject:* RV-List: Gear Legs >> >> Hi folks, >> >> I'm getting stuff ready to do my first annual condition inspection >> on my recently purchased, completed RV7. (I'm having a GREAT time >> flying!!) I want to change tires and was really nervous about the >> wing jack when I swapped tires 9 months ago. I was told to put a >> piece of pipe inside the landing gear strut before removing the >> nut and jack it up. Does anyone have their gear leg out in the >> open and could give me a measurement? Mine is all wrapped up in >> wheel pants and tough to get to right now. I think a 1" pipe is >> about right but need to know the inside diameter of the gear leg >> tube. >> >> Thanks in advance. >> >> Greg >> >> * >> >> * >> * >> * >> * >> >> >> http://www.matronics.com/Navigator?RV-List* >> * >> >> >> http://forums.matronics.com* >> * >> >> * >> * >> >> ** >> >> >> >> >> >> >> - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> >> --> >> http://forums.matronics.com >> * >> * >> >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> >> http://www.matronics.com/Navigator?RV-List* >> * >> * >> ** >> ** >> * >> http://forums.matronics.com* >> * >> * >> * >> >> * >> * >> >> - The RV-List Email Forum - class="Apple-converted-space"> * >> --> http://www.matronics.com/Navigator?RV-List - NEW >> MATRONICS WEB FORUMS - class="Apple-converted-space"> --> >> http://forums.matronics.com > > * > > http://www.matronics.com/Navigator?RV-List > http://forums.matronics.com > > * > > ** > > > ** ________________________________________________________________________________
Date: Oct 23, 2007
Not a bad idea... ----- Original Message ----- From: John Morgensen To: rv-list(at)matronics.com Sent: Tuesday, October 23, 2007 4:28 PM Subject: Re: RV-List: Gear Legs Harbor Freight sells a 1500lb ATV/Motorcycle lift that will pick up the whole airplane. I am using this on a Grumman Yankee (a.k.a. RV Trainer) and it works great! I built a box to fit on the rails and topped it with a piece of plywood and the pink hard foam from Home Depot. Just center the lift under the CG and service all three wheels at once. John Morgensen RV-9A Fuselage plumbing Grumman AA1B-150 (RV Trainer) Greg Williams wrote: > Hey Folks, > > Thanks for all the replies. I'm looking for the right size pipe to > use. My thought is to weld a 16" piece of pipe to this old scissor jack > that I already have. It came out of some import car and is in good > shape. It will go low enough to slide the pipe in after the wheel pant > and little bracket are removed. That way it is always in my hangar > ready for use. I wouldn't ever worry about the pipe falling off the > jack either. If a piece of 3/4" sch 40 water pipe (7/8" OD) will work, > I'll grind off the galvanizing, weld it to the jack & slap some paint on > it. If I can get something bigger in there, that's better. > > Anyone know or can easily measure the ID of that gear leg axle for me? > > Greg > > On 10/22/07, *Dave Cudney* < yenduc(at)sbcglobal.net > > wrote: > > > On Oct 22, 2007, at 11:45 AM, Tim Bryan wrote: > >> Yea, I understand that. What you do is remove the little wheel >> pant bracket, place the jack inside the axle through the axle >> nut. After jacking it up you remove the axle nut and slide it >> onto the jack bracket pipe. You slide the wheel onto the jack >> bracket pipe as well then you can place a block or jackstand or >> something under the axle and let it down. This allows you to >> remove the wheel from the jack bracket to do whatever you need. >> >> >> >> Reverse to re-install. >> >> >> >> Tim >> > > Thanks that makes sense. > > dave >> >> ------------------------------------------------------------------------ >> >> * From:* owner-rv-list-server(at)matronics.com >> [ >> mailto:owner-rv-list-server(at)matronics.com] * On Behalf Of *Dave Cudney >> * Sent:* Monday, October 22, 2007 1:32 PM >> * To:* rv-list(at)matronics.com >> * Subject:* Re: RV-List: Gear Legs >> >> >> >> Tim: >> >> >> >> I'm having a hard time visualizing how you get the wheel off with >> the jack attached to the axle??? How does that work? >> >> >> >> dave >> >> >> >> >> >> On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote: >> >> >> >> http://www.averytools.com/p-181-rv-jack-stand.aspx >> >> I see they have the already modified axle nuts as well. >> >> http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.a spx >> >> >> Here are the brackets for wheel pant connection >> >> size=2 width="100%" align=center> >> >> * From:* owner-rv-list-server(at)matronics.com >> [ >> mailto:owner-rv-list-server(at)matronics.com >> ] * On Behalf Of *Greg >> Williams >> * Sent:* Monday, October 22, 2007 11:57 AM >> * To:* rv-list(at)matronics.com >> * Subject:* RV-List: Gear Legs >> >> Hi folks, >> >> I'm getting stuff ready to do my first annual condition inspection >> on my recently purchased, completed RV7. (I'm having a GREAT time >> flying!!) I want to change tires and was really nervous about the >> wing jack when I swapped tires 9 months ago. I was told to put a >> piece of pipe inside the landing gear strut before removing the >> nut and jack it up. Does anyone have their gear leg out in the >> open and could give me a measurement? Mine is all wrapped up in >> wheel pants and tough to get to right now. I think a 1" pipe is >> about right but need to know the inside diameter of the gear leg >> tube. >> >> Thanks in advance. >> >> Greg >> >> * >> >> * >> * >> * >> * >> >> >> http://www.matronics.com/Navigator?RV-List* >> * >> >> >> http://forums.matronics.com* >> * >> >> * >> * >> >> ** >> >> >> >> >> >> >> - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> >> --> >> http://forums.matronics.com >> * >> * >> >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> * >> >> http://www.matronics.com/Navigator?RV-List* >> * >> * >> ** >> ** >> * >> http://forums.matronics.com* >> * >> * >> * >> >> * >> * >> >> - The RV-List Email Forum - class="Apple-converted-space"> * >> --> http://www.matronics.com/Navigator?RV-List - NEW >> MATRONICS WEB FORUMS - class="Apple-converted-space"> --> >> http://forums.matronics.com > > * > > http://www.matronics.com/Navigator?RV-List > http://forums.matronics.com > > * > > ** > > > ** ________________________________________________________________________________
Date: Oct 23, 2007
Can you do that to an RV without damaging the bottom of the fuse? Sam Buchanan ======== Konrad L. Werner wrote: > Not a bad idea... > ----- Original Message ----- > From: John Morgensen > To: rv-list(at)matronics.com > Sent: Tuesday, October 23, 2007 4:28 PM > Subject: Re: RV-List: Gear Legs > > > > Harbor Freight sells a 1500lb ATV/Motorcycle lift that will pick up the > whole airplane. I am using this on a Grumman Yankee (a.k.a. RV Trainer) > and it works great! I built a box to fit on the rails and topped it with > a piece of plywood and the pink hard foam from Home Depot. Just center > the lift under the CG and service all three wheels at once. > > John Morgensen > RV-9A Fuselage plumbing > Grumman AA1B-150 (RV Trainer) ________________________________________________________________________________
Date: Oct 24, 2007
John, Got any pics? -------------- Original message from John Morgensen : -------------- > > Harbor Freight sells a 1500lb ATV/Motorcycle lift that will pick up the > whole airplane. I am using this on a Grumman Yankee (a.k.a. RV Trainer) > and it works great! I built a box to fit on the rails and topped it with > a piece of plywood and the pink hard foam from Home Depot. Just center > the lift under the CG and service all three wheels at once. > > John Morgensen > RV-9A Fuselage plumbing > Grumman AA1B-150 (RV Trainer) > > Greg Williams wrote: > > Hey Folks, > > > > Thanks for all the replies. I'm looking for the right size pipe to > > use. My thought is to weld a 16" piece of pipe to this old scissor jack > > that I already have. It came out of some import car and is in good > > shape. It will go low enough to slide the pipe in after the wheel pant > > and little bracket are removed. That way it is always in my hangar > > ready for use. I wouldn't ever worry about the pipe falling off the > > jack either. If a piece of 3/4" sch 40 water pipe (7/8" OD) will work, > > I'll grind off the galvanizing, weld it to the jack & slap some paint on > > it. If I can get something bigger in there, that's better. > > > > Anyone know or can easily measure the ID of that gear leg axle for me? > > > > Greg > > > > On 10/22/07, *Dave Cudney* < yenduc(at)sbcglobal.net > > > wrote: > > > > > > On Oct 22, 2007, at 11:45 AM, Tim Bryan wrote: > > > >> Yea, I understand that. What you do is remove the little wheel > >> pant bracket, place the jack inside the axle through the axle > >> nut. After jacking it up you remove the axle nut and slide it > >> onto the jack bracket pipe. You slide the wheel onto the jack > >> bracket pipe as well then you can place a block or jackstand or > >> something under the axle and let it down. This allows you to > >> remove the wheel from the jack bracket to do whatever you need. > >> > >> > >> > >> Reverse to re-install. > >> > >> > >> > >> Tim > >> > > > > Thanks that makes sense. > > > > dave > >> > >> ------------------------------------------------------------------------ > >> > >> * From:* owner-rv-list-server(at)matronics.com > >> [ > >> mailto:owner-rv-list-server(at)matronics.com] * On Behalf Of *Dave Cudney > >> * Sent:* Monday, October 22, 2007 1:32 PM > >> * To:* rv-list(at)matronics.com > >> * Subject:* Re: RV-List: Gear Legs > >> > >> > >> > >> Tim: > >> > >> > >> > >> I'm having a hard time visualizing how you get the wheel off with > >> the jack attached to the axle??? How does that work? > >> > >> > >> > >> dave > >> > >> > >> > >> > >> > >> On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote: > >> > >> > >> > >> http://www.averytools.com/p-181-rv-jack-stand.aspx > >> > >> I see they have the already modified axle nuts as well. > >> > >> > http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx > >> > >> > >> Here are the brackets for wheel pant connection > >> > >> size=2 width="100%" align=center> > >> > >> * From:* owner-rv-list-server(at)matronics.com > >> [ > >> mailto:owner-rv-list-server(at)matronics.com > >> ] * On Behalf Of *Greg > >> Williams > >> * Sent:* Monday, October 22, 2007 11:57 AM > >> * To:* rv-list(at)matronics.com > >> * Subject:* RV-List: Gear Legs > >> > >> Hi folks, > >> > >> I'm getting stuff ready to do my first annual condition inspection > >> on my recently purchased, completed RV7. (I'm having a GREAT time > >> flying!!) I want to change tires and was really nervous about the > >> wing jack when I swapped tires 9 months ago. I was told to put a > >> piece of pipe inside the landing gear strut before removing the > >> nut and jack it up. Does anyone have their gear leg out in the > >> open and could give me a measurement? Mine is all wrapped up in > >> wheel pants and tough to get to right now. I think a 1" pipe is > >> about right but need to know the inside diameter of the gear leg > >> tube. > >> > >> Thanks in advance. > >> > >> Greg > >> > >> * > >> > >> * > >> * > >> * > >> * > >> > >> > >> http://www.matronics.com/Navigator?RV-List* > >> * > >> > >> > >> http://forums.matronics.com* > >> * > >> > >> * > >> * > >> > >> ** > >> > >> > >> > >> > >> > >> > >> - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> > >> --> > >> http://forums.matronics.com > >> * > >> * > >> > >> * > >> * > >> * > >> * > >> * > >> * > >> * > >> * > >> * > >> * > >> * > >> * > >> * > >> * > >> > >> http://www.matronics.com/Navigator?RV-List* > >> * > >> * > >> ** > >> ** > >> * > >> http://forums.matronics.com* > >> * > >> * > >> * > >> > >> * > >> * > >> > >> - The RV-List Email Forum - class="Apple-converted-space"> * > >> --> http://www.matronics.com/Navigator?RV-List - NEW > >> MATRONICS WEB FORUMS - class="Apple-converted-space"> --> > >> http://forums.matronics.com > > > > * > > > > http://www.matronics.com/Navigator?RV-List > > http://forums.matronics.com > > > > * > > > > ** > > > > > > ** > > > >
John,
Got any pics?
-------------- Original message from John Morgensen <john(at)morgensen.com>: --------------
> --> RV-List message posted by: John Morgensen
> John Morgensen
> > Hey Folks,
> > Greg
> >> ; Yea, I understand that. What you do is remove the little wheel
> >> Tim
> > dave
> >> * From:* owner-rv-list-serve r@matr onics.com
> >> mailto:owner-rv-list-server@matronics.com] * On Behalf Of *Dave Cudney
> >> * To:* rv-list@matronics.com
> >> Tim:
> >> dave
> >> http://www.averytools.com/p-181-rv-jack-stand.as px
> >> * From:* owner-rv-list-server@matronics.com
> >> Williams
> >> Hi folks,
> >> I'm getting stuff rea dy to do my first annual condition inspection
> >> tube.
> >> Thanks in advance.
> >> Greg
> >&g t;
> > > * st uti
Date: Oct 23, 2007
Pictures: The 1 1/2" hard pink foam gets poked by the odd nut sticking out but it supports the weight of the plane without crushing. On the RV and the Yankee, the CG is on the flat part of the bottom where the spar is located. The top of my platform is about 18" x 40" or about 5 square feet. The pressure on the bottom of the fuselage would be about 1200/5 or 240 lbs/sq.ft. Bill Settle wrote: > John, > > > > Got any pics? > > > > > -------------- Original message from John Morgensen > : -------------- > > > > > > Harbor Freight sells a 1500lb ATV/Motorcycle lift that will pick > up the > > whole airplane. I am using this on a Grumman Yankee (a.k.a. RV > Trainer) > > and it works great! I built a box to fit on the rails and topped > it with > > a piece of plywood and the pink hard foam from Home Depot. Just > center > > the lift under the CG and service all three wheels at once. > > > > John Morgensen > > RV-9A Fuselage plumbing > > Grumman AA1B-150 (RV Trainer) > > > > Greg Williams wrote: > > > Hey Folks, > > > > > > Thanks for all the replies. I'm looking for the right size pipe to > > > use. My thought is to weld a 16" piece of pipe to this old > scissor jack > > > that I already have. It came out of some import car and is in good > > > shape. It will go low enough to slide the pipe in after the > wheel pant > > > and little bracket are removed. That way it is always in my hangar > > > ready for use. I wouldn't ever worry about the pipe falling off > the > > > jack either. If a piece of 3/4" sch 40 water pipe (7/8" OD) > will work, > > > I'll grind off the galvanizing, weld it to the jack & slap some > paint on > > > it. If I can get something bigger in there, that's better. > > > > > > Anyone know or can easily measure the ID of that gear leg axle > for me? > > > > > > Greg > > > > > > On 10/22/07, *Dave Cudney* < yenduc(at)sbcglobal.net > > > > wrote: > > > > > > > > > On Oct 22, 2007, at 11:45 AM, Tim Bryan wrote: > > > > > >> ; Yea, I understand that. What you do is remove the little wheel > > >> pant bracket, place the jack inside the axle through the axle > > >> nut. After jacking it up you remove the axle nut and slide it > > >> onto the jack bracket pipe. You slide the wheel onto the jack > > >> bracket pipe as well then you can place a block or jackstand or > > >> something under the axle and let it down. This allows you to > > >> remove the wheel from the jack bracket to do whatever you need. > > >> > > >> > > >> > > >> Reverse to re-install. > > >> > > >> > > >> > > >> Tim > > >> > > > > > > Thanks that makes sense. > > > > > > dave > > >> > > >> > ------------------------------------------------------------------------ > > > >> > > >> * From:* owner-rv-list-serve r@matr onics.com > > >> [ > > >> mailto:owner-rv-list-server(at)matronics.com] * On Behalf Of > *Dave Cudney > > >> * Sent:* Monday, October 22, 2007 1:32 PM > > >> * To:* rv-list(at)matronics.com > > >> * Subject:* Re: RV-List: Gear Legs > > >> > > >> > > >> > > >> Tim: > > >> > > >> > > >> > > >> I'm having a hard time visualizing how you get the wheel off with > > >> the jack attached to the axle??? How does that work? > > >> > > >> > > >> > > >> dave > > >> > > >> > > >> > > >> > > >> > > >> On Oct 22, 2007, at 10:29 AM, Tim Bryan wrote: > > >> > > >> > > >> > > >> http://www.averytools.com/p-181-rv-jack-stand.as px > > >> > > >> I see they have the already modified axle nuts as well. > > >> > > >> > > > http://www.averytools.com/p-179-modified-rv-axle-nuts-for-rv-jack-stand.aspx > > > >> > > >> > > >> Here are the brackets for wheel pant connection > > >> > > >> size=2 width="100%" align=center> > > >> > > >> * From:* owner-rv-list-server(at)matronics.com > > >> [ > > >> mailto:owner-rv-list-server(at)matronics.com > > >> ] * On Behalf Of *Greg > > >> Williams > > >> * Sent:* Monday, October 22, 2007 11:57 AM > > >> * To:* rv-list(at)matronics.com > > >> * Subject:* RV-List: Gear Legs > > >> > > >> Hi folks, > > >> > > >> I'm getting stuff rea dy to do my first annual condition > inspection > > >> on my recently purchased, completed RV7. (I'm having a GREAT time > > >> flying!!) I want to change tires and was really nervous about the > > >> wing jack when I swapped tires 9 months ago. I was told to put a > > >> piece of pipe inside the landing gear strut before removing the > > >> nut and jack it up. Does anyone have their gear leg out in the > > >> open and could give me a measurement? Mine is all wrapped up in > > >> wheel pants and tough to get to right now. I think a 1" pipe is > > >> about right but need to know the inside diameter of the gear leg > > >> tube. > > >> > > >> Thanks in advance. > > >> > > >> Greg > > >> > > >> * > > >> > > >> * > > >> * > > >> * > > >> * > > >> > > >&g t; > > >> http://www.matronics.com/Navigator?RV-List* > > >> * > > >> > > >> > > >> http://forums.matronics.com* > > >> * > > >> > > >> * > > >> * > > >> > > >> ** > > >> > > >> > > >> > > >> > > >> > > >> > > >> - NEW MATRONICS WEB FORUMS - class="Apple-converted-space"> > > >> --> > > >> http://forums.matronics.com > > >> * > > >> * > > >> > > >> * > > >> * > > >> * > > >> * > > >> * > > >> * > > >> * > > >> * > > >> * > > >> * > > >> * > > >> * > > >> * > > >> * > > >> > > >> http://www.matronics.com/Navigator?RV-List* > > >> * > > > > * st uti > > * > > > * ________________________________________________________________________________
Date: Oct 24, 2007
Subject: Re: Gear Legs wheel replacementGear Legs wheel replacementGear
Legs wheel replacement I used a jack under the wing last night on my RV-8. We started to jack both wings but realized the cg was forward of the jacking points when the tail wheel started coming off the floor so we put some weight (carefully) on the horizontal stabilizer and jacked one side at a time. Worked fine, was very stable, and it allowed unencumbered access to the wheel.=0A=0AAs someone e lse implied earlier, the wings support the entire weight of the plane when we're flying and can support several times the planes weight when flying. B esides, Dicky V. says that the tie down mount is fine for jacking the plane . If he says it, it's probably true.=0A=0AJohn ________________________________________________________________________________
Subject: Gear Legs wheel replacementGear Legs wheel replacementGear
Date: Oct 24, 2007
I should have elaborated when I posted my comments about the jack. I did post about using my wings for lifting each and every time I fly. I have absolutely no aversion to using wing jacks. The problem for me is I never really need to lift the whole plane but typically only a wheel. I don't own any wing jacks and they are a bit more expensive than I want to pay. They also take up some extra room in the hangar. I have access to borrow them but it would take me longer to go transport them for use than to just use the little rig from Avery or one of the others as mentioned. I have seen methods for jacking with a floor jack and some blocking to the wing but that doesn't appeal to me. This is probably the main reason why many of us choose to use something other than wing jacks. If you have them available by all means use them. This is just my opinion however and I know there are others. Someone mentioned if something goes wrong and that is probably valid also. Any plane lifted regardless of the method needs to be secured. A wing jack is probably more secure than lifting the wheel with some form of pipe or avery rig. Make sure your plane is sufficiently choked. If your plane is nose heavy when picked up by the jack points I would sure double check my weight and balance. I am not saying either way because I don't know, but it would seem a little forward. Of course with a pilot in there it would be different. Were the tanks full? Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Dalman Sent: Wednesday, October 24, 2007 9:21 AM Subject: Re: RV-List: Gear Legs wheel replacementGear Legs wheel replacementGear Legs wheel replacement I used a jack under the wing last night on my RV-8. We started to jack both wings but realized the cg was forward of the jacking points when the tail wheel started coming off the floor so we put some weight (carefully) on the horizontal stabilizer and jacked one side at a time. Worked fine, was very stable, and it allowed unencumbered access to the wheel. As someone else implied earlier, the wings support the entire weight of the plane when we're flying and can support several times the planes weight when flying. Besides, Dicky V. says that the tie down mount is fine for jacking the plane. If he says it, it's probably true. John ________________________________________________________________________________
Subject: Tip-up gas struts
Date: Oct 24, 2007
FYI, The tip-up canopy struts supplied by Van's are Lift-O-Mat PN/752818. Van's price is approximately $23 per strut, which turns out to be a fairly competitive price. I shopped hard on the Internet and basically matched this price from various suppliers. Van isn't such a bad guy after all!! Steve Chambers N99ST RV6 ________________________________________________________________________________
Subject: New product annoucement
From: "=?utf-8?B?Qm9iIE5ld21hbg==?=" <rcnewman(at)mycingular.blackberry.net>
Date: Oct 24, 2007
Fellow RV builders, I'm pleased to annouce we have added two new models to the Safety-Trim product family. In addition to our standard features of time limited servo control, adjustable speed control, emergency reverse and simplified pilot/co-pilot wiring we now have models with that provide 2 user adjustable preset speeds. This feature allows you to control your trim response based on aircraft performance. This feature is especially useful in aircraft with a large performance envelope such as the RVs. For all the details please visit our website. www.tcwtech.com Thanks, Bob Newman. Rv-10 #40176 Sent via BlackBerry by AT&T ________________________________________________________________________________
From: "Michael D. Cencula" <matronics(at)cencula.com>
Subject: Aileron trailing edge skislope effect
Date: Oct 24, 2007
Greetings listers, I'm working on my ailerons (RV-7A) and seem to be getting a skislope effect at the trailing edge near the ribs. Some places are worse than others. You can see what I mean by checking the third photo here: http://www.our7a.com/20071015.html or the second and third photos here: http://www.our7a.com/20071024.html Any thoughts on what's causing this? It seems to like the trailing edge bend may not be in exactly the right location. I sent this very question to Van's and got the following response: "Mike, I looked at your aileron trailing edge photo and it is not perfect, but it's acceptable and within tolerance. It will not cause you any flight problems. Bruce Reynolds brucer(at)vansaircraft.com" Although it's nice to know that it's still safe, I really need a *solution*. Thanks, Mike Cencula ________________________________________________________________________________
Date: Oct 24, 2007
Mike, It couldn't hurt to order another rib for the worst ski slope end to see if that improves the fit. Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael D. Cencula Sent: Wednesday, October 24, 2007 7:15 PM Subject: RV-List: Aileron trailing edge skislope effect Greetings listers, I'm working on my ailerons (RV-7A) and seem to be getting a skislope effect at the trailing edge near the ribs. Some places are worse than others. You can see what I mean by checking the third photo here: http://www.our7a.com/20071015.html or the second and third photos here: http://www.our7a.com/20071024.html Any thoughts on what's causing this? It seems to like the trailing edge bend may not be in exactly the right location. I sent this very question to Van's and got the following response: "Mike, I looked at your aileron trailing edge photo and it is not perfect, but it's acceptable and within tolerance. It will not cause you any flight problems. Bruce Reynolds brucer(at)vansaircraft.com" Although it's nice to know that it's still safe, I really need a *solution*. Thanks, Mike Cencula ________________________________________________________________________________
Date: Oct 24, 2007
Subject: Re: Aileron trailing edge skislope effect
On 17:15 2007-10-24 "Michael D. Cencula" wrote: > Although it's nice to know that it's still safe, I really need a > *solution*. Some alternatives: 1. Make a new rib for the worst location, drilling holes to match the skins. 2. Remove the clecoes from the worst rib, and drill new holes that match the skins in the spaces between each of the existing holes. When you get to painting, fill the unriveted holes and then paint over them. 3. (Van's suggestion) Drive the rivets as-is, and rig the plane to fly straight and true once you're done. Personally I wouldn't go looking for extra work, but if pushed i'd probably opt for option 1. -Rob ________________________________________________________________________________
Date: Oct 25, 2007
Mike, The trailing edge doesn't look too bad to me. However, you really will not know if it causes a trim problem until you fly the airplane. The shape can be perfect to the eye but still require altering because of a "heavy wing". Initially my 6A flew hands off perfectly until I had the plane painted. After checking all the alignment points of both ailerons, the gear leg fairing etc., only thing I found was an impression on the top of the right aileron midway along the trailing edge. It looked like someone in the paint shop picked up the aileron by the trailing edge and put a slight dent/depression in the top skin right where a thump would have squeezed it. Following Van's procedure for correcting a heavy wing, http://www.vansaircraft.com/pdf/Wing_Heavy.pdf, I had to reduce the radius of the right aileron trailing edge and increase the radius of the left aileron trailing edge to get back to the 'hands off' trim I had before painting. Dale Ensing RV-6A EAA TC & FA ----- Original Message ----- From: "Michael D. Cencula" <matronics(at)cencula.com> Sent: Wednesday, October 24, 2007 8:15 PM Subject: RV-List: Aileron trailing edge skislope effect > > > Greetings listers, > > I'm working on my ailerons (RV-7A) and seem to be getting a skislope > effect at > the trailing edge near the ribs. Some places are worse than others. You > can > see what I mean by checking the third photo here: > > http://www.our7a.com/20071015.html > > or the second and third photos here: > > http://www.our7a.com/20071024.html > > Any thoughts on what's causing this? > > It seems to like the trailing edge bend may not be in exactly the right > location. > > I sent this very question to Van's and got the following response: > > "Mike, > I looked at your aileron trailing edge photo and it is not perfect, but > it's > acceptable and within tolerance. It will not cause you any flight > problems. > Bruce Reynolds > brucer(at)vansaircraft.com" > > Although it's nice to know that it's still safe, I really need a > *solution*. > > Thanks, > > Mike Cencula > > > ________________________________________________________________________________
Date: Oct 25, 2007
I believe I have seen this issue before and it was traced to skins that were bent wrong and Van replaced them. You may want to check with Ken. Carl W Bell New Venture Consulting Mobile: 803.640.2760 www.newventureconsulting.com carlbell(at)gforcecable.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Rob Prior Sent: Wednesday, October 24, 2007 11:44 PM Subject: Re: RV-List: Aileron trailing edge skislope effect On 17:15 2007-10-24 "Michael D. Cencula" wrote: > Although it's nice to know that it's still safe, I really need a > *solution*. Some alternatives: 1. Make a new rib for the worst location, drilling holes to match the skins. 2. Remove the clecoes from the worst rib, and drill new holes that match the skins in the spaces between each of the existing holes. When you get to painting, fill the unriveted holes and then paint over them. 3. (Van's suggestion) Drive the rivets as-is, and rig the plane to fly straight and true once you're done. Personally I wouldn't go looking for extra work, but if pushed i'd probably opt for option 1. -Rob ________________________________________________________________________________
Date: Oct 25, 2007
From: George Inman 204 287 8334 <ghinman(at)mts.net>
Subject: using wing jacks
For you guys using wing jacks.Do you put the jack against the tiedown ring,or use a pillow and platform arrangement? -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Subject: Re: using wing jacks
Date: Oct 25, 2007
I use a 2x4 block drilled out to go over the moving part of the jack. Then that is covered with a rubber mat material for softness. Ron Lee ----- Original Message ----- From: "George Inman 204 287 8334" <ghinman(at)mts.net> Sent: Thursday, October 25, 2007 8:18 AM Subject: RV-List: using wing jacks > > > For you guys using wing jacks.Do you put the jack > against the tiedown ring,or use a pillow and platform arrangement? > > -- > > George H. Inman > ghinman(at)mts.net > > > ________________________________________________________________________________
Date: Oct 25, 2007
Short steel bolt with the same thread as the tiedown used as a hardpoint. Or you can go the Lancair route and machine a cup to fit over the jack with a stud to screw into the tiedown mount. I've also found that I can use my engine hoist to lift at the steps; good for getting a main wheel up. I can get the nose wheel up by connecting the tail tiedown to a tiedown point with a come-along and pulling the tail down. Patrick Kelley - RV-6A - gluing the tip-up canopy in place -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of George Inman 204 287 8334 Sent: Thursday, October 25, 2007 7:19 AM Subject: RV-List: using wing jacks For you guys using wing jacks.Do you put the jack against the tiedown ring,or use a pillow and platform arrangement? -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Oct 25, 2007
I too just use a grade 8 bolt threaded into the tie down blocks. This will not let the plane slip off the jacks, at least not with my arrangement. -Mike -----Original Message----- From: "George Inman 204 287 8334" <ghinman(at)mts.net> Sent: 10/25/07 10:18 AM Subject: RV-List: using wing jacks For you guys using wing jacks.Do you put the jack against the tiedown ring,or use a pillow and platform arrangement? -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Date: Oct 25, 2007
Geoge, This suggestion assumes aviation style wing jacks are being used. Failing that jack stability is a must. Get two 2" or 3" x 3/8" national course bolts. cut off the heads. Remove the Van's tie down rings. screw in the headless bolts. If needed modify the jack stand by drilling a shallow hole (depression) to accept the headless bolts. Jim in Kelowna ----- Original Message ----- From: "George Inman 204 287 8334" <ghinman(at)mts.net> Sent: Thursday, October 25, 2007 7:18 AM Subject: RV-List: using wing jacks > > > For you guys using wing jacks.Do you put the jack > against the tiedown ring,or use a pillow and platform arrangement? > > -- > > George H. Inman > ghinman(at)mts.net > > > ________________________________________________________________________________
From: "Mile High Aviation" <joe@mile-high-aviation.com>
Subject: Best Prices Offered Anywhere
Date: Oct 25, 2007
Mile High Aviation We Will Not Be Undersold! ASA Pathfinder CX-2 Electronic Flight Computer CX-2 Flight Computer Price $61.95 Retail Price $80.00 To Order Call: 401-228-6677 Http://WWW.MILE-HIGH-AVIATION.COM ________________________________________________________________________________
Date: Oct 25, 2007
Linn, Thank you for your helpful response, it is much appreciated. I was hoping to purge the moisture without removing the ASI but it looks like I will have to remove it, I like your idea of placing it in a box. The pill bottle is a good idea too! --Larry ------------------------------------------------------------------------- ------- ------------------------------------------------------------------------- ------- ----- Original Message ----- From: linn Walters To: rv-list(at)matronics.com Sent: Tuesday, October 23, 2007 6:56 AM Subject: Re: RV-List: Water/Moisture in Static System Larry Mersek wrote: RV List, The glass on my airspeed indicator is fogged up with moisture. I have removed the static line from the back of the instrument and found droplets of water in the line. I'm looking for suggestions on how to dry out the airspeed indicator and removal of water from the system. I have used compressed air to purge out the water droplets through the static lines and put a small wattage heat lamp under the airspeed instrument with no success. I am also concerned this moisture will migrate to my Dynon D10A. Remove the AS and place it in a box with a 100 watt bulb ..... so that nothing is touching the bulb that will burn. The last is very important. I first noticed the moisture two days after flying through a small rain shower. I have 630 hours on my RV-6 and have flown it through rain showers before, this is the first time I have ever had an issue with moisture/water in the system. I do not have the Cessna style static water sump collection bottle sold by ACS installed in the static system and am considering installing one. Probably the best option ..... or make your own. Get a plastic "T" that fits your tubing, and glue it into the top of a pill bottle. They seal pretty well. Be sure to label the pill bottle "EXPERIMENTAL" and mount it where it's easily accessible with a 'low spot' at the pill bottle. ;-) Linn Thanks in advance for your help and suggestions. Larry Mersek N336RV ________________________________________________________________________________
Date: Oct 25, 2007
Vans sells a kit that includes a attachment for the gear legs (a hose clamp will work) and 2 screw in jack points for the wings.....I have grove gear so the gear leg attachments don't do much for me but the jack points are wonderful. Sal RV8 N898SC -----Original Message----- From: Ron Lee <ronlee(at)pcisys.net> Sent: Thu, 25 Oct 2007 11:19 am Subject: Re: RV-List: using wing jacks ? I use a 2x4 block drilled out to go over the moving part of the jack.? ? Then that is covered with a rubber mat material for softness.? ? Ron Lee? ? ----- Original Message ----- From: "George Inman 204 287 8334" <ghinman(at)mts.net>? Sent: Thursday, October 25, 2007 8:18 AM? Subject: RV-List: using wing jacks? ? >? >? >? > For you guys using wing jacks.Do you put the jack? > against the tiedown ring,or use a pillow and platform arrangement?? >? > -- >? > George H. Inman? > ghinman(at)mts.net? >? >? >? >? >? > ? ? ? ? ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 25, 2007
Dale, Thanks for your helpful reply. I did order the bottle and will install once I get the moisture purged out of the system. Good idea with the light bulbs. --Larry ------------------------------------------------------------------------- ------- ------------------------------------------------------------------------- ------- ----- Original Message ----- From: Dale Walter To: rv-list(at)matronics.com Sent: Monday, October 22, 2007 9:55 PM Subject: RE: RV-List: Water/Moisture in Static System Hi Larry, I installed that bottle and it solved my problem, which was similar to yours. I put it at the low point in the back, behind the baggage compartment, extended the static line all the way to the bottom of fuselage. The line going from the bottle to the instruments is punched in to protrude an inch inside making it easy to keep any drops from moving forward. Putting that end of the bottle upward would do the same thing, but my connecter broke on that end of the bottle so I turned it into an opportunity. Bottle nipples are fragile. Since I live in South Florida with lots of humidity I also installed two 60 watt light bulbs (wired in series to reduce effective voltage per bulb) under the radio stack and plug them in to wall outlet in the hanger. This keeps the moisture out of my radios, the series wiring reduces the excessive heat a bulb would normally have in this confined area. Prior to this I was getting problems with my transponder after a humid week. No problems since. Dale RV6a 935 hrs, Lyc 0-360 A1A, Hartzell Youtube videos channel name: "lionheart33026" ------------------------------------------------------------------------- ----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Larry Mersek Sent: Monday, October 22, 2007 11:45 PM To: rv-list(at)matronics.com Subject: RV-List: Water/Moisture in Static System RV List, The glass on my airspeed indicator is fogged up with moisture. I have removed the static line from the back of the instrument and found droplets of water in the line. I'm looking for suggestions on how to dry out the airspeed indicator and removal of water from the system. I have used compressed air to purge out the water droplets through the static lines and put a small wattage heat lamp under the airspeed instrument with no success. I am also concerned this moisture will migrate to my Dynon D10A. I first noticed the moisture two days after flying through a small rain shower. I have 630 hours on my RV-6 and have flown it through rain showers before, this is the first time I have ever had an issue with moisture/water in the system. I do not have the Cessna style static water sump collection bottle sold by ACS installed in the static system and am considering installing one. Thanks in advance for your help and suggestions. Larry Mersek N336RV ________________________________________________________________________________
Subject: Re: New product annoucement
Date: Oct 25, 2007
I'd be interested to know if anyone has tried a two-speed setup using a 5-position inline switch like this (51MX down at the bottom): http://www.machinecomp.com/js_sa.htm First position, slow, push it a little farther, fast. It might be one of those ideas that seems clever but isn't, but I can't really see why it wouldn't work. Any thoughts? Tom Young RV-4, long, long way to go ----- Original Message ----- From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> Sent: Wednesday, October 24, 2007 1:54 PM Subject: RV-List: New product annoucement > > > Fellow RV builders, > > I'm pleased to annouce we have added two new models to the Safety-Trim > product family. In addition to our standard features of time limited > servo control, adjustable speed control, emergency reverse and simplified > pilot/co-pilot wiring we now have models with that provide 2 user > adjustable preset speeds. This feature allows you to control your trim > response based on aircraft performance. This feature is especially > useful in aircraft with a large performance envelope such as the RVs. > For all the details please visit our website. www.tcwtech.com > > Thanks, > Bob Newman. Rv-10 > #40176 > > Sent via BlackBerry by AT&T > > > ________________________________________________________________________________
Date: Oct 25, 2007
I use the jack points that Van's sells with his Jackpoint Kit. They appear to be a hard plastic and screw into the wing tie down points. http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1193337723-284-291&browse=airframe&product=jackpoint The wing jack is cupped and the jackpoint fits in very nicely. Dale Ensing > For you guys using wing jacks.Do you put the jack > against the tiedown ring,or use a pillow and platform arrangement? > George H. Inman > ghinman(at)mts.net ________________________________________________________________________________
Date: Oct 25, 2007
After looking at the pictures, I don't see the problem. If this is all you have to be worried about, then you are building a real fine RV. My RV has some cosmetic imperfections, dents, smiles, scratches whatever, now 5 years into flying, things that I thought were so important, I can not even find them, let alone allow it to bother me. This is sort of in the category of "who cares?" I would never have noticed without the straight edge in the picture. If you are building for flying, then move on, if you are building an Award Winner that will be exhibited in some technical museum, keep redoing it until it is perfect. If after flying the RV for a few years and it still bothers you, then rebuild it. But, by then you will be having way too much fun to worry about cosmetic accuracy. Bob RV6 "Wicked Witch of the West" At 07:15 PM 10/24/07, you wrote: > >Greetings listers, > >I'm working on my ailerons (RV-7A) and seem to be getting a skislope >effect at >the trailing edge near the ribs. Some places are worse than others. ________________________________________________________________________________
Date: Oct 25, 2007
Tom, The component you found is a multi-position switch. Although it can select multiple actions it has no way of providing any speed control function on its own. Additionally, it does not provide any of the valuable features of Safety-Trim, such as the time limited servo drive, or simplified pilot/co-pilot wiring. -Bob Newman TCW Technolgies www.tcwtech.com Sent via BlackBerry by AT&T -----Original Message----- From: "Tom Young" <teyoung1(at)comcast.net> Date: Thu, 25 Oct 2007 12:48:11 To: Subject: Re: RV-List: New product annoucement I'd be interested to know if anyone has tried a two-speed setup using a 5-position inline switch like this (51MX down at the bottom): http://www.machinecomp.com/js_sa.htm First position, slow, push it a little farther, fast. It might be one of those ideas that seems clever but isn't, but I can't really see why it wouldn't work. Any thoughts? Tom Young RV-4, long, long way to go ----- Original Message ----- From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> Sent: Wednesday, October 24, 2007 1:54 PM Subject: RV-List: New product annoucement > > > Fellow RV builders, > > I'm pleased to annouce we have added two new models to the Safety-Trim > product family. In addition to our standard features of time limited > servo control, adjustable speed control, emergency reverse and simplified > pilot/co-pilot wiring we now have models with that provide 2 user > adjustable preset speeds. This feature allows you to control your trim > response based on aircraft performance. This feature is especially > useful in aircraft with a large performance envelope such as the RVs. > For all the details please visit our website. www.tcwtech.com > > Thanks, > Bob Newman. Rv-10 > #40176 > > Sent via BlackBerry by AT&T > > ________________________________________________________________________________
Subject: Re: gear legs wheel replacement
Date: Oct 25, 2007
If your plane is nose heavy when picked up by the jack points I would sure double check my weight and balance. I am not saying either way because I don't know, but it would seem a little forward. Of course with a pilot in there it would be different. Were the tanks full? You want your airplane to be nose heavy when you jack it up by the jack points.? That means the CG is where it is supposed to be.? Remember?aerodynamics 101:?the wings lift and the tail gets pushed down in flight. Joel Haynes RV-7A N557XW Bozeman, MT ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 25, 2007
I wasn't suggesting that, I was suggesting using that switch with your two-speed box (or two of the Matronix boxes and a relay) to provide the multispeed capability at the pilot's fingertips in a single switch, rather than using a separate switch actuated by the flaps or somesuch. - Tom ----- Original Message ----- From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> Sent: Thursday, October 25, 2007 3:02 PM Subject: Re: RV-List: New product annoucement > > > Tom, The component you found is a multi-position switch. Although it > can select multiple actions it has no way of providing any speed control > function on its own. Additionally, it does not provide any of the > valuable features of Safety-Trim, such as the time limited servo drive, or > simplified pilot/co-pilot wiring. > > -Bob Newman > TCW Technolgies > www.tcwtech.com > > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "Tom Young" <teyoung1(at)comcast.net> > > Date: Thu, 25 Oct 2007 12:48:11 > To: > Subject: Re: RV-List: New product annoucement > > > I'd be interested to know if anyone has tried a two-speed setup using a > 5-position inline switch like this (51MX down at the bottom): > > http://www.machinecomp.com/js_sa.htm > > First position, slow, push it a little farther, fast. It might be one of > those ideas that seems clever but isn't, but I can't really see why it > wouldn't work. Any thoughts? > > Tom Young > RV-4, long, long way to go > > > ----- Original Message ----- > From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> > To: "Matronics list" ; "Matronics list" > > Sent: Wednesday, October 24, 2007 1:54 PM > Subject: RV-List: New product annoucement > > >> >> >> Fellow RV builders, >> >> I'm pleased to annouce we have added two new models to the Safety-Trim >> product family. In addition to our standard features of time limited >> servo control, adjustable speed control, emergency reverse and simplified >> pilot/co-pilot wiring we now have models with that provide 2 user >> adjustable preset speeds. This feature allows you to control your trim >> response based on aircraft performance. This feature is especially >> useful in aircraft with a large performance envelope such as the RVs. >> For all the details please visit our website. www.tcwtech.com >> >> Thanks, >> Bob Newman. Rv-10 >> #40176 >> >> Sent via BlackBerry by AT&T >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 25, 2007
I used a simple 2 position switch that connects a wire that by passes a resistor that slows down my pitch trim. When switch is closed the resistor is ineffective and I have fast trim. Now I have 2 speed trim, all I need. (KISS) Dale RV6a 935 hrs -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tom Young Sent: Thursday, October 25, 2007 5:29 PM Subject: Re: RV-List: New product annoucement I wasn't suggesting that, I was suggesting using that switch with your two-speed box (or two of the Matronix boxes and a relay) to provide the multispeed capability at the pilot's fingertips in a single switch, rather than using a separate switch actuated by the flaps or somesuch. - Tom ----- Original Message ----- From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> Sent: Thursday, October 25, 2007 3:02 PM Subject: Re: RV-List: New product annoucement > > > Tom, The component you found is a multi-position switch. Although it > can select multiple actions it has no way of providing any speed control > function on its own. Additionally, it does not provide any of the > valuable features of Safety-Trim, such as the time limited servo drive, or > simplified pilot/co-pilot wiring. > > -Bob Newman > TCW Technolgies > www.tcwtech.com > > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "Tom Young" <teyoung1(at)comcast.net> > > Date: Thu, 25 Oct 2007 12:48:11 > To: > Subject: Re: RV-List: New product annoucement > > > I'd be interested to know if anyone has tried a two-speed setup using a > 5-position inline switch like this (51MX down at the bottom): > > http://www.machinecomp.com/js_sa.htm > > First position, slow, push it a little farther, fast. It might be one of > those ideas that seems clever but isn't, but I can't really see why it > wouldn't work. Any thoughts? > > Tom Young > RV-4, long, long way to go > > > ----- Original Message ----- > From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> > To: "Matronics list" ; "Matronics list" > > Sent: Wednesday, October 24, 2007 1:54 PM > Subject: RV-List: New product annoucement > > >> >> >> Fellow RV builders, >> >> I'm pleased to annouce we have added two new models to the Safety-Trim >> product family. In addition to our standard features of time limited >> servo control, adjustable speed control, emergency reverse and simplified >> pilot/co-pilot wiring we now have models with that provide 2 user >> adjustable preset speeds. This feature allows you to control your trim >> response based on aircraft performance. This feature is especially >> useful in aircraft with a large performance envelope such as the RVs. >> For all the details please visit our website. www.tcwtech.com >> >> Thanks, >> Bob Newman. Rv-10 >> #40176 >> >> Sent via BlackBerry by AT&T >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 25, 2007
While your system is interesting, my elevator trim motor draws 2-3 amps, my roll trim is under 1 amp but the elevator is not. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Newman Sent: Thursday, October 25, 2007 5:02 PM Subject: Re: RV-List: New product annoucement Tom, The component you found is a multi-position switch. Although it can select multiple actions it has no way of providing any speed control function on its own. Additionally, it does not provide any of the valuable features of Safety-Trim, such as the time limited servo drive, or simplified pilot/co-pilot wiring. -Bob Newman TCW Technolgies www.tcwtech.com Sent via BlackBerry by AT&T -----Original Message----- From: "Tom Young" <teyoung1(at)comcast.net> Date: Thu, 25 Oct 2007 12:48:11 To: Subject: Re: RV-List: New product annoucement I'd be interested to know if anyone has tried a two-speed setup using a 5-position inline switch like this (51MX down at the bottom): http://www.machinecomp.com/js_sa.htm First position, slow, push it a little farther, fast. It might be one of those ideas that seems clever but isn't, but I can't really see why it wouldn't work. Any thoughts? Tom Young RV-4, long, long way to go ----- Original Message ----- From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> Sent: Wednesday, October 24, 2007 1:54 PM Subject: RV-List: New product annoucement > > > Fellow RV builders, > > I'm pleased to annouce we have added two new models to the Safety-Trim > product family. In addition to our standard features of time limited > servo control, adjustable speed control, emergency reverse and simplified > pilot/co-pilot wiring we now have models with that provide 2 user > adjustable preset speeds. This feature allows you to control your trim > response based on aircraft performance. This feature is especially > useful in aircraft with a large performance envelope such as the RVs. > For all the details please visit our website. www.tcwtech.com > > Thanks, > Bob Newman. Rv-10 > #40176 > > Sent via BlackBerry by AT&T > > ________________________________________________________________________________
Date: Oct 25, 2007
Oh, sorry I mis-understood. With the Safety-Trim two speed controller you only need a simple SPST switch to activate the two speeds. The switch just grounds the "two-speed input" wire or leaves it open. The safety-trim control box does the rest. The switch can easily be a simple manual switch on the instrument panel. -thanks, Bob Newman. Sent via BlackBerry by AT&T -----Original Message----- From: "Tom Young" <teyoung1(at)comcast.net> Date: Thu, 25 Oct 2007 15:28:43 To: Subject: Re: RV-List: New product annoucement I wasn't suggesting that, I was suggesting using that switch with your two-speed box (or two of the Matronix boxes and a relay) to provide the multispeed capability at the pilot's fingertips in a single switch, rather than using a separate switch actuated by the flaps or somesuch. - Tom ----- Original Message ----- From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> Sent: Thursday, October 25, 2007 3:02 PM Subject: Re: RV-List: New product annoucement > > > Tom, The component you found is a multi-position switch. Although it > can select multiple actions it has no way of providing any speed control > function on its own. Additionally, it does not provide any of the > valuable features of Safety-Trim, such as the time limited servo drive, or > simplified pilot/co-pilot wiring. > > -Bob Newman > TCW Technolgies > www.tcwtech.com > > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "Tom Young" <teyoung1(at)comcast.net> > > Date: Thu, 25 Oct 2007 12:48:11 > To: > Subject: Re: RV-List: New product annoucement > > > I'd be interested to know if anyone has tried a two-speed setup using a > 5-position inline switch like this (51MX down at the bottom): > > http://www.machinecomp.com/js_sa.htm > > First position, slow, push it a little farther, fast. It might be one of > those ideas that seems clever but isn't, but I can't really see why it > wouldn't work. Any thoughts? > > Tom Young > RV-4, long, long way to go > > > ----- Original Message ----- > From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> > To: "Matronics list" ; "Matronics list" > > Sent: Wednesday, October 24, 2007 1:54 PM > Subject: RV-List: New product annoucement > > >> >> >> Fellow RV builders, >> >> I'm pleased to annouce we have added two new models to the Safety-Trim >> product family. In addition to our standard features of time limited >> servo control, adjustable speed control, emergency reverse and simplified >> pilot/co-pilot wiring we now have models with that provide 2 user >> adjustable preset speeds. This feature allows you to control your trim >> response based on aircraft performance. This feature is especially >> useful in aircraft with a large performance envelope such as the RVs. >> For all the details please visit our website. www.tcwtech.com >> >> Thanks, >> Bob Newman. Rv-10 >> #40176 >> >> Sent via BlackBerry by AT&T >> >> >> >> > > ________________________________________________________________________________
Date: Oct 25, 2007
Bruce, can you provide me a brand /model # or any other info about your elevator trim servo. We have not yet run into that limitation before and like to fully understand it. If there's room to offer another product that drives a common higher current servo we'd like to look into it. Thanks, Bob Newman. Sent via BlackBerry by AT&T -----Original Message----- From: "Bruce Gray" <Bruce(at)glasair.org> Date: Thu, 25 Oct 2007 17:49:41 To: Subject: RE: RV-List: New product annoucement While your system is interesting, my elevator trim motor draws 2-3 amps, my roll trim is under 1 amp but the elevator is not. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob Newman Sent: Thursday, October 25, 2007 5:02 PM Subject: Re: RV-List: New product annoucement Tom, The component you found is a multi-position switch. Although it can select multiple actions it has no way of providing any speed control function on its own. Additionally, it does not provide any of the valuable features of Safety-Trim, such as the time limited servo drive, or simplified pilot/co-pilot wiring. -Bob Newman TCW Technolgies www.tcwtech.com Sent via BlackBerry by AT&T -----Original Message----- From: "Tom Young" <teyoung1(at)comcast.net> Date: Thu, 25 Oct 2007 12:48:11 To: Subject: Re: RV-List: New product annoucement I'd be interested to know if anyone has tried a two-speed setup using a 5-position inline switch like this (51MX down at the bottom): http://www.machinecomp.com/js_sa.htm First position, slow, push it a little farther, fast. It might be one of those ideas that seems clever but isn't, but I can't really see why it wouldn't work. Any thoughts? Tom Young RV-4, long, long way to go ----- Original Message ----- From: "Bob Newman" <rcnewman(at)mycingular.blackberry.net> Sent: Wednesday, October 24, 2007 1:54 PM Subject: RV-List: New product annoucement > > > Fellow RV builders, > > I'm pleased to annouce we have added two new models to the Safety-Trim > product family. In addition to our standard features of time limited > servo control, adjustable speed control, emergency reverse and simplified > pilot/co-pilot wiring we now have models with that provide 2 user > adjustable preset speeds. This feature allows you to control your trim > response based on aircraft performance. This feature is especially > useful in aircraft with a large performance envelope such as the RVs. > For all the details please visit our website. www.tcwtech.com > > Thanks, > Bob Newman. Rv-10 > #40176 > > Sent via BlackBerry by AT&T > > ________________________________________________________________________________
Date: Oct 26, 2007
Huh??@*&?? I have been jacking my RV up for five years at the tiedown points and never has the tailwheel left the ground. I must be violating aerodynamics 101, of course I do not believe that Bernoulli was right! Bob RV6 "Wicked Witch of the West" >If your plane is nose heavy when picked up by the jack points I would sure >double check my weight and balance. I am not saying either way because I >don't know, but it would seem a little forward. Of course with a pilot in >there it would be different. Were the tanks full? > > >You want your airplane to be nose heavy when you jack it up by the >jack points. That means the CG is where it is supposed to >be. Remember aerodynamics 101: the wings lift and the tail gets >pushed down in flight. ________________________________________________________________________________
Date: Oct 26, 2007
I'm not sure why Bob with the RV-6 has not had a problem, although maybe an RV-6 is different in this way. I think my cg is right where it needs to be. I looked at my weight and balance charts and found out: The main gear wheels are at 68.76" CG of plane, no pilot, with half fuel is 77.8. Since this is aft of the mains and forward of the tail wheel the plane sits fine on the ground. Since the fuel cg is at 80", and the jacking location is aft of the fuel, I would guess the tie down/jacking hole is about 85" aft of datum. I'm not at the airplane so am just guessing at this. Since the jacking position is between the cg and tail wheel, it takes load off the tail wheel and will ultimately lift if off the ground. -------- John Dalman Elburn, IL RV-8 N247TD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=141954#141954 ________________________________________________________________________________
Date: Oct 26, 2007
Subject: for sale: RV9 tail kit and tools
For sale: RV9 tail kit with electric trim. I am located in a western suburb of Chicago. I can't pack it so someone will have to be in driving distance. I also bought the Cleaveland tool kit for RV's including a pneumatic squeezer. The tools are barely used. $1300 for the tail kit and $2100 for tools. More info: jharrison46atgmaildotcom * <http://forums.matronics.com/> * ________________________________________________________________________________
Subject: Safety-Trim update
Date: Oct 26, 2007
Fellow RV builders, many have asked about on-line ordering of our products. I'm pleased to announce our On-line order feature is now up and running. Please visit our web site for all the details on Safety-Trim. www.tcwtech.com Thanks, Bob Newman. Sent via BlackBerry by AT&T ________________________________________________________________________________
Date: Oct 27, 2007
Subject: [ Rob Ray ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Rob Ray Lists: Rocket-List,RV-List,RV3-List,RV4-List,RV6-List,RV7-List,RV8-List,RV9-List,RV10-List Subject: Bigger Tires http://www.matronics.com/photoshare/smokyray@yahoo.com.10.27.2007/index.html ---------------------------------------------------------- o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ---------------------------------------------------------- ________________________________________________________________________________
Date: Oct 28, 2007
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: RV-6/6A Trivia-Wing Bellcrank
All ye RV-6/6A builders: Think waaaay back when you built your wings (actually when you installed the aileron bellcranks and pushrods). RV-7/8/9 builders don't apply, you have a different bellcrank set up. Anyway, I was installing this for the last time tonight and ran into a problem. The bellcrank installed in the mount with its quarter inch bolt (and washers/spacers) ok. But when I installed the AN3-10A bolt in the hole in the where the pushrod (rod end) goes, (and installed a thick washer and nylock nut), the amount of bolt sticking out of the nut created interference with the bottom (angle aluminum) mounting rail and the bellcrank couldn't move full travel. The bellcrank mounting rails, if you recall, are 1.5 inches apart and the bellcrank is centered between them. Van's old plans call for an AN3-10A bolt, thick washer and stop nut but that's obviously wrong. I checked my rail spacing just to be sure and yes I built them to the plans. So...I switched the bolt to an AN3-7 and with the thick washer and stop nut there is 2-3 threads sticking out of the stop nut. The bellcrank rotates freely but looking at the clearance between the end of the bolt and the bottom rail I would guess about 1/16 of an inch is all I have. This makes me nervous, the bellcrank mounting rails are 1/8 inch thick and that area is pretty stout but, the rod ends mount into the outer ends of the bellcrank itself (two pieces of 1/16 plate spaced apart by thick AN3 bolt washers in 4 places plus the center bearing mount acting as a spacer). If there is much flexing in the outer ends of the bellcrank in flight then it might be possible for the bolt end to come in contact with the mounting rail and ruin my day (life). I looked at going to an AN3-6A bolt but it doesn't look like there will be ANY threads sticking out of the stop nut when it's tightend (if I'm lucky and use a thin washer, I might get the threads to edge of the nylon in the end of the stop nut). Also if I used the -6A bolt I'll be violating the "grip length rules" (unthreaded bolt shank will not go all the way through the parts I'm bolting). Anyone remember having this problem? Did you use the -6A bolt or.... the -7A and live with the close clearances? How critical is it to adhere to the "grip length" rules? Dean Psiropoulos RV-6A N197DM If I'd quit running into crazy crap like this I'd be done now!!! ________________________________________________________________________________
Subject: Re: RV-6/6A Trivia-Wing Bellcrank
Date: Oct 28, 2007
> The bellcrank mounting rails, if you recall, are 1.5 inches apart and > the > bellcrank is centered between them. Yes I remember this well and solved it at the time I built the wings. The clearance was so small I feared that even with a modest wing loads it may interfere and lock the ailerons! I was told the popular solution is to go for the shorter bolt and thin nut. Perhaps a castle nut with split-pin may be better. My fix was to remake the spacers so the bellcrank is no longer centered but offset sufficiently to allow the bolt to clear the support angle. Doug Gray ________________________________________________________________________________
Date: Oct 28, 2007
If the grip length is a concern, try this: Use the correct length bolt, with a thin washer under the nut. Put a combination of thick/ thin washers under the bolt head (up to 3) that will give you just enough thread showing on the nut. You should have plenty of clearance for the bolt head, so raising it up a bit won't hurt. Or, you could use a thin locknut. Jeff Point RV-6 flying RV-8 building Milwaukee > ________________________________________________________________________________
Date: Oct 28, 2007
Would this problem apply to an RV-4 as well? I just picked up a second-hand wing kit and I'm curious if I will have the same concerns at that time when I get them built... Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Jeff Point wrote: > > If the grip length is a concern, try this: Use the correct length > bolt, with a thin washer under the nut. Put a combination of thick/ > thin washers under the bolt head (up to 3) that will give you just > enough thread showing on the nut. You should have plenty of clearance > for the bolt head, so raising it up a bit won't hurt. > > Or, you could use a thin locknut. > > Jeff Point > RV-6 flying > RV-8 building > Milwaukee > > >> > > ________________________________________________________________________________
Date: Oct 28, 2007
Subject: Re:RV-6/6A Trivia-Wing Bellcrank
Dean, Greetings from your old stomping grounds in (currently) sunny Oregon... Wish you'd have posted this yesterday when my wing ports were off, but here goes. I don't recall that fuss with my bellcranks, but then again, memory ain't so good, too much alum dust I guess... If you;re worried about the 1/16" clearance, try flexing the bellcrank by hand sideways and see if you can make it hang up. If everything is snugged up so there is no slop, I can't see you having a problem. Hard to imagine flight loads severe enough to deflect the B-crank that much, and if so, can't see it getting stuck in that kind of position. If I go to hangar next couple days I'll take one of my ports off and see what I did. I'd stick with whatever bolt lets you see at least one thread past the nut and keeps the proper shank length. I have some thin AN3 stop nuts if you need a couple. You can also use high temp, smaller stop nuts in that situation. I've done that a couple times when clearance or access was an issue... HTH & YMMV... Regards, Jerry Cochran In a message dated 10/28/2007 12:00:08 A.M. Pacific Daylight Time, rv-list(at)matronics.com writes: From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> Subject: RV-List: RV-6/6A Trivia-Wing Bellcrank All ye RV-6/6A builders: Think waaaay back when you built your wings (actually when you installed the aileron bellcranks and pushrods). RV-7/8/9 builders don't apply, you have a different bellcrank set up. Anyway, I was installing this for the last time tonight and ran into a problem. The bellcrank installed in the mount with its quarter inch bolt (and washers/spacers) ok. But when I installed the AN3-10A bolt in the hole in the where the pushrod (rod end) goes, (and installed a thick washer and nylock nut), the amount of bolt sticking out of the nut created interference with the bottom (angle aluminum) mounting rail and the bellcrank couldn't move full travel. The bellcrank mounting rails, if you recall, are 1.5 inches apart and the bellcrank is centered between them. Van's old plans call for an AN3-10A bolt, thick washer and stop nut but that's obviously wrong. I checked my rail spacing just to be sure and yes I built them to the plans. So...I switched the bolt to an AN3-7 and with the thick washer and stop nut there is 2-3 threads sticking out of the stop nut. The bellcrank rotates freely but looking at the clearance between the end of the bolt and the bottom rail I would guess about 1/16 of an inch is all I have. This makes me nervous, the bellcrank mounting rails are 1/8 inch thick and that area is pretty stout but, the rod ends mount into the outer ends of the bellcrank itself (two pieces of 1/16 plate spaced apart by thick AN3 bolt washers in 4 places plus the center bearing mount acting as a spacer). If there is much flexing in the outer ends of the bellcrank in flight then it might be possible for the bolt end to come in contact with the mounting rail and ruin my day (life). I looked at going to an AN3-6A bolt but it doesn't look like there will be ANY threads sticking out of the stop nut when it's tightend (if I'm lucky and use a thin washer, I might get the threads to edge of the nylon in the end of the stop nut). Also if I used the -6A bolt I'll be violating the "grip length rules" (unthreaded bolt shank will not go all the way through the parts I'm bolting). Anyone remember having this problem? Did you use the -6A bolt or.... the -7A and live with the close clearances? How critical is it to adhere to the "grip length" rules? Dean Psiropoulos RV-6A N197DM If I'd quit running into crazy crap like this I'd be done now!!! ________________________________________________________________________________
Date: Oct 28, 2007
"I have been jacking my RV up for five years at the tiedown points and never has the tailwheel left the ground." Does your hanger face into a headwind?!! Pete Cowper RV-8 #81139 (working on fuselage) ________________________________________________________________________________
Date: Oct 28, 2007
Make a new set of bellcrank spacers to provide clearance for the AN3-10A bolt between the mounting angles. Steve RV-6A built two sets of spacers myself........the first set per plans, and the second set to provide bolt clearance...............doesn't everyone do this? :-) > > All ye RV-6/6A builders: > > Think waaaay back when you built your wings (actually when you installed the > aileron bellcranks and pushrods). RV-7/8/9 builders don't apply, you have a > different bellcrank set up. Anyway, I was installing this for the last time > tonight and ran into a problem. The bellcrank installed in the mount with > its quarter inch bolt (and washers/spacers) ok. But when I installed the > AN3-10A bolt in the hole in the where the pushrod (rod end) goes, (and > installed a thick washer and nylock nut), the amount of bolt sticking out of > the nut created interference with the bottom (angle aluminum) mounting rail > and the bellcrank couldn't move full travel. .................... ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Date: Oct 28, 2007
For years, I thought this was unique to my plane... KB ----- Original Message ----- From: "Steve" <stevea(at)svpal.org> Sent: Sunday, October 28, 2007 6:19 PM Subject: Re: RV-List: RV-6/6A Trivia-Wing Bellcrank > > Make a new set of bellcrank spacers to provide clearance for the AN3-10A > bolt between the mounting angles. > > Steve > RV-6A > built two sets of spacers myself........the first set per plans, and the > second set to provide bolt clearance...............doesn't everyone do > this? :-) > > >> >> >> All ye RV-6/6A builders: >> >> Think waaaay back when you built your wings (actually when you installed >> the >> aileron bellcranks and pushrods). RV-7/8/9 builders don't apply, you >> have a >> different bellcrank set up. Anyway, I was installing this for the last >> time >> tonight and ran into a problem. The bellcrank installed in the mount with >> its quarter inch bolt (and washers/spacers) ok. But when I installed the >> AN3-10A bolt in the hole in the where the pushrod (rod end) goes, (and >> installed a thick washer and nylock nut), the amount of bolt sticking out >> of >> the nut created interference with the bottom (angle aluminum) mounting >> rail >> and the bellcrank couldn't move full travel. .................... > > > ________________________________________________________________________________
Subject: Ignition Problem - Troubleshooting
Date: Oct 28, 2007
We went from Atlanta to College Station, TX this weekend to see my wife's Aggies play (and lose to) Kansas.. Today, we made the return trip. And about 30 miles from home the engine lost a little power (~100 rpm). Some in-flight troubleshooting showed that the Electroair ignition that I have on the right side had quit. I flipped the on/off switch several times, reset the breaker, etc. and the ignition didn't come back to life. That being the case, I left it off for the remainder of the flight and made sure to stay high enough to glide to an airstrip if the other ignition system (a magneto) decided to take the day off too. And once we landed, I flipped it back on and voila', it was working fine. Which was a good thing. Sorta... Because troubleshooting an intermittent problem is a pain in the tuckus. I plan to check all of the connections between the battery, the breaker, the switch, and the ignition system. I'll check the ground connections too. Beyond that, I'll call the folks who are now supporting the ignition and see if they have any ideas. Any other thoughts on how to troubleshoot this problem? Thanks in advance, Kyle Boatright N46KB ________________________________________________________________________________
Date: Oct 28, 2007
Subject: Prop Mounting-clocking
Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing __________________________________________________ ________________________________________________________________________________
Date: Oct 28, 2007
Subject: Re: Prop Mounting-clocking
Must be a secret society! Linn Paul Besing wrote: > > ________________________________________________________________________________
Subject: Re: Ignition Problem - Troubleshooting
Date: Oct 28, 2007
It sounds like the electronic ignition is getting hot and shutting down. I have a friend with a 9A that had a similar problem. The problem was the blast tubes for cooling the E-mag was not positioned correctly. Russ Keith Slow build 9A ----- Original Message ----- From: Kyle Boatright To: rv-list(at)matronics.com Sent: Sunday, October 28, 2007 8:33 PM Subject: RV-List: Ignition Problem - Troubleshooting We went from Atlanta to College Station, TX this weekend to see my wife's Aggies play (and lose to) Kansas.. Today, we made the return trip. And about 30 miles from home the engine lost a little power (~100 rpm). Some in-flight troubleshooting showed that the Electroair ignition that I have on the right side had quit. I flipped the on/off switch several times, reset the breaker, etc. and the ignition didn't come back to life. That being the case, I left it off for the remainder of the flight and made sure to stay high enough to glide to an airstrip if the other ignition system (a magneto) decided to take the day off too. And once we landed, I flipped it back on and voila', it was working fine. Which was a good thing. Sorta... Because troubleshooting an intermittent problem is a pain in the tuckus. I plan to check all of the connections between the battery, the breaker, the switch, and the ignition system. I'll check the ground connections too. Beyond that, I'll call the folks who are now supporting the ignition and see if they have any ideas. Any other thoughts on how to troubleshoot this problem? Thanks in advance, Kyle Boatright N46KB ________________________________________________________________________________
Date: Oct 28, 2007
This message was very strange. I have a preview feature on my computer that lets me see incoming messages superimposed over the screen I'm working on. Paul's question was there on the preview screen but empty here. I don't get it. Dave RV6 _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Paul Besing Sent: Sunday, October 28, 2007 6:14 PM Subject: RV-List: Prop Mounting-clocking ________________________________________________________________________________
Date: Oct 28, 2007
Is the control unit in the engine compartment or cockpit? Some have had problems with wire fatigue right where they exit the mag timing housing. My controller is mounted inside, above the rudder pedals and have monitored temperature with digital sensor going to my Grand Rapids EIS and never had temps above 130 F (and no blast tubes on it). I thought E-mag was a much different animal vs Electroair? Dale RV6a 938 hrs _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Russ & Marilyn Sent: Sunday, October 28, 2007 9:27 PM Subject: Re: RV-List: Ignition Problem - Troubleshooting It sounds like the electronic ignition is getting hot and shutting down. I have a friend with a 9A that had a similar problem. The problem was the blast tubes for cooling the E-mag was not positioned correctly. Russ Keith Slow build 9A ----- Original Message ----- From: Kyle <mailto:kboatright1(at)comcast.net> Boatright Sent: Sunday, October 28, 2007 8:33 PM Subject: RV-List: Ignition Problem - Troubleshooting We went from Atlanta to College Station, TX this weekend to see my wife's Aggies play (and lose to) Kansas.. Today, we made the return trip. And about 30 miles from home the engine lost a little power (~100 rpm). Some in-flight troubleshooting showed that the Electroair ignition that I have on the right side had quit. I flipped the on/off switch several times, reset the breaker, etc. and the ignition didn't come back to life. That being the case, I left it off for the remainder of the flight and made sure to stay high enough to glide to an airstrip if the other ignition system (a magneto) decided to take the day off too. And once we landed, I flipped it back on and voila', it was working fine. Which was a good thing. Sorta... Because troubleshooting an intermittent problem is a pain in the tuckus. I plan to check all of the connections between the battery, the breaker, the switch, and the ignition system. I'll check the ground connections too. Beyond that, I'll call the folks who are now supporting the ignition and see if they have any ideas. Any other thoughts on how to troubleshoot this problem? Thanks in advance, Kyle Boatright N46KB href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Oct 28, 2007
Sounds similar to my electroair troubles: http://bowenaero.com/mt3/2004/10/more_ignition_w_1.html http://bowenaero.com/mt3/2005/03/electronic_igni.html http://bowenaero.com/mt3/2005/04/electronic_igni_1.html -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com *From:* Kyle Boatright > *To:* rv-list(at)matronics.com > *Sent:* Sunday, October 28, 2007 8:33 PM > *Subject:* RV-List: Ignition Problem - Troubleshooting > > We went from Atlanta to College Station, TX this weekend to see my > wife's Aggies play (and lose to) Kansas.. > > Today, we made the return trip. > > And about 30 miles from home the engine lost a little power (~100 rpm). > Some in-flight troubleshooting showed that the Electroair ignition that I > have on the right side had quit. I flipped the on/off switch several times, > reset the breaker, etc. and the ignition didn't come back to life. That > being the case, I left it off for the remainder of the flight and made sure > to stay high enough to glide to an airstrip if the other ignition system (a > magneto) decided to take the day off too. > > And once we landed, I flipped it back on and voila', it was working fine. > Which was a good thing. Sorta... > > Because troubleshooting an intermittent problem is a pain in the tuckus. > > I plan to check all of the connections between the battery, the breaker, > the switch, and the ignition system. I'll check the ground connections > too. Beyond that, I'll call the folks who are now supporting the ignition > and see if they have any ideas. > > Any other thoughts on how to troubleshoot this problem? > > Thanks in advance, > > Kyle Boatright > N46KB > > ________________________________________________________________________________
Date: Oct 28, 2007
The coils (and control unit) are in the engine compartment. Today was nice and cool (probably 32F at our cruising altitude), so I tend to discount heat as an issue, since I probably have a couple of hundred hours on this system in 80F+ ambient conditions. Beyond that, we had been in a reduced power descent for about 5 minutes when the system quit working, so things should have been cooling off at that time. I'll take a look at the timing housing wires. Never heard of that problem, but the number of these units in the field is relatively small, so forums like this are an outstanding place to share information and document a service history on 'em. As far as I know, there is little or no commonality between the E-mag and Electroair systems. KB ----- Original Message ----- From: Dale Walter To: rv-list(at)matronics.com Sent: Sunday, October 28, 2007 10:03 PM Subject: RE: RV-List: Ignition Problem - Troubleshooting Is the control unit in the engine compartment or cockpit? Some have had problems with wire fatigue right where they exit the mag timing housing. My controller is mounted inside, above the rudder pedals and have monitored temperature with digital sensor going to my Grand Rapids EIS and never had temps above 130 F (and no blast tubes on it). I thought E-mag was a much different animal vs Electroair? Dale RV6a 938 hrs ------------------------------------------------------------------------- ----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Russ & Marilyn Sent: Sunday, October 28, 2007 9:27 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Ignition Problem - Troubleshooting It sounds like the electronic ignition is getting hot and shutting down. I have a friend with a 9A that had a similar problem. The problem was the blast tubes for cooling the E-mag was not positioned correctly. Russ Keith Slow build 9A ----- Original Message ----- From: Kyle Boatright To: rv-list(at)matronics.com Sent: Sunday, October 28, 2007 8:33 PM Subject: RV-List: Ignition Problem - Troubleshooting We went from Atlanta to College Station, TX this weekend to see my wife's Aggies play (and lose to) Kansas.. Today, we made the return trip. And about 30 miles from home the engine lost a little power (~100 rpm). Some in-flight troubleshooting showed that the Electroair ignition that I have on the right side had quit. I flipped the on/off switch several times, reset the breaker, etc. and the ignition didn't come back to life. That being the case, I left it off for the remainder of the flight and made sure to stay high enough to glide to an airstrip if the other ignition system (a magneto) decided to take the day off too. And once we landed, I flipped it back on and voila', it was working fine. Which was a good thing. Sorta... Because troubleshooting an intermittent problem is a pain in the tuckus. I plan to check all of the connections between the battery, the breaker, the switch, and the ignition system. I'll check the ground connections too. Beyond that, I'll call the folks who are now supporting the ignition and see if they have any ideas. Any other thoughts on how to troubleshoot this problem? Thanks in advance, Kyle Boatright N46KB href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.m atronics.com ________________________________________________________________________________
Date: Oct 28, 2007
The message didn't show up in Thunderbird, but in Kontact it does. Anyway, here's his question: On Sunday October 28 2007 09:13:49 pm Paul Besing wrote: > Ok, silly question...my prop needs to be re mounted and I can't for the > life of me remember which position it looks like when stopped..when looking > at it from the cockpit, is the high blade on the left or right? i.e. the > blade you can see should be in the 10:00 or 2:00 position when viewed from > the cockpit? > > Thanks. > > Paul Besing > > > __________________________________________________ ________________________________________________________________________________
Date: Oct 28, 2007
Ok..try it again..here goes. Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing ----- Original Message ---- From: Paul Besing <pbesing(at)yahoo.com> Sent: Sunday, October 28, 2007 6:13:49 PM Subject: RV-List: Prop Mounting-clocking __________________________________________________ ________________________________________________________________________________
Date: Oct 29, 2007
Mine is on the right (2 O'Clock) as I look out the windshield. An easy way is to stand in front of the plane like you are going to hand prop. Which feels the best? Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Michael D. Cencula wrote: > >The message didn't show up in Thunderbird, but in Kontact it does. Anyway, >here's his question: > >On Sunday October 28 2007 09:13:49 pm Paul Besing wrote: > > >>Ok, silly question...my prop needs to be re mounted and I can't for the >>life of me remember which position it looks like when stopped..when looking >>at it from the cockpit, is the high blade on the left or right? i.e. the >>blade you can see should be in the 10:00 or 2:00 position when viewed from >>the cockpit? >> >>Thanks. >> >>Paul Besing >> >> >> >>__________________________________________________ >> >> > > > > ________________________________________________________________________________
Date: Oct 28, 2007
Mine (and most I see) stop at the 2:00 position as seen from the cockpit. This is convenient for hand propping if you're so inclined. KB ----- Original Message ----- From: Paul Besing To: rv-list(at)matronics.com Sent: Sunday, October 28, 2007 10:34 PM Subject: Re: RV-List: Prop Mounting-clocking Ok..try it again..here goes. Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing ----- Original Message ---- From: Paul Besing <pbesing(at)yahoo.com> To: rv-list(at)matronics.com Sent: Sunday, October 28, 2007 6:13:49 PM Subject: RV-List: Prop Mounting-clocking ________________________________________________________________________________
Date: Oct 29, 2007
How else does one start an airplane??? ;) Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Kyle Boatright wrote: > This is convenient for hand propping if you're so inclined. > > KB > > ________________________________________________________________________________
From: "Flamini, Dennis, Fran" <flamini2(at)comcast.net>
Subject: Fw: 160 HP 0-320-H2AD
Date: Oct 28, 2007
i bought a wrecked Acro II last weekend in central Michagan. The plane lost power and landed hard on an upslope. The prop hit the ground in a horiz. position, i looked at the engine unassembled and think it would be a great buy for someone. It was overhauled by Wag Aero and had 370 hrs SMOH when it crashed in Aug 2005. No carb or mag. The owner does not want to ship it so it would have to be picked up, i could help ship it but i am 200 miles away myself. i was thinking the Michigan guys might want to take a look at it. He wants $2,500 for it. i attached a photo of the plane wreck. Dennis in Chicago PS, i was all ready to go back and pick it up but my Wife noted that i already have 2 1/2 biplanes in the garage and an engine in the basement. ________________________________________________________________________________
Date: Oct 29, 2007
FWIW, 10:00 when viewed from the cockpit. If you ever want to hand prop it, that's the best position .... which is 2:00 when you're facing the prop. It doesn't matter what the 'stopping' position is .... if you're propping it, you want the rising blade to pass through 2:00 when the impulse fires at TDC. With the mags off (and a set of plugs removed is better) you can pull the prop through to see what position it's in when the impulse clicks. Linn Paul Besing wrote: > Ok..try it again..here goes. > > > Ok, silly question...my prop needs to be re mounted and I can't for > the life of me remember which position it looks like when > stopped..when looking at it from the cockpit, is the high blade on the > left or right? i.e. the blade you can see should be in the 10:00 or > 2:00 position when viewed from the cockpit? > > Thanks. > > Paul Besing > > ----- Original Message ---- > From: Paul Besing <pbesing(at)yahoo.com> > To: rv-list(at)matronics.com > Sent: Sunday, October 28, 2007 6:13:49 PM > Subject: RV-List: Prop Mounting-clocking > > ________________________________________________________________________________
Date: Oct 29, 2007
Dean, I think the general consensus was to offset the bell crank a bit to create a more comfortable clearance. If memory serves, I think I ground down one spacer and added thin washers to the opposite side rather than make new spacers from scratch. Steve dinieri Iflyrv10.com capsteve(at)adelphia.net All ye RV-6/6A builders: Think waaaay back when you built your wings (actually when you installed the aileron bellcranks and pushrods). RV-7/8/9 builders don't apply, you have a different bellcrank set up. Anyway, I was installing this for the last time tonight and ran into a problem. The bellcrank installed in the mount with its quarter inch bolt (and washers/spacers) ok. But when I installed the AN3-10A bolt in the hole in the where the pushrod (rod end) goes, (and installed a thick washer and nylock nut), the amount of bolt sticking out of the nut created interference with the bottom (angle aluminum) mounting rail and the bellcrank couldn't move full travel. The bellcrank mounting rails, if you recall, are 1.5 inches apart and the bellcrank is centered between them. Van's old plans call for an AN3-10A bolt, thick washer and stop nut but that's obviously wrong. I checked my rail spacing just to be sure and yes I built them to the plans. So...I switched the bolt to an AN3-7 and with the thick washer and stop nut there is 2-3 threads sticking out of the stop nut. The bellcrank rotates freely but looking at the clearance between the end of the bolt and the bottom rail I would guess about 1/16 of an inch is all I have. This makes me nervous, the bellcrank mounting rails are 1/8 inch thick and that area is pretty stout but, the rod ends mount into the outer ends of the bellcrank itself (two pieces of 1/16 plate spaced apart by thick AN3 bolt washers in 4 places plus the center bearing mount acting as a spacer). If there is much flexing in the outer ends of the bellcrank in flight then it might be possible for the bolt end to come in contact with the mounting rail and ruin my day (life). I looked at going to an AN3-6A bolt but it doesn't look like there will be ANY threads sticking out of the stop nut when it's tightend (if I'm lucky and use a thin washer, I might get the threads to edge of the nylon in the end of the stop nut). Also if I used the -6A bolt I'll be violating the "grip length rules" (unthreaded bolt shank will not go all the way through the parts I'm bolting). Anyone remember having this problem? Did you use the -6A bolt or.... the -7A and live with the close clearances? How critical is it to adhere to the "grip length" rules? Dean Psiropoulos RV-6A N197DM If I'd quit running into crazy crap like this I'd be done now!!! ________________________________________________________________________________
Date: Oct 29, 2007
Larry, What are you planning on using on your 7? -------------- Original message from "Larry Bowen" : -------------- Sounds similar to my electroair troubles: http://bowenaero.com/mt3/2004/10/more_ignition_w_1.html http://bowenaero.com/mt3/2005/03/electronic_igni.html http://bowenaero.com/mt3/2005/04/electronic_igni_1.html -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com From: Kyle Boatright Sent: Sunday, October 28, 2007 8:33 PM Subject: RV-List: Ignition Problem - Troubleshooting We went from Atlanta to College Station, TX this weekend to see my wife's Aggies play (and lose to) Kansas.. Today, we made the return trip. And about 30 miles from home the engine lost a little power (~100 rpm). Some in-flight troubleshooting showed that the Electroair ignition that I have on the right side had quit. I flipped the on/off switch several times, reset the breaker, etc. and the ignition didn't come back to life. That being the case, I left it off for the remainder of the flight and made sure to stay high enough to glide to an airstrip if the other ignition system (a magneto) decided to take the day off too. And once we landed, I flipped it back on and voila', it was working fine. Which was a good thing. Sorta... Because troubleshooting an intermittent problem is a pain in the tuckus. I plan to check all of the connections between the battery, the breaker, the switch, and the ignition system. I'll check the ground connections too. Beyond that, I'll call the folks who are now supporting the ignition and see if they have any ideas. Any other thoughts on how to troubleshoot this problem? Thanks in advance, Kyle Boatright N46KB
Larry,
-------------- Original message from "Larry Bowen" <Larry@bowenaero.com>: --------------
Larry Bowen
Larry@BowenAero.com
Thanks in advance,
Kyle Boatright
N46KB
Date: Oct 29, 2007
Check the variable reluctance pickup for low resistance or open circuit. If that checks out check the gap between the gear and the pickup. This is the part that tends to break over time in the Electroair systems. I was flying over the middle of Lake Michigan when mine did the same thing. Regards, Bob Japundza RV-6 flying F1 under const. ________________________________________________________________________________
Subject: RE: Prop Mounting-clocking
Date: Oct 29, 2007
Linn- >FWIW, 10:00 when viewed from the cockpit. If you ever want to hand prop >it, that's the best position .... which is 2:00 when you're facing the >prop. I though you had a Pitts, not a Moth.... ;-) glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Oct 29, 2007
If you monitor all 4 EGT's check them if it happens again to see if it's th e whole unit, or just a coil. The temps should increase on the cylinders fi ring only one plug. Chris _________________________________________________________________ Windows Live Hotmail and Microsoft Office Outlook ' together at last. - Get it now. http://office.microsoft.com/en-us/outlook/HA102225181033.aspx?pid=CL10062 6971033 ________________________________________________________________________________
Date: Oct 29, 2007
From: "Greg Williams" <mr.gsun+rv-list(at)gmail.com>
Subject: Re: using wing jacks
I used the hard plastic jackpoint with a borrowed wingjack. Worked great. Then I got worried that the plastic would shatter and the wing would jam down on the jack and make a big dent. So I got a short bolt w/same threads and used that with some help one side at a time to dismount and rotate my tires to even out the wear. Still I had this worry that somehow, someway the jack would come off and drive itself up thru the beautiful, fragile wing structure. A nightmare in real life!! That's why I wanted something that would jack up the landing gear itself. Now, after a bunch of landings (some better than others), I'm going to replace tires & tubes. I got a piece of 3/4 steel rod to weld to the top of my scissor jack. Also bent a short piece of 3/8 rod to weld on for a cranking handle. Hope to weld and paint it today because it isn't going to be georgeous flying weather in Western Washington until later in the week. Anyone got a great source for tires? Michelins are on there now and they work fine. Greg On 10/25/07, Dale Ensing wrote: > > > I use the jack points that Van's sells with his Jackpoint Kit. They appear > to be a hard plastic and screw into the wing tie down points. > > > http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1193337723-284-291&browse=airframe&product=jackpoint > > The wing jack is cupped and the jackpoint fits in very nicely. > Dale Ensing > > > For you guys using wing jacks.Do you put the jack > > against the tiedown ring,or use a pillow and platform arrangement? > > George H. Inman > > ghinman(at)mts.net > > ________________________________________________________________________________
From: "L Klingmuller" <l_klingmuller6(at)earthlink.net>
Subject: Denver Area - Hangar Space for lease
Date: Oct 29, 2007
My hangar mate of several year has sold his RV-6 and I now have a very nice, heated space for rent. Location is at KFTG - Front Range Airport - which is user friendly ( no waiting for traffic, lots of private planes etc) and has one of the lower fuel prices in the greater Denver area. If interested send me an off-list e-mail or call my at (303) 984-4469. Lothar Klingmuller, RV-6A, 750 hrs ________________________________________________________________________________
Date: Oct 29, 2007
Greg Williams wrote: > I used the hard plastic jackpoint with a borrowed wingjack. Worked great. > Then I got worried that the plastic would shatter and the wing would jam > down on the jack and make a big dent. So I got a short bolt w/same threads > and used that with some help one side at a time to dismount and rotate my > tires to even out the wear. Still I had this worry that somehow, someway > the jack would come off and drive itself up thru the beautiful, fragile wing > structure. A nightmare in real life!! That's why I wanted something that > would jack up the landing gear itself. Seeing a jack go through a wing is indeed a real nightmare! We had this happen to a local -6A, and fortunately (?!?) the jack *only* penetrated the bottom skin without damaging either the spar or fuel tank. But it was a mess and very disheartening to deal with. I don't recall how the jack was attached to the wing but since an RV can be readily jacked up via a gear leg, and a jack failure is more or less a minor event when jacking a gear leg, I have *no* desire to use a jack on the wing. Sam Buchanan ________________________________________________________________________________
Date: Oct 29, 2007
Ok, there is a vote for each...any one care to make a tie breaker? Paul Besing ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Sunday, October 28, 2007 10:20:31 PM Subject: Re: RV-List: Prop Mounting-clocking FWIW, 10:00 when viewed from the cockpit. If you ever want to hand prop it, that's the best position .... which is 2:00 when you're facing the prop. It doesn't matter what the 'stopping' position is .... if you're propping it, you want the rising blade to pass through 2:00 when the impulse fires at TDC. With the mags off (and a set of plugs removed is better) you can pull the prop through to see what position it's in when the impulse clicks. Linn Paul Besing wrote: Ok..try it again..here goes. Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing ----- Original Message ---- From: Paul Besing <pbesing(at)yahoo.com> Sent: Sunday, October 28, 2007 6:13:49 PM Subject: RV-List: Prop Mounting-clocking __________________________________________________ ________________________________________________________________________________
Date: Oct 29, 2007
2? o'clock viewd from the cockpit dp -----Original Message----- From: Paul Besing <pbesing(at)yahoo.com> Sent: Mon, 29 Oct 2007 11:09 am Subject: Re: RV-List: Prop Mounting-clocking Ok, there is a vote for each...any one care to make a tie breaker? Paul Besing ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Sunday, October 28, 2007 10:20:31 PM Subject: Re: RV-List: Prop Mounting-clocking FWIW, 10:00 when viewed from the cockpit.? If you ever want to hand prop it, that's the best position .... which is 2:00 when you're facing the prop.? It doesn't matter what the 'stopping' position is .... if you're propping it, you want the rising blade to pass through 2:00 when the impulse fires at TDC.? With the mags off (and a set of plugs removed is better) you can pull the prop through to see what position it's in when the impulse clicks. Linn Paul Besing wrote: Ok..try it again..here goes. Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right?? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing ----- Original Message ---- From: Paul Besing <pbesing(at)yahoo.com> Sent: Sunday, October 28, 2007 6:13:49 PM Subject: RV-List: Prop Mounting-clocking ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 29, 2007
Paul Besing wrote: > Ok, there is a vote for each...any one care to make a tie breaker? > > Paul Besing Paul, the high blade will be at the 2:00 position when viewed from the cockpit (10:00 when facing the prop during a hand-start). Sam Buchanan ________________________________________________________________________________
Date: Oct 29, 2007
Date: Oct 29, 2007
Paul, It's 2:00 viewed from the cockpit. I've propped many airplanes and that has always been the orientation. I can't imagine trying to prop one by somehow twisting my body and flipping up on the prop. The prop usually stops between compressions so as you pull down on the prop you will be going though a compression, which is what you want. The impulse coupler works on each and every compression. Larry Pardue Carlsbad, NM
October 10, 2007 - October 29, 2007
RV-Archive.digest.vol-ta
