RV-Archive.digest.vol-td
December 02, 2007 - December 10, 2007
      http://forums.matronics.com/viewtopic.php?p=150099#150099
Subject: Vacuum Guage hookup
Date: Dec 02, 2007
I have a small vacuum gauge that has two smaller ports on it labeled V and P. I assume the V is for the vacuum and the P would be the export. I understood there was a port on some of the other gauges that would allow me to just run a hose from it to the vacuum gauge. Does this suction gauge need to be plumbed in series with the other gauges in order to take advantage of the filtered air? It has smaller ports on it so would have to find a hose that would fit between the larger ports on the gauges and the smaller port on the suction gauge. Any thoughts? Thanks Tim ________________________________________________________________________________
Date: Dec 02, 2007
Subject: Re: Vacuum Guage hookup
In a message dated 12/2/2007 4:18:37 P.M. Pacific Standard Time, n616tb(at)btsapps.com writes: I have a small vacuum gauge that has two smaller ports on it labeled V and P. I assume the V is for the vacuum and the P would be the export. I understood there was a port on some of the other gauges that would allow me to just run a hose from it to the vacuum gauge. Does this suction gauge need to be plumbed in series with the other gauges in order to take advantage of the filtered air? ========================================== Actually, that would be the intuitive take on things, but it would be exactly wrong. The P stands for Pressure (in this case the negative pressure) that is seen at the intake of the vacuum pump (but before the regulator). The V stands for Vent (in this case Static) or ambient outside pressure (or aircraft ambient). Look for a Rapco schematic that I think is available on the web or in the ACS catalog and it explains the whole setup in detail. N1GV (RV-6A, Flying 870hrs, O-360-A1A, C/S, Silicon Valley) **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) ________________________________________________________________________________
Date: Dec 02, 2007
V is usually for vent and P is for the pressure or "suction". refer to Aircraft spruce which used to have an excellent schematic for how to do a suction system. In my case I left v alone and hooked the p to one of the suction instruments. the whole shmear is in series with the air coming through the big filter first, then to the two instruments, then to the regulator, then to the pump. On Dec 2, 2007, at 5:14 , Tim Bryan wrote: > > > I have a small vacuum gauge that has two smaller ports on it labeled > V and > P. I assume the V is for the vacuum and the P would be the export. I > understood there was a port on some of the other gauges that would > allow me > to just run a hose from it to the vacuum gauge. Does this suction > gauge > need to be plumbed in series with the other gauges in order to take > advantage of the filtered air? It has smaller ports on it so would > have to > find a hose that would fit between the larger ports on the gauges > and the > smaller port on the suction gauge. > > Any thoughts? > Thanks > Tim > > ________________________________________________________________________________
Date: Dec 02, 2007
Tim, The gyro should have a small port which goes to the gauge. The "V" is the "vent" and the "P" is pressure (positive or negative) so the "P" connects to the gyro. Since there is no airflow through the gauge, there no need to connect the "V" to anything or worry about filtered air. Dave Tim Bryan wrote: > > > I have a small vacuum gauge that has two smaller ports on it labeled V and > P. I assume the V is for the vacuum and the P would be the export. I > understood there was a port on some of the other gauges that would allow me > to just run a hose from it to the vacuum gauge. Does this suction gauge > need to be plumbed in series with the other gauges in order to take > advantage of the filtered air? It has smaller ports on it so would have to > find a hose that would fit between the larger ports on the gauges and the > smaller port on the suction gauge. > > Any thoughts? > Thanks > Tim > > > ________________________________________________________________________________
Date: Dec 02, 2007
Thanks everyone for the responses. I surely would have got it backwards. The question then is if the pressure (P) were to be negative then wouldn't there be air flowing through the gauge? If I don't put a filter on the vent side you say it would be OK? Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Dave B > Sent: Sunday, December 02, 2007 8:26 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Vacuum Guage hookup > > > Tim, > The gyro should have a small port which goes to the gauge. The "V" is > the "vent" and the "P" is pressure (positive or negative) so the "P" > connects to the gyro. Since there is no airflow through the gauge, there > no need to connect the "V" to anything or worry about filtered air. > > Dave > > Tim Bryan wrote: > > > > > > > > I have a small vacuum gauge that has two smaller ports on it labeled V > and > > P. I assume the V is for the vacuum and the P would be the export. I > > understood there was a port on some of the other gauges that would allow > me > > to just run a hose from it to the vacuum gauge. Does this suction gauge > > need to be plumbed in series with the other gauges in order to take > > advantage of the filtered air? It has smaller ports on it so would have > to > > find a hose that would fit between the larger ports on the gauges and > the > > smaller port on the suction gauge. > > > > Any thoughts? > > Thanks > > Tim > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 02, 2007
Subject: Re: Looking for RV tools
RV tools on ebay - http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=STRK%3AMEBTOX%3AIT&viewitem=&item=180185424704&_trksid=p3984.cTODAY.m238.lVI Mike Divan N64GH - RV6,flying :) SLOW 7 Builder :( EAA - 577486 FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS! ----- Original Message ---- From: dnimigon <dnimigon(at)telusplanet.net> Sent: Sunday, December 2, 2007 3:54:55 PM Subject: RV-List: Looking for RV tools Looking to buy tools to build my RV-9. Already have rivet gun. Looking mostly for c-frame, hand squeezer with acc. , dimplers etc. -------- Dave Nimigon Alberta RV-9 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=150099#150099 Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how. http://overview.mail.yahoo.com/ ________________________________________________________________________________
Subject: LSAs
Date: Dec 03, 2007
Ralph, It depends on which category you certificate it in. If it is in the experi mental amateur-built category then it is no problem. But if you were able to get it certificated in the Light-sport category then you would have a pr oblem. In this case I don't think you will have to worry as I don't think it will qualify for the Light-Sport category, just the amateur-built catego ry. Mike Robertson Das Fed From: rgf(at)dcn.davis.ca.usTo: rv-list(at)matronics.comSubject: RV-List: LSAsDat Speaking of LSAs....Chinese or otherwise...Van's RV-12 got me to thinking. That doesn't happen often and when it does, I take advantage of it. I gotta think that the RV-12 could fly faster than the LSA speed limit (120 kts) with maybe just a coarser pitched prop. If so, would it be legit to: - build or buy an LSA--say Van's--switch the prop, and fly it out of the LS A class with your PP-ASEL and current medical - then if you don't want to renew your medical for some reason, simply swit ch the prop back again to be below 120 kts Can the same plane, with a minor alteration, switch between LSA and not? Ralph Finch _________________________________________________________________ You keep typing, we keep giving. Download Messenger and join the i=92m Init iative now. ________________________________________________________________________________
Date: Dec 03, 2007
Subject: Re: LSAs
D'oh, You're probably right Scott. I still stand by the rest of my blasphemies though : ) Tracy On Dec 2, 2007 6:10 PM, Scott wrote: > > I believe he was referring to 48" of pitch, not prop diameter ;) > > Scott > http://corbenflyer.tripod.com/ > Gotta Fly or Gonna Die > Building RV-4 (Super Slow Build Version) > > > Tracy Crook wrote: > > > > > > > BTW, 48" prop? Wow, I'm not surprised that the 52" outperformed it in > > almost every way. Maybe I'm thinking of a different Aircoupe. (one > > with C85 engine?) A 48" prop is way too short for the one I'm > > familiar with. > > > > > > > > > > ________________________________________________________________________________
Subject: Chinese LSA - My Bad
Date: Dec 03, 2007
Cheeeeez! I never thought my original post would generate so many responses. Wish I could take it back so we could focus on RV building. But I guess it's like saying the f-word in front of your mother - you can't take it back. Anyway, I'm finishing up the cockpit wiring and trying to figure out a good way to raise the fuselage (-8A) to put her on the gear. Anyone have words about what worked - and what didn't? I'm contemplating the use of the engine hoist with a cable wrapped around the roll bar, but that seems too rough and perhaps unstable. Booger ________________________________________________________________________________
Date: Dec 03, 2007
I did it this way, but with the engine mount. Mine was a -6 however. It doesn't really weight much unless you have the engine mounted. At that point I would use the hook on the top of the engine. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Valovich, Paul Sent: Monday, December 03, 2007 12:42 PM Subject: RV-List: Chinese LSA - My Bad Cheeeeez! I never thought my original post would generate so many responses. Wish I could take it back so we could focus on RV building. But I guess it's like saying the f-word in front of your mother - you can't take it back. Anyway, I'm finishing up the cockpit wiring and trying to figure out a good way to raise the fuselage (-8A) to put her on the gear. Anyone have words about what worked - and what didn't? I'm contemplating the use of the engine hoist with a cable wrapped around the roll bar, but that seems too rough and perhaps unstable. Booger ________________________________________________________________________________
Date: Dec 03, 2007
Subject: Re: Chinese LSA - My Bad -> lifting for gear
I had success with using an engine hoist and the engine mount (sans engine) and later the engine mount to fuselage upper bolt holes - same engine hoist. My intent was to put the stress in the same place that would see it in flight...... -----Original Message----- >From: "Valovich, Paul" <pvalovich(at)dcscorp.com> >Sent: Dec 3, 2007 1:41 PM >To: rv-list(at)matronics.com >Subject: RV-List: Chinese LSA - My Bad > >Cheeeeez! I never thought my original post would generate so many >responses. Wish I could take it back so we could focus on RV building. >But I guess it's like saying the f-word in front of your mother - you >can't take it back. > > > >Anyway, I'm finishing up the cockpit wiring and trying to figure out a >good way to raise the fuselage (-8A) to put her on the gear. Anyone have >words about what worked - and what didn't? I'm contemplating the use of >the engine hoist with a cable wrapped around the roll bar, but that >seems too rough and perhaps unstable. > >Booger > ________________________________________________________________________________
Date: Dec 03, 2007
It is not recommended to use the engine hook to lift any more than the engine itself. All the weight is going through one small section of the engine case. Consider the consequences of cracking the case - it may hold or may not but is it worth the risk? Your choice, your money. Regards, Greg Young _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan Sent: Monday, December 03, 2007 12:55 PM Subject: RE: RV-List: Chinese LSA - My Bad I did it this way, but with the engine mount. Mine was a -6 however. It doesn't really weight much unless you have the engine mounted. At that point I would use the hook on the top of the engine. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Valovich, Paul Sent: Monday, December 03, 2007 12:42 PM Subject: RV-List: Chinese LSA - My Bad Cheeeeez! I never thought my original post would generate so many responses. Wish I could take it back so we could focus on RV building. But I guess it's like saying the f-word in front of your mother - you can't take it back. Anyway, I'm finishing up the cockpit wiring and trying to figure out a good way to raise the fuselage (-8A) to put her on the gear. Anyone have words about what worked - and what didn't? I'm contemplating the use of the engine hoist with a cable wrapped around the roll bar, but that seems too rough and perhaps unstable. Booger http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV-List http://forums.matronics.com ________________________________________________________________________________
Date: Dec 03, 2007
Subject: Re: LSAs
Not to worry! I have days like that too! ;) Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) Tracy Crook wrote: > D'oh, You're probably right Scott. I still stand by the rest of > my blasphemies though : ) > > Tracy > > On Dec 2, 2007 6:10 PM, Scott > wrote: > > > > > I believe he was referring to 48" of pitch, not prop diameter ;) > > Scott > http://corbenflyer.tripod.com/ > Gotta Fly or Gonna Die > Building RV-4 (Super Slow Build Version) > > > Tracy Crook wrote: > > > > > > > BTW, 48" prop? Wow, I'm not surprised that the 52" outperformed > it in > > almost every way. Maybe I'm thinking of a different Aircoupe. > (one > > with C85 engine?) A 48" prop is way too short for the one I'm > > familiar with. > > > > > > > > > > ________________________________________________________________________________
Date: Dec 04, 2007
You could build a 2X4 rack and lift it using wide ratcheting cargo straps slung under the fuselage. Or you could use the engine hoist and wide cargo straps and lift one side at a time hooking it on the frame one step at a time. Walking it up to the level where you could get the gear on. Just a thought. Have you got an old swing set? By the way wash your mouth out with soap. Bob Perkinson RV-9 -------------- Original message from "Valovich, Paul" : -------------- Cheeeeez! I never thought my original post would generate so many responses. Wish I could take it back so we could focus on RV building. But I guess its like saying the f-word in front of your mother you cant take it back. Anyway, Im finishing up the cockpit wiring and trying to figure out a good way to raise the fuselage (-8A) to put her on the gear. Anyone have words about what worked and what didnt? Im contemplating the use of the engine hoist with a cable wrapped around the roll bar, but that seems too rough and perhaps unstable. Booger
Bob Perkinson
RV-9
-------------- Original message from "Valovich, Paul" <pvalovich(at)dcscorp.com>: --------------
Booger
Date: Dec 04, 2007
Subject: Re: Installing Gear Legs
> > >Anyway, Im finishing up the cockpit wiring and >trying to figure out a good way to raise the >fuselage (-8A) to put her on the gear. Anyone >have words about what worked and what didnt? >Im contemplating the use of the engine hoist >with a cable wrapped around the roll bar, but >that seems too rough and perhaps unstable. I not sure what your situation is and I built an RV6 so my comments may not work. The fuselage is very easy for one person to lift the front or back end. I assume you do not have the wings on. If not, build two sawhorses taller than the gear leg and put the fuselage on the sawhorses. Make sure you pad the saw horses and place them under a bulkheads. I have a different aircraft fuselage in my hanger right now in that very same condition. Bob RV6 "Wicked Witch of the West" ________________________________________________________________________________
Subject: Re: Painting colors
Date: Dec 04, 2007
Go to an RB fly-in like the LOE event in October. Ron Lee ----- Original Message ----- From: bert murillo To: rv-list(at)matronics.com Sent: Tuesday, November 27, 2007 4:38 PM Subject: RV-List: Painting colors Hello: Well. finally, I am ready to start thinking about painting my rv6a... Can some one tell me, where can I find, photos of planes or designs, I can look at .. No I idea where to start....// Thanks for any help on the subject... Bert rv6a do not rachive ------------------------------------------------------------------------- ----- Get easy, one-click access to your favorites. ________________________________________________________________________________
Date: Dec 04, 2007
Sorry you didn't enjoy the ensuing discussion as much as many of us did. But to get back to your current point, Give that -8 fuse a little more credit. Lifting it by the roll bar should cause no problem. It didn't when I did mine that way. Tracy On Dec 3, 2007 1:41 PM, Valovich, Paul wrote: > Cheeeeez! I never thought my original post would generate so many > responses. Wish I could take it back so we could focus on RV building. Bu t I > guess it's like saying the f-word in front of your mother ' you can't t ake > it back. > > > Anyway, I'm finishing up the cockpit wiring and trying to figure out a > good way to raise the fuselage (-8A) to put her on the gear. Anyone have > words about what worked ' and what didn't? I'm contemplating the use of the > engine hoist with a cable wrapped around the roll bar, but that seems too > rough and perhaps unstable. > > Booger > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Dec 04, 2007
I didn't have the engine mounted so I bolted angle iron to the upper and lower engine mounts using 2x4 wood stand-offs to clear the firewall flange. I then bolted a piece of angle across the two verticals (forming an H) and mounted an eye bolt in the center. Hooked up an engine hoist and was not only able to lift the fuselage but rotate it. The tail was not mounted and I let the aft end of the fuselage it rotate on a padded sawhouse. I then lowered it onto sawhorses to mount the gear. John Ciolino RV-8 ----- Original Message ----- From: "Bob" <panamared5(at)brier.net> Sent: Tuesday, December 04, 2007 10:00 AM Subject: Re: RV-List: Installing Gear Legs > > >> >> >>Anyway, I'm finishing up the cockpit wiring and trying to figure out a >>good way to raise the fuselage (-8A) to put her on the gear. Anyone have >>words about what worked - and what didn't? I'm contemplating the use of >>the engine hoist with a cable wrapped around the roll bar, but that seems >>too rough and perhaps unstable. > > I not sure what your situation is and I built an RV6 so my comments may > not work. > > The fuselage is very easy for one person to lift the front or back end. I > assume you do not have the wings on. If not, build two sawhorses taller > than the gear leg and put the fuselage on the sawhorses. Make sure you > pad the saw horses and place them under a bulkheads. > > I have a different aircraft fuselage in my hanger right now in that very > same condition. > > Bob > RV6 "Wicked Witch of the West" > > > ________________________________________________________________________________
Subject: Dang B1rds
Date: Dec 05, 2007
Maybe this will work: http://www.vansairforce.com/community/showthread.php?t=24147 -----Original Message----- Sent: Wednesday, December 05, 2007 8:47 AM Subject: RV-List: Dang B1rds Well, I got me another n-b1rd in-flight midair collision yesterday. I've no idea if it was a Chinese b1rd, or if it was a tail dragger, had a sliding canopy, was painted with self-etching primer or ran auto gas in its nuclear reactor because I never even knew it happened until I starting cleaning the airplane and found goo on the prop and spatters on the cowl. Guess I need to dig the air cleaner out to look for extra wings and such. Sorry 'bout that Mrs. Mama B1rd.... ________________________________________________________________________________
Date: Dec 05, 2007
Subject: hidden antennas
Anyone -- Getting my quickbuild wings next month and am planning wire runs through wing before I close it up and want to hide the following antennas -- VHF COMM, VOR/LOC, GS (glide slope), and MB (marker beacon). I'll have a normal VHF COMM wire whip and XPNDR antenna on the belly and a GPS antenna on the glareshield or back deck for VFR operations. ** Anyone have suggestions for which VOR/LOC antennas (dipole or grounded) work best in wingtips? Bob Archer's stuff? Van's copper foil? ** Anyone know if Van's VHF COMM copper foil on the windscreen set-up works? ** Anyone ever mount a GS or VHF COMM diploe antenna in a main gear leg fairing? ** Does 40" of foil in a wintip work for a marker beacon antenna? Sorry for asking this stuff for the millionith time. Thanks. ________________________________________________________________________________
Date: Dec 05, 2007
You may want to consider the need for marker beacons.... the FAA is turnin g many off, and your GPS provides you with positioning. Marty Heller RV-7; installing interior systems (day job supports FAA Navigation systems) Date: Wed, 5 Dec 2007 12:20:37 -0800From: airlincoln(at)sbcglobal.netSubject: RV-List: hidden antennasTo: RV-List(at)matronics.com Anyone -- Getting my quickbuild wings next month and am planning wire runs through wi ng before I close it up and want to hide the following antennas -- VHF COMM , VOR/LOC, GS (glide slope), and MB (marker beacon). I'll have a normal VH F COMM wire whip and XPNDR antenna on the belly and a GPS antenna on the gl areshield or back deck for VFR operations. ** Anyone have suggestions for which VOR/LOC antennas (dipole or grounded) work best in wingtips? Bob Archer's stuff? Van's copper foil? ** Anyone know if Van's VHF COMM copper foil on the windscreen set-up works ? ** Anyone ever mount a GS or VHF COMM diploe antenna in a main gear leg fai ring? ** Does 40" of foil in a wintip work for a marker beacon antenna? Sorry for asking this stuff for the millionith time. Thanks. _________________________________________________________________ Connect and share in new ways with Windows Live. http://www.windowslive.com/connect.html?ocid=TXT_TAGLM_Wave2_newways_1120 07 ________________________________________________________________________________
Subject: Re: hidden antennas
Date: Dec 05, 2007
Do a list search for antenna. I have the aluminum flate plate strip VOR/GS antenna in a wingtip and it works fine. Can't remember the name. Ron ----- Original Message ----- From: Lincoln Keill To: RV-List(at)matronics.com Sent: Wednesday, December 05, 2007 1:20 PM Subject: RV-List: hidden antennas Anyone -- Getting my quickbuild wings next month and am planning wire runs through wing before I close it up and want to hide the following antennas -- VHF COMM, VOR/LOC, GS (glide slope), and MB (marker beacon). I'll have a normal VHF COMM wire whip and XPNDR antenna on the belly and a GPS antenna on the glareshield or back deck for VFR operations. ** Anyone have suggestions for which VOR/LOC antennas (dipole or grounded) work best in wingtips? Bob Archer's stuff? Van's copper foil? ** Anyone know if Van's VHF COMM copper foil on the windscreen set-up works? ** Anyone ever mount a GS or VHF COMM diploe antenna in a main gear leg fairing? ** Does 40" of foil in a wintip work for a marker beacon antenna? Sorry for asking this stuff for the millionith time. Thanks. ________________________________________________________________________________
Date: Dec 05, 2007
THAT IS THE BOB ARCHER ANTENNA IN YOUR WINGTIP RON. WE HAVE USED IT IN OUR 7A AND GOT GOOD RESULTS. DOUG PRESTON -----Original Message----- From: Ron Lee <ronlee(at)pcisys.net> Sent: Wed, 5 Dec 2007 3:42 pm Subject: Re: RV-List: hidden antennas Do a list search for antenna.? I have the aluminum flate plate strip VOR/GS antenna in a wingtip and it works fine.? Can't remember the name. ? Ron ----- Original Message ----- From: Lincoln Keill Sent: Wednesday, December 05, 2007 1:20 PM Subject: RV-List: hidden antennas Anyone -- ? Getting my quickbuild wings next month and am planning wire runs through wing before I close it up and want to hide the following antennas -- VHF COMM, VOR/LOC, GS (glide slope), and MB (marker beacon).? I'll have a normal VHF COMM wire whip and XPNDR antenna on the belly and a GPS antenna on the glareshield or back deck for VFR operations. ? ** Anyone have suggestions for which VOR/LOC antennas (dipole or grounded) work best in wingtips?? Bob Archer's stuff?? Van's copper foil? ? ** Anyone know if Van's VHF COMM copper foil on the windscreen set-up works? ? ** Anyone ever mount a GS or VHF COMM diploe antenna in a main gear leg fairing? ? ** Does 40" of foil in a wintip work for a marker beacon antenna? ? Sorry for asking this stuff for the millionith time.? Thanks. ? ? ? href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________ ________________________________________________________________________________
Date: Dec 06, 2007
Subject: Matronics List Fund Raiser - 2007 List of Contributors
Dear Listers, I would like to thank everyone that made a Contribution in support of the Lists this year! It was really nice to hear all great comments people had regarding the Lists! As I have said many times before, running these Lists is a labor of love. Your generosity during the List Fund Raiser underscores the great sentiments people have made regarding the Lists. If you haven't yet made a Contribution in support of this year's Fund Raiser please feel free to do so. The great List Fund Raiser gifts will be available on the Contribution site for just a little while longer, so hurry and make your Contribution and get your great gift! Once again, the URL for the Contribution web site is: http://www.matronics.com/contribution I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Jon Croke of Homebuilt HELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of discounted merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Jon and Bob!! Your support is very much appreciated! And finally, below you will find a web link to the 2007 List of Contributors current as of 12/6/07! Have a look at this list of names as these are the people that make all of these List services possible! I can't thank each of you enough for your support and great feedback during this year's Fund Raiser! THANK YOU! http://www.matronics.com/loc/2007.html I will be shipping out all of the gifts in the next few weeks and hope to have everything out by the end of the month. In most cases, gifts will be shipped via US Postal Service. Once again, thank you for making this year's List Fund Raiser successful! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 06, 2007
Subject: hello
How about "Becker". It fits in a 2-1/4" panel hole. Price is reasonable and quality is very good Jim ________________________________________________________________________________
Date: Dec 06, 2007
Subject: Bob nichols
Hi:I have sent many emails trying to contact Aero electric Bob.. but message does not show... can some help as to correct e mail address for him./ I used the one on his web page, but nothing... can some help thanks \\ Bert rv6a Do not archive ________________________________________________________________________________
Date: Dec 06, 2007
Subject: Re: Bob nichols
That's about the only way. Bob doesn't like to publish is actual email. He'll reply to you after leaving a web email from his page. DWS On Dec 6, 2007 6:57 PM, Bert Murillo wrote: > > Hi:I have sent many emails trying to contact Aero electric Bob.. > > but message does not show... can some help as to correct e mail > address for him./ > > I used the one on his web page, but nothing... can some help > > thanks > \\ > Bert > rv6a > > Do not archive > > -- David W. Schaefer RV-6A N142DS "Geek One" TMX-IO360 Dual-LightSpeed, Hartzell Blended Airfoil, GRT EFIS www.n142ds.com ________________________________________________________________________________
Subject: Van's 60A alternator
Date: Dec 06, 2007
Guy's: My alternator quit working yesterday after 7 months and 130 hours in service. I called Van's and asked if there was a warranty on this unit. The answer was 60 days from purchase. It sat in the box nearly that long before installation. I had it diagnosed by a alternator rebuild shop and they said the rotor had failed and was not worth rebuilding, a "throwaway unit". It is a light duty Suzuki Sprint 60A ND alternator, model 5022, also used extensively in other Japanese autos. The newer test machines are computer controlled and need model parameters input before the unit can be tested. I was able to buy an identical replacement and exchange the pulley for $145 with a year's warranty. I am somewhat disappointed that Van's will not guarantee the unit as most reputable auto parts stores currently do. Dan ________________________________________________________________________________
Date: Dec 06, 2007
Subject: Re: hello
In a message dated 12/06/2007 8:43:02 AM Central Standard Time, bertrv6(at)gmail.com writes: Any commests on the unit, for those who have one? >>> Have been using a Micorair 760 for 3 years on my RV with very good results. Using el-cheapo bent whip on belly for antenna. Only squawk is occasional difficulty hearing very few other planes with ancient radios- never a problem with ATC. Otherwise, installation was easy and sure can't bitch about the price... Mark Phillips _http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5256_ (http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5256) **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) ________________________________________________________________________________
Subject: Re: hello
Date: Dec 06, 2007
Hi Mark, Ive got one in my Piper Cub, Im not to happy with it. It has a hot mike and I understand they have a mod for that. Plus, Im always having to set the sidetone on it. I can hear transmission ok but my transmit is always garbled. Any pointers??? The Other Mark Phillips Williamsville Illinois ----- Original Message ----- From: Fiveonepw(at)aol.com To: rv-list(at)matronics.com Sent: Thursday, December 06, 2007 8:49 PM Subject: Re: RV-List: hello In a message dated 12/06/2007 8:43:02 AM Central Standard Time, bertrv6(at)gmail.com writes: Any commests on the unit, for those who have one? >>> Have been using a Micorair 760 for 3 years on my RV with very good results. Using el-cheapo bent whip on belly for antenna. Only squawk is occasional difficulty hearing very few other planes with ancient radios- never a problem with ATC. Otherwise, installation was easy and sure can't bitch about the price... Mark Phillips http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=525 6 ------------------------------------------------------------------------- ----- money wasters of 2007. ________________________________________________________________________________
Date: Dec 06, 2007
Subject: Re: hello
In a message dated 12/06/2007 9:40:09 PM Central Standard Time, mphill(at)gcctv.com writes: It has a hot mike and I understand they have a mod for that. >>> Not sure about a mod, but I originally tried mine with the hot mike setup, gave up and installed a Sigtronics SPA 600 intercom I grabbed off of ebay- shoulda mentioned that in previous post. No problems after the intercom addition... (the other) Mark Phillips - Columbia, TN, that is, y'all... **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) ________________________________________________________________________________
Subject: Air Race History DVD
Date: Dec 07, 2007
Not specifically RV related, but there's a great DVD "The Story of the 1929 - 1949 National Air Races" for all you Air Races history buffs. Check it out at www.NationalAirRaces.net Disclaimer - I have no financial interest in this product, it's just a great DVD produced by a couple of good friends and pilots. Dave RV-7A ________________________________________________________________________________
Subject: Expanding my flying comfort zone
Date: Dec 07, 2007
MessageExpanding My Flying Comfort Zone Prior to getting my RV-6A I had perhaps 250 hours over 20 plus years. My cross country experience was limited. I did not like to talk to ATC. I had never flown in the mountains in all the years I had lived in Colorado and less than ideal/good weather flights were avoided. I considered myself a wuss when it came to bad weather and was very proud of it. The following parts will detail how this grasshopper went from a relative newbie pilot to one that is far less newbieish. After getting the RV I gradually expanded my cross country experience. Going to La Junta was a cross country technically but timewise trivial in the RV. I took trips that could be done there and back on one tank of gas then those where I needed fuel at the destination. Then I took trips where more than one tank was needed. In the process of gaining this experience I got the Flight Guide books from Airguide Publications and the WAC version of the Air Chart Systems aviation maps. These provided a lot of the info that I needed to conduct cross countries. At first I avoided MOAs but now fly through them. Some are little used and not a concern but others like Vance I use flight following to ensure separation. While I don't normally file a flight plan I do use flight following with ease now. Talking to ATC or going into controlled fields is not a concern. I have made day trips to see Devil's Tower, Mt Rushmore, Meteor Crater/Monument Valley/Shiprock NM, etc. Longer trips have been made to Monument Valley and Death Valley, Kitty Hawk, Key West and the Bahamas. To overcome the mountain barrier to the west I took the mountain flying course from the Colorado Pilots Association. The classroom work plus the mountain flying with an instructor gave me the basics to safely fly in the mountains. It was one of the best courses that I took since it has opened up my flying to a region that is beautiful beyond what many pilots will ever experience. http://home.pcisys.net/~ronlee/RV6A/CreedeSep2007/DubPikesPeakSmall.jpg http://home.pcisys.net/~ronlee/RV6A/CreedeSep2007/CreedeValleyApproach2Sm all.jpg http://home.pcisys.net/~ronlee/Leadville16Oct05.jpg The weather issue remained the biggest limiter to cross countries as recent as three months ago. While I did take instrument training (never got the rating), seeing fronts that extend from the Gulf to the Great Lakes with radar returns of rain all over was an automatic NO GO for me. Then I planned a trip to Memphis for an air race, Kitty Hawk, Key West, Bahamas and Crystal River to swim with manatees. I took off knowing that the weather was not my normal "ideal." Some rain was forecast as were lower than 12,000' ceilings. The initial region of lower clouds was in Kansas or Oklahoma and I did consider turning back. But I kept going since forward visibility was good, I was not scud running and I kept checking six to ensure the 180 degree turn option was good. My fuel stop in Siloam Springs AR gave me the first real opportunity to make a bad decision over continuing. The direct path to Memphis placed me over terrain that may have come too close to clouds for my comfort. So I diverted to the south towards Little Rock then followed an expressway towards Memphis. This option only took 10-15 minutes to clear the terrain and I got to General DeWitt airport easily. Two days later I had to encounter more lower than desired clouds to get to Kitty Hawk from Atlanta. What made it worse was that I had to get low (2500 feet (?)) over water which I was not fond of. That made me rethink whether I would make the trip to the Bahamas. A tropical system that past north over the Bahamas cancelled the Bahamas and Key West portions anyway and a charging system issue had me heading home. On the way home I had the chance to overfly a cloud layer or try to skirt it. Since it was of limited width (100-150 miles), well above the ground, thin (300-500 feet) and temps well above freezing, I overflew it. All conditions were acceptable and had I needed to descend through it in an emergency I had my Trio autopilot to help maintain a wings level attitude. It was a non-issue. My overnight stop was Springfield MO. It was late in the afternoon and I was headed towards the west. Ahead I saw what I thought was a cloud layer so I descended. Turns out it was just haze but I felt better being a bit lower so that I could use the ground below me for attitude reference. While I learned to fly in Georgia, haze had since become a complicating factor for flight decisions. When you can see mountains 100-150 miles away, going back east is a dramatic change. Nonetheless, I arrived home with my comfort zone enlarged. A month later the Bahamas, Key West, manatee goals remained unmet and I took off again. No issues until I got to Florida. I had been watching the haze and noted that it had a uniform appearance that may differentiate it from all clouds types. I got a briefing from Flight Watch but without current satellite info, I elected to descend below rather than get stuck above the clouds. I flew about 2500' MSL from there to my unplanned fuel stop in Cross City then on to Ft Pierce. Visibility was around 10 miles so I was never in MVFR conditions but certainly marginal from what I consider normal in Colorado. The next day saw yucky conditions to the east so I elected to try Key West instead of the Bahamas. I knew that there were rain showers in and around Key West. Launch to the south and instead of flying direct I flew a bit east to fly over water in sight of the Keys. The following picture shows some of the upper Keys off to the left: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/KeyWest1Small.jpg When I contacted Key West Approach they mentioned significant rain in and around Key West. I elected to do a 180 then decided to land at Marathon since it was below me. I checked the radar and talked to a pilot who had just come from there. Based upon recent info, I proceeded to KEYW and did have to get low and pass through some light rain as you can see in this picture that shows the airport ahead and to the right: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/KeyWest2Small.jpg This is on final to KEYW: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/KeyWest3Small.jpg After going to the southernmost point of the US, Hemingway's house and a neat butterfly "zoo" I headed back to Ft Pierce. The next day the morning weather was better so I finally put my apprehensions on hold and started the trip to the Bahamas. I initially headed south towards West Palm Beach then in that area turned east towards Grand Bahamas. This is the Florida coastline looking north as I commit to going out over the ocean: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas1Small.jpg The next picture shows the GNS 430 screen shot well out into the ocean with MYGF (Freeport) as the destination: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas2Small.jpg This shows only ocean (plus clouds) below (no land): http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas3Small.jpg Here I am approaching Grand Bahamas: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas4Small.jpg At this point I made the turn from Freeport to North Eleuthera Island (MYEH) http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas5Small.jpg Another shot of just water for landing although there are strips of land in the distance: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas6Small.jpg At last I am on final to MYEH: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas7Small.jpg Here is the plane at the White Crown FBO. Note the official looking large N numbers: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas15Small.jpg My objective on this island was to see Pink Sand beach. Unfortunately it was not as pink as I had hoped although it is still a nice beach: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas10Small.jpg http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas9Small.jpg The trip back was not a problem. I did not violate the ADIZ and was able to open my flight plan as I headed towards Grand Bahamas. This picture shows the Florida coast near West Palm beach: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas11Small.jpg Here I am flying north along the coast to Ft Pierce. I am not sure about whether I had to land at West Palm Beach if I crossed land there so I stayed off-shore until I got closer to Ft Pierce. http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas12Small.jpg The weather was not suitable for getting to Crystal River after I cleared customs so I stayed at Ft Pierce another night. The next morning was rainy. It was just in that area so once the weather cleared to the south I took off that way with the initial thought of skirting the rain. Once airborne I decided that it looked promising "on top" so I climbed up to 10,500' and was able to get over the localized clouds. This picture shows a plane going into Orlando and why I use flight following: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas13Small.jpg The next morning I swam with manatees which was a great experience. Back to Crystal River airport and looking at the adds.aviationweather.gov cloud cover with VFR/MVFR/IFR condition circles I knew that trying to head northwest was not in my newly expanded comfort zone. The weather towards Atlanta was better so I went that way. Spent the night at my brothers then made it from Atlanta to 00V the next day in about eight hours (a record for one day). Total flight time was 29.2 hours. In addition to further expanding my piloting comfort zone, I got to do some neat things....all thanks to a great airplane. With that I will leave you with a picture that I took at the Homosassa Springs State Park south of Crystal River: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas14Small.jpg ________________________________________________________________________________
Date: Dec 07, 2007
Ron, This was a great story for me and has many points that were similar for me and my flying. I hope to make Bahamas some day as well and maybe we can organize a trip with others as well. Thanks for sharing, I enjoyed the photos also. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee Sent: Friday, December 07, 2007 12:24 PM Subject: RV-List: Expanding my flying comfort zone Expanding My Flying Comfort Zone Prior to getting my RV-6A I had perhaps 250 hours over 20 plus years. My cross country experience was limited. I did not like to talk to ATC. I had never flown in the mountains in all the years I had lived in Colorado and less than ideal/good weather flights were avoided. I considered myself a wuss when it came to bad weather and was very proud of it. The following parts will detail how this grasshopper went from a relative newbie pilot to one that is far less newbieish. After getting the RV I gradually expanded my cross country experience. Going to La Junta was a cross country technically but timewise trivial in the RV. I took trips that could be done there and back on one tank of gas then those where I needed fuel at the destination. Then I took trips where more than one tank was needed. In the process of gaining this experience I got the Flight Guide books from Airguide Publications and the WAC version of the Air Chart Systems aviation maps. These provided a lot of the info that I needed to conduct cross countries. At first I avoided MOAs but now fly through them. Some are little used and not a concern but others like Vance I use flight following to ensure separation. While I don't normally file a flight plan I do use flight following with ease now. Talking to ATC or going into controlled fields is not a concern. I have made day trips to see Devil's Tower, Mt Rushmore, Meteor Crater/Monument Valley/Shiprock NM, etc. Longer trips have been made to Monument Valley and Death Valley, Kitty Hawk, Key West and the Bahamas. To overcome the mountain barrier to the west I took the mountain flying course from the Colorado Pilots Association. The classroom work plus the mountain flying with an instructor gave me the basics to safely fly in the mountains. It was one of the best courses that I took since it has opened up my flying to a region that is beautiful beyond what many pilots will ever experience. http://home.pcisys.net/~ronlee/RV6A/CreedeSep2007/DubPikesPeakSmall.jpg http://home.pcisys.net/~ronlee/RV6A/CreedeSep2007/CreedeValleyApproach2Small .jpg http://home.pcisys.net/~ronlee/Leadville16Oct05.jpg The weather issue remained the biggest limiter to cross countries as recent as three months ago. While I did take instrument training (never got the rating), seeing fronts that extend from the Gulf to the Great Lakes with radar returns of rain all over was an automatic NO GO for me. Then I planned a trip to Memphis for an air race, Kitty Hawk, Key West, Bahamas and Crystal River to swim with manatees. I took off knowing that the weather was not my normal "ideal." Some rain was forecast as were lower than 12,000' ceilings. The initial region of lower clouds was in Kansas or Oklahoma and I did consider turning back. But I kept going since forward visibility was good, I was not scud running and I kept checking six to ensure the 180 degree turn option was good. My fuel stop in Siloam Springs AR gave me the first real opportunity to make a bad decision over continuing. The direct path to Memphis placed me over terrain that may have come too close to clouds for my comfort. So I diverted to the south towards Little Rock then followed an expressway towards Memphis. This option only took 10-15 minutes to clear the terrain and I got to General DeWitt airport easily. Two days later I had to encounter more lower than desired clouds to get to Kitty Hawk from Atlanta. What made it worse was that I had to get low (2500 feet (?)) over water which I was not fond of. That made me rethink whether I would make the trip to the Bahamas. A tropical system that past north over the Bahamas cancelled the Bahamas and Key West portions anyway and a charging system issue had me heading home. On the way home I had the chance to overfly a cloud layer or try to skirt it. Since it was of limited width (100-150 miles), well above the ground, thin (300-500 feet) and temps well above freezing, I overflew it. All conditions were acceptable and had I needed to descend through it in an emergency I had my Trio autopilot to help maintain a wings level attitude. It was a non-issue. My overnight stop was Springfield MO. It was late in the afternoon and I was headed towards the west. Ahead I saw what I thought was a cloud layer so I descended. Turns out it was just haze but I felt better being a bit lower so that I could use the ground below me for attitude reference. While I learned to fly in Georgia, haze had since become a complicating factor for flight decisions. When you can see mountains 100-150 miles away, going back east is a dramatic change. Nonetheless, I arrived home with my comfort zone enlarged. A month later the Bahamas, Key West, manatee goals remained unmet and I took off again. No issues until I got to Florida. I had been watching the haze and noted that it had a uniform appearance that may differentiate it from all clouds types. I got a briefing from Flight Watch but without current satellite info, I elected to descend below rather than get stuck above the clouds. I flew about 2500' MSL from there to my unplanned fuel stop in Cross City then on to Ft Pierce. Visibility was around 10 miles so I was never in MVFR conditions but certainly marginal from what I consider normal in Colorado. The next day saw yucky conditions to the east so I elected to try Key West instead of the Bahamas. I knew that there were rain showers in and around Key West. Launch to the south and instead of flying direct I flew a bit east to fly over water in sight of the Keys. The following picture shows some of the upper Keys off to the left: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/KeyWest1Small.jpg When I contacted Key West Approach they mentioned significant rain in and around Key West. I elected to do a 180 then decided to land at Marathon since it was below me. I checked the radar and talked to a pilot who had just come from there. Based upon recent info, I proceeded to KEYW and did have to get low and pass through some light rain as you can see in this picture that shows the airport ahead and to the right: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/KeyWest2Small.jpg This is on final to KEYW: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/KeyWest3Small.jpg After going to the southernmost point of the US, Hemingway's house and a neat butterfly "zoo" I headed back to Ft Pierce. The next day the morning weather was better so I finally put my apprehensions on hold and started the trip to the Bahamas. I initially headed south towards West Palm Beach then in that area turned east towards Grand Bahamas. This is the Florida coastline looking north as I commit to going out over the ocean: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas1Small.jpg The next picture shows the GNS 430 screen shot well out into the ocean with MYGF (Freeport) as the destination: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas2Small.jpg This shows only ocean (plus clouds) below (no land): http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas3Small.jpg Here I am approaching Grand Bahamas: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas4Small.jpg At this point I made the turn from Freeport to North Eleuthera Island (MYEH) http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas5Small.jpg Another shot of just water for landing although there are strips of land in the distance: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas6Small.jpg At last I am on final to MYEH: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas7Small.jpg Here is the plane at the White Crown FBO. Note the official looking large N numbers: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas15Small.jpg My objective on this island was to see Pink Sand beach. Unfortunately it was not as pink as I had hoped although it is still a nice beach: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas10Small.jpg http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas9Small.jpg The trip back was not a problem. I did not violate the ADIZ and was able to open my flight plan as I headed towards Grand Bahamas. This picture shows the Florida coast near West Palm beach: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas11Small.jpg Here I am flying north along the coast to Ft Pierce. I am not sure about whether I had to land at West Palm Beach if I crossed land there so I stayed off-shore until I got closer to Ft Pierce. http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas12Small.jpg The weather was not suitable for getting to Crystal River after I cleared customs so I stayed at Ft Pierce another night. The next morning was rainy. It was just in that area so once the weather cleared to the south I took off that way with the initial thought of skirting the rain. Once airborne I decided that it looked promising "on top" so I climbed up to 10,500' and was able to get over the localized clouds. This picture shows a plane going into Orlando and why I use flight following: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas13Small.jpg The next morning I swam with manatees which was a great experience. Back to Crystal River airport and looking at the adds.aviationweather.gov cloud cover with VFR/MVFR/IFR condition circles I knew that trying to head northwest was not in my newly expanded comfort zone. The weather towards Atlanta was better so I went that way. Spent the night at my brothers then made it from Atlanta to 00V the next day in about eight hours (a record for one day). Total flight time was 29.2 hours. In addition to further expanding my piloting comfort zone, I got to do some neat things....all thanks to a great airplane. With that I will leave you with a picture that I took at the Homosassa Springs State Park south of Crystal River: http://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas14Small.jpg ________________________________________________________________________________
Date: Dec 07, 2007
Subject: Re: Expanding my flying comfort zone
HOLEY-E-COW! I get nervous flying to Catalina and it is only 25 miles away! Well this has me wanting to "expand my flying comfort zone".=0A =0AMike Di van=0AN64GH - RV6,flying :)=0ASLOW 7 Builder :(=0AEAA - 577486=0AFREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS!=0A=0A----- Original Messa ge ----=0AFrom: Ron Lee <ronlee(at)pcisys.net>=0ATo: rv-list(at)matronics.com=0AS ent: Friday, December 7, 2007 10:24:28 AM=0ASubject: RV-List: Expanding my flying comfort zone=0A=0AMessage=0A=0A=0A =0A =0A=0A=0A=0AExpanding My Flyi ng Comfort Zone=0A=0APrior to getting my RV-6A I had perhaps 250 hours over 20 plus years. My =0Across country experience was limited. I did not like to talk to ATC. I had never =0Aflown in the mountains in all the years I ha d lived in Colorado and less than =0Aideal/good weather flights were avoide d. I considered myself a wuss when it came =0Ato bad weather and was very p roud of it. The following parts will detail how =0Athis grasshopper went fr om a relative newbie pilot to one that is far less =0Anewbieish.=0A=0AAfter getting the RV I gradually expanded my cross country experience. Going =0A to La Junta was a cross country technically but timewise trivial in the RV. I =0Atook trips that could be done there and back on one tank of gas then those where =0AI needed fuel at the destination. Then I took trips where mo re than one tank was =0Aneeded. In the process of gaining this experience I got the Flight Guide books =0Afrom Airguide Publications and the WAC versi on of the Air Chart Systems aviation =0Amaps. These provided a lot of the i nfo that I needed to conduct cross =0Acountries.=0A=0AAt first I avoided MO As but now fly through them. Some are little used and =0Anot a concern but others like Vance I use flight following to ensure separation. =0AWhile I d on=A2t normally file a flight plan I do use flight following with ease =0An ow. Talking to ATC or going into controlled fields is not a concern.=0A=0AI have made day trips to see Devil=A2s Tower, Mt Rushmore, Meteor =0ACrater/ Monument Valley/Shiprock NM, etc. Longer trips have been made to Monument =0AValley and Death Valley, Kitty Hawk, Key West and the Bahamas.=0A=0ATo o vercome the mountain barrier to the west I took the mountain flying =0Acour se from the Colorado Pilots Association. The classroom work plus the =0Amou ntain flying with an instructor gave me the basics to safely fly in the =0A mountains. It was one of the best courses that I took since it has opened u p my =0Aflying to a region that is beautiful beyond what many pilots will e ver =0Aexperience.=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A/CreedeSep2007/D ubPikesPeakSmall.jpg=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A/CreedeSep2007 /CreedeValleyApproach2Small.jpg=0A=0Ahttp://home.pcisys.net/~ronlee/Leadvil le16Oct05.jpg=0A=0AThe weather issue remained the biggest limiter to cross countries as recent =0Aas three months ago. While I did take instrument tra ining (never got the =0Arating), seeing fronts that extend from the Gulf to the Great Lakes with radar =0Areturns of rain all over was an automatic NO GO for me. Then I planned a trip to =0AMemphis for an air race, Kitty Hawk , Key West, Bahamas and Crystal River to swim =0Awith manatees. I took off knowing that the weather was not my normal "ideal." =0ASome rain was foreca st as were lower than 12,000=A2 ceilings. The initial region =0Aof lower cl ouds was in Kansas or Oklahoma and I did consider turning back. But I =0Ake pt going since forward visibility was good, I was not scud running and I ke pt =0Achecking six to ensure the 180 degree turn option was good. =0A=0AMy fuel stop in Siloam Springs AR gave me the first real opportunity to make =0Aa bad decision over continuing. The direct path to Memphis placed me ove r =0Aterrain that may have come too close to clouds for my comfort. So I di verted to =0Athe south towards Little Rock then followed an expressway towa rds Memphis. This =0Aoption only took 10-15 minutes to clear the terrain an d I got to General DeWitt =0Aairport easily. =0A=0ATwo days later I had to encounter more lower than desired clouds to get to =0AKitty Hawk from Atlan ta. What made it worse was that I had to get low (2500 feet =0A(?)) over wa ter which I was not fond of. That made me rethink whether I would =0Amake t he trip to the Bahamas. A tropical system that past north over the Bahamas =0Acancelled the Bahamas and Key West portions anyway and a charging system issue =0Ahad me heading home.=0A=0AOn the way home I had the chance to ove rfly a cloud layer or try to skirt it. =0ASince it was of limited width (10 0-150 miles), well above the ground, thin =0A(300-500 feet) and temps well above freezing, I overflew it. All conditions were =0Aacceptable and had I needed to descend through it in an emergency I had my Trio =0Aautopilot to help maintain a wings level attitude. It was a non-issue.=0A=0AMy overnight stop was Springfield MO. It was late in the afternoon and I was =0Aheaded towards the west. Ahead I saw what I thought was a cloud layer so I =0Adesc ended. Turns out it was just haze but I felt better being a bit lower so =0Athat I could use the ground below me for attitude reference. While I lea rned to =0Afly in Georgia, haze had since become a complicating factor for flight =0Adecisions. When you can see mountains 100-150 miles away, going b ack east is a =0Adramatic change. Nonetheless, I arrived home with my comfo rt zone enlarged. =0A=0AA month later the Bahamas, Key West, manatee goals remained unmet and I took =0Aoff again. No issues until I got to Florida. I had been watching the haze and =0Anoted that it had a uniform appearance t hat may differentiate it from all clouds =0Atypes. I got a briefing from Fl ight Watch but without current satellite info, I =0Aelected to descend belo w rather than get stuck above the clouds. I flew about =0A2500=A2 MSL from there to my unplanned fuel stop in Cross City then on to Ft =0APierce. Visi bility was around 10 miles so I was never in MVFR conditions but =0Acertain ly marginal from what I consider normal in Colorado. =0A=0AThe next day saw yucky conditions to the east so I elected to try Key West =0Ainstead of th e Bahamas. I knew that there were rain showers in and around Key =0AWest. L aunch to the south and instead of flying direct I flew a bit east to fly =0Aover water in sight of the Keys. =0A=0AThe following picture shows some of the upper Keys off to the left:=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A /Bahamas2007/KeyWest1Small.jpg=0A=0AWhen I contacted Key West Approach they mentioned significant rain in and =0Aaround Key West. I elected to do a 18 0 then decided to land at Marathon since it =0Awas below me. I checked the radar and talked to a pilot who had just come from =0Athere. Based upon rec ent info, I proceeded to KEYW and did have to get low and =0Apass through s ome light rain as you can see in this picture that shows the =0Aairport ahe ad and to the right:=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A/Bahamas2007/K eyWest2Small.jpg=0A=0AThis is on final to KEYW:=0A=0Ahttp://home.pcisys.net /~ronlee/RV6A/Bahamas2007/KeyWest3Small.jpg=0A=0AAfter going to the souther nmost point of the US, Hemingway=A2s house and a neat =0Abutterfly =0A=0A"z oo" I headed back to Ft Pierce. =0A=0AThe next day the morning weather was better so I finally put my apprehensions =0Aon hold and started the trip to the Bahamas. I initially headed south towards =0AWest Palm Beach then in t hat area turned east towards Grand Bahamas. This is the =0AFlorida coastlin e looking north as I commit to going out over the =0Aocean:=0A=0Ahttp://hom e.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas1Small.jpg=0A=0AThe next pictu re shows the GNS 430 screen shot well out into the ocean with =0AMYGF (Free port) as the destination:=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A/Bahamas2 007/Bahamas2Small.jpg=0A=0AThis shows only ocean (plus clouds) below (no la nd):=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas3Small.jpg =0A=0AHere I am approaching Grand Bahamas:=0A=0Ahttp://home.pcisys.net/~ron lee/RV6A/Bahamas2007/Bahamas4Small.jpg=0A=0AAt this point I made the turn f rom Freeport to North Eleuthera Island =0A(MYEH)=0A=0Ahttp://home.pcisys.ne t/~ronlee/RV6A/Bahamas2007/Bahamas5Small.jpg=0A=0AAnother shot of just wate r for landing although there are strips of land in =0Athe distance:=0A=0Aht tp://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas6Small.jpg=0A=0AAt las t I am on final to MYEH:=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A/Bahamas20 07/Bahamas7Small.jpg=0A=0AHere is the plane at the White Crown FBO. Note th e official looking large N =0Anumbers:=0A=0Ahttp://home.pcisys.net/~ronlee/ RV6A/Bahamas2007/Bahamas15Small.jpg=0A=0AMy objective on this island was to see Pink Sand beach. Unfortunately it was =0Anot as pink as I had hoped al though it is still a nice beach:=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A/B ahamas2007/Bahamas10Small.jpg=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A/Baha mas2007/Bahamas9Small.jpg=0A=0AThe trip back was not a problem. I did not v iolate the ADIZ and was able to =0Aopen my flight plan as I headed towards Grand Bahamas. This picture shows the =0AFlorida coast near West Palm beach :=0A=0Ahttp://home.pcisys.net/~ronlee/RV6A/Bahamas2007/Bahamas11Small.jpg =0A=0AHere I am flying north along the coast to Ft Pierce. I am not sure ab out =0Awhether I had to land at West Palm Beach if I crossed land there so I stayed =0Aoff-shore until I got closer to Ft Pierce.=0A=0Ahttp://home.pci sys.net/~ronlee/RV6A/Bahamas2007/Bahamas12Small.jpg=0A=0AThe weather was no t suitable for getting to Crystal River after I cleared =0Acustoms so I sta yed at Ft Pierce another night. The next morning was rainy. It =0Awas just in that area so once the weather cleared to the south I took off that =0Awa y with the initial thought of skirting the rain. Once airborne I decided th at =0Ait looked promising "on top" so I climbed up to 10,500=A2 and was abl e to get over =0Athe localized clouds. This picture shows a plane going int o Orlando and why I =0Ause flight following:=0A=0Ahttp://home.pcisys.net/~r onlee/RV6A/Bahamas2007/Bahamas13Small.jpg=0A=0AThe next morning I swam with manatees which was a great experience. Back to =0ACrystal River airport an d looking at the adds.aviationweather.gov cloud cover =0Awith VFR/MVFR/IFR condition circles I knew that trying to head northwest was not =0Ain my new ly expanded comfort zone. The weather towards Atlanta was better so I =0Awe nt that way. Spent the night at my brothers then made it from Atlanta to 00 V =0Athe next day in about eight hours (a record for one day). Total flight time was =0A29.2 hours. In addition to further expanding my piloting comfo rt zone, I got to =0Ado some neat things....all thanks to a great airplane. =0A=0AWith that I will leave you with a picture that I took at the Homosass a =0ASprings State Park south of Crystal River:=0A=0Ahttp://home.pcisys.net /~ronlee/RV6A/Bahamas2007/Bahamas14Small.jpg=0A=0A =0A=0A=0A=0A=0A=0A=0A=0A =========================0A =============0A=0A=0A=0A=0A=0A=0A=0A _________ ___________________________________________________________________________ =0ANever miss a thing. Make Yahoo your home page. =0Ahttp://www.yahoo.com/ r/hs ________________________________________________________________________________
Date: Dec 07, 2007
MessageActually there is a group that goes yearly. It may be to tyhe Turks & Caicos with a stop in the Bahamas. Look for posts from Paul Rosales Ron ----- Original Message ----- From: Tim Bryan To: rv-list(at)matronics.com Sent: Friday, December 07, 2007 12:19 PM Subject: RE: RV-List: Expanding my flying comfort zone Ron, This was a great story for me and has many points that were similar for me and my flying. I hope to make Bahamas some day as well and maybe we can organize a trip with others as well. Thanks for sharing, I enjoyed the photos also. Tim ________________________________________________________________________________
Subject: Condition Inspection Log Entry
Date: Dec 07, 2007
Can someone point me to the proper wording to enter a condition inspection in the logbooks? Thanks Tim ________________________________________________________________________________
Date: Dec 07, 2007
Quoting David Schaefer : > That's about the only way. Bob doesn't like to publish is actual email. > He'll reply to you after leaving a web email from his page. Strange, as it's on every message he posts to the AeroElectric list... nuckolls.bob(at)cox.net -- Dan Brown, KE6MKS, dan(at)familybrown.org "Since all the world is but a story, it were well for thee to buy the more enduring story rather than the story that is less enduring." -- The Judgment of St. Colum Cille ________________________________________________________________________________
Date: Dec 07, 2007
Hi Tim here we go: I certify that this aircraft has been inspected on (date), in accordance with the scope and detail of FAR Part 43, Appendix D, and found to be in a condition for safe operation. Plus signature and cert number. Happy inspection Thilo Von: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] Im Auftrag von Tim Bryan Gesendet: Friday, December 07, 2007 10:51 PM An: rv-list(at)matronics.com Betreff: RV-List: Condition Inspection Log Entry Can someone point me to the proper wording to enter a condition inspection in the logbooks? Thanks Tim ________________________________________________________________________________
Subject: Re: Condition Inspection Log Entry
Date: Dec 07, 2007
MessageTim, Look in FAA Part 43. FAA.gov Mike ----- Original Message ----- From: Tim Bryan To: rv-list(at)matronics.com Sent: Friday, December 07, 2007 3:51 PM Subject: RV-List: Condition Inspection Log Entry Can someone point me to the proper wording to enter a condition inspection in the logbooks? Thanks Tim ________________________________________________________________________________
Date: Dec 08, 2007
FAR 43.11 Content, form, and disposition of records for inspections conducted under Parts 91.... (a) (1) (2) (3) (4) "or" (5); (b) "if necessary" -------------- Original message from "Tim Bryan" : -------------- Can someone point me to the proper wording to enter a condition inspection in the logbooks? Thanks Tim
-------------- Original message from "Tim Bryan" <n616tb(at)btsapps.com>: --------------
Date: Dec 08, 2007
Subject: Re: KLX-135A Internal Battery
Just today I realized that the Bendix/King KLX-135A has an internal battery with what is claimed to be a 3 to 5 year life. Mine just went TU after 9 years. It's supposed to give to a warning on the screen that data will be lost unless replaced within a week. Since I haven't flown for a few weeks, I guess the warning went unheeded. At least I think that's what's going on here. My GPS was non-op as it lost its initial position and the radio freqs default to 120.00 on power up. I wasn't going to fiddle with it in the air so I just ignored it but it never did capture. This prompts a few questions. Can anyone confirm my suspicions with the available evidence? Has anyone personally replaced this battery or is it absolutely necessary that it to be done by an avionics shop? I'm assuming that Bendix/King (Honeywell) won't sell me a replacement directly, so it's probably the latter. If anyone has had this done yet can you tell me what the $$ damage was? I will probably just take it to LAC at the San Jose Jet Center on Tuesday. -Thx N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) ________________________________________________________________________________
Date: Dec 08, 2007
Yes, It is in your operation limitations that are supposed to be in the aircraft . Mike Robertson Das Fed From: n616tb(at)btsapps.comTo: rv-list(at)matronics.comSubject: RV-List: Conditio n Inspection Log EntryDate: Fri, 7 Dec 2007 15:51:06 -0600 Can someone point me to the proper wording to enter a condition inspection in the logbooks? Thanks Tim _________________________________________________________________ Your smile counts. The more smiles you share, the more we donate.- Join i n. www.windowslive.com/smile?ocid=TXT_TAGLM_Wave2_oprsmilewlhmtagline ________________________________________________________________________________
Subject: KLX-135A Internal Battery
Date: Dec 09, 2007
Hi Gary, I can confirm that your KLX-135 has an internal lithium back-up battery. They usually are an off the shelf item. I'd be tempted to pull the cover and at least take a look at it. If it's soldered to the board you will need a replacement with "tabs" or "leads". (Flat or round) Most are available that way if you specify it. A quick search on the net should pull up a source for a replacement. Good luck. Nine years was pretty good. Dave _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com Sent: Saturday, December 08, 2007 7:40 PM Subject: Re: RV-List: KLX-135A Internal Battery Just today I realized that the Bendix/King KLX-135A has an internal battery with what is claimed to be a 3 to 5 year life. Mine just went TU after 9 years. It's supposed to give to a warning on the screen that data will be lost unless replaced within a week. Since I haven't flown for a few weeks, I guess the warning went unheeded. At least I think that's what's going on here. My GPS was non-op as it lost its initial position and the radio freqs default to 120.00 on power up. I wasn't going to fiddle with it in the air so I just ignored it but it never did capture. This prompts a few questions. Can anyone confirm my suspicions with the available evidence? Has anyone personally replaced this battery or is it absolutely necessary that it to be done by an avionics shop? I'm assuming that Bendix/King (Honeywell) won't sell me a replacement directly, so it's probably the latter. If anyone has had this done yet can you tell me what the $$ damage was? I will probably just take it to LAC at the San Jose Jet Center on Tuesday. -Thx N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) _____ hottest products and top <http://money.aol.com/top5/general/ways-you-are-wasting-money?NCID=aoltop000 30000000002> money wasters of 2007. ________________________________________________________________________________
Date: Dec 09, 2007
Thanks everyone, I did find the exact wording they wanted in my operation limitations as well as other entries required. Tim _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Mike Robertson Sent: Saturday, December 08, 2007 10:36 PM Subject: RE: RV-List: Condition Inspection Log Entry Yes, It is in your operation limitations that are supposed to be in the aircraft. Mike Robertson Das Fed _____ From: n616tb(at)btsapps.com Subject: RV-List: Condition Inspection Log Entry Date: Fri, 7 Dec 2007 15:51:06 -0600 Can someone point me to the proper wording to enter a condition inspection in the logbooks? Thanks Tim blank>http://www.matronics.com/contribution t=_blank>http://www.matronics.com/Navigator?RV-List p://forums.matronics.com _____ Your smile counts. The more smiles you share, the more we donate. Join in! ________________________________________________________________________________
Date: Dec 09, 2007
AHA! It is so seldom I am able to offer real experience to address problems. I concur with most of your observations. I was surprised to find this battery is not a rechargeable one! It just sits there keeping the GPS catalog alive for years. I mention this to point out to you that it is not going to revive. Mine gave me warnings for some time before it croaked. My KLX-135A gave up its battery ghost at around eleven years. I hope its replacement will last another 11. I went over to the on field avionics shop, and ordered the battery, 31 bucks. It is about the circumference of a silver dollar but much thicker. It has three solder pins and solders in to a circuit board. This circuit board is several layers in to the guts. Not sure I would have ever found it; however I was born under a lucky star. While I was in the shop I noticed a KLX-135 on the bench getting its battery replaced!! What the hell I took a correspondence course in electronics in 1970, so I ignored the shop owner's advice that I could not and should not do it myself. Took about an hour. Works good. Post script. Once it goes, it will take a looonnng time for the GPS to find itself, with or without a new battery. I recall around 40 minutes to an hour. As a possible precaution, you might leave it outside with power for an hour to see if it comes around. This would tell you if it is just the internal battery. Post Post script. If he will do it for an hours labor, I would go for it, unless you have some credentials as a solderer with circuit board endorsement. You could encourage such an agreement by showing up with it in your hand so it is just bench work, IMHO. Good luck. On Dec 8, 2007, at 8:40 , Vanremog(at)aol.com wrote: > Just today I realized that the Bendix/King KLX-135A has an internal > battery with what is claimed to be a 3 to 5 year life. Mine just > went TU after 9 years. It's supposed to give to a warning on the > screen that data will be lost unless replaced within a week. Since > I haven't flown for a few weeks, I guess the warning went unheeded. > > At least I think that's what's going on here. My GPS was non-op as > it lost its initial position and the radio freqs default to 120.00 > on power up. I wasn't going to fiddle with it in the air so I just > ignored it but it never did capture. > > This prompts a few questions. Can anyone confirm my suspicions with > the available evidence? Has anyone personally replaced this battery > or is it absolutely necessary that it to be done by an avionics > shop? I'm assuming that Bendix/King (Honeywell) won't sell me a > replacement directly, so it's probably the latter. If anyone has > had this done yet can you tell me what the $$ damage was? > > I will probably just take it to LAC at the San Jose Jet Center on > Tuesday. > > -Thx > > > N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) > > > hottest products and top money wasters of 2007. > > ________________________________________________________________________________
Subject: Apollo GX?? was:KLX-135A Internal Battery
Date: Dec 09, 2007
The Apollo GX series radios also have a battery that the manual says requir es FACTORY replacement. THEY have been user serviced. They are in a battery carrier and will pop out with a screwdriver. I have a coworker that is a T-18 builder / flyer that did his own and set me photos. Gary A. Sobek 'My Sanity' RV-6 N157GS O-320 Hartzell, 2,0643 + Flying Hours So. CA, USA From: d-burton(at)comcast.net Subject: RE: RV-List: KLX-135A Internal Battery Date: Sun, 9 Dec 2007 06:49:21 -0800 Hi Gary, I can confirm that your KLX-135 has aninternal lithium back-up bat tery. They usually are an off the shelfitem. I=92d be tempted to pull the cover and at least take a look atit. If it=92s soldered to the board you will need a replacement with =93tabs=94or =93leads=94. (Flat or round) Mo st are available that wayif you specify it. A quick search on the net shou ld pull up a source fora replacement. Good luck. Nine years was prettygo od. DaveFrom: owner-rv-list-server(at)matronics.com[mailto:owner-rv-list-serv er(at)matronics.com] OnBehalf Of Vanremog(at)aol.com Sent: Saturday, December 08, 20077:40 PM Subject: Re: RV-List: KLX-135AInternal Battery Just today I realized that t heBendix/King KLX-135A has an internal battery with what is claimed tobe a 3 to 5 year life. Mine just went TU after 9 years. It'ssupposed to give t o a warning on the screen that data will be lost unlessreplaced within a we ek. Since I haven't flown for a few weeks, I guessthe warning went unheede d. At least I think that's what's going onhere. My GPS was non-op as it lo st its initial position and the radiofreqs default to 120.00 on power up. I wasn't going to fiddle with it inthe air so I just ignored it but it neve r did capture. This prompts a few questions. Cananyone confirm my suspicio ns with the available evidence? Hasanyone personally replaced this battery or is it absolutely necessary thatit to be done by an avionics shop? I'm assuming that Bendix/King(Honeywell) won't sell me a replacement directly, so it's probably thelatter. If anyone has had this done yet can you tell m e what the $$damage was? I will probably just take it to LAC atthe San Jose Jet Centeron Tuesday. -Thx N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, S ilicon Valley) hottestproducts and topmoney wasters of 2007.href='http://www.matronics.c om/contribution'>http://www.matronics.com/chref='http://www.matronics.com /Navigator?RV-List'>http://www.matronics.com/Navigator?RV-Listhref='http: ======================= _________________________________________________________________ Connect and share in new ways with Windows Live. http://www.windowslive.com/connect.html?ocid=TXT_TAGLM_Wave2_newways_1120 07 /9j/4AAQSkZJRgABAgEASABIAAD/4STlRXhpZgAASUkqAAgAAAAMAA4BAgAgAAAAngAAAA8BAgAW AAAAvgAAABABAgAMAAAA1AAAABIBAwABAAAAAQAAABoBBQABAAAA4AAAABsBBQABAAAA6AAAACgB AwABAAAAAgAAADEBAgAbAAAA8AAAADIBAgAUAAAACwEAABMCAwABAAAAAgAAAKXEBwCyAgAAHwEA AGmHBAABAAAA1AMAAFgGAABPTFlNUFVTIERJR0lUQUwgQ0FNRVJBICAgICAgICAgAE9MWU1QVVMg SU1BR0lORyBDT1JQLgBDNTVaLEM1NTAwWgBIAAAAAQAAAEgAAAABAAAAQWRvYmUgUGhvdG9zaG9w IENTIFdpbmRvd3MAMjAwNzoxMjowOSAwODoyNToyMgBQcmludElNADAzMDAAACUAAQAUABQAAgAB AAAAAwDuAAAABwAAAAAACAAAAAAACQAAAAAACgAAAAAACwA2AQAADAAAAAAADQAAAAAADgBOAQAA EABeAQAAIABSAgAAAAEDAAAAAQH/AAAAAgGDAAAAAwGDAAAABAGDAAAABQGDAAAABgGDAAAABwGA gIAAEAGAAAAAAAIAAAAABwIAAAAACAIAAAAACQIAAAAACgIAAAAACwJ2AgAADQIAAAAAIAKOAgAA AAMDAAAAAQP/AAAAAgODAAAAAwODAAAABgODAAAAEAOAAAAAAAQAAAAACREAABAnAAALDwAAECcA AJcFAAAQJwAAsAgAABAnAAABHAAAECcAAF4CAAAQJwAAiwAAABAnAADLAwAAECcAAOUbAAAQJwAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAF BQUAAABAQICAwMD//wAAQECAgMDA//8AAEBAgIDAwP//AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAFBQUAAABAQICAwMD//wAAQECAgMDA//8AAEBAgIDAwP//AAAAAAAgAJqCBQABAAAAWgUAAJ2C BQABAAAAYgUAACKIAwABAAAABQAAACeIAwABAAAAfQAAAACQBwAEAAAAMDIyMQOQAgAUAAAAagUA AASQAgAUAAAAfgUAAAGRBwAEAAAAAQIDAAKRBQABAAAAkgUAAASSCgABAAAAmgUAAAWSBQABAAAA ogUAAAeSAwABAAAABQAAAAiSAwABAAAAAAAAAAmSAwABAAAAEAAAAAqSBQABAAAAqgUAAIaSBwB9 AAAAsgUAAACgBwAEAAAAMDEwMAGgAwABAAAAAQAAAAKgBAABAAAAqAUAAAOgBAABAAAA1AUAAAWg BAABAAAAOAYAAACjBwABAAAAAwAAAAGjBwABAAAAAQAAAAGkAwABAAAAAAAAAAKkAwABAAAAAAAA AAOkAwABAAAAAAAAAASkBQABAAAALwYAAAakAwABAAAAAAAAAAekAwABAAAAAQAAAAikAwABAAAA AAAAAAmkAwABAAAAAAAAAAqkAwABAAAAAAAAAAAAAAAKAAAAZAAAABwAAAAKAAAAMjAwNzowNzox MCAxODowMzozMwAyMDA3OjA3OjEwIDE4OjAzOjMzAAUAAAABAAAAAAAAAAoAAAApAQAAZAAAAE8A AAAKAAAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAAAAAAZAAAAAACAAEAAgAEAAAAUjk4AAIABwAEAAAAMDEwMAAAAAAA AAYAAwEDAAEAAAAGAAAAGgEFAAEAAACmBgAAGwEFAAEAAACuBgAAKAEDAAEAAAACAAAAAQIEAAEA AAC2BgAAAgIEAAEAAAAnHgAAAAAAAEgAAAABAAAASAAAAAEAAAD/2P/gABBKRklGAAECAQBIAEgA AP/tAAxBZG9iZV9DTQAB/+4ADkFkb2JlAGSAAAAAAf/bAIQADAgICAkIDAkJDBELCgsRFQ8MDA8V GBMTFRMTGBEMDAwMDAwRDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAENCwsNDg0QDg4QFA4O DhQUDg4ODhQRDAwMDAwREQwMDAwMDBEMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgA oACbAwEiAAIRAQMRAf/dAAQACv/EAT8AAAEFAQEBAQEBAAAAAAAAAAMAAQIEBQYHCAkKCwEAAQUB AQEBAQEAAAAAAAAAAQACAwQFBgcICQoLEAABBAEDAgQCBQcGCAUDDDMBAAIRAwQhEjEFQVFhEyJx gTIGFJGhsUIjJBVSwWIzNHKC0UMHJZJT8OHxY3M1FqKygyZEk1RkRcKjdDYX0lXiZfKzhMPTdePz RieUpIW0lcTU5PSltcXV5fVWZnaGlqa2xtbm9jdHV2d3h5ent8fX5/cRAAICAQIEBAMEBQYHBwYF NQEAAhEDITESBEFRYXEiEwUygZEUobFCI8FS0fAzJGLhcoKSQ1MVY3M08SUGFqKygwcmNcLSRJNU oxdkRVU2dGXi8rOEw9N14/NGlKSFtJXE1OT0pbXF1eX1VmZ2hpamtsbW5vYnN0dXZ3eHl6e3x//a AAwDAQACEQMRAD8Azp0TEpp0TElY7qLkylP4KCPg0HLzcfFkj17GsLhyAfpO/ssSiDIgDcmvtUTQ JPRhuKlOi3rug9Nre5rRa4NJAJs5jvoxCPSunj/B2f8Abh/8irR5HL3j9v8AYwjmsfj9jiylK1H4 XTm/4J5/647+5CdRhAeykk6aOucNO/5qH3LL3j/zv+9V96x+LRlKVe+z4R/wDv8At16kMbC/0Lv+ 3Xf3JfcsveP2n/vUfesfj9jQnVSBWkzD6efpVub5+o4/wTnE6WON0/13f+RS+5ZO8ftP/ep+9Y/H 7HNJk/cn7q5bTgMMhjnf9dI/9FqvZbgViTU/5W/+okDyeQdY/ar71j8fsRp5hEtrrOFjZ1O4V5Dr K31uIdssqI9m8NZu9Sp7LfooAKgnEwkYlljISFjZJOqkHIW78U+5NSmDhBKUoYOiW5G1P//Qyd2g KYlDrdNTT4gfkUtyx3UXLitf6qUet1lru1FVtv8A0fSb/wCfVjbhx3XSfU+KMTqvUXDSmoVg/Ky+ z/qK1PykeLNDwN/4rDzM+HDM+Ff43pdPLreLHlp0n8oDlm5DrwTAcQyC8xoA76G7+sruMKb8DGsy Gte+yttj26QXWMZY/wDlbtz1S6n0nBvwr6mY1duVdU6ih1haJc5p9Bpsf7WObb6fpWf4Ja0jqXPA 0alnqH80obWZDnhrGOL3aNaBJJ/khcp/zS6o3Q4Dp2h3utaJB+iQXbd25DHRrcO+u3Ioaxtd76Xt GQwHfXSMvay1hZ9JllWx9dv6T+Zr/SJtpp612T6TWvttrra5zmAvsY07mR6rNr3Ndur3s3Jv2hh/ 9yaP+3q//Jrm35H1Y9aj0ekvsoya3MDL7z6tdgOz1m3VBvq+wfzN36NZTqa2mPsvdwEtfrtMJHa1 dae6d1DELSBkUz/x1f8A6UVM5bCSRkUHXtdV/wClFyeLiuzMurBx8Nr8i94rraWvGp/Od/IZ9Ox6 7qnpv1BopZVmHOyn1tcDYKGBr21ktfZW1rH2+lp/pUI6kgdrUWh61ljbHtcywVN3vLLGO2tlrN7t j3e3e9jFWtLnNFhOhkgd9Fr3dA+oWXhh3TbcnGybLG141t9Dyw2Wh32djvTqr2s3s3+o5/8A0Fy2 O3KswOpUvgWYUW7XuYx3ff7Hu3vd9D+b9TYos0J0K6r8co3q9D0wG2vNxhJmkX1/18cut/6eK/Ka o7o4VToWfZi3U5Ouxnputb2exux9lT/3t6u5eP8AZMu7FncKHljHeLP8E/8A65VssVLPH0xl/gn9 jbwS+aP+EGO7VPKHIlOHKszpd2gToYPHknlFT//R5+t0MLf3XOb9xKluQQYstH8qfvAKluWRTqJJ XR0l2N9Q8x7TD8z1o89xbh1/+e3rmHPgEngCSus6pV6PRumdMPL3YbHjzcW5N3/Se5Xfh8fXKX7s T/zmnz5/VCP70ohrdZtdTmurYfZUyuusfyWMbW3/AKhN07KeRa6yWBrNzbBB2ln6XdtPvb9H6dfv UesuyH4dTcEVHIaPfZcXbA0y9+z0f5bnfS/R+mq7ag/Cua+wh/pSTXoDw6xzGuO51O7/AKtW5D12 xiQ4CL2TPOaMj04NW1+x9pJ9usPs2/S/lKv1qrHd0e3LjbVj9QezdcWEj1cfFaxxqcz6b6v3fT+z qrmYuATft6jkuvrHvx3VxXp7f0Nrbne+r/i0DNId9XWYryHtf1O1z3PkEuqxsBjWu/tWpsTV0Atz xsREge+rR6UKTb6TyfTNJG9onWdzLH/1o+muhwMSm7pzWPsLW0kMuZoHMZvew+s7XY+76Hrf6Rcz gV2OyGWtvLDuvBqayGBtRr9jRu9L9K2x/wCZ+i9P/CLee/Fq9QNa9te/aXiGhw3ut2O19/pz7P3F KalADUVbUzkiUDw8fg3ug+3rdIaGg3Mtraxpe4je0XenW5zne38z0/3P/BCZ/wBXfrJVbZe3p9ll L7Hljm5G1w3Oc5r3tsyKNm5rv3FXDbsiaGtvF22Gix7axoxu17PT/Ss2foshnp/6Gn/QUq6br+nM syG25ALnPO+q20ANJY2vcw2ua727LPa308f/AAX86oYxlCcpD5pARrdnlkjw10iejmnpn1jrqFTc K7FoY9jw597QxrqyRVY1zLrXbWbvpNauatfQ/qzr76Bl0t/SXVhwBsgua7ZbU2lnu/nN+33/APCL oepdXychtdHrvyRcweoy62wkujj065raz/C/RXP5/qWZLbHsdWXjbuEhrjH82z95n/CJGczIcdeC 6NEXHzbdnUOmvyWM6bW6uktmxjtPdLRtaNz/AOUtvNeLsbCzG/n1HGt/4zF21tn+vhW4a5Cs7AH6 w1xDSAI1BLff+cup6c/7T0fLo5dSK86of1D9ly//AADJrt/9BVDlhcJAf3h5s+KdTiT19KPdqnDp KDu1Ug5UablpS/slu/KhApbkKTb/AP/SyXU45G4Vjc4AEnv4d1TvhplgDR2Cv3gAEN1drEeZ2ArN tdNh7wSfu9qyQ6i1FduXl0YjD/SLa6eP33Nr/wC/Lr/rPkuPVKXY7Q01PuyAH6tb6TPTY+yI/Rb3 rC+qlDX/AFgw3uBPol+S4H/gWPtb/wCCemtrKfW/quS62v1W101VanQG95se4j872VbVp8lEDHI9 yB/iud8QkeOAH6IlP+CHomP9Zsn1TV0nprW0uFRs6g23aHvDbPTpo3XObva+t/rWV/zf+EWWx+V9 uvp6nhV9Prqc+myugvLN3qUNdVXaLLXbfa9y6OrrGViPtoxB+zmWO3VkOD/Uc1uyvc64O+j+j/r1 fq6wc6zFuyLsm5jqnOvqc5zT7n2vL7X/AExt/wAD/N/+CKYm5fxYCIiFdxuB3a+XhYbHfaMW0Nhj /UNnrHbBa/1fWyaaq7Xbd7NuNa9R2UD6tMuvsa8VdTvAZaN26WYVb79+7b+j2/8AgqWV1XENeRiX MuZvY5jHtez02S1zWv2lm/Y3d++moyrMLo+LbQfb+0M9ocQNpAGFsbZuDv3N/wDYUcdCT4ebLlIk dAPIekNbplFNvVatpoZS0m4HLl+PLoPp5G76WPbs9N60rsXK6hkZIqqaKm2S9llrtzXu91tTbGz6 rKXfo2Pe73rHwKn5tLnYVdjsoNsbZkAhu6RFxfY5380+t/6Sr+X6fp2LqeksLcrNrPZzHHjksa6f ZLfduT5z9Gg1B/NiERLLjif62x1+SbKtnVKnTWyp4ZArNj3FwDRsrl/t3OqYNm7/AAiX7IzLMV9v 2LHrDD6bbg46l3vurdu+m53877f8ItVrApHd9H80TtBPE+AUXGetM55bGRw6+d6uO7pVjq2VmpkM ZsIbAadG7fb/ACNm1ixeu9F6qzAsvsdWaccBx2E7zP6JztfzPfucu0ZMcKOVjNysS7Fs0ryK31Oc IlosaWb2/wApm7emcIJBN+k2GWI4BIR/SjwnX6vmGXn3hv2N9ddTntDXEPadCNNjdNu5dF9V8rEx 7aftLBbQ9opeZ9vp2luPlOf++37K7IZ/xi6dmDjYOM/pNOJQMVgeNj2Cx1jQXb33Ou2vtst2Nfvb 7P8ARrkMXDoxsy3EDYrZYWsZM7WWA3VNa+Xez2XM+kquHnceS+GBj1Fniv8AR1QcUtNXqLujdNqt NTsZu6tzq36v+k07Od6GemdLAJ9Bvt7kv/8AJ/urQss+0U0ZR1ORU11n/GM/Vr/859Xqf21FrQXa /ROhHw/8xQJo1Q+zo2o6xBaY6T0ySPQbJ49zv/JqP7KwefsmkT9J39X9/wDeVuHBze7gdsR4/wC5 E9McbREzx2+lKN76D7FU/wD/08rIdsLzx3I8gPZ/5NZ1O2SHAOkQBPirmc6W9xpx8VnB1osbtIJB BEg9llxGhdO3p/qhVOV1HIj+ZoFQP8q57R/56osRagy2/Oe90evkGpmjSG+gxrW2v3uZ7WWqz9Tq AOkZN4GuVlNafhTXJ/8ABMlVej5Lzg25Htb6OVdUDHd7nvtc8OPu/MWryorDEecnI57jlmIhV0Ia /wCNND1U5ThtxnV32tPtddox7Z2vbvbY59te/wBPZX/g/wDCKv8AZ3ODfttAtPqtJa15hj2s9tm+ t36Ta7f/ADi0M7IF97rbHDc5obO6WgiXbw1uyvf6jt6BRfXRjNvLPWvmxwhxAa9gZs9tYd9Jn0/3 /V9T8xOq5dqC2jCAO9Vua3/7j91xMrExzbk2e31LNHbw+shrob+lrbuctOvp+TZ0LZh1F4OZnuDn AkMqLsWH7g17vdj1P22KjlYNH6awucLr3Nt3Bgpc5zvfHDf3vz6/etTEf17H6GbeleqcfHzeoNzr agIFbXUlvqhp3bdvq/Q+gmDQknamQeoRA1JLg/aLqn1XUWgsDB7ZO2w/4Qbfa61jv5f5i1vqlk23 5+cy55seGNJc4yfa41t/6G1qxH1vea7KazFMtDDtaIEaT+Y539X3rQ+plrD9Y85rN2x+PIDwA4EO rncGusb/AJr0ZGMsYrf8eEr4xMZgEUYkg/3vle1a1TDB3UmiQpNb3UQDPawZpomLJ+JREiJSICgX K619Yuj0ZZws3N9D9FW65jWFx3Eeoxhe017Pbts+l+4uUyur9NyerziZDrx6QHqPbsJNT/WqH8pz KXZTPUT/AF86Xk2daqvxKH3uyMUPsFTS4g0OdQ9xa3/gvQXP4mHk4vVsVuZQ+pr7RX7wQCXTXo/6 DvpfvKpHkMUOLJGUrIlLhuPDxH/B4v8AnqGWXEI0KsD6PpPRslmT0++gEOdiWC0A967x6Ng/s300 /wDbqsvI3B7WlvBjngfvLC+q7nV9VpqcIqzGPxXk8A2AOpP9nLroXQADVpA1Gp/h/ZcjOFCJHUfk y4paEHoWDg4k+YDh2Oh50RN9ccn6O/jzTBoAaQNW6R5HT+CnsMRGvH9mZhNo0V/V/9TDzTLHDnWJ +CosIDpVnLf73AeJVKwgNcRzrHxWZEaOm+i/V6ltP1f6e0yHWNsyOP8AS2OLf/A2VrnumNwGdNfZ lAuORlXXMBqDmhhcWN9Ox/0tzv5zauwfWzCwmUy79Qxms2n6I9Opnqbf7Vaw6MLp1mL0rGy23ANZ WyyysQxrnNfbdve4e5/83t9n/CeotkR4cUf6ocPJlJzyox9RPDchGzfyuVkW9MkgUNO2eK2iY/8A OkStvT2dJsO2G3G4Ufo4G/X6TQd385/JUM2nHorfXU1pFT7dnqkHcx1h9Dc5vp7rttW32OVa+uxl IAaaWMts2h24tBn3bNrfd+l3/mpkYyJsjQrp5SYiv3vy9J/xZIcbEz8ttTTluN2P9Gutjdp9w2S6 19Wxm36Hp+p6fvV2r60u6N9Wr+iZFTcj9pPz67Lq7AWV7wz/AAjPUZkPq+0Wb/Qt9L/hFTxWNbY1 97i9jSJIhzv+NrDq2Na+v/BqXTcW7HwaaLaS19b73PbYwQ4uPqfZ6rLGvb+mo/wjN/0/0iXBRScw G2tEf87+881Vl20OfVTc4MJDm17N+pG7e2t3v+j+etb6k2j/AJxOO5zy+ixrnOEaywx/0V0TOj9b zsRrem4d9j8UtrN4dTWwms7b6qr3bLXt+lU930FHof1S+teF109Sy+j7qC2xppGTS0+4Qx3qNue/ d7Wb3qEXKxw8Isxvv/WbUhGPARMTuMZ6fo8W8P8ABejY9EY5sc6qtlftqvEybLvq67FqrY8i+jOF 1rIBLbm0N2+pt/0a5nonUeq5Da8jJ6jc5nrsqto3V7vSfs/T17/0v0Xfzvoej/wiRHDVnwTGXEaA ey3N8UtzZ8Vpf82ah/2vzdP5dX/vOm/5uVjjPzP86o/+66dwX1W+6Ozzf1gz8/Dwm24Brrstt9Gy 1zQTWx7H2tcwu9rGb8f9Jv8AZ+euIzetdYzcGuvMZS9mNc28ZABFrjW4tb+d6P53+CrXqmZ9VMfN p+zZPUMt1Rex+0+iRuYd9TnN+zbX7HfmvXm1/Qsyh9Fd7aDQy+zCdWxjhY80n9au31Mspr9jmWOt uux7f+M96BxjTaRtaZkk8NjRtY+RkC9teLrYbAaI53ucHU/9N1a7LMa195uDYbkNFoaeRvG9zP8A rdvq1pY31Y+r2yu+nGsbLWWVuFtukNb6ZafV+kza1I1NrZZjsn9SuLGBxJcarmjNoc7duc7ba7Mo /wCtJuTlpQw60eHsrl+cx5cxjHiFi/UKQ1gEkRyNPL/Vynr5fRnlO1uv+vfUIk9tvef4qtWhbvV/ /9Xmb9XEnXX/AGqfS8T7X1bBxCJ9fIqY74F7d/8A0EOz8qHjZ2Xg5rMvEeK7qDNbi1roJBbO2wOb 9F6o4ImUwO2p8m/lmIRv6DzfTes3ergZxrLt14dW2Glxm53pN2sHuc79Iq/ULGmn7O/Fy22MYK7S 3EfbWC1oa79L7ar2N/e+guKH1u+sntJyx7HNe39FV9Jh3s/wf7wU8764/WPqOM7Ezspt+O8tc+p1 NQaSxzbWbtrPo+oxq05zJoRGni5UMRBMpEXtoL0d+vp1mRjY9WRTfYKtotsyKHUONjJ/mtzd/va7 2Uf4T+Z9OxZPXHjGy7nFgaAXgNBbDg8+wTG785irdR+t/wBYuqYj8HPym3Y1u0vr9Ktsljm2s9zG B3tsY1Z+XnZOdZ6uY4XWFxs3FrQdziHOcNo9u7alGRA8Vp5e58RlYvir/Fqv8V1sfdVlPZk1VEgE BtjntYHtc12y31a8Z/6Rjn/zanjC6nNN7dtmPjkh7dpdYGkel63taxn8879H+k/sLLt6p1C+w2W3 Fz3AAmAJ2ja36I/dT19Uz6pLLo3Da6WtdLQd207mu+ijMkxIj+JScF5BkPCSP6v5S4nZv+tnUsLp b6Om5d2Hbihx2CqpzDG1zm2G5tlvrMfb7/8ABrMf/jE+ulbax+0txsaCJoo7zB/mVTssfc+19sPd cSbZAhxP0js+j7lF1VVhburafTG1gAiAO3thRCEq1IZ70AoaOtjf4xfrM31m5uX9qIaQKTj0tBJB a5j7a/Qc1v8ALrWD9Vn2N6g9jtx/VrGt3akbdr9oMbm/RVuutlTt9bQxxf6hIH5/76lTWym31qmh lkEbxPDhtcP7SUscjEiwmM6INDTtu+5NsFjG2Dh7Q77xKZztF5Oz61fWRrGsb1G0NYA1oAr0AED/ AAamPrR9Yzz1K/8A6A/JWniKw1ej6PmZYqBkrjMm5t+V13HAb6RrfnkBoDg8VNyaL3fv/pMTLo/9 CPf+jWQ/rnWrtLc65/xcP4BBbkX732Gx2+2s02PnV1R3bqXn86v3v9iJgSY1WhtIIAPjo979X8ht 3SquZqLmEDWADvZ/0HtSzG7OpMInZnY76TpzdjH7dit/t47uoriaM3Mx2lmPkW0tJ3FrHloJP53t Uzn57ixz8q5zq3b6ybHEtdBb6jNfa/a5zVNOpxkD+kC08WCWPOMokKsmnqnNI7QQNfAqfadePxmF k9CyrLBdVa9zy3a9pcS4x9B30pWtp491newfc9ux5/Tidb3hwe5X0/5r/9blbJEnw7Ks1++51TG2 WXaksrY55gRr7JVi1w1+Kzcs+nk7wXCW6Fji0yRH0m/1VU5U1I+Tc5kXEeBbZFgcWGm8PHLfRfIn +Tt/lJWl2O0PyK7qWOMNdZU9oJ52gva1ZtNtoe39I/QQPc7QeHKsPste2Hvc8DUBzi4D5OKt8Zag jaUZmJ++f80qQzcT986fySqik3lLjPZPD4toZ2H++7/MKf7fh/vO/wAwqsUp1S9w9grg8W1+0cMf nOn+oVIdSwh3f/mf7VTPCXZH3T2CuDxb/wC1MCI3Wf5n/mSYdUw4/wAJ/mj/AMksiz+c+YUgXPJ2 NLtphxaByjxk9FtB2WdTxnHayu155gNB/wC/In7QYCG/Z75PA2Af9+WES9rzUWuFndvB8ddU7zYz aHNcN+jRPP8A0kuOfh9iqi9Jj25WRW23HwMq2t+rHta3aRJb7XF37zVWPXMdji002S0kES3QjQrD eHsYbHtIYNJkH/qXJFtvp+pshkTMjhHjl2RQd2v6wUPsbWKS0vMB1j2MYPN9jvaxqsM6rU4w12Pz GuS3w3bvbWXbVy7WeqD+kYyOzyQT/V9rludJx6s2n0GFu51cwSAQfoz7vzv5LfejGciatXCOzv8A 1W6o/J639mZUAxtdhtta/c3a3bDme1u9rrPT2Ls/lrzx3/8AOVyH+LvCDa+o5zocdzcWtwkSGfp7 3N3Q73OdR9JdjA8VAchOYHqBTMIgYiO5t//X5G468qjnjRrvAkf6/etPJpcCSBpys/MbNRB0gz9/ tVLAfVH+W7dzC4y/ls0GGHD4qzKrisk+0jTxMflRNr9dB/nBXKagNM1IHhCDH+A/zmp9j/AeP02o Uq0rk0qJa7wH+e1N6b/Bv+e1LhKeJJOiU6KGx/g3/PakGOJgbJPA3tKXCVcSJ38781f6PT1I15Nu LRTZW0xa+5rHBmjnbmutezZ7FSFbjYBoSTEDXXhEbiNcGue8NfElpY6Wn90/1U4LUnTXZ37TJw3V nIDXNDrGtLS0Dc4xkexu1jFDNyMq7OrtusabWkEODGgN2n2tbW39Ht9qc4jD9Kyf+tuKX2dka2O/ 7bKNH+RQ3LqOo9XqrsycyjbucGeo6qmNff8Ao2j6HtVDIycl2K3DfeX00EtqYGt2jUhxa9o3+7c/ 3Jn49A1LzPia/wDahlrOBaP8w/8AkkipHPvIEBXmVFuP6xjawga86z7x/VhUnw1wcx4e4QDpt/8A Ol0GDg5WTijp7Qy45FjanPa1wsAsLNrvpOZ6dTvf9CvYjEAg30CrIIrq939U8T7H9X8Nj9LL2Oyb D33Xn1Nf+s+mtPTmdY2/wlDYWjYGiGN9rR4NHsb/ANFqJDeNeZ+XKq9b8bbNaV4U/wD/0Mt9DSPj JQ7emY9r9r2h06HlXS2TA54/FPaTW8PaBMkw7v2WWLGzp+biu+reM53tL2z2BkfihH6uY5dpYS0a OMjn7lrlr3mXS6RqCfH/AKLVKGsYGwPuP+cpfcmP0ix+3D90OIfq/SebHCAA4mIA4bw1IdAoggWO g+7t27/RW00NkCPa3UjmSpNZLmhw9zjJ00hL3sn7xV7UP3Q5Nf1YrDN7rHAk7QdDqRqPolQP1bpB ne4iTEkDQc9l0FjhDZmBMAadkFzBt00I4Eaaoe9k/eKvax/uhxj9W6nQfUcdNZI4AjwRKegYzXjV xaDugu7j876K1g1ocYOgHMeSQpmSRu+SXvZP3in2sf7ocr9j4QJPpDSDJLjyk7peJtHsH+cZ5Wma zDjA57k9krGQA3yjk8pcc/3j9quCP7o+xyWdNxoJNTeQO/8AFR/Z2N7x6TdI7cdlqNq9gHPfXxTU 0E2uBEyPyFIzlrqftVwx7D7HDswKmyfTb4cKdPT63wwtaCYgwOT/AOZLWfjSHGCToR3RMbHGgcNP hoQiMku6jCPYOWeiPfRfVWwGxzHemIH0h7mhv9ZWfqdmZbur4+O2h1jg5ottbLRVW1rmWG9pb/1d la6XDx2tgxqAACtmgu9P3EkGDE9wpsWSQBG/Ew5McSQdqWrJ2kceXwRfU7f2kJg1OsciOfFEg+Hb xTlP/9n/7SQuUGhvdG9zaG9wIDMuMAA4QklNBAQAAAAAACscAgAAAgACHAJ4AB9PTFlNUFVTIERJ R0lUQUwgQ0FNRVJBICAgICAgICAgADhCSU0EJQAAAAAAEFjF/OEct7ZnftlrakWDgDo4QklNA+0A AAAAABAASAAAAAEAAQBIAAAAAQABOEJJTQQmAAAAAAAOAAAAAAAAAAAAAD+AAAA4QklNBA0AAAAA AAQAAAAeOEJJTQQZAAAAAAAEAAAAHjhCSU0D8wAAAAAACQAAAAAAAAAAAQA4QklNBAoAAAAAAAEA ADhCSU0nEAAAAAAACgABAAAAAAAAAAI4QklNA/UAAAAAAEgAL2ZmAAEAbGZmAAYAAAAAAAEAL2Zm AAEAoZmaAAYAAAAAAAEAMgAAAAEAWgAAAAYAAAAAAAEANQAAAAEALQAAAAYAAAAAAAE4QklNA/gA AAAAAHAAAP////////////////////////////8D6AAAAAD///////////////////////////// A+gAAAAA/////////////////////////////wPoAAAAAP////////////////////////////8D 6AAAOEJJTQQIAAAAAAAQAAAAAQAAAkAAAAJAAAAAADhCSU0EHgAAAAAABAAAAAA4QklNBBoAAAAA A0UAAAAGAAAAAAAAAAAAAAXUAAAFqAAAAAgAUAA3ADEAMAAwADAAMAA5AAAAAQAAAAAAAAAAAAAA AAAAAAAAAAABAAAAAAAAAAAAAAWoAAAF1AAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAA AAAAABAAAAABAAAAAAAAbnVsbAAAAAIAAAAGYm91bmRzT2JqYwAAAAEAAAAAAABSY3QxAAAABAAA AABUb3AgbG9uZwAAAAAAAAAATGVmdGxvbmcAAAAAAAAAAEJ0b21sb25nAAAF1AAAAABSZ2h0bG9u ZwAABagAAAAGc2xpY2VzVmxMcwAAAAFPYmpjAAAAAQAAAAAABXNsaWNlAAAAEgAAAAdzbGljZUlE bG9uZwAAAAAAAAAHZ3JvdXBJRGxvbmcAAAAAAAAABm9yaWdpbmVudW0AAAAMRVNsaWNlT3JpZ2lu AAAADWF1dG9HZW5lcmF0ZWQAAAAAVHlwZWVudW0AAAAKRVNsaWNlVHlwZQAAAABJbWcgAAAABmJv dW5kc09iamMAAAABAAAAAAAAUmN0MQAAAAQAAAAAVG9wIGxvbmcAAAAAAAAAAExlZnRsb25nAAAA AAAAAABCdG9tbG9uZwAABdQAAAAAUmdodGxvbmcAAAWoAAAAA3VybFRFWFQAAAABAAAAAAAAbnVs bFRFWFQAAAABAAAAAAAATXNnZVRFWFQAAAABAAAAAAAGYWx0VGFnVEVYVAAAAAEAAAAAAA5jZWxs VGV4dElzSFRNTGJvb2wBAAAACGNlbGxUZXh0VEVYVAAAAAEAAAAAAAlob3J6QWxpZ25lbnVtAAAA D0VTbGljZUhvcnpBbGlnbgAAAAdkZWZhdWx0AAAACXZlcnRBbGlnbmVudW0AAAAPRVNsaWNlVmVy dEFsaWduAAAAB2RlZmF1bHQAAAALYmdDb2xvclR5cGVlbnVtAAAAEUVTbGljZUJHQ29sb3JUeXBl AAAAAE5vbmUAAAAJdG9wT3V0c2V0bG9uZwAAAAAAAAAKbGVmdE91dHNldGxvbmcAAAAAAAAADGJv dHRvbU91dHNldGxvbmcAAAAAAAAAC3JpZ2h0T3V0c2V0bG9uZwAAAAAAOEJJTQQoAAAAAAAMAAAA AT/wAAAAAAAAOEJJTQQUAAAAAAAEAAAAAThCSU0EDAAAAAAeQwAAAAEAAACbAAAAoAAAAdQAASSA AAAeJwAYAAH/2P/gABBKRklGAAECAQBIAEgAAP/tAAxBZG9iZV9DTQAB/+4ADkFkb2JlAGSAAAAA Af/bAIQADAgICAkIDAkJDBELCgsRFQ8MDA8VGBMTFRMTGBEMDAwMDAwRDAwMDAwMDAwMDAwMDAwM DAwMDAwMDAwMDAwMDAENCwsNDg0QDg4QFA4ODhQUDg4ODhQRDAwMDAwREQwMDAwMDBEMDAwMDAwM DAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgAoACbAwEiAAIRAQMRAf/dAAQACv/EAT8AAAEFAQEB AQEBAAAAAAAAAAMAAQIEBQYHCAkKCwEAAQUBAQEBAQEAAAAAAAAAAQACAwQFBgcICQoLEAABBAED AgQCBQcGCAUDDDMBAAIRAwQhEjEFQVFhEyJxgTIGFJGhsUIjJBVSwWIzNHKC0UMHJZJT8OHxY3M1 FqKygyZEk1RkRcKjdDYX0lXiZfKzhMPTdePzRieUpIW0lcTU5PSltcXV5fVWZnaGlqa2xtbm9jdH V2d3h5ent8fX5/cRAAICAQIEBAMEBQYHBwYFNQEAAhEDITESBEFRYXEiEwUygZEUobFCI8FS0fAz JGLhcoKSQ1MVY3M08SUGFqKygwcmNcLSRJNUoxdkRVU2dGXi8rOEw9N14/NGlKSFtJXE1OT0pbXF 1eX1VmZ2hpamtsbW5vYnN0dXZ3eHl6e3x//aAAwDAQACEQMRAD8Azp0TEpp0TElY7qLkylP4KCPg 0HLzcfFkj17GsLhyAfpO/ssSiDIgDcmvtUTQJPRhuKlOi3rug9Nre5rRa4NJAJs5jvoxCPSunj/B 2f8Abh/8irR5HL3j9v8AYwjmsfj9jiylK1H4XTm/4J5/647+5CdRhAeykk6aOucNO/5qH3LL3j/z v+9V96x+LRlKVe+z4R/wDv8At16kMbC/0Lv+3Xf3JfcsveP2n/vUfesfj9jQnVSBWkzD6efpVub5 +o4/wTnE6WON0/13f+RS+5ZO8ftP/ep+9Y/H7HNJk/cn7q5bTgMMhjnf9dI/9FqvZbgViTU/5W/+ okDyeQdY/ar71j8fsRp5hEtrrOFjZ1O4V5DrK31uIdssqI9m8NZu9Sp7LfooAKgnEwkYlljISFjZ JOqkHIW78U+5NSmDhBKUoYOiW5G1P//Qyd2gKYlDrdNTT4gfkUtyx3UXLitf6qUet1lru1FVtv8A 0fSb/wCfVjbhx3XSfU+KMTqvUXDSmoVg/Ky+z/qK1PykeLNDwN/4rDzM+HDM+Ff43pdPLreLHlp0 n8oDlm5DrwTAcQyC8xoA76G7+sruMKb8DGsyGte+yttj26QXWMZY/wDlbtz1S6n0nBvwr6mY1duV dU6ih1haJc5p9Bpsf7WObb6fpWf4Ja0jqXPA0alnqH80obWZDnhrGOL3aNaBJJ/khcp/zS6o3Q4D p2h3utaJB+iQXbd25DHRrcO+u3Ioaxtd76XtGQwHfXSMvay1hZ9JllWx9dv6T+Zr/SJtpp612T6T Wvttrra5zmAvsY07mR6rNr3Ndur3s3Jv2hh/9yaP+3q//Jrm35H1Y9aj0ekvsoya3MDL7z6tdgOz 1m3VBvq+wfzN36NZTqa2mPsvdwEtfrtMJHa1dae6d1DELSBkUz/x1f8A6UVM5bCSRkUHXtdV/wCl FyeLiuzMurBx8Nr8i94rraWvGp/Od/IZ9Ox67qnpv1BopZVmHOyn1tcDYKGBr21ktfZW1rH2+lp/ pUI6kgdrUWh61ljbHtcywVN3vLLGO2tlrN7tj3e3e9jFWtLnNFhOhkgd9Fr3dA+oWXhh3TbcnGyb LG141t9Dyw2Wh32djvTqr2s3s3+o5/8A0Fy2O3KswOpUvgWYUW7XuYx3ff7Hu3vd9D+b9TYos0J0 K6r8co3q9D0wG2vNxhJmkX1/18cut/6eK/Kao7o4VToWfZi3U5Ouxnputb2exux9lT/3t6u5eP8A ZMu7FncKHljHeLP8E/8A65VssVLPH0xl/gn9jbwS+aP+EGO7VPKHIlOHKszpd2gToYPHknlFT//R 5+t0MLf3XOb9xKluQQYstH8qfvAKluWRTqJJXR0l2N9Q8x7TD8z1o89xbh1/+e3rmHPgEngCSus6 pV6PRumdMPL3YbHjzcW5N3/Se5Xfh8fXKX7sT/zmnz5/VCP70ohrdZtdTmurYfZUyuusfyWMbW3/ AKhN07KeRa6yWBrNzbBB2ln6XdtPvb9H6dfvUesuyH4dTcEVHIaPfZcXbA0y9+z0f5bnfS/R+mq7 ag/Cua+wh/pSTXoDw6xzGuO51O7/AKtW5D12xiQ4CL2TPOaMj04NW1+x9pJ9usPs2/S/lKv1qrHd 0e3LjbVj9QezdcWEj1cfFaxxqcz6b6v3fT+zqrmYuATft6jkuvrHvx3VxXp7f0Nrbne+r/i0DNId 9XWYryHtf1O1z3PkEuqxsBjWu/tWpsTV0AtzxsREge+rR6UKTb6TyfTNJG9onWdzLH/1o+muhwMS m7pzWPsLW0kMuZoHMZvew+s7XY+76Hrf6RczgV2OyGWtvLDuvBqayGBtRr9jRu9L9K2x/wCZ+i9P /CLee/Fq9QNa9te/aXiGhw3ut2O19/pz7P3FKalADUVbUzkiUDw8fg3ug+3rdIaGg3Mtraxpe4je 0XenW5zne38z0/3P/BCZ/wBXfrJVbZe3p9llL7Hljm5G1w3Oc5r3tsyKNm5rv3FXDbsiaGtvF22G ix7axoxu17PT/Ss2foshnp/6Gn/QUq6br+nMsyG25ALnPO+q20ANJY2vcw2ua727LPa308f/AAX8 6oYxlCcpD5pARrdnlkjw10iejmnpn1jrqFTcK7FoY9jw597QxrqyRVY1zLrXbWbvpNauatfQ/qzr 76Bl0t/SXVhwBsgua7ZbU2lnu/nN+33/APCLoepdXychtdHrvyRcweoy62wkujj065raz/C/RXP5 /qWZLbHsdWXjbuEhrjH82z95n/CJGczIcdeC6NEXHzbdnUOmvyWM6bW6uktmxjtPdLRtaNz/AOUt vNeLsbCzG/n1HGt/4zF21tn+vhW4a5Cs7AH6w1xDSAI1BLff+cup6c/7T0fLo5dSK86of1D9ly// AADJrt/9BVDlhcJAf3h5s+KdTiT19KPdqnDpKDu1Ug5UablpS/slu/KhApbkKTb/AP/SyXU45G4V jc4AEnv4d1TvhplgDR2Cv3gAEN1drEeZ2ArNtdNh7wSfu9qyQ6i1FduXl0YjD/SLa6eP33Nr/wC/ Lr/rPkuPVKXY7Q01PuyAH6tb6TPTY+yI/Rb3rC+qlDX/AFgw3uBPol+S4H/gWPtb/wCCemtrKfW/ quS62v1W101VanQG95se4j872VbVp8lEDHI9yB/iud8QkeOAH6IlP+CHomP9Zsn1TV0nprW0uFRs 6g23aHvDbPTpo3XObva+t/rWV/zf+EWWx+V9uvp6nhV9Prqc+myugvLN3qUNdVXaLLXbfa9y6Orr GViPtoxB+zmWO3VkOD/Uc1uyvc64O+j+j/r1fq6wc6zFuyLsm5jqnOvqc5zT7n2vL7X/AExt/wAD /N/+CKYm5fxYCIiFdxuB3a+XhYbHfaMW0Nhj/UNnrHbBa/1fWyaaq7Xbd7NuNa9R2UD6tMuvsa8V dTvAZaN26WYVb79+7b+j2/8AgqWV1XENeRiXMuZvY5jHtez02S1zWv2lm/Y3d++moyrMLo+LbQfb +0M9ocQNpAGFsbZuDv3N/wDYUcdCT4ebLlIkdAPIekNbplFNvVatpoZS0m4HLl+PLoPp5G76WPbs 9N60rsXK6hkZIqqaKm2S9llrtzXu91tTbGz6rKXfo2Pe73rHwKn5tLnYVdjsoNsbZkAhu6RFxfY5 380+t/6Sr+X6fp2LqeksLcrNrPZzHHjksa6fZLfduT5z9Gg1B/NiERLLjif62x1+SbKtnVKnTWyp 4ZArNj3FwDRsrl/t3OqYNm7/AAiX7IzLMV9v2LHrDD6bbg46l3vurdu+m53877f8ItVrApHd9H80 TtBPE+AUXGetM55bGRw6+d6uO7pVjq2VmpkMZsIbAadG7fb/ACNm1ixeu9F6qzAsvsdWaccBx2E7 zP6JztfzPfucu0ZMcKOVjNysS7Fs0ryK31OcIlosaWb2/wApm7emcIJBN+k2GWI4BIR/SjwnX6vm GXn3hv2N9ddTntDXEPadCNNjdNu5dF9V8rEx7aftLBbQ9opeZ9vp2luPlOf++37K7IZ/xi6dmDjY OM/pNOJQMVgeNj2Cx1jQXb33Ou2vtst2Nfvb7P8ARrkMXDoxsy3EDYrZYWsZM7WWA3VNa+Xez2XM +kquHnceS+GBj1Fniv8AR1QcUtNXqLujdNqtNTsZu6tzq36v+k07Od6GemdLAJ9Bvt7kv/8AJ/ur Qss+0U0ZR1ORU11n/GM/Vr/859Xqf21FrQXa/ROhHw/8xQJo1Q+zo2o6xBaY6T0ySPQbJ49zv/Jq P7KwefsmkT9J39X9/wDeVuHBze7gdsR4/wC5E9McbREzx2+lKN76D7FU/wD/08rIdsLzx3I8gPZ/ 5NZ1O2SHAOkQBPirmc6W9xpx8VnB1osbtIJBBEg9llxGhdO3p/qhVOV1HIj+ZoFQP8q57R/56osR agy2/Oe90evkGpmjSG+gxrW2v3uZ7WWqz9TqAOkZN4GuVlNafhTXJ/8ABMlVej5Lzg25Htb6OVdU DHd7nvtc8OPu/MWryorDEecnI57jlmIhV0Ia/wCNND1U5ThtxnV32tPtddox7Z2vbvbY59te/wBP ZX/g/wDCKv8AZ3ODfttAtPqtJa15hj2s9tm+t36Ta7f/ADi0M7IF97rbHDc5obO6WgiXbw1uyvf6 jt6BRfXRjNvLPWvmxwhxAa9gZs9tYd9Jn0/3/V9T8xOq5dqC2jCAO9Vua3/7j91xMrExzbk2e31L NHbw+shrob+lrbuctOvp+TZ0LZh1F4OZnuDnAkMqLsWH7g17vdj1P22KjlYNH6awucLr3Nt3Bgpc 5zvfHDf3vz6/etTEf17H6GbeleqcfHzeoNzragIFbXUlvqhp3bdvq/Q+gmDQknamQeoRA1JLg/aL qn1XUWgsDB7ZO2w/4Qbfa61jv5f5i1vqlk235+cy55seGNJc4yfa41t/6G1qxH1vea7KazFMtDDt aIEaT+Y539X3rQ+plrD9Y85rN2x+PIDwA4EOrncGusb/AJr0ZGMsYrf8eEr4xMZgEUYkg/3vle1a 1TDB3UmiQpNb3UQDPawZpomLJ+JREiJSICgXK619Yuj0ZZws3N9D9FW65jWFx3Eeoxhe017Pbts+ l+4uUyur9NyerziZDrx6QHqPbsJNT/WqH8pzKXZTPUT/AF86Xk2daqvxKH3uyMUPsFTS4g0OdQ9x a3/gvQXP4mHk4vVsVuZQ+pr7RX7wQCXTXo/6DvpfvKpHkMUOLJGUrIlLhuPDxH/B4v8AnqGWXEI0 KsD6PpPRslmT0++gEOdiWC0A967x6Ng/s300/wDbqsvI3B7WlvBjngfvLC+q7nV9VpqcIqzGPxXk 8A2AOpP9nLroXQADVpA1Gp/h/ZcjOFCJHUfky4paEHoWDg4k+YDh2Oh50RN9ccn6O/jzTBoAaQNW 6R5HT+CnsMRGvH9mZhNo0V/V/9TDzTLHDnWJ+CosIDpVnLf73AeJVKwgNcRzrHxWZEaOm+i/V6lt P1f6e0yHWNsyOP8AS2OLf/A2VrnumNwGdNfZlAuORlXXMBqDmhhcWN9Ox/0tzv5zauwfWzCwmUy7 9Qxms2n6I9Opnqbf7Vaw6MLp1mL0rGy23ANZWyyysQxrnNfbdve4e5/83t9n/CeotkR4cUf6ocPJ lJzyox9RPDchGzfyuVkW9MkgUNO2eK2iY/8AOkStvT2dJsO2G3G4Ufo4G/X6TQd385/JUM2nHorf XU1pFT7dnqkHcx1h9Dc5vp7rttW32OVa+uxlIAaaWMts2h24tBn3bNrfd+l3/mpkYyJsjQrp5SYi v3vy9J/xZIcbEz8ttTTluN2P9Gutjdp9w2S619Wxm36Hp+p6fvV2r60u6N9Wr+iZFTcj9pPz67Lq 7AWV7wz/AAjPUZkPq+0Wb/Qt9L/hFTxWNbY197i9jSJIhzv+NrDq2Na+v/BqXTcW7HwaaLaS19b7 3PbYwQ4uPqfZ6rLGvb+mo/wjN/0/0iXBRScwG2tEf87+881Vl20OfVTc4MJDm17N+pG7e2t3v+j+ etb6k2j/AJxOO5zy+ixrnOEaywx/0V0TOj9bzsRrem4d9j8UtrN4dTWwms7b6qr3bLXt+lU930FH of1S+teF109Sy+j7qC2xppGTS0+4Qx3qNue/d7Wb3qEXKxw8Isxvv/WbUhGPARMTuMZ6fo8W8P8A BejY9EY5sc6qtlftqvEybLvq67FqrY8i+jOF1rIBLbm0N2+pt/0a5nonUeq5Da8jJ6jc5nrsqto3 V7vSfs/T17/0v0Xfzvoej/wiRHDVnwTGXEaAey3N8UtzZ8Vpf82ah/2vzdP5dX/vOm/5uVjjPzP8 6o/+66dwX1W+6Ozzf1gz8/Dwm24Brrstt9Gy1zQTWx7H2tcwu9rGb8f9Jv8AZ+euIzetdYzcGuvM ZS9mNc28ZABFrjW4tb+d6P53+CrXqmZ9VMfNp+zZPUMt1Rex+0+iRuYd9TnN+zbX7HfmvXm1/Qsy h9Fd7aDQy+zCdWxjhY80n9au31Mspr9jmWOtuux7f+M96BxjTaRtaZkk8NjRtY+RkC9teLrYbAaI 53ucHU/9N1a7LMa195uDYbkNFoaeRvG9zP8Ardvq1pY31Y+r2yu+nGsbLWWVuFtukNb6ZafV+kza 1I1NrZZjsn9SuLGBxJcarmjNoc7duc7ba7Mo/wCtJuTlpQw60eHsrl+cx5cxjHiFi/UKQ1gEkRyN PL/Vynr5fRnlO1uv+vfUIk9tvef4qtWhbvV//9Xmb9XEnXX/AGqfS8T7X1bBxCJ9fIqY74F7d/8A 0EOz8qHjZ2Xg5rMvEeK7qDNbi1roJBbO2wOb9F6o4ImUwO2p8m/lmIRv6DzfTes3ergZxrLt14dW 2Glxm53pN2sHuc79Iq/ULGmn7O/Fy22MYK7S3EfbWC1oa79L7ar2N/e+guKH1u+sntJyx7HNe39F V9Jh3s/wf7wU8764/WPqOM7Ezspt+O8tc+p1NQaSxzbWbtrPo+oxq05zJoRGni5UMRBMpEXtoL0d +vp1mRjY9WRTfYKtotsyKHUONjJ/mtzd/va72Uf4T+Z9OxZPXHjGy7nFgaAXgNBbDg8+wTG785ir dR+t/wBYuqYj8HPym3Y1u0vr9Ktsljm2s9zGB3tsY1Z+XnZOdZ6uY4XWFxs3FrQdziHOcNo9u7al GRA8Vp5e58RlYvir/Fqv8V1sfdVlPZk1VEgEBtjntYHtc12y31a8Z/6Rjn/zanjC6nNN7dtmPjkh 7dpdYGkel63taxn8879H+k/sLLt6p1C+w2W3Fz3AAmAJ2ja36I/dT19Uz6pLLo3Da6WtdLQd207m u+ijMkxIj+JScF5BkPCSP6v5S4nZv+tnUsLpb6Om5d2Hbihx2CqpzDG1zm2G5tlvrMfb7/8ABrMf /jE+ulbax+0txsaCJoo7zB/mVTssfc+19sPdcSbZAhxP0js+j7lF1VVhburafTG1gAiAO3thRCEq 1IZ70AoaOtjf4xfrM31m5uX9qIaQKTj0tBJBa5j7a/Qc1v8ALrWD9Vn2N6g9jtx/VrGt3akbdr9o Mbm/RVuutlTt9bQxxf6hIH5/76lTWym31qmhlkEbxPDhtcP7SUscjEiwmM6INDTtu+5NsFjG2Dh7 Q77xKZztF5Oz61fWRrGsb1G0NYA1oAr0AED/AAamPrR9Yzz1K/8A6A/JWniKw1ej6PmZYqBkrjMm 5t+V13HAb6RrfnkBoDg8VNyaL3fv/pMTLo/9CPf+jWQ/rnWrtLc65/xcP4BBbkX732Gx2+2s02Pn V1R3bqXn86v3v9iJgSY1WhtIIAPjo979X8ht3SquZqLmEDWADvZ/0HtSzG7OpMInZnY76TpzdjH7 dit/t47uoriaM3Mx2lmPkW0tJ3FrHloJP53tUzn57ixz8q5zq3b6ybHEtdBb6jNfa/a5zVNOpxkD +kC08WCWPOMokKsmnqnNI7QQNfAqfadePxmFk9CyrLBdVa9zy3a9pcS4x9B30pWtp491newfc9ux 5/Tidb3hwe5X0/5r/9blbJEnw7Ks1++51TG2WXaksrY55gRr7JVi1w1+Kzcs+nk7wXCW6Fji0yRH 0m/1VU5U1I+Tc5kXEeBbZFgcWGm8PHLfRfIn+Tt/lJWl2O0PyK7qWOMNdZU9oJ52gva1ZtNtoe39 I/QQPc7QeHKsPste2Hvc8DUBzi4D5OKt8ZagjaUZmJ++f80qQzcT986fySqik3lLjPZPD4toZ2H+ +7/MKf7fh/vO/wAwqsUp1S9w9grg8W1+0cMfnOn+oVIdSwh3f/mf7VTPCXZH3T2CuDxb/wC1MCI3 Wf5n/mSYdUw4/wAJ/mj/AMksiz+c+YUgXPJ2NLtphxaByjxk9FtB2WdTxnHayu155gNB/wC/In7Q YCG/Z75PA2Af9+WES9rzUWuFndvB8ddU7zYzaHNcN+jRPP8A0kuOfh9iqi9Jj25WRW23HwMq2t+r Hta3aRJb7XF37zVWPXMdji002S0kES3QjQrDeHsYbHtIYNJkH/qXJFtvp+pshkTMjhHjl2RQd2v6 wUPsbWKS0vMB1j2MYPN9jvaxqsM6rU4w12PzGuS3w3bvbWXbVy7WeqD+kYyOzyQT/V9rludJx6s2 n0GFu51cwSAQfoz7vzv5LfejGciatXCOzv8A1W6o/J639mZUAxtdhtta/c3a3bDme1u9rrPT2Ls/ lrzx3/8AOVyH+LvCDa+o5zocdzcWtwkSGfp73N3Q73OdR9JdjA8VAchOYHqBTMIgYiO5t//X5G46 8qjnjRrvAkf6/etPJpcCSBpys/MbNRB0gz9/tVLAfVH+W7dzC4y/ls0GGHD4qzKrisk+0jTxMflR Nr9dB/nBXKagNM1IHhCDH+A/zmp9j/AeP02oUq0rk0qJa7wH+e1N6b/Bv+e1LhKeJJOiU6KGx/g3 /PakGOJgbJPA3tKXCVcSJ38781f6PT1I15NuLRTZW0xa+5rHBmjnbmutezZ7FSFbjYBoSTEDXXhE biNcGue8NfElpY6Wn90/1U4LUnTXZ37TJw3VnIDXNDrGtLS0Dc4xkexu1jFDNyMq7OrtusabWkEO DGgN2n2tbW39Ht9qc4jD9Kyf+tuKX2dka2O/7bKNH+RQ3LqOo9XqrsycyjbucGeo6qmNff8Ao2j6 HtVDIycl2K3DfeX00EtqYGt2jUhxa9o3+7c/3Jn49A1LzPia/wDahlrOBaP8w/8AkkipHPvIEBXm VFuP6xjawga86z7x/VhUnw1wcx4e4QDpt/8AOl0GDg5WTijp7Qy45FjanPa1wsAsLNrvpOZ6dTvf 9CvYjEAg30CrIIrq939U8T7H9X8Nj9LL2OybD33Xn1Nf+s+mtPTmdY2/wlDYWjYGiGN9rR4NHsb/ ANFqJDeNeZ+XKq9b8bbNaV4U/wD/0Mt9DSPjJQ7emY9r9r2h06HlXS2TA54/FPaTW8PaBMkw7v2W WLGzp+biu+reM53tL2z2BkfihH6uY5dpYS0aOMjn7lrlr3mXS6RqCfH/AKLVKGsYGwPuP+cpfcmP 0ix+3D90OIfq/SebHCAA4mIA4bw1IdAoggWOg+7t27/RW00NkCPa3UjmSpNZLmhw9zjJ00hL3sn7 xV7UP3Q5Nf1YrDN7rHAk7QdDqRqPolQP1bpBne4iTEkDQc9l0FjhDZmBMAadkFzBt00I4Eaaoe9k /eKvax/uhxj9W6nQfUcdNZI4AjwRKegYzXjVxaDugu7j876K1g1ocYOgHMeSQpmSRu+SXvZP3in2 sf7ocr9j4QJPpDSDJLjyk7peJtHsH+cZ5WmazDjA57k9krGQA3yjk8pcc/3j9quCP7o+xyWdNxoJ NTeQO/8AFR/Z2N7x6TdI7cdlqNq9gHPfXxTU0E2uBEyPyFIzlrqftVwx7D7HDswKmyfTb4cKdPT6 3wwtaCYgwOT/AOZLWfjSHGCToR3RMbHGgcNPhoQiMku6jCPYOWeiPfRfVWwGxzHemIH0h7mhv9ZW fqdmZbur4+O2h1jg5ottbLRVW1rmWG9pb/1dla6XDx2tgxqAACtmgu9P3EkGDE9wpsWSQBG/Ew5M cSQdqWrJ2kceXwRfU7f2kJg1OsciOfFEg+HbxTlP/9kAOEJJTQQhAAAAAABTAAAAAQEAAAAPAEEA ZABvAGIAZQAgAFAAaABvAHQAbwBzAGgAbwBwAAAAEgBBAGQAbwBiAGUAIABQAGgAbwB0AG8AcwBo AG8AcAAgAEMAUwAAAAEAOEJJTQQGAAAAAAAH//8AAAABAQD/4R7maHR0cDovL25zLmFkb2JlLmNv bS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6 a2M5ZCc/Pgo8eDp4bXBtZXRhIHhtbG5zOng9J2Fkb2JlOm5zOm1ldGEvJyB4OnhtcHRrPSdYTVAg dG9vbGtpdCAzLjAtMjgsIGZyYW1ld29yayAxLjYnPgo8cmRmOlJERiB4bWxuczpyZGY9J2h0dHA6 Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMnIHhtbG5zOmlYPSdodHRwOi8v bnMuYWRvYmUuY29tL2lYLzEuMC8nPgoKIDxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSd1dWlk OjJlNWQ2MTFhLWE2NzMtMTFkYy05NzBlLWYwNTY1ZDdlZDU1MicKICB4bWxuczpleGlmPSdodHRw Oi8vbnMuYWRvYmUuY29tL2V4aWYvMS4wLyc+CiAgPGV4aWY6RXhwb3N1cmVUaW1lPjEwLzEwMDwv ZXhpZjpFeHBvc3VyZVRpbWU+CiAgPGV4aWY6Rk51bWJlcj4yOC8xMDwvZXhpZjpGTnVtYmVyPgog IDxleGlmOkV4cG9zdXJlUHJvZ3JhbT41PC9leGlmOkV4cG9zdXJlUHJvZ3JhbT4KICA8ZXhpZjpJ U09TcGVlZFJhdGluZ3M+CiAgIDxyZGY6U2VxPgogICAgPHJkZjpsaT4xMjU8L3JkZjpsaT4KICAg PC9yZGY6U2VxPgogIDwvZXhpZjpJU09TcGVlZFJhdGluZ3M+CiAgPGV4aWY6RXhpZlZlcnNpb24+ MDIyMTwvZXhpZjpFeGlmVmVyc2lvbj4KICA8ZXhpZjpEYXRlVGltZU9yaWdpbmFsPjIwMDctMDct MTBUMTg6MDM6MzMtMDg6MDA8L2V4aWY6RGF0ZVRpbWVPcmlnaW5hbD4KICA8ZXhpZjpEYXRlVGlt ZURpZ2l0aXplZD4yMDA3LTA3LTEwVDE4OjAzOjMzLTA4OjAwPC9leGlmOkRhdGVUaW1lRGlnaXRp emVkPgogIDxleGlmOkNvbXByZXNzZWRCaXRzUGVyUGl4ZWw+NS8xPC9leGlmOkNvbXByZXNzZWRC aXRzUGVyUGl4ZWw+CiAgPGV4aWY6RXhwb3N1cmVCaWFzVmFsdWU+MC8xMDwvZXhpZjpFeHBvc3Vy ZUJpYXNWYWx1ZT4KICA8ZXhpZjpNYXhBcGVydHVyZVZhbHVlPjI5Ny8xMDA8L2V4aWY6TWF4QXBl cnR1cmVWYWx1ZT4KICA8ZXhpZjpNZXRlcmluZ01vZGU+NTwvZXhpZjpNZXRlcmluZ01vZGU+CiAg PGV4aWY6TGlnaHRTb3VyY2U+MDwvZXhpZjpMaWdodFNvdXJjZT4KICA8ZXhpZjpGbGFzaCByZGY6 cGFyc2VUeXBlPSdSZXNvdXJjZSc+CiAgIDxleGlmOkZpcmVkPkZhbHNlPC9leGlmOkZpcmVkPgog ICA8ZXhpZjpSZXR1cm4+MDwvZXhpZjpSZXR1cm4+CiAgIDxleGlmOk1vZGU+MjwvZXhpZjpNb2Rl PgogICA8ZXhpZjpGdW5jdGlvbj5GYWxzZTwvZXhpZjpGdW5jdGlvbj4KICAgPGV4aWY6UmVkRXll TW9kZT5GYWxzZTwvZXhpZjpSZWRFeWVNb2RlPgogIDwvZXhpZjpGbGFzaD4KICA8ZXhpZjpGb2Nh bExlbmd0aD43OS8xMDwvZXhpZjpGb2NhbExlbmd0aD4KICA8ZXhpZjpGbGFzaHBpeFZlcnNpb24+ MDEwMDwvZXhpZjpGbGFzaHBpeFZlcnNpb24+CiAgPGV4aWY6Q29sb3JTcGFjZT4xPC9leGlmOkNv bG9yU3BhY2U+CiAgPGV4aWY6UGl4ZWxYRGltZW5zaW9uPjE0NDg8L2V4aWY6UGl4ZWxYRGltZW5z aW9uPgogIDxleGlmOlBpeGVsWURpbWVuc2lvbj4xNDkyPC9leGlmOlBpeGVsWURpbWVuc2lvbj4K ICA8ZXhpZjpGaWxlU291cmNlPjM8L2V4aWY6RmlsZVNvdXJjZT4KICA8ZXhpZjpTY2VuZVR5cGU+ MTwvZXhpZjpTY2VuZVR5cGU+CiAgPGV4aWY6Q3VzdG9tUmVuZGVyZWQ+MDwvZXhpZjpDdXN0b21S ZW5kZXJlZD4KICA8ZXhpZjpFeHBvc3VyZU1vZGU+MDwvZXhpZjpFeHBvc3VyZU1vZGU+CiAgPGV4 aWY6V2hpdGVCYWxhbmNlPjA8L2V4aWY6V2hpdGVCYWxhbmNlPgogIDxleGlmOkRpZ2l0YWxab29t UmF0aW8+MC8xMDA8L2V4aWY6RGlnaXRhbFpvb21SYXRpbz4KICA8ZXhpZjpTY2VuZUNhcHR1cmVU eXBlPjA8L2V4aWY6U2NlbmVDYXB0dXJlVHlwZT4KICA8ZXhpZjpHYWluQ29udHJvbD4xPC9leGlm OkdhaW5Db250cm9sPgogIDxleGlmOkNvbnRyYXN0PjA8L2V4aWY6Q29udHJhc3Q+CiAgPGV4aWY6 U2F0dXJhdGlvbj4wPC9leGlmOlNhdHVyYXRpb24+CiAgPGV4aWY6U2hhcnBuZXNzPjA8L2V4aWY6 U2hhcnBuZXNzPgogPC9yZGY6RGVzY3JpcHRpb24+CgogPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJv dXQ9J3V1aWQ6MmU1ZDYxMWEtYTY3My0xMWRjLTk3MGUtZjA1NjVkN2VkNTUyJwogIHhtbG5zOnBk Zj0naHR0cDovL25zLmFkb2JlLmNvbS9wZGYvMS4zLyc+CiA8L3JkZjpEZXNjcmlwdGlvbj4KCiA8 cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0ndXVpZDoyZTVkNjExYS1hNjczLTExZGMtOTcwZS1m MDU2NWQ3ZWQ1NTInCiAgeG1sbnM6cGhvdG9zaG9wPSdodHRwOi8vbnMuYWRvYmUuY29tL3Bob3Rv c2hvcC8xLjAvJz4KICA8cGhvdG9zaG9wOkhpc3Rvcnk+PC9waG90b3Nob3A6SGlzdG9yeT4KIDwv cmRmOkRlc2NyaXB0aW9uPgoKIDxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSd1dWlkOjJlNWQ2 MTFhLWE2NzMtMTFkYy05NzBlLWYwNTY1ZDdlZDU1MicKICB4bWxuczp0aWZmPSdodHRwOi8vbnMu YWRvYmUuY29tL3RpZmYvMS4wLyc+CiAgPHRpZmY6TWFrZT5PTFlNUFVTIElNQUdJTkcgQ09SUC48 L3RpZmY6TWFrZT4KICA8dGlmZjpNb2RlbD5DNTVaLEM1NTAwWjwvdGlmZjpNb2RlbD4KICA8dGlm ZjpPcmllbnRhdGlvbj4xPC90aWZmOk9yaWVudGF0aW9uPgogIDx0aWZmOlhSZXNvbHV0aW9uPjcy LzE8L3RpZmY6WFJlc29sdXRpb24+CiAgPHRpZmY6WVJlc29sdXRpb24+NzIvMTwvdGlmZjpZUmVz b2x1dGlvbj4KICA8dGlmZjpSZXNvbHV0aW9uVW5pdD4yPC90aWZmOlJlc29sdXRpb25Vbml0Pgog IDx0aWZmOllDYkNyUG9zaXRpb25pbmc+MjwvdGlmZjpZQ2JDclBvc2l0aW9uaW5nPgogPC9yZGY6 RGVzY3JpcHRpb24+CgogPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9J3V1aWQ6MmU1ZDYxMWEt YTY3My0xMWRjLTk3MGUtZjA1NjVkN2VkNTUyJwogIHhtbG5zOnhhcD0naHR0cDovL25zLmFkb2Jl LmNvbS94YXAvMS4wLyc+CiAgPHhhcDpDcmVhdGVEYXRlPjIwMDctMTItMDlUMDg6MjU6MjItMDg6 MDA8L3hhcDpDcmVhdGVEYXRlPgogIDx4YXA6TW9kaWZ5RGF0ZT4yMDA3LTEyLTA5VDA4OjI1OjIy LTA4OjAwPC94YXA6TW9kaWZ5RGF0ZT4KICA8eGFwOk1ldGFkYXRhRGF0ZT4yMDA3LTEyLTA5VDA4 OjI1OjIyLTA4OjAwPC94YXA6TWV0YWRhdGFEYXRlPgogIDx4YXA6Q3JlYXRvclRvb2w+QWRvYmUg UGhvdG9zaG9wIENTIFdpbmRvd3M8L3hhcDpDcmVhdG9yVG9vbD4KIDwvcmRmOkRlc2NyaXB0aW9u PgoKIDxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSd1dWlkOjJlNWQ2MTFhLWE2NzMtMTFkYy05 NzBlLWYwNTY1ZDdlZDU1MicKICB4bWxuczp4YXBNTT0naHR0cDovL25zLmFkb2JlLmNvbS94YXAv MS4wL21tLyc+CiAgPHhhcE1NOkRvY3VtZW50SUQ+YWRvYmU6ZG9jaWQ6cGhvdG9zaG9wOjJlNWQ2 MTE5LWE2NzMtMTFkYy05NzBlLWYwNTY1ZDdlZDU1MjwveGFwTU06RG9jdW1lbnRJRD4KIDwvcmRm OkRlc2NyaXB0aW9uPgoKIDxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSd1dWlkOjJlNWQ2MTFh LWE2NzMtMTFkYy05NzBlLWYwNTY1ZDdlZDU1MicKICB4bWxuczpkYz0naHR0cDovL3B1cmwub3Jn L2RjL2VsZW1lbnRzLzEuMS8nPgogIDxkYzpmb3JtYXQ+aW1hZ2UvanBlZzwvZGM6Zm9ybWF0Pgog IDxkYzpkZXNjcmlwdGlvbj4KICAgPHJkZjpBbHQ+CiAgICA8cmRmOmxpIHhtbDpsYW5nPSd4LWRl ZmF1bHQnPk9MWU1QVVMgRElHSVRBTCBDQU1FUkEgICAgICAgICA8L3JkZjpsaT4KICAgPC9yZGY6 QWx0PgogIDwvZGM6ZGVzY3JpcHRpb24+CiA8L3JkZjpEZXNjcmlwdGlvbj4KCjwvcmRmOlJERj4K PC94OnhtcG1ldGE+CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAK ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAog ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAo8P3hwYWNrZXQgZW5kPSd3Jz8+/+IMWElDQ19QUk9GSUxFAAEBAAAMSExpbm8CEAAAbW50 clJHQiBYWVogB84AAgAJAAYAMQAAYWNzcE1TRlQAAAAASUVDIHNSR0IAAAAAAAAAAAAAAAAAAPbW AAEAAAAA0y1IUCAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAARY3BydAAAAVAAAAAzZGVzYwAAAYQAAABsd3RwdAAAAfAAAAAUYmtwdAAAAgQAAAAUclhZWgAA AhgAAAAUZ1hZWgAAAiwAAAAUYlhZWgAAAkAAAAAUZG1uZAAAAlQAAABwZG1kZAAAAsQAAACIdnVl ZAAAA0wAAACGdmlldwAAA9QAAAAkbHVtaQAAA/gAAAAUbWVhcwAABAwAAAAkdGVjaAAABDAAAAAM clRSQwAABDwAAAgMZ1RSQwAABDwAAAgMYlRSQwAABDwAAAgMdGV4dAAAAABDb3B5cmlnaHQgKGMp IDE5OTggSGV3bGV0dC1QYWNrYXJkIENvbXBhbnkAAGRlc2MAAAAAAAAAEnNSR0IgSUVDNjE5NjYt Mi4xAAAAAAAAAAAAAAASc1JHQiBJRUM2MTk2Ni0yLjEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFhZWiAAAAAAAADzUQABAAAAARbMWFlaIAAAAAAAAAAA AAAAAAAAAABYWVogAAAAAAAAb6IAADj1AAADkFhZWiAAAAAAAABimQAAt4UAABjaWFlaIAAAAAAA ACSgAAAPhAAAts9kZXNjAAAAAAAAABZJRUMgaHR0cDovL3d3dy5pZWMuY2gAAAAAAAAAAAAAABZJ RUMgaHR0cDovL3d3dy5pZWMuY2gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAZGVzYwAAAAAAAAAuSUVDIDYxOTY2LTIuMSBEZWZhdWx0IFJHQiBjb2xvdXIgc3Bh Y2UgLSBzUkdCAAAAAAAAAAAAAAAuSUVDIDYxOTY2LTIuMSBEZWZhdWx0IFJHQiBjb2xvdXIgc3Bh Y2UgLSBzUkdCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGRlc2MAAAAAAAAALFJlZmVyZW5jZSBWaWV3 aW5nIENvbmRpdGlvbiBpbiBJRUM2MTk2Ni0yLjEAAAAAAAAAAAAAACxSZWZlcmVuY2UgVmlld2lu ZyBDb25kaXRpb24gaW4gSUVDNjE5NjYtMi4xAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB2aWV3 AAAAAAATpP4AFF8uABDPFAAD7cwABBMLAANcngAAAAFYWVogAAAAAABMCVYAUAAAAFcf521lYXMA AAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAKPAAAAAnNpZyAAAAAAQ1JUIGN1cnYAAAAAAAAEAAAA AAUACgAPABQAGQAeACMAKAAtADIANwA7AEAARQBKAE8AVABZAF4AYwBoAG0AcgB3AHwAgQCGAIsA kACVAJoAnwCkAKkArgCyALcAvADBAMYAywDQANUA2wDgAOUA6wDwAPYA+wEBAQcBDQETARkBHwEl ASsBMgE4AT4BRQFMAVIBWQFgAWcBbgF1AXwBgwGLAZIBmgGhAakBsQG5AcEByQHRAdkB4QHpAfIB +gIDAgwCFAIdAiYCLwI4AkECSwJUAl0CZwJxAnoChAKOApgCogKsArYCwQLLAtUC4ALrAvUDAAML AxYDIQMtAzgDQwNPA1oDZgNyA34DigOWA6IDrgO6A8cD0wPgA+wD+QQGBBMEIAQtBDsESARVBGME cQR+BIwEmgSoBLYExATTBOEE8AT+BQ0FHAUrBToFSQVYBWcFdwWGBZYFpgW1BcUF1QXlBfYGBgYW BicGNwZIBlkGagZ7BowGnQavBsAG0QbjBvUHBwcZBysHPQdPB2EHdAeGB5kHrAe/B9IH5Qf4CAsI HwgyCEYIWghuCIIIlgiqCL4I0gjnCPsJEAklCToJTwlkCXkJjwmkCboJzwnlCfsKEQonCj0KVApq CoEKmAquCsUK3ArzCwsLIgs5C1ELaQuAC5gLsAvIC+EL+QwSDCoMQwxcDHUMjgynDMAM2QzzDQ0N Jg1ADVoNdA2ODakNww3eDfgOEw4uDkkOZA5/DpsOtg7SDu4PCQ8lD0EPXg96D5YPsw/PD+wQCRAm EEMQYRB+EJsQuRDXEPURExExEU8RbRGMEaoRyRHoEgcSJhJFEmQShBKjEsMS4xMDEyMTQxNjE4MT pBPFE+UUBhQnFEkUahSLFK0UzhTwFRIVNBVWFXgVmxW9FeAWAxYmFkkWbBaPFrIW1hb6Fx0XQRdl F4kXrhfSF/cYGxhAGGUYihivGNUY+hkgGUUZaxmRGbcZ3RoEGioaURp3Gp4axRrsGxQbOxtjG4ob shvaHAIcKhxSHHscoxzMHPUdHh1HHXAdmR3DHeweFh5AHmoelB6+HukfEx8+H2kflB+/H+ogFSBB IGwgmCDEIPAhHCFIIXUhoSHOIfsiJyJVIoIiryLdIwojOCNmI5QjwiPwJB8kTSR8JKsk2iUJJTgl aCWXJccl9yYnJlcmhya3JugnGCdJJ3onqyfcKA0oPyhxKKIo1CkGKTgpaymdKdAqAio1KmgqmyrP KwIrNitpK50r0SwFLDksbiyiLNctDC1BLXYtqy3hLhYuTC6CLrcu7i8kL1ovkS/HL/4wNTBsMKQw 2zESMUoxgjG6MfIyKjJjMpsy1DMNM0YzfzO4M/E0KzRlNJ402DUTNU01hzXCNf02NzZyNq426Tck N2A3nDfXOBQ4UDiMOMg5BTlCOX85vDn5OjY6dDqyOu87LTtrO6o76DwnPGU8pDzjPSI9YT2hPeA+ ID5gPqA+4D8hP2E/oj/iQCNAZECmQOdBKUFqQaxB7kIwQnJCtUL3QzpDfUPARANER0SKRM5FEkVV RZpF3kYiRmdGq0bwRzVHe0fASAVIS0iRSNdJHUljSalJ8Eo3Sn1KxEsMS1NLmkviTCpMcky6TQJN Sk2TTdxOJU5uTrdPAE9JT5NP3VAnUHFQu1EGUVBRm1HmUjFSfFLHUxNTX1OqU/ZUQlSPVNtVKFV1 VcJWD1ZcVqlW91dEV5JX4FgvWH1Yy1kaWWlZuFoHWlZaplr1W0VblVvlXDVchlzWXSddeF3JXhpe bF69Xw9fYV+zYAVgV2CqYPxhT2GiYfViSWKcYvBjQ2OXY+tkQGSUZOllPWWSZedmPWaSZuhnPWeT Z+loP2iWaOxpQ2maafFqSGqfavdrT2una/9sV2yvbQhtYG25bhJua27Ebx5veG/RcCtwhnDgcTpx lXHwcktypnMBc11zuHQUdHB0zHUodYV14XY+dpt2+HdWd7N4EXhueMx5KnmJeed6RnqlewR7Y3vC fCF8gXzhfUF9oX4BfmJ+wn8jf4R/5YBHgKiBCoFrgc2CMIKSgvSDV4O6hB2EgITjhUeFq4YOhnKG 14c7h5+IBIhpiM6JM4mZif6KZIrKizCLlov8jGOMyo0xjZiN/45mjs6PNo+ekAaQbpDWkT+RqJIR knqS45NNk7aUIJSKlPSVX5XJljSWn5cKl3WX4JhMmLiZJJmQmfyaaJrVm0Kbr5wcnImc951kndKe QJ6unx2fi5/6oGmg2KFHobaiJqKWowajdqPmpFakx6U4pammGqaLpv2nbqfgqFKoxKk3qamqHKqP qwKrdavprFys0K1ErbiuLa6hrxavi7AAsHWw6rFgsdayS7LCszizrrQltJy1E7WKtgG2ebbwt2i3 4LhZuNG5SrnCuju6tbsuu6e8IbybvRW9j74KvoS+/796v/XAcMDswWfB48JfwtvDWMPUxFHEzsVL xcjGRsbDx0HHv8g9yLzJOsm5yjjKt8s2y7bMNcy1zTXNtc42zrbPN8+40DnQutE80b7SP9LB00TT xtRJ1MvVTtXR1lXW2Ndc1+DYZNjo2WzZ8dp22vvbgNwF3IrdEN2W3hzeot8p36/gNuC94UThzOJT 4tvjY+Pr5HPk/OWE5g3mlucf56noMui86Ubp0Opb6uXrcOv77IbtEe2c7ijutO9A78zwWPDl8XLx //KM8xnzp/Q09ML1UPXe9m32+/eK+Bn4qPk4+cf6V/rn+3f8B/yY/Sn9uv5L/tz/bf///+4ADkFk b2JlAGSAAAAAAf/bAIQAEg4OFhAWIxUVIywiGyIsJxwcHBwnIhcXFxcXIhEMDAwMDAwRDAwMDAwM DAwMDAwMDAwMDAwMDAwMDAwMDAwMDAEUFhYdGR0iGBgiFA4ODhQUDg4ODhQRDAwMDAwREQwMDAwM DBEMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgF1AWoAwEiAAIRAQMRAf/dAAQAW//E AT8AAAEFAQEBAQEBAAAAAAAAAAMAAQIEBQYHCAkKCwEAAQUBAQEBAQEAAAAAAAAAAQACAwQFBgcI CQoLEAABBAEDAgQCBQcGCAUDDDMBAAIRAwQhEjEFQVFhEyJxgTIGFJGhsUIjJBVSwWIzNHKC0UMH JZJT8OHxY3M1FqKygyZEk1RkRcKjdDYX0lXiZfKzhMPTdePzRieUpIW0lcTU5PSltcXV5fVWZnaG lqa2xtbm9jdHV2d3h5ent8fX5/cRAAICAQIEBAMEBQYHBwYFNQEAAhEDITESBEFRYXEiEwUygZEU obFCI8FS0fAzJGLhcoKSQ1MVY3M08SUGFqKygwcmNcLSRJNUoxdkRVU2dGXi8rOEw9N14/NGlKSF tJXE1OT0pbXF1eX1VmZ2hpamtsbW5vYnN0dXZ3eHl6e3x//aAAwDAQACEQMRAD8AqJBNKcLPbqko STpKUE0JwkUlLJASlCQSUskpEaSmSUrlNCdJFSimTymQUvKZPCiQkleYSCYaJxqkhkkmlJBKkkyS KFJJJJKUAkdEuNUiklRUU6SQUoJymiE4KSFBSUU/CSVkk5CZJCk6in5SUuEoTJyklQTgpkklLlN3 TpklLhJIJpSUum80kgkpRSiEkpSUukUydJC6R4SCR4SUx4TpJBBKkySSKlwpFQKeUFKSTJHRFSgn CZJJTJRlPKRSUsn4TFKZQUpJKUklLpk4KZJS8p4lROqUwkpdKEydFSyUJKSCmKeEgUkVKTEp0nJK WhJJIJIXCUpEpQlSVJBJMkpefFIpQkkpZIJ4TBJC8apRCaU6SV0xCQTpKVEJpTlMkpScKKdJC6Y8 J0kkqCUJgnKCF4TJJFFKwUlFPCClJ1GdVJFCuEkyeYQSy7JglKTUVKKdIiU6SFuygiHhQKCVgnCY JSipc6JJJFJSpSOiSR1SUumSTpKWKSdMkpQ0SSSSUo6p0kxSUyTFOEu6SlkjqkUklLJ4hIaJSkpU Jk5MJJKWhOkkUFLSnKSZFC4TlMEkkqKflMkElLkJk8ykEkLQpJgnKSVgnhKEySFJJcJJKUEikmSU uFKVEJJKZFRCeEoSUrukUk6Slkk6cFFSwSTppSUpOkmSUqNVJME6SlkkkuUkLlME5TAJJXKcJpSh JSkyRTcpFS4TqJTpKXKSZJJT/9Cmn4TcJ1nt1XKcaKKdJTKUxTFKUlLhJRkpIqXlJMnhJSyeUxTg IKUkUkySlSkkSmCSlEwnCSSSlJJk4KClFJIpkUskkwS0hBSkkgm4RUpOmCSSlcJJFMElMk8pkpSU uU3dOmlJCxSSSBSKmSSYFJBKgnlMEyKGSRCQKRSSsn5TJJKXSSCSSlJBJIJKXhJNKcFJS6XZIJ0k MOUkgeyUpJXCZJJBSk0QnTpKWSKRTIqX+KRSSlBSuySRTJKXhKEwPZOTKSlQmSlPHdJSkkkkVKlP CjwnlJSkp8EuUuElL8pkgmPMpKXSTpklLppSJSAlJCkoSSJSUpOmCfhJKpSTJ0lKlJMnSUoFMQkE /KSlkkkkkKUgoqQSSopk5UUkKiU6YpykpdN3SSSSocpyUyXdFC6dMnPCCWITlMFJJTEKSZOUlKCR SCUpKXKQS5TJIZykNVFOCkpTuFCVNxQ0krpJ06CmKdJJJSkuEk8hFShqExUpgKCSlwlKSSSlFJMn GqSlSn5TEJklLp0k0JIXlJR1UgElLgJvgkkklSRTBJBSgnSSKKlkkk8JIUnTFJJKk8Qm4SSQpIpQ nSUpIJk6SlFLukUwKSlymKflNEpJUkmlSSQpJMnCSmUJk5TJKWGqko906SlFIJinCSl0pSTFFS4U lAKSSlJJJJIWTpinSSolOExTpKUNU7lEJ3IoWKQKUKJQSuU6ZOgpcJKKSKn/0acJcJBOs9urJ0kk VKTEJ0wKSlJFPCRGiSlk8wo8KUoKWlOCmKSSl5SKQTcpJWThIBI6IoXKZJIIKUlCSUwklSRSJSSp Sk0pJIKUnKZOipadExKdwUYQUyCXCSRRUpOop5SQyUeE6aElKSSCROqSV4KZIlJJS6ZP3TSkhcJy mSlJKyR5SBTlJSgmSBgpykpdIJk4SUopBMVLskpYGFIqKcHRJTEpJ/JMgpdNwnTSkpdJMkkpRSSC XCKl0ycJcoKVCbhJKUlLpkgkfFJS8SkmkKSSluEpSTIqXTJRBTpKWThMnSUudEk3KQSUpJOkgpZJ M5JFC6SSWoQSpJME/wAEVKS5SKaEkLpJFJJKk44SSSUskn7KKSGXKQKQKbukpcyknATJJUQmCdMk pdIpBMkpdJJLlJCpTymhOklYcqUKITpKUkSm7pykpdMn7JgkpccpJJBJC6aU6YpKZPEBQUnmVFJK iU4KSYoKVMp0yQSUpOmToqVymlP8E3KSlykkUgkpUJcJ0wSUo6pwEyfskpXdMUu6RQUulCZOEVKK aU5TAJKX5SCXdJJSkkpSSQpJME6SlSkExT8JKUkkOE8JKWSSSGqSlQU8JlIpKWTdk6ZFSglKXkkg pZydvCSdJKyclRTpKXS7pJSkhSchKUiUlKTpkkgpdRmFJNEpKUnTJFFTJJMkUlLEqQUVIJIXSCaJ TpJXHKi46pwokykpdMkkgpSdNynSUrhJJJJT/9KmkkEoWe3VJ03xUgUlLJQkUpRUpKUyRSUvCZJJ BSuEimlJJS6adU8pJKWlKUkkVLhNEJHROglZIlJJJSpSlMU4SQukkfNIJJYqQUSJThJCkxTn8Ekl KTJymQSt8E6cpkVMgkmCSSFkk/ZMkpdJJJIKUUwKc+CaUkrpJQl2SUrukUk5SUxTlJOkpSdMkElK TpikkhcJwVFSCSWMJApEwkgpSSdMipdJMnQUslCSZFS6cFLhKUlKhNCRSSUopBJJBS0qQKaE/CJU opinKaElMlFIiEglSFwkQmSSSuE5UQU5SQpJMpJJYpBJOkhQ1SS45UZKKWSSQSCCFJAJEJJJXSTJ ykpSSZKUlLgpuEkj4pKUkE0p0kLpJkklLpDlJMipSSdMglXxTpk6SFSlKXdIoqUE/dME5CCVk6ZP 2SUpJOUklLJ0k4SUqUxSTkJBCz9EwKk/VQ4SSyKSYJzqgpSYJ0kULSnCSSSVQknlRSUpLhJJJSgU 5S4CQKSlBKU8JiEFK80kk6KlJJk6SFJkphJJSk6YJ0lLSknIUQkpcJylwlykpZIlOdE3KSlSlKZO kpfkpJpSlJS8pJJBJS51TJxokSkpaU6inSUsnBTQkkpdPCZIJKXiEykVFJK/dSUQnSQsSkmTpKXJ ThRTgpKUSmSSlJTJNKSZFS6cJFMElM0lGU8pKXUZhOOFFC1L8pJJuUlLgpymCSIUqUkySCn/06cp 1FIFZ5bq6dMklSl0ikmRUpJMpcoKWlI6ppTpKUkkkkpRS7JJSkpYpJQnSUqU0J0xSUsnCYpApKX5 TJSlygldKUwShFC/ZJMkUlKlKUkkErpJSkipSZOmSQumSToqUEySdBSwTpoSSUukEuEgkpQThRUh wklZJJOipYpwVEpwgpkmlJMUVLpwmTSgpdSGiiVIJbKYpBMeUklLhIFLySSUpI6JJeaSlkk6ZJSk 6eEySlJk6ZJS6ZOUySmSUpkikpdNKUpu6SFykUil5pKUknJSKSWKkNUyQSQpIpJIqUnhI+aSSlJk k8oKUEikOU54lFKySUpkkLp00pJKXjRNKUpJUpSScpgglUJJFMihdSKiFJBSyYpJIqXASTBSCSmM JwEim7JKXhJOmKSVwkVEKSRUspKCkkhSdMnSUsQnBhJIoKUE6YJ/NFSz+VFScZTBBKoSShKZSUpO mCcFJCkkgl5pKWKfhMU/KClSmhPwkilUJoTpJKXHCZJJJSkyeEgEkKITpJJKUkmlJJSlIJkikpUp gkkkpRTzASTBJS/KQ0TJykpZMU5UZRUuCkkB4pygpcapJgnSUpI8JJJKWSSTpbKVKZJIpKUnBTJw UlLkpkkklKlSUU/CSlkuU6SKlaJJpThAKUmhSTJKUEyeEiipQUlEeKcFBSk6YKQSUrtCh3UniEyS lcpSklEJKXSTJ0VLFJIlJBT/AP/UpQkdEuU6z26sCnlKISSUpMU5SRUoFIpoTlJSikm4SPkgpcJE pkySl0uEydJSydMn+KSl0iopJKXCZJJJSxSS7JQkpdKUgmSUvCblOmSUpOkkkpSQKSQSSpJOUxSC lJ00ykkhdJJKISpSk3dJOipRSlJJJSxTgpJJUpSSSZKlLpBNKdKlLpikAlCVKXJTJ0uEqUpOCmSA SoqWPKeUyeJSpKoSTpuEqUpMNE8JyEqUtKaE6QSpSkgJTQnCVKVoUydNCVKUU41TJcJUhdNKceKY JUldMlPgkEqQuUySQSpSuUkk4CVKV2SCRSRpSgkUuEihRUtynlIJRqipdNKlCjCVKW5TpaJJKUEi klCFKWTymSRpS/KkPBMAn7oUpbuknhIpUpiknhIFGlKSKQTnhCipZIJ0yWqlJwm7qXCVKWKQSKXC VKX4TJk4SUop00p0FLFPwmKdFS6UJBJJSgkkOUggpQTwmCkElIyNU/CXdJJKikEiklSlymSSRQqE iU8JJJWSSTBBS5SBTpJIUmSSRUygJkkoSUukUwKSSlSnSKigpcJymTHVJS5SlJJJS0p0ydJSkoST ApWpdI6JkiUlKShIqQCSlkykQmSUpIeCSYJKZApFIJJKUdEyYpAJKXhMNVIphoEEqSTpJKWUuFEp 0UKTlME5KSlkkycpKUkEuyQSUyTaJ+FE8pKZJinBTEpKUkmSSUyBUghqQSUuTJTJp1TlK1LSnSCf RJS3KdMOUu6SloSTpJKf/9WmExThKFnt1QKSZOkpUpJQmSUuEimSSUpJJMkpdIpk6SlJinSSUtKS QCeElLJk8pJKWKcJk6SlJ1EKUoKWSSSRStwnTSnQQsSkkUyKl06Yp0lKlJMnSUsFIqMJ0VLpJk4S GqlQiV1OfwtXAxGXN94VujFrrfDVaji6liOSnMb0q1wmFMdIeVt23OY3a1UvUee6l9sMXuFo/shx T/sd57q56j/FL1Hjul7YV7haf7Hd4p/2O7xVr1X+KRtf4pcAV7hav7Gd4hIdGd4qz6r/ABTerZ4p cAV7hQ/sZ3il+xj4o3rWeKXrWeKXAFe4UI6O4d0/7GPiEX1n+Kb1bPFLhCvcKP8AY899U7ej+al6 jz3Teo/xS4QrjKv2N3lL9j+af1X/ALyb1X+KXCFe4VfsbzSHRh4peq/xKXqv8UuEK4yr9jD95I9G B7pvUf4lN6j/ABS4QrjLP9jeaX7FH7yH6j/3il6tn7xS4QjjKQdGHil+xhxKF6j/AN4peo/94pcI 7K4ym/Yw8U37GH7yD6ln7xSNj/3ijwhXuSTfsUeKf9jNPdVzY/8AeKb1H/vFLhHZXHJs/sYeKb9i jxVf1bP3il6r/wB4ocIV7hbH7FHin/Yw8VV9Wz94peq/94pcIV7hbX7Gb4pv2M3xVY3WfvFL13/v FLhCvcLaHRx4qP7JYDBKpnJeOXpxc92u5Cop45Nz9kM8U/7HZ2Kp+rYPzil6r/3ijQRxybv7HaeS kejNPdUvUefzim9Wz94pUFccm9+xW+KX7GbHKo+rZ+8UvVs/eKVBXHJvfsYfvJv2K0/nKj6ln7xS 9Sz94pUFccm/+xR4pj0QeKperZ+8U/rWfvFKh2Vxybn7FH7yb9jDxVT1rP3il6tn7xS4Qr3JNv8A YzR3S/Yo8VV9az94petZ+8UuEK9wtr9ij95L9ix3VX1X/vFOLrP3ilwhXuSbP7G80v2L/KVf17R+ cUhfb+8lwhXuFs/sXzTfsQ/vKv69v7xS9e394pcIV7kmx+xCO6f9hnxVcZFv7xTjIu/eS4Yq9ySY 9Ejul+xfPRC+0XfvFP69v7yXDFXuSTHooHdN+xh4oXr2/vJ/Xt/eKXCFe5JkeinsU37FPim9a395 P61v7yXCFe4VHoh8Uv2K7xCXq2/vFL1rf3kuAK9wrfsR3in/AGM/xCXr3fvJfaLv3kuCKvcKx6M/ xS/Yz/FP9ou/eS+1X/vIcEU+4Vv2PZ4hN+x7PFS+1X/vJfbL/wB5Lgir3CxPR7PFIdIs8VL7Zf8A vJ/tt47hLgir3Cw/ZFgTfsm3yRPt+R4hL9oX+IS4Iq9wof2RcmPSLUb9o5A7hI9TvHglwRV7pQ/s m0BIdJuHZG/aeRHZR/amQPBDgir3SjPSrlIdItPkp/tXI8kj1W/yS4Ip90oT0u0FP+yrT2Rf2rf4 BN+1sjwCXtxV7pQ/su4dkj0u7wR/2tf5JftW/wAkvbir3S1/2Zd4Jj02791Wf2vf4BP+2Lh2CXtx V7pav7Ov7tTDp9w/NKuDrVvdoTjrdn7iXtxV7paP2C790pfYrv3Vf/bjv3Ev24f3EPbir3S532K4 fmlP9jtH5q0P27H+DTHrg/0aXtxT7rmuqe3kIRBC1qOsi6xrHsG1xhWeo9PrcN1QgppxA7LhlefS AV2zp9jBJ4VPhV5QMWUG1cJjonTEymJUkkNEikpZOkEikpRKYJJxogpQCfhNwkklclJMkEkMlEqS iipcJ5TBIpKWThJwTJKZSmcUmpklLynTcpklLylKScJJXhMkkTCSFk6ZLskpclIJgkkpeUuUuEkl LpikkkpflIpJFJKycJoT9kkKTylKYoJVKeUw1SRQuSopQnAlJSkkkkFP/9akpKISVBurpQmCeUFK TJymhJSkkgE6SlkvNIpJKVCSUpSkpSZOmKSlBOCmhLhFSjomTlJBSkySdJSkkySClEppPZOmRUyl MEoSASUpIpJJKWThJJJSk6SZJKxTgpJJIXUmhQGqNS2XBPhqUHZ6HAZtrlWKRLiVGgbakSjQErQD TkdUVxmVVCsv1lVwnLApMnTILmKRTpigpZMU6ZJSkydMglSZJOkpZJJJJSySdMkpRTJ0ySlJJFMk pZJMkSkpSUpkxKSF5TSmlKUlLpk0ppSUvKSjKSCl0pTSmSUvKDeSwfFEKsDGGZTtb/ON1hCQJGi6 NXq5Kk1xbqOU7qnMMOGqlVUXnRVBGQLa0psgyJThROgjwSCthqndlKaUwTyihUpJgkUkLpApJ0lK TpkuUlLpFJJJSkwTpJKUnTJJKXSSSSUukEkklLhOmTyklcJ1FOkpknCiFKUkMoTgKMqQKSl4S2pb ktySlbUtqW5LckpW1NtT7kwckpfao7VLcm3JKY7U21T3BNKSmBakWqZKYlJKMhRIRUxSUiIUEUqK CkaYqRTQkpYpJJklKKUpJklKlKUiVElJS8piU0piUlMpTSokqJcgpcuQ3vTFygU0ldTMO2AO8DK6 5jvXoa4dwuRj2wuh6Ff6lJrPLU6JWlPZ76/wWBazY4g+K6TZ9JvzWHn17X7vFNyiwzYi1Ew1SJTc KkzrpFNMpJJUE5TJFJCk4EJkikpcpJBKZQSumKUpIoXBTJQnSUtwkmTxokpdME6bhJSpTJxylCRS qUgkkkpflIJJBBSkimGpTlFCyeUyUpKUEk6SClFIJFMipkkEwTpKXSCYlOElKShOkdElMSkklykl QTpQkkhcqMpFLskpdJMkkp//16MJ00pLPbq6dNynSUpMnUZSUqU6blOkpZOkE0JKXS5SSRUsClMp JIKUkkkkpSYpwmKSlBOmhJJSkkinSUskknQUsE6ZOilZMnKYJIUnTFJJSvJOEycJKUmOicpklLhW 8Js2AKoFp9LZLwVNiHqWT2d13trAU2CK5Q7+AER+lavBqFrIARxqgdynLQpMnTFNSskkmSSpMnTI KWTJ0kkrQmTmUkFKTJJJKUmKSRSUslKZJJSlFIpklKKaUiUySFSmSTEpKUlKZMSkpdNKSaUlLpEq KSSlyUkxSCSlKVdjqnb2GCopJKbT+per/OMBPiguvngQhpIJBPdkfd8VFJPCKFkkgnCSlBIpJJKU kkE6SldkkkklLpFIJFJSkkkyCl0kydJS6SZOkpScJkpSSySTJJKXKdMlKCmQSUQnlJTKU8qCUoqZ bktyhKaUkJC5NuQyU0oqS70tyDKeUFJNyW9ClKUVJdyW9DKaUlJdyW5DlNuQUl3ptyEXJSkpIXKB KhKYlBLMlMoymJSUylMSoylKSl5TEppTSkpeU0ppTSkpclRlMSoSgUsi5QJTEqJKbaVyVFJJNSkO i0eh3enkbDw9ZpU6rTTYywdinA6oOz2Fo2PDux0Wb1Or2khalhFlYcO4lV8hm+v4hSSFhUDReYkJ J3ja4jzTLPkKLbCgnTJIJUnUZSSQvCcJkgkpeEpTOSSUuE40TJSkpRSlJMkpRClOiikkpkmThMSk pQSSSlJKySdIJBS5TBOmJSKlBOUkkELBNynSSUukEgmlFS6YJyUwQUuEikkipf4p1FSSUoFOdUgU xOqSlFJIlMkpdN5pSnQUtKXkmCcoqX7JJkklP//QoKSYEJyFnt1SSZPKSlJJJikpQSSlIpKUE6SU pKWSTpikpUpBMUklLlKZSlNwkpUwkdUikCkpeFFTlRhJSkk6RSUrhMU6igldI6pJIoUNEkkkFLJJ d0iipSeUySSmUpkgkkpYLd6PX3WGOV0vSmbWK1hHViyHRuWv2mO6G9ziNU2Ro9qd40VsBqlgFXPK sBV3fSKJQFJk6ZNSskkU0pKXTJSkklSZIpkFLpkpTSgldMU0pSkpSYpSmJSUpMlKaUlKJTFMSmJR QpNKRUUlLppSlMkhUpkkxSSuUySaUFKKSYlJJS6UpkpSUunUU6Sl0oTKUpKVCcBJJFS8JoThSSUw TwlKSSlQnSlKUlKhNwnTJKUkkmQQukmSQSvKZJJJS6SSSCV0pTJJKXTpkklLykklKSlwmJSTFJSp SlRKYkpKZEppUSVElFTIlKVCU0oqZyluUJTEpISbk+5ClPKSUhKeUKU8oISSmlR3JSEVLlNKaVGU lLkpKJKaUEs9yYlRlIlBS8pk0pEpKXlMmlRSUvMJpTEqJKaSlclQJSJUZQKVEpkySZaWSQ5TJ28p Wlm7VRePbCkOUinBBelw+r4tVDWWTIEFGxMhmaxzq/ogwFy9rvYAtH6s3Q91R4PCeJXosqkfUKfT tPgVVBW31mj2h/gsNVs0aLbgbC6ZOmlQrlFIJJBJTIJJAJklLlMnSSSoEJFIaJJIVKSSdIKYwknT JKXlMnSSUseUk/KZJKoTpJkFMkyUpBFCk6ZOkpZIBJOgpaUkykEVKSCRSlJSydNKdJSlLhMnOqSl xqmKccKMpKVMp0yUpKUkUkySlJJApDxSUvCSSSSn/9GhqnlIFKFnt1SdMkkpSUpJJKUmSSStS4KS YpSkpccJJSkUlKTfFJIFJSk5STFJS3wSTcKSKlJ1FOCgpfhKUyUwkpUpJpTpKUkkEklLSnKZKUlK S5SSSUpIJinSUqUk6UIqZsEkLq8JsVhcvit3PHxXW0DayFdxDRr5SgyfpD4qb/oqGT2PmiHVqsNZ AOEB+jkcFAt+kkVBjKUpJk1csUydMkpUppSKaUlLylKikglUpSmJTJKXlMSokqJKSmW5IlQlIlJS 8p5UEpSUuSmJSJTJIUU0pSmKSlyVFOU0pKVKYpJklLlMkUyCVymSSKSlSmlKUkkLynUZTpJXCeVG UiUlMw5KVCUkVM9ycOQ5TgpKZkppUZhIpKZAp9ygE8oKZSkCopBJTIFKU06pJKXJSSSQUumSSQUu EkwSSSyTJpTpKXSTSnSUukmSSUumTpkFLFRKcqJRUtKjKRKYlFSxMpSokpiUVMpTzohylKSmcpSo ymQUzBTyoSkCkpISmlQlKUlMpTSoylKSmW5KVAmUpQUzTJpTSkpeUxTEpSgleU0pimlC1UtKaUxj soyU0lIXJTFMSmKaSldIpkkEspTt1KZSYkFLnRNMlIpDkI2pe4+1F6fb6FzH+BQLzonA9sBGJ1RI aPa51QtqMdwuSiDB7Lq+nXDKxWu7gbSudz6vSvcOxRyxuNr8R6NYJingplTZ1gpFMEikpdMnCSSl wYTJFJJS6ZOkkpSSdRCSl0xTkppSUumlPCiUlLgpd0gmmEkskpTJJIXSSTQgpdP2UVKUVLJ0ySSl oTjRJJJSpSTFPxokpSdRHKkkpdJMnCSl5hRUnBMkpUpkglKSlxomTEpwkpSQSShJSoSSSSpL/9LP ClKhKks9urzqkmhOElKCaE6SSlkkpSOqSlJQkE6KlkkpToKWTcp+UklKTJym4SUohJJJJSkhoknK SVJinTHVJCySSYpWpdPKZJJS6ZIFOkpRSSKSSlEpApJkVLpwmlSARCm705m6yV07dGhYHSmSZW+d Ffxig1Mh1a+UPb81MasTZI9idmrFKwhAOUK7lGHKHeNQkkIUxUoTFNSwTEqRCYhBTFNKltTQkliU 0qRCjCClEpinhMipiUxKcqJSUsmJTJSkpUp1CVIJIXKZJMipcpkkyClJk6ZJSyScpklLFJJMkpdM kmKCVJk6YpKXTpkklKTgpkklKKdRTpKXlIFMnCKlJwVFLskpn5pkzTokgpeU4KZOElMkkySSl06a UpQUukmKZBK6SaUpSUunUZSlJTNJRTgpKXSTSlKSWUpk0pSgpRUCnKgUVLFRKRUSihadEyUqJKKl wnlRlLhJDKUpUSkklkkCoymlJTOU0qJKUoKZSmBUZTAoKSSmCinmElMkxTSk4oJUUyRKaUCUrymK UpuyaSlaUykmTbTTFMnSTSpZJOkhaVwpMUJRGaBIKpZOOUkm6FOUwvPA80VvCDbq8DsjDwRCC7v1 bu1fSfiE/W6IIsHwWb0q/wBDLYeztCun6nR6tTh5SpgOKNLImpPJJvNNxokqMhRpuBcJQmCdNUsl +VOUklKTlMkUlKCRTSkSkpeUgmKQSUul8E09k6SmSieUlFJK8pJ0ySlJ0wTykpdMnTJBS4CUpBMk hSdMnSUsnTKQSUslCR8kklKTpgpQkpbhSaoqTUlLEpkncpAJJUkkkkhZIpuVKElKlIlKEu6SlBJJ JJT/AP/TzQpBRCnKzy3V0iEySSl0ySSQUpMn5SSUsknTFJSgnSCSSlJJ0ySlJikUklKCSSQKSlJJ J0EsZTSpFRhFC6UJJBBSwEJ0kk5SkkinCSlkkkglSl0ikmSUuFIKIU2amE6O6C73SGQ0FaruYVPp zNrR8Fadq5aEdmnPdjeJYU1P0B8FO0e0oVJ9oT2PqwjVQyBoEUD3JsoeyUkhqpJBPCalhCYqcKJC CWJTJ4TIKYpk5TJJWKYp1AlFDEpiUnFQJSQsU3KeUxSSspSoylKSGRTJiU0pKXSlRlNKSmaaVGUp SSyKZMSmmUlLpSmlNOqCmSZNKZJTJMmlJJTIpKJKeUlKSCcJ0VMSnSKZBS6SZTa0lFTAJFENZ8FA tMapKYypAwmgp9pQUvKUphonLYSUqU4cowlCVKZbk+5QISgoKZbktyingopXBTSltKRaUKUvKUpt pSDUqUvKcFQgqUJUpeUtyjBTwlSl9yW5RgpQUqUqVEuTwUxYUqUwlMVLYUxYSkpgUxU3MKbYUVMQ kVL0ym2lJC3ZJPsKRYUksClKlsKRYkpZRUoTQe6ClkwKkWpg08oKVKXmngp41QStymKnt7qBEIFL ElKUnJpTSleUgoEqbSmlK8JQiNaFLamlcEMKMI8BQITU0iSlScEMlJC5KKwe1BKL+aEVLpN1TJ2n xRQiJmxHCA0+8o4TghcmIcO2q7bGu+047XxyIXFDzXR/V3J31OpP5pkKWB6MctDbjZlXpXOb5qut frtG14sHfQrHVbLGpNuBsLpJJKFcqU6aEh4JJWS7JJwEULQknhMgpcGUkgnhJKjomSKSSFJk8Jkk skxKedFEmUlMpTJgJToKXSSlKUUKCZJJJS6SZOkpSeUxSSUopwmCRSUupcKISlJS5KkoqXARUxTS kkgplGkqKeeyYpKVCcJpSlJTJNCcpklKlJIpJKf/1M0HspKDTKmFnt1SkFFPKSlzomS5TcJKXhMn lRJSUuklKblJS/dJIpJKXTcp+yZJSkkk0JKX5TJBOElKSSSSUslykkkpSSeUySlwUxSSSUslKdMi pSdMCnSUumSSQUui47dzwPNBVzAZusCmxjVbI6PTYwhqLCVQhiJt0lXw0pbo3/RKq47parT/AKKo 0O1I80VnVsR7lHKPsTzqqeVcIISSpuqJCFQN7ZGqmHhNXrwokKTrA0eKCctv7pQtTIhRIUPtQ/dK b7W390oJZEKMKTcitw10Pmm9Rh7pKUW6IDytShtL2kP0KysiGuIGoTqQSjJTtEoRcJVv1aMcDefc eEkI/RKY1kLTgkAgaEKnmZDcZs2d+E1LTLSltKF+16x+YUh1hn7hQtWiXYSo7Cm/bNXdhlN+2a/9 GUbUy2OS2FN+26/9EVH9t1j/AAZStTPYfBINKh+22f6Mpx1xn+jKVpZbCm2HwUf22z/Rpfttv+jS tGjLYUthUf22wc1pDrTD/g0lMjWU2wpndbYP8Gm/bjf9FqgrRlsKRrco/txvepI9baf8GjadF9hT 7CoHrTefTUf2wP8ARoWjRM1pRfRdEqoOtjk1repDram2gQCipyHVkIZK1L72YfvuEtPZV+pX4drG 24zhJ+kzuiEaDRpNcJ1VynIx2Pa2ZJWHddAkKpTmena18TBmE3ql7p9QcYDVnZN9OM7bboSnP1j9 4e1nbhYHWep/a7xYBtgRCJVbqjqeKDqFL9qYfgVzH2ohL7UfBBT056lieBSHVMQdiuY+1HwS+1Hw StWr0/7Tw/NMOpYvmuY+1HwS+1HsErU9OOp4fcFL9p4fcFcz9qPgm+1HwStWr056lidwUv2pidgV zH2spfanJKeq/aWKexUf2nieBXL/AGopfanJK1en/auIOQU46lieBXL/AGpyf7WfBJWr1H7TxPAp DqeGexXMfa/JR+1u8ElavUHqWJ2BSHUsPwK5f7U7wT/aikrV6f8AaWJ4FP8AtLE81y/2s+CQyz4J K1eoHUsPvKR6jh+a5j7Y7wTfbD4JK1eo/aOH5pv2hhjxXMfaz4JfayOySnp/2hh+aX2/COq5j7Wf BL7X5JKen+34XiYT/bsLxK5f7WfBP9r8kkvUDOwfFL7bhdyuX+1+SX2seCSnqDmYP7yX2rA/eXL/ AGodwl9qB7JKemOTg9nJfacGdHaLmftQ8EvtLT2SVq9Qb8Hu5R+04P765n7S3wS+0t8EFWXphfgn 85R9bFLgGv1JgLm/tTfBSrymtsY+PouDikq3rn4cfmnVVji1kHe4NcPzT3Wjb1+mxojwXMdbz/Xv DhoISTaV4gwoFAovLxBPCKSoiuXUq2klDmU/qdgmpbYACZwceFOoNYyXfehvyW/miUxex2u7pQ7u oOyY7If25reWlKlbJCEIozMqqwwNChWN2OM8IbKWJRUEFE3apIZuTjQKDipEkBOUiq1cSjhAo7nz R05ampYbHBoV/pNn2bMDTw72oPSWepfHgE3UJx8jcNCDuUsRpayWr0XWKPUpd5arlBxqu2BGRSHd nBcdk1+la5nmm5hYtlxHSkaZOmKqM6pjhMnKZvKClwJT8JcKKSmUpQop5SSsCpBRhPOiSFEpJkkl LpFIaJEpJWlMeU6ZJC6dMkkldJJNCSmQCcpgU5SQxTpk4QUumhIlMipcFJME6SlJBJIJKXCc8JgE 5SUtKSUJBJKxSThMkhdJIlIJJUn4SSlJCkk4KSCn/9XLZBCIg1nRFWeW8unUU6SF0kkySl0ySaUl LwkkkgpSSQSSUumSSlFSkkkySlJ00p0lKShMkkpSSUJ0lLFJJMUVL8JSkkkpSZPEpIKWSCUJQihk EyUp0krLV6TXLiVlhb/R6varGEasUzo650ajSPT80NwlLUCFcaZ3YuOizKnRY4ea0n8LH3xaQktG 7fLlgZmSfU2eJWxYZCoO6Lba8XToEeidy6vTmbQI7hVbBD3DzV7F9hAPZBvpBsJB5TSyNIoZCtnG dPioOxXDlMpLVKGVc+zawnt6fZW3fEtSq1W5pCgOVcqFYeN+re8IuRj45sBqdDfA9kqTbJ79tU+S yC8kythzW2N2Eqv+z6gNXJ3RaQ5L7SOFm3ZTnGPBdFbgUxEkKq7pFDBLphBFJGdYudU1ruwWd1Xq Nl+0HstXC6LTku2McT80a76uVVOiyfigSEiJLyf2lyb7U5dHmdDobU5zCQ4CQVypSSm+1OKX2pyB CW1BSX7U5P8AaXoMJQkpN9qcm+0uQoShJSX7S9L7Q5C2poSUm+0vS+0uQoS2pKS/aXJfaXIUJw1J SX7U9N9pehFqaElJvtLwn+0uQNqeElJvtDlsYvWLmUioukDhYQBS1HCKHV6j1B97ACdAZVP1/UIM Q4KrqeVJvKSqbVryWqpB5VguACZpB0hBKwzLR4IL3usMu5Wm3pz3NlrSq1lBr+k0hO4Shpp4Rd7R 2SMO4TUohISJlE2poSUjhJEhKISUjSRISDUlI0kUthNCSkcJQiQlCSkYCSJCUJKRpQihsp/TKSkK SMKym9MpKRJQjbClsMwkpDCSLtJ7Jbe6SkSsY+MbgTMAIcI1Lg2I57pKbP7LG4DeIPdL9kkkje2B x/KUhdHKl6x7AwngIaZwLAdAoHDt8FqM3OaXgaDlNXb6jg1vJS4VW5ZxbB2UTjvHZbFrjS7Y8QUn uNUbhEocKXG9F3gm9N3gtj1WlPvb5JUi3F2HwS2HwW1LTzCkx+2dsaoUlwi0poW7ILSyBBUTSx0E tCNKcSE61nYNZJOo8FXdhgd0KUi+3WbQ3TRAtudaZcVdbj1jQ6lQuxA0bhwhSmGGeVc3KpQQ3QIr nQmEJBSPsjQJMeKvcdSgNdJkqL37ihSbbBtsyHe7jwV6rDe4TwFDBayob3qy/qJv0qEAKKR6Bkj4 sfsDe7tUG3p3gVI2O5lBsyba9RqELK7RpXUuqMFOy8n2uV0XtyW7XCHLPe3aYTx6t/mWEVqGxvhE a6VTedJRqXSEDGlW2JlEcfahhStPsKClqPoooKHVo1EanIdj6tsL8l57Bqbr+12Ttb2GqB0nObg5 G9/0HCHIeXkDJvfa36JPtlSg+lZ1eh+r9/q43pnlh/BZvXKfTtD+xS6BkenklnZ4Wp1vH9Skkct1 RPqimBqVPL6SkU3KdUTo21k8Ql3TE6oUpRMpkkklKThJKCkpRTpk6Slkk41TFJS6iU8JJbqWSSHK dBSkkkhCKVDVOnCZJSkp7JkgkhlKSSSSVjynTJ5SQoJJk6SlpThMnCSlxqUnFO3lRKSl5TJkkkrp wmKSSF0kgkkpeUk0JIqXSSCSCn//1sekyEYKtQrIVCTeZcpBMnKCF0xSSJSUuolOCkkpSQTJBJSk 6UJgkpdMnlNzwkpeEySSSllJMkkpUpfJJJJS6YlLQJJKWTlJJJSkikkipjKlKbzTpKWSlKUpSUun TJwihk3UrqOm17GAHlczS3c8fFdhiM2sBVvCNLYchSE6pEpHlRcVYajCw6LCsdFxWxa7Rc9kWRcQ kVo3dFj9xAVwvdWNv5pWViO3WBaL3EFFkCJxcToYT+m8e6Z8UWtocVYNLGiQdUKXW0CbAdCovfce 8q6WMQyAOEKVbSHrTK2KM61zNljO0SFXZbt7SpPvLxHCVBR1ci3DO6ASNVEYbgZ3ErTTFK1NFlDh 3Rdh8VYBjVSLy7lK0sLrN7AzaDHdAstcWhhb7QrMyj0MY/QmCm0q3PxrvQdLTB8VO627Ij1HTHEC EXIxA0yFWDgDCYY6rgW0CDU4O/dK8/c4Bzm+ZXf2Nih3jBXn+2bDGuqcsO60JI/ppvTSShhKEb00 vSSpSLaSn9MowaQnDSkpBsKbYUcsJS2dklIdqbaj+mQm2FJSEtTKwGHhQ9IpKRJoRvSKb0ykpgyJ 1TPuAMAaIorIVR/KSkzX7uAtPD6a7I5gIfT6Rt3Eaq098GBp8EQhDl9HyMYbi2W+KFR06+5stYSF 0mHZc6v0y7ezzVyqssbtYYHkn+lWry46DlOgbVMdPfi/TEFdOKXj84qvdXbXL53fyXIaJp50ZNlZ lhIVmvqHrjba0OB7pr2tyHbgNp/OVVs1OLRykDrSCOqY9HFr9zG6LTq6OwMH6M7lodBycd1W1x/S d2rVdlCNrWwnGggPKZPTKWNg1lp8VnX9KLW76zuC7UmdXahc51K5td22k+08pDXRJ0ec9IhL0itL KhsOd3VX1W+KZKNKBtr+kR2TekfBWDa3xSD2u76pqUHplN6RVp5DOYUfUZ3KSkHpFP6RCN6jPFL1 W+KKkPpFN6RHKOLWeKXqN8UFIWsc3UKUO5U/Ub4p/VZ4pKYbHEKPpulF9Vvin9ZviEVIzU46pvTd MhG9Vnil6jfFBSEMckGu4Ri9vimNjfFJTXdURqnNZZtd4o1jxtgQZTXaMaElJmgbfNXsbqDaK/T2 TBmYRunfZm0h1o3PJjar7Ok1mwuDS4H81SxFBYS5hz6Tu9hG7sn+00Q1wbBC2B9Wd9m+NrCPoyi/ 802F074b4JXXVWrkX5mLkE7xrHtKgX4du3eTxC3/APmnR+8UZn1YxByCUOMKALy7asIkhTGLhEE7 vkusb9X8Jv5k/Eoo6Nhj/BhLjCaLwmbiV1uHpGWlVRQfFej/ALJxP9G1Mej4h/wYTeIWnV869Eju i42Lbe4hp1XdP6BiO4bHzQD9XWN1qeWn4IghBt5pmDc1wa8aHhyz8jexxbGg0ld9jdNdS3a9249i sjPwMuDsrDhPZPPCUavMZOBdUAW+6ROikaXejOpVjIy8mggOrLSPbqrfQ73ZTzU8AAapoHRNvM1N IJHeVJxR8tnp5FjR4qs4qIiiuXOjVBhlyRfOiiDBQU232FwDewRcRx3FswCqe6TqjUu2vHxTCNF4 OrpFqDkMlqtOao2NDmkKG6ZXLbIMhNaZMog0JagvUg1LGVp9vkiY5kKs92kKxjcIyGiAdW2OUrXm IKTdSIUMg6/NRjdemrPtCmCht4UwUQtZ88qQUQpBPC1JVaabG2D80rt7QL6p/eC4UiRC67ot/r4j Z5b7SpI9lp0NvL2V+m9zD2KGVpdap9O/cOHBZrtVVyRqTbibC/CYpEwko1ygEh5p+yiUFLwnnsmS RUo6pJJBBSgkknlJKySUpSkhYJylCUpKUkEkoSCmQ1STAp5SUxS4TpikpcJ0wKRSUsFIpgnJSUoJ JgkkpScJpSRUzGiiCnTIKXUYTzCdJS3CdMUklLpJJklLpQklKSlJJ+UklP8A/9fDp0VkKrUdVaaq Mt290ZcJBMnTUMkyfsmlJSkxTgpEJKWSCSRSClJJJcpKUkE6ZJSiEyeEyQUvKRSCSSlpSCUJJKXh MpBMUlLppSTIqXSCaUklLpilKSSlkko8UkqQyThRCkEVNrBbusC6+sbWBcx0iubJXUu0CvYxUWtl KNQeVNCepmqWpe7Rc3lPm5b+SYXM5Tv06bJUd3V6cd1gWoR7oKzekiXT5LRs5RDKlYAOFJxQ6tOU VpaPpBFSMlRTnlNKalSSSaUFKSSTIJWKSUpJKUCiVugymFRInt4qL2Fhgoqbdm2wTugrNurAOmqJ CjAQKkfrHY5pPDTouMoIDnF3iuutYTujmCuLIIcfigjq3fUb4pvUZ4qkAXGES/HfQQH99QlaWybW +KQtb3Kq0Y7r37G8qFlbq3ljuRokpuG1vil6rR3QKcV9zHPbqG8qvqlam/6zfFL1m8oD8V7Khcfo lADS4gDukpu+u3xS9dnigZOM/HcA7uJUKaTc/Y3koKbPrs8U/rs8VTsrNbiw8hEpxX3Nc5v5qSk/ rM8UvXaqKPZiubULZ0KSm0y1h7rPt+kYSancwo2p1enPlkK9lYb8Zotd9ArAovNPwWhd1R99Hok6 J1ilvV1emdQZjEttHsPdbteWx+tcQuJZedvuEwp/aax9GR80217292WQJkBVm3NukMO4+C5IZLT9 In5lX8PqIx4NI908lOjqdUHR0s7FZj0usf7H8gLmDl77JdoCtTrWRZkAGw6/9Fc6WlpgoyNFaLLr 073n9GfcNdCrLerZVem/71ggkcaKQeZ5R4u6iHoG5WXmHaX6FXqqMTABdku3uPZcxW90RJClMnUk /FSxIYyCmzT9qsIpB2/mtWYQWktPIWhU8ssBHKp3GXuceSVDk3ZI7KZU97XPaJDeUNrjyrmM8srf t7hUwBCjXJbWWbBY76J7oWp4Vy17jjtYeJVVsSElKtrfUQH6SEq63Wu2N1JVjNebHAu7CFDFdtsB HISUgc1zXFruQp11PsBI7J7zuscfEo2K8tY+OCISU1AZUzS8V+pHtKhoFae8+gGniUlNTVTex1ZA d3TDlHy3bi2ewSUgaC4wOUvcDBRMf+cEcprTLyfNBTEFxmOyQcSNUWke1xCHAAhJTc6b06zPtFbO O5XdY31VxGsAsJeVifVgenWXERJ5XY4lu7RNE/VSa0QYvQ8TFMtbJ8XLRDQOE6UhSWtUko+o3xTh wKCV0kpTbgkpdJNuCW4eKSl0k24J5SUpJKUklKSSSSUjux6727bGhw81hnoAw7vtGLx+dWugSThI hBFvlOcHDIsLhBJlVHL0nq/TsVzXZNtW4j6W1cwLei26QWFI0dVbaPMlRK1c7BpHvxn7m+HdZJTE swURpVcGEas6JFTvMcHMB8kpCn0vp9mTQbSQGN/eQWvxy4guJA7tVbewzDZpXth/xQcgBjZWjfRj 2Nmizc4fmHRyxr3OmHdk+GqJInGVaoOipnlWaTopJbMYb1Z1lQt+kpU6qLzL1CN2TonCk1DlTaQi EFIFMIYKmFIFqQLZ+rl+y19J4cJasYBGxLfQvZZ4HVEHVEtnd67Rvq3DlpXOAzqu0ymC2sjs4LjH s2S3iDCZmGls2I6MSZ+CcJgnCrMypTJJ0FKBlJyZJJS7UyQKQSUvynUQnlJS3CQSKUJKXSTTCQSt S6dMkEkrwmhJKEkKHikUkySmbQmlIcJJKUITlRTpKUEkkyKlJwkmSUzKinKQ1QUrlJIJ0lLJk8JJ KXCZPKZJSohOEilCSlSkmSSU/wD/0MFujlbaVTOj/mrTeFRk3UidRCdNUvKY6pJApKUE6iSkSkpd MkmCSmSSbhIaJKXlMnTEpKUkkmSUuE6ZJJSp1SSTpKVKZJI6JKUVFOkipUpBME6BUoaJ0kkQpUJk 6YIoXT6pgnGqIFlTvdErn3LdsWd0ivbWCr79StCI0aeQsTwhPRXIFhhSBrSOrm5bolcvku/Syuiz HRK5vIPvTJL4PU9Dx/UY4jkK1U81vLXKv0BxFTjx5o+33FztZTqZLZcnRScCOUF426go7HhzNUCp GUgYTFROiba5m9wOoEKEppSQtS6SZOEFKTKdbPUMTCgQQYSUoExE6JkiklaVKDiRwpFVzYO6VqTD 2AuAkkQuX/YeXa5zmMMEkhddjMF0SYadNy1a8b7Id7DLe4TxXVYXzOzp2RU/a9hBVrIwsnJ2ksJg Quj+seQ59lfotMjl6z/tOcI9MIUoG3Gqw8jHfu2kEIV+PbZY5xaZK6E5ee4e4BQOVnM5Y0pEJcXG bbW1waCJEFVPRd+6V0BzssT+jAV/pmWXNP2qqSPolNKRq8y/1DjhhB2yqza3AjQrtfWqOoAAPYpv VrOhDfuQtPC8jmFzy3cOAoYwe14LQdy7B1lRMFrSfgreBXQ90vDWgJwpRFPBXtc57iQZnVTx3FrX bfmu5z78cWfomtI8YXOdXLN+4AAuHZDRDz8rqukdFZnUAvdAn6K5Xau/+rRH2Vp7oxWSNPMdf6Uz ptzWVmQ4Sslw0XTfXHXIZ8Fztg0CRRA2LXx8V+Q7a3Uq/kfV/Kxq/Vc07eSrX1bv9Gxzmjc8cNV7 rdvUchm5xir85oRoUus28yDohlTnSFApi5kzlW8eRLh2VNpV7EftJHjonRUjzMp2QQIgBV8trmuG /mFoZrAGgtgeKoZmV9pc0xBaNqUkInRATBMnagpsUCSiOaWuhQodBRrPcZU0dlhWY4NeCeFQv1e4 jxVu1phVCo57ro7NjFcBU8HkqoQjtb7CUMpi5tXOBx2t7hU2/SCM8QAohvuCSkma4OeNvgo4ZDbJ dwme3WE1TdUlMLvpuI8UfHcBW4HkoWyQSkB7UlIiFZscDUAguCk4aBJSNv0gi5Lg5wjwQxqUncpK SYxDXyUOwy4nxSamIQUnpcBW7xQmNLyGjk6JDha3QcT7RfvPDdUCaFqeswsYY2MxneNUPNy30Vk1 mHdlbc6VjdTtBeGeSgjqWQ7NVnXc98N9QyfJO/rWdSdj36jxCq42Wytmwt3EHRwVk9Rqc8u9LQhX QAQwaBMOrZ3p+ryzxhKn6wZrwSyCByg1dUrqqdVtMOMhJudjB5dsIDhtgfvI8IUm/wCc+T3gp/8A nLd4BVDdiBoGz3eCc34ThO3/AHocI7qptj6yW9wFIfWJ55b+Kqmzp7pERpp/WWWWDsdJQMQkB6Ef WVzfzfxRB9ZieWH71zbW+KYtlCk09MPrKB+afvRWfWloOrXLBx8Siyv1Huh06hWK8Ktu9rXAiJaS ncC16Kn60Y7zD5b8VfHWMdwkPC4uvADdrg4OB5CP1Dp7mHdSPbEu/kpcCrL0131hxqRq4LOP1wYD ArLh4hcxdhWhwDPdInhKrp1rx7nAawm8KaL6Fg59XUad7ODoWlea9VxhjZVlfYOMLqPq62zDtc1x ljlU650TKysl11TdzSOyRHRA8Xmse0sco5JBfIRrsO3GdttaWnzQbRqmkUuB0QkIuO0k+SCdCrVD oEcSkluVY91+jJLf3fzVfq6RmM1ZAV3puTX6Yr0Dh+K0Ta8t2tKFDsuDzGV0vJDt1glw/Oas3Irc eeQuwFhrMO0WN1p+O8jYR6neEtEkPOkQVYp1Q7NUbGgoS2WhuY+klQGtiKwbRAQa/pFQMiVzoTtS iVNrAEQohkEVqi0AKQUixKIScZCiCnBSpT13Tr/tGK13caFc91ar0ryY0dqtD6u36voP9Zql17H3 Vizu0p8hcU4zRp58JJDhJUS2lDRSaJUApAwgpRCbsnJTcpKUkCnCZFS6YlIpoSUybqk5QkpyUlKT puE6apdIJkgYRUuUwTlMkpdNCdMkpkkmSS3UoJyZTSmlFTLsmCSQQUpOknCKlFMEikgpdJJJJSkg kmSUuUk6ZJS6RTJJKXSUSYSRrRT/AP/RwbR7kevhDvGqnUdFSOzdSp5TBPCYpdKYSGiRSClk8Jkk lK+KXxSlNMpKXSSSSUumKUykkpSSQTSkpdNMJ5TFJSpSJSSRUpIlIJQkpbhJOmKSlJ5TJJKXBTlR TpKXTSkEkULqdQ3OAUOFYw27rApMYsols9Zgt21hFcdUqW7WBKJ1V4NGbAoNpgIzlWvOikDXk4ma 7lYF/wBIfFbOe/VYlv0h8VGdSyw2ew6Yw140nunFhAhW8bGc/CG0yQJhUKHNvPBbCcyJN0opdAQX 7GaAygOtTSVwDYLwUwcqm9PuKjtdTb3JblU9RP6pCVp4W1uSlVhaU4tQtHC2ZSlVxal6yNp4WwXJ iUD1VIWJWqmZMgqiajZyeFdraX/R1VTIaa3aaeISQkp6k9rxiQNh1KvXPLGwHmP3ZWb0/HGRmBwm ANV0uZiUtrL3aR3T9gsedLi7WJW30apjqyXAbp4WabANG8IZePEg+SbdLqLe6wa3eyn6f5xHCzmY 7vzipCwDskbz2QMkiJYuxz2coih4OpTm49lE2uKFruEr2UdyJQ/s4PZHZcYgo7Lq9p3DVHRaQQ0x VHZM+hx54VgvCi8yEUNcM2jRZnV2e0O8FoTqp2Yf2yotmHDhKkHZ5HsV331YbGMJXDsxnesKnfvb V6N03COGxtRM6SnDRjlq8r9bz+tNB8FguI4JW39bjOWB4Bc8UJbox/Klbc6kh9bocO4WsOvZdtZY 9wI44WTVQbBI1RDU8aEcJq+wwiVB4gorAJ1UbyC728JLmDeVaDo2qq3lHa0kIhTdznfowe5WKeVr XWCxoEdlX9Gs8hOItDThSYFdbjMdxoUrMCxg3N9wS4SphQAHwUfuq9Ti14lXbW6yO6lixyZU4v2h 21ZN1bmPc09jC1N5q1Bg+KrubOp5KZMWVonTewOh3ZmI6ysahYtdL3v2RrMLd6bdkUyKrCxpH9YK Y6fWR6gd7idfFMJCvcPZBn9FtrxhkNEtH0/5KyMZhfY0ea6IUWhprbadjvpNVCvFFV21xho/OQ0K fc8GhmVurtIAhWOmYD8mTC0LsagjcbJPBSqpqrG+q3amp43CtqfS81nQgrRb00nHLvzo3QmNDrnu iXxq4/yURmRW0wwEjhwlFdGduTVW614YEfNo9KAFfspqc0uqBDxrCuYdLLMc2vbvcOyB0TbgYtPq Pg8JZVYa/wBhkLWruw7D9E1nx7IOVhODhtEg8EJJtpY+NvYXExCrOaQYV/aafa4R5I+JhfaXgtbp OqRNC0jVN0zoTslgfZ7WrocXCrwxtrHKuVMDWBo4AUX8hVDMyPgzcIAWcsK1psyXnuGrfbqqVmKy ux7x+cE6JooItx+nY9V1djHCHD85XTi438zB9Tbu3LNx3mlpA5c7UrUdpkA9ti0YVTXN2jZh47A1 j5L38FZOQw1WOr5ha1zv0lUeKBlYzLbC4mCUSLUC521xjQgHutZ3TsZzC1rv0oG5QynuGMGtcB22 /vKPTf0c0vaRYRLXlAAKJWbgY7a2vuftlZzyA8hurexWrRluDm49lciY3lSFDHOczaPa6UiAoFyJ VvDwX5QLpDWjuVWyINroGko2K62w/Z6zDCZKaALSSU37LtNnp6Hvu/NSd06xjwwiZ8EfOy3i0UUH ttKtsd6RbUDLgPcn0FttevFfQ5rSOSt/Mo2UF45hZeE4lokydxWxfYX47hGqdXZberxmRnZDHQCN PJVq25F7jsJLvJWDjG64hxiByljWvY77PS4EkzvUJGrL0djpFThUHOJ3MMOCH1K/qFWVuxHHZHH5 quYV0Cxp8Amy3Fp07hDJpqtiL0LmX/WDIsHo51TXDxHtcsfNYw/pKj7T2/OC1OqVeowP7hY2h57q LitfVaNUhF3ljZHZRLYMJWCG6JyG6zNrtbDh6bv3wtrGY2usH1ZcdeVyjBqrb+NOUEh6l1VNzYtt EFcxmMqpsLajuAP0kJgkwUG36RRSzDS9pI7J8cwUfFsa2tzX9xoVXY0hyadbU6RPtQaeSVNzvah0 HRQ9GRtNThRGql3QSkCeVFsp1KGMspUghqQTlrd6df8AZ8lj+xO0rqs6kW1ub4jRcS4mNO3C7XEu GRjss8oKdHsrY28ZtLSWnkaJQrvVaPQyHeDtVSKqTjRbkTYYnlSJ0TJTKjSqU4TJygpUpJvNPKVK WOqSkooqUkTKSYoKZBMnTSkpkm7pJd0lLwmSSCSmQ4UU6ZJS5CSSUo0pQCZOmQUvJSCSdqKlFSao ynnRJS0JJSnQUt2SHKSfhJSySdMkpeUlFOCkpfhNykkkpYpJJIqf/9LFyAmpOiJfwg1HVUh8rd6t kOUgoBSTFLn8UkpTSkpdMTCSXKKl0k0pAoKVKSXKSSlBImEgkkpR8kwOqdJJSikmSSUulCZPKSlH wSBSTcoqV2SCdJFSkySXKClJwmSKSF0pTBOipS0OlM3Wys+Vt9Gr5PcqfCNVk9noR7WoUqVphqEC rgaUlyVUynaKySqOW7RPa53cDOd7oWYRusaPNXM18v8AJVscbr2jzCj6s8dnt8Sr0mt3E7YUsm9o btYICK4lrGtmRGioZHCNr2na+UEpOJ7qBcoyyhclPuUJSlNXM5SlQlKUEpA5KfBDlIuQKUkp5Qwp SkpnKdsuMDkoZKdqXVBdHDqc10d0LrGIaHiwfRdyjYl5p9x1Qeo57Mtm0AghSnZi6pMduyve3Qqq 97rHEuJKt0WRR5qg4oE6JAspywBm6RHghOdPCHyZTgkKO2QBeVElOPBMUEqmExKjKcFJS8pbyokp SkpmHo7XBw0+aqyp1SXQ3kp4K0hi9uxyBlvc2A2RPcK3kA8cEKr1GxoYx06Jw3YpCw5zqt5jkldp 0IO9AbiSR4rjqbxvBHZdv0l4dWD4p5a/DReW+sjGuzdfBY5oqla/1hcPtxHeFkWNHzSJCIwNWJJ6 +nsdqNE78IVnaSZV1jqhRMe6FUNo55QBBYZcYLnWs9NxaUElXM+xr3As7KmR3TG7G6FtjGpDtTwj PEcKGHqNUV6cFyIlIFMdSnCfFSepXmHRUKzqrtZkKRaWvlUNf7wIchNtEQ5WrtWkKg2pzwXDgJLC vluBaHD5qWKPVEBReNzNoUulHa+O4KiloWKYBi7fpupxhOgnlVa3kPAnSVq5H6TFMe7Xss2ugyJa QmAgg2t9Q2+Vnl2FlhAMImG12UH1j3OhN1CkusGk+1S6Xuxnuc3QlqB+Wx8yaJOo9LUd0q57YiCm Z0jIY0gtkJruovBJLZ111T1Z73tLoIhC5L40RVIqHOxXuZYNstQcOneS4jujZo9ba7wCnjQ6sbUw T1ZYR4RoysxzQ4O4BEKmcp1bPYYc1yt2sdTG+QCdJWW8hrz8U4mymtXXr9HJE2t2vP53ihhxwiQ7 WpyHtLhLQYUH5Bq9p1Hdrk0mwvIYW4sP3tO6t2rT/wCildwbH4zg1g0cYKBgWNBcKjLPzqv3f+KV 7GxyLg8asP8A0UyUtKXAPQDQBCfyiEqESqvVlWaVVtfuJ17K2xvuhZOPWQ608iSporXKbnuqD6wA RJUm9XsFeyATwHIlOJU8u3Tyifs+g+KvxBrRgNW1aOquqZsc0OI4d+6jO6ixjRA3k8+Sl+zKT3Kj +yqzpuKfqtoNXJzPXaABt2mVcHV2FmrD6gEByj+yWk6PUD0mOHhD1BNBJR1SrZ+maS9p9pCHj9Ra 19jnfnfRTHpTuzwonplg4cCh6lUGrv1nzWl066mth3u2vKq/s24nsmPTLu4B+aQsJLfx/s1NpebA 4kcqQsqqu9T1N27T+qsw9PuH5qicK4fmo2VtO7XbXQQ0OBkytt1oLCARqFxtNFrfzSitsymv3QYO ieJLSG3kO2PLjGgWfTUzJYSPbZPZVsiq0umDqq5a5vYhRSOrIA9LU6WuZOoAlW7GWWARxC5Wu1zG GCQSVYGQ8AQSD5FNmbCoii6+Ri2mpwDSfBc/dVZSJsaWnzV+nqWXSZZZPk7VNmdUfnN/TsAcOC1R iguOrkljnGUNxkwrj6gWbgdfBUSdUQbQkLYAKK86JOIIE8prdYCSmLDqoPaXGQjNZt17+C0sfpj3 +5/tCNJclrHBT2ldCzp9LBxPxUji08bQgSFwi4JfLYnVPWYELadiUH81BPSan8HYPNRml1FpVmUY IFtL8ZxB1aPzk7LtyaQq+7YAlOhixRc4lOC0pZUgUIIgT1jNdJ9Wr91b6XctMhc4Ar/R7vQymn81 3tKIOqjs6f1ipmttg/NK55dr1CgXUuZ5aLiNRoeyjzDYs+M6LylKZJVWZdIFIpJKWKdJKEFLpk6X ZFSwTOThIpKXHCZJMgpkmJTpiUlMuybzSBSSUuTomlOmRUpJIpSkpdRTymCSl04TJ0lLwnITJ3cJ KWlIFMnQUpJKUwRSumT6JkFKS5TFOEkKHKUqUKJSUuko8JJKf//TyrRoq9ehVmwaKqzQqjHZu9Wy NU/Ci0qSapSSfukkpQTJ+VFJS/KXCZJJS6eUwSSUvomJThJJSkimTJKXTJ0kVKShJJBSkkgnKKlF KEyeUlKTFOlCSlkydJFS0p0yfhJC/K6fo1cMBXMtEldh05m2sfBWsI0YshS3ukgIcqVmrlFWQ0pL OKzstyvuKy8w6J5YOrz+Vq4pdNbvyG/FRvOpV/6uY3r5Ejsow2I7PTuMGFUyTorNo2vIVTJdpKS9 zXHVQ7qR5QiYKYyhmSE0qCcoLmRKUpnCFGUFM5SlD3JpQpKYOUpQdyeUaUlBTgoO5XunZlWPYTaz c09/3UgEEp8S4OY6vvyCqloHKvOdXZk7sVstcPcE2Zi7dYhPI0Y0e2KxCrHTlaPp/opPZZZdqhIL olkBJgJHQwVAvSLpTKX2y3AKMyok+Kbft4SpVspTKBcm3BKlWzL1HehFyjMpUi02+DPZSe4Pd7Co XY1tQDnj2u+itPpeALTLuAngLSWp6DgwuJJ+KnXiNyGtYWbzzotnN9KqvaG6LAyM23Ccx9Bgj95G tVhOjndQoGHkBorLdPouXb9FaDjMd4hcn1LNs6jtutAaWjbDV1vSWbaGeBCeRo1hK5PM9ZwRlZr3 F4aRosrL6ccav1C6Qt7qF+OzIsbaw759r03Uuq42ZhHHDCLABt+SbuaXiQjF519x2gNOkcIbZIR8 bCc8QBwp766SWuElNIpA9Rc6Jcnc2AYRXkPd7REqDmkAygGZLhcFEfyg0jaJRrOU5VoSmHKcpgE4 JTsV2k6Qq2FYGvExHda7KWh25qkC0tC36JQsAbmWNPgtfKxmvYXcOCyel62PZyidAsK+wfYy4iHN Oh8VWxG8u7ELRz6bfTI2wwdlS6RsfNTzGvtUANlhIuJbOGHGzYHEAqy/OFZhxdoYSbQ2q5u34aqb 68Tc6X6zqIQIFoxg1SL7TuIcC6FesqDXNa15c5wB2/FVtmKWH3kD4LQua0Vse0gGNHD3OUcjWzNT mZlVWNZsIMkSqrraRpJlaOfXW9zXXWQSNNOVTdRizO6T8E6JsLYXxEfotvDrry2bCCCO6ni124Vb qdogulpKn08VhxAdMjiFDqW4UEuJABUB+ZnBpv8AUsqrKx21PqPqabeFzzun7nWMLdRqh12VPb7t xjh25XKyX1n3TpoVJO9FBu0572isOrG1ngqnVmVZd3q0sLNPdKy2vZG10kjwKg5suEFxHdsoUQFx Nt/pk4VjrfT3SNCrv2zc4EDaZWG5jp0kN81dw8mug/pWbx8foqKUTuuB6PSV2eoJRgIQ6XsewOrE Apy9QMqwMOVfIY2vcQIlHHiq+XMEu4hPG6HFpdqfijb1VrdqfipWy5pA5WnE6NU7pTl1jQlMMyo/ nKpVcytoa4Qfgn+0VE6x9ydaG825rvomUi9Zxe11jXVjj6RCs7pStSf1Et6BuTbkrU2N6XqKvuSD 0rS2PUhL1UAOTF0IWptC0qfrFZdlzg4MboT3RDUY9zzKIKG0+4koRs1VWxhYJa86eKQfIlRkr20w C0+mAJdwiW/VnMaNzYI5VLfAJ8lDF6zm4xHpvdHg73NSkUW13vNRLHA7hoUPaAQR3XQ1/WFj/ZnU B7T+ez6SWR0/BzG78GyCNfRd9JModE241cGl08grPZq/VWLaSHuHBCrVv2mUAKSnvA3CFKAXCUDd ucESdUlN3ppYckeof6vxXS7QeDquOY7Y4PPAMrp8fLrvADHS6ETskFO9jgfcICHt3I7b3sEcjwKc WMsG36BTCy21oDeUN0nlFsqLPpceKESmFLBwBEHULIysd1L9zNQthZefmCdjNfEpRtEqYVu3iUTh VsV/tR9ycdFg1SN4RGlV2nsjNKIQU7USS33DkGUJpUw5JT21FovpbYO4XIdSo9HJc3sdQtz6u3+p Q6o8sKq/WPHjbcPgU6Y4opxmjThFKUkypENleUkwTpKZFMmlJBTIcJHhIJkkrjhMSkEzikpeUwST hJS8KJUk0IKUnHmkEkVLppSTN5SUumlOSm7oKZdkwCc8KIRUuE4TQkkhl8UiUyRQSop0ySSlSlKZ JFS5TJJ+EFKSTDzToqUm7p0ySlJJJJUp/9TLcqh0crhVOz6SowbpbDSpKDOFMIJXSlMNU6CFTCZO U3CSl0kioglFTLhJJMgldJJJJCkkpSSUpJMeE6KlBOUyRSUqEimTykpXmkkNE5SUpIJp7JSkpRSK dKElLJuE6SKE+K3fY0ea7HGAaxcr0xm62fBdXWNrNVdxig18hRO5JUVIqKnDUmjsMBZGY5alpgLG zD2RkxBxsgrc+qYhznnwWDkLo/qw1npuJ0KbHq2A6N9upI1WffZu0VnIO18DhW8jpbLKPUY6HASk V4efcUMRyVMPnlMYTF4YymJTpiEEsto27gR8EIlORCigkLEpw5IgAJkFy5KUlMn4SUyCm1DUgEUF 1+j5Dce07hoeCn6jnfabRWBweVRxgWmU1LZtjxTmMh17Zcza3mFnfZyzVw0VwP8ASBPMKv8AtFzm 7HCWHj+SiUBrWVwhshzSQRp2V6ysFshZttcGU0rhqrd5qD366aBQ4TSgupSeU2vKaCkml5TykB4h IVlC1U2KJtc1p4nRdNa1uJUI+a57pzYvZPitv6xUPdVubwE8HRjkNXMtuFpmfksvqhiE+H73j8Uv rI0DYRp4oBBFNhzG/Yd0ag/SXV9J1xmfBefHJubjisOBYTqvQ+mN2YzB/JCkOzBXqt5z6wZfrOFB rgtOlnisnZKtdRpuu6i8VMcUGzGuqMWNIKOjGY3Raj7rK9GOjxUA2RLtSVG4HdBROyVNgaBaAEK4 x5ohKE/WUJbKBRst/N7I9iqNHuVqzhMXBC4pJikHGITopbGM8MeHHgLdZZU4bqXAn91c806q3Ro4 FSBaXU+0ch42k9lTxafRyNw4K07mturgkO00c1ZuIIfAdu/76idlhb2flVWUuY1wJjhYPSP5w+QR 7qxuMeKB00xeR5KAx4SwiRIlbrsn12uKvfZQ2xzpaZMwqdRa57dYIKueg5l5dBgoS3Ri3YW4gdW4 AgIxxq31McIFjBAd+amuaXMIAnRR9M+i2dNv5qZMM8t2HUsc5oYXuDXNHP7yHViitm0w4+KnnMsv paa2xB4T4m6uva8EEJR2TEa2zx6ttknwWZ1N5d7Z7rUPvcIWNney8A6Au1TD8y+k+Fj1lu3YSfGU Fw9IlgnnhXg5v0WfgqnULjSPb/OHv4J5IISxxcKPdYEV9VDHj3bPkq+NZLBJknlGfUXtl+g8XIXe i7owvx67iBXaJRa+ngOAc0+O76TVTLcYWDc+XdoCu0WBljSx/wAigT0UG/0+wuDmjsYWgWqthNLd 24Q6e3dXXKrIUWUbInaBVc10Uk+CtHVMahcw1O4cIRiNVEvLVOBmOFNVsrpl2NcaiDz7USvo+daP awwr4OjXITSo6IF3Ss3H1saUA1XgTqjaG6Sm3QqH6XkzCj61gS4lU6MpiVn+vYoHJs4Q4lU6IKeV QGVZCf7VYddErU390KO8qj9rf4JDKf4JWluPYH6HQpjUzvJ+areq88Ji613klxKpsCpgMwpEwqjX XA88KXruJjbqU20pg7Qp2v2PAiRCtYXTr7Sdw2eG7uoZ+FfRtd4H6QQJUAjsJfyIVEHbaI011W1n 4oZQ25locDyzusSyQ6eyFKLZyRvBn6Xj5LLOhWn1HhrvFoWbtJSCSyrMGUTUmE9LWMMvBKt7a7Hb 627QE5CIv2OB0Mdlps6jRaP0g9N4+jtWQ8ySUNJTsWZmVjQbACw9x4LTxHHLq9WNoPC5XfsEHULU o6nbRU1jYgdkPNNu4XWUiSNzO4Q7xJmsGD2WY36wXt/NB+KTvrBlP0AaEKC7iLesoJEP4K53LpGO 8tBkdlZszb7j73c+Cz7jLtUggm23j/RRiUCnRoRimyXRZA6ozVXHKOxKOyJJgpgoQKnPdFaHV6Hf 6GUAT7Xjat7q2P62O5o7arjm2lha8diCu8aW3VBw4cE+KrqTwYEqMKxmVGi97PPRAIVSYoltjZin SKSjUunTSmSCWUwkm0SBSQvKifFPKZJSgpKITpKXCdMkklSUpJJKUUgYSCSClJJJJKUUgkkipdKU 6ZJDIKKfsmQSpJJIlJSkyRKdJS0pJESkipcJymCUpKWTpFMkpdJN5pJKf//VzSFTu0KuHVVMgQZV GG7eOzOs6IgQa9EZI7oXSJTSkmqXSlJMUVLhMlwnSUqUkkoSUumSS4SUoJ00pIKXSTJJKXTJFIIq XSjVKUhqkhSSZJJKkgklKSl0gZTJ0VLEJwkkiEOv0avUuXRv0bAWP0auGA+K1rzEK/DZq5DqiKiU imKli1Jte86LEzHarYyDosPLdqlJbFy7zJXW9Dpa3E395XI3aldp08bMJpkapsdmwGpe7c+Oyll3 FjNjSVEfpbJHij3t01EhBc5DhCaEW1m0whEpq8KKikdUoTVzElQUymhBIYQn4TxKeJTVyycBKFII 2pI3HeW7wJb4p2tTse9oLQSGnkIgIiO6ctLIywSE+MPfuUi4BmqljMJkhFY27Gu+zusAkLEa72rS ba7Zta72zq1ZjxFhHYpEqi6lX82CqtrN5iYV7ptbrAQI2wqmSzY8tSKhu1TUl6bQiaTqm+CayJHW lzAyAI7hCDAFMMkSmhJS+xsacqO1qeITRCClodpt0I1C1epdSF2M1ondHuWY10KVx3skdk4LJC2t hODSPGUTrFAve0KGFinIuABgqz1yaL6/JCK3KNKDj/ZRbuZIaWaw4/SXoPT/AOjN+C85mjIsc607 XE+1ej4ALcdoPgpLsMFUsHVyCwj+V5Kj1+4sxtwImVnvafWfAOpVXqA3U7JiT3UBJ42YD0ON7bGn cdeQh1OkljnfBVLLHVOLDqAVA2t7BT8S0BuvdtMFQMOkhUjZKLQ6SUOK00zrALtVZtVesS+Ua06J IG6EpBR3SYU2jw5TguZBWquQgNrJ4RWk1/SClCG7vNZlhhQwn7ryPzjyndBaCDIVfFdsyQRwUeiw p8hsPcFRwvbkLczsYbfVb81h42l4PioZMNVYdUaWDyKvPu9O+XztIWc52qi/K3PDXHRNO6zHu7Nz oAB0DuDKFvhgqrdu11QjUL2be/YrSxOjte0Akz4hHhBbZHdo5zW+gGslpBUenOOwteZjiVq9TxBj Ugg68BYVVhsnc/bHkhw1sx3Um9Y4AtLeZVTqeHvJcBMQ4obbbGWgNcHI12Y9sknWIUMxRBZBK1sP Jc/9I1rW7foyhXUHJtL3iCR2+igYtL7KfMuKd4vw3BuoB+aeR6dF1tjp5GEyyp9cgkuDj2Qb8xmY BvI9v0QFJtj7Qa3n6WgBVUdOtaC0jVMiO6bWfj+5tjRO10q5lZ32t3srawRBVal94b6YBEaIQw32 El7o1TRE3qkF3Ol3bx6ZEOH/AElqOBWF0an0r9jQdR9JdCfNRzGq8bIITRBlWm1h3ZTOJuSESoli LmPA3tBcOCiDKPZD+yuHCj9ncFNZY24Mndo6CqmR03FyZlu0nu1SbS4InpuCeChzH/VykjSyFm5X 1cuYZqIePD6K6J24JhYQiSp5un6u2HW4hquM+r+KPpuJ+S1HvnlBKiMiu0ap6DgkQJBWLndEsx3f o272nw7LpQj12bU8SQ8lX9X77BMBqO36uXHwBC6VzpUC5N4kvMfsXJBjbHmrDeit/PJldB6hQnBC UuyQHNb0jGA7gqI6fjYrvUbq4K89UbmEqKyuZszi87XfJEuIfWWu4IVOumDKr9Qzm0QwnUqYbMez mmsEnbrBhV5r9zbNP3Uet4budyCgWNa+TGiKFZb99TNZjRUWP2nyVy6G1gAayqr2Aa+KIUUsiFZx Po6qm0S3TsrVJ21/EoqUxga47xIPChfQGat+5Hc/YZcVF7Q8xwT3SU0HqweB8EO2naeZUnnhJLGU 4KGSZSGndJDYCqOMuVidEGNUkt2vgBSJQanqcphC+KQI7fFAajNQCJJQpAoYUk5azIkQuu+r+Qb8 XYTqw7VyIWx9XMn0sh1R4eP+knBEu7P6xUbLG2gc6LGldd1vG9bHdHLfcFyDToosw1ts4zYXcop+ Uyrr15SSCSClwlHgkEpRUpMlMpFJSgn4TJFJTIJJglKSlJJGE6ClkoSTJFTJJMnSSopJikkhlKQT J0lLu0CinKZJKkkpSlJSk8ppTIBS6XKSZFS6cpk6SlkkkklKhJIpJIf/1s5VbxorKBcJCz47t47I qSjhVquVZCfLdA2ZJKMp0xSkkoSRUuSmTpklKTpk6SlJJJgkpQSTpklKThIpgElLlLhLhMUlLpJk 8JKXhJMkkpSSXdNKKl5SlMnSUunAkwoolLd7wPNPgLK0vVdMr2sb8FYvPuhPiN2sQrT7irwacjqs mcUgUzzopYtabSyCsPJdrPZbGS5YeQ7lNmqDRdq4ea7PSrFb/VXH1jdY0eYXW5Ic2kNPYJo+VsRa eJdtfJ1C2attntBXP0BaWOQ1w5SjsktTLqLLS3wVbatbKZrPcqi6tAhcC1tqYthFcIUHFMXhGQmR a2B5gkDzKg9m0wDKBXBgkD4KROkJgmpWUhqmUw08pKZBTBUEgU5aUpMhWcF8VvPZVawSZV3FurYH sLZ3DlOCwhsZODQzC9VjwHAbp/e/4Nc6zUqlY1zXkyYnRXCQ5shA6oFxFu90qr0QXucAD5oOc5lt ks4WIxuoJJ58VdfY1g5+CJKAbKQMSNYVayLK/UY6C36bVWHUS2s1jUH87uo+Js+33LsNxbCN35vi ovxnVmHaLLq6g70jRJ2nzTwfTJdYSfzRKXEn2j0LfLT2TPDuSsdtlo1c4wU/rWchxTmI2N3Ugqxh 1eo4sI5CwjkXN/O0UmZlhcNriChdLTJ0ciizHsB1GvIQursfWG79SdZlVL77HCHOJRM+3fVW09gi EE25bdbWyO4XqWKIoB/kheXUsJtaRqNwXqOOYqg+CkGzDJps6rU53vEOaY/rLC+slzL4LOO6tZeO ceySQQ/UQsTqT5c6FAbM2QfK4D+VFSfyoqRClOowUOVOvlJTbqOqjY8uciN0CI0B3A1KKBogDXHg KYrJ7ot4FXLgT5Kqb4TgQubTWuHC1MXqr6hsurFtZ/zgsSvJaD7phamIcfI9vq7HeD1LErSqx9Rc TSC1h/Nd+aqzARcCeJVzMw7sYbyNzf3m8IDSCGu7kpxWull5A2emsJmlo+K1M0EWR5LMAiwfFQyY Zblt3EzKH1ANdt28QrT2AlV30GYHdNpEckY7o8e2yvgkLaweo5o9rHSPMLMbUavpaQtjp+fRjj9J PyCeAy8ce7Ox9tj915nyVJ3o+oRZo08I+f1Nl7v0TSG+JWY9xdqiVhmDsle2r1NrCQ090G9hafp7 gpNdscCdfJWLbKckhgaRJ1UMwbZIEJ8Z4DRXxPBUMuu1jYdMjWUXGyKsMNa4AtaZ/lK91PMqzmB+ PIe3xH5qUdQyHR5dh3Wjd2Wub3hsubu81C7YAHuYCQQtbD60Gkg1ggiPagNUvOZeXZrt0EImG4Gs T9I91Ysx6/WdLdHe6ETCtpxGvr2aOM6ppUGNeR9meHnQj/qVtVZDbhuaZCxurPr6jW30WglnInY5 yza8w4Lg6udpGrT2co5w6rgae/obLZRhC44/WxzKPSZWd7hEqljdf6hQNhbu8yFJGOmi0l9B0USQ uHP1uy2g7qxIQa/rVmvbO0SnUi3vwQp6QvPW/WXPBktkfBXKfrjaz+eqPyR1Vb11jQUE1SsrC639 rgkRK1G2gppKQsaFA0I/qBRNgCam0PopelCmbQom4IKWNaiWJzcEM3SgSlntAUSEJ2QAhPyWt5Ka SuS2NCqWNCr3dUrbwVlX9Y3HYwEu8EgEEulfe2ppc7gLn345y3+sXDXgJVX25LyHHto1XKcR7G73 nX92E+6W7oacMkETPwVS3dU6CFpCloO5oMhI1XNOpFjXD3D86tK1U5l7w+sGIMoNhDq2nw0V67LD GGh9YMcOVNsei5p5mQiDogomGFax5d7RCrVGU7jsMjlPU2iHzoJH7pUfUaTqYKdnqMEu1B4Q3bNS 7UykpjaewMqD9FJx4hDOqSWHdOOURrAeUZ1dbGjuT4JKQkwENg3OhWbMd22QhYrZs1QvRVarA7XQ jgoN+jpU2FA7LhoU4RmoAKM06IBBSAqYMoQKICitZjVGxrfQvZb+6UEHVORIhFT6A8C1niHBcHfW arXMPYrr+jXi/Ea784e0/JYX1go9K8WDhwSyC4smI9HKTJ0iFTbCwKSZSACSlwUvNMnlJS0JJJJK VCRTqPdJS4SSTJKXlOmKSClJwmKdJSpSTFKUlLpJBKUlLp1EKUwkpRhNKYp0ksZT8pinmElLpkiU 09kkLpBLlJJS6RKZJJKkk6SSliknlJJT/9fMCHdqEQKDxos4bt5qVnVWGlVho5WGlSyQEiSblPCY lSZOmCSFQnSTJJXCQ1SSSQv2TJJwgpZKU6ZFSk41TJ0lKBSTFIJKXTJcpJKVKdRBhJJS6SUpBFSk kxCSSlwrvTmbrgqUrW6NXueXKbENVktnpaRDFTcdSrrvbWqEq4GlJm0qFhgJ2lRu4UsWtNzcp2ix bitfLOixrzKjnuvgtgMFmQ1p4ldPlk1N0Mhc90mvffPgtrP4AQOzYDWe8vAgAHxCuYYc46qo0QIW lhVbBJQikqyRuf8ABAc2ArFhkygOCcoNe0Ks4K3Y2UEU2WGGtJTCF4LWKjMK1bhW1N3WaBVG2VPO 0PE+CjIK+wunCmKSfokH4FJ7Cz6WiFKthKmELlECQSUjWk6hRSBgyEplOWswCVBpIeiVN3c8KLQG vOnZJBaV43Ewg0vlkHspus9K0g6oNENLhxroiBqxyPpbTBp4prHjlEYRsPigGIRKzHs1rLDJgxKF Ti2XTs7aolkDUKeHkFhgaSmlnJLULHMPuHCLXaSdeFK+wEkHlAEjRIhdCRDetur9MMaNZ1cmtqcw AuETwkyuos0dL/3VJzbNnunb+aUyKch1ar2k6pmHaZKR5hEdXHuTmAqMOI81Y6pVZTsDgRI080AD UT4q11m97yxrnbg1vt8k4bKLU6c26ywNr+iCC4L0lmlfnC816T6jshprn6Q3R4L036TCRzCcNmOT nWMqNT9wG9olcVZa65rnuEGV02dVfc19zyC1oiW+1y5ZmRXWYOo7qMDUr+gaDmSguYQtF2RV2CZ1 lTwIGvdOtTb6J06jJY59tga4fmFLqeIykNLI5VRjK3H2yDyh23B4hs6eKB3UD0XafFCsuPZQc+UI lOUvMpa8qTRGqmLS3UJKYMgmDoET0pPl4oLXQZV+q+myBa3a7tYz/wBGVohRdDByn1N2gmO4d9FF pfQbw5vE+5izrGku9Mn3R7HfvKtSLBZtaPeCpRLosrs9J1KsH9I3usQ/zo+K28k7GNqvMErJyaTT cBMg6gqOTCW+7lOWSNUnCIUwi05IXCFFroKlaOE1g0RtdGI3LF8nhNGiLWAQmsMaeKVsnFrQRu0b KuY9DRDg4EHyVEmRCL9qYxgA0ITJ2Bo2Iar9Ue2p7dgg+KfHzrY90EeCBtN9vu1aBIWnRkCr2vY1 zT/nIQOjMUdj2bSSJ0WVXfY4+0wPJE6g7Y4hn0TwruJWMdoLQC7+UgN0ssfL0IsEmNCgdQuYS1wb Bj71azrGXsDwwMeOdv0XLJqb69sHhusFCQ9VqDdx8x0EFoj4IOZi+uGlui0Kc30NHVtcz/pKXqtD Wuqbul3tYlPUaIJp542uryKzt1aRIXXN6r6hAZRJKwr6XVZBNjRWT4+5a+Ja+tu+ixrnj80hOgNN FX1cbrX6xkBrGbHRq1UMYPx8hjXCYP0V0mWzKfaM69rQGtgNCDjX1uf6ljg0nyQuzooHu3R1Kx7t rccH5Ln+rXNvyvczYIggLo/tGTVcLKCxzXe0koFtQue9+QWue4/m9kjKt0Eno87QBje6qwgeELTo 6rkOHs90c6LRbg4/7gAOnKicUNgUAVkaOn3blESCgW0x1TLdAA58lB3UcoDc4w2YmFdGPkDQ2Nj4 IeRh2+i5xe1wGrmhBNlBVffe0vbcB2jap2MzGf4WdJ+is7aAQ5Xcy99djQASC0cJGJvRUTaK+3Jr AJt+l/JSsFwIByNYmNqKwue17HtI03N3KFlH2h1Xu2SIlKiDRSN1UV3PLgbpgTt2wgMofkgvdOxv 0tVsfsl/Tchpc7eLBt+aDVW66x9TQ0bZlv7yaRwyXgtQUYLWbgdR4lIzW9t11f6N3trsVWypskbA RK0tmQ7E9eA6lv5pdwpKsIJct2EHvJY7vKuOYwuBsJLe8KpkvdW4PB27hMIjQC1tjjOvHigdggbq tzHUWbahNf5pPKFWTl7nPf6ccD95Eymtvd6jG7GgfRQMf0Wnde0lg7JABeUWbS5tbXHxjxVXHAsd sd4aK49tZpftPtn2t/dVGk7XtcfFIbELTuwb7XEeai8yUbKb6dpHjqq5OqkGuqktd72HTUeCdzpM +KemkkbipPaJRUjgnhMQjg6IbkksQ1Eq9p17oUp5SU3/AF/3tdFVjad7eQoSVH1CDqm0m2d53Dcm pMp4lpUaZ4Q6J6tlv4qYKgE06oIKcFFagsKM3RFCQKagFJJTvfVvIix9J76hXPrBjerj7hywyuf6 dkHHyWPHEwfmu0yaxaxzT+cE8ahUTUngAdJT9knsNbiw/mmEypyFGm2snlMnhNUuEkkklLJJBKUl KlJMSnCSl0kkklLJ1FSCKllJRKeUFLwmhKU6Clk5TBOUlKCcKMwnKSlkpSlMklflJIFOkUKTJHRM ipceKdMkEFMkyUpJWpRSlNKSKl0k0pIKf//Qy0ncJJis5vNJ2jlYYgW6ORWHRTHZaN0qRSCQUa5Q KSSQSUopJSkkpSSSXKSlylKRSSQsklwkipeU0pJJKX5SSCaUlLpFMn80FLFJJMEVLpcJJ0lKThRT hJSl0PQqvZPiVzx8F1vSKtlTfFWcI6sOQ6N7JO1kKiVbyz2VMlWg1JLtKhcdE4KHcdE8NeTl5R7L JvK0co6lZdxUctSyxdPodUuc9Xs07nQEPobNtUlLLd7iQhJnC1YL3ALaLQyoLLxGcFXbXbYaiNlF YlQ2py6OU28dkUIrnMpG9/0Qs27622sBqxWNDf3nI/V63X45azkLkWaaHlNJURbZuyrrzNr3O+ei A7hJxUY0lMSAsHObwSCtHD6raCKrjuZxr+as0iNSruFhnIeCBABSSHbLNdOE+0qwYiFDRCmS2ABG qcjd5J0SkNc4Duii0rK4bCb09Nw0PipZb9jNNEfYHYwd4hOWEuNlYGT6wftHkg2Y14dq2FsAtdXy ZWXJ3x5o0sJrRTaLSILSoWUWtMbTC07NYAKJVVIl0whSgXnbca88MJCAca0fmO+5ej9MAZRJ7nur Fbq7SW+0nwhKl3E+XGt4/NP3KIYZkggL1MYlbT9ER8Ezsak8sb9yBAXCT5yz02as1HwU25byz0Qf aToFtdYsGNcBU1u0+IQDtfqWj5BNASTeri2AHnkJerIgla+R6TddgVRz6u9YKRC22rXFhHkVPqke rHgFbw8Wqxws2wAeJVXqhDsp3hCKCh6QXMyGlvE6r0pjiWGeV530gObktDTAJ/zl6MxpDYTxsxze bvzi9lldRlhkEFc3eTYwMc0adx9JH6tXfh5NkH2kyqjGXWs3giEyqJXx1ARuxdok907aWjUd1JtV zztJEJixzS5jtYQUVNa1hkKmWlpRKgWu+KewaapBSIETJQzqURle9DmE5TIy0SRp4qUiF1lvSmP6 L6357W71yIHtSpK9IaTDlLZB01CG0Lo/qx0o5zbHGIHt+9IIcFryHCeAV0Ia1kOYIPMrn31llzqv B5b+K27mMDIDiTHinBBb2Wx19YfExys3qEh1ZPgtvGBGNuPICzM5zWOqsI3N7tSmWMx6ti1gDGng lRHCsZj2uY0tEDsFU3QNEhqGjkGujC/stE4dVlAsE8LPbVZkAgDhaNeWWMFPpy+I5QlelM0I0NXO qOia4E6ogbZjuLi0QVJ7LHDcG6Qn0tMCDbCltdrw130TzCXUentxxLTzwmxjDxtEmeFczLi+osc0 gzyo5A34M0NAWnj4xbc0PcGtcPpLaw+lVZe4F53N4j/z4s6W5FbNpLXsG06KMkP2i4hx8AmgM3GK amX060l7ZBLHEafnbVpYeI21tW54l2jmx9BKu1uIwhxLpOphQ2OBlr4afcPalraRLRtdZ6QMVjbK iSC4NcHfylkUYLqshpc4Nrd7XPP5qundfBfaXhp0CfJyqrPY5xaQedqUrOyBIN3F6LTkOe0vJA+i WrJyKzhWupOpY4GR3Uhk7dWWlp8gq9lZsaXtdvLu/mgdk2JFFcDmXy0mI7rUp6cTWTW4Fw/N/OWf hOAc5g+lEq96V231A0lo/OCdCS4hq5mW11QDyQ4aIGHiutAOgB/eVfMB78TqtSt+5rW1idEI6FVN wYVuO2HxHI2pqLcLFefUaS/xUaHOY412AtJGgcilzWO3Oc2SNGkIk6sZNMszq2NbWWN08NFAXCpn qH6MSkb2OaWWFjSeHhqJRZ7IDmxEb49qjkfBXE1v2tSeJ+5MMlt73bOC1TdkV1EBpY/950bU7thc Hsc3X8wJfRUpFyBW5528lagquHp2tElo2uDlUY4136czBVvqbiaAW6kHRGR1C3GbdHOyDmhgYza4 TuLtvH+jWDL9uw1yGklrpU3U5DNl4YfTBG8lXqbZ3s+eqEiRuyOY/qlr43gu2fR3O+iq7s62zUmD 4wq9xJsfH0SdEw4hGgdUgFKb7IiZ+SsU5VYZ+lJBnUfmqkRoo6ImNhIDduvxbSS5xmPZ5KDsqljQ xusa6KntHZDI8EBBNOnbmvyQ1jBO391CL7AZc0mDwfoqviv9N4KLWy65zgwEjXVNIo6J1YXXbS4u rLd4/spYL9jCIB1ULnOfSA76TTtURuazQRogY2K6o6pM+oWuFjNRHuVGBMhJ1hcZJ1SY0kSnxBAp W7YrdvIYToh3NDH7Qmp+kByJRsysMfPinJ3CMahQcnYkUVBGnTd08JKTBjHAQYPgoW1Fp8kTGDXE tIn4oxDeEE01auY7FTrZtcQVBzdpkIk+6U0pCSEM8okoZOqaElPWUUaKtW6NFYBTliVpUwhtUgih k4afDVd10+8ZGMyweGq4ccLpPqzkbq30H80y3+qjFR7uX1yj0cons73LOC6X6y4+6ptoGrSuaGih yjW2zA2FiI55SCRjlIKBeuEioynSQuolOmKSVJwmTpKXTJEpSkpScFRCfukpdIpJklKSKSSSlBSC in5SUspKIUigpZNCfyTJJUAnTSkihdNKSSSlBPPdME6ClJ5TSkkFKCc6qKeUVLpJkkFP/9HMlRKe Uyzm81LxropVahPeFCkqbeK3qnBUlFSAUa5UpJj4pJKVPikkkipeU6aUyCGSYBJOD4pKWSSKZJSk 6YhPKKVSkkmQUvKdMUkVKKSRSSQpOmSlJSk4TSlCKEtQ3PAPiuzw64aANAuQwa99zQu3obDFbxD0 sGQtTJPuhViUW0y4oJKsBqFaUG8ohKr3HRPYi5WQ7UrOt7+KvXmSqFnKiO7LF6bpY243nCqWHc75 q/i7W4wA8FUZXus04QkzBt4OO4u3HQBPa/1Hk+Ck++BsZoEGduiKmZch7goOJQyUlJXPVO7ExbpN jff+81EJUHEphK6nOs6K38yzT+UoDov71gjyWiSmQXU16umU16OJd5K42GCGCAoJSkpmXlNuSaey UQkpdHxh7pQGhWsSC6O6IQVs3Vuqnj7zjGT7RwlnFpE8KVFf6sT2KS3o1GOAaVVaNz5CLf8Aojt8 UGqJnunRWyGzoaEgjwVhnU6qahXZUSZ+kCqzYLZkT4IDrhWfeJb3CYSvxwsui3qdjKzVWAGH6O76 Sp41mQXm5roe3/qUPMsbTW2yohzHeHb+Qs6vOewkt7qLikW4IQiaIdi/q2Y9zSHajsB9JbPTOr/b Q5rxte3lc1T1Rp1c0At7pV3Bm69p97ijxEaFBwxkLj8zo9Wo9UG3wKoMMgI2RkevQNujz2QrHGps 2cp4LUIrRr5R3Q3sg3MDQNQoOtLjqoOkhArXTw3batvi5ZPUTOS5aWOQGM11HZZHUbd17njQpySl wgPtNW7Qbl6Vu2s3cgLzjpbN+RU/cDr9FeitB2QOTwnjZim8P1c/bMkvbLQRGviqH2W0N+mAFb6n TZVkurs9jif7OqpNosD/AEi7TxTZLo7BZuNa50b9fFM2lweQ8yB3Cd1BBjedE/pbBu3TKavKnCCE Si7FNbmXgz2IUC3cRKrWMM8JBa1i6Cdp0UO6k/mE3xRS+hixruhuHf0y1ee67YK6s5J/ZRYD2XKu e5wE6wnHZHVZq7j6l3NrpsadDMria5W70Jzqy4cTygFFr0tY7Mttfo3e7bP70rQsa2x0kBYdhLnv Y2YLjotOmq3Fr3PcHAj6PdqkAWupXmUVtLSTqIhUOpw6thHiouaSJAJ0T5ojGYDoQU2YYuIk02i7 fjt8QFTtuDWSDqnfbuqaZ18FSsM8oA0xGAlJt0OPYqZLvpTLhwh313YzmNcwg2fQ807q8llwx3MI scJa1PptCqpd+QXCNZ7yil7mt0OiA2q99xoFbja3UtUc53plogidHBAmgsnEy2XpeS6VZe9ztCdF Ua3ZUbQ07QdXASpOyC2v1SCKzw+PahuvAAFM22bPGUnPJbvPI7odtm0NNjSA76Gn0lHLbsrhwId4 O/dS2RKNigmrvfb9MyEY2P8AEwFTafTpbaQdp03R7UR95Y0OeCGu+iY+kkuoM23mse0kFHa1lzNz 3Q5VLXbXBr2kOd9ER9JX8SiuyG2hwjlp9qR0CyQFNRzWtJAKYsdEAwtRmNQ8TtDR/KcjNwsY1vc+ uC0bhDvpBAkb0x8JGxalbGUOZeyN+3aVr4/W6KqTXaC46/R/O3LLpFThFTedY3KzeynH2bGTuEmU yqZr0pz8bGZfj3QPoncAreF1OuhlbXgAVmRDVJjvUO2sQ387aU76wxpJlx3bUKo6o4j0bXUeqY2U axUC6yfpR9Fv56zuosLy1w07IkR9HkdgQgux3V2OLHHbt9Ta5O6rLNtJtIYZJJC0MP6MdpQhjvsE knXwKFcwt9ocQ4ctckRa2RI1prOxS1xkxqi1D047mUF11k/TOii3IePzijRpYcumzZvJZkHzEpqB v3sJMHUO/dVQ2uJ3clWqqW3sFjX7bAfc0nb7UCNF2OQdmjqVrsd2O+HAjbvWPnY9thDqhIDdpVi9 tgaPs2kj3Sfzk2GLt2290VEw/Z9JMBstggEOIA6genawjcfpfuqxkVMqyWUttJa8anb9FXb66mOs Fb5YNa9/0tyBk9QZdkVZArg1xuH7ycBujiADXbVWco4/qnYB9Pah47GXOtDrIDJ2mPpK6M+sZ/2o MhhEFqHi5ldF1riyWWzA/dRXcQaVbW2Y7ri+HNMbY5TWNY3HbcHy48shXun7XUW4pGrzLT4KeRiu GI3HeBuB+mmmQBXBo21MpDLGv3E6kQr+F1OvDJd9JjtXVoOV+laxjW+5o1P7yoXVmow4QhVqS5mX XY95qbtY4yGnxVPd5qw+mt9IcHgPB+gU9mNWcVtjB759+qKqaRKuY99fp7HjX95VjUY4KLW/0CLG iQUbQytZ6TgRwVayP0tIc3kKrdZXYJbz4I+I7e01n5JJazSnKYDa6DynIRUjI1TpEJvkkpkxxY7c OQieuSZgIbW7jA5Vi3CtqYHkS13EJKRve0objCTmwYOij5JpCbTk6KAKdv0VFNSUrSrLSqgVis6I hanaphDbrwpgpISArQ6Nkehlt8H+0rOBUg4tIcOQZSCej3WdQL6X1nuNFwcRLTyNF39FovqZYOCF xnVqPs+U5vY+4JZBYtkxHo0ilCRSVVmUE6blOUFKlNykEySV0kkgkhcpJiVJJSyQTJ0kqSTSnhJT FSShJJS4CSYJwkpSRSBTEpKVKdMkkpdKQmlJJSkpTJwgpQTpiUpRUulCZJJS6ZLU8pIKXCSSSKX/ 0sspoUkxWa3kFwkINfOqsWCQqzDqpo7LTu2QnJhMCnTFyikklGiSlBOop5RKl0kkyClymCSdFSxS CSSSl0ydMkpdJJJJC0pJ0ySlJ0ydJSiUyRSSUukmBUgiFOl0Zk3T4Lrhoxc10Grlx7ldHku2sV6A 0DUyHVoPBkyguUpUCVKGsSxOqq5BgKwSqmWdE87MY3cu4qkBue0eJVm1yHiN9TIaPNQjdni9mMEO xJY4bon/AMwVLAZ6jCTAMIbqmvvgqjePTsLfBHdcTTb2gE6pFwKr0Oa6QeUWytgGh1SVbOWRqdUA uaiNaCZPCG9+sCECgzpgQoljhyFLeQQQrN3UHWM2EDiOEOFb74RfYbdgsAG13CG/GsbyoY+Q7HeH tPH3KednHJMmPklS4ZrCLaU+0qtu8ZSrcN2pKFJGVtbHAcaJQQpjNLazXyJQxZucHIL+JfUcotTQ 54lwb/KUX27jKrWPgapKMm51BjbB7HAnyWlhbH4WwuG8fmlcyww8R3K6TPrDBXt5jlOC27crqYFb mvHwQKYa6eZRMy0PpLHDVp0cq7XSBCQTLYOjcWFkAQ7xVC69n0bgSPL6SuB5gRyFRybn+oCGgn8q YWbCWizbvIYZYVZsYzbtTX0vf+lAE/nNb+aqwu7FAFnlE2ow0+KPTY57oQ2AtfLjsPLTG5Gprstf JLUyVLgKbNoZAaw690nT6WusFCFO9ztpA2+aJSNzS0p0dmrk+YtTcSl7ok8KTRqWnWCiOIiI0QtZ SXFEuHksbNd+ld8Vv4bNC4Lnsoza74p4QW50cVuyquzwfvXpDv5ojuAvPuh0WOuZbsmtpgvH5q9B LtrC4cgKUbMM+rwGY8WucLHFrwdA5BbjscdX6nlqs9cvsy8ltj2Bum0EfnqpfXVtBaYs7+CEl0dk b6Gg8lM/HbtBBg+KCS5JoLtHHRRsltutpnTWAqz7rJIlHrEcFRupYBuB1Q6oaTmF+oUQw+Ck0OBk IgyHjQwfinIds+7APjCwYMahb1ZJwyeCss5T26QE5SCmWnifJbPTS4OO5u2eFmDOeOwV/p+S69/u EQkKQXQY3HxCQ2vc52u5UmYN17yGAhhPf81BfnWV2OAA0OkqdvVMq5m1zg1p/c9qlsLC3jk3Yo9O l4LR5IGbY6+gW2auBiUXCwvWoLyTAQsmG0lgBIn6X7qjnSyjdsGN3VAqrkUkt05VzH1oBTHkDxRG zX4iJFs9Xxn+jjWeqS2W/wBhS6pTbXm0W+ruEaOH5qjZiOZAse3xDSgvphstcHfBLiDY4jejD7W+ vOdk+odfbIQswvy3e8yTwYhChSLnH5IHVmpPi5N+NjWYoILHT24UX5Vw6f8AY3EEdjChXqYcYlDu Dm6HUdklU63Vaco4GO8uDmgt935yf6xUZDmV+qQZboWrVou6dk0squG3Qc7tu5Z/UsWyl/ptBfWB +jdz7U4i9FkiQCQ1qK8mzoz2hwLWnVpHu5Sz6MqzpNL5DmtLf6zUKlllj/QYdu/QhWLcA1tNRuG0 HWvtuTbrRYMhI0DLrNWWPst7nNIBG1wH7yuZ5ubksZaQd4kFqzcyj7MGVXWzP82JlMxr2WMfYS7Y Qdf3UpVSSZHo2WYBzfY0gOa4tgrTbhvoY7Hd9I1nVUhbSzIFlVwY57pY149u5ad11ps9S6ytu0EN DZ925MJuNMh0aXRMLFvbLj+lbog5wADNZAe6rcPzkK37VWQ87Sx3D2tTm9tlPo3vDIdvY6O6BJIC OIWmwulZGOXXGCwA8cpZT4aX8cOU8frnoVmptjHeBO5AdmY7hsLgQW7XO/N3JSN0gkArU9JtutF9 UFv0vNWLHAuB8WuYpYPVGYbYFjX6ccKrbmUhwse8El5e5rfzWuSkeIIMhejWdhWZrGupaXR7dCiZ GM5oLniHsHuaU/T+sHGtLWa1bi5s+as52dVlOssJDQ5m0Cd0uTuI1S6RH1cB5DjI4SNbjq1qtU0B rQTqSmu6nRiSwtL7PL6KkthGK9Sg9J51IhR2NLttnCi3rTCfdXA8irzX13s3D3NKbYK72uoRuzHU BvpQdv0ZQXdQte8uENceYRmYzPU2OEtIkKpk0tqILdBMSojwg0yQiTuyeLXONhjce6EdTLhqpGJj cZ/dUYaTEmQn0voMXjspU0OvftZyouLY0KtMDKtrmglzh9JpTSaCDHVgcG9msd4EFIVWslx/N+kC VbfVZt2CWu+ltcUGyl4YTaCSewPKZqV3Cha4keu1xbGiFkNbb7r3O3H8+FbrbWaXs2uBbrtVpl73 1ek8AsI4j3JnFv8A1V8Y8WjlUVUitwPvn6LwNWoQx2kHa6SB9Fa1NIx59LSVB1DXWeoeSIMJhyhs fdpNXGabWbFmkmpxb2nVaV2CyNwJCoWUxqFJCjr+815wMTRRta0mW6eSsUP2PBTHHq9Le18unhIt gBykBtbRZZTdtkjg6qI10R7nCytp7hUnOJ4TkNi51NbYaS5/f91Vd5crFOPvPu0RxUGcBNtO7QDb DwCrVOTbWA1wkA6eSOE4CHEuEUGRZ6hLz9IqqCDwtA1A/JVcjHLSC3ukCog7qbwok6ojqjW0HuUJ ySkgKPWVVaZVmtJa2GogQwiBJDJqnE6KLVIBJIeq+rt/q4pr7sMKr9ZcUlrcgdvaVW+r9/pZJrPD wt3qmP6+O+vkgSE/cJgak8Qm5SExryEgqZFFsqTpkkFKTJ0ySl9E6ZIaIKX7p+NEydJSycJpTgJK WlOmSSUpJOkUkqSTJFJTIKKlKjKSl5TJk4KSl4hNynTFBS6Upk6KlASlEJ+EklLQmCc6JJKW4ThJ JJSkk3CSSn//08tJIpLObzBw0VQaOV0hU3Ng6KSCJJwpKDNVNApUknhMQgpXKSSc+CSlkpTpAeCS lkykmhJSk0J0kVKSSCSCFJJ0xlFS/kmKSWqSlwmJSSRUoJcJJ0lLcJ/JMpNEkBGO6C9R0SqKwT3W jnuhsIXTGbax5BLOMuACvhpZNWookpyolSBrliVn5roEK+VmZxRkdEDdz7NUTpLZyQfBAsV/obJe 56iDOHZA/WJWdnNPrOV+f0wKq9QbF0+KKJ7NRpA50Ki8yY7qx6JAkhDaJshIseORO6Zh0gqJgnVF YyRKi+tJkMbQvaG8aoMlxgKwKXP0C0cPpNhILhoixjHrq5leIOXzCg+qsGF1b+lte2Cq1nQ2O7oM 1B5y7GgAtVbZ4rq7ulkNhvZYN+O6pxDhCaiUWm1gPKM1wGnZSFXdLaBwgoRK8Sq1x7KztVa1pnyS SQgbo9p8wulz3gBhPELndvuaTxK2epPk1tGuiKBoGo4VhriXiTwFWYwyqGTX+ld4p663OcASdUqW cetOvvaDEqrc8z7DqqF1Lg8gnjuhWMcNdUCGSM6lo3ce81En70L12iz1CJ8lTfe7gAwEXDDrnFob Oij4W2c2w/dTvyG2HadB+af3f5CFtA51nwVV25ji2IgotDXGUaWSyk+beYwEeCsVacJU9HstaHVW AyJQKxax+2xwbrt3IUxhlXLnyi317Invqmym+iJa4FyoWZNk666JtEqJrR1sKwMDgeCsK+PVfPEq /iZTnuDCs7I/nH/FSrXV6Ebm3NLN3ol0Oj6Er0AxsM8d1559X7XV5DQCds/R/NXoVkNYXH6MajyU g2YpvLdcz6spra62Q1n5zvpLnSxrj7tAtjqt2Oy1rcYbmPGoOjq3rPbiWtM7ZakVW57mtBIGqKzF da3cxpIHJCLlY2525rCxngTKnW2wM2UyD+dr9JMIZLa9Ah0KL26mAdPBXKsO3dJE+MJ8fqz8LcwM DtSNUFW5zExbMlMbAXExEnhE3iEVOvj64bgshzZ4WlXltooLI3SqO4nyRQEIrd4K/wBOiqyX6BVw SURo1ThG0lnc0G50cHhRADhA5Wpi4rLYDgR5hbN31cpymtNJ2PaP85ScNasZQdNrsZi+k0S52on9 1Z763ehYzggqx1HPzGFtN4DTWfa9vt3KvXcLabJ+kVFMIMh8vVrYxmmPApOOo+KbE/myPNKzhIbN Kek2znn9Iw+LQpVuDqnAcgqHUB/NO8gghljS6xoJbHuUTfwtcHaSnfaHcIZrkz3S9LupBsvSesNE xsBBCH6RTeloQip6rEybThhjsfewtjeAm6f1bHx6hRkhxc0+HCodP6/bg1MpMFo8VfyWs6ywX1EV 2s0ew/ntTmIns0bMhlmc2zHEVEj6SbqFLjkurjQmd0KvfQ/HtbXZyTytPLuFDvTG4iAZ3KKehW4z qdEWbgUZzay+zY5mh0T+g8aDKkRH0FHJyfRxPtDQS6VGjJfaxry8N3DukdtWb1MLemMvc1z7wdpn Ri2W4H2qpzmP4EQVi35VmLU61pa49wFco25dQtZuaY9w3fSRB00Qb6p+lWbcUNdqGuIhZHV3Cq07 m7t30Vcsd6tD3tLmvYfoz9JVcJ1l1nucAT+c73KMA6ljvWi5WPkspc3cBzqt/L6M8j16y3Y4bvaU B/RqqrXPseHx79rQjWYbMkh7Q5sj6IT4yVMA9HNrtDBt2z5oVtxLSxtcn9/yWvV0phH0yAJlpH5y hTUWNJpc7adD7UTIHbdbjFHUOPgZjK7mtfG0+wkj6K08/pDcZvrMsa9h42qNeC3Fab6xL2nVr2oe J/SZcwHf2P0Uga1XSIJqmFV2m08oWVgtyDu+i7x7LU6lS0NBaBE8hZ4Lm8FIHi1WjLwnhk0B0kg+ 54haOPjCpoYwFM19hMAiVZ+01VPa4SXgf9JA6Mscgls17XvreCGkxoqoNrsit22IcCZ+it1+Q99Z c1vuP5h/6tKh1lwLDXLzwyf/AARN31pcLa2Wy4dYq9rZLfDRRw6rh1a5oa2S3iELIoBa6072X1GN Xe4IOND2vyXud6rfzgdrk7iVxapekV2B2UwtboTOnH01SotZsAf9IHRXcZjJNvua1303bvpo1mHh taSOT5oEgrtXKszHvOomEajLDNSwknuCpuxag4MfW9pd9FxRK2hzNv5zfao5UFDdmwFz3Pe4NaRr P5ycNbt37gBwFVgvEHU+CmcbeGizRwUe4LPDSQT7mH84KBc3xCh9mrPZROPX4KtQdULvcwtIJAWX Y7UgOG2Vo/Zq3e0jlZrq9r9vZWcVU5/Mj1MAwDUOCMR+KA97gdvYIu7TXwUzViaQPcfoo+PTPuPC q8uWsxha0BEmkAMQ0BOQpHzUhW/90lRr0ZHCUIvpWH80wmNTz2H3pJYRCkWy1S9F47j71JjddpiD 3TCuDQtcILe6plWriwbgImVVKmjsxldjlbrGipM5V6vhErU7EUILUZoQQzCIFAKSBXBJVb6NrLB+ aZXdSHgOHDguGdQ709/5pXV9GyPtGI2eW+1PitOht5PqFH2fIfX5yqwW79Z6Nr2XDg+1ywQfIqHJ HVsxNhmBu4Tmswhh5HCn6p78KMBNrFRCeUwQopVynCaUgUKKl06jMJyUqUoKSgCnJCVFSk8JgU5d 4JUpQKTkmgu4TOKVKXCblPOmiYFKkskyRKbcEqKlyUuVDdqpbo5QpSk8JSE09kaKFynTbkpSpK6U ppSkJUUK5SKaU8ylSlJ+U0hMfJCkrpJAjlJKlP8A/9TNaJVz9GwQRKDW3aZUi7cZKojRuFmXsP5o hRJb2aE/JTEFK1Luc2PohQ3AjgJ3NMIZBCVqSNeAOAo7xPASDZCi5p8ElKNg8Eg8cQFGFJo8UVKk DsoB+qk4gIfJlBSQuKE90KTggPmUQpkXqBJPCUwpDX4oqWa4ga8qXrECIUYTEIJV6pTh5KHBCk0w kplvTCwlM490ySly90pjYVFIeaKGQeSkXKPPCRhFS5ej4k2WtaT3VWJ4Wj0irdkfBSQGqyR0e0xG 7WKtkD1HHyV2sbWIWK31S4q4GpLdzTpyoEo142vIQCnBgLFyy8wyVp2GAsfKdJKEtlRaNhWx0RoZ WXnuViWGQtup/oYzR5JgZgdGxZbtu3NRc17bi1zTB4WYeosGrmH4quOqVkmUUEgh2rMN1bN7jI8V WrrBO5Vh1jHazYHOHkojq9BMD8iSI0HTB28cIlTDa4NCzj1bHbyTHwR8P6w4ddgc8mPghbJb0+Lg 10CSNVa3t7FYrvrV01wgvP8AmuWPb1rDrs3UWnaeWkOS33W29VbltZ9HUoFfUmuEOEO8Fgj6x4YE 7z8Nqg/6xYTzMlvyS0S9LXe6w8aJ7qmXCHiVz+N9ZcKsEOef80o5+tPT/wB8/wCaUClHmYnpGBws 41xwrmR9Zen2AiXH5LKd1jGJ0n7kwrgQ2wNFWyGlpUP2tjjxUbs+tw3A6FJRXABcJ4nVabmQQQdB +asE5dZcAJkldHbDGNcOY1TwxyNBxHND7ZHErU9Cyy4VVlrBEy8cqm07rQT3K1vsnr3FtlnptA9p 7ORO7WgbJcTJxXm0+5s8FHpw7hW51b2bgPouV6zCx7nbbCdze44c1ArxhBLDDAdPNMlIDRvwwSkO Jr012X0F1gDXA+CsYz6unsNxaHHmQpem+1rmsPtb9JVXYjCwiSAQohkpd92mNQ52dnMyLzfU0AOG oT4l+92wgRCrXYew+06eKs3YLcdjLK37i6NzVIdQx8BBopMcfS9MOawH3OB9qYmv6MyrAruiG1OA PgdFTdTseRcNuntDk0shhwi1nNFeuyR4yoXBkidJCl9ogbYkKNpFo3EgOH5qQGrAZAssBv6VVHNB sd8Sr/T2k26cwVnl0PfPiU9IdLojnNzGM7L0BxIYTHHivPegndnM8QvQny+pwGpjQJ42Y5vB9ZyK svLDqa9j2ja8N/O/4RWLK68ljAbNpb9JvDlHHLh1KHsLXNHBQupmLnyySeHfuoHekJG5lFA9E17m 9nSrLHYbiRZXLSOGO925ZDpFYJI+H5ynYwmI4Tl2rdwKhQ5wmQT7QfpbVUyOlXueXNAIJ0Mp6qy5 7Q4kNPLlfOBWC4bjAHtO5AQO6HHPR7/3Y+aEcJ1Ltr1bDHMmSTBVZp3PlAghcLSFge0AaEIfoeJl GENbKrveSiuDMVojW9wgNmVZYIT4qb3Tsuyi1o272k+5v8n/AINd9RZU4ez7l501z6nB7TBHC1MT rDw8erAk/STjGwsOj1HVenjOpLBAd+a5cWam0MsZbAe07QF1lPUHGQ4gu/Nj6Kw+t015UX1fzn0b Wf8AoxMMTVLTRLkYWrHeKk8aFRwzG9p7KZdCbHZp5Pnbjn0ZNTGWOLHs8tyD6LNQLjB7bVTvsLoA KW3SZIKbTYxiRF/KkPS6OfWP3FR/ZmPE+ufuUA0kRuMqVJPdKl/DPuzHS6S3f65hPX0ul+ovMDyU Jh8DutHpbKnucyxsz+d+6idBaJExIB/SaJxdz/Tad/mtDHyL8cta2Aa/o7lDqDW49rfTG0xyPouV R9rnclHQ0sjLhJ1bPVeoWZrmG0NG3jYrmTXVlGu2u1sBsOBKrY7aPs7rLRvsDoidvtSZ9ie6H17B HO7umEcR/uskbviDoU2NrqNRDbKz4lNOPH8wyP6yyG37ZaGaA6KziW0vYReNpB9o8k+iF+rfnHH+ BYP7SuUvrAAtrhg+iGrJYcWwure3bAlj935yHm5DbHMLHSA3a6CmWVWW0+vZ6/at4/Rg/SVHpVZb a11rDtA+kjm3F9MMsmwDUEHVqsYmVhGabN1dcS0k/nI1YP8AWWmOts8yysg7OSCs1+NdklllALhH Y8OVzGsqDXsL5YHnY530ixD6f1D7A8jbuYHGNv7rkyAMSuG2rdbMFrhDvzllWV231j0pJBLTtK1H 9Rqy7zYPY3aB7vz3KrjZLcS5wAD2OdvRBqRKRTNgs9BzbP5wN3aqhRRdktFrXNBH7y28q8ZNu5jC z2Oa9zu6zOlWNaxzCQDJ5/dQkd6Yz/zUHrPsd6NkCTG5G/Z0tcQ/Vvb95VMhrRa4NMjyQzp4/ejW mjVkRxUfU3P2bu4fHtnhSF9FOMx76g927ZunaqR2HUEz8VbwrGDEe57A8Ndw5NldatmGmjYa6i4g 5DfT/c930kRrKKrA7FJ9b8wB30lXqvqyh+kpAb+a7duTUtfU8O9NjQOHtd72oxtsFldaXvtqvrLL i3cXE/SWX0lwLnteNwI1atm02C1r8in+cGxtxdP9RZmKxmM2y6Je15bH8lNlpYWEJar23M9JlJFX 53u9rUB2C4mGsG2ZncrbHMLQ91fp1OOrg7RyldRhAAtOv9b6SUdGRbKyrXsZZk1ufW0wyyVm/pBc 7YTtI3bStN1llbRiXVubW7VjXO9qz63Pdb6rwGge35JskKqDnaNhpHir1wc8jfYHPjnwWe9zS87T IPgnNBYwuGrSE0FkDZJYNNwKG57PFZzfo6pEqAwsunGfpDd9Vo1BVLNc0vDmFKQVUvOvwUuONFrc xIEBa46z4qbBvHOqE9pLQ7smGisBpKaPd8Fr7gQIWW3xVmm32x4ITFhQbDipHj6RnwQwQ6EZzRGn KjXo/vSgEaJwRwptDWjcTr2CSUZaBypFwaw+aGbJ1VS67cZPyQEbTdMryIjuqoRAS4a8oamDGV28 q7XwqjBqrdY0SQnajBAaUZpQKEoSdwmBScdB8Qgud+zH/VY8BKX1avh76T+cNwWw3HD6CPFn8Fyf T7/QyGWdgdpUpWnUPWZrA5hkAgdisoPqcdGj7lu2tDgR4hYT2trJafFMn3ZceoZbahywKEs42NA+ CkGjlQOhUVstM5qPDW/ch+wnVgjxUgBBBUCSBEyEhJFLvfUzUMaSoMsYZBraE4YI0UY8ErVST2Dh jU49M/mBRY0EaqRahaaXLau7RPwQ7TWyJrEFPEJWskCeUeJVMRtifTEJ2vp52CfgoyW6dkxrEz3S tFMw6qdGgSpfopnY2VENMRCUDhDiTTMMpdywIZFYOjGqURwoOJBhK1Ulio8sb8kMspnStqiQeBwp hohG0UqGN4ramFdMya2lTjzTGvuErVTE00nUVgKBFI/wYU3vgRMSmAgS5G1Mhj0OEmsKLaaXc1gJ 2Og/yVIcoEpXDaRp6YUTRQdRWFIKQQ4lUhfTjcmsfJN6WK4fzcHwT2EgqIEGSihXoYxEemEjh4x4 YjNE6jhM5g5SUh+zYvBYkp2AN51STuiH/9Wo0aJRCckAJmulUm4yOvCYA904UiE1KznRwh75KdwH CYMakplIhQc7wScYUCQElLbipzootcnlFSxMqLQJTlw7KPIlJC7kAnVGI01QyI1KIKWJbKW2U4TO O3XslalgPFInwS0PKjHYJKWI3cKYboowpxCRUGBEJinKiEVLcJydNU+35pj4IoYN0KlyUhom76Io ZNatv6v1bnl3yWKAun+r1O1k+JlTYhqsns79p2Vk+SB0l/0h80+a7bWqNNpqMhWRs0idVZLt1rj5 oBUnGSSopzEgvMNWPkOlauU7RY95KbJdFqxucG+JW1mgBgaOwWVit33NHzWtkjeCUIr5bOXa1wYd NFR2rYcR6JB+lKzPTRIY+Kgi2jukIYZ7K3XhusEjQIW5lJIcJcE0qErYum4aCB4lCdjkDdyPJO+5 1nPHgk0uGoTWWihICaJRHNJ+aPj4xekuCBlBJE6A91K/E9Iw0yrTsQ9plM7Gf+ckupzi2DqE3Cs2 1QgBsoIYhpKk1sHyT68dkwbrokp0m4tdokGEP7HtMSFGuDwdpUbWuH0iUVWzoracljORuErqc6kN G5vEcLmelM3ZTfJdF1SJAYZ8U8bMeQ6NHEG61vxWjbhNde51xO3/AAexyzsOfXaFdNWL6j7L3S6d zdpTZbsOCNyo/vM8Wk5HqNJ94Ht+CHVdXSza6Se/9ZVb8h+/7RjAkDkj6Tf/AFGhX4WdlxdQx0O1 cYUABk70iIx30bTc01sNbG/SP0lOk1ubvfo1vKBd0fOFLWAOPjA9zUzcHKgNfU4NGv729I4yiGWM juwyMb1Wm8QGE+xv8lZmyHhs8nRa1mPlWEk1OA7CFRtxthLXzuiR4oRJjoWPMBL1D9BubbawPdoq HVN5c2TPzU6g1wG8vcYT+nU60NcCGnQbkdjbBO+FpY9e98HhHvpaxm4aGYVuuitlh2iSNOVHILLW uZBaW+aHEb8GtWjPpGOHvJsdtaRoVhZLNlz2gh0OPuC1umu27iZ4WK/6Z+KmSHd+r4s+2M3t9p4c u7vJbS5zTBA0K4L6ute3LYTJrP8A1S74tFtewaTonjZjlq+fm/JOYbXO3vj6YCs4173vfvOpHubC 7KmpuPZ6YABjsPpLH+sJFdzS3Qka7R7nJpkLpdwdXlbg0DaAAJ/tqUqN5nWRz/bTlOCW8+4uqgcK hx3P3q69017QqQ4mE8laG44l9J17KhXo3zKvXkspHgqTWmAeyElBVugACByiXGShhNDImrHiFar0 PGh7KtW0u7rTLwW7WkfH85SgLSgdDTrMJtgWjg5lD6XYeUCA92lzdU3V+mDAIfSC6kj6Scttr4uW 7HI2jyIW3j1Mc85MakQuZYddfiug6fdFXv1A4StaXF+hkWgcIFlilv35Dz4oF3MKqSxSjc1uHR81 aY4HkhUnmCD5KTbpHaUo7NoCtk50OiJV4qn67j2CcZDk5TefWQdxKu4rxRS6+JM7dqxRkPnxhaeO BsdcDBH5qR1DFMWQzy8wZbWjYWlqrNc0aFWMWyy9+ypsuI4SsqsosZbaNrZiT9H+2kCAxShbRLv0 wbPyVkhR6i4OvbY0Dw3t+i5SKMTbYjHhFLJj5p02icuW8k8JpT6dkFUpJNITjUwkpUBKQm7wUpCK qXgFODH3qMp3EQgh2c7GyML0wX7mvO3hZuY0VvNThPmFdyHiiiuyt7tRw8e1rv8Ag1Qdc20y8y49 1GRRY5A9GvUNvwRnsc3kQhAeCs49NuY4sadQO6JawgDd/MwDpbG3j85H6Y/YbQQHCJ2FL7Bk1gAk QToj4GHdTabngFo9pCZMimcAmv6rCjNbboKGhg5M/RT20Pc87W1mv4+5OzNNr3MZQ3QmQqTy8kww eUIQbDp3W3hjLX176WkBri76P9RVKgK7r2kBzSPUDCrTPtdmJuFYfUzlpd+7/wAGqu4OsOQBqa/o f98QmFq1FjclseiPTHPu9rUN2MQ/21s2zodynTcLGyKttfLyCrRGGWSIhIaL6RX5FpDbrai+sHa2 0u+is63Ce97vTfoTO2VesvfVUA6txxiYBk+mgZLRRmgNnY5s+0IHQoAtr42DZU9xI4EwpV5l5pc1 gBYfpNPKs22VseIeQ49nt/NQMR9VTyLR6mpjamEWdV4oOX6lbP8AB/8ASSORX/o/xWpfVRdZ6jG7 WfulI4lJ4YEpGMd2eGOU/lLk12Na7c1sEeam+0FxcW6lX/s9TTLWwoXVte34JvGCV0sEgLJQ3VN9 Dc3g6qgBIWjUzfWWhZbpYSFJjvUNWSpIUhYe+if0tzZCA4EGFKtdJllTK5eHC3839yEwunUFUZdE Tp4JhI0CbwrrdH10J1/mqexxUQ4jRLhVxNl90oBeSfJQklMnUi20wdlA6FPWUnjVBLNgVpiBWJCs NSQWbUVpQmogSKErSk522HeBBUWlSInRNS91l5TW4jrm8Fun9pcTEtn5qweoZFmOMV8emO/5yCE4 yVEaPaYF/wBoxmWeUFUc8bH8fSQfq3fLH45OrfcFe6jXur3eCJ1CYGi0NwdoRBUXRolIUHGSCFXL ZSlu4ILvaEZvgoloPIQU14MKdYPKjPYKVTjwipknb+CiAZTmQYQUqYUvpNhRd7dVNhgoWpDWA7Q8 hF3FvCgSd2oTl4HKdalOJIJ7pmmUzjPwTMIGiSkhcYiJQ7GkN3FGEqBETPCFqRNtnVF29zwhNE6h SOoRtDMwotsjhPW4EQUjWOySmFzJEjlEaRY3jVOGyNNVANNWv5qKl2jsncICTTuMhTI7IKYKQKRB UXGdDyglTxOqjHZTEEQUIt+9FStW8KW4kGFEa8lTaEbQjIJ7JKegMDlJG1P/1s7Y4nXhS1HCVZJ5 1TyqNtxQsISlx7qQaogapJYlmuqnwPNLvCcwgVMYHKi5s6qcDgJoSVSzAk7RSOgQ3FJTDRT+CZp7 JEpFTF5khQOqRJJUxz5IqWiFAlTcQhHUlLdKiozKfXhRI7ooZABImeE/AUWpJYymJ0Tu5TASnBau zjRNMqREDRRY2UvFSlIcJ9o7apAwlaViZXadGr2VD4LjqWb3tHmu7wWbWBWcWzBkLHPdoGqiQreX q9ViFYaR3RqJUnKJTlhaWW7RZFpWlmO10WXaVFLdfFN01k2F3gFY36z2TdMrJqe4clTbTB29+6cF 8tmT6ha2GaGVVtFOMTulzlbeW0Afiq1uObHevX+kb+c385qG5phkA577Xky32tPYIW0O81sfYKsl m+l0O7scFR+zOrJB5RIZYgBBUwEw4QERlLrjsrBJU3WiNvJXb9A6ayikWuEvdrKVACyvtw+n/VuR 6mUYH7q38bpWFUPYz5q3l4TL2w/gaqq2yprhVWAB+9+ajd7KbTsehgktaAhuw8ewTsaQVWvFjXfS 18f8G5Goymshjhtn/NTSEho5v1bxcoaSx3i1cn1HoN/TDud7quzx/wCjF6NCHdU21hreJaRwmlL5 c4ACUE6arSy8M4t76vzAdEraaHAbTBTVNBtsiCJUyTzz8VcZhfnNG4KxbhhtXqxuHdreUUEMOkOp OSHEFsD3BbfVcig2D0dWxqsvojKnOfu5I0/kqswmux7TxOideiwjRt49zKn7oK08RuO6t7nsDi49 /a9qxWCZITstIMCUCqGhsOgMMVvmt5aTx+7/AFFst+sLKWitzDuGk9isEXOsYWkQ4fRlZDq7ydWk oVWzPKcpbvcs+stH5zXD4Kf/ADjxf5X3LgTXcexTbLvApLKfQR9YcQ6e77ly2dgjLyH3MeGhx0lZ Arv4gqQ+0DxQ3XAkOs3p+TUAPUbCld0POymB7C14b5qDL7NjQ/sj/tG3HYSwkA9ghwhJmSKadNNl RItDd0+KHfjWEl7dsEcbkB2YbXlzhEqdeQ1sgJpACwy0pni1vZW7yasEiTK38R+5tusCFgp6novq 5c92RXVMs1O1dpd/MOI0XD/VkzmtH8kru3RXSTG5vJanjZjlu4Leo5O0Q4ad4VHqGVbdYPUdJA7B HddXc8vqbsYfzVTy3fpIk8cD6ShiPUyn5XJuMiNOf+uJRMBSv0b257/ziYOZH0gplgbji4tiNB3V P4JbwPzvxS3t/eCJKKZ3kO2tHPdJw2/JQaS8klK0w1C0hrOKTBqmlEY3uiFzYZWSNzSPh+crRD2V zpHdVgIM8KzU8tc1512mYd9FShaXraqGHHYxzWPgB0gJXGanMPcbYKzXdcxchzWPDqbOGvZ+a7+x /glcyWyGMe4uMbjI2tsb/wClEQxvKPqdj2bLOe0furTtsOPjbh3Cn1CttzNILgfY7/vih1aGY7GD k8oSOiCXFxJNmvJSuYdYSxtLQrNgAVcC2GUqkG5i47AGlwBMfnK9XXj16lgdI4CqMHtYVZAA4CjJ o06MBcQWT66XNgMbPwQvs7BoWj7kThPJcddU3iK+kXoVjhoSFDR2hFITkBCyqghFYGo0PiE76w8Q /wBw80WEyVqoIvs1cRtCRoYeQjJQjZVQRei2eEvQZ4IsJ4SsqoIfQb3ATeg1HAS41CVlVBF9naOQ mOOzwRydxkp9qNlVBB9mrHICX2ev90I0SlEpWVUEP2dngFNmLXGrZRWM3ENWvX09wb8U4WVpoONY N7BU7Vg+i3wTnCrABLWmey0vsv2Y73AOUNrD7xynUVunZy34jBy0BM2hrDLND5K1c7c5DAUZJXcI 7MNpiCTCW0jWTqiQkGk8aptJ4Qi9EfS7nlQOMw9lYiEwCKqCJtZYC1rnBp5Y0+xyQpaI040RtvcJ +eUtSrhDXroawFrdAeR2Q/2fQBG1W9sJ0k0ERaXVfZ3EmocMTGgFzbPzm6NPkjJwjuigwyW/ay11 0FzPouQR0+hpLmtgnlWSE4RVTW+xVeCf7FV5qwmhNIBXCRGyEYFB5CY4GN+6UeUxKIAHRPHI9Xnu sYzMGxppkNd4rGe3c6fFdX1un1sTdGrCuaqf6ZBhO21DBJJSfZt81G6gvO9o9qeppMl2gKNq4ASZ BSpTVNRHKhtHZaW/xAPxVe1zGauCNFWjSeYQVdLqXcgqJ9GNAUVrUU9shG3MHA1TG1v7qCmDCj7N zfNQZDhICJqECuBZVtRw2FVDy3VWGWh2h0TdbSaShSCYBOja1mFNqHwiNQtVM+FMKAU5QS3ek3+h lsMw13tK661gcCPFcIXEe4cjVdzj2+tUywdwnwOlIOhtw42y3zUJgqzm1+naSPzlWcZ17hQSFFsg 2FaorSChHXhJpjTumpYvaAZUCDukKbz3Ki7Qz2KVqZSTwnLtVGXAyOFOQ7VJSznSITt1TbUxEGQg lk4wUwGklKyS2UJtzjzqAiEFIQo+4fBJj2nkokSkpZkAQUUjcNUFzfBQBgwTCSlxLXR2UuO6jdA1 BUDYNIMoqTHTUKcTqFBpkJAoKXbZtJSmRqkU3KVqpiGFus6IjiAB4lNEiExJAhG7VS7HkaKLhrKe QfikPJIFTIN7hDJgorTPkVG1p0PdFTWc1wPKI15iE+pTbXcobqWc4jXukrn2ZjxzBST+ErbD/9eg BATiE8aapbAeVRtuspB0TbEiAFAku0CCmbW+KjAJTbi0QnmQkpi54anaTyFB8O0UxoElMuUN6fcm cfBBTFoB+KThI1TjRRLkVMAZUiFCdVN+gRKWAOviouIU9vdCI7hEIWOpUolRaCVJoSKgsUkiDKfj VJLE6nVNMJOMKIE6pwWsnFMNEw1CfhJXizJgKLTKXKXCSW505nqZDR4aruKW7WBch0GvdaXLsRo1 W8YoNbIdWpbq4lVyFYeZQHKdqFC/RDcdFN5QnmGlHoxly8o6rOtKuXmSVSeNzgPNRdWWLu9MD6qG lvPKll7nO3HQnlHqyPstTWQNAq9mQ7LeNIATwulro0M07QAi9Pxw79Jr8lW6luLwI4VzAzjgGXCW lJiiLlf7rovyya9oYNzfEaof2c5DfcwA+SP+1Kbfc2tFu6mBXDGgFFmecyH4rX+nBY8H3H81y7zp rg7GYRxC87vosyb/AGiSeV33SanY+O2t/ICYdlRtsZOJ9ogFxDe7R+cgfs5tQ/RD5Hur25PITRIh dTlFziTXWyCOWu+j/wBbeotoNZHqNgLXkKJI7o8SkbGjaNvCZ52hSdYBwqtz5Cal5TqdoZc5z4LT wqeMaMixo8fFD69S9uRvcPYeEDGbTYIadp/I5NCrdbqHSLGD26DsZQaMa8kBpM90O2/JqaGOlwHB BVdmRkTIkfNOVbfwsc+s5sQYWfa11dxB4K0ej3Ct7rLpcTKoZeSH2QwaSndFpYb9dOVbcNrR2VBs l2nitPIO4tjwTZbJxjVCDKccpEQp1iXD4qNmTNxm/nEpq6WPkSZHBVqxvMCFWx3Na47xKcha7FDI h0ykMVnJcZ+Cjo5/tBafMq24AsgclClOaBGhRwwPpcD4IZaQrFbZpfHgkFS2efZoiShsBdp5pyC3 lFhIdDp72DGvDmzPnwsIDRauPpiWO8SsvhFc9F9W8my3JZSQNrASCB7l2z2h9TmTtBn3FcL9ViG5 og/mld1YGupcHglpBnb9JPGzFLd5XqD2Y7xTSQbGxvc36Dv/AFIqjLXWbtz/AHfuge5BDKqxZ6ZJ bJ2Ej3f9dVmquwUy1oPj7tUuEBVly8m1g/RxJ7uP0lTIqI7yuh6h02itjLCC4v8AEqs3p7G7d1Ms JjdvTLvVdxAOORVEiZUG7SYXQZuBhYhb6gI3cbUJ+Jh+jvpn1fAog2oStpjaQGmfNRuMadlIEjUi dEL1mh0vEj91EpCOEaskFNfl0v0rr2fOUAZBHCIK50WozA1xhxhZtWbsPuEhdL0nDxOqMca3Ftjf 8G4/6/oVKCFpcpzNpg8eSLdn5J2kWFwYZaCP/A3oudgW4bw17I3fRc07mLPf7TofcnWtp2mZTM5o ds2mdQPFB6pdWZrc0l4+i791D6Y8vfrMgalV+oO3WE9k2eoY5aBp45i1pKuWjVUq9LAr1p1UMWCe 4b9P81WQrCr45/Qt8FZAUU93TxfKFQnSSTGRSUJ1IGElMYShSSRpDFPCdJJS0J+UkoSUtCUKUJJK WAlSJ7JJQipZPwlCJjMbZa1rzDZSCHS6Zh7R6tg9x4C0XuDRKFk5deMBu5PACpWZ9VgkEz+6pGLU sL3OcZcdFQscXHThTtuNh8kJNkV8Qu0tE7myTx/JUOFLhLnlNXrQpNJbqNEylGkpIYk7tTymhShP CVKYp4Tp0aUwhKFJPE6AJUpjCXKeEuElKhKEk5CKlkykQmSUxhMpkJoQpKz6xbTYw9wuJDYMHkGF 3VJ90eK5DOp9G97T4pwFhjkjB3D4Ioc0Kq5yj6hRBpY322MiTMKtlWsc3aBEIAsRGUOyrBUz6Z4R tTWDgn3Bav8AzbyuDAUv+bl3BcE0kBdRcYuUHFbw+rb/APSD7k//ADaPewfchxBXCXDpft1RPWRM 3Bf0+3036k6hVCUUbJjZKW5BlPKSnVpO5koirYLpBHZWHaaphSuSptKA4wpsdKAUU4Km1CCIEShm NdF031dv9THNR+kw/guZWp0K/wBLK2Hh4hKJ1SdnZ6mz2h47crKJDpA5W/k1b2OasBrgDt7puUdW bGbFMg4gCU7iOUxBISb4FQMinHSQmEDQqU6Qok8SkpiwmS0qNY2uLU9ggykTEFFSQFMTB1SDt2qY gkoKXiSY4QwBEd0ZjdUCXB5CQUs4A8ozSBwmk9wFKZ7fcnKVuPggmHFGPKgR4IWpZ0bYQS1scao1 UumdEmsa5xHPkiEL1E8EqZQCC0aeKMDPKBSpplKwwNEg2FICQkpALyD7hCLvDhCg5hCWnI0RQu2R onEh0HhJpkSE7hOvcIJZHhSZZI2O+RQwDM9k5I7IhCzm+mZ7KbMuokacIZsn2lDDQTA0KdaKtu/a qzwElTDCNY1STuIo4X//0KiiZ7KfKQCoN1hJCdvM91KZ4Tkd0lLd9VFzQEi/w1Q32dilSrWjXRTc BGqizUqbxqkVMCNFHkwAncYQmkkykpOYQbBtUyhWGTqkFLNKdzpEJmtgp92sIpWAPihuJCk5zQZ7 qJcCiEMWgoojuhNMnREI8EioKKjMlSIUe0oJYu0GqiE5HmmaNFINlp3U10KUTqmbopdkCpYaJynD PFNqiN1PQfV6r2l3iV0r/a1Y/RqdlTY+K1cgw1XYhqZDq1XITiiOQXKRrlE5V7nQ1HcqmUYCJ2Y+ rl2mSgUM9S5o80S0qx0er1ciT2CiG7PF07y0mI47qDazW4PGrfEKwKQ55BUjjvo1H0T2T1k7ty8l 82HSZRasd4bLva3+UrTC4v2VtAcfziiPwLJm0mUNVmpOjQbTSTwPkjna1sNEBWWYtYMEpvswn3cJ zMPFz8dttdk1EEH/ADl0uJlloDbRHmqFeCXmaQNO7lYa7YRVdG48EFRmv8JkANOvMiQhvdCq1Wms 7QeOWlVsvrDR7Kxvd5fmobIbxuSDyVjtzbSPoiVLG6u3d6dwDT2d2QJpIDrElU8i/boOVK65/bjx VJ7w3U6kpupXaBxerte6C489lm10SYHK1bnOteS4aBDNMwYRGi0i2u3JAHp2iR4/nNUXYxjfW7ez /pNVn7K0/SUBh7ZfU/a4diixSiei2M2ap1iVnXna+B2WxYT9nFh5J90LHyBpPmkV4ZY3usA8StS9 u1+1ZeHpc34rVyHTYShLZfDdaq1tc727gk2Gu3AaTMI9FdT2+9pJ8ihX1it0N4TWRM/NDp9pTYrg GEObIGoPcqsojN9ER6gA8CldqpsOtNrw4N1HAVh+Rc5pbZWIPdqzftzbDIeAR3AVmqwPYS14cipF tPZWK/5l/wAEAt0VgCMdx8kAiWzzbHEfelY+QSoN8VCwykxugwx08+ZWYD4rVtAbgD4rJHCcp6L6 uNrbmjYd3t8Nq7ol1dZcAJ7A8Livq48Pe1oYA5onePpFdjlwMdxJgRynjYMU3h8y11b7L9zC5zta m+7YtVnSLLMf7Sxvuidu5c69uOK3Colz92rirX7VtNfpsL2aQSHe1ycSno6mcz7QKGAbgRq1pR7e n241LXNb+jLgXGdzmrC6V6DbSy5zhu+g+dGla1jbKyK3PLmH3ANfua7/AK2oweEUgjRDm5VL7g1z SbGfRLVmdRuaXbgCHHkFae30vUucIcR7ZH0VzmRkPudveZKAIpEQbYuuPCevHsu1Gg8Si4eMHnc7 6IV86aIsrSHTwPpO+5P+z2R9Iq0BJSceyCGg7CePokFRZVbU4WVna4fnNPuar0qJbKN0l3cb6wi6 k0Z43Af4QfT3f4P/ANWVrFvuLnlzPoE/5yrPkf1UzrYM9ipIyW07fTBo57eTpCs5Y9HHc4AS76e4 f9QqmN+iomYnWQiYORZe59Vzt7C0mHJTs6sUjrTis0cPir9vKzzo8x2ctCxRx6sOTeLex9ahHirr TGvKzsR01nyK0Bwo5uji+VcpQknTGVRSSThFCkk6SKlQnKSeEkMVINSSSUslCdOipaEkoSSUpKJT pfBJS5c50FxLo8U2iQTpKWhKFJMkpZJOmSUqUk+iWiSlAJ9UpCkToiFMUoTpSkhQgeadkz7dCmTR KSlzzqmCUJ0krcp4SlJJC6inSStSyaFOExCSVmGHA+a5/wCsdXp5G8cOGi6CFmfWirfj13DlphOi sk8s4yoE6pyUXFxbMt4rrHfU/uppIAsrUTGuedrQS7wC6TpHRciqwZFhDYH0Vo9O6bVgt9urz9Jy 0gfFZ2Xm/wBGDLGHdYVzq4yVIMATgpSqhyzluV9LbVF1BPZHY8NHGpQvUM6KaIoWZepFudl9Ox8o /p2mR+d+cufzvq++kbqD6g8Pzl1j3OOpCA+ClHPOB/eiu4QXz5zSNDoU0rqepdMbkje0RZ4/vLmL K3VuLXCCFpYsoyDT5mCUOFsYzy1XpJCzaTqtSkBKZoroCww0cpsEJnjY7yKK0SmCSTFcCERohNCm 0KQljpkNVNjzU9tg/NKTWyiBs6JnFS6re0Dg9oeOHBc/lVelcQBotLo1xuxg08s9qfOqDjPippDi ijGaNOW0Tqn0lRBDHFjvkkdFVIpsLTPxTCSPNTa0btyd0T5IJYNM8pESogQFIJJU0AapnGONVJrQ mbpokhk0aITtT5qcwVKCASkpHrEJ6nbgmYfV+jqQohsE6IqTQCmIgpSOUz3QY8UFLt9p+KDdWZ3N 5R2kEc6p3tJEjVEFCGhpPPKIQG907YbqoEh/CO6l5j4KTXKAJiCpAyNEKUtboJQyByO6m4mIUJRC WbPJTIQmCEcGQgdELBIieExEKRceNEgpEWE6qNRAdDkdh3koZJHyTwhMKCZIjakhTuCSSn//0ao0 5USwzpwizCg52iot1hLuAFPgapm7uylMoKY7D24UH1DkouqE8JBS7BHzTPcApNamewJKQF3zUmeJ CYmOEg/RJS7gq7+UUu3hAaZ5RAUzbxp2SiNU7AAClM8JJRxrqpFslMdExGkooUwAOlTJ8E1cd09h I4Q3KWJJhQ14UyVFxRCCwAKI1spg0nsptBboUSVBiYCTWyfFO7VS4EwgpdzlEN3QPEpvpaq1hs32 tHOqfDdaXrens2tA8kfIPASxRAULz7leDTkgcguKM8oLk8MMkTlQyzor7lmZbtUjssA1c60rU+r7 Adzj96yrTyuj6PjOGJowl5O5NizB0L8qrFaPTG557+CoOyBYZJ3O/wCirT6HuYSRwqLWOeDpBTqY J8V+DJtzCdlw9vZzfpMV3FzbGu9Nw9ars/8AOaqVOO5zw0hXbKravYGw0/nApUEY4yJ4j6W+7Hx7 x7SAVn5lZxQJ1n6KiyqywhjnCB4qt1XFuc5tT3TWNdEwkgNzHG5AFsvyMetobaC5x/wdR3LOyW45 saXMsoE/zjvzUfeWVhlT9hH/AAf/AKNVprQQBkONgd+cdC3/AK2q5u28QOiPKZmQCyxl7QPY7Rrn /wDAfo1Vq6gDQfSaK3Aw5vfcrD8LGvY6pjjTcPov/Mf+4sfGqya7ZtZOvvPZ/wDwimidGiY+spas 6xrw/VpHOiPmTkM3WAEEaFvtWgHNJ9zQApZ1tbq4rAJ8Aj0Q81hdXyekv2P/AE1JP0HfS/sLpbLc bKpFlLS1x/NXN3YN935ka+K2+nZVlLPQvqDmfvtI3tSBQUFjHHRJmI4ahGsaWOLhq381VrBlZIhx FbP3WnVyYuJAR32emdrPc7wCovcHybjqP8GFbrx7KwWt0B7qscC+1wboXnzRAYZykdnTOPXfgEgb Y1Cw7sJzmy08rormHFxTRZo8LMc4loB4UnCCiUzENLHwra3hxiArj9XEo1DDY4MbyUS3p1zHQ8Qo 8gplwS4hZVj301tg6E8qvaQ50jUIv2Gw9wFIYFij3Z2rCG6gOdOkfuq/9gs8kRvTLXdwEgq2iymp h3bRI8FYBrhwAgnyV1vTCzkglTHS7XeAHxT6RbkFsK3a0tw3EeCvDoj3OHuHKP1jA9HCPpmdvKQF LZHR8/a0gQQoMYS4DzWtRLXuNghRyLKtvsIc6U29aWEs88H7EC8Q6VhdlvdRJdghx8VhJyXpPqq4 Ov2gSQ1dtbsNW276H5y4X6q6ZL4/dXcX1+rXt3bSRypBsGKXV4Xq5x22ejigGuQQ+Pzv3FHLN19Q raxoa3XeOUfqdD8fJ+zvIdEOCFc11bv0TZYfphxTSVzU6c307dto3VuHu1/6hXTiUY1gdj2h7Ty3 85iqxY3WtoB7GUbKbVc1hrr2WtP6R35r0wnRNKtvBY9syR2lYrlfmS/zVK1hrdtKERSg62O0NqbC kQTwo4rw+oR2RXe1PUloxW2jY136U8NQLsa2l22xsEKDm7vj4ojcqxulpLx/K+kklrpifBXDXVd/ Nn3fulVn1uYfcEFIiPvVcUGIcfb4KyQgvfHYoWl08eLKxW3QdkbAq2ZG3+SVW6fPtMcladZb9sGz w1TyTTEQDZ/defvG2w/1loWCAPgqWcNtzwP3lfcJaPgkN2tk/RS4ejHBaFerQVm4hgELTp+iFFN0 MXysoKSdOmsq0J0gE6Slk6SdFSyeNOfkkkkhQCflKEgYRUoBPCl8U2iSloTcKSk17Qwt2y4/nJIY cJkxSlC0ryn0UUkrUvKUqKcJWlSeUySSlJ0yRMoKZSpBDUgUQUMyUiohOihWqSeUwKKlBJOmSUop J5TSglUJ0pTyEVLSklKW5K0KhC6pT9pwLG/nN1CIXQi1He19ZE7giCgh8+x6H5NjaahLnGF3GJ09 mBWK2j3fnOVH6tYHoOsveJJJa34LasWdzWUk8A/RXQGqIaKQ1QnWMrg2ODZ4lV8vqbcYEVt3vAn+ SqHCZbBldNjJUDbU53ph7d/7srnb8/I6hUx9QIO7a9lfgtCzobX3VXU/o9sb9fcphir5zwy/dW23 HZlbex05KEeq45r9RpkTHzSs6P6thsfaYP5sJqujU0MdU1zi1xlSmeMCkUWVGczIO1h08E2+q0lr HAuHLfzkOrowrtbcx/0fzQNu5Vc3p1xsJoDQXHdv+i9iMoRkAbSCUtrS3nhYnVsUWt9Vv0hyrbMj IxwRkatB26/mqLni1heOOChC8cr/AEVx1FPP47dwPktHHOnmq1LNjnhWMfRxHir+TUWww0NNi1ge 2EOh06dwjgCD5qr/ADdvkVCCykN0CURoUGFFCfbGQzaFNQClKaUur0K7Zc6s8OC1s1hNbtvIXMU3 elcyziCuwdDhPYhWcZuNMR0lbzQ9/wAU4PZGt/R2FuiE5u0TCgloWyGDRJgqbmwJCW1sgjnuiy0g 8pqWqHGYOiKW6KEB2o5CUgFClL6h0Qpkd1BzogqRMhJTBxj4orQHNMlCMkAhJhLXfFJS4s2CG6NQ gw75adCpvPuTMae/ZG1UlA0UXt0+CkCniUFIqQCYVgDdIQmtDT5ookFFCC4aacqFRMT96lbLH+RS 0bzwUVKdI1TNJmQifSGmqE47ClulKQXSCEEvHBVidJQLmhzeEApZph09gjNsjVBYpOnbCKEpG7UJ NABUGEbZ7pDVJSazQghDJ3Etn5JyDAUbAWQ8coqZA7dCkobydSEkkP8A/9IMbh5obhCLu04UCZ0V FusACeVKYUgwhRQUweSeFFumh1RCEgAkpRE8FAtPblO9xbxqh7S4oBTEe8xCIadvwUWaIjiUVInO a1DcpWGdUIz2TgFMgU4kcpAFJ8HRJTBxlKDEJzAGqiDOiKlHRTEHUpnNTzogliPFRP0k+p4TnQIo TEgAIZcCUMOJClXCFIZtAKk5sqJkHRSkzJQUwaBMLT6W0Ov+CzpHK1+hN3Oc9TYhZtbPQPUUABqo PfLyr/0Kz8Fmcq6GlIsiZQipSoFPDCSwedFkZDpK1btGlYtrpJlMkqLUtPK6XFvfj4rNji0x2XNu G5wb4mF0eSw11Nb4AIDZlDXfdY5xdvJJ7yosve06OMpt2uqFy5IFYd24bXO1JMp2ucWn3Ex4lDYj 02tqklocCIgpWuDTttmoNkyqRc8aAu+9XLWyYaPkqzmuDwwiHHsgFROto99kRJ+9Rc9x5J+9FIPq emQd/gobC5+wD3eCNL7T4r4BDiStdzKTVodYWVU2GyRrOoWmzLrAgskEQmIQkzjbe6e51Hot9NpF n5yd/trEcKsXgpo2RZ6Iw0gyGn70exo0c2Z7qV7Q3bGkhVXPMwiDa4WtkEnSZCqkx3KsWgyo+kDy USUENNwJKt9OpBcSeZVO2WuhX+mCdSdZRCyO7e6mBDS0yFnEq/nkGsbuJWc4jboe6kDFk6p22itm 9v8AOA+0qd/UsnLgWO0HEKk/+bJHinrMiUyYBX4JHhpIXvJ1cUG3Isbw86KcmdFUuMlR02LK5zL/ AN8phn5LeLChRKYhFNujR17JqPua14/lqB6xlEmIAPZZ6l2StDfZ1u9mp58ZVu7ruTnUip5AY4w7 95YdnCNjO0HxSJ0Q2bSxjC5gIIMH86VH063QS0SdSpXxZWW1tgzqoesK2Dc2Y0kKMFbuUvUvbgAD jdwufIXQ9SI+wDXuDC5+J04Ui96P6qVubkOkfmrscgb6vcFyX1ZNjrnHdu2thdg9rPT/AExhh5Ug 6MMurwHVoOfDRwBwntL8c7m/pGkcfuofUmVNz3DGcXV+KewurJAJcHD/ADUw7sgRV5FrSRsmUZ9Q 9Nr2E759zUBst1ElFdT7Q9rjunVv7qYVyJp9z547o+YzEtxw+t/6Zo+gfzkERufPgqRaiEJcS703 Q7hau4OEjVYOqs05bmaO1Ccgh0zqmKEzLrdzoi7mu4IQSwLNZCKMhx9tg3Dx7qBIHdDsvawcppSm srbt3VuBHgqD3O4jnwTesCZKNVYwGeSjEaolIAW7nQ24wduynbdn0Wu+i9FN1FmTvphocY2hUR1D dWKnRtbxohYzx9oZHEqcx0avuWaH6TW6npc8eBVlp9jT5IPVBGQ9Er1qCiB1W5Nh/ebVJB4V+k+w LLw9TC1KeFHNv4jokTpAeadMZVaJ9EwThFSk6SRHlCSFJ0oShFSk6UJJKWlOklCKlAkcKTodwIUQ kZStSxTBOZ8Uk1KySeUySlJBOQmhJSkoSSSUpJKUklKThMnCQUySBSSRQqUphJJJS8pkyQCVqXCd KCkipSUpQkgpYlKUoTQklclSqdDgTwoQnCCE9UMkDQSi2gsY58SQJAQWA7xPCtWNlseSzcoqZtIe Vpq/arg9wdLXe5x+j/xa0B0nfdvc4enxsAVnFxfsbCyZk7lYb49lFPKbqHyLwENGTRVuqxmiWCSF UwuuWZQcG0FzwY9v0EMbquoe1pcLBqfzWqxT0S3Hsc+i8sY/UthPAgB6vmn64oK3U2X5GC99rfTc 33ANcg9LOdk47XV3NDRpqPcrlFdFe9vqOudxY36Sjh31bS3FpcAD7hwhxVExA/SU1m5t3quw8mN8 Syxmii3Lsoo3XDc9phwH0g399WmWVZFxc6kiysakoDLMW1z3wQX6PlSiuHUfMrqzu9O1obZq140l Y9+JZiuLqT+j/OY5Wb8K57QyiwPY10hp+mxAdkXVXOqsG5kT/KahAGOx44/uLnNsbDy4d0q37Xyj ZLA3Vn0SqrjGqvRPFBhOkrdUDVVMtu2HjsVZqduYCo5TNzT4woY6Fm3DKl0gFWAs/DfLfhor4UjG zBT8qIUkihRbIhdZ024X4rHeAj7lykrb+r1306T/AFgn4jrSyYSdQr2vDvFVXH2rU6hXNZPgsppk IZRRZoGwj26ypMMEkJWExoh1d45Ua8pC7VQ3gmE7uJUNsFJSUt3CBymaI0SB1lOTHPCCmDTAO5SH YpbZ+CdncJKWInUKLi5vHzRHBCLS46cpKSBLfBhRanEmQkpmADypfBDBPgpgQihFdJAKTveAjEtd 7UAFzDt5HZFSo0gJnNJU3DvwpAxqkFImmBBRHNgaJOc0mRomaZ0KRUw1CfSZ7JPmIQwSQQ7slulI 4QCp1kuGqYSRqpMMaIIXiEzm7mqRcoh86JBSNlZI1ST6tSTlP//TBuJ5UCQTIUnnRQA8oVFuMwR8 0iFCYOimRIQSie8hKTCrvdrCsBvdIqCxbKjYNo0UyYQS9xPGiI1UzYNEgSniAokkDRBSF5UNwiQn cSm2JymYKHrJT7SEpISSxIlIBR154Uq2klFC7jATNEiCnjx4ShBTOGtEILuU8kpASiNEL1M01Ui2 OE7oYE4M6lA6pW2bhr2Uj7VGQFBztZSQqZ50XS9BqioHxK5o6jzXZdLr2VMHkrOIMeQ6N/IO2srO 7K7mmGgKkdFZDSO6ygVIlRT2IoMgw1Ylh1K2MwjYsR3ko5L4rY7d97W+crpckbmHxCw+ks9TJE9h K3AdzXDzSDJ0aL2+CCdFasgDRVHGXJBilu2GFE9Eu4MINZRyNwG0wgVbhgMO1r27TJJSz8W1mXVJ 1U3Y7rCGGz3dkO3De2yC8lwSBQCRoq/GuPUG6w6EMY9hz3EmDCduK99hO47wJ1QzWa3h+47p1SsM kdVXUPZaQ4zKHaHUuidAnyc0l+4adkB1xfqUxtnFEh18Q12FrbnbWkcqGZTWNangnd9FVK7RYAxz eOHKLchrXgbBzyh4NbQaNrKcSIDZhZznumXaLU+1Ch8loeD2VXJr9Szf9EH81KIpeChtlzJHIQ2v gGR80YVlggHRBe3skUFqPd7iVqdMAd2WcWNPxWz0ust8zHCctiKR59u+ggjgrJ3g8K1lWfoXzzuK yhZKfdMco26P2gtpcwHQp6RoAqga5zJkDyVpkwITZJgCBq2L6hUAQ4OkduypusjtMog3k8pONjpj UBRsoLRLvJQLiEeENwCclCX6ogMqJCYOhAqXeZbCmx2xoPmhEypP+gPikpumyHBsROqFkgtZ81Wu J0I4Qt7naEpoHVFOn1DXCafNYpWzmmcBnxCx09Jel+qbSXvI8F12UJoLXaz2C5H6pkBzwdJXYZFx ooNrBLmjhSDowy3L59k4VuLeXOBYHH2yh/aranHdqD4rY651K3qFLHente09tVklj9sPIJOoTDqy hGzNcJA7oj2vaAQ+ZPZDa3aZ0UiwtaHTrPATCFyrLQ0at18fFAORXH83+KlkXveS08BV5HdEBR1Z +rWfzPxTvsrcIDNp+KCY7JxqitTVY77yGs1KjXRaXFo5bytbplJbFp7A6d0SvLxHPc4Y55hz9yS3 ic5uPe/RgVtv1fyn45yRDmiZE+72rRddjNMbGlv9ZaLmPxKC+ukmgiXCuz27f8J+hSCiSGj03pmJ 9iOTZXvcPzZUMTK6ZkWCr0Nni5x9q0GZLPsrWY9JLLOaw73f56r09FoymEuca3jhpRgLYibOrNrc E2entZt8dyJmUswB6n2aBMCxrtyzRg49Z2/Z3PI/OD1pvyb76vs9tbvT00c9u7/txE31VcejgdWq DLQ4Sd43e5KrWoKfWRZvaHs2NA9uu7chUn9Gmjdjns3sVndXaDoVRxHmQrtOhKZNu4dk4KkohOmB mXSSTyipSm6wuAa7twoJwihSUp00JKVwnTJ0lLpJk5CKlJJJJKUm5TpoQUuI7pR4JoS+CSl4TJJJ KXhNEpBJJStqUJ5SSUtCcBJOEqUoBPCSUIqVCUJJ5SUtCYBOCnlJSgnhRCm10DXhEIYlqUJynASp S0SmhSKiUipaExTkppTSUtmvgFWFUpO5pHgVaaZVHmtDf7yg4ORlNw813rOOxzZapCu7qGtk109m j6T1pZGNVY8WPaC5v0SmHMKoZx04R6/3mVFl2Ox8cup0LR+CpYDsh9hsaS5j2/nHRjlpPsZWN1hh vmmoyvWjYwis8O4lKFyFCPF/WQWtj9INbhaLCLgZlo0VyvHbQ9z2zLzLlm2ZdlttmOd0t+j6H/f3 qXSciyyp7C4vtadG2e121PlGQ+ZDes9Kgmw6F2hKotwqyS6h41MkOHCtEZNjCHtYx/5p+kFRZTZh 7rbYc93Lwf8A0Wnk6aH/AAVIrOnuYS9jpd5J2NL2h1sF4/ORG3DHhtjSNx+n+b7lG3IYLfQP0iJH g5MJkdl4cW+g0AjWCZCo2uW/l1b2wVzuQNjiFd5efFv8zFkFauphO3Vx4I72y1UOmP5atKJBQlpI r4mw5mMdtjm+a02HRZdnsv8AitKsyE8reqUcJwmUgEkKAVzp1vo5LHdj7SqoSJIG4cgylE0bQRYe yuZuBHiude0scW9wV0NFvr1NsHcLHz2endPYqxkFhGI9EEpgwNkpaTopFVWdgYJlPI47pnPDdEnC dUlKB3GPBOQHJgITx3SUs0wok6yO6dv0k5OiSmRBIQmmT4EI1bC8iNFO3GNbh7m6+aIFqtCXaxCe IdKcsLdCRCZvgkRSF+Sk47knDWQmIP5vikpcaFBsLW+5WxWe6E9sHXhEAqYtdurkFRqsJbBCiXhj tNAVPvHcIKZjVMWwo7gHT2Km5soqYSGqBbtMnhQeHEqbJcASipMmDSeyIKwRIKG4O4BKFKSFsBDI I47olWjYcZTWDuEtlInNcBqkiWTtlJFT/9Ss4EhRaYEFIzwnmOFQLdV6Z7IdpgQib9NVVfJKSlqm 7irTVCkANnup7kiUqKGYlTe8AIbTJkIIZO8UOx2ik4n4ITj2KKkRdKYHwSKQ5T1MiSQonTlSJIOi i6SgljuCNXxPZAnXhWBo3RIoWLgUPnhSazcZTRExykFKYGu8kQQUOtrhwiN/FIoWLdx1UHQ3RTJk oboKCVoBTcKQAcitaNuqNqY0M3vA813GG0AAeAXH9PZuyGgcLtcdukq5j2a+UoMwy4BVCj5DpsKA 5ThqEsVGU8qJKcxktLNcIIKxnlaWa6VlPOqiO7JF1Oht1e8dhC0qXe1wPJVLpA2Y7nHQkq5US4n4 JwXFAQQ3+Cpk6q83Qe6VStjedvCXVjyJq3SrBEnRU6jJV1lrmHRwCBTA9WTJZcySfHUI/rQ9ztYn wRa8zcR69jS0DQQoHNsYCxj2bJlshRjddxC92m+zdYT5Ildja49Rm5p7qN1ptdvsc0k6e1V72agi dsJE6qibOjXzWm101tDW+ajQLGiHtDh4tUdwD9eFdw663bnHjySttGEgLtEysnUBVm6Pk+KtMDmO dM7I9sqiXCfmkGpkOodLGtrquL7Gh7eyrWy61zmaMPDVGmoOMyD5Kzj477tz2AENPilfReLR0+2d wlVr9HT2RX3tLuISez1GyguLVAkgrd6Y3c48D2rDJ2ghw1B0Wn06wFjiOwThugCg5twmu2ezis14 AMBW32OFdka+7VUWkuRlutGyQOO2Oy0mNLwABJjhZbtAtfEscwgtMGE1IYNaWv10Kha99YMd1ate 65xe/nyVd+M+yp1jTICHVc5htKgbSUzlAhFLIWHhHDSQAqoGqsAEJpSzNZ4hO9n6L5olUxxI8VN5 Bqdu8ZQtLRsAEAcIRIKsX2MeGlgiOVXKcFpdXKE9PYT4rH7rdvDD0lszuB0j4rBRU9V9VnS5+7wX XWv9OqYBI/NK4/6pe572nuF2OQwNpMdgpezDLq8X1DJbZbZbs2BsDa0+1UiX2DRjgCPa/wDNVp1z XU2WPZu3OjamotfYPT2uYG/Ra4qKrK8HRzgzImCHfcpPd6ZhzSB2K0vQeTrOvmq+Q+6o+hewiPoh 3/V1oELgbc+2v3w2fdwnvwrKLm0vjc76KPkB5A/dBBU+o2V2W1WMM7YlEJOjUswrK7xjujceEjhP F/2cwHeKuZl1NuVXbU4mI3afuqWY6puYy9m7bpvkbUUW2MB2z9A8gvbMqu01y7ZW6JIdtci2X1Mz RbR7muG10jantfj03uZXW/edXbXJtUWO7KmYGO/lhB+K1sX7Y3GczHa40AFpZLf+uel/hVmfaKfT AktcOyuUdVGPUW02xPLP/O08BkOoT4r2eg3YCzlsOP5yzGYWYy31R7gD9HcrWP1HGrrNbmQfzNfU 96GM21mjns+BamAkEsYiz35IMiog/wBZaDrKMjHP2lrmZIBgj97/AAf/AASzqMltgc6Q4j82dv8A 22r7qftOKcnHtaC0EurcP3UbKeCnE6gHCmtruQUGowxWM9/q1VvPMawqbjtYgxzFuhhkAgBaFP0y FmYh41WnT9Iymy2bGJsJJJwExnUnCQ8kkULpAhOW6SooqZSD2STJIqXSSSSUvCSSSSlJJJJKUmUk 0IKYpJ0oQSsnShJFC8pkoTpKWTpQkkpScJoThJTJMkkipSSSdJSySSSSlJpUk0IKWkp5TJJKVKUp JIWlUpk8JIKSY5h8eIVpipMO1w+Ku8OVbmY3C/3UdVWBBDNsEq04aIZbI1VOGPqV9ud1PHFuO4Ok ge4Bv0lUZjWZrWGHVgQS4u5/60tWYKnJPKZ7piOGKatFRh10WG1k7naOSvd6Pvrr3WO/d/8ARqOE K+SyGWCt3730kwSJOqmozqTnXjHsYA53drt23+umFvqXHHvZDh7mfuuQ76BeWm+xoLTM1t2vf/bR cwU5TI3Frh9GxT1HSlNawtzXOrYS3ZoZ1Yq1/TXk+o18vA0EeCu4dDaK9u8PcTLnIrh4IGZjKo/K kauduL2y4Qe6wuo17Hz4rpLAsbq1M17h2U3Lyqf95UxcXPwHxZHitzvHiuZoftsBXSNJIBVnKKla zGdHPz2wQ7wKt0OkKOezcw/eh4btzAlfpSd2+FIKAKkCkhmkNUykEEPQdBt30GruwonVKgaxZ3aV mdGt9PJ29nj/AKlb+TXvY5vkrUfVFiGknCiUnDXRRGjY8E/IVU7tpiQO4UHuHAU2uB57JrAAkpiH QR4IsA8IO0kQjM1SKmEEFR3OiOyLt0kIZASUoEgQmtZuCUmIHZFcDtSUiLdzQfBT4ITME8pnajwh FSSNR4oxaQIHKr7tJRq2uf7pTorSsDHKi/UJ2jkOTtBOidK1BrwHaQpbI1TS5pM6jskXiJ4TClTW ng8KYk6JB08JjrxympU5m7VArEBzCfNWFWfJdMcJwKGzj2VtEPn5Ijtp+jMIePYATubMopeHGGiA nboRNeyYOqISxw1mFC06gQpbTEpKZh9YbABJ80kEnaZ5lJFD/9Ws0SpROkKIbASLjOioN1ha7YNF Xb7jPirFrUKtjQeUeikwbol6gGiU6qDjCCmFvvU2AAIYJJ0RJjskVLc6qtaNdFYLjEKsXQdUQFMC 09km7gkXEnnRJvinIZEyokwkSn1SSvW3VFsE6cKNbTulSLCHSUCpQGweKGWidEeE+zuULUgI7BEb Ma8p5aTEJAt4QJQwcQNUHbJRLCeBqnrHiiNksmtEJnO7DhQtsnhLUDVIKdPole64k9guvZo1c30C uWud4ldG87WFX4DRq5Tq5z9XEoRRJkITlMGoWJUHnRTKFYYCcxuVlmSs2w/er2SdSqDtXAeJUO7N EO6wCvDYANSrOG9wJA1EIOVY2ttdLvBToA3g7i1EHuvmKopXe0EN7qqMNx+PmdqtGwNcVGxwyQbH OiNIaOU6wNWCWpabnei8MgbifH2qxm1WYu0+17Xfun3NVE5lWO+Xt3kaaqx+2KMp7GuaWtaVGZNy OEcI/wCcwc2HQ5h+9OysWODQrWe6ux4c2QwjkKqGtDwKnbhzxtcnxIpzskCMlV+r4m7d0oVtnWSo Ck/ReCR4BSZ16xgNVgDo8eVAdeawzsn5oUG3EAbMMnplTG+oQ5oKotc2sENlWcjqN2edQAwdgqVv tJCVBZlnMagqx7nus2g6Srxxqu4VHpsm6VqWbWk6iUJCtl+MWNWsaGVguaNYVPp9xtsc1xA00/N9 yvXz6ZjX4JmUutsZj0hoJH5w7qNcd9GdDaHVOF7SLtdjmn2Ki37QOWAH4hS6ng5NR9NwAeP3fzmq kcV5Gtbp7+5O1Rq6D2sdT7gfW+PtR+nVllDiBL+Tt9yp4+LaWxWNpjXd7lfw8i7CqL2kB/8AVSG6 S41pPpvOsk8Bqq1Ve3UELpG5VrwXTBOp0U6rX2AiAfknIp51tbS/a47RH0loYT2B8P4C092zsPmE O7OsLh7WED+SgkCmk9zd52cIMaSDp3Vt2a8SdjNP5KCep2ARsYR4JtJcuzZOiES0lah6gw/SoaVB 2Vju/wAAAfijSXMnVGrAOpV9zsYN3mkR5FM1+K7iqPmmkWlrttNcgHRNa/e0iVf9HDe3c5jgR4FJ uNhFs+4fNDhU5WRUK4AMyq7hC03twt0kPI8ii0YGJlPDA57GnlztdqIQWORp0xg8ViLout47MTGb TU/e0HRy54ooem+qOj3kcwu0t3OZDI3HjdwuL+qGtrm+S6/qJ/Vnx2HZSdmKXV47OB6fY7GvYHbj 6jSxWzW27Y54cf7SqnIPpshxLyeXauRMqWM3MLgRCilZ2XAFlZRTDiCZbqBuWf1HKdfta4lxHdx+ iiZ5DLmPI3HbqP3kK0vzm+nRSGFush3uQF7lILXx6W2P9Mv2k8H81Rg0uLbG8KeNU+i0V5LCGv03 fuuRMvDvxD+kcCD9F30k/dR7r47XXWB9bNAdSr2c17mthsuB7KrQ22zFe1gLjPDUK8V1tHplwsOj mP8AzUzc/wB1W4Ub30uO5o1QLb3Wv3/RMRohuBHKaSVJuqMQGceKm0AIe091MSTpopAudDFxqriA e61LvqoX176Xy791651pcDIMQtTG+sOVjN2EB/g785GrCDfRoMDsez0nN2kaPa5NdYKn7mwClk5L 8qw22fSdygVUtsua1xgFRShRsLr0SPy32kB5kdkrhDUG6v0bizkAqzlD2AphYyNV8d5bHxW9WZfK 52owwHzXQ1nUeYQLLBtABJMnCYyqCdJMipeUkkklKifJPBCSSSlJJJ0VKSSSSUqEkikkpSdJJJSv JKFJRSQqEoSSQUuEkgkipSZOkklSSeEjokpSZOkkpZJOkElLJ0kgkpSUJJJKWTJ4SQUt8EoTpFBS ySklKSWJ01V76QaR3VLlWajNY8kyYuEgtLYcZ0Q7He2FMGQg2cQswTq14QgqIuLzFYn+UfooWTpX I8dU9mdTjgbzyNGqDhJ29S9P6Bf9NxJ8vorKuxcj1N4d+jB7K7jZj8uuwAbHj6Kya6sqyfXO49tV PjiRd8KC2MzA/aDm+k8NeB7mEqvXRspfi2vAsaZGq1Mep1bxa1pJ27XaIOX077RYbdpa4+YUkZ/o n5UU0MKm3HcXWPDmuGgR6CXvLSdp/NUjh2VwdswI1VF9eRUZYe86pGpE/LxKFhv2Ocz6eo/eCrZV YtrcPJRr6i+dl7Y/lIrHAyBwmiJgbK+7eQILHfArosV++sFY3UafSuI8dVodKs3MLVoZPVESYYaS IbtwBbHiqGGdss8CtKJBCzW+y8jxUQ2IZZOk0qSGwoiIWFmE6inSKGbLPTe2z90rs5Dmhw4IXE8i F1HSL/Wxm+LfaVPiPRin3aOXX6dxb2OqCNNFf6pX9GwduVmkxymZI0WxA2F9oCI4bghyQQW6gopc Excic0AggqVcAwptYHaqQqLdDynCJK0lGTtPkhHgkq0+mY2n4qu8Fpg9kCKSoNj4KQHgogy1JmpI TUsZCg4Tr2Um+07eyZwDhA7JKZtHtU2GOFBmoTtBSU2G2NiDymPPKAQY80mmU7iK2l/UbMHQhCsa SZHCnYRII5SNmmvCVppVbSD5KUawFFlhOimD7kFMGtIKVrNJUg+THgnsPccJKQa6Qj1P1juhMPqT GhCdh2u93KchNcZ4EKFR3BEM8qLTBjulaqYuBIhJSaZcQUkbU//WAAT8EnnaEi7wQy7uVQpuI3WH unB7qRAOqUJFK7johmQpl0IYdKFKWa2FIlLSUgdEVIt3MITkRzoCEXk6pwQw0kqUCdCkCDynI0jx Tipi6DpKYGeFMwEM6FK1NiolokqZslQrbpKlAHCYQpIHQYTPslBOpTvMIUpkBKiTrCVbp1PCckAx 3RUya0Ibj2HCcujlDaZ1CQSsIlSJjVM2J1U3HhvinRFkKOz1PR6hTU2e+sLTyTFcxCB01kMbPYIm a7QBXwGjMtLsoFTKG5SBryYFBvMNRiquUYCJ2WhybjJKBjs33saOJCJai9Jr35QnsFEGeLo3W1jK i5hLAPpI7am2kuoBLPEomZ6tD27bGua4j2gfRVx1LD7uHeSRWymdnItmY7orKHVVh7wdv50dlJ7f 0g+K0m4tW4OMk+E6ISLHdG3H6o/ADA6mbbD/ACSsSm6LQ62k7Z7LpKnX5WQ+qp7WNbxuAT251VLv TuAD2/S05ThEE6s8ck++iO8497B9nJ3H8yPorPe19VgPDgtqnHfmVG7Fc1seIQsDdmMLbi0mY3fR Q2LFl4pD+s5d+2/WxolAZjUtMkSt6/CpoO0wR5FA9Ons1ONLR7g/caHrNaIqELPuu1K3nNqA3bNB 5rPv6tjZLdhaTHltQXcEj8xcR1zwfaSAoB8anU+am4A6s+jPB+kEMls6hMNs4FbM2ZFlZJrcWz2V 0dT3EPNY9RvDmkhyz9saq9iZePTG8e7x5QURbZPU/XO65kuGgL3OUPtLTrs0+KugV5A9SBqoejWD wloxmEjsWmckDhsfNaG79A3SJQvTq4gaqzls9FrewKcPBMQRuUIeAIV3CzKMRx9TVrgspztUSu5z NQPmUgm9XQutqcZrOiA5k6jVV6nFzlba+CR4IFduh3NbW9pbJPBWW9pB1WwbW3ODONYlQtoNN/ph wc2J3BIFbLRxi1RDC74K6+07iBEDyUPVPgElgmrL27Gho+KRxvRDXToQpMLbTBATWP3AMnSYQDKD aWNtcngqsXbtJR8vRsNMiFQglIpXcBJV7DEM3Axqs6Z5WnhtirXukor9cMYtQ81z5W71552VVnjl YUJIen+p4/SWE+AhdhkVs9JwsO1pGrlzf1b9Np2tndtG6dF0mW0vpc2DJEaKQdGKXV4K+pzbAysy Q72u/eb/AKRbeVhXDDNrbmuc0bn1EDULOLfstsWQ8j81x96WRdWWyKgPg5Nlp0XOfmZHqua6NANE Fpa/QSH+M7Qnv279dAowBwUhsupcN5kkwouZtE7tE+5hJJUHOaYAHB5RKqdLG9SrHdtJa4nQhQ6h U5zGvklw5V1zh6IdG1V77BsgqKOuqtnPk+AHkmL9uidjpcZ7KArfYTtEqRIVuJTiVAeCKFIEr6ju pAymKbUJyF3AgSFXc8z5jhWm6iFWtaEyaFOebHBzuVaudurVJgjQqyTLIUKJKYZr810VJ+gfJczW 6RtXRUOllfwQOzJB0NCn4UQnTLZV0kkklKhPCZOipScfimTpKUkQkE5JPKKlk6ZOkpSSSSSlJJQn SUsnS5SCSlJyknARpC0JJ0oSUskEkkFKBU9pcFCERhCIUUZEJQpvUYQUsE6SSSlHRJJJJK0pJ4lM gpQ8kinhLhFTFLhOlwgpZJOkglYo+OZDmoKnjmLB56JUgtmsyFGxJuhIUrFjTFSIXBpvbuaW+IWc cY5DgQONHh3tCv33toBceQJhUvWOX6drSSw6OZ+6ljsC+i8smOooGku1ja36CY9RsEOaAxnB2+56 JV0oEu9QkMP0WNKvVYtVQAa0adz9JOMoj+stcffm3OIklnb95W24jg+q3aZAh61JTFNOXsE05GLX kUXvLwfSedP5KHm22U3aGWEfnfRWu5AeAeYIR49bpIcS+yqww8RPBanrBbA5CvW4lbtQIPkqN7LK JsBnxhSCQkKCtnL63XO1/wAlW6U+LIK08vbk0Et5GsLCxXllgKvY/VjMf0osctJAvTAa7VnZI2WN PyWg06hVM5sie4MqOJ1ZTqEzCjAqtU6Wgo4KIWFIElEFSTlq4Wx9X7ttj6jwfcFjAqxg3ehkss7T tP8AaT4GiskLD1GdV6lLgOeywmSW6rp3QdPFc4+v0nuZ5qXKNLXYj0U0ANhRce3dSBULGkhVmZf1 vSgkTKslwuALdIVQjc2CnDy0ggp4lS0xtuPftglDe5ts7Twh+odfNDBcwyI10KPECoClMbE6pAQZ SB7JBRlcwtrgyOUmNjVTcdFBpJPkkpmwDt9yeCShj6RUzpwkpeS3nVI8S3ROTpJ7JwQQkpGRubEq L3Dbrwiw0nRBsZvaQOQipjU302zOiPv47EoVTfYJUmkd0SgMdu10kzKMXacKL2zx96dryIBQUiaY cT4ohIIkobiWuJjRHG0t4TlKrdAhTawu1UBojNlw2jlIalB0RtaQUkYNiPxST+FFv//XEBCBaZMI 7nE6lBPu1VBuraNCckEQFAlSGgSpSJ7tqk0SJUiPBMZCSmLpSJ0Uj5ob9DogpG4eCGfBTLiVB08p 4UxidFKNNUykW9yipHon1nySDRMp4HdJSZsgJpKiXGOFJBS4bpJTA6pwd3CGNHfFBCYg8pcCSpdk xOialrWuDj7Snam2iZ4TNnlPUErSOynSw2WsHmga8hX+lM35A7xqpMYsols9jiM2tQct0vhWqhtY qN2ryVdDQmichFTKgU8MBYFUcwxorxWZmO1SlsgbubYtH6vN973n4LMtPK2+hsDKHPIJk8BRs4SW ZD2vOyBr3CkzNufo4gx5KcU5byJc1wHdqq1u9Nzm8hOjRaRMhLU6KsyXF24cog6lkAaED5KnqrmL isuabHuhrfBOIFWVkpSMqivTkvsf7wI5JDVa9VoJLmtLe3tTYfoGa6y4g9yNquNo2CANFEQTszwj OtWkbqYPIIHZvtWZZk2WN2GNvgBtWrdl11EtsDhPfb7Vn5eKylrbK3bg/XUJRq9WPLxgNP2tHmnY N/BV7Hiuh1kAmdNyrPyb3tEbJP8AJTjNfhwSyVqhyqwwSTPm0qhLToVuU0PD2hxaSTxt9qn1DEyM KHFlZrcYaYQJbJwygd3njRvO3kE/SarDuiuAMOmNVf6jj7n1ipoa8xu2qWWS2siYMQm3YtdE3f8A Vec9M8cRojUUBztoOvitttfp01sYG73/AJz+6s5GG7DaBltYCfoPYkDatS4ljTW6A4EeSYuA1K1q jS72AtL3cKNjb8a9tbwxzSdRCRNLJYze+jSw2tfZqJHZa3VGOLGacLPZYxmYQBEnQN+itTqZioQj HuuiKDiXOIGgSZaXsAPASsBc0juk1mxoCC5sY+hkI4dqSg4wj4p3v2A+aSU9TyW6RLjAlGzsZ2NA eWy4aQsd+SWt2/NCfmGyNxmPFKloDa9Igy4hFuxrKaxa9oLD5quyxjxq0KT7xERIH5soEqoMyA33 jQEIVux9A2th06uUhkNP5mnxUq3Nud6bWanzQtIFMBDmDcFD7L6mkwrWXQ/HcGvCrep4JsiyxZP6 eWiVZwqpAb4Kt9ocRBV/FMOAQx31VOujm/WJw9VjfALKqr9R0TCv9acHZMAzAVBrdFIseu+r9Gxx cXh0tGn5zV01jnBkt0IXL/VxgZc7w2hdNkuc2kubqQNJUg6MM+r5/wBVc7I6g42GXaNkCFdyul5I xxcWxW3uPpKvhhuTmPtvd6Th9H27myt5+ZbZU5rclpZw6GcBNJGy8PM149b32DJa8kN3MNf/AH9E dRgiZbaPaHf2loDJaboxXtcCzY4OCI3J3HYX1SW+nthyIqtUWXJsx8Rkwy36IOv5qX2XFcS0MtaY Gp/MK0MjLupea3tY47ds/wAlV39StIjY0mNroSNEaK42V9pDRQASAOUCxsgKZyGZGrGua4CHa+1R cCQI0KjApLWpHEjVGNZIOpaoUNkFxPuB4P5yE8W3E6w0J64JKMatwl74+CV9QrI2zHmp11tYIk6d k91cM3AkjzTglrpBT2gNBnUqA0UgQkrVe9WGlByAhLZHVAHaSjt+igN4RWn2lV1FjUZBC6LH1rYV zdZ1XRYpmhk9kCvg6bAI1Ukzfop0xlUnhMnlFSkkk8JKWSTwkipUJFOlwkhaE6SSSlJ+EpSSUoFJ OnRUsmhOU6SlgnTJ5SUqeydMFIu8gipjykU8pJKWTjRMkJSUzcB2UIT690kFKhKEkklLJ0k8BJS2 qQTJwgpRTAJc8Jkkrwl8UkkFLuaBwVFKEkipZODtIPgklE6FBTbcNr/jqpO4Q7DLWP8Aklbcyms2 WGGhZ3MRqen6SouDZhX5GS4uPsHHwWrTQ2hu1gACwM3rtlxLcf2s/e7qmx9j/wCdcdeNU8ctPIBf 6uK4zAexEDkj705sa3uuK2+Mn5q1h3mokE+0psuRMRYPEgZAXpnZbAguzgFknKrPdROVX4yoBhl2 X2HW/aAHZJ2cx+hELG+1MKHZmsaNNT4J4xS2pVh2H5FYaXE6BZdvWqZIDC5Ubcz1Bt4BVJ0Aqxi5 YbzWyn2bbs1hcSxsAiCFQNLd0tPfunESkrkYCOzEZW7VFm+sE/BPlM3MWTReang9jyFsvO9m4KtO PCWeMrDUxnezVWmlUqCQXN81bBS6qSAp1AFLcpKtjShJzvaULclOiNIt7fCuF+Oywa6Kh1Cn9IH+ KH9Wr91DqTyw/wDRcr+czdXPgpzrFZA1Jyxpyhue7hFjuhkjVVW0wcRGnKbWNO6REuhJszBSUkrZ v07pFobyogmdE4cXj3JBC+iWhEhMPaI5CFUIkDxSUka4ElsqHfTlNtPMe5PqDryklTxBnsUiTEfc iOjaCFGTCSmYIhRZoYTMM6JHnRJDMgDVRP0vJEA0UHaCUlIw2JZ9ylTLiWngKIIdqO3KkHQ8OGqc KtRZAT5KBaNyPawE7m/chOEcpHdQWcwWaHsiNHtUHCGlw0TV2hzQQkhm0k6KTSQoMkEhTGo1QU2K 7t2jufFJVyPwSUnGaW8L/9Cq+eymxvt17qJcXGB2UmmOVQLcRvYGmQg2GTAVizxKrDbOiKWbIGic nVRnVRc/wQUyJlDcVNrY1Q7C08pKRkAcqMjlOXD4BMdE8IUNeE7iQEzeEnSUkrHXhO2e5UQ5wTt1 OvKRQzc9SLpCC7QwifFCksw7bymDdxlQJnQKbI4QQzA2pPGmicp3HRNU126zPIQ2u2/ejDXlCcNU 8JSSOy1+hsBsc5Y4JIXRdApIZJ7lTYRqsyHR6Q6N+Sy3GSVpXHawrLHCthoy3YuUCpuUCnhhkwdo Fj5bpK1rNAsXIdJKElRaVp0K6Tp1xwsdjpifLcubfLiB4mF0trIYxonQBNAZJS4Y2yOTUXusLpc4 cbdqr0taWvc7mdFFzNqgWyFII00RMynqjOqvY19QqdW9xaT3jcgVVypWVBqJFhj4iJkhuDMY6j7O 17TGnqRscqIbsPvyHT203bkzaw4HdM9ht+kolp7g/cm14tj7xpt6nQys8ZNQqs0aPzgNVQ6hfXbt bU4lrRzCiWk6QY+Cg5vaD9yHD1WZM3FoA2aLnso2BjXg+Ky7sh24NDdpB9oat7GxX1NbYAHfvMcd qD1UZGUAMen0/EktURjezpcvMYw5FeffXY0uBkdoVvJzrXO1aHtOu1x7oNOH1Klwe+Hj+VCv3V25 LhNIrI+k4O3JpBDLkyxn04WtlF919XpiHnsE/UcewVkuaRBhyFkv22h1TiC384KD8jJugPe5zSfc nAaBpjINQG+XEiullItdE/BRyXXOAb6O4jljyXempW3VUWNcBYLQPpVpssmxws9R0nzTBVMsRbCi lzgd2O0Pn2hQbeW3elZQGu8ZRGt9NnqF73R+6fch1XY91hMWeoB+emyXFDRaftWgEBafU27sYOGm qy8Kpxve+NNVrui7Fg8AqaKwHTVxqKi53miWs3ujiE77wz2sb80g5rzroUiCg5IjddjACpX1QJeD qjMZFJyGxDD9E91CzqBtqNz4j80IFdxAjRq4mH6t24Dc0fSCqvx6jkO3AsbOjVsU4t76hdXY1odw He1VsuyvG2jJAc8/nMKaZWjXo18xrWOAb4IIMchRzcttjw+l0QNQVVObb4hEbLw2rDpoFPHIJngj uFUqvvuMM2khWaGW1lz7h7fFvuTZFKW10t0JdP7yqO5Vp2SQ0V7gWdtNUBx3cILkbldwb3C0NcdD wVT27uNVZw9otDLSQZ9qcEFrZ1hoyrBAduH5ysDo7hSLN4kiYhVOrA/az8AtP7W40tYQIhR5JGNU uiAbbv1cw7sS0uu4ePYupyL/AE6y8CYHBXKdEybLckscSWNA2N/dXSZ/9Hcp4mwC156F543sLjug E+6ANEF1Ntb3PqLCx41at3oLAQ/cAdAFMYFWPe702wDqjWq95vZdI2trafmr/VDXlsaW1NqsaQ7f Lf8AW1dKMdrhqAhWdKps+k0IHzQ8F1F4uvkHSOUE1fylLqo+y5L6QJ2lVRmuPDUhoNU02qhtMIjh uExMKnTlOteAAr0aQkVNdgLrNSYHARLWSd7uAoOftdA5T3ZIrMNElJIR2P2w5vf95JuQ+CDBlAdY 6w7nFTbqnBLMBNBUgk4FSBS7RrKHk8Ig8VHJ4QIW9WkEZn0UAGCisOigKVqjqugwBNAA8VzjPpQu g6d7qCO4KBXB3PTLWgkgz4Jhqos4CmExlWTwlCklSlgknhMkhQTpk6KlJJQlCSlJ0kklKThMkipd JI6pkrUunTQkkpUJJ0ySl0gmTpKXSTJJKXTpkklKCUJJ5SUsnTKQSQoJiE8pkVLJSkkglSQMJBJB SySdMUkqSTJSgpkVEqW/SAIUUCpOwzQR+6VyvWM12VbsH0G9l1WL7t9Z4cFw+c70rHN7gkI+2JET O8VpNMDDdSYQzlbT4wqznSoqRjbTs0u1AhRGY9VpTSlam07MsOih9ps8UFMgpL67/EqLnl3JUNUk lLFxTSU7lFFS8pAwmTpKZh5W9iW76BrqFzy1umO9sKHKNGTGdWZcG2HzVgOVTJ0eHIzSoa2ZSn3J pQ5TgqYBiJSynlQBTylSHU6Df6WWGk6PELrbG7gWrz9thqe2wctIK79jxYxrx3EqWOy06FwSNriP wTP8Qj57fTu/rIBKrTFFsjUKaPFCe73jwRqnjuNUN7YMoJWnWVMt0TA7hPdTBEIKYahqi87Wz3RN hd9FNM6JKW3Dkp7BuAcOyYjTRSa0bY7JKRuJHCiO6mR4JmtEykljWPdIRTyhN9pkIpMjRJDNJ4EK IM6px7jCCmuAGknupElw00SsZtJITCSJTgpO1Kxoco18QU79BykpltAEHhVX1gAlhgow1Hu4UCNn wKIQyqduHgURrXb9PoqDQpGQUlMnhJTMkJJKf//RrAgJ5CUEKDnkKg3F3wVFlYHISad5gKU9kkoC w7pTkSiPVa3QS0pKS9vNAf7VEPICcO3BO2QxBUdeVKI1Ue6KmbT3TbgpNKi7VJLFw7qTJKi5MwkJ dEM3NTAwE5f2KgYQSWRs7QisEiSgESrDfbokQhm2EO4mNETkaKu4lx+CaBqpYPUTLjATx4pwfAJ6 lgC06rsui07am/CVyO3eQ3uSu56e3aweQVnEOrFl2S5ZhqokK5lGSAqjgQp2oUTlAqblEp4Yi17z DViXnUrYyjosW06pkkxR0N9S9jfNdXVc71tjXe0N1auf6RWLMtvgAt5tHpWWWbg4HSWodF06EUGb YHkR2VYiGypBu4/FPkAhrWqbo58dSZJKeFbxgPVk9gSqdRVuhphxHMRqhPZWPWSvtL3En19uv0dr VawL3vY91j94HBiFFuDewAH04P5yFXRZRVaHbQSfzf5tQS2b5jEJGtscN3rkA9gxqrC51lTmvdvG /a1xbtWiMW2tgaHs4/OCymV2VMh0bi4/R+j/ANbRlXREogDRI7C9fJb6rT6YZz2VOnGre9zS122f a7c5TyqM4AvDnE+CwGjKe4saXNPgTtTbpvYIDh1dXHaz1vTtc70iex3I9eH6GS59Qd6QGjnLNrxM lpl4O395XMd9tTXBziWkH2lNJNMecC9GpYQ5zj4lPXY+siJ299EsQbrW6aSrzLbL7Hhrw3bwIUhP Rz8MJE2F6eoCi71qzyILHtKpZYryrjaXlm78xjPanpvvvLg94Dm6aBHxzffLN7WkfnlM6N725DVr 4t4wn72WF39Zim28WWG/dLjpxtaiU2v3WMteHgDwWc7bHtM/yUgLDBKZifU6GBWRY8vMEqzTZ7TU dYKB0p+2qzQHzKjhMfZcGM5dopohBlt/Wa1pG8hFpqDpJcGjxKJ1DAuwrR6kEO+i5qDU3mE5rzri 1dCun9D6b3ANc+HWDVu1WcvpOEanMba0O2+36PKzKDmBxZQQG/nNd9FGsr6gW+wsJ/dG1yjOjPA0 KR5bA3HorOp0WP1UgvDdu1w7LoC2201Wsc31a9S16rdfqyeoljn+k3ZP0T7/AHKMEAMw0eXhRLVo v6TewAktAPHuUHdMuI3S0jyKVrkOHuNga0bieytVW2Muc0e0H6Qj85TwKMjDt9atzZAgojq3vsNj 3Nc95mAU2RCWvbo9RH4qOTdtsII4QfWHgnBTZxTaCRVyUWg2nKb6v0wUDGuaJJHwRqrPVy2axJAk oDdBDHq1jmZZI7gSnZYSAB3RvrPjCjIY4PD9w/NWZi5Tt4kAxwClKNr4l6T6vAtyXF4I0HK6fNI+ zuIPZc/0TPsyshzbAG7QIhdB1EbsV48lJDQBhybtX6vuEPgzwjPvab3eSxfq08UV2HsVIZBc8u80 8jqut6Rlw0R2WBxhc8MyEm9R2P5QIS4eW25/Vb/RIBM/SG5qzOnVZBvsFcBwndpLVcysu7HyzZju 2uI1P0lXr6hkY9jsit0WP+lp9JNWcSDp1drrbAzTQ79FdZ7QSOQlTk2UD1q9LLT+kKk1xMk890Fz TZY1jzwd3P8AJQsoQ5O5zWvM6SnyoMfBHooIGx81MIYHgicJwXJmqcbgoskIkaaqUIYAkKORq1OO IT3asQKHNnVTZ3Q3aFOx2qrlcu0kO0W90uXUv+KwByt3ozpY8DyQKQ71X0QeFMKFJ9g8ESE1kXGi SZJJS6SUp0VLQlCloEkqUxTp0kqUsknSQUtEpQnlJFSoSTpJKWTpJpSUulCSdJSoSASkJSihcJJJ FJSolNCcJJKVCUJQkkpRCUJKUpKYhOmToKWKUhJJJKkydJBTFJPCZJKkkydBSySSSCUmO7ba0/Jc h9ZafSznDs73LquNfBZH1xp91Vw4IgqSGyyQeUTSkUyLGo6pJJJKUkEkySl5SlJMkpYpk5TFJSkk kklLrQwbNrYWeFbxG7nQEyYsLobt7LEiUq+AjWM9iFXq1VwdGcrgqYKjEHRSCmiwyZyn+KiCnRQF OEiF2HQMj1sRoPLPauPlbf1Yv2XPpP5w3BOjuiTt9QZID/BZgbJ1W3fXvYWlYm6JHMKPKOrNjOjE tgqRMjwCRZMEFRbrIKiZCsPaYnROOVFwI44RD4hBSIy0khOwz7iFMRwpUtD/AIBFSwrnhRAI41RZ IMqG2NR3SpTB3xgJtsiJRHDcJQQ0wCEEonAgwFZrJiChvMGVNpPyRQybolJBTjXlIg9klMbgRr4o LX9grThubqqzaxPt0RCkrCmIEpCQfii7e5QUsYIUH17q5BHwU+fJRgzHZOCFmt0E8hEPCC9xEIoc AOUipm10hJMx0yCkhSn/0hbpQHCSiaHjRRIMqg3F2NQ7H7Sik9kF4M6pJYOJJQnmDCLBcfBQ9MAo oYSDpCidEZwAEoXCO6UZfooGwcIjxKC8J4paSmmUtUOCRomc/RCk2kLj3TIXqSpgykYqtmSEx0Hk og+Cfd2SpLFzj2RqbPH7lBsFMaxyEtENsuEIYIPKet4IjumLY1TFI3ETolEKfpg8cqTmwjakmHXv uaPNdxjCGrkekVk3a8BdlUIaFcxj0sGUtTJd7oQC5Tt1eShlTNViVEpyolFYWllnRY9pWnmFZNhT Jbro7On9X6XPe94E7RC0XPtDXVsp2idSsPpmRZTvFbi3TsrONmZFgJdYeU4arMo034W7VW5pEiJU sjcSARKhusewncZRmVObWXOJJ7J3ExwxenQsKmGeNFa3mkEbN7Xcqh679vgU9D7LDLjAQMrVHl+H UFO61hbtNJ2/105zwyr0vRJrPaUPJY+tu5j/AJIPT7y6w+sTCYaDIMciaMmZyKdsGh23w3FSszpD WmpwYBoG/SWj6uOO6XrY/iouMdmb2T+85n7WzNpZWDsP77feFi2dLtsdudvJPdbWfkurP6M6FBZc 8EF7tCpAQQsIIPzIcMdQo/R1F0H98K39lyNpDmy4950CV9hAljjCq+q4/nH70iOJF9CWxg9LyKn7 iAYGglNe3MrcbHVAjj9H9JDYNwl1pB/dUn321D2vJ80CL3ZIAR2cXblCxzmVvBJ8FdrZklu30yD4 oz+oWO0J1QDlWD6LjJ803hDYOWxVNknJZUQ+tuv5zPpKrs2j+bkQkLrSdHFFpeX2NrcTqU4ABryi C2um1ltTy4ETwgVWvofvrMOB7rdvLXENn2wsxz6W7mAA+alBYJx1H9VjfmZPUnNY4CW6hrVNvT8i gzAV3pewtLmCI0lXeSkV0cY+Y+qTiiu20OrbDj4KzYyjGqD8at32gCNp/O/0iHl4lF1u5xh06hp2 yELGrey17aahexvdz/oqLyX3q1LLcxgN7mtYfCfesu17r3Gx+rir3UwHa21OZZ2c0/olnkP28aHu lVMm61t7rGCt30BwFPFzLWfoK9u137yRpe5u0QhsxnNd+kYHN/kuQSNG41+UAWCoQdC6VMYFbXM2 SXT7pEIDCGAtezcz833Q5qJht3WiJ+EptaLZSppZtTje4gaKv6LvBalzZtM8KAY2UrpeA54YWnXx RAYvYe0hH9MPeGniVC6sV3geBCANlB0T/WIzcyQR7VlUexwctT6wuLrGSZ0WYzhPKnrujOD7JFZY 4D6X766LLcRjOcBJA4XPdDyLDZsedzQBH8ldDlu247jEkDhPjsxTeLqzS3dtG3dw1RrySPaOe6rN yarrS93s/kwrGZk05QaC4t28OrbsSJTbM5xGndDdlvaQ9zSG9nEe1VXY9I19R/3LR/bLvsv2KQ6q I3Fv6RqFrrC+W2t2x5BJePzfaqjqqWjVro+KbNcLKqw35Sq9rH1xr3GkqMbKpv5FVVIYyC785pna maZKF1Fxf6UfJSrOvgQlHZLTIBscBwllfRCcsJtcB21SyNWBS9EdWuETlCHKKkFyZh8UTchVkBE5 UoQtAnRO4S2EjoZ7qTtWnxRK0uVaIKg0wUW4aoEqud16QnVbXRTO/wCCw51Wz0R36Rw8k1IejxRL JKOq+Lo2PNHBTWRdJMnSUpSaY1TJSkpSdMnCKlJJQnSQsnITJJJUknTQkpSSSSClJJ0gipSWidIp KUkDCUpQkpfROop0kLymSToqWSSSGqSl0pShMkpUp9VFPKCl0k0pcpJUkkkgpXZKEkikpYpiUk5Q SxKSdMglYhVvrDT6/Tg/uwq0iOr9fDtpPgU6G60vnCSctIkHsmT2JYpk5TJKUUkxSSUpJJJJSlEp 0ySlJJJJKVK0+mN3Se6zFpdKdqQo8nyrobuq7VkKrXoSFdazc0nsFRaIsPmqobJ2ZlJShMp4FhkF xonTBOnsaxVnAv8As+VXYeJgqtwmcJGiKX0U669isO+rZY8fNaXTsj7Ti12eUFA6jXDg8IzFhOM0 aaEEBLXcVMndChqCYVVsKcYhMeNVKfZ7kwDgJ7FGlLAFuhCmCWA6cpOua9o53BELhs157J1ItCSI kKTh4KLmhzfD4Ke41tAcPggpUCEECDEFG3yENxLjyQglg5hPKJUBGqG0zo7VEa2OEFMtBoE24j4J O0KTNDCKGTHBwQHex8dkXvATWIpRmdyNMof0xpyE4d2SUs5hkOUzrqn17JyRAMapBDF8Ae4fBQgS PNTfq1QB0TuiEwA+aSdsEykgl//TpvgnhSZqNQoOHips4hUW4ox2KgQT3UnOhDdJ4QUo2Bp2zqok zoeFAz4KYSpTC3hCglWHgHQoBBGqcEsfJQIUtxTCEUMTI0CYtRSIQ4hEFVMSwBRdpwiT2SIjVG+6 KR6tCGZPKOVDZrJTgQgsWlw4S3OOiKGxqpgA8IEhICCCNArFOurlB4JKdsg+SadQoNn4JnPITtKH YZOqYBqudnobJLn/ACXVfRb8lgdAqisHxK3bTDStCOzUyHVzyZJKYp0xT2FgVBymVB3CIWFyc06r LsK087QrLsKjkmLLCP6QjxCvUggQs3DP6cfBawapILc3R0MYTWVYbaTXHgg4+jUV+jEivhoKaTzu KbYQlMFSL5TWRZ1YHHdRDSDA5RNpKiSQUFLEFvKjrEqTiSozpCFJYzKYp4USkpXOibbqkpbuyCqY lo8E9jS5kDgJ5B4Sa6Ckpouae4Uizuj3kDQceaAHaQgUhVbAXeanSC29vcylQ0l0jhWMIb8sBIKL rOtroBdaz1JHH7qzHFrgXhoAKtZ+u4KmWllcEQpejFIBlRl2Y4IrgBTPV7xrAVQOhRPiEFnEdmVt 3qk3PrBPdV2ZTGfQY5s87XQtTMyX2Y20MDQBqVhUXgOE8ShsuAb5va5oY9hLf3dygH1RtFbo8JRr KhvBaZBVqmk5V/pMgaIWi5W0zRWRuDHQf5SbbX+4771azHnFd6TuQqgyoMppLKGBqxwZc14nzRW4 lAMtc8Eapb/XIAGqsEbWyiEFi/FotPqPc4fBU3VYzTpY9Se9z1Qtrc8buAOyauBbgrx2Hc25wP8A VU8bHozslgc+AOXOH7qoPkBXumCZJ8UQFvFqg+swDclrBBAHKx6pedoiVqfWL+kgfyVjN1OphIrn svq/Va28ixu0gcfvLpcx23Hc7ggd1yP1Y3bnbjMcFdZmEtxHubqQJUgYZvE2/rIL3Q138kaLOsea nbXcq6Mo3sLg0sPgnw+lMycWy+0kvH0IKaSbXgNHe+3Ro4UhVYBqIKl02drvNXHJkpULZscBM0xp eWem+GuLPzXIuXfXkhxdU0PPD930EB0KBhQcZbHsAdUxsLLK7WbXFg/OKTrfUeXkAE+Cq2AQfJPi 6gKWGzXnDhNNqna02EiXEKpaP0UHlHcIs+IUA5g/RuEyVLbG0663WGGqQBboeVovdWxpbTo4fvLN d6hdA1PkkClM3RWK6DcPaRKzrBZX9LSVEXuHBhPEgh2v2blgbhWXjxYgREt4Pg76Shh9fy8Myx24 fuuWlkdfxuoMi+rbaPovan2Ct1eevbBKqkaq9lM/OGoKpnlQy3XBda/RDFseIWOeVqdG/nx8ExcH p8R0AyrHKrY4gkKyCmsgVCfbCUpJKXTJ06Slk6Q0SlFS8pJinSQpJJJFS0FKITpIJWTymSSUukPN JOkpdJMAlKKF0kuU8DskpSZKUgkpRTFOAncQUksU4TJ5jhBSySdNASUpOklwkpRBCSQEp4SUslKe EiISUrlNKSUIKUYTQlCUFBKxCW1OmOqClKxguAsLCNHCFXUqX7bGu80QdVEaPDdUp9DLsrHAcVSW /wDWyj0szcPzxKwFKWI7rJJJkEKKZOU0pKUkkkkpRUVJRSUpJJJJSld6a6LI8VSRsN0WBNlqCmO7 0jR2VO32vCu1EgyqmUIO7zVMbtroumIUhqmKlgxSWUviop+QpmJSQ0SSSXPS/Ve4lj6Ty0yFsZTN 9Z8lyfRbzRmN8H+0rs3CZCeNQtGhcImAoyDJUrW7HOaeJQ2WMd7YhVSNWyzaJOqDqHkA6eCKQWaI dggggaJbKXDmsdJkn8FNzy8QUO0uOvZKt0jVLopcDkFSJcYkyEkvwQtK40UXtJMqQGqawSElMXCd RykTEJHQKLBv47JKSFMeRClyFEapBC5aZlScZCi5zgQAnE8JKCPdtEjkJ98gKLQRMp9o2wUUpN5A 0Tn9INeUMjSQptMooXIICA90GPFGcCO6g5soqZ1g7tUk/PySQQ//1KL1JoMeCTgDqSpN0GiotxG9 jz3UZhTIPfhQLIEjlBTEuLkmujnlIvJTvdpxCSkTyoGYU9Ahu3dk4KYlOHKMSlBBhOUykKOqUgaJ be8oKUEx0SED4py5FK0h3CQSA7pA66JIZkjuFIQOEMydFINkQeyaldzkzXhO1wKj3SUlB8En/RJU B4BFrG9wafFGI1UXrOkV7Km+MK9kmGIeEza35J8o8BXw0plrJipKJTmNjCg5EUXDRFYXF6gNVk2F a/UQsewpkkw1RUOi9vxXQtXM1n9M34rqKtU6CMvRuN0aFO8wxIDgJ8xoAAKMl8dnPJKSkQoGUxel a7xU5lV1NphOUzOqETBU5Q3JFTIETJKi4yRrooO0UZTEszYBxwVBx8EyYoJZgiNOU8goJU2oKU6C IKru9pgohOsprGhwlBK+Ofd8FZ6R78ou+Kr42gJPgl0i4sudB5lIIO7r2X6vEfNZ9zpZqrgcfe3s 5UbmwyO4U/RikglOx20ghQBUimtcnVPnZtuW3a6AB+6qtVVTDJEqTWyVStuLXFoQICgZy2bbX7XS EduUGP8AUAh3iFltvHcq905nruJdq1qBpdwzDPIvbe7c4S5AIqPaEZ7mkkBogFPU1lgdI4CaSvAk ia4MMhWLrJaIVLdGqskywFFkFsWPnhRsEAgcKDbC1ye+S726gpq5A9u7hX+mtAgO01VQNLTDlp9M pFjxPA1KMUEOP9Y3Tl/2VjNidVr/AFj2jMOwkiPzllVCXQdAe6JS9Z9VPY1zmwQT+cuozCBjOLgS 2NQ36S5v6tMZW2xshw7ELqH1utq2NMFwiSnhikLeDIY4k1mGdvUQdjGvcSNI7LqR9UdINv8A0UJ/ 1Pe4k+sNf5KYd2UB5rFsqrJ3GAVOy6qfa6VrZP1RuxwHMPqju1o2uWbk9NGO7bYwsP8AKTJ7M+HS TXNzexUDc1SONX4KJxmKD0ts8TF9gI5T4ZlvzUXY7E+GNS0cKaFVo1Mt3q2bgWOFrgQzxWbdZLiR xK3HPD2ek7VvgqNmGysnaZB7FSMCBr3tGo3HxRKmPPumD4I7KobtA5TkFjoIjxStTXdTvnfr8VF2 K0BXHgObAhQ2kaFC005rqI1CC6WnVaVjI1CrW17hrykhHXf+a7goTmgHRM4bUpSKVncrQ6SYvafN Z7ld6cdtrDPdBQespEPKtgqpWIslWZTWUMkgmTykpQTylKTZ7JKX07pJeSZFS6dMn4SUvCSZJFC4 SOqUpSkpaE5CSeQkpiE6SUoJXBhKE8JiihXCQTJ0lLpQkmSUpOo/FOCkpWiUJJIJUkPFJKZSUpJO kQkhYT2SSSQSpOklKSlJFMkkpRSkp0klLKKkmQSxiUoj8qkopqXO+uNfqU1X+Gi40heg9Vr+0dMc O7FwAU/RiLEtKiUQ+HKu1dFyrhu2ho/lnagtc1MtDJ6TfjN3ugt7lpVGElLJQtnp+BkMHqhjYPHq Js3BdrbAHi1qFppx4TFaf7ObfV6uOZI+kxyzi0gwUrQxTKUJkVLKVLtrwfNRTN0KBU9RU4ENJUMx ggwlivmsHwRbhLZVI6FtjZr1atCchDx9Wx4IpHdSRYyxTpQnAU7CVu6SnCfbKSWAcWEPHLSCu/ps 9attg/OC4PZOi6r6v3mzG9N3LNE6KClzaNzp8VnbdgnlbOXIZuHZZZG8QVHkDNA2EjNjme46quGa zyE7m8AJNcRpwoiV7F43SAhsrLUUtPKEXObrOiCUoG5LeCYISDtw0TOkIqXkgpxJB8VFrtU9Zhx8 0kMTJ8vFRZLTHZEiJHgmcgpmENxIOgU2OJ5TPl3HZJTNsD4pSoB0RKd7p4RUweB3T1zBaUrNdeyj MEOCQUy3RonLQeEvpA+ITtJRUpwB1TPZqHDjuFMGTBTxokpkBpokocBJFD//1aTjKk06JHnlSIlU W4wLfAqDvBTcoEE8oKRkeKTuFIsk6KD9DBSUxOnCg78VIqJ1TlI4+9IAhIxKTSSnKXKSZKYQUoJp 7J1GdUVLg6cJAEpSnH+pSUyaXDhEJn4qAYPHRPHgmlS0wkDuGqdw01UNEkswCEfAYX5DZ4Vb3ToZ C1ejAuvJPYKXGNVstnrKBDUDId74VpghoWfc6XlXA0ZFlIUSoSlKKLZEKDk6Z3CKwuR1AaLEtPK3 c8SCFz9p0TJqxtev+cHxXU4xkBctT9IldLgukBGCcgt1d4Y4OPAVnIy8W1uvKyr7JkDhZdtkaIkr 4us+zHHBQjbV4rFNsHVQNzU1c7htq8U3rVjusQWyp+pCSnZN1fio+vX4rHNwCXrjuJHgnKt2ftDP FMbWHusV9zXGWiB4JvtEIUp2fVZ5KJsZ4rH+0ApvXHimkJdY3M8VH1mgzKyC5p76pNs05QpNuw+x vKG+0BnPKzjbuAEqOVcC4MHAQpVuyMmqulwH0lT6TLsmJ7ErPLyVo9FE3OI7BELTq6zbJL1X0e1w 7p8c+58oNJ9xUq0sAOykQj0+1xI10QHXbne4iUy2IR1UatJlAspaQQQEc3Acx96g6xrvBBlAA2X6 Z02i7JDLNG+au5GA3DveKneyFnB4GoPwR8G1rtzHO9zuJTZbKtk3pt9TN5B2v1EoNTDW18+Oq2X5 uS4MaS32cf8AmapvHqFznxucZICaSu6NAVBzC5KPaAOUR5EEAQAhE6BOtQQOEJmakJ3kl0Jw0jUJ pUQp7iXFa2EdgbEgrOpYCZPdaWM1272j2junBDz3XDOW74LNZyrnUzOS9AxWCy1rDwSkueq+rQhj hE/wXW1yGt1hYnR6KKg5lM7wBu3fRd/xa3A7cGlwlP6MR3biSQSTGVAbSDC5j61P3XVM8AV1Xfhc X9b3uGXWBoNsoSFhfiNSDkvHdRVV1755UfWcVX4C3PcDaHOiDiOhzp8UH7Q4agp8SyXkHkqaAoNb LIE6N9tjzw2R5FSA3GToo1b2jaACPGUdtJHunlOJpjESVi3aJQ3QdZUrHR2Qd/kgheZ0Tk6c6KHf yS2kBJSNzuxUDCk7fxCj6Fh/NKVoad41lDgjlFvBaYKDKcpZyuYP8434qo5WcQwR8QgoPXVH3q2C qdf0x8FbCaWQMk8Jk6CV0kyeUVLpfFIJ0VKASSUmuhFC/plQUt0puUlLJSkU3xQSygJ1HhS3IoXA STbkklKSSSSUpIJ0klKTEJ0pSUtCUJ9yUpKWSUkoQpTGQmlSITJJVKkI+aiEoSQyBA5CRjsmT6pK WkJk6aEEqhJKE8JKUDCYp0kFMUoTlMglaUk8JikpPjt9Su2o9wvO30ubY6sDUEiF6Hhu22geK5nP 6fmfarPs8BszP0VJE6LJKx8arplYssbvvP0W/uq3RRlZp3W+0fuhT6ZjZJcTltBcOHLdaQxsAJLH Ks6bUWGsk68lZP8AzZ9O5rw8OpGpn6a6R6A7VMMqX9GhkZTZhjYA0VV+17SC7UrV9IHlJuJXM7RK Zupw+n0WUuId9E91DJ6S3IfvY4NnkLoia6xtcWtn81SFQIloCBkb0SA8k/6v5H+DIcFnZGJbj6Wt LV3RLQYkfeh3NFrS14DggMp6p4Q8CVBXOoY4oucwcBVG8qwDYtjIp3unkmuByr7z7Y8FndPMBaTA HNKqT+ZsQOjQrMOIR4lAI22+RVgIhRU1sogYnYiBSgsRCLanDUSE8JyGAYtLodpqydnZ4/6lUQFO uz0XtsHYojdBexe2QQsIt2kt8Ct4ODgHDuJWVmV7LCR3SyDRdiPRqF0apbz8knNA9yiBu4VdnZMd KgRr5Ib2lpACZx7SipsCBqlu3JmMMSFF2hCClN5kqRd7p4KiXEFR2ge7lJSV9hiTwojTTsoNk6Dh IyHAtRUlDtU8yoAEqUwkhh5J920BRIh0+KmCHmElJTqgGCNEZB0a4hEKSDVs907QAUzfDskXQkpk Gx3TiCoxu5TAjgcooZCYOiSZwM6FJJT/AP/WpQCpHwSAnVOqDdY6KDrBwneZ4Qy3xSUyDo+JTOZO qQaTwiETykprP0QolFsGqGQnhDAiEhITFOjSluTqkkl2SUvyE0Sk0kpySgpZSA0TR3RBwkVKbCbd ATgpjqZQSz7aoY5UwExbAkJBTEuhb3QGSHPiDKwZkLqeh1bah5qxiDHkOjunRvyWW4SSVpWmGlZ3 KtBpSYwmUikEUBUKLuFKUN50SWlzs3ULnLzErpcv6JXM5WibNWNHQOStzCcQ1ZdG0VafSlX8Z8NQ C47uvi0DIftPAU7qq2naGjRT6OJa95QbXS4lErwEZawfmhQLWH80KcpSEFzENZ+6JS2N/dCXdSBR UxLG/uj7kw2t/NH3Kcp/SJAPAPigpG54P5rY+ChLf3R9yKaH+HzUHVECdI8QgbSwLgfzW/comD+a 1E9J23d+aoBpcYCCqYEN/db9yiWMPLQims8aSl6R4kT4JqUDq2fuhQspqI1aEZzSNFB88IJpo5WE Kq/WZx4K10Ll7onSFY6kS3CDe6l9V26l3gisKYVuJMAj5KNLduhEu8FZvvc69wk7eyqvljxB7qXU hgE9yz3WMMNZ8TCzsqmyx/trMre9V7KXOkymaz06Rl23Tpu9PlyZRtdGVvOHp2UR/NO+KqupcOWl dbX9ZcYt2gPkrFts32l/5pPCIZGhjt2OgtOq06raQ8TXBA+kChi9oEQYQriHwWghNItTeruDpduA 1QhYDZPMBUQrWO0uqeAJP7qBit9zXhpVjhw0qA3OEDsp9dyBkUVsqxzXt5csQNt80VwdS1hncAot c6CRofArN33DguSD7WkEygl0xlPBADQVuUZFobsa5rqokwPcFjZdouY0VtAIieyP06WusHkkJdFU HAy3brnnzKlhfTgfS7Sg2aucfMp6CwPHqSG945RU970mq+prhkbZgbdi3KmkNbBgrC6IzEc1zsYu Og3ep/3xb1QEAHhPGzHLdtpJpCeUxkYNJnVcT9dJGVUR+4V3EDlcV9cq92TVrptKKgaLyrifJQ3l WXY48UF9EcJtLuIrU1m94YCGk936NTbHUW7TyPBDd4FPW5reRKS0l1mWMLQSQEfHymWy0GSsFyet 5YQ4JEWyQnwu5ZtGqFtB45Qa8htn09B4orrWt0bwhSCWe1rfpnRJ9tZHsHzKF7jpMpnMH5+iSFnX xIJ1/kqtZeSNSU91tVejNSqbrN3KNIZH36lCnVKSR5JIoXcj4yAUfH+5BIetafc0+S0XRtEcrMqd oz4LQGoTSvC4STgpJJVCeEpSSUukAkEkVLpgkpQkpUJyUycjSeyKGMpJJIJWThIJJKXS4SGidFCk 6YJSUlL90kwKdJSkilKUykpaE/klPZJJSgU6RS7JKUlCZJJSgE8JBKUFKSSS5SUpMkkglSaU6RSU qUkxCQQSqFINJRWVCJJTkhvCdS20RZCi6ApvfKF5oFIXa/a5pHYp8vDY/INhniefahuCuXn2sf5Q lHZEkbWxopQo7kn2AILQjeglNdeBys27qlVZ9zgmrnTB1VHJy32P+zYx9359n7iojqpySasbV55d +axqv4rK8Vmxplx1c7xclSLVT02ql28+6z99x3JP6WywlzrH6+DlZFgKICmSC4Fzv2FifyifHchO 6LUz+bfY3+0tchDeFGSV4eIz6TVcWEl3m5VGjVdB1tjGvbYWz81i3bfUlogFWYGwwz0LoYRIPktV vgsrGiQtSskEEKHINWXGdGnkDa4HzRmqOU2QUmGU0LynaigILTqigqUMZZQnCjuTbk9YUgSIkQob k4cjSHqelXetjNnluhS6gyWbh2Wd0C6HvqPB9wWzezewhP3CImi44cHN8VCU7G7ZaokkGFVbK+0E yUBjvcWkIgfDoIQ7TD5HKSmwBA0QXDcQfBGIJ5UG1iYSUqQdO6bsWqWwBQfoklerXQJ3Aj5JmMA9 wKmXT2SQx3kOUihmsuEKbJAgpKYzPHKkJUGmHGAiHVs9/BFTNuvKjbHKeriVFx3AtKSFTopBodqh tcRoeERpCKlBwBhJwAMqBAmUblJSx4STsgmO6SKn/9em13YcJjPZPt0UNwVBuMZ2n3IghCs92qkw acIqXcY4T9kxMKE+KCUTzqocqbuVB2qeEMDA45T8DXVRmdCpFEqCwCYpHySH4pKZDQeCjP3pyE/w QUrtqpccKE/cpaxokllH3pmgjhKUmk99AghU+Kk4khMSDqnjSUksRp7e5XZ9NZsY0eS4/HZvtaPE ruMNoA+AVrENGHKlyHe2FThWskzAVaFYDULBMpQmgorVkOzhFIKBYiFkmjlfRXM5fK6XKOi5nK1f HmmTXY0tTYaAr+K0GRwqdbVo4dNjgS1pI8QkEjWT0HT2enjE+KovEkladbdmMB3jVZ7YDpdx3Rky BFCW1Wn7O0EEqFjK+N2pTVzXhKFY/R7g0/RHJTXBsHaQkpBCcuDhDhx4KbAHNMkISSkjrp9se1QD 2tADRooFRJQUkssDhwf7kKYSTbk1LIvHhqo7hMkaqbfozAJTsE8gA9kko3OBQn6mVYIbJZGvigO+ lHmmpY9XcBQ0KfQdwpc4HafFB62Yqai9OaW4Zgc9k4LD1dCq59tRNhB15hCqrm0OEaeKm1hZjNAE SU+Ow+punsU7owBK05FriW3NYJ+i4IdJe21zXua8AcgBXsXDbawO9I6nuVnV4loyrWVtLQ2J3lKl xiK0ZXWOLokMZHZoXL5J/SOgrrcXDqyLn15R27Ro1p+kuWycbZa9rXbmBxa0x+alVBMRTTLj4lOJ 8Sk6shMAUGRv4Fmw/SifmoZuW/cWF0gd+ETpmLVkFxvf6Yb9D+UhnHbcbHc7dAmk0ggbtQXxySR8 UxeHCJK2eh49bq7Bc0e7RsrKdi+nY5jiJB0RUaWgNEFMATqOFZxsezKs9CsiT3IQMjHfjWmku3Ea y1JAj1ZsLZh5O3yWpg+lWLHMJIA7qg3puR9m+2gjZ4fnK1g2u+z22jv4hJds4biHOcRwSU1VnpOD gAY7OTTyVFJT3fQ+pWdQY972tbsgQzRbxh1QIXIfVU7Q8rsK9pYA4wO6kBYju1g93iiBzvEoV+yl 4DHtII8RKTbm/vD700hkbTMh7dFzv1ufuspHcSt1jwTyPvXOfWt36zWPAIJcB7vBQe4AaqTj7uEN w3FApQWaoIVmyI41QNqSFdlCYKIGyE2zVJSQPI+lwoOMatKtOqJZA1Vf0ikpH6r/ABTFzjyieiQp MqLuTCSkO0lLYilgmBqptpLuELTSLbAUBqrN9BrAk8oQr2pWpGQjUIVggouNqkp6igzUwrSZx5rL xP5lpC1GNO2SmleGcykFEJwEFzJOFFOkhdIJk6Kl06iE8oqZAwlun+5RKSSF0kgkklSSSQ1SUv8A FJOAlCKFJJykkpaEuE6SSlpSTwnEJKWSSTBJTKUlHhOkpSSSRKSlQlCSdBSwSTzCYpJWTyn4TSgp SW6EyUJKXGqm0AKCQSCku9DcZ1TSmKRKgFJk5STUsSjWkuw3bfpMQirWGA4PrPBCdHdEtnDGTf8A uz8Co5V9tdW8iCufyN+Je7a4ghx7opzsi7aL3bm9tETFjtHfa93ucSfKUKQ/RwlWLmSFWY0g6o0q 0T6vT1aYnwUa3WVGWuIRcgQ2PBVWgu0lFDuVdVNYAfDvEtWzRkV2N3ssbHxXF7fNRI2lNMQUgveb +4cD81Uy89lLdxM+QXHtsLPokiU4eexUZxLuOmzmZjsp+52g7BV7RIDki6USN1ZCkArQMUjrafHd pK1K3S0FY2I7Ra2OZb5hR5AzYzqlyBIVeg+34Ky/VqqVaOLVCGYtiVIP7IZUZUsWKScPSlCBUgVI sSgpShgqQKKG706/0cljuxO0rsCuCJjXuNV22Hd69DLPEJwQd3Nvp9N7o+KC+VoZ9eocFn7d2p5C rzFFsRNhZrBIUXs90lT7wErGghNXMWS32njxUyNfJRrduTkkD4JKWb4JtZjsVJrpKT3JKWEBJwJg hMY7KesJKRvO0weUzDJPgme3fr3CXMEIqZhsGUQiQoHhSBlBTFkj2lSDZOqUgnzUgihhG3RRjuFO zxUAd2iKmTm+ClG0JmukRwQpaQkpQ5SSZwkip//QqgaIbj2UyRwoPEhZ7dRvkJ2uBGshNwnklOQt yVF0KRKi4kjRJSMnVRJAUtvimMDzTlIyNyR1UpjhRPKKlJAykRCYRKSmZUY8Uj8UhCCVaHupkQFC fBSSQvtA5OqceCg74J9dEFKb33JNBiTwnhOSkltdMZ6mQD4LtMce2VyvRGTYXeAXW06NV3GNGtkO qG/VyERCVthLvJR3ypg1ivuS3BQJTootlvVa0hFJVewogMcy52YYBXOWa3Aea6DOcsGo/ppHKZLd dDQEt6sSV1GDnjFp9MN0XO47d7wPNbZNBYWNsaXgTsSVi2Jdo4pfV8dVlPw7AYhMOp3MrAGipv6h c7kpebKGwcV/gm+zO4hV25Nh/PKi7MczlzpQXW2vsjvBN9lcOypjNsfw4/NP9pu/eQsJbJxneCb0 HBV/tF37yA/NtB5QtTdNLvBQNLvBUvtlzuSn+03fvIWq22aXDsVH0j4Kocm395P9otI+kgq2wWHw KgWOQDk2DkpfaXHuUF1hNsPgjY+JZc8BgJVE5L/FWMTqluM+WnTuhRTYW+sdZxixhEyrfTaWPww1 7iwePKyus5bsy9rnaxwtSjOxqsVrH7t3/RTgdWKWzdzGBjW1gyI5TYdUGDxBQDe3OIdST7RqITVZ bK9zS7UjbCPRio7N5nUa6men6+g+ifT9ygHh+7IF8v8Aol+3ZtWa2x7WFpsE/my1GwshrGGtxD3E zx7P+uIm11Fle5pB9C9r7Y+m9uxqwNzg87zr3/dXQZRpyAWXCtrI0YzsVmNwK2nWxu3sO6JXBztn qPJcgWDaSAtX9n7XEtsZB/eQrOlOeZFrE3VdYR4xdXUC94dT+433PYrDrmDa2q5rmuP0Nm16lThi gbq3MbZ3dO5rkY4zshwDBS2z95h+kmmNpLLJxjY0DQrQw8NrahLAT96z83p11JDbLmmfzVV9NzR/ OkDwBUcoSqkwIG7vupDNWtDfgqt+LU6t0hu4jlZHpzxaZ+KNQx7Ad1jTPiUzgmGXijVIXXZOHj+k 4tNfYTKlRW44D3NBgySR9EKN3TK7B7LG7v5SvPtfg9NdU21pdBHtVgA1qwPIAJlNjdFu9I+rd+Z+ meNtQ1935ySU3QbPRae4PK6DItNlWwTBWOzJpfd6dTQwN9pLeHKzn2OZUXMOnijbCd9HmMj9De7b OiICLWy0lVL3ucdzjJKHW4tMhG2V0WWOZyT96kbp1JJ+JVZuQCPcNfJS3NPB0TtFJNwPZMWzqFDc BwVEvHigQFWp7QPNAcB8kWW9kC16alVbt0hOVXadVcIAAKCmDLHNMhWftQd9MfMILXt8E7rWnsgp L61Z5Tb6jyEDc09kwcB2STbY9SvsAFF+QYhoCFvCRsCFJtgC4nVTDCNSmF8ajlDsuc/UlFCrXl5k o2JEFVSi47ockh6bBP6EfFalZkLJ6aZp+a1a4hNLIEo5SlJIJq5cJQlMcJIqZAEpJpSRQunUU6Sl JwmSSUunTJ0lLKSZJFTMFJRGidFC6faAmTJKUkkkkpdOmTykpZJOUklLJASkkkpdIhMSlKSlJJSl ygpSSSSSVJkkkFKSSmEkFKmU8pkoSSpL4JJklLpJinhJSyNiP23NHY6IJSa/Y4O8CkNCo7PMfWWs 05bm9j7gqEiBC6P65Y4LmW9iFzVcFnwUpYi3CNzZ8QqkHv2KuUndV5hVLW6kRoggMcke2VRb4rTc 3cwhZ1beQTEJJKpHgonURCs+jXr7+0pehV/pO24JIasK7Rs2kFoPn3UPQrmA/kSpVk1HaCfkJTSq kECUWsSY8UdmPXY6JcHHiW6Kvq1xB5BRtZIFhQdjyFq43JCy7BstB7FaFBhwPZMnsyQOob/IVQmL PirbSqtwhwPmq3Vs9EqgVIGVEhSxLGVwVKVAKQUrGyCmFBSCKGQXSfV2/fU6o8sOi5+ml1gLhwFd 6Nf6GSAeHaFEKOz02SzfWVkkaALcIkLHtYWkt8EzIOrJjKANcDzomcTwETzUHkxI7KFlQhpaY7qU umOyZ8iD4onHKSlMb28Eo0hOD2PdD4cRKSliCCAiCRykDooE66JKZkwFE6CSoufr4qfZJS7eEzZn VRHMFIaa+CKmTzBlGBgaoLwXN0UjugJIZHwUIMy3kKYGkoZOqIUpjgTMQe6mWxqEwRORCKkTQ4fN JTcCBPKSVof/0arjB8lE7ndlNztNAq91piAdVQbi+yD7imMKLOIUzqipiXCEjLhB0ScVGO6SmLtE IhEKi5oOhRCmHkokKcaKMIqVKQCQ8+U4RUsmhSdxomlBTEHVTBnlRAIUonVIqVPZKZTAAmeE8oqX IPYpCeAE0pz96QS7/Qq4YXeJXS8N+SxejVxS0+Oq17zDCrsRo08h1aBOpJSRG0ks3BCUrBJSeUye EljElBeUciEB4Twxlx890ArHxRNjitTqTolZ2COT4qI/MybQLq4LffPgFVw2CzItsI40Wj05oLyD wRCPb02rBrc6txJeZ1QO6YaQthW7dUSqzij4rSanKqSkV4NpWuhBuMqTShvQKbZVHVHJVWvRFLkw rgWZMBVrOURztEFx7pJJXaiQoMCmUkBE7hSrd3UHHRPXwgpnkWbyPaB8EFvdFuEQhMPIRSsU7OU8 KLTGqSWF5mwLb6PXTdU8XNDo+iCsjIqLS154I0Vnphc9ha067ko7rS6Qx2Ybg4OdWTxohZWM0WNs a6S7UytHqNzs1jaYaCCJM6qpd/OBvEBOJNsMjqGpkEF0eCqVuLSS0xKM8wSZQGd1JEaMWWR4tGDm yVDZBRNxaZUDLinaLImRLF4Eorcc7d06eCH8UbhqjbgGjWDJRWt2+XgosPuRXuPdBdS1z3OguJd8 UTFofZO1hcfABDILmkBbHTOp14rBrB4dpqkpzhhgzNZB+Kj9jjlplbH23De8vNziT4tRnZnTreXk fAIC11B559MaMBlXrPq5mWYxcwDceG/nLTZl9PpM79w+CsZP1pxcdkhrneAjaiig0OlfVmrBb9pz iDA3QfoM/wCMWb1/60/aJxsE7afous+jv/4j/gVmdW67k9VcQ87Ku1TeP+urJaAe8JqS7XSKxEjk nutXqod9mcW8AatWf0dsgea0+osLscsAkHlJgJ1ePc6Qk0I2XUKyGAER4quHEaIMydoRI7ILX7eV F7XO9wOiKkzmKHdCBMQE7GuBlBKY6KvYVbsrft3xoqewudASUxZyr1ghgVIN2ugq1ZZuaB4JIQ90 5TDlSKSWMpyVFJJStxUZTpikpQUSklKSmSnSPcmA1CLX7XIKd/px/RO+K1KjosnpZlr/AIrVp4TT svCcSnURIUgmr10kpSSUuklKSKlJxokkkhXKdMnSUvp2TgqOiSKl5TpkkVLgp1FPKSlwnlRlKUkM kk0pSkpdOoykipluTTKZJBK6SZPKSlJBJJJSikmSQUvKR80ySSmRTJoSSUumShJJK6dNGiQMIIWS JTlNoklSZLVJBKpTOAKdLdpEIKYfWGv7R09tnJauLxhIIXfmv7Rg2V+AK4HHaW2ur76qcahhLrdF uxmudRl6Ns+hZ+45Wsno7mPDWPa5p+i6VjWU7RteCCPFVnvcz6JIHxQQNHbzOntxGe54c49mrnRs DnSeUX1JcOSo3ENMQE1cWTLqwHAiZEKwc2qHSwHcA3j6O1Dqqc4e5sT9Ewj1U5DSN7AW/naBOWlH Z1Jjt0MHubt48FF8A12t/OAb/aRb7nMMbGbAedqnYxpaBtJaxweWN/cTCVMnAtPI081nXfTJWxl3 YNkmmhzZb5/SWbfVFbXxHjKaNCuns1rwNocFbodIBCrlu9hHgpYjvannZjgXYaZhAyRofJTrIgKV w0Mqr1bgRsMtCcoWO72x4IpTwsKykFGFIKUMRZAJyUwSf9EpyHd6bj7qmz3VDJHoXmPzTK6Hp1TT TXtmI7rH65R6WR/WEqStEB6ilwfW1w7hUM1u109im6FebccNPLdFZzm/o58EyQsLoGi5hOmqatok +BTwYlQmNSqzYXewAQeFAaGD8kX6YQ2+5sFG1KcNY8EnDThSJ1BS2yYQUia/sdE+yCYUXVyZ8FMg lFShBbMKDQSRCKT2KE9oJ0SCF9muqdo2SeydhBB7qQ1EhFS7Qndqog6KUpKXaSdCoPZBUiZTubI1 SUsxTAQQ/wB8BGn70VKKSSSXRT//0qjtOEJ0d0UglBd8VQDcYhncaKTnKOiYo0pcnyUSpEaKBkJB SjKgfFOQT3UR4FFSyYnwUiowipidTCeI0SISRUslISmE2iSl5Tz3USE48EqUpKQVGE6Skggc6pN+ kB2KijYrd9rWkd06I1UXsun17GNHkrGYYYlijaEPNdAACuxaMy3K6poEHWFleM+K16Xfq4PksYHk pw6sckkJAJgVIIrGDkF6O5BsT2MvO9WOhQcGv9GD4qfVz+KtYNe2seKjAsrpmoN/pleslE6s8hgC Phs7qt1T3PAHZDYriaxhv/ZG14XqDkhc04w0rTZc/bADj/JWXdkMrdseHNcT3Cba8G9mbSmenh3Z jvuTFlh/wb/uStBLEKRKb07f9G77k5rtdoK3/cmkqBYvdoEMlNdcGEMeC157Qpii48VuhBk6Ja2z ASMzCNXVaxzXbDoplry8uDDqE2wuDQdoPmnZo1EsxrY+gdVH0bAI2lCwjqzyhDQVTa7VW3V2vZtL Toqz6yxwY4EEo2EpWxsLkIn2oxpeG7Y/FRdQ8iO3xSvVRLF9ps2tPZXegPDLC4tLmh2oCznhzTot DoRNdju3dPGmqziDsdR9LIyq30tIj6ZjaqGS8F7iiXZtrnmHe1BNDrBOn3o0d2IHinX7rWdxKGBA U7iWaKubSVINmKQuRS6nQaomH6m4+mASBruQK8k1nczlGosZZvfa4tJ4hNJZoQG6B5LnGeZRCfbq UHufCUd7y5uh47IBnQV6lTtiBA1Ua/P707mnSToUUKrdqpCuWyeVF1RDS4agIuPftEOEtKaUtYWN rMO4KM/Y0SDIULGB/aU7cZu0EElOWkpKwTq2E3UrDZTLhHwRsaouMaAKHVXNNZDU0oBed5TASnby mIlNZHpulfzbYHzVvqJJqIb3VPpMuY0cQr+bjG3Hc4OaCPzSdr3f1E8DVrnd53OqDdpAgkKq2gkS VsZGObnV1tMOI7qJ6SWGH3MB/dQ0XCVaIMHplWQf0lvp/EI2Z0Gqmh11WSxxH+D/ADkU9CfAdv0K G/oRqG8vaB4lHRffVw6qy5waTE9ytX9jWVM9XcxzZ/Nd7kQdMcdGW1uMcKFeMfSc9pixroICFBXE 2BV7CCPhCoVY59US0gLcw2gx3Kt3MAdAhR5PSLbGKHuGnkcrGdvMDuq/pWDsV18R4Jjr4KD3/Btf dPF5Da5usLZ6b0Z+ZSbwRA/NWi5rXCHAFUA+zHMUyGeAUonYtrTx8EqbA6XS0QRJ8Ux6XSNS07v+ inHUrI1YhnqF7pDfo/8ASTLkrRsWfV1llPq1e3T84rl7GFpIPZa7sikgtt9Td8fanwn45DmXV72k 6On3p4JG60i3DThslXMilocdgIHYOQG1OcdAn2xnRI9obtI7p2j3qeQ3bsB5URo4IA6Kd3pgkPA8 lpY5J4VDpBkuBPIWrTQ9mpGhS6Lgy4SDkb0j3SNB8ChRX2imUpRBWptonVClWhlKUX0Sl6fklRVa OUgSiBiXpQlRVbCUyIK/BS9Io0q0RKZG9JIVSlRVaKUkYU+EJeifJKiq0SdT9JS9IpUVWiS0RPSK bZ5pUVWw0jRIKYYPFP6Y8QlRRYYJSienHcJCtGiqwjHwSRgwjhwTen5hKlWESSL6WsSm9PzSoqth yElP0gPzk/pjxCFFVhHKSL6YPdL0m8bkaVYQp0X0h+8n9Ng/OQoqsIZTIvpN/eT+i0d0qKbCKUkU 0tH5yQqb+8jRRYRJkcVs/eT+lX+8lwlXEEMptEcV1n85P6VX7yHCVcQQBIglWAyocuS2VHhyPCVc Qa21NCt+lX+8U7a6pgkhDgKeIMunid7TwQvP86cXMLmchy9IqFFB3B34rh+vOxjkPc3cZ/zdykGg YybttVdWoymenltHk5v02rOsxsR9mlpDPgscefCu/svJFfrek4MI0cgVApb24+N/NncfNUBY0uJs BM+ChsLvJT+zv0gTKACiW27J9Zga4uLW8CdqsU41dtYtDnwe25Cp6XY4fTAn81I9OyWEiuTt5DUC OyLSZVVWOA14e5p41QMnNL49Ka9ojlJuPku1d7o/ecPamfg3uO5wAnzQAHVGqEZdx/PKi+179HuJ Vg9LyBy3RN9geOY+R9yOiNUVXh4qGP7HlpRC3Y7RDsGy0HsUVsdJU6tPEotuo1QaNQEayFVO7dGz SoMOcPNWlTYNryrYTyFiykDCYhOnxWFkCms+iUgFOJTwte4wHB+PU7n2hYP1heHZLR+63VWuhdQY zH9Kwhpr4nusbKuORc63x4UniiOjo/V+8V2urP53C6Kxu5pHiuMxLPRvZZ2BgrtuRKCNi4jht08E J7NfJW8uva49pVIHcCJCryFFtA2EgHt0QWktdtPdEaCOIKE9jt27hNSkALSfBLfqna0xqnLZCCkU 6lTj70i2Dwm3QUVLuHdRsZMEcKW47oCUbm6pBTAAsTglp8ikwjhOdEUMo1S4ScJ1TQRykplJhO10 tUW8wishJCAtPI5Tgu7qf5+37knt1kfNFSjA1STAeKSSn//TqIblIyoEFUG4iDoKW4pERon5TlMX GeU0ppnjVPKSmBCQGqUhOTARUs4Rqo/NJx8Uw1SUokFMUmhIoqWgJBsp0w1SQyiUjCZJx1QSqJTC RopQmM9kVKjzV/pLN+QPJUGhbXQ6veXeClx7rZbPVUCGqrlGXq5X9FULPc8q2GjNIy+KixxPkgAK W2U8FOYjZUAnSlSSUjKBZwjlAtMBPYnmOq+6wN81qYjAB5wsnN9+U0DXVbNQA+KbDqjKaEQ6+OIY CUB7/wBYmO3hKtgBjBOmiqA5LS6ylktP57voJkmYg8IAVnyaddDOkLn81m6yppmVuua+4AZjw1p+ iK9Vn5+GKbW2Nf6jQNNNqAGi3gkDbW927kpFzh3P3qQcOSNfBOyp9x/RNLj3CfQanrJpGHu7EqFr 3nQOI+auDAyR/gnJndOynERU6E0mK8QyA/pOdmNcbqtSSpy4nVxifFSz63tymVuG1zWzqnY33D4o AAhmmSOEOq124tb4BCztorJPgi0W0NJ9Vxa7shdRtx7KSGPJd2EKKm2K4WjlWfoK2ieEYlzK621t Bsd+8quVoGNPgr5ZVYxhJcHNiC0wh0DCD6jaDMGXiMm2sAnja1VvtRIG3cXH+Qtc5JvaTkWPhnjC Az7PcdjH2SUrG1MopBdXmV1C0Mbsj85qDn+6tjgACR7oV19Yt/QvdY5v7pd7UDLFDnNpdulvDWjc lVFExY0aW2Wgqz0zRzoMGFMVVPpc6txlpgtcNqDhGLD5hSA2wUQdWyBr81SyCbMlrAdB4K8XQUEY 7Q/1wZlPKcW0pML9TAQWVuLgACjE7nkqDLnNcSNETsxxOurPK3tbtsZtn6LoRMPezHc4MBaTq4qr bdZa3bMgeJQ7Lbm1bJ9vcKNtA66MvUbOhUvX81nhp4AJKf3E7YO7whFc3hbtETonN86SqA3TEGfB ItMxBnwSU6BuJEF0hSrI1EhZ4JnZBB8FJg90QUVOrRS614Yxpcf5KnmYwxXDZbvJ+kI2uZ/xiqY+ RbiPFlJO/wAFf6ncLXh7qTW8j3E/nJ1MUho1W3bB5qvkEGpxUtDpCe5sUuQkNGOB9Wrhs1SDC4na nrEpgDMBRNp6TpYAa34K7nYb7qTY2Ibzr+kVbpwI2ieyLmV7wfEdwnx3YStQ2cil3YBDyOj+vdY+ 0PaZmsge1yHlatbHggTc2P0hI8JSESdWM5BE6t31c9rQzY4x5ItHr5H6HMa9tB+k5o9yzvWt/eP+ cpVOvtcGMMk/ykOEjVeMwqk/7Obj5gOM1xp2/Teqd+HUGvuLnBxP0Qi5mJlBhc18hv0gHIIb6tAb +KHivibdbpFDntaZEK1kgeofJYtdV4DfQOo5RPRyu41+Kizn003+UHqtvEKMKl6WV+6U2zI7gqjT pt303WGGiSsx9FVpO+w1vb/mojjkM1AI81S3EudOpI1VnH8rncz8yI5RjYdSDyFp0MBAPdY1TNSt HFyHUREEfulTEANUKzsa61whvt/eQ3YD62y1w3LSfn0vGgLD4HVV3ZVI5doo7K+mnkvc9oL9XDkr NLiDorOXkNsdDBoglns3KSI0WSYHUglG7oJVgiCCnLHd6I0fpHHsNFo2YOZaGubZAKzuimK7SPJd Rigmtp7QnAaJui5Q6XmkD9NoiNwc9mguW2IUolO4UcRefPTMwmfV1TjpGZP86VvgKQCXCFcRcNvR 8mINpTfsTK/0y3kkqCuIuAeiZI4uTO6NlO1NxldAmKVBXGXmn9Hym6i2VTux8qnmz8V1dgkLIzW+ KPCFcZefOTkMOrkP7fkCfdqp5AhUyO6jOi7iLZ/aN7dQ7lL9oXfvKmooJtvt6jb+8iNzLTw5Z3wR Q7RCykG3Rrz7p1OivV57wOAsBlkao7bidAiD3TLwdr9ou5gJftF41gLNbj3PjYJJRn9JzWxLJB7g pwK0xI3b37Td4BP+1H8QFRPSc0GHN+f5qQ6Tm7tpbB8ZRWt39qO4gSn/AGq7waqLek5xkbNR490z elZpk+nqO0+5FTf/AGm49gojqTh4KkOkZ23cGz5TqnPSM0AHZIPgfooqbo6m/kAJftR4E6Km7pOY 2AWc/nT7Uj0jN3bNgH8qfakhuftJ/kkepPMDRUh0nOJ27OEm9JzSCdmo7fnJKbhz3nSVJue4nQ6L PHTc7buFZ+H5yc9Pzmjd6Zg+H/f0lOgM8pvt7yJlUT0/NbzXymOFmtO30zr9ySm+M54Eyp/b3NHO pWb9ky920VOlMKcl3+Cdp5JKdN2a/iUvtpnbKy9mQRuFboHkkBeBuNbo8YSU6gyyTE6J2ZZkrK3X MEljteNE3qWMEFrgT4hFTqNziQSU/wBucBP4LJL3gbdpB8ITG5xO2DPhCFqdd2e8AQdUnZj5AlZH rye8jyTjI1nshanSty3CR2WLe1lzvcST4NRnZALZQLbnVEPrMSNdE0oOzHG9HCvFzm+sG/mFbeN9 ZcYOcbmvhwgM/Mb/AMWucfe6w+/kqMT8Qktuk2Q6o3GzHEMJ9rXrT6JVVmOcy9wY783T6SwrKw88 wUakmmCTKQ3QTZu3VycaxtxqawwPH/vilU00uLSSwuTV9Ze1sOG4IWV1ptzQ1rNsfnFIso1aN9A3 x+dP+co0l8ufBc1piUP7XFm8ax4omLlvY4BgmJ3N7aqGQteNE2VnE1bBMoT6hjOrcCS/k6KvkZLr Xang6eStY+VlBm5p0/lBAggKKHNbttJ4nVAubuDTyVq+kcwtuMEj6X7q6PBxaLmS5gnwhTY4mQa8 iImy81jzARn+S6wYNA/NCf7JV4BI4L6sg5mFPC7Xb+CrLWu8Cux+yU+Cc4tZ7J3srPvEXkNrj+aU 4rd4H7l132atP9mZ4Je0o8xF5EMdxtKmGO8D9y6r7KxL7MxO9vxW+/F5cUk8tKltI7FdN9nYkMZn dH21e/F5dx007LsemX+vjMd3iCuc6ph/Znbhq1yu/Vm+Wvq8NQmGNMlgiw6eezQO8FluBmQt29m9 hCxnDt3UORsYzohaT809m5wHkpbE5aComRTAY1SqMAiUp/BMyZ4QUy3OmJ0UDJdPKc6OTbvdCKl+ VIWbRBA8FHbqHHsn0LoRQwewRIGqnoRrymcNYT9oSSyB0ScCQmaFONEkI4hSaSo7dplECSmNg7hP JUjqhh44KKGYEiEkgEklP//UpEpipOIUXcSFnt1DtEylp804E8qLht4TkKUSeyYEhJzh8UeqmJUV IOlLaPFFTGAmGicBMeUlMmjzUXDzlImNFHVIKXTqI8E4ACJUqJSPgnJ8FHhBRXSOqQMqQbuRUs0A Lo+hVwwnxK55ohdb0WqKW+anxDqsyGg7B40VFzDJV5xACFIKshpkW1dsJ9pVgwm0RtbSCE5CmVEo haQiOirXmArDlTyjDT8E47MPV5xo9TN+C3KwdzQeJWJge7Ie89lt4h3WtCUdlmQXMB1Mmv1Yr7JZ tN/obN0MA+jwpvyG41oc8ew6T+6r79l7NIc0phboGjyOPXaXy0SPFbWBRfkuIvYBWPou7opYGODG iB4BbFUNYJ0CB0CXneq4Yw2+o3hP0J4s3PaZ7IXXeqMyT9nq1aDL3Kz9XmbKHHxcopn0ohCpW624 +KW4nukXSmGqrFneY6/W45ItAnTaqWOwi1rXtIk6StHrLybQAeFmWZL97XFx3N+irMD6aaeWAvjd XDOCLbftQl8+2R+ao5T+nW0emxv6WfaYVNnU73PG4gjuC1X/ALTcSXbWbY040SlY0pIyCnI6m0+o G+AVm2p1VDXNmPFyr03Y9j3HLa+y2fZ6f0Esk0PINbnNd3oP5icI6BUY63+8gLnkQXGDymD3M+iY U217uOyG5saJ1UyrfaLmu9jtT4rYqzC2trbK2es3X1d30lgWbGn3yGd4WgHNZU0Gg20n6Fn+ETSl sWWFzHvsI3OPDSs/FMWJOfU5w9Ks1n+Umpd+llKIprT+ZvtdtdLTBTPG2SeSpNMAtLQQe6HZ7W6o nUrxpAtJxIM91Ou+tpl7ZUQwuEhR9IuT5C2EEBPbZQ9stbBQXVYxx94ti4f4P81CcwjRG+yG2kem AXd9VHXCzxI3Q9PyXUXB41I7FaFnUbH5jbdrd0cLNbi212NDvaCYn83+2j5uM+jJYN7XT+c3hv8A XRX227eoPfmttLQCBx4psjqBfmMs2NBHZVM2l9OS0b2un84fmqOfQ+q5pD2uB/Ob+akq29m9Qc/J rt2NBah9UzHZLmlzQ2P3VWz6zS5jt4eDGrfzVfz+m2V013Ete10aM+kiBqiRoNTHZ6tjW7gyT9M/ mq/1Rj63gG4WiPaf3VXqwnOILxsYOS5NlGtz/wBHx4o2xE2G5V0l9rZ9QDSVn5DSxj2EyQuhpI9N sEAgeCwsz3eoohIyJtPCAQ8/WOUbGBDyQ0uA5AQ6hpotDpTRLySQQNEhuznZ1sF0HaPu/OCLkw5h EkPQ8KCT+XumyZduI0I7p8WHsgyXQGgzwEAHsrF9m5jSPBVqw+wgAqQbNecdVyB4I+Aweu0kCfij XYTaYD7mzz9Eqo3I9B4fWASPHgphNg0mIIOrt9RqaaXna0HxmHLF6dbjs2i8EsGjgOUW7rFuQ01l jWtIUMbFtzKdtDA5zeVFEEbtqJDpUemHEUz6f5m76SOSSUDCY1jBvIaRoWn6SK6xskAqLmDo6HKb lRKiUt7T3US5viqLpIrZgqi92IKodIuPc/RWk1rbTtLgFmsNe99T2B8fnFXMXyubzPztHFDQ4lxB aVdoqa5+1uoPYLLsa0OO3QTwpU3vpcC06hSkWNGoDTpdQxG0OhpI04csp7FcyOr25MG73EcFUzlN MkBNiJAaryQ13N1RXuOwM8EvtAcIIjzUeVIxsHDRWD2QXjRFP0Qkh1+mWbarPOF1+LpW34LhcZ+2 lw8Suib1YMY1oHAT4lRd6ZUgQFzjurvPAQ3dWs7J9hFPUbwmNoHdcXb1y0aKu7rdh/OS0VT3ZuaO 6Xrt8VwH7ZuPcwpt6na7kpWFU976rT3Uw8HuuEHU7BwSj19atYdUtFU9k9ZecNCqmL1sP0crGTa1 7CQiFtPN5JG4yVS+Ks5ThuKqO1KiO68KMdkw8FHkaKdZ1TUpm1OKl9nPda+PTW5gkqZxWHuCoeNk EXC9IhWMdkkk8BaTsQKlYNjD5oiVrgK1beHk7Hhw7FdhTqPJwXD449MALr+m2epQ09wpYdl+X1QE m21nLDx2SDdw2nkIjuQUjo6fFSW1Ee3c2fzgk5sw8cogEOI8UmjlqVqYFu07x35Sja7yKm0S2ExE t+CVqYhsEs7FIMkFhU3cByTtCClake3cIPISIkBw5CJw74pNEEhK1MCIIePmlG10jgqTRILUolvm ErUxDdp29imDZlh+Sm7VoKTtCHJWphBcI7hMRuG4chEIh8+KTRDiPFK1I3CIePmkW7TP5p7KbRy1 IDc2PBK1I9gadp1aeEhWCdjtfAqZ9zJ7hJ/AcErUj9MP0IG4cFRFTXCQAHDyR3aODko2v8ilamv6 LCN4aJ76Jjj1AbgxsHkQrDRDi3sUmDliNqazsWoabG7D2hROFT9BzGlvbRWmjc0t8Eo3MnuElNQ4 FDjtdW2exhV8ro9OYws2htg+i5q036gO8Ez9HBwSQ+a5NRqea3iHN5Sre0iHcLovrTiCu1t44fo7 4hc4xtZe3dMSgVk4sbKWz7DoqzmRyVrW7WWGplQdAmZTnGbW3fkVCsHgOlR2uiCHGMIlNz6SXVmD wpXNYDLfoqFZLXS3tqkWQMLDJlwO7zVui4uaKnElvYeCr5GQ7Idvfyp0XuY0tAGqaRYXO/j1NqaG s4Wt0x0OLVkYYPoNPC0MJ+yweau4xo1MmoLuxKW1OFJC2oCw2p4TpIKWhKFJMkpaEoTpJKYwlCcp gipodXq9Sgkdli9AydmQB4mF09zN9Zb4hcPWTj5JH7pRIuP91t4TcSH0grHyGBjytTHsFtTXDuFU z6/zwqkxo28ZaDDKZ47jRO47dQnJ3CVXZ0Ud0pPPZJxUXuG3aJSSkf8ARBCg9pkFPSIZtOqlo4JK UAZThspg2BEpMnUJKWeCfkk3UGVMHcDHIUACRqihZjv9qKTHKgQl9IT3SUu5ydrp1SAkKIEaDRJS WZ1UIlxlO0wNUztdQihkBtSTB0pJKf/VpEKJOmimR3QrTPCoN1GU20zBUihkmU4BCxEd1AyCpym5 7pyltE0p2AJj4oKYyfFSAHcpDVMfBJS5jtqmATHXTgJExwipaddFKYKgD5KaRUoptByoukJ5SpVs hHMJAdwmElSbKSlwNQPFdz02vZWPguLxBvta3zXeYrYYrOIaMOUrZBgKtJCLku4CBKnDVJZbin3K CeUVts5UXJAhIlELZFE5Z+c7bWVoOWT1Z+2op0tmIbuX0oSHu8St3ple66fALI6WyKB5lbmHY3Ha 613A5Q2CwG8rdySG6ESCqN2K5nuoeWj91WB1TGzKfUa122YVd11Th7Sfim02+IDS2g6/IadXGVZZ VZc3dlXkM/dB9yBbzoZCdtlDQfVJP8lqWquId2hlWsL9lIIYO5XU9FY/7MHDgrmMh28HYNjfxWn0 959EBro+ar5AQGXHMGwHpQ0xryoFr+yyIcBJsH+cmYHyDun5qHXsyuX1lzjfE8KBwGHaXWEGJMpu oum8kgx3VqgDLeHUvgN0On/k1YGgFNGRJkQflRV49VcWMfpP5wVjKsYK3Q4a+Ch1FhrYGyDPgs0M b30CIjxalgMxE8IdDplee2iaCxlJP03xvag5Zse8MurDXD/DN/wqDUzpwbL7LHOn+bb7WIzmbX6X eqz80fuKUNwbIWsLCYKG5je51ViN0mVXIRKgga2wvHpNDnj80/nK8GWn3Y9za3/n0O/MVMVse8B7 /S8Hj95Hyjh6Nya3CwDS5v8Ahf5aYQuRXCzcPVPqeOxOLKDcDQ1zdIcLCgNurqJFE7f5SVLy+ze7 koBhlV/1nWc6lgAe6HH81Vr/AAGqCb2Ot26F7eJVj1jOo+5Ebr5CxSBlNp+i0x4ov2fTUgfNJzdw ncYUHWACOydbEYDqzGLUR7rBKA7CB+i4IzbA4ToIQ98+CC8gMThWD+UPIyoupeNS06IjCXO28Spm y2s+1x05HLUkcPi0D7iiCsdlbbkbtSG/cpC7dptb9yKKPdo7VpY+HRezc60scOyXptIl1bUJzKHc gj4IHwVRG6LIqDDtbYbB5qIYCOdUduO1/wBCwfB42qNtNlIlzZH7zfc1IaLCCkGdfAa4ggf5yDd7 q3TzCGLApPP6N3wQoBQJJFuRQ2ZVvp9tVNh9ckNPcIWLWSfkhuJB+CYN21u9PhMG0uHyKrWXg2OY NT+cgYfXWVM9O5hA/eaqt3UnFxNTfafL3J0Tqx8JtvWgWRJ08EM2BhaG6mUzXFw3ERI4Q2VuedzS Bt1lSbhrmuLV6b7RLYcWzHBasLIwqa3S+9ge86Vj81XaDc+l2TfdtDZbozcVUJw3Hc60udzuNeqg joSz6FourNbi09vBWKXurxi+t5bYP3VaZgU5Ac+m1znt0hzVLptl+BLjULP32omQKYCmm94hrnGX HkpiddFczcrCzLm2vY5jAPcxn7yy7RW64mpz2U/mz7nqLJHiDcw5BA6p/cm3OQdlX+nf/mJ/s9jh +gc95/qKH2i2/vMWb3EjUoWN/OEBaGF0/In9Yx3vaY/kuatG7p73QMXFdX4lxUsYECmtlmJG3mTV vs2gxJVh+FU2Wy4OAmf8GVoH6sZz/dtAnsXKX/NfP49v+cpaLXcB9WnKrFhaumP1SzeJYJ81L/mb mfvs/FGkPKgIzBpPddKPqXld7Gfipj6l3/6Vv4oUl5d40RgJYCuk/wCZdpEG5v3Ig+prw3abh9yV ILzjdKj8VdY6AJW236oDbtN2nkEUfVasaG533I0guCXIT3SJXTf82KD/AIVxRB9V8Tu95+aNKeFv MlA2rvz9VMA6kv8A85L/AJp9PP7/APnJJ0eB5MgK5RVuC7E/VPAPd/8Anf8AmCkz6rY1f0Hv+aKn kjSl6S6x/wBWmn6Fv3hV7Pq5kN+g5rv+imlIecFcK8zJIZBT5eDfiibKyB4jVqzH2h2gQBISVr3h xlVzxKIVAtSQx3E8aKbC4GU0KYMJpSG9hZ1jCWisWAK6epvZzjt+9C6CWsc8uMA91tGuuzgtPzUJ 3ZQ5TesgtI9ACe8lAv1DR4laeThgMLh2WdYP0jAnRpJ2Y2D3tb2XS9Dslr2eC52Ju+S2uhP23Fvi FJE6r4645B6Hlqd3AKTOCEhq1SNRTuQUjo6Ujq2UndighcaOITN7hOeQUuHJKYgS0hI6tUm6EhM3 ghFSncApO0cCmGrUnatBSUvw74pN5ISd2KR0cCkpZo0ITct+Clw74pN5ISUxdq0FO/QgpN1aQmOr ElLnR8+KQ0cR4pnatBTv5BSUswalqZolpb4KR0eD4pDR5Hikpj9JnmEn6tDvBOzktTNEtLUlKfoQ 5J2jwfFN9Kv4JWasB8EVLj2vjxSYIcWpWfmuSdo8HxSUswSC3wTfSr+CkNLCPFMzlzUlOb12n7Rh EjUt9y4R1hYF6SWepU+s+BC4djHMY9jYaQSN0bkCaCiLDXy7HjZazlwhKy/Nz2+jc6K2/vBWMwkY zbGgS0/S8Vv9Exjk0N+0atPua1MiV3R57G6Fl5bAyuDWOCdEWz6pZrNGwfgV2mXaOn4xfUwENH0V gVfWYul18sHYMROgsrgCdnmLej31O2Ob7lD9n3sER81u9W6zh31xRPqfvFYbcy61wrkkKISMtvlX mIG+7sYmle1x1Vit0EHwQcasNbKnJEhXoaAW1JAEl6Wp25oKJKz8Al9YJOqt7T4okatKqLLZrMqa B6Tv3ioGmw8PKVX1T9W0lKABYO4Uvf5IUtSpIMP8Utr/ABSpSUpgh7XeKkA4d0aUkXF9cp9DK3Dh y7ASsD6z0SxtngjHqP3mbCal/edj6v5HqUbTyFo5LNzCFy31YyYftP5y65wlV5DVuRNFw+0KAO0I 1jNj3BB2h3KqkUW2otBEwmLQBBRpgQQgb+J8UFLsADdExAjnupCASEwbKSWQ8Ug6CnOgQ3GOUFJG R27pmiJCZgkylY2DKSGJOoKnOuii5oKk2JhOUzCiY+5SCg72/NJTIEEKJbDiRwnHiE5EcJIRPmPa kpDkg8JIqf/WqGAq9hnhFLkGZ5VABuMCPApjoIUobOhSs1KepER4KJ5RHhR8kQpbkJEpSm0QUu3z TfEpinCKlimKeFEohC8qTSonhMCQlSmUwdeExglIkk6qJSAUzgt+CU+CbUpxqlSnQ6TXvyBHZdvU IauT6Aze9zl13AAVuAoMGU6tLIMvhBhGsMuKjClaZ1YJIkJoRtbSwTwpNakQiESQlYPXXRXC33aL meuOlzW+JRlssju2MNm2lg8leyjswn+ar0thoHktivFrvoDLRLUDssxa5CXKw6/Sw2N5nVPs3aRJ 8lay2trIYwQ0cBTw6LWPFmwkRojdC2PJcslNE47+Np+5Cex7PzT9y3X22udu9NwgQFB1l7GDa15f MuBA/wCgovcPZcMJ7vNXNcTD/afBa2B051tO1nuB/O4VfNwMzKuNoqIBHctTszs7pbQxzA0HjciQ JDxbGL0XbpfsFlbfe4o9fRzitL6TudztcsW76yZNggtaPgq1fVeol7WeqNpPdN4WyJX1b3UHF50G pUOm4FNz3Evkx7mD27ULLOY18WsgfvD6KnidPstYbWv2NPP7zk3hoMWSYQX0srcRW/eP+pVawaRw rt+IaHAFwLTrI+kq9tTJgP8Ab4uClFU0uCRlxfo8Tfodmsra1uMxsf4Uxue1VYc9xsx6dniHeKI2 pm1rXZhe78ytv0Wu/M9VZ2Zl31WFtxLneLPopB0Oje9G7VxYB81UYTY/Y3nzVUZVrml4Do76qLMx 3IYQjYKqdBjPTeRZUbRw4D83/hFqXt6jUwljWXUxpxuq/wCDWf0wWXkux7fTI+k1356Le3CcXeje +p/+EYZ2OSKnPuDnH3tAPgFY6R01+XaWjRoEklDbDTodw8VcptGOx1usgdjtSrRqRkTkps5XRxhu 3naXfvR7lnV5bNzmESI5VrF6rZk4294G4k/ylXPULePb/mpoBLYlOMTwlqh7nyARtQRZ81ofa3uP ta2fgh23n89gHyRosfuQ6tJ9xBjSFE2ta2XK36rD+a1M57Tyxp+SFFPHE9GlVlNJAlW7HNJhrgpB 7B+Y37kvUrmdjZRpXGB0k1Hv2ugajyRbLtkaHVWPXaOGtUxdPO34QkQriHaSAvc0TMtTbwdSji1v HtTizwgoUg5B1DXFg7afFGGZYBtboFI2yZMT8FE3F37v3I0Ue6EUzqR+CtYGBd1AuZVA2jUuQnX2 O03DRTpvtqO6p5a/+SlRSJxtNhdONeQ/HyGgPA0E/S/4StUj0HKcTsZIk9wrjs512mVWLTx6k7LE Sy9ljWsrYWBo/elRVK9EmQGoLSH1fyyP5v8A6QRqejZeO7catwJE8KDi4O3NJ0P7xWrX1t7RJql3 9b2oyEh0RHID1a/WC1ljQBEjhZwaGuDRz4qxnZf2ywWPAZHblAcN5kKSANasOSQt1seh7+nvDRuM n2rKbgXiP0Lk/qurmHEE9gtrA6MbmB19zgSJAa9R0Y2zw9Q/uoOl476mPDmOaSdJVx2KA1zw07iN TKwS80ZDmOsLmscRz9OFds6vQZaK3OLhrud7QopxN2yAhx3MaSZ7FX+m9KZlgudOh/sqtUNz9gja SusxqxWwNbwpaTAXqthdGw8fUM3Hxf7lrNhohoAHkgVo4RZGclKUyeUEKTJ0klLQlCdJJTEtShSS SUxjySjyTpJKY7fJPHklCYkeaKlQnEpgAPFI6CQElMtU2qYahS0SUrVLXwTFLTxQUr5JxHwTfNPq kpc6iOQud6x9XqsgG3GGy0csH0HrofiEJ5+aIFounzEy0lp5HKYlX+u1ivMfHfVUGQXhrjAOk+CY RS8asZUpWnd0TbrXcxwKpfY7GmDB+BTOIELqIdX6vWtY9zbI2H95dAcbGtPt2H+qVwdu5ntJQmkt PtJHwKZw2V9vdZmA2usuBcPn7VikTaFm4uVkPeGOtcWn80laxH6cDyQqlx2YN/nSVodIfGSJ81Rr H6VyN09+3IB80+O6/H+kP6r2beSk3uEw+knH0ipWoVhq2EuWpM7hJv0YSUp3AKd3IKblqTuJSQud HJho4p3dikdHBJSze4SAlpCcaOTN5ISUsdWJ3cApN4ITDVqKl3cgpcO+KZ2rZTu7FJSm6OITM7hO dHApDR/xSUxAlhCR1ZKk3khMzghJSz+AUn6OBSGrEnasBSUudH/FM3R5CVh4KTtHg+KSlmfnNTN1 YR4JxpZ8UmfScEVMT7q58E9h9ocmr+iWph7qo8ElMrNHNckdLB5qLzNYPglafouSUuzSwjxXHZzG 0Z9gcdrTquweYsafFcv9Y6215jHuMNcNZQOoSGnkbbK3tb4Lb6Bkb6GeWiw2PobaGtgAjUj85aWJ lNZfsaNrCoopD0PUajfjPY3UkLy3IfYCWv0gr1bHs3CCub6v9V/XsN1bg0H80qS9Fw7PHYhIJIaH E6arTxcPYNx5V2npf2fRw0HgjufpAEAKMG5UuqgxqMNATRDvikCmP0QQrrVp1OmWali1AyFhYT9l o81vhGTVyaFYhNCkkmrFoTQpJJKY7SlCkklaGOzzTbfNTTFK02ttVLq1HrY7m+SvKL27mkHuiDRT GVEF4jpF5oub4gr0Zp3NB8V5rez7NlOb5yF3vSb/AFsdp7hMyxouhfVhnN2vB8VUkclaWbXvZPgs x2h+KqZA2IGwybrygHQwitdrCa0AEFRr0bh7g770YBQeOHBO06JFS7x2QWtceeQil4lNMoKWAg6c qTwXCfBIwQk0BJTB3KcAqUJyipYuJ47Jbg7Q8pMOqbbqihmB2SiNEiSNVEkzISUuXRqQkmfDgQki p//XpGAFXAnlHtIA0VdUQ3FpA4CjM6pzqowCnKXkKCRJCREpKXOigSpfFRgIqV3TykkdUlMSE25T iFGAkhU6JQng9kySVuNU3OqlJTAIoVKmBoog+KmG6eaPVQek+rtcVz4ldE8wFldEr2VN+C1LjDSr gauQ6tEmSkCkkpGvS8p0yQSQUjUnJBJ6QWya9hXL9SPq5TG+a6W4wFzLpfmT4InosGgJdZjYMFbl Q21geSxahJ+a3OGgeSUlvLjcuXkNL7JAlFyH+uWiHBgGv5qtVCBKa8kMMKMlnjiAPF+81rC51Jqr mf3ih4TbaHl1uukQ0ooB2yPnCjZBb7AQ5K2XhDXyMd7ySzcCexcVLNacxjK7AQG95Thry0aw7vKF kV2PAHI8kKRwhrnplQB/ePiUB3TA4Q98/gr9jJAbChbWXHTsNCla4CtmVb762ek2wFsRrqo1B9Ii Gub5oFNbgeDHmiPeTokUGAO6cNOXLg0Nawdll2Fu7aW7gtbFJZjvd4lDxnemdzGyTpBQulkoiI0a tmRigAU4wB4cXH/z0ssYwfdAf6bDqd/u2rrL7GUMD7QNvw+guc6vl1WubbEjj2j6SXFbHEyJR/sj JsJ9K5rmjgypt6WW/wA7eGunWP3Vmh+73Na7b4j6KNhkOyq2nST3S1ZaI6tivHbi5Qc0m1g1H7q1 MzqlN4Isxhv/AH26f98Vofa32FlDmbB4hqI2zNpuYLS3YTqAGp16bMfq67OC1vgjZlgbiPHGiNlm b3kaJhqIInyTyfS1sR/W6tfp5H2JmmqruOq0sjRsDQRwFmtYXkx96MNl2X5yybYW8IhM+5/HgmYB WdrhJU6rm1vl4lOJYhRkh9RngAoOOqvWVPzWG2isFo5d9FUFGS3ccaTVUhw3bSR4tKg4MD+Dt/6S sNIFf0nN/qKp3/iUmVsNrZzDoUG1tdOjon80Kbq5/PMgf2VXa9w4JHwKSmTw3dDGmBzKKAANEEEo 7OEgiQBC0bvpfeo+iCrjOlZGTUb6g0tH5s+521VRaHgBo1Oie0pxILAUjxRmaBFbgZJ1ezaB4oe3 aeQgCCsNjQrKbCQoE+H3pADx+ZSUCuedAn1hQcHTodFIwGyDKCLYEp5gSh+r4gp2uL+AUVUpjQ14 cT3C2cgE2iulrBpMvUcFhfT+a1wPJ9zkJ9oOURaQ328qvKdypvYo6Mn+rjlpsZS5pcGmPpKtn42+ /wDQsAZpu1R8htD2j0rQXT9EqvnWPZYA0jWENbXyADb9Vr7GspDIaPdI9y16uFgNIZlAOhst/wA5 b9RRivAoNypWAq9SsDTnT4p6maSGbqxy9v3qP2ygf4Rv3oJ4T2TJ0D7ZR/pG/el9so/0jfvQVwns nSQhk0n89v3qQurP57fvSRwnszSTB7Tw4fenkeISVRWSTwmIKKKW+abhSg+CaD4JKWBSnzT7SkAS kpU+aQPmng+CYg+CSmPuJ0IhS1SjySjySUt8kxjwS080p8CipQPgfvQ7SRz94RNe4BCBaR2kIjdB eL+s7duSHeIWCXLofrXAcxy5VzyU2e64bNptxbwYRqsktJJPKzdxRKnwYKYQF1lPc8vdKiCU8Apw wngIbJbWDrc34rdeCMgADkLGw6LA8OiADqVtlxF4dPZRE6sv6IVVX+mcEOg7bZ8CiMcfWce5QWn3 H4ojdfj+Z7dpnafEKf5yDSZYw+SMfpBTtWW5UPpFJvcJfnfJIfSKSFm8EJctTt5ITN4KSlO1bKTu xS5Yk76MpIU76QT/AJyZ/YpO+kCkpTfpFJncJfnJD6RSUsNWpHVidvcJm6tIRUp/AKd3IKY6sSf9 EFJS/D/imbo4hJ/IKR0eElLM7hM3VhCkNHnzTM5ISUsda0rDoCkzVpCjzWipk/RwKY6WfFNYZYCl YdWuSUpmjyPFNX+c1JxiwHxTN0sI8UlLN1rI8EzjuqBT1cuaos1Y4eCKmVp9rXLJ+sTGlrLHRA01 WmTup+Co9cq+0YcfBKkh5HIqrFe+sgO8AUXCdbb9IyRw5WKOnVs1d7nLSxcNpmdI/NChXiNOhgZW 4DX3Dlad9TcqosPdc7aDjuFlY0/OW1hZIcAQdCkDaiK1easvtwXOrgyP3yqRyrbpLYXW9ZwW3Vm0 CXN/ELlQ8Rta3aERCyuMvTYRmp5Eud9ys0t9kIZPthWKh7RCtCNNYyJXrdtId4FdFU7c0Fc03khb XTX7q4PITzqGvlHVvykmSTGFdJMkkhdJJJJSkxTpoSUsE6UJJKeR+slPp3NsHdbP1YydzDWVD6w4 ouo3d2rJ+r2V6dzfA6J0xYBb2M3APdvbuBCxns1LfBbSy8tm2w+BVKY0bOMteIKVgkKIkktKcN7K FmYCSJCk2YSbpITbu4QSs4Q7VONJCcgEJi2NUVMQ7b9JOx3gnIDgmcNNEkMimaAClu+9NPuRUjLi 22OxCO88FDIEjxRDrokplo4JmiNFGs9gpiCkhiGgmUk7uUklP//QzbtDCEUS12qgDKpBuLTCUt8d UiB3TGBwOUQpG468SnBnlJPGiSmBCUKR0UNxSUuAEjonA08ExCSmMykOUiVJohFClGVJRjWUkqJP ZJMTIgp4RQrVGYNxDfFC17K1hM33NH3p0dSrYPZ9Pr2sHwR8g+1LEbDVHIOoCuBpyLXSSTpzGpMn KQSWlkCk8piou4RCyTTynbQVzuJ7shzlu9QdDCVhdOLZe5x1JSvVaR6S7OKJe34rbfwsbp43WjyC 13uAMFKRTgjUVN0CHc8sbLefNGVfINYgWcdlG2VrXuaAR80Ntu4S4xKK8DZJEgdkHdXcAQJA4lJS G+1zXQOAh2vcII47/vKw9gdqeQqnqse/aRKKmNt20cxouYvvsseZeYnxXUZZBrLQ0HTuuQILSQeQ U1LpYP2p8lhO0diVpi17x+lEOCfBLfRbAhSsEpFLYItbQzZG0n3JrMp2OAQBI7/nKy8D0mMHYLLy XAv+CVWaYM0uEN+213oCx4Dmu/NQasrHaQLaWuYOyPkMrNFbXv2aDsqD627msqeHl2nCdCmsck+L ThdWpmIanfYmO2Onc36Ib/nrFwMVrL4IkgmCtevouQwGrePcJlVem0lmQarDq2dR3RI0LLORsBWM youeS526YhsoxqYy9m1zjpJa8K3jWZmMHVspEbi7efzkW26/JeHW1CtrATvmUyxVMxPpefvO6x5H ipMDPT2w4WdnBQe6C5w8VKS1u4Ok/uqY6BpYNchXvkMh3Kz95HCvZDiWyqArc7hKOy7IAZm1vWI1 lQfa5wkaq9j9OpvE+pDvAqGVi1UN0f7h2+kmHILpfHGN0+K2cMuN3pydGKlCtMfjDGANZe8/4T81 qqgIDUtvYNtri1oAcAPCFTPMwrxqeKtWt2qkBJHbVOKmy4ljJ2aQqoVq0Db9I/eqoQKF/irVIbPv PtVdoBMHhH444Tggup06uiyl4bea7CT7d0N/7b/wiy6KxVc1p9zt35q1MKygYzhkUOLO97Bu/wDB Fk+pQy4Or3PraZG76SB6sU9wXqrWtLSC1xMf2ly+gcfiVsv61jbCNj5I7rGaWuBcXESo8QIu2PKR opNqQS3WPFL7Lda3dUC5v4KrmOsoaGOEE8qQyCwQJTMyqwCHfSUTks7OMfBVadpPv+ipuFRB0M9o TbbHtRbByGngz8kjktHJI+SqkBoG3numc8kJWu9qL03S3h1PvcNPD6SJa00ZXqmn1mObt+iqFINe EHh22TpH0kZtXtn7RYNPFV69VskRWyTJrxLqgGUPrvBBaQ386f8ACf8ABKh1Rg9du7Q6Kxutuxiz 1DIMeo47VRdjWY9rDcd24iHT7XI3rqtlq6m0VZLLn1eqC3bx7W/y1ouvZUDY72t8FlWWXHI2izZW B9H95BusdmXen+aEY2z443v8sW1d1qx52U+0eKoW5GQ4+9xPwKtHDa0QQY/eaq1mMB9Fyl4D1XHK BpANZ9w5O4oD8l3aUS1jm/nKo7zKaQFe7Jjbn2tOhQ/2ld4oOQ3VAIKCven3bw6nb4orOqWEgEwP FZhCdvKSvek75zCzmwkof7WtB5/FU7rvUDZ7BAcUBavdLqDrVwOhP3lEb1y4/nH/ADisZyes8oo9 49ouuOv3Dhzv85TPXL4nefvWCSjNIc3mCkr3T2i6p67kD84/5yiOv3jhxHwKxtx4USUk+6e0Xc/5 w3jXc7/OUm/We8fnO+9YcSxCKKvd8IvTs+tVw5cVZZ9b7B3HzC48Apwgr3B1jF7qv61vP0mtKsV/ Wio/TZ9y4pjZaE+w+KKuKB/RfQaetYdv5xYfNWH2NtEscHjyXnLGvHAJVqm7Ip1YYhISpXtxl8p4 W99aRNbT4Fck4Lo+q54zcaXaPB1/lLnSjI2xkGOhYpQn2pbSmoUCpCxw4KiGlS2kpKbuJkvdY0E6 Sukdpa1criAtsafNdS4+5p8VDIAFnBuK7dLih8OPxRBpd5Qhke5wQC6HzB67DduoYSrbuQqHTXb8 Vp8FefwCrDBk+Yrn6QS/O+STuQkfpBJYofSKTe6X53ySb9IpKWbwUhqxJvJCTPokJKU7VspP7FMN WJO+gihd3IS/PSfwCk7kFBSh9IpM5ISOj0ho8pKWZq0hNyxOzkhJnBCKlnGWgpWdikNWQmdqwFJS 7tHApcP+KTzoCmfo4FJSmaOcFGvhwTnSz4pm6WEeKKmI1rITPM1gp6/zmqDNayPBFTK06NclYYsa fFQcd1U+CVrva13gkpf6NvxTV6Pc1NcYc1yZzttvxRUqrVrmoVo34zgdYU2Hba4eKjUfpsSS8w/O aGxEKfSM0OyDXPIWdkYe17y8kieOETpgFd25rdRzPKgLLYejyWyxwPgsnoWc6ux2O+YB9hV2zObY DofuWPkZNNbw4ucHA8QmxkNk1o99Q8WMXLdUxPs1xA+i7ULc6XkC1gcOCFW+sjIpFoElpU8DRYqv R5i1+0fEq9WIasttvqOk9lfZYQFODbDIUzI92i1emOBaQsku4VvCfsf8U4a6MeQWHcTQpBPCZbWB WASMJQkgolSZPCeEkMU6eE0JJtSYp0+iSrtrZjPUpcPJcNiONN0cFrl6DGkLheqVehlu7Ap41iR+ 62cB3D6DiWi6prx3CB1Bugd4Kn9Xcj1KNh5atTIZvYQVWkGzA0XHj3T2Tls6pwEiFVO7aRx7oUon hDedp1RBofIoFK41THVPGqUaaJIRNlhjspyms0glJ7gwjwKKlFkpw3T28pt2qT36QOUVKeDMwpNM jzQ2kwnae45RQsxsPReDKbupgzogpg4aykiOGiSKn//Ry51PgokEHRSbwkAQqTcQie5SKmQhkRoi pcNTuIiAmaUxKR1UsmS+CQ1SUueFAlTKhyNEgpbuphM3UqRRKgs5RTmU0kJBRWjxTgpbpTAooSNM 8FaPRmb75PZZrSFudArkucpMQ1RM6PV0iGKvfq5Who2FSe6XK2GkWMJwE25OHIrVQnLYTF6ffKKC sVF0EKRKi6Y0RDGXH6q6GR3VLp1HoVF9jDvd+8Ebqz3GGs1cT7f6ysXOyfTYL3e4DUQm7lbk0gzw rW0uNj/ogLVxbBms9WsHb5rDLSMd57rW+r1hrpax57cJHqy4R6Q3TW/wVe3EdafdOnC0jkMB5Q3Z VfimMrRspe5u0z5+aE3HNYgcK87IrPdCdkV/vJJarqHEFVm9Pc0zJMdldOTWO6gctg4KSmmenuL9 5cZ8Fm9W6E94N9A9w+k395bbs5hQvt7AdDqmppw+i3i39WslrhxotZ2IZgHkohzapkNE+MJNzqy5 vxSu003sjBIbB5aNFjVl7nR6Ic49pW/lZzY2t1JGiyK68p2rCD8w1Oa2SidWtlWW3xvr2tb4KvsA 1IVyzIyaXFlhAcp09TtpMja4fuuCljoNGnOMeLSWrXrO5pJc4+Gqt9MG1tj/AM7soZb23gXVsDP3 gENtnp4zzMFCZsKgJcfDI8Taq/ab27t7dVOmzI9G1mS4OI4UsfMo9NgLxwEG20Oque0yCYlRmIDd mAI6OVX9EJ7r8XGa02tebHGBs+ilXwFR6oS66pk6TMKSTV5UayLfyy0tln0Sq1s7RCLePaFUNr+A UQNESszP95I3EvtbuZXI8VTeTW7a5gDhyFpgusa1rrA0/m6lsrPyi4OO8+/glRGiW2I0A7BfljCE Nayn86fpQsoWs7OUcq270wwvLmxwFQFbjoATKQLM6ozNNpfLUP1a/wB5Ubca2mPUY5s8bmp7cS+p oe+tzWH84t9qVqpuC2rxT+vV4qk/Dvaz1XVu2fv7dE4wsg1+qK3FnO6Palaqb32inklW27XNDmHc FjV4WRa3fXW5zR3AUcc21nfWOOQnCSCHt+ljMqxt9O2yvXbUfprDyXXOsL3ViuT9EdkbpRfe4zd9 n04n6X/TQMqstsIstDyD9JPG7XzbMG753EIhaXDQBBNLhqDISaY7otWiTbudLexlG126J+j+YsTr habRtkT2crFedZjshgBHmFldRy3ZLt726jwVUwPFbdhIHTqyY51JkJxdE8aqdeFhWMrc+5zXP+m3 91M7DwGgkXukOj4tUjMw9WG7dENzp5Rn4eCN8Xu9v0Z/OSdhYJcWtudBbuH9ZC1MhaW0CTpu4Wm7 qWO0AOY8aIGBUy/F2e3c09z7nLXr6hax259bLdI9zmgqPqkEU0+nuY+lxI3MJ4cgZwb6lZIAZI2w VY9YUNc/a1u47hUw+0KhlZVeY9jtgYWkd0yjxErDSY31VZDhaTEaQNyhjZAbb6lXZXaLn41r7a2B 4eI11QLG0uq2Mxyy4mfVBRia1bOOYGh+WTuUW13iWO2P7tKjfiPdy0HzCw2Zjsc7Ht3D94BWW9Tb /g3kHwlWBlBCjgBNwOi9+Cf3FSOER2AR7ep2H88FUbc17vz1DOY6LhgkN2p1OjYR5rNOivZFvqH3 EyPFV5Z3To6hhmOE0glp7JwNVYca+x0UTsPCNLF4USrlFNL2y86+RVSwAEgGUEsDynZyonQpNMHR JDEqSgTqn3BJCiSkYTSlKSWzU3dUT5oW0DnQImO+AW+KIWDvwiEtN2091MNnUKyKmeSUN40ARpTp Y2GbKQ6AUSrDM/RVenK9NsBxA/6KmM93ZyEiKZI4yXQZiAAlx2hVci1rBtZ96rvzY1cZWdkZpOjV Xoks4jGGsiwybPzQqxhRLp1KZTBrTlxG2YcE/qca8ISUIrUu8eKcWAGRoQhBOQkptU3e4CdCV0zt NhXK1FsiV1H+DYVFPdmj8qR2loKi7+cIUrDD2lM/+c+SaujuHoujOnF+BWm7ViyOhOmpw8CtYasV gbMeX5yu/gFO7kJnasSfwCkxLn6QTfnfJJ/IKR+kElKb9IpM5IS/P+STfpFJCmcEJhqxOzkhMzgh JSnasSfwCkNWQkdWIqXfyCkdHhM/6IKT+QUlKGj0m/SISdo4JcPSUszghM3VhCdujiEq/wA4JKYn WtKw+0FJmrCE3NaKlWGC0qLzFgPilYZYCmt/NKKlDSwjxUK9HOapWaWNKifbb8UlMa9WOaozuq+C kzSxw8VCrhzUVLWmaw5NcfovTMO6sjwUHO3U/BBLOw7bGnxTTtu+Kha6WNd4KN7/AHNelann+sVl t5BftB9wBCpVZDsZ24nc12m5a/WqmPtbY8kAD81YeRWTWSNA0yJUU91zsFuRs3tALSqlrA7+caAV qdJs9bGDT2VLqmO0tJImFFWujIDbsdAsHpho7LW6rX6mM8eS5f6qv+k2CAD3XXZTd1Lh5KaLGd3z 6oEklXZAaq9bYLh5qZ10VoaMMt09bxYJajVO2kFApbt0RGp0dCtOr0lLpaCiKpgv3MCtpkhRafgs mTlMghdJJJJSkkkklLJJJJIXXLfWfHIc20D4rqVmdbx/Wx3RyE+G9fvMuI1IOd9WMnbZsJ5XYESv N+k3mq1p7gwvRmO3NB8QoZii3urlZLPTsKiNVazmagqhvAJCqzGrZibC7gJITVkka9k0OOoUWOId BTFzM2BS3aShuABUxCSliQ4KIcDoUhEQnFPcJKZFgIQrKz2RAmfx5ohTFh0UiI4UOBKmOAkplPin bo7RM7hOzzSQys4STkSkkp//0ssidOyTxATcJiS5Um4xJHCSYt8U21FS5fGkJvNEjRDggoJYRqkn OqSKFacFMSnUSI4SUyCRjukAe6SSlpHKinPKZEKKojlOII0S+KfnhK1LuG0Lpuh1foQfFc1Gmq7P pVW2pohT4h1Y8mzpkbWrOLpJWhkHaxZmqtRaMyylOoJSistmnCgCphJK5UHEQpKNvCcxkvO9StDb 2biQNw4V3JIe8Fk7Y/OWT1N5+0NgTBWs602gdtFGDqjJfCG1RgtycfY4xPcIteM6twoqMkDRWsVu 2poWX1IuNvtJBHgkd2UnhiEV9r2PLHkgjkKDXF+klZuQckukHVHuxOoBrTXBnwTZGlgmS3BSXGAd VH02g6kys443Uz+aUxw+p8QfwTRJk4nRNdfiUmUh5gH71m/YupHx/BMcHqR8fwRMlcRdPYWmOfMK R9Fo1Oqyf2f1E9z96f8AZXUfOPiE21cXi6jRW8w1P6AnUjTzWM7pud3J/wA5Q/Zub4n/ADkk8Xi7 WWdzgWnQJsVs2NjxVfp+Lltb6b2Bw7EuWri4V1VrXWNhvlqng6atfLqQtmtx3W++wtMcQhYOBXnW msWQ1vfhz0+Rjvuuc5jSR4qvZjurIDxtPZPjtu1wQJ3KPpd1/wBX6/SLarHDwn3KhiYT34pa9pcd 2o/ehWrGuLq8epzmlwk7SqHUa8ughu55IM/S+m1MNlvcIJEh6XUZs9QOOI4NDdv0WuVfLxX+hZ6N RaHGWsWbW/IstbAexvc71q9R6fkUVm1lzoA90lIghdOPEHHNFlQHqNLfiq76K7rAXD3Dhy17Xudh 17iST3KzGD3/ACRJsMHLx4ZSDDK0aAFQMyr+RIhQc4vGoUo2YTKpH+81iXgQfkgEBzveCrzA3duJ E+H5yH1K27YN7ZA4coi24WQxyBg/ZgafUbf5/QVDCyH1ZFbyZgzCn9qNrBWRwnbjiz6Ojk0M2r0H XervuoaHNAggpdU67Zfh+mWATHuWZnYt9tAA1I/MH0lKzDtswPUNjA4DWo/zici3Tf1uw4PpbRGz buUMHrlteEKgwFoaWyqGLgW5GAXi1jS3/Bu+noodJwzfQ9rrm1lvDHpKt0Oj9btoxtgaCJcucvsd Ze97eXGdFqdC6e7J9RhtYyDwfzk+J0w+s9r7KwWmNT9L+WlS2U+H+s2Oh14+1xy2OeY028t/zE7c KrIc41exgOher+Lj14Ze82sMtj2lZ+D1KzELmNYLGucTDkrP6LCTxD1eltO6d6VZebQfBsInSMfD uD/tEbu27T/MQrus2OaWtpazdyUsfCpto3Pe71fDs1GJlXqQIxB0RZwppcDTx3ErNyA20QBr4q09 gGh90HlMXNj2CCngMEpVKw3MPMx2Y9VV1YL63fS2/mI1uZgBtlbWaFwez9GPassNj6Rk+CeCeOfJ NIZxlLfyMnp9zrNNu8Div89qRd08vBOks2mGfnKjQG22NrdweQVp29JpcYBLTOijlMRNMolIhwWV BroHAJ2n+SrtN1VRPqt3A+SLTgsfY5lloaG8ae5UMjfj2bQ4Ob4pGiiPEDZZZmRS5w9LTxUaBFoI GiuMfi2M9wG5ZtdzqLC5o0nRN8GStbdDqNjTWNoc0zzwsne6dCfvV7I6g7KZse0NAVMgcgcJtaLz IOlJMPLjMf6/o1k2u9x1nVaDM+kxuc5pHOkqjdY1zyWaieUyF62ush0bC5rWNqDZI7hG+x3spORY BsH7rVTytxZXsOvaE4ZnOrcXvc2vvKEReq7iPdz8p+9xd4qqj5HtMOO7zQJUwWFSnWCSAFCZRKzD h2PYpKdN1F7GbyAI7FvuVZ1m9hBAlFu+0vBLnl7B3VWsmHIUooidUyZyYIoYnlKUimSUlhreRMqT aw4bogJrPogq3iZ91dbqWNa5rudw1TUhq7QPopGI81KHM9pAQ3acpwUpO2O6iUgZSUzDoERIU2wR wAeyGSY0UqdZBCSrIXLDPmhmlzlcbtLTshBburkFs/BNtFtR7CwwVFHuBcd22AhbU5LFOlBSSUoJ ymhOkhdmhC6ms7sdpHZcuOV02KZxR5KObNDYti3lpSt/nAmt+i1Pd9JpTAkbuz0B3841bbPorA6C YucPELfr4IU8dkZ/mX/MTO1YnZ9GEw1Yiwrv4BSfyCmdqxO/gFJSnfSCXD/kk/sUnfSCSFDR5SZy QkfppDR5RUszghJurEmfSISZ3CSluWJ3/RBSZ9EhNyxJS9nYpn6OBSdqyUrOAUlKOj0m6PI8UrNH NKZ2jwkpTOXBRZwQpDSz4qLNHuCKmI1rIUX61SpV/nNUGa1kIqWuPta5RuMOa5IndV8EO0zWCild 522g+KgHRafNNcfouUbTDwULUphhzmodbva5qdx22/FDB22EJpK5QdNceChY7dWCosMbmqAMtITb TTU6s11tI2/SlY72urmuwakLduHqUkeC531y1x0BITTqouj0DJAf6TuVrZ1W5hC5PEu9LIa+Y1Xa Xe9sjuE0ikxLjfVkFttgLp1XbuE1keS5HpLfTyHjxK69urPknhbLd87udZXY4AdyoNyXgwW6q1fp c8eDiod9VOAe62ZHZOwmEYHVDbwkSdFKNGJ1+nWR7StLePFYnTyBZB7rY2hGVbtOehZ7gluCiGhK AmLGW4Jt4SgJiwFLRIZF4CW4FRACfRJJplKaUyUpLWUqFrQ9hb4hOn5S2SDT5+9hx8lzPNd90nJF 1DRPuA1XIfWCj0cgPHBWz9Wbg4ub3hLKOroA2AXeymb2LJAE6rccJBCyLWNa4gyBKqTDYxnSlBsc ITx7p8UZpB4UbADHKiZENkAgnhSgHjhSDQRqU4bASpSEtBOqINNFAt3f3KQG6EkrkQok6wVMgxCg 2UlMR4KbtEzm7XQpkbhCSGG+dE7NTqo7S2DEqTZmEVJAYSSHmkgp/9PK3ToeEjpwmcoSqQDcWI7l SBgKI14UiIRUsHJOMpcpggliAnIJTkeCiUkKiE8Sok6eaTUVMiYSdI4SnumdqJCCVuVHWVInRRBB 0TghcpNTkAhMNElJqW7nhvYldxhwwAeS47p7N97QuzrGohWsWzBlKXLPthUNquZDp0VYqwGlLUsC EoUylCLGWICnCYKSSeiyFd9FGCBkmGlFY8/VScjN/qrqmdIrIkkysf6vViy19vnC64BU5TN0G5wC hbTbihogdkGzpdVjtzplaUJIcUlGIOjlHouOeQUh0WkcF33rVSQsoEIhy/2LT4u/zk37FoPd3+ct ZMhZTwhyv2JT3Lv85Qs6PitEuLh/aWrba2ppe4wAuD611izNs2M0rBj+siLJSIAu3Vi9NyH+ky0l 3huVv/m7TG3e+PiuCaw0uFg0IOi9K6XknKxmWO5I1RNhPAALDQH1boHLnH5pf828fxP3rcSQso4Q 4n/N+oD2uIR6+mWVDbXZDfAjctRJKyjgi5TOm2sBAsBB8WqpmdLvgWAh0RIAW+nIkJ0SVsscSNnm c7JrZYwelveBo4O2bVcxK6879JcJPZr3fRXH5ctyLRuOjtNVD0rY3l5A/rKeOyBGtHtMzpuMGAtY JnsVm5eeamim6glv5oe5waVmdDf+lD3FznNMt/Oauh6obMqoNt21VTu3uDp/9RpS0SQA0+oOBor2 N2gx7VnF7CfaCD3V3qF1RbXXW/eQI9qzWyHbXAg+aA2YcehkWOQoPdDdBJR7QCVUtBMgaDxT5S0p GLH+kWpjY/rE3OMBp7fSR8+6q6obXkuH5qzHOc2RPdQbqo70ptUkq5V7G1Ko1iCr+NyISG6XoMBr Huiwxpym6hhsvPtjcPovH5/9dDxqhY4Aq8NtT9tggeI+irIFhgkHnfs22dw7pnY43TGi0MxjqwbK vcCeFVD7XB0tDSPzf3lGTR2W+0TtJE7Hby3lCdUTyJVljrnEhzQ2BLf5Sdrrd4a5oaCPpFLj8FDA esmq2uNYRGPcwyETfcHAOYAD+clY65muyRMT2Q4/BRwX+ko3vcibXRqZPkoWm5gLmsDmjwSDrWua GtkHnb+alx+CPu/aS8So6q17SI4KQrB5OnklxI+7eLWAgIYs2mQT9yPl+s2HVNmsfSH5yC2xtoJY eOR3CHEqWEgWPUkxCHZDPGV0Fn0vDVc9hOByGDvK6F42n5qrm3ZsezRtxMa13ujd31hV7OkVn6Lo /FGv6PXkuNjHFrjyqjunZdWldgITQe0l9KZ0w0WB4cCB5Ky4Bx1AKq1fbm2Bt2rJ9xCvlgn5pkib 1KQA89kx6jhwFXLoVjMcG2vESZVbR/xVgbLadLGqquphwB8T+eqOTU2l0V8K7iOaK4e4CP8AOQrH 0utmxzXCNCohfEezJTHIdsZW9hghWK+r5hpdU1rSw87gq+UQwMc2CwHhWW9ZqFLqTTun84fSCcBo kOW6gPBLtCFUcI0KLbbrpIQSZUq1Q5VyiohwsAlwOgP0VT4R8d5LwCCW92tSU6ORnXGWuY1o/kBU qhMq/fnUH21VuZ/WKqUCSUFNRyYHwUn+Hmo90UMHJQpuamASUkeP0YKuYGbj0tc26svJ4LTtQD/M j4o+AzGkm9+3T2mNyYdQuDVbqTEweNya0QpX2Q4w7cAdCgOt3cpw2QVKTBKhwk10HTRFTc9VjGBg bDu7p5UMf6R8wtCzFwK6A5lxfcfpNj2qjUALNOEiFpK1Q9jwEmCuPcSEXHGr2qWJRXkDXduH7qCQ iNQg7eCgbFoCC41gOED88Ko4QSCiprlqbaEYhRISRaJSDZUyBHGqkyByJ+KSmAbqugwTOMVhOidA tvphmlzfBRzZsZ3bdn80D4J7uGlR5pT2GawUxc6PRXbcqPELpWclcp0x23KZ5rqm/SKmjsrPuD/V XZ3CTPokJM+kUmdwnNdYasSOrEmfRISbqxFS7/ogprOxSOrEn6tBSUu7RwTH6YSs4BSfyCkpQ0ek 3RxSd9MJcPSUpncJmfRITt0eUzOSElLDVkJHVievghMzVhCSlWfRBTWfmlLmtJ5lgKKlP0eCmOln xSt4BUbdC0pKUNLCPFQr0c4J7DFgKifbb8UVMGfRc1CHuqIRG6WEeKhXy5qKUbjur+ChaZYHKTPo lvgh81keCaUrXO1a5DtMPB8VJ/urEIduoBTSuDEmHnzUGmHEJWH3AqJMPTClYcELmcmW2mOV0oMO IWB1Okts3BIKOzkOdDp7grvOn2/aMVr/ACXCP93IXZ9AbtxBrKUloKXHAF66inVoXLVmMiF1GP8A QCEF03geq+ozLsazxVetz51Vzrw2dQd4FV61ZG7HMtscJ50lDYdNVF1jX+0FPumOm5S+HAhdDWZA K5pmjVv4dm6sJ51DVyjq2YShOkmMStoS2ApSnlBQLD0mp9oCeUkbKrWgJQlKUpItUJJSlKSnE+sl G+jeOQsroGV6V7J76LqM+r1qHN8lwmM40Wx+6U46xH9Vu4TcafT5WdmgMdJ7o/T8kZNDX94T5VYe 34KrINjGaLns+5SsGmiGWklFiRBVcthFuAAKTpDpnQobRyPNFgaSglZxIHimjTRS8k4hJTCNwhNX p8kogqTXQdUUMLDMFOwknyRCGkcIbInRFTMktUTJUiCoOGkJKStKSizhJJD/AP/UyHQOSokyERzA oEwFTDcYhItBTiIkJikpREJifBPr4Sox4JJXUS6OE7j3hMdfikELeaQ0CaCE4KKlwQOUw504UjA4 UB8EFMi7sogApHRNuATgD0QTTMp0KUQGRyEeAo4g6vQ69127wXV1iXLkek59OE53qzrxC2qvrFiN JJn7lbgKDBkNnR0bj7kJZj/rBiOdpu18lA9fxx4p7V4T2daElk/84MYdnKQ6/jHsU61hiezqhOso dfxfApft7GPAcinhNbOoFUz37ayfJVh1/FHZyq5/V6chhbXM+aRK0QlezpfVlv6Mu8SumC4vonW8 fDrFd0g+S2x9Z8H94/5qonct2i7SZY4+s2Cfzj9yY/WbB/eP+akrhLtJLE/5z4P7x+5L/nPheJ/z UrVwl20yxf8AnRheLv8ANTf86MHxd/moWrhKT6w2bcRwnlcbXjBwC3+odfxMlu0AuA8QsZ+dS7sR 5AKSARqs6pryGt1XadHxXY1Aa7vrC5Tp3UMXHt9S0GF0H/OjC/lR/VTZbprTR3Elif8AOjC8Xfcl /wA6MP8Alf5qCuEu2ksM/WjCHd3+al/zpwvF33JK4S7iR4WH/wA6MLxd/mp3fWjCjQuJ/qpwVwl5 XqrWC+yBruQbKtjN22D8VLOym5FpsaIEyhPuY5sAH71YGzGQ3OjwHa8ebti6rKujEgEyR+Y5tv8A 256v+DXHYWX9mMkx8ty08vrdV1PploeY5Ldjm/8AFemn6UtkCRo1a2lh3DQj6KcWvsfNpk+KFjX0 PB9d7mx+6ED7U1jiRJA4QkxYoyjGXE336LNzC9wIbwjuzg/sQhWZDXNLY1PdMLLAUGnj4xuGphSz MVmOQWbte7lYx7m0s2xLvFDybbMkQ8wBwEK0X621a9eVextXSFXaz2x2R6Xhh8UQEu5i2it4MTK1 Tay5paRMDUfnLmTmtjjVGr6uG8jXs5TxkOrFKNtrIsNWOHV8g6SqL8t9vus1f+8FG7qAuZsI+ari 0cKOdEroggNs5j7P53Vw+iVL7fba4etDmjgKl6o8Eha3kpq5uO6hdYQ2wg1jhoUft1u3YD+jn6Kq G5qQtCSm59tsZPpe1p5afcosyrKjurMaQqvqpvWSU2W2PbLrSC09/wB1WC8Bo2mQe6ojJkQRoq1Z dS72OIb+6kQkeLs0W2AHbEfykJuri7x5VduXt7Sm+2HWGoKI0TYkDIa7zW67JBOo7rlqrDW8WDkG VcPU3zMKLJDiLHEEaOiMO+7ddj2ESdGfmoZd1Or6de5UqOo7AQ4EyfFWmdedX9Bv3lRmJ7cS8ApW 5eSS31KS1rjG5WRM/NZ93Xn3AAtiNUM9ZeeWhM9snoloZrAch2mvdVnBo5CtWXerYXnvyhPAJ8la jHRiINoiyedQmrYwO9/CJtUmQPNKkjiZZOxrGmIZOsK3XkYAoc1rttnYwq3qMP0mhwTB9PapqZwk MlsGNw7T+mfHmAs57A1xDTLZ0K1g6oc1tUm21H/BtTwFpJciprC4b5294WlX9nqdNbwP3SUY21/6 Nqb1av8ARtSpWrbzbMDa012B7o92m33LOwmNe90IvqVH/BtTiwV6sACBBVq5j2QSPMoUahXyAST4 qPotJRopa9jIQ4V8tBSDWD81KlurXj9AfiiYPT/tdgrDgD/KRnEEQRAQzU08BM4SvDLKwHVPcwtB 2/nTostzdVp+kDzKRpYOycAVFzFqsxBjhry1ts68qLam+Cf0mg+3RGii29kdKddX9qcGUgf4MO9z 1l1t22iEU1CZ1lSayOeUSLQQtRAvcCYBCsYX6nYLIaSDP0vagloJ11Tem3uE3hKho6edm2dQtFlg a0NEANWNkN9ytNcGnQKLwHHVOpTRmOVAuJWh6bfBPsYOyFKDm7nHRRkrT2MPZS9NvEI8KXLkrb6O 6WuBVc1s8FNjtghuiZKJK+MgHTZ/NuCRM0/BZwe4d0vUdxOib7ZTxB18N+2+s+a7D8/5LzsWuaZB 44VgdVygd3qGRwpIxoUunISA/qvejR5Sbo4rhP2rlbt/qGUw6plA7/UIJT+Fhp7tnJCVZkELgx1L KGosMlIdRyWiBY4JcKqe7aZYlM1rgx1DIAhthhL7dfG31DHgjwqp7t5GyU9hG0GVwX2y8jabDHgm dl3EQXuIHCXCFU97a4AtMpPcGvElcEcq10S9xjzSOTc46vJKXCqnvS4CwCRqkHtFhEiVwJyLSZLz KX2iyZ3GfGUuEKp71j27yJCauxkuEhcH61nO4/eo+o8/nFLhCqe8rtYWkbhAUW3MNZ9w+9cMbHdi fvTb3DvolQVT3Dr6zVO4femtyK/TB3BcQHHuUiSe6VKp7S7JqAadwULsqoOadwXG/EynlFT19mTU LA4OEIX2ukWE7hC5XclISU9O3KqDj7tEIZdTZBcucTkzyhSbd0ZlW0iUI5dZbzqsblP3TeFVuo7K YYUX5TCRHZZhHgpIcCuJvuyWl0jhVMyw2CKwNe5QpTySkIBRk0P2e491qdHcMEu9R0g9kFPyjwhA LfGU31t/Zb9HXMZrQHEgrkpTpCACTK90nVnfbcr126N80FoMqclMU9aTajq2ENlIa6QiJIVrar0p Ky0hXsXqoobtc0lZkp1IJUxygJbu2euM/cKX7db2YViymBhHiHZb7MXbPW45YQm/bo/dWO+xz+Uy XEOyvai7H7c8GJv26f3FkSlKPEOyvaj2dc9bd+4o/tt37oWUlwhxDsr2o9nV/bVn7oTftq390LL4 ThHiHZXtR7Oies2uBbAErIOMwuLzyUZMU0ysL4xEdm9g9Rtwm7WQR5oz+s3uHA1WYCn5TV4LaOdY pjPshUlIapnAF3GWy3JfyCj05TnH3LPlEqMOS9sK4y7LHzqe6kECh/tgowkHRVZCjTPE2FnaEFTd 4lRcZTk6aoJZNImFAs90pmu9wCIUlLAyovgJyI1USQRryiFMmu0SQq9OUklP/9XKJg6qBAKRcCdU 0Aqk3FbpCbhSLpTfFJKpSmeyYlMTCSlFMnIlRMAJBChyk6YSZonnwRUxIBTEwpOJ54UdUgpG8yoj XunsTBWoDRrTOquEkk6esXlOohIIqZSkDtTJQlal5lLlJJK1K4Ug4jQaKCcpWpdMEkhokpeVLQ8q KUoKtdOEyQKSrK6UhMkPBKlWuD2SJTE9kplKlWuSlMJpSRUvKeVGU6Sl9E4cVDyTlKlWylIuUEie 6CrZ7k0phwmRpVsiop00ooX+KaUpSSUun0UU6SV5TJJcJIXBjlLRNKQMpKXlJNKeUVL8pSmBTykp SQMpjolqgpfcmJTQkUlL6p0yUpKXTgzoopIqXlMkkgpkmPgl5JIqXlKVGE58ElLgylymSQUvGiQT cJcJKXhJMlwipScJJphJS6dJNMJKXJSTGUklLpzqmlOkpb4JcpFJJSycFOUySlTKcFKEklKSGiZS PkkpZKUydJSpTpBJJSoSSTJKVyn7JSkkpQSSSSUvCYJ03CSl06ZIJKUknTJKXSSKZJS89k8ph4JA pKZBJMkkpdKZSKZJS8qUqKdFCuU8pk+iCVSkmKcIoUnTJSkpeUpTcpJJXTyEycJIUkkmlJS8pApk 4CSlJDVLkp0lKSSlNKSlwlMpJJKUE4TJJKXCSUpIqVqnhIGEw41SUyBT8polIJIXSOiQMJHVJShq nEDlME5IiElLFOlKZJSk4ideEueE3KKmRI7JkycJKUn7JuEkkLgBIpaJkkr6JxolCSSFJk48EySV wnTJJKXCdRTjVJTIJ2mCmCR0SU6eO7VW2zOqzcd2gWkwyAVXyjVmxnRjYySC1TLdISbonPChZUYY Q6fFT5Sa/cNFETrCSlwCfgmLdEt4I0ShJSNgdOqSMBCSKn//1sYgcpxwm1nhSII4VItxil20TR4p caJKYxron4T6jnhIie6SWJjlLlMfBJGkLwkXbU34pnHSEKUvPim0KR4hRlOAUSifylqk7lOrUdmr LdWqdNynTlq3CdINSiElK7p9Aop0lKlP2TcJQkpdOFFOkpSSaE6KlJJBOgpScCVFOEVKlJJJJS8p JkklLpQmSCSlJ58UkuUlLJ+UwKclJSgnlRSHgkpdKfBMUklLylKZJJC6SYpQklc/ilKQSOoRQvoU 3dKU6SlJQmTpJUknSSQpKUyUpKXTJSkNUlLpkpIMp5HZJStQkPNKEkkqSS5TJIVOicJhKfVFSk6Z JJS6ZONUoQUophAUiooqXhIjxSBSnVJSkkpS/KkpfhJMkElMko7qIThJSk5TBKElLpcJBJJSpTHx Twm5SUul5J0ySl+EkkuElLQnmUkoSUpJJOkpSXKXJSCSlJk6XKSlJDRLhIpKVKUpBOkpZPykkCkp SUwkEklKShIJwkpYhKElIFJS0JSnCbukpXZPMpcpBJSinCZJJSpTqKlKSl+UydJJShJShIlMNUlL pJlJJSkkydFS6aVLdpCikhUJ0gkkpSdNwkUlLtSTJ0lKT8JkklLymTwmKSl0gkkipSdLlKISUpSA UU4KSFQU6bVJJS8qR0CjPgnSUqUikkkpSfRNKdJS8wop0w1RUumShJJSk6SSSlJJQkkpkkkkkpZK U50TBJSk6Yp0lKTjRME6SFwnUU6SmxQVp0PJELJpOq0aHgcqLKLDJjOragykQT3SfqQRwmcYVZsL MYWnXhTpMTI0Ua9Qk1FCiwNmOE7DGiRdPKbzSKWQ05SUXEhJBT//18cS0ptSnjwSgqk3FidupTyS EphM0pJUddCm44Tkj4qO4zokpbXultCYiSlwkhcNjumPKkYHZQiUglR1SPCUKLjCcNVpRd1KFDVT CthqFUJJ0pRUpIBKUkVK0S8kkuUlKhJoSTpKWhIeCdJJSkgkkkpUJFJJJSpSSSSUopQkNEklKlL8 qRSSUpJPCYJKXCSbhPokhYJy0t5TJzKSVpSS1CZJTLlMEpSSUoyn07pgUikhePBMRqlyn1RUqJS4 SlIyglSQGibhP8EkK0TpkkVKCfhNCeUlKkJJHVJJK/CaUk6SFk5jslyYSSUogpy7smSSUrlJMnSU pKZ5S1SRUuG6SE8aJktUlKTSnITEJKXSmUyQSUul8EydJSikEk4SUpICEx1TpKVqE8pk/CSlgnhJ JJSgkklKSlBLRJJJSkpSTpKUkknSUsnTFIBJS6blPCeElLap5STJKVylEJwkkhRTQkkklfhJMeEk lKlPwmCdJSkhoklMpKXTJcJeYSUpPKaUklLpJBJJSuUuU6SSlk8pSkUlKSTpJKUU4TDVJFC8JBJM gldOmCSSFwkklKKlJJJDVJS6kG+2SUyYpKVKSUeCXdJSikE8aJklLpJwm4RUvKSZOUlLpQmGqQQU yTJJBFSkgkNU6Sl03CRTpIUCnJUU4SUulwkNdESwNAEGSkpEnS+CR0SUpJJJFSjykl8EklLpJJBy Sl08wmTwkhbzSJhOdFElJLIJiYThMUlKGqSbzUkkLhJNJS5SUunnumCdJLJhgytHH1OvdZkxqr2O /goSFhMdC6TfBI68qO3XcpA+6PFUi2mFZAJUyJGiE0HeUSs9u4RUuBubKcQRAUa3cg+Ki2WuI7JK VwdUk12hBCSSn//Qx5I1TTKRKjtHKptxc6JFOCDoomJ11QSsI5CR8kkxRUrUahODPKREBMHGEkKM n4pzomElL4oJWMFRfoFIKFhkJ8N1ktkYUwotKkrYaqkkk6KlJhqkkkpQTpk8JIWTpJfBJKpSTJwk pRTc6p0ySlcpJ0klKTJ0ySFJ0kkkqlLRLskNElKSTpkkKSSSISSsnlIhJJSjqkkkkpWiR0SS7pKV ynTBOkFLJ58EkyKlaKSaUuElKlIJ0ySlJBLhJJC6SYKRSUskklokpSUJcJ0lLJ9UkklKTfFOm50S UuEudClCeEVKSCYJ0lLSlMp03CSlJ0k0FBSo1TlMUkVK4TlNCmXbgAQElME6dMkpflJMnSUsTCko qRSUpJIQkdUlKSSSSUpJMnSUqE4SSKSlfBMnBTwkpZPCUJJKVCScJklKCcJBIJKXTFOSmSUslykC EklLpGEx0SSUukmSCSl0iUk890lLSpaKMJJKUkPNKUuUlL99E8qKeEkKCdME4RUpOkEySlJ4TKSC lpSTwlCSlJBIpIpX4TBIlJJC6UpQkklQTwmlJJC6SaE8JKUEglykkpflLhJKUlLpilOieElKSTTK dFSpTymTpKWTpk+qSlDlOTqmSKSl0iUgmSUuE4CXCaUkLjRLlIJ0lK4SiU+2BJUQZSUv8Ux1Tpik pdPCaICQ1SUopJJyipblTJURqnJSQo6pJgVImUksVJRUklLJJJSkhScJk6Sl0gmCdJS6sUHsq8ol ToKSXZrfIBUyA0yq2O6Wx4I5JOqpyFFsx1DID3p3tgyoA7SJRjHcJq5HWPFM4gFSk7YCi9hcAipi 736JJ3Axqkkp/9HHAUYjVSiNZUD4qk3FR4JFS7KJStLGUgUiFGPFOQyI8E0JQkR4IKUNExOqedFF ySGQQ7VPhCedVJDdZM6KaFKJSHCdWg11JSkmSUoKRGkpvgmSUpJJJJS6UpkiISUukmCeUlLJ0wCd JSydJJJSpTcp0klKShKEpRUo6JJJSgpZPyklCSFJDhPKblJKyQCf4puElLx4JJaJSkpSSUJQkpSe E3KeEUKhOUgmSUvEpkoThJSkpSTJKXITQknSUsAnCSQSUopJJBJSkk5CYeaSlwUktEySlwkm5ThJ K4TpkkULd0k5Cc+KSloCUJk8pKUZS4SSSUuNU0Jw4BMTKSlJJwmSUvqm7p5SjukpUJJ5SlJSgEuE 5CYpKUlCSdJSxSSSKSlFJPEJJKWTwlwkEkKCdMpJJVKaJTpFJCgmlOEuUkq5TpQlPikhSZOE0JKX UU+qdJLGE6SRSUpKEvypJKV8U4CZOdUlMjHZNykEpSQxKSc6pJKVCc+SYa8KUJJWCSQEJ0kLKQEJ kklKKSQTwklSR1SSlFCviknSSSoR3SPkkUkkKSSCSSVJ4lMnSQpLlJIJKXTJJxCSlJJJSkpSUlOk EVKAT8JTAhMElKThJJJSkpjRME6SlJJJJIXSKZOkpfhKEydJS6Ycp5lMfwSUu5yQEJz5JuElLhMl KXKSl0ySUoqUniNEydJSyRTykUlKT900p0kKCflRT8JKUknTJJUAkkkUkLpwmTjRJKipNMGU0JpS U6mK/VXY00WZQ6IK026fNV8o1ZsZ0WieURvCgDKmCoWVcNAkFJuoUHfSiU4kHRFDEnRJOdCkgl// 0scnvwojwSe2dUzQe6ptxc8KEFT1CjwgpYiO6XZIiUgIRUsNeEjKfjRQIlFTKfFRJ1TqI5+CQQVy QhE6opQwJKlxseTZkE6QB4UnaiI+asMDGfBNCeE4CSloTEqRCaAkpSSdRSUohJPCWqSlk6RBTAJK ZJkkySlJykAkkpR1TJ4SgpIUl5JtVLhJKyXKUJQkpRS1hKCn290lLSkNE8eCUFFSySfbKbbCClkl KJTRqkhSeEoSgpJWUgltSIRQskpAQlCSmMp5SIKUJKWlOlBKeElMSnTwlCSlk/CeISSUxT+SUJAF JSglCeEoRUtKXCchNCClABIhPCeEVLdtElLalB4SUxj703xTwlqkpUJKQkJi1JSoTHwThOGpKY8p KW2OEtpKSlgEk+1LakpZIcqUJtqSlaJA6qYaowZSUomUyfaltKSliknDT3S2nhJShqkn2lPtPdJT FJPsT7UlMUlLaltKSGJUphPt8U8JJYp1LaUtqKFgE0SpgFINQUxIShS2JbEqUxS0U9icsRUjEjhJ E2d02yUqUjhJT2Jo8EqUxTKe1LahSWPCSnsS2gJIYJQpbVLaEVI4SARNoSiEKUwCeSVKBCQARpTG EoU9EoCSmEJFTMQmCVKYynUoBTgBKlWwhKIUtE8BKlWxShS0SkJUpjCSkIKbcEqUpMpy2EwcEqUx iE6W4FPuCVKWhJOHBPvaUaUslCc2AJt4SpSk4BS9RqQsASpSxTwm9RpT+qEVLxKUJvVCb1QEEMtp TQU3rBL1RwkplCUd1AXBN6wPdKlJQ1KEMXhL1wUlJOU4agesAVI5IKKkndPCCMgSkcgcoKTAdk5V f7QEvtARTSdO0DuVXOSE32kdktFU2iNUjoqv2kcpvtIS0RRbUfelCqjLATHKCSqbh4TgSqP2sHun GWBolaqbieFS+1JvtgS0VTe41TSqP2tL7UlYVRb+iQVA5fmm+2JWFUXQlIEBZ/2tN9qSsKp0k0hZ 32shL7UUrCqdIOCW4LL+1FP9qKHEE8Lph4S3BZX2opfaiUuIK4XosdwLdVp1mWArkacpznBo8V1m PrUI5Ciymxovxiil2qQMphxKYjRV2dTh3UmlQcdEmugSjSl7BqkiOAISSQ//08UhycAjlSn70wcV SbixcOFAtUnJkkqGvKRTJcFJSiJUO6K5xiOEIIhClEpGUg1OWqJgJMA5KR1CqPcQdFLjY8jdDgEt wVH1Cn9QhTWwt7cExeJ0VL1Sn9RK1NzcE29qp+oUt5StTcLgluCp70t5StTc3gp9wVHeVL1EbU29 wS3BVvWTF/cIWptSEtwKpbyl6hStTeDgluaqXqFI2FG1N0vCbcCqfqFL1ELU3dzUg4Kl6hSFhStT e3tiUtwVH1Cl6hIRtTe3tThzVR9QphYUrU3i4JbgqPqFL1Clam8XhIkKj6hT+oUrU3dzUt4Ko+oU /qFK1N7cE28KkLCl6hStTeLxwU28Kl6hTeoUrU6G8FN6gCo+oU3qFK1N/eEi8KhvIS9QpWpvB4Ck XtWf6hS9QpcSnQDwl6jQfJZ4sITmwpWp0N7UxsEws/eUvUKXEp0N4KQsBVD1Cm3lK1OhvCcuHKzt 5S9QpcSm+XhL1QFQ3lLeUrU6BeITiwALO3lNvKXEinS9QHVL1As8WFMXlLiVToeqE5tCzt5S3lLi VToeoFE3DuVQ3lOXFLiS6AtCRtCz95S3lLiU6HqtCf1hCzt58Ut5S4kU6HrBI3BZ+8hNvKPEqnRF vil6wCz9xSLihxKp0RcEjcFm7in3JcSqdH1wl64WbuKfcjxKpv8ArDsmFwCob05ehxKp0RkDum9c FZ25LcjxKp0TkBL7QFnb0t6HEqnRF4Tm9Zu7zS3pcSqdE5ASF48VnbpT74R4lU6H2jupfaVmb0+9 LiVTpfaAnbkifJZm9LelxKp1PtQS+0g6LL3pi9LiVTq/aABym+1BZm5NvhDiTTpnLCicscrO3J5R 4lU3nZSb7UqMlLVLiVTf+1JfaVQlOhxKpvfaZ5SGSqEpJcSqb/2lN9p+9UpKSXEqm8clN9oVIJSU uJVNz7Ql9oVOUkuJVNwZKX2kqmklxKpufaUvtPcFU0kuIopt/aEjknhVEkuIppt/aYS+0KoklxFT b+0JfaVUBTpcRU2TkFL7Qq3CYJcRU2ftBS+0FVkkuIqps/aCl9oKrJ0uJTYOQSm+0FV0kuIqpsHI KYXoPKSHEVUnN5TeuUFKEuIqpN6x5TesUJS4CXEVM/WIS9YoSRS4iqkvquTeqShxKSVlSQ2lL1TC EnSsqZm0peqUNOlZUz9QpGwofwSStST1SmNhUEkrUy9QpeoVCUkrUz9QpjYVBJK1M/UKb1CoFJC1 Mt5Th5PGpQx5Loq66unY4sLN73IqcI7hzopBlruGldN6DcgMe9sd4hRzLwz9GwgE6QPpJKecbVa/ 6LSVF7XV6OEFdTc9uNWIhphZn7PflWC25w2n83ySU5ldNtoljSQnFNhdtDSSuifc9lrKKGQzu4K0 xtbHufpKSnlBTY4mBxymrqfa7YwSV1F1DWVuIgF/dU8GlmNdsa7c53JSpTjsxrXuLQJI5Ra+nX2a tHtC37gzEIrH07Dqo5AvfYxtWlY5KSXA+w3b9gbJQHsLDB5C6yWkuLNSBC53Mxn1nc/SUqS0k6SS CFJwmTjVJTf6ZX6lwngLrmt26LB+r9O4uf8Act8cA+CjkWSIZtdpCkhg+7yUy4DRMXrOaFJrNPFC JMyEWY+KIQuQY0STNce/KSdQQ//UxokpOHinlMSqLdWIS5S4UT5IqXae6TiOyZpTwkpiT4pEpFMT CKFilCU9k8zwihZVbQrUKvcFJjOrHkGiBI6Jwo2qdgYySptrLjAUYWn0bYbod8kkhA3peQ4SGoDs a1j9jgQ49it3MvvryAySyvs5Eyq7Hsa/cHbTzHuQVTjfszJ7NKA+iys7XiD5rqbXksa7fs81XzMq pzWtBD7ElU4Q6fkO1DSqz63sMPBB8Cupdkg7Q8mo/wDRVLq9Nj2C3RzR+cPpJKpw2Mc8wOU9lVlZ h4IKvdLZvuBU+sWbrQPBJTQross+iJUrMO+sS5hhbvTWj7OXsEvCq4/U8tzizYHfySElU5DKnPMN 1RTg5AE7DC3OmsDi9xZts/dVdvVMlt+wjSYiElU49dL7TtbqfBO/HsrMPaRPiumsqYy5trQAXcwj ZVDcpu08jVFTyxw72jcWmPFL7Jdt3Bp2rrSR6ZZ3AQ8V4FcHhBTylePZYDsEwoPqfWYeIK6yjHGM 9z+ztVm9eE7XpKcIylqpQmiUULapap4SSUtqlqnhKElLapap0kFLapap0oRUtqlqnSSUtqknSQUt qlqnhKElLJ9Uk6KlJoTpRKSloSgp06CmEFPBTp0lMNU8J4SiElMYKUFSSSUxgp4KeEklLQU0KUJI qWjzSgqUJIKYwUoTwkZSUtCUFShLVJK0SlCeE0FFCoShErpdZwolpBQUxShPBSgpJY7UoUoKRBSU xhKFKClBSUxhKFKEoRUxhKFKEoKCmMJbVKEoSQxgJ4TwUoKSVoTRKltKW0pKWLQlCltKbaUkLHwS 0TkFNCSlQlCSUpKUCkUkklLQpNKiSk1JTNJOmJhFSk6GbE28pKSpiotfOhU0lKTJ9O6YhJSkk6SS lJJJJJUkkkUkKSSUmMLzoEksYRm473CeytV47WCXcol1uxkdyozLoF4i0GUueYCJ9kd4qxQPTbuK j9oYyY5Q4j0Vwhq+i4Hb3RRiHuRKsVv3Au5KCyux75doEeIq4QhfQ5nKTqC1slXjte4NHZCyWPcY A0CQlajFpNbvMBFtp9PnlGxaodJSyKnvdPYI3qitGoxheYarX2Vrfpu1UsUhs+KZ1LnvkkR3QMtU gMbcbaNwMhVVcyLgG7G6qmnRvqiQUASYHJW3jdGrbX6uS6B4LJx3BtjXHgFdNcK82sAOGninIarc TCsb7dB4qthYuNZY5j5J7LXZ6WOz9IWmB2VTGqprc7KtcJ/NCSVM6NTW422n2DgIGN0+rMsNgEVD iPzle+1051ZaSAPNCwb6qmmkOGndJH/SVkYmOxh9kKOB02ptfqPbJPiiXZdNFZYX7nHuoM9F7QfU IA51SVTV6m1rGw1gH8pYi2uq9QrsaKqtQPzlipKKkuEydJCyQSSlJSkpSSSUsknTJIUkkmSUopk6 SSlimTlMkpcGNVsVdaDWBr2zCxkxKSnWd1qwv3/cFSGU71RcdXAqsmRtNtvKzH5Ltz/uUWZVjSDu OiriSpCsnRK0W6v7btiAAD4qv+0bdmyeeSqwoMwnFBRsqtsW59tzQxx0CjTe6pwcw6hB9Nw1TgQU LTbYsyH2u3uMlEPUbyNu7RVuNU0pWm07My2v6LlC7IfcZeZQkkFWsnTJJIXUgmRKGGx4b5oJer6N UKccE91ogyDCHQyKw2NAEZoBCiJZI7MO6JAHKGGgcKUSguUwCSpEd026CpDVJTCfcI4SUoASTuiO r//Vxh5pGCk4JiFSbq3HJTHVOVGdfFJDLbCbUKUqKCWGvdI6aKWqb4p6GMJ5hJJJSghXCEUeSHaJ TobrZ7NVNYNJTkapP1arLVYBSY8sMtMEKDeE6SXUr6zcBteA4D95Qv6tZa3YAGjyWclqkm29d1F9 9XpPAgd1Ta4gyOVFKUEW6zOt2bQ2xoeBxKFk9Vfe3YAGt8lnJJKts4eWcV25olDyLjc8vPJQuEkl NrFzbMYzWfktD9tu5DGg+KxmogSS2251rbTaDqVd/bROrmDd4rISSS3rOo2WPD+I7I37XeH7w0eY WYklanTHVnB5ftGv5qgOpkNLY0Oqz0tUrU6T+rvezZGvigZecclga4AR3VUJkFMdqUJykEkMYShE cyBMyoIqW2pbQpQmKSloCeEkklKhIgJ0yCltqW1OkkpW0d0oCdJFS20QlCdJBS0J4SShJSgEtqlC SSVoCUJ0ikpbaEoTpBJTHaE8BOmKSloTwkkkpUJQEkklLQpQEydJS0JQE6SSlkoTkQkkpaEoCcpJ KWgJQnSSUrhJJJJSkoCSSSlQlCdMkpaEoTpJKWS+KSSSlJQnSSUtCXwTpQkpSSXCSSlkk6ZJSkyd JJS3KYhSUSkhGUkikihSSSSSlinaolSakhkpbdwTJwSNUVIXMITQVeFzXCHNChuaOAiVNZlZ5RVJ 1m7ThQ5QUpMkkkpeUkySSl0kkoQSpJJJFSlNlpbwoJIKZ+oZlJ1pdyoJJUE2UhtcRHZQTeaSSrZt sLeCpnIedJQUkqCrLNtjhwpeu/xQkkqCrKQWuHBSNzj3Q0kqCrLLeeU/qOPdQSCVIsrkpkikipeV Jtrm8EhQSSVbN1jnfSMpt7joToopJJsstx7aJpKaUkkWVyUpTJJKsrpuU6QkpKWSlO4QmSUpIpJJ KUmSS4SUopJFJJCySSSSlJkkklKTJ1FJSkycqKSl5Ug2dVEBFZqkplt9oIRXCIKepu6sjwUwN1c9 wnAKVEOBPdFDYdHionVgPcIhMua4p1KRkdlB1M6hWi33FRDfFKrU0iCDCYqzdXpuCrFMIpKkySUI KXSCQCSSl1o9Jq9S8HwWcF0f1exg4Gw/JNOyQ7+2PgmaeyJtkILvaZUTKFxqSpDlRI7hTaCkli9O zRMXJ2SUVL6T8UkImHR3SSQ//9bHJlN5JO1TKi3Vj4Jh5cJGSk0pyFyO6Ynsn+CYhBLHRIlKSm41 RQo6pktEkULqL2wp8KLiDokN1HZpv0S7J7BqmbwrQapRNUw0lRbEqxXBSUEYrKZ1ZCtiuRIQzoha 6mrwkpP5UUVqkkgkkhSSSSSVwpoYU0lMwkkkgleUuEwTnRJKkkuUklKSKSSSlkgJSSSQtKSSQ1SU ukmTpKWSSTpKUkkkkpZJJOkpSSSSSVJJJJIUEktEklLp0ydJKkk5EJuUlKSSSSUpIpJJKWTpuUik pSSSSSlJ0ydJSkkkklLJJJJKXSCSSSlJFOkkpZJJJJSkkkklKTpJ40lBTHhKE6aEVKSSSSUpJMnh JSvJJLRJJSkoSTpKWSSSSUsl5p0ySlKJTlRJlJDApJJuEULpJJJKWKdqiVJqSGSSdMileU4ICikk peUySSSlJJJ0kLJJJJKXSkpk6Slk6ZOUkqCUpJkkLpkk6SVJJk6SlJJJJIUkkkklUpJJJKUpBhIl RSlJSkkkklKSTJ0FKSSSRUpJJJJSkikkkpSXCSSClJwYTJpRUukmKSSFFJJMkpdNykkkpUpkkklK TSkmSUumKSSSlkykmSUvCLXzCGApt0gpKbmODvLT3UqWwXMUWnbY13ijPHp3T+8nhDCrVhB7KbQX Vz4KIG2wg91OkauYipKRMOHCZwgqVetRH7qZ/YoqXcwvZCzHjaYWtWJELOyWbXlNkkIUyUpJiV0k kklMgu06PT6NDZ78rkMWs2Wtb4ld5WzYwAeCZMrgEvAQeUQHhNAlRsjBohTCYc6pOHEJKYbfeptg FIyFEFJSi2XSkpO8kklP/9fGLlF3kpnzUdFSbrFOEtTwkdAkpYfcVF2qkSFEyiELcJiJUwIUYRUx lSCSSSF5UTwnkJGEgktSwKLCi2hBboVZjs1ZbsDo5TBUbeUpTlqZtzmpnWSh7k+7RCl1qcoJcpJI WSTpJIUmTpJJUFMKCm0SkpkCnSCSSV9UydMgpSSQ8k8RykpSSSSSVkkpSKSFkk8JklKSlOmRUukm SCCl+UiklwkpSZOmSUoJ0ydFSkkkkFKCSSQKSlwnTJJJXSSSSUpJLlIpKUmTpklKS0SSSUpJJJJS 8JJpTpKVCYp0ySl4STJ0lKSTFOkpSSUpJKUkkkkpSSSUJKXSSlJJSyZOmSUpJJJJS6ZOmSUukkkk pSSSSSlJk6aElKST8pklLOUSFIqJRQjSSSSQukkEklMXKTeFAojeEkLpJJJKUkkkipSSSZJS6RTJ SkpdJNKdJSkkwTykpSeUySSlJJSmlJS6SbclKSl0lHcluCSmSSbcE24JKZpk24J5lJSk6aUpCSlJ JtwCiXhJTNJQ9QJbwkpmlKh6gS3hJTNOheon9RJSRJQDwn3JKZJk25MXpKZJShmxL1ElJEkP1Cm3 lJSWUkLeUt5SUlTFC3lLekpIkoh8p5SUpKUkySlFNKdMkpdMpbD4JbSkpZMVINKYtISUyATtKk3Q aqLeUFNqfYHeBVrKMtbYFVo9zC1Waz6lBaeQpAha/RzXqY9tgPYoZO+oHwRCZa1yKk1Ih7mpbZaf JImHhym36RB7oqWqiVWz64O4KywFpU8mk2tDW8lIiwkbuLCbhX/2ZY630Qfi781Vb6vSeWTMKJKN OE3CcIKdboVHqXz2auuErF+rlG2svPdbOoMlRSOrJFkPBNJB0TwokwUFzLQqIA/NSiQQUOt0aIqT wCNUNzRMhSBlReJSUz7JJm8apIKf/9DFJUXHRSJ0UZBVJurBpnlIeA7JTCTnAIoXKgedFLcCohIK KvimlJNARQrVOPBRlTEBEqCpCRHdI6pSglBagd1at1VUcqeB0a8xqtbxKiNQi2tEaGQgtUjGumUi QmQSpNKdMkhSSSdJSkydMkldSBUVJqSmYTpgnQSpOmCSSl0iZSTJJXSTJJKUkkkkhSZJJFS6ZJOk pZOmSSUuE7oB0TJIKWSTwmRUpOmToKUnTBOCkpZJJKUkrpJJBJS8pBJJJSkkkklKTJ0klLJ4SSDS RKSlkkuEklKTpkklLpk6SSlkkkklLpJkklLpJJJKWTpJJKUkkkkpSQTpcJKWKSSZJSkoThMkpSSS dJSkkkklKSSSSUpMnTJKUkkkkpYqBUyoFJBYpJkkULpkk6SmJCm1DPKIEkLpJJIqUdFBzwEnFBJl JTM2FIEpNbKM1iSkMEp4JVj00+wI0pqwUoKs7EvTlKlNaCn2lWhXKn6MiEqRbSa7spqFjdroUwgl i4whySneU7QkpYAlS2FFY2UUMSU1dhS9Mq1slP6aNKauyUvTKtbE/ppUhqispnNLFdbWoZLPalSm sNUniEzUzyglhMqQbKZqMxJTEVyl6Sstb3UtqNKanpJ/SVvYn2JUhp+kl6SuemU4YjSmk+qBKi1X rGQFSGiBFKC50QSZRHlDCCV2tlEFaZuisViUlI/SSNSs7U+xOpDV9FO2lWdqfahSmq6pDdVCubQk WiEaU58QnBhTtEFCTUpEyfskUlLI+JX6lgagItNzqTubygp2LHV1fSjyaEC+uWtawcnssxzy924n VWWZ1jBAKFL7DotqG6I0aFSpxzZd7hohMzLGkkHUpxm2TMogINLZtfpvhV2p7bHWGXKI1SQWzS/a 74q3i+17mHuqDTBlWhZteHhOCEtYALmHROwbmEFCNg3Fw7qTHap1qptt1YPEK06uC0+KBjsDoB4W rVjAgHwTwLWkue+stcQjUnb7j2VmyqJPiq7WwIRpKOvqY97nwI+j/KWFa/e4nxRsxmx5CrKIr1KT ROnioq3gU+rc1p8ZTCp7Dp1foUNb3hWSZEobSAAFKY+ChZBskaZCTh3TNgKXZFKKfBMeZTt0dAU4 B4CSlh2UnaIZB4RDwgpeElBhlJJT/9HE40UYRC1QVJurKMQpj4JvjoihaU3KRCYIoUlxqnTBFS0y lonITAGElL/FMSU6ikFKI0VVw1VxogFVLFLAsWQK/NQWozeEEaFSsK8pJJSglZJJJJC6SZJJS6SS SSVlJqZOElJAE6iFJJKkkpSQUpOmSSSukkkkpZJJJJCimTpklKSSToqWT8JJIKUkkkkpUJlKQAoo qXTgwopJKXSSToJWSTiEySlJ0ydJSk6ZOkpdJMkkpSZOkUlLJJSmCSmSZIGNEgkpcuTJJJKX7Jk6 aUlKI8EkkklKSCSdJSgmSSSUvCREJkklKTpJJKZABMmTpKWSSSSUskkkkpSScpklLpJJBJSkkpSS UpMnSSUt5JJJJKWUCpKJRQWCSSSSFJJymSUsphQRAkhSXCSZ3CKkTzKi3UpyEmDVJSVngrTGKqDB RQ/RIKT7fFL00PeQn3pyEgYn2IfqJeojopLsCKG+CrB5RW2GU4EILSymw9DRcky/VBUZ3XI3cqbV A8ojUFNitGEKGLjWZB219kVmLa5xb3HKIKltE+itUdHy727mAAeaFbgZFVgqc33FOtVI5CUhW7+i 5NDPUcQf5IR6fq7da3c61oStDnh4ChkGWlGzcRuK/Y14f8FUtPtRvRVNUIb0RDco0rsRWIbEQJKb LXKe4AKzR04WVtcTq5K/ppqtbWDz3TgVNYOT79YWljdFqtl1lha0Id3S6jYKsazeTyf3UbVTSD4T eots9DxNpax5dYOdVg2s9NxalaKSF+4Kg7Qq00wCVUcZ1QkbUweotUnqLU1KQI7HQghTCSk/qAd0 5tha3TKKqavXez1HngRuhTPoZOQ0hvHuLYRtVOMLJTbyVv5WftaWV0QON23RUeo7WVNaAB4o2mnN Lyo7yVElLlC0I7UEIj1AcoKZpk6SSlk4CSRSUuEk0JJKZTKUpk+iSlnJgpEJgkpkDCkHkoXJhGY0 BBKRvmptfCGnRS2mZbmHQK9T1p7NI0WQnThIhVA7u83qtdo1EJb5Mt4WCj49xrPOidxo4eybqLdZ Wer+dYHQqCYVKC2/q/Vut3nssUeS6rolGynd4mUyWyQ61rJGidrt2hUjqEBhg6qNlTkKbCocKTYS UieIcpMfrqpWgEhAMh0JKTOMjRIjRMRLdE7TokphXoYSTPO10pJKf//SxiSVCU8EFNu7QqQbihPJ Tc6J5ATRCKmB5SKc8pjJ5RQt2TJyUiSnIUnGqinhAqCimKdJEKU10qvaNVYbqg2hOjusnsjZCE8Q 5EaYULuZU7AskkkgpSaUkklKSSTpKUmSThJSk4TJJJSBSUQpT2SSpJJOgpZJOmSUpJJOkpSZOATw EySlkikkkpdNKflJJSkk0JJKXhODCZMipX5Uk6ZBSkkk6SlJJJwklZJOmSUqU/KZOkpUpwkDCcmU lLJJJIKUkUkjqipZMnSSUsnSSSUpJJJJSk6ZJJSkikkkpQSSSSUpJJJJS6ZJJJSk6ZOkpSSSSClJ FJJFSySSSSlJJJBJSk6ZOkpSSSSSlJk6ZJSkkkklMSouUiovSQwSSSRQpPEpkklKjVTCgOVNJCkz uE6i7hJTGEzRBTgpIqZAStbpNDbXkOErJatbppLWlySU7MNtdjw4COyP0vDrcHPeAZ+jKsANupL2 8lEpFFbWssfDvAIqc/7NXseNokFL020YvuALj3V9lIdkFvYrN6vYA70m9kVOXpypM5UFNkBJDXu+ khFEedxlQTSpg4KbdFEqQKCnc6EQwucVour2l9g4KxsLIZVU4H6R4Wm3qNbscMJG4ohc3G499tbf Ss2BDfk1jIFbn+4D6RVR2e1ljNjvb+ciephOtO8j3D6Scikufj301ufVYHNKBhOc3DLieU2Xk42L SaqHF5KrHPrbjChs7u6KnNiTKa7RqQPih2PnQcIFCJRcJUpTSmqWaIRWoUo1RAIJSU9HQ3aGN8Ar bgcg+qPzVjDqomdvAhSxur+jW5hElxRC6nUaaG0k5JIafBAwfRb6lmOCGcarOy+oi+sVtGgUendR +yct3NPZFTe6OC59trtBPdZWS8WWOPmr+Z1o3M9OpoY3yWUSBykUFk4wxVJU7bZ0HCDKBQukBqml KUFJAiNE6ITXIgcElPR4f2jFa1rB6gPMdlYaIvc9olwHAWFV1S6pu1roChV1C2sktdqUlzp5N+da 4NsbtrlN1DDvtILW+0BZtvUrrTLn8KD8+14hzyR4IqQuEGEphQ9QJnO0QWo3GUmqJU2pKZJlKEyS lkydJJSk6UpJKXjRLhOHJuUlKTFOkkpkxsaoiYKSC5SSSSKlxqkmTzKSVynGqYaKSSl7DMTqhJ3G UySGbGbnAeK7bDZsqFY8FyfTavUuaCuyYwCAEySYpGDRMWyU7XRITk6KNkVwpMOkqI1GvKkw6IqW sPtlCLp1RnREeKrNRUmaZUmqNccJwNYQUp0RqkmsEiEklP8A/9PH1KG5SJlR76qkG6xSMqUAJcoo Rz2SmOUx50TnXlOpasUxTkptSihSkoJ+UilR8UxKkokpBTJsqFo7hO3lNZwjHdB1DWnVK0aJO5Tv +irDWKIJ0wSQUpIpJIqUkkkgpSdIBIiElKlJMnSSka7ROFFqlCSVwUgkkkpcJJkuUEqSSSSQzZa5 gIb3UCkkkpSZPwmhFS8wlwmT8IKUCmS5TykpZJKEklKSSSRUpJJJBS4SSCSSlJFJJJSkkkkkrhOm SSUunUU6SlJJFKElKTJJklKTpk6SFJk40SMdklKSShJJKkySSSlJJJBJC6SSSSlJJJJJUnTJJKXS 4TJ0lKSTJJKUkkkElKTpJklLpApJcpKUkkkkpSZOmSUpJJI6JKWUCFMqDkUFimTpJIWSSSSUoBTC gFNJClF5UlB6KmAKYlIlRAlJSRr1ZZkFogHlVQ1PCSm8zOsYNrXQEzspzzucZI7qlCRajabdD7fb O7cZQrLzYZcZPiqsJ4StVpTYAoG6dE21De2EEM5TFMOEnGElMS5IFRGqmAkpk2wqXqKO1PCSmXrF L1ZUdqW1JVsvUhLeTwmDU4aipgXkcpwZU7GaIbUFLoZcpOKGkpSkCUgFMNSUtuIT7in2pwCkpjuK fcVIMT7CkphJTESjBo7hNtCSkBamhWNklMWSkpBCW1WBWkaoCSmvCUI2xLZqkpCkjFgS9NJSGCpQ i7E+xJTXIhKVbNQcNFVcISUxRWoQRgElKJUSnTJKUEkwKeYSUvwkSovfuKYJKZApAwmBShJS6cFK CU4aZSUkaVNDa1TEpUm106jKeUkrpBMnmEFLpi5MTKblFVqlOEykEEO50HH3Oc/7l0UyICzejUbK A7uVqtCjkyRVtg+SnoQhPJ4CedNU1czAI+CYaKQJTwipYoBEGUd3iod0lMYjVTnUFM9IBFTNySXI SQU//9THCERqiFDVINxTgSlxoVJpCi8TqkpieUycTEJuE5Cx5SckkT2TkLEhO3xUQpJFSxKYlP8A FI8JIY8FO5MFM6iEVdGm5SH0UrBCTeFOGuULUkuHJ0ULJJJIKWSSSRUulKSSSl0uEySCmYUgotKl KSWQCZOkglSSWiZFSk6ZOkpSQ10S4SQUu5hbqeFFOSSmIRUpJJJJSkkk6Slkk8pkFKSSS5SUpJJJ JSk8JJJKUEj4pJJKUmTpJKUnTJ0kqTpJIKUmCcpIqWSTpklLBPCZOkpYpJymSQulKRSSSpMU6ZJS oSSSSQpJIpJKXSSSSSpJNKcJKUkkkkpSeEkySlJk5SSUumSSSUumSSSUukmTwkpXKSZJJSkydMkp YlRcpFQcigsUk6ZJapIpJJJU1TUGhSlJC8IdhRAhvElFSIqTQmcIU28JKZtbKIGKLXIu5EKYempe mpboUtyKkYqT+mp7wluSQoVdyg316SFYD1C8y1E7KaY4UXqag9MSpoRWtlDYit0SUkDE4qKW5SL4 5RUsKk/ppNfKfcihbYFL0wmlLckpa1mhhVRorjz7VThApDF6i0J3hMxBSRoRmtQmorSkpJsCfYFD cn3SihntCUBQlOxrnuDW8nRFLKAmgLTH1ezI3HaNJ5VR/TrmMNhjaElNcgJiArdPS77oiBPirNv1 euqbvfY34IKcvRLRa9f1de4BzrWtCHT0J17nBtg2t/OKSnLkJpWjndIOI3cHhwWWkpnKaQoJJKSb kg5D1SSUna9VLeUYHlAckVLMRAoNCmgpZJOmKSmJKgTKclMkpSmAkxslGc2AkpEOU45TFSSUyadN U86KIEFOBCKmYMKQ107Ic6IiKGbWiJJTspc4buyjtmR2Vmt0gMCKLazm7VErWysIMpFgWSUJClwN sU6SSalSLS3c4AdyhwVodIp9a8TwNUFPU4rPTYG+Sst1TFoCI0aKEso2YOAhM3XlPyosMyCklMCn cgh20o26QjSmJ481AaqXKQaNUlMXnsmbKd47JNEBJS4JSTDTXskkp//VxCRKXaU0apy5Um4x54TO 8E/Ci4ohSgkRol8EychYHVInxTTCcooYypBMR4JxxKRUFc6lMNUpSJSClTCk4qHdTJSKhs17RrKG wwUWyUFvKnjs15bsH/SSUrRrKiU5askkkgpSZOmRUukmToKUkkkklkCphQEKUwkpknTTKdBKySdM ipSeUySSlSlwkkkpSSSSClJBJJJSkkuUpRUpJJJBSkkkklKShOkkpZPCZJJS6SQKdJKySRSSQpOm TykldJKU6ClkkgkipSipJklLJ00J0lLJJ0ySF0k0p0kq5TJJJKUkklKSFcJJJJKXSTJ0kqTJ0ySF 0kySSV0iklKSlfBNykUkULpJJSglSSQSlJSkkkklKSlJKUlKKZPKZJSxUCplDKK1SRTJ0kLJipKK SmTVIqLVJJKgU0SU4SOhRQie1O0aKbtU0JKZ1t3OA8Vt5XSKqq2uYTudysjFE2Aea6itpsEk6NST Tm5/S6MWkPYXF58VK7orKsX1tx3xPkruTOU5jfAqxfVZ6TmvcHaaAIqc/A6bhPpFuS5wJ89qrdW6 dVhkGkksPir7bcaihv2gF0cBZXUM4ZbgWja0cBHoqmkAmuOicFQvOgCSECYiUkyapdohEaoNU2pK SCfNbXRfSqD7rWbo8Qs6jPsoEMj5hbmFdk345cxoc74IhSsl2Pn0GyuvaRxosFmLfbrXW4gd4XQZ GVdh40WlotP5oWfX9YcqobW7fijSac52NezV9bmjxIQ1ayOp5OT/ADjtPAKqkhez6KqkqxcdIVch AqW5CYCCnhIIKZBEAUGqYSUunSEJpSUurvS2b8lvlqqMrR6TZVVaXWmBCIU6vUaZDnOydv8AIaUa ljTjCjkws7Kq6af0gc5z5lM3qdbLmvE7AEV1M+otcx9dIJGusJ+pEvuqpB07qvf1Cu7LFzp2NUHZ 7H5QucCGDt+ckp0eoDC/w9jpA+i1SwqKzjCsvLQ7j95U8nM6fbLvTLn+ar3dSa4NawQGlJXRP1ex tTRj1gx+85YpV7Pzm5RG1sQqEoIKkwTpSghSZJNuHdJS7jAQZlSc6UmhJS4CkmTpKUmITpFBSIpJ 3JkVJa9NVAv1TApoSUzc6dFM8KDRCkElMo4KlGqiDITjVFDLaUVjdJTMALoJU2iZATgFL7dVOo7H h3gUmgQCQpga6BPC10LrwAWHg8LEeIKulpcfNVb2Fp80JpiiSTJ1EvXXQ/V6iSbFzwC7HpLBTQ2O /KbLZIdBymE2iblRMqhyVATuPgpwmc6EVMnNlqavQKJdLUSsaJKUSGlIGdQkYKG10EhEKUTDlKU1 mqYkwkpd+o0STpJIf//Ww/Mp/gkQlEBUm4sNVFzY+KXGqYuLkQorJjqpccpifBOWrBqUpplJFCoT 9k0J2pFK35ExEKREKJMpBBV+VTHCGpNKJUCwtEqurNhkKsQpIbMU91WCRKGEVwlqEOFIxqSSTIKU kknRUpJJJJSkkkkFKU1AKYSSylKUySSV5nlKUyZJDJKVFOElMpTEpkklLylKikkldKUySSGUpKKd JS8pAqKQ1SUzlJRSSSylMkmSUvKeVBOkpkCkop0FLymTJFJTIFKVFPyipnKUqKSCV5SlRISSRbOU 0qKRRUvKUqKdJS5SlMmSUylKVFIJKZSlKZKElLpSmTJKZEppTQmSUzBSlRUklKJSlMmSUylKVFJJ TKUpTJJKXlNKRKYJKZByUpkklLylKZJJS4TymlKUlLkppTJASgpeUpTQkipeVA8qaGUkFSSSSSlK JTp9uk9kkKbwpcKLVJJSk+jh5qKSKli0tTblMOKYweySmVNxrcHDkLQb1a0AjT3LMgJbQkm3Vb1Z 7eAJQqeoPqJPO7xWdCW1G1W3789142uiB4KvIKEAFKR4JIZ7lB2vKfem3eSSkZUZRdE0eSCkcqTX QpJJKXFgCsVZ9tLdtby0eAVaE0JKTPyTYZe4k+ajvCilKNqZypAqG4hL1Ckpk7XVCcCp+oSm3FIq RkFRgou4pSUFIxKkC7wUpTSUlK3HwS3nwSSKSltx8Etzk6SSlpclLkkoSUqXJvcnSSUtqlB8U6SS ltrvFLafFSICZJStp8Uo80oSSUohR2qSSSmIanhPKUpKUlCSSClJ0ydJKN4UVNwQ0ULpJJBJTOUR oE6oQRPApKZNHIU28QmAgqTRJhFC48Sjt0MITBCIASQfvTwgp2sIafwTgEweyZpIdrwpgS2CnLWb ICFm16ByMxEvZvqJ8ECLCQ4pSTkJhyomRPjV+pY1o7ldvVXsaAOwXLdFp33bvBdW06KOS6LOZCjE GUmGUpMprIoOKiDuOqIAJQ3mElMnR3U2P7IMTqURqSmRGkqAOvxUim0RQoiE3KVo0lRr1CSkgEaJ KIKSSn//18YSouMooGmqE8RKpN1XZQcQpTGiiWlEIKolRdoVJRcEQgrCAkYTNUinFDHsnbwlKQSU o6po7pFMHJIVGuqk1RKQMcolQXd8FVdyrR1VewJ8GOa3LUAI7CgnQqViUkknhBTFJSTJKUkmTpKU kkmSUuiNOkIak1JLJJJMkpSflRKQSUySTJJKXTJ0klLJQnKZJSiISSJTJKZQkkNUklKTJymSUukm SSUyTFOkkpZJIpgkpdPCZOElKTJ0ySlJ0ydJS6SSSSVQmTpJKUmKdMQkpZOEycJIVwkkkkpSSSSS lJJ4TQkpZOkkUlLJJJ4SUpJJPCSlJk6ZJSkkglCSlJ1FPCSlFJKEklLpk6ZJSkkikkpSSSUJJUkN E0JwkhSSRCWqClSoKcKCKlJJJJKUmJKdRKSGYTpgnSUpJJJJSkydMkpdJJJJSkkkklKSSSRUpJJK UlKCSZOkpSSSSClJJpToqUEkkklKKZJJJS6ZJJJSkkkklKTpuEoSUpIpJJKWSTpklKSCSSSlfBJJ JJSkkySSl0pSTEpKXSTJSkpdJNKaQkpkko7gluCSmSSjuCW4JKZJ1DeE+9BS5GiEUTeENFSkkkgk pkEYCWoIMKYPikpK5wgFN6sGQEMuHZRkpWpsCwlWKy4iAJVBpKu40zzCfEoLosDjBcwkBEc5jidI JV7EcC2C4J7sdrxPKlpjB7ufs4gyrDPcwsKpZDTV9GR5KWHkb3bXILq6uZcza4hQVvPYG2GOCqoE nTkqE7sj0XQ6YYXnutsBUMCs1VAeKvDhRHdkjsu3RSBUYhKYCauZubKE4SdVPdqoHRFTN3CkD2UG ca8pwZKSkg4URpynHKT2oKVyIQWSEcKBA1RQsCCZSSYJSSU//9DLjTRCIRXcaKLRJVBuoiNVAnWE Z4AQg2SnhSiYUXKZA7KEIhaWLUinhN+VOQpMPJIp26JIWTRCkSo8IhShqoz4qcdlAooZ68oFghHB kIVoRjuiY0RNKhZypDlNb4qZgYKSZOglaExUkklMAnTwkQkhiknTIqUp1kAqCdJTZc0RIQtqHKW4 pJSQlChuKW4oKSAJQh7inLklM4lIhQ3FLcUlM4ShD3FLcUlM4ShQ3FLcfFJSSE+1C3lOHlJTOPBK FDcUt5SUzhKFDcUtxSUkAShDDylvKSkm1NCjuKbeUlM4TgIe4pbikpJCUIe4p9xSUzgp4IQtxSDy kpNCW1D3FLcUEpITwhbz3ThxRUzIKbbKgXFR3FJSQtKfahbilJSQlhKCh7im3FJSUhINlC3FLcUl JoKbaUPcU0pKSwkQhSUpKSkpCW1ClKSkpLCePFBkpSkpNCaPFCkpiUlJYTwggpSkpMAnhBBSlJSW EoQpTSkpPCUIIKSSkwCUDxQZSSUlIHilp4oKdJSWB4pQPFCCSSk2ibQd0JJJTNzpUEkklLJ0ydJS ybupRKaNUlMgnTJwElKhNITOKDyUUJ9wSBCiKjypispUq1klP0TynFBRpVsEpU/RS9IpUq0fySny RfTKXpFKlWi+SXyRjSU3pJUq0Wvgn18ET0il6ThyClSrRa+CfVG9B3gU4x3dwlwqtr6+CUlWfszj 2S+zO8EuFFtYBxMQpbHeCOMZ3gn+zO8Cjwqtr7XeATbHeSsfZ3jsnGM89kuFVtba7yT7HeSsjFee yl9js52pcKranpu8ktjvEK2MV/cJ/sVngEuFVtLY7xCWwjuFdGG89gn+xP4Efelwqto7D4hLYfEK 79jePBMMN3iEuFVtPYfFIs81c+xnxCRxCO4S4VW0tnml6cd1d+y99wTfZv5QS4VW0tg8SlsHirv2 UHl4TfZWn84QhSWlsCjtV44zB+eFE47P3kqU0oTQr32dg/OTfZ2eKFKaUJQrnos7FRNLUlNVJWfS an9JqSmpCdWfRaE3pBJTXSVn0gl6QSU1oTgKx6QTioJKa0JK4K2+CFcwDhJSCE6cBRJSUolIDxTc JplJSTcBoFEuKTWo/oxE90lIBKkC4cK0amtdwisYN0I0i2o3IsbwSrVXVLa9Jn4qy2lr65I1Q7cB paNuhKeOIIsJftzb/p8pzWGne0rPtx3UGCZCsY1umx3HZC+6U+Z7wHIGHV6lrW+aLf8AzfmrHR69 1m7wTCuD0jGhjQAiDXhQcZTNfCiZQk7aqR1Ci2O6kDISSsIUnFQ+CRk90lKaYMIjWhCHKmx2qSmS JyhwiBum6UFMfJDfM6IndRPCKlMEcpKBMhJJT//RygNEzeVMhIAQqLcYOEoW3VGcotHcpJYQoOHg iRPKiZ7JyGCYqUQf4qJajaGKUp4THlOWrHySHmnlN5pKVPgoqcTqmcCUVFjwUrRISjunPEo9UdGq dCpbdw0UXDVMHFpkKYMBXgcFLb4Iv2gOEOaD5oZcDxojSFtpTFpTmEhCClBhTFpCfTxKcNB7pJY7 UxaiirxKXpJIR7E21F9PzS9LtKSUO0ptpVj0p7pvS80UINpS2lH9LzTel5pKRQltRvS803peaSkU FKCi+l4FOKp7pKQwlBRfRPin9HzSUgghPBRRTPdP6B8UlIIKcBG9DzTelPdJSKE4aieifFL0vNJS KClBRvR80vRM8pKQwlCN6PmkadeUlIYKfaUb0PNOcc+KVKa8FKCjmjzS9AxykpDBS2kIvodpT+h5 pUpDBTbSj+hPdP8AZ/BySkMJ4KJ6Hmn+z+aFJQ7Sngon2c+KXoeaNKYQolpRvQ80jj/ykqQghKCj /Z45KX2ceKVKQ7U0FHNA8U/oDxSpTW2lOGlH+zjxS+zjxSpSLam2o32ceKf0B4pUpBs0lNtRzQPF OMcdylSmvCfajmho7pDHHcpUprwniUf7O3xTjHb4pUprwm2qx9nZxJT/AGdvilSra0J9qsChnBJT +gzxSpVtbalCs+izul6FfjKVKa0JoVr0WJeizulSra0QlCs+izwS9GsJUpqwnVn0mJelWlSmtA8U lZ9NiXp1+CVKa+iaArOxngltb2CVKtrEBLThWgxvgnsYGjQBGlNTRKAiepHITm0eAQUiICkA1S9T yCXqHwCSmJ8goR3KIXk6KKClBSaoqbUVMHN0Qa/pKw7hBY33JKdRt0Ae0aKf2g9mj7lXaNFPaeU4 FVMzc7wCY3HmAmPmmhHiVTL7QewCb13DgBKPJMGpcSqUb3c6JzkP8k0DwS47IcRVS/rP7J/Wco6d kxRtVMja+eUjY/xUQUuUuJVMvWf4qPqPHdLuo7kDIqpn6r/FI3P7lDLvEpbh4hLiVTP1X+JTF7/E piQO6iXjxS4iql97/Epg9w7pi8HukXAd0rUz3v8AEwn3u8UPe3xS9Rs8oWUs9zvEpiXRyVH1G+KR tb4pWVLy5OJUPVZ4peq3mUrUz1SKGbmpvWalakhTSUP1mpvWalakmqSH6rUjcErUkI8UxCh6wUfW QtSaEkH1U3qpKTpSger5JeqkpMkg+ql6xSUmSQfVKXqFJSdKUD1Sl6jklNhMgCxyXqOSUnlPIVb1 HJvUKSm1uhDs1CD6hTbyeUlKdooxCJEqL0EIipBqQCkEVMwNJV1zZqDxyFTYdIV/F99Rb4J0UFVo 9rXKbhtc0jhQZ7qjPZJxJYHJ61t0kEloSBJbHgh1e1zT4owEPLfFOQv6RtaQBJKyQ012bTytrF3O dtKp51Gy7ThMkOq6PZDkuBgBbvQqYpLu7lzrv0jo8dF2uJR6VLW+ShkyBj2SBAATwolMZU0hOFBj ZEqZMDRBS7SoxCdspu6KmUQNEzPpJAaJuElJHaKUwomQEoJQUuHSUgBJnlRDSCpkd0VMPJJPGqSS n//SzDKcaJjqU8qg3Vj7tVGFPhMdEUIi1RghG2piEbUiA7JOMKcKO3SUlIoUYRNZSInROtDE8KJA RXtJUHNhIFRDEBQLlMtUCE4IKplJpMEJGI0TMO0wihBYIKgjXDWUFTDZgO6koSSRQqEydJJSykJC ZIJKSB0p5lCIhNJRQnBTIJcUpKSkwKlKr7in3FJSaU8qvvKW8pKTylKBuKW9JTYJSCF65iDCh6iS mxKUwq/qpeoipsApKv6if1EFJvNPKBvKYOKSk5clKDvKW8hJSaUpQd5S9QpKTykq/qJeqkpsJblX Fif1UVNjcU8qt6qQsSU2JSlVy8pbikpPr3Tyq+4p95SU2N0JpQN5S3lJScuSlV/US9WElNiU8wq3 qphYkptSUpVb1Uhakpsykq/qJbylamwClKr7ylvKSmxMJgUDeUt5StTYmeeElX3kJvVSU2ZlKZVb 1UvWStTaSJVX1im9ZJTalOqnqealuJStTZnt4JpQCfBNuKVqT7ktyr7ilJStTZmeE5I7qpuKYvSt TbkJSFS9RL1Slam6HBLcqe8pvUKVqbm4JbgqnqJwZStTaDgm3Kuklam210qTzohUhEfwleimsUyd MmpUlwkkkpSSUpklLojEOESoiYKIQydUSFXLCFtYzBExIQLWN3HRPMUAucLHt4Kf1bPFWSweCW1v gm0lq+pZ4lL1LPEq1sHgkKx4JUq2oXP8U8v8SreweCRYPBKlW1A5/iU3u8SrmzvCQE6QlSrakPPi m2v81c2wOE4b5JUppbXHxS2uV0N8kg0+CVKaWxyfY4q5tPgmA7pUpqem5L0yrpBGuij56JUpqek5 L0XK5q7iEh4aJUpp+kSnNJ5VmT4gJ58wjSmr6B5S9A+CtlzQORKjuA7hClNf0D3SGOSjk+LhqkSB +clSkHoEpfZyjbm+KbcPFJSP0CkaFPe3xTb2+KSmPoJjSpF7fFS9Rm2O6SkfpJNraD7uEi9qReEF LFgnThNsCcuamLgkpbaAngJpCaQkpeAm0S3BKQkpWiWiQITSkpdNKUp9ySlSkCluTbklMpSlNvTb 0lKJTSnLpTbklLFMpSlKSmTEnJgYU9HIJRAJwYTxCZJCWqN2quYJh5HYqiOQrNB22g+KcEHZtUiH OYoV6gsRbfbcD4qEbbT5qRazbAaCeQVZcYc13iqjG6kKyPfUO0IoSNJa5LqIhm7upFuoKtCht7Q2 zhI7JG7j9MoORc0N1A1JXZN9oAVfHxaqBFTYVmFVJtnA6oXHUjuokSJStEP+KmBAhBeyr92gUXD7 1Kh2w+ad5D9QEaQs0pP01Q2kjRHeJCCWM6SotEJMEaJ+dAkpfdu0TifkmZA0UhykpcSk106JFICE FMXGCkk4Skip/9POa2UnNjhTboEzgqDdRxKkRomDD2TwTyipafFMVIwdExEIIYRKRYpgJpEwipHE jyS2hSOmihrMIqZFkcKDhKK5shQjWEEonMQ3SrLh2UNkp4K0hrRCaO6O5uuqg+vwTgUUiuEiQq0K 8xkiFB9GuifGYGjHKBOrUSRnVHshFjgpAWMghikmIcE3uRQySChqkHFJSXlRUmmUklMUoTwlCSlJ lKE0JKWhJOmISUpRcpJolJChQ7buI0SFRUi94G2dFGXFFS+xNsTElKSkpk2gvIA5KNl9NvxAHWNI B7oAe4ahaL+o3ZFPpWOloThVINuaNVJLbCSYlSSSSSVkinShJC1dLrZ2iYS9PtGqdpczVphNJ5SU r0im9MlKSlJRUo1FW2dIyLK/VY2W+SqSVfw+o30DY1xDSnCuqDfRoAFpg8hSRLoc8u5kyhpqVJFP KSCVQkUkklMWtL3bRyU7sdzTtOhTgEGRyk7c4yZKSFegQl6aaHJHcipl6RKNi9MtyyRUJIVeXIuP kW47t1ZIKIrqpDdRZjvLLAWuHZSGoVrMuOSQ95lyrIFQWSTpIJWSTpklMXnRSbQS3cmSIKSmQokT IT+ghwUoKKEnoJNxdx5AQ9U/uSU6OZ0KzHpF4cHN7ws1h01Vmu9+0tc4x4IKJrooArJJ4hMmpUlK SSSlnJq6w4wTATwlCSlem2YlP6bfFR2J/TIRQv6bfFMK2+KbYU4rSU6eBgYuQx3qWbXjhZtlXpPL QZA7p2DaZU3ncZRJFKpHEJwE8SnDSmpS1BSs+ikzQKDw53wRtVIiEk5qKdtBKbaaYwlCkaCl9nKV hVMUyI3GKkcRw1KXEFcJQykifZT3UvshCXEE8JYtuezRroTnJeeSnOOQl9mlHj8UcJY+u7xS9Z51 lS+ymYRDhjshxhPAUPqu8U3qu8UU4kJ/siXGFcBQ+q7xSNrvFG+yxyofZ0uNXAUfqnxS9V3Yooxp EpDHCXGFcJQmw+KXqHxRjRCQoHCXGFcBQ+p5pvUPirBo7BP9nCXGrgLW9TzKW6FZ9AIn2cQhxhPA Wlu+KUq4KAU/oNQ9wK4C0d3xS3K8MYKDqoPCPGFcBahcmlXfSS9IJcauAtKU+7yVp1YnRTbUEuMK 4Gnr4JtfBaXpCFA0gFN9xPttCD4Ja+CvmsBRNYhL3Fe2WhB8E+vgrZan2DwTuNHA04cmhyvFgIUA xLjVwNXa5Ntcrhao7UuJXA1tjkthVuBCjsS4lcDV2FLYVaITObCXErga2wp/SKPBUy3RLiUItYVF P6SO0Jy1DiTwtf0Sl6SshSgFDiVwtT0kvSVqITER8UeJXA1vSS9FHhOAlxK4Wt6SfYjlNtR4kcKL 0lIVhEhSaJQtIiEfphSbUjQpNammS7hDTtrhAIWjeyWrPI1UkTYY5CiuDojg8HlVwjMBLE4LHTvl 7Wv7hCyNIdKlV+lx47hRI31SpVi7TD57FWqfcHNVUmQHKzU6LJ7EIqK7Z2g+Cv47vFUhq4gqxjOH ASU7VR9qMDIkKvjnRHbwQqpFFsDZDc3cQ7unJIKd/mouMoJX1HCdpTgpNSUp2iIDIQyNyk3QJJUR CbjVPMpn6pKWedNERqG0HuptdrCSGXdROpUjymJQSpwgSknPCSKH/9SmBqoWHVO066prWSqLcZNG iY8SpM+il20SSwbxJUXGUYGQhl2kJIWA0UQ3UqYEjVINSUjcJKjGsjlTDNVIN1RUvtlRIjlGMAqB MlBSEDxSeBOiLt0USyOEbUiLEhWiklIDulakGyDopvrlTB14U3CUCpqurjVQNatFpKi5ndPBQ0nV gqBr7K9slD9GNU7iW8IaXpE/JRNSv+mkavFHjRwOdthPsKuejqm9HxTuNHA0iwqMOWhsA5Cf0x4I 8aPbc/a5LY5XxWOE5p8EvcCuBz9rk20lXxV4qfpgnhD3Fe25rmEKGq0bWDshekE4TBWmDVG5KHK4 KwE7a0uJXA09pTlrlfNQ4SNKHGngc7VOZV30JOid2PBhHjCOAtEApbSVf+ykBL0QAUuMJ4C55BCU lXTTJS9LTVLjCOAtESn1VttQlSNPglxhXAWlJTwVbNYKkypLiCuAtKHJQ5XjSh+mQdQkJgq4GpJS Eq76IOvZS+zgiQlxhXAWhDk8HlXRRqk6mEuMK4C0NU8FW/QlO2ofNHiCuAtPVLVW3VQUvS0S4lcB avuSlyuClOaSOyHGE8BafuUocrba5RG0ABDjCuBz9rk0uWk+iB5oYplITCjBo+4pocr/AKOsJfZ5 KPGFcBaEOSIIWh6IUXVBLjCuAtDVPDlbFSf0UuMI4C09rktrloCkDlM6h0bo9qHGngaAa5Ptcrld UogokpcYVwNDa6JUTuWi/HDBqh+giJhRg0g1xT7XLR9DRRFQ8EONXttDa5RAcTC0jSIQhT7tUhMK MC09rk4YVbdVBU216JGYUINEsKYMJV819lD0u4S4wrgaordwn9JyusrRfSBQ9xPtud6TueyY1OWl 6YUH1gCUhkVwOeKyVL0Srwq04RRWAOEjkUIOeKCjspgaq6GaJFngmmZK7gAazWT2UvTVljY1KnEp vEV1BplgISY1reysFsKJA4hDiKqRbQUtg7aIoaowZ4StNI2c6qZCKytO5kJWprR3UmndqiEDvynD ANUrUif8FGIVgNHKjYwIhSKN3CNI8EzQJhEDQEipEW91A6cI7hAUSAmqREJnNRNvyTQR2RUwAAUS BKNE9lHYTwlamMSmDe5Tu0GqYFFS5gKMeKm4feoBpSUoNU3SkzQojhKCkbWwExZqiFoUeErUxOmh SIUy0cpbdElI4gSouGiIdEx8kVI9spw3VMTPCIxFTMcIUaop0UdoPCYlgUwCIdFFqKkRalCI5R4C NopYeCGiwoEdzwiCorQmKICCmStFI40SDdFKYBSaIRtDAhItMIhATO4RBVSM8eakOEw5TkkaolCh ypx3UY7lTATSUhiB2TgKRCUQhaaWLZ4QiDKsRoo8ogqKNwnlKCpuSDUrRSItSjVELNUiIRtVMIMq QCcBSEIWqlBEYotbqphvZNSu9ktKybBBWzy2FkXCHFSYyx5GARqTrCAnDtplTMLpYbw0OadApNe1 oIJWb6hKkGudqU7iRTfdewt2hFZYHxHIWfU2HahdN03HreNWhOjqtkaaYaC6Wp6va5aN+K0cD7lm XWGp0AJ9Ugau7jP0VnzWbi2BwEcrRmAq0xqzxOiG8ncE44T2aie6eUxexYfdCdujpTO0MhO7lFTI lTBQokQpN0QSqYMJz4qJ0KnIKSmJKn8EOJKIkpW7SSm0mU54TcpKZghJDaIKSSH/1aRalEqR8FFr YVJuMo0ScCW6JyIUhqIQ2Uja2FF3mioQElFTJvCY6lTHCYt8EFIzoYKcKTgAPNRbzokpmW7lEhFD UOJMIJYnhSbxqmgjskJOiKFhwm5T7fFO0JymIbrKM+vRCfI4Rw4lolNKQ1y6EpR9soThCK1hCiWb hPZFiEP3H4JKU1oCdzZKnW0jkJyBMhJKAsjhKAUfaO6eAdQkprlgKWwEQEfaEwajakPpqIYrEFMW RqlakQqJUH17QrW0tEqvrZyNEArZrgSYUw1EDNuoU2gd04oa/pzynDCOysOb9ydrSfglakYq01UQ 0zAVr041BQHAtMpWpGWlqeIUgNxSeDPkipTdNErA0fS7+CmGxr2TO80FIDBMNT+lOkopY0apAQkp B6Oqm6vsjAeKdzUt1Nb0vFHYwAKZYFCwg+0BDdSB5O6fzVKAjNqBGuig1paY7I2pgWH5JvTEaI5b u+CQYG6BK1IvS2jVMWzyjO9wgoTGH5IJYBnulSLSNUYVg/FJ9YGiNoa+1zlIMU2tIThpJStTDZ3U gwkSibfPVOwEIJRsrlEbXCcaFECBKkBaHaBOKgpbSDJUwJCKEBrgyk4CYKKayTIUhVuGuiSmvEBD DJ7K3cwACNVBrmjjlFTW9NTawKzoeVE1iZlJSBrI54UsmwvaGtiFNzW8ofpd5SBUiY6NAjMdCiGI gHgkSpG/3GEthGhTtknhGLt7YI1SUh2SfJO+qOFIGNDypjXlK1IuygWBHePBL00EtcgDRS2QNFJ7 IKns0SUiawP4S9MDRGY0DRSLQTKVqQtYG9knNB7Ig15TBp1lJSJI8IpZPCcsHzSQ1teCptJlENeo UnMRtS06Jg6dER1Y2wkxmiSlAgpSibZQXyDARUu4qBKkGFINnlNKmMlMSE72E8KJHZEKZscpP1Q2 MPdScw+KCmDvaQnL4TbT3UgySipYv7KTW7vgpAa6odjolrEgFLAAFSDteFGthIgohbGiRUxc/doo yQpemRqFE6lBSpnVRkqY0Tkd0lMCU+6ExBTEFFTB/uKZzY1CKD5KJHiiFLCSlEJyFAt7pKSNHdOD Ketu0JiNpQSxgyUiNFMieExHYpIX1hJwlOPBMgpERqkRI0Uw1IwAipCGqTdOE8aJohFTPWEo7qTd Qm+CaliRKYs1U+2qQOqSkb2pnN0U4kpiOyKUYEaFMSpA6wmcitYBoUjpqpAJEfclaqRHVOOFKJTB uhRUwPiokIgiE2iIQUe3VF2qLolTAJSJQAsWpNlEIMKESguZlqYthTAkJneSClNTNGqkIHKPEt0R CC1XNPKcIwbKhtSKmHKZwRY8FF48UAUsA1PsJ0CmBoiDhK0MGtga8qQCX0SixOqCWDRqsvMZD1tB sKhnM1lPgaKyQsOWdFDlEeJMBSayFOwLMbHKJujhMkkpkCeUavLtr+i4hASRBIU6NfVrm/SMorM1 tx92hWSnGhlO4yqg9RhGHacFbJAI0WB0Ww26nst8KKRtdEI3QAogypWt0lC41QXpCZ0UiJCGHImp QUsyJhSnWFCANU41SUyhIt8E5mEmmUlMS7boE7EiAEg7XRJLKUzUmjVSISUo6pJhokkh/9au0btO 6Zo117KAOim2YVKtG4p57BM0QEp1UiglZ3CDPYIzxohNGsIjRCSEgk5JqCVntkJ2MTOdBhTYDyl0 QyJQ3GCpGZUSEks2ugfFJoAUNPFRDoRKF40JKgzU+Sm4wE1YIM9kQpT+EVoICEQZR3iAECoLBB1c 5FSaElFGU0IjolRHKSl+AhiyD4qRHKiIARQrfu7KRbITHyUgYSSuG6QEh4JwQOE2p1QUojsEzGE8 qeg1KrutM6cJeSUtr9uigwSoaH4qVY2lEBDJ7NYUQJMdkayxrmkRLjG10/zf+l/4z1UOISQsGJ9k BSACYydSglixgGqRAJhTrduCE5pD0aQsGJwxEdoEo2iSeUVIXAnvonaAQpFoIUGx2QUudNExhThI tDdCkpQbPKlBKb0/BLcRxqUksnRHmg+nOpKTmb/ceycFGqQtJCQdrqn7ykYeNdEFJNwIgBQLgOeU 4G0acoervpcpUlkGzwnaA0yk0RqphwKRUoM3anRV3E7oVomRohenBlAKVUx7tY0RAwpA9gpzCSlm tDUok6Jmt3EyiNbqkpZtRKIaYEojRoo2OICVKYbWx5JNcwDxCA6TzwmYZ4TkJfW2iAFEO3c8pwBG qcjaNEEoXgnlCbyrJ81AVS6UlLAQmDST4I5YnhBSAsnsnNRGqd7odAU3HaNUVIts9lONNFKfbKi2 AYQUjc3apEaKT2yUwE6BEFSzB6g81NrI07pmANGqJIPCRKgg2uBgogaE5cewTRJQSxc2U/pz3SJk +KKBISQhDNVMVlIAkqNhLTCCWJZBU4gKA041UoJCKEZd4J5lRIhSDfBFS8JFOKrDxx5pOrc0wUKU yJAbBUmkRKgfCJTlscJKZgoVg1TjdKZ4lG1KKcDxUI2p3OhBTF3koEpnudPkmeE6kNhroCedZCi0 aQUj7eAgli7UpwJCiCXGFCXNKKF3GRona2U7SDykZA0SUyaNFMT4aIYf7ZUw/SUErnVRhs6Jw+UN yVIVAmEtsapmu7py4cJUpZ0DVI6pO0EpJKYO0S5GiUKIYfkipTjCaSpwe6jACKkjdQnOqfZomFcJ qlwIUXqXZQhJTHcnkJABSLRGqKliYUdFKAQo86JBTGd3CaNE4G0peScplWAQpbYUa9OEXb4phKUJ GkpgpuTbfkkpiTqmI1SdynI1SUjMCVHlEcwzKgQnBDJoULBqiN0Ci/XhAbpYzpCYKUeKTo5RQx2e KYtCcu10UZRCCyhOJOiTQU+reEClnGigAp8piEFKAAamGoUwNFAN2lFSQNBRWkEQFFogILnRoERu htMYSmdUU+O+dFZc3SU+gsstEtgqTmyjOAJ05Q3iNFGdCvRhuimBAUmhE2yEClrd9VYaNEzmDlTY 3TlJC7WSgZlO9qsAQilkhEGlF5p1e1RWj1CjYZAhZ0KeJsMMhSydJPCctWSCdMkpdJPwrOBgvzXh o+h+8gTSnZ6BWRWXHudFvNCBXjtoDWt4CscJi8I7EGSeUV6hs7opUNUUIYCkCkVKKk1QJkqbSglk BKfhMClKSmD5UBIRSVAoqZsMKXCGNDqiOQUxSSKSKn//16cQUV4gKIEFSf4FUm4jM8qYKQCZ4gJK WcZ4UGGHIgGkqDTJSUldHdDaTKI5u4KO2OUFMXAIrD4ILW6o9Q1SSFHXyUDCm8xwhapIW7pOEJwN ZSfrCKlOghTBAaoNCfThK1MK3bnK07xVZgh3krbuEJJCI8KMGFIglLaYRtTAABPMpAdlINhC1Uxg 902zxU3kMEnsosvDhwlqqlhWkGxyo/aJ0U2Wh41S1Uu1ilIaqtlhnRCL3eKIieqrbF9k6BAnbqVE bnKQGmupTqrRavE6qXKTdBClHdIqZNIiO/dOW+BUW6lSaY0CCVTHCHuJ50Ui4fNNIPZJSzdNU9kO iFGdupGiX09UUM94Y2DyhEnxRHEEacoYHikpcOkQUogaKbW7gkPJBS1b3AiRKNY1jhunVQEpWNB0 RtVMW3CICg4A8Jm1lszwk0JbKVuIEEpxI7JQHg+Sl6ZA0KSlmmFLc2ONU4ZA11TPhw9qCkbpA+KZ jieVJm78/ROIJRUuYnRO3lSiE2zzTbSp3tUQC5M9p7KVcoqZAQigbk22U4B7IKWA1RmBBa0l0K19 FJSxKC7VFLpKG4DmUilC7XRIV7RAUQ4FyMSEkLN807wSoucmOglJTAtIHinpPioB0mE40cipOopi SkYhNUjdAdKg+2TopRuOoUdrWmQnhSRrtwhOQCog90g7wQUvugwnYSVD0y486KLGluiVKS7SCk58 6DRJpIOqZwLtUErgmOdUpQxJRGkjlJDFnKOCVXOhCPPCBSqY5Q3QTrwlYSn2Db5pKYgiYCck/JQA hSmUUKcGgeaQOiiTOiTjtE9kVMzZAhQbZr4pj7hKGwwYhLdTaNg8Etw+aD3gp0FJZUHOB+Khu1SZ rKSmU6JNHikAkTBSUxd7dQmrcXDXUqREpAjgIoSwBqoTKk/X4JmgQklgQQoORA7XhQI1lFCh7VEv nhTfqo7dyCmbRpqlzwpB27RORCCUZMHVMXSpuZITAFFCMNShFjRINSUhGpg8JzI0CnEJnERojakb ZJTmfFPKccaoKYvkjzUB5ovJ1U2sAOn3IqVOii8HxRHEnlBMgoaJUCBpKfQqJTQPiihmGykU27bo kdxKSmMEnRR7+amBCgQe6SlbpUSSDCkRAUQUUM6hrojugINZhEMkppXMH8JDVSs10TQUuiGDxKeJ TuanASUjsaSdFENIRTzKiRqkFLD8U22dUiYKn2SUidookaSpvCgRKcpgBronI0U2iE5StTFhMQkP NJvMJ51IQO6lwk5O1shTcPBJTBpjQqRHdPtlPsRUuBIQjX3VjahhpJhIISY7mt1dwiPukwEANI5R IjhHiVSVrVGxs6KTCSpHRBKIAjQKYgDVPE8J0FMJkKdf3Jy0xAThkIoWLfBHYdEzWqbGIKR34zbe Vj5HTntMtEhdCWypMGicDS0h41zHM5BCjIXZOqZYdQCmGBR3aFJxrOF46Qj04l1xhjCfNde3FpZw 0fcrAbA0AHwS41cLg4X1eLjuyDp+61bzKWUtDWCAFNphM4Sh5ppUqe4IfCnARUxsEhD1RX6BB3QY RUvHcJNaU4UhJGqCloTDQqcaKA5SSyCeY1TEJwJSQs12/tCTm6p51TTqipkeZTkd1FymDI1QSwlJ KNYSSU//0KjTLkQ+4qLGxqniNVSbi5PZQeFLQpIKW4CiDKd3Ep2xCKmQOiYHkJwhnQygFMw08ojT AlCDiiyNqRSs7XVCglGPCYhEIYRCUSJUjoJTxDeZRUwa4a+KjPgpRIQ2nWChSklX0oVkqtSZerLk 2W64Iw2ErHhglIuDVVusL9PBIC1Fk24HU6KDrnHjVMGzp3U2tLQQn0ttEXlyTLCO2iTvBIAgI6IU QZlKJ0UxAEpwe6RUoNgIZbrCKddVDV/CQUVo2uhIAEpbS3jlJviUlLgGY7IrWpMaOUhyUFLEBqcQ Qosr1RywDhBKLZrKiWkHVFkj4KLiYkIoW26IMgHajgmJhBcPdPdJSmmNOyeAfikAQYUxX3SSuPBO 1sKMhphNYZOiCmZGqEZlS3Tp3UCSSiApnzqVJpCgCDCI0AGYSUvtaR4JmiOVIiTPZJxDQgoIbieB wmrZCcOJ4TOMFGlL7dx1TFocfgpgd0i2eNEFMdpGikRAUpjlQc2eEVLBpIRK2Fo1TgQpAHugVKAT 8JajhS27ggpkwAalSfxJTRwne7sj0UgLvBRLtFPbHCg9msBBLDcpkADRQ2galTZBTkKB0UHkk+AR GzOvCcVtdq4pVakQGqcgTKcbZ04T7Z7pUpiHbeUnlSLWnlQd7igpZxAGidrY1CfQ6cJBHZDGeyIx jWj4odscd0hoNUQlQcRp2UmnbPmmADteydrQkSoKAlI6CFKQPgoPPgmpWa3WVMCULcQiNKRQwcId qjtKE7lTZoOEFKc4dlEOKcCeUiQNAklaJOqUQmA1lM8kIhCxaZ8k8SIKQ4SCSlaQnqInzTbRwFJj C3U8JKU4y6FEiFJwI1UdvdJShXJkp9kcFO2fknJSUj5T9k7R3Ts80VItpPdMAZUw7wSbyihcunlM XRxwp7UvSJQSi0PdIypbIKkNeEkIwXA+ScOD3aKcRoVBrJMyipIQB21TDVIjamLY1KCWZKgTCdIp KYSmLjx3Utu3VMTJSQs124Qo7Q3upxCj3SUxJTAwUnQOOEgYRUuTqpNdJUCe4GqKwHbKXRTI6aFO 6E0+KimpURI0UIgqcwm1RtCpTboUgoObKQUrVReYU5I0CiW+KIUseNEMA90UuBbA7IZ01RQzrGqM RqhNcAjQSJTSkIypDUJFojnVJgQSsR4qO1EMKKSmHBTR3UnhDaTwkpY8qehCgRqihsDVFDAjRRLY 4RHCQmOmiVqYNhNtKfuncdEVLBoCRAlJoUiBMhLqpdp0TlqbhTAkeSSloTsEp2iE50lBSnaJw0Sm BlGGhSUjLUg2QpgJcCEgpesEIoG4T2QmjXVGadIRQxaIKTmpEKfpgoqWgbYRWCQhs1RgY4SUvsUg nB0SHCCkgATNGqZo7qYTkMNsOROE+1IxCKFzoEQFBrl3wCM1FTIcpn6cKTtEh7gihHJ5UmPBTx2S a2CihTzoqwklWHt9qA3QoqSNHinmE6ZwhBLAlx07KQEKPwUkkMpU2obeURqSVo1USPcpOKiRwUlM njRKsp3athRaI0SUzcUlGCkgp//REdQot0CcjSFASFSbiXkKBCcHWE7hCSkTtW6J2tgapu4ARHGC gpgdOE2h5UlEpKWgDVWGjRAkBWAZCRSxcJTHRSdxoopBTCzXRP5BSIkpi0I2hiRCi4fek7lM86Iq XrkGSrG4FUw6NExtgoGNpuklzwTooNbJlO1u7Upw6NAiFpWOhUp7nRO9+4zGqibD9EjVOpShDjCg 4wn3uadp+SfcCY4KCkbDKmDOhTgAcJ2cpKWEhO0d05OqkPAJJRWQXAKTSOAn0JMiUzRtRKEjONEw k/BNv2qTSHjVBKtoA0OqZrjOqk4ABBa3afJNU2HO0hCJ0804eCm5RQwcT8k4EapHVIRMJKZMZBlT d5KO8zCJ2SSjLQ4GVHsp6wh2EE+CSEcSVMtLP70wYQpNaRyUVLA+CMAOyiBOicAhApX7oF53HyRX kRBQmCOeEAVKYYClM88pFs8J2oqZDTlNPinBPdIhBTGwHlRDtvKI4QhCXFFSVhJEhTa48KLRtEJ2 CZJ5QUy5RQEIIh4SUie8zCkwbkN4lEYduiSmQbCE+ZR4kII51QSx2D4orRCE7yRdEULbmylIPPCi 5oTN0SBpTB/OidjXRKYySpxBhFS0FMWQiARqoOO5BTENUdZgIrQltEykpA5pJ11KR5RC2NU2jkbU wLtqmHSosAcYIRw1oCCkTHyIKfvBRWsHZDsaNyVqRubrophqQ5UnTKSmJGqkwwSFB59ym3Uygllo huPdGIkaIDmkaJKUx2qdx1lRiCAOVMt7ooX3BQcfBMBHKW2DKSlAQUWUNyYA/JJTNxlODKiXAcpa JKZDQpyZUdTwkZhJKiY4SHBTQeCn+ikEIQNY4VgViNFXdo5GDpCJUzIDQmLj2Qy6dFEkgyEggrud rHdJkgaptmsqDiSdEVJHtBGvKelRiRqlXIQKmweUzgJS3KLyCkleAomE0qBJ7pKZqCcCU3CSl4JT OEKbHqBdu0SQijlSDS7lLhSDoHCSkYbrBR9m0JcqReBoUkojKduqUydE0JKLJwEaJgE/ZJJTGIUX c6KW7xTbZ1SQoFMU0dki2UaUwDYTQeEQeCRbJ0RUjiOeFaYZGiA/iFYpjamlSzglGqcmTAUgmpYF CdyjkDuhEA8J1KWIQ4gqbgQE2vKClFvulTOqaJTtSUsQovRDoUNwlJTAeSRAISLCnDQnIYiJ1UiY OiY16ymKSFwNUVsnRQa3ups0KRUya2OE8SnKbgoJYM0KOASZQy3VGYCQkhQMFOYTd1NokoqYtgqb RKRbCmwQkpYiCiBRsIU2mRKKltqm0JwQUm6JIZN4hIN0gpxpqotJkohSRqU6pm6HVS0mUVLkSEwE BO1FsLYEcogIYVtIKLCEwlFAhFDKJUgITApSkpYp0xOiYHRFSrOEEiCjO0bKH9JJS54UZTlNqkpf lOAman3AcpIWjVELgFE6pBJK7jKduo1S2p5SUsdEm6mUpT9klLpJkkFP/9IT9FGO5Ujwm7Kk3Fmx Kd5UWgjUpOMoJYthxRXahC41TgykUK1GndMZlF+CjBJRUttk68I0whE6x2RXDRIqDF7kiEiQE6AU jJg6pHXVSKQ1CIUjOpTWcKTZJScipCdOEwBlFDUztDoihidAmBSc6CmAjhJTJhk6qUbnT2UAJMlO 2USpZ4IdKctnVTcJE90MEkwmqX2lO0AfFINMp/zpSSwcQOdE7SZ50TvG5KtqKGQGuqi4nsiOjtoo EhApYjnVEbwkHBFrYBqeElIx4FNa2BypkgaoD/cgortrG2fFJrVOvQJn6BFC7x4Jto5UWvUg+ZRU wD4klOx5OqiyQSIU/ozCKmZdIVdwlSJ7KLq3DlABRStPZO4ymZMKQBKBSs0qReAJKnEoTiCSEFLO cHiQoyI0SawSojV0o0pJW0jVKwx2SkgogcCEFLNmNVIeaiGkayovdOg0SUovT9pjVBDiHbY+aNrE IkUpkyDypQBxqmaNEmuHAQUvJ5ClyEyYOnlJSwEqe0FLUKIOqCkpbtaq51KK8w2UBj5RCWUgFE3Q hEgnVPykhk54UQJSc2OUMmEt1M411RI1lQY7cpOdtISUu8KO0KTzpqhhxCSkkQfJRJS3JxqkpHZO 1M3QaIjxCW726IqQ1aSCjtIiCh1yeUQ8oKZNAAhDedU7jtkoczqglQk8IjfNNunhLdoihgQCUSsB QHMFTaACkpmdAhugoo41Qy4SmpX078piISGphJ40TkLObAlDDJBkogb2UtqSmNbAWnxU6moZcGiB ypMf3RUzcxNAB0TF+uiZxkoUpZ0gmEzTGhTOmdOUjJRUyMQocpGRynnRJTGyvcIT1iBBTE91JnuE hJCzxHCbZCIWp9gSUxJQi0yiWtnhMDA1RClgSNUQaiSowORwpgaIFSgmLZ7KTQnJ0SS15gwpOgKZ aDyFBzeyKF2iEx1Ug7sokd0FMCPJQEgwUaVBxJOiKlFqYeSk3zSIg6JKZDVLYCmrkDzS29yUErlr QkWpogJmkooZxoo8pFspwCipgRqnLtEoBKRbAQUvEjzUBAMJi091PaY0SUwHtKZ09k5jkpOduAAE QkpQ0RKzKHBCNU2DokVLgap5PZIjVSiExcis0UIRXtlRARQxglvCYN0lTJ7KJGiSlpSbyk0FSGiK lTJTOKThBUSZKSliZKQgcpHQpjodEqQu7yUB5okmJTBshJSiFMRwlGkFO1spKZcJ1E6iE4dASUyL dZRFCSVMkBIKWI1lEGiYNnVSZyipb6WiIGkBR+iVMuJSQsQIlO1ImQnkASipkxSJhM2BqixISQs0 zonBUWqTAkpjEKZOiYhKSQnIZtEqXpl3CavhS1BRG6irbtOqmYT26pmp1IZMGmqUwotM6KRagpju lM3XRNEFSboipewgNQGu18kZwBCDs1SUlkJiocIgEhJSzSpOA7pNScDKSlaJyJTOUmlBSjoonlSU dySloKJGignBkJKZ8JKIMpJKf//TBvLjEJ3u2/BPHdMRKptxjOiQA7pvmnjRBTLRQI7KQ4lMUFLs M6JCZlNW2JKkNdUQpeJKk6ODyotOuqM5wcIhDdSLamHgpE+KZpkykpeNIUToFM66qDtAnKRMcQU5 1KWnCi5JTPsoOEqRIjVNuBHmkpg9oUg0BR2ydVPgooUAEkgEzhOoQKlzxKGHEnVEbqm2wUkrkmY7 IYmSEXjVMPEpWpcN0UuyYHSEpQUw50KfaPgl5hKCdUUMSD2Uy6BCkGAobgQ7RJLEOiQm3eCJBOhQ yNhSClxITk9ik0btVElKlKFfulFa3XRDDj8lH1HNPCKGRkOlEaJTA7hqFBxjgoJVA3GCpOBIgaqG 0E6ojW7e+iKGABjTREqfubHdKCUme0oJU523QocmYU3PDjKRCAUu1kiUw5TTOkJN92qKme2VHjRO HmYUwPFBSMtHIUd0hFeYGirw4nQJBSQP0Tzu1CZ7NYSYwhFSQSAnadYhSABSAIKClnA9goTHZGLo 5UYlJSmwQm2lS2wnjxQSwJ0hCc1FeRMKDvBFCwgp944TCG6qYr7pKYPdKg2TypPICk3XRFS40TFs mU8BvOicOBGnKClrXHRNGiZ7e55TSSOUVLhk6JoNY9qk1juZTE9klMXFxCcN0807jpKYv0mEkM5D U29DJDjOqnHBCCVPcIhQDUR4nnlQa6DCIUoFLaZUpSGhSQuGqTTJTT2USPBNXJCQQgPIYU8k/FOW h/KICFw6TKnMqOwdlIEJKWOikoOIUgDHkkpYNnnhSsrAGmiYABEIkapBSJg0lImeCiDQQmIEIqRu BS1CnE8qRrkaJBCP6QUSNNE48EnAcJKR7d2hVloDWgBBDPBFHEJKY8u1UiYMKJ0MqLyQdNUVLvmd UwYCm2klSiOElKgNUtwQiNx2o/ptAQUxlRSLw0wVIHckpgVAyOER2g80INPKKmLgeVJroGqkPNQ2 EmUlL8lSgKIGiQ10SUu6AoEg6FTfHblRISUkEAJQHapDQJi5ClLN1JnspQoTCeHHhFTI+CiBCRBn VKNUlKB1UjCi4J2NhJTFxCYTKk5oUdOySlizxSBlO7hJrYSUs4qbDqmICkwCUipK5sFKNFM6pJqU MKPCIZ7KDm6pKYgE69k8KbRPCaAOUFIyAEo1lShO4cIqWICZ40lSDSUwB7pKQuOqaZKsFsqG0BG0 MQdPgmCkJOint0hJSPbonraURogJVlJSw5TbfbJU2jVO6ElKr9zZCfT5pm8aJnN3BFCSp2pRBoUB jdpRiYMJKZkSpkSFATCJXwkpTRonDZCTdU4BIhKlMmjRPqnaISOqKGI0KIwKDYmERuiKld0w1lMH aqQbGqIQV2DVEgqDCicoqUNeVIaJuCnlK0MRIKmHJkiNUVLuUW8pykAipRCgCpkaIXBSUu4JwYCT ikkpbdCmDKYNCfhBS7ik0qMynCSl3FJoTHVOxFTLbKQEFIHVJBSoCSUpJKf/1BO8kwXGJKmG49jp KkuMSQU9mI2qPguOSSKntEwXGJJBT2rPpKWsriEkEvbWIbe/iuNSSQ9u2Y1ULeFxaSeh62uNxnlK zlckkgp6oJx5LlEklPXMnupLj0klPXjkpx3hcekkl69nkpfnLjkkCp7F0SnMLjUklPY6JOn5Ljkk QovXiEV8bQuLSQU9n281D8q49JFT2T/LlCP8pckkl1Q9eZj2oYiPcuUSRCnrtIUWROq5NJBT1rlA xPmuVSSCnqzCR40XKJJJeupmFKyZ81x6SJU9cNql20XHpIKevYpCZ14XHJIKez+CkPJcUkkp7FyH SuSSTkPXa7kVcYkgVPasUiuISQS9o7zTsXFJIqe3eouXFJIKeydym8VxySQU9Zp3R2caLjEkVPX9 ypNiFxySKHsnbdJ5Um8ri0k1L2lnmoO481xySSHshMaph3XHJJBL2PbVRbC5BJFT2rdqgfJcakkp 6/X85LT5rkEklPXs5TuiVx6SCnsjzqpaLi0kFPY6dkhC45JFT2Q5Td1xySSnstFMcLikklPY6dlP VcWkkp7bso9lxaSSnszPZEG6FxCScEF7JndJ8aeK41JJT2SL7ZXEJIFT2dvKiIXHJIqezKjp25XH JJKevZ9NGMz3hcUkgp7J8TqnC4xJHop7Huk5cckkp6/SdEj5LkEklF69kd1J0LjkkFPWnamrhcmk nFT1xTs291yCSap7B0d0guPSSU9g3unELjkklPZO8lHVceknKexMd1DTsuRSSU9ekVyCSSnrkhM6 LkUkFPbMlOfNcQkmpe1Q3eS45JIqexCg/wA1yKSQU9gISdK49JJD2TOEy45JBL2JlMeFx6SIU9U3 du04RTuXIJIqewExqk3lcekkVPZHnRIrjUkOinsBKIJjVcWkih7YQpO81w6SKHu2oreF5+kkp9AZ 5JxyvPkkVPooThecpJIfRO+ik1ecpJyn0UI3bVeaJJKfSq4lTXmSSSH1BM5eYJIqfUBwl2Xl6SKH 08cqYXlqSKn1EoJ5XmiSSn0wzCbVeaJJKfTBPZSK8xSSU+nJ15gkgVPqHfVOvLkklPqA5UivLUkl PqSS8tSSU//Z /9j/4AAQSkZJRgABAgEASABIAAD/4SAxRXhpZgAASUkqAAgAAAAMAA4BAgAgAAAAngAAAA8BAgAW AAAAvgAAABABAgAMAAAA1AAAABIBAwABAAAAAQAAABoBBQABAAAA4AAAABsBBQABAAAA6AAAACgB AwABAAAAAgAAADEBAgAbAAAA8AAAADIBAgAUAAAACwEAABMCAwABAAAAAgAAAKXEBwCyAgAAHwEA AGmHBAABAAAA1AMAAFgGAABPTFlNUFVTIERJR0lUQUwgQ0FNRVJBICAgICAgICAgAE9MWU1QVVMg SU1BR0lORyBDT1JQLgBDNTVaLEM1NTAwWgBIAAAAAQAAAEgAAAABAAAAQWRvYmUgUGhvdG9zaG9w IENTIFdpbmRvd3MAMjAwNzoxMjowOSAwODoyNjo0NQBQcmludElNADAzMDAAACUAAQAUABQAAgAB AAAAAwDuAAAABwAAAAAACAAAAAAACQAAAAAACgAAAAAACwA2AQAADAAAAAAADQAAAAAADgBOAQAA EABeAQAAIABSAgAAAAEDAAAAAQH/AAAAAgGDAAAAAwGDAAAABAGDAAAABQGDAAAABgGDAAAABwGA gIAAEAGAAAAAAAIAAAAABwIAAAAACAIAAAAACQIAAAAACgIAAAAACwJ2AgAADQIAAAAAIAKOAgAA AAMDAAAAAQP/AAAAAgODAAAAAwODAAAABgODAAAAEAOAAAAAAAQAAAAACREAABAnAAALDwAAECcA AJcFAAAQJwAAsAgAABAnAAABHAAAECcAAF4CAAAQJwAAiwAAABAnAADLAwAAECcAAOUbAAAQJwAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAF BQUAAABAQICAwMD//wAAQECAgMDA//8AAEBAgIDAwP//AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAFBQUAAABAQICAwMD//wAAQECAgMDA//8AAEBAgIDAwP//AAAAAAAgAJqCBQABAAAAWgUAAJ2C BQABAAAAYgUAACKIAwABAAAABQAAACeIAwABAAAAfQAAAACQBwAEAAAAMDIyMQOQAgAUAAAAagUA AASQAgAUAAAAfgUAAAGRBwAEAAAAAQIDAAKRBQABAAAAkgUAAASSCgABAAAAmgUAAAWSBQABAAAA ogUAAAeSAwABAAAABQAAAAiSAwABAAAAAAAAAAmSAwABAAAAEAAAAAqSBQABAAAAqgUAAIaSBwB9 AAAAsgUAAACgBwAEAAAAMDEwMAGgAwABAAAAAQAAAAKgBAABAAAA+AUAAAOgBAABAAAAwAYAAAWg BAABAAAAOAYAAACjBwABAAAAAwAAAAGjBwABAAAAAQAAAAGkAwABAAAAAAAAAAKkAwABAAAAAAAA AAOkAwABAAAAAAAAAASkBQABAAAALwYAAAakAwABAAAAAAAAAAekAwABAAAAAQAAAAikAwABAAAA AAAAAAmkAwABAAAAAAAAAAqkAwABAAAAAAAAAAAAAAAKAAAA+gAAABwAAAAKAAAAMjAwNzowNzox MCAxNzo1NDozNwAyMDA3OjA3OjEwIDE3OjU0OjM3AAUAAAABAAAAAAAAAAoAAAApAQAAZAAAAE8A AAAKAAAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAAAAAAZAAAAAACAAEAAgAEAAAAUjk4AAIABwAEAAAAMDEwMAAAAAAA AAYAAwEDAAEAAAAGAAAAGgEFAAEAAACmBgAAGwEFAAEAAACuBgAAKAEDAAEAAAACAAAAAQIEAAEA AAC2BgAAAgIEAAEAAABzGQAAAAAAAEgAAAABAAAASAAAAAEAAAD/2P/gABBKRklGAAECAQBIAEgA AP/tAAxBZG9iZV9DTQAB/+4ADkFkb2JlAGSAAAAAAf/bAIQADAgICAkIDAkJDBELCgsRFQ8MDA8V GBMTFRMTGBEMDAwMDAwRDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAENCwsNDg0QDg4QFA4O DhQUDg4ODhQRDAwMDAwREQwMDAwMDBEMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgA oACNAwEiAAIRAQMRAf/dAAQACf/EAT8AAAEFAQEBAQEBAAAAAAAAAAMAAQIEBQYHCAkKCwEAAQUB AQEBAQEAAAAAAAAAAQACAwQFBgcICQoLEAABBAEDAgQCBQcGCAUDDDMBAAIRAwQhEjEFQVFhEyJx gTIGFJGhsUIjJBVSwWIzNHKC0UMHJZJT8OHxY3M1FqKygyZEk1RkRcKjdDYX0lXiZfKzhMPTdePz RieUpIW0lcTU5PSltcXV5fVWZnaGlqa2xtbm9jdHV2d3h5ent8fX5/cRAAICAQIEBAMEBQYHBwYF NQEAAhEDITESBEFRYXEiEwUygZEUobFCI8FS0fAzJGLhcoKSQ1MVY3M08SUGFqKygwcmNcLSRJNU oxdkRVU2dGXi8rOEw9N14/NGlKSFtJXE1OT0pbXF1eX1VmZ2hpamtsbW5vYnN0dXZ3eHl6e3x//a AAwDAQACEQMRAD8A9TlKUAWD+Cl6g8UaW2kJTHVR3JF4SpVvPfXmWdDNrfpMyKXA+MOXP5hD+n04 N2Ntuhtoy3u3PNZMsbHu+m3+X9Bb/wBebGDoRLzDDkUB58AXry/qfWc+zPswjYW4+D+r1Nb7XEN1 /Sv+m/6SIJAIHUsc4cRHk6zsvOZjHFrveMXcXCgmWTM7tqlj3WMtYWRvdDROo9xhYjch+3QnTQkf 7VU6p1bIxfSbTscLGu3lzZ4Om391PO2uzHHCf3npPrL0/OqfRh3MrxrGDe9wkueCT73a+1GycK7p GVg/bXbq5rsaCd3sDm7lwn7dz5ne0/Fs/wDVJN691Bs7XM4ge0aJvEN6LL7ZqrfUf8Z3S+rdYwsO 3pjvXx6nF1lDHgbtw/R2Ru92xZ31W6V1Xpn1ey6+qH067X76MZzg4saB+lfE+xr1yfT852Ri+tkF ofuc0bQG6Daf4psu2ot5aY44JRFbrtdnqPqq8WYLQ2Cyq8hgIkEOcQ3/AKpSdX6ORZX3Y8gntr4f csv6k5Vn2+/D3A1PrNlVZ1AsaWOJbu/4Lf8A5i3+rUirqlrW6McNzGnmJDv+l6ijLJD5QOzTItB0 mAtf6qlw6qZ71n8CFgZGZZSdg4Wn9T8p9nWw2w81u4+ScCNFkg7n1tLxm0u0G6rT5FYG/v38Vv8A 1x/n8Rw5cxw/Fc9tPEj4KKXzjzDPH+b+hf/Q9AZcdNunjypi88LJGSJmZAnQEa/DncpDK9wAmBMg /fzH0VOYsVur6476Ty0pesDrPgs0ZOjZniSDH9b81I5AdJ+lqPj212/9+TeFNuf9eLgPq+57iCBk 4xI7RvleTfWi8/8AODPe2Nl9vrMLeC2wNsb/ANEr0v67Wer9Xcrb+a+pw10gF/B/srzLrrW2Y2Da 0S+H1OI5IBDq2/8ASeo5b0uHRzftJmVpdByGO6mHPqxLgK3ezqDXPpn2ydtbq3ept/m1o9F+oGdn Btudc3CqOuwDfaR/VllbP89dVif4tvq1WAbn5N7vE2tYPurq/wC/qjl+IYIExGQmf9QcfD/3LKMc j008XPbmYnfE+rYP7ow7XH/z8pfaK3Ca8L6vO8hgP/jYukp+pH1TpEsx3if+7N347XtSv+pn1UcC 40PnxGRfP42OUJ547+5P/Fh+XEn2x+6HyXqt4/aWTtrpr/SOMYzdlIJ1Ior/ADKv3GKn6s8hem5v 1A+rL2n0m30uJ+m27dP/AG7W9cv1f6i34odZg3eu0f4N4Ad/nt/8gpsXxHl5kR4jGW3rHDqg45Do 1Pqfc8ddxmsO11jizd4BzXBzoXofX9ozMKyJdbUGz5bB7P8AoLzf6os3fWLDrPtm0NPY8Oa7+r7V 6Z9atjB0uxo2y6tru+rmPH/UbFc6FEXmeosJyAPEgfetD6qNdV9Y62OGpY8R8RuSsqaOoYriPb61 e4niN7RqtY4teL9dqvROhaJ+JYRH/RSjVA3+lEfaie5HgS3/AK3kAYjyN0hw/IudlvMa+HZdF9cR NGKYmHOn7lzX5s9kzJ/Ox84skP5k+Un/0dum17yTpprqZiPzQB+aiMuOzX3RyfuAd/5DeswWOe1w dqwmZOh3HwbP7qNXc4E6EE+6R2J+T/zVZYqdEZB1PBHIOmpn6Gu5yYvMbtznajziNfaqQsYyZMgD 2mDBHy3p/XggBxIB0Dv+/NQKmv8AWW4u6FmAfyXRJOsWBv0vpLhunCuzJwvXgsrte/3cSG+z/pLt OvS/oeWRBEAaRIcGvP0dy4npxfk9Sw8doAAucTHG0NdKp8z8uX+4f+jJlhvHze8x8olg9NpVht+S 7tCljVVV1j2mOxhXaram/wCDB+K5SRjxVdeNNxqNOSUnfaf9ZWi/qDWtDdjWk6ggTAH5zv8AvqjX 1H1GuAYHgmJIGkf1VP7MODj9w0dqjJFm64XJusyQILdAs3LyXtY7e06910N1zSNWiFk54ofW4RBB 1gzEjuoschfdc8D0x1I+uDHcVutJMeJb7l6R9dnt/ZuHaAG+nbjxt8Hk7f8ANp9Jea4dbKfrexlm tfqO1HgWO2r0P653Od9XQ54aCw4hG3+Ud7f82ldTirgj19EGqdz5yaOe1prkD5p+kZNtvWse+9xf Y9/vceTpCV7g+gRwRyhdMcGdRxiDBFjdVCJHjiP6w/NfMaE+D0f1ue77HQWmIsP5Fyu4/S3H4Lpv rc4nBq7xaNfkuU3ieO0wp8v89Hzj+aIfzJ8pP//SIHSS06hwJ7xHP0RuaptdoHTEcgiTrxud+9oq DLiQWlzpEAgCNB/5ki1uc4wZHHBMn83cpuJbToO3MJJhoGgaOSR+fomDjA2nUQNTwJ3NVLfGoMdm jk6w2dsqYkj3ESOXHidfFK0Ux6u5v7KyQDo7a0AxwQ9cv0Bu3rdI4j1NP7K6DqLi7CyQeWsP37Ss HoUDrFJmIc9sj+qqfNH0Zv8AZ/skyY94+bqWW5+LldR6rXY+mnGfdQ6+x3qVOLzTVjU0Yr3MYx2O 5+/1LX/Z0sPrHWeo2VYgz31T9ta6+ptZc4Y7W31S6lvpbv8AB+tR/wBbXR4Rxbq7W1Mbs9axlzXN EOtBAuc5rv5z3fnKu/6zYuPdVVewUVWZN2K651jNrPs7WPdc/wBLdt3+pt9N2y1iw45+O4x5cZJw FRkRHijGOP0+mcZcfD65tgxr9KgXEu6v1R+FjPccg5hwi9rvc1rnF1jRZ6dVNn2m7ZtdZ9p9On9H /wAKjNzusVdWxnMNz3Xux2uoLLWey1tfrOqZtsxXUsd7rLHvZ/1v9ItrL+tGJj3YWy1t2JmPtZbl h5DajSGbi5u07/ptRj9Yun/YsrMxLq82vEbvvra4hwEj3Dds/wDM/wCb9RWYczLigPu4x45GUYyP yQ9zJwerhx/qvXBYYjX1WXmTmdbszG4jc7Ja67JFOXc6v202m3IqprxmOb6foXYTKsjayx9f/CKh j9czH/p7H01uyG0HJvsZG8sqsDabHVN3epk+m/0n7f8Ai1293UcRtdpfktDcYsZkOMtDHWhrqWun 6Pq+oxZmZn9Mvc6j7Tj2WtftNTnMLg9pgDY//CMf9FQ/eBxZInlREXw6Aemjxf5v/Z8K/h2PG8aD XV9cazY2aw87h3jY4LtPrTc8/VnJbdG8NxHNI7kne0H+pQVxcsZ9b6XWtD2b/e0+Ba5pXUfWS1// ADezWWgBzmY72geJIcxv8nZS5bOD+bh/s4MR6+ZZuu3UN2/uhAwbXDqGOf8AhW/lTV2bsdkfuhLG cBlVHv6jfyqKRqY0/SSdY/R6j61f0BpI4sGi5OPdweOV1f1ne1mBucZhzZK5P7S3ncI4VjL/AD0P 8H/pKx/zMvI/k//Tzq7RBj6XHlHgpizTb2HEfFDDNNZHnKcDx1HknWVJDfYSRIM6gc8qP2ixsgHj gfFPshniO/8AsUXNgawPwEjsjqhhbYX12scZa+pwhUOjsnqDHOEFj5+9u1XXbTXkAagUu+J9p/O/ kqv0rcM4B30twJnzAVXmv5vN/sz+U10Pmj/edqjO6pg5GVj0dJuy2vyrL67muaysstLXj3Ob9JiD Z0TqZsbk1Y1Npxep5GQzGuLdt9F/p/pnGXN3bmP/AEdn/fFvU/RWPdkdYp61l20MyL6qm2+lQBYa nTj0/ZNHN+yOZ9u3/wAw/wC17/U9T9AxYGDNIykccYQlwmUzIz/W8Ppr5/Rx8f6LZlEdbOqV3Seo 5uR0i+/p+PiVYV9xycWssdX6T217H7B7LXvc13qMRMroNp6nl5WPi1fZLenmkUjbW2zID22Ussrb s/ROcyr1X/6NV8Pp3UHXYNOc3LP2e26vItN7y2yoVevhWW2Y9gpe5uRY6n2fT9P07VLM6dlU41oo ZkOceoBzQX3XRiNY4Vu9Ku9lttXrOt/R+rW/+b9b9Gp8UpDIP1kQMcCRQMsVSzSlD/K8U/1nq/2S 0ixsdT9flRdS6P12119FYpto6oMR+bkvdtey6gM+0WtrH876769/tas7O6HaWXWHEYbn39Qs3+wv LbGF/TH7wd39I+g3/B/4RaF2F1Wx+5hyaKrGsYwg2Ndt349F77KbrLvS/QZGZ9n9/rsfj3erZ+hp Wlmah0DTsEMnM5McomMoni9R4QYy1xxj+s9XzcHB/wCFpEAeheEtIH1upNg3AkbgfNrty3OvvI6H lNfy6upzf+jtH/bSxMgf9llEiQe39l61Otuno+SD+4wgn4gD/orYwH9Xj/2cGM/peZTUkmhgH7o/ IpUAjIrPg9p/FQxj+gZ8B+REYSLGnwI/Ko8pqf1UPl+j1P1jDndPeNJlpB7Lk9rtsbRu8V1nXRvw XiIENkLmPQZujcrGY/rsfmP+krH/ADM/r/0X/9TPqcCO3tEideFI2kHjgkggePfRVhYB/FSFsdpR tJCZz9p4k9jwfw9qE62GwDpHHx4UDbuBA0nnsgPcB8R+VK0U2ayHl7SR7mOb94I/ghYJb+2n1s1g tA+IDdyjg+7K2jux35Cnwa7mdec8RAaQ3TvA7f1dyg5jWGXxxn/u0w+aPm9lRW7QGBJjQg94WTi/ WO+7Ctzn4Xp4rKrLarG3C0uNTxVZVbRWxtlNn+EatSl8bDGre3PmeViH6sX20PqtzWSaraWWV1bH u9V4s3Zr/U/WvQb7Mev2ekufxw5WE5DPZHor59jxSl/N/wDU2zIzIHD4ulgdZdkW5NOTXXiOxW1v 9Zl7Lai22djXXjayu72/zLk2T1Kz9t04mPk1Pa41utrO302Yxb/PPu/R78292z7JTT6v6L/Bfnpf szpWHZkvuGPT0/MFTDh2BjKfVrn9KGvIpdba3+Qi5eDh5FT8KhmOy1rGMJa1nqVVO9n6PaPUr347 bK8V/wCYlHLi9UQPRIAx4o8ePHLg4Z/znuerjn/6Gqjp3CB/WB+zcnL3syMqseqMVpG9rbXbOnYz 66/cz1K3Uf56iMhmViU5Nf0b622NHcbhJb/Yd7EC3pp6jlW3k1VdPt2bLMV8+uxl32uvZs2uxbNz NmVkMtt9eyqr0vT9NExsNuDitxGPL663PNe7lrHudY2rdLt/p7/5xNkMR1BJyynxEfuwlHWN/vQm uF/Snjc07frRjk8SPxDlo9YP+SMgH9xsH5ws7qkN+s2MTwSJ+B3BaHVyf2Xkg6/oxHy0W/y/83j/ ALkWA/peZT45/QM/qj8iI1xDgRyCCPkULH/mWf1R+REA1UWY+v6qjs9Z1m204Bl+5zmgkxouZ93l u/BdB1ez9Q8IrC5r7QYiFZz/AM9j8x/0lYv5qfkf+i//1cQ688pTp5eKXfwBUT/qU1kKideUN+og /epyhuKKwssUluQ7XiqyI8mn6KHg25H27HD3l2+33E6Eja6P+pUscxcdf8HZ/wBS74IWIXjLxCR7 fV0I4+jYouY/m8v+zP8A6kVH5o/3nuKSNjY8P4o7SqFrnfZwGuNZc+theww4B9jGP2O12v2uRW4Z 125WSDBibdJ8/YuWmATZNa1/ity2n9YvsBDRls9Kx1NjMfOspOTVW5xaLcf7M3d+sZDP5q5zP+LV LJbn4nTen5mJi2V5ORgnpl1Alz6y9s4N9k/6Gzfv3/zXqemq7+u9Ur6fk5Re+p9LmCtv2gkuY520 v2V+pY5m19P6T+Zs9b+dVe76y9QZg42S24ufki0O232EA1vazUMa1zW7f5z/ALd/m1o4uXzCMIgR mIzMSDPihL0Snw/3f0/n/nP+qMRlGydtOz19dFeLjVYtX83jsbUz4MGyf7W1V7eVVqtqzc7KxxfZ FAbLasp07pcx/wChY4ObX7Wf1P7aY0tx8oMY60i2p5cLbH2asdUGuHrOft/nH/RVOEOHIOMnj+c2 N7/Wb2yXppts8l12G/WXFniWT8yVc6oT+zcgHX9HoqP1gIH1hxHHxbP+crnUT/k/IBn6Gn3roeXN wxn+r/3TAf0vNtUn9G34BTnVBrPsb8ApE6qHN831VHZ6frD46cJG0emD5rlvUZO6T4yuk6wf8nNP jUNfkuSlu3fOnirWb+dxnxH5qxfzU/I/k//Wwo0SKbcRwef4pifNNZCo+EQoOUj4KDkVhVU6Ltw0 9j5/zHKtiX2uz8RpHsFo184ejsBLxAkkO0/suUKTFmKOf04OvmHqPN8mX/Z/9+ofNHzetvdtw3PJ ADHMcXHQCLGHc793YsXFy+rnp+a0ZL3ZHoVfZRZbW47vUb7Wne/da6j1vtSnf1DqlHULKanObjua DW4MDgD6NrnHc5pb/Svs6hZ1e+m99TnYdj923dbQxoAIp2+q9v8AWvfczZ+j2er/AEb0ViYsUxGu GE+PhzC/VoOGXD8v+OzykL3Ir0tzpFua7NotyrrGN9XZduexjSwVXOZU/Z9PFY9mLsZ/N+pZZX/p FRY/qlVtrX2WV0h1jqRU5rYY62vd6PpbGsu+x/afR9T/ANB/0yLi9XfdlU4voYjvUdUx9/2dgAc+ 3HxrWbN7v01Xr2/R/RfQ9Kz01Z6b1EW5mBiX04znZdN1j310MZteyy6uhjY3/SrxL3/+cJ0uOBlM 441wj09o4/cycQ/wUCjQs7uVfk9V3v25PpMlxY5+RUyzaXMdU211drd72112eo7+Z/SfQVzo9rnt dudve31C47/UAa/7P6LTd6l+7+af+fv9n+E/nrHyOtZVbsiut9Nb23PZSwNpa7bXZk1bRq5z/wCY o3eoz7R/ov52hV8zJ6rYWnGyb8qlwMPDQwOaaqHseytjG7d77LPzk+QnOPDw48f9YGXb+6oUDdku V9Y4HXMNx49s/wCcrOe79RvB19un3qp9YDt6n08kOEBujzLuW6Pd+c/99Wc7+iWt8hH3rR5b+ax/ 3f8Aulst5ebaafaEioNOmiRDio8u6hs9J1gx0tkf6L+C5Wf0e2O3C6jqfu6dWO5rA1XPeh7Y7+Ks 5j+sx+YVi/m5+Rf/1+fDh8PBMXBC3jgH4pbkGQpC5QJUS5pbM++fo+I8VAuKK0hNS4C9p/rD72uV apwFtBnQX/k3J3Elrg3R0aFUupe6ltVZkbnl5Hb81rU2UeISH70eH/pf98tOhHgbe/xXHYBrH3qy A0kSBIO4EgSDGzdqPpbPZ/UXmGN1jrWHDaMl20cMd7v+qlamD9bPrPflUYdLK7r8ixtVTC3bue87 GN3l7GN9x/OWHk+EZ7JhKEvrwtgZo9be9ZTQ0NDaqxtjbDGiIjbthvt27Wp9lbdWsYI1BDQIjdx/ 25Z/25YsVzP8ZNX0uiB39V7Hf+e7XJg3/GO/QdGDf6z2N/6u1qj/ANF82eg/xgn3sfd13MY2XNY0 OJkuDQCT+9MKpkl0HUrnOvdT+uvSLKquoUVYrsgOdU1rq7SQwgP/AJi23b9L85YF/U+v5ell9m09 mjaP+gApcfwnPfrlGP8Azig5o9LLf+sl1f7SxAHBzqnDeBrALhEo2Wd2K/wIbH3hYDMeyuwPukah xLufEH3Lbe8Ow57O2x/nBbGLF7cIxu+EVbFxWSe7aFjRypi1niqNr9SoB2vKjyYeLW0CVPY9QcDg VR+4NPksPeOI1WnmvIwKiRHsGqx/VbEz357p+b+cx/Rkxfzc/q//0ORL/HRPuIMHQ+CDvMafcn3z r+RJfaXd5pi4oe8+KfcS2YMdz2/kpKtkXTW8d9v8Vl5NpGQ7aRtmGkacLQY6d08bTIWPduFr9fzn fDlJaW5XmXMqkfAzrof/ADJByr7bWtEAua4OHw/8iqzbLOAZ7Qm9a1p0MfDRK1tNkX5UkiljT30j n5pxbluOjGadkD7Tktja5wI414lRfmZL5D3l06ao34lVNhmTkeqSQ0ENAlrY4Jdu9se7VT+1ZDg6 XEwJ1J76eKo+tZETpym9SzseELTSe173RJLo+iTzr7lqB23EDPNo/ELFYXF7ZMmQtawxS0eLm/lQ KR1SWOkpg7UIbnJgfcECh7DKsBwqT4MWZ+gngeK0M2z9TpkbYYsuRPIUWb+cx/Rmx/zc/q//2f/t H3pQaG90b3Nob3AgMy4wADhCSU0EBAAAAAAAKxwCAAACAAIcAngAH09MWU1QVVMgRElHSVRBTCBD QU1FUkEgICAgICAgICAAOEJJTQQlAAAAAAAQWMX84Ry3tmd+2WtqRYOAOjhCSU0D7QAAAAAAEABI AAAAAQABAEgAAAABAAE4QklNBCYAAAAAAA4AAAAAAAAAAAAAP4AAADhCSU0EDQAAAAAABAAAAB44 QklNBBkAAAAAAAQAAAAeOEJJTQPzAAAAAAAJAAAAAAAAAAABADhCSU0ECgAAAAAAAQAAOEJJTScQ AAAAAAAKAAEAAAAAAAAAAjhCSU0D9QAAAAAASAAvZmYAAQBsZmYABgAAAAAAAQAvZmYAAQChmZoA BgAAAAAAAQAyAAAAAQBaAAAABgAAAAAAAQA1AAAAAQAtAAAABgAAAAAAAThCSU0D+AAAAAAAcAAA /////////////////////////////wPoAAAAAP////////////////////////////8D6AAAAAD/ ////////////////////////////A+gAAAAA/////////////////////////////wPoAAA4QklN BAgAAAAAABAAAAABAAACQAAAAkAAAAAAOEJJTQQeAAAAAAAEAAAAADhCSU0EGgAAAAADRQAAAAYA AAAAAAAAAAAABsAAAAX4AAAACABQADcAMQAwADAAMAAwADMAAAABAAAAAAAAAAAAAAAAAAAAAAAA AAEAAAAAAAAAAAAABfgAAAbAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAEAAA AAEAAAAAAABudWxsAAAAAgAAAAZib3VuZHNPYmpjAAAAAQAAAAAAAFJjdDEAAAAEAAAAAFRvcCBs b25nAAAAAAAAAABMZWZ0bG9uZwAAAAAAAAAAQnRvbWxvbmcAAAbAAAAAAFJnaHRsb25nAAAF+AAA AAZzbGljZXNWbExzAAAAAU9iamMAAAABAAAAAAAFc2xpY2UAAAASAAAAB3NsaWNlSURsb25nAAAA AAAAAAdncm91cElEbG9uZwAAAAAAAAAGb3JpZ2luZW51bQAAAAxFU2xpY2VPcmlnaW4AAAANYXV0 b0dlbmVyYXRlZAAAAABUeXBlZW51bQAAAApFU2xpY2VUeXBlAAAAAEltZyAAAAAGYm91bmRzT2Jq YwAAAAEAAAAAAABSY3QxAAAABAAAAABUb3AgbG9uZwAAAAAAAAAATGVmdGxvbmcAAAAAAAAAAEJ0 b21sb25nAAAGwAAAAABSZ2h0bG9uZwAABfgAAAADdXJsVEVYVAAAAAEAAAAAAABudWxsVEVYVAAA AAEAAAAAAABNc2dlVEVYVAAAAAEAAAAAAAZhbHRUYWdURVhUAAAAAQAAAAAADmNlbGxUZXh0SXNI VE1MYm9vbAEAAAAIY2VsbFRleHRURVhUAAAAAQAAAAAACWhvcnpBbGlnbmVudW0AAAAPRVNsaWNl SG9yekFsaWduAAAAB2RlZmF1bHQAAAAJdmVydEFsaWduZW51bQAAAA9FU2xpY2VWZXJ0QWxpZ24A AAAHZGVmYXVsdAAAAAtiZ0NvbG9yVHlwZWVudW0AAAARRVNsaWNlQkdDb2xvclR5cGUAAAAATm9u ZQAAAAl0b3BPdXRzZXRsb25nAAAAAAAAAApsZWZ0T3V0c2V0bG9uZwAAAAAAAAAMYm90dG9tT3V0 c2V0bG9uZwAAAAAAAAALcmlnaHRPdXRzZXRsb25nAAAAAAA4QklNBCgAAAAAAAwAAAABP/AAAAAA AAA4QklNBBQAAAAAAAQAAAABOEJJTQQMAAAAABmPAAAAAQAAAI0AAACgAAABqAABCQAAABlzABgA Af/Y/+AAEEpGSUYAAQIBAEgASAAA/+0ADEFkb2JlX0NNAAH/7gAOQWRvYmUAZIAAAAAB/9sAhAAM CAgICQgMCQkMEQsKCxEVDwwMDxUYExMVExMYEQwMDAwMDBEMDAwMDAwMDAwMDAwMDAwMDAwMDAwM DAwMDAwMAQ0LCw0ODRAODhAUDg4OFBQODg4OFBEMDAwMDBERDAwMDAwMEQwMDAwMDAwMDAwMDAwM DAwMDAwMDAwMDAwMDAz/wAARCACgAI0DASIAAhEBAxEB/90ABAAJ/8QBPwAAAQUBAQEBAQEAAAAA AAAAAwABAgQFBgcICQoLAQABBQEBAQEBAQAAAAAAAAABAAIDBAUGBwgJCgsQAAEEAQMCBAIFBwYI BQMMMwEAAhEDBCESMQVBUWETInGBMgYUkaGxQiMkFVLBYjM0coLRQwclklPw4fFjczUWorKDJkST VGRFwqN0NhfSVeJl8rOEw9N14/NGJ5SkhbSVxNTk9KW1xdXl9VZmdoaWprbG1ub2N0dXZ3eHl6e3 x9fn9xEAAgIBAgQEAwQFBgcHBgU1AQACEQMhMRIEQVFhcSITBTKBkRShsUIjwVLR8DMkYuFygpJD UxVjczTxJQYWorKDByY1wtJEk1SjF2RFVTZ0ZeLys4TD03Xj80aUpIW0lcTU5PSltcXV5fVWZnaG lqa2xtbm9ic3R1dnd4eXp7fH/9oADAMBAAIRAxEAPwD1OUpQBYP4KXqDxRpbaQlMdVHckXhKlW89 9eZZ0M2t+kzIpcD4w5c/mEP6fTg3Y226G2jLe7c81kyxse76bf5f0Fv/AF5sYOhEvMMORQHnwBev L+p9Zz7M+zCNhbj4P6vU1vtcQ3X9K/6b/pIgkAgdSxzhxEeTrOy85mMcWu94xdxcKCZZMzu2qWPd Yy1hZG90NE6j3GFiNyH7dCdNCR/tVTqnVsjF9JtOxwsa7eXNng6bf3U87a7MccJ/eek+svT86p9G HcyvGsYN73CS54JPvdr7UbJwrukZWD9tdurmuxoJ3ewObuXCft3Pmd7T8Wz/ANUk3r3UGztcziB7 Rom8Q3osvtmqt9R/xndL6t1jCw7emO9fHqcXWUMeBu3D9HZG73bFnfVbpXVemfV7Lr6ofTrtfvox nODixoH6V8T7GvXJ9PznZGL62QWh+5zRtAboNp/imy7ai3lpjjglEVuu12eo+qrxZgtDYLKryGAi QQ5xDf8AqlJ1fo5FlfdjyCe2vh9yy/qTlWfb78PcDU+s2VVnUCxpY4lu7/gt/wDmLf6tSKuqWtbo xw3MaeYkO/6XqKMskPlA7NMi0HSYC1/qqXDqpnvWfwIWBkZllJ2Dhaf1Pyn2dbDbDzW7j5JwI0WS DufW0vGbS7QbqtPkVgb+/fxW/wDXH+fxHDlzHD8Vz208SPgopfOPMM8f5v6F/9D0Blx026ePKmLz wskZImZkCdARr8OdykMr3ACYEyD9/MfRU5ixW6vrjvpPLSl6wOs+CzRk6NmeJIMf1vzUjkB0n6Wo +PbXb/35N4U25/14uA+r7nuIIGTjEjtG+V5N9aLz/wA4M97Y2X2+swt4LbA2xv8A0SvS/rtZ6v1d ytv5r6nDXSAX8H+yvMuutbZjYNrRL4fU4jkgEOrb/wBJ6jlvS4dHN+0mZWl0HIY7qYc+rEuArd7O oNc+mfbJ21urd6m3+bWj0X6gZ2cG251zcKo67AN9pH9WWVs/z11WJ/i2+rVYBufk3u8Ta1g+6ur/ AL+qOX4hggTEZCZ/1Bx8P/csoxyPTTxc9uZid8T6tg/ujDtcf/Pyl9orcJrwvq87yGA/+Ni6Sn6k fVOkSzHeJ/7s3fjte1K/6mfVRwLjQ+fEZF8/jY5Qnnjv7k/8WH5cSfbH7ofJeq3j9pZO2umv9I4x jN2UgnUiiv8AMq/cYqfqzyF6bm/UD6svafSbfS4n6bbt0/8Abtb1y/V/qLfih1mDd67R/g3gB3+e 3/yCmxfEeXmRHiMZbescOqDjkOjU+p9zx13Gaw7XWOLN3gHNcHOheh9f2jMwrIl1tQbPlsHs/wCg vN/qizd9YsOs+2bQ09jw5rv6vtXpn1q2MHS7GjbLq2u76uY8f9RsVzoUReZ6iwnIA8SB960Pqo11 X1jrY4aljxHxG5Kypo6hiuI9vrV7ieI3tGq1ji14v12q9E6Fon4lhEf9FKNUDf6UR9qJ7keBLf8A reQBiPI3SHD8i52W8xr4dl0X1xE0YpiYc6fuXNfmz2TMn87HziyQ/mT5Sf/R26bXvJOmmupmI/NA H5qIy47NfdHJ+4B3/kN6zBY57XB2rCZk6HcfBs/uo1dzgToQT7pHYn5P/NVlip0RkHU8Ecg6amfo a7nJi8xu3OdqPOI19qpCxjJkyAPaYMEfLen9eCAHEgHQO/781Aqa/wBZbi7oWYB/JdEk6xYG/S+k uG6cK7MnC9eCyu17/dxIb7P+ku069L+h5ZEEQBpEhwa8/R3LienF+T1LDx2gAC5xMcbQ10qnzPy5 f7h/6MmWG8fN7zHyiWD02lWG35Lu0KWNVVXWPaY7GFdqtqb/AIMH4rlJGPFV1403Go05JSd9p/1l aL+oNa0N2NaTqCBMAfnO/wC+qNfUfUa4BgeCYkgaR/VU/sw4OP3DR2qMkWbrhcm6zJAgt0CzcvJe 1jt7Tr3XQ3XNI1aIWTnih9bhEEHWDMSO6ixyF91zwPTHUj64MdxW60kx4lvuXpH12e39m4doAb6d uPG3weTt/wA2n0l5rh1sp+t7GWa1+o7UeBY7avQ/rnc531dDnhoLDiEbf5R3t/zaV1OKuCPX0Qap 3PnJo57WmuQPmn6Rk229ax773F9j3+9x5OkJXuD6BHBHKF0xwZ1HGIMEWN1UIkeOI/rD818xoT4P R/W57vsdBaYiw/kXK7j9Lcfgum+tzicGrvFo1+S5TeJ47TCny/z0fOP5oh/Mnyk//9IgdJLTqHAn vEc/RG5qm12gdMRyCJOvG5372ioMuJBaXOkQCAI0H/mSLW5zjBkccEyfzdym4ltOg7cwkmGgaBo5 JH5+iYOMDadRA1PAnc1Ut8agx2aOTrDZ2ypiSPcRI5ceJ18UrRTHq7m/srJAOjtrQDHBD1y/QG7e t0jiPU0/sroOouLsLJB5aw/ftKwehQOsUmYhz2yP6qp80fRm/wBn+yTJj3j5upZbn4uV1Hqtdj6a cZ91Dr7HepU4vNNWNTRivcxjHY7n7/Utf9nSw+sdZ6jZViDPfVP21rr6m1lzhjtbfVLqW+lu/wAH 61H/AFtdHhHFurtbUxuz1rGXNc0Q60EC5zmu/nPd+cq7/rNi491VV7BRVZk3YrrnWM2s+ztY91z/ AEt23f6m303bLWLDjn47jHlxknAVGREeKMY4/T6Zxlx8Prm2DGv0qBcS7q/VH4WM9xyDmHCL2u9z WucXWNFnp1U2fabtm11n2n06f0f/AAqM3O6xV1bGcw3Pde7Ha6gstZ7LW1+s6pm2zFdSx3usse9n /W/0i2sv60YmPdhbLW3YmY+1luWHkNqNIZuLm7Tv+m1GP1i6f9iyszEurza8Ru++triHASPcN2z/ AMz/AJv1FZhzMuKA+7jHjkZRjI/JD3MnB6uHH+q9cFhiNfVZeZOZ1uzMbiNzslrrskU5dzq/bTab ciqmvGY5vp+hdhMqyNrLH1/8IqGP1zMf+nsfTW7IbQcm+xkbyyqwNpsdU3d6mT6b/Sft/wCLXb3d RxG12l+S0NxixmQ4y0MdaGupa6fo+r6jFmZmf0y9zqPtOPZa1+01OcwuD2mANj/8Ix/0VD94HFki eVERfDoB6aPF/m/9nwr+HY8bxoNdX1xrNjZrDzuHeNjgu0+tNzz9Wclt0bw3Ec0juSd7Qf6lBXFy xn1vpda0PZv97T4FrmldR9ZLX/8AN7NZaAHOZjvaB4khzG/ydlLls4P5uH+zgxHr5lm67dQ3b+6E DBtcOoY5/wCFb+VNXZux2R+6EsZwGVUe/qN/KopGpjT9JJ1j9HqPrV/QGkjiwaLk493B45XV/Wd7 WYG5xmHNkrk/tLedwjhWMv8APQ/wf+krH/My8j+T/9POrtEGPpceUeCmLNNvYcR8UMM01kecpwPH UeSdZUkN9hJEgzqBzyo/aLGyAeOB8U+yGeI7/wCxRc2BrA/ASOyOqGFthfXaxxlr6nCFQ6OyeoMc 4QWPn727VddtNeQBqBS74n2n87+Sq/StwzgHfS3AmfMBVea/m83+zP5TXQ+aP952qM7qmDkZWPR0 m7La/Ksvrua5rKyy0tePc5v0mINnROpmxuTVjU2nF6nkZDMa4t230X+n+mcZc3duY/8AR2f98W9T 9FY92R1inrWXbQzIvqqbb6VAFhqdOPT9k0c37I5n27f/ADD/ALXv9T1P0DFgYM0jKRxxhCXCZTMj P9bw+mvn9HHx/otmUR1s6pXdJ6jm5HSL7+n4+JVhX3HJxayx1fpPbXsfsHste9zXeoxEyug2nqeX lY+LV9kt6eaRSNtbbMgPbZSyytuz9E5zKvVf/o1Xw+ndQddg05zcs/Z7bq8i03vLbKhV6+FZbZj2 Cl7m5FjqfZ9P0/TtUszp2VTjWihmQ5x6gHNBfddGI1jhW70q72W21es639H6tb/5v1v0anxSkMg/ WRAxwJFAyxVLNKUP8rxT/Wer/ZLSLGx1P1+VF1Lo/XbXX0Vim2jqgxH5uS9217LqAz7Ra2sfzvrv r3+1qzs7odpZdYcRhuff1Czf7C8tsYX9MfvB3f0j6Df8H/hFoXYXVbH7mHJoqsaxjCDY123fj0Xv spusu9L9BkZn2f3+ux+Pd6tn6GlaWZqHQNOwQyczkxyiYyieL1HhBjLXHGP6z1fNwcH/AIWkQB6F 4S0gfW6k2DcCRuB82u3Lc6+8joeU1/Lq6nN/6O0f9tLEyB/2WUSJB7f2XrU626ej5IP7jCCfiAP+ itjAf1eP/ZwYz+l5lNSSaGAfuj8ilQCMis+D2n8VDGP6BnwH5ERhIsafAj8qjymp/VQ+X6PU/WMO d0940mWkHsuT2u2xtG7xXWddG/BeIgQ2QuY9Bm6NysZj+ux+Y/6Ssf8AMz+v/Rf/1M+pwI7e0SJ1 4UjaQeOCSCB499FWFgH8VIWx2lG0kJnP2niT2PB/D2oTrYbAOkcfHhQNu4EDSeeyA9wHxH5UrRTZ rIeXtJHuY5v3gj+CFglv7afWzWC0D4gN3KOD7sraO7HfkKfBruZ15zxEBpDdO8Dt/V3KDmNYZfHG f+7TD5o+b2VFbtAYEmNCD3hZOL9Y77sK3OfhenisqstqsbcLS41PFVlVtFbG2U2f4Rq1KXxsMat7 c+Z5WIfqxfbQ+q3NZJqtpZZXVse71Xizdmv9T9a9Bvsx6/Z6S5/HDlYTkM9keivn2PFKX83/ANTb MjMgcPi6WB1l2Rbk05NdeI7FbW/1mXstqLbZ2NdeNrK7vb/MuTZPUrP23TiY+TU9rjW62s7fTZjF v88+79Hvzb3bPslNPq/ov8F+el+zOlYdmS+4Y9PT8wVMOHYGMp9Wuf0oa8il1trf5CLl4OHkVPwq GY7LWsYwlrWepVU72fo9o9SvfjtsrxX/AJiUcuL1RA9EgDHijx48cuDhn/Oe56uOf/oaqOncIH9Y H7NycvezIyqx6oxWkb2ttds6djPrr9zPUrdR/nqIyGZWJTk1/RvrbY0dxuElv9h3sQLemnqOVbeT VV0+3ZssxXz67GXfa69mza7Fs3M2ZWQy2317KqvS9P00TGw24OK3EY8vrrc817uWse51jat0u3+n v/nE2QxHUEnLKfER+7CUdY3+9Ca4X9KeNzTt+tGOTxI/EOWj1g/5IyAf3GwfnCzuqQ36zYxPBIn4 HcFodXJ/ZeSDr+jEfLRb/L/zeP8AuRYD+l5lPjn9Az+qPyIjXEOBHIII+RQsf+ZZ/VH5EQDVRZj6 /qqOz1nWbbTgGX7nOaCTGi5n3eW78F0HV7P1DwisLmvtBiIVnP8Az2PzH/SVi/mp+R/6L//VxDrz ylOnl4pd/AFRP+pTWQqJ15Q36iD96nKG4orCyxSW5DteKrIjyafooeDbkfbscPeXb7fcToSNro/6 lSxzFx1/wdn/AFLvghYheMvEJHt9XQjj6Nii5j+by/7M/wDqRUfmj/ee4pI2Njw/ijtKoWud9nAa 41lz62F7DDgH2MY/Y7Xa/a5FbhnXblZIMGJt0nz9i5aYBNk1rX+K3Laf1i+wENGWz0rHU2Mx86yk 5NVbnFotx/szd36xkM/mrnM/4tUslufidN6fmYmLZXk5GCemXUCXPrL2zg32T/obN+/f/Nep6arv 671Svp+TlF76n0uYK2/aCS5jnbS/ZX6ljmbX0/pP5mz1v51V7vrL1BmDjZLbi5+SLQ7bfYQDW9rN QxrXNbt/nP8At3+bWji5fMIwiBGYjMxIM+KEvRKfD/d/T+f+c/6oxGUbJ207PX10V4uNVi1fzeOx tTPgwbJ/tbVXt5VWq2rNzsrHF9kUBstqynTulzH/AKFjg5tftZ/U/tpjS3HygxjrSLanlwtsfZqx 1Qa4es5+3+cf9FU4Q4cg4yeP5zY3v9ZvbJemm2zyXXYb9ZcWeJZPzJVzqhP7NyAdf0eio/WAgfWH EcfFs/5yudRP+T8gGfoafeuh5c3DGf6v/dMB/S821Sf0bfgFOdUGs+xvwCkTqoc3zfVUdnp+sPjp wkbR6YPmuW9Rk7pPjK6TrB/yc0+NQ1+S5KW7d86eKtZv53GfEfmrF/NT8j+T/9bCjRIptxHB5/im J801kKj4RCg5SPgoORWFVTou3DT2Pn/Mcq2Jfa7PxGkewWjXzh6OwEvECSQ7T+y5QpMWYo5/Tg6+ Yeo83yZf9n/36h80fN62923Dc8kAMcxxcdAIsYdzv3dixcXL6uen5rRkvdkehV9lFltbju9Rvtad 791rqPW+1Kd/UOqUdQspqc5uO5oNbgwOAPo2ucdzmlv9K+zqFnV76b31Odh2P3bd1tDGgAinb6r2 /wBa99zNn6PZ6v8ARvRWJixTEa4YT4+HML9Wg4ZcPy/47PKQvcivS3OkW5rs2i3KusY31dl257GN LBVc5lT9n08Vj2Yuxn836lllf+kVFj+qVW2tfZZXSHWOpFTmthjra93o+lsay77H9p9H1P8A0H/T IuL1d92VTi+hiO9R1TH3/Z2ABz7cfGtZs3u/TVevb9H9F9D0rPTVnpvURbmYGJfTjOdl03WPfXQx m17LLq6GNjf9KvEvf/5wnS44GUzjjXCPT2jj9zJxD/BQKNCzu5V+T1Xe/bk+kyXFjn5FTLNpcx1T bXV2t3vbXXZ6jv5n9J9BXOj2ue125297fULjv9QBr/s/otN3qX7v5p/5+/2f4T+esfI61lVuyK63 01vbc9lLA2lrttdmTVtGrnP/AJijd6jPtH+i/naFXzMnqthacbJvyqXAw8NDA5pqoex7K2Mbt3vs s/OT5Cc48PDjx/1gZdv7qhQN2S5X1jgdcw3Hj2z/AJys57v1G8HX26feqn1gO3qfTyQ4QG6PMu5b o935z/31Zzv6Ja3yEfetHlv5rH/d/wC6Wy3l5tpp9oSKg06aJEOKjy7qGz0nWDHS2R/ov4LlZ/R7 Y7cLqOp+7p1Y7msDVc96Htjv4qzmP6zH5hWL+bn5F//X58OHw8ExcELeOAfiluQZCkLlAlRLmlsz 75+j4jxUC4orSE1LgL2n+sPva5VqnAW0GdBf+TcncSWuDdHRoVS6l7qW1VmRueXkdvzWtTZR4hIf vR4f+l/3y06EeBt7/FcdgGsferIDSRIEg7gSBIMbN2o+ls9n9ReYY3WOtYcNoyXbRwx3u/6qVqYP 1s+s9+VRh0sruvyLG1VMLdu57zsY3eXsY33H85YeT4RnsmEoS+vC2Bmj1t71lNDQ0NqrG2NsMaIi Nu2G+3btan2Vt1axgjUENAiN3H/bln/blixXM/xk1fS6IHf1Xsd/57tcmDf8Y79B0YN/rPY3/q7W qP8A0XzZ6D/GCfex93XcxjZc1jQ4mS4NAJP70wqmSXQdSuc691P669Isqq6hRViuyA51TWurtJDC A/8AmLbdv0vzlgX9T6/l6WX2bT2aNo/6AClx/Cc9+uUY/wDOKDmj0st/6yXV/tLEAcHOqcN4GsAu ESjZZ3Yr/AhsfeFgMx7K7A+6RqHEu58Qfctt7w7Dns7bH+cFsYsXtwjG74RVsXFZJ7toWNHKmLWe Ko2v1KgHa8qPJh4tbQJU9j1BwOBVH7g0+Sw944jVaea8jAqJEewarH9VsTPfnun5v5zH9GTF/Nz+ r//Q5Ev8dE+4gwdD4IO8xp9yffOv5El9pd3mmLih7z4p9xLZgx3Pb+Skq2RdNbx32/xWXk2kZDtp G2YaRpwtBjp3TxtMhY924Wv1/Od8OUlpbleZcyqR8DOuh/8AMkHKvtta0QC5rg4fD/yKrNss4Bnt Cb1rWnQx8NErW02RflSSKWNPfSOfmnFuW46MZp2QPtOS2NrnAjjXiVF+ZkvkPeXTpqjfiVU2GZOR 6pJDQQ0CWtjgl272x7tVP7VkODpcTAnUnvp4qj61kROnKb1LOx4QtNJ7XvdEkuj6JPOvuWoHbcQM 82j8QsVhcXtkyZC1rDFLR4ub+VApHVJY6SmDtQhucmB9wQKHsMqwHCpPgxZn6CeB4rQzbP1OmRth iy5E8hRZv5zH9GbH/Nz+r//ZADhCSU0EIQAAAAAAUwAAAAEBAAAADwBBAGQAbwBiAGUAIABQAGgA bwB0AG8AcwBoAG8AcAAAABIAQQBkAG8AYgBlACAAUABoAG8AdABvAHMAaABvAHAAIABDAFMAAAAB ADhCSU0EBgAAAAAAB///AAAAAQEA/+Ee5mh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8APD94 cGFja2V0IGJlZ2luPSfvu78nIGlkPSdXNU0wTXBDZWhpSHpyZVN6TlRjemtjOWQnPz4KPHg6eG1w bWV0YSB4bWxuczp4PSdhZG9iZTpuczptZXRhLycgeDp4bXB0az0nWE1QIHRvb2xraXQgMy4wLTI4 LCBmcmFtZXdvcmsgMS42Jz4KPHJkZjpSREYgeG1sbnM6cmRmPSdodHRwOi8vd3d3LnczLm9yZy8x OTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjJyB4bWxuczppWD0naHR0cDovL25zLmFkb2JlLmNvbS9p WC8xLjAvJz4KCiA8cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0ndXVpZDo3MDg0NDAzZi1hNjcz LTExZGMtOTcwZS1mMDU2NWQ3ZWQ1NTInCiAgeG1sbnM6ZXhpZj0naHR0cDovL25zLmFkb2JlLmNv bS9leGlmLzEuMC8nPgogIDxleGlmOkV4cG9zdXJlVGltZT4xMC8yNTA8L2V4aWY6RXhwb3N1cmVU aW1lPgogIDxleGlmOkZOdW1iZXI+MjgvMTA8L2V4aWY6Rk51bWJlcj4KICA8ZXhpZjpFeHBvc3Vy ZVByb2dyYW0+NTwvZXhpZjpFeHBvc3VyZVByb2dyYW0+CiAgPGV4aWY6SVNPU3BlZWRSYXRpbmdz PgogICA8cmRmOlNlcT4KICAgIDxyZGY6bGk+MTI1PC9yZGY6bGk+CiAgIDwvcmRmOlNlcT4KICA8 L2V4aWY6SVNPU3BlZWRSYXRpbmdzPgogIDxleGlmOkV4aWZWZXJzaW9uPjAyMjE8L2V4aWY6RXhp ZlZlcnNpb24+CiAgPGV4aWY6RGF0ZVRpbWVPcmlnaW5hbD4yMDA3LTA3LTEwVDE3OjU0OjM3LTA4 OjAwPC9leGlmOkRhdGVUaW1lT3JpZ2luYWw+CiAgPGV4aWY6RGF0ZVRpbWVEaWdpdGl6ZWQ+MjAw Ny0wNy0xMFQxNzo1NDozNy0wODowMDwvZXhpZjpEYXRlVGltZURpZ2l0aXplZD4KICA8ZXhpZjpD b21wcmVzc2VkQml0c1BlclBpeGVsPjUvMTwvZXhpZjpDb21wcmVzc2VkQml0c1BlclBpeGVsPgog IDxleGlmOkV4cG9zdXJlQmlhc1ZhbHVlPjAvMTA8L2V4aWY6RXhwb3N1cmVCaWFzVmFsdWU+CiAg PGV4aWY6TWF4QXBlcnR1cmVWYWx1ZT4yOTcvMTAwPC9leGlmOk1heEFwZXJ0dXJlVmFsdWU+CiAg PGV4aWY6TWV0ZXJpbmdNb2RlPjU8L2V4aWY6TWV0ZXJpbmdNb2RlPgogIDxleGlmOkxpZ2h0U291 cmNlPjA8L2V4aWY6TGlnaHRTb3VyY2U+CiAgPGV4aWY6Rmxhc2ggcmRmOnBhcnNlVHlwZT0nUmVz b3VyY2UnPgogICA8ZXhpZjpGaXJlZD5GYWxzZTwvZXhpZjpGaXJlZD4KICAgPGV4aWY6UmV0dXJu PjA8L2V4aWY6UmV0dXJuPgogICA8ZXhpZjpNb2RlPjI8L2V4aWY6TW9kZT4KICAgPGV4aWY6RnVu Y3Rpb24+RmFsc2U8L2V4aWY6RnVuY3Rpb24+CiAgIDxleGlmOlJlZEV5ZU1vZGU+RmFsc2U8L2V4 aWY6UmVkRXllTW9kZT4KICA8L2V4aWY6Rmxhc2g+CiAgPGV4aWY6Rm9jYWxMZW5ndGg+NzkvMTA8 L2V4aWY6Rm9jYWxMZW5ndGg+CiAgPGV4aWY6Rmxhc2hwaXhWZXJzaW9uPjAxMDA8L2V4aWY6Rmxh c2hwaXhWZXJzaW9uPgogIDxleGlmOkNvbG9yU3BhY2U+MTwvZXhpZjpDb2xvclNwYWNlPgogIDxl eGlmOlBpeGVsWERpbWVuc2lvbj4xNTI4PC9leGlmOlBpeGVsWERpbWVuc2lvbj4KICA8ZXhpZjpQ aXhlbFlEaW1lbnNpb24+MTcyODwvZXhpZjpQaXhlbFlEaW1lbnNpb24+CiAgPGV4aWY6RmlsZVNv dXJjZT4zPC9leGlmOkZpbGVTb3VyY2U+CiAgPGV4aWY6U2NlbmVUeXBlPjE8L2V4aWY6U2NlbmVU eXBlPgogIDxleGlmOkN1c3RvbVJlbmRlcmVkPjA8L2V4aWY6Q3VzdG9tUmVuZGVyZWQ+CiAgPGV4 aWY6RXhwb3N1cmVNb2RlPjA8L2V4aWY6RXhwb3N1cmVNb2RlPgogIDxleGlmOldoaXRlQmFsYW5j ZT4wPC9leGlmOldoaXRlQmFsYW5jZT4KICA8ZXhpZjpEaWdpdGFsWm9vbVJhdGlvPjAvMTAwPC9l eGlmOkRpZ2l0YWxab29tUmF0aW8+CiAgPGV4aWY6U2NlbmVDYXB0dXJlVHlwZT4wPC9leGlmOlNj ZW5lQ2FwdHVyZVR5cGU+CiAgPGV4aWY6R2FpbkNvbnRyb2w+MTwvZXhpZjpHYWluQ29udHJvbD4K ICA8ZXhpZjpDb250cmFzdD4wPC9leGlmOkNvbnRyYXN0PgogIDxleGlmOlNhdHVyYXRpb24+MDwv ZXhpZjpTYXR1cmF0aW9uPgogIDxleGlmOlNoYXJwbmVzcz4wPC9leGlmOlNoYXJwbmVzcz4KIDwv cmRmOkRlc2NyaXB0aW9uPgoKIDxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSd1dWlkOjcwODQ0 MDNmLWE2NzMtMTFkYy05NzBlLWYwNTY1ZDdlZDU1MicKICB4bWxuczpwZGY9J2h0dHA6Ly9ucy5h ZG9iZS5jb20vcGRmLzEuMy8nPgogPC9yZGY6RGVzY3JpcHRpb24+CgogPHJkZjpEZXNjcmlwdGlv biByZGY6YWJvdXQ9J3V1aWQ6NzA4NDQwM2YtYTY3My0xMWRjLTk3MGUtZjA1NjVkN2VkNTUyJwog IHhtbG5zOnBob3Rvc2hvcD0naHR0cDovL25zLmFkb2JlLmNvbS9waG90b3Nob3AvMS4wLyc+CiAg PHBob3Rvc2hvcDpIaXN0b3J5PjwvcGhvdG9zaG9wOkhpc3Rvcnk+CiA8L3JkZjpEZXNjcmlwdGlv bj4KCiA8cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0ndXVpZDo3MDg0NDAzZi1hNjczLTExZGMt OTcwZS1mMDU2NWQ3ZWQ1NTInCiAgeG1sbnM6dGlmZj0naHR0cDovL25zLmFkb2JlLmNvbS90aWZm LzEuMC8nPgogIDx0aWZmOk1ha2U+T0xZTVBVUyBJTUFHSU5HIENPUlAuPC90aWZmOk1ha2U+CiAg PHRpZmY6TW9kZWw+QzU1WixDNTUwMFo8L3RpZmY6TW9kZWw+CiAgPHRpZmY6T3JpZW50YXRpb24+ MTwvdGlmZjpPcmllbnRhdGlvbj4KICA8dGlmZjpYUmVzb2x1dGlvbj43Mi8xPC90aWZmOlhSZXNv bHV0aW9uPgogIDx0aWZmOllSZXNvbHV0aW9uPjcyLzE8L3RpZmY6WVJlc29sdXRpb24+CiAgPHRp ZmY6UmVzb2x1dGlvblVuaXQ+MjwvdGlmZjpSZXNvbHV0aW9uVW5pdD4KICA8dGlmZjpZQ2JDclBv c2l0aW9uaW5nPjI8L3RpZmY6WUNiQ3JQb3NpdGlvbmluZz4KIDwvcmRmOkRlc2NyaXB0aW9uPgoK IDxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSd1dWlkOjcwODQ0MDNmLWE2NzMtMTFkYy05NzBl LWYwNTY1ZDdlZDU1MicKICB4bWxuczp4YXA9J2h0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8n PgogIDx4YXA6Q3JlYXRlRGF0ZT4yMDA3LTEyLTA5VDA4OjI2OjQ1LTA4OjAwPC94YXA6Q3JlYXRl RGF0ZT4KICA8eGFwOk1vZGlmeURhdGU+MjAwNy0xMi0wOVQwODoyNjo0NS0wODowMDwveGFwOk1v ZGlmeURhdGU+CiAgPHhhcDpNZXRhZGF0YURhdGU+MjAwNy0xMi0wOVQwODoyNjo0NS0wODowMDwv eGFwOk1ldGFkYXRhRGF0ZT4KICA8eGFwOkNyZWF0b3JUb29sPkFkb2JlIFBob3Rvc2hvcCBDUyBX aW5kb3dzPC94YXA6Q3JlYXRvclRvb2w+CiA8L3JkZjpEZXNjcmlwdGlvbj4KCiA8cmRmOkRlc2Ny aXB0aW9uIHJkZjphYm91dD0ndXVpZDo3MDg0NDAzZi1hNjczLTExZGMtOTcwZS1mMDU2NWQ3ZWQ1 NTInCiAgeG1sbnM6eGFwTU09J2h0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC9tbS8nPgogIDx4 YXBNTTpEb2N1bWVudElEPmFkb2JlOmRvY2lkOnBob3Rvc2hvcDo3MDg0NDAzZS1hNjczLTExZGMt OTcwZS1mMDU2NWQ3ZWQ1NTI8L3hhcE1NOkRvY3VtZW50SUQ+CiA8L3JkZjpEZXNjcmlwdGlvbj4K CiA8cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0ndXVpZDo3MDg0NDAzZi1hNjczLTExZGMtOTcw ZS1mMDU2NWQ3ZWQ1NTInCiAgeG1sbnM6ZGM9J2h0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8x LjEvJz4KICA8ZGM6Zm9ybWF0PmltYWdlL2pwZWc8L2RjOmZvcm1hdD4KICA8ZGM6ZGVzY3JpcHRp b24+CiAgIDxyZGY6QWx0PgogICAgPHJkZjpsaSB4bWw6bGFuZz0neC1kZWZhdWx0Jz5PTFlNUFVT IERJR0lUQUwgQ0FNRVJBICAgICAgICAgPC9yZGY6bGk+CiAgIDwvcmRmOkFsdD4KICA8L2RjOmRl c2NyaXB0aW9uPgogPC9yZGY6RGVzY3JpcHRpb24+Cgo8L3JkZjpSREY+CjwveDp4bXBtZXRhPgog ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAK ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKPD94cGFja2V0 IGVuZD0ndyc/Pv/iDFhJQ0NfUFJPRklMRQABAQAADEhMaW5vAhAAAG1udHJSR0IgWFlaIAfOAAIA CQAGADEAAGFjc3BNU0ZUAAAAAElFQyBzUkdCAAAAAAAAAAAAAAAAAAD21gABAAAAANMtSFAgIAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEWNwcnQAAAFQAAAA M2Rlc2MAAAGEAAAAbHd0cHQAAAHwAAAAFGJrcHQAAAIEAAAAFHJYWVoAAAIYAAAAFGdYWVoAAAIs AAAAFGJYWVoAAAJAAAAAFGRtbmQAAAJUAAAAcGRtZGQAAALEAAAAiHZ1ZWQAAANMAAAAhnZpZXcA AAPUAAAAJGx1bWkAAAP4AAAAFG1lYXMAAAQMAAAAJHRlY2gAAAQwAAAADHJUUkMAAAQ8AAAIDGdU UkMAAAQ8AAAIDGJUUkMAAAQ8AAAIDHRleHQAAAAAQ29weXJpZ2h0IChjKSAxOTk4IEhld2xldHQt UGFja2FyZCBDb21wYW55AABkZXNjAAAAAAAAABJzUkdCIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAA EnNSR0IgSUVDNjE5NjYtMi4xAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAABYWVogAAAAAAAA81EAAQAAAAEWzFhZWiAAAAAAAAAAAAAAAAAAAAAAWFlaIAAA AAAAAG+iAAA49QAAA5BYWVogAAAAAAAAYpkAALeFAAAY2lhZWiAAAAAAAAAkoAAAD4QAALbPZGVz YwAAAAAAAAAWSUVDIGh0dHA6Ly93d3cuaWVjLmNoAAAAAAAAAAAAAAAWSUVDIGh0dHA6Ly93d3cu aWVjLmNoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGRlc2MA AAAAAAAALklFQyA2MTk2Ni0yLjEgRGVmYXVsdCBSR0IgY29sb3VyIHNwYWNlIC0gc1JHQgAAAAAA AAAAAAAALklFQyA2MTk2Ni0yLjEgRGVmYXVsdCBSR0IgY29sb3VyIHNwYWNlIC0gc1JHQgAAAAAA AAAAAAAAAAAAAAAAAAAAAABkZXNjAAAAAAAAACxSZWZlcmVuY2UgVmlld2luZyBDb25kaXRpb24g aW4gSUVDNjE5NjYtMi4xAAAAAAAAAAAAAAAsUmVmZXJlbmNlIFZpZXdpbmcgQ29uZGl0aW9uIGlu IElFQzYxOTY2LTIuMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAdmlldwAAAAAAE6T+ABRfLgAQ zxQAA+3MAAQTCwADXJ4AAAABWFlaIAAAAAAATAlWAFAAAABXH+dtZWFzAAAAAAAAAAEAAAAAAAAA AAAAAAAAAAAAAAACjwAAAAJzaWcgAAAAAENSVCBjdXJ2AAAAAAAABAAAAAAFAAoADwAUABkAHgAj ACgALQAyADcAOwBAAEUASgBPAFQAWQBeAGMAaABtAHIAdwB8AIEAhgCLAJAAlQCaAJ8ApACpAK4A sgC3ALwAwQDGAMsA0ADVANsA4ADlAOsA8AD2APsBAQEHAQ0BEwEZAR8BJQErATIBOAE+AUUBTAFS AVkBYAFnAW4BdQF8AYMBiwGSAZoBoQGpAbEBuQHBAckB0QHZAeEB6QHyAfoCAwIMAhQCHQImAi8C OAJBAksCVAJdAmcCcQJ6AoQCjgKYAqICrAK2AsECywLVAuAC6wL1AwADCwMWAyEDLQM4A0MDTwNa A2YDcgN+A4oDlgOiA64DugPHA9MD4APsA/kEBgQTBCAELQQ7BEgEVQRjBHEEfgSMBJoEqAS2BMQE 0wThBPAE/gUNBRwFKwU6BUkFWAVnBXcFhgWWBaYFtQXFBdUF5QX2BgYGFgYnBjcGSAZZBmoGewaM Bp0GrwbABtEG4wb1BwcHGQcrBz0HTwdhB3QHhgeZB6wHvwfSB+UH+AgLCB8IMghGCFoIbgiCCJYI qgi+CNII5wj7CRAJJQk6CU8JZAl5CY8JpAm6Cc8J5Qn7ChEKJwo9ClQKagqBCpgKrgrFCtwK8wsL CyILOQtRC2kLgAuYC7ALyAvhC/kMEgwqDEMMXAx1DI4MpwzADNkM8w0NDSYNQA1aDXQNjg2pDcMN 3g34DhMOLg5JDmQOfw6bDrYO0g7uDwkPJQ9BD14Peg+WD7MPzw/sEAkQJhBDEGEQfhCbELkQ1xD1 ERMRMRFPEW0RjBGqEckR6BIHEiYSRRJkEoQSoxLDEuMTAxMjE0MTYxODE6QTxRPlFAYUJxRJFGoU ixStFM4U8BUSFTQVVhV4FZsVvRXgFgMWJhZJFmwWjxayFtYW+hcdF0EXZReJF64X0hf3GBsYQBhl GIoYrxjVGPoZIBlFGWsZkRm3Gd0aBBoqGlEadxqeGsUa7BsUGzsbYxuKG7Ib2hwCHCocUhx7HKMc zBz1HR4dRx1wHZkdwx3sHhYeQB5qHpQevh7pHxMfPh9pH5Qfvx/qIBUgQSBsIJggxCDwIRwhSCF1 IaEhziH7IiciVSKCIq8i3SMKIzgjZiOUI8Ij8CQfJE0kfCSrJNolCSU4JWgllyXHJfcmJyZXJocm tyboJxgnSSd6J6sn3CgNKD8ocSiiKNQpBik4KWspnSnQKgIqNSpoKpsqzysCKzYraSudK9EsBSw5 LG4soizXLQwtQS12Last4S4WLkwugi63Lu4vJC9aL5Evxy/+MDUwbDCkMNsxEjFKMYIxujHyMioy YzKbMtQzDTNGM38zuDPxNCs0ZTSeNNg1EzVNNYc1wjX9Njc2cjauNuk3JDdgN5w31zgUOFA4jDjI OQU5Qjl/Obw5+To2OnQ6sjrvOy07azuqO+g8JzxlPKQ84z0iPWE9oT3gPiA+YD6gPuA/IT9hP6I/ 4kAjQGRApkDnQSlBakGsQe5CMEJyQrVC90M6Q31DwEQDREdEikTORRJFVUWaRd5GIkZnRqtG8Ec1 R3tHwEgFSEtIkUjXSR1JY0mpSfBKN0p9SsRLDEtTS5pL4kwqTHJMuk0CTUpNk03cTiVObk63TwBP SU+TT91QJ1BxULtRBlFQUZtR5lIxUnxSx1MTU19TqlP2VEJUj1TbVShVdVXCVg9WXFapVvdXRFeS V+BYL1h9WMtZGllpWbhaB1pWWqZa9VtFW5Vb5Vw1XIZc1l0nXXhdyV4aXmxevV8PX2Ffs2AFYFdg qmD8YU9homH1YklinGLwY0Njl2PrZEBklGTpZT1lkmXnZj1mkmboZz1nk2fpaD9olmjsaUNpmmnx akhqn2r3a09rp2v/bFdsr20IbWBtuW4SbmtuxG8eb3hv0XArcIZw4HE6cZVx8HJLcqZzAXNdc7h0 FHRwdMx1KHWFdeF2Pnabdvh3VnezeBF4bnjMeSp5iXnnekZ6pXsEe2N7wnwhfIF84X1BfaF+AX5i fsJ/I3+Ef+WAR4CogQqBa4HNgjCCkoL0g1eDuoQdhICE44VHhauGDoZyhteHO4efiASIaYjOiTOJ mYn+imSKyoswi5aL/IxjjMqNMY2Yjf+OZo7OjzaPnpAGkG6Q1pE/kaiSEZJ6kuOTTZO2lCCUipT0 lV+VyZY0lp+XCpd1l+CYTJi4mSSZkJn8mmia1ZtCm6+cHJyJnPedZJ3SnkCerp8dn4uf+qBpoNih R6G2oiailqMGo3aj5qRWpMelOKWpphqmi6b9p26n4KhSqMSpN6mpqhyqj6sCq3Wr6axcrNCtRK24 ri2uoa8Wr4uwALB1sOqxYLHWskuywrM4s660JbSctRO1irYBtnm28Ldot+C4WbjRuUq5wro7urW7 LrunvCG8m70VvY++Cr6Evv+/er/1wHDA7MFnwePCX8Lbw1jD1MRRxM7FS8XIxkbGw8dBx7/IPci8 yTrJuco4yrfLNsu2zDXMtc01zbXONs62zzfPuNA50LrRPNG+0j/SwdNE08bUSdTL1U7V0dZV1tjX XNfg2GTY6Nls2fHadtr724DcBdyK3RDdlt4c3qLfKd+v4DbgveFE4cziU+Lb42Pj6+Rz5PzlhOYN 5pbnH+ep6DLovOlG6dDqW+rl63Dr++yG7RHtnO4o7rTvQO/M8Fjw5fFy8f/yjPMZ86f0NPTC9VD1 3vZt9vv3ivgZ+Kj5OPnH+lf65/t3/Af8mP0p/br+S/7c/23////uAA5BZG9iZQBkgAAAAAH/2wCE ABIODhYQFiMVFSMsIhsiLCccHBwcJyIXFxcXFyIRDAwMDAwMEQwMDAwMDAwMDAwMDAwMDAwMDAwM DAwMDAwMDAwBFBYWHRkdIhgYIhQODg4UFA4ODg4UEQwMDAwMEREMDAwMDAwRDAwMDAwMDAwMDAwM DAwMDAwMDAwMDAwMDAwMDP/AABEIBsAF+AMBIgACEQEDEQH/3QAEAGD/xAE/AAABBQEBAQEBAQAA AAAAAAADAAECBAUGBwgJCgsBAAEFAQEBAQEBAAAAAAAAAAEAAgMEBQYHCAkKCxAAAQQBAwIEAgUH BggFAwwzAQACEQMEIRIxBUFRYRMicYEyBhSRobFCIyQVUsFiMzRygtFDByWSU/Dh8WNzNRaisoMm RJNUZEXCo3Q2F9JV4mXys4TD03Xj80YnlKSFtJXE1OT0pbXF1eX1VmZ2hpamtsbW5vY3R1dnd4eX p7fH1+f3EQACAgECBAQDBAUGBwcGBTUBAAIRAyExEgRBUWFxIhMFMoGRFKGxQiPBUtHwMyRi4XKC kkNTFWNzNPElBhaisoMHJjXC0kSTVKMXZEVVNnRl4vKzhMPTdePzRpSkhbSVxNTk9KW1xdXl9VZm doaWprbG1ub2JzdHV2d3h5ent8f/2gAMAwEAAhEDEQA/AO4SSSSUpJJJJSkkkklKSSSSUpJJJJSk kkklKSSSSUpJJJJSkkkklKSSSSUpJJJJSkkySSl5SlNymISQvKeVGE6Sl0kydJSkpTFMkpeUpTJJ KXSlJNKSl5SlJMkpeUpSTJKVJSlJMkpW4pByYpQipclMXJSmcEFMHXOanFpITETymhFCNuU/ftI0 VkvKCWiZRNHDVIpDh9VcXOg91hWOfUfY4t+C2eoMIsJ8VjZPJlBSfG6i959O7Un6LlJ41lUMbW0B apZLVJFhnFVF0GFpVZKwXy06KbL3pzEJU77rweFXsfKpVvcUdrC7lNpkBJWOqC9qvtpUH0JCKac0 tQHthahoVa6mE6kEU5+9NvTPbDlHam0ttn6ib1FHam2oUttn6it4144Kz9pU6ztKICbeoxnhw0Vw Fc9i5G1bFOUwjUossZd20QokIZyGeKDZltHCC7iC2U4NELByDLldycncs8mSixE2Vi1RIRAExCSk akCmhIJpSGcpiUgUxSUVkwSSCKErDCsMVZqOyVGUhNCW1SYU8plrwEZBCG58IriVXeE4KKJ7yeFA VSjtYitrUoWbtP0oSLFdNcoL2wiU0Wo5qrW6K3ZoqtmoUa9rFMnJTIrmTXQrLLIVQp2kpKLeD9ys 1BZrZVqu5zUFAui1sJ3EAKq3JUXXSkm0ltkquSkXSmRWFdRKdMigs6xJWrisWZQJK2sVqes6unQ1 XmBVqQrITSyhkmlNKYlNSolV7LIU3uVHIthFSDJyIC5/P6gGd9UfqGVtBXL3Wmx0lAlZuUl2W+wz OirlyjKaU1kAAXlKVGU6SWQcQrmPnvq5OiopApLSAXrsPPFg0K2KbpXAY95qOnC6fBy94CIKzYvR tdKclVarZCPuT16OxVLArTyqtictaloWfe2FpWKjc1Apcq0KseVeub3VN4TCsdXDfLQrrSsvDdoF oNKBXw2blaMgVIyDKEb/ACQpRnoW1JTIBFDZUAFaqZISU1XtVdyvW1wqT0lInlA7oz0A8oKKZimh NKJykpZJOmRQyCmFAIiSlJJQmRQsnBhMUkVMpTApJuCkpeUpUeEkkM5SlQCUpKSEppTSoykhnKYp pTlJSyZIpIoUmSlIIKT08rUpCyquVq0FIJLcYIRQoMKIE5DNqKEJqKE1LNJMnQUgtCzbwtOxZ14R 6Louc8aoRCLYhqMsqySSSalSSSSSlQmhOmSUsmKeUxSUsmJTlRSQpJJJJT//0O4SSSSQpJMkkpdJ NKSSl0k0pBJVrpJJphJS6SaUklLpJpSlJS6SaUklLpJk6SlJJpSlJS6ZJJJSkkpSSUpJJJJSkuUk klKCSSaCkpSSSR1SUpOE3CbVJS6UppTgJKUnSTESkpYlPMph5pQipSUJJFJSxSlOkgpaExClCSSk YMp0nNjVOEVMHNlLbCJomhBThdSbJBHCw8rQre6puDo4b4rByeUktWk/pAtfFs3NcCsioS/5K9jP 2mFJFikVrR7kmDVSsHulOwap4a9NzHatCqtUqAtKoQgWaATMrTPrlFCg6U22QhrmpU8lkBaJ4VHM MBOtbPZwbPplRUrPpFMgwsYTQpwmIQWo4jlMpFMklQsLeET7W4ISYpKSnMs7KP2h55QyEgjQUl3l ykChApbklWn3QmLpVc2Hsk10oWq08ylCgCpApFeGQSKSYlNSVkkkk5alYjsKqtcjNcoyuBbTXAJ5 VfcnD0yl1pnEQq7jqk56GXp0QolssCsNZoq1Dg5X62qVMQi9NVrWLRe2BKpWlBeQ5twhU36CVcve JWbkW9k1SHcluQtybelaU8qQCEwo7Ala0lKxsowahsCMAki2MJ5UoUSE4BBK6cJk6SLWSlJMkEtn G5W5ihYWLqVv4hT1o3dKoKwgV8I0phZVKJKclQcUlIbXQsnLshaVxWLmuhFBed6pdJhZBKvZ5l6o ymFUNlkySSC9SSSSSl0kkklKC1OmXwdqzFYxCQ8FJbIaPZ4tkhXwZWPhPWqwqQIBZOVexWDwq9ic hrPVO0K49VbQglzbm91Rs0WhcqFg1TSsKfEMaLTbqsnHMOWrXwmr4Nuko8qvUjTKDIFiVGU7iohB KRqv0CAs9qv1PEIqR5JHCzn8q5kOlVDykrqgeEBytOCr2NKCSuzVFhCrRkkLRCZOUyKmQUwhhTCS FymKeUxKSFiUkkyKlJFIpikpUppSJTSitZSmlNKSSmaZIFMkplKZKUklKlMklKSFJJk8pJTVLSxz CzKuVp0aoBRdBhRQUBiME9CVqKEFqK1NSzCSZOgpFYs+9aFnCzr07ouDnWaoaJbyhFRFlUmTSmlN SyTSoylKSGUpSoylKSV0kwTpKWTQpQkkpaEk6SSn/9Ht0kkkkKSSSSUvCSSZJSkxTwnSUsklCSSl cJSkkkpSSUJJKUkkkkpdMklKSlJ00pSkpdMkkkpUJQkkkpSUpJJKUSkklCSlJJJJKWSSSlJSkk6U pKUmCSUSkpRSSTgpKWSSKaIRUvITJJ5QUtqmIUiJShJTEHspQlCYJKWKiOVJyYQipfhRmTCmmI1Q U4fVAS8EnTgBYWSNYXRdU8SNQVzuWIKSWnX9IjuFZqMHVV643FFaYTwwy3bXJUwFGvUI0Qno4U9L 4WlRa0hY8wi127ULTqHeBTFZgztoS/aEoJ43QeQBJWVmWbkn5e5U7rNyFrSbarhLpS2qQClCFrKR wouCPtUHDRC0ENcqMKZUYTkKTQnSRUwKZTIUUlMZhIpyFGElLRKkNFFOAkhmDKI1DaEQJFcGaYp0 xTV5WSSSTlqk8kJk6CivvKbcUxSGqFIX5SCkAnLUaXr1u2lX6sqOVnwlJSpcHStzWgLKyc1z9G6K FmuiE5qC7dBZaVRfJV57JVd1coIapBSDSrPppemguthWCrbGqDGKzWxJDNgU4UmMU9ifSEUJiEYs UHMhOAWksEk5TIFQWUVIpoQXFPjcrexHaLn8bQrdxSnLY7utWUZAqKOE0sqlBymokJKalyxc0crc tasjLZKcoh5LOZrKzyFt5tMysd7IKbIIj2Rpk5CZMXqSTpBJSk4TJ0lKVnFbLwq4C0sCmTJRA1Wy OjuYY0C161n4la062wFItipyrvVlwVd6SWs9VbQrb1VtSU59wWfYFo3rPtTSsK1ZgrWodIWOxaOO 6E1Md3SrKNyq1RVlqDMGBmUgIRgyUi2EksAiVuI0UFNoSUu/VV3BWiFXsCSkQ1QbWo4KhYNEFzXa ihBHKKEli6aFJMilbhSCZOEkMkxThMUlLJk6ZFCkikUklMSmSckEVpUkknSUuEycJJKUkSkmKSl0 kwTpIUmTpkVJa+VpY58Fm18rSx01c6FZlWGhV6wjtlPWpAEQKAUwgpklKaU0oJY2LPvV55VC9Hou DnWIJKLYglRllCiVGUimlMUohNokSkipSSSSSl06aEkFLynTJSkleUkySSn/0u2MHlOm+jwnSWqT ap0kkqSSSSUpJJJJSkkkklKSS5S4SUpJJJJSkkkklKSTpoSUpJJJJSkyeEklLQnSKaElLxCaUkpS UpPKbhJJSuU6SSSlimAUk0BJSgE6bXslKSlJSklCSlvipSmS80lLpJkklKlNAnzTxCUpKXTEhJLR JSlGVJKAUlMREKPdSI8E21FS4KRTHxCWqCnN6t9DafiuZy+V0vWCCGa/Jc1lc+SSWozR3yRAhtHu +SIE5hlu2cd8mFac9jCA4qgwayjmo26nlSBaSa0TlwPHCaCoVsLVYAlIrg1nNICBrMSrr2qk4a6J pY5bpWtKntQmkhED1GUgsg1PCQIKlwguYkINiM4qtYUQskiKZOmT1oUkmTpJWKZSUYSUxKUKUJoR UxhPwnSSQoBTCiFIJFIZJFJMU1eVk6ZJOWsgkmCSCCpTYEMo9IlEIG7MNT7EdlaM2iUQGamgWQok LRfRoguphEhADQLEItV59fdVHiCmlI0QPahFiskSoFqCig2BLZCNtS2pUq2DWKzWzRDa3VXamSiA pZjEUVyjMqVhlEo0mmiWIb2LTfRCr2VJKIcx7YQpVy5kKmkVo3UmTpimhcyqdDlt4j1gg6ytTEs4 RWjd6GlysgrPoerjCgWVJKYpBOkpDYJWdkVytVwlVbq5RCXmcqlYuRjx2XWZNErIvx05YRRebcwh QK1bsXwVV2ORwmGK4SakJQjGk+Cb0im0U2iUg1Gbjk9lZrxEREoMgEFFBeVuYlEQo4+NC1cemE+q Wb6p8etXmt0UKq4RyICS9BYqz1Yeq70kIHqpaVaeqdxQU0bis6zVXrys+wyU0rDuuwrQo1Wc3RaG MUER+Zv1q1WqbVcq1QbAbLRooPCmFB2qC5GDqiMQYgo7EVqSNECwQrbBKFcyEktBwgqDnSEZ4Vd6 CQgnVFagkwURhSQlTJSmSQoqQUVIIqZJFMpJKYJFShMUULQmTwkkpgUgkeU4CKFoTp4SSUskkkgh SSZJFS6UpSkkhSSSSSkjOVpYyzWLRx0EulWjgqvWrATkMwphQBUwkpdMUoShBKN6oXBaL2qlcxFc HLtGqCVZtbBVZyYWUMCmTpFRpWSSSRUsknTIIUE6aU8oqUnTJSkpdJIJIJf/0+2BTpkxJCS1ckpc 8pmulOkpdJNCUApKXSTQkAElLyklCUpJVCSSSSlJJJJKUlKSSSlJJgnSUpJJJJSkkk0pKXSTcp+E lKSKSbhJS6UJiR3TpKWTpEpuElKTpgZShJSvglPilCUykpdJMZTSkpkmhNynSUvwmTpjokpSSQTJ KXTpgkUlK0STRPKeElLJJjBUoSUwJAUPU5kaIjgO6G5oSU5vUdjwIOvK5zM8l0eSxrZLztMQCuez GhunKCWk3lFAlCb9JFCeGGW6eoLRx6pWbS6DqtzCAKeFQ7Izjxwm9OFpOr0Ve0bUrXHRzrvaFRI7 q1a4uJQXBR2xlZrUTYkwIhgJtppHthMZCnuCYwlakTigPVh0IFiIWyCOUkydOWLJlJMUVBZJJJJK ySdJJTGEoTpklLhSCgphJUWYUSpKJQDIdlkkySKxdPKZJBBUVZx+VVKtY51Tgh1KmAq2ytV6FdaE bbIGiN9coDqVdIUHNStIDl3VwFlW/SW1lQAsS0y5AsZ3YEKKkSooBBVCQTJ5RQuFo0CVmg6rRxTK IQDq6Ndcq5WwAKtVwrDUrZ13sBVaypWoQbQlaujkZTeyzFqZZ5WV4pFi6rlMlKYpq5ZWsWyCqoUq 3bXIrS9JjWStGtywcW5a1NiS+Jb4KdCa5EBQXrob2yiSolIIaN1UrPuxpW25sqtZUCnWqnn7MZVn 4vkugfQEB2OEbRwuCcQFMMMLbOOEhjhC0cLktxQrDMbyWk3HRmUBK08LUpx1eqqhFZUAjBoCCapZ rYUXlO54QnOStSN5QHorigPKKEFhVG4qza9Z974TVNS96oOMlHvfJVZNKwJWq/ilUGK5iHWElu0g 6DSrdJVUAqzRyg2G4OFEp0joEFyMp2lQJU2oqbtAlLJbAU6OEPKd2SR0cx51QHhHfyhuCC4NN41U mKVgUa0kFMAlCcJcJKWThMnCKGQTqITpKXTEJ0ikpimhSTwihGQlCnCYhFCg1IhSASISUjhJShNC Clkk8JQihZJPCSSGKdOmSUyb4rRxis9i0McILnSrRwq9asNTlrIIjVAIgSKWQUwFABOmqZEKpe0K y5yp3uTgkBzMjlUXFXLzqqZCZJlDFJJJRrlJJQkkpUJkpTEpKUmSJSlJC6SZOkldJMkkh//U7aZS hKE0IrV0pTaBIJKUHA6KUBQIHKcfFJS6WiiQZUgUlKS4SlMXDgoKZFMmjwKcFFStUgkkgpRSSkpQ kpSUpJQkpQT8poKbcBykpdLRKU0JJXlPKaEh4JKUSkT4JQlCSlBKUpSmElKTfFKE8JKXTJJtUlLp aJoKcIqW4Tpo7hKEkK4SJ8E6aJSSvKSaE+qClk8pvyp/ikpWiZLQlOElKhMZTwkkpaExEpTql5pK WkEKEkO04U0iElOT1SXiDwueyo4Hgun6iNzfMLl8g8oJajOUYITeVNODDLdm0wVs9PugrEJVzFth wTgsB1emLpCoZJKsVP3NVfIEoFlk5x0QXnVWHBVLeU0MckrSkdUFtscqXqhIhNsimmFA3BDN47JI JTOcqz3SVF1xKGXwiEbpJSBQTaE3rBORwlsymVf7R5JC8ngIaq4SnKUqubz4KW8uGgRXcKWU8qsS 8qbN5E+CVJ4SlJUSVEB5TFj5gI0jhLOVMFVy2yVMNeOUqSI0nlM4oG2zxT+k899UKTwpJSlCFb45 TNqf4o0jhTSluQjSfFM6t3ihSjApSUamwAqoK3dyour8CUVcD1GI8O0WkxpXDFmwTvIPxUg63h1j vLVBcOIaPdEINjg0ElcY19jTpa/70nhx+k9x+aSbk7WZf5rJc8EyhGhvJJ+9RNbQeUkUUhePFNuC i+hoEqIqbHkioxZmwJvVHiohjCpGliSOFfeFcx8hrTqVSdUxoDgouayJ7pK4XpqMqs/nBWxk0t5e 0fNcb6THdtUvRYDwguFvZWZ+NWAXWNAdwqtvU8Yj22ArmW0M7hT9CvgQio8TbycljjAMql6gUgGx oNQn9MRISRwsPVb4qPqA91JrW90XZWONUk0g3JF4KOQyPNSArdoUkcK1GW1gknRaVPVqG6Ocsohg J8Em11ntKCuGtnoW9axWjV6n/wA4MQfnfguc2s7ASpe2OOUqXau+frFiDuZQ6/rJjPMGW/FYmxvI 5Qy5sgRolSNXft+smMwS2XIZ+slBGjXLEaAdAi6ASdEqTr3dR31hxuwch/t+g8Ncs4keCXtOhSoK 1bx6/T+4edVP9uUDUtcsuxskQPmnLm8IUmy6DvrFSPoscUWv6w45PuBAWOQOYT6QlStXdH1ixfNR P1ixj3KxmsrjUaoL2tmIRpGvd0ndVDXE0u3NOsH81Fq65S9sWe18rF9MSQ3uhWMbMJUjV6P9o0O4 cFB2Ww8OC5x1QaobB3QTq7ll7SNDKz8ixUXbmcEhMXHukoi1nmSopT4pxCaikjArFBh4QGIrNHBF ik7bWSJRqRCHQ72IlZgoFsRNgNmVCx8JAyk5klBeiGpR2qOyFNoRU2KLNphRyDuTBqd4SQ0XhRHC LYEJvKC5Ba1BbEq3c2AqndJBThJM0qSSmKScpIoUE6QShJS6clMdEpSUuE4UQphFCx5TwkOU6KFk xT8JikpZMVJRKRQpNCkkkFMUycpkUKSlMUpQUzCv4yoN1V7HKC5061Yaqtasgpy1IEQIbSiBJTMJ Jk6CVnKlerrlTvRCQ5V6qHlXL1TKjkyhimTpJi5ZMpJikpimUoSISUxSATpAoKXhKEpToqVCSSSC n//V7MjXnRKANE3GnZSB7FFattI1BUkpjlMTHKSmUqJaOYSiUhpykpWgKlPimmUtexSUsQlCW7sn 54KSlR4pJAHulJSUoz4J0pSAhJSt0pJJp8UlL6pTHKaE8JKVKWhS0S0SUqISlJKPBJS0p/ilKSCV cqJMKSYieUlKThMBCeZRUqEoTJJIVrKeUk6CVgUikQEklKS1CUeCUQihdKU0pkErymlOlHgkpSUJ hATRqiplCSbdHKcoKUeNUkwPimiNQkpYwEiJTkJikpUwm3gap4TEDhJTm9SsMAzouaygO2o8V0nU x7CAJXN5QgABBLUZ9JFAUKmySiwnhhluxiFNji0p40UYRW072HbuaiX8LLw7tpgq/ZZITSvGoajl Vu5RbbmsBLjAWPk9SBnZqmxKCG454byq7slswFRNrniSdFHdqnp4WwckngaJG1xQgRGnKUwiuoJA HOUdoPJSa/uU7zPCQVS7Gg6I+0DVVmTyPuRg48FFSpBmOyICIBHzQjqdOOE8duCkpRHcKbHwnYXH jlD2mdElMzbBSFkSR3QnERqhuBBBHBSU2mvLeOFLd3lU9zojw7olY3x6h+BSS2A6eUweOCqxJJ8C FYDxA9TlJDIkJmv7hNHhx4IbwGfR4KSk73gBMLROuiA4T8U8ANmdUFNlzgdSkGbmKuHEhHFwaIHd G1I9rgNeEOsh40Vp2o3NMjwVNziNOySWbng8hRc9wgN7oZZuMKe07SHcjjzQVSmEyXFQdeQdOFB1 hBJ7KO+uYPJQVSYuc7RIOMfBRERHBCGSWmEVU3S8enuGrkFh9sdyh1ljhEwZ0UPUBBAMCeULQm2h O4lx1MBDD2gbSdU7rmRKPElMCDAmR3TOrAMnUJq9kSO6g9wAnt2StCRz9vtCgC+fPsoF4edTqjix jdHckJWlZr+J5Kk523tMIbHBxIOplMbQCUrRS7ZLieCiCToFWDg10zI5RpkbgULUyYDYYTlpn28J qbC6YEhEDjG0aI2lGWnmNEt0O0+in3BnJ4QjcxuoIIStCcyRITCz0yfMJNdvB2GfJQgk+8ahK00z gjnUnhM2QJ/BE5Pt1lMRt15HdG0MS8DUfS/dSlpE8H91DaQdRr5qbXiuHOGnikpkxwE66dymsdv1 GoCZ5bZ7m6BJgiQkpY2uY0GJUS8u1jVNth3MhIcwkpkLAwiOe6Y2ydwTsZtdxAKlsYSQyTBSUiaX OMd0Rj5PiOFB1Zafdo0d01Ttz5aNB3SpSdzg3nlMXB3uQPUa9x7hKWAuMwklmPbx3UPT1k8JOJDt dSQlIDp4A1QUjuM6d0MkSAiWfpHSNEPbBQUs8iJ7zCkysOB11TOAgHumY/a4EpKYWN2xPKErN7T8 lXIhIhIU15HCMLvvQ40TbUEEAu5iZAc3Qq0x47Lmm2OrMtK1cTKD9DygUjTR26tVYAlVccyrjAgF 7BzUzAiOQg6CiothrU7homa6VOJSU0rWqqTBV65qpPEpKXf7mqidHK2QRyqtnKCSkapoTSicpIUk knRQoBIp0ikpYpBMUgUlMlIIZKkHJIZ8J5kIe6SluRUyTEqMqJKKGcpFD3J5QQylKVGVGUVLkppU SU25K0M5TSoSkULSlYVoY5WaxaGMgl1KlZaq1RVtuqetZBECgERqRUyCdMnQSsVTuVwqrciEuTkD VUnK/kBUX8pkmUMZTSkmUa5eU0pcJklLylKZJJSk6ZKUFLpBNKUpKZJKMpJKf//W7MEzBT8KPqTw nl3BTlq+h0SDdITEkfBLeByYQUvtlM2eCk4DlPM90lL8JcKIdJS54KSmRcmlqbUcpEA8a+SSmUpb j4KITweQkpf4JoJSmE41SUtJTgylKR8QkpQSA0lIGeVFwI4SUzCUBRT6hJStvgnUde/KXCSl4Tbf Ap4SjukpbjsnlOCCm5SUolKZSiExjnhJS4kJ5CbbKUeCSlT4JSUxBCefBJSo8EgCEtSkBCSlHwSB PdOR4po8ElK2lPylCYmDBSSpKE6bQpKUCnUTqYiQnASUtJSa6eU8x2TJKVKQEpbiOQkT4FJSjom0 KeYTQkpRjlLQ/FMVHcB3goKc7qT21tDSdHH3Lms0+4kajsuk6qABunlcxkhDqlFj6uKsbUDD1fr4 K4WyVKGIo4TFEhQeEEUxFm0ymyeqtqZofd2VTJvDAVjlxcZKYdUgNi7JfeZcfkgjThROieUmQCkt bpUy0j5oTTA80atpMQiFLj2+acCfvStIgRz3Ud3t80UJbGFmh5UqxvbodUMEkRMpiAzTuipmN3I5 RiNxnhA3DSEYCRPiihg9rmPmdOU9rjG4KQBaY7J3VxDmwQkpY2AjRPuMeB8Uzg36QGvdONTDklMA +TqmLgTA0TbyB7hwYR66xfryYSU13Twptk6g6eCeADtOoUWiDA1A4SUyiR4KLqjEzMJBzph3KYve 1xd2PZJSangPPHCJa0Ngjug0u500KI5/AHbxSUjfuYZHCr23taYJ17KxefYX9x2WG8kkymkpAbYz NfcJCn9uEQBxws9JNTTe+3FL7a7XzVFPKSW3bnPeICj9st/eVZOkpKb3HvymbZCEkElNkWnxSfkF 3PZVpSlBSYWBP6iBKSKkxuJCQsJQU/CSk3qEaBMbHeKFKRKSkzbS3VJ97nO3HlCD50USUFJTafHV L1ihJIqTeu7sm9d44KCnlJTbxc11FgcdWz7h/JSuznPte5mjHHRv8lVFFJFJzkP2ls6HlQ39kNJJ KduS9ugMJ/tT3H3OKrpJKbAy7G6hxCPX1OwOkwZVBIJIp3qHEj1AOU7mnSeyhU3ZU3xRGyfgnhCg JMcBKx5GnY8pOZAnsk1p5Og8UUMdgcSdycEDUp4DSN30SmsbGhCSmZu3e3xSre5hEaAcoQkDQapP cdAZQUlLnOJk6ITfaIkgFOBOhEhKtzSZs0CKWTCGjhCMB3EhNY4WGe06J29iElMd8OO3v+Ck1u50 dyk5sDTjuoh0kdklMXloIb3mCiZLGMIDHbtEE7QTqoboAI5TUqJInxKaoAuAKcxElMzV2iSEj3Ej aeAhFpHKm8GPFQJ4lEqDCYUzoJ8UJ3MpTKbaVyZUq3FpBHKGApgIKek6bfvAnkLYBXM9LdteQV0d fCC4MiguGqKXIZ5RSlrVhglVqwrtLUkIMivSVmWaFbeUIasazlJKPcO6q3eSNYNFWsTUqYUcaoFa OEULp5TJIoUkknKSWCaVIqJSQVd08qJKaUkMpTbvBQ3JpSQklRLlHcolyKkkpShylu0QUkLlEuQy 5RLkUJNyaVCUpQSklNKjKUoqTMK0cUrMYVo4qCnXqVtqqU8K21PWswVMKCk1IqSBOmCdBKxVW5Wy q1wRCXKyAqDxqtDIVB6ZJlCJJIpkxcpJNKSCFykkkklSZOkkpZJJJBSoSSSSQ//X7EOLe2iQsJHh CYxyVIlw1iU5Yt7weZClAeNeFEWg/R+5O4ykpmBpCG4EcJQYBGhClIcIISSoNCRbGqiQ1w15S2uP eUlMxokSPmmAI5SMjUIKX3A8HUJfgUx1+KeY0SUraUpjhKfNKZ0CSl5JTHQyEpSPkkpUTqnhREhP pKSl1GRMJzooEHlJTM+aQKQkJiPvSUyUZjsnAnlKISUxJDtOFMAJaJiY7JKXSIMaJTPZMTtEpKW+ KcFKdNUvkkpZpJ5SkHSYKc+5ROvZJS4B4JUuyjMKUpKW2+aQHgmA10U0lLQ490k5HcKJfCSle4GO ycieUwcCJSgpKUNNE0ynhOI7JKWHmngBPKgZ8NEkrlwOiZohIptpSUzIBUXSE0aaFLd2KClQlpPi lCY66JKcjrLg3aBrJlc/mEF0jiFvdSbJJ/dXP5Y28oJR9PE2kHwV2IJVLphHqOnw5V7SdFKxlYhQ eiKD0igOF1EgP2hUG8qznH9KQqgUa8bJAJTAzwog6qQ0KKUrRKLXb6U+fCHpCIwNM7vDRJS3KkHb QR491Bo8FKYOqKlnRALdCpsl/f3JM7SJUw0T+RFCiD4SlJMxwoxPinkuOmiKkjJJ1Tulh29ihxuB AMEJ7JdBPPgkimXEymkFJxLdSoh7SJ/BJTLYU7LPRJEQ5M2BE6gp7QOQUlMHEnU90SC4buyjo4Dx Src4Da3ieEkso78zopuZtEd0N5JJIHyS9wduPAHtSQlrbOii8ubr4qDXTrOqm5rhykpA+za3TuFk OMla+R9AkiFju5TCuCkkySCV0pTJJKZJSmSSUvKSZJJS6SZJJS6RTJJKXSlMkkpcFIpkklLpJkkl LpSmSSUqU8pkklLpkkySl0kySSlJJJJKUpM5EqKdupSU7NTgRA18EWAGyOfBQpY4NHbzUwAAJHzT wsXc/wBTQJwO08JpYx+0nzCdtmxvtI1SUr1Axw3ccKY9JphpkHkphD/pBQJ7ggjsEVK2E94TOsJM fimBcHebtSluDZ00n3FJTJhrI2t5HdMW7z2hPBa3cYnsoNIH8on6RSUp4awahQhsCO/JUvpuJBlr eQol5BkaHwQSp5O0iUwLQBMyoROrjEp2ENcC7UBJTEtDjp81F7Awxyiuc1w9vMz8kInsEClbyHCU gGe6k2IgnVCd7SkpYlzyTKJENnuh9xCKXTMoKQESU25FeyGh3ignVJSRgnVFiJKFXp8VId5SU3+n mbAupZoFyOG/bY0+a65p00QXBYhC3aorzDSVXBkpKbdS0aYWbUrdb9qSl8w6LHfytTIO4LNsEFJS FzZCrWt0V6vwQLmwkuaTOVabqFVGhVlvCCGUJiU5KZFSlJQBTygkKcoFScoFJBWKieU5USUUFiSm lJ2qiSkheVGUlElJS5KUpimQUuSkVHlOiheUpTFMklmCnUJUgUkJWLRxSs1i0MXlJTt0q00qnQdF canrUikFBSCSkgTqIUkEqKrXBWVXuRCXLyFnvK0chZtiaWUIymSKaFGuXSShPCClk6aE8JKUklCe EFLQmhShNCSloSTpJKf/0Oxa7dPZIu2ptrToQhkOaRtHt7p6xIYOsJ4LTPI7qO9h5kJg9s7SSgpL zwUiPFD9rdQDCc6fBJStrgZnRO4dwmLACHNKcEgwkpbdOhMFS3R5pjH5ycFrhI4SUsCCfBT2+CiH A8FNPySSy2EJbGzPdQa6eEt5CSmbyW6xISnuOE2p4TAubygpkDuGqRngqLST8FIAchJS4kDVIuCZ xUQ49klJIBTccptwCbafkkpeD4qQMDXlRBCQM8JKXTOaCJlO4Jt0dklKAHYqU9lDd4jRIgEJKXJH dSHGiYAAaJtsahJSiY0Tz4pc6pQElLpQExLYTSCElLRHCXHdSA8UiQdISUoFNtHZPwE0wkpQOsFO YKYmUogaJKUQTodUjrwEgCnkjlJTDd4qe6U2h4UCY50SUz05SM9tUwHmk7TUJKWgD5pQCkXEcqO7 dxyklnwEiZ4UZnlIslBTk9QcKyGxI7rn+oOY9sN08V0HVG7WSdfNc1lztMoJQ9Ns2WmeCFfJhxA1 AWPjOLbNVoNcZhSMRbUqDynZqoPMJEqeezjNxVWVYyzNpKrpi8bLtEoobHKGJGqmCTyklKwtEykw qIafvRYRUrUapQXaJyZbsPZNXoYRUuJRGn2zOsqI19vdMDOvZFCWYB11UHghwPBTHmVI+DuElLu0 17qWvIKFuAMFGAAI1RUjBOsnhLcORoVPgnbqpMAHuOoHISQhBI0RDaBLS34FO8azXqOyjtn3R8Qk liDt+KK06E9z/wBFD29z8knbtGzoUlMhv27gZ8Uxe4mSdOybVnZTrDXSH/JJSzYb20RQZ5+SCHRp Gvinc57xtbEDkpIRPe/aWE+1ZLuVpWkPbtPIWaUwrgskkkglSSSSSlJJJJKUkkkkpSSSSSlJJJJK UkkkkpSSSSSlJJJJKUkkkkpSSSSSlJJJJKUkkkkpSSSSSlKTOQoqdergkp292gk6xqnn83kdlBjJ AI1ASggl3537qetVsY74JwxpfqJhMwku3EAkdkrHu27UVLkOLZAMqLSB9IangJxe8A+CZx3bQdB3 cghXuBPipB2u7keH7zk9Ybw0z5qJaCdYgcJJXsZDRMiSot/Rzt480UmuRvdI8Ag7CT4t7IqXDjqf uTsaHAzz4pmnbJeNAoGwARJA8fFAqXcRxGkpiSQQwQO7lEOHIEqQkz2BKSliQGwOT3Q9sACVIkNJ I4OmqYOaToglEfcYCYqbiPDUd1B2pQUpok6c9lKY+KgDJEcqe4td5pKYz28FAgKTzPzUQkpm3xRA PduKETCI0y1JSauGvEeK6yt3tEeC5GtwOi6PFsJgHwQKQ6Dmy2EMVwrDYISc1JctWrACAzQqy1JD GxuioWthaThIVO5qKWiDBStbIlM/QqZMsTUhzHiHaIzChW/SRK0kdU0JiE6YpKYp0inSSGJCiVMq LklIyoHREQykgsHKKk5RRWrKKlKikpSZI6JpQUyhOEglMJKUVFS0KYhFSydMnBSUlrV/G5WexX8Z JTs0nRXGFUaDorrE8LEsqYKgFMJKSBSUApIJXQLUZBt4RCnMyVmW8rTyAsy0apsmWKJJJIKJeuE6 ZSCClkk5SSSpJJJJS8JJFNKClQkkkkp//9Hrw6dCVIgx7dUMPJEiDCeXfmc+aesWDyB7hKlIcPJJ zj+eIPio17TpGiSmQPJThxAnkJw2vw1TH2e7sgpReAeOUzpI9vKnAcPJMDwQkpgzXXkpyWzB0KeW kyPmpkh3IlJTAaieUhY06tS27eE4brPikpXKi0OadeFKXTpomO8fSSUu0wnJTFoOoUdkCNUkswQO FEgz5KLSWjVPuIJjUeCSmTmnluvkkZHklJHGiTfNJSg7cYcnho4MJF0aQm3HuEFLkaJgW8J00BJS mtg8qR15TN81I+XCSmLVKO4UYSAEQkpeO4T7x81AsBSiRqkplunhIFQaTyNVIGSkpflKBOvKUxoE xidUlKI26hPvUHnx4TAAcapKSR3TgShkB2h0PglsDRASUzLSPgo7XAzOicE9k4cTykpcGdUxd5Jn s3cGE+g0PKSmDg7sFLyKUEJtp57pKUG+KYQDzqpB4cdpTbdSfuSUqSOeEiZSG7vEJh4cJKYlxGia Dy0/JT45TEtaJCSXN6i1zq3OBHPC5fM4MrpOqkPaNmpnWFzeWCGweU1Lm1u90d1eqBn4KjUJeVfp CeGOTerEhRurnlWKG6J7mQCUCh47K0tcPNCCNliLXBBBhBeNmYEKYaG8qJcJTSilM0n5JSQfJDa4 hS3d0lJd0mSkTrKi4lpE8ptDoTBRUmFhPOp7FNJmQgPcZGqJ6hI8wlakhJA8EnuOkifNMH7TD9ZC hY0tAJMhJDL6XKJOgnVA3t/OCY2QlamyyCIHCaxpYYd3Qi8HXurmRayzHqdy9u5jvFG1IWV/emid RyhFzgPFIWbe6VqS7ncqW7c2Xc8aIItmTzGiTLI5StCQhzDqZB7pAggoTiJ1TgxqNQlaUkhpE8FS a8A8qu9wcoscOErUktZuk9lmO5WlZY11ZGu+dFmvEHVNKWKSdKEErJKUJQkpZMpQlCSlkk8JQkpa ElKE0JKWST7UtqSlklKE0JKWSTwn2pKYpJ9qW1JSyZThKElMUk8JQkpZJShKElMUyltShJTFJShI hJTFSYYcEylWQDJSU6lNm3Q6Aoz7G+Mqk29obHilZkbuBwOUbQ3CxwOwfSIlCFkktfq5VW3OYdzS QfFQ9QzPilaqbr3aiYEJ3WtiAJ1VQ2DSeO6c2kj2o2qk7z7Y4J7p2mQPJVQ867jqo+s7uULU23Mg QBLlIXENiVR9d3in390rU3PULvb27qO4vdJPH5FVNpUC88JWp0TYGxpE8FV7LXkwDp2VYvTz48oK SkkH3J7HbdAIQPUKW+eUlJi6AmaZMFR3CNDJUS7skpM4tBhpUTG6FCSmDtZSUzckCoEpSklKYPCK BAVYBGY/SDwihJVytnEtghZFfKvs9sIFL0lTphHVDDskK+DKCUcwVaZqFSuHgrWO6QipPCrXtgK0 1Dyme2UVONYNUP1NohHsGqrWBApDUu5U6yoWJ2FBTYlNykEikpcJ1FTCRSFiNENyI7hQIQSwQnKb tFAorUblFSch90lqimTqKSl5lMmSCSmcJk7U5SUsNEkkklLJJJklJWK/jcrPZyr2MYKSnao4V1ip UK6wqQLEoU2qIUgkpmFJRCkglSDbwjINqIU5uQsy1aeQs2wpsmWKBOkkol6pTymSlBS8pJpSlJS6 aUk0oKXlNuTSmlFTKUlFJBT/AP/S6zawEnseVB1YmQ4iFMSPo6KIyBO1wkqRYy8t090xhus6FObA DtIMjunJDhp80FLuJGpHzCQuA8pQ4cBI4Ug/eIHPglSkghp0MeSYv1gGJQ4bEO5Cm10+06+CSmfk dSk5ocIGhUYeNW/comxx1gghBTIAs5180vUDjHCTbN3CW4nhsJKZbhHmkHB2hQ5I+lr5pNJdyUqU kaDPKQBCaANOynDjwdEksTM+IKctBTBrlEnbyOUlMzz7lEn5hMCSYPHZSlvzSUxboYP0eyciBAKi QZgnRF1iYlJTAjcPNOPNQcN+oEEcpe8cJKZyO2iiRB3DlKXHmEiexKSlhY6Yj5qQdrqJUhMaalMW Qd6SmJPc6DxUmujjVPuDuEmxGiSlGO6hY3dwYPipgRqhk7XapKZM3RB1Tz96iJPGidoI1PKSmW+d CE39VS3aSFHcOyClwQ4ahIPadFDc12syQk5m47p1SUp8A6cp9pd3hMxxP0xqO6awka1nVFTLcWaK R1Hgo7yGnfygMsNnOhSpTYIPjqmBcNCohrmlOdRIMEJKXdxB1Ta9gn9x4ATEPIgGCkpRcGn2mCk4 u7/IqAZGrvpJ9e6Sl3Wd4TAt5HCZxJ7pbw0+A7oJc3Nc5r/bAAnX4rms4x8l0WeQTodDoudzhEgp qWljN3H5rSZXtdHgs3GnjxWrjhOWU3qGol9ftPwUqBoi2t9hPkgVVo8Bk6vcfNBCPkfzj/iUIaJJ GzKAU2oKUwkXbkksuCk5wKTQJ14TPEEgahJKi+Qn3SoQnBCSFifFOLOVE8pCBqklfee6W88IntMK PsBhJCPVIkomiclp7JKRBxPKW8g6KXtBTbgkpQe6IT7jymDwEQEEfBJTEEzqiSBr5KLbA3VJ1od2 1RUyDDElO1hOo+5IWNaOVFloaZSUwcHApnumPxU7LpEofOqBUu1xESh5Ah5RPJCuEFJKMBFbWSmr EmF0GJ0v1GzCdGNrSacL0yEhUSurb0IkSQpDoWnCk9rxWcfg8qKCnOOfBda3opMaIo6GfBL2x3Tx ns8YaSn9A+C7T9hE9km9CM8aI+2O6OM9nizQQkKCuyd0EjgKbegzyEvbHdPEezxZxyl9nPgu3/YW kxqnf0AgTCXBHuriPZ4f7OUjjOiYXbt6DLZj5J/2D5IcEe6uKXZ4b0D4KX2Z3gu2b0HWIU29D1iN UeCPdHFLs8KcY+Cf7M7sF3D+hSYAU29BHcIcEe6eKXZ4X7K7wUfs7vBd07oW3kaKTOgAjQaJcEe6 uKXZ4P7M5P8AZneC7w9BA7J/2BIgjVLhh3RcuzwQxnHsn+yu8F3jegDwTjoQ4IR4Yd03Ls8D9nI7 Jxiu8F3P7Cl0QijoI7ocMe6Ll2fP/s7vBQdQ4dl6Aeg6iQh5fQIYYEpcMe6bl2fO3CE0K9m0elYW oHpaKIitF4NqLYaD4qQZpqVZvrDaqyNJ5VJ0yglKAOCdExDULVPJSUkDQptIBMHRA1SSUmcGAA8q PsPCHEpklJgGkwouglQB1SDtdQkpn7QR2HimcQCY1UCUklLgSpmIhBkpxJSUvCSYOhOHJKXAM6Ju 6addEpSUkc0hQJTtsITcpKVKeZ5TFIJKZgqcyhDlElJTapVxjlRpVgOO4IJD0WA32rQlZ+GYYFaD pSSycdUer2qrOqtV6ooLbq1Usn6KagJsp3tRQ5FgkqtYNFbcNUGxuiC4Obao18wi2t5QauUFNtoU tqZp0U0ksYTp0kCli4Toou4UyoEIJQuCGUVyE4JywsHIZRCENyS1aVEp0xSUskE3Km1JS4Uki1MU VKS7KJOqSClFNPdIpJKSMV3H5VFh1V7H5SU7OOdFfYqGOr9YTwsSBTCiApBFSQJwohSQSug2oqFY iFObeFm2hal6zbE2TLFrQkpwlChXsElOE0JJYpoU4TJKWhJOkhaloTQnlJJTGElIJJIf/9PrA6Rw kfTOggkfmqLHz/JPcKQYxx9ujj3Uixk10zAIPmk0mJPKZr3tMPGvin3h3HKCl/UI81Ew8ggQRwUi 5o9xd8Ugd40KSlFxAkjXuoOJI9uiJvgphY1/tMapKXYTpJkpPfB9wgphtB2nSFJxc0cS3xQUx3ga zBU/ULhEIYa5+re3ZTDGsMjvyEVKLZETqlB/OHzUTBdHB8VIF8wYjxQUqATyp8ccoT2aQBomB2ca +SSmTt4Ph5pw9x7SkA46tdI8Cm3c+PgElKcWv0KdsD4pgdw00PmpOdPPKSlpnU8JN11adP3VHQcG CfFOHa+CSmYkayn1UYkymO46D70ksyAfpfgobxwEzKyNe6cjdrEQkpTXQNpUneJQnVx+dIP4KEkS 0Ok+KVITl+3smIB9wUaw4D3apnHcYjRJKUN3CSpN1CgwduQo94aPikpLu8E0aTKGGFvknBBOnJSU uWqPq7dAJKm4EcoZEGQkpJG/UfNRLnNmRI8lB9Zjcw/EKXHGoSUx9U2fR0PmpuJgTEpzDdTyom3b +bKSmYJcIdChtAKjtZZ7xqFIt3tj7ikpnuMxyEwG7Uc+CixwboRqn3ToRqkpTpGreUwf2PKYsPIU WjcPgkpmS5ukSol9bRJkJnOc5vt5UCwv+l7UqUuSQeZRQARqhCGjbGnipgd5kJFLk9TEQRoubzTo uk6i4HSNAVzecZgBMS1ceQ6QdFrVHWVk4okytSgpxWurQUe0+w/BVKjEQrFmrD8E1TwVxmx58yhg aqVv03fEqBfoiobKdom0UXOkppSXJN2iiXxoFFMUlL7oTSklCSlCSnktKUJQkpee6iTqpgJ4HZBT BMDBRNqYhJTE6poUyQlPikpiQpDRIHVS3ApWpjCW2OE+9PvCSmG0qQbBUi4BOShamKiTCIUN/KSl ByVmolDBRCQWeaKlVaEFek9AbW/HBMSvNAui6b1d+K0N5anXSPF9DbW0dlLa3wXGD6yX94jxRP8A nGRHu1/OQtFvXbGpANauQr+sE7nWEx+bCD+3bD7nanlqVqt7cEdkzto5XEH6wXOkOMHsou69kFsG ClarL3ILXJt7AY0XBjrVgPtcQEQdbc8S6UrVZe43N7RKYPYdJXBnrBJmS0qR65cPomErVb3W9gMT qpyFwB61YSTu55KVfVr2mWW89krVZe99Rqg7IYFwtfW7aT9LdJ7qf7fuHvBE9wlare39dhgqZeDw uFHXrXHUiTwf3UFvV7mOJbYdf81C06vefaGAlpOo5TjKqPDguC/atjjucfcEx6o97pHKVosvfWXs A1KGcytg92i4VnVrqyYO5p/NKker2Rq7TwKSXum5lThoZTnLqHJiFwlXVzS0kH4NQ3dV9TlK0W9+ cusDdOiY5VYPK4H9pudwTI4CL+2HtHu47JJe2sz6qxJKA/qtUe7QRquOZ1dzBJ9yFkdVdkt2wGjs kpz+pOFmS5zeJ0VZ2iKxzdx3/JNa0DQGU61Kyss3BtY+iFWcNUzhtcAplqZslimSKZFS6bkppTJK ZcJhomTJKXShKUtySlHRJNKSSlyJS2ppSlJSoS2lPKkH9klMITIhKgkpZJOkipScJk6Sl0RCRG6p KbFUhHH0wEKsKQPvSU9HjuhgBVpjtCVlU2aAK618VkoBclY+Sr9JWVRqtShFDdrdCHkGUk9g0RQ5 7goRu0RnoLTDkFzTuZCoNPuhbGUxY79HpKLcYURBrKKEErkpJJkErJnmAnKi7UIBSJ5kIRRXITtU 5BYyhOROENwSWMVFykkRokpgptUVMDuEgpmCmTpFFSMwmCkR4KGqRSFymSTpqmTeVdxzqqTVco5R Q7mNoFoMKzsU6LQYE8LCmBUgoBSBRUzCkohOgldCsRUN6IU596zbeVp3rNt5TZMsUEJJ4SUJZFkk kk1SxSKRKZJSySSUJKUmKdJFSySdJJD/AP/U6dhDyBHPdTc3932uHZDJBZo2CnrJGjnKVjSMOnu0 KTrdp11Hknlw7SEzQxusaoJY7GMcSB9LVQNpb7dpHgQk4va4CIaptLq3Hbq1FCqbpidErXNLoIUn NFmg08ihgEEh+o4QSz2T7eSoh5Z7eOyltNY29vzSpNc4jZYNUlKA/NP3p5LTBMoXp2h2jk77Nkbk KUzeSQHMIS3NsGh18FB7iRNYnxTegXe6sw7ukpI3e2QAE7AfpEwUI2PiXaPH/SRHGYdyD4JKXLtp niUnPLSHcoLQ1xLZ3Ioa5oAbp8UqUs4bnTx5pyZGh1SAeNXAFSaGuMt9pSUxOuvBUi+APao7ZdB5 HCUEje3juElJJJGgTAkfSQ5e4xyk3cPp6lKlJN1Z5OqjYCTLeFJiZr2udHdBK2kQ4JnMrPLdfFSc YMO4PCbd2CSl2Q3QceaIRpoYKHAPPKYAO0IKSlentMg7Spl88c+Kht0hIgd+fFJTMNA41Sa2BJKG Wuj2nVQDvTG4ukHskpM6Ha8hQLJJj7lIHc3UaJbCdAkpTNDodp807XAk+PioyQIs1UQHF0N4SUzl wO3lRJg+aZzyDDuT4KYaCNTqkpZxPLRHihEk6Ih399HdlFry4QR7gihIPaVG281Nn6QTj3DUSpBo GjjJ8EEoTZZYBt07p21EiQ7XwSENMEQkwBxkdkVLHTUD3hP6s+1+k91Ita72kaqLgBpZ2QUuGt45 CYBp54CRAHCk2rcNEkuTnvIZoPZ4rms72iV03UmuYNpMt/iuY6iNvtTEtfGPceK0meSy8RwHK0qz CK10sd2itWH2H4KjSYVuZHyQU8Hef0jviUCZVjNbsvePNVyikbLSnTJJJZAJAKKUoKXlPKjKSSl5 TgqCSSmZTAqMpJKZbkpUUpSUzlKVGUySmUp5BUUklMk8qEpSkpnKW5Q3JJKTSVGwJB/kncZCCkMp wolJOUmA1CszAhV6vcQFZsrI4TSdUsTa48p/UJ4TemVNtLhwjohb1CEhbPKKaHO5TfZzKHEFIy8z ylvKP9lco/Z3TEJcQUwDymL3fJE+zuUm4rilxBTXJ7pFxCufYXQojDdKXEFNcvLvJRMlW3YbgU/2 JyHGFU0weyWoV77C4awkMRx5Q4wqmkTGgTbnK/8AYnHhOenvHZLjCqaEmUxJ5V77GQYSOC48I8YV TQLim3FXTguCY4hHIS4gppyTypSQdFcbhOOhCTsFzeQlxhVNLcUi48q39lPAUTjEJcQU1pUZhwKs Ox3AKHowjYUitG2Ck+1obA5T5WjQqRKIUuXSZU96EnSUzlLcoJ0lLymlNKSSl0pTJIqXlPKilKCl 0pUZTyipeUpTJJKXSTJklM5TJkklMklGUpSUySlNKcJKXCmwoYUwkptsOiTXSVBp0SYdUEh1sd2i 1GMlsLHw5XQY0QEglj6W1XKFFzdE9GhRQW81O8aQmHCmRIlFDQuaqrtDKv3NVK0ILlZBlkrEt+kt Z7vbCyb/AKQSSdk9ZVgKrWrIOiCgyOqSaU45TUrFRcNEQofZIJQuCGeUUoTuU5YUZUCiFQISWo0x UyokJKYjlFaEIcooPZIKXEpFOExTlLIbkSChuCBSGKkE0J01RZNVunQhVGq3VykEO1jcLRrWXinR adZUgWlsBPCiFMJyFwpBMAnQSuhvREN6QU0b1m2nVaV6zLjqmyZYoZTSokqMqEsjNMSoylKCmRKY FRlPKSmYCUJBOjSloSTpigpaEk6SSn//1epLrGV7uSP+pUG2tOs+4KJcyv2kENOod+apNdW4CIUr GzJJcQTBOoSJdPvn5KJ95IdxwpQQ2Agpjv8AbJnb3RKy13uYU4Ba7cB8kzWtnjbKSVzYD5obyHCW 8qXoBhOuh/BRZQW6TKWilw4vENI/qlSNbnaE6hD9o+i3Ud1Mv3EbhqkpmHFwjuO6Re8HgOCE29p0 bpCdt752lsjsQlSmYa130fuUS3WGmSkS46OCY7eZhw/OSUu55Gh1KTa3NMD6J4KmDOrRJ8ULc8uN btAkpkWBrjIn4KEve0gyPBE2PncHAwna9vca+CSmJuZo2zlMSAQWGQp+qxxiPcOVIwOwJ8kFLF2v n4KPrFrtoEhSDy4T28FXtssiWt45SUneNkOaNClryfuVc2l4AEhpVlsbZCSmDoeZaId5FSiz8yCf NQPpudvGjuNwRyCD2hJTBrt4h/PdN6YmZkdkxHulxTP2s1JO3ukpcWNaeYKiHucHbeR2SLwB7W7h 4p2O3cBJS9Nm7U6HuFK2kP1B1/6pO6skhw9pQm+oxx3kR2SUyaHBuuhCcODxDm6KG9xBDzH7pUdh JmZHgkpKZYJaJCb1xoDo4/mog1QrmSQDp4FBLI7dQRqnaNw80htAh5Tl4B2gpKXaTHu5USWh2h5Q bIssHIIRXOmGFv8AaSUuRJg8cg+CQ2jUcKFohugMd0Bj/ds5aOyKm5LRoDr4oJYXET805rrHughO 4NsALToEFLE9hx5qLGCQRLXIzgWiWwU5b3PIRUi5E90xhx1EHzTl5cd3goPrdaAWhJTKHN+jqERp keCgNBpoU4mZdx5IFLldSYRZEyAFzOZqV0nUnCTHJ0XO5rUxLRoB7eK0q4JWZRYW6R3iVfrI7FFa 363xorrH6LLrerrXaJKDzPWqtl5PisxdB1yncA/wXPoJCyZOVFFK8pSmKSSlJJJJKUlKZJJS6Upk klLymSSSUvKUpkklLylKZJJS6SZJJS6cFRlJJTLdCfcVBOElKhPCQKUpKS0aPHxW6yjfqsCt3uBX SUPloVbMSKK+KzcQIzcYBTa5S3qD3CmlhjA6IjMWvuo70+9N4yU0zNTBwFEVNnQJbipNKHGpK2ms 8hTFdbRAAQt6b1E3jKaTbQEoZ4Kv6iXqIcZU2DtPICidvgg703qI8ZUlgSpaIBelvS4ihMWtKbY1 C9RLelxFSfa2I7JEBV/US9RLiKk+1vCj6bULeluR4ipn6Y7JjWD81Den9RLiKlnVNGoTFg5jVPvC jvTxMopi6tp7IL6G9kbeFBzkvcKacPqNe2FmrV6qZhZau4zcQWM7qSTJKRC6RKZJJSk8pkklLlMk kkpUpJJklLpJJJKUlKSZJS6SZOkpSSSSSlSnTJJKUnBTJSkplKm0ocqbElJgdFNmqhOkItQkoJDo 4h1C3scTwsDH0cuhxAAJ78pJbYOkKDHAPjxU26jcqljiLAQiguu3VFA0QK9QD4qw1FDUyNBCoWaq 5l/TVRyBXBpvMLOvMlaN4WfYJQSzrKsg6KrUrLUkBmE4TBOmrlyoKRUUglGShOKI4oRTlpYFROql KiSUlrApinITFJDFqIG+KGEYapKXCUKYbGqQb3TlMYQ3hHhBsQKQjhJOEimqKmq1UqgVqkpBDsY3 ZaVRWbirSrUgWlsBSCg1TCchmCphQCkE1K6g/hTUH8IhTRvWVeVq3rKvQkyRahTEp3KKhLIvKUpk kErypSownhJDIFSBQ0kEs5TSopApIZSkmSQtL//W6Yu2Nl8j/qVD7OL+ND9JTFxLTIkfnNUC9ji3 YYb/ANSpWNap9jSfbIRw42D9Hz+c1QYHbnBxj4ptm86CCNeUipky50QdSOfFM64P012+CQc14kkE D/OCnAZAkFJTBj67GwHEEcFKSz2uMlTYGMcQIB8+FDcddoDh5JKSB7axIb8kgN3uaI8k1e2z3dkr AAfADugllsY4zGvBTkhnkE24Wasdp5JFxIAJ/wDMklLPh/B+CGyl7RqZTN5O8CFOZPMAJIXFgZ9L vpopXPa2A4/1Sq5bucCHCFZIlu5xDgklA9kwZ0RWktbE/AqLHNcSwaAd1P0g3UHdpwkpiQ7d23f9 UoteWuLTAd2/lJNrY/3Nn71HYA6SNfNJSX1XEw5sJWbnQS2CO47qDD6Z3tBIKNO4bghspH6e5pJM JmWiuJ79x9FFe5oaXOEhBawObt4HmjupffSCXd+6K2xkeSgBURrOmiZpqdLG8jsgpk5jHaboJUhW G6TPihA7Za9shRbcxztpn28fmpKZ+6D6UGOJQ22W2N/SCB5Kbg1x2klpH0SogisbXGUVJCHcAacg pm2OIh4lvj+6l6m2APon85J4MbmOEIKSbtIOqi4tbqD8kF1gqANmpOim5wez2g6cpKZuLjw0ykyb G+8/f4obLdRBgDlSLXF08sPKSmJrfJ2EGfpSp1tLWgGHQk+wMMO0BHKGz+RqZSUnFsQ0iCVH+bMS pCydHDXuon0wIeZkoJXJcDLdQfpBQcWNggQ7wUGNp1bW7UaQowHCXgu2n6QRQ2RZoCfmh2PAO3SD 9FSbYHAjdA/dKrjaxwZYJB0BSSkaYO2CCNZ7IzSSTA1VYMNToE7fNTN7XnaJbpo6EihKXF2jmwe6 G5pnaSdEP1dhDXE6+PdStI0cAZ+if6qSWZrsZDmu3A8p/c35oTCK/br5FE9UtG4CUClxuoA+oXTx ysHNnldB1FhM2ERrC53qPCYlzWGPmVdrdqqTRuaS06hWGuO0EIrS32GFartWULCdVYrsSU2swC2s hcnY3aSF1IfIWD1CnY8kIJaMJk5KiilSSZJJSkkkklKSSSSUpJMkkpdJMkkpdJMnSUpJMkkpdJMk kpdJJMkpdJJJJSpSSSSUyaYK3cayWBYIWji3ACFDmjYSHX9SEhas85ATfaSqoxldbpCxOLB4rNba Sk+1w0S9sqt1PVCf7SFjm13im9WEfZVxOuckKP2kcrJFrlIWFH2VcTpHJCX2lZpcVIElOGEKst/7 UEhkzwqScgpeyFW3DkpfalTgpbSj7QVbc+1BL7TKqBpTwQmnGFW2/XUvWVKXKQJCacYRbb9ZL1lX iVPahwBNpvUS9RCgJxAQ4VWk9RNvQyQo70uFVpTYhueoOfCr2XIiFqtq57pKz1ZyH7lWV2AqNLSp JJJPQpJJJJSkkySSlJJ0ySlJJJJKUkkkkpSSSSSlJJJJKUkkkkpSSSSSl0kySSmSm1DUgkpMCj0m CgdkRiCQ6lQ1ELoaOIWBhneQt+swPNIJTuaWjRDDQ4qTn9k1YkooLoUnSFYHCrViBKsTARQ08jmV VIVjI1EICC5pZA0VCQDqtLJ4WTdwglkx4JVtqzaTqtGvhJASwlCcJym2vYkKPCmVBJSN7UEhHeEJ w1TlpQwmKkmKS1GVEqRUSkhZvKOxqAOVbrbPKQUyDYT7UT004ZCkpCPaqtohaHpyqVzYKBSGuEkk lEVxXCs1cqsFYq5CIWuxirUr4WXiHRatUKSK0pgnCQClCchcKYUQpIJXUHqSi5IKaN4WXeFq3rMv QkyRaTlFScoqEsqkgmlPKapdOmlOkpSSSZBSoTpJcpKUkkkkp//X6U2NrHtjd5qNZDXFr42uE/NT cXvENaIP0pQ2h7PzQW+P7qlY0jAY2jVh7oduIANOUm7QeTsPPkiOrfWQQN7exlJSGmsRu/ORdrrD tEAdiogVus+iWv7hFDAySOB27pKWax2geAXN7hLc2S2Nrhxqq7msY7fWSQeWlEJa2HAQO8pKXaHt aSfipRID3gkeShvc4x4Jnbg+W/Pakpk0VklwJa0pOoLB+jf33CVOXD4Ie5ziIiR9FJSUv3j3QXJ4 aweAQG1ixxewQ7hzVJtYjawncglK1rXA6SFU3uodJEs/6SNVva73g/FGeWRuKKEbbRYQWCWnw+k1 P9n3fQcWnwQttbSHNkSeyIayDusO5vCSWPptYZs0P77U77ASNus9inLq6ztGrfBRDTvgN07JKSNy HkaM2lJzyYJcAmh+6S4FMG7p2mPFClKbaywmTwpv2kaDVDrsa0Q72n/qk736ho0KSmVT2OMDRx5a UN9AH82fdKmDXaYLfmpGvadOAkpG0Sdzn+Seyku59w8lLaxskyCe6g19jXS1sjuQkpFS1zRDjIB0 lWQWO0f38UjDtShOsJPIJB9phJTB2O6lwNGrT9JFIa90EbHH8VCpobo8kHwRZBIAEnjVJSK2ouET uARmNDmw0qZBEFB3Wh/ubykpkcUzLTr+cm9F7yWA7QBoQk+zgPBGvKjuEljnR4fykFJGl1UMeJ81 EbDr27JmbgNDoNWlLY5xO+BPcd0ksS1rnbHt1/NdPKdtZPI1lRe41wdu5o/ORW2l4LoHkihHZayS 9ogj2uURkidCA7/qlEWh5LY2uOjp/O/4RKuk7dp9wB1/eSUmbBbvJBHkpOe1wmCUNtLKSXNJLD9J qb1e9bjAQSye4PjY7j80/mojb3ObBA+SG2you3N1ceeyKa951gAdklLP2wCXAiO6Cdw17FRsc2sS NeyQrfHiBqP5KSmTdJn3fuuRmEkRMEj+yqwe5romCNYRnNZZ7p2/vJFLkZu8gbgdoOp/N3LBzjPP ELfzbHEGr82Z+K5/P0CjKXNoc9jpb9yIyr275Ua27xHfyUdxboOZ1RQmEorHKsHozXJIblZQM2ve 2USsorxuEIJeZe3aVCFfzKdrlRKKWKSdMkpZJJOkpZJJJJSkkkklKSSSSUpJJJJSkkkklKSSTpKU kkkkpSSSSSlJJJJKUi1uhCUmoKTF5Kk3VBCIEFJ2WBqRvJQU6HCFJHPJSBUApBKkswVMIQRBCCkr dTqjDaq/dTDkLS2QWhM4hB3BSDkCUpAQVPSEAO7okiEFLyEiQobwolyVKZHVNwhlyHPdKkNgP00U w+QqW6AmFhCHApuOtIS9WSqLrXFDFjgiMaLdQvUS9Z4yHJG95Q9sqtuE6KtaSoNscAovsKeI0q2u 8oam7VQUiFJJJIqUmTpJKWSTpJKWSSSSUpJJJJSkkkklKSSSSUpJJJJSkkkklKSSSSUpJJJJSlNq gpsSUl7IjENTYgkOv0wS6VvMJ5WH0wclbFZmAEgptvdpKVPMoF9sODO6sYxlFRdGsAtTOfIhSrCD a7a+OyKEdmqCVZezRVnILmllnwWbc3RarxuJVDIZEoJc+o6rRrKzWfShaNR0SKA2QUpTNOiUpq9c qBKkonlJTB6EUV8IZRC0oyoFTKgUVrAqLtOUQqBCCFVt3GFoVVlvKoU6OWxV7hqnRQWAapQi+l4J xUpaQhOg4VDJOq1izRZmS2ChIaJju0YjlMpkKKhK4qCsVKuEevlAIdnE7LVrCyMMwtepSxWFOApB IJ05S4UlFOEFLqLlJRcklpXhZl4Wpcs29CTJFoOUCVN6GoSyqSSSTVLhOCmCdBTKUySSSl0kydBS kkySKn//0Ohax7mFn5o1Dh9JAY4MMbvb5qxcwEGC5ruzh9FRreCNro3ePKmY0nrVTsLfmFBrD/g3 w0KQrMbWAB0c+KD6JJ22Rv8A+i9BTZaWidxB01UfWpeYcRrw6VB7AYGza8d5+kq7saSN4AYUqU2a iWgtc4EDSQoQ2wEayDz+8oNqrqG6s6fnBEraGPkS5pEoqZsrDRpoFD0hO8O2niUT1HUu3D6LuVB7 aXn3e08ygpPY31G+7Q/vD85CAEBrtUm+o8Ebw5naAhucziydO4SSv6DhYXgxp2/OUhY9o9QDc3xC etzHvI1M8JgDUYJieEkLOdbbDmCPipnUTu2u+9jlFjrG8kbTrtU63tLSB7Qe3KSWb2iB6vB/dQaj qa3OlnLSVNjHFvu9091UyX2uOwiCzWf30lNx9LK5e06zJTesLOBog4+Q6QT7QdPciV7g8ubETG78 xJTJzTtPiNQU1bvVkjQxqph82GDDxz+6U9tT3Hc0xCCmLmPFe36Q7QnYHBkQq1rLBXNbvdy5Gqm+ sRBI+kkpbUP3d0V9zgJPHcKAAmBr5qbKmj2nVJS7Ld7drBwmY5726aaaIAAYZGrihUvfW9we47Z+ jztSpTdsn0wD8yEGwNdGnu8fFPX6ZAe52p/ORnP2kAOBCSkbWttjZyE/pu1HMpp9QyzkJH1Sd7hA hJSzQGt2AafkRHvsYJdqFGxhuaHB0f8AflAvNWoBIQUzexzjBOiQYyCNBGiX2kE7dpk8KL6902Vt 9wPub++kpmGuaIiWxqgVXMrBDdR2BURktiayWidQUVr2D9JIKKlNt3kGeeYURQytwJM+CdtrLDuZ 7H9we6nIL9hHuiUlMbaq7mSfa4fRKYOsrLWOHuPt3fvKZrDwC8x4KF1Be3aZ01a4JJTlzWtO9v0e EGtrbXB4aGH8qbFre1x3+5xCnVLw42ANIOgSUxfpDtsmYRDSLSCxxY8HUFQsqa7UAh3/AEVB7b6/ fURryx3/AKUQUysDmu95A8lFzfpOb7j+6Powhkl+vD+4KEPVDh6ZIaPpBJTZDp1LfmpkgfS4KrV1 ub7g6Q46tVnZDfd9E/nIFLl55LR6bYdu1j91c9ncLZzWit38qfwWRnCSYPKYUuYy01nTuUnt2nc4 ypASJOsd0JrnO55RQzGuqK3RD7KbElNqtWW8KrWVZYYSU1cuncCVh2M2ldPYJCwc2vaZQU0SmTpI pWSSSSUpJJJJSkkkklKSSSSUpJJJJSkk6SSlJJJJKUknShJS0JKQaVIVkoKRp0UUOPZEbiPPZKwq 2tCcK39hepDBf4IcQRbUUwrjenvPKO3pVh7FDjj3VbnQnC2GdDtdwCjt+r9x/NKbxx7pcJOuib9W 7Ty1FH1ZsPZD3Iq1eZClK6kfVl3kERv1aPchD3Ip1eUkpwV1w+rI/eCcfVpv7wQ9yKtXkQSparrh 9W6/3gpD6uV/vIe5FWryGqcyuw/5u1/vJh9Xaj+clxxVq8eZTahdn/zcq8Uv+blX7yPHFWrxRkKJ nwXbf83av3kx+rlX7yXuRVq8QQU0Fdv/AM26v3lA/Vqvs7VL3YqovElRIXaO+rLexQnfVo9iEvei qi8dEFFAldO76sP7IZ+rdo4S96KNXnYgIMydV0jvq9d4IDvq9cPzURkj3Vq884KELed0K4fmlDPR bf3Sne7HupxIShbJ6NaOxQn9KsbyCj7ke6nLhNCvu6e8dkF2K4dk7iHdTWSRjQ4dlDYUbUwTKW1N CKlkk8JJKWSSSSUpJJJJSkkkklKSSSSUpJJJJSkkkklKU2qAU2pKSIjEPsi1oKDs4BgLVpcHOAWL jPgBa+KJcCkFzJ7HPtLvBaGKI0TU1BrTPcqVI2vhFBdKtRsq3EHwU2CESEUNa0Kk9aNgVCxsFBc1 Ih2qpZgglXrdDKpZWoQS5I+mtCorPd9NXqykjq2W6qSgxECauWOqgUQjumSSjcENwRnBQcNAiEFA QoEIxEoYCKxhCiQiEKDkFKx/5wArdqrgLCqHu+a36nSAnQ3WySBqkCAphshRc1TrFnOELIzHSdFq kFZuS2Sgdl0Rq5xQiNVYLYQXcqCS9YI1aCEatNCHVxCtepY+KteoqWK0tsKSg0qactUpJk6CVJin TFJLUuWZkLUuWZkISXxc56iiPCGQoSzLJ+E0JJql5ThMnQSunTJJKXhNCSdJS0JJ0kFP/9Hom2hw 2O0jhVmt952ghyNY972jbAI8lOq5xMGGn9781SsaAEyDYdFZFjLPY4Aj95CIdbaN58ip2UsZ9GDK SmD2GkEgFzR2TNtZZ9AGf3HKDWXsdsYC2U1tVxOp2OCKmbaGtO4CHHsnrL2WE7DA7BPTW8NmJd3U mC0mNGlv0mT9JJSjY+x0Vthp+kHqWrzstAO3hI3S4Mc0gEaPCZlrS7aTLh7UFKcGN0Y7Ye0ogAJG +HH+Snsa3U2NJMcj85qrsfWxwsr1B0/d2pJRQ8ucwN4OhHKLX+k9287hyCrLXuHvcAD+8PBIyXbo EO7pWhg/AbaJcYPZwQ2bq3gQHR4aKQAaSRx+6U1brHkhwaWApJQXMexxsqJB5cwn2ojb3PGrfcVB 59B7toIns5CdluaYc2O6SEtQO4ssBP7vxR8dhdv126w5qEHzDqzJ5Rxc233PG140ckVIXUAu2tMO HBH7qk8byPSe7c36bSk7bqeY5/ehM/Ydp3an2n+UklHa6ogMta6t/wCY795GbiVgb98eEJPNtbdh bvaDoe6aquu47wCB4fupKZDdBIaQ781wUd4uO130hqiM3MeWuJjkPU3bbCdC4jwQUxY0QfJCfta7 ae+rSi1l4MNh3/RQ3VMtIeO3YJKWj1G7R7mlDNUsNE7fAogYQdzWlpHefpJV2v8AcXAOYD8IRUvQ 0Vj03SDH+r0THs3h0umD3Qa2Q4O3afulH3tLpPteP+kgVIXemHlrDP7zPNSolstIkfun6SI++qdz va4+2fFSZ7dYkpKQUuIsLWkAfyk1jJdPI8WlSe2D+k1B7hD2sfqyZaYCSmde0t3NRm1e3aXR34Vc GsD3MOvdEdv2gxMef5qSlPbcdRBA03IjqdrQLNSfBCrtbYTG4OHY/RUWF0OZb7Z/D+WxJSVw+zg7 DI5c1yi/d6ZLHc6qqyk1PDmWS06aoktrJFcwfpApUpILWOaWPGo7d0VrNvvY6fJyi+xlUSAQ72k/ upnXMr+kTP5un0moKXOQJDRyeyI2WhzgBHcFAtLnODnQR+Y4Ib7Gh4InQxY0/R/4xJK7rtsA6hx4 /dSe6xmrNJ5UhEmtzfbGjgofZ9w3McSPNFSRjyR7fpjlv7yIx5cNND+c0oUFpkawpm4ubuAkfvIF LmdR2ggDU8OCwMxkra6g4Osa1nIHuWRnNnRRlLkQDO/lNWARopCxtbHMcJJ4/koDbDEIobBOkKTX IbSDzyiBJTYYVZYVTYVZYUkJnHRZWe3RaZKoZgkFNS4pTJ3CCmTkrJJ0ySlJJJJKUkkkkpSdJJJS kk4Ck1hKCmCeFYZjOcrtPTXP7JpmBupzAwlFbjuPZdDjdGJjdoFp1dJqZyopZ4hVF5GvBc5XKukv dwCurbjVs4ajN04VeXMnou4XnKugPdqRCu19AaPpELYCkAoTzEinhDnV9GobyrNfTsdv5sqwUhKj OaXddwrjEoj6ITjGpH5gTpappzFPCkbVWOGhEAaOAEAOIUg/xRGVHC2A5PvhBDk25O40Um9RIPQd yffCXGqku+UwcQh7k+5LjtVJN5Tb1GZTp3ESql9yW9MmSsqpnvSL1CUueEuIqpnvTeooQU0FDiKa Sb0t6FtKUFDiKqS7lGVCClBS4iqmcpElDkpElDiVTMlMSh6pSQhxppJJUSSobimLikZKpnuS3FCg 908wm8ZVTIuKg7XsE+6FEuCdxUikTq2nloVd+LS7lqtFyCZKQme6aaT+mUO40VW3orDq0rVIUSE8 Zpd0GLz9vRHDjVU7OlWN/NXVEKBU0eYkFvC8c/Cc3lBNBXZPa13ICrvxanDhTDme6OF5E1kKJBXS 2dMaeCs+/pzmeanjliUUXJSVmzHLUP0ipLtCJJSLYUUVKSSSSUpJJJJSkkkklKUwoKYSUzCNVqhI 9KBSG9QeFvYwhvxWHSIK3cY7gAEAkuowSAPJL04dKkzjzT2O2iU5DdrEhEQcZ4e0EKxCKELxKo2h X7eFn2u3THZBIado0VHJ4Whbws6/hBeHJs0ertRVO76QVmopLTu3GIgQmozU1cGRCZSUZ1QXMXDR QPZEcdEMpwQUbkKIKMRIQnBFYsoFSJTEIIYV6OW9jjcAVhNMOW9iN0To7rS32N0UDWZVho0TcKZY iFcqjmVALTVLNRSN3CeyCVWcFesGqpPGqryZGCLXooQiMUYOqnSxCtalZGMtakqeKwtxpU0NqmnI ZBSUQpBBSkxUlEpJatyzb1pXLMyEpL4tF6gVN6HKgLMqEoTSnTVKSSSQSukkkkpSdMkkhSSSSSX/ 0ugydrAHgER2+khV2727gIB4KZjSHyNJ1LXe5N6Lpd6erSdVMAxpbd+0Pc5pbx7VENL9Ww5CnaI/ On71NjHVO3lhDT/mpKT0EEFjydw4b3Q7GvDXbmEwmuMGYJM6D+T/AMYgOvyGkkuO390pKS1McwCx khp+kCnbfDwX6k6I1DmFkCZKD7LCa3ggfi1JTN1voRLSD2P8lCvtFjhY2s7h9I/vNRmY1shjX7m8 jcoGd5riS1BKq8uxpLmMJaPFFrubaJfIc7hCqfB7ieVJ4pc3WQW67kUNdpLXksJG38wqwy4tb7Pc D+Yfa5PXjifUoeC6PvUBa/b/ADfn8EEqbnNdDrGlgbpuj/z4mkB+9p9hOjkQsFvvs0d/J4QQzcfY 2D5JIbAu9QEgiQY2EJramuh5Ek+121PUy5hcZAJ1hBqfYHH1CGud+f8AmpJWbY2t+12m3siXZJ/N G1v73ihWUWCwukF/b916LVYy1u2068bf3UlLVgucBu9vipnGY1wAMHlqRuDZY2N7fon81yqW5Vj4 JABPP7qSG5Y5ofsdInzTgvYYYfYfzlWtda8CsQfNFx91LdHz3LCklObaXGGvAd3UH1Bojedw4LUH Ki2NwH8kjlSZlNqHpn2nsUFM3NY6A18uKib6qX+4Oa48O+k3cpvxm6WaB3A/lIL6fVI13EcoqbNG S15IJBJ4H0UG+dWO9rTrPdCcwDRkbm+5s/8AntGGRDRvZqeEqUhcXPaKiS1sc/8Af1ZNTg3aNXDV r/3kmudXqf8AMcq9jn1awdT/AJqSklrLLqw8abTLm+KLS8v/ADtwHb85DFj4JrfIPaEH0HOcHsO1 44SU23UMbJaYHdpQKqi1x/OaeCptfZze0u/lNSN1IG2Sw/SE+CCkdzPUbzHkf3lJ94rDY0193mEm PDWw73tOqVjGOaOxGoaUlKHp2PIrc5sD/OTM3WtJJAA7KYaA6HmIHMJ5bXXO31NfzSklAfRsAkQ3 v4qVjWOZtEkD6B4R3sZbtc3R3aUF3DgBrPuZ/wCQSUzqqDWQXSZ+iVL1HMadPcPohVq3NAgAyCrT qzuk8Hj+skpDWQKztABbq5hUqsql7Cdpg6WDwSex9xIcBvB9v5vsQ7C6tpBEx+RJSUNewBrXQD9B /wCb/UsQfful8gz+YfalVazcWtJ9M9udqXoMrDi4knkQgpb1Glw2nvqrYDNe0cqnO7nWfJW2WBrY e3nRIqDl51x3bSJA4Kw8oQtjNBDiHDb5LJvghRS2XuRed+ndVw3aYKsXtIchN1I8ERstZGNERqi4 J28oqbDUdiAwQjNKSExOip5QBCtSq9/0SmpcOwQVBEu+khpyVkkkklKTpk6SlJKQaSj145cgTSkA aSisoJWlj9PLuQtOnAa3lQTzAbKouNTgOf2WlR0k99Fq11BvAVhrJ5VeWclcItSnp9bNTqVdrrDe BCm1oRAq8pFeAprVOFGVIKIzTTEtThqmnAQKWIapQnShMSpOnhPCNKYp06dHhQsAnhJJOEVKhPCc JwE/htFrQlCmAnhP9tFsITwpwn2o+2q0aeJUi1QMhDhIVa8JEJtyInCNqRwlCJCeEfbVbCE21EhJ H20WwDU8KSYlHgCrWhRMJyVENKaY2q1iltRNqRKHtptEQolEUCozCk2wITQpFMmUliVFSTFMpTAq JUyopUpaE0KUpQjSkZUTCIQhlpQ4SliQOyGWooakWJwBU1HVlCLSFfLENzUdQimiQoOCuOrQn1p4 kimjZU13IVZ2KwAx3WiaygPbCmjkI6racS/ELSqj6yF0LhKq247XK1DN3WmLiEQmV27GLVVc2FYB B2WsEkoSRUpJJJJSlNqgiNSUzRqUEo1KBUHWY32gha2AZ+SzMY7mrX6c2AfuQC4unXPKbJdLDCk1 20IbxuTwhL0mzQsPZasSs3Dp9M7vFaYSWhBfo0lZDJIJPitTLdDVnBu0ILgisCzMoQtRzZWXmH3F Jc5N/MqxSeFXyEWgoLTu6DOEcIFR0RwmleFyo91KFHuglT+EIlGdwglEKKx4QXcIpCg4JywoymTp EJqmHBW1hWEALFOhW90+uRKdHdadnTrJIU9qdjYCmpmNEWqpmMMSr6rZerEUh525VHcq3edYVUqv NkYwptCaFJqjvVLexlrUhZWMFrUqeCyTZaiBRaFMBSLVwphRCcJqmSiU8qJKSmtcszIK07lmXpFf Fz3lDlEeNVCFAWZZJIJ0xcoJ0ykkpZOkAnhBSySeE21JS0pJ4SRQ/wD/0901OG14geaLeXt2kD+t tQJrbDmgkO5aUzrPs5a5ugPBUqxjbcC8FgEHhw/6hFdfe1vsO4DRzT+65CsvFjjLAdfpNUS57hzE cEfuoobNbHhoDwf5LpQ7W8tOpd2P/fHqLbHUCbHEMRS+t7YHv8I+k0pKRUMLWy6SO6OGCySwncOP 5ShTlWRtBDXT+d+c1EPqF+4AEdwPa5IpR1ZLHyDIsHM8oTbDJc7spWltTtz2HXvKFZVW/wDSNLgD 2QQnAqnefcXDSFAPsYPUqIBHtcx6Zgp2xB3eI/NUhW0vP5xjg+1yKWHo2FvqsbDwZ9v0HJmZFuw2 B+zX6BRGVupAcywjyco+rY/dtG7d9NsJKWpAvdvB2j87aUW2l7zvrs3+BZ9L+2q7am4+tstdHt2o tLRYd1ftcfzm/wDoxJDB7XOAO8iwGFO3I9J3o3Vy8iQ6fa9VbWu9Ueo33jQu/eR8moFocZDgkpLt DW7iCI4EoTLnaEtBPijV49wbAMnnVEqfsJDxB5I/eSSpnBNg18E3oVWD2g6qDsismKveD+b+5/wa htMneHNY7/ooKZOwdhHuJI7AqRoYHh1U7oQWlzHRJIHBKsi0AhzSJ7pIU2+tuhbr/wB+QGOa8F7x J/dRw8v/ADYPKC6+utx9Ruh/OCSWFruHtrLWfnay1WQwPZvDof8AmlJm1zO8cFI4rdpFbg4H6Q7p KY07bTtt0uGqe+xzHDX2n/olVobY6D+b7Qfz1YdSSQQ4aeP0klMqn+sNphzgPwTTZVADiQTHuCE6 ljHEg6/uhN9ptokWgkct/kpKbDgfpO0b5JxYN3pgADkFyr43q5YdMGR/VUzU91ZAO4j81JS9t1tR 37TE89kG93qNLxG5wTeqCyN0dnNKLS9hYQ/kfnJKYYDixuwj2xyroHqNI/OHH9VBDmNqG4gfyT+e o0sZfLw012NHYpKTOYHN2k7XDhUqsi2r3Fg55artdjXgBpk+KC3JeIAaHBph4+if+MQUjvGz9MwF 9f0nA/mpXXNrLSwHa73Hujit5ad2jJmP5CHYaWt/QOlw1b3bP7iSmTLAZtrEiYcp5FjLG7dwBBkD 6O5qr0312e0ghztXAeKIzZQdjhubP6N37qCmRsk7an7tJhwQHZbnjb7gQfd+6iZPUDW/0/Tgn87/ ANGJVNsqbJ91bhDnfykVNdjBv3N+aladjv5DvBTfjvbtfX4wXfmx/LQbbJshxjafpNSSl9R4cBoG +H/mavsvAG0auVJ7mvh+hM9v3VYA9Ib/ALkDspzepEuIaBqeVkWN1Wn1F7rHiT7BqAs9wUE9l4cf KIMtiDPP/fEBuwmO8KzkuY1zg4anj+sq7LGuO0iCnR2QWIITtOqd9YaVAHVOQ2WGUdpVWs+CsNKS E0oFvCKEOzhNS4t49yCrGSNVXTkqSSShJSgEZlcqVVRctPHxoUc5iIUBaCjEJWpRigdlOuqFcraq U8pK8BZlaO1qcNhEaFXlJcApgRQEwCmAo+JdS4CkAmTymEkpXAUlFSCAClwFJRmEpTqpTJOoSnlO CGcpSoSnlJTMJSm3JpT9EMpThR3Jw5PFKZJ5TBwSkFPsLWYTyhhyW5HiVSbcnDkHclKPGqk0hMYK DKW5DiVTMhM16iXKMppPZKfen3KvKeUeNVJ96jvQpSlLjVST1Eg6UJOChxKpMICfeECUpTuJFJDY OyiXIcqJKaZJpIXqO5QlNKjMk0zlNKhKUptpZTCYuTSkU06qVKYhMVHVNpLPam4UHPIUd5TbTTMl RJUdxThOBKKZSmLk0piU+9EKlRKRUSULSsQouaCpJkRopA6tBfUrZUHJyGg+lAdXotEhCfWCpYyt BDluZPKpX4/gth9UID61PCZBWkPPvZCgr2TXBlUiroNhjKySSSKl1NqgptSUylGpQUalAqDrYj4g FdFhNGyR4rl6tSAuqxgGtaPJALm0/RsoTNVO06QoMIJTkOhj8K010qvSEU+0ykhBlGTtVJ/Ks2He 5Ce3RJIQlZGYfcVsFY+SJJ80Fzk5PHkpY7kspuihjHhJaXUqKshVauFaHCaVwZqB5UgmcguWPCg4 KZUSElIyJUEU8oZCctKOFEhTKYpqEJW70qyGhYpC0umOhGJ1QdnoJTSotOiSsMTLcg3uBEFTKq5D oRSHFyR7iqqtZPJVaFVmWVaFJqUKTQowpt4vK2KVj4/K16TorEFkm61SUWKcKRYpOkE6SVkxUlEo Ja1yzb1p2rOvSkvi5zwhI75QioJMzBIFSTFNUqU8qMp5QSylOohPKCmSSinlJS6SaUklP//Uv2Wu c5riTP7qn65Dw5jeOd30Uze28a+KsVaPh8DyP5ynY194v0Y0McoMDxYWFwa6P7Kk3GFxd6Wkawo7 GE7XgsI4/wDO0Eq2W6h7ZaOdqiHVATu+XDk7shriaxLXN4eD9JQNVDmgl0ykhl6VpaS47x/0kMWP c5pMgt4KevHbTL5JaD2/dRH5lDHAsdLT3j6KSmbrWvOx4EH8U7qR+aHAjukX05MNB2nsf5SlZUaT D3aQkpizI2j3yG8F0KA3udoQ/wDdd9FGqYWktncx47H/AF/SIWOC4mv8wHkhJKUWm10XeyO35qVr yXt9KCzuWqbXBjiC7+q6EK+2phAr9ryJkIIY2Y7L7N7HjePpNJ+knFrG2B9R1ja4fylVOOyx82Ag n/CI9QbBqsEj8qKUj8x+4syAwsI/NUK2/ZiY91Z43a7UR9FZbuAII5lQx6muE/SjtKCmR3WsFtYh ze89v+LSZlW2kCwN0OjkKyx0gNOxo9wHipgjaS4au/OSUu8it29pDZPvH5v+emJebCQZZ4BFZdX6 YpLQ4FCdjspG5p2tnhFCxyHNfssrkfmO/eRcdpBc5o9v7v7qI977AGgyOWt/9SKNdweTJII/NQSx bkbHFj3Dae8fRRKnOfuaXtLfggWMZVL3ElrtWO+lt/4NMwNsBjR44CSEZY+mbqvoH2varFDtQ1zN D+c0qbJtYY9sD3s+CG2wuYCNKDo74pJQ2sLLDVund2ARKsVrTFgPlu7pPodafY4bm/Rd+c5QNlvt Ik2NO1wKSm16bCCx7dAYa785qm55aIFgmNsPCi2x+0vaPKyv/v6DZuuIrsEs5b/JQUiFZkQ4SOIR G+oWkh4EHhPTi1yGsPuGoIT2iwuJBBAHZFTF1rmtIuYHz+c32uU7KR6ZsY32lsIjmj0N7QIidfFA urHplzZG4cN/eQUipc81Nf8ASrb9Jv8AKU/XJftbWWnlp8k1NVbmCAWPPOvtcp2F3pkNMWM+lP7q KmLrK3tI27Hc88KItaCN7txOm5GYQwRb7ht9rvJPWzcAxjQ4Ea/yUFLHdU7YHHYezvc3/PSNdTTo Ig/SH0NyQyi+cfaK3eDvzv6irOe2sH0JB4fW73N/4ypJTesaCzdtI/lNVR1RulpG0TG4/nf8KrgG xgIEg8iUrS1rdJ11/kpJaTXupHu1sYY9351f+kR69j2atO130hPtTtx7WO3sIBOrQ73Dag1F4ljg GvBn+TtSUlqp9rmkkA/Raq9jS3YH17BPKsCx7mlrawe/P7v+jUC997WOkhvcOSUoWtY4gR8FZY5u 0ayf3SgsLQ8mNHd1bdiDaHsEn4oFLi5sh5nQjss0D3QtLMYa3Q9paDxKosAJJVfJsvDg9TEWgEae KAys6nuFc6pq4AnjUIWO3WZjRPh8oWlDuJ5TDRTcDMqATkJq+Udqrt5R2JKTBQepA6KL9U1Tk5Q1 VVXMrlVEUrIjGyogK3j1bikTQtTcxaRytSpo7KtTXGiv1MhUJzssgDJtaMwQk0IjQqsjqvpmBKmF EKSiJtLMJ1EJ0FLqSinCSmSkoAqUoqXlJMEpSUyBTyoSnlEFC8pSopJKZynlQTyiFMpSlQSlG1JN yW5DlJHiUz3JblAlKUrKkocnlBlIvTuJFJtyaULcnBQ4lJJlIqEp5RtTKUpUJSlC1M5SlQlKUbUz BTyhylKVqSSmJQ9yYlHiUy3JpTSmlMu0slGUpTIKXlKUySSmSSjKeUxK6SaUpRtTEgKCm4qBQSpJ MmlEIXTQlKaUVKKiU5USkpZMUimSUuoOClKRTgpAmdqplQITgUIT5oFjPBWXITh4KQSU5WTXIWTY 2CuiuYHBY+VTtKu4pdGOQaSZOdElYWKUmqIUgkpkrFCro9CB2UHRpbLgunxToFzWOJcF0GO7RNBX FtXPhPQd5lUs5/t0VvAO5jT96eguxVwpXfRlNUNFK5ssIRQ59btxJUniFDDaRuBRrUikNK3RpWZa wxK1bx7Vn2AQUFzjZQ0QMfTRWckaFVsdBBdOnhWmqrUrLSmlIZpFMpILmJUVIqBSUohQcplRcigo imhSKZNKEZVnAfD4VdwT0Ha8FK6UQ9NW7RElVaXSEZWQWFm5yoZL1afws7Jd4pE0EhoWmShDRSed VFVJGyyLwpNUVJqaN0tmjQrXpWRTytWgwrMFkm8xFQmFEBUjGyTqCeUkskxSTIJQWhZ9wWjas+5K S6Ln2BCLUd6CVXkzhgWpoU0yalhCaFNMgpYJwUkuEkLpBJNKSWSSjKSSn//V1Wuu9I1+mHEd/wA5 qZuSA0eo0OIHdWKB60tY/a4cBVn+pQ8tsbH/AElMsSl4sAdIYHfR2oRda13p2wdZY4j6TVVdW2pu oO0nkdlbZaxwhx3NHDj+akhm4WbnMc1sRuag1XS6WMDJ5B1CW1zhJG9n730faizWxu1zdzOZH02o qZG4QWObD+Wvbx/mIDnMkeszn6RarD349m00u9w045CHYKmuEiHDkfvIBLBgoLvTaZaeEr8c0loe 4uqP0e+xTa2g/Rnd20RGMDpDyZRQpoaWlgMMOoP8pBrcHPitx/lN8VYGPuafeNp1On5yrXVlxdt0 8S1BTZbiuDTBgxIr/OQvtj3x6rNzW+XuYh42PZYd4klvB/OajtuurfO4OB+kHBJST1WkS5/6I6jR MKxfusbrGhb+9/LUG+5zg2JPA/NTFzmWBrwWOP7v0XIJZ1ttZyJBET/6USO1kMtO2eD+ahWAMeQC 4nvKK2p9lRqJnu3ckphY8AiddITPDmV7wQ7tCntJY0OIOug/dcnuOxu61sVdy38xyKGu17qx9GHc yixU8/pDvDuQ381yNVfRa3gvLUKuwWWSxu1h5HmkpXpPoOh2VnjclZkWExaWkHgtH0kZ2OwyHy8d igupYa/0cOAOoQUp1voWbWEOafpVEfQTi7dqwAiY82qBxq2HcJDzwPBFq3x+66fpeKVKQOcSdzwd 3f8AlKy2sV/TBNbxBHn++lZ6h9ruT9zk7bhW0ANIPn7mtSUh+ztB8K/j9FyLXY21pc32vb7TP538 tCaLXOlkOb+c1Jlg9QBoDJCSU1BvYxzhDnfnblGy7SHVxtggg/moWT61rD6ToLT9EfnJqnF1f6QF ze4SpTKxs2tIa4Rq4fvtUrbdw2sZoPdP521DLOIcXVR3+kxDBe0i5stA0J/eb/LSU2GWWUj1K2Es P0mqZeHAFhLNPbp7VSys6+Qyp3tHMD81ENlrqgWQfEFBTaa25teyyCyJY4IBu2sk8j2PafD/AEqr iqxsHIJ2EabeyPXR6hmvUnkPSUuxrKfYCS6JZr7Nv7inXYGtAcdjXd/5ag4tDPTtZDRw9iGyl727 QO6Skpaw6XPme/5ycWVw5gERw9JhEFlrQ6B7T+dCr+rLXMZrpARUnZi2ufvaY7FvYpnl1jHUgkOa Z2cg/wBtJ+0UNLyd3BSbWWua+lwcf3EErC+q5jaq3ODv3eNjv/SaIx7Xxj3y149ocNUB1DLLC4CA fptH5j1LKodXSLWH3MM6/SSUyeA4lgcS5uh81A110uEWQT2P5qi7Ie5ocXAg86e5Tc5z4d46ahJS 4sfU7ezWPpfu7VpNzWtAO0if3VnV12McDIbCttHpAkwfD91ApDj577H2zY4uA+i391VmBHynEvI0 E66IFfKrZflXxcjPDi8sEbeT+8gN38N44lT6ppf7fDlRNnpjaWp+P5QtO7C5hboeQq4Kk9xdqVEe KehK0o7Sq7UdpSUlBTPSBTPKapzspU1dylUAlFLKtklbOHT3VLGqkytmivRVs0+gXxCZjIVkNQ2i EVqoSNsjNuiJCg0IgTErhSCYBOEylMgnUZSlFTKU4UQnlNUyCdRlOCiApknUQnlOpC6UplFIhTKU pUZSlNSyBTyoSluRGikkplDcluStDOUpQ5TyiCpnKUoe5LclamcpSobkpStTOUpUJTylamcpblCU 8oqXlPuUJSlJTPcluQ5SlG1My5NuUZTSm2pnuTyhynlK1MpTyoSmlJTOU0qJKUpKZbkpUUpSUyCk hgp5Q3SylPKhKRMpKXJQypEoZKCV0imlKUlKlJNKYlFC5KjKclRlFSiolOmKSlpUlFOnhDByg4yF NyEUjoliVB4UioEpwKkD1RyWbgr9iqWqfHKitLiWNgoatZDYKqlaANhhUpBRUgipcKzj8qurGNyg dkjd1scarWpMLJxlqUqMLymtrNhA8StOioVaBV8Nu50ngaq84Hb+KlWFu18IvIQKDLQjtSQ1TUGn 5oVogK3YO6BaJSSGjbqFmWclal3gs28CUFzk5I1PgqdHKu5Ko1aPKSJOpWdFZYqlatMQKQlShO1P CYvYgcqMaIrRyogJWpgQoHVFcEOEUIyFFTKigUI3CVBFchoIdbEyZHmrnqrCps2FXxcCFJCWjGQ2 LboWbdbuRLbZVRzpKU5LgFkkydQErlKTVFSCA3U2qeVp0rKqMFatGoVmDGW4wowQWIoUq1knUVJJ SkiklKCUNiz7loWrPvKRXRaNiCUSwoBcoJM4XlJR3JSo6SuUxSJTSipUppSlMXJIXlNKjKUpJX3J JpSSU//W0WhrxtBh3g9HtYWsFbhteOHfS9qq00tuaW2CSNWuna7ancxkAMcS0d1MsY2hzBtDg4Hk BQpZvmRuhWK3MYNxBc3vCVhqqAfrB+i4dj/wiQUx2B7fSaSHj8wqbJrDSHw8HuPap+oMjbwdvBHt clbjet7i8SB9Hj/1YkpsPoj9IAxwOj4/M/4VVW3VtJqtZv7Ez2VWkPGsEAfS2q39orA3NA3t0g/n tSUtjMua0mkTtPf85qZ9osa64gh40dCG6xzHyPokSYKs/ba6h6jJ2H6YSKEGPkPAI1aCOW+5DYBY JY47u5KI7Lxgd2OXMdxtI+k1yEHWsdLgC0/nJBLbZoAXS5pGuz2vaUO+q14ho1Gv8pzUbd6Tdz7A yPAShXv2vFlJl3735iXVC2PYHt2OEAdz7VOutjnbmP3Fuoa4/wDntSfm5FQhzWHcJmFOu4tLZaGl /iPaElIMt7LW79hY8diU9ZL2Nk7h/wBJqM91nurvGn5p/dVXHbYd1TOx1/qpBSYUCswJE6gSj+va 2BsD2uEPCeyl4q2GHVjVr/zmIVFx5ILv6qG6WFgbW303Nhv0mfvx/o04sa/a2mB4hyiSwPBef6s/ +jE1p2PDC0bSJa4IoTN3D9IwzGj2AqDX4odJDmWHuma5redH/lUnXvI9F7CWHVrvBBSO13oWQwEl 3Mqz9pmGObLe/wC81VXPa57Wtn4OR3m6p5dYyXcbv3mpJamTvpcHtcYDtP5S0DbVfXLyf/IlZ1m+ wAT7SZj+Uj4rbG2aDX90/nBLopeqxzbCHOkj9385FdTU68XB4BI0a785yGLKGWua5hrI7n6KJbY2 +GEBxI9rmJWpm+/aSXEN11ak/IfQC4FsHhyC15/mbQPiVJuJWxhcPc3wSUsOpWAHdUD+84fQISuu ZSQ6SKSIH8n/AINDxhZYx7WGJEtASp9W5npXw5vdse5iSmTmC9o9M7SO37zEO0UVVlrpLj9Ej81E rD6W7C3cwH22j9xQcxrZMmXH2/yklIcYNcNhJBP0p4RT61LTth7N2hRQ6u47HM2wOToqr2OZW7aS deAkptOdW0bDpa76TFC/Gc8bRII/Ob9GFJ5osY21oG/QOlQx7XMdtcCQJ0B/MSUjFz2N2u+mz84f ntU67vXqMkNM+10IwyKxG7Rh4Me4KvXXYwFzG7wDoR+6kpKWuA32EHtop4zd0OYyP5fmhHHtcfUg hsdvzUWglkQSHT/YLUlMyx79zq3hrx9L+Uosx77WbLRLYhpTWNawOcfpTJ28IIttqdtYSWu10P0U FMyLamCuxswY45/64kMixsBv0WnVv7zf/SibIusYxrwS8TDmz7kPdWTNLjud9Ld+aklsA7HFzm+x 3DkWpwggn290BmrIJIg+791yKWOcCWCQOUCoOZlbQ8gCVVqcWq9mcaEbhyqDBKr5dmSO7ldS3esN vBVK4l8nwWj1B21/G7SY7rOneIb80cfyhB3YkEDVRGiQmNU0KRCRpRmnwVdqM0pIThM5IJFNKmlk KvUJKsZCFjjVHol1MauAtCo9lWxxorlaz8htlCZoRBohgogVc0uZtUwoNUgmpSJ1CVKUgheUpUZS lAqZynlQlKUxLOUgVCU0o2hJuThyFKeUuJKTcmDlCUpSMlM9yW5QlKUFM9yaVGUpStTKU8qEpSkp mSlKhKUoqZJKMpShamaUqMpSlamUpEqMpbkFMpSlRlKUbVTKUpUZSlC00ylPKhKW5JFMpSUJSlK0 s5SlQlKUlM5TSoylKVqZSkoylKVqZSlKhKUpIZp0OU8pJZSlKhuTbklMyVAlMXKMpKZpEqMpSnIX lMmlMSkpclNKYlNKchkmUZTyklUpwVGUpTooWcUNymShlIpYkoblMqDkQpE9VrOFZdqq1iligubk BUStHI1We4LQxnRiluxUgoqQUi1kFZxuVVVnG5TZbJG7sYzZ1WlUFSw9VeZomBe6WFwR4rQ0IhZ+ HwCtEahSBYzp40VlqoNt2W7D3C0G8SihjZwq5g/lVizhU7bPTrc75JJDVeZM+az8luq0CNB8FUyW 6JLnEyAs+vR5Wjk8rNBh6CC6NR0VysKlUrtaBUE7VJM0aKSYvUAo6qaiE1cwKgUVyEU4FBYlQhEK gkVqNyGUVyGU20LEKTXkKKZBTMuJUZSSCFqXCdME6ClJwmThIKbFPK1aNFlU8rVoVmCyTeYUQIbE UKZjUnTJ0EqSKSZJKKxZ960LOFn3oFdFzbiq5KPcqyhkzBeUpUSnUa5eU0pJ4SUtKYlShNCSGKZS IShJSySeEkkv/9e8cVljA6slxA4UGiNGug/uolgtpY1zT7TpLD3VV7i86tcHT9JTLEm5xEWgjxj6 Ct0O9hax4Ef4N35yr1C4tjf7D+aVKyq6oh5HsGm5JSPIocyHTO467UWmwFprscAR9FxU8wNNYeDr wYCpsY6Yb7p8UlN11tbXQXEOPdv0XKejhOjRwXuCq1Bm3a8FpaeVOvfW4lrvUrdzP0UVJW0O5a3e B+c1QdZW4bXsie6I2vIqH6I+385vgo766GudMg9vpJIUamAbLGlpH83Z/wB8VV9T9wbuPu1/kuVr 9DbSfTLtw/e/NQ2XOrPuAeznRAKSV1VVzVkO2OP0Sfc1wSLaa3RIfWdCWFFtZjXgAMcLPpNn85Vi 8MkFpCSW0ykN0a8OY4Q3ciemQAyxwb2Eqi4VZFf0y0/mp2Y9bvbcCSR9KeD/AKRJCVjHMmrfAGni oGuzVxPH5w0TVVkbmO7aO3fnfy96JjXkOdWxwaO7bPzv6liSlh0081uJMbtD/wCBp6rg/wBgllg0 IP7yE9gc31KHlj2nVoKm/HtADiJP0i4HckpsPrYWh7gHEfSDfpbVGlldL4O70+Waf9BAYyuRY86A 6lv0lI37nkUBzmd2u/8ARaSmFlu15a8bh2P8lTbY/boTI+jKlSPUDm2S0eYR2NfU07S1zfzf3kks DW59e5x1+lwiVNsc0GuxrxHtn/z0h12jcQ6W2Dt+a5QuZjtE3N2uP5zUFM7qGl0QG2HU6/ST1lv0 bZcCNCEIlpawuG5nZ/dFBeysvxxuaPzXc/56XRTXqrfcXN1dt0937qjTYMWwssBBjbLfzUXHvM7n +wn6Sg6gOeX1AuafvSUzqqFvtDg5vJ3fTULQLQaiDp9B7ONv/CpNxDHq6ODfpMna6Fac/wBKqaSG B+nu9ySmpjsvrEMhp7O/eU3GyypzHHa48lMLQaRXbI2uRdxjUj0+NzUlLMstoo23gmocuRHYzXgW UHcw/mqAfjMaWB8tcOHfmoZpqrc1jCRpO5v0UlNprLrDskSPzXIDA6ou2shwPuH5sKNu5wa1z9Ae fz/89FYNstsftE/SKSmD/QZuO7aY3NY795EFddoa57ttpHH7yhY66prWlrLK/wB/99v/AKUVaz9M QKwWkiWtJ/8APaCmyWuE028jVhP0dv8Aoko7UywT7mO7u/kKtVnZbai14D2/y/p7U5D76Gl30mn2 lv0tqSm36loeCRB1mPzlBuU+djXN2j6Bd/57TVZJ1ZqHR+d+8oOoFrC5rPcNXSklkHbrHMcA18fS nR6Bj2jX814P009DCIcBIadp/ku/fRfRD7CXjXlJSJ9ZcQ4vEg8tR66NgO9u5rj7S1QfXWyfaY7f 1kGpraSCTofNJTMEuMbS140P8pitsl0d40Vf1Q501u3D/pK1XtDDYHSI1agVBx8zVx29ig1ot59Q lzRHgg1u11VbLsyR3cjqbiHTwfyrPmBoYK0epH3weFScBMd07H8oQd1oIEHuoJa90uFIhcIrUIFF aUEJgnKZqRSU1L1DGbLlO5Pij3IHZIdWoQFbrKrsGiPVos+bME4UwhqYKgSkCkChynBTVJZTSoSl KCmcpSoSnlBLMFJRBSSpS8pSoSlKalnKeUOUpSUklKVBJJTOUpUE6CmUpSop0lLylKaE8JFSk8po TwipSSSeEFLJJ4TgJKYpKUJQkpZJPCQCSlklKEoQUxSUoShJTFJPCUIqWTKUJQkpikpQmhJSyZSh KElLJJQmhJSpSlMUyKlJiUkxSUolKUySNKXSlRSlJS8ppTSmRpDKU0qMwkCiFMkyiSmlFTOUiYQ5 SLkRopdQJSlRJRUsSou1SJUSiFMHaKvYjuMID+FJFDSuCzrOVo3FZ9nKv49mKSNSCipBSrWSsY3K rKxj/SQOyRu7vT+YWg5sFZmE7a4LYcyTKjC9uYxgLQrKzqTCuVvgKQLGpkOd6u/wW7UdzQR3CyxT 6nK0qNG7fBOK3qvZqFjZzzozsStiw6FZFrfUtA8ElzPsgXD2kqzGkKvkaNPwQXh5/JOpWZ/hFpXc lZdh/SILTs6NBlaFazscrQrQKg2W+CdRbwpKMsiuyiDClGiiEFLOUCVNyEUQpioEqZ0UCitYlQKm 5QTULFRUyoFAqXlOmTpql0kkklKThMnCSk9PK18fhZFXK1cc6KxBZJ0GFFBQayiqdjXTpkkErpik mSSjs4WfetCzhUL0Cui5lyrQrdwVYhQyZwwhJSKiVGpdKUyQSSyTqIToKUUxCklCSmJSSKSSn//Q lAYRZUY/ebyrVmfa87Q0QRyR+cijCDACXNA8+Uz7KLD6LxvP5tjPbCmWLjKuaw1kAfvAoDXRNJlw P0dU7RXuDy4yPbufwmP6R0mGkHskpm+twYQHad2O/NUaqnsO4GArjnXuq9RjmODdII2v2oO99bA8 w5p4H7qSkjpLfcQTwYRmMdU0mlwDI/SMcqD8YWV+rSII+kB2RmFpl9jw6wD6DvzklJKsuiIr3bx2 /NTzQ8ltsteeHjhBt/SFt7WiojQx7kZxDm+9u/4JKQ2trLtpdLhzp2RKmUNjY8ce5pQ3WuoeAaYn xKlYaLD7hsd4pIZ3UWY59Sp0VnifcquRkvLw/d6gPkkMYglkGHHx03IjcZ2rXCAfypKY1hhILNQe R+45W2sIMXjcB7mkfuoDcapzdolrgeU73WYj2saZadNfc1IpSOv9MF9bPZMc7lF2M3JIsYBEaj+U hZLG2t3gFjwNQ36CWIC5m1pku1+DkkJaWtfLLBsISvrsxo9IEkn+c/Mc3/i1F2S21pZcwh49vqD8 1NSTWA1toM/vfvJKWDdx/Sw0jWFLDyGueQRtcP5sj/z2rdmtjWXavj6P/kFS1xriaxvb/wBSEkrn Ie8uFoI8j+b/ANcT1sePpOBadYRX11Ah4LtxE+73NQb6HOZ6zYDCPc1v5pQUjcKCCGOJB/N/Orci ikNafUG7sXFBDRYA/bP738pEfWwQ6rdsOjmP/NRQxZ61BDQfaex9zHK1S59Ly9wcxv5wb9H+ugVO FJ0Mgj6LvzVape5z99ZkkQWlJTVDH+sSDuB9zZRMjHD3C+SNIfCOw1F0NdEAyS32td/o0NttU7L2 uDxpu/MchalqxXY1wsPtPt3fuO/9Jp3Objs9Nzg6k6O/O2uQSWXgsf7LG6A/m2IdlbwzcWRBG7/0 oklKwMYIZ72xo4qXqMsYC6NP3fzXf8IoAVBsiQ+fo/mqYdXtJtpdH+kYkpM5rj9IB5IhV3WPr0iW eClVXXew1VOLXj6G785Q2/4G0RYI1b+ckpN6YFZtaN1fdoP6Rjv/AEmnx7ha3ZoG8Q5QGCz6bnfS Me07VGyllRgEEt0cPzv66SlWUPx7DU0TWfcGg+3/AK2i/Z6yGvB9zD7mH81RuLg30STJ97J/9F3I MF1gfqHEfnfnuCCm47EaG+q13jx9E/8AqRVqrtoNdf02/RQJdrcPY4H3R/6SRWZPqkG2fUA9rme1 JSrHXaOc+ZGun53+jUm3BjNzAXP0I/d2/wCjQftRaHei0xyQ/wAUwpa9gsBO535UlNhtbHlz26Nc Poj8yxMJ3NFjy2Ro6Pa13/CITrGtMVtMx7z/AC0zLHsj39+Ckpnc60aGHNB+k1Kx0yABsI4/Oa5F tuDRLGFuu3d+aqvqMeNrmkWfmub3SSzqHpun6B7SrdT4aXtYD2cqrXteza7kI9dTSJdMEdkCkNDM O5wDRt8VXa2Fcy69jhHuBCpN1E91WzbL4uL1B254rKAD6Ti12vb4K7mUBzw5xAE6n91Uy0B7i124 dnfvJ2P5QgoeNEnJSSUxCkQoeaK090MIjUkJgkUwUjwgVNW9LF5SuSxtCmy2SN3YrOiO0wqrHIzX KhkLMGxKeULcpTKrrkgcpByFKkE1SWU8qAUggFLp0yfhFS6flKE4RtTEpoUyEoTCpjCeFKEoQtK0 JQpQnhJDGE4CeE8JJYwnhShKEFMYTwpQlCNoWhKFIaKbw0H2mQnAaWpHCSlCUJqloShSSASUxhPC lCUJKYwlClCeElMIShTATlqVKRwlCnCUIbKYQlCmAkiphCaFNKElMIShShKEFMIShShKElMCE0Ik JoRSjITEIkJoSUjITEIkJoSUjhMikKJCNqYEJoUyExCKGBUUSFGElMCExCmQmhFSNMVMhRIRUxlR JUiFEhOUxJTSkVEoqUSokpiokpwCFiUCwojjCA8qSIU1bSqFnKvXFUXnVXcezFJgpBRTqVayCNjn 3ICNT9JA7KDs45ggrYpuDwB3WLStHE5UQZC6rCrDDKptcrdQ3H4KULS3qCrLDBQKmwEeNNE5axud DSsysFzyVbynwFXxxDSUEsggZmlRKswqmc6K4PikueetCy7dHrWtHKyb9Hygg7N2g8LRrKzKCtGo pFAbTSicobTopgqIsgXUVIFMglgVAhEKiUlIioFTKiUUMColSKigVqxUVIqKSlJ00J01S6SZIIKX SCScJKS18rUxysuvlaVHCsQWSdKtyMCqtZRwVMsSJKMp0lLpJk6CUdnCoXq/ZwqNyR2XRc61V3BW LQq5UEmcMEx8U5TEqNKtE8QmlJJS6cKKdBTJJRTopWKScpIIf//Rsmt9ZFroe0iU7rt7vaBH4sU3 uB/SBgDD7XMnj+WhhjA3a5pbYNWu7PYpli7bMgMcxgBYfpBSYZYBtkRwoVuAaSGkj+SfoolbJh0k Ac/yUVMBA9ln0Tq1W7QceAWtLHe5tn7rlXyWm07SC4g+17UzbDt2ukPb+a76KCGy71ck7mhrHD90 /wA43/0ok6pmQ9uu18cn6Kh6VWQ3ebAw/uKdxZV7XEkn6UJJZvdZU1zCwzwXD3MP/CIFbLQBY0wR of3U5LmVl1BJb3aSmY6wgAPaJ4SUjvJb+cHDsB+YjF9eQ0PdW7eNHOBURTLnEvAefL22IIrew+2W /ulJDY9B7gA921p+iT2Q7sP0yHb9zT+c08Ks7Ise/c8biP7Kt0PayLK/0bXH873takpd94BDPUEk Ru8P+MSrosaTXPqN+ltamDq3vd6zA7t+j/O/4StCax/qBolm3VhP0i3/AIRJLae41kPqlrTo9jk5 xwGDYdjx+fPtc1VLXWvc3cO/tK0G2V3t2Ehjm/Sa76JSU1cVluRoSC5p5Qrt29we3Y4n+y5XPTNo d9mraBwfd+d/waq1ve4iq3V48UkLiz0drXiWTrZ+4itr33O+zuL2kSI/NTenVBFu5sfmINFDi4uo cY7eKSlUNsa41w7cO0/RT1h9L/cdX8buNqNUx9bg4OgzG5ye2/3Gh43g+5rh+a5JKA4zxO0ief5L kN1VjNXHTu1PXexg9wLh22/mf8GrLsjGtG8Ha4aem76Y/wDUSSGs3IbWdQHjuOHKwzKxxD2h2393 85rkqjTPuZr+92TO9AyayK7G/mvHssQJSnda3KENPpu/H/rqr325FZa24gsP0XR+6gAWZHusbr+8 xGNrtgadYKVKVZdvbudqCp+vc1oe0Rptc937qm19FbmurabGkSZH0VB11Y3Q4ivX9HzCSmNTKw01 vJNnLdv0USLcQNe581u9r2fuT/N70Gy02Uh1bdgb/nJVVMmWkuBHKSl31B7XnUP+k1w7ITb7mAXO G4tIn95XfV9OIhzTpP7spMZUCWucA8aDwf8AuJKYVX0Ze8WM2A6lxP0UrKyC17Je1vs9TxrUX7AN ltZa4HV4/dUmCygOGO/cwjQwkpgya9Hy4A+1p/d/4JWH0G5w2H2kaNcUIttFW0tJJ7KBLHNAJLXf yv3klJGYxLC4tO8e1zT+cg1tJ9tjToI+CO54aA/c7Zw4g/Qf/wCjE4Fp9wIcyN0nRySkTR9mcQ4A sPYqdDq6Zc3VvKG+uvIiygkj8+tOz07SIJAj6KCVVveXWbnAu+k3T6SBufcJjaR7gPzVMva1xdrp +CLYTW4GrQOHP5rmf+ir60kIw42MLH6TwP5SW67aA72x9F0Kd5aDsA3NdEu+i5V3h73ek5xO0e1p SS2acl4cZAg/SeEYAkAcRwqjBIVmmvc3iY41QKg0LS2wnY4kj6QKqsIEq5kaEwO2pVFp0lVs2zJF x+obS8Ndoex8VRAg6cK9miLIP0XBM2ggAjVpGifD5Qg7tV/ioz4qT5Bgp40T0LNRGqACK1JDMJyk E5QU1rlCj6SJcEKkw5Nlskbug1yOx2qqsMmUdioSDMG0CpgoTSiNUBXJBypgKARAmFS4CmEgFIBJ SwClCeFIBBTFShPtTwkpYBKFJOEFMITwpxKaEFLQnhPCeEFMYTgawnhQtqFrS0ox31UyIgwU8JNE CFKEjupjCeFKEoQUxShThKE6lMYT7VKE4CNIYQlCJCW1CksIShThO1s8JCKmEJQpQpbUaQwHKdx3 FS2pbUdapTCE0Iu1NtQ4VI4ShE2p9iXCq0MJQi7EtiPCpFCaEXYmLUOFSOE0Iu1NCHClHCaEWE21 KlI4TQi7U0JUpHCaETaltSUiITFqKQokJKREJoRCExCSkcJoRCFGElI4USEQhRITlMCFGEQhNCIU iIUCEZwhQcITlISFAhFKgQkpEUJyM4ITk8IQuKrvcjvVaxTxQWvaVTcrNhVZyuR2YixThMnCehkF Oo+4IaJV9IIFTsVLSxdAsunhaePwogyt5pV2hwPxWcHaI/T3l7yPDVSBYXeqMhGZoPghVI7Pypy1 zs0bfmmpEMHmgdVsLbAewVquC0EdxKJSFDzWd1DUALQdoFm5kuP4ILnHuCycge9bGSNFj5P0kFHZ s0EQFoVlZ2Pwr9SRWhttKIChsRFGyBkkkmTUrFM5KUxQUwchuRShFFRYlQRCoJFYxTQnTQgVLJ0o SQUpOkkUEqSTpfFBCWvlaNGizWHVamOFYxrC3GI4CDWFYAU6xZSCSdJSk6ZJBLB6o3K89Ubgkdlw c60qu4qxdyqpKgkzhRKiSnKgVGlRMp0yUwiplKUpuU6ClBOopAJKZFJMUkkv/9K5Y+vbDJg8yP8A qEdzq2sDgCdOT+amcwWV7tpaB9LyUTXdjw4u3VkQP/SamWNe1+0y2Q53Gz6Dm/8ApRFox/W0Y4h0 fRP5yBvrPtEgTx+4ptD3yXP9w40+kipnVUGOgEsPBa76I/qK0ajuDMiLAR9Jh96CM0lgdczc0GCQ jHDLwLMdzWA6tEoWhpW1vraWs+hxqo/arBW1jmgOadH/AJ0IocWWfpZkj3RqmstZkaVuAHcv9rkk snMcPe52xrvouH0f+LQn0v8ATO6sEjUWNKduM9817m6eam1l4aWuaIHKSkTM3dWGlswZ+DlcGVbk NLGOEj8wj/qLFSNbWmeR5K3i0uLv0BAPI3pKR7/V+k8NcOxG3cguY1jpEwdf7St5DfVafWIL51LU KvOe1orMbmH2teOR/wAYkpaump7C2w7Z4IPuYp1tLfbaS6PbulDa2bTuA3PH9lO1rKmOqsLg8Hj8 1ySm4HuprjYLGzOp9yr2PH02N2sP73/pVTrY14BqBa8c6/S/62nuoubUYfx7vTP0bP8A0nakppix wME7TPKvn1HaFrXiOfopqLm5LIgMIHEfS2obL6iQDu3HTYfo7v8AgrEkLttc9oNhMN0Gnu2p/wBH sDmbg4fnNR6bS13pOcA8j2u8P+MWa4W1TLpg/SH0SglNZlPulg1rP0p+luCVjnNO28DaYh49rkAi eNHHv/KRaS57djjucB/mooTtwwxpNR3zq3+UmyQ7cLG1gQIcqTn2NY2HaTx+6j3h11jbd8gDQT9F LVLMuYLGOHDh72/uuT3uL3FrgPbwT+c1CsxgXF495/dUGljGu194MbD9LagptYjntG5h04LQfooV 9jGt2BxLifew/mf8IpY3o7Q8NMj6TQUXJ9Nobcayfzefzv8AhElMGAhu3cY/Nc33KFm5wjQO4mNv /bintNhHpQx3OhUn02vaS924fvNH/n1JSqqyK3OaW72fSZ++o2NYKxcwODdNzUKx1TmtADhcOf3H NRGMaPcDqPpNJSUux7ntc2NzTqB+cxTdSKgLXE2MiI/Pa5Oyh7HepU8An80fuode9tjgHe7kB2u5 JTL1biWiOeJUvTdSQ1zywk6fuygjMEzt5+kwf98UnE7JZOzwckpsvZaPc6wP/kt+kgW0XO1a6Z7O CrkGk+oDM9vBWPtT3ugOaG95/NQUt9mc4S4bS36X8pDZfj7do3bh4/Q3f+klIm1gLS7e0nlWGUkN 3AtJGsIqQ3ZDqPdXEEaj9z+Qh3CqwB7WwZ9w/wC/o9WGLW+qXAOn6LvopMx7WPNf0XH5tj/g0FIa tCGOga+3+UrOXbUP0YaC8chqqOyHBzqrnB0EQQEe94ZDqXN4nUe9IqYela9sAEsH/RUXNB99hBJ4 d/6UUHZBawMa/R5lzfzmqLKmvBaNT3QS2w5jYftIPDh+a7/1Ij+nj3HdW6YH0Xe1yqU0l5Aa7cD+ aimsCS5sOCRS518hxa6dFXVzIbpJcST4qnqAVXy7L4uT1B7twafojX+0qjR3DtVdyXFt0A+0jUFU 3va9/wCjbtCdDYIO6x1MpOUtRykU9CzQjNaoNRQkhcBIpaJIKa93dVa/pK1fwqTTBQ6JdOohWQFS qKtsVGY1Zg2WCUUCENgVhglVyLXLgIjQkGIjQmmKFAKYCiBCI1NCloUgE8JwEOqlQlClCdIlLGEo U0gE1TFPCltShJS0JAKcJw1BTCEoRNqfanUpGAn2ooapBicI2hDtT7Ub004rR4FWhDE4YrAaAn0U ogEWg2QkGqwAn2hO4EW19il6asBqW1H21W1/ST+mrICYhLgAVbX2JbUU6BMBKbSkW1LaUcNUtqIg q2sGpw1WA0JywIjGq2tsSDUcNTFqXBSrRFhTBhVgKW1EY0W1tig5itliE9qEoUkFAWqO1GIUYURC Ue1KFOE0JqWEJoU4ShNUw2wmhEhNCCUcKJCKQokJKREKJCKQokIKREKJCKQowkpGQokIhCYhFSMh NCmQkAnBCIhDcEdwQnBEpQkIZCMQhuCSkTgguVghBcE8Kaz1VsVuxVLdArEFpaVqAUaxAKvBiKyd MnCKF0Sv6QQ1Or6QQU69IWlVoFnULQrEKJlbI1CsdNY5r98acFBq5C16mNDdNAVIFhdBgRWlV6Hb gizCctaPVKvULT2PKejiPkrVzd9Z8Rqq9DYj70Slewys/LbpKv2COVVyx7fkguDh5HBWNlrZvHis fLQUdkmOdNFoVLNxdAtGopFYG41FCExGaoyyhdMnASA1TUsVE6KcKLkFMHBDKM5CKVqYFQKIUMpL SxISTpJIWSCSSaVKTpJJJVCSeEkFM2crUxjwstq0sYqeCyTpVowCBWUcFWGNdJJJJSkkkkEsXcKl errlSvCRSHMvVQlW7wqTuVDJnCpSUU6jSqEoTpFBKydJJFSk6ikgpeEkkklP/9O2+zcP0hIc7v4o bXWVjZy2dWqzkZHq17mgS3R/7/8A20gPtbkMHuDXt4H7ymWMX+mR/L7Qp0W1uE3u2jiUL0RYdXR/ KKKKWBhbuBj8UVKfFJBYSWu5/cemaABuD9p5AhOx0SxjJ7t/kpV3D09r65/lj81BTNljr4JEH+SV F1AsdL2Rr7j+8htqLHhzZAP53grg9QPix3P5zvouSU57yyh5ArdtB7/98U43jcxzmtJ4J/8AA1cy aTUd5I2H/CN97VSeay8bhtJ/OH83YgpLWxjLA6/g87P3ke5ldjXtYH7Y9v8AJVbIY0ua0gSBzP0l cx8e8MIY7T85p/dRU0MQwZa7WO4RKcQ5JgGX/uol2K6Wsa0a/Re0/S/4NVH0uodsslrkgptuBx5r vGn5v7wRm2Ma0zWbNNHfuf10AWM2w47vNyfFursa6uSHA+x3/ot6SmFNllb9zATGuiJ+0HPs9Zss I0fI3NcmZRfU4Fmg8EX0XVbnyGgiR/K/9SJFSGyGOFlLnNDj3HtUnXi32lkFp1eChjfsLXhxafdH 5qbGq9duwnbH0XpKTW2A1FwcSQePz2f+olHHuEfpNQ4R/Vci14JFbyILo58VUpi3RjgCOQUFN7Hp Bbtc2XdjKq+m1l3uH0tW/wBb+WluM+mDJIhoP/fLEzyxp9WwO3fRc0/vpKb9jPbBpiwH6U+woBcW uAYAPEIDmvuHqDRrYls6qTprE81n83/0mkpPZi3b22QQSJJ/NMKnaWvs31j3T7gfoq5iVW2tcMa2 CDIY5V7fY/3fT/PaOEuqklj8cAy1zXR2+juTAuY31Sd1cjcAi0urteN3t8A785AyW7LgQ3ZW/mPc 1FFrNxw95BJ2zI/qq02oPqLmPIcONPpf8YoPfXDRRLLW8OP0HtVdll9b9h5dy0fRcglNVe9w9Nwa CO/dqhXSHkvc0jT6Q/1/m0rKmEgakn6TfouamscTVtrJ9MH+01ySmLrTbHpkjapfai5/vGrfouH5 yVlJG3053RJ/lBRhoc1gaZPikpK+1jyLmCRM/wDk60XIyK3UiysHdwZ+ihemxj9oBOvuA4TNfjv3 MI2nXlBSV1osixga0ge5v738tV7PTYYcwkzO4fRc1SY6qtha4TpLXD6TCo1uyNnqNcHNnuElJLMg P9jRFbtA1/5v/F2JY9n2B3p2tLpHthO3GFtfuIMjcNp/6Cauhj2w5xkH9G79xFSRwN520u3M4gja 5qhbL2bHFzXM7T/57RMhpq2gD9KdDaD7E2QwvcA8fpG/Rub9Cz/jUFKEs9t1Yew67h9NDy/SeZa1 7XM/f+iitqrDybCRa33ED3Me3+Qq97hZ72vIaTGx35qSk5sY1ge4NcSNu3/0YhHKbDYA3j6SK0Pa YAaY7oFhF0OkbhoSB9JqSUgguDgQ1pP0v3VbsquME+8D84H6SoEbfZHOqsMqtqAdXqP3ZQKg0cmz 1nSBpOqBGhR7Xgh3ZxMgITNVWzbMkXFzAfX3ASDy1VbHBr5aIHgVczHWNvlhjRU5JcRynY/lCCkN m8yVByk0AaprDKkQoFFaVXBhFa5JCRJRlKU1SG86KkOVbuKpjlFLeoKv1BZ+OVpUqll3ZY7NuoSj hsIbBCsNUGi5k1ShR2xwiNUZkpcBSDU8KQTNLSoBPCknASKGICeFKEky0sYUgEk4QUvtTAKYSTih YBSASCkAgEqhKE6SfaFwph0KAClCcCUL7ktUoTgJ9lSoTwknTghcKUSmCUqQFDIJSmTOMomSlyYT HRNCeAmalLE6p2pOEIZd2CfDGSbKCUhsDU28uVfcAdUjYSdre6sUIrd2wHg8FPuI81W+ylokOUrL dkDklETiiik9SdE7DCC0hxO37iovDmmW8ImpC1NyddEQAqpXYZEhW9yhIAK5dRICW4JnFAkUpg8C EIhT3JiQq51XIyE0J5TSoilaEoSJSTUrJJJJqWJTFSKiUApYqJCkmTrUwITbURNCICkRaokIxCiW pEKQ7UoU4ShIFSJwQnBWCEJwSJUgIQ3BWCEItlK1IHBBcFZc1AeO6eCpq2BU7Qr1gVR48VZxnVaX NtEIBVrIidFWV8bMLFOkkipdEq+kEIIlX0ggVO3jDVaXp7VnYejwFtX1kAT4KIMq1Ghla1J3jVZF XK08Vx+5SBYW3VLX8aK1EquCRHlqrAKctYkwPiq7JBjuTCPZx+KrCzYS7nRJTK0/idqrZP0SEV7o e1vcDcUO7UILw4GT3WPl8LbymwVi5fBSUdlYvC0azKzMY6LTqSKwN1iMOFXYjhRlkCRuqYJgU/KY uYqJUuUxKSmDlAqZUCgpgQhlFKG5FBYpQklCBQuUwTpIKUEk6SSlkk6SCmQV/GKoNV2jRTQWF06y rDSqlblYa5WWNLKeVCVIJKXSSTSglZ3CpXq64qlekkOXeVTcrt6pEqKTMGKSeElEuXTpoSQSpNCd JJTEpwmhOkpdJNqkkp//1HtYXn1QSZ+keCi4+MyxkAHf+YVLdY5m8Ogj6Q8VGAKdHGZ+ipliRjol ryAYja5VK5Y2IgK7U2vIa4OYS+Oe6EGN2bd26OQQkpFVJBmzaRwUbHzngFoYDPJ5QHMggug/lR2C qxpLXbXjln7ySk2JYy0Ftlm0j6JhQusdkVxa8PDDBAG3/rir0gb9wOh/OVrJxHU173tEHh6RUi2t qMSTU781KG2CKmGOzT+8nbXaW7LO/wDNvH7yi0OZZ77DI+lCCkld73MkMaXs0LT9NRaW2S8ucwH8 0fvIjq7PU9Vj5k6uIQrm2sscXEbT+79FJSMObS4epOx2o/rK1i5hcHFlYJGvvO72oUNNf6V25g1a AoUGnfHuZ4IqbRuruANhY3uNoUKXNtJOwDyn6X/F/wDCoVuPuBDSS4a8aOSZZ9HQAdwf3kFL1XML gXksaOFarveJaXC2k6Dd7XIFmRbMsDTproheuXOG9nmA385JTe+00hoaC5rwPbGrHIbnGmuagYd9 KR9FDqyXUtc5tbS1x+g76bVMdSeCKrjsrcNPbuSUiPq1mN+6t/u0VhmI2fVYQ4Ee5n8pBrpNu5tQ BDfc3X81WKK6mcAmwjVv5wSU0W0uPtdIMyyFK2i5rC6yS2dxKLbj2vDrKz726/8AmakXPua17yRY B/ZtakpDZjVCoWNfNh/M/kpV1taC5xJ+Ck+tlcRO793/ANJqTGVaBoiz/ouRUj9IVv3tdA/Nd/6U TmAZcRB/Pb7lZrLS721w8/vH2f8AErPaxrXOI9s/m/msQ6qdUl20Cza9m3RzfpKrVZY0Q5wcQ4Fr SPpJ2UmkB2okaQfalk5Dm6NhzD3j6LklNvJpOQPYwsd/K+j/AGFBlnqM9N7A22v89xQWvNkua524 D6Lvdt/9RoLrDY0eoAZSUmpusI2WND6/EfTTuZ6nsiANI+iXITA232j2ItdJcXbjEH6SSmv6NjXg PJ2/mKwyh17NpYS7s+fownfaKne52h/tJwXuaXVkvYDJA9r2pWpluraCXAyNJb/6MVdz2EkBocD+ d9FzCouYLLCcadp+k1/7yezfW73sLdPzuHuQUwAc6na6CA6Dp71K+sAD0nDU/RRTkb4seAO3p/vj /wBKIORk1l7dCGDy2mEVJHPc0ek5gBPD0MsaQ0CWv13l30XInqMYHAOLg46T7kKvL0lxBPBYR/4I gpm7JdVTsLQ7d+e36THINFvpACyTV+cEZuRpFbQJ9rtyJVigP22GGnwSpSCu+qh01uMTo4/uotpr us3OEECLD+a//hlFpxQ41OnT5aJOxzQ7aXQ06td/J/0aSlPtLGmnvIc0/wAlRaa7jEbXg/2Hqza1 lgD2vBAG0tP5qqMoNpOzkcpKSD2OhwMA+Ku7HsG8HaOW+az2te/RxmFcLagwCzdIHshApDmXay4c /nFRq1CJbXpLfmFCrTnuq2b5WSLi9SaPVmYIVRjy55eVe6jWH3AeIVOzdSQ0EEOGqdj+UIO7O1wf BCGSAEg6BCC4mZUiFyVMHRBLlJpQQnBTkobSnJSUjuKqjlWLCq45SS3MdadIWbjha1LVSzbskW1X 4KwwKFbUcNgKobXsgFIBJqmAo5JUFIBIBSCaCpQUwownlG1MkxCUpSmkqVCkAmlKUgplwmBTSlKV qZqQKHKUpAqSSlKHKeUbUlDoTh6DKW5OE0U2BYE/qNVaU8pwyKpPuCfcFXlLcj7iKbG+EhYq8pSl 7hTSfdqn3IEp9yIyIpOHpF6BKdskx2UuI8cqQdAyLzyeEI3epo0Ir7Gs+lwhi+s6BX6pjYbC4yii A4R2CXqSIhRlVMkutrwGdj3EQ1JjQ3Xv4qG5NuVaWToF1JHta/nlVzU9hlplvgiboT70Y5iFGLKt 5RdyBuS3JSy8RtQCUuTF6FuSJTONNM9yW5QlNKZxFNM5SlQlKUOJVMpTSoylKHEqmcppUJTylaVy VGUxTSlal5SUZSlJS8ptyUpiU4WheU0qJTSlxFVLyEpUClKVqZEIbgiShuRIUjIUSFMlQKGyUThK A8KyUJwTwUNOxqo3AhaVgVK5isYytLj2oJVm9sFVitEbMLFOmTpyl1Ov6QQ1NnIQU7eKYIXR3N3N B7Qubp7Erp64toB8FFFkadfJV3FMuAPCpgbZCs47oKkCC6WU8V0OcOToFLDu9VgPlCq5X6VsDgBP 0tx2lp7J6xuvOkKoD7wDxyrL1n5Di3UIJTYzvVsts7fRCVgJMdlHprS3H1/OcURxhpQSHFz4HCwM vhbvUHawsLK4KSSxxjp5LTpWVilatJSKwN1iMEBhlGHCjLKGaRKaZTFNSuFElJMU1SxUSkVEoKUe ENymeFEooYJJJJIUkkkgpSdMnQUpOmToKXCvY6ohXqFPBaW9WFYaEGtWQFZDEuE8pQlCSlJJJkEr OVO9Wyqd6KQ5l5VM8q5eqTlFJmivKUpgnI8FCvXBTqKdBS6Yp0kFMUk5TIqWSSlJJT//1Ttuspdt MHbyIRhax4/RFrzG7Z9Hb/waDjvdYdSN7fH85DsrqdD2P9xMOrUyxX2mtwD27q7Bptb9GFJ9oDJb 9L9795DfUGuBB50IRbqb6RsJBrf7mpJQG/2gsbFjTz2hPbZVa7dYIdGu1Hpc5lZDQDOhDlGrDe6X MEwkphW5jXSNGn95EYwulr95qP7p9gcpWYtgG7cC2P8ANUWv2sBdOwn+ykhlTVvJpa0u/wCiWpV0 k2FjmkPGhCNVSGuJseA3s6UG6plpJx3ltjf3nf8AnpBTOl/pk72lwBjZ9FB+0Bjn+iS092vTY9lt hcCSZ+kfgobWn6To11lJTNm0sjfEkaR9JWSz0nQYfI9uqqei7ftZrPCIx5rBZY0B3gUkpXtyG1l0 gCUG26s1CCHEnX99qPVkVlrnvAiILZQq8Q2MLmRCSFqrwwglwb+7I3K2+9od6b4LHDc0j/X9GqDc R9jnVtHvbyFbY2vaA8FxGmn5iKlrMprLmtY4Wt2wNzdr2/8ABo3rh4FdzNrR9F0bvcgupZe01uZF jdWvB+kEBptxXt13s+k0/m/9cQUyuodu3Dkdgma+9jw4HaY0cFZfbVlPbtllv/gaevqNocNzZ2e3 QJKXrebGkWkEHnaYcmtoa0h1Ly+ON35qc041lptIc0O+kP5aHXlWY01WVl2v6OxJSrci1z9tjRpq 0t/eCZ2QLSC9nt7lvthNk52R9F4aJ13NGqm5uPYxoNu0Ee4RwUlJK2G1xdW/bH0d35yezE3/AKVx Ae4+/wD9KKo+t1LNwO+uY3j81Hos9MmsDeCNw/klJTKthrfFI3OH047s/wCCRLHfaB7WkuB9wjlA vdkV2NscNriNHNRG3PNgLiWvP5zdNySmPptdriuIeOayoVvFEtdBDva+t30m/wDCJm1OeHh79rm9 4Usttppa1zW7m+5tv73/AAaSmYDKoL2kt8lI31kyyw7fzmuCenKtLJDGhwHf6KE3LZDm2NAe7Sfz UFM7MdoLdzoYRLTE7f8AgVSfua4OYTpwVbZXBHvDmxIZKCXsthrJ3a+0/upKZNfYXbgPa7k/ylJ+ QXs9EEnxa/8AMd/wajUWNpdXZuBTtosqhw7/AEd35ySmPp7K5sOjdR8UcEXNEtEEcT7mod1jrWAv MvHtDY/NQKHuDtsCSI1SUk/QwHVOItafouH0kRtTHgvd3/Ob+a9QPrMJe5gLgkWVuO57tgd4fR3J KXx6mtcG2RtdwT+ai5FFrbJIOxujSwygte3aQ4B0H3D95qGyx1djhW4is8ApKSsyn3O0aNzfbJ+k 7+ujC/0gC1gcZ9zH/m/8Sq7Kxe13pGLRrB+jZt/c/wCET1v+2MJIgj6WvuSUvbcxzw6us1u7gFRe 5rXTt0Hgdqs3W244bU8B7C32v/P/AOL/AONVQ4j5kbth8UFJ6mes4FuhA4R376zDpDSgV4+Na0sJ NdgHtdwoP9ZjdzHbmjmt/wBKf+BekUta4Ct5a0n4pUw4It4EAuPPKDjgAblVz7Mkd3G6k8NuLHDQ j2n91VXu9QCfpBWOpa36jtyq14cXAEQRonY/lCCxslqEXToj7zw5BfAOilQwOicKMp2oKSgp5UGq SSkdiC3lEeoMElJTexWytihqzcQd1rUBUMxuTLHZtsbojNUBopSq10vZcKYUJlOCoiUs1IKATpim Up5UQkjqhlKeVCU8pqWUpSoynlJS8p1FKUKUylKVFJFTJKUySSmSQUU6QUulKZJJDKUpTJIqXlKU ydJS6SZOipcIpcGCQq1ry1stVN2U48rR5cCI4j8zHLVPbcO6kyqTJQaJeZcrRKjzZjsExiylNyoy mNsfRUAjpcj6VyQMcU2w9iEAuJ5KgT5o3Dsqi2XMcFDdCG21zeCies1+jxHmEeGEvlPDJWoZBycF A2vYYcZb2KICopR4TSUkpSoSnCapkkmSlBSkkySaldMSkmKSl0kyUpKUSopyolFKk0pJkkLymJSK jKOqlyUxKZMUlLymlMmlFTKZUXJwVFxT+iGJKiUiUxKFJYkobipEqDkQpE5VrhIhWXqvYpYrS4+S 0hUytPJZOqzXDVaeM3FhluwKSRTKRC6k3lRUmjVBTt0cBb3Trpaaj34WFjtIaCr1DiCIUOxZG++A YUqjqhflUmmFIEF2MdosbPjolXX6DwOynjtgCPCUa1s69ynrEb3fgs3KMlXXy3lUX+90eaSXQrYK 6mgfFDtb4eCk4kEN8AAiPAiT4wguDzPUNHkLGy+Fs5+thPmsfMHt80lIMU6rVpKycc6rUqKSxvVl HCrMKsNKjLIGaXCSSauWTFJJNUxKgVNRKSmJKiVJMUEMUydMUlLJJJIIUkkkgpdJJJJTIK7jFUQr eOVNBaXVrVlqqVFWmlWgxM0k8pikpYqKkVFJLEqpcrRVW4JJc29UnaFXbwqT1FJmixBTpJKFepJN CSSmQTyopIKVKSZNKKl0kx1SQU//1obNhBsHPfsi3Fj3gHg6hwCljXEgtdo3iCjmhztRFm3t9FTL Wqx7tA/VoKk07SWzpOrXf98UzS6SWiP5KV7A2LCSHfuFJCrsR7G+p9JkxLVOvKsqj07Pd4EJvSdp YSCOYBRWjHuO59gb4bklKGU+xxIht35wP0LE5ZdU2NzRW8S6sJWuZaQKbGmOCWp2sc8b7apjRzmo dFNGimt9hrOrDwSfoopwjj2bSRLeFG40OduYDtB1apO9Jn0Gu2/vu/NRUkaXm07HDceQ32ob7Wgy 36bTD2Ee1FL8dr2Obr+81yg8Me82Y4299pSUlqm07gNonTafoqF9dllhc/3Ob3KL9ke5guJA17GF Xtu9Ju4VkwdXg7mkIKRjGDyXOgac/vKGOfd7P81Wbsthsa9jYYfpAj6Kd2VhNLmbXOa7gxt2OSSh iz1ZaSHjiEVtxadxOs+9BooLyCOexCttwybZBDbO4ckhg+M5p9LkHhx9ycb62gEgjwP5qBmVsNod vDnH6Rb7NqNVUxxLbnGP3/pJKWba0QLW+4abm+3+2ibXtBFZl3M/vt/9LKD8al30HF5A9qap7a2k S4OA9pb/AOjElNik22tDmkMP0f3tzv8Aha1E5Fgr+z5Mhw1Y4BV6bPaWvbE/nfykW17n1t2tMtG1 xc7ckVMHXuDgdJbq3ciEVZIc8AMsA9zP32/6SpRbVtIdIkcblLMqdYRaQQB7Zb9FJTWD30tLWkFp /Iotu2AbQfirAreKyatpI1LTyh0BthDXnaCkpNjbbTJPub5p8iuvKLq2ENc33RP00DKq2FpYWuDT 9Nv0tp/0lag3Edc6WiZPtS3UnZbdjAOa4em72ucRu9v8tPk3UBvpgS5vgfZ/YQMit9YFbifB7Twm +zljYb8iP+oSUyodZwwbp0UmMfXupe2R9Ij9xynhGxriKgCY1af/AEV/wiY3ua/e06u9sFJTDZWS D/1P5qsMse9jTtBI9kj6aHv5YAGlo937yAxz929msGYSU6AusfSQdpE7Xt/wqbfUaYGpYdQ4+9qp Op+0E2sBBcU7qX1QMluh+i8fS/4tJSRvqEuLWyB7tfpbf+CQ43P9TdpzKIB6Z/RuJI/eSBcCLbQ0 scYJ/d/4xJShuteYsG6C4bvzv+DUarWOYJEFEza8ZrgaxrGu07mJV01WNlr27uwKClwPTO+gyDy0 6qzTjucS8ObsI9u//wA9Kg0Csi0Q7xZ3/wCEVl7HOcTzU4CWA/RSKms+z1HPa0QPLs9Gc0vb6jYB j3t/e2pr6G0w0EFrvcNeP66QvBAGnHb/AL+kpK2+m5gba8tA8U2P1C3HgD3tmPTVV4PLGwOdeP7C nXY5zYDdZ/zv6iVJegrbRnM37RPf95rkPI6TXY32e13isqqmy1xsxnFlw+kz95Gptz2uhz/juDfa mm0uZktdUXVP/NOqeoe34qOW57rC975ceVKpsNVbPsvi4vUWg3DXUjaAqj2lntdyCr2c5jrgxw0/ eVRzCQWsBJHfyTsfyhBU2tvEoDwOAk+wOjsolSoRJwU7hqmSUzCdRCkgpE9NUNVJ6egSUDoFOtjM 0C0aBqquO2AAr1QgrOlqbZg2UkwKdRSFrl1JME6iMUsgnUQnTQpdOmlJAqZJSmThBS8Jk6ZIqXTp gnQUpJMkkpdJJJJS6SSSSl0kkkkKTpk6SVJJJJIXSSTE6FOjqaUgyLdohVqanWHd+aoWFzzpyr1b djAFeyTMIiMd1gDLSI8E/I80oDRudoq1t24iBAChiP3/ANJclLp07JkzXalp48UnSNeykniJP9RA Ktu5MSAhGwu0HCiS6E30xTq2CyDpqEoQ6rCNOUVtjXaO0KcIQnrE8MkWRuyYdIPCeIS2HnspN107 oGJkOE/PFVrKQTJwq1UuUkpNYTwkRGhQMDuq2KSSSZslRTJ0ySlk6ZJJSxUSpFRKNKUmlJJJSxKZ OmRUsVEqRUSiFLJimJhKUQEMlAlOmKepgouKkVAoKYlDJRDohOKNKYOKrvR3Ku9SxU0sjusx41Wn cs60aq/h2YpISkkUlOsUnGhTJxykp2sU+wLQo5Wdi/RC0KOVX6so2byNitIsa6JEqsDorGJdtftK lC0u/XHKZzoJ8kqgIk9wh2auHnonrUF5Lee+qrYrfUtHgrGWPZvJ40QsJsEnw1SKm04TZI8VDIft b+KI06/JBzPon4ILg83kGXFZuX9ErStESs3J1BSU1cc6rTrWVQdVqVcIrG6wo4KrsRm8KMrwmUpU FOUxexSKSYoFS3KYhOUyCmJUSpFRKSmKYp+6YoIWTJ0yCFBJJJBS6UpkkgpmFao5VQK1jqaC0unU rTVUqVppVkMZSSnlRBSRUumKdMUFMSqtwVkqtcilzrlReNVfuVJ3KikzRRwlCdMoV6kkySSF0kky CVFMnUYRUsklCSCn/9d63i2TwiOaWwa9T+dqosoaWF9Z9w/wf7yVVIc2eGnlTLF3vrtgtlj+HN/N P8tRsrdy6SR4qd+Myja+t0sd99b0/wBqsrIkbh3lJS7LW1t9R1XqMGmh1QaqmWE2ObubztCOckcN Gh7AJ6vTZ+ka4ieWwkpiKG+nuqaedAQh+tdtO5xa385qm+19Dn1tcTW7UR4otFdjgLXtD2D2n81J TUbc6onYZB8kQ77GwyQDqVPJp2AWVtis9t30UD1RW4EOcB4IJXpqkbSNzR+civbXMtJ3eSBXfYJD BIPKKMb27hweXeCKmwBZY3cYLh2hD+02MeZYBPLPzXf8IpCR7hY1oGhQXPO/c47v5bUEJa2C0mBD eQwqVtTSwWOYWgfSdyHILrXEkAEiPa7+UpUdRvDSydCIeCEksKdjHESY/N/NVuvdcXB7gCON353/ AFxUbciy0NBAhujTCsV5eVuDRsE6fRRQzxrS9rqoaQJlx7f20Cssc8CCYOu385MHW4rnbmAhxhwT MdvMViB+6EFN3J9rQa49M67P8IgNyamgxuDv3XD/ANGKDKW7nFjiHR+dop2CrYC4F7SIlv5j/wDh ElLV5rQSGs2sI9zed3/FqNjQ8lzJ01B/k/8ACJY3owS86jt+8p2va0BrXGD3b2/kWJKXvew1tre0 kchzfzXJmXFh1uIqdo7/AMzYoOE16Hg6ojrKtgD6p7b5SUlryq2S0APaP+kgWuqtfDG7WuHDlYoY C02lh2D2z+6q1tVYO0OJn3N3D/wJLqpnRi0WS1xO9s/R4clvsFG1n82TrI+i5EH6Pa6stafzgVUL i6z3nQ9m/RCSkzrHWbRAAj6Q/wDRie5lgYASAHe729kqrzS3aD7TopXYgfX6uICSP5xh/wDRaSlm 7JD9dwHZNv8Aa5uhD/d/KY9Dsc522xgjSHBSdupdDhJIlu3hBTJlTjXuDdz2/wDSapV1suewMaay R7tVGtgvYQZa5vZv5yM57KWGt7/cW+yR+a5FS7aH1A0kiXH2nz/c9RVGb9jmOG4zGvZL1nNrDD9M H2/uuTy5zSASG8kIKYw5xafzgP6qkLDeTu0D+f5Sk99zWtdY0PadGwptyG3s9N7Q1oOh/PaipE7G fUBABaO4Sip7eIcNRHIKsvuDXh1X6VoEEN9u7/hPTWeHB5LmmEFN2urdLmDf3J+jtQX7mXSfc4gf QRmCxlYLSW7p930muZ/hK1B9Bo2urJbLdzXf9Wkpg1wMmBz9H85C9RrdIiUXKx37m27g8vHucz/0 Yj1NqrEZc7Tq1JTCyxjawPcXRGz9xQptczznkf8AoxFyCwt9rwW8s3Da/b/o0Foa1wkn3aghJLcZ kltm6lv6TxOqvWZFr2EuraQ4aie6yfbW+JkE8hFuFLRua5wc7lrkCoNK4y0iO/Kk0+1ReSBA4Tjh Vc+zJFyMvZ67QeT4oVzvR3Nqd7gidQg2AHuqDgWyEcZ9IQUIdOvdElRBaE+6VMhi4yoqcKJSUuFJ ME6Ckb0bFElBfqj4n0k2eyRu7VQVxiqVK1Xys8syYaKQKgU4MKEmjSUgUpUAUN97W8lLdTYCUrPf 1GtpiVXv6pt+iNUfZlvS3iDsbk4KwB1Yl3HtV+jqVdh28JssUhrSRIOipBDDpU1DsuXSSSQUukmT oKXSTSnSUpJJJJSk6SSSl0kyaUUMkk0pApUpdOmSQSvKhYYaT5KRQrdWkBSQ+YIKDAYbHOJ7K2+x rNG6lU8d/pkt4lHaGx7ytCUOLUfMx3TBxLtXalNslGIDRub7knXAQAmR5ck3IpMmAIbJchNtc4z+ b4KVh3ghRaE7MTGgFRpIKw7VvPgoFnY6KRMDzT7hEO1CiqJ3+ZOqINiT4KTHdik+uRLTIQwVHMEb JDaZIHtRPUB55VYO84TQ5plpnyVjFMUBL5lhHZuHxSbqQENthESpz3HISniqXF0UJaUlucWu2t0h K0yGnv3TAh53n5prDJCWQERkT8v6ChuGCSRTSs5lUkmJTbkqUukmlKUqUoqCkSmSAUskkmlFSimS lNKKl0N6nKg5OjVoLhX9Tc2xwHAKjX1g7vcNCqWY0Ntdt4VVaYwRMbYuIvY1v3tDh3TlVOmgtoaC ZKtlUJAA0yhiVEqSgUxTByGURxQyipE5V7FYdqgWKWKGlcs63laN3CzreVexMckJTJykrCxScJk4 5SU7ON9ELQq0WfjfRWhWq/Vl6NidE+IZymNPBMKHZW68Iktsb/WUsVpehaIbHghWESVJrpaHeIQj qU9a0+qOOwAcHVSwnTVPj7U+Yz1KT4tKDhe3az+0kp0SPv0Cq5hO0jzV6sSQf7Sp3ND93wlJcHnr hzCzMgaFat4grLye6CmjT9JalPCyqvpLUoRY24xHGiCxHaEwsgSBOmATqMr1KJTpigpYpk6ZJTEq JKkVAoIWSSTFJCxTJ0yClJJJSgpSdMkgpkFax1UCt4/KmgtLpVK01VqlaarIYiySThJFKkikmKCW JVa5WCq1yKmhcqT1duVN6ikyxRpJFJQr1kkkpQSpNqnlRlJS0pJSkUkKSShJJL//0LooAaPTeA4D 6X7v8hUbX7+A4OH0/wB1/wDwim+59rha6A4+07Udz+73a93QpVrSEdpjzVltrmODtgjj+S5QNbLA 4tMgd0zrGNDd5MfyUlJbcxrjtYIMzP7v/qJRsvsEt4B+lHu3INTmNdrq0/vJoLZ2kQDoEqUzrdII aPafzf3UZ5qraLGu3EfSq43Ie1z2+ptM+SLQ8H2sEnu13/pRJSJ2y1/Gxh4BP0VIsr3Fn0gOdqa0 EwC072n+zCgxzC467B2dCSmXptYyRM9ipVZprYWucQD9IfvJmWNEssnbyoNNFjSLdD+a6Ppf8Ykp eyyt7RsLdrdQPzkWqh2RuNZadNWfR3ITWCsCG6kSjVVVubLTtdP+ajSFU3aARDh2ULHVXHTc1/gr T7TRcBktmRo5vt3I5BuaXNbNrfoN+j6g/wCM/wBMgVOe/wBLbA3bvhoi1WPZLC0Pa4a/vN/qKuy6 x53TqD7mkJ7QS+WucCddv7v9RJLcZXJOrt3G36Sr3D0bQ9rSPEH95QpawyHPc2yVZdS4PLb3SR+e Pz0kI6g7PfNrgHt+geEc4t1BL21gsiX6yq7MdrQ6SWu/NUGPa6BW51dkQ4T7LElJmuit1rPpDmvb +Z++hH0nsBrJn89p+ipVZVtQNYG140ke5Se6hrGgSLfzmJKXvpDGb2O9w5bCQYHlrmGT3rU7OoDa G2PLTEMIb/59QqHmRtjcPopKYMJG4tJH8n91SdfYPe8CwHQO/dUnlrh67SW2g+8fmOTOINRe0Ftk 6ifY5JSTFcLWua9wZ/WH/ntBNDoc6twcGnj86E7/AFQC6w8j3CP/AARHGwM9oHqEe10/RSU1r3hj WWVkFzuf/Vak26z6dTosBkt/e/62i2YYLd9hAcB+ag0te4B7SJH0mfnIJSWZHryHt1PBGkOVZgeG 7XGC3gd1YdfWXfon7mOGst2uY9DtZXa4bTLoRQnhjq/UrdDm/TD+/wDxaHYRDa7BqBurd/JcoOxg 1u8iW/vp6G072ix52cT+4kpLXW0Ni2W66eCTwxrXMmLRq2fovYk8gsdjsfuZPscQq2yXenZLdogz 7kFJg26ot1gn3NCk15Lzb9I92/R9yapr6gHNIdP0XO/NUaLTY5xtgtJ1j27nIqZNyHNf6joEHQNH ChaW2Oc4fTd7vaPYivp9LbLeZcEJ1bGtDmOmT9H91BTYxmvdXDGat13N+l/22gXNLPc4Ea6A/nNT 2ua1odS4tfPuaoWOsqGpnd+a7/z4kpauyyv21cdxCk0+qZf/ALlN85jmAAMsAj2nSz/1ImbWWbm2 O2z7Z/6ixJLD1XQa7Wj4phYayNp+9GNjagGvAeY0eCo2A2GCB5JIXpLTqI11hWbw0MB7FVWtAcA4 QPFWbmhjfadxH3bSgUhpXQTpwAhggt8VK32ie6E9zNvt0PcKrn2ZIudnO2O41I0Kplrg3e0zP0lb z7XaAEcaIFHt0MccJ2MaBB3am3cJTFpCNYBy3QIUQpULFMUikkpdOmCeEFMHo2IPcgvRsMiU2eyR u7dY0VmvlAr1CsMGqz5BmSp4TJwVAUsXuhpK5rJynWOIJ0B4XS3gFh+C5BwhxB11Vrl4DW2OZbNJ kprzLpSpIbqeEMgyT2V+hTGypHu1Sc8tfLU/0RKHE6oGIIU9N0zK9dkH6QWiFz/R8hoea+CVvgrH zQ4ZM8ToyTShXXtqEuMBULurV1uaOQ5Mjjkdgm3U3Jw5YR60A8tjTsoU9ZeWkuGo4T/Yn2RxB6GU 6ycPqrLyGHRxWmHKKUDHdINsyVHd3VXPvfRSXsEkLAHUbg4uceRopceEzFhBNPUeo3xTteHajVcn RlOYHSTJVzCzHUCHatT5csQjid229tY3OMAKlf1RjGb266xCx8vLNzjPHZUi48KbHy1iygyegf1l rQCByruNmNvYHcE9lyxcXNg9lKi41unyhPlywI0+ZHE9i106qUrF6bkObDOWnv8AurYBVCcDA0vB XJVe+4VtL3cBSutDBJWJ1TLn9EOOXKbDiMj/AFUEsD1N1l7ANGTCBk5d7LnN3aNOipNmQRyCtq/B a53rP0Do0WpHEAGIyRYFmVdYdror5M/mq868V2NqmXuEqi7qDWXMrqE1fRs/tKGTQ63qEVaFu3b/ AFU6h0Q7DJHuPZPY4scP3T9E+Ky+s5paBRToXfTKH0zqLa2fZsnWr81/etR5IcQpINOyCUi7xUhS 5vg5v5rh3VbMuFLN6zjjkJUy2wyM1uON06obOqU3u2v9jvzXfmOWLc9z3FxPJULGmAFdhhoUWMyd HIdk4lnqO1Z2LfooNebaX7t3dAxuoXYvt+nV3rd/3xWX4jMlvrYZ8zUfpN/qKT249kWXTxuoi0Fr vpDlaTLg4TOoXHNudU7X2u81tMsNJ3kyCNWhIit1O2LBGuik0ysQ5JDgXH2nhaePYHDRRZoccaCY mi2SUNz4SLlgdT6mS7069I+ks7HiM5cLKS6ludW1pdPGnzWSevO2ugaj6CxxYQNoOhMkKDtFfjys R83qYzN6Eda2+nvb9P6X8lazbWu+iZBXEk7hBKsUZ1lFjXjgDbtTMnKivSkTexlAfksY7a4wSlVc LWB7eCue6uSy92vI0/kqrix8UuFeS77cypwkOEcIm/RcS15Gg+K0j1KwUBoOs6lTz5UjZaJu/blM q1c4AJxe0kCRJXI2XF7Q13EyiG8tc1zTxCP3XRHG9eDKi7RZeN1dji1j+Xd1qHVV5YzE6r7tyMjp bLHF7TEqm/pDvzSrl/UhVYWkaDunHUa3N3HRWoSyAMZq2xgUmmraVaKFTa21u5pkFFJVSVkm2QbM SoFM54HKh6gPdCilkRCE5E3SoO4TlIXoFisOKrvT4oaVw0WfbytG5Z1vKvYmOSEqKkVFWFi6dvKi nCSnbx+AtZtJDA7ssjG0AXSFm3GaVCN2RpAawtb1DU0VA6FZlIG8buO6sSN5jjsnhBdLFtaWmufo 6ojz7lTadr2x25Vlxj5J6GcB0g8EKmw7XGP6oVkugT4KuYDwe30klN5riGnyEIem0n+ykHS0E/nG VIt9n4oKDz2YIcVkZHdbWc2HLGyNJSXOfX9JalCy2aOWnjngosTeYNFYaqzCrLOEwsgSBOmGqSjX rFMkUkFKUU5USUFMSoFSKiUkFaUkimJSQsmSlMgVLpJpSQUulKZKdUUMwrWPyqjSreMdVJBBdSpW mqrUrTFZDEkCSSdFTFMVIqJSSwKr2qyVXuSS51ypuVy5VHKKTLFHCZSTFQlkYym5TlNKSFkk6SCV uUykmSUtwkkUkkP/0YWem159E+w8SrLC232QQ8d+WOULKSysbhAJ0f8AuuQ3W2NsABG4d28OUq1V lVuK4te0tn/NVmpzbmhtn0R+6Pcq4gbm3PInifcg1Fze/KSm2W1tcPSO8dtP+rU32tANb6trh+fK am+t/wCjsEgiJHtUPsjX6VE7xoayfpf8XYkhKWWeiXhm5nJI+k1BxhJ0GnmptsspALHlx4dX+6gt vYHuNzTqPzEkprXHHd+rv0P06vpbFO2xjwGbCHnv+aq/qSWmeNOFYuqaGwQ4bhLHfuu/cSQwFDye Nzm9v5CYPxhJewkH836LlDZYRDzqFZt9J7GlxMj80t/N/rpJROpsIG32s/M3IDnjd7WkOH0oOj0R 1BYY3A1n3NM6JmtDmEkgOafo/wAlAKSvddkgekDtbptedyFZXksaSQ5oB11+ilWSdGu08f3UT0rH Om57iSEUIq77GmSZDvpafSSqsLHbvpAdnJV0v3CszJ4HipNY+okRz7SHIJWroNznOYQHD3BpP/ga TBXYYc0sPEg/nJm1GYEzyilzqIeWh08fykVKf6rPbYeDwnsiyLNpDW/ShQHpmTJaDrtHu2owfbWC 5gFtbmw8cJIWsLWagEtRL8mw0DQED26t/wC/odNrX0lgaQ8H6U6QnbSAILw0dtySmUVtrFrnB0aG s/SaVXuFIfIaWg+7+SiEe4gASBEIjrHVtlzZj2nd9GElNZ1gOjT9LUFE3suANsggRohmlnDgQDqy FAMNZ2k/JJLP2tdFZc9rhA3fmFWKbA1pF7Q4TqPovQGkO4EEeanfVa1wssBJPJKSGVhbWdtBJP0m 2fyf9Ao+mzJkk+7xHtUX2V7htG1se5jj+d/wakXMMktBDxt/qoKZU0B52FwkoL2+nLhrGm5qmKHQ 1ogumWu/ORH2WYxc17NSZd+cipA2xrhLpB/B6NurtrI2wR5qZoJE1Fu08B30kOwOc7a8Brm8+aSm dV1bZa9heyI2/uvQK3y/36T4q2aPWGytp9QcwhtZ6mhcDsPva76bUFM2vY2sgtLmnX+qq1VT7DDA OfbKk2qx7Hek72DUtTY43MIa/a76TW/vf+pElJHPurZvdB1jb+cxCsNTyHVkgn6c/vIjS0ND3AOa 4w6PptcgWEGdIP5qSmwWVMIfc1wD+7UrCKwS0b2n9791Q9Utbt3Esd9Jv7qi+ovbLTLh2/kpKSOt a5gbtGvuB/lKLbQ4bDDoPdFbittbD3bTzqoNYyolph37wSSj9NhETp2/klRc5zGgaTKIQDwfY76K G6ssncNf3kkJh+kfFpgcwPoqxa67QEjaPo6KlSDPEjwV2x4huxxLI+ieEikNKwnWdUC2NnmjXajd EAqvaYCq5mSLnZ5LXMdGqrEm15ka+St9Rd7Q0mDEx+8q4aXkWBOhsEFC8uENKi4FEyAZ0MoQ81Ih gUlIpikpQTpgnQUwei4vKE/RFxPpJs/lSN3dpJIVlirVDRWa1QkWZIkE8JlVlukMbj7D8FzAAc4/ FdLf9A/BcqHQ8nzV7lDYLFPd0MfH9Yhi0m9MZEFVelHc+Tytx0JufJIS0VEaPNZ+OMdwaOCqsiFq dX2uI/eCyDJVrFImIJWndt9PDfWEmCF0z7NokrmOmsD7RK0epZrWn0/HlVc0eOYAXxNBo9TyXWWb QfYqJMn4J3OjRFxqHXugKyAIR/urd2u4kmSpsJDDHC1LOjHaS0+7wWVBbLT25RjKMtlUtW8sMjQr pemZ/wBoG12hC5l4hXuj/wA+JMKPPjEo31iqJp6DqFrq6XOaJK5R7nHUrquoWOroc5okrmGzaY5J PCj5bQFMmDHeKsu/Rgs7FCtrayCEqybDt7lWjrqtYnwCTACYK2KOj7oLyg5nSzSPUZqBymDNG+FN FpbgPaULkpEyiVCJJHZS7LU1WRZjulhXUVWeowPHcLkqgXnXUDldTilrq27PoqlzMRoyRLRzLnC4 yf0bBud8ViPu37nO5JldPl4jLmbOCTLv5SpnpFTiBwE/HOMaigjqiwMFlNIyrYJP821SfRlZ5mwb GD81vgrrjSafsVmjT9H+TCau2vEZq8w3sDuVieTTRYA03dJZWBEzKtsqDMyxxEn0gVLG6m3KJrsI /kEp3Ni92Q0gtFZYWpY76lReXNjshzrH8uP3KLhtO09k1TiAe2vCR1Kep2ujZDgSwO9o/MctDNON cAL/AG68hYvTKh6u+eOyt9VqL2B47KrKVZKX1oo9HqfrTcD5FDt6HkctIcsYtPjCmw2tMB7h/aVu 1jp09Eu3A2DRX/2a5sFntI7hYb7rhxa+Pihi+0OBL3H5qOUeLVTvXY1jxF1Yf/KH01Vb0UfSqe5h 8HLJdkWtdO933oozrAJ3E+UpWQNuJLrDCuZ7bYc394fmqzik1t76HuqOHmOsEzPxWgH7xAUJyWaH pXVov1LINeMXt54XLSZnuV0XUtMR0awRoueIkB/ipoxEdR+kt6IuCrLcay0bmCUGoAvAdwSuwprD GBrRAhMzZeBIFvIW476tXCEHldZ1Ghr6XB3YTK5QcI4snuBRFO50K5211TuB7gqvWGgX7geQNEul ZgrsFbuCm600C6QdY9yijGsqr0c9rFYAbsIKqhxCNTU+921gkq0SALK1CdUgVcuwLaRucNPEKuyu SgJA7JVQze6CuqxifSaJkxyuXJDWw3la/Rsh7wa3duCq3MRsX+6mJc/qNu6wiNAVV9XaIVvqI32E jSDCzyFPj+UIL0vSoFOhnVTzcoUNk8ofSYFPt8dVk9Rv9S0jsFSEOPIV90FsnOfaB2QG5LwZBQnS ltMSrgxxAqllu1i5wfDXfSV4GVyrXFpDvBdFi2i1gdMqnmxcBsfKyRlejN6rvVl47qtYoormnd4L Ot5Wlas23lXsLHJCVFSKZWFiykFFOElOzT9ELqYL8RhXLY+rQupwXb8KO7SohuyNFhAJCLXygdzP ii1lOQ6Ak1wPpFEqJe2DzChU4Ct1n7oVfBv9Rs95TkN3tCrgzp34RXO1hAa/Y+fBFTYsftJb4Dar VkBoA8AFn6vsY3u50lX36u+aCnFz2alYOTwuozq4YXFctk90lznt+ktOjsspv0lq46LE3qwrLeFW rVhnCYWQJAkdEgmTCvWKaUimQQuolKVElBSxUSnKikhRKhKclRSUvKYlOVEoIVKeVGU6Cl5SlRSR UzbyreOdVTarNB1T4oLsUnRWmKlTwrbCrIYimBTyopSipeVFPKYpLmJQLUcoFqCnPuVN/KuXKm9R yZYsExTpKAsjEpoUkxSUskkEikpZIlOVAoqUkmSQU//SIy4uaS9/f3SlU7Ga+LSdp4LezlJ927/B 6+IQXOMbHMDmnWfzmqValeyl7S4gyOJ/OQBULYDWxPElHA3MAa8Onhn5zUANcDqO6QUkFWx20wTw QlY21stIA26ggpnx6gcwbT+c1Sut2jdWRHDmoKY/azMs0d3cVN9+8tfcATH5vf8A4xVocGdiP+ki srIZIgk9iipJbtLt1c7Y1b+6pB1JbtfvDx9DXcxCPqY7oa7QjVOXOBY4sAEQD++kpbI3OAc46nwR abzY0Nudxo0oeQ40iWga/S/koG0ABwPySU28jHdjPbsLXMcJkf8AkEFoh0SAptu9VuxzjA+iCn2F w3CNo5n97/0mgpJTWbyawWknRMGu1Za73M0CA4BhFjWlviW/QRMjIY8BwBF0/SOrbEVMrrXXwLfp N+i5qHYNzTE6/SlGcXXuFpGxwH5vDnItl7sqoi0hj26/8alSGmcYmvfJ0O3ckKSdAZj6QKshzXVF u34uT1mkH3k7vo+1JSP9EP0dgPiHt/8ARilay2kg0E7HCGmfppPawwWglw+l5tSIa8jY0mfP85JT BtoLYeYI/wA5SbWR7i2WkpOtDSWPZHmNU78c+n60kMn81JSO8bQDHwUrcit7GtEz+fr7XIIyrI2h wcHcyrFVbnjeA0yDMoKQt/SCRpGiLaBI7Ob7TruQjUaxuIOog+CPTYzYGhsWD84opZ/YxfS5wAFj dWv3IOK4iQ4/fqlWNZ02n81TLWh20tIP7ySExtrteW3BrWgaGFVrsDDFXuaNeFINaSQ4neOJ7hNa 8Mitw2vH+ErP0v5FiSkbi29/qRE+GimaRWQS5xB7lEY8tYYh1QMlp+nuUXZVL2GtzC4nh07fTQUs 201wBqJlK+wZLg95Ic3uf3UNoeSJ0IPKe6iyu0+r7ST/AGUlL736GSCDDXD27mqVGLY5++tsu8D+ ciWlrBss+kNWRq1Klp3b27mnxaUlLV5ddDt9YO4H6P8Ao/8AS1IJtJLncEncIRrLnb/0rJL59/73 /qVCaPTEiDOm0pKZmned7YDj9Jv5qC9znv8A0hBI00VljW2zUWulw/6SAaTU6NJGkFJTJsNdEy38 VbOE5rRZWRp2n6bf9GqttVlDg57drTqmsNZskQWuHtLfb/rakptjLq3wazqNsOPb/g1Sa0+oRG6N Ib4JrrPUawWPkt0iNrmqxX6ZDnBxa8fQe3/0YkpYhgna3du7n83/ANSKFgMS0EH83wUN7pb7onl3 /pRGDbaB6jiA08N5SSzxMf1X7XaOiQPFWL3QA0tEDt+cqVNjvVkuPkVdyci0gPeWxGjh+d/6kQKg 5uU8u5EDsqtmohGvmQfFAtPYDVVsrIGpm1iyJ0LRIKqtDg0ETBR+okvewRwP85BZJgDg/lRx7BBY uMiDyCgERwj28nugkSpEMSlCaITyipYKQUVIIKRvRsT6SC/VHw/pJs9kjd2qjorNars4lWK1nyZm wE0JipSoZG0ob/oH4Lk3D3GPFdZf9E/BcrYZefirXK7Fjnu6PTb21El2hhX7OqN0aNSRKwJLQlJM eSllhEpWUA02rcj1H73ID4JnsptgjzT1Veo/apTUR/dWt7o9Eu3kcJupYNj7i9gmVs4tApZtCnY4 MBJ7LPOYifEGTh0eY/ZlxGgWv0/F+ysO86lByOrNDSWanhZ9ma9zCAZ3cqc8eQV8oW6B3b8ljKy5 pk9oXLusNj955JUmWQ3YhnQqXFi4LQTaU8Eo3TWNfaNxiCq0kCUbAa11rQ8wnz+UoD0nUHPbQTX9 Jcux5Y/cNCun6i4tx3ObyAuXYDY7xJ5UHLbFdJVnuMnurvS8b1Lgf3dVSAjQrU6RUfW3ToFNlNQN IG70Yah3D2nvpwjBDunYY5hZIPqZXjrGQ4+E6I1TgNT4KNgfJe7uUIu0gLZGsQwlkHls7eCuo6aW +g0jiNVzNbCNSOV0tDxXQGgdpKhz0QkJLrhW0vPA1VNmedvrEQPzB+8qofZn2wzSsIGfktn0atdu jnJYcNeqfzKlLoFsvLBcQNXnl3g1BDw2qAgu9uiPj0PuENEgqY0BZQGs8btCpY992NIrd7Xchy0G 9IsP0jCr5mL9nIHIKQnEmgqmnEKIBU+U/CkQ6PSq91gdMEdluurBEQsLpbA+3U6jgLedY1v0jHxW dzF8ejJFxeo9O2TbWNPzgsxhDTJXUuvZOwkT4Kldi4znQdHeClx5jVSQQ4Zd490IrZf0xthOx2qA /pFjRLTuU4yxW05ZElJwIEK4/BsYNxCruaniQOyqY47jW8OC6Lplgud5RqudHErX+rW71bHctgAh MljBkJKvR3qfTcH12AEEQuQysOzDMOHsJO1y6rKtZQ4PnnQLF691E5GyhogD3OUiA52IGC1u/USu vAXG02Cm1rzqAV2LHbgCOCFn83dhkiwvaHMcHcQVxLtCY4ldte4NY4ngAyuLeWkktECU/lNiqbKj b6rN2gBGq0urtBtkGZGqzKNpsaHcSFodWcGXiOdsFWTXGFjR9EDnRbfRcfZWXHklYdj4PK6DoutJ M90zmTUEx3bz2SCD3XJ3sNNjgPHRdiQuOyZ9Zwd4lQcqTZXSYbo51K1uj2Euc06t5WO/nThanRXO 3lo+irGb5Fg3a/UnTcREKiRCu9TJNxn5Kk90p2P5Qou90twbQ4hY+RYbXl5EarQ6e4NxnrMe4dky AHFI9UnZZrd7g3xWkemQ2QVV6ezfaPJdDEqPNlMCAExFvKXtLCWrV6U72EeCll9P9R24cqXTsZ1R Idx2SnMTh/WUAQW3YVWerD0CxVQyNO7hZ9oWhaqFqu4WOTWKZOUysrFk4TJwkp2Mb6IXS9DsBD6X dxIXNYurQtPFeWWsPGuqhvVkbdrYeUzDCnlub6pDNWoQIT0NysOuHojQHVDwh6bnVq705odud+c1 Rycc03lw4IlPA0Qpx4KrvOoUy7lBsKSmzgu35Jd2Y1X3HX5Kh0pmlr/GGq0DP3oKavVLIp+JXK3n QrpesuhjW/Nc1fwklzm/SWljlZreVo0IsboMKsNKqVlWWFMK8J2lInVQae6eeyYvUVCU5TFBSlAq ZUUkMCoqZUYSUxTJ0ySFSolShRKClk6ZOEFKSSSSUuFZo5VZqs0cp8UF1KVcYqdKuMVgMZSgpSmC dOQpJJJJLEoNqOUC3hBLn3CFRedVfuVCzlRyZYsJSlQKUqEhkZymJUZToKXTSmlOkpYqKclNISUt MJJJJKf/04mq6hu4OlvxTV3OIO2Y7qdF43EenuB/NKJS98kshn7w52qVajrppsBLCd08IzBW0Hc7 ZZMGfcm9Cpri71gCf+qVYse3WInukpNkuLTLvcOxHgguMwHAR20RanOcY08PcnZb6D4fAHn7moKV WQRHbuisLKZDHS0oFr2B21rpPaNG7U+9jBMieI/eSUnb1Guh0ekHjgu/eQrMp7muYGRUTua13LE5 trjQR+8P3lPIZDGkkEHjX3t/4NJS7i01Au2idA4au/67WqjWw06AjhEbjgj26tP5qi5tbPomHAwa 3JKS0gVAF5lruQnMVE/ZzIPLXBDdcHM2A6D82Po/9cT02v7fekpM3Ltd7Ia0HRwhI47HsI03g6Oa 5Df6Dvc4Fr/3m/Rcm/REt2QP5X8pJSZuY2sCuCHRq781FNtjPdbWHNjRAtxsmdpAMjcIVdt7gCwa T2KKkzrntduiQewT2ZFTmgFkv8W+3ahenuPOsKYboNzgHA8FJTBzyCJkH95Fp3sO5oLgNSpucy2H 2biQfcPzEiDW8W48hh/MPuSQwax1rnWVgE/uo77Gw3Ia2APbdUHfS/60n30Al7JEe4n+Ug5BN7za 2Gv7hv56RUhtrbW/2fzbvcz+SiNYXNNRfA+kEKqvaNByrNVbLmOqLQH8h7vakpPTWQAwmWO8B3Sd j1PBqe7a8a+4bS4IDbH1jbYSWjsFKy1zqw+w+owGB/pGhyRUjINUlhDm8FyZlFlrXBgk+CTXNmLZ a13Dv3kzbGVHaAT4FjklLCttzQ5khw9r2qfpemfSdoSO/ZA9rp9pAM6/nKbHsDQXgukbWun6Lv8A hEFMfRewua4fPsVYONYa2usA0+jH0lX3W2CCdBo1O1pDdpeZnx9qSmbHMfDDMzoiWW0v3MLXHaeX H3M/9RKLaG7Q8P8AeD9H/wBGKVuVa136TaXcbgPpNSKmvtAHj2R67DWDua703CHNB/O/MQ8esEe1 wDj+aiBjXs22FzC0+4/4NiSUDrCQ1o3AtOod9HajO9EtD2A75hzT/wCi0MNcYaTuYDo9vgil+1r2 s22N8T7T/wCrUlMHvDAIJJDva0fSTiv7QHn0yXfSa4H3MSpsD9S2XD/pfyFI5TQILSGz7XfnV/8A B/8AFpIRCmwhpJLgPH81EvBxyanNgO4VgNyyZDd3eY+k1UAy2HHQtB/O+kkpturca2l7Jdy3Z/hG oFTvY7Q+ZH5n9dTx3NawGpzmWE8j6GxTbSK7tlln0hIsZ7uf9MklA9ovcG16x4fnJOb6hDHuIA4n 81OXBj3MbJP5r26e5IiGguPun3fvIKZiJ21mfNWhTI3Ng/vT+8qtYsts9sB58VfNYfG2WvaPc3/0 YkdlByLidxaRBlVbNDyrWQ577HEmTKrPhpgalVsjIGvlvL3NreYaB7UBm5hA2zojZbqwWl4JJCAy 1xduGgGiMNkHdHYS4QBHmhfR0R3nRzhwgN1EqVCNx1TfBO7wSSUtKkmSCClno2J9JAejYmrk2fyp G7tsGisVoFQ0VhioSZkySZOq0ko7jDSfJcm/3OJGi6rI0Y74LmBBMlXOV6sc90Z00RGiQrOLifaH wtinpjG86qxPLGG60AlxKKXvPsC2un4Zr9zhqr1WO2v6IhGiFSy5zIUF4itwsHrOUT+jZ2+kVuWC WkDkhcfbuZa4POsoctASlZ/RVIo5IbCVNbnmGo7WNI5Wx0zGaxm/kq/kmIRtjAtpUdIsJ9+gVK6g 02ljuy6i65tLdztFy+Tb6ji5Q4skpnX5VxADC4g6hEwgHWAO8VWOqtYIabBu08FPPSJWjd6HqRc3 GcWwubrsDRoPdK6jMB9Ejkwua2tb8Z+iq3LnQhdJfIAcA4K30dpdcDMQqFnCvdHaHXT3Cmyj0FA3 eoCjaSGkt5jRSCjbO0kcwskbsrytljnOJfwTwq72wJHBRLrC57i7QzwhyJ14WzDYMRS4bDZZJPtb q7+qtzGtF9O/hp0WUatlWxo9zxLv6q3en1tfQHAQ1My61/VUHO6ta3FAqxzAd3CyG+0ad1o5uN6j 3H6O0aD94KlTXvaSpRMEWikYBcV0uJsFYDY81z4/Rzqotsc0yCQo8sDMaKD1Flra+SufzbvtFm4c IORc6x5JMpmO0gpmPFweopJRxCaFN7fDhDarK10OmNa6wFxgt4VrrDDubZP8lVOm0tfYHOMQVuZV AvrLT8lSySAyC2QbPMusLnSSZ8U9jzu3EyfFRfW6s7X6EJEglWwInULC3+nXfpC551P/AEltB7T3 XMNfHB41UnZBNnqceSrZMJkbC4F1uo5LamGNXeCwi4vMnupXO3uLvEyhAqbHj4B/WWksnwBAW59W pFdpPiFhbS5dN0PGdVS/d3gqS+iG3lYzb2bXeMrl+s1CnLcB5aLsq+NVyv1jqIzHPH0SAjooOVWd rg4iQDwuqxctj626wSFyrNNTqFKu4tDgO/CgzYvcC4Gnouo5IdU5jCN0arlyIKIH6Ek8qB1Cdix+ 2KUTbe6dh+taHO+iNUTrQb6zQPpRr/VVzoeMWMdY787hVuuFvqtj6UaqITvLSa0cu1obwui6E0No Mdyubd7jquk6GGikwZM6o818iobuoVx+cCL3T4rsCuQz2kXOHmq/KbldPZqrW6K5xeWj6Kyy0xot Lou9thj6J5VzL8hYxuj6sXG0g6ALPiVp9WsJv93BWcfaUcfyhR3dfADXUOA00WO4Q4hbnSHB7HNj hZeZQarDPE6KPHL1yCTstgNm9vkukK5aq303BwXSVWh7A4dwoOZibBXQXcQohyxcvMey0hp0CPgZ brXbXJhwyEeJPELdFyr2Kw5V3pkVxatyz7loWqhaFdxMcmqUycplZWLJwmSCSnYwxDQrzDrKoYLp bqr7FAd2QbNkFSGqGERs7gfNSBBd7p7Cam6QToUXMZva09xoi1uBHt00BCrZTxuLJ5Ep4WtBw1QX ao9jY+Sru5SS6WCNmPPi5E2iPlKG92ypjR4bkQu4nnQIKcjrTvcG+ACwcj6PktbqTt9pWTf9EpFL mt0ctChZ7fpK/RCLG369VYbwq1Z0R2lNK4J2nsnKGCpSoyvC/ZIpFMSEEqUSpTKiUFLFRUlEpIYp k5TJIYpinKYpKUEkySCl0kkklLt5VinlV2qxVynxQXUoKusVGnRXWKxFjKYJ0gnhOQsmUlEpJYlB sRig2cJJaNyoWq/cqFvKikyxQFRKkmURXrBOkE6FpWSUgmQUxTKcSowkpiknKSNof//UJYHQbCdn mEOva468fvIW9obtDyGE/nfRRX3w0Pa0S32uA/O/lqVCSmiv1DXpM8p7qg5szJb2CCGNs40nVO/f X7WkbHCTHigUMWVNtcGuMNKZ1NtJcyNwHdGqo3c/dKdjLHAhmgnXxSS1gJgt0cNCp2UurhroLSrn 2Vj2EseA8dne3ch2CtlYaPcPzx+45HZCXDqGugcCNQ5V2NovLmuBaB9yQe5rIif+j/1xNi2tdNVj QZ7k7fcgphta1pDLNp/dP56aG2N3PBLvFOKHOJaRqOI9yOa27Wu4PZJTCtxtHpgBgH537yb0Dq48 d4ULfXrMP0B9wTuy3sLSyG/D3ByVqZvNbDAO4ETP8pDbDmGYHl/6TU/VY9xfa0Qf9GlsaeNR2n81 IKS4ltjXe33gDidu5qlWaDLHskOMtM++pQcx/wBKzRw09v8A6MStFbh4vH/Taipayg0EuJBHb+qh +r6QHrEGt/5/dqeqmmSXuIb/ACvck6vf+jrlzeTogpRfMtaZbPtI/OVpuU4CCyHN7/yf+LVQsdUB HyU/tT7CHSS9o0n91FTddcy4gtIHaOFB1QZLjDTMQqzXC8jisgaz9F6dry3c14j4e5qSEwtprMzu 8R/5BPddVcN1k6D2n/0qqpsDm+1vH3qdFoPJ8uElMw5oYHn6PBbKG6B7m8cFG9JoguBDezlDcyth ZawkO+jYPzUlMXYz3FrNwAOv9VRFdjHEfS287UmV+kfY+RxoiMY6iQSRI4CSV6rK7mem4lrgfb/6 TQS2QdoMD6fgjU49V9ZIftsad0fvKBuLySwwCPdt/OQUqtu/2ASHcD94qL2uaCOCDqx302/+o02k BrjsLYPCa3IcLC5ri/t6n7wSUkblGza1wG4QA7j/ALe/4NSyrrd/pvDdoMt2pmCnJBlhD44b+cq0 ViPSdIOj2n8xySkuQdhFjS2T2CJTlvpd6gkAiHab2uQS6trtlghpMF3/AH9TaBSXNa/ce3mkpsYw 9Qyxmp7M+gkfeS65pZDoft+j/IVdl1t2lctn6Yb+comu1urXEj90pISteWWzj6O/lfRdCe7PsJ/S 1gkn3kabv/UiGH2B4LteOVP0iwOsImsa7f3dyCWNeQ6o7g5wdPtg/m/6NSyMq1+0u8ZQa2BzoOjX IjqZY4sk7eY9yKkXsJ9+gmdEd2UGP3SC4Rs9v84z/hEBr3yNrRB/ORb63VuYLWtG4ex37yClWV7X j1IDXDd7SgxuI2HXsjNIpAbczeQZAn2Oah7XGXMA2vOg/cSUkAO4Gxs/lVi+3YJqJc0iNyqix4I3 yC0Rr+6luDHkPbuEaAIFLXcwsG13IQ3jWRopbi7mZ800T8fBV8uy8NLMrL3BwHAVHeWuPgr+SHhw fXOnKA6pr/0g0B5Rx7BB3XLGubodfBVjLdFYNzWn2j2oDrN5lSoYkKJCefBIpKYynHCUSnCCmD0X E+khvRsQe5Nl8qRu7VSstVerhWGrPmzJQpBNCdVyEocn6BjmFypncV1WT9A/Bc2NZJV7lRoWKbpd H1J8FutCxOjggkdluBVs59ZXR2XSSSVYlewtEtIHK4/JrLHuaTLgeV2RGi5nq2Ga7d7R7Xf9UrXK yqVLZhz2kwjY+VZS72HRVwSNOydsBaEgCNWJuZmS6x0HjwVN7ieVbxMF+QZ7I2R0i1phuoUcZQh6 V1EuawAqzhtHqAnsi19IvcYiPNXMfo1gMvMRwlkyRoi1AF08vd6BLeYXL3aunv4LrbaDZSa5gxG5 Zp6G0j3H3eKrYckY7riLcDXhafR6g64O7hX/ANi1acz3V6jBrpcHtEEJ+XmImNBAi2wmeDBjlSAS IWeCLZHjMiX2uJEGU9VX554HZdUcOsv37dVL7MwahoWlHmQAxmLzGLi3ZVuoMHv/ACV1ZDWMFbdI RatjhDW7Y5hRjcSUM+UcOn6agNXK6nguvG6swQOPFYno21kjaZXYFqgawedVBj5jhFFcY28cWnvy l6T+IXWnFYeWhTFLfAKb72Oy3geZxumvuPuEDxVrK6Ua27qpPit4VwpbVGeZld9E8LyYxbnD2gwk 3AvcCdugXVbAn2J33sq4XBwunvJ3u0A7Ld26KQapKvkyGZsrgGlkYNd/0hqsu/o7mglhk+C6BRLZ RhnlHqgxeSOHaOQQUH0XzEGV2Lq1D0m9wFZHN+C3geS9Fx0go7emWuaHAansunFI7gKWxNPNHorg cnB6Z6Xvf9LwWxjN9rgE21GxdA5DDkM8mqpCgwD9vZZ2RS3Kc4PEgrWsAglUK2qfmZGICIC3ncnp FlQc6vVo1WWWEciF3RZKG/HY7loPyUUOar5lxi8UGE6AStbB6SXgPs0BW6zFrZo1oCO1sJuTmrFR UIIm1hrYHAWB15k2NIBkDUrpCEKyoPmRKgxZeGXEVxDw8aLpOhhvonbzPuVn9m07g7bwrFFDaQQw RJkqfNnjONBbGNJCuRzTGS8O7FdeQsnI6Qy17rJIJUfLzECeJMhbz3qaz28Fq9IlzyW/R7on7Dls 7tUfF6aca3cDLYVvLkiY6FYAbc7rDHeruPCzfpGCuh6jguvJcDxwFkPwLmEe0o4Zx4atRDp9IjaY 5CfqtIc3dGoUukteAQ8Qr1te8EHuqsp8OS1wGjx7mlpVqrMdS3a0zKn1HF9B2nBVLYYnsr+kxbHs ta7c6Vo9KYNxKzFtdMpLWbj3TMxqFJjqW6UGxHcgv4VGLKWnaFQtWhbws65XMLHJruUVIqKtLFkk kgkp1sP6AV+tUcT6AV+tQHdlGydqNS6LGjxMKuNEmP23Vk8BwTwtL1jG7GDy9qoZD5IPgVo2kQfA jcFl2kE+RUiGD3ADXuq7RvcGjxhGcAWFzuyjg62Bx45QU3bmw6OwhqdxBHzTl24z4kuUXaNPwSS8 /knc8lUL+DKv3tIOqz7ykVOb+cr1J0VE/SV2jhFjb1fCsNQKuFYamlcEjdE4KYBP3TCvXSKdMU1K yiVJMUihim5TpigpiU3xTlNykpYqKkkkhiknSQUsknhKElKCsU8oHdHp5TooLqUBXqwqVCvVqyGM pQE6QTpyGJUSpFQKSQxKDZwjFBsQS0rVRsCvWqnYo5MsWuQowiJioSyMITwnClCbamMJQppQklhC iRKKQokJKREJKZCSVqf/1RV2OqaatjXg9j+ap0ODJDvmFIvp9tlI935+7hD9T03ktgBx4/dUiE3q Xtb6Yj0zroPco1V7AdAfiVMwyAHyT+7+ap7w6W3w14Gj0ihBXiv2mxpjb5qLrTpY5xl2ij6mhDe+ jv5aekvdW6oOG0/mkf8AUJJbA3loc38U1outrLuA3naqkPpMTqpvtdb+ke4lw0Lfo7kFMxjvLPUa 7+zKXp1vGjTIHu81Ku95aBVGnkqrrnl0nR0pKbVdNzILePHyQrGbXna6dZkJqr31uDw4pOabHS08 lJSYWvOp9w77kO5+90hu0Hkdk9FbnOj70RxdQNhmCfokJKY1gOftDo+P5rkrN7AWu1PYhNY99zwb AA4eHdFeWNbElx7/AL1aKkjbqwwPex25vO36TkJ+S2yWMAAOrS5ANtjNdYOm5PvJbAGnjGqCF7bH PgOA08Eaq+3YGMeB4HvCDDbSS93vjT+UmDgAWvBB7FJKWyzeBTaALGn22DuiPxHMaHAhwPdp+j/X VZmQ2vRzNwPf91J9bA4PpDmyPdu/eRQmLW8OMOH5pRWOa53pkFxj2lqrux3trbY50tJ2/wApidlo rdO2HDmUlLM2BzgCd3EJ2tLj7NdeFAvaXF7hp4hSsbWSXB8Aj6QStSZ7XkbXvcWDlqBZEFlby+v6 UH81ynQ2y1rmbtYlv8pBfS+s7LBsedRP5yCmTqX1OaQIDhuapvNtjptdJHChXXJggyEdtegJ1RUt S91V+3cG7hzG5Rexzd2kwZ3gIt9puAY8jaz6Dw3Y9Q+1EN2gHTx/N/8AUaSl6t+UAHPG5g9of+cP 9Gp2xsFm2Bw6DpuSqZXliHQ21vua4fnqo1zLXAvMAna5JTZx7wDuB2vbqB2TZGQ51u41ta4HVreH KFtJoc4chugcEqDw7lJSRl2+3cxgc39xyAysknT5IhbscHPft3Gd6L6lrGl9ha+uYJ/PaP8ASJKY 77K9mx0EcFv0kO6527UncO6VljXO3NZEiCQfp/8ACoQDyPHzQUycTc6S4uM91NzNh3uPtnaWAqTf SsbGou/NI+i5Dex22SCCDqkpNU8BwJIaAPaT+cmZnurNhbO5xkWD/wBIpPq9NrQ/3Ajdp9Nii1gi BqRqf6qSk1O+ys1TDD7pCFXS+53pNIeYmT+Yp1Yzb5HqhrBxPt3JA+j7HAtcP8IPzmpKRMoc+Wsd DgPcHfRdt/0SZtFgG9jZH50Ih33ACA1zex03t/8ASiEGWtcC4ls6c+1JSe252QQXExG2CFGTt/SM O1p/nB+Y5DJcHgF3B1RsvV4aLPY7VwH/AKNQKQ1Nxn3GCU7G8lJ7mulzZ/dUmcEKtmNBeHJzHEP2 yQ08whV7ho3UK5fiPyHRXq5vu+SpCxznbphw0KOPYIO7Cxxd7SIUWjajPbOpQHuk+SmQrzTER8FI lMTKSmMJwmUgEFMHo+IfcgvCLifSTZbJG7t1qyxVWHRWayqEizJwnUQpKEpQ5Iljo8FzDZPxXVub uEKsMCvmOVNgyiANrJC2t0ZrhM/RW2AgUVNrENEI6hySEpGS6IoLJ0klXK5ZDsqFg2uEgoqSQNKL Qs6bS/8ANT19OpZ+ar8JQpPdl3W0ETKWs0AhT2SpQnUZkSmmOxOGqSSBJSqE21SSQtS0JwEkkbUu kkluhEBTICAokQo+pYDpCLVkFx9O0CD3CnjGMyIgrTYZABjST3QgEbI4AbwhJZ9CI/uIj3UlCSSr rlJQkkjalJJJJKUkknSUpMkkkpSRSSRUtCUKScsIie6VE7KYQkjjGJ5SdjOHCl9ie9I4ggIU8b85 RII0KjW6HkDunYLjkFolqE5Eqo1sEhWwQAO6BZHqGO6uc2LhayG60JQnSWVbMxhPCdMkpRUCFMqJ SUxhNCkmRUsmhOkkCpglCkUxRtFMC2VAsRCm5TgSFMA2EipKJSu1NXJobc2HKhZ0wbdrdFrEKLhK nx5TFaY241PTA0y/VaDWhogIpEKDkJZDPdIFI3ID0dyA9KKmtcNFm3BaNqzruVewscmuVEqRUVZW LJwmSCSnZx9GiPBXmBUMZxLQVuUUB1Bf3lQVqyhrKz9k3Y3rjndtVY6BbrKRTjA8teNw/rp8VpbD Ld1LD3ja5U7OfgVDHtJ3MP8AWClaZ18U9COxu5jgO2qDg27WO8eEdjtdeDoq7WekdviZSU6dWoPw AUnM3Ejsmxm/o2+ZlFYPpfBFQeey2w7RZV2i180Q5ZF/cIFc5p+krtJ0VI/SVyg6IhiLoVcKy1Va labwmlcEoSSCdRlepMU5TdkEqUCpJigpimKdMUkMSmUkyCloTKSYhBSySeEkrUtCeEk8IIWhGr5Q u6KzlOip1KDor1ZWdQVfrKtRYi2AUpUAUiU9DIlQKSYpJWKE9FKG9BLRtVN6u2qk8KOTLFEoqUJo UBZFk4ShMgplKdRCSSV0k0ppSQopJiUkkv8A/9aNlVm0vO0NPP8AWQqi11cOE+YQ3NZ9GSSe35qI xsDQxp2T0JmNZSJje08/muCY1Nu9zRMdnn3QqgeGHmQpkB59kkJKXFYH83oPNWmUlrfVJgA6oNR2 uBdwlY4CfSMAmdqSmd7q7G7mAgg+5SuqBDNw2hw0cD9JQZkWNPtgCIOig5znaOj4JKWY4UEnlJrm ubqJSYOTzCauxswRqElJjS0AP0E6/wBZCrfJ9mmqnbW+QYIadWgphbWPbGqSmyyp1rxBgnkfvJ32 MbaaMhztre/5yF6IsECyNv0XBRdiuBD7XzP5ziihlbUx7v0dggcFLIa6hvsLbA8e795igKyxxNZg +abbt1frPAQSzxay72udDedeylY9tTy2t4cCNS3hDqudS+YB8j9FzVOxwshtLQCfdx+d/wCk0ipT BSQRw8atP5qE+6WgnQg/2URlxIIeQ147bfpKTdtjfRLwGH3HT6DkkLUPsrBdWAZ5EILCQTEkeH7q sU0ktc9j42nQ/moV9hdZqwVuGjtv0bP+ERSkoNjQW7va7t8ESsC8n3hrx9Dd/hAgMt9hY7x47f8A GKw3Fx2kNuJbuE1ub7vckhrGp0nTuk4y3b2Gv8pEhtMPrsl45aVOw2Wj7Q4tsjRzPoP2oKRe9pHp mYhzS3lEsyLLj6dnu1mXfSYhC6to3VFzXfm/yT/o0N1xfO8S4/nJWlnEO+lCNVU4hw2lzh/hGn6K qOPczKPRktqbuaPkSkhLTkseHsscDp7dw925B3esQ+w6gQpPy2vO41jfyCP3kB7nXPL3aE6mElNj IIbSH1tI2nWwJmtrsYdujok7j9JKt9gaWB3sPLT9FCZS6dBJCSlzktNYY2v6P588o+PkNrMFoLXa GeyVnpV2Na4FoI9zm+7Up67DTYfQMtj/AAjUgpEaNz9jWkk/ip0Wtx3FpMkiG6Jmv3t3kQWmXEcJ Pvqc13tkzLHIqXZtA3MLZGmw/SUjc+trXSOCZUTFx+hssj6Q/Oao73Vt9sAj/pNQUzxq3PI9Ngef IqVj8hxFdpga7f8A0kotvrLmmsGkxtL2lBIIJY524zr/AOTSUkJsrfurJBAADuf+tqLbHAl4kPP0 tvdPUS0xE7tP/M07rCLNz53/AJySkJDQSDJHwR2lu39IOBET7lPFznVEkMDjHFiizIpseDY3bJkl v5qSmDNpdtyCRpAef/A1Ha+gw/3AcA/nIv2jmsMDgdJP7qFaQ5wDJgDg67UFMWEHSNusgKzkiuBZ Y2SOzf8ACIDHGfJFyS4ubGhHikUtVrQIiQDw0oreFF7Q0wSPKEVo9pVXPsyRcrLftuGpbpyFSe33 eInnxVvLDSYdz2Qw9zRAAKdj2CDuiJB0PZC0JgIm08kKB5Uy1cwFGeyYyUkkKUgoqQQSwsU8Yw5R fwp4o1CbL5Ujd2ajIVmtVqRCssM8LNkzBOFJRCmoTslQUoUQEQJgUuBCkop0gUqTqKkmFSkkykgp SSSSKl0kk4QUpOmSSUukmTpKUnTKUgd5ThG9UKmFFLzKcIE9kqUHMlTUm9yjDdBWq2uls6nsf++J BRaAHAu4TzOqlyS4hf6SAukkkoFykkyUp1IXlJMkElLpJJ0lLJJJJKUlwklCSlHVToI3wVAoZfsc HKXEamL2QdnRda0GSdE7LQfgqu5rxBVd9z6eBLTzC2bYHTLGW8oD8SDuYdfBV6coO1aZ8lYGUByh wxJuvUqyxZVA3O5Cq2GbDHZTvzBrCr1nd7vFVuamBHhXwGqdJIJLJZlJk6SKlioFSKiUEqTJ0kUL JinKZJSxTEpyolOUsmTpkVLFRKcpikpiUjwnKiSnAoRFQKIUMohKJyC/RGcgWFSRQWras+5aFnCz 7ldwscmsUycpirTGxKnUA54B4J1UE4KSnbDBXo3gLo8Rs4e7zXL4xlgJXV9MO/BjwKiG7I5gb7gD xK1s57qq2UdvpBUsPa3Kbu+jOqLnvDr3bTuaNAnhawYS1wd4KxZ/tVYNkQih+4fgkliDBUrYPu8R AQyYUmHc3+rqnIbOO+AfIbQrbTDCfE7Vl1OgifHctBx9jQPNyCg4+dySsbIW7nMhYWQkuc08q3TI Eqm76St0nRFiLo1lWWqrVorTOE0rgmCRTBPKjK9SXZMmJQSumJSlMgpZNKSbugpSSSRQQsmKdMgp SSSSClJ0gkkpSKzlD8kRnKfBBb9CvVlUaVeYrUWMpwnTNUk8LWKZShMkliUN/CIUN6CWlcqb1dtV J6jkyxRJpTqKgLIumTSmlBTKExTSlKKlFMSmJTFJS5KSiklSn//XpO3ggERHBTttLHbnCT5/nKw+ xz/cXAAfRYpH0nlrS4cf5qehqvc2wyWhg8ApVEhxDHadneSuUuxscmvIBd+69qqu2V2n03eo3sY2 pKTY5c08pg2t7v0p2unmPzUvtDXRI2x4Il9z7oscNzhoY8EVMb/QqdFLvU8dIQjax0EgqeVkNua0 emGOH57fzv66GGkETHigpsvqYS12PIB+lKe9lLXfpCSSPpfylXfYbHeyQPD95Gpta33GuR+c1yKm DhXtDQ/d8PzUwsOnqN9seHu2obw17y5jdrCfo/uotlNrQ2H7xGgCCkTSKz7CSP8AvqK2+tgILd4P Gv0VXEtPEeSIGs2F48YSUy2kANAPiHeSZzRs1ncOE7ncbXFwI+j+4mdY61onsI0H/nxJTLHFW79I 7aPFPdWQ4OENB4c09lGisWAxoQiWV1h4DZLY1b+6/wDkIqR5dbawHMsa/d2H0kqgDq8wO5CK9zXV Fj9og7mSP0n/ABaaWNaPVEfukfnJKX3NbPoTt/O/ctTesxjy6xhLXD2td+b/AMXYiYxA1DZk/wA3 +83/ANKJW5nrE0gxXOgcPcCgpiTUWyCWl3Dv3f8AjEP1LKYc4h8cIjf0DpgO7bfzXJrsasa0/Rdq W/6JJTWh7nF8QedFZoYLHG1x9zT7v6qA0MA9zjI5U3VsYTuDiCNC1JS+VpY57oDSdIH/AIIosr3j 2DUKdVr9oL27mD2/1UzLBW7e1pEHhJTPHdIBAEtOu7hPcPcS9oaT9EN+i/8A4tRteXH2Nnd7gfzk 9V9tp9rpLPoh4+ikpC4t0YNT2hOz3PJn3I7aTa9zplx90t9vvQ2vaXTaIeREgfnf8Ikpe2tzTJc0 tjSEK69tgB2hrgNvsP0kxqLeRJmD5JvTNZG/6J4KClmABsmYCs42Sxr22GYH9pTFjmgUvjZ9JTyc WvW1jfTAhu0nl3+kRQve91lxvrZuYfpNaPpD/i0OpuMC55LvS5IaPdWoU22VmGuLfgpevXju1Ac4 /nfmub/wiSkb9r3AMeXMH0T9F2xJ8ghrySOxhEvyGl7RWNrW9/8AX/BKdZbVYPXMtI5Z7klNZzw4 h22IEGPz0cY4cN4EAcuR6qse21vpOhxne1/tBVf7TbWxwqH6Nrtdf9f0aSkdjH1PlzSGn6Dv31D0 3Fx2AxOiNbmWXsFTm6D6MlO8AFrQHVvgS0/Rsb/pElLDKIbFo0Om6PoqLwGmXEOA7hTdaT+iIBrm Zj3qVlPpVttoIdXOp/8AS1KRUgF4bI0cCEzHBp3RPkme0AkwBOun5qI6t9MFxB3CW7UlMayXGRoP BWbXABjK2ne7Xd9Jm1VBWHOEcq3TVZi2ixoHGyD2SUGifaSzwKss1aqbQRMnUkq8waBU8+zLFxMt 8WR8lVLC3XzVrqDf0oKG5nt01nhPx6gILEv01GqC8gnRHeHN9rxqFWfoFKtVu0TJgpJIUFJqiFMJ JYPRcT6SG/hExPpJkvlSN3Zaj1CCgs4RmcrOkzNgBTCgpSoidErhSCjKdQ2lkE5TBOgpQUkydC1K ThMnSUoJ0ydJSkpTTCqvzqWz7hLeU4RJ2U25SlZjur0Bm8GQi1dSrsLQOXcJxxSrZFt9KVGVn5XU PQubSR9LuhGBkaG6rdLsSojRYTurv9U1gSAhs6zYCd0eXxVg4JLeJ6MFSWd0zIffVvfyTotAKvKP CaK6104ngJk7TBQhuorJ4TBOgVKTEpKDzofgkApHZkMrMOME+Kg7MqaQC6J4XL5d9l1k2ct7ITrS 6J7K/HlbAWGT1z8utkbnAAo7XBwkagriXWl/J0Gi6To5f6MPED834JmXBwRtIlbqhOohOqi5SSfl MUlKSSSQUsVB7ZCImKIKmuy30tHfer9WSwjhVHslVLKHAywwfwV/FzNaSY5RdOzFpt9zfafFqr3Y jmNABJcVjftt2Nb6do0/eatnF6pVkN3BwIC0IkSFsRsNGprnbq7RDm6z+a5XK4IEcKzkVtvrLQYL hAcqtNTqWCt3IESqPN46HEGSErSpJ0yzWZSSSYpBSiUyHSLA2LDJU0iEqSSTJKUmTpkQhZMVLhQK KlimTlMUlLJk6YpymBUSpFRKSmBQ3KZUCnBSJyBYjuCA9SRQWrYqF6v2KheFdxMcmoUyk5RKtMay SSSSnWxfoBdP0Wz9Xsr78rl8My0Lc6e8sJA/OEKHqydA2MS5tWQXPEiEIuDiSNBKhYCHkFO0p9op s1wdPFPYz0nFnzSxnAPk8DVVfWNlznHudEQpslRYdS3sU0oc6yihI7mB3hq07HRYPIALOpbvuY3z lXNS4nw1SUhzG7gXfFc1k+C6bNeBUSOVzF+spLi5ruVbx1UPKtUFFiLoU8QrbOFTqKtMKBXBOElE FKdVGV7JMkmlNUqU0pJiglSZJMUELpkkkFKTJ0yClSnTJIKXCXCZOkpdTbyhojOU+CC6FKvVqjSr 1atRYynaFOEzQpp61gmKmVApJYFDeiFDeglp2qlYrtypWKOTLFCVEpyokqAsixTJ0yClSlqkkipS ZJJJSoSUkkLU/wD/0Kr2mvntz+6pNpDzu0g+KhXc9zh3A7H6KlVWx9sOboT9EJ6mVlb3CQB7UmBz ocdPAhDyqhQ9zYcwDhpMqLLHdjogCpuOa4wQQHfvc/8AbiZtb6WGw8DRw+j/ANtoT7jtkiI/OaoE 2XlosJPZqSGTYsHtBOvKttdX6ZYWAk938tVZjdhLH+2D27KbzscCw7vAFFTETXPEpi617tzpJj4S oXNsl1jwBHLQi0B1pjcG+EpKRuYQN4BAU22UOZ9FzbB3afa5PYbWnY8x4eCQFbG/pJb8PouSUjuL TBMh35yY44eQaTJP5n5yc5DSTtE+BTA2NA2aa6HwQUoWkET27J3W73lzPbP0gpPFm6bB7u58VFxJ dugfJJSi6wCDoFNwbW4ESA7j+sincKg18BvLbP8A0WmD2hrWTLTzHu2oqWHuk2MLjB2/+TUsW8gB pYHjn3e0otb6nna55bHl9JD2Mud7NA0dz9JK1MT+kt9SomTyz6Pu/kJ7nxLXVkEH6Tvp7v8A0moG w1e1musiwcbUd2TDha2IH0mn3bkkIJaW75me0oleR6T/AFPSkHkSoWWHJfurYGk/9L/1IpOc+gGl zwA4cR7muSStdYL3BzWNZHhyf+MQoPZKpwkB+o7q7QMXc7cHGo/57ElIAx7H+m47Z8VJwdW/ZuDg DrH0UK+ioO/Qvc8R+d9Jv8hToYwe2DPkihc3WUvhkHbq385StyzkA3ENbY3Q7dJ/r1pngMcNtZbt /wCkqwO15c0c/kQSkF1riXQ0g+HtTuNhY1zoLQds/ntUa2tcdu6Piojkg9v+kkptNobsIseAOQf3 kCuprhtg7ydJUmAfScSGz/momUC1zXNe1zhxCSEdcVv9N/LfzU1h3kuDSxv7rzuRTkuyGBu0B4M7 vzv+LVihoZLrHNDXCDXZ7klNOWubDZlNU1rSZbM/mpywtlzoe2YluiYNa4jYCHz/AJ6KkzNoEPZA H50qJvLmbWgBk+3T3f8Abia2G+20Fvki6Oq21TJ+kHD2x/pGf8Igpqei17S5x9oOvii1VUvbElrv zf5SJi/ozua6XkQWOCutxG1VGy4Qw+5uz+cb/USU0yxzqxWay1wMGxRe0V7W2WbiNCz85rf+DtTY tGQ/cGOdt5cw/uodxY93pjVg48YSUoXWUO3tHsBhriNyQD7g4tABJ3H/ANVolNtrGmth9hPua4So Wh7CHEBp7AJKVtc07Inbq4ILW9x8VJ5H0hILvpBNO0Et/wDOUEsxA7zKPZextcDTwd+8qxDHOlkk Hx/eVwU1D+dYS0DcS36W5Lopzw8P92oPf+srbPooLHeqDDdvfVFZBb5Kpn2ZIuVnkeqNxhviq/qu JJYNPJWuoS2HAgj85ios3NJLRoeydi+UIluyNhePdq5DLdEet+/nnxUSQTHdTrWuQm4U3lQBSQyB UwoNUwEFMH8KeKYdKhYpYv00yfylI3dpitVhV6zpKNW7VZ8mdsJJ+yiq8lzKVE2gd0LJfsrc4cgL mnZT7NSU/HhM9VspU9ex0jRTWf0p7nUjd2WgoJx4TS4GwunTBOmqUnTJ0VKSSSSUsTGq4/MsDbn7 DoSuwK43NaDc7ZxKu8oBZWTRmz2bfOVZ6ba5t7e4VABafSt4tbA9quZABErBdvULC6kXPzGMjRuo K3Vj9Rc8XTA2ME7lR5b+cXy2cSokvJ8yoWGDp4qLHlp3ecp9peSVp9bYno+isdXWZOh1C2AVj9Ga 5jDu+5a4KyM3zlmDNIKMqTXxKigNUqTqEynBTeql0OyYMKag/g/BOjuovH5VhfYS7kaFVyj5Li6w lwgzqgOjstyHyhgO60rqOjl3o+7j81crOq6fo+9lXv4/NUHM/Kui64UpQw5PuWVTKzlJD3pw5Kip mkoboTylSl0k0p01S0KDhKIVFycNFPJ9WaW3mFTxsk479w4P02rqMrBqvdveNVUPSaPCFp484EQC xSDa6dnV5Df0b+OWO+ktg1l9c91g43TqabQ5vJ7rcxgQNDoVPYyRKzYoQZCdRd7XEJbljThwyIbA LJMmlKUxK6ZJMUlKTJEqO5GlLlJNKRKSlFRTqMooUmSJTSipSZOVFFTEqJ0UioFJLEobkSFApwUh cgWKw5AepIrS1LFSuV6xVLm6SruJZLZolRKm5QKtMbFJJJJTqYR9oWrW/YRCycH6K06z4qA7sg2d C9kEO7HVCBTvfMBRTglKwkuDR3Kt9UobVa1zRoWhD6bW6y8PH0WfSWr1CDVES4H/AKKkCwuL2Q3a KYUHJKT9P1uc48BqsyJJQ8ABrLHHk+0KTT7fnKSkfUjFA8yubu7re6s/2sb5LBuGiSXNPKt0Kp3V qhFY361ZaVVYrLUCoJgVJDCmNVGV66RSSTUrFMpJigpZMnSKCWKSdMgpZJIppQQuklKSSlJJJSgp SKzshcIjE+KHRpV+oKhQr9SsxYy2GqSiFJSLViVAqRUCklYoblMobuEEtS5UbCrtxWfaUyTJFESm KiXJblAWVdKU25NKCmSSjuTygpeEgE0pSlamYSUZSQS//9GjWByToiF9Y/m9x+Pt/wCmi7wyA356 KNjARyQD2T6QjqudR+YHSPz0GZO76M9kYtdVE6tPBUXV7/ojUchBK7HOEgceakS99ZaSdPopCl7u CCeyQvdWIc2SkpeWenyfUn+zCiGPkefCm5wsHtaIPb91SqqsfoTDQihhkaH03sIf+9Kevb9F6b0D uJa4uaD9IovpNcN4cN/7iQSie6zb6cy2Z/lIzLX7NgAifzksj2gOeR6h0ho+k1RY9sFrmzPGvCSF ntO8hwglTFzWQHgyPDu1Nax1PscZPITvaGthzZJ19v5qCmDXN3+0+w/vfmo+RjisCxjg4Hlv57UJ uMNnqbhHghuLy6W/h4IqT0lrZ3e7cPopUB1JljZgTCAASILiJT0XPqdPJ4MpKTZTjeRdc8SR7doV YMDxI0Kts2Nx3n2kzq0/m/8AFKQilotpIe06PY76YKKkIw7m7THtdxCZ1bQSD7SOD+a5yM7Of6os riqO30lK1xe4j1Ra13uOm33oKarLNw00IRh+mdDwCToXOQ8nIFzgfTDC32nb+eo1WDdBQUnFFLm6 2Br2mNqbYbq4dDXDTd+8hClt1hFcD+sp13ekNp0dPyRUtWH1EE6AHlFrvLrNHBhP5zvoqNuT6zPS cIg7gR9JDq/S/ojEHTVJSS+6x4LHPBg6bVBo3e5xnsEMsbU4t1gHRHruJ9rBuB/Nj85JCBvuPGo/ 6SmAGukApvVLjtjaiN52uJhIJYWWg9pHE/8Ak09m2AWVwQId/wClFO6oUu9vuaRuRRliiH4nMe9t nu/7aSQ1hULSHDQnkoluPbU3dtkH88pjU53vEtLuY/eSZfklhYDLAZcElM8arc15bBgTtJ2/9tqV VgeDuAjSXH6TSh2aNFjNumh192qb1C5xDgAT3RUmZjNuLg1wAB9psKVmN6bAZBP8gpOoaB6lmhHM /Sco110v0psh06tdp7UFLOtdLXaAge1zUQXOJFlpfrwWhVxi2Vy9hBg8cuRajbYYtl1Z95DUlMbs gGwtY8uZ+afou/4uxRrNTo9UlrZ+kOyYsaQDVzPB+kjNsNTnNJBa4e4EfnJKR1tra4tdYCBw799q jezHaQanOeIgg/mn/g1KtlVjwGV/cVGzCvoG97Yrnke6EkrM0aS46kewfvItFT7K3ua0Ob+d++xR sfUGhjWncDJdP0kDcNSCWnwlBCVrfSMg8a7key27IZ7XDa0ccFyrNgNl5+lo3/1Ii2VZNZa21kMI lhbqkdkoKf0h0PZGYRtlC9tUgO1U2yGqpn2ZIufnXek8bfpnSfJAcHV1l0o3UvzeOf7f/qpU5Lva n4/lCCu2C1QkAyET0zEEoLxGilWonkyk1O7XVRCSkwUwhtCMElIrOE+L9JKwJsb6SZP5Sobu2zhE ZygNdAR2crMmWwG3KSYJ1ASlFlGKzPguTmSuqyzFTj5LlWakq/yvylinu9P0kk0/BaSzOkEmnVaa o5fnK+Oy4TqIUlEuXSTJ0lKShJOipiVQfh0SSWjVaBXJ9UzXWXENJAaY+as4IykaC2Rp1/RxWdgF ZofUdGR8lyT7S7kq70ifWDiYaOValgkRrJYJPWNE+SwuvXOBFLPonUu/9Fra9TdoOPFYPXC9pb+4 f+qUWCoyofMkuKRGiTSQkXd0mkkwFo9GN2sHNOOSyzurVvWBXYGBshYlgDY/eCr+o4mZ1VX2IyNr 7p6IdaHq+nt9sxKenqr7MkVNbLQSsGsWWv01cSrofX0+SDvyCP7Nf/GJ8eXiDaDJuM6wfWNbwA0E hPR1h77tpHsnssAuJ17nlHx2OJlpggJssEaJSJPZVWb2z2TuVTpznGhu7lW3LNIqVL3j8zcbXbxB lV3N9uitdQLxafU57f1VVY+FsQ+UMUt2DQtevILWAbtewVE1cOCYvnlCY41B06c5+oJjSAhY+fYx x3ukQqgdCiQmDFHsm3RozLffJkkIWNm2AuBdoQVXe72Ad0ASiMUeyOJuU51lW6Xcqxh9Rex/vdLf BZgEmE4cGzPPZGWGJGyuJ6xmZWSG7tTwrQK47GuDXS7sNFt9Mz/VGyw++dFQy4DHUMgLrKLk4Mpn KqFzz3V8uyuz02nTlZv2uzu4q/1iqbd09uFkd4WvhhEwDFIp6su0WMhx+kF6BYwBu5o7LzdjZe0c +4L0m1u1oDTpCsCIGywuLl3lldjyYIGi51vU7zWRu1nn91b+Zt9KwP1bGq5Kwgn28KrCAlKXEP0m S6Dp19Ytbaxzz7OHLpmPDwHDg6hcIu2xo9JkcbQq/NY4xAMV0TbYTFOolUQvc/qeY7DY17RMmCqL Ot7nxHtjlG680Gie4Oi5laOHDGcLPzMcpUXq8LqQyRqIMxCvkrkumP25DOYnVdYVBmxiEqHypBto HqdYL2nlij+1KtgeToTCw+puByHbRB7qu5/tDfmrEeXiQCtMnph1Kku2A6qQzaiJ3aLlpHPZOLAA WxMonlR3VxvWfaGHSRql6g8VyjbCCCCQVL7S6Ns95TTyvinjep3BR3LnG5ljSYPZF+3vA54CYeXk E8TuyoErLxuo73Bru61CVFKBidUg2jcgPR3ID0YpatgVXIdordvkqN6uYt2OTTcoEqTlFW2NZIJJ JKdTC+itJizcMexaTBpKgluyDZsDUJ+FBpUiU4Jdro9Rrrc88WD/AKlEvsBOvcf9JHxKPs+MGnUj 3/5yzcl/YdjKkCxrvBB+KE4aojpPuKg48RzKSkzHbKgB31U29p8ErWxDfJPHdJTndTfL48NFl38K /lnc8/FULuEilzDyrVAVU8qzSisLerVkKtWrAQKglaiMcByhAqbBuMJhXMk6ZJMK5UpJJkFLlRTk qKClJFNKYlKlLymTSmQUylJRlPKSl5STSkgpdEYUFGaU6O6C6FC0KlnULQrKsxYy2WqRUGlSUiFi oFTKiUEsCoORChuSU0rlnWlaNyzrk0r4tUlNKTlFQSZWW5LcoappQUk3J5lDlSlBTKVIFQBTgygl ICkogpJKf//Sq+o6sxoY8FEvNmsqOwtMhSBDeQnKStNg9hPtPCjaHVnVwM+Ck91gZssBh2rHIQoP bVJTMvEANEO8VEMMBxhRcC0hrvwTsYXGBykpLuABcB8kaq294L6mtLY+gef7CrC4zJbHkih21+9k CdQihendq94JDuzfageo0jaGwZ9p/ORsm9979xaGeO389PXUy0GXAP7SEEoi4OAaW+7s5M97Do0m fzpTvD2Ru7dk1twuIO0NI/d/OSUwAI+SvV2vo2+kfc7QzwqQ480RjanMkPIeOySG0XW0udXa0e7y /wCoQLLXt0s/nG+H7qetxmCZ8SVFjhW8kEafve4JKYvdMEn2nWPBEDmaHlqEdTpBnw7KTQ5hMjT8 7ySU2BOx1mOdrDo6tw3qo1waI269iEVtgoMt58PzVCy51ri5zQ2f3R7UlMmO2mCA7WZVr7GHA3UH 2z7md63Kr6jGnXUEfm/muQZdPOqKm5a5r2wWkWj/ADXqUGtosuZEfR09rkBr3tcHtd7u5T3B7xLn Og9j9BIqU+71Xb2sDPJv0UX7O4OLXw3TcD+agta5g+IT1gAQQZn6Xkkpb7SSAbGztG1rm/8AoxRL nWENgALQbuqBrDCC4aGJa5UbAWADieySlS6lxa6JCcveRvJGp7fS/rpg1pbqfd/BS9Ju4Cp0hw4d p7klIju8JlSDoIdzHIRXmzFIDuSNCh2P01EPmd6WyElt7bXlzSdkfRdyEF4a1wLNAQogh0Tp5qVt RbwQ4ESC1BLbbkvextIt2j84OHt/7cQWtfW4lj/LT6LkI2NMbWxA1/O3KbzWWzW3adNyKmRLXPIu EGNu5v8A58U2eqxkVgFvG4ofqyyGMgx7p/8ARaLh3sb7Ht3Nd+akhi9xexrn2F5Etb/wZ/8ASaC2 ov0PhMqdj9HNja6eEqbhRq0An+UkpLRjWPO6kHc0bp/faoCw2e0P2yotyHmA76LeGpjc0tcyBJ11 +kkpkGAOLJ22iId+YoxJLne4zrH7ydtDa2Cyw+2YI/OUrjRvacTc2PH89ySlVuspBurjTQt/PVcE u+iTr2n6X/W1N7rHu9Q8jRGnEbo4WB8TEfnf+k0FIA11gg8t+i0J+GkuEOHtLSjtZ6xP2bQ/ml/0 1Xtda9zhcZcD7yklQYywiXbT3R5JeGmWDRnO7d/wjEEbBoAHAj/NTtfY5oFgL3A+x37iKlensJa4 QWkhTB0num27WODjqD9FOydqqZ9mSLm50F0kDd2JVQZDvBXMqoXWtaeANVTtbs82/mu8UcWwQd2T ajBf2QyxS3lvCQJKnWoi1QAVhzUJBC7UYBCaijhJKOwaKGPo5EsGiHR9NNnsUjd12nhWKzJVdghW axCy5s4bIUlEKSrrkOSYrcfJcm08wusyf5tx8lyXir/KbFhnu9P0bSlaay+j/wA1qtRU83zlfHZd SUQnUK5dOmToqUkkkgpYrjupPa+9xaI193xXYFch1F7X3uLREHX4q9ynzMc9mkVq4YNbKnN/PdDl mtEnVaePY5hpa0aEk/2VoZD6Sxjd6ULC66LNzQP5s/8AVLdCw+vb27Y+gf8AqlmYP5xlOzhObtMF PTZ6TpiU7fcQErCCYHZavgxJf5wT3QYV/ExjlD26Ryr7eivtcHE8cqPjiDwppzmE4le8/wA476H/ AKUVVkDU6uK27Ojvvdvc7Xho/kpx0KRq/VNOeHdXCXA7qyywNZA+kttvQ6o1JlGHR6CAI47qOXMQ Oi4RS9Nc51DSRCuFNVSK2hreApOWcTcrXvH9Sc82kWcjj+qqSu9Q9T1SLORwqgAWzj+UMJ3TtsaY DhoPBOwB7trVGvYPpcFXMLBN8uGgQkRHVI1abgZUXaLeZ0iDJKQ6K0mS5Re/BPC4bQSE2rV0DOjM Z3THo1fil78VcLz2oSWpf0exgJGo8FngQfdypozEtlpDAK7h5DKXbnCSqbzrok1qU48QoqBp7Kqw WNDhwVMrP6Vv9KXmZ4haBWPKNSpmea6w8jI8oWa8Ajd960us/wA+Pgsqww2Fq4fkDFLd2ugdLfkX tyHD9E3v+8uqyH7ASoYNYGJW1ug2qje82ONbTqFPI8IWDUtW+BS9z/okFci7w7Lt2MZbWaH6EiAu QzKnU2Gp4gt0/rKHGN5D9NeWvyR4Lt8Ug1MI42hcU5paAfFdnhEGisj90KtzewXQbSiVJRKzWVye tgHHJPY6Llhzrwuq61BxjPjouVWtyvyMM2905/p5De8ldWuSwS71mOAmCutKg5r5gujs8p1V4feY EEaFVXNgBXeqPBuIiCDHxVJx9sK7j+UMZ3WdwISYJKYS7Qao32exupaU8kDdSIiDokYJ0RfTd4IW 0gpWCpUxood4U3tIMqTWSRHdJTFoggzC28XJFg29wFiXNgwrmG41WAHhyhzQ4o3+6mJouu5BejEo L1QiytWwKla2VdsVO0wrmJZJovEKCk4yVFW2NSSSSSnVxB7AtBqoYohoWi2s7N/aYUB3ZRsyaVJ7 oE+Ci1RsBcDCeEF6d9xNTXTo5kLKtfJ1VjHt9TEYT+boqr+U9asBvadeEqfc4Jm8OHiFHDdAJPZJ Lbnc+e0qTzDfvKDWY1UyC4QEkOPZyVUtKu3iHEKjYguc13KsVKu76SsVJzGW9WVZCq1K20TCRUGS mFEKYUZXrymlJIpqlEppSSQSqUySZJSiU0pFMghSZJJBSydMkgpkmSTJKXRWFCRGFPioujjrQrWf jrRrU8WMp2qag1SUi1YqJTlRKC4LEobiplQckpqXLPuC0LgqNoTJMkWm4KMIjgowoJMrDam2qaaE 1THaltU4TwkpHCeFOExRUoJJJIKf/9OoHGp0EeakWmwF4Ikdkz2lujuRpKhAHEynKXc9zgAXEx4/ RTQ48lJoM8aqTLnVulrfkUVLABupRDYAQ5g9w7p2AXuJAjvCiG7jFfyQUuby8yRyU9u17twbt8R+ 9/LQ4dMRqpFtt543Hj2pKTBgeyNwAnunysaytoe0hzf3mn/0WqujDD+RyO4TsvfSd1f3nVK1Mwxr mEumexCTgdolo8nJm5DpJOu76Q8VO2pob6jXDaTqyfc1JTENLYeCNDwnc822bi0NceY+iUMB1pho k9oTQ7uIStTYJDHBhHpn8535qgZpduaWvU631OhuQTs8QovFO+KSYmAXjakheuz3bwAD4dkV9zbS HT6ZPte0fRLf30Bz3udAgR+6mtrfsAc3UnRySln7WuLWQQOCE7rXFgZ2UGDdzoQrMNrYXNeN37pS SsPSqr9+rjpAQQzSY0/FRLnSpteXEGIhJDdxGuO70YLiI96qtdY2WWO2gcN/Nck6wh4eCQ7xj2qF 7Xhxc6NddElKa/cTAjyRTkPbLH6ghCeG7Q9rvdwWpnXWvZtcZakpl6tjg0FxIA08k4taDLgXEqMN 7u0PcJy5riA0aAe6O6SkzsnFe0NbUQ8aO15Ua30tBbc0uY7/AD2/1FFx36MAIbw/6LnBSrqda2ao LgdWORUjrY3VpfDeQXKWwS33+0naWu/M/wDUKHuAB3SHA/RUnRbxqI4SUnhrGloMuBj2/nN/4JV3 WM2nbLXf9V/xiYEVmQdQjPyKdzbGsO7/AAm76L0FIGJ7CSRuPHCm94tsBraKweGqd1OzSwjd+bHu SUsDtYHhwIJ2ub+c1SDXWthkEAz/ACkAMa4+/tyQpMFgBsqPtbr8kVLemQ3c7QfxTO9veZUn2esS XnTkDsnHqAa/Rd7QUFJabGO2+qYaO/go5NlTnAM9zW/QcBt3NTY4pJLXu9M+Lhu1UaH2B4bWWkgk NP5sIqXcTc4PeQdOyZ7amuAqfvBE/B3+jQWtre47js8/5SesHlg1Hggps3VGoFz5bp+d3Va657wC 90wI1SFvLne/yd/6LSreGmYHwKSFQGjkglS3ANIMh3/RTvY5rt0Q06/yVFzg7VySVV/pHaET9ydj nB0j2g/mzuCAQXaBSx9ziXH6I+l/JSU2CI05KJX9E+SbFO58zIHdOzQk8yqufZfHdz8pxmBMx7YV RzzYwMOgBlXcl0PG3R8c/mqo9pe0g6EI49gorPLHEADgJP40UGyCCO6RftU61cyRKA5GD9EE8oIS sCK1CYjBJSOwaIVA96PYg1fTCZPYpG7rM4CsMMlVm8KxUsybYDaaiIbQiwogEoMrSt3wXI9112VP pujwXInkz4q7yuxYp7vSdGEVLVWT0b+aWsFSzfOV8dl1JRTqFcukkkkpdJJJFSxXIdTtFt5gQRou vK4/qdgsvdAiNFd5T5lk2vRWHva09yt4OofkChrXNfXAFn5rksLpmJXSzLusg/ShAs60+3J/VWjY T/aetKVcJthG70LmOrMO5WB18Olpn2fxW4LrLQDYsTrzXy0/4P8A78szFQy+n5WU7OFE8J2N3GEm cp3mHaLTY3e6HVta7z7Lba57foR8Vh9B4c4rcHCy8pIyMoSPh0GId38E21Ss1dpwmVeZ9S4LQnhJ PKballFynKg5EbqLx2e55ucH9joqit5wf6rt/MwqfC28fyhgluzC6HotZDC4/RPC55pXQ9Fa7aXH 6J4Ch5n5F0XZaE8JBSWTbKxhKFIpkrUjc1ct1DGNFhPYmQurcuc6rURZuJ9p/wCirnLSPEskHMaA RJTOcCdFKBCGR3C0t2N6Lo1bmVkkgh3ELVPCyui1ltZcTId2WqVkZfnLKHmuuSLwZ0hG6D0n7ZYL rh+ibwP30bPx6zd6t2o0DK/33LosYDGp9+jjqR+6tbAPQLYZns1ut9SbiUks54aAs7p1rra23OPv /OKwurZgzMgkfQbo1bvSHB+M2BEcqHmZEAFdANjqUVtdY3SBuCxOpxl4zMtvLfa9b+ZH2eXcAEOW GyG9JcIMEmP85HB1VJxHmV1/TjONWR4Ljl13Snh2MzaZAEKLmx6Qug6KiU4KiSsxlczrIBxnbvku VDSTAXU9Yc0UEO7nRc0RtMtWry2kWGabFtNdrQ3uQuuXHYgLrmkfvBdjOsqHmh6gmLy3VnTe4RBC z1pdWdNxEahZ5bGquYvkCw7t3pMfaACJBXSbB4LA6Q8C4CNT3XRgKlzMjxMkRogNLY4Cx78yptm0 NkDut4hcnnAC50eOqPL+o0VS0bjLceyAWxJV5uBWPcAsCl/vb31XWs4CkykwIooGrz3UsQ1Q9urV UN5cW+IW71Zk0mFzQMEFTY5ccdVshRemH0QfJQcnqeXVifBM9UTuy9Gpaqdw0V2xUruFZxbrJOe7 lMpO5UVcY1JJJJKdbG+gFv1tnCH9Zc/R/NhdJj64IPmoRuyOeFZxq5Bc76J9qrq3W8117ex1TgpJ XYG7mDg8KDjKFMGUVychi0wQoNZskeJTuRHajd5IoSM4R6tD8iqrDEBHaZJP9lJTmZbYcs21amWN SVmW8oLnMfyj1IDuYVikJzGW7SVbb2VSpWggVBIFNQCkCoyvDJMkmKClkk6ZBSxSSSSUsmKSSClJ k6ZBSyQSKQQUukkkkpSI1QU2p0VOjjq/WVnY50WhWrEWMtkFSUAVKU9CiolOmKSWJUHKai5JTUtV G1X7VQtTJMkWq7lRUnFQJUEmVdNCaU8pql4TpApwklYpoUkklMISU4SStT//1KZNzJYNI5CgxxHC I29rRLZ9Qd/zXKDn79TyipJvcIM8KJtcXF24ye6HqIPdFZYxxO/khFTN/our4cbe37qg0EkADU8I rM9zGekK2nwc76SG20EHfMngtStSa0VNBIltjT7qna7kAPcw72OIHYhT+0Bha57Nzh+cfzkzrQXu dW3Y0/mfS2oKSGiyxptc3e08vlBrtNPA18+EnBu0bS7+UPzEqw0mDPkkpTX6HTlMysWHXQ+adzmg 6AtI5/lKdl4eA0t47pKWFr2Nisx591CXPMuJLkmWEadkenHbaCfUaxw1G785JSIHZwiGqp2ofEjU O/Nch1sLyQOUne8a6EaFFTBvOmnwViXtcNtgdA3QfzXIYqduBdoOxTuqc8GwuAgwfFJSR7X2D1rI 17hAcZggaBRcPOU+rdCUlKBJOqLa4Q3aZ/eb+6oB5do7gKw+4uZFW07edPckhEHPawukFo/NQhU5 rd4HtlSrdtO7vzqpXtGj2kQ780H6CSmLbiwywQeFKtxAhvfxTMq3tLi4At7H85QBngIJZvse2WaQ ef3UmF7P0lbg0hCnwGimPT2ztJeihkyyxsuaR7udELaD4/JEY7anO1oa4SHTqPzUkoh49lKNeYRL 437i0sDhIan9I6ah0iYSQhjxUi+dCmDgToJHgk8t3EBu3+S5BS5G75KB9pkg+RTjT4IzcizYaiR6 Z4kbtqKkYuJ0CaNIEgJnOJAKkLSG7T9FJTAmEX1CANdJUXOLxryOEixwYXx7QYd5IKZPc5zpOvn+ 8kNm4gGPCUza3RPZD8wIRUzcGlxcRDf3QltcDNchvYqBO9TORa5vpu0Y0zCClnNgCfFOCGmY4RXG aw8a2k8Hjaq0R2jxSUydduGnA4Tt0G4dlE1yPJJ2ogcJKWtcXat5KHW59Z3a6ojnNHeCq9O6yyDw iFOkx4NMMEJVaMIHgp3sNUNOkjQKDHCDKrZ9l8d2hntG1uhLoVVlziC2NFo2GXtH50aFQyq9/wCk b7R+enQHpCDu0S/cADwoOBKLAYNUznkhSIRnQIU6ozhKDGqSEzNEVphCaiAwkpTkOpvuRinqYJTJ 7JG7dYNEeoaoTRojUrMm2A22qcobSpyorShvEsPwXInkz4rsLxLCB4Lj3SHH4q5yvVinu9D0U/oy tgLA6JZoWLd3KrnHrK6OzNPKHuCW9QUvSSkhmwDkqJvYDtkSiIqtPKSq/batTumOVOnJZcJrMhO4 DSLTFcln7r8ktDYdO0fyl1vK5+6LcyX+3ZLv6ys8p8y2WzQzRsa3HHDdXf11DD3Nsbs5lAfYbHue eXGVYwt5tbs5laE/lLEHr2jRY3Xmv2tcP5vv/WW0FQ6vWX47iO2pWXiNTDKdnlmxMKdwH3IcGYCl EnVazE2un5rsV/8AJPIXVVXMsEtMhcW4aq3g3ur3bTyOFWzYRL1BcC9eTCfcuetz7KgGu5LZQBn2 Or2hx3cKpLBK19vT70+5cr9ssfWWOcQUJuZe+GbvJEcsVcT2AMpnKn0573VAvM9grhPiq5HDKlzx +f6jbC2zxMKnK0Oo0WesS7gn2rPLY0WzirhDDLddupXR9FY4NJJ9v5q5xmi6LojX7S5x9vYKHmfl TF2wnUQpLJLKpJJJIKYuXOdXqizcTIPZdE9c/wBWp/Sbp0Pb91WuX+ZbJyHCNZUOCnJgpg6FqsT0 XRWQwvmZ7LaaAPc7hY/QaPYbXH2lar3l3wCzMgqdlkCDFxftOaciz6NY/Rt/lIH1jzTXX6YMPcYC 2MasMpnu7VcX1jI+0ZZ/dZ7QtOGkAw7yczbGi6vpDw/GbpEaLmLfcdO66bonvoDByCq3Mi4hki6d 7QMeD+dKwepM2dObGg3cLoMtwc4Mb9FoWJ9YGGvFa3tulHAfUY/uxVJ5rtK0ekZ/2Z5a/wCg5Zx4 hMDBU04iYorQae4FreJCZ1gHcLjq7nB8yfNM65xBlxlUvumu6/idDq2UMghrfojVZUqZeXNA8FEa BXIR4BSwm2zhOi5gb3K61cx0ehtt0u/N1C6dUuZI4qZI7PM9ZM3ERwqAdIgrS6ySbYI+Cy+BormL 5Aslu6PSHht8ETK6QaLm+kODLQeSdIXSKjzI9a+Gyx1XKZ8es6PFdWVyme3bc4+afyu5VNBjg+o2 BOq65o01XI0uh4PmutafaPgpOZ3BRBp9R1qd8FzHBXT5+tTvguY7p3LfKUT3eix5NbSeYSemxSTU 2fBSeqp+Ysg2atipXcK7YqV3dWcW6yTQdyoqThqoq4xqSCSSSnWx/oBdH08zhEdwVzeNrWFu9Md+ je3tChG7J2RQOEe5pZDT4KNYBsaHfRnVLII9Q7NR2TghYSR5lE3khQZr8VJ9ZrO13xTlMSpVy4be wUJT1ktJA7ooZMOuqsM+j+KqvIB04R2kwAkpqZTSQsq5bWQwlqxb0Eua46o9OqA7lGpTlhb1RKtt 4VSr8itjVAqCRuqkFEaKUphXhSSUymTVKTFOmQUpMkkgpZJJJBKxSSSSQskkkmpXTpgkkhdTaUMo jU6O6G7QtCtZ9Cv1qzFYW00qSg1ST0KTEpEppSSpRKcqJKCmtcqFyv2rPuQkvi1HqEqbuUNQSZlJ 5TJBNUyBUwhtMqaCmSSSYoJXCSaUklP/1aAIDSwiddCltLIJUBop2bdoIMnuEkpXWBsGFF7m2vBa 3aD2KH2B5U2vAduA+RRQkEN9pgjxT2moRsOvghttaSZaIP8A0UvVYBBbu8HfnJKTudSGggO39wfo OCA6sRuDv7Kc5B2Bm0f1vzlHdOiSk/2OxtfqyAPA8oJMtBbyFL0pG7dqOAoSD2SUy3PaQ92vxRHM Lm7pA/koe90bT9FSaK9pDmkuH0XT9FJTAN5MgwoENf2U2NDzDjtB7pH2yAQfNJSmyDHCnaLAR6jY I7ppmI5SLtw1JkfckpHJ5khEroNx9vISkaqLXbRMwfBJSc1ippD2FxP0HtOm5QLm2MDNsPHL1I2N DNoO7v8A2kJhGoImUVKLSwwdEmkF0kQPJLkgPnTRLTUDgIKWc4HSNE0RqE8HbP5sp2jWAkpZwgTG nimBI4RX3e30jI8R/KQ4I80kKD45GqiQRrCmX7hsLRPId+cp49bXO2l4bpy5JKNsHUqbg10hp0A/ OQi3VPXzE8IoZvc60AHlunyUJ29tfJTLbdpt2ksHLgoF7SJMg9kEsmHWRp3RXXXZRDSAXeKryTop F4LIcI2/nj6SSGL2OaddAnnWeUwBPGqQdCSlE8R2U/c4BoOkqEp5MaHRJS5a5pg6EJxc8SOx5TcK bwdrSQNv737ySkRcZ5+Sdp26pi1zfdGnikfEpKXlO8vPKGNdSdFIF7vo+5JS+g76pTJhSDa/TO4n 1J9qjBB4+KSmTZOnZM9oICcgN7pQNm6dZ4SUjcQ1QYyWmwEDafo/+QRRUXTsifNDoawPkOAPgiFJ r3uIDySfik0+2Sp57HhvtIdB9236KDQdJKr5RYXhnYx0hzSNBMfnKm7LfeTJ9s/QVyxzfUDtkkCG ws9zi+0u27ddUYfKEHdDa7sFJhJU7KASXAobTCkCFyNEFw1RS6EI8pKSNRGmENoKKEkM0SvQoYRW Jk9khtNKNWgNRqzqsybYDbCeVFqkq5SwtG5pHkuRsEPcD2K7EiRC5PNbtucO8q7yh1IY59GVFxq1 aYKvN6tZDfHusk66J5IVqWKMtSsBdJ/U7oImDOigeoWFwcToREKi8kgSlKAwx7JttnJsj0ifNDfa /cHTMaIcEie6fmCeyIhEdFWz3mqS0zvGqtdGtcy6B9Eqhc3bBnlaHR5ZaCNQ7nyTcgHAVA6vTDlc r1TIsN5a4Rt+j/KC6po1hcr1d1j8hzHj6P0f6qq8qPUuls1PT3jcO3KL0+PWAJIP5pCBXYWI+JU9 9jTXyTor8tIm1gewZMap3tDgQeCmYIAHdThYpNFmeZ6h0z7MTbX9CeP3VmOcRC7WysPEESud6n05 9cPr1bP0f3VoYM/FpJYYuY54fAhODtUQw+CO0sId6sxHtj95XLGyymzngvdW7xYFUB2GFaznTXRY 3ktIj4Ki9xdqeUiNVJTO3d4qDGbipeq417IEAyCojcNYKbYVq9P0ou9H3HvotBZ/R2uFA3d+FokL JyfOWUPK9TrsbaXu+iT7VQ3LX6tXe0kETWeIWYaHkfRMeK0sUhwhjkEQK6DojXBpcfo9gsR2LawB xaYK3ujY9lbSXzB4CZzEgYJiHYCkohSWUyKSSKSSmLtVz3V6v0u+edF0JWF1fEse/wBRmrT+b4Kz y5qWq0uE4d1Omo3vDB35PkrD8G4NDtpgotOPdjUus2nc72NWqJRPVioutgOa8nYfY3QBaUboA7rJ 6NhOx2Fz+Xdl0GGzUvdwOFnSHuZdGTYL5VoopJ7NC88Lt+55+kTK6z6xWudX6VQJLjB8mrmn4FzY 9p1WiZAaWxgIqg61wDBL/wA0Lrunt+yU7HR6vgPzVj9Lx78dtz2t/SgDZPaVo9Ore2v9Lq+dXKvn mIxsfN+iuiC3A1Qz6m5H6N+rYRhoQnyIdYdvCqY5EQlL9JeRq8NmYzsWw1u+XwVcarruodPGWyOH j6Llz+R0q6gTEjyV3FmEhr86wxaQSRPSePzT9yRpeOWlT8QW0x5aoco1dL7CGNB1WxjdFDHh1hkf uqOeWMBqkRtL0bFNTDY7l3HwWsUmtgQnKysk+OXEygU811p7vV2Ee3kFZa1uuB4sE/QjQrIIWph+ QMUt2/0l+28ac6LpwPFct0pxbkNgTK6nhU+a+ZfDZRXKdRj13R4rqiuX6oP058U7lTqqbVqJa8Ec yusZq0E9wuSrJDhHMrq6z7R8E7muiINfPH6J3wXLd11WYJqcPJcs4QU/lflKJ7vQYn8034KT9FHD BFTZRHqvL5iyDZq2eSo3q9YqN6sYt1kmg4yVFSdyoq4xqSSSSU6uN9ALX6c6HEeKx8X6AWjQdpBU PVl6NmzQwohSsOqgnIT1HXVNbkerYZQw6OFezcFtO2xnBGv9ZOCC1RqozBTwouRUu4Hc1virAE/J AY4vtk9morTrokhlkaVF3fhYF3dbmc6KgPErCuOhSS5zuUepAPKPUixlu1K2FUpVppSKQllOFEJw oyuZJk6SalUpk6aEFLJJQlCCVkykmQUsknSQUsUydMgVLp0gkkhSk1RU2pw3U3cdaFaz8daNasxY 5J2hOQk1TUiEaZTIUSEEsVEqRUSgprWqjaFfsVK0Jsl8Wk8IZCM8KBaoJMwRwkpkJoTbUspAqMQn SUylOop0lKSSlJBL/9ai5oBUI2lKRzwUtSklkAJ1TD8E4aRCYjVJC+4EcQU7GlxgcqJBiUpSSvsJ OohO4Bo7yEQO9upj+Skch7RtAG3xhFSPdH0eU4MhMI78eISAEweEkM20ucCW6x2RBS99fqAgActd ygvBYdZhJoDzJ5SUqC4aJxtYSHjXwUZ7TBTQO3KCkgs9u1wEHuokEfDsUjMc/JPvc+ATICKmOsiO VNoa+dxg9kjX+dOiZzQG7pB8vzklLAngqbZYdRz4qEynduIExHZJSxGsphHBTlpbAPdIkOiJnukp I5jgPZq09v5SiJ+CTTt1BgqVlrrXS+NyKGb37hBaBGkqEtDYiSUxMCFEaHVBK7rXW1hlg+j9Ej6Q UNoPxCk7Y0naTB8UiwAxz8EkKa6dHIuS8HYA1rY/Oafc7/jUF23SNExDOW890lMja+Czcdp5YPop gBwkWlokpw4ngSUlMnNe1oge3kHzU/tdrHFwLfc2HaKDpjcXSXctUHbCQWk8e6f3klLB20aaJM2f nT8k4gap7CCQRA07JKUGEiWg6aqAUmWvqMsMToVGJSUuO6kbHPAZJ2t+iP3VCFIDskpRD2iJlvgm IkyU5HmlqUlLJ2kfRURpqVIGdCElMmw0+46qO8uMqJ17JxzASUrgT3KXxRH1WVOh/J1CG8GeNUkM SY45KYV6EuhpB9yfceeAhuraW7hO4oqbTzEMb9GEzBA0TVlrmDcYI0hODPeFXzbMgWtDpA/NOmn5 jlXyXSSJHt0n95FyA42Njtzqq1tAutBB5ElOx6xCDu1w9wMwi6ESe6lkBu4AGQByENzgQYUi1GSJ UCpQoRqglK1EaoNCIElMx4IlYUAiV8pktlBsAItQ8UOUSrlZk+rYDbapJgnCrlcvCwusYxBFrfmt /RDsrDxB4UmKftytZIWHjwmK6G3pNb3SNAofsVh5K0BzEGPhLhE6BSMAyFvDo1XcorOk0jsh94gr hLz5dIAjWU7muc4bQumZ0+lv5qsNpaOAFEeZHQLuF5E41r9Q06LZ6PiPq/SOHK1wwBTa1MnzBmOF QjTIEDnlY2b06zLuL3GG/mrX2yZTwoRl4T6V1PNt6FaZlwVzG6P6RDi73ArY2p4RlzE5CkCNKAUk k6rFetCi5oKmknA0hrOxq3TLRqqz+lY7hG1aSaE8ZZd1U57ul0mtlZE7ZhN+yqONq0iEoT5ZpXug BqMw62jbtEKYxq+No0VhPCjOSXdNMGsDdApwknhMu9VI3MB51CiKmjQBGhNCcJFSL0xwQphsKUJI GRKqUnSTJql0kkklLKJapJIgqR7FK2uCG+CIwSVEncZ8VNxER/vorViG+CuvHp1gcQoYte47zwEH OsLjsCt4B7cDkkslqaagG8l57omxSaIClCpymSbX0jaCwy1G2BwlnzaoQkAQZGhRE7HDL5VUsnsA DjHdTsh0PGk8qNn01Jw8MJK6sCFEsREyrAkLkJrCiax4BWIUSn8Z7opA2lo4ARA1ShKEDIlVLJiF IqJTUoL8dl7drxIVR3S6CQdsQtKFEhSwySGgK0ho4+BXQ8vaNSrkJ4STZSMjZSBTErOzMBt7t3B7 rRKYiU6EzE2FEW4DukODpaRAK2GiAAiQown5MhnugCkGS0urcBzC5i3He06hdW4ILqwVJhy8GiJR trYlZZUAVJ8FG2wEF6F2bS1rFSuV2xU7tVZxbrS5zhqmUn8qCtsSkkkkVOphfRWg3lUMP6IV9iry 3ZRs2SdAmTSSknhCShp9Rp8DJWxmH9F6Z4+kFnYDCX7vzT7VZyLJInw2p4Q0JUHKbuVEoqS0DRzv kmBhO0wyPFQCSGOe7Ro8lkXDQrQzHS6PALPvGiSXNdyj08oLuUanlFYW/UrAVetWG8JFQSgwnCiN FIaKMrkjzJlRTJ01KkkuU6alZMpJkLUtEpJJQgVLEJJ0kFMSEoTwmKBUpOkE8JKWU2hRUmpw3Q3c fhaFazscrRqVmGyyTZaFOFBpRFKFjEqBRChlBLAqBUyolJKCxU7ArliqWJkl8Wo4KEKb1BQFmCxC jCmmTVMIShShIJKWhKFJJJLFJShJBT//18x3OicDsOU4HijlorbuBaZ9sfnJJQ8Jncyptrc8Egp6 tn58x5JKRFSgct0UizuDKRBbpI1SUyaWAQ6SeyavbPv4UdjgN0GPFTazdoNUVLOdsG1plp5Sb4FE spgSOR9IeCG9myAIKCmVlrrBtcZA4UQCRoon7lIbhwUkKeIMOGvipOO2C4SPJTpDoI27h3JUGEN7 8cSipi5zXGWCG+CmHbBMJ2uG7c3Qprq3j3ke0pKRugnTRL0xyOVNoG3dz5JhuGvCSlAQmB7pnPJT uLHQW/S7pKXhwPuB8dUiRMk6HwUvUdPuM6QovDZ01CSlgY5RN7IEiP5SgyInuE4sBdxHkkpk72n2 HcEI+4z4qbnbXSwRHb6SYS5248ykpQEe3xTQRoDr4p9rpJHZOBuKSmGvfUomwFm6QIMR3TXOLYYR qO6jW/YQ4AEjxSUkYGN1fJaeISNjqSHMcJ/6Sfd67i5wgcnahFupjgIoVMmYgnlSawGdQISIG0EH 3dwVF4cNTrKCl4Mb9vtH0koaQXTA7BJtrmAgagiIQw37vBJLM1h2rPDWVFpHBCQIKkQImdUkMdOV IDudFKtrSYc/YPFTsyHv+kQdujdo5RUg0BJ1EqRLfzZTObqHPOh+imLyJjkoKZGAPNQYQNTqiNqd YPZE9wUMe7nhJTKRyEtSU8zpGgTlhbBPce0pKYOD90GQPNJxsaQRrP5yJZe+wBhOjUB8jSUlKslx AOpJTWXO3bR7mjROSR9A6hErxza31HkbphyKlw7exoiI7qdYnsmI2tEeYRaQY1VfN8q+O7TzLjXb AAMj85Kqx9bS9+v+1PmhjXbnan80IVVjmgkCexSxfKFHdhq7R3JTmuApguefgom3boeVMsQlsFCd yil8oR5QUkaERoUGojUEsgisQ1NpQlsobtgBFr5Q2mUSs6rLn1bAbYUwoBTCrlcuE8JgpBNQoBPC cJ0lLQnhJOlalJ4STwgpaFKICZOT2T47EoKydJJMSukmSSUukE0pwUlLpJpTpKXSTJ0gpblOmSlL dS6SaU8pIUnUZCW5GlMklHcm3I0pkko7ktyFKZplHcn3JKZJlGUpR4VMklHcnbqYSESdFWkBDWEn k8IaT3hxgcDhSoG+wDsp+HilGA/RW3WrbdZ9nrgLNaS8lzuSrGdbJ2+Krgwp+ZNVAbRWx7pE6huS 3KjTIzSUNwRKWh8k/RHJRjEk0q13e2oTySmuEP8AioXW+qdPoj6Kle4ODXeKtnWEoj9Bb1WTKO5P KpkLl1Ep5USUErpkpSRUpMUxKSSlJinTJKWTSnKYoqYpJymRUxKgVMqDgipgUMohUCiFMSdFWeju QHqUIa1ipXq7YqdytYt1hc9/Kip2DVQVxiWSTpkVOpi/RWixZ+IPaFoMVeW7KNkgTlME51lOCi6u BLKXA+O4Kve+SUeqz9Xae/CpvKkGy1iTKjzH3JEkajspVAF2vxSUysjQBNwndq4lM7QIqaNx3OKq XahW3qpaglzXco1SC7lGqTmNvVKy1VqyrLUCoMwpBRAhShMK5kE6ZPCYlSSUJIJUkkkmqUmTpkFK TpkklKKZOmTVKThMpIqUnCZOERupt45WhUVm0mFo1lWobMZbbCpgoTVNSLWRKgSnUSkliVAqRUSg pDYqlit2KnamyXxaryhqbyh7lBJmXSTSlKaldMmlKUlLpwoynBQUySUUkFP/0KDiwcTKgnJk6hTZ t/OSXMedCiOrDQC0gnwTWVtHurMjuP3UzAO5hJC5sc+DAEDsoBEYSDLdSoOmTIgnwSUl9ezaWgwz vCVd3pfREocGPJRgjlJTJz3O1eSXHkpgISiU7GOcYGp8ElMmEcHhOS1w0+RQ5njRO4HukhJL6gCd QUOS8ye/YJtvfVSa4Rx80lL7SNIhO7a/iRHMqIOukqbnumQEVMILTpqndI5UmguMN5PZM9zY8SEl Mdpjd2Th1eyIO/8AeTBwJJTTpED4oKUGjn708Qfb9FJs9kT0nuB2iQNUVI9wBUnEPO4iAh7gfo/i k2DykpIAYkJgQD4phPHZEqDuwlJSSxtV2z0gWPGjtfY9CDZO0iCDqnsrJcSRE6pBmhJMH/qkUJrq 21NBDgZH9ZVtvmpBm3Ud1NjMctO8uFn5u0JKRkhokGJTv2CHBwJ/OYobweBok4tgbYnukpiXDmNE /byTtt9PUAH4ojvTt3PI2fBBSOWzwVM1bI9QQSJalW7TUCO6ndkMs0brA2s3DX/1WipFY1rHQxwc D3T1tBdDxPwSNgiIAKltpDQZdv8Azx22/wDBpKUaw5zgxp2c68pvax8sM+KnZaxmmMXAEe7cgbYa gpd7mNO1nu7z+6pWF1wa50bWmI4cmY9m0tc2dZ3BQAkoqZvpcwztOo3e33e1MWNLdxMdtFKu+2on Y6NI/soTmkQQNEFJXOJhtf0QNZTGt4BcRI8UOUt7n6cAcFJS7XdnBM6BoU7WQZiQim4Ma6Q1xd+9 +b/xaSmuARxyVNrHVjXmVE1OIBnlFxrXs3VNa18iff8ASRUkYQJgqWNJ1QAyJ3AtnXRWcVsAqtn+ VfHdrdRrDwNQHDUTysx9hA07q9n1F1m46tA1/eVe/bADZLR5fRRx/KFFaiw7dVMgEJmhsy3unLtF MsRubCFypufIQ26oKStRAoDhECCmSmzlQCIzlNlskJwICLUNUIlFqWZPq2A2wpgJmqSgISunCipB NUyCdME6Cl06ZJBS4Tpk4SUumTqI0CedIqXTlMEigFMH2tYYcYlBdm1B+zdqsvr9kbG6juCsaq1w dvHIVvHy/FHiWGVPVtz6XOLZ1GqizqVD5h3C5c2GSeCUIuPZSDlQjiezqyq7fou18FYBXDMtLSCO y6npmZ9pqk/SChzcuYCwkSt0kphMkVUXo7rm1NL3cBYtvWjvise3xR+t2PbTDRLT9Jc2HK/y+ASH EVhlT1OPnust2wNnktGVxdGQ6pwcNNQusxsht7A9qjzYeE/1VAtXPz34jxIlhVEdbdv/AJPgl1PC vstLmguYeFRHTbyN21TY8ePhF/Mgkt5vVrDYf3ZUG9VsbZuJls8eSovx7KBLwQq24lTxwwOyDIut +2LQ/dPt8EqurWepLjoVnVUvvkMElWR0vIAnbKEseMaFQJbtfVHm6ZOzwRcrPdTaHB3sI4UMPpT2 uDrOPBQyek2OeSzVp1UPDj4q6LmFPU37yXGWlRPUrmO3EktJ0CG7pV7dY0ULaLA0NeCAOFKIYydF tlK3qtgdun29wrOP1CxjTkWE7XHawLGD2iQVpX41lmPRTXyAXEKX24R1W2Sw/aFjH7tx2yug6Hvd W/JsP0z7R/JWCOlXvABgSQuryGjHobWzhohLHGA9Q/RVInZxOqZxrduZzMBZTOp2sfuJnyV3qeO0 hriViuAJIGqbGMZ3Ip2dHEz3B/udoUvt1lFpc5xLXaBCo6ZfdBYOVqM6cMWHWD1LAPawfRah7cL/ AKirYYYvLDZk2enWeN300HI605/6DH0qn6R+k5Nf03JzLBZc4EfufmsSf0J24bXDakZYhpFVHq7H qRTvmYbMqvkZjz09uSzkf3qfoBmP6PYNiUPpbGZPT7KAZjc1M5aMSZBUi5TOq2mtxLvd+aos61eI k8CCs5lb44OmhhMWkciFL7MNlcRetw81mS32/SAG4Kh1HqN2NbsbBaRLVn9KyPSuDTwVZ69XBZYO /tVcYRHJwn5JLuLR1Om5hy6y88gwVasftaXeAlYXQHkF4nT91aPULdlDzMGNFBPHWThHypB0c53X HBxge1bGLa62pr3clcY33GPErs8Wr0amsmYCk5jHGAFfMqJtOmKdMqa9ZMU6ZJSxTJymKKmJUCpl QKKmLkMojkMohTBzSdQgPVjeWgjxVd6lCGtYqtjJBKt28Kpa8gK1j3WFzbOVBTs5UFcYlJkkkVOt i/QC0GcLPxtGBadbJZKrndlCgov1EKQ8E7OZ7J0VFtUH9CAeQoPTB+sdk5UgWrATI8k2OZaSeyYG Ck0bZHiUlMxqnLS7hRaj0HV0+CKnMubDiFTt8FoZP01n290CpzX8o1KE/lFrCcsLerCshVqlZakV BIApKIUxooyuC/KSSXCauUlCSSapSSZOmqUmSSQUpJMkgpdMkkkpSdMnQUunCinCcN1NmlaNSz8d aNQVmDGWy1EhRYpqVaxKiVMoZSUxKiSpFQKC5FaqVgV2xU7UCmLSsCEUexBKgkzhZOmS4UalJ0kk kqSlJJFSgUkySCn/0c9sHlLUKxAvcXEgPcdd3tCEYaYI1HgklhE/3JwGnnnwRPVaTJGicvZukCWj /ORQxdGkCE0eCclrtWiE8l2scJKYHXnlOWxE8KTz6kaRHCf2zFhO1BKMjwSLnTOoKk55do3hM3fM DlJDADVTLSw6pFpb8QkBOpSSkquewl1fPgfcgn3GTyfBO0ckJhHf5JKZh0EBkhIzMKOsSna7adAi hl6ha6RoQpTLS48kqN1r7QGuaBHBHKg0Dx1SUuCkSJ0RXANhwPnCi54JLw2D+6ElIw4tRW3ucA1x gD91MQ0cEOBGo/dUdsEJKZFgaJcPmhGJRXMaXGDokxjXOg8JKRjVSbIOinf6AePs5dt/O3f98TtY HHTQeaIUubnO+mVCQfMBStqsYdWkA6tKG5h5SQzaWuMNkT4olLGNd7ztg6kIVlD2gbhAOoKTAY3C JGsFJSc0421zm3SR5e6UFrGkFzjDj5fSTEsgnQE67QoDQSBMJKZwW6mEQFlsNJFcD6X7yDZb6jt5 AGiJaKva6t0z9Jv7jklI2lpkGCOJSJ7eCRO6NBojX0vlpeQWuGm3/wBGpKQt0knVPptG5uvIcnL/ AEnwIO1SPq5QLy6S3VrPo7Wf8EgpBtM6okAACUnOZa0bJD+8/RKlY9sARFg8O6KmJbPuj5BP6cgu JHwStudaWlwDSBt9v5yRoGw2QdwI1/N1SUxeQ8j0wdOzk91L64Lo94lqUnbLT5JmisOAsJJKSlNZ BAfElSvxbMchj4EnRK4VgjaIBGmqixsGWjt8UlMSNntjVMTs1mf++p3l3JKmWtew2EhsGI7/AOYk pCBvMjgIl1rXWNtH0x7XR7f+uJm37d2znxKG57QwSIcT2+jtSQle4sDmt5lWceYkqHqsdWKywCDO 9v00ajv+CrZ/lZI7uf1F4Nm0NJcW8zogvsftADgZG1yuZbWG4OaJeRBCo3H9I7Y2GjTVHH8oUd2B ms6InIQQwu9w4U5hTLUVjCCk0QnsMpBBCQKQUQpBAqZqbFBTYhLZI3TAo9XKFCLVysufVsButClM qAOikB3UJKV1IKIUgo1MgnTBJBLJOmTpIUnTJ0QpSSdMjIqUkUkxQU8/9YX6tZ35WPjt32Nae5ha /wBYHNLmsI90SFlYYm5k6arXw6YmGW70bOl0jshZHR6nNOzR3ZXvtNYHIVbM6g2qouYZd2VSM58S 55V+jiPDRb31f2+/X3eH8lYbiXvJ7krpOi4hpr9R4hzlb5g/q9fmWx3dkJnJwh2v2NLjwFkgWWVw ep54sc6oatAj+0sZEySDYS3jlX+lYbbw5zxoNAtiFY4WxHVzWiXLpek+ysskHVYudhux7I/NOrSi 4T7KbWl30SdUzMPchYVHR6mJSLUmmeFNZlkFkcvqu1tB3jQrlfgut6q5raDuEhcnoCY4WnypuLHJ 3OhVe1z/ABPC3Q1YvQGQ1zvErdCp8wfWV8QraltUklWtcjLVl9a9uOT5ha5WZ1fTHdOoKmwyPEFp DyrieF12PWAWjuGNlc1gY4yL2td9Ee539ldDgXfaHOuHc7R/VatPmDWNjG7qY1e6z4ap8+3eRXGn KNhiNziqtp3WEqtfBh/2i7eThdchrGn86VndPxrMm3bWNO7vzWrc6h045gbJ2taZc7yWVldRZW37 PhiK/wA9/wCc9WOXHo1WyPZ6Gm1mPX6VMOcObAmA7lcziZJqdI+gkOqWsedpkT3UGTHORofKuFB6 lPC5mrqdo3bnc8K70zOsst9J2oOsqvLDKItcC6mQ0OY4HuFmfVp0PurafbyVqXAFhniFh9BcGZj6 wfpNKs8p1WT2b2BWG1mP3imzcZjqnaCYUPtdWE80P0g6IGX1ZuxwrEniU0ifuafvK6OLjs32MHck LqM7HGRS5nlosDp2O7IvHgDuJXUuE/BHPOpx/qpAePxLzjXNf+6YKv8AW8jeW1jw3LPzKvSuczwK G95fG4zGis8AkRNbdaOh0XGFthe4SG/9UumCyehU7Ki8/nFbAWfzErmf6rJEaKTFOmVZesmTpklL FMU5TIhTAqJUyolFSMqBRChlEKYOQHBHcgPUkUFrv1VK4K9YNJCo3aq3j3WFz7OVBEtGqGrjEskk kip1sb6AWzRHo/BY2N9ALWx3foyoOrKNmBGuimyRr2KiVLgAdkQpc6EKZKgpAp4QxKmfcJ8FEp2H snIXadFJhg/FDB1UxEJIa+RzKzrlo3CVnXIJc530kWooL+UalOCxvV+astVWsq0BqkVBKE4UVIKM rguPNOmTphSumSSQSskkkmqUkkkgpSSZJJSkoSSQUpOEycIKUnCZOE4KbWOtKtZdBgrSqKswY5N1 imhMKJKlWLFDKIShlJcwKiVJMUEobFUsVyxVLE0rotN6EQjuCGVBJmCOEoRIShRpRwlCJomISSjS UyE0IoRpIkJJWp//0qDK/WMEwpVUOe7Y2A7zS2m1xJIB8VEOkeaSWTmurJY8Q4HXwSLdJ4UnWODP TcBHO785M2wtO4cpKU3hIPMQFFzyUgkpI99bgA1pDu5P0VFpIOmqkLWgFpbJPf8AdUWu8UUJP0Tm 6A7u5/NQmtcRLdYUod+b9FNtLBLuySl/UtdLgfjomBClY1jWbmP9x/NQdSkpsV0b3bARr3Q7K3VE sdG4FM3c3WNEjW6N0e3xSUoO080wO1KPFIDsglIch7tXJA7/AKRgnuoljTBbM90nNgAng8IoZOa1 rtrhEfSRK7KmmNhcJVfjRTDjt8glak1zxa8tpr9P+Tyht27vf9H85M+9xIJ0I0CGZdyUlJXtbvIB AbHtKGAQUiYiAigtOiSl22sDCxzJJMh/7qZte/QOAPmn+0HRuu0dkNwDtYRUkmxmm7cEmB233fRJ /tKJaW8qBaTydfBJCV7bHtLWnc1uolDaHSA0SSkQWmDofBSa9sfyvJJTNuNLHHY4vHh+agC0sGh1 OkKfqOZoHO1HuUq7G1iTDh4FJSL0Tt36Rx/KUiyGgkaSndtcd1WhI9zVAWyNnMcIKXA2mHiSfolQ ZG7xRXO36kEgIjb6awCwE2A/RI9iKmAEN3CDGkfvIYl7paAJ7J32B53bQ3+S1Lf6ctc2J1hJSwGp YdDPZTvrdW+HncY5UGkHkT5qfqNYQQ0lo5SUxc17Y3DQ8KL7HERJj91PO524zt7D91RfyTz4IKZb 37dv5pRny9shsNHBjl38t6CGPc2W8hIFwr27yQTqxFTJkFhbA3TO7u1TaX06gmYjj95QY0ObIMQj MucG66j83RJTVc0D875KBrDhu8CiBu8kkkHlRG384xKClBjOzvceyHqCHEQRy0oocHkSQ3b9F0K4 4m1rTeQ+v/SVjViNKa4BAl2is0OG4wg3AWPIYZa36M6O2olERpyq2f5V8d0GY0b2ub7SD9NUbNz7 HB4JJ1lW8xlXqA2kj92P3lSfc91gJ7DRHH8oUd2AlnsOgRHHSAoCt+4ufwVN5+5TLUbmwkpTJUXH VBDIFTBUApBBTNEYVAKbAhLZITSjVIMI9YWXNsBuBSUGqSgXMgpBRCkExDJJIJ0kqThJJBC6dMkE RupkmTlMjLdSkxTpigFOB18iWAjXs5YjHEGe62/rARLB3WLSw2PDfFa+A/q9WGW6d1rgAQdVXseT ot+vozIBcZKa3ojHasJlNGWAKaLiYx2PDyJAXW4mQ25u5v3Lkr2GpxrMghavRH7XyTq7SEOYjxR4 lRejlZPW7zXWA3vytRc91XNrtPpjkKngjcguOzjiSY7rrcPHbRUGt+JXJt5BWvb1Kxm0NIAgK/ni ZUAxhsdax3PYLG8D6QWNRaazIOngr2Z1CxxLJG0jsszvojiieHhkkl7DByRkVh407K2sPoZ2tcJB B4C2wVm5Y8MyyBo9UcG0O3cFckTroF1vVHhtBLhIXJvGpjhXuV+UrJPQdCZ+jLvktsLD6CPa509+ FuNVPmPnK6LJOmTquuWKy+rmMd2kytQrM6wQ3HJPcqbD8wQXF6Q9rb3NPL2kNWl0WoV1ug6yRtWC x+x4eOQZXVdMxWut9Rv0bPctPNEyiAGIaOzHp0geOqp1Mkeo7hWsst4J0VN9hs8mjgKHPUQAf0F0 XN63YLKw0nbX3aO65hwE6cdl0fWQ0Vhx5nRc64jdIUmCRMUENijGttZ7QSEQdIyOYC2ul647dIV8 BQT5gxJASA83+xbyBwtHpvTn4jy9xmQtSAnUMs8pClwCK4SxwPELlen2elmsP8rb/ZXVXAFjg7iF xjXena1w/Nd/FWeU6rZ7On9YmbckO/easrUBdl1HFZeWOeJkaLE6h0xtdfqVdvpNVmWSInwrANGx 0QsDNgHuPuJWuRouY6Tkene1p+i5dQs7mARP+8yx2ef69jgbbhoT7SFk41XrWtr8Sug62yaJ8Csj pTA7JbPxVvFL9Vf7qwjV6imsVtDRoAipgnWYTZZQpMnTJqVkxTlMipiUk5UUlLFRKcqJTlMSVB3k puQyiFI3ITgjOQXKQIa1ipWq7YqdnKtY91hc+zlDRbRBQldDEpMkkip1cb6AWri8ELKxPohaWM7W FB1ZRskI4ClYNro5AUX6EpcohTNuqWoTN5UrXCQE8IKxTBIFRJ1RQycdYClMKBGoCkdUlMXN3Ssu /SVreoawT4iFj28nzSU57uUapBdyi1BOWFv1hWQqtSshIqCbhSQwpgqMrgunUU6YUr8JJkkEqSKS SapSZJJBSkkkkFKSSSQSpOmThJCk4TJwnDdSarlaVRWbVytCpWIMZbtZRUBiKFMtXKGVMqBSSxUS pKJQUisVSxW7FVsTSvi1XKBRHoagkzBQShOE6jXMEjopwmhJDApJyEySlJJJJKf/06ESNBIRqthb tLSX/mkIRDmwDoCp12Gs7mmHeKKVEmYGpHZR76iPJFstfaQ4n3+KgXOJ92p8UlK2BwjumYCREapA gHXVTDp40SQsQYLRE+aiAAptDHw1+kfnKIaC/aySOxKSlOe55hojyRGtdT7ntkA/RKc3bRsgBwP0 0FxJeZcSUlKfDnEtG0EztH5qmN7DBAghQL9h/eTtPqnXVJS4e4aTAUS7b7Tr8PopatJb27KYY0Mn v4JKU1gePc7aAOVFh2GeVMOIboQBCABpokpmASedT2RbbCYa4fR7fmoRgtjv4qAnsUlJdXk7QJ5h QDyE5r0BDpP7qf0XxMJKXbL9OZ4lKylzHbHjaUhY4fQ5UmtL59R0HskpHoNCCjUuAMdlKotBBgxw 4fSQn+wwOCihm8yTI3fBQra15Aedo8Qoh37ug8VNp26ETKSkjLGsBE68GVBx3j2kGO0aoQYYnkqe gh0jXt+ckpVrHOAeRA+jIRRiNtG0Pa10TqUnNIJspJ9M6e7ncofZ6tu7eA6f5spKYUhx9kjXx4Se 5rmhrWw4HV35rk7PS1FoJP5u1RDI45nhJSxYGECeVO50ewNiOT+8k5ziNr9Y+ilvcQIJJI/6KSlg XbQ0at5UyNxHqEMbxuCNi4+1htc8Vtj6R1k/6LYqpLAZa3t9H81JStzHTP8AZI/OTve50bzMCB/J amawghpEKbsZ7Hhr4E8FJSxeILSSf3SEfCz8ig7a2t17vCrOrLXGvkgwNvuSc41yx7SD3lJTK9j6 3S4zu1lv0EOza2I+MIjAy6yG7gyNB/KVh1zLh6LxLW/QP+Eb/I9RJTXrLi82Vt0Gu1yi4VGXgEH9 z91MCTJDojiVDdPJkn6RKSk1rmuALG7Q0e4/voQcW6tMO7JWBxZro3iUWrKdWw1yC0iDLd21JTXJ Me491Fol0DhJ53OlM37kFMw1upn4yiV37HbQ72/ut+iVGnJNG4ta12mu9Lp/vcGloLj/AJqchNey HhwOpRafBBurLLCfOIR6JVXP8rJHdqZ7Q52zkx7Vnh+yQ4arQzWOdc3aY01n6Kpthgc06ulHF8oV LdgbnEw8qW6QmubtIB5hSbXpAUyxGonlWCzaq7+dEFJApASoNUwkpmERiGEVqbLZITtCMzlCCJWN Vl5N2wG2FJQCmq65kNVIKIUkEMgnTBOgpdJIJJKXThMpNMBOiLKlkkkk0qUmKdIoKef+sJEMB5WT gn9OyfFa/wBYD9AR81iVODPd3HC18IvFTDLd7QaaJnEASdFzNfVrgIJQrc+26Nx0CrjlpWm1uoWi 65zx8ETpe71mhvKrhhudIHJXQ9OwRX+kIh3grGSQhDh/SUBrbouMAwuQyWlrydNSeFu9ZvdTU0MM OJ/6K5yNxUfLRocSpJceo2GGjVFsxLgfc06re6bhtqrB/OPJWhslCfM1LRQi8uOnWuA01Kr5FBoG 14hy7DYsXruI57Rc3Xb9JLFnMpUVGLkYtzqngiYkTC7FjtwBHBXE1vLCHBdZ07J+0VboghLmo/pJ it1NwbQS4SPBcmQJ04XWdUeK6C4iQuTPJLeE/ldkSeg6EyGF88n6K22rE6DTDXPOnaFuBU+Y+crw ySSSVdLErO6s4NoJIkLSKzertc7GcGiSVLiPrCC8mDrC7volZw8RrLvpakfyWuXP9D6RZdcLrhFb dYP5y6LMye4C27oWwHsxvdvcEuyFUDy7lGWPmnxStmAoOT1hrTWC7sVzzmND/KV0fWaC+nc2ZaVz RJKucufTutk79GeyqkOI0BhGPVKw0PEkFc96jtu0qG8xHbwQOAEpt6N/VqmtDhrKk/qtNZEkwe65 kOKXueJ7BD7vHuq3rPVZkVF7TLSCuQa0GxrexeB+K6rDqaMYNbqCFzVjRXc3aIhw5/rJ3L0DIIkL ezyfptb2AVXMYTS4N5hXcke8GIkIFoOx23mDChzGsqYjR4/DDfXYHmBK7LnVcXX/ADwL9Pd7vvXa DUBHmv0SmIcvrf8ARj8VjdI/pTJW71evdQdJgrD6Szfkt8tU/Ef1UkEavVgQnSCdZxZAsmKdMQiF LFMkklspZRTpikpYqBUyoFFTEoZRCoFOCkbggu0RnILypIoa9ipWq69UrQrWPdYWhadUJEs5Q1dD EsknTIqdXD1YPJaFeiz8Rp2A9itFugVeW7KNkr3SkmiQnTlLgwpWUO2i7sdEPhaAcG0GvsfcE8IL RCiVJMUUL16uJ8ApHlKrQEp0lI8kQ0LKt1WrlcQsu3hJTnkSVYqqcRMaKu4wVYpteNAdE5YW3Xyj Tt07lVwNx8EdlYDt3dIqCYBTUWqYUZXLpJJJhSulCZOglRTJ0yapSSSSClkkk6ClkkkkFKTpgnQU pOEkgnDdSarlaFSz6uVoVK1BjLaYiobERSrViolSKiUkrKJTpikpG9VLFbeFVsTSuDVeoQiPUFXk zhQTpk6jXKTJ5UZSQpRKclMUlLJJJJIf/9QTrPVOjt1Q+i1+n/barvgklv0VKsMOjhKIK9uhEopQ 6ASpyRqdWqTnMB8/BSa6NTx4JIRsgmWfcVJzTWS1w1Ke4+o6Ws2afRlDaCe6SmTA2JJ9w7J7LDoA AB/JTHYB9Ez8UzWsj6UeKSlOLXNgD3JnQ2NZ+CQAhOGgg7dISUyrs9M7gAfik+926Q0aoTYHmnBh JS/ufyQk7WJPCRGsnUeKdzquWAx5/vJKYv26SJcpBu8+ChpqUtSIPCSmdjIO1p3juQokkCDwi1NJ advPh5KEbDrqkpewOaA5oEdyOVF9rnQJMeCk4erGwQf+rQ9pHPKSmYra5h1h/wCahDcI8fFWWt9Q bQYKiR6ZLXjVJS9brZhvJTOZZQ79KIdz7lFriBMkeSZ7nPMkk9tUVJvtBdJIBkJvRo9Ik2RYPot8 VFtUtJOjR+dCf7NpuJB0SQyrHqQXECBp/KSe6kjg7/zoUQ6pzQ17DofpN+kotfW08GJ+e1JSi4Wk BgIjT+spmr0tzbGe6Pzvzf5bEm2sbOh1+j4pnOdY4Oe6eySkUDtoVITMn71OwsZBr0BUSd/u/Ikp cM3O2Tzyk9oa4tY7cPEJ2tJlxIBCledhDmjQj3JKQnHe73alqVUA6mApkvdAqOg7KLTH0+ElMzWT ZtcdP3z+6o2VOZYWPdOujvL/AEiMay4yw7mgcHlQc4FkRyZa9x9zG/6NFSINLXwOxjc1GuDrLNtl m/z/AHVFtz6GxURJ8kKtzJJsJ18P3klMHSSQwHRSrc1kyJPgpNcJLpI8woCv1PiUFM247sjc9ggA SWT+ahFoa0OOs8J7BsOxwII0dqpG6KzT4wdvmgpZu2Nu729/ioiyfbW2PIpNuJHpxLO/in9QbiAD pw7ySUja0qJsnRo47ooDOQS3TVyixgImZP8A1SSlFwjY5vHcKeOCTBb7fFQD3awedFNrS49wD28U 4ISPHJcfcj0ShXANIB58EegKtn+VkjugzbA0bdZPCy2anaR7vFaHUGEua+Dp5e1VMhzCWtrBHfd+ 8jj+UIO7C0hrh4xqis7EcJNqh4FiO9gBgcKVageZKrP5Vp6q2HVBTJvCkFBqmCkpIEVqC1GYmy2S Gw0ozICAAjM1Ky5tgNoKQUAphVyuZJwmUgghkkkE8oKXSTJ0lLp+yZOU6OllSySdMmqXSKSSCnO6 ljPvaPTAnvP7qxbei3McA3ULqiE21WceeUBQWmNvMM6LcedEVnQrJ1cF0W1OGqQ81JHC5OJ0gUmX GStUNUgE6rTyGRsrgGrl4bMpu1444VcdIoEaajutKEoSGWQFAqpixkCApwlCdMvqpaFFzQdDwppI g0ponptDnbtuvgrTKRUIAgIhCkywN0eJClBM9CUbIn1h4hwkeCp/sugO3Buq1fRD9aiCD2Qi0tMH Qo1PH/dVoUVdQr0aIRQkkoSbSukkiCqBudoEhEy2Uwa0u4TvLKwQBud/0UnXE6N0CG1suA8VPCom h6poKbGrIabHnU9vzWqpeRbZ7fotV3Nt9MBje6psbCt8xk4Y8H6X6SyI6smhShIJ1mksjBzZVc4l UztEq0mThMjZVNY4tZ5aFH7HV+6FbhKEfcl3VTUGHWOGhTbjVj80aqxCeEjkl3VSJtYaICk3pjLx 6kCQdFOJ0HdXnD0mBjVZ5aBkbPyrJGmllCXNPkhEKd7pfH7qZR8wf1hXRGjU+xUySWiXcqxClCUK EzJ3XIntnQ8IFOHVSZY2CrSaEuIgUFUtCcpJJqlkxTpklMUykooqWKZOUyKliolSKiQjSmDlEhEI UHhPAQhchPRnBBcnBTWsVK4q69VLQrOPdYXOtGqEj2BBKvBiWTJ0yKnVxLIYGnxWm4QFlYjZA+K1 7I2gBQS3ZIrt4lMU7TomKQXLtAcQDwrbj7QD8FWpAcTKK89lIFpQuEJinJkqLkUM2aM8yn807o0A TO4SU18h24wqFo0VuwyqtnCSnNfyi0oT+UWtOWN+s6qyFWqGohWAZKBUEgUlEKQTCuZQknLyQGng JFNSoJkk6YlSZIpcoKUkkkgpSZOkgpZJOmQUukkkkpdIJJwiN1JaeVoVKhVytKhuiswWFssCIkxi JtUyxEVAopaolqSUSRU9qYhJSF6rWhW3BVrGppXBpP5QyUawIRUE2YKSlNKRKiXKTJkklKSTSkkp eEkkkrU//9XPlGY6EItglvgnDuyKUz3eXKgXApW2PdHqdh7U/sI41SQuQYmfkkCQNDCgOJ5Pgpsa 6zQJKYB08/cpOh7uNo7p216HxCiJhJSzmAGGmQnZW9+gElJp7IlLpBadCe/glSmBYWkh2kJaAeSP XsaPcN38oJ9zGSGAe7s//viKkL2CJ7KIB7ceaJYx9UAkEHUR2UvT9QBpO34oKa8HsisZvIkx/BEx 6rLCWCABySoiogkhw0RUks311EMZLZj12/uqs1lZABOilbY8e3cdvaPolBhBSV21n0dVMGt7SSdh A0H0t6GaCBuJlO0lhDo+EpKXDmuggHb+cFAuAMePCOf0nucDE8N4Tuvx3M2NqM/mvKKEQrLmlwI0 7KLu2kJwBoXJt06R8ElMw2zYXMMsH0moX0nalTfuAALI7z/JSB3e1rRr3SUz+zusM1O4Eu/9RoLd dOU4Bnk/BScY4EDxSUp1bg3fGkwlWx9hhmpTmxzxtDobzBUBuaZBjzCSlCXDUaSjPx3hotLRtPt9 v7yYPe9pY07mnV4TVxU6Wy5vO0pKYEloE8qJBmCY8k5MkuaIk/R8FHbPJ1QUyNbgJmAe6LVQXv21 6nxKGXHbzoiYl4qeHEkR3aipgaiy0skOIPI+ilc0Odp7SBDh+ahmWuLh31RWhjhuc0z/ACUlMK65 buIJYOUQYj7AX1tlnkpNz76mOYwBrH+0tIUA8Nr27i3VJTF3pnRhOg4/lJrWggCow784pbC4kg/E qWw+mHtIIna4fnNKSmD2Ct2w+8j6RCEGg+7uiRBhvflHaK31bad3rz9H8xzUFIZ3QG+0juoOJ8p8 VL7Pa1w3tlx/MCm8Gthpcz2v1Bn+bSUgYYcOOe6JbkOdX6Ya0MmQY9zf+LSvoFMAODwRyPzVCuqR LjoElKLIG78395O29x76BO07mxrz9HshNrn3HxTghPa4lwA1bH0v/RasUa8Ks3QbR35VrHAVbP8A KyR3QZWXbS8V1vADtCwhUTW8POn0QrefZtsDGtDi4f62KuHvgNH0+C7yRx/KES3Yep7p5VgmQgGs 1v2lWi0AKVa1nqrZyrrxoqdg1SUu1TCGOEQFBLNqMxBajsTZbKCZFrEFDajtiVl5N2wGwBopBRap gKBKgpBMnBTVMk6QSQUunTJ0lLpymCXdP2ihSdMnTErJ0k6Clkkk6SlJJBOlalk6SSSlJJJ0lKST J0VKSSSQUumITpI2pEWlpluiKMljhttSIQ3MBViGYjQ+uC0i20a2WR6ehUGMJJnQDxQGV2M9zfoh WG5tNjYs57qz7UMnqH6v+qsshRfW36OpQySdSjtqpsEMOqi7He0TyAosmKY+Uej+ouEgiUqdXfBS rofZ2j4qxVjOqO4kFNwYpcQJHpVKQpqZP0wFBTyHTbKim8wbmUx2XTJk8qulSSaU6JSpMnSQUpOm RKqjaYHHinRiZGggmmVDC527sEsm8N45KstDaGw3UrLsf6thcey0R+ox/wBeTH8xUwHk8qaYJ1my Nm2VSYp0xQSxSkBJJEFSySSRSQsmKdMipYqKdJJTEpk6ZFSxTJFMUQpY6KBcpOQyn3SGDygvRnID 04KLXeqlrpVx/Cp2GFZx7rC07RCrFHvdKrlXhsxKTJ0yKnWxR7BKvNkDaVnYn0VoVqCR1ZRsnTFI EJnGAkEp6B+cneVDFdLCE7lIFqNxPZOzV2qceCjQfwRQldG6FF5S5SLZSU03iCq1iuXNhypWDVJT nv5RKkN/KJUnLC3q+QVaaq1I4KssCBUGYUgFFqmmFcFJwUkkxKk6ZOmpW4SSSQKlJJJIKWTpk6Cl JJJkFLpJSkgpdOAmSCIU2aBLlsUNgLJxfparWrKt42ObaapFDYVMlTLAxKiQnlNKSWJCYhPKiSgl iQq1qskqrYgdkhp2hAIVmxVyoJs8WCSkmKhXMYSTnRMdUlLQkkmQUyCSZJJT/9aiZ84Sb4KQtLPo p6yN0uE+SKV/c0RA1TkNaPo6/vJWljXQ0w06gfupt7h7Z0KSGTPdwIIRTa8gsaAB3Qx6lIDw0wfz vzVEvc4TOiKmTq3cjSP7SYVXuEDWUzLDqNRPgpNPpj6UOHHikpbbs07/APUqWwvjcOExsa6CAQT9 KfzlJ1wJEGCBBKSlNra4e3Vw/NQ7a9p5jyU2+o8bmxIUXOadX/S7IKY1CZHKkXEiJTnZcBsGxwGp n2vQmtLtfBJTYIc5oAdB7fylK3He2HkDT2xKGxjyJ3CB2JUscgu/SSG8x/5BFTC3e3WySPD91Q3E mK+PNGse0T6Jc5h11QHBzvc4oKSWBw0doDwk12kO18D+6ots7RKK0FkFwifo/wApFDG+zb+jY4PZ o7c1CHYgolj2WH2tDfGEzLGNcN7Zb5fSSSprmMJD2kjwSsyrHAM0gfREIbjuJLdW9p5RPUEDa0t/ eJ/OSUl+0XH2PdA4Lo3e1QLNjdwMtBif3lA3x/NiCR7pUjXcwQ7QOG4D94JIZb6n6id45/dUWXBu oE/1vopvR2gbTM8t/dTNJf7HcBJSMyTpoU7Wu4GvcrQY5l7Ntu0bPozpuVa3FdWS2t4fPdn/AFCS kLdu3kg9oU6rCBtrAaRrvKHJb7SIKK2zYQ4gEcQUlMGtc7QHzKRBPtB5KI8GuHVuGvYfmITmaB06 zqElK1MiNUx480hWZmYCcO2agSkpQMTqE7mWBosrB2dz+6VCZ4EIlWTbV7GGQddv5rklMHWF5JIP /knJ6zLtW7jHChY4lxJADp1aEq3urMtMH95BTOhzWuPYRwkXsLNPbYOG/vJmVlx2Ayeyk3DsdrHf bP8AKRUjFx13CSRCGHbTLSQfFHe30dzXNlw05+imbc4VEQ2Cdf30FMW3WY7w9pPqdu6k9z3S6x3v dz/KQjqJA181ODZ9FpMBJSmkMb6btG/BDaHEbZkk6JB5bHdSExIjd4IqXdwAPDsk0nbEHwhMHw7b JkcohOzU6lFDF3I11Vyj7lTssdc4bzqArdGg/iq2b5WSO6LKJ9T2s3vIgfyFWa33a6Hv/WRc0kOa 5pgg/NV3ukbfOd3dLH8oRLdmRLz380TshFm0iEYDRTLUDgqdp1V5wVC3lBS4UwhtRAkpK1HYgNR2 JstkhO3hFrElBARqjqsye7YDbaFJQa6VMKEpUnCaU4UamYSTAqSClJ0ydJS4SSCSJ2UpOmSQpS6S ZOgpdJMkkpdOmSQUukkkipSdRlOkpSdMkkpdJJJJS6SQ14Uoa3V33J0YkotYAlSLmM83IbrC4QNA kBCkuMdvVJG6z3Os548AhOoaeyMmhNMySlrDdQ4Obx4K3V1AHk6qBbKg6kcxorWLmCBXzRWmIKWz NI41KssydzJKrU0tcYKJkSG+wSfBW8U5SBkfkWSA2RE73Fw58FEuhBe70Wku0I8Vi5XUDkD1azD2 fSb+81UzjOSRK+6dl+bUx20nUIH7UoPdc7be/IG6tpknXb7lax+h5uSZLdg/lKaPK2jiDuN6hQ7h 3KtNdPCzK+h42OA7IfuPgFdb1rDx/YwA9vNKXJ9bRx9m42p7uGlP9ns5hBPULX6tG1QGRkD85QHH iGhkusturHc90OEBWnva0bGQFnfbrj9P8FUe6153T8lPjlixDT1FaQTuzyc/0wddQo41ouZvaZBW N1qw1taz976SsfV9jhU4n6JOibmPHDj/AMVMdNHaCSYJ1nsikxTpiklikkkkhSiU6YpKWSSTFOUp RKdMkpZMnKiUVLFMU5UUQpiVEqZQ3apwUwcQgOMqbmDsoOCeEIHqncFceFVubCs491hc21BRruUF XgxKTJ0yKnTw/orTpb7SVl4v0Fq0GWaKCW7KNlJjronTgSUgplSPT08VMqB01UlIEK4Ki0FpJ7FS TnUIoUEWogOkoIPZT4CSkGVq6Qs+3lX7lQuSU51n0kSpDfyiVJywt6swI8VaaVVZ2VoeKBUEgUwo BSUZXLpkgnTSlSRTBOmpUmTpkFKCdMUkEqSlJJBCkkkyCl06YFOgpdJMnCIU2KHbXStWp4cFitKu 02EK1A0skHVa4BP6kqq1yI1TLU0pEqASKSlyVEuUSoEoKZFyr2FScUB5SOyQgsKCSpvKCVXkzxXl I6ppSlRLlJk6SSmMJQpJQhalkk6SKn//16bXBnafiotlzpOinSzcYiUz3BpG0QQilRtLQWjUTzCY Hupi4NMwJ8FA68CElM/WcW7CfbPCbfrqoNAjwU2lum5JTJtg3SBtHgiCtjj7jAUdwaS6sS3+WoCH cooZWho0BkJq3Nr15Pgn9Nh03aqFlex22QfMIKWMnjRqmywDkSox2PKs7a2VF0y/82ElNcgwXQAF ENJ44UvpiD8UzLHMB9unmkpkyov1I0HJUHvbYeTpwn3uc3aTDT2UXAcBJTJoMiJ80i09oj4pmO2n zCldZ6zy8tA/qpKYgFxiYUgSz6R3f9Sh7A5FpaCfcC4D80cpKUywNJdAJPYqLSxpGmncJOaHEua3 a08BNBmBqkpLWawfJRdve46k+RU37yA542HtI+knuLtkzIP0vFFCDjWVPc0j9ITpxCgGnwSjWCIQ Su2wAe7U9kR1rXAO2meHO/eQyPKZTOcaztOiSGQY98gN410UofWA4aSoh7iSZOv0k97qnkCsnaOX nRFTIuFmhdr5oQ3OMN1USGyQDub2cp1Mnnskpg2xveZSc6NRyrDsgXhoc1rGj27/AP0oh72wa9HC dHj6SSlq2gD3d0oBdFbp/lJaHQaqLg5ri3SUlJGVPDDZoWztcme4Oie2gQ3a6BSdRY0Cx7dHfRKS mDuSQna0E/BSaXH2sEFMa37ZI04QUt7QJEgE8J3BoHtc6Pj3Q9p0j8VPa76I1nskpEI0hO5jAYb2 Ui0NJB0cPzUwgBJTKqu26fTbMfS8kTHrc50+qKx3KCS6ZEhkR8U1rWubvAg/u/vIqSZNTqrNm4W1 t9zXM/8ARiYmBuH3fuoTYGnbvCk4jhvCSli0vJnQlEI2kag+P8lJzGbZ3Sf3VNtWwSCCIlEIYuGv CtY7ogqq07ddSEfH11VbN8rJFHmAbwSJKg2CNsd+UbJEuCA0wli+UIluycwTDUQNgaoYOsovIlSr UNvks206rSeFnXcpKWCmEMHREaklMzVWGKuzUo7E2WygnARKyhBEr5WZk3LYDbapyhtRAq6VBSCi pBMUyCdIJ0lKTpk6AUv2SSOiSfLdCkkkxTUqlLcqOTnihxbGoG5UR1omsv26jgKWOKUhYCLdzclK wretPaxrg36SazrLw5sfRP0k4cvPsjid/cnlYX7aIsIIGxHr6xUSQ7RA4ZDoq3XlJCrsD2hzTIKm oSKSvKW5Z/VM04rARy7hZbur3WVhletneAp4YZSFjZBL0m5LcuVs6za8Na2Q4fSWi5mVdWH2EUs7 ud+cpByskcQdjepjTVxgLncjq7WNDMclzhobHKvd1O2wtIcRCeOWI3RxPVG0HRnCYLDxur7gd44E q/h5zMkS3QjsoZwkOnpXAt8J1AFSVcpUkkkklQBOg5RamuLHNcNOyAXurO4fNPXe+10Ayr/LY4kW T/gsciU2O0hpce6VmR6LS4HXwT32llcfcqPpl2rjJU8pxwx4R8y0Di1Xd1Sm39HkgAkd1VZh9NDt zNCe0+1Uus4RtixupA4WIzGscfa0qTFkiY2fmQYno9XVlUY/tx2gx+6muysq8e07QU+PQGtB27SR JHmrG0KDJzRuopEB1eUz6763za4meP3VSaYMjldJ1atj6/d9IatXNEGYU+KfHHVB0em6TlG9rmu5 b+RaoCwuhNAl35y3gszOAJGmULEKDtAiKtlvLanubqQDCjhqaSXm+q5Aybw1v0R7Qujw8cY9Qrb2 XLdOoN97e4B3OXYgK1zB4RGAWhknSSVFepRKkmKSWKi50alSKzeq3OqoLm+KkhHiNIJbZvZAO4QV IPB4MrjTc4tDSdAZC0ukZX6YtedXq1LljEGSzieiCSYJKpsvWKZOmSUsmTlRRUsVEqRTFFTAqBRY lDcU4BSNyE8IrkFycENexU7dVceqdqs491haFw1QEe/lAV8bMRUmTpkVOnjRtELUxdWkLIw/owtb EdqoDuyDZm4JhypOUQkEs04OiQOijwU9DJIeCSaYKchXdTJUXe1KUlMLGyFnXLUOoWXfykpzX8ot SE/lFpTlhb1atN0VWtWmlAqCQKSg1TlRlcF0ySSaUrpkkkEqSKUpJqlJJJJqlQkkkEkqKbhJJBC4 ThMkgpdJJIIqSN5VuoKo1XagrMFpbdYRwEKsIzVMxrhIhShMUVIyEMhFKGUkonKtYrLlWsTSkNV5 QCUaxCIUEmcLJwUySiXLylOqZOkpknCYJ0lLEJJ0klP/0M8GONFLc4jyUSIMFSbpoklQ40Gg7qbb QGwBMpy4hu2IQklLlk6nlFFe3koewsAJOhThpOkoqXHudBRn1lmsQhQWcorWl3vPCchiyoukiVHb CsGw1jawkT2Q7RtduYZlAqRNa1x19oUq6WEkOMHsUnW7xtgc/S/OSrqLp29vEoKRyWHnXyS3l3Ik pCp7uGlJtVjnbW8pKVCZoE68eSlG36WpU3PbsjaJ/e/OSUieQPojQdzynDzEeKLtxy073Fr/AM3+ UgNEjwKSkhAIk6EeCibHDyhLcWjRNv8AuSUvvnXuj0hw97OQq+h47cqTiDzoEVJrs620em4yyZDT 4obdjpJdtPYeKFA7IjXEs2AAiZJSUuNTroiOa97dzRLG90NxD4gRHKiXA6Nnd4fmpKXb7jzCGQI1 OoRBWSDu0jlwSLGgaOBPggpHJ8dEiPmpNsNZlsT5qIO3skpdoHMcKLhIPmmA+KPTQ+76BBMcFJSF oceFKA3TsnZcWN2wJKYCTqQPiihidwEp2kDhSdU47bHj2u7/AJqi8sLvYDt8CkpKa9jN4IHlPuQX kuA1On+ap+g543NE7dXa9lFtzeSNElKrcRo4wO7lF1kjaHEgqZLCTOrYQxsf20HdBTMEnQ9uEnMe 12p+YUXfyTITFj2mHAidQT3SUweA3Ue7zKJXY1v0m7viotbrp28UvWIMgSe8pJSW1vhsAAHXaPzV EQ8iNB/KQ22HmZ0hPG73O5A0SQkILNzdoM/nKDanTB5KK0V1NBuklw9rWKDGP2728A6nuipbbtdt e2NYTlhqcWDQJ90Ak8nhNj2tIIeDrxH/AH9FDJw0AGniFZoInRVAKtsCS+eT+6rWOIPwVbN8rJHd bKJmOyDpIVi9wJkn5IejtAlj+UIluwMF0jhE7KAHuIUyY5Uq1BYVQuVu12qpWGUlMQptQwphJLYY fFHaq7CrDCmy2UGw0IrRqhsOiI3lZmTdnDYaiBQapAhVyuXCkEwUgmKZJwkE8IKUnCZOE6O6lHlM nOqSUt1KTFOmKAU811cvN5A4AWY07uVo9btsF20/Rj2rNY7stjEPQGGW7N3HkEPceFrYnSzcyXmG nhFPQRrD/gl70BoVUXHEBsjlD3k6LWu6NYxp2ncVlhmsHRPjKMtkHR1ul5xqMP1boF0YXN9N6dRl vLHWEQN0/urpqKm1NDJL47qrl5fiNxXCVOfnYpzduOPbPu3n81WsHpuP05hNZ3WfnPP5qF1LOqxW gvPP5rfpFc1k9VuyAWN9jTzH0irWKAhGlpJLr5ebj4rX34jGve4w55+i1Yz8q3Ifuufv8B+YP+tq fTXhjjU9u6u0bXN/9GsWseg0/mOJb2lOlIBAefdoU4Oi3x0Oockqvf0VzRNbp8iohmgTS6nFDyEa m1zDIJGqg5pY4g6Edk28qUgSCLp6/Byhks3dxoVcCwOiXtJLOCeFvNKyMseGRZQySSSUISsQpYzY MhRUqX7X/FWuXlUwtlsyyfc1p7BChWq69wcx3HLVWbJGvIUnNRN8SIdmJbKjsA7BEUSVUEivpSg5 4HKFdlMqHuKwMvqRu4kQpoYjNaSk6tZ6zpbw1ZHJRLLDYZ4lavT+nB8PeIjgK+CMMNVm5bfRsc1M LniCVrDRRa2AprLyS4pWyhYlYHW8xzHCthgx7luuK5bqNZvySWcuO2FNy4HFZQXQ6DSG1mzu4rbC q4dAoqbWO3KtKLLPikSkLpJklElSYp0xSUxKxOu3bWNYOSVtOXN9ecC9o8ArXLRuYWy2ciVKp5Y4 OHIQynC1SLDC9tU/exrvEAoiz+l5IupA7t0K0FiZI1IhnBWKZOmTUrE9lFSUSipYpk5USipRKGVO JUXCE/dSIoLkYoTkQhrWKparlip2qzj3WloX8qurF/KAr42YSsmTpkVN/D+itTHd7llYR0WlUVBL dkGzafoolO8zwm4SCWbUnmCAk0wh3g7g4DRPCEgCZ3CUykfDsnIXdwElFpJcPJTJ1SUs4w0rMt1l aTy0D3cLNtaJMcdkVOa/lGpCFa0tdBRaUVhbtYVlir1hHGiBUEoCkoBSCYVwZBJJJNKVJ0ySalSS SSaVLJJ0kFKSSTJqV0kySSlJ0ydJC6QTJ0gpIzlX6QqFfK0KlZgsk260cINaOFOsXUSpKJSUwchF EcUNySWDlVerLlWemlcGs9CIRnoRUEmaLGE0KUJQoly0JlKEklLBPKZPqElKSSlJBL//0c4qc6R3 TOEGQITsGsJLltznaKWrU5mTuiVEapIZtI5iVJtja+JlQJIEhJro90aoqZk+u72gieym72y06Edk L1HclOysvBcDqPFFC8uafyJOcUhPwKZwjnVBTEAcHRGY9xHptj+sUPaCPNRMxokpnYbXH9I7UqBG 2fckSXwHJwx0w3WPBJTAA8kpQpBrnGOPin0jXjxSUs+ojUqERqiFoJ0MqBdu0jhJS7QXaKJ0MKZP t0SAnXsgpgnHnwiPDCAWjUcp67GtPuG4FFTEs7gGFMMhp8VP1Hbdk+1K1rQ32vJd3aihrEzxolAj vKmBOg0Vimiqwllz9n7rgglqDceU0ollVlDyyQ7+U3wUANJ7JKYgAqYO3QcFMS0CI9yaZ+KSl3OD NWmJ4TE/vHTyRa63PMMiT4qMOktdAISQjiTqnITvcQ0afNQJAOiSmbi9zds+391SYN/LgB2lM2ov BjlR9IgDzRSxc4s41+CeQRKTmub5J21g6OcAPFBTEAOOv0VL1trTW36J5SdUQA4EGTx+cnfW+sAu EykpCXkeQCLdlvvYxjp2tUXNkTEJrAWNmOeElMWkDkSFNzY2gjlM0OP0RqpiyywBoOoMhJSS+mgV B7H+6fdUfpKvq7tCi4y8us9zjyVJj3EwQB5pIZPrrDAWEmwn3N/kqDXdjwVO0FriXEEnkhD00Ewk pju3PDfJX8O59D4Y36ftl30EKj0g8ySTHYKVbbG2Flx9o9zAeE5CzNrXy8SAeyPUWuc4t+iToqrn kEgABvdFqfs1Kgy6xZAlt2T7+ANECtx7Kd1gsMjgpyGUAa7nEShj+UIO7HfL5KVjpUCd53cBPYYE KRa1bjAVMlWLyqiCmSk091CVIFFLYYrDVWYVYYmy2U2WeSu01D6TjAVSpXNoLRuPtVEjUlmbDbKh wJRWip/aEFtrRo0KW4O8kAYn92Skzsdg1DlD02j85QBTKOfAP0Ui07WsPipGkDuot/RsLyPgoCx3 cpS4APUPUjVJ6U/RUQCOUha5TD930k0RgT6fmTqjSUnM2/BRUEgQdVyyiVJRKCnluuF32iD9GPas xnMLU69u9fXiPasxpgytnF/NhgO71+A1woaH8q4AFj9M6g1zNjzDgtHBzqMmwsaZI1hZ8scpTIpe DQT+mTwFns+rrHPe+14hxnb+6rjc4PY6x4NbQdP5Sw8/qdlzXNb7G8N/ecr+HEMYWEku0zH6dhH6 QDiNup+kiWWVhujoB4XLdP6Z61oNgln0nEroRT6rpA07aI5MgiKAUIoOodO9aoWVOBeT7Wu/P/4O v/hFzR9usQZgtK6bqctxn1MB3M22McP39yxetCckOiHOa11jf5afACrQSw6c3fe0cLqWrmOnVj1g SYjVdIHDuqPME8XpXxbAKYhQDgO6Fk5LaWFxPyVWpEr3E63UG2B47jVZAGqtZuY7KduKrLXxgiA4 mI7ut0OrdbumC3hdO0rF6Lj7W7yNVtBZnMG5FkiySQ32tb9IgKLrmt+kQFAIlclJUHhDOQxp1cAm syGM0c4BPiCDYQ36LC7lCtG2wx3QsS5pftlFyHAuBCv5fXi4mMaSYErPz89tDSB9NWMm8U1l57Lk 8i91ri5x5VbBh4zZ+VeTSsnJdkHc/lAGvCcCSt3C6fXVBf8ATWhIxxhj3a/TemF59S0aDgLoWNhD BDdFMPAMSFm5ZymdWQBKmKiHhOTKr0uaPVLzTQXNMO7LF6VU6y8PmY1Ks9ZyWWfoR9MFWulYTaGb /wA93Kuj0Y/601rqBOSg2WtraXuMAcrGs61+khv0I/FV44pT2TdO9uhPK5RvU7ixwJmTz+6reL1l zQ0Waj84qSXLSAtXE9CmQ67BY0ObwVOVVqiuYO8Fx3ULTZe6TMGF1t9grYXnsJXGXvD3ucNATK0O UjuWObPGxn5BIYOEBzdpgrf6JWBUXeJWZ1Sn0rz4H3BWo5LmYMdaN7oNnuc2e0wt+VxmLaarWu89 V2IMwfFUuajUr/eZIFkmSlJVGRZMnKZFTEpoTlMUQpXCG8qRKiRKfd6BCIoTkVwhCciFNexVLROq tvCq2qxBaXOvVdWbwq6vjZhWTJ0ycpu4Z0+a02eKzcMaLRZ4KCe7LHZsCeU6Zp0TykFLqywj0tp5 mVVAkwrHZPCChKblTeJKgYTkMmDVIlO3RqZJSO8w2Fn2cK9kHSFSs4SU5r+dUWkwUOzlEqMJywt5 isNVdisNQKgkGikFEKQTCuXTpgnTUqSSSJTUqSSTpqlkkk0IKUkkkgpSSSRSUpJMnTVLpJBJFSRh 1WjSs5nKv0lWYLJN+tGCBWUYKdYyKgVJQKKmBQypuUCglG5AerDlXemlIa7kIor0IlQSZ4rJSknU S5aU0p0kilZNKchNCSFcpJQkkp//0qFjdsdp4TbidEQy+GuPCiWNmAfmkuUKzMJyD2TObsPtMjxT DTVJCg1OkXGZPdSBnThJShJ08UXYz887SFHeKzDefyJje8Pl3uKKFy8EQUNxEw3hLnlSDmD6YJH8 lJTAPhO0NPKiIHOqmxhcYYJPgglKKhBBI8UJtjmmRoVFw2Jbh8EUMy8vndydZKgBpqeEk2o1hBSR rSeO6ctc0lvB81ATyDqlqe8koqS12fZyHz7hwCoOtLpPYnhQ2kGCniUlMnMY5ognd3H5qbbGkJpc Pki1sbEvdtCSkWx3DtI11RPUB7Qob9TJ3D80lMJHKKlySfgnsYGwNwM/9FJzdZJlNtgTEoKYiGHT VOBMwYHgl7SNQiNFeosBAj27f3klIw6WwR35T7YJgT5oldxpPtGv3qLXNdO47R5JKQF0nwUvV0AA EzyU79m32gg9ykyT2DklMS1zvPyTCFJxeDtGhH0kNwj5pKSh7O88dkJMTpon4gIKZh0hQkpQpQee QkpjHccnlR3GdUVw/RmwaBv0kEEwHfekpk15I+CQe52hOidjgZA0BTOgQOT2CSl622uB2gwNdEnv YGy0nfOvhCdttg4cWjh0IbX+mR6Y790lKEHxkqQBA40Cg5xc4mde8JS4/BJSVllbRusbu8AEMgk7 hAACiBpITb/x5RQzrh7gHGG93KWwlx2v3BvBP7qr6OnwVjGsFUQ2QOU4IZVs2hWKRu0PCEGFx047 I1B8PFQZNmQMrWtZzx4INYDjr9FHvjdB+CE5llLuIDuAUIHQIO7K0tLvZwhWBRILXQUjqpFrVvVR XbGyq7md0FIk4TEJAopbDCrDVVYVZYmy2U3adVdcJr+CqY7C7hXtpHtKpkaFlDBqK1CY2TCM/wBk N7qtjFGzsvLJ2gSaJdKTrAW6p6hpKmABK1tj9KNhVZ9Dq9TqPFJ7iCIRA/WezhqllEZ/30DRCCnn RRiNFI8KrHS15S1v3jYfkoKA9plHsEw4cFOl6o8X6UUbIyolSKYhQhc8x13eLhP0Y9qywwxuWv1m m629rWiQfoq3T0rHxK/VzDMCdi2cPyBglu5/Tek35Y3j2s/ectUW4HRmwDvu77fcquV1DMzG7MVu yj+T+cs4dKvmS2Se6cZwB3RRL0FX1mxbdLmafyh7Vpk1WMF1NbXtXGXYF1TZc3TyQsXNyMMzS8gf un6P+YpIyEkGL1x6pSHFjGCe4RWZ73ahrWtHksfH6xj3EHMr2P8A9LX/AOjFqFhtAdW4OZ+btVXK ZRN/orxTR6l1m+lkVho3eSy8i85VDc2wAXB3puP5tjfzFp9Rx3ua1jREnVzvzVjZt7CBj0ma2a7v 3nqTFKUo+pBro1XOIMtR35bnsayT7VXIlTDe6cYx6qCS/Ke8AFx0Suse8N3OkQhEdxwkXSPJARj0 SSWIZu0C1cHpRdDrOPBZTeV0OBnggVvPblMzykB6URdWtgaIHARVFplSKySSSyuL1tkgPnVvZY2R kvtIJPAhbXWdoHuMEj/OWCYJgLSwAGOq2TK7I3xzwmtyvV1OhiEJwlQDdVYEYrLLpYuVtuD2HaID XArqMdvrcnXsuSwGMtsAfourDY1Cr5ZiJ4P0FwDndXezYanGHjUBc4RuXWdTwRn1i0aWM0WUzodh +kU7GY4xv8yjq44GqtXZJcWkE6BaDOhk8u+Cj+w3+ITjlxncoALRdmPeQ5xMpXZb7HBwJCut6JZ+ cQFIdCdH0tU3ixJ1W6Zlufd+ldJjRbriQDHMFZuH0oY7t7jLgm6tm+izY0w88KrKInP0LnB9998f nucuvrbsaG9wFg9EqD7HOcJI1ldFCdzEtRH9xAcHreSQRW0/1liCSYC0+rVmy8lrTI+kpdGxS95s cPaOFYxyjDHa0gkucaLGt3bTHdCldmWCIjRcz1WltN8M4I3QnYs3GaQRTsdDvNlJa46tOn9Vaqwv q86RY0rcJWfnFZCyx2aHVCRjvjwXJLe6/cQGVg+ZWEPEK9y0ahf7zHLd6vApFNLWjwlZ/XWCGujX xVrH6hUaQ8mNsNcq3UMqm2vbyT7mqCAkMllJ2cNjtpBHZdbg5AyKg8adlyMQug6G4itwJ0nQKbmo 3G/3UQOrsJJJlmUzKUU5TFFSxUSpJAJwFqWDUzjCmTCE8yp9IhaichFEchOUYSgsVO0K49VbVYgt LQv1VUq1cdFVKvx2YSsmTpk5TcwlpMWbhgrTr8lBPdkjsnapKDRAUkAuZV6nzRXlPTSSz1RxO1Re pRstWJkKBCk3iEw5Hkihm7gBRUnmTCiUlNe7Uqo8K1YNVVsSS51nKJSoW/SU6k5jLerKsNKr16j4 Kw2ECoJBonSTwmFcunTJJhSunJTJJpSpJJIIKUmTlNKClJJJIKUmTpklKTpk6ClJ4TJ+UlMm6LQp WeAr9HZWILS3q1YCrVqw1ThjZKBU1ApykblAqblAoJYOVd6sOVexApDXehFGehFV5M4YpJJBRLlJ k6UJKWhIqUJklMUlKEkkv//Tz92umidMIHKbXskuXPknEx5JAHulM8pKX41CiXEGU8bnQ3hItLTH dJC25EDxG2NELlSBgaJKZm0RtA+aZzg8yBtUIRWSBMJKYFpTguHBhS1PJlQifgkpQ0RWe3sENrmt MO1SPiD8kVM7TSCPTBDvzgfoqBeXc8JF3Y6qUiIa2XHughTarSC9jS5o5P7qW4fNIZFjAQ0lv70I evKSkgaSkdOEmtJESpvqc0eCKmB2sb7XanlqbkJw0E+AU20uJ5+CSmGzaJcYJ4TOMASOeE5buGup 7JFjI5MpKYBNJGiYnSIUtoHdJSm+BRS4DUDX95LbWGkiZ7BDfoJSKlDcXyPpHxUXF73EnkcpSl9D RwMeSClohpKW0ASHan81Inco7hwNEVKDYbMqbQ0j3Ie13MaKTWayeEFLGDMcdkgJPmndGvgUzCRw Y80lKA18UnN2uizTyChBaAGp9msnUpKU4jYGjjsozwEZnpAO9WSY9kfvIPx7pKVEaN5lS2RJ3Dd4 JiC0hJrW6mfd2CSlHUaaKBMI9tDWOhriZE69lCD4aJKYtcZI7Qk3Q7nJmDRNwQO5SUz9UBsAa9lG y42O9QhrdPzVJgdBaGgkCEAMLtCJhFC4h2pKNaz7M9kGTz8nKGxpbI02/wDSUrciuytrC0+oDDXB EKSMDtY5VigxEoMhpg6geCJWZBhQ5Nl4S5JDTJ0PZViXh02Tu51ViyxzRAbJP/RT1AXAmw+4D2yh j+VEt0DwZk90nDTRPsdujlRJ7KRagfCA9GfqUB8JKROUJTuKgUkpmFWqlTYZVyjUgIFTrVu9OvcO SjY+QeHahRDA+vYORqosrIOqqyJEv6rIHQc0Vzb2VRpLzuKPXc0yx3BTPrFWrdQVDkje3yLgwd2C LVwR2QeUYaN0TMZ1MlFPv3RtjzULB7gR9FAII50Ra3y0gp3GJf1ZKqmJMlOeVBuqmeVWJ0K5RRKX A+x3BQxqplrWDc5HHd/1EFm6pwMcpnMa36ZhQfdY8S3QIW2Pc7UqThhE/vI1amf1SnAcIZueRyub zM6zNd79G9mq31ut7bNx+ieFlN5WjjIMLDERRes6fT6dLQeVdDFV6e1zKWh/KuSsrITxFlDAsXN9 YxfSs9RujXdvNdM4rneskufvH0OIU3LSPFSJByi4kQeFr9DsdvLZIEaLHHuW50ZxLi1w+BV3Oais iz67a5tTWSTuPiufC6Hrroqa2OTyueAJMJYDcFSbOEwW3MaeCV1DcOofmhc/0ykG9snhdU3VVeZm QaC6Ia4w6m8NGqz83pLXAupEO/d8VtwoOCr480gd15DxE7fikHSjZutrjEaoDVrj1Rth2L1fSr32 0+/kaLRWR0e91jCHCAOFrhY+YVIswQX4td/0xMcID+m0P1LVfTQmDIRsUtM4FLuWjROcKp2paFch KE73Zd0U1W4VQduDQCrAClwkmykTumlqztdB4KlZQajB4PCi4IzCbq4OrgrEP1kOH/KQ+VadCg2p bVJJVTdrmG1LaplMUrUjMLleqvNmS4H83QLe6llfZ6S4fSOjVzeM12Re0OOrjqr3LRoGZWF3ujY5 qplwguK1IUWCNFNVck+KRK4BGWA9kwYGaNEDyRVEpvETolz8zPrxva7Unsudz7/Xs36TCl1Kqyu4 mzx9p8lTBAIJ11WphxiI4h6pMUjrT0vRKDVSXO5cZWoVXxLW3VNezQEcIzis/ITKZteNnm+tXB9n pxq3usvyRsuTc+TOqhVQ+2dgJhauMCMAxnUsA4xHZOHkxPZW2dOud+bB81L9k3jUhLjh3VRadgjV WumX+lc0njhVrmuYdrhBCWPZ6Tw+JIRkOKJCBoXs0kLHt9Wtr/EIqxZCjTOFJinKYpBLFLhJMeU4 IVHihuRFEhSbqQFCcjvCC5ABTXeFUtV14VS5WIbrS5uQqytZCqq/HZhKkgYMpJk5TrV5LbgAGxCs sWbhLTqEhQT3ZY7JgkdAmTnXQoBKbFedhb5yk5DpbsnzUyVKCtU0wZQ6X+8hS4Qw3a8lFCYmSkmC SSkVwhUrOVfu1Co2pKc636SnSoXfSU6QnLC369FYCr1o7UCoJZUgohSCjXKSSSTUrpJk6alZOkmQ UpJJJNKlJJJJKUmTpkEqCdMnQUpOEkkUM2q7QqTVepViC0t2tHagVqw1ThjZKBU1AoqRuQyplQKS WBQHo7lXemlIQPQiiPKE5QSZ4qlJMkoly4KdR5TykldJJKUFLJJJJKf/1KEaAp+DIEKE6p9xMSUl yTcTJPzQyY47qTDBT2gB2keKSmIaXcKXAhRDipPsDoG2COT+8khZo3dp8/3U7iGugGfNSFjq/oHn wQ+ToElJGGXbin9UzPYdihOk/JItIEng90bVTJxZy3nwS3wNeCkyppkl20gfeoNc5BSvgp7fNRBT ggjVJS8Ryk57TxoUp1UyHvq+iC0H6X5ySEQkeam01jV4MeAUJgR4pGO+qSV2khE3ueIPCG5xOh4C XPdFCZ7i4aHQIG4qW6Ei6UlLMcivs9VsOOrfo6IfJhIuAKSmLgQU7i0jj4pNrLzoE4dBhvPmkpYm eT8FAk8J97jzHwTl7zAOgCClAGPFMN3aSn3aa/cpNyNjSANT38ElI3Pk8Jtw1Eapg4RCIC0iYhJS xbLdxdB/c8VEvcBASDZKRG3TnzSUprWjVxU217hIiPNDIGncpRJ1mElLghx1TOb7jB07Kbw0OIaN FAtJGiSmTHj84fNCA13ImxxE9krQzcGtBEfTP7zklMAZO49u6mGCN0wJhD/ImDZ1d9ySl3ENd7TI 8Un/AEdCS48tTh4b9AQONUMgz5pKX1+CTWku8T4Iu8OEVgkHlCZY4fR0KSmTiGmSY7Qhvsj6E68p wHGR27kpwWhu0dklLDU6Kba6g532glpj2bf31Aa8D4KLrCw7RqfEpyGwLH+0QAR96s45A55VWCRL jr2VmgCYUOX5V4S5G5oJHKAKLGM3nRv96NlA6Ryq7rHOgEz4JuP5Qg7panBhIKHY8E6JnvJ7Qhwp VqKxV3lHt58lWckpGSoqRUSEEsmFaGIJcFnMWlg/SCB2U6AeQ4qTrXO0J0QCYeVNpWfkkdmYJmlW abOxVZqI3RQxnR/qriE72bDI4PCOG+2QhVP3DafkiF+32n5qxEAAlYVxe1ukSk1rXiWiPJRFLT9E pg/XaOEAb+YK8lek5mp4TjVKuwtMchTcWsEt7qI4wRp8i61i4ME90GC4yU+p1KkoZT6D5U0sCW8J jJ1KkkUOIlTznXK3eoDPsPH9ZY4EO+C2Ou1vFgfMtjhZJcXH4LVwfIGKW7s0dTNdcRJHCM/q5BAa NVhOOkpg8kyU04Ik2ridfL6pYHgD6PdUL7DbLz9GeFXe4u5TGYgp8cYii1msLjouo6biupZLtSVV 6RglrfVd34C22tgKrzGa/SF8Q5PXH7ag2PpFc6PaV0vWbfTrAidx7/mrmSIKn5b5FsnT6YwOtaZ1 ldQ1cp0kF17V1jVU5r5l8dmSiQpJnKoDqueU6k/fcdII0P8AKWcNVsdakWxEafS/eWOtrCbgGGQ1 eg6JcXA1xoAtwLneg6PcD4Logs3mR6yyxZJ0wTqsuUkmTpKUkkkjaliosea3z2PKmoObIT8c+CVo Its2V16vDoQXNjUGVW94cAdWq1UwvMs0CunHDIOKHzLLI3YlQcUS2JkfNV77BWwuPACpnGRLhXXo 4nXL2uArH0mncl0XDg/aHfBqybbXXvLnckrrMOn0amsHYK7kPt4xH95aNS2WhOTCQULJIIHMaKhu V6t4PdKQVx919oscC4gzrC6Hpl4sqABkhTzwGA4kWnyMZlw97QVzvVcJuMQ5mjT+VdQSsPrzSWtI 4H0lJy85cQH6K2TX6Hkllvo9nLY6hb6VD3eULB6Kf1ofArZ6tv8AQ2sbu3GCpMsR7oQNnliZ1K6P o2Oaqt5/P1WJ9hu3QWnQ6rq8av062s8An8zkAiBFUQzDUxaipis7iZKcDrlAAbZ34KxBouq6linI qLW8gyFz5wL4nYVp4MgMKJYpDV3OkPmiJ1BWisno+NZRuNgjdwtZUc1cZpkjspMnUVEuWKQSTFOG iFnFIJoTqSNlSN4Vd2qsvQH8JxU1nqparj9NVUsCkgtLn3qqrWQqpWhHZhKyZOmTlNzD7rWx9QVk 4fdauKVDLdkjslSiSpOCYeKaFzKYTymTgqQLVkiJTpDmE5CwTpiITykphYJCo2q+QqN+iSnNu+kp 0odx9ynSnBYXQrR2quxWGoFQShPKYKQUZXKTpkuU1cuEkkk0qUmTpIKWSSSTVKSSSSUpJJJBKydM nQQukknSUyar9PCohXKVZgsLfrVgKtWrLVYCxRUCpkobkVIyVAqZUCglgUCxHKrvTSkNZ5QiUWxB KgkzxUkCmTSolzNPKhKUoKZylKhKeZSSylJRlJJT/9XOc0sdtfoVIxOmoUtm8bnO1HZDcAHQ0yku Zhpe7a0cpOpDY11nUKO8gbeyjMcJKZ7Ce8JyzYYd3UN0Jhykpc7QdFJroSI2jRMQBqEkLTPxUiXH SdPBID5KJ+9JLIEDnVNP3pw8DU/clujhJC7RIJCUt2+ai1+0/wAFN79xLoASUsx7WzuEpb3RE6Ja fNQLpKSmYcIhQ8ylITnUQkpTXRMJ9jjx8VKzZp6c/wAqf3lGdn0T9ySlBoPklCQgzPZRSUzcQAoA Ep2guSfaXAN7DhFCQbmjcNB3KhoCohxAglLzQUmfb6kNYwCOXd3IbxBiZ+CYvjsmAHzSUokEqQrJ EjgeKiHQmkEyRKSl2AEyRKZ8E+w+1Ik8DRI8QkpXwKbWIlJ2vaI7pe3v8klKE8gIznWQHkg/mhv7 oQG8yeFPcZhpie6KmJdBk8pA6aHnlL2zrqU77GuIDG7Y5/lIKYkxymgxJOiKx4afd9HuhOd2HB4S Up0kHyTAOJj84+P7qW+E7nW2+52sDakpgB5p9AA/5BIMNfI+9TNhP0jIHb81JTBznPIA4A4CbUan RFL3WOmA1vkmvbUx/wCicXtI7/muSUic0uCYkqRA7mFJtbXMc9xA29v30lIw6JjhDfqdw8e6mGyC Tp32pw/eySNoTghLu4BVzHO4iUBlwZWWACH8k/SarFA107KDN8q8JL9gd7kF7WyADKJlPOjdNe6h 6I2w36U8oYvlRLdRrLzKHZXsRCSNO6Ft3FSrWs8aKs8K3YI0VV6CkJCYhT26p9qSWDAtDC0cPiqT Qr2LoUUNy1pa8pMRshurXeIQ2rMyiiWeKZiIoN0UwqxXsmmEV+oBQVYaJapsfqBitK7XNrHiSna5 jzxBQgC6USquNSpY2SBXoWlaQ2Smbq3VScGg+7nwTTPwTMh4dEhQCkmSVO16kk6SSmnlYNeSQXzo qA6HWCfcVtQlCmjmlEUCtItxP2Ez94p3dCrI0JW1tCW1P+8T7q4XFb0OsGSSVbZ0uho+jKv7U8Jp zTPVXCwYwN0CmnhJQk2lFdS21u14kFUj0nH27I0WlCUJ8cko7FFNXGw66BDBCttEJgFJNlIy1KQF JFJJNGimtkYrMgbXiVWf0mh8S3jwWjCeFIMkojQopr04tderRCsBOEkwyJ3SpOmSTUrpJJklLpJJ klLpk6ZEKYPbKi3IdXofvRSoOZPKnxZTjK0i1OcCJlZ3VbQ2gtM+7RXRXtPkpWVNeIIlqlnMSkJh AFaPN9K6e62wPsBDRr/WXStCTWAaBShQ5cpmbSApM5STFQg6rnk+rUiu4lvflV8PLdivDhx3C6bO wxks2/ndnLl8jDtokvGgPK1cU45IcEmKQO7vP6vS0AjXcFldRzPXd7T7SOFncK1i4dmW4hnHdycM UMfqRZLpdAqHvsI14BW5tQcPFbjVituvmrMLPzZOKZIZAEe1SATwkoSSupRTFOmKQUwIlR2oiZOB RTANhOnTJXaVkxTlMUlLJinKQ4TgLQs1IpBMdeFPHQIRPMoLkUmEIppOqUNqqWq0/UqrapYLS5+R oVUKuZKprQjsxHdZMU6ZOQ28NauNysnEmTC1KdCoZbskdm44KCm5QCHVcySCQSedsBPC1eVGYKdM UULv0SCZw9sp4jRFSlQvMlX+xKzrdSSkpzrfpIlKhaPcp0pywt6oKw1BqRwgVBmFKVEKQUZXLpJJ BNK5SdNynTSVKTQnSTVLJJ0kFLJJJJKUkkkgpSdME6CVJ0ydJDIK5SqbVcpViC0t6tWGlVqyjtVg MZZEqBUioFOUxKgVIqBTUsXKvYjlAsQSGs9BcjPQXKGTPFimSKZQrl0kyU+KSl5SlNKaUFMwkoyk ip//1s9x0UdFIAOOiiIQXrz46poT6duU0pIUQOycJhop6ESTBSSxnspmsBodOv7qHuS1PJSQuHSU 4aD3hR45SlFS4PdOGl/CiNFLcQIB5SUtMJp8VN1bdm4OG790/nKAB5iQkpf4KYYTqOByoBT3EaDg 8pIYQm27k7nabQmDi3UJJZOZs7yokpOee6YnTwSQygtHPKY+P4KM66JyI7ykpW6NU+4HVRhIIKZg p95I/io8pRP0eO6Kl93ilBITPLQBBk90wJKSGYr3aTCYt2mJTCY1lNIB4SUykaQPioDXVTJnWP8A zFEZXWRNjo/q8pKYE6AchQJB1Pipvrc3VhkHv+6hjT4pKZR2lM9hrMEcpDb3Tkz5pKYDx7pbiT+V IuCk4tLQAPd4pKYS384T5Jy506JomQOfHwS7AT8UlMw2R5+KiXEzBgph79CYUC6IjjxSUye5zjuJ kptscpGeAmcJ4KSmQDrNG8BIOjRRaSBA7lSLRHtGoRUxNZImZ8U23cYAUnuJMHlRjdzoPFJTFw2y O6fa8t4MJObA9usakqVdmwh5kx2RCGYIHAV+hpadeVSa86uMDyVzH1iVBl+VeF8hu4iEnHZAH0vF TuBJ8lEva6I7fSQxfKES3U8Tqhn2KzY5uzTlU4KlWoX6qvYIVp4VeweKSkKUJwFOEEsWhWadCgtC OxK0Ok4b6Z7hCaj4pDgWnghAgtJb4KhnGts0U7UQKDeFMKmyLgSVZ4EKsNFYBkK1y+xWSVugyOEn XtA3DlDPu9g5TbPaApTLhW0msAdtf3PKincfaAkqWU+peNlJBJJQrl0kkklKSSSQUukkkkpSSSSS l0kkkVKSSToKWhOkkkpSSdJJSydJJJSkkk0pKXSTSlKKmSZNKUoKZJkkklKSSlNuRQumTSnlFSoS GnPCSRSBpSydODIg8puEZRr+6pSSYlKU2krEShWUtsBa4SCjSm5TgSENQYVQEbAi10trENAA8kZK E45CdyqlgEk6RUdpYpJJJKWTJ0ySlJkkkVLJk5UYRUsmTlMiFLfFOmSKfE0hilPZJIhSRNqRPEoT kdyrvSIpSFwVW5WrNFVtUkEFzslVFbyNVUK0Y7MJWTJ0k5DYxDBWpV2WVinValeihnuyR2bm6Qko N1UkAlkNEn1mxu8fmlRR6nbR8U8IQAynKciCopyFpkgeaI/mFFo1TlBSzzoVn2K886KlZHyRU513 0lOryULvpKdScsLoVI7VXr4RwgVMwpqKkoyuC4ShIJJpSpOmlOmpUkkkmqUkkl8EClZJOmQUpJJL lBSk6ZOEFLpJk6KGQVupVArdKsY1pbtasNCAwqw1WAxlRQyiFDKcoMColSKgU1LEoFiOVXsQSGu9 Bci2ILioZM8WBSSlMolyim1SSQUqUpSSSUqUkkklP//XzmxwndWQNw4TbgTKlYQI2kkdx5oLkcH5 FLhI6pSUkshqoQnSBSUy0bwkD85UJlTLXATGiSFFryJjRNMCAkXHiUwSUyCaY80jtjzSMQEVKLTy U8uiBwo/FOTIhBSoJSgjlIFPKKlMAJ9xgJwAO+niU2wu+gEwIH0hKSFENnx81KvmU26OybnhJTN7 Buhka8/yVDbt0TujgBM1s8JKWhODCcVWPnZ2SDSEFLADulMDTumiNCU8SJHZJSg6OE5eD2iFFztZ CR11RUyc4gQnqDJ/Sat8kPckN0R2SUykawICYwRCQIAhRJHZJDMWECGpOLnHcUg0CNdVIvI0Gnik pgPBNLRprMp26nUwEtoJhknzSUxcHQCfuTCZCmGAy5swPFQFnJCSme3eYmBCg5wMNHHcpEe2Z/sp g0NaI58ElKkRwozDdeVJ0mFGPuSUy550TQYl2nglAPmoucTpzCSmbKwW790O/dUduocRofophEAH 5pE+6Z0SUr6POsqJcHE9wEZwdAHblDLpJd3PKKlEkjTRqnIeGiNf4IJ5A7KeoM+CIQmczYQAZHKu 4xEwqFcSQRyruMRuDe3ioMvyleGy7cOFWGh3eaNbM6fNQ27iABAHKGL5QiW6ntJG7gIU6I7yCIQo 0Uq1C9VrFZs5VZ2qSmAH3KcJBSASUxARmoSIwoFTdoftKs5DAT6g+apM8QrlNo+ieCqkyJXFlCmI gUhSPzeFIVxyqRxytktgAiHQAKLngaBO4+wRz3VjEBEFadUfD5Voljhu4KrQilvslATviVSidxTq LQpKnI2bXBdJMnTUq4TpgnSUpOmSQUukkNUklKSSTpKUkkkkpSSSdJSkkkklKTpuUklLpJkxKSlE qvdlMqgOOpVLqPUPQlg5WBkZbroLuVbxcuZ6n5VhlTuO63W10RI8U1HWPUdtLVzkkqbHlmoVv7tE BbxPRV9ZY5xa4QB3WlXe14BB0PC4qx8mUZmXY1rWA6BRz5UV6UiT2gcnlZXTuofaJaeQtMFUZQMT RXsLrPTaXHssP9uPaYeJ+C3bGhwIPBXHZlLqLC1wIn6Ks8vCM9JLZGnVo64XP94Aatqi5trQ9vBX ELo+iWOLCD9H81ScxhERxRRGVu0kogqSoL1imLux+9OoOTonoouX1PqJxya26OI5WWOr3bNs+7xU 8p4sudRkEDX9HZ+5/wAYs19TmP8ATd9KYWpDBARtjMjdPU9LzHZNfvGrdJ/eWgFUwccUVBg8NVcC zMlcRr5WQKSSSUaVJinTFJTFJJJFKyZOmKSFFMkkUlMSmTlMipYpFIpphFSimPCdM5SBCgFBzoU4 UHNTxoNFInFCOqsObogO0SIPVSF6q2jRW3DRVbRopYLS5l6qFXL+CqZWhHZiKySSZOQnxfpLVYsr G+ktRh8FFPdki2WHRElCYiJgSolGAgIA51Rj4KQIYvCgpkyolOQzZ3UVL81RSUit4VV6s2qrYklz 7x7lKlRu5UqU5jLoVjRHaq9asN0QKgzCcJo1ThRlcunS7JJq5SdIJJqlJgnTJql0kkyCV0ydMgpS SQSQKlJ0ycIIUE6YJ0aUyHKuUqmFcpVjGtLdYrAVetHBVgMa5QypJiipGQoFEKG5BLAoFiMUF6RS GrYgOKsPQSFBJmiwTFShNChXsUkiE3CSl0kydJS6SSSCX//QpVsFxDTDf5SgRDi0mQOCFEuTh8cI L1y327uyh8FL4piElMQJT8KQElSLWQSSd3YJKRqTnaQJhRSDS7QJKUAkSBwlwlykpfRMUykIHmkh WnfVLTukNCnJSUx76Jz5Japw0wXeCKlGRwUg0fncJ2N3akwFFwaDDDIQUvoJ1+CiIUobtJPPgoiU kLie6aTz2Tuc06NCjEIqZ7pPOndLbuMDQJthSJHASUtAlIAnXsEhzrwn3amBAQUuxu7Q6BPYGVuh rt4H5wUQQ0EnUnsoiB8EUKLp47pueUtAkHduEEqJEaKQLCIA1OsptDwpkEt3AgHiEUMHbR9EynbH 5xhM1sBNPMpKU0b/ADCm5zmmG+1QaY0CdwM6JKXex1cbtJCGnP0pPKRdPZJS0wdU30nE8BENjdgr A1J+l+6h7vuCSliddOPFNM8+CMLNzCGtQQdfgElK4EFMI4HKc+PKm2J14KSmJEHVJujiXET2SYN0 NHj9L+SmczZZt8ElM3vJO52kqM7fo6Apk3f8iKmJGuqISZDWKLiXmTqe5SLZMt0J7ohCUAgajgq9 QSXTwFSAAGyZJVvHMuABlQZvlK8bpchxA8kAvn3TCnmv2QR4odjhUQ24Alw3CEMOsQiW6nWGZKcO EShXvh0N4hDa+W6qZaze4KuTqoueWlNuSQlCmENqIEErKbEMlM2zVIq6txpU2HVADtysMELNy7ln DYbYQFLeShgaIgCgMiV9LgIu8tYhwixuYUYE6oKzfNHcfaAhMbKm9GOkZEoKwTpgnCrLl0kydJSk 6ZOkpSdMnQUsnSSRUoJJJIKXSSSSUukmSSUukkkkpSSSSSlFV8m9tLS5xjwR1mdYrD6ddNVLjAMg CgvP5mY/IdJ4HCq8qTmlqt9PwjfYJHs7rXuMI+DDqSlw+lPvG52jVdu6K0j2GHd/NbLGACBwpELP lzMjLReA8hk4FmPq8aeIVRdjl1tsrc1/0SFxztCQr2DIZjVZIU3sOxgeC4kRyuqptba0PbweFxNf K6/p4ilnwVbmojdfEtsrB65SSGv7LfVTLx23MLX8KthnwyBXEPGrT6Xmei8Nd9ErPtbscW+BRMRz W2A2cLVyATgxDQvaNKlKr41rbWB7eCrCxZCjTMFFVM20VVOJMdgrZWR1fIYyvY8STwpMUbkAgvN2 uLzJV5lZy/RcPpztcf6izit3oYLmEEaAy0rWmeGBYhqXdYIgIgUWqSxJHVnCkkkkFKUSpJigliUk kkVLJk6ZFCyZOkkpiUykVFOQsmTpiUkqCYqQ4TFSgaIWCYpQnKlggsHKs9WHILwjJQQuVO10K28K ncCjBRaOQFRKvZHCpHlX4bMJ3Ypk5TJ6E+N9Jalay8b6S1K1FNfFss4UiotTlMC9LRBJnwUnKvju iwo7lIFrFR7+akhzFkeKKEzjoopEmdUkVIrBpKq2hXbBIVOzhBLnX8qdIUb+VPGIB1TwxlvVhGCh WQimDwgVBkE8phJUvioyuUmlOkmpUnTJJqVJJJJql0oSSQUpMnTJJUkkkgpZOmToIZJ0wSTlMgrd KphW6VNBaW9WrDRKr1qy1WAxrwokKagU5SMoTkZyE5NKURQLEdyBYgkNZ6EUR6E4qGTNFZMUimlQ r1FRJTkpklKhOFFIFJTJJMkkl//RzohNydE8k/BMHeKC9XdSmVEyUySlwY4TkE6nuopw1JS4hKSe FHun0GqSlk8z8k5duMxCRcSkpaAkISgpQkhUJynLIMAyFCElMgYTHbzOvgnjbyOeEhAKSlBu7RO1 zmERyEjsafdJ8YUdCkhT3l5lxkpDnVLanLTG5w9viipYkToonXlSDZ7pFhadYSSxG4JxHLjAS1Kb b+8gpUxPdICeeSmIT8JKVMaFRPGnKlyJKY+74JIVEBMdfin0hSDZ7gJKWDWgS4kJiCdeyZ3hMqYd tEIoYR4/cpN2j6WgSc8AwzjxTROpSUyFjTALTCgeOdApbk2giUlLR85SDQJKkXNLoYIEapEyS0d0 lMWhs+75p37XH2CB3SeBOnzUDA7pKVqT5KXp6SefBQkn2+Kdrdf4pKW0KYgnVydw2zOpT6Bo7lJS 4LSyBpGqG10OmNFNgHL+/ZDBJdHI7JKU2dSe6Tht18lMyQB2HCGQfn3KSltU1hLQPwRHsDWNIMl3 Lf3VE0neA4jVOCGwxwc0EnUdlbxiJ0EFAfUK6mkEa6RKsY+pE8qHN8pXxWzxvbHidFQNAgPfYS6d mwrQznMa33zHaP3lSGA4gvc7Qe73fSTMPyqluwzA2qNnJVdl6Lk7hED2gKs1vuU6xI58mClKe+Gg IQOqSm1WZRJQWFTJQUtY6FVNuqPYZCqO+kkp1MZ0hXWlUMX6KvN5Wbl3LYjs2W8KY0UGoiqlcuj0 ETB4KApNMFSYjUtUHZtgCrhBcZMpjYXOjskVJmIqgtC4TqKdU166dMnSUpKUkklLpBMnQUvykkkk pSSSSSl0kydJSkkkkVKSSToKUkklykpSHZW2wbXCQpp0Qa2U1TiVkatH3IjKgwQBARYTFP4ydCim JIbyh2XMZ9IgSqnVrNlPMLnLsx9jQD+b3U+LBx6rSad7Jyqrw6qee65lw1I7Sn9QlEprD3w4wFoY 4e2GMm2107Bde7UQ3xXUU1itoa3gKthMY2sCvVviroWdnyGRZIhkoOCImKrg0ueR6ljmq1xI9pPt KotGq6brDJqmdFzJ0K2ME+KLFLd6Tou9tZDvo/mrXBXK9PzHV2NBPtXUAys/mIES/vLwVPK5rrTn etrxGi6C+wVsc49guOvtdY6TqpeVhrxIkUQ9xhdb0uj0KRW/nxXKVtLngDuV2lFfpsa09gp+Znwi v3lsQniE6blOss7sykkkxTVLqKdMUUrJJJklKTJ0yKFkimSSUsUycqKKFJinTIqWSPCkEipojRBW CYpExomU0dNEMHIThKI/RQmUClA7RVLohXLBCpW6aJ0dEFz7yqblbuVRyvQ2YjuwTJymT0Jsf6S1 qQsrG+ktbH81FNfFsBIpEJKMLysxuwyiuMqEqQM8qQLVpTOEuBTpxqnoUCnURonJSUs46QqditlV LUFOffylSmv5UqBKesLfr0COECvhHagVBmFJRCdRlcvKeUwSTSldJJJNSpJLVJNUvCZIJ0lKTJJI JUmTpkEKTpJIKXS5SSRUyCt0qmFcoU8Fpb9YVloVaoqy0qwGMsoUSFKVBxRUjchORHFCcklGUCxH cgWJpSGrYgEo70BwUUmYMUk8JlCvUmhOkgpjCUJ0klKCSSSCX//SzZlIkdvvTAJR4pq9W6dVNkTL uFABOEVMnmTxwoA+CUJRCSl5SClEAFR76cJIURCQ0SlNMpJXE9lIVlzts7fim41CiSTykpYkgxyP FO326pAjRIkSkhkXJAAzJ1UmVG08gfFDc3a4tPI8ElLSAYUxt78KMwE2hMlFTMS8w35JEmNp5B4U Q6AkDA80ELgapiCDBSSPmipWoTcqW0cphogpSUqQcCZhICtxO/QdoRUwc7ueVECOVN0JS08BJSt2 m0cIZ1+KISZlNuk68lBSmVydTCW2SkXmNOyYGNUUMtpJganyUJI5TyT5KRggknVJTDV2qX8E+hS7 pKU0HkjRKT4aJR5qJ5gJKXbH0naBMILpA0SA11KkxpedvAPdJS23lxPeA1Q5kI1jW1uLCZA/OCHJ bqAkpgw6+4aBJ/JI7ojnF8uPJ5Q50SUotAI7pMdBMDy1TFsQpkjdokpgZjTskCS3XTyRNIJPPZRg FsnkIqRtnsmcXPcABrxKeQDKRb7SDrKKGwBvALO30pVzHMuE6ws2sEcTtC0sciQFBm+Urwt1AEVk gSVQrre0zcSCIgfvLSzXem0O8/vVWy17f51u3dqz+qm4PkVLdq573BvBh3dUmTOqvZzrLS1rhoPo oJrgiVOsRPBMeCTQrD69JQWhJSRhU5hQAUkFMLDyqp5Vl4VZ3KSXSxj7Qr9Z0VDFGiutWbl3LOG2 xTAQ2aBFVYrmQ1UoSZyit948wpIwvVaSxDdpST9yUyZk7JC4STJ1CUrhJJJJS6SSSSlJ0ydBSkgn TJKXSSSSUpOmTpKUkkkkpSSSSSl0kkklKTJINuQyoS8wEQCdkJkxQDlVgB24QURljbBuaZCcYkKa vUMMZTNhMHsVz1nSMhpI2yuuiVAtU+LOcYpaRbxD6X1GHggqO4hdjkYzLm7XiQVzGbiHGdt7dir+ LOMmh+ZjIpNgdRdS4A/R7rpqL22tD2GQVxA0W90N9gMH6EfioeZwiuILol6AJFMCpLNZGtkUttaW P4K46+r0nuZ4Fdu4SuX6xQ5lxeR7XcK9ys6PCskGpiuY14L9Quqxr23VB7eCuMmF0PRXOFTgfozo puZhY4lsS2uo5TaWw7XdouXueHukaLX6xL3t19oGixYkp/LwAjapF1eisa6zUSfHwXTNCyOjYpqY Xu5dwthqo8xO5ml8QySSSVVepMnTJKUmKdMilZMkkkpSZJJFDFJOmSUsUydMipZMnKiUVLp03GqZ T49FpUmKcpiFIFMH8IQCKUMpHe1I3qlerrlSvT0OZeqjlcvCpuV2GzEd2BTJymT0Jsf6S1scw5ZF H0lrUHVRTXxbhCZSIUSmBcrySCcCUohPCFFIJJk5C5STnhRBlFSiqt4VpVcgglJTm38qVCjfypUp wWF0K0YIFaO1NKgzCdMnTCuXSSSCalSdMnTUqSSSKBUpKUkkFKSSSQSqEydMgpSdMNE4QUpOEoSR QyCt0qmFbpU8FpdCvRWGqpWVZaVYDGzJUCnLkMuRUs5CKm4oZQSxKA9GcgvQKQ1nIJCO9BKhkzxY QmKkmKhXMUuE6ZJKjymTpJKUklKSCn//083hIyTqlHikBPHKavWSH4p+6U6pKVCeFElOCSipeNJT caJwD2SjcdUlMCEvNTe1rTDTuTSElLBKCp6vhvYKBG0wDKSlQD8Ek0a6JQUlMxrIdwoDQJ0g0lJC hqlCWg0KdpI5SUxiVOWx5pvypOY5v0hCSmPKcDuUgewS07JIXeSTPZRBhOSfkE2qSly6SkBKbckA UlMiZ0KhG2T2SGikHng8IqWEFMn1PCcOaPMpKZBo2l0/IoXJSLZ1+4KUGNAkpjyY8E5MDRIpx+CS mPwUtG6ykA08JtwB0SQsXbiZ7JF3thJxL/ce+qe1xfBgCNNElMIkhPJmToEuNTylKSmddvpS0NDt /wC9+aolhYYcQJHZRJ18kiWnzKSmdbvaQIEhSof6ZBEDTk+5DaYUdpAnt+8kpm2z27SAe/8AKQw6 CCAna0cu/BOCDwICSlO3BsdjyoWAfS7KRBmPBRcElMdpcATwOFOQIg6nlNGuvZJ4YYDBr3lOQkoa 8+1ndXaDJlU6iGkbtW+Ct44E6cKHN8pXhl1An09FkutfMEk6f9Fa2a4BokSCYjyUHUsyC5zYYGt9 oTMPyqlu0x7AHoNtu988KT9/tsdoOyg50mVOsZvdIhQAUnukAKPZJS4SCSceKBUxdqqruVcOqp2D VJLo4v0VeaNVSxOFerWbl3LMGw3hFGiGzhEVY6L2QdCLXYAUBSZypcc6NLSGy9sCfFDTuMqKZm+b RQXThME6gK5dJJJJS6SSSSlJ0kklKSSToKUkkkkpSdMnRUpJJJBSkkkklLpJJJKYlcz1x9nrbHfQ H0V05WN1qsmrcNQDqrPLkCWq2Tger7Nnmtrod7zNZ1bysAwCtTp+Z6Ra0DTur+aFw0DGDq9OCnKr MyGOaHToVN17GjcSI8Vl8Btktm5cv1e1zrSw8D6K37MysDQzPguZzL/VJnsVc5aJErWyaY1Wx0Xf 6un0e6yQO63+h1PALzo3t/KVnmDUCti7rVJRAhSWOysSs7qlQfS7d2WkUK1geCDqCpMcuEgoLwpE FWcXKdjuBHHgpZuKaHkEe2faqq2hU4+DCdCmtvdaZcZTVHVQMK/0podcJEps6jEpGr0OHV6VbWnl WwoNEBTCxZGzbMF0kkkxKkydMklSYp0yKlkySSSlkydJFCyYpymSUsoqRUUQpSZJJFSydMnUsEFS YpcplYC1iUMhEIUCkQpG9Z96v2cKhb3RU5l5VQq3kKmVdhsxHdZMnTJ6EtH0lqVFZVJhy1K1FNfF vzIUUzHaJwmLmQTWHbCQSc3eD5KQIKh4pFM3jVOnIV2TMEDVRf8ARReySmKp3GVcPCpWcpKaF/Kl So38qVKcsLfr4R2+CBWUcJpUGY1S+CblSTCuUE6bhOmpVCeEkyaldJJJBSkkkkFKSCSSCVJk6ZAq VKSSdBCk6ZOkpcKzSVWCs0qeC0t5iO1ArVhoVkLFFRIRYUCIRQiKgUVyGUEoyg2IxQHoFIa1hQC5 HsVZxUUmaK+5KUOU8qAr2UpKMpEpKXlMmlKUlLpJpSSS/wD/1M8GBook7jI4SkfNMCgvXnxS2k6j hOdvzUJKCmYaXGG8qOo0KUmNNEjKKlyCkCmg+KUpKUkfBS3CIAUTJSKlj+CQ8E4bHKWiSloI5RAx pZuc6D+6oJIIUYCkGPLS6NBym0HxRqb/AEjJEjuEVNee6fcnsLXvLmjaP3P3VECSkpk0xqk5z3n3 GSmBTJKVKUhJx7JkkMg2TCThB0THwT7TEjgJJW4TFxPKfRITyEkKmEgAfiltjzTHRJS5AA51TgKK XGiSmQPKXqFogJgJ+CTtre6Kl3ukQofSGnCYn8VMPIMDQpKVt8NAk/0wAGgz+cUpETMQoyAkhcDd p4pnCDtB+ik3xPKltLgY1KSmA51S41OqW7QJbiQR2SUsYJ10TkCJTDnzT7Y5SUxPKLusc0MGjCZP 8oochNJPtnTmElJn1B1Zt3NBGmz95CaZHmk6Oe6aO4PzSUrnRReYUzpx3TBonXlJSOJ+KRkiGjWV MCCZUQ8sdI5KKF266FX8YfgqO6TryVfoIEAc91Fl+Urx0X6iwvZDTBPCobK7WDZoQIeP3loZjN7Q 06TpKoZOLZita6Q5gMbmqPB8qp7sLKyWhrtPJQrZBIPZGIJaHl2rlE+0wDPmrCxZ0HhNtgKT2lqj KSFQmCdIIJU4KlZyrx4VG3QoJdHE4V1uipYn0VfYFnZNyzDZsM4RAhM4RW6qqV7IBSHKZOCnQHqQ Ur+yjKdxkBMll+ZQXCdME6hSukmTpKUnTJ0lKSSTpKUkkEklKTpJIBSkuEkkVLpJk6SlJJJIKXTJ J0lLIN1QtaWO1BRkxCdE0bCHjs7CdivIg7PzXIVbg0Hx7LsLqW2tLHCWlY1/Q/dNTob4FaWPmIyF TYzFzReTXsHMyhuyXFgrJ0BRX9NyWGNs+YUP2fkExsKnHt/1UarttBZHdViSTKvUdMue6HDaPEq/ X0ITL3SPJNOSEOqqJafT8I5BBI9q6SmoVtDW6AJU0NqaGN0ARwFn5spmf6q8ClJ0klWXrFRcFNMi Cp53rdJaRZ+aeyxC3zXbX0NuaWPEgrHd0Fm6Q4wtLBniI1JilFwgOy3Oi4zmuNpGhClX0JrXSXS1 bFVYrAaOAhnzgjhiqMUgCkmhOs47sqkkkkFKTJJJKWSSSKSVkySSKFkkkkVLJkikipZRUlFFSyZO kipQCeEgokqaOgWqlMmSGikjJSihlTJUSpLQ17VSt0VyzUqldomdVOdkBUir2QqRV+GzEd2KZOUy ehnV9JatXCyq/pLUqOijmvi2mIgQqyiqMLlIjEIordApAgsSIKipuUITkKieVJJqc+SCmB4VN4Vt 50VWxFTn38qdKhfyp0IrC3q+EcIFcIwQKmYUlFOEwrl0kkkwpXlJJJBK6ZKe6SClJ0wSQUumSSlB SkkkkErJ0ydNUunTJJwCGQVqlVArdCmgtLerCstCr1lWmqyGMsoQ3IhKG5OUichFEcUIlNSwcgPR nFBegkNawqq4q1YqrxqopM0WBSSSUS9cJ+VEJSgpc6JJJikpeUkpSSU//9XMATgpQO6afuQXrlsC UwMp3Gde6QMpKWGnKU7ipAxwm76pKWGqeAmBClECSkphxwn1TSOUkFLnRMBOqkNDMJHXsipgpTCi RKKC6mHCCSElMPNONTKjAOpTgaaJKUeZTc6papcJIUG/epBs6HRRlL4pKXgJHlMkCkpeDOqW4jRM kRqkpQEDyCRJ7JBxEgd0gSUkLhvclROmqlPmiHG3Dc08fSBRUgnRSkfElP7dO4TExxokpY/GU0Du psa384wPFMQOxlJS2sykG6c6qRqLRuJ57KMwElLH8UpUwNkEaO8VEEd+UkMhXugA+791Re303Frj qOwUrCG6tQYgJKZfSPkkDOoSEECNEgNElLuc9xAdx2SdJEpvMpEePASUtwRPJTgRp3KiPd5JSkpR 9szrCTQTHYJSG9pSH5ElL6N+lr5KHKkA2ZdwoQCZ80lMvI6JnQ1oj6UzP5sJz7jJKgRJ1TkMwJ1V 6ho0MyVTYCWwPjKt0SBI7qHL8pXhJnPa2uXfR7qpaxtTP0pPoEbq2z7tytZu305f9HuqVNbK2zeC Wn6MqPB8qp7oXXzWGRpMqIM8BFyLa2MFdY7zKE126FYWJi4kJiITH2/BJJSoTBScmbyghTgqNv0l fcqF30kkuji/RV5vEKhin2q9Ws3LuWcbNpnCI1DZwiBVjuvZp1EKYRG6GUQAkpO1ACZDINVBScJk lEldOmSSUukE0pSipkkoylKCmSdRlKUqUySTSlKVKZJKMp5SUunUZSlJC6dRlKUqSyTqMpSkpdJN KSSl1EtTpSiEMNiRapppR4ipbapAJJShZUvEJJpSlBTKUlGUpSSukmlKUqQopoSlKUVK2p4Tbkty Sl5TqMpShSWSSiSmlKlMklHdKbclSrZJiVEuTbkaVa5TyoSm3I0q2SRKhuTF4RAJRbIpiVA2NHJ5 UTa0GJEo8JVaQlNKrHMqEkuGiY5lUA7tHcFOEJHoi20mQWZDHu2g6o6XAQm1kkoSJTwpSiQlKjPZ SAhCioEqZQ3+CdakTlTuVuzhU7dUBupzclUitC/RUDytCGzDLdimTpk9DOv6S06tVm1fSWnUo5r4 tmtFQ2cKfCi6r1wJIhFKFUdUVylC1iPJRPilKR0RQyboEyccJkVI7FVsVt4kKpaNJQU0cgEHVToU b3E6HsnoT1hbzEZqFWjNTSpkpKKcJhXLpBNKdNKV5STJ01KkySdAqUkkUkFLFOkmQKlJJJkFLhJM kkplKdRTpKZBWqCqjVboU0Fpb9astKrVqw0qwGNmUNxUiUNycpG4oZUyhlBcwKC9GKC9Aqa71WcA rL1XcoZs0UZCZSKiVEvWSSlRKSmXCUqMpwjSl5STpIKf/9bMThukpoKR8k1eykHkKPkknI0knXwR UoiDA1SGp93ZJpIMhIku1PKSmRshuwcKCce3zlR4SUoBSiUwEJEoKX+KYu+5L4Jw4DkSipjISDe6 QATztOiSFgJ1CdLlMfNJSoTmJhJIGBCClEz8U2iXOqblFTIGFGCpSm3EpKXjRO7XvKiB2SJ18UkL jTzTeaQd4J2+7ukpifBIknhPI4hNJ4RUqAngakpj2hLlBS8iUi4DgQkTooyipful5pNBcYCiB4pK ZOJMCU+709RyobY17qbQWjd4JIRxA15UhAMlJ9rnHc7UlPv2hJS9xDiXAbR2ah+Hgpt2jUidFBzp PkElLmN0BJwk68KPBhOXku2jwSUuXNiCOe6j3mIT6AeacSYB7JKXG0Ak89lBvifuTdj8UwSUpxk6 Ke4AaiUxhs9yUMiT5d0lM2mNE1lu3RsCQnbDdTwotY107jtjUJyGTHuaNDCu09vFU6o2yeVaxxGi iy/KV4bWTJZDIJ7zwsi603Dc9+vDWDyWtkkekRMNPJWfZVUaZaQSPoqPD8qpI31G1rdNrQotaGnT hGtL7Kw0aKvBrME8KdYytMkDsnCH9IoqSFik3lIlMEEsnHRULuVfdwqF3KCm/ifRWgxUMMaK+xZ2 Xcs8dmwzhECGzhGaqxXrqagApp0d0JrNAEOUSzgIaGX5kBdJMnUK5SZxTrN6rlnHrgcu0T4R45cI QSyf1OtryzuNZQD1pgnT4Khj9KstZvJiVY/Yh0G5XPbxR0JWWW0/qzG1tsAknkfupndYra5vdp5/ koB6NIgu0CiehEiN2qAji7q1bjOsUunsB+KTer1GsvPY8Kn+wv5XxT/sSfzvmlwYu6rLd/a1G0GU 7+rUsjXlZv7Ef3cE7ui2OH0hol7eL95Vl0z1SgPDJ5TO6pSyz03GD49lmM6JZyXaotvRS/VroPmh wYr+ZNlujq+PO2Y81JnVaHmA6Fmt6G8EEuB8lJ/RXbpafZ3CPBi7ost9vVqCCSYI/FMzrGO4ckQs 2zolk+1whSq6M9rvfBaj7eKt1WXS/a+PEyVJnVcd7S8O45Cz8jo8geno5Cr6M/f+kPs8kPbxEbqs uqOqUbPU3aDt3Tt6lS5u8O08FjO6LdugEFviiWdDskbD/WS9vF+8qy6berUOBJMR2Tu6pSG750Wc /orwRsdp3lNd0ewkemdO8oe3jvdNl0P2tTs9QEwot6zjuEyVmHpF/wBEkRKR6Nd4hO9rF+8iy6be s0O7kfFTHVKnNLgeOyxT0a/d2I8U46PkTGkInFj/AHlWXX/a9JbuTftijbuBPwWSOjXzGkeKsP6M TAYYPdA48Q6qst0daoLN2s/u/nJftmjbukz+6s0dDtmJEKzV0QCfUMjyQMMQ6qstgdapLC/UEdkx 61X6e8DX93uqJ6HZu+kNqPb0ZryNh2xz/KR4MPdVlsHrNWwuHPghHrlcCAZVY9Cdu+l7U46E6fpa I8GHuqynf1pu2WjWYSf1xoaC0SZghV29DdMOdARq+hta7cXEjwS4cIVZS/tYvDdo1d4rUqeXsDiI J7KlT02ut4fzHAV8BVcnD+iuDkZ/VjjXBrPcB/ONVf8Ablm0uczQ/QK2H4lbi4lol30igHp1JrFR HtU0ZYqAIUbcc9cvLQNAZ1I/dRrOtnQsB+avt6XjgEBuh5U3dOpLBWWy1vCeZYv3Vuriftq/b85l J3WrnFxGgIgD91bY6dSJ9uh5Q/2VjiPZwj7mL91VFymdTudtJMafeqruoXmRvPK6L9n0/u6eCQwK QZ2CQkMuMfoqovOtz79we5x0URlWDd7j7l0/2WuI2iE32Wv90I+/D91XCXljbY9oaSYBU3eqXBwm V04x2DUNEpxU0CAEvvEekVcLyvpWu7FSFVzREGAuo9MJFgS+8+CuF5Zr7K3BwkELpcTIF9Yf37qt 1CsCkuA1CH0RxdU49pTpkThxj5kDQ06pUfiphQKqkL2Map05KjKdEAKU5CcJUjqmKepBZqqlohXH qpaUhupzcjUKgVoXhUHcq/j2YZbsSmTplIhJT9ILTr1WZT9JalAkqOa+LZYpFMAnKiC9hSffCsHh Aa2HSjzKlC1ihudDgplQeJhFCUnRJRHCcoqURIVO0K4FUu5QU59ylQJUb1OhOCwt6tGahV8IrdUC kM0kku6YldJMnTClaVJMkgldMkkgpcpJJpQUpJPCZBSkydMglSSSdBCk6ZP5oqXardCqtVilTQWl 0KyrDSqtastCshjXcUMohCiUUonIZRHKBQSichPRig2IKaz1XeYR38qu8qKTNFgSmlKUyiXqKiVJ IhJTElSCaE8JKpeUkvgkhan/16JbUK+/qdgPoqIDCNdFEg8+KbXsmr1zooxJlONSpQBykpjMpJJS kpRT/kTJIqXLR2SaGx7/AL0tXaSmGh11SQzcByyYCgQQZOpKfSfb8076nMAc6IKRUwTpQkDCCVx4 pWWOsjcdAokpT4ooXGqYnskPJODCSl3MDWB27U/mKP5E8SZTSkpXKcQmASJCSlpjlI66J+U4E88J KWkBKe/ZSJA7SmCSFx8VDjVO4gk7RA8E2vKSkgrY4EudthCA0SdrCXHwRUo6CApQ2ZiExPgmCSlz 4t4UQYUjpokDAgjlJCw8UpnTseyR8AlBBSUrtCjGmqnw0nuojQpJU7QJgBKc68CTOiRkTI45SQsd E3HuS8u/KREx4JKUTr4qRJc7c7lIOACk5+4z9ySkbe/xTMifNO1vjyowWyTokplEgzz2UCNJPZTc 1wAPimEAbRykplsIE8tHJQ9oncdQDwpG54BrBhp+l5qAIbq7hEIZth8kaa/RV2rQgd1Rpa550Bnl XqTqNZlR5PlK4JcwNdUZ4jVZDAHtGkQFr5wLqjWNN2kqhfU2lzKd24tb7i1RYPlTJA87Wt1QSSSt HIZV6Q2iIVCtzTKsLGdehkornTCrh2qISkpclJpSIUQgpk4qlb9JXHFUreUlOnhnRXgs7EOivtKz svzFnjs2mcIgKFXwiBVSvSNKkCohSASukJC8EAeCZRhSQmeI2oKCdMnTEqKwOu62MHfwW8sDrWl9 blY5f51ktnZobFbfgjQoVGWgnwCKopHVIW2pbVJJMtcttCUKSSVopjtS2qSSVqpbaltUkkrUx2pE KSFe4sY5w7CURZUukudyes2PDfT0PJQrOtXPiDHj/KVocvMrLAele4NBJ4CpVdQbdZ6bBI8Vi29X utG0ntBVanIdS7c3QqWPLGjfzI4nsQnhc0/rNpdLdB+6n/bdvqbhAb+6o/u008QeliUoXNnq9rrB BhsroXWBrd54iVFPHKFX+km2F97KG7rDAQTnVen6s+1ZnUnMymG1j9G/mrIDjtjsrGPl+IWfmWk0 9R+0KC3cHaJv2lRs3zp4Llt54KmCI81L92COJ6j7fTt3zoonqVG0unQGIXLCx3EqW4nU8Sl92HdX E9djZNeSCWdlYhYXTjTSDcHGO4W1v3N3N1BEhUskOGVD5V4LIqhnZv2WCBIKxsi7J3mx0tEqnkXu tduJlWcfL3qT6VpNPVYmU3JbuESFYkLjce51bwWlXLsu2SQSG9kJ8ub0UC7WbmDGaDyT2TYGd9on cQIXM23OsdLjJSrudWZaYUn3b01+mjie0Y9rj7TJHKIFy2FXlBzbq9QSunYZAJ57qllx8Bq+JkBt molRttbWNzjAVbEzW5YcWiNphRiJq/0Utbq+U/GrDq+SYVvDt9alryZJGqzuvn9C3+srPSIbitg/ FWJRHtCX6XEtvV0AEoSBTqqvYwmhSSStTGEoTpJKYwmhSUUUKUSpFMUVNXLANTgfBZ/QwWhw8+Fp ZP8ANu+Cy+iEEvPdXMf83JYd3blRckk4KEmwuYpkkkAlZDcYRHIJ1T7UjeqtpVp+qq26J0d0Fp2E Rqs1/KvXqg7laGPZhluxTJ0ykQzq5WpRysurladJghRzXRbqSchIKMbsik7T4pkk9au5JuqRSBhP QpOk4JgZSUudVUtVohVrgkpzr1OlQuOqnQisLfrRQhVowQKQv+KfRMnTClScJkk0pXSTJ5TSpRSS SQSpOmSKClJJJcaIKUmSSQSpJJKEkLp0ySSmQKs0qsFZpU0EFv1Ky1Va1YarIYmai5SUSE5SJyG5 GcguQSjKA9HcgPTSlrWKu8QrD1XcJUcmaKKElKISUNr1gmhSUUrUqU6ZOEFLpJ0kFP8A/9DM1OgT vbsgTKfdAgDXxUUF6481GE6ZJSiU6QCXaUlLHyTnRIQnhp1SKmKcGE+3seVIME7HQfNBTAQOE5M6 kol1dbCBW7dpqhyCIjX95FC7GbjqYCgD4KXwTEx2SSopjBTkkhNBiUkKmOEgUiAkUlLk6JhJTD3f JS+CSlAgc8KKcpwQDqNElLT3URrqnJngQkBrJSUop9eyZMT2SUvAA800zykeISjTQJIX407lI6HR PwoSkpchSB79kh5pnu3Ge57JKYjXRIc+YTwRwkwBo17oqW3aqbX7ONT5qOnJTdkkMyGnjlQ0b5lJ p00UhpqOQkpiCWa90xJ1J5PKk5xc4ucZJSieUlMdpGp7pfFSkCRzPdSqx32yWDjxSUijx7JjroNE Q0vEzy36Sb0yIPjwkpbcAVEAuOqm4bTBSaw8xykpZzo15A7JqS1h3OEz2SIL9ANUi0kDQwkphoJM fAJMOpB4SBkwpk7RtA1J5RQu2wgQ0wTorVXIBVTaK3hpIM92q3SJdJ5UeT5SuCTPBdSWjlVjg1VC sah5Hvd+8rOWf0ZBPzWVW+x5D5Pg1RYPlTJnaWPMMHtHJKrvIc7ThWrqoaAwye6r1s12lWFjEcoq baA6QpEQkpR4TBOmCClOVK3mVecICo26FJLfw+FoMWfh8LQYVn5fmLNHZs18IoQq+EYKoV64UwoB TagEMk6ZOgVLp1FOmpUVgdaEXsd38FvlYHWxF1bgdVY5f51ktncpMsafJFQaSS0E+CMoZbrgunTJ JiV0kkklKSSTpKWlOkkkpSi4SCPFSTFEKaQwKWTDRqqt+DjVNLy0QpdT6gcUhrdSVjZfUbMjTgRB CvYozlRv0scqapZus21jQnRa1PRmuH6QmfJZFLi14cOQVo2dQvD+R8lbnxaCKxoX0nHsLHditzBp xsmqGt1/OB+ksfMyHXvl3ZDxr30vDmGClOMpR34ZqD1NPT6KxAaPmiZRa2l2/wCgBqh4Wa3KnbyO VZtYLGlrhIPKzSSJepkeJ3aQOFNrXbSey1T0l1d081chU8pz4Ia3bXK045AdIsZDTFTnAuaJA5UR KvYBsEgD2H6SBRUbbQ0eKkvdai2GJ7Igrca9wGgVnNa5j9RDZ0RMc2vMs+hOqaZaWmnPY4t0/Bdh VYPRa4aNiVk2dKN128QGHlbTawGBnaIVLmJxlVLw4nUeoNd7GasPJWI/nThb1nR2ssLy6K+dqz86 mr6dJG0aEKxilECorZNKs7TPgtV3UKzSQWieECiik0l1h9yqMaHOgnRSECX+Ahg6CdOEwaTwtPIZ jtomv6Sj062qkF7zzpCXHpdKpbB6i/F9p9zSeF1FbtzQ7iRKzcXEx7Hi+sarUHCzuYlGR0HDL9Jl i5/Wf6M7x0VXoL5re3sCrHWv6MfiFU6A8lj29gZT4j9Sf7yDuz69/NN/rKl03qX2dprcJHIVzrwm lp8HKnhdKGRWLC7Q+Clhw+16/lQbvR1On9VblO9Nwhy1As3C6XXiv9RupiNVpKll4eL0fKyC1Jk6 ZQpWSSTIqUmSKZJSlFSUSnIQZJit3wKyuhM1e5auR/Nu+CyeicvKt4/5uSw7h3VAlOExUJPZctCY qXCiURolG4qB4RCIQigpiVWtCsOQLDpqpIoLmZGioO5V/J1VBw1Wjj2YTuxTJ0ykQzr+ktKrQhZj OVpV8aqOa6Lo9gopMOiQUa9flIp0zzATwhQKRCiCpJ6GWpCgDqnHCZo0lBTI6KvkI5VbIOqKnOu5 RKdAh3cotCcsLdYjBBZwjN4TSoMkkyflMK5dJME6aUqSSSTVKKSSdBKkkpTSmqXSSTJKUkkkglSS ZOghdJMnRUuFZpKrDRWKVLBBb9ZVliq1K01WQxpFAqSiU5CNyC7VFcguSSwKC9FKE5NS13oDgjvV dxUUmaLFRlJMVFS9SXKZOgpSfhMnRUvCSaZSQU//0cz4JhzonAlOAgvURpKZOQ35pigpk3UwmPMF NMJDTVFStAm5TuO4ylB5QUqZSAA0TSlPY8JKXIjnulKRTAfeipf4JpSA1S5QUrzSkqTRKZziTJSU smGkkp5lIjuihdoHfQJNI5TbTEpSkpW4kz3KRM8pc8JtElLyokQU/KXeUlKISKR8Qlr3SQqZSKSU xr3SSoaaJafJMwPs0b805iUkKk8tSE7piSUxMJawipf4puUgnPCSljCbn4J3RGiiB4pIZAwmEn4J cpFJSxG0QEtpATyoie6SmRT7yQGjQBQMwmPgNQkpedIHBTyTqVGfBPPgkplq6SdSkLXQI/3KMbRJ 1SB0SUvuLNSdUjY9o9piVEp3O/NH0QkpgPb5KcueD4KH4pdiZg9gEVM64aOJlWayN2n3qoyRp3Vx kAiEzINCkMssbq3AeCp0Y92KxlzgId9FXsuAwkaiFWra+6lu8jZO0OnVv/W1DgGhTJHZoxziPcSh scCONUa6tte5odIB0KrM4VhYyaIKdw1SaJKIGapIRQkEVzVADVBKzgqF3K0XBUMgapKbeHwtFnis 7D4Wi1Z+b5meOzarOiIChVooVU7r0gCkFEpwUihknTSnTCpSdJJNUolYHW4FjD3C3ysDrgAtY785 WOX+dbLZ2scksbPgjqvjT6bZ5hWAoZ7lcFwkkkmJUnTJ0lKSSSSUukkkkpSRSSSU1cnFrvEPErNv 6TQ1jiJECVtFVcyfReBztMKziySBABWEPI0sNjg1vJMLSzOnejT6gPuHKrdOqNt7QOx1W51Rs4zo V7JkInEBYA43S6BfdrqBytx/TKHtLdoE9wsfou719Pox7l0wUOechLQpAc3C6WcWzeHSPBahCrOz GNJBOg5Rw4OEjgqrMykbK9w+sWW1PBaYYeFjnIeRBMgrV681+4O/M7f1lhrSwAcALFJOLXBu0HRM yws4UOyJS3e7b4qY0tZPtc8Q4yE1V7q+CjOxLR7QOVWtqdUdrhqmiiKS9D0q51xcfzR2Wt2WF0Jp Ac7t4LcJ00WZmFTpkDT6hV61ZY120rAd06wabhr5omVVlWvc4tIBPAVU49zGb3CGhXMMTEaGK2TM YNsxICHbjPrPuSrtdBbyhPeTorAu9VrKtjrDHZW/sIHLwAqQcQi002X6M5Slag7/AEuqukFrXBxO pWqFzeN07JqcLWGHLoWTtE891l5wOK742UNDrABxnfJU+guJa8RoFc6vrjOVDoLz729v+/KWP8yU HdJ17+ab/WVnozR9mEdyVX65rS34o/RyBjADXXVI/wAyP7yurqAJ1EOTqkWQKKSSSClkydMkpYpJ FMUULJinTFFSG/St3wWN0QfpHnuti/VjvgVjdEH6R/jCt4/5uaw7h3QkkE3Krr14TQnJgKMqQIYu KGQiOQ3cJbpROQLNFYdCrWFOigubkKg5aGQFnu5Wjj+ViluxTJJKRau3kLTq4WY3laVXCZPZdFuM doihArRgol6/CTm7wUxKkxSBBRNRJTEQknIWPGikzhMRKlHZBSlUtOpVr4qpZqipoXDVFp0CHfyi 08Jywt1iKEJiIE0pZFOmhPKjKVJJJIFKk6SSapYJykkglSSSSClJJJSgpSSZPKCVkkkkkLynTSkE lMgrFCrAqzSpYILoVhWWqrWVZYrIY0ii4KSg4pyETkEozkIoFciIQnhGKE9BTWslVXFWbFVsKjky hgSmlRlKVEV7OU4UAVIFBTKEikkglZJI6pIqf//Sy48FITwonwT8IL2xUKmibeeyA8tLvZ9HzTHV KRx3SUqUgUwg8pz5oKUCE2pSASSUqFKFECUiUlMhMeSRdIhR/In3CCElKAlMZSlIDVFSjJTQTxwp JwUkKG2NOVEmTokSClACSlEnsEiE+491ElJSt34JhqFJpgyU090lLhNHdKUuUlLFS4UTon80lKie E4EJiZRN5AhFCnOfYSTp4whxrKdzzBAOhSnQBJSnMO3dHtB5TE9uyZz3P05AS1+CSlEjkBIDxCbd 4BScREpKXDg3SJKgUhqpObuAjkJIUox3KUkjyTsbuIEx5pKWiEx1Kk72ugGfAqJBiQkleAD7fmp3 O9Z42NDQBED85CghOJB00KSlFpGhTQQE0E6DmU5kgA8BJC4bu17JSI0SkxHZOQ1uh5SUrTt80M+S dpIcZ4TahJS0ymDw2SRKcDSFA+HYpKStfuO48q1WdRAVaus9lZraGmOCE2eyU2TBqPwWV67fSbW1 sOB1cte0TWZ8FlU0Pc1vqe1rToocHVMl8h/s4jzUaKd6u5TWmnTsqtZIbPirCxdrNphFCG0ojUkK chDQojlAcoKZFZ2SNVpHhZ2VykltYXC0GrNw+FpNWfm+Znjs2a+EUIVfCIAqp3XpE4SCcJEIXUlE KSYpQTpgpJqliVgddjew/nLfWD16A5h/OVjl/nWy2djGn02zzCOFXxZ9Jk+CsBQz+YpC8pBMnlMX LpJk6Kl0kydBS6SZIpKXTEpDzTFEKQvya2yHOAIEwuczuouvf7DDeFPO6de/IcWjcHfnK5idGYyH 2GXDsr8BjxjiJ45MZtL0jF9OvceSj9SaTjP+CuNbCjfWLGFh4IhV/cufEf3k08z0p5baHcNA9y6D 7VWG79w2juues6ZkVSGiR5ITcDJIgNMeCuThHIeLiWahfIy/Utc5v0XFdVTqxseAXO4vSbi8F4Aa DqulaICh5gxoCK4W4XXW2SHD+b/78smrEtuEsbIXY20ttEOEhNXQ2toa0QAlDmeCPDXqUY28tbh3 Vs1boOSqbXFpkLtX1hwIPBXM5nTLKHksBc3sQrGLOJ6SWmKAMyHaAHXhRsxrhq8FSLrzBIdA4Se7 IvJJBKmBr91axxsuygywwuqxb/tFTbYiVzmL0225w3NhveV1FVYraGt0AVPmTA7fOvjbVzcxmM2T q7wXN5eU7IeT27Ba2b0q2/I9QH2H/oq3R0qmk7gJPmjjnDGAb45qIJcvpmM1v6S0geAKo5TW+q7Z 9GdFp9UwLZNlerTy0fmqvhdOttd7xDAdZU8cgozJ/wAFbScYPrYjSwe/n+sssGzGeJlrguwbWAIH AQr8Su8fpBPmq8eZ1Il8i7hc7G6xXtHqfTmFfy8r7NULQJCr19Gpre1zTMSVdupbawscNCo58HEK +X9JIcHqPUvXZ6bB7XCSq/Tc37K4gjQq+egifpmOyiOgju9WRPEI8N+laQbaWX1A5TNjhqDIhNg9 Rfi+wfRJ1V89CaeHKTehVj6TiUePFw8P6KqKAdbtAgRM/wDRXRMdLQfELLq6PQxwdqSFptKp5jA1 wMkb6s0lGUpVZcumTEptyNIXTJSoFyNKZEplA2AakhOCjSkd/wBAz4FY3RR+kf4rZu+iR5LG6MB6 r/FWsf8ANzWHcO2nCQSUAC9Y6pk5UZTlMCoO5RChlAKYOVWxWXaqtYpIoc/I4Wc5aN6z38rQx7MU t2KZJJSrV28rRq4WczlaNXCZPZdFt1oyDWjKJesUQaBDAkonCeEKcoKYPZROichTVJJqikpR4VOx WncKrYUktK5FoQruUWnhPYy3GnujBBYihNKQyCdRUgoylSSXKSBSumSSTVLpFMnQSpJNKSCl0kyS BUpKUkySl0kySClwnUQnCKmQVikqsrNJUkFpb9atMKqVlWWFWQsKVQKlKi7VOQjcguRXIRQXMCgv RShPQU1rFUerT1Vf4qMssUJTJyEgFGV64UgEw0UkErhSUQnTUrJKR1SSQ//TzCU2qkRHCaD2CC9Q A7p2hv53CaU3KClflTSQpaymCSl+dSExidAp7yRBOngoEyUVKBTlMR2Sjugpct7kpvknGp1TljYk Ez4IoYpy2BKkA3k/cowZQSsHIjGsM+oSB2jxQ4hIz3RQuJAgaBRHmVIHXXRNLZ0SUsBCdMn455SC mYcG8gHtBQyncQ3XlLlJChokS2fbKRYRE8FItDZCSlAptUu8J9p57JKWS7pQnJaB5oqY/kUyRG0j XxTaAapvgkpm122NnbuVBznPcXOMkpa9xATQgpctg66Jts88BJ0nlLQa90VKdGkGVGJ5UmCZJTdp KSF+0Jk4E6pVmDJSUs5paJj5panRO5xIInTwS4akpRkd1AgkhIfBS8UlKA1lNBKaJ+Cm0xqOUlLN YOTymcQ50jRMdfc7lKYEJKVwdNSExdPZMD7ZSHmkpWhHmkQyJMhROiT+J7SkpmND7dQVbrYBr3VG uyDKuhwc4EoT2SmyD+hd8EEb3VsuEbGePLnKy922skeCzfXaA1+pA/zPUUGDY/3kyXvsdYC55iey G1pABPfhEcLLaza/uUEOJMHsrCxKNVMKFbgpF0FJCnFQBScoAoKTE6LPySrhOio5BkpJbeHwtJnC zMPhabOFQzfMzR2bLAiwh16qZKqnRezThRCkgTamQTpgnTFLynCSSClisPrxANfj4rdWJ146MHcn lT8v84Wy2dPEn0mT4J8jJZjxv7pYw21NB8Fm9e/m2nwKQiJZKKroN8ZtRcGg6lFryGPMNMlciHOn c3sp42W6mzeFPLldNFvG9jKg+1rDDjCCMhorFjuIkrmsvPdkWTwAdFBjwGZ/urjKnq/WaDBOpRAZ XG2ZDhYHTxC6Pp+cMlmv0gjkwGA4lCVuikmCRKrL1i5KZWH1jPLHGluh5lN0nPc8+k/UnurHsS4e NZxdHbKcLA6vnOD/AEWGIVzpOY7IYQ7Vze6JxSEeNVurKiXBZHUup+j7Kz7hysu/qNlpBB7JQ5eU hajJ6qJSAXM09UtZAJkBbf21r6Dc3gBKeKUVW24TyuUyOpW2v3AwB2UXdRtJ3bipPu0iEcQeuBlO CuRs6ja924Ex4LS6dnW5V4n6Mapk+XlEWkSd2JUS1SCRVYGlyEtCjtA00Wb1l769r2mB4LJt6jZY 6ZhXIYpTFgrCQHqhyphclZn2PMgkLX6d1A3uLHHgaSmzwSAtQIdVxA5US9visfrL3MLXNOnELHsy rHmZ+5HHy5kLtRk9cXsmCRKk2CJC431XHuVu9IvdYHTMBHJgMBdqBt15QXZVbXbCRKw8/qLjZ+jM BqzrLXWOLjMpQ5YnUqMnr2XMcYaQSiFy42u91bg8HULd+1PtwnWD6cIT5cxI1+ZQk36smu4kMMkc pr8hlDdzzAXL4Nz67Rs5cVsdcg1CexROHhmI/ozVbpV2ss+iZ7qORc2hhe7gLH6E/c58nUAQi9cL tjQPo/nJvtfrOBV6NunqVVrmtHL+EfJyBj1mx3AXM9PubXewuHdb3VCBjvnUJ08IjOMf0ZKEkR6x WHQBIjdKPhZzcppI0I5C5ehjnkhvYImFe6m5rm8zEKaXLRo18yOJ6bLym0MknXsse3qtjqwWmDKH 1i5zrdh0A1CBXiWWUmwcBLHhiIgyQZF3sHNbks/lD6QWfl5VlFzwTLXDRUOmvLb2gGJKJ1Vrm3mT oeEhiEZ1+jJXFojsynloErd6Za+ykF/PZAxMGo1NJG6e60WMDRA4UWeca4YhdEFVn0T8Fi9IIF9j VtP4PwWL0kgZD/HVNxfJNR3DuJFKVFQA0vUU0J0inbqYlDIgKZ5USU5SJ/Cr2aq0/hVbE4Ic7IWc 7laWSsx3K0MWzFLdYpkklKtZM5WjSs5nK0qUyey6LZrCLKG1TULIvU4SQiFArPuRipQtY8FJ3KSG 8w4FOQnAgJk8yEggpG9VbB4K25VbEVNG7lFpQrjqjUcJywtxnCJCExFCaUhl2TpgkCo0qTpk8oFK kkydBSkkkyapdJJMkpdJJMgldMkkgpSSbhJBS6dMkihkFYpVYKzUpYILeqVlqq1K0xWAsLNRKmol OUjKE5FchFJSJyE9FKFYmpaz1WerL1WeFHJliiKYJykomRYKSQSQKV1IKKfVBDJJMkgp/9TL+KkH EcaJuUggvX2GN3ZNPgmOiXwQUry7p4I5STFJKkp7pApcooVynGiW2Pio8lBTJpjUJpnXxSOnCQGq KF9ybU90oSJHZJSgI1S7JDwS4SSpLyTBOXEpIZBo78JgQokpccpKZBoJ1KkWtJhh+9Qjw1S14OhS Uv38SmghNECEgUlLxCRSE8qYjvokhgIdqOEjzqiPsk6KAPiipiZSjjxRHEO1AUJASUs9wPjKjOvk FN1hc0NJ0CYgjhJTFziU48FOusvcGyJPioubtJB7GNElLOaW86JSAJKi0ySSpEAhJCpJTQRqUzSA dUiS4pKVGuqcflTkgHxTboSUouLvakAO5hO55MM7DVMGnwklJS+g1KjzymJk69lMHbBhJTGN2vA8 FGZKIWse2To7sFNtpERH3JKQH8Ex1Un8mQogE69klLbSBJTOEN/khSJ1hTtJaNojUJKQMEDVW6tT 7uwVYeB7KywgERwmy2S2rNanE+Cy63h7W1a7Br/1xarvoEniNQsyix3purraPcfpfuqDB+kmSW17 thYTO1AYWhvmiZFb62QTr3VVhkSVZWJ2HXRTKG3QSmDkkM3FDnVMXaeaiDqglI53gqlupRyVXsOq Sm5iHRaTDIWZirSrVDN8zNHZuVlSJQ6yiBVpL12qagFNR2pmE6ipBNSvKdME6ClFYnXjDWDuSttY vXjDGf1lYwfOFktnRw59FgPgqHXRNIPgVfwxFLRzoqHXv5gH+Un4/wCd/wAJB2a3RmB26RqqGfW2 u9zWaCVodC5cqvV9vrafS/OVuJ/WELOjfcWuwCAdI/FYmPX6ljWHuVqHb+zzHPdUOnM33tB8ZRho JlRbvVcNtTW2NEa7Uui1j1N88dle6wxpoO7tws3owm8GdAmCRliNp6vVApFM1OVmdWV5nrml3xCq dOs9O9p81d63HqRGsBZdIJeI5WtiF4qYZbt7rNgddAGoHKu9Ee3Y4D6Q5Wb1J82NB5AElaHRHDa4 RqEJj9VSgdXO6hcy23c0R+8rXT+nsvrL3cqllua61xboJW/0uDQICU5GGMUrcuBl1+jaWcwtnpDm WVOqj4qn1dzRdAGsao/QT9Md03IeLFxJG7Zs6PQeAQufvYK3loMgFdpC5DPc117y0aTCHLZDIkFU g3Ol4LMlrnP5BW5jYdVBlggqh0Ig1OHeVtBV+YnLiIv0roheExUlEqp1XuH1ytzmhwOg5CwA0vMD lb/XKy5oeDo3ssjAE3t1jWVrYDWO2KW7C7Fso+mISxZ3tA5la3V3NNQg6zws/AqFtoHhqniXFAmS 1u9bafa+dOIVHptDbrgHnQdv3le6zUTteOBpCqdLrDrg6Y2psT+q0T1egbiVD80KT2iljiwRAmAk 3KqP5wT2WTWXN10KoXInVe8ja/e4u8St3pVA9CXjkrBsILiYjXhdV04ufjtL+Vdzy4YClo3cLqlD KrYZoe4Vuhrm4TvT1K2H4tb3b3CXDugZdfp0P9MQY7KEZhLhimnmMWxzLWlvMhbPXD+hHxWExxa4 O7grU6hlty2BrNI11VmcbnGS1l0EgPeO8KXXLYLawfih9CgPeDzCh1p7XWbQPcOSo6vMno59Jixs eIXUZrg2lxOui5RvIXTXn9UM6nbynZx6olAc3ohHqOHkqj3GrJJaIIdomwst2K+W6zyi0k5OUHjx kqQggyJ+ThQy6q4uu2nwELXwgXYzR4hY/WNL/kFcrzTj4zBGpUUwTCPCkbqr6Yarm2NOgVLq0i8+ BWjV1L13hoED85ZvVm7byZkFLHxGfr34VHbR1cC+uulrS7jlaTTIlcY0OdoNV03SnPNMWduFDnxc PqtdE9G27hYnS3D7Q8fEhbjlhdMMZTx8UzF8k/7qZbh3JSThMQq69aU0pFMiCpZM5P3TJ8VMHqtZ wrDiqzxypENC/hZj+Vp5OgWY/lX8WzFJgkkkpVrJnK0qNVms5WlQeEyey6LbhSSSUI3XrAQZRCol OpAhYqFjdwCmlE6J6Fx5qSjwnCSlnKrYVZcq1iSmjbyjUHRCt1KNSITlhbTEUIbEQJpSun+KYeCc KNKk6aEggUrpJJggpSeUxSTVLwkkmSUumSSQSpJOmQUskkkkpdJMnQQuFYqVcKxSpoILfqVpiq1K 2zhWAsLMBMQpobinoRvQHIzkFxTUoyhWIpQbEEtaxV3FHsKrOKjkyxYpQmTqIsi8J0wTpqlQnhIa JJKWlJI6pJKf/9XK+KcHskfFJNXqHKXBS1TkHukpYweE6QgHVPpz2SUttLRJ+SYkqRcXwSdBwFEy UlKGqkQAOUtGqJRUoJzymnTzUmVl0xEDXVJTHlSG3SeEx0EqKSF3eITgx31UST2SBHzSUyOiaB25 SEQkkpaO6UQnlNKSVF0cJxJMnlLQHlLU690kKhIaJR80gSkhW/5BMTJhPP3pSI80lLJxIUU4CKlc pRpKXkkkpaCe2qk3dwEu0hIv01SUtugaclMmA0TxOpKSlgCZCccpagJvJJCjojMexjS5zQQdBPZC Y/YZiSk/36uPJ4SUsNJ803HxS50SnXySSuOJSLzKW7WUmkHQ6DxSQxaI18U5JdydE0apcad0lLOO milMJmt3TJ2wnPtSUu5hADieef3lGWkQUzj3KZJSpAkBPt2gEnWVEAz5pi4gQkplX7n+4zqjs0f4 +Cr1w08ozOfNNlslvEj0yD4LKqyIIj6I9xatQt3VkfJUBjUuoMCHs1e6fzVBh/STJhk5G8F/7yrN bMQmad4Ph2R6xtGqsrGDnRoEMuUpkqJ5SUqUycjzUeEFKJQXlFKC7lJLcxCtOtZeItWs6Kjm3ZYt mtECHWihVCvZBSCYJwmkKZJwmCdMUyThRToKUsfrpipojkrYKyeuOikDxKnwfPFbLZuYIilo8lT6 6P0A+Kt9P0oZ30VXrulEeakh/O/4SDs0+hH3O8VX6zs9f28x7kboZ97vGELrO31oHPdWh/PLOidm 12C4D+0qnTGtNwk8aq7SGvwXBvzKpdOa02gO5CN+mana6qGmg7uAsjpjZyGxwtbq4acY7vksfpIn Ib5KPH/NSSd3rWlOUzUis7qyvOdcj1Y7wsyp+wytPrgAtHwWc2kurLxwOVr4f5sMMt0Vjy90lbfR ngtLI7TKw2mCt3o9jXS0DXmUc3yoDkXkeq4jxK6Ppj2vpG3SFzmSR6riNNSuh6U4OoAGkFRZ/kC4 OZ1pwN20DVo1KsdAPuePJC6zaPV2gagaovQfpPQl/Mq6u6uR6iWnIeW6a6/1l1y5LqLg/IfAhRcr 8xTJ2OhvDqiANQdVshY3Q3h1RaBBB1K2QoM/zlfFkolSUSoAlxOt1F7A4cN5C59ri0yF0PW2OcwO BgDkLCpqNrw0d1rcuR7bDLdjbY46OJKvdHDDd7uQPao9QwTTDhqCgYLN9rRMKSVSgaQN3T60wloc OB2WRWS33AwVsdZp3gPBiB9FZuBQ264B5geCZjIENUlCXPed0Fb+Hc84znEagaK/XS1oiBCa4bWO 2+BgKtPKJkClwDx7zLifFdZ0+wvoaXCCuUcZdPnwuqwLHPpBeIPgpeZ+UIi3VVzdxqcGfSjRV87q Ixva3VyDXmvyMd7h9MKrDHLSf6K8l581mY7p7K31/SBClWXOsEfSJWx1hn6AHuCFpGdERP6TE1+h OAscO5CB1axr7TtEEcovRD+lcPEKpnj9O6fFMA/Wkp6NULo6SRhSdYaVzi3enuP2N3iJRzDQf3kB xqqnXP2sElSoc+q0R9IFW+jn9OYGhCDlF1eUTwQ5OMrJj/VUm6y4m0T+6EdmGcnFaT9IfR/qqv1c O9Rpd3atPpxP2cbvkopExhEhIcXEDm3BsxrqjdXbFxPihMZOTtB/ORerMi7Q8hP/AEwf6qnT6bSz 0QRrK0WN2rM6dfXXQBu1HK0K7Wv4PmqGbi4ivizfwsHpziMt3nK3nLB6fpmPHxT8Pyz/ALqpdHeS KSYquvYlMU5TJKWSISTEynxQiegWIz0B6eFNDJKy3crVyOFlv5Whi+ViluwSSSUq1dnK0qTqs1vK 0KimSXRdDkJJMMtlMol7JLhJMnhC/KTdEySehm5ME4O4KJKClnKvarBVe5FTQt5VilVreVZpTljb bwiAobNVP4phSyGqSSSaUrgpJJJpSpLlJJNUpJJIIKUnSTBJKkkkkFK4SS0SQUsUkikgpScJk6KF wrFKAEelSQQXQqCtMVSoq0xWQsKVRcnUHJyEbkB2qM5BcguRFCeiuQnoKa1ndVn8qxYqzyo5MsWM pKJMp5UZZGSkENSlNUzCYpkkEqJSSSSU/wD/1s0apERqohSJPyTV6+7seFFO5p5KiDqkpfdoRHKX Kdz92saeSjMapKZtAHKiY1hMZ7Jp1hFSvl804UgdIKjKSld0plPOqYQkpcuMQPuTRCRmZCQk8pKV tJShJzp07BMNEkLgpSTykeU0E6pKXhLQJbiEiYSUrSUtx+SXCYykpc6jRInsEycCNSUkMSE8ePdP A57pQeUlLGAk37koASEjVJS0jukTHzSHGugSBkSUVK2lIj7k/Ak8JjqkpRg6JydE0KbYkTwkphu0 +CZIw50KVrwY2iISQxjakRDZKeNJnhRnxSUuNUiAPa0z3JT6DjlRkjVJS8CZPCbdI8kx1MpTrokp Q1EJAnkpwe6SSmLpkSfknOuruBwmPikZPCSlzA1KbaGmZ5UiQ1wjWFHVxLj3SUoTPOqg8abuym7b oG/2lB/v0bwkpTXozDrPICE0QI8CrAIIEaDsmy2S2XO9pHchUW+jS3Y6Xkj3f1lfc2WAd4WO5nu5 BkqHF1TJK6ypjIYIIQfU3BWDSyDs101KrVNAGqsLFpSS2yZUiISUsVEpyUggpG4ILuVZcFXeNUkt vEWpWVl4mi1KxKo5t2WOzZrRkKsIqqFeyCkFEJwmlTMJ0wUgmlSk6SdBSlj9d0pEfvLYWT1wH0NP ESpsHzxWy2bHThFDUDrf9G+aN00j0GgJ+oUm6ktHJTweHLZ/eRuHC6Zktx3ku76JdWsZZZLOfFQ/ Zl4jRSb0q5zgCNPFXbhxcfEx+DpYTGnDPgfpLGxnNbcD+aCuoqxhXV6XaIXOZuE/HsMD2H6JUeKY kZD99cQ6vU76nUQTO7Viz+jsa64OcdQdFRfudAIPktfo+A5rxa8RHATpAY8ZF/MoGy9C1IpBOVls rzXXx+mb8E3TqPWosHij9dqlwfHblE6I2anfFaInWIUxEavP2N2OLfArY6I7Utjnus/OoNNzmnid CtLob9SyPOVNlleO0AauXlGbnnjUre6RYHU7RyFS6zjEP9Ro0P0lVrznUsDWaHumEe5AUnZN1mwP uAA1aFZ6B+eFn5OUcjaSNRotzo9JZT7hBKbkPDi4TukbukdVyvVbGuvMCI5XVLk+qODsh2kdioeV +ZMnV6G4GstA1C2gsHoD9HsjzlbwUPMfOUxXTFOkVAFzidcq3MD5jb28VkdOG69omFsdcpL6w4HR vb95Y/T2epeweBlamIj2ixnd1ussJpniCsTFZvtaJjVdF1Wg3U6aEarnsdm6xoJjVHEfQVpDq9ZY S1rp47LP6cxptBcYjVaPWaTta4Hjt4rDktTsfqhVqez9VrdCQE1h0MeC49973kFxJIWx0l9l1pLu AFWlg4PVa4G3HcTvnvK6TCyd9YDjDlT6h09xf6tY/srKte4OjUFTkRyxFI2bnWXMdbIPuj3ImCxz MV72auKzW1WXOgAlxXQNxnUYpYwe+J+aUiIRjC0bvP44cbQG8ytrrU+gPiFkU49zrNAQ6Vu9Vodd jw36TYP9ZLJIccFAOV0d0WuHi1VCx9t2w/SJhaXTMGwBz3DbuaQEHG6feMhu8QAZLv3k/jiDI2qm fUsFtFTXNGoMOKJ024ux7GEfREhauZQbqnMA1PCpYODbQ19biCHDRQjKJQ9XzcSaaHRifV04P0lW z932l27mdFsdNwH4vudyeQoZnTHX2+q10caJwyxEz+7wqotbrFb9jHHURqf5So05j6mFgOhXTvqb YzY/URCzqekMY4l+o/NQhmhw1JVFy8Ib7xJ7qz1eqLNw5I1Wo3p9TXBzRqEZ9LXncRqmnOOISHyq 4dHkwSOFs9GD95L5iNFfGLW0aAIzWhvyQy5hIcICRGmZWJguP2x8cGZWnlZApZKzukN3vfb8kzGK hMlJ3DsplIJFVl7ApinKQRClioFTcoKTqhHYgPGiM8obk4bqc3I4WY/la+SNCsh/Kv4tmKW7ApJJ KZauOVoU8BZw5WhRwmS2XRb1Z0hSQq0UKNeyCjYYUpUS3cCnBChqnUWlSKchk06KPdLdCZuolJS6 rXHVWVVt1KIU0bOVZp4Vez6SsVcJyxtNRAhtRAmFIZJQmTymFKkpSlJAqXSTFKU1K6SSYJKXSSlJ BSkkkk1KkkikUgpZJJJJS/KQSCSSlwrFKrhHpUkFpdCtWWqrWrLFZCwpQouUlFychE5BcjOQXIJR FCejFBsQS1bFWerNhVZ6jkyxRpwlCeFGyLBOkkmqUnTJwkpcJJkklP8A/9fLBB0SAhIFOSmr1HzT 7REpT96aEVL6hIN3fFIJ5brIlJTHjQFI66JRKSSlFh7FKI5TGUtZSUy2k6gaKI15UgY4ScJ1SUsS Et27QJmgnROdNEkKjRMTonnbqmaJ4QSrX5JAeCctI0cITB3gihfcQIUdQnhOeJSUWM/cn8jwlync AANde4SQxCUyfJSZAKJDLXElwa3silDKRJ4TD3cohYWAHxQQjEJDQypToUwMJKWGpKYaaclJOEVK 1iSi7mhsES7xQjqkUlLwNpk6qOp0SmSn50SQvtA07qB0Kk4g6N+aiNDKSWTm7udPJJ3ZIQeeVHnV JC4EnzTHwT7tuoUWiTJSUkdBA7JjG32jVQJ90xoEmmElKIhLnVO4yU7yD9ER4pKYR3KRMnRTLRt0 UNQPNJShonDS7kqIPh3CU9klLcap9wHxhJvgpOMNLgNElI63OGg5KNXIOohBZER3lWSXb/cI7IS2 S3QCWLEad52sGusrbbowysSkOqe4ERP/AFKr4tykpbLDWz0xyeUFrobtRIJ9wGiE3XVWVjMmFAmd E+xx1TsbKSmMQpAIhCW1BSJwVawaq8QqdwhJLYxCtSswFlYhWkxUs27LHZvVcKaHTwiKtJeuFIKK kFCpmFIKAUwgpdSCipJKWhVc2r1qnM8Rorag4SjE0QUFwOlZYqmt/itoWNPflZOb0txcbKtCeQs9 7726OB0Vw445DxRKwGtC9MCDxCdsdly7cy1k86qQzrAzbJ5Q+7y7q4g9TKg5gdoVzp6nZ7YPHKmz qT/V3E6JvsTGqeIO2aGeA0R2t2rn6uqPG6T8FJnV7NpJ57JHDMqsPQgp5XPftuzbEe7xUj1pxZoP cmfd59k8QduxjXiDwo1UsqEMEDwWQ/rRaBAEnlTs61tcBGh5R9rJVKsOldj12iHiUqcdlIhgACzn dbZu9o9qb9ttDvo6Je3k2/RRYdZ9bXiHcFZ+R0mm36I2kcQg/ttu4e32qZ6zWHR+b4oxhkjso0no 6bTVGkkd1faAFl09WrsdEQnZ1qokg6QhKGSW6bDqkqlkdOpvducNfFAr6xU8wdPNN+2aw4tPA7ps YZInRRIb1GOygQwQrMrJq6zS8wdEzetVGQRxwlLFMmyFAh15SJWXV1Vj2l0ahDZ1qtzC4iD4Jnsy 7J4g6F9DLhDxIQ68Oqtwc1sEd1Vq6s2xpdER2Sp6tXcSIIgSpODIBXRFh0HMDhB4VZ3T6XODyII8 FWb1dri4Rwmq6yxw9whEQyDZFh0LaG2iHiUJ2HU6JaNFSr6xucQR7Rwmr6xv3DbxqERDINlaN/7J VM7RKKytrOABKxm9cMGW69kw624j6OqJxZCqw7hAKC/HredxaJCyD1l4Zx7lJnV3+nucNfFD2phV h2AwDspQFz37au2kd+xUf2vbsjv4o+xPqiw9HtHgkuaf1a5wGseKVvVLHPa4HQco/d5p4g9JCYkD WVzI6ja1xIOhQTlvLS2TqZThy56lHE9YXDiVA2NiZELlnX2v1E6aFM1l7vaAfFL7t3krieodkVt5 cEP7ZVIAdyuZdVdyQdVLZcAHbTonfd4/vK4noD1CoSCdWqD+o1NjzWCabSZIOqO3p17hwj7MBvJH EXTPVGaiOEB3V/boNVVPS79OERnR3n6RR4MQ6qsru6s4nRAPUbDInnhXq+kMA9xJR6+nVNiBqhx4 oqqTkMNuWdvgt3ExxQwNCIylreAiwoMmXi9MfTBfGNbqSKSYlQLmJTJyoyiFKcVEqUpipFIXIL0Z wQXcIhDRvOiyn8rWuHdZVvK0MWzFJgmSSUy1Q5WhTws9vKv1JstkxbdfKMEKtGULIsVJmij3hETw gsCISUzqFAeCchiVIDRLlOSkpiVVsKtOMBVHhFTUs5VmpV7OVYq4RWNlimFBqnxymlLJJIeCSYld JKUvggUrpgkl8E1Sk6UpJKUkkmQUukklKCVJJk8oKWTpkkFLpJJSkpcI9SAEepSwWlvVlWmKtUFa YrIWFImKcKLinIRPQXIrkFyCUZQXoxQnoJar1WfyrL1Xco5MsWCcJJwoiyKShOEk1LFMnKaUQpeU kySSH//Qy3ED6PKYIgdtMjXyTF06lNXsR4J5Lfml8EvikpdID7kvNNp2RUop5jVRRGuI44SUx2gi I1lI8+2UY3DcHNaBAhCe9z3bnclJDHVIiDryEonlLa2CSdfJJLLRRIKYjwTw0iDOiSGPPCdpKXAT apKZOeXHVJRgBOCO6SlbZ0A1TEePZE9QlDcSUlKCR18k8JkkLJ9AIS+KTTCSVDzTSTOqfjlOATJ7 JKUyBqUxglPGkpu8JIVA8Uo7BMTBTwZRUtKREnyUnKEydEFK2mEpTz3S1dyipYcaJuOU+kJfFJS8 yFEg8KYbugKLudUkMXDVO6N0DQKTdIJ1UBz+VJK7nEiPBMT4JE6+SUJKWJ8Ej4DVSDTMd03GqSmR dtBjlD8yn0A80wISQyAgbuyh3UyDpKYmTJ1SUrSRt/1Kg5zg0xwiNEanRIAuknjlJSKsCAAj6B0D 3DxVdnPkrDT2bwmy2S3Wk7T4LKLS55e7QcBajXEtjsVl2Mm4zIHYqDFuUyTUvDmua7hV2kAcKxqP YB2koNdZIM8KysWDiiMCC3mFYYElLkKKIU0IKYEKpeFeIVLISUyxVpMWZirSrVLNuyx2btRRAg1I oVUr2cpwoKUqMpSAqQQg5TlNUkCdQ3JwUSpkE6iCnQUxc2VA1AiCipIgkIprHGYewQndPqJnaJV5 JEZJd1UHJd0eoyQEL9jNbqHStuEoTxnn3Rwhwj0XWQ5S/YjZ1cVt7QnhH7xPurhDjDolc8lFb0mt oLfzStSAnhA55nqrhDi/sSvXUqA6EyNXGey3YS2o/eJ91cIcNvQ2AauJKX7DbH0jK3IShL7xPurh DgfsPT6aT+haex0FdBtTbUfvM1cIefHRXtEtfr8EzuhWRo7X4Lodqfal95mrhDzw6I4Qd0+Ke7oh JlhgeC6DaltS+8S3VwvOu6E4cO+KTuhvHD/iui2pbUfvM0cLzp6La36D/ipO6I6PadV0G1LaEPvM k8Lzp6LYPovHml+xbRw5dFtS2o/eZI4Xnj0SwcPHmpjokEHdI7re2pbUPvMk8Lgu6IT9F0BSPQ2/ muI8VubUoS+8T7q4Q4buhVngkJz0OuZBIC2oTwh94n3VwhyHdGqdHYBHHTqw3ZHtV+E8JhzSPVPC HLPSKCZ2qX7Lomdq0oShL3pnqrhDl/sjHmdqm3pdDfzVoQlCPvT7q4Q0/sFIEbQnGJW0yGhW4TJp yy7qpAKGjgAKXpDwRYSQ4yqkJqHgm2BFKSXEVUi9MJbAiJtEuIpphtS2qZTJWpjEJJEppSUpIpiV A2Ad0QFMkxQ22teYBkqTnACUaKlEqJKHTeLQdvYwq2bkemNE+MCTSCW5KRKzMXMLyAe60ZT5QMN0 A2weUJ3giHQob0Alp3cQsi3la9/CyLeVfw7MUkaSSSnWrt5V+pUGcrQp1TJbLotpiKShtUiVEGRk 3UqZQazLkcqQLVmnsmKZIlFC7QmOqmOFAoqYP4VZ6sv4VZ6Smo/lWalWdyrNXCKwtlqn3UG8KYCa UhkEk3CdNSpJIpJql+UkphMglRSSSQUukmCSClJJJFBK8pkySSl5SlMkgpdPKinSAQuCrFPKrhHp 0KkgguhWVbYqlatNKshYUqi7RLcoEpyEbkEorkNyC5GUF5RShPQU13qu5WH8oLlFJmiiKQ1TlMol 68pFKUyClcJiFIQkkljCSnCSSH//0cwD8EpTHTQJRpPJQXq7Jj4pDVPCClCSUpgwkG7kjoipkJKR JHtSDi07gme7e7d4pKUUyUhupSJJMnhJTIugGDyoiOybunGnCSl0xM6JpKc8JIVJ7JjB1TSn0SSv oVEFODom4SQoafBS4UY1TwUlK44ThN8EwCSl5SPikmKSlJApdtU/PCKlki1PwkXJIWgBSBkpNbOi RhJTE6pDhIamUxnsgpdMTqlPY8JcoqUTroEtwSgJQkpYujhIiNApAaymLp7JIW+KZzY0TwOSmKSV TAj70oj4J48TomY0v0/KkpRJlOwGwwPxSIhIOMbQkhZwAMJkxJI0UohJKp7eKT2bGgzqeyXBhJ7C 0gnukhYax4pny8uB0I4CkAomWHU+5JTFkASeVOrXQJmt1k/FSY7c7wQKW2HCI7rLtvNlkDsdFpAE wAgiqjdLj75lQY9CUlAanMJ3GNNyG23uVbzLWEuEdtCqLGgt81YWMuSrDCgMKKElJfNMmCcIIXMw qOV4K85UclJKsQrUrGiy8SQtWswFTzbssdmzUUWUFhRQqcmRkEiYCSi/hM6qc9ufN23twrmXlChu 7xXPTtuMeK0OpumlvirhxR4o/wBZjEjTfxc4XO2q694YJJ0C53pRi2StXqZ/QOUWTEBMRH6SQdE1 Wax/CtyuRxsgsInhdRS/ewO8QhlxcCom1faGameOVL1miCToVz2Xc4vIZoJ9yEcxxgeCeOXJFq4n qPUExKmCuVOe/wBXeDougrvBqFh4hR5MJikSttbo5S3Sucy+pOc72mNUv2m9rgQUvu8qtXE9KClK p4mWMhm7uhZ/UBiwDqSFF7ZJ4f0k26Mp5WXgdR+0na7lWMzK+zM3pHGRLh/SVbclPKzcfqbL3Bo5 KvOeAJPAQMCNCm0kppWW/q9YcGt1UX9YDLNpGninDDLsi3YlJApvbaNzTopufAkpnCQaTbOU6oN6 lSXFpOoVtlgcJGoKRgRuFWkTqvZksrMOMFKrJbdq3VLhNWq06dBsubWJcYCrM6nQ520FEQJ1pVt9 NKE60ASToqo6lSSRPCQgTsEW35SlZzOqVWEtB4Ts6lU/yIR9qXZVugnWczqtDtJhXmvDhI4KbKBj uE2zlMq9+UygS/QKq3q1RJCcMZIsBFukkq2PktvBLeysAphBGhSukkkglSaYSUHugJAWhlKaVg29 ccCWgcFDf1x8iOFZHLzPRbxB6KUpWZ07POVuLu3ZU7uqvZcWdp0TRglZH7qeJ35TEqLDIB8QqnUb jVS5wOoUcYEnhTbaLh3KQfPdcg/PtceVd6PlON21xkOCsnlSI2s43fdYG8mFWszq2Dd24WT1TMLr Ng/NMKjY922OydDlrAJUZPVV3NtEs1Cp5XURS4t7rK6Zl+k8NJ0J1T5eHdba4xpOhRGACVS+VHFo ns6we3zQXdUfyOFm21mtxa7kLQxMD16g46aqwcWOIsreIuk7LBxt86nRZDcpxOpV7KoFGMWeaodO rFlu13EJmOMQJS6JJK1WW+mzctvKt3UF7O4kLEz6BTZA4Wk7+h6eCWSMTwyCgSi6Q4kuPZVcl5uu 2+cI3SOXHyQah+taeKfQE5H92KOjGys41gC3WmQCquXii0g9wVbYIEKvlmJgfvL4imJQXor0F0qI LmtdwVkWjVa1okGFk28q/h2Y5IkydJTrF28rRoWczlaNHZMlsui2wE5ShOVEF7Bmj0cocKYKkCFi oOMFT5ULBICchKSoqIKlqkpi7hVrCrLlWs7pKajvpKxVwq7jqrNScsbLVJRapphSpPKZJNSukkkm qUUh5JcJBBKkkpSSUqUkkk1SySSdJSk3KSRQSpJMnQQpOmToqXCNSUAKxUJUkEFvVGVaaq1StMVg LGcJiIUgmcnItC5CKM5BcguRlCeilCegprOQXFFegkqKTNFimhJLhRFesnSThJS4TwkFIaJpUtCS kAkkp//Sy0oSmEp+5BeqB3SjwTCZSSUqeyeD30Ui2Aokk86lJS0fcnSAhImUlKmEjqmSn5JIXhMU /GqYDuklRASAJ8kgdCnPlqkpXPKZP5JikhRSSTiIkpKWCkYgjuUwA47lM5pAk90lKmE0yl5lPwkp cGNFE+CQ1TuiY8UlKkJAwmOnwTc68BJS8RwlGvmm1nVPz8UUL/NNEJRCQ+CSlwmcY1TSQn2kpKZS SI08VHT5pARqm3JKWICdwgBIamT9yTRPOqSlHThRJIEKRJJTRpKSlgAeEgJTkk8cJCPkkpURwmJJ RGNmSOEMDxSQoDw5TTponHumNEjxp2/FJSo26BNJnXhIiE30kksm+6dqaVLtAURAMpIWnVM5m3Q8 pwddU9j93PKSl2GBoZCk1sulBaZMDSURpIdr46oFIbDJnXRUGtebiQJE8q+AS4Rx5qpflwSxogzy oce5UUl1JL2yZkSq7q/T0R8YkS488ShWsAcADKnWo2jXyVjaosYiSkhYJ0kwQUuVSyFeKpZCSVsb QrTYszGGq0q1Tz7ssdmzWjoFfKMFTkyMwmfwnCZyYN1PMXnbc4jxVnMdupYq+WIudHio2vLmDwC1 gL4SwNjpzgLRK1erE+gQPHVY3T3Rc2fFa3WXEUiPFQZB+tikHRwWjVdTgkGkQVyocul6SR6UTqjz Q9Npju2HYzNdOeVy+QzbY5o4BK7A6rkszS9480zlZEkgqmHQwumNewOs7qx1EGnH2sEBW8EH0W7v BC6sD9ncR2UfGZZAD8vEmtHm6a3XvDRyVZzMF2O0OPHCbp7mttBctnqFRyKIZzyrU8nDID9BbWjQ 6NafV29kXrsS3xTdLwbK7A94gJ+vnRijsHMKT0R9EeBYQeTwr/VnhtUmCs3orw2yI1KvdcMUD4ps x+uCgdHL6a53rjb4rX6va9tQ2cH6SxOnucLhtWr1j1A0Fv0fzk/IP1kVA6ONTW65+1vKnk41mO73 cdii9MsLLh5rczaW2Uu3aiJT55OGQFelFW4vT891Dg380nVdJfDqyOxHK5Chm54HaV1drR6JB+jt UOeI4gQuF08o87XETMFdT0536uz4LkyNYC6np2lDQn8wPSEAuT1e95u28AcFWOiZBLjX2iSqfV7X G3a4aDhG6ISLSI7alIxHtbKvV0OrAPqkmIXO1mXiTAldF1Wtr6fcYjULnKWhzwHGBOqOD5Co7vV5 FXq0bGnt7SuXfXY0kFplddW0bQBwBondWO6r483ASK4kkW8ZuLT4FSa5zjA1R+ptIyHSIHZH6NWH 3ajgaK8ZDh41lMcbp9tx1BAXT1N2MDfAJ2tHZSOizMmU5CyAU5HWSHNAOhGoXPb9VqdbefVAPACy FoYI1BZIu90XIl3p+S32rlOlWNrtBd8l1TVR5mNT0ZIlkkkkqq5ZVc0F9Tg0wY5VoqrmtL6nAGJC kx/MEF410gmeVfq6VbYA7QAiVQj3QfFdjW0Na0eAC082QwApiAtoYXTvsri4umRCwnti3aT35XXk aFcfY0esWk6blHgmZ8RKSKewqgMaOQAFR6yf1c/FXqhDGgcQIVDrInHPkVVx/wA4P7y/o5HTsVmS 4h3YLbpxK6foiCszoTgHPaeSFtkqfPKXFX6KyIeWzgftDh5rcbjNdQAQPorCzG7b3DnVdPUJrbPg n5ZcMYUoB5rGqAc1/MP2kLpy1DZiMZwI1n5o5EBQZcvGRS4CnmeraXRxotTpeuO2VndY/nfktHpR mgTpCnyH9VFaN2XU49EysnpdgbZB7rW6kQKHT3XONdtIIRwDigQqWhb3VSDZIKvPbtxNPBYxs3ul +q3L4diy3iNEZjhEIoDR6To9wPgmqaDfp4pdKHucfJDxzGTHmpDvL+6jo7sBJRc8NElONVnkMzF/ CA5HegOTgpq2mAsm3la12gMrIt5V7DsxyRpk6ZTrGTeVfqWe3lX6jomy2SHQHCccpmatTtUTIuUw UoUU4IXKQTeaUpwQsRCkk5NKSFiq1qtQq1yQS0ncq1VwqrvpK1UnLGy1SCi1SlMKV0kkoTUqSSTo JUkEk0IKUkkkgpdMkkhSld06ZJBS6ZOmSUpJMkgpcJJJBFTIKxVyq4R6lJBBb9atMVSsq0wqwFhS jRMSkEinIROQXIrkJyC5G4oL0VyE9Aqaz0JyM9BcopM0WBShOUlEvVCdJSQUsFJME6apcJJSkkp/ /9PKieUvJLUaJ2hBesAnCR8EwSUu5xKjr3TxronHikpjzopQSojlTDtvHKSmPxSlKfFLkJKUnJ0U mVh5GsIj6G1675SQ1xrqVPgwonThKCEkqJnVOSWpcJ5nU9klMdU+3SfBS1PujRRJnQJIWAAE+KQ8 Sl21S7JKW80tsnVOD4p3H93nukpiBB15Tw3ulE690xEpKXjwSDeZKfU8cKEF3kEkMy4uSadvChIS 2zKKl086aKISJngQgpfcmmeU8kFLUa8koqVunngJgQYKcjsmSUokdkifPVIAclNqeOElLnXVLQ6e CUBuqiUkMgYCaO6YkwnlJKx10TR3RLAAYCifBJSo0TRrHZN2SJ7JKZHnnRR4CbnTsnPlwkhd0ASd fJQ1UuCnLhCSlRAnxUSA0ylEp7WCJb9ySl6Xw/fEx2TMOpA8VFmmhUmEIFIbJ0cPNVbWBjy4RorY EwSqN7SXlz/oTwoMZ9RSdkxs3NDAdAJVat0mVOhk+46ApViJ+KsLEhKYFNuSaZRQzKZSKiUFLlUs g6K4Toqd6CVYp1WmxZmNytNip592WOzZr5RkGvRGlU5LwyCRSCR1TOqXncoTe4KryYV9+uUQqrG/ pY81rQOg/usBS4rfTuAV/rTyWNb4lUn+3KgeKtdYsgtb81HIXkiUjZoOx9tO88ytfox9pHjqsV1h c3b2C0eiu95HkjmBMDahu75XJZ4jJd8V1q5TqP8ASXHzVblfmK6T0WBPot3It9QsYWHg8oWACKRO qtKvM1PRcNnkMvFdi2Ea7fzStLpmbPssOnZaOXityG7XfJczYx+M/aeQr0SM0aP84xn0l69oCxuv jRisdOzhYNrzrwFX68Paw95UGKJjkAK4nRrdGfFu3xV/rn8wPis7o79t0eK0utfzHzU0/wCeCBs4 mECbm7eZW91Sp1lPt7alYOECbmhvMrrYkQhzEuGcSqLyFFnpvBXRUZTbfZ2VDqPTNv6Sr+0Fm1Xu rkDSU+QGUcUfmRs9QzFqjRo8US9o9JzT9GNVQwM4Oio+HK0LoLHbuI1VMiQlUl7xzmw4gdiukwHi vHbuMLmnaOMcSrDshxqDfBaGSBmAFls+o5Pr2acDhWuiE+oQB25WTK1uiuPqR2QyR4cdKBst7q7A +nUwRqPNYGOxrrAHmAVv9YaDRryDosChoc9odxKZh/myk7vZVABoA4jRTKhVG0RxCm5Zx+Ze8r1c u9cg/JF6FPrEeIQurucbyHcDhF6H/PEeS0j/ADP+Cs6vStSck1QudDSfALMGpZHl+qF7rjv/ALKz 1ayLnXOlysV4jTjOtcNfzStiB4Yi2E7oMIsbYHP4C66syAfJcVW4AyeAuxxXbq2nnRVObGxXxbKS QSVBlWKq5rS+lzZgwrZVPOYX1OAMacp2P5gtLxx0K3cfqwFYBGoACw3CDCLXi3PEsaVr5IRkBxMN 09Nj5IyWF407FcuWD1dp43LoOm4zsekh/J1KwXtaLiPzdyhwgAzEflXF66oANAHhoqXVgDQZV2qN jY4jRUur/wBHcqkP5wf3l/R5uq11LtzTBWz03LdfadxkRwsrExTkvLQYgStrE6c3HfvBkq7mMOvz sYtxcsbb3fFdVUZY0+IC5bNaG3OAM6rpsc/omT4BRcx8sV0d06YqmeoVideFamRPYqnwkbr3nesE +rHktDo5Poa+OiodZJNuvhor/SCTRr4q7k/mQxj5kvUP5l0rnKKja8MC6TqB/QOWJ0ts3aI4DWMl Ut2vdWanlp7LZcZw9PBZ/VI9bTw1V8Hdhz5J+Q2ISQGp0mNzvGEKofrOnii9JA3uHeECw7MgnwKd vKQ/qq6Oh1GwtgBXadWCeYWRkXC9zYWvWNoA8lXyRqI7rhus9CcjO1QHKEL2tfwse3la93CyrRqr +HZjkgSTkJlOsXbyr1PCohXaU2SQ3qzpCmzlBrKO1Rr2fKZwThM/QIhSyZM0ynTwgshwok66J2mE 3KSl1XuVhVbUgppke5W61VPKs18IrGyxSUGlTCaUrlIJpSlMSySTJ0ClaUk6SClkkkkCpSdJKEFL Jd0k8IJWSTpoSUpLlKEkFKSKdKEghQR6kABWKeVLFBb1SssVapWWqwFhSgqJTpjwnIRuQnIrkJyC UTkJyMUJyakIHoJCO5DKikyxRx96aESFEhQr2MJ0k4SSsnISSQUsknSRU//Uy9fkkYKjMcpBwHmU GRn8SmPiEycacJIWJTtPimOqc6iUlKgEydExGklLamnt2SUvqlMJaQkAkpkHeCYgj+CW6UtTMpIW I1TkzoFHnVLnRJS+oKRJ5OqR8ko+5JSpnTsnaSwSOSmIATRrISUu1o5KUnxTwD3UZA5SUuApB3YK MyEtBoElLkgfFQhP2T7CBPdJS2vyUidPNRmeCn4SUxA115TwPmk0AFLWUUKKcu7nlRj5pQe33JKU O5lO1MfA6JEwkpk4yYCaAB5lNOhJUeSkpRI7pSpFuiTWAmElLTOqWsynIAOiaCkpUJydvxTTHHKd rC88wkhjrM9k+5M53ZPt7jskpW0lICNT3T7zMjwTTGpKSmM+CcjunmeEnJKWaJMJE+2IHKUToOUi DKSmIU32EkO8FAQT5J2sL2mOQipasuLpbynZ4KFeoIU2iOOE0rg3Q0uhU7QwZEO9wHK0Gj2hZ9rf Uu1dDVXxfMVSRssgpgdJUiQ07GmfNMYb7QrKxflP3UCYUydUkMpUSpHhRjxSUonRU71cKqXoJXxl pMCzccLSZwqmfdljs2auUeFXqOqPOqpleySOqScqNLiH+llCa2co+RV/7M77R6h4UPQIyd0aFXhM V/1Nipq5A25mnOil1eyXNb5KWdW4ZQcBzCh1Vv6Zs+GqkiQTE/1UFrsw7HM9QcI/S3EWgBbVdUVB vksHFaa8jb4FD3OOMwqqIepXLdTB+0uK6kcLmOrCMg+Kg5bSZXS2dzpwPotlLqFzqatzfHVLpwil qj1Ss2UEN5GqioHJr+8no1cLLfkWkE+0BE6niNtYXd2jRY2Dkmh4PZbeRm1CqZ1I0U8oGEwYoBsO BjPNVg+K1OtndWw+KyanE2B3eVsdYafSYfDlTz/nIFaNml0h+26ImVq9ZP6ufisbp1wqtB7FbHVT vxztUeQfrYqGzhYYJuaB4rq3XNr+kYXK4bC+0AeK0uty3Z4cI5occ4xUDTpUZbMklo7LJ6n0/wBP 9LWNO4S6MP0m6e3C3LQHNM6iFF/MzqPyrtw8tj3+m4fFdI29t1JePokQVyz9oedv0Z0XQYRY7GMf R7qXPEGpdUB5+0AOIbxOi0MLp7circ4ka6LPsIDzt4nRdF0lv6uPipMsjGAIQ89kUGh5Yey0uiuI s2hB6u1wvO7jsj9FDvUmPbCUzeK1Dd0eqNa6gh3jp8VztDAbAHcSuj6ntFHv+XxXOsaPUAJ9qjwH 0FJevojY2OIRSh0xsbt4jREcs8/MveX6yXG6Dx+apdD/AJ8jyTdYLhaZGn5ql0X+ePwWif5n/BWd XpAg5NjWMJdxwjAyqPU3sFe1/fhZ8BcmR5eyA4gcSijJfsLOyC4aqzVg2vEgLYNAC2FqBdX0vd6D dx+C5UgtMHkLoujBwrJJkHhV+aFwXRdgKSiE6ymVRVPNbuqcCY05VsqrmND6nNJgEcp+P5ggvIbP ft8+V1tFYawAcALk2sl+3zXWV2Na0NkcBX+ZJqNMcUjmiD4QuQftFx/d3Lri8GRI+C5F+31TH0dy HLfpKk9dXG0RxGip9VE47lP7ZWwNHjoFW6he23HcWngwVDGJEwf6y69Gn0ON7gfBbq5zpeU3Hed3 DlqM6kx+neYClzwkZ30QC4vUWBt7gODqugxHn0GE8wsbq9JZabPzXflUMfPcys1/5qllAzhGkXRR 3W/piW8TwunYZYDxoubwaftFocexldNGih5ggcMR80Uxef6yT6oHaNFc6KD6J+Kqdaa4Wgn6Me1X ukVllPu7nRPmf1IQPmTZ520krF6WYvhbuY1zqnBvKysDEfVbvcIEJuMgY5BMhqg6uB6vnCu1+7Dn yRM7CGQQeCO/krLagGbeyRyDhiP3VVq5HSB7yUuoYzjZvaNCtSqhtf0QpuYHIe96+IK4dHIw8d26 XdlsEaKIrA1UzwhPJxrhGkZQXhHIQXqMJaV6zLOVq38LLtGqv4dmOSAqKkVFTrFxyrtKpDlXauE0 pDbrVgKvWrAUbIvKaZ0TkpmhELWAEaKSdw7puycFMSpBMBKkihiVVs8Vadwqr0glrH6StV+SrHlW a0ViccKXwUAVMJpSukEtEh5JpSvCSSUJqV0kkkFLJwkkgpSdJJNSslwnSSUpKEkkFLJ0iEkFKhPC SSKlI1RQkarlPitLdrVlirVq0xWgsLMBIpwmKchE5BcjOQnIJRlCeiFDcmpQuUFNyGVFJmixSTpQ oV7FKE8JJKUlCSSSlQkkkgp//9XJjxTg6eSjHhwpeZTWRaD3SBA45TTPCQJb8UVL6904M6dk0gfF KSOUkLuABgGUxd2CQICkEFMWgu50TwefwUp7JIqWifim40UuEi2GzOvgkpgGwkdYTmT5BOAO6Slu E0nkqTnBxSSQxOnxUhuIPgm4Pmk46eCSmPkpaD5JBpOgSlJS4k6BM06pt06JRPCSlfBS1cdSoifv Tu0EBFSx0MJ0tE2qSlxASPMKIBiOU6CF3CDISEu1GibnROXGPJFTEnxTiJkqM9ynKSmUjjsmkfJR GqX5UlK1OnCeAFESRI+9LjjlJTIuB0A47pgCUmtngqTXBoI7lJTGUjppKRTTGqSlxHdJwA0KnS1v NmrfJC7pIUNRon1OiafwU9vt3E/3pKYgwowQlJhOUkr7YHOqYnsEhJTTHxSQvunlJpnQclQmeFJr 9nCSlnEN07p2mYCVbdx1U/ztPFA7JDotENhUcp4rd7ANNFfB0gcQs24AWkFskKthPqKZbLCprGh5 d7nnjwQw0AnVKxlklxEAGEKY5VpY2DBMqE6pi5M0JISSkkmSSoqrcrRVW3lBTKhaFZWfSFfrVXPu yRbNaOFXr5VgFUpMgZhSUApBRpXDUgwKQUglakTqWkyQoWYrbCC4TCspwjxEbIpiGQIWfZ04G31G 6GZK00oQjMx2VQKwCyep4JtcH1j3d1sAJiE6GQwPEFEWgw6jVUGHkIr27hCmAnTJSs2oB5fqWA6p 5sYPaeVnuc50Su0fUHaFBOGwxIGiuQ5qhUgsMHI6Z00gi2z+yFrZdPqVFo5I0VlrAFItUE8xlLiX CLxbqXVuII1ajuzXOp9I/JdHbitsBkciFnN6HXOpJVsZ4SFy+aKzhI2aHSqDZaHfmha3VMR2RX7O W6/FXcfHbS3a0QEYtlV557nxD9FcI6PG12updpoe6u5HU3ubtB7arWy+mV5BmId4hUn9DEjaYHdW Blxzoy+ZbRDj1s3uA8SunrqZVSRENjVNjdMrpMjlXXVgiO0KLLmEiAPlSIvGWBu8lv0Z0XSdKg47 YVJ3Qz6kg+yeFs0UCpu1ugTs2WMogAqALzvWQ71vdxHtROil/qkD6MarQzunOyXh26B4Jun9OfjP JJkInLH2uH9JVapepNYaSLOFzLANwniV1+TjNyK/TdwVj19Ddv8Ac72/wQw5YiJBKiC7ePHpt28R oilRqYGNDRwOFMhUpHVe8x1gv9WHfR/NT9F/n/ktLN6ccl8kwB2Uen9OONYXEz2V33Y+1w/pLK1d QcLL6wGljQ4weQtWFn9RwXZUAGIVbEQJAlcRo89h1Cy4NdxK6oVhoiNAs3p/TH0Wb36rY2qbPkuW h9MUAPJ9SoNVxng+4K70Kwl7mniFoZvTmZTtzuQFDp3TTivLiZnhPlmjLHR+dFauoE6ZOs8sixVP OYH0uBMeauoN9QtaWHgp0DRBUXiyS1xRRluDmn91b7uk0uZsj5ph0igEEDhaXv4yNWLhLR6bd6lx nkgrMyGtFh28Suqqw66nFzQASk7CrdMtBlRjPGMrA9KeF5Q2vO0a6fRV+sPsxHjaZmVu/ZWae0ac IgqACUuYHQKES8i3EuJA2nVW8fAu3B8RB1C6I1JwwBNlzRIqlCDXysdt7dru6xP2PZJE6LpdqjtC ihnlEaLjG2piYjaGgDkclW4TwkopSMjZSBSC6htv0hKkxgaICIUkuI1SaYESo7YRCFFK1MYTEKai UbUxUSplRRUxhIpFMnBC0oTtUQ8IZUgU07hIWZaIK1bhAWXdyrmHZjk1nKCm5RVhYocq7UVSbyr1 SaUht1o4QGaIoKiZFypAKIMqfCcEKKilKU6py1YeKbkyeVOFGEbUwfoFXerFmirPSSh7qzXwqvdW a0ViYKSiFNNKVJ0kgmpUpKKdNUulKSaUErpJFJBSk6ZOmpWTpJJKUnTSkgpSQSCSCl06ZLlJS6NU gjVGq5UkEFu1q01VayrDCrQYyllMSkCmKKEbkIorkNxSSiKG9EchOQShchlEcoFQzZosEk8JuVCv UlKUJR2SUpOlCSCVSkkkkh//1smSmBTwXKREGBqgvWAkJ3uD4MRGiYJE8ApKWkpBw5RK7Nh3aHyK gW9/mkplIA4Ud2g800jhO7TlJS4BSMsOvKZroCYlJS+7sEwPinGiTXapIVujU6pg4cp4BOqTo7JK XLe47qP0fknb4pFJSiSouUtphMkpfcfmm2ykNRon0ASUqCdYgJpTgnjsnMNRUrQAHv4JAAn3KPJl SPHikhiCB8AnL+/imInRTaIgckpKREnsnA7ooY1v0+EEkE+SCmWp4TBxkwlHgkI+SKlASlEKWh1U ZPZJSt4KQMaKPOiefuCSly4HQaBMdBpykDHHJTtbJ8UlLAFogpj4BPMlPMniAElLTqmMlO6CZ4US ElL7o4TA+ClodXJvyJIVtESnkTJEqPKdroSUoEiZTeCWrj5J5SUo6aqMKXHKiNAkpaEhoU3kn17B JSg4yQnDpcoBxGvdSYSfdGnigVwdaoTKoPgZMA6Aq5Ufas+2l7bd0SCq+L5yqWyWy4WvIOoklUXw Xe3hWpgEN5KrEBundWViuVNqgdSpNKSknZMn5Td0EKdoIVS1WyVTt5SCUtKu1qjTor1aq592SLYZ yjhAajqlJkZhTCgFMFMKWYUgoBSTVMk4UZUkFMkkydAqXTQnSSUsnSSQUvCSSSSlJ0wTpKVEpoTp IqVCdCFhcdOB3Tl5HZGlMyEtoSa4OTobKUAlCdJBK21PCSdJC0JtqkkjaloTbVJJC1LQnKdJBLEh IBOkUULRKUJ0klMQ1PCdJK1MYlKFJMklSSRSSUpNCdKUlMSEoTpJWhaEoTpkkrQkQnSKKGJCZSUU lKTJ0xSSskkSmmUUKKZJMipZMnKYpKWUSnTFFSxTFIqJTlKJUZTlRKcEKlQKlMKDtTKlCGrfx8Fl 3crVuWVarmFZJrOUVJygp1jJvKu0qk3lXqeybJIbcKYKZJRMigYciuQ47qcp4QsSmLoKdQeCU5al PEJlHkJ0lMLNdVWs4Vpyq2BJKDurLFVH0lbrRWJmqQUQnHCaUrp+yZJNKVwnTDlJNUyTJJIJUkEv gkgpdOmSTUqThMnQUqUkkkFKSSiUklLgp0yQSUyCLWdUEaI1XKkggtysKy1VqwrbArIYyyTFShRc E9CNyC5GcguQSjJQnIpQ3JqQhchlEehlRSZorJQklKhK9ZJOkglSSZOkpSSZJJT/AP/XzHsAA118 FDcU/P0imPMDhBerckD4pJAJJUI7pbdvmniOEuUkLSlO5OOdeE7huHgAkphH3JRJU4BESmMDSNUl KiNSOVI8aJgSeVAOJOugSUuQSlwpT4KJ1SUtp2U2CdSo+fZOXJKZkCEMmNOyRPcpNbuICKFpT6Dl O4QdE3mUlLfBIJEp4njRJSwMJwdZPCYiPNKYklJS8jlyIywNJMfBCAnROdEkKcdx1TbgOEi6O0pE 90FKmOU+4KIKfUmUUrtMeZUSRMlOATJnRMRISQuLNvbUpSPimA7lICTAKSlTCUwNOUnDaYPI5Sho jx7pKWkRpoU7WkapGEjqUkKZqdUxgeac/imEDU8+SSViZTk/ck4ApgO6SlwPFNMzGqRTgQICSloS AHKIwhkl47QEGSdBwkhefFI/gnGid23bP50pJYtbOqkywt1ao7uyaYRQyY31X+7QHlW7b2tYKmt0 8FS3uOqTdXQSmlLqUCGSqVrH2Pc4OAYzXVXaB7IWdlhx4+jPuVbF85TLZastskjQkyhuiZRvSbXX ubqZhVXjTzlW2NbdqptQwERqCUgSCccJkkLFU7eVcdwqb+UkpK1fq4VGsK9Wqudkg2Wcow0QGKwF RkyMgphRCmFGUrwpBME8JqlwO6cJoUklKCcJk6ClwkEk6Clkk6SRUoJ0ydJKk6ZJJClCyT7R3U+F ECTKI7qZAJQnTpWpGWBJpI0KIokSjd7qpknTJJqV0pSSSUpOmSSQukmSQSukmTpKUkkkipSSSSCl JJkkVKSSSSUpJJMkpSSSSSlJSkkkhZJJJJKkycpkVLFMnTJKWKSSRCIKFimTlMkpZMU6YoqYpk6Z JSyiVIpinKYqJUioohSyiVIqJTlMTwoBTI8UOU+O6ChyOFk28rWuMhZN3KvYmOTWcoKblBTrF28q 9V2VEK7VwmlIb/ZIJm6tTjnyTF7JIFNynBRCCopcpymlOQpJO5NKSlncKrYrRVe5JLVHKtsVQcq2 wpyxKFJME8ppSFJ00JwYTCldJMnGiCl0gmSTUrpJJIKXCSSSalSSaU/PCClJ4SCSClJJJIKXSTJ0 lKCPUghFrKmggt+tWWqrWVZarIYyklM4pwolOQichORXITkFyMlDciFCcgpG5CciOQnFQyZorJJi UplQr2SSaUklLpk8qKCVTCSYpJIf/9DJIhIEDU8eCYMPPZPtgbgfkgvWKUzymIlSnt3RUoumA0JS D8UpS4+aCmQIHmk9z3mSowQfFTaZG5yKGOza2Z1TaRCTju+CcweEkrB0aJ4nhI+0aCVEuHzSQydr odAFGfHhIGPNKZ7QgpRPzTuE+7slxoExMpKXOvmmGqkIA0TOMmR80VKeNp2pRKjqeApbdPMpKVoE xcTqlodAkQJ8klK1STvcXwTxEBMQGjzSUvwkSTymgwmgEE9wkpcEASmBHPdIvJ5SBHJSUpzp1PJS M90uOycxpyT3SUsCnmUxAnThKZ0CSFzA51KadJUSPuS+lwkpcHwTpEbdCIS0KSlvNOBGqjzxwngF JSiS4+QTDy5SMkpDVJSQQfpFQIhNCee54CSlxpym8+6Y6mSkI5KSl9TyUwgapgd2oTuJA8klK+Kb uk0Rz3SLhKSlhqVI1gjQ690x0S3H6MxKSFVDSVAROndEALT8U26Xlx7oFIdLGd7CO6pZ8NbEa7va VcxjDfiqOS19jtB7WnUqvi+cplsradgPnCDc3XY1Wq2tO4uOv5rVTseQ4gq0xq2gKTUPdKk1BKRJ IJIKYuVYtkqy5VzyiFM28q5WqTDKu18KrnZINhhVgFV2hHGipSZAkBUwUMKQKjKUoKkEIcqYKaVM wpKEqQKBUunTSnTVLpJk6SVJJJ0lKSShOgpZJOkkphCkEoUoTibQsnShJNSpKE6SKlkk6SSlJJJ0 lLJJ0kFLJJ0klLJ0kklKhMnSSClkk6SKlkkkklKSSSQUskkkipSZOlCSlkk6ZJSuEydJJSyRSSKV qWTFOmSUsk4zqUkk66FIWTFOUySlkySSKmKZSKikpZMU6YpymKZSUUVLQoFTUCiEMSUMnVTKG5PC kVh0WVdytWwSFl38q9hY5NVygpuUFYWKHKt1KoFaqKBSG/UfapAoNZRAmUvZypKLVI8IoVKZMCnR QyB0Ue6U6JDzRUpV7irEKrYklA36StMVVvKtMRWJQU6iFIJhSuUpTJSmpZfFL8iUpkCpeYThMkEC pflJMnTaSuEkydBSk6jynlNSukmSSUukmTygpdOop5SUvMItZQUWtSQQW7WVaY5VKwrTFZDGUspi U4CYpykbkFyK5CcUlIyhuUyhuTUo3ITkRyEVFJmCySSZRL158U8gqKUoKZpFRBSnRBSikmJSRU// 0cgmU3IlPJS/KgvXnskYmO6jqn2oqXiFN57oe0DulO3QcoKZaHVJzp0UPinHgihfYAJOoSBJ+aR5 SnxSTSjp318EmkN1KdzxtDQNe5UA8JIZkiEtYUQRBlLtygpeRz2TaEyAlGoHim0GndJLI68JmiEx 0Uw4tiOQihiHQUiY5lIy524pnOcUlMidJnVRiU0ePKeElMiSR2hRboZKcNHJTHySUqQNSpEabimB A1PZNKSlySRASAAiOybcOByl8ElLcnTRSmJAUJlO0SkhQIHdPIOnZIho7pj96Sl47JNdtMgT4JpS khJSi4uMnlJx7dkpUhEEnw0SUwIj4QkNAklElJSp7J5TCeyaDwUlLjzTkQJnnsmkf3qRgcJKWB8Q Ck07fkmTgwkpUNA0+kohwbyJU3uL3F7tJUQ6TMJIURHxTEQU7Sok+CSk1b2tkuE6QJQI7pHXQKTY mSkpZonXwTSdyfaW6OOp1TN1JQK4OhQTBnuquRZJNUkD6ToVmge2Fn5Zm0A6A6Kvj/nCqWzKn6Mt knzQbXOLzuVkj3+nVIGiqvEvI8FaY12BSahg7URpQSlHikUwKcpIYP4VQnVWn8Kp3SCUtavVFUWq 5WVWzhfFtsGqOFXrKsAqjJlDIKcKAUwoylcKSQUoTSpQThNCdBS8p0ydBS8p5TJBJTKUpTJJKZSl KinQSySUUpSUyTqKcJKXTppSlJS6SaUpQUySUZTykpdJNKUpKXSTSnlJSkkpSlJSkkkklKSSlN3S UvCUJSkkpSSSaUlKSSSSUpJKU0oqXSTJSkpSSSSClJkkpRUpMkkkpZMnKZJSySRTIqUUydRRQuVF JIoqWUU6ZIKWTJ0xTlMUycqKKFKJTkqBTgpiUJxU3GEB745UkQpg90BZlzpKs3WwqTnSZV7FGgxS KMqBUyoFTLVBWKlXCPWgptsKMFWYUcFBclBUlAKbUkrRBTp3BRSQopwICaFIhJSx4VWxWSdCqrwi lE3lWWHsqzOVZaksSBS5UQnQKV00+KSZBLJKUkyapklKaUwKCmQTkqAKRQpTMJ1CYTymqXlOFBOC gQlkkoylKFKZpKCeUKUymE6jKUpUlmi1coAKNWdVJEILeqVpiq1lWWlWAxpQouKQTFOUjchORnFC cklEUNxRChuTVInIRKK5CI8FFNmix3JSlCZRL1FJJMUFMgU8qBSRUvKSYhJBT//Sx9BzylPzTiO6 iY5CTIydBMNOiUGYB0Ta/JPyYHCSF3ADRMNUzZT6nnRJS0d5hJSOp1TbPAygpYBKZOqWvgnaIElF S7YM6JToVJ7mvIDRAhRJaNCghjuB4ScAEpHZIeaKlac90vMJifDhPOmiSV4jnlLQcqJJGpTT37lJ TOZS+iVHSNUtfkghW7xCUpdpSjxRUocpzqkPwTbpSUqPFIyUiCeU4bGqSlEEaHTyTE6J3OLjKQ4S UxlSBEaqM6acp906JKYl3ZSa0HyTR3TzPKSFzzA4TkANkfSnQfyUwDu30VEnsCkpXOikD3CjCeyC Y7BJKvpalNqdOycOGo7pasE8pKZCCDu+SGTImNFIMcWl5+imkH4JIWEgSknJ7pROgSUoajmCkdob AGvimhJrC6YSUsSpNZunsU3HxTCUlKBhLnQaJ5TcJKUfBLhREd0/JSQm2kQXjQILSHOlugRJDjoZ Q9SdeyBXBuY741VZ7yyzfoQisdDZVa550jxUMB6yVHZsWOcWbzyICoF8OKtOc5zv0ggxoEC8hzoH ZWFjEAHlErGqE2UVoQUlHgkkkRKBQisVcDVHuMIAKcEsgrTfaAqzdVLKtAiFHMXokN6t6shyyKch XmWyFRnAgsoLeDkQFU22IrbFAYrrbQKlKAHogcoyFJQnQw5SBTaSzCdRBUpQUulCaVJBSkk6SSlk k6dBK0JQnSSUpJJPCSlkk6SKlBJJOkpZJOlCClkk6UIqWSTpQgpSSdJJSySdJJSySeEklLJJ0kVL JiFJMkpSZOkgpZMpJkVLJJ0klLJJ0ySlJk6ZJSkk6ZJTEpQnTIhSimhOSokooVCZPKYlFSyZKUxK VKWlMUpTEpwCFSokqMqJejSmRKhKg56GbE/hQl3eKG56C60BV33qSMCVWnssCq23QgW5CqPtJVmG LqVhkvZZuKiNUOVJpVkLF3KBUyoFFSkatAR60FNhisNOiAzlHI2nRBczCK0ITTqjApKXKikTqmSU uAmKmOFApKYOKrv4Vh6rvSSibyrTYVVnKstCKxIkEyfhJKgkSklpwmpVKSZLhJC6aUkyCl5SJUZS JSpDMFKVAFPKaQllKUqEp58UCEspSlRSlClWzlKVCUpQpKSUpUQdUpSpSQFGqOqrgo9SfFDfqVli qVlWmqcLEoTEpApjqipgUMlEchOSKWDkMqZQymqYOQyEQlQJUUmYIyExCmSoqJcx2pQpJkEsSElJ MkpjwknlJJT/AP/TyC2dVEiOVJz4EDhRBjnRJeoA8pCTokNFIOHgklWvcQkBJUTYQng8pIZSGjVQ kEyEge6luMeCSmRsc0bVCTElONU0jhJS3bUwlAB11T6TPKRPdJStO3CbjhPJ+SQHeElK14nhIFRL 45S3F2vgkpl8UyR1SnVJSpAUhEKEAdtSn+CSmQiNUwIKQO0z3TfDkpIZPMnQKPHPKdokjck5wJgc DiUlLE6pbjEDhKJ4CYpKVA7fNLlLX4JbTyUlLlgCfaBrCgn5OpSUqCTynJA0TT3TRJgJKVM8HROB PCkW6SIUNySmTR3mU8gEyFH8qbVJTIAkacKJIJDQn3dk24cpKZEzoeE0hKNEwE6pIWA18k504Tbg T5JzKSloASgnhIS5IuCSlAe0n8E+nbhRLpT8JKXGmvZRnckUR9bR9E/FJSLlSdWazsKWg1SEkgnl JCmE/CExMlFEgloHKFyUCuDNxho80NwBbJ5/NCe58geXCAQXmI4HKZEaoKe5moJdvMD5IFhBedug RK2Bh9ztCJ0Q7oa7RSrEnpnbPgmrTB5iE9YQSmASUgmKCGtdoFXCPf4KvKKWRdAVeyzcVN7kApJZ tshWqsghUU4dCbKIKQadhmQFYZcsRthCK3IIUEsPZdxO621FbYsWvKhWGZMqvLEVwLrCxTFizW5C K29QnGU26AepB6otuRBaEzgS3A5SDlTFqmLE0xU2dyeVXFilvQpKeU8oO9Lem0pPKUoQen3JUpKC lKHuS3JUpLKUoe5LclSkkpKAcluSpSRJQ3JByVKSJKG5LchSmYSUdyW5KlMklHcluSpLJJQ3J9yV KZJKG5LchSGaShuS3I0lnKZQ3JbkqQzSlD3JbkaUkTSobkwclSkiUqG5NvSpTOUkPcm3pUpLKaUL em3hGlJZTbkIvTb0qUllRLkIvUTYnUpMXKO5BNiibUaUnLlEvQDaoG0J3Chsl6gbFVNyG68JwgUW 2zYoG1U3XjSEJ2QpBjKrbxuAQn3TyqDslBfk6KWOErbb7r0F1/ms915Q3WkqYYUGTbsyB2Vd9xKC XFRlTCIC22RdKikknIUptUU4SUyKaEpSSUsjVoRRK0lNtqICoDUKYQSyB7qw3hBaEVpSSopu6cpv NJTM8KJTzKSSkbxoq9nirT1Vs4QUiZqVaaqtfKtMTlrNJOm4QSpMkUyClSklIhMkhdNKSYoKVKSb lKUVMgkmCRKClTCUpkkFLpSm4SQSunTJIUleYTqKdKlM2o9XKrtR6iiEFv1lHaq9eqssUoWpAnJT hRKcpg4oblNyG5ApYFDcUQobkFMJUCnUSVFJmisQmKRKaVCV6oSTSkCkpdKE6SCmMJJ4SSQ//9TG 3aaKQIjjXxUBCd2kRqCkvXIB1TNBcYTNJ8VNpBMk/FJSxZyJ4TTGisZAqaP0SrbhMQkoMnO7JgCU jASkDRJS5n6PdMOYMJ4g6cqMAfFJTIFNtnlNu7QnAMxwkpcABLdIjhRIjumI0lJTIFL4alR00KkE lLflUnvL+0Qm1BmUi+TJ1SUymB5qPCfhNu0jskhREweyXJ1TD8E55lJS6Wh1ITDhRhJSQETpokWk QXCJ4URA1ck55fyfJJS3mkXJnFINJ9x4SUv20SkcJhB1SIJ5SUrn4JB0cJEjhL6IGuqSlyeyZ0A6 a6JcJARqkpUR8UvgnJHdRnwSUu3XlIho0CQHCRaO3PdJSnnbpym3HidE4APKjA57JKZACPNTeQYH cd0OSkPEpIZiII7qAlNxwnEn4JKX0PA+KY8py7boOVDzPJ4SUkr9plIgPHhCj5pHb4pKX2mCfzQo g9gncSOO6QaDAHzSQzd4hBMTojEknaeyGYBhJIR2t9hJTNtIYGO0B5PdLI0EA8oIYRtLtW90Ahs4 1GoNn0ef7KjcQ6wkCG9glXdtcSNZ0CHbuDoPKchkHdgiVhQbXDdymzRBSZM5O06KL9ECpp5DtVXL lO4yUIoqYuMqCnCYhJLCEk6ZJSkpSTJKZBxUxYQhJIUpsjIKM3KIVFKU0wBTbqNy0VuX5rH3FOLC mHCCnidwZQRBkrCFpUheVGcCeJ3m5KIMgLC+0EKQyimHAnid4ZCkLwsIZamMzzUZwFPE7guUhcFi Ny1IZaacBTbtespeqsb7WpDLCb7JVbseqpeosgZakMuE32im3V9RP6iyxlg91IZQ8UPbKrdPen3r MGUFIZQQ9sqt0fUS3rP+0hOMkeKHtlToeolvWf8AaEvtCXAVOhvS3qh9pCX2kJcBU396W9UPtACX 2kJcBU3y9NvVH7Ql9oS4Cpvb0i9UftCb7R3lLgKm96iXqKh9oB7pvtA8UeAqdDem9RZ/2hMckJe2 VW6HqJvUWf8AaQonJR9sqt0fVTG1Z32mVE5CPtlVul6qiblmnJPZN6z5AgpwxFFukblH1llvyC0w dCh/a04YSq3WN6ib1knLUTlpwwFXE6xvhQdkLIdloRyinjAUGTsHIUHZKyDklQN7ipBgW8TqnKhD dlLM9QqO4p4whHE6LspBdlSqcppTxjiEWWycglDNpKEkn0EWzLyVGUySKlSkkkkpSSSSSlJ0kklK TpJ4SUpJJOkpcCVJqValEFJTbr1anChQdIU0EpW+CkFBqfzSSlTA6pAykUlLnRJLsmCSlOVa1WSq 1qSUNfKtNVWvlWmpLGYTJFOglikUimSUpJJIpIUVFOUySlSm5TnVMipcaJJJkFKTlMkgpSRSS4QK l0kyQQSyS1TJI0pm3hWKvFV2qxUkFN2tWWKtWrTFKFqQFIpwE5CKkTkJyM5BcglGUNxRCUJyCUZK iSpFQIUUmQMUxTkJoCiXrJwlCUJKZJ1EFSTUqSSlJFT/AP/VxpEaJERoeUiWyCNE7i0A8z4pL1iE iY0TAhKJ0CSlSpw2JJ1TTB1GigDuOmgSUuSE8QPFIujnVRHiklfXsUiAnggKIb4pIZQY04TaBI6J SI1SUoapbo41SSidAkpY+KRBHOikwbXT4FHyMp15G8SRwUkW1mjvynj705d4hNISSoSfilPYcpte yUQkpQ1SOiW4lOBCSlgVKZEcJOfI1UQZ7JIXGqLTT6rtoIBQoUmuhEKKR9BmPuQXNjQq425rm7Xj XxUnY/qNLgdEKRbTDy35oZIAgKRYRyozr8EkrgaTCQ5lOdR5pmjRJSjrqUw1OikSJ4kKJMDhJS7u IB1TARyls2gHxTCO6SlwSTKclRJnVSaAT7uElMd2kJAa6pGQkQfOUlKmU8JphITBckpXxSJ8OEgZ SgdkkKGpTlp5UeFIkpKU5sqIgFSb33JgAAZ57JKWc4uMJ5gwkWulIFvdJTJuvxQ3gg+KM2J8EN5I SKQivbOoT0klhae4iE9/0R2TUONYLm6aJBY26cdlDGuePdBKqZDt9kolDhY6XnshWsDXkBFCQuhk JNScwBoI5TsCBSkaEO4wEYCVVyXaQkhpv5UCITkpiZSXMSE0KUJQkpGQmhTITQkpgkplqjCSlkyl CRCSmKSdMkpSSSSSlKTYnVRTpKXc6SmlMkkpeU+5RSSUy3FOHkKCSCknqFP6pQ0kqCkvrOUheUBO hQTbdblAciU/2tvgqKSHAFWW+MpvgkcpqoJIcEVWW/8AaW+akMpvis5PKXtxTxF0DlDxSGSD3WfK aUPbiriLo/aR4p/tI8VmynlL24q4i6IygeSl9pHErNlPKXtRVxF0ftQ8UjlDxWdKUpe3FXEXR+0j uU32oeKzpSR9uKuIuh9qb4pHJb5rPSS9uKOIt85TUhls7iVQSS4Iqst/7U0cBIZjR+aFQTo8EVWX Rd1ARAaAhfbnKmlCQhEKstv7c+ZlQdlvdqSVXhKEaCrLN9rnalQLilCYooVuKaUkyKl5STJJKUkk kkpSSSSSlJJJJKUkknSUsknTwkpinTwlCSlklKExCSloTpQnhJSwUgEoSSUohJOkkpmzQqy9ge3c OVWBVmtxASUxqMGEdyrnQ6IwMhBLNqIhNRQdEkhdpTqI81NJSgdEhqm4TjQIJXVW7urJVW1FRR1q y1VqxqrLUljJMnTFJKkyXZKYSQpMklKSlFMUimJQUuU0pJIqUnTBJBS6UpkkFKSSSSUpLVJIIJXT wmThJTJqPXoq7VYrRU3ayrLCqtYVphhPC1OCkSohyYuTlMXFBcURxQigSlgVBxUyoOQSjJUFIlDK ikyRXTJSmUS9SUpJcoJXBTyohOElMpSTJIKf/9bHEAaiSm07ppScfFJev7eQpFrRyhgjv9yRPZJT LTsUnAEJg3wSslpg9klK2tmAdEnCNBqmHgnDRoUlKeQTI0SATvAJlpURoNUlM/SJIaIkiU3pu4CZ pJ5Thxn26pKX2uaDPCYEjQd0iSQl5JKWaCeBomE691KY0HBTboG370lLapF2sJ2glTc8OABjTTRJ TDnyTHyUyTA0gBMImUkMCST5pQSp6HjRO5rRwdfBJLGJUS6Snc1o0aiV1lw0IEa6pKRyTqpfQ9xM lJx3OnQSokOMujQJIX3SYWlQ6sAa88rMGg/In39+6cgp7/e4knhV2lTBMEdjyh/HjsE1IXkj+KiS D8U8duAkOUkrATp3TlrgdU87eExJ+9JCtXJhrqeEoPdOdTxASUtz8Epd8lIT5R2SPuMcDwSUxhOd E+1saKOwxqkpWruE5Hbt3TSmmUkMieyQZ7C6fgFAmNT2RbGvrJY8Q4cj+skpgE51G4D2+KiDJ8VM vgbJ05SUx3QOExJPPKfQanlNPikpkWxoE4ZuEgccocgcKUu47JKZsI4Kg7mU7BGiTwD8Ukhhedwk 8KDX7qyXfR7BTf7hp2GqDV9AkjQpBYWwHg7ABAH4pZJBfA7BF9JxDCdBCq3kF8jiEUMhKKxCbwis QUmOgWdkEEwrVr9ICoWTKKWJbAUYTpERygliQnSKUJKYlMnIShJSxUVKEtiSmKRbCltTpKRwmhEh PtlJSKEoUwE7mpKRQkp7UtmqSmCZT2pFsJKYJKUJQkpikpQlCSmKSdJJSlMBQCv04brGBw4QU04S hXbcN1RAcInhR+z7oDdSTCSrakJQrjsZzSWlpkGOFH7O4nbtM9tErVbVhKFaGLYdQFA0OnhK1NeE oRm1F3Ck6khJTXhKEf0imNZCSkMJQi7ClsSUihKEUVzwpekkpBCUI3plTbQXcJKa0JQrQoLjAS+z nhJTWhKFb+zFN9nI1StTWhKFZbQXCRwisxXEEwlamjtT7VotwiSRHCNXgGCHCBpr/JStVuTsPKcV lbDOnubLeR4+SY4BDgIOqSLcj00Oxu0wt53S3lge0EyS0rKzqDQ/Y7lIFV200ydJFKydOAn2pKYw lCnt0ShJSxbCjCNGkoZCSmMJ4UgE+2ElMEoUy3RMAkpaE8KW2E0JKWhKFPbHKkGykpGAlCmQpACE lIVKE5anhJTEBIhSSIQUxhKFKE4bKKloRmqO0JwQElLu48wpMchkypM0QUnaZRWeCA0qxXKSWRbC XZTKgUkqIUkwSQUsToqtisuOirWIqYVlWQq1asBJayKZJIpJUmITymj7kkLJvJOUySl0k3CSSlFM kUgkpdKUyeUFKJSSTJKXSSSQUsnTd06SVwkm5TpKZBHrCC3VHrSU26yrLUCoKywJ4QyASKkkQnIR FDcjOahOCCUZQ3IhQ3IKROQypkoZKjkyhUpSUpTKEr15SlMlCSl5TymTwkleYSSSQU//18V5BM8B MZHHCUAayozKDIvPkpNIaDPJ4UJjQJSO/CKlyfAJp0S+CeCDofmkhYuATzonYwHlI8mOElKLRElN JTaxJTB06BJLOUpA4S2zrwlBGqSFwdEzgeAltSc7dA8ElKASDgOEzQSplu10P7eCSmIcRwnD+4UY J1Ck9kAHiUlKA/eS2lyjsl0A8qTmlpLT2SUsREJEg+SbU6kpcccpIUNNU4MymBkpOgGOySVwnbYQ NOFCZ4SISUWRfuSDk3CaQRpykpI1+2ZUGlo5EnsmAHdOPFJFKOvKXATCTqpOOnmkpin0TCeyidTC SmYjukGl3HCQBA0TDj4pKUNTopSIjkzyoxCU+CSlB33pEl2hSaU5OiSlgEh3lKYTt4MgGe6SGEJw AEoBSSSocpHRLSU5ISQxnVPtc4EjgJp1UiQGkd0lMZhPKifFO0eKSmbdRqmd9GR4ojfb9FQeYSKg tpBCjdU6trOIdw0Ke72klCBcTI7cHwRC0pmWaBjtFVsjdA4HCu5JOS1pYPoD3Kk4aiEihmzQIrTO iCJHKcugJJWLpUHQVFpBOvCK4fupEqQ7QNVBxLiiEE6Ji2IJQUj50TlhjROGzwk4nhJLAjRMpnVK AkpgGp3BShNCSkcJ4UoTFJTAhJST7UlI0+qns7pxWTokpgkBoVPan26aJKRAJOCKWxyoxCSkcJw3 siBumqclJSHakWxyrDGyVCwTqkprJKRGqJsHZJSNrZXo31d6bTdhNLxJlcE1oZqu8+r/AFAMpDCd IThG1pI6ujb0Ci1250/1fzUU9ExSANg01keKsDPrImU32+uNShwHsj0terpLa4aDoCTwoWdGqdEn j6P8lWHdSrCb7a13OiXAeytGoPq/ToTyOT+8EH/m1ULd7DAWi3qDJgmURmcx3dLgKtHA/wCZtLCT W9wJ7FI/VCojRxGvC33ZzQYGpQ3Z7ShwFVDu4zPqjVJDnHb4BVz9V/Se5oMs0guXRDMYDyhvzAT7 tQlwFNeLzl/1XhoI5mFZH1QoGwucR+8tenOYZB4CM7IkACJS4CqnBs+qlZfNR9sqNf1S3SSe612d RG6DpHIR29QYeDBCPAVV4uG/6pgERBBOqkfqq2HFpj+Stn9otPdN9uYBJMIcBVXi5Vf1UrIl7iP6 qJX9UcZpkucVps6gw6Jv2gyYmEeAood3Pd9WK9xLHEA+KnT9WcdjvfLgOysv6iGvAB0RWdQafdKX AU6IK/q7iscTBIM6fmjcpVdDxayQ5u6eJ/NVj9os7HRQs6lWNQdQjwHsgcLM9KoJBLZAEAJO6VjO cCWDQRCg3qVZ+kUzuosYJBlLgKtGwMChvDAifZqjB2jTjRUG9WY4+STers37eyPtlVxdP02xECF5 n9aKRTmFg4A0XeftavXyXA/WO31snf4hAwI1KQR0cIhNCMxm8woFsJq5kGCAQlEKYadoI7py0pKR xooqwGJvTlJSMHSEjqphkJ9qSkQAUh4IrKtyRZCCkZGiiGowrJS2EaJKRHVPGkBFbXOhS9OCkpEp NRvRmCCNUX7E8Ak9v+kkpplII3pF0QOUtpbzyElIIlMWlXJB+j3TOiEVNdrCSB4pFmsd+6INNVFz hEpKVsBEd022FHfool5SUuXwmnVR54TTBSUkBUmlDBlSBSU2Gaq1XxCp1lW2nRBISSolKZS5SSyA USpcBRQUxeVWsOisP0VazRFRWrVgKvWrARWrpJJIKW4S/IlGnkmlJSjAKZJMkpeZTJJtElKKUpFN KSl5TymJSSUukmSQUukmSQUukm4S4SSyCdRThFDNqsVKs3RWaUkt6tWG6qvX5q2xPC1kAnhSCZxR UicguRXILkEsChORCoOQUhcglGcEJwhRyZYsZKQKY+ITEqIsjMJ0MFOCkpmnUJTygpmEkySSn//Q wjoOUwBGqfbKQkagJL1okp4lPtnn5Jo1I8EErzpAUfind7W6nlMNRPZFC89khqkX7jJTgzwkpRHj qnJjWIUQCeNfFKJSUuXk6wmkfNMQPkkCPmkpfdpynbJCae6RPZJTJvt1SLt3wUdClzwkpm3yTvf6 h3FCBTnUT2SUyLtfNM7UyUzZCeCeeElLEhSATQACO/ZNJ7pKXnXRMQT8UjHJKdsFJSwkahO0SYTt MBIO0hJCiDqOVHTskDBgJboEAJKXDQSeyZuvwSlOBGiSWMwlKfSDPKW3SSkhTnSISM8JgpOOgCSl pnRIaKJCfiYSUuTOvdNMJ/bEnnwTAiZcElKMpyCOdE2g0UnHd7idUlLbHFpf+aOSmLjCcvkR2UZM pKZAlMexd3S17pPe58E8AQEkLbtVIcgd03aUh4jhJShMyURxY7kbQB/nuUbHAxHZDJBSUoapxA+K YCVNoBMH70lJWtJaYQbOymyQY7KLtHzykoMHOIEBDrNj3CtnPgibtEse40bnt5IRC0rsgN59xOqA 52uik57W1hrRr+cVDaSgpIIOqDaYCIBooP1SUja6NQptt0Qy2OFGElNgPUC+TKET3SB7pKbJMNAH KjGqD6kojDpKSme2DPKg5vgn3yJThzUqUr0yIk8pnMjhEJaPNEkESfklSmqWpbe6temIAPKeykNA CVKagZrqpFqutaxrI0JU2VVuE90qVbQa091NtTtSr7KmT7lG1m0SEqVbRraHEBEsqax5aNQEUNad VDaJKNKtCWyColgiFZDWn2ypOaGHTjxSpTVFQ27iommI81Y5MN1CIawCAUqU1PS2ieyFtJnwV57W lsjlVN20EDvygpAGFx0TAwUQnaEGUkpC5a2Dlmtu1YsqxVZCdGVIIt3j1Fw7pDqD3NJngrIFknVT 9TTRS+6Vnth0X5z4idFMdSce6yHPTbjwh7ieAOsOoEd9UT9pEd1iboS3lL3FcAdtnUnTMqX7ScNJ WGHkJbyl7iuEO+eok6pftFzdQdViNsKl6hS40067M3XlS+3nsViG08KO770ONFO1+0DMzKc55cZ8 Fh+oSpCwo8Sqdd2Y6eVP7e4d1j707rNEuNXC6ozj4p/tzjoVjmzwTesQlxq4Q6rs4lP9vcAdVkby VNriQUONXCHRGa6eVKzN0ABkrLEwpAuiEfcVwhvjOIMyptz5BCyywp2sKHuK4Q3m5haee6k7MJ4P zVE1EqBa4pe4VcIbx6gRofgsrKsNjpKK8Fokqk52qEpkhIiA3ulsY/IDXjQgqpd9IjzRsJ+x5f3A T5VRaA4/ne4KNKJvAaFbqqPKpNO0q03JLRoiApJ6J5T/AGcgbghDI2ncdUQ5pLYRpS5pa3lP6EmP FVrLnE8p/XOgSoIbTccAzKZzGgaayq/rmDqi1uc+pxImEqCkjWgCe/gmds0lVxkEccqLnHk8pEBT bdsLQRymfUIG3iOVS9Y8dlM3aAJJSwGgeam28gQT7e6C3c8aagKDzpKCkzXEcIrbmF5FnMaFUDYY hQsdJkJKdMMreCRpCrvYY01hCpsO0iU7LSCISUic/soz2Rradok9+FWmCglSRSlNKSlpS5TSpJKZ DRSBUApBJSZphWmnRVWo7DogkJZTzCYJJJSE+CZMNUiUkrPVS1WnqrYkgqrVgKvUjhFayKZKUxQU oExCae5S5TFJS/xTEpFMUlKlJJMkpRSSKZJS6SZONElLhJME6ClJJkkFKJSlJJJK8p0wTooZtVmr lVmqxUgp0KlZYqtStNKeEJQmckCouKcpg4oDkVxQigUsCoFTKgUFBG4IRCMVBwUMmaKEqMIhCiQo 16OElMtTQjalk6eFIBBSyScJJKf/0cGC7hKeycuI+jomBMpL0jSI15Stdv2hoiOfNRd5nVR+lokp k/Q/JQ5TxHKUxqkpXeUnNB4TfBSHEpKWOnfRKCeEtsCUx+4pKXInkJSU0lO3U+CSlEk69k0jgKXk E4DQNUlMQNvKbWJj4lONedVLefopKWA0lRCcknVOfJJK5gjjVR3eITTPKcJIXB5/BNMacpGUpAEe KSl58U0piSnCSl58U4aXT4KO0dtU/kkpbQ8JRBTBo4Uvo6FJSomSoKe0gaJj7dCkpQGvCk4GY4CT ACQFFx1hJCgn26pgEtvZJTOtwYZiYUAD24TzGqYHxSUuQInmUpHZNBKkQ2PNJTGNJSPnymA7qT2N aAQZJ5SUslE/FNKcuKSgomUycGB4phxKSF3ADzTeaREHVMSHFJLIEgEN7pPYW86eSk07dQoTKSFy 3aB4pN0hIxwEwAOpSUlDT8VB5gyEQDSAoWCBpyUipE90NMd0HXaT4IxkGBymxtjifU+iBwkFpZVV wwOePaShv8QisLXtDSCNeEF8g7T2SKlwhWOgwiAwgWuh0JKWJlSaWjlCc+U4cO6SkrWgiCoOYCdF OuzYCRyQhz3SUxLCEpMKYfKd20AefKSUbdU0lHLW7BHPdCLC06pKZhSBk6qAb9ycCUUJjYYE8KRv kR2CEAfFTdSGkQUbUs6ydAkHuI51UjQ0Ce6mGgt2pWpYWkQpOyjyUxp2tmRCk7aAGgTCNoYfaD94 UarXNMdintA02jREq2OI3D5IJRve3sU4c6Ido0pPrDZ3DR30UznDaBOqSmAdGikLC6GqW1rNeVBr g3UalJTNr40sCVjGzpwmeZMlSewCsEGXE6hAqadpEEd1WKPdo4hAKCVSj06nVV0ak6pKdANATEBQ D0vURQzgd0g1R3Jb0lMtkJwwIfqRyn9RJSTaCo7B2Q/UlL1ElJUpCFvS3pJSGE0Ie+U4eghmAnhD 3pvUlJKTRIoe9RLklJEyhuTApKSzCk1wCAXJt8JKbLXqRsVTcn3oobvqCNUm3KmXpt8JKb/qBTYQ RB5WeLVMXFqSk+REFZROqt2XbgqRQS6FD2OYQBDkQM9RonjhUKJJ05Vv1Nf4IhC9uKWc+Ch6TiNw 44Un5G4QUm5JDdvZKlMDUdvaE3plo3KLnToiB7QNp5SUw9M8nsFP7O8t36AJ7L9wg6xwVAvJbE6J KXOO+JTMFglre6i20xCmLCNeElMSxzZkHeErA+JcEcZUnd34QrLDafikpExkkbvo90a8N3/o/o9k Rj2s0OpKG7QEgJKVW6GkTAQmEPIDuESXVEg9wgh0JKSvqa0El2vggktLdOUnOkz2QyglnWYKs1xH mqhMjVTZZASUmvcRDT2Vdzp5Un2bzJUJSUsUynKhCSlJ0hwkkpkFIKA5RAkpI0ozDqgtRWFBKdqk oBSSSunJTJSkli9VbVaOqq2JIK9SOECtGBRWslEp00pKUmJhOm5QUsdEkkxRUqUkpSQUsUk5Tdkk LhJMnSUpJMnQSrySSS0SUsUkuEkkrpxEpk6SGbdVZp5VZis1lJLfrKsMKqV6q2wJwQlCRCcJinIR OCC5GcgkIJRlRKmQokIJDEqBUiolQyZQxhRLURMoivRFqUKZCSSmMJlNKErUxhJShJJT/9LBAJ4S HKTwZIOhHZInSEF6xlIOA55THUpwipf6WpSGh0THySkRHdBS5k6JeSjr4pbpRUWRBTT4pN18ktPm kpUkBIuPdJ2h9yTSQdOySlaJSTokZSglJShPPdKS+T4Jo8dVNzpOmg8ElMYifJO7tCj8VKPHhJSh roE5kDT5poCYiOSkpUlIpDwTgEnRJStAE4g8pObtPMqBkJKZbo4S8zwmhIacJKXMt7QmPmpbvFQm SkpkAeeyUmPJNrMKRMtA8EkLAwkCQmDSfNOWxPgkpdzpie2ievbPvmPJQKfTgJKWklKNN0/JJyRH ZJSuU50803CdwaILTPikpYT2SlMUgEkMmkqM9ynnuU0pJUNU8bdAoiVLmSUlKB1mEvlBTeaae3dJ DIgxPyTEbU+4xtSGqSlGAPNMNdeyMxosEEhoEme6jaI2iI+H5ySlMdMA90z+dVNpgT3ULAOOyRUE RECRyh027AR4ojnbeBqUCqo2Ogc8BJBbbGy32mXk6Kv3nv3Vv0fQFjDBsZGoOipkEanvqkUBkqVp 9xVuVUfyUksQpAKIU5SUzdqNEOeyUpAJKXBLdUxJUgEx1KSmW7xUxaO+oQUySk4d2UnO0j8UAFE3 6apIZjspG7XVDaQdOFJwhsR80VMxbAghMCdUIlIBwEpKS+pCi2yShEqR1+ilakxeWyQdEMW6qJdD YKgzUpWpsOsLtTyo79NeyZ4AUWtESeUlMi+QrDHtrrBcASVUMdk0T3StSf1Q5J9vbhB2QeVLeJ14 StSKwy4lBKI8aoZQSsptMKCSSmwHpw9ADktySk4enc+OCq+5LckpP6iW9A3JSkpsb029AlLckpPv SL0DcluSUm3qXqKvKW5JSfeluQNyW5JSfem3oO5LckpPuTFyDuS3JKS7ktyFKbckpNuSLoQpSlJS TckXIUpSkpLuTF6HKUpKZFyiUySSk1D9pUzpKCxTJSUuCVMFxQ26KQbKSF3S0weUnaJP11UUkriV OsskbuFBxlRgjskhmeTHCbcU8gQVFJK4MlEaTMofKRMJITv2kpm8alBDiVIOkIqZXP8AvQCZRHcQ ohuvKCWIBOik9pboVMO7JydNUlNeUQtAaCo7UZ9bWAjnwKSmvKdMU88JKXTTCYpJKXTJJxqkpcIo QgitQUkCmFEKQSXJgVJDCmCgpeYSTHwTwipTtAqlqsv4VaxJRXrKOEGtFCK1eUimSSUpKU3wSKCl ikkdE0pKUdE6aEklKTJ/imSUukmTpKXTBJJBS8pfFMlCSlFLRMU/KSV0kydJCRqsVlVmqzUklu1K 2xVKlaYnBamCYpApiU5SNxlCciuKESglgVEqRUCgpiSoFOVElRTZguEkyf4KFepJKEkFKShKUpSU pJJJJT//08D1CTJOqRIiFE68aJ58El6jPKfYQ2TwVHUJSkpeB8kwPgnJ01TiToElLkQNOUx00SEz 5KdprO3bO785JShXLS5x1US2IJ7pj5pikpePmm7wEgT3UxYWggclJTDXup8DXhR27dDynJ7FJSxP YcJBP5p2s3E6pKWfH5vzTS5wg6JRPJSnwSUsRHKW4J5k6pnET7dUlMgJ5OiYFPI7qJlJS8ACe6cc ymjXVMTJkpIXITcqZeXd+FEkSkpdu0fFMDCXITGPkkpm0ifDxSdoSPuURCKTwZSUi3FNEmZU9gdJ GihzwkpcAAapbe57qOvdSDiUkqKbWUhrxylH3lJCoUuSm4bHdOBOp1SUx5T6lO6CSQIB7JuQkpaY STgCNVESeElLkzwm5Uw2BMpneXCSmMykBCcNJ0Sc2DEpKVMJ4kacKI1S7QkhlITd/JMRCcESElJG c6JrOU4E8fNKzkJFQQukkACCh44HqjcdBqiPOslQqrBBj6SIQWw9rbjZcPaydGqq47irFO6fRd8w hWAMOnCBQwVfZJJVgoLzCSURCbhPKR1SUrnlI86JQkkpcOhNwkpHV2vCSmJ4SbodVMsj4JiQOElL ggnXhNoOE0ymISUzGqmx5GiGCURxB17pIbAc0QXCUIQ55jRqgXEiExO3QIqWd9JSDQeNFHvrymLj wglTjopM7IRU9QElMnOBKadI7ponhROhSQyLoEKTWGJCGTqpboSUtu115TiXHROTMSohxaZSSvaR wRr3QCER7pCGSkpikknhJSySeEoSUsknhKElLJJ4ShJSySeEoSUsknhPCSmKSltS2pKYpKW1Lakp ikpbZTlhSUwSUtqW1JTFJTDJTFqSmKSltTlsJKYJKe1PsMJKRpKZamhJTFJJJJSUNAEg6pHRRYpH VJS4KeTyk1ODCSl5BE90whLbKiZCSmXeAmnxTBP8UlL7lFScZUYSUyAmUgJTCQn15SUolRiE6nXq UlI5TSiloiUMulJSgCVMmdFAFT0SUsDtSeZScZKiXaJKYJwmlSZGspKWIhMpkzooEJKUnTJJKZBG bqgt5VgIJDIIjdUMIrUEsgFIKITpKUeU6SaUVLWFVno71Xekgs2IqExElFDIJSmSJSUrlKUkySlF NKkVElJSinlMkgpSbySTpKUkkNUklKCUJJIKUn40TJJKWSCSSSVwpKKSSGbVZqOqrt0VipJLerMK w1yqMKsMTghOCkQmanJRQwchORHIZSSxKgSpFQJQUwKgSplQJUUmWKpUlFOFCWRdNKSY+KAUqUpU UohFTKUlGUklP//U5+PJLbCUB2qREhJesUgAl5AJ2hJSo8EhqFPeW6gKG5x+CSlA6yVKx4e4uiEP kqWpSUqRCQI8NSm5TvaWHaUlLta0zuMABRBCcujRFqscz6A1hJCKQNUpjVPsJ0TCfmklR8SnhM50 8pAEiQNAkpW0DnVKZPn2TT4p90cBJCuDrypteNxc4Tohk/eUplJSQbdpJn+SoDy1S5MFSaBBKSln ANjWSk0gaxKafvTgwkpQl3kkZJgpgY17poI5SUzIIgpiS5MRCbQaJKZEAHTUJKTXFmreVGI78JKX ISbWCRu4UOU8Twkpk+AdOExb4KAUx4kpKXGiTjLp5TSmJSUunmNPFQEqbmObG7vwkpZrZMFOBtdI OgURzPZI6cJKUNeeE7nhxnskJamLYSUu46+0Q1RjdonJ8EmgkwOSkpURym44S1JTggHUSgpZx/FS YQzzTO1UUVLz96QMwmJgKVRgykpmGlpISs0SrOvxKT9UkBD4JUAOeRMJ5gzzChEO8PNIILYYa63u H0vAqrc6XkjROHEElCc4EpKXlCeZTykCJ14SUw2pjoiFwkqBSQtKYcpBI6JJXmE41KgU6Sme6NPF RdodFMAbUySlMICR1UTqUpSUuJ4RAIj8VIVwzf4oQd4pISaFTcAfghseJ1RnDTRFTX08VEKQHJUE EqcZKISNoA5QwNUQGCCElKaNYUS33Kbn7vilW0ExwkpVI93u4St2+oS0QJ0CdxI0QiUlJGlRcI0U Q6EgZ5SUva0CI1QnCEVpgwovOsJKRgJ4UxoE7RISUw2pg1EISaCkpgGpQjBuuqRAJMcJKQ7VL0iV KE40SUw9NLYApqYbISUhIS2hFgFOWgBJSDap7EQR2Th+qSkXpz8U4bClPgmaZ5SUxDTypRA8lIpE z2SQi26ypASdVKYCaO6SVBkaKewcJwSnBAGqSGDqwQSFANjUoukJnN7pKROglIDRSdoogDg6JJYl sKBEogI7qJSUjSTpklJKxrqp2CDCEzlEcJKSlgSE8pw2U8d0lMSI7px5pQm4SUoJj5JyEohJSw80 8wnmeEySmJKmyTommCpsI3AnhJTN7PSII1UX2EmUUs3ExqEF7RMBJCNxTMEmFPb4piyADPKSV3gT omEwmkSnDoSUxJKYlTDS86BReACkpiQiGstEqACMbNzdUlIE5KZMkpSdMpBJTOsIwQWI4QKQzCmF BpUkEswnUZUwkpYpQkUjwipG4qu9WHKu9JBSM4RENiIiheITFJJBSuEkxSKSl0ySSSlkkikipSSR SQUukmSSUukkkkpSUJJkFKS8kySSWSQTJwkhm1Wa1WYrNfKSm1WFaYFWrKsNKcFJxokVFpTlFDFy E5TKG5JLAqJUuVEhBSMlQJUyhOUUmULzCfcoJAqJkSSmlRlKUFLymTSmSUukmlJJVP8A/9XCDI07 pFoHaUOU+8hJcpxg+CeJbodU24cu1T+13kPBJTGY4TnxTBsnwUixo03apKWaDyBMJOI/NUg0xDTo o/R5GiSlRCYmTqlE8FIDwSUrhFq80Nsd9Qk5wmGpKbFgadWiAgvAJUm3RzyhuMwkhUd0pPCiQn0C SVwI+KSTpTBJTJpjlNHgEgC4wOUwSUyLRwOUhIjumiEx14SUqYSM6k90+0tEzypATzokpYQBryok k8pbfmnSUrceEidFJzQW7goASZKSl5+SaT3TgykPBJSgNxgcpjLfin4SbokpZNJUi7UQp1ua0y4S B+akpiAOSmH4JE9/wTmYSQokJEzyk0AlRE90ksxAEnlRbLvimjVPICSmTXlohRdp5JpJMBIjUxwk heNU0nlO5/bhIvMBvYJJUGEkgfNRmONUgSkSBwkpcgNEk6pASpNOu5QJJ4SUuHRqk0wUzhHmmEd0 lJmu04Sc4gSE7S3gJnzEdkkBF5whssgknw0RTI0Qi4bwT+akEFjW1z3agwTChkNDHGOFZsyiJYNB MgKk9xeZKSluU0wkEikpYpJiUSseKSlnt26+KGjXGdPBCCSlk4KR5TBJTKU5domA8UiBKSltUSqv efghhWqnhjT4pKZZJ2NDFVBTvcXmSl9FJTIQdUVuogIQIBlTYTukIoXtE+SDARrrNx5QZlBShICZ PpCjKSWRKQd3S0SkJKZSShmFKVHhJS4SDNxhSaY1SnwSUttIPwSe7cZKdsyjV11uJ3mNNElICkIh W8cNrdOhhDsDHPLhoPBJCMREFSYQpEMTsqB4KSlHb4IZaTqEUNbrrqE7CJ14RUgAISIV0sa4gO0Q n1NDi2eEFNZqmNEY48CZUY7JKYOIIgJh4I1dQJLhqER2N3byUVNUNTuEKyMQ+PyUWsAdDxpKSmtG sKMEFaBw26QQquwaoKRGTqU54hWW0iNyHYxoP9ySkEaJwiOrAMAyk1gGpSUtrMhJojnVPY5vb5qT WyIjUoqR2kOPsEDwTFjz2hRbY6t2id1pKCmBa5L03Hsn3lNuKSlvScnNLgYTElNuKSVei6Y7qOwo m8nnlICUlMNhHKIBIlOX6QhTCSmxtAHKbeI8kIOPKQMpIZEgcJimdqdFFJKTaCFA6pKMJKZt5S0B TA907nSZSUsdUgYT7oTHUpKTV2bUJzpMpHRLaCJSUyYVB/KnWJMBJ47d0lIzJS3KQ9p1TTrKSmyH hjBBVZwLjongRryozCSlk6jMpJKXKZKUySl0gmU2hJSRgRQhtU0Ehk1ECG1ECCV1JrtFFPwkpdJJ JFSN3iq7kd5QHcpIKRpRAht4RAihcJSkkgpctO0OUUQWSzbHCGUlKTFJMUVLpk6SCFJJkpSSukmS SQukEydJKkkkkFLJJk6SVwnUQnSQkarFarsVioapJbbFZY1CrarLQnIZN0SKkAlCIQiKE5Gd5ITk ksCoOUioFBTByGUQoZUUmUMYTJykoqXrJyUh5pFBK0pJ00IqUkkQkkp//9bANXgfin9ERM6obiU7 R3JSXMms26lQg8lMdVIzoAkpcNSGqWiYEhJTItiAouJPOqQSHmkpkKi1u4qJbqmJPCdpjUJKZbSN UwJmVL03Eb40UXO10SUrn4qREwAogwpvcDDRokpHMaFSbzxKT2g6NMpgD2SUraRqVIameVESmmOE lLxGoTR3TbiU+qSmTSAm1jhNtcBu7cJxykpeDyloNUznFxkpikpdo7JyFEJ5B0CSlyNE0DgFOYnT hMSPBJSiTwkAlOknhMYA80lLkSniUgQBqoAJKX7KQ4UWiDBSnwSUlfDvdI+CgCOTqozPHKfSPNJC 4bOniogRp4JGRwm1OiSmYRN2kN47oRAB8Ui8uOiSVccJo7BJuqafHhJC8FIAJbvBRSUycADpwm0A TADkpfFJS8gpgU89imCSV3BOx3Y8KMpBJCeNx3N4TWaj4pg6de6k9JQQzBlAaC989p1KsObAQqS3 eA7iZhJBZOqJe5/hqqtjpdKteqciyToOP7KrZRb6p2cDhJCIlRlOU0JJUnDoSATEJKX3SnDZCgpT AhJS5AAUSnJTJKXCYlSPEqBSUzaVJz54UOEgUlMgYSceCopSSkpnu0U2lA4Ug4pKZEydU4AhD4T7 klM9ohRKdrk7niUlMRKeE++OFEu0SUoBSDQUOU+5JTL6KRdIUJThySmUlO1yYyAo7klJQ7RRDo5U CZ1SlFCQ2aacJhYQoSlIKCWW9TFxiELgpAwkpO1/c8p9+h8ShNdqkXI2hmXnsmNk86qEnkJklJpK JXklsa8KsXFvCiClam47IJ1JTucDE6lVBqnJRtTdrtaBxr2TWZIcZAgqmHwmLpStTdbkAachMXs5 Zof5Spl5hMHTyhaqbdl4d7gAD3QHWTxyhbo0RGnXckpIWFrQeZ5CcuMAcKT8gSC3Q90K2zedxSUw tBaYKjKZzieVFBLPjlKByoEp5hJTOY5UQJKYvJTAkJKSbC3U8J3AA6GVAvJGqYuSU2L8c1QZBDhO iBMJOfugHsokpKZlwTTqoJSkpISmCgSlKSmUpTKjKUpKZQpcqO8ppSUySJnRQlKUlMi1wE9kgm3K JKSkjX7TKkXaz4oMpSkpI8ypM2hsnlBlKUlJHv3KCaUySl5STSkkpdIpkklLqbEMIjElJWqYUGog QSuEQIaIEEqGikopwipdIpFJJTB5Vd3KO/wVc8pIKVqIhtU0ULjhP5ppSKClHxTJ00JKUkkkipSQ STBJSikkU0IKXSSSSUpJJJJSpSSTIKUkkkkleU6ZOkhm1W6FUardPZJTerVlgVasqwwpyEyiVIBI hOUhcEJ2iM4oLkEoyVAqRUSgkMChkohQyoZMgWlJMUlGvXSSlKULSsU3KeUxRUqEkikgp//X53U6 9k7tNY0UdDolIHkkuXDZ54Uw8sB299ENImUlLg+CcPA1HKYEBImOElLTBlPEqMhSJPASUvt7pg6R 4JzxEqG6ElJq7C0yEV5ZaC53td5fnKtPklKSl2t1UolD80pjhJDIHulPhoo7k4OiSVCeE5EcnlMC ToO6dJSxTmJ0TBOGGJHCSmU6bTwoSngxM6Jx2nhJTFKAncZMgQEySlFyW5ODHCiBCSlaH4J4lLaO yfVJS+ndR3AnRLRJJTLb2SB2mPkmcfBMkpmKtzS6RAUeEuTAUra9joGo7FJTAgBLb4J2+JTh26B2 CSElVDS6HOgDWUPdpEfNMXtiACpPY5sbwRPCSVMsLAY7qI8AmlPuEpKZBoafd8k2+RCYgnukYaY/ FJCtANDqogpSpnjVJLAEa6JOPgmJAS4SUvKc6qIgpSkpUJ4TQnbzxI8EkM2xPkpvOmiFoT4BEdwI QUFiQdFXLgx+7xV3FYC8An4qn9O4tYBEooKV1LHtfZX7Q2PZ+8s+wguJHCvuZ6LS0OmRLv8A0ms9 x3GUkKdB4UUydJLJM5IJikpiknSSUqdEphJMUlLgpSopJKZEpSopJKSB0BRlRlJJTJSrdBlQlKUl J7iHGQgymJSSUzJlRJSSSUtKUpJklMpTSmSlJTKUpUZSlJSR1hIhNKhKUpKSSExKhKSSkgBOqcth IkQI5SCSmJKaVJMkpUwpF8iEwSKSlw+BCTj4KCUpKZbvFNKiU0pKZh0JbkNJJSYPHBUZQ0klJNya VCUklJA+E25QSSUk1TblGUySmRKUpkklLylKinSUqU8qKSSmUpSopJKZSmlMkkpdKUySSl5STJ0l KlKUySSl5SlMkkpdKUySSl5TSkkkpUpJJJKUkkkkpSSSSSlJJJJKXSSTJKXCI1DCm1JSVuqKENqI EEsh4qQUQJThBLNIJk/ZJSpTpkklI3lAPKK4oXdFBStUwhtKmkhdJJJFSkpSTIKXSKZJFSilKUSm 8klLpkpSQQoJ0kkkqSSTIKXTDwSTpKYp0ydJS4TpkpSUkarVSqsVulJTeqCtsEKpWYVlpTwhOFFy QMpiUVI3IDijOKC5BKMqBUyoFBIYlRKcqJKgkyBjCSeU0pi9UJk89kjwgpYgJoSlMilXmkkkgp// 0OeLwBEapMideEwcNpkSfFRElJcmea9ogEOn/oqDnTp2UTzqlAHKSlQYlKDElNu+5OXTzqElMmNa 5wB0HcpQ0TB76JhEjsE0Ez4DukhREDnVI6hNCcT34SSoQNEtEnAEgDUpxEwQkhYQmmFMw0As+aiI nVJShB5TgeCdpAKW81mG90ksRKcx8U0yn3EJIYyXFS4TSSpAwZ5SSotjlMdUjJ1hM3lJS8eaQCX4 wnbqkpbdAjxTNAOvCnWBuI58EMknVJDNruRPKToGgMqA9xT6HUJKVwlKW0wkAElLyeEyXKdpjzSU pqdz50OqYDcfBMNNElLpHRRlONeUlJKgAQT2KP1DNdlOAMAN4hVudEzvadNUlLhvE6BNOvimEu0l ORtJSSokDRJyTnbuUoI17JIWjWO6fRMDulL4pKWiE8T800Tql8ElMjwmg/m9uVHcSpS4DyKSViRE KTXFnChynBSQzZ5ojgefBQYC2CiuDncclApCzLSwO05Vdg3OgaT3U3GFW2vsftZyUVpZv5cH8zqF WuguJAgLRdX6IdURLyPpLOuDgYcIKSESdJJJK6YqQTFJTFMpJEJKWSKeEklMEycpJKUkkkkpSSSS SlJJJJKUnTJ4SUpJJJJSySSUJKWSTpJKWSSSSUpJJJJSkkkklMgVKVBPKSl5SlMlKSmYKYlRlKUl KlNKSSSlJkkklKSSSSUpJJJJSkkkklKSSSSUpJJJJSkkkklKSSSSUpJJJJSkkkklKSSSSUpJJJJS kkkklKSSSSUpJJJJSkkkklKSSSSUpJJJJSkkkklKSSSSUpOmSSUumTpklLhTCgERqSkrUSVBqIE1 LJqcJgE4SSuE8Jk/kipQTOTqLkFI3IXdEch90UFI1TlQaphJC6SZOAkpSZOmRUo8pvgnKSSlkgkU klKSSKSCF4STJR4pJXTJSkgpSSSSSlkuEkpSUunTJ0lM2q3SqrVZqSU3qyrTCqbCjtcnIbQUXFDD k8kpymLihOKKUJyCWBKGVMqBQSGJUSnKgSoZMoUUyRKSjXKTFOlKSVkydOgpZJSASSU//9HmpJTh 0cJvgnDQOUly0z8UeqkWzJ93ZD9oB0klIuSUsWFhIPblOBPJSaSOU2pSQye1v5qbcQNo7pAlO1xA hJS2p7JiPHhKT24TNEpKZbhB80gYTEhSNTwz1D9GYSUwLpMpEqOqm0Tykpkxyd4I5EaKGnI4RN24 QefFJSMacpAnsmJIMHlT2jbun3E8JKRgqQa4iY0TBTPhKSlpLeVGZSPlqpMjukpfUfNNGsTwk9pb 9OQTwmAnukpU7U3OifbpPZKUlK2kKc+wt7BQJ7qQJiew5SUsBrDkxg8cJ3PLjJ1KYaiUlKMu40Tk HmEkx8klLgE8KJGqkDHHdR3RykpfaD8U4ZBg8JFw7JnOkQUlLg6mOEwOsOSJiAmOqSmWmscKACcG OEg0udCSmTIjVO4+1QILSR4JcpKWmU86pRqmOiSl5SaZ0UQE8d0lLkawE54TDUyeFGYOqSVaqRTv duAHYJmjuOEkJGukbUUuLdUMDv4ohMgeSBSEHI15URaa3jbyVLgT3Q2sYX+4kQiFpSvBDzJ1Hgqe Va65253wV19pNk16BrYVPJG0hszpKSGukAnIhJJK8KKlKiUlLSnlRTpKXSTJJKUU0J0klMUk6ZJS kkk4SUuAlCSdJSySSSSlJkkklKSSSSUpKEk6SmKSSSSlkkkklKSSSSUpOmTwkpSSeEoSUsknhKEl LJlKEoSUxSTwlCSlkkkklKSSSSUpJJJJSkkkklKSSSSUpJJJJSkkkklKSSSSUpJJJJSkkkklKSSS SUpJJJJSkkkklKSSSSUpOkkkpZJOmSUpJJJJSkkkklKSSSSUpJJJJS6ZOmSUyCmxQCmElJmojUNq k3lNSlCdMkklmEiEzY+aclFSyi5SUXJKROQxyiPQgkhKFJRapJIXSSlJJS8pkkkVKS4SSSUtKSSS SlJBJMgpcJcpJJKUkkmSUulKSZJSvJIJJJKXCdMkElJWhWWFVW6qzVqgptMVhiDW1WmNTlLtCmnA SciEI3FCKI5CcklGVEqRUCgkMSVEpOUZUMmULpkkhqo1yk3KflJBKkk6UJKUkl8UklP/0ua15Tbi pOrLJB7d1EADhJLLcW+Skwt5Khzqp1gEjRJTFzvBME5TtaSCSNAkpfZPJTEwkSITDVJSvpcJwDGq TiAfam3GI8ElMi0eMyk4aDuFEGEi4pKVwE/IKhyp9oCSmMqW7uo8KcgtghJS30vilCW5S27huPAS UtJiE0RyojyTtJGhSUuSk1PuEaJo7pKZWvNhG7WBAUDICXJSIjnhJTLmB2Uri327REDVC7pyT80l KHmlPZSPu1KiTPCSlm+acBNBCQMaBJTJsA6pnHXTgpCPzlL0xsLgdRwPFJSxcDHknY8NaRGp7qBC cADlJS3JUhoU3eU7WudwElM5LYJEyo2WF7i5ynXj2P4H3orcdtX04c7wSUjooNx5geKubMapsRvd 4qrZY4nsB4BDeSEVLPILpaIHgnJNTdQPcEKVIgmEFLN7kpSCna6DPgltmSfkkpidEwJ7BIyU8eHK SlmlEZZtO4iShxHxTgpKU524k+KcAu0HKiTKQmJCSkjHHsrDzIJmICrAHkIzhLUlBFEhBI9wnujk oFxBcCEggpXuZMzECAAqbhMq441vB3cgdkDJLS4FggQkhrlNCR5SCSVyFEqcqBSUxTpk6SlJJJJK WSSSSUskknhJSycJEJBJS6cpJikpZPCYIjQkpjtShF2qJCSkcJkQhRISUxTpk6SlkycpklLJJJJK UkknASUqFMBIBSSUtCZSSISUwKZOUySlJ0ySSl0kydJS0JiFJIhJTBJOQmSUpJJJJSkkkklKSSSS UpJJJJSkkkklKSSSSUpJJJJSkkkklKSSSSUpJJJJSkkkklKSSTpKUkkkkpSSSSSlkkkklKSSSSUp JJJJSkkkklLpJJklMgiBDaihJSRqkFEKQQSkCcpgnKCVA6qSYeKSKl1ElSUSkpC9DCI9DCS1KFJR CkipdKUydBSpTJ0xRUpJJJJS4CRHgm1TeaSF0kkkEqSSSSUopSm4TpKUkmSSUpJJJJS6cJk4QUza rdKqt8lbpSS3agrDVXrVhqeFqQJEJBM4oqRuQXaojkJyCWBUHKZUCgkI3FDlEKGQopMsVSn3JoSh RFeqQpSowUkFMpSJUEkVLpJpSSU//9k ________________________________________________________________________________
Subject: F697 thickness? (hat section in front deck structure)
Date: Dec 09, 2007
Any -7 tipup builders out there that just received their finish kit? I'm working on the front deck of the fuse & I'd like to fit the F-643-1 center channel, but it butts against a flange of the F697 hat section & this piece is included in the finish kit, not the fuse kit. Can someone measure the material thickness of the F697 for me? Thanks, Charlie ________________________________________________________________________________
Date: Dec 09, 2007
.040 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of ceengland(at)bellsouth.net Sent: Sunday, December 09, 2007 10:34 AM Subject: RV-List: F697 thickness? (hat section in front deck structure) Any -7 tipup builders out there that just received their finish kit? I'm working on the front deck of the fuse & I'd like to fit the F-643-1 center channel, but it butts against a flange of the F697 hat section & this piece is included in the finish kit, not the fuse kit. Can someone measure the material thickness of the F697 for me? Thanks, Charlie ________________________________________________________________________________
Date: Dec 09, 2007
Subject: Re: KLX-135A Internal Battery
In a message dated 12/9/2007 7:32:01 A.M. Pacific Standard Time, denis.walsh(at)comcast.net writes: Post Post script. If he will do it for an hours labor, I would go for it, unless you have some credentials as a solderer with circuit board endorsement. You could encourage such an agreement by showing up with it in your hand so it is just bench work, IMHO. ================================================== Denis- Cool. As it turns out I was trained exactly for this task by Uncle Sam back in my previous life as a GCA radar tech in the USAF, so have no problem at all doing the work. I work in the defense electronics business these days so we have all of the soldering and desoldering tools to do the work laying around in the lab. I will see if the shop can order a battery for me, or I'll pull it out and examine it to see if I can Google a replacement. -Thx N1GV (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley) **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) ________________________________________________________________________________
Date: Dec 09, 2007
Subject: Re: F697 thickness? (hat section in front deck structure)
Great; I'll make a shim to simulate the hat section & I can match drill the rest of the structure. Charlie Bob Collins wrote: > > .040 > > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of > ceengland(at)bellsouth.net > Sent: Sunday, December 09, 2007 10:34 AM > To: rv7-list(at)matronics.com > Subject: RV-List: F697 thickness? (hat section in front deck structure) > > > Any -7 tipup builders out there that just received their finish kit? > > I'm working on the front deck of the fuse & I'd like to fit the F-643-1 > center channel, but it butts against a flange of the F697 hat section & this > piece is included in the finish kit, not the fuse kit. > > Can someone measure the material thickness of the F697 for me? > > Thanks, > > Charlie > ________________________________________________________________________________
Date: Dec 09, 2007
Subject: GRETZ AERO ELECTRIC TRIM MOD FOR RV-4
I purchased Gretz Aero's electric trim modification for my RV-4. I am finally getting around to installing it and I am having difficulty trying to install the 24 inch "push-pull" cable. It seem to me that a 20 inch cable would be about the longest I could install. Have any of you RV-4 builders used Warren's kit? If so, any pictures or plans? All I have seen is the installation in an RV-6. I have tried without success to contact Gretz Aero by phone and email as listed on the web site. Any comments would certainly be welcomed! Happy Flying Safely, Wally Hunt Rockford, IL RV-4 Finishing Kit **************************************Check out AOL's list of 2007's hottest products. (http://money.aol.com/special/hot-products-2007?NCID=aoltop00030000000001) ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Subject: Off Topic: Hanger Lighting
Date: Dec 10, 2007
I am building a new hanger on my house and was looking for information on what type of hanger lighting to install. The ceilings will be 16' tall and it is 44' x 60'. I would like good work lighting throughout. Also, if anyone knows of the light spacing it would help. Thanks -Mike Kraus RV-4 Flying RV-10 wiring ________________________________________________________________________________
Date: Dec 10, 2007
Mike, Just some advice...go to an industrial lighting shop. You will need to define what you need the lighting for. Are you just illuminating the area so you don't trip over the dog? Are you lighting it for general housekeeping, such as moving equipment around and stacking things? Are you lighting it for fine work, such as reading prints and diagrams and working on wires, and things that require good light to enable good vision? They may even suggest providing high quality lighting in the work area and lower intensity lighting in the balance of the hangar. They will also look at your ceiling height and determine the correct diffuser to use to distribute light and to prevent shadows...a big deal if you are doing maintenance. A quality job only costs a little more but you'll pay dearly if you put some crappy home-brew lights in the hangar if you use it for anything but a place to park your airplane. Just a thought. Chuck -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Michael Kraus Sent: Monday, December 10, 2007 8:02 AM Subject: RV-List: Off Topic: Hanger Lighting I am building a new hanger on my house and was looking for information on what type of hanger lighting to install. The ceilings will be 16' tall and it is 44' x 60'. I would like good work lighting throughout. Also, if anyone knows of the light spacing it would help. Thanks -Mike Kraus RV-4 Flying RV-10 wiring ________________________________________________________________________________
Subject: EZ-1 Alt. hold
Date: Dec 10, 2007
Bert The installation of the EZ Alt hold was realitivly easy. I am not flying so I can't give info on that yet. Frank @ SGu RV7A ...........NDY.............. > Date: Mon, 10 Dec 2007 09:19:45 -0500> From: bertrv6(at)gmail.com> To: rv-li st(at)matronics.com> Subject: RV-List: EZ-1 Alt. hold> > --> RV-List message p osted by: "Bert Murillo" > > Hi;> > Wopuld like to hear comments on the EZ-1 Altitude Hold, Installation> easy of use etc...> > Ver sus the Altrac Unit, Prices are way up for both of course....> > > Thanks,> -======================== ===========> > > ________________________________________________________________________________
Date: Dec 10, 2007
Subject: Re: Off Topic: Hanger Lighting
Hi Michael, I can't speak about hangar lighting specifically, but I'll share my experiences w/ lighting the garage. I initially went with some dual florescenct bulb fixtures (40 watt, I believe) that hung from an 8' ceiling about one foot. Sadly, they just didn't quite put out the kind of light I was wanting. Especially if I was going to be working under them. And, admittedly, I was a little tight in the wallet when I purchased them. I eventually replaced the above units w/ some dual flourescent 8 foot, 96 watt bulbs (F96T12 bulbs). The fixtures attached to the ceiling. At the time (~4 yrs ago), the fixture and bulbs were about $50 per setup at Lowes. Also, the nice thing about the F96T12 bulbs is that you don't have insert-and-twist to install them. They use the spring loaded setup that works axially; so it's more of a stab-and-release operation. About a year ago I helped a friend replace some 2'x2' units in his office. The new units used some little skinny flourescent bulbs (~3/4 of the diameter of the traditional flourescent bulbs) that relied on electronics rather than ballasts to operate. When we 1st turned them on, we couldn't help but notice how bright they were. Don't know if they exist in the longer versions or not, but you might consider them. Also, since you're installing in a hangar (and with a high ceiling that is probably dark and does not reflect any light), I'd consider adding some kind of reflector that covers the top of the fixture to relect light back down where it's needed/wanted. No sense wasting light upwards. Good luck, /\/elson RV-7A - Fuse (getting close to the canopy work) Austin, TX On Mon, 10 Dec 2007, Michael Kraus wrote: > > > I am building a new hanger on my house and was looking for information on > what type of hanger lighting to install. The ceilings will be 16' tall and > it is 44' x 60'. I would like good work lighting throughout. Also, if > anyone knows of the light spacing it would help. > > Thanks -Mike Kraus RV-4 Flying RV-10 wiring > > ________________________________________________________________________________
Date: Dec 10, 2007
Subject: Re: EZ-1 Alt. hold
Bert Murillo wrote: > > Hi; > > Wopuld like to hear comments on the EZ-1 Altitude Hold, Installation > easy of use etc... > > Versus the Altrac Unit, Prices are way up for both of course.... Bert, here are articles detailing my experiences with both devices: http://thervjournal.com/altrak.htm http://thervjournal.com/EZ-2.htm Bottom line, they both work nicely. The EZ-1 has more capacity for being calibrated to your preferences and can be easily upgraded to an even more feature-rich unit. The servos for each system are also very different with the EZ servo being lighter and it also is more advanced in the way it communicates with the control unit. Installation is similar for both systems. You can download all the manuals from each manufacturer's web site. Sam Buchanan ________________________________________________________________________________
Date: Dec 10, 2007
What was suggested to me as the cheapest and simplest way to get good lighting is to use those mercury vapor yard lights. You can just tape over the light sensor, or I rewired mine around the sensor. Lots of light, they only cost about $25 each, and they are not sensitive to cold as fluorescents are. brian -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Monday, December 10, 2007 8:02 AM Subject: RV-List: Off Topic: Hanger Lighting I am building a new hanger on my house and was looking for information on what type of hanger lighting to install. The ceilings will be 16' tall and it is 44' x 60'. I would like good work lighting throughout. Also, if anyone knows of the light spacing it would help. Thanks -Mike Kraus RV-4 Flying RV-10 wiring 11:06 AM 11:06 AM ________________________________________________________________________________
Date: Dec 10, 2007
If this is not a heated area I would not recommend using the 8' fluorescents. They do not respond as well to colder weather as they flicker. You can use 4' fixtures with light shields (ceiling height) but there are better options. Lowes and Home Depot sell a 65 watt fluorescent area light that is round and has a parabolic type reflective lens. We have many hangars here at our airpark that uses these including mine. A new hangar was just built and 9 of these were spaced out in there which provides excellent lighting in this hangar. The cost for these is around $44each. We have some metal hangars that have very high ceilings and the same light were used but were mounted on a metal extension to get the light down to about 10-12 feet off the floor. I am not an engineer and I didn't stay in a Holiday Inn Express last night but I did spend over 20 years installing lighting systems in both residential and commercial applications. I used these lights in my hangar and they work well. Tim > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of David Nelson > Sent: Monday, December 10, 2007 8:41 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Off Topic: Hanger Lighting > > > > Hi Michael, > > I can't speak about hangar lighting specifically, but I'll share my > experiences > w/ lighting the garage. > > I initially went with some dual florescenct bulb fixtures (40 watt, I > believe) > that hung from an 8' ceiling about one foot. Sadly, they just didn't > quite put > out the kind of light I was wanting. Especially if I was going to be > working > under them. And, admittedly, I was a little tight in the wallet when I > purchased them. > > I eventually replaced the above units w/ some dual flourescent 8 foot, 96 > watt > bulbs (F96T12 bulbs). The fixtures attached to the ceiling. At the time > (~4 > yrs ago), the fixture and bulbs were about $50 per setup at Lowes. Also, > the > nice thing about the F96T12 bulbs is that you don't have insert-and-twist > to > install them. They use the spring loaded setup that works axially; so > it's > more of a stab-and-release operation. > > About a year ago I helped a friend replace some 2'x2' units in his office. > The > new units used some little skinny flourescent bulbs (~3/4 of the diameter > of > the traditional flourescent bulbs) that relied on electronics rather than > ballasts to operate. When we 1st turned them on, we couldn't help but > notice > how bright they were. Don't know if they exist in the longer versions or > not, > but you might consider them. > > Also, since you're installing in a hangar (and with a high ceiling that is > probably dark and does not reflect any light), I'd consider adding some > kind of > reflector that covers the top of the fixture to relect light back down > where > it's needed/wanted. No sense wasting light upwards. > > Good luck, > > /\/elson > RV-7A - Fuse (getting close to the canopy work) > Austin, TX > > > > On Mon, 10 Dec 2007, Michael Kraus wrote: > > > > > > > > > > I am building a new hanger on my house and was looking for information > on > > what type of hanger lighting to install. The ceilings will be 16' tall > and > > it is 44' x 60'. I would like good work lighting throughout. Also, if > > anyone knows of the light spacing it would help. > > > > Thanks -Mike Kraus RV-4 Flying RV-10 wiring > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 10, 2007
I have a standard T hangar. I have 4 typical 2 bulb florescent fixtures, but I suspended them from the ceiling to where they are about 10' high or so. Plenty of light to do just about anything. I have them over the wings, and over the tail. I may add one more over the middle of the fuse, but 4 seems to be fine. Cheap and very effective. Obviously the work bench would need a suspended light above it as well. Also, if you can epoxy the floor that would help if you used white or light grey. Paul Besing ----- Original Message ---- From: Michael Kraus <n223rv(at)wolflakeairport.net> Sent: Monday, December 10, 2007 6:01:33 AM Subject: RV-List: Off Topic: Hanger Lighting I am building a new hanger on my house and was looking for information on what type of hanger lighting to install. The ceilings will be 16' tall and it is 44' x 60'. I would like good work lighting throughout. Also, if anyone knows of the light spacing it would help. Thanks -Mike Kraus RV-4 Flying RV-10 wiring Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Dec 10, 2007
Subject: Trio Customer Service
Hey all..quick note. Have an EZ Pilot in my RV-4. Put it in about a year +. It quit holding a course and would engage and disengage the servo. I called trio, they said, "another one is on the way". 2 Days later I had a new one. They said to ship the other back when I had the chance. I installed it, it was programmed already for my aircraft, and it worked perfectly. Absolutely wonderful customer service. Don't forget those guys when you are building your panel. Paul Besing RV-4 N73DD Looking for last minute shopping deals? ________________________________________________________________________________
Date: Dec 10, 2007
Mike, I see you have received quite a bit of info on hangar lighting. However, you should check with your county/city inspector about hangar lighting requirements before proceeding. When I built my hangar next to my home, in a private residential airpark, the county required me to put in special lighting fixtures that meet a national code.Did not make me happy but I had no choice. They would not give me a Certificate of Occupancy without the approved lighting. This may be especially true if you live in a residential area, such as an airpark, but they told me there is now a national code that covers all airplane hangars. A friend tried getting around the requirement by calling the building a storage building. But, when the inspector came out he saw the hangar door and the 'storage building' claim went down the drain. Good luck! Dale Ensing ----- Original Message ----- From: "Michael Kraus" <n223rv(at)wolflakeairport.net> Sent: Monday, December 10, 2007 8:01 AM Subject: RV-List: Off Topic: Hanger Lightingn > > > I am building a new hanger on my house and was looking for information on > what type of hanger lighting to install. The ceilings will be 16' tall > and it is 44' x 60'. I would like good work lighting throughout. Also, > if anyone knows of the light spacing it would help. > > Thanks > -Mike Kraus > RV-4 Flying > RV-10 wiring > > ________________________________________________________________________________
Date: Dec 10, 2007
It depends on where you are. In cold weather florescent lights are not too usefull. the take a long time to warm up and then are nto as bright as they neomaly are in the warmer months. Up her in theh Colorado high country, I have found that a mercury vapor hi bay frxture works best. thy take a few minutes to get goiong but when they light it is bright. Jim Carey _____ From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Paul Besing Sent: Monday, December 10, 2007 8:39 AM Subject: Re: RV-List: Off Topic: Hanger Lighting I have a standard T hangar. I have 4 typical 2 bulb florescent fixtures, but I suspended them from the ceiling to where they are about 10' high or so. Plenty of light to do just about anything. I have them over the wings, and over the tail. I may add one more over the middle of the fuse, but 4 seems to be fine. Cheap and very effective. Obviously the work bench would need a suspended light above it as well. Also, if you can epoxy the floor that would help if you used white or light grey. Paul Besing ----- Original Message ---- From: Michael Kraus <n223rv(at)wolflakeairport.net> Sent: Monday, December 10, 2007 6:01:33 AM Subject: RV-List: Off Topic: Hanger Lighting I am building a new hanger on my house and was looking for information on what type of hanger lighting to install. The ceilings will be 16' tall and it is 44' x 60'. I would like good work lighting throughout. Find them fast with Yahoo! Search. __________ NOD32 2713 (20071210) Information __________ ________________________________________________________________________________
Date: Dec 10, 2007
You might epoxy coat the floor with a light color paint. It will double the effectiveness of any lighting fixtures. Bruce www.Glasair.org -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Chuck Jensen Sent: Monday, December 10, 2007 8:47 AM Subject: RE: RV-List: Off Topic: Hanger Lighting Mike, Just some advice...go to an industrial lighting shop. You will need to define what you need the lighting for. Are you just illuminating the area so you don't trip over the dog? Are you lighting it for general housekeeping, such as moving equipment around and stacking things? Are you lighting it for fine work, such as reading prints and diagrams and working on wires, and things that require good light to enable good vision? They may even suggest providing high quality lighting in the work area and lower intensity lighting in the balance of the hangar. They will also look at your ceiling height and determine the correct diffuser to use to distribute light and to prevent shadows...a big deal if you are doing maintenance. A quality job only costs a little more but you'll pay dearly if you put some crappy home-brew lights in the hangar if you use it for anything but a place to park your airplane. Just a thought. Chuck -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Michael Kraus Sent: Monday, December 10, 2007 8:02 AM Subject: RV-List: Off Topic: Hanger Lighting I am building a new hanger on my house and was looking for information on what type of hanger lighting to install. The ceilings will be 16' tall and it is 44' x 60'. I would like good work lighting throughout. Also, if anyone knows of the light spacing it would help. Thanks -Mike Kraus RV-4 Flying RV-10 wiring ________________________________________________________________________________
Subject: Re: Trio Customer Service
Date: Dec 10, 2007
I agree that they are very good. My EZ-Pilot allowed me to fly eight hours in one day recently with minimal fatigue other than a sore derrierre. Now I need to get the altitude hold to make long cross-countries even easier. Ron Lee ----- Original Message ----- From: Paul Besing To: rv-list(at)matronics.com Sent: Monday, December 10, 2007 8:41 AM Subject: RV-List: Trio Customer Service Hey all..quick note. Have an EZ Pilot in my RV-4. Put it in about a year +. It quit holding a course and would engage and disengage the servo. I called trio, they said, "another one is on the way". 2 Days later I had a new one. They said to ship the other back when I had the chance. I installed it, it was programmed already for my aircraft, and it worked perfectly. Absolutely wonderful customer service. Don't forget those guys when you are building your panel. Paul Besing RV-4 N73DD Find them fast with Yahoo! Search. ________________________________________________________________________________
Date: Dec 10, 2007
From: "David E. Nelson" <david.nelson(at)pobox.com>
Hi Tim, Good point on temps. I do notice it takes a couple of minutes for them to warm up and brighten up. I've also observed that the same applies to the standard length units also but admittedly I've never compared the two. By the time I get the kerosene heater going and the garage warmed up in the cooler months, the lights are good to go. ? - Why wouldn't the 65 watt fluorescent units that you talk about below suffer from the same effects (or is it affects)? Regards, /\/elson On Mon, 10 Dec 2007, Tim Bryan wrote: > > If this is not a heated area I would not recommend using the 8' > fluorescents. They do not respond as well to colder weather as they > flicker. You can use 4' fixtures with light shields (ceiling height) but > there are better options. Lowes and Home Depot sell a 65 watt fluorescent > area light that is round and has a parabolic type reflective lens. We have > many hangars here at our airpark that uses these including mine. A new > hangar was just built and 9 of these were spaced out in there which provides > excellent lighting in this hangar. The cost for these is around $44each. > We have some metal hangars that have very high ceilings and the same light > were used but were mounted on a metal extension to get the light down to > about 10-12 feet off the floor. > > I am not an engineer and I didn't stay in a Holiday Inn Express last night > but I did spend over 20 years installing lighting systems in both > residential and commercial applications. I used these lights in my hangar > and they work well. > > Tim > >> -----Original Message----- >> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- >> server(at)matronics.com] On Behalf Of David Nelson >> Sent: Monday, December 10, 2007 8:41 AM >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: Off Topic: Hanger Lighting >> >> >> >> Hi Michael, >> >> I can't speak about hangar lighting specifically, but I'll share my >> experiences >> w/ lighting the garage. >> >> I initially went with some dual florescenct bulb fixtures (40 watt, I >> believe) >> that hung from an 8' ceiling about one foot. Sadly, they just didn't >> quite put >> out the kind of light I was wanting. Especially if I was going to be >> working >> under them. And, admittedly, I was a little tight in the wallet when I >> purchased them. >> >> I eventually replaced the above units w/ some dual flourescent 8 foot, 96 >> watt >> bulbs (F96T12 bulbs). The fixtures attached to the ceiling. At the time >> (~4 >> yrs ago), the fixture and bulbs were about $50 per setup at Lowes. Also, >> the >> nice thing about the F96T12 bulbs is that you don't have insert-and-twist >> to >> install them. They use the spring loaded setup that works axially; so >> it's >> more of a stab-and-release operation. >> >> About a year ago I helped a friend replace some 2'x2' units in his office. >> The >> new units used some little skinny flourescent bulbs (~3/4 of the diameter >> of >> the traditional flourescent bulbs) that relied on electronics rather than >> ballasts to operate. When we 1st turned them on, we couldn't help but >> notice >> how bright they were. Don't know if they exist in the longer versions or >> not, >> but you might consider them. >> >> Also, since you're installing in a hangar (and with a high ceiling that is >> probably dark and does not reflect any light), I'd consider adding some >> kind of >> reflector that covers the top of the fixture to relect light back down >> where >> it's needed/wanted. No sense wasting light upwards. >> >> Good luck, >> >> /\/elson >> RV-7A - Fuse (getting close to the canopy work) >> Austin, TX >> >> >> >> On Mon, 10 Dec 2007, Michael Kraus wrote: >> >> >>> >>> >>> >>> I am building a new hanger on my house and was looking for information >> on >>> what type of hanger lighting to install. The ceilings will be 16' tall >> and >>> it is 44' x 60'. I would like good work lighting throughout. Also, if >>> anyone knows of the light spacing it would help. >>> >>> Thanks -Mike Kraus RV-4 Flying RV-10 wiring >>> >>> >>> >>> >>> >>> >>> >> >> > > -- ~~ The early bird may get the worm, but the second mouse gets the cheese. ~~ ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Date: Dec 10, 2007
Mike, In my hanger I have the T-12 cold weather 8' units. Great lighting, work in cold fine, easy to replace, just started replacing bulbs after 3 1/2 years continual use, pricey but great lighting. Lowe's carries the 8' fixture and bulbs(green ends and they just push in, no twisting). In my work areas I have added specific lighting to the situation. Bandsaw, lathe, drill press (dangerous areas) have separate lighting on switches. I would not hang any lighting on the 16' ceiling though. Lighting disperses geometrically. So whatever lighting that you choose, suspend it from some cheap chain and lower it to about 2-3 feet above your highest point on the floor, ie tail of plane. Reflectors are cheaper than lighting units and you will save electricity which equals $. More $ to spend on RV's. Remember, whatever lighting that you put in, you will not want to replace anytime soon, if ever, by lowering your units, maintenance will be easier also, unless you just happen to have a 16' step ladder. Mike H 9A/8A ----- Original Message ----- From: "Michael Kraus" <n223rv(at)wolflakeairport.net> Sent: Monday, December 10, 2007 8:01 AM Subject: RV-List: Off Topic: Hanger Lighting > > > I am building a new hanger on my house and was looking for information on > what type of hanger lighting to install. The ceilings will be 16' tall > and it is 44' x 60'. I would like good work lighting throughout. Also, > if anyone knows of the light spacing it would help. > > Thanks > -Mike Kraus > RV-4 Flying > RV-10 wiring > > > ________________________________________________________________________________
Date: Dec 10, 2007
Absolutely. I'd give up my EZ pilot before I gave up my altitude hold, for comfortable x/c flying. Trio is first-rate. If/when they interface with the GRT EFIS systems for full functionality (tru-trak is the favorite with GRT for now) I'll be totally content (and perhaps finish my panel upgrade to all-glass.) -Stormy On Dec 10, 2007 11:52 AM, Ron Lee wrote: > I agree that they are very good. My EZ-Pilot allowed me to fly eight > hours > in one day recently with minimal fatigue other than a sore derrierre. > > Now I need to get the altitude hold to make long cross-countries even > easier. > > Ron Lee > > ----- Original Message ----- > *From:* Paul Besing > *To:* rv-list(at)matronics.com > *Sent:* Monday, December 10, 2007 8:41 AM > *Subject:* RV-List: Trio Customer Service > > Hey all..quick note. Have an EZ Pilot in my RV-4. Put it in about a > year +. It quit holding a course and would engage and disengage the servo. > I called trio, they said, "another one is on the way". 2 Days later I had a > new one. They said to ship the other back when I had the chance. I > installed it, it was programmed already for my aircraft, and it worked > perfectly. Absolutely wonderful customer service. Don't forget those guys > when you are building your panel. > > Paul Besing > RV-4 N73DD > > > Find them fast with Yahoo! Search. > > * > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > * > > ________________________________________________________________________________
Date: Dec 10, 2007
Get the T8 bulbs available at almost any major hardware with, I can't remember exactly, but I think they're called bright or brilliant white. 20,000 hour lifetime, relatively cheap, don't buzz and instant on. Everyone who's built a hanger since mine was built has installed these and are very happy...and so am I. Chuck ----- Original Message ----- From: "David E. Nelson" <david.nelson(at)pobox.com> Sent: Monday, December 10, 2007 9:25 AM Subject: RE: RV-List: Off Topic: Hanger Lighting > > > Hi Tim, > > Good point on temps. I do notice it takes a couple of minutes for them to > warm up and brighten up. I've also observed that the same applies to the > standard length units also but admittedly I've never compared the two. > > By the time I get the kerosene heater going and the garage warmed up in > the cooler months, the lights are good to go. > > ? - Why wouldn't the 65 watt fluorescent units that you talk about below > suffer from the same effects (or is it affects)? > > Regards, > /\/elson > > On Mon, 10 Dec 2007, Tim Bryan wrote: > >> >> If this is not a heated area I would not recommend using the 8' >> fluorescents. They do not respond as well to colder weather as they >> flicker. You can use 4' fixtures with light shields (ceiling height) but >> there are better options. Lowes and Home Depot sell a 65 watt >> fluorescent >> area light that is round and has a parabolic type reflective lens. We >> have >> many hangars here at our airpark that uses these including mine. A new >> hangar was just built and 9 of these were spaced out in there which >> provides >> excellent lighting in this hangar. The cost for these is around $44each. >> We have some metal hangars that have very high ceilings and the same >> light >> were used but were mounted on a metal extension to get the light down to >> about 10-12 feet off the floor. >> >> I am not an engineer and I didn't stay in a Holiday Inn Express last >> night >> but I did spend over 20 years installing lighting systems in both >> residential and commercial applications. I used these lights in my >> hangar >> and they work well. >> >> Tim >> >>> -----Original Message----- >>> From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- >>> server(at)matronics.com] On Behalf Of David Nelson >>> Sent: Monday, December 10, 2007 8:41 AM >>> To: rv-list(at)matronics.com >>> Subject: Re: RV-List: Off Topic: Hanger Lighting >>> >>> >>> >>> Hi Michael, >>> >>> I can't speak about hangar lighting specifically, but I'll share my >>> experiences >>> w/ lighting the garage. >>> >>> I initially went with some dual florescenct bulb fixtures (40 watt, I >>> believe) >>> that hung from an 8' ceiling about one foot. Sadly, they just didn't >>> quite put >>> out the kind of light I was wanting. Especially if I was going to be >>> working >>> under them. And, admittedly, I was a little tight in the wallet when I >>> purchased them. >>> >>> I eventually replaced the above units w/ some dual flourescent 8 foot, >>> 96 >>> watt >>> bulbs (F96T12 bulbs). The fixtures attached to the ceiling. At the >>> time >>> (~4 >>> yrs ago), the fixture and bulbs were about $50 per setup at Lowes. >>> Also, >>> the >>> nice thing about the F96T12 bulbs is that you don't have >>> insert-and-twist >>> to >>> install them. They use the spring loaded setup that works axially; so >>> it's >>> more of a stab-and-release operation. >>> >>> About a year ago I helped a friend replace some 2'x2' units in his >>> office. >>> The >>> new units used some little skinny flourescent bulbs (~3/4 of the >>> diameter >>> of >>> the traditional flourescent bulbs) that relied on electronics rather >>> than >>> ballasts to operate. When we 1st turned them on, we couldn't help but >>> notice >>> how bright they were. Don't know if they exist in the longer versions >>> or >>> not, >>> but you might consider them. >>> >>> Also, since you're installing in a hangar (and with a high ceiling that >>> is >>> probably dark and does not reflect any light), I'd consider adding some >>> kind of >>> reflector that covers the top of the fixture to relect light back down >>> where >>> it's needed/wanted. No sense wasting light upwards. >>> >>> Good luck, >>> >>> /\/elson >>> RV-7A - Fuse (getting close to the canopy work) >>> Austin, TX >>> >>> >>> >>> On Mon, 10 Dec 2007, Michael Kraus wrote: >>> >>> >>>> >>>> >>>> >>>> I am building a new hanger on my house and was looking for information >>> on >>>> what type of hanger lighting to install. The ceilings will be 16' tall >>> and >>>> it is 44' x 60'. I would like good work lighting throughout. Also, if >>>> anyone knows of the light spacing it would help. >>>> >>>> Thanks -Mike Kraus RV-4 Flying RV-10 wiring >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >> >> >> >> >> >> >> > > -- > ~~ The early bird may get the worm, but the second mouse gets the cheese. > ~~ > > > -- > 269.17.0/1180 - Release Date: 12/10/2007 2:51 PM > > ________________________________________________________________________________
Subject: Trio EZ-Pilot or Altitude Hold
Date: Dec 10, 2007
Bill, perhaps I misread your post. If I had to have only one of the two, I would pick the EZ-Pilot (wing leveler/follow GPS course). Besides following a course perfectly, it adds the safety of a wing leveler IF I ever enter clouds, a 180 degree option if you enter clouds plus other functions. I can maintain altitude semi-well without an altitude hold and not flying it but an altitude hold with the EZ-Pilot (two axis control) would be ideal. Ron Lee ----- Original Message ----- From: Bill Boyd To: rv-list(at)matronics.com Sent: Monday, December 10, 2007 10:48 AM Subject: Re: RV-List: Trio Customer Service Absolutely. I'd give up my EZ pilot before I gave up my altitude hold, for comfortable x/c flying. Trio is first-rate. If/when they interface with the GRT EFIS systems for full functionality (tru-trak is the favorite with GRT for now) I'll be totally content (and perhaps finish my panel upgrade to all-glass.) -Stormy On Dec 10, 2007 11:52 AM, Ron Lee wrote: I agree that they are very good. My EZ-Pilot allowed me to fly eight hours in one day recently with minimal fatigue other than a sore derrierre. Now I need to get the altitude hold to make long cross-countries even easier. Ron Lee ----- Original Message ----- From: Paul Besing To: rv-list(at)matronics.com Sent: Monday, December 10, 2007 8:41 AM Subject: RV-List: Trio Customer Service Hey all..quick note. Have an EZ Pilot in my RV-4. Put it in about a year +. It quit holding a course and would engage and disengage the servo. I called trio, they said, "another one is on the way". 2 Days later I had a new one. They said to ship the other back when I had the chance. I installed it, it was programmed already for my aircraft, and it worked perfectly. Absolutely wonderful customer service. Don't forget those guys when you are building your panel. Paul Besing RV-4 N73DD Find them fast with Yahoo! Search. href="http://www.matronics.com/contribution">http://www.matronics.com/c href=" http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navi gator?RV-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 10, 2007
The National Electrical Code (NEC) has covered airplane hangars for a long time. More than 30 years that I know of. It covers all airplane hangars but a common mistake is the whole hangar is not classified the same. All wiring above a classified area must be in metal conduit however there is not a specific restriction on the lighting unless it is in the classified area. The area classification is premised on the fuel in the airplane and that any leakage or drips allow the fumes to gather at the floor. Therefore typically the classification is up to 18" above the floor and at the nose of the airplane and around any fuel tanks. Just stay out of those areas and you will be fine. If this job is getting inspected than you need to wire in metal conduit. That can also include the bx type flexible conduit with wires already included. If you need more detail contact me off list. Tim Bryan ex. Electrical contractor and electrical inspector for State of Oregon. > -----Original Message----- > From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list- > server(at)matronics.com] On Behalf Of Dale Ensing > Sent: Monday, December 10, 2007 9:59 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Off Topic: Hanger Lighting > > > Mike, > I see you have received quite a bit of info on hangar lighting. However, > you > should check with your county/city inspector about hangar lighting > requirements before proceeding. > > When I built my hangar next to my home, in a private residential airpark, > the county required me to put in special lighting fixtures that meet a > national code.Did not make me happy but I had no choice. They would not > give > me a Certificate of Occupancy without the approved lighting. This may be > especially true if you live in a residential area, such as an airpark, > but > they told me there is now a national code that covers all airplane > hangars. > A friend tried getting around the requirement by calling the building a > storage building. But, when the inspector came out he saw the hangar door > and the 'storage building' claim went down the drain. > Good luck! > Dale Ensing > > ----- Original Message ----- > From: "Michael Kraus" <n223rv(at)wolflakeairport.net> > To: > Sent: Monday, December 10, 2007 8:01 AM > Subject: RV-List: Off Topic: Hanger Lightingn > > > > > > > > > > > I am building a new hanger on my house and was looking for information > on > > what type of hanger lighting to install. The ceilings will be 16' tall > > and it is 44' x 60'. I would like good work lighting throughout. Also, > > if anyone knows of the light spacing it would help. > > > > Thanks > > -Mike Kraus > > RV-4 Flying > > RV-10 wiring > > > > > > > ________________________________________________________________________________
Date: Dec 10, 2007
Subject: Van's foil comm antenna
Has anyone successfully used Van's copper foil comm antenna that mounts on the windscreen...or anyone who would recommend NOT using it? ________________________________________________________________________________
Date: Dec 10, 2007
Subject: Re: Trio EZ-Pilot or Altitude Hold
Ron - from a safety standpoint, it is as you say, but for convenience, I find that hand flying a GPS course line on cross country to be a piece of cake compared to maintinaing a VFR cruise altitude when fumbling with cockpit chores in my RV. Hence I would sooner give up the a/p function than the convenience of altitude hold. Both work well and I'm very glad I have them. I have not yet upgraded them over the most basic functionality. On Dec 10, 2007 2:13 PM, Ron Lee wrote: > Bill, perhaps I misread your post. If I had to have only one of the two, > I would pick the EZ-Pilot (wing leveler/follow GPS course). Besides > following a course perfectly, it adds the safety of a wing leveler IF I > ever > enter clouds, a 180 degree option if you enter clouds plus other > functions. > > I can maintain altitude semi-well without an altitude hold and not flying > it > but an altitude hold with the EZ-Pilot (two axis control) would be ideal. > > Ron Lee > > ----- Original Message ----- > *From:* Bill Boyd > *To:* rv-list(at)matronics.com > *Sent:* Monday, December 10, 2007 10:48 AM > *Subject:* Re: RV-List: Trio Customer Service > > Absolutely. I'd give up my EZ pilot before I gave up my altitude hold, > for comfortable x/c flying. Trio is first-rate. If/when they interface > with the GRT EFIS systems for full functionality (tru-trak is the favorite > with GRT for now) I'll be totally content (and perhaps finish my panel > upgrade to all-glass.) > > -Stormy > > On Dec 10, 2007 11:52 AM, Ron Lee wrote: > > > I agree that they are very good. My EZ-Pilot allowed me to fly eight > > hours > > in one day recently with minimal fatigue other than a sore derrierre. > > > > Now I need to get the altitude hold to make long cross-countries even > > easier. > > > > Ron Lee > > > > ----- Original Message ----- > > *From:* Paul Besing > > *To:* rv-list(at)matronics.com > > *Sent:* Monday, December 10, 2007 8:41 AM > > *Subject:* RV-List: Trio Customer Service > > > > Hey all..quick note. Have an EZ Pilot in my RV-4. Put it in about a > > year +. It quit holding a course and would engage and disengage the servo. > > I called trio, they said, "another one is on the way". 2 Days later I had a > > new one. They said to ship the other back when I had the chance. I > > installed it, it was programmed already for my aircraft, and it worked > > perfectly. Absolutely wonderful customer service. Don't forget those guys > > when you are building your panel. > > > > Paul Besing > > RV-4 N73DD > > > > > > > > Find them fast with Yahoo! Search. > > > > * > > > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > > href="http://forums.matronics.com">http://forums.matronics.com > > * > > > > * > > > > * > > > > > * > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > * > > ________________________________________________________________________________
From: "Jim Fogarty at Lakes & Leisure Realty" <jfogarty(at)tds.net>
Date: Dec 10, 2007
Mike, http://www.businesslights.com/high-bay-metal-halide-fixtures-c-277_477.html We used this type of light in our hangar and they work good. We have an insulated hangar with a white medal ceiling, I'm not sure what size of light but they were installed for about $300.00 per/light at the time. They are very costly compared with other lights, however, they have all worked good over the past 4 years in our 70'x70' hangar. We are located in Minnesota. I hope some day we get the floor painted. They do come up slow but once they are on they are bright. Jim RV9a builder
December 02, 2007 - December 10, 2007
RV-Archive.digest.vol-td
