RV-Archive.digest.vol-tb
October 29, 2007 - November 14, 2007
      http://n5lp.net
      On Oct 29, 2007, at 10:09 AM, Paul Besing wrote:
      > Ok, there is a vote for each...any one care to make a tie breaker?
      > Paul Besing
      > ----- Original Message ----
      > From: linn Walters <pitts_pilot(at)bellsouth.net>
      > Sent: Sunday, October 28, 2007 10:20:31 PM
      > Subject: Re: RV-List: Prop Mounting-clocking
      > FWIW, 10:00 when viewed from the cockpit.  If you ever want to hand
      > prop it, that's the best position .... which is 2:00 when you're
      > facing the prop.  It doesn't matter what the 'stopping' position
      > is .... if you're propping it, you want the rising blade to pass
      > through 2:00 when the impulse fires at TDC.  With the mags off (and
      > a set of plugs removed is better) you can pull the prop through to
      > see what position it's in when the impulse clicks.
      > Linn
      > Paul Besing wrote:
      >> Ok..try it again..here goes.
      >> Ok, silly question...my prop needs to be re mounted and I can't
      >> for the life of me remember which position it looks like when
      >> stopped..when looking at it from the cockpit, is the high blade on
      >> the left or right?  i.e. the blade you can see should be in the
      >> 10:00 or 2:00 position when viewed from the cockpit?
      >> Thanks.
      >> Paul Besing
      >> From: Paul Besing <pbesing(at)yahoo.com>
      >> Sent: Sunday, October 28, 2007 6:13:49 PM
      >> Subject: RV-List: Prop Mounting-clocking
      > http://www.matronics.com/Navigator?RV-List_-
      > ============================================================ _-
      > forums.matronics.com_-
Subject: Re: Prop Mounting-clocking
From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: Oct 29, 2007
Its 2. Mike Paul Besing To Sent by: rv-list(at)matronics.com owner-rv-list-ser cc ver(at)matronics.com Subj ect Re: RV-List: Prop Mounting-clock ing 10/29/2007 12:09 PM Please respond to rv-list@matronics .com Ok, there is a vote for each...any one care to make a tie breaker? Paul Besing ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Sunday, October 28, 2007 10:20:31 PM Subject: Re: RV-List: Prop Mounting-clocking FWIW, 10:00 when viewed from the cockpit. If you ever want to hand pro p it, that's the best position .... which is 2:00 when you're facing the prop. It doesn't matter what the 'stopping' position is .... if you're propping it, you want the rising blade to pass through 2:00 when the impulse fires at TDC. With the mags off (and a set of plugs removed is better) you can pull the prop through to see what position it's in when the impulse clicks. Linn Paul Besing wrote: Ok..try it again..here goes. Ok, silly question...my prop needs to be re mounted and I can't f or the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade o n the left or right? i.e. the blade you can see should be in the 1 0:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing ----- Original Message ---- From: Paul Besing <pbesing(at)yahoo.com> To: rv-list(at)matronics.com Sent: Sunday, October 28, 2007 6:13:49 PM Subject: RV-List: Prop Mounting-clocking ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Subject: Re: using wing jacks
Date: Oct 29, 2007
The best system I've seen for jacking is as follows: Bolt two scissor jacks one either end of a strong trestle. Bolt a piece of 2*4" wood to the tops of the scissor jacks. Pad the wood with foam or similar. Place under the fuselage across the spar and jack the aircraft off the ground winding each jack a bit at a time to keep things even. This is really a variation on the motorbike jack but much cheaper anjd more stable and allows both mains to be serviced at the same time. Move up to the firewall to jack the nosewheel (where applicable). Best regards Peter ________________________________________________________________________________
Date: Oct 29, 2007
Got it thanks folks...one of those things I just couldn't picture, because I've seen both, but couldn't remember what was "normal". Paul Besing ----- Original Message ---- From: Sam Buchanan <sbuc(at)hiwaay.net> Sent: Monday, October 29, 2007 11:06:05 AM Subject: Re: RV-List: Prop Mounting-clocking Paul Besing wrote: > Ok, there is a vote for each...any one care to make a tie breaker? > > Paul Besing Paul, the high blade will be at the 2:00 position when viewed from the cockpit (10:00 when facing the prop during a hand-start). Sam Buchanan __________________________________________________ ________________________________________________________________________________
Subject: RV-6/6A Trivia-Wing Bellcrank
Date: Oct 29, 2007
Dean, I remember the problem well. I offset the bellcrank slightly by modifying the spacers and using a thin washer and a thin stop nut ( I'm at home and can't recall the PN but they are in the Spruce catalog). Then ground a couple of threads of the bolt and wound up with about 1/8 in. clearance. So far seems to work out O.K. -- Harry Crosby RV-6 N16CX, 412 hours -------------- Original message ---------------------- From: "Steven DiNieri" <capsteve(at)adelphia.net> > > Dean, > I think the general consensus was to offset the bell crank a bit to create a > more comfortable clearance. If memory serves, I think I ground down one > spacer and added thin washers to the opposite side rather than make new > spacers from scratch. > > > Steve dinieri > Iflyrv10.com > capsteve(at)adelphia.net > > > > > > All ye RV-6/6A builders: > > Think waaaay back when you built your wings (actually when you installed the > aileron bellcranks and pushrods). RV-7/8/9 builders don't apply, you have a > different bellcrank set up. Anyway, I was installing this for the last time > tonight and ran into a problem. The bellcrank installed in the mount with > its quarter inch bolt (and washers/spacers) ok. But when I installed the > AN3-10A bolt in the hole in the where the pushrod (rod end) goes, (and > installed a thick washer and nylock nut), the amount of bolt sticking out of > the nut created interference with the bottom (angle aluminum) mounting rail > and the bellcrank couldn't move full travel. > > The bellcrank mounting rails, if you recall, are 1.5 inches apart and the > bellcrank is centered between them. Van's old plans call for an AN3-10A > bolt, thick washer and stop nut but that's obviously wrong. I checked my > rail spacing just to be sure and yes I built them to the plans. So...I > switched the bolt to an AN3-7 and with the thick washer and stop nut there > is 2-3 threads sticking out of the stop nut. The bellcrank rotates freely > but looking at the clearance between the end of the bolt and the bottom rail > I would guess about 1/16 of an inch is all I have. > > This makes me nervous, the bellcrank mounting rails are 1/8 inch thick and > that area is pretty stout but, the rod ends mount into the outer ends of the > bellcrank itself (two pieces of 1/16 plate spaced apart by thick AN3 bolt > washers in 4 places plus the center bearing mount acting as a spacer). If > there is much flexing in the outer ends of the bellcrank in flight then it > might be possible for the bolt end to come in contact with the mounting rail > and ruin my day (life). > > I looked at going to an AN3-6A bolt but it doesn't look like there will be > ANY threads sticking out of the stop nut when it's tightend (if I'm lucky > and use a thin washer, I might get the threads to edge of the nylon in the > end of the stop nut). Also if I used the -6A bolt I'll be violating the > "grip length rules" (unthreaded bolt shank will not go all the way through > the parts I'm bolting). Anyone remember having this problem? Did you use the > -6A bolt or.... the -7A and live with the close clearances? How critical is > it to adhere to the "grip length" rules? > > > Dean Psiropoulos > RV-6A N197DM > If I'd quit running into crazy crap like this I'd be done now!!! > > > > > > > ________________________________________________________________________________
Date: Oct 29, 2007
Subject: Re: Ignition Problem - Troubleshooting
I'm going to try the mag/EI combo again. This time I'll use the P-mag it stable, otherwise a lightspeed. -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com On 10/29/07, Bill Settle wrote: > > Larry, > > > What are you planning on using on your 7? > > -------------- Original message from "Larry Bowen" : > -------------- > > Sounds similar to my electroair troubles: > > http://bowenaero.com/mt3/2004/10/more_ignition_w_1.html > http://bowenaero.com/mt3/2005/03/electronic_igni.html > http://bowenaero.com/mt3/2005/04/electronic_igni_1.html > > -- > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > *From:* Kyle Boatright > > *To:* rv-list(at)matronics.com > > *Sent:* Sunday, October 28, 2007 8:33 PM > > *Subject:* RV-List: Ignition Problem - Troubleshooting > > > > We went from Atlanta to College Station, TX this weekend to see my > > wife's Aggies play (and lose to) Kansas.. > > > > Today, we made the return trip. > > > > And about 30 miles from home the engine lost a little power (~100 rpm). > > Some in-flight troubleshooting showed that the Electroair ignition that I > > have on the right side had quit. I flipped the on/off switch several times, > > reset the breaker, etc. and the ignition didn't come back to life. That > > being the case, I left it off for the remainder of the flight and made sure > > to stay high enough to glide to an airstrip if the other ignition system (a > > magneto) decided to take the day off too. > > > > And once we landed, I flipped it back on and voila', it was working > > fine. Which was a good thing. Sorta... > > > > Because troubleshooting an intermittent problem is a pain in the tuckus. > > > > I plan to check all of the connections between the battery, the breaker, > > the switch, and the ignition system. I'll check the ground connections > > too. Beyond that, I'll call the folks who are now supporting the ignition > > and see if they have any ideas. > > > > Any other thoughts on how to troubleshoot this problem? > > > > Thanks in advance, > > > > Kyle Boatright > > N46KB > > > > * > > * > > * > > > * > > ________________________________________________________________________________
Date: Oct 29, 2007
Subject: Re: RE: Prop Mounting-clocking
glen matejcek wrote: > >Linn- > > > >>FWIW, 10:00 when viewed from the cockpit. If you ever want to hand prop >>it, that's the best position .... which is 2:00 when you're facing the >>prop. >> >> > >I though you had a Pitts, not a Moth.... ;-) > I do ....and for the first 13 years I hand propped it before I got smart and put a battery and starter in it. The clue is 'rising blade' that you didn't quote! ....at least I think I said that! When you pull the 2:00 blade CCW, the impulse will fire when that blade is at 8:00 on the down stroke. Linn > >glen matejcek >aerobubba(at)earthlink.net > > > > ________________________________________________________________________________
Date: Oct 30, 2007
If your prop is mounted that way, try and prop it. Do not do this alone. Have someone standing by with a cell phone to call an ambulance ... if needed. ;-) Linn dougpflyrv(at)aol.com wrote: > 2 o'clock viewd from the cockpit > dp > > > -----Original Message----- > From: Paul Besing <pbesing(at)yahoo.com> > To: rv-list(at)matronics.com > Sent: Mon, 29 Oct 2007 11:09 am > Subject: Re: RV-List: Prop Mounting-clocking > > Ok, there is a vote for each...any one care to make a tie breaker? > > Paul Besing > > ----- Original Message ---- > From: linn Walters <pitts_pilot(at)bellsouth.net > > > To: rv-list(at)matronics.com > Sent: Sunday, October 28, 2007 10:20:31 PM > Subject: Re: RV-List: Prop Mounting-clocking > > FWIW, 10:00 when viewed from the cockpit. If you ever want to hand > prop it, that's the best position .... which is 2:00 when you're > facing the prop. It doesn't matter what the 'stopping' position is > .... if you're propping it, you want the rising blade to pass through > 2:00 when the impulse fires at TDC. With the mags off (and a set of > plugs removed is better) you can pull the prop through to see what > position it's in when the impulse clicks. > Linn > > Paul Besing wrote: > >> Ok..try it again..here goes. >> >> >> Ok, silly question...my prop needs to be re mounted and I can't for >> the life of me remember which position it looks like when >> stopped..when looking at it from the cockpit, is the high blade on >> the left or right? i.e. the blade you can see should be in the 10:00 >> or 2:00 position when viewed from the cockpit? >> >> Thanks. >> >> Paul Besing >> >> ----- Original Message ---- >> From: Paul Besing <pbesing(at)yahoo.com> >> To: rv-list(at)matronics.com >> Sent: Sunday, October 28, 2007 6:13:49 PM >> Subject: RV-List: Prop Mounting-clocking >> >> >> >> >> >> >> > > > ------------------------------------------------------------------------ > Email and AIM finally together. You've gotta check out free AOL Mail > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=AOLAOF00020000000970>! > > ________________________________________________________________________________
Date: Oct 30, 2007
Date: Oct 29, 2007
Why does everyone have an overwhelming support for 2:00 then? ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Monday, October 29, 2007 10:22:18 PM Subject: Re: RV-List: Prop Mounting-clocking If your prop is mounted that way, try and prop it. Do not do this alone. Have someone standing by with a cell phone to call an ambulance ... if needed. ;-) Linn dougpflyrv(at)aol.com wrote: 2 o'clock viewd from the cockpit dp -----Original Message----- From: Paul Besing <pbesing(at)yahoo.com> Sent: Mon, 29 Oct 2007 11:09 am Subject: Re: RV-List: Prop Mounting-clocking Ok, there is a vote for each...any one care to make a tie breaker? Paul Besing ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Sunday, October 28, 2007 10:20:31 PM Subject: Re: RV-List: Prop Mounting-clocking FWIW, 10:00 when viewed from the cockpit. If you ever want to hand prop it, that's the best position .... which is 2:00 when you're facing the prop. It doesn't matter what the 'stopping' position is .... if you're propping it, you want the rising blade to pass through 2:00 when the impulse fires at TDC. With the mags off (and a set of plugs removed is better) you can pull the prop through to see what position it's in when the impulse clicks. Linn Paul Besing wrote: Ok..try it again..here goes. Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing ----- Original Message ---- From: Paul Besing <pbesing(at)yahoo.com> Sent: Sunday, October 28, 2007 6:13:49 PM Subject: RV-List: Prop Mounting-clocking Email and AIM finally together. You've gotta check out free AOL Mail! __________________________________________________ ________________________________________________________________________________
Date: Oct 30, 2007
This is what I sent in another email .... but it hasn't shown up yet. I apologize if y'all get it twice! Also noted error from other post :-( . Fixed in red .... like my face! We all may be talking the same end result. Nice pic! I see where the confusion comes in. I talk about when the impulse mag fires ..... which should be in the 2:00/8:00 position as viewed from the front, not where the prop stops. As you pull the '2:00' prop blade around, the compression stroke will start and, hopefully that same blade will be at 8:00 when the impulse fires. The prop may, indeed, stop with the prop in the 2:00/8:00 position as viewed from the cockpit on a 4 cylinder engine, but I'm pretty sure it's different on a 6 cyl engine. In my mind it doesn't matter where in rotation the prop stops, it's where the mag fires and the prop 'starts' that's important. I may have been a little premature (and harsh maybe) in my reply to DP .... and I apologize. No offense meant. Again, I clock the prop on where the mag fires, not where it stops. Hope this helps! BTW, I also caution my friends (and enemies) to get some instruction on how to properly 'hand prop an airplane. I've had some friends injured .... none fatally ..... in their education process. Linn Paul Besing wrote: > Why does everyone have an overwhelming support for 2:00 then? > > ----- Original Message ---- > From: linn Walters <pitts_pilot(at)bellsouth.net> > To: rv-list(at)matronics.com > Sent: Monday, October 29, 2007 10:22:18 PM > Subject: Re: RV-List: Prop Mounting-clocking > > If your prop is mounted that way, try and prop it. Do not do this > alone. Have someone standing by with a cell phone to call an > ambulance ... if needed. ;-) > Linn > > dougpflyrv(at)aol.com wrote: > >> 2 o'clock viewd from the cockpit >> dp >> >> >> -----Original Message----- >> From: Paul Besing <pbesing(at)yahoo.com> >> To: rv-list(at)matronics.com >> Sent: Mon, 29 Oct 2007 11:09 am >> Subject: Re: RV-List: Prop Mounting-clocking >> >> Ok, there is a vote for each...any one care to make a tie breaker? >> >> Paul Besing >> >> ----- Original Message ---- >> From: linn Walters <pitts_pilot(at)bellsouth.net >> > >> To: rv-list(at)matronics.com >> Sent: Sunday, October 28, 2007 10:20:31 PM >> Subject: Re: RV-List: Prop Mounting-clocking >> >> FWIW, 10:00 when viewed from the cockpit. If you ever want to hand >> prop it, that's the best position .... which is 2:00 when you're >> facing the prop. It doesn't matter what the 'stopping' position is >> .... if you're propping it, you want the rising blade to pass through >> 2:00 when the impulse fires at TDC. With the mags off (and a set of >> plugs removed is better) you can pull the prop through to see what >> position it's in when the impulse clicks. >> Linn >> >> Paul Besing wrote: >> >>> Ok..try it again..here goes. >>> >>> >>> Ok, silly question...my prop needs to be re mounted and I can't for >>> the life of me remember which position it looks like when >>> stopped..when looking at it from the cockpit, is the high blade on >>> the left or right? i.e. the blade you can see should be in the >>> 10:00 or 2:00 position when viewed from the cockpit? >>> >>> Thanks. >>> >>> Paul Besing >>> >>> ----- Original Message ---- >>> From: Paul Besing <pbesing(at)yahoo.com> >>> To: rv-list(at)matronics.com >>> Sent: Sunday, October 28, 2007 6:13:49 PM >>> Subject: RV-List: Prop Mounting-clocking >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> >> >> ------------------------------------------------------------------------ >> Email and AIM finally together. You've gotta check out free AOL Mail >> <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=AOLAOF00020000000970>! >> >> >> >> > > ________________________________________________________________________________
Date: Oct 30, 2007
I have an Electroair system and although I have not had exactly the same problem I did have one with the pick up signal that I use to provide the RPM indicator. The problem was a poor contact on the main Electroair Ignition unit. Mine which is a 1998 model had several spade connectors that connect the wires including the 12 volt power to the control unit. Probably over time (800 hours) the connector had worked loose plus some oil may have been the cause of the bad contact. I cleaned the contact and made it a tighter fit and since then there has not been a problem. I would imagine that if your system started working again after a landing which may have vibrated the wires the problem is one due to a poor contact and not a component failure. Hopefully when you have found the cause of the problem you will post the information. Barry RV6A F-PRVM -------- Barry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=142693#142693 ________________________________________________________________________________
Date: Oct 30, 2007
Subject: Re: Tire Source
At 08:25 AM 10/29/07, you wrote: >Anyone got a great source for tires? Michelins are on there now and >they work fine I use Dresser Tires, they advertise in Trade a Plane, they are somewhere in Tenn, I finally went with Goodyear Flight Custom IIIs. I like the tire, wears well, and with Michelins tubes, no loss of air between annuals. On the other hand, the Goodyears are a little heavier than the tires that Van provides. Bob RV6 "Wicked Witch of the West" ________________________________________________________________________________
Subject: "Bubba" wing jack
Date: Oct 30, 2007
Last month, my son and I found ourselves on a Saturday morning at the far end of the taxiway for runway 1 of the Greenville Downtown Airport with a flat left tire. We were loaded with fuel and ready to complete the second leg of our trip to Cleveland. Air from the fuel truck didn't help and it was obvious that the tire would need to be removed at the spot for repair. The good fellows at SATS Air sent a golf cart down with a mechanic and some tools to remove the wheel pants and take a closer look. Back to the hanger for more tools, a wood block, and the biggest guy in the shop, "Bubba" (not certain that's his real name, but it fits). With the mechanic at the ready by the tire, my son and me on our hands and knees (backs on the wing spar), and Bubba between us on his back (with his hands on the spar), we arched and Bubba pressed and the mechanic removed the tire in less than 30 seconds. After replacing the tube in the shop it was back to the plane. Bubba jack in place, arch and push, and wheel replaced. Now, I would like to believe that my son and I provided a lot of lift for the operation. In reality, though, Bubba likely could have lifted the plane by himself. Either way, consider the Bubba jack in a pinch for emergency repairs. John Paulich N121PR, "Hot Flash", RV-7 Naples, Florida ________________________________________________________________________________
Date: Oct 30, 2007
In a message dated 10/30/2007 6:18:57 A.M. Pacific Daylight Time, panamared5(at)brier.net writes: I use Dresser Tires, they advertise in Trade a Plane, they are somewhere in Tenn, I finally went with Goodyear Flight Custom IIIs. I like the tire, wears well, and with Michelins tubes, no loss of air between annuals =================================== Actually the company is Desser, in California at least. I think you can buy directly from them or many of the outlets like Chief will have Desser drop ship the product right to you. They advertise in TAP, PF and I have them listed in the Yeller Pages. I have had good luck with the Condor brand tires and use the Michelin leak stop tubes. N1GV (RV-6A, Flying 870hrs, O-360-A1A, C/S, Silicon Valley) ________________________________________________________________________________
Date: Oct 30, 2007
I HAVE BEEN PROPPING VARIOUS AIRCRAFT SINCE 1960 AND THEY WERE ALWAYS AT 2 O'CLOCK AS VIEWED FROM THE COCKPIT. NEVER SEEN ONE POSITIONED OTHERWISE. DP -----Original Message----- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Tue, 30 Oct 2007 12:22 am Subject: Re: RV-List: Prop Mounting-clocking If your prop is mounted that way, try and prop it.? Do not do this alone.? Have someone standing by with a cell phone to call an ambulance ... if needed. ;-) Linn dougpflyrv(at)aol.com wrote: 2? o'clock viewd from the cockpit dp -----Original Message----- From: Paul Besing <pbesing(at)yahoo.com> Sent: Mon, 29 Oct 2007 11:09 am Subject: Re: RV-List: Prop Mounting-clocking Ok, there is a vote for each...any one care to make a tie breaker? Paul Besing ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Sunday, October 28, 2007 10:20:31 PM Subject: Re: RV-List: Prop Mounting-clocking FWIW, 10:00 when viewed from the cockpit.? If you ever want to hand prop it, that's the best position .... which is 2:00 when you're facing the prop.? It doesn't matter what the 'stopping' position is .... if you're propping it, you want the rising blade to pass through 2:00 when the impulse fires at TDC.? With the mags off (and a set of plugs removed is better) you can pull the prop through to see what position it's in when the impulse clicks. Linn Paul Besing wrote: Ok..try it again..here goes. Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right?? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing ----- Original Message ---- From: Paul Besing <pbesing(at)yahoo.com> Sent: Sunday, October 28, 2007 6:13:49 PM Subject: RV-List: Prop Mounting-clocking Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 30, 2007
I THINK THIS SHOULD GET ALL OF US ON THE SAME PAGE.......NO PROBLEM LINN. DP -----Original Message----- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Tue, 30 Oct 2007 1:19 am Subject: Re: RV-List: Prop Mounting-clocking This is what I sent in another email .... but it hasn't shown up yet.? I apologize if y'all get it twice!? Also noted error from other post :-( .? Fixed in red .... like my face!? We all may be talking the same end result. Nice pic! I see where the confusion comes in.? I talk about when the impulse mag fires ..... which should be in the 2:00/8:00 position as viewed from the front, not where the prop stops.? As you pull the '2:00' prop blade around, the compression stroke will start and, hopefully that same blade will be at 8:00 when the impulse fires.? The prop may, indeed, stop with the prop in the 2:00/8:00 position as viewed from the cockpit on a 4 cylinder engine, but I'm pretty sure it's different on a 6 cyl engine.?? In my mind it doesn't matter where in rotation the prop stops, it's where the mag fires and the prop 'starts' that's important.? I may have been a little premature (and harsh maybe) in my reply to DP .... and I apologize.? No offense meant.? Again, I clock the prop on where the mag fires, not where it stops.? Hope this helps! BTW, I also caution my friends (and enemies) to get some instruction on how to properly 'hand prop an airplane.? I've had some friends injured .... none fatally? ..... in their education process. Linn Paul Besing wrote: Why does everyone have an overwhelming support for 2:00 then? ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Monday, October 29, 2007 10:22:18 PM Subject: Re: RV-List: Prop Mounting-clocking If your prop is mounted that way, try and prop it.? Do not do this alone.? Have someone standing by with a cell phone to call an ambulance ... if needed. ;-) Linn dougpflyrv(at)aol.com wrote: 2? o'clock viewd from the cockpit dp -----Original Message----- From: Paul Besing <pbesing(at)yahoo.com> Sent: Mon, 29 Oct 2007 11:09 am Subject: Re: RV-List: Prop Mounting-clocking Ok, there is a vote for each...any one care to make a tie breaker? Paul Besing ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> Sent: Sunday, October 28, 2007 10:20:31 PM Subject: Re: RV-List: Prop Mounting-clocking FWIW, 10:00 when viewed from the cockpit.? If you ever want to hand prop it, that's the best position .... which is 2:00 when you're facing the prop.? It doesn't matter what the 'stopping' position is .... if you're propping it, you want the rising blade to pass through 2:00 when the impulse fires at TDC.? With the mags off (and a set of plugs removed is better) you can pull the prop through to see what position it's in when the impulse clicks. Linn Paul Besing wrote: Ok..try it again..here goes. Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right?? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing ----- Original Message ---- From: Paul Besing <pbesing(at)yahoo.com> Sent: Sunday, October 28, 2007 6:13:49 PM Subject: RV-List: Prop Mounting-clocking Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 30, 2007
The clock in my airplane shop is digital... now what? hee hee ----- Original Message ----- From: dougpflyrv(at)aol.com To: rv-list(at)matronics.com Sent: Tuesday, October 30, 2007 11:02 AM Subject: Re: RV-List: Prop Mounting-clocking I THINK THIS SHOULD GET ALL OF US ON THE SAME PAGE.......NO PROBLEM LINN. DP -----Original Message----- From: linn Walters <pitts_pilot(at)bellsouth.net> To: rv-list(at)matronics.com Sent: Tue, 30 Oct 2007 1:19 am Subject: Re: RV-List: Prop Mounting-clocking This is what I sent in another email .... but it hasn't shown up yet. I apologize if y'all get it twice! Also noted error from other post :-( . Fixed in red .... like my face! We all may be talking the same end result. Nice pic! I see where the confusion comes in. I talk about when the impulse mag fires ..... which should be in the 2:00/8:00 position as viewed from the front, not where the prop stops. As you pull the '2:00' prop blade around, the compression stroke will start and, hopefully that same blade will be at 8:00 when the impulse fires. The prop may, indeed, stop with the prop in the 2:00/8:00 position as viewed from the cockpit on a 4 cylinder engine, but I'm pretty sure it's different on a 6 cyl engine. In my mind it doesn't matter where in rotation the prop stops, it's where the mag fires and the prop 'starts' that's important. I may have been a little premature (and harsh maybe) in my reply to DP .... and I apologize. No offense meant. Again, I clock the prop on where the mag fires, not where it stops. Hope this helps! BTW, I also caution my friends (and enemies) to get some instruction on how to properly 'hand prop an airplane. I've had some friends injured .... none fatally ..... in their education process. Linn Paul Besing wrote: Why does everyone have an overwhelming support for 2:00 then? ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> To: rv-list(at)matronics.com Sent: Monday, October 29, 2007 10:22:18 PM Subject: Re: RV-List: Prop Mounting-clocking If your prop is mounted that way, try and prop it. Do not do this alone. Have someone standing by with a cell phone to call an ambulance ... if needed. ;-) Linn dougpflyrv(at)aol.com wrote: 2 o'clock viewd from the cockpit dp -----Original Message----- From: Paul Besing <pbesing(at)yahoo.com> To: rv-list(at)matronics.com Sent: Mon, 29 Oct 2007 11:09 am Subject: Re: RV-List: Prop Mounting-clocking Ok, there is a vote for each...any one care to make a tie breaker? Paul Besing ----- Original Message ---- From: linn Walters <pitts_pilot(at)bellsouth.net> To: rv-list(at)matronics.com Sent: Sunday, October 28, 2007 10:20:31 PM Subject: Re: RV-List: Prop Mounting-clocking FWIW, 10:00 when viewed from the cockpit. If you ever want to hand prop it, that's the best position .... which is 2:00 when you're facing the prop. It doesn't matter what the 'stopping' position is .... if you're propping it, you want the rising blade to pass through 2:00 when the impulse fires at TDC. With the mags off (and a set of plugs removed is better) you can pull the prop through to see what position it's in when the impulse clicks. Linn Paul Besing wrote: Ok..try it again..here goes. Ok, silly question...my prop needs to be re mounted and I can't for the life of me remember which position it looks like when stopped..when looking at it from the cockpit, is the high blade on the left or right? i.e. the blade you can see should be in the 10:00 or 2:00 position when viewed from the cockpit? Thanks. Paul Besing ----- Original Message ---- From: Paul Besing <pbesing(at)yahoo.com> To: rv-list(at)matronics.com Sent: Sunday, October 28, 2007 6:13:49 PM Subject: RV-List: Prop Mounting-clocking ------------------------------------------------------------------------- - Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________________
Subject: Prop Indexing and Jacking
Date: Oct 30, 2007
Humpf, Prop indexing is not only a function of that which is convenient to hand propping, which if indexed properly(there's a pun in there) will put the right side descending blade up high and going through a compression stroke as you pull it down, but it is also a function of crankshaft and engine balance design. For this reason many certified prop/engine have indexing marks to help ensure proper(pun again) installation. RE Jacking, I made a heavy flat plate of 3/8 aluminum that is 1.5 inches wide and about 6 inches long with a u-bolt that straps it on to the tapered axel just inside of the wheel. I welded some .5" edges to the bottom side to stiffen it and provide some grip for a jack/board underneath. A couple of bricks and a five foot 2x6 underneath this plate and I can lever the wheel off the ground easily, and the plate fits into my tool kit easily. I figure I can always find either a scissors jack or a board and some bricks at any airport. If you look at the plate end on with the u-bolt it looks like this <[ and sideways it looks like this 1_____ with the one being the u-bolt that slips over the axel and is tightened as close to the brake backing plate as on can get it. I do remove the brake first, but one has to do this to get the wheel off anyways. W ________________________________________________________________________________
Date: Oct 30, 2007
Subject: RV8 comm antenna spacing
Has anyone out there been flying with two comm antennas mounted on their rv8 belly, just aft of the fuselage spar carry through bulkhead? Any problems with coupling between the antennas or reception? Sam Ray __________________________________________________ ________________________________________________________________________________
Date: Oct 30, 2007
Subject: which plugs are from the left mag?
My engine runs rough on the left mag. Which spark plugs are fed from the left mag in a Lycoming 0-320 E2D? Kim Nicholas Seattle ________________________________________________________________________________
Date: Oct 30, 2007
Usually the top of one side and the bottom of the other. Just follow the wires. Bruce <http://www.Glasair.org> www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com Sent: Tuesday, October 30, 2007 8:17 PM Subject: RV-List: which plugs are from the left mag? My engine runs rough on the left mag. Which spark plugs are fed from the left mag in a Lycoming 0-320 E2D? Kim Nicholas Seattle _____ See what's ne ________________________________________________________________________________
Subject: Re: RV8 comm antenna spacing
Date: Oct 31, 2007
Sam, I put two Comant, bent whip type, on the belly of my "8". I was told to put them as far apart as possible to keep them from interfering with each other. To accomplish this one is mounted on the center line of the fuselage just aft of the main spar center section. The other is also on the centerline but aft of the rear baggage area. Both are mounted on doublers on the skin to reinforce those areas. After 100 hours all is well and my radios have worked great. If you like I can send you some pictures off list. Let me know. Hope this helps. Steve Struyk St. Charles, MO RV-8, 100 Hrs. ----- Original Message ----- From: "sam ray" <sam95037(at)yahoo.com> Sent: Tuesday, October 30, 2007 3:36 PM Subject: RV-List: RV8 comm antenna spacing > > Has anyone out there been flying with two comm > antennas mounted on their rv8 belly, just aft of the > fuselage spar carry through bulkhead? Any problems > with coupling between the antennas or reception? > > Sam Ray > > __________________________________________________ > > > ________________________________________________________________________________
Subject: For Sale BMA EFIS One
Date: Oct 31, 2007
Posted to the Rv list for Giff Marr, See details below and contact Giff directly if interested Ed ----- Original Message ----- From: Giffen Marr To: Rotary motors in aircraft Sent: Monday, October 29, 2007 10:25 PM Subject: [FlyRotary] For Sale BMA EFIS One New Dual Screen BMA EFIS/One Version 3 for Sale!!! Upgrade to an Electronic Cockpit. Everything you could want in a single package EFIS. True A/S, True Course, Built in GPS, Ground Speed, Solid State Internal Platform, Moving Map Display with Terrain Elevation. Includes user programmable full engine monitoring, fuel flow, individual CHT's, EGT's and more. Reduce cockpit clutter. Accepts outside nav inputs, such as the Garmin SL-30. A $16,000+ Value for Thousands Less! Asking $10,900. Giff Marr 817-223-9671 (Cell) 817-306-9592 PS: What is the RV List address??? ________________________________________________________________________________
Date: Oct 31, 2007
Sam, Put one on the belly between the gear and put a Rami type on top of fuse aft of canopy. No problems with this setup and less shadowing. Dick At 04:36 PM 10/30/2007, you wrote: > >Has anyone out there been flying with two comm >antennas mounted on their rv8 belly, just aft of the >fuselage spar carry through bulkhead? Any problems >with coupling between the antennas or reception? > >Sam Ray > >__________________________________________________ > ________________________________________________________________________________
Date: Oct 31, 2007
I wish I had done this on my RV-6. I put both comm. Antennas on the belly and I have no problem except with ground communications when my flaps are down. The -6 is wider however and so spacing is probably less of a problem. Flaps do cause a shadow for me at least. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Richard Seiders > Sent: Wednesday, October 31, 2007 10:04 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: RV8 comm antenna spacing > > > Sam, Put one on the belly between the gear and put a Rami type on top > of fuse aft of canopy. No problems with this setup and less shadowing. > Dick > > > At 04:36 PM 10/30/2007, you wrote: > > > > >Has anyone out there been flying with two comm > >antennas mounted on their rv8 belly, just aft of the > >fuselage spar carry through bulkhead? Any problems > >with coupling between the antennas or reception? > > > >Sam Ray > > > >__________________________________________________ > > > > > > ________________________________________________________________________________
Date: Oct 31, 2007
The RV-8 canopy slides over the whole aft fuselage, all the way back to the empennage fairing, so it is not possible to mount a comm antenna on top of the aft fuselage. Kevin Horton On 31 Oct 2007, at 12:04, Richard Seiders wrote: > > Sam, Put one on the belly between the gear and put a Rami type on > top of fuse aft of canopy. No problems with this setup and less > shadowing. > Dick > > > At 04:36 PM 10/30/2007, you wrote: > >> >> Has anyone out there been flying with two comm >> antennas mounted on their rv8 belly, just aft of the >> fuselage spar carry through bulkhead? Any problems >> with coupling between the antennas or reception? >> >> Sam Ray ________________________________________________________________________________
Date: Oct 31, 2007
From: George Inman 204 287 8334 <ghinman(at)mts.net>
Subject: Wing root faring at bottom
What did some of you builders do where the wing root faring meets the skin that extends from the bottom of fuselage to the wing? The holes provided in the wing root faring do not seem to provide enough attachement points. RV-8 QB. -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Date: Oct 31, 2007
Subject: Re: AD INQUIRY - 2003 Van's Aircraft (RV Series)
Thanks for your interest in my RV8A. Attached are some photos. To give you some background info, I am the original builder of the airplane and it was built from a quickbuild kit. It includes most of the kit options available - rear seat rudder pedals & throttle, deluxe throttle quadrant and aileron trim. It has been completely flight tested by myself and a friend who is an ex airforce T-37 instructor. It has been spin tested and put through the basic acro maneuvers - loops, rolls, cuban eights, emmelman turns, split S's, etc. Engine- Lycoming IO-360 180HP. TTSN 700. The engine had a prop strike back in the early 90's but was compeltely torn down, inspected, and reassembled by Signature Aviation. A top overhaul was done approximately 250 hours ago, due to low compression (valve), and the need for oil impeller AD. While the engine was down, I decided to replace all cylinders, valves, pistons and rings. The engine has a solid crank, which is very durable, but precludes use of a hydraulic constant speed prop. Prop - the prop was made by Craig Catto out in CA. It is a three blade fixed pitch 66" X72" unit. Instruments Avionics - as you can see by one of the photos, the panel is pretty basic, being designed for day/night VFR flight. Avionics are: radio - Icom A-200, Transponder - Garmin GTX 327, TruTrak ADI (combination horizon/dg), Navaid wing leveler and Grand Rapids engine monitor. Performance - Top speed 204MPH (average of four runs at 8000' at 75% power). Typical cruise is 170MPH block to block at a throttle setting of 2400RPM. Climb is around 2,000/fpm, a little better on a cold day. Paint - done professionally by Rick Harris, Nashville, TN Top color is Lexus pearl, bottom is metallic teal and the "flash" begnins in gold metallic and gradually turns to tangerine metallic. Flash is outlined in apple green hand striping. Hope this meets your needs. I can snail mail you a CD which contains many pics, specs, etc., if you have the interest. Thank you, Walt Shipley Chuckey, TN P.S. The price IS NEGOTIABLE! -----Original Message----- >From: Trade-A-Plane Web Site <webmaster@trade-a-plane.com> >Sent: Oct 31, 2007 3:29 PM >To: rveighta(at)earthlink.net >Subject: AD INQUIRY - 2003 Van's Aircraft (RV Series) > >A Trade-A-Plane web user wishes to inquire about your ad. > >This message is from: jandmbaling(at)hotmail.com > >PLEASE SEND US INFORMATION AND PICTURES OF PLANE..THANK YOU ________________________________________________________________________________
Date: Oct 31, 2007
From: "Greg Williams" <mr.gsun+rv-list(at)gmail.com>
Subject: Re: For Sale BMA EFIS One
I have one of these Blue Mountain Efis-one units and it is amazing. Sophisticated, updates are expensive but it sure is cool. Sure is a let-down when I fly behind steam gauges these days. On 10/31/07, Ed Anderson wrote: > > > Posted to the Rv list for Giff Marr, See details below and contact Giff > directly if interested > > > Ed > > ----- Original Message ----- > > *From:* Giffen Marr > *To:* Rotary motors in aircraft > *Sent:* Monday, October 29, 2007 10:25 PM > *Subject:* [FlyRotary] For Sale BMA EFIS One > > New Dual Screen BMA EFIS/One Version 3 for Sale!!! > > Upgrade to an Electronic Cockpit. > > Everything you could want in a single package EFIS. True A/S, True Course, > Built in GPS, Ground Speed, Solid State Internal Platform, Moving Map > Display with Terrain Elevation. Includes user programmable full engine > monitoring, fuel flow, individual CHT's, EGT's and more. Reduce cockpit > clutter. Accepts outside nav inputs, such as the Garmin SL-30. > > A $16,000+ Value for Thousands Less! > > Asking $10,900. > > Giff Marr > 817-223-9671 (Cell) > 817-306-9592 > > PS: What is the RV List address??? > > > * > > > * > > ________________________________________________________________________________
Date: Oct 31, 2007
Subject: Re: Fw: 160 HP 0-320-H2AD
What engine is it, do you have any details on what's included with it? You can email me directly offline if you'd like. DD On 10/28/07, Flamini, Dennis, Fran wrote: > > i bought a wrecked Acro II last weekend in central Michagan. > The plane lost power and landed hard on an upslope. > The prop hit the ground in a horiz. position, i looked at the engine > unassembled > and think it would be a great buy for someone. > It was overhauled by Wag Aero and had 370 hrs SMOH when it crashed in Aug > 2005. > No carb or mag. > The owner does not want to ship it so it would have to be picked up, i > could help ship it > but i am 200 miles away myself. > i was thinking the Michigan guys might want to take a look at it. > He wants $2,500 for it. > i attached a photo of the plane wreck. > Dennis in Chicago > PS, i was all ready to go back and pick it up but my Wife noted that > i already have 2 1/2 biplanes in the garage and an engine in the basement. > > ________________________________________________________________________________
Date: Nov 01, 2007
Subject: November is Matronics Email List Fund Raiser Month!
Dear Listers, You've probably noticed that there are no banner ads or pop-up windows or spam from any of the List and Forum services at Matronics. These include, for example: The Email List Postings - http://www.matronics.com/listbrowse The Email List Forum Site - http://forums.matronics.com The List Wiki - http://wiki.matronics.com The List Search Engine - http://www.matronics.com/search This is because I have always enjoyed a List experience that was completely about the sport we enjoy - airplanes - and not about advertising! But running a high performance, highly available service like this isn't free and a fair amount of money in terms of computer upgrades, business-class Internet connectivity, and electricity. Consequently, many similar sites turn to advertising to support these costs. Advertising that you have to look at each and every time you read an email message or browse the their web site. Rather than subject my List community to another constant commercial bombardment, I have chosen to hold a PBS-like fund raiser each year in November to support the continued operation and upgrade of the List services. It's solely through the Contributions of List members that the Lists and Forums continue to be possible! During the month, I will be sending out a Fund Raiser reminder message every few days and I ask for your patience and understanding during the month throughout these regular messages. Think of them as PBS' Pledge Breaks... :-) To minimize the impact of the Fund Raiser on the List community, I implemented a new feature late last year specifically related to making Contributions. If you are an Email List subscriber, once you make a Contribution using the online web site, you will no longer receive the email from me regarding the Fund Raiser! There are a couple of exceptions to this, however. If someone replies to a Contribution message I've sent, you might receive that. Additionally, the messages will always be posted to the Forums site. To a first order, however, once you make a Contribution, you won't get my email messages about the Fund Raiser for the rest of the month. For Contributions by check, the squelch will take effect once the check is received. There is a whole new line up of really great Contribution gifts this year! When you make a qualifying Contribution, you can select one of the many free gifts that are available during the Fund Raiser. These gifts are provided through the generous support of a number of our industry's leading supporters including: Bob Nuckolls - AeroElectric - http://www.aeroelectric.com Andy Gold - Builder's Bookstore - http://www.buildersbooks.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Please visit these guy's respective sites, as they have some great products to offer and are generously supporting the Matronics List Fund Raiser. You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. From the Contribution site, you can select any one of this year's free gifts with a qualifying Contribution amount. The Contribution page is pretty loooonnnnng this year in order to list great selection of great gifts available so be sure to scroll all the way to the bottom of the web page to see everything that's available! Please make a List Support Contribution: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous support! Your Contributions truely keep this operation afloat! Thank you, Matt Dralle Matronics Email List Forum Administrator ________________________________________________________________________________
Date: Nov 01, 2007
Thought we were talking about a 6, my mistake. At 04:33 PM 10/31/2007, you wrote: > >The RV-8 canopy slides over the whole aft fuselage, all the way back >to the empennage fairing, so it is not possible to mount a comm >antenna on top of the aft fuselage. > >Kevin Horton > >On 31 Oct 2007, at 12:04, Richard Seiders wrote: > >> >>Sam, Put one on the belly between the gear and put a Rami type on >>top of fuse aft of canopy. No problems with this setup and less >>shadowing. >>Dick >> >> >>At 04:36 PM 10/30/2007, you wrote: >> >>> >>>Has anyone out there been flying with two comm >>>antennas mounted on their rv8 belly, just aft of the >>>fuselage spar carry through bulkhead? Any problems >>>with coupling between the antennas or reception? >>> >>>Sam Ray > > ________________________________________________________________________________
Date: Nov 01, 2007
From: Jeff Dowling <shempdowling2(at)earthlink.net>
Subject: Nose Gear Leg Intersection Fairing
For those flying the nose draggers with an intersection fairing attacthed to the cowl, have you found you need some space between the front of the fairing and gear leg fairing for stretch/movement of leg on landing? I have it pretty tight right now but am thinking a hard landing will flex the leg and crack the fairing. Thanks Shemp N915JD RV-6A, 300+ Chicago Dave/Deb wrote: > The clock in my airplane shop is digital... now what? hee hee > > ----- Original Message ----- > *From:* dougpflyrv(at)aol.com > *To:* rv-list(at)matronics.com > *Sent:* Tuesday, October 30, 2007 11:02 AM > *Subject:* Re: RV-List: Prop Mounting-clocking > > I THINK THIS SHOULD GET ALL OF US ON THE SAME PAGE.......NO > PROBLEM LINN. > DP > > > -----Original Message----- > From: linn Walters <pitts_pilot(at)bellsouth.net > > > To: rv-list(at)matronics.com > Sent: Tue, 30 Oct 2007 1:19 am > Subject: Re: RV-List: Prop Mounting-clocking > > This is what I sent in another email .... but it hasn't shown up > yet. I apologize if y'all get it twice! Also noted error from > other post :-( . Fixed in red .... like my face! We all may be > talking the same end result. > > Nice pic! > I see where the confusion comes in. I talk about when the impulse > mag fires ..... which should be in the 2:00/8:00 position as > viewed from the front, not where the prop stops. As you pull the > '2:00' prop blade around, the compression stroke will start and, > hopefully that same blade will be at 8:00 when the impulse fires. > The prop may, indeed, stop with the prop in the 2:00/8:00 position > as viewed from the cockpit on a 4 cylinder engine, but I'm pretty > sure it's different on a 6 cyl engine. In my mind it doesn't > matter where in rotation the prop stops, it's where the mag fires > and the prop 'starts' that's important. I may have been a little > premature (and harsh maybe) in my reply to DP .... and I > apologize. No offense meant. Again, I clock the prop on where > the mag fires, not where it stops. Hope this helps! > > BTW, I also caution my friends (and enemies) to get some > instruction on how to properly 'hand prop an airplane. I've had > some friends injured .... none fatally ..... in their education > process. > Linn > > Paul Besing wrote: >> Why does everyone have an overwhelming support for 2:00 then? >> >> ----- Original Message ---- >> From: linn Walters <pitts_pilot(at)bellsouth.net> >> To: rv-list(at)matronics.com >> Sent: Monday, October 29, 2007 10:22:18 PM >> Subject: Re: RV-List: Prop Mounting-clocking >> >> If your prop is mounted that way, try and prop it. Do not do >> this alone. Have someone standing by with a cell phone to call >> an ambulance ... if needed. ;-) >> Linn >> >> dougpflyrv(at)aol.com wrote: >>> 2 o'clock viewd from the cockpit >>> dp >>> >>> >>> -----Original Message----- >>> From: Paul Besing <pbesing(at)yahoo.com> >>> To: rv-list(at)matronics.com >>> Sent: Mon, 29 Oct 2007 11:09 am >>> Subject: Re: RV-List: Prop Mounting-clocking >>> >>> Ok, there is a vote for each...any one care to make a tie breaker? >>> >>> Paul Besing >>> >>> ----- Original Message ---- >>> From: linn Walters <pitts_pilot(at)bellsouth.net >>> > >>> To: rv-list(at)matronics.com >>> Sent: Sunday, October 28, 2007 10:20:31 PM >>> Subject: Re: RV-List: Prop Mounting-clocking >>> >>> FWIW, 10:00 when viewed from the cockpit. If you ever want to >>> hand prop it, that's the best position .... which is 2:00 when >>> you're facing the prop. It doesn't matter what the 'stopping' >>> position is .... if you're propping it, you want the rising >>> blade to pass through 2:00 when the impulse fires at TDC. With >>> the mags off (and a set of plugs removed is better) you can pull >>> the prop through to see what position it's in when the impulse >>> clicks. >>> Linn >>> >>> Paul Besing wrote: >>>> Ok..try it again..here goes. >>>> >>>> >>>> Ok, silly question...my prop needs to be re mounted and I can't >>>> for the life of me remember which position it looks like when >>>> stopped..when looking at it from the cockpit, is the high blade >>>> on the left or right? i.e. the blade you can see should be in >>>> the 10:00 or 2:00 position when viewed from the cockpit? >>>> >>>> Thanks. >>>> >>>> Paul Besing >>>> >>>> ----- Original Message ---- >>>> From: Paul Besing <pbesing(at)yahoo.com> >>>> To: rv-list(at)matronics.com >>>> Sent: Sunday, October 28, 2007 6:13:49 PM >>>> Subject: RV-List: Prop Mounting-clocking >>>> >>>> * >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> * >>> >>> * >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> * >>> ** >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> ** >>> ------------------------------------------------------------------------ >>> Email and AIM finally together. You've gotta check out free AOL >>> Mail >>> <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=AOLAOF00020000000970>! >>> * >>> >>> >>> >>> >>> >>> * >> >> * >> >> >> >> >> >> * > > * > > > * > > * > > href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > > * > > * > > > * ________________________________________________________________________________
Subject: Re: Nose Gear Leg Intersection Fairing
Date: Nov 01, 2007
Jeff, I had a hard enough landing to require replacing the main landing gear in my Rv-6A and the front gear did not damage the fairing at all. YMMV Ed ----- Original Message ----- From: "Jeff Dowling" <shempdowling2(at)earthlink.net> Sent: Thursday, November 01, 2007 12:34 PM Subject: RV-List: Nose Gear Leg Intersection Fairing > > For those flying the nose draggers with an intersection fairing attacthed > to the cowl, have you found you need some space between the front of the > fairing and gear leg fairing for stretch/movement of leg on landing? I > have it pretty tight right now but am thinking a hard landing will flex > the leg and crack the fairing. > > Thanks > Shemp > N915JD > RV-6A, 300+ > Chicago > > Dave/Deb wrote: >> The clock in my airplane shop is digital... now what? hee hee >> >> ----- Original Message ----- >> *From:* dougpflyrv(at)aol.com >> *To:* rv-list(at)matronics.com >> *Sent:* Tuesday, October 30, 2007 11:02 AM >> *Subject:* Re: RV-List: Prop Mounting-clocking >> >> I THINK THIS SHOULD GET ALL OF US ON THE SAME PAGE.......NO >> PROBLEM LINN. >> DP >> >> >> -----Original Message----- >> From: linn Walters <pitts_pilot(at)bellsouth.net >> > >> To: rv-list(at)matronics.com >> Sent: Tue, 30 Oct 2007 1:19 am >> Subject: Re: RV-List: Prop Mounting-clocking >> >> This is what I sent in another email .... but it hasn't shown up >> yet. I apologize if y'all get it twice! Also noted error from >> other post :-( . Fixed in red .... like my face! We all may be >> talking the same end result. >> >> Nice pic! >> I see where the confusion comes in. I talk about when the impulse >> mag fires ..... which should be in the 2:00/8:00 position as >> viewed from the front, not where the prop stops. As you pull the >> '2:00' prop blade around, the compression stroke will start and, >> hopefully that same blade will be at 8:00 when the impulse fires. The >> prop may, indeed, stop with the prop in the 2:00/8:00 position >> as viewed from the cockpit on a 4 cylinder engine, but I'm pretty >> sure it's different on a 6 cyl engine. In my mind it doesn't >> matter where in rotation the prop stops, it's where the mag fires >> and the prop 'starts' that's important. I may have been a little >> premature (and harsh maybe) in my reply to DP .... and I >> apologize. No offense meant. Again, I clock the prop on where >> the mag fires, not where it stops. Hope this helps! >> >> BTW, I also caution my friends (and enemies) to get some >> instruction on how to properly 'hand prop an airplane. I've had >> some friends injured .... none fatally ..... in their education >> process. >> Linn >> >> Paul Besing wrote: >>> Why does everyone have an overwhelming support for 2:00 then? >>> >>> ----- Original Message ---- >>> From: linn Walters <pitts_pilot(at)bellsouth.net> >>> To: rv-list(at)matronics.com >>> Sent: Monday, October 29, 2007 10:22:18 PM >>> Subject: Re: RV-List: Prop Mounting-clocking >>> >>> If your prop is mounted that way, try and prop it. Do not do >>> this alone. Have someone standing by with a cell phone to call >>> an ambulance ... if needed. ;-) >>> Linn >>> >>> dougpflyrv(at)aol.com wrote: >>>> 2 o'clock viewd from the cockpit >>>> dp >>>> >>>> >>>> -----Original Message----- >>>> From: Paul Besing <pbesing(at)yahoo.com> >>>> To: rv-list(at)matronics.com >>>> Sent: Mon, 29 Oct 2007 11:09 am >>>> Subject: Re: RV-List: Prop Mounting-clocking >>>> >>>> Ok, there is a vote for each...any one care to make a tie breaker? >>>> >>>> Paul Besing >>>> >>>> ----- Original Message ---- >>>> From: linn Walters <pitts_pilot(at)bellsouth.net >>>> > >>>> To: rv-list(at)matronics.com >>>> Sent: Sunday, October 28, 2007 10:20:31 PM >>>> Subject: Re: RV-List: Prop Mounting-clocking >>>> >>>> FWIW, 10:00 when viewed from the cockpit. If you ever want to >>>> hand prop it, that's the best position .... which is 2:00 when >>>> you're facing the prop. It doesn't matter what the 'stopping' >>>> position is .... if you're propping it, you want the rising >>>> blade to pass through 2:00 when the impulse fires at TDC. With >>>> the mags off (and a set of plugs removed is better) you can pull >>>> the prop through to see what position it's in when the impulse >>>> clicks. >>>> Linn >>>> >>>> Paul Besing wrote: >>>>> Ok..try it again..here goes. >>>>> >>>>> >>>>> Ok, silly question...my prop needs to be re mounted and I can't >>>>> for the life of me remember which position it looks like when >>>>> stopped..when looking at it from the cockpit, is the high blade >>>>> on the left or right? i.e. the blade you can see should be in >>>>> the 10:00 or 2:00 position when viewed from the cockpit? >>>>> >>>>> Thanks. >>>>> >>>>> Paul Besing >>>>> >>>>> ----- Original Message ---- >>>>> From: Paul Besing <pbesing(at)yahoo.com> >>>>> To: rv-list(at)matronics.com >>>>> Sent: Sunday, October 28, 2007 6:13:49 PM >>>>> Subject: RV-List: Prop Mounting-clocking >>>>> >>>>> * >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> * >>>> >>>> * >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> * >>>> ** >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> ** >>>> ------------------------------------------------------------------------ >>>> Email and AIM finally together. You've gotta check out free AOL >>>> Mail >>>> >>>> <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=AOLAOF00020000000970>! >>>> * >>>> >>>> >>>> >>>> >>>> >>>> * >>> >>> * >>> >>> >>> >>> >>> >>> * >> >> * >> >> >> >> >> >> * >> >> * >> >> >> href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List >> href="http://forums.matronics.com">http://forums.matronics.com >> >> * >> >> * >> >> >> * > > > ________________________________________________________________________________
Date: Nov 01, 2007
Yes ----- Original Message ----- From: "Jeff Dowling" <shempdowling2(at)earthlink.net> Sent: Thursday, November 01, 2007 10:34 AM Subject: RV-List: Nose Gear Leg Intersection Fairing > > For those flying the nose draggers with an intersection fairing attacthed > to the cowl, have you found you need some space between the front of the > fairing and gear leg fairing for stretch/movement of leg on landing? I > have it pretty tight right now but am thinking a hard landing will flex > the leg and crack the fairing. > > Thanks > Shemp > N915JD > RV-6A, 300+ > Chicago > > Dave/Deb wrote: >> The clock in my airplane shop is digital... now what? hee hee >> >> ----- Original Message ----- >> *From:* dougpflyrv(at)aol.com >> *To:* rv-list(at)matronics.com >> *Sent:* Tuesday, October 30, 2007 11:02 AM >> *Subject:* Re: RV-List: Prop Mounting-clocking >> >> I THINK THIS SHOULD GET ALL OF US ON THE SAME PAGE.......NO >> PROBLEM LINN. >> DP >> >> >> -----Original Message----- >> From: linn Walters <pitts_pilot(at)bellsouth.net >> > >> To: rv-list(at)matronics.com >> Sent: Tue, 30 Oct 2007 1:19 am >> Subject: Re: RV-List: Prop Mounting-clocking >> >> This is what I sent in another email .... but it hasn't shown up >> yet. I apologize if y'all get it twice! Also noted error from >> other post :-( . Fixed in red .... like my face! We all may be >> talking the same end result. >> >> Nice pic! >> I see where the confusion comes in. I talk about when the impulse >> mag fires ..... which should be in the 2:00/8:00 position as >> viewed from the front, not where the prop stops. As you pull the >> '2:00' prop blade around, the compression stroke will start and, >> hopefully that same blade will be at 8:00 when the impulse fires. The >> prop may, indeed, stop with the prop in the 2:00/8:00 position >> as viewed from the cockpit on a 4 cylinder engine, but I'm pretty >> sure it's different on a 6 cyl engine. In my mind it doesn't >> matter where in rotation the prop stops, it's where the mag fires >> and the prop 'starts' that's important. I may have been a little >> premature (and harsh maybe) in my reply to DP .... and I >> apologize. No offense meant. Again, I clock the prop on where >> the mag fires, not where it stops. Hope this helps! >> >> BTW, I also caution my friends (and enemies) to get some >> instruction on how to properly 'hand prop an airplane. I've had >> some friends injured .... none fatally ..... in their education >> process. >> Linn >> >> Paul Besing wrote: >>> Why does everyone have an overwhelming support for 2:00 then? >>> >>> ----- Original Message ---- >>> From: linn Walters <pitts_pilot(at)bellsouth.net> >>> To: rv-list(at)matronics.com >>> Sent: Monday, October 29, 2007 10:22:18 PM >>> Subject: Re: RV-List: Prop Mounting-clocking >>> >>> If your prop is mounted that way, try and prop it. Do not do >>> this alone. Have someone standing by with a cell phone to call >>> an ambulance ... if needed. ;-) >>> Linn >>> >>> dougpflyrv(at)aol.com wrote: >>>> 2 o'clock viewd from the cockpit >>>> dp >>>> >>>> >>>> -----Original Message----- >>>> From: Paul Besing <pbesing(at)yahoo.com> >>>> To: rv-list(at)matronics.com >>>> Sent: Mon, 29 Oct 2007 11:09 am >>>> Subject: Re: RV-List: Prop Mounting-clocking >>>> >>>> Ok, there is a vote for each...any one care to make a tie breaker? >>>> >>>> Paul Besing >>>> >>>> ----- Original Message ---- >>>> From: linn Walters <pitts_pilot(at)bellsouth.net >>>> > >>>> To: rv-list(at)matronics.com >>>> Sent: Sunday, October 28, 2007 10:20:31 PM >>>> Subject: Re: RV-List: Prop Mounting-clocking >>>> >>>> FWIW, 10:00 when viewed from the cockpit. If you ever want to >>>> hand prop it, that's the best position .... which is 2:00 when >>>> you're facing the prop. It doesn't matter what the 'stopping' >>>> position is .... if you're propping it, you want the rising >>>> blade to pass through 2:00 when the impulse fires at TDC. With >>>> the mags off (and a set of plugs removed is better) you can pull >>>> the prop through to see what position it's in when the impulse >>>> clicks. >>>> Linn >>>> >>>> Paul Besing wrote: >>>>> Ok..try it again..here goes. >>>>> >>>>> >>>>> Ok, silly question...my prop needs to be re mounted and I can't >>>>> for the life of me remember which position it looks like when >>>>> stopped..when looking at it from the cockpit, is the high blade >>>>> on the left or right? i.e. the blade you can see should be in >>>>> the 10:00 or 2:00 position when viewed from the cockpit? >>>>> >>>>> Thanks. >>>>> >>>>> Paul Besing >>>>> >>>>> ----- Original Message ---- >>>>> From: Paul Besing <pbesing(at)yahoo.com> >>>>> To: rv-list(at)matronics.com >>>>> Sent: Sunday, October 28, 2007 6:13:49 PM >>>>> Subject: RV-List: Prop Mounting-clocking >>>>> >>>>> * >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> * >>>> >>>> * >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> * >>>> ** >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> ** >>>> ------------------------------------------------------------------------ >>>> Email and AIM finally together. You've gotta check out free AOL >>>> Mail >>>> >>>> <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=AOLAOF00020000000970>! >>>> * >>>> >>>> >>>> >>>> >>>> >>>> * >>> >>> * >>> >>> >>> >>> >>> >>> * >> >> * >> >> >> >> >> >> * >> >> * >> >> >> href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List >> href="http://forums.matronics.com">http://forums.matronics.com >> >> * >> >> * >> >> >> * > > > ________________________________________________________________________________
Date: Nov 01, 2007
Yes. My upper nose gear fairing rubs against the leg fairing and though not damaged, it does scuff the paint off. This would have been prevented had I the foresight to place a few hundred pounds of weight in the cockpit to simulate gross weight conditions prior to locating and installing that fairing. At the least, prior to locating the fairing permanently, I suggest positioning it so that some gap exists between it and the forward nose of the leg fairing when the plane is empty and at rest. Rick Galati RV-6A "Darla!" RV-8 FWF ________________________________________________________________________________
Date: Nov 02, 2007
Had my first RV-8A set up this way and never ran into any problems......... ....until it went undrwater that is. Mike Robertson > Date: Tue, 30 Oct 2007 13:36:39 -0700> From: sam95037(at)yahoo.com> Subject: RV-List: RV8 comm antenna spacing> To: rv-list(at)matronics.com> > --> RV-Lis t message posted by: sam ray > > Has anyone out there b een flying with two comm> antennas mounted on their rv8 belly, just aft of the> fuselage spar carry through bulkhead? Any problems> with coupling betw een the antennas or reception?> > Sam Ray> > ______________________________ =================> > > _________________________________________________________________ Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop by today. http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_Oc tWLtagline ________________________________________________________________________________
Date: Nov 02, 2007
It depends on if you have two mags or if you are running one electronic ign ition. If you are running two mags then normally, but not always, it is up per left and lower right. The best way to trace the leads from the mags to their respective plugs. Mike Robertson From: Knicholas2(at)aol.comDate: Tue, 30 Oct 2007 20:16:42 -0400Subject: RV-Li st: which plugs are from the left mag?To: rv-list(at)matronics.com My engine runs rough on the left mag. Which spark plugs are fed from the l eft mag in a Lycoming 0-320 E2D? Kim Nicholas Seattle See what's ne _________________________________________________________________ Windows Live Hotmail and Microsoft Office Outlook ' together at last. - Get it now. http://office.microsoft.com/en-us/outlook/HA102225181033.aspx?pid=CL10062 6971033 ________________________________________________________________________________
Date: Nov 02, 2007
Had my RV9A set up this way. Never any problems. Chuck ----- Original Message ----- From: Mike Robertson To: rv-list(at)matronics.com Sent: Friday, November 02, 2007 8:55 AM Subject: RE: RV-List: RV8 comm antenna spacing Had my first RV-8A set up this way and never ran into any problems.............until it went undrwater that is. Mike Robertson ------------------------------------------------------------------------- ----- > Date: Tue, 30 Oct 2007 13:36:39 -0700 > From: sam95037(at)yahoo.com > Subject: RV-List: RV8 comm antenna spacing > To: rv-list(at)matronics.com > > > Has anyone out there been flying with two comm > antennas mounted on their rv8 belly, just aft of the > fuselage spar carry through bulkhead? Any problems > with coupling between the antennas or reception? > > Sam Ray > ________________________________________________________________________________
Subject: Precision Airmotive - on Carbs
Date: Nov 03, 2007
The following cannot be true!!!! Does anyone have any other information? Doug Gray ------------------------------- Peter Nielson Product Support Mgr. Precision Airmotive LLC 14800 40th Ave NE Marysville, WA 98271 360-651-8282 Subject: Letter to Industry Here is the text of a letter we are sending out to the industry today. Precision Airmotive LLC has discontinued sales of all float carburetors and component parts as of November 1, 2007. This unfortunate situation is a result of our inability to obtain products liability insurance for the product line. Precision Airmotive LLC and its 43 employees currently manufacture and support the float carburetors used in nearly all carbureted general aviation aircraft flying today. Precision has been the manufacturer of these carburetors since 1990. These FAA-approved carburetors were designed as early as the 1930's and continue to fly over a million flight hours a year. After decades of service, the reliability of these carburetors speaks for itself. Nonetheless, Precision has seen its liability insurance premiums rise dramatically, to the point that the premium now exceeds the total sales dollars for this entire product line. In the past, we have absorbed that cost, with the hope that the aviation industry as a whole would be able to help address this issue faced by Precision Airmotive, as well as many other small aviation companies. Our efforts have been unsuccessful. This year, despite the decades of reliable service and despite the design approval by the FAA, Precision Airmotive has been unable to obtain products liability insurance for the carburetor product line. While we firmly believe that the product is safe, as does the FAA, and well supported by dedicated people both at Precision and at our independent product support centers, unfortunately the litigation costs for defending the carburetor in court are unsustainable for a small business such as Precision. Therefore, as of November 1, 2007, Precision Airmotive LLC has been left with no choice but to cease production and support of its float carburetor product line. We are working with the engine manufacturers and others in the industry in an attempt to minimize the impact on general aviation and to provide future support for this product line. There is a substantial quantity of parts and carburetors stocked at our distributors which should be sufficient to support the industry for a short time. ________________________________________________________________________________
Date: Nov 02, 2007
OK, I will bite, if no one else will. What happened that the plane that it went underwater- if you would care to share. I doubt that your 8 is any better at being a submarine than my 6 ! Illinois Keith 3LF From: Mike <mailto:mrobert569(at)hotmail.com> Robertson Sent: Friday, November 02, 2007 8:55 AM Subject: RE: RV-List: RV8 comm antenna spacing Had my first RV-8A set up this way and never ran into any problems.............until it went undrwater that is. Mike Robertson _____ > Date: Tue, 30 Oct 2007 13:36:39 -0700 > From: sam95037(at)yahoo.com > Subject: RV-List: RV8 comm antenna spacing > To: rv-list(at)matronics.com > > > Has anyone out there been flying with two comm > antennas mounted on their rv8 belly, just aft of the > fuselage spar carry through bulkhead? Any problems > with coupling between the antennas or reception? > > Sam Ray > ________________________________________________________________________________
Date: Nov 02, 2007
That is unbelievable. I checked their web site and confirmed that it is true. The product liability issue they speak of is not a new story for them. About a year ago I needed to overhaul one of their carbs and tried to order an overhaul manual from Spruce. They had it in their catalog for something like $30.00. I was told that the old overhaul manual was no longer offered and now you need to buy the new manual with the one year subscription for updates for something like fifteen hundred dollars. I suspected that it was just a way for them to take overhaul work away from small shops that were not authorized service centers since you are not legally allowed to overhaul a carb unless you have the current maintenance manual according to the FAA. I called and was told that the truth was that they needed to do the overhauls in house because their liability insurance was so high that they were not making any money. What is the world coming to? Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Doug Gray Sent: Friday, November 02, 2007 8:09 PM Subject: RV-List: Precision Airmotive - on Carbs The following cannot be true!!!! Does anyone have any other information? Doug Gray ------------------------------- Peter Nielson Product Support Mgr. Precision Airmotive LLC 14800 40th Ave NE Marysville, WA 98271 360-651-8282 Subject: Letter to Industry Here is the text of a letter we are sending out to the industry today. Precision Airmotive LLC has discontinued sales of all float carburetors and component parts as of November 1, 2007. This unfortunate situation is a result of our inability to obtain products liability insurance for the product line. Precision Airmotive LLC and its 43 employees currently manufacture and support the float carburetors used in nearly all carbureted general aviation aircraft flying today. Precision has been the manufacturer of these carburetors since 1990. These FAA-approved carburetors were designed as early as the 1930's and continue to fly over a million flight hours a year. After decades of service, the reliability of these carburetors speaks for itself. Nonetheless, Precision has seen its liability insurance premiums rise dramatically, to the point that the premium now exceeds the total sales dollars for this entire product line. In the past, we have absorbed that cost, with the hope that the aviation industry as a whole would be able to help address this issue faced by Precision Airmotive, as well as many other small aviation companies. Our efforts have been unsuccessful. This year, despite the decades of reliable service and despite the design approval by the FAA, Precision Airmotive has been unable to obtain products liability insurance for the carburetor product line. While we firmly believe that the product is safe, as does the FAA, and well supported by dedicated people both at Precision and at our independent product support centers, unfortunately the litigation costs for defending the carburetor in court are unsustainable for a small business such as Precision. Therefore, as of November 1, 2007, Precision Airmotive LLC has been left with no choice but to cease production and support of its float carburetor product line. We are working with the engine manufacturers and others in the industry in an attempt to minimize the impact on general aviation and to provide future support for this product line. There is a substantial quantity of parts and carburetors stocked at our distributors which should be sufficient to support the industry for a short time. ________________________________________________________________________________
Subject: Charging system failure cuts short a long x-country trip
Date: Nov 03, 2007
I first flew to Memphis to enter the Memphis 100 race. I did it. Then on to Atlanta to visit family. The next day I flew to Kitty Hawk. That was uneventful other than flying over water and turbulence on approach and departure from the 15 knots gusting 25. An aerial view is here: http://home.pcisys.net/~ronlee/RV6A/KittyHawk/KittyHawkAirSmall.jpg This is my aircraft with the memorial in the background: http://home.pcisys.net/~ronlee/RV6A/KittyHawk/KittyHawkGroundSmall.jpg I thought they took off from the hill but no. It was flat terrain north of the hill. The starting point is here: http://home.pcisys.net/~ronlee/RV6A/KittyHawk/FirstStartSmall.jpg And the end of the first flight here: http://home.pcisys.net/~ronlee/RV6A/KittyHawk/FirstEndSmall.jpg I refueled at an airport west of Kitty Hawk and planned on getting back to Atlanta right around sunset. Unfortunately, around Rayleigh the voltage went to just over 12 and the amperage went negative. I had been hearing a static like popping since leaving Kitty Hawk and someone suggested that it was arcing from the failure. I told approach that I was getting lower than the approaching cloud deck and decided to make a precautionary landing at Sanford NC (KTTA). No mechanics were around so I got a rental car and went into town for the night. The next morning I replaced the voltage regulator with no success so I removed the lower cowl and found that the battery ring terminal wire on the alternator B point was fatigued and broken. It was previously bent to make proper contact. I had a mechanic install a new ring terminal but that did not make the alternator work. Using advice from a primo mechanic at home (and not being able to find a replacement alternator), I bought a battery for my Blazer, wire, ring terminals and added the new battery in parallel with my aircraft battery. Nothing blew up so I prepared to leave. The engine started normally and to my surprise the alternator worked. It worked all the way home with four restarts. On this trip I flew below an overcast with less than 6000' between me and the ground (perhaps 1500'). I flew over a broken cloud layer. I flew in less than 100 nm visibility. As I approached Springfield MO towards sunset, I descended thinking that I was about to overfly a cloud layer. Nope. It was haze. Silly me. It made more sense to stay where I could see ground to the sides anyway. I had planned on going to Key West and the Bahamas but elected to get home to fix the alternator problem. TS Noel would have kept me from doing that anyway. In retrospect, the alternator to bus wire/ring terminal should have been made better long ago. That will be corrected. I am now in the process of trying to decide which readily available alternator I will install. The current one will not fly again. I also did not know what my safe flying time was when the ring terminal broke. Perhaps I could have flown another two hours (4-5 amp current draw and one EI) on a PC925 battery. But since I did not know for sure, I played it safe and landed at the nearest airport. With the truck battery, it may well be 20 hours. Regardless, I did buy a battery charger just in case. I did find out that the RV community is awesome. Three guys stopped by to offer assistance (I did the repairs on the ramp). The FBO at Sanford was great as was the mechanic shop. Stopping at new airports is fun. I expanded my flight experience beyond CAVU but nowhere near scud running. The haze illusions were baffling but I just reacted with safe flight adjustments. ________________________________________________________________________________
From: "Kyle Boatright" <kboatright1(at)comcast.net>
Subject: Ignition Problem Followup
Date: Nov 03, 2007
As a follow up on this thread, last week I spoke with Electroair's technical support folks (Jeff Rose and Mike Kobylik) regarding my ignition problem. Both indicated that the symptoms sounded like a sensor problem, so after doing a little troubleshooting, I ordered another timing sensor. This is the little 3/8" probe that inserts into the timing housing, which replaces the right mag in a single mag/single EI system. >From these discussions, both Jeff and Mike indicated that they have upgraded the timing pick-up since mine was purchased 7 or 8 years ago. They have improved both the potting material that surrounds the wires that terminate in the probe and have improved the wire wrap they use. Both of these changes are designed to improve the reliability by preventing fatigue breaks in the probe wires, which was their best guess as to what caused my problem. Anyway, when I dug into the system this morning, it turned out that I'd suffered a mechanical failure of sorts. The probe (which determines crank position by counting teeth on a rotating gear) had slid into the gear. Eventually, the gear cut a groove into the pick-up and failed the probe. How or when did the probe slip? No idea. As I recall, the two set screws that hold the probe in place seemed tight before I removed them today. Of course, I wasn't looking for loose set screws and may not have noticed if they were loose. Based on this problem, I may add "check EI probe gap" and "retorque EI set screws" to my conditional inspection list. My guess is that it'll add 10 minutes to the inspection. After fixing the problem what did I do? I went flying, of course. I am always amazed at the difference in performance when my airplane is light vs heavy. Last weekend, we were probably approaching my plane's gross of 1675 lbs, and the plane flew just fine. But today, at 1300 lbs or so, what a difference! I swear the tail was up and I was off the ground after a roll of a couple hundred feet. Followed by an amazing climb out of the traffic pattern. Yeeha!!! All I can say is build 'em light... Kyle Boatright RV-6 N46KB 160 HP Aymar/Demuth ----- Original Message ----- From: Kyle Boatright To: rv-list(at)matronics.com Sent: Sunday, October 28, 2007 8:33 PM Subject: RV-List: Ignition Problem - Troubleshooting We went from Atlanta to College Station, TX this weekend to see my wife's Aggies play (and lose to) Kansas.. Today, we made the return trip. And about 30 miles from home the engine lost a little power (~100 rpm). Some in-flight troubleshooting showed that the Electroair ignition that I have on the right side had quit. I flipped the on/off switch several times, reset the breaker, etc. and the ignition didn't come back to life. That being the case, I left it off for the remainder of the flight and made sure to stay high enough to glide to an airstrip if the other ignition system (a magneto) decided to take the day off too. And once we landed, I flipped it back on and voila', it was working fine. Which was a good thing. Sorta... Because troubleshooting an intermittent problem is a pain in the tuckus. I plan to check all of the connections between the battery, the breaker, the switch, and the ignition system. I'll check the ground connections too. Beyond that, I'll call the folks who are now supporting the ignition and see if they have any ideas. Any other thoughts on how to troubleshoot this problem? Thanks in advance, Kyle Boatright N46KB ________________________________________________________________________________
Date: Nov 04, 2007
Subject: List Fund Raiser
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. I've got a bunch of really nice incentive gifts this year. There's really something for everyone! Please make a Contribution today: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 05, 2007
Unfortunately, this is very true. If you go to Precision's website this is the very first thing you see. Let's hope that they find a buyer for the c arb line very soon. Mike Robertson Das Fed > Subject: RV-List: Precision Airmotive - on Carbs> From: dgra1233@bigpond. net.au> To: rv-list(at)matronics.com> Date: Sat, 3 Nov 2007 11:08:43 +1100> > ollowing cannot be true!!!!> Does anyone have any other information?> > Dou g Gray> > -------------------------------> > Peter Nielson> Product Support Mgr.> Precision Airmotive LLC> 14800 40th Ave NE> Marysville, WA 98271> > 360-651-8282 > > Subject: Letter to Industry> > Here is the text of a lette r we are sending out to the industry today.> > Precision Airmotive LLC has discontinued sales of all float> carburetors and component parts as of Nove mber 1, 2007. This> unfortunate situation is a result of our inability to o btain products> liability insurance for the product line. Precision Airmoti ve LLC and> its 43 employees currently manufacture and support the float> c arburetors used in nearly all carbureted general aviation aircraft> flying today. Precision has been the manufacturer of these> carburetors since 1990 . These FAA-approved carburetors were designed> as early as the 1930's and continue to fly over a million flight hours> a year. After decades of servi ce, the reliability of these> carburetors speaks for itself.> > Nonetheless , Precision has seen its liability insurance premiums rise> dramatically, t o the point that the premium now exceeds the total> sales dollars for this entire product line. In the past, we have> absorbed that cost, with the hop e that the aviation industry as a> whole would be able to help address this issue faced by Precision> Airmotive, as well as many other small aviation companies. Our> efforts have been unsuccessful. > > This year, despite the decades of reliable service and despite the> design approval by the FAA, Pr ecision Airmotive has been unable to> obtain products liability insurance f or the carburetor product line. > While we firmly believe that the product is safe, as does the FAA, and> well supported by dedicated people both at P recision and at our> independent product support centers, unfortunately the litigation> costs for defending the carburetor in court are unsustainable for a> small business such as Precision.> > Therefore, as of November 1, 20 07, Precision Airmotive LLC has been> left with no choice but to cease prod uction and support of its float> carburetor product line. > > We are workin g with the engine manufacturers and others in the> industry in an attempt t o minimize the impact on general aviation and> to provide future support fo r this product line. There is a> substantial quantity of parts and carburet ors stocked at our> distributors which should be sufficient to support the =====================> > > _________________________________________________________________ ! ilnews ________________________________________________________________________________
Date: Nov 05, 2007
Most of the folks that have been around the rv-list for a while know about this already sop I did not expand on it. I built the -8A out in Hawaii in 98. It was about the 4th quick build RV-8 kit that Van's sold. Anyway, wh en I left Hawaii on a job change the plane stayed there with my build partn er. A couple years later he sold it to another very good friend. He went through the entire plane and got it just the way he wanted it, to include a full IFR panel with a Garmin 430, an SL30 Nav/Com, an EFIS D-10, and a Vis ion Microsystem's engine monitor. About a month later he was flying betwee n Oahu and Kauai and the engine went to idle. When he checked the throttle control he found it had that disconnected feel. With that big Hartzell co nstant speed prop going to flat pitch it glided about like a rock right dow n to the point of a water landing. The plane snuffed and flipped over on i mpact. Due to good Hooker seat belts my friend wasn't hurt and got out with in about 20 seconds. He had been on flight following and alerted them to t he problem. The Coast Guard was alerted and off the ground before he hit t he water. They found him and he was rescued within 20 minutes. He stated the the saddest part of all this was that the plane stayed afloat for about one minute, then the trapped air in the fuselage gave way and the plane sa nk out of sight. With the excellent water visibility in Hawaii he was able to watch the plane sink gracefully out of sight, the radios and instrument lights still burning brightly. The spot that the plane went down was over a very deep trench between the t wo islands, so recovery was totally out of the question. We will never kno w exactly what happened. Such a sad end to a beautiful plane that only had 75 total hours. Mike Robertson Plane 5 and still building From: khedrick(at)frontiernet.netTo: rv-list(at)matronics.comSubject: RE: RV-List : RV8 comm antenna spacingDate: Fri, 2 Nov 2007 20:39:09 -0500 OK, I will bite, if no one else will. What happened that the plane that i t went underwater- if you would care to share. I doubt that your 8 is an y better at being a submarine than my 6 ! Illinois Keith 3LF From: Mike Robertson Sent: Friday, November 02, 2007 8:55 AM Subject: RE: RV-List: RV8 comm antenna spacing Had my first RV-8A set up this way and never ran into any problems......... ....until it went undrwater that is. Mike Robertson > Date: Tue, 30 Oct 2007 13:36:39 -0700> From: sam95037(at)yahoo.com> Subject: RV-List: RV8 comm antenna spacing> To: rv-list(at)matronics.com> > --> RV-Lis t message posted by: sam ray > > Has anyone out there b een flying with two comm> antennas mounted on their rv8 belly, just aft of the> fuselage spar carry through bulkhead? Any problems> with coupling betw een the antennas or reception?> > Sam Ray> _________________________________________________________________ Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop by today. http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_Oc tWLtagline ________________________________________________________________________________
Date: Nov 07, 2007
From: "Michael D. Cencula" <matronics(at)cencula.com>
Subject: Re: Aileron trailing edge skislope effect
RV-Listers, Thanks all for the comments and suggestions. I thought I'd post my solution in case anyone runs into the same issue. I ended up ordering new ribs from Vans that didn't have prepunched flanges, then match drilled them to the skins. They actually gave me a break on the price, so all four ribs came to only about $15! If interested, you can see how the fit compares: Original prepunched rib: http://www.our7a.com/images/20071024-02-tn.jpg New non-prepunched rib: http://www.our7a.com/images/20071106-04-tn.jpg Best regards, Mike Cencula RV-7A wings Bob wrote: > > After looking at the pictures, I don't see the problem. If this is > all you have to be worried about, then you are building a real fine RV. > > My RV has some cosmetic imperfections, dents, smiles, scratches > whatever, now 5 years into flying, things that I thought were so > important, I can not even find them, let alone allow it to bother me. > > This is sort of in the category of "who cares?" I would never have > noticed without the straight edge in the picture. If you are building > for flying, then move on, if you are building an Award Winner that > will be exhibited in some technical museum, keep redoing it until it > is perfect. > > If after flying the RV for a few years and it still bothers you, then > rebuild it. But, by then you will be having way too much fun to worry > about cosmetic accuracy. > > > Bob > RV6 "Wicked Witch of the West" > > > At 07:15 PM 10/24/07, you wrote: >> >> >> Greetings listers, >> >> I'm working on my ailerons (RV-7A) and seem to be getting a skislope >> effect at >> the trailing edge near the ribs. Some places are worse than others. ________________________________________________________________________________
Date: Nov 07, 2007
Subject: What Listers Are Saying...
November is Matronics List Fund Raiser month and a number people been sending some really nice comments regarding the Lists. I thought I'd share a few below. The Lists are completely supported by your Contributions. All of the bills for new hardware, connectivity, and electricity are paid by the generous support of the List members. Please make your Contribution today to support the continued operation of the List and Forums: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ================= What Listers Are Saying ================ Flying and building is much safer with this List!! Robert D. Thanks for having and maintaining such a great resource to all of us builders and flyers. Wayne E. Love the fact that you haven't caved to advertising! Peter J. ..a great resource!! Robert C. Not building at the moment, but the Lists keeps me right up to date with what's going on. Chris D. The web forum has been running great. James O. I enjoy this [List] site very much... Paul C. This is a great list! Albert G. ..a valuable resource! Roger C. I am deployed to Pakistan right now, and being able to go on-line and keep up with the aircraft discussions helps keep the aircraft building dream alive in my mind! Gregory C. ..fantastic service! Roger M. ..clearly a work of passion! Mike C. It is a great service to us! Kevin C. The list is a wonderful resource... Ralph O. [The Lists] have been the single greatest resource in building my RV-9A and now my RV-10. Albert G. ..a valuable and always improving service. Dick S. STILL THE BEST BARGAIN AROUND!! Owen B. ..such a valuable tool. Jon M. [The Lists] have been an invaluable resource for me as a Zenith homebuilder. David G. The opportunity to meet (on line at least) many other interesting builders and to make some new friends is truly appreciated. Albert G. ________________________________________________________________________________
Subject: Another RV6 built tail for sale
Date: Nov 07, 2007
In addition, EAA 186 (Manassas, Virginia) has a completed (except for fiber glass work) RV-6 tail available. Asking $1000. We also have a pair of the aluminum angle for longerons. Asking $50. Contact me off line at: Marty Heller 703-732-3264 marty_away(at)hotmail.com RV-7 (fitting roll bar) > From: dale1rv6(at)comcast.net> To: rv-list(at)matronics.com> Subject: RV-List: RV6 tail & wing kit for sale> Date: Wed, 7 Nov 2007 01:27:31 -0500> > --> R V-List message posted by: "Dale Walter" > > The EAA c hapter in Fulton NY, near Syracuse, has had this kit for a few> years, stor ed in a big, dry, wood box. The original builder made a good> aluminum fram e to hold the wings, and drilled the skins and ribs in both> tail and wings . He had not started the dimpling. Tail dates back to 1994.> All plastic wa s removed. Frame included. Any reasonable offer will be> accepted to a good home. Proceeds go to the chapter. Please contact me off> list.> > Thanks,> =================> > > _________________________________________________________________ Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop by today. http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_Oc tWLtagline ________________________________________________________________________________
Subject: Aileron trailing edge skislope effect
Date: Nov 07, 2007
You did the right thing ... ! Jan -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael D. Cencula Sent: 07 November 2007 06:02 Subject: Re: RV-List: Aileron trailing edge skislope effect RV-Listers, Thanks all for the comments and suggestions. I thought I'd post my solution in case anyone runs into the same issue. I ended up ordering new ribs from Vans that didn't have prepunched flanges, then match drilled them to the skins. They actually gave me a break on the price, so all four ribs came to only about $15! If interested, you can see how the fit compares: Original prepunched rib: http://www.our7a.com/images/20071024-02-tn.jpg New non-prepunched rib: http://www.our7a.com/images/20071106-04-tn.jpg Best regards, Mike Cencula RV-7A wings Bob wrote: > > After looking at the pictures, I don't see the problem. If this is > all you have to be worried about, then you are building a real fine RV. > > My RV has some cosmetic imperfections, dents, smiles, scratches > whatever, now 5 years into flying, things that I thought were so > important, I can not even find them, let alone allow it to bother me. > > This is sort of in the category of "who cares?" I would never have > noticed without the straight edge in the picture. If you are building > for flying, then move on, if you are building an Award Winner that > will be exhibited in some technical museum, keep redoing it until it > is perfect. > > If after flying the RV for a few years and it still bothers you, then > rebuild it. But, by then you will be having way too much fun to worry > about cosmetic accuracy. > > > Bob > RV6 "Wicked Witch of the West" > > > At 07:15 PM 10/24/07, you wrote: >> >> >> Greetings listers, >> >> I'm working on my ailerons (RV-7A) and seem to be getting a skislope >> effect at >> the trailing edge near the ribs. Some places are worse than others. ________________________________________________________________________________
Subject: Re: Aileron trailing edge skislope effectAileron trailing edge
skislope effect
Date: Nov 08, 2007
Wow! what did vans say re such a noticable missmatch? Charlie Heathco ________________________________________________________________________________
Subject: Question for A&P Types (or anyone)
Date: Nov 08, 2007
Hi all, I am planning to start my first condition inspection on my -6 today. It was due by the end of the month in October, but travel got in my way of completing it. I would like to get the oil warmed up good before draining it and also doing the compression check. It seems I didn't really get it warmed up good last time I tried to just take it out and run it up. Am I allowed to do a solo flight to warm the oil up as a test flight even though it is not current? Thanks Tim ________________________________________________________________________________
Subject: Re: Question for A&P Types (or anyone)
Date: Nov 08, 2007
NO!!! -----Original Message----- From: Tim Bryan <n616tb(at)btsapps.com> Sent: Thu, 8 Nov 2007 2:50 pm Subject: RV-List: Question for A&P Types (or anyone) Hi all, =C2- I am planning to start my first condition inspection on my -6 today.=C2- I t was due by the end of the month in October, but travel got in my way of co mpleting it.=C2- I would like to get the oil warmed up good before drainin g it and also doing the compression check.=C2- It seems I didn=99t r eally get it warmed up good last time I tried to just take it out and run it up.=C2- Am I allowed to do a solo flight to warm the oil up as a test fli ght even though it is not current? =C2- Thanks Tim ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http ://mail.aol.com ________________________________________________________________________________
Date: Nov 08, 2007
Not if your operating limitations are like everyone else's. But you could do a compression check as warm as you can get it, along with the rest of the condition inspection, then sign it off and fly it assuming the compression check was OK. Then change the oil after the inspection. I wouldn't think the FAA would be thrilled to find out it was out of annual if anything happened, but your insurance company would be overjoyed... Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Thursday, November 08, 2007 12:50 PM Subject: RV-List: Question for A&P Types (or anyone) Hi all, I am planning to start my first condition inspection on my -6 today. It was due by the end of the month in October, but travel got in my way of completing it. I would like to get the oil warmed up good before draining it and also doing the compression check. It seems I didn't really get it warmed up good last time I tried to just take it out and run it up. Am I allowed to do a solo flight to warm the oil up as a test flight even though it is not current? Thanks Tim ________________________________________________________________________________
Date: Nov 08, 2007
Hi Tim, I believe you need a ferry permit to fly it legally. Check with the local FSDO to see what they have to say about this. It shouldn't be a big deal. Dave RV6 _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of dougpflyrv(at)aol.com Sent: Thursday, November 08, 2007 3:12 PM Subject: Re: RV-List: Question for A&P Types (or anyone) NO!!! -----Original Message----- From: Tim Bryan <n616tb(at)btsapps.com> Sent: Thu, 8 Nov 2007 2:50 pm Subject: RV-List: Question for A&P Types (or anyone) Hi all, I am planning to start my first condition inspection on my -6 today. It was due by the end of the month in October, but travel got in my way of completing it. I would like to get the oil warmed up good before draining it and also doing the compression check. It seems I didn't really get it warmed up good last time I tried to just take it out and run it up. Am I allowed to do a solo flight to warm the oil up as a test flight even though it is not current? Thanks Tim ========== ution">http://www.matronics.com/contribution ========== or?RV-List">http://www.matronics.com/Navigator?RV-List ========== p://forums.matronics.com ========== _____ size=2 width="100%" align=center> Email and AIM finally together. You've gotta check out free AOL Mail <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=A OLAOF00020000000970> ! ________________________________________________________________________________
Date: Nov 08, 2007
Your biggest risk is insurance will not cover it during that time. Dale _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Thursday, November 08, 2007 3:50 PM Subject: RV-List: Question for A&P Types (or anyone) Hi all, I am planning to start my first condition inspection on my -6 today. It was due by the end of the month in October, but travel got in my way of completing it. I would like to get the oil warmed up good before draining it and also doing the compression check. It seems I didn't really get it warmed up good last time I tried to just take it out and run it up. Am I allowed to do a solo flight to warm the oil up as a test flight even though it is not current? Thanks Tim ________________________________________________________________________________
Date: Nov 08, 2007
No, for all intents and purposes your aircraft is illegal to fly, just as y ou are when your medical expires. ________________________________________________________________________________
Date: Nov 08, 2007
Sure, you just can't fly it until you finish and sign off the condition inspection. Bruce <http://www.glasair.org/> www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Thursday, November 08, 2007 3:50 PM Subject: RV-List: Question for A&P Types (or anyone) Hi all, I am planning to start my first condition inspection on my -6 today. It was due by the end of the month in October, but travel got in my way of completing it. I would like to get the oil warmed up good before draining it and also doing the compression check. It seems I didn't really get it warmed up good last time I tried to just take it out and run it up. Am I allowed to do a solo flight to warm the oil up as a test flight even though it is not current? Thanks Tim ________________________________________________________________________________
Date: Nov 08, 2007
A ferry permit is not a big deal. An A&P will make a long entry, CALL your insurance Co to let them know. I flew from TN to TX on a ferry permit, when a grumman expert just did not show up for over a month to do the annual and could not set a date. A local guy signed it for $20, as he was at the airport anyway. Tim Bryan wrote: Hi all, I am planning to start my first condition inspection on my -6 today. It was due by the end of the month in October, but travel got in my way of completing it. I would like to get the oil warmed up good before draining it and also doing the compression check. It seems I didnt really get it warmed up good last time I tried to just take it out and run it up. Am I allowed to do a solo flight to warm the oil up as a test flight even though it is not current? Thanks Tim Sherman Butler RV-7a Wings Idaho Falls __________________________________________________ ________________________________________________________________________________
Date: Nov 08, 2007
From: "Greg Williams" <mr.gsun+rv-list(at)gmail.com>
Along a similar line, what does a non-builder have to do to get a certificate to do his own condition inspection? On Nov 8, 2007 3:07 PM, Bruce Gray wrote: > Sure, you just can't fly it until you finish and sign off the condition > inspection. > > > Bruce > > www.Glasair.org <http://www.glasair.org/> > > > -----Original Message----- > *From:* owner-rv-list-server(at)matronics.com [mailto: > owner-rv-list-server(at)matronics.com] *On Behalf Of *Tim Bryan > *Sent:* Thursday, November 08, 2007 3:50 PM > *To:* rv-list(at)matronics.com > *Subject:* RV-List: Question for A&P Types (or anyone) > > Hi all, > > > I am planning to start my first condition inspection on my -6 today. It was due by the end of the month in October, but travel got in my way of completing it. I would like to get the oil warmed up good before draining it and also doing the compression check. It seems I didn't really get it warmed up good last time I tried to just take it out and run it up. Am I allowed to do a solo flight to warm the oil up as a test flight even though it is not current? > > > Thanks > > Tim** > > * > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > > * > > ________________________________________________________________________________
Date: Nov 08, 2007
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
True... this happens all the time, no big deal. Darrell --- Sherman Butler wrote: > A ferry permit is not a big deal. An A&P will make a > long entry, CALL your insurance Co to let them know. > I flew from TN to TX on a ferry permit, when a > grumman expert just did not show up for over a month > to do the annual and could not set a date. A local > guy signed it for $20, as he was at the airport > anyway. > > > > Tim Bryan wrote: > > Hi all, > > > > I am planning to start my first condition inspection > on my -6 today. It was due by the end of the month > in October, but travel got in my way of completing > it. I would like to get the oil warmed up good > before draining it and also doing the compression > check. It seems I didnt really get it warmed up > good last time I tried to just take it out and run > it up. Am I allowed to do a solo flight to warm the > oil up as a test flight even though it is not > current? > > > > Thanks > > Tim > > > > > > > Sherman Butler > RV-7a Wings > Idaho Falls > __________________________________________________ __________________________________________________ ________________________________________________________________________________
Subject: For sale: Matco wheels and brakes
Date: Nov 08, 2007
I've bought a set of Grove wheels and brakes for #25 and would like to get something out of the Matco's I have. These have been on the airplane for a number of years but were never used in anger and are in very good shape.? I'm asking $400 but will take just about any reasonable offer. Maybe one of you guys knows someone building a HR2 on a budget. Included are: 2- Matco 5" wheels 2- Matco single piston calipers 2- Torque plates 2- 5" axels w/nuts 2- Air Hawk tires w/tubes If anyone is interested please respond off list or give me a call at : 407-687-3126 Danny ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Nov 09, 2007
Build your own airplane and apply for the repairman's certificate. That's about all there is to it. Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Greg Williams wrote: > Along a similar line, what does a non-builder have to do to get a > certificate to do his own condition inspection? > > On Nov 8, 2007 3:07 PM, Bruce Gray > wrote: > > Sure, you just can't fly it until you finish and sign off the > condition inspection. > > > > Bruce > > www.Glasair.org <http://www.glasair.org/> > > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com > ] On Behalf Of Tim > Bryan > Sent: Thursday, November 08, 2007 3:50 PM > To: rv-list(at)matronics.com > Subject: RV-List: Question for A&P Types (or anyone) > > >Hi all, > > > > >I am planning to start my first condition inspection on my -6 today. It was due by the end of the month in October, but travel got in my way of completing it. I would like to get the oil warmed up good before draining it and also doing the compression check. It seems I didn't really get it warmed up good last time I tried to just take it out and run it up. Am I allowed to do a solo flight to warm the oil up as a test flight even though it is not current? > > > > >Thanks > >Tim > > >href="http://www.matronics.com/contribution">http://www.matronics.com/chref=" >http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > <http://www.matronics.com/Navigator?RV-List> > href="http://forums.matronics.com">http://forums.matronics.com > > ________________________________________________________________________________
Date: Nov 09, 2007
Repairman's certificates are specific and only apply to one "N" numbered airplane. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Scott Sent: Thursday, November 08, 2007 10:27 PM Subject: Re: RV-List: Question for A&P Types (or anyone) Build your own airplane and apply for the repairman's certificate. That's about all there is to it. Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Greg Williams wrote: > Along a similar line, what does a non-builder have to do to get a > certificate to do his own condition inspection? > > On Nov 8, 2007 3:07 PM, Bruce Gray > wrote: > > Sure, you just can't fly it until you finish and sign off the > condition inspection. > > > > Bruce > > www.Glasair.org <http://www.glasair.org/> > > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com > ] On Behalf Of Tim > Bryan > Sent: Thursday, November 08, 2007 3:50 PM > To: rv-list(at)matronics.com > Subject: RV-List: Question for A&P Types (or anyone) > > >Hi all, > > > > >I am planning to start my first condition inspection on my -6 today. >It was due by the end of the month in October, but travel got in my way >of completing it. I would like to get the oil warmed up good before >draining it and also doing the compression check. It seems I didn't >really get it warmed up good last time I tried to just take it out and >run it up. Am I allowed to do a solo flight to warm the oil up as a >test flight even though it is not current? > > > > >Thanks > >Tim > > >href="http://www.matronics.com/contribution">http://www.matronics.com/c >href=" >http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Naviga tor?RV-List > <http://www.matronics.com/Navigator?RV-List> > href="http://forums.matronics.com">http://forums.matronics.com > > ________________________________________________________________________________
Date: Nov 08, 2007
skislope effect Here's Bruce's response: --- Mike, Several of us have looked at your aileron trailing edge, and some wish theirs looked that good. Just finish them and move on. The trailing edge is fine. Bruce Reynolds brucer(at)vansaircraft.com --- I didn't agree, so I ordered new ribs to fix the problem. I'm glad I did. :-) Charles Heathco wrote: > Wow! what did vans say re such a noticable missmatch? Charlie Heathco > * > * ________________________________________________________________________________
Date: Nov 08, 2007
If I'm not mistaken, Tim is a builder...? Darrell --- Greg Williams wrote: > Along a similar line, what does a non-builder have > to do to get a > certificate to do his own condition inspection? > > On Nov 8, 2007 3:07 PM, Bruce Gray > wrote: > > > Sure, you just can't fly it until you finish and > sign off the condition > > inspection. > > > > > > > > Bruce > > > > www.Glasair.org <http://www.glasair.org/> > > > > > > > > -----Original Message----- > > *From:* owner-rv-list-server(at)matronics.com > [mailto: > > owner-rv-list-server(at)matronics.com] *On Behalf Of > *Tim Bryan > > *Sent:* Thursday, November 08, 2007 3:50 PM > > *To:* rv-list(at)matronics.com > > *Subject:* RV-List: Question for A&P Types (or > anyone) > > > > Hi all, > > > > > > > > I am planning to start my first condition > inspection on my -6 today. It was due by the end of > the month in October, but travel got in my way of > completing it. I would like to get the oil warmed > up good before draining it and also doing the > compression check. It seems I didn't really get it > warmed up good last time I tried to just take it out > and run it up. Am I allowed to do a solo flight to > warm the oil up as a test flight even though it is > not current? > > > > > > > > Thanks > > > > Tim** > > > > * > > > > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > > > href="http://forums.matronics.com">http://forums.matronics.com > > * > > > > * > > > > > > * > > > > > __________________________________________________ ________________________________________________________________________________
Date: Nov 08, 2007
NO! You would be violating your Operating Limitations. Sorry!!! Mike Robertosn Das Fed From: n616tb(at)btsapps.comTo: rv-list(at)matronics.comSubject: RV-List: Question for A&P Types (or anyone)Date: Thu, 8 Nov 2007 14:50:17 -0600 Hi all, I am planning to start my first condition inspection on my -6 today . It was due by the end of the month in October, but travel got in my way of completing it. I would like to get the oil warmed up good before draini ng it and also doing the compression check. It seems I didn=92t really get it warmed up good last time I tried to just take it out and run it up. Am I allowed to do a solo flight to warm the oil up as a test flight even tho ugh it is not current? ThanksTim _________________________________________________________________ Climb to the top of the charts!- Play Star Shuffle:- the word scramble challenge with star power. http://club.live.com/star_shuffle.aspx?icid=starshuffle_wlmailtextlink_oc t ________________________________________________________________________________
Date: Nov 09, 2007
Unless you hold the specific "N" numbered repairmans certificate for that particular airplane, it must be signed off by an A&P. In other words, if you hold a repairmans cert for your RV-6, you can sign off your condition inspection but not sign off your buddies RV-6. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Darrell Reiley Sent: Thursday, November 08, 2007 10:57 PM Subject: Re: RV-List: Question for A&P Types (or anyone) --> If I'm not mistaken, Tim is a builder...? Darrell ________________________________________________________________________________
Date: Nov 09, 2007
Subject: If You Got This Email, You Haven't Made A Contribution Yet! :-)
Dear Listers, If you received this particular Matronics List Email message, its because you haven't yet made a Contribution to support your Lists! Implemented for the first time last year, the Matronics system selectively sends out the Contribution messages to those that forgot to whip out the 'ol credit card this year to support the continued operation and upgrade of the Matronics Email Lists! Don't you wish PBS worked that way? :-) You heard that right. Once you make your Contribution, these support requests messages during November will suddenly stop coming to your personal email inbox! I wanted to implement something like this for a number of years, but it was always such a daunting task to modify the back-end List processing code, that I just kept putting it off. Finally last year, I just decided to bite the bullet and put the code-pounding time it to make it work. A few days later, bam! A working system! I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site like this. It also goes to pay for the commercial-grade Internet connection and to pay the rather huge electric bill to keep the computer gear running and the air conditioner powered up. I run ALL of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercialism that is so prevalent on the Internet these days and I particularly don't want to have it on my Email List site. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Please note the following regarding the selective posting system. There are certain circumstances where you might still see a Contribution related message. These situations include if someone replies to one of the messages, or when using the List Browse feature, or when accessing List message via the Forum. Since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Subject: Needed: Artificial Horizon
Date: Nov 09, 2007
Just informed by Rudy's Aircraft Instruments that my Aeriatalia Artifical Horizon (part# 36100 9, Serial#03374) cannot be tilted 7 degrees for my RV10 panel. Anyone out there have a good vac artifical horz for sale or trade preferably with the 7 degree tilt already done? I bought this one from a friend who had it overhauled and Rudy went thru it too. I'll take any reasonable offer...or trade. Chuck Weyant Santa Maria, CA 805 878-1922 ________________________________________________________________________________
Subject: Las Vegas Rvers
Date: Nov 09, 2007
I am going to be in LAS next week on business. I would love to hook up with a local rver, maybe for a ride, or just to look at airplanes, whatever. Al Grajek RV8 LEX 859-361-9460 ________________________________________________________________________________
Date: Nov 09, 2007
I have digest only so probly have enuf info but wanted to add that I did my comp check cold this year (july) and it was only one to two pts lower than last yrs hot check, Charlie Heathco ________________________________________________________________________________
Subject: Vacuum Pump Repair
Date: Nov 10, 2007
I was ready to replace the failed vacuum pump (210 hours) in my RV6 this week. But my friend, Rob Kermanj (RV10 and RV6), suggested that I check the operation of the shear coupling in the pump. I found out that the shear coupling had sheared and replaced it for about $22 (I was later told that Aircraft Spruce sells it for $14). It's very easy to replace this part in the pump. The fun part is removing and installing the pump. The shear coupling is made from some type of plastic that deteriorates with high temperature and time. I plan to replace this part every couple of years or 200 hours as a preventive measure in the future. -- Gabe A Ferrer RV6 N2GX South Florida email: ferrerg(at)comcast.net cell: 561 758 8894
Gabe A Ferrer
RV6 N2GX
South Florida
cell: 561 758 8894
From: "Steve & Denise" <hurlbut(at)ns.sympatico.ca>
Subject: Propeller for sale
Date: Nov 09, 2007
MT Prop model MTV-15B/183-50. 136.5 hours flight time since new. No damage ever. Log books included. Manufactured June 2006. Removed from RV7A IO-360 for flight testing other props. Email for pics. $8000 OBO Steve RV7A ________________________________________________________________________________
Date: Nov 10, 2007
Subject: Falcon Altimeter
Listers, FWIW - I have a Falcon altimeter that I installed in my RV-6A about four years ago. The plane has been flying since February 2005 and has about 130 hours. The altimeter has been certified twice to 20,000 feet per FAR 43 App. E at an FAA repair station with no problems, the latest check in February this year. I even posted and e-mail on the RV-list indicating my delight in this reasonably priced, Chinese made instrument being so precise and reliable. A week ago in checking the cockpit in preparation for a flight, about two weeks since my last flight, I found the altimeter reading about 4000 feet. In in the process of trouble shooting, I disconnected the static line from the altimeter and found that it was still reading 4000 feet. The problem was obviously internal in the altimeter. I removed it from the instrument panel and took it home. After a week on my desk, the indicated altitude has increased to about 9000 feet and is still slowly climbing. Consulting with the Wultrad folks I found that the instrument could be overhauled for $150. Since the current price is about $250 this was not attractive. And, since my confidence in the reliability of the instrument had been destroyed, I "bit the bullet" and purchased a United, TSOd altimeter at about three times the price of the Falcon. If you, have one of these you may want to keep a close eye on the field altitude at the correct altimeter setting. I noticed a small increase in the indicated field altitude a few weeks before the very large increase I mentioned. Best regards, Richard Dudley ________________________________________________________________________________
Subject: Need some help in Denver
Date: Nov 09, 2007
I am thinking about bidding on a thickness planer in the Denver area. The only problem is that it is local pickup only. Is there anyone in the Denve r area that would be willing to run by this pawn shop, if I win, pick this up and take it to yellow freight to ship it. I would definitely be willing to pay whoever something for the inconvenience. Mike Robertson _________________________________________________________________ Peek-a-boo FREE Tricks & Treats for You! http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us ________________________________________________________________________________
Date: Nov 10, 2007
Subject: New Van's service bulletin (SB 07-11-09) applicable to all two
place, tricycle gear RVs. http://www.vansaircraft.com/public/notices.htm Requires replacement or modification of nose gear components on two-lace, tricycle gear RVs with finish kits shipped prior to Feb 2005. -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 900 hrs RV-10 #40059 under construction * * ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Subject: Re: Needed: Artificial Horizon
Date: Nov 10, 2007
Aren't 7 degree tilt instruments for taildraggers? Unless you redesigned the 10's panel. Mike H 9A/8A ----- Original Message ----- From: Chuck Weyant To: rv-list(at)matronics.com Sent: Friday, November 09, 2007 3:03 PM Subject: RV-List: Needed: Artificial Horizon Just informed by Rudy's Aircraft Instruments that my Aeriatalia Artifical Horizon (part# 36100 9, Serial#03374) cannot be tilted 7 degrees for my RV10 panel. Anyone out there have a good vac artifical horz for sale or trade preferably with the 7 degree tilt already done? I bought this one from a friend who had it overhauled and Rudy went thru it too. I'll take any reasonable offer...or trade. Chuck Weyant Santa Maria, CA 805 878-1922 ________________________________________________________________________________
Date: Nov 11, 2007
Subject: Re: Vacuum Pump Repair
In a message dated 11/10/2007 9:44:24 P.M. Pacific Standard Time, ferrerg(at)comcast.net writes: I was ready to replace the failed vacuum pump (210 hours) in my RV6 this week. But my friend, Rob Kermanj (RV10 and RV6), suggested that I check the operation of the shear coupling in the pump. I found out that the shear coupling had sheared and replaced it for about $22 (I was later told that Aircraft Spruce sells it for $14). It's very easy to replace this part in the pump. The fun part is removing and installing the pump. The shear coupling is made from some type of plastic that deteriorates with high temperature and time. I plan to replace this part every couple of years or 200 hours as a preventive measure in the future. ================================================ Just a stupid question, but... maybe it sheared for a reason? I would check to see if the vanes are in good condition and not partially fragged. N1GV (RV-6A, Flying 870hrs, O-360-A1A, C/S, Silicon Valley) ________________________________________________________________________________
From: "Joe & Jan Connell" <jconnell(at)fmwildblue.com>
Subject: Does anyone trim the trailing edge of the main gear leg fairings?
Date: Nov 10, 2007
Gentlemen, I've been searching the archives to no avail. The instructions for the RV-9A say the following: 1. "Trace the root end, trailing edge, and tip end trim lines onto the fairing." 2. "Trim the root and tip ends of the fairing but do not trim the trailing edge." I don't see any indication that I will ever trim the trailing edge. There is a comment about using a long stick and sandpaper to remove excess "tail" on the fairing and even the sides of the trailing edge. Will any trailing edge material need to be removed before fitting the hinges? Will any trailing edge material need to be removed to fit the ready-made intersection fairings? Many thanks. Joe Connell RV-9A N95JJ ________________________________________________________________________________
Date: Nov 11, 2007
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: RE: RV-List Digest: 3 Msgs - 11/07/07
Functional checkout of my electrical system has gone well so far with no smoked wiring or equipment. I bought an equivalent of an Odyssey 680 a couple years ago and trickle charged it occasionally hoping it would at least be good enough to do electrical checkout, first engine start and maybe a few times around the pattern. But it appears that is not the case. Voltmeter says there is 12.5 volts at the terminals but it can't produce enough amps to fire the battery contactor or even make some sparks when shorted, pretty pathetic. I substituted a Panasonic 4.5 amp hour sealed lead acid battery that I bought second hand about 6 years ago. It's got enough oomph for the checkout but I'll need a new 680 for 1st engine start. I did a test on my magneto P-lead (one mag on left side, electronic on right side)with an ohm meter. Thinking that when the key switch is in the off position, the resistance across the p-lead should measure close to dead short and, it does. By the same logic, I thought that when the mag was ungrounded the resistance across the p-leads (I used a shielded wire with the shield grounded at the magneto through the key switch, no local grounding). But when I measured across the p-leads at the magneto the resistance only went from 0.2 ohms to 0.4 ohms when I turned the key. Not an appreciable increase in resistance but it was consistent (happens every time) and measurable. I thought maybe I had a faulty key switch but not so, I removed one p-lead from the mag and made the same measurement and the resistance with the key in that mag's position read infinite. I suspect that there is some thing about magnetos I don't know and that this is not a problem but would like to be sure. Anybody ever done this test? Did you get the same results? Also checked out the VM-1000 and it seems to work fine except for dimming. I used one of the B&C dimmers connected to the VM-1000 dimming input but I don't seem to get any dimming action (backlight works ok). Anyone else experience this? Have I missed something in the VM manual and it doesn't use an external dimming input? Any thoughts? Thanks. Dean RV-6A N197DM closer to 1st flight. ________________________________________________________________________________
Date: Nov 11, 2007
The tilt in the attitude indicator compensates for the fact that the instrument panel is not vertical when the aircraft is in level flight. The amount the instrument panel is tilted is the same on tricycle gear and taildragger aircraft. Kevin Horton On 10-Nov-07, at 9:39 PM, mike humphrey wrote: > Aren't 7 degree tilt instruments for taildraggers? Unless you > redesigned the 10's panel. > Mike H 9A/8A > ----- Original Message ----- > From: Chuck Weyant > To: rv-list(at)matronics.com > Sent: Friday, November 09, 2007 3:03 PM > Subject: RV-List: Needed: Artificial Horizon > > Just informed by Rudy's Aircraft Instruments that my Aeriatalia > Artifical Horizon > (part# 36100 9, Serial#03374) cannot be tilted 7 degrees for my RV10 > panel. Anyone out there have a good vac artifical horz for sale or > trade preferably with the 7 degree tilt already done? I bought this > one from a friend who had it overhauled and Rudy went thru it too. > I'll take any reasonable offer...or trade. > Chuck Weyant > Santa Maria, CA > 805 878-1922 ________________________________________________________________________________
Date: Nov 11, 2007
I have a artificial Horizon I just removed from my RV8a that works fine . I Just up graded to OP Technologies Glass panel contact me if interested at 847-727-0026 Dane Sheahen N838RV RV8a Aren't 7 degree tilt instruments for taildraggers? Unless you redesigned the 10's panel. Mike H 9A/8A ----- Original Message ----- From: _Chuck Weyant_ (mailto:chuck(at)chuckdirect.com) Sent: Friday, November 09, 2007 3:03 PM Subject: RV-List: Needed: Artificial Horizon Just informed by Rudy's Aircraft Instruments that my Aeriatalia Artifical Horizon (part# 36100 9, Serial#03374) cannot be tilted 7 degrees for my RV10 panel. Anyone out there have a good vac artifical horz for sale or trade preferably with the 7 degree tilt already done? I bought this one from a friend who had it overhauled and Rudy went thru it too. I'll take any reasonable offer...or trade. Chuck Weyant Santa Maria, CA 805 878-1922 href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator ?RV-List href="http://forums.matronics.com">http://forums.matronics.com (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?RV-List) ________________________________________________________________________________
Date: Nov 11, 2007
Subject: Re: RE: RV-List Digest: 3 Msgs - 11/07/07
Remember that inside the mag, there is the set of points. One side of the points is connected to ground and the other side is connected to the P-Lead and one side of the coil. If the points are closed, you would read very close to a short to ground (as you did). You might have to rotate the engine (and I would suggest turning the prop backwards to avoid an accidental start!). At some point, the points should open and you would read an open with the ohm meter. Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) DEAN PSIROPOULOS wrote: > >Functional checkout of my electrical system has gone well so far with no >smoked wiring or equipment. I bought an equivalent of an Odyssey 680 a >couple years ago and trickle charged it occasionally hoping it would at >least be good enough to do electrical checkout, first engine start and maybe >a few times around the pattern. But it appears that is not the case. >Voltmeter says there is 12.5 volts at the terminals but it can't produce >enough amps to fire the battery contactor or even make some sparks when >shorted, pretty pathetic. I substituted a Panasonic 4.5 amp hour sealed lead >acid battery that I bought second hand about 6 years ago. It's got enough >oomph for the checkout but I'll need a new 680 for 1st engine start. > >I did a test on my magneto P-lead (one mag on left side, electronic on right >side)with an ohm meter. Thinking that when the key switch is in the off >position, the resistance across the p-lead should measure close to dead >short and, it does. By the same logic, I thought that when the mag was >ungrounded the resistance across the p-leads (I used a shielded wire with >the shield grounded at the magneto through the key switch, no local >grounding). But when I measured across the p-leads at the magneto the >resistance only went from 0.2 ohms to 0.4 ohms when I turned the key. Not >an appreciable increase in resistance but it was consistent (happens every >time) and measurable. I thought maybe I had a faulty key switch but not so, >I removed one p-lead from the mag and made the same measurement and the >resistance with the key in that mag's position read infinite. I suspect >that there is some thing about magnetos I don't know and that this is not a >problem but would like to be sure. Anybody ever done this test? Did you get >the same results? > >Also checked out the VM-1000 and it seems to work fine except for dimming. >I used one of the B&C dimmers connected to the VM-1000 dimming input but I >don't seem to get any dimming action (backlight works ok). Anyone else >experience this? Have I missed something in the VM manual and it doesn't use >an external dimming input? Any thoughts? Thanks. > >Dean >RV-6A N197DM >closer to 1st flight. > > > > ________________________________________________________________________________
Date: Nov 11, 2007
Oops, disregard my last post. Going through my Eisemann magneto service book, it looks like no matter if the points are open or closed, you will be reading through the primary of the coil to ground, so what you saw is probably correct...ie a reading of 0.2 ohms or so greater than when the switch was grounding the P lead through the ignition switch. I'll go back under my rock now...;( Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Scott wrote: > > Remember that inside the mag, there is the set of points. One side of > the points is connected to ground and the other side is connected to > the P-Lead and one side of the coil. If the points are closed, you > would read very close to a short to ground (as you did). You might > have to rotate the engine (and I would suggest turning the prop > backwards to avoid an accidental start!). At some point, the points > should open and you would read an open with the ohm meter. > > Scott > http://corbenflyer.tripod.com/ > Gotta Fly or Gonna Die > Building RV-4 (Super Slow Build Version) > > > DEAN PSIROPOULOS wrote: > >> >> >> Functional checkout of my electrical system has gone well so far with no >> smoked wiring or equipment. I bought an equivalent of an Odyssey 680 a >> couple years ago and trickle charged it occasionally hoping it would at >> least be good enough to do electrical checkout, first engine start >> and maybe >> a few times around the pattern. But it appears that is not the case. >> Voltmeter says there is 12.5 volts at the terminals but it can't produce >> enough amps to fire the battery contactor or even make some sparks when >> shorted, pretty pathetic. I substituted a Panasonic 4.5 amp hour >> sealed lead >> acid battery that I bought second hand about 6 years ago. It's got >> enough >> oomph for the checkout but I'll need a new 680 for 1st engine start. >> >> I did a test on my magneto P-lead (one mag on left side, electronic >> on right >> side)with an ohm meter. Thinking that when the key switch is in the off >> position, the resistance across the p-lead should measure close to dead >> short and, it does. By the same logic, I thought that when the mag was >> ungrounded the resistance across the p-leads (I used a shielded wire >> with >> the shield grounded at the magneto through the key switch, no local >> grounding). But when I measured across the p-leads at the magneto the >> resistance only went from 0.2 ohms to 0.4 ohms when I turned the >> key. Not >> an appreciable increase in resistance but it was consistent (happens >> every >> time) and measurable. I thought maybe I had a faulty key switch but >> not so, >> I removed one p-lead from the mag and made the same measurement and the >> resistance with the key in that mag's position read infinite. I suspect >> that there is some thing about magnetos I don't know and that this is >> not a >> problem but would like to be sure. Anybody ever done this test? Did >> you get >> the same results? >> >> Also checked out the VM-1000 and it seems to work fine except for >> dimming. >> I used one of the B&C dimmers connected to the VM-1000 dimming input >> but I >> don't seem to get any dimming action (backlight works ok). Anyone else >> experience this? Have I missed something in the VM manual and it >> doesn't use >> an external dimming input? Any thoughts? Thanks. >> >> Dean >> RV-6A N197DM >> closer to 1st flight. >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: RE:Propeller for sale
Date: Nov 11, 2007
Hi Steve- I've got a prop, but what was the outcome of the testing, aside from selling the MT? Enquiring minds want to know! >Removed from RV7A IO-360 for flight testing other props. >Steve glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Nov 11, 2007
Subject: Post Mortem - Matronics List Pummeled By Spam...
Dear Listers, Over a 3-day period, Thursday 11/8 though Saturday 11/10, the Matronics Lists were pummeled with over 450,000 spam emails causing posting delays and a few duplicate messages. Yeah, I really said nearly half a million spams! The good news is that I don't believe a single one of them actually made it to the Lists thanks to the aggressive List filtering code and the Barracuda spam filter. The bad news was that it caused quite a back log of email messages starting Friday and continuing until late Saturday when I noticed that delivery seemed a bit sluggish. By about 11pm on Saturday night, I had managed to get the backlog cleared out of the spam filter by temporarily adjusting some of the filtering. A check of the queues this morning, and everything looks like its working great and there are no incoming filtering delays and spam levels appear to be back to "normal". There were a number of people asking what was going on, so I thought that I'd send out a follow up post mortem on the event... November is the annual List Fund Raiser. Your contribution directly enables me to buy systems like the Barracuda spam filter that keep the List free of that garbage. Please make a contribution to support your Lists! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: magneto
Date: Nov 11, 2007
A magneto is not like a car ignition, it is the complete circuit from ground to ground both in the primary and secondary. So points open or closed, p-lead open or closed will still read <1 ohm circuit to ground. That's why a test lite won't work on timing the mag. It needs to have an oscillator to sense the coil/condenser being grounded by the points or not. W ________________________________________________________________________________
Date: Nov 11, 2007
Subject: Re: magneto
Yup, you're right! That's why I retracted my statement and sheepishly crawled back under my rock ;) I found my Eisemann mag service manual and took a look at the schematic (after I first posted). Dang I hate when that happens (got to me before my morning coffee and my brain's mag switch was still grounded!) ;) Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Wheeler North wrote: > >A magneto is not like a car ignition, it is the complete circuit from ground >to ground both in the primary and secondary. So points open or closed, >p-lead open or closed will still read <1 ohm circuit to ground. > >That's why a test lite won't work on timing the mag. It needs to have an >oscillator to sense the coil/condenser being grounded by the points or not. > >W > > > > ________________________________________________________________________________
Subject: Sensenich Prop and finished, painted Van's RV spinner for sale
Date: Nov 11, 2007
I recently replaced my Sensenich 72FM8S9-1-84 on my RV-8A with a Hartzell prop. I'm selling the Sensenich prop, prop spacer, prop bolts, spinner and spinner SS hardware as a package. Here are the details: Sensenich 72FM8S9-1-84 Prop. 350 hours total on my RV-8A (O-360 A1A). I bought it new from Van's. It is in perfect condition, never hit, never anything, The package includes everything to bolt on the prop and spinner on any RV4, 6, 7, or 8. The spinner was painted when I did the plane, 'Midnight Pearl Blue" using PPG base cost/clear coat. If you don't like the color, repaint is easy as all the pin hole work is done. The spinner hardware consists of #8 SS flat head screws and #6 SS tinnermans drilled out and re-dimpled to #8 screw. I found using the smaller tinnermans allow for much cleaner, flush fit along the contour of the spinner. Package price: $1400 Carl Froehlich 540 371-8482 ________________________________________________________________________________
Subject: For sale: Intake system
Date: Nov 11, 2007
I have an intake system from Massey Aero that I want to sell. This system converts the stock "smiley" intake to a round intake for the engine induction only. The system includes: Machined AL intake Machined AL filter mounts (2) K&N filter Molded glass inlet molded filter nose piece This is a really cool setup. I was going to use this on #25 but I'm working in JGTDTD (Just Get The Dam Thing Done) mode so someone else can play with it. The cost was $800 but the first $200 (OBO) takes it. Danny Melnik F1 #25 Rocket Factory Melbourne, FL ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Subject: SOLD--------- For sale: Matco wheels and brakes
Date: Nov 11, 2007
These parts have been sold Danny Melnik F1 #25 Rocket Factory Melbourne, FL -----Original Message----- From: vft(at)aol.com Sent: Thu, 8 Nov 2007 9:07 pm Subject: For sale: Matco wheels and brakes I've bought a set of Grove wheels and brakes for #25 and would like to get something out of the Matco's I have. These have been on the airplane for a number of years but were never used in anger and are in very good shape.? I'm asking $400 but will take just about any reasonable offer. Maybe one of you guys knows someone building a HR2 on a budget. Included are: 2- Matco 5" wheels 2- Matco single piston calipers 2- Torque plates 2- 5" axels w/nuts 2- Air Hawk tires w/tubes If anyone is interested please respond off list or give me a call at : 407-687-3126 Danny Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Subject: Price for nose gear leg?
Date: Nov 11, 2007
BlankHas anybody been able to price the U-603-3X nose gear leg from Van's? I spent an hour searching the list on his website and couldn't find it. I m anaged to get a price on the fork (WD-630-1) but no luck on the gear leg. Thanks Charlie Ennis RV-6A Do nor archive ________________________________________________________________________________
Date: Nov 11, 2007
Charlie, Here is the story on the gear leg mod from Harmon Lang. This is to go from a -2 to a -3, if you have the -1 I believe you need the new leg, I was unable to find the price on "the list" either. You probably need to call Van's. /"The procedure to send the nose gear for modifying. Pack it up in a box or tube and send it to Langair Machining 33094 Church Rd. Warren Or. 97053. A drawing for a box is on the web site. A tube from a carpet core also works. Include $75.00 for the work and enough to ship it back. Cash or check. We don't take credit cards. Include a return label. We will remove it from the container, cut the 1 in off, rethread and put it back in the same container. The rethreading is done with a carbide thread milling tool running in a CNC mill. If you have the mill you can do this yourself. Cutter cost and set up will only cost about $300.00 or so. Expect the time in our shop to be about 4 days. Until we know how many there will be, we have to set one day aside to do the batch that comes in for the week. Please help by making the repackaging go as easily as possible. NO CONFUSION. Harmon"/ -----Original Message----- From: Ralph Hoover [mailto:hooverra(at)verizon.net] Sent: Saturday, November 10, 2007 7:41 AM Subject: RV7A U603-2 Modification Harmon, Please supply a quotation for modification of a Vans U-603-2 nose gear leg to a U603-3 per SB 07-11-09. Thank you -- Ralph C. Hoover RV7A hooverra at verizon dot net -- Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
Subject: SOLD For sale: Intake system
Date: Nov 11, 2007
These parts have been sold. Danny Melnik F1 #25 Rocket Factory Melbourne, FL -----Original Message----- From: Danny <vft(at)aol.com> Sent: Sun, 11 Nov 2007 8:09 pm Subject: For sale: Intake system I have an intake system from Massey Aero that I want to sell. This system converts the stock "smiley" intake to a round intake for the engine induction only. The system includes: Machined AL intake Machined AL filter mounts (2) K&N filter Molded glass inlet molded filter nose piece This is a really cool setup. I was going to use this on #25 but I'm working in JGTDTD (Just Get The Dam Thing Done) mode so someone else can play with it. The cost was $800 but the first $200 (OBO) takes it. Danny Melnik F1 #25 Rocket Factory Melbourne, FL Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Subject: For sale: Matco parking brake valve
Date: Nov 11, 2007
New in box Matco parking brake valve. ACS price is $108. First $75 takes it. Danny Melnik F1 #25 Rocket Factory Melbourne, FL ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Subject: Re: SOLD For sale: Intake system
Date: Nov 11, 2007
Thanks for the picture you sent earlier, but I guess someone beat me to it while I had dinner tonight... ----- Original Message ----- From: Danny To: rocket-list(at)matronics.com ; rv-list(at)matronics.com Sent: Sunday, November 11, 2007 9:36 PM Subject: RV-List: SOLD For sale: Intake system These parts have been sold. Danny Melnik F1 #25 Rocket Factory Melbourne, FL -----Original Message----- From: Danny <vft(at)aol.com> To: rocket-list(at)matronics.com; rv-list(at)matronics.com Sent: Sun, 11 Nov 2007 8:09 pm Subject: For sale: Intake system I have an intake system from Massey Aero that I want to sell. This system converts the stock "smiley" intake to a round intake for the engine induction only. The system includes: Machined AL intake Machined AL filter mounts (2) K&N filter Molded glass inlet molded filter nose piece This is a really cool setup. I was going to use this on #25 but I'm working in JGTDTD (Just Get The Dam Thing Done) mode so someone else can play with it. The cost was $800 but the first $200 (OBO) takes it. Danny Melnik F1 #25 Rocket Factory Melbourne, FL ------------------------------------------------------------------------- ----- Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________________
Subject: For sale: Team Rocket wing tips
Date: Nov 12, 2007
These tips will fit the straight wing wing F1, HR2, and RV4,6,7,and8. They were originaly sent with my kit and are approx 8 years old. They were warped a bit and I spent a lot of time getting them fitted to my wings. In the end they needed more work than I was willing to put into them so I bought a set of Vans tips for #25. 20/20 hind sight says I could of had these looking pretty nice in the amount of time it took to start over with the Vans parts. These would be great for someone on a budget and include the clear lens for the landing/position light but no lights. Asking $100 OBO. Please note that these are large pieces so shipping may cost a bit. Danny Melnik F1 #25 Rocket Factory Melbourne, FL ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Nov 12, 2007
I have a like new Sigma Tec A/H still in the box if interested. email me mike109g6(at)insideconnect.net. Need to sell it since I've gone totally electric. Mike H 9A/8A PS I also have a NIB Rapco Vac Pump kit for Lycoming that has never been out of the box since I bought it from A/C Spruce that I need to sell also. ----- Original Message ----- From: FASTPILOTRV8(at)aol.com To: rv-list(at)matronics.com Sent: Sunday, November 11, 2007 8:11 AM Subject: Re: RV-List: Needed: Artificial Horizon I have a artificial Horizon I just removed from my RV8a that works fine . I Just up graded to OP Technologies Glass panel contact me if interested at 847-727-0026 Dane Sheahen N838RV RV8a Aren't 7 degree tilt instruments for taildraggers? Unless you redesigned the 10's panel. Mike H 9A/8A ----- Original Message ----- From: Chuck Weyant To: rv-list(at)matronics.com Sent: Friday, November 09, 2007 3:03 PM Subject: RV-List: Needed: Artificial Horizon Just informed by Rudy's Aircraft Instruments that my Aeriatalia Artifical Horizon (part# 36100 9, Serial#03374) cannot be tilted 7 degrees for my RV10 panel. Anyone out there have a good vac artifical horz for sale or trade preferably with the 7 degree tilt already done? I bought this one from a friend who had it overhauled and Rudy went thru it too. I'll take any reasonable offer...or trade. Chuck Weyant Santa Maria, CA 805 878-1922 href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV-List">http://www.matronics. com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ://www.matronics.com/contribution">http://www.matronics.com/contribution ="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/ Navigator?RV-List .matronics.com/">http://forums.matronics.com ------------------------------------------------------------------------- ----- See what's new ________________________________________________________________________________
Date: Nov 12, 2007
For those who inquired:. MT PROP IS STILL FOR SALE. REDUCED TO $7500 MUST SELL. I just finished real world testing on MTV-15B and Hartzell Blended airfoil on Oct 31. I have a Mattituck TMX-IO-360 on RV7A. Thought I would share my findings: At 6000 ft, 2400 RPM Hartzell is faster by 1.8 kts. At 6000 ft, 2500 RPM Hartzell is faster by 2.5 kts. Rate of climb from 4000 to 6000 (@110 kts IAS) Hartzell is faster by 157 fpm At 9000 ft, 2400 RPM Hartzell is faster by 1.4 kts. At 9000 ft, 2500 RPM Hartzell is faster by 3.1 kts Rate of climb from 7000 to 9000 (@110 kts) Hartzell is faster by 209 fpm Other observations (lessons learned) people may not consider: 1. Hartzell is 11 lbs heavier (55 vs 44 lbs). Recalculate C of G 2. Because of its greater mass, engine is harder to start with Hartzell 3. Because of its greater mass, engine takes longer to shut down. This really surprised me. My MT would stop very quickly (within 1 engine revolution), the Hartzell averages 3-4 revolutions before stopping. This sometime causes it to turn past the 10-4 o'clock position where the MT would stop every time. 4. The Hartzell takes longer to change pitch. This is evident when adding power fast. During several overshoots I pushed in the power quickly and RPM would exceed 2750 and cause the engine warning to flash. The prop caught up quickly (back to 2700) but this was never an issue with the MT. Same with initial take-off. Add power slowly with Hartzell. 5. MT is smoother. At 2400 RPM Hartzell is good but at 2300 RPM it has noticeably more vibration. I'm going to dynamically balance the Hartzell. 6. MT is a bolt on and forget. Spinner made and no grease nipples to worry about. Hartzell you need to make the spinner, backing plates, etc. Putting on the MT prop takes 1/2 hour. Hartzell takes ~12 hours of labour. So both props in my opinion are good. Very close in performance. People claiming 10 kts increase between the two may need to review the flight test technique, speed calculations, and consider other factors. I'm going to sell my MT prop eventually if any early takers out there. Total flight time on it is 136.5 hours. Steve RV7A Hi Steve- I've got a prop, but what was the outcome of the testing, aside from selling the MT? Enquiring minds want to know! >Removed from RV7A IO-360 for flight testing other props. >Steve glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: SOLD: Matco parking brake valve
Date: Nov 12, 2007
This part has been sold Danny Melnik F1 #25 Rocket Factory Melbourne, FL -----Original Message----- From: Danny <vft(at)aol.com> Sent: Sun, 11 Nov 2007 11:54 pm Subject: For sale: Matco parking brake valve New in box Matco parking brake valve. ACS price is $108. First $75 takes it. Danny Melnik F1 #25 Rocket Factory Melbourne, FL Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Nov 12, 2007
Steve, Thanks for sharing the results of your testing! Curious... 1) For our benefit, were the altitudes below density altitudes (versus indicated)? 2) Also, how did you measure speed to .1 knots? 3) Did you attempt each maneuver (i.e. best rate of climb) multiple times to understand the potential variability in technique etc? 4) Any other insights to can share from your testing approach? Rick -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Steve & Denise Sent: Monday, November 12, 2007 8:39 AM Subject: RV-List: RE:Propeller for sale For those who inquired:. MT PROP IS STILL FOR SALE. REDUCED TO $7500 MUST SELL. I just finished real world testing on MTV-15B and Hartzell Blended airfoil on Oct 31. I have a Mattituck TMX-IO-360 on RV7A. Thought I would share my findings: At 6000 ft, 2400 RPM Hartzell is faster by 1.8 kts. At 6000 ft, 2500 RPM Hartzell is faster by 2.5 kts. Rate of climb from 4000 to 6000 (@110 kts IAS) Hartzell is faster by 157 fpm At 9000 ft, 2400 RPM Hartzell is faster by 1.4 kts. At 9000 ft, 2500 RPM Hartzell is faster by 3.1 kts Rate of climb from 7000 to 9000 (@110 kts) Hartzell is faster by 209 fpm Other observations (lessons learned) people may not consider: 1. Hartzell is 11 lbs heavier (55 vs 44 lbs). Recalculate C of G 2. Because of its greater mass, engine is harder to start with Hartzell 3. Because of its greater mass, engine takes longer to shut down. This really surprised me. My MT would stop very quickly (within 1 engine revolution), the Hartzell averages 3-4 revolutions before stopping. This sometime causes it to turn past the 10-4 o'clock position where the MT would stop every time. 4. The Hartzell takes longer to change pitch. This is evident when adding power fast. During several overshoots I pushed in the power quickly and RPM would exceed 2750 and cause the engine warning to flash. The prop caught up quickly (back to 2700) but this was never an issue with the MT. Same with initial take-off. Add power slowly with Hartzell. 5. MT is smoother. At 2400 RPM Hartzell is good but at 2300 RPM it has noticeably more vibration. I'm going to dynamically balance the Hartzell. 6. MT is a bolt on and forget. Spinner made and no grease nipples to worry about. Hartzell you need to make the spinner, backing plates, etc. Putting on the MT prop takes 1/2 hour. Hartzell takes ~12 hours of labour. So both props in my opinion are good. Very close in performance. People claiming 10 kts increase between the two may need to review the flight test technique, speed calculations, and consider other factors. I'm going to sell my MT prop eventually if any early takers out there. Total flight time on it is 136.5 hours. Steve RV7A Hi Steve- I've got a prop, but what was the outcome of the testing, aside from selling the MT? Enquiring minds want to know! >Removed from RV7A IO-360 for flight testing other props. >Steve glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Nov 12, 2007
Subject: Re: Question for A&P Types (or anyone)
Or go to school and get your A&P license. Takes about same or less time than building a plane. Kelly A&P/IA Scott wrote: > > Build your own airplane and apply for the repairman's certificate. > That's about all there is to it. > > Scott > http://corbenflyer.tripod.com/ > Gotta Fly or Gonna Die > Building RV-4 (Super Slow Build Version) > > > Greg Williams wrote: > >> Along a similar line, what does a non-builder have to do to get a >> certificate to do his own condition inspection? >> >> On Nov 8, 2007 3:07 PM, Bruce Gray > > wrote: >> ________________________________________________________________________________
Subject: FW: [NHREIA] Fw: NEW CREDIT SCAM (IMPORTANT)
Date: Nov 12, 2007
FYI on a new scam out there. According to snopes.com, this is a real scam, not one of the popular =93the sky is falling, send this to everyone you know=94 fakes. brian HYPERLINK "http://www.snopes.com/crime/warnings/creditcard.asp" \nhttp://www.snopes.-com/crime/-warnings/-creditcard.-asp HYPERLINK "http://www.snopes.com/crime/warnings/creditcard.asp%3E" \n<http://www.snopes.-com/crime/-warnings/-creditcard.-asp> This one is pretty slick since they provide YOU with all the information, except the one piece they want. Note, the callers do not ask for your card number; they already have it. This information is worth reading. By understanding how the VISA & MasterCard Telephone Credit Card Scam works, you'll be better prepared to protect yourself. One of our employees was called on Wednesday from "VISA", and I was called on Thursday from "Master Card". The scam works like this: Person calling says, "This is (name), and I'm calling from the Security and Fraud Department at VISA. My Badge number is 12460. Your card has been flagged for an unusual purchase pattern, and I'm calling to verify. This would be on your VISA card which was issued by (name of bank). Did you p urchase an Anti-Telemarketing Device for $497.99 from a Marketing company based in Arizona?" When you say "No", the caller continues with, "Then we will be issuing a credit to your account. This is a company we have been watching and the charges range from $297 to $497, just under the $500 purchase pattern that flags most cards. Before your next statement, the credit will be sent to (gives you your address), is that correct?" You say "yes". The caller continues - "I will be starting a Fraud investigation. If you have any questions, you should call the 1- 800 number listed on the back of your card (1-800-VISA) and ask for Security. You will need to refer to this Control Number. The caller then gives you a 6 digit number. "Do you need me to read it again?" Here's the IMPORTANT part on how the scam works. The caller then says, "I need to verify you are in possession of your card" He'll ask you to "turn your card over and look for some numbers". ; There are 7 numbers; the first 4 are part of your card number, the next 3 are the security Numbers' that verify you are the possessor of the card. These are the numbers you sometimes use to make Internet purchases to prove you have the card. The caller will ask you to read the 3 numbers to him. After you tell the caller the 3 numbers, he'll say, "That is correct, I just needed to verify that the card has not been lost or stolen, and that you still have your card. Do you have any other questions?" After you say No, the caller then thanks you and states, "Don't hesitate to call back if you do", and hangs up. You actually say very little, and they never ask for or tell you the Card number. But after we were called on Wednesday, we called back within 20 minutes to ask a question. Are we glad we did! The REAL VISA Security Department told us it was a scam and in the last 15 minutes a new purchase of $497.99 was charged to our card. Long story - short - we made a real fraud report and closed the VISA account. VISA is reissuing us a new number. What the scammers want is the 3-digit PIN number on the back of the card. Don't give it to them. Instead, tell them you'll call VISA or Master card directly for verification of their conversation. The real VISA told us that they will NEVER ask for anything on the card as they already know the information since they issued the card! If you give the scammers your 3 Digit PIN Number, you think you're receiving a credit. However, by the time you get your statement you'll see charges for purchases you didn't make, and by then it's almost too late and/or more difficult to actually file a fraud report. What makes this more remarkable is that on Thursday, I got a call from a "Jason Richardson of Master Card" with a word-for-word repeat of the VISA scam. This time I didn't let him finish. I hung up! We filed a police report, as instructed by VISA. The police said they are taking several of these reports daily! They also urged us to tell everybody we know that this scam is happening. __,_._,___ 11/9/2007 7:29 PM 11/11/2007 9:50 PM ________________________________________________________________________________
Subject: Re: getting way to much mail
Date: Nov 12, 2007
Every day now I get about 12000 emails from RV list. how do I stop receiving the archives? There must be some simple way to stop the madness. thanks dave > > ________________________________________________________________________________
Date: Nov 12, 2007
http://www.matronics.com/subscribe/ _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Cudney Sent: Monday, November 12, 2007 9:30 AM Subject: RV-List: Re: getting way to much mail Every day now I get about 12000 emails from RV list. how do I stop receiving the archives? There must be some simple way to stop the madness. thanks dave href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/N avigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 12, 2007
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Subject: RV Nose Gear Leg "Box"
Date: Nov 12, 2007
Where is the web site that has the description of the 'box' they desire you to use to send your gear leg to Lange for shortening? thanks ________________________________________________________________________________
Subject: Re: RV Nose Gear Leg "Box"
Date: Nov 12, 2007
http://www.langair.com/matchdrilling.html I used plywood for a sturdier box. Ron Lee ----- Original Message ----- From: John Fasching To: rv-list(at)matronics.com Sent: Monday, November 12, 2007 9:37 AM Subject: RV-List: RV Nose Gear Leg "Box" Where is the web site that has the description of the 'box' they desire you to use to send your gear leg to Lange for shortening? thanks ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Nov 12, 2007
If you are getting 12,000 emails daily, less than 50 are from the RV list o r else your ISP has something horribly misconfigured. I would suggest eith er investing in a good SPAM filter for your desktop mail client or a real q uick fix is to change your email address to something else and resubscribin g. If you want a idea of the number of emails you should be getting on any giv en day you can go here: http://www.matronics.com/browse/rv-list/ This shows that 71 messages were posted to the Matronics RV List in the las t 7 days. Hope this helps. Michael Sausen From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server@matro nics.com] On Behalf Of Dave Cudney Sent: Monday, November 12, 2007 9:30 AM Subject: RV-List: Re: getting way to much mail Every day now I get about 12000 emails from RV list. how do I stop receivin g the archives? There must be some simple way to stop the madness. thanks dave href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.co m/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Skybolt Anniversary Sale
Date: Nov 12, 2007
I just called Skybolt to order my cowl fasteners. I had attended their Forum this past year at SnF and they agreed to offer a 20% discount whenever I was ready to order. When I called, they told me they have just reduced their prices on ALL fasteners in honor of their 25th Anniversary by 25%. Just passing along the good news... http://www.skybolt.com/ Bret Smith RV-9A "Fuselage" Blue Ridge, GA www.FlightInnovations.com ________________________________________________________________________________
Date: Nov 12, 2007
From: Bobby Hester <bobbyhester(at)newwavecomm.net>
http://www.langair.com/matchdrilling.html If you are using SeaMonkey as your browser the drawing does not show up, use Internet Explorer and it will show up. ---- Surfing the web from Hopkinsville, KY Visit my RV7A web site: http://www.geocities.com/hester-hoptown/RVSite/ John Fasching wrote: > Where is the web site that has the description of the 'box' they > desire you to use to send your gear leg to Lange for shortening? > > thanks > * > > > * ________________________________________________________________________________
Subject: Airpax Circuit Breaker/Switches
Date: Nov 12, 2007
I purchased a number of Airpax circuit breaker/switches from a vendor at Oshkosh and have used them successfully in my rv-4 for 15 years. Recently one has failed (my strobe light can only be turned off with the master switch now). Does anyone know of a source for these items? Thanks, Ivan Haecker -4 1430hrs. S. Cen. TX ________________________________________________________________________________
Subject: airpax circuit breaker switches
Date: Nov 12, 2007
There are circuit breaker switches available from Digikey. www.digikey.com I used one of these to add a pitot heat circuit to my Glastar. they are a W31 series circuit breaker switch. PB417-nd is a 10 amp breaker. They are availbe from 1 amp to 50 amps Bob Newman ________________________________________________________________________________
Date: Nov 12, 2007
yesterday I got 19568 --- all from RV list dating from May 31, 2006. dave On Nov 12, 2007, at 9:21 AM, RV Builder (Michael Sausen) wrote: > If you are getting 12,000 emails daily, less than 50 are from the > RV list or else your ISP has something horribly misconfigured. I > would suggest either investing in a good SPAM filter for your > desktop mail client or a real quick fix is to change your email > address to something else and resubscribing. > > > If you want a idea of the number of emails you should be getting on > any given day you can go here: > > > http://www.matronics.com/browse/rv-list/ > > > This shows that 71 messages were posted to the Matronics RV List in > the last 7 days. Hope this helps. > > > Michael Sausen > > > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Dave Cudney > Sent: Monday, November 12, 2007 9:30 AM > To: rv-list(at)matronics.com > Subject: RV-List: Re: getting way to much mail > > > Every day now I get about 12000 emails from RV list. how do I stop > receiving the archives? There must be some simple way to stop the > madness. > > > thanks > > dave > > > href="http://www.matronics.com/contribution">http:// > www.matronics.com/contribution > href="http://www.matronics.com/Navigator?RV-List">http:// > www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > > > http://www.matronics.com/contribution > http://www.matronics.com/Navigator?RV-List > http://forums.matronics.com > > ============================================================ _- > www.matronics.com/Navigator?RV-List_- > ============================================================ _- > forums.matronics.com_- > =========================================================== > ________________________________________________________________________________
Date: Nov 12, 2007
Subject: Re: Airpax Circuit Breaker/Switches
Airpax was acquired by Sensata this year. Product and source information is available at: http://www.airpax.net/ Mike > I purchased a number of Airpax circuit breaker/switches from a vendor at > Oshkosh and have used them successfully in my rv-4 for 15 years. Recently > one has failed (my strobe light can only be turned off with the master > switch now). Does anyone know of a source for these items? > > Thanks, > > Ivan Haecker -4 1430hrs. S. Cen. TX ________________________________________________________________________________
Date: Nov 13, 2007
Subject: List of Contributors
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Factory recall gear leg
Date: Nov 13, 2007
On 12-Nov-07, at 10:52 PM, Jeff Dowling wrote: > > > > Why is it our responsibility to pay for a design flaw? Could you > imagine what would happen to Ford? Would you rather that Van increased kit costs to cover potential future costs of recommended design changes? Fords come with warrantees, and the design must meet standards set by the feds. The feds require that the costs of mandatory recalls be borne by the automobile manufacturer. If you want an aircraft with a warranty, and that meets some specified design standards, you need to purchase a type certificated aircraft. Check out the cost of a new Cessna, then decide whether the cost of an RV, plus a replacement nose gear leg is a good value or not. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: Needed: Answer; Is Non-TSO Altimeter - Good for IFR?
Date: Nov 13, 2007
Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check.? The altimeter (I just found out) is non-TSO'd.? Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft?? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff ________________________________________________________________________ ________________________________________________________________________________
Date: Nov 13, 2007
Subject: Re: Needed: Answer; Is Non-TSO Altimeter - Good for IFR?
My gut says non TSO is a no go for IFR, but I will try going through the regs tonight when I have more time. My thought is you'd probably want the best and most trusted equipment for flying IFR since you only get one chance to get it right ;) Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) darnpilot(at)aol.com wrote: > Help. > > My Glasair III needs its two year IFR certification, i.e., > pitot/static, altimeter, & transponder check. The altimeter (I just > found out) is non-TSO'd. Does anyone have the Regs and/or > clarification that says this is legal for IFR in an experimental > aircraft? My local avionics shop says no, and will not do the test > and certification. > > Thank you in advance. > > Jeff > ------------------------------------------------------------------------ > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>! > > ________________________________________________________________________________
Date: Nov 13, 2007
I ENCOUNTERED THE SAME PROBLEM WITH 3 DIFFERENT RV'S AND 2 AVIONICS SHOPS. I PUT IN A TSO'D ALTIMETER AND ENCODER SO THERE IS NO QUESTION. GOOD LUCK. DOUG PRESTON RV-10 N372RV? 78 HRS. -----Original Message----- From: darnpilot(at)aol.com Sent: Tue, 13 Nov 2007 6:18 am Subject: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check.? The altimeter (I just found out) is non-TSO'd.? Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft?? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff ________________________________________________________________________ ________________________________________________________________________________
Subject: Re:Propeller for sale
Date: Nov 13, 2007
Yes density altitudes. The tests were done 3 days apart and OAT and altimeter setting were almost equal at altitude. Yes I measured it to 0.1 kts using 3 way GPS heading. For each RPM (2400 & 2500) and each altitude (6000 & 9000) the test was performed 4 times (and results averaged). 0.1 kts is difficult to measure but I actually recorded the GPS speed every second for 3 mins (using a laptop & GNS430 & GNC300XL). The values were then entered into Excel spreadsheet and observed if the speed settled out. I decided before the test if the variation was greater than 0.5 kts, I would discard the data. This only occurred once during the test. Typically the variation near the end of the run was 0.3 kts so I consider the error in the measurements to be +- 0.15 kts. To get the actual TAS a excel spreadsheet was again used. The speeds are not averaged but instead vectors determined, wind, actual mag heading, etc. This is a normal flight test technique that is well known. Again the best rate of climb was performed 4 times each and timed. Feet per minute calculated. Other insights? Not much beyond what I wrote earlier. I did perform the test on 3 headings 000, 120, and 240 degrees but you can actually use any reasonable headings. Not 090, 091, and 092 obviously but they don't need to be 120 degrees apart. You just need 3 vector data. I flew the legs both with autopilot (2 axis) on and off. The error with each was about the same. Of course recording the data with autopilot on is easier. Also try and record as much data was you can by voice or recording equipment. I did write some stuff down but for example during the start of the climb I wanted to record OAT, MP, start the clock, and ensure maintaining exactly 110 kts IAS. Hard to write these things down sometimes. Another thing to keep in mind is it can be beneficial to record magnetic heading as well. A vector calculation later can provide your actual magnetic heading and therefore the error in your compass. And easy compass swing although you'll only have data for the 3 headings you flew on. And of course make (especially for the climb tests) sure your airspeed ind is accurate. Steve RV7A > Steve, > Thanks for sharing the results of your testing! Curious... > 1) For our benefit, were the altitudes below density altitudes (versus > indicated)? > 2) Also, how did you measure speed to .1 knots? > 3) Did you attempt each maneuver (i.e. best rate of climb) multiple times to > understand the potential variability in technique etc? > 4) Any other insights to can share from your testing approach? > Rick > ________________________________________________________________________________
Date: Nov 13, 2007
One other thing...the EAA on their website says it is OK.? Seems a bit of a gray area, but the EAA seems confident in their interpretation.? Is there any FAA type letters confirming the EAA's position?? I called several major avionics shops, and mostly got it was OK, but a couple "no it is not".? I'm confused, but would prefer to not spend $800+ on a TSO'd altimeter, when I have what seems like a perfectly good altimeter.? If it passes the test, then how is it inferior?? Would the (God forbid) insurance company take a more strident view? TIA Jeff -----Original Message----- From: darnpilot(at)aol.com Sent: Tue, 13 Nov 2007 7:18 am Subject: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check.? The altimeter (I just found out) is non-TSO'd.? Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft?? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff ________________________________________________________________________ ________________________________________________________________________________
Date: Nov 13, 2007
Date: Nov 13, 2007
Jeff, I just sent a post on the RV-list about my experience with a non-TSOd altimeter (Falcon). Mine passed the altimeter/transponder/static system two times in the last 3 years at an FAA repair station. The technician said that he couldn't issue a yellow tag because of the non TSO nature ot my altimeter but attached a label that it was certified to 20,000 feet. In case you didn't read my previous post, I will add it below. It now reads 10,000 feet. ============================ FWIW - I have a Falcon altimeter that I installed in my RV-6A about four years ago. The plane has been flying since February 2005 and has about 130 hours. The altimeter has been certified twice to 20,000 feet per FAR 43 App. E at an FAA repair station with no problems, the latest check in February this year. I even posted and e-mail on the RV-list indicating my delight in this reasonably priced, Chinese made instrument being so precise and reliable. A week ago in checking the cockpit in preparation for a flight, about two weeks since my last flight, I found the altimeter reading about 4000 feet. In in the process of trouble shooting, I disconnected the static line from the altimeter and found that it was still reading 4000 feet. The problem was obviously internal in the altimeter. I removed it from the instrument panel and took it home. After a week on my desk, the indicated altitude has increased to about 9000 feet and is still slowly climbing. Consulting with the Wultrad folks I found that the instrument could be overhauled for $150. Since the current price is about $250 this was not attractive. And, since my confidence in the reliability of the instrument had been destroyed, I "bit the bullet" and purchased a United, TSOd altimeter at about three times the price of the Falcon. If you, have one of these you may want to keep a close eye on the field altitude at the correct altimeter setting. I noticed a small increase in the indicated field altitude a few weeks before the very large increase I mentioned =============================== Best regards and good luck, Richard Dudley RV-6A flying darnpilot(at)aol.com wrote: > One other thing...the EAA on their website says it is OK. Seems a bit > of a gray area, but the EAA seems confident in their interpretation. > Is there any FAA type letters confirming the EAA's position? > > I called several major avionics shops, and mostly got it was OK, but a > couple "no it is not". I'm confused, but would prefer to not spend > $800+ on a TSO'd altimeter, when I have what seems like a perfectly > good altimeter. If it passes the test, then how is it inferior? > Would the (God forbid) insurance company take a more strident view? > > TIA > > Jeff > > > -----Original Message----- > From: darnpilot(at)aol.com > To: rv-list(at)matronics.com > Sent: Tue, 13 Nov 2007 7:18 am > Subject: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? > > Help. > > My Glasair III needs its two year IFR certification, i.e., > pitot/static, altimeter, & transponder check. The altimeter (I just > found out) is non-TSO'd. Does anyone have the Regs and/or > clarification that says this is legal for IFR in an experimental > aircraft? My local avionics shop says no, and will not do the test > and certification. > > Thank you in advance. > > Jeff > ------------------------------------------------------------------------ > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>! > > ________________________________________________________________________________
Subject: Trade RV7 vertical induction cowling for horizontal cowling
Date: Nov 13, 2007
Anyone out there having a horizonal induction cowling for an RV-7 for sale or trade? I have the original vertical scooped cowling but decided to buy a horizontal feed engine. Contact off line Marty Heller RV-7 (Fitting the roll bar) _________________________________________________________________ Peek-a-boo FREE Tricks & Treats for You! http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us ________________________________________________________________________________
Date: Nov 13, 2007
Without question, non-TSO is OK for experimental aircraft. I would consider making the shop show you where it says that a TSO is required to pass the static-system test. I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and they both pass every time. Both are easy to calibrate down to less than 10' error at any altitude. - i.e. they both outperform any TSO steam guage. But that is beside the point. If you google you can find a copy of the instructions for performing the static system test. Dave Leonard On Nov 13, 2007 7:18 AM, wrote: > Help. > > My Glasair III needs its two year IFR certification, i.e., pitot/static, > altimeter, & transponder check. The altimeter (I just found out) is > non-TSO'd. Does anyone have the Regs and/or clarification that says this is > legal for IFR in an experimental aircraft? My local avionics shop says no, > and will not do the test and certification. > > Thank you in advance. > > Jeff > ------------------------------ > ! > > * > > * > > -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net ________________________________________________________________________________
Date: Nov 13, 2007
Jeff, There is no requirement for any instrument to be TSO'd. By regulation the ELT and the transponder must meet a TSO standard. That's all! If the inst rument can be tested to show its accuracy then it is acceptable for use in your Glasair III under IFR. Mike Robertson Das Fed eter - Good for IFR?Date: Tue, 13 Nov 2007 07:18:19 -0500From: darnpilot@ao l.com Help.My Glasair III needs its two year IFR certification, i.e., pitot/stati c, altimeter, & transponder check. The altimeter (I just found out) is non -TSO'd. Does anyone have the Regs and/or clarification that says this is l egal for IFR in an experimental aircraft? My local avionics shop says no, and will not do the test and certification.Thank you in advance.Jeff _________________________________________________________________ ! ilnews ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Date: Nov 13, 2007
Jeff, I believe that the regs actually state that only an A&P with correct equipment can do your 2 yr/signed off by IA. In other words, an Avionics shop is NOT your only source to get the work done legally. Sounds like someone is trying to sell you an instrument. Ditto, it doesn't have to be TSO instruments, they just have to pass. If that were the case I think that Garmin, Chelton, Avidyne, and OP are the only companies that offer TSO'd electric panels(MFD"S), and they cost mucho $. And there are a bunch of MFD's that are IFR compliant, and used. As Dave pointed out, more accurate than steam gauges. Try contacting your local EAA counselor or the EAA wedsite for more info. Also you FAR/AIM '08 edition will spell it all out for you. Mike H ----- Original Message ----- From: David Leonard To: rv-list(at)matronics.com Sent: Tuesday, November 13, 2007 10:04 AM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Without question, non-TSO is OK for experimental aircraft. I would consider making the shop show you where it says that a TSO is required to pass the static-system test. I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and they both pass every time. Both are easy to calibrate down to less than 10' error at any altitude. - i.e. they both outperform any TSO steam guage. But that is beside the point. If you google you can find a copy of the instructions for performing the static system test. Dave Leonard On Nov 13, 2007 7:18 AM, wrote: Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check. The altimeter (I just found out) is non-TSO'd. Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff ------------------------------------------------------------------------- --- -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net ________________________________________________________________________________
Subject: Factory recall gear leg
Date: Nov 13, 2007
I think it is the idea of a "design flaw" in an experimental aircraft kit that bugs me. If we take this concept to its logical conclusion, any refinement or improvement in the design means that the previous version was flawed. Attach liability or responsibility to correct all previous versions and that would put a stop to any improvements and make the concept of experimental meaningless. Terry -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: Tuesday, November 13, 2007 3:11 AM Subject: Re: RV-List: Factory recall gear leg On 12-Nov-07, at 10:52 PM, Jeff Dowling wrote: > > > > Why is it our responsibility to pay for a design flaw? Could you > imagine what would happen to Ford? Would you rather that Van increased kit costs to cover potential future costs of recommended design changes? Fords come with warrantees, and the design must meet standards set by the feds. The feds require that the costs of mandatory recalls be borne by the automobile manufacturer. If you want an aircraft with a warranty, and that meets some specified design standards, you need to purchase a type certificated aircraft. Check out the cost of a new Cessna, then decide whether the cost of an RV, plus a replacement nose gear leg is a good value or not. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Nov 13, 2007
From: "Greg Williams" <mr.gsun+rv-list(at)gmail.com>
Subject: Re: Trade RV7 vertical induction cowling for horizontal cowling
Was wondering if there are any flight benefits to the horizontal induction cowling vs having the snout underneath? Drag, speed, power etc? Or is it just a personal preference "looks" sort of thing? On 11/13/07, Marty Helller wrote: > > Anyone out there having a horizonal induction cowling for an RV-7 for > sale or trade? I have the original vertical scooped cowling but decided to > buy a horizontal feed engine. > > Contact off line > Marty Heller > RV-7 (Fitting the roll bar) > > > ------------------------------ > Peek-a-boo FREE Tricks & Treats for You! Get 'em!<http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us> > > * > > > * > > ________________________________________________________________________________
Date: Nov 13, 2007
So does that mean that the glass cockpit stuff (Dynon, Blue Mountain etc) won't be usable for IFR in an RV? On 11/13/07, darnpilot(at)aol.com wrote: > > Help. > > My Glasair III needs its two year IFR certification, i.e., pitot/static, > altimeter, & transponder check. The altimeter (I just found out) is > non-TSO'd. Does anyone have the Regs and/or clarification that says this is > legal for IFR in an experimental aircraft? My local avionics shop says no, > and will not do the test and certification. > > Thank you in advance. > > Jeff > ------------------------------ > ! > > * > > > * > > ________________________________________________________________________________
Date: Nov 13, 2007
The horizontal induction is supposed to add about 7HP to engine performance .... at least that's what I was told when paying for the extra sump. Marty Heller RV-7 (fitting roll bar) Date: Tue, 13 Nov 2007 09:39:17 -0800From: mr.gsun+rv-list(at)gmail.comTo: rv- list(at)matronics.comSubject: Re: RV-List: Trade RV7 vertical induction cowlin g for horizontal cowlingWas wondering if there are any flight benefits to t he horizontal induction cowling vs having the snout underneath? Drag, spee d, power etc? Or is it just a personal preference "looks" sort of thing? On 11/13/07, Marty Helller wrote: Anyone out there having a horizonal induction cowling for an RV-7 for sale or trade? I have the original vertical scooped cowling but decided to buy a horizontal feed engine. Contact off lineMarty HellerRV-7 (Fitting the rol l bar) Peek-a-boo FREE Tricks & Treats for You! Get 'em! _________________________________________________________________ Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop by today. http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_Oc tWLtagline ________________________________________________________________________________
Date: Nov 13, 2007
"Why is it our responsibility to pay for a design flaw? Could you imagine what would happen to Ford? " Safety! Value! Van's prices are very reasonable, his designs are first rate and the overall value is unquestionable. The cost of a new fork and re-machining the gear leg is trivial compared to many other things. Look it as Gear leg 2007 and you don't even need to buy a new airplane to install it. My recalled Volvo tailgate latch was free but they charged me $200+ to reattach the interior that had broken loose due to slamming the gate. I say cheap insurance. Van could build this cost into everything he sells plus a war chest for the likes of Alan Wolk. You do have the option of not upgrading the gear. It's all a matter of perspective. We should just willingly pay a fair price for value. If all folks were fair we would not be paying the usurious rates we now pay for so many things because of lawsuits and the idea that if something bad happens someone else must pay. Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
Date: Nov 13, 2007
Time to find a new avionics shop. Paul Besing ----- Original Message ---- From: "darnpilot(at)aol.com" <darnpilot(at)aol.com> Sent: Tuesday, November 13, 2007 5:18:19 AM Subject: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check. The altimeter (I just found out) is non-TSO'd. Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Nov 13, 2007
Good luck with that. As soon as they find out it's "Experimental" some places are sent slamming their doors, throwing away the key, and changing their phone number because they are so afraid of those crazy people who build airplanes in the garages. I was lucky, I'm at an airport that has alot of experimentals, and they are easy to work with. As a matter of fact, my "Non-TSO'd" Rocky Mountain uEncoder was more accurate than most he tests...he was very impressed :-) Oh yeah, and I built that in my garage too, which also gives my altitude to ATC in an IFR environment! Scary! Paul Besing ----- Original Message ---- From: David Leonard <wdleonard(at)gmail.com> Sent: Tuesday, November 13, 2007 8:04:54 AM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Without question, non-TSO is OK for experimental aircraft. I would consider making the shop show you where it says that a TSO is required to pass the static-system test. I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and they both pass every time. Both are easy to calibrate down to less than 10' error at any altitude. - i.e. they both outperform any TSO steam guage. But that is beside the point. If you google you can find a copy of the instructions for performing the static system test. Dave Leonard On Nov 13, 2007 7:18 AM, wrote: Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check. The altimeter (I just found out) is non-TSO'd. Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net Get easy, one-click access to your favorites. Make Yahoo! your homepage. http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Nov 13, 2007
I upgraded the fork when my engine was being rebuilt this summer and I have ZERO, ZIP, NADA interest in suggesting than Van's pay for it. I did not have to make the change and I do not with the service bulletin out. Avoid non-smooth landing/taxiing surfaces and you may well never have a problem. Ron Lee ________________________________________________________________________________
Date: Nov 13, 2007
So, if I want my -7 blessed for IFR, I take it to an avionics shop friendly to Experimentals and ask them to certify the airplane or each instrument? On Nov 13, 2007 3:13 PM, Paul Besing wrote: > Good luck with that. As soon as they find out it's "Experimental" some > places are sent slamming their doors, throwing away the key, and changing > their phone number because they are so afraid of those crazy people who > build airplanes in the garages. I was lucky, I'm at an airport that has > alot of experimentals, and they are easy to work with. As a matter of fact, > my "Non-TSO'd" Rocky Mountain uEncoder was more accurate than most he > tests...he was very impressed :-) Oh yeah, and I built that in my garage > too, which also gives my altitude to ATC in an IFR environment! Scary! > > Paul Besing > > ----- Original Message ---- > From: David Leonard <wdleonard(at)gmail.com> > To: rv-list(at)matronics.com > Sent: Tuesday, November 13, 2007 8:04:54 AM > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? > > Without question, non-TSO is OK for experimental aircraft. I would > consider making the shop show you where it says that a TSO is required to > pass the static-system test. > > I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and they both > pass every time. Both are easy to calibrate down to less than 10' error at > any altitude. - i.e. they both outperform any TSO steam guage. But that > is beside the point. > > If you google you can find a copy of the instructions for performing the > static system test. > > Dave Leonard > > On Nov 13, 2007 7:18 AM, wrote: > > > Help. > > > > My Glasair III needs its two year IFR certification, i.e., pitot/static, > > altimeter, & transponder check. The altimeter (I just found out) is > > non-TSO'd. Does anyone have the Regs and/or clarification that says this is > > legal for IFR in an experimental aircraft? My local avionics shop says no, > > and will not do the test and certification. > > > > Thank you in advance. > > > > Jeff > > ------------------------------ > > ! > > > > * > > > > > > * > > > > > > > -- > David Leonard > > Turbo Rotary RV-6 N4VY > http://N4VY.RotaryRoster.net > http://RotaryRoster.net > ------------------------------ > Get easy, one-click access to your favorites. > > * > > * > > ________________________________________________________________________________
Date: Nov 13, 2007
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
I agree... time to find another shop! Darrell --- Paul Besing wrote: > Time to find a new avionics shop. > > Paul Besing > > ----- Original Message ---- > From: "darnpilot(at)aol.com" <darnpilot(at)aol.com> > To: rv-list(at)matronics.com > Sent: Tuesday, November 13, 2007 5:18:19 AM > Subject: RV-List: Needed: Answer; Is Non-TSO > Altimeter - Good for IFR? > > > > Help. > > > > My Glasair III needs its two year IFR certification, > i.e., pitot/static, altimeter, & transponder check. > The altimeter (I just found out) is non-TSO'd. Does > anyone have the Regs and/or clarification that says > this is legal for IFR in an experimental aircraft? > My local avionics shop says no, and will not do the > test and certification. > > > > Thank you in advance. > > > > Jeff > > > > > > > > > > > > > > > > > Never miss a thing. Make Yahoo your home page. > http://www.yahoo.com/r/hs Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ ________________________________________________________________________________
Date: Nov 13, 2007
The only things that have to be certified for IFR are the transponder, encoder, and altimeter. All can be done in about an hour of work. You don't really certify the "airplane", just that the pitot/static and transponder have been tested and are within the standards of the regulations. This needs to be done every 24 months to be IFR "certified". I wouldn't even tell them that the instruments aren't TSO'd. Just go to an avionics shop and tell them you need a transponder and pitot static check. If they won't do it because you have a big "experimental" sticker on your plane, then you probably won't want to do business with them anyway. Ask any of the flying IFR birds, lancairs, glasairs, RV's, etc around your field and they'll tell you where to go. Paul Besing ----- Original Message ---- From: Greg Williams <mr.gsun+rv-list(at)gmail.com> Sent: Tuesday, November 13, 2007 4:40:15 PM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? So, if I want my -7 blessed for IFR, I take it to an avionics shop friendly to Experimentals and ask them to certify the airplane or each instrument? On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com> wrote: Good luck with that. As soon as they find out it's "Experimental" some places are sent slamming their doors, throwing away the key, and changing their phone number because they are so afraid of those crazy people who build airplanes in the garages. I was lucky, I'm at an airport that has alot of experimentals, and they are easy to work with. As a matter of fact, my "Non-TSO'd" Rocky Mountain uEncoder was more accurate than most he tests...he was very impressed :-) Oh yeah, and I built that in my garage too, which also gives my altitude to ATC in an IFR environment! Scary! Paul Besing ----- Original Message ---- From: David Leonard <wdleonard(at)gmail.com> Sent: Tuesday, November 13, 2007 8:04:54 AM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Without question, non-TSO is OK for experimental aircraft. I would consider making the shop show you where it says that a TSO is required to pass the static-system test. I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and they both pass every time. Both are easy to calibrate down to less than 10' error at any altitude. - i.e. they both outperform any TSO steam guage. But that is beside the point. If you google you can find a copy of the instructions for performing the static system test. Dave Leonard On Nov 13, 2007 7:18 AM, wrote: Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check. The altimeter (I just found out) is non-TSO'd. Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net Get easy, one-click access to your favorites. Be a better sports nut! Let your teams follow you with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ ________________________________________________________________________________
Date: Nov 13, 2007
Thanks for the replies.? My shop is actually pretty good (and the only one in town).? I understand, somewhat, that they are caught between the FAA and their own ignorance.? The local Orlando FSDO (avionics inspector) says the shop cannot "certify" a non-TSO'd altimeter.? They showed me the FARs that they THINK says this, but it is clear that they are wrong. My philosophy is to try to give my local shop the work, but I might be forced to go elsewhere.? It bugs me because there is no reason that I have to go to all the additional trouble and expense of an out of town avionics shop for this simple requirement. I'm going to contact the EAA and get them on the ass of the local FSDO and try to educate them accordingly.? This is the kind of excrement I was trying to get away from by going to the experimental world. Jeff -----Original Message----- From: Paul Besing <pbesing(at)yahoo.com> Sent: Tue, 13 Nov 2007 7:25 pm Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? The only things that have to be certified for IFR are the transponder, encoder, and altimeter.? All can be done in about an hour of work.? You don't really certify the "airplane", just that the pitot/static and transponder have been tested and are within the standards of the regulations.? This needs to be done every 24 months to be IFR "certified". I wouldn't even tell them that the instruments aren't TSO'd.? Just go to an avionics shop and tell them you need a transponder and pitot static check.? If they won't do it because you have a big "experimental" sticker on your plane, then you probably won't want to do business with them anyway.? Ask any of the flying IFR birds, lancairs, glasairs, RV's, etc around your field and they'll tell you where to go. Paul Besing ----- Original Message ---- From: Greg Williams <mr.gsun+rv-list(at)gmail.com> Sent: Tuesday, November 13, 2007 4:40:15 PM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? So, if I want my -7 blessed for IFR, I take it to an avionics shop friendly to Experimentals and ask them to certify the airplane or each instrument? On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com> wrote: Good luck with that.? As soon as they find out it's "Experimental" some places are sent slamming their doors, throwing away the key, and changing their phone number because they are so afraid of those crazy people who build airplanes in the garages.? I was lucky, I'm at an airport that has alot of experimentals, and they are easy to work with.? As a matter of fact, my "Non-TSO'd" Rocky Mountain uEncoder was more accurate than most he tests...he was very impressed :-)? Oh yeah, and I built that in my garage too, which also gives my altitude to ATC in an IFR environment!? Scary! Paul Besing ----- Original Message ---- From: David Leonard <wdleonard(at)gmail.com> Sent: Tuesday, November 13, 2007 8:04:54 AM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Without question, non-TSO is OK for experimental aircraft.? I would consider making the shop show you where it says that a TSO is required to pass the static-system test. I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and they both pass every time.? Both are easy to calibrate down to less than 10' error at any altitude.? - i.e. they both outperform any TSO steam guage.? But that is beside the point. If you google you can find? a copy of the instructions for performing the static system test. Dave Leonard On Nov 13, 2007 7:18 AM, wrote: Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check.? The altimeter (I just found out) is non-TSO'd.? Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft?? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net Get easy, one-click access to your favorites. Get easy, one-click access to your favorites. ________________________________________________________________________ ________________________________________________________________________________
Date: Nov 13, 2007
you folks should read the requirments to fly in an IFR inviroment and then equip accordingly -----Original Message----- From: Paul Besing <pbesing(at)yahoo.com> Sent: Tue, 13 Nov 2007 4:25 pm Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? The only things that have to be certified for IFR are the transponder, encoder, and altimeter.? All can be done in about an hour of work.? You don't really certify the "airplane", just that the pitot/static and transponder have been tested and are within the standards of the regulations.? This needs to be done every 24 months to be IFR "certified". I wouldn't even tell them that the instruments aren't TSO'd.? Just go to an avionics shop and tell them you need a transponder and pitot static check.? If they won't do it because you have a big "experimental" sticker on your plane, then you probably won't want to do business with them anyway.? Ask any of the flying IFR birds, lancairs, glasairs, RV's, etc around your field and they'll tell you where to go. Paul Besing ----- Original Message ---- From: Greg Williams <mr.gsun+rv-list(at)gmail.com> Sent: Tuesday, November 13, 2007 4:40:15 PM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? So, if I want my -7 blessed for IFR, I take it to an avionics shop friendly to Experimentals and ask them to certify the airplane or each instrument? On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com> wrote: Good luck with that.? As soon as they find out it's "Experimental" some places are sent slamming their doors, throwing away the key, and changing their phone number because they are so afraid of those crazy people who build airplanes in the garages.? I was lucky, I'm at an airport that has alot of experimentals, and they are easy to work with.? As a matter of fact, my "Non-TSO'd" Rocky Mountain uEncoder was more accurate than most he tests...he was very impressed :-)? Oh yeah, and I built that in my garage too, which also gives my altitude to ATC in an IFR environment!? Scary! Paul Besing ----- Original Message ---- From: David Leonard <wdleonard(at)gmail.com> Sent: Tuesday, November 13, 2007 8:04:54 AM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Without question, non-TSO is OK for experimental aircraft.? I would consider making the shop show you where it says that a TSO is required to pass the static-system test. I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and they both pass every time.? Both are easy to calibrate down to less than 10' error at any altitude.? - i.e. they both outperform any TSO steam guage.? But that is beside the point. If you google you can find? a copy of the instructions for performing the static system test. Dave Leonard On Nov 13, 2007 7:18 AM, wrote: Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check.? The altimeter (I just found out) is non-TSO'd.? Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft?? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net Get easy, one-click access to your favorites. Get easy, one-click access to your favorites. ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Subject: Nose Gear Leg
Date: Nov 13, 2007
Has anyone found that shortening the leg in anyway reduces the prop ground clearance? I also find that the Langair web site now states to include a check for $100 and they will refund or bill for any difference. Marty in Brentwood TN From: Ralph Hoover <hooverra(at)verizon.net> Subject: RV-List: Price for nose gear leg? Charlie, Here is the story on the gear leg mod from Harmon Lang. This is to go from a -2 to a -3, if you have the -1 I believe you need the new leg, I was unable to find the price on "the list" either. You probably need to call Van's. /"The procedure to send the nose gear for modifying. Pack it up in a box or tube and send it to Langair Machining 33094 Church Rd. Warren Or. 97053. A drawing for a box is on the web site. A tube from a carpet core also works. Include $75.00 for the work and enough to ship it back. Cash or check. We don't take credit cards. Include a return label. We will remove it from the container, cut the 1 in off, rethread and put it back in the same container. The rethreading is done with a carbide thread milling tool running in a CNC mill. If you have the mill you can do this yourself. Cutter cost and set up will only cost about $300.00 or so. Expect the time in our shop to be about 4 days. Until we know how many there will be, we have to set one day aside to do the batch that comes in for the week. Please help by making the repackaging go as easily as possible. NO CONFUSION. Harmon"/ -----Original Message----- From: Ralph Hoover [mailto:hooverra(at)verizon.net] Sent: Saturday, November 10, 2007 7:41 AM Subject: RV7A U603-2 Modification Harmon, Please supply a quotation for modification of a Vans U-603-2 nose gear leg to a U603-3 per SB 07-11-09. Thank you -- Ralph C. Hoover RV7A hooverra at verizon dot net -- Ralph C. Hoover RV7A hooverra at verizon dot net Marty ________________________________________________________________________________
Date: Nov 13, 2007
Subject: Re: Nose Gear Leg
Not for sure here, but I think the prop/ground clearance stays the same. The redesigned nose fork is where the difference is, it allows the leg to be shorter, therefore allowing more clearance between the nut and the ground. Just placed my order a few minutes ago :-) ---- Surfing the web from Hopkinsville, KY Visit my RV7A web site: http://www.geocities.com/hester-hoptown/RVSite/ Emrath wrote: > > Has anyone found that shortening the leg in anyway reduces the prop ground > clearance? I also find that the Langair web site now states to include a > check for $100 and they will refund or bill for any difference. > > Marty in Brentwood TN > > > From: Ralph Hoover <hooverra(at)verizon.net> > Subject: RV-List: Price for nose gear leg? > > > Charlie, > Here is the story on the gear leg mod from Harmon Lang. This is to go from a > -2 to a -3, if you have the -1 I believe you need the new leg, I was unable > to find the price on "the list" either. You probably need to call Van's. > > /"The procedure to send the nose gear for modifying. > Pack it up in a box or tube and send it to Langair Machining 33094 Church > Rd. Warren Or. 97053. A drawing for a box is on the web site. A tube from a > carpet core also works. Include $75.00 for the work and enough to ship it > back. Cash or check. We don't take credit cards. Include a return label. We > will remove it from the container, cut the 1 in off, rethread and put it > back in the same container. The rethreading is done with a carbide thread > milling tool running in a CNC mill. If you have the mill you can do this > yourself. Cutter cost and set up will only cost about $300.00 or so. Expect > the time in our shop to be about 4 days. Until we know how many there will > be, we have to set one day aside to do the batch that comes in for the week. > Please help by making the repackaging go as easily as possible. NO > CONFUSION. Harmon"/ > > -----Original Message----- > From: Ralph Hoover [mailto:hooverra(at)verizon.net] > Sent: Saturday, November 10, 2007 7:41 AM > Subject: RV7A U603-2 Modification > > Harmon, > Please supply a quotation for modification of a Vans U-603-2 nose > gear leg to a U603-3 per SB 07-11-09. > Thank you > > -- Ralph C. Hoover RV7A hooverra at verizon dot net > > ________________________________________________________________________________
Date: Nov 13, 2007
Subject: Airplane jacking, nose gear removal
I just finished removal and packing of my gear leg. Packing is worse that removal. I put a short padded saw horse under the tail and loaded it with 3 bags of sand. (I strapped the bags to the tail) The tail feathers are off until the gear comes back and I move to the airport which should happen soon. For packing I used a heavy cardboard tube ~1/4" wall. I cut it at 20 degrees about 10 inches from the end and spliced it back together with plywood angles screwed inside the tube. The gear leg is a close fit between the splice plates. the top end is held with a plywood disc with a hole to fit the leg screwed into the tube. -- Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
Date: Nov 13, 2007
With the new fork there is a 'rake' adjustment. Shortening the leg does nothing but raise the threads as the thickness of the fork yoke is narrower. How much difference in 'rake' (angle on the fork) to my knowledge has not been published. Darrell --- Bobby Hester wrote: > > > Not for sure here, but I think the prop/ground > clearance stays the same. > The redesigned nose fork is where the difference is, > it allows the leg > to be shorter, therefore allowing more clearance > between the nut and the > ground. Just placed my order a few minutes ago :-) > > ---- > Surfing the web from Hopkinsville, KY > Visit my RV7A web site: > http://www.geocities.com/hester-hoptown/RVSite/ > > > > Emrath wrote: > > > > > Has anyone found that shortening the leg in anyway > reduces the prop ground > > clearance? I also find that the Langair web site > now states to include a > > check for $100 and they will refund or bill for > any difference. > > > > Marty in Brentwood TN > > > > > > From: Ralph Hoover <hooverra(at)verizon.net> > > Subject: RV-List: Price for nose gear leg? > > > > > > Charlie, > > Here is the story on the gear leg mod from Harmon > Lang. This is to go from a > > -2 to a -3, if you have the -1 I believe you need > the new leg, I was unable > > to find the price on "the list" either. You > probably need to call Van's. > > > > /"The procedure to send the nose gear for > modifying. > > Pack it up in a box or tube and send it to Langair > Machining 33094 Church > > Rd. Warren Or. 97053. A drawing for a box is on > the web site. A tube from a > > carpet core also works. Include $75.00 for the > work and enough to ship it > > back. Cash or check. We don't take credit cards. > Include a return label. We > > will remove it from the container, cut the 1 in > off, rethread and put it > > back in the same container. The rethreading is > done with a carbide thread > > milling tool running in a CNC mill. If you have > the mill you can do this > > yourself. Cutter cost and set up will only cost > about $300.00 or so. Expect > > the time in our shop to be about 4 days. Until we > know how many there will > > be, we have to set one day aside to do the batch > that comes in for the week. > > Please help by making the repackaging go as easily > as possible. NO > > CONFUSION. Harmon"/ > > > > -----Original Message----- > > From: Ralph Hoover [mailto:hooverra(at)verizon.net] > > Sent: Saturday, November 10, 2007 7:41 AM > > Subject: RV7A U603-2 Modification > > > > Harmon, > > Please supply a quotation for modification of > a Vans U-603-2 nose > > gear leg to a U603-3 per SB 07-11-09. > > Thank you > > > > -- Ralph C. Hoover RV7A hooverra at verizon dot > net > > > > > > > > Click on > about > Admin. > > browse > Un/Subscription, > FAQ, > > Forums! > > > > > Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs Get easy, one-click access to your favorites. Make Yahoo! your homepage. http://www.yahoo.com/r/hs ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Nov 13, 2007
It is shortened from the bottom which increases ground clearance for the fork but has no impact on prop clearance. Attached pix might help. Not sure whose it is but it shows the difference well. Also the $100 from Lang is really $75 for machining and $25 for freight back and he sends you a check for the diff. I think mine was about $8 back. He did a perfect job and I had it back in two weeks. A bargain! Building the box was the hard part. Bill S 7a Ark -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Emrath Sent: Tuesday, November 13, 2007 8:16 PM Subject: RV-List: Nose Gear Leg Has anyone found that shortening the leg in anyway reduces the prop ground clearance? I also find that the Langair web site now states to include a check for $100 and they will refund or bill for any difference. Marty in Brentwood TN From: Ralph Hoover <hooverra(at)verizon.net> Subject: RV-List: Price for nose gear leg? Charlie, Here is the story on the gear leg mod from Harmon Lang. This is to go from a -2 to a -3, if you have the -1 I believe you need the new leg, I was unable to find the price on "the list" either. You probably need to call Van's. /"The procedure to send the nose gear for modifying. Pack it up in a box or tube and send it to Langair Machining 33094 Church Rd. Warren Or. 97053. A drawing for a box is on the web site. A tube from a carpet core also works. Include $75.00 for the work and enough to ship it back. Cash or check. We don't take credit cards. Include a return label. We will remove it from the container, cut the 1 in off, rethread and put it back in the same container. The rethreading is done with a carbide thread milling tool running in a CNC mill. If you have the mill you can do this yourself. Cutter cost and set up will only cost about $300.00 or so. Expect the time in our shop to be about 4 days. Until we know how many there will be, we have to set one day aside to do the batch that comes in for the week. Please help by making the repackaging go as easily as possible. NO CONFUSION. Harmon"/ -----Original Message----- From: Ralph Hoover [mailto:hooverra(at)verizon.net] Sent: Saturday, November 10, 2007 7:41 AM Subject: RV7A U603-2 Modification Harmon, Please supply a quotation for modification of a Vans U-603-2 nose gear leg to a U603-3 per SB 07-11-09. Thank you -- Ralph C. Hoover RV7A hooverra at verizon dot net -- Ralph C. Hoover RV7A hooverra at verizon dot net Marty =D2=D3=AC List 7-Day ________________________________________________________________________________
Date: Nov 13, 2007
The hole for the axle and the forward hole for holding the nose wheel fairing are in the same place. The top of the fork is in the same place. The bottom angle has changed but is not a factor. Ron Lee ----- Original Message ----- From: "Darrell Reiley" <lifeofreiley2003(at)yahoo.com> Sent: Tuesday, November 13, 2007 8:34 PM Subject: Re: RV-List: Nose Gear Leg > > With the new fork there is a 'rake' adjustment. > Shortening the leg does nothing but raise the threads > as the thickness of the fork yoke is narrower. How > much difference in 'rake' (angle on the fork) to my > knowledge has not been published. > > Darrell > > > --- Bobby Hester wrote: > >> >> >> Not for sure here, but I think the prop/ground >> clearance stays the same. >> The redesigned nose fork is where the difference is, >> it allows the leg >> to be shorter, therefore allowing more clearance >> between the nut and the >> ground. Just placed my order a few minutes ago :-) >> >> ---- >> Surfing the web from Hopkinsville, KY >> Visit my RV7A web site: >> http://www.geocities.com/hester-hoptown/RVSite/ >> >> >> >> Emrath wrote: >> >> > >> > Has anyone found that shortening the leg in anyway >> reduces the prop ground >> > clearance? I also find that the Langair web site >> now states to include a >> > check for $100 and they will refund or bill for >> any difference. >> > >> > Marty in Brentwood TN >> > >> > >> > From: Ralph Hoover <hooverra(at)verizon.net> >> > Subject: RV-List: Price for nose gear leg? >> > >> > >> > Charlie, >> > Here is the story on the gear leg mod from Harmon >> Lang. This is to go from a >> > -2 to a -3, if you have the -1 I believe you need >> the new leg, I was unable >> > to find the price on "the list" either. You >> probably need to call Van's. >> > >> > /"The procedure to send the nose gear for >> modifying. >> > Pack it up in a box or tube and send it to Langair >> Machining 33094 Church >> > Rd. Warren Or. 97053. A drawing for a box is on >> the web site. A tube from a >> > carpet core also works. Include $75.00 for the >> work and enough to ship it >> > back. Cash or check. We don't take credit cards. >> Include a return label. We >> > will remove it from the container, cut the 1 in >> off, rethread and put it >> > back in the same container. The rethreading is >> done with a carbide thread >> > milling tool running in a CNC mill. If you have >> the mill you can do this >> > yourself. Cutter cost and set up will only cost >> about $300.00 or so. Expect >> > the time in our shop to be about 4 days. Until we >> know how many there will >> > be, we have to set one day aside to do the batch >> that comes in for the week. >> > Please help by making the repackaging go as easily >> as possible. NO >> > CONFUSION. Harmon"/ >> > >> > -----Original Message----- >> > From: Ralph Hoover [mailto:hooverra(at)verizon.net] >> > Sent: Saturday, November 10, 2007 7:41 AM >> > Subject: RV7A U603-2 Modification >> > >> > Harmon, >> > Please supply a quotation for modification of >> a Vans U-603-2 nose >> > gear leg to a U603-3 per SB 07-11-09. >> > Thank you >> > >> > -- Ralph C. Hoover RV7A hooverra at verizon dot >> net >> > >> > >> >> >> >> Click on >> about >> Admin. >> >> browse >> Un/Subscription, >> FAQ, >> >> Forums! >> >> >> >> >> > > > Never miss a thing. Make Yahoo your home page. > http://www.yahoo.com/r/hs > > > Get easy, one-click access to your favorites. > Make Yahoo! your homepage. > http://www.yahoo.com/r/hs > > > ________________________________________________________________________________
Date: Nov 13, 2007
Ditto what Bill said. The rake diffrence is in the fork due to the shortening of the leg at the threads. No clearance difference at all to my knowledge. Darrell --- Bill Schlatterer wrote: > It is shortened from the bottom which increases > ground clearance for the > fork but has no impact on prop clearance. Attached > pix might help. Not > sure whose it is but it shows the difference well. > > Also the $100 from Lang is really $75 for machining > and $25 for freight back > and he sends you a check for the diff. I think mine > was about $8 back. He > did a perfect job and I had it back in two weeks. A > bargain! Building the > box was the hard part. > > Bill S > 7a Ark > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On > Behalf Of Emrath > Sent: Tuesday, November 13, 2007 8:16 PM > To: rv-list(at)matronics.com > Subject: RV-List: Nose Gear Leg > > > > Has anyone found that shortening the leg in anyway > reduces the prop ground > clearance? I also find that the Langair web site > now states to include a > check for $100 and they will refund or bill for any > difference. > > Marty in Brentwood TN > > > From: Ralph Hoover <hooverra(at)verizon.net> > Subject: RV-List: Price for nose gear leg? > > > Charlie, > Here is the story on the gear leg mod from Harmon > Lang. This is to go from a > -2 to a -3, if you have the -1 I believe you need > the new leg, I was unable > to find the price on "the list" either. You probably > need to call Van's. > > /"The procedure to send the nose gear for modifying. > Pack it up in a box or tube and send it to Langair > Machining 33094 Church > Rd. Warren Or. 97053. A drawing for a box is on the > web site. A tube from a > carpet core also works. Include $75.00 for the work > and enough to ship it > back. Cash or check. We don't take credit cards. > Include a return label. We > will remove it from the container, cut the 1 in off, > rethread and put it > back in the same container. The rethreading is done > with a carbide thread > milling tool running in a CNC mill. If you have the > mill you can do this > yourself. Cutter cost and set up will only cost > about $300.00 or so. Expect > the time in our shop to be about 4 days. Until we > know how many there will > be, we have to set one day aside to do the batch > that comes in for the week. > Please help by making the repackaging go as easily > as possible. NO > CONFUSION. Harmon"/ > > -----Original Message----- > From: Ralph Hoover [mailto:hooverra(at)verizon.net] > Sent: Saturday, November 10, 2007 7:41 AM > Subject: RV7A U603-2 Modification > > Harmon, > Please supply a quotation for modification of a > Vans U-603-2 nose gear > leg to a U603-3 per SB 07-11-09. > Thank you > > -- Ralph C. Hoover RV7A hooverra at verizon dot net > > -- > Ralph C. Hoover > RV7A > hooverra at verizon dot net > > > > Marty > > > > > List > 7-Day > > > > Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Nov 13, 2007
The regulation calls for a "sensitive altimeter". Reference is 91.205. No mention of TSO at all. If you want to minimize cost, buy an overhauled unit from one of the reputable instrument shops like Century Instruments, for about $375. For certification the requirements are in Part 43, Appendix E. Again, no mention of TSO. In general, TSO is only required for Part 135 and 121. darnpilot(at)aol.com wrote: > Thanks for the replies. My shop is actually pretty good (and the only > one in town). I understand, somewhat, that they are caught between > the FAA and their own ignorance. The local Orlando FSDO (avionics > inspector) says the shop cannot "certify" a non-TSO'd altimeter. They > showed me the FARs that they THINK says this, but it is clear that > they are wrong. > > My philosophy is to try to give my local shop the work, but I might be > forced to go elsewhere. It bugs me because there is no reason that I > have to go to all the additional trouble and expense of an out of town > avionics shop for this simple requirement. > > I'm going to contact the EAA and get them on the ass of the local FSDO > and try to educate them accordingly. This is the kind of excrement I > was trying to get away from by going to the experimental world. > > Jeff > > > -----Original Message----- > From: Paul Besing <pbesing(at)yahoo.com> > To: rv-list(at)matronics.com > Sent: Tue, 13 Nov 2007 7:25 pm > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? > > The only things that have to be certified for IFR are the transponder, > encoder, and altimeter. All can be done in about an hour of work. > You don't really certify the "airplane", just that the pitot/static > and transponder have been tested and are within the standards of the > regulations. This needs to be done every 24 months to be IFR "certified". > > I wouldn't even tell them that the instruments aren't TSO'd. Just go > to an avionics shop and tell them you need a transponder and pitot > static check. If they won't do it because you have a big > "experimental" sticker on your plane, then you probably won't want to > do business with them anyway. Ask any of the flying IFR birds, > lancairs, glasairs, RV's, etc around your field and they'll tell you > where to go. > > Paul Besing > > ----- Original Message ---- > From: Greg Williams <mr.gsun+rv-list(at)gmail.com > > > To: rv-list(at)matronics.com > Sent: Tuesday, November 13, 2007 4:40:15 PM > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? > > So, if I want my -7 blessed for IFR, I take it to an avionics shop > friendly to Experimentals and ask them to certify the airplane or each > instrument? > > On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com > > wrote: > > Good luck with that. As soon as they find out it's "Experimental" > some places are sent slamming their doors, throwing away the key, > and changing their phone number because they are so afraid of > those crazy people who build airplanes in the garages. I was > lucky, I'm at an airport that has alot of experimentals, and they > are easy to work with. As a matter of fact, my "Non-TSO'd" Rocky > Mountain uEncoder was more accurate than most he tests...he was > very impressed :-) Oh yeah, and I built that in my garage too, > which also gives my altitude to ATC in an IFR environment! Scary! > > Paul Besing > > ----- Original Message ---- > From: David Leonard <wdleonard(at)gmail.com <mailto:wdleonard(at)gmail.com>> > To: rv-list(at)matronics.com > Sent: Tuesday, November 13, 2007 8:04:54 AM > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good > for IFR? > > Without question, non-TSO is OK for experimental aircraft. I > would consider making the shop show you where it says that a TSO > is required to pass the static-system test. > > I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and > they both pass every time. Both are easy to calibrate down to > less than 10' error at any altitude. - i.e. they both outperform > any TSO steam guage. But that is beside the point. > > If you google you can find a copy of the instructions for > performing the static system test. > > Dave Leonard > > On Nov 13, 2007 7:18 AM, > wrote: > > Help. > > My Glasair III needs its two year IFR certification, i.e., > pitot/static, altimeter, & transponder check. The altimeter > (I just found out) is non-TSO'd. Does anyone have the Regs > and/or clarification that says this is legal for IFR in an > experimental aircraft? My local avionics shop says no, and > will not do the test and certification. > > Thank you in advance. > > Jeff > ------------------------------------------------------------------------ > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>! > > * > > > * > > > -- > David Leonard > > Turbo Rotary RV-6 N4VY > http://N4VY.RotaryRoster.net > http://RotaryRoster.net > ------------------------------------------------------------------------ > Get easy, one-click access to your favorites. > > * > > > * > > > * > > > * > > > ------------------------------------------------------------------------ > Get easy, one-click access to your favorites. > * > > > * > ------------------------------------------------------------------------ > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>! > * > > > * ________________________________________________________________________________
Date: Nov 13, 2007
Subject: Re: Needed: Answer; Is Non-TSO Altimeter - Good for IFR?
I didn't cover the other requirements, and yes, there are other equipment requirements, but as far as an inspection for IFR cert goes, there are no other inspection/certification requirements besides the pitot/static and transponder. Obviously things like VOR checks (pilot check) and having all the other equipment, etc is another discussion. Paul Besing ----- Original Message ---- From: "passpat(at)aol.com" <passpat(at)aol.com> Sent: Tuesday, November 13, 2007 6:21:52 PM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? you folks should read the requirments to fly in an IFR inviroment and then equip accordingly -----Original Message----- From: Paul Besing <pbesing(at)yahoo.com> Sent: Tue, 13 Nov 2007 4:25 pm Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? The only things that have to be certified for IFR are the transponder, encoder, and altimeter. All can be done in about an hour of work. You don't really certify the "airplane", just that the pitot/static and transponder have been tested and are within the standards of the regulations. This needs to be done every 24 months to be IFR "certified". I wouldn't even tell them that the instruments aren't TSO'd. Just go to an avionics shop and tell them you need a transponder and pitot static check. If they won't do it because you have a big "experimental" sticker on your plane, then you probably won't want to do business with them anyway. Ask any of the flying IFR birds, lancairs, glasairs, RV's, etc around your field and they'll tell you where to go. Paul Besing ----- Original Message ---- From: Greg Williams <mr.gsun+rv-list(at)gmail.com> Sent: Tuesday, November 13, 2007 4:40:15 PM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? So, if I want my -7 blessed for IFR, I take it to an avionics shop friendly to Experimentals and ask them to certify the airplane or each instrument? On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com> wrote: Good luck with that. As soon as they find out it's "Experimental" some places are sent slamming their doors, throwing away the key, and changing their phone number because they are so afraid of those crazy people who build airplanes in the garages. I was lucky, I'm at an airport that has alot of experimentals, and they are easy to work with. As a matter of fact, my "Non-TSO'd" Rocky Mountain uEncoder was more accurate than most he tests...he was very impressed :-) Oh yeah, and I built that in my garage too, which also gives my altitude to ATC in an IFR environment! Scary! Paul Besing ----- Original Message ---- From: David Leonard <wdleonard(at)gmail.com> Sent: Tuesday, November 13, 2007 8:04:54 AM Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Without question, non-TSO is OK for experimental aircraft. I would consider making the shop show you where it says that a TSO is required to pass the static-system test. I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and they both pass every time. Both are easy to calibrate down to less than 10' error at any altitude. - i.e. they both outperform any TSO steam guage. But that is beside the point. If you google you can find a copy of the instructions for performing the static system test. Dave Leonard On Nov 13, 2007 7:18 AM, wrote: Help. My Glasair III needs its two year IFR certification, i.e., pitot/static, altimeter, & transponder check. The altimeter (I just found out) is non-TSO'd. Does anyone have the Regs and/or clarification that says this is legal for IFR in an experimental aircraft? My local avionics shop says no, and will not do the test and certification. Thank you in advance. Jeff -- David Leonard Turbo Rotary RV-6 N4VY http://N4VY.RotaryRoster.net http://RotaryRoster.net Get easy, one-click access to your favorites. Get easy, one-click access to your favorites. Email and AIM finally together. You've gotta check out free AOL Mail! Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how. http://overview.mail.yahoo.com/ ________________________________________________________________________________
Subject: Nose gear Mod, MSB
Date: Nov 14, 2007
Heres my take on this. I have hit nose hard twice in my 6a landing in gusting very high cross winds, hard enuff to hear and feel the nose gear protesting, thought it a miricle that prop didnt hit the pavement. No damage resulted for wich Im gratefull. I rarely go in to a grass strip, and when I do, I have checked it out on foot first.Then I am extra vigilant and hold nose off as long as posible and taxi slowly. I know 2 6a owners back in Atl area that have taken there 6a's into grass strips often, and under less than ideal conditions, never a problem. My conclusion is these nose gear foldups are pilot error, in some form or another. As for me, I am keeping the orig "problem" gear, and maintaining healthy respect for proper landing techniques. Charlie Heathco Fayetteville Ar ________________________________________________________________________________
Date: Nov 14, 2007
Subject: Re: Nose gear Mod, MSB
I tend to agree with you on this and am debating whether or not I will do the upgrade... My only concern is how your insurance company will react if you do have an incident and you didn't comply with the "mandatory" service bulletin... I am gong to call mine this morning and see what they say... -Bill VonDane www.rv8a.com > Charles Heathco wrote: >> Heres my take on this. I have hit nose hard twice in my 6a landing in gusting very high cross winds, hard enuff to hear and feel the nose gear protesting, thought it a miricle that prop didnt hit the pavement. No damage resulted for wich Im gratefull. I rarely go in to a grass strip, and when I do, I have checked it out on foot first.Then I am extra vigilant and hold nose off as long as posible and taxi slowly. I know 2 6a owners back in Atl area that have taken there 6a's into grass strips often, and under less than ideal conditions, never a problem. My conclusion is these nose gear foldups are pilot error, in some form or another. As for me, I am keeping the orig "problem" gear, and maintaining healthy respect for proper landing techniques. Charlie Heathco Fayetteville Ar >> >> >> ________________________________________________________________________________
Subject: Needed: Answer; Is Non-TSO Altimeter - Good for IFR?
Date: Nov 14, 2007
Not bad. You are exactly correct right up to the last sentence. Even for 121 and 135 there is no requirement for TSO. If that were true then the Ce ssna instrument cluster for their engine instrument cluster would have to b e removed as it is manufacturer specific and not TSO'd. Outside of FAR 91, which calls for a TSO for the ELT and that the Transponder must be shown t o meet a TSO standard during testing, the FARs that covers ALL instruments installed in aircraft is FAR Parts 23 through 29, and they do NOT mention T SO's at all for instruments. And we all know that FARs 23 through 29 do no t apply to Experimental aircraft. The only thing we have that covers what has to be installed in our aircraft is FAR 91.205, and only because the Ope rating Limitations bring them into play. I know that the old school inspectors with the FAA and with older establish ed repair stations don't buy this but if they were forced to look through t he FAR's and prove to you what states that all flight instruments must be T SO'd to be used for instrument flight, they could only point to the require ment for the encoding altimeter and transponder having to meet a TSO standa rd during testing, and to the ELT. Sorry for the rant but this has been a touchy subject within Flight Standar ds that I have fought, and proven. Mike Robertson Das Fed P.S. For 121 and 135 aircraft they are held to only those items listed in t he aircraft parts manuals and/or to 337's. > Date: Tue, 13 Nov 2007 22:09:17 -0700> From: kellym(at)aviating.com> To: rv- list(at)matronics.com> Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altime m(at)aviating.com>> > The regulation calls for a "sensitive altimeter". Refere nce is 91.205. > No mention of TSO at all.> If you want to minimize cost, b uy an overhauled unit from one of the > reputable instrument shops like Cen tury Instruments, for about $375.> For certification the requirements are i n Part 43, Appendix E. Again, no > mention of TSO.> In general, TSO is only required for Part 135 and 121.> > darnpilot(at)aol.com wrote:> > Thanks for t he replies. My shop is actually pretty good (and the only > > one in town). I understand, somewhat, that they are caught between > > the FAA and their own ignorance. The local Orlando FSDO (avionics > > inspector) says the sh op cannot "certify" a non-TSO'd altimeter. They > > showed me the FARs that they THINK says this, but it is clear that > > they are wrong.> >> > My ph ilosophy is to try to give my local shop the work, but I might be > > force d to go elsewhere. It bugs me because there is no reason that I > > have to go to all the additional trouble and expense of an out of town > > avionic s shop for this simple requirement.> >> > I'm going to contact the EAA and get them on the ass of the local FSDO > > and try to educate them according ly. This is the kind of excrement I > > was trying to get away from by goin g to the experimental world.> >> > Jeff> >> >> > -----Original Message----- > > From: Paul Besing <pbesing(at)yahoo.com>> > To: rv-list(at)matronics.com> > S ent: Tue, 13 Nov 2007 7:25 pm> > Subject: Re: RV-List: Needed: Answer; Is N on-TSO Altimeter - Good for IFR?> >> > The only things that have to be cert ified for IFR are the transponder, > > encoder, and altimeter. All can be d one in about an hour of work. > > You don't really certify the "airplane", just that the pitot/static > > and transponder have been tested and are wit hin the standards of the > > regulations. This needs to be done every 24 mo nths to be IFR "certified".> >> > I wouldn't even tell them that the instru ments aren't TSO'd. Just go > > to an avionics shop and tell them you need a transponder and pitot > > static check. If they won't do it because you h ave a big > > "experimental" sticker on your plane, then you probably won't want to > > do business with them anyway. Ask any of the flying IFR birds, > > lancairs, glasairs, RV's, etc around your field and they'll tell you > > where to go.> >> > Paul Besing> >> > ----- Original Message ----> > From : Greg Williams > mr.gsun+rv-list@gmai l.com>>> > To: rv-list(at)matronics.com > > Sent : Tuesday, November 13, 2007 4:40:15 PM> > Subject: Re: RV-List: Needed: An swer; Is Non-TSO Altimeter - Good for IFR?> >> > So, if I want my -7 blesse d for IFR, I take it to an avionics shop > > friendly to Experimentals and ask them to certify the airplane or each > > instrument?> >> > On Nov 13, 2 007 3:13 PM, Paul Besing < pbesing(at)yahoo.com > > > wrote:> >> > Good luck with that. As soon as they find out it's "Experime ntal"> > some places are sent slamming their doors, throwing away the key,> > and changing their phone number because they are so afraid of> > those c razy people who build airplanes in the garages. I was> > lucky, I'm at an a irport that has alot of experimentals, and they> > are easy to work with. A s a matter of fact, my "Non-TSO'd" Rocky> > Mountain uEncoder was more accu rate than most he tests...he was> > very impressed :-) Oh yeah, and I built that in my garage too,> > which also gives my altitude to ATC in an IFR en vironment! Scary!> >> > Paul Besing> >> > ----- Original Message ----> > Fr om: David Leonard >> > To: rv-list(at)matronics.com > > Sent: Tuesday, Nov ember 13, 2007 8:04:54 AM> > Subject: Re: RV-List: Needed: Answer; Is Non-T SO Altimeter - Good> > for IFR?> >> > Without question, non-TSO is OK for e xperimental aircraft. I> > would consider making the shop show you where it says that a TSO> > is required to pass the static-system test.> >> > I hav e 2 non-TSO altimiters (Rockymountain and Bluemountain) and> > they both pa ss every time. Both are easy to calibrate down to> > less than 10' error at any altitude. - i.e. they both outperform> > any TSO steam guage. But that is beside the point.> >> > If you google you can find a copy of the instru ctions for> > performing the static system test.> >> > Dave Leonard> >> > O n Nov 13, 2007 7:18 AM, > > w rote:> >> > Help.> >> > My Glasair III needs its two year IFR certification , i.e.,> > pitot/static, altimeter, & transponder check. The altimeter> > ( I just found out) is non-TSO'd. Does anyone have the Regs> > and/or clarifi cation that says this is legal for IFR in an> > experimental aircraft? My l ocal avionics shop says no, and> > will not do the test and certification.> >> > Thank you in advance.> >> > Jeff> > --------------------------------- ---------------------------------------> > <http://o.aolcdn.com/cdn.webmail .aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>!> >> > *> >> >> >> >> >> > *> >> >> >> >> > -- > > David Leonard> >> > Turbo Rotary RV-6 N4VY> > http://N4VY.RotaryRoster.net > > http://RotaryRoster.net > > ------------------- -----------------------------------------------------> > Get easy, one-clic k access to your favorites.> >> > *> >> >> > *> >> >> > *> >> >> > *> >> >> > ------------------------------------------------------------------------ > > Get easy, one-click access to your favorites.> > *> >> >> > *> > ------ ------------------------------------------------------------------> > _ -======================== ===========> > > _________________________________________________________________ Peek-a-boo FREE Tricks & Treats for You! http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us ________________________________________________________________________________
Date: Nov 14, 2007
Subject: Is this quote true, that insurance will void if not replaced?
Van is basically voiding every RV nose dragger's insurance policy until this is fixed. This quote is from one of the earlier posts. Is this true? Will my insurance company not honor any claims unless this repair is made? For the record, I do plan to make the change, I just have a distrust for insurance companies... and lawyers... and car salesmen... and cell phone companies... and Rottweillers... Kim Nicholas RV9A ________________________________________________________________________________
Date: Nov 14, 2007
In a message dated 11/14/2007 6:28:11 A.M. Pacific Standard Time, bill(at)vondane.com writes: I tend to agree with you on this and am debating whether or not I will do the upgrade... My only concern is how your insurance company will react if you do have an incident and you didn't comply with the "mandatory" service bulletin... I am gong to call mine this morning and see what they say... ==================================================== The effectivity date on the service bulletin is by next condition inspection. I will do it by then (02/2008) and I believe that that meets the letter and intent of the mandatory requirement. Am I mistaken? N1GV (RV-6A, Flying 870hrs, O-360-A1A, C/S, Silicon Valley) ________________________________________________________________________________
Date: Nov 14, 2007
If the nose gear modification is "mandatory", why has Van's Aircraft not notified builders instead of letting it be discovered? It is possible that an owner could fly for years without learning of the modifaction if he did not visit Van's web site or belong to one of the on line groups. Dale Ensing > > My only concern is how your insurance company will react if you do have an > incident and you didn't comply with the "mandatory" service bulletin > -Bill VonDane > www.rv8a.com > ________________________________________________________________________________
From: "Russell Lassetter" <rblassett(at)alltel.net>
Subject: Construction/Restoration
Date: Nov 14, 2007
Hello all, I would like to offer my aircraft construction/restoration services to the group. I have a 40' X 60' hangar in NE Georgia and have a lifetime of experience with various aircraft. I can construct large projects for $15.00 per hour with first-class workmanship. Please email me directly or give me a call. Russ Lassetter 202 Aviation Blvd. Cleveland, GA 30528 706-348-7514 rblassett(at)alltel.net ________________________________________________________________________________
Date: Nov 14, 2007
Hello Mike, I have the Dynon D10A and plan to use its encoding altimeter which is not TSO'd. Will it be acceptable per the FAR's for use if it meets the testing requirements at the instrument shop? 91.217(c) indicates that the encoder must meet TSO. Thanks in advace for clarification. Bill -------------- Original message -------------- From: Mike Robertson <mrobert569(at)hotmail.com> Not bad. You are exactly correct right up to the last sentence. Even for 121 and 135 there is no requirement for TSO. If that were true then the Cessna instrument cluster for their engine instrument cluster would have to be removed as it is manufacturer specific and not TSO'd. Outside of FAR 91, which calls for a TSO for the ELT and that the Transponder must be shown to meet a TSO standard during testing, the FARs that covers ALL instruments installed in aircraft is FAR Parts 23 through 29, and they do NOT mention TSO's at all for instruments. And we all know that FARs 23 through 29 do not apply to Experimental aircraft. The only thing we have that covers what has to be installed in our aircraft is FAR 91.205, and only because the Operating Limitations bring them into play. I know that the old school inspectors with the FAA and with older established repair stations don't buy this but if they were forced to look through the FAR's and prove to you what states that all flight instruments must be TSO'd to be used for instrument flight, they could only point to the requirement for the encoding altimeter and transponder having to meet a TSO standard during testing, and to the ELT. Sorry for the rant but this has been a touchy subject within Flight Standards that I have fought, and proven. Mike Robertson Das Fed P.S. For 121 and 135 aircraft they are held to only those items listed in the aircraft parts manuals and/or to 337's. > Date: Tue, 13 Nov 2007 22:09:17 -0700 > From: kellym(at)aviating.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? > > > The regulation calls for a "sensitive altimeter". Reference is 91.205. > No mention of TSO at all. > If you want to minimize cost, buy an overhauled unit from one of the > reputable instrument shops like Century Instruments, for about $375. > For certification the requirements are in Part 43, Appendix E. Again, no > mention of TSO. > In general, TSO is only required for Part 135 and 121. > > darnpilot(at)aol.com wrote: > > Thanks for the replies. My shop is actually pretty good (and the only > > one in town). I understand, somewhat, that they are caught between > > the FAA and their own ignorance. The local Orlando FSDO (avionics > > inspector) says the shop cannot "certify" a non-TSO'd altimeter. They > > showed me the FARs that they THINK says this, but it is clear that > > they are wrong. > > > > My philosophy is to try to give my local shop the work, but I might be > > forced to go elsewhere. It bugs me because there is no reason that I > > have to go to all the additional trouble and expense of an out of town > > avionics shop for this simple requirement. > > > > I'm going to contact the EAA and get them on the ass of the local FSDO > > and try to educate them accordingly. This is the kind of excrement I > > was trying to get away from by going to the experimental world. > > > > Jeff > > > > > > -----Original Message----- > > From: Paul Besing <pbesing(at)yahoo.com> > > To: rv-list(at)matronics.com > > Sent: Tue, 13 Nov 2007 7:25 pm > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? > > > > The only things that have to be certified for IFR are the transponder, > > encoder, and altimeter. All can be done in about an hour of work. > > You don't really certify the "airplane", just that the pitot/static > > and transponder have been tested and are within the standards of the > > regulations. This needs to be done every 24 months to be IFR "certified". > > > > I wouldn't even tell them that the instruments aren't TSO'd. Just go > > to an avionics shop and tell them you need a transponder and pitot > > static check. If they won't do it because you have a big > > "experimental" sticker on your plane, then you probably won't want to > > do business with them anyway. Ask any of the flying IFR birds, > > lancairs, glasairs, RV's, etc around your field and they'll tell you > > where to go. > > > > Paul Besing > > > > ----- Original Message ---- > > From: Greg Williams <mr.gsun+rv-list(at)gmail.com > > > > > To: rv-list(at)matronics.com > > Sent: Tuesday, November 13, 2007 4:40:15 PM > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? > > > > So, if I want my -7 blessed for IFR, I take it to an avionics shop > > friendly to Experimentals and ask them to certify the airplane or each > > instrument? > > > > On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com > > > wrote: > > > > Good luck with that. As soon as they find out it's "Experimental" > > some places are sent slamming their doors, throwing away the key, > > and changing their phone number because they are so afraid of > > those crazy people who build airplanes in the garages. I was > > lucky, I'm at an airport that has alot of experimentals, and they > > are easy to work with. As a matter of fact, my "Non-TSO'd" Rocky > > Mountain uEncoder was more accurate than most he tests...he was > > very impressed :-) Oh yeah, and I built that in my garage too, > > which also gives my altitude to ATC in an IFR environment! Scary! > > > > Paul Besing > > > > ----- Original Message ---- > > From: David Leonard <wdleonard(at)gmail.com <mailto:wdleonard(at)gmail.com>> > > To: rv-list(at)matronics.com > > Sent: Tuesday, November 13, 2007 8:04:54 AM > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good > > for IFR? > > > > Without question, non-TSO is OK for experimental aircraft. I > > would consider making the shop show you where it says that a TSO > > is required to pass the static-system test. > > > > I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and > > they both pass every time. Both are easy to calibrate down to > > less than 10' error at any altitude. - i.e. they both outperform > > any TSO steam guage. But that is beside the point. > > > > If you google you can find a copy of the instructions for > > performing the static system test. > > > > Dave Leonard > > > > On Nov 13, 2007 7:18 AM, > > wrote: > > > > Help. > > > > My Glasair III needs its two year IFR certification, i.e., > > pitot/static, altimeter, & transponder check. The altimeter > > (I just found out) is non-TSO'd. Does anyone have the Regs > > and/or clarification that says this is legal for IFR in an > > experimental aircraft? My local avionics shop says no, and > > will not do the test and certification. > > > > Thank you in advance. > > > > Jeff > > ------------------------------------------------------------------------ > > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>! > > > > * > > > > > > > > > > > > * > > > > > > > > > > -- > > David Leonard > > > > Turbo Rotary RV-6 N4VY > > http://N4VY.RotaryRoster.net > > http://RotaryRoster.net > > ------------------------------------------------------------------------ > > Get easy, one-click access to your favorites. > > > > * > > > > > > * > > > > > > * > > > > > > * > > > > > > ------------------------------------------------------------------------ > > Get easy, one-click access to your favorites. > > * > > > > > > * > > ------------------------------------------------------------------------ > > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>! > > * > > >======== > > > Peek-a-boo FREE Tricks & Treats for You! Get 'em!
Hello Mike,
I know that the old school inspectors with the FAA and with older established repair stations don't buy this but if they were forced to look throu gh the FAR's and prove to you what states that all flight instruments must be TSO'd to be used for instrument flight, they could only point to the requirement for the encoding altimeter and transponder having to meet a TSO standard during testing, and to the ELT.
Mike Robertson
Das Fed
<BR>> Date: Tue, 13 Nov 2007 22:09:17 -0700<BR>> From: kellym(at)aviating.com<BR>> To: rv-list(at)matronics.com
> --> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com>
> mention of TSO.
> > the FAA and their own ignorance . The local Orlando FSDO (avionics
> > they are wrong.
> > Jeff
> > -----Original Message-----<BR>> > From: Paul Besing <pbesing(at)yahoo.com><BR>> > To: rv-list@matroni cs.com
> > lanca irs, g lasairs, RV's, etc around your field and they'll tell you <BR>> > where to go.<BR>> ><BR>> > Paul Besing<BR>> ><BR>> > ----- Original Message ----<BR>> > From: Greg Williams <mr.gsun+rv-list(at)gmail.com <BR>> > <mailto:mr.gsun+rv-list(at)gmail.com>><BR>> > To: rv-list(at)matronics.com <mailto:rv-list(at)matronics.com><BR>> > Sent: Tuesday, November 13, 2007 4:40:15 PM<BR>> > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR?<BR>> ><BR>> > So, if I want my -7 blessed for IFR, I take it to an avionics shop <BR>> > friendly to Experimentals and ask them to certify the airplane or each <BR>> > instrument?<BR>> ><BR>> > On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com <BR>> > <mailto:pbesing(at)yahoo.com>> wrote:<BR>> ><BR>> > Good luck with that. As soon as they find out it's "Experimental"<BR>> > some places are s ent sl amming their doors, throwing away the key,<BR>> > and changing their phone number because they are so afraid of<BR>> > those crazy people who build airplanes in the garages. I was<BR>> > lucky, I'm at an airport that has alot of experimentals, and they<BR>> > are easy to work with. As a matter of fact, my "Non-TSO'd" Rocky<BR>> > Mountain uEncoder was more accurate than most he tests...he was<BR>> > very impressed :-) Oh yeah, and I built that in my garage too,<BR>> > which also gives my altitude to ATC in an IFR environment! Scary!<BR>> ><BR>> > Paul Besing<BR>> ><BR>> > ----- Original Message ----<BR>> > From: David Leonard <wdleonard(at)gmail.com <mailto:wdleonard(at)gmail.com>><BR>> > To: rv-list(at)matronics.com <mailto:rv-list(at)matronics.com><BR>> > Sent: Tuesday, November 13, 2007 8:04:54 AM<BR>> > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good<BR>> & gt; fo r IFR?
> > Dave Leonard
> > On Nov 13, 2007 7:18 AM, <darnpilot(at)aol.com
> > <mailto:darnpilot(at)aol.com>> wrote:
> > Help.
> > pitot/static, altimete r, &am p; transponder check. The altimeter
> > Jeff
> > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>!>> >
> > David Leonard
> > http://N4VY.RotaryRoster.net <http://n4vy.rotaryroster.net/>
> > http://RotaryRoster.net <http://rotaryroster.net/>> > ------------------------------------------------------------------------
http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>!>> > *
Get 'em!
Date: Nov 14, 2007
If it can be shown that the D10A encoder meets the testing requirements of FAR 43 then it may be used. What 91.217(c) states is that the altimeters a nd digitizers must meet the standards of TSO-C10b and TSO-C88 respectively. So, they do not have to meet the TSO, just meets the standards of the tho se TSO's. Basically, if the encoder meets the testing standards in FAR 43 they will meet the TSO's. The electronic standards of today's world meet or exceed the TSO requirements of yesterdays world. Dynon knew what those TS O standards were before they designed and built their units. I had the cha nce to speak with the folks from Dynon at length several years ago when the n D10 first came out, as I was concerned about this very issue. Mike Robertson Das Fed From: wgill10(at)comcast.netTo: rv-list(at)matronics.comSubject: RE: RV-List: Nee ded: Answer; Is Non-TSO Altimeter - Good for IFR?Date: Wed, 14 Nov 2007 17: Hello Mike, I have the Dynon D10A and plan to use its encoding altimeter which is not T SO'd. Will it be acceptable per the FAR's for use if it meets the testing r equirements at the instrument shop? 91.217(c) indicates that the encoder mu st meet TSO. Thanks in advace for clarification. Bill -------------- Original message -------------- From: Mike Robertson <mrober t569(at)hotmail.com> Not bad. You are exactly correct right up to the last sentence. Even for 121 and 135 there is no requirement for TSO. If that were true then the Ce ssna instrument cluster for their engine instrument cluster would have to b e removed as it is manufacturer specific and not TSO'd. Outside of FAR 91, which calls for a TSO for the ELT and that the Transponder must be shown t o meet a TSO standard during testing, the FARs that covers ALL instruments installed in aircraft is FAR Parts 23 through 29, and they do NOT mention T SO's at all for instruments. And we all know that FARs 23 through 29 do no t apply to Experimental aircraft. The only thing we have that covers what has to be installed in our aircraft is FAR 91.205, and only because the Ope rating Limitations bring them into play. I know that the old school inspect ors with the FAA and with older established repair stations don't buy this but if they were forced to look throu gh the FAR's and prove to you what st ates that all flight instruments must be TSO'd to be used for instrument fl ight, they could only point to the requirement for the encoding altimeter a nd transponder having to meet a TSO standard during testing, and to the ELT . Sorry for the rant but this has been a touchy subject within Flight Stand ards that I have fought, and proven. Mike RobertsonDas Fed P.S. For 121 and 135 aircraft they are held to only those items listed in the aircraft part s manuals and/or to 337's. > Date: Tue, 13 Nov 2007 22:09:17 -0700> From: kellym(at)aviating.com> To: rv- list(at)matronics.com> Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altime m(at)aviating.com>> > The regulation calls for a "sensitive altimeter". Refere nce is 91.205. > No mention of TSO at all.> If you want to minimize cost, b uy an overhauled unit from one of the > reputable instrument shops like Cen tury Instruments, for about $375.> For certification the requirements are i n Part 43, Appendix E. Again, no > mention of TSO.> In general, TSO is only required for Part 135 and 121.> > darnpilot(at)aol.com wrote:> > Thanks for t he replies. My shop is actually pretty good (and the only > > one in town). I understand, somewhat, that they are caught between > > the FAA and their own ignorance . The local Orlando FSDO (avionics > > inspector) says the s hop cannot "certify" a non-TSO'd altimeter. They > > showed me the FARs tha t they THINK says this, but it is clear that > > they are wrong.> >> > My p hilosophy is to try to give my local shop the work, but I might be > > forc ed to go elsewhere. It bugs me because there is no reason that I > > have t o go to all the additional trouble and expense of an out of town > > avioni cs shop for this simple requirement.> >> > I'm going to contact the EAA and get them on the ass of the local FSDO > > and try to educate them accordin gly. This is the kind of excrement I > > was trying to get away from by goi ng to the experimental world.> >> > Jeff> >> >> > -----Original Message---- -> > From: Paul Besing <pbesing(at)yahoo.com>> > To: rv-list@matroni cs.com > > Sent: Tue, 13 Nov 2007 7:25 pm> > Subject: Re: RV-List: Needed: Answer; I s Non-TSO Altimeter - Good for IFR?> >> > The only things that have to be c ertified for IFR are the transponder, > > encoder, and altimeter. All can b e done in about an hour of work. > > You don't really certify the "airplane ", just that the pitot/static > > and transponder have been tested and are within the standards of the > > regulations. This needs to be done every 24 months to be IFR "certified".> >> > I wouldn't even tell them that the ins truments aren't TSO'd. Just go > > to an avionics shop and tell them you ne ed a transponder and pitot > > static check. If they won't do it because yo u have a big > > "experimental" sticker on your plane, then you probably wo n't want to > > do business with them anyway. Ask any of the flying IFR bir ds, > > lanca irs, g lasairs, RV's, etc around your field and they'll tell you > > where to go.> >> > Paul Besing> >> > ----- Original Message ----> > From: Greg Williams <mr.gsun+rv-list(at)gmail.com > > <mailto:mr.gsun+rv-list (at)gmail.com>>> > To: rv-list(at)matronics.com > > Sent: Tuesday, November 13, 2007 4:40:15 PM> > Subject: Re: RV-List: Neede d: Answer; Is Non-TSO Altimeter - Good for IFR?> >> > So, if I want my -7 b lessed for IFR, I take it to an avionics shop > > friendly to Experimentals and ask them to certify the airplane or each > > instrument?> >> > On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com > > > wrote:> >> > Good luck with that. As soon as they find out it's "Exp erimental"> > some places are s ent sl amming their doors, throwing away th e key,> > and changing their phone number because they are so afraid of> > those crazy people who build airplanes in the garages. I was> > lucky, I'm at an airport that has alot of experimentals, and they> > are easy to work with. As a matter of fact, my "Non-TSO'd" Rocky> > Mountain uEncoder was mo re accurate than most he tests...he was> > very impressed :-) Oh yeah, and I built that in my garage too,> > which also gives my altitude to ATC in an IFR environment! Scary!> >> > Paul Besing> >> > ----- Original Message --- -> > From: David Leonard <wdleonard(at)gmail.com <mailto:wdleonard(at)gmail.com>> > > To: rv-list(at)matronics.com > > Sent: Tuesd ay, November 13, 2007 8:04:54 AM> > Subject: Re: RV-List: Needed: Answer; I s Non-TSO Altimeter - Good> & gt; fo r IFR?> >> > Without question, non-TSO is OK for experimental aircraft. I> > would consider making the shop show you where it says that a TSO> > is required to pass the static-system test. > >> > I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and> > they both pass every time. Both are easy to calibrate down to> > less than 10' error at any altitude. - i.e. they both outperform> > any TSO steam gua ge. But that is beside the point.> >> > If you google you can find a copy o f the instructions for> > performing the static system test.> >> > Dave Leo nard> >> > On Nov 13, 2007 7:18 AM, > @aol.com>> wrote:> >> > Help.> >> > My Glasair III needs its two year IFR c ertification, i.e.,> > pitot/static, altimete r, &am p; transponder check. The altimeter> > (I just found out) is non-TSO'd. Does anyone have the Regs > > and/or clarification that says this is legal for IFR in an> > experimen tal aircraft? My local avionics shop says no, and> > will not do the test a nd certification.> >> > Thank you in advance.> >> > Jeff> > --------------- ---------------------------------------------------------> > <http://o.aolc dn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp0005000 0000003>!> >> > *> >> >> >> >> >> > *> >> >> >> >> > -- > > David Leonard> >> > Turbo Rotary RV-6 N4VY> > http://N4VY.RotaryRoster.net > > http://RotaryRoster.net > > - -----------------------------------------------------------------------> > Get easy, one-click access to your favorites.> >> > *> >> >> > *> >> >> > * > >> >> > *> >> >> > ------------------------------------------------------ ------------------> > Get easy, one-click access to your favorites.> > *> > > >> > *> > --------------------------------------------------------------- ---------> > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/te xt.htm?ncid=aolcmp00050000000003>!> > *> >>=========> > > Peek-a-boo FREE Tricks & Treats for You! Get 'em! _________________________________________________________________ Windows Live Hotmail and Microsoft Office Outlook ' together at last. - Get it now. http://office.microsoft.com/en-us/outlook/HA102225181033.aspx?pid=CL10062 6971033 ________________________________________________________________________________
Subject: Re: Is this quote true, that insurance will void if not replace
Date: Nov 14, 2007
NO - this is not true. -------- David McCoy Branch Manager Light Aircraft Division NationAir Aviation Insurance www.nationair.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=146024#146024 ________________________________________________________________________________
Date: Nov 14, 2007
A Mandatory Service Bulletin does not have to be complied with under an "experimental airworthiness certificate" and Part 91 operations. Insuance companies do not have requirements in their policies that state service bullitens to be complied with for you to have coverage. -------- David McCoy Branch Manager Light Aircraft Division NationAir Aviation Insurance www.nationair.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=146025#146025 ________________________________________________________________________________
Date: Nov 14, 2007
From: "Greg Williams" <mr.gsun+rv-list(at)gmail.com>
So how about the GPS moving map (Blue Mtn EFIS one) being used for a GPS approach? It isn't TSO'd. Would I use the same arguement? If I have the altimeter, pitot/static system & transponder & encoder inspected can I do approaches using features in my EFIS/one? Greg On Nov 14, 2007 12:30 PM, Mike Robertson wrote: > If it can be shown that the D10A encoder meets the testing requirements o f > FAR 43 then it may be used. What 91.217(c) states is that the altimeters > and digitizers must meet the standards of TSO-C10b and TSO-C88respectivel y. So, they do not have to meet the TSO, just meets the > standards of the those TSO's. Basically, if the encoder meets the testin g > standards in FAR 43 they will meet the TSO's. The electronic standards of > today's world meet or exceed the TSO requirements of yesterdays world. > Dynon knew what those TSO standards were before they designed and built > their units. I had the chance to speak with the folks from Dynon at leng th > several years ago when then D10 first came out, as I was concerned about > this very issue. > > Mike Robertson > Das Fed > > ------------------------------ > > From: wgill10(at)comcast.net > To: rv-list(at)matronics.com > Subject: RE: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR ? > Date: Wed, 14 Nov 2007 17:19:29 +0000 > > > Hello Mike, > > I have the Dynon D10A and plan to use its encoding altimeter which is not > TSO'd. Will it be acceptable per the FAR's for use if it meets the testin g > requirements at the instrument shop? 91.217(c) indicates that the encoder > must meet TSO. Thanks in advace for clarification. > > Bill > > > -------------- Original message -------------- > From: Mike Robertson <mrobert569(at)hotmail.com> > Not bad. You are exactly correct right up to the last sentence. Even fo r > 121 and 135 there is no requirement for TSO. If that were true then the > Cessna instrument cluster for their engine instrument cluster would have to > be removed as it is manufacturer specific and not TSO'd. Outside of FAR 91, > which calls for a TSO for the ELT and that the Transponder must be shown to > meet a TSO standard during testing, the FARs that covers ALL instruments > installed in aircraft is FAR Parts 23 through 29, and they do NOT mention > TSO's at all for instruments. And we all know that FARs 23 through 29 do > not apply to Experimental aircraft. The only thing we have that covers w hat > has to be installed in our aircraft is FAR 91.205, and only because the > Operating Limitations bring them into play. > > I know that the old school inspectors with the FAA and with older > established repair stations don't buy this but if they were forced to loo k > throu gh the FAR's and prove to you what states that all flight instrumen ts > must be TSO'd to be used for instrument flight, they could only point to the > requirement for the encoding altimeter and transponder having to meet a T SO > standard during testing, and to the ELT. > > Sorry for the rant but this has been a touchy subject within Flight > Standards that I have fought, and proven. > > Mike Robertson > Das Fed > > P.S. For 121 and 135 aircraft they are held to only those items listed in > the aircraft parts manuals and/or to 337's. > > > ------------------------------ > > > Date: Tue, 13 Nov 2007 22:09:17 -0700 > > From: kellym(at)aviating.com > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for > IFR? > > > > > > The regulation calls for a "sensitive altimeter". Reference is 91.205. > > No mention of TSO at all. > > If you want to minimize cost, buy an overhauled unit from one of the > > reputable instrument shops like Century Instruments, for about $375. > > For certification the requirements are in Part 43, Appendix E. Again, n o > > > mention of TSO. > > In general, TSO is only required for Part 135 and 121. > > > > darnpilot(at)aol.com wrote: > > > Thanks for the replies. My shop is actually pretty good (and the only > > > one in town). I understand, somewhat, that they are caught between > > > the FAA and their own ignorance . The local Orlando FSDO (avionics > > > inspector) says the shop cannot "certify" a non-TSO'd altimeter. They > > > showed me the FARs that they THINK says this, but it is clear that > > > they are wrong. > > > > > > My philosophy is to try to give my local shop the work, but I might b e > > > > forced to go elsewhere. It bugs me because there is no reason that I > > > have to go to all the additional trouble and expense of an out of tow n > > > > avionics shop for this simple requirement. > > > > > > I'm going to contact the EAA and get them on the ass of the local FSD O > > > > and try to educate them accordingly. This is the kind of excrement I > > > was trying to get away from by going to the experimental world. > > > > > > Jeff > > > > > > > > > -----Original Message----- > > > From: Paul Besing <pbesing(at)yahoo.com> > > > To: rv-list@matroni cs.com > > > Sent: Tue, 13 Nov 2007 7:25 pm > > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for > IFR? > > > > > > The only things that have to be certified for IFR are the transponder , > > > > encoder, and altimeter. All can be done in about an hour of work. > > > You don't really certify the "airplane", just that the pitot/static > > > and transponder have been tested and are within the standards of the > > > regulations. This needs to be done every 24 months to be IFR > "certified". > > > > > > I wouldn't even tell them that the instruments aren't TSO'd. Just go > > > to an avionics shop and tell them you need a transponder and pitot > > > static check. If they won't do it because you have a big > > > "experimental" sticker on your plane, then you probably won't want to > > > do business with them anyway. Ask any of the flying IFR birds, > > > lanca irs, g lasairs, RV's, etc around your field and they'll tell yo u > > > > where to go. > > > > > > Paul Besing > > > > > > ----- Original Message ---- > > > From: Greg Williams <mr.gsun+rv-list(at)gmail.com > > > > > > > To: rv-list(at)matronics.com > > > Sent: Tuesday, November 13, 2007 4:40:15 PM > > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for > IFR? > > > > > > So, if I want my -7 blessed for IFR, I take it to an avionics shop > > > friendly to Experimentals and ask them to certify the airplane or eac h > > > > instrument? > > > > > > On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com > > > > wrote: > > > > > > Good luck with that. As soon as they find out it's "Experimental" > > > some places are s ent sl amming their doors, throwing away the key, > > > and changing their phone number because they are so afraid of > > > those crazy people who build airplanes in the garages. I was > > > lucky, I'm at an airport that has alot of experimentals, and they > > > are easy to work with. As a matter of fact, my "Non-TSO'd" Rocky > > > Mountain uEncoder was more accurate than most he tests...he was > > > very impressed :-) Oh yeah, and I built that in my garage too, > > > which also gives my altitude to ATC in an IFR environment! Scary! > > > > > > Paul Besing > > > > > > ----- Original Message ---- > > > From: David Leonard <wdleonard(at)gmail.com <mailto:wdleonard(at)gmail.com> > > > > To: rv-list(at)matronics.com > > > Sent: Tuesday, November 13, 2007 8:04:54 AM > > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good > > & gt; fo r IFR? > > > > > > Without question, non-TSO is OK for experimental aircraft. I > > > would consider making the shop show you where it says that a TSO > > > is required to pass the static-system test. > > > > > > I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and > > > they both pass every time. Both are easy to calibrate down to > > > less than 10' error at any altitude. - i.e. they both outperform > > > any TSO steam guage. But that is beside the point. > > > > > > If you google you can find a copy of the instructions for > > > performing the static system test. > > > > > > Dave Leonard > > > > > > On Nov 13, 2007 7:18 AM, > > > wrote: > > > > > > Help. > > > > > > My Glasair III needs its two year IFR certification, i.e., > > > pitot/static, altimete r, &am p; transponder check. The altimeter > > > (I just found out) is non-TSO'd. Does anyone have the Regs > > > and/or clarification that says this is legal for IFR in an > > > experimental aircraft? My local avionics shop says no, and > > > will not do the test and certification. > > > > > > Thank you in advance. > > > > > > Jeff > > > > ------------------------------------------------------------------------ > > > < > http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid =aolcmp00050000000003 > >! > > > > > > * > > > > > > > > > > > > > > > > > > * > > > > > > > > > > > > > > > -- > > > David Leonard > > > > > > Turbo Rotary RV-6 N4VY > > > http://N4VY.RotaryRoster.net > > > http://RotaryRoster.net *> > > ------------------------------------------------------------------------ > > > Get easy, one-click access to your favorites. > > > > > > * > > > > > > > > > * > > > > > > > > > * > > > > > > > > > * > > > > > > > > > > ------------------------------------------------------------------------ > > > Get easy, one-click access to your favorites. > > > * > > > > > > > > > * > > > > ------------------------------------------------------------------------ > > > < > http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid =aolcmp00050000000003 > >! > > > * > > > > >======== > > > > > > > > > ------------------------------ > Peek-a-boo FREE Tricks & Treats for You! Get 'em!<http://www.reallivemoms .com/?ocid=TXT_TAGHM&loc=us> > > > * > > * > > blank>http://www.matronics.com/contribution > t=_blank>http://www.matronics.com/Navigator?RV-List > p://forums.matronics.com > * > > > ------------------------------ > Windows Live Hotmail and Microsoft Office Outlook ' together at last. G et > it now!<http://office.microsoft.com/en-us/outlook/HA102225181033.aspx?pid =CL100626971033> > > * > =========== com/contribution =========== nics.com/Navigator?RV-List =========== =========== > * > > ________________________________________________________________________________
Subject: RV Nose Gear SB Question
Date: Nov 14, 2007
I have the 'improved' nose gear leg on my RV6A that was provided by Van's several years ago, so I am going to have Harmon cut/rethread mine and purchase a new fork from Vans. My question for those of you that have done this: What is the change and/or difficulty with the brackets that attach the fairings to the axle bolt and the fork? What is needed or difficult to do? I can't get a handle on this area of the change. Thanks for any advise. ________________________________________________________________________________
Date: Nov 14, 2007
All: I had a heart-to-heart with the Orlando FSDO today.=C2- A conference call with the [troublesome] Inspector and his boss.=C2- The Inspector was belli gerent and arrogant, stating unequivocally that I was wrong.=C2- The only quarter he would give was that I should send him the information I had for h is review.=C2- I said I would and did (via email).=C2- His boss was very quiet on the call, and at the end I pressed him for an opi nion.=C2- He said to send the information and he would ensure its review. =C2- Well, this afternoon I got a call from the Inspector.=C2- He was (t o his credit) very soft-spoken and (my impression) contrite.=C2- He said i t "looked like" it was possible to do what I wanted, and said that by tomorr ow he would have a final answer.=C2- Yea! I suspect that my call with him and his boss got the ball rolling, and I fur ther suspect that the EAA (whom I contacted about this) may have made an inq uiry or two. I think I have may have gotten this resolved.=C2- Principle is sometimes a good thing to stand up for.=C2- Now those coming behind me will have an e asier time, and I will not have to hunt down a shop to get my IFR done. I'll let you know what tomorrow brings. Thanks for all the replies, opinions, and help. Jeff -----Original Message----- From: Mike Robertson <mrobert569(at)hotmail.com> Sent: Wed, 14 Nov 2007 3:30 pm Subject: RE: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? If it can be shown that the D10A encoder meets the testing requirements of F AR 43 then it may be used.=C2- What 91.217(c) states is that the altimeter s and digitizers must meet the standards of TSO-C10b and TSO-C88 respectivel y.=C2- So, they do not have to meet the TSO, just meets the standards of t he those TSO's.=C2- Basically, if the=C2-encoder meets the testing stand ards in FAR 43 they will=C2-meet the TSO's.=C2-The electronic standards of today's world meet or exceed=C2-the TSO requirements of yesterdays worl d.=C2- Dynon knew what those TSO standards were before they designed and b uilt their units.=C2- I had the chance to speak with=C2-the folks from D ynon at length several years ago when then D10 first came out, as I was conc erned about this very issue. =C2- Mike Robertson Das Fed =C2- From: wgill10(at)comcast.net Subject: RE: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? Date: Wed, 14 Nov 2007 17:19:29 +0000 Hello Mike, =C2- I have the Dynon D10A and plan to use its encoding altimeter which is not TS O'd. Will it be acceptable per the FAR's for use=C2-if it meets the testin g requirements at the instrument shop? 91.217(c)=C2-indicates that the enc oder must meet TSO. Thanks in advace for clarification. =C2- Bill=C2-=C2- =C2- -------------- Original message -------------- From: Mike Robertson <mrobert569(at)hotmail.com> Not bad.=C2- You are exactly correct right up to the last sentence.=C2- Even for 121 and 135 there is no requirement for TSO.=C2- If that were tru e then the Cessna instrument cluster for their engine instrument cluster wou ld have to be removed as it is manufacturer specific and not TSO'd.=C2- =C2-Outside of FAR 91, which calls for a=C2-TSO for the ELT and that the Transponder must be shown to meet a TSO standard during testing, the FARs t hat covers ALL instruments installed in aircraft is FAR Parts 23 through 29, and they do NOT mention TSO's at all for instruments.=C2- And we all know that FARs 23 through 29 do not apply to Experimental aircraft.=C2- The on ly thing we have that covers what has to be installed in our aircraft is FAR 91.205, and only because the Operating Limitations bring them into play. =C2- I know that the old school inspectors with the FAA and with older establishe d repair stations don't buy this but if they were forced to look throu gh th e FAR's and prove to you what states that all flight instruments must be TSO 'd to be used for instrument flight, they could only point to the requiremen t for the encoding altimeter and transponder having to meet a TSO standard d uring testing, and to the ELT. =C2- Sorry for the rant but this has been a touchy subject within Flight Standard s that I have fought, and proven. =C2- Mike Robertson Das Fed =C2- P.S. For 121 and 135 aircraft they are held to only those items listed in th e aircraft parts manuals and/or to 337's. > Date: Tue, 13 Nov 2007 22:09:17 -0700 > From: kellym(at)aviating.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IFR? > > > The regulation calls for a "sensitive altimeter". Reference is 91.205. > No mention of TSO at all. > If you want to minimize cost, buy an overhauled unit from one of the > reputable instrument shops like Century Instruments, for about $375. > For certification the requirements are in Part 43, Appendix E. Again, no > mention of TSO. > In general, TSO is only required for Part 135 and 121. > > darnpilot(at)aol.com wrote: > > Thanks for the replies. My shop is actually pretty good (and the only > > one in town). I understand, somewhat, that they are caught between > > the FAA and their own ignorance . The local Orlando FSDO (avionics > > inspector) says the shop cannot "certify" a non-TSO'd altimeter. They > > showed me the FARs that they THINK says this, but it is clear that > > they are wrong. > > > > My philosophy is to try to give my local shop the work, but I might be > > forced to go elsewhere. It bugs me because there is no reason that I > > have to go to all the additional trouble and expense of an out of town > > avionics shop for this simple requirement. > > > > I'm going to contact the EAA and get them on the ass of the local FSDO > > and try to educate them accordingly. This is the kind of excrement I > > was trying to get away from by going to the experimental world. > > > > Jeff > > > > > > -----Original Message----- > > From: Paul Besing <pbesing(at)yahoo.com> > > To: rv-list@matroni cs.com > > Sent: Tue, 13 Nov 2007 7:25 pm > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IF R? > > > > The only things that have to be certified for IFR are the transponder, > > encoder, and altimeter. All can be done in about an hour of work. > > You don't really certify the "airplane", just that the pitot/static > > and transponder have been tested and are within the standards of the > > regulations. This needs to be done every 24 months to be IFR "certified" . > > > > I wouldn't even tell them that the instruments aren't TSO'd. Just go > > to an avionics shop and tell them you need a transponder and pitot > > static check. If they won't do it because you have a big > > "experimental" sticker on your plane, then you probably won't want to > > do business with them anyway. Ask any of the flying IFR birds, > > lanca irs, g lasairs, RV's, etc around your field and they'll tell you > > where to go. > > > > Paul Besing > > > > ----- Original Message ---- > > From: Greg Williams <mr.gsun+rv-list(at)gmail.com > > >; > > To: rv-list(at)matronics.com ; > > Sent: Tuesday, November 13, 2007 4:40:15 PM > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good for IF R? > > > > So, if I want my -7 blessed for IFR, I take it to an avionics shop > > friendly to Experimentals and ask them to certify the airplane or each > > instrument? > > > > On Nov 13, 2007 3:13 PM, Paul Besing < pbesing(at)yahoo.com > > >; wrote: > > > > Good luck with that. As soon as they find out it's "Experimental" > > some places are s ent sl amming their doors, throwing away the key, > > and changing their phone number because they are so afraid of > > those crazy people who build airplanes in the garages. I was > > lucky, I'm at an airport that has alot of experimentals, and they > > are easy to work with. As a matter of fact, my "Non-TSO'd" Rocky > > Mountain uEncoder was more accurate than most he tests...he was > > very impressed :-) Oh yeah, and I built that in my garage too, > > which also gives my altitude to ATC in an IFR environment! Scary! > > > > Paul Besing > > > > ----- Original Message ---- > > From: David Leonard <wdleonard(at)gmail.com <mailto:wdleonard(at)gmail.com>>; > > To: rv-list(at)matronics.com ; > > Sent: Tuesday, November 13, 2007 8:04:54 AM > > Subject: Re: RV-List: Needed: Answer; Is Non-TSO Altimeter - Good > & gt; fo r IFR? > > > > Without question, non-TSO is OK for experimental aircraft. I > > would consider making the shop show you where it says that a TSO > > is required to pass the static-system test. > > > > I have 2 non-TSO altimiters (Rockymountain and Bluemountain) and > > they both pass every time. Both are easy to calibrate down to > > less than 10' error at any altitude. - i.e. they both outperform > > any TSO steam guage. But that is beside the point. > > > > If you google you can find a copy of the instructions for > > performing the static system test. > > > > Dave Leonard > > > > On Nov 13, 2007 7:18 AM, > >; wrote: > > > > Help. > > > > My Glasair III needs its two year IFR certification, i.e., > > pitot/static, altimete r, &am p; transponder check. The altimeter > > (I just found out) is non-TSO'd. Does anyone have the Regs > > and/or clarification that says this is legal for IFR in an > > experimental aircraft? My local avionics shop says no, and > > will not do the test and certification. > > > > Thank you in advance. > > > > Jeff > > ------------------------------------------------------------------------ > > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?nci d=aolcmp00050000000003>;! > > > > * > > > > > > > > > > > > * > > > > > > > > > > -- > > David Leonard > > > > Turbo Rotary RV-6 N4VY > > http://N4VY.RotaryRoster.net ; > > http://RotaryRoster.net ;> > ----------------- ------------------------------------------------------- > > Get easy, one-click access to your favorites. > > > > * > > > > > > * > > > > > > * > > > > > > * > > > > > > ------------------------------------------------------------------------ > > Get easy, one-click access to your favorites. > > * > > > > > > * > > ------------------------------------------------------------------------ > > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?nci d=aolcmp00050000000003>;! > > * > > >======== > > > Peek-a-boo FREE Tricks & Treats for You! Get 'em! blank>http://www.matronics.com/contribution =_blank>http://www.matronics.com/Navigator?RV-List ://forums.matronics.com blank>http://www.matronics.com/contribution
October 29, 2007 - November 14, 2007
RV-Archive.digest.vol-tb
